AeroElectric-Archive.digest.vol-ny
June 29, 2017 - July 11, 2017
      >  Overvoltage connections just before connection to contactors.  Any
      > issues you can foresee?
         Not sure what this means . . . what hardware are
         you using for regulators . . . do they
         have ov protection built in?
Date: Jun 29, 2017
Subject: Re: Master contactor catch diode failure
Bob, "Always double check before hitting send...a motto I clearly forgot." What I meant to say was I placed the ANL Current Limiters Before the connec tions from the B-Lead to the Starter Lead and Crossover Lead. (50 amp prima ry, 30 amp secondary) I am using the B & C Regulators (LR3C-14) on both circuits. From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> To: aeroelectric-list(at)matronics.com Sent: Thursday, June 29, 2017 3:19 PM Subject: Re: AeroElectric-List: Re: Master contactor catch diode failure At 08:56 AM 6/29/2017, you wrote: I am using your Z-14 dualalternator and dual battery design with the batter ies under the pilot andcopilot seats, battery contactor within 6 inches of battery. =C2- Okay =C2-The crossovercontactor and starter contactor on firewall with 2 inch crossoverconnection to starter contactor. =C2- Okay Alternator B-leadsconnect to crossover input and starter inputlead. =C2- Okay =C2-Overvoltageconnections just before connection to contactors.=C2- An y issues youcan foresee? =C2- Not sure what this means . . . what hardware are =C2- you using for regulators . . . do they =C2- have ov protection built in? =C2- Bob . . . ________________________________________________________________________________
Date: Jun 30, 2017
Subject: KX155 repair; OT
Hi all, Could anyone refer me to a shop to repair a KX 155 - transmission is garbled and weak. You can contact me off-list. Thanks Rumen ________________________________________________________________________________
Date: Jun 30, 2017
Subject: Re: KX155 repair; OT
At 08:27 AM 6/30/2017, you wrote: > >Hi all, > >Could anyone refer me to a shop to repair a KX 155 - transmission is >garbled and weak. >You can contact me off-list. > >Thanks >Rumen It's been 40 years since I had any dealing with these folks http://tinyurl.com/yd4586bg . . . but they were the go-to place for getting your black boxes worked in the Wichita area. Bob . . . ________________________________________________________________________________
Date: Jun 30, 2017
They fixed a KX-155A and KT-76C for me just a few months back, at very decent prices, and one week turnaround. I can highly recommend Bevan-Rebell. Ed On Fri, Jun 30, 2017 at 5:28 PM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 08:27 AM 6/30/2017, you wrote: > > > Hi all, > > Could anyone refer me to a shop to repair a KX 155 - transmission is > garbled and weak. > You can contact me off-list. > > Thanks > Rumen > > > It's been 40 years since I had any dealing with > these folks > > http://tinyurl.com/yd4586bg > > . . . but they were the go-to place for getting > your black boxes worked in the Wichita area. > > > Bob . . . > ________________________________________________________________________________
Subject: Ground wiring and hours meter/RPM
Date: Jul 02, 2017
Hello all, I have another question about my wiring diagram just before to begin on the plane. (4 questions) : 1) I followed the Z19R diagram, but my auxiliary battery is a small 7ah. (Main 18ah) Both battery on the nose of my canard aircraft. So I have to wire it via the main bus like another accessory ? (I don't remember were I read that) Do I have to connect the "-" of the auxiliary battery to the Ground bus of the main battery ? If yes, I am then note sure how to wire grounds of my aux. bat bus. I set only fuel pump 2 and IGN 2 on this bus battery (to handle the worst situation, because on the main bus powered by the main battery I have an essential bus with Pump 1 and IGN1). But in this case I'm not sure how to wire the ground of this aux. bat bus. I think a lot about this ground question because friend of mine loose his engine in flight du to fuel pump ground broke down (the both main an aux. pump ground) in a E-racer. And therefore, I would like a 2 dependent system, just joined for the aux. bat charge that it seems to be the case on the Z19R I set a quick drawing done for this post quickly. (it's not my wiring diagram) 2) When I read the ground Z15.3.1, I see that oil pressure sensor (same for CHT/EGT/oil T) will be grounded on the engine, and for the gauge, I have to wire the ground of the gauge on the engine ? (not on the panel or firewall ground bus,so in this case for a canard I have to run a wire thought the plane just to wire the gauge to the engine ? ). 3)I don't find how to wire a counter of engine hours. Previously it was wired with bat. master switch, which is a bad solution for engine count hours. (I would not like to add a oil pressure switch) 4)My RPM gauge have to be wired from an electronic ignition, I have to set shielded wire ? and breaker on this line ? Thank you and sorry for this kind of question it's not my favorite speciality electricity. [Embarassed] [Embarassed] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470646#470646 Attachments: http://forums.matronics.com//files/capture_dcran_2017_07_02__142809_102.png ________________________________________________________________________________
Subject: Re: Ground wiring and hours meter/RPM
Date: Jul 02, 2017
The 30 amp relay should be disabled during engine cranking to prevent cranking current from overloading the aux circuit. The aux battery could be grounded at the same location as the main battery. All grounds, including engine block, need to be electrically connected together, preferably at the same physical location. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470650#470650 ________________________________________________________________________________
Subject: Big Bitcoin Invest 1 btc and Return 60 btc in 1 day
Date: Jul 02, 2017
Big Bitcoin Invest 1 btc and Return 60 btc in 1 day Large and constant income of financial flows should be followed by increasing the level of security of the finance. That will ensure far more confidence for our investors, secure their deposits to the utmost, and let us put all the efforts upon achieving the maximum business profitability. We give the best and the most reliable profit to the investment world. We can claim that you are investing in the right place. Your asset safety is our main concern, and we guarantee that your investment will be safe with us. We offer 3 investment plans with different profits and investment time. Our system enables our customers to decide how much to invest by choosing the profits that they plan to receive. The amount of bitcoins they earn will depend on the amount of bitcoins that they invest. Invest 0.1 btc and return 5 btc in 48 hours Invest 1 btc and return 60 btc in 24 hours Invest 5 btc and return 400 btc in 6 hours Invest Now http://www.bigbitcoin.info/ Guaranteed Of Payment http://www.payinghyiponline.com/bigbitcoin.html Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470652#470652 ________________________________________________________________________________
Subject: Re: Lightweight rechargeable battery backup unit
Date: Jul 04, 2017
Just as a follow up to the various posts on this and similar threads, here is the schematic of the final wiring diagram I settled on. The switch used incorporates a warning light when the Battery Backup is activated. There are probably cheaper ones than that quoted (but I had a few spares from my old panel, so no cost to me). The Battery Holder is cheap, and fitted into a blank on my panel I had made for a potential Dynon AP at a later date. Obviously, it does not provide a rechargeable option, but I took on board Bob's calculations that if not used in anger, the batteries should be good for 12 months, so test as part of pre-flight checklist, and replace batteries at Annual. It is offered here with absolutely no warranty whatsoever, i.e. use at your own risk. I have yet to have the unit approved by the UK LAA. Thanks to all those who contributed to the thread. -------- Bob Dawson XS TG || 912 ULS || G-NHRJ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470684#470684 Attachments: http://forums.matronics.com//files/bbu_559.pdf ________________________________________________________________________________
Date: Jul 05, 2017
Subject: Sealing ELT Connections
Folks, I bought an Artex 1000 ELT and just soldered the wires to the supplied D-Sub connector. Artex also supplied two sealant strips. You can see them in the bottom center of this photo that I took: The instructions read: 4) Install two sealant strips (850-0814) into the receptacle of the ELT. > Peel the adhesive backing from the strips and stack one on top of the > other. Push the pins through the strips. If I understand that correctly, ACR wants me to mush the sealant strips onto the male D-Sub connector on the ELT. Do you agree? Then, after system operation is verified, ACR's instructions call for disassembling the D-Sub connector and injecting sealant (ACR recommends Dow Corning=C2=AE 4 Electrical Insulating Compound) "into the back side of the plug, so that sealant surrounds all exposed electrical connections and the back of the plug." The instructions also state, "Coat the mating pins/receptacles lightly with sealant." Is this the dielectric grease that I have seen discussed several times on this list? Why would I use this for a connector that will be inside the airplane, never exposed to weather? Thanks, -- Art Z. -- https://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
Subject: Re: Sealing ELT Connections
Date: Jul 05, 2017
Who knows what conditions will exist after the ELT is called upon to transmit an emergency signal? Best to follow manufacturer's directions. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470711#470711 ________________________________________________________________________________
Date: Jul 05, 2017
Subject: Today's trivia dump . . .
Subject: Measuring current in fused branch circuits http://tinyurl.com/ycr7quwp http://tinyurl.com/y7re7r3a http://tinyurl.com/y8zwaget http://tinyurl.com/yaz9vt5p Bob . . . ________________________________________________________________________________
Date: Jul 05, 2017
Subject: Re: Today's trivia dump . . .
Got a heads-up from a reader telling me that Harbor Feight offers on of these products at a very attractive price http://tinyurl.com/ycocd4o6 Bob . . . ________________________________________________________________________________
Subject: Re: IVO Prop current limiter
Date: Jul 06, 2017
Attached is the Arduino code for, and a diagram of the IVOProp controller. For the diagram, I used part of one of Bob's drawings, and added the Arduino components. These are the components I used: - Funduino ATMEGA328P Development Board - ACS712 Current Sensor Module 20A - SLA-12VDC-SL-C 12V 30A relay module I had never worked with Arduino before, so I just bought what I thought made sense. The Funduino board might be over-kill for this application; I'm sure there are plenty of alternatives available. The Funduino board is apparently an Arduino-compatible clone. All of the components were purchased on eBay. For expedience, I put the current sensor between the prop adjuster switch and ground. It would probably be better to have the sensor between the switch and the prop, on one of the power lines. That would allow the code to see positive and negative readings, depending on which direction the pitch is changing. You could then prevent further movement of the prop in the same direction after a limit has been reached. Right now, the code cannot determine in which direction the blades are moving. The txt file is the Arduino code. Replace .txt with .ino to open it in the Arduino code editor. -------- Doug Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470727#470727 Attachments: http://forums.matronics.com//files/ivoprop_control_186.txt http://forums.matronics.com//files/arduino_prop_control_998.jpg ________________________________________________________________________________
Date: Jul 06, 2017
> This might be another opportunity for an open source > project. Once you've finely tuned the code, we can > poke it into chips for mounting on a dedicated > ecb . . . have you considered solid-state > switching as opposed to relay? Bob, I'm open to any of your great ideas. I had not considered a solid-state switch instead of a relay, but that does sound like a good way to go. It would be nice to have this in a small package. Right now, I have the Arduino (clone) board in an enclosure, and the other components in the separate enclosure I had been using for your original circuit. Thanks, -------- Doug Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470728#470728 ________________________________________________________________________________
Date: Jul 06, 2017
For a smaller package, the 5 volt arduino clone pro mini boards are under $2. delivered and can replace the funduino. In my mind that makes them a no brainer to incorporate when building multiple copies of something, instead of starting from scratch. http://www.ebay.ca/itm/Pro-Mini-Enhancement-ATMEGA328P-5V-16MHz-Compatible-to-Arduino-PRO-mini-/191679508570?hash=item2ca0fd305a:g:AxIAAOSwT6pV5YIu Boards like the funduino (uno clones) are much larger but include the 5 volt power supply regulator and USB interface and are usually more convenient for one off projects or a first project. Ken On 06/07/2017 12:16 PM, kfav8r wrote: > > >> This might be another opportunity for an open source >> project. Once you've finely tuned the code, we can >> poke it into chips for mounting on a dedicated >> ecb . . . have you considered solid-state >> switching as opposed to relay? > > Bob, > > I'm open to any of your great ideas. > I had not considered a solid-state switch instead of a relay, > but that does sound like a good way to go. > > It would be nice to have this in a small package. > Right now, I have the Arduino (clone) board in an enclosure, > and the other components in the separate enclosure I had > been using for your original circuit. > > Thanks, > > -------- > Doug > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=470728#470728 > > ________________________________________________________________________________
Date: Jul 07, 2017
At 11:16 AM 7/6/2017, you wrote: > > > > This might be another opportunity for an open source > > project. Once you've finely tuned the code, we can > > poke it into chips for mounting on a dedicated > > ecb . . . have you considered solid-state > > switching as opposed to relay? > > >Bob, > >I'm open to any of your great ideas. >I had not considered a solid-state switch instead of a relay, >but that does sound like a good way to go. > >It would be nice to have this in a small package. >Right now, I have the Arduino (clone) board in an enclosure, >and the other components in the separate enclosure I had >been using for your original circuit. Yup . . . make it work on the bench then 'distill' it . . . Do I recall correctly that once you have 'golden code' in the silicon, the chip can be lifted out and dropped into an embedded controller with minimized peripherals? If I were stuffing this functionality into an 8-pin PIC chip, I would explore something like this . . . Emacs! Set up Q1/R2/Q3 as a classic, ultra-fast current limiter. Select R2 to target stall motor current limit. Current limit is approximately I(limit) = Vbe(Q3)/R1 Vbe(Q3) is about 0.6 volts. Hence, setting R1 at 0.1 ohms would get you a 6A current limit. I think we were shooting for 9A so R1 = 0.066 ohms. I would parallel a number of resistors on an ECB to achieve 66 milliohms. Q1 doubles as a motor controller turned OFF by clamping gate to ground with Q4. D8/D9/R10/C11/Z12 conditions the COMMAND SENSE signal to a discrete input. R5/C6 conditions a CURRENT LIMIT SENSE input to an analog input. Q4 is a software driven clamp to remove drive from Q1 during a LIMIT CURRENT shut down. The +12 source in schematic above can be BUS, a precision 5v source ie easily acquired for small uC chips with a circuit like this: Emacs! Smartware would read something like this: Power-up routine SETS a LIMIT LATCH which drives gate of Q4 HI. A rising edge on COMMAND SENSE clears the LIMIT LATCH which removes drive from gate of Q4. LIMIT SENSE is monitored for input greater than 0.5 volts for greater than 0.5 second. Any excursion below 0.5 volts resets the limit timer. If limit times out, then the LIMIT LATCH is SET, gate of Q4 goes HI and motor power is removed. This condition is sustained until next rising edge on COMMAND SENSE. It looks like the tiny Arduino products could piggy-back onto a board that hosts the peripheral components . . . but as long as you're making a board, you might explore the option of programming a chip in an Arduino development system for dropping into your target ECB. To the extend that any of this is useful, feel free to adopt or adapt as you see fit. Bob . . . ________________________________________________________________________________
Date: Jul 08, 2017
The software that Bob describes would be pretty simple to write for the PIC12F683 chip, the same chip we used for the wig-wag open source project. I'll volunteer to contribute the software if someone wants to pursue Bob's hardware design using a PIC chip instead of the Arduino as an open source project. Paul Fisher On 7/7/2017 3:03 PM, Robert L. Nuckolls, III wrote: > At 11:16 AM 7/6/2017, you wrote: >> >> >> > This might be another opportunity for an open source >> > project. Once you've finely tuned the code, we can >> > poke it into chips for mounting on a dedicated >> > ecb . . . have you considered solid-state >> > switching as opposed to relay? >> >> >> Bob, >> >> I'm open to any of your great ideas. >> I had not considered a solid-state switch instead of a relay, >> but that does sound like a good way to go. >> >> It would be nice to have this in a small package. >> Right now, I have the Arduino (clone) board in an enclosure, >> and the other components in the separate enclosure I had >> been using for your original circuit. > > Yup . . . make it work on the bench then > 'distill' it . . . > > Do I recall correctly that once you have > 'golden code' in the silicon, the chip > can be lifted out and dropped into an > embedded controller with minimized > peripherals? > > If I were stuffing this functionality into an > 8-pin PIC chip, I would explore something > like this . . . > > Emacs! > > Set up Q1/R2/Q3 as a classic, ultra-fast current > limiter. Select R2 to target stall motor current > limit. Current limit is approximately > > I(limit) = Vbe(Q3)/R1 > > Vbe(Q3) is about 0.6 volts. Hence, setting > R1 at 0.1 ohms would get you a 6A current > limit. I think we were shooting for 9A so > R1 = 0.066 ohms. I would parallel a number > of resistors on an ECB to achieve 66 milliohms. > > Q1 doubles as a motor controller turned OFF > by clamping gate to ground with Q4. > > D8/D9/R10/C11/Z12 conditions the COMMAND SENSE > signal to a discrete input. > > R5/C6 conditions a CURRENT LIMIT SENSE input > to an analog input. > > Q4 is a software driven clamp to remove drive > from Q1 during a LIMIT CURRENT shut down. > > The +12 source in schematic above can be > BUS, a precision 5v source ie easily acquired for > small uC chips with a circuit like this: > > Emacs! > > > Smartware would read something like this: > > Power-up routine SETS a LIMIT LATCH which > drives gate of Q4 HI. > > A rising edge on COMMAND SENSE clears the > LIMIT LATCH which removes drive from gate of Q4. > > LIMIT SENSE is monitored for input greater > than 0.5 volts for greater than 0.5 second. > Any excursion below 0.5 volts resets the > limit timer. > > If limit times out, then the LIMIT LATCH > is SET, gate of Q4 goes HI and motor power > is removed. > > This condition is sustained until next > rising edge on COMMAND SENSE. > > It looks like the tiny Arduino products > could piggy-back onto a board that hosts > the peripheral components . . . but as > long as you're making a board, you might > explore the option of programming a chip > in an Arduino development system for > dropping into your target ECB. > > To the extend that any of this is useful, feel > free to adopt or adapt as you see fit. > > > Bob . . . > ________________________________________________________________________________
Date: Jul 08, 2017
If you're going to use a pic you can dispense can > On Jul 8, 2017, at 9:59 AM, Paul A. T. 743 Fisher wr ote: > > The software that Bob describes would be pretty simple to write for the PI C12F683 chip, the same chip we used for the wig-wag open source project. I' ll volunteer to contribute the software if someone wants to pursue Bob's har dware design using a PIC chip instead of the Arduino as an open source proje ct. > > Paul Fisher > >> On 7/7/2017 3:03 PM, Robert L. Nuckolls, III wrote: >> At 11:16 AM 7/6/2017, you wrote: >>> >>> >>> > This might be another opportunity for an open source >>> > project. Once you've finely tuned the code, we can >>> > poke it into chips for mounting on a dedicated >>> > ecb . . . have you considered solid-state >>> > switching as opposed to relay? >>> >>> >>> Bob, >>> >>> I'm open to any of your great ideas. >>> I had not considered a solid-state switch instead of a relay, >>> but that does sound like a good way to go. >>> >>> It would be nice to have this in a small package. >>> Right now, I have the Arduino (clone) board in an enclosure, >>> and the other components in the separate enclosure I had >>> been using for your original circuit. >> >> Yup . . . make it work on the bench then >> 'distill' it . . . >> >> Do I recall correctly that once you have >> 'golden code' in the silicon, the chip >> can be lifted out and dropped into an >> embedded controller with minimized >> peripherals? >> >> If I were stuffing this functionality into an >> 8-pin PIC chip, I would explore something >> like this . . . >> >> <5a5abb6.jpg> >> >> Set up Q1/R2/Q3 as a classic, ultra-fast current >> limiter. Select R2 to target stall motor current >> limit. Current limit is approximately >> >> I(limit) = Vbe(Q3)/R1 >> >> Vbe(Q3) is about 0.6 volts. Hence, setting >> R1 at 0.1 ohms would get you a 6A current >> limit. I think we were shooting for 9A so >> R1 = 0.066 ohms. I would parallel a number >> of resistors on an ECB to achieve 66 milliohms. >> >> Q1 doubles as a motor controller turned OFF >> by clamping gate to ground with Q4. >> >> D8/D9/R10/C11/Z12 conditions the COMMAND SENSE >> signal to a discrete input. >> >> R5/C6 conditions a CURRENT LIMIT SENSE input >> to an analog input. >> >> Q4 is a software driven clamp to remove drive >> from Q1 during a LIMIT CURRENT shut down. >> >> The +12 source in schematic above can be >> BUS, a precision 5v source ie easily acquired for >> small uC chips with a circuit like this: >> >> <5a5ac43.jpg> >> >> >> Smartware would read something like this: >> >> Power-up routine SETS a LIMIT LATCH which >> drives gate of Q4 HI. >> >> A rising edge on COMMAND SENSE clears the >> LIMIT LATCH which removes drive from gate of Q4. >> >> LIMIT SENSE is monitored for input greater >> than 0.5 volts for greater than 0.5 second. >> Any excursion below 0.5 volts resets the >> limit timer. >> >> If limit times out, then the LIMIT LATCH >> is SET, gate of Q4 goes HI and motor power >> is removed. >> >> This condition is sustained until next >> rising edge on COMMAND SENSE. >> >> It looks like the tiny Arduino products >> could piggy-back onto a board that hosts >> the peripheral components . . . but as >> long as you're making a board, you might >> explore the option of programming a chip >> in an Arduino development system for >> dropping into your target ECB. >> >> To the extend that any of this is useful, feel >> free to adopt or adapt as you see fit. >> >> >> >> >> Bob . . . >> > ________________________________________________________________________________
Date: Jul 08, 2017
Sorry - defective iPhones and all that. Possible simplifications to consider: - If you=99re using a PIC maybe you could dispense with the current limiter. If you sense the current the PIC can send the FET high impedance within a few microseconds. - dispense with the command sense input, and power the PIC with a simple potential divider from the command sense network instead. To reset the timer, remove the power shutting down the PIC and rebooting it when power is restored. > On Jul 8, 2017, at 11:12 AM, Alec Myers wrote: > > > If you're going to use a pic you can dispense can > On Jul 8, 2017, at 9:59 AM, Paul A. T. 743 Fisher > wrote: > >> The software that Bob describes would be pretty simple to write for the PIC12F683 chip, the same chip we used for the wig-wag open source project. I'll volunteer to contribute the software if someone wants to pursue Bob's hardware design using a PIC chip instead of the Arduino as an open source project. >> >> Paul Fisher >> >> On 7/7/2017 3:03 PM, Robert L. Nuckolls, III wrote: >>> At 11:16 AM 7/6/2017, you wrote: >>>> >>>> >>>> > This might be another opportunity for an open source >>>> > project. Once you've finely tuned the code, we can >>>> > poke it into chips for mounting on a dedicated >>>> > ecb . . . have you considered solid-state >>>> > switching as opposed to relay? >>>> >>>> >>>> Bob, >>>> >>>> I'm open to any of your great ideas. >>>> I had not considered a solid-state switch instead of a relay, >>>> but that does sound like a good way to go. >>>> >>>> It would be nice to have this in a small package. >>>> Right now, I have the Arduino (clone) board in an enclosure, >>>> and the other components in the separate enclosure I had >>>> been using for your original circuit. >>> >>> Yup . . . make it work on the bench then >>> 'distill' it . . . >>> >>> Do I recall correctly that once you have >>> 'golden code' in the silicon, the chip >>> can be lifted out and dropped into an >>> embedded controller with minimized >>> peripherals? >>> >>> If I were stuffing this functionality into an >>> 8-pin PIC chip, I would explore something >>> like this . . . >>> >>> <5a5abb6.jpg> >>> >>> Set up Q1/R2/Q3 as a classic, ultra-fast current >>> limiter. Select R2 to target stall motor current >>> limit. Current limit is approximately >>> >>> I(limit) = Vbe(Q3)/R1 >>> >>> Vbe(Q3) is about 0.6 volts. Hence, setting >>> R1 at 0.1 ohms would get you a 6A current >>> limit. I think we were shooting for 9A so >>> R1 = 0.066 ohms. I would parallel a number >>> of resistors on an ECB to achieve 66 milliohms. >>> >>> Q1 doubles as a motor controller turned OFF >>> by clamping gate to ground with Q4. >>> >>> D8/D9/R10/C11/Z12 conditions the COMMAND SENSE >>> signal to a discrete input. >>> >>> R5/C6 conditions a CURRENT LIMIT SENSE input >>> to an analog input. >>> >>> Q4 is a software driven clamp to remove drive >>> from Q1 during a LIMIT CURRENT shut down. >>> >>> The +12 source in schematic above can be >>> BUS, a precision 5v source ie easily acquired for >>> small uC chips with a circuit like this: >>> >>> <5a5ac43.jpg> >>> >>> >>> Smartware would read something like this: >>> >>> Power-up routine SETS a LIMIT LATCH which >>> drives gate of Q4 HI. >>> >>> A rising edge on COMMAND SENSE clears the >>> LIMIT LATCH which removes drive from gate of Q4. >>> >>> LIMIT SENSE is monitored for input greater >>> than 0.5 volts for greater than 0.5 second. >>> Any excursion below 0.5 volts resets the >>> limit timer. >>> >>> If limit times out, then the LIMIT LATCH >>> is SET, gate of Q4 goes HI and motor power >>> is removed. >>> >>> This condition is sustained until next >>> rising edge on COMMAND SENSE. >>> >>> It looks like the tiny Arduino products >>> could piggy-back onto a board that hosts >>> the peripheral components . . . but as >>> long as you're making a board, you might >>> explore the option of programming a chip >>> in an Arduino development system for >>> dropping into your target ECB. >>> >>> To the extend that any of this is useful, feel >>> free to adopt or adapt as you see fit. >>> >>> >>> >>> >>> Bob . . . >>> >> ________________________________________________________________________________
Date: Jul 09, 2017
I've converted Bob's sketches to a CAD file. =C2-Anyone with interest in the project please look over my work (see attached PDF) and post any change s/critiques for the group to consider. =C2-When we're all happy, I'll tur n it into a printed circuit board, stuff it with parts and a DIP-8 socket, and send it to Paul so he can add a programmed PIC to test with his code. A couple of notes:- I've assumed that the DPDT motor-control relay will be mounted elsewhere (off the PCB).- I've drawn a notional wiring diagram incl uding a switch and a second relay. =C2-If this isn't how the IVO prop wor ks, let me know what to change.- I guessed at the correct PIC GPIO pins to use. =C2-Paul, let me know if you need something different. Things to consider:- For BOM simplicity, I used the same 2k resistors for R 1-R8, and 0.1uF for C2 and C3. =C2-Any problems with this?- Any other com ponent substitutions or value changes? - What's the desired physical envelope (PCB with mounting holes / PCB for a small potting box / something else...)?- What type of connector(s) should be used (a DB-9 is shown)?- Are the fuse values on the wiring diagram appro priate?- What AWG should be specified for each wire run? Doug (kfav8r), in order to give you credit on the schematic, would you like to send me your last name? Cheers, Eric JVBERi0xLjQKJcfsj6IKNSAwIG9iago8PC9MZW5ndGggNiAwIFIvRmlsdGVyIC9GbGF0ZURlY29k ZT4+CnN0cmVhbQp4nOy9y65uSY8cNq+nqLEAyXm/zA0Y8Mw6j9Cw1DD+A0PSQK/vxYggmbtaAgRP ugaNgyrE/hbJjGTe7//lz/Ifavuz2D8H//T7j//tP+4///N/+6P+af/+63/+w36etZQ/1/r+91// 7z/+07/74/z53z+B/1NC//H/+JdCv/5YkPl/vv/s4ydT+zh/1lPqn78/vC/xPz7R2tf4s+6z8MXw qVtfxvr++hR/O+6m80lVwwV43vx9Whh9JR4tZcambv/wpO4ymUmZXR+8U+aU1D0tbQIrLMiIwz7J bc8Pt6PY4MuaiA00Piph6fs9LK2dlvB7+OLIF8bvUHua9ufQ8Ms+xCsxeEgGIZwn5HMS35oyd4fu LSVs3tIiLMfGwWXATbrgLJvOn7Fxjd8/2Hk8b+sRz1tPhlFnhl17chIG15qedF2Lm9lMvFOmt9Tt M232nWEJg4NkwE265Lwf3N949hnxJDvE0/5S3ganJVv2+16Qul+eGtVKxrnzzwFv22/90Fu33j/7 Hd93Q6OyRN3S/xzTPGgeHsjTliJjHKDP0piO+vGvfZh100BOhpV2gT7biN39SqZQa/61Ldf4/pYV 4w3LQAgNX8EAGmAFK5O+ApuzPa4r7ABZXBvwb6J9Quure+zXT9ZQ2LpHtmZrKbuOyy7nN88Qv3kY o/PnvIzR+BCYfv51tPxrHa7xMZKVj4F+K9flynTdLwWJzvUwzPfUAD9YcaYeb7GOUBiXVeCNVoHo 11Xc16tcxW/VEWj719Zcoy2g72vz/LFUZ11U6h1+3Fa9+/fpLBdqRnwdTfln9av848i+VvlEcp+f 1ljy4ppLnmUYls/Wqs4L9SS4Cl2XszjNiN2I2I2IXWdJOV/hmxsOO99PgP/gr+siWvbrQrnjryqC lG5Wgs8oBpF840v6jdrF2oYPwg1fpv4gytbHPuAKgV1CbfcwBm5tBuwtBPoKNcSExuBMBoGYMmBC 0KEASFIN1GkMEWIQHreM6EJlAxbrdcBMz3nJwx/3hmPuijBvMmEeBz9mcrA+GRcKIIY3430jISwI wVOWCxyUdKgdVP4wdtL3py4PWNDoSMBISm2UMGYRUhAeN0R0muWG2gRwQHGaDdaoCATdhTPMBmvc MRM+AiXUEB6NAbL4IaIqfwqveJrQ3K8/2rjmuq82+W3YnIvWt41juRitb7PK9MM98dkpc/j7ReVC XbO5kLptlupFoFmlmnimzJePXdeqWLc5v8bPwyK+PWXIDbriDJsbbRvDejF1fxkjlDiri4TR+nwY xWQEa+byLzaW+zpjfMeDH5lzQxcekk3imrEhDhaoDfSlb6UIdOZFisDunOHhjXRTqs2SXMfJWDue KQMvURfek02GPG/itVJm3dTdPW3ukWEpNcFhr+RGGXLePX20Hr+slXjeN/Zovb8QOnGwODfZ3Zas 7wnM0QBlWAapy6JJmwf9G4Z11NfRX2NHirCvrt9bhnZaezXmSY358NiZn63IBY+dqXOU59HUnxae FIYnj5epFrrwpGySwy6Jp3rGZ1jJmxgNWeXwYfSfrc6YC3nkG5pYaUbr+Q0QWuJdU2av1N2bNgOj 9ZQMRx7URTrL5i4ZljA4SAbcpAvOsun8FRtp/P7Bzr58WQ01xm/ncR6uHJ/od/Eb/rt7aZf00i6P l+7jpft46T5euukl17WQd0kv7ZpeYlNOXTbgtLlbesmxcXAZcKvpJbfp/NNLpvH7Bzt8WawBIp7z 0R+PXY5KKcNRKa32nvw4QrUhZeDdUgbx7E/8ZZP4kRk3dTlitiErOglh33FJGXCQ7pxpk/iREQfo iltyDq+cJ/XPSE/s++CZXnny8OYIm6EpDyMELwstZRBj6cITskn8yJyWumelV85O+45LyoCDdOEJ 2SSeKSMO0F37L5zdK6fe8ArnUeiJU1vikiX4lBFeOeXJyyofCMHLSksZi7HrmifcJvBTbtj3km69 4ZXTMi8GLikzd+qaJ9wmcHlkSuYz55acwyuzp1e8PsXAbz04S9DpO73SR4bWW7Lumd4ugxhLF554 SpB1OkPmKUFn9vTKU4LOU4JcBhyeEuQ2idvDM/OZc0vOv5zRVr1isb9Zr8SckzVK83LOjrhmnr1K tYnBrfhheDvDd4EfGfOv61pobhP4qYmvzw8qZLUU263ii9m6PfndFjXzPcrBNoRXe0JcU2YrPqa7 FQezuWvGR9jykcsgDvvhfZ74nEdGHKArbs45OAhbve8ylkdcFzH29hA4S9fdI/IRualtXKVM99cq tTu7VVrkyFV6yd81Tq5W5fSBOaUPV8PQ2Ot8GD25al3AD8/EnGekDOss6tJ3tMn6a3/0+1iU/8wF /oIMma/v7rrWMXSb5xsYeFjE6htARtygK86weYf8YhqzI7eA9VTbgt9rxmyWDI34l38Z8Au/qOwB q29lPOaqwWNi7oo8JvrNjPP0+JfE5iOX2TV1zaduExwYVvBRqn0aqx/G7RjO1FlMZ2KWQsrUE6Fx jogsAkNmBVOX/xqrzw4ZHZPvwjvDtVgutuPW5Qc394owvCV5eFE8iVVbQKY+unU86bFYgxGrXoT2 i7fqvP0VInz57Xj1x9YuO9LWcHjsZC6J/id8Zn0W9zenWWSpj8Rth7852yPdmqkeGDJZSlze/M1Z Gvp7u493hmv+5qwP/a3+FHzmfSvzpeQZy545WDwp0x7del4f7RX+3jP98gNr4ow+3mx5iZfWdSxT odx/X9ZsUQcQa26bUpNrBPgyS9EX/NWRkpRirPg7PcXfMUrU7xox6st87M7yftk9v3idyi+rZohn Pl+sBLiOSgOx5mv01039xV4ef/d8uIaVMvkF+Ecou44IZXs54BfMBAk3+X+1YT5nbJqlK2sRK05f upzwkvrqxFzpogxrOOqOQjwiD1lx7Zz/qFakA4+eMmOn7ixpE3EY6QPnABlxg644w+Z6U8PmKsIb +4c3buas6Aeu3lMHOL7cGrnRikG0SMCRG01KuRFfIjfyL+VGSKlM4nflRvzO3MjfIzfiy3zsRm7E F+ZGfonceGvmRuDIJ9fy1pz80j0HUmrJ38RME8h0cVxZl5fyYMiw3Sgz6/iysl6vJj+EI+dXmzjr nKGvNgUObvBBe/BMeYuneAqXlOmPbn/9t056f6kNhfaLPSV3Ofzy2/F5Pb7bCI8bdo9xtlK/R010 UX5u+HuzdaYGRxrEyvf3KRvQdV+WB/coS/C31/FlZb1eUU5a+Fvhwt8qP/A3Z+jos8Az5RGbmflS PCnTH90+Xx+xz028H+0X3/742764v7fWsNpZ98/ZsabdzpfBgP/hv3OmjL+jFtDvSzN/+DKw9tds kDMH5w3PlyU/jNlL9MgH5xbRC++Y1G8YtTi2UZLLrJG6NiJzmxby4Fyk8E6ZVlIXOUY224ywuGpK DoFryoCzdBEX2WQc94PLG/vJ2IPR/PGlp1fHau+XM9Jjp2To+2El34Mt54EZC2HETjKI9X68cR4v nZH41pS5I3XvSZtP6swn1QLXlAFn6SIusok4KiyPL2P/OWjOijUT4kZtG6lyLKDQumLfDTP9bdnG cX9kLGTXtdDcJjDmXBh74mDRRqQbrXrqzNPyy3n07wzvrZL5bZVMEa790nurZH4LXFPGvOe6faRN cLhZ8sjBea96wnvLPWaW+snQRgnvcR2W3nPcHxmE3NNj6/Eke/2M/VIv1EPOXE+r7r2F3qa+aF+B vqz0uNav+Pt99bWyQ+yevX/Bmn0gF/viHtnatyT9O9LWzvqLOPRRLwqf+eifMoPxKT++jIz/GZlu nC/T7/XNVWcnF85/SerF+y0n9sV5+XxQrzfq6/51ory+1u+oD/Q76mj9rvqaX1hff3h63frhqK97 tZkM1sUf3l5H93pW4ltT5o7UvSdt3qivHe+UaSV1UefKZpsRFutocgjcUmad1EVcZHP1DGs99bX+ moz9feprfenpVa+v9Rfqa4VySoa+H1byPdjunrEQvjVl7khdeOM8Xjoj8a0pc0fq3pM2n9SZT6oF bimzTuoiLrK5eoa1nvr6sxr1tXCj9r5e5yq0rthHff3hkng9Mhay666eNlfU14y919ce8oh08/pa Oqfll/Po3xneY91K762SKcK6mN5jHc34BG4ps07qrpk2V8+w1lNfkzfra2H32PU6V6GNEt5jbUrv OV6PDELu6bH1eJJ1NGPv9bWHnLne62vpoL7WF9XX+rLS46yv9ft99VlfC7tn719wmw8X1tfCqq/p aZvu+C1Pc/sJ48sVa4Vx7oNbyjjD42s2srkzl7LeZ2o7xl4EL6Mjde9Jm4jDk7OcA2TEDbriDJt3 P17imhCZcgMMmR7ld67NlGB6ygmmjm9NmTtS9560ea+v3wi3lTLtpm7PMsDVCYXlZXc/uKUMOPcs A24TcVRYHt9sr2zF3fPIedol7hNAvtjcWfPb8faa+WCFf0WOuV6v2da+p8ReecnK0HVPlsTrkTHm rmuc3Cb4nWy9iIPFPVEebrYptm4xZqTuHZlXuWfVcZbf+7RgXIehlwPHWo3iJnnEWbXlMXnVA2dk uJaKdyhFL7l5qgc+KY/YiCdxSZn26La3D3H3jRS9Mz32A+/7eO/OJw2Vutz6vtq5X5fBdqiPhdk3 jOXHtLkNrrKOOQy3xBxHU4Yzn2PZzAPX5m0Rw+dCxr6JMVcuGcyPSxezFrLJGYxHhivS1OXOi4G5 eI60ad9xTxlwkC7m+mUTeD4y4gBd5x+cf3mMb0uvcA2bMea6Oy1xDXtgBUH4jJRBbKSLWHKNRniF jHZjQJe7NGlTOzMQluNVU2au1CXn9WDNw4bG7x/sPJ7WIvwWJ+2Q4O9jun6P2Q/a4urdmDavcR8m T+jcSEh8xNxktKYNXa3PwyZ3Jn54PviRsbRivSym3GEPfHx/OUPrK9JN5xMYQjvhS9ac9LFj84zL WJq4LkLgqg7xyJx6xkzdcdPmUyocg8PIUuS64Cybzj/T7XDt5mEX8dyZP3V6ghqrZ9irJqeVecxl EIeV+fPs9uCZMqek7sn8yfpaYZ3Mny4DbueJ237ivN/8eU7mz+Nz3sPWXM7N/HnUxis/6IvlE53K gMYtM3HNOuDWEXlJK/Cweut6rN660mqraYnzosI3rfasTXROglZ99pB/cU4bMb+ql/D7iLDtWANG oMLL5+q/juU37MJcvXV1gW0u9StWo3H9kNh3oFFqS2MYBkfbcj8aa8t5zSrTfuHYg3CtIbN49KET H9oMfGrKMO2pe0vaZH3HsITBgTLkRl1yps3gr9hI4/cPdh7PXjgva5x6TVu9l0e/cxXv6+fYIY2S UmdGjHquPH1/Dc6JQ4ojWkldX2synw/uFCFWH6zWa4c1yBhYu3falzGHdhYBH/TZP7wNb+Kb8l+G Haoxm/nZ8ddVCRk7WMK5kg8fwyXwvjNk9tXvww6SkMOXvcdWn0tMeyNrC4Hro9Yz+fDDlKWi2ZEU x2bJZcCIumTEXUPCyUi1HnU5B0+b3KHEsIjJgTLkRl1xng9uHhtp/P7BLuI5N7+YFPsS/N3bRvx1 Rw1v3J5MdAYKDNl/I3PHFp7LWEyli9DuqA8eKTNu6rKHQptcMWJYcyYHypAbdcV5PLg+3rhcl37Y /VJ+uEveMB7r4bp28ls38s/1VW2Gch8vncdL5/HSebx0Hi+dx0vnCfk+XrqPl254aZYSXpqlhJcc o0ctGXK7j5fu46X7eAkav3+wUzxnacvj+eGaYdSdYbMGIidhcK3hSde1uMFm4psyXk5Ml+uNtKky g7C8DJyQIbcsD24z+D/x5M6Zh53lhq/ymIX5hFKey6bhkWHMlXZXefBKmV1Slz0L2tyqS9qDU6bZ HvOyTvplPv7a0/PtsaNv3etYYGib95STDNfqOd0Op1WesiTuN3xZVRKNR/X6x6yOqAMTpwziWbPE uU1irw+P42DB05H8Mvzk79UeBesB9OFrmvFl8LQwsMZz+ksjFaynsmYfWE9l2zaKrUxyR8/Auilb WZu+TbxSpt3Uxa4B2QQnjWCIT8gc9b9MV60RbKpVQ1hqscDBsXFzmdJTt5SwqTieB3vP0XY+nIZ2 lngU/2L66nPVmT3bih7vSU7qCbentwwZ5m/qarwIm8yLw9Z0A/eUAW/qgqtsCj8yK9MpuIlzcBC2 lWWXga9XpofbJC4pw7LK9Jjen4a3uYd8lKf/bnuYjuccY8G+AllztAes886QuRqDmq73uM3m9dQ8 iesjYyv03lsHa89p1jMu90nZ+6TsHW+OvziaJ7wzZ9/1Ysanml338Ex5S/Gr8UgbD74pY57k3In4 rYerZhQgI2/bMWW1y0i1O9WyTDsI3Lh3zjY8Aj9fMFssPOf7Rf1WOxTsvfiv8ohefM9e/BzoxbMH PNuDd8qs7N3bZsuwCU7c3Ut8esqoh76yd0+b6tEjLOYSchDuT68fnKWLuMgm4qiwPL6M/bC+Nmct iNvwL9ZvZz05h/Xnp+Jpx7jpfXDqrK+FHxn2wKjb5TuMGCZxSWy8XQYHvKXbS9okfmRmppNzc87J U/imjPnadS0N3CbxSJl+Iz26zuLR2507Tmy5BhgsuuGW7Lh/mqw5niM+M2XOSV1PNbN5a3rI8SOD dDqZi7rnNOj2J2XHk7IjUtZ4DO4qI5aXLIwxMpcPeWngWP+K1HR5S/HB8jnnTLxqypgnxxzBb4z7 4PT2cG+bTeUES7Xh43tr8sdhG2wzycDPl8NxoGHWmf7lqj85rKfJ/afWlRiX+7Kr+eay3/i5wzD7 dRaLwDtlvooqdHdPm8bpsp9JzBkLymhUA131XWCT+Zxh8cwSOQiPHMmQs3QRF9lEHBWWx5exnxjL IAcQ+15G2sWZympdLGDYxbjhCYM5jnbVl7cDxaVUl/nwcN0Pk5Pt1iicR6zjJrYTCi4zMQp4fMeS gVWC4i2UMZ12suC3W/UURE97JIu2kp1648DyEmTce+jh12Tq3r6JwVQy8+n5gx13UhOPJ3+iX/7b Q1tPCFP5a2SffpUHn5SxlR7XRQhrPfimzJ6pyxqGNjnuY1jC4CAZcJMuOT/eWp53XOP3D3bKVbNo LGq4+n5TWKhYNxVWj918WfuLbzCs7u+V8nbI3nv+6xkF2LqXy2yMCNJLta8H15RpylUYKYzwWNWZ 3d6unSBBugmjhurd+om8VaT3cvN3692xRhNGf1Ay6Ll8urHz/MPbT5/03uqDV8q0R7fXtAmssNrD oZ3kZr2qoflNfcHZV2lg5CFL6AH47zMt6ezBFwfjfeGLbr1P7bCAX2YZYWmqhtWXinVCfmmPxuiP 1OL+HH65PXzMu0roP//d/DrvCaz9CZBZ5YSPF9eK4eNVe/g48EqZ9ugaU7cJ1jfTwTmYZ5yb+Xhq l69ig7Hlh7efLqH3eOcJY7a4i6djV76wWXIZMOqZ0tyF7DgZrdFTF+2zbD451THPqGymwQ5dcT4P nk+aL5xyf9lFPHfJeCqHQoPr3QxbuRWchGFJMu2mLuK2nzjvzN1r39Q9LW2ekWEJ88xMy3juzHey GfyfeHJPzcPul+ewm3l4XfdNHfmlXN+dTY1dxoNv5M/teXL4WQpa9XMV+SWs1qxZdusPztqHa4bS 7ZlziT219hgRC56c0e8rawHOauh3vxvLll3q4hkGWzipy/sK/LLQAhP7TDb+0tkm63RUrZfask3V nnabAK2LM4K2rF95S0e1BZnA3/AtZL5+ZOjaPWtu0zjp7BQxV5kow1NO1OWsH2zSlwxLp5zAIXBL GXCWLuIim4ijwvL4MvbDtLkKSuzrQtYxw7EpfDEeR3E2flyzIyeeJxd+ZDiOoC7H17TJ0eXtIzF4 Swa8pQuuskl8U+Y86SRuzjl5Kj16ysDX50kP2SSeKbNLpoevr8Hbh6eJ7Eqlqnknu9ysHs85dpMb ZzDAWvNXxJznpUy9qatUg02lpnko8EmZYTf0KWWNtVZxiH18hNQ8T8qe+eb4gxpR+GTO1i14xPJS t9sBPfVryj+3191ZHjxTBrcMcpRHfufh+nj7uLfNF8oJlmrHVw9s9NcL9x/YcZ6uWXJi9pWnnaLT jPa0dVH1d+f+6l/NgE87XVh4SsTGaYG/kENm9tS1E1duExwUlvN52HEunIx8Hm0us7s4ggXeMXbs 5cTYsRcfC1t4GlPP+eCWMuAkXYS8H048F0sWy0fLCO1en1Pq1dcfoVM1jja76uPCB7WnbxyvR8b8 VzXOtThUHwtbCD5G/tKhagy+TV7jaDvN6fjr3oWMpWGdNeKgfjNxz3R2DtAVN9jsJcMSBgfnb9yU nuRcMi4+i1KSA+LuM0X9wY8MfCie7k9416/37M3M8JD+h21KkA1sGzaFyE3ZxNHd7NiGgG1txD+/ cGtn642Tn6aP6UhuM22YpnRcUgY3InLrGHFY9S9m1Y5JhUZJS5i0dVxTBpO8sgrsVm0YhL9+c+uc x/WrCF6pgw0RldvWFjG7Gf36NotuM0T6ot9jwOBfjPu+qX///O/cyGaJMNo6XhYHesYsH8KYJfjw ZEkBtjyBGn6gd15Rq49u89WBU6bdG7roz8lms/Pt8XtNeeRp2gHtwCNlUF9JdyXPiItFU6ExZk/I 9uWgnJ2Ic9VKEeX0haymWEVuFkZNKJneInYVfezPAxYLtFOfl2piy3Yu02bokgVtEo9HZrbU/cG0 lWTa5Cewuw/T8zDdmQ51r0wr/k7W50lPpXlN+0jzVk4wCjxTpiUH4pMyHhZio9lqhtwwnyeMfi1z T+AvB7SZseFMP2PZxn1wTZk+I8atZSyb0gAx8/QoKYPY9IyNbAo/MnOmrsYdzIe9Zpnq9c2T+gJ+ nd4D714yrzXMySkOnoIWh9MyDvtJncerLgN+J/OUbJJRSZn+pGYyNRYD54nE9CnDXZaMBeexycIx LHloM3Q5J/HkkVFThqdhqMsTM7Q52omwhMFBMuAmXXKmzeD/xAZjYYWsVWPmMH2hrSdXDeU84F0y vD0jd/JuEVnd5wlvYgfT0HyD1z2444NfGs9hJ9+5z4MzPN7rId2Z/pgz/TSfnOgybYYuWezy4Efm jNT9UUuukrUk51jcZ+upe3hHrDRY0xH3LImr7/AZz4bI6vDwcN9FZUrgvouWtfqWVdvf+uP3uh+2 u6XHKRV298ovXuvAn/rSboygZWtlunAEKJlZIi148plpsUeWA8etpAxPUGe8ZZN4PTI7y8H+UT/y dCAxzzHQm4GH78Yl0/OkxHlSiGMvyZSescGoPcOK2NzMHS5jTKWLGMgmcX1knnaPPD2tDmZspKF9 QuShL+S3syU7T+qc1TIOnjrbdwvLR2NHHBy3kjLg96SCbBLvR2Zn+5BMsXcVp/ipced94qAv4Hef nHSfONyd6cA1EunejANvemIcHKPr+vTMpEsW+z74kVmZhsn0YzEK5nihMYp6I7Y+WdQqDlwiTktD 8onba2ncv1iSn0ZtUfpG9H4MZy9n1Ky/Rl0qS8Nwd2+MuiJ3B7b9pZKxxW/XtRrEbZKDem8rODjv eiOtRr1RHob3WhDyiZo2MJhmz8Z1GbNs8cbTQxqtRjqMVqP9Hq1Fu+4YHCQDbi1bNrcZ/DM2DXsu 0U8b0Wsxq2Mko/Gwmw875RLuW37Ttu0orc8XY9Ub80/fxJ5nuko+9x4w/0yTlweAS+alXqKFvGHV 6jTXZmh1JFaPFzKleH04vJ9TsH8ic5JjXkOf3pBu7w+j/jBtTwxMtzfvVWCdHDvi4MYxVMtiDbwq H2K1XkxNXj2vMhLXlOlYt6du72nTNjAgrCxVQyndhDO1xi6RB+IL8hbv+JfOfq1N9UqB1UJYGZpq Ib6KZcwS7deYpbwhYt2Q2O+p0V8rel3AUUf6F6TlXNH3HXOuxGNHek/v15tuj3HW4NlcliPHVr5c xnL2zP672ySej8xqqbv2G4eT9dcq0aqO9fYxBk+m0mtrzKiReH6VNVXgkzIWt+W9ii+V18ryv1SH F9P1EZvpet9/J26PjMVn7ayPuEojPHvKjJm6o6XNfjMsxw9/cPO0Mc7ZQxprZd0kDoy72nL4xHFN mZU8w5+ZBuueTAPdw8T01xdw2iXrCp74ojbXboSb508rv7vfKL9bKWLllzfcsPxG/8/k543y67im DMqvdFF+ZRPld2sOjP62vaO/lQ47RxGDe0r1u/fMm//+aQ/Ou6D0YK+e5kjsIgOfF8HOyMIWiZij QsrQ+9DlLmPaLMj1AztPNQ807E6xwDdlMA8rXczPyuZ6wloPB8iI28w5HtisWnshU/UWwLS2jI3m SrB78sfv3ppb9YgvvxV29R4nv+AmBX3RTQqMn3/pzecy6YPK9KU2cyax15zQ0LwFNBryFqVaTY3G vEiZQhmEdmd4uV7Gb6zE8JRkVknd9dhcT1iQEYcZ8xzugYZzv8MeUgEODew4kKU5Eq+WMizV1N37 tbp3+DW/WMq0OyMl2z2RYl2xsJR8f29an5Vdlmva9RJP/XYiHr2d4Nh7eoc7+4S1W5R2e2UOAfbR J+yOmnnHTyMxnfwL9na0TNfRM70HR7WUkXehy9oAaTzkXUtjx5ZOLrNK6q7H5nrCWjlDQt365vKx Z8ZBZQ93qR7641TfOzJwWlBzGcKvn/hGzmvJvTHPjvLCHRkD+36X5/7YFzGwT3g1ho1Vd2Hs+JAM boWTLm6Oq1lvzZPpSOwsVsl8R6vO3PYqeGoteRkayue4J5HjAaSEY/Omy+Bk91MWuP/B8U2ZnanI W+Fk8/QMSxgcTuYS122PzRZhea7kTY0Mme9cuAf8S9NdpK6/PU0MczRBGfkeuj358fZ08nY8Z8qs krrrsbmesCBTsm1IpghhMlcCH8a0z8Q8M5F15D5PDNg2EruXTGalV/fcGZs5MzYzy4nLgKl012Nz PWFBRhxm8PT8dUrWTMdnxRC2fzFOfG+CXLnGLW1Pke6npD2l+cIE6zW+7kAmPAWh8FbW+udHeeVZ Z+F1H7t3ZL3Gs27COq2HTb2D9z8Pm/Qc3L8JqVHUUvN3tQLHf1cYg/sDqVFVO9nv5cy0dJ76fVTs aUFsB1dJEdvBFUdZmsmjrpoy3gsx3f3D6n54xJduYz61GnYOrrXIX6PVnVjxg0yJ/PVVsZG/Rr1R hweeM2WMn+uux+Z6woJMi/wFbunLNqJmA87Y8TwD451fjFWbJ3X2k1sxMPJ4d/UZeotxL7U9fiux 8XIZ49uzvwGbgdsj01bq9ujP6DwAw3IMDj1qp9Btj80WYblvOkdZDNlHCPyyW37ZTz35mYl6UqeM aZnnkoXLw+RmynNvPraux+/cv0872E+vOnA89qfCdW84XiVl1sNhPRzgyZu5o9+nPRjjRmke4z7l /OtEZL6Zdb9f+sov3fuEEyPgHaV+ZnuH373UT7V9Lm/afK5Ty8jNBitz8aklYqxjN7uN+CfWs0jW PEiBkNuFCy5serHk/3r1SrPzSYPLBcK8jtDqNA0Qm50/zd9tYMarDIlrSZmq323IhcRpF0NIXqlp O+QTX5fpdtZVur1gQMjLe4jLTJmi32tywxBah+EVAxxwajZvO/T0lJ2qGmyGGTO+wtZsL39gDHy5 dZCh8XocsuC1OcIPI17jR10ku2xiGKuwhMFBMruk7orhbfJnbFzj9w92EU9M/IjTeWzp2n3qH0xv NTtLpqPrlOIlINQm/uV/8VpYSnGrKH9Xd6pdHFHHlnDhd4P04FNhxEyZjqH9urHdN39HCtcHr5Dx jaKtRO7gYJ6X/HGQL9wzB2EK1XXtYIbbJK4h4xz6TG4dnH/EhtcDcqKixzbrD5eImW9EtQrQcW8p 0zNnkYU2LwOPljLavAzdWdLmbBmWMDhIhrmSuuAsm85fsZHG7x/sIp6LqQZO+7F166Nvz5vAG8cv P6AUL0ig9om9Mzx4NCI3HN/YfHn1AaVwCcPSxmPDanb/y1dX2WU+/97mDf99+bPZeyDNHtfEc8nn z//9//3j/3oqT9sq3jjCbOuz3tg+NLvkvekmX7vcrg1WU3YRdRu8KZYYPQzJlJm6vIOUNnkfrg1p hH9ZyPaFd6PaxvE2WNWQUb8Zgmaumk0AtsGbPtcwW3x3ziYSG0ex/jstuTy1wUra69FGGNJej7bL i62xuvQTNG4y5Kwztaf77HP7ZLUNH/BV12YXh+PpNufq+MtxIWPecN3e0qZx8LCcT7KbOD0gRj1T a3o8LbSZKcTWtNn1Wm3ydT6kUOCaMuOm7thp0zwfv49HvqSdvh/8hIuYSRf8ZdPjojTfGbMMGV/M Y5v5B/jGl8/ywtoIdZb73ooC7+lFOrCBd1xThrdoU7dkXlrKxxY7x5ZWLtNb6los1pNWHhZkxAG6 4uacg4PjmzKWgq5rKes2iTOV+b4u8yC5/XXrnfnNN6gRs6vJLbHsXnI7JruFtqvDp0251VJ4PDIj t8bZkdaw2XNr38SWPN8mhy+81oFf/KqFwa2dB8MpWzPBHX4ehraPUXtnGJoypQynUqnLQR1tcoLL jpP2ygUFbEd2fEbK3JK6d6VNMFVYwOIAGXGD7nls+vATHm44DkUWTV4yD7czE8sSZHamTuNkMFhr khSbbh3fkjLGyHWxnc3Z3QwLMuIAXfULyaJzShsstKwKFh3ZkCw6J4DBwvEtKWMhuK6F3Fv6rvdH ZozU5VQBbc5MJ8fgIBlwky44y6bzz7ymTWUIOTZowZZ/MVujZIpoKxnxybzT900enEojPxzdFm9h xEcyiOd+4u+pcDMsk3EOpptMN6aAVWoxjatUKImt1GojGWOjXDtj65mwvASZnl7l9dEZlsfGMRi1 LBWuC596at4MCzJecoKnpwirdmp4pU8e/sX4aQkVvOcTh/nEk49OSXdlHLTxDHFwfEvK3JW6YDEz ReYTB+cA3WA6daDP48CNamPhWBknYvgADyc2Vr1+AFD4nMfS4nLOY+mXUpcXAQu3EzHleIupzodr aImPVbKudjwemVFTF4/hyCZwybK6S3/47Zv8dtQT4PHUaPup0bSISPzUaPup0bQFDam1V5Yfx7ek DB4heWq0/dRoHhZknhpt/6jRDjcb2Hw+sGto69jktrb0wPH8jUspKQPd8cPqSM/kl46tXZnD/Wp6 /nUxZqTUXZnrri8Z4QDF5QIhsU+u2XnSYQfaf5PZ4AF46A8edNfvVey7/y5evjEKuJyb2j7dbGmD v34L+3VM0h9qnW1b0ojcM3gIY+AKjR+/j6fM4Iu8IikPsZXqOWnUGzX5qOJIXD0njbqj7hqV0+n2 8lD8jo1ZW/UktixFmxn2j8JVjkm8UgZMHz85B8jsaHvFwb3U6o14Nl8ss1IcX3A1S8t4tj4Sq1cC mRF1/Wgz6ithtQ64IEatA/YJuIZjXEJS0nvt8XC7LbHKEmR21DfagJVhuScdw3s7SkzogukZie8j 4x4Onp5LevYNtanL4+lfVm790qUq0VLoghXhKJNWEjq3/yD0nj1T/O6sutcy3X//y8Qjji2ih/mb OCYM869vBGI9xfiSf+mLdgT9ev76/Vj+lz33hYMVXH60k8feE187N2DYrhbf/EDMnihlWGNCV5so YFObK/DMk3rr27Z+Bs4NGHhuSbp2htht2gt9HhYxOVCG3KArzrAZGzCgUTmRDtY8sqbffTOBnZvt vIRNWFfOSodtMXXYzgK3WoOJNjaCSWvJRKUQsW7MR/CGYxyOoAy8J114VTbBQWEFn4xd42IYpXxi HY9mdS7eEbMGsLnpDzIV0T/kUrFNu/U+xGMm3o8M+qIjc4BsErOPAkbdexmLBxhK5KvBBVVY4qSN tO9KfEaGttMznduqYFPlCJ5U+YKHA9+QQYpIFyklm2TKsIjvChlxg644w6Y/ZUKmg+MYaI+W+Uo9 ZVriwuzGcQoudeIxscG6DbnNcXlkcDxEurjsgjaRZvodsZe8HvC7kX6O900ZeH1l+rlNj4tyTsuY Zcge58k+CeI5vf7bfAwWX8BqckSFXKWFl5UPwEqGNTp1d6bh5IaCzScmMw1dBtdg7KwPZJN4PjLk QF1nChaL2wygsVRux4xtGrYc0JdSfUre8fQFKlrq6y+W3E8bk4LCsotLEl/srSx8wNl64f7y3Svz 2faeAHzlX/joaAvfatmf2qcn1lVU5HWqOK7otep35Zfy19/rw0p9XrA6fswKTHjwnEwOa3pqzGTF lQ7JjKybTs/6khf5Mic4xgEGyfSauj1tEs9HRq0NDz+8Jfg+uZknTYVX5iNeBEhtPnLNuuCebM94 LRVj4xhHIlSXWf0lXXhbNslBbaTzoR9x6ED1d6+xacHY+aYF/q42yOWj9h/lRO3/9bLDw0NHNxf6 m2ptbD2wtqj9A+9HBn3eFrWH2wTmAXax89EnrZ5oO9W7/eU8+GWxr7uSh9ftI7ZIUEa1KnRncd/7 9grLJYF5ACP6EqHb0ybxfmTU34DuiZy+2Hu2ONilY+pJW9EdasOtXhg6aLlxEWLrieV5yJT7pI+s Ih2kzdBaTywfQ6Zcbxl8O8bGMYBSPE8G5jGNqGlCtz+M+sO0PzFoMV5QLfONBlgzATN3k4XnevTD Z7I+UfvrAkfh7A0OzSwiNXlRfYblqekYRzlmtM6h29Mm8X5kTktd32a3eTziRqnSFhBod/cRjkq0 8EX3VLPzML2yN1M7esAIG7/H/HNF3xhXzRJX3zhWZ27npS1vcytmxfVlrjg6TQ32uIjZplGGNRx1 uaGBVn2zHTQaHvWhRmMNh/P6jXM2VgC+vijjgT6n8Bkpgxlc6V7ZDLweGbbE1GVrRJus7RiWMGeg MzauOx+bM8KK2FweSajC8l6NL7TFUQE0dACGmDkfMp3tfuUcdPLT9lvwdmzxcRnOQd+Iv9u8T1ic 8b7pi2CKENjmELNNQBo6xqzwPsl0PzFYT8xWTZmZXtUMdoQVsRmZOi6D2Ej3PjbvExZnmmfqet0I FqOUyM/Dj9AgPv5loq+f+Xl4KqDXmTlAh6Gp25PH8C2FlbO2aXUqr5ql2c6DS1jl0qZ0xWLt/N28 xKVQltapkPdj/zSG6x6YT7lwmftwuA8HyCgs6HobTaY7c63mjusz70x2M3OkY1jytMp5Z4bMsQ7x eWROlmxeHSebd2VYN2sIlwG383ja82mE5bFZ7BHCX8vLRYnj1GCk49TEPdmtx9fLe0G0qvJy+7/4 wrVGfsn6t+QXPNAk3+Dhpp11qY4ZEXsLAY3Ng2jQ4KPPlNrtPjjzGPe7SLdk6dOBHXjZMZ90ypLl uvexeZ+wINOz9G0//sYQeCyXmCs9KD+OOb+e9QSvblcMTku8M615EZZis1rGZt6MzczazWU4o54l YD/50MOCzMk87DukyELjBtTu0U8HD30BPx1fpsYTh/PE8zz5mJeLMw5XNfReic9ImVtS9z427xMW ZHamZjI1FrdlnrztzZP+BZxa5kk+vSHtp92/vh2Wf530AK/HlSV5HCGsJ3briZ2nSkndK5uJHxnl noOxRnGbg49nIKzA3ESdZcF152NzRlgWG9shVjrrPZvP58W3/js17NDZz9+fegZfLJ9Y31FSdoOR pJB/RqGHhZ8yMwo3iBLfaH8Dz1y7sBgNXsilkE9JvGvKrJXeWCW9NHd6b+70avaaQvc+Nu8TFmTO St37tIe+YgIWvJKK7GrviVv0e0bNfs+HMz1rzXR2bKG5DFYhst8TNu8TFmT6TV1fnUEaaha24oD7 bqmxZ1rKHDnqeep6HIn/7fi8uUHHtRA771HyWvto1z4c7V1gPDblvs8VBoTNY1/C55HhCgN1b6Zt L5nmjrkSEuU8dOdjc0ZY7qU+mo8vRvcSMP35KpwrGD37GcLuCx0FI/bDmbA1eFgA3vee1sX16unx 0TMnjvH0u8d47I6fdlf0/8ZYT/8vvljcR/Zbx8j+7OCFvpJRmYPuzbQYPmcF707OWRGPGRqOsaV7 RK9yzKdMzD4Sqz8PmadMzKdMRB9xJcYiylMm5lMm3OZ9woLMUyZmlAmTsqPFnto6uszfW8TZ/urV R5Nj+WUXYLhO1mU8BkxvOMYh4BpjieG9jdl9b7dwybqMl8rSG+tEb2ask/l9ZV8yZCymrnsfm/cJ 65bkcIKn57I9Mi9tP8jIuOmLcdoj88weJ+MwM3X3emsI7SOgxs3SqbV9hnAyrR2D4cl0dN0rm455 KShlzlN3ah4VNk9NT54nv7nMXKk7H5szwvISx8d8hXP08RP7QSGG0Xd476y3HT4aNV/h9PitLXLW 9XmDkXgev/yf3O9I7jf7zLrkXzItfX9r+p73JNJPjs9IGfPrzb5x2LxPWJDJMdqImVSGdmNuZdyb LePTQxl3Z5t/d/Zunh7WeHpY4+lhjaeHFbr3sXmfsCBzsw2696lP9agY6mk9FQANPRUwnge9hMdT gmapx+tpPQQQX2bMOwFHSseXhacAoubUk1vS3iOxXxkEvpU7K6yN+jCl+DtzYy9//f3lW0v0liWl FJs1W49Zs2TPmiV+1hH9Tl3bL90WKaZr9ZFigW0hvWYbGLr3sXmfsCAzR+pmO2dSmz433OrrGz7j Q1st29nZ1nylTvSFp/cL+PsND/78/anb8CXCOE+en71Hnp/ekzCNnjMl02eyIFOjdM6u1LNHu/13 82b3Gs10e/QYw77l2p6tXWDzYM/exXx6MMEBMll7ioN7qa8sFz17bTNmqUwme5LzxyzV5PNAwn6p HeyOU702nd4zsZTwHsvX35oje+jCbnc8duOyPPw1a8zszJh3qoZjNDrHjRF1YIv5zNFo6F7ZDNwe mZynnN7vMJu6MAZhOQaHHuOB+cybhc0ZYUVseNyZIft6MO3qC+zOk3ZXltmZvb85f3rp7khV7WZk jG6m6iqZqs+s0lxqEUx3vb1g/OVs//KFB1H5JcbXa+QX475mtF9zrZp4Z32jC1+ouzONVsTPv4TV nEObK9ug+fS95vZy9+lGn6k7NqufkbnVHzQv7Kdd2DmfNrfS2OX/xU4je4tt8sC9PUM0eaTPXnSb vO7+2BvyJEoI/hRAFQQ1Hv+HMUbdGnB5x55LDrhCoJdQs1InY1boFATg7SFwt6uJZFukriAe6EfG 7DrhyRV1QrjJOhTyDGhymd1emZvct2pzQgEfgXAoPEFjhDXI7/oGjdPj/F1PclEejS0NIpfR91jk YIpg1ZLs0PwwhoIrBOANqpmPZAzhoXUnRGVFgXVDDR0UGkO7ziCYTgiYEHQoAJJUA/WVDkAQEbeM KEYmNuc198n0OzcI3RY073F4UBggwGfiocaOMYxxDwKC8O0I/APllzZGZF9eTcBfNaTi76i3+fvM wHdkSnagGfgO3/Nme7iLs4Fwl6C5SwLmLqmV4sYYMIIIDtjYZ9sT1Y4Tcy9ltZesJ1coq/00ua+q 2qSCWspqkwqBP+eGjJV76drSrNsE1mN7dglT9BlklQ8P2uLV5PF1seATBWZ8dj5RYKfYE6+UaSV1 W/N+guOZMrx8n7q8oJ82xxOW4x4y5NYfT+hpXOf/xEbPQiJkPlTF3/n4AH/fj7Y/78uwMTYi5poV UydwNZychqfIZ2no8W7ih7eeLUV8+Bh3hBXxd7xSBv66yVo2hXfIiAN0h/bkiAWfu6KGLvxT3PTF OA0904349Cc+vIhf+Mqu5aVvmBB2Z1lut8cX2Jrug+09Hccjw9Mjo+DBpyjIj8+twTeBV8og3jfz mGwK35ARB+gGU8aBT06gzHA+R783lavxl9/jeeQrjfCAP7lAD8wsTXNkrPnclLDnZJPpmdu5Dlmt COfvxzBjbY8icy6JnpF9Oyo1eZxRMRWGByQDpipZwCqJkOmZ+6b6DWJ0ntjsJzY788ZcT2zWE5vV Mjbric16YrOf2OwnNueJzXlis5/Y7EzzuZ7YrCc2q71pzgcameYscfp9Zpr/+N21rzQizf0hS3xZ Kg99EKf/1lMe1lNXcNeh4/Qf5wCl27Ku4NVQ9FPglTKtpG5rYVM46+j11BXBlCxm5mifbxQPfiG/ mTXnmlm+2a+WzFN/82JsxcHr/vrglTLg9+RQ2RSjljIz64NgivRam7VaFQ6N/Vg65cFvbcnHxITP m2/4yBbzjZ6F0u8n8s3P3+drF+MdhXjfWmTXE57lDCm9tmsNr3HdmF4LvFLG4ue6FsJ+Un4/rfN+ cs1W6wybvWVYPXPf9pbghi45t8y5DCtiM7J8bL0AwtZTX2hrZCu+nxzEi60ks5RrTHdlrt5Rmq0H xGuqql2T+XULW3if56+ocX7U2od1M+J3VC9a7XRGlrTz5NijXAqZp54+Tyt5muKzHlxTxvKMdMlO dT/weGTGTN2n3Tiqy8HB6/iZ/C1tnT9iPDJ/n56t5enZazvRYwKLo1rR8JInjMXqkSL6nYz2E3vv SV3vB8tDZ6QX1fOs9cErZcDuKZVnP7HZWTc4t3qCGz2hJyvE6Cltx0sbcpK+gOt9+iZ6lJy41ojP ffp/t2bflvjX8yWstuxvch+A8FOWrucj0+0Z0+tPCSMduEdZX1Tn4veV9aMeNOfvWmmvNumFMYBp Y94s2qPV88vEqIG2TKOpz0TMeJsMr5umblPfyx4o9dHErg/eKXNK6hoLt0l8Q8Y57P0yHZMjC2O6 Z44yoNHSEmcUhaPfAg+wd0fcX99wh5q8od71enrdFrvOR86EHxk+Uk7dnR7ral8wo+q4pszYqTtW 2iR+ZMQBuuLmnJ2DY/hFMvCLdOEL2SReKXNqetsfV4SUHtyG50dLS8Ofz+2Yu2ReJ+799eqZkePG 8ZGGzWj5l/n09qFx+4Nv5DjvsS/MiWZa+6Ou+eV3aGRKTLYDwietaswKXc9NzbHHYmIdXhr9Rlpz HpX5gfOozPmBd8qckroIQaNc4kyvOTMtpno0sDmfsBz3lAE36ZLzebCPZS0duc+QOYV79hTyfry6 swTN85YgXmwu/KN2WVj9ERMvQZjXHcn8toyR450y4HEz7FXqg9OT3l/d2WeGzVWztAbuKTOzvy3O 68FvPHlSXiG3qCufLytmlGW3p/eXanDg4V5anbO67qX91LR6PpQaN9N0PTXt8jrHZJ6adj01rcvA S09Nu556wMM6JTns7TPO7gH1QpFPvPcIjZq5eD9lZrdHRj3G/cx5ymrf4de/fBknv4zzeNy/wH/q 68B/8/Hf3Im9P8i/lN9hd/fXrr7A7k6f751lZ5/64P1qX7Gyfof8s8aDa/Y5J6YoM0+cpz46ngdN pmRLcrx2Pz4rytQOvFPGfO66p6VNYIUFGXGArvfSyYKzfdSIlhHx0Rfwe/K194KBR5avo/EZdEfm Fb/PjrUQby1gDvEeHBhqFuA8vTzi8bJdJWohvyi22mIeepK/3dbJPH+e9u6ojLg8tC9KDPtXxBxh 2LL9XHq4FiWMT8/b0r5WgepFiXQ8UwalVrqWH9wmMB+QvPc4/uVWLx9r3bEMIhbsK1yMK5kvL8ae wrelzF2pixDYxgrPlGEbC92tx22xTqTHbc9IvG/KgNt9PCGbzj9js/EID0Pm5cr6vd1gxLUV/e5j RIbNeVviLU4lMeottmLgtHdNS55qPcaLlJk348P2M8KK+AvDLzP95br3pE3inTI702PHk9RgwdxJ jcx5I7/s6/WMuN4nPnc8WKUJeYn3PtLuWZGXbn5hOeuhf+Z98IjwzqzhG5Vk8DvKrRyTroify2Cc K12wcP+dDAsy4gDdYIo4bD7KjbrPH2nG2JBWV/nL79orqTjsmx6IB8L35djNPXBLxvqW9ObxnGwe uJnbz1WJaPn7GT6C/PAyO+kZt2+jdY0ZEdPA65E5yQGs7+Olm7nv+GwjYzOe2PQnNj1jc1vGRuNN 6raMjf9useEOdMWmP7HpT2zGE5vxxKY/sekZG+cAmZaxuc1jY2l4Z4s0v8ox/H1Fmv/8PXwhDU9z SsUX9FJbsbnku/brP/Zf6RvV2NDYj//247+TrcDVw9bwmcoo/OT1bEsZxPtk/eA2iUfKiAN015Oj v+5o5GjgiEN8+fh9OGrOxbt4hEvUIatk/b2KHg9HHJTjEIdsB0Lm4xe6YFF2YoUFmbpStz710ip6 kPwKh0Z/LI364PF6oKsdNDzaa3dOzzeLe+n99+v55i+/z9fu3OnZ+cPn+/GsniuH1/RA/ee1VZRi n9cCI+b78Yh0EUKm/NIj3pTJXLPKrWnzPmHdlhy8JZipC85nJM6a7/ur4k4vhlxLtKolv5itmnXi qk8OqjVzUNVT9NBtkauFf30lDRsuVOqAedmmJfTksxOtYC+H/z58xl54lZRZ+v16T6pZxlAP68M7 8Wwpg5010sU4SjaBFRb39Oj3kdxmzV6YvmAvnjR4kzMtoYflv8+0pL14lOJ+E/qCu0E+3uhvrcD7 h/d2V3gY8TRI4feZsWDvQ7+vI+2OXvoI7aMT2/Sgf8Guhl7D4we1vuMW3ueOZOnyUl54n/c60PuO Z0sZ84frgoVsEu+UEQfoBlPso+DluUgL9iWkMR9LvLdb+L4eQN9deL6+udgDxhhxv3Cz6uTDPWLH V84dPzK1hjduSY9xdrjZW5CB206Z1lO31bRJfFJGHKArbs45eWYedZm5Utd84TaJR8qUG96+Gt9L 6imtdz6W/Dpk5NE7mHuANaPeyh0+Vmq1PuOXZlt6/Uu5KO/0wX3K+33KO2TQJ5Quyy+tam9sfgmr Kv2wtMeDb1pF6ytd1JGyesYTi11GWNVt+oWb3Ta1h49tWsXGNuHaUwZrZ9RFCBwvOb4pw3oAupv5 ATY5u8KwhAvX/lbExusQcr4P9thwRmUwTeqf2qSmkPtKRv0mHv31BW4dEB5vWm/cBC4mqoNujJ7E nLfoM0bCtadMjdGTwl7twSdlMHqS7n5s7pVh7ZUcPP1j9Oecz4PbGxvsR1PImtORXX6h3ZN5iRvU pK0a3PAp4SWMtU546azM61yJEp6Zpl6vcc/ajdhxTMVYO649ZWrWiYiDbBKvmjIr8+qJ1gIs0M9h PuFoSRqnpqWnzJxbUuYqF5vu/WEVM2Ku8X655caXqzs0GFd9KfdmfWm+8TrsPnUzcHtz7PX8HqOP sKtWj2tr6XPWbtIe/cHn1Z7kC3xK1CPCBat3+6TVnXmCZz6E1yOzRqT2VSp5WJ7ajmtPmbpCl/H0 snIiLMqofEBXM/NigTvrpKETo4oPv5Bf5muNABxPj8PirULQXaVGjSesWmjx3ApyyOK5FTD88EmN Xh88k+2yBum3Y39bwy4Y+sYAyl9ma6zUHyfD8DIy/PdfeblhtXuCsaaGbTnCnDy0vwo3Atmuu6qu N7BL0dB//c/+89SM9SLGTGO1G6SFPo7/9Ifj8qckv9hK/0P2/csR/HV8+YGSQtAnhlVIIiQP/5/+ +E//7o9qm7n/RpT++Q9tMLd24H/q1eITG/hLQxLwMUyOVtIc1WBub21R0g5Gy9qHnDl+BUdIElFf eIs5Q/Lw/+LMvweldOZXVVZfvbPvvnp3f2Tkv082+LvnzFbpTLxpwHdPiZsvP8UXudylHvdDyr7g SZWKtzgMV7z6UL/G1ZElpvBaf0ry65hI/0P2/RvL6tdv4C1JIOkTm1VIIiQPP13+N6L0z5Er58ny ZJiJbWvNjlpkgW+woCxgd9tIf9XIAvgViQ1JIuoLH2UBhuTh00V/IzqeI2+1GqPjDE6N2tEa+Kgo 8QdbL4iwzD/Sv3AIQfWWjUoB79dao34RMNaEX00EKaucoMkay/pb/K11SQFQk/CzZlKw72FG9vtX ZhEu3d2v+zYn6dbtx3XyF6smcDAIVlaFEKBeESxkavUPNVEpgQN+a11SBMuZwhqkzL6H+dNf/3os 3F+9FtzAaQ7rpQr/g3hU7fnBZcyjzJAC5pdqd7jw1SjrKgLznTKbjHBkqStsTwZQstv1z9D/kH1v 1X+196coCSR9YrMKSYTk4Ydn/06Uou05uOiXm06BHzcLy5n9zGAODI54AMBRMO+ni/lXY4k5kJjr V7zY2oejEcxlFZKz/Znh/3Tm34RSNuTN7gjBDQXEfE+BV5wT24Xpdi/l2Cnlz0HX3XT3iH2pm7ja U3WfzA6Eqp7YKnhKrq/zQf2Fnp5NoOhXu6eFkkDSJzarkERIHn423n8jSulmHIKY3R0I/I8fLndn npHMDZOjbTp2lMxPc+anOXNDzpy/GkdKAvVkTquQHM7c0F+c+feg9NOZ9aYzq58bMenZuIvROACD 17R3Ihw1ZzvtZiRK2j211DcktvoVNzJAEkj6xIdsFZKH/9OBfxNK4UDLnP/mwP//DmztTu9KNrv0 Ux0iYl91vCM7llgB0eiTUhz+vNq/7K/hPZlmzwYANzu6id6HELokjsufkrTX6qiP/kzrVmvxVxty UJKI+sCwCkmE5OGH+/9OlCL/mms1rmy2fqtxJbGPPvOLXO5Sj/tD6nC6c2uo1+zWYQzKHFkFJGzP +VHy65dIHz2UZi/q6dc7XfLO1L/TrUISIXn46fK/EaV/jlzJ4R4T1jAT2wZmjlpkARvESdLeOKQ+ hntMWP66lksCSZ/4KAswJA8fLvo70YkKYdT5PyrefzvnZZH+e1DKTv0ePtistw8fbRLz1klMOsUN lKgEMKpyDR9h1Ys7Ehv3RrVNXG3r1LBJbkfokxBbPQ9JW16gviH7bu/68tcxXRJI+sRmtV8PycPP RuxvRCnyrJ3PVaceT7hGp77hqh72D1or0/sHwOqtQiZ6rtRg/5Ya7N++2r/sr+FNeatXTXnjBVFf o+sIGYf4a6ApaY029dmUN7umVL9WNeVC1Bc+f1ISIUX4WRb+RpSyd7Hk5t8/XC4HqjcODsAt7qxz VJ0t+tiS/Prd0kdvHBz0a1VvXKhXZ0urlLSQIvyfDvybUIqJGLt906dYxo0pFmCfLRjlnS2YuHAX Gy8o5Zfe6S9seet2ryZwt/NXH6qOhvVvhG2Gg5J4wQj63RK42yks/jrLliQR9Ykn7ldvHpKHn/MI fyNKkWdtc8rk6xbET5XxP8D/Vhn8r1YGs6Rj5w8HzoftsI2xsDGC7XjYjmALSfCaD9sZbKcthkOS iPrC9ox3sJ3/0oF/I0rhwP7kzD5fB1o/xNla74Y2rMdDu0LRDyIHSIIX9MXWejf6dTlbohv9IFld zjbC/9k1+5tQiq6ZreLpgSvioTfe60a9wplY4MttCZ+ZH1g9C76hGL2M9vQ/2o/+h72Zoxm81ppm 8FrDvJqNcoRYzjhbZy1F0wye9BfblFH81zFdcszUH9OtQhIhefhP1fD3oRQJM58+sy2JeZ8ZWH3m MZ9b27FN43+q0eIEJ/7inLAt2gFjIe+TWYG4Oo87yG2qA5L2Aiv1DWl5j7/aQh4lgaQvvLi8p5A8 /J9r4H8TSuH+zqto21+c+W8O/F90YLOLN75WALNoxLpZoluthb9+O9ZZV8qtR2eib0ypFy9pcI2N 1QzxVG+ai0sTXVcuWRnmMpbdDeXIyqQwHlaF5NdJlX7Tekv1X20Zi5JA0ifeWtxiSB7+X9bb/h6U PJmOTRaz/Tw+b/xVGTXxrz/swLJkAPn7eUUOLqlAy2ZXkQAeO5BrLZCA5Q7CL99BypISmmzT7Ogp f/POw8kexfFuBqRg38MMB/8rs4i6o/RwKnHMwGNLvKa7LYU4CY1t5piYFsJ0NTF2TbWliW3oa7rb 7q3WrxjRQ5Jje+oTm9V+PKT+V5/9nSjlFHAfPgOPReDcwWUzSXXwngDg50tupLKD0tzedJZvpCLi Rijh8qckbcsU9bmRyrb96ldsXYMkEfWBYXX7RqoIP137N6LkrsUuzf9gO5C/pLBdn7a2XG0bq3Hs xTBqADuVUnXYzYbq3AFLyKtSTEIn+kxRB/rMHl/w/OD9U0f7bKe2w69cuMA3Lne1r/PoxlaNIAwq 4HmTz1zJ03atchuuZYJuW2R45QpjU6/T/vLsdKPCpvGZv7zNwQ6W6jqi84XvJz8txs0zmf0+JP1x 49F+2NBZzy8j83Gier+BS8ATAl/3UWqwzKtIAHVC2AR0PM/UeK8XjOlItQVBiIApADpUA8mZ8fAN ey79+yVkM6pfz+ZyHx9+14lx46GjesZuJ9GTAieJxlFcM3c1GTrzd+MCv/92XMINwtBW2v527NeR YWpIhxAtl2FNRJkPKyVIZ6yglMQ8Uk0ZeQq6UxnXbPIQLSacylSuqg9eKWP9ete1bXxu03r5Hhaw OEBG3KArzrDpBxLJAtvNP7yI/8Hc3PiMe7VJMqznRMx41QUwn3SnjI4sQpcPFNGmji9aoQyMyTzJ DJsC4SFWxuBmzKpfkWrp9vUDmxeAyk4dsla9OpiNKWstk37GE5+UsS1X0rX0h83Ey2Va0eHwT7cV XtBhNpsfq7VhrbBxcBnj5rrivB7sOdI1fv9g94uz9K00HngFj/ZwbTf5dRXa5r+H3dG8UvnwzNC9 mE/HKjONO7EUV5V1hLF6aqyHx35k9ko/nR9WT/WimF/ApOIZQrG6j/+zJC/+pbLYqq4ba3Y9yOib S+Tbnl1CTdHsEpYPN2J75IkHMoRrykz9bro8EEWbXFmwm79G5/G4/hFIvEPG3p53XQxKZNPmfj0s 4ZMy5EZdcYbN7Yv0YMqjH8C8KpiMeJGYY2rbM9CDh8762SlvrHntceuYC6kZsmTAiNcSkymvKxbr u5P1VWzME1f2v8FX1xPSze4gHh1D/zbwrC8PrAw8XswDWsMmHhq1bVon8U2ZNVJ3LdpMPEKGj/1S t/P4HWx2HnhFWI6Ng8vwMWHqkvN4cPXYSOP3D3b2ZZkHGvIdebSHKw/S6neG4fKPXTyR9GFjOJ7Q x01Luo6n2eteo68STDqPZjKM1VKDx8mI9yPDA3jU3T+s8piZNO6TjkMxByulEaR0dcynv/nXb+FR dLxr81EnHAa1M3rA/3CMPN7sHN/gQ5Nt8+mmRYznnVBW7ManoUN+dnN94poyeDRLunOkTXBQWM6H 7Jat6+AyQWrz8SZKHeYKMD1+DO7aiHUzX2Ob8mapu+X4Y1nNTuEOf/hBX/DYn76MRwO9O/2uaTP9 tTErSymmmb03OXh1lrAuuKXUKdIwz+KCCLHlIVirlQcvpWl2Rjmw5UGXsXzgulhxpT+Ed8gclh7o 8iEs2uQ1VQzLMVbRJGPcXJec94PH4+ODPvPLLuKJaw5li8dmr6/aRdgsbeQkDK6SQRz6E7f+xJkH DSnDw2rUnTVtssZnWMLgIBlwky44jyfO/c1LOkb/sIsva0Qu44FQ6e+eXLXvo5fTmTdsCsselGc+ EcaVC92O3w1endatqR28Oq3bToaxcQixW8dN+arbjv3ELWTKOaFrO/3dJjkwrOBDdtC+A/NMfJBt UGr7I2mydE9o87iu4wyNV6RRl3mJNnm1QS9Y9XWcMvaaux5qk1duD+xXDHdMhrN8fzjKd/+aUi/T X+39lG99QfnWl/FooEzrd5Vv/YXyLSmU76/liPItrPJNKZZvvO2uMiq2l+GhxqNf27yJ10mZ3VN3 R/l2vENGPoMuyy5tskwzLMdjpswoqdtP2uxP+U6N3z/YRTxRvmWrjwyj1wy73eQkDK6SQRz6E7f+ xHn0lBkndWdNm7NnWMJjpgy4SbeftNmf8p0av3+wiy9rRC5j+Zb+7snVyzeeON+4ELd/PWDifziW B2zr/lasiz3S3Gm14Gls5nxbTOd1Ad2eGErcUmaf0LU3Xt0mOTCs4POwm0hRYtUyCGE9eDME2xzA i+A6n5aWPNht1lz3BmZsKMNY7pqxX+vBNWWmfsez1/IKeHqpGsUfcofnP6zcisfSG3PGdfxLX5ZS wb6s+mjcnhqaX5XGYI4G5qJBG6bdWZ98Pab8ffqT6sKjpczg77Y/YnlutcfRZ/OcG9hWTl3my1yh C9Yj4+ZhQUYc1kpuC0+/H/eYPfK+ppfPzks/vphtf669YzWWl/woxrs9+KaMPAzdM7xcdV6Q+uHx 4EfGzpbwih/FYKXf1zmP3/lIlrBqYrPEa/cdr0gPXpZK/7o8HlZvPfzrGI+1t/TvVm24YCcZ7ZL+ 5XWM9C+vIJF/b9QYhaXNc+Tumb/2eKyON3/x2kV9UU4HXjfDVulB2HtF2GrH29wPHilj3nZd+EU2 4S/9Dj/uTDW3g9gI90fGUt91wf/JLXt6K4HQFLMM+dcfp40/D+bj7HARL1I9H332F2xalhet2rQq +xZEXV85cjANXidiVjhqsCs7/KJHq6sP5iNsqo5tHUJG+pvFo8stEDauTkPYfG3MvuMiC/62nWN/ rKNWgHWUWVhH6w9t9Z1aw4XhXIK0G9iBbacDn/rhmB9PGnXOVOAZnl4ScxRKGV5CRF2OPWgTD+Y0 PFxAbCHb9XqD1zjYG9tzsHdLRnNnCMEVdvEEh8LTbAukdkkeuyaPHeHZxeXciM6wealJw1XlHNdZ Xv7wSR734XRPyEzOE0B3FsZ643GjSbwTn0eGTyM93uMYUg8jMZ5rDE+SBb8gReyBEiWIVXNKD3uq RMlB2HYIIDGohrSgMbh/IZ5KCavHlRDWlCgdyAKup2WlAg0iERgM0oAicDV/3TUCVwLQIK42BaR7 Fi93Hw7pHLsRSj5bfB0Tsmu7lxYdTzhDYF9PGhJC+RSswQ1pTW7IAmtHSvz6Y7MQoMDhqSiWsxav XVmHUN63cva58SZcIdBaqMH7NIYmwIq74FdWkWGx9mcVi7xPFuhi0PJUyYbBhaKNYNAqUoSP77XI 8yHrVQIu0f8t2zeZIOaAngWbXZI0K7aDtI13bjXZcbGCXIhtqyBvvtnY9cYJRuGaMuuk7uIECmzy JhurE4UR8v3Tt2vbRbqzcnoOjLgphSH4BhXabahMGR5f25UU7w7S7yt4tDqemDZWQ8QcxFvLMhsH 99ay5O+2qYy3CBGPmjJDv9t5q6EJHuzYowxW0YVtad1lwE66YD2eeCosyIgDYiBuVqm2mPKryKeH U2WDGBOU17NyGyjvXRN1qM5rYk0qQqaN1G2aVB1RtY9RHVvIdvRuDE7yIa/zVioy0lS1v42rab2s zhneuimlSUX8rkns8VbnozV/4+EL4/irEApPk8k13pKjjKp2cj2arsV7FD1j5PikDFicJw738d5N GVXt0J2a6h3d35Wjfcd9pUxvqdtL2iQeD88Tus4tOds22rWjOZ9Pc75QtbA5X09zvp7mfD3N+Xqa c+oyzefTnM8fzbnt3/PmfD7NORnNnSF4c067TP/1NOfrac7X05yHvLRRaSO/zWwYFJ4q84vHSuCO m03pzab0ZlNqi/RyBWHbIQBH3GxKbzald930ws2m9M7iZYAsEG1algduNqU3m1KK8MnRbErv25TS IBZtbGu/WjSGiBbtzp5wp8Chy4x1NI+2tq5GE/fVsylFtOhSu6I4YPRrLtva9NxN8rcGeQacbS2M MXnoOcEZAivyuUh2p84Sgggp4BldLkRecKwQoKNOQr9QgZudMICrLdq3bk/BY0cPMNo3TkjgrK2m EYhbymgCFLocptKmpiZweleLAr1aLq4+WWktJeoqMmqlRQhNy7a027Bsy/CaphwhVWfwaHUHD/7+ i1OuX5tTOHVbvM3puBuuDTE0GU3PAGt6BjJdE5mm22Ma92tzKGPlULiwveI07h2hy7j1k3g8MmOm rrg55+AgjJdpJYMYj0wR5w/cd8p0peZwbnodrt+ud7m6YSw621tcXfeV9y+l+m3xvlu/er3WrukI fFOm9dRtK2zaE1Rdd6kT+wuGOJqzU9ffbsMpmJZhzZEcHJeQIeep98N62GQc/U3R5hxsS6/donH1 klGvbukX3x/rl+9x0K6/3Gn6+4lPvJ4yO4feeIOj+TC82jb+7q+nDEwL0DM27bT9pSvDevEJMnrx Cbr+8o3Z5NYJO/GQ+JHBdImukzs2mPf3iwxff9vEQuMNyPxy9DYTftdLQPi9+psnp/odJ5JaGQe+ qBd2+U4HYuFvjRhzPgJdbR21+wt2aybeI2U+B4UuQr4PJ72KBBm9hWW611+JsUMKZURYjo2Dy4Db fWJwn/j7Ox2h8fsHO4/n1YtHA+WhZhh63QZh+2tLMzG4Smbf1LW4eVkivinjb2eZrl6YgU29X4iw hMGhZ267T9q6Tef/xLOfiOf1jVeUWzXjqTe2oDEzPbXpjJz8ra6RMojDfOK2njivTE/d+0/d/aSn 3iFCWDvzlMuAm3TJ+Ymzv3gYGr9/sPulrbqFLx7inmltvcJeVW2Hsgv5Z+EbObj3uXDTol2iH9ia aZdZI3WtJ+Y2ra0vLLnAvIOeMtqGBV1tz4JNbdtCWNySRQ6Ba8pgJ650LS5uE9uRFZbHl7HHCJdb u2xnkSy5XyruCRdmfcqw+4P5blvBgaUhv5SUB2++eoTbtB0jnpJB/MdIv/T74JEyTf41m026xto3 dmrxEqXTrujXotn3hUuT2EQiTN52c+vQmy12AnvohaZih0z1fguWVh2fRwbLo9JFyPIFMPmRhW8l Zch8Q5BffDMYdbgZjF+4GYz49FcK/SZ9Ye0FrHdUrNc19CYnlqP1Jqf1aQZvDq62XzDxShnbeOS6 xtVtmpf0O7wkeXhJduAlx+eRMS+5rvGXzYjL4xnFLEP2OKuOoi3eZ4UFaR5Jq9aHSvzKGI++Mg7s CTCE8cSfqUu/cAso/eX4pAz8y54G/c6NfsSsfSlDDtQlN9psN8NyvFIG3PpIzioNiItKGOJIDoy7 59SS+Dwy8CF5hj8f7y551/DJssAblIVPlpfL9plMKV9t28Rl/YfNDoFXysAr7PXQW/s8uKfMOum5 9eRezY8hr83CF0otzlPbii0Gk3cyw6rwL/+Lb+1Rqm9PhakN48Teo8Fd1GWyLgHezWM9taUXd0br PRPcgV1O8bIQ+NyUsZdlpEsWuyVmK0mmmurUlxv1wtSmTWDV7xxn1cht3jZgFFO9ZN8HZ/uBmLlu aWmzPO3Kvdne3BV2EEvH55GxWLqu8fd2yOMSJT5iliF7nCtm0YSzLhV2/Zo1+qehWTh79rPqZKfd WvFhztV8g+avycHM07S7Swbnam22JPAuKYNzJ9LdkzaBTZ6zUMScaYOMZuCgq1ku2OTrqwxr1hoc HBs3lzHOrmtxcZuIl8ICf7XjODmNGPwWdqvjieWI0H7x4HloGJbGwEWswucEJ5uXcE4DF8BqpvEk J2LNzpmMzyKe9CNsyr8Iy9k5H7CrtmW04HKVD3+1TNGLELgGgltMKy5N0QsSYyW2Lakug7Oy0p2T NoHtGhbO8hHrPQjIcN6ZutwsSpu6VX3ogsvg4HilDDhLF3GRTWCFBd3uL+zYduGiN3KAZbWVjBnw jJvlR2qcERpWpQReOzhZj8s5Wa/JOVkv0zkR620ayOjNGujq1QHY1Bs3CKvGVV3Cv7Tlme/Zf9i2 RA1tf7aNpZqDtys/9CqHzVIHbiVl2kjdNmkT2OTHSczZVcpoky50tUkXNjW3jrA4n0oOOzeOu0zp qYu4rNzK7WFB12dyO7bM8pUF4q3t6xlL4q0yaCP50ACWBjbFCWNzJjn1nvHp2JxKTjZ74ZyI6RfK 0F/UpR9pk/5lWGLnfLgmZNpdq192ypwbltvGhmqWYDPo2503NigLz5oyc6TuXLQJvH0zu7DWuCY2 xdfQ1aZ72Bx8bwFhaUM9ODjuO2V6bthHXNwm4nUf/ldl0J6iQgx+C7vV9sSyRWimcWZq4FAANWwx NbBtSxMnu2zBOdmeGudk67vOifickJG/1ko/wqb8i7DELvhg1nPZPNjhhlV7pqdrm926uKkWM4W2 X6Zrm93GvbTCtaVMTV3bj9a5cQJ7eTrHKcLcMkYZbkShLuePafP0DIvbjciBmNyOeKYu40KbwjV1 VaK6rZ4jBr8dy+rJWBIf95FtrHENYGn0kbjd5IRbeMWpjeTUgocw/UIZ+ou6SgPYpH8Zltg5H/Rx bM1lNL5wiZqNc7ofPobR27I1sQ83Yjv6gfndbzy9ElvZcRkrU647T9rEoYtRH7xTZtbUnSNtss/K sLCmKQ6OW8qAs3QRF9lkHPeDNSa2haPR+ALxsJLQvFdMu5t+sSMTbcuWhc0+NcPYI+1ytEHMEQxl zkldztrQJg/kDdxd5/iRsc3rjbM/9BfnRXV4RSN2W8SE53875qhz4PYEji5tQebDZHROeuz0xPum zN6pa3ePu01gpvKskSt++Rf2tfmFowj+zuNl/N1f3LQ+Gw7q/BYPHtohj15W8Oglw+48fCd8Uqa1 1OUL6bTZFOeV2FpIlzF/dawqkl3nKI+4/WCKAz6yytlQhqb8DBYjPdaV34CVJyEzd+ry7Uza5JFP MhUGU8mAKVOH7DgPQOyvr5Mp+tyyumeGtney2I9PT3vwTZn7+JSzQLR5VzIVBlPJgClzM9ntx6f3 9am1X86UbRlD46E2shh1BLtR06fcNSGZdlK3pU+544JMHRtTl8EBOs6Kgx0P3AnrHST9pZoAIc/0 /PDXU23RdHBfhrC/tGzrkvdwQq5uP1WOaYvKR5yqjWpr8eG1nSOvmkTaD35kSkvdUtJmKX7G3cYK hL8iXETBPlTvRCsEnp6ueBGinbTKhTVquDtsFVYX2NgirE/arOEHuO3iWJ++WcnHIDMLBO51NRD7 B61VHdi1bU2JH5kvhXW+19Zz+eYWYC3F5/kWDugzSvhSfb5lN0YEX8r7xe5g52hQOn08rhucvyau MetUuWGByTfajORTnoJzAz8ylnyua452m8CKtTl9+JFihTwiAYevr9isy9doMHshvH4zvFEzvPGE N1bi2VNmPlznyTisknFbmWVdphoH1k1kp5kvYK+bLOOEJ9fOmC5dBaSsUUdZnmOqSiRxXSnDOpu6 LfOPe3XXBz8ydomFe/uCQ03sc/wMjavW/OIrushBY2YOyi+Wg8boqePvH0+7mKRxXpCY61bTDrer F2PXqtbGmt72+9TGNaxpcxmBR8pYaK5rcyJuE5jet1MNwsGC9RO/+MoVdbiyTMzVXnLiS8fCN3lz vYlWKW87hSoP+X54J7arnFzGrjxWT4csznpwTZmt3y3O7GEtO/Tf/A0Je1C4NhzYqvagcOUehWp7 Xiv3+H3YGLHnskZ6SfikzGqpy9U92ly0OeuDZ8pYPmksD7bPtTaWMWLv5zC0jflvftn+1NXs9Ay+ lPfLsi9npo7Pw9k0b22dr70C60VLSHGEbk9hK6dg/kQcW1nnwY8MQpsxJxM2gf0lx+M4WAy9vRlW f/lf3C9Gfb3paZf2NL0VCuwxqh0pyfcS2yXGXNR0j34YKcnZLrubuGkWDFivnbYoE9Jdmt+6nsKY NUv8yDBHaIYOMb2Jl2acGBrH4vyy/f1Lu+6Gvd/vS32/IE+dmjreb7c6feh6DmCfF+fLP81r2VHV AbA1j1qn18qJH5nSUtd6ITHXXhiWamXhXxFy95ZFVn+5/tDst+Fekp+6CeDnv1vYfSYeJWW0goXQ hlYR7XY4X+VaiW1+yWXsOL3rgp1sAissyIgDr6wmNxth1Wgnly7AVusDrBZk1FK8ZRnVWyV4byWu PWW8JYLnj7c+o2qVZ9cHPzLWP/VVkQsO0ZUZ1e9bZGg9+iLA0frAS2p9ni/W263qBUAnrgAZulLg t2PduIPLAnTlDuao2GXDEebOWhkXgAd+ZGyc7bptpU1gXTGCeSVv+xUy+i/8ogM6FUfgB29Kgl31 8WFr6JoW4HIi7KErfsCP6cj48PKai7lBxztlVk1dzo2dxOxOU0ZXwsxNbsDGk70O2HeMezdr+tR1 c85QuDwy4oDrLMQtOeOeevuyeFHM7cQmhXEWZyJs+dPHVrb8qdk6YaUOZJSC0OVMBG1yluHeHRdC 2IKnzwzamEIpjnfTPw47cVzmgrFV4RoB7jCNK5fw/lPDvmPep6gvn+XrYz/pNL8CAZeJ8OVr4q3r CjCj0ohtLuPo2oPjMySNLwA4fmTsXSDX5ezNTsy24OKCkvWDha5uWGH1l/7quqKhYd6hpi2/iRJr FnaWyfae2mUvjYdbsa7ReEjY2l/N5/SCmScepCXWEX3InJ66h3s4YfNwPyvuc3X8yOBuTu22LeAw EvsBS4TWC3etIu1L8TjgqpXN/bP9/YJxf1mpU/3gY1Od+dtx41HJiicFeAgSLYCOOmfr0XE5u+Py yFgudN3S0yZw0VHE6zhYoEbRl+6H/Ev3+lN2RxxG/jAPZrLlEn5k2HKdjM/k7whtkbetBvGETcct vtUP1vYHr5Sx3FtXyzjo2gDikjLj0fVD6maTx74ZluORMk0teHJuGZd5M47igLiLG3zi+JGhD5/0 mO7drdYTVygUb0l7Q8uoKwrWzFRbSMGbWId4IdNK6vr1C8hReaw+8CODW2h5iLez/1MTN7+gAKGh D60v3fOO5fo6eZj89vfLke9Dx8d3qF82dwkQc4/W5fqhWjOsK+qCL1wQwTocl3k4fmRwKY10cbGH bALr0rBxHAcL9gD4JXoAuDKG79L+f419S7YlK45sP0cRQ3D+MIxaMYRsvE6e9pt+ucxMEvuciFvZ 2cu2IwlJfBxwEKTSuwHf7rhrBH2ndvMK16Tx4GAIQkIayPRgYjUxvnuKBjbMy4Z12bAuGukA3gwC CJ1DB+FekqbP5O07ZRI/STP1Rq6um3nFxmhjMWyhfd8aorJwYWPqDbsM6y1ZHVdbjBINIsCJtzKk 7nou3JOG39XIy0UzypRlyEsYOogGuslK6twv/Lg14vj60A7vWgv4i92n0uNcunJXhZ5Lv+7P8Xa3 yMm6L8fymBqRWTuZHBFDw6lRj2k1NRoCriNpFOAOvByvUya/J9hKYuKLxsYtUzsGHuiQHp6+TmfL jH1yPYBY5WZ+nXOmVNVI5KZRFbSYl3aigdbihTWSCdzTj9N3dDHnIW+HVK9v9gnzy7FieCJgjlo0 cMsRHb+gU6rT2168paCfCO3TVG7VaVie+uL+MEDVuXDWSYZKYJkzDAhrz/I5IDVlcCNyj6yJa+6U utJLa4sbMXZtKcPCAdreoKlQlq+7CoNOIEBkmdyNZx8r33lUv/BKGkV0Ba9CukImd/4xr616u9/X QZmc7W1bnWTQBlIthaO0HJbvCNu4Ynuyl7SVrKleDHh7LXt0veSXOBhIQs8VIhOSuPZF7jNvbp5z IDfXo+xQQGF5CWs1RVT8nkPMbyx2rKGoHxRm3rYnSic07NNy0psPFObz1AuvoMFNxzolQk012yN+ kmaJ12QqCOmBnnrjIEDw9mjKL4dOfcCCXVLq9npmEbOLToCQY4jD4g3zPUhu7uEmbitp2GrIy36D MrkWAB9trsTDF44tDL3TmC/ECzslk5oyL+Ke/nLdwCudIdN3/1MLfv6hdvvSel/WKHgxsNoAaBTy FbzslyhT7QeWqV3BMmFoMbOUxUutV5ay8iKmDqSRbuCVzpDpH5Wg6eEOWeKaks6TOfD5b36Frhsz wjLe7gb4pRoW5nRzhd4iztfNt8aoRtOeC7ekYR9I3q4v0kbT9RWyOEbO5/2HfrnYOcW69RXWwqju Ed/L6/Yvr8Y9L0nrSRp98Qfv0vdPk8neys54Jh5BYzfOvLimNeOy0oP22u7NOjr6IWJqNOwSRo1R xrRra/RN3cL/Dvafwy6sDFyTZjzJawF5XSYw/TX2cPzbUxgUmSmh3+u4Onn+wXaRVr35kYdGB+Ce XO8QLqnHkU7tF445/0cyB3utYddODn09XuXCM2ns6knn3S1lmqaeF/EOGtfNeF1nkzn9/Aa8N3ke hZa1yxq+iSm1zdsX+uYLbo7e4XuGbZJf+I2NkviNjZhtlTQcZ5D3Ks/JmjfGSTwvGqsjepdSu375 wntk5LYYjp05891BKj/7gTo2eQk28QlLX38sfcMybVfL2rRa1iaNZEijFm1WMLASay6DNeGyx8Qn aay0nNf0c5nEF416A/Cyf7bBcdXoiPKFzUtOAx3Ea550mcQXjXQAr3RLncOrY6dXVM7wlpf/Sjwv GuQ2rtzY28Dv3I35YrNMPQZyZs+DqzEd211NTgOvqI7AW1e9WOPynHQAr3SDTL7BmJcwdHD9Tbcx Lp2zPq6rP3IdYLt0g08cXzTw4dU3LcWt0L+9o84yDKFyO4n3U0OjzRV7aOr01ots7exY/cInacwr DG0ob51z4expGKRWntsrPedjXuasdxxwfy57NtfAiUfW8Q+8+i0Lo2/h6bmAbmd7jrNMqK3H8zfc 0iOnl/CUzimhvI7eAdZSA9ekGU/yIreWfdipWd9O9fmonQ5/tH4NrJltxQkWrYPgrIZW+GucYbQ1 kcQXjZ1Qd95SUibwjHUA4dBCgcp7SP2tPAr3nh3EDdDqfMGZlBaySgmOwpOCX9KkaDYLSRxNwrpS Y9UiME5QigYnGmtqq9OHwjtpdJsDePtMmX61w0pc8mQkdRMvdb4si9myc3x9aOczPls+93WRU3Nd 5FTNzu3cV811EWLOHY/28+O8Wc05sq52E8456Gm5LuI3WEBmz3URx9Ch56qDX35BnfuFfe3LOb4+ tPN1kTNyXYQniKXfyHWRM3KOfMa9LnJWjXWRo7UtWz04vkJjGq5cFznXKo4uJSHNzpWHo7oOmWoD tlIR+KLBSbyd6yLnWnnKKwdwNuyJdZGhO94OzonVWBcZ2vhluY0nV2cSXzQWyMt57dIjlwn8RJmP uECFOZft6wiS+tt5VqyLDF1AQZ32hU9LvU+siwT9wWnk+KIljHUR0aA8x3Mu/c6TePekWVHmL95e PwevQ3CteY80uUuNlSGdIdZzzRtXtGLvl3ov0Ttq39VhJLEavWP3KxosVovWJxFfyfFFY+3eeUtJ mcDsu9HHdN/7rJxb9I7d3y7MgzuC0Dt2zf4hS6sCGbcpOM7FcbKfZrgYcoyoEeaReqKfGdVbhMUn 2VnW2hVkfYIwy4I0LC999YPHubvI8Qia9kQfNbTLFzKbtLO8HJsOTmO6tSdLVzuZQv/oZ8Dx9aGd +pnRvOabHiV1bSXrZfM+tPtz9TOjtehngL01ttZTw5atsWWvOFqfSTOyJbdR0tIR/Uzii8ZOv7ae dbplTz7auFt4mzP6mbazn2l7pdSd/Yx/gYYW59JuZz/jvLBmZz/T5uVH32vLnFf2M365AXl6f6Kf 6VrJNJ16z36mj3jvKIIUpTo9InPN7Gf6zH6m+7sCoTWzn+kj+5nes072nmXeW/YzsauQmq4a9nhL xPN9UupJLw19CeWVX4/uOzNcfDcg1gk9xfC3FL+cpRMzpfdIoWSl4PIv3Pplh6mCpN/M5rY/iv15 c5gNWhUWArh6YzDVIsXwtxTdNYXrlz1sjkn1FEpWyqfSQdJvZlP6j2K/K13ttpXedYGI4aEoJ4if FymGv6WwbHu/r7Ll5S9KgeT1zdMf9+AGOZhHG38W+0NpXIW5e16LufWBlP8WPpQLe+DDjZsFlHKE f/Kc4dLI4dhpPo35cT9nZvf9ts+te/m+G8P7O2mMsH/txb+lyFy7pPSGXWRKqXWmah88SKE0cjh2 mg9j8iLRn9n5paRfl7p/NKbiqNvmRgrD6/hnaKRg6MA463Ebvb1XPMWiAWdK5UGzlLb3LW0dpiA6 +5/ygTTd70DJiuftNJ8OsO3bzhpK0QFXyofy3x1gJ+E29pHYsMbDLds4/g9Phfn09Bq0vADCZC3F MHXMp07r+Atct4R86hLCTMsMl0x+5vujkTW8U/hGwk3iXSfvaqt/TfF/ntIUKJw8g3EHIHn4OCP+ eUry+L8v8X9Ku1NcWjbNHxehO/N3QxHTldbgNlc3Zj1/ee5/9Nzlgp52QKSrFH/0POj9zxdZP+Rc z3+Y9v362b8ZxoE1DMDdtG7AHn957n/03OWCngZApCsUf/Tc6ePPF1k/5FzPfxj2/e7dvxlW7dPR qPiYic41L7m39au/pPg/T3n8rjDwNLydKblVT9nfUpLH/32J/1PaneLSvr01eN/zpyo/DLVXorc0 m4BkS+vrbynxz1Oi1YBHLQ2Sow3GP08Jnvj3Jf5PaXfKzzY4nmyDH6r8MHRenc386FJm/WvK1dnM j85mXp3N/Ohs5v6WkjxXZzPrD2l3yk9D59XZzH/qbIrtW5Q5jB3m5uCOz7+ktGiYxC6dPDSHkl21 /OcpyTOjGZL/U9qd8sPQnzc5/83Q9x1bvCVizBAtsdkO77+k+D9P8YZBHrZESvZWlf88JXji35f4 P6XdKT/a6I872f/aRottZXona/zCtB/GRiwD8TDtc7SdLgL6t52biaeMwxno4C55w/15Z8Gg7BYl CfxA/7b17K6nw3aggnIgAij5iREipyn+Yur3bytj+47QH5axfTQFRunbv6ZoV58ptqHEUxBp4fEd /7aJCf++HAdPy3zm811a8Dwf0p7PFMUWDa31hRM4vrXYhSKudT0Xz1wntbaLYzKlZMrYHzywlKvL 9IevfDGFB1GD6tZ6pz36XrXC6qQJjsjfVox1XtQ+7ga+7c/2h6x3udTQ8A6TwXDeRyF1BOthCgu2 /nnwWpqF8H24acd2UI8HF2bX7qhVon8zSCWfItC6fW4QmrjaHNiaICntYBb5Db3plS/7ypNSpAQS P3HFiaSHoSRTP1Rl3InBsMcFd2t4SGP+K1wy+UxpJ1OI/cNKm837HuLkmZlPaz+liefjXvv4Fyn+ MY1ac/MJcYYcnqk1w0EqpT87teaCrEvrV0q5eagbj6fQH77mgJRHAT/PR0q7dGuhW3r6PxfNZafy R+mvCDEa+LY/q7Jl3XUeO1Siufty3kchlSuFRp2/DCgYt4urF8Cz+PjITtUNzI+Ip5/uYGwxxHUV 1ipxvujtjEzhnV3K4m8LKwz5NHnc0XBRgI6KcICPDtZxA7+2vDI0Fjb/EZf6/QWMXZS+fr+F/zx/ Q8SivXwC1Hde6YsrRbkEA+znRxDZid+AhbWv5lq/mbgLr6bY9pcJJIP+sAiAYwFp4RgNiwB46Li4 AhPxflni/V2BcS0gzf0Py0SMF8M+W9iju9v2knZ4BSCxvo8wrs7hFVjE4/vQYIzpLwmJ1avgR386 bftr4Vbtha332AmJ45B2/nvhIOGL3v5uLR1hKHaBYbdFDaGB/ha42Vl3UNq4i/yGbOiwup7i1QtK IPET22ll28fTy8auU+mH/tT21+JY0JdwfCSYOBaUL79e462ze6QsBEyJFIS9OX9KeWqkhGSmrPkt xTWwfSXdToh8OeZGd+bChe+g+WwxMMXicnxdJkLoXpfy+zZrXCkfBv8oYgtsX3RRub2ycuG42Hni wsgMQcWUmTxBxZSWPEHFlOfiaTePfeYLnufmweloLV0H1bdOuCXJh/r2BSN4Z/uHZW/YxvNWFNH6 ujzAS9GTKj0gnqBKD4gnqNIDztNuHtjmPM/NA80bvxYE1R88IJIP9eEB551Xwg8PWBfmmlkNSw/Y GNQ1Cyqm9OQJqhidOk9QsVbui6fcPLbHznmCKkb1bkVQfXoAW8tF8qm+jRyDufe/u6CWVK3aoaug rCVVSyqm1OQpt2rVXoHBU28e2yHjPEHFlJY8QcWUGvYl1beX2hlB8qE+zhQFc/0HF6CG98JoO7hU NXoTq+G9cmdKUEU7cJ6ginbgPEEV7SB42s1jNTx4npuHZzPZnwXVz3bgJB/qY6eH8872977wdVyP 17oVQX7aMc/hJf91UdG/5+JxKqbM4EmqKBPxJBVTnoun3Ty2+VujhqT6rARWB31g8aF+WSeZQ9Af XYBDxZUDCxwddme1B2+qzlvFnQrO4b9FHqdKHh5YTarkaS152vPBM1fwND8ICH0YtDKpPoc2DyM4 lD+oj3PQq0ZK238ZdTXGp+VXFMaD9Q89to+JA9+kQoqF1wgep2JKT56gYkpJnqBCCtZunKfcPDb+ gj5fF9WnC3pLkk/1bQ9NMM8r5WdDaDnARnX3MTIPkDOUfVKx6l6D8qBiSg+epGJKCZ6kyuruPOXm 2av7+D2pvjWEHiSf6nOU5Myr/33wX+zeUU2U+Nl8aleK4cFTD0ETioHqSyniIJU4enA7B+drxB7z GQ3Wc//Mxdz0oVfmj9jQHGLa0Q1EdC7b40rzbJChf5tLlRv2BpVh5EQLixfAdsqQlDZLIL8hG8xb NBc8haaglM7gJ7Y9CRuTzGb8rt+/PwqLa4AyqN+mYsChlHBIOq77MafLcT9nMLZ5oPFwLpakmh/w in9frDCRkv+UUptuJM9/X5dkSxm//v+9yPWaUdscPjaqig/B59tX0eyfIouBquvGRozYI+WtHlXR OKadRFA0C2FFQzIanr4AryJw2EGFyrh/xWaJiUfS2B5q512XzHXlBRrpYLypKWzoJW3wPW60QSnQ r116t3HhkjbUHTYoYhtsUDwx2BB4JA30E++6ZK4rL9BIB/BK0/4WXbFdA7XxjKgdMqmcYxU7FFsV vdKmncK//zXBZXoyFpP8flUHxIXC+SjEi7Ld74rJjV3x2nO07GRSG4l1XhQ0lfuswMubCilT+3x3 8XNc1Rb3A+OklGjOTF6clKJM26LpeRFLB9BIN/BKZ8jsNfO6cdPmFVvj1K55Yd5/aus8devMKvb7 a7/sxrkseWVc+KKBJ+blLckE5g2MtGD4uWukHO5EA9b+UuS8L9/5c9DsxOeiYdxmWqBz2hu7/uWX cuGZNDj1di5fUyax8gKNdDgrdcPptu1LasZxFLHFrDntuew8vI+UVP3cKe0kT8QIs3NXZ56ok9w9 LaqV+vp6Empce57lHM13GduqE2/mAHd7tMsTkk6PsjvaFYrcZLnVYt8/bV4+inUDzwpbjXMa86zz Wg2VTGrKvAyHDhZn2nWz3S6us32pevwGYGqNoa64y7xTFOntfKRsk8DP8+RpHzz9ktZnlmCzq5K+ nMpvQuA/ftKnP7UrGn6W7fC/dtnavVq+W3rvxLBLNLDX/bZDJrXAarPjEzQla3BjvBDKZLwQ5sV4 ZtTBsenmNKaz866SMteV1wodfjtHW2F9adGyW6nnwpdUnZsHr/bzQgth+35ZtLd3X/RWbsX7TbNS O2n3ynxhpfeDhbqFV1p6VPTwYsk+NPQEjfIFb7nbUpnZlnRXNC2b2ZbKfBKPbG/FIw4abz9pfb/K pl9lJoyy7Jc1/Sr7UdMCxfN7Lh1AM7Mtuc6QOaMtWcq6LNuXBfvy1/bofPjndf/FtbTLSxXncClL kQjhgdpTblWZEJek0SkA8OocDGSqfDZoWnjJsVnkNGap854dMqG18hLOeuG6gbdfMvUNQpqO7D0Y 51t4lZtqP0m1rx6/MWYU+6VMsfpd+a0EPB4zynnOlXLulHaltGxzjCyl54oy1TGqecdsrS2+QcYi Ni67ubKp1IcNoHViwG7PbDoxQLyTRv0dePWegEz2U3ZjSeKaNBN5Zf1vayfW+ZsJbd/q1jq3xgLH 8B+p74uwdd7RAUs9crT+MYVUSuHI7rFTwPyKZ7HWXqyoMjjFq93qON87L/wkjaL2gXdpV7rJXHGy ok69mUu78E6ad4AavLW5zGoRpZWX45k08hl4zyVTPkZeN/boaxbxui6dsgD2sxR2RtXPT2w/uYsI dnWpXT2P49fioKEnlp9lG3EimVhv7xr4t//T2bkjDF0Nt5p49JtjtuTYt6zNj+JI2Xp3geP4cgek KYZPAYefOwFP51u9Crv22nT9ZESF4GAkBOKrtH1USxwnPmJEbH52+hKREBDdL3AtSVOvETS0UK9N XJJG5+0Qy0FvmoKIDbcH904PHo/2zX+1hQdObXdKuXhanMnBOLVGyzmX147eSnXcY1lrF2c/yaGz fBgTrqwxumOOWBE3QKNoMuCdNdra8dMjRqPTI+bZwDtpzLPOa147M+vK8diMoYNo1kzedclU20Re N44Vnr3Se8DnucrinMf92h6/x5f/uIfnYASos6N227Hf82S3qTw1rG5PCasT76SxO5SdtzaXCS3a U3fi1pKmzeRtl8z+ZF69pg790q0/qXOLUpZM2dhaYt+PRA5+USDH3Enl5W947JQ6euY2Smoxogdr z2ip6YioTu1Rqyk2nlXLsvtvHrVcWKnWZ/vwH7VieGWV9Na8vJh1SnqKZvTkjTmuaVqeaEcabcuy c1l/RuJ9+dTfTGa9n+czC/ZVNnqDwxrHO2mg0b7Kfs+0YJ/EZySNzoPWa4ZQNm25LNPNZxgjlnhz NEXwPTmqpmWK+EtcLxpF9wKvR+IymU2toF14Jk3BaD6t4R4V4VgKxz+dJUXO86N0zlU650mddKoO HDtLp2S/9uIsnbKydMrK0ikrW1TgnTTwcPZHkimtV5ZOyTiz0k2855KZh8leDn5LI3d90jNxKIxU 3HbOlPqRoujl5Uphu6ptJE//4NH5Roytde7WvFPzDGBTBHJ4x2Oqm3cC76QxC53XLK+zpR35rmz1 aq0137NNkWwpc2U/WnfWpsDVaaTzireTZMpGRRc+oUNYr6juZRKHFufS7mT/UU/2K+1JmqZ1EOPl 3T6UyTkB8/L5gf7VEyXS6keKIuoBt5wh4EwpZgJfjvP8ePOIyMQ6B7p9ZI/znkFvcyfdbMNcHO+c FTwlZxHm5+an8mvOOkCz893SvCxi5uCzhefkbMHwPVugPj4nMH/EbIH/FKECVNdsAWfL30JQlFJb 2VEcNvSfRWfOH3+bCz89adS3V1tBOxGDouo6Fgu5UI/6+bYT95Y0fSRv3ylzXHmNSwfQSLc+Uufe aIvy+oZ9NNLwdmaLBW4R67RpR7FF1GiPRn8t1stw+j7xRQNPiBcekkxgRUQYgX97ylB8c6y7dfeX 3trCiskGjTSKhKZOb7apR+7lwiNp4K91+VQjUOKWNBqB2La7R2ec7XPTE6e5wcH4MtC6PHcK18uU 0jKPiIPy5FtyBP6tWljmjlpYPLYs1p56cisCa431INGM6rVQ60eSqRPcrfgaEz3muLek6SN5+06Z 48prXDqARrqBd14yfc87NeXeIXKvyy/HvWclWhV3BthrrvXOmpG2WBlCtHutBrFOBq4XTUne+qRM 4KtV1ZgzMeceuvp2v3JKZWl9CVe/9ol0vDuJkke7LK+a3YJqZTl65HS2Lt11YhOaVj99ohTYrh6i Pf7ecDzCP7oTDry6Ew7l3by3KBceSWNl6bzjkjmuvIzGdejjQ1Oj4tZO2BB7IKmHUqCfRwEC1Uqs +A2gUfwG8Lassx6/ATY4HkkDG1qWq8scV16gqVlnXdMe74LGmJR2zCbegeX4u0j4XN8ZoSffS9L5 471kYxB/+4xrFUv/PHLS/vZesgBc73CIH9HtYzZ3i7/YYv8x5qt9dlcEQsc9adjfkVdxZCGTfast lXjsw1124lqTpmbcRAsGGjLbk3kRn6RRPFrw7kumx6Pd37BHULTlnjoYKwV4Km7s2+yqYirvUiNK oYUrU5RC7GNIfNOU4IWHJJPeYrQcWuAR/eCjWeX3QRxSFREVUnl4gVLblUO7aHpJXr4dKVPRWm0N yXEpSQPrOd+GdooWTewxlfkPX66U87pTFjdgMOWyNGL2Wvzf9x/DRhj2lTzyKKohZbGF8XlJWRHx D15bPb2mGO2wXLHb4RFFz6Ok0S580TBaD3lnek2RAOE1x6UkDVYDZ3qN64/C3ur4b6XXlvdi+Kc1 R1BFFF6mPMkTq4b8x3No0H176Q//8s46uxXFGJFYhW3E6DR1Jy/yVk0gvmgUSxe8o6XM0TMvYegg Guh2+V4yQ3+Voji+PrTz8lVcPfQoHgUXchl9hrLYSwrXpJkneqOt3gUyvQcCTYtewTFWPr1nGskL X0hmy/ixwtljefRgrpP2lLk/SvD0LHWPEIaUw3c+2kekwMs6rQeeUz54cpdXjRi//Ndiu1Q9425t h5vpSOXb7JhyrpST/f65LD73VtL3dR2aAV8pOo3AdceSmjWLOxYpfkOClVBTnEArufZwnmYliktV /uMcfBcQz500XtI9xtmUyRGklXp71GKxdiWMmcWMkgveulMmtJ47sd5HoFF8dK51XTL3hzcUBx2a nktTxQaHpooZDk1PSU2FIfXUzO1cWpxL0xN1VXMG0ii+4s51LMrUXWXISzMG6OD4WUnz9OR9Sshc XHmMdi4d3PqiaO2YPdSWWtS0QCt01LrVC1807SSv9lFCZm+pRW93zitqtNbD9HxcOYy7RpdzcZyP FJ7wA66xCRVj6pJ1Pfaww29Vbc38poM+8JtuPiTHSL/VfH813aBI3p41uvasJ7VnjXaMeUnPeuK8 mMfkeyryAh5ZT6QbeWfWkxpbcqHFaWnZuSzbJ63hGo9wtmete5F3ZS2rimQPy1a2AMfQYmX9qVc7 dJntybxazH5Es7P+1KtVxX2A9hpujavpxBrble5fv9EjayyPcWHTvdf2Rkt805TghSckk/jJetii TkFSy5qjmQY5Wpbax2rb2vou/uV46x3cYqXLPmfm88dXxhyvpDmi6bEKt058U3+1ei7cgoaanydK VDKFLxqvDT10o8+uVTh6XbMdloBmO5i1LFvtWoyCbpdrvJheqvY1mX2UHQKquhNCuCUNIwqCd3J1 DDI1grWLP15Mmb1deCUNooaLF9GVJXNceY1LB9BIN0RgLilTo13k9YF9HXZ1fD/n2BCYozgLsF11 O5ENn19Mqc1y1uiLo1TietHAE+KFhyQTmHMBWhDjUEgaPf3O1StycDxNjhhb4N+K45jvOPg66o9d qZ6yS/JvP5ptqsaYGLi4R3xs+uU8GudzRJn+376GAu11nADaa8RHjnmSwyMY8x+jmZAq3m1Yb8W6 OGWdusOnitkLDsXsJVbJgsZrLEZ/JWrgUW2xGnj0hsUaruOVNIgL7TWqpcxx5TUuHUDj5fqkzpBZ b79y36i420cKVw+ZMrO+HK7u8bl/tUHtPDo5CByj3oFdpFH62E8ZuTTdEk4qr61YIZ0uGWO9kVQe PXVhdVop7cRIzjzaFKea3BoTEM+be7NnwQqjWnJ/ErcV31ohVXFvKcl7E+CWOatXhUbqbXt8L8UR 4MBc/Y2eJXjHJXNceY2WOozQ031ZdOCYuHgN1A5JtIpWygqpxU9dwoaiM8fA9WrVrbQsvTI+clQb G8LRYrTXD7VeIyzpsqOffvG88JM0mgmAdw1vMfq+qZJQmaLkHK+k4crwSK+ty+79XHgmzT7Jey6Z J2w+XA3+kqa1PmGBAk4IpzVVI+YaI0paE7jH6jEsc3qre9X7glxtXr1kvr3FijTqlVaqF9eaW1jm 9OPSc1x6guYZyeujFObMUQqxv2lyHEtNR0lrRo365rheNPBKz3rgMoFbTe3aXaPqzhqlWMWUtC5J a174KoOZNUp3ilPmzBoVR/TbhVfSwC/ihb9m1ijPa1w6gGZljXKdIXPfrYj3WYv7pP3xbRZU+gLL lPKRoj68f6RYqTR+lSPPxziylBxHPjvHgtd4TphlAxpZgLGxLLORu1ayF745O95Jg1HsjjdfyCSe F81J3hNjuxib1nbhJ2mgg3jxfVsyicdFU5LXa037Nh5FzdZ4FPhjPIpTQZP97MTdNXzj2iU0L4YP cUpqsrUKl6Tx81zG++RJo3md7ZqKqTR3YrspxGnWSN6VNwDNdeW1Lh1AI93AWy+ZtWdeN46T/3Nw PfrLMWeXOAE1uQI4cU/OkCdO3MMzca+O45umJC881PPEnNa+aYGP6JjC0SW52fqYw+ypBVvrxK06 wnYWxWngC/Gu4zf3OL5o1k7eXVLmbpnXvqzcVxmLt18ye+T1++L4+tDut+vB/gA8q9QrZfG+KqZc floRkwy3yLDVE3uAJfKsPH+4Ls24g1bPx33ab0mXkfewQHvdEwo/rJ0+d4z7gXb603nX8f22ji8a rmlN3h1TQ+Z+0ueOx0ga6Cbefsnskdfvi+PrQzv37C7p85hHoGVufnFFi+XhY+a4R+a4x7zwkzQ9 W7tWyClTcdZm8bN1bHWOV02albuN4SWXua681qUDaKQbeOclc97tafOwLbnXnXLcT8Jh286S2zs8 W2KNeuKsl69Ro484Gf6tHo9+Tsnc280c57rz550IpPIRu3lOZ9PgUZ3zQv7tSS11LkySVBdGnE1j afB8GUvjqG7OOJvG0nC8atKYR5137ZS5rrzWpcPaqdsaqfOqv+Jsmqxp01ua73ulNfVcuKXFXG0i L+eA9JDjE/t1zLKgn9gXrDo3uFKvlhb5TtPaT9KWX74nlxa0mZZlHxR6rktP0JSTvP59jznzFlni EWeBfXWemqrfHjm/s5ac+KYpyQtvjZ3YW1Dg356y4uS2zuoJ75E27MuGE+3J52j01xnp6zOyPETD +V1NTfdVrsqrhw5qI1gxVxvxPbB8/kQbO1yh/3Jcr5aMfTluXenrTmkzJY915zmvFN9Xwn9Hviq+ 14Y+KSdGGq0+0Sf5vEb4osnT5dgf4/VMcxPkFWEL+a9mKdWapVQ9ugJqUR0lalT1UQFW5XfUKI3V UaO05owaFfimKcnbc+5APEpq4V+4mLJL6rov7pN6t6u/inE+/+lc+soVZfip1exRWs12p50oxO2i aT15W0QF8LVl5nXPCVBbGXAFJ+F97Zf4HiPDpxojA99jZJ4JZjwEntlt2ouM5x54Gmesu3Z+74h6 wDPZ3U+fAuvsXvEoBuRtulPbzkzE84hugBNzimjAc9su/yhf4HnhiHpAraWDcNJ4XsbbzrqtaTut aTMt0Fkl4BqnVRXbQLx+WnVdzxHnYKY1OnlxLvmne5wDWeN4Bw0taHki3XU4O/MCr1Z9dPKvWYwE 7n+1tb4m/yEugm4Gt7G+Y3t7Oo2N1Jr8OiGHOSJqgs6M2SUhTbnbSLX52c164ZE0C/EYdCJW8RsS 96QpGWHAdYPM52RejtelP2ysl84jbamXjdIBtks3xooQ7hdNSz3dn96KWO6+O35f8ST+GKBnlNm8 LDJMvO1b9gDyQcXdYOvicSqm9OBJKu1KDJ6k4teqffGUm8eOo3mM06AKKyJAj8ey/1AfAXqCefV/ CJAK40ZNGWPcLlCM9KBKFziPU6ULFG48qNIFo6YLggfGOU+5eaD5GOmCnxHX4QKSfKpPFzjzulK2 1RGGMzCuF8045ut/vv7V7etaJOQ/pXwkpKQWX11waVTXY0CQ2+E+JYA1UoyjN4Y5OZMwOJQAjkgp OKabWYdKh2cUUtdbq1qxlds4alVMU3AoARyRYhyFccyMo3iwMnAoARyR0mxizI/9gJ43/syOQMTE 4XS7nZMcgB/PxUEcdthrURsKDH48FwdxpFgkQM3Rz0vim9v9z2uF7WiNhPynlLJ6JqQkf3zY7/wa HjBl/BrH7197Ibu/EdAqzjtoFHm3aajou10FI6puoU+CAyHMdlckYUKcQjGooxgv9HvRDK6AMwn8 +I1HAqYwHrKxaPKC9QkCi1XIfVtmQucEmlANsutuI9aHvly7bhNvqdd3C/1gpRQUnhcNVBTvIg1k QrNunykTn6SZoSc8J0WFo4t6W83mZBeQ73VbuuQF7oQ8zWbbGxTSx3Y9iLbF3US2aSTgDgJbFWZE NHNS2wyGAMh3Hwg4DLKRsM5M2zbnrUB7cIr0FIZsGCxNhRsdMUPXbl9lg341V7HbHe2B904a2+RA heEsaSxcRtI8dPQJpbvtzwutK+5L5re/I2gOW/6dGzBtxNH1Pd1G0Xe7b14MxM5hQssaunORgY9Z TEWn599ff2oxjpdiTBjsScAT0m+RFi7KWZEWaWjdl8MdBBaDTWwjhY3MYvTI2ELFSZ1uWWjFFyZK e+HavOjEgCKN52O6eOF+0ahNzTACRV3CbSfx3klzWvKeS+a58jotdTgldduXNdbFraJTm7+WTiSs X8tvmvw1/ZzZr+lxiX5NnvF7C2wurw9CPVJfTcUxXArRUuri+buXg7tBrMy4F8TkCdVIfXMTx2uH pAB114W51dAgtPrNvpmGonOipSg/mgpIWSCgMHRYlIbynStqs8O9g+B1uLOdFAa4nIAmgI12oYxp LOQ6nEkwa7C9dcaFAfbQTBnPVCeUfM1vWJC3mTNiiXMLHJ9qmIYBCcPNEmrOCqLJULzgnY11kM+1 0w8ss+HqAGHtHcFWyYoNIvgSXbEORogNd83ewPyKiKUVHvZExJ06STtqwJ4E2I9ENtsIJGHWNelp 60HL/U2ELaDt5BYBDj2QDSc1RsDqdlgmsiPyk33wgwyUT4TRdmHibG7YdO/AyNlWcSsD94vmtTN4 MeKSTKve/rz1pK8n5dSWuKykKT15ob9kui1hcViWOeOc0VB1wnGiqvODtv9FV5JWdyKhH1W0aVyc Qqp+CGnIyzj9V/344g6I6zdJYMHw/O7ZHcJ2ZrEzY378C7aZwuJm9jfr1z/dDZGvoKj8A/1nS7Nm 85vPjcbPb8JTy82Zfi6qd/cnDAo8V9Kslrxrp8x95bUvHUAj3VZLnSFTI1lsoUJltX1mdB4Q3hlr 4yAQUFW9X8sbw8IHTtDZZJ2oD09t3lqxtY5SWkhu2WIMq/pY1rKdEMNHU0NWmR4yyhRRPTVNZJ6p 4rCPIGjRrhabwCMlPIt2VehuOxYHZ1TT4nPj40S3D/m8Qbrbh8KOIWa3T+4OEUGXBDZoFdugsIDT CQa7cGMbfOeaMM6HkYXDZzmBqSM2KjkTqh926q9bITdqTDdqYBX7pba7fKmH3bPjcAYB5uip0iSB 3Q60wgE8LNZtAwjPmdEowZEEZvWa4Yu5Ao50izIeqY4J40AWWThMAlNnPKHkOKH6esIgZVxSHTOe EC5Z6U1q5j6TA9/6hJN/3XYPzR1q8uwWlOcHbJg009ApLYxADjS2SVoThhk4rJs+TTedF8KAwwEr Kw53uUKyhgGAqi1GUI/7belbIcU1qj9mPjezFusFnru5oF9Jf1ixX8esTelv+S/V/EXagCNl8JPw JeM3y2AfPn+rK+N8dru0dDMbK46NFWKUgSbLgCUIjhrNy3aypZyqYm4JTxDUl6Bsd9ne4Ujfz8lM sOzOTFQxTTIns1bDuGMTVdDh62sneEvA2QaFOVxJsKKIjvoME7Z3ZCFoGe+02atrCHN9o/EfnAe7 FNLz8qgy4T5rLjkYc+GRIyhY/PiR/nH6Qqr9JIdvcbU1blxo17D01u1bbNPKW9OpZhsWAPptOwdx 2wef42q79zmfYiTb7Fjx/VSH+duZuBTPMyKJC0RM13ZwTxB89CDgfyW0O65PwHkLxGCUUHsvKRCH z0ivXbgNt8DzDkPASXXXDDixbklofccgtF5tB4T3SIAxSsPN8aiskQXgDmjdE2szbl9vYRaFEbIm gkAZG5sC7DBrXrOIrLFV7c36wVNXiPcmOy2qAu54PyrfLkbmCBI9lXYlGSu2lOBDXLfJcV34mNEt cL+2/BNPvipBox60jgjV17HQ4BgbpvAZrVeM0US/cIh2EePIwiQ+me+O4wLdzrdAN8MIsEfcntSz 4Ujrk1h6gsbzPTuP+MoyfIyQxaOkxZwQVQs38vFc279pm5YMmLe3X6Zg1Zx4sxMj1U4Nd3FZCNyM z9bC7ETgm8CPb0ChL7f7tfvRTeHZkmbIr803zmRe7lfHJ47G0mfipabz0pp5kUY6gNcHL5VbYGjN XL51nxacskI7vROCnpNOhK4rmpqO4Ebe4ubzKl1rcttib+84SI1AGN1ivddVSMkQjKg5fQT+7Rx8 35KDy5PkYLdEDh2p6x0HpXFvGFP89gamcNOVeJZPuo8ONJtlGaqcOTKE+YtPYkgSDQ70sifpCINI DTsPivA5joBwcGIx4RUGsXccLREeFw22aKHzkQ1cQSBuI2mkA3ilG2SyBJiX44sGunF0Q525pklb 2O/TRukA26UbfEJMX5GGPtRKxwk9f7t2W35HcMgsabUbPt8jrdGGLso6+Jgt/KTe58ky8OcFNXMn vsrpyHc8OkK/W5j9wwFwRwgjYRxPEQ02abUsD5c5rrxAIx1wzEW6WXlE4Ep703e7hKPwNGO37bKF pwGJm0ZmuEmJS8oDlzVxndHuPC2cy3b7slc4l+021A48dtLYwqrz9kum6aC8Qh843OYmpc0Z2jVF F1B+TLEAGYXTQuXNFwu5WajEOnnFf53fyyC3+xAdspQCWRpvkKOnXO4hEA2X8MnLag39Oqs7bvJy fE7QwK/ipRaUSdzT964DeENTaMHZCzg0JcXzocEgntfUerSbe1yeHeFZ+2SoFFinSRQ5Lm+OU8MD gyN78M6nRN7TPxWgXBk5lykeA4NeUwpkaS6EPPRqJ3Y7YtFevOww4PHFRgKPOzaviQbeFC+1qCNx mUkjHcD73LVxrcsGemDa7bb69GFBTF4aDuntOpnFObXwc0ni9b+3pEjp6Y3dVbcePv9PPE/PeFyJ bpvinRt2iBt5iFvPZWtN7sP+4E09m/UfeMhb8xved4s5HOIQ+6dWqw2V+1KFW/NSq49Kx+5G4Pm2 boFxXqx+Y134onlHVsFrwzGXCczPW6ZfjT2k6Obsrkp0SV+cHns3NNGF1Qs/mo0N64a0phBdUl9X F2kTdVz2C7yS3qoDwzphdurdnM0GPd+F2wqb1kKe6C4XLgoUHqnnwr169cK+YHDpabzRddKaqVWA c3Wd1EkpJbtL2KPukljLXaA5O+zhRjJK7d7AYVFvXKUC1lIQOBzbJUxaLil4XiK3PlILdX6kafIq Ot0W3lPHCe8FPkkzRvJCU8kEVl6g8TWb43qGNWeGNUNlZdYEtlvZW/po1B0WjJp+VGdMGq35mDW+ huh5hTWOT9KYprHQeFImsPICjXQAb+tXXeANUt2OwxVf6APHuqTuS+rWuJc2THID+xge/yaCjtE6 Ho6hZ2ZNz0y1AKfXekRN7jGSG5eGeV0fye30kTc27ylvXYIEz75zsOOefXF4NvFJmjGSlxcx1cS9 JE1fyTt6yuRHWuYlDB1G1PPgLT1luv5RQu/8WGszhp/h/VDt3g8BX5qecftiTy+hl9s75161YIN3 QMtXH9d08DZonLfZy85HURYFgTM4e622FWMdh+8oxAlsB4TYegqzjEfCdo28eOUjtPB7HfFO0HPL JkZXuAI5oMZQRsD5HtieeP9zXQmvf4e2ZeaJl7/YkHWNV2OMwUZkjJsiazqxb77gsBWlBPVOcSfF afMrdV5kNBjD2s3FoS9Bucz2nDl8XhjGjrHcBYOvYEC9BY2A8wHzxuBUyrOQNxye4wSmvthMZwkD HGGfZ2xs8xoFMXgcs9YoEItOUU3GiTGcB3zDYEOMkH1iiCpGPpV2NRgPX+A2Hjix3FkZKRuLl7WU +BgjrFXfusvjy526wwtrx3V7hxSnmtBp+eSTkQ56vKrr1leJdhL3lTSYMrZYIH7lr8S+Ot2oD7BN Kx91KDjVdU3KGj9aLq6nruYrVliL1EoWlva08tUsFKTWKd5paU+cgTWwLhu8uVpHrJW451m58iUt cOkDU3wlBCuaWhMT3sxjzcTQdV+6Lq2Rmj2rJcZ4QDT8GE2bB9dfPS8tnwY+ueb2YDWGdZWacoxB vFrSSAfwbl+8niiYEXYybJyex9L31KqAFlu1KoDVVq0W+POd3P6mfBi+bfiKq681PB7u7T/xXCu+ JbnRAArXXlgavFwDNvK5j8IKVllY6Yl9wvcggDYWbssgzOcUi+f8roWnsVpsK/BktXgLmr1aiIXO ql3snlPO3y2kQufYxOJYOcSXABL0GWyjhrDBLByyWYGAMxWwjRTGARyy4PoPMh6pjghMSX0xMNUp DAYxC7ctDB1cejMthq8alTJ+cScyn6tOdIs27M+LrctTP6OeOyDfmCBgoYONZQ5xXknKOwrhxamE /j3P1JparTc4gnWOYG2/GKGScF2lrs1PRr8UpI7POVg3v/DIrJ6yMr6988fTJ12xWrhiNXfFa97a rF5v49MHRdsJo4mxxZzQsvY7V/Zvi4DylRHMy7Mu7u2XnbEkY0lGI+B7E2zsB6z2a3neKkzAEwRj BNtIYSOzGKmxse2rlmhjp5FsTTSRuT9/tdtlehXQdk9ADjVAwPcF2FpU/d3ubDhLs03yjMeIJqGt tqBe0QnsfRUR79ch9J1gRlQYcAbCeesKHp/hNK/XjjI16CNMoy8PvylTjn9UtuoWKa9VhUENkXXh gULhFu2gPPICeGs05cLjl92uQw/cZ9LYDMB5xyVzXHmBRjqA1zWlDRwlW6UvPGio56d6tf98vmd6 FSmq4U5lVVxUqMKFoQ+F19WDlKKGaJcfM4wgteXVHrSCV3gI1500TfXXeH1gSqkcNZMjUsyzDOZH j/MaC3HsLCGGiBEN35rk5azYtpTFcyuhorrXIKdHabl86Hey5BzDhpMl5zqMSwfQKC/wzqu3KpU7 YJADw7aQo6qeYCXEPWbYZ7+ws8r3wD4Z4b8dTRk4/ecp5pt6+ayurNUMdiIa95nx5guq1JG12rHZ 5zSwYqY/XOa48gLNzlodmsI37YmXllae3AZPKVjOTxtaWYlrtkzNEMnbVtjQuJAIGxybHk4zavKO S+a48gJNSRtCU9owTtowjvdHxsM9K8A+oHjFJ7Y1E66HwYb+RM/74qz3Ws+inWqxsFMdoecVdgpD 1501znnHJXNceRmN69BDz9+uNRdXgbXxC1poaxisGTUt0HzN7hdNnDToycQLP0omcN/ZHrov2FJq DvnK6OvytqdApxFvq6L9XOTOkU4Z63rvFB+/gOPstO7EmFArS/SxY6xKXX2F847hF8gLl6SZGkYa 75T3TOaU93A5e81ydpqyk7dcMkvkFdZ0tp4lnO3KUyDreuPNy0tzjsxvZbvSNjLqt9IXjmHPmmnn yjrmMseVF2iuN15qihx4RAmYlwOy7gW2DxM5KkFEKrdg5cClrJJvisWpK6xZXA2OvMKak6XjNKMm 77hkjisv0NRsecvXyFCjtZeCHON+P+g7O1OiTsLqnR7YNQaKiXEYLT2wr75xX30mv97LA+fywEkP rJ0ecAwrzmXdSQ+4zHHlZTSuQw89vU7unh7Yfnk7bVOK6aRFCtozsg/cV/3cCq6DnRINyw3Y4tJG 7N2IaWK1Y0JNe09slU/Dojo5UbTnFi71aAtIfeF0Kf0JgdwPBgItxhpbryPF9Tp8W0c+f9WyeZyy 6a5h9YkeqGdJeOnXu3bZ2PN+PT/cx2THzo42n+D8HOCuvvXXQhU4xGG8HZmfHjme2GzE1VcQqDM2 tqGdSdgCVj0LhzzjCzhjQ7ApKWGubyg/enEvDa8FthNIzyFFe3mMeoyAs0c2nOyDbbVQf7VL3Goh TtujTIZ2ZRlkMRuBPvwaGyNyQdx8LpfPEVt2ps85zHY9h5RRXTajXxG2Fdm04i5T726OVOdu7nVo Z5jq9KIQG7JusUFIWYBAGRtb6GY7znna1+qdtgWDeqeM0xJeRTQRrIfQF0ErTiPRWDv/pM1N9lRa v0P4+6nveDIpi0Ngy4gk8t7yjGzuGmW+ZpT5GlFIS5XC2Ppw7zEGLrzn0JYF+nBzV+75WiMatrIA gTI2tnUZu9ktm7FbCo32i3GYXnh+7dSNi21QyOHbbTrBK1lslt+e0e55wSvhjo5BK2lgOynsRI1h JFtmfFIdEZiSYjPVJaxHFm5bFM4p2wtH23Pw1PeCWY6H3wIMFsY7QmNJXAxX1+q4gjYRjw5BW4dB wAGDlSU/ukcuKkuHrw9EYJ4RGzTd4cVzkkAZY5L8XF3zOxHvbiRwmOYppsuLo7G+U/Rozi/eiXs0 f/vH7dnE0YYGJp+sP8MmpVy5wbnOMqIYSlE/AcyJMmnq8bIsRc0LMn1LodFoq+Guie3MpNOYD8Rr rnGZ8IDyIs6OJHQD77hkzqu+lLKO9yulrJPcu6bU7GXe6XPmUFVLDk7u31JriT7ie0o9mZLv9Rop KLvaov6VepUXT1kJR6XGv1VS7iq3XNV3yF0t5a6TsvZIfO4a1XjMgLjHNuDEts2ix8vsxfF+eqei KVVTUdLUeHf4jrPIS20msJWeaOBz8bYnZRK3i6aX5O1X110Y90ccvrmf9qjuQ7/VU+/9XHinDT5W Md6T9cNj7rAd9BpvLWDXsNfk0FYJ4X1p28vwV1fp7RqEvdPLtGOU6D00VQyqub3XL2PFVvAyZF+v 357PO/dx1agRNQopHGoy5VzjFE+Bh3wgMjGhW4lL1oRZY7DiGwwgdUav5ikhtWULmC1r8OzZ2029 tsCb70lh985cPbyj08R8rhLv9dvzdQ2hkOI+iGO+PKnO1WeUuaZZKHPf2oydbSW1WvVux9OHw6C6 +4fF073EK99bgW3/28p+Y830zprptTVG0vR4dxVtpI68vCU6RqiAnn2weGlDjv89L9LMfIfF6SVq cdWhFXUIeasOQacc1/okDdw7x+NlezQV24hceNcVNiJ77g0T0/kkluYnrSMv3yS2ihUYk26OVHu5 6LHbUJuwsduQVnfsMGS+HVPRpQ3fO0rK9qEEtrei04/Uk1gbr0GjfMHri6q0hv4ih3uSOimlpPd6 Se8Rl9gMjYtI3B7e+UWpfv8XLdLORmIeKiCH42J4pNR15Txn4rGTRtvia49dkZGXe89xz32X8Izz jkvmuPICjXTooWdYw90MwIeTE1gT+LWG9xNQ0yO/mAWnnAuXpHlGWnOyLmhUS2uEodHJcnbecckc V16gqVmPTkQAsLpwuGfatpgDB8e8JHFhm3hdRyEQUerLsY+qceDiUYp9HH+u7f2Mbclt74/P6rHJ nrfGcpP9s/MwxLOjZiCE3H8uenLbrgzntt0azj1GcvO57HtubsRdevLgBuM9UtuiY0bA+/E+oBa+ A8FbZh5wcGz68YZX6u30Zg8j96POvPK79wGeLw4T1Cdqca1PlF1gs8bpR+pJvJ+g8XyNt/joBUcX FHUK2vFGVmpd+0p8Hengfa7i5ViEmtY89uAYmooGmop3XDLHlRdoRkte3ysPv1e+N8nh7014z1Og 356pt7xhuMlLRtOe6H0VMY9SPV4lLWp1efuubdbkmFkn+aFDUkfm3MaTuNekaTO8x5iWmZd7z7F5 wGkQY6/lQRGXOa68QDNm8s77sBJvMheHf2qmPUqBfjsPvvDuVuKuelgQh/KEL/QJB1LjM0mkuFRt 1aOkml7qLVu09nOQt2ffQOxW9JN1ILbpwZueAllXufd9WbHy+E73lmi8aq0N8VXirRvYvOk05mXn HZfMceUFmpMtLjRFPR4ck+Iwz1BLMY5Ro3etOk4qvC8PaPxO7CN7ytXanPVLOm/P57SiYVvq/dwX ySiLn++Yo3++g3dmyf54lixJrRGS+2RJ6jQqeMfu4VmtP8KzjvtKGvjgZF/mMseVF24XKDGe0e21 jCnYcBPxw7PDT9Nh/t/38/4wvDat8z82ZLxDCvofc+a4no98btDlB9FXkvwj/fV8jj+GMmS4Q6ef 4+N5RPRzI2Vv8SvuIjdl/F8mFF73h+wyZSfL/mAJsu8pqYwrdvwDyJ0N8H+RcucD/EeeT6X/zrOf b1r/MZ8/2HN0yPyxd9S+NWAK8H+TEvpIt/8mZV/S9i0t9XHdZu9Xyuzdq32k5D9V/EyJf6r6mRI2 uD2REnQ/Uv7OE9a5pf9Fyr6k7Vvabam39f/LB0mXncIffKCe4P/0W0j4wfN3aX/3ddBlB3R79PJ1 pvy9FELCD56/S5uXtPlDA5f2mfJ3nn3ls3/k49I+Up5f/+9f//Ov/wV3BFxcZW5kc3RyZWFtCmVu ZG9iago2IDAgb2JqCjQwMDQ4CmVuZG9iagoxMiAwIG9iago8PC9MZW5ndGggMTMgMCBSL0ZpbHRl ciAvRmxhdGVEZWNvZGU+PgpzdHJlYW0KeJzMvUuuLknOHDjPVeRYA7W/HysQ0EPlEgotNRp5B60G JGj3HTQzkn5u/TUvJPJc+yJIOkmne/jb/98/y3+u7c9i/zn4x68//o//uv/87//fH/VP++9//Pc/ 7PGspfy51vfnf/xff/y3//TH+fN/fQT/p4j+63/5Z6K//lig+X++/+3lR1Nnb3+2se+fvz7cjuH1 59+Gt+GaeA1io5kXGLxzEs8HX8MbeJSkH0a/GvEy+Z14Z7rDePcBntIN+CReNelXTz2BpSdo5sML 3f7ylG+FxYZnUcrjw7WGprP2sGZWWdYfXJLGvOK85i2XCc/dRzvgv+S7OUv43VQJ7vFI6un32dLv s63we2DTtKXfnR7W9B5+nyP97uma3+dIv5tu7jvH5lOnN2tcT+Cefvd0wQvd/nJrvhz/5RzI/Xiz mCPAJ/Lqy5PVlVeGxw6L1mxh6ZpMvW/DmVeBHxrzpPNaai4TuKdFxKHFSM1XxtLntbUW9TN8dng5 sOl6Zup6RuTWOiXxfmh2i5hc60QOWVqeQ4FP0pj3nReaSibwyVx0HcALPT0f1j1p5z0erV/au5d4 Yzh9429M8634A0fLErTrCet2HWHd9hJnNOWGdYFP0pjmzgstJBNYaYFGOoA3NIUWTy7uSY5tGinC tz1XhH+uA33i+kpav0v664/7Va/Fq9bxhcmfvXx/fv0x+lcKgP92fAtxN3yJy5+9lgb8Wflh0n91 SeKkaXcHb7sjZLavjonn5yT96SGn7f3gmjRfHAUv9JdMt8XMVGq07EnZ3nxx3us8YbPh5NEbajWl lXHA5cL9pOa9hXUVFcnnAbMCmf3hk7jupDGvipdaUCbxeGhmS94fmraSmjb5CdrdR9PzaLozH+pe mVd8Tq3Pk5/K85LykeeWrmvk2DR1GlhwV+KTNJ4WrNmsdplyaws5ArxqRE/gLwLaTGvaTIu/b9aD a9L0GRa3llY2z6eTGNaIBtb0tEYyhR+aOZN3VeWNxaE5yuOrozrwXNMb6NfLCb17yVgzwrBBOQgb Tksb9pM7j1edBvqdjCnJpEYlafqTm6mpaTHKTE2fMtxvDy36raGFY0gSDVLwumNRZuA6gmbUtGC0 GTK/1CMtYeggGugmXupcR+IyX2vGihwZY3mO7HhDWU9UDUUecdZVY8+ITjYDJXWfJ715bqRnOCNA byBrntR37oyG+aQ31wi750x/zJl+mk8kOo35VbzUYmU+zP3QUAfyhqamxSpZS65yHp+tp+5ZNeub 1TKK2TgRTd/hs9VTD2IvNbsyJ6yG3zVr+C2pX7v85/O6Hm3tjWtLqpC78wu39/uF0BvouFfG0V6Z L3tmrO2R5YAfXubFHlkOHJs/nab14KUWM8vBXlkOpAN5XVOmcEfUj8dLwn5wNZyanicnzpNDp2Qd ekp+u/bNb9dWXQFrbkaH05imp+S365QsBUqLNC2/XdTT8+qcGjliOHNEb6jfztJ4ntw5KyPrzKzj z8g6/oys4x1Dj6f+Pk8uSKbwQ7OzZKWmFlX3aUPcH1/m+7Qh7hNJ97Hh7syHe7KE35M23NvCBsem h9OYfuKlFk9tdB8bpAN555MPo+R3ahSW1/4V1VFUB3/h+9FQ0likT1xfSeP8Jkl+GrVF6QP+2/GY ruGoMzT8sMpA/fCKL96HI7oTl6D5Gr/BazWIy6QOTCv0Sb3rjbz6cJSHUc/KlE+Uh8DQ9Ky04La0 7EY+jFZ20LQaefjhEzJbq5GWMHQQDXQTL3SWzNA/rWmddWAdxJHySO3aeLSbj3Yr2vVocD9Sd5TW 982n1dccwpuvZw3sMdNlkcVJl6VfwftwT1wyltp9vi4u1eo052Zq5CYuw+s9cZO3eZmB1BKR5Pjr wQRNi5Q/nDKJpWl7LDBeWmmafv2x8WULNP0qkjGqYuzzxSiMw23PXVOjL8rpmvirMJ3ma8kFb+8r ZH7tGqaVpWr0+NoBZ26NdSIG4g1ia8zMx7FfafOLrl+OFV1WhiZ1tL7YGE9Ujx9RN25hGYKkp581 ZvYtgaOO9DfIy7lKxPOcI/HIEm+9ci8XHMihTbPHlzewlS+nscgWL7UYWQMpLdKskrzrrSGsfeQ2 rBJtwq95eB4PLvoWXlv86qNGWtLbaqrAM2kO6OMbPtZKOzlkgl7aWHtEXK+9o6Q6bg+N2bN2fM8+ ORnLpmfQeOskdaNMttaYluNHf+im/jB09jwzW9ZKG3dN26kbfSIMX4kGPqSe4c/Mg3VX5sF9+o3+ hjrdrCt2yTjatTzYy4qV3/1Z5+VXbTWUX2/nWfndM8vvVn1p5dexld89s/x6O8/Kr7f/rPzuvqW3 +Xtvld9uOHrLeO75s70vV/z5x21VQq9sf1tV4WMko+Q4zbB+fWEfjJiSSMPUwFs2PAOZZcGegfEe fl9HP4nHSprZkneelLlqpgUsHWaO2YDXdR6LttAyjEZwHGBwDCWt8bGSu397rsHbT+/CN7+UNqni Dcsn33hswT5/08yXs4cP1JYgt3wAvIfLvTZmsMmNcYUaVK0mRysrpLYiGkvtppfVfvh+JIanRDNP 8poNLhO4PjTSwXhb248H2kCN+9XWxMHB2oeSGMfEqyUNayLy7h9S9w6/5hvLmXZn5KS+snje9d3D 6M7zvN35ymW7jHLvGyH2eXY7Ons/0LH39E5nrUWMto/L7ewlEo/yyB01Y2fU++Sxv8FIRct8Hb0+ +EYeD3kXvKxvkcdD3rU8dmz55DRmhfNCC8kkfmikA3jrG+WD/VlyKIq2UR36Yxv3oaRTYyxD+PWT fcd/SnJvzLOivCy2Sgf68h793TCtq9b3b0z7Iw1cVtKUnryWDy7T8DwZ5cSuxSor9Fs/4nzNzC19 mcihOLecWPKy5YRj86bTmJfXUxbWzJzQV5k0O3ORkxeSqToQaQlDB9FAN/FCZ8l0/TMqd8l6a5f6 eMDfYNyg7ODfnieGnzzZ8j14ew/9dk9fODZ7nMbsdF5o0bKceVqgKfltSE2RwkQLivgoF1pijIKc mZqenhbsxzL3EkZKelrDL3GkFdY8ZcxpoKl4YcHK2s/TAo10mKGnx9cpWeOdsh87/Y3pdGrm9Hm+ Bef5Rpz+1j9n7qjXzqPtYYuQ6a0sD2fXVyv2v4nXG0F3ZE16n7r+ni4qa/2Uwjz6Uvxw5DCe/x3P pdX050rjK9vD0wBW+R3ljJR0Rur79cibWwvsadSs/0adqUddJWm8RWK8+4fU/ejxfqfH850ez3f6 61StxCVaQOP5Tg/NZlgef7h7fAX+YiRoTL/nOx0ygetDk9/pkd9p81kbUbMBp3VN1pnd+ca0anMn z/t9/j4bJexW/5b+UGsM3NLdbHIMvbzFln1jpNBrefBD06K8fc3fqA0/HLVNYNPBaaBbi9owZLr+ 6Zs+W9jZZ3vf7JJvtvNYKibGPfAFRUhWP1v40eRmzvcjL818Disu5aBfXqPlFvKH0nVvBD5Js2rq QJw0nhY8eZ7S/EnOnB73jZtZM26mj4zzTc9SwX6xl3qbN/BSP2fUikPzCXp+otRPLSv4usg75leJ Ob5iEw7e0p8rZ22N0Vv9tqgj8UPTs5dgi0ZCZo+Z3THvemZ58cZmV3/pDWda7c0snM20N8NmPE+m odlPcrP/STxv0tAb5GWtSZmsn8wpXfWWTckHtpaU05ydvLenTGiqtIClA2ikG3jPI/OE520mkL1e aKGRLXi4nZlYkkCzM3eaPLl7tPFtOijw2Ulze/Kapi4T+Dw00gG83j+HFp09MmjROQ8OLTSmBi16 naGF47OTxlJwXku5t/Rd7w/NGMnLXjhlzswnx9BBNNBNvNBZMl3/jDXNiSLlmF+ELH8zc7aU/PeR ezJ2+r6pB1uC1E+xAL2FYY9oYOd+7D9ZLjytm7Ou4E1NN3owqA2IWbZRggPXmAeFpmNmCR5YiCTs XjKanl4dnFGPtNwax9BINKap88Knnpsr0wLNzNgcPoOBHLE/niOzvznib0w/LgOj3lweJvzYOTkD RN6VNmjeFDY4Nj2c5vbkhRYzc8TTAs3I3ExNoQWW+pGD86xjFcyywupVjZvfZZtsBX1gb5tC0mrz N0leV+/Soq7e7YSlu6/I9d0zbrfqs7Ef/NCw55D1qMsELpmjxK7fvqnfvm9u+Ru2vR89TpYfzoiK ZmX50QwqcmuvLD+OzeNOc3OWlVrszC1PCzQnczo1nZhNZfk5g9g5Tt0hSTOfxD1r98NxCfKOH1JH eibfdMx2jnyz9PXGr3vQFgDVdfvsuZaBfV7AL9bAO2YIwW+tc44immYfDj/g+d/+vEr74s+ll8/r AZdzkjsi0kZS7dcv4eozhuQftAut6hGR9GFFWPv9+Uh/4Y28IipP0dYtKZI+HPXV0Dok4h01//Cv L3iXvkoln29r6bNnaD78ZEaEhfyjdBUxgW9PGmj6+Ml1AE3W9NLBvWRzgG5nq0+JjjfsTaSdrbfE Xu8ZjepT8M74pgvr64BBeX0dMMDuHIGtfV1KSn083G5NrLYLaOS9FTOLmZZ70rF5oGV7KHih6WmJ 70PjuRB6epT0FjWr5iTdTn+zcuYSuqpPQu4+E0f0WUnoavla6n1FywTP/47nJ0pO9xbrOjl6v3aO 3q+do/dr5+g9Me0mDVtg4NUIPGRqZH7dHL3fJUfvbamM09hyGue1attl7p6j98TUgTTUDbzSGTJj 9B4cdTdahpbyDUkxSm/rZHvll5nYazTy8EtIHuYwcGMtBE1aTU1aS00av0CwurHOhTccY2UdaeA9 8cKrkgkdlFbok9Y11qSk8vWk9oHDKrpfjjnzuK6NT3P+Z6F1xl7Buhh5ph6nJd4PDVqCIyPAZQKz doZG3b2/uPqtRFwNjjtAkmaaya12BPAZmdpOz/Tdw2NdMYY2peIHq/2EzfPdY6kFL3JKMqkp0yKm DqCRbuCVzpA5vN8PTQfH/MGtdYDEHOGjpKWUsV6PKdQba/cQbY7LQ2N5Jl7kmWQiz+J5D/qFNYCU g/xzvFfSwOsr889lui20DKnRsidlt3myRQA7p7cIQKc30GrOGlE1504sTUCza1g3d+bh5Gj0Rvvy ZB46jXlVvNRiZT2htEgzMw8fTW0su2R5Xiq3w8bKubpiDxsfV67PSnrH855XUl+/SXI/7VmiVG7J 7fU37N84+MDeuM/ZhvVU9so42/4dhq/0hjw7axeNGZP79MRec0Cv4yUT7cSMC62WW9Yq//m8PFod 6gutSOWW2EivR8JZmfp5IkEr3kgzMs7VFoV1h/ULIsGx5abTtBO81OKp288TCcfLYHtGoWHRHZl/ d2Qc3ZV1wd2Z8vXYXD5STU3vybh2jPV08r3VX+KFtyWTOqys+663Ga2+wMj2L2rhI96mnY9483kt Xr/ouWr/r427vfb/2rjh4a+FXL0m8VFxy5EPb689Au+HBi3OFnV2yNyFaYV22hYjqae4h4EjSvzN Ykvz0UM1F3HU875yjrzK6ZKtdIuSwK0lTctVd9SCMoUfmsznV1NryXVF+iVWHfHh4vWCt3VtcufD LbHK+4xRd88fSUU+iJupkZu4xpfax+zJqxoJqxHVBqorcZtJ03O83ybPQqOeaZFGFoC396xlvrZ4 YyQZPiu18KhHK7in1or0q9mBwFn7f7hEbmp+P9Ly3HRsOdLym+q81Dprf0+LNPnlkJ5eqvpTqvpT qvpTqvpTqrrnmjW7uvUWP+7a0QLGNx/PY/TXOk0fC/K25g4hezNzLQhl+SieLRaNN7PHvhtycAyQ mB4hDUfGyMsxBUr1PR/gUN6Bg7MzWI764UJutEspCW1OYWtDOA12fIiXO15a4vXQMC/Iu1vK5GgG 0xKGDjutcV7oLJmu/2PNhV+tMQysNzfeUBZLATh6mYnriPQ0mwPe3lI/rd2A3o7RHhYN9p2I1+x3 mcAlaVwH+CI0RQr85hBz1QPy0PFc0UalpvuxYD2WKc9BM9OrGj+OtMKakbnjNLBGvLDgiSNPCzTS 4YSeniP9ZjxzdNfj2d9MtPUznkfNeB4tI0AtaPBqXQmkjh7pWUuxp9TJdgAkzZYpTM9bo6k1PDOl ha2T9+fmJc5LsbRqtSY85vK30nUPBD5JY5q6DsD1oVFa4PW+ETXdWTrn2qnperSbGZGOIUk03I3z aLGzdM7z0PAbTd6bpXPejH7H0OFm3jgvdPY4LZ6WW7M4Bgl/LeUy9+KkdtqLQ9xTu/X4enlrnVLZ ryDHzzccg+Qb77HDDn9jdiz3K1a3tNB97YwY38pLjj1K5MruGa37ibHdSkjdHtFY/3LCm1v1AUaA S5Ygp8Henaf+cJnED410AK+vDmMK3NNBzHERlB/HEyPaj6ZPPu4nH/fuSfPE4X7icD9xuJ843E8c 7icOXSbwE4f7icOddbj1CThbjtr9+Gw59NAb6Hee+vA8NpzHznPzS3dL2nD5vYcNjk0Pp8HenZtf OpcJ/Nhwnvrw0dRa8Jz3Bcdtb73vb6BTW6Hr7WnDfWq06Avw185673pumSR5fOWuHlq3HutEg109 T67cnd+xex4aRQ949R3bGI1vnlZg6HCzvnVe6PxE2/WVwtZyGqWz3rM2aFF08zk5bMXyz+dPPYM3 8PENKtvyKyrEzyj0sPBTZkaZ8f0dmsu3MhN4rujPmEUfjngbZd8Hl6RZUQN88m96aa703ozvb9DY mnDntTXrLpP4oTkzee9TMr6PabR7xtNqHFqZTNyidH+9tijdH878rCXz2TF6gqLBTqSsx0MmcH9o sv0I3TLPq8rwvsTBsR9JGZEj1hbQhqUvJfqUbzTY7L97oHmeWK9Cfl0ndhHVnTuKoKHTYC/T43ut KCA+M2kUI+C9mbfe2kNa96YON8p58ELnJ6aa7ziHl7q+PcAc6Ucp0eoCW9CBJfmuXW9PLYGNIu4l rhdwuYMr2OF9zXPDotHS46PPxOOp1bA6yOUO3zFAuTPaf2PMp/0Xb8z2saImGGP3xCfaGEOrgcmb 9a6wl95ZbpReHsdCDsdzxc4aSJ1PmZhPmZhPmZhPmZhPmZhPmZhPmZhPmZhPmZhPmZhPmZhPmZhR JrivZkVua98Ln0eNtfHrem9yrLkfbyyuJQLWHmR4w7F5Y9eMQY0+wgM72+TohjvNuvF1GevE12Ws E62ZwGbRyi9H8MKGm5H1tHhCh9OefS/UqJ+IpR3RC9v0xnTaT+7usdKembm73z7w2Nk3HFrdS0kn 81o7XGCdY2h4Mh+dF/o9lmrXMWhOybzWPDxkakwVaTk2HU72SYPXdHaZrn+WuKM+A/BTYn/gbJdf vnHvnfnWCoczW+TxsWHoeJ9ydjUCYZHl2CKLM/rU/T7l7D7l7La079b0/X3K2X3K2X3K2X3KmfOa pi4T+Cln9yln12dGmdrdEQH31tTuqYfvzm/+3TU1XTM1fb4j9/mOOA202DW121k73Oc74jqA9z71 6Swt+lDA4vhwSJql9wc//clZ6vR6+nsz3zdci0uetw6JN9NSXFG2puZoyb1rYh8bpb7cEWPfqFnV iu44P426f2r/eF7uq28tEX+iUo7NOiPHplZckyNL/Kw9cuzDkWNTp9nAOm+n7J7483rQmG9rjjaE TODx0MyavOk/o1L7w3ArTyt3anU3ZLUn/9gCCapTwoMaRdXzFR78+fz5MuNNpHH648Heo100tb4Z HD6SBZzfhqnxT/Kqt/qFQDw3b2r/sX2JZpdF+5G/la57KvBJmltTB+D60JSdvL4+EFb31aNcaG0D OdZKSTnyMft+46zPLBd9v3IHd4oJk99yQnOm1t6amjOFXGKXO+YIuWO/5U07leDZWWJUZY5sKX44 WpCBzXKnMfuc19LmLmbHD02Lr/GcnJOAzCmPW1qOTQengW5PNMS4WfG0whqNIiPlGJGFXB9fNrk+ Cmlycwx3zhzbnfOnl27m6ryZqzP74FPrDYlr9MHn8lG7j3e1V6rWG5Lj55uRpWVFS+wrjvHGdF/Z kvjwSbyytPhIEnh35tEK+/xNSD0jJZ30tPYHg0b7g8GrnUuQumMO4vuIzM3ZeXhhPyXpGTOa28fW pj/nKZbjzj+bphq+MPsqrPknTvazrufnLYJ//GE5AGgOBJW1QpuVk3+YKBziiPVGeG6ZNE3e6mZ2 J/jEtEVo8Q0qAOM0MfHjF2HV3iMbGXTxBv25HRRn60xbxQTLxDvMovOptqzY8oCPx+o/Qg0O2jKA 1tAawnl6XJRmmw8aT9yCwIbGNyHqcxJgCRfYuHYOwioWN9uW/cb9sV/WBvyqFif4amZn+3LHhd1M 4mbCIKA6xiYlTVjTJ526oe1GOFOcjtSz8ocfvwTVywQ9l7+D3leS8zkafYTjec7OI+jZdyREMYG6 PJXKjp9srCBt4UZjHYocEFxJwDNHwbZKCJs7nppPRTtOSOBRqMyrHQR9BFtPzXroK3/IjkzP7UM3 au5BKMcPNPdp3w0HT1RHgkHAKQSwzcb8slNRUTiRxFQ9xPNFcXgDtOaZVyRZN+A8btZERpANbVrE neCMg0XhLtGaE1kX67zQ5r5XahajHManmidi1OEJ2pua3dQMBEwNbGpt85xcHeT4ffBtEAiHGWAu DV/Wvw3bglJUSo4rMQaZFnCPZQu9Y6GtYwxcTeBRkn5g2UIhtqnwLrwzXWzN6+Sd0g34JMYmPdGv nnqunnqCRumCV8tfZA22NopjnPcNum56oy4a9ngED3C8MZ6GLcXiP49eD+a2+5CFJqGwOheShckz 4bqT/8U6nIX8re6Q1VQJi3+lLd6g1RssfRLWdseuw3j4pjdf3koqVkKU5RUSc7oPpjI0NOY5ze3z /nxEZPi2+i9fHm4sDxY30hA3n5N7/uBe3Qe9qOF4PMRjcaT5faTe1z/DfX18YI12c2MJY3p4jGKA 7kSMOp4jabBJr6feLhMa9fQfjxEUzbjJO3vKnCPTmit1EIZuooHO4oUtkgkblZbb+1i/b0TH2D/e rMerGnLgr1l7eIzDbUydZ0JTqynfm7asiWmFY7POabBNsKQ3XObqTCuwao0VQ3jibStlPrkzn1xz DN1EA53FC1ta1nqeltubJc32sXhJmzPrtLky0udSHRjHAXXrVSV+aJCyeJHazLziph9ZP+qrxeyR b37gEK1bqsfNuqXYszRWzzTWU6dzolc0NT2zVHdDpnLBbGPTnh52bJ53mnmS13LKZZqmnhbxSRrp Bl6v9+MoIaX14nYeX6ynTub0MnNkrZta7xo5wi4BcyTwQwNPrCw9LhN4PNaMH1qsEjmyfnwZFg5f lFzVQz0GZOXhk1/KdfIr6BjeEA28dPIruJ66bd0RmMcokGY/ZY2dFMrcKmuW1vacLYlNt/2Ucedt J2Xi2CKl5fam9bayy6y37/humc9b3xVo17LW3r09OGuFrbIAXv8WNB9aVlpjvSmfGjnCiW09n09q 8/3u7pvfyn1Tj1Mynrm4lnqcmrlzvK2DweIdnnRsnnSa3pK3nZRpOnharg+1s4PFDjqp3faejOOx +rWgzjoRz8fj32hUw9gSSMdzJ41tXnHedVPmbkxLsW0pHLZtDF/ltMX8VTRYabtFWmDQuIRGgUvS tJO8Zud9oueclX4/b37elvl52/tFunPlm6f+vE8s3e6+RC9XOQ1NTtaG9+Q34O78NlyvP9AxzhwN jAHorG+cHp7ZypPlg8ts7Xq6AwPfJSL63iwljldNeljztCpdT9DsLCXUTT76PrbVv+caPoams8wX T9f6w8fzOekx9Nxc08QnaVYMXEO7D9fE2eaBPuA1mWoXfVkXA+Xi2D21jjbywiDxjDc8lPPjx/D0 SdzHyzEejvW0dWY90QacPKITOT05gY2cTnyTxnxWT5SBWVX7ms+4xBc5PTmMQJ2a18TrwTdpODyd PuPRIMLnBo3rgIF06WYyuSRa9p/oWwUNdDvz0bmmLTeiOXQw210384lj81XLcht6uj+j3pqtRr01 uVUK9dZsLb7Ds6kdNjAEf7zeCjx30nz1VvCumzJ3Y1qWcrNmRNuY2hZGjfZhu88AfsF4V+OXoVmT onELRsNQWuD60JTkrSdlAmNSHZdwCIcWOABVbzT03xbuiUDLgJjfhmbNnMTdcA9dT6UeNqjHSUjH SbMv9UDKyJNMC3g8+CbNfHhNU5dJfILGdTDeE942DxyM2ohDwznSD8vf9EYTm9TQ38C6OdKi+Vg6 VnoAPT/x9hvWcasJrQt8k2Y+vNBCMqlRTZqZnnk0tRSeXDyKB7uL42z6ZtnzTe61SB943VfS/V2S v7mPn+4PP93HT3fO8M19/HQfP93Rw0/38dN9/HQfP93HT84LLR4/3cdPrgN4Q1OLgrsV05s4OPYj SWWIuL8eWCqxhl/f9NKu+wY4SlG8wUEvvboPOpecibufxKO/3DPKYC87ymDizm0CIXXXlLQeqeuh mVEGO5eTZVryfuKbNPPhhZ2rP/gkza7Ju58aD5trFScf7qndfTS9j6Znp6ZH8XPzObS+Sg0yS1jg 8vNAHmrkeD46wALpQNzTmrPTmuP1hh3+V1v1WOoc05PUllI5QSyskS/aWevyWOq1eYwe3HTDPP8S 1m04/pyanPH78yHuK46P2zozzXscesPvDd/4N8C6SfElurhZhzkPjrUTb9ZPoGFpIS9rGErdrx0H fX3HlGo2HZWCazUaygq5T5QbS+80egG4r1fuuOGfM0v44cwW/vnxfPyQi3FFpTjL+waTw3qjCVra qDew/SjSweE+Ad7hn8MahLxo2Uiqlhw2W8n01bRMz/DFAh5yBK6G0+vsqzA19k8cJ81hFO9i32Ys w8+0DNf64JU0rSSvaSqZwjtopAN4r65UYWpcWixN96Pd46O70kdc+CLeJX+t57l5ZcmCG7U1LJD8 XSfTDY2EoaloYMF+rFmPNUoLvKs8eXNv8bzpPCYEeZPYtmeV69b0kvnRuclSFt+bFnt+mMX3sfKW tOw+/hUNNPV8aiGTRx0wLaNxHXgcQvWvEw5QwBIS+KtzCZA42iOptwc/9cZH1bwk6qsVcjFtL7mz pdw5UtbciVd55Y6dcqNNCrm7eQmPrxufTy/hvz1vr9wd5VhU8easfON1OfOVb5iX+qLwgq8Z2L8u 98aXA7z6ojzHR/zlVKwBbQCpc2aobXz7Ojk6vgqUhO9jL4nbQ6PxBKUnqaUGt1J79BM3aFrGb63H S1Tn3FPDxujAJ2lgj3hxaLRk8nqvkjSyALxa1qtfXtcWPyxOHLNErHBJVNKjZ2ZrY33Ob5ac87Pz +30uTbgS55wfeTl+ZZdFJs45v9lyzm+2nPObLef8Zss5v9lyzm/2nPPjAT/CI+f85sg5P+GaNEq3 v3N+tIZjxeTw8Vu+4Zwf3/j47Ww550ccb0rO+ZH/PHo9OOb8yM85P2Ifz6AszkMR1538L/a5G/Br zo/Y5/zIv9KWmPPjG875Efuc36w554e81ZwfqDTnN8c754ec1qwdclqzdshpzdrp+YjIiFm7+cwY Ir+ce+Scn56T+8eM4fSjMt0OzfOR2+f2JrYK41gwYh60+ZcilgvCaK1mzRDhmjWjXI5WEfebNIrS mrOElOlRnbOEs+Usoa0SCJqes4Sw1GWOnCUklg4jZwnJK517zBJ6Do9z0jPrkeqzRIiXsWbETsz7 gWdi4zR5pr5xknYzQmd7S9VcN3lWas97Tqn9vCXyklsWP2ybAK4sqYkx9yUaXLUhXtPWZVqkxfOS 9LiCQ3Jsc3rghwbXfYgX+kum25J+cssyZbd5FUYQZnIUgZYzq2SOrZpxrTkx4ZM0rSdv21H/racO jvkuxBw3TdIKXvghqplWaJ6KNKNHvC6VtDofbPNMHI2drSR9a35RB3OBWxqYO56uxfdaLbVejyeE R016WD8fT4zHE+PxhLa1dDul1ueQJi7OkO8KtkzMyGceJv5pVP3KDuzzDWwzf05jcxfOy5kvysw5 qr9k8+6qr5dfzcFY4OHg9NGWPeZHzS1RI8claSw/nLfslAn8fNl2f8sXj4/Rm/V+tWyUzt9wxE4c O0vhjvJt9fyZWc+fmRwc7ZIkjejQ+0dloGDeqYf3z15hK/tj9D7HtOh9x30njXnfeTFbJpnmfR8p y1tmvyr8+wAPrYOsg4upP/C1lWzeHIDrIAFt8BZUtt6x2jIxXwdZLz5xeH5tQNnk2d5Hm4oH4DpI QFvmCCqCVmIdpMQADlUJtvjRxRv051gHOT6FeFSyrQ6rc/piRlxQzZVkldP7hO0GQeNKMmNDjFIY QtdWklVucbKFYg6/TpkTfG0NZzsnhN1M4mbCIKA6YJspTCvUzk+o5QjQmBvKIY77yWnHzvTU1CA1 NpWSuvsivbq4NtL0WFql2A1u12Nh3x8SX4gYOEDQ3CICc5bYzIUrlht6Ej0SlkJ7+DLLyvJIuKcr tLXabhqkj75EuGHblk06XElgISW2VULYF0/+1JQX7Tgh4WvkOOw7CPoItp6a9dD3LyVCOzI92Xdw vpzlQT1aCvlpx4F82Mc5aljNWyAJexKMEmxcxghhw9dECnLZZL04uQVac2aXJDe8z1oBBGf7ct16 li/XdTiNlrk6k9aceLRA0hS6vmTVU7MQ4a5xqMnRFSjv8ATtTc1uagabmRps1kzqz2WTNrzmXah1 sgu1TnahhCtxdqHIy27TuvPB2YXaJbtQPB2KXSgbxPEu1C7ZhbIup3ehds0ulH3dArfsQu2WXSjh mjRKt75dKFrD7hA5vAvFN+xC8Y13lKxTHDzl7UKBR10o8p9HrwdHF4r87EIRexeKstiFIq47+V/s XSjwqwtF7F0o8q+0JbpQfMMPKLF3oWzNi3ehkLfqQoFKXajd3i4UclqdIOS0OkHIaXWC9HxEZEQn aD8dMOSXc7fsQun5YD6+3Ii4UVdoy7NeGKE8O5Ga80xFxyVoeIOBLL0Zxbx5QHrfElHpGB1N0dQT vNT0Zi4pLeGMXOkGXukMmcNLyf0Naz8Gc3i0zO3hHjbrxw6t1cmy4ajBm5U6zsEK/NDAW+PxEGUS t8ea9kMLRinf6C4x8bD8UO664WF145hrbFRT19XSUmF4QzTwEnnpvZVxyD1Ujm/SqNyB96yUycUn TIvLEKjDuakbaagzeWnLyXpRaYW9af3EHkPWXLw5klpoySi00zJRaM3OqeORNC1jREs6KZOLRJiW VvnrF5fu7bzJUc/7k5oGbPVm1+TYjx4n43nKY9DjZu6oQwpP8hwfelIYnpxeplrwwpOSSR0er87t cbTREeyMI+xDlz0rOnOIZ3W2bPjSO3+bnUV5fidNixsbP3xD5kaHT/tY+FVS15T4qPzn0kWUNi1d RH22PHr6g0vSnNjPTjslk1hRjrso13hyx9zpubPLW6tv7CnSm55y9xNL2wc94P29S5RJTtaJY2VZ V+eONCPL7XZ/zwdjZ/yJXBc9PLOn8sQ6m0t4R7qIGHb/GNF7Z6Q7Rvd3Zd0jPYln1gWeLnh92SQ0 PTgZnF+0U0/kyWlZ/x9v0Vi37ilXp2esHvkXvF15bjJ71rDC8IRoYP15WiinZik8PizAX7h7USnv sKFxcaHn2i0r9Lsl4+fcjLGjMgb9vKaz7uhRC6o++CQNurs3PXyeb9i5WauyNUpeLXxEDnIXPeU7 LitpsA+vZI3vMomTxnWA77zeCZ3dX7dly8X33evNavnmKWN3ej1p9cq9NeqVe0fUK/ceL8WzqOYu tsSvdK9XAtuCMKexekW8qFckc3OBpiZkbGdv503jX2vtEP/tmJP/trXbl37gVCXuqW+2yk9Tbdhb 6MtA6pwPLkkzdvKOnjKhg9Jyfagd7inldDkxJ1Rx3hJPCWq2DV0TaK3OnFizRnHimTRIWbxITTKB UW5lvU+78815fHQeHyFO6COecUkfaVINPqqc2ISPeKoQfRS4JM2z3AOaukzooLRcn9SuotNPjao6 33qDqBT2hRbwX+UUMc+NVIrmS56xTg15s3mruLFUkTHOgx+a0ZPXUnOZSJnTwtRPkwiecmreMt8H z4D/5Xgoympi6DpG6joyBtgPcfzQ9BLxw7MIMi3gnRhndrbMXeeFpn08+CbNyAjwW+DkDZzkIA4t i5d+5+abc1/f6E3eHuUcj6VcJkAaRTtPFS1pHZd80Drh3ZMGmosXWkgmNWpJcx7PpKZ2S9KTi13x gBPqubSRp2cqHnDGvqKauLyS2u+SvvqxzhwLsPjzPnYdORYgXIlzLIC87P/XOR+cYwF2GHLQrxwL qCvHAsx7ke7KsQDrcHv/v+4cC6gnxwKsUx16nhwLII3S3e9YAK1hv54cPhbAN+zL8I238+vKsQDi eDNyLID859HrwTEWQH6OBRD7WABlsZdFXHfyv9jHAsCvsQBiHwsg/0pbYiyAbzgWQOxjARYlPhaA vNVYAKg0FgBZMRZQn02QyGn15pHT6s3r+YjIiN48zgpz7pNjAUxD3CfHAoKe3CenU6HheDykqVVq fh+p9/XPcF/n5Cjs1gQnYnp4jObkKGLU8c7JUcSZ856cHKVGPf2nyVHSsD1LXrajKZOTLUxrrtRB eOYWSuos3pGTwbRRabm9j/XcQkmN9o836/Gqb6HEL22hRCra7ojU1b+FVtoeCW3VB4YVjnduoYTV zntyCyV00hZKYtUaJ7dQkretlPnkznxyzfHMLZTUWbwj+9u0UWm5vVnStIWSeGadpm2QTG2pDtyx bZJnwDl+aEZuoWRqM/NKWyhpvW+hVMo98i22UIJncQocb7TFkVjWoV/tcZtbK+G91TPetJUR9jie M2lmS95xUiZ0eDy56qv3Giu8t9xjmHrdmdq64T1ta+SZcY4fGqQsXqT2eHJ5CeuOQ4uZNf/ab2zb xQTx5ry15brpcW0kxPPd3tqE9z0L9/T+D+xLHqCLvXGP7PHm5OHEMXHJ+uv4qAB4DscLiOt4+Xtq fPr75dOkKN+srCd4+5qe/9DllkeX8+jy4FveL+U5j16+qdI+3uMufXesJzblSeuJqfbC2WhTZddo hsr0SYwenWjsBjLnPTdloi+9wleLG8x+OT6KuBEb1Xj23M2v1L0rNXJckmbkJjd66WRcaDMbPfPG 2OSNG3gz/TYNvRkt34yQO0uNto2wc9QSLYXJhYmwYpYbdV88x2Y19rt5glmJGmvWEt6YtRavBSZP ZkUrLPFJmlOT9/SUCU1vtNRCB5w4J922bZg7bk3fPDtNkTF5zA4iY3obkWewDY+M6W1EnMHm7cWd NGck77kp8zY/p+1rF98drd92V7R+sRJYrUrHlThav+LlJqe754Oj9Yv9IkF/ovXb7AoXtX4bJu09 3ROtX6zxVYu32WCDt35tEMJbvzY44a1f4Zo0Svc+rV9Zw5YsOdT61Ru2fvnGl87eE61f4XizovUr /vPo9WBv/YofrV9htX4lCy0y4bqT/8VqxZCfrV9h30ZB/pW2eOtXb7j4lFitX6wiV+uXecvWL6nU +oUsb/0yp9l+ZU6z/cqcZjvVn4+IDG+/Yq22t36RX2r9Mg3WAHpO7h/zaKAasn1l65fPy6P5faTe 1z/DfR2tX9rNFixjeniMRuuXMer4jqS52fqF3mr9UqOe/lOLlDQcFSLv7CmTy8SZ1lypg/CeSbNb 8q6TMle0ftPex3q2fqnR/vFmPV710Tz8YuuXqbClytTZgqVWU74/0fqlFY7vSJqbrV94Q61f6KTW L3ErSdN68raVMp/cmU+uOd4zaXZL3nVS5orWb9qbJY2tX+GZdRpbsEptqQ6M1m+7uz/4oVkneddO mStbv7R+1FcLtn75Rq1f8qj1izdq/RK3Ht5bHrfR+qX32LKl91bPutvxnkmzW/KukzJXtH5Tn9Sb rV9h91i0fpXauuE9tk3pvcAPzTrJu3bKXNn6pfXjrXnV+uWb/ca2Wr98c97aUq1fvGHrl8+99atf 3I5I3NP7P/Acjy5s/QoPz0nztDbkwtPHa+GYvWEaXPrjuCSNNARvya/zKRmlbEUztx1jBsXL6IlF iYgayqQNOvJCOL/Irht4pTNk+oZiajqyrXFGxtMZWUq19Zea6vsPTb0tMJIGqY2sHShT2o1H6zmS Zmab4qyaMle2QXjUhnQQhm5evlvywpb55MbMrw918O/VLT1i5Jys6/zQjnavlmH+cny9dYKWPmdT iHt+a+9TYrU5GGWI5zWzDAV+aNCrEO/aKRO4pidjOxtTRnTqTXf9tg7M8Ny9+5G1njTmybRnevPq q2VeDoweTU3bRA+bvQZefmAGW5KeLnpDW/Ech3kw13WwB6KB9LJm5Rebeopm5jfnjudbqf6MLDsP d+Lo58h7OApROHJ3bp4HDVnVD+hodnWhDvRALuqgD+yw/rC8cRLfHYeB2P43PwzE9uP5oR+lNj97 +i/6b5atutnwVT0xvBcDf0/eBIw8mdruBY0Cl6TBqdc3SkTIBN4rPbOfugF9LMWV+lvxBrWG3oyU W1u0Ed4+zfWjK2hFU7/k4EiLiI6pWSThpKn3hAfqnWn1jW974pY06Ind+BaGTOKkcR147EX0mXQE huupPtByGkSieGkxZTqOfo8O9EC0SjePsKbvCo4q8bJuKaj3ZfnZvMYFzYkIc2wR1rwnNpyXEUaZ jLDm9b4d3fV1GdBLAOYZ1M0OKPEZHTtKRDe9NTtwqPPM6mbHWCeuSdNK8taTMuthWoYxh6WDmETF zZ7kZquFz+mLjluN3+da/yWdcCow5Xbflk46ftXsH2CkHnc8i2O2B89XLtuVxFqVI+8cyu24Fa6n d7iJmpgbP0nDdhJ5ORtnnarOM7ybdaQS36SZDy/0k0xgpTUfHcB79uuB+/jGazXmtt503PScNgyP AtxY18KGUWXPNrxDD+K//BeP4kDa7KPo+c444NG1er7643GeHc705hONU/qZz9Rfgc8C36SZD6+l wPO8Ha+kwSE34m2PTLaRmJYwdGjpC+elzuvB5fH9HCWijzezKOWREcczbB3f1xdYWSU83njnFipp smZquFpqzu3ptMjxTZr58CJttt6J+UUmjfINvDykhTLPkyNeAmbS9IcXOu+sQ3xDmH7xyB6mrDFZ ydUbyL1ZmuZN7y9FADG9VDvuEEfpFUZ+VbsYSNiocBt5vaAC1ni0eNCfE8/88QYbAvUGY4V6jvao nmv9HN/M9uhyH10ePLVhWrrc1Mt7u9W6wH1gbL3atjyV6GoEvcND2LTSuSJYGKtGRHP03HiRO5TZ 8b2vE7X6Jn0fD75JM3ryjpUyx8m0gKUDaKQbeKWzyRyaNaCmg16CpqOe0JTrkmU9fEFNR62haeCb NKMn71gp07QbrT74JA36z+LtM2X2nWmhjyMdHJekgc7ihS2SSRvPg5Xj1AL3MejN6qnddB910w/b noQ12onNRx6VwBzHqbaxsHPshtpOeQk3w1dpdR780OAWevHWljJri6infhot95QZnSOk/iWPzHEi d3lqtuT2Jw33lNG09CbrYXo5MOrqmbaJHjaj3VBta0znKE2dqDlGxjZr3mq7gqCb53rglfSwRnoS t6RRuuBt44nneWrk6JwP94tPfb2HQ22EdQwENu7959WOLbv8r//lj4qjRSaOJRLWeId+9efN/PFm PW90l0psvqlYXLXQKKi8MpSFFgvBeCKqMKp70bAiIC8rC5u6STwML+KZ9LYsabHiwOWz6wq3THcb 7yXvlm6GT3/wSnpcpio9gaUnaJQueDWwzpQ3JquEGU5YwLcZQtCUJ6jSGu4jrXYHdeKZNLw6Nb3l MoFZnHgZqC7M0Rucn6Q3DDriucMGLjymDXvJR9evHqW/9rrh68AlaSyfnJdXnrbUTmm5Po926CRI IzXc9QYTqsSnBM+2y0FHRBJPbhPVSn8cFgTSzB4a8owjah54GG5hndMv0O+IpOPeaJmueYbnHjGS jqLz9AevpMdFpyujyvUEjdIFrxcvaocBBHHcjBguMeZzLp3m8+ufdfjitvQXL0n158qV8vvz8aTN oR+loQ6e6DyyKrHbcUfax6ET4dleuZ31AXBaa1efHsq1vLgqyaDyEg6c+XXXibJ1V5bwy08d8sXx 6UkDXcXLa1zbg7N0uA7gPW/03pv5ctXtZqz4my+pryUScTZ4QpHjKFGj1OZxNrhgufKSUg3DVVvZ 2hfOzq02s9i5maPiYt9FLzf74HLwu1pfvC/mivXXA9vyUacZN3mtkewyUedO5bWtyMXFzpZyjVqu 2ixk54B6tVtWOofpq6141QXR1Va2Jr5JM3ryjpUy7cPFS6SFz0iac5KXtTpl3p5pscamDo5L0kBn 8cIWyYSNSsvtTeut1v0ljVQD83lZoeku68mpzS4CcooD/cwpbidhTu1ZI6e2PN974tGSZtzktZxy mah1NVlUbSymb2zrEfZohbanrMhDDvvTHzxJlH7ad4f/tvxnfg18k8bywXktf1ymeeM8nuGpqKKp K3gPu06QyakEpnVaDx0Cl6QxnZ0XtkgmbFRabu9jvcoOcM9oO919ZE2j0+k94PHGwLkl+RXR4Nd+ Y/FgIlX4vPlyS4188ROxGSuqRxErvP6RscIhe8bKlcYWKzwdm7Hi2GLFaSxWnNdixWVarPhWEtpx V0YET3+jd+/MiODyIuYGt5gwlwLfpLFcdd6xUuY4TCvwbkmzMyJ4Yp1knowInjsqHU5GhNNA550R 4TJho9Jye8P6UerxUj24zEhUN6Pj3qf+HTy9FDk1eGFk5WXYfXlODZ6PjZwaRZ7HldzCdsq404yb vLYQ2WXaUkA/N/X3RjquvGqXA0B2UDQwhjasxRJv5o83/XnTnjfZSDfl28DoY4VY3h2s51ufT3s+ bz6f3tS8ducRKxgbgG4cM6t2snbTWISdoP1hOrrsxLUnjR31J16kMMtKXGvS1Bm8s6ZM9liYljB0 EA11Iy91pszQn9aYnbOrcFTiSLmf1Gi0B8/XF5jpFR79fcO+EjVZNTWcJzWfKy0ShqWigR6rZtpr Jt4laXZPXjZpKHM/ae2TOqjZA92U59B5l8Trh51eLR5iFZZ8Q7nqhEHufbyvzpbhVfrj/bVbRCL3 sDKNFU1F3Iw3M42l8V6mvrDeipiXX1SbMHGMQrT5wYJWu6SF6+4HJ40aC0ztzPCguoPwrGPzuNNY TkRD44RM4R000gG8u4zHmo25LeE+05o+05o+0hp1Gc2C3e6De9I8pWPXHdZslSyzZj+lzGmgacsc kUzhLMXSgbzdY8byc+sjCQ7/fFIPvqF+a6TeK3OHO2NFo24beEfGNA8Hlg3C0GNk+REvtZhZfpQW adZI3tS0/NlKUdN/G47ORfPG/mdnvRpiAD7Xaeo9er4NywI7i+VEKan+OSvjwTdoTCPnNU1dplng aRHfrLnKE1/S2WTClsydwrFS1HulZY1bnnzm/krhHiXy83ypK+q9ohkz/VKTGDzRZC35BrnIA7+Z u7yCwrkzisv8oa83Yg5xvql9RB3C2WVS+UwzU+QctHBbj168hEJYzZdSA6PU1ZWlrq6sMeu8D35o Ztb4dWSpqyNLnWPLJ6exHBAvbZjjwVnqpAN51w9rOApM7F/hGpjWKGJvXMMpC25+Jet5aE6Wv5oR i7TCmp3lz2mg6XlyJKPX0yLNzfJXr0eT5Wfr+d1p/f0m6A30ay0jqLXMnfa0Bpq62+BVC6MMv0SU Njg2PdrTChEvtahZwzcvKyt0IK80jSPTvqbujZNhgbVUYMzfsJ8Gqzc46uClcqH/47/7Yx7IPrDb 1m7GGNxrOx19Nv3jD8ed13d287IS/JC9tyEWPv3SFCUR+YEh1SiZkqf/jz/+23/62pj/699Kpf/7 D54O1TnqOmPjxn/g+7/+rTT/N3Ym1s7ImcQcMG9t35/4ZyCvnoG87vtml7QPp7/DEhvUETpp3zpu nw3cSNpO+/jULCElUdpHqRjaLm6fod9c/u+hUrh87qw75n4diF/S1q6qpQw7bI1yiZiasC61pV6U Rm3tKD09va6tEPmvawtKprT/yYH/RiqlA6u1GxmBwHF56PiBEdfm2Is7mvmBwVXfI85yblmXGP5q ffuIg6F5j2nYKRqFfRZg7iuq9ujFyWHNHtwz/ctwJ652HEazT4DQV3f94w/hr4coytn/FP+H7P2c /nRVpwQSPzCkghIpefqRkf9OKkVNjtPc5X3DlYvYcZLo8r7HR2g3RNWFGQ1Cv2PZf9iZoPd57j/8 udqH8eNXivxbyizPct2zHnmp9D8rna/5Tpz48T3HJer+3H/4cw3Kx49fKfJH+oxRpO8hGulzMQSh 9ofED6UTz/2HP9fAZfz4lSI9/a/9hjEfrbcS/lt4uzZY98PaH7jxKM1qE9XCf6mQ3ZoF7uebw0HV gctTCg5ztR4cz6HFJWFWHzj+wgyUdjGLpKE+qTblzae2zIqUQuAnNqmgZEqefpaMfyOVvGRUm2Bs i63FYve/8ORV4LpPlJJ9fisle0d07/uUEt6DhgIQz/2HP99PKXnl7IzSVnBxz5ViwxX7y39xRXzZ m7jZ4TsfzXS0UNMLW4cWlNM6geCf+FLY5ks9xQgOKInIDwypoERKnn5+vP6NVIqctdz2AgTcOVhz rSX74vIWGbRrf3L4m86ZXotHYMRot5WzQnV45OIoFlGW/qf4S/fI5VOLUVISkZ/YpJISKXn6PwvT v4lK7nIOxc9zbcuJjZlPDLhzcp6Y08kTw/IcJbDlMPF84+qe/uCTNBw5nAcXrXHlzzEarYi6/cEn aBYuRiLv4tVD58E9aaQDrxuibhdX/fjKIlvwUBgeaIFxXAgHQneeAwbLusaRJi6kEb4raBavA5qu BWQm7kmjVXPgbS1lah0W0hKGDqKBbuKlzv3BvqbNOX790C7s5Fom6sSxJT5f7eGvhSvLrBWqESRQ 1brDoqpVyvrFaUZScXaAz30szIbCcUnML8fTV2fe61fy1c7LorgC1D4QymFb5BfX8OFN1zSWvXGv kINjJ+TwaSxSYe26uDm+NHBNEkdviX2MjVRbHN1PPoO2uuiu2sLuzrG3agu7A7eaNDZ1KV5qwXEh YqwZEw1Hzcl7bsrkuBDTIqYOpKFu5KXOlBn6h4/B8euHdm6nxgIhi/v8ycELjpg29/xTJ8cmyWna Cl7YprgRnknDsVXyMsopk+NFTIuYOpCGurUatklm6J92Vi78ebSLN317lH1Rmn6qY6Wu2kW5raVS sekJkD62/X6Cf/1h92Djxy/Bex9WxKed1dF4l5LN3TeeCmBnfjQaBoEVEUiI6QMSYDKbbBg4pjCU LiahLeL7YozR0rOWRatoRpMEC08EwQgCTFyTDQOqdsOqoO2SxEloBpvT2h7JVjFFcDi6CYXK9dRs syQOOHM1d9pMCJN22rzS5pU2z7RZW0ihfMOOX9pxkjFh0xZcZAQvSwZsCgBb0dZ4jt+xPpUyYtpI MOpXW3rWuLXKVkA0niJBiCkmEjBPwIbOAoUxe+YJuFoQ2AeSBz2ck8FwIiv/0g80s5geplz4VOvk bbEdBrx/CapNSbOwmpCa3Bb63dQa49uUjRgF5EkNIOBAL9joSAjjdiyYJWhmicDab2JbGCpGwqZb K25W5Y9PN4xd40sEs0TNp1DTaSPHJ+okQHakkM1DjTrkLTtbgLM8wTJxwAjCkPvdEU9c2owom1ne Zh8JdxAgZ8g2Iqa5aYRJaP8IytDEpCtK1txR3maWwrm2F72pUohZ7etFjxBFb6qQNadF0ePs8+Ek 9vKix9RQ9LjsmWqetJkQJu20OUshNSPBSpvnU5EtTG3RjpuMCVddmSfcYgK4ylGMIq8Q3hNrHoaH IJc/ICSGKk885zICQsw1INy4/B1B6E/N8noDskpdmcXLVMLyErukAUu5DY6ENwhOsp0RwgCZxMmE LVyljvV2/BYqUuPqQSrPzMRTfVdQRCaOBSZc7iWTgzWgcNg8w4vkPFFQebo2ZaMxIHicgNt3wMaV BRC20CxFSRY0H4nAXCs2K8lcqEDdtLiT5mJtJ51we5hFaj7d4RpfFbqpHpp9wEvre+pmFD1vvEG5 B+xAYwVUyYPlBdwQsRH1nMTbjLweODhwvyxHrOrCwgZuF9HzS1x+f64JxGXRofTQNVV6C7HE9IBT w68d3DqOoxH26TtbF/Dzje6epPWdK01JFTw2yNQXPWETbJ0r8OxgZsgKHBxWhfBOuYrxX15Z4M9l 4/n9uXILN+V2HJ8lzHWrGGnmdspqJ0a0zulfjEVLD1vWGnidpFkree0GcpcJrI4aaLZorvmGXSpb ZuBaW5iGnXZKtu7Orbcvv8/W31wcl1NtSffzBjfF4ntEnusRd3EDK8cU7FzrxuMB6kVnkgs6LjqT XGzCNLjWkHiMpBk7ednFokxOY9uoXuKHxipe3mUu7RiRxL5d7uLmdC6lMmXUjRUVl0PpObVwetmp 7hXsNG+cljacnZJ8y6utDGxch99sZSBwvuEQZWvIgXjT7CZkbjUEz/U5xYZbbHk4bYO93AKKeTau v0dLo3HFvdLg/bTEfSUNN4CSF60uyeTd8K21Bz80HfmI7cDUjsd5EPvhJG3ofnvYgBxYSTXFjefU zukfO/dj537s3I+d+7FzP3aex85zk/c+dt7HzvvYeR87z2MnR0CJvcQ3G3g4HBRo2IHROc1vgxBH U/jAWnkMGk3/g5eDHM2mngLbamYtPLkz6S/o2b20gZDTcqun0u02o8FjDKuNV3Ue0V87Vjw7Xklv q4SlJ7E2poKG6ZLXB0jszOV+BhfPwALtBICVc6Sk6YMH7FTm+GHxWoi/0NoU9u2XA4eo843teetF hzb84OEb1m9jPthpfiya+KdZgSe534c4a3sWRzxjd2cUn6Wxg2Va+ypac1+zTEND0sA//thYLvL9 2WiYf38IFu+qOyMmewIKjD//p559gWY+/CLxe2lfSQP/+BoIixC1jlERYOpL0F9+4H+/Lrg5yYS6 1ieZnsmn0PNfms9JIphvh4bBfJtnhvkGZL5BSDMqgl7SfIlxSPDVVTLf9szCfNuSC/MNyHyDsNCo CNp1801agH82n+nCfJ/jeua+Qs//yHzO6trBM7/+wFbk7hXezzf1X74xHDdcGN0oPAHUpI1y/M3+ +ebh8V+ezg9p75uQFubnpPTvqvyToZiXltJzvua8b6wn8h+/AQ7VjM7NmfM1NH55OsETvzydH9Le N/+Bob9Pq/9rQzEFLKVxTXiY875Z+1+9AQ7V1pNvJi0NjV+eTt5z0tOctX+X9r75Dwz9fQb7Xxuq /W9Quv7Itx9v+r98s17V6mNOffMgf3k6yfPkW+2/S3vf/AeG/tOiq39lKFcRSenylsT3zfdd/Zdv ziMddG5OeUtV/vJ0wpySJZHp/JD2vvlnQ/95QdS/MpS9h80N2oG9R2WYfQRbsCw0MG1F/LUERYnV DuBH9ZyY/TdD/5O9OSw8z/TWzfQMU7J1AYVOpmd7rkW5PT1Dnp6eatb5f7LH17m4/Zf6tIarrctu tmtOiFNxxM2u1gSlXR+LvuDGdyGkrUfaCmkrpO1H2glpJ6QdSQvP/HLJvkBh+aKEeOPzqOYCzalX 2wodU9eUdtizog/Gjx40W1uQFm/il785Gv3LX78eyT9bQrFa4tejMJifif+fSv5T+B3sy+EMDwbW hmUxGwHbLvjE/pxtTZZ6sNoDTxv2C9VAl+8xmGW3fhqljUaS35C99zHKurkzaDsivzBuP7WU7O7W 0O8fnD+zQTR2a22gpdnpQXWxDQHUiSwga/Wn2K2EpTpEl+8N2+WtpBzD+VnAmJY9xUwsKInIL2zv 0fDADLLrx2C9sRaGWTgiiO6IpWQr1575iQpDAd5iJVpy/P3Q/AyHZ+nNlwFvcrFa7Zer/S+aRljn //WUcRBQQZ/KBvZsXT+qsVYwRoAaATsKgKvNMILSERuIrZxH2glpO6StR9oq/nQOp5w/pJk7LsZh Hdt0k6P/7U8tim1fQkPrEKvQLtbFYE+BntoQLCmBEDKJOU6wIj3HtjdjRXrCxezeSq/awILSw74M Pb3dKW+kl/jvtE+rddzW0ATdnF+PVuTBggEMtRIfP4DjYg8gpdUSPd+/nl/xxqXFr1/OHxr4r1+P 5N/Cz5eb/HoUTiXf1T7n/Ivw6zZie3m+to1+tevnaHN+nG+sAOabga683uzzvsE8Ot/YcSr5xq53 bwfdT4xaN1ZYNm9gt+dhwyCQrSe1nhGfokpuy1FH4BIPDJsb5bjOP7ge1epSPrW6jJRA4ic2+VjM BfmuHwJ/8nY0amsHDNhtZx/C3WiFm/iAsDp2+VPMiduYFNFgasCWg6Sc1/kntbXlx3yKPAQlkPiJ CydjJN/1+wfzI7W1a1Op7Ziu7Zip7Viu7diuLRFTIzYdSGl6kZ/ajunajuHaEol/uLbWe5X88WrL lTgjl1H7jiZY+r7JDbXWJfY3WJodPD/e7PHwYIXx0XLtgcEtFfvZn3SQJm8NI+b5n0Gj6B2/pUIO YnGUl8OOcPd4793j3U5AY2TbSWEe7314vNvhhIxHIsYrsZlASots8jPe7cw0PW0e70Tibx7vdtqj 5Lt+yJN+MoK4gqNXjs8zVmz8OyKoRATViKD6RFCNCCoeQeRnBNkR8Xp6PIKIyC9cOFOBlUOpH7Rt jH4Oc27XtkXpbE/pbFE6W5TO9pTOFqWzRelsT+lsUTpblM72lE5iDGkt1zb0+0fWoyO3HEXs9jN+ vMnoaU8ZaT/KyI8390fE9Yx3mw/JeO/zSedk9BLPODvwjd7xWyrkIBZHezieHVa+7NiXIx8/xPuf 9l6V9Rjlb2juegvxu2UgpP3Tbozgif1bUVnozf4PFhU2O9/vK1YYccdSrMEjO/l8cocSnvPCSz7v uQCbYd63PpR2hKrN/g4ctbe8+jWET8/WUx65VgLp0wVsE2WgnN2rX0MofFdPbTqLlESqCoBRlRwc 0df/TP34sTii+OX4PJWcvyHWRnr94qwEsXime5SuxOms6OjyO9I1t46mc7fi/Et4aOXUyv1Vzxa7 vlI86SfvKCTWuY/J++5qmv+q2z+spO+m5eI2WIB1rbZWUegQYQWrP8UJdttWqBJ1rWA1/NWzovyc L/7B5eZWx/EphiWMkqhrBS3StxW0NhVge7pTP/RkOo57aVqvP6WN1f+OUts+4+lybYmYGrHpQErT i/zUFmd08ml3bYnE311bnBmL4YLQD9oOHpqinTaFmCvhhDqR2d7jaQfXcsReILENvpDSBmTIP+nb Ov1puU4JJH7gbr7F8SLd3rt+1BYDrq6t2Vbmz1rsn7YOdb/q6Z82UnS/pOCfV4j7m2N7Zop9Rzjo Vf5cfm9m/Pj1B+4JiBf5S29+vEhJ/th26c6OZRz2aHadRTTuZ7pegDXeVL9Dhhxx8Qs49AIc8cY4 +pN0qHR5QHTq+mqFbUbkAAwOvQBHvMHu/VZ1/j1hcOgFOOLNF6XHxj84QnzCI/ixBq/sBo7LSu00 RXIA/nguDuKwwz6o5AD88VwcxPFm26DL4KjZR9Ji0QV/fFbYZHO8yF96U/fIFynJH1+r/L5ayCo4 div/nLwO25a7zcvznldAC5wR5LjRQfS4mVxUuC07OGzqd3DK0pICNPm4dQGTw3aBPc/ya8+9D4Ar CTjxDDZdTht3uzVeGa4Z4iDouLLBTYDmDrUYG8pIObyXdrjDQuoNa/9KP1gpBYXXQ7NH8m7SjFAS 4gLPkTQr9ITnpKiwNG2YcuYtBoC+BsCP2CLkAelt+3QzTq4SrUX14TICzj5VdlGCYGLG2v3VdTsI IA/7BgHP0p7LT3i0S6r60Tp9OEV6CkM2DJamwl2OCF3HWSXp13UVce1G4NOTBpPhPRwnjYXrTJpC R59QGvkQWpuNX3N9ybmAaLDZ+P12mDZi89dZbqPokYdiIA75NpS0Z5X8ytNXLJsqa3fLvHhqBL0G HEmgY+pt5Jx3l1id5RqOgLY1UwS2N1NsK4WtTAIETHiuUMdqtq31RTBR2gu37lknBmRpPm8uXng8 NON4VktHZHUNt83EpyfNucl7H5n3SQs00uGs1O081lgVtytzYvy5eTn1lyecTSEaqnOWLrvufy6t btl/8vRaiwehGW8/V4pjhRSgpbdsIBjHrl4MNy9K+ORtv1bB336piePLfEkBGq7L0SHorkFo9Rfr ZhqKyomWIv9oquDw2ovCUPdQGvKX4hDNDk8SfA53tpvCAJcT0ASw0S7kMY2FXIcrCeYOtjlC2ByR xNyR8Ep1QsnP/I6ZFOtEjMbTE4wET7UyZWDwA0t1CdU2A9HqmFoB7+qMQT5Xnw0sq6NzK6xj7HvF QhTe3rqx/uTPvwX9rmRLrRNiD+Gfuu+y+bWyJeBIAhuREVu/IczGIvxpD1obNpUEmw4QxKFWJMBi VLJhLeoIqE1PTER2RHqyD36QgfKJsC42XfDIchvlHRj5+ba5lYHHQzNa8vabMj9L83lPeisKLqe1 xHUlTe3JC/0l020Ji8OyTBkrF7fC6YNVTqw2nsGwqZcL7wPyRCQQaKUlxsK4cNKEaX3kwF56wFUS niCwsUGx2YZDCcPpEz2gEj4l1DE2KYlou2nH6nu6IfIVFJV/oP/qadbqWuMJGqUKXrfMZGptKfJR +q7y4JM01np13lNSptUsnhawdACNdAOvdIZMXcllnUwG68b5QOY8oEGEPQSGjheXDW+Z1L29hNiX R8gGQvl2eEnZfbsUS42Sla7roPCxpGU74WxSQ1aZHjJq074rTWSeqeJw3CAYEccbbqcwJMwkXAdU Ura0ildHDKs6ObE4Nm9aA6y4xBnQDr8UHCUIrNEqtomrhx3OEgS8kQJsHFaBMN6QgiQc4gIoEJg6 YjMlJcz1hfJO/etVSEZN3HtAKWyx2/IEntk4bH2Cw++L4gTfd2bOVAlLj3E54NzhAJ6riCv/uCeF RjlMArN6z/DFWgFnukUJj1THhLEhiyQEWxKYOux2QMl5QvV1wyAlXFIdM54QLtnhTWnmPgsHLjZf EUQn1ORBiFB+ncj0lYYuaWEEqwfbIq0Jm+HA5d1003nj6D04YGfgqFVikrdiyKCixQjacb/tvh5x neobtT83szbjAs/dXNDvpGcbYlt741D6sqWSTNMaJGzoEPaUcdiaShl/MQ/O5fMvXA9WLw87H5IL 95Ed50Ye8P5xwhoE18vE/vNmSeFo+TAfOfziwAm+VgxneaHQOeHIq9qIieBgaSaiwDTJGWFXMfqF oMPP107w/eNsJllFBjAJdmQRD1qnMKzBZxKCljAJoI6Ha3Vhrm8Ufp4p/yik57UomGwAp9TqzB+O 2kn4L/81VAkaVaaMs2447GajaxcX79j8Fc5890u++JzNAkB9c/DD7jC253ZTPK/fxFPe/2aXNr5P tc8P44CDnWRLaPgN6yCCqh2XITIbdJ8uoV0tewKuV2Ano8FVH4E3LBrXLcJFdhjtAlxU1y6WE7T7 5thGsmP4J9uHJpubBwnhPRLwQmXLSm5VjCQMflW3wztFALPIBt0ojBBJkEAJG5sa6Ez6UvmF0ajQ +LZQ6M5QU3dUdFy1B0bKPjdSvC1SFKNoEUNtbD/PdXBYAHtHR+uxEE+YsQ4aXjJCXh6bP6yhFnhh Od4g7km/lp9IO9rufuLtsNOTIl0sgONgW7OtTjzzdbSbuJfUs+PE2/tg6gkaT5dHmKjlAGt4DYks Zp7wOSa0hi2D//lcJzDRto0TC5je1o5TvdnsmBnmNgdR7dTwVJeFRXQDMUzMrzF849h8dtx/9tz9 ailgKk54nqRhkbL2XtOwX6TlfnV8Z9DAZ+KlppRJvE7SSAfwnvrYfyutWVhcdMMCfRL4nJV70JMb Z4iQG2ncJ3/Fzefidnof7B12tZ+WdQ7MG/IKhGHXc3nkWF0j/JdzYFZfHP0mB4dkyKGj94ddvoVl nb/8zf3xhoPHfLO8v27SjnrjF+t54GGkyG0xw6YgA3P1D2m4/oeaVNu+RQ0xg3mkIdb4sCM/sJKC g0xjlAc/NAPz4DWsO6Ml5oATaaTDeHSDTOYA0xJuDw10Y0UonUfaMmbaKB3Koxt8okEJ+Io09CH1 DH/S79Bu0+/QemdOH34P+fzUtEbXaVDWxbm8wiX1VosGesdzROBI/OTTle9abEIcXBfGAb2RK2aG zRwHjWnnvFjI1jI/PC3QSAcuGWyZH+pW4Es/7GNTGxtuy1a2NrXcDHe1zGyotjMZ+yjUjr18w3Yx 184Pl60ZqJ3D13ZffGAb63Sar+4L3vHINB2UVugDh9uXrnY13aCRN4uYHt9Yj6ByT63S3pQFbjbf he8jd+CwG8odOoKOsvQGsrhmQRwj5Q6GKWlY5MjLoX3ox4v1hh3jGBhHqbUafhUvtaBM4pG+dx3A m5riHKmZNtwd2vHCTT7n4Ql6ruME9evx7EzP9ngD63jOgDgeb6rVQBq27MnLzyuleh8W+arqFm+2 z3bCa3oDWbyynmmoM0TsdhiNogi8irQNnB53fGfQLE46pH6SSfxEu+sA3tTUtNiPDfSAbXmvmw2V ZWsPNj/AC1ONuyTWIeyUdHA80ysp3oz0Bi+RH9Z9rdyDoedPLPrejGEb250bdogbaYibz8Xt9PFZ RLm87BMTD8Vn+w0fj0PbMnFxiaGwN50sGlopjCRgTnUZVSvKHTurgAeqD7sTopXBaLNFeo7HQ2M7 dJ131JQJXIbrJ+zVnPUoUSV530fV0EIVVh/MjAdNu8I7qsX9VJF2dAF2yQL3oN92on0vGsboUc1x IUnTsNCNatFi06tLuxkp8Ew9N6rR+mDqCRpP13ij6qQ1LMbkiB4ldNKbmtUl7FF1KXzDtn5X2nMf PWKQql1WZr8crxkcjs0zY7WQyhtYmBrvkhX2QSuj6fLq5RKWv5+03HuOzQNOY55x3pkVKrHSAo10 AO+arzV3hDXqn8Eax2bNbOmj2VZY4MN/NStj0pSR1ijfPK2wRhga3cxn5zULXCbxTRrpYLzU02Nh suLiMqtdkmM/Us8j9cQwEz4VHNsBPv15s+qJSFo183nVE1avliWGz437qzOCe9bkttSdG8/F7fSR dvN4wx4fH2W1NX4aEMImkhqlLPCYSTNr8mKjr2IJuJ+kGSN5Z0mZiiWk5TF8k6b25IXOkun6Rw5h 0fyvwDGa08bVgJVx3EdT75VTFtbTEPs5SvjscsAG3wCOhxPO+NrxuA987Di4jpYdh9wHT56Odp1D XOMWrTpnGylMI0h/pw7xfRtcDGVaDF8lZV9yPbdkRl/+dRv+qTcY37/hDYOrQSMoynElfP4dXh94 gqmjxvdewghvEChhYwvdbOzo8JOMpSjxHR0nxd0Ud58m2sA5LIQadIKqNvbzS5ADyBODTjLLBp2i ecVLlCBjZnN0+lfTBp2Ge2OqLbp9/AnecIhBp+Pqz2xvShjgDPs8YQw69TSKhwgxaQYkNL4RJjxh J2ijcSJGyCYjUrzROnNG0Ua7xHrn2I6lAWZgfZw/rHFlaxucGENt5Y7AtSRN9aFSO3WNXSbI5GGY GGgOzJP/hlf+n5wYWm0lpwaaH9XA1HhboXBPSVxv7TgGn73Tu9EZ7vFZaGqzYXLN8ehJg66qf/Aa tyAEltagKTG10U6JKZh24ugJDPtypyXHd4FvjChqBA1Dihpxw815Gh/BLaiBrZHmNDlKiEHYkAnM EcBSRo64ecoxVhsjMBhJ1Vic8GEaGB0Uhq770RWzGBj/bLz613FJGtRUTHlrWNfT0rBt4JtjfQUj i6zlqCnnf4Rv0kgH8B4fhOWoXw07uRJMzzXOr1+n+iCvRvdoJ0cp9PyM5D7uy3ucm5pobJDpnRoa OrfTR8GrHPNhbiCcGcKV41nq0NSeQU+siynB0/mZxq2z/sXDcw6M6g5o6HKxmjlJ9IW3kjwY29XW 0LJwWpnmRfbDiijvuh92DKdDW4EoAluAKDabypUwm8plhQjIIgYCDnKCbaYwDjYhCY6VIeGZ6ojA lCQbVKcwGDTC0PH6YnJYybSY7jurp2ym1p/rCuJh51v6c8yIUj+jXjsgv9QgOHKMzREMN3b6mmY7 j9U2Dv8S9HlEU2tplsDgDNY1g7Xgxy9BnVQL+o2DbEC/dWwPn+MeSvhla9bDnrIGLF/L432qE9lg 0e7hiu1NWzNvH4bRF/mbw/kVE5m032YvOadpi301pwkoXxnBejzr4r5gccaajDUZjYCtHbDxW2nR ryrBAsahnT0jgtmCbaawmUnM1BhH1jw+9SJmM53aC4rE/Xm143+mh4AXVcDr6muRKdj69hQJPRmc wTPscF3e940icVZS757wySLeU0voK9Aq5h1LxBFPyMLj64NZ5jVN0QK+VQBuz/jlcnwy28It3nxW VZ6DjaQr72ET7lEOapEXwKsawHpfRY7qI/HoSTNu8kILyeSM6kMjHcDrmtIGDtRZ0NfCOWo+Z7PR Hv187os8aMM5HuFOZSEuKoRwLXIrcX+4Kw5hRG5WNV+gLc9bphU8z1a4raTpCkTj1b13kop778QR b8yzlcPJ8HiVtuDY98E1cqV6ITLeqRxaz3PTg/NJFhy1qnD0R/5Quu79wDdpoGkGX+gAGqUFXp2b ypxo7KEihSYvGUdjrxSSWluJs2oybvke+K3MajsZ1e28Ue1vzDft8RnvVRFeGdVtZlS3/EB9uIaf HJt9TgMrZvrDZQLvh2ZnVIem8E0v8dECThv8TcVYVdrQs3aqvcWn28e5yOsVFMbITtjgeOT0AvTr T8l0mcD1oSlpQ2hKG+ZOG6a3Z5D2Zj5gfIbjLRWjWcI27Ku+JWxQl5O23Yx7jaPRTn1/YSfnmyKt sFMYuu6MuH4e285j800a12GEnn+51hzUBZ41S9xUHJs1s6UFs6lR0wOXmzSoycQLP0om8DhZHoaP I1HqyKj3O4fpAX8DncYJj8356DQzkvzEXf5aJescdScpSX5CCmoc9JHY/OQ05j/nxWlFJUv4qtEy 9HEq8GpsCjJXy7IXuCRNHckLnWtJXN66dXEkBHX5GtE2KfkGskbG2Hq8pAVppFG9Cd796LfTF45h z1PunZcnN/XET/3hOoA3NbU3d0Xp4bFEjD3HmDRpWXr2E3u7ngeXpCmPV2+WHq2MpzV3pUZPyXBe bMSo5cEPTcvS40cpMaL3iC5Mjfl9vllZf8QED60+6QFvipkHollmBw3V9MCp6YFTzoMfD9z0gFbt RVruAcew4jzW3fSAyyROmpO9peqbw6VFTw+cfh47/U3DVFTG+hk7bZjZIjvLtw7YkaE7ltZ0zd6X p5toZ1b2zi0IBn2ZBHZjcYwAh5ZeLU+xzarLpYwSAlVnG8HwJSE2oDhS3Gic2DfqeG6r2bjjB/TU EFK07MCo2esnfPQbWqtj0EfP8ONq1Y+vQxu2W3toxZQNY7Ki/7rdAW8PAkv89kjRFzPZQuQg0Ipi Y9PsgAnT6uMWC9KQsBOsWIiMjY4Stp6FyHiunR6Wnk872gokPYeUcUMKF00Crh7JLC3e6r7kGOJ2 e8Th2F1Sc5QNMs4KeKeLW4xlY+NZ6BDnN7KDerFfgufe5zDb9RxSlLdGPUJrdoZJ0Ku7bHE41Ry5 5MjPvQ4/pzvBvc6GpHuEpidhBB5U/dHNdjCdCG9fBWfUJ2XclvA8xrLdwj1XMwVubvflbivmgD2V 1l8hfp/WJ5A3F59bQttXk5obtidk3djIc147Tjgjk7aCwtg4G2Le26wuzHsOPzc4wb3OhqTnDLiS QAkb236MPdrz9Ik6irz59Wa17O3z80ndfAHcp5DDr6w5we3Bdq8LMy205RXwRMVwFKPGdlPYjYg5 90TCN9URgSkpNlNdwswgJSHbInN4qBW04LnmfDp9nd2X4pUvbIWE5sitsAT+vlqVF0xBq+sKWke8 BVRNtGLJsuUlj8SOVJSXNzPFCW4skIamJ2pPT8IIlPAN3WRj5VVYoK+8SOsvt4dveM1miyytpUdx /vBO7I3Otu0XxxyIfTATG0B5Swvyo9a5PENq1ZLPgS7wSNx70rBZQ95WPYu9kw39ao2FloG/OAka 84Hz2qGWkgkPKC3iLCuhG3jnI3M+8VKr7+grxMF9SkrNWqbyBhrSNFW1xstrY1yqOrrg+O1N2/mm 7Sfv9AZ5x8vF6ZvWo5qvbbTEs7xy15NilAjI9Xg3uYo/yN0ZB+30xPeNqM5xS2JV01ZaHFtp6SOl 9h5V34dTan+iUUs3oJFWukVaKjOBLfec5t7ghZ2SSdwfmn6TNyIcWqweXurRCoE9q3vtXftOL6vL SXxW2qCCCt776PF+Y+pQebyF2DUcj+YjP4l19OdDU0eNJtP3pj9yZ007Zs34n94YJ9WKT1z1Vgae 7/jI/Xz+ttfwJtJ469g6b8k392n2+Bt4SCvfwMELWoRrNH1wWqZ7UQ0GSF3taf3gl0tdT022npIR rRSjmTWlZsu0xkA9rF1qVOGkUA4y6PkJ7/x83h4fqFlBue+ntmpPE/Jcm5qQ59rVBI5dx4Nf36qj yM340ezw1XxeEvfO6HNsJTEaHsO7X5K00mt7ZmndvsAdx+7WKIlaLYiS6NhKUzRLbvDShpl552mB Rjrc0NPt3BwWJcetr518Q53uSF2feDpPPMWWAFsAXae+jRiQqbGIvU55HwMy6hQZzWCXELz/f2PX kiA5CEL3fYo5Qvyg5hhzitn03H87LQ94pCvpqR0loKhoRQS0OMftVB1wKfAr/YSjctCruQsHjw4j kjkwj2i3q5nFHLvVzOJO4S3BJ+nVDHSE67zL2ZHraQVvt0tT6xlMz+B20zNkMoyagXo4yBc7hwAe 4WDuewF4Z6VMPnPoEeanw7AjwTHotu5ruReu8Q4jTyd8cFRtr7Csu42jB8M1Rs9gHT2jgZHqDEm9 Thipwv07ZOghp/cGL4IbbC7v2pvJebZdAL2Z1IsB7QYsizRYDR0mKuoCniJHbxyGqYjz7LwwLVEX vC2lmdSjkd3xfe/Z16q+9/TOvacL9x6Dbe9BH84JfSkpz4euholD+g768HXYNDP0UWMl2ZpUOVYp hGuiqYu85rZ/qF+vhTAswmo08bAANcBwbufJFRN3dR2mlRU6v4QaudL8wORCenD3QW41/gjbc24t HxEMQW7t6dkihEXT6voI4IleK18cGX+xBuETO0O97VyaovkzyjHe+mDnpbyz34qxto0qMJSqemAj giscs/1szKNYgzHwkKxxSyUcpiptH+FakHcxvMSu4SBvLp9nlgoOepDK9zPFFFyWKKb4uafD26j7 3Fa7rgNHWYTrjH7YdR14G0Nbivv9gwrXidtuVe1yrG/Xl2K7vj5Nie9jTclqpwTAMAqDZtQsq9W6 /ZmcuyTukriVZiRZLfBou44UD06ahPsgjVTySqpTUluSeqC8K4fw4IkZUNmlF+AV+0c1x24NvUEW MkjULJRma1Pjfh7w9lNzGn2VDbzNX+Jx3bC2Qh5K1ypXRbNTn5bjhKRadimveVU0nKm0P63OjIE9 CRh34Y3klq5lbXIltFkID85os5lAjt3C8bAQs+2t5rCOnzBMrKVZ9DoVnonGZFDekLSoQ+4IzTVX TdVcnBWglcgND22FIdfgQu2OqzHVPq91a6Vzl8RdErfS4KQG3oOhdGZvVj1xuA/SSCWvpDoltSWp B8rb8s7WhTtFl9gpTmKqpkjlius+b5t7cNfoM+uGtCPqlRZjcxCDZ1gZyiYp/NCc0UFjfVU5/BtH c/mP0I34ymuk8fziPgZeJ+BEU7kuKalKgdB2cHiYvM6RY1Q+oX5LGhuZ/DcQ0z/lXUmOlbVGVhqZ lUbjZPCf2aOVZhzxrfn1Fc+gvWH5ATWv5cl0lBscEeod5ZpHM3JF+o99fMhpLSvpW6YXlkuqP4j+ kuRH+lQ+5DadJlJuOv2QS3lklfROWn9LzQ0AoeCbCP1lMhGzyLIuLEH2HUNhXLCz3jQjb2JyOwrf 8lyFfuZZxzepb9u56c9Zoz9f/z9ZAmAUfgcT8phs72BWqm3l2iiPyzZ6xoweah8Y/jLFJ6Ymnnbh EbYDODAt1XbFPPNE77ynb2BWqm099dTX+v/GgHTcFG7GoObafhi3qOGF57m257GuSbZ2kU2O61gT 8zwLLcl25XmubaTaxosEXtsV88yzUjvrpR2v7YI5fv35+P3xD/C2n8tlbmRzdHJlYW0KZW5kb2Jq CjEzIDAgb2JqCjI1NDk2CmVuZG9iagoxNiAwIG9iago8PC9MZW5ndGggMTcgMCBSL0ZpbHRlciAv RmxhdGVEZWNvZGU+PgpzdHJlYW0KeJxkvUmuZjsPJDb/V/HGHtjqmxUU4GHlEgp2Aca7A5cHtX0f RZAM3iwkkIj7iaRCVN8c6f/9p/zvtf1T3j8H/+3nP//Hf93//Pf/7z/1n/fvf/z3/7yfZy3ln7W+ //7H//Wf//t/+8/5539+Av+nCf3X//K/Cv35z4XM/4Og8mTqnfOf2k//5+c/rZRK/O+Ha3m4EPcP 70O8Hm7Ca0lmFelOysPmF8m/X1x3Of7z/bX2P3WU9sX84fHwgdRjNOqKGIifxn4h/UDjo/Nh2j2V v//rv49KPP33P8aK2mRLbYujn0gFtSXPuB+rWTe1F7Frz6Q9B5mXL3VztvDBdB88mSmugYtknjeo +8V73KZx6PISOQS7vcRuy3+rtGC3qtK2KnO6jIdX5FDgkPk8vF33w8Nt0vP++0uNy+8uO2snXCUz j3Qff7fpaWHKXmxMWY4ZIY/rl4c/jpfn1cv33Ubo7FYjRbsqH3bZCQ+l+k6l9NwoS+tspc7wSjJI kem+VLhN4h0yzmElbs45eAIzdyjDHKQuc5Y2HUtm3RZlkNyeV8Zn9XyWnlfGF9sxFvOL4RSmYL3f jfV58sU8Vx1/VpfLfLFt122lLbfZSq+My3LqSfXL/Hh4yb9njyhJZ+/wxUHbw9ITOMk8P7ru86/b BO43/EL8x/+6bD2e1P1Vt+9V3X7Ybd0pHxObRit3uAZwCtnDY2m15pDae+g8/K/jGS1Iq2t7HW1f tnop+HD3OiocMvCs6cKzZhOejd+/Ohryu8vO2glXycwjXfCfRxj8/3hsSFmOOdJ8q9J8a6S51Six rbXiJfbDy1vND1+voa31aGeEi2S+2mS65E2b5NDUzhgHqxGtzeI14sPLa8RnqHqN+PD2GtGaeeZW x6gRJoMaYbqoEWYTNQJxvZhH+6z2sl7bNfonBfyv41uI+8OXuPzTK1q+0b8C9WHKfzELS6Z9Bdh1 21c03Wb7WMfv50j+6/TdTvsqmHCVzNe8hi74m01PC1OG2JiyFPMLOZ/cKxmeZi8llLMQsprG6mmg 7zOMGmsyvUXqKnL988BLRevER7huyTyvmi5Z0CbxSDKzSfcX01bEtJmfwO4mpicx3cqHupfyir+T 9Un5aXleZB953soJRo4fU5dBCu4SPpLxuJAa61sZ86sxP45Rbll6An8loE2lpk2luI2bcJVMn5Fi 1k7FFSkzjNSYDFLTlRqzaTjJzCndVVOdeo7y8tWt5SUPCwG/Xk7w7kVlraEVtzRYDiINpykNO+VO 8qrLgN9RmTKbZFQk01NuiuljMcoU01SH++3Bot8aLBzDkskgBm87Fm0GriNkRlUKRpth84s94jIM DiYDbqZLznUIl5lTM1bkyBjLc2RHCG2lUjWs5BGrrRp7RukcWx4m9vjmuRHftLEPuVsIbM0jvnOr NMwU31wj0s1ROv0xp/w0U0l0medX0yWLpXyYO8mQA3WD6WOxilrJVU7y2UptD8fUptFUildXTVx9 h89WF4/VPb5Xa3ZlTrwWfle18NusrvbX73Ulti/E2VIq7G71cHvnHsJCwHEvlaO9lC97qqztoXqw h+rBHqoHjp8/Xab10CWLqXqwl+qBcaCuM2UMd0T7eLwm7ITrw2J6Uk6clEOnqA09RX3Xvuq7trUV SM1V6XCZx/QU9V2nqBZYXJRp6rvI0/PqnBo58rByxELIb6s2npQ7Z6lknak2/gy18WeojXcMHqn9 PikXzKbhJLNVs8T0laqbxhD3V8980xjippJ0UxruVj7coxp+j9Jwb4s0OH48XObxM12ySK3RTWkw DtSdKR9GUT81Cutr/6rqKNYGf8X3k6GlsSgvXLOlcf6yZH4atUXtA/7X8ZjOcNQZDD9sdaB+eEWP 9+Eo3cIlZNo32XHd14K4TXJgXMFHvOuNvPpw1IfxTeQU84n6EBhMz1IKblPKbuTDaJgbU6bVyMMP n7DZWo24DIODyYCb6YKz2Qz+Sk3rbAPrII6Yh9i1kdjNxG7FuB4D7mR1R23NIR+r3lh++iD2MtMt Ra+cdEvpV/E+3IWLylK7qXdxq69Nc23GRm3iMrzdM23qNq8zsFqiJDn+ZjAh0yLmD8smsTFtKQVP l6l8TL9J1BiNrdXXkIxRrYx9vhiF5XC/353pky+W01X4azBd5hvJhW7vK2x+4xrGpVo1evR2wMqt sU6UgQhB2RpT+Th2tjZrY8/7sJWuV4cmOb652BipVI9fpW7cwjoES2meNabmlsDRRnoI8nKuEuV5 ziE8VOPnKFEvZh9RX2aPnjfwq18u80q26ZLFUAtkcVFmFemu3EK88ZGnYZUYE37Dw5M8uOhbeG2x 10eLtIz3a6kCT8kcyEcfPtZSOrmSiFnaWHtEuV57R0113JLMS8/a0Z99dlSWH8+Q8dGJuNEmR2uM y3HiD242HwZnz7OXlrWUxl2VdnKjTwzDVyYDH5Jn+FN5sO5SHtw0b/QQcrpqK3ZROdq1JOx15dXf 3XfUXxurof76OO/V3z1Vf7e1l6/+On71d0/VXx/nvfrr479Xf3ffxvv5e2+rv/3hmC3jd8+f7XO5 4r9/2q9J6JXj79dU+BrJKFqnGW9eXzgHI6YlyjA26BasHNFmwcrR18z0WAd62w6Bx5LMbNKdRzZX VVzAxmFqzQa6znkspoUpw2oE1wEG11CUGl8rufuv35uVhoG1qQavIm5KRQjrJ0O8bCF9HtKeL2cP H9hYgtrmA+A93O59awab2lhXqCHVqjRaWWG1FZN5sV152cYP3x/C8JTJzCPdlwa3CVyTjHF4uo+b PNAGWtyvtSYODbY+tMRyTLyaZNgSUXf/srp3+FUhL2fanZGT1svi9279HlZ30u/tzmyX4zLavbmE vO7Z09E5+wHH3uWdzlaLeLRkt3OWSDxKsjuqys6oN+Wxh2CloilfR68J38jjYd6FLttb5PEw7748 dvzyyWVeKlwXLMwmcZIxDtCtuZQPzmepYaVoP6lDf+ynfWjp1FjLMJz99Prx35bcG/OsqC+Lo9KB ubyX/v4wU1ff3L8x7k80cFmSKV26Lx/c5sPzqJQTO4tVVvBbv8r5msot65moYeX85cQyL7+ccPy8 6TLPyyvVhTWVE9YrU2YrF9cpsmltIOIyDA4mA26mC85m0/mrVL79NE8n99bcAx6CdYOyQ397njyc 8mSb76Hbe/DbXb5w/NLjMi+drgsWTfXM44JMUd8gpohhYgRFfCwXmjBWQc4U09OVgp1S5l7CSklX atgTR1yRmlTHXAZMTRcpWGr9PC7IGIcZPL18naIW75Sd0ukhj9OpyumT+oKT+ojTc/tz5o527SS2 hyNCxrdUH86umRXn38Qrl6A71JLe1Nbf003qjX7e1t4PYxxF/Qx+/zd+N1bTf7c4vro9PA5gq7+j nCFLZ4jvNyNvnlpgj6Oq/Rt1ikddRTI+Inm6+5fVnXjkfnqkfnqkfvqbVC3hEiOgkfrpYbsZL48/ 3L18Bf7KSMg8fqmfDpvANcmonx7qp5/P2oiWDVipa5a6l26FPFZtbunk/vnrNkqk2+a39IeNxqBt 3F+aHIOXj9g0N0YMvZaEk0yL+vYNf6M1/HC0NoEfB5cBtxatYdh0/vJNny3S2WfLIbsoZLvOi+WZ cQ+MGq2Jz7MNJyZXOd+PeWnqd6Ti0g7m5TVGbmF/WLzujcBHMquKA7FkPC548qTa/FlWTo+by82s KjfTV8YZ0lUrOC/2Wv/2DbzWzxmt4rD9BPv9RK2fdmrqmyLv2F8l5vrK23Dwkf5c2rV9ij7qn2Mn nGS6Zgmza2eXmHV+3pV2eRHydld/LIQ7rS9kFu5mvpDxdjyP4rDdT2pz/kk8r2ToDeqy1aRNtk/P Kd3arbm78BtJuczZ0r1dNsHU4gI2DpAxbtA9yeYJz7+dQM56wcJWtuDhdqawWYLMVu408+TuMcZ/ 20GBz5bM7dJ9TN0m8EkyxgG6Pj8Hi84ZGVh07oODha2pgUWvM1g4PlsyLwbXfTH3Jt/1nmTGkC5n 4bQ5lU+OwcFkwM10wdlsOn+VNdsTRcyxvwhbHjK1W0r9m+welZ2+r3hwJEh+VhbA2zDSYzJI507p P6oXHtfVrit0xXRjBoPWgJh1GzU4cI19UDAdUzX4m0EIu5eeTJdXB3fUIy5PjWMwMpnH1HXhU8/N pbggM1U2h+9gIEdmV47MnnPEQx6/yT058OYpRsMpnZM7QNRdSoPtmyINjh8Pl7ldumAxlSMeF2SG clNMwQInk6jBfdaxCnZZkep3ULFP9stvsxXygX1sCkurzb8seVu9ccLVcDuR0t1X5PruKrfb2rOx E04ynDmoHXWbwEU5uu2cpFm94rdvzi0P4dg78TiqP9wRNZml+mM7qMitvVR/HD+Pu8zVLitZbOWW xwWZo5wW04ndVNafM4hd49Qdlmznk7irdT9cl6Du+GV1yDMK6djtHApZ1nvjr3fU7sekrqfv/T6q 13f8xRZ4xw4h9N/onKuIj9mHww/4/V//vRr74r8bL9/XAy7nSDtK5FtJfX/9GK6+Y0j9wXRhVD2i JH3YSlj7+/chfyHEvGJSHuM7t2Ql6cPRXg07h0S8o+Uf3vtCd1mvVPT7fiN9zgyfDwfP7aGEhf1j 8VqJCXy7ZMA0+ck5QEYtvXFwL709QE9nq6lGRwhnE0pn603Y270nY+0pdGf06SNOAyKljbtHwG+B 3TUCv/F1KbKaPNxuFbaxC2TMeyt2FhWXe9Lx80DTeCh0wfQ04ZtkPBeCp5eS3qJltT1JT6eHLO1c gqvNSajdp3CUvlcTuo18X+x9xcgEv/8bv5+oOd1HrOto9X5trd6vrdX7tbV6T8x0U4YjMOjaCjxs 2sr8ulq930Wr9++ojMu84zSu+5ptt7m7Vu+JyYEy5AZd4wybsXoPjbobU4aR8g1LsUq/6/uLPTOx t2jUYU9IHeYwMM/NkkmrYtKamDT2QEg1z+XSG45xso4y8J7pwqtmExwsruCj1DW2pJTy86Svg8Mp uh/H3Hlc961Pc/9nYXTGWcG6WHkmj9OEd5LBSHCoBLhNYLbOYNTd+4un30qUq8F1B1iynWZq2zgC +AzFtuWZvnt4rFsZw5jSyg9O+xl+nu9ellroIqfMJpkyLmJygIxxg65xhs3h834wHVzzh7adAyTm Ch8tLYsZ5/UYQ71xdg+lzXFJMi/PTBd5ZjaRZ/F7D/mFM4C0g/xzvJdk4PWl/HObnhamDLExZSlm T/PkiADpnD4igJyFgNWcNUrVnFvYmEBm10jd3MrDydXojfHlUR66zPOq6ZLFUjthcVFmKg8T07eW XVSfl9Xb8dbKebpij7c+brk+K+Udz3uypb7+suR+2rNErdxmt9e/sPdx8MELcZ9zDOux7KVytr0f hq8shDpbrYutGVP7dGFvOcDreM3EOFHlwk7LrTcq//17SawO+YIVpTwlb6XXS8JZiv2kkmAn3igz VM5tLIrUHbYvKAmOX266TDuhSxapbT+pJByvgy2tQiNFdyj/7lA5ukttwd2K+XrZXL5STab3qFw7 xnk68/1rv0wX3jab5LDU9l0fM772AivbP2ThK96Pna948/davH2x3631/8a421v/b4wbHv5GyNVb El8Vfzny4e2tR+CdZDDibNFmh81dGFewO1ul5BtbFvcwcJQSD1kcaSYe1nIRRzvvJ+eoazldNEp/ pSRwa5JpOnVHFrRpOMkonzPTN5LrVtIvsbURHy7eLvhY923ufLgJW32fseru+WNWkQ+mzdioTVyj p/Y1e+pai4TTiDYGqku4Tcl0rfe/zbNg1BUXZSwF0LWvl+jhxvVt4rPEwks9RsFdrK2kX9sdCKzW /8MlctP29yMuz03HL0ea+lTXJWu1/h4XZdRzGE+vVT3Vqp5qVU+1qqda1T3X3rCrv9nip107RsDo 8/F7rP6+SdOngryt+kLohUydBaEtX8V7h0UjZPb47oYaXAMkpkcow5Ux6nJNgVb9mw9oWN5Bg7sz OI764UJtjEtpCWNOw28M4TL44sN0+cVLE15JhnlB3d1kk6sZjMswOGylxnXB2Ww6/5SaC7++wTCw hdwIoS3WAmj0MoXriPhsNwe6vYmfnd0Ab8cYD5sMvjsx3Zd+twlcJOMc4ItgihjY5xDz1APy0PFc MUYl051SsFLKLM8hM+VVWz+OuCI1Q7njMkiN6SIFqRx5XJAxDid4eo70q/LM1V0vzx4yMdZXeR5V 5Xk0lQAbQUPXzpXA6ugR3xspdlmdHAfA0myKYXrePplawzPTWLxz8v778xL3pVhb7bQmPOb2t8Xr Hgh8JPOYOgfgmmQsLuj63IhMt2rnXFtMV2I3VSIdw5LJ8GucxGKrds6TZNhHU/eqds6r0u8YHK7y xnXB2ctp8bg8NYtrkPDXslzmtzhiZ9/iEHexW8nXy0frtMp5BTV+h3ANkiE+Y0c6POSlY7lfcbql Bfe1VWKWj1mgsUeJXNldpXWnMrZbCavbSzTOv5zw5rb2ACvARTXIZfDtTmo/3CZxkjEO0PXTYYyB 33QQc10E9cfxxIp2Yprycad83LtLJpXDncrhTuVwp3K4UzncqRy6TeBUDncqh1tt+JsTcLccrfvx 3XLwsBDwO6k9PCkNJ6XzXPV0tygNl/090uD48XAZfLtz1dO5TeCUhpPaw8T0jeC57wuN23K77yHg 1FZwvV1puKlFi7kA/9pq967n1rNkHl/6qoepWyl1JoOvelKu3K1+7J4kY6UHutaPbazGN48rMDhc tbeuC86ptF0/KfxGTqN0tntvDFqsdPN3arwTy79/T+0MQuDjG1Lvk1+TQvkZhR42nOrMKDP632F7 +a/OBJ4r5jMvRR+O8jbKvgkXyaxoAT77V16aS96b0f+GzDsT7rrvzLrbJE4yZ0r3pprxdaYx7hlp 1DjsZDJxi9r9zdqidn9Y+VmL8tkxZoImgy+R1I6HTeCeZDR+BDflebU6vC9xaOxkSSVyxNkCpmFZ T4k5ZS4Nba/wQPM8ebMK8+s68RVR3fqiCAxdBt8yJd/biQLiMyVjZQS6V3nroz3Eda843KjnoQvO qUw1/+IcXurW9wBzpR+1xE4XvAMdOJLv7HpLrQQ+FHEv9X6S3cET7PC+7XMjRaPJ46NP4ZFaNZwO crvDvxig3RnjP+AY/0XIS/tY0RKMsbvwiTHGsNPA1FW7a9hr7yw3au8c0eMFniu+rIHVmerETHVi pjoxU52YqU7MVCdmqhMz1YmZ6sRMdWKmOjFTnZhRJ/hdzYrctu9e+Hu0WBt/XZ9NjjV38sbiWSJg +wYZ3nD8vLGryqCtPsIDW2NyTMNdZt3oXcY60bsgLvfGSu3RUs8RukjDVclKI57gcFr67oWM+omy tKP0Im0W8jjtlLt7LKVnKnd3ngOPrbnhsNO9tHSU1/aFC1LnGAyP8tF1wS+l1L46hswpymvbh4dN W1NFXI4fh6M5aeg+zm7T+avGHZszAKca+wtrXH4Z4t47M7cKhztb1PG1YXC8qZ5dW4F4JcvxK1nc 0Sf3m+rZTfXsNqXvVvn+pnp2Uz27qZ7dVM9c9zF1m8Cpnt1Uz67vjDK2u6ME3FvFLrXDd6vPv7uK 6ZpimvqRm/oRlwGLXcVuq3W4qR9xDtC9qT2dpcUcCtg0PhyWZuk94TSfnKVOb6e/kJlDeBaXOrkN iZD5YlxRt6bt0VJ7V2FfGyVffhHz+qhZbRTdcbUeuX+0f/1ebuZbS5Q/k7Icm3VGjk07cU0N1fhZ e+TYhyPHpt1mg9T5OGV34c/rIfN8W7XaEDaBR5KZVbry35Oy8cfDraRR7rTT3bDVUv5xBBJSp4QH bRXVfl/hwd+/p54ZIRHH6cmDvce4aNr5Zmj4Shaw+oZp65/UtdnqVwTi9+dN+/749USzW4p2sr8t XvdU4COZW8UBuCaZsqXr5wOR6neeweuFnW2gxlqypJWP2XcuZ32qXvSd7Q5+KWaY+i8nbM/0jbem 7ZnCLrHbHXOE3bFzfbMvleDZWWJVZQ6NFD8cI8jAL+Uu89Lnui9ufsXsOMm06I3n5J4EbE7z+IvL 8ePgMuCWSkOsmxWPK1Jjq8iIOVZkYdfXl59dX4V8drWGO6fWduf87aWrXJ1XuTo1B5923pC4xhx8 Ll+1+3RXy1btvCE1focM1ZYVI7GvOkbI4740kvjwEV6qLb6SBN2tPFqRPg8Jq2fI0pGn7ftgyNj3 wdC1L5dgdccexNeJzM3deXhhp5qU1ozm9rW16b//+c9Xef/n9195l5FiEvxN1g7xv46RCfWdi6g8 oIt7Tis/CcDdpnXwisp3n2ng2SQzjnS/XjhsjqLf+5J8O7LTks2abJYtXfA3m54WJg+xWcoU8x+T 4+UETKdfQWAhODhlIWuGN2bN+jPpcwnYsC0eUooX/pDx5sV6nVdQWgrflZj3hhfsSsxHO/A6ktlJ F9d1ms1zGFfgPiUzunRnDZu84Idx7SkOjh83l6lJF2kZ8rjH5elV6g8+XbeQI09um8wzX/aZkUfH r2l9cq2U6/rArs+BFO3eIbt3zKx9kzavJeTv3aW+MtvKIEfgnHft1UHL4cbPIiKkzbBcbQOEf7Wp OLnNSv1feF6lHiE/jvuvEPmldSyUo9Y0HrRCXjVO61FrGj8iRq0J/NWakHkXRrru4+c2wVW5Y9hZ 8DI4hvhnyqaP4yYW4hfK4q8xT3iBywsm5Vd/wtujrPC8X3dmOkdxjjNCf3aP/12KuYzZS9cqK9Iy r9LIS8Qow46HunaV8CvjgT/jn0wL37r88/nk9amvNWs89INWLuKd4FNYtwa5WZ0L/K77dHmk5qaU Gc8n4/Hu4PmluL2rSXmM6MP3w5bDX3/YtuXqNytq2/zdgSnzLul0vIdk3pWopjtghzbfubbmx5GY 5r2tHf3wqc1b83baCB/x+iz68XSVRcevLLrMyw/XffnkNh/mVRP0y/bLjZFTt7JcvRy85tVn6abc P5Y7wKcpNsvBp3vMw8/mSTl+rCTMhNeRzE66L6fc5mPqcQFf5aZz24nzs3mr15jH9A6VeE5WDZ8q S94bl4fZnrwP5/kpLOpR4Fc2Xeblmeu+PHObo+j3l3qXx1Fas9OSzZpswuvqdcOmp0Xth6dMMVtp 7gWLkCjNvXgf8tJjfcv7ML9Yn4PP7ry/GsJ7SOYdJDPdATu0+UpzL83L0fuou1jL2t+BY3mjlxPj kQ9fL832+x/6PrTfBxKu/TZKXJu/X8+r0MaN8m/98qOKcvyatg+T5bsSnJ9R1jd3sMvlDe8mGZY/ 6mJYbTYxDa3v1iO/RH7ionnDrYbM/OZqrvtmAm5z9riw3jA5UIbcqHuTTZvC17diiwvoPWXczmcK uG1Pq76F/3F9IZgykPcYjONdAs/Pqex3piHkof3mLa4Nhq6NOGYL5qYd8oz7sZquvfwS+QjpZAW8 f4XgIinTuSVitOvZESMPf9JXnHLQV4utH/KF291MX+ASMvCg6Q5eF6+yYXEFH7FbOP5tjMbNIYch NYfA09weNx2/Ah1cDsdf4HLYjoGLXXUOu9vL78NeZt8Ybysd28ovLmtfN9K9rdzhsnbDz08mA//t rZw0m2C6vWyu4AAZ4wZd4wybp0TK3rXnQ6XudEq96+OPldPH6HhuHWFY7cpp130szlDNOTPJpFpn PQltLtVSx+CwVPKP1+oZNoN/Ss1RDh67wsDsWgjsHrUQ5zbZYm8FfG1qaX9xnDvfDOHa1Jm2LAS2 bhcvblkbHjPiu+YP6Jo/Hr9rrdDzh+PnJ5d5/nPdlzqzSdyTTFeuB1OywKKCsaAHyOIop+9WTjuG paNcdF3EfKPsNesdn0zjkVvo4q52s4k73C2uwO+aepN53Fz3cXabwT9S07jZbTH3lNMRArt9y671 iNAeR3imnG61RqsGHDntIbDFZVzTvzfhovg4XiePfZXuveQPw/CTycB/povUqW31uCBjHKAbTF/r 0ypnm7MN4tAYssRFXMOzZQ80tnXAueVs3KpGq+YX/9vv1iK2v38v2S4Of1qMO+dls9b1Yn7Yw2v8 GI9eq5wjwGuOkfKr9Lnui4FLzoZrkmk9dO0RANjkh3iMy3EZIUNuTSXIbAb/lJqpEuSf69WJRwqm ShDnvqaxpvBWTWhWIqB7mtJzUj/c+l3eQ7c+leo+o28b/MtrRQ/9N++xOerrn5qPL14O2ygCdsdQ rvITcJNpMQZrvDbDbFbVOx5spGcdf/2QyyAnTBc5ZDaRBouLeHTJjCtdjesaPze3uDIeXt7egxdj L6X4NKUs1bQRownMREePks9Pw6kxu7Rni3FBm9X6/DfbrlaaPn7TSiVm3kVpcJmXNtMFi5l8MZvq vj3oQ92h9tUe/aF9wyXJgEM/kTczlW6PCzLGoSRu4uwlj9eCkt0qM4WsohC/oNPk+PgOpdYI763m bfgroe9rCy+t3CQnr53K1fby1mNOD38HrpJ5eeK6LzazyZhTzVpeMyzmGBWbVS9B79pwL0F7JLsz emXD7pFTa6R7b7XuGR/75Npi3+rH9t0p9ncVlcd+eow62xnJls89GXLUcvMqKrPko636sJWjIsx1 gRhTui5jOCXhJRlvnTHnL2HzFpVBw+BgMuR2VSLMZvBX+p/Gzy92Xk/vXJHOO9Vm2UoCcb8R3+1F PNoQv1ajzDtuSeal03SRfrNJPDQOurNId6rfv1PtgOOSZMBhaixhNon7lYxxKImbOHvu372jHN+9 FdJL3T4XUggt4wgEdCAV5bIXbKAaXtG22UfK4IgPPaxu2gfL8LFwlcw+0gWn1YQ1qzAcLJjTDPG1 MejUGm0PcErtjbYHnzUnnV293PS6oi3pVflhFwKhLAduQzK9hy7jVl2xi4JM5kzp3iqbtyuu28Xh 1vCT6RrnlbDnt2v8/GJn9aPzujLaaqoT9oCK4Rb1wy4opVVeXEp+TX1C4JZkelywyvT7SAu4N8mM Kt0R9cMebjH7I+pHyICD6oTbJG5XMsahJG7i7P7qLcYDvatHtytHydqvH7WQLT9yxd8spfrgY7GX t45fjrhM76HLGLbKej9JxsoIdO+Szat0GiaHG+MQ1yXnk1IWNcY1fn6xs7FsH1xnRsjwcQk+SlHe pvFat8cVKTPEe4ybrWptJoU8XrOoho7km+G7Kqj7vDTdsD/MNfAhNVckkappdeVUv3iHPpnJJ/Oq Dq0iGdupgK49Qwibvvb02rXAJ2RQzmL9Cxf+qD1YLY3aO7fADY8dObmsVsLqiDlGX1r56z5ugsyO uYp9uoER71ewatQmx6+WuUzv0gW7NYSnctG59RLckKNr1JyaqxzdWu3se+RW9l2041JnZW+clULc T/zrxvpjt56YGieNlfodJUrE1ZjGPiimp2yvdPBj5Oj3hatk9pEuYl5qH29qFe4omcWKmZ9ZtXI5 aokR2yg34vhwpMgOsxv2uHEQPtYPh/eNuOBnRX87ilaSArcaMhMfDqjdcZuPqcdFfKZkbpXulc1a PM34tNhaCGDrFctOGFeDimlVmf5wFe5dMi1Wp+zTasVlZTrwY+cyvUv3pcZsEo8kM7Z0Z1qJGDYO oIb3qYzbQsBJpco+iTZtG7EC+w4v/mojRmB2tY+VGQ+BrZb80bps8ZCcyXiPNvyKUvJrWmUL3LZk epduj0+rDfckox5ZTMliLaVhxVhsRwj57SHeyTftXKXBZgjQvYnH3dnqlWd6kTd6bcJNJau3aIPt swBa9UsBWbO6+fvVrD5j1PlhG422v37/5YOutR2T8ny0PXwwGUXp9l0tYC8fL26bPT1dHr1jPvqu 08tHxy8vXAYfPWjm5TaJtfrvHCYfKfHe/uKIf4x27Gg+vTE1P7aj/IY1PxvDUvN0h+coPlhQyobt R9Qu/NoNkyGjc8X0xpzZ4yLWmohzg+5ssjnbSrkzd/RCwModCwG/uWMVb8x1hKdK6PTW6+mO6FXt QRLmjmNwGkdcp1qdqfU4j4syWzU0mJIFd0QnPti4J6fB9kofv1WUhlWucI21nbGa0rB8pfN9pNBV whw/HkvrS6H7eC+tR3lclCkpDbH3CRYnZmD2SYSnwULIbyfeqdVYvhr6ZHxuPPzhEkvDrErDVIvl MuCXfL+WytjaSWZf6f5iyk8ryGJ3tTh2YoQ4eXvXGIeNXdQu23POYOoYD48Utbmui0dIkrd3SzIp p/wjENbPPdWi2Yk1/u7z6PbX73m/AyGeV3vmlnLbPmkbxMHkJrZXbE/JPd4+1XcRxilpn3vYWTh4 zXcQn9dOUyvIMSC95vil3GUej6Od9HG6epEzkkwqG777CJu+29aFwUFnB0baZXSbwT+lZp/w39le X2F3xyxlcLRqdo9GQOeqHl/zUps40YCj2YbR3rf3hbmdPsAxqdr5ZPdrTOwkQntfvAtXycwj3Tll Exjj/fYmMYaDBWYpFnI9BOcY8BALpQZav/Y24D/M+C5OlvaEq2QaZaCL8YnZ5OPySI/jlWReGlx3 Ttkk7pIxDitxc87BgXgVybx7rlwXKTabxC3JYObXVtnODf56UrjiiXjaBSdM52zy18SYgvnJw+HM T55xY/p5jQHzM3CVzDzSfel3m8B8+h28Z8ulamLd2kKWhyAOrBDTZ5w5my2M1UzDxrTUWLjoihrs I6jBBz6o4Y990P8LjxswrbyygD5Ynkfvd8sjl4f2O1Do2sgB02YcKfdMO+SN7Tt5sRj3xGmLHmz5 7IThobrC04Cm24xfSfjJW/nbSf6lh5/itXcAurK1ZZnzeC9OeTD9PP1xojw55kkQlT/jSexltEe8 1G2e4mnnUX6shPNciGncE5bYZhu2PWRLG67JIvaHM+wvfHJiOvbZB0uXhcAfx9K947yG4dHDZ2xJ TdfbhzhvQt8YRvpMBqkwXbIY8tOZSYYcqPuL6cXpLLK4tQQ7Xn5gTO8S01vE9AwxPVVMT1VsZ4gF dcmONoFvkYxxgO6NFmXiHMkIb98+Uj5cywec4YiQi5PgSzprZZ1Dazi7cUb2CEPokZs8cqN9bsW9 g5Mc4RE7yYG4Gx8ghUccv1S5zOLJj/CI2yTXu+SRmzxyUrpbwVk1YzGWWFitAwsrWWDRt1iMIhZj icVswivJrCXd3WRzT8VlGBxMBtxW8twqwtP7hYkTI1GbWrldudhqZTqBPZ074fpw1CY73cE4uLth uC3JNOUa90YUl6fNMNJsMvCF6YKp2STuSWYU6Y5Ujltb7F+AW9TX33h5C3QGQ34c/7aF2Zzp2OyJ 6eCaATFX8umzwPWd9o8RVOtNedSb/Ner8pFrD+TBy5QVl/vMMNJtMvCH6YKp2SRuSaapjPWexgyt nxklnc8IGLvdhdcU03nFdEZf07hSQaaGGdvsYkFdsltTeCeZrfrcz0w5MlhWX1vURo3e6cOyNDQq sTMeXqPfq2I/jlvPISPGn20Mj/H2CEFah8YPbUz5Zkz5zHcQ+NcsNTw7rurvsBEyYjgrvGYYKTcZ pu8qfXx+1bFkpvkAZyla9BdttuhHAuOsSYtRhesa55twzakZLbw0R5SgHSG0pV64TfXOdj7DZHaN OsMvPczq9hb45fa8zcdSbd4YK9r3IO0dIP7r95bZXuXpvGm20dZUrvj4ECc0Usu2NOZqPBVsuk01 kxdr0cuG4f2Vap3pgsXqyrmVeggfZUJ3pnF026n8rHvE7iamJzHdTUy3MS36Hay3jXoei9uVAhuv FYvXGTkGU43pnAPxSTJb7fra3tJOnEc5kSP7xvyqcdzH30+r+r3nun9mjFDaWUdSRy37uTE7abfW pH37in6BFzLRY9farB2nJdh68wInetLln/fuVhtnGCk1GXiAVxOQ0Z1ix9MhJtOtxX4nVmz+9zx/ e/KYfbFhrI9aznu8NwK/c72N6qW2rL+iDsQVmRZi7RrwSbWj1xL9oV2R2fjYUI/Wr3OXo9kjRzaD 3glXyeBRpB75FTb5+FN4x3CwaDFe6X6REWZGeHb1x+NbU/Gto/h2VRx7CZ8kc4d0bfQJm/cqbfcq zTfGRnZWwtgpt7/uNnu/9ZgL2mkBxtBazOHs5ABqqeNXDlwGz7yYLmPoR3gkGRtZQnce2bQ5PeLS XD9kwG1GXXSbwT/m4dD4+cUu0mmjIdgyD0PjNMVt4wpw8v59hAzTcFLabrQJvRfJ9Cof9Rpz3u6j qheX47Ulg+eVqkqF2Qz+SicvccrsPJ2jjkgnv4Y2jata0q2U3LhW37je6Kldd/FK+5FwkmnRGvdh c/6LJ2VjTScwHmoyGT4Fq9pmNoO/0jlsxid2tgLSx4wVEHv0yfjNI34rVkDi8SXWz3Fa1M9hJQDP R/lqz2N4EsOrEjeLZGaN1agPj0jptBzF5Zk1WvKQwZmMopI0tmrPbDHyx9NQx1fR7Ep7z+lVVKJ5 /XzjE1A+S31nQG5X3DdGBY6fmsvg4aapWafbBKel3s/OephMixWXvrpsLq124gJ85xC4SOZxNl2m pcnXK5WMFSsv+Es9rT14a+M8D2F8K0bAH77CW3my2DdT9yyl86Rxed9F8e2S47MQPtxUFd+uio/P 0JpMV3y7Kz6/0F8hYVXjP3sQwLFafl9D45NRKll7pXWwb6ISM89+Tszr+tG4tx+bUR1csRmzqJDH dfwnVuwcowyc1FKerbSdpfJzpsrPsRlYxXX/O1oTP7FLpreon71aXe282Ml+H+pBb17NxYWRtjY7 yojVzpHWOYbWIZZdq/jj2pZSXM+4o38cZccown7/Q+6jXFtxwlmXFMeN0ZRd0Ch5a9cWr3f8MbvV zpEzpLXjeTeaWue46rDxcaZLfT675COwPf15VrO1Tw7RmHf8Wl0YfK6x2YNJURdH9Ezt9+/+hKLZ vVd2b+ZiOzoI+bXL4iF4WolXUJvG6MI9SuvwFQzotmh17NEklFDHi6chYg7vumTR5dE+ksy40p1p dDr67krDTuPCbzpefHQ6xo4VquG9C04PnNjfGDy3x3IVuEoGj69qHyJsAs+Y4RgOFixJDLleI273 CxINj2iNhN9pghEzNruckL6ftnoE3LpkrF7iJEWNlmL4TP3GZYn05dTKiOuC6dQamMdFmX6kO7K3 306Ml5h5q9idxHQnpmuK6TKmRb+DtY3NXy2aauvc/ioWbzC6Q0w17nYOxFo98riou9L4bawa6wkf Vp7HrlL7+/e0noAQz/NVc71aK/ab7ASAacwlrLWjsbrqlffaz0v++/OSr0s8L62pfF6eOovXU7q0 nxMyYDqX8EgyXeVl9dwuLe3njKX9nJHm/nbCwHFufV7PbmtsY5e0n4M3ftxLWzsyY2tHZmztyDgG w60dGddl3NpFHXsmGe3I2PkEs5nK4U5l1WV4tiHWrNxm8E+pOTFmGfukXREPod2zZfeqzmyt5YzY 9RpL+/HE3DsfS/vxY2o//i1B+h78exdVWPvx7+3U0O3ajyfm2P7dfab9eMbM/XiG+NoZ4hjcjR1j xP40bNmcAxr+mFV7t7jVwb6R2HtzxDJw0ojYViaRVmubkFY+isq0WjsFHoGrZPqRbp+yCX438bsn sZj1RFqnz3ipj7OYZpclBOnm5WrtdQnCUzLgzfrI9Hg+Ys+bv789XmvZXpfzYZQUfL3v+CaZt99m rR+ZsvUj3lUyxuEmbrDJUs24HCcZcGONIGeuyjItZyqNxmEmbvCJYfjKZODDk/LD51iwtMzvE3ct KGZrjfl7qxHzqp43uLXBc61L+y5p43fTdnkrxW+fmjM/sN2pxOxUYnhaymSKUmrtIDwQ+MmXGrxd /qWH7WN7dzBXm6vA8x7vjhu9Gu9xsJKNXf2u1Lj8S6XzBDaekLF4n+66uSxvrprxdgjLZ54PUL3Y O1m1c+WWNpz9Mrx3Cjm9R+059mwRS5OHTOyu7/DTSXnKh8tMhvNg6povt84R0DdXvnEZ7I+bLliY TeCWZIwDdH8zZZ9FFkf1+XgdmH5fhMmkOnPmCKZ2JoA3dhhGbFN12HXBbqncelzc7S/S9ZkycvFy PgyN6zPlwf37HvmrkN3jDAJ1vKenjs3msSfu83ykykKQ2ptaOO7yG04txE0tHB9gs7it58Fuv+Gz JYNTBEceuakEely3iwN0Z0p3K/jWAyx87/+x8L3/x8JuegCLwGdL5nbpvl2R0ppwTzIcq1F3NNkc U3EZBocR/UHognMvwvYVCvK3lRW1CThysRWuqgFXT+dO+O3SqzbZTQ2Mg3Ndi+8ucbpFXM9QGk5K m2Gk+Qz54hb56Mp3Hhd3+yPXjKens+HLYmJ+g2jaCTffCQG/yvMLwO23LXzlZTrjJp+1tcNnNquG zwLXt6Me46rWrvKoXfnP1qgps1XG+GSB4nKfOX7pdhns5G/5qan/jri4268y1n03AbH5yHDiXsAb 7GxGTdyjlfLzB9TlzI+eaCWYOkZsJoOdfNO9SzaBR5IZV7oxenw50q2snrgDwjROspTKT7+pVWo2 9yf2kyqDu/8xKrUdf89pD1k4FxDjB9vlN+0mn40Y5+EvG+dBY6n+2r4+Y5grvOYYdzyYDHby1Z7D pnCSMR9A91bZvKp/jsHhVqVG47Cw6fyVmslZLmKeNUrQVgj209UL240MhlMJsnUK6o5omQ17bs/V fCzle/z2O/OBtzzm31tmu5SnfoMDU76acsVHeBN3PtyE5R07CQDdeZRz8yjnHOPcwVGuuC72xEtN WDLO4WxyS0xT+bF5ONmp57R9fZOxfgG63ZgW/b5xJsBGPY/FUnvs9o/FG4w0BwgZpEDjjeAAmaF2 ffU0K2t7xKys+YjwtZQ7tYL7xKys7ROzMuEqGdyLqVlA2AQeYrrHySxWzMrMqpe3M3aE2Lo2f9cY sGlO/UJsjZtSqY6eX+XtLLUhJ2Icm7cc2Jz3w4rR9vBhSyMr/HUUIx+hZU7eOYRv4tjLDI2exiKG jSP++nEcuQadG7UeOIXsFpZrzSHVeuGnU3uUk87vKFFOep3RyvtuO75gtd32gV1y6+O48x5z45AZ Q7rvXkm3CQ6zCEePD21L0djEVq4+nCzZfOBp81Ymw1UytqsOXTsFCJvNW72e8JEMdrDrkVdO9Im2 I+9+bCPKKnAKOQzZv0IW9uKVXy2X797b8Pa09xqrO737PBJPXS5vNQLjVgG1V6GLZ+Y1X+zRtz+Z fqRrLTxsWr1CXIbBYcQsP3TJ+SbsvYNr/PxiF+k8Tem0NgEaWjnpdkKQnLz0DckgDTulTaOq3k+S 0epKHzb6w151iXWHwI+Dy4Db3UrbSWn2vaHQ+PnFzsvx4OlKSp1YofM9cMQxtGLyYcVn+9iQsf1t 6Nq+N2xOG8Phocimmugy3DOPPs335IFnnn10+2qDISONKfrkfgdSpxA+ialy7Pd2Yq0P9x/Yul9f LY0Y+lolcn7NWFnp3ufx2UnVyDVi9BoYNyaM6M1DF7viUyUi9X899ZG+S03dk2xq9tqX1lyFi2TA 2XSRlq2c87g8vUr9LtF/9a21362Qid3uGJPZTQeGu3LYdrip29U67egZoDFTfPNXfDPFt1J8O8V3 UnwnxZdaw31utsrTaNS4se7TT+nCNcYS/aRyeppy6/hZDZTywzNG8PlNLf2tKs03ejf8pTlmv34O 8YWMYmuHfRJbj9xjtWLpyUOTmtFTjqKxrO9a8/cb45pRSxo/4BUI4z6qaro9F07t6nu4r36PxnN/ 0G6+Gt75+7/+u/o1+/0Pa+how1YR3vN2Q3E0n72939Xy2+/unWbegd2ZPDp8V6Bjlzn8Hl++03O9 R583+kozu9FvrG6M0WYKGS1mAUNzvhfPGNEbjmH1nb9bj9P+/n1ku2MpxpG5zBLt1ph5nh0h2BlW +R0xE5v+cJ7JaEVg+KwPO88+QjrCbyd4qBUKXfBTuxxxQeZGS5WYduwRV6Uhz0jsG27i5eOZ6t9h k/fSzsqHYwwvXCXTj3RfzG6zT/8m21jknZWxtLNiVq3XwK7kj+Mbs0zhF/c54qqZr31L7bhKRjN3 3zGNuDwflmbuIXO1Y0qmmrlHXLeLwwmens49Yv43fMV+4hvum7CY+oo9dEvM/+J3PIKndmnETkGy fyxeZ+QYO5BdObK1khMcbldc0M3jMvtSm3lu+6L83du99tfvM/U2CPE83yvXq1Nj/WpE+z/9e27T vlNeOlteOkNest93fCNOLx2t8ob9Y/F6Sh3fLpm7xAGsr2Q8LnjppDHM4H3WFsNosjpUknwPgDjt mozTh69xjZPXs8fhGSN66cQ6kH3zzVTz+WNL6U6p20c8jlJ0tNY2zpXM1W7RuDVWBT8c463Aj4PL zCNdcj4Jp32j8W6J9tJwexo3Rgjs9iG7I9ZMxh1L2LxU8c2t3eePbxL9NpKr+/zfck7cpX91nz9l eO85dflNPm3ym/zXaPkd/qvrPv81dJ//GrrPf03d5/+aF4+LmBwoQ25LO/Vm0++0AIvB94vsm29q 4Hb+phQMu53gpnv+gUeS4U0h1OUNA7TJmyv4fbnjI5l3Cze/gGIK+N25Yb/jbzXs5eOODeBZcho4 W6CHJ98BAid+CU6u/KbcsN33BZl+Infs1lva5K0h4Dp5pxByxzHOATR52HV1boBpsLiILWdnfAdv uivZ9LulyfTyrtQ7460AMLI73Yh5h8zi+wPM/6a3BcDa3hx4nWLgobcLwIhfEZGp3fVGXFSm7EWb xd14S0GcMkB+PKa8TYjsRmI3i1jzNpmQpzb2uE0bnEwbPKbKv2u7vDy2u2nj2/IWeb73zFLuV+zx 7pA6dk/P18z/+n3fkdK3eYMT4/C7neDzk1J+jHvFrvVJWF7gfrHpVsujot977CPXxRcIauSj2x8W r+fpSX46yX8nlUrnAJmmknj8zRp6g/cRUsNvKlx85eAonTul8yhXj5UPyNwdtd3uxYXV63euQePy PS6G+P1l8I2H4P7+5Fe7P5a494jvms+gm3x5q+qB47El8/zhumBhNoFHkhlql8W02i51pME8sGIH uq4dO9Afjh1ox1WW/G20ZMnypRWcH0AIsDFstQZD+6oZlaNVaxXeejK/cEZpEk4yuHvedHHPvtl8 t5D777ir3uT5BfXy9l64hgy/vrab0PkWQbTLxt/yOVKmmK2N/yaJ29v4Dw/Z3Vd2dxdeTTIzeuBW Z/TArY6t9Fg7zfcEhrfHIfPW5atqVtiE31cT3l0y+0r3JJv+Ch1Y9KKU9aKUtauUtauUNbv18sbu MHW580ubbSllfPSeKXP8WLjM2NKdXTbniriIr1Jm3KBrnGGzl0gZdoqjNfR36ZCzdosdGHUvg0cY Vk1mdunORZvCScbGFtC1kRJs8sZvxrW6OCyVZdcl55twyanh3e2M2e9TR33xENi6Rfp3BbbXLCEz aom6Zq9fwuqoPVnlyUfTaE2W2hHuS1Y5GqOuRlTxfblpLFp9O0L+uC094iGwteQFPnRr+HTFZ+NL 6N4YazSedqT3HY8tmdmlC34neWAnmaUyJqYVe8Y1mE4bweCdv6pyNavKleOxJTO7dF/Ms9eEk4x5 ErqzyuZUrXLMtwaj1wtdcr4J53Z+bpWreIkKueghsHWq9M8WvipX3Emm7iqqM8tvMAPbxdtqieeW xoyRWlsaqdsuLmNbKUWrq42x963ggTTubMvKbT/CY0vmeXglz7tN4JFkZpXuzG2M3TdMDR/jMT0W An5HNXylGrpujKOb3WIHXa6T06qvmbP13XyFB33p9nbp7Uon5vZ2quE0Mm67GSfsRQdbvIQQI6oP q93YKa/tdSzKbPXR21ry14/77x3vLFpO4Pt3tYluf1i87lnHSM9VL+AcgHeS2UW6K3vppFw5eeTd Lm+xB6ej/HrvNNwYuUOKIfjW3XyO79WHxhF3xIjWcMRyYnzf7tbo5LrXqn9BT685xo576gtv6gvv UY26N8m4B98euZWhjlcVoz4Fft/VldTHmy4535Qyf+MrNH5+sftDHr3MmB8CW27ba4iG15Vnejkx d+nxGi5CatueMwoB+1qiheq17cSs8t59fOdXNdvqdUUvbdhjaezVKHVmeIhfvqFsx+91xosBwPza nTKtRvnvzdv6t7PufcARxu67ryt06c4lm2CqEU5wwMkA44ZzBTt7k1/cm6V9cshOIX6vJf76nBse 6HZDMTRuGgl3nr4zfGIM3n1Vp2Kn2PyBHecZJSxwDRl83ZlWq9wm8Yx+sPvJOotZ9bj7dxnU4T2J hmvUjPjmm/r8gt1wz6VtFpVc7/Vf+saOEUZPI48+1IL3cSUzS/Q8fZZYp+mzRnsXGLvX3rJ36YL3 7cIn2vXggJ31HfOoPvI6TZ9dqbHXfcluHGH1r59MF+ul0mt36ZL1OmK9VHpnqls+2gAeKr2zxzpN 95HNYz1bLqMztQVTbXz302aYS2AH3FYIbTecJWvZmxW80V8ly++q5Y3+ScbWKaFrs17Y9PWDnvCR DG73X1fsNAPo6+Rc8JeFbuwvM4a9otW3HWm20I6fZ7ZWV0P3xWDvGBGfJOOrq0/3qtXfV7nsGBxu tPquS86nCO/c6tsaVWJnK2Rf1b2+QvZhcT0a23Zf1XF52T0jVks/rPbnTKX0aPV78ityZ3I0v7Wv wk3jqB096h370VjjmxqlmQj+8tIXIWDi7w0AN9XL29J8BX9523L9dfGnM3gCzbCVWLwaMGLOF7/X +Hrc8EoyK2Y4o+wY1X54ey0NPLZkZpfuXLI5l+KCjNfYIm5vz77klnJU7zGPf0WOfBz2ZiJTdmMl JzAs3SgRoftYVM06P5xkWoxl/JUB2Kw2z8Q7CT1qVrxEwNcNYizjNoN/lD5o/PxiF+mcUR5G3bLV Slr7Gm1HmzV6Xq3EXx7S/M0nyo3ocYe/RgPcU4+LW+atPI3RoscdQzsBY/TocYe9CYNUBa4hA5+Y LmLzt2XS7flkd1OPO0aVF0aP+vK+aTb/4HvlqTim6rB96W3Y4z5xtzx1bd0TNmvMHv1e+sV76W3E UyUztnRfWZmqmR4XsdZJnRt1Z7IZowy/Nd5mpMN3NnBzueO3O6/1kw+rvk7NlYa9hsPUWHvUcEv+ Usqs/eq6MZ/s9hJrtWVhk/fWS8Y5jOBp7dpYLVZngZVOD2m6uZ7p6THOGUsr2iNeccZfW6NwYJUZ D4Gtu6V/ky2Nr4f3suCxY3Xcvummb5ZGHyGDdO8YJ4RN4JtkrtpEMa12KiHSEKMM3P3eYk1n7B4z 9LGTb/aIVYmxZ6yhjT3FY8+WrU55Zi95w2fMwFsla58qq5rvxV48a9YpapFPiX3FD1ur1f7+Pa1e IcR9cEqu+2fJB2eqXPuODvCI9aVxvFV+uj3m/SN2jI7wy4u06xO6YDGq8EwyU7X3rDQmHJe34KM9 8feUnzeuVuDH9Z1Y7KYvyVgM0PUcfTZTyq7tVfUu/NoNl3mMXPcxdZsvBVcr886BMqm2G2faPFW5 M+2V5ac94/3l5+EI+fjN0mI178NduEYJncVbr6dbYhX6wzEzCfxxCpnZpQsWml1FXJDR7nNiChYz 1niBUxq0j/bhlIY1hDUDm/Z2M3XPUBrOVhrOFg/NnEIXvHcXXklmpjTkfbRZR6wGzRrr8I9H1a7C rGodZk15knaqZq2xOvtNBGOF+MOxQhz48XCZx68m31ftj0dckOlTur+ZXnm7ah1vxlrHw8nbdW0x XU1M5xXT5LHYd+rSBbvkbY8LMimnqr86/urnbLV5izb9PUH+Hi3aX7+nVh0hnletzmx3TB/tATuT ppW72WZP+Ga7fJGTOM6C4K8b7fo3pY1WcNrLTPBa29GbBX4pb5rFhS7ivtGLzF4k01PZ6D5GOg/H jCDw4+Ayj5vrPs5u0/krNb3HvjdwjBgiBHa11/NN71WCuq8xPOxe2nX63R5177hvw/A23OPE0Mb7 GpyXbr2vUbfu/MDlAMJFMm1IF6eZzCY4WFzOh+xa3OxBbTt5BCnb3wJTv9mj7hE3exj2dTjqcPWc Olf6Nl5FSu3kDlJqp3X2its8mFI7ubP7SbhIpumU0E4ng8DB43I+ZNftzosfS7Wt3rzhjt2dYZaW /MR7Kwy7L4+fsjFdjrdok2sLu/eEj2Rwxugo/20lauseEDCNOzKoze8P6zvoWe2tJP7OeUzIU3sX ae8u7b2kvbu0d8naz0v29jR8vM33Ne7LoDd28ve2GCDDNpu6ZUS+8Y4M423lAueHDPO+jBrlwnVx D4TZ3EtxARuH3cVtbXGGTX9FEl6ydSmw4P0XdeNWkKU6ZutPm+94FFk1md2lu+PuDMNWRiBjZQS6 VhamTjkxLsPgkMqL64Kz2XT+Sg3P1TLm46395umhGek8bYS+jTsNqyTZu97UHSqTx9+mi5CwyrEd LS2Vw7OLrHImR92tPDzRYgy8LNHC6m2yepu48vsOkykrfGYnmODL437VKSf43mVw3sd0ccbHbAK3 JGMcoGvfgrCcX54po4afdds8eVSUBo4LyNvaEuDdlQbzBnRP4nFSfK3wTc9Xr5qNSe13MvwS8Nfv zgk3SnBu9OyaVIRw73PzxoupvIiQfvyuCtPoS3hEH9QKR/vUtRLxduJsNLlx14Th9y25y+CuCdMF vzGFe5LpRbrB9KX1nfrx1NXc17bKsQqxv0IMVpXrSsD2hvPGmRvH7yyOl8DjL0cw1a0eYWuPIGP+ x4kutWutWu+MGzkM49aOGy1w6L40NLVxERdkWowKmn97ytjaiXrjJ4XIblfh1cR0Rr35cA2mNgIE U8eIzWTAYi6xW014J5m9pPurHPdSI6+6ryFunliqkYZeot40G8URt2gX/SwSdbt49Kin0Jgpvvkr vpnimym+leLbKb6d4jspvpPjG2pt27BUPC8P68Nwhsb6NtzmoH4uZHD7QyoDQ/1cGy3JpBoxusrY 6Cp7jsGhq7aOVKOHeoW4UYO5NfjaH2OeO6fzFqXzDMWxU9w7cdoq9y6DNJyhtN2SsGSm+YW3V0SP 3CbXyxGX4zEkgxNBJaXtnoSjfTx+/0TdeBHD8h83QnBHcPNeClq9N84WEVt7xTsxUk8QVl9b4trp lBLxiPGcaZtut/KiU1BvDBP43RThMntJdyebO8W1Uwqguzyfu51d8ny2M0obt2OYx3g7RvIF56yG 0zjE7uvIlmxmgVM9NpL0Uz0oY7uq5du+K8GQLVtbo++23QfL8R/7y/bgIGX7bvCgnbMB9lu/TGrd 6FePzwI235nwfDneQhZh3A8xVRddFyyW6u7ZScZndbhb4sqmzdgQl8/etmTATbO3sOn85ePDVzQT O0/n5TkS2Lrmmadxvd68szdet4rws+QyLw2ui7sr2hbuSWY06doIEjZ9hFCFwcFkwG3EvCJsOn+l 89roU+wixPKz4VTOlP5RKSO2+WsvXKcn7lEr3lkhflHwbPViI/K3B15OzCl7OU3Yy+jxdzZM13uX Z3PGmKJzbQ3tV+B3B4HLvG+hXfd9ie4231fKHhfwaZLRTCM4w6ZmGr9x7p174ykY4LpjJGSvZ5C1 /97jJQ3DVzK8PRutcW81xhcfjrlPYN6wEWOH0N1LNoFP9AjBAS+B+FgD54B6Ts2Iut3tpfFXRnrr 0eb2ZiOHtyPv+FlyGTAa8jW/pDY8k8wa0l1XNndTXLuJw4q6HbrgPKfwSHUbGj+/2EU6b7STvVfZ 6j3VGT/1s3kCKFZ2elrZ6VrZwV9cz6OU2rTu31CjPcXbED+Ooy/AuRZjDHzlc+9hcFsCT/68VZK+ SrRLwlUyOH+iniNsAid+c93MwtrEvdyqzQH6asfnAH3ZSHbshKvf2mBcbYUGtznMKjyaZHrM4rud oY24vOQ7XlsyuGmiR3saNoFnkplbuquldG6NPD8co7u+NQLqS2uG3U7ckukZYnqqmJ6q2M4QC43U wuZeiuvJOAfcBpFHlX3z7BJKsp3KpcZIlmZNOI08u531Jc59XN88F4dyYidi+bul4psj//59z2x3 x2qlSbndwzMtxFVl8VS1KbbLCO3jO8+we2zmDtxKtmtra7A1VK591eXx/f17zXbHCL7+mgNz8KyY 23Zf8XjlOnDlTRpeEs5VCTmpRecNpCazY4zfz4oxvr1rwdLiGHd4LLXWR6tiYZM4yVz1BjevXeA9 Ck/njbVJpM1CcIrJ1z/Pw6qnPoYADv/V6fd/wK7d/2G4B6tvQha1baQeeqT1jRG9+0m4SAbnlGas F4dNcOhHuJ7Mbsd4bRTzGX73cWD76/ed6ghCIm0neXPUuryVGLVGCzCq5qcfjhYg8PNAVe0O3b1o M3BLMpqf+vkk2uxXcfUrDj1GEKELzpqfDr9BlKmu1kMh5ptawwiBrbOkf5Ld3RTfWuLhq76P39zi rbY3ZJDOldK/m/BJMmdJN5jiNpdavLaO5rPBnfC7gUU9zGg9xl8f7sJaG7F3SZiaplnyaJo9B36M mkb4obuXbAL3JNOvdEdq2/ESiOdIb9GGjz5ijDr6VMzdx7r1YZWLrtUq4SIZnA0z3VdH3CY4aA5h HILdVa1K+2Sjewl5Mfga+5M5KgmOwVT7c6GLlF3lfr/Rm49Yzek8S+a6o8nmaMqnoZVH4SIZnoYr kXq3+dLocXl6Y6Yz+Iqp4Z1GemPaWi/OazVr0XEDzQo8exqNjjljNj+mxq9jpvIf3029Jxx93/Nc 7XsSb8Pa9zxH+57voWvf0zxb+55nnoS17/m6wtDt2vckB4ur531P/GU3LhBz7IEYBks9McvV2+Lw mxUOXjAw+a3bFN4lHIHPlsxLpX0HiNTbt4LEHBdShrXwHdr12xfeZR41vkY87/Ztu32B7HZit+Uj W20LeWrDrmkjPtO+S9r8/YjHzh7ju6yGU37GKUL4xs5HEnuZA5c1VB7WyDoegrv/2dJQg+tdxE0p XOYr6LIlO9ztrJEXjnEnvsnw1YAbzN0msMUFGeMA3ZF9sNagD14M7AXsdyt/7e/fR/bAWvKA3ZFl Ibgx0kL8FgemyUKQ1qtyulhTD98gaML+vTY0tvHF3uNUubCzesRjhFXbPaVuVx3kfUL0rGO+VNDC a6770uA2r+5/oIxxgG74hjudLTywfY3iYP/UQrh/WsWb7S2wnfODjI3SoXuqeJya4zu9RU7yxVn/ /URO/v69pfx6Pzlbf6/W5LiCzhCfxxzuY5YI4Wqb55KH4E79ojLPG3YcF6WQMzPoHquveInA6jFe IjCM1wS22hnXBT+zSSwZ54B794MpeHMGzfT4XRSHO46qGfY9HVrme3u02Del4XJF+fAmhh0tv8sg 7qt66zaxb1mGsLWVuJ2+RZ3/cNj0ncTDXcVo34WLZLgTur03CZtIY13CZeTU3yi9rVi/hN+9F1iO /1gcrVz3l+8FQoPv0xr2ngw3LIzgxxt2yTswdjyjfQh5vBDAkczhHqT5vShe7kcuLzu+Hwk/Or7a szy8s1954Dxx+/+OsmPc/ngMXJEmXi0YBX47sPNGCmzfESlrswgPpbJZb4p7+VMuN8tBpMZLwpYM UqOeOGwCzyRjHE7w/OMsTtTm1k7U5q0Q8DtXvG/U7I+GSqHtfULXTq3Baq+pFcRfbpX395ulJi/1 PmV1KM95f79ZHT6e4N5ntIK+D2q/Ryv41+/ZB31FK2hS1qK1wVkBmNhYFRo2VjWsfPRxHV4tMJ/h 1YKjUukYLw8clUrXxZ37pSYsGeeA+/d9hkAWPItLphrj+T0Oh/uu0fsFhqXRFMNQ+zSm/D1WkllH unvI5l6Ka6tEuwxfKFA9d5vOP6XmKkfGjRzZCpnaI4XGTDliZ+co00aUHztfB6uzpT6tzVQL5kl9 WoTA1k7xpXTMVNtt35K6I/o039s8aZ8T/nOZq5sfyGJe4ZVkUrskpmDBfcqDvWD1gn6Pw+GLAPKA namjjPc4uNM/W11dnlEI7v4/KnH2HQc1dhVeah9sBZi6mnnYWwH0jGPc66+ZR+jyTQCVSo8LMlvt 4zq5ddg2Lnmps9VdaOwqS7uq3O+WRrttF2sDcONCrnPbxkh4U8DY8g2CGamzdWKkzvFj6DLgkXrX nVJqX45SZmtMsLd6Bfvik3F5/zgkA24pR9ym80+puTF2t7sbvMfzEOzOptbuFOX6MV8CN29d34mA Y9q4b6BoVHCT92MvlCHcP2fI1riFdzDa775//kJ6acPHc+3ajOL1wzFqO/r93eBc1HL0UkOm8z0j pLT76Am7k94nH+F397bLvDu5Xfcu2QQuMSMLDreI2yuV90adw14re7OxiZ/UqHEnw+Ee7Ha/9LK6 sK8UYL+3SNfGNrBpPRD3UZdSbzLYg91bKRhX2G7LZmz2NSnxiF6729ebxD3y45ORf6tqyYejDQiM NxtUS7qtuIJF7UW4Ncm439/+qtX0d+t79VtXkP5q81fewBCj3F5PldWTy1e910tk513XxK2JX/OZ N3ZkY+WjN+91V8JJBvvIPXqNsIl3Fnr0nCGP/Wizg7soHFfJYC+7R10Lm56WaMUjZYrZ02znzIhb jG17r9Hbxe8Tu7Y14SSj0chnM0bq3VZBkedd49OQwcsHGo2ETeIqGc//Im54x8BX3Bmyj68Z9Vi5 W/w9LHn+F//dS0w3L+GuhiJfDs3LdVcFQ3rMpLDTHBo7zTZ9j5d41fDxnKo//vvUbjHxTjInRlt9 as3Rd5rhY8fPxy7zUu26d8nmXYoLMkuecW54TSGvRWJP2Ebh3e5ngvdWVQuwzGOvBjh+lpbmv6H7 WCy1+X31JONjqBH7zLQ5h+IyDA4mA25D+eE2nb/yfFn5F7tI57lKp5UZaGzVXLufgpwMw5LWKEMX aTsq3etKZhf5yMcuz+auqpGOx5YMdtPV24ZN5690ptFRjzuvDl9riH64x3m1w/caYl7U94hZnO+E E0+1XfYNAnU1fjP8J4WEVY1Z+tbosvNdJpO5VVY1j+9xvypSe6yPuniVQb3m0Vy525cA/N3vYjnc e91RQ31952nY2S9iv9/oYO+1LF8f8HsYDvZhHVe/kwGpGEWrw8O+wjRcJFOjfxilxLxyFK12BH73 YRfNGUP33WLtNomTTB/SHWn8j53hH9eYV7kVIeC3tnjvLnya0mDeg+5NPGLsg/1GW08CHjEeEX53 Rgx5pnbFXHsTbl0yNWYeo9ZoHUctMR8O/DzgMrdL9y7ZBO5Jpm/pjjSPHXVFLzBqrDlw77V5v/vh Ka67KA17CZ/U0o6W7Pq6E/ARq6YVyNFs3HnenuxV+elF+RO4SAb7sDfGFGETHE4TjrR17F0Wbx9H bzE2Hb7G8+7g//17LnG9RX01qQhJJc5HCc9/fWylSPPswM8DLnO7dBGD5tmja549+u7S3SondoKe cZ0mDvvKk6kGdK0TWFzupaG1d93NAVseMnXnx+E7I7Ibq1Endk6pq7XQD8esJTDe8CgxwgpdsKhT uCUZ7ZQkpojBVp2Az4naGvjtD5/E9KiGjlS6Y1UIr43Iq2MupcbHjkcYjOYS01QX3CbwTjLG4QRP z5GpdcBhp+mJT/THY17FPG/s9PoNHmC6tIsjXCQzhnRxc8hVXfC4nI/YrRGjK7/jA5aWl5DiN4RY zE0lwTGYNvUTK/UBbvOleKlvHEv7Xh8+0l1DNpfyyfcQ+apJ4mYy4LxiJhs2kcapNmWNGHEsvqfy Y1irMB33eEzvoUda9Rg+5iBWedxbfWmspOC1DNUWx3g5Y6vl8FHJjfdBDM8hGZ+zvtc+Roz8hr9r RaZ8X9xwiTHrSOsr8TteptD6yrDbuCjTY83Hb+FAanz/D69sdOXa0Rg6dF8K3Caw9pmDw0uNc0Nq /K2ct+CAVyN+Ho4XKvDcsr0ygeeWa0c+fzheqMCTz4FbDZl3LaTr1h4vVOCzOHuhwjDfL6MM37+i 7k02+b4H4uK6OjkELiFDztRlWmiTaWRckV6kvvJrdbx6UvN7GK2c7aczaJfvXlB/8M0QpGHYbRsf E5zhwDszZMhXqipfwZhi7p6c/vtj8r5QNm34w7URh/mYv9MfLq9cnJ6L079Rp/bsHgfftWAcwPMk 7qtZ7HEmwXUsBOx5csE0+D4LcVEK2TpaHHxVG/nHb9A/fIT5zbrKgeuCRVEqLC7IGAfoBlOkm/cT MvfthT773UpC+/v3nj3AF7sYn7/YxRC+CMsQf2ERafIQ+GmrfC6+rkVtvq5F7K83QWPzhTFo2MtJ hS9XSIPr2SbDl5moyzeEwMJecqr6/p3ecZnnNdftK2wS9yTTVYO3v2YGT9nbStTwt5XewpyHkJ97 AF+Kb+Gj0rEt50t8lW5Wb47vVLVJ9nKS/X4iJ3//3lJ+2XtPsOvfpZtc3wqxLxUshK8fMcRfEoKn LQTs7W0jxrJPwiVSeNaIXDpT7dfxdvMI4wUNr9NdumCxS8JJhhyoG0w73tA40Qb4Lcj21xnhz7vV XvKbcLajN6WBtyWRt+PXHpsM4jZdcLpbpesepYFr5pBppUSdb7wFGTZb4dtOL65WvE05CZeQeZxd 96XFbTKNVzXbb03GX83eIX6MgP/133t1pob/WByVL0kijqq+w04WGF49eFS++0ndcYJ3YHwxHu2D y1e8jWF9Jd7M2Ob3EvHCLzzJi7IDbu5Hx3irwvvTFTyJV5fMHNIdqSVrjS+AEo8WjAK/kxH9Rgq4 Ws2U8USD4aZU8qZl1ITWUi43y328SeElYUsG71PUGDW4TeKeZMiBuiO1AK2tqM3A0V55CPmtK957 CB+VwmYehu5t4nFbtnqjFWy83YeW7IVk4hqtoJ2eoC7nybTqc2aWsD6iFWycD/vv0Qr+9Xv2QR/R CpqUtWg4oRBsbcQEjXMTLmLLl96g29eNfPSRHV67WMoLl8FLG3sqdacknGRutIZ2esLTMHoPpjyp ailo0fu1UaP3CwxLLXq20H0x83St4ZFkxpGu1RPYnEtxTZVokyG3VM/NZvBPqdnKET/XyjJgIbSl PsZexzB8YwxupyeoO60GPauzpD4N5xA8vulvJYK7hdDWVHwzpWOm2j579GlttujT7N0M+skx3qto 0V+Fbo/3NAyPJJPapWBKFpsjLLyosZPGUZvAL8MN3xgt2+kJ6i47Q0irq6p9iBCkbi2VOJ5cMI1Z hT2Hj79TYbrWn1ScyjjhGcf4It37nC5dsBhqWyyuqnc5THfl1mHZiAWpu2oV11X5XlflfpeRPXCs DbBTEgrZHCMhddvYvtRtz+t3qsDaLLw/YRivZTR5f6fedaeU7qExwZ4aE+ypXmEv9RaOwcFzJE5t GOehdnbHuA5/7Ri7N//CzuzuGLs3fq1ndo9yfd+Y49jpiT/Wsx/z39nE6P3ft/RWeze+n9/RNp+r UYS9YAmZ6yOb6icpaPNWS1FP+IQMav5NNf9oBGbfy3s5uTvGvMDBIuXJdZ9VvPnAscCT6qUvadwl u71o3cBOMYC5nW7AiMFOPWA8E5hfp28vA67LmLU+YKcYTMbGP/wqvsmm1XbEZT0ZONzmHnZd47wT 9t7SNX5+sfN0Vr7mDVs8r0CN6qOb6mcXyMnxs+QyLw21KW21l4STzJjSnUU2Z1dcU742GXLTSMBt Bn+ls85oNbp/12ZyGvPaCQrT2PJx3fK9Y1jaU2lQy9xjfIqzF5LhKV7qNp+9vnMVNUabjsHBZMDN dMn5pjT7W/Ch8fOLnafz3eFj9aHzPh/+3hLXdqK3XDzJ8OP4pFagDxuhvf3XMZQXtkYEuzb2IK5b MtV8HOcSzGaJ3gVnF6wdDIy3MUrzdtN14VeziTRYXMTqj50bdUeRzRg9giluIDbtFasWO0LAb+wY 69r7GIZPjI36uDHWtbc1zKq/to6/FufsiJunG/n7vDFfs1MN9vtKbZzt99Ovy+oB9sRHrGHal+7k tMwHeGnC/VFDBr4xXfjMbJLplI/5NbzJrCPdnWz6nK77KxXG4SRu1i5xHz96B7fJNC55Ys00W+27 n0j97qodvnYEXGO2amcLLLZ7xOLG6K9vrba6PGrlrspN3n/ImmvxIpW7x7ygpzWlwL1L/nkxrUc5 T8oUldSV16ztRQzDU+XcT0WiV+8842n4lKTP11kNVzH5hWcaF9pJBMM9t5u8/8Z0Ti6VvOeH+Jar HMNevuXYN+GJPsn2/h0rx+4d0RbecyI3rq8LLOGWZJ4Xr1bZ3Kbh6HfsnAF07ZwBcm8UH+ct4ZJk 3isHpvtKits0rD7LOZTETZz/eIrnlVesZ+OphqHYRvUyFxhfu5sMUjOLUjmv8Eoyu0t3X9k8TXGd Jg47eiDXJec1hGfqgaDx84udp7OWmH3YuQT7XavObx8fbwTQFm8FxChxtCYmrUeb8GGVozaSjK9N PV0bP8Om7+/0hE/IIJ+b9iFG0zrFJ59mIjhx4PnGUwYWw1G+tRMjh8DPMy7T49SDxaCdgNHVw42u 0dXoVfnWm/Kta5TmMuDWq3xtNoO/8q1X5VvL64ijz2hnRzcP83xCV9yjiJP3rkMySMNIaZtHeCUZ ja5Gt7E9bNroCnFplOYy5KY1TrcZ/FM6NbMePe+EDJ6YNE43RkI7QlBORoneYgztBQ1bd6GMr9ng 9EH0m4b/pJCw6qsOk9+OB9Zqy4evrC6V0BE7Ex3fl8csZvh6CaR8BIdWbVjr/fCsqY8ZC+fSqbNa LgerRO8z1q+avY7ade/Hz/A3NFiv14p1wOHjh9qF8cbJirUU10WpWFrXHUurafbmhsncGMN8w7Me NneJ+fuHYy1JuIQMOG/1P26TabxV+EQfib397ePk4e9UMfdOXd57jqO50jhli5PGumPbvsGTsfk4 dGOejvMCJ9ovxyfJ8CyAeG/tD3hckDEO0D2pHJ8qDo5b4o/3NTQDD/7EktnarzFu3sLbblTh3v6O VvpoJvFh1d8zNDo4K8ks9Q5nqV061g7gLMBWrTQZ1J+j2ffHQaXr2E3PzM1ze+TsbbnPvhpJjXsU x02l3HeKXpt1d+wOuzxy/J5YSQz8POYyeP9jx57AuEvt5vU+Pt7/aG/SO66v6OJ9EZsD9qozD73q zENvOvPQu8489K4zD33qzENfOvPQl8489K0zD33rzAMxdxYow/kmdW+yyVE44rJzDuAQWGceyNl0 q848MI0Wl6eXqV8689BPPvPQeeP+pF9wOmEpbrbKxPRqH9Vvm/jwkDx4M0c67oKYSqfL8NaKGn6x NXPiLh/ZuYv+7oi3fgUpGL7C1XF3BtfiyG4ndid5j7Uw5KkNu6a9u7TBw7Txu2m7vDzGG/2pMb3N QyyT4z+GbOeLG/gtpMdN/qbBVgOY580ow1elqMs7JWh11cxkzRZ5Z6ccUCZ4FusrK0+7K32rn8R2 NeMU5yXC7q5RV9ZWmbIzDu+j4L9+r9kuXvSyGO2mRAu5UyF3Jv94CG6iL/KJnW0grqqdNn+E7m6q edtbKpRJnjUzzFaIGo5rnFqg1a0SwzNohqfqwk7lfw/VW54jY/l3jHskTAb3WZgumJpN4JVkjMMK nu49OyEBFtYLgcWxVoK3+x+xuGqpXAb3NZgu7/BXLeSZMpPhPJ+6nHHAJm+dYFyOwaGr7LouOJtN 559Sg9eLLWa7X4+54yGwtZr0U46clGt8fdJ0z1R6Tm7/72kRn995byEralErxUOm3ezw49j6gLET fmcZZqTc7pcHw2azU2LzlO64h9dasVLscZmXA/MO+uG5Erq8s34KjyRjHFbw/GOxVZ4VAYuqOtZ4 T6vhc8TU/fqYmr/B1EoomKq0hgxYnCZ25whfyTgH3A9RUp/U+Bo1NfzNaXreQ5AG9+rTGFXYc+H4 Pf2m+/839h1nuuW4kvu2okygFmbMV0bMpnP93J/DiIDI6qo3vbk38j8ACIBagTP0qDO1hDiD4ent X+ntlN5ZkcaN9FqJ9BjPgrxawe4Ra9/Sa8N7LzvRAC/rpEOfHkuCXm5RG51mx2kIpjBq4Jlo5AHG vIgyxmiwSmuN0GHVsGaGxS2V7TZSL4SzE+a9dlJ73zrnAJDVa5T7XiLtXkInw4geUaJMGy/i4New uae60XuU+y6/QKbGMUhLGDp0H+s4L3RuUW/tTqKouF/U34kfRgH7/ut+rqEjHoXKyIvYrrMPxBoR MmaFSUWMf0l9bYlxI7UTpcq4QbOihNn4c+LVAZWRGvhFW/Ex6grenWTulNZOFoD3pnbyy/Rio4Km 2b9+91HBX35PY6PGF5+YhkUXY67w/oTw8l46cH04PDNWtF1jnsDjBg3nUJ3vEUTbNbr30o75rkG0 S8YLTUfUYUsLNCvarrF8pIdXAXyk9+GoP7MkTW/S9Ea9GGopX4Qd+x1a3+X5PFUXZpK/lK5pZBiR LFJ9MR348kHQWFqw5uSW+L16ark270p2rspeGngUz6mVcmFZ34hTDfQ2TjUYrkGDUxPD5zIuE7j6 uEnYteg+opRU0zyNQpuNVRHJ/1dPs1vYl8aRbUsrxFNQi/hqxLZ8HxabgbniONG8Mmy8Y4TM56Wd Wlmjx+kIm5nuhGvQ8KREdc+YTLMlPGOWRcpuM1f0KEv9GF5LsL6/JDyDBrqqJOINAZujvDgTNew/ mrXhFQTN5hCLImZ2ToP3CmrUsRNznbZTCTUddtINeaDxHvLAcKKB9ZpjUecYrZ0aLb3p0JNubQTG 2wg1Sqfpaf4M755xfTR5YjbadM6XOLXnZycvHh/J26kS1HPDK06e0HM7xoAn1h/aSS3VsRbsWTai vbBYzixrt7AXwnsGyle8Z1B9riD8p/21htt5bSyBcyWRI9dO36Au3MuxFGJaNG+fu87kdsS96J4n vahNfrtbjhMN3j/ong8uExrdpPfdkT+9TG8xuo3j+bqB+7UXtYcb5028xvcS7XDgRAPLoj13mbDs en/u9DjncldYeVdYeXtYeUtYeZLFeXzvlkXKZnOd1fKq12hLhY2/Rovea88+45sA5NEJWv7evD8R hiycplBe48SFjwNepIbjJa13zcOfjT3WE3rn+XPiuYJGY1Dwao4NmcNrdU/jPceIgyGad/vceBnX wsc+nhbw2kGze/DuJDPPI/sovi7URzGbx44vT78RKxqdNziFVXpB03wU1Ef3mZSwamCf01fuFNlB v3fvE/qMOYiwaTuvj+b6VMv5/Dq3t4R9bh919SkfPL8aRuyL7fML50Usi5M0uuFjW+VCfP/iKxRd 9306o074umJf1ccTgUvQtBG8fLnBWy9Py+xVe4cTF8etXzuo1opSmEYmfWlMCN5+Qovu/WS3Vbee 6PG2w4jcXDFO8HRh5fZxKXRzr+wT3opVZdeT7zYkj44oqbHaV/09A1l2o5yvPKrDX9YG7JrLyz7e r3UfHa2/4JNGwn1rdRJ4p7HZV22O15TTspZHaxR8hyB/uT3asLuivt8xA9va3Dt/MH2u5/SI5r/C 04bxGsAKL97pvUe/I9q426N83+4jkn6bj0g+nCwdpfhK6jcPbN7SMwaFNLWevgSGpBMtkPEi0n6p CTvNKNXHWsNXk975huZeccxTH9XKt/NS552w9SPG8fNLO7dz+OraKCvJ8tlE24ycoLZ/MGooqWrM P4VNbqu+azOaVgSwSx87I4Fn0HSPPE+7dZ+kI0KCrbI83hitfNhz0fFONIxI7/VOUeuFawsaW7lI uiFuhK3NroQTDXQrO3SuM2yJNVXXoSfd4JPuu0JOU2foaf70HmR8A0WrU8DuCZX/iZMYJXH0GPWN HitOo9s+Onm0Sgc8rX1B1PhVvZz4GUN+GV6/x6/9ljHr9jIwq89XxtRa2/PDLN57fthnzo7fXe0Z 643O+/JrxpwDaTluN2j6CN6RZI4eaY0VOoykW/QdzgtbeuSLpWX2+kgKUe9/DPtI9sldWmnAiQH1 jDhJEHOWsVrUxdVL4JFo1MKB10ZYT+b0UWrgEzTv9Yg1vJcfK1YaxvJch6bqbSF1p9ROeGPF3uVY sac5dCoRNLv4+HjYzhD22KuvMwQ+QTPiXAS1i3nTsDeDlNr09lrRAJRC93nv0DlG1F3DiE7Qo0zt 2N0cO3Y9x56JZkV7rXu0lLmjvTYMHXbyRGpjTabpH+3t3t5eSzsrVdtWHRFLIHtA5ySJY/460vx1 nO2jm5HmryPNX0eav440fx1p/jrS/HWcFTUvzV/HmT4XG3yxiPb4/PUdCLfd/Xpjd/81w7ZD/7oC 27lvNXb3W4/d/TZid7+N2N1vM3b334K47e4Ts9SShqWWvDfJZFuPtLSjDx0cx+4+ddap+Ru7+7RR tz1v3t1vI3b328q7+5D7dtDfl3f3WrvpDfEJWqRhJ7ZuinQAPBINyzB5OcqiTJa9hmgNhk/QvB1o nR6Av3Rbj9jOTrYaO/rkZpl6nbbtyfN3liOnJ/eMHX3kg3HP2NHn7+KeeUcfljIWr7Dlet7df12o 7fsT2z5H4z68Ul/EwWNfuCs/XXu+9WA4LFR7TV75ihEQ6FucDRDm2YDr9hkvtJBM4kQjHcA7sw8W 5/iVsQyalwK1le8xod+/r5x7i/WP6XnZxBee2+YXu/FPm/QFtt4oO3xXgtw6qUZs/SI43qOM5lm+ 6SCqmThmCaljuGd1Kr0xAsJ0zxrGGQHRcG9/uDdNJnGikQ48X1CSZzdi4YjDxsOoGfYF+nHFCnof 9lXENUoHX4UjL994o1R7743pnX48J4/OS+N3nZd+Ofnr935SfvG1OMkduYQc3pPkFzsNjC+XNznw 5Vp/Ck/bl6e97r0hFd2HY4pqK2EhVwrAq16jMQJC9VwyzP3+4TlgvNDvRl2wtB6N6TB21hRUnB/T np36FkQikD/1/gLb6as2uxaPREA7uXIHvQ2PGjRI+3rJcZlzedQD4laDhuP/htMH3WXq5Xqk9eFr OgQuQfNuPYqXtuguB2xsNXAt2Xqu2lKjmzg4R+Dvdgej8d7/cH/ZTa8b++TAdksMkRE4CgSvohhA b8fToyS0muhb9T35hngAqjW9eLqNcQWalZ3G12DpR8PYAS/eL5mewNITNJYuzwWklgz//BheOzQy XH2PHRYw/h4ta9ZrYl89rFQUhlcTbJ/f03JrrCTsoJkRzYHWjMgnS2v20GG4nn+aFmd5jje7rUF7 9AX63cgdxT8QjlKo+Afg7TX06NGS64tJZcxBSerhJZ2rJ82IPNe5ekq1M2woYX15K4jBo5U8reW+ VvD37yu1gvhiPug7jQLaaOGDoRrK3e4ZuHhr0GyU14ZHPWiMgBCl0jDPA0zPI+OdK2QC10TTvDVs w3YAqQXv1lCL6b2fRS5ojIDgvZ9jSBrRPhkvUp7hb0bsE82OejX2DZmnRVonSrTRQLdUz02m6R/W zOL9EnCUH/uCiATFx1VtphzhuxKi4VybvD1qyrTVdZSHeWakd1Kf5l8g60TJn8kOxgIUjXwG3ul9 2oe9T3M8dtDMHrzQYs3AO9Gkdik0xR44by007JRHL6h3JShp1fDASj3Osh5Hu+xJag/PxBfEJIjx jN50EMfegZfPwhTdQLzqT3hWYLhnDI8dNNBPvNBincA70ZxoH+19M+bu5skkWLdrtIo6YwpJOmNK bDeqYcMuarGw657bzq0xEvbWpS321i2v8cbEcesM46zADO/v1LvuZKnWAEizY0ywT/QK+0RvYZj7 +909v1OOmEzTP6w5xcfu7ZTc49kX7JGX6LV0U4LcNeriabnFv8b9cPcRX9P6OvpLvqJL7jt8xhk4 aNDGixe5K5nEaXR1SxrX9XdbUdZ1u7kIjuTvG/4o9m4F9OhaSW+IQ2AjKX9vQinoVizwSDRcTSOv +mTIVG1/N2odn6DBHnHMP/SGhfBqWVOeyaPUk1LTjVFoEWsLHlXh4VqCplZfM/jwdE2r6kntCZ+g eZrWGFPpbQvi2krStA5fodB7E0otVh/0xoS0mz3wSjS7Bu/uoeleoeleoalooGm0H3q3QnjfpGlT P1M2saVmkQ0uIhVEjltkA2DddwaN+h/wqv+BTM0+a0/4BM3TVLdCqd0NrZvP4d5fvTSby/S2w55m q7INEQ+4G0N8c83oMQfsPc8BO9/dFV75y+Aojl9SbveTRk/dVqoaIiD09OW9UOpfVrV2wOINwBND efY8NHbUG8fVaWqKVUD9Vg3cw4ujr6zF9LGvpJp980ZrYfEr8fv01kJYrVx/dzV+DHfvC/qy8Wvs DbfqN/xp0Yr1NqOBReJFyha5ALj6SLH7HRF84XsB/GI3+cGxI49WXq/o++zgON4P2U35hvfYreUp D6uHHhaxn2XKcaLBG/bNx4Eu8/nCfsc79TZe6yGn7ISr08Av4oX+dlvPbIncNcsiZbP53X3DeKDa O/KyzdZ6O+/2uy+ij+gnRiUfTn5R3kKm8hx+Gblc3Rrl6v7WSTfwQGVRxR7deLN7fRk208dtd60e 8BZ8kjXK8dW9YW0xbvXL1rejokg8Da/KC48RNHiFPmr2KOcGjlnL0Ln+xvfer8u0vuSl5f3Kdhro VqMfHqlPGvaOUXD8/NLO7FTkHuiUegrF5jf+NtU7vl3T6b3gsPk69kB9ToxdzO4t6ujRr42YH/MG u7eoHgufPIN3rcDD0z3+pURejvHrC+cZ8IvNl57G3gq+l7qjdRw2d+o98NuhMZq3C2a8eP07egZF fRe+Ph4es/jMdOj0MGRqzxRpzerjysAlaMpwXtgimbTxrsAxy8I74BwXNI/urlHpWK1aLf4a9ePl y2Yy2K8sI+HqNIotA17FkIPMeby9cVyChnrf0NvizN3paYHGdChJN9PZ9bQZe6J5vk4zMdd/Ytc3 aGbsMUk3jU6wo6vRie3uvlbSdmipXYyjhuZVxCvRxDjK7p5Tps0YesJx572le+u0YERLsWIMgJvr x3N299RXYSfT6oL1PNjtTKVcd/fQiuieNXLT6LEHrJVg7AHfKP3em3W/Mw799u6BV7R229bL3q7s jFZtW5yYhejiPIe3077iRlRz9gubEdE7cewfCp+g4dicvCxrlMl2kGnZrcnFeOVox9bx+7Gk0o4e Uhh2vmpxTw+tzcKeHvukjT099lUrxTF3enBvxB8nN7Q1bqRB7p3imDt9+GniHTfhdp17Wnu4ET+c LSWxnVuHLjrvAJ5VM4++LMYr7669zgIu7vGFhRq/MQ2eFN+IV85WEF43jHjlJ3LJeKH5DSuU1uZu XXde1xR2L+7NrB23dFfEJW+L8crT7z3nHt+UUHo2LucX3mHkF5sJbsYrb+5P1XP6ifWc3Bw/E1sr DA7FmVqMVx7lQncliOtxqTp9QV7OhTbjlQ/3rGHsgImG8cqjXkgmcUs01IG87hvEK2fkJ3LYfsRG zHF+oX7mgemxy4k5riGNcr5s26+T1JPTO1wDWoxXXjzHdKN2MV55+t3itCK9w1E55J6aW5PTI4+P tY78woje/GJRauBpfYH2Oo/BVHbkmM5vkIb7luRVfUW8ctVj7MQJM1558xwwXmhBmcQ70ahVaztr 2rEX17wNuBaBhn/tqBmKHoF2TbHIF+KVJxsu53Ob8cqJEa98RekS72a88qi3d4cNfMtTNNdbYIsz vhGv3Epv91jki7uBrpvRLMYrVw0+LpM23igPfjdiIS4528anEfC/7ffmrazwn0qjcoVnIRY5++PF GOUn8Nymh8UlJ69aG8Yr9/ayMRoVbRP9RrxyjhU245XL78XT3TV2x3aN+Omb8cq7+dfp+3I9iaOn 9HQZr7xHS9a0/kLcl2vkuPqO2GK88uKWaf2FuIaVOiO6sW+ZclnrO5vxyqtrZDTcVyxugWQSt0RD HchrKw3UYnptbm16bd7+hfqtyB3dvCDeUQoVu5y8J+lhcxP/4lJveEN7d8LeR9reHXi1dwepvneH Etb78lKo2xYr4pKjFfz9+y8f9O49uqjUomEXzLTVGShynPCH4oyThr4hr8ZajFcepdIw45VHqTRe aEGZxKnkSgfy+hjsaTGa95AWfxxa6FbsZrzy7lqMGBs4DeOVe+/X0vitaa2KNKMFr+oJd/dqpCVc YqePug3vC0ym65+sWZEjfq8VZUBfKCv6GItdTnxbpHePl5+pGtTz3t1ivPKoBXOmPs2+QNYckd5M dugELWma92kf9j7N7sLCT4YZr9z7K+eFFn0EHokmtUuuKbXg2afNeOWJI5UlxS4XvkFzNcr0HTqT qr07cPgXWLdiPGNxw8kxZuAe7YPOgpG3TffMaj7HcIzbuaJhvPLQWzKJR6KZ0T6umVuHpREL9waj VVwnSYrxdPOIn7Rhqw14+Fed43umtE7xxzfjlRe3bqvNwm6XMOOVe3/vvH157HLikWhGjAn2jF5B sVyYlvWPsdNH3UbUM8l0/ZM1vKnMlHfu8ewL5O7otTR3JffZge0uD7x/ktwTox/FEP/T/uIZ4cW4 4eED3Xvh72kU4rHA3l+9aOaF6NpW05a9kA7cS0/jPETado7j/Y3FASfWWCLtWD0fGP3G/ljMkB1j fyxql+18UdM9Aq8VNDb2iHjlmxHBLY8Y+bvYTNsifMOCGiVI+E+Oq3pVfwsO9VqIs71PcMtm4FWC hqsI5LWZOfbKvAx0jdvgC8OtOg18UWNebjKp6SqBo8Uy3ch7ksyzkmWNsbGhXVObgyjd0c93G4cB txY08h14NTuCzOI91Ye9jXLcqtNAOx97dZcJa1r0oqYDafoN3pFkjjQK7y1WKHovSeoKzN+t/Gtd FxwjcfTj9fj9xdP2wKOl/q+P4/P2Puw2Kcq6vizuY3kd/3ANvKLO6PQ1eWM80NM4wTHigIsG8cFn aC6ZxDvR7B28pilsmLXZGLDrzI1+V0lvf/09rergy/PA2z0S1cYdU60GYF+N8yzhmrkZTxE1dnaf RXS9OgIr5oiSr7M1pJnXa/tcJ0vl2TFy2Bd49q3XWq4oZjk4Vokc0notaKyvf7xaS34zJ/+9+qvv LB2r+njV5O+mdM37hhGBvIZt0oFa36CZMXbtvmaMnFiMj8YUokfvWiem1Bnt5rLz8Mv2H38Mz7S6 gYje5r9te1rwgb4sxhgPn+mWD2Vdn8N1GynA9ydKtW4R0U+p1TIaWBGjjJ5GGZbWZrzxKNWuKXyz Yx3GX1OXDTH66LsnG2Im3dMowKKVkzfmJl3xPWCD4baDBvrNsMFGH8Aj0fRkQ14x6jtWjPr2dRjs qfLsC7H4sb9q+O1Zxui6cyWKtp1Y++s6kU6a6uPMT3604TrNDjsNYx+4RIkzXuyPxmzT0iJNr8Hb czm+NezUGyf83cordNIK08PDVnQYzdzL24dlG+7Tsj9DZG/DNWgYyd37OZPJlGOFqftKD7W43rZI qvIEr8z/GFbLyz3aGrquG7ouz4cPl8BR9kYZ3ivopfhIS3niuO2gQbz0WOE3mcQr0US5lZ7Kk1FV 0xn93NehRlVNh1dj/Vz4T7OB0QmAq6+PHt3eVW9jN1uRRotRmd3AZXrXRxwf9hFH4JdCtDhGD2/b yg/2jNXqIpp587G/3czdvHXrKwyOEeW8eRs60mhlpNUkTxf3pC1WAa0ZUWJ8vEKdhvdGdmd3cR+7 B45x9dCqEXlPCT1OatcttvvGneLrI8jRYxb/4R04VjEsDjt4e89Se/cV779+GTe+jLTmYF+ge0/2 9WRfT/b1ZF9P9vkZJPhzFB8zAJvuI9bzxki5xJUZ1/ZeL5kj7+2MGftTY/76Mq6PEsfsv3g0x30l VW+doKROs/DtWVvdfjTTV1wdv53QGWtbxgubZqxtjbQeMeaJPJsxe9INY8pcJdqLVaKGOC5OQ51v 1HLJpI0naua0OBBv4wc3lX8MzzTD/wae1dtq3QFDzdPdMOp0R8K+Kj30+i54087WUBQwtO0rdhic BlHPT+gtmcLRokiHdUI319n1FG5Jf+xMFx9du/5d76Ubzdo+XpNumnmNzTMRaDttN+7gRvIM7brP L4furRHPRLNq8GpPBTJtr6UnfJwG9WrH/s/YsYv70XjNfX+d4zl78oxnnDG9LpxYxbbo5sK+96Co 5MzNE/sN48R+g+O2gwax2mM9w6KeE8csAPoAF4+8jlxjRPZnz409/pMig58Re/xnxh7/SXeEhU/Q sC6Ql3WEMjUHuHmP/+AGL0+qH9y2Zat0sGOv1Rbe4G3ObWvHwD3R0E7ycnxPmezZT+0JR8zvwxu8 YY3Wr4ltHfTgRi7bMnLLftzgZbtz0s1epyc3buSKmzd4U3riTjd7nV7c2H1ne8Fd/+rcej8SvytG En+31mbnkwXYF0++tJVQ3H3Nv1vrDjvUilEP6ysObrVyxHlq3KklB0dNxPO4dxTJh7wcfR2cJ2C5 REkxjBu8osHN3hk+M5nAK9FIB/DaqJRaMO4POWwVkWnrC2/pXtdV70Yc3sytCWffKAYQOXgCHpI2 zzicHm+Qnx5vokNDo+EN3O0W7WSpWjLSsMUi7466tVWCkJYwbxC3sEa80Hkla2bOT8UtAsdhvK7D O7rBraiIpCmRn7rfSy3Y8lM7YWh9ozUxXtxmLZGflhZoWpQFj6OEEvp+svxk1IQ/VZftS403yal3 slrvkJOGvSN5d9Jj/0qPt0RRg67GDRf3fLvXoPz7sUgmh7eBi2t7Ld4Mv/Cs30HUbutH4E/7ghu3 LfzPk7LCI9qzm0rfnd3z4s7leWEYN3RFg1vDqfSZTN4ZTjQtSl/SVPd1fwyrZr4dkaIyhxMG5vG3 58+xyWudAwfNxskDnWy402USd2+dm6+788ut5mNg72Fa5WnYg/u3M9KoHD2Au1pPMi0it2h4lpG8 6p0gU70ETgNwXH2wuy/87i4bDe7TVm+lXOb06N/C1IE0YwTvTDLt1POxswpu2Q6P6dYwpdraNvRu nBuAW7GY4Htbb+aZge6SWg2/2IzvRlTvk95QP+lt9ZPeXIePjIbnBCIPNUMkHqnPwr79j6W8Eofd WEIZa6tb6x3nAeCPzlyHtn16zbSde2LtPYOm+ZihaZaHkqvXtg7PBlzPFaNB3O3m7YbJFI4c1Qvn 5J3e37Vu9XMFbokGOgxvc10m8QqadoJXuoXO7tVzwyscVdJbNm4pCc+gQWonpXajnmtf4Lx76aNG yrrFexD5WXgmGt4Avu6tEeMaO49Az0mHmXRDhHPr91bCiQY3kk/y4o3yyLs5tNF0qEk3nnBoXjpE Ax9KT/dneHfovAfwrpHajNZC+w/QSKfY6cXtIwa7MYzyYZg3j2t4bs3w3IwyZ+NaRgO/4XWVFUYM 9zq0eKrhR3i2XAfn8VFnmyNq6i98Uq+FL1Yfp90wAN1K9XnZ3ONwT/14/6Fd9MMXwCPvFD8F+aU3 PVFTHQcN8svWw++MnXngGDkKm637Fq8Z2n8+3JeOmrFTzTAa7JWf6Ol2qhm6OYpSqVs7KK0n1YyT aobRID6yehLeTY2aofPeoDEdZtINN35TzdipZuxUM7Z5unoEadhy1CLzhmtx2023MhzDV6dG23pS zdjX8/hZ0IeXsWPlgjzHR+bAZudNrcRt0QJcGxMO37c/sW9PO40G92/Fi/u3Neqe/f5sNvraQw7u 4rbo5UQDm8UL/W+N/uR4D4TcPz6zEJXZfFVLYKfF+eIXnnrkl5PHN3d1qz+6zaua1SsjNuBLbe7B XovXATtxcOKuqkYEvZ5tY4gPT7NRd0MldYekulrQqN0p8bY3ZWo8iXuoaiuw/26jmho0I978fnnt MmHBaoF3D5p9g/fMkHlSycJdVa1p2L1VcLTifUtv1VvRrtdAhRNNzNl6i5nqh5d7pdmdN/z17kYp F3tPUvViJqT26XPVbqsszwad4oO/bMUFsaENl6B5frdbGPe4TOowIs/8rhb/Oi20Oz7/izjOxCpJ vLs6rd582NtAe2v7lJ1w0EAn8SJlySQuUSI9mvRrH7riehDfVG/65FtukDtrlL1ZwzeOZ9AgBnSM 6brOwME2nYE7iAetvpM76dXaGccz0WAPf0TpmTHu6+xFRWMj/6QbzwLUSMtwooFuGm9C53bCFhsD ztChJt3gkxF5YCcEeKIg8sB6+/PH//zrjbc55n7/LguL6n/8/Guc/CH+0pdfH0KS/fxN4P+YHRu2 7ydAkN/PIn0Aq395HKPj2tfjGF2vuYNDH8DhXx5HT0m7Shc1KOmatWoNA5D3E6Bz6AM4/MvjqA2L lo+jNr2hAw59AId/wSPhFZUO0F37/lgDJy6IPRbtfCuArKZzhg/xhziI3Y6+mjgAf/0uDmL/srFM 9X7//l0WWsf/+Kx43Z9/iL/0xUJE+R8/LvP9fL8y9WaS8yj44JezilXxNRFT3eZy+ArOcHIsT4t+ vMfXRDXObcGBq4fvuvEPkhq6hYxHQPWw6FvpZquIxXY9Fp1eFR2+BF9idT0twKf19xZL9D3eH13V F9YB1WtDGSmH79IOz6JKPTxPKv1gpRQUXolmj+DdpBmuJMQ5niNolusJz0lRYRtf4DAEFwZ4LkL3 YN/xhOpQcUxwOAHNCe69K470O/rAhSPckifEhXESTJyxMH/Z1XZA9sAg4HAZd85ZUnDNXAei4BTp KQzZMFiaCnc5wnXF7ovTf36ViojQ6vj0oDnXFIazpLFwnUFT6OjjSiMfXOtnI6LU0LkWsAZv5LAw 8tkWs/GF7SI5bBQ98lAMxC7/7Xcoqi8ghxu4P9as1Pqvj8Cicb6aGgSKkVziEcdj98wQglVwxiuP fAjyKB9N2IokQMCEsZRNdV7LZpEuYaK0F27dsk4MyNL4vZl44ZFoxrGslo7I6upum4FPD5pzg/cm mTelBRrpcFbodpI1r4nTvu5XEOwN6vqHdhWAhtqcpfeA+x/aDf0yTPu0X3kQmv71c6U4lksBWvqq 3YqPQ3sVX55txv/75G17Cci+fqmJ48t8i006TPLTRdHSXQPX6k+2zTQUjRMtRf7RVMFhrReFoe2h NOQvxaE0GzxB8Dnc2G4IA1xGQBPARruQxzQWcg2uIJjb2eZwYXN4EnN7wivUcSU/8/s3Pm24LTIa 1oZAjV81zh56EfCR8KGwEqyr481F8K7OMsjfdbYNLOtFBPwxrL1nHNNu2KRBPCC+SUMIQYj0wxVS BA/iwd5vTkWNAYvDEQTfAMrYvrGlCeOtCMLutFinoYTWHNblBLh8Qbanr4RJddrxEpEdnp7sgx9k oHwijLoLE1dXUp+N8g6MXNyXhpWOR6IZLXj7DZmfpfF7D/pXFUxOa4HrCpragxf6S6bZ4ha7ZZHy N+B6B/pYnOp7c4NOrO+ZDRabDzZ5iBBdOAlwso1sSIjC4OX6Hg5pGODXd07Q4XGCPZztFBd2uidx uif8CKTOY5OSKG037Fgdu9zQSL6CovIP9F89zFo8DyUapQpes+zJ7MPskT9hUOATNG/0arynhMzX slhawNIBNNINvNIZMrUD/16WYWHlZsRzHpd4iV7uvBRfV81yv+GtJ/XtwdJDr+cRGte+Dqsp74yr pPRhkpWu6aDi85KW7YQYPj41ZNXTQ0Zt2nelicx7qhgc1wmGl+MNt1MYEmYSpgMaqXd6iOe+cNCH TyziFQLGORmvW+RB+vFuuBscxQneoFVsXwJ8sBFwFifgdBhsnA1DGCfzSMLgl7AInjpie0pKmOkL 5Y36Jysko/jsFKVwxL7frJQD53fgx+DXoxjB188wlgNVwnGi8cYIvC9HnbH4ioggXDOnUQaD4Fm9 p/tiLYcz3KKER6jzhHEgiyQEWxA8dTjtgJLzuOrrukFKuIQ6z3hCuGS7N6WZ+cwduDh8RSE6riZj VUJ5hkuBSSsMXdLiEazubIu0T9h0B9rSPXR+/bkyckfB0ajkSd4qQw+qtDyCdsxv9nYExXWq/6jt 92fWZrnA72Yu6HfQcwzxDrgzmAJOjW2V/Dcg4UCHsIeMw9FUyPiTeXAuf/+K68Ge9qfJ/uPcbtlx rufBxYEKwuoE1+rE/uNGTeEjTji5Z/ArB0bwjWJu9VJ3jjvyqjViIni4hYmoYD7JUcKuyuhXBA1+ vjaC7z9je5JVZQCDYHsW8eEoCsMqL5MQfAmTAOpYca0mzPT1yn+53hQK6fdaVJjeAk6p1Zhrqd46 VTvWrr+GGsFHFSnXovAdn2P/51/94o25tyyMc/Rd+/j8ncMCQPU5+GPgimy/eNgKYwr8ig2X/t6h zL/qCi3uBPAEMBIaugxJIqiKx7YYugbvXzGiDalZxQBXFtjJuBCGKgm8btG4ZtE3ZJ44Mka4qO5X 3A1+7QbP9va3qcErS5A9x3YI75EA0/D+spILlp7Eg1/TbfBOEcAsskE3CiNEEiRQwo9NA3Qmfan8 wmqUa3ybK3Snq6n1aVx7ICNln+sp3uYpilG0KEMMb4tLYoPLAtieGAwOfBNmWQcNA1SRl4Fuxhuo OX7jPQauwll5p1/LggaPhmdn2WY0PhzMtD7fNoaqwZtZjQ8IIfab4V5Cz45r1zdh6gkaS5fXnTVy UGDgERYzT/g7toLw1tfv37VNRts2Dnkxva3jX/qyOTFbxR7AFdUODU81Wc/WNy39MczeGL4xvHC9 eLsvj/n1pYANfOF5goZV6o339ChtpGV+NYyNQ9LAZ+KlppRJvE7QSAduOtZkP8MtUourHF2Lv5t2 atydntzY2CQ30rgpf8XN38Vt9LbYO96Zira5yP52dBqDH31tR/WS89qaZk9SiQPHx8TRb3BwSYYc uhYyRq18OPrHvtxfX7h4zC/L5utP2tFs/Pqjx0yRQZzHO8Pi+Ekymgp6alLf88TUcDQ8N8zfsanN ifzoyEGUlrcjFjjRvPH/wZYSNT2jBeaCE2mkw0i6QSZzgGkJt0QD3dgQSucRtowZNkqHknSDT7Qo AV+Rhj6knu5P+h3abfodWu/IaR6i1O+nhjU6XElZfJpEuITeGtFAb/8dJXAETvl05btnP6/JIRZl u1zQe28/OX4zL6N52hnv09pkAtfIM9NhrNAN+aFpBXr68Tqb2jhwe4EtgP8t3DUye0u1PKU1Js7E Y795vEBsle9CjPfYbO1cvn5XXhy/tU6jwTl78Y4kE2fumZbrA4e/nq52Dd34gpgaQ6bHL29GUPlC sNLelAVuDt+Fb5LL6MKUOxSLmbL0BbLGDP4xQi7f5hINqxx5ubQP/Ubl72cG5q2A6n4VL7WgTOIR vjcdwBua4uWsGTbc7dpNDLv4+2yh9dQLAforeXaGZ7t/gXV83UAcyZsaNZCGI3vysnulVJvDIl/V 3C7GoyvJ4/oCWbwFzDQ0GSI2Ox6NShF4VdL2tRPr9LjhO51mcdMh9JNM4lTaTQfwhqbFXroSBz2w KmLTkbvhXPsmXvb6lLDOElESX9fNkvzLCG/wbu1409fKWzD6PZVFux2D4KTGDTvEjTTEzd/FbfTe LaJeXs6JiYfKZ/sLPlYOd+GXH8M2dHqlAZHYfgxzq+tRtaLcWe9cNaf/8+0+lcHShneWhEeiGSN4 +eZSCVyG6SdszdybUaJJsrmPmqGFJqwmzIwHTbvC25vFnZrId7WsNk2i34Ud0b/QAZ8cLWN0b+be bNDSfWXQmsVXNq253CPhGXpuNKM1YeoJGkv38XrTSWtYjcnhM0ropC81mkvYo+ZS+Lpt/a6w5yY9 fJGqXTZmP4bXdA7DzzM8UkqpfFSGqfHYqbAtWj2aLq8+mb2699RwwnuGxwya5xnjndGgEist0EgH 8K6ZrbnDrdH8DNYYrh4ulZrOttwCW/6r0RiTpoywRvlmabk1wtDoRj4b77PAZBLfoJEOj9ee0GFZ mGy43luowM6xk9STpB5fZkJXwbUd4NPTFwbhoHUMgEHPMDCGfm9RY/j74x4nuJ8mxj1HcON3cRu9 p92svFUP2QbPKpQbPKuD0fCs4zGDZtbgncNCsAn3EzRjBO8sIVNlCWlZGb5BA93EC50l0/T3HGpT HQKxr+a0cbVgVSyom7SzWTll4TwN8SzWmfuCDfoArocTTu/t+vKhHRfXMbLjkju6Va7zoN8x+E4u bB/VGdsIYVpB+nfo4P3b4GGohfDp7Q8fBej3lwzPf5Pauno8zm16DBsYXC0aQVGuK6H7N3ht4Qmm jur9vYQRXidQwrhQ3sKJ47BLxlEU70fHCXE3xN00RBu49UKoRSeoytOBhFxAnlh0kllv0cmHV3O6 N2YMR6f1mm/RaZg3psai29af4A2DWHQ6pv6M8aaEAU63zxLGolMPo94PyiktGEHj68WEEW+c1gcn YoRsMiLF66MzYxStj0tQEQrHJcC1qlt4t4lKSdiXdD8a39pw+ldN+ebNwJaV4dGD5k2falU30p5M X5JvxRrnS32A3y0u2zF4YxudWaamp4TWp4fWp5WEQ2tNgKG10Tcsx4TWhp/WRoNpaw+teR9RuIbW p4TWp4TWx87acQn4rQatzbVe4Ouri1pNw/KiVt/6ndvWSj5cAvNRL9LEiiEWZF0mMFcDSxmx+mYp +7qtr8ZgVVXrcsKHaWClUBi67qQrdjSwFtp4Rd5wCRq0Wkx5a4nX0tISruMb634Fq4xs8agp94KE b9BIB4YLtAVZrgBWt5OnwvS71vz116m24KuVPtrJFQv9fkZwH/MlLkCcaqu+tk7I9E51DY3b6L0S Vq7/MDdQnFmEK9e2NLmpPQo9cVdv9Hg6u+zH0q33w+9cJMXvHJ3gV2sy3x/q7V8NHCzbr+IPVtr3 TtZgKX/VfrD6fuNhh+80ogjeYUSxvW1dCXvbumwcAVnFQMAFT7DNEMaFJyTBdTMkPEMdEZRibFCd wmDQcENH9sXkEtPTYprvXns0cX+bv+sq9Jd899+xO0r9HvXaDtlrg+DIMW+/YJix0843v+ueC+Go CG1P8am1tGPw4HTWNZ214I8fwb2Dle8egX4rgBB/R8Q++GVrB+T9yhawfKOQ/KteJoBFDL5BgTbM febxUaHxYiryntMH36Ym7X87mdzffAd/tb8JKF89gpU8a+K+wmKMNRhrMD4CjnzAxn7zlX41Ca/A GPwKgBHM5mwzhM1IYobGj+0kn1oVe7ueCoOIxO33Tzud/XwOs6oKeE19HTgFW9+WosXzYjJ4mOxL vgCqSpwV1LsHTFl0pvT4oJ1Gq9iDLF6OLjc63s/XFrae17RdC5ibgFq4r005trH9ipt/+azCLqeM /XAP3L0e1CIvgFctwJuJFTmqj8CjB824wQstJJO7q4lGOoDXNKUNXLR7hb4W7lfzdw4h30+/f7cD H7ThHCvhRvWKuKhQhGuRW4l74uZjTcjNqqEStOUTULSCTwgKtxU0XQXx8erBC0nFUxji8C/Ps5VL y/B4lbbg2Dfh6rlSrRI93qkcWun3pwf3ll7hqFWVoyf5Q+ma9x3foIGmUfhcB9AoLfDq2VvmRONs FSk0eelxNM5QIam1FTiapsct3wPnxqy2E6W6nVyq7cvzTUs+a3sEXlGq24xS3aKD+nB1Pxl+9hkN rJjhD5MJvBPNjlLtmsI3vXinBRw22JeKdauwoUfr9BUt77ptzYu81kBhvey4DYZHbDVAv55qpskE rommhA2uKW2YO2yYNp5B2pv5gLUarr1UrGwJvyVgzTNhg6aftO1GudeaGu1U/ws7uffkabmdwtB1 R4nrJ9l2ks03aEyH4Xr+aVpzIgU8a9S4qXL8rJktLJhNg5ru+L0+bzRoycQLP0om8DhRH4atKVHq iFI/x0zeti/QaRz32JxJpxklycLC8i+GHxLHnWGd/IQUNDjoI/DoQfP8Z7xPP4YxEq4+MrQ1K/Bq nQoyV4u657gETR3BC51rCVxy28qnxNiWr+FjkxJfIGtEGVvJSzqcRhq1m+DdSb8dvjAMe1K9N17Y v3rg1H6YDuANTa+FLSLm480se4axgdKi9uxU9nY9CZegKcmrN2qPTsnTmrtCo1QzjBeXMmpJONG0 qD324DRL9B4+ham+188vK9oP3+yh1Sc8YEOx1gM/D5waHjg1PMCAQ4aTB254QCf4PC3zgGFYcZJ1 NzxgMomD5sRsSXpamTw9PHD6SXbal4ZtqSjrDHsk7hkjsrPsGkF5Ez8/ZtO1k1/SNPGbIP/RO68j PGhHJnAzi2sE7YUvvzqqcv/QrsWTwjgYhMzxRzDseMhbXBwhbjRu8j9q/51PLVoymtJBio4gPGrO +gmTfkPndh60lTT8cXUCyM6kjbbfEV+e4HlLmmzo2xkOb3eCl/jtnqIdbHqHkp1Ap4sfm3YKnjCd RG5+OA0JG8HyQ8m49ChhKx1Kxu+69fHSsy3IdxpJv0PKuC6FBygBV/dklg5ydTt+DHG7JXF40oPU XHuFjLMc3mniGAITbIyMCXGrJJcvzkvwu805nu36HVKUt496uNacDJOgV3MZw9LBkUuO/Nxr8HO6 EdxrbEi6e9G0JB6BFaqedHu3mY4XbzsR96hPyLgt4EnGctzC+1czBG5e/eXNK+bA+1Vaf5U4/1pT Qd48iP4SsuBycMO2hN401vOcsSoJp2fSVqF4bNwZed5jhDl4z+DnBiO419iQ9JwOVxAo4ce2k7FH 958+UUclb36zWR2B+/x8Qjc7DPcpZPCra0bwSTa2e03Y00LXXwGPNwxHZfSx3RB2vcScezzhG+qI 4Ckptqe6hD2DlIRs88y51Yv27e75O+3M3ZfilS/eaQntl7/K4vjrtSpfTINW1xR8E/HmUC3R8uPL Ly/vdtfpJPPLyxuZYgTXD0tD0+OtpyXxCJTwdd1k4zf5bmYksJtmX54uH/Ys/YatXp0r42sL26Cz 7fcX1xyIbTETl0HrpM8mJqXLMqRWHf8cmAKPwL0HDYc15G3Vstgm2dCvVj906fi9KGo0zwfGe6/L hAeUFnHUFdcNvDPJnKm81Gq3+wqxc58SUqOV+abSkUJTU/t4GaXEpGqiC46/fGk7vrSd8k5fkHeM 3UbftO7NfGWMNuFZstyVUvQaAblW3p9clT/I3VEO2umBby5RneuWxGqmX20x/GpLHyGV8c4oqfeQ 2lNp1DEOaKRTb56W6ozjl3tGc6/zwk7JJO6Jpt/g9RIOLVZ3L3UfhezuX6jfDi9rykl8Vtigigre m/TIfQwi4VrpGs2r9oeDY0SXWEdPHY3e0xXuPcmdNeyYNcr/tME4qZZ3cdVGGfh9eyf3+/c8XsMX TyO3sV8FKvHlpmGPfYGHdAoOHKvMwNWHPopcS14NGCB1tTT6UURbcaSWbKWa4aOURzNrSI2RafWF eli7NKgamPRN98JSjiO67a/fW/KBhhWUm7vaqvtNyHNdcEKe64YTOHYdCWffaqLIi/k+7LCTfVYT 947SZ/jVRB94DJt+SdIKr+0ZtXXbYfdi8W0jLauJhm8PGtgzolXcM/LO0gKNdLiup9m5uSxKjluz nfxCne4IXVN5Oqk8+fWAdxi6juMHx+vYfqC9DmpCPPU7DkXxUDF4hx+wdlwRn9oPZDs9lrs4jRtY UOKW3TvYbekOLJVxufAdbIVu/+Zh5sA36LFARD2JqSdplC54bYEZ1kwd4ccikp3UhE72BctAxQ/L fy3GCMxFfdK06/bMOGAt/Kcseqcjfgxz5EIOYSydnRZSd0p598ArvKqlrIFFKvOq0jLvGcYilWiw SCVeaCqZwDvRSIfhepo12uojtkPoPfCzZsWB/A83t2BxoZu47qDh4h+sWSXKguZjsMYwFmZK5LPx cpktyoKlBRrpMFxPKwuLI7i3rQrsHKlULfmFWG0PbeD8j9jDJ1y1Hz+Gb5QYbdIRp/xnNEF6wOix MHOXe8AwFmZu5JV2LaGfrgEJl6BZfjnha3v8qkXdNmWEDW85ycr/qaHdSXml5SenJ/dYwZ0WgqCH cY9YyHL68BgjUIvjhkW3haV2iWEgdvNwK+yiw9ve8YsRieaVz3R5wmU+2+z3Z5vRlxNySnfc73Ya tIXihf6S6baoxpSwLFI2m6/WFSBr3pDF3Orn/OX3X7l1Ocegl2yMTroTLdy1k0X8chPPTWW58cUe XjQp1kq9k0m64vLOExVdfXnniQy/80QlXYMxXp58KgkHTS3DeRlRmjIZUZppOS5Bw9NacTnGZJr+ bidevP4xrEWA6y9n82JWHaFdtcUoyKo8/0hsU2HQNc5+IFfzAf5uV4oQLzqu2jTvCZ4svqHDL/aG Di20L89CbUKRo56Ewwu9RA61GznUbuSQ4efllrxvvNCiloQTTYscck1hnTa8cDGozx0cK0laK/D+ 5QEuhBPbGBma9+u9ZBvN663jd85Nt2DggZEus+mMJnEZ4aUbF8Z6tKpIy7xkGJZGq+q8z4aRPGZp jRs6DNfT7NTiLTn0Crps05enkw720J5Zwwb5FfjXNb9xhrUYTSu6/J1WvBbj9+/nl1Znh1Z2MARf ZtJ3hr4lvjwdZw+9ZvTrLY2J2lRrD17r118InOLjOsejB83z54z+22UC90TTd/CO1Jq2uVrYYEdy oMeqzW1YMa5rWvqlDTcu2vG4umw4Pk6N36+9As1Limmc4vKH0jVdV7LTaJ6mpgO0vsnO08NOteGI Y3kj/OSD9qZj+n2UFFPR/3hThBzGsgV9z/Qzfp9JvhP9BMn/Sp9+X/Nvw2cyxKbRr/nrd48iaUbK 3tpyAvwA+F9+wF/SKb6cYDm/WJzsr19CGVPstr9JZv6XX3I6wH/L81vpf+Y55S9a/206f2PPo5M9 zV6VC02l9X/zxfWRbv/Nl5OknSwt9DHdLMJ6/KVi71/iLxX8+NIST//FMyMdYv/Sk7TfX/6Zx60z S/+LLydJO/9kqdX1/58Pgi4ahb/xQcvS/he/uYT/4Plnaf/s65Z06790m+W3r+PLP+dCT7r95vln aStJW/+hgUn7/eWfeU5K5/xHOibt15fyx//91//51/8DMVvCkWVuZHN0cmVhbQplbmRvYmoKMTcg MCBvYmoKMzc4NjQKZW5kb2JqCjQgMCBvYmoKPDwvVHlwZS9QYWdlL01lZGlhQm94IFswIDAgNjEy IDc5Ml0KL1JvdGF0ZSA5MC9QYXJlbnQgMyAwIFIKL1Jlc291cmNlczw8L1Byb2NTZXRbL1BERiAv SW1hZ2VDXQovRXh0R1N0YXRlIDkgMCBSCi9YT2JqZWN0IDEwIDAgUgo+PgovQ29udGVudHMgNSAw IFIKPj4KZW5kb2JqCjExIDAgb2JqCjw8L1R5cGUvUGFnZS9NZWRpYUJveCBbMCAwIDYxMiA3OTJd Ci9Sb3RhdGUgOTAvUGFyZW50IDMgMCBSCi9SZXNvdXJjZXM8PC9Qcm9jU2V0Wy9QREZdCi9FeHRH U3RhdGUgMTQgMCBSCj4+Ci9Db250ZW50cyAxMiAwIFIKPj4KZW5kb2JqCjE1IDAgb2JqCjw8L1R5 cGUvUGFnZS9NZWRpYUJveCBbMCAwIDYxMiA3OTJdCi9Sb3RhdGUgOTAvUGFyZW50IDMgMCBSCi9S ZXNvdXJjZXM8PC9Qcm9jU2V0Wy9QREZdCi9FeHRHU3RhdGUgMTggMCBSCj4+Ci9Db250ZW50cyAx NiAwIFIKPj4KZW5kb2JqCjMgMCBvYmoKPDwgL1R5cGUgL1BhZ2VzIC9LaWRzIFsKNCAwIFIKMTEg MCBSCjE1IDAgUgpdIC9Db3VudCAzCj4+CmVuZG9iagoxIDAgb2JqCjw8L1R5cGUgL0NhdGFsb2cg L1BhZ2VzIDMgMCBSCi9NZXRhZGF0YSAxOSAwIFIKPj4KZW5kb2JqCjcgMCBvYmoKPDwvVHlwZS9F eHRHU3RhdGUKL09QTSAxPj5lbmRvYmoKOSAwIG9iago8PC9SNwo3IDAgUj4+CmVuZG9iagoxMCAw IG9iago8PC9SOAo4IDAgUj4+CmVuZG9iago4IDAgb2JqCjw8L1N1YnR5cGUvSW1hZ2UKL0NvbG9y U3BhY2UvRGV2aWNlUkdCCi9XaWR0aCAyNDgKL0hlaWdodCAyMDEKL0JpdHNQZXJDb21wb25lbnQg OAovRmlsdGVyL0RDVERlY29kZS9MZW5ndGggMTc3Njc+PnN0cmVhbQr/2P/uAA5BZG9iZQBkAAAA AAH/2wBDAAICAgICAgICAgIDAwIDBAYEBAMDBAcFBgQGCQgJCQkICAgKCw4MCgoNCggIDBAMDQ4P DxAPCQwREhEPEg4PDw//2wBDAQMDAwQDBAcEBAcPCggKDw8PDw8PDw8PDw8PDw8PDw8PDw8PDw8P Dw8PDw8PDw8PDw8PDw8PDw8PDw8PDw8PDw//wAARCADJAPgDAREAAhEBAxEB/8QAHwAAAQUBAQEB AQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAAAgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1Fh ByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZ WmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXG x8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAEC AwQFBgcICQoL/8QAtREAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHB CSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0 dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX 2Nna4uPk5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD9/KACgAoAKACgAoAKACgAoAKACgAo AKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgA oAhlLAfLnOe3X8O2frQA1XJfaeoz29+/HHBH1zQBYoAKACgAoAKACgAoAKACgAoAKACgAoAKACgA oAKACgAoAKACgAoA85+Kvi/xB4E8Ca14m8KeBdU8ZeJoGgg0/wAMaOyJLqNzNMkMStK/ywwh5Fea dgVihWSQg7MUAfMv7DnxQ+MfxP8AC/x2/wCF46/pWqeNPCnxM1rwz/xIrZYLG0hto7X9xa/Isjwr K8wR5i0pUjexYEAA+4KACgAoAKAIJGZVysZc4P4cE89/bgE89KAPi39r3wf4w17w2vigfEv4vad4 D8PW8MzeCvgJapD4n1rUJZ0hSX7X5jGS2jikkZrZI1HytMzv5SKoByv/AATf8Z6x4++AuteJdQ+J Wq+NNCl8WavD4duvE+oJf67pmkJKot7XWJUXH20kyTlSz4iuYNrbCiqAfoHQAUAFABQBDKSEfDY4 +9jOPf8ADrQB+aX/AAUY/ad8U/APS/gV4Z8G/Ei68Ba1408T7NQ8YR6Hb6zDpmjwKiXjPayo5d1a 9tpVRF3MsLqGUkBgD6B/Y28bXnxC+Etz4quf2kbX41xXOrTpD4ot/DUPht7FUSJTZy2KYZHVg0wa RVZkuI2C7SjMAfWVABQAUAFABQAUAFABQAUAFABQAUAFABQAUAVpx8nQnOegPoT25/zxzigD5H/Z E+F/jr4YN+09/wAJ1oP9mf8ACW/F7xH4p0f/AEmC4+2aZdfZ/In/AHTts3eW/wAj7XGPmVcjIB9g 0AQSybAp7Z5OM4/DqecDA5yRQB8wn9sv9mkfGI/AU/FzSv8AhaRv/wCyRpIgufK+3YJ+zfbPL+ze du/dbDLuMw8nAlBSgD6cjlWQrtYMpUMHXkEHpg9889PSgCSUqANyk89hnFAHxr8ePhn+0nffEXwZ 8X/2cPivpFjqllp8mjav4A8f3F4/hzU7Ri8q3Qjt1MkV6krj51AZkSMbkWOSOYA6n9kr4Ea78BPh zrOm+NvGB8TfEzxjrt54w8VatFAlvbS6teiPz1tY1jTbCvlIBlVLNufbEGWJAD6moAilfy13e4FA HlWvfGj4b+GPib4K+DeteLraH4oeL4bi60fw5HHJNPPDBG8jyOUQrChSKYq0pUO0UqoWKMFAPUkZ jjLA5GQR3+n+T1oAWbO0YbacjnGcc+nv0/GgD48/ag8K/HQa78H/AIv/AAF8N+FPFniTwDf3ZvfB 2vWdlFc6vZ3qxwT/AGDVp1LWEyKrE7HRXUkyecI1hkAOX/Y5+DfxO8KeM/2ifjv8WvB/h/wP4q+L ur2l2Ph/4eaO5TRILMTostxdxMYprm4Nw00rIMM5MhKtK0MIB95UAFABQAUAFABQAUAFABQAUAFA BQAUAFABQAx/uk+nNAHyB+yJ8UPHXxPP7T3/AAnOuf2n/wAIl8X/ABJ4W0f/AEWC3+x6Xa/ZvIg/ dIu/b5j/ADvuc5+ZjgYAPsKgCrcZ2Lz3A6nqeB068kenrkYoA/ILx74B8CePNLP7AP7KHwrS0+CY 16Of4n/EG0eb7Dof2a6trq5srfUZRMLrWCFtlKuZfIQRxMpCv9lAP18iyXYkjcVB29CM9CR1z1HJ /h4xzQBZZVfG4ZwcigDxv9oTxJrfgb4C/G/xt4XvzZeKPD/hDWtU069MaTfZrmCymlifY4ZW2uit tZSpwAQRxQAfs8+JNa8bfAT4JeNvE16LzxN4g8IaLqmo3oiSH7Tcz2MMsr7EVUXc7u21VCjOAAOK APZqAOI+I3jbTPhr4A8b/EXXLe6n0bwtpF5rN5DYxrJPJBbQvM6xqzKrOVjYAMygkjJAyQAfz8fC T4//AAy+If7an7J3xq8QfE4ax8SPFOveIrbVNKjttRaHwZZXtktnoOgRM8EUMoiluJw9xBEqtNcy vIWXEzAH9GcAbMhZgfmIOPUE9/pjjtjGTigC3QBVmjUgMFHmA8MRnA4z9OB/9Y9CAeBfsufHH/hp H4H+CfjYPC48OL4jF4f7HF79u+zm3vJ7U5n8uLfu+zhvuLjdjnGaAPoegAoAKACgAoAKACgAoAKA CgAoAKACgAoAKAGN91voaAPgL9gb737af/Zf/GH/ALZ0AfoBQBDIcBfc4wDjOf8AOfwoA/NzVP8A gnp/wTx0bxF4d8L6x8N9IsvFmvmc6TpN5411aG71QxKHlNvE18HkKLhmKK2BgnA5oA/R6Jdh2hcc Z+v9SfUnGc0AW6APn/8Aax/5NZ/aV/7EDxD/AOm64oAb+yb/AMmtfs1/9iB4e/8ATbbUAfQVAEMv ReM/MMD1Pb8uv4UAeJ+NdA+DOofFj4N6542udGT4t6N/a3/CF297rBtbmX7RbiK/+z2nmqLjMIXf mOXYMMNpOaAPaUyXPGDgnJ75P58fh2oAs0AIe31oA+AP+CXH/JivwN+ms/8Ap5v6AP0AoAKACgAo AKACgAoAKACgCFzIF+TGfUgnH4Dr+lAHzefih8ate8bfFDw18PPhd4L1LRvBuswaNJqHiLxpeaVP dSyabYagSsEWlXIVQuoImTJklScUAav/AAkn7U//AERr4Wf+HK1P/wCUFAB/wkn7U/8A0Rr4Wf8A hytT/wDlBQAf8JJ+1P8A9Ea+Fn/hytT/APlBQAf8JJ+1P/0Rr4Wf+HK1P/5QUAQyeJf2pQFz8HPh WMnp/wALJ1PngnH/ACAPbtn+oAPif9ijWvjzbN+1r/winw18Baj53xs8Uy6j/avje+082t6xtvNi iC6RMZoVGzbM3lM2TmJMAsAfb3/CSftT/wDRGvhZ/wCHK1P/AOUFAEUviP8AalKjd8Hfhao7kfEv Ux+v9gfj+H4EA+Ivjnrnx6b9sf8AYVm1L4ceArbxDb/8Jt/Zen2fje/ltr4nSYvP+0TnSFaDYmGQ xwzeYxIYQ9aAPtxPEX7USkrH8H/haV7f8XI1JfT+EaCdv0BPXqetAE3/AAkn7U//AERr4Wf+HK1P /wCUFAHh/wC0x4g/aOm/Zx+P8Ov/AAo+G1noUngnXFvbux+IGoXU8EBsZxI0cL6JEJXC7iqGSMMQ FLqCWABH+zN4g/aQg/Z0/Z/t9B+FPw4u9Ej8D6Glnc6h4/1C0uJ4VsIAkkkK6JIsTsu0siySBScB mA3MAe6f8JJ+1P8A9Ea+Fn/hytT/APlBQBFL4j/alKjd8Hfhao7kfEvUx+v9gfj+H4EA+Ivjnrnx 6b9sf9hWbUvhx4CtvENv/wAJt/Zen2fje/ltr4nSYvP+0TnSFaDYmGQxwzeYxIYQ9aAPtxPEX7US krH8H/haV7f8XI1JfT+EaCdv0BPXqetAE3/CSftT/wDRGvhZ/wCHK1P/AOUFADH8TftSIrM/wc+F aqASWPxK1PC+5/4kFAHxH/wTl1r492X7G3wfs/BXw18Bat4bi/tb7Pfa343vtLupM6peMwkto9Iu FTDlwuJWyoVjtLFVAPt//hJP2p/+iNfCz/w5Wp//ACgoAP8AhJP2p/8AojXws/8ADlan/wDKCgA/ 4ST9qf8A6I18LP8Aw5Wp/wDygoAP+Ek/an/6I18LP/Dlan/8oKAIm8TftSJgt8HPhYB6n4k6njoT yf8AhH+PqcUAL4U+JXxU/wCFpaF8NPiX8PPC+jf2z4f1TXLLUvDniu51nP2G50+CSKSObTbQru/t KNgwLD92RjnIAPoWgAoAKAGnnH1BoA+f/g0qr8Rf2rlUAKPH9ngDgf8AIreHqAPoKgCrOzovyfeJ wCeQOD26n6Dk+3WgD5S+IXx48V3es6p4T+C9poFxJp1xJZan4x14zXVlp13G2Jbe2tIWR754tjpO wmgjgdgoaeWKe3jAPOD8Tv2ost/xXnwsDcNt/wCEF1JtoPQE/wBtqQe/I5Bz6qoAn/Cyv2oZT5b+ OvhWQQSQPAWptwASSQNcPAGSfYH6UAfIn7I3jj4+aWP2nm8NeLvANsbz4veIbrUP7V8JX97596wt /NkhKapEIYThNsLeY64OZGyMAH17/wALP/ak/wCh9+Ff/hCal/8AL2gBD8T/ANqIAs3jz4VbQCST 4E1TjAz0Gtkk54A4ySORQB8h/GTxr8eJ/wBq79jXUNY8UeBZPFFgfFo0u6tPCd/DbWZbToxcC5gb U2eclMY8uWLafvGTpQB9dj4mftSINv8AwnXwrGMDnwLqmQCAVP8AyGgCrA5BB7EYGKAHf8LP/ak/ 6H34V/8AhCal/wDL2gDyD9oP4hftH6h8A/jfY6342+G0+i3HhDWIruCw8FajbzywNZyrIqStrEix MVLBXaN1BwSrD5SAH7P3xA/aN0/4CfBK10Lxp8N4NGh8I6RDax3/AIK1C4mSJLKBUWSZdYjWWRU2 bnVEU5BCgHAAPX/+Fn/tSf8AQ+/Cv/whNS/+XtACH4n/ALUQBZvHnwq2gEknwJqnGBnoNbJJzwBx kkcigD5D+MnjX48T/tXfsa6hrHijwLJ4osD4tGl3Vp4Tv4bazLadGLgXMDamzzkpjHlyxbT94ydK APrsfEz9qRBt/wCE6+FYxgc+BdUyAQCp/wCQ0AVYHIIPYjAxQA7/AIWf+1J/0Pvwr/8ACE1L/wCX tADf+Fm/tSNn/ivPhYcc8eA9T4xzyRrhwO2fegD5C/YN8cfHvRf2UPhVp3gnxd4Bs/DMP9pi1t9b 8JX2oXKZ1K7Z/MuItVgRiXZyAsS4XaDuILEA+v8A/hZ/7Un/AEPvwr/8ITUv/l7QBNa/Fz9pvTJ4 r681P4X+JLWMgPosOiaj4de63fKMX5v74Q7Swc5tZN4UoNpYOoB9Z/Dn4i6D8TNBbXdDFzbyQTNZ 6hpOoKsd5pF6gVpLW6RSyrIodGBVmSRJEljeSKSORgD0SgAPIoA+fPEIx+1P8HtvGfAHjEnHr/aP hnrQB9B0AFABQA0/1oA8A+Df/JRv2r/+x/s//UW8PUAfQNAHEfEey8X6l4A8baf4A1W00vx9c6Te Q6HqWoKGt7LUGhcW00qlJAUSUozAo4wp+U9CAfAXw1m0F/AHg+38L6bd6RodppsFjBoWoMVutIFu vkm0nUuzLNCyNBKrnes0UisSwYkA7kNt/iAXAGM7QAPQdOATjoATnnlWAMLS9N8ffEnxNrfg74b/ ANi2Vrocds2s+K9fhuL+CwnnRpYrW3tIfKF1OEjR5o3uLVoI761lHnK4QgHd6p+zx8UPDsA1LwJ8 VpvF1z96bRfiTDa2iz5YYFvfabZxG1ILu7iW1ujJsjRfs+WkIBwXhfxHa+KfDmmeIrOG7t1uYTJL Z6hF5c9lIuVlt7qNWYRXMMiTRTRbiUliKnBDKABviLXrjR49LtdJ0/8AtPxJq+o2ukaXpnnlRdXM 7AK0hVGKwxxmSedlSRo7e3nl8t1jZSALqPgK10jWtE8O/Ej9rLw94N+LmqrCdF8CaWdJSzdpW8qC KSC+U3+oAz74mlt5LLz0QKkVs+WoAQt4r8JeK7z4f/EO106HXorEapYapo8kqWWuWnnPFJKizIrw zo6xtNbqblYFvLUG5k81cgHRAsS6jeWVigCbm+fA4LDjAZk5A+7k8kCgCl4C8C+PvjTp9r4o07xd D4O+GV1NKNO1TSrdb3WdaiSSWNLq3+0I1pa27tCskMhS+Fza3CuPszkNQBF488CfEH4JaZN4rvvE kXjT4XWbQrqGqanbrY65osDSLE11OLeFbW6giaUzSybbJba1t3ZhcsrMQDSZtok+b7m5sFmfGMlt 2ApwFHHA5z94EbQDn/EOu3OkJpVno+n/ANp+J9W1C20nSdLMzYu7qZgFMhVGZYUTzJ5mVJGit4J5 djiNlIB3lh+zd8RNS01dY1742S6P4kSNXtNH8OaXZTaLbZUMI7p7mJrq9UMxR5YZrDzo0XZFasS1 AHA58XeEvFFz8P8A4i2emw6/FYDVLHVdHllSz1yz81onlRJUDRTo6I08CvcLbreWgNxJ5qkAHQli N67sMCyD5ujAbmG48NtGCMDkA9OoAOf0238f/EHW9d8MfDTw/ZvHo1ylhq/irxDOsVjpVxJDDN5S WyM1xdXC293aziELDBIsrRteROpWgCfxr4d+Lfwg0rV/FfjoaL4v8D6bbPqGreJPC9s+k3OjW0as 8002nXNxKJreKKJpGkgupLhi0ca2jYMpANkl0bZISJMn5WbBBGMgDPYkZbvkcL0IAEuVZVb5iMfM 20c8E5J4wMkcNyBkEZFAGt8CLa+vfj/421jw/hPDtj4Yt9M8RTsmVvL1rg3GmQRuAwWW1t5dRkmQ MjBNUsmdZA0ZhAPuWgAoA+ffEP8AydP8HP8Asn/jL/05eGKAPoKgAoAKAGn+tAHgHwb/AOSjftX/ APY/2f8A6i3h6gD6BoArXBQRfP8AdyCT6d8/X098UAfA/wAQPDknw1+MOoWcERi8F/ET7RrGnhEZ YrPW40H2+3QBViT7REI76NRueSZdVnkLKuKAJwrO22MBlLKRgN0zkbsA7SMK3TrwOSKAPRv2SprF /h7440+UI3iuz8Z66NdkcK7yPPctdWRmlBImxpNzpSr8zGOJYoTtMRRQD58/4Jv614Nu9L/a20Pw n4mtNYsovjJ4hvID/ap1K4n0+dYFtbl55ZHlmWZbaUrPIzGVo5CWYqxoAu6JLb33j/49apoShfB9 x4zuY9Oit0eKKN4bW2ttQ2R7cxk6rb6oz5RRJK0kuXEquwBu+EZLW3/aM+DdzrjhtIuNM8Q2GlNO vnIuuulpcQsicmKY6daa0PPIUCNpYgw80KwBxH7Qlp4b+JPxk8ZfCHxV8J/E/h34LyHSb/x34r8N /D3VdV1D4o3MCJNZadDfafaTbLK2Xy/PnZxOWxbwiNTJIQD3L9pqWzl8bfs+WOlxhPFsGqapqE0k aCOUaFHps8F0rTHAMBvrvRt0BbMjLE4VxCWQA8Z+Kdh4m1L4X/ETTvBc13H4suNCvodLltLg28sd 40DLD5czFRGyybMOZAQcMTgGgD2v4x6h+zn4g/Z18Caj4ofStO+COqnRrjw9Nd6ZqK+H7YuqHS31 Sytmt1/sxXa2LQ3hitsrErlG8qgDxj9jLVfB+hfs2ftG3/jeO1ufg3pPjbxlM15HaGfw3qWgxuWm l0awVZVi0ll+0KtqklypdbgiRy7KoAnwtsfE2m/DL4dab4wa5k8V2ug2FrqstxcG7le7jgVJt86b 1ZhJvJbcysSSG+9kA6jwi1tD+0X8H7nXD5mj3GleINP0szJ5yLrkiWlxC8aAMYpv7PtNaxOwVQjS xBh5oRgDyf8Abh8c/GbTPiN8A7BfCfim3+HFp8XfCFvYx6HeaULbxq2ReNHcGS7WdZhcxJFBbyxw 2ytbPPLPK0kAtQD6U/adns5vHP7Pmn6coTxjBqmq6jNIibJRocemzW92pmbAaE311ohaAsPMYQsF bySyAHLKG24XeygHjDHceBtBIAG3Ax8xYnHfkAEng25ttN/YISe18daP4I8Sa34LuxfeKdZ1f+yo NE8U6gsovJbq5BH2KVNZubgPGoVoZcxoisixAAZ+x1rOoaXrHxd+B3jZdfufjP8ADWHw9a+J9b1H xvq3inTtdkurD7RFeWjXzK1q8jeeZIY4EUERgPJhfLAPMvhHFaWvghLDRVUeEdP1bVrDw6Y2DxS6 HBqFzFpbQy5JmhNilqY5yW81GEm9yxZgDqvFXiK18J+HdW8QXlvdXMdpFmOx0+MS3d9cMQsFtaxl l824lmaOKKMMpeR1VTuYUAfW3wN+Hd38M/AdjomuTWtx421CWTV/EV9auZVutUuCHn8uVlWR7eLK W8HmrvW2t4EYnaKAPZqACgD598Q/8nT/AAc/7J/4y/8ATl4YoA+gqACgAoAaf60AfPnwgYp8Qv2s X4+Xx9aE5OP+ZV8Pf55oA5r9qf8Aat+H/wCyp8PZPGXjG4W+16932+g+F7WUJc65dJgsqsQfLhQM hlnIKxKw4eRoopAD4L+B/wDwWK+HnxH+Iuj+DPib8OH+Hvh/VCLeHxVLrw1C2t7piPKW6X7LF5ML 5ZTNuZUbaWCpvlQA/TH43fDub4ofDvUdE0f7LD4006SLVvDd5qGUittUtm3w+a6q0i28vzW9x5QE jWtxcRgguaAPlDwv4isvF3h3TfEVna3Vs1zEZJrC/VI7vTrpflltblAxMVxDMjwSo3zJIjqxJBoA BbeMND8U3PjX4a+LotF8VXVtBp17Dqdimqadq0EMk0lvHdwAxzqYGvbxla2nhLNKGlMqoIyAdDq3 xY/aA8Z2hsmHh34c2OGMt74avj4j1G5IIP7iS9s4YLQKylXElreF0dtq25RZWAMXw/oOj+GNB0Pw roNskOhaPawadp9q0jTGKGFVSNC7MzNkBAcljhRyxagBPEeg23iPTRZXFxcW01vd299aX1ns86xv LWdLm2nj3KyM8VxAkgjkRo/kxIrR7lYA6K0+Ln7Q2jac3h8WPgnxNx5dt4v1We50q4tEwFSS606C F4ryZSPNZo7iwSZmKJFahQ5AOXsNM1WTxBq3jPxh4kn17xxq0UFrPfm1gsore3heaWK1tLZANsEc t1dMod5rnEoWWeUKjqAdAu0sGABmAxuiXfyNwHTJJ+9nkswGeAQSAYnhbVPib8KGvYfhrqGl6z4V ury7v28EeKP9FiiubiaW4maz1OFGmgMlzcTzyfaIrsMQsUQtUyygB4l1b4nfFn7D/wALA1DStG8I 291bajb+CPCYNxHPNbTxzwS3epTxJJMYri1guYxbx2irho5hdIRkA2/kkJY7JFGxS2Rgc5Xrkqpw pO4DqSwVSCADC8Q6HZ+JNNjsbq6mt7iG4ttQsr6zMYls7u2nS5tp4UdXDNFPFFIFdWiyhWRSoZWA Ols/i7+0Nount4fWx8E+JmKmO28YapNc6Vc2aFQiyXWnQQvFdyjHmM0dxYJMzFFitQocgHL6bpWq tr+reMPFniKbXPG2qwQWtzemzjsoILeBriaK1tbaJQFgilu7tkMrzTgTASzzAK1AG8Vzhfk3OFQl huL7eARgYz8/zFiTkDAA6gHP6VqPiz4fx+MNJ07wrofjT4U+Jp7i61bwNqo+z3Ef2iNVvBZPIzWs kc6RtI1nNFCs1zfTzy3MayFSAQv4j1a58Ja78PPgl8HdO+BvgPWFnGpXscFla6sJZYfKlksLXSpj BbzGMwmPUHuJHjeAhrVkCyAA3LKx07SbG20vS7C2sNLsokt7e1tESGK1ijAjWNEVVCooCKq4VQAF 5HQAr+HvD8nxI+MHhTwa0YPh7wi1p4x18gsu6VJ3GkW/BVgJLu1mu98bME/skwzKyXK7gD7Q8d+P vB3wr8H+IfiF488Q2mi+C9FthcX2p3ZYJBECQu0KpLuzMqJGgLMzKqhmZVIB+NEn/BbjwynixbH/ AIZ71b/hDft4ibVR4jh+2CyMgHn/AGT7OYzN5Z3CL7TsLYXzcEsAD9nvh94/8I/FHwnoXj7wD4it Nb8H61bi5stQsydsi5wwKsAyOrKyPG4V42VlcBgVUA828Q/8nT/Bz/sn/jL/ANOXhigD6CoAKACg Bp/rQB88fCFivxD/AGrzt3Y8f2hxj/qVfD3pz7cAnnpQB+H/APwWh+Hvi9PjJ8OPic2gXjeAbvwz b6BFrcUe6H+0Iru9ma3cqflkMU6uocKHAbYW8uQKAfjhpOj6nr2qaboei2FzqOsahNFa2em2MTzT 3c0jKI4IolDM7s7KqqoYksMA9gD+4j4V6H4n8LfCv4c+GPHeujWvGGj6Dp+naxrAuZLsX99DbxxX ExmlUPKXlR23SLuYnLYJIAB8n/EHw4/w2+MWoWscJTwZ8RBNq+njy28mz1uJB9vtoxtWJPtEQjvo 0G55Jk1SeRmVcAAmZmfKs2+PAABJYFecBlPfGCQfXHagDnfFXiO18JaBqniS8s7q++yRgxafYos1 zqU7HZDbW8bMvnXE0rpDFGG3O8iKM5CkA6HU/hX8Fvhr4K0Hxj+1vfWXjXxRq01lpsunazBLrenf 2rdYVLLRNGjt/wDSSJmuFgla2lvhC8oeZowwUApfET4c6F8LfDGjfFv4Zya5p/wyaW3l1zwbqST/ AGbStNuAyfbLa1uo1uNOFs72PnWzSQ2lrZQXRFusiDIBcZMn5t+7nJIyzZABwoLDIA+b5myGXlRl gAYUOk678Q/H2ifC/wAM67faKklrNrPiHXtLiiluNH09QY7eOJ5oZoFubi5MYQSxMklvbX5Uq8MZ oAfrui/sPeGNa0nwR4p8B67pXjHWPEMXhix8a6t4Z8UW+qX+qTTFI4IvFTwi4kMm1o1db1ka2Xbu MHy0AV5NK1zwB471v4X+JtcvNZjW1h1rQNb1WOCOfV7Bwsc6TGGKKCW4trpHWQQxKqW91p5Ys8rG gCn4z1fV9N0qGy8L29vd+ONduY9H0K0u1d4pr+fKJJOqfvGt4U33FwyBmjtbadwCIyKAN3x34d/Y 9+D1+uj/AB6E3xG8bHSLjxBdTeMdBm8XXOm6XA+2W9+w2tq9vpdoMpE00VvbxzeQDK0jxs4AKniz wppvwsm8A+JvBnjDU9f+B3i4pYxzajqTa5Ho89xGj6dcQag4aVrK5YXMZe5ubgtPc6fDAEjkZVAN txjJZTvGVO7GGbG0kbiMg9TlgQBggYwwBi+FvCOm/FOX4g+J/HHizVND+CHhGQ2M0mn6mdGi1ieB Xmv559RjxKtpbbrWJXtrmBvtFtfQzho4wpALPgnw5+x58Y7mTRfgRJN8PfG39kW/iCCfwfoFz4Pu NR0u5ZkivVsLuzS21S1O2RFmlt7lITcMyNFJKrsAY/g/Vdav9Ln0/wAVW9vaeONFup9I1+ys1eKK O/gKrK8UbkuLeUMlxC0m13trm2kZcyUAdVn3I+nGKAKd/qVjotjdavqmoQWGl6fE91Pe3UqxRWcE alndmYgKioHJwQAueoyCAe5/sveEdQ0H4aDXvE2kz2PjDxnqF14n1CG9SSG5gS4Pl2MNzCwUw3MO mw6fbzIqgCS3ckuxaRgD5H/4K8eAfF/jn9lSwufCegXeqp4X8UWuvaqLJd72dhHZ3sUlwVHzMiNc RltoO1SzthEZlAP5YwiNjlfMCjjJx0AzkA9BnOcAEHr0oA/q4/4JPeC/Hfgz9kTQZPG9zefZfEGr 3mtaBp14Zw2n6XKIkjCxyACNJZYri6QR5R1ullBJkbAB9X+If+Tp/g5/2T/xl/6cvDFAH0FQAUAF ADT/AFoA8A+Df/JRv2r/APsf7P8A9Rbw9QB6b478AeDfid4P8QfD/wAfeHrXWvB+t25tr7TbsHbM u4MrBlIZHVwrpIpDo6q6lWUMADwH4R/sPfss/AvxhD4/+GHwltNK8YQW8trBqVxqN/qD2ySAK5iW 5mkWN2UFC6AMUd1ztdwwB9XbFznGDjGQccUAePfHP4bTfEz4d6jouj/ZI/GenSxat4cvb4lYrXVL dvMgEsiq0i28uGt7jy8SPbXE8akGTNAHyR4W8R2Xi3w9pfiCzt7m0a7TdPp+oBEu9PuB8s1rcxqx Mc8MqSQyxt8ySRurElTQBj/EPT9UvfDcd5oen/2jrWhanpniKz0oOkR1SfTb2C/jtBKxCxee1qsJ lbKoJS21tu0gG7+0H8OdS+OPjb9jv4//AA80PX/GHww0KDWb68s/BWvP4e1m6tNW06P7Jc2s0lzZ FY98cYlH2iKQrKAVdTIFAIbyD4t+Fv2HPC/wi+O+sDWfjv4+02bwLPcG6F1IjXqXRZpp1XZNPZaU s88pZ/8ASHsmRZnkmSVgDfVUQRqoDxlQNocKJQRjIJAAyMDd8wIAORtIIBL8LdWi8G/H6P8AtBfM tfiRo8Gh2d4YXQxalpkmoX6xbDuLG4tr2/lZyVEQ0zaxZ7iIAA68/DXxp4//AGv1+LnjvRWs/hn8 MNA+weAStzDKNV1PU4/+JjqCtEyyx7IUSzEE6vG24TRlW6AHH/FfVY/GP7QStY/8ePw30S60K6uO c3Go6o1heywFWClfItbTTpA4DJJ/aJUMrW0ikA4Pxnq8HgvU/h58Wr5Q2j/D3XP7c1ONiVC6fJZ3 en3c5ZQzf6Pb6hLd7FVnl+y+Sq7pVZQDO/bF+AnxW+InxQ8Q+KvCfgHVvE/hfV/hFrHg3TU8H61b aFfWOuXFwJYW1OVrmza601lZf9GaW5iDLKzW6l90gB6b8TrbVdE+D37OX7P+vHSrj4gXUehXupza DaCCxtLfQHsLy8uLWCOKKMwSXcdlZrCiwlEvxIsey3kUADU3RqscbEkIRlSVJXbtIVRztCjbsHVV OAFbAAN/4C2PhvxB4C+NH7OfjKxS6sYbzVLi8t/MkiGr6L4hub26WUOhXyQZptRswgk83/QfN+QT RgAHmn7Lf7N3j7wf8brr4seIz4p0jwX4Z8A2Xw08K+HvHdxot7q8mnwzw3Qmlk0lVtoYo2j8lEZ7 idz5kkkkYMaUAU/BusW/jTUfiB8WNPATRfiBrY1vTkViwksI7Kz0+zmDbVJ8+2sIrzYyq8X2zyWU NGzMAdszAAk8cHB7Djv/AJ46ngGgDmbrQYfiN8QPAPwkumT+w9U+1eINeik5W/0nTJLYSWYTDB2u Lq6sYpoJY2R7Rrtdys0YIB+jURYsSygSY5CnIB9M8EjOcZA70ATuiyDawyvcetAHxJ/w7j/Yq/4S r/hMv+FD6X/a51A6kYDqGofYvOMnmFfsPn/ZvJLceR5Xk7fk2bfloA+2giqcqoHvj6D+g/KgDwHx D/ydP8HP+yf+Mv8A05eGKAPoKgAoAKAGn+tAHgHwb/5KN+1f/wBj/Z/+ot4eoA+gaACgAoArT7RG 3mY2d8+n05z9McmgD4G+Ifh1vhl8X9ThjUReC/iCJdY08sfLgstbiC/2hbJ8qxoLiEJfJGu6WWZN VmcsFBUAn6bvlbqRk4GAD8vQn5jw24HHQgA0AfNvxx8TS/s4/Djx58ZvhxqWu+G9Whnhn1Gw8LXt taW+szXV3FFLNNbXVtdWZumaRHa8NsbllhVPNCEqQD2XSfB+l2OsT+LNQmvNe8cXULW9z4q1+f7b fyxMyyPCjtxb2zSgyrawrDbozM0cSZNAHWdC3uSx/wBonGSfUnGcnqcnqTQBj674c8P+KdKvND8T aFYavotyEa4sNRtEu4pxGyyKHjcFWCsgYBuFIyMGgDwNvGvi0fGpv2b2+KHxFfwK3g4+KzCvilN5 Avjb/Z21LyDq2DLifeNQJC/uNpiOxQD3zQPDvh/wrpFroPhfQ7DStCtCywWWlWsdrbxqx3kpHGqh Qzu74CjLMzdSSQDYP3XOCcKSMHHOOAT2BOB+NAHzJ8RvEeofs8x/DHT/AIS+JvEPhDR/GHjHTvCb 6R4au9P/ALO043RkYTw2V9Z3UFqUZZWdLSOATtKXlZmUEgHuPh3wZ4b8NSape6XYyS6vqjINQ1nU 7mXUr/UjEGEX2q/naSe6MavsQyyN5agIoVQFAB1RGRj3B+pHNAHK+IvB3hzxLLpl9qlk8WtaYHGn 65pl1Jp2paYHx5otb+F457cSgFZDFIu9GdWDAsCAeH/DrxHqX7RUHxNsfi14j8SeLtE8GeLtR8KR 6L4kurBtNv8A7MYmaeezsbOzguNzGJ0S5juPKaJWjZGJZgD6cZ2dtzHLep7UAC4yNzBVzzkA8d8A soZv7o3D5tv0IB6H+yr4fOqeHte+NOoLIbz4iJazaWWY7ofDkCv/AGWu5SATKtxdX3zIksQ1EQPx bpgA+tQqr0GKAHUAFABQB8++If8Ak6f4Of8AZP8Axl/6cvDFAH0FQAUAFADT/WgDwD4N/wDJRv2r /wDsf7P/ANRbw9QB9A0AFABQA0jPr+BxQBwXxB+HfhP4laHBoHizTprizguUure5s725sLqxmUMv mW93byRzwOyPJEzxOpaOWRGyjupAPnlf2ULxySf2kfilvIDE/ZfC45PJ5/sc9fqenJOBQB8cf8FB P2e7jwJ+yJ8XPFD/ABv8f+IFsxpinR9ai0Fba536naR/vDa6bDN8u/cu2RfmVd25dykA+x0/ZSvJ NoP7SfxTOFwGFv4WwuCQVH/EoOMHqBx09KAJf+GTLv8A6OT+Kn/gP4X/APlNQAxv2T7xMMP2k/in wQd32fwt8uOc/wDIHGPT8aAPjZP2e7o/8FBj4JHxv+ICzj4N/wBqjxAYtB+3lf7c8r7LgaabfyQf nJ8rzdxA37QVIB9l/wDDJ14SWP7SnxT3Hq32fwtlvqf7Hyfx6UAL/wAMmXXf9pP4pkejW3hYj8jo 9AHxr+2P+z3d+Ff+GWBJ8cviBrX9rfGTw1pKf2vFoX+gNL9pxdQ+RpkWZo9uVEpeIgkMjfLgA+xF /ZRvW5/4aS+KnAx80HhYle+M/wBkHrnsOcfSgCb/AIZMu/8Ao5P4qf8AgP4X/wDlNQBG/wCylewr uX9pP4rbuV+WHwuvUYxn+yB16fU88ZoA+N/2Ov2fLrxY/wC1Ts+Nvj7Rl0f4y+JdKP8AZMOgkag0 Rtybmb7Rpsp85t+G8vZENo2ovOQD7M/4ZMu/+jk/ip/4D+F//lNQBf0v9kvwu14jeO/iT468daEv zf2B4iuNOtbKZs4P2hNOs7VrmJkLxvbXDSW0iyMJInIUqAfWAAHQUALQAUAFABQB8++If+Tp/g5/ 2T/xl/6cvDFAH0FQAUAFAEMjFduCM57/AP6/x+gNAHz7efBDWG8X+PPFfhP45+P/AAmvi3UIdVv9 L0a20Ca2NzHZWliGT7bplxKuYbG3yPMI3ZIAJNAEv/CnfiL/ANHY/FT/AMF/hD/5R0AH/CnfiL/0 dj8VP/Bf4Q/+UdAB/wAKd+Iv/R2PxU/8F/hD/wCUdAB/wp34i/8AR2PxU/8ABf4Q/wDlHQAf8Kc+ Ihx/xlh8VOOn/Eu8If8AyjoAQfBn4hKdw/aw+Km7GMnTvCB4/wDBJ7UAfEv/AAUY+G3jLw/+xv8A GHV9X/aD8feJrCD+yt+h65ZeHI7W6LapZqvmNaaXBP8AKzB12Sr8yru3LuUgH2rH8HviGSSP2r/i nuIwWGneD+SCQR/yBT0OeOgz9aAJv+FO/EX/AKOx+Kn/AIL/AAh/8o6AGv8ABv4i8Y/aw+KZI5wd O8Ic9en/ABJOD70AfEqfDbxof+CjX9g/8NAeP11Y/BP7X/wk4svDv27yv7d2/ZCh0v7N5OSJM+R5 wbA8zb8tAH25/wAKd+Iv/R2PxU/8F/hD/wCUdAB/wp34i/8AR2PxU/8ABf4Q/wDlHQB8Tftr/DTx jpA/ZM/tL9oTx7rv2342eF7O3GrWXhxP7Onf7Ttu4fs2lxbpo8EqspeEgndGx24APtRPg98RCf8A k634qDjvp3g8kexP9inr9O1AEv8Awp34i/8AR2PxU/8ABf4Q/wDlHQBFL8HviIoUn9q/4qnntp3h H0Ppof8Ak474oA+J/wBif4ZeMdW/4a0OnftA+PtCaz+NniizuDpVj4cY6nMn2YNdTfaNLlxK+fmE XlwjA2xJzkA+3f8AhTvxF/6Ox+Kn/gv8If8AyjoAP+FO/EX/AKOx+Kn/AIL/AAh/8o6AD/hTvxF/ 6Ox+Kn/gv8If/KOgA/4U78Rf+jsfip/4L/CH/wAo6AD/AIU78Rf+jsfip/4L/CH/AMo6AD/hTvxF /wCjsfip/wCC/wAIf/KOgBf+FO/EX/o7H4qf+C7wh/8AKOgC94S+DF7oPj/T/iL4l+L/AI08aa3p 2j32i2MHiOLRYILSC8ns5p2VbGwtmZy2n2wBdmAAbABbNAHulABQAUAMdVcbWGVPUev1oAAqgsw6 nGaAH0AFABQAUAFABQB8Af8ABUX/AJMV+OJ9Dop5/wCwxY0AffaqAWbucZNAElAEU23y28zb5fff 0x70AfkF490z9uXwt8YvhF8EvCv7cb+JPGXjD7Xfag6fDLRYIPDOi2wPnX12yea4MkpSCBWWOOWY MjTRkAkA/XeGVnC72G4qCBgrngZ4IyMHseRnmgC3QB8Aft8/82W+/wAf/CAP/k3QB99KOfpkD25/ +tQBLQB82/tcfGvU/wBnX9nf4l/GPRdDtNW1rQILcWdlfyOkBnuLqG1jeTb8zIjTq5RSpcJtDxlt 6gHy38K/iv8AGP4X/tJfC74M/FL9ozQfjT4V+Lnhq51jw5qmiaDp2l3WmTW4a4WeSO1l2NYXNqs5 jnBlaSWEqioscjOAfpbG7MQpYk47jvweT26jggGgCzQAUAFABQAUAFABQAUAFABQAUAFABQAUAFA BQAUAQyttUNwPmAJzjuKAPg39vPxn8Krj4W6Z8B/ihoXxG1+8+KU5h0/w98KdLjvtauF06SG+nlj WUGJUjaOAOPnbbISqkK7xgH0F8Afj34R/aH8Jap4u8J6Xr+jvpWq3Og6t4f8VaebDUdI1C3KmW3u IssquEkhf5XYASBW2urqoB7tQBDINy7e5OBzj8j64yaAPjD4ffCTx7P+2x8e/jv47gul8K2/hjSP CPgSQTWXkz6dIqXmoJJEgM4eO+jyrTFcrcOF3KE2AH2kEVSzBfmPU+tAEbkqBtznPTHX2z0Gf880 Afnn+1v8UPhNq3jH4b/D3U/Bfxd8f+Mvht4o0rx7cab8GtBj1d9Du7cSmyj1XdxHHcLJKyxKRKVj DkorI0gB9tfD3x/4S+KXhDQfiD4C1+01rwfrlut1Y6lYsxSVTwwIYKyurBkZHVXR1ZWVWUgAHc0A eN/H+D4jXfwd8fWnwl8M+FvEfj6eyMVn4e8axtJpmrIWUT2s6BkDebAZo1DMqF3TeypuIAPzg/Za /ZI17Rfj54P+Juq/staT8CvA/gDT9Rm0+wtvF6eJdR8SatqEa2sjXN0WlP2KC0jcpASnlyyl1aQS yhQD9eot25sk46bTjgcY6evJ/GgCzQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAQTH9236k Nt2juc+1AH5B/tX+G9PtP25vh1q/jz48ap8F/hl4u+GVz4fj8X6JqNvpVzqNxY6j9tk0+O+fd/Z+ POs5jOwCyqpt1JaVhQB9Q/sEeOPiL4y+EHiex+IXir/hMIfCPi7VfC+geP8A7MY/+Ex0mzZI4dQM okkS4LSfaE85Hbd5Q3tJIJJGAPuKgBjorja65X0PQ/WgBgUbiwzzx1OO/bp369/wFAE1AFeXdgY+ 9njgkDg9cf8A1u1AH47/ABG1DWNE/bL/AGkJPDH7TGgfs1yXGj+FGutR8VWGnainxHdbe6CXtr/a MkSQpbrizZbcsjPCxco5wAD69/4J4w20P7GnwFS18F3HhaH+yHY6XdySyyTu08rNe7pAGCXbE3iK BtVLlVQsgViAfadADWVWxuHQ5FADRGg+6uOc8cUAKEVfujHXgdOaAH0AFABQAUAFABQAUAFABQAU AFABQAUAFABQAUAFAEbqrjaw45/lj+tAHHeNPh54A+I+mQaH8RPA2geKNEhuFu4tP8RaZBqEEU6q 6iVY5lZRIFkkAYANh2GcE0AdDpOkaVoOmafomh6Zaado1hBHa2ljYwrDDbQxqFSKONQFRFVVVVAA AAAAAFAGpQAUAFABQBGyhtpYA4Ofof8AOR+NAHn3jj4R/Cr4nf2X/wALK+Gnhbxb/ZokFl/wk+j2 2pfZPM2+Z5XnI2wt5abtuN2xc5wMAHoSqqjC/rzQA+gAoAKACgAoAKACgAoAKACgAoAKACgAoAKA CgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgCNyR jB+bPA9aAII5GZgD/dB5BH0OMcZ54J7CgC3QAUAV5yyxOykggdQMkfQdz7d+lABE0hKiQgNjJXPI 4H5855GB7UALISAMMAe2fp6d/pxQBCjyFpM/wuRhgenbBx0xznnkkdRQAsEhlUHdvHXcBwT+Q9iD 3zkcUAXKAI3JG39c/wCPagCvBIZVB3bx13AcE/kPYg985HFAFygAoAKACgCCQkAYYA9s/T07/Tig COFpC8wbPDEYP6YOBkY5zzySOoNAFugAoAKACgAoAKACgAoAKACgAoAKAK8zlIyy43dt2P8AEdOv XtQB4Xrvj268FfFO4t/HniC20/4Ya34Y+0aZd3xjtbXT9Q09rqbUVuLl1TEktncWs0SFmBi0y+k2 xCFmkAPIrX43at4H0nQ/G/xY0XXnupfBPjj4gmDe1pd6XotrqFhc2+nXOmZjga/jsr+0gZ5GDRS2 kyCSQTySMAL4J/awvPG+peJvCHhuw+G/i/4hw+GtR8RaNpPwz+I0HiGC9eza3iNre3L2lsLF5pby 2WFysisFuCxj8pRIAaV9+2N4GuT4kXwZZ/2/nQNO1Dwt+9msv+Eo1K9Nl5OnjzYB9lB/t3w1/pEv yf8AE3OQBaXJQA9K/aa1jV9C/Zx/aC1zRdUutM1jTvBWuXVnqNnM1vPaTx2MxjkikUhkZXCsrA5B 6EECgDj/ABt8e/FfhmT4v69ofgDTdV+H3wpLr4r1C88QS2Wo5j0+31S4/s6yS0lhuNtndw7BLdQF pg8beWoErgDvH3x98W+GH+Luv6L8PNK1H4efCosfFWpX3iKWx1BjHp0GpzjTrRbOWO5xaXduE864 t9829D5aqJmAM3wR8UNUf4x/H34caeLvxD4ktvG2nstjNeslt4Z0ZtA0SSSeVzv8lWla6aG3Rd1z cNLtCxpd3FuAUdH+PHiq51Xw94L+HHwvTV9f17UPHLiTxB4tkittP/sXxAthJJc3DwzTrDO1yzRR wxS+QxhgSMQ7poADorL4++LPE8Pg/QvAvgHSbv4iasfEJvNP1/xBJp+nWn9hajHpmo+VeQ2dxJKD eTxiDdbRmWEO7+SyiJgD034RePNZ+I/gk+I/EGh2mi61b6vq+jXenWN+1/BFcadqVzp8jxXDRQtJ G7WhcBo0YBiCDigDxPTPjr4ql1Lw34O+G/wvXWNd8Raj46KSa/4rlitrE6L4gWwlkuLmWGaZYJmu maOKCKUwN5UCx+TumgAKHij44fFrVl/Z6vvhr4Z8Pi71/wAba54W8QaPretyWsM11p1nrMUsEV0l hO5tTdaZNOlwIopWW3gVolFxKIQDrvHPx+8V+Fm+Leu6N8P9K1P4efCzf/wlepX3iCWz1HMOnW+p 3H9n2aWcsVxttLuHZ5tzbF5hIjCJFEzAHrHxV8fy/DL4WfEf4lLp66k3hPw/qOu/2Z5ghN0La3ln WMyDcE3CMqWw3qB2oA8K8RftKePPCjePF1/4Km2HgzQYvG+uE+JLeX7H4ck+1bFykZ36wf7PvB9j QNZ5i51EBkLAFz49ftO2HwJ1Jm8Qaj8Nv7FstJbWrvTtX8dDSvEN3bo0wkGnaU9oy3bskDCFTcRL JMTGSgXzSAchr/x/b4Sa98b5de1bSme9+Jtn4b0STxr4jGjaNpefCWlai8c146Sm0hbyrtlEcMm+ 4nVSqmVpFAPbvgV8bNO+NXh7xFqljceH5bvw/rB0S/vPCmuJruk3M/2W2uwbK+WOIzJ5d7CjFokZ ZUlTB2h2AM+7+K3xK1PxX450j4e/DPSfEGg+CdQh0vXZr3xGdM1G4umsra/ePTrU2slvN/o99bhD cXluDNvRzEiiZgDnvHX7QHivww3xg8QaJ4B0nU/hx8Kyf+Eo1S+1+Wy1EiPTbfVJjp9ktnLFckWd 3BsEt1b75gyN5ShZWAKHi/8AaL8aeG7346ajZfCu0uvAXwiuCfEOv3viIW8t5aLpNnqkp061W1fz rqOK6dTDPJbRFvI23DebKLcAPF/7RXjPw7e/HW+sfhTbXXgH4R3BPiLX7rxELee7tF0mz1SVtOtV tZPOuo4bl1MNxJbQk+RtnbzZRbgHK/Fj9tDwz8LvF3xD0a9uvAcGm+BSn9tWfiLxtFpWu34FlDqD f2PpZtnF6Wt7qJIg9xB5lwrx4VVErgHrOofFj4j33ivxxpPw/wDhhpeuaD4L1CHTNblv/Ev9m6lN dNY2uoPHp9qbWS3m/wBGvrZVM93bK0xkRmijUTsAUNI8dfF2+/ae8feAP7J0B/hXpfhnQdRS4bV5 Eu7WS4l1dWlSAWJEryy2kcLRtcqscUEcyMzzSRIAUPA3x98V+J5PhJrmt+ANL074d/FMJ/wimp6f r8l5qOZdOuNUgGo2TWkUVsTZ2kwfyrq4CzGNF8xGaZADtPgJ8T/GHxj8B+HviRr3gC18K+HfEeka fqukWp1oaheyJPCJJDcIsCRxICyNCVld5InVpEt5N0KgHutABQAx0VxtcZFAHnfxM+G3hT4oaBZ6 D4utBLp9tqFtfq4SJmPlviWAmRWHk3MDz2c6AfvLa7niJCyNQBjeOvhJ4Q+JOqrf+Lobq8tW8L63 4RuNNSYwQXWn6o1kbwOyfvVfFhEqvG67Q0mckqVAJPBPw91rw5qdxq3iH4ueM/Gl19nNrCviFtNt rezVmVpdtvp9pbRyOxijG+ZZWjUMsRjEswkAOO0f9nH4YaIng37FpKx/8I5r9z4gtx5VriYSljFZ yFYhusbXytNNrCAvlDRdMwc2seAD074heCtN+I/gHxx8O9bnvING8VaTeaLeTWbok8MFzA0MjRuy socK7MpZWGQAQRxQB5l4u+AOj+Mb3xpu8ceKdH8JeOMnxV4Q0z7B9i8SK1rFZS+c9xaSXcPmWVvb 27i1ng2rGGTbKWlYAf4z+AOj+MNR8bE+OPFOj+FvG/8AyNnhHS/7Oay8SE2sVlL50k1rLdxeZZW9 vA32S4gwsQdNkrNKwBtx/BrwynizXPHVre6tZ+LtR15NefUraSMPCRZWFhcWKgxYayuINLtvNilV 9z7ZkKSxW0kIAvhX4L+GvCXiXSPFOnahq8moaWPEwiS7midP+J7qsOrXm/agPyTW8aRYI2xkhjI2 GUA8v8c/CZ/BmiaHrXw2tviRP40s9W164ivvAlx4dfUILbW9Qk1S/iZNYC2bWpuo7fbtQ3KiCJVb a0xYA9D/AGd/AupfDn4U2PhvU7W5tLp9X1zU47PUNQbUbqzgvtVvL2CC6ujLIZrmOK6RJn82UGVZ CssgIkYAueFPgv4U8JeJNG8TaVqWqNqGn/8ACUGKO4li2P8A27q0GrXm4BA2Ent40iwQVjYht7YY AGfc/A3QX8MaXoek+I9c0fVtK8Tap4v0rxFYSWkt5pd/qNxfzXLRLNBJbyI0eqX1uqzQyYjkDZ81 VkUAzvGfwD0vxZqPjUjx74p0jwr42dR4s8J6WNO+xeI1a2isZfPkntXu4TNZ20NqTa3EOBGHTZIz SMAep/EHwXpXxG8AeOPh7rtxdW+i+KdIvNGu57BlimjhuYXhdoi4ZVcCQlWZWG7GQRxQBx3jb4Me GfHS/FtdWvdUi/4WJ4Qg8F6obOWJFtrNP7S/eW+5G2z41a5JZ9ynbEAvDbgDj/iN+z1ZfEKP4iWt n8UvGnhDQfH0Tp4l0jw8ukmHVWe0isXnZ72xnnhlazgtoD5Ekar5SMFEhkdgDodb+Bvh7VLzxJre m+JNf0XxVqPieLxbb65pclq02iaiukQaMxt47iCWBkaxidGW4imx9okddrCIxgHfeCfC134V0qez vvGWv+KNRu52u59Z8QTxNPOxVVQLFBFFbwosccaiOCKJSQ0jK0ssruAefa78FY9S8U+ItZ0b4m+M /DGk+JJ4rzX9B8NzWNvBq06QRWpla5lt5L21Z7W1toN1ncW5UW+9CkrNIwBS8afs/aJ4x1Pxq7+N /FOkeF/G/wDyNfhLTDp7WfiQtax2UvnSTWst3D5llDDbsLS5gwke5NkrPIwBu638GPCviLw38ePD GoXmqJYfFcXH9sywyxrJatLpNtpLi0LR4XEFnGwMgbLux5UhQAS698GfDOu+Gvjz4Wvb/VEs/iyZ xrUkEsSSWom0m20pjakowTFvaRsPMD/vNx5UqoAMvWvgrDq3ibxH4g0f4k+MvC9h4oniu9f0Pw/N YwQ61KkEVt5jXMtq97aubW2toS1pcW5j8sPGUmLSsASa58E49R8SeJdd0P4l+NPCuneJp0u/EOg+ Hbiwgg1i4W3htWla4ktZLy1dra3toS9ncwFREsiFJS0rAHWXPw/spfiNB8StP1rVdO1R9Pi0zVLG 1S3ktNctYDcPaJcLLC7oLeW9upUNvJCzNKRKZFVVUA8/8G/ADR/CepeDJG8b+KNX8KeCWYeE/CWr /wBnCy8NYtZbGIQywW0d1Nss7ieBftc85ZZw8geVVkUA9T+HHgvTfhz4D8EfD7RLi6m0Xwto9nol pLeyJJO8FrEkKGZkVVMhVFLFVC7t2AAcUAd3QAUAFACEAjmgCIxRsu1kBU8EY4IxjkfSgBwRd24j JzkE84+npQAwRqvAyDnPU/5/x59TQA7y48Y2jb6dvyoAPLQFm28nBOO5HegAMUbAqV+UjBHqPQ0A HloT90dQeO+On5UACxRrtCoBtGBx0+lACrGqjaucfU0ANEUYG0Rrt2hcY7DoPpz0oAfsXduwM+v+ fqfzoAaI1VdoyM+5/nQAvlxgBQowOgHbvQApRfp9DigCMRRqFUINqjAGOg64HtwOPagBfKjznYM5 z+Pr9ffrQACNB69MDk8f5z1oAXy485289z69Bz69B+VADti+np+lADTFGwKlflIwR6j0NAClV54A zwSOD7UAIsMarsVFCf3QOPyoAPLQFm28nBOO5HegBwRQeF/z/kmgCMQxjadvI4yeT2zz74GfWgB4 jQLtVcL7cYoAFjVcbVxjgew9Pp7UASUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFA BQAUAFABQAUAFABQAUAFABQAUAFAH//ZCmVuZHN0cmVhbQplbmRvYmoKMTQgMCBvYmoKPDwvUjcK NyAwIFI+PgplbmRvYmoKMTggMCBvYmoKPDwvUjcKNyAwIFI+PgplbmRvYmoKMTkgMCBvYmoKPDwv VHlwZS9NZXRhZGF0YQovU3VidHlwZS9YTUwvTGVuZ3RoIDE0MzM+PnN0cmVhbQo8P3hwYWNrZXQg YmVnaW49J++7vycgaWQ9J1c1TTBNcENlaGlIenJlU3pOVGN6a2M5ZCc/Pgo8P2Fkb2JlLXhhcC1m aWx0ZXJzIGVzYz0iQ1JMRiI/Pgo8eDp4bXBtZXRhIHhtbG5zOng9J2Fkb2JlOm5zOm1ldGEvJyB4 OnhtcHRrPSdYTVAgdG9vbGtpdCAyLjkuMS0xMywgZnJhbWV3b3JrIDEuNic+CjxyZGY6UkRGIHht bG5zOnJkZj0naHR0cDovL3d3dy53My5vcmcvMTk5OS8wMi8yMi1yZGYtc3ludGF4LW5zIycgeG1s bnM6aVg9J2h0dHA6Ly9ucy5hZG9iZS5jb20vaVgvMS4wLyc+CjxyZGY6RGVzY3JpcHRpb24gcmRm OmFib3V0PSdjYWVmZGExYS02NmQ2LTExZTctMDAwMC0wMGIzZDY4MzNiYTYnIHhtbG5zOnBkZj0n aHR0cDovL25zLmFkb2JlLmNvbS9wZGYvMS4zLycgcGRmOlByb2R1Y2VyPSdHUEwgR2hvc3RzY3Jp cHQgOC43MScvPgo8cmRmOkRlc2NyaXB0aW9uIHJkZjphYm91dD0nY2FlZmRhMWEtNjZkNi0xMWU3 LTAwMDAtMDBiM2Q2ODMzYmE2JyB4bWxuczp4bXA9J2h0dHA6Ly9ucy5hZG9iZS5jb20veGFwLzEu MC8nPjx4bXA6TW9kaWZ5RGF0ZT4yMDE3LTA3LTA5VDAwOjUwOjM2LTA3OjAwPC94bXA6TW9kaWZ5 RGF0ZT4KPHhtcDpDcmVhdGVEYXRlPjIwMTctMDctMDlUMDA6NTA6MzYtMDc6MDA8L3htcDpDcmVh dGVEYXRlPgo8eG1wOkNyZWF0b3JUb29sPlBTY3JpcHQ1LmRsbCBWZXJzaW9uIDUuMi4yPC94bXA6 Q3JlYXRvclRvb2w+PC9yZGY6RGVzY3JpcHRpb24+CjxyZGY6RGVzY3JpcHRpb24gcmRmOmFib3V0 PSdjYWVmZGExYS02NmQ2LTExZTctMDAwMC0wMGIzZDY4MzNiYTYnIHhtbG5zOnhhcE1NPSdodHRw Oi8vbnMuYWRvYmUuY29tL3hhcC8xLjAvbW0vJyB4YXBNTTpEb2N1bWVudElEPSdjYWVmZGExYS02 NmQ2LTExZTctMDAwMC0wMGIzZDY4MzNiYTYnLz4KPHJkZjpEZXNjcmlwdGlvbiByZGY6YWJvdXQ9 J2NhZWZkYTFhLTY2ZDYtMTFlNy0wMDAwLTAwYjNkNjgzM2JhNicgeG1sbnM6ZGM9J2h0dHA6Ly9w dXJsLm9yZy9kYy9lbGVtZW50cy8xLjEvJyBkYzpmb3JtYXQ9J2FwcGxpY2F0aW9uL3BkZic+PGRj OnRpdGxlPjxyZGY6QWx0PjxyZGY6bGkgeG1sOmxhbmc9J3gtZGVmYXVsdCc+RGlwVHJhY2UgU2No ZW1hdGljIC0gSVZPIFByb3AgQ3VycmVudCBMaW1pdGVyLmRjaDwvcmRmOmxpPjwvcmRmOkFsdD48 L2RjOnRpdGxlPjxkYzpjcmVhdG9yPjxyZGY6U2VxPjxyZGY6bGk+RXJpYzwvcmRmOmxpPjwvcmRm OlNlcT48L2RjOmNyZWF0b3I+PC9yZGY6RGVzY3JpcHRpb24+CjwvcmRmOlJERj4KPC94OnhtcG1l dGE+CiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKPD94cGFja2V0IGVuZD0ndyc/Pgpl bmRzdHJlYW0KZW5kb2JqCjIgMCBvYmoKPDwvUHJvZHVjZXIoR1BMIEdob3N0c2NyaXB0IDguNzEp Ci9DcmVhdGlvbkRhdGUoRDoyMDE3MDcwOTAwNTAzNi0wNycwMCcpCi9Nb2REYXRlKEQ6MjAxNzA3 MDkwMDUwMzYtMDcnMDAnKQovVGl0bGUoRGlwVHJhY2UgU2NoZW1hdGljIC0gSVZPIFByb3AgQ3Vy cmVudCBMaW1pdGVyLmRjaCkKL0NyZWF0b3IoUFNjcmlwdDUuZGxsIFZlcnNpb24gNS4yLjIpCi9B dXRob3IoRXJpYyk+PmVuZG9iagp4cmVmCjAgMjAKMDAwMDAwMDAwMCA2NTUzNSBmIAowMDAwMTA0 MjI4IDAwMDAwIG4gCjAwMDAxMjM4NzcgMDAwMDAgbiAKMDAwMDEwNDE1NSAwMDAwMCBuIAowMDAw MTAzNzAyIDAwMDAwIG4gCjAwMDAwMDAwMTUgMDAwMDAgbiAKMDAwMDA0MDEzMyAwMDAwMCBuIAow MDAwMTA0MjkzIDAwMDAwIG4gCjAwMDAxMDQzOTMgMDAwMDAgbiAKMDAwMDEwNDMzNCAwMDAwMCBu IAowMDAwMTA0MzYzIDAwMDAwIG4gCjAwMDAxMDM4NjcgMDAwMDAgbiAKMDAwMDA0MDE1NCAwMDAw MCBuIAowMDAwMDY1NzIyIDAwMDAwIG4gCjAwMDAxMjIzMDcgMDAwMDAgbiAKMDAwMDEwNDAxMSAw MDAwMCBuIAowMDAwMDY1NzQ0IDAwMDAwIG4gCjAwMDAxMDM2ODAgMDAwMDAgbiAKMDAwMDEyMjMz NyAwMDAwMCBuIAowMDAwMTIyMzY3IDAwMDAwIG4gCnRyYWlsZXIKPDwgL1NpemUgMjAgL1Jvb3Qg MSAwIFIgL0luZm8gMiAwIFIKL0lEIFs8NTRGMDU3QzlCNzdBRDZDNEYwQjg0N0M3MzU1NUQ0Q0Q+ PDU0RjA1N0M5Qjc3QUQ2QzRGMEI4NDdDNzM1NTVENENEPl0KPj4Kc3RhcnR4cmVmCjEyNDEwOQol JUVPRgo ________________________________________________________________________________
Subject: Re: IVO Prop current limiter
Date: Jul 09, 2017
The DPDT switch is mounted in the panel (in my case), along with the red and green LEDs. For the Arduino setup, I have the relay and the current sensing module in a box behind the panel, and the arduino placed nearby. On my Arduino layout drawing, the right side is from one of Bob's original drawings. He included the 10 Amp circuit breaker there, since that is what is delivered with the IVOProp. For wiring, I used 16 AWG for any wires handling prop motor current; that is the size delivered with the prop. My name is Doug Garland, but true credit goes to Dennis Glaeser for starting this discussion years ago, and, of course, Bob. -------- Doug Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470815#470815 ________________________________________________________________________________
Date: Jul 09, 2017
Nicely drawn Eric! Your message asks a lot of questions that I'm not qualified to answer. However, I can answer the question about the PIC pins you chose - they should work fine. I'll write the code based on the brief description Bob gave in his note. I'm assuming that a LIMIT SENSE of greater than 0.5 volts for more than 0.5 seconds is the trigger we want. I'll put those values in EEPROM fields on the chip so they are relatively easy to change if we want. At some point we'll need someone with an IVO prop to actually test this and give us real world feedback. This is fun! Paul On 7/9/2017 3:05 AM, Eric Page wrote: > I've converted Bob's sketches to a CAD file. Anyone with interest in > the project please look over my work (see attached PDF) and post any > changes/critiques for the group to consider. When we're all happy, > I'll turn it into a printed circuit board, stuff it with parts and a > DIP-8 socket, and send it to Paul so he can add a programmed PIC to > test with his code. > > A couple of notes: > - I've assumed that the DPDT motor-control relay will be mounted > elsewhere (off the PCB). > - I've drawn a notional wiring diagram including a switch and a second > relay. If this isn't how the IVO prop works, let me know what to change. > - I guessed at the correct PIC GPIO pins to use. Paul, let me know if > you need something different. > > Things to consider: > - For BOM simplicity, I used the same 2k resistors for R1-R8, and > 0.1uF for C2 and C3. Any problems with this? > - Any other component substitutions or value changes? > - What's the desired physical envelope (PCB with mounting holes / PCB > for a small potting box / something else...)? > - What type of connector(s) should be used (a DB-9 is shown)? > - Are the fuse values on the wiring diagram appropriate? > - What AWG should be specified for each wire run? > > Doug (kfav8r), in order to give you credit on the schematic, would you > like to send me your last name? > > Cheers, > > Eric > > ________________________________________________________________________________
Date: Jul 09, 2017
At 08:59 AM 7/8/2017, you wrote: >The software that Bob describes would be pretty simple to write for >the PIC12F683 chip, the same chip we used for the wig-wag open >source project. I'll volunteer to contribute the software if >someone wants to pursue Bob's hardware design using a PIC chip >instead of the Arduino as an open source project. I'm up to my eyeballs in a couple of development efforts along with juggling domestic duties . . . but if someone wants to brassboard this project, I'll volunteer to package it into a readily duplicated product. I've posted a proposed schematic of the controller at http://tinyurl.com/ybbtw6dp A minimalist approach to packaging would look something like this. The fat power transistor would be on the bottom, heat transfer surface down. This would facilitate using airframe for heat-sinking like our schottky e-bus diode did. The connector would be 15 pin. The ECB footprint would be about 1.25 x 1.75 inches. The 'kit' would look something like this except that the 700-2-7 switch is missing. Emacs! Oh yeah, had a gray-matter fart while crafting the schematic. The software can get MUCH simpler. On power up, the initialization CLEARS the LIMIT LATCH and removes gate drive from the clamping fet. The analog input is monitored for amplitude greater than 0.5 volts; greater than 0.5 seconds whereupon the LIMIT LATCH is SET, gate of clamp fet goes high and removed drive from the current limit fet. An excursion below 0.5v will reset the LIMIT TIMER. After limit time out, the condition is sustained until next power-down/power-up event. I need to keep my head down on some more pressing tasks for the next 10 days or so. You guys can shepherd this along in the mean time. Bob . . . ________________________________________________________________________________
Date: Jul 09, 2017
At 09:58 AM 7/9/2017, you wrote: >Nicely drawn Eric!=C2 > >Your message asks a lot of questions that I'm >not qualified to answer.=C2 However, I can answer >the question about the PIC pins you chose - they >should work fine.=C2 I'll write the code based on >the brief description Bob gave in his >note.=C2 I'm assuming that a LIMIT SENSE of >greater than 0.5 volts for more than 0.5 seconds >is the trigger we want.=C2 I'll put those values >in EEPROM fields on the chip so they are relatively easy to change if we want. > >At some point we'll need someone with an IVO >prop to actually test this and give us real world feedback. Yes, brass-boarding is the acid test. You guys had pushed this cart further down the road than I thought since I sat down at the keyboard last night. Both .pdf and .dwg files of my work product are at http://tinyurl.com/yby3waw6 for use as the chefs of this design stew see fit. I'll be standing by . . . Bob . . . ________________________________________________________________________________
Date: Jul 09, 2017
At 12:45 PM 7/8/2017, you wrote: >Sorry - defective iPhones and all that. > >Possible simplifications to consider: > >- If you=99re using a PIC maybe you could >dispense with the current limiter. If you sense >the current the PIC can send the FET high impedance within a few microseconds. The motor's current profile is rather trashy. Without active current limiting, you'll have motor inrush currents during spin-up. As I recall the mechanical details of this product, the prop-pitch mechanism has soft stops that will compress as the mechanism approaches limits causing the motor current to ramp up toward stall current. The original design goal was to tolerate a deliberate opening of the prop pitch circuit breaker . . . which is a rather slow device . . . on the order of hundreds of milliseconds. All this electron/silicon herding does is get us a more predictable, solid state replacment for the thermal breaker. The current limiter adds one transistor and one resistor and offers a predictable upper bound on stall current. Bob . . . ________________________________________________________________________________
Subject: Fat wires
Date: Jul 10, 2017
Hi all, Some buddies asked me to install the wiring in their brand new project. The engine is a Rotax with short connexions so the fattest wires in the ship will be AWG 6. Due to restricted space, they installed their fuseblock on a hinge within inches from the battery contactor, but the gauge 6 wire from the contactor to the bus proves very stiff and hard to manage with this pivoting installation. I considered using a short length of welder cable, but the insulation is so thick that it did not help much. What would be your opinion about downsizing this particular wire to AWG 8 or 10 for more flexibility ? Thanks in advance, -- Best regards, Gilles http://contrails.free.fr http://lapierre.skunkworks.free.fr ________________________________________________________________________________
Date: Jul 09, 2017
Subject: Re: Fat wires
what about using a short stub of 8 gauge with a good splice to 6 gauge? On Jul 9, 2017, at 18:54, GTH wrote: Hi all, Some buddies asked me to install the wiring in their brand new project. The engine is a Rotax with short connexions so the fattest wires in the ship will be AWG 6. Due to restricted space, they installed their fuseblock on a hinge within inches from the battery contactor, but the gauge 6 wire from the contactor to the bus proves very stiff and hard to manage with this pivoting installation. I considered using a short length of welder cable, but the insulation is so thick that it did not help much. What would be your opinion about downsizing this particular wire to AWG 8 or 10 for more flexibility ? Thanks in advance, -- Best regards, Gilles http://contrails.free.fr http://lapierre.skunkworks.free.fr ________________________________________________________________________________
Date: Jul 09, 2017
At 05:54 PM 7/9/2017, you wrote: > >Hi all, > >Some buddies asked me to install the wiring in their brand new project. > >The engine is a Rotax with short connexions so the fattest wires in >the ship will be AWG 6. > >Due to restricted space, they installed their fuseblock on a hinge >within inches from the battery contactor, but the gauge 6 wire from >the contactor to the bus proves very stiff and hard to manage with >this pivoting installation. > >I considered using a short length of welder cable, but the >insulation is so thick that it did not help much. > >What would be your opinion about downsizing this particular wire to >AWG 8 or 10 for more flexibility ? Wires need to be sized for the expected service. Fat wires in the starter circuit will, no doubt, want to be 6AWG. Given that the bus loads on this aircraft cannot exceed the system loads. The bus feeder can be downsized. What size alternator is installed? Bus loads generally don't exceed alternator output . . . 12AWG would be fine for up to 30A of engine driven power source. I would use a fusible link on such smaller bus feeders . . . a 6" piece of 16AWG under some firesleeve would be about right for 12AWG bus feeder. Bob . . . ________________________________________________________________________________
Date: Jul 09, 2017
Maybe a couple of extra coils in the wire would solve the flexibility problem. Raymond Julian Kettle River, MN The things we admire in men, kindness and generosity, openness, honesty, understanding and feeling are the concomitants of failure in our system. And those traits we detest, sharpness, greed, acquisitiveness, meanness, egotism and self-interest are the traits of success. And while men admire the quality of the first they love the produce of the second. -John Steinbeck, novelist, Nobel laureate (1902-1968) On 07/09/2017 05:54 PM, GTH wrote: > > Hi all, > > Some buddies asked me to install the wiring in their brand new project. > > The engine is a Rotax with short connexions so the fattest wires in the > ship will be AWG 6. > > Due to restricted space, they installed their fuseblock on a hinge > within inches from the battery contactor, but the gauge 6 wire from the > contactor to the bus proves very stiff and hard to manage with this > pivoting installation. > > I considered using a short length of welder cable, but the insulation is > so thick that it did not help much. > > What would be your opinion about downsizing this particular wire to AWG > 8 or 10 for more flexibility ? > > Thanks in advance, > ________________________________________________________________________________
Date: Jul 09, 2017
My Rotax 912 powered RV-12, along with 500 others that are flying, all have 12 AWG wires about 4 feet long connecting the Dynamo and battery to the main power bus. The starter is connected with 8 AWG about 2 feet total length. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470832#470832 ________________________________________________________________________________
Date: Jul 09, 2017
On 7/9/2017 5:54 PM, GTH wrote: > > Hi all, > > Some buddies asked me to install the wiring in their brand new project. > > The engine is a Rotax with short connexions so the fattest wires in > the ship will be AWG 6. > > Due to restricted space, they installed their fuseblock on a hinge > within inches from the battery contactor, but the gauge 6 wire from > the contactor to the bus proves very stiff and hard to manage with > this pivoting installation. > > I considered using a short length of welder cable, but the insulation > is so thick that it did not help much. > > What would be your opinion about downsizing this particular wire to > AWG 8 or 10 for more flexibility ? > > Thanks in advance, > You didn't mention the actual load, but if the plane is Rotax powered, I'd guess that it shouldn't be too large. I did a quick google search for a DC current capacity calculator, & found this: http://www.solar-wind.co.uk/cable-sizing-DC-cables.html If you plug in 30 amps, 1% voltage loss, & 0.2 meters length (~8"), It says that 14 AWG is adequate. 70 amps asks for 10 AWG. Remember, with less than a foot of wire, there's very little resistance loss unless the wire is grossly undersized. 6 AWG sounds like major overkill to me, unless they're trying to run the starter current through it. Charlie --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jul 09, 2017
Eric - See Bob's redesign. I was in the process of writing code for your drawing when Bob sent his note. I now have a version of the software written (but not tested!) for both versions of the hardware, so you just need to let me know which one you want to pursue. Paul On 7/9/2017 11:06 AM, Robert L. Nuckolls, III wrote: > At 08:59 AM 7/8/2017, you wrote: > >> The software that Bob describes would be pretty simple to write for >> the PIC12F683 chip, the same chip we used for the wig-wag open source >> project. I'll volunteer to contribute the software if someone wants >> to pursue Bob's hardware design using a PIC chip instead of the >> Arduino as an open source project. > > I'm up to my eyeballs in a couple of development > efforts along with juggling domestic duties . . . > but if someone wants to brassboard this project, > I'll volunteer to package it into a readily > duplicated product. > > I've posted a proposed schematic of the controller > at http://tinyurl.com/ybbtw6dp > > A minimalist approach to packaging would > look something like this. The fat power transistor > would be on the bottom, heat transfer surface down. > This would facilitate using airframe for heat-sinking > like our schottky e-bus diode did. The connector > would be 15 pin. The ECB footprint would be about > 1.25 x 1.75 inches. The 'kit' would look something > like this except that the 700-2-7 switch is > missing. > > > Emacs! > > > Oh yeah, had a gray-matter fart while crafting the > schematic. The software can get MUCH simpler. > > On power up, the initialization CLEARS the LIMIT > LATCH and removes gate drive from the clamping > fet. > > The analog input is monitored for amplitude greater > than 0.5 volts; greater than 0.5 seconds whereupon > the LIMIT LATCH is SET, gate of clamp fet goes > high and removed drive from the current limit fet. > > An excursion below 0.5v will reset the LIMIT > TIMER. > > After limit time out, the condition is sustained > until next power-down/power-up event. > > I need to keep my head down on some more pressing > tasks for the next 10 days or so. You guys can > shepherd this along in the mean time. > > Bob . . . > ________________________________________________________________________________
Date: Jul 09, 2017
paulf(at)hughes.net wrote: > Eric - See Bob's redesign. I was in the process of writing code for your drawing when Bob sent his note. I now have a version of the software written (but not tested!) for both versions of the hardware, so you just need to let me know which one you want to pursue. > > Paul Paul, I was just composing a post to ask Bob a couple of questions in that vein. Stand by while I sort that out and we'll press ahead shortly. One question for you: am I correct in assuming that PIC outputs are push-pull (that is, when low, they actively pull to ground)? Thanks, Eric Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470837#470837 ________________________________________________________________________________
Date: Jul 09, 2017
At 09:06 PM 7/9/2017, you wrote: > > >paulf(at)hughes.net wrote: > > Eric - See Bob's redesign. I was in the process of writing code > for your drawing when Bob sent his note. I now have a version > of the software written (but not tested!) for both versions > of the hardware, so you just need to let me know which one you want to pursue. > > > > Paul > > >Paul, > >I was just composing a post to ask Bob a couple of questions in that >vein. Stand by while I sort that out and we'll press ahead shortly. > >One question for you: am I correct in assuming that PIC outputs are >push-pull (that is, when low, they actively pull to ground)? > The general purpose outputs are active pull-up/pull-down. A bit more robust in the pull down as I recall . . . Yes the output will pull down to less than 0.6 v with a 8.5mA source. Emacs! Input will pull up to within 0.7 of Vdd with a 3.0mA sink Emacs! Bob . . . ________________________________________________________________________________
Date: Jul 09, 2017
Paul, One more question: with respect to GP3/MCLR, should it be left floating, pulled up to Vdd, or have an RC power-on-reset circuit? Eric Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470839#470839 ________________________________________________________________________________
Date: Jul 09, 2017
Bob, I have a few questions/comments about your drawing (http://tinyurl.com/ybbtw6dp (http://tinyurl.com/ybbtw6dp)): A. The big current limit MOSFET is going to be in one of three states: 1. Fully on: The pilot has moved the switch, the PIC is powered on, and LIMIT LATCH is released, allowing motor drive voltage to pull up the MOSFET's gate through the 1k resistor. Rds(on) is at minimum value and dissipation is negligible (less than 1/4W). 2. Fully off: The PIC sees >=0.5V for >0.5 sec on LIMIT SENSE. LIMIT LATCH goes high, turning on the 2N7000, which pulls the MOSFET's gate to ground. Dissipation is zero. [0.5V = 7.5A motor current.] 3. Linear region: Motor current has spiked to >9A, causing the sense resistors and 2N3904 to regulate the MOSFET's gate to hold the 9A level. Dissipation is high, but LIMIT LATCH will trip in 0.5 sec max, dropping it to zero. So, it seems to me that unless we worry that the pilot will continue to cycle the switch in the stalled direction with the limit light illuminated, we don't need to be too concerned with heat sinking the MOSFET. Your thoughts? B. You're powering the PIC from the motor drive voltage, but you mentioned in your reply to Alec Myers that this is likely to be a "trashy" rail. Your new schematic only uses this rail to power the PIC and pull up the current limit MOSFET's gate. Could we eliminate the two 1N4001 diodes and the wires linking them to the switch, and instead bring in a constant supply on a single wire from the bus side of the switch? Is there some benefit to turning the PIC on and off with the prop switch? C. Your current sense resistor is shown rated at 2W. I've calculated 2.4W dissipation at 6A motor current, rising to 3.75W at 7.5A and 5.4W at 9A. I used three 0.2R 3W resistors in parallel to get 0.066667 ohms at 9W. D. The 2N7000 that switches the TRAVEL LIMIT light can tolerate Vds=Vdg=60V. What is the 24V Zener diode doing? Cheers, Eric Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470840#470840 ________________________________________________________________________________
Date: Jul 10, 2017
At 10:59 PM 7/9/2017, you wrote: > >Bob, > >I have a few questions/comments about your drawing >(http://tinyurl.com/ybbtw6dp (http://tinyurl.com/ybbtw6dp)): > > >A. The big current limit MOSFET is going to be in one of three states: > >1. Fully on: The pilot has moved the switch, the PIC is powered on, >and LIMIT LATCH is released, allowing motor drive voltage to pull up >the MOSFET's gate through the 1k resistor. Rds(on) is at minimum >value and dissipation is negligible (less than 1/4W). yes >2. Fully off: The PIC sees >=0.5V for >0.5 sec on LIMIT >SENSE. LIMIT LATCH goes high, turning on the 2N7000, which pulls >the MOSFET's gate to ground. Dissipation is zero. [0.5V = 7.5A >motor current.] yes >3. Linear region: Motor current has spiked to >9A, causing the sense >resistors and 2N3904 to regulate the MOSFET's gate to hold the 9A >level. Dissipation is high, but LIMIT LATCH will trip in 0.5 sec >max, dropping it to zero. yes . . . >So, it seems to me that unless we worry that the pilot will continue >to cycle the switch in the stalled direction with the limit light >illuminated, we don't need to be too concerned with heat sinking the >MOSFET. Your thoughts? the fat fet needs some heat sinking but just enough thermal mass to keep the silicon in limits during the trip time-out interval. Generally, a metallic mounting base is enough. There's a cartoon of the board layout below . . . the fet is on the bottom of the board with heat-sink surface facing down to contact mounting surface. This is something to be explored in development . . . see if you can deliberately smoke one! >B. You're powering the PIC from the motor drive voltage, but you >mentioned in your reply to Alec Myers that this is likely to be a >"trashy" rail. Your new schematic only uses this rail to power the >PIC and pull up the current limit MOSFET's gate. Could we eliminate >the two 1N4001 diodes and the wires linking them to the switch, and >instead bring in a constant supply on a single wire from the bus >side of the switch? Is there some benefit to turning the PIC on and >off with the prop switch? The current signal will be trashy but the supply voltage comes from the bus (low impedance source). The precision shunt zener combined with the 10uf Vdd capacitor will offer us a very clean source of power for the pic. >C. Your current sense resistor is shown rated at 2W. I've >calculated 2.4W dissipation at 6A motor current, rising to 3.75W at >7.5A and 5.4W at 9A. I used three 0.2R 3W resistors in parallel to >get 0.066667 ohms at 9W. Good eye, I wired 4 x .24 ohms in parallel as you can see below . . . while marginal for continuous operation at this dissipation level, half-second intervals will be no sweat . . . or should I say no smoke? >D. The 2N7000 that switches the TRAVEL LIMIT light can tolerate >Vds=Vdg=60V. What is the 24V Zener diode doing? Yeah . . . probably not really necessary . . . just a carry-over from my DO-160 qualification days when I was obligated to put some protection on all i/o lines designed to clamp off very low energy, 300v spikes. In practice, that zener can probably be left off. Here's how the board layout shaped up . . . Emacs! Bob . . . ________________________________________________________________________________
Date: Jul 10, 2017
If for any reason the PIC crashes (cosmic rays? It does happen) when the motor reaches its limit the FET will sit in an intermediate impedance state dissipating high power for an indeterminate length of time, possibly long enough to be emit the magic smoke. Without adequate heat sinking for the FET the PIC software should use appropriate watchdog timers and brown-out protection to minimize this risk. This is more of a problem if the PIC is powered from the 12v rail because it will be operational for effectively unlimited time before the timer is called into operation. If the PIC is powered from the motor command voltage this risk is much reduced as the PIC run time begins only when the motor is first powered. The motor supply for sure is going to be trashy but PICs are designed to run in very unclean environments. I agree that clean rails are better than dirty ones but you could clean the motor supply rail with a simple RC network too. > On Jul 10, 2017, at 8:17 AM, Robert L. Nuckolls, III wrote: > >> 3. Linear region: Motor current has spiked to >9A, causing the sense resistors and 2N3904 to regulate the MOSFET's gate to hold the 9A level. Dissipation is high, but LIMIT LATCH will trip in 0.5 sec max, dropping it to zero. > > yes . . . ________________________________________________________________________________
Date: Jul 10, 2017
Just out of curiosity, wouldn't a Polyfuse, similar to what's used in a car's electric window circuit, do what you're after? They're available up to 14 A ratings. http://www.mouser.com/Search/Refine.aspx?Keyword=polyfuse ________________________________________________________________________________
Date: Jul 10, 2017
At 07:36 AM 7/10/2017, you wrote: >If for any reason the PIC crashes (cosmic rays? It does happen) when >the motor reaches its limit the FET will sit in an intermediate >impedance state dissipating high power for an indeterminate length >of time, possibly long enough to be emit the magic smoke. That's true . . . but if we were going to do a reliability study for a PIC chip in a high hazard application, we would find that the chip itself is probably good for 10 to the minus bazzilion failures per operating hour. Given that this chip operates only seconds per flight hour, I think a high degree of confidence is not misguided. >Without adequate heat sinking for the FET the PIC software should >use appropriate watchdog timers and brown-out protection to minimize this risk. . . . but if the chip goes TU . . . what's the probability that built in safeguards are operating? > This is more of a problem if the PIC is powered from the 12v rail > because it will be operational for effectively unlimited time > before the timer is called into operation. If the PIC is powered > from the motor command voltage this risk is much reduced as the PIC > run time begins only when the motor is first powered. Exactly . . . >The motor supply for sure is going to be trashy but PICs are >designed to run in very unclean environments. I agree that clean >rails are better than dirty ones but you could clean the motor >supply rail with a simple RC network too. The power supply configuration depicted has been used on products fully qualified under DO160 stresses for trash. The 5v rail is very precise, rigid and clean. Bob . . . ________________________________________________________________________________
Date: Jul 10, 2017
For this application, if we go with Bob's most recent design, I suggest we leave GP3/MCLR float. Unless we plan to use the MCLR function, I'll disable it in software making GP3 a "normal" input (I put normal in quotes because I can't do a weak pull up on GP3). I've had issues in the past with that pin unless I software disable it. Bob answered your other questions, and way better than I could!! Paul On 7/9/2017 10:33 PM, Eric Page wrote: > > Paul, > > One more question: with respect to GP3/MCLR, should it be left floating, pulled up to Vdd, or have an RC power-on-reset circuit? > > Eric > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=470839#470839 > > ________________________________________________________________________________
Date: Jul 10, 2017
At 08:59 AM 7/10/2017, you wrote: >Just out of curiosity, wouldn't a Polyfuse, similar to what's used >in a car's electric window circuit, do what you're after? They're >available up to 14 A ratings. ><http://www.mouser.com/Search/Refine.aspx?Keyword=polyfuse>http://www.mouser.com/Search/Refine.aspx?Keyword=polyfuse Probably. The advantage here is the limit annunciator light that would be very slow if it didn't illuminate until the pollyfuse warms up and operates. The disadvantage is that assuming you DID hold a command at the limit until the fuse operates, you would not be able to drive out of that limit until the fuse cools off . . . We looked at polyfuses on three separate occasions at Lear and Beech over the years . . . aside from exploiting the benefits of inrush limiting on incandescent lamps (NTC devices), there wasn't enough going for them to encourage a development program. They're designed to install inside some piece of hardware. We would have to enclose and terminate the things to make them an airframe component. To be sure, the price is right! Bob . . . ________________________________________________________________________________
Date: Jul 10, 2017
Maybe I=99m misunderstanding: If I read it right, the design calls for the PIC to run whenever the bus is powered, i.e. during the whole flight. PICs do crash and suffer brownouts: that=99s why they have built-in brownout protection and watchdog timers. If these events only happened every bazillion years, Arizona Microchip wouldn=99t waste the silicon. So when you say seconds per flight: the timer is called for for only seconds per flight, but the PIC is running through a do-nothing loop for the entirety of the rest of the flight. If that loop locks up at any time (and it will do so invisibly) then the timer won=99t operate when called for. Again - if watchdog timers were *not* needed, the facility would not be embedded in the silicon. > On Jul 10, 2017, at 10:22 AM, Robert L. Nuckolls, III wrote: > > At 07:36 AM 7/10/2017, you wrote: >> If for any reason the PIC crashes (cosmic rays? It does happen) when the motor reaches its limit the FET will sit in an intermediate impedance state dissipating high power for an indeterminate length of time, possibly long enough to be emit the magic smoke. > > That's true . . . but if we were going to do > a reliability study for a PIC chip in a > high hazard application, we would find > that the chip itself is probably good for > 10 to the minus bazzilion failures per > operating hour. Given that this chip operates > only seconds per flight hour, I think a > high degree of confidence is not misguided. > >> Without adequate heat sinking for the FET the PIC software should use appropriate watchdog timers and brown-out protection to minimize this risk. > > . . . but if the chip goes TU . . . what's > the probability that built in safeguards are > operating? > >> This is more of a problem if the PIC is powered from the 12v rail because it will be operational for effectively unlimited time before the timer is called into operation. If the PIC is powered from the motor command voltage this risk is much reduced as the PIC run time begins only when the motor is first powered. > > Exactly . . . > >> The motor supply for sure is going to be trashy but PICs are designed to run in very unclean environments. I agree that clean rails are better than dirty ones but you could clean the motor supply rail with a simple RC network too. > > The power supply configuration depicted has > been used on products fully qualified under > DO160 stresses for trash. The 5v rail > is very precise, rigid and clean. > > Bob . . . > ________________________________________________________________________________
Date: Jul 10, 2017
Thanks for all the quick replies. I think I have all the info I need to bang out a second revision to this schematic and wiring diagram. I'll see if I can get it done today. Then if everyone's happy with it, I'll start on a PCB layout. Eric Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470854#470854 ________________________________________________________________________________
Date: Jul 10, 2017
At 10:02 AM 7/10/2017, you wrote: >Maybe I=99m misunderstanding: If I read it >right, the design calls for the PIC to run >whenever the bus is powered, i.e. during the whole flight. No, only while the command switch is calling for change of pitch. >PICs do crash and suffer brownouts: that=99s why >they have built-in brownout protection and >watchdog timers. If these events only happened >every bazillion years, Arizona Microchip wouldn=99t waste the silicon. Brownouts are EXTERNALLY generated events caused by sagging supply voltage. The power supply configuration shown will maintain operable Vdd levels on the PIC to LESS than 10V on the ship's bus . . . which means that the airplane has a lot bigger problems than a malfunctioning prop-pitch controller. >So when you say seconds per flight: the timer is >called for for only seconds per flight, but the >PIC is running through a do-nothing loop for the >entirety of the rest of the flight. Not so. Vdd is generated through a diode OR input that routes MOTOR(+) power to the regulator . . . power that is present only while the switch is calling for prop pitch motion. > If that loop locks up at any time (and it will > do so invisibly) then the timer won=99t operate > when called for. Again - if watchdog timers > were *not* needed, the facility would not be embedded in the silicon. Do the FMEA . . . suppose you were tasked with CREATING a situation that would confuse/damage the PIC, how would you go about it? Can you demonstrate the condition(s) on the bench? Assuming such an experiment is successful, what is the probability of that condition occurring in the aircraft? Bob . . . ________________________________________________________________________________
Date: Jul 10, 2017
At 09:43 AM 7/10/2017, you wrote: > >For this application, if we go with Bob's most recent design, I >suggest we leave GP3/MCLR float. Unless we plan to use the MCLR >function, I'll disable it in software making GP3 a "normal" input (I >put normal in quotes because I can't do a weak pull up on GP3). I've >had issues in the past with that pin unless I software disable it. > >Bob answered your other questions, and way better than I could!! > >Paul I've updated the schematic with pin numbers and chip labels that conform to the ECB layout below. ECB files are posted also . . . See http://tinyurl.com/yby3waw6 Emacs! Bob . . . ________________________________________________________________________________
Date: Jul 10, 2017
Ok, so I'm advocating for a design change that's already part of the design. My bad. On Jul 10, 2017, at 12:11, Robert L. Nuckolls, III wrote: No, only while the command switch is calling for change of pitch. ________________________________________________________________________________
From: "Dennis Glaeser" <glaesers(at)wideopenwest.com>
Date: Jul 10, 2017
kfav8r wrote: > The DPDT switch is mounted in the panel (in my case), along with the red and green LEDs. > For the Arduino setup, I have the relay and the current sensing module in a box behind the panel, and the arduino placed nearby. > On my Arduino layout drawing, the right side is from one of Bob's original drawings. He included the 10 Amp circuit breaker there, since that is what is delivered with the IVOProp. > For wiring, I used 16 AWG for any wires handling prop motor current; that is the size delivered with the prop. > My name is Doug Garland, but true credit goes to Dennis Glaeser for starting this discussion years ago, and, of course, Bob. All I get credit for is asking the question: what would it take to make the IVO 'dummy proof' to save the gear box 8) The rest is all Bob... It took me 2 tries to build a working version of Bob's 'original' design. What a blast, working on something designed just for me (at the time)! Fortunately I didn't have any issues with it working reliably for the couple of years I used it. I moved 'up' to an MT prop, and sold the IVO - hopefully it is still working for the new owner. What you guys are doing now is a testament to the ingenuity you all have, and the amazing technology available today - at even more amazing prices!! I remember when I started doing research in prep for building my RV7A (in 2004!!), and discovered the AeroElectric list (and Vans AirForce). Wow! My plane has been flying for over 9 years now, and I still follow all these forums and continue to expand my education, and stay amazed at all of the talented folks involved who are willing to share their time, effort, and knowledge, with Bob solidly at the head of that line. Dennis Glaeser Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470859#470859 ________________________________________________________________________________
Date: Jul 10, 2017
Subject: Re: AeroElectric-List Digest: 17 Msgs - 07/09/17
I got a gazillion pages of gibberish. J=C3=BCrgen On Mon, Jul 10, 2017 at 1:00 AM, AeroElectric-List Digest Server < aeroelectric-list(at)matronics.com> wrote: > * > > ======================== > Online Versions of Today's List Digest Archive > ======================== > > Today's complete AeroElectric-List Digest can also be found in either of > the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the AeroElectric-List Digest and can be viewed with a generic text > editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style > 82701&View=html&Chapter 17-07-09&Archive=AeroElectric > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style > 82701&View=txt&Chapter 17-07-09&Archive=AeroElectric > > > ======================== ======================= > EMail Version of Today's List Digest Archive > ======================== ======================= > > > ---------------------------------------------------------- > AeroElectric-List Digest Archive > --- > Total Messages Posted Sun 07/09/17: 17 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 01:05 AM - Re: Re: IVO Prop current limiter (Eric Page) > 2. 07:01 AM - Re: IVO Prop current limiter (kfav8r) > 3. 07:59 AM - Re: Re: IVO Prop current limiter (Paul A. Fisher) > 4. 09:07 AM - Re: Re: IVO Prop current limiter (Robert L. Nuckolls, > III) > 5. 09:19 AM - Re: Re: IVO Prop current limiter (Robert L. Nuckolls, > III) > 6. 09:26 AM - Re: Re: IVO Prop current limiter (Robert L. Nuckolls, > III) > 7. 03:55 PM - Fat wires (GTH) > 8. 04:22 PM - Re: Fat wires (Alec Myers) > 9. 04:39 PM - Re: Fat wires (Robert L. Nuckolls, III) > 10. 04:40 PM - Re: Fat wires (rayj) > 11. 04:47 PM - Re: Fat wires (user9253) > 12. 04:50 PM - Re: Fat wires (Charlie England) > 13. 06:43 PM - Re: Re: IVO Prop current limiter (Paul A. Fisher) > 14. 07:07 PM - Re: IVO Prop current limiter (Eric Page) > 15. 08:12 PM - Re: Re: IVO Prop current limiter (Robert L. Nuckolls, > III) > 16. 08:35 PM - Re: IVO Prop current limiter (Eric Page) > 17. 08:59 PM - Re: IVO Prop current limiter (Eric Page) > > > ________________________________ Message 1 > _____________________________________ > > > From: Eric Page <edpav8r(at)yahoo.com> > Subject: Re: AeroElectric-List: Re: IVO Prop current limiter > > I've converted Bob's sketches to a CAD file. =C2-Anyone with interest i n > the project please look over my work (see attached PDF) and post any chan ge > s/critiques for the group to consider. =C2-When we're all happy, I'll t ur > n it into a printed circuit board, stuff it with parts and a DIP-8 socket , > and send it to Paul so he can add a programmed PIC to test with his code. > A couple of notes:- I've assumed that the DPDT motor-control relay will b e > mounted elsewhere (off the PCB).- I've drawn a notional wiring diagram in cl > uding a switch and a second relay. =C2-If this isn't how the IVO prop w or > ks, let me know what to change.- I guessed at the correct PIC GPIO pins t o > use. =C2-Paul, let me know if you need something different. > Things to consider:- For BOM simplicity, I used the same 2k resistors for R > 1-R8, and 0.1uF for C2 and C3. =C2-Any problems with this?- Any other c om > ponent substitutions or value changes? > - What's the desired physical envelope (PCB with mounting holes / PCB for a > small potting box / something else...)?- What type of connector(s) shoul d > be used (a DB-9 is shown)?- Are the fuse values on the wiring diagram app ro > priate?- What AWG should be specified for each wire run? > Doug (kfav8r), in order to give you credit on the schematic, would you li ke > to send me your last name? > > Cheers, > Eric > > > JVBERi0xLjQKJcfsj6IKNSAwIG9iago8PC9MZW5ndGggNiAwIFIvRmlsdGVy > IC9GbGF0ZURlY29k > ZT4+CnN0cmVhbQp4nOy9y65uSY8cNq+nqLEAyXm/zA0Y8Mw6j9Cw1DD+ > A0PSQK/vxYggmbtaAgRP > ugaNgyrE/hbJjGTe7//lz/Ifavuz2D8H//T7j//tP+4///N/+6P+ > af/+63/+w36etZQ/1/r+91// > 7z/+07/74/z53z+B/1NC//H/+JdCv/5YkPl/vv/s4ydT+zh/1lPqn78/vC/ > xPz7R2tf4s+6z8MXw > qVtfxvr++hR/O+6m80lVwwV43vx9Whh9JR4tZcambv/wpO4ymUmZXR+8U+ > aU1D0tbQIrLMiIwz7J > bc8Pt6PY4MuaiA00Piph6fs9LK2dlvB7+OLIF8bvUHua9ufQ8Ms+ > xCsxeEgGIZwn5HMS35oyd4fu > LSVs3tIiLMfGwWXATbrgLJvOn7Fxjd8/2Hk8b+sRz1tPhlFnhl17chIG15qedF2Lm9lM > vFOmt9Tt > M232nWEJg4NkwE265Lwf3N949hnxJDvE0/5S3ganJVv2+16Qul+ > eGtVKxrnzzwFv22/90Fu33j/7 > Hd93Q6OyRN3S/xzTPGgeHsjTliJjHKDP0piO+vGvfZh100BOhpV2gT7biN39SqZQa/ > 61Ldf4/pYV > 4w3LQAgNX8EAGmAFK5O+ApuzPa4r7ABZXBvwb6J9Quure+ > zXT9ZQ2LpHtmZrKbuOyy7nN88Qv3kY > o/PnvIzR+BCYfv51tPxrHa7xMZKVj4F+K9flynTdLwWJzvUwzPfUAD9YcaYeb7 > GOUBiXVeCNVoHo > 11Xc16tcxW/VEWj719Zcoy2g72vz/LFUZ11U6h1+3Fa9+/ > fpLBdqRnwdTfln9av848i+VvlEcp+f > 1ljy4ppLnmUYls/Wqs4L9SS4Cl2XszjNiN2I2I2IXWdJOV/hmxsOO99PgP/gr+ > siWvbrQrnjryqC > lG5Wgs8oBpF840v6jdrF2oYPwg1fpv4gytbHPuAKgV1CbfcwBm5tBuwtBPoK > NcSExuBMBoGYMmBC > 0KEASFIN1GkMEWIQHreM6EJlAxbrdcBMz3nJwx/3hmPuijBvMmEeBz9mcrA+ > GRcKIIY3430jISwI > wVOWCxyUdKgdVP4wdtL3py4PWNDoSMBISm2UMGYRUhAeN0R0muWG2gRwQHGa > DdaoCATdhTPMBmvc > MRM+AiXUEB6NAbL4IaIqfwqveJrQ3K8/2rjmuq82+W3YnIvWt41juRitb7PK9MM98dkpc/ > j7ReVC > XbO5kLptlupFoFmlmnimzJePXdeqWLc5v8bPwyK+PWXIDbriDJsbbRvDejF1fxkjlDiri4 > TR+nwY > xWQEa+byLzaW+zpjfMeDH5lzQxcekk3imrEhDhaoDfSlb6UIdOZFisDunOHhjXRTqs2SXMfJW > Due > KQMvURfek02GPG/itVJm3dTdPW3ukWEpNcFhr+RGGXLePX20Hr+slXjeN/ > Zovb8QOnGwODfZ3Zas > 7wnM0QBlWAapy6JJmwf9G4Z11NfRX2NHirCvrt9bhnZaezXmSY358NiZn63I > BY+dqXOU59HUnxae > FIYnj5epFrrwpGySwy6Jp3rGZ1jJmxgNWeXwYfSfrc6YC3nkG5pYaUbr+ > Q0QWuJdU2av1N2bNgOj > 9ZQMRx7URTrL5i4ZljA4SAbcpAvOsun8FRtp/P7Bzr58WQ01xm/ncR6uHJ/ > od/Eb/rt7aZf00i6P > l+7jpft46T5euukl17WQd0kv7ZpeYlNOXTbgtLlbesmxcXAZcKvpJbfp/ > NNLpvH7Bzt8WawBIp7z > 0R+PXY5KKcNRKa32nvw4QrUhZeDdUgbx7E/8ZZP4kRk3dTlitiErOglh33FJGXCQ7 > pxpk/iREQfo > iltyDq+cJ/XPSE/s++CZXnny8OYIm6EpDyMELwstZRBj6cIT > skn8yJyWumelV85O+45LyoCDdOEJ > 2SSeKSMO0F37L5zdK6fe8ArnUeiJU1vikiX4lBFeOeXJyyofCMHLSksZi7Hr > mifcJvBTbtj3km69 > 4ZXTMi8GLikzd+qaJ9wmcHlkSuYz55acwyuzp1e8PsXAbz04S9DpO73SR4bWW7Lumd4ugxhLF 5 > 54 > SpB1OkPmKUFn9vTKU4LOU4JcBhyeEuQ2idvDM/OZc0vOv5zRVr1isb9Zr8SckzVK83LO > jrhmnr1K > tYnBrfhheDvDd4EfGfOv61pobhP4qYmvzw8qZLUU263ii9m6PfndFjXzPcrB > NoRXe0JcU2YrPqa7 > FQezuWvGR9jykcsgDvvhfZ74nEdGHKArbs45OAhbve8ylkdcFzH29hA4S9fd > I/IRualtXKVM99cq > tTu7VVrkyFV6yd81Tq5W5fSBOaUPV8PQ2Ot8GD25al3AD8/ > EnGekDOss6tJ3tMn6a3/0+1iU/8wF > /oIMma/v7rrWMXSb5xsYeFjE6htARtygK86weYf8YhqzI7eA9VTbgt9rxmyWDI34l38 > Z8Au/qOwB > q29lPOaqwWNi7oo8JvrNjPP0+JfE5iOX2TV1zaduExwYVvBRqn0aqx/ > G7RjO1FlMZ2KWQsrUE6Fx > jogsAkNmBVOX/xqrzw4ZHZPvwjvDtVgutuPW5Qc394owvCV5eFE8iVVbQKY+ > unU86bFYgxGrXoT2 > i7fqvP0VInz57Xj1x9YuO9LWcHjsZC6J/id8Zn0W9zenWWSpj8Rth7852yPdmqk > eGDJZSlze/M1Z > Gvp7u493hmv+5qwP/a3+FHzmfSvzpeQZy545WDwp0x7del4f7R > X+3jP98gNr4ow+3mx5iZfWdSxT > odx/X9ZsUQcQa26bUpNrBPgyS9EX/NWRkpRirPg7PcXfMUrU7xox6st87M7 > yftk9v3idyi+rZohn > Pl+sBLiOSgOx5mv01039xV4ef/d8uIaVMvkF+Ecou44IZXs54BfMBAk3+X+ > 1YT5nbJqlK2sRK05f > upzwkvrqxFzpogxrOOqOQjwiD1lx7Zz/qFakA4+eMmOn7ixpE3EY6QPnABlxg644w+ > Z6U8PmKsIb > +4c3buas6Aeu3lMHOL7cGrnRikG0SMCRG01KuRFfIjfyL+ > VGSKlM4nflRvzO3MjfIzfiy3zsRm7E > F+ZGfonceGvmRuDIJ9fy1pz80j0HUmrJ38RME8h0cVxZl5fyYMiw3Sgz6/ > iysl6vJj+EI+dXmzjr > nKGvNgUObvBBe/BMeYuneAqXlOmPbn/9t056f6kNhfaLPSV3Ofzy2/ > F5Pb7bCI8bdo9xtlK/R010 > UX5u+HuzdaYGRxrEyvf3KRvQdV+WB/coS/C31/FlZb1eUU5a+Fvhwt8qP/ > A3Z+jos8Az5RGbmflS > PCnTH90+Xx+xz028H+0X3/742764v7fWsNpZ98/ZsabdzpfBgP/ > hv3OmjL+jFtDvSzN/+DKw9tds > kDMH5w3PlyU/jNlL9MgH5xbRC++Y1G8YtTi2UZLLrJG6NiJzmxby4Fyk8 > E6ZVlIXOUY224ywuGpK > DoFryoCzdBEX2WQc94PLG/vJ2IPR/PGlp1fHau+XM9Jjp2To+ > 2El34Mt54EZC2HETjKI9X68cR4v > nZH41pS5I3XvSZtP6swn1QLXlAFn6SIusok4KiyPL2P/OWjOijUT4kZtG6lyLKDQumLfDTP9b d > nG > cX9kLGTXtdDcJjDmXBh74mDRRqQbrXrqzNPyy3n07wzvrZL5bZVMEa790nur > ZH4LXFPGvOe6faRN > cLhZ8sjBea96wnvLPWaW+snQRgnvcR2W3nPcHxmE3NNj6/Eke/ > 2M/VIv1EPOXE+r7r2F3qa+aF+B > vqz0uNav+Pt99bWyQ+yevX/Bmn0gF/viHtnatyT9O9LWzvqLOPRRLwqf+ > eifMoPxKT++jIz/GZlu > nC/T7/XNVWcnF85/SerF+y0n9sV5+XxQrzfq6/51ory+1u+oD/ > Q76mj9rvqaX1hff3h63frhqK97 > tZkM1sUf3l5H93pW4ltT5o7UvSdt3qivHe+UaSV1UefKZpsRFutocgjcUmad1EVcZ > HP1DGs99bX+ > moz9feprfenpVa+v9Rfqa4VySoa+H1byPdjunrEQvjVl7khdeOM8Xjoj8a > 0pc0fq3pM2n9SZT6oF > bimzTuoiLrK5eoa1nvr6sxr1tXCj9r5e5yq0rthHff3hkng9Mhay666eNlfU > 14y919ce8oh08/pa > Oqfll/Po3xneY91K762SKcK6mN5jHc34BG4ps07qrpk2V8+ > w1lNfkzfra2H32PU6V6GNEt5jbUrv > OV6PDELu6bH1eJJ1NGPv9bWHnLne62vpoL7WF9XX+rLS46yv9ft99VlfC7tn719wmw8X1tf > Cqq/p > aZvu+C1Pc/sJ48sVa4Vx7oNbyjjD42s2srkzl7LeZ2o7xl4EL6Mjde9Jm4jDk7OcA2TEDb > riDJt3 > P17imhCZcgMMmR7ld67NlGB6ygmmjm9NmTtS9560ea+v3wi3lTLtpm7PMsDVCYXlZXc/ > uKUMOPcs > A24TcVRYHt9sr2zF3fPIedol7hNAvtjcWfPb8faa+WCFf0WOuV6v2da+ > p8ReecnK0HVPlsTrkTHm > rmuc3Cb4nWy9iIPFPVEebrYptm4xZqTuHZlXuWfVcZbf+ > 7RgXIehlwPHWo3iJnnEWbXlMXnVA2dk > uJaKdyhFL7l5qgc+KY/YiCdxSZn26La3D3H3jRS9Mz32A+/ > 7eO/OJw2Vutz6vtq5X5fBdqiPhdk3 > jOXHtLkNrrKOOQy3xBxHU4Yzn2PZzAPX5m0Rw+dCxr6JMVcuGcyPSxezFrLJGYxHhivS > 1OXOi4G5 > eI60ad9xTxlwkC7m+mUTeD4y4gBd5x+cf3mMb0uvcA2bMea6Oy1xDXtgBUH4j > JRBbKSLWHKNRniF > jHZjQJe7NGlTOzMQluNVU2au1CXn9WDNw4bG7x/sPJ7WIvwWJ+ > 2Q4O9jun6P2Q/a4urdmDavcR8m > T+jcSEh8xNxktKYNXa3PwyZ3Jn54PviRsbRivSym3GEPfHx/ > OUPrK9JN5xMYQjvhS9ac9LFj84zL > WJq4LkLgqg7xyJx6xkzdcdPmUyocg8PIUuS64Cybzj/T7XDt5mEX8dyZP3V6ghqrZ9irJqeVe > cxl > EIeV+fPs9uCZMqek7sn8yfpaYZ3Mny4DbueJ237ivN/8eU7mz+Nz3sPWXM7N/ > HnUxis/6IvlE53K > gMYtM3HNOuDWEXlJK/Cweut6rN660mqraYnzosI3rfasTXRO > glZ99pB/cU4bMb+ql/D7iLDtWANG > oMLL5+q/juU37MJcvXV1gW0u9StWo3H9kNh3oFFqS2MYBkfbcj8aa8t5zSrTfuHYg3Ct > IbN49KET > H9oMfGrKMO2pe0vaZH3HsITBgTLkRl1yps3gr9hI4/cPdh7PXjgva5x6TVu9l0e/cxXv6+ > fYIY2S > UmdGjHquPH1/Dc6JQ4ojWkldX2synw/uFCFWH6zWa4c1yBhYu3falzGHdhYBH > /TZP7wNb+Kb8l+G > Haoxm/nZ8ddVCRk7WMK5kg8fwyXwvjNk9tXvww6SkMOXvcdWn0tMeyNrC4Hro9Yz+ > fDDlKWi2ZEU > x2bJZcCIumTEXUPCyUi1HnU5B0+b3KHEsIjJgTLkRl1xng9uHhtp/ > P7BLuI5N7+YFPsS/N3bRvx1 > Rw1v3J5MdAYKDNl/I3PHFp7LWEyli9DuqA8eKTNu6rKHQp > tcMWJYcyYHypAbdcV5PLg+3rhcl37Y > /VJ+uEveMB7r4bp28ls38s/1VW2Gch8vncdL5/HSebx0Hi+ > dx0vnCfk+XrqPl254aZYSXpqlhJcc > o0ctGXK7j5fu46X7eAkav3+wUzxnacvj+eGaYdSdYbMGIidhcK3hSde1uMFm4ps > yXk5Ml+uNtKky > g7C8DJyQIbcsD24z+D/x5M6Zh53lhq/ymIX5hFKey6bhkWHMlXZXefBKmV1Sl > z0L2tyqS9qDU6bZ > HvOyTvplPv7a0/PtsaNv3etYYGib95STDNfqOd0Op1WesiTuN3xZVRKNR/ > X6x6yOqAMTpwziWbPE > uU1irw+P42DB05H8Mvzk79UeBesB9OFrmvFl8LQwsMZz+ksjFaynsmYfWE9l2zaKrUxyR8/ > Auilb > WZu+TbxSpt3Uxa4B2QQnjWCIT8gc9b9MV60RbKpVQ1hqscDBsXFzmdJTt5SwqTie > B3vP0XY+nIZ2 > lngU/2L66nPVmT3bih7vSU7qCbentwwZ5m/qarwIm8yLw9Z0A/eUAW/ > qgqtsCj8yK9MpuIlzcBC2 > lWWXga9XpofbJC4pw7LK9Jjen4a3uYd8lKf/bnuYjuccY8G+ > AllztAes886QuRqDmq73uM3m9dQ8 > iesjYyv03lsHa89p1jMu90nZ+6TsHW+OvziaJ7wzZ9/1Ysanml338Ex5S/ > Gr8UgbD74pY57k3In4 > rYerZhQgI2/bMWW1y0i1O9WyTDsI3Lh3zjY8Aj9fMFssPOf7Rf1WOxTsvfiv8ohefM9e/ > BzoxbMH > PNuDd8qs7N3bZsuwCU7c3Ut8esqoh76yd0+b6tEjLOYSchDuT68fnKWLuMgm4qiwP > L6M/bC+Nmct > iNvwL9ZvZz05h/Xnp+Jpx7jpfXDqrK+FHxn2wKjb5TuMGCZxSWy8XQYHvKXbS > 9okfmRmppNzc87J > U/imjPnadS0N3CbxSJl+Iz26zuLR2507Tmy5BhgsuuGW7Lh/ > mqw5niM+M2XOSV1PNbN5a3rI8SOD > dDqZi7rnNOj2J2XHk7IjUtZ4DO4qI5aXLIwxMpcPeWngWP+K1HR5S/ > HB8jnnTLxqypgnxxzBb4z7 > 4PT2cG+bTeUES7Xh43tr8sdhG2wzycDPl8NxoGHWmf7lqj85rKfJ/afWlRiX+7Kr+ > eay3/i5wzD7 > dRaLwDtlvooqdHdPm8bpsp9JzBkLymhUA131XWCT+Zxh8cwSOQiPHMmQs3QRF9lEHBWWx5e > xnxjL > IAcQ+15G2sWZympdLGDYxbjhCYM5jnbVl7cDxaVUl/nwcN0Pk5Pt1iicR6zjJrYTCi4zMQp4 > fMeS > gVWC4i2UMZ12suC3W/UURE97JIu2kp1648DyEmTce+jh12Tq3r6JwVQy8+n5gx13UhOPJ3+ > iX/7b > Q1tPCFP5a2SffpUHn5SxlR7XRQhrPfimzJ6pyxqGNjnuY1jC4CAZcJMuOT/ > eWp53XOP3D3bKVbNo > LGq4+n5TWKhYNxVWj918WfuLbzCs7u+V8nbI3nv+6xkF2LqXy2yMCNJLta8H15RpylUYKY > zwWNWZ > 3d6unSBBugmjhurd+om8VaT3cvN3692xRhNGf1Ay6Ll8urH > z/MPbT5/03uqDV8q0R7fXtAmssNrD > oZ3kZr2qoflNfcHZV2lg5CFL6AH47zMt6ezBFwfjfeGLbr1P7bCAX2YZYWmq > htWXinVCfmmPxuiP > 1OL+HH65PXzMu0roP//d/DrvCaz9CZBZ5YSPF9eK4eNVe/ > g48EqZ9ugaU7cJ1jfTwTmYZ5yb+Xhq > l69ig7Hlh7efLqH3eOcJY7a4i6djV76wWXIZMOqZ0tyF7DgZrdFTF+ > 2zbD451THPqGymwQ5dcT4P > nk+aL5xyf9lFPHfJeCqHQoPr3QxbuRWchGFJMu2mLuK2nzjvzN1r39Q9LW2ekWE > J88xMy3juzHey > GfyfeHJPzcPul+ewm3l4XfdNHfmlXN+dTY1dxoNv5M/teXL4WQpa9XMV+ > SWs1qxZdusPztqHa4bS > 7ZlziT219hgRC56c0e8rawHOauh3vxvLll3q4hkGWzipy/sK/LLQAhP7TDb+ > 0tkm63RUrZfask3V > nnabAK2LM4K2rF95S0e1BZnA3/AtZL5+ZOjaPWtu0zjp7BQxV5kow1NO1OWsH2 > zSlwxLp5zAIXBL > GXCWLuIim4ijwvL4MvbDtLkKSuzrQtYxw7EpfDEeR3E2flyzIyeeJxd+ > ZDiOoC7H17TJ0eXtIzF4 > Swa8pQuuskl8U+Y86SRuzjl5Kj16ysDX50kP2SSeKbNLpoevr8Hbh6eJ7Eqlqnknu9ysHs85d p > Mb > ZzDAWvNXxJznpUy9qatUg02lpnko8EmZYTf0KWWNtVZxiH18hNQ8T8qe+ > eb4gxpR+GTO1i14xPJS > t9sBPfVryj+3191ZHjxTBrcMcpRHfufh+nj7uLfNF8oJlmrHVw9s9NcL9x/ > YcZ6uWXJi9pWnnaLT > jPa0dVH1d+f+6l/NgE87XVh4SsTGaYG/kENm9tS1E1duExwUlvN52HEunIx8Hm > 0us7s4ggXeMXbs > 5cTYsRcfC1t4GlPP+eCWMuAkXYS8H048F0sWy0fLCO1en1P > q1dcfoVM1jja76uPCB7WnbxyvR8b8 > VzXOtThUHwtbCD5G/tKhagy+TV7jaDvN6fjr3oWMpWGdNeKgfjNxz3 > R2DtAVN9jsJcMSBgfnb9yU > nuRcMi4+i1KSA+LuM0X9wY8MfCie7k9416/37M3M8JD+h21KkA1sGzaFyE3ZxNHd7NiGgG1tx D > +/ > cGtn642Tn6aP6UhuM22YpnRcUgY3InLrGHFY9S9m1Y5JhUZJS5i0dVxTBpO8 > sgrsVm0YhL9+c+uc > x/WrCF6pgw0RldvWFjG7Gf36NotuM0T6ot9jwOBfjPu+qX///O/ > cyGaJMNo6XhYHesYsH8KYJfjw > ZEkBtjyBGn6gd15Rq49u89WBU6bdG7roz8lms/Pt8XtNeeRp2gHtwCNlUF9JdyXPiItF > U6ExZk/I > 9uWgnJ2Ic9VKEeX0haymWEVuFkZNKJneInYVfezPAxYLtFOfl2piy3Yu02bo > kgVtEo9HZrbU/cG0 > lWTa5Cewuw/T8zDdmQ51r0wr/k7W50lPpXlN+0jzVk4wCjxTpiUH4pMyHhZio9lqhtw > wnyeMfi1z > T+AvB7SZseFMP2PZxn1wTZk+I8atZSyb0gAx8/QoKYPY9IyNbAo/ > MnOmrsYdzIe9Zpnq9c2T+gJ+ > nd4D714yrzXMySkOnoIWh9MyDvtJncerLgN+J/OUbJJRSZn+ > pGYyNRYD54nE9CnDXZaMBeexycIx > LHloM3Q5J/HkkVFThqdhqMsTM7Q52omwhMFBMuAmXXKmzeD/ > xAZjYYWsVWPmMH2hrSdXDeU84F0y > vD0jd/JuEVnd5wlvYgfT0HyD1z2444NfGs9hJ9+5z4MzPN7rId2Z/pgz/ > TSfnOgybYYuWezy4Efm > jNT9UUuukrUk51jcZ+upe3hHrDRY0xH3LImr7/AZz4bI6vDwcN9FZUrgvouWtfqWVdvf > +uP3uh+2 > u6XHKRV298ovXuvAn/rSboygZWtlunAEKJlZIi148plpsUeW > A8etpAxPUGe8ZZN4PTI7y8H+UT/y > dCAxzzHQm4GH78Yl0/OkxHlSiGMvyZSescGoPcOK2NzMHS5j > TKWLGMgmcX1knnaPPD2tDmZspKF9 > QuShL+S3syU7T+qc1TIOnjrbdwvLR2NHHBy3kjLg96SCbBLvR2Zn+5BMsXcVp/ > ipced94qAv4Hef > nHSfONyd6cA1EunejANvemIcHKPr+vTMpEsW+z74kVmZhsn0YzEK5nihMYp6I7Y+ > WdQqDlwiTktD > 8onba2ncv1iSn0ZtUfpG9H4MZy9n1Ky/Rl0qS8Nwd2+MuiJ3B7b9pZKxxW/ > XtRrEbZKDem8rODjv > eiOtRr1RHob3WhDyiZo2MJhmz8Z1GbNs8cbTQxqtRjqMVqP9Hq1Fu+ > 4YHCQDbi1bNrcZ/DM2DXsu > 0U8b0Wsxq2Mko/Gwmw875RLuW37Ttu0orc8XY9Ub80/fxJ5nuko+9x4w/0yTlweAS+ > alXqKFvGHV > 6jTXZmh1JFaPFzKleH04vJ9TsH8ic5JjXkOf3pBu7w+j/ > jBtTwxMtzfvVWCdHDvi4MYxVMtiDbwq > H2K1XkxNXj2vMhLXlOlYt6du72nTNjAgrCxVQyndhDO1xi6RB+IL8hbv+ > JfOfq1N9UqB1UJYGZpq > Ib6KZcwS7deYpbwhYt2Q2O+p0V8rel3AUUf6F6TlXNH3HXOuxGNHe > k/v15tuj3HW4NlcliPHVr5c > xnL2zP672ySej8xqqbv2G4eT9dcq0aqO9fYxBk+m0mtrzKiReH6VNVXgkzIWt+W9ii+ > V18ryv1SH > F9P1EZvpet9/J26PjMVn7ayPuEojPHvKjJm6o6XNfjMsxw9/ > cPO0Mc7ZQxprZd0kDoy72nL4xHFN > mZU8w5+ZBuueTAPdw8T01xdw2iXrCp74ojbXboSb508rv7vfKL9bKWLllzfcsPxG/8/ > k543y67im > DMqvdFF+ZRPld2sOjP62vaO/lQ47RxGDe0r1u/fMm//+aQ/ > Ou6D0YK+e5kjsIgOfF8HOyMIWiZij > QsrQ+9DlLmPaLMj1AztPNQ807E6xwDdlMA8rXczPyuZ6wloPB8iI28w5HtisWnshU > /UWwLS2jI3m > SrB78sfv3ppb9YgvvxV29R4nv+AmBX3RTQqMn3/pzecy6YPK9KU2cyax15zQ0LwFNBryF > qVaTY3G > vEiZQhmEdmd4uV7Gb6zE8JRkVknd9dhcT1iQEYcZ8xzugYZzv8MeUgEODew4 > kKU5Eq+WMizV1N37 > tbp3+DW/WMq0OyMl2z2RYl2xsJR8f29an5Vdlmva9RJP/XYiHr2d4Nh7eoc7+ > 4S1W5R2e2UOAfbR > J+yOmnnHTyMxnfwL9na0TNfRM70HR7WUkXehy9oAaTzkXUtjx5ZOLrNK6q7H5n > rCWjlDQt365vKx > Z8ZBZQ93qR7641TfOzJwWlBzGcKvn/hGzmvJvTHPjvLCHRkD+36X5/ > 7YFzGwT3g1ho1Vd2Hs+JAM > boWTLm6Oq1lvzZPpSOwsVsl8R6vO3PYqeGoteRkayue4J5HjAaSEY/Omy+ > Bk91MWuP/B8U2ZnanI > W+Fk8/QMSxgcTuYS122PzRZhea7kTY0Mme9cuAf8S9NdpK6/ > PU0MczRBGfkeuj358fZ08nY8Z8qs > krrrsbmesCBTsm1IpghhMlcCH8a0z8Q8M5F15D5PDNg2EruXTGalV/ > fcGZs5MzYzy4nLgKl012Nz > PWFBRhxm8PT8dUrWTMdnxRC2fzFOfG+CXLnGLW1Pke6npD2l+cIE6zW+ > 7kAmPAWh8FbW+udHeeVZ > Z+F1H7t3ZL3Gs27COq2HTb2D9z8Pm/Qc3L8JqVHUUvN3tQLHf1cYg/ > sDqVFVO9nv5cy0dJ76fVTs > aUFsB1dJEdvBFUdZmsmjrpoy3gsx3f3D6n54xJduYz61GnYOrrXIX6PVnVjx > g0yJ/PVVsZG/Rr1R > hweeM2WMn+uux+Z6woJMi/wFbunLNqJmA87Y8TwD451fjFWbJ3X2 > k1sxMPJ4d/UZeotxL7U9fiux > 8XIZ49uzvwGbgdsj01bq9ujP6DwAw3IMDj1qp9Btj80WYblvOkdZDNlHCPyy > W37ZTz35mYl6UqeM > aZnnkoXLw+RmynNvPraux+/cv0872E+vOnA89qfCdW84XiVl1sNhPRzgyZu5o > 9+nPRjjRmke4z7l > /OtEZL6Zdb9f+sov3fuEEyPgHaV+ZnuH373UT7V9Lm/afK5Ty8jNBitz8aklYqxjN7uN+ > CfWs0jW > PEiBkNuFCy5serHk/3r1SrPzSYPLBcK8jtDqNA0Qm50/zd9tYMarDIlrSZmq323IhcRpF0NIX q > lp > O+QTX5fpdtZVur1gQMjLe4jLTJmi32tywxBah+EVAxxwajZvO/ > T0lJ2qGmyGGTO+wtZsL39gDHy5 > dZCh8XocsuC1OcIPI17jR10ku2xiGKuwhMFBMruk7orhbfJnbFzj9w92EU9M > /IjTeWzp2n3qH0xv > NTtLpqPrlOIlINQm/uV/8VpYSnGrKH9Xd6pdHFHHlnDhd4P04F > NhxEyZjqH9urHdN39HCtcHr5Dx > jaKtRO7gYJ6X/HGQL9wzB2EK1XXtYIbbJK4h4xz6TG4dnH/ > EhtcDcqKixzbrD5eImW9EtQrQcW8p > 0zNnkYU2LwOPljLavAzdWdLmbBmWMDhIhrmSuuAsm85fsZHG7x/ > sIp6LqQZO+7F166Nvz5vAG8cv > P6AUL0ig9om9Mzx4NCI3HN/YfHn1AaVwCcPSxmPDanb/y1dX2WU+/ > 97mDf99+bPZeyDNHtfEc8nn > z//9//3j/3oqT9sq3jjCbOuz3tg+NLvkvekmX7vcrg1WU3YRdRu8KZYYPQ > zJlJm6vIOUNnkfrg1p > hH9ZyPaFd6PaxvE2WNWQUb8Zgmaumk0AtsGbPtcwW3x3ziYSG0ex/ > jstuTy1wUra69FGGNJej7bL > i62xuvQTNG4y5Kwztaf77HP7ZLUNH/BV12YXh+PpNufq+ > MtxIWPecN3e0qZx8LCcT7KbOD0gRj1T > a3o8LbSZKcTWtNn1Wm3ydT6kUOCaMuOm7thp0zwfv49HvqSdvh/ > 8hIuYSRf8ZdPjojTfGbMMGV/M > Y5v5B/jGl8/ywtoIdZb73ooC7+lFOrCBd1xThrdoU7dkXlrKxxY7x5ZW > LtNb6los1pNWHhZkxAG6 > 4uacg4PjmzKWgq5rKes2iTOV+b4u8yC5/XXrnfnNN6gRs6vJLbHsXnI7JruFtqv > Dp0251VJ4PDIj > t8bZkdaw2XNr38SWPN8mhy+81oFf/KqFwa2dB8MpWzPBHX4ehraPUXtnGJo > ypQynUqnLQR1tcoLL > jpP2ygUFbEd2fEbK3JK6d6VNMFVYwOIAGXGD7nls+vATHm44DkUWTV4yD7czE8sSZHamTuN > kMFhr > khSbbh3fkjLGyHWxnc3Z3QwLMuIAXfULyaJzShsstKwKFh3ZkCw6J4DBwvEt > KWMhuK6F3Fv6rvdH > ZozU5VQBbc5MJ8fgIBlwky44y6bzz7ymTWUIOTZowZZ/MVujZIpoKxnxybzT900enEojPxzdF m > 9h > xEcyiOd+4u+pcDMsk3EOpptMN6aAVWoxjatUKImt1GojGWOjXDtj65mwvASZnl7l9dEZlsf > GMRi1 > LBWuC596at4MCzJecoKnpwirdmp4pU8e/sX4aQkVvOcTh/ > nEk49OSXdlHLTxDHFwfEvK3JW6YDEz > ReYTB+cA3WA6daDP48CNamPhWBknYvgADyc2Vr1+AFD4nMfS4nLOY+ > mXUpcXAQu3EzHleIupzodr > aImPVbKudjwemVFTF4/hyCZwybK6S3/47Zv8dtQT4PHUaPup0bSISPzUaPup0 > bQFDam1V5Yfx7ek > DB4heWq0/dRoHhZknhpt/6jRDjcb2Hw+sGto69jktrb0wPH8jUspKQPd8cPqSM > /kl46tXZnD/Wp6 > /nUxZqTUXZnrri8Z4QDF5QIhsU+u2XnSYQfaf5PZ4AF46A8edNfvVey7/ > y5evjEKuJyb2j7dbGmD > v34L+3VM0h9qnW1b0ojcM3gIY+AKjR+/j6fM4Iu8IikPsZXqOWnUGzX5qOJIXD > 0njbqj7hqV0+n2 > 8lD8jo1ZW/UktixFmxn2j8JVjkm8UgZMHz85B8jsaHvFwb3U6o14Nl8ss1IcX3A1S8t4tj > 4Sq1cC > mRF1/Wgz6ithtQ64IEatA/YJuIZjXEJS0nvt8XC7LbHKEmR21Dfa > gJVhuScdw3s7SkzogukZie8j > 4x4Onp5LevYNtanL4+lfVm790qUq0VLoghXhKJNWEjq3/yD0nj1T/O6sutcy3X//y8Qjji2ih / > mb > OCYM869vBGI9xfiSf+mLdgT9ev76/Vj+lz33hYMVXH60k8feE187N2DYrhbf/ > EDMnihlWGNCV5so > YFObK/DMk3rr27Z+Bs4NGHhuSbp2htht2gt9HhYxOVCG3K > ArzrAZGzCgUTmRDtY8sqbffTOBnZvt > vIRNWFfOSodtMXXYzgK3WoOJNjaCSWvJRKUQsW7MR/CGYxyOoAy8J114VTbBQWEFn4xd42IY > pXxi > HY9mdS7eEbMGsLnpDzIV0T/kUrFNu/U+xGMm3o8M+qIjc4BsErOPAkbdexmLBxhK5KvBBVV > Y4qSN > tO9KfEaGttMznduqYFPlCJ5U+YKHA9+QQYpIFyklm2TKsIjvChlxg644w6Y/ > ZUKmg+MYaI+W+Uo9 > ZVriwuzGcQoudeIxscG6DbnNcXlkcDxEurjsgjaRZvodsZe8HvC7kX6O900Z > eH1l+rlNj4tyTsuY > Zcge58k+CeI5vf7bfAwWX8BqckSFXKWFl5UPwEqGNTp1d6bh5IaCzScmMw1dBtdg7KwP > ZJN4PjLk > QF1nChaL2wygsVRux4xtGrYc0JdSfUre8fQFKlrq6y+W3E8bk4LCsotLEl/ > srSx8wNl64f7y3Svz > 2faeAHzlX/joaAvfatmf2qcn1lVU5HWqOK7otep35Zfy19/ > rw0p9XrA6fswKTHjwnEwOa3pqzGTF > lQ7JjKybTs/6khf5Mic4xgEGyfSauj1tEs9HRq0NDz+8Jfg+ > uZknTYVX5iNeBEhtPnLNuuCebM94 > LRVj4xhHIlSXWf0lXXhbNslBbaTzoR9x6ED1d6+xacHY+aYF/q42yOWj9h/ > lRO3/9bLDw0NHNxf6 > m2ptbD2wtqj9A+9HBn3eFrWH2wTmAXax89EnrZ5oO9W7/eU8+ > GWxr7uSh9ftI7ZIUEa1KnRncd/7 > 9grLJYF5ACP6EqHb0ybxfmTU34DuiZy+2Hu2ONilY+pJW9EdasOtXhg6aLlxEWLrieV5yJT7 > pI+s > Ih2kzdBaTywfQ6Zcbxl8O8bGMYBSPE8G5jGNqGlCtz+M+ > sO0PzFoMV5QLfONBlgzATN3k4XnevTD > Z7I+UfvrAkfh7A0OzSwiNXlRfYblqekYRzlmtM6h29Mm8X5kTktd32a3eTziRqnS > FhBod/cRjkq0 > 8EX3VLPzML2yN1M7esAIG7/H/HNF3xhXzRJX3zhWZ27npS1vcytmxfV > lrjg6TQ32uIjZplGGNRx1 > uaGBVn2zHTQaHvWhRmMNh/P6jXM2VgC+vijjgT6n8Bkpgxlc6V7ZDLweGbbE1G > VrRJus7RiWMGeg > MzauOx+bM8KK2FweSajC8l6NL7TFUQE0dACGmDkfMp3tfuUcdPLT9lvwdmzxcRnOQd+ > Iv9u8T1ic > 8b7pi2CKENjmELNNQBo6xqzwPsl0PzFYT8xWTZmZXtUMdoQVsRmZOi6D2Ej3 > PjbvExZnmmfqet0I > FqOUyM/Dj9AgPv5loq+f+Xl4KqDXmTlAh6Gp25PH8C2FlbO2aXU > qr5ql2c6DS1jl0qZ0xWLt/N28 > xKVQltapkPdj/zSG6x6YT7lwmftwuA8HyCgs6HobTaY7c63mjusz70x2M3OkY1jytMp5Z4bMs > Q7x > eWROlmxeHSebd2VYN2sIlwG383ja82mE5bFZ7BHCX8vLRYnj1GCk49TEPdmt > x9fLe0G0qvJy+7/4 > wrVGfsn6t+QXPNAk3+Dhpp11qY4ZEXsLAY3Ng2jQ4KPPlNrt > PjjzGPe7SLdk6dOBHXjZMZ90ypLl > uvexeZ+wINOz9G0//sYQeCyXmCs9KD+OOb+e9QSvblcMTku8M615EZZis1rGZt6Mz > czazWU4o54l > YD/50MOCzMk87DukyELjBtTu0U8HD30BPx1fpsYTh/PE8zz5mJeLMw5XNfReic9ImVtS9z42 > 7xMW > ZHamZjI1FrdlnrztzZP+BZxa5kk+vSHtp92/vh2Wf530AK/ > HlSV5HCGsJ3briZ2nSkndK5uJHxnl > noOxRnGbg49nIKzA3ESdZcF152NzRlgWG9shVjrrPZvP58W3/js17NDZz9+ > fegZfLJ9Y31FSdoOR > pJB/RqGHhZ8yMwo3iBLfaH8Dz1y7sBgNXsilkE9JvGvKrJXeWCW9NHd6b+ > 70avaaQvc+Nu8TFmTO > St37tIe+YgIWvJKK7GrviVv0e0bNfs+HMz1rzXR2bKG5DFYhst8TNu8TFmT6T > V1fnUEaaha24oD7 > bqmxZ1rKHDnqeep6HIn/7fi8uUHHtRA771HyWvto1z4c7V1gPD > blvs8VBoTNY1/C55HhCgN1b6Zt > L5nmjrkSEuU8dOdjc0ZY7qU+mo8vRvcSMP35KpwrGD37GcLuCx0FI/ > bDmbA1eFgA3vee1sX16unx > 0TMnjvH0u8d47I6fdlf0/8ZYT/8vvljcR/Zbx8j+7OCFvpJRmYPuzbQYPmcF707OWRGPGR > qOsaV7 > RK9yzKdMzD4Sqz8PmadMzKdMRB9xJcYiylMm5lMm3OZ9woLMUyZmlAmTsqPF > nto6uszfW8TZ/urV > R5Nj+WUXYLhO1mU8BkxvOMYh4BpjieG9jdl9b7dwybqMl8rSG+tEb2ask/ > l9ZV8yZCymrnsfm/cJ > 65bkcIKn57I9Mi9tP8jIuOmLcdoj88weJ+MwM3X3emsI7SOgxs3SqbV9hnAyrR2D > 4cl0dN0rm455 > KShlzlN3ah4VNk9NT54nv7nMXKk7H5szwvISx8d8hXP08RP7QSGG0Xd476y3 > HT4aNV/h9PitLXLW > 9XmDkXgev/yf3O9I7jf7zLrkXzItfX9r+p73JNJPjs9IGfPrzb5x2LxPWJDJMdq > ImVSGdmNuZdyb > LePTQxl3Z5t/d/Zunh7WeHpY4+lhjaeHFbr3sXmfsCBzsw2696lP9agY > 6mk9FQANPRUwnge9hMdT > gmapx+tpPQQQX2bMOwFHSseXhacAoubUk1vS3iOxXxkEvpU7K6yN+jCl+DtzYy9// > f3lW0v0liWl > FJs1W49Zs2TPmiV+1hH9Tl3bL90WKaZr9ZFigW0hvWYbGL > r3sXmfsCAzR+pmO2dSmz433OrrGz7j > Q1st29nZ1nylTvSFp/cL+PsND/78/anb8CXCOE+en71Hnp/ > ekzCNnjMl02eyIFOjdM6u1LNHu/13 > 82b3Gs10e/QYw77l2p6tXWDzYM/exXx6MMEBMll7ioN7qa8sFz17bTNmq > Uwme5LzxyzV5PNAwn6p > HeyOU702nd4zsZTwHsvX35oje+jCbnc8duOyPPw1a8zszJh3qoZjNDrH > jRF1YIv5zNFo6F7ZDNwe > mZynnN7vMJu6MAZhOQaHHuOB+cybhc0ZYUVseNyZIft6MO3qC+ > zOk3ZXltmZvb85f3rp7khV7WZk > jG6m6iqZqs+s0lxqEUx3vb1g/OVs//KFB1H5JcbXa+QX475mtF9zrZp4Z32jC1+ > ouzONVsTPv4TV > nEObK9ug+fS95vZy9+lGn6k7NqufkbnVHzQv7Kdd2DmfNrfS > 2OX/xU4je4tt8sC9PUM0eaTPXnSb > vO7+2BvyJEoI/hRAFQQ1Hv+HMUbdGnB5x55LDrhCoJdQs1InY1boF > ATg7SFwt6uJZFukriAe6EfG > 7DrhyRV1QrjJOhTyDGhymd1emZvct2pzQgEfgXAoPEFjhDXI7/oGjdPj/ > F1PclEejS0NIpfR91jk > YIpg1ZLs0PwwhoIrBOANqpmPZAzhoXUnRGVFgXVDDR0UGkO7ziCYTgiYEHQo > AJJUA/WVDkAQEbeM > KEYmNuc198n0OzcI3RY073F4UBggwGfiocaOMYxxDwKC8O0I/ > APllzZGZF9eTcBfNaTi76i3+fvM > wHdkSnagGfgO3/Nme7iLs4Fwl6C5SwLmLqmV4sYYMIIIDtjYZ9sT1Y4Tcy9ltZesJ1coq/ > 00ua+q > 2qSCWspqkwqBP+eGjJV76drSrNsE1mN7dglT9BlklQ8P2uLV5PF1seATBWZ8dj5RYKfYE6+ > UaSV1 > W/N+guOZMrx8n7q8oJ82xxOW4x4y5NYfT+hpXOf/xEbPQiJkPlTF3/n4AH/fj7Y/ > 78uwMTYi5poV > UydwNZychqfIZ2no8W7ih7eeLUV8+Bh3hBXxd7xSBv66yVo2hXfIiAN0h/ > bkiAWfu6KGLvxT3PTF > OA0904349Cc+vIhf+Mqu5aVvmBB2Z1lut8cX2Jrug+09Hccjw9Mjo+DBpyjIj8+ > twTeBV8og3jfz > mGwK35ARB+gGU8aBT06gzHA+R783lavxl9/jeeQrjfCAP7lAD8wsTXNkrPnclLDnZ > JPpmdu5Dlmt > COfvxzBjbY8icy6JnpF9Oyo1eZxRMRWGByQDpipZwCqJkOmZ+ > 6b6DWJ0ntjsJzY788ZcT2zWE5vV > Mjbric16YrOf2OwnNueJzXlis5/Y7EzzuZ7YrCc2q71pzgcameYscfp9Z > pr/+N21rzQizf0hS3xZ > Kg99EKf/1lMe1lNXcNeh4/Qf5wCl27Ku4NVQ9FPglTKtpG5rYVM4 > 6+j11BXBlCxm5mifbxQPfiG/ > mTXnmlm+2a+WzFN/82JsxcHr/vrglTLg9+RQ2RSjljIz64NgivRam7VaFQ6N/ > Vg65cFvbcnHxITP > m2/4yBbzjZ6F0u8n8s3P3+drF+MdhXjfWmTXE57lDCm9tmsNr3HdmF4L > vFLG4ue6FsJ+Un4/rfN+ > cs1W6wybvWVYPXPf9pbghi45t8y5DCtiM7J8bL0AwtZTX2hrZCu+ > nxzEi60ks5RrTHdlrt5Rmq0H > xGuqql2T+XULW3if56+ocX7U2od1M+J3VC9a7XRGlrTz5NijXAqZp54+ > Tyt5muKzHlxTxvKMdMlO > dT/weGTGTN2n3Tiqy8HB6/iZ/C1tnT9iPDJ/n56t5enZazvRYwKLo1rR8JInjMXqkS > L6nYz2E3vv > SV3vB8tDZ6QX1fOs9cErZcDuKZVnP7HZWTc4t3qCGz2hJyvE6Cltx0sbcpK+ > gOt9+iZ6lJy41ojP > ffp/t2bflvjX8yWstuxvch+A8FOWrucj0+0Z0+tPCSMduEdZX1Tn4veV9aMeNOfvWmmv > NumFMYBp > Y94s2qPV88vEqIG2TKOpz0TMeJsMr5umblPfyx4o9dHErg/ > eKXNK6hoLt0l8Q8Y57P0yHZMjC2O6 > Z44yoNHSEmcUhaPfAg+wd0fcX99wh5q8od71enrdFrvOR86EH > xk+Uk7dnR7ral8wo+q4pszYqTtW > 2iR+ZMQBuuLmnJ2DY/hFMvCLdOEL2SReKXNqetsfV4SUHtyG > 50dLS8Ofz+2Yu2ReJ+799eqZkePG > 8ZGGzWj5l/n09qFx+4Nv5DjvsS/MiWZa+6Ou+eV3aGRKTLYDwietaswKXc9NzbHHYmI > dXhr9Rlpz > HpX5gfOozPmBd8qckroIQaNc4kyvOTMtpno0sDmfsBz3lAE36ZLzebCPZS0d > uc+QOYV79hTyfry6 > swTN85YgXmwu/KN2WVj9ERMvQZjXHcn8toyR450y4HEz7FXqg9OT3l/ > d2WeGzVWztAbuKTOzvy3O > 68FvPHlSXiG3qCufLytmlGW3p/eXanDg4V5anbO67qX91LR6PpQaN9N0 > PTXt8jrHZJ6adj01rcvA > S09Nu556wMM6JTns7TPO7gH1QpFPvPcIjZq5eD9lZrdHRj3G/cx5ymrf4de/ > fBknv4zzeNy/wH/q > 68B/8/Hf3Im9P8i/lN9hd/fXrr7A7k6f751lZ5/64P1qX7Gyfof8s8aDa/Y5J6YoM0+ > cpz46ngdN > pmRLcrx2Pz4rytQOvFPGfO66p6VNYIUFGXGArvfSyYKzfdSIlhHx0Rfwe/ > K194KBR5avo/EZdEfm > Fb/PjrUQby1gDvEeHBhqFuA8vTzi8bJdJWohvyi22mIeepK/3dbJPH+ > e9u6ojLg8tC9KDPtXxBxh > 2LL9XHq4FiWMT8/b0r5WgepFiXQ8UwalVrqWH9wmMB+QvPc4/ > uVWLx9r3bEMIhbsK1yMK5kvL8ae > wrelzF2pixDYxgrPlGEbC92tx22xTqTHbc9IvG/KgNt9PCGbzj9js/ > EID0Pm5cr6vd1gxLUV/e5j > RIbNeVviLU4lMeottmLgtHdNS55qPcaLlJk348P2M8KK+ > AvDLzP95br3pE3inTI702PHk9RgwdxJ > jcx5I7/s6/WMuN4nPnc8WKUJeYn3PtLuWZGXbn5hOeuhf+ > Z98IjwzqzhG5Vk8DvKrRyTroify2Cc > K12wcP+dDAsy4gDdYIo4bD7KjbrPH2nG2JBWV/nL79orqTjsmx6IB8L35djNPXBLxvqW > 9ObxnGwe > uJnbz1WJaPn7GT6C/PAyO+kZt2+jdY0ZEdPA65E5yQGs7+Olm7nv+ > GwjYzOe2PQnNj1jc1vGRuNN > 6raMjf9useEOdMWmP7HpT2zGE5vxxKY/sekZG+cAmZaxuc1jY2l4Z4s0v8ox/H1Fmv/ > 8PXwhDU9z > SsUX9FJbsbnku/brP/Zf6RvV2NDYj//247+TrcDVw9bwmcoo/ > OT1bEsZxPtk/eA2iUfKiAN015Oj > v+5o5GjgiEN8+fh9OGrOxbt4hEvUIatk/b2KHg9HHJTjEIdsB0Lm4xe6YFF2YoU > FmbpStz710ip6 > kPwKh0Z/LI364PF6oKsdNDzaa3dOzzeLe+n99+v55i+/z9fu3OnZ+cPn+/GsniuH1/ > RA/ee1VZRi > n9cCI+b78Yh0EUKm/NIj3pTJXLPKrWnzPmHdlhy8JZipC85 > nJM6a7/ur4k4vhlxLtKolv5itmnXi > qk8OqjVzUNVT9NBtkauFf30lDRsuVOqAedmmJfTksxOtYC+H/ > z58xl54lZRZ+v16T6pZxlAP68M7 > 8Wwpg5010sU4SjaBFRb39Oj3kdxmzV6YvmAvnjR4kzMtoYflv8+0pL14lOJ+ > E/qCu0E+3uhvrcD7 > h/d2V3gY8TRI4feZsWDvQ7+vI+2OXvoI7aMT2/Sgf8Guhl7D4we1vuMW3ueOZOnyUl54 > n/c60PuO > Z0sZ84frgoVsEu+UEQfoBlPso+DluUgL9iWkMR9LvLdb+L4eQN9deL6+ > udgDxhhxv3Cz6uTDPWLH > V84dPzK1hjduSY9xdrjZW5CB206Z1lO31bRJfFJGHKArbs45eWYedZm5Utd8 > 4TaJR8qUG96+Gt9L > 6imtdz6W/Dpk5NE7mHuANaPeyh0+Vmq1PuOXZlt6/Uu5KO/0wX3K+ > 33KO2TQJ5Quyy+tam9sfgmr > Kv2wtMeDb1pF6ytd1JGyesYTi11GWNVt+oWb3Ta1h49tWsXGNuHaUwZrZ9RFCBw > vOb4pw3oAupv5 > ATY5u8KwhAvX/lbExusQcr4P9thwRmUwTeqf2qSmkPtKRv0mHv31BW4dEB5vWm/ > cBC4mqoNujJ7E > nLfoM0bCtadMjdGTwl7twSdlMHqS7n5s7pVh7ZUcPP1j9Oecz4PbGxvsR1PI > mtORXX6h3ZN5iRvU > pK0a3PAp4SWMtU546azM61yJEp6Zpl6vcc/ajdhxTMVYO649ZWrWiYiDbBKvmjIr8 > +qJ1gIs0M9h > PuFoSRqnpqWnzJxbUuYqF5vu/WEVM2Ku8X655caXqzs0GFd9KfdmfWm > +8TrsPnUzcHtz7PX8HqOP > sKtWj2tr6XPWbtIe/cHn1Z7kC3xK1CPCBat3+6TVnXmCZz6E1yOzRqT2VSp5WJ7ajmt > PmbpCl/H0 > snIiLMqofEBXM/NigTvrpKETo4oPv5Bf5muNABxPj8PirULQXaVGjSesWmjx3ApyyOK5FTD88 E > mN > Xh88k+2yBum3Y39bwy4Y+sYAyl9ma6zUHyfD8DIy/PdfeblhtXuCsaaGbTnCnDy0vwo3Atm > uu6qu > N7BL0dB//c/+89SM9SLGTGO1G6SFPo7/9Ifj8qckv9hK/0P2/csR/HV8+ > YGSQtAnhlVIIiQP/5/+ > +E//7o9qm7n/RpT++Q9tMLd24H/q1eITG/hLQxLwMUyOVtIc1WBub21R0g5Gy9qH > nDl+BUdIElFf > eIs5Q/Lw/+LMvweldOZXVVZfvbPvvnp3f2Tkv082+LvnzFbpTLxpwHdPiZsvP8UXudylHvd > Dyr7g > SZWKtzgMV7z6UL/G1ZElpvBaf0ry65hI/0P2/RvL6tdv4C1JIOkTm1VIIiQPP13+ > N6L0z5Er58ny > ZJiJbWvNjlpkgW+woCxgd9tIf9XIAvgViQ1JIuoLH2UBhuTh00V/IzqeI2+1GqPjDE6N2tEa+ > Kgo > 8QdbL4iwzD/Sv3AIQfWWjUoB79dao34RMNaEX00EKaucoMkay/pb/K11SQFQk/ > CzZlKw72FG9vtX > ZhEu3d2v+zYn6dbtx3XyF6smcDAIVlaFEKBeESxkavUPNVEpgQN+a11SBMuZwhqkzL6H+ > dNf/3os > 3F+9FtzAaQ7rpQr/g3hU7fnBZcyjzJAC5pdqd7jw1SjrKg > LznTKbjHBkqStsTwZQstv1z9D/kH1v > 1X+196coCSR9YrMKSYTk4Ydn/06Uou05uOiXm06BHzcLy5n9zGAODI5 > 4AMBRMO+ni/lXY4k5kJjr > V7zY2oejEcxlFZKz/Znh/3Tm34RSNuTN7gjBDQXEfE+BV5wT24Xpdi/ > l2Cnlz0HX3XT3iH2pm7ja > U3WfzA6Eqp7YKnhKrq/zQf2Fnp5NoOhXu6eFkkDSJzarkERIH > n423n8jSulmHIKY3R0I/I8fLndn > npHMDZOjbTp2lMxPc+anOXNDzpy/GkdKAvVkTquQHM7c0F+c+ > feg9NOZ9aYzq58bMenZuIvROACD > 17R3Ihw1ZzvtZiRK2j211DcktvoVNzJAEkj6xIdsFZKH/9OBfxNK4UDLnP/ > mwP//DmztTu9KNrv0 > Ux0iYl91vCM7llgB0eiTUhz+vNq/7K/hPZlmzwYANzu6id6HELokjsufkrTX6 > qiP/kzrVmvxVxty > UJKI+sCwCkmE5OGH+/9OlCL/mms1rmy2fqtxJbGPPvOLXO5Sj/ > tD6nC6c2uo1+zWYQzKHFkFJGzP > +VHy65dIHz2UZi/q6dc7XfLO1L/TrUISIXn46fK/EaV/jlzJ4R4T1jAT2wZmjlpkARvESdLeO K > Q+ > hntMWP66lksCSZ/4KAswJA8fLvo70YkKYdT5PyrefzvnZZH+ > e1DKTv0ePtistw8fbRLz1klMOsUN > lKgEMKpyDR9h1Ys7Ehv3RrVNXG3r1LBJbkfokxBbPQ9JW16gviH7bu/ > 68tcxXRJI+sRmtV8PycPP > RuxvRCnyrJ3PVaceT7hGp77hqh72D1or0/sHwOqtQiZ6rtRg/5Ya7N++2r/ > sr+FNeatXTXnjBVFf > o+sIGYf4a6ApaY029dmUN7umVL9WNeVC1Bc+f1ISIUX4WRb+RpSyd7Hk5t8/ > XC4HqjcODsAt7qxz > VJ0t+tiS/Prd0kdvHBz0a1VvXKhXZ0urlLSQIvyfDvybUIqJGLt906dYxo0pFmCfLRjln > S2YuHAX > Gy8o5Zfe6S9seet2ryZwt/NXH6qOhvVvhG2Gg5J4wQj63RK42yks > /jrLliQR9Ykn7ldvHpKHn/MI > fyNKkWdtc8rk6xbET5XxP8D/Vhn8r1YGs6Rj5w8HzoftsI2xsDGC7X > jYjmALSfCaD9sZbKcthkOS > iPrC9ox3sJ3/0oF/I0rhwP7kzD5fB1o/xNla74Y2rMdDu0LRDyIHSIIX9MXWej > f6dTlbohv9IFld > zjbC/9k1+5tQiq6ZreLpgSvioTfe60a9wplY4MttCZ+ZH1g9C76hGL2M9vQ/2o/+ > h72Zoxm81ppm > 8FrDvJqNcoRYzjhbZy1F0wye9BfblFH81zFdcszUH9OtQhIhefhP1fD3oRQJ > M58+sy2JeZ8ZWH3m > MZ9b27FN43+q0eIEJ/7inLAt2gFjIe+TWYG4Oo87yG2qA5L2Aiv1DWl5j7/ > aQh4lgaQvvLi8p5A8 > /J9r4H8TSuH+zqto21+c+W8O/F90YLOLN75WALNoxLpZoluthb9+ > O9ZZV8qtR2eib0ypFy9pcI2N > 1QzxVG+ai0sTXVcuWRnmMpbdDeXIyqQwHlaF5NdJlX7Tekv1X20Zi5JA0ifeWtxiSB7 > +X9bb/h6U > PJmOTRaz/Tw+b/xVGTXxrz/swLJkAPn7eUUOLqlAy2ZXkQAeO5BrL > ZCA5Q7CL99BypISmmzT7Ogp > f/POw8kexfFuBqRg38MMB/8rs4i6o/RwKnHMwGNLvKa7LYU4CY1t5piYFsJ0 > NTF2TbWliW3oa7rb > 7q3WrxjRQ5Jje+oTm9V+PKT+V5/9nSjlFHAfPgOPReDcwWUzSXXwngDg5 > 0tupLKD0tzedJZvpCLi > Rijh8qckbcsU9bmRyrb96ldsXYMkEfWBYXX7RqoIP137N6LkrsUuzf9gO5C/ > pLBdn7a2XG0bq3Hs > xTBqADuVUnXYzYbq3AFLyKtSTEIn+kxRB/rMHl/w/OD9U0f7bKe2w69cuMA3Lne1r/ > PoxlaNIAwq > 4HmTz1zJ03atchuuZYJuW2R45QpjU6/T/vLsdKPCpvGZv7zNwQ6W6jqi84XvJz8 > txs0zmf0+JP1x > 49F+2NBZzy8j83Gier+BS8ATAl/3UWqwzKtIAHVC2AR0PM/ > UeK8XjOlItQVBiIApADpUA8mZ8fAN > ey79+yVkM6pfz+ZyHx9+14lx46GjesZuJ9GTAieJxlFcM3c1GT > rzd+MCv/92XMINwtBW2v527NeR > YWpIhxAtl2FNRJkPKyVIZ6yglMQ8Uk0ZeQq6UxnXbPIQLSacylSuqg9eKWP9 > ete1bXxu03r5Hhaw > OEBG3KArzrDpBxLJAtvNP7yI/8Hc3PiMe7VJMqznRMx41QUwn3SnjI4 > sQpcPFNGmji9aoQyMyTzJ > DJsC4SFWxuBmzKpfkWrp9vUDmxeAyk4dsla9OpiNKWstk37GE5+ > UsS1X0rX0h83Ey2Va0eHwT7cV > XtBhNpsfq7VhrbBxcBnj5rrivB7sOdI1fv9g94uz9K00HngFj/ > ZwbTf5dRXa5r+H3dG8UvnwzNC9 > mE/HKjONO7EUV5V1hLF6aqyHx35k9ko/nR9WT/WimF/ApOIZQrG6j/+zJC/+ > pbLYqq4ba3Y9yOib > S+Tbnl1CTdHsEpYPN2J75IkHMoRrykz9bro8EEWbXFmwm79G5/G4/ > hFIvEPG3p53XQxKZNPmfj0s > 4ZMy5EZdcYbN7Yv0YMqjH8C8KpiMeJGYY2rbM9CDh8762SlvrHntceuYC6kZ > smTAiNcSkymvKxbr > u5P1VWzME1f2v8FX1xPSze4gHh1D/zbwrC8PrAw8XswDWsMmHhq1bVon8U2 > ZNVJ3LdpMPEKGj/1S > t/P4HWx2HnhFWI6Ng8vwMWHqkvN4cPXYSOP3D3b2ZZkHGvIdebSHKw/ > S6neG4fKPXTyR9GFjOJ7Q > x01Luo6n2eteo68STDqPZjKM1VKDx8mI9yPDA3jU3T+s8piZNO6TjkMxByulEaR0dcynv/ > nXb+FR > dLxr81EnHAa1M3rA/3CMPN7sHN/gQ5Nt8+mmRYznnVBW7ManoUN+ > dnN94poyeDRLunOkTXBQWM6H > 7Jat6+AyQWrz8SZKHeYKMD1+DO7aiHUzX2Ob8mapu+X4Y1nNTuEOf/ > hBX/DYn76MRwO9O/2uaTP9 > tTErSymmmb03OXh1lrAuuKXUKdIwz+KCCLHlIVirlQcvpWl2Rjmw5UGXsXzg > ulhxpT+Ed8gclh7o > 8iEs2uQ1VQzLMVbRJGPcXJec94PH4+ODPvPLLuKJaw5li8dmr6/ > aRdgsbeQkDK6SQRz6E7f+xJkH > DSnDw2rUnTVtssZnWMLgIBlwky44jyfO/c1LOkb/sIsva0Qu44FQ6e+ > eXLXvo5fTmTdsCsselGc+ > EcaVC92O3w1endatqR28Oq3bToaxcQixW8dN+arbjv3ELWTKOaFrO/ > 3dJjkwrOBDdtC+A/NMfJBt > UGr7I2mydE9o87iu4wyNV6RRl3mJNnm1QS9Y9XWcMvaaux5qk1duD+ > xXDHdMhrN8fzjKd/+aUi/T > X+39lG99QfnWl/FooEzrd5Vv/YXyLSmU76/liPItrPJNKZZvvO2uMiq2l+ > GhxqNf27yJ10mZ3VN3 > R/l2vENGPoMuyy5tskwzLMdjpswoqdtP2uxP+U6N3z/YRTxRvmWrjwyj1wy73eQkDK6SQRz6E > 7f+ > xHn0lBkndWdNm7NnWMJjpgy4SbeftNmf8p0av3+wiy9rRC5j+Zb+ > 7snVyzeeON+4ELd/PWDifziW > B2zr/lasiz3S3Gm14Gls5nxbTOd1Ad2eGErcUmaf0LU3Xt0mOTCs4POwm0hRYtUyC > GE9eDME2xzA > i+A6n5aWPNht1lz3BmZsKMNY7pqxX+vBNWWmfsez1/IKeHqpGsUfcofnP6zcisfSG3PGdfxL > X5ZS > wb6s+mjcnhqaX5XGYI4G5qJBG6bdWZ98Pab8ffqT6sKjpczg77Y/YnlutcfRZ/ > OcG9hWTl3my1yh > C9Yj4+ZhQUYc1kpuC0+/H/eYPfK+ppfPzks/vphtf669YzWWl/woxrs9+ > KaMPAzdM7xcdV6Q+uHx > 4EfGzpbwih/FYKXf1zmP3/lIlrBqYrPEa/cdr0gPXpZK/7o8HlZvPfzrGI+1t/ > TvVm24YCcZ7ZL+ > 5XWM9C+vIJF/b9QYhaXNc+Tumb/2eKyON3/x2kV9UU4HXjfDVulB2HtF2GrH29wPH > ilj3nZd+EU2 > 4S/9Dj/uTDW3g9gI90fGUt91wf/JLXt6K4HQFLMM+dcfp40/D+ > bj7HARL1I9H332F2xalhet2rQq > +xZEXV85cjANXidiVjhqsCs7/KJHq6sP5iNsqo5tHUJG+pvFo8stEDauTkPYfG3MvuMiC/ > 62nWN/ > rKNWgHWUWVhH6w9t9Z1aw4XhXIK0G9iBbacDn/rhmB9PGnXOVOAZnl4ScxRKGV5CRF2O > PWgTD+Y0 > PFxAbCHb9XqD1zjYG9tzsHdLRnNnCMEVdvEEh8LTbAukdkkeuyaPHeHZxeXc > iM6wealJw1XlHNdZ > Xv7wSR734XRPyEzOE0B3FsZ643GjSbwTn0eGTyM93uMYUg8jMZ5rDE+ > SBb8gReyBEiWIVXNKD3uq > RMlB2HYIIDGohrSgMbh/IZ5KCavHlRDWlCgdyAKup2WlAg0iER > gM0oAicDV/3TUCVwLQIK42BaR7 > Fi93Hw7pHLsRSj5bfB0Tsmu7lxYdTzhDYF9PGhJC+RSswQ1pTW7IAmtHSvz6Y7MQoMDhqSi > Wsxav > XVmHUN63cva58SZcIdBaqMH7NIYmwIq74FdWkWGx9mcVi7xPFuhi0PJUyYbB > haKNYNAqUoSP77XI > 8yHrVQIu0f8t2zeZIOaAngWbXZI0K7aDtI13bjXZcbGCXIhtqyBvvtnY9cYJ > RuGaMuuk7uIECmzy > JhurE4UR8v3Tt2vbRbqzcnoOjLgphSH4BhXabahMGR5f25UU7w7S7yt4tDqe > mDZWQ8QcxFvLMhsH > 99ay5O+2qYy3CBGPmjJDv9t5q6EJHuzYowxW0YVtad1lwE66YD2eeCosyIgDYiBuVqm > 2mPKryKeH > U2WDGBOU17NyGyjvXRN1qM5rYk0qQqaN1G2aVB1RtY9RHVvIdvRuDE7yIa/ > zVioy0lS1v42rab2s > zhneuimlSUX8rkns8VbnozV/4+EL4/irEApPk8k13pKjjKp2cj2arsV7FD1j > 5PikDFicJw738d5N > GVXt0J2a6h3d35Wjfcd9pUxvqdtL2iQeD88Tus4tOds22rWjOZ9Pc75QtbA5 > X09zvp7mfD3N+Xqa > c+oyzefTnM8fzbnt3/PmfD7NORnNnSF4c067TP/1NOfrac7X05yHvLRRaSO/ > zWwYFJ4q84vHSuCO > m03pzab0ZlNqi/RyBWHbIQBH3GxKbzald930ws2m9M7iZYAsEG1algduNqU3m1KK8MnRbErv2 5 > TS > IBZtbGu/WjSGiBbtzp5wp8Chy4x1NI+2tq5GE/fVsylFtOhSu6I4YPRrLtva9NxN8rcG > eQacbS2M > MXnoOcEZAivyuUh2p84Sgggp4BldLkRecKwQoKNOQr9QgZudMICrLdq3bk/ > BY0cPMNo3TkjgrK2m > EYhbymgCFLocptKmpiZweleLAr1aLq4+WWktJeoqMmqlRQhNy7a027Bsy/ > CaphwhVWfwaHUHD/7+ > i1OuX5tTOHVbvM3puBuuDTE0GU3PAGt6BjJdE5mm22Ma92tzKGPlULiwveI0 > 7h2hy7j1k3g8MmOm > rrg55+AgjJdpJYMYj0wR5w/cd8p0peZwbnodrt+ud7m6YSw621tcXfeV9y+l+m3xvlu/ > er3WrukI > fFOm9dRtK2zaE1Rdd6kT+wuGOJqzU9ffbsMpmJZhzZEcHJeQIee > p98N62GQc/U3R5hxsS6/donH1 > klGvbukX3x/rl+9x0K6/3Gn6+4lPvJ4yO4feeIOj+TC82jb+7q+ > nDEwL0DM27bT9pSvDevEJMnrx > Cbr+8o3Z5NYJO/GQ+JHBdImukzs2mPf3iwxff9vEQuMNyPx > y9DYTftdLQPi9+psnp/odJ5JaGQe+ > qBd2+U4HYuFvjRhzPgJdbR21+wt2aybeI2U+B4UuQr4PJ72KBBm9hWW611+ > JsUMKZURYjo2Dy4Db > fWJwn/j7Ox2h8fsHO4/n1YtHA+WhZhh63QZh+2tLMzG4Smbf1LW4eVkivinjb2eZrl6 > YgU29X4iw > hMGhZ267T9q6Tef/xLOfiOf1jVeUWzXjqTe2oDEzPbXpjJ > z8ra6RMojDfOK2njivTE/d+0/d/aSn > 3iFCWDvzlMuAm3TJ+Ymzv3gYGr9/sPulrbqFLx7inmltvcJeVW2Hsgv5Z+ > EbObj3uXDTol2iH9ia > aZdZI3WtJ+Y2ra0vLLnAvIOeMtqGBV1tz4JNbdtCWNySRQ6Ba8pgJ650LS5uE9uRFZbHl7 > HHCJdb > u2xnkSy5XyruCRdmfcqw+4P5blvBgaUhv5SUB2++eoTbtB0jnpJB/MdIv/ > T74JEyTf41m026xto3 > dmrxEqXTrujXotn3hUuT2EQiTN52c+vQmy12AnvohaZih0z1fguWVh2fRwbL > o9JFyPIFMPmRhW8l > Zch8Q5BffDMYdbgZjF+4GYz49FcK/SZ9Ye0FrHdUrNc19CYnlqP1Jqf1aQZ > vDq62XzDxShnbeOS6 > xtVtmpf0O7wkeXhJduAlx+eRMS+5rvGXzYjL4xnFLEP2OKuOoi3eZ4UFa > R5Jq9aHSvzKGI++Mg7s > CTCE8cSfqUu/cAso/eX4pAz8y54G/c6NfsSsfSlDDtQlN9psN8NyvFIG3Pp > IzioNiItKGOJIDoy7 > 59SS+Dwy8CF5hj8f7y551/DJssAblIVPlpfL9plMKV9t28Rl/ > YfNDoFXysAr7PXQW/s8uKfMOum5 > 9eRezY8hr83CF0otzlPbii0Gk3cyw6rwL/+Lb+1Rqm9PhakN48Teo8Fd1GWyLgHezWM9 > taUXd0br > PRPcgV1O8bIQ+NyUsZdlpEsWuyVmK0mmmurUlxv1wtSmTWDV7xxn1cht3jZgFFO9ZN8HZ/ > uBmLlu > aWmzPO3Kvdne3BV2EEvH55GxWLqu8fd2yOMSJT5iliF7nCtm0YSzLhV2/ > Zo1+qehWTh79rPqZKfd > WvFhztV8g+avycHM07S7Swbnam22JPAuKYNzJ9LdkzaBTZ6zUMScaYOMZuCgq1ku2OTrqw > xr1hoc > HBs3lzHOrmtxcZuIl8ICf7XjODmNGPwWdqvjieWI0H7x4HloGJbGwEWswucE > J5uXcE4DF8BqpvEk > J2LNzpmMzyKe9CNsyr8Iy9k5H7CrtmW04HKVD3+1TNGLELgGgltMKy5N0QsSYyW2Lakug > 7Oy0p2T > NoHtGhbO8hHrPQjIcN6ZutwsSpu6VX3ogsvg4HilDDhLF3GRTWCFBd3uL+ > zYduGiN3KAZbWVjBnw > jJvlR2qcERpWpQReOzhZj8s5Wa/JOVkv0zkR620ayOjNGujq1QHY1Bs3C > KvGVV3Cv7Tlme/Zf9i2 > RA1tf7aNpZqDtys/9CqHzVIHbiVl2kjdNmkT2OTHSczZVc > poky50tUkXNjW3jrA4n0oOOzeOu0zp > qYu4rNzK7WFB12dyO7bM8pUF4q3t6xlL4q0yaCP50ACWBjbFCWNzJjn1nvHp > 2JxKTjZ74ZyI6RfK > 0F/UpR9pk/5lWGLnfLgmZNpdq192ypwbltvGhmqWYDPo2503NigLz5oyc6TuXLQJvH0zu7 > DWuCY2 > xdfQ1aZ72Bx8bwFhaUM9ODjuO2V6bthHXNwm4nUf/ldl0J6iQgx+ > C7vV9sSyRWimcWZq4FAANWwx > NbBtSxMnu2zBOdmeGudk67vOifickJG/1ko/wqb8i7DELvhg1nPZPNjhhlV7pqdrm9 > 26uKkWM4W2 > X6Zrm93GvbTCtaVMTV3bj9a5cQJ7eTrHKcLcMkYZbkShLuePafP0DIvbjciB > mNyOeKYu40KbwjV1 > VaK6rZ4jBr8dy+rJWBIf95FtrHENYGn0kbjd5IRbeMWpjeTUgocw/UIZ+ou6SgPYpH8Zltg5H / > Rx > bM1lNL5wiZqNc7ofPobR27I1sQ83Yjv6gfndbzy9ElvZcRkrU647T9rEoYtR > H7xTZtbUnSNtss/K > sLCmKQ6OW8qAs3QRF9lkHPeDNSa2haPR+ALxsJLQvFdMu5t+sSMTbcuWhc0+ > NcPYI+1ytEHMEQxl > zkldztrQJg/kDdxd5/iRsc3rjbM/9BfnRXV4RSN2W8SE53875qhz4PYEji > 5tQebDZHROeuz0xPum > zN6pa3ePu01gpvKskSt++Rf2tfmFowj+zuNl/N1f3LQ+Gw7q/ > BYPHtohj15W8Oglw+48fCd8Uqa1 > 1OUL6bTZFOeV2FpIlzF/dawqkl3nKI+4/WCKAz6yytlQhqb8DBYjPdaV34CVJyE > zd+ry7Uza5JFP > MhUGU8mAKVOH7DgPQOyvr5Mp+tyyumeGtney2I9PT3vwTZn7+ > JSzQLR5VzIVBlPJgClzM9ntx6f3 > 9am1X86UbRlD46E2shh1BLtR06fcNSGZdlK3pU+544JMHRtTl8EBOs6Kgx0P3AnrHST9p > ZoAIc/0 > /PDXU23RdHBfhrC/tGzrkvdwQq5uP1WOaYvKR5yqjWpr8e > G1nSOvmkTaD35kSkvdUtJmKX7G3cYK > hL8iXETBPlTvRCsEnp6ueBGinbTKhTVquDtsFVYX2NgirE/arOEHuO3iWJ++ > WcnHIDMLBO51NRD7 > B61VHdi1bU2JH5kvhXW+19Zz+eYWYC3F5/kWDugzSvhSfb5lN0YEX8r7xe5g52hQ > On08rhucvyau > MetUuWGByTfajORTnoJzAz8ylnyua452m8CKtTl9+JFihTwiAYevr9isy9doMHshvH4zvFE > zvPGE > N1bi2VNmPlznyTisknFbmWVdphoH1k1kp5kvYK+bLOOEJ9fOmC5dBaSsUUdZnmOqSiRxX > SnDOpu6 > LfOPe3XXBz8ydomFe/uCQ03sc/wMjavW/OIrushBY2YOyi+ > Wg8boqePvH0+7mKRxXpCY61bTDrer > F2PXqtbGmt72+9TGNaxpcxmBR8pYaK5rcyJuE5jet1MNwsGC9RO/+ > MoVdbiyTMzVXnLiS8fCN3lz > vYlWKW87hSoP+X54J7arnFzGrjxWT4csznpwTZmt3y3O7GEtO/Tf/ > A0Je1C4NhzYqvagcOUehWp7 > Xiv3+H3YGLHnskZ6SfikzGqpy9U92ly0OeuDZ8pYPmksD7bPtTaWMWLv5zC0jflvf > tn+1NXs9Ay+ > lPfLsi9npo7Pw9k0b22dr70C60VLSHGEbk9hK6dg/kQcW1nnwY8MQpsxJxM2gf0lx+ > M4WAy9vRlW > f/lf3C9Gfb3paZf2NL0VCuwxqh0pyfcS2yXGXNR0j34YKcnZLrubuGkWDFivnb > YoE9Jdmt+6nsKY > NUv8yDBHaIYOMb2Jl2acGBrH4vyy/f1Lu+6Gvd/vS32/IE+ > dmjreb7c6feh6DmCfF+fLP81r2VHV > AbA1j1qn18qJH5nSUtd6ITHXXhiWamXhXxFy95ZFVn+5/tDst+Fekp+ > 6CeDnv1vYfSYeJWW0goXQ > hlYR7XY4X+VaiW1+yWXsOL3rgp1sAissyIgDr6wmNxth1W > gnly7AVusDrBZk1FK8ZRnVWyV4byWu > PWW8JYLnj7c+o2qVZ9cHPzLWP/VVkQsO0ZUZ1e9bZGg9+iLA0frAS2p9ni/ > W263qBUAnrgAZulLg > t2PduIPLAnTlDuao2GXDEebOWhkXgAd+ZGyc7bptpU1gXTGCeSVv+xUy+i/ > 8ogM6FUfgB29Kgl31 > 8WFr6JoW4HIi7KErfsCP6cj48PKai7lBxztlVk1dzo2dxOxOU0ZXwsxNbsDG > k70O2HeMezdr+tR1 > c85QuDwy4oDrLMQtOeOeevuyeFHM7cQmhXEWZyJs+dPHVrb8qdk6YaUOZJSC0OVMBG1yluH > eHRdC > 2IKnzwzamEIpjnfTPw47cVzmgrFV4RoB7jCNK5fw/lPDvmPep6gvn+XrYz/ > pNL8CAZeJ8OVr4q3r > CjCj0ohtLuPo2oPjMySNLwA4fmTsXSDX5ezNTsy24OKCkvWDha5uWGH1l/ > 7quqKhYd6hpi2/iRJr > FnaWyfae2mUvjYdbsa7ReEjY2l/N5/SCmScepCXWEX3InJ66h3s4YfNwPyvu > c3X8yOBuTu22LeAw > EvsBS4TWC3etIu1L8TjgqpXN/bP9/YJxf1mpU/3gY1Od+dtx41HJiicFeAgSLYCOOmfr0XE5u + > Py > yFgudN3S0yZw0VHE6zhYoEbRl+6H/Ev3+lN2RxxG/jAPZrLlEn5k2HKdjM/ > k7whtkbetBvGETcct > vtUP1vYHr5Sx3FtXyzjo2gDikjLj0fVD6maTx74ZluORMk0teHJuGZd5M47i > gLiLG3zi+JGhD5/0 > mO7drdYTVygUb0l7Q8uoKwrWzFRbSMGbWId4IdNK6vr1C8hReaw+ > 8CODW2h5iLez/1MTN7+gAKGh > D60v3fOO5fo6eZj89vfLke9Dx8d3qF82dwkQc4/W5fqhWjOsK+ > qCL1wQwTocl3k4fmRwKY10cbGH > bALr0rBxHAcL9gD4JXoAuDKG79L+f419S7YlK45sP0cRQ3D+ > MIxaMYRsvE6e9pt+ucxMEvuciFvZ > 2cu2IwlJfBxwEKTSuwHf7rhrBH2ndvMK16Tx4GAIQkIayPRgYjUxvnuKBjbM > y4Z12bAuGukA3gwC > CJ1DB+FekqbP5O07ZRI/STP1Rq6um3nFxmhjMWyhfd8aorJwYW > PqDbsM6y1ZHVdbjBINIsCJtzKk > 7nou3JOG39XIy0UzypRlyEsYOogGuslK6twv/Lg14vj60A7vWgv4i92n0uNcunJXhZ5 > Lv+7P8Xa3 > yMm6L8fymBqRWTuZHBFDw6lRj2k1NRoCriNpFOAOvByvUya/ > J9hKYuKLxsYtUzsGHuiQHp6+TmfL > jH1yPYBY5WZ+nXOmVNVI5KZRFbSYl3aigdbihTWSCdzTj9N3dDHnIW+ > HVK9v9gnzy7FieCJgjlo0 > cMsRHb+gU6rT2168paCfCO3TVG7VaVie+uL+MEDVuXDWSYZKYJkzDAhrz/ > I5IDVlcCNyj6yJa+6U > utJLa4sbMXZtKcPCAdreoKlQlq+7CoNOIEBkmdyNZx8r33lUv/ > BKGkV0Ba9CukImd/4xr616u9/X > QZmc7W1bnWTQBlIthaO0HJbvCNu4Ynuyl7SVrKleDHh7LXt0veSXOBhIQs8V > IhOSuPZF7jNvbp5z > IDfXo+xQQGF5CWs1RVT8nkPMbyx2rKGoHxRm3rYnSic07NNy0psPFObz1AuvoMFNxz > olQk012yN+ > kmaJ12QqCOmBnnrjIEDw9mjKL4dOfcCCXVLq9npmEbOLToCQY4jD4g3zPUhu > 7uEmbitp2GrIy36D > MrkWAB9trsTDF44tDL3TmC/ECzslk5oyL+Ke/nLdwCudIdN3/ > 1MLfv6hdvvSel/WKHgxsNoAaBTy > FbzslyhT7QeWqV3BMmFoMbOUxUutV5ay8iKmDqSRbuCVzpDpH5Wg6eEOWeKa > ks6TOfD5b36Frhsz > wjLe7gb4pRoW5nRzhd4iztfNt8aoRtOeC7ekYR9I3q4v0kbT9RWyOEbO5/ > 2HfrnYOcW69RXWwqju > Ed/L6/Yvr8Y9L0nrSRp98Qfv0vdPk8neys54Jh5BYzfOvLimNeOy0oP22u7NOjr6IW > JqNOwSRo1R > xrRra/RN3cL/Dvafwy6sDFyTZjzJawF5XSYw/TX2cPzbUxgUmSmh3+u4Onn+ > wXaRVr35kYdGB+Ce > XO8QLqnHkU7tF445/0cyB3utYddODn09XuXCM2ns6knn3S1 > lmqaeF/EOGtfNeF1nkzn9/Aa8N3ke > hZa1yxq+iSm1zdsX+uYLbo7e4XuGbZJf+I2NkviNjZhtlTQcZ5D3Ks/ > JmjfGSTwvGqsjepdSu375 > wntk5LYYjp05891BKj/7gTo2eQk28QlLX38sfcMybVfL2rRa1 > iaNZEijFm1WMLASay6DNeGyx8Qn > aay0nNf0c5nEF416A/Cyf7bBcdXoiPKFzUtOAx3Ea550mcQX > jXQAr3RLncOrY6dXVM7wlpf/Sjwv > GuQ2rtzY28Dv3I35YrNMPQZyZs+DqzEd211NTgOvqI7AW1e9WOPynHQAr > 3SDTL7BmJcwdHD9Tbcx > Lp2zPq6rP3IdYLt0g08cXzTw4dU3LcWt0L+9o84yDKFyO4n3U0OjzRV7aOr01ots7 > exY/cInacwr > DG0ob51z4expGKRWntsrPedjXuasdxxwfy57NtfAiUfW8Q+8+i0Lo2/ > h6bmAbmd7jrNMqK3H8zfc > 0iOnl/CUzimhvI7eAdZSA9ekGU/yIreWfdipWd9O9fmonQ5/ > tH4NrJltxQkWrYPgrIZW+GucYbQ1 > kcQXjZ1Qd95SUibwjHUA4dBCgcp7SP2tPAr3nh3EDdDqfMGZlBaySgmOwpOC > X9KkaDYLSRxNwrpS > Y9UiME5QigYnGmtqq9OHwjtpdJsDePtMmX61w0pc8mQkdRMvdb4si9myc3x9 > aOczPls+93WRU3Nd > 5FTNzu3cV811EWLOHY/28+O8Wc05sq52E8456Gm5LuI3WEBmz3UR > x9Ch56qDX35BnfuFfe3LOb4+ > tPN1kTNyXYQniKXfyHWRM3KOfMa9LnJWjXWRo7UtWz04vkJjGq5cFznXKo4u > JSHNzpWHo7oOmWoD > tlIR+KLBSbyd6yLnWnnKKwdwNuyJdZGhO94OzonVWBcZ2vhluY0nV2cSXzQWyMt57 > dIjlwn8RJmP > uECFOZft6wiS+tt5VqyLDF1AQZ32hU9LvU+siwT9wWnk+KIljHUR0aA8x3Mu/ > c6TePekWVHmL95e > PwevQ3CteY80uUuNlSGdIdZzzRtXtGLvl3ov0Ttq39VhJLEavWP3KxosVovW > JxFfyfFFY+3eeUtJ > mcDsu9HHdN/7rJxb9I7d3y7MgzuC0Dt2zf4hS6sCGbcpOM7FcbKfZrgYcoyoEeaReqKfGdV > bhMUn > 2VnW2hVkfYIwy4I0LC999YPHubvI8Qia9kQfNbTLFzKbtLO8HJsOTmO6tSdL > VzuZQv/oZ8Dx9aGd > +pnRvOabHiV1bSXrZfM+tPtz9TOjtehngL01ttZTw5atsWWvOF > qfSTOyJbdR0tIR/Uzii8ZOv7ae > dbplTz7auFt4mzP6mbazn2l7pdSd/Yx/gYYW59JuZz/jvLBmZz/ > T5uVH32vLnFf2M365AXl6f6Kf > 6VrJNJ16z36mj3jvKIIUpTo9InPN7Gf6zH6m+7sCoTWzn+kj+ > 5nes072nmXeW/YzsauQmq4a9nhL > xPN9UupJLw19CeWVX4/uOzNcfDcg1gk9xfC3FL+cpRMzpfdIoWSl4PIv3Pplh6mCpN/ > M5rY/iv15 > c5gNWhUWArh6YzDVIsXwtxTdNYXrlz1sjkn1FEpWyqfSQdJvZlP6j2K/ > K13ttpXedYGI4aEoJ4if > FymGv6WwbHu/r7Ll5S9KgeT1zdMf9+AGOZhHG38W+0NpXIW5e16LufWBlP8WPpQLe+ > DDjZsFlHKE > f/Kc4dLI4dhpPo35cT9nZvf9ts+te/m+G8P7O2mMsH/txb+ > lyFy7pPSGXWRKqXWmah88SKE0cjh2 > mg9j8iLRn9n5paRfl7p/NKbiqNvmRgrD6/hnaKRg6MA463Ebvb1XPMWiAWdK5UGz > lLb3LW0dpiA6 > +5/ygTTd70DJiuftNJ8OsO3bzhpK0QFXyofy3x1gJ+E29pHYsMbDLds4/ > g9Phfn09Bq0vADCZC3F > MHXMp07r+Atct4R86hLCTMsMl0x+5vujkTW8U/hGwk3iXSfvaqt/TfF/ > ntIUKJw8g3EHIHn4OCP+ > eUry+L8v8X9Ku1NcWjbNHxehO/N3QxHTldbgNlc3Zj1/ee5/ > 9Nzlgp52QKSrFH/0POj9zxdZP+Rc > z3+Y9v362b8ZxoE1DMDdtG7AHn957n/03OWCngZApCsUf/Tc6ePPF1k/ > 5FzPfxj2/e7dvxlW7dPR > qPiYic41L7m39au/pPg/T3n8rjDwNLydKblVT9nfUpLH/32J/ > 1PaneLSvr01eN/zpyo/DLVXorc0 > m4BkS+vrbynxz1Oi1YBHLQ2Sow3GP08Jnvj3Jf5PaXfKzzY4nmyDH6r8MHRenc386F > Jm/WvK1dnM > j85mXp3N/Ohs5v6WkjxXZzPrD2l3yk9D59XZzH/qbIrtW5Q5jB3m5uCOz7+ > ktGiYxC6dPDSHkl21 > /OcpyTOjGZL/U9qd8sPQnzc5/83Q9x1bvCVizBAtsdkO77+k+ > D9P8YZBHrZESvZWlf88JXji35f4 > P6XdKT/a6I872f/aRottZXona/zCtB/GRiwD8TDtc7SdLgL6t52biaeMwxno4 > C55w/15Z8Gg7BYl > CfxA/7b17K6nw3aggnIgAij5iREipyn+Yur3bytj+47QH5axfTQFRunbv6ZoV58ptqHEUxB > p4fEd > /7aJCf++HAdPy3zm811a8Dwf0p7PFMUWDa31hRM4vrXYhSKudT0Xz1wntbaLYzKlZMrY > HzywlKvL > 9IevfDGFB1GD6tZ6pz36XrXC6qQJjsjfVox1XtQ+7ga+7c/ > 2h6x3udTQ8A6TwXDeRyF1BOthCgu2 > /nnwWpqF8H24acd2UI8HF2bX7qhVon8zSCWfItC6fW4QmrjaHNiaICntYBb5D > b3plS/7ypNSpAQS > P3HFiaSHoSRTP1Rl3InBsMcFd2t4SGP+K1wy+UxpJ1OI/cNKm837HuLkmZlPaz+ > liefjXvv4Fyn+ > MY1ac/MJcYYcnqk1w0EqpT87teaCrEvrV0q5eagbj6fQH77mgJRHAT/ > PR0q7dGuhW3r6PxfNZafy > R+mvCDEa+LY/q7Jl3XUeO1Siufty3kchlSuFRp2/DCgYt4urF8Cz+PjITtUNzI+Ip5/ > uYGwxxHUV > 1ipxvujtjEzhnV3K4m8LKwz5NHnc0XBRgI6KcICPDtZxA7+2vDI0Fjb/ > EZf6/QWMXZS+fr+F/zx/ > Q8SivXwC1Hde6YsrRbkEA+znRxDZid+AhbWv5lq/mbgLr6bY9pcJJIP+ > sAiAYwFp4RgNiwB46Li4 > AhPxflni/V2BcS0gzf0Py0SMF8M+W9iju9v2knZ4BSCxvo8wrs7hFVjE4/ > vQYIzpLwmJ1avgR386 > bftr4Vbtha332AmJ45B2/nvhIOGL3v5uLR1hKHaBYbdFDaGB/ > ha42Vl3UNq4i/yGbOiwup7i1QtK > IPET22ll28fTy8auU+mH/tT21+JY0JdwfCSYOBaUL79e462ze6QsBEyJ > FIS9OX9KeWqkhGSmrPkt > xTWwfSXdToh8OeZGd+bChe+g+WwxMMXicnxdJkLoXpfy+ > zZrXCkfBv8oYgtsX3RRub2ycuG42Hni > wsgMQcWUmTxBxZSWPEHFlOfiaTePfeYLnufmweloLV0H1bdOuCXJh/ > r2BSN4Z/uHZW/YxvNWFNH6 > ujzAS9GTKj0gnqBKD4gnqNIDztNuHtjmPM/NA80bvxYE1R88IJIP9eEB551Xwg8PW > BfmmlkNSw/Y > GNQ1Cyqm9OQJqhidOk9QsVbui6fcPLbHznmCKkb1bkVQfXoAW8tF8qm+ > jRyDufe/u6CWVK3aoaug > rCVVSyqm1OQpt2rVXoHBU28e2yHjPEHFlJY8QcWUGvYl1beX2hlB8qE+ > zhQFc/0HF6CG98JoO7hU > NXoTq+G9cmdKUEU7cJ6ginbgPEEV7SB42s1jNTx4npuHZzPZnwXVz3bgJB/ > qY6eH8872977wdVyP > 17oVQX7aMc/hJf91UdG/5+JxKqbM4EmqKBPxJBVTnoun3Ty2+ > VujhqT6rARWB31g8aF+WSeZQ9Af > XYBDxZUDCxwddme1B2+qzlvFnQrO4b9FHqdKHh5YTarkaS152 > vPBM1fwND8ICH0YtDKpPoc2DyM4 > lD+oj3PQq0ZK238ZdTXGp+VXFMaD9Q89to+JA9+kQoqF1wgep2JKT56gYkpJnqBCCtZun > KfcPDb+ > gj5fF9WnC3pLkk/1bQ9NMM8r5WdDaDnARnX3MTIPkDOUfVKx6l6D8qBiSg+ > epGJKCZ6kyuruPOXm > 2av7+D2pvjWEHiSf6nOU5Myr/33wX+zeUU2U+Nl8aleK4cFTD0ETioHqSyniIJU4enA > 7B+drxB7z > GQ3Wc//Mxdz0oVfmj9jQHGLa0Q1EdC7b40rzbJChf5tLlRv2BpVh5EQLixfAdsqQlDZ > LIL8hG8xb > NBc8haaglM7gJ7Y9CRuTzGb8rt+/PwqLa4AyqN+mYsChlHBIOq77MafLcT9nMLZ5oPFwL > pakmh/w > in9frDCRkv+UUptuJM9/X5dkSxm//v+9yPWaUdscPjaqig/ > B59tX0eyfIouBquvGRozYI+WtHlXR > OKadRFA0C2FFQzIanr4AryJw2EGFyrh/xWaJiUfS2B5q512XzHXlBRrpYLypKW > zoJW3wPW60QSnQ > r116t3HhkjbUHTYoYhtsUDwx2BB4JA30E++6ZK4rL9BIB/BK0/ > 4WXbFdA7XxjKgdMqmcYxU7FFsV > vdKmncK//zXBZXoyFpP8flUHxIXC+SjEi7Ld74rJjV3x2nO07GRSG4l1XhQ > 0lfuswMubCilT+3x3 > 8XNc1Rb3A+OklGjOTF6clKJM26LpeRFLB9BIN/BKZ8jsNfO6cdPmFVvj1K55Yd5/ > aus8devMKvb7 > a7/sxrkseWVc+KKBJ+blLckE5g2MtGD4uWukHO5EA9b+UuS8L9/5c9DsxOeiYdxmWqBz2hu7/ > uWX > cuGZNDj1di5fUyax8gKNdDgrdcPptu1LasZxFLHFrDntuew8vI+ > UVP3cKe0kT8QIs3NXZ56ok9w9 > LaqV+vp6Empce57lHM13GduqE2/mAHd7tMsTkk6PsjvaFYrcZLnVYt8/ > bV4+inUDzwpbjXMa86zz > Wg2VTGrKvAyHDhZn2nWz3S6us32pevwGYGqNoa64y7xTFOntfKRsk8DP8+ > RpHzz9ktZnlmCzq5K+ > nMpvQuA/ftKnP7UrGn6W7fC/dtnavVq+W3rvxLBLNLDX/ > bZDJrXAarPjEzQla3BjvBDKZLwQ5sV4 > ZtTBsenmNKaz866SMteV1wodfjtHW2F9adGyW6nnwpdUnZsHr/bzQgth+ > 35ZtLd3X/RWbsX7TbNS > O2n3ynxhpfeDhbqFV1p6VPTwYsk+NPQEjfIFb7nbUpnZlnRXNC2b2ZbKfB > KPbG/FIw4abz9pfb/K > pl9lJoyy7Jc1/Sr7UdMCxfN7Lh1AM7Mtuc6QOaMtWcq6LNuXBfvy1/bofPjndf/ > FtbTLSxXncClL > kQjhgdpTblWZEJek0SkA8OocDGSqfDZoWnjJsVnkNGap854dMqG18hLOeuG6 > gbdfMvUNQpqO7D0Y > 51t4lZtqP0m1rx6/MWYU+6VMsfpd+a0EPB4zynnOlXLulHaltGxzjCyl54o > y1TGqecdsrS2+QcYi > Ni67ubKp1IcNoHViwG7PbDoxQLyTRv0dePWegEz2U3ZjSeKaNBN5Zf1vayfW > +ZsJbd/q1jq3xgLH > 8B+p74uwdd7RAUs9crT+MYVUSuHI7rFTwPyKZ7HWXqyoMjjFq9 > 3qON87L/wkjaL2gXdpV7rJXHGy > ok69mUu78E6ad4AavLW5zGoRpZWX45k08hl4zyVTPkZeN/ > boaxbxui6dsgD2sxR2RtXPT2w/uYsI > dnWpXT2P49fioKEnlp9lG3EimVhv7xr4t//T2bkjDF0Nt5p49JtjtuTYt6zNj+ > JI2Xp3geP4cgek > KYZPAYefOwFP51u9Crv22nT9ZESF4GAkBOKrtH1USxwnPmJEbH52+ > hKREBDdL3AtSVOvETS0UK9N > XJJG5+0Qy0FvmoKIDbcH904PHo/2zX+1hQdObXdKuXhanMnBOLVGyzmX147eS > nXcY1lrF2c/yaGz > fBgTrqwxumOOWBE3QKNoMuCdNdra8dMjRqPTI+bZwDtpzLPOa147M+ > vK8diMoYNo1kzedclU20Re > N44Vnr3Se8DnucrinMf92h6/x5f/uIfnYASos6N227Hf82S3qTw1rG5PCa > sT76SxO5SdtzaXCS3a > U3fi1pKmzeRtl8z+ZF69pg790q0/qXOLUpZM2dhaYt+PRA5+ > USDH3Enl5W947JQ6euY2Smoxogdr > z2ip6YioTu1Rqyk2nlXLsvtvHrVcWKnWZ/vwH7VieGWV9Na8vJh1SnqKZvTkjTmu > aVqeaEcabcuy > c1l/RuJ9+dTfTGa9n+czC/ZVNnqDwxrHO2mg0b7Kfs+0YJ/ > EZySNzoPWa4ZQNm25LNPNZxgjlnhz > NEXwPTmqpmWK+EtcLxpF9wKvR+IymU2toF14Jk3BaD6t4R4V4VgKxz+ > dJUXO86N0zlU650mddKoO > HDtLp2S/9uIsnbKydMrK0ikrW1TgnTTwcPZHkimtV5ZOyTiz0k2855KZh8leDn5LI3d9 > 0jNxKIxU > 3HbOlPqRoujl5Uphu6ptJE//4NH5Roytde7WvFPzDGBTBHJ4x2Oqm3 > cC76QxC53XLK+zpR35rmz1 > aq0137NNkWwpc2U/WnfWpsDVaaTzireTZMpGRRc+oUNYr6juZRKHFufS7mT/UU/2K+ > 1JmqZ1EOPl > 3T6UyTkB8/L5gf7VEyXS6keKIuoBt5wh4EwpZgJfjvP8ePOIyMQ6B7p9ZI/ > znkFvcyfdbMNcHO+c > FTwlZxHm5+an8mvOOkCz893SvCxi5uCzhefkbMHwPVugPj4nMH/EbIH/ > FKECVNdsAWfL30JQlFJb > 2VEcNvSfRWfOH3+bCz89adS3V1tBOxGDouo6Fgu5UI/6+bYT95Y0fSRv3ylzXHmNSwfQSLc+ > Uufe > aIvy+oZ9NNLwdmaLBW4R67RpR7FF1GiPRn8t1stw+j7xRQNPiBcekkxgRUQYgX97ylB8c6y > 7dfeX > 3trCiskGjTSKhKZOb7apR+7lwiNp4K91+VQjUOKWNBqB2La7R2ec7XPTE6e5wcH > 4MtC6PHcK18uU > 0jKPiIPy5FtyBP6tWljmjlpYPLYs1p56cisCa431INGM6rVQ60eSqRPcrfga > Ez3muLek6SN5+06Z > 48prXDqARrqBd14yfc87NeXeIXKvyy/HvWclWhV3BthrrvXOmpG2WBlCtHutB > rFOBq4XTUne+qRM > 4KtV1ZgzMeceuvp2v3JKZWl9CVe/9ol0vDuJkke7LK+a3YJqZTl65HS2Lt11YhOaVj99ohTYr > h6i > Pf7ecDzCP7oTDry6Ew7l3by3KBceSWNl6bzjkjmuvIzGdejjQ1Oj4tZO2BB7 > IKmHUqCfRwEC1Uqs > +A2gUfwG8Lassx6/ATY4HkkDG1qWq8scV16gqVlnXdMe74 > LGmJR2zCbegeX4u0j4XN8ZoSffS9L5 > 471kYxB/+4xrFUv/PHLS/vZesgBc73CIH9HtYzZ3i7/YYv8x5qt9dlcEQsc9adjfkVdxZCGTf > ast > lXjsw1124lqTpmbcRAsGGjLbk3kRn6RRPFrw7kumx6Pd37BHULTlnjoYKwV4 > Km7s2+yqYirvUiNK > oYUrU5RC7GNIfNOU4IWHJJPeYrQcWuAR/eCjWeX3QRxSFREVUnl4gVLblUO7aHp > JXr4dKVPRWm0N > yXEpSQPrOd+GdooWTewxlfkPX66U87pTFjdgMOWyNGL2Wvzf9x/ > DRhj2lTzyKKohZbGF8XlJWRHx > D15bPb2mGO2wXLHb4RFFz6Ok0S580TBaD3lnek2RAOE1x6UkDVYDZ3qN64/ > C3ur4b6XXlvdi+Kc1 > R1BFFF6mPMkTq4b8x3No0H176Q//8s46uxXFGJFYhW3E6DR1Jy/ > yVk0gvmgUSxe8o6XM0TMvYegg > Guh2+V4yQ3+Voji+PrTz8lVcPfQoHgUXchl9hrLYSwrXpJ > kneqOt3gUyvQcCTYtewTFWPr1nGskL > X0hmy/ixwtljefRgrpP2lLk/SvD0LHWPEIaUw3c+2kekwMs6rQeeUz54cpdXjRi// > Ndiu1Q9425t > h5vpSOXb7JhyrpST/f65LD73VtL3dR2aAV8pOo3AdceSmjW > LOxYpfkOClVBTnEArufZwnmYliktV > /uMcfBcQz500XtI9xtmUyRGklXp71GKxdiWMmcWMkgveulMmtJ47sd5HoFF8d > K51XTL3hzcUBx2a > nktTxQaHpooZDk1PSU2FIfXUzO1cWpxL0xN1VXMG0ii+4s51LMrUXWXISzMG6OD4WUnz9OR9S s > hc > XHmMdi4d3PqiaO2YPdSWWtS0QCt01LrVC1807SSv9lFCZm+ > pRW93zitqtNbD9HxcOYy7RpdzcZyP > FJ7wA66xCRVj6pJ1Pfaww29Vbc38poM+8JtuPiTHSL/VfH813aBI3p41uvasJ7VnjXaMeUnPe > uK8 > mMfkeyryAh5ZT6QbeWfWkxpbcqHFaWnZuSzbJ63hGo9wtmete5F3ZS2rimQP > y1a2AMfQYmX9qVc7 > dJntybxazH5Es7P+1KtVxX2A9hpujavpxBrble5fv9Ejay > yPcWHTvdf2Rkt805TghSckk/jJetii > TkFSy5qjmQY5Wpbax2rb2vou/uV46x3cYqXLPmfm88dXxhyvpDmi6bE > Kt058U3+1ei7cgoaanydK > VDKFLxqvDT10o8+uVTh6XbMdloBmO5i1LFvtWoyCbpdrv > JheqvY1mX2UHQKquhNCuCUNIwqCd3J1 > DDI1grWLP15Mmb1deCUNooaLF9GVJXNceY1LB9BIN0RgLilTo13k9YF9HXZ1 > fD/n2BCYozgLsF11 > O5ENn19Mqc1y1uiLo1TietHAE+KFhyQTmHMBWhDjUEgaPf3O1StycDxN > jhhb4N+K45jvOPg66o9d > qZ6yS/JvP5ptqsaYGLi4R3xs+uU8GudzRJn+376GAu11nADaa8RHjnmSwyMY8x+ > jmZAq3m1Yb8W6 > OGWdusOnitkLDsXsJVbJgsZrLEZ/JWrgUW2xGnj0hsUaruOVNIgL7TWqpc > xx5TUuHUDj5fqkzpBZ > b79y36i420cKVw+ZMrO+HK7u8bl/tUHtPDo5CByj3oFdpFH62E8ZuTTdEk > 4qr61YIZ0uGWO9kVQe > PXVhdVop7cRIzjzaFKea3BoTEM+be7NnwQqjWnJ/ErcV31ohVXFvKcl7E+ > CWOatXhUbqbXt8L8UR > 4MBc/Y2eJXjHJXNceY2WOozQ031ZdOCYuHgN1A5JtIpWygqpxU9dwoaiM8fA9WrVr > bQsvTI+clQb > G8LRYrTXD7VeIyzpsqOffvG88JM0mgmAdw1vMfq+qZJQmaLkHK+k4crwSK+ > ty+79XHgmzT7Jey6Z > J2w+XA3+kqa1PmGBAk4IpzVVI+YaI0paE7jH6jEsc3qre9X7glxtXr1k > vr3FijTqlVaqF9eaW1jm > 9OPSc1x6guYZyeujFObMUQqxv2lyHEtNR0lrRo365rheNPBKz3rgMoFbTe3a > XaPqzhqlWMWUtC5J > a174KoOZNUp3ilPmzBoVR/TbhVfSwC/ihb9m1ijPa1w6gGZljXKdIXPfrYj3W > Yv7pP3xbRZU+gLL > lPKRoj68f6RYqTR+lSPPxziylBxHPjvHgtd4TphlAxpZgL > GxLLORu1ayF745O95Jg1HsjjdfyCSe > F81J3hNjuxib1nbhJ2mgg3jxfVsyicdFU5LXa037Nh5FzdZ4FPhjPIpTQZP9 > 7MTdNXzj2iU0L4YP > cUpqsrUKl6Tx81zG++RJo3md7ZqKqTR3YrspxGnWSN6VNwDN > deW1Lh1AI93AWy+ZtWdeN46T/3Nw > PfrLMWeXOAE1uQI4cU/OkCdO3MMzca+O45umJC881PPEnNa+ > aYGP6JjC0SW52fqYw+ypBVvrxK06 > wnYWxWngC/Gu4zf3OL5o1k7eXVLmbpnXvqzcVxmLt18ye+T1++L4+tDut+vB/ > gA8q9QrZfG+KqZc > floRkwy3yLDVE3uAJfKsPH+4Ls24g1bPx33ab0mXkfewQHvdEwo/ > rJ0+d4z7gXb603nX8f22ji8a > rmlN3h1TQ+Z+0ueOx0ga6Cbefsnskdfvi+PrQzv37C7p85hHoGVufnFFi+XhY+ > a4R+a4x7zwkzQ9 > W7tWyClTcdZm8bN1bHWOV02albuN4SWXua681qUDaKQbeOclc97tafOwLbnX > nXLcT8Jh286S2zs8 > W2KNeuKsl69Ro484Gf6tHo9+Tsnc280c57rz550IpPIRu3lOZ9PgUZ > 3zQv7tSS11LkySVBdGnE1j > afB8GUvjqG7OOJvG0nC8atKYR5137ZS5rrzWpcPaqdsaqfOqv+ > Jsmqxp01ua73ulNfVcuKXFXG0i > L+eA9JDjE/t1zLKgn9gXrDo3uFKvlhb5TtPaT9KWX74nlxa0mZZlHxR6rktP0JSTvP59jz > nzFlni > EWeBfXWemqrfHjm/s5ac+KYpyQtvjZ3YW1Dg356y4uS2zuoJ75E > 27MuGE+3J52j01xnp6zOyPETD > +V1NTfdVrsqrhw5qI1gxVxvxPbB8/kQbO1yh/3Jcr5aMfTluXenrTmkzJY915zmvFN9 > Xwn9Hviq+ > 14Y+KSdGGq0+0Sf5vEb4osnT5dgf4/VMcxPkFWEL+a9mKdWapVQ9ugJqUR0lalT1UQFW5Xf > UKI3V > UaO05owaFfimKcnbc+5APEpq4V+4mLJL6rov7pN6t6u/inE+/+lc+ > soVZfip1exRWs12p50oxO2i > aT15W0QF8LVl5nXPCVBbGXAFJ+F97Zf4HiPDpxojA99jZJ4JZjwEntlt > 2ouM5x54Gmesu3Z+74h6 > wDPZ3U+fAuvsXvEoBuRtulPbzkzE84hugBNzimjAc9su/ > yhf4HnhiHpAraWDcNJ4XsbbzrqtaTut > aTMt0Fkl4BqnVRXbQLx+WnVdzxHnYKY1OnlxLvmne5wDWeN4Bw > 0taHki3XU4O/MCr1Z9dPKvWYwE > 7n+1tb4m/yEugm4Gt7G+Y3t7Oo2N1Jr8OiGHOSJqgs6M2SUhTb > nbSLX52c164ZE0C/EYdCJW8RsS > 96QpGWHAdYPM52RejtelP2ysl84jbamXjdIBtks3xooQ7hdNSz3dn96KWO6+ > O35f8ST+GKBnlNm8 > LDJMvO1b9gDyQcXdYOvicSqm9OBJKu1KDJ6k4teqffGUm8eOo3mM06AKKyJA > j8ey/1AfAXqCefV/ > CJAK40ZNGWPcLlCM9KBKFziPU6ULFG48qNIFo6YLggfGOU+ > 5eaD5GOmCnxHX4QKSfKpPFzjzulK2 > 1RGGMzCuF8045ut/vv7V7etaJOQ/pXwkpKQWX11waVTXY0CQ2+E+ > JYA1UoyjN4Y5OZMwOJQAjkgp > OKabWYdKh2cUUtdbq1qxlds4alVMU3AoARyRYhyFccyMo3iwMnAoARyR0mxi > zI/9gJ43/syOQMTE > 4XS7nZMcgB/PxUEcdthrURsKDH48FwdxpFgkQM3Rz0vim9v9z2uF7WiNhPynlLJ6JqQkf3z > Y7/wa > HjBl/BrH7197Ibu/EdAqzjtoFHm3aajou10FI6puoU+CAyHMdlckYUKcQjGooxgv9HvRDK6AM > wn8 > +I1HAqYwHrKxaPKC9QkCi1XIfVtmQucEmlANsutuI9aHvly7bhNvqdd3C/ > 1gpRQUnhcNVBTvIg1k > QrNunykTn6SZoSc8J0WFo4t6W83mZBeQ73VbuuQF7oQ8zWbbGxTSx3Y9iLbF > 3US2aSTgDgJbFWZE > NHNS2wyGAMh3Hwg4DLKRsM5M2zbnrUB7cIr0FIZsGCxNhRsdMUPXbl9lg341 > V7HbHe2B904a2+RA > heEsaSxcRtI8dPQJpbvtzwutK+5L5re/I2gOW/6dGzBtxNH1Pd1G0Xe7b14MxM5hQssa > unORgY9Z > TEWn599ff2oxjpdiTBjsScAT0m+RFi7KWZEWaWjdl8MdBBaDTWwjhY3MY > vTI2ELFSZ1uWWjFFyZK > e+HavOjEgCKN52O6eOF+0ahNzTACRV3CbSfx3klzWvKeS+ > a58jotdTgldduXNdbFraJTm7+WTiSs > X8tvmvw1/ZzZr+lxiX5NnvF7C2wurw9CPVJfTcUxXArRUuri+ > buXg7tBrMy4F8TkCdVIfXMTx2uH > pAB114W51dAgtPrNvpmGonOipSg/mgpIWSCgMHRYlIbynStqs8O9g+ > B1uLOdFAa4nIAmgI12oYxp > LOQ6nEkwa7C9dcaFAfbQTBnPVCeUfM1vWJC3mTNiiXMLHJ9qmIYBCcPNEmrO > CqLJULzgnY11kM+1 > 0w8ss+HqAGHtHcFWyYoNIvgSXbEORogNd83ewPyKiKUVHvZExJ06STtqwJ4E2I9ENt > sIJGHWNelp > 60HL/U2ELaDt5BYBDj2QDSc1RsDqdlgmsiPyk33wgwyUT4TRdmHibG7YdO/ > AyNlWcSsD94vmtTN4 > MeKSTKve/rz1pK8n5dSWuKykKT15ob9kui1hcViWOeOc0VB1wnGiqvODtv9FV5JWdyKhH > 1W0aVyc > Qqp+CGnIyzj9V/344g6I6zdJYMHw/O7ZHcJ2ZrEzY378C7aZwuJm9jfr1z/ > dDZGvoKj8A/1nS7Nm > 85vPjcbPb8JTy82Zfi6qd/cnDAo8V9Kslrxrp8x95bUvHUAj3VZL > nSFTI1lsoUJltX1mdB4Q3hlr > 4yAQUFW9X8sbw8IHTtDZZJ2oD09t3lqxtY5SWkhu2WIMq/ > pY1rKdEMNHU0NWmR4yyhRRPTVNZJ6p > 4rCPIGjRrhabwCMlPIt2VehuOxYHZ1TT4nPj40S3D/m8Qbrbh8KOIWa3T+ > 4OEUGXBDZoFdugsIDT > CQa7cGMbfOeaMM6HkYXDZzmBqSM2KjkTqh926q9bITdqTDdqYBX7pba7fKmH > 3bPjcAYB5uip0iSB > 3Q60wgE8LNZtAwjPmdEowZEEZvWa4Yu5Ao50izIeqY4J40AWWThMAlNnPKHk > OKH6esIgZVxSHTOe > EC5Z6U1q5j6TA9/6hJN/3XYPzR1q8uwWlOcHbJg009ApLYxADj > S2SVoThhk4rJs+TTedF8KAwwEr > Kw53uUKyhgGAqi1GUI/7belbIcU1qj9mPjezFusFnru5oF9Jf > 1ixX8esTelv+S/V/EXagCNl8JPw > JeM3y2AfPn+rK+N8dru0dDMbK46NFWKUgSbLgCUIjhrNy3aypZyqYm4JTxDUl6Bsd9ne4Ujfz 8 > lM > sOzOTFQxTTIns1bDuGMTVdDh62sneEvA2QaFOVxJsKKIjvoME7Z3ZCFoGe+ > 02atrCHN9o/EfnAe7 > FNLz8qgy4T5rLjkYc+GRIyhY/PiR/nH6Qqr9JIdvcbU1blxo17D01u1bbNP > KW9OpZhsWAPptOwdx > 2wef42q79zmfYiTb7Fjx/VSH+duZuBTPMyKJC0RM13ZwTxB89CDgfyW > 0O65PwHkLxGCUUHsvKRCH > z0ivXbgNt8DzDkPASXXXDDixbklofccgtF5tB4T3SIAxSsPN8aiskQXgDmjd > E2szbl9vYRaFEbIm > gkAZG5sC7DBrXrOIrLFV7c36wVNXiPcmOy2qAu54PyrfLkbmCBI9lXYlGSu2 > lOBDXLfJcV34mNEt > cL+2/BNPvipBox60jgjV17HQ4BgbpvAZrVeM0US/cIh2EePIwiQ+me+ > O4wLdzrdAN8MIsEfcntSz > 4Ujrk1h6gsbzPTuP+MoyfIyQxaOkxZwQVQs38vFc279pm5Y > MmLe3X6Zg1Zx4sxMj1U4Nd3FZCNyM > z9bC7ETgm8CPb0ChL7f7tfvRTeHZkmbIr803zmRe7lfHJ47G0mfipabz0pp5 > kUY6gNcHL5VbYGjN > XL51nxacskI7vROCnpNOhK4rmpqO4Ebe4ubzKl1rcttib+ > 84SI1AGN1ivddVSMkQjKg5fQT+7Rx8 > 35KDy5PkYLdEDh2p6x0HpXFvGFP89gamcNOVeJZPuo8ONJtlGaqcOTKE+ > YtPYkgSDQ70sifpCINI > DTsPivA5joBwcGIx4RUGsXccLREeFw22aKHzkQ1cQSBuI2mkA3ilG2SyBJiX > 44sGunF0Q525pklb > 2O/TRukA26UbfEJMX5GGPtRKxwk9f7t2W35HcMgsabUbPt8jrdGGLso6+Jgt/ > KTe58ky8OcFNXMn > vsrpyHc8OkK/W5j9wwFwRwgjYRxPEQ02abUsD5c5rrxAIx1wzEW6WXlE4Ep703e7hKPwNGO3 > 7bKF > pwGJm0ZmuEmJS8oDlzVxndHuPC2cy3b7slc4l+021A48dtLYwqrz9kum6aC8Qh843OYm > pc0Z2jVF > F1B+TLEAGYXTQuXNFwu5WajEOnnFf53fyyC3+xAdspQCWRpvkKOnXO4hEA2X8MnLag3 > 9Oqs7bvJy > fE7QwK/ipRaUSdzT964DeENTaMHZCzg0JcXzocEgntfUerSbe1yeHeFZ+ > 2SoFFinSRQ5Lm+OU8MD > gyN78M6nRN7TPxWgXBk5lykeA4NeUwpkaS6EPPRqJ3Y7YtFevOww4PHFRgKP > OzaviQbeFC+1qCNx > mUkjHcD73LVxrcsGemDa7bb69GFBTF4aDuntOpnFObXwc0ni9b+ > 3pEjp6Y3dVbcePv9PPE/PeFyJ > bpvinRt2iBt5iFvPZWtN7sP+4E09m/UfeMhb8xved4s5HOIQ+6dWqw2V+ > 1KFW/NSq49Kx+5G4Pm2 > boFxXqx+Y134onlHVsFrwzGXCczPW6ZfjT2k6Obsrkp0SV+cHns3NNGF1Qs/ > mo0N64a0phBdUl9X > F2kTdVz2C7yS3qoDwzphdurdnM0GPd+F2wqb1kKe6C4XLgoUHqnnwr169cK+ > YHDpabzRddKaqVWA > c3Wd1EkpJbtL2KPukljLXaA5O+zhRjJK7d7AYVFvXKUC1lIQOBzbJUxa > Lil4XiK3PlILdX6kafIq > Ot0W3lPHCe8FPkkzRvJCU8kEVl6g8TWb43qGNWeGNUNlZdYEtlvZW/ > po1B0WjJp+VGdMGq35mDW+ > huh5hTWOT9KYprHQeFImsPICjXQAb+tXXeANUt2OwxVf6APHuqTuS+ > rWuJc2THID+xge/yaCjtE6 > Ho6hZ2ZNz0y1AKfXekRN7jGSG5eGeV0fye30kTc27ylvXYIEz75zsOOefXF4 > NvFJmjGSlxcx1cS9 > JE1fyTt6yuRHWuYlDB1G1PPgLT1luv5RQu/8WGszhp/h/VDt3g8BX5qecftiTy+ > hl9s75161YIN3 > QMtXH9d08DZonLfZy85HURYFgTM4e622FWMdh+8oxAlsB4TYegqzjEfCdo28eOUjtPB7 > HfFO0HPL > JkZXuAI5oMZQRsD5HtieeP9zXQmvf4e2ZeaJl7/YkHWNV2OMwUZkjJsiazqxb77gsBWlB > PVOcSfF > afMrdV5kNBjD2s3FoS9Bucz2nDl8XhjGjrHcBYOvYEC9BY2A8wHzxuBUyrOQ > Nxye4wSmvthMZwkD > HGGfZ2xs8xoFMXgcs9YoEItOUU3GiTGcB3zDYEOMkH1iiCpGPpV2NRgPX+ > A2Hjix3FkZKRuLl7WU > +BgjrFXfusvjy526wwtrx3V7hxSnmtBp+eSTkQ56vKrr1leJdhL3lTSYMrZYIH7 > lr8S+Ot2oD7BN > Kx91KDjVdU3KGj9aLq6nruYrVliL1EoWlva08tUsFKTWKd5paU+ > cgTWwLhu8uVpHrJW451m58iUt > cOkDU3wlBCuaWhMT3sxjzcTQdV+6Lq2Rmj2rJcZ4QDT8GE2bB9dfPS8tn > wY+ueb2YDWGdZWacoxB > vFrSSAfwbl+8niiYEXYybJyex9L31KqAFlu1KoDVVq0W+POd3P6mfBi+bfiKq681PB7u7T/ > xXCu+ > JbnRAArXXlgavFwDNvK5j8IKVllY6Yl9wvcggDYWbssgzOcUi+ > f8roWnsVpsK/BktXgLmr1aiIXO > ql3snlPO3y2kQufYxOJYOcSXABL0GWyjhrDBLByyWYGAMxWwjRTGARyy4PoP > Mh6pjghMSX0xMNUp > DAYxC7ctDB1cejMthq8alTJ+cScyn6tOdIs27M+LrctTP6OeOyDfmCBgoYONZQ5xXknKO > wrhxamE > /j3P1JparTc4gnWOYG2/GKGScF2lrs1PRr8UpI7POVg3v/ > DIrJ6yMr6988fTJ12xWrhiNXfFa97a > rF5v49MHRdsJo4mxxZzQsvY7V/Zvi4DylRHMy7Mu7u2XnbEkY0lGI+ > B7E2zsB6z2a3neKkzAEwRj > BNtIYSOzGKmxse2rlmhjp5FsTTSRuT9/tdtlehXQdk9ADjVAwPcF2FpU/ > d3ubDhLs03yjMeIJqGt > tqBe0QnsfRUR79ch9J1gRlQYcAbCeesKHp/hNK/XjjI16CNMoy8PvylTjn9UtuoWKa9Vh > UENkXXh > gULhFu2gPPICeGs05cLjl92uQw/cZ9LYDMB5xyVzXHmBRjqA1zWlDRwlW > 6UvPGio56d6tf98vmd6 > FSmq4U5lVVxUqMKFoQ+F19WDlKKGaJcfM4wgteXVHrSCV3gI1 > 500TfXXeH1gSqkcNZMjUsyzDOZH > j/MaC3HsLCGGiBEN35rk5azYtpTFcyuhorrXIKdHabl86Hey5BzDhpMl5zqMSw > fQKC/wzqu3KpU7 > YJADw7aQo6qeYCXEPWbYZ7+ws8r3wD4Z4b8dTRk4/ecp5pt6+ > ayurNUMdiIa95nx5guq1JG12rHZ > 5zSwYqY/XOa48gLNzlodmsI37YmXllae3AZPKVjOTxtaWYlrtkzNEMnbVtjQuJAIGxyb > Hk4zavKO > S+a48gJNSRtCU9owTtowjvdHxsM9K8A+oHjFJ7Y1E66HwYb+RM/74qz3Ws+ > inWqxsFMdoecVdgpD > 1501znnHJXNceRmN69BDz9+uNRdXgbXxC1poaxisGTUt0HzN7hdNn > DToycQLP0omcN/ZHrov2FJq > DvnK6OvytqdApxFvq6L9XOTOkU4Z63rvFB+/gOPstO7EmFArS/ > SxY6xKXX2F847hF8gLl6SZGkYa > 75T3TOaU93A5e81ydpqyk7dcMkvkFdZ0tp4lnO3KUyDreuPNy0tzjsxvZbvS > NjLqt9IXjmHPmmnn > yjrmMseVF2iuN15qihx4RAmYlwOy7gW2DxM5KkFEKrdg5cClrJJvisWpK6xZ > XA2OvMKak6XjNKMm > 77hkjisv0NRsecvXyFCjtZeCHON+P+g7O1OiTsLqnR7YNQaKiXEYLT2wr75x > X30mv97LA+fywEkP > rJ0ecAwrzmXdSQ+4zHHlZTSuQw89vU7unh7Yfnk7bVOK6aRFCtozsg/cV/ > 3cCq6DnRINyw3Y4tJG > 7N2IaWK1Y0JNe09slU/Dojo5UbTnFi71aAtIfeF0Kf0JgdwPB > gItxhpbryPF9Tp8W0c+f9WyeZyy > 6a5h9YkeqGdJeOnXu3bZ2PN+PT/cx2THzo42n+D8HOCuvvXXQhU4xGG8HZmfHjme2GzE > 1VcQqDM2 > tqGdSdgCVj0LhzzjCzhjQ7ApKWGubyg/enEvDa8FthNIzyFFe3mMeoyAs0c2nO > yDbbVQf7VL3Goh > TtujTIZ2ZRlkMRuBPvwaGyNyQdx8LpfPEVt2ps85zHY9h5RRXTajXxG2Fdm0 > 4i5T726OVOdu7nVo > Z5jq9KIQG7JusUFIWYBAGRtb6GY7znna1+qdtgWDeqeM0xJeRTQRrIfQF0ErTiPR > WDv/pM1N9lRa > v0P4+6nveDIpi0Ngy4gk8t7yjGzuGmW+ZpT5GlFIS5XC2Ppw7zEGLrzn0JYF+ > nBzV+75WiMatrIA > gTI2tnUZu9ktm7FbCo32i3GYXnh+7dSNi21QyOHbbTrBK1lslt+ > e0e55wSvhjo5BK2lgOynsRI1h > JFtmfFIdEZiSYjPVJaxHFm5bFM4p2wtH23Pw1PeCWY6H3wIMFsY7QmNJXAxX > 1+q4gjYRjw5BW4dB > wAGDlSU/ukcuKkuHrw9EYJ4RGzTd4cVzkkAZY5L8XF3zOxHvbiRwmOYppsuLo7G+U/ > Rozi/eiXs0 > f/vH7dnE0YYGJp+sP8MmpVy5wbnOMqIYSlE/AcyJMmnq8bIsRc0LMn1LodFoq+ > Guie3MpNOYD8Rr > rnGZ8IDyIs6OJHQD77hkzqu+lLKO9yulrJPcu6bU7GXe6XPmUFVLDk > 7u31JriT7ie0o9mZLv9Rop > KLvaov6VepUXT1kJR6XGv1VS7iq3XNV3yF0t5a6TsvZIfO4a1XjMgLjHNuDE > ts2ix8vsxfF+eqei > KVVTUdLUeHf4jrPIS20msJWeaOBz8bYnZRK3i6aX5O1X110Y90ccvrmf9qju > Q7/VU+/9XHinDT5W > Md6T9cNj7rAd9BpvLWDXsNfk0FYJ4X1p28vwV1fp7RqEvdPLtGOU6D00VQyq > ub3XL2PFVvAyZF+v > 357PO/dx1agRNQopHGoy5VzjFE+Bh3wgMjGhW4lL1oRZY7DiGwwgdUav5 > ikhtWULmC1r8OzZ2029 > tsCb70lh985cPbyj08R8rhLv9dvzdQ2hkOI+iGO+PKnO1WeUuaZZKHPf2oydbSW1WvVux9 > OHw6C6 > +4fF073EK99bgW3/28p+Y830zprptTVG0vR4dxVtpI68vCU6Rq > iAnn2weGlDjv89L9LMfIfF6SVq > cdWhFXUIeasOQacc1/okDdw7x+NlezQV24hceNcVNiJ77g0T0/ > kkluYnrSMv3yS2ihUYk26OVHu5 > 6LHbUJuwsduQVnfsMGS+HVPRpQ3fO0rK9qEEtrei04/Uk1gbr0GjfMHri6q0hv4ih3uSOimlp > Pd6 > Se8Rl9gMjYtI3B7e+UWpfv8XLdLORmIeKiCH42J4pNR15Tx > n4rGTRtvia49dkZGXe89xz32X8Izz > jkvmuPICjXTooWdYw90MwIeTE1gT+LWG9xNQ0yO/mAWnnAuXpHlGWnOyLmhUS2uEodHJcn > becckc > V16gqVmPTkQAsLpwuGfatpgDB8e8JHFhm3hdRyEQUerLsY+qceDiUYp9HH+ > u7f2Mbclt74/P6rHJ > nrfGcpP9s/MwxLOjZiCE3H8uenLbrgzntt0azj1GcvO57HtubsRdevLgBuM9UtuiY0bA+/ > E+oBa+ > A8FbZh5wcGz68YZX6u30Zg8j96POvPK79wGeLw4T1Cdqca1PlF1gs8bpR+ > pJvJ+g8XyNt/joBUcX > FHUK2vFGVmpd+0p8Hengfa7i5ViEmtY89uAYmooGmop3XDLHlRdoRkte3ysPv1e+ > N8nh7014z1Og > 356pt7xhuMlLRtOe6H0VMY9SPV4lLWp1efuubdbkmFkn+ > aFDUkfm3MaTuNekaTO8x5iWmZd7z7F5 > wGkQY6/lQRGXOa68QDNm8s77sBJvMheHf2qmPUqBfjsPvvDuVuKuelgQh/KEL/ > QJB1LjM0mkuFRt > 1aOkml7qLVu09nOQt2ffQOxW9JN1ILbpwZueAllXufd9WbHy+ > E73lmi8aq0N8VXirRvYvOk05mXn > HZfMceUFmpMtLjRFPR4ck+Iwz1BLMY5Ro3etOk4qvC8PaPxO7CN7 > ytXanPVLOm/P57SiYVvq/dwX > ySiLn++Yo3++g3dmyf54lixJrRGS+2RJ6jQqeMfu4VmtP8KzjvtKGvjgZF/ > mMseVF24XKDGe0e21 > jCnYcBPxw7PDT9Nh/t/38/4wvDat8z82ZLxDCvofc+a4no98btDlB9FXkvwj/fV8jj+ > GMmS4Q6ef > 4+N5RPRzI2Vv8SvuIjdl/F8mFF73h+wyZSfL/mAJsu8pqYwrdvwDyJ0N8H+ > RcucD/EeeT6X/zrOf > b1r/MZ8/2HN0yPyxd9S+NWAK8H+TEvpIt/8mZV/S9i0t9XHdZu9Xyuzdq32k5D9V/ > EyJf6r6mRI2 > uD2REnQ/Uv7OE9a5pf9Fyr6k7Vvabam39f/LB0mXncIffKCe4P/0W0j4wfN3aX/ > 3ddBlB3R79PJ1 > pvy9FELCD56/S5uXtPlDA5f2mfJ3nn3ls3/k49I+Up5f/+9f//Ov/ > wV3BFxcZW5kc3RyZWFtCmVu > ZG9iago2IDAgb2JqCjQwMDQ4CmVuZG9iagoxMiAwIG9iago8PC9MZW5ndGgg > MTMgMCBSL0ZpbHRl > ciAvRmxhdGVEZWNvZGU+PgpzdHJlYW0KeJzMvUuuLknOHDjPVe > RYA7W/HysQ0EPlEgotNRp5B60G > JGj3HTQzkn5u/TUvJPJc+yJIOkmne/jb/98/y3+u7c9i/zn4x68//o//uv/ > 87//fH/VP++9//Pc/ > 7PGspfy51vfnf/xff/y3//TH+fN/fQT/p4j+63/5Z6K//lig+X++/+ > 3lR1Nnb3+2se+fvz7cjuH1 > 59+Gt+GaeA1io5kXGLxzEs8HX8MbeJSkH0a/GvEy+Z14Z7rDePcBntIN+ > CReNelXTz2BpSdo5sML > 3f7ylG+FxYZnUcrjw7WGprP2sGZWWdYfXJLGvOK85i2XCc/dRzvgv+ > S7OUv43VQJ7vFI6un32dLv > s63we2DTtKXfnR7W9B5+nyP97uma3+dIv5tu7jvH5lOnN2tcT+ > Cefvd0wQvd/nJrvhz/5RzI/Xiz > mCPAJ/Lqy5PVlVeGxw6L1mxh6ZpMvW/DmVeBHxrzpPNaai4TuKdFxKHFSM1Xx > tLntbUW9TN8dng5 > sOl6Zup6RuTWOiXxfmh2i5hc60QOWVqeQ4FP0pj3nReaSibwyVx0HcALPT0f > 1j1p5z0erV/au5d4 > Yzh9429M8634A0fLErTrCet2HWHd9hJnNOWGdYFP0pjmzgstJBNYaYFGOoA3 > NIUWTy7uSY5tGinC > tz1XhH+uA33i+kpav0v664/7Va/Fq9bxhcmfvXx/fv0x+lcKgP92fAtxN3yJy5+ > 9lgb8Wflh0n91 > SeKkaXcHb7sjZLavjonn5yT96SGn7f3gmjRfHAUv9JdMt8XMVGq07EnZ3nxx > 3us8YbPh5NEbajWl > lXHA5cL9pOa9hXUVFcnnAbMCmf3hk7jupDGvipdaUCbxeGhmS94fmraSmjb5 > CdrdR9PzaLozH+pe > mVd8Tq3Pk5/K85LykeeWrmvk2DR1GlhwV+KTNJ4WrNmsdplyaws5ArxqRE/ > gLwLaTGvaTIu/b9aD > a9L0GRa3llY2z6eTGNaIBtb0tEYyhR+aOZN3VeWNxaE5yuOrozrwXNMb6NfLC > b17yVgzwrBBOQgb > Tksb9pM7j1edBvqdjCnJpEYlafqTm6mpaTHKTE2fMtxvDy36raGFY0gSDVLw > umNRZuA6gmbUtGC0 > GTK/1CMtYeggGugmXupcR+IyX2vGihwZY3mO7HhDWU9UDUUecdZV > Y8+ITjYDJXWfJ715bqRnOCNA > byBrntR37oyG+aQ31wi750x/zJl+mk8kOo35VbzUYmU+zP3QUAfyhqamxSpZS65yHp+tp+ > 5ZNeub > 1TKK2TgRTd/hs9VTD2IvNbsyJ6yG3zVr+C2pX7v85/O6Hm3tjWtLqpC78wu39/ > uF0BvouFfG0V6Z > L3tmrO2R5YAfXubFHlkOHJs/nab14KUWM8vBXlkOpAN5XVOmcEfUj8 > dLwn5wNZyanicnzpNDp2Qd > ekp+u/bNb9dWXQFrbkaH05imp+S365QsBUqLNC2/XdTT8+ > qcGjliOHNEb6jfztJ4ntw5KyPrzKzj > z8g6/oys4x1Dj6f+Pk8uSKbwQ7OzZKWmFlX3aUPcH1/m+ > 7Qh7hNJ97Hh7syHe7KE35M23NvCBsem > h9OYfuKlFk9tdB8bpAN555MPo+R3ahSW1/4V1VFUB3/h+9FQ0likT1xfSeP8Jkl+GrVF6QP+2 / > GY > ruGoMzT8sMpA/fCKL96HI7oTl6D5Gr/BazWIy6QOTCv0Sb3rjbz6cJSHUc/ > KlE+Uh8DQ9Ky04La0 > 7EY+jFZ20LQaefjhEzJbq5GWMHQQDXQTL3SWzNA/rWmddWAdxJHySO3aeLSbj3Yr2vVocD > 9Sd5TW > 982n1dccwpuvZw3sMdNlkcVJl6VfwftwT1wyltp9vi4u1eo052Zq5CYuw+ > s9cZO3eZmB1BKR5Pjr > wQRNi5Q/nDKJpWl7LDBeWmmafv2x8WULNP0qkjGqYuzzxSiMw23PXVOjL8rpmvirMJ3m > a8kFb+8r > ZH7tGqaVpWr0+NoBZ26NdSIG4g1ia8zMx7FfafOLrl+OFV1WhiZ1tL7YGE9Ujx9RN25hGYKkp > 581 > ZvYtgaOO9DfIy7lKxPOcI/HIEm+9ci8XHMihTbPHlzewlS+ > nscgWL7UYWQMpLdKskrzrrSGsfeQ2 > rBJtwq95eB4PLvoWXlv86qNGWtLbaqrAM2kO6OMbPtZKOzlkgl7aWHtEXK+ > 9o6Q6bg+N2bN2fM8+ > ORnLpmfQeOskdaNMttaYluNHf+im/jB09jwzW9ZKG3dN26kbfSIMX4kGPqS > e4c/Mg3VX5sF9+o3+ > hjrdrCt2yTjatTzYy4qV3/1Z5+VXbTWUX2/nWfndM8vvVn1p5dexld89s/x6O8/ > Kr7f/rPzuvqW3 > +Xtvld9uOHrLeO75s70vV/z5x21VQq9sf1tV4WMko+Q4zbB+ > fWEfjJiSSMPUwFs2PAOZZcGegfEe > fl9HP4nHSprZkneelLlqpgUsHWaO2YDXdR6LttAyjEZwHGBwDCWt8bGSu397 > rsHbT+/CN7+UNqni > Dcsn33hswT5/08yXs4cP1JYgt3wAvIfLvTZmsMmNcYUaVK0mRysrpLYiGkvtppfVfvh+ > JIanRDNP > 8poNLhO4PjTSwXhb248H2kCN+9XWxMHB2oeSGMfEqyUNayLy7h9S9w6 > /5hvLmXZn5KS+snje9d3D > 6M7zvN35ymW7jHLvGyH2eXY7Ons/0LH39E5nrUWMto/L7ewlEo/ > yyB01Y2fU++Sxv8FIRct8Hb0+ > +EYeD3kXvKxvkcdD3rU8dmz55DRmhfNCC8kkfmikA3jrG+WD/ > VlyKIq2UR36Yxv3oaRTYyxD+PWT > fcd/SnJvzLOivCy2Sgf68h793TCtq9b3b0z7Iw1cVtKUnryWDy7T8DwZ5cSuxSor > 9Fs/4nzNzC19 > mcihOLecWPKy5YRj86bTmJfXUxbWzJzQV5k0O3ORkxeSqToQaQlDB9FAN/ > FCZ8l0/TMqd8l6a5f6 > eMDfYNyg7ODfnieGnzzZ8j14ew/9dk9fODZ7nMbsdF5o0bKceVqgKfltS > E2RwkQLivgoF1pijIKc > mZqenhbsxzL3EkZKelrDL3GkFdY8ZcxpoKl4YcHK2s/TAo10mKGnx9cpWeOdsh87/ > Y3pdGrm9Hm+ > Bef5Rpz+1j9n7qjXzqPtYYuQ6a0sD2fXVyv2v4nXG0F3ZE16n7r+ni4qa/ > 2Uwjz6Uvxw5DCe/x3P > pdX050rjK9vD0wBW+R3ljJR0Rur79cibWwvsadSs/0adqUddJWm8RWK8+4fU/ > ejxfqfH850ez3f6 > 61StxCVaQOP5Tg/NZlgef7h7fAX+YiRoTL/nOx0ygetDk9/ > pkd9p81kbUbMBp3VN1pnd+ca0anMn > z/t9/j4bJexW/5b+UGsM3NLdbHIMvbzFln1jpNBrefBD06 > K8fc3fqA0/HLVNYNPBaaBbi9owZLr+ > 6Zs+W9jZZ3vf7JJvtvNYKibGPfAFRUhWP1v40eRmzvcjL818Disu5aBfXqPlFvKH > 0nVvBD5Js2rq > QJw0nhY8eZ7S/EnOnB73jZtZM26mj4zzTc9SwX6xl3qbN/BSP2fUikPzCXp+ > otRPLSv4usg75leJ > Ob5iEw7e0p8rZ22N0Vv9tqgj8UPTs5dgi0ZCZo+Z3THvemZ58cZmV3/ > pDWda7c0snM20N8NmPE+m > odlPcrP/STxv0tAb5GWtSZmsn8wpXfWWTckHtpaU05ydvLenTGiqtIClA2ikG3jPI/ > OE520mkL1e > aKGRLXi4nZlYkkCzM3eaPLl7tPFtOijw2Ulze/Kapi4T+Dw00gG83j+ > HFp09MmjROQ8OLTSmBi16 > naGF47OTxlJwXku5t/Rd7w/NGMnLXjhlzswnx9BBNNBNvNBZMl3/ > jDXNiSLlmF+ELH8zc7aU/PeR > ezJ2+r6pB1uC1E+xAL2FYY9oYOd+7D9ZLjytm7Ou4E1NN3owqA2IWbZRgg > PXmAeFpmNmCR5YiCTs > XjKanl4dnFGPtNwax9BINKap88Knnpsr0wLNzNgcPoOBHLE/niOzvznib0w/ > LgOj3lweJvzYOTkD > RN6VNmjeFDY4Nj2c5vbkhRYzc8TTAs3I3ExNoQWW+pGD86xjFcyywupVjZvfZZtsBX1gb5t > C0mrz > N0leV+/Soq7e7YSlu6/I9d0zbrfqs7Ef/NCw55D1qMsELpmjxK7fvqnfvm9u+ > Ru2vR89TpYfzoiK > ZmX50QwqcmuvLD+OzeNOc3OWlVrszC1PCzQnczo1nZhNZ > fk5g9g5Tt0hSTOfxD1r98NxCfKOH1JH > eibfdMx2jnyz9PXGr3vQFgDVdfvsuZaBfV7AL9bAO2YIwW+tc44immYfDj/ > g+d/+vEr74s+ll8/r > AZdzkjsi0kZS7dcv4eozhuQftAut6hGR9GFFWPv9+Uh/4Y28IipP0dYtKZI+ > HPXV0Dok4h01//Cv > L3iXvkoln29r6bNnaD78ZEaEhfyjdBUxgW9PGmj6+Ml1AE3W9NLBvWRzgG5nq0+ > JjjfsTaSdrbfE > Xu8ZjepT8M74pgvr64BBeX0dMMDuHIGtfV1KSn083G5NrLYLaOS9FTOLmZZ7 > 0rF5oGV7KHih6WmJ > 70PjuRB6epT0FjWr5iTdTn+zcuYSuqpPQu4+E0f0WUnoavla6n1FywTP/ > 47nJ0pO9xbrOjl6v3aO > 3q+do/dr5+g9Me0mDVtg4NUIPGRqZH7dHL3fJUfvbamM09hyGue1attl7p6j98TUgTTUDb > zSGTJj > 9B4cdTdahpbyDUkxSm/rZHvll5nYazTy8EtIHuYwcGMtBE1aT > U1aS00av0CwurHOhTccY2UdaeA9 > 8cKrkgkdlFbok9Y11qSk8vWk9oHDKrpfjjnzuK6NT3P+Z6F1xl7Buhh5ph6nJd4PDVqCIyPAZ Q > Kz > doZG3b2/uPqtRFwNjjtAkmaaya12BPAZmdpOz/Tdw2NdMYY2peIHq/ > 2EzfPdY6kFL3JKMqkp0yKm > DqCRbuCVzpA5vN8PTQfH/MGtdYDEHOGjpKWUsV6PKdQba/ > cQbY7LQ2N5Jl7kmWQiz+J5D/qFNYCU > g/xzvFfSwOsr889lui20DKnRsidlt3myRQA7p7cIQKc30GrOGlE1504sTUCza1 > g3d+bh5Gj0Rvvy > ZB46jXlVvNRiZT2htEgzMw8fTW0su2R5Xiq3w8bKubpiDxsfV67PSnrH855X > Ul+/SXI/7VmiVG7J > 7fU37N84+MDeuM/ZhvVU9so42/4dhq/0hjw7axeNGZP79MRec0Cv4yUT7cSMC > 62WW9Yq//m8PFod > 6gutSOWW2EivR8JZmfp5IkEr3kgzMs7VFoV1h/ULIsGx5abTtBO81OKp288TCcfLYHtG > oWHRHZl/ > d2Qc3ZV1wd2Z8vXYXD5STU3vybh2jPV08r3VX+KFtyWTOqys+663Ga2+ > wMj2L2rhI96mnY9483kt > Xr/ouWr/r427vfb/2rjh4a+FXL0m8VFxy5EPb689Au+HBi3OFnV2yNyFaYV22hYjqae4h4EjS > vzN > Ykvz0UM1F3HU875yjrzK6ZKtdIuSwK0lTctVd9SCMoUfmsznV1NryXVF+ > iVWHfHh4vWCt3VtcufD > LbHK+4xRd88fSUU+iJupkZu4xpfax+zJqxoJqxHVBqorcZtJ03O83ybPQqOe > aZFGFoC396xlvrZ4 > YyQZPiu18KhHK7in1or0q9mBwFn7f7hEbmp+P9Ly3HRsOdLym+q81Dprf0+ > LNPnlkJ5eqvpTqvpT > qvpTqvpTqrrnmjW7uvUWP+7a0QLGNx/PY/TXOk0fC/K25g4hezNzLQhl+ > SieLRaNN7PHvhtycAyQ > mB4hDUfGyMsxBUr1PR/gUN6Bg7MzWI764UJutEspCW1OYWtDO > A12fIiXO15a4vXQMC/Iu1vK5GgG > 0xKGDjutcV7oLJmu/2PNhV+tMQysNzfeUBZLATh6mYnriPQ0mwPe3 > lI/rd2A3o7RHhYN9p2I1+x3 > mcAlaVwH+CI0RQr85hBz1QPy0PFc0UalpvuxYD2WKc9BM9OrGj+ > OtMKakbnjNLBGvLDgiSNPCzTS > 4YSeniP9ZjxzdNfj2d9MtPUznkfNeB4tI0AtaPBqXQmkjh7pWUuxp9TJdgAk > zZYpTM9bo6k1PDOl > ha2T9+fmJc5LsbRqtSY85vK30nUPBD5JY5q6DsD1oVFa4PW+ > ETXdWTrn2qnperSbGZGOIUk03I3z > aLGzdM7z0PAbTd6bpXPejH7H0OFm3jgvdPY4LZ6WW7M4Bgl/LeUy9+ > KkdtqLQ9xTu/X4enlrnVLZ > ryDHzzccg+Qb77HDDn9jdiz3K1a3tNB97YwY38pLjj1K5MruGa37ibHdSkjdHtFY/ > 3LCm1v1AUaA > S5Ygp8Henaf+cJnED410AK+vDmMK3NNBzHERlB/HEyPaj6ZPPu4nH/ > fuSfPE4X7icD9xuJ843E8c > 7icOXSbwE4f7icOddbj1CThbjtr9+Gw59NAb6Hee+vA8NpzHznPzS3dL2nD5vYcNjk0Pp8H > enZtf > OpcJ/Nhwnvrw0dRa8Jz3Bcdtb73vb6BTW6Hr7WnDfWq06Avw185673pumSR5fOWuH > lq3HutEg109 > T67cnd+xex4aRQ949R3bGI1vnlZg6HCzvnVe6PxE2/WVwtZyGqWz3rM2aFF08zk5bMXyz+ > dPPYM3 > 8PENKtvyKyrEzyj0sPBTZkaZ8f0dmsu3MhN4rujPmEUfjngbZd8Hl6RZUQN8 > 8m96aa703ozvb9DY > mnDntTXrLpP4oTkzee9TMr6PabR7xtNqHFqZTNyidH+9tijdH878rCXz2TF6gqLBTqSsx0Mmc > H9o > sv0I3TLPq8rwvsTBsR9JGZEj1hbQhqUvJfqUbzTY7L97oHmeWK9Cfl0ndhHV > nTuKoKHTYC/T43ut > KCA+M2kUI+C9mbfe2kNa96YON8p58ELnJ6aa7ziHl7q+PcAc6Ucp0eoCW9CBJfmuXW9PLYGNI u > 4l > rhdwuYMr2OF9zXPDotHS46PPxOOp1bA6yOUO3zFAuTPaf2PMp/ > 0Xb8z2saImGGP3xCfaGEOrgcmb > 9a6wl95ZbpReHsdCDsdzxc4aSJ1PmZhPmZhPmZhPmZhPmZhPmZhPmZhPmZhP > mZhPmZhPmZhPmZhR > JrivZkVua98Ln0eNtfHrem9yrLkfbyyuJQLWHmR4w7F5Y9eMQY0+wgM72+ > TohjvNuvF1GevE12Ws > E62ZwGbRyi9H8MKGm5H1tHhCh9OefS/UqJ+IpR3RC9v0xnTaT+ > 7usdKembm73z7w2Nk3HFrdS0kn > 81o7XGCdY2h4Mh+dF/o9lmrXMWhOybzWPDxkakwVaTk2HU72 > SYPXdHaZrn+WuKM+A/BTYn/gbJdf > vnHvnfnWCoczW+TxsWHoeJ9ydjUCYZHl2CKLM/rU/T7l7D7l7La079b0/ > X3K2X3K2X3K2X3KmfOa > pi4T+Cln9yln12dGmdrdEQH31tTuqYfvzm/+3TU1XTM1fb4j9/ > mOOA202DW121k73Oc74jqA9z71 > 6Swt+lDA4vhwSJql9wc//clZ6vR6+nsz3zdci0uetw6JN9NSXFG2puZoyb1 > rYh8bpb7cEWPfqFnV > iu44P426f2r/eF7uq28tEX+iUo7NOiPHplZckyNL/Kw9cuzDkWNTp9nAOm+ > n7J7483rQmG9rjjaE > TODx0MyavOk/o1L7w3ArTyt3anU3ZLUn/9gCCapTwoMaRdXzFR78+ > fz5MuNNpHH648Heo100tb4Z > HD6SBZzfhqnxT/Kqt/qFQDw3b2r/sX2JZpdF+5G/la57KvBJmltTB+ > D60JSdvL4+EFb31aNcaG0D > OdZKSTnyMft+46zPLBd9v3IHd4oJk99yQnOm1t6amjOFXGKXO+YIuWO/ > 5U07leDZWWJUZY5sKX44 > WpCBzXKnMfuc19LmLmbHD02Lr/GcnJOAzCmPW1qOTQengW5PNMS4WfG0 > whqNIiPlGJGFXB9fNrk+ > Cmlycwx3zhzbnfOnl27m6ryZqzP74FPrDYlr9MHn8lG7j3e1V6rWG5Lj55uR > pWVFS+wrjvHGdF/Z > kvjwSbyytPhIEnh35tEK+/xNSD0jJZ30tPYHg0b7g8GrnUuQumMO > 4vuIzM3ZeXhhPyXpGTOa28fW > pj/nKZbjzj+bphq+MPsqrPknTvazrufnLYJ//GE5AGgOBJW1QpuVk3+ > YKBziiPVGeG6ZNE3e6mZ2 > J/jEtEVo8Q0qAOM0MfHjF2HV3iMbGXTxBv25HRRn60xbxQTLxDvMovOptqzY8o > CPx+o/Qg0O2jKA > 1tAawnl6XJRmmw8aT9yCwIbGNyHqcxJgCRfYuHYOwioWN9uW/cb9sV/ > WBvyqFif4amZn+3LHhd1M > 4mbCIKA6xiYlTVjTJ526oe1GOFOcjtSz8ocfvwTVywQ9l7+ > D3leS8zkafYTjec7OI+jZdyREMYG6 > PJXKjp9srCBt4UZjHYocEFxJwDNHwbZKCJs7nppPRTtOSOBRqMyrHQR9BFtP > zXroK3/IjkzP7UM3 > au5BKMcPNPdp3w0HT1RHgkHAKQSwzcb8slNRUTiRxFQ9xPNFcXgDtOaZVyRZ > N+A8btZERpANbVrE > neCMg0XhLtGaE1kX67zQ5r5XahajHManmidi1OEJ2pua3dQMBEwNbGpt85xc > HeT4ffBtEAiHGWAu > DV/Wvw3bglJUSo4rMQaZFnCPZQu9Y6GtYwxcTeBRkn5g2UIhtqnwLrwzXWzN6+ > Sd0g34JMYmPdGv > nnqunnqCRumCV8tfZA22NopjnPcNum56oy4a9ngED3C8MZ6GLcXiP49eD+ > a2+5CFJqGwOheShckz > 4bqT/8U6nIX8re6Q1VQJi3+lLd6g1RssfRLWdseuw3j4pjdf3koqV > kKU5RUSc7oPpjI0NOY5ze3z > /nxEZPi2+i9fHm4sDxY30hA3n5N7/uBe3Qe9qOF4PMRjcaT5faTe1z/ > DfX18YI12c2MJY3p4jGKA > 7kSMOp4jabBJr6feLhMa9fQfjxEUzbjJO3vKnCPTmit1EIZuooHO4oUtkgkb > lZbb+1i/b0TH2D/e > rMerGnLgr1l7eIzDbUydZ0JTqynfm7asiWmFY7POabBNsKQ3XObqTCuwao0V > Q3jibStlPrkzn1xz > DN1EA53FC1ta1nqeltubJc32sXhJmzPrtLky0udSHRjHAXXrVSV+ > aJCyeJHazLziph9ZP+qrxeyR > b37gEK1bqsfNuqXYszRWzzTWU6dzolc0NT2zVHdDpnLBbGPTnh52bJ53mnmS > 13LKZZqmnhbxSRrp > Bl6v9+MoIaX14nYeX6ynTub0MnNkrZta7xo5wi4BcyTwQwNPrCw9LhN4PNaMH1qsEj > myfnwZFg5f > lFzVQz0GZOXhk1/KdfIr6BjeEA28dPIruJ66bd0RmMcokGY/ZY2dFMrcKmuW1vacLYlNt/ > 2Ucedt > J2Xi2CKl5fam9bayy6y37/humc9b3xVo17LW3r09OGuFrbIAXv8W > NB9aVlpjvSmfGjnCiW09n09q > 8/3u7pvfyn1Tj1Mynrm4lnqcmrlzvK2DweIdnnRsnnSa3pK3nZRpOnharg+ > 1s4PFDjqp3faejOOx > +rWgzjoRz8fj32hUw9gSSMdzJ41tXnHedVPmbkxLsW0pHLZtDF/ > ltMX8VTRYabtFWmDQuIRGgUvS > tJO8Zud9oueclX4/b37elvl52/tFunPlm6f+vE8s3e6+RC9XOQ1NTtaG9+ > Q34O78NlyvP9AxzhwN > jAHorG+cHp7ZypPlg8ts7Xq6AwPfJSL63iwljldNeljztCpdT9DsLCXUTT76PrbVv+ > caPoams8wX > T9f6w8fzOekx9Nxc08QnaVYMXEO7D9fE2eaBPuA1mWoXfVkXA+ > Xi2D21jjbywiDxjDc8lPPjx/D0 > SdzHyzEejvW0dWY90QacPKITOT05gY2cTnyTxnxWT5SBWVX7ms+ > 4xBc5PTmMQJ2a18TrwTdpODyd > PuPRIMLnBo3rgIF06WYyuSRa9p/oWwUNdDvz0bmmLTeiOXQw210384lj8 > 1XLcht6uj+j3pqtRr01 > uVUK9dZsLb7Ds6kdNjAEf7zeCjx30nz1VvCumzJ3Y1qWcrNmRNuY2hZGjfZh > u88AfsF4V+OXoVmT > onELRsNQWuD60JTkrSdlAmNSHZdwCIcWOABVbzT03xbuiUDLgJjfhmbNnMTd > cA9dT6UeNqjHSUjH > SbMv9UDKyJNMC3g8+CbNfHhNU5dJfILGdTDeE942DxyM2oh > DwznSD8vf9EYTm9TQ38C6OdKi+Vg6 > VnoAPT/x9hvWcasJrQt8k2Y+vNBCMqlRTZqZnnk0tRSeXDyKB7uL42 > z6ZtnzTe61SB943VfS/V2S > v7mPn+4PP93HT3fO8M19/HQfP93Rw0/38dN9/HQfP93HT84LLR4/ > 3cdPrgN4Q1OLgrsV05s4OPYj > SWWIuL8eWCqxhl/f9NKu+wY4SlG8wUEvvboPOpecibufxKO/ > 3DPKYC87ymDizm0CIXXXlLQeqeuh > mVEGO5eTZVryfuKbNPPhhZ2rP/gkza7Ju58aD5trFScf7qndfTS9j6Zn > p6ZH8XPzObS+Sg0yS1jg > 8vNAHmrkeD46wALpQNzTmrPTmuP1hh3+V1v1WOoc05PUllI5QSyskS/ > aWevyWOq1eYwe3HTDPP8S > 1m04/pyanPH78yHuK46P2zozzXscesPvDd/4N8C6SfElurhZhzkPjrUTb9ZPoGFpI > S9rGErdrx0H > fX3HlGo2HZWCazUaygq5T5QbS+80egG4r1fuuOGfM0v44cwW/ > vnxfPyQi3FFpTjL+waTw3qjCVra > qDew/SjSweE+Ad7hn8MahLxo2Uiqlhw2W8n01bRMz/DFAh5yBK6G0+ > vsqzA19k8cJ81hFO9i32Ys > w8+0DNf64JU0rSSvaSqZwjtopAN4r65UYWpcWixN96Pd46O70kdc+CLeJX+ > t57l5ZcmCG7U1LJD8 > XSfTDY2EoaloYMF+rFmPNUoLvKs8eXNv8bzpPCYEeZPYtm > eV69b0kvnRuclSFt+bFnt+mMX3sfKW > tOw+/hUNNPV8aiGTRx0wLaNxHXgcQvWvEw5QwBIS+KtzCZA42iOptwc/ > 9cZH1bwk6qsVcjFtL7mz > pdw5UtbciVd55Y6dcqNNCrm7eQmPrxufTy/hvz1vr9wd5VhU8easfON1OfOVb5iX+ > qLwgq8Z2L8u > 98aXA7z6ojzHR/zlVKwBbQCpc2aobXz7Ojk6vgqUhO9jL4nbQ6PxBKUnqaUGt1J79BM3aFrGb 6 > 3H > S1Tn3FPDxujAJ2lgj3hxaLRk8nqvkjSyALxa1qtfXtcWPyxOHLNErHBJVNKj > Z2ZrY33Ob5ac87Pz > +30uTbgS55wfeTl+ZZdFJs45v9lyzm+2nPObLef8Zss5v9lyzm/2nPPjAT/ > CI+f85sg5P+GaNEq3 > v3N+tIZjxeTw8Vu+4Zwf3/j47Ww550ccb0rO+ZH/PHo9OOb8yM85P2Ifz6AszkMR1538L/ > a5G/Br > zo/Y5/zIv9KWmPPjG875Efuc36w554e81ZwfqDTnN8c754ec1qwdclqzdshpzdrp+ > YjIiFm7+cwY > Ir+ce+Scn56T+8eM4fSjMt0OzfOR2+f2JrYK41gwYh60+ > ZcilgvCaK1mzRDhmjWjXI5WEfebNIrS > mrOElOlRnbOEs+Usoa0SCJqes4Sw1GWOnCUklg4jZwnJK517zBJ6Do9z0jPrkeqzRIiXsWbET s > z7 > gWdi4zR5pr5xknYzQmd7S9VcN3lWas97Tqn9vCXyklsWP2ybAK4sqYkx9yUa > XLUhXtPWZVqkxfOS > 9LiCQ3Jsc3rghwbXfYgX+kum25J+cssyZbd5FUYQZnIUgZYzq2SOrZpxrT > kx4ZM0rSdv21H/racO > jvkuxBw3TdIKXvghqplWaJ6KNKNHvC6VtDofbPNMHI2drSR9a35RB3OBWxqY > O56uxfdaLbVejyeE > R016WD8fT4zHE+PxhLa1dDul1ueQJi7OkO8KtkzMyGceJv5pVP3KDuzzDWwzf05jcxfOy5kvy s > w5 > qr9k8+6qr5dfzcFY4OHg9NGWPeZHzS1RI8claSw/nLfslAn8fNl2f8sXj4/Rm/V+ > tWyUzt9wxE4c > O0vhjvJt9fyZWc+fmRwc7ZIkjejQ+0dloGDeqYf3z15hK/ > tj9D7HtOh9x30njXnfeTFbJpnmfR8p > y1tmvyr8+wAPrYOsg4upP/C1lWzeHIDrIAFt8BZUtt6x2jIxXwdZ > Lz5xeH5tQNnk2d5Hm4oH4DpI > QFvmCCqCVmIdpMQADlUJtvjRxRv051gHOT6FeFSyrQ6rc/ > piRlxQzZVkldP7hO0GQeNKMmNDjFIY > QtdWklVucbKFYg6/TpkTfG0NZzsnhN1M4mbCIKA6YJspTC > vUzk+o5QjQmBvKIY77yWnHzvTU1CA1 > NpWSuvsivbq4NtL0WFql2A1u12Nh3x8SX4gYOEDQ3CICc5bYzIUrlht6Ej0S > lkJ7+DLLyvJIuKcr > tLXabhqkj75EuGHblk06XElgISW2VULYF0/+1JQX7Tgh4WvkOOw7CPoItp6a9dD3Ly > VCOzI92Xdw > vpzlQT1aCvlpx4F82Mc5aljNWyAJexKMEmxcxghhw9dECnLZZL04uQVac2aX > JDe8z1oBBGf7ct16 > li/XdTiNlrk6k9aceLRA0hS6vmTVU7MQ4a5xqMnRFSjv8ATtTc1uagabmRps1kz > qz2WTNrzmXah1 > sgu1TnahhCtxdqHIy27TuvPB2YXaJbtQPB2KXSgbxPEu1C7ZhbIup3ehds0u > lH3dArfsQu2WXSjh > mjRKt75dKFrD7hA5vAvFN+xC8Y13lKxTHDzl7UKBR10o8p9HrwdH > F4r87EIRexeKstiFIq47+V/s > XSjwqwtF7F0o8q+0JbpQfMMPKLF3oWzNi3ehkLfqQoFKX > ajd3i4UclqdIOS0OkHIaXWC9HxEZEQn > aD8dMOSXc7fsQun5YD6+3Ii4UVdoy7NeGKE8O5Ga80xFxyVoeI > OBLL0Zxbx5QHrfElHpGB1N0dQT > vNT0Zi4pLeGMXOkGXukMmcNLyf0Naz8Gc3i0zO3hHjbrxw6t1cmy4ajBm5U6 > zsEK/NDAW+PxEGUS > t8ea9kMLRinf6C4x8bD8UO664WF145hrbFRT19XSUmF4QzTwEnnpvZVxyD1U > jm/SqNyB96yUycUn > TIvLEKjDuakbaagzeWnLyXpRaYW9af3EHkPWXLw5klpoySi00zJRaM3OqeOR > NC1jREs6KZOLRJiW > VvnrF5fu7bzJUc/7k5oGbPVm1+TYjx4n43nKY9DjZu6oQwpP8hwfelIY > npxeplrwwpOSSR0er87t > cbTREeyMI+xDlz0rOnOIZ3W2bPjSO3+bnUV5fidNixsbP3xD5kaHT/tY+ > FVS15T4qPzn0kWUNi1d > RH22PHr6g0vSnNjPTjslk1hRjrso13hyx9zpubPLW6tv7CnSm55y9xNL2wc9 > 4P29S5RJTtaJY2VZ > V+eONCPL7XZ/zwdjZ/yJXBc9PLOn8sQ6m0t4R7qIGHb/GNF7Z6Q7Rvd3Zd0jPYln1gWeLnh92 S > Q0 > PTgZnF+0U0/kyWlZ/x9v0Vi37ilXp2esHvkXvF15bjJ71rD > C8IRoYP15WiinZik8PizAX7h7USnv > sKFxcaHn2i0r9Lsl4+fcjLGjMgb9vKaz7uhRC6o++CQNurs3PXyeb9i5WauyNUpeLXxEDnI > XPeU7 > LitpsA+vZI3vMomTxnWA77zeCZ3dX7dly8X33evNavnmKWN3ej1p9cq9NeqVe0fUK/ > ceL8WzqOYu > tsSvdK9XAtuCMKexekW8qFckc3OBpiZkbGdv503jX2vtEP/tmJP/ > trXbl37gVCXuqW+2yk9Tbdhb > 6MtA6pwPLkkzdvKOnjKhg9Jyfagd7inldDkxJ1Rx3hJPCWq2DV0TaK3OnFiz > RnHimTRIWbxITTKB > UW5lvU+78815fHQeHyFO6COecUkfaVINPqqc2ISPeKoQfRS4JM2z3AOaukzooLRcn9S > uotNPjao6 > 33qDqBT2hRbwX+UUMc+NVIrmS56xTg15s3mruLFUkTHOgx+ > a0ZPXUnOZSJnTwtRPkwiecmreMt8H > z4D/5Xgoympi6DpG6joyBtgPcfzQ9BLxw7MIMi3gnRhndrbMXeeFpn08+ > CbNyAjwW+DkDZzkIA4t > i5d+5+abc1/f6E3eHuUcj6VcJkAaRTtPFS1pHZd80Drh3ZMGmosXWkgmNWpJcx7PpKZ2S9K > Ti13x > gBPqubSRp2cqHnDGvqKauLyS2u+SvvqxzhwLsPjzPnYdORYgXIlzLIC87 > P/XOR+cYwF2GHLQrxwL > qCvHAsx7ke7KsQDrcHv/v+4cC6gnxwKsUx16nhwLII3S3e9YAK1h > v54cPhbAN+zL8I238+vKsQDi > eDNyLID859HrwTEWQH6OBRD7WABlsZdFXHfyv9jHAsCvsQBiHwsg/ > 0pbYiyAbzgWQOxjARYlPhaA > vNVYAKg0FgBZMRZQn02QyGn15pHT6s3r+YjIiN48zgpz7pNjAUxD3CfHAoKe3Ce > nU6HheDykqVVq > fh+p9/XPcF/n5Cjs1gQnYnp4jObkKGLU8c7JUcSZ856cHKVGPf2nyVHSsD1LXrajKZOTLUx > rrtRB > eOYWSuos3pGTwbRRabm9j/XcQkmN9o836/Gqb6HEL22hRCra7ojU1b+ > FVtoeCW3VB4YVjnduoYTV > zntyCyV00hZKYtUaJ7dQkretlPnkznxyzfHMLZTUWbwj+ > 9u0UWm5vVnStIWSeGadpm2QTG2pDtyx > bZJnwDl+aEZuoWRqM/NKWyhpvW+hVMo98i22UIJncQocb7TFkVjWoV/ > tcZtbK+G91TPetJUR9jie > M2lmS95xUiZ0eDy56qv3Giu8t9xjmHrdmdq64T1ta+SZcY4fGqQsXqT2eHJ5CeuOQ4uZNf/ > ab2zb > xQTx5ry15brpcW0kxPPd3tqE9z0L9/T+D+xLHqCLvXGP7PHm5OHEMXHJ+ > uv4qAB4DscLiOt4+Xtq > fPr75dOkKN+srCd4+5qe/9DllkeX8+jy4FveL+U5j16+qdI+ > 3uMufXesJzblSeuJqfbC2WhTZddo > hsr0SYwenWjsBjLnPTdloi+9wleLG8x+OT6KuBEb1Xj23M2v1L0rNXJckmbkJj > d66WRcaDMbPfPG > 2OSNG3gz/TYNvRkt34yQO0uNto2wc9QSLYXJhYmwYpYbdV88x2Y19rt5glmJGmvWEt6Yt > RavBSZP > ZkUrLPFJmlOT9/SUCU1vtNRCB5w4J922bZg7bk3fPDtNkTF5zA4iY3obkWewDY+ > M6W1EnMHm7cWd > NGck77kp8zY/p+1rF98drd92V7R+sRJYrUrHlThav+LlJqe754Oj9Yv9IkF/ > ovXb7AoXtX4bJu09 > 3ROtX6zxVYu32WCDt35tEMJbvzY44a1f4Zo0Svc+rV9Zw5YsOdT61Ru2fvnGl87eE61f4X > izovUr > /vPo9WBv/YofrV9htX4lCy0y4bqT/8VqxZCfrV9h30ZB/pW2eOtXb7j4lFitX6wiV+ > uXecvWL6nU > +oUsb/0yp9l+ZU6z/cqcZjvVn4+IDG+/Yq22t36RX2r9Mg3WAHpO7h/ > zaKAasn1l65fPy6P5faTe > 1z/DfR2tX9rNFixjeniMRuuXMer4jqS52fqF3mr9UqOe/lOLlDQcFSLv7CmTy8SZ1lypg/ > CeSbNb > 8q6TMle0ftPex3q2fqnR/vFmPV710Tz8YuuXqbClytTZgqVWU74 > /0fqlFY7vSJqbrV94Q61f6KTW > L3ErSdN68raVMp/cmU+uOd4zaXZL3nVS5orWb9qbJY2tX+ > GZdRpbsEptqQ6M1m+7uz/4oVkneddO > mStbv7R+1FcLtn75Rq1f8qj1izdq/RK3Ht5bHrfR+qX32LKl91bPutvxnkmzW/ > KukzJXtH5Tn9Sb > rV9h91i0fpXauuE9tk3pvcAPzTrJu3bKXNn6pfXjrXnV+uWb/ > ca2Wr98c97aUq1fvGHrl8+99atf > 3I5I3NP7P/Acjy5s/QoPz0nztDbkwtPHa+GYvWEaXPrjuCSNNARvya/ > zKRmlbEUztx1jBsXL6IlF > iYgayqQNOvJCOL/Irht4pTNk+oZiajqyrXFGxtMZWUq19Zea6vsPTb0 > tMJIGqY2sHShT2o1H6zmS > Zmab4qyaMle2QXjUhnQQhm5evlvywpb55MbMrw918O/VLT1i5Jys6/ > zQjnavlmH+cny9dYKWPmdT > iHt+a+9TYrU5GGWI5zWzDAV+aNCrEO/aKRO4pidjOxtTRnTqTXf9tg7M8Ny9+ > 5G1njTmybRnevPq > q2VeDoweTU3bRA+bvQZefmAGW5KeLnpDW/Ech3kw13WwB6KB9LJm5Rebeopm5jfn > judbqf6MLDsP > d+Lo58h7OApROHJ3bp4HDVnVD+hodnWhDvRALuqgD+yw/rC8cRLfHYeB2P43PwzE9uP5oR+ > lNj97 > +i/6b5atutnwVT0xvBcDf0/eBIw8mdruBY0Cl6TBqdc3SkTIBN4rP > bOfugF9LMWV+lvxBrWG3oyU > W1u0Ed4+zfWjK2hFU7/k4EiLiI6pWSThpKn3hAfqnWn1jW974 > pY06Ind+BaGTOKkcR147EX0mXQE > huupPtByGkSieGkxZTqOfo8O9EC0SjePsKbvCo4q8bJuKaj3ZfnZvMYFzYkI > c2wR1rwnNpyXEUaZ > jLDm9b4d3fV1GdBLAOYZ1M0OKPEZHTtKRDe9NTtwqPPM6mbHWCeuSdNK8taT > MuthWoYxh6WDmETF > zZ7kZquFz+mLjluN3+da/yWdcCow5Xbflk46ftXsH2CkHnc8i2O > 2B89XLtuVxFqVI+8cyu24Fa6n > d7iJmpgbP0nDdhJ5ORtnnarOM7ybdaQS36SZDy/0k0xgpTUfHcB79uuB+/ > jGazXmtt503PScNgyP > AtxY18KGUWXPNrxDD+K//BeP4kDa7KPo+c444NG1er7643GeHc705hONU/ > qZz9Rfgc8C36SZD6+l > wPO8Ha+kwSE34m2PTLaRmJYwdGjpC+elzuvB5fH9HCWijzezKOWREcczbB3f > 1xdYWSU83njnFipp > smZquFpqzu3ptMjxTZr58CJttt6J+UUmjfINvDykhTLPkyNeAmbS9IcXOu+ > sQ3xDmH7xyB6mrDFZ > ydUbyL1ZmuZN7y9FADG9VDvuEEfpFUZ+VbsYSNiocBt5vaAC1ni0eNCfE8/ > 88QYbAvUGY4V6jvao > nmv9HN/M9uhyH10ePLVhWrrc1Mt7u9W6wH1gbL3atjyV6GoEvcND2LTSuSJYGKtGRHP > 03HiRO5TZ > 8b2vE7X6Jn0fD75JM3ryjpUyx8m0gKUDaKQbeKWzyRyaNaCmg16CpqOe0JTr > kmU9fEFNR62haeCb > NKMn71gp07QbrT74JA36z+LtM2X2nWmhjyMdHJekgc7ihS2SSRvP > g5Xj1AL3MejN6qnddB910w/b > noQ12onNRx6VwBzHqbaxsHPshtpOeQk3w1dpdR780OAWevHWljJri6infhot > 95QZnSOk/iWPzHEi > d3lqtuT2Jw33lNG09CbrYXo5MOrqmbaJHjaj3VBta0znKE2dqDlGxjZr3mq7 > gqCb53rglfSwRnoS > t6RRuuBt44nneWrk6JwP94tPfb2HQ22EdQwENu7959WOLbv8r// > lj4qjRSaOJRLWeId+9efN/PFm > PW90l0psvqlYXLXQKKi8MpSFFgvBeCKqMKp70bAiIC8rC5u6STwML+ > KZ9LYsabHiwOWz6wq3THcb > 7yXvlm6GT3/wSnpcpio9gaUnaJQueDWwzpQ3JquEGU5YwLcZQtCUJ6jSGu4jrXYHdeKZNLw > 6Nb3l > MoFZnHgZqC7M0Rucn6Q3DDriucMGLjymDXvJR9evHqW/9rrh68AlaSyfnJdXnrbUTmm5Po926 C > RI > IzXc9QYTqsSnBM+2y0FHRBJPbhPVSn8cFgTSzB4a8owjah54GG5hndMv0O+ > IpOPeaJmueYbnHjGS > jqLz9AevpMdFpyujyvUEjdIFrxcvaocBBHHcjBguMeZzLp3m8+ > ufdfjitvQXL0n158qV8vvz8aTN > oR+loQ6e6DyyKrHbcUfax6ET4dleuZ31AXBaa1efHsq1vLgqyaDyEg6c+ > XXXibJ1V5bwy08d8sXx > 6UkDXcXLa1zbg7N0uA7gPW/03pv5ctXtZqz4my+pryUScTZ4QpHjKFGj1OZxNrhgufKSU > g3DVVvZ > 2hfOzq02s9i5maPiYt9FLzf74HLwu1pfvC/mivXXA9vyUacZN3mtkewyUedO5bWty > MXFzpZyjVqu > 2ixk54B6tVtWOofpq6141QXR1Va2Jr5JM3ryjpUy7cPFS6SFz0iac5KXtTpl > 3p5pscamDo5L0kBn > 8cIWyYSNSsvtTeut1v0ljVQD83lZoeku68mpzS4CcooD/ > cwpbidhTu1ZI6e2PN974tGSZtzktZxy > mah1NVlUbSymb2zrEfZohbanrMhDDvvTHzxJlH7ad4f/tvxnfg18k8bywXktf1ymeeM8nuGpq K > Kp > K3gPu06QyakEpnVaDx0Cl6QxnZ0XtkgmbFRabu9jvcoOcM9oO919ZE2j0+ > k94PHGwLkl+RXR4Nd+ > Y/FgIlX4vPlyS4188ROxGSuqRxErvP6RscIhe8bKlcYWKzwdm7Hi2GLFaSxWnN > dixWVarPhWEtpx > V0YET3+jd+/MiODyIuYGt5gwlwLfpLFcdd6xUuY4TCvwbkmzMyJ4Yp1knowInjsqHU5GhNN > A550R > 4TJho9Jye8P6UerxUj24zEhUN6Pj3qf+HTy9FDk1eGFk5WXYfXlODZ6PjZwaRZ > 7HldzCdsq404yb > vLYQ2WXaUkA/N/X3RjquvGqXA0B2UDQwhjasxRJv5o83/ > XnTnjfZSDfl28DoY4VY3h2s51ufT3s+ > bz6f3tS8ducRKxgbgG4cM6t2snbTWISdoP1hOrrsxLUnjR31J16kMMtKXGvS > 1Bm8s6ZM9liYljB0 > EA11Iy91pszQn9aYnbOrcFTiSLmf1Gi0B8/XF5jpFR79fcO+ > EjVZNTWcJzWfKy0ShqWigR6rZtpr > Jt4laXZPXjZpKHM/ae2TOqjZA92U59B5l8Trh51eLR5iFZ > Z8Q7nqhEHufbyvzpbhVfrj/bVbRCL3 > sDKNFU1F3Iw3M42l8V6mvrDeipiXX1SbMHGMQrT5wYJWu6SF6+ > 4HJ40aC0ztzPCguoPwrGPzuNNY > TkRD44RM4R000gG8u4zHmo25LeE+05o+05o+0hp1Gc2C3e6De9I8pWPXHdZslSyzZj > +lzGmgacsc > kUzhLMXSgbzdY8byc+sjCQ7/fFIPvqF+a6TeK3OHO2NFo24beEfGNA8Hlg3C0G > Nk+REvtZhZfpQW > adZI3tS0/NlKUdN/G47ORfPG/mdnvRpiAD7Xaeo9er4NywI7i+ > VEKan+OSvjwTdoTCPnNU1dplng > aRHfrLnKE1/S2WTClsydwrFS1HulZY1bnnzm/krhHiXy83ypK+q9ohkz/ > VKTGDzRZC35BrnIA7+Z > u7yCwrkzisv8oa83Yg5xvql9RB3C2WVS+UwzU+QctHBbj168hEJYzZdSA6PU1ZWlrq6s > Meu8D35o > Ztb4dWSpqyNLnWPLJ6exHBAvbZjjwVnqpAN51w9rOApM7F/ > hGpjWKGJvXMMpC25+Jet5aE6Wv5oR > i7TCmp3lz2mg6XlyJKPX0yLNzfJXr0eT5Wfr+d1p/f0m6A30ay0jqLXMnfa0Bpq62+ > BVC6MMv0SU > Njg2PdrTChEvtahZwzcvKyt0IK80jSPTvqbujZNhgbVUYMzfsJ8Gqzc46uCl > cqH/47/7Yx7IPrDb > 1m7GGNxrOx19Nv3jD8ed13d287IS/JC9tyEWPv3SFCUR+YEh1SiZkqf/jz/ > +23/62pj/699Kpf/7 > D54O1TnqOmPjxn/g+7/+rTT/N3Ym1s7ImcQcMG9t35/4ZyCvnoG87vtml7QPp7/ > DEhvUETpp3zpu > nw3cSNpO+/jULCElUdpHqRjaLm6fod9c/u+hUrh87qw75n4diF/ > S1q6qpQw7bI1yiZiasC61pV6U > Rm3tKD09va6tEPmvawtKprT/yYH/RiqlA6u1GxmBwHF56PiBEdfm2Is7mv > mBwVXfI85yblmXGP5q > ffuIg6F5j2nYKRqFfRZg7iuq9ujFyWHNHtwz/ctwJ652HEazT4DQV3f94w/ > hr4coytn/FP+H7P2c > /nRVpwQSPzCkghIpefqRkf9OKkVNjtPc5X3DlYvYcZLo8r7HR2g3RNWFGQ1Cv > 2PZf9iZoPd57j/8 > udqH8eNXivxbyizPct2zHnmp9D8rna/5Tpz48T3HJer+3H/ > 4cw3Kx49fKfJH+oxRpO8hGulzMQSh > 9ofED6UTz/2HP9fAZfz4lSI9/a/9hjEfrbcS/lt4uzZY98PaH7jxKM1qE9XCf6mQ3Zo > F7uebw0HV > gctTCg5ztR4cz6HFJWFWHzj+wgyUdjGLpKE+qTblzae2zIqUQuAnNqmgZEqefpaMfy > OVvGRUm2Bs > i63FYve/8ORV4LpPlJJ9fisle0d07/uUEt6DhgIQz/2HP99PKXnl7IzSVnBxz5ViwxX7y39x > RXzZ > m7jZ4TsfzXS0UNMLW4cWlNM6geCf+FLY5ks9xQgOKInIDwypoERKnn5+ > vP6NVIqctdz2AgTcOVhz > rSX74vIWGbRrf3L4m86ZXotHYMRot5WzQnV45OIoFlGW/qf4S/ > fI5VOLUVISkZ/YpJISKXn6PwvT > v4lK7nIOxc9zbcuJjZlPDLhzcp6Y08kTw/IcJbDlMPF84+qe/ > uCTNBw5nAcXrXHlzzEarYi6/cEn > aBYuRiLv4tVD58E9aaQDrxuibhdX/fjKIlvwUBgeaIFxXAgHQneeAwbLusa > RJi6kEb4raBavA5qu > BWQm7kmjVXPgbS1lah0W0hKGDqKBbuKlzv3BvqbNOX790C7s5Fom6sSxJT5f > 7eGvhSvLrBWqESRQ > 1brDoqpVyvrFaUZScXaAz30szIbCcUnML8fTV2fe61fy1c7LorgC1D4QymFb > 5BfX8OFN1zSWvXGv > kINjJ+TwaSxSYe26uDm+NHBNEkdviX2MjVRbHN1PPoO2uuiu2s > LuzrG3agu7A7eaNDZ1KV5qwXEh > YqwZEw1Hzcl7bsrkuBDTIqYOpKFu5KXOlBn6h4/B8euHdm6nxgIhi/ > v8ycELjpg29/xTJ8cmyWna > Cl7YprgRnknDsVXyMsopk+NFTIuYOpCGurUatklm6J92Vi78ebSL > N317lH1Rmn6qY6Wu2kW5raVS > sekJkD62/X6Cf/1h92Djxy/Bex9WxKed1dF4l5LN3TeeCmBnfjQaB > oEVEUiI6QMSYDKbbBg4pjCU > LiahLeL7YozR0rOWRatoRpMEC08EwQgCTFyTDQOqdsOqoO2SxEloBpvT2h7J > VjFFcDi6CYXK9dRs > syQOOHM1d9pMCJN22rzS5pU2z7RZW0ihfMOOX9pxkjFh0xZcZAQvSwZsCgBb > 0dZ4jt+xPpUyYtpI > MOpXW3rWuLXKVkA0niJBiCkmEjBPwIbOAoUxe+YJuFoQ2AeSBz2ck8FwIiv/ > 0g80s5geplz4VOvk > bbEdBrx/CapNSbOwmpCa3Bb63dQa49uUjRgF5EkNIOBAL9joSAjjdiyYJWhmicDab2Jb > GCpGwqZb > K25W5Y9PN4xd40sEs0TNp1DTaSPHJ+okQHakkM1DjTrkLTtbgLM8wTJxwAjC > kPvdEU9c2owom1ne > Zh8JdxAgZ8g2Iqa5aYRJaP8IytDEpCtK1txR3maWwrm2F72pUohZ7etFjxBF > b6qQNadF0ePs8+Ek > 9vKix9RQ9LjsmWqetJkQJu20OUshNSPBSpvnU5EtTG3RjpuMCVddmSfcYgK4 > ylGMIq8Q3hNrHoaH > IJc/ICSGKk885zICQsw1INy4/B1B6E/N8noDskpdmcXLVMLyErukAUu5DY6EN > whOsp0RwgCZxMmE > LVyljvV2/BYqUuPqQSrPzMRTfVdQRCaOBSZc7iWTgzWgcNg8w4vkPFFQebo2ZaMxIHicg > Nt3wMaV > BRC20CxFSRY0H4nAXCs2K8lcqEDdtLiT5mJtJ51we5hFaj7d4RpfFbqpHpp9 > wEvre+pmFD1vvEG5 > B+xAYwVUyYPlBdwQsRH1nMTbjLweODhwvyxHrOrCwgZuF9HzS1x+ > f64JxGXRofTQNVV6C7HE9IBT > w68d3DqOoxH26TtbF/Dzje6epPWdK01JFTw2yNQXPWETbJ0r > 8OxgZsgKHBxWhfBOuYrxX15Z4M9l > 4/n9uXILN+V2HJ8lzHWrGGnmdspqJ0a0zulfjEVLD1vWGnidpFkree0GcpcJrI4aaLZorv > mGXSpb > ZuBaW5iGnXZKtu7Orbcvv8/W31wcl1NtSffzBjfF4ntEnusRd3EDK > 8cU7FzrxuMB6kVnkgs6LjqT > XGzCNLjWkHiMpBk7ednFokxOY9uoXuKHxipe3mUu7RiRxL5d7uLmdC6lMmXU > jRUVl0PpObVwetmp > 7hXsNG+cljacnZJ8y6utDGxch99sZSBwvuEQZWvIgXjT7CZkbjUEz/ > U5xYZbbHk4bYO93AKKeTau > v0dLo3HFvdLg/bTEfSUNN4CSF60uyeTd8K21Bz80HfmI7cDUjsd5EPvhJG3ofnvYgBxYSTXFj > efU > zukfO/dj537s3I+d+7FzP3aex85zk/c+dt7HzvvYeR87z2MnR0CJvcQ3G3g4HB > Ro2IHROc1vgxBH > U/jAWnkMGk3/g5eDHM2mngLbamYtPLkz6S/o2b20gZDTcqun0u02o8FjDKuNV3Ue0 > V87Vjw7Xklv > q4SlJ7E2poKG6ZLXB0jszOV+BhfPwALtBICVc6Sk6YMH7FTm+ > GHxWoi/0NoU9u2XA4eo843teetF > hzb84OEb1m9jPthpfiya+KdZgSe534c4a3sWRzxjd2cUn6Wxg2V > a+ypac1+zTEND0sA//thYLvL9 > 2WiYf38IFu+qOyMmewIKjD//p559gWY+/CLxe2lfSQP/+BoIixC1jlERYOpL0F9+4H+/ > Lrg5yYS6 > 1ieZnsmn0PNfms9JIphvh4bBfJtnhvkGZL5BSDMqgl7SfIlxSPDVVTLf9szC > fNuSC/MNyHyDsNCo > CNp1801agH82n+nCfJ/jeua+Qs//yHzO6trBM7/+wFbk7hXezzf1X74xHDdcGN0oPAHUpI > 1y/M3+ > +ebh8V+ezg9p75uQFubnpPTvqvyToZiXltJzvua8b6wn8h+/ > AQ7VjM7NmfM1NH55OsETvzydH9Le > N/+Bob9Pq/9rQzEFLKVxTXiY875Z+1+9AQ7V1pNvJi0NjV+eTt5z0tOctX+ > X9r75Dwz9fQb7Xxuq > /W9Quv7Itx9v+r98s17V6mNOffMgf3k6yfPkW+2/S3vf/AeG/ > tOiq39lKFcRSenylsT3zfdd/Zdv > ziMddG5OeUtV/vJ0wpySJZHp/JD2vvlnQ/95QdS/MpS9h80N2oG9R2WYfQRbsCw0MG1F/ > LUERYnV > DuBH9ZyY/TdD/5O9OSw8z/TWzfQMU7J1AYVOpmd7rkW5PT1Dnp6e > atb5f7LH17m4/Zf6tIarrctu > tmtOiFNxxM2u1gSlXR+LvuDGdyGkrUfaCmkrpO1H2glpJ6QdS > QvP/HLJvkBh+aKEeOPzqOYCzalX > 2wodU9eUdtizog/Gjx40W1uQFm/il785Gv3LX78eyT9bQrFa4tejMJifi > f+fSv5T+B3sy+EMDwbW > hmUxGwHbLvjE/pxtTZZ6sNoDTxv2C9VAl+8xmGW3fhqljUaS35C99zHKurkzaDsi > vzBuP7WU7O7W > 0O8fnD+zQTR2a22gpdnpQXWxDQHUiSwga/Wn2K2EpTpEl+8N2+WtpBzD+ > VnAmJY9xUwsKInIL2zv > 0fDADLLrx2C9sRaGWTgiiO6IpWQr1575iQpDAd5iJVpy/P3Q/AyHZ+ > nNlwFvcrFa7Zer/S+aRljn > //WUcRBQQZ/KBvZsXT+qsVYwRoAaATsKgKvNMILSERuIrZxH2 > glpO6StR9oq/nQOp5w/pJk7LsZh > Hdt0k6P/7U8tim1fQkPrEKvQLtbFYE+BntoQLCmBEDKJOU6wIj3HtjdjRXrCx > ezeSq/awILSw74M > Pb3dKW+kl/jvtE+rddzW0ATdnF+PVuTBggEMtRIfP4DjYg8gpdUSPd+/ > nl/xxqXFr1/OHxr4r1+P > 5N/Cz5eb/HoUTiXf1T7n/Ivw6zZie3m+to1+tevnaHN+nG+ > sAOabga683uzzvsE8Ot/YcSr5xq53 > bwfdT4xaN1ZYNm9gt+dhwyCQrSe1nhGfokpuy1FH4BIPDJsb > 5bjOP7ge1epSPrW6jJRA4ic2+VjM > BfmuHwJ/8nY0amsHDNhtZx/C3WiFm/iAsDp2+VPMiduYFNFgasCWg6Sc1/ > kntbXlx3yKPAQlkPiJ > CydjJN/1+wfzI7W1a1Op7Ziu7Zip7Viu7diuLRFTIzYdSGl6kZ/ajunajuHaEol/ > uLbWe5X88WrL > lTgjl1H7jiZY+r7JDbXWJfY3WJodPD/e7PHwYIXx0XLtgcEtFfvZn3SQJm8NI > +b5n0Gj6B2/pUIO > YnGUl8OOcPd4793j3U5AY2TbSWEe7314vNvhhIxHIsYrsZlASots8jPe7cw0 > PW0e70Tibx7vdtqj > 5Lt+yJN+MoK4gqNXjs8zVmz8OyKoRATViKD6RFCNCCoeQeRnBNkR8Xp6PIKIyC9cOFOB > lUOpH7Rt > jH4Oc27XtkXpbE/pbFE6W5TO9pTOFqWzRelsT+lsUTpblM72lE5iDGkt1zb0+ > 0fWoyO3HEXs9jN+ > vMnoaU8ZaT/KyI8390fE9Yx3mw/JeO/zSedk9BLPODvwjd7xWyrkIBZHezieH > Va+7NiXIx8/xPuf > 9l6V9Rjlb2juegvxu2UgpP3Tbozgif1bUVnozf4PFhU2O9/ > vK1YYccdSrMEjO/l8cocSnvPCSz7v > uQCbYd63PpR2hKrN/g4ctbe8+jWET8/WUx65VgLp0wVsE2WgnN2rX0MofFdPb > TqLlESqCoBRlRwc > 0df/TP34sTii+OX4PJWcvyHWRnr94qwEsXime5SuxOms6OjyO9I1t46mc7fi/ > Et4aOXUyv1Vzxa7 > vlI86SfvKCTWuY/J++5qmv+q2z+spO+m5eI2WIB1rbZWUegQYQWrP8UJdttWq > BJ1rWA1/NWzovyc > L/7B5eZWx/EphiWMkqhrBS3StxW0NhVge7pTP/RkOo57aVqvP6WN1f+OUts+4+ > lybYmYGrHpQErT > i/zUFmd08ml3bYnE311bnBmL4YLQD9oOHpqinTaFmCvhhDqR2d7jaQfXcsReIL > ENvpDSBmTIP+nb > Ov1puU4JJH7gbr7F8SLd3rt+1BYDrq6t2Vbmz1rsn7YOdb/ > q6Z82UnS/pOCfV4j7m2N7Zop9Rzjo > Vf5cfm9m/Pj1B+4JiBf5S29+vEhJ/th26c6OZRz2aHadRTTuZ7pegDXeVL9 > Dhhxx8Qs49AIc8cY4 > +pN0qHR5QHTq+mqFbUbkAAwOvQBHvMHu/VZ1/j1hcOgFOOLNF6XHxj84QnzCI/ixBq/ > sBo7LSu00 > RXIA/nguDuKwwz6o5AD88VwcxPFm26DL4KjZR9Ji0QV/fFbYZHO8yF96U/ > fIFynJH1+r/L5ayCo4 > div/nLwO25a7zcvznldAC5wR5LjRQfS4mVxUuC07OGzqd3DK0pICNPm4dQGTw3aB > Pc/ya8+9D4Ar > CTjxDDZdTht3uzVeGa4Z4iDouLLBTYDmDrUYG8pIObyXdrjDQuoNa/ > 9KP1gpBYXXQ7NH8m7SjFAS > 4gLPkTQr9ITnpKiwNG2YcuYtBoC+BsCP2CLkAelt+3QzTq4SrUX14TICzj5VdlGCYGLG2v3 > VdTsI > IA/7BgHP0p7LT3i0S6r60Tp9OEV6CkM2DJamwl2OCF3HWSXp13UVce1G4NOTBpP > hPRwnjYXrTJpC > R59QGvkQWpuNX3N9ybmAaLDZ+P12mDZi89dZbqPokYdiIA75NpS0Z5X > 8ytNXLJsqa3fLvHhqBL0G > HEmgY+pt5Jx3l1id5RqOgLY1UwS2N1NsK4WtTAIETHiuUMdqtq31RTBR2gu37lknBm > RpPm8uXng8 > NON4VktHZHUNt83EpyfNucl7H5n3SQs00uGs1O081lgVtytzYvy5eTn1lyec > TSEaqnOWLrvufy6t > btl/8vRaiwehGW8/V4pjhRSgpbdsIBjHrl4MNy9K+ORtv1bB336piePLfEkBGq7L0SHorkF > o9Rfr > ZhqKyomWIv9oquDw2ovCUPdQGvKX4hDNDk8SfA53tpvCAJcT0ASw0S7kMY2F > XIcrCeYOtjlC2ByR > xNyR8Ep1QsnP/I6ZFOtEjMbTE4wET7UyZWDwA0t1CdU2A9HqmFoB7+ > qMQT5Xnw0sq6NzK6xj7HvF > QhTe3rqx/uTPvwX9rmRLrRNiD+Gfuu+y+bWyJeBIAhuREVu/ > IczGIvxpD1obNpUEmw4QxKFWJMBi > VLJhLeoIqE1PTER2RHqyD36QgfKJsC42XfDIchvlHRj5+ > ba5lYHHQzNa8vabMj9L83lPeisKLqe1 > xHUlTe3JC/0l020Ji8OyTBkrF7fC6YNVTqw2nsGwqZcL7wPyRCQQaKUlxsK4cNKEaX3kwF > 56wFUS > niCwsUGx2YZDCcPpEz2gEj4l1DE2KYlou2nH6nu6IfIVFJV/oP/ > qadbqWuMJGqUKXrfMZGptKfJR > +q7y4JM01np13lNSptUsnhawdACNdAOvdIZMXcllnUwG68b5QOY8oEGEPQSGj > heXDW+Z1L29hNiX > R8gGQvl2eEnZfbsUS42Sla7roPCxpGU74WxSQ1aZHjJq074rTWSeqeJw3CAY > EccbbqcwJMwkXAdU > Ura0ildHDKs6ObE4Nm9aA6y4xBnQDr8UHCUIrNEqtomrhx3OEgS8kQJsHFaB > MN6QgiQc4gIoEJg6 > YjMlJcz1hfJO/etVSEZN3HtAKWyx2/IEntk4bH2Cw++L4gTfd2bOVAlLj3E54NzhAJ6riCv/ > uCeF > RjlMArN6z/DFWgFnukUJj1THhLEhiyQEWxKYOux2QMl5QvV1wyAlXFIdM54QLtnhTWnmPg > sHLjZf > EUQn1ORBiFB+ncj0lYYuaWEEqwfbIq0Jm+HA5d1003nj6D04YGfgqFVikrdiyKCi > xQjacb/tvh5x > neobtT83szbjAs/dXNDvpGcbYlt741D6sqWSTNMaJGzoEPaUcdiaShl/MQ/ > O5fMvXA9WLw87H5IL > 95Ed50Ye8P5xwhoE18vE/vNmSeFo+TAfOfziwAm+VgxneaHQOeHIq9qIieBgaSaiwDTJGW > FXMfqF > oMPP107w/eNsJllFBjAJdmQRD1qnMKzBZxKCljAJoI6Ha3Vhrm8Ufp4p/ > yik57UomGwAp9TqzB+O > 2kn4L/81VAkaVaaMs2447GajaxcX79j8Fc5890u++JzNAkB9c/DD7jC253ZTPK/ > fxFPe/2aXNr5P > tc8P44CDnWRLaPgN6yCCqh2XITIbdJ8uoV0tewKuV2Ano8FVH4E3LBrXLcJF > dhjtAlxU1y6WE7T7 > 5thGsmP4J9uHJpubBwnhPRLwQmXLSm5VjCQMflW3wztFALPIBt0ojBBJkEAJ > G5sa6Ez6UvmF0ajQ > +LZQ6M5QU3dUdFy1B0bKPjdSvC1SFKNoEUNtbD/PdXBYAHtHR+uxEE+ > YsQ4aXjJCXh6bP6yhFnhh > Od4g7km/lp9IO9rufuLtsNOTIl0sgONgW7OtTjzzdbSbuJfUs+PE2/ > tg6gkaT5dHmKjlAGt4DYks > Zp7wOSa0hi2D//lcJzDRto0TC5je1o5TvdnsmBnmNgdR7dTwVJeFRXQDMUzMrzF849h8dtx/ > 9tz9 > ailgKk54nqRhkbL2XtOwX6TlfnV8Z9DAZ+KlppRJvE7SSAfwnvrYfyutWVhcdMMC > fRL4nJV70JMb > Z4iQG2ncJ3/Fzefidnof7B12tZ+WdQ7MG/IKhGHXc3nkWF0j/ > JdzYFZfHP0mB4dkyKGj94ddvoVl > nb/8zf3xhoPHfLO8v27SjnrjF+t54GGkyG0xw6YgA3P1D2m4/oeaVNu+ > RQ0xg3mkIdb4sCM/sJKC > g0xjlAc/NAPz4DWsO6Ml5oATaaTDeHSDTOYA0xJuDw10Y0UonUfaMmbaKB3Koxt8okEJ > +Io09CH1 > DH/S79Bu0+/QemdOH34P+fzUtEbXaVDWxbm8wiX1VosGesdzROB > I/OTTle9abEIcXBfGAb2RK2aG > zRwHjWnnvFjI1jI/PC3QSAcuGWyZH+pW4Es/7GNTGxtuy1a2NrXcDHe1zGyotjMZ+ > yjUjr18w3Yx > 184Pl60ZqJ3D13ZffGAb63Sar+4L3vHINB2UVugDh9uXrnY13aCRN4uY > Ht9Yj6ByT63S3pQFbjbf > he8jd+CwG8odOoKOsvQGsrhmQRwj5Q6GKWlY5MjLoX3ox4v1hh3jGBhHqbUafhUvta > BM4pG+dx3A > m5riHKmZNtwd2vHCTT7n4Ql6ruME9evx7EzP9ngD63jOgDgeb6rVQBq27MnL > zyuleh8W+arqFm+2 > z3bCa3oDWbyynmmoM0TsdhiNogi8irQNnB53fGfQLE46pH6SSfxEu+ > sA3tTUtNiPDfSAbXmvmw2V > ZWsPNj/AC1ONuyTWIeyUdHA80ysp3oz0Bi+RH9Z9rdyDoedPLPrejGEb250bdogba > Yibz8Xt9PFZ > RLm87BMTD8Vn+w0fj0PbMnFxiaGwN50sGlopjCRgTnUZVSvKHTurgAeqD7sTopXBaLNFeo7HQ > 2M7 > dJ131JQJXIbrJ+zVnPUoUSV530fV0EIVVh/MjAdNu8I7qsX9VJF2dAF2yQL3oN92o > n0vGsboUc1x > IUnTsNCNatFi06tLuxkp8Ew9N6rR+mDqCRpP13ij6qQ1LMbkiB4ldNKbmtU > l7FF1KXzDtn5X2nMf > PWKQql1WZr8crxkcjs0zY7WQyhtYmBrvkhX2QSuj6fLq5RKWv5+ > 03HuOzQNOY55x3pkVKrHSAo10 > AO+arzV3hDXqn8Eax2bNbOmj2VZY4MN/NStj0pSR1ijfPK2wRhga3cxn5zULXC > bxTRrpYLzU02Nh > suLiMqtdkmM/Us8j9cQwEz4VHNsBPv15s+qJSFo183nVE1avliWGz437qzOCe9bk > ttSdG8/F7fSR > dvN4wx4fH2W1NX4aEMImkhqlLPCYSTNr8mKjr2IJuJ+kGSN5Z0mZiiWk5TF8k6b25IXOkun6R > w5h > 0fyvwDGa08bVgJVx3EdT75VTFtbTEPs5SvjscsAG3wCOhxPO+ > NrxuA987Di4jpYdh9wHT56Odp1D > XOMWrTpnGylMI0h/pw7xfRtcDGVaDF8lZV9yPbdkRl/+dRv+qTcY37/ > hDYOrQSMoynElfP4dXh94 > gqmjxvdewghvEChhYwvdbOzo8JOMpSjxHR0nxd0Ud58m2sA5LIQadIKqNvbz > S5ADyBODTjLLBp2i > ecVLlCBjZnN0+lfTBp2Ge2OqLbp9/AnecIhBp+Pqz2xvShjgDPs8YQw69TSKhwgxaQYk > NL4RJjxh > J2ijcSJGyCYjUrzROnNG0Ua7xHrn2I6lAWZgfZw/rHFlaxucGENt5Y7AtSRN9aFSO3WNXS > bI5GGY > GGgOzJP/hlf+n5wYWm0lpwaaH9XA1HhboXBPSVxv7TgGn73Tu9EZ7vFZaGqzYXLN8ehJg66q > f/Aa > tyAEltagKTG10U6JKZh24ugJDPtypyXHd4FvjChqBA1Dihpxw815Gh/ > BLaiBrZHmNDlKiEHYkAnM > EcBSRo64ecoxVhsjMBhJ1Vic8GEaGB0Uhq770RWzGBj/bLz613FJGtRUTHlrWNfT0rBt4Jtjf Q > Uj > i6zlqCnnf4Rv0kgH8B4fhOWoXw07uRJMzzXOr1+n+iCvRvdoJ0cp9PyM5D7uy3ucm5pobJD > pnRoa > OrfTR8GrHPNhbiCcGcKV41nq0NSeQU+siynB0/mZxq2z/ > sXDcw6M6g5o6HKxmjlJ9IW3kjwY29XW > 0LJwWpnmRfbDiijvuh92DKdDW4EoAluAKDabypUwm8plhQjIIgYCDnKCbaYw > DjYhCY6VIeGZ6ojA > lCQbVKcwGDTC0PH6YnJYybSY7jurp2ym1p/rCuJh51v6c8yIUj+ > jXjsgv9QgOHKMzREMN3b6mmY7 > j9U2Dv8S9HlEU2tplsDgDNY1g7Xgxy9BnVQL+o2DbEC/dWwPn+ > MeSvhla9bDnrIGLF/L432qE9lg > 0e7hiu1NWzNvH4bRF/mbw/kVE5m032YvOadpi301pwkoXxnBejzr > 4r5gccaajDUZjYCtHbDxW2nR > ryrBAsahnT0jgtmCbaawmUnM1BhH1jw+9SJmM53aC4rE/Xm143+ > mh4AXVcDr6muRKdj69hQJPRmc > wTPscF3e940icVZS757wySLeU0voK9Aq5h1LxBFPyMLj64NZ5jVN0QK+ > VQBuz/jlcnwy28It3nxW > VZ6DjaQr72ET7lEOapEXwKsawHpfRY7qI/HoSTNu8kILyeSM6kMjHcDrmtIGDtRZ > 0NfCOWo+Z7PR > Hv187os8aMM5HuFOZSEuKoRwLXIrcX+4Kw5hRG5WNV+gLc9bphU8z1a4raTpCkTj1b13kop77 > 8QR > b8yzlcPJ8HiVtuDY98E1cqV6ITLeqRxaz3PTg/NJFhy1qnD0R/ > 5Quu79wDdpoGkGX+gAGqUFXp2b > ypxo7KEihSYvGUdjrxSSWluJs2oybvke+K3MajsZ1e28Ue1vzDft8RnvVRFeGdV > tZlS3/EB9uIaf > HJt9TgMrZvrDZQLvh2ZnVIem8E0v8dECThv8TcVYVdrQs3aqvcWn28e5yOsV > FMbITtjgeOT0AvTr > T8l0mcD1oSlpQ2hKG+ZOG6a3Z5D2Zj5gfIbjLRWjWcI27Ku+ > JWxQl5O23Yx7jaPRTn1/YSfnmyKt > sFMYuu6MuH4e285j800a12GEnn+51hzUBZ41S9xUHJs1s6UFs6lR0wOXm > zSoycQLP0om8DhZHoaP > I1HqyKj3O4fpAX8DncYJj8356DQzkvzEXf5aJescdScpSX5CCmoc9JHY/ > OQ05j/nxWlFJUv4qtEy > 9HEq8GpsCjJXy7IXuCRNHckLnWtJXN66dXEkBHX5GtE2KfkGskbG2Hq8pAVp > pFG9Cd796LfTF45h > z1PunZcnN/XET/3hOoA3NbU3d0Xp4bFEjD3HmDRpWXr2E3u7ngeXpCmPV2+ > WHq2MpzV3pUZPyXBe > bMSo5cEPTcvS40cpMaL3iC5Mjfl9vllZf8QED60+6QFvipkHollmBw3V9MCp6YFTzoMfD9 > z0gFbt > RVruAcew4jzW3fSAyyROmpO9peqbw6VFTw+cfh47/U3DVFTG+ > hk7bZjZIjvLtw7YkaE7ltZ0zd6X > p5toZ1b2zi0IBn2ZBHZjcYwAh5ZeLU+xzarLpYwSAlVnG8HwJSE2oDhS3Gic2 > DfqeG6r2bjjB/TU > EFK07MCo2esnfPQbWqtj0EfP8ONq1Y+vQxu2W3toxZQNY7Ki/ > 7rdAW8PAkv89kjRFzPZQuQg0Ipi > Y9PsgAnT6uMWC9KQsBOsWIiMjY4Stp6FyHiunR6Wnk872gokPYeUcUMKF00C > rh7JLC3e6r7kGOJ2 > e8Th2F1Sc5QNMs4KeKeLW4xlY+NZ6BDnN7KDerFfgufe5zDb9RxSlLdG > PUJrdoZJ0Ku7bHE41Ry5 > 5MjPvQ4/pzvBvc6GpHuEpidhBB5U/dHNdjCdCG9fBWfUJ2XclvA8xrLdwj1 > XMwVubvflbivmgD2V > 1l8hfp/WJ5A3F59bQttXk5obtidk3djIc147Tjgjk7aCwtg4G2Le26wuzHsOPzc4wb3 > OhqTnDLiS > QAkb236MPdrz9Ik6irz59Wa17O3z80ndfAHcp5DDr6w5we3Bdq8LMy205RXw > RMVwFKPGdlPYjYg5 > 90TCN9URgSkpNlNdwswgJSHbInN4qBW04LnmfDp9nd2X4pUvbIWE5sitsAT+ > vlqVF0xBq+sKWke8 > BVRNtGLJsuUlj8SOVJSXNzPFCW4skIamJ2pPT8IIlPAN3WRj5VVYoK+ > 8SOsvt4dveM1miyytpUdx > /vBO7I3Otu0XxxyIfTATG0B5Swvyo9a5PENq1ZLPgS7wSNx70rBZQ95WPYu9k > w39ao2FloG/OAka > 84Hz2qGWkgkPKC3iLCuhG3jnI3M+8VKr7+grxMF9SkrNWqbyBhrSNFW1xstrY1yq > Orrg+O1N2/mm > 7Sfv9AZ5x8vF6ZvWo5qvbbTEs7xy15NilAjI9Xg3uYo/yN0ZB+ > 30xPeNqM5xS2JV01ZaHFtp6SOl > 9h5V34dTan+iUUs3oJFWukVaKjOBLfec5t7ghZ2SSdwfmn6TNyIcWqweXurRCoE9q3vtXft > OL6vL > SXxW2qCCCt776PF+Y+pQebyF2DUcj+YjP4l19OdDU0eNJtP3pj9yZ007Zs34 > n94YJ9WKT1z1Vgae > 7/jI/Xz+ttfwJtJ469g6b8k392n2+Bt4SCvfwMELWoRrNH1wWqZ7UQ0GSF3 > taf3gl0tdT022npIR > rRSjmTWlZsu0xkA9rF1qVOGkUA4y6PkJ7/x83h4fqFlBue+ntmpPE/ > Jcm5qQ59rVBI5dx4Nf36qj > yM340ezw1XxeEvfO6HNsJTEaHsO7X5K00mt7ZmndvsAdx+ > 7WKIlaLYiS6NhKUzRLbvDShpl552mB > Rjrc0NPt3BwWJcetr518Q53uSF2feDpPPMWWAFsAXae+jRiQqbGIvU55HwMy6hQZzWCXELz/ > f2PX > kiA5CEL3fYo5Qvyg5hhzitn03H87LQ94pCvpqR0loKhoRQS0OMftVB1wKfAr > /YSjctCruQsHjw4j > kjkwj2i3q5nFHLvVzOJO4S3BJ+nVDHSE67zL2ZHraQVvt0tT6xlMz+ > B20zNkMoyagXo4yBc7hwAe > 4WDuewF4Z6VMPnPoEeanw7AjwTHotu5ruReu8Q4jTyd8cFRtr7Csu42jB8M1 > Rs9gHT2jgZHqDEm9 > Thipwv07ZOghp/cGL4IbbC7v2pvJebZdAL2Z1IsB7QYsizRYDR0mKuoCniJHbxyGqYjz7LwwL V > EX > vC2lmdSjkd3xfe/Z16q+9/TOvacL9x6Dbe9BH84JfSkpz4euholD > +g768HXYNDP0UWMl2ZpUOVYp > hGuiqYu85rZ/qF+vhTAswmo08bAANcBwbufJFRN3dR2mlRU6v4QaudL8wORCenD3QW41/ > gjbc24t > HxEMQW7t6dkihEXT6voI4IleK18cGX+xBuETO0O97VyaovkzyjHe+ > mDnpbyz34qxto0qMJSqemAj > giscs/1szKNYgzHwkKxxSyUcpiptH+FakHcxvMSu4SBvLp9nlgoOepDK9zPF > FFyWKKb4uafD26j7 > 3Fa7rgNHWYTrjH7YdR14G0Nbivv9gwrXidtuVe1yrG/Xl2K7vj5Nie9jTclqpwTAMAqDZtQsq > 9W6 > /ZmcuyTukriVZiRZLfBou44UD06ahPsgjVTySqpTUluSeqC8K4fw4IkZUNmlF > +AV+0c1x24NvUEW > MkjULJRma1Pjfh7w9lNzGn2VDbzNX+Jx3bC2Qh5K1ypXRbNTn5bjhKRadimv > eVU0nKm0P63OjIE9 > CRh34Y3klq5lbXIltFkID85os5lAjt3C8bAQs+2t5rCOnzBMrKVZ9DoVnonGZFDekLSo > Q+4IzTVX > TdVcnBWglcgND22FIdfgQu2OqzHVPq91a6Vzl8RdErfS4KQG3oOhdGZvVj1x > uA/SSCWvpDoltSWp > B8rb8s7WhTtFl9gpTmKqpkjlius+b5t7cNfoM+uGtCPqlRZjcxCDZ1gZyiYp/ > NCc0UFjfVU5/BtH > c/mP0I34ymuk8fziPgZeJ+BEU7kuKalKgdB2cHiYvM6RY1Q+ > oX5LGhuZ/DcQ0z/lXUmOlbVGVhqZ > lUbjZPCf2aOVZhzxrfn1Fc+gvWH5ATWv5cl0lBscEeod5ZpHM3JF+ > o99fMhpLSvpW6YXlkuqP4j+ > kuRH+lQ+5DadJlJuOv2QS3lklfROWn9LzQ0AoeCbCP1lMhGzyLIuLEH2HUNhXLCz3jQj > b2JyOwrf > 8lyFfuZZxzepb9u56c9Zoz9f/z9ZAmAUfgcT8phs72BWqm3l2iiPyzZ > 6xoweah8Y/jLFJ6Ymnnbh > EbYDODAt1XbFPPNE77ynb2BWqm099dTX+v/GgHTcFG7GoObafhi3qOGF57m257GuS > bZ2kU2O61gT > 8zwLLcl25XmubaTaxosEXtsV88yzUjvrpR2v7YI5fv35+P3xD/ > C2n8tlbmRzdHJlYW0KZW5kb2Jq > CjEzIDAgb2JqCjI1NDk2CmVuZG9iagoxNiAwIG9iago8PC9MZW5ndGggMTcg > MCBSL0ZpbHRlciAv > RmxhdGVEZWNvZGU+PgpzdHJlYW0KeJxkvUmuZjsPJDb/V/ > HGHtjqmxUU4GHlEgp2Aca7A5cHtX0f > RZAM3iwkkIj7iaRCVN8c6f/9p/zvtf1T3j8H/+3nP//Hf93//Pf/7z/ > 1n/fvf/z3/7yfZy3ln7W+ > //7H//Wf//t/+8/5539+Av+nCf3X//K/Cv35z4XM/4Og8mTqnfOf2k//5+c/ > rZRK/O+Ha3m4EPcP > 70O8Hm7Ca0lmFelOysPmF8m/X1x3Of7z/bX2P3WU9sX84fHwgdRjNOqKGIifxn4 > h/UDjo/Nh2j2V > v//rv49KPP33P8aK2mRLbYujn0gFtSXPuB+rWTe1F7Frz6Q9B5mXL3VztvDBdB88m > SmugYtknjeo > +8V73KZx6PISOQS7vcRuy3+rtGC3qtK2KnO6jIdX5FDgkPk8vF33w > 8Nt0vP++0uNy+8uO2snXCUz > j3Qff7fpaWHKXmxMWY4ZIY/rl4c/jpfn1cv33Ubo7FYjRbsqH3bZCQ+l+ > k6l9NwoS+tspc7wSjJI > kem+VLhN4h0yzmElbs45eAIzdyjDHKQuc5Y2HUtm3RZlkNyeV8Zn9XyWnlfGF9sx > FvOL4RSmYL3f > jfV58sU8Vx1/VpfLfLFt122lLbfZSq+My3LqSfXL/Hh4yb9njyhJZ+/ > wxUHbw9ITOMk8P7ru86/b > BO43/EL8x/+6bD2e1P1Vt+9V3X7Ybd0pHxObRit3uAZwCtnDY2m1 > 5pDae+g8/K/jGS1Iq2t7HW1f > tnop+HD3OiocMvCs6cKzZhOejd+/Ohryu8vO2glXycwjXfCfRxj8/ > 3hsSFmOOdJ8q9J8a6S51Six > rbXiJfbDy1vND1+voa31aGeEi2S+2mS65E2b5NDUzhgHqxGtzeI14sPLa8 > RnqHqN+PD2GtGaeeZW > x6gRJoMaYbqoEWYTNQJxvZhH+6z2sl7bNfonBfyv41uI+8OXuPzTK1q+ > 0b8C9WHKfzELS6Z9Bdh1 > 21c03Wb7WMfv50j+6/TdTvsqmHCVzNe8hi74m01PC1OG2Jiy > FPMLOZ/cKxmeZi8llLMQsprG6mmg > 7zOMGmsyvUXqKnL988BLRevER7huyTyvmi5Z0CbxSDKzSfcX01bEtJmfwO4m > picx3cqHupfyir+T > 9Un5aXleZB953soJRo4fU5dBCu4SPpLxuJAa61sZ86sxP45Rbll6An8loE2l > pk2luI2bcJVMn5Fi > 1k7FFSkzjNSYDFLTlRqzaTjJzCndVVOdeo7y8tWt5SUPCwG/ > Xk7w7kVlraEVtzRYDiINpykNO+VO > 8qrLgN9RmTKbZFQk01NuiuljMcoU01SH++3Bot8aLBzDkskgBm87Fm0GriNkRlUK > Rpth84s94jIM > DiYDbqZLznUIl5lTM1bkyBjLc2RHCG2lUjWs5BGrrRp7RukcWx4m9vjmuRHf > tLEPuVsIbM0jvnOr > NMwU31wj0s1ROv0xp/w0U0l0medX0yWLpXyYO8mQA3WD6WOx > ilrJVU7y2UptD8fUptFUildXTVx9 > h89WF4/VPb5Xa3ZlTrwWfle18NusrvbX73Ulti/E2VIq7G71cHvnHsJCwHEvlaO9lC97q > qztoXqw > h+rBHqoHjp8/Xab10CWLqXqwl+qBcaCuM2UMd0T7eLwm7ITrw2J6Uk6c > lEOnqA09RX3Xvuq7trUV > SM1V6XCZx/QU9V2nqBZYXJRp6rvI0/PqnBo58rByxELIb6s2npQ7Z6lknak2 > /gy18WeojXcMHqn9 > PikXzKbhJLNVs8T0laqbxhD3V8980xjippJ0UxruVj7coxp+ > j9Jwb4s0OH48XObxM12ySK3RTWkw > DtSdKR9GUT81Cutr/6rqKNYGf8X3k6GlsSgvXLOlcf6yZH4 > atUXtA/7X8ZjOcNQZDD9sdaB+eEWP > 9+Eo3cIlZNo32XHd14K4TXJgXMFHvOuNvPpw1IfxTeQU84n6EBhMz1IKblPKbu > TDaJgbU6bVyMMP > n7DZWo24DIODyYCb6YKz2Qz+Sk3rbAPrII6Yh9i1kdjNxG7FuB4D7m > R1R23NIR+r3lh++iD2MtMt > Ra+cdEvpV/E+3IWLylK7qXdxq69Nc23GRm3iMrzdM23qNq8zsFqiJDn+ > ZjAh0yLmD8smsTFtKQVP > l6l8TL9J1BiNrdXXkIxRrYx9vhiF5XC/353pky+W01X4azBd5hvJhW7vK2x+ > 4xrGpVo1evR2wMqt > sU6UgQhB2RpT+Th2tjZrY8/7sJWuV4cmOb652BipVI9fpW7cwjoES > 2meNabmlsDRRnoI8nKuEuV5 > ziE8VOPnKFEvZh9RX2aPnjfwq18u80q26ZLFUAtkcVFmFemu3EK88ZGnYZUY > E37Dw5M8uOhbeG2x > 10eLtIz3a6kCT8kcyEcfPtZSOrmSiFnaWHtEuV57R0113JLMS8/ > a0Z99dlSWH8+Q8dGJuNEmR2uM > y3HiD242HwZnz7OXlrWUxl2VdnKjTwzDVyYDH5Jn+FN5sO5SHtw0b/ > QQcrpqK3ZROdq1JOx15dXf > 3XfUXxurof76OO/V3z1Vf7e1l6/+On71d0/VXx/nvfrr479Xf3ffxvv5e2+rv/ > 3hmC3jd8+f7XO5 > 4r9/2q9J6JXj79dU+BrJKFqnGW9eXzgHI6YlyjA26BasHNF > mwcrR18z0WAd62w6Bx5LMbNKdRzZX > VVzAxmFqzQa6znkspoUpw2oE1wEG11CUGl8rufuv35uVhoG1qQavIm5KRQjr > J0O8bCF9HtKeL2cP > H9hYgtrmA+A93O59awab2lhXqCHVqjRaWWG1FZN5sV152cYP3x/ > C8JTJzCPdlwa3CVyTjHF4uo+b > PNAGWtyvtSYODbY+tMRyTLyaZNgSUXf/srp3+FUhL2fanZGT1svi9279HlZ30u/ > tzmyX4zLavbmE > vO7Z09E5+wHH3uWdzlaLeLRkt3OWSDxKsjuqys6oN+Wxh2CloilfR68J38jjYd6FLttb5PEw > 7748 > dvzyyWVeKlwXLMwmcZIxDtCtuZQPzmepYaVoP6lDf+ynfWjp1FjLMJz99Prx35bcG/OsqC+ > Lo9KB > ubyX/v4wU1ff3L8x7k80cFmSKV26Lx/c5sPzqJQTO4tVVvBbv8r5msot65moY > eX85cQyL7+ccPy8 > 6TLPyyvVhTWVE9YrU2YrF9cpsmltIOIyDA4mA26mC85m0/ > mrVL79NE8n99bcAx6CdYOyQ397njyc > 8mSb76Hbe/DbXb5w/NLjMi+drgsWTfXM44JMUd8gpohhYgRFfCwXm > jBWQc4U09OVgp1S5l7CSklX > atgTR1yRmlTHXAZMTRcpWGr9PC7IGIcZPL18naIW75Sd0ukhj9OpyumT+ > oKT+ojTc/tz5o527SS2 > hyNCxrdUH86umRXn38Qrl6A71JLe1Nbf003qjX7e1t4PYxxF/Qx+/zd+ > N1bTf7c4vro9PA5gq7+j > nCFLZ4jvNyNvnlpgj6Oq/Rt1ikddRTI+Inm6+5fVnXjkfnqkfnqkfvqbVC3hEiOgkfr > pYbsZL48/ > 3L18Bf7KSMg8fqmfDpvANcmonx7qp5/P2oiWDVipa5a6l26FPFZtbunk/ > vnrNkqk2+a39IeNxqBt > 3F+aHIOXj9g0N0YMvZaEk0yL+vYNf6M1/HC0NoEfB5cBtxatYdh0/ > vJNny3S2WfLIbsoZLvOi+WZ > cQ+MGq2Jz7MNJyZXOd+PeWnqd6Ti0g7m5TVGbmF/WLzujcBHMquKA7FkPC548qTa/ > FlWTo+by82s > KjfTV8YZ0lUrOC/2Wv/2DbzWzxmt4rD9BPv9RK2fdmrqmyLv2 > F8l5vrK23Dwkf5c2rV9ij7qn2Mn > nGS6Zgmza2eXmHV+3pV2eRHydld/LIQ7rS9kFu5mvpDxdjyP4rDdT2pz/ > kk8r2ToDeqy1aRNtk/P > Kd3arbm78BtJuczZ0r1dNsHU4gI2DpAxbtA9yeYJz7+dQM56wcJWtuDhdqawWYLMVu408+ > TuMcZ/ > 20GBz5bM7dJ9TN0m8EkyxgG6Pj8Hi84ZGVh07oODha2pgUWvM1g4PlsyLwbX > fTH3Jt/1nmTGkC5n > 4bQ5lU+OwcFkwM10wdlsOn+VNdsTRcyxvwhbHjK1W0r9m+welZ2+ > r3hwJEh+VhbA2zDSYzJI507p > P6oXHtfVrit0xXRjBoPWgJh1GzU4cI19UDAdUzX4m0EIu5eeTJdXB3fUIy5P > jWMwMpnH1HXhU8/N > pbggM1U2h+9gIEdmV47MnnPEQx6/yT058OYpRsMpnZM7QNRdSoPtmyINjh > 8Pl7ldumAxlSMeF2SG > clNMwQInk6jBfdaxCnZZkep3ULFP9stvsxXygX1sCkurzb8seVu9ccLVcDuR > 0t1X5PruKrfb2rOx > E04ynDmoHXWbwEU5uu2cpFm94rdvzi0P4dg78TiqP9wRNZml+mM7qMitvVR/ > HD+Pu8zVLitZbOWW > xwWZo5wW04ndVNafM4hd49Qdlmznk7irdT9cl6Du+GV1yDMK6djtHApZ1nvjr3fU7sekrqf > v/T6q > 13f8xRZ4xw4h9N/onKuIj9mHww/4/V//vRr74r8bL9/XAy7nSDtK5FtJfX/ > 9GK6+Y0j9wXRhVD2i > JH3YSlj7+/chfyHEvGJSHuM7t2Ql6cPRXg07h0S8o+Uf3vtCd1mvVPT7fiN9zgyfDwfP7aGE > hf1j > 8VqJCXy7ZMA0+ck5QEYtvXFwL709QE9nq6lGRwhnE0pn603Y270nY+ > 0pdGf06SNOAyKljbtHwG+B > 3TUCv/F1KbKaPNxuFbaxC2TMeyt2FhWXe9Lx80DTeCh0wfQ04ZtkPBeCp5eS3qJltT > 1JT6eHLO1c > gqvNSajdp3CUvlcTuo18X+x9xcgEv/8bv5+oOd1HrOto9X5trd6vrdX7tbV6T8x0U > 4YjMOjaCjxs > 2sr8ulq930Wr9++ojMu84zSu+5ptt7m7Vu+JyYEy5AZd4wybsXoPjbobU4aR8g1Ls > Uq/6/uLPTOx > t2jUYU9IHeYwMM/NkkmrYtKamDT2QEg1z+XSG45xso4y8J7pwqtmExwsruCj1DW2 > pJTy86Svg8Mp > uh/H3Hlc961Pc/9nYXTGWcG6WHkmj9OEd5LBSHCoBLhNYLbOYNTd+ > 4un30qUq8F1B1iynWZq2zgC > +AzFtuWZvnt4rFsZw5jSyg9O+xl+nu9ellroIqfMJpkyLmJygIxxg65xhs > 3h834wHVzzh7adAyTm > Ch8tLYsZ5/UYQ71xdg+lzXFJMi/PTBd5ZjaRZ/F7D/mFM4C0g/ > xzvJdk4PWl/HObnhamDLExZSlm > T/PkiADpnD4igJyFgNWcNUrVnFvYmEBm10jd3MrDydXojfHlUR66zPOq6ZLFUj > thcVFmKg8T07eW > XVSfl9Xb8dbKebpij7c+brk+K+Udz3uypb7+suR+2rNErdxmt9e/ > sPdx8MELcZ9zDOux7KVytr0f > hq8shDpbrYutGVP7dGFvOcDreM3EOFHlwk7LrTcq//17SawO+ > YIVpTwlb6XXS8JZiv2kkmAn3igz > VM5tLIrUHbYvKAmOX266TDuhSxapbT+pJByvgy2tQiNFdyj/ > 7lA5ukttwd2K+XrZXL5STab3qFw7 > xnk68/1rv0wX3jab5LDU9l0fM772AivbP2ThK96Pna948/davH2x3631/8a421v/ > b4wbHv5GyNVb > El8Vfzny4e2tR+CdZDDibNFmh81dGFewO1ul5BtbFvcwcJQSD1kcaSYe1nIRRzvvJ+ > eoazldNEp/ > pSRwa5JpOnVHFrRpOMkonzPTN5LrVtIvsbURHy7eLvhY923ufLgJW32fseru > +WNWkQ+mzdioTVyj > p/Y1e+pai4TTiDYGqku4Tcl0rfe/zbNg1BUXZSwF0LWvl+ > jhxvVt4rPEwks9RsFdrK2kX9sdCKzW > /8MlctP29yMuz03HL0ea+lTXJWu1/h4XZdRzGE+vVT3Vqp5qVU+ > 1qqda1T3X3rCrv9nip107RsDo > 8/F7rP6+SdOngryt+kLohUydBaEtX8V7h0UjZPb47oYaXAM > kpkcow5Ux6nJNgVb9mw9oWN5Bg7sz > OI764UJtjEtpCWNOw28M4TL44sN0+cVLE15JhnlB3d1kk6sZjMswOGylxnX > B2Ww6/5SaC7++wTCw > hdwIoS3WAmj0MoXriPhsNwe6vYmfnd0Ab8cYD5sMvjsx3Zd+ > twlcJOMc4ItgihjY5xDz1APy0PFc > MUYl051SsFLKLM8hM+VVWz+OuCI1Q7njMkiN6SIFqRx5XJAxDid4e > o70q/LM1V0vzx4yMdZXeR5V > 5Xk0lQAbQUPXzpXA6ugR3xspdlmdHAfA0myKYXrePplawzPTWLxz8v778xL3 > pVhb7bQmPOb2t8Xr > Hgh8JPOYOgfgmmQsLuj63IhMt2rnXFtMV2I3VSIdw5LJ8GucxGKrds6TZNhH > U/eqds6r0u8YHK7y > xnXB2ctp8bg8NYtrkPDXslzmtzhiZ9/iEHexW8nXy0frtMp5BTV+h3ANkiE+ > Y0c6POSlY7lfcbql > Bfe1VWKWj1mgsUeJXNldpXWnMrZbCavbSzTOv5zw5rb2ACvARTXIZfDtTmo/ > 3CZxkjEO0PXTYYyB > 33QQc10E9cfxxIp2Yprycad83LtLJpXDncrhTuVwp3K4UzncqRy6TeBUDncq > h1tt+JsTcLccrfvx > 3XLwsBDwO6k9PCkNJ6XzXPV0tygNl/090uD48XAZfLtz1dO5TeCUhpPaw8T0 > jeC57wuN23K77yHg > 1FZwvV1puKlFi7kA/9pq967n1rNkHl/6qoepWyl1JoOvelKu3K1+ > 7J4kY6UHutaPbazGN48rMDhc > tbeuC86ptF0/KfxGTqN0tntvDFqsdPN3arwTy79/T+0MQuDjG1Lvk1+ > TQvkZhR42nOrMKDP632F7 > +a/OBJ4r5jMvRR+O8jbKvgkXyaxoAT77V16aS96b0f+GzDsT7rrvzLrbJE4yZ0r3pprxdaYx7 > hlp > 1DjsZDJxi9r9zdqidn9Y+VmL8tkxZoImgy+R1I6HTeCeZDR+ > BDflebU6vC9xaOxkSSVyxNkCpmFZ > T4k5ZS4Nba/wQPM8ebMK8+s68RVR3fqiCAxdBt8yJd/biQLiMyVjZQS6V3nroz3Eda843Kjno > QvO > qUw1/+IcXurW9wBzpR+1xE4XvAMdOJLv7HpLrQQ+FHEv9X6S3cET7PC+ > 7XMjRaPJ46NP4ZFaNZwO > crvDvxig3RnjP+AY/0XIS/tY0RKMsbvwiTHGsNPA1FW7a9hr7yw3 > au8c0eMFniu+rIHVmerETHVi > pjoxU52YqU7MVCdmqhMz1YmZ6sRMdWKmOjFTnZhRJ/hdzYrctu9e+Hu0WBt/ > XZ9NjjV38sbiWSJg > +wYZ3nD8vLGryqCtPsIDW2NyTMNdZt3oXcY60bsgLvfGSu3RUs8RukjDVclKI > 57gcFr67oWM+omy > tKP0Im0W8jjtlLt7LKVnKnd3ngOPrbnhsNO9tHSU1/aFC1LnGAyP8tF1wS+ > l1L46hswpymvbh4dN > W1NFXI4fh6M5aeg+zm7T+avGHZszAKca+wtrXH4Z4t47M7cKhztb1PG1YXC8qZ5 > dW4F4JcvxK1nc > 0Sf3m+rZTfXsNqXvVvn+pnp2Uz27qZ7dVM9c9zF1m8Cpnt1Uz6 > 7vjDK2u6ME3FvFLrXDd6vPv7uK > 6ZpimvqRm/oRlwGLXcVuq3W4qR9xDtC9qT2dpcUcCtg0PhyWZuk94TSfnKVOb6e/ > kJlDeBaXOrkN > iZD5YlxRt6bt0VJ7V2FfGyVffhHz+qhZbRTdcbUeuX+0f/1ebuZbS5Q/ > k7Icm3VGjk07cU0N1fhZ > e+TYhyPHpt1mg9T5OGV34c/rIfN8W7XaEDaBR5KZVbry35Oy8cfDr > aRR7rTT3bDVUv5xBBJSp4QH > bRXVfl/hwd+/p54ZIRHH6cmDvce4aNr5Zmj4Shaw+oZp65/UtdnqVwTi9+dN+/ > 749USzW4p2sr8t > XvdU4COZW8UBuCaZsqXr5wOR6neeweuFnW2gxlqypJWP2XcuZ32qXvSd7Q5+ > KWaY+i8nbM/0jbem > 7ZnCLrHbHXOE3bFzfbMvleDZWWJVZQ6NFD8cI8jAL+Uu89Lnui9ufsXsOMm06I3n5J4EbE7z > +IvL > 8ePgMuCWSkOsmxWPK1Jjq8iIOVZkYdfXl59dX4V8drWGO6fWduf87aWrXJ1X > uTo1B5923pC4xhx8 > Ll+1+3RXy1btvCE1focM1ZYVI7GvOkbI4740kvjwEV6qLb6SBN2tPFqRPg8Jq2fI0 > pGn7ftgyNj3 > wdC1L5dgdccexNeJzM3deXhhp5qU1ozm9rW16b//+c9Xef/ > n9195l5FiEvxN1g7xv46RCfWdi6g8 > oIt7Tis/CcDdpnXwisp3n2ng2SQzjnS/XjhsjqLf+5J8O7LTks2abJYtXfA3m54WJg+ > xWcoU8x+T > 4+UETKdfQWAhODhlIWuGN2bN+jPpcwnYsC0eUooX/pDx5sV6nVdQWgrflZj3hhfsSsxHO/ > A6ktlJ > F9d1ms1zGFfgPiUzunRnDZu84Idx7SkOjh83l6lJF2kZ8rjH5elV6g8+ > XbeQI09um8wzX/aZkUfH > r2l9cq2U6/rArs+BFO3eIbt3zKx9kzavJeTv3aW+MtvKIEfgnHft1UHL4cbPIiKkzbBcbQ > OEf7Wp > OLnNSv1feF6lHiE/jvuvEPmldSyUo9Y0HrRCXjVO61FrGj > 8iRq0J/NWakHkXRrru4+c2wVW5Y9hZ > 8DI4hvhnyqaP4yYW4hfK4q8xT3iBywsm5Vd/wtujrPC8X3dmOkdxjjNCf3aP/ > 12KuYzZS9cqK9Iy > r9LIS8Qow46HunaV8CvjgT/jn0wL37r88/nk9amvNWs89INWLuKd4FNYtwa5WZ0L > /K77dHmk5qaU > Gc8n4/Hu4PmluL2rSXmM6MP3w5bDX3/YtuXqNytq2/zdgSnzLul0vIdk3pWopjtghzbfubbm > x5GY > 5r2tHf3wqc1b83baCB/x+iz68XSVRcevLLrMyw/XffnkNh/ > mVRP0y/bLjZFTt7JcvRy85tVn6abc > P5Y7wKcpNsvBp3vMw8/mSTl+rCTMhNeRzE66L6fc5mPqcQFf5aZz24 > nzs3mr15jH9A6VeE5WDZ8q > S94bl4fZnrwP5/kpLOpR4Fc2Xeblmeu+PHObo+j3l3qXx1Fas9OSzZpswuvqdcOmp0Xt > h6dMMVtp > 7gWLkCjNvXgf8tJjfcv7ML9Yn4PP7ry/GsJ7SOYdJDPdATu0+ > UpzL83L0fuou1jL2t+BY3mjlxPj > kQ9fL832+x/6PrTfBxKu/TZKXJu/X8+r0MaN8m/98qOKcvyatg+ > T5bsSnJ9R1jd3sMvlDe8mGZY/ > 6mJYbTYxDa3v1iO/RH7ionnDrYbM/OZqrvtmAm5z9riw3jA5UIbcqHuTTZv > C17diiwvoPWXczmcK > uG1Pq76F/3F9IZgykPcYjONdAs/Pqex3piHkof3mLa4Nhq6NOGYL5qYd8 > oz7sZquvfwS+QjpZAW8 > f4XgIinTuSVitOvZESMPf9JXnHLQV4utH/KF291MX+ASMvCg6Q5eF6+ > yYXEFH7FbOP5tjMbNIYch > NYfA09weNx2/Ah1cDsdf4HLYjoGLXXUOu9vL78NeZt8Ybysd28ovLmtfN9K9rdzhsnbDz08m > A//t > rZw0m2C6vWyu4AAZ4wZd4wybp0TK3rXnQ6XudEq96+OPldPH6HhuHWFY7cpp130szlDNOTPJ > pFpn > PQltLtVSx+CwVPKP1+oZNoN/Ss1RDh67wsDsWgjsHrUQ5zbZYm8FfG > 1qaX9xnDvfDOHa1Jm2LAS2 > bhcvblkbHjPiu+YP6Jo/Hr9rrdDzh+PnJ5d5/nPdlzqzSdyTTFeuB1OywKKCsaAHyOI > op+9WTjuG > paNcdF3EfKPsNesdn0zjkVvo4q52s4k73C2uwO+aepN53Fz3cXabwT9S07jZbTH3lNMRA > rt9y671 > iNAeR3imnG61RqsGHDntIbDFZVzTvzfhovg4XiePfZXuveQPw/CTycB/ > povUqW31uCBjHKAbTF/r > 0ypnm7MN4tAYssRFXMOzZQ80tnXAueVs3KpGq+YX/9vv1iK2v38v2S4Of1qMO+ > dls9b1Yn7Yw2v8 > GI9eq5wjwGuOkfKr9Lnui4FLzoZrkmk9dO0RANjkh3iMy3EZIUNuTSXIbAb/ > lJqpEuSf69WJRwqm > ShDnvqaxpvBWTWhWIqB7mtJzUj/c+l3eQ7c+leo+o28b/MtrRQ/9N++ > xOerrn5qPL14O2ygCdsdQ > rvITcJNpMQZrvDbDbFbVOx5spGcdf/2QyyAnTBc5ZDaRBouLeHTJjCtdjesa > Pze3uDIeXt7egxdj > L6X4NKUs1bQRownMREePks9Pw6kxu7Rni3FBm9X6/DfbrlaaPn7TSiVm3kVpcJmXNtMFi5l > 8MZvq > vj3oQ92h9tUe/aF9wyXJgEM/kTczlW6PCzLGoSRu4uwlj9eCkt0qM4 > WsohC/oNPk+PgOpdYI763m > bfgroe9rCy+t3CQnr53K1fby1mNOD38HrpJ5eeK6LzazyZhTzVpeMyzmGBWbVS9B79pwL0F > 7JLsz > emXD7pFTa6R7b7XuGR/75Npi3+rH9t0p9ncVlcd+eow62xnJls89GXLUcvMqKrPko636sJ > WjIsx1 > gRhTui5jOCXhJRlvnTHnL2HzFpVBw+BgMuR2VSLMZvBX+p/Gzy92Xk/ > vXJHOO9Vm2UoCcb8R3+1F > PNoQv1ajzDtuSeal03SRfrNJPDQOurNId6rfv1PtgOOSZMBhaixhNon7lYxx > KImbOHvu372jHN+9 > FdJL3T4XUggt4wgEdCAV5bIXbKAaXtG22UfK4IgPPaxu2gfL8LFwlcw+ > 0gWn1YQ1qzAcLJjTDPG1 > MejUGm0PcErtjbYHnzUnnV293PS6oi3pVflhFwKhLAduQzK9hy7jVl2xi4JM > 5kzp3iqbtyuu28Xh > 1vCT6RrnlbDnt2v8/GJn9aPzujLaaqoT9oCK4Rb1wy4opVV > eXEp+TX1C4JZkelywyvT7SAu4N8mM > Kt0R9cMebjH7I+pHyICD6oTbJG5XMsahJG7i7P7qLcYDvatHtytHydqvH7WQLT9yxd8spfrgY 7 > GX > t45fjrhM76HLGLbKej9JxsoIdO+Szat0GiaHG+MQ1yXnk1IWNcY1fn6xs7FsH1xnRsjw > cQk+SlHe > pvFat8cVKTPEe4ybrWptJoU8XrOoho7km+G7Kqj7vDTdsD/ > MNfAhNVckkappdeVUv3iHPpnJJ/Oq > Dq0iGdupgK49Qwibvvb02rXAJ2RQzmL9Cxf+qD1YLY3aO7fADY8dObmsVsLqiDlGX1 > r56z5ugsyO > uYp9uoER71ewatQmx6+WuUzv0gW7NYSnctG59RLckKNr1Jyaq > xzdWu3se+RW9l2041JnZW+clULc > T/zrxvpjt56YGieNlfodJUrE1ZjGPiimp2yvdPBj5Oj3hatk9pEuYl5qH29qFe > 4omcWKmZ9ZtXI5 > aokR2yg34vhwpMgOsxv2uHEQPtYPh/eNuOBnRX87ilaSArcaMhMfDqjdcZuP > qcdFfKZkbpXulc1a > PM34tNhaCGDrFctOGFeDimlVmf5wFe5dMi1Wp+zTasVlZTrwY+ > cyvUv3pcZsEo8kM7Z0Z1qJGDYO > oIb3qYzbQsBJpco+iTZtG7EC+w4v/mojRmB2tY+VGQ+BrZb80bps8ZCcyXiPNvyKUvJrWmUL3 > LZk > epduj0+rDfckox5ZTMliLaVhxVhsRwj57SHeyTftXKXBZgjQvYnH3dnqlWd6kTd6bcJ > NJau3aIPt > swBa9UsBWbO6+fvVrD5j1PlhG422v37/5YOutR2T8ny0PXwwGUXp9l0tYC8fL2 > 6bPT1dHr1jPvqu > 08tHxy8vXAYfPWjm5TaJtfrvHCYfKfHe/uKIf4x27Gg+vTE1P7aj/ > IY1PxvDUvN0h+coPlhQyobt > R9Qu/NoNkyGjc8X0xpzZ4yLWmohzg+5ssjnbSrkzd/RCwModCwG/ > uWMVb8x1hKdK6PTW6+mO6FXt > QRLmjmNwGkdcp1qdqfU4j4syWzU0mJIFd0QnPti4J6fB9kofv1WUhlWucI21 > nbGa0rB8pfN9pNBV > whw/HkvrS6H7eC+tR3lclCkpDbH3CRYnZmD2SYSnwULIb > yfeqdVYvhr6ZHxuPPzhEkvDrErDVIvl > MuCXfL+WytjaSWZf6f5iyk8ryGJ3tTh2YoQ4eXvXGIeNXdQu23POYOoYD48Utbmui0d > Ikrd3SzIp > p/wjENbPPdWi2Yk1/u7z6PbX73m/AyGeV3vmlnLbPmkbxMHkJrZXbE/ > JPd4+1XcRxilpn3vYWTh4 > zXcQn9dOUyvIMSC95vil3GUej6Od9HG6epEzkkwqG777CJu+ > 29aFwUFnB0baZXSbwT+lZp/w39le > X2F3xyxlcLRqdo9GQOeqHl/zUps40YCj2YbR3rf3hbmdPsAxqdr5Z > PdrTOwkQntfvAtXycwj3Tll > Exjj/fYmMYaDBWYpFnI9BOcY8BALpQZav/Y24D/M+C5OlvaEq2QaZaCL8YnZ5OPySI/ > jlWReGlx3 > Ttkk7pIxDitxc87BgXgVybx7rlwXKTabxC3JYObXVtnODf56UrjiiXjaBSdM > 52zy18SYgvnJw+HM > T55xY/p5jQHzM3CVzDzSfel3m8B8+h28Z8ulamLd2kKWhyAOrBDTZ5w5my2 > M1UzDxrTUWLjoihrs > I6jBBz6o4Y990P8LjxswrbyygD5Ynkfvd8sjl4f2O1Do2sgB02YcKfdMO+ > SN7Tt5sRj3xGmLHmz5 > 7IThobrC04Cm24xfSfjJW/nbSf6lh5/itXcAurK1ZZnzeC9OeTD9PP1xojw55 > kkQlT/jSexltEe8 > 1G2e4mnnUX6shPNciGncE5bYZhu2PWRLG67JIvaHM+wvfHJiOvbZB0uXhcAfx9K947yG4dHD > Z2xJ > TdfbhzhvQt8YRvpMBqkwXbIY8tOZSYYcqPuL6cXpLLK4tQQ7Xn5gTO8S01vE > 9AwxPVVMT1VsZ4gF > dcmONoFvkYxxgO6NFmXiHMkIb98+Uj5cywec4YiQi5PgSzprZZ1Dazi7cU > b2CEPokZs8cqN9bsW9 > g5Mc4RE7yYG4Gx8ghUccv1S5zOLJj/CI2yTXu+SRmzxyUrpbwVk1YzGWWFitAwsrWWDR > t1iMIhZj > icVswivJrCXd3WRzT8VlGBxMBtxW8twqwtP7hYkTI1GbWrldudhqZTqBPZ07 > 4fpw1CY73cE4uLth > uC3JNOUa90YUl6fNMNJsMvCF6YKp2STuSWYU6Y5Ujltb7F+ > AW9TX33h5C3QGQ34c/7aF2Zzp2OyJ > 6eCaATFX8umzwPWd9o8RVOtNedSb/Ner8pFrD+TBy5QVl/ > vMMNJtMvCH6YKp2SRuSaapjPWexgyt > nxklnc8IGLvdhdcU03nFdEZf07hSQaaGGdvsYkFdsltTeCeZrfrcz0w5MlhW > X1vURo3e6cOyNDQq > sTMeXqPfq2I/jlvPISPGn20Mj/H2CEFah8YPbUz5Zkz5zHcQ+ > NcsNTw7rurvsBEyYjgrvGYYKTcZ > pu8qfXx+1bFkpvkAZyla9BdttuhHAuOsSYtRhesa55twzakZLbw0R5SgHSG0pV64TfXO > dj7DZHaN > OsMvPczq9hb45fa8zcdSbd4YK9r3IO0dIP7r95bZXuXpvGm20dZUrvj4ECc0 > Usu2NOZqPBVsuk01 > kxdr0cuG4f2Vap3pgsXqyrmVeggfZUJ3pnF026n8rHvE7iamJzHdTUy3MS36 > Hay3jXoei9uVAhuv > FYvXGTkGU43pnAPxSTJb7fra3tJOnEc5kSP7xvyqcdzH30+r+ > r3nun9mjFDaWUdSRy37uTE7abfW > pH37in6BFzLRY9farB2nJdh68wInetLln/fuVhtnGCk1GXiAVxOQ0Z1ix9MhJtOt > xX4nVmz+9zx/ > e/KYfbFhrI9aznu8NwK/c72N6qW2rL+iDsQVmRZi7RrwSbWj1xL9oV2R2fjYU > I/Wr3OXo9kjRzaD > 3glXyeBRpB75FTb5+FN4x3CwaDFe6X6REWZGeHb1x+NbU/ > Gto/h2VRx7CZ8kc4d0bfQJm/cqbfcq > zTfGRnZWwtgpt7/uNnu/9ZgL2mkBxtBazOHs5ABqqeNXDlwGz7 > yYLmPoR3gkGRtZQnce2bQ5PeLS > XD9kwG1GXXSbwT/m4dD4+cUu0mmjIdgyD0PjNMVt4wpw8v59hAz > TcFLabrQJvRfJ9Cof9Rpz3u6j > qheX47Ulg+eVqkqF2Qz+SicvccrsPJ2jjkgnv4Y2jata0q2U3L > hW37je6Kldd/FK+5FwkmnRGvdh > c/6LJ2VjTScwHmoyGT4Fq9pmNoO/0jlsxid2tgLSx4wVEHv0yfjNI34rVk > Di8SXWz3Fa1M9hJQDP > R/lqz2N4EsOrEjeLZGaN1agPj0jptBzF5Zk1WvKQwZmMopI0tmrPbDHyx9NQx1 > fR7Ep7z+lVVKJ5 > /XzjE1A+S31nQG5X3DdGBY6fmsvg4aapWafbBKel3s/OephMixWXvrpsLq124gJ85xC4SOZxN > l2m > pcnXK5WMFSsv+Es9rT14a+M8D2F8K0bAH77CW3my2DdT9yyl86Rx > ed9F8e2S47MQPtxUFd+uio/P > 0JpMV3y7Kz6/0F8hYVXjP3sQwLFafl9D45NRKll7pXWwb6ISM89+Tszr+tG4tx+ > bUR1csRmzqJDH > dfwnVuwcowyc1FKerbSdpfJzpsrPsRlYxXX/O1oTP7FLpreon71aXe282Ml+ > H+pBb17NxYWRtjY7 > yojVzpHWOYbWIZZdq/jj2pZSXM+4o38cZccown7/Q+6jXFtxwlmXFMeN0ZRd0Ch5a9cWr3f8 > MbvV > zpEzpLXjeTeaWue46rDxcaZLfT675COwPf15VrO1Tw7RmHf8Wl0YfK6x2YNJ > URdH9Ezt9+/+hKLZ > vVd2b+ZiOzoI+bXL4iF4WolXUJvG6MI9SuvwFQzotmh17NEklFDHi6chYg7vumTR5dE+ > ksy40p1p > dDr67krDTuPCbzpefHQ6xo4VquG9C04PnNjfGDy3x3IVuEoGj69qHyJsAs+ > Y4RgOFixJDLleI273 > CxINj2iNhN9pghEzNruckL6ftnoE3LpkrF7iJEWNlmL4TP3GZYn05dTKiOuC > 6dQamMdFmX6kO7K3 > 306Ml5h5q9idxHQnpmuK6TKmRb+DtY3NXy2aauvc/ioWbzC6Q0w17nYOxFo98riou9L4baw > a6wkf > Vp7HrlL7+/e0noAQz/NVc71aK/ab7ASAacwlrLWjsbrqlffaz0v++/ > OSr0s8L62pfF6eOovXU7q0 > nxMyYDqX8EgyXeVl9dwuLe3njKX9nJHm/nbCwHFufV7PbmtsY5e0n4M3ftxLWzs > yY2tHZmztyDgG > w60dGddl3NpFHXsmGe3I2PkEs5nK4U5l1WV4tiHWrNxm8E+ > pOTFmGfukXREPod2zZfeqzmyt5YzY > 9RpL+/HE3DsfS/vxY2o//i1B+h78exdVWPvx7+3U0O3ajyfm2P7dfab9eMbM/XiG+ > NoZ4hjcjR1j > xP40bNmcAxr+mFV7t7jVwb6R2HtzxDJw0ojYViaRVmubkFY+isq0WjsFHoGrZPqRbp+ > yCX438bsn > sZj1RFqnz3ipj7OYZpclBOnm5WrtdQnCUzLgzfrI9Hg+Ys+ > bv789XmvZXpfzYZQUfL3v+CaZt99m > rR+ZsvUj3lUyxuEmbrDJUs24HCcZcGONIGeuyjItZyqNxmEmbvCJYfjKZODDk/ > LD51iwtMzvE3ct > KGZrjfl7qxHzqp43uLXBc61L+y5p43fTdnkrxW+fmjM/sN2pxOxUYnhaymSKUmrtIDwQ+ > MmXGrxd > /qWH7WN7dzBXm6vA8x7vjhu9Gu9xsJKNXf2u1Lj8S6XzBDaekLF4n+ > 66uSxvrprxdgjLZ54PUL3Y > O1m1c+WWNpz9Mrx3Cjm9R+059mwRS5OHTOyu7/DTSXnKh8tMhvNg6povt84R0DdXvnEZ > 7I+bLliY > TeCWZIwDdH8zZZ9FFkf1+XgdmH5fhMmkOnPmCKZ2JoA3dhhGbFN > 12HXBbqncelzc7S/S9ZkycvFy > PgyN6zPlwf37HvmrkN3jDAJ1vKenjs3msSfu83ykykKQ2ptaOO7yG04txE0t > HB9gs7it58Fuv+Gz > JYNTBEceuakEely3iwN0Z0p3K/jWAyx87/+x8L3/x8JuegCLwGdL5nbpvl2R0ppwTzIcq1 > F3NNkc > U3EZBocR/UHognMvwvYVCvK3lRW1CThysRWuqgFXT+dO+O3SqzbZTQ2Mg3Ndi+ > 8ucbpFXM9QGk5K > m2Gk+Qz54hb56Mp3Hhd3+yPXjKens+HLYmJ+g2jaCTffCQG/ > yvMLwO23LXzlZTrjJp+1tcNnNquG > zwLXt6Me46rWrvKoXfnP1qgps1XG+GSB4nKfOX7pdhns5G/5qan/ > jri4268y1n03AbH5yHDiXsAb > 7GxGTdyjlfLzB9TlzI+eaCWYOkZsJoOdfNO9SzaBR5IZV7oxe > nw50q2snrgDwjROspTKT7+pVWo2 > 9yf2kyqDu/8xKrUdf89pD1k4FxDjB9vlN+0mn40Y5+EvG+dBY6n+2r4+ > Y5grvOYYdzyYDHby1Z7D > pnCSMR9A91bZvKp/jsHhVqVG47Cw6fyVmslZLmKeNUrQVg > j209UL240MhlMJsnUK6o5omQ17bs/V > fCzle/z2O/OBtzzm31tmu5SnfoMDU76acsVHeBN3PtyE5R07CQDdeZRz8yjnHOPcwVGuuC > 72xEtN > WDLO4WxyS0xT+bF5ONmp57R9fZOxfgG63ZgW/b5xJsBGPY/FUnvs9o/ > FG4w0BwgZpEDjjeAAmaF2 > ffU0K2t7xKys+YjwtZQ7tYL7xKys7ROzMuEqGdyLqVlA2AQeYrrHySxWzMrMqpe3M3aE2Lo2f > 9cY > sGlO/UJsjZtSqY6eX+XtLLUhJ2Icm7cc2Jz3w4rR9vBhSyMr > /HUUIx+hZU7eOYRv4tjLDI2exiKG > jSP++nEcuQadG7UeOIXsFpZrzSHVeuGnU3uUk87vKFFOep3RyvtuO75gtd32gV1y6 > +O48x5z45AZ > Q7rvXkm3CQ6zCEePD21L0djEVq4+nCzZfOBp81Ymw1UytqsOXTsFCJvNW7 > 2e8JEMdrDrkVdO9Im2 > I+9+bCPKKnAKOQzZv0IW9uKVXy2X797b8Pa09xqrO737PBJPXS5vNQLjVgG1V6GL > Z+Y1X+zRtz+Z > fqRrLTxsWr1CXIbBYcQsP3TJ+SbsvYNr/PxiF+k8Tem0NgEaWjnpdkKQnLz0DckgDTul > TaOq3k+S > 0epKHzb6w151iXWHwI+Dy4Db3UrbSWn2vaHQ+PnFzsvx4OlKSp1YofM9cMQxtGLyYcV > n+9iQsf1t > 6Nq+N2xOG8Phocimmugy3DOPPs335IFnnn10+2qDISONKfrkfgdSpxA+ > ialy7Pd2Yq0P9x/Yul9f > LY0Y+lolcn7NWFnp3ufx2UnVyDVi9BoYNyaM6M1DF7viUyUi9X899ZG+ > S03dk2xq9tqX1lyFi2TA > 2XSRlq2c87g8vUr9LtF/9a21362Qid3uGJPZTQeGu3LYdrip29 > U67egZoDFTfPNXfDPFt1J8O8V3 > UnwnxZdaw31utsrTaNS4se7TT+nCNcYS/aRyeppy6/hZDZTywzNG8PlNLf2tKs03ejf8pTlm > v34O > 8YWMYmuHfRJbj9xjtWLpyUOTmtFTjqKxrO9a8/cb45pRSxo/ > 4BUI4z6qaro9F07t6nu4r36PxnN/ > 0G6+Gt75+7/+u/o1+/0Pa+how1YR3vN2Q3E0n72939Xy2+/ > unWbegd2ZPDp8V6Bjlzn8Hl++03O9 > R583+kozu9FvrG6M0WYKGS1mAUNzvhfPGNEbjmH1nb9bj9P+/ > n1ku2MpxpG5zBLt1ph5nh0h2BlW > +R0xE5v+cJ7JaEVg+KwPO88+QjrCbyd4qBUKXfBTuxxxQeZGS5WYdu > wRV6Uhz0jsG27i5eOZ6t9h > k/fSzsqHYwwvXCXTj3RfzG6zT/8m21jknZWxtLNiVq3XwK7kj+ > Mbs0zhF/c54qqZr31L7bhKRjN3 > 3zGNuDwflmbuIXO1Y0qmmrlHXLeLwwmens49Yv43fMV+4hvum7CY+ > oo9dEvM/+J3PIKndmnETkGy > fyxeZ+QYO5BdObK1khMcbldc0M3jMvtSm3lu+6L83du99tfvM/U2CPE83yvXq1Nj/ > WpE+z/9e27T > vlNeOlteOkNest93fCNOLx2t8ob9Y/F6Sh3fLpm7xAGsr2Q8LnjppDHM4H3W > FsNosjpUknwPgDjt > mozTh69xjZPXs8fhGSN66cQ6kH3zzVTz+WNL6U6p20c8jlJ0tNY2zpXM1W7RuDV > WBT8c463Aj4PL > zCNdcj4Jp32j8W6J9tJwexo3Rgjs9iG7I9ZMxh1L2LxU8c2t3eePbxL9NpKr > +/zfck7cpX91nz9l > eO85dflNPm3ym/zXaPkd/qvrPv81dJ//GrrPf03d5/+aF4+ > LmBwoQ25LO/Vm0++0AIvB94vsm29q > 4Hb+phQMu53gpnv+gUeS4U0h1OUNA7TJmyv4fbnjI5l3Cz > e/gGIK+N25Yb/jbzXs5eOODeBZcho4 > W6CHJ98BAid+CU6u/KbcsN33BZl+Infs1lva5K0h4Dp5pxByxzHOATR52H > V1boBpsLiILWdnfAdv > uivZ9LulyfTyrtQ7460AMLI73Yh5h8zi+wPM/6a3BcDa3hx4nWLgobcLwIhfEZGp3fV > GXFSm7EWb > xd14S0GcMkB+PKa8TYjsRmI3i1jzNpmQpzb2uE0bnEwbPKbKv2u7vDy2u2nj2/ > IWeb73zFLuV+zx > 7pA6dk/P18z/+n3fkdK3eYMT4/C7neDzk1J+jHvFrvVJWF7gfrHpVsujot977CPXxR > cIauSj2x8W > r+fpSX46yX8nlUrnAJmmknj8zRp6g/cRUsNvKlx85eAonTul8yhXj5UPyNwd > td3uxYXV63euQePy > PS6G+P1l8I2H4P7+5Fe7P5a494jvms+gm3x5q+qB47El8/ > zhumBhNoFHkhlql8W02i51pME8sGIH > uq4dO9Afjh1ox1WW/G20ZMnypRWcH0AIsDFstQZD+6oZlaNVaxXeejK/ > cEZpEk4yuHvedHHPvtl8 > t5D777ir3uT5BfXy9l64hgy/vrab0PkWQbTLxt/yOVKmmK2N/ > yaJ29v4Dw/Z3Vd2dxdeTTIzeuBW > Z/TArY6t9Fg7zfcEhrfHIfPW5atqVtiE31cT3l0y+0r3JJv+ > Ch1Y9KKU9aKUtauUtauUNbv18sbu > MHW580ubbSllfPSeKXP8WLjM2NKdXTbniriIr1Jm3KBrnGGzl0gZdoqjNfR3 > 6ZCzdosdGHUvg0cY > Vk1mdunORZvCScbGFtC1kRJs8sZvxrW6OCyVZdcl55twyanh3e2M2e9TR33x > ENi6Rfp3BbbXLCEz > aom6Zq9fwuqoPVnlyUfTaE2W2hHuS1Y5GqOuRlTxfblpLFp9O0L+ > uC094iGwteQFPnRr+HTFZ+NL > 6N4YazSedqT3HY8tmdmlC34neWAnmaUyJqYVe8Y1mE4bweCdv6pyNavKleOx > JTO7dF/Ms9eEk4x5 > ErqzyuZUrXLMtwaj1wtdcr4J53Z+bpWreIkKueghsHWq9M8WvipX3Emm7i > qqM8tvMAPbxdtqieeW > xoyRWlsaqdsuLmNbKUWrq42x963ggTTubMvKbT/CY0vmeXglz7tN4JFkZpXuzG2M3TdMD > R/jMT0W > An5HNXylGrpujKOb3WIHXa6T06qvmbP13XyFB33p9nbp7Uon5vZ2quE0Mm67 > GSfsRQdbvIQQI6oP > q93YKa/tdSzKbPXR21ry14/77x3vLFpO4Pt3tYluf1i87lnHSM9VL > +AcgHeS2UW6K3vppFw5eeTd > Lm+xB6ej/HrvNNwYuUOKIfjW3XyO79WHxhF3xIjWcMRyYnzf7tbo5LrXqn9BT685xo576 > gtv6gvv > UY26N8m4B98euZWhjlcVoz4Fft/VldTHmy4535Qyf+MrNH5+ > sftDHr3MmB8CW27ba4iG15Vnejkx > d+nxGi5CatueMwoB+1qiheq17cSs8t59fOdXNdvqdUUvbdh > jaezVKHVmeIhfvqFsx+91xosBwPza > nTKtRvnvzdv6t7PufcARxu67ryt06c4lm2CqEU5wwMkA44ZzBTt7k1/ > cm6V9cshOIX6vJf76nBse > 6HZDMTRuGgl3nr4zfGIM3n1Vp2Kn2PyBHecZJSxwDRl83ZlWq9wm8Yx+ > sPvJOotZ9bj7dxnU4T2J > hmvUjPjmm/r8gt1wz6VtFpVc7/Vf+saOEUZPI48+1IL3cSUzS/Q8fZZYp+ > mzRnsXGLvX3rJ36YL3 > 7cIn2vXggJ31HfOoPvI6TZ9dqbHXfcluHGH1r59MF+ul0mt36ZL1OmK9VHpnqls+ > 2gAeKr2zxzpN > 95HNYz1bLqMztQVTbXz302aYS2AH3FYIbTecJWvZmxW80V8ly++q5Y3+ > ScbWKaFrs17Y9PWDnvCR > DG73X1fsNAPo6+Rc8JeFbuwvM4a9otW3HWm20I6fZ7ZWV0P3xWDvGBGfJOOrq0/ > 3qtXfV7nsGBxu > tPquS86nCO/c6tsaVWJnK2Rf1b2+QvZhcT0a23Zf1XF52T0jVks/ > rPbnTKX0aPV78ityZ3I0v7Wv > wk3jqB096h370VjjmxqlmQj+8tIXIWDi7w0AN9XL29J8BX9523L9df > GnM3gCzbCVWLwaMGLOF7/X > +Hrc8EoyK2Y4o+wY1X54ey0NPLZkZpfuXLI5l+KCjNfYIm5vz77klnJU7zGPf0WOfBz2 > ZiJTdmMl > JzAs3SgRoftYVM06P5xkWoxl/JUB2Kw2z8Q7CT1qVrxEwNcNYizjNoN > /lD5o/PxiF+mcUR5G3bLV > Slr7Gm1HmzV6Xq3EXx7S/M0nyo3ocYe/RgPcU4+LW+atPI3RoscdQzsBY/ > TocYe9CYNUBa4hA5+Y > LmLzt2XS7flkd1OPO0aVF0aP+vK+aTb/4HvlqTim6rB96W3Y4z5xtzx1bd0TNm > vMHv1e+sV76W3E > UyUztnRfWZmqmR4XsdZJnRt1Z7IZowy/Nd5mpMN3NnBzueO3O6/1kw+ > rvk7NlYa9hsPUWHvUcEv+ > Usqs/eq6MZ/s9hJrtWVhk/fWS8Y5jOBp7dpYLVZngZVOD2m6uZ7p > 6THOGUsr2iNeccZfW6NwYJUZ > D4Gtu6V/ky2Nr4f3suCxY3Xcvummb5ZGHyGDdO8YJ4RN4JtkrtpEMa12KiHSEKMM3P3e > Yk1n7B4z > 9LGTb/aIVYmxZ6yhjT3FY8+WrU55Zi95w2fMwFsla58qq5rvxV48a > 9YpapFPiX3FD1ur1f7+Pa1e > IcR9cEqu+2fJB2eqXPuODvCI9aVxvFV+uj3m/SN2jI7wy4u06xO6YDGq8EwyU7X3rDQ > mHJe34KM9 > 8feUnzeuVuDH9Z1Y7KYvyVgM0PUcfTZTyq7tVfUu/NoNl3mMXPcxdZsvBVcr886BMqm2G2f > aPFW5 > M+2V5ac94/3l5+EI+fjN0mI178NduEYJncVbr6dbYhX6wzE > zCfxxCpnZpQsWml1FXJDR7nNiChYz > 1niBUxq0j/bhlIY1hDUDm/Z2M3XPUBrOVhrOFg/NnEIXvHcXXklmpjTkfbRZR6wGzRrr8 > I9H1a7C > rGodZk15knaqZq2xOvtNBGOF+MOxQhz48XCZx68m31ftj0dckOlTur+ > ZXnm7ah1vxlrHw8nbdW0x > XU1M5xXT5LHYd+rSBbvkbY8LMimnqr86/urnbLV5izb9PUH+Hi3aX7+ > nVh0hnletzmx3TB/tATuT > ppW72WZP+Ga7fJGTOM6C4K8b7fo3pY1WcNrLTPBa29GbBX4pb5rFhS7ivtGLzF4k01PZ6 > D5GOg/H > jCDw4+Ayj5vrPs5u0/krNb3HvjdwjBgiBHa11/NN71WCuq8xPOxe2nX63R5177hvw/ > A23OPE0Mb7 > GpyXbr2vUbfu/MDlAMJFMm1IF6eZzCY4WFzOh+xa3OxBbTt5BCnb3wJTv9mj7hE3exj2 > dTjqcPWc > Olf6Nl5FSu3kDlJqp3X2its8mFI7ubP7SbhIpumU0E4ng8DB43I+ > ZNftzosfS7Wt3rzhjt2dYZaW > /MR7Kwy7L4+fsjFdjrdok2sLu/eEj2Rwxugo/20lauseEDCNOzKoze8P6zvoWe2tJP7 > OeUzIU3sX > ae8u7b2kvbu0d8naz0v29jR8vM33Ne7LoDd28ve2GCDDNpu6ZUS+ > 8Y4M423lAueHDPO+jBrlwnVx > D4TZ3EtxARuH3cVtbXGGTX9FEl6ydSmw4P0XdeNWkKU6ZutPm+ > 94FFk1md2lu+PuDMNWRiBjZQS6 > VhamTjkxLsPgkMqL64Kz2XT+Sg3P1TLm46395umhGek8bYS+ > jTsNqyTZu97UHSqTx9+mi5CwyrEd > LS2Vw7OLrHImR92tPDzRYgy8LNHC6m2yepu48vsOkykrfGYnmODL437VKSf4 > 3mVw3sd0ccbHbAK3 > JGMcoGvfgrCcX54po4afdds8eVSUBo4LyNvaEuDdlQbzBnRP4nFSfK3wTc9X > r5qNSe13MvwS8Nfv > zgk3SnBu9OyaVIRw73PzxoupvIiQfvyuCtPoS3hEH9QKR/ > vUtRLxduJsNLlx14Th9y25y+CuCdMF > vzGFe5LpRbrB9KX1nfrx1NXc17bKsQqxv0IMVpXrSsD2hvPGmRvH7yyOl8Dj > L0cw1a0eYWuPIGP+ > x4kutWutWu+MGzkM49aOGy1w6L40NLVxERdkWowKmn97ytjaiXrjJ4XIblfh1cR0Rr35cA2 > mNgIE > U8eIzWTAYi6xW014J5m9pPurHPdSI6+6ryFunliqkYZeot40G8URt2gX/ > SwSdbt49Kin0Jgpvvkr > vpnimym+leLbKb6d4jspvpPjG2pt27BUPC8P68Nwhsb6NtzmoH4uZHD7QyoDQ/ > 1cGy3JpBoxusrY > 6Cp7jsGhq7aOVKOHeoW4UYO5NfjaH2OeO6fzFqXzDMWxU9w7cdoq9y6DNJyh > tN2SsGSm+YW3V0SP > 3CbXyxGX4zEkgxNBJaXtnoSjfTx+/0TdeBHD8h83QnBHcPNeClq9N84WEVt > 7xTsxUk8QVl9b4trp > lBLxiPGcaZtut/KiU1BvDBP43RThMntJdyebO8W1Uwqguzyfu51d8ny2M0obt2OYx3g7RvIF5 6 > yG > 0zjE7uvIlmxmgVM9NpL0Uz0oY7uq5du+K8GQLVtbo++23QfL8R/7y/ > bgIGX7bvCgnbMB9lu/TGrd > 6FePzwI235nwfDneQhZh3A8xVRddFyyW6u7ZScZndbhb4sqmzdgQl8/ > etmTATbO3sOn85ePDVzQT > O0/n5TkS2Lrmmadxvd68szdet4rws+QyLw2ui7sr2hbuSWY06doIEjZ9hFCF > wcFkwG3EvCJsOn+l > 89roU+wixPKz4VTOlP5RKSO2+WsvXKcn7lEr3lkhflHwbPViI/ > K3B15OzCl7OU3Yy+jxdzZM13uX > Z3PGmKJzbQ3tV+B3B4HLvG+hXfd9ie4231fKHhfwaZLRTCM4w6ZmG > r9x7p174ykY4LpjJGSvZ5C1 > /97jJQ3DVzK8PRutcW81xhcfjrlPYN6wEWOH0N1LNoFP9AjBAS+B+ > FgD54B6Ts2Iut3tpfFXRnrr > 0eb2ZiOHtyPv+FlyGTAa8jW/pDY8k8wa0l1XNndTXLuJw4q6HbrgPK > fwSHUbGj+/2EU6b7STvVfZ > 6j3VGT/1s3kCKFZ2elrZ6VrZwV9cz6OU2rTu31CjPcXbED+Ooy/AuRZjDHzlc+ > 9hcFsCT/68VZK+ > SrRLwlUyOH+iniNsAid+c93MwtrEvdyqzQH6asfnAH3ZSHbshK > vf2mBcbYUGtznMKjyaZHrM4rud > oY24vOQ7XlsyuGmiR3saNoFnkplbuquldG6NPD8co7u+NQLqS2uG3U7ckukZYnqqmJ6q2M4QC 4 > 3U > wuZeiuvJOAfcBpFHlX3z7BJKsp3KpcZIlmZNOI08u531Jc59XN88F4dyYidi > +bul4psj//59z2x3 > x2qlSbndwzMtxFVl8VS1KbbLCO3jO8+we2zmDtxKtmtra7A1VK591eXx/ > f17zXbHCL7+mgNz8KyY > 23Zf8XjlOnDlTRpeEs5VCTmpRecNpCazY4zfz4oxvr1rwdLiGHd4LLXWR6ti > YZM4yVz1BjevXeA9 > Ck/njbVJpM1CcIrJ1z/Pw6qnPoYADv/V6fd/wK7d/2G4B6tvQha1baQeeqT1jRG9+ > 0m4SAbnlGas > F4dNcOhHuJ7Mbsd4bRTzGX73cWD76/ed6ghCIm0neXPUuryVGLVGCzCq5qcf > jhYg8PNAVe0O3b1o > M3BLMpqf+vkk2uxXcfUrDj1GEKELzpqfDr9BlKmu1kMh5ptawwiBrbOkf5Ld3RTfWuLhq > 76P39zi > rbY3ZJDOldK/m/BJMmdJN5jiNpdavLaO5rPBnfC7gUU9zGg9xl8f7sJaG7F3SZiaplnyaJo9B 3 > 6M > mkb4obuXbAL3JNOvdEdq2/ESiOdIb9GGjz5ijDr6VMzdx7r1YZWL > rtUq4SIZnA0z3VdH3CY4aA5h > HILdVa1K+2Sjewl5Mfga+5M5KgmOwVT7c6GLlF3lfr/Rm49Yzek8S+ > a6o8nmaMqnoZVH4SIZnoYr > kXq3+dLocXl6Y6Yz+Iqp4Z1GemPaWi/OazVr0XEDzQo8exqNjjljNj+ > mxq9jpvIf3029Jxx93/Nc > 7XsSb8Pa9zxH+57voWvf0zxb+55nnoS17/m6wtDt2vckB4ur531P/ > GU3LhBz7IEYBks9McvV2+Lw > mxUOXjAw+a3bFN4lHIHPlsxLpX0HiNTbt4LEHBdShrXwHdr12xfeZR41vkY87/ > Ztu32B7HZit+Uj > W20LeWrDrmkjPtO+S9r8/YjHzh7ju6yGU37GKUL4xs5HEnuZA5c > 1VB7WyDoegrv/2dJQg+tdxE0p > XOYr6LIlO9ztrJEXjnEnvsnw1YAbzN0msMUFGeMA3ZF9sNagD14M7AXsdyt/ > 7e/fR/bAWvKA3ZFl > Ibgx0kL8FgemyUKQ1qtyulhTD98gaML+vTY0tvHF3uNUubCzesRjhFXbPaVuVx > 3kfUL0rGO+VNDC > a6770uA2r+5/oIxxgG74hjudLTywfY3iYP/UQrh/WsWb7S2wnfODjI3SoXuqeJya4zu9RU > 7yxVn/ > /URO/v69pfx6Pzlbf6/W5LiCzhCfxxzuY5YI4Wqb55KH4E79o > jLPG3YcF6WQMzPoHquveInA6jFe > IjCM1wS22hnXBT+zSSwZ54B794MpeHMGzfT4XRSHO46qGfY9HVrme3u02Del4XJF+ > fAmhh0tv8sg > 7qt66zaxb1mGsLWVuJ2+RZ3/cNj0ncTDXcVo34WLZLgTur03CZtIY1 > 3CZeTU3yi9rVi/hN+9F1iO > /1gcrVz3l+8FQoPv0xr2ngw3LIzgxxt2yTswdjyjfQh5vBDAkczhHqT5vShe7kcuLzu+ > Hwk/Or7a > szy8s1954Dxx+/+OsmPc/ngMXJEmXi0YBX47sPNGCmzfESlrswg > PpbJZb4p7+VMuN8tBpMZLwpYM > UqOeOGwCzyRjHE7w/OMsTtTm1k7U5q0Q8DtXvG/U7I+GSqHtfULXTq3Baq+ > pFcRfbpX395ulJi/1 > PmV1KM95f79ZHT6e4N5ntIK+D2q/Ryv41+/ZB31FK2hS1qK1wVkBmNhYFRo2VjWsf > PRxHV4tMJ/h > 1YKjUukYLw8clUrXxZ37pSYsGeeA+/d9hkAWPItLphrj+T0Oh/ > uu0fsFhqXRFMNQ+zSm/D1WkllH > unvI5l6Ka6tEuwxfKFA9d5vOP6XmKkfGjRzZCpnaI4XGTDliZ+ > co00aUHztfB6uzpT6tzVQL5kl9 > WoTA1k7xpXTMVNtt35K6I/o039s8aZ8T/nOZq5sfyGJe4ZVkUrskpmDBfcqDvWD > 1gn6Pw+GLAPKA > namjjPc4uNM/W11dnlEI7v4/KnH2HQc1dhVeah9sBZi6mnnYWwH0jG > Pc66+ZR+jyTQCVSo8LMlvt > 4zq5ddg2Lnmps9VdaOwqS7uq3O+WRrttF2sDcONCrnPbxkh4U8DY8g2CG > amzdWKkzvFj6DLgkXrX > nVJqX45SZmtMsLd6Bfvik3F5/zgkA24pR9ym80+puTF2t7sbvMfzEOzOptbuFOX6MV8CN > 29d34mA > Y9q4b6BoVHCT92MvlCHcP2fI1riFdzDa775//kJ6acPHc+3ajOL1wzFqO/ > r93eBc1HL0UkOm8z0j > pLT76Am7k94nH+F397bLvDu5Xfcu2QQuMSMLDreI2yuV90adw14re7OxiZ/UqHEnw+Ee7Ha/ > 9LK6 > sK8UYL+3SNfGNrBpPRD3UZdSbzLYg91bKRhX2G7LZmz2NSnxiF6729ebxD3y45ORf6t > qyYejDQiM > NxtUS7qtuIJF7UW4Ncm439/+qtX0d+t79VtXkP5q81fewBCj3F5PldWTy1e9 > 10tk513XxK2JX/OZ > N3ZkY+WjN+91V8JJBvvIPXqNsIl3Fnr0nCGP/Wizg7soHFfJYC+ > 7R10Lm56WaMUjZYrZ02znzIhb > jG17r9Hbxe8Tu7Y14SSj0chnM0bq3VZBkedd49OQwcsHGo2ETeIqGc// > Im54x8BX3Bmyj68Z9Vi5 > W/w9LHn+F//dS0w3L+GuhiJfDs3LdVcFQ3rMpLDTHBo7zTZ9 > j5d41fDxnKo//vvUbjHxTjInRlt9 > as3Rd5rhY8fPxy7zUu26d8nmXYoLMkuecW54TSGvRWJP2Ebh3e5ngvdWVQuw > zGOvBjh+lpbmv6H7 > WCy1+X31JONjqBH7zLQ5h+IyDA4mA25D+eE2nb/yfFn5F7tI57lKp5UZaGzVXLufgpwMw > 5LWKEMX > aTsq3etKZhf5yMcuz+auqpGOx5YMdtPV24ZN5690ptFRjzuv > Dl9riH64x3m1w/caYl7U94hZnO+E > E0+1XfYNAnU1fjP8J4WEVY1Z+tbosvNdJpO5VVY1j+9xvypSe6yPuniVQb3m0Vy525cA/ > N3vYjnc > e91RQ31952nY2S9iv9/oYO+1LF8f8HsYDvZhHVe/kwGpGEWrw8O+ > wjRcJFOjfxilxLxyFK12BH73 > YRfNGUP33WLtNomTTB/SHWn8j53hH9eYV7kVIeC3tnjvLnya0 > mDeg+5NPGLsg/1GW08CHjEeEX53 > Rgx5pnbFXHsTbl0yNWYeo9ZoHUctMR8O/DzgMrdL9y7ZBO5Jpm/ > pjjSPHXVFLzBqrDlw77V5v/vh > Ka67KA17CZ/U0o6W7Pq6E/ARq6YVyNFs3HnenuxV+elF+ > RO4SAb7sDfGFGETHE4TjrR17F0Wbx9H > bzE2Hb7G8+7g//17LnG9RX01qQhJJc5HCc9/fWylSPPswM8DLnO7dBGD5tmja549+ > u7S3SondoKe > cZ0mDvvKk6kGdK0TWFzupaG1d93NAVseMnXnx+E7I7Ibq1Endk6pq7XQD8esJTDe8Cgx > wgpdsKhT > uCUZ7ZQkpojBVp2Az4naGvjtD5/E9KiGjlS6Y1UIr43Iq2MupcbHjkcYj > OYS01QX3CbwTjLG4QRP > z5GpdcBhp+mJT/THY17FPG/s9PoNHmC6tIsjXCQzhnRxc8hVXfC4n > I/YrRGjK7/jA5aWl5DiN4RY > zE0lwTGYNvUTK/UBbvOleKlvHEv7Xh8+0l1DNpfyyfcQ+ > apJ4mYy4LxiJhs2kcapNmWNGHEsvqfy > Y1irMB33eEzvoUda9Rg+5iBWedxbfWmspOC1DNUWx3g5Y6vl8F > HJjfdBDM8hGZ+zvtc+Roz8hr9r > RaZ8X9xwiTHrSOsr8TteptD6yrDbuCjTY83Hb+FAanz/D69sdOXa0Rg6dF8K3Caw9pmDw0uNc 0 > Nq > /K2ct+CAVyN+Ho4XKvDcsr0ygeeWa0c+fzheqMCTz4FbDZl3LaTr1h4vVOCzOH > uhwjDfL6MM37+i > 7k02+b4H4uK6OjkELiFDztRlWmiTaWRckV6kvvJrdbx6UvN7GK2c7aczaJfvXlB/ > 8M0QpGHYbRsf > E5zhwDszZMhXqipfwZhi7p6c/vtj8r5QNm34w7URh/mYv9MfLq9cnJ6L079Rp/ > bsHgfftWAcwPMk > 7qtZ7HEmwXUsBOx5csE0+D4LcVEK2TpaHHxVG/nHb9A/fIT5zbrKgeuCRVEqLC7IGAfoBlOkm / > cT > MvfthT773UpC+/v3nj3AF7sYn7/YxRC+CMsQf2ERafIQ+GmrfC6+ > rkVtvq5F7K83QWPzhTFo2MtJ > hS9XSIPr2SbDl5moyzeEwMJecqr6/p3ecZnnNdftK2wS9yTTVYO3v2YGT9n > bStTwt5XewpyHkJ97 > AF+Kb+Gj0rEt50t8lW5Wb47vVLVJ9nKS/X4iJ3//3lJ+2XtPsOvfpZtc3wqxLxUshK8fMcRfE o > Kn > LQTs7W0jxrJPwiVSeNaIXDpT7dfxdvMI4wUNr9NdumCxS8JJhhyoG0w73tA4 > 0Qb4Lcj21xnhz7vV > XvKbcLajN6WBtyWRt+PXHpsM4jZdcLpbpesepYFr5pBppUSd > b7wFGTZb4dtOL65WvE05CZeQeZxd > 96XFbTKNVzXbb03GX83eIX6MgP/133t1pob/WByVL0kijqq+ > w04WGF49eFS++0ndcYJ3YHwxHu2D > y1e8jWF9Jd7M2Ob3EvHCLzzJi7IDbu5Hx3irwvvTFTyJV5fMHNIdqSVrjS+ > AEo8WjAK/kxH9Rgq4 > Ws2U8USD4aZU8qZl1ITWUi43y328SeElYUsG71PUGDW4TeKeZMiBuiO1AK2t > qM3A0V55CPmtK957 > CB+VwmYehu5t4nFbtnqjFWy83YeW7IVk4hqtoJ2eoC7nybTqc2aWsD6iFWycD/ > vv0Qr+9Xv2QR/R > CpqUtWg4oRBsbcQEjXMTLmLLl96g29eNfPSRHV67WMoLl8FLG3sqdacknGRu > tIZ2esLTMHoPpjyp > ailo0fu1UaP3CwxLLXq20H0x83St4ZFkxpGu1RPYnEtxTZVokyG3VM/ > NZvBPqdnKET/XyjJgIbSl > PsZexzB8YwxupyeoO60GPauzpD4N5xA8vulvJYK7hdDWVHwzpWOm2j579Glt > tujT7N0M+skx3qto > 0V+Fbo/3NAyPJJPapWBKFpsjLLyosZPGUZvAL8MN3xgt2+ > kJ6i47Q0irq6p9iBCkbi2VOJ5cMI1Z > hT2Hj79TYbrWn1ScyjjhGcf4It37nC5dsBhqWyyuqnc5THfl1mHZiAWpu2oV > 11X5XlflfpeRPXCs > DbBTEgrZHCMhddvYvtRtz+t3qsDaLLw/YRivZTR5f6fedaeU7qExwZ4aE+ > ypXmEv9RaOwcFzJE5t > GOehdnbHuA5/7Ri7N//CzuzuGLs3fq1ndo9yfd+Y49jpiT/ > Wsx/z39nE6P3ft/RWeze+n9/RNp+r > UYS9YAmZ6yOb6icpaPNWS1FP+IQMav5NNf9oBGbfy3s5uTvGvMDBIuX > JdZ9VvPnAscCT6qUvadwl > u71o3cBOMYC5nW7AiMFOPWA8E5hfp28vA67LmLU+YKcYTMbGP/ > wqvsmm1XbEZT0ZONzmHnZd47wT > 9t7SNX5+sfN0Vr7mDVs8r0CN6qOb6mcXyMnxs+QyLw21KW21l4STzJjSnUU2Z1dcU742 > GXLTSMBt > Bn+ls85oNbp/12ZyGvPaCQrT2PJx3fK9Y1jaU2lQy9xjfIqzF5LhKV7qNp+ > 9vnMVNUabjsHBZMDN > dMn5pjT7W/Ch8fOLnafz3eFj9aHzPh/+3hLXdqK3XDzJ8OP4pFagDxuhvf3XMZ > QXtkYEuzb2IK5b > MtV8HOcSzGaJ3gVnF6wdDIy3MUrzdtN14VeziTRYXMTqj50bdUeRzRg9gilu > IDbtFasWO0LAb+wY > 69r7GIZPjI36uDHWtbc1zKq/to6/FufsiJunG/n7vDFfs1MN9vtKbZzt99Ovy+ > oB9sRHrGHal+7k > tMwHeGnC/VFDBr4xXfjMbJLplI/5NbzJrCPdnWz6nK77KxXG4SRu1i5xH > z96B7fJNC55Ys00W+27 > n0j97qodvnYEXGO2amcLLLZ7xOLG6K9vrba6PGrlrspN3n/ > ImmvxIpW7x7ygpzWlwL1L/nkxrUc5 > T8oUldSV16ztRQzDU+XcT0WiV+8842n4lKTP11kNVzH5hWcaF9pJBMM9 > t5u8/8Z0Ti6VvOeH+Jar > HMNevuXYN+GJPsn2/h0rx+4d0RbecyI3rq8LLOGWZJ4Xr1bZ3Kbh > 6HfsnAF07ZwBcm8UH+ct4ZJk > 3isHpvtKits0rD7LOZTETZz/eIrnlVesZ+OphqHYRvUyFxhfu5sMUjOLUjmv8Eoy > u0t3X9k8TXGd > Jg47eiDXJec1hGfqgaDx84udp7OWmH3YuQT7XavObx8fbwTQFm8FxChxtCYm > rUeb8GGVozaSjK9N > PV0bP8Om7+/0hE/IIJ+b9iFG0zrFJ59mIjhx4PnGUwYWw1G+ > tRMjh8DPMy7T49SDxaCdgNHVw42u > 0dXoVfnWm/Kta5TmMuDWq3xtNoO/8q1X5VvL64ijz2hnRzcP83xCV9yjiJ > P3rkMySMNIaZtHeCUZ > ja5Gt7E9bNroCnFplOYy5KY1TrcZ/FM6NbMePe+EDJ6YNE43RkI7QlBORoneYgztBQ1bd > 6GMr9ng > 9EH0m4b/pJCw6qsOk9+OB9Zqy4evrC6V0BE7Ex3fl8csZvh6C > aR8BIdWbVjr/fCsqY8ZC+fSqbNa > LgerRO8z1q+avY7ade/Hz/A3NFiv14p1wOHjh9qF8cbJirUU10Wp > WFrXHUurafbmhsncGMN8w7Me > NneJ+fuHYy1JuIQMOG/1P26TabxV+EQfib397ePk4e9UMfdOXd57jqO50jh > li5PGumPbvsGTsfk4 > dGOejvMCJ9ovxyfJ8CyAeG/tD3hckDEO0D2pHJ8qDo5b4o/ > 3NTQDD/7EktnarzFu3sLbblTh3v6O > VvpoJvFh1d8zNDo4K8ks9Q5nqV061g7gLMBWrTQZ1J+j2ffHQaXr2E3PzM1ze+ > TsbbnPvhpJjXsU > x02l3HeKXpt1d+wOuzxy/J5YSQz8POYyeP9jx57AuEvt5vU+ > Pt7/aG/SO66v6OJ9EZsD9qozD73q > zENvOvPQu8489K4zD33qzENfOvPQl8489K0zD33rzAMxdxYow/kmdW+ > yyVE44rJzDuAQWGceyNl0 > q848MI0Wl6eXqV8689BPPvPQeeP+pF9wOmEpbrbKxPRqH9Vvm/ > jwkDx4M0c67oKYSqfL8NaKGn6x > NXPiLh/ZuYv+7oi3fgUpGL7C1XF3BtfiyG4ndid5j7Uw5KkNu6a9u7TBw7Txu2m7vDzGG/ > 2pMb3N > QyyT4z+GbOeLG/gtpMdN/qbBVgOY580ow1elqMs7JWh11cxkzRZ > 5Z6ccUCZ4FusrK0+7K32rn8R2 > NeMU5yXC7q5RV9ZWmbIzDu+j4L9+r9kuXvSyGO2mRAu5UyF3Jv94CG6iL/ > KJnW0grqqdNn+E7m6q > edtbKpRJnjUzzFaIGo5rnFqg1a0SwzNohqfqwk7lfw/VW54jY/ > l3jHskTAb3WZgumJpN4JVkjMMK > nu49OyEBFtYLgcWxVoK3+x+xuGqpXAb3NZgu7/BXLeSZMpPhPJ+ > 6nHHAJm+dYFyOwaGr7LouOJtN > 559Sg9eLLWa7X4+54yGwtZr0U46clGt8fdJ0z1R6Tm7/72kRn995byEralErxUOm3ezw49j6g L > ET > fmcZZqTc7pcHw2azU2LzlO64h9dasVLscZmXA/MO+uG5Erq8s34KjyRjHFbw/ > GOxVZ4VAYuqOtZ4 > T6vhc8TU/fqYmr/B1EoomKq0hgxYnCZ25whfyTgH3A9RUp/U+Bo1NfzNaXreQ5AG9+rTGFXYc + > H4 > Pf2m+/839h1nuuW4kvu2okygFmbMV0bMpnP93J/DiIDI6qo3vbk38j8ACIBagTP0qDO1h > DiD4ent > X+ntlN5ZkcaN9FqJ9BjPgrxawe4Ra9/Sa8N7LzvRAC/rpEOfHkuCXm5RG51mx2kIpjBq4Jlo5 > AHG > vIgyxmiwSmuN0GHVsGaGxS2V7TZSL4SzE+a9dlJ73zrnAJDVa5T7XiLtXkInw4ge > UaJMGy/i4New > uae60XuU+y6/QKbGMUhLGDp0H+s4L3RuUW/tTqKouF/U34kfRgH7/ut+ > rqEjHoXKyIvYrrMPxBoR > MmaFSUWMf0l9bYlxI7UTpcq4QbOihNn4c+LVAZWRGvhFW/ > Ex6grenWTulNZOFoD3pnbyy/Rio4Km > 2b9+91HBX35PY6PGF5+YhkUXY67w/oTw8l46cH04PDNWtF1jnsDjBg3nUJ3 > vEUTbNbr30o75rkG0 > S8YLTUfUYUsLNCvarrF8pIdXAXyk9+GoP7MkTW/S9Ea9GGopX4Qd+x1a3+ > X5PFUXZpK/lK5pZBiR > LFJ9MR348kHQWFqw5uSW+L16ark270p2rspeGngUz6mVcmFZ34h > TDfQ2TjUYrkGDUxPD5zIuE7j6 > uEnYteg+opRU0zyNQpuNVRHJ/1dPs1vYl8aRbUsrxFNQi/ > hqxLZ8HxabgbniONG8Mmy8Y4TM56Wd > Wlmjx+kIm5nuhGvQ8KREdc+YTLMlPGOWRcpuM1f0KEv9GF5LsL6/ > JDyDBrqqJOINAZujvDgTNew/ > mrXhFQTN5hCLImZ2ToP3CmrUsRNznbZTCTUddtINeaDxHvLAcKKB9ZpjUecY > rZ0aLb3p0JNubQTG > 2wg1Sqfpaf4M755xfTR5YjbadM6XOLXnZycvHh/J26kS1HPDK06e0HM7xoAn1h/ > aSS3VsRbsWTai > vbBYzixrt7AXwnsGyle8Z1B9riD8p/21htt5bSyBcyWRI9dO36Au3MuxFGJa > NG+fu87kdsS96J4n > vahNfrtbjhMN3j/ong8uExrdpPfdkT+9TG8xuo3j+bqB+ > 7UXtYcb5028xvcS7XDgRAPLoj13mbDs > en/u9DjncldYeVdYeXtYeUtYeZLFeXzvlkXKZnOd1fKq12hLhY2/Rovea88+ > 45sA5NEJWv7evD8R > hiycplBe48SFjwNepIbjJa13zcOfjT3WE3rn+XPiuYJGY1Dwao4NmcNrdU/ > jPceIgyGad/vceBnX > wsc+nhbw2kGze/DuJDPPI/sovi7URzGbx44vT78RKxqdNziFVXpB > 03wU1Ef3mZSwamCf01fuFNlB > v3fvE/qMOYiwaTuvj+b6VMv5/Dq3t4R9bh919SkfPL8aRuyL7fML50U > si5M0uuFjW+VCfP/iKxRd > 9306o074umJf1ccTgUvQtBG8fLnBWy9Py+xVe4cTF8etXzuo1opSmEYmfWlMCN5+ > Qovu/WS3Vbee > 6PG2w4jcXDFO8HRh5fZxKXRzr+wT3opVZdeT7zYkj44oqbHaV/ > 09A1l2o5yvPKrDX9YG7JrLyz7e > r3UfHa2/4JNGwn1rdRJ4p7HZV22O15TTspZHaxR8hyB/uT3asLuivt8xA9va3Dt/ > MH2u5/SI5r/C > 04bxGsAKL97pvUe/I9q426N83+4jkn6bj0g+nCwdpfhK6jcPbN7SMwaFNLWevgSGpB > MtkPEi0n6p > CTvNKNXHWsNXk975huZeccxTH9XKt/NS552w9SPG8fNLO7dz+ > OraKCvJ8tlE24ycoLZ/MGooqWrM > P4VNbqu+azOaVgSwSx87I4Fn0HSPPE+7dZ+kI0KCrbI83hitfNhz0fFONIxI7/ > VOUeuFawsaW7lI > uiFuhK3NroQTDXQrO3SuM2yJNVXXoSfd4JPuu0JOU2foaf70HmR8A0WrU8Du > CZX/iZMYJXH0GPWN > HitOo9s+Onm0Sgc8rX1B1PhVvZz4GUN+GV6/x6/9ljHr9jIwq89XxtRa2/ > PDLN57fthnzo7fXe0Z > 643O+/JrxpwDaTluN2j6CN6RZI4eaY0VOoykW/QdzgtbeuSLpWX2+kgKUe9/ > DPtI9sldWmnAiQH1 > jDhJEHOWsVrUxdVL4JFo1MKB10ZYT+b0UWrgEzTv9Yg1vJcfK1YaxvJch6bq > bSF1p9ROeGPF3uVY > sac5dCoRNLv4+HjYzhD22KuvMwQ+QTPiXAS1i3nTsDeDlNr09lrRAJRC93 > nv0DlG1F3DiE7Qo0zt > 2N0cO3Y9x56JZkV7rXu0lLmjvTYMHXbyRGpjTabpH+3t3t5eSzsrVdtWHRFLIHtA5ySJY/ > 460vx1 > nO2jm5HmryPNX0eav440fx1p/jrS/HWcFTUvzV/HmT4XG3yxiPb4/ > PUdCLfd/Xpjd/81w7ZD/7oC > 27lvNXb3W4/d/TZid7+N2N1vM3b334K47e4Ts9SShqWWvDfJZ > FuPtLSjDx0cx+4+ddap+Ru7+7RR > tz1v3t1vI3b328q7+5D7dtDfl3f3WrvpDfEJWqRhJ7ZuinQ > APBINyzB5OcqiTJa9hmgNhk/QvB1o > nR6Av3Rbj9jOTrYaO/rkZpl6nbbtyfN3liOnJ/eMHX3kg3HP2NHn7+ > KeeUcfljIWr7Dlet7df12o > 7fsT2z5H4z68Ul/EwWNfuCs/XXu+9WA4LFR7TV75ihEQ6FucDRDm2YDr9h > kvtJBM4kQjHcA7sw8W > 5/iVsQyalwK1le8xod+/r5x7i/WP6XnZxBee2+YXu/FPm/ > QFtt4oO3xXgtw6qUZs/SI43qOM5lm+ > 6SCqmThmCaljuGd1Kr0xAsJ0zxrGGQHRcG9/uDdNJnGikQ48X1CSZzdi4YjDxsOoGf > YF+nHFCnof > 9lXENUoHX4UjL994o1R7743pnX48J4/OS+N3nZd+Ofnr935SfvG1OMkduYQc3pPkFzsNjC > +XNznw > 5Vp/Ck/bl6e97r0hFd2HY4pqK2EhVwrAq16jMQJC9VwyzP3+ > 4TlgvNDvRl2wtB6N6TB21hRUnB/T > np36FkQikD/1/gLb6as2uxaPREA7uXIHvQ2PGjRI+3rJcZlzedQD4laDhuP/ > htMH3WXq5Xqk9eFr > OgQuQfNuPYqXtuguB2xsNXAt2Xqu2lKjmzg4R+Dvdgej8d7/cH/ZTa8b++ > TAdksMkRE4CgSvohhA > b8fToyS0muhb9T35hngAqjW9eLqNcQWalZ3G12DpR8PYAS/ > eL5mewNITNJYuzwWklgz//BheOzQy > XH2PHRYw/h4ta9ZrYl89rFQUhlcTbJ/f03JrrCTsoJkRzYHWjMgnS2v20GG4n > n+aFmd5jje7rUF7 > 9AX63cgdxT8QjlKo+Afg7TX06NGS64tJZcxBSerhJZ2rJ82 > IPNe5ekq1M2woYX15K4jBo5U8reW+ > VvD37yu1gvhiPug7jQLaaOGDoRrK3e4ZuHhr0GyU14ZHPWiMgBCl0jDPA0zP > I+OdK2QC10TTvDVs > w3YAqQXv1lCL6b2fRS5ojIDgvZ9jSBrRPhkvUp7hb0bsE82OejX2DZmnRVon > SrTRQLdUz02m6R/W > zOL9EnCUH/uCiATFx1VtphzhuxKi4VybvD1qyrTVdZSHeWakd1Kf5l8g60TJn8kOxgIUjX > wG3ul9 > 2oe9T3M8dtDMHrzQYs3AO9Gkdik0xR44by007JRHL6h3JShp1fDASj3Osh5H > u+xJag/PxBfEJIjx > jN50EMfegZfPwhTdQLzqT3hWYLhnDI8dNNBPvNBincA70ZxoH+19M+ > bu5skkWLdrtIo6YwpJOmNK > bDeqYcMuarGw657bzq0xEvbWpS321i2v8cbEcesM46zADO/ > v1LvuZKnWAEizY0ywT/QK+0RvYZj7 > +909v1OOmEzTP6w5xcfu7ZTc49kX7JGX6LV0U4LcNeriabnFv8b9cPcRX9P6O > vpLvqJL7jt8xhk4 > aNDGixe5K5nEaXR1SxrX9XdbUdZ1u7kIjuTvG/4o9m4F9OhaSW+ > IQ2AjKX9vQinoVizwSDRcTSOv > +mTIVG1/N2odn6DBHnHMP/SGhfBqWVOeyaPUk1LTjVFoEWsLHlXh > 4VqCplZfM/jwdE2r6kntCZ+g > eZrWGFPpbQvi2krStA5fodB7E0otVh/0xoS0mz3wSjS7Bu/ > uoeleoeleoalooGm0H3q3QnjfpGlT > P1M2saVmkQ0uIhVEjltkA2DddwaN+h/wqv+BTM0+a0/4BM3TVLdCqd0NrZvP4d5fvTSby/ > S2w55m > q7INEQ+4G0N8c83oMQfsPc8BO9/dFV75y+Aojl9SbveTRk/ > dVqoaIiD09OW9UOpfVrV2wOINwBND > efY8NHbUG8fVaWqKVUD9Vg3cw4ujr6zF9LGvpJp980ZrYfEr8fv01kJYrVx/ > dzV+DHfvC/qy8Wvs > DbfqN/xp0Yr1NqOBReJFyha5ALj6SLH7HRF84XsB/GI3+cGxI49WXq/o++ > zgON4P2U35hvfYreUp > D6uHHhaxn2XKcaLBG/bNx4Eu8/nCfsc79TZe6yGn7ISr08Av4oX+ > dlvPbIncNcsiZbP53X3DeKDa > O/KyzdZ6O+/2uy+ij+gnRiUfTn5R3kKm8hx+Gblc3Rrl6v7WSTfwQGVRxR7deLN7fR > k208dtd60e > 8BZ8kjXK8dW9YW0xbvXL1rejokg8Da/KC48RNHiFPmr2KOcGjlnL0Ln+ > xvfer8u0vuSl5f3Kdhro > VqMfHqlPGvaOUXD8/NLO7FTkHuiUegrF5jf+NtU7vl3T6b3gsPk69kB9ToxdzO4t6u > jRr42YH/MG > u7eoHgufPIN3rcDD0z3+pURejvHrC+cZ8IvNl57G3gq+l7qjdRw2d+ > o98NuhMZq3C2a8eP07egZF > fRe+Ph4es/jMdOj0MGRqzxRpzerjysAlaMpwXtgimbTxrsAxy8I74BwXNI/ > urlHpWK1aLf4a9ePl > y2Yy2K8sI+HqNIotA17FkIPMeby9cVyChnrf0NvizN3paYHGdChJN9PZ9bQZe6J5vk4zMd > d/Ytc3 > aGbsMUk3jU6wo6vRie3uvlbSdmipXYyjhuZVxCvRxDjK7p5Tps0YesJx572l > e+u0YERLsWIMgJvr > x3N299RXYSfT6oL1PNjtTKVcd/fQiuieNXLT6LEHrJVg7AHfKP3em3W/ > Mw799u6BV7R229bL3q7s > jFZtW5yYhejiPIe3077iRlRz9gubEdE7cewfCp+g4dicvCxrlMl2kGnZrcnFeOVox9bx+ > 7Gk0o4e > Uhh2vmpxTw+tzcKeHvukjT099lUrxTF3enBvxB8nN7Q1bqRB7p3imDt9+ > GniHTfhdp17Wnu4ET+c > LSWxnVuHLjrvAJ5VM4++LMYr7669zgIu7vGFhRq/MQ2eFN+ > IV85WEF43jHjlJ3LJeKH5DSuU1uZu > XXde1xR2L+7NrB23dFfEJW+L8crT7z3nHt+UUHo2LucX3mHkF5sJbsYrb+ > 5P1XP6ifWc3Bw/E1sr > DA7FmVqMVx7lQncliOtxqTp9QV7OhTbjlQ/3rGHsgImG8cqjXkgmcUs01IG87hvEK > 2fkJ3LYfsRG > zHF+oX7mgemxy4k5riGNcr5s26+T1JPTO1wDWoxXXjzHdKN2MV55+ > t3itCK9w1E55J6aW5PTI4+P > tY78woje/GJRauBpfYH2Oo/BVHbkmM5vkIb7luRVfUW8ctVj7MQJM > 1558xwwXmhBmcQ70ahVaztr > 2rEX17wNuBaBhn/tqBmKHoF2TbHIF+KVJxsu53Ob8cqJEa98RekS72a88qi3 > d4cNfMtTNNdbYIsz > vhGv3Epv91jki7uBrpvRLMYrVw0+LpM23igPfjdiIS4528anEfC/ > 7ffmrazwn0qjcoVnIRY5++PF > GOUn8Nymh8UlJ69aG8Yr9/ayMRoVbRP9RrxyjhU245XL78XT3TV2 > x3aN+Omb8cq7+dfp+3I9iaOn > 9HQZr7xHS9a0/kLcl2vkuPqO2GK88uKWaf2FuIaVOiO6sW+ > ZclnrO5vxyqtrZDTcVyxugWQSt0RD > HchrKw3UYnptbm16bd7+hfqtyB3dvCDeUQoVu5y8J+lhcxP/ > 4lJveEN7d8LeR9reHXi1dwepvneH > Etb78lKo2xYr4pKjFfz9+y8f9O49uqjUomEXzLTVGShynPCH4oy > Thr4hr8ZajFcepdIw45VHqTRe > aEGZxKnkSgfy+hjsaTGa95AWfxxa6FbsZrzy7lqMGBs4DeOVe+/X0vitaa2KNKMFr+oJd/ > dqpCVc > YqePug3vC0ym65+sWZEjfq8VZUBfKCv6GItdTnxbpHePl5+pGtTz3t1ivPKoBXOmPs2+ > QNYckd5M > dugELWma92kf9j7N7sLCT4YZr9z7K+eFFn0EHokmtUuuKbXg2afNeOWJI5Ul > xS4XvkFzNcr0HTqT > qr07cPgXWLdiPGNxw8kxZuAe7YPOgpG3TffMaj7HcIzbuaJhvPLQWzKJR6KZ > 0T6umVuHpREL9waj > VVwnSYrxdPOIn7Rhqw14+Fed43umtE7xxzfjlRe3bqvNwm6XMOO > Ve3/vvH157HLikWhGjAn2jF5B > sVyYlvWPsdNH3UbUM8l0/ZM1vKnMlHfu8ewL5O7otTR3JffZge0 > uD7x/ktwTox/FEP/T/uIZ4cW4 > 4eED3Xvh72kU4rHA3l+9aOaF6NpW05a9kA7cS0/jPETado7j/ > Y3FASfWWCLtWD0fGP3G/ljMkB1j > fyxql+18UdM9Aq8VNDb2iHjlmxHBLY8Y+bvYTNsifMOCGiVI+E+ > Oq3pVfwsO9VqIs71PcMtm4FWC > hqsI5LWZOfbKvAx0jdvgC8OtOg18UWNebjKp6SqBo8Uy3ch7ksyzkmWNsbGh > XVObgyjd0c93G4cB > txY08h14NTuCzOI91Ye9jXLcqtNAOx97dZcJa1r0oqYDafoN3pFkjjQK7y1W > KHovSeoKzN+t/Gtd > FxwjcfTj9fj9xdP2wKOl/q+P4/P2Puw2Kcq6vizuY3kd/ > 3ANvKLO6PQ1eWM80NM4wTHigIsG8cFn > aC6ZxDvR7B28pilsmLXZGLDrzI1+V0lvf/09rergy/PA2z0S1cYdU60GYF+ > N8yzhmrkZTxE1dnaf > RXS9OgIr5oiSr7M1pJnXa/tcJ0vl2TFy2Bd49q3XWq4oZjk4Vokc > 0notaKyvf7xaS34zJ/+9+qvv > LB2r+njV5O+mdM37hhGBvIZt0oFa36CZMXbtvmaMnFiMj8YUokfvWiem1Bnt5rLz8Mv2H38 > Mz7S6 > gYje5r9te1rwgb4sxhgPn+mWD2Vdn8N1GynA9ydKtW4R0U+ > p1TIaWBGjjJ5GGZbWZrzxKNWuKXyz > Yx3GX1OXDTH66LsnG2Im3dMowKKVkzfmJl3xPWCD4baDBvrNsMFGH8Aj0fRk > Q14x6jtWjPr2dRjs > qfLsC7H4sb9q+O1Zxui6cyWKtp1Y++s6kU6a6uPMT3604TrNDjsNYx+ > 4RIkzXuyPxmzT0iJNr8Hb > czm+NezUGyf83cordNIK08PDVnQYzdzL24dlG+7Tsj9DZG/ > DNWgYyd37OZPJlGOFqftKD7W43rZI > qvIEr8z/GFbLyz3aGrquG7ouz4cPl8BR9kYZ3ivopfhIS3niuO2gQbz0WOE3mcQr0US5 > lZ7Kk1FV > 0xn93NehRlVNh1dj/Vz4T7OB0QmAq6+PHt3eVW9jN1uRRotRmd3AZXrXRxwf9 > hFH4JdCtDhGD2/b > yg/2jNXqIpp587G/3czdvHXrKwyOEeW8eRs60mhlpNUkTx > f3pC1WAa0ZUWJ8vEKdhvdGdmd3cR+7 > B45x9dCqEXlPCT1OatcttvvGneLrI8jRYxb/4R04VjEsDjt4e89Se/cV779+ > GTe+jLTmYF+ge0/2 > 9WRfT/b1ZF9P9vkZJPhzFB8zAJvuI9bzxki5xJUZ1/ZeL5kj7+2MGftTY/ > 76Mq6PEsfsv3g0x30l > VW+doKROs/DtWVvdfjTTV1wdv53QGWtbxgubZqxtjbQeMeaJPJsxe9INY8pcJdqLVaKGOC > 5OQ51v > 1HLJpI0naua0OBBv4wc3lX8MzzTD/wae1dtq3QFDzdPdMOp0R8K+Kj30+ > i54087WUBQwtO0rdhic > BlHPT+gtmcLRokiHdUI319n1FG5Jf+xMFx9du/5d76Ubzdo+ > XpNumnmNzTMRaDttN+7gRvIM7brP > L4furRHPRLNq8GpPBTJtr6UnfJwG9WrH/s/YsYv70XjNfX+ > d4zl78oxnnDG9LpxYxbbo5sK+96Co > 5MzNE/sN48R+g+O2gwax2mM9w6KeE8csAPoAF4+8jlxjRPZnz409/pMig58Re/xnxh7/ > SXeEhU/Q > sC6Ql3WEMjUHuHmP/+AGL0+qH9y2Zat0sGOv1Rbe4G3ObWvHwD3R0 > E7ycnxPmezZT+0JR8zvwxu8 > YY3Wr4ltHfTgRi7bMnLLftzgZbtz0s1epyc3buSKmzd4U3riTjd7nV7c2H1n > e8Fd/+rcej8SvytG > En+31mbnkwXYF0++tJVQ3H3Nv1vrDjvUilEP6ysObrVyxH > lq3KklB0dNxPO4dxTJh7wcfR2cJ2C5 > REkxjBu8osHN3hk+M5nAK9FIB/DaqJRaMO4POWwVkWnrC2/ > pXtdV70Yc3sytCWffKAYQOXgCHpI2 > zzicHm+Qnx5vokNDo+EN3O0W7WSpWjLSsMUi7466tVWCkJYw > bxC3sEa80Hkla2bOT8UtAsdhvK7D > O7rBraiIpCmRn7rfSy3Y8lM7YWh9ozUxXtxmLZGflhZoWpQFj6OEEvp+ > svxk1IQ/VZftS403yal3 > slrvkJOGvSN5d9Jj/0qPt0RRg67GDRf3fLvXoPz7sUgmh7e > Bi2t7Ld4Mv/Cs30HUbutH4E/7ghu3 > LfzPk7LCI9qzm0rfnd3z4s7leWEYN3RFg1vDqfSZTN4ZTjQtSl/ > SVPd1fwyrZr4dkaIyhxMG5vG3 > 58+xyWudAwfNxskDnWy402USd2+dm6+788ut5mNg72Fa5WnYg/ > u3M9KoHD2Au1pPMi0it2h4lpG8 > 6p0gU70ETgNwXH2wuy/87i4bDe7TVm+lXOb06N/C1IE0YwTvTDLt1POxswpu2Q6P6dYwp > draNvRu > nBuAW7GY4Htbb+aZge6SWg2/2IzvRlTvk95QP+lt9ZPeXIePjIbnBCIPNUMkHqnPwr79 > j6W8Eofd > WEIZa6tb6x3nAeCPzlyHtn16zbSde2LtPYOm+ZihaZaHkqvXtg7PBlzPFaNB3O3m7Yb > JFI4c1Qvn > 5J3e37Vu9XMFbokGOgxvc10m8QqadoJXuoXO7tVzwyscVdJbNm4pCc+ > gQWonpXajnmtf4Lx76aNG > yrrFexD5WXgmGt4Avu6tEeMaO49Az0mHmXRDhHPr91bCiQY3kk/ > y4o3yyLs5tNF0qEk3nnBoXjpE > Ax9KT/dneHfovAfwrpHajNZC+w/QSKfY6cXtIwa7MYzyYZg3j2t4bs3w3 > IwyZ+NaRgO/4XWVFUYM > 9zq0eKrhR3i2XAfn8VFnmyNq6i98Uq+FL1Yfp90wAN1K9XnZ3ONwT/14/ > 6Fd9MMXwCPvFD8F+aU3 > PVFTHQcN8svWw++MnXngGDkKm637Fq8Z2n8+3JeOmrFTzTAa7JWf6Ol2qhm6OYpSqV > s7KK0n1YyT > aobRID6yehLeTY2aofPeoDEdZtINN35TzdipZuxUM7Z5unoEadhy1CLzhmtx > 2023MhzDV6dG23pS > zdjX8/hZ0IeXsWPlgjzHR+bAZudNrcRt0QJcGxMO37c/sW9PO40G92/Fi/u3Neqe/ > f5sNvraQw7u > 4rbo5UQDm8UL/W+N/uR4D4TcPz6zEJXZfFVLYKfF+eIXnnrkl5PHN3d1qz+ > 6zaua1SsjNuBLbe7B > XovXATtxcOKuqkYEvZ5tY4gPT7NRd0MldYekulrQqN0p8bY3ZWo8iXuoaiuw > /26jmho0I978fnnt > MmHBaoF3D5p9g/fMkHlSycJdVa1p2L1VcLTifUtv1VvRrtdAhRNNzNl6i5nqh5d7pdmdN/ > z17kYp > F3tPUvViJqT26XPVbqsszwad4oO/bMUFsaENl6B5frdbGPe4TOowIs/ > 8rhb/Oi20Oz7/izjOxCpJ > vLs6rd582NtAe2v7lJ1w0EAn8SJlySQuUSI9mvRrH7riehDfVG/ > 65FtukDtrlL1ZwzeOZ9AgBnSM > 6brOwME2nYE7iAetvpM76dXaGccz0WAPf0TpmTHu6+xFRWMj/ > 6QbzwLUSMtwooFuGm9C53bCFhsD > ztChJt3gkxF5YCcEeKIg8sB6+/PH//zrjbc55n7/LguL6n/8/Guc/CH+ > 0pdfH0KS/fxN4P+YHRu2 > 7ydAkN/PIn0Aq395HKPj2tfjGF2vuYNDH8DhXx5HT0m7Shc1KOmatWoNA5D3E6Bz6AM > 4/MvjqA2L > lo+jNr2hAw59AId/wSPhFZUO0F37/lgDJy6IPRbtfCuArKZzhg/ > xhziI3Y6+mjgAf/0uDmL/srFM > 9X7//l0WWsf/+Kx43Z9/iL/0xUJE+R8/LvP9fL8y9WaS8yj44JezilXxNRFT3e > Zy+ArOcHIsT4t+ > vMfXRDXObcGBq4fvuvEPkhq6hYxHQPWw6FvpZquIxXY9Fp1eFR2+ > BF9idT0twKf19xZL9D3eH13V > F9YB1WtDGSmH79IOz6JKPTxPKv1gpRQUXolmj+DdpBmuJMQ5niNolusJz0lRYRtf4DAE > FwZ4LkL3 > YN/xhOpQcUxwOAHNCe69K470O/rAhSPckifEhXESTJyxMH/ > Z1XZA9sAg4HAZd85ZUnDNXAei4BTp > KQzZMFiaCnc5wnXF7ovTf36ViojQ6vj0oDnXFIazpLFwnUFT6OjjSiMfXOtn > I6LU0LkWsAZv5LAw > 8tkWs/GF7SI5bBQ98lAMxC7/7Xcoqi8ghxu4P9as1Pqvj8Cicb6aGg > SKkVziEcdj98wQglVwxiuP > fAjyKB9N2IokQMCEsZRNdV7LZpEuYaK0F27dsk4MyNL4vZl44ZFoxrGslo7I > 6upum4FPD5pzg/cm > mTelBRrpcFbodpI1r4nTvu5XEOwN6vqHdhWAhtqcpfeA+x/ > aDf0yTPu0X3kQmv71c6U4lksBWvqq > 3YqPQ3sVX55txv/75G17Cci+fqmJ48t8i006TPLTRdHSXQPX6k+ > 2zTQUjRMtRf7RVMFhrReFoe2h > NOQvxaE0GzxB8Dnc2G4IA1xGQBPARruQxzQWcg2uIJjb2eZwYXN4EnN7wivU > cSU/8/s3Pm24LTIa > 1oZAjV81zh56EfCR8KGwEqyr481F8K7OMsjfdbYNLOtFBPwxrL1nHNNu2KRB > PCC+SUMIQYj0wxVS > BA/iwd5vTkWNAYvDEQTfAMrYvrGlCeOtCMLutFinoYTWHNblBLh8Qbanr4RJddr > xEpEdnp7sgx9k > oHwijLoLE1dXUp+N8g6MXNyXhpWOR6IZLXj7DZmfpfF7D/ > pXFUxOa4HrCpragxf6S6bZ4ha7ZZHy > N+B6B/pYnOp7c4NOrO+ZDRabDzZ5iBBdOAlwso1sSIjC4OX6H > g5pGODXd07Q4XGCPZztFBd2uidx > uif8CKTOY5OSKG037Fgdu9zQSL6CovIP9F89zFo8DyUapQpes+ > zJ7MPskT9hUOATNG/0arynhMzX > slhawNIBNNINvNIZMrUD/16WYWHlZsRzHpd4iV7uvBRfV81yv+ > GtJ/XtwdJDr+cRGte+Dqsp74yr > pPRhkpWu6aDi85KW7YQYPj41ZNXTQ0Zt2nelicx7qhgc1wmGl+ > MNt1MYEmYSpgMaqXd6iOe+cNCH > TyziFQLGORmvW+RB+vFuuBscxQneoFVsXwJ8sBFwFifgdBh > snA1DGCfzSMLgl7AInjpie0pKmOkL > 5Y36Jysko/jsFKVwxL7frJQD53fgx+DXoxjB188wlgNVwnGi8cYIvC9HnbH4 > ioggXDOnUQaD4Fm9 > p/tiLYcz3KKER6jzhHEgiyQEWxA8dTjtgJLzuOrrukFKuIQ6z3hCuGS7N6WZ+ > cwduDh8RSE6riZj > VUJ5hkuBSSsMXdLiEazubIu0T9h0B9rSPXR+/bkyckfB0ajkSd4qQw+ > qtDyCdsxv9nYExXWq/6jt > 92fWZrnA72Yu6HfQcwzxDrgzmAJOjW2V/Dcg4UCHsIeMw9FUyPiTeXAuf/+ > K68Ge9qfJ/uPcbtlx > rufBxYEKwuoE1+rE/uNGTeEjTji5Z/ArB0bwjWJu9VJ3jjvyqjViIni4hYmo > YD7JUcKuyuhXBA1+ > vjaC7z9je5JVZQCDYHsW8eEoCsMqL5MQfAmTAOpYca0mzPT1yn+ > 53hQK6fdaVJjeAk6p1Zhrqd46 > VTvWrr+GGsFHFSnXovAdn2P/51/94o25tyyMc/Rd+/j8ncMCQPU5+ > GPgimy/eNgKYwr8ig2X/t6h > zL/qCi3uBPAEMBIaugxJIqiKx7YYugbvXzGiDalZxQBXFtjJuBCGKgm8btG4ZtE > 3ZJ44Mka4qO5X > 3A1+7QbP9va3qcErS5A9x3YI75EA0/D+spILlp7Eg1/TbfBOEcAsskE3CiNEEiRQwo9NA3Qmf > an8 > wmqUa3ybK3Snq6n1aVx7ICNln+sp3uYpilG0KEMMb4tLYoPLAtieGAwO > fBNmWQcNA1SRl4Fuxhuo > OX7jPQauwll5p1/LggaPhmdn2WY0PhzMtD7fNoaqwZtZj > Q8IIfab4V5Cz45r1zdh6gkaS5fXnTVy > UGDgERYzT/g7toLw1tfv37VNRts2Dnkxva3jX/qyOTFbxR7AFdUODU81Wc/ > WNy39MczeGL4xvHC9 > eLsvj/n1pYANfOF5goZV6o339ChtpGV+NYyNQ9LAZ+KlppRJvE7QSAduOtZkP8MtUourHF2L > v5t2 > atydntzY2CQ30rgpf8XN38Vt9LbYO96Zira5yP52dBqDH31tR/ > WS89qaZk9SiQPHx8TRb3BwSYYc > uhYyRq18OPrHvtxfX7h4zC/L5utP2tFs/Pqjx0yRQZzHO8Pi+ > Ekymgp6alLf88TUcDQ8N8zfsanN > ifzoyEGUlrcjFjjRvPH/wZYSNT2jBeaCE2mkw0i6QSZzgGkJt0 > QD3dgQSucRtowZNkqHknSDT7Qo > AV+Rhj6knu5P+h3abfodWu/IaR6i1O+nhjU6XElZfJpEuITeGtFAb/ > 8dJXAETvl05btnP6/JIRZl > u1zQe28/OX4zL6N52hnv09pkAtfIM9NhrNAN+aFpBXr68Tqb2jhwe4EtgP8t3DUye0u > 1PKU1Js7E > Y795vEBsle9CjPfYbO1cvn5XXhy/tU6jwTl78Y4kE2fumZbrA4e/ > nq52Dd34gpgaQ6bHL29GUPlC > sNLelAVuDt+Fb5LL6MKUOxSLmbL0BbLGDP4xQi7f5hINqxx5ubQP/ > Ubl72cG5q2A6n4VL7WgTOIR > vjcdwBua4uWsGTbc7dpNDLv4+2yh9dQLAforeXaGZ7t/gXV83UAcyZsaNZCGI3vysnulVJvDI l > /V > 3C7GoyvJ4/oCWbwFzDQ0GSI2Ox6NShF4VdL2tRPr9LjhO51mcdMh9JNM4lTaTQfwhqbFXr > oSBz2w > KmLTkbvhXPsmXvb6lLDOElESX9fNkvzLCG/wbu1409fKWzD6PZVFux2D4KTGDTvEj > TTEzd/FbfTe > LaJeXs6JiYfKZ/sLPlYOd+GXH8M2dHqlAZHYfgxzq+tRtaLcWe9cNaf/8+0+ > lcHShneWhEeiGSN4 > +eZSCVyG6SdszdybUaJJsrmPmqGFJqwmzIwHTbvC25vFnZrId7WsNk2i34Ud0 > b/QAZ8cLWN0b+be > bNDSfWXQmsVXNq253CPhGXpuNKM1YeoJGkv38XrTSWtYjcnhM0ropC81mkvY > o+ZS+Lpt/a6w5yY9 > fJGqXTZmP4bXdA7DzzM8UkqpfFSGqfHYqbAtWj2aLq8+mb2699RwwnuGxwya5xnjndGgEist0 E > gH > 8K6ZrbnDrdH8DNYYrh4ulZrOttwCW/6r0RiTpoywRvlmabk1wtDoRj4b77PA > ZBLfoJEOj9ee0GFZ > mGy43luowM6xk9STpB5fZkJXwbUd4NPTFwbhoHUMgEHPMDCGfm9RY/ > j74x4nuJ8mxj1HcON3cRu9 > p92svFUP2QbPKpQbPKuD0fCs4zGDZtbgncNCsAn3EzRjBO8sIVNlCWlZGb5B > A93EC50l0/T3HGpT > HQKxr+a0cbVgVSyom7SzWTll4TwN8SzWmfuCDfoArocTTu/t+ > vKhHRfXMbLjkju6Va7zoN8x+E4u > bB/VGdsIYVpB+nfo4P3b4GGohfDp7Q8fBej3lwzPf5Pauno8zm16DBsYXC0aQVGuK6H7N3ht4 > Qmm > jur9vYQRXidQwrhQ3sKJ47BLxlEU70fHCXE3xN00RBu49UKoRSeoytOBhFxA > nlh0kllv0cmHV3O6 > N2YMR6f1mm/RaZg3psai29af4A2DWHQ6pv6M8aaEAU63zxLGolMPo94PyiktGEHj68WEEW+ > c1gcn > YoRsMiLF66MzYxStj0tQEQrHJcC1qlt4t4lKSdiXdD8a39pw+ldN+ > ebNwJaV4dGD5k2falU30p5M > X5JvxRrnS32A3y0u2zF4YxudWaamp4TWp4fWp5WEQ2tNgKG10Tcsx4TWhp/ > WRoNpaw+teR9RuIbW > p4TWp4TWx87acQn4rQatzbVe4Ouri1pNw/KiVt/6ndvWSj5cAvNRL9LEiiEWZF0mMFcDS > xmx+mYp > +7qtr8ZgVVXrcsKHaWClUBi67qQrdjSwFtp4Rd5wCRq0Wkx5a4nX0tISruMb6 > 34Fq4xs8agp94KE > b9BIB4YLtAVZrgBWt5OnwvS71vz116m24KuVPtrJFQv9fkZwH/MlLkCcaqu+ > tk7I9E51DY3b6L0S > Vq7/MDdQnFmEK9e2NLmpPQo9cVdv9Hg6u+zH0q33w+9cJMXvHJ3gV2sy3x/ > q7V8NHCzbr+IPVtr3 > TtZgKX/VfrD6fuNhh+80ogjeYUSxvW1dCXvbumwcAVnFQMAF > T7DNEMaFJyTBdTMkPEMdEZRibFCd > wmDQcENH9sXkEtPTYprvXns0cX+bv+sq9Jd899+xO0r9HvXaDtlrg+DIMW+/ > YJix0843v+ueC+Go > CG1P8am1tGPw4HTWNZ214I8fwb2Dle8egX4rgBB/R8Q++GVrB+ > T9yhawfKOQ/KteJoBFDL5BgTbM > febxUaHxYiryntMH36Ym7X87mdzffAd/tb8JKF89gpU8a+K+ > wmKMNRhrMD4CjnzAxn7zlX41Ca/A > GPwKgBHM5mwzhM1IYobGj+0kn1oVe7ueCoOIxO33Tzud/XwOs6oKeE19HTgFW9+ > WosXzYjJ4mOxL > vgCqSpwV1LsHTFl0pvT4oJ1Gq9iDLF6OLjc63s/XFrae17RdC5ibgFq4r005trH9ipt/+ > azCLqeM > /XAP3L0e1CIvgFctwJuJFTmqj8CjB824wQstJJO7q4lGOoDXNKUNXLR7hb4W7 > lfzdw4h30+/f7cD > H7ThHCvhRvWKuKhQhGuRW4l74uZjTcjNqqEStOUTULSCTwgKtxU0XQXx8erB > C0nFUxji8C/Ps5VL > y/B4lbbg2Dfh6rlSrRI93qkcWun3pwf3ll7hqFWVoyf5Q+ > ma9x3foIGmUfhcB9AoLfDq2VvmRONs > FSk0eelxNM5QIam1FTiapsct3wPnxqy2E6W6nVyq7cvzTUs+ > a3sEXlGq24xS3aKD+nB1Pxl+9hkN > rJjhD5MJvBPNjlLtmsI3vXinBRw22JeKdauwoUfr9BUt77ptzYu81kBhvey4 > DYZHbDVAv55qpskE > rommhA2uKW2YO2yYNp5B2pv5gLUarr1UrGwJvyVgzTNhg6aftO1GudeaGu1U > /ws7uffkabmdwtB1 > R4nrJ9l2ks03aEyH4Xr+aVpzIgU8a9S4qXL8rJktLJhNg5ru+ > L0+bzRoycQLP0om8DhRH4atKVHq > iFI/x0zeti/QaRz32JxJpxklycLC8i+GHxLHnWGd/IQUNDjoI/DoQfP8Z7xPP4YxEq4+ > MrQ1K/Bq > nQoyV4u657gETR3BC51rCVxy28qnxNiWr+FjkxJfIGtEGVvJSzqcRhq1m+ > DdSb8dvjAMe1K9N17Y > v3rg1H6YDuANTa+FLSLm480se4axgdKi9uxU9nY9CZegK > cmrN2qPTsnTmrtCo1QzjBeXMmpJONG0 > qD324DRL9B4+ham+188vK9oP3+yh1Sc8YEOx1gM/D5waHjg1PMCAQ4aTB254QCf4PC3zgG > FYcZJ1 > NzxgMomD5sRsSXpamTw9PHD6SXbal4ZtqSjrDHsk7hkjsrPsGkF5Ez8/ > ZtO1k1/SNPGbIP/RO68j > PGhHJnAzi2sE7YUvvzqqcv/QrsWTwjgYhMzxRzDseMhbXBwhbjRu8 > j9q/51PLVoymtJBio4gPGrO > +gmTfkPndh60lTT8cXUCyM6kjbbfEV+e4HlLmmzo2xkOb3eCl/ > jtnqIdbHqHkp1Ap4sfm3YKnjCd > RG5+OA0JG8HyQ8m49ChhKx1Kxu+69fHSsy3IdxpJv0PKuC6FBygBV/ > dklg5ydTt+DHG7JXF40oPU > XHuFjLMc3mniGAITbIyMCXGrJJcvzkvwu805nu36HVKUt496uNacDJOgV3MZ > w9LBkUuO/Nxr8HO6 > EdxrbEi6e9G0JB6BFaqedHu3mY4XbzsR96hPyLgt4EnGctzC+1czBG5e/ > eXNK+bA+1Vaf5U4/1pT > Qd48iP4SsuBycMO2hN401vOcsSoJp2fSVqF4bNwZed5jhDl4z+ > DnBiO419iQ9JwOVxAo4ce2k7FH > 958+UUclb36zWR2B+/x8Qjc7DPcpZPCra0bwSTa2e03Y00LX > XwGPNwxHZfSx3RB2vcScezzhG+qI > 4Ckptqe6hD2DlIRs88y51Yv27e75O+3M3ZfilS/eaQntl7/ > K4vjrtSpfTINW1xR8E/HmUC3R8uPL > Ly/vdtfpJPPLyxuZYgTXD0tD0+OtpyXxCJTwdd1k4zf5bmYksJtmX54u > H/Ys/YatXp0r42sL26Cz > 7fcX1xyIbTETl0HrpM8mJqXLMqRWHf8cmAKPwL0HDYc15G3Vstgm2dCvVj90 > 6fi9KGo0zwfGe6/L > hAeUFnHUFdcNvDPJnKm81Gq3+wqxc58SUqOV+abSkUJTU/ > t4GaXEpGqiC46/fGk7vrSd8k5fkHeM > 3UbftO7NfGWMNuFZstyVUvQaAblW3p9clT/I3VEO2umBby5RneuWxGqmX20x/ > GpLHyGV8c4oqfeQ > 2lNp1DEOaKRTb56W6ozjl3tGc6/zwk7JJO6Jpt/g9RIOLVZ3L3UfhezuX6jfDi9rykl8V > tigigre > m/TIfQwi4VrpGs2r9oeDY0SXWEdPHY3e0xXuPcmdNeyYNcr/ > tME4qZZ3cdVGGfh9eyf3+/c8XsMX > TyO3sV8FKvHlpmGPfYGHdAoOHKvMwNWHPopcS14NGCB1tTT6UURbcaSWbKWa > 4aOURzNrSI2RafWF > eli7NKgamPRN98JSjiO67a/fW/KBhhWUm7vaqvtNyHNdcEKe64YTOHYd > CWffaqLIi/k+7LCTfVYT > 947SZ/jVRB94DJt+SdIKr+0ZtXXbYfdi8W0jLauJhm8PGtgzolXc > M/LO0gKNdLiup9m5uSxKjluz > nfxCne4IXVN5Oqk8+fWAdxi6juMHx+vYfqC9DmpCPPU7DkXxUDF4hx+ > wdlwRn9oPZDs9lrs4jRtY > UOKW3TvYbekOLJVxufAdbIVu/+Zh5sA36LFARD2JqSdplC54bYEZ1kwd > 4ccikp3UhE72BctAxQ/L > fy3GCMxFfdK06/bMOGAt/Kcseqcjfgxz5EIOYSydnRZSd0p598A > rvKqlrIFFKvOq0jLvGcYilWiw > SCVeaCqZwDvRSIfhepo12uojtkPoPfCzZsWB/A83t2BxoZu47qDh4h+ > sWSXKguZjsMYwFmZK5LPx > cpktyoKlBRrpMFxPKwuLI7i3rQrsHKlULfmFWG0PbeD8j9jDJ1y1Hz+ > Gb5QYbdIRp/xnNEF6wOix > MHOXe8AwFmZu5JV2LaGfrgEJl6BZfjnha3v8qkXdNmWEDW85ycr/ > qaHdSXml5SenJ/dYwZ0WgqCH > cY9YyHL68BgjUIvjhkW3haV2iWEgdvNwK+yiw9ve8YsRieaVz3R5wmU+2+ > z3Z5vRlxNySnfc73Ya > tIXihf6S6baoxpSwLFI2m6/WFSBr3pDF3Orn/OX3X7l1Ocegl2yMTroTLdy1k0X8chP > PTWW58cUe > XjQp1kq9k0m64vLOExVdfXnniQy/80QlXYMxXp58KgkHTS3DeRlRmjIZUZ > ppOS5Bw9NacTnGZJr+ > bidevP4xrEWA6y9n82JWHaFdtcUoyKo8/0hsU2HQNc5+IFfzAf5uV4oQLzqu2jTvCZ4svqHDL / > aG > Di20L89CbUKRo56Ewwu9RA61GznUbuSQ4efllrxvvNCiloQTTYscck1hnTa8 > cDGozx0cK0laK/D+ > 5QEuhBPbGBma9+u9ZBvN663jd85Nt2DggZEus+mMJnEZ4aUbF8Z6tKpIy7xkGJZGq+ > q8z4aRPGZp > jRs6DNfT7NTiLTn0Crps05enkw720J5Zwwb5FfjXNb9xhrUYTSu6/ > J1WvBbj9+/nl1Znh1Z2MARf > ZtJ3hr4lvjwdZw+9ZvTrLY2J2lRrD17r118InOLjOsejB83z54z+22UC90TTd/ > CO1Jq2uVrYYEdy > oMeqzW1YMa5rWvqlDTcu2vG4umw4Pk6N36+9As1Limmc4vKH0jVdV7LTaJ6mpgO0v > snO08NOteGI > Y3kj/OSD9qZj+n2UFFPR/3hThBzGsgV9z/Qzfp9JvhP9BMn/ > Sp9+X/Nvw2cyxKbRr/nrd48iaUbK > 3tpyAvwA+F9+wF/SKb6cYDm/WJzsr19CGVPstr9JZv6XX3I6wH/ > L81vpf+Y55S9a/206f2PPo5M9 > zV6VC02l9X/zxfWRbv/Nl5OknSwt9DHdLMJ6/KVi71/iLxX8+ > NIST//FMyMdYv/Sk7TfX/6Zx60z > S/+LLydJO/9kqdX1/58Pgi4ahb/xQcvS/he/uYT/4Plnaf/ > s65Z06790m+W3r+PLP+dCT7r95vln > aStJW/+hgUn7/eWfeU5K5/xHOibt15fyx//91//51/8DMVvCkWVuZHN0cmVhbQplbmRvYmoK > MTcg > MCBvYmoKMzc4NjQKZW5kb2JqCjQgMCBvYmoKPDwvVHlwZS9QYWdlL01lZGlh > Qm94IFswIDAgNjEy > IDc5Ml0KL1JvdGF0ZSA5MC9QYXJlbnQgMyAwIFIKL1Jlc291cmNlczw8L1By > b2NTZXRbL1BERiAv > SW1hZ2VDXQovRXh0R1N0YXRlIDkgMCBSCi9YT2JqZWN0IDEwIDAgUgo+ > PgovQ29udGVudHMgNSAw > IFIKPj4KZW5kb2JqCjExIDAgb2JqCjw8L1R5cGUvUGFnZS9NZWRpYUJveCBb > MCAwIDYxMiA3OTJd > Ci9Sb3RhdGUgOTAvUGFyZW50IDMgMCBSCi9SZXNvdXJjZXM8PC9Qcm9jU2V0 > Wy9QREZdCi9FeHRH > U3RhdGUgMTQgMCBSCj4+Ci9Db250ZW50cyAxMiAwIFIKPj4KZW > 5kb2JqCjE1IDAgb2JqCjw8L1R5 > cGUvUGFnZS9NZWRpYUJveCBbMCAwIDYxMiA3OTJdCi9Sb3RhdGUgOTAvUGFy > ZW50IDMgMCBSCi9S > ZXNvdXJjZXM8PC9Qcm9jU2V0Wy9QREZdCi9FeHRHU3RhdGUgMTggMCBSCj4+ > Ci9Db250ZW50cyAx > NiAwIFIKPj4KZW5kb2JqCjMgMCBvYmoKPDwgL1R5cGUgL1BhZ2VzIC9LaWRz > IFsKNCAwIFIKMTEg > MCBSCjE1IDAgUgpdIC9Db3VudCAzCj4+CmVuZG9iagoxIDAgb2JqCjw8L1R5cG > UgL0NhdGFsb2cg > L1BhZ2VzIDMgMCBSCi9NZXRhZGF0YSAxOSAwIFIKPj4KZW5kb2JqCjcgMCBv > YmoKPDwvVHlwZS9F > eHRHU3RhdGUKL09QTSAxPj5lbmRvYmoKOSAwIG9iago8PC9SNwo3IDAgUj4+ > CmVuZG9iagoxMCAw > IG9iago8PC9SOAo4IDAgUj4+CmVuZG9iago4IDAgb2JqCjw8L1N1Yn > R5cGUvSW1hZ2UKL0NvbG9y > U3BhY2UvRGV2aWNlUkdCCi9XaWR0aCAyNDgKL0hlaWdodCAyMDEKL0JpdHNQ > ZXJDb21wb25lbnQg > OAovRmlsdGVyL0RDVERlY29kZS9MZW5ndGggMTc3Njc+PnN0cmVhbQr/2P/ > uAA5BZG9iZQBkAAAA > AAH/2wBDAAICAgICAgICAgIDAwIDBAYEBAMDBAcFBgQGCQgJCQkICAgKCw4MCgoN > CggIDBAMDQ4P > DxAPCQwREhEPEg4PDw//2wBDAQMDAwQDBAcEBAcPCggKDw8PDw > 8PDw8PDw8PDw8PDw8PDw8PDw8P > Dw8PDw8PDw8PDw8PDw8PDw8PDw8PDw8PDw//wAARCADJAPgDAREAAhEBAxEB/ > 8QAHwAAAQUBAQEB > AQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAAAgEDAwIEAwUFBAQAAAF9AQI > DAAQRBRIhMUEGE1Fh > ByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3ODk6Q0RF > RkdISUpTVFVWV1hZ > WmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKz > tLW2t7i5usLDxMXG > x8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6/ > 8QAHwEAAwEBAQEBAQEBAQAAAAAAAAEC > AwQFBgcICQoL/8QAtREAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRo > bHB > CSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldY > WVpjZGVmZ2hpanN0 > dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPE > xcbHyMnK0tPU1dbX > 2Nna4uPk5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD9/ > KACgAoAKACgAoAKACgAoAKACgAo > AKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKAC > gAoAKACgAoAKACgA > oAhlLAfLnOe3X8O2frQA1XJfaeoz29+/HHBH1zQBYoAKACgAoAKACgAoAKACgA > oAKACgAoAKACgA > oAKACgAoAKACgAoA85+Kvi/xB4E8Ca14m8KeBdU8ZeJoGgg0/ > wAMaOyJLqNzNMkMStK/ywwh5Fea > dgVihWSQg7MUAfMv7DnxQ+MfxP8AC/x2/wCF46/pWqeNPCnxM1rwz/ > xIrZYLG0hto7X9xa/Isjwr > K8wR5i0pUjexYEAA+4KACgAoAKAIJGZVysZc4P4cE89/bgE89KAPi39r3wf4w17w2vigfEv4v a > d4 > D8PW8MzeCvgJapD4n1rUJZ0hSX7X5jGS2jikkZrZI1HytMzv5SKoByv/ > AATf8Z6x4++AuteJdQ+J > Wq+NNCl8WavD4duvE+oJf67pmkJKot7XWJUXH20kyTlSz4iu > YNrbCiqAfoHQAUAFABQBDKSEfDY4 > +9jOPf8ADrQB+aX/AAUY/ad8U/APS/gV4Z8G/Ei68Ba1408T7NQ8YR6Hb6zDpmjwKiX > jPayo5d1a > 9tpVRF3MsLqGUkBgD6B/Y28bXnxC+Etz4quf2kbX41xXOrTpD4ot/ > DUPht7FUSJTZy2KYZHVg0wa > RVZkuI2C7SjMAfWVABQAUAFABQAUAFABQAUAFABQAUAFABQAUAVpx8nQnOeg > PoT25/zxzigD5H/Z > E+F/jr4YN+09/wAJ1oP9mf8ACW/F7xH4p0f/AEmC4+2aZdfZ/In/ > AHTts3eW/wAj7XGPmVcjIB9g > 0AQSybAp7Z5OM4/DqecDA5yRQB8wn9sv9mkfGI/AU/FzSv8AhaRv/wCyRpIgufK+3YJ+ > zfbPL+ze > du/dbDLuMw8nAlBSgD6cjlWQrtYMpUMHXkEHpg9889PSgCSUqANyk89hnFAHxr8 > ePhn+0nffEXwZ > 8X/2cPivpFjqllp8mjav4A8f3F4/hzU7Ri8q3Qjt1MkV6krj51AZkSMbkW > OSOYA6n9kr4Ea78BPh > zrOm+NvGB8TfEzxjrt54w8VatFAlvbS6teiPz1tY1jTbCvlIBlVLNufbEGWJAD6mo > Ailfy13e4FA > HlWvfGj4b+GPib4K+DeteLraH4oeL4bi60fw5HHJNPPDBG8 > jyOUQrChSKYq0pUO0UqoWKMFAPUkZ > jjLA5GQR3+n+T1oAWbO0YbacjnGcc+nv0/GgD48/ag8K/HQa78H/AIv/ > AAF8N+FPFniTwDf3ZvfB > 2vWdlFc6vZ3qxwT/AGDVp1LWEyKrE7HRXUkyecI1hkAOX/ > Y5+DfxO8KeM/2ifjv8WvB/h/wP4q+L > ur2l2Ph/4eaO5TRILMTostxdxMYprm4Nw00rIMM5MhKtK0MIB95UAFABQAUAFABQAUAF > ABQAUAFA > BQAUAFABQAx/uk+nNAHyB+yJ8UPHXxPP7T3/AAnOuf2n/wAIl8X/ > ABJ4W0f/AEWC3+x6Xa/ZvIg/ > dIu/b5j/ADvuc5+ZjgYAPsKgCrcZ2Lz3A6nqeB068kenrkYoA/ILx74B8CePNLP7AP7KHwrS0 + > CY > 16Of4n/EG0eb7Dof2a6trq5srfUZRMLrWCFtlKuZfIQRxMpCv9lAP18iyXYkjcVB29C > M9CR1z1HJ > /h4xzQBZZVfG4ZwcigDxv9oTxJrfgb4C/G/xt4XvzZeKPD/ > hDWtU069MaTfZrmCymlifY4ZW2uit > tZSpwAQRxQAfs8+JNa8bfAT4JeNvE16LzxN4g8IaLqmo3 > oiSH7Tcz2MMsr7EVUXc7u21VCjOAAOK > APZqAOI+I3jbTPhr4A8b/EXXLe6n0bwtpF5rN5DYxrJPJBbQvM6 > xqzKrOVjYAMygkjJAyQAfz8fC > T4//AAy+If7an7J3xq8QfE4ax8SPFOveIrbVNKjttRaHwZZXtktnoOgRM8EUMoiluJw9 > xBEqtNcy > vIWXEzAH9GcAbMhZgfmIOPUE9/pjjtjGTigC3QBVmjUgMFHmA8MRnA4z > 9OB/9Y9CAeBfsufHH/hp > H4H+CfjYPC48OL4jF4f7HF79u+zm3vJ7U5n8uLfu+zhvuLjdjnGaAPoegAoAKACgAoAKACg > AoAKA > CgAoAKACgAoAKAGN91voaAPgL9gb737af/Zf/GH/ALZ0AfoBQBDIcBfc4wDjOf8AOfwoA/ > NzVP8A > gnp/wTx0bxF4d8L6x8N9IsvFmvmc6TpN5411aG71QxKHlNvE18HkKLhmKK2BgnA5 > oA/R6Jdh2hcc > Z+v9SfUnGc0AW6APn/8Aax/5NZ/aV/7EDxD/AOm64oAb+yb/AMmtfs1/ > 9iB4e/8ATbbUAfQVAEMv > ReM/MMD1Pb8uv4UAeJ+NdA+DOofFj4N6542udGT4t6N/a3/ > CF297rBtbmX7RbiK/+z2nmqLjMIXf > mOXYMMNpOaAPaUyXPGDgnJ75P58fh2oAs0AIe31oA+AP+CXH/JivwN+ms/ > 8Ap5v6AP0AoAKACgAo > AKACgAoAKACgCFzIF+TGfUgnH4Dr+lAHzefih8ate8bfFDw18PPhd4L1LRv > BuswaNJqHiLxpeaVP > dSyabYagSsEWlXIVQuoImTJklScUAav/AAkn7U//AERr4Wf+HK1P/wCUFAB/ > wkn7U/8A0Rr4Wf8A > hytT/wDlBQAf8JJ+1P8A9Ea+Fn/hytT/APlBQAf8JJ+1P/0Rr4Wf+ > HK1P/5QUAQyeJf2pQFz8HPh > WMnp/wALJ1PngnH/ACAPbtn+oAPif9ijWvjzbN+1r/winw18Baj53xs8Uy6j/avje+ > 082t6xtvNi > iC6RMZoVGzbM3lM2TmJMAsAfb3/CSftT/wDRGvhZ/wCHK1P/ > AOUFAEUviP8AalKjd8Hfhao7kfEv > Ux+v9gfj+H4EA+Ivjnrnx6b9sf8AYVm1L4ceArbxDb/8Jt/Zen2fje/ltr4nSYvP+ > 0TnSFaDYmGQ > xwzeYxIYQ9aAPtxPEX7USkrH8H/haV7f8XI1JfT+EaCdv0BPXqetAE3/ > AAkn7U//AERr4Wf+HK1P > /wCUFAHh/wC0x4g/aOm/Zx+P8Ov/AAo+G1noUngnXFvbux+ > IGoXU8EBsZxI0cL6JEJXC7iqGSMMQ > FLqCWABH+zN4g/aQg/Z0/Z/t9B+FPw4u9Ej8D6Glnc6h4/ > 1C0uJ4VsIAkkkK6JIsTsu0siySBScB > mA3MAe6f8JJ+1P8A9Ea+Fn/hytT/APlBQBFL4j/alKjd8Hfhao7kfEvUx+ > v9gfj+H4EA+Ivjnrnx > 6b9sf9hWbUvhx4CtvENv/wAJt/Zen2fje/ltr4nSYvP+0TnSFaDYmGQxwzeYxIYQ9aAPtxPEX 7 > US > krH8H/haV7f8XI1JfT+EaCdv0BPXqetAE3/CSftT/wDRGvhZ/ > wCHK1P/AOUFADH8TftSIrM/wc+F > aqASWPxK1PC+5/4kFAHxH/wTl1r492X7G3wfs/BXw18Bat4bi/ > tb7Pfa343vtLupM6peMwkto9Iu > FTDlwuJWyoVjtLFVAPt//hJP2p/+iNfCz/w5Wp//ACgoAP8AhJP2p/ > 8AojXws/8ADlan/wDKCgA/ > 4ST9qf8A6I18LP8Aw5Wp/wDygoAP+Ek/an/6I18LP/Dlan/ > 8oKAIm8TftSJgt8HPhYB6n4k6njoT > yf8AhH+PqcUAL4U+JXxU/wCFpaF8NPiX8PPC+jf2z4f1TXLLUvDniu51nP2G50+ > CSKSObTbQru/t > KNgwLD92RjnIAPoWgAoAKAGnnH1BoA+f/g0qr8Rf2rlUAKPH9ngDgf8AIreHqAP > oKgCrOzovyfeJ > wCeQOD26n6Dk+3WgD5S+IXx48V3es6p4T+C9poFxJp1xJZan4x14zXVlp13G2Jbe > 2tIWR754tjpO > wmgjgdgoaeWKe3jAPOD8Tv2ost/xXnwsDcNt/wCEF1JtoPQE/wBtqQe/ > I5Bz6qoAn/Cyv2oZT5b+ > OvhWQQSQPAWptwASSQNcPAGSfYH6UAfIn7I3jj4+aWP2nm8NeLvANsbz4veIbrUP7V8JX9 > 7596wt > /NkhKapEIYThNsLeY64OZGyMAH17/wALP/ak/wCh9+Ff/hCal/ > 8AL2gBD8T/ANqIAs3jz4VbQCST > 4E1TjAz0Gtkk54A4ySORQB8h/GTxr8eJ/wBq79jXUNY8UeBZPFFgfFo0u6tPCd/ > DbWZbToxcC5gb > U2eclMY8uWLafvGTpQB9dj4mftSINv8AwnXwrGMDnwLqmQCAVP8AyGgCrA5B > B7EYGKAHf8LP/ak/ > 6H34V/8AhCal/wDL2gDyD9oP4hftH6h8A/jfY6342+G0+ > i3HhDWIruCw8FajbzywNZyrIqStrEix > MVLBXaN1BwSrD5SAH7P3xA/aN0/4CfBK10Lxp8N4NGh8I6RDax3/ > AIK1C4mSJLKBUWSZdYjWWRU2 > bnVEU5BCgHAAPX/+Fn/tSf8AQ+/Cv/whNS/+XtACH4n/ALUQBZvHnwq2gEknwJqnGBnoNbJJz w > Bx > kkcigD5D+MnjX48T/tXfsa6hrHijwLJ4osD4tGl3Vp4Tv4b > azLadGLgXMDamzzkpjHlyxbT94ydK > APrsfEz9qRBt/wCE6+FYxgc+BdUyAQCp/wCQ0AVYHIIPYjAxQA7/ > AIWf+1J/0Pvwr/8ACE1L/wCX > tADf+Fm/tSNn/ivPhYcc8eA9T4xzyRrhwO2fegD5C/YN8cfHvRf2UPhVp3gnxd4Bs/ > DMP9pi1t9b > 8JX2oXKZ1K7Z/MuItVgRiXZyAsS4XaDuILEA+v8A/hZ/7Un/AEPvwr/8ITUv/l7QBNa/ > Fz9pvTJ4 > r681P4X+JLWMgPosOiaj4de63fKMX5v74Q7Swc5tZN4UoNpYOoB9Z/ > Dn4i6D8TNBbXdDFzbyQTNZ > 6hpOoKsd5pF6gVpLW6RSyrIodGBVmSRJEljeSKSORgD0SgAPIoA+fPEIx+ > 1P8HtvGfAHjEnHr/aP > hnrQB9B0AFABQA0/1oA8A+Df/JRv2r/+x/s//UW8PUAfQNAHEfEey8X6l4A8baf4A1W > 00vx9c6Te > Q6HqWoKGt7LUGhcW00qlJAUSUozAo4wp+U9CAfAXw1m0F/AHg+ > 38L6bd6RodppsFjBoWoMVutIFu > vkm0nUuzLNCyNBKrnes0UisSwYkA7kNt/iAXAGM7QAPQdOATjoATnnlWAMLS9N8 > ffEnxNrfg74b/ > ANi2Vrocds2s+K9fhuL+CwnnRpYrW3tIfKF1OEjR5o3uLVoI76 > 1lHnK4QgHd6p+zx8UPDsA1LwJ8 > VpvF1z96bRfiTDa2iz5YYFvfabZxG1ILu7iW1ujJsjRfs+WkIBwXhfxHa+ > KfDmmeIrOG7t1uYTJL > Z6hF5c9lIuVlt7qNWYRXMMiTRTRbiUliKnBDKABviLXrjR49LtdJ0/ > 8AtPxJq+o2ukaXpnnlRdXM > 7AK0hVGKwxxmSedlSRo7e3nl8t1jZSALqPgK10jWtE8O/Ej9rLw94N+ > LmqrCdF8CaWdJSzdpW8qC > KSC+U3+oAz74mlt5LLz0QKkVs+WoAQt4r8JeK7z4f/EO106HXorEapYapo8kqWWuWnnPFJKi > zIrw > zo6xtNbqblYFvLUG5k81cgHRAsS6jeWVigCbm+fA4LDjAZk5A+ > 7k8kCgCl4C8C+PvjTp9r4o07xd > D4O+GV1NKNO1TSrdb3WdaiSSWNLq3+0I1pa27tCskMhS+ > Fza3CuPszkNQBF488CfEH4JaZN4rvvE > kXjT4XWbQrqGqanbrY65osDSLE11OLeFbW6giaUzSybbJba1t3ZhcsrMQDSZ > tok+b7m5sFmfGMlt > 2ApwFHHA5z94EbQDn/EOu3OkJpVno+n/ANp+J9W1C20nSdLMzYu7qZgFMhVGZYUTzJ > 5mVJGit4J5 > djiNlIB3lh+zd8RNS01dY1742S6P4kSNXtNH8OaXZTaLbZUMI7p7mJrq9UMxR5YZrDzo0XZ > FasS1 > AHA58XeEvFFz8P8A4i2emw6/FYDVLHVdHllSz1yz81onlRJUDRTo6I > 08CvcLbreWgNxJ5qkAHQli > N67sMCyD5ujAbmG48NtGCMDkA9OoAOf0238f/EHW9d8MfDTw/ZvHo1ylhq/ > irxDOsVjpVxJDDN5S > WyM1xdXC293aziELDBIsrRteROpWgCfxr4d+Lfwg0rV/FfjoaL4v8D6bbPqGreJPC9s+ > k3OjW0as > 8002nXNxKJreKKJpGkgupLhi0ca2jYMpANkl0bZISJMn5WbBBGMgDPYkZbvk > cL0IAEuVZVb5iMfM > 20c8E5J4wMkcNyBkEZFAGt8CLa+vfj/421jw/hPDtj4Yt9M8RTsmVvL1rg3GmQRuAwW > W1t5dRkmQ > MjBNUsmdZA0ZhAPuWgAoA+ffEP8AydP8HP8Asn/jL/05eGKAPoKgAoAKAGn+tAHgHwb/ > AOSjftX/ > APY/2f8A6i3h6gD6BoArXBQRfP8AdyCT6d8/X098UAfA/wAQPDknw1+ > MOoWcERi8F/ET7RrGnhEZ > YrPW40H2+3QBViT7REI76NRueSZdVnkLKuKAJwrO22MBlLKRgN0zkbsA7SMK3TrwOSKAP > Rv2SprF > /h7440+UI3iuz8Z66NdkcK7yPPctdWRmlBImxpNzpSr8zGOJYoTtMRRQD58/ > 4Jv614Nu9L/a20Pw > n4mtNYsovjJ4hvID/ap1K4n0+dYFtbl55ZHlmWZbaUrPIzGVo5CWYqx > oAu6JLb33j/49apoShfB9 > x4zuY9Oit0eKKN4bW2ttQ2R7cxk6rb6oz5RRJK0kuXEquwBu+EZLW3/aM+ > DdzrjhtIuNM8Q2GlNO > vnIuuulpcQsicmKY6daa0PPIUCNpYgw80KwBxH7Qlp4b+JPxk8ZfCHxV8J/ > E/h34LyHSb/x34r8N > /D3VdV1D4o3MCJNZadDfafaTbLK2Xy/PnZxOWxbwiNTJIQD3L9pqWzl8bfs+ > WOlxhPFsGqapqE0k > aCOUaFHps8F0rTHAMBvrvRt0BbMjLE4VxCWQA8Z+Kdh4m1L4X/ > ETTvBc13H4suNCvodLltLg28sd > 40DLD5czFRGyybMOZAQcMTgGgD2v4x6h+zn4g/Z18Caj4ofStO+ > COqnRrjw9Nd6ZqK+H7YuqHS31 > Sytmt1/sxXa2LQ3hitsrErlG8qgDxj9jLVfB+hfs2ftG3/ > jeO1ufg3pPjbxlM15HaGfw3qWgxuWm > l0awVZVi0ll+0KtqklypdbgiRy7KoAnwtsfE2m/DL4dab4wa5k8V2ug2FrqstxcG7le7j > gVJt86b > 1ZhJvJbcysSSG+9kA6jwi1tD+0X8H7nXD5mj3GleINP0szJ5yLrkiWl > xC8aAMYpv7PtNaxOwVQjS > xBh5oRgDyf8Abh8c/GbTPiN8A7BfCfim3+HFp8XfCFvYx6HeaULbxq2ReNHcGS7W > dZhcxJFBbyxw > 2ytbPPLPK0kAtQD6U/adns5vHP7Pmn6coTxjBqmq6jNIibJR > ocemzW92pmbAaE311ohaAsPMYQsF > bySyAHLKG24XeygHjDHceBtBIAG3Ax8xYnHfkAEng25ttN/ > YISe18daP4I8Sa34LuxfeKdZ1f+yo > NE8U6gsovJbq5BH2KVNZubgPGoVoZcxoisixAAZ+x1rOoaXrHxd+ > B3jZdfufjP8ADWHw9a+J9b1H > xvq3inTtdkurD7RFeWjXzK1q8jeeZIY4EUERgPJhfLAPMvhHFaWvghLDRVUe > EdP1bVrDw6Y2DxS6 > HBqFzFpbQy5JmhNilqY5yW81GEm9yxZgDqvFXiK18J+HdW8QXlvdXMdpFmOx0+ > MS3d9cMQsFtaxl > l824lmaOKKMMpeR1VTuYUAfW3wN+Hd38M/AdjomuTWtx421CWTV/ > EV9auZVutUuCHn8uVlWR7eLK > W8HmrvW2t4EYnaKAPZqACgD598Q/8nT/AAc/7J/4y/8ATl4YoA+ > gqACgAoAaf60AfPnwgYp8Qv2s > X4+Xx9aE5OP+ZV8Pf55oA5r9qf8Aat+H/wCyp8PZPGXjG4W+16932+g+ > F7WUJc65dJgsqsQfLhQM > hlnIKxKw4eRoopAD4L+B/wDwWK+HnxH+Iuj+DPib8OH+Hvh/ > VCLeHxVLrw1C2t7piPKW6X7LF5ML > 5ZTNuZUbaWCpvlQA/TH43fDub4ofDvUdE0f7LD4006SLVvD > d5qGUittUtm3w+a6q0i28vzW9x5QE > jWtxcRgguaAPlDwv4isvF3h3TfEVna3Vs1zEZJrC/VI7vTrpflltblAxMVxDMjwSo3zJIjq > xJBoA > BbeMND8U3PjX4a+LotF8VXVtBp17Dqdimqadq0EMk0lvH > dwAxzqYGvbxla2nhLNKGlMqoIyAdDq3 > xY/aA8Z2hsmHh34c2OGMt74avj4j1G5IIP7iS9s4YLQKylXElreF0dtq25RZWAM > Xw/oOj+GNB0Pw > roNskOhaPawadp9q0jTGKGFVSNC7MzNkBAcljhRyxagBPEeg23iPTRZXFxcW > 01vd299aX1ns86xv > LWdLm2nj3KyM8VxAkgjkRo/kxIrR7lYA6K0+Ln7Q2jac3h8WPgnxNx5dt4v1We50q4 > tEwFSS606C > F4ryZSPNZo7iwSZmKJFahQ5AOXsNM1WTxBq3jPxh4kn17xxq0UFrPfm1gsor > e3heaWK1tLZANsEc > t1dMod5rnEoWWeUKjqAdAu0sGABmAxuiXfyNwHTJJ+9nkswGeAQSAYnhbVPib8KGvYfhrqGl > 6z4V > ury7v28EeKP9FiiubiaW4maz1OFGmgMlzcTzyfaIrsMQsUQtUyygB4l1b4nf > Fn7D/wALA1DStG8I > 291bajb+CPCYNxHPNbTxzwS3epTxJJMYri1guYxbx2irho5hdIRkA2/ > kkJY7JFGxS2Rgc5Xrkqpw > pO4DqSwVSCADC8Q6HZ+JNNjsbq6mt7iG4ttQsr6zMYls7u2nS > 5tp4UdXDNFPFFIFdWiyhWRSoZWA > Ols/i7+0Nount4fWx8E+JmKmO28YapNc6Vc2aFQiyXWnQQvFdy > jHmM0dxYJMzFFitQocgHL6bpWq > tr+reMPFniKbXPG2qwQWtzemzjsoILeBriaK1tbaJQFgilu7tkMrzTgTASzzAK1 > AG8Vzhfk3OFQl > huL7eARgYz8/zFiTkDAA6gHP6VqPiz4fx+MNJ07wrofjT4U+Jp7i61bwNqo+ > z3Ef2iNVvBZPIzWs > kc6RtI1nNFCs1zfTzy3MayFSAQv4j1a58Ja78PPgl8HdO+ > BvgPWFnGpXscFla6sJZYfKlksLXSpj > BbzGMwmPUHuJHjeAhrVkCyAA3LKx07SbG20vS7C2sNLsokt7e1tESGK1ijAj > WNEVVCooCKq4VQAF > 5HQAr+HvD8nxI+MHhTwa0YPh7wi1p4x18gsu6VJ3GkW/BVgJLu1mu98bME/ > skwzKyXK7gD7Q8d+P > vB3wr8H+IfiF488Q2mi+C9FthcX2p3ZYJBECQu0KpLuzMqJGgL > MzKqhmZVIB+NEn/BbjwynixbH/ > AIZ71b/hDft4ibVR4jh+2CyMgHn/AGT7OYzN5Z3CL7TsLYXzcEsAD9nvh9 > 4/8I/FHwnoXj7wD4it > Nb8H61bi5stQsydsi5wwKsAyOrKyPG4V42VlcBgVUA828Q/8nT/Bz/sn/jL/ > ANOXhigD6CoAKACg > Bp/rQB88fCFivxD/AGrzt3Y8f2hxj/qVfD3pz7cAnnpQB+H/APwWh+ > Hvi9PjJ8OPic2gXjeAbvwz > b6BFrcUe6H+0Iru9ma3cqflkMU6uocKHAbYW8uQKAfjhpOj6nr2qaboei2FzqOsahNFa2em > 2MTzT > 3c0jKI4IolDM7s7KqqoYksMA9gD+4j4V6H4n8LfCv4c+GPHeujWvGGj6Dp+ > naxrAuZLsX99DbxxX > ExmlUPKXlR23SLuYnLYJIAB8n/EHw4/w2+MWoWscJTwZ8RBNq+ > njy28mz1uJB9vtoxtWJPtEQjvo > 0G55Jk1SeRmVcAAmZmfKs2+PAABJYFecBlPfGCQfXHagDnfFXiO18 > JaBqniS8s7q++yRgxafYos1 > zqU7HZDbW8bMvnXE0rpDFGG3O8iKM5CkA6HU/hX8Fvhr4K0Hxj+ > 1vfWXjXxRq01lpsunazBLrenf > 2rdYVLLRNGjt/wDSSJmuFgla2lvhC8oeZowwUApfET4c6F8LfDGjfFv4Zya5p/ > wyaW3l1zwbqST/ > AGbStNuAyfbLa1uo1uNOFs72PnWzSQ2lrZQXRFusiDIBcZMn5t+ > 7nJIyzZABwoLDIA+b5myGXlRl > gAYUOk678Q/H2ifC/wAM67faKklrNrPiHXtLiiluNH09QY7 > eOJ5oZoFubi5MYQSxMklvbX5Uq8MZ > oAfrui/sPeGNa0nwR4p8B67pXjHWPEMXhix8a6t4Z8UW+qX+ > qTTFI4IvFTwi4kMm1o1db1ka2Xbu > MHy0AV5NK1zwB471v4X+JtcvNZjW1h1rQNb1WOCOfV7Bwsc6TG > GKKCW4trpHWQQxKqW91p5Ys8rG > gCn4z1fV9N0qGy8L29vd+ONduY9H0K0u1d4pr+fKJJOqfvGt4U33FwyBmjtbadwCIyKA > N3x34d/Y > 9+D1+uj/AB6E3xG8bHSLjxBdTeMdBm8XXOm6XA+2W9+w2tq9vpdoMpE00VvbxzeQDK0jxs4AK > niz > wppvwsm8A+JvBnjDU9f+B3i4pYxzajqTa5Ho89xGj6dcQag4aV > rK5YXMZe5ubgtPc6fDAEjkZVAN > txjJZTvGVO7GGbG0kbiMg9TlgQBggYwwBi+FvCOm/FOX4g+J/HHizVND+ > CHhGQ2M0mn6mdGi1ieB > Xmv559RjxKtpbbrWJXtrmBvtFtfQzho4wpALPgnw5+x58Y7mTRfgRJN8PfG39kW/ > iCCfwfoFz4Pu > NR0u5ZkivVsLuzS21S1O2RFmlt7lITcMyNFJKrsAY/g/Vdav9Ln0/ > wAVW9vaeONFup9I1+ys1eKK > O/gKrK8UbkuLeUMlxC0m13trm2kZcyUAdVn3I+nGKAKd/ > qVjotjdavqmoQWGl6fE91Pe3UqxRWcE > alndmYgKioHJwQAueoyCAe5/sveEdQ0H4aDXvE2kz2PjDxnqF14n1C > G9SSG5gS4Pl2MNzCwUw3MO > mw6fbzIqgCS3ckuxaRgD5H/4K8eAfF/jn9lSwufCegXeqp4X8UWuvaqLJd72d > hHZ3sUlwVHzMiNc > RltoO1SzthEZlAP5YwiNjlfMCjjJx0AzkA9BnOcAEHr0oA/q4/4JPeC/ > Hfgz9kTQZPG9zefZfEGr > 3mtaBp14Zw2n6XKIkjCxyACNJZYri6QR5R1ullBJkbAB9X+If+Tp/g5/2T/ > xl/6cvDFAH0FQAUAF > ADT/AFoA8A+Df/JRv2r/APsf7P8A9Rbw9QB6b478AeDfid4P8Q > fD/wAfeHrXWvB+t25tr7TbsHbM > u4MrBlIZHVwrpIpDo6q6lWUMADwH4R/sPfss/AvxhD4/+GHwltNK8YQW8trBqVxqN/ > qD2ySAK5iW > 5mkWN2UFC6AMUd1ztdwwB9XbFznGDjGQccUAePfHP4bTfEz4d6jouj/ZI/ > GenSxat4cvb4lYrXVL > dvMgEsiq0i28uGt7jy8SPbXE8akGTNAHyR4W8R2Xi3w9pfiCzt7m0a7TdPp+ > oBEu9PuB8s1rcxqx > Mc8MqSQyxt8ySRurElTQBj/EPT9UvfDcd5oen/2jrWhanpniKz0oOkR1SfTb2C/ > jtBKxCxee1qsJ > lbKoJS21tu0gG7+0H8OdS+OPjb9jv4//AA80PX/GHww0KDWb68s/ > BWvP4e1m6tNW06P7Jc2s0lzZ > FY98cYlH2iKQrKAVdTIFAIbyD4t+Fv2HPC/wi+O+sDWfjv4+ > 02bwLPcG6F1IjXqXRZpp1XZNPZaU > s88pZ/8ASHsmRZnkmSVgDfVUQRqoDxlQNocKJQRjIJAAyMDd8wIAORtIIBL8LdWi8G > /H6P8AtBfM > tfiRo8Gh2d4YXQxalpkmoX6xbDuLG4tr2/lZyVEQ0zaxZ7iIAA68/DXxp4// > AGv1+LnjvRWs/hn8 > MNA+weAStzDKNV1PU4/+JjqCtEyyx7IUSzEE6vG24TRlW6AHH/ > FfVY/GP7QStY/8ePw30S60K6uO > c3Go6o1heywFWClfItbTTpA4DJJ/aJUMrW0ikA4Pxnq8HgvU/ > h58Wr5Q2j/D3XP7c1ONiVC6fJZ3 > en3c5ZQzf6Pb6hLd7FVnl+y+Sq7pVZQDO/bF+AnxW+InxQ8Q+ > KvCfgHVvE/hfV/hFrHg3TU8H61b > aFfWOuXFwJYW1OVrmza601lZf9GaW5iDLKzW6l90gB6b8TrbVdE+D37OX7P+ > vHSrj4gXUehXupza > DaCCxtLfQHsLy8uLWCOKKMwSXcdlZrCiwlEvxIsey3kUADU3RqscbEkIRlSV > JXbtIVRztCjbsHVV > OAFbAAN/4C2PhvxB4C+NH7OfjKxS6sYbzVLi8t/MkiGr6L4hub26WUOhXyQZptRswgk83 > /QfN+QT > RgAHmn7Lf7N3j7wf8brr4seIz4p0jwX4Z8A2Xw08K+HvHdxot7q8mnwzw3Qmlk0lVtoYo2j8 > lEZ7 > idz5kkkkYMaUAU/BusW/jTUfiB8WNPATRfiBrY1vTkViwksI7K > z0+zmDbVJ8+2sIrzYyq8X2zyWU > NGzMAdszAAk8cHB7Djv/AJ46ngGgDmbrQYfiN8QPAPwkumT+ > w9U+1eINeik5W/0nTJLYSWYTDB2u > Lq6sYpoJY2R7Rrtdys0YIB+jURYsSygSY5CnIB9M8EjOcZA70ATui > yDawyvcetAHxJ/w7j/Yq/4S > r/hMv+FD6X/a51A6kYDqGofYvOMnmFfsPn/ZvJLceR5Xk7fk2bfloA+ > 2giqcqoHvj6D+g/KgDwHx > D/ydP8HP+yf+Mv8A05eGKAPoKgAoAKAGn+tAHgHwb/5KN+1f/wBj/Z/+ot4eoA+ > gaACgAoArT7RG > 3mY2d8+n05z9McmgD4G+Ifh1vhl8X9ThjUReC/iCJdY08sfLgstbiC/ > 2hbJ8qxoLiEJfJGu6WWZN > VmcsFBUAn6bvlbqRk4GAD8vQn5jw24HHQgA0AfNvxx8TS/s4/ > Djx58ZvhxqWu+G9Whnhn1Gw8LXt > taW+szXV3FFLNNbXVtdWZumaRHa8NsbllhVPNCEqQD2XSfB+l2OsT+ > LNQmvNe8cXULW9z4q1+f7b > fyxMyyPCjtxb2zSgyrawrDbozM0cSZNAHWdC3uSx/wBonGSfUnGcnqcnqTQBj674c8P+ > KdKvND8T > aFYavotyEa4sNRtEu4pxGyyKHjcFWCsgYBuFIyMGgDwNvGvi0fGpv2b2+ > KHxFfwK3g4+KzCvilN5 > Avjb/Z21LyDq2DLifeNQJC/uNpiOxQD3zQPDvh/wrpFroPhfQ7DStCtCywWWlWsdrbxqx > 3kpHGqh > Qzu74CjLMzdSSQDYP3XOCcKSMHHOOAT2BOB+NAHzJ8RvEeofs8x/DHT/AIS+ > JvEPhDR/GHjHTvCb > 6R4au9P/ALO043RkYTw2V9Z3UFqUZZWdLSOATtKXlZmUEgHuPh3wZ4b8NSape6XYyS6v > qjINQ1nU > 7mXUr/UjEGEX2q/naSe6MavsQyyN5agIoVQFAB1RGRj3B+pHNAHK+ > IvB3hzxLLpl9qlk8WtaYHGn > 65pl1Jp2paYHx5otb+F457cSgFZDFIu9GdWDAsCAeH/DrxHqX7RUHxNsfi14j8SeLtE8GeLtR > 8KR > 6L4kurBtNv8A7MYmaeezsbOzguNzGJ0S5juPKaJWjZGJZgD6cZ2dtzHLep7U > AC4yNzBVzzkA8d8A > soZv7o3D5tv0IB6H+yr4fOqeHte+NOoLIbz4iJazaWWY7ofDkCv/ > AGWu5SATKtxdX3zIksQ1EQPx > bpgA+tQqr0GKAHUAFABQB8++If8Ak6f4Of8AZP8Axl/6cvDFAH0FQAUAFADT/WgDwD4N/ > wDJRv2r > /wDsf7P/ANRbw9QB9A0AFABQA0jPr+BxQBwXxB+HfhP4laHBoHizTprizguUure5s725s > LqxmUMv > mW93byRzwOyPJEzxOpaOWRGyjupAPnlf2ULxySf2kfilvIDE/ZfC45PJ5/ > sc9fqenJOBQB8cf8FB > P2e7jwJ+yJ8XPFD/ABv8f+IFsxpinR9ai0Fba536naR/vDa6bDN8u/cu2RfmVd25dykA+x0/ > ZSvJ > NoP7SfxTOFwGFv4WwuCQVH/EoOMHqBx09KAJf+GTLv8A6OT+Kn/ > gP4X/APlNQAxv2T7xMMP2k/in > wQd32fwt8uOc/wDIHGPT8aAPjZP2e7o/8FBj4JHxv+ICzj4N/wBqjxAYtB+ > 3lf7c8r7LgaabfyQf > nJ8rzdxA37QVIB9l/wDDJ14SWP7SnxT3Hq32fwtlvqf7Hyf > x6UAL/wAMmXXf9pP4pkejW3hYj8jo > 9AHxr+2P+z3d+Ff+GWBJ8cviBrX9rfGTw1pKf2vFoX+gNL9pxdQ+ > RpkWZo9uVEpeIgkMjfLgA+xF > /ZRvW5/4aS+KnAx80HhYle+M/wBkHrnsOcfSgCb/AIZMu/ > 8Ao5P4qf8AgP4X/wDlNQBG/wCylewr > uX9pP4rbuV+WHwuvUYxn+yB16fU88ZoA+N/2Ov2fLrxY/wC1Ts+ > Nvj7Rl0f4y+JdKP8AZMOgkag0 > Rtybmb7Rpsp85t+G8vZENo2ovOQD7M/4ZMu/+jk/ip/4D+F//lNQBf0v9kvwu14jeO/ > iT468daEv > zf2B4iuNOtbKZs4P2hNOs7VrmJkLxvbXDSW0iyMJInIUqAfWAAHQUALQAUAF > ABQB8++If+Tp/g5/ > 2T/xl/6cvDFAH0FQAUAFAEMjFduCM57/AP6/x+gNAHz7efBDWG8X+PPFfhP45+P/ > AAmvi3UIdVv9 > L0a20Ca2NzHZWliGT7bplxKuYbG3yPMI3ZIAJNAEv/CnfiL/ANHY/FT/AMF/ > hD/5R0AH/CnfiL/0 > dj8VP/Bf4Q/+UdAB/wAKd+Iv/R2PxU/8F/hD/wCUdAB/wp34i/ > 8AR2PxU/8ABf4Q/wDlHQAf8Kc+ > Ihx/xlh8VOOn/Eu8If8AyjoAQfBn4hKdw/aw+Km7GMnTvCB4/wDBJ7UAfEv/AAUY+ > G3jLw/+xv8A > GHV9X/aD8feJrCD+yt+h65ZeHI7W6LapZqvmNaaXBP8AKzB12 > Sr8yru3LuUgH2rH8HviGSSP2r/i > nuIwWGneD+SCQR/yBT0OeOgz9aAJv+FO/EX/AKOx+Kn/AIL/AAh/ > 8o6AGv8ABv4i8Y/aw+KZI5wd > O8Ic9en/ABJOD70AfEqfDbxof+CjX9g/8NAeP11Y/BP7X/ > wk4svDv27yv7d2/ZCh0v7N5OSJM+R5 > wbA8zb8tAH25/wAKd+Iv/R2PxU/8F/hD/wCUdAB/wp34i/8AR2PxU/ > 8ABf4Q/wDlHQB8Tftr/DTx > jpA/ZM/tL9oTx7rv2342eF7O3GrWXhxP7Onf7Ttu4fs2lxbpo8EqspeEgndGx24APtR > Pg98RCf8A > k634qDjvp3g8kexP9inr9O1AEv8Awp34i/8AR2PxU/8ABf4Q/ > wDlHQBFL8HviIoUn9q/4qnntp3h > H0Ppof8Ak474oA+J/wBif4ZeMdW/4a0OnftA+PtCaz+NniizuDpVj4cY6nMn2YNdTfaNLlxK+ > fmE > XlwjA2xJzkA+3f8AhTvxF/6Ox+Kn/gv8If8AyjoAP+FO/EX/AKOx+Kn/ > AIL/AAh/8o6AD/hTvxF/ > 6Ox+Kn/gv8If/KOgA/4U78Rf+jsfip/4L/CH/wAo6AD/AIU78Rf+ > jsfip/4L/CH/AMo6AD/hTvxF > /wCjsfip/wCC/wAIf/KOgBf+FO/EX/o7H4qf+C7wh/8AKOgC94S+DF7oPj/ > T/iL4l+L/AI08aa3p > 2j32i2MHiOLRYILSC8ns5p2VbGwtmZy2n2wBdmAAbABbNAHulABQAUAMdVcb > WGVPUev1oAAqgsw6 > nGaAH0AFABQAUAFABQB8Af8ABUX/AJMV+OJ9Dop5/wCwxY0AffaqAWbucZNAElAEU23y28z > b5fff > 0x70AfkF490z9uXwt8YvhF8EvCv7cb+JPGXjD7Xfag6fDLRYIPDOi2wPnX12y > ea4MkpSCBWWOOWY > MjTRkAkA/XeGVnC72G4qCBgrngZ4IyMHseRnmgC3QB8Aft8/82W+/wAf/CAP/ > k3QB99KOfpkD25/ > +tQBLQB82/tcfGvU/wBnX9nf4l/GPRdDtNW1rQILcWdlfyOkBnuLqG1je > Tb8zIjTq5RSpcJtDxlt > 6gHy38K/iv8AGP4X/tJfC74M/FL9ozQfjT4V+Lnhq51jw5qmiaDp2l3WmTW4a4WeSO1 > l2NYXNqs5 > jnBlaSWEqioscjOAfpbG7MQpYk47jvweT26jggGgCzQAUAFABQAUAFABQAUA > FABQAUAFABQAUAFA > BQAUAQyttUNwPmAJzjuKAPg39vPxn8Krj4W6Z8B/ihoXxG1+8+KU5h0/ > w98KdLjvtauF06SG+nlj > WUGJUjaOAOPnbbISqkK7xgH0F8Afj34R/aH8Jap4u8J6Xr+ > jvpWq3Og6t4f8VaebDUdI1C3KmW3u > IssquEkhf5XYASBW2urqoB7tQBDINy7e5OBzj8j64yaAPjD4ffCTx7P+ > 2x8e/jv47gul8K2/hjSP > CPgSQTWXkz6dIqXmoJJEgM4eO+jyrTFcrcOF3KE2AH2kEVSzBfmPU+ > tAEbkqBtznPTHX2z0Gf880 > Afnn+1v8UPhNq3jH4b/D3U/Bfxd8f+Mvht4o0rx7cab8GtBj1d9Du7cSmyj1 > XdxHHcLJKyxKRKVj > DkorI0gB9tfD3x/4S+KXhDQfiD4C1+01rwfrlut1Y6lYsxSVTwwIYKyurBkZ > HVXR1ZWVWUgAHc0A > eN/H+D4jXfwd8fWnwl8M+FvEfj6eyMVn4e8axtJpmrIWUT2s6Bk > DebAZo1DMqF3TeypuIAPzg/Za > /ZI17Rfj54P+Juq/staT8CvA/gDT9Rm0+wtvF6eJdR8SatqEa2sjXN0WlP2KC0j > cpASnlyyl1aQS > yhQD9eot25sk46bTjgcY6evJ/GgCzQAUAFABQAUAFABQAUAFABQAUAF > ABQAUAFABQAUAQTH9236k > Nt2juc+1AH5B/tX+G9PtP25vh1q/jz48ap8F/hl4u+GVz4fj8X6JqNvpVzqNxY6j9tk0+O+ > fd/Z+ > POs5jOwCyqpt1JaVhQB9Q/sEeOPiL4y+EHiex+IXir/hMIfCPi7VfC+geP8A7MY/+ > Ex0mzZI4dQM > okkS4LSfaE85Hbd5Q3tJIJJGAPuKgBjorja65X0PQ/WgBgUbiwzzx1OO/ > bp369/wFAE1AFeXdgY+ > 9njgkDg9cf8A1u1AH47/ABG1DWNE/bL/AGkJPDH7TGgfs1yXGj+ > FGutR8VWGnainxHdbe6CXtr/a > MkSQpbrizZbcsjPCxco5wAD69/4J4w20P7GnwFS18F3HhaH+ > yHY6XdySyyTu08rNe7pAGCXbE3iK > BtVLlVQsgViAfadADWVWxuHQ5FADRGg+6uOc8cUAKEVfujHXgdOaAH0AFABQAU > AFABQAUAFABQAU > AFABQAUAFABQAUAFAEbqrjaw45/lj+tAHHeNPh54A+I+mQaH8RPA2geKNEhuFu4tP8RaZBqEE U > 6q > 6iVY5lZRIFkkAYANh2GcE0AdDpOkaVoOmafomh6Zaado1hBHa2ljYwrDDbQx > qFSKONQFRFVVVVAA > AAAAAFAGpQAUAFABQBGyhtpYA4Ofof8AOR+NAHn3jj4R/Cr4nf2X/wALK+ > Gnhbxb/ZokFl/wk+j2 > 2pfZPM2+Z5XnI2wt5abtuN2xc5wMAHoSqqjC/rzQA+gAoAKACgAoAKACgAoAKACgAoAKACgA > oAKA > CgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAo > AKACgAoAKACgCNyR > jB+bPA9aAII5GZgD/dB5BH0OMcZ54J7CgC3QAUAV5yyxOyk > ggdQMkfQdz7d+lABE0hKiQgNjJXPI > 4H5855GB7UALISAMMAe2fp6d/pxQBCjyFpM/wuRhgenbBx0xznnkkdRQAsEhlUHdvH > XcBwT+Q9iD > 3zkcUAXKAI3JG39c/wCPagCvBIZVB3bx13AcE/kPYg985HFAFygAoAKACgCCQkAYYA9s > /T07/Tig > COFpC8wbPDEYP6YOBkY5zzySOoNAFugAoAKACgAoAKACgAoAKACgAoAKAK8z > lIyy43dt2P8AEdOv > XtQB4Xrvj268FfFO4t/HniC20/4Ya34Y+0aZd3xjtbXT9Q09rqbUVuLl1TEktnc > Ws0SFmBi0y+k2 > xCFmkAPIrX43at4H0nQ/G/xY0XXnupfBPjj4gmDe1pd6XotrqFhc > 2+nXOmZjga/jsr+0gZ5GDRS2 > kyCSQTySMAL4J/awvPG+peJvCHhuw+G/i/4hw+GtR8RaNpPwz+ > I0HiGC9eza3iNre3L2lsLF5pby > 2WFysisFuCxj8pRIAaV9+2N4GuT4kXwZZ/2/nQNO1Dwt+9msv+ > Eo1K9Nl5OnjzYB9lB/t3w1/pEv > yf8AE3OQBaXJQA9K/aa1jV9C/Zx/aC1zRdUutM1jTvBWuXVnqNnM1vPaTx > 2MxjkikUhkZXCsrA5B > 6EECgDj/ABt8e/FfhmT4v69ofgDTdV+H3wpLr4r1C88QS2Wo5j0+31S4/ > s6yS0lhuNtndw7BLdQF > pg8beWoErgDvH3x98W+GH+Luv6L8PNK1H4efCosfFWpX3iKWx1Bj > Hp0GpzjTrRbOWO5xaXduE864 > t9829D5aqJmAM3wR8UNUf4x/H34caeLvxD4ktvG2nstjNeslt4Z0Zt > A0SSSeVzv8lWla6aG3Rd1z > cNLtCxpd3FuAUdH+PHiq51Xw94L+HHwvTV9f17UPHLiTxB4tkittP/ > sXxAthJJc3DwzTrDO1yzRR > wxS+QxhgSMQ7poADorL4++LPE8Pg/QvAvgHSbv4iasfEJvNP1/xBJp+ > nWn9hajHpmo+VeQ2dxJKD > eTxiDdbRmWEO7+SyiJgD034RePNZ+I/gk+I/EGh2mi61b6vq+jXenWN+1/ > BFcadqVzp8jxXDRQtJ > G7WhcBo0YBiCDigDxPTPjr4ql1Lw34O+G/wvXWNd8Raj46KSa/ > 4rlitrE6L4gWwlkuLmWGaZYJmu > maOKCKUwN5UCx+TumgAKHij44fFrVl/Z6vvhr4Z8Pi71/ > wAba54W8QaPretyWsM11p1nrMUsEV0l > hO5tTdaZNOlwIopWW3gVolFxKIQDrvHPx+8V+Fm+Leu6N8P9K1P4efCzf/ > wlepX3iCWz1HMOnW+p > 3H9n2aWcsVxttLuHZ5tzbF5hIjCJFEzAHrHxV8fy/DL4WfEf4lLp66k3hPw/ > qOu/2Z5ghN0La3ln > WMyDcE3CMqWw3qB2oA8K8RftKePPCjePF1/4Km2HgzQYvG+uE+JLeX7H4ck+ > 1bFykZ36wf7PvB9j > QNZ5i51EBkLAFz49ftO2HwJ1Jm8Qaj8Nv7FstJbWrvTtX8dDSvEN3bo0wkGn > aU9oy3bskDCFTcRL > JMTGSgXzSAchr/x/b4Sa98b5de1bSme9+Jtn4b0STxr4jGjaNpefCWlai8c146S > m0hbyrtlEcMm+ > 4nVSqmVpFAPbvgV8bNO+NXh7xFqljceH5bvw/rB0S/vPCmuJruk3M/2W2uwbK+ > WOIzJ5d7CjFokZ > ZUlTB2h2AM+7+K3xK1PxX450j4e/DPSfEGg+CdQh0vXZr3xGdM1G4umsra/ > ePTrU2slvN/o99bhD > cXluDNvRzEiiZgDnvHX7QHivww3xg8QaJ4B0nU/hx8Kyf+Eo1S+1+ > Wy1EiPTbfVJjp9ktnLFckWd > 3BsEt1b75gyN5ShZWAKHi/8AaL8aeG7346ajZfCu0uvAXwiuCfEO > v3viIW8t5aLpNnqkp061W1fz > rqOK6dTDPJbRFvI23DebKLcAPF/7RXjPw7e/HW+sfhTbXXgH4R3BPiLX7rxELee7tF0mz > 1SVtOtV > tZPOuo4bl1MNxJbQk+RtnbzZRbgHK/Fj9tDwz8LvF3xD0a9uvAcGm+ > BSn9tWfiLxtFpWu34FlDqD > f2PpZtnF6Wt7qJIg9xB5lwrx4VVErgHrOofFj4j33ivxxpPw/ > wDhhpeuaD4L1CHTNblv/Ev9m6lN > dNY2uoPHp9qbWS3m/wBGvrZVM93bK0xkRmijUTsAUNI8dfF > 2+/ae8feAP7J0B/hXpfhnQdRS4bV5 > Eu7WS4l1dWlSAWJEryy2kcLRtcqscUEcyMzzSRIAUPA3x98V+J5PhJrmt+ > ANL074d/FMJ/wimp6f > r8l5qOZdOuNUgGo2TWkUVsTZ2kwfyrq4CzGNF8xGaZADtPgJ8T/GHxj8B+ > HviRr3gC18K+HfEeka > fqukWp1oaheyJPCJJDcIsCRxICyNCVld5InVpEt5N0KgHutABQAx0VxtcZFA > HnfxM+G3hT4oaBZ6 > D4utBLp9tqFtfq4SJmPlviWAmRWHk3MDz2c6AfvLa7niJCyNQBjeOvhJ4Q+ > JOqrf+Lobq8tW8L63 > 4RuNNSYwQXWn6o1kbwOyfvVfFhEqvG67Q0mckqVAJPBPw91rw5qdxq3iH4ue > M/Gl19nNrCviFtNt > rezVmVpdtvp9pbRyOxijG+ZZWjUMsRjEswkAOO0f9nH4YaIng37F > pKx/8I5r9z4gtx5VriYSljFZ > yFYhusbXytNNrCAvlDRdMwc2seAD074heCtN+I/gHxx8O9bnvING8VaTeaLeTWbok8MFz > A0MjRuy > socK7MpZWGQAQRxQB5l4u+AOj+Mb3xpu8ceKdH8JeOMnxV4Q0z7B9i8S > K1rFZS+c9xaSXcPmWVvb > 27i1ng2rGGTbKWlYAf4z+AOj+MNR8bE+OPFOj+FvG/8AyNnhHS/ > 7Oay8SE2sVlL50k1rLdxeZZW9 > vA32S4gwsQdNkrNKwBtx/BrwynizXPHVre6tZ+LtR15NefUraSMPCRZWFhcWKgxYayuI > NLtvNilV > 9z7ZkKSxW0kIAvhX4L+GvCXiXSPFOnahq8moaWPEwiS7midP+ > J7qsOrXm/agPyTW8aRYI2xkhjI2 > GUA8v8c/CZ/BmiaHrXw2tviRP40s9W164ivvAlx4dfUILbW9Qk1S/ > iZNYC2bWpuo7fbtQ3KiCJVb > a0xYA9D/AGd/AupfDn4U2PhvU7W5tLp9X1zU47PUNQbUbqzgvtVvL2CC6ujLIZrmOK6RJn82 > UGVZ > CssgIkYAueFPgv4U8JeJNG8TaVqWqNqGn/8ACUGKO4li2P8A27q0GrXm4BA2Ent4 > 0iwQVjYht7YY > AGfc/A3QX8MaXoek+I9c0fVtK8Tap4v0rxFYSWkt5pd/qNxfzXLRLNBJbyI0eqX1uqzQyYjkD Z > 81 > VkUAzvGfwD0vxZqPjUjx74p0jwr42dR4s8J6WNO+xeI1a2isZfPkntXu4TNZ20NqTa3EOB > GHTZIz > SMAep/EHwXpXxG8AeOPh7rtxdW+i+KdIvNGu57BlimjhuYXhdoi4ZVcCQlW > ZWG7GQRxQBx3jb4Me > GfHS/FtdWvdUi/4WJ4Qg8F6obOWJFtrNP7S/eW+5G2z41a5JZ9ynbEAvDbgDj/iN+ > z1ZfEKP4iWt > n8UvGnhDQfH0Tp4l0jw8ukmHVWe0isXnZ72xnnhlazgtoD5Ekar5SMFEhkdg > Dodb+Bvh7VLzxJre > m+JNf0XxVqPieLxbb65pclq02iaiukQaMxt47iCWBkaxidGW4imx9okddrCIxg > HfeCfC134V0qez > vvGWv+KNRu52u59Z8QTxNPOxVVQLFBFFbwosccaiOCKJSQ0jK0ssruAefa78FY9S8U > +ItZ0b4m+M > /DGk+JJ4rzX9B8NzWNvBq06QRWpla5lt5L21Z7W1toN1ncW5UW+9CkrNIwBS8afs/ > aJ4x1Pxq7+N > /FOkeF/G/wDyNfhLTDp7WfiQtax2UvnSTWst3D5llDDbsLS5gwke5NkrPIwBu638GPCvi > Lw38ePD > GoXmqJYfFcXH9sywyxrJatLpNtpLi0LR4XEFnGwMgbLux5UhQAS698GfDOu+ > Gvjz4Wvb/VEs/iyZ > xrUkEsSSWom0m20pjakowTFvaRsPMD/vNx5UqoAMvWvgrDq3ibxH4g0f4k+ > MvC9h4oniu9f0Pw/N > YwQ61KkEVt5jXMtq97aubW2toS1pcW5j8sPGUmLSsASa58E49R8SeJdd0P4l > +NPCuneJp0u/EOg+ > Hbiwgg1i4W3htWla4ktZLy1dra3toS9ncwFREsiFJS0rAHWXPw/ > spfiNB8StP1rVdO1R9Pi0zVLG > 1S3ktNctYDcPaJcLLC7oLeW9upUNvJCzNKRKZFVVUA8/8G/ADR/ > CepeDJG8b+KNX8KeCWYeE/CWr > /wBnCy8NYtZbGIQywW0d1Nss7ieBftc85ZZw8geVVkUA9T+ > HHgvTfhz4D8EfD7RLi6m0Xwto9nol > pLeyJJO8FrEkKGZkVVMhVFLFVC7t2AAcUAd3QAUAFACEAjmgCIxRsu1kBU8E > Y4IxjkfSgBwRd24j > JzkE84+npQAwRqvAyDnPU/5/x59TQA7y48Y2jb6dvyoAPLQFm28nBO > O5HegAMUbAqV+UjBHqPQ0A > HloT90dQeO+On5UACxRrtCoBtGBx0+lACrGqjaucfU0ANEUYG0Rrt2hcY7Do > Ppz0oAfsXduwM+v+ > fqfzoAaI1VdoyM+5/nQAvlxgBQowOgHbvQApRfp9DigCMRR > qFUINqjAGOg64HtwOPagBfKjznYM5 > z+Pr9ffrQACNB69MDk8f5z1oAXy485289z69Bz69B+VADti+np+ > lADTFGwKlflIwR6j0NAClV54A > zwSOD7UAIsMarsVFCf3QOPyoAPLQFm28nBOO5HegBwRQeF/z/ > kmgCMQxjadvI4yeT2zz74GfWgB4 > jQLtVcL7cYoAFjVcbVxjgew9Pp7UASUAFABQAUAFABQAUAFABQAUAFABQAUA > FABQAUAFABQAUAFA > BQAUAFABQAUAFABQAUAFABQAUAFAH//ZCmVuZHN0cmVhbQplbmRvYmoKMTQgM > CBvYmoKPDwvUjcK > NyAwIFI+PgplbmRvYmoKMTggMCBvYmoKPDwvUjcKNyAwIFI+ > PgplbmRvYmoKMTkgMCBvYmoKPDwv > VHlwZS9NZXRhZGF0YQovU3VidHlwZS9YTUwvTGVuZ3RoIDE0MzM+ > PnN0cmVhbQo8P3hwYWNrZXQg > YmVnaW49J++7vycgaWQ9J1c1TTBNcENlaGlIenJlU3pOVGN6a2M5ZCc/ > Pgo8P2Fkb2JlLXhhcC1m > aWx0ZXJzIGVzYz0iQ1JMRiI/Pgo8eDp4bXBtZXRhIHhtbG5zOng9J2 > Fkb2JlOm5zOm1ldGEvJyB4 > OnhtcHRrPSdYTVAgdG9vbGtpdCAyLjkuMS0xMywgZnJhbWV3b3JrIDEuNic+ > CjxyZGY6UkRGIHht > bG5zOnJkZj0naHR0cDovL3d3dy53My5vcmcvMTk5OS8wMi8yMi1yZGYtc3lu > dGF4LW5zIycgeG1s > bnM6aVg9J2h0dHA6Ly9ucy5hZG9iZS5jb20vaVgvMS4wLyc+ > CjxyZGY6RGVzY3JpcHRpb24gcmRm > OmFib3V0PSdjYWVmZGExYS02NmQ2LTExZTctMDAwMC0wMGIzZDY4MzNiYTYn > IHhtbG5zOnBkZj0n > aHR0cDovL25zLmFkb2JlLmNvbS9wZGYvMS4zLycgcGRmOlByb2R1Y2VyPSdH > UEwgR2hvc3RzY3Jp > cHQgOC43MScvPgo8cmRmOkRlc2NyaXB0aW9uIHJkZjphYm91dD0nY2FlZmRh > MWEtNjZkNi0xMWU3 > LTAwMDAtMDBiM2Q2ODMzYmE2JyB4bWxuczp4bXA9J2h0dHA6Ly9ucy5hZG9i > ZS5jb20veGFwLzEu > MC8nPjx4bXA6TW9kaWZ5RGF0ZT4yMDE3LTA3LTA5VDAwOjUwOjM2LTA3OjAw > PC94bXA6TW9kaWZ5 > RGF0ZT4KPHhtcDpDcmVhdGVEYXRlPjIwMTctMDctMDlUMDA6NTA6MzYtMDc6 > MDA8L3htcDpDcmVh > dGVEYXRlPgo8eG1wOkNyZWF0b3JUb29sPlBTY3JpcHQ1LmRsbCBWZXJzaW9u > IDUuMi4yPC94bXA6 > Q3JlYXRvclRvb2w+PC9yZGY6RGVzY3JpcHRpb24+CjxyZGY6RGVzY3JpcHRpb24gcmRmOm > Fib3V0 > PSdjYWVmZGExYS02NmQ2LTExZTctMDAwMC0wMGIzZDY4MzNiYTYnIHhtbG5z > OnhhcE1NPSdodHRw > Oi8vbnMuYWRvYmUuY29tL3hhcC8xLjAvbW0vJyB4YXBNTTpEb2N1bWVudElE > PSdjYWVmZGExYS02 > NmQ2LTExZTctMDAwMC0wMGIzZDY4MzNiYTYnLz4KPHJkZjpEZXNjcmlwdGlv > biByZGY6YWJvdXQ9 > J2NhZWZkYTFhLTY2ZDYtMTFlNy0wMDAwLTAwYjNkNjgzM2JhNicgeG1sbnM6 > ZGM9J2h0dHA6Ly9w > dXJsLm9yZy9kYy9lbGVtZW50cy8xLjEvJyBkYzpmb3JtYXQ9J2FwcGxpY2F0 > aW9uL3BkZic+PGRj > OnRpdGxlPjxyZGY6QWx0PjxyZGY6bGkgeG1sOmxhbmc9J3gtZGVmYXVsdCc+ > RGlwVHJhY2UgU2No > ZW1hdGljIC0gSVZPIFByb3AgQ3VycmVudCBMaW1pdGVyLmRjaDwvcmRmOmxp > PjwvcmRmOkFsdD48 > L2RjOnRpdGxlPjxkYzpjcmVhdG9yPjxyZGY6U2VxPjxyZGY6bGk+ > RXJpYzwvcmRmOmxpPjwvcmRm > OlNlcT48L2RjOmNyZWF0b3I+PC9yZGY6RGVzY3JpcHRpb24+ > CjwvcmRmOlJERj4KPC94OnhtcG1l > dGE+CiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg > ICAgICAgICAg > ICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAg > ICAgICAgICAgICAg > ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKPD94cGFja2V0 > IGVuZD0ndyc/Pgpl > bmRzdHJlYW0KZW5kb2JqCjIgMCBvYmoKPDwvUHJvZHVjZXIoR1BMIEdob3N0 > c2NyaXB0IDguNzEp > Ci9DcmVhdGlvbkRhdGUoRDoyMDE3MDcwOTAwNTAzNi0wNycwMCcpCi9Nb2RE > YXRlKEQ6MjAxNzA3 > MDkwMDUwMzYtMDcnMDAnKQovVGl0bGUoRGlwVHJhY2UgU2NoZW1hdGljIC0g > SVZPIFByb3AgQ3Vy > cmVudCBMaW1pdGVyLmRjaCkKL0NyZWF0b3IoUFNjcmlwdDUuZGxsIFZlcnNp > b24gNS4yLjIpCi9B > dXRob3IoRXJpYyk+PmVuZG9iagp4cmVmCjAgMjAKMDAwMD > AwMDAwMCA2NTUzNSBmIAowMDAwMTA0 > MjI4IDAwMDAwIG4gCjAwMDAxMjM4NzcgMDAwMDAgbiAKMDAwMDEwNDE1NSAw > MDAwMCBuIAowMDAw > MTAzNzAyIDAwMDAwIG4gCjAwMDAwMDAwMTUgMDAwMDAgbiAKMDAwMDA0MDEz > MyAwMDAwMCBuIAow > MDAwMTA0MjkzIDAwMDAwIG4gCjAwMDAxMDQzOTMgMDAwMDAgbiAKMDAwMDEw > NDMzNCAwMDAwMCBu > IAowMDAwMTA0MzYzIDAwMDAwIG4gCjAwMDAxMDM4NjcgMDAwMDAgbiAKMDAw > MDA0MDE1NCAwMDAw > MCBuIAowMDAwMDY1NzIyIDAwMDAwIG4gCjAwMDAxMjIzMDcgMDAwMDAgbiAK > MDAwMDEwNDAxMSAw > MDAwMCBuIAowMDAwMDY1NzQ0IDAwMDAwIG4gCjAwMDAxMDM2ODAgMDAwMDAg > biAKMDAwMDEyMjMz > NyAwMDAwMCBuIAowMDAwMTIyMzY3IDAwMDAwIG4gCnRyYWlsZXIKPDwgL1Np > emUgMjAgL1Jvb3Qg > MSAwIFIgL0luZm8gMiAwIFIKL0lEIFs8NTRGMDU3QzlCNzdBRDZDNEYwQjg0 > N0M3MzU1NUQ0Q0Q+ > PDU0RjA1N0M5Qjc3QUQ2QzRGMEI4NDdDNzM1NTVENENEPl0KPj4Kc3RhcnR4 > cmVmCjEyNDEwOQol > JUVPRgo > > ________________________________ Message 2 > _____________________________________ > > > Subject: AeroElectric-List: Re: IVO Prop current limiter > From: "kfav8r" <kfav8r(at)outlook.com> > > > The DPDT switch is mounted in the panel (in my case), along with the red > and green > LEDs. > For the Arduino setup, I have the relay and the current sensing module in > a box > behind the panel, and the arduino placed nearby. > On my Arduino layout drawing, the right side is from one of Bob's origina l > drawings. > He included the 10 Amp circuit breaker there, since that is what is > delivered > with the IVOProp. > For wiring, I used 16 AWG for any wires handling prop motor current; that > is the > size delivered with the prop. > My name is Doug Garland, but true credit goes to Dennis Glaeser for > starting this > discussion years ago, and, of course, Bob. > > -------- > Doug > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=470815#470815 > > > ________________________________ Message 3 > _____________________________________ > > > Subject: Re: AeroElectric-List: Re: IVO Prop current limiter > From: "Paul A. Fisher" <paulf(at)hughes.net> > > Nicely drawn Eric! > > Your message asks a lot of questions that I'm not qualified to answer. > However, I can answer the question about the PIC pins you chose - they > should work fine. I'll write the code based on the brief description > Bob gave in his note. I'm assuming that a LIMIT SENSE of greater than > 0.5 volts for more than 0.5 seconds is the trigger we want. I'll put > those values in EEPROM fields on the chip so they are relatively easy to > change if we want. > > At some point we'll need someone with an IVO prop to actually test this > and give us real world feedback. > > This is fun! > > Paul > > > On 7/9/2017 3:05 AM, Eric Page wrote: > > I've converted Bob's sketches to a CAD file. Anyone with interest in > > the project please look over my work (see attached PDF) and post any > > changes/critiques for the group to consider. When we're all happy, > > I'll turn it into a printed circuit board, stuff it with parts and a > > DIP-8 socket, and send it to Paul so he can add a programmed PIC to > > test with his code. > > > > A couple of notes: > > - I've assumed that the DPDT motor-control relay will be mounted > > elsewhere (off the PCB). > > - I've drawn a notional wiring diagram including a switch and a second > > relay. If this isn't how the IVO prop works, let me know what to chang e. > > - I guessed at the correct PIC GPIO pins to use. Paul, let me know if > > you need something different. > > > > Things to consider: > > - For BOM simplicity, I used the same 2k resistors for R1-R8, and > > 0.1uF for C2 and C3. Any problems with this? > > - Any other component substitutions or value changes? > > - What's the desired physical envelope (PCB with mounting holes / PCB > > for a small potting box / something else...)? > > - What type of connector(s) should be used (a DB-9 is shown)? > > - Are the fuse values on the wiring diagram appropriate? > > - What AWG should be specified for each wire run? > > > > Doug (kfav8r), in order to give you credit on the schematic, would you > > like to send me your last name? > > > > Cheers, > > > > Eric > > > > > > > ________________________________ Message 4 > _____________________________________ > > > From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> > Subject: Re: AeroElectric-List: Re: IVO Prop current limiter > > At 08:59 AM 7/8/2017, you wrote: > > >The software that Bob describes would be pretty simple to write for > >the PIC12F683 chip, the same chip we used for the wig-wag open > >source project. I'll volunteer to contribute the software if > >someone wants to pursue Bob's hardware design using a PIC chip > >instead of the Arduino as an open source project. > > I'm up to my eyeballs in a couple of development > efforts along with juggling domestic duties . . . > but if someone wants to brassboard this project, > I'll volunteer to package it into a readily > duplicated product. > > I've posted a proposed schematic of the controller > at http://tinyurl.com/ybbtw6dp > > A minimalist approach to packaging would > look something like this. The fat power transistor > would be on the bottom, heat transfer surface down. > This would facilitate using airframe for heat-sinking > like our schottky e-bus diode did. The connector > would be 15 pin. The ECB footprint would be about > 1.25 x 1.75 inches. The 'kit' would look something > like this except that the 700-2-7 switch is > missing. > > > Emacs! > > > Oh yeah, had a gray-matter fart while crafting the > schematic. The software can get MUCH simpler. > > On power up, the initialization CLEARS the LIMIT > LATCH and removes gate drive from the clamping > fet. > > The analog input is monitored for amplitude greater > than 0.5 volts; greater than 0.5 seconds whereupon > the LIMIT LATCH is SET, gate of clamp fet goes > high and removed drive from the current limit fet. > > An excursion below 0.5v will reset the LIMIT > TIMER. > > After limit time out, the condition is sustained > until next power-down/power-up event. > > I need to keep my head down on some more pressing > tasks for the next 10 days or so. You guys can > shepherd this along in the mean time. > > Bob . . . > > ________________________________ Message 5 > _____________________________________ > > > From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> > Subject: Re: AeroElectric-List: Re: IVO Prop current limiter > > At 09:58 AM 7/9/2017, you wrote: > > >Nicely drawn Eric!=C2 > > > >Your message asks a lot of questions that I'm > >not qualified to answer.=C2 However, I can answer > >the question about the PIC pins you chose - they > >should work fine.=C2 I'll write the code based on > >the brief description Bob gave in his > >note.=C2 I'm assuming that a LIMIT SENSE of > >greater than 0.5 volts for more than 0.5 seconds > >is the trigger we want.=C2 I'll put those values > >in EEPROM fields on the chip so they are relatively easy to change if we > want. > > > >At some point we'll need someone with an IVO > >prop to actually test this and give us real world feedback. > > Yes, brass-boarding is the acid test. You guys > had pushed this cart further down the road than > I thought since I sat down at the keyboard last > night. > > Both .pdf and .dwg files of my work product are > at http://tinyurl.com/yby3waw6 for use > as the chefs of this design stew see fit. > > I'll be standing by . . . > > > Bob . . . > > ________________________________ Message 6 > _____________________________________ > > > From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> > Subject: Re: AeroElectric-List: Re: IVO Prop current limiter > > At 12:45 PM 7/8/2017, you wrote: > >Sorry - defective iPhones and all that. > > > >Possible simplifications to consider: > > > >- If you=99re using a PIC maybe you could > >dispense with the current limiter. If you sense > >the current the PIC can send the FET high impedance within a few > microseconds. > > The motor's current profile is rather trashy. > Without active current limiting, you'll have > motor inrush currents during spin-up. > > As I recall the mechanical details of this > product, the prop-pitch mechanism has soft > stops that will compress as the mechanism > approaches limits causing the motor current > to ramp up toward stall current. > > The original design goal was to tolerate a > deliberate opening of the prop pitch circuit > breaker . . . which is a rather slow device . . . > on the order of hundreds of milliseconds. > > All this electron/silicon herding does is > get us a more predictable, solid state > replacment for the thermal breaker. The > current limiter adds one transistor > and one resistor and offers a predictable > upper bound on stall current. > > > Bob . . . > > ________________________________ Message 7 > _____________________________________ > > > From: GTH <gilles.thesee(at)free.fr> > Subject: AeroElectric-List: Fat wires > > > Hi all, > > Some buddies asked me to install the wiring in their brand new project. > > The engine is a Rotax with short connexions so the fattest wires in the > ship will be AWG 6. > > Due to restricted space, they installed their fuseblock on a hinge > within inches from the battery contactor, but the gauge 6 wire from the > contactor to the bus proves very stiff and hard to manage with this > pivoting installation. > > I considered using a short length of welder cable, but the insulation is > so thick that it did not help much. > > What would be your opinion about downsizing this particular wire to AWG > 8 or 10 for more flexibility ? > > Thanks in advance, > > -- > Best regards, > Gilles > http://contrails.free.fr > http://lapierre.skunkworks.free.fr > > > ________________________________ Message 8 > _____________________________________ > > > From: Alec Myers <alec(at)alecmyers.com> > Subject: Re: AeroElectric-List: Fat wires > > > what about using a short stub of 8 gauge with a good splice to 6 gauge? > > On Jul 9, 2017, at 18:54, GTH wrote: > > > Hi all, > > Some buddies asked me to install the wiring in their brand new project. > > The engine is a Rotax with short connexions so the fattest wires in the > ship will > be AWG 6. > > Due to restricted space, they installed their fuseblock on a hinge within > inches > from the battery contactor, but the gauge 6 wire from the contactor to th e > bus > proves very stiff and hard to manage with this pivoting installation. > > I considered using a short length of welder cable, but the insulation is > so thick > that it did not help much. > > What would be your opinion about downsizing this particular wire to AWG 8 > or 10 > for more flexibility ? > > Thanks in advance, > > -- > Best regards, > Gilles > http://contrails.free.fr > http://lapierre.skunkworks.free.fr > > > ________________________________ Message 9 > _____________________________________ > > > From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> > Subject: Re: AeroElectric-List: Fat wires > > At 05:54 PM 7/9/2017, you wrote: > > > >Hi all, > > > >Some buddies asked me to install the wiring in their brand new project. > > > >The engine is a Rotax with short connexions so the fattest wires in > >the ship will be AWG 6. > > > >Due to restricted space, they installed their fuseblock on a hinge > >within inches from the battery contactor, but the gauge 6 wire from > >the contactor to the bus proves very stiff and hard to manage with > >this pivoting installation. > > > >I considered using a short length of welder cable, but the > >insulation is so thick that it did not help much. > > > >What would be your opinion about downsizing this particular wire to > >AWG 8 or 10 for more flexibility ? > > > Wires need to be sized for the expected service. > Fat wires in the starter circuit will, no doubt, > want to be 6AWG. Given that the bus loads on this > aircraft cannot exceed the system loads. The > bus feeder can be downsized. What size alternator > is installed? Bus loads generally don't exceed > alternator output . . . 12AWG would be fine for > up to 30A of engine driven power source. > > I would use a fusible link on such smaller bus > feeders . . . a 6" piece of 16AWG under > some firesleeve would be about right for 12AWG > bus feeder. > > > Bob . . . > > ________________________________ Message 10 > ____________________________________ > > > Subject: Re: AeroElectric-List: Fat wires > From: rayj <raymondj(at)frontiernet.net> > > > Maybe a couple of extra coils in the wire would solve the flexibility > problem. > > Raymond Julian > Kettle River, MN > > The things we admire in men, kindness and generosity, openness, honesty, > understanding and feeling are the concomitants of failure in our system. > And those traits we detest, sharpness, greed, acquisitiveness, meanness, > egotism and self-interest are the traits of success. And while men > admire the quality of the first they love the produce of the second. > -John Steinbeck, novelist, Nobel laureate (1902-1968) > > On 07/09/2017 05:54 PM, GTH wrote: > > > > Hi all, > > > > Some buddies asked me to install the wiring in their brand new project. > > > > The engine is a Rotax with short connexions so the fattest wires in the > > ship will be AWG 6. > > > > Due to restricted space, they installed their fuseblock on a hinge > > within inches from the battery contactor, but the gauge 6 wire from the > > contactor to the bus proves very stiff and hard to manage with this > > pivoting installation. > > > > I considered using a short length of welder cable, but the insulation i s > > so thick that it did not help much. > > > > What would be your opinion about downsizing this particular wire to AWG > > 8 or 10 for more flexibility ? > > > > Thanks in advance, > > > > > ________________________________ Message 11 > ____________________________________ > > > Subject: AeroElectric-List: Re: Fat wires > From: "user9253" <fransew(at)gmail.com> > > > My Rotax 912 powered RV-12, along with 500 others that are flying, all > have 12 > AWG wires about 4 feet long connecting the Dynamo and battery to the main > power > bus. The starter is connected with 8 AWG about 2 feet total length. > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=470832#470832 > > > ________________________________ Message 12 > ____________________________________ > > > Subject: Re: AeroElectric-List: Fat wires > From: Charlie England <ceengland7(at)gmail.com> > > > On 7/9/2017 5:54 PM, GTH wrote: > > > > Hi all, > > > > Some buddies asked me to install the wiring in their brand new project. > > > > The engine is a Rotax with short connexions so the fattest wires in > > the ship will be AWG 6. > > > > Due to restricted space, they installed their fuseblock on a hinge > > within inches from the battery contactor, but the gauge 6 wire from > > the contactor to the bus proves very stiff and hard to manage with > > this pivoting installation. > > > > I considered using a short length of welder cable, but the insulation > > is so thick that it did not help much. > > > > What would be your opinion about downsizing this particular wire to > > AWG 8 or 10 for more flexibility ? > > > > Thanks in advance, > > > You didn't mention the actual load, but if the plane is Rotax powered, > I'd guess that it shouldn't be too large. > > I did a quick google search for a DC current capacity calculator, & > found this: > http://www.solar-wind.co.uk/cable-sizing-DC-cables.html > If you plug in 30 amps, 1% voltage loss, & 0.2 meters length (~8"), It > says that 14 AWG is adequate. 70 amps asks for 10 AWG. Remember, with > less than a foot of wire, there's very little resistance loss unless the > wire is grossly undersized. > > 6 AWG sounds like major overkill to me, unless they're trying to run the > starter current through it. > > Charlie > > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus > > > ________________________________ Message 13 > ____________________________________ > > > Subject: Re: AeroElectric-List: Re: IVO Prop current limiter > From: "Paul A. Fisher" <paulf(at)hughes.net> > > Eric - See Bob's redesign. I was in the process of writing code for > your drawing when Bob sent his note. I now have a version of the > software written (but not tested!) for both versions of the hardware, so > you just need to let me know which one you want to pursue. > > Paul > > > On 7/9/2017 11:06 AM, Robert L. Nuckolls, III wrote: > > At 08:59 AM 7/8/2017, you wrote: > > > >> The software that Bob describes would be pretty simple to write for > >> the PIC12F683 chip, the same chip we used for the wig-wag open source > >> project. I'll volunteer to contribute the software if someone wants > >> to pursue Bob's hardware design using a PIC chip instead of the > >> Arduino as an open source project. > > > > I'm up to my eyeballs in a couple of development > > efforts along with juggling domestic duties . . . > > but if someone wants to brassboard this project, > > I'll volunteer to package it into a readily > > duplicated product. > > > > I've posted a proposed schematic of the controller > > at http://tinyurl.com/ybbtw6dp > > > > A minimalist approach to packaging would > > look something like this. The fat power transistor > > would be on the bottom, heat transfer surface down. > > This would facilitate using airframe for heat-sinking > > like our schottky e-bus diode did. The connector > > would be 15 pin. The ECB footprint would be about > > 1.25 x 1.75 inches. The 'kit' would look something > > like this except that the 700-2-7 switch is > > missing. > > > > > > Emacs! > > > > > > Oh yeah, had a gray-matter fart while crafting the > > schematic. The software can get MUCH simpler. > > > > On power up, the initialization CLEARS the LIMIT > > LATCH and removes gate drive from the clamping > > fet. > > > > The analog input is monitored for amplitude greater > > than 0.5 volts; greater than 0.5 seconds whereupon > > the LIMIT LATCH is SET, gate of clamp fet goes > > high and removed drive from the current limit fet. > > > > An excursion below 0.5v will reset the LIMIT > > TIMER. > > > > After limit time out, the condition is sustained > > until next power-down/power-up event. > > > > I need to keep my head down on some more pressing > > tasks for the next 10 days or so. You guys can > > shepherd this along in the mean time. > > > > Bob . . . > > > > > ________________________________ Message 14 > ____________________________________ > > > Subject: AeroElectric-List: Re: IVO Prop current limiter > From: "Eric Page" <edpav8r(at)yahoo.com> > > > paulf(at)hughes.net wrote: > > Eric - See Bob's redesign. I was in the process of writing code for > your drawing > when Bob sent his note. I now have a version of the software writt en > (but not tested!) for both versions of the hardware, so you just need to > let > me know which one you want to pursue. > > > > Paul > > > Paul, > > I was just composing a post to ask Bob a couple of questions in that > vein. Stand > by while I sort that out and we'll press ahead shortly. > > One question for you: am I correct in assuming that PIC outputs are > push-pull (that > is, when low, they actively pull to ground)? > > Thanks, > > Eric > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=470837#470837 > > > ________________________________ Message 15 > ____________________________________ > > > From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> > Subject: Re: AeroElectric-List: Re: IVO Prop current limiter > > At 09:06 PM 7/9/2017, you wrote: > > > > > >paulf(at)hughes.net wrote: > > > Eric - See Bob's redesign. I was in the process of writing code > > for your drawing when Bob sent his note. I now have a version > > of the software written (but not tested!) for both versions > > of the hardware, so you just need to let me know which one you want to > pursue. > > > > > > Paul > > > > > >Paul, > > > >I was just composing a post to ask Bob a couple of questions in that > >vein. Stand by while I sort that out and we'll press ahead shortly. > > > >One question for you: am I correct in assuming that PIC outputs are > >push-pull (that is, when low, they actively pull to ground)? > > > > > The general purpose outputs are active pull-up/pull-down. > > A bit more robust in the pull down as I recall . . . > > Yes the output will pull down to less than 0.6 v with a 8.5mA > source. > > > Emacs! > > > Input will pull up to within 0.7 of Vdd with a 3.0mA sink > > > Emacs! > > > Bob . . . > > ________________________________ Message 16 > ____________________________________ > > > Subject: AeroElectric-List: Re: IVO Prop current limiter > From: "Eric Page" <edpav8r(at)yahoo.com> > > > Paul, > > One more question: with respect to GP3/MCLR, should it be left floating, > pulled > up to Vdd, or have an RC power-on-reset circuit? > > Eric > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=470839#470839 > > > ________________________________ Message 17 > ____________________________________ > > > Subject: AeroElectric-List: Re: IVO Prop current limiter > From: "Eric Page" <edpav8r(at)yahoo.com> > > > Bob, > > I have a few questions/comments about your drawing ( > http://tinyurl.com/ybbtw6dp (http://tinyurl.com/ybbtw6dp)): > > > A. The big current limit MOSFET is going to be in one of three states: > > 1. Fully on: The pilot has moved the switch, the PIC is powered on, and > LIMIT LATCH > is released, allowing motor drive voltage to pull up the MOSFET's gate > through > the 1k resistor. Rds(on) is at minimum value and dissipation is negligib le > (less than 1/4W). > > 2. Fully off: The PIC sees >=0.5V for >0.5 sec on LIMIT SENSE. LIMIT > LATCH goes > high, turning on the 2N7000, which pulls the MOSFET's gate to ground. > Dissipation > is zero. [0.5V = 7.5A motor current.] > > 3. Linear region: Motor current has spiked to >9A, causing the sense > resistors > and 2N3904 to regulate the MOSFET's gate to hold the 9A level. > Dissipation is > high, but LIMIT LATCH will trip in 0.5 sec max, dropping it to zero. > > So, it seems to me that unless we worry that the pilot will continue to > cycle the > switch in the stalled direction with the limit light illuminated, we don' t > need to be too concerned with heat sinking the MOSFET. Your thoughts? > > > B. You're powering the PIC from the motor drive voltage, but you > mentioned in > your reply to Alec Myers that this is likely to be a "trashy" rail. Your > new > schematic only uses this rail to power the PIC and pull up the current > limit MOSFET's > gate. Could we eliminate the two 1N4001 diodes and the wires linking > them to the switch, and instead bring in a constant supply on a single > wire from > the bus side of the switch? Is there some benefit to turning the PIC on > and > off with the prop switch? > > > C. Your current sense resistor is shown rated at 2W. I've calculated > 2.4W dissipation > at 6A motor current, rising to 3.75W at 7.5A and 5.4W at 9A. I used > three 0.2R 3W resistors in parallel to get 0.066667 ohms at 9W. > > > D. The 2N7000 that switches the TRAVEL LIMIT light can tolerate > Vds=Vdg=60V. > What is the 24V Zener diode doing? > > > Cheers, > > Eric > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=470840#470840 > > =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Jul 10, 2017
Subject: Re: IVO Prop current limiter
> >I remember when I started doing research in prep for building my >RV7A (in 2004!!), and discovered the AeroElectric list (and Vans >AirForce). Wow! >My plane has been flying for over 9 years now, and I still follow >all these forums and continue to expand my education, and stay >amazed at all of the talented folks involved who are willing to >share their time, effort, and knowledge, with Bob solidly at the >head of that line. What you're describing is what I call "back of the napkin germination, evolution and perfection of an idea". The most elegant solutions are most often the amalgamation of time and talents in a demonstration of spontaneous order. I have had several jobs where this kind of collaboration and refinement of ideas took place . . . automatically. The most fun jobs I've had the pleasure to hold. I think Burt told us during the Mojave roll-out that Voyager was conceived on the back of a napkin (or perhaps an envelope) at a local beanery. Now I'm never without my favorite back of the napkin design tool . . . http://tinyurl.com/ybum6b78 . . . for decades, some of the most exciting germinations over tacos at Connie's El Mexico cafe were frustrated by ball-points that plowed holes in the napkins. Wetting your finger in salsa is a poor substitute. I discovered these pens a few years ago. They draw cleanly and damage free on the cheapest of napkins. I now carry two . . . one to 'talk' with, the other to give away when my partner(s) in contemplation are impressed with the utility of the tool. In our case, the 'napkin' is a modern collection of applications and byte-thrashers, not the least of which is Matt's servers. But what we do here has roots in antiquity. It is in the finest traditions offered up by the likes of Kettering, Edison, Johnson, Beech, Rutan, VanG, et. als. Bob . . . ________________________________________________________________________________
Date: Jul 10, 2017
Subject: Re: AeroElectric-List Digest: 17 Msgs - 07/09/17
At 12:32 PM 7/10/2017, you wrote: >I got a gazillion pages of gibberish.=C2 J=C3=BCrgen > Looks like your email client didn't recognize an image file and dumped it out as a 'text' file. What email program are you using? Bob . . . ________________________________________________________________________________
Subject: Re: Fat wires
Date: Jul 10, 2017
> > > / >> / >> / > /You didn't mention the actual load, but if the plane is Rotax > powered, I'd guess that it shouldn't be too large. > > [...] > > 6 AWG sounds like major overkill to me, unless they're trying to run > the starter current through it. / Charlie, Joe, Bob, Raymond, Alec, Thank you for responding. Indeed the Rotax 912iS alternator is rated at 30 A, so 12 AWG with a 16 AWG fuselink seems adequate, and the wire stiffness problem will be solved. Thanks a lot, -- Best regards, Gilles http://contrails.free.fr http://lapierre.skunkworks.free.fr ________________________________________________________________________________
Date: Jul 10, 2017
I proofed the ecb layout I posted. I'll get some made. I'll have 5 or so boards to 'share' with anyone who wants to participate in beta-testing the hardware/software. Boards should be in about Wednesday. Bob . . . ________________________________________________________________________________
Date: Jul 11, 2017
FYI: Everyone who reads the list via email just got a gazillion pages of gibberish due to your post. This is an extra PIA for those of us who subscribe to the digest as we have to scroll through all of the gibberish you posted to get to something that matters. Thanks for sharing. -------- Jim McChesney Tucson, AZ RV-7A Finishing Kit Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470887#470887 ________________________________________________________________________________
Date: Jul 11, 2017
On Tue, Jul 11, 2017 at 7:55 AM, rvtach wrote: > > FYI: Everyone who reads the list via email just got a gazillion pages of > gibberish due to your post. This is an extra PIA for those of us who > subscribe to the digest as we have to scroll through all of the gibberish > you posted to get to something that matters. Thanks for sharing. > > -------- > Jim McChesney > Tucson, AZ > RV-7A Finishing Kit > Jim, I get the list via email (*not* digest; is that how you actually get it?), and I have no idea what you're talking about, or who you're talking to. You might need to be a bit more specific. Charlie ________________________________________________________________________________
Date: Jul 11, 2017
Hi Charlie- I apologize for not being clear. I was directing my comment to Jurgen - the poster who complained about a gazillion pages of gibberish and in so doing included the gazillion pages of gibberish for the rest of us to experience. I get the list via the once daily digest. When someone replies to a digest email, the entire content of the that 24 hours of email are included in that reply. And then when the list subscribers get their next digest email they have to scroll through an entire 24 hours of list postings in the middle of the current digest of emails. Jurgens post includes an example of how the digest version of the list arrives in subscribers' mail box. Regards- Jim -------- Jim McChesney Tucson, AZ RV-7A Finishing Kit Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470901#470901 ________________________________________________________________________________
Date: Jul 11, 2017
I've got code written for the PIC as well. I may need to tweak the voltage and time parameters to get exactly 0.5v and 0.5s when we get down to the actual circuit. But that's easily done in EEPROM values. Paul On 7/10/2017 10:11 PM, Robert L. Nuckolls, III wrote: > I proofed the ecb layout I posted. I'll get some > made. I'll have 5 or so boards to 'share' with > anyone who wants to participate in beta-testing > the hardware/software. Boards should be in > about Wednesday. > > Bob . . . > ________________________________________________________________________________
Date: Jul 11, 2017
can you post your code for review? On Jul 11, 2017, at 17:50, Paul A. Fisher wrote:
June 29, 2017 - July 11, 2017
AeroElectric-Archive.digest.vol-ny
