AeroElectric-Archive.digest.vol-nz
July 11, 2017 - August 08, 2017
      I've got code written for the PIC as well.  I may need to tweak the voltage and
      time parameters to get exactly 0.5v and 0.5s when we get down to the actual circuit.
      But that's easily done in EEPROM values.
      Paul
      > On 7/10/2017 10:11 PM, Robert L. Nuckolls, III wrote:
      > I proofed the ecb layout I posted. I'll get some
      > made. I'll have 5 or so boards to 'share' with
      > anyone who wants to participate in beta-testing
      > the hardware/software. Boards should be in
      > about Wednesday.
      >  Bob . . .
Subject: Re: IVO Prop current limiter
Date: Jul 11, 2017
Certainly. Bob, could you please add the IVO Prop controller software to your site with the rest of the files? It's currently in our Dropbox share. Please be kind on your comments on the code - I haven't tried to clean it up to make it presentable - it's still at version 0.03, so I may still do quite a bit of tweaking before we declare v1.0. But I am interested in anything you see that we could improve on. Thanks! Paul On 7/11/2017 5:03 PM, Alec Myers wrote: > > can you post your code for review? > > On Jul 11, 2017, at 17:50, Paul A. Fisher wrote: > > > I've got code written for the PIC as well. I may need to tweak the voltage and time parameters to get exactly 0.5v and 0.5s when we get down to the actual circuit. But that's easily done in EEPROM values. > > Paul > > >> On 7/10/2017 10:11 PM, Robert L. Nuckolls, III wrote: >> I proofed the ecb layout I posted. I'll get some >> made. I'll have 5 or so boards to 'share' with >> anyone who wants to participate in beta-testing >> the hardware/software. Boards should be in >> about Wednesday. >> >> Bob . . . >> > > ________________________________________________________________________________
Date: Jul 11, 2017
At 05:28 PM 7/11/2017, you wrote: > >Certainly. Bob, could you please add the IVO Prop controller >software to your site with the rest of the files? It's currently in >our Dropbox share. Sorry for the delay . . . was in Wichita putting the finishing touches on a staircase to my sister's deck. Paul's software offering can be found at: http://tinyurl.com/yby3waw6 You guys might be thinking about how you'd like to configure the 'elegant' package. The ECB I've crafted will lend itself to either an open- to-the-sky style of installation, like our old AEC9005 . . . Emacs! of course, this can be put into some form of enclosure with the connector extending through the wall. There's a kinda cute extruded aluminum enclosure offered from several sites on the 'net . . . Emacs! The final configuration could be converted to surface mount components. Connections brought out on flying leads through a grommet. The advantages for thru-hole components is that more people might be encouraged to take on the project. Anyone spotted another option? Bob . . . ________________________________________________________________________________
Date: Jul 11, 2017
On 7/11/2017 7:30 PM, Robert L. Nuckolls, III wrote: > At 05:28 PM 7/11/2017, you wrote: >> >> >> Certainly. Bob, could you please add the IVO Prop controller >> software to your site with the rest of the files? It's currently in >> our Dropbox share. > > Sorry for the delay . . . was in Wichita putting the > finishing touches on a staircase to my sister's deck. > > Paul's software offering can be found at: > > http://tinyurl.com/yby3waw6 > > You guys might be thinking about how you'd like to > configure the 'elegant' package. The ECB I've > crafted will lend itself to either an open- > to-the-sky style of installation, like our > old AEC9005 . . . > > Emacs! > > of course, this can be put into some form > of enclosure with the connector extending > through the wall. > > > There's a kinda cute extruded aluminum > enclosure offered from several sites on > the 'net . . . > > Emacs! > > The final configuration could be converted to surface > mount components. Connections brought out on flying > leads through a grommet. > > The advantages for thru-hole components is that > more people might be encouraged to take on > the project. Anyone spotted another option? > > > Bob . . . > ----------------- Hi Bob I would like one of the IVO prop current limiters if you have one left . Emil Radtke pulsar111 with Jabriu 3300 engine ------------------you can send me info on this page. thank you ________________________________________________________________________________
Date: Jul 11, 2017
Wow -- I went to work for a two-day trip and you guys have the project all but finished! I guess with the through-hole PCB layout done and ordered, there's probably little point in me continuing my effort to do it here. I'll lay down my pencil unless there's another way I can assist. If it's decided to pursue a surface mount version, I'd be happy to work on that. Just say the word... Cheers, Eric ________________________________________________________________________________
Subject: Troubleshooting 200G/ Z-17
Date: Jul 11, 2017
All, The good news from today is that I successfully ran my freshly overhauled O-200 today in preparation for a FAA inspection in a few weeks. The bad news is that I am getting no alternator output at all. The alternator is a B&C 200G PM dynamo, wired per Z-17 (no master contactor.) Running the engine between idle and 1800 RPM saw no change in bus voltage, which stayed at the same 13.1V as it did with the engine not running. Troubleshooting so far- besides checking all wiring connections, I verified that the OV relay is working and that I wired it correctly. I verified that the alternator's raw output was as expected (15-25VAC, increasing with speed.) I measured voltage at the capacitor (just downstream of the regulator) and it was the same 13.1 and did not vary with speed. Disconnecting the regulator I verified that there is zero volts coming out of the regulator, although I understand from the troubleshooting documents that it must have bus voltage applied in order to output, so I'm thinking this doesn't mean much. Is this as simple as a bad regulator? I'm going to call B & C first thing tomorrow but I thought I'd check here first. Thanks Jeff Point Milwaukee ________________________________________________________________________________
Date: Jul 11, 2017
At 08:32 PM 7/11/2017, you wrote: > >Wow -- I went to work for a two-day trip and you guys have the >project all but finished! wouldn't bet on that . . . but it did take a quantum jump >I guess with the through-hole PCB layout done and ordered, there's >probably little point in me continuing my effort to do it >here. I'll lay down my pencil unless there's another way I can assist. Let's see how the >If it's decided to pursue a surface mount version, I'd be happy to >work on that. Just say the word... The board I have is about 2x the area that would be required for SM components . . . and if I were tooling up to build quantities, I'd go SM. But if we're wanting to maximize penetration into the DIY community, TH is probably better. Once the hardware and software are successfully married, an SM version in the smaller extruded aluminum enclosure might encourage someone to build up small quantities for sale . . . to be sure, the plug-n-play community is larger than the DIY community. B&C might be intreseted in adding it to their stable of products . . . let's see how the project matures. Bob . . . ________________________________________________________________________________
Date: Jul 11, 2017
> >Hi Bob I would like one of the IVO prop current limiters if you have >one left . Emil Radtke pulsar111 with Jabriu 3300 engine >------------------you can send me info on this page. thank you Emil, at the moment, this is a spontaneously organized cooperation to develop the product. The boards I mentioned are bare boards which I will make available to individuals who will be the beta-testers . . . they'll have to acquire parts and assemble them. At the moment, I have no plans to produce them here but somebody on the List might be willing to help you out. Bob . . . ________________________________________________________________________________
Date: Jul 11, 2017
Subject: Re: Troubleshooting 200G/ Z-17
At 10:04 PM 7/11/2017, you wrote: > >All, > >The good news from today is that I successfully ran my freshly >overhauled O-200 today in preparation for a FAA inspection in a few >weeks. The bad news is that I am getting no alternator output at all. >The alternator is a B&C 200G PM dynamo, wired per Z-17 (no master >contactor.) Running the engine between idle and 1800 RPM saw no >change in bus voltage, which stayed at the same 13.1V as it did with >the engine not running. > >Troubleshooting so far- besides checking all wiring connections, I >verified that the OV relay is working and that I wired it >correctly. I verified that the alternator's raw output was as >expected (15-25VAC, increasing with speed.) I measured voltage at >the capacitor (just downstream of the regulator) and it was the same >13.1 and did not vary with speed. Disconnecting the regulator I >verified that there is zero volts coming out of the regulator, >although I understand from the troubleshooting documents that it >must have bus voltage applied in order to output, so I'm thinking >this doesn't mean much. Yes . . . was your alternator disconnect relay closing when you moved the switch to ALT+BAT postion? Bob . . . ________________________________________________________________________________
Date: Jul 12, 2017
Bob, The only relay I have in the system is the small black relay which connects to the crowbar module, and I did verify that it was working. I cycled it on and off several times while running the engine (via the circuit breaker) with no change in bus voltage. Jeff On 7/11/17 11:16 PM, Robert L. Nuckolls, III wrote: > > Yes . . . was your alternator disconnect relay closing when > you moved the switch to ALT+BAT postion? > > Bob . . . > ________________________________________________________________________________
Date: Jul 12, 2017
At 06:50 AM 7/12/2017, you wrote: >Bob, > >The only relay I have in the system is the small black relay which >connects to the crowbar module, and I did verify that it was >working. I cycled it on and off several times while running the >engine (via the circuit breaker) with no change in bus voltage. > >Jeff Hmmm . . . without putting my own hands on it and probing with the instruments . . . it does sound like a faulty R/R. Check with B&C Bob . . . ________________________________________________________________________________
Date: Jul 12, 2017
Subject: Gobledigoop
My apologies for loading everyone up with the pages of code (that did not come from me). I didn't know how else to get the message across. J=C3=BCrgen ________________________________________________________________________________
Subject: Newbe Question about getting started.
Date: Jul 12, 2017
New Guy here....I am building a Bearhawk Patrol, and reading thru AeroElectric Connection for the second time. Following Bob's recommendations, I have started a "Wirebook" with a few Bus and system schematics. How do I bring together a safe and reliable aircraft electrical system from my wire book? I had a thought. Build a peg board mock up of my instrument panel and firewall with all the tubing that exists between the two, then assemble and wire all the switches, contractors, relays, Fuse Blocks, diodes, crow bars, D-sub connectors, fuses, and what not. I could add the electrical accessories as I acquire them... Maybe acquiring a few products at OSH this year? Seems like building a mock up is a good place to start help acquire the tools, and wiring skills. In the end I suppose I could wire up the avionics, antennas, and finalize the wire bundles then bench test the whole system prior to installation. Does this method seem prudent? What have others done? Brooks Cone -------- Brooks Cone Bearhawk Patrol Kit Build Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470950#470950 ________________________________________________________________________________
Subject: Re: Newbe Question about getting started.
Date: Jul 12, 2017
Yes, that is a good approach but the big schnitzel to eat first is building the airplane. Bob has published a great resource. Avionics shops are usually happy to wire-up radios you buy from them. I have wired three airplanes; for me just installing stuff and running wires works OK. There are always things to figure out: shields, comm mic hi, comm mic lo, crimp or solder D-subs, RG-400 vs RG-400A vs RG-58, etc, but with the internet, the answers are readily available. Question is whether it is something youd really like to learn and do. -Kent > On Jul 12, 2017, at 4:53 PM, bcone1381 wrote: > > > New Guy here....I am building a Bearhawk Patrol, and reading thru AeroElectric Connection for the second time. Following Bob's recommendations, I have started a "Wirebook" with a few Bus and system schematics. > > How do I bring together a safe and reliable aircraft electrical system from my wire book? > > I had a thought. Build a peg board mock up of my instrument panel and firewall with all the tubing that exists between the two, then assemble and wire all the switches, contractors, relays, Fuse Blocks, diodes, crow bars, D-sub connectors, fuses, and what not. I could add the electrical accessories as I acquire them... Maybe acquiring a few products at OSH this year? Seems like building a mock up is a good place to start help acquire the tools, and wiring skills. In the end I suppose I could wire up the avionics, antennas, and finalize the wire bundles then bench test the whole system prior to installation. > > Does this method seem prudent? What have others done? > > Brooks Cone > > -------- > Brooks Cone > Bearhawk Patrol Kit Build > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=470950#470950 > > > > > > > > > ________________________________________________________________________________
Date: Jul 13, 2017
At 03:53 PM 7/12/2017, you wrote: > >New Guy here....I am building a Bearhawk Patrol, and reading thru >AeroElectric Connection for the second time. Following Bob's >recommendations, I have started a "Wirebook" with a few Bus and >system schematics. > >How do I bring together a safe and reliable aircraft electrical >system from my wire book? > >I had a thought. Build a peg board mock up of my instrument panel >and firewall with all the tubing that exists between the two, then >assemble and wire all the switches, contractors, relays, Fuse >Blocks, diodes, crow bars, D-sub connectors, fuses, and what not. I >could add the electrical accessories as I acquire them... Maybe >acquiring a few products at OSH this year? Seems like building a >mock up is a good place to start help acquire the tools, and wiring >skills. In the end I suppose I could wire up the avionics, >antennas, and finalize the wire bundles then bench test the whole >system prior to installation. As suggested . . . get the airplane built first . . . or at least mostly built. Check out exemplar airplanes at OSH, talk to the builders, join one or more Bearhawk forums. Find out what things make sense to assemble out of the airplane. The peg board is used in production environments to great advantage for cookie-cutter airplanes. But know that most peg boards are designed around a harness that was built up in the airframe first then used as a model for duplication. Further, the board may be 'adjusted' several times before the installers offer to buy beers for the folks on the wire balcony. Do the page-per-system wirebook. Wire each system one at a time . . . there are no 'complex' systems . . . after you've completed a dozen or so pages of wiring you find yourself all done. There is VERY little wiring associated with radios that is not concentrated in instrument panel area and again, on a radio-by-radio basis . . . pretty simple. Your biggest single asset is a line of communications with folks that have been-there-done-that. It's even better if you can see what they've done by looking at the airplane (osh again). But I cannot recommend purchasing any whippy products offered over the counter at OSH until your fellow builders have given the thumbs up for return-on-investment. Having been to osh perhaps 18 times, I can say that super-selling over the counters and digging through the super-garage-sale at the north end are problematic for the neophyte builder. The biggest bargain I ever purchased out of the Fly Market was a King KY-90, S/N 110 . . . probably built by hand in Ed King's farmhouse factory south of Olathe, KS. I think I paid $10 for it. The various Lists and Forums on the 'net are your best resources for data and advice. Your best resource for materials may just turn out to be eBay . . . Let's talk . . . Bob . . . ________________________________________________________________________________
Date: Jul 13, 2017
>How do I bring together a safe and reliable aircraft electrical >system from my wire book? Not nit picking here . . . but read chapter 17 again. There is no such thing as a 'safe' airplane, only low-risk and lower-risk airplanes. All airplanes are dangerous as hell in their ability to make your day very miserable. What does 'reliable' mean . . . nothing ever breaks? Won't happen. ASSUME that everything you bolt to your airplane is going to break. How will you KNOW that it has broken? If in flight, how does failure influence likely outcome of the flight? Can the failure be pre-flight detected? If loss of that feature raises your level of discomfort to unacceptable levels (too much risk) then what is your Plan-B for mitigating that failure? The lowest risk FLIGHT system is fabricated by a builder who understands systems sifted for high risk failure modes and flown by a pilot who is confident in the builder's decisions for crafting a FAILURE TOLERANT airplane. Bob . . . ________________________________________________________________________________
Date: Jul 13, 2017
I don't often offer my advice but I will on this one occasion since the ori ginal post was from an admitted newbie. Don't buy any major components (Avionics, Engines, radios, props, =C2-etc .) until you are ready to use them. I have found thru very expensive experience to make an ordered list of smal l projects to be completed over a measured period of time.=C2- I then rev iew that list, determine the parts (if any) that are required and order the m at that time.=C2- I=C2-keep the time frame short for the list (1 mont h at most) and delay any major purchases until I know that I can't work aro und them.=C2- Make your decisions on what you are going to use and build toward that but be flexible, so much is changing that you don't want to get caught with a lot of expensive equipment you will never use. My advice is free but the experience that it is based on was very, very exp ensive. Bob Reed From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> To: aeroelectric-list(at)matronics.com Sent: Thursday, July 13, 2017 12:15 PM Subject: Re: AeroElectric-List: Newbe Question about getting started. At 03:53 PM 7/12/2017, you wrote: --> AeroElectric-List messageposted by: "bcone1381" New Guy here....I am building a Bearhawk Patrol, and reading thruAeroElectr ic Connection for the second time.=C2- Following Bob'srecommendations, I have started a "Wirebook" with a few Bus andsystem schematics. How do I bring together a safe and reliable aircraft electrical systemfrom my wire book? I had a thought.=C2- Build a peg board mock up of my instrument paneland firewall with all the tubing that exists between the two, thenassemble and wire all the switches, contractors, relays, Fuse Blocks,diodes, crow bars, D-sub connectors,=C2- fuses, and what not. I couldadd the electrical acce ssories as I acquire them... Maybe acquiring a fewproducts at OSH this year ?=C2-=C2- Seems like building a mock up is agood place to start help ac quire the tools, and wiring skills.=C2- Inthe end I suppose I could wire up the avionics, antennas, and finalizethe wire bundles then bench test the whole system prior toinstallation. =C2-=C2- As suggested . . . get the airplane built first . . . =C2-=C2- or at least mostly built. Check out exemplar airplanes =C2-=C2- at OSH, talk to the builders, join one or more Bearhawk =C2-=C2- forums. =C2-=C2- Find out what things make sense to assemble out =C2-=C2- of the airplane.=C2- The peg board is used inproduction =C2-=C2- environments to great advantage for cookie-cutter =C2-=C2- airplanes. But know that most peg boards are =C2-=C2- designed around a harness that was built up in the =C2-=C2- airframe first then used as a model forduplication. =C2-=C2- Further, the board may be 'adjusted' several times =C2-=C2- before the installers offer to buy beers for the =C2-=C2- folks on the wire balcony. =C2-=C2- Do the page-per-system wirebook. Wire each system one =C2-=C2- at a time . . . there are no 'complex' systems . . . =C2-=C2- after you've completed a dozen or so pages of wiring =C2-=C2- you find yourself all done. =C2-=C2- There is VERY little wiring associated with radios =C2-=C2- that is not concentrated in instrument panel area =C2-=C2- and again, on a radio-by-radio basis . . . pretty =C2-=C2- simple. =C2-=C2- Your biggest single asset is a line of communications =C2-=C2- with folks that have been-there-done-that. It's even =C2-=C2- better if you can see what they've done by looking at =C2-=C2- the airplane (osh again). =C2-=C2- But I cannot recommend purchasing any whippy products =C2-=C2- offered over the counter at OSH until your fellowbuilders =C2-=C2- have given the thumbs up for return-on-investment. =C2-=C2- Having been to osh perhaps 18 times, I can say thatsuper-selli ng =C2-=C2- over the counters and digging through thesuper-garage-sale =C2-=C2- at the north end are problematic for the neophytebuilder. =C2-=C2- The biggest bargain I ever purchased out of the FlyMarket =C2-=C2- was a King KY-90, S/N 110 . . . probably built by handin =C2-=C2- Ed King's farmhouse factory south of Olathe, KS. Ithink =C2-=C2- I paid $10 for it. =C2-=C2- The various Lists and Forums on the 'net are your best =C2-=C2- resources for data and advice. Your best resource formaterials =C2-=C2- may just turn out to be eBay . . . =C2-=C2- Let's talk . . . =C2- Bob . . . ________________________________________________________________________________
Date: Jul 14, 2017
Thanks for all the advice. I started scratch building the Bearhawk Patrol about three years ago, decided to abort that in favor of the kit last year at this time, and took delivery of the kit in March of this year. The build is going well, and faster than I had anticipated. Bob Nuckolls, Your concise advice as sound and I've read, and I take it seriously. THERE ARE NO COMPLEX SYSTEMS.....and NO SUCH THING AS A SAFE AIRPLANE... ASSUME EVERYTHING...WILL BREAK, Craft a failure tolerant aircraft. Have a plan B for mitigating failure. Robert Reed, I hear you....Delay-Delay as long as I can. NO plans for big purchases...and will heed the temptation. -------- Brooks Cone Bearhawk Patrol Kit Build Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470990#470990 ________________________________________________________________________________
Date: Jul 15, 2017
The boards didn't make it here yestereday . . . flight delay . . . will be here Monday. How do you guys want to disposition the 5 extra boards? I'll keep one to play with. If as many as five others want to build one, it sorta makes sense that one person in the build group buy parts and split up into kits. Saves on postage, procurement $time$ and perhaps increased opportunity for quantity breaks. Bob . . . ________________________________________________________________________________
Date: Jul 16, 2017
Subject: Re: AeroElectric-List Digest: 1 Msgs - 07/15/17
Bob, You can put me down for one. If I break away from the Tailwind then I can concentrate on another project. Merle On Sun, Jul 16, 2017 at 2:59 AM, AeroElectric-List Digest Server < aeroelectric-list(at)matronics.com> wrote: > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete AeroElectric-List Digest can also be found in either of > the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the AeroElectric-List Digest and can be viewed with a generic text > editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style > 82701&View=html&Chapter 17-07-15&Archive=AeroElectric > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style > 82701&View=txt&Chapter 17-07-15&Archive=AeroElectric > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > AeroElectric-List Digest Archive > --- > Total Messages Posted Sat 07/15/17: 1 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 07:31 AM - Re: Re: IVO Prop current limiter (Robert L. Nuckolls, > III) > > > ________________________________ Message 1 > _____________________________________ > > > From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> > Subject: Re: AeroElectric-List: Re: IVO Prop current limiter > > The boards didn't make it here yestereday . . . flight > delay . . . will be here Monday. > > How do you guys want to disposition the 5 extra boards? > > I'll keep one to play with. If as many as five others > want to build one, it sorta makes sense that one > person in the build group buy parts and split > up into kits. > > Saves on postage, procurement $time$ and perhaps > increased opportunity for quantity breaks. > > > Bob . . . > > ________________________________________________________________________________
Date: Jul 16, 2017
Update- A call to B&C and a new regulator was on it's way to me. They agreed that, while rare, the symptoms and trouble shooting indicated a bad one. I got the new one, installed it... and nothing. The same results. I've confirmed that the dynamo is putting out AC voltage which varies with engine speed as it should. I confirmed that the regulator is seeing battery voltage (13.1) with the motor off. I confirmed that the relay is working. Interestingly, after a longer runup including 10 seconds at full power, battery voltage at the end was 0.2V higher than when we started the run. This was measured at the panel voltmeter and confirmed by my electrician friend with his high-doller Fluke meter at the battery. One data point that I failed to mention- I'm running a Earth-X 680C LiFePo battery, and perhaps this battery with it's built-in electronics is somehow disrupting the normal workings of things? I would still expect bus voltage to come up to the set point of 14.4 at full power, but it did not. Jeff On 7/11/17 11:16 PM, Robert L. Nuckolls, III wrote: > At 10:04 PM 7/11/2017, you wrote: >> >> All, >> >> The good news from today is that I successfully ran my freshly >> overhauled O-200 today in preparation for a FAA inspection in a few >> weeks. The bad news is that I am getting no alternator output at all. >> The alternator is a B&C 200G PM dynamo, wired per Z-17 (no master >> contactor.) Running the engine between idle and 1800 RPM saw no >> change in bus voltage, which stayed at the same 13.1V as it did with >> the engine not running. >> >> Troubleshooting so far- besides checking all wiring connections, I >> verified that the OV relay is working and that I wired it correctly. >> I verified that the alternator's raw output was as expected >> (15-25VAC, increasing with speed.) I measured voltage at the >> capacitor (just downstream of the regulator) and it was the same 13.1 >> and did not vary with speed. Disconnecting the regulator I verified >> that there is zero volts coming out of the regulator, although I >> understand from the troubleshooting documents that it must have bus >> voltage applied in order to output, so I'm thinking this doesn't mean >> much. > > Yes . . . was your alternator disconnect relay closing when > you moved the switch to ALT+BAT postion? > > Bob . . . > ________________________________________________________________________________
Date: Jul 16, 2017
Occasionally relays will physically close but not pass current. Might be worth hard wiring across the relay contacts to confirm. Might be worth clipping a conventional battery onto the Earth-x to see what happens. I think my dynamo will go a lot higher than 25vac if it has no load. My next step might be to conform the AC output under load perhaps by clipping an automotive headlamp onto the AC output. I'd expect it to brighten right up at fast idle. Ken On 16/07/2017 8:12 AM, Jeff Point wrote: > > Update- A call to B&C and a new regulator was on it's way to me. They > agreed that, while rare, the symptoms and trouble shooting indicated a > bad one. I got the new one, installed it... and nothing. The same > results. > > I've confirmed that the dynamo is putting out AC voltage which varies > with engine speed as it should. I confirmed that the regulator is > seeing battery voltage (13.1) with the motor off. I confirmed that the > relay is working. > > Interestingly, after a longer runup including 10 seconds at full > power, battery voltage at the end was 0.2V higher than when we started > the run. This was measured at the panel voltmeter and confirmed by my > electrician friend with his high-doller Fluke meter at the battery. > > One data point that I failed to mention- I'm running a Earth-X 680C > LiFePo battery, and perhaps this battery with it's built-in > electronics is somehow disrupting the normal workings of things? I > would still expect bus voltage to come up to the set point of 14.4 at > full power, but it did not. > > Jeff > > On 7/11/17 11:16 PM, Robert L. Nuckolls, III wrote: >> At 10:04 PM 7/11/2017, you wrote: >>> >>> All, >>> >>> The good news from today is that I successfully ran my freshly >>> overhauled O-200 today in preparation for a FAA inspection in a few >>> weeks. The bad news is that I am getting no alternator output at all. >>> The alternator is a B&C 200G PM dynamo, wired per Z-17 (no master >>> contactor.) Running the engine between idle and 1800 RPM saw no >>> change in bus voltage, which stayed at the same 13.1V as it did with >>> the engine not running. >>> >>> Troubleshooting so far- besides checking all wiring connections, I >>> verified that the OV relay is working and that I wired it >>> correctly. I verified that the alternator's raw output was as >>> expected (15-25VAC, increasing with speed.) I measured voltage at >>> the capacitor (just downstream of the regulator) and it was the same >>> 13.1 and did not vary with speed. Disconnecting the regulator I >>> verified that there is zero volts coming out of the regulator, >>> although I understand from the troubleshooting documents that it >>> must have bus voltage applied in order to output, so I'm thinking >>> this doesn't mean much. >> >> Yes . . . was your alternator disconnect relay closing when >> you moved the switch to ALT+BAT postion? >> >> Bob . . . >> > ________________________________________________________________________________
Date: Jul 16, 2017
At 07:12 AM 7/16/2017, you wrote: >Update- A call to B&C and a new regulator was on it's way to >me. They agreed that, while rare, the symptoms and trouble shooting >indicated a bad one. I got the new one, installed it... and >nothing. The same results. Has this system EVER worked? Bob . . . ________________________________________________________________________________
Date: Jul 16, 2017
Jeff, With the engine running, measure the voltage between the regulator red and black wires. Then measure the voltage between aircraft ground and the regulator black wire. Engine still running, measure voltage between the battery positive terminal and the regulator red wire. Let us know what you find. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471070#471070 ________________________________________________________________________________
Date: Jul 16, 2017
This is a new installation on an almost-finished but not yet flown homebuilt ... so no. The 200G did work in its previous installation, but it was sent b ack to B&C for an inspection following a prop strike accident, at which time it was updated to the latest and greatest guts. The new guts required a ne w regulator as well, as the old one (which worked in the previous installati on) would not work with the updated unit. Jeff Sent from my iPad > On Jul 16, 2017, at 4:30 PM, Robert L. Nuckolls, III <nuckolls.bob@aeroele ctric.com> wrote: > > At 07:12 AM 7/16/2017, you wrote: > >> Update- A call to B&C and a new regulator was on it's way to me. They ag reed that, while rare, the symptoms and trouble shooting indicated a bad one . I got the new one, installed it... and nothing. The same results. > > Has this system EVER worked? > > > Bob . . . ________________________________________________________________________________
Date: Jul 16, 2017
I'll give that all a whirl... but with Oshkosh around the corner it will be a couple of weeks. In the mean time help me out- what would you expect to learn from these measurements? I also have an old but serviceable Odessey 680 that I will swap out for the Earth-x and see if that makes a difference. Jeff See you all in Oshkosh next week. Sent from my iPad > On Jul 16, 2017, at 4:54 PM, user9253 wrote: > > > Jeff, > With the engine running, measure the voltage between the regulator red and black wires. Then measure the voltage between aircraft ground and the regulator black wire. Engine still running, measure voltage between the battery positive terminal and the regulator red wire. Let us know what you find. > > -------- > Joe Gores > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471070#471070 > > > > > > > > > ________________________________________________________________________________
Date: Jul 16, 2017
Subject: Z13/8 Schottky Diode Voltage Drop Increasing
I was flying along this week in cruise configuration, and was paying closer-than-usual attention to my voltage due to a battery swap. I notice that my main bus is running around 14.3 volts, and my ebus is down around 13.4. It has been a few years since I put this part of the airplane together, but I recall that one of the main selling points of the Schottky diode was to provide less of a voltage drop than that. Is there a failure mode or degraded condition of the diode that would cause it to have such a large drop? These measurements are with the Skyview EMS, taken right at the fuse block for each bus. My data collection archive for the two buses only goes back to December, but back then I had a more reasonable difference of a half volt or so. It seems like the difference between the two buses is increasing with usage. If this is an indication of an upcoming failure, I'd like to fix it, especially with a possible Oshkosh trip coming up. Things always seem to break on the way to Oshkosh. Has anyone else seen this? Thanks in advance! Jared ________________________________________________________________________________
Date: Jul 16, 2017
At 11:36 AM 7/15/2017, you wrote: >Bob, > > I would build one of those Prop limiters for my electric adj. IvoProp. > > If you need someone to make the initial order for parts, I'd be > happy to do that. I could disseminate the parts kits to the > interested builders. I have uploaded an illustrated bill of materials and a parts locator to . . . http://tinyurl.com/yby3waw6 Note that the BOM does not call out a mating D-sub connector (D15S) since each builder may choose from either crimp or solder-cup connectors. Also missing is a callout for a D15H hood. The builder will need 6-32 hardware to fasten the assembly down to the mounting-surface/heat-sink. A LED travel limit annunciator is also missing from the BOM. Something like this might tweak your fancy . . . http://tinyurl.com/y8j6qrva Unless the builder has programming capability for the PIC chip, I'll suggest the chip not be ordered from Digikey rather from someone in the project group with programming tools. I think the mechanical aspects of the data package are now complete. I'll assemble one here as well so we can beta-test software and compare notes. Bob . . . ________________________________________________________________________________
Date: Jul 16, 2017
Measuring voltage between the regulator red and black wires will tell if the regulator is working or not. Measuring voltage between aircraft ground and regulator black wire will tell how well the regulator is grounded. Measuring voltage between battery positive and regulator red wire will tell if all connections are good and have low resistance. The more information that we have, the easier it will be to troubleshoot the problem. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471080#471080 ________________________________________________________________________________
Subject: Re: Z13/8 Schottky Diode Voltage Drop Increasing
Date: Jul 16, 2017
If the electrical load has not increased since December, then the most likely cause of an extra half volt drop is a bad connection. Fuse holders are likely suspects. Measure the voltage between the two buses by touching both buses with the voltmeter probes. In other words, do not use ground as a reference point. Instead use one bus as a reference and measure various points until the voltage drop is found. The diode might not be the culprit. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471081#471081 ________________________________________________________________________________
Subject: order aero electric book and cd bundle about week and
a half ago
Date: Jul 16, 2017
recieved confirmation from aeroelectric but never a paypal notice. Jeffrey C Warren RV14A #140195 864-275-3798 heffnhane(at)mac.com (SC47) ________________________________________________________________________________
Subject: Z14 with SDS EFI...
Date: Jul 17, 2017
I'm planning on a dual ECU SDS EFI system for my RV-7. I'm also planning to (eventually) equip for IFR. Given all that, I'm looking strongly at a Z14-based electrical architecture, but I have a few questions/concerns about it. My plan was to split the critical engine systems and the PFDs across both battery buses, so the aircraft could run solely on one bus or the other. I wanted to maintain the ability to fly indefinitely after one failure and provide a minimum of two hours on battery power alone. However, as I dug into it I started realizing that this plan might have a problem. Unlike the ignition, there aren't redundant injectors, so the install manual splits power for them across two (or four) separate sources for some level of redundancy (which I assume will give a rough engine but some reduced power). If I split two injectors to one bus and the other two on the second bus, I'm not fully redundant. If I lose one bus entirely, I'm down to two injectors. Plus, the way Z14 is drawn, if I lose either the main or aux contactor, that side's injectors are now running on battery power--the crossfeed doesn't help because it connects after the battery contactors. That prompted a couple of ideas. First, is there any reason why the crosstie has to be "downstream" of the battery contactors? Could I not just place it directly between the batteries, and feed its switch through diodes off the battery bus? (I called this Mod 1 in the attached item) Second, does anyone see a problem with feeding the injector power through diode bridges? (mod 1a) As an expansion off that, does anyone see a problem with feeding an "engine bus" off a pair of Schottky diodes straight from the batteries? (mod 2) Finally, does anyone see a problem with "hard wiring" (through fuses of course) components that will not draw power without the engine running--that is, the coils, injectors, and injector relays? I've attached simple block diagrams of the above ideas. They aren't full wiring diagrams so please don't get wrapped up around wire protection or details like that yet. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471104#471104 Attachments: http://forums.matronics.com//files/electrical_block_diagram_793.pdf ________________________________________________________________________________
Date: Jul 17, 2017
From: Lawrence Handberg <stinsonwagon(at)yahoo.com>
Subject: Re: order aero electric book and cd bundle about week
and a half ago He didn't charge me until he shipped mine. You may want to call him to make sure he receive the order. From: Jeffrey C Warren <heffnhane(at)mac.com> To: aeroelectric-list(at)matronics.com Sent: Sunday, July 16, 2017 5:48 PM Subject: AeroElectric-List: order aero electric book and cd bundle about week and a half ago recieved confirmation from aeroelectric but never a paypal notice. Jeffrey C WarrenRV14A #140195864-275-3798heffnhane(at)mac.com(SC47) ________________________________________________________________________________
Subject: Re: Z14 with SDS EFI...
Date: Jul 17, 2017
With Z14, I run each of my separate EFI systems off it's own battery buss on each of my two little 8 amp-Hr batteries. Neither goes thru a battery contactor. I would not be comfortable running them thru a contactor. There are no "battery contactors" between the crossfeed and my batteries. I have one contactor that feeds the non engine busses instead of a classic battery contactor that disconnects the battery. The general advice here seems to be NOT to plan for 2 independent failures on the same day or you tend to get tied up in overly complicated knots with little or even sometimes negative safety advantage. Losing half your injectors will lose MORE than half your power. In my case I can maintain flight with one injector offline without shaking the airplane apart. Not so much with 2 offline. I did look at relays and feed diodes but my solution for simple operating procedures and independent electronics was to simply weld in a second set of injectors. It also avoided some other failure points that can take down some dual ecu systems such as relying on a single mechanical fuel pressure regulator that may be less reliable than the ecu's... Two alternators plus 2 hours of battery power seems like a lot of overkill. I can run for an unlimited time on either alternator so I happily take advantage of small and light batteries. The crossfeed auto closes during cranking so if the engine cranks smartly I know the crossfeed is working which is it's operational check. Has worked well for 11 years and 730 hours. I can't comment on diode bridges. Ken On 17/07/2017 10:15 AM, gtae07 wrote: > > I'm planning on a dual ECU SDS EFI system for my RV-7. I'm also planning to (eventually) equip for IFR. Given all that, I'm looking strongly at a Z14-based electrical architecture, but I have a few questions/concerns about it. > > > My plan was to split the critical engine systems and the PFDs across both battery buses, so the aircraft could run solely on one bus or the other. I wanted to maintain the ability to fly indefinitely after one failure and provide a minimum of two hours on battery power alone. > > However, as I dug into it I started realizing that this plan might have a problem. Unlike the ignition, there aren't redundant injectors, so the install manual splits power for them across two (or four) separate sources for some level of redundancy (which I assume will give a rough engine but some reduced power). If I split two injectors to one bus and the other two on the second bus, I'm not fully redundant. If I lose one bus entirely, I'm down to two injectors. Plus, the way Z14 is drawn, if I lose either the main or aux contactor, that side's injectors are now running on battery power--the crossfeed doesn't help because it connects after the battery contactors. > > That prompted a couple of ideas. First, is there any reason why the crosstie has to be "downstream" of the battery contactors? Could I not just place it directly between the batteries, and feed its switch through diodes off the battery bus? (I called this Mod 1 in the attached item) > > Second, does anyone see a problem with feeding the injector power through diode bridges? (mod 1a) > > As an expansion off that, does anyone see a problem with feeding an "engine bus" off a pair of Schottky diodes straight from the batteries? (mod 2) > > > Finally, does anyone see a problem with "hard wiring" (through fuses of course) components that will not draw power without the engine running--that is, the coils, injectors, and injector relays? > > I've attached simple block diagrams of the above ideas. They aren't full wiring diagrams so please don't get wrapped up around wire protection or details like that yet. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471104#471104 > > > Attachments: > > http://forums.matronics.com//files/electrical_block_diagram_793.pdf > > ________________________________________________________________________________
Date: Jul 17, 2017
gtae07, Any of your options will work. Of them, I like MOD 1A the best. If the cross tie contactor is left on after shut down, both batteries will be run down. Loosing a battery contactor does not cause a loss of power because power comes from the alternator, not the battery. Most alternators will keep on working if the battery is disconnected, although the voltage could be unstable. Another option is to wire an automotive 40-amp relay in parallel with the battery contactor. The relay must be disabled during engine cranking. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471109#471109 ________________________________________________________________________________
Date: Jul 17, 2017
On 7/17/2017 9:15 AM, gtae07 wrote: > > I'm planning on a dual ECU SDS EFI system for my RV-7. I'm also planning to (eventually) equip for IFR. Given all that, I'm looking strongly at a Z14-based electrical architecture, but I have a few questions/concerns about it. > > > My plan was to split the critical engine systems and the PFDs across both battery buses, so the aircraft could run solely on one bus or the other. I wanted to maintain the ability to fly indefinitely after one failure and provide a minimum of two hours on battery power alone. > > However, as I dug into it I started realizing that this plan might have a problem. Unlike the ignition, there aren't redundant injectors, so the install manual splits power for them across two (or four) separate sources for some level of redundancy (which I assume will give a rough engine but some reduced power). If I split two injectors to one bus and the other two on the second bus, I'm not fully redundant. If I lose one bus entirely, I'm down to two injectors. Plus, the way Z14 is drawn, if I lose either the main or aux contactor, that side's injectors are now running on battery power--the crossfeed doesn't help because it connects after the battery contactors. > > That prompted a couple of ideas. First, is there any reason why the crosstie has to be "downstream" of the battery contactors? Could I not just place it directly between the batteries, and feed its switch through diodes off the battery bus? (I called this Mod 1 in the attached item) > > Second, does anyone see a problem with feeding the injector power through diode bridges? (mod 1a) > > As an expansion off that, does anyone see a problem with feeding an "engine bus" off a pair of Schottky diodes straight from the batteries? (mod 2) > > > Finally, does anyone see a problem with "hard wiring" (through fuses of course) components that will not draw power without the engine running--that is, the coils, injectors, and injector relays? > > I've attached simple block diagrams of the above ideas. They aren't full wiring diagrams so please don't get wrapped up around wire protection or details like that yet. > I can't hit every point, but do have a few thoughts. I wouldn't split injector power across buses. If you lose a bus & half your injectors, you've lost close to 75% of your power, & stuff could break just from the abnormal firing with only two cyls working. My choice (full disclosure: not yet flying) is to do something closer to what you have as mod 2. My attitude is to build a good engine bus, make sure my wiring practice is sound, and live with it, just as I live without backups for my single pair of wings (redundant controllers on the same bus). I have the luxury (automotive engine) of running identical alternators, so I have only one battery. I have one engine bus, controlled with a high current toggle switch (no contactor) fed directly from the battery utilizing a fusible link in the feed. The 'rest of the airplane' bus is controlled by a master contactor, as is typical. I have an emergency crossfeed switch (same high current model) so that either bus can draw on the other, as needed. I can shut down either alternator's output, either bus's feed (and crossfeed from the other bus), or if there's a serious fire, I can still shut down all electrical power if needed as a last resort ('standard' aviation design practice). As drawn, your mod 2 has no way to isolate anything from the batteries; the contactors just interrupt power from the alternators. is that what you intend? It also doesn't show the 'rest of the airplane' buss (avionics, etc). How will that be integrated? Charlie --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jul 17, 2017
Ken, How big are your batteries? With two alternators you shouldn't ever need to know battery capacity, but I can tell you that most automotive style engine controllers (high pressure injection) will suck a PC680 dry in about 40 minutes. That's just the electrical loads of the engine itself + fuel pump; no avionics, etc. Charlie On 7/17/2017 12:28 PM, C&K wrote: > > With Z14, I run each of my separate EFI systems off it's own battery > buss on each of my two little 8 amp-Hr batteries. Neither goes thru a > battery contactor. I would not be comfortable running them thru a > contactor. There are no "battery contactors" between the crossfeed and > my batteries. I have one contactor that feeds the non engine busses > instead of a classic battery contactor that disconnects the battery. > The general advice here seems to be NOT to plan for 2 independent > failures on the same day or you tend to get tied up in overly > complicated knots with little or even sometimes negative safety > advantage. > > Losing half your injectors will lose MORE than half your power. > > In my case I can maintain flight with one injector offline without > shaking the airplane apart. Not so much with 2 offline. I did look at > relays and feed diodes but my solution for simple operating procedures > and independent electronics was to simply weld in a second set of > injectors. It also avoided some other failure points that can take > down some dual ecu systems such as relying on a single mechanical fuel > pressure regulator that may be less reliable than the ecu's... > > Two alternators plus 2 hours of battery power seems like a lot of > overkill. I can run for an unlimited time on either alternator so I > happily take advantage of small and light batteries. The crossfeed > auto closes during cranking so if the engine cranks smartly I know the > crossfeed is working which is it's operational check. Has worked well > for 11 years and 730 hours. > > I can't comment on diode bridges. > > Ken > > > On 17/07/2017 10:15 AM, gtae07 wrote: >> >> I'm planning on a dual ECU SDS EFI system for my RV-7. I'm also >> planning to (eventually) equip for IFR. Given all that, I'm looking >> strongly at a Z14-based electrical architecture, but I have a few >> questions/concerns about it. >> >> >> My plan was to split the critical engine systems and the PFDs across >> both battery buses, so the aircraft could run solely on one bus or >> the other. I wanted to maintain the ability to fly indefinitely >> after one failure and provide a minimum of two hours on battery power >> alone. >> >> However, as I dug into it I started realizing that this plan might >> have a problem. Unlike the ignition, there aren't redundant >> injectors, so the install manual splits power for them across two (or >> four) separate sources for some level of redundancy (which I assume >> will give a rough engine but some reduced power). If I split two >> injectors to one bus and the other two on the second bus, I'm not >> fully redundant. If I lose one bus entirely, I'm down to two >> injectors. Plus, the way Z14 is drawn, if I lose either the main or >> aux contactor, that side's injectors are now running on battery >> power--the crossfeed doesn't help because it connects after the >> battery contactors. >> >> That prompted a couple of ideas. First, is there any reason why the >> crosstie has to be "downstream" of the battery contactors? Could I >> not just place it directly between the batteries, and feed its switch >> through diodes off the battery bus? (I called this Mod 1 in the >> attached item) >> >> Second, does anyone see a problem with feeding the injector power >> through diode bridges? (mod 1a) >> >> As an expansion off that, does anyone see a problem with feeding an >> "engine bus" off a pair of Schottky diodes straight from the >> batteries? (mod 2) >> >> >> Finally, does anyone see a problem with "hard wiring" (through fuses >> of course) components that will not draw power without the engine >> running--that is, the coils, injectors, and injector relays? >> >> I've attached simple block diagrams of the above ideas. They aren't >> full wiring diagrams so please don't get wrapped up around wire >> protection or details like that yet. --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jul 17, 2017
Charlie Yes I would not want to count on my little Dekka 8 amp-hr for much more than 10 or maybe 15 minutes at most based on my typical 16 amp primary system load and original testing. (I run a few things like strobes off the other alternator.) The BRL (Big Red flashing Light) low volts light from the EIS is pretty attention getting though and it just takes a switch flick to fix things. The second alternator certainly removes worrying much about battery capacity. It's not a capacity check, but these 120 CCA batteries do fairly well on 60 and 100 amp load tests even after 5 to 12 years. Interestingly I picked up a new one a few months ago special order at Lowes (America not Canada). $60. was a better price than anywhere else I found on the internet and it was manufactured in PA within the previous month. Ken On 17/07/2017 2:49 PM, Charlie England wrote: > > > Ken, > > How big are your batteries? With two alternators you shouldn't ever > need to know battery capacity, but I can tell you that most automotive > style engine controllers (high pressure injection) will suck a PC680 > dry in about 40 minutes. That's just the electrical loads of the > engine itself + fuel pump; no avionics, etc. > > Charlie > > On 7/17/2017 12:28 PM, C&K wrote: >> >> With Z14, I run each of my separate EFI systems off it's own battery >> buss on each of my two little 8 amp-Hr batteries. Neither goes thru a >> battery contactor. I would not be comfortable running them thru a >> contactor. There are no "battery contactors" between the crossfeed >> and my batteries. I have one contactor that feeds the non engine >> busses instead of a classic battery contactor that disconnects the >> battery. The general advice here seems to be NOT to plan for 2 >> independent failures on the same day or you tend to get tied up in >> overly complicated knots with little or even sometimes negative >> safety advantage. >> >> Losing half your injectors will lose MORE than half your power. >> >> In my case I can maintain flight with one injector offline without >> shaking the airplane apart. Not so much with 2 offline. I did look at >> relays and feed diodes but my solution for simple operating >> procedures and independent electronics was to simply weld in a second >> set of injectors. It also avoided some other failure points that can >> take down some dual ecu systems such as relying on a single >> mechanical fuel pressure regulator that may be less reliable than the >> ecu's... >> >> Two alternators plus 2 hours of battery power seems like a lot of >> overkill. I can run for an unlimited time on either alternator so I >> happily take advantage of small and light batteries. The crossfeed >> auto closes during cranking so if the engine cranks smartly I know >> the crossfeed is working which is it's operational check. Has worked >> well for 11 years and 730 hours. >> >> I can't comment on diode bridges. >> >> Ken >> >> >> On 17/07/2017 10:15 AM, gtae07 wrote: >>> >>> I'm planning on a dual ECU SDS EFI system for my RV-7. I'm also >>> planning to (eventually) equip for IFR. Given all that, I'm looking >>> strongly at a Z14-based electrical architecture, but I have a few >>> questions/concerns about it. >>> >>> >>> My plan was to split the critical engine systems and the PFDs across >>> both battery buses, so the aircraft could run solely on one bus or >>> the other. I wanted to maintain the ability to fly indefinitely >>> after one failure and provide a minimum of two hours on battery >>> power alone. >>> >>> However, as I dug into it I started realizing that this plan might >>> have a problem. Unlike the ignition, there aren't redundant >>> injectors, so the install manual splits power for them across two >>> (or four) separate sources for some level of redundancy (which I >>> assume will give a rough engine but some reduced power). If I split >>> two injectors to one bus and the other two on the second bus, I'm >>> not fully redundant. If I lose one bus entirely, I'm down to two >>> injectors. Plus, the way Z14 is drawn, if I lose either the main or >>> aux contactor, that side's injectors are now running on battery >>> power--the crossfeed doesn't help because it connects after the >>> battery contactors. >>> >>> That prompted a couple of ideas. First, is there any reason why the >>> crosstie has to be "downstream" of the battery contactors? Could I >>> not just place it directly between the batteries, and feed its >>> switch through diodes off the battery bus? (I called this Mod 1 in >>> the attached item) >>> >>> Second, does anyone see a problem with feeding the injector power >>> through diode bridges? (mod 1a) >>> >>> As an expansion off that, does anyone see a problem with feeding an >>> "engine bus" off a pair of Schottky diodes straight from the >>> batteries? (mod 2) >>> >>> >>> Finally, does anyone see a problem with "hard wiring" (through fuses >>> of course) components that will not draw power without the engine >>> running--that is, the coils, injectors, and injector relays? >>> >>> I've attached simple block diagrams of the above ideas. They aren't >>> full wiring diagrams so please don't get wrapped up around wire >>> protection or details like that yet. > > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus > > ________________________________________________________________________________
Date: Jul 17, 2017
Not to get too far into the weeds, but what are you testing at 60 & 100 amps? If you're just testing whether it will grunt the load for a few seconds or minutes, it won't tell you much about how long it will last when loaded at, say, 10-20 amps (typical range of automotive style injection plus fuel pump, depending on the system). There have been in-flight tests of PC680's, and they're good for around 40 minutes to an hour, tops, when being loaded at around 10-15 amps. If you look at Odessey's spec sheet for a PC680, it's a 16 ampere-hour battery, but with a 15 amp load, it lasts for ~45 minutes; a virtually exact match for 'real world' tests. When load gets close to or above the AH rating, life gets *really* short. 8AH batteries should be a lot cheaper than that. IIRC, I've bought from Apex in the past (and several other vendors, as well, and they have pretty good prices. Here's a pair for $20: https://www.apexbattery.com/apc-back-ups-xs-900-12v-8ah-replacement-battery-160798.html?gclid=Cj0KCQjwwLHLBRDEARIsAN1A1Q67Bm55WDDHCRfTkPBhdUZNs9zNyRdHkiBlSIlgAhFDJMFcXbHCBGsaAr2oEALw_wcB Not sure of their shipping prices. But Amazon has them for $20 each, free shipping if you have Prime. Charlie On Mon, Jul 17, 2017 at 2:58 PM, C&K wrote: > > Charlie > Yes I would not want to count on my little Dekka 8 amp-hr for much more > than 10 or maybe 15 minutes at most based on my typical 16 amp primary > system load and original testing. (I run a few things like strobes off the > other alternator.) The BRL (Big Red flashing Light) low volts light from > the EIS is pretty attention getting though and it just takes a switch flick > to fix things. The second alternator certainly removes worrying much about > battery capacity. It's not a capacity check, but these 120 CCA batteries > do fairly well on 60 and 100 amp load tests even after 5 to 12 years. > Interestingly I picked up a new one a few months ago special order at Lowes > (America not Canada). $60. was a better price than anywhere else I found on > the internet and it was manufactured in PA within the previous month. > Ken > > On 17/07/2017 2:49 PM, Charlie England wrote: > >> ceengland7(at)gmail.com> >> >> Ken, >> >> How big are your batteries? With two alternators you shouldn't ever need >> to know battery capacity, but I can tell you that most automotive style >> engine controllers (high pressure injection) will suck a PC680 dry in about >> 40 minutes. That's just the electrical loads of the engine itself + fuel >> pump; no avionics, etc. >> >> Charlie >> >> On 7/17/2017 12:28 PM, C&K wrote: >> >>> >>> With Z14, I run each of my separate EFI systems off it's own battery >>> buss on each of my two little 8 amp-Hr batteries. Neither goes thru a >>> battery contactor. I would not be comfortable running them thru a >>> contactor. There are no "battery contactors" between the crossfeed and my >>> batteries. I have one contactor that feeds the non engine busses instead of >>> a classic battery contactor that disconnects the battery. The general >>> advice here seems to be NOT to plan for 2 independent failures on the same >>> day or you tend to get tied up in overly complicated knots with little or >>> even sometimes negative safety advantage. >>> >>> Losing half your injectors will lose MORE than half your power. >>> >>> In my case I can maintain flight with one injector offline without >>> shaking the airplane apart. Not so much with 2 offline. I did look at >>> relays and feed diodes but my solution for simple operating procedures and >>> independent electronics was to simply weld in a second set of injectors. It >>> also avoided some other failure points that can take down some dual ecu >>> systems such as relying on a single mechanical fuel pressure regulator that >>> may be less reliable than the ecu's... >>> >>> Two alternators plus 2 hours of battery power seems like a lot of >>> overkill. I can run for an unlimited time on either alternator so I happily >>> take advantage of small and light batteries. The crossfeed auto closes >>> during cranking so if the engine cranks smartly I know the crossfeed is >>> working which is it's operational check. Has worked well for 11 years and >>> 730 hours. >>> >>> I can't comment on diode bridges. >>> >>> Ken >>> >>> >>> On 17/07/2017 10:15 AM, gtae07 wrote: >>> >>>> >>>> I'm planning on a dual ECU SDS EFI system for my RV-7. I'm also >>>> planning to (eventually) equip for IFR. Given all that, I'm looking >>>> strongly at a Z14-based electrical architecture, but I have a few >>>> questions/concerns about it. >>>> >>>> >>>> My plan was to split the critical engine systems and the PFDs across >>>> both battery buses, so the aircraft could run solely on one bus or the >>>> other. I wanted to maintain the ability to fly indefinitely after one >>>> failure and provide a minimum of two hours on battery power alone. >>>> >>>> However, as I dug into it I started realizing that this plan might have >>>> a problem. Unlike the ignition, there aren't redundant injectors, so the >>>> install manual splits power for them across two (or four) separate sources >>>> for some level of redundancy (which I assume will give a rough engine but >>>> some reduced power). If I split two injectors to one bus and the other two >>>> on the second bus, I'm not fully redundant. If I lose one bus entirely, >>>> I'm down to two injectors. Plus, the way Z14 is drawn, if I lose either >>>> the main or aux contactor, that side's injectors are now running on battery >>>> power--the crossfeed doesn't help because it connects after the battery >>>> contactors. >>>> >>>> That prompted a couple of ideas. First, is there any reason why the >>>> crosstie has to be "downstream" of the battery contactors? Could I not just >>>> place it directly between the batteries, and feed its switch through diodes >>>> off the battery bus? (I called this Mod 1 in the attached item) >>>> >>>> Second, does anyone see a problem with feeding the injector power >>>> through diode bridges? (mod 1a) >>>> >>>> As an expansion off that, does anyone see a problem with feeding an >>>> "engine bus" off a pair of Schottky diodes straight from the batteries? >>>> (mod 2) >>>> >>>> >>>> Finally, does anyone see a problem with "hard wiring" (through fuses of >>>> course) components that will not draw power without the engine >>>> running--that is, the coils, injectors, and injector relays? >>>> >>>> I've attached simple block diagrams of the above ideas. They aren't >>>> full wiring diagrams so please don't get wrapped up around wire protection >>>> or details like that yet. >>>> >>> >> >> --- >> This email has been checked for viruses by Avast antivirus software. >> https://www.avast.com/antivirus >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Jul 17, 2017
week and a half ago At 07:32 PM 7/16/2017, you wrote: >recieved confirmation from aeroelectric but never a paypal notice. > > >Jeffrey C Warren >RV14A #140195 >864-275-3798 >heffnhane(at)mac.com >(SC47) > I had invoiced you on the 7th then inadvertently double invoiced a few days later. When I caught the error, I canceled the second invoice but it seems that BOTH of them got canceled. You should have been receiving email notices on each of the snafus . . . Sorry 'bout that! Just re-issued the invoice . . . Bob . . . ________________________________________________________________________________
Date: Jul 17, 2017
Agree with most of what you are saying but don't forget that there are relatively cheap standby power AGM batteries and then there are power sports batteries that are rated and capable of cranking engines. In that last group there are ones with proven reliability such as the Odysey and Dekka lines. You won't find those for $20. Ken On 17/07/2017 5:44 PM, Charlie England wrote: > Not to get too far into the weeds, but what are you testing at 60 & > 100 amps? If you're just testing whether it will grunt the load for a > few seconds or minutes, it won't tell you much about how long it will > last when loaded at, say, 10-20 amps (typical range of automotive > style injection plus fuel pump, depending on the system). There have > been in-flight tests of PC680's, and they're good for around 40 > minutes to an hour, tops, when being loaded at around 10-15 amps. If > you look at Odessey's spec sheet for a PC680, it's a 16 ampere-hour > battery, but with a 15 amp load, it lasts for ~45 minutes; a virtually > exact match for 'real world' tests. When load gets close to or above > the AH rating, life gets *really* short. > > 8AH batteries should be a lot cheaper than that. IIRC, I've bought > from Apex in the past (and several other vendors, as well, and they > have pretty good prices. Here's a pair for $20: > https://www.apexbattery.com/apc-back-ups-xs-900-12v-8ah-replacement-battery-160798.html?gclid=Cj0KCQjwwLHLBRDEARIsAN1A1Q67Bm55WDDHCRfTkPBhdUZNs9zNyRdHkiBlSIlgAhFDJMFcXbHCBGsaAr2oEALw_wcB > > Not sure of their shipping prices. But Amazon has them for $20 each, > free shipping if you have Prime. > > Charlie > > On Mon, Jul 17, 2017 at 2:58 PM, C&K > wrote: > > > > > Charlie > Yes I would not want to count on my little Dekka 8 amp-hr for much > more than 10 or maybe 15 minutes at most based on my typical 16 > amp primary system load and original testing. (I run a few things > like strobes off the other alternator.) The BRL (Big Red flashing > Light) low volts light from the EIS is pretty attention getting > though and it just takes a switch flick to fix things. The second > alternator certainly removes worrying much about battery > capacity. It's not a capacity check, but these 120 CCA batteries > do fairly well on 60 and 100 amp load tests even after 5 to 12 > years. Interestingly I picked up a new one a few months ago > special order at Lowes (America not Canada). $60. was a better > price than anywhere else I found on the internet and it was > manufactured in PA within the previous month. > Ken > > On 17/07/2017 2:49 PM, Charlie England wrote: > > > > > Ken, > > How big are your batteries? With two alternators you shouldn't > ever need to know battery capacity, but I can tell you that > most automotive style engine controllers (high pressure > injection) will suck a PC680 dry in about 40 minutes. That's > just the electrical loads of the engine itself + fuel pump; no > avionics, etc. > > Charlie > > On 7/17/2017 12:28 PM, C&K wrote: > > > > > With Z14, I run each of my separate EFI systems off it's > own battery buss on each of my two little 8 amp-Hr > batteries. Neither goes thru a battery contactor. I would > not be comfortable running them thru a contactor. There > are no "battery contactors" between the crossfeed and my > batteries. I have one contactor that feeds the non engine > busses instead of a classic battery contactor that > disconnects the battery. The general advice here seems to > be NOT to plan for 2 independent failures on the same day > or you tend to get tied up in overly complicated knots > with little or even sometimes negative safety advantage. > > Losing half your injectors will lose MORE than half your > power. > > In my case I can maintain flight with one injector offline > without shaking the airplane apart. Not so much with 2 > offline. I did look at relays and feed diodes but my > solution for simple operating procedures and independent > electronics was to simply weld in a second set of > injectors. It also avoided some other failure points that > can take down some dual ecu systems such as relying on a > single mechanical fuel pressure regulator that may be less > reliable than the ecu's... > > Two alternators plus 2 hours of battery power seems like a > lot of overkill. I can run for an unlimited time on either > alternator so I happily take advantage of small and light > batteries. The crossfeed auto closes during cranking so if > the engine cranks smartly I know the crossfeed is working > which is it's operational check. Has worked well for 11 > years and 730 hours. > > I can't comment on diode bridges. > > Ken > > > On 17/07/2017 10:15 AM, gtae07 wrote: > > > > > I'm planning on a dual ECU SDS EFI system for my > RV-7. I'm also planning to (eventually) equip for > IFR. Given all that, I'm looking strongly at a > Z14-based electrical architecture, but I have a few > questions/concerns about it. > > > My plan was to split the critical engine systems and > the PFDs across both battery buses, so the aircraft > could run solely on one bus or the other. I wanted to > maintain the ability to fly indefinitely after one > failure and provide a minimum of two hours on battery > power alone. > > However, as I dug into it I started realizing that > this plan might have a problem. Unlike the ignition, > there aren't redundant injectors, so the install > manual splits power for them across two (or four) > separate sources for some level of redundancy (which I > assume will give a rough engine but some reduced > power). If I split two injectors to one bus and the > other two on the second bus, I'm not fully redundant. > If I lose one bus entirely, I'm down to two injectors. > Plus, the way Z14 is drawn, if I lose either the main > or aux contactor, that side's injectors are now > running on battery power--the crossfeed doesn't help > because it connects after the battery contactors. > > That prompted a couple of ideas. First, is there any > reason why the crosstie has to be "downstream" of the > battery contactors? Could I not just place it directly > between the batteries, and feed its switch through > diodes off the battery bus? (I called this Mod 1 in > the attached item) > > Second, does anyone see a problem with feeding the > injector power through diode bridges? (mod 1a) > > As an expansion off that, does anyone see a problem > with feeding an "engine bus" off a pair of Schottky > diodes straight from the batteries? (mod 2) > > > Finally, does anyone see a problem with "hard wiring" > (through fuses of course) components that will not > draw power without the engine running--that is, the > coils, injectors, and injector relays? > > I've attached simple block diagrams of the above > ideas. They aren't full wiring diagrams so please > don't get wrapped up around wire protection or details > like that yet. > > > --- > This email has been checked for viruses by Avast antivirus > software. > https://www.avast.com/antivirus > > > =================================== > - > Electric-List" rel="noreferrer" > target="_blank">http://www.matronics.com/Navigator?AeroElectric-List > =================================== > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > =================================== > WIKI - > errer" target="_blank">http://wiki.matronics.com > =================================== > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" target="_blank">http://www.matronics.com/contribution > =================================== > > ________________________________________________________________________________
Date: Jul 18, 2017
At 09:15 AM 7/17/2017, you wrote: > >I'm planning on a dual ECU SDS EFI system for my RV-7. I'm also >planning to (eventually) equip for IFR. Given all that, I'm looking >strongly at a Z14-based electrical architecture, but I have a few >questions/concerns about it. > > >My plan was to split the critical engine systems and the PFDs across >both battery buses, so the aircraft could run solely on one bus or >the other. I wanted to maintain the ability to fly indefinitely >after one failure and provide a minimum of two hours on battery power alone. It seems you have abandoned the fundamental feature of Z-14 . . . With two alternators, you should be designing for continued flight to intended destination using the energy from only one of the two alternators. Batteries are there to add stability to the system dynamics and start the engine. Recall that the single most reliable sources of energy on any airplane is the judiciously maintained battery. Then comes the engine driven alternator . . . a more prone to failure but still a rare source of anxiety in the cockpit. Adding a second alternator not only sidesteps probability of declaring an emergency because of one alternator failure, it also reduces the need for tailoring battery capacity(ies) to design goals for battery-only endurance. Have you crafted a load analysis for all electro- whizzies needed for competent/comfortable termination of flight? I'm particularly mystified by the spreading of engine critical accessories across both systems. Z-14, as published, offers reliability on the same order as modern biz-jets . . . better than King Airs. Spreading things around the bus structures only adds complexity without reducing risk. Let's back up. You have two itty-bitty batteries which, I presume, are used in tandem for cranking. What size alternators? Suppose your engineering design manager says, "Okay, load up the 4 busses with system accessories and explain your decisions." After you have everything hooked up, then do the FMEA . . . what kind of failure will cause you to re-position some switches? After re-configuration, what new limits (if any) are imposed on the probability of comfortable termination of flight? Bob . . . ________________________________________________________________________________
Date: Jul 18, 2017
Subject: Re: IVO Prop current limiter
> I think the mechanical aspects of the data package are > now complete. I'll assemble one here as well so we can > beta-test software and compare notes. The boards are here. Thought I had all the parts to stuff one but found a couple of shortages. On order for delivery by priority mail . . . Bob . . . ________________________________________________________________________________
Date: Jul 18, 2017
Bob and all, I've got 7 of the PIC chips in inventory today, so I can program them and send them to people who want to do some beta testing. Or I could send them all to whomever is going to be putting the kits together. I would suggest we let Bob assemble one of the boards and do a quick check of the software before I program the rest of the chips. Paul Fisher On 7/16/2017 6:30 PM, Robert L. Nuckolls, III wrote: > At 11:36 AM 7/15/2017, you wrote: >> Bob, >> >> I would build one of those Prop limiters for my electric adj. IvoProp. >> >> If you need someone to make the initial order for parts, I'd be >> happy to do that. I could disseminate the parts kits to the >> interested builders. > > I have uploaded an illustrated bill of materials and > a parts locator to . . . > > http://tinyurl.com/yby3waw6 > > <http://tinyurl.com/yby3waw6> Note that the BOM does not call out a > mating D-sub > connector (D15S) since each builder may choose from > either crimp or solder-cup connectors. Also missing > is a callout for a D15H hood. The builder will need > 6-32 hardware to fasten the assembly down to the > mounting-surface/heat-sink. > > A LED travel limit annunciator is also missing from > the BOM. Something like this might tweak your > fancy . . . > > http://tinyurl.com/y8j6qrva > > <http://tinyurl.com/y8j6qrva> Unless the builder has programming > capability for > the PIC chip, I'll suggest the chip not be ordered > from Digikey rather from someone in the project group > with programming tools. > > I think the mechanical aspects of the data package are > now complete. I'll assemble one here as well so we can > beta-test software and compare notes. > > Bob . . . > ________________________________________________________________________________
Date: Jul 18, 2017
Subject: Relative position of Transponder and DME antennas
Date: Jul 18, 2017
I am retrofitting a panel mount DME into a low wing metal airplane and trying to figure out where the antenna should be installed. There are several complicating factors, particularly that it is very difficult to route the antenna coax from the panel aft past the spar. The transponder antenna is already placed under the fuselage between the spar and the firewall under the passenger's knees with one comm (comm 2) antenna in a similar position under the pilot's knees. There is a position for the DMA antenna just ahead of the spar on the center-line, but this puts it around 15" from both of the other existing antennas. This busts the 36" between antennas rule of thumb - but so does the existing comm & txpdr antennas with no apparent ill effect. However, King recommend the DME antenna should be more than 3ft from a comm antenna and 6ft from a txpdr antenna. One method to install the antenna towards the rear of the aircraft could be to route the coax alongside the comm 1 coax (RG400) for 5ft, but that appears to be poor practice. The DME is being installed to support IFR operation and will be used only infrequently, but when it is needed it will during an instrument approach and so reliable operation from (say) 10 or 15 miles is highly desirable. Any degradation in the current good comm or txpdr performance is undesirable, no matter what the phase of flight. My questions are, * Will the installed performance of the DME be noticeably degraded if the antenna is mounted 15" away from an existing comm and txpdr antenna? * Will the installed performance of the existing comm and txpdr be noticeably degraded if the DME antenna is mounted 15" away from both of their existing antennas? * If the DME & comm RG400 feeders are run in close proximity for 5 feet will they mutually interfere with each other? Thanks for any advice, Peter ________________________________________________________________________________
Date: Jul 18, 2017
Minor comment in line with some of the others - Why do you have/need main and aux contactors? I ran an electrically-dependent airplane (for about 5 years before I sold it) with a rock-simple marine battery selector switch with off-1-2-both positions. Used 1 alternator and 2 pc680's and, IAW group guidance, changed one battery every year. That said, that particular airplane had electronic ignition, but did not have EFI, and would easily run >1 hour on one battery alone. In the case of the higher loads of EFI, I might agree with using two alternators instead, one belt drive and one pad-mounted, and one battery. FWIW, Andy -------------------------- Andy Elliott, N127VE, GP-4 CL: 480-695-9568 "If things seem under control, you're just not going fast enough." - Mario Andretti ________________________________________________________________________________
Date: Jul 18, 2017
Subject: Re: Relative position of Transponder and DME antennas
Peter, In my RV all the antennas cables except the GPS run together down the cold side of the firewall and back in the wire tunnel. I had to drill s couple holes in the spar carry through bit Van's daid this was no issue. All the cables are within an inch of each other. They are all RG400. The length of the runs where they ate together is roughly six feet. Antennas are 2 wingtip (archer) 2 com 1transponder/adsb out 1 adsb in 1aprs Two GPS, 1xm and the GPS for the aprs are under tbe cowl. All have worked perfectly for nine years now with the atchers working up to 50 miles if over 8000 feet altitude. On Jul 18, 2017 2:43 PM, "Peter Pengilly" wrote: I am retrofitting a panel mount DME into a low wing metal airplane and trying to figure out where the antenna should be installed. There are several complicating factors, particularly that it is very difficult to route the antenna coax from the panel aft past the spar. The transponder antenna is already placed under the fuselage between the spar and the firewall under the passenger=99s knees with one comm (comm 2) antenna in a similar position under the pilot=99s knees. There is a position for the DMA antenna just ahead of the spar on the center-line, but this puts it around 15=9D from both of the other existing antennas. This busts the 36=9D between antennas rule of thumb =93 but so does the existing comm & tx pdr antennas with no apparent ill effect. However, King recommend the DME antenna should be more than 3ft from a comm antenna and 6ft from a txpdr antenna. One method to install the antenna towards the rear of the aircraft could be to route the coax alongside the comm 1 coax (RG400) for 5ft, but that appears to be poor practice. The DME is being installed to support IFR operation and will be used only infrequently, but when it is needed it will during an instrument approach and so reliable operation from (say) 10 or 15 miles is highly desirable. Any degradation in the current good comm or txpdr performance is undesirable, no matter what the phase of flight. My questions are, - Will the installed performance of the DME be noticeably degraded if the antenna is mounted 15=9D away from an existing comm and txpdr antenna? - Will the installed performance of the existing comm and txpdr be noticeably degraded if the DME antenna is mounted 15=9D away from both of their existing antennas? - If the DME & comm RG400 feeders are run in close proximity for 5 feet will they mutually interfere with each other? Thanks for any advice, Peter ________________________________________________________________________________
Date: Jul 18, 2017
Good Afternoon Peter, May I ask whether or not you will have an IFR approved GPS in the RV? If so, why not forget about installing the DME? The GPS can be used as a su bstitute for ANY DME function. Saves time, money, and weight! Happy Skies, Old Bob -----Original Message----- From: don van santen <donvansanten(at)gmail.com> Sent: Tue, Jul 18, 2017 5:16 pm Subject: Re: AeroElectric-List: Relative position of Transponder and DME an tennas Peter, In my RV all the antennas cables except the GPS run together down the cold side of the firewall and back in the wir e tunnel. I had to drill s couple holes in the spar carry through bit Van's daid this was no issue. All the cables are within an inch of each other. T hey are all RG400. The length of the runs where they ate together is roughl y six feet. Antennas are 2 wingtip (archer) 2 com 1transponder/adsb out 1 adsb in 1aprs Two GPS, 1xm and the GPS for the aprs are under tbe cowl. All have worked p erfectly for nine years now with the atchers working up to 50 miles if over 8000 feet altitude. On Jul 18, 2017 2:43 PM, "Peter Pengilly" wrote: I am retrofitting a panel mount DME into a low wing metal airplane and tryi ng to figure out where the antenna should be installed. There are several complicating factors, particularly that it is very diffic ult to route the antenna coax from the panel aft past the spar. The transpo nder antenna is already placed under the fuselage between the spar and the firewall under the passenger=99s knees with one comm (comm 2) antenna in a similar position under the pilot=99s knees. There is a position for the DMA antenna just ahead of the spar on the center-line, but this pu ts it around 15=9D from both of the other existing antennas. This bus ts the 36=9D between antennas rule of thumb =93 but so does the existing comm & txpdr antennas with no apparent ill effect. However, King recommend the DME antenna should be more than 3ft from a comm antenna and 6 ft from a txpdr antenna. One method to install the antenna towards the rear of the aircraft could be to route the coax alongside the comm 1 coax (RG40 0) for 5ft, but that appears to be poor practice. The DME is being installed to support IFR operation and will be used only i nfrequently, but when it is needed it will during an instrument approach an d so reliable operation from (say) 10 or 15 miles is highly desirable. Any degradation in the current good comm or txpdr performance is undesirable, n o matter what the phase of flight. My questions are, Will the installed performance of the DME be noticeably degraded if the ant enna is mounted 15=9D away from an existing comm and txpdr antenna? Will the installed performance of the existing comm and txpdr be noticeably degraded if the DME antenna is mounted 15=9D away from both of their existing antennas? If the DME & comm RG400 feeders are run in close proximity for 5 feet will they mutually interfere with each other? Thanks for any advice, Peter ________________________________________________________________________________
Date: Jul 19, 2017
yellowduckduo(at)gmail.co wrote: > With Z14, I run each of my separate EFI systems off it's own battery buss on each of my two little 8 amp-Hr batteries. Neither goes thru a battery contactor. I would not be comfortable running them thru a contactor. There are no "battery contactors" between the crossfeed and my batteries. I have one contactor that feeds the non engine busses instead of a classic battery contactor that disconnects the battery. The general advice here seems to be NOT to plan for 2 independent failures on the same day or you tend to get tied up in overly complicated knots with little or even sometimes negative safety advantage. I'm not planning to run engine loads through any contactors. They'd all be wired right off a battery bus; some components would have their own switches and others would be hard-wired on (with a fuse to pull if needed for maintenance). Anything going through a contactor is non-essential or an alternator. ceengland7(at)gmail.com wrote: > I can't hit every point, but do have a few thoughts. I wouldn't split injector power across buses. If you lose a bus & half your injectors, you've lost close to 75% of your power, & stuff could break just from the abnormal firing with only two cyls working. > > My choice (full disclosure: not yet flying) is to do something closer to what you have as mod 2. My attitude is to build a good engine bus, make sure my wiring practice is sound, and live with it, just as I live without backups for my single pair of wings (redundant controllers on the same bus). I have the luxury (automotive engine) of running identical alternators, so I have only one battery. I have one engine bus, controlled with a high current toggle switch (no contactor) fed directly from the battery utilizing a fusible link in the feed. The 'rest of the airplane' bus is controlled by a master contactor, as is typical. I have an emergency crossfeed switch (same high current model) so that either bus can draw on the other, as needed. I can shut down either alternator's output, either bus's feed (and crossfeed from the other bus), or if there's a serious fire, I can still shut down all electrical power if needed as a last resort ('standard' aviation design practice). > > As drawn, your mod 2 has no way to isolate anything from the batteries; the contactors just interrupt power from the alternators. is that what you intend? It also doesn't show the 'rest of the airplane' buss (avionics, etc). How will that be integrated? "Rest of airplane" loads would come after the contactors, per usual practice. I'm not worried about those right now. My biggest concern right now is to make sure the juice (electrical and hydrocarbon) keeps flowing to the engine. I know running on half the injectors would be bad so I'm trying to figure out a way around that. The other thing I'm trying to do is minimize the amount of switch-flipping in the cockpit, and minimize the number of contacts, break points, etc. between electrical power sources and my engine. I'm kind of weighing the options between "hard wiring" and putting a switch on either every component, or on each side of the engine bus. nuckolls.bob(at)aeroelect wrote: > At 09:15 AM 7/17/2017, you wrote: > > > > > I'm planning on a dual ECU SDS EFI system for my RV-7. I'm also planning to (eventually) equip for IFR. Given all that, I'm looking strongly at a Z14-based electrical architecture, but I have a few questions/concerns about it. > > > > > > My plan was to split the critical engine systems and the PFDs across both battery buses, so the aircraft could run solely on one bus or the other. I wanted to maintain the ability to fly indefinitely after one failure and provide a minimum of two hours on battery power alone. > > It seems you have abandoned the fundamental feature of Z-14 . . . > > With two alternators, you should be designing for continued flight to intended destination using the energy from only one of the two alternators. > > Batteries are there to add stability to the system dynamics and start the engine. > > Recall that the single most reliable sources of energy on any airplane is the judiciously maintained battery. Then comes the engine driven alternator . . . a more prone to failure but still a rare source of anxiety in the cockpit. > > Adding a second alternator not only sidesteps probability of declaring an emergency because of one alternator failure, it also reduces the need for tailoring battery capacity(ies) to design goals for battery-only endurance. > > Have you crafted a load analysis for all electro-whizzies needed for competent/comfortable termination of flight? I have. Engine/pump/ECU/coil and PFD load comes to about 12 amps. With radios and IFR GPS it's closer to 15 amps (IIRC; electrical budget is at work right now). nuckolls.bob(at)aeroelect wrote: > I'm particularly mystified by the spreading of engine critical accessories across both systems. The idea is that each bus powers the equipment to keep the engine running by itself. So, bus 1 powers the primary ECU, the coil driven by the primary ECU, one fuel pump, etc. and it's enough to keep the engine running on its own. The secondary bus would power the backup ECU, its coil, the other fuel pump, and the injector switching relay (which isn't powered when running the primary ECU). The problem I ran across is that I didn't realize (until I really sat down to start planning this out) that the injectors were powered separately and just triggered by the ECU. That means I need to find a way to power all of the injectors regardless of which bus is online. Unlike ECUs, pumps, and coils, there's not a redundant set of injectors. I don't know how I'd go about installing a second set as mentioned by another poster. nuckolls.bob(at)aeroelect wrote: > Let's back up. You have two itty-bitty batteries which, I presume, are used in tandem for cranking. What size alternators? Suppose your engineering design manager says, "Okay, load up the 4 busses with system accessories and explain your decisions." I'm looking at a pair of EarthX ETX900s, which which each have plenty of cranking juice on their own. Each battery could power the engine loads and PFD for about 70 minutes, or those plus IFR GPS and radios for almost 50 minutes, based on their published discharge curves. Primary bus alternator would be 70A conventional, and the secondary bus a 20A gear-driven. For the buses: Main battery - primary ECU/coil/fuel pump, injectors, PFD 1, IFR GPS, (com 1?) Aux battery - secondary ECU/coil/fuel pump, injectors, injector switching relay, PFD 2 Main bus - pitot heat, seat heat, 5VDC accessory outlets, flaps, lights Aux bus - Com 2, ??? nuckolls.bob(at)aeroelect wrote: > After you have everything hooked up, then do the FMEA . . . what kind of failure will cause you to re-position some switches? After re-configuration, what new limits (if any) are imposed on the probability of comfortable termination of flight? I'm getting there. Will be working on more detailed wiring today as I'm laid up from minor surgery. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471155#471155 ________________________________________________________________________________
Date: Jul 19, 2017
Hello Bob, Yes I will have an IFR GPS, and no, the DME isn=99t optional. In Europe enough approaches have DMEs where the range is =98slugged=99 to read zero at the threshold that trying to use GPS will get you in trouble. Sadly Eurocontrol do not have the same opinion on the substitution of DME with GPS as the FAA. Its bad enough for an amateur pilot to fly the approach accurately without having to figure out the actual range!! Regards, Peter From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of bobsv35b(at)aol.com Sent: 18 July 2017 23:53 Subject: Re: AeroElectric-List: Relative position of Transponder and DME antennas Good Afternoon Peter, May I ask whether or not you will have an IFR approved GPS in the RV? If so, why not forget about installing the DME? The GPS can be used as a substitute for ANY DME function. Saves time, money, and weight! Happy Skies, Old Bob -----Original Message----- From: don van santen <donvansanten(at)gmail.com > > Sent: Tue, Jul 18, 2017 5:16 pm Subject: Re: AeroElectric-List: Relative position of Transponder and DME antennas Peter, In my RV all the antennas cables except the GPS run together down the cold side of the firewall and back in the wire tunnel. I had to drill s couple holes in the spar carry through bit Van's daid this was no issue. All the cables are within an inch of each other. They are all RG400. The length of the runs where they ate together is roughly six feet. Antennas are 2 wingtip (archer) 2 com 1transponder/adsb out 1 adsb in 1aprs Two GPS, 1xm and the GPS for the aprs are under tbe cowl. All have worked perfectly for nine years now with the atchers working up to 50 miles if over 8000 feet altitude. On Jul 18, 2017 2:43 PM, "Peter Pengilly" > wrote: I am retrofitting a panel mount DME into a low wing metal airplane and trying to figure out where the antenna should be installed. There are several complicating factors, particularly that it is very difficult to route the antenna coax from the panel aft past the spar. The transponder antenna is already placed under the fuselage between the spar and the firewall under the passenger=99s knees with one comm (comm 2) antenna in a similar position under the pilot=99s knees. There is a position for the DMA antenna just ahead of the spar on the center-line, but this puts it around 15=9D from both of the other existing antennas. This busts the 36=9D between antennas rule of thumb =93 but so does the existing comm & txpdr antennas with no apparent ill effect. However, King recommend the DME antenna should be more than 3ft from a comm antenna and 6ft from a txpdr antenna. One method to install the antenna towards the rear of the aircraft could be to route the coax alongside the comm 1 coax (RG400) for 5ft, but that appears to be poor practice. The DME is being installed to support IFR operation and will be used only infrequently, but when it is needed it will during an instrument approach and so reliable operation from (say) 10 or 15 miles is highly desirable. Any degradation in the current good comm or txpdr performance is undesirable, no matter what the phase of flight. My questions are, * Will the installed performance of the DME be noticeably degraded if the antenna is mounted 15=9D away from an existing comm and txpdr antenna? * Will the installed performance of the existing comm and txpdr be noticeably degraded if the DME antenna is mounted 15=9D away from both of their existing antennas? * If the DME & comm RG400 feeders are run in close proximity for 5 feet will they mutually interfere with each other? Thanks for any advice, Peter ________________________________________________________________________________
Date: Jul 19, 2017
On 7/19/2017 6:00 AM, gtae07 wrote: > > > yellowduckduo(at)gmail.co wrote: >> With Z14, I run each of my separate EFI systems off it's own battery buss on each of my two little 8 amp-Hr batteries. Neither goes thru a battery contactor. I would not be comfortable running them thru a contactor. There are no "battery contactors" between the crossfeed and my batteries. I have one contactor that feeds the non engine busses instead of a classic battery contactor that disconnects the battery. The general advice here seems to be NOT to plan for 2 independent failures on the same day or you tend to get tied up in overly complicated knots with little or even sometimes negative safety advantage. > I'm not planning to run engine loads through any contactors. They'd all be wired right off a battery bus; some components would have their own switches and others would be hard-wired on (with a fuse to pull if needed for maintenance). > Anything going through a contactor is non-essential or an alternator. > > snipped//// Not a requirement, but a 'typical' consideration is being able to shut down the entire electrical system (even the engine's electrical power) in case of fire or emergency (potential crash) landing for other possible reasons. Lots of switches/fuses/breakers do make that harder to manage in an emergency. Not saying don't do it; just do it with eyes open. My choice is one bus, with two ways to power it. I can take my system down with one *carefully placed* motion. --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jul 19, 2017
Subject: Re: order aero electric book and cd bundle about
week and a half ago Jeff, Are you sure your 'spam filter' isn't intercepting PayPal traffic? I've sent you three invoices over the past few weeks. Bob . . . At 07:32 PM 7/16/2017, you wrote: >recieved confirmation from aeroelectric but never a paypal notice. > > >Jeffrey C Warren >RV14A #140195 >864-275-3798 >heffnhane(at)mac.com >(SC47) I had invoiced you on the 7th then inadvertently double invoiced a few days later. When I caught the error, I canceled the second invoice but it seems that BOTH of them got canceled. You should have been receiving email notices on each of the snafus . . . Sorry 'bout that! Just re-issued the invoice . . . Bob . . . ________________________________________________________________________________
Subject: Re: Z14 with SDS EFI...
Date: Jul 20, 2017
ceengland7(at)gmail.com wrote: > Not a requirement, but a 'typical' consideration is being able to shut down the entire electrical system (even the engine's electrical power) in case of fire or emergency (potential crash) landing for other possible reasons. Lots of switches/fuses/breakers do make that harder to manage in an emergency. Not saying don't do it; just do it with eyes open. My choice is one bus, with two ways to power it. I can take my system down with one *carefully placed* motion. That's the other thing I'm weighing out. I've accidentally killed the master switch before in another airplane (turbulence). The engine was conventional (carb/mag) but thanks to a latent fault in the EFIS backup battery that kept it from activating, I killed everything. That wasn't a big deal as I was VFR, but I don't want one switch accidentally taking down the entire engine. I suppose a way around that would be to go with my last option and just put heavy-duty switches on the engine bus, but that's another failure point... I suppose the question is, which is more likely--a latent component/connection failure killing power to the engine, or there's a situation where I need to kill power but can't? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471182#471182 ________________________________________________________________________________
Date: Jul 20, 2017
On Thu, Jul 20, 2017 at 5:19 AM, gtae07 wrote: > > > ceengland7(at)gmail.com wrote: > > Not a requirement, but a 'typical' consideration is being able to shut > down the entire electrical system (even the engine's electrical power) in > case of fire or emergency (potential crash) landing for other possible > reasons. Lots of switches/fuses/breakers do make that harder to manage in > an emergency. Not saying don't do it; just do it with eyes open. My choice > is one bus, with two ways to power it. I can take my system down with one > *carefully placed* motion. > > > That's the other thing I'm weighing out. I've accidentally killed the > master switch before in another airplane (turbulence). The engine was > conventional (carb/mag) but thanks to a latent fault in the EFIS backup > battery that kept it from activating, I killed everything. That wasn't a > big deal as I was VFR, but I don't want one switch accidentally taking down > the entire engine. I suppose a way around that would be to go with my last > option and just put heavy-duty switches on the engine bus, but that's > another failure point... > > I suppose the question is, which is more likely--a latent > component/connection failure killing power to the engine, or there's a > situation where I need to kill power but can't? > > Agreed on the inadvertent shutdown issue, but my way of dealing with that is, I guess, ergonomics. The 'kill everything' switches are kept away from any other commonly used switches/controls, and out of reach of any passenger, unless they reach completely across the pilot. ________________________________________________________________________________
From: "Dennis Glaeser" <glaesers(at)wideopenwest.com>
Date: Jul 20, 2017
I have an all electric engine (Subaru) and put locking switches on both the main and aux ignitions and fuel pumps. Solves the inadvertent bumping issue. All of my switches mounted low, and Up=On, so inadvertent bumps typically turn things on, not off. You can also use switch guards... I have an SDS ignition as well - one unit for all 6 EFIs and ignitions (coil on plug). Dual power feeds (one from each battery) through diodes to the SDS unit. The ignition and fuel pumps are powered directly from the respective battery bus (Main and Aux). My electrical architecture is very close to Z-14 (mine was done before Z-14 was published). I've been flying 9 years with no issues (that I didn't cause myself, like leaving the master on :x ) Dennis Glaeser Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471201#471201 ________________________________________________________________________________
Date: Jul 21, 2017
Got the board stuffed. http://tinyurl.com/ycemckye I need to get my pic programmer up and running for a couple other programs. I'll pop a 9023 chip and see how critter works. Bob . . . ________________________________________________________________________________
Date: Jul 22, 2017
Subject: 1.57542 GHz Filter
In the Garmin installation manual, it says the following: "The GPS antenna is lass susceptible to harmonic interference if a 1.57542 GHz filter is installed on the COM transceiver antenna output." Does anyone know of anyone who had to do this? Getting ready to install a GTN650 in my RV-8 so trying to anticipate potential problems. Thanks, Stan Sutterfield ________________________________________________________________________________
Date: Jul 22, 2017
Subject: Re: 1.57542 GHz Filter
At 01:10 PM 7/22/2017, you wrote: >In the Garmin installation manual, it says the following: > >"The GPS antenna is lass susceptible to harmonic interference if a >1.57542 GHz filter is installed on the COM transceiver antenna output." > >Does anyone know of anyone who had to do this? > >Getting ready to install a GTN650 in my RV-8 so trying to anticipate >potential problems. > >Thanks, > >Stan Sutterfield These were found useful on some makes of comm transceivers that had unhappy amounts of harmonic radiation on or near GPS frequencies. I don't now recall the brands/models of radio involved but as I do recall, it was just a select few. Try it without the filter. It's easy to add later if indeed you do need it. It's simply inserted into the transceiver coax feedline 4-70-54-Inline-Gps-Notch-Filter-Bnc I doubt you will find it necessary. Bob . . . ________________________________________________________________________________
Date: Jul 22, 2017
I've tried the filters and they didn't make any difference. On Jul 22, 2017, at 14:10, speedy11(at)aol.com wrote: In the Garmin installation manual, it says the following: "The GPS antenna is lass susceptible to harmonic interference if a 1.57542 G Hz filter is installed on the COM transceiver antenna output." Does anyone know of anyone who had to do this? Getting ready to install a GTN650 in my RV-8 so trying to anticipate potenti al problems. Thanks, Stan Sutterfield ________________________________________________________________________________
Date: Jul 23, 2017
At 09:28 PM 7/22/2017, you wrote: >I've tried the filters and they didn't make any difference. What symptoms suggested that the filter was, perhaps, necessary? Bob . . . ________________________________________________________________________________
Date: Jul 23, 2017
I'm sorry - I should have given more detail. The GPS reports zero satellites in view and takes itself offline during, and for a few seconds after, any transmission on either VHF COM radio on one of a select few frequencies: 121.175MHz I think is one of them. It=99s an old GPS and not a new problem. I=99ve put a fair amount of resource into trying to fix it some while ago, but not found a resolution. The inline filters didn=99t make any difference. > On Jul 23, 2017, at 11:53 AM, Robert L. Nuckolls, III wrote: > > At 09:28 PM 7/22/2017, you wrote: >> I've tried the filters and they didn't make any difference. > > What symptoms suggested that the filter > was, perhaps, necessary? > > Bob . . . > ________________________________________________________________________________
Date: Jul 23, 2017
At 11:35 AM 7/23/2017, you wrote: >I'm sorry - I should have given more detail. > >The GPS reports zero satellites in view and >takes itself offline during, and for a few >seconds after, any transmission on either VHF >COM radio on one of a select few frequencies: >121.175MHz I think is one of them. It=99s an old >GPS and not a new problem. I=99ve put a fair >amount of resource into trying to fix it some >while ago, but not found a resolution. Understand. Some background on cross-system interference issues may be helpful . . . When one runs the DO160/MIL-STD 461/462 gauntlets, it is incumbent on the manufacturer of a new product to measure and document extraneous emissions to be sure they are below tolerable limits for other systems. We know that its difficult if not impossible to drive all potential interference emission to zero but the design goals call for reducing them to insignificance. I.e. the victim system's performance is not degraded. Emacs! A fairly recent edition of DO160 offers these testing limits for radiated emissions. Note those 'notches' in the allowable emissions plot. They are centered over specific ranges of spectrum where RECEIVERS of itty-bitty signals would like to have a clear shot at detecting the information on those frequencies. Note the notches cover vhf nav/comm, uhf nav/comm, transponder/ tcas and gps bands. Not sure what service is being protected up round 5 ghz . . . The energy levels allowed are the sum total of energies radiated from all components of a device and associated cables when laid out on a copper-top table like so. Emacs! All this is fine and dandy for potential antagonists that are NOT designed to radiate buckets of energy on purpose . . . i.e. transmitters. Tests for bkackbox/harness radiation are generally no big deal . . . I've never failed one. Then there are transmitters. By nature, they're intended to radiate signal levels on the order of 130 dBuv/m at 3 meters from an antenna. Given that 'extraneous' emission limits at GPS frequencies are on the order of 85 dBuv/m LOWER, this means that the 13th harmonic (121 mHz x13 = GPS) power has to be on the order of 1 times 10^-8 lower than the fundamental. Modern designs have no problem achieving this goal but there's a goodly number of legacy comm equipment that was designed and qualified before GPS became the backbone of aerial navigation. GPS signals are exceedingly weak . . . generally at or below atmospheric noise. The predictable nature of the incoming signal makes if possible to digitally sift useful data out of what would otherwise be noise. If adding the notch filter didn't fix the symptoms, then perhaps the interference isn't being radiated from the antenna . . . there have been cases of incompatible appliances were the interference was getting out of the enclosure (i.e. wouldn't pass the bench test as described above). Will your gps interference symptom repeat on the ground? You might try dummy loading the transceiver and see if the interference goes away. Oops, just noticed that it repeats on two separate transmitters (same brand/model?) How far apart are your comm and GPS antennas? Bob . . . ________________________________________________________________________________
Subject: ADS-B Out Antenna
Date: Jul 23, 2017
I recently purchased a uAvionix Echo ADS-B Out device for my RV-6A. The instructions say to position the ADS-B Out antenna at least 3 feet from my existing transponder antenna. I will be forced to locate the new antenna in the aft fuselage with at least a 15-20 foot cable - not an ideal situation for me. Is there really a significant reason for the distance requirement for the ADS-B Out antenna? How about proximity to a VHF antenna? Charlie Brame RV-6A N11CB San Atonio ________________________________________________________________________________
Date: Jul 23, 2017
On Jul 23, 2017, at 1:22 PM, Robert L. Nuckolls, III wrote: > Not sure what service is being protected up round 5 ghz . . . Probably 802.11a WiFi systems. In the U.S., four channels between 5.180 and 5.240 GHz, and five channels between 5.745 and 5.825 GHz. Might be other stuff as well; that's in an Industrial, Scientific and Medical (ISM) band. Eric ________________________________________________________________________________
Subject: Another useful pilot App
Date: Jul 28, 2017
Greetings All! Aviametrix is pleased and proud to announce a new iOS app for pilots! The new App is Crosswind-Live! This app pulls current official aviation weather from an Internet connection and draws the wind arrows over a runway map of the closest airport and also calculates the crosswind components. If you like, the app will draw the current conditions at any other airport! It also gives you the airport info, comm freqs, and the full METAR. Crosswind-Live! contains a database of over 55,000 runways at over 45,000 airports worldwide, including airports, glider ports, sea bases, heliports, and many closed airports. This is a great app for student pilots, taildraggers, and anyone who likes to plan their takeoffs and landings. Crosswind-Live joins the other three Apps for Pilots developed by Aviametrix and yours truly! AvAltimeter - an actual, working sensitive altimeter with a Kollsman Window adjustment. Smart features like Oxygen alarm, TAS, and takeoff performance. Twilight Calculator - A self contained app which calculates Civil Twilight, standard sunrise/set, Nautical Twilight, and Astronomical Twilight. At your current GPS location, or anywhere in the world, for today, or a different date. AvWx No touch METARs! The simplest weather reports for pilots. Just open the App and it shows you the closest METARs. You can sort the METARs by age, bearing from your location, or by distance! You can find FAQs and documentation for these apps on the support page for my web site. Thanks! -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471331#471331 ________________________________________________________________________________
Date: Jul 29, 2017
Subject: Re: ADS-B Out Antenna
Sorry but I can not answer any of your specific questions, but consid er putting the echo in the rear tail cone near the new adsb antenna. =C2- This would minimize the coax run but longer runs for power and gps.=C2- Larry Get Outlook for iOS _____________________________ From: Charles Brame <chasb(at)satx.rr.com> Sent: Sunday, July 23, 2017 5:53 PM Subject: AeroElectric-List: ADS-B Out Antenna I recently purchased a uAvionix Echo ADS-B Out device for my RV-6A. The ins tructions say to position the ADS-B Out antenna at least 3 feet from my exi sting transponder antenna. I will be forced to locate the new antenna in th e aft fuselage with at least a 15-20 foot cable - not an ideal situation fo r me. Is there really a significant reason for the distance requirement for the A DS-B Out antenna? How about proximity to a VHF antenna? Charlie BrameRV-6A =C2-N11CBSan Atonio ________________________________________________________________________________
From: William Hunter <billhuntersemail(at)gmail.com>
Date: Jul 29, 2017
FWIW... Dynon recommends the ADS antenna have 24 inch spacing from the transponder antenna and no spacing requirements from other antennas. Thanks, Bill Hunter On Jul 29, 2017 9:17 AM, "Larry Rosen" wrote: > Sorry but I can not answer any of your specific questions, but consider > putting the echo in the rear tail cone near the new adsb antenna. This > would minimize the coax run but longer runs for power and gps. > > Larry > > Get Outlook for iOS > _____________________________ > From: Charles Brame <chasb(at)satx.rr.com> > Sent: Sunday, July 23, 2017 5:53 PM > Subject: AeroElectric-List: ADS-B Out Antenna > To: List AeroElectric > > > I recently purchased a uAvionix Echo ADS-B Out device for my RV-6A. The > instructions say to position the ADS-B Out antenna at least 3 feet from my > existing transponder antenna. I will be forced to locate the new antenna in > the aft fuselage with at least a 15-20 foot cable - not an ideal situation > for me. > > Is there really a significant reason for the distance requirement for the > ADS-B Out antenna? How about proximity to a VHF antenna? > > Charlie Brame > RV-6A N11CB > San Atonio > > ________________________________________________________________________________
From: "William Hunter" <billhuntersemail(at)gmail.com>
Subject: Do I need a Pull Up resistor?
Date: Aug 01, 2017
Hi All, Still plugging along...I know you all have been pulling for me!!! The question is...did I buy the wrong magnetic sensor...or...do I need the "Pull Up Resistor" as shown in the attached "Open Collector Sinking Block Diagram"? As a recap on my project I built a fiberglass air filter box with a small door that will be pop open if the air filter becomes blocked with ice and I bought a MP1007 Series Magnetic sensor to monitor my air filter bypass door through my Dynon Skyview Engine Monitor System. I am currently bench testing the sensor with it hanging in open air and I hold a small magnet near the sensor or away from the sensor. Pin 8 of my Dynon EMS is going to monitor the following two items: -Dynon Pitot tube heater failure. The Dynon pitot tube control box has a white wire that is open when the heater is working properly and then when the heater system is off or failed the system connects the white wire to ground. Because of the logic of the Dynon pitot heater system I set up the EMS Pin 8 to watch for a ground and if it sees a path to ground the indicator on my EMS screen shows an amber dot and the word "ICE" (indicating a failure of the Dynon pitot tube heater) and when the pin does not register a path to ground the indicator is black and disappears from the screen. This setup is working perfectly. -Air filter door position. This will be monitored by the MP1007 sensor however the sensor logic is working opposite of what I expected. I thought the black output wire of the MP1007 sensor would be open when the magnet target is close to the sensor (like when the air door is closed) and then when the magnet is pulled away from the sensor (like when the air door pops open) the black output wire would connect to ground...however it is exactly opposite meaning magnet close = black wire grounded and magnet away = black wire is open. IF...this sensor works like I want it to then the it would work perfectly and in parallel with my Dynon pitot heater. I have connected the following wires of the sensor to my airplane system: Sensor Wire Airplane Wire BRN Pin 18 of the Dynon EMS system (this is a 5 VDC source) BLK Pin 8 of the Dynon EMS (this is a "general purpose" sensor described above) BLU Ground The MP1007 sensor instructions state: Open Collector (NPN) -Output switches low (off) when the magnetic field at the sensor exceeds the operate point threshold -Output switches high (on) when the magnetic field is reduced to below the release point threshold Any help or well wishes would be GREATLY APPRECIATED!!! .. Cheers!!! Bill Hunter ________________________________________________________________________________
Subject: Re: Do I need a Pull Up resistor?
Date: Aug 01, 2017
Bill, Do you have a SkyView or D-180 or what? Do you have to connect the pitot sensor and magnetic sensor to the same EMS input? Is there another input that you can use? Yeah, the data sheet is confusing. It says "OFF" when the transistor is actually on. If you ignore the "ON" and "OFF" and just read the rest of the text, it makes sense. It sounds like the sensor is working properly, a close magnet causes the output to go low. If you want the signal inverted, another transistor can do it. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471418#471418 ________________________________________________________________________________
Date: Aug 01, 2017
Thanks Joe I knew I could count on you!!! > Do you have a SkyView or D-180 or what? Skyview 1000 >Do you have to connect the pitot sensor and magnetic sensor to the same EMS input? Is there another input that you can use? I have used all of the input pins so I thought that it would be cleaver to combine the ice systems into one sensor pin. >Yeah, the data sheet is confusing. It says "OFF" when the transistor is actually on. If you ignore the "ON" and "OFF" and just read the rest of the text, it makes sense. It sounds like the sensor is working properly, a close magnet causes the output to go low. If you want the signal inverted, another transistor can do it. I assume that "another transistor" means I need to buy a "another sensor"? Do you by chance know what the name of the correct unit will be? Regular switches are called Normally Open or Normally Open so what would a Normally Closed sensor be called? THANKS AGAIN!!! Bill Hunter On Aug 1, 2017 8:27 PM, "user9253" wrote: > > Bill, > Do you have a SkyView or D-180 or what? > Do you have to connect the pitot sensor and magnetic sensor to the same > EMS input? Is there another input that you can use? > Yeah, the data sheet is confusing. It says "OFF" when the transistor is > actually on. If you ignore the "ON" and "OFF" and just read the rest of > the text, it makes sense. It sounds like the sensor is working properly, a > close magnet causes the output to go low. If you want the signal inverted, > another transistor can do it. > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471418#471418 > > ________________________________________________________________________________
Date: Aug 01, 2017
Bill, The data sheet confirms what you're seeing at the bench, but this sensor can be made to work. The fix is pretty simple -- you just need to invert the output logic. This can be easily done with a few cheap components. However, paralleling the inputs to Pin 8 without knowing how the pitot fail signal works is potentially dangerous. It's possible for one input signal to short the other one. The two inputs should be isolated from one another so they can't interact. See the attached schematic diagram. Resistor R3 provides a weak pull-up on Pin 8, holding it at 5V. When your air door is closed and the sensor output is pulled to ground, P-MOSFET Q1 is turned on, and both sides of Schottky diode D1 (and therefore Pin 8) are at 5V. When the air door opens, the sensor output goes high impedance, allowing resistor R1 to turn Q1 off, in turn allowing R2 to overwhelm R3, pulling Pin 8 to ground through D1. D2 prevents the PITOT FAIL signal from holding Pin 8 at 5V. Likewise, when the PITOT FAIL signal pulls low through D2, D1 prevents Q1 from holding Pin 8 at 5V. A couple of notes: 1. This circuit will pull ~5mA from your Dynon's Pin 18 at all times. You should check that this is within specifications. 2. Please check that your PITOT FAIL signal puts 5V on Pin 8 (when the pitot is working normally), and not 12V. If it's 12V, then this circuit needs to be changed slightly: R1 and R2 should be 2.7k, and the connection point labeled DYNON P18 should instead be connected to 12V. If you need help building this circuit, just say the word. Cheers, Eric Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471422#471422 Attachments: http://forums.matronics.com//files/inverter_148.jpg ________________________________________________________________________________
Date: Aug 02, 2017
Bill, the Dynon EMS has 13 general purpose inputs. Are you sure that every one of them is already being used? -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471426#471426 ________________________________________________________________________________
Date: Aug 02, 2017
> the Dynon EMS has 13 general purpose inputs. Are you sure that every one of them is already being used? yep... every one is used... funny you should ask because I was going to post another question about thermocouples... I'll ask that on another thread Thanks, Bill Hunter On Aug 2, 2017 5:16 AM, "user9253" wrote: > > Bill, the Dynon EMS has 13 general purpose inputs. Are you sure that > every one of them is already being used? > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471426#471426 > > ________________________________________________________________________________
Date: Aug 02, 2017
Subject: Sharing thermocouple inputs?
On a different subject this week but with the same theme of "running out of EMS pins" , the question I have is can thermocouple wires be run through a switch and then routed to the EMS? I have only one thermocouple input left in my Dynon EMS however I still have two locations that I want to monitor temperature (one on a full-time basis and the other on a once in a great while basis) . Specifically I have a thermocouple probe mounted in my engine compartment that I want to use as a engine fire sensor and I have programed the EMS to change colors and give an audio warning when the temperature exceeds 400=C2 =B0 f. The second area that I would like to monitor on a once-in-a-while basis is the temperature of my intake air after it has left the intercooler. I have spliced those two pairs of wires and run one pair to the top two screws of a Honeywell double pole double throw switch and the second pair of wires I ran to the bottom two screws of that switch. The middle two screws of the switch are wired to the EMS pins... the thinking that I can simply position the switch in the direction of the sensor I want to monitor. The problem is that the EMS indication is the same temperature regardless of where the switch is positioned. In other words I could heat up one probe with my heat gun and regardless of where the switch is positioned I get the same reading on the EMS screen regardless of where I place the switch. I would have thought that if I heat up the cowling temperature probe and I watch the indication on the screen ride up to 250 degrees Fahrenheit then if I move the switch to the intake temperature probe then the indication would drop back down to ambient temperature however no matter where the switch is placed the indication on the screen will only indicate the temperature of hottest probe... never the coldest. Is it just unrealistic to be able to expect to Route thermocouple wires through a switch and be able to select the indication? THANKS AGAIN FOR YOUR ADVICE!!! Bill Hunter ________________________________________________________________________________
Date: Aug 02, 2017
Bill, how about connecting the output of the magnetic sensor to a panel mounted LED light? A 150 ohm series resistor will limit current from a 5 volt source. I glued an LED into a hole drilled into the instrument panel. http://www.mouser.com/Optoelectronics/LED-Lighting/LED-Emitters/Standard-LEDs-Through-Hole/_/N-b1bc8Zscv7?P=1z0yt1mZ1yzxspgZ1yztlcbZ1yzrt8pZ1yztnraZ1yzldgwZ1yztlq8Z1ywu49aZ1yzuk8tZ1yztj3sZ1yztm0dZ1yuo70f&Ns=Package+%2f+Case%7c1 -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471435#471435 ________________________________________________________________________________
Date: Aug 02, 2017
Subject: Re: Sharing thermocouple inputs?
On Wed, Aug 2, 2017 at 9:15 AM, William Hunter wrote: > On a different subject this week but with the same theme of "running out > of EMS pins" , the question I have is can thermocouple wires be run throu gh > a switch and then routed to the EMS? > > I have only one thermocouple input left in my Dynon EMS however I still > have two locations that I want to monitor temperature (one on a full-time > basis and the other on a once in a great while basis) . > > Specifically I have a thermocouple probe mounted in my engine compartment > that I want to use as a engine fire sensor and I have programed the EMS t o > change colors and give an audio warning when the temperature exceeds 400 =C2=B0 > f. > > The second area that I would like to monitor on a once-in-a-while basis i s > the temperature of my intake air after it has left the intercooler. > > I have spliced those two pairs of wires and run one pair to the top two > screws of a Honeywell double pole double throw switch and the second pair > of wires I ran to the bottom two screws of that switch. The middle two > screws of the switch are wired to the EMS pins... the thinking that I can > simply position the switch in the direction of the sensor I want to > monitor. > > The problem is that the EMS indication is the same temperature regardless > of where the switch is positioned. In other words I could heat up one pro be > with my heat gun and regardless of where the switch is positioned I get t he > same reading on the EMS screen regardless of where I place the switch. > > I would have thought that if I heat up the cowling temperature probe and I > watch the indication on the screen ride up to 250 degrees Fahrenheit then > if I move the switch to the intake temperature probe then the indication > would drop back down to ambient temperature however no matter where the > switch is placed the indication on the screen will only indicate the > temperature of hottest probe... never the coldest. > > Is it just unrealistic to be able to expect to Route thermocouple wires > through a switch and be able to select the indication? > > THANKS AGAIN FOR YOUR ADVICE!!! > > Bill Hunter > Bill, That's long been a way to monitor 2 (or more) different thermocouples. Conventional wisdom is that as long as you switch *both wires*, there should be minimal error between the two (or more) sensors. The idea is that by switching both leads, the junctions induce equal and opposite errors in the two wires, cancelling the error. Charlie ________________________________________________________________________________
Date: Aug 02, 2017
!!!IT WORKS!!! It seems I had on pair mislabeled and polarity connected up backwards. Using alligator clips and jumper wires and a couple of bad words allowed me to figure out my error. Now the correct pair and polarity go to the bottom pair of screws and the other (correct) pair and polarity go to the top pair of screws and out from the middle pair of screws come a couple of wires that get routed to the EMS and now I have thermocouple bliss!!! .. Cheers!!! Bill Hunter From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Charlie England Sent: Wednesday, August 2, 2017 9:01 AM Subject: Re: AeroElectric-List: Sharing thermocouple inputs? On Wed, Aug 2, 2017 at 9:15 AM, William Hunter > wrote: On a different subject this week but with the same theme of "running out of EMS pins" , the question I have is can thermocouple wires be run through a switch and then routed to the EMS? I have only one thermocouple input left in my Dynon EMS however I still have two locations that I want to monitor temperature (one on a full-time basis and the other on a once in a great while basis) . Specifically I have a thermocouple probe mounted in my engine compartment that I want to use as a engine fire sensor and I have programed the EMS to change colors and give an audio warning when the temperature exceeds 400=C2=B0 f. The second area that I would like to monitor on a once-in-a-while basis is the temperature of my intake air after it has left the intercooler. I have spliced those two pairs of wires and run one pair to the top two screws of a Honeywell double pole double throw switch and the second pair of wires I ran to the bottom two screws of that switch. The middle two screws of the switch are wired to the EMS pins... the thinking that I can simply position the switch in the direction of the sensor I want to monitor. The problem is that the EMS indication is the same temperature regardless of where the switch is positioned. In other words I could heat up one probe with my heat gun and regardless of where the switch is positioned I get the same reading on the EMS screen regardless of where I place the switch. I would have thought that if I heat up the cowling temperature probe and I watch the indication on the screen ride up to 250 degrees Fahrenheit then if I move the switch to the intake temperature probe then the indication would drop back down to ambient temperature however no matter where the switch is placed the indication on the screen will only indicate the temperature of hottest probe... never the coldest. Is it just unrealistic to be able to expect to Route thermocouple wires through a switch and be able to select the indication? THANKS AGAIN FOR YOUR ADVICE!!! Bill Hunter Bill, That's long been a way to monitor 2 (or more) different thermocouples. Conventional wisdom is that as long as you switch *both wires*, there should be minimal error between the two (or more) sensors. The idea is that by switching both leads, the junctions induce equal and opposite errors in the two wires, cancelling the error. Charlie ________________________________________________________________________________
Date: Aug 02, 2017
> how about connecting the output of the magnetic sensor to a panel mounted LED light? Great idea Joe. I thought of that as well except that I paid big bucks for all of this fancy EFIS stuff I and now addicted to all of the cool colors and audio alerts. Dang...back in the day a guy cold fly all around the country and all he needed was an oil pressure gauge, a sectional chart, and a wrist watch...now with all this fancy stuff he "needs" more sensors and widgets (but no sectional or watch)!!! Anyhoo...Can you PLEASE take a look at this sensor and help me determine if it will work? The MP200702 advertises it is a SPST-NC and it is only two wires (attached data sheet). Since this is a two wire switch I can dispense with the 5 VDC power wire and wire it up so that one wire goes to the EMS pin and the other wire is connected directly to ground. I just need some "encouragement" that I picked the correct switch this time because I just I got burned the last time by the wording of the catalog... I want it to be OPEN when the magnet is close and CLOSED when the magnet is pulled away with the door. .. THANKS AGAIN!!! Bill Hunter -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of user9253 Sent: Wednesday, August 2, 2017 8:25 AM Subject: AeroElectric-List: Re: Do I need a Pull Up resistor? Bill, how about connecting the output of the magnetic sensor to a panel mounted LED light? A 150 ohm series resistor will limit current from a 5 volt source. I glued an LED into a hole drilled into the instrument panel. http://www.mouser.com/Optoelectronics/LED-Lighting/LED-Emitters/Standard-LED s-Through-Hole/_/N-b1bc8Zscv7?P=1z0yt1mZ1yzxspgZ1yztlcbZ1yzrt8pZ1yztnraZ1yzl dgwZ1yztlq8Z1ywu49aZ1yzuk8tZ1yztj3sZ1yztm0dZ1yuo70f&Ns=Package+%2f+Case%7c1 -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471435#471435 ________________________________________________________________________________
Date: Aug 02, 2017
Bill, it looks like your reasoning is correct. But why take a chance? Buy part number MP200703 with form "C" contacts. Then if the logic is wrong, just interchange the wires. Did you notice that it is says "Reed-based" ? It is probably just a magnetic reed switch enclosed in a cylinder. Another hint is that it uses no power. Not that there is anything wrong with magnetic reed switches, but it might not be as sensitive as the electronic type. Sometimes reed switches can be finicky about the strength and orientation of the magnet. They work best when the longitudinal axis of the magnet is parallel with the longitudinal axis of the switch and they are both side by side. I am not saying that other orientations will not work, just that they work best as described. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471446#471446 ________________________________________________________________________________
Date: Aug 02, 2017
This hall effect proximity sensor has two outputs. It is pricey though with $20 shipping from England. http://www.newark.com/comus/s1456/hall-effect-proximity-24vdc-cable/dp/49X0853 Allied also sells it, but for a higher price. I am not guarantying it will work for your application. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471447#471447 ________________________________________________________________________________
Date: Aug 02, 2017
Joe, you are definitely the guy to ask about this stuff!!! > Buy part number MP200703 with form "C" contacts. Then if the logic is wrong, just interchange the wires. Good advice!!! > Sometimes reed switches can be finicky about the strength and orientation of the magnet. They work best when the longitudinal axis of the magnet is parallel with the longitudinal axis of the switch and they are both side by side. I am not saying that other orientations will not work, just that they work best as described. Hmmm...my plan is to insert the MP200703 into the foam board frame of the air box (imagine a AA battery inserted into a foam board at a 90 degree) and then on the fiberglass flapper valve I plan to bond the magnet (encapsulated in fiberglass) onto the flapper door so that when the flapper door is closed the aspirin pill shape/ sized magnet will be lying flat on top of the AA battery with a thin fiberglass sheet in between. THANKS AGAIN!!! .. Cheers!!! Bill Hunter -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of user9253 Sent: Wednesday, August 2, 2017 1:07 PM Subject: AeroElectric-List: Re: Do I need a Pull Up resistor? Bill, it looks like your reasoning is correct. But why take a chance? Buy part number MP200703 with form "C" contacts. Then if the logic is wrong, just interchange the wires. Did you notice that it is says "Reed-based" ? It is probably just a magnetic reed switch enclosed in a cylinder. Another hint is that it uses no power. Not that there is anything wrong with magnetic reed switches, but it might not be as sensitive as the electronic type. Sometimes reed switches can be finicky about the strength and orientation of the magnet. They work best when the longitudinal axis of the magnet is parallel with the longitudinal axis of the switch and they are both side by side. I am not saying that other orientations will not work, just that they work best as described. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471446#471446 ________________________________________________________________________________
Date: Aug 02, 2017
Thermocouples and their management is covered in some detail in the 'Connection starting on Page 14-11. Bob . . . ________________________________________________________________________________
Date: Aug 02, 2017
I posted several links to form C reed switches the 1st time Bill floated this. Burglar alarm contacts are available that are designed for 'end to end' orientation (recessed window/door contacts); I'm pretty sure I sent some links to those. FWIW, reed switches are some of the most reliable components you'll find; close to the reliability of wire itself. Charlie On 8/2/2017 4:02 PM, William Hunter wrote: > > Joe, you are definitely the guy to ask about this stuff!!! > >> Buy part number MP200703 with form "C" contacts. Then if the logic is > wrong, just interchange the wires. > > Good advice!!! > >> Sometimes reed switches can be finicky about the strength and orientation > of the magnet. They work best when the longitudinal axis of the magnet is > parallel with the longitudinal axis of the switch and they are both side by > side. I am not saying that other orientations will not work, just that they > work best as described. > > Hmmm...my plan is to insert the MP200703 into the foam board frame of the > air box (imagine a AA battery inserted into a foam board at a 90 degree) and > then on the fiberglass flapper valve I plan to bond the magnet (encapsulated > in fiberglass) onto the flapper door so that when the flapper door is closed > the aspirin pill shape/ sized magnet will be lying flat on top of the AA > battery with a thin fiberglass sheet in between. > > THANKS AGAIN!!! > .. > > Cheers!!! > > Bill Hunter > > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of user9253 > Sent: Wednesday, August 2, 2017 1:07 PM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Re: Do I need a Pull Up resistor? > > > Bill, it looks like your reasoning is correct. But why take a chance? Buy > part number MP200703 with form "C" contacts. Then if the logic is wrong, > just interchange the wires. > Did you notice that it is says "Reed-based" ? It is probably just a > magnetic reed switch enclosed in a cylinder. Another hint is that it uses > no power. Not that there is anything wrong with magnetic reed switches, but > it might not be as sensitive as the electronic type. Sometimes reed > switches can be finicky about the strength and orientation of the magnet. > They work best when the longitudinal axis of the magnet is parallel with the > longitudinal axis of the switch and they are both side by side. I am not > saying that other orientations will not work, just that they work best as > described. > > -------- > Joe Gores --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Aug 02, 2017
Thanks Charlie, As they say... size matters... and the location I want to use these in my battery box is very limited so therefore the square like window switches would not work however the barrel shape and AA size battery shape would work perfectly in this installation. I found the switch that Joe and I had discussed at Newark 4 less than 20 bucks delivered. I will report back with my results. Thanks again for the advice, Bill Hunter On Aug 2, 2017 4:11 PM, "Charlie England" wrote: > ceengland7(at)gmail.com> > > I posted several links to form C reed switches the 1st time Bill floated > this. Burglar alarm contacts are available that are designed for 'end to > end' orientation (recessed window/door contacts); I'm pretty sure I sent > some links to those. FWIW, reed switches are some of the most reliable > components you'll find; close to the reliability of wire itself. > > Charlie > > On 8/2/2017 4:02 PM, William Hunter wrote: > >> billhuntersemail(at)gmail.com> >> >> Joe, you are definitely the guy to ask about this stuff!!! >> >> Buy part number MP200703 with form "C" contacts. Then if the logic is >>> >> wrong, just interchange the wires. >> >> Good advice!!! >> >> Sometimes reed switches can be finicky about the strength and orientation >>> >> of the magnet. They work best when the longitudinal axis of the magnet is >> parallel with the longitudinal axis of the switch and they are both side >> by >> side. I am not saying that other orientations will not work, just that >> they >> work best as described. >> >> Hmmm...my plan is to insert the MP200703 into the foam board frame of the >> air box (imagine a AA battery inserted into a foam board at a 90 degree) >> and >> then on the fiberglass flapper valve I plan to bond the magnet >> (encapsulated >> in fiberglass) onto the flapper door so that when the flapper door is >> closed >> the aspirin pill shape/ sized magnet will be lying flat on top of the AA >> battery with a thin fiberglass sheet in between. >> >> THANKS AGAIN!!! >> .. >> >> Cheers!!! >> >> Bill Hunter >> >> >> >> >> >> -----Original Message----- >> From: owner-aeroelectric-list-server(at)matronics.com >> [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of >> user9253 >> Sent: Wednesday, August 2, 2017 1:07 PM >> To: aeroelectric-list(at)matronics.com >> Subject: AeroElectric-List: Re: Do I need a Pull Up resistor? >> >> >> Bill, it looks like your reasoning is correct. But why take a chance? >> Buy >> part number MP200703 with form "C" contacts. Then if the logic is wrong, >> just interchange the wires. >> Did you notice that it is says "Reed-based" ? It is probably just a >> magnetic reed switch enclosed in a cylinder. Another hint is that it uses >> no power. Not that there is anything wrong with magnetic reed switches, >> but >> it might not be as sensitive as the electronic type. Sometimes reed >> switches can be finicky about the strength and orientation of the magnet. >> They work best when the longitudinal axis of the magnet is parallel with >> the >> longitudinal axis of the switch and they are both side by side. I am not >> saying that other orientations will not work, just that they work best as >> described. >> >> -------- >> Joe Gores >> > > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus > > ________________________________________________________________________________
Subject: Starter Solenoid Diode
Date: Aug 02, 2017
My Spanish uncle would call it a "Dye-Oh-Doe" and I know I need one however I do not know what value nor where to install it. I want an indicator on my EMS to monitor the starter motor being energized and a cyber friend recommended installing a 1N4004 diode on my "I" pole of my starter solenoid to protect the Dynon EMS sensor and he drew up the attached PDF diagram and I will certainly do as he recommends. The additional question is.can someone also provide me with a quick schmatic of what diode I should use and where and what polarity to install it to protect from electrical spikes (in the same manner as one does for master contactors)? .. THANKS GUYS.I am making progress this week (for a change)!!! Bill Hunter ________________________________________________________________________________
Date: Aug 02, 2017
Thanks Bob. I have read, highlighted, studied, re-read and studied your book practically cover to cover. It is a really great resource. .. Cheers!!! Bill Hunter From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Wednesday, August 2, 2017 3:40 PM Subject: RE: AeroElectric-List: Sharing thermocouple inputs? Thermocouples and their management is covered in some detail in the 'Connection starting on Page 14-11. Bob . . . ________________________________________________________________________________
Subject: Re: Starter Solenoid Diode
Date: Aug 02, 2017
Bob Nuckolls' diagrams have diodes and part numbers. Choose a diode that is physically strong enough to not break easily. Diodes are connected in parallel with coils to protect the controlling switch. The banded end of arc suppression diodes must connect to the positive side of coils. Connecting a diode backwards will cause smoke. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471461#471461 ________________________________________________________________________________
Date: Aug 02, 2017
On 8/2/2017 9:07 PM, William Hunter wrote: > > My Spanish uncle would call it a Dye-Oh-Doe and I know I need one > however I do not know what value nor where to install it. > > I want an indicator on my EMS to monitor the starter motor being > energized and a cyber friend recommended installing a 1N4004 diode on > my I pole of my starter solenoid to protect the Dynon EMS sensor and > he drew up the attached PDF diagram and I will certainly do as he > recommends. > > The additional question iscan someone also provide me with a quick > schmatic of what diode I should use and where and what polarity to > install it to protect from electrical spikes (in the same manner as > one does for master contactors)? > > .. > > THANKS GUYSI am making progress this week (for a change)!!! > > Bill Hunter > The diode *is* a 1N4004; that's the ID of the diode. The bar at the pointy end of the symbol matches the band on the diode. Google the part number & you'll get specs (current handling, max allowable reverse voltage, etc), but it's not particularly critical if it's just used for isolation in a sensing circuit. Now, what it will do, connected as shown, is another question entirely. Without knowing the characteristics of the Dynon's input, it seems unlikely that it will do anything. The I terminal goes from floating to high (12V) when the start contacts close. But the diode, as drawn, will block that 12V from reaching the Dynon. Now, if the Dynon's input needs a signal to go low (zero) instead of high, to activate the input, the circuit shown won't do that, either. --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Aug 03, 2017
I had the same concerns as Charlie but did not say anything because I was not sure. After sleeping on it, connecting an inductive load (starter) in parallel with a Dynon input might not be a good idea. I suggest that input be used instead for the Air filter door position sensor. That diode will NOT protect the Dynon input from an inductive voltage spike. Notice that the diode and Dynon input combination are connected in parallel with the inductor (starter). And the banded end of the diode is connected to positive. That is the same orientation as arc suppression diodes. Therefore the diode will conduct inductive spikes right through the Dynon input. The Dynon manual states, "The voltage on the general purpose inputs must not exceed 15 volts." I would call Dynon support before connecting an inductive load in parallel with an input. If Dynon gives the OK, would the circuit actually work? I assume the Dynon input supplies 5 volts through a pull-up resistor. The input will be normally grounded through the starter motor. When the contactor is energized, Dynon input current will stop flowing because the load (starter) will draw current from the highest voltage source which is the aircraft battery. The Dynon input will then go high from the 5 volt pull-up resistor. Like I said, I am not sure. I will not be insulted if someone corrects me. Opposing views encouraged. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471472#471472 ________________________________________________________________________________
Date: Aug 03, 2017
Joe and Charlie, As always I am VERY GRATEFUL for your time and help!!! I will call Dynon today as soon as they open. As Joe recommends, I might just eliminate the "I" post input to the Dynon and roll (err...fly) with a simple LED next to the starter pushbutton. As Joe was hitting send I was studying the AeroElectric diagrams. Regardless of what I do with the "I" post, I still need an external diode on my Ford starter solenoid. I assume that the external diode needs to run from the "S" pole to the solenoid case ground (a composite airplane) with the banded end closest to the "S" pole as shown in the attached schematic). Can you PLEASE look it over and make sure I got it right. > I assume the Dynon input supplies 5 volts through a pull-up resistor. This whole "Pull Up" resistor thing is confusing. The sensor inputs of the Dynon EMS show 5 VDC. Here is a quote from the Dynon Tech Support on one of the threads " The pin is pulled up internally to 5V. This means it's 5V when nothing is connected and some path to ground is needed to reduce the voltage below 5V. So you get 5V when nothing is connected and 0V when you connect the wire to ground. This isn't "magic," it's just a 10K resistor to 5V." .. THANKS AGAIN!!! Bill Hunter ________________________________________________________________________________
Date: Aug 03, 2017
Bill, yes the diode is connected correctly. It is directly across the coil with the banded end on the positive side. About pull-up resistors: The only way that an input can tell if a switch is open or closed is by sending a small current through the switch. Current flows when the switch is closed and current stops when the switch is open. The current must be limited to protect the 5 volt source and to protect the wires. A 10K series resistor limits the current. That resistor is called a pull-up resistor. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471475#471475 ________________________________________________________________________________
Date: Aug 03, 2017
Thanks Joe!!! Very clear explanation...You would make an excellent electronics instructor!!! Thankfully there is still a Radio Shack in town...limited components but I hope they will have the Dye-Oh-doe I need. .. Cheers!!! Bill Hunter -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of user9253 Sent: Thursday, August 3, 2017 7:57 AM Subject: AeroElectric-List: Re: Starter Solenoid Diode Bill, yes the diode is connected correctly. It is directly across the coil with the banded end on the positive side. About pull-up resistors: The only way that an input can tell if a switch is open or closed is by sending a small current through the switch. Current flows when the switch is closed and current stops when the switch is open. The current must be limited to protect the 5 volt source and to protect the wires. A 10K series resistor limits the current. That resistor is called a pull-up resistor. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471475#471475 ________________________________________________________________________________
Date: Aug 03, 2017
At 09:07 PM 8/2/2017, you wrote: > > >My Spanish uncle would call it a =93Dye-Oh-Doe=94 >and I know I need one however I do not know what value nor where to install it. > >I want an indicator on my EMS to monitor the >starter motor being energized and a cyber friend >recommended installing a 1N4004 diode on my =93I=94 >pole of my starter solenoid to protect the Dynon >EMS sensor and he drew up the attached PDF >diagram and I will certainly do as he recommends. > >The additional question is=85can someone also >provide me with a quick schmatic of what diode I >should use and where and what polarity to >install it to protect from electrical spikes (in >the same manner as one does for master contactors)? > >.. > >THANKS GUYS=85I am making progress this week (for a change)!!! > >Bill Hunter Can't imagine why . . . if your EMS has inputs designed to attach to any source of power on the airplane for the purposes of monitoring (voltmeter input) then just tie it to the "I" terminal directly. The diode as he as shown it would actually prevent the EMS from seeing voltage on the "I" terminal. Bob . . . ________________________________________________________________________________
Date: Aug 03, 2017
At 10:38 AM 8/3/2017, you wrote: >At 09:07 PM 8/2/2017, you wrote: >> >> >>My Spanish uncle would call it a =93Dye-Oh-Doe=94 >>and I know I need one however I do not know what value nor where to install it. >> >>I want an indicator on my EMS to monitor the >>starter motor being energized and a cyber >>friend recommended installing a 1N4004 diode on >>my =93I=94 pole of my starter solenoid to protect >>the Dynon EMS sensor and he drew up the >>attached PDF diagram and I will certainly do as he recommends. >> >>The additional question is=85can someone also >>provide me with a quick schmatic of what diode >>I should use and where and what polarity to >>install it to protect from electrical spikes >>(in the same manner as one does for master contactors)? >> >>.. >> >>THANKS GUYS=85I am making progress this week (for a change)!!! >> >>Bill Hunter > > Can't imagine why . . . if your EMS has inputs designed to > attach to any source of power on the airplane for the purposes > of monitoring (voltmeter input) then just tie it to the "I" > terminal directly. The diode as he as shown it would actually > prevent the EMS from seeing voltage on the "I" terminal. Oh, okay. If the input port to the Dynon is NORMALLY looking for a 0-5v signal, then yes . . . as Joe has pointed out, a pull-up resistor on the Dynon side of the diode is needed to raise the input to approx 5v when the "I" terminal RISES ABOVE 5v (starter getting power from battery). If, in this case, the EMS input is tailored to 0-5v sensor inputs, then it may NOT be protected internally for general used looked at voltages elsewhere on the system. Do check with Dynon as to absolute maximums that the input will tolerate. Bob . . . ________________________________________________________________________________
Subject: 2 AWG crimping tool
Date: Aug 04, 2017
Hello, I have a question about crimping 2 AWG wire. I was wiring my plane and it came the time to wire my 2 AWG cable. For that I bought a crimping tool, this : (Not the best I agree) http://www.electricianstoolsonline.com/mini-hex-crimper-6mm2-to-50mm2 We can see that is for : 6mm, 10mm, 16mm, 25mm, 35mm, 50mm Hexagonal crimp My cable was a 2 AWG mil spec and my terminal is bought on the same website bandc-aero. I tried to crimp one with the 25mm2 jaw (for me 2 AWG it's 32mm2 ?), cable looked well maintained but terminal was deformed. With on a side a sharp edge. So I crimped with the 50mm2, I performed a light traction test it seems to be ok terminal stay on the wire, but how could be sure that crimp is ok ? It not seems to be tightened with a good strong deformation. I ask the question because if it was on my car, I will see with time. But on my plane, even if I have two battery, (with one small wired with standard small temrinal) I don't want to try tings. Thank you in advance to sharing you experience on this subject. Good flight. Mickal [Wink] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471500#471500 ________________________________________________________________________________
Subject: Re: 2 AWG crimping tool
Date: Aug 04, 2017
For the price you can't beat this: http://www.ebay.co.uk/itm/Tube-Terminals-Lugs-Battery-Cable-Wire-Crimping-Force-Hydraulic-Crimper-Tool-Kit-/132282830917?hash=item1eccabd045:g:kp8AAOSwSplZgvnD John Sent from my iPad ----x--O--x---- > On 4 Aug 2017, at 05:51 pm, "Achille" wrote: > > > Hello, > > I have a question about crimping 2 AWG wire. I was wiring my plane and it came the time to wire my 2 AWG cable. > > For that I bought a crimping tool, this : (Not the best I agree) > > http://www.electricianstoolsonline.com/mini-hex-crimper-6mm2-to-50mm2 > > We can see that is for : 6mm, 10mm, 16mm, 25mm, 35mm, 50mm > Hexagonal crimp > > My cable was a 2 AWG mil spec and my terminal is bought on the same website bandc-aero. > > I tried to crimp one with the 25mm2 jaw (for me 2 AWG it's 32mm2 ?), cable looked well maintained but terminal was deformed. With on a side a sharp edge. > > So I crimped with the 50mm2, I performed a light traction test it seems to be ok terminal stay on the wire, but how could be sure that crimp is ok ? It not seems to be tightened with a good strong deformation. > > I ask the question because if it was on my car, I will see with time. But on my plane, even if I have two battery, (with one small wired with standard small temrinal) I don't want to try tings. > > Thank you in advance to sharing you experience on this subject. > > Good flight. > Mickal [Wink] > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471500#471500 > > > > > > > > > ________________________________________________________________________________
Date: Aug 04, 2017
You can beat it pretty easily with a small propane torch (already in your tool box), some rosin core solder, a couple of inches of shrink tubing, and the knowledge that there's no more risk of fatigue damage with a properly soldered joint & downstream support, than there is with a crimped joint. ;-) On 8/4/2017 12:03 PM, John Tipton wrote: > > For the price you can't beat this: > > http://www.ebay.co.uk/itm/Tube-Terminals-Lugs-Battery-Cable-Wire-Crimping-Force-Hydraulic-Crimper-Tool-Kit-/132282830917?hash=item1eccabd045:g:kp8AAOSwSplZgvnD > > John > > Sent from my iPad > > ----x--O--x---- > >> On 4 Aug 2017, at 05:51 pm, "Achille" wrote: >> >> >> Hello, >> >> I have a question about crimping 2 AWG wire. I was wiring my plane and it came the time to wire my 2 AWG cable. >> >> For that I bought a crimping tool, this : (Not the best I agree) >> >> http://www.electricianstoolsonline.com/mini-hex-crimper-6mm2-to-50mm2 >> >> We can see that is for : 6mm, 10mm, 16mm, 25mm, 35mm, 50mm >> Hexagonal crimp >> >> My cable was a 2 AWG mil spec and my terminal is bought on the same website bandc-aero. >> >> I tried to crimp one with the 25mm2 jaw (for me 2 AWG it's 32mm2 ?), cable looked well maintained but terminal was deformed. With on a side a sharp edge. >> >> So I crimped with the 50mm2, I performed a light traction test it seems to be ok terminal stay on the wire, but how could be sure that crimp is ok ? It not seems to be tightened with a good strong deformation. >> >> I ask the question because if it was on my car, I will see with time. But on my plane, even if I have two battery, (with one small wired with standard small temrinal) I don't want to try tings. >> >> Thank you in advance to sharing you experience on this subject. >> >> Good flight. >> Mickal [Wink] --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Aug 04, 2017
I have crimped them similar to this method but I used a piece of steel with a half-hole for the anvil http://www.thebackshed.com/forum/printer_friendly_posts.asp?FID=4&TID=8298 Or do a google images search for crimp large cables and youll see lots of crimpers If you have a welding supplier nearby, they can crimp those large cables. Welding cable is often used in battery runs. Very tough and flexible. -Kent > On Aug 4, 2017, at 12:51 PM, Achille wrote: > > > Hello, > > I have a question about crimping 2 AWG wire. I was wiring my plane and it came the time to wire my 2 AWG cable. > > For that I bought a crimping tool, this : (Not the best I agree) > > http://www.electricianstoolsonline.com/mini-hex-crimper-6mm2-to-50mm2 > > We can see that is for : 6mm, 10mm, 16mm, 25mm, 35mm, 50mm > Hexagonal crimp > > My cable was a 2 AWG mil spec and my terminal is bought on the same website bandc-aero. > > I tried to crimp one with the 25mm2 jaw (for me 2 AWG it's 32mm2 ?), cable looked well maintained but terminal was deformed. With on a side a sharp edge. > > So I crimped with the 50mm2, I performed a light traction test it seems to be ok terminal stay on the wire, but how could be sure that crimp is ok ? It not seems to be tightened with a good strong deformation. > > I ask the question because if it was on my car, I will see with time. But on my plane, even if I have two battery, (with one small wired with standard small temrinal) I don't want to try tings. > > Thank you in advance to sharing you experience on this subject. > > Good flight. > Mickal [Wink] > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471500#471500 > > > > > > > > > ________________________________________________________________________________
Date: Aug 04, 2017
Found similar at Harbor Freight an it works great. Bob Reed Sent from my iPhone > On Aug 4, 2017, at 1:05 PM, Kent or Jackie Ashton wrote: > > > I have crimped them similar to this method but I used a piece of steel with a half-hole for the anvil > http://www.thebackshed.com/forum/printer_friendly_posts.asp?FID=4&TID=8298 > > Or do a google images search for crimp large cables and youll see lots of crimpers > > If you have a welding supplier nearby, they can crimp those large cables. Welding cable is often used in battery runs. Very tough and flexible. > > -Kent >> On Aug 4, 2017, at 12:51 PM, Achille wrote: >> >> >> Hello, >> >> I have a question about crimping 2 AWG wire. I was wiring my plane and it came the time to wire my 2 AWG cable. >> >> For that I bought a crimping tool, this : (Not the best I agree) >> >> http://www.electricianstoolsonline.com/mini-hex-crimper-6mm2-to-50mm2 >> >> We can see that is for : 6mm, 10mm, 16mm, 25mm, 35mm, 50mm >> Hexagonal crimp >> >> My cable was a 2 AWG mil spec and my terminal is bought on the same website bandc-aero. >> >> I tried to crimp one with the 25mm2 jaw (for me 2 AWG it's 32mm2 ?), cable looked well maintained but terminal was deformed. With on a side a sharp edge. >> >> So I crimped with the 50mm2, I performed a light traction test it seems to be ok terminal stay on the wire, but how could be sure that crimp is ok ? It not seems to be tightened with a good strong deformation. >> >> I ask the question because if it was on my car, I will see with time. But on my plane, even if I have two battery, (with one small wired with standard small temrinal) I don't want to try tings. >> >> Thank you in advance to sharing you experience on this subject. >> >> Good flight. >> Mickal [Wink] >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=471500#471500 >> >> >> >> >> >> >> >> >> > > > > > ________________________________________________________________________________
Date: Aug 05, 2017
Subject: Fuse Blocks
Folks, I need to select fuse blocks for my plane, less than 20 circuits. I found the Littelfuse POWR-BLOCK on Digi-Key and it looks cool but I have to order a zillion pieces to make a complete set of stuff that is ready to go into the plane: fuse blocks, interlocks, mounts, terminals. Is there an easier way? Something off-the-shelf and maybe available locally? Or should I carefully get together all of the parts that I need and order the POWR-BLOCK from Digi-Key. Thanks, -- Art Z. -- https://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
From: "John Ciolino" <JohnCiolino(at)carolina.rr.com>
Date: Aug 05, 2017
There is something simpler. See www.bandc.aero, look under electrical supplies/circuit protection devices/fuse blocks. A 20 circuit block ready to use is $30. Good luck/ John Bearhawk Patrol From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Art Zemon Sent: Saturday, August 05, 2017 6:53 PM Subject: AeroElectric-List: Fuse Blocks Folks, I need to select fuse blocks for my plane, less than 20 circuits. I found the Littelfuse POWR-BLOCK on Digi-Key and it looks cool but I have to order a zillion pieces to make a complete set of stuff that is ready to go into the plane: fuse blocks, interlocks, mounts, terminals. Is there an easier way? Something off-the-shelf and maybe available locally? Or should I carefully get together all of the parts that I need and order the POWR-BLOCK from Digi-Key. Thanks, -- Art Z. -- https://CheerfulCurmudgeon.com/ "If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel ________________________________________________________________________________
Subject: Re: Fuse Blocks
Date: Aug 05, 2017
Something like this can fit right on your panel http://www.cooperindustries.com/content/public/en/bussmann/transportation/products/power_distribution/fuse_panels/series_15710_rearterminalatcfusepanel.html Or do a google images search for ATC fuse blocks and youll see many other styles. Some are available at auto parts stores. I have used the 20 gang version http://www.ebay.com/itm/NEW-Bussmann-15600-18-20-18-Position-ATC-Fuse-Panel-Block-RV-Trailer-Boat-Solar/272378729318 and also used 12 gang and 8 gang models to set up a main and essential bus. With the 20 position version, it is also possible to cut the center conductor, silver soldered a extra tab on the end and made a main/essential bus out set up out of it. -Kent > On Aug 5, 2017, at 6:53 PM, Art Zemon wrote: > > Folks, > > I need to select fuse blocks for my plane, less than 20 circuits. I found the Littelfuse POWR-BLOCK on Digi-Key and it looks cool but I have to order a zillion pieces to make a complete set of stuff that is ready to go into the plane: fuse blocks, interlocks, mounts, terminals. > > Is there an easier way? Something off-the-shelf and maybe available locally? Or should I carefully get together all of the parts that I need and order the POWR-BLOCK from Digi-Key. > > Thanks, > -- Art Z. > > -- > https://CheerfulCurmudgeon.com/ > > "If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel ________________________________________________________________________________
Date: Aug 05, 2017
That's exactly what I need! Thanks. -- Art Z. Sent from my phone. Please excuse brevity and bizarre typos. On Aug 5, 2017 6:54 PM, "John Ciolino" wrote: There is something simpler. See www.bandc.aero, look under electrical supplies/circuit protection devices/fuse blocks. A 20 circuit block ready to use is $30. Good luck/ ________________________________________________________________________________
Date: Aug 05, 2017
Art, I got mine at West Marine. Ron Burnett May you have the Lord's blessings today! Sent from my iPad > On Aug 5, 2017, at 6:57 PM, Art Zemon wrote: > > That's exactly what I need! Thanks. > > -- Art Z. > > Sent from my phone. Please excuse brevity and bizarre typos. > > On Aug 5, 2017 6:54 PM, "John Ciolino" wrote : > There is something simpler. See www.bandc.aero, look under electrical supp lies/circuit protection devices/fuse blocks. A 20 circuit block ready to use is $30. > > Good luck/ ________________________________________________________________________________
Subject: Re: 1.57542 GHz Filter
Date: Aug 05, 2017
Hi Bob I=99m *very* happy to have your expert attention consider this, even though it=99s not a homebuilt. VHF comm equipment is (are?) a King KX165 (com1) and a KX155 (com2), each connected to its own roof-mount antenna. The GPS is an Apollo GX50, with the =9Cpatch=9D antenna on the tailcone, so there=99s about 6 feet between the antenna systems. The coaxes are routed diversely, the GPS under the floor and the COM via the pillars to the cabin roof. The interference is generated from both com1 and com2. A > On Jul 23, 2017, at 4:22 PM, Robert L. Nuckolls, III wrote: > > At 11:35 AM 7/23/2017, you wrote: >> I'm sorry - I should have given more detail. >> >> The GPS reports zero satellites in view and takes itself offline during, and for a few seconds after, any transmission on either VHF COM radio on one of a select few frequencies: 121.175MHz I think is one of them. It=C3=A2=C2=C2=99s an old GPS and not a new problem. I=C3=A2=C2 =C2=99ve put a fair amount of resource into trying to fix it some while ago, but not found a resolution. > > Understand. > > Some background on cross-system interference issues > may be helpful . . . > > When one runs the DO160/MIL-STD 461/462 gauntlets, > it is incumbent on the manufacturer of a new product > to measure and document extraneous emissions to > be sure they are below tolerable limits for other > systems. We know that its difficult if not impossible > to drive all potential interference emission to zero > but the design goals call for reducing them to insignificance. > I.e. the victim system's performance is not degraded. > > > > > A fairly recent edition of DO160 offers these testing > limits for radiated emissions. Note those 'notches' in > the allowable emissions plot. They are centered over specific > ranges of spectrum where RECEIVERS of itty-bitty signals > would like to have a clear shot at detecting the information > on those frequencies. > > Note the notches cover vhf nav/comm, uhf nav/comm, transponder/ > tcas and gps bands. Not sure what service is being protected > up round 5 ghz . . . > > The energy levels allowed are the sum total of energies > radiated from all components of a device and associated > cables when laid out on a copper-top table like so. > > > All this is fine and dandy for potential antagonists > that are NOT designed to radiate buckets of energy on purpose > . . . i.e. transmitters. Tests for bkackbox/harness radiation are > generally no big deal . . . I've never failed one. > > Then there are transmitters. By nature, they're intended to > radiate signal levels on the order of 130 dBuv/m at 3 meters > from an antenna. Given that 'extraneous' emission limits > at GPS frequencies are on the order of 85 dBuv/m LOWER, this > means that the 13th harmonic (121 mHz x13 = GPS) power has to > be on the order of 1 times 10^-8 lower than the fundamental. > > Modern designs have no problem achieving this goal but > there's a goodly number of legacy comm equipment that > was designed and qualified before GPS became the backbone > of aerial navigation. > > GPS signals are exceedingly weak . . . generally at or below > atmospheric noise. The predictable nature of the incoming > signal makes if possible to digitally sift useful data > out of what would otherwise be noise. > > If adding the notch filter didn't fix the symptoms, then > perhaps the interference isn't being radiated from the > antenna . . . there have been cases of incompatible > appliances were the interference was getting out of the > enclosure (i.e. wouldn't pass the bench test as described above). > > Will your gps interference symptom repeat on the ground? > > You might try dummy loading the transceiver and see > if the interference goes away. Oops, just noticed that it > repeats on two separate transmitters (same brand/model?) > How far apart are your comm and GPS antennas? > > > > > > > > > Bob . . . > ________________________________________________________________________________
Date: Aug 05, 2017
Before you decide on which wisdom (solder vs crimp terminals) to follow, try to do your own research. Most industry standards and federal guidance lean towards crimp connections for vibration prone applications in aircraft. They seem to show a preference for solder joints only on the lighter weight terminals found on circuit boards and etc. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471538#471538 ________________________________________________________________________________
From: Stuart Hutchison <stuart(at)stuarthutchison.com.au>
Date: Aug 06, 2017
SteinAir has everything - http://www.steinair.com/?search_category=&s=fuse&search_posttype=pro duct <http://www.steinair.com/?search_category=&s=fuse&search_posttype=pr oduct> Cheers, Stu > On 6 Aug 2017, at 10:16, Ron Burnett wrote: > > Art, > > I got mine at West Marine. > > Ron Burnett > > May you have the Lord's blessings today! > Sent from my iPad > > On Aug 5, 2017, at 6:57 PM, Art Zemon > wrote: > >> That's exactly what I need! Thanks. >> >> -- Art Z. >> >> Sent from my phone. Please excuse brevity and bizarre typos. >> >> On Aug 5, 2017 6:54 PM, "John Ciolino" > wrote: >> There is something simpler. See www.bandc.aero <http://www.bandc.aero/>, look under electrical supplies/circuit protection devices/fuse blocks. A 20 circuit block ready to use is $30. >> >> Good luck/ >> ________________________________________________________________________________
Date: Aug 06, 2017
"SteinAir has everything" - apparently not: they don't seem to to the 16 and 20 fuse sizes !!! Sent from my iPad ----x--O--x---- > On 6 Aug 2017, at 05:31 am, Stuart Hutchison wrote: > > SteinAir has everything - http://www.steinair.com/?search_category=&s= fuse&search_posttype=product > > Cheers, Stu > >> On 6 Aug 2017, at 10:16, Ron Burnett wrote: >> >> Art, >> >> I got mine at West Marine. >> >> Ron Burnett >> >> May you have the Lord's blessings today! >> Sent from my iPad >> >>> On Aug 5, 2017, at 6:57 PM, Art Zemon wrote: >>> >>> That's exactly what I need! Thanks. >>> >>> -- Art Z. >>> >>> Sent from my phone. Please excuse brevity and bizarre typos. >>> >>> On Aug 5, 2017 6:54 PM, "John Ciolino" wro te: >>> There is something simpler. See www.bandc.aero, look under electrical su pplies/circuit protection devices/fuse blocks. A 20 circuit block ready to u se is $30. >>> >>> Good luck/ >>> > ________________________________________________________________________________
Date: Aug 06, 2017
Sure, but two 12s = 24 more than enough :-) > On 6 Aug 2017, at 16:25, John Tipton wrote: > > "SteinAir has everything" - apparently not: they don't seem to to the 16 and 20 fuse sizes !!! > > Sent from my iPad > > ----x--O--x---- > > On 6 Aug 2017, at 05:31 am, Stuart Hutchison > wrote: > >> SteinAir has everything - http://www.steinair.com/?search_category=&s=fuse&search_posttype=pro duct <http://www.steinair.com/?search_category=&s=fuse&search_posttype=pr oduct> >> >> Cheers, Stu >> >>> On 6 Aug 2017, at 10:16, Ron Burnett > wrote: >>> >>> Art, >>> >>> I got mine at West Marine. >>> >>> Ron Burnett >>> >>> May you have the Lord's blessings today! >>> Sent from my iPad >>> >>> On Aug 5, 2017, at 6:57 PM, Art Zemon > wrote: >>> >>>> That's exactly what I need! Thanks. >>>> >>>> -- Art Z. >>>> >>>> Sent from my phone. Please excuse brevity and bizarre typos. >>>> >>>> On Aug 5, 2017 6:54 PM, "John Ciolino" > wrote: >>>> There is something simpler. See www.bandc.aero <http://www.bandc.aero/>, look under electrical supplies/circuit protection devices/fuse blocks. A 20 circuit block ready to use is $30. >>>> >>>> Good luck/ >>>> >> ________________________________________________________________________________
Date: Aug 06, 2017
Perfect! I'll drive over soon. Nice 'n' convenient and I can support the local economy with my huge purchase :-) Thanks, Ron. -- Art Z. On Sat, Aug 5, 2017 at 7:16 PM, Ron Burnett wrote: > Art, > > I got mine at West Marine. > -- https://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
From: William Hunter <billhuntersemail(at)gmail.com>
Date: Aug 06, 2017
Hi All, I know everyone has been rooting for me so I figured I would post back on my progress. I tried wiring up the sensor pin using the diode as was suggested on the Dynon forum however I did not have any luck so I had to use my lifeline and called Dynon tech support and as usual they were extremely helpful. After trying different EMS settings and diode polorisation and such it appears that the only way I could get my starter contactor annunciation to work is to connect the sensor pin to the same 5/16 starter contactor output terminal that the starter motor cable is connected to... in other words the "I" terminal will not work. It seems that the sensor pin needs to see some kind of a ground for it to get "pulled down" to low and since the "I" terminal does not have any path the ground when the starter contactor is not energized there's no way I could get it to work. I'm happy that at least now my starter engaged annunciator will illuminate however after I got off the phone I am now wondering if I need some kind of protection between the starter contactor output pole and the EMS sensor wire. Anyhoo, thanks for all your help, well wishes, moments of silence, finger crossing, and other positive energy telepathic thought waves!!! Baby steps to Dynon Bliss!!! Thanks, Bill Hunter On Aug 3, 2017 9:51 AM, "Robert L. Nuckolls, III" < nuckolls.bob(at)aeroelectric.com> wrote: > At 10:38 AM 8/3/2017, you wrote: > > At 09:07 PM 8/2/2017, you wrote: > > > My Spanish uncle would call it a =9CDye-Oh-Doe=9D and I know I need one > however I do not know what value nor where to install it. > > I want an indicator on my EMS to monitor the starter motor being energize d > and a cyber friend recommended installing a 1N4004 diode on my =9CI =9D pole of > my starter solenoid to protect the Dynon EMS sensor and he drew up the > attached PDF diagram and I will certainly do as he recommends. > > The additional question iscan someone also provide me with a qui ck > schmatic of what diode I should use and where and what polarity to instal l > it to protect from electrical spikes (in the same manner as one does for > master contactors)? > > .. > > THANKS GUYSI am making progress this week (for a change)!!! > > Bill Hunter > > > Can't imagine why . . . if your EMS has inputs designed to > attach to any source of power on the airplane for the purposes > of monitoring (voltmeter input) then just tie it to the "I" > terminal directly. The diode as he as shown it would actually > prevent the EMS from seeing voltage on the "I" terminal. > > > Oh, okay. If the input port to the Dynon is NORMALLY > looking for a 0-5v signal, then yes . . . as Joe > has pointed out, a pull-up resistor on the Dynon side > of the diode is needed to raise the input to approx 5v > when the "I" terminal RISES ABOVE 5v (starter getting power > from battery). > > If, in this case, the EMS input is tailored to 0-5v > sensor inputs, then it may NOT be protected internally > for general used looked at voltages elsewhere on the > system. Do check with Dynon as to absolute maximums > that the input will tolerate. > > Bob . . . > ________________________________________________________________________________
Date: Aug 06, 2017
Subject: Backup Alternator / Backup Battery Sanity Check
Folks, Can you give me a sanity check? I am building a Bede BD-4C with an MGL EFIS. This is largely a mechanical airplane so manual trim, no gear motors, manual flaps, etc. Between the low current consumption of the EFIS and using LED lights, a backup alternator will run everything in the airplane except the pitot heater; the typical current draw is 21.57 amps and maximum is 31.49 amps. (Pitot heat adds 10 amps.) With that in mind, I plan on including a 30 amp backup alternator and no backup battery. I figure: - If the engine is turning, I will certainly have one of the two alternators operable. - If the engine is not turning, the main battery ought to keep the electrons flowing until I reach the ground. Am I missing anything? -- Art Z. -- https://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
Date: Aug 06, 2017
Subject: Re: Backup Alternator / Backup Battery Sanity Check
At 12:41 PM 8/6/2017, you wrote: >Folks, > >Can you give me a sanity check? I am building a Bede BD-4C with an >MGL EFIS. This is largely a mechanical airplane so manual trim, no >gear motors, manual flaps, etc. Between the low current consumption >of the EFIS and using LED lights, a backup alternator will run >everything in the airplane except the pitot heater; the typical >current draw is 21.57 amps and maximum is 31.49 amps. (Pitot heat >adds 10 amps.) > >With that in mind, I plan on including a 30 amp backup alternator >and no backup battery. I figure: > * If the engine is turning, I will certainly have one of the two > alternators operable. > * If the engine is not turning, the main battery ought to keep > the electrons flowing until I reach the ground. >Am I missing anything? Nope Bob . . . ________________________________________________________________________________
Date: Aug 06, 2017
With the pitot heater shut off, I would expect the continuous current draw to be closer to 10 amps. Have you actually measured 21 amps? Regardless, the backup alternator should run everything. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471551#471551 ________________________________________________________________________________
Subject: Aircraft theft prevention?
Date: Aug 06, 2017
So with the understanding that most aircraft security is only good enough to keep honest folks from running off with your airplane... But does anyone have any ideas on ways to prevent the engine from starting? Other that the big chain prop locks. Early on, I was considering second, hidden mag switches. But I'm wondering if there's an alternative. Note: I do not have a keyed ignition switch. Just a toggle switch for each mag and a push button starter switch. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471552#471552 ________________________________________________________________________________
Date: Aug 06, 2017
From: Robert McCallum <robert.mccallum2(at)sympatico.ca>
Subject: Re: Aircraft theft prevention?
If you have mags, anyone can cut the "P" leads, hand prop the engine and fly away, regardless of anything you've done short of the prop chain idea so long as fuel is available. Maybe a hidden locking fuel valve. Be careful, as this may not prevent the engine starting and there might be just enough residual fuel in the lines to get airborne before the engine quits. The prop chain has the added benefit of being a visible deterrent so they won't even try, but rather go to an easier target. Bob McC > > ---------- Original Message ---------- > From: donjohnston <don@velocity-xl.com> > Date: August 6, 2017 at 4:35 PM > > > <don@velocity-xl.com> > > So with the understanding that most aircraft security is only good enough > to keep honest folks from running off with your airplane... > > But does anyone have any ideas on ways to prevent the engine from > starting? Other that the big chain prop locks. > > Early on, I was considering second, hidden mag switches. But I'm wondering > if there's an alternative. > > Note: I do not have a keyed ignition switch. Just a toggle switch for each > mag and a push button starter switch. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471552#471552 > > > > > > > > > > ________________________________________________________________________________
Date: Aug 06, 2017
You may want to check out a product we sell called SmartStart. It allows for a hidden arming switch that when pressed gives you 1 minute to crank the engine. It works with the standard start contactor, can interface to a push button switch or standard key switch. It also listens to interlock switches that must be closed before arming can occur Www.tcwtech.com Bob Newman TCW Technologies, LLC 610-928-3420 > On Aug 6, 2017, at 4:35 PM, donjohnston <don@velocity-xl.com> wrote: > > > So with the understanding that most aircraft security is only good enough to keep honest folks from running off with your airplane... > > But does anyone have any ideas on ways to prevent the engine from starting? Other that the big chain prop locks. > > Early on, I was considering second, hidden mag switches. But I'm wondering if there's an alternative. > > Note: I do not have a keyed ignition switch. Just a toggle switch for each mag and a push button starter switch. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471552#471552 > > > > > > > > > ________________________________________________________________________________
Date: Aug 06, 2017
Since no one else has replied, I will give it a shot. I do not know if the EMS input needs protection or not. But if you want to add protection, the attached pdf should work. The left diode blocks aircraft current from flowing into the EMS input. The diode on the right shorts out any induced voltage spike. The two 500 ohm resistors divide starter voltage in half. The bottom resistor also provides a ground path to pull the EMS input voltage low (to about 0.25 V) when the contactor is not energized. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471555#471555 Attachments: http://forums.matronics.com//files/starter_status_124.pdf ________________________________________________________________________________
Date: Aug 07, 2017
Take a look at the TCM Smart Start Don. Kind Regards, Stu Sent from my iPhone > On 7 Aug 2017, at 07:18, Robert McCallum w rote: > > If you have mags, anyone can cut the "P" leads, hand prop the engine and f ly away, regardless of anything you've done short of the prop chain idea so l ong as fuel is available. Maybe a hidden locking fuel valve. Be careful, as t his may not prevent the engine starting and there might be just enough resid ual fuel in the lines to get airborne before the engine quits. The prop chai n has the added benefit of being a visible deterrent so they won't even try, but rather go to an easier target. > > Bob McC > >> ---------- Original Message ---------- >> From: donjohnston <don@velocity-xl.com> >> Date: August 6, 2017 at 4:35 PM >> >> om> >> >> So with the understanding that most aircraft security is only good enough to keep honest folks from running off with your airplane... >> >> But does anyone have any ideas on ways to prevent the engine from startin g? Other that the big chain prop locks. >> >> Early on, I was considering second, hidden mag switches. But I'm wonderin g if there's an alternative. >> >> Note: I do not have a keyed ignition switch. Just a toggle switch for eac h mag and a push button starter switch. >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=471552#471552 >> >> >> > > ________________________________________________________________________________
Date: Aug 07, 2017
I have a keyed master, and the starter button won't work without the master. But I guess the aircraft could be hand propped as the mags are both on toggle switches. John Keen 0412 141 833 > On 7 Aug 2017, at 06:35, donjohnston <don@velocity-xl.com> wrote: > > > So with the understanding that most aircraft security is only good enough to keep honest folks from running off with your airplane... > > But does anyone have any ideas on ways to prevent the engine from starting? Other that the big chain prop locks. > > Early on, I was considering second, hidden mag switches. But I'm wondering if there's an alternative. > > Note: I do not have a keyed ignition switch. Just a toggle switch for each mag and a push button starter switch. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471552#471552 > > > > > > > > > ________________________________________________________________________________
Date: Aug 06, 2017
Not an option for me as I have a 24v electrical system. rnewman(at)tcwtech.com wrote: > You may want to check out a product we sell called SmartStart. It allows for a hidden arming switch that when pressed gives you 1 minute to crank the engine. It works with the standard start contactor, can interface to a push button switch or standard key switch. It also listens to interlock switches that must be closed before arming can occur > > Www.tcwtech.com > > > Bob Newman > TCW Technologies, LLC > 610-928-3420 > Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471564#471564 ________________________________________________________________________________
Date: Aug 06, 2017
With the understanding that additional layers add complexity and reduce reliability, you could wire your master switch in series with another ubiquitous toggle far from the master, and label it something like "Safety/Normal". Speaking of extra switches, I had a customer with several planes who put a landing gear switch in his Glasair FT. Just so he didn't get out of the habit! --Dave On Sun, Aug 6, 2017 at 1:35 PM, donjohnston <don@velocity-xl.com> wrote: > don@velocity-xl.com> > > So with the understanding that most aircraft security is only good enough > to keep honest folks from running off with your airplane... > > But does anyone have any ideas on ways to prevent the engine from > starting? Other that the big chain prop locks. > > Early on, I was considering second, hidden mag switches. But I'm > wondering if there's an alternative. > > Note: I do not have a keyed ignition switch. Just a toggle switch for > each mag and a push button starter switch. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471552#471552 > > ________________________________________________________________________________
Date: Aug 06, 2017
Joe, See the Amps table on my electrical system overview diagram . It comes to 21.57 amps typical, 31.49 amps maximum. Cheers, -- Art Z. On Sun, Aug 6, 2017 at 3:13 PM, user9253 wrote: > > With the pitot heater shut off, I would expect the continuous current draw > to be closer to 10 amps. Have you actually measured 21 amps? Regardless, > the backup alternator should run everything. > > -------- > Joe Gores -- https://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
Date: Aug 06, 2017
Hi Art; For what it's worth, I have two 20 amp, internally regulated, permanent magnet alternators and one battery. Caution: System is untried at this time. Cheers! Stu. ----- Original Message ----- From: "Art Zemon" <art(at)zemon.name> Sent: Sunday, August 6, 2017 10:41:33 AM Subject: AeroElectric-List: Backup Alternator / Backup Battery Sanity Check Folks, Can you give me a sanity check? I am building a Bede BD-4C with an MGL EFIS. This is largely a mechanical airplane so manual trim, no gear motors, manual flaps, etc. Between the low current consumption of the EFIS and using LED lights, a backup alternator will run everything in the airplane except the pitot heater; the typical current draw is 21.57 amps and maximum is 31.49 amps. (Pitot heat adds 10 amps.) With that in mind, I plan on including a 30 amp backup alternator and no backup battery. I figure: * If the engine is turning, I will certainly have one of the two alternators operable. * If the engine is not turning, the main battery ought to keep the electrons flowing until I reach the ground. Am I missing anything? -- Art Z. -- https://CheerfulCurmudgeon.com/ "If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel ________________________________________________________________________________
Date: Aug 06, 2017
Hi Don; How about a second switch (toggle or rocker) in series with your start button, on the panel or elsewhere, whose function is not called out? Cheers! Stu. PS: I only have a start button, but my canopy locks. ----- Original Message ----- From: "donjohnston" <don@velocity-xl.com> Sent: Sunday, August 6, 2017 1:35:09 PM Subject: AeroElectric-List: Aircraft theft prevention? So with the understanding that most aircraft security is only good enough to keep honest folks from running off with your airplane... But does anyone have any ideas on ways to prevent the engine from starting? Other that the big chain prop locks. Early on, I was considering second, hidden mag switches. But I'm wondering if there's an alternative. Note: I do not have a keyed ignition switch. Just a toggle switch for each mag and a push button starter switch. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471552#471552 ________________________________________________________________________________
Date: Aug 06, 2017
Art, I see what you mean. It will be interesting to see how measured current compares to calculated current. You have nice neat documentation. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471573#471573 ________________________________________________________________________________
Date: Aug 06, 2017
Subject: Standby Alternator Wiring
Folks (esp. Bob), I want to include a B&C standby alternator system bundle <http://www.bandc.aero/alternator20ampshomebuilt1-1-1.aspx> in my plane. I am looking at figure Z-12, which calls for a B&C SB-1 controller. Is the SB1B-14 in the current bundle a straight replacement? Does the bundle come with a diagram to update/replace Z-12? If I understand Z-12 correctly, I need a switch for the standby alternator on/off. I do not see a switch for the main alternator on/off. What would happen if I were to turn on the standby alternator while the main alternator is operating? Would anything be damaged? Thanks, -- Art Z. -- https://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
Subject: Re: Standby Alternator Wiring
Date: Aug 07, 2017
The main alternator is switched via one half of the master switch. Nothing will be damaged if both alternators are both turned on, although voltage regulation might not be stable. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471583#471583 ________________________________________________________________________________
Subject: Bob Nuckolls misquoted
Date: Aug 07, 2017
Bob, have you read the September 2017 Kitplanes Magazine? The author of "Electrical, Part 3" has quoted you out of context to make it seem that you recommend two aircraft batteries. The author also stated that avionics need protection from power surges that occur during engine starting. And he wrote that hall effect sensors contain an induction coil. Do they? -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471584#471584 ________________________________________________________________________________
Date: Aug 07, 2017
I use a throttle lock when travelling. One can start the plane and taxi, but that's it. It is a heavy thing to carry around but hey, I figure the thieves would see that, and just move on. Marty Subject: AeroElectric-List: Aircraft theft prevention? From: "donjohnston" <don@velocity-xl.com> So with the understanding that most aircraft security is only good enough to keep honest folks from running off with your airplane... But does anyone have any ideas on ways to prevent the engine from starting? Other that the big chain prop locks. Early on, I was considering second, hidden mag switches. But I'm wondering if there's an alternative. Note: I do not have a keyed ignition switch. Just a toggle switch for each mag and a push button starter switch. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471552#4715 <http://forums.matronics.com/viewtopic.php?p=471552#471552> ________________________________________________________________________________
From: Christopher Cee Stone <rv8iator(at)gmail.com>
Date: Aug 07, 2017
Hydraulic Crimp tool... I have used this tool with great results on AWG 2 and smaller cable. https://www.harborfreight.com/catalogsearch/result/index/?dir=asc&order=EAScore%2Cf%2CEAFeatured+Weight%2Cf%2CSale+Rank%2Cf&q=crimp+tool Chris Stone RV-8 On Sat, Aug 5, 2017 at 8:33 PM, wesk wrote: > > Before you decide on which wisdom (solder vs crimp terminals) to follow, > try to do your own research. Most industry standards and federal guidance > lean towards crimp connections for vibration prone applications in > aircraft. They seem to show a preference for solder joints only on the > lighter weight terminals found on circuit boards and etc. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471538#471538 > > ________________________________________________________________________________
Date: Aug 07, 2017
I think that if you do your research, that preference for crimps has more to do with unskilled labor, quick training time, and quicker operations in a production environment. Crimping is without a doubt, much faster than solder, even if you have the skillset to do good soldering. Problem is, purchasing expensive tools for basically 'one-off' jobs. If you've got access to a press, or even a good shop vice, you could do this... Virus-free. www.avast.com <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> On Mon, Aug 7, 2017 at 10:08 AM, Christopher Cee Stone wrote: > Hydraulic Crimp tool... I have used this tool with great results on AWG 2 > and smaller cable. > > https://www.harborfreight.com/catalogsearch/result/index/? > dir=asc&order=EAScore%2Cf%2CEAFeatured+Weight%2Cf% > 2CSale+Rank%2Cf&q=crimp+tool > > Chris Stone > RV-8 > > On Sat, Aug 5, 2017 at 8:33 PM, wesk wrote: > >> >> Before you decide on which wisdom (solder vs crimp terminals) to follow, >> try to do your own research. Most industry standards and federal guidance >> lean towards crimp connections for vibration prone applications in >> aircraft. They seem to show a preference for solder joints only on the >> lighter weight terminals found on circuit boards and etc. >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=471538#471538 >> >> >> >> >> >> >> =================================== >> - >> Electric-List" target="_blank" rel="noreferrer">http://www.matronics.com/ >> Navigator?AeroElectric-List >> =================================== >> FORUMS - >> _blank" rel="noreferrer">http://forums.matronics.com >> =================================== >> WIKI - >> lank" rel="noreferrer">http://wiki.matronics.com >> =================================== >> b Site - >> -Matt Dralle, List Admin. >> target="_blank" rel="noreferrer">http://www.matronics.com/contribution >> =================================== >> >> >> >> > ________________________________________________________________________________
Date: Aug 07, 2017
I put a 5 amp breaker hidden under the throttle on my CH701. I call it my "air show breaker". I was sitting in the ramp one day when some idiot let his kid sit in an airplane by himself. Kid figured out how to hit the starter and make the fan turn...... Could have been ugly. My 701 has dual electronic ignition, no mags but as long as they cant find the CB for the starter I am air show capable.... Paul -------- I'd rather be flying than building but there's an end to the means here (I hope). Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471600#471600 ________________________________________________________________________________
Subject: Re: Bob Nuckolls misquoted
Date: Aug 07, 2017
Hi Joe, Sad to say, Kitplanes is neither a scientific journal with peer review, nor a major newspaper with several levels of review and fact checking. Favorite flying magazine of mine, though it may be, it is just a popular press magazine, not a technical journal. It is heavily dependent on advertisers and probably has only one or two people on staff including their excellent editor who actually knows anything in detail about technological issues. They are, however, pretty good about printing letters to the Editor with corrections. -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471602#471602 ________________________________________________________________________________
Date: Aug 07, 2017
> , nor a major newspaper with several levels of review and fact checking. Not that fact checking ever matters nowadays... just say'in... Thanks, Bill Hunter On Aug 7, 2017 4:37 PM, "rampil" wrote: > > Hi Joe, > > Sad to say, Kitplanes is neither a scientific journal with peer review, > nor a major newspaper with several levels of review and fact checking. > Favorite flying magazine of mine, though it may be, it is just a popular > press magazine, not a technical journal. It is heavily dependent on > advertisers and probably has only one or two people on staff including > their excellent editor who actually knows anything in detail about > technological issues. > > They are, however, pretty good about printing letters to the Editor with > corrections. > > -------- > Ira N224XS > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471602#471602 > > ________________________________________________________________________________
Subject: Questions for the alternator mavens
Date: Aug 08, 2017
Hi I am looking at options for my RV10 electrical system. I am keen on preventing OV issues so I'd like to make sure I do this right. Here is my plan (for now): 1. I plan to install an externally regulated Nippon Denso alternator (60A) as a primary alternator. 2. I plan to install a gear driven (B&C) back up alternator 3. I plan to use a VP-X Pro to monitor line voltages and provide OV protection. The VP-X would also ensure only one alternator was online at a time. My questions is: Is there any reason I can't use automotive solid state voltage regulators rather than *aviation* ones sold by ACS? The *aviation* regulators are 4-10 times the cost of automotive regulators. Cheers Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471618#471618 ________________________________________________________________________________
Date: Aug 08, 2017
At 06:29 AM 8/7/2017, you wrote: > >Bob, have you read the September 2017 Kitplanes Magazine? The >author of "Electrical, Part 3" has quoted you out of context to make >it seem that you recommend two aircraft batteries. Hmmmm . . . my first design goal is to figure the elegant architecture for meeting anticipated missions with the minimum of hardware and system complexity. Figure Z13/8 is probably suited to task for 98% of OBAM aircraft flying . . . and it features only one battery. There are considered instances where a second battery is useful but I'd sure sift the sands of simpler options before making that leap. Batteries are a commodity . . . a fragile one at that. They're like house plants . . . treat them nicely within limits of their requirements and they'll serve you well. Bumping those limits is deleterious if not fatal to battery performance. We use ONE battery because it serves a vital role . . . but adding a second one begs a careful evaluation for return on investment and sweetening the FMEA. >The author also stated that avionics need protection from power >surges that occur during engine starting. This individual obviously has not exploited the original material on my website. Here's a piece published back in 1996 http://tinyurl.com/q5uzw78 I published a similar article in Sport Aviation about that time frame. > And he wrote that hall effect sensors contain an induction coil. Do they? Some do . . . the more accurate, 'closed loop' sensors do feature nulling magnets wound onto the gapped core. The sensor assembly includes electronics configured to drive the nulling current such that force in the gap is maintained at net zero flux. http://tinyurl.com/yb8rqoo7 This same article speaks to open-loop sensors. While not as accurate and free of drift they are getting better. I keeps some around quick-n-dirty look-see on some unknown current . . . or when I want a really small sensor mounted right onto a circuit board. Emacs! Here's an open loop device that will convert a 200A current flow into a +/-2.5v signal. A closed loop doesn't have to be huge . . . Emacs! This little board mounted device is one of my favorites . . . VERY linear and low temperature drift. Bottom line is that they come in both flavors. The alternator output sensor on the B&C standby alternator regulator is an open-loop device. I used to do some writing for Kit Planes but I've become somewhat disenchanted with their editorial policy for peer review. Bailed out of Sport Aviation way back when for the same reason. See: http://tinyurl.com/5hug5 Kettering opined on several occasions: "There is a great difference between knowing and understanding: you can know a lot about something and not really understand it." In the context of this missive, I would add: "If you understand something, you OWN the knowledge. Ergo you can also explain it. When you cite the work of others as germane to your assertions and conclusions, you're kinda obligated to at least provide a hyperlink to a source authored by that individual. The author of the Kit Planes article would have done himself and his readers a favor by offing links to anything I have published either here on the List, my website or print articles. This isn't a contest, it's about doing the best we know how to do today and making it better tomorrow. Speaking of those lead brick house plants, some of my farmer/rancher friends are spending kilobux on replacement of batteries that died before their time . . . and you thought the last battery you put in your car was rather $breathtaking$. I am pleased to see that our old friends at Deltran have a solar version of the Battery Tender series of charger/maintainers. I'm about to try a pair of them out on a 24v John Deere road grader. Bob . . . ________________________________________________________________________________
Date: Aug 08, 2017
At 02:41 PM 8/7/2017, you wrote: > >I put a 5 amp breaker hidden under the throttle on my CH701. I call >it my "air show breaker". I was sitting in the ramp one day when >some idiot let his kid sit in an airplane by himself. Kid figured >out how to hit the starter and make the fan turn...... the master switch was on too? Bob . . . ________________________________________________________________________________
Date: Aug 08, 2017
At 11:04 AM 8/7/2017, you wrote: >I think that if you do your research, that preference for crimps has >more to do with unskilled labor, quick training time, and quicker >operations in a production environment. Crimping is without a doubt, >much faster than solder, even if you have the skillset to do good >soldering. Problem is, purchasing expensive tools for basically >'one-off' jobs. If you've got access to a press, or even a good shop >vice, you could do this... I bought one of these Harbor Freight tools a few years back . . . lots of capability for the bux. Took it back a couple weeks later . . . Emacs! It seems that the designers for this tool had a poor knowledge of the die openings appropriate to installation of terminals on wire. Emacs! As you can see in this excerpt, the die set is labeled "0 AWG" . . . when in fact, the hex opening in the closed jaws MIGHT just admit the stranding on 2AWG wire and it's certainly way too small to accommodate the terminal appropriate to a 0AWG wire. I took some wire and terminals along with me to show the manager . . . he didn't quibble about giving me store credit for the return. Sadly, this latest illustration pulled from the website suggest that nothing has been 'fixed' with the sizing of this products die-sets. While this tool has the mechanical 'oomph' needed to apply large terminals to fat wires, the die-sets suggest capabilities not realized. In the years since this article was published http://tinyurl.com/ct36xen I have installed dozens of terminals on fat wires. Although I do have access to some pretty capable crimp tools, I've found that the convenience and economics of this technique are very attractive. Bob . . . ________________________________________________________________________________
Date: Aug 08, 2017
At 05:56 AM 8/7/2017, you wrote: > >The main alternator is switched via one half of the master switch. >Nothing will be damaged if both alternators are both turned on, >although voltage regulation might not be stable. > >-------- >Joe Gores Running two alternators simultaneously is generally not a big deal. The alternator with the higher set-point will 'hog' the load until it's capacity is exceeded. The bus voltage sags and the alternator with the lower set point picks up the difference. Figure Z-12 shows how a second alternator is added to a single-alternator design. This is done on hundreds of TC aircraft where the B&C standby alternator is offered as an option. The standby alternator is set approx 1.0 volt below normal bus voltage (0.5v in a 14v system) In flight, BOTH alternator field switches are ON. The standby alternator regulator 'sees' what it perceives is a too-high bus voltage and completely relaxes . . . s/b alternator field voltage is reduced to near zero. If the main alternator shuts down, bus voltage sags, s/b regulator 'wakes up' and the second alternator goes to work. The only thing 'magic' about the s/b alternator is the current sensor system that annunciates 's/b alternator active' and assists in load shedding to some value at or below the alternator's rated output. But even when the alternators are on line together and closely adjusted for set point, they're well behaved. Bob . . . ________________________________________________________________________________
Date: Aug 08, 2017
Bob, While I totally agree with you regarding the indicated sizing of the dies, I made a few test crimps using the dies supplied and was able to find the a ppropriate die for each of the fat wires and connectors=C2-I was using. =C2- Did not require the 0AWG in my application so the die sets were suff icient and the crimps have proven to be more than adequate, especially for the limited amount of crimps I needed. Bob Reed From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> To: aeroelectric-list(at)matronics.com Sent: Tuesday, August 8, 2017 10:55 AM Subject: Re: AeroElectric-List: Re: 2 AWG crimping tool At 11:04 AM 8/7/2017, you wrote: I think that if you do yourresearch, that preference for crimps has more to do with unskilled labor,quick training time, and quicker operations in a p roduction environment.Crimping is without a doubt, much faster than solder, even if you havethe skillset to do good soldering. Problem is, purchasing expensive toolsfor basically 'one-off' jobs. If you've got access to a pres s, or even agood shop vice, you could do this... =C2- I bought one of these Harbor Freight =C2- tools a few years back . . . lots of =C2- capability for the bux. Took it back =C2- a couple weeks later . . . =C2- It seems that the designers for this =C2- tool had a poor knowledge of the die =C2- openings appropriate to installation =C2- of terminals on wire. =C2-=C2- As you can see in this excerpt, the dieset =C2- is labeled "0 AWG" . . . when in fact, the =C2- hex opening in the closed jaws MIGHT just admit =C2- the stranding on 2AWG wire and it's certainly =C2- way too small to accommodate the terminal =C2- appropriate to a 0AWG wire. =C2- I took some wire and terminals along with me =C2- to show the manager . . . he didn't quibble =C2- about giving me store credit for the return. =C2- Sadly, this latest illustration pulled from =C2- the website suggest that nothing has been =C2- 'fixed' with the sizing of this products =C2- die-sets. =C2- While this tool has the mechanical 'oomph' =C2- needed to apply large terminals to fat wires, =C2- the die-sets suggest capabilities not =C2- realized. =C2- In the years since this article was published http://tinyurl.com/ct36xen =C2- I have installed dozens of terminals on fat wires. =C2- Although I do have access to some pretty capable =C2- crimp tools, I've found that the convenience =C2- and economics of this technique are very attractive. =C2- =C2- Bob . . . /9j/4AAQSkZJRgABAQAAAQABAAD/2wBDAAEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEB AQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQH/2wBDAQEBAQEBAQEBAQEBAQEBAQEBAQEB AQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQH/wAARCAGQAZADASIA AhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAAAgEDAwIEAwUFBAQA AAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3 ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWm p6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6/8QAHwEA AwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSEx BhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElK U1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3 uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD+/iii igAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKK ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAo oooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACii igAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKK ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAo oooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACii igAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKK ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAo oooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACii igAprMqKzMQFUFmJ6AAEkk9gADknA96/Mj9s3/gqr+zf+yFFqHh2TVE+KHxXt45I1+H/AIPv7WSP SLvyt0Y8X+IB59hoKhivmWEUd/rYXk6ZHGyyj+WL9qL/AIK0/tZ/tPXd/pcni+X4feArqaZLfwL8 PpLrRNMezkaSOK31jUY5TrHiCUxOEm/tK+ksnY74rGAbUXuw+X4jEJSSVOm2vfnvJdXCC96SW17J X2bPNxWaYfDXir1qi+xT2T7Sm/di11WslrdaM/s4+J37aP7KnwcN3F8RPjx8OdBvbEAXOlR6/b6z rMchBKwHSNC/tLURcNjiE2wdQQzhUIavkfVP+Czv7B2mXL2yfEHxPqhR9nmab4H1loz1IZBeiymk UqNwKREleQvav4vfDXw58b+MrOTWtTlksNJJJbVtTZ1t7qQkqyWsbMZbyUSZDtCPJVseZNkgV8mf GfWLjS9fn8BfD/xvcXHiGxnt/wDhJ9X0nTNOg0PwjADvktL3VbttSu9W8QXSAfZdH002IssiXUWj A8o+v/YVOFBVp1Z66JWUHOWnuwg4uUpPok27dLe8vHWfV6taNKnSpK7TlZTnyRdtZzvGKtd3012j dn+iv8KP+CmX7Fnxi1S30Pw18Z9I0fWbx4orPTvG1nqHg9rqWZ/Ljhgvdat7fSnmZyFWE34lcsNi MMkfeEUsc8aTQuksUqLJFLGyvHLG6hkkjdCyvG6kMjqSrKQVJBBr/Keh8RapamGQavrjSRhRHdyX 92sk8kW2NpWaOQRNKZMPMYlKqSylFGBX9bP/AAb+ftofFP4ma343/Zo+IXiW88VeH/C/gV/G3gK7 1eVrrU9Histb03StU0WG6lLSnTZI9VguobYuYYJImaGOFpJvN8rGYH6tD2kJc0U4qUW4ylFycYpv lsmuaST+Vr309vAYx4ycqMkoVVCpONtY1I0oOpNL3nytU4ymruz5WtHZP+oyiiivPO8KKKKACiii gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAKKKKACisXxD4j8P8AhLRtQ8ReKdb0nw5oGk28l3qmta5qFppel6fbRKWknvL++lgt reJFGS8sqjoBkkCvwS/bL/4Lp/DH4ax6t4M/ZksLb4k+LYTPZv8AEDWYZ7fwNplwjSQvLomm7odS 8UzREBop5/7N0gtskR9RgO1t6GGrYiXLSg5bXltGN3b3pPRb7bvomc2IxeHwseatUUW/hgvenL/D Bav10S6tH7WfGX47fCX9n7wdeeO/i/450PwT4dtUk8ufVLofbdTuI0L/AGDRdLgEuo6zqMgGEs9O tribnc6pGGdf5VP26P8AguL8TPilJrnw/wD2Z0vvhb8O50n0248WSBU+I/ia1Ztkksd3C7w+EbG5 RWQWmlyy6q0UjibVoxI9tH+Onx0/aV+M37R/jC88Z/Fbxnr/AIz1m6d1hbU7si20+AtlLDTNMgEe n6Rp8WB5Vjp1tbW6n5vLLl3aj8MPgx4s+I1yZYbMWWkwfNdazesYLC2XgkCV8LcSnORFCWy2N7Ku M/QYPKqdNqVS1apo9YydOmr7pP3ZXbtea8+U+Yx2b1a14Qf1ej1tK1WaXSc425U735KbfZuSujye O21/xlqRaT7XqN/fTnJbzrmaeedydxBDtPI0rFi2SxJLEkscfW/gv4FeFfAWkN43+L+o22madZRx z/2ZdXKQIxZw0Md5KxwZbhyIo7SFXklkYRRpNMfKb0u2m8BfCZv+EV+HujH4hfEye3DTusULppiS I4F/qdy6PaeH9JVgWjnvAJrwqEsbfUJQqn5c+M37QHgb4RTf258SNTX4rfGotNdeF/h3pM4k0Hwj Kw2x6hIlwZLHQ0iDlbvxRrDS6xJGjR6VBbW8h0+voY0KNKLq15U4qKTc6jtGPLy6JX0loko/HJtW j7yPBdWrWahRjJ8zXKor35LT4YtJw0+23yq71On/AGivjBrVv8P7nX3nuPhR4LIj0LwlD9hjt/Hf iu8vFEVlpvhHQLwY0Dzoy80+v67C97pNhFNqX9iQbYJB+YfhfSQsK6do1pJb2rTzXUzyySXE0l1d P5k95qF5KWmvby5kkLz3ErNNM+XJGdobr/iDx78d/Ez/ABC+JmtXE160U1v4Z0bTleDw74UsJ2DL FoVjcbmupEIjZ9Uvk82/mUTmOS3EKL98/sTfshfEz9q74o+HPg78JtKa7u5Y47nxB4l1Xzn0Xwj4 Zt5YotT8V+KtQjjZo7O3DhIoY8Xmsam8GmabE93OFj4cRiYV0pN+yw9KMmqk2oykm0nLlu3G99Ip c8uX3rtpLvw2GnS/dqPtsRVlD93B80Y6P3XPXncbuVSUvdTeiUYtnzjo/gea8ltLSK0u9U1C+lSK 2tbWKWW4uJ5yFjgtbW3WSa5nkbCCOJJZJCRsB4A/sQ/4IYf8E7fid+zuPFv7Svxn0K88EeIPHvhK Lwf8P/h5qqSQ6/p3he61Kx1fVvE/iexlIl0a91abS9MtNH0e6C6hHp8d3e6hb2hu7WI/pr+xv/wT e/Zw/Y10Kwk8JeGLPxj8TxBH/bPxd8WadaXniq7u9g83/hHopPtNt4N0oSGT7Np+iMlyYWVNT1LU 5VE9ff8AXzWOzCniKfsKNLlpKUW6lTlc5qDjKNklaKclzNpqTfY+oy/L6uGn7evV5qzjOMYQvyU1 Ui4ySk9ZNwbhdJJJtK9woooryj1wooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigA ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACivnv42ftWfs8/s76fLffGD4r+EfB0yRPL DolzqSX3ie9CBflsfDGl/bNdumYsqq0dj5SlsySooZh+HX7Q3/BwB4f06S/0T9mv4WSa66pcQQeN fiTNJZWpkOY4ruw8IaPO11LEB+/hOq61ZSE7FuNNCh0O9HDV67tTptr+aVow/wDApWT9E2/I5K+O wuH/AItaCl/InzT6bxV2t/tWR/RZ4l8UeG/BujX3iPxdr+j+GNA0yFrjUNa17UrPSdLsoUVmaS5v r6aC2iGFOA0gZiMKCeK/ET9q3/gub8DPhWNR8M/s/wCkyfGbxfEssC+JLr7Vo/w7064UsgmSdki1 rxGI2AZUsYdP0+4T5otYZSCf5kP2iP2xv2iP2m9ck1j4vfEPW9fjZ99loKTPpvhnSlAKrHpHhrT/ ACNJsNqswaSC1FzISzXFxO7Fz836N4a8TeKb9bHRdJv9RnduRbwSS7VxzJO+Fgt4wBuMs8saLyQ2 K9rC5NFuLrt1ZX/hwUlHTV3a1lbVpXXezPBxOeTm3GgvY0+tSTi6jjprq+WGt00ud6O0k9vp79pn 9uP9pH9q3WZr/wCLHxC1O80mO4lfS/CWmH+yfB+jLucAad4esnWyEqJiNdRvPtmpTKD5t7LuJr5h 8OeDfEfjDUY7HQ9OvNUu5258mMyMi8lpZJHKxW8XILSzusYXq2cAfROjfAfw34UshrvxT8T2VmkB WZ9H0+6iYoqqz+XdapMy28MknAK2sNw5OQs29SB6BqHxK0/wz4We50Gx8OfCn4cWyBrzxx43n/sK 2vIIQS8+k2FzLBrniW5eM74ppDYW1wMC3uLlT5Z+ioYNRWsI04RXwU0kopWu5WskrptuTV0r3vY+ crYxzm3Fyq1JXvKV2nLpzSfxaW0Sk1tGyVjndF+EPw++GdmniL4qaxaX9/GUNt4esZAbMXTH91a3 E6N9o1G7aRtsdjYwsZWGxPtG4Ar8TPiyNH8NRa38QfFOn/s//Ce2Ro9Js2WKPx94pkjjykOheHFj nlsbmQForZprS+1qECRhpulTyJep8BfEH9trTNGvL+9+CXh6TxrrrJNayfGz4pRyJpWk5EsSv4D8 DRCFY4iZH2SzjT01DEf286iio9fFF3pHxK+K3iKbxn4w1bV9c16+LGfxV4ymkmuIYDMkptvDnh1W SHQ9NZFPkW9vFYwFi0ZhdATISxlGguShTVeo76xTVNbLmnUUr1NElanypv4qii2npTwVas1PEzVC Caau487vZvkp7Quus4ykl9hrWP0t8Uf22de1ayvPAnwD0a9+FHge9uJEvPEd6De/FDxjJIqRyX7T zi7bQ5r9EIkvtSk1PX3hdMyQSR7Y/G/CHgAzxJq3iCKe4v5p2v5Y7+5l1Ge4uHYmO71e7uGebUb3 OGHns6pKFk25VQvZ+Ffh/pOh4kRXvtQm2tcajdRx+czqCCVCqsdrGpBHlxbVBwWLt8zfun+wN/wR m+Pn7XTaV4+8bpefBX4GXAW5i8Y+ItMkbxJ4vtVbAHgDwpdm2lvYJG4XxJrTWOgoqSPZHWJYTanz q1ay9vjK0VCPwUleMFezcYUo6OTVm3GLbvzSk9WvRoUW37DBUm27OdT7T29+c52dur+FLRRjbQ/N n9mL9l34sftVfFPw38IvhD4buNc8S63Ij3N06yQaJ4b0SIomo+JvFGphWj0vQtKjcvLcynz7qXyr Cxhu9Qnt7Wb/AEGP2E/2Hfhd+wt8HLD4c+B4ItW8V6olpqPxJ+IVzapDrHjfxJFAY2mbDSPYeH9N 8ya28OaDHK0Gm2jyTSm41O81C9ue3/ZT/Y9+Bf7G3w9i+H3wV8KRaTHcGO48TeKtSaLUPGfjXU41 K/2l4n14wxTXRj3OLDS7ZLXRdIjkki0vT7RJJd/1FXzuOx0sU1CC9nQhtBbzktpztpe+qj9l7N7v 6fAYGOEi5TftK87Oc+kVb4ILsnduTXM+9kkFFFFeeegFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAF FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUZHrQAUVia34h0nw7Y3Goazf21lb20Et wwkkXz5VhQuUtrbd511NIFKRQQI80shWONC7AH8Tf2j/APguX8Ivgzq2r+C/CvwW+LOvePtNjiL6 Z8RtFuPhPZQLOQYr17TWre98S3mnTR5e0vbbRY7K+4Fve7QXrjhmOX1MwhlEcfgv7VqUZ4mGWvF4 dY+WHpuKqYiOEdRYh0KbnFTqqn7OHMuaSururGdHDvF1aVaOFU1B4j2VR0VNq6i6kYuCk10cr97M /c2vMviX8Z/hN8G9JfXPip8RfB/gHTEUus3ibXbDTJbjgnbZWc8wvb+U7W2w2VvcStghUJFfxzfH D/gtb+2R8WPtlh4a8SaT8GvD9wJkWx+HenLa6uLeXKIk3irWH1PXDMiHb9o0ybSNzN5iRxuVEf5e +KviD4s8c6vPrni7xV4i8X63ftuuNU13VdQ1jUrh3GR5t5qM9zdSHoFQyEAhFCgAZ+hoZVVqK9Sc Ybe7H35dG+0dNr3evpY8HEZ3ThdUaUp2+3UajH1UU3KSas1rFNPdH9bfx8/4Lufs2/D1b7S/g74Z 8UfGLXoVdLfUriNvBng4S5IWU3epwT+ILyEBd2ItCtY5gQI7pRuZPxE/aA/4LAftk/HEX2n6d42j +E3hW8E0X/CP/DCGXw7K1u5z5d14nee68UXTCPakhg1WzglVWH2Vd5UfnNpfw68ca+Y5LfRbi3tn USC9vlWxthHwpbzLoxFuo5RWJyNoIzXUy+BvAXhLY/xD8dWcFzuQLpFhNCt5cl2VEjt45g1/duzk qosdLleQf6sk4Ne3hsoow/5dXldWqV2mk9Ps+6mt7e69+uy8LE5xiK14uq7fyULrorp295ro3KVt 7M8u1jxHq/iG/n1HWNU1PXNUvpXmub3UL65vry7llYyNJJdXLyzzzSMWJeWR3diCXLNuPR6B8MfH XiTy5IdNl0uwlIK3moMNOttoK8q83+kSuFyxEEEpb8BXZ678QvCPw300atZeFdB8Cacwnjt/Gfxh 1a38DWTNAu5JLHTdWhv/AB1qnmqGkh/srwrDDIi71uY1ANfHXjz9tzQ9Ueax0PVPHXxcvJHcpYeF bW9+EXw7KOmxrabXHk1P4la7GATJE9nd+G0vU+VoYlcJXoShhqLTq1Y+87qC91NLZcqXtJeXJFyb va1teD9/Xt7GDsnq5RcktrttTjCK095zlFqz12PtW38F/CvwRe29v4t8RT+KPEs7lrPwpoi3t1f3 9wq+aUh0bSkvPEN6jJ1bybWBvvSlY60PHvxx074X6Ix8S6p4O+BHhoJKbeDxE8eqeN9STyUkhbR/ hx4akn1K7u3dtirq95bTiQfvbZ+UP5dTfEv9pHxPDLZaFeaJ8EfCl/Gq3GifDnS00HUL2PGxX1zx NM994213UETaJbzUdUhEuMiX5wayLD4R6EtxLq3iCW98U61clZbzUdduZ7+5uZ1B/ezyTzPLKHLE lZ57tCjuNnzYpxxVk40KHK3ypTmvZ0+lnd+/NPVX/d27a6EsJFtfWKyk1/y7p+/rppf3acW+t3Us /S79k8S/tr6hr2pzRfAv4bahr+sxybIfit8azBqmoWMjtI6Xnhv4eacbfw9oKbW/0Z9UvbO6RCv2 63nJLHxLWPDfjbx7q6eJfi74013xx4ill81pdXvvtdvpsTbd1rpVikdto2jWgQskdno2nWyJGSPt c7fvW9BWzs9PhjhtI4baGEfuoraNIkRANhEUa7ViB3EgRqoA3YVQVrrvA3w/8c/E3xNpPg7wD4Y8 QeLvE+vXiWWkeH/DekXms61qdzOQkUVpp+nw3FzcszkB2WMxxrlpXjRTjmlKpVb+sVOaMWpODSp0 YJpN2grwuk9alVt23erOunGnTaVCmqWy5tZVpO609o9Uk9eWnypPVLc8803w3oenXaXCW/nywRmG GSSPzREo2gx26n93EAApL7fObYpklcrkfV37Of7KHx0/aq8cW/gH4J/D7XvF2tSmOS/mhhW10bw/ YTSpH/a3ijxDdGLStB0xTIubnULiM3JcQ2cd3cMsB/ef9iL/AIN7vG3iVdH8cfti6/N4C8OMsN/F 8I/CN/a3fjzUhJGJUi8T+IkF5o3hGKTzImnstKGs64vlz2ksuiXIWZf6n/g38DPhH+z54Msfh98G fAPh34e+ErABl0zQLIQyX1xgq2oa1qUzT6rr2qSA4m1TWb2+1CVQqvcFERV8zFZrRoqVPDJVJ6pt JKjF6Waas52tfRWd0m7I9fDZVWrNTrOVGmrNJ61pppd21DZ3veS/lufjz+wX/wAENvgj+zj/AGL8 RPj/AP2R8cfi/bGDULXSbqyaT4X+C9SjZZI307R7+MS+MdTtmUbNX8SW8enxuztZeH4Joob5v3bj jSKNIo1VI41VERFVFREAVVVECqqqoCqqqFVQAoAAFPor56rWq15udWbnJ97WS7RSSUUuiSSPoqNG lQgqdKChFb21cnteUndyk+rbbCiiiszUKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAo oooAKKKKACiiigAooooAKKKKACisTWPEeh+H4Dc61qtjpsQGVN3cJG0hHVYoifOmb0SKN2PYV4Z4 i/aJ0K0UxeGtNu9bnJIW5uVbT7FemGCSI17KMcgeRDnOCwINfn/Gvip4e+HlCVbjDizKMmqKCnDA 1cSq+a4hP4Xhspwqr5jXTdo89PDOnF/FOKTa9nKuHs6zqajlmW4rFRuk60Yezw0G/wCfFVXDDwa3 cZVVLR2TasfRpYDA5yfauT13x34S8Nqx1jXbC0lVSwtfNE144XqEtLfzbhm4wP3YGSMkDmvjHXfi T8Q/FPm/atVbRtPdcG203Om2+0knmZGa9mC5wd87I2ACmCa85ubnRbBWuby7Wdjl2lllSC33ggMW mlkCE5YH/WF2J4Bbiv4+40+nNgqXtcP4e8H18dFc8YZ7xZWeWYFuN0quHyfBzq4/F0paSXtMbgqq XuypRlofpOU+E9eq4PNsxUZSa/2PK6f1mq7292WKqctCnPWzUada26ukz6y1j9onQ4BJHoWi6lqj YPlXN46adalgDyUxcXTJ6qYomOOxryDW/jF8RtfJFrcHRLUqVEGjWwiZgwIJlvrkS3W/BxmGW3A4 bYCa+e9T+JmmWm6PS4FuGKqFkt02xBx13TzrGGUkDDQpPyc5wQTyFx8TNYkJYJaxg4wry3UwGBk4 WJ7RWyM8E4/iXHGf5O4w+lP4t8VOrhMTxxUyrCVnaeC4RwNPJqEIS0dOOZYd1c2ceklWx0rq/PF3 aP13JPCLA4aMatDh6nVnFpqvnFX6zVklb3lhqnLQje1706C1Widm37bPBqt9M1xfzTXVw+N1xfXZ nnPBz+8nlkkwckYJIXjjGMfNv7T37J3w6/ak+Hl34O8dGz0nXLGCSbwR8Q7S1tZ/E/gbWD+9juLC 7aJZ7jQL2UJF4j8LvOthrliz5WHUoLC+tNYfEHV2Yktp5JB+/a3bZ5x/FfsB/sgnByD0px8aa3Mo AvLSAgFg0Ol23mDI4dZJ2n2sBwMZOecjg1+L5dxhmOUZ9guJ8uzbO4cQZfjYY/C5pTxf+308XTnC cKsqspUpVG2mqkKlTkrRlKFVVIzlF/XYrgHG47CVsuxlLL/qVelKjVoTpydP2bio8sYxhVUJR15J QjeErSioySZ/Kx4s+Blr8J/HPif4ceOdO8f+JvHfgrVhpWvaJ4W8PXlxplwkkMV/pOrWGrQwPZ3G geINLuLPWNH1N9Qs1mspkSdbS8gvLW2828bfGjwb8GLW6k1TT/hf8KbuNN9hH468ZWet+Mr35VAk tPBfgeHxj4ildZDjy5tS01nIJ8yIBnH6af8ABZr4Ta54s8A+CPjpofivxVoepeGdZsPh58Q7rw14 gvPDz674M1mS+vPBy60ujTaXcaiNB8VS3umWDG6LWcHi+eMh7UGFf5ytH+HXhPTbubUotDsPt0sj tNqdxAt/qcssu4vNcaneNcX0s7ncWlkl3O3zs+SBX+9vgB4vU/GHwuyLi+OFp4PN06+UcRYaEadO nQzvLnCliZ06FOVWVKljcPPDZlQorEpUqOOpUpVG4Nv+CPEXgatwRxZmGSYqtKthoKjisDUip/vs FiYKVFxnP2abpSVTD1HKi71aM3a0k37fqn7aUni2W2bRrL4tfECTyLiN7TQtNtPgx4Au2lyqNear f3fiT4gXVmdpMcFpquiPgeZIFwIl8sufiF8fdZuLh/DF34O+COn3kJjuj8PdCiu/GUsJLfLqXj/X vt3ia/nIJLXB1RgWAaJUUiuts7Gzj58gAfKPuhCRllDHg8sSABloxnAGWJGsyQqOMBFBLHA4Qg9P ugc4ABOV6noK/aX7Sqk6laTWzhTtSbTjFL3uZzkpJqOstZO21j4W9KDtTop26zanJaKy5bey/wDJ OqVrHgqfBjStVvjr/jDUNZ8ceIZSPtOteMdXvNavbhguzLNdzSFEAJIjjKIJMmQkDB9R0jQNC0ZS LS0trVUUqxtoIYZG4x8xiXceVAJkdjtO3NaDXpDtFFGzp8+1EVmJ5wxLZJzkEZABLEdcrXtXwO/Z l/aB/aX19fD3wN+Enjb4lXgmtor2fwtotxcaDo/2qcWsVx4g8U3X2Twx4ft0mVzLLrOtWIjWKV1D hdtZy+r0Y814xsvflKe7au25SSeq0k22293qja+IrWgnKTfLywjGTSTs1yxjdRsnbVKyV3Zqx47L c26ARxBVKkbQoQt0XJLE4JAODjGc56gmtfw54U8W+O9f0zwr4N8Oa14l8S67dw2Wj+HvDuk3ut67 qt3dTxQQwaZpOl29zqF7I0s0aYt4JvLLjeQrE1/TP+yp/wAG5HiK/GmeJf2vPinbeGbR1juLj4W/ B+eLVtfYS20okste+I+r2J0XS7q1uWj86Hwz4d16OWNXW08RxsUmX+j79nb9j/8AZt/ZT0U6N8B/ hJ4U8CST24t9U8Q21o2p+MteQ+UznX/GesSX/ibVkklhS4Nrdam1hDPlrS0t02ovm184oU040FKr J6NyvGnpZ3u23Lr8MYu/2+i9LC5NiKiTrSVCF7tSSlVa0+wvdhdbqUm9dY9D+UD9kD/g3x+P3xUT R/GP7Smu23wF8IXMtvdv4REVt4h+K9/p0sCz7ZtMilk8PeD7iRmFuU1q91HU7Rw/2vw7GY1il/qt /Zj/AGLv2cP2Q/DUXh/4H/DbRfDl7JZQWeteM7qCPU/HfihoooEluNf8U3UZ1GcXUlulzJptm1jo kE5/0HS7WNVRfqeivDxGNxOJv7WpaN7+zguSC20ajbmtbeV/zPocPgsPhrOnC80re0n70/k3pFeU Ut7BRRRXKdYUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU UUhIAJJwBySegHqfQDue3U0m7av+vN9kurACQOtQXN3bWkL3F1PDbwRAtJNPIkMUagZJeSRlRQPU tXwpqv7anhvxB8QPGfws+Hk2lXHibwXqMemanPcXtrqFw0s0Es0U9vpNpM0tklwsFzJp51gxPqVt bTXdnby26lhxeva14g12Tz/F3iGebdzHb3MxdVyCQINNg2W0PXA2QoxJ5Lc1/IfiL9MXgHhHE4zK eGMuzHjfOMJOdCrVwrjlnDtCvGycaudYuEnXjFtNVMFg8Thq0LSo4qSlFv8AT8p8LM9xcaNbNp08 ko16dOtTo14Sr5jVo1EpQlDBUmnFTTaftasJ03GXtKacHE+vvEXx08EaIGhsLibX7tQcR6Yim0DA E4fUJituQpGG+z/aWB4CkjB8M1z41+PfEReLRoovD1m3y+ZZAy3ZHrJqF0uFznrBDAQBlWJBI8Jv db0fR4vMKQxN/DcatIVeTGCfs2mw+ZcTHjKAwgcAFlrznXvinvDw2avPtwFkuf8ARbRSSQPLsbeR pX28ELcXGxgSGjx8tfxRx79KrxY4u9tQnxHT4PyuspRjlPBtKtg8XOnKzjGvndZ1s3k5Q0lWwU6W DqSc7xjG6P17hvwny6m6dTC5TLMqqcW8dm7jUoxd1eUcNHkwfu78tTmrRsrpbHsF/JFJPJea3qs+ oXhGZXaeS9n4LFvNurhn2LzyWcKoORgcVx2pfEHQ9KyliiPMDtP2ZVvJzgYJa5craW5x1KySlcZK k5FfPOr+MJdRkCXuo/aCctHaebFbwrksCY7KExqAWU4kKO5Y4LHmsaTU8oygqexUYIVerDr8pUfM M9QMgfNgfzPisyxNatVxUKb+sVpSqVcdj6ksZmFec7SnVnVqVKtRVXJ3dVVpKSd3Tjbkf7PlnAlB RpLHYl14wUYfVcNH2GFgk0uSMYqP7tdFyRstpy3fq+sfELWL8t5LJZp0LMy3l0OQVIeZRbRZAGPJ tgRniQthq4K71O4upfNuJprqZ/8AlpcStLJg9dpbIQZACxoECngAYrnzcSSAfOFBHAAyQw3FsZPy luOuQCcDJqIu2chzlfxLZwN3JztO7ocZx1HJrxq6q13zYjEVcQ3LntOXLTvpr7JctOL13jCMm73b u2/usDk2BwMVDC4ejRcUoycIe/ayajKq+acrbWlJrS9tbLVN07F2yFJyAd3BXB6HB2kHknBx0IJ5 pySBmB3EgFiX3KfnGT8xOcgAAAYxg5xuGKyFOW47cnGM/wDAif4TjAAwTjHtU6XOwk45zkfLhcKc 9+vchvmBIORziuRxmmmkkk0302te/otNNd0tjvdJW5Yr3n263tZadd7bfMsvMVnz/CdpOM4bB9R9 05JyAOoI4AxV+Bg2wklgCcbhtIYjDHHIJAGSe2CMAVirIs7bYiZXOV2whpjk45ZYyzZB4I2g98EH jvvD/gfxvr4H9ieDfFerKP8AlpZ+H9SeLv0neBLcB8Yy0gTggMCTXrZPk2bZriI0MqynH5niakoR p0cuwWKx1abk0lGNPC06s5Su/hUea93bQ8zMsZgsBRVTGYvD4SEUvaVMVXo4enGCSV5Tqzgo2fVt Ls+h8mftt+FLLxj+yT+0Bpd9bR3P2L4a654s09XGTFq/gNbfxpplymD8rx3Xh9QpJ+67ZBBIr+Rn z4TKcSAqdwUIQM7ssBtCMRgAlWPy4O1jnmv78Nd/Yv8Ai38T/h/448I31v4a8Ix+L/AnivwxC3iq 9a+RJvEvh3UdHie90/Qkvpvs9s97HJdwtdQymNWSMiTGPkT9mz/g3D/Zk+Hi6VrH7RHxH8dfH7xB aCymutA0lj8L/hy80VqqXVpPY6Je33jTVbRrotJHNJ4w0wTRqiXFjtMiH/Xr6D3D/GvA/BvGOB4z 4ezfh7DZjnmXZtkeFzbCvCYnEyq5fPC5jWWBxEoYvCqMcLgIt4mhR9rzJ01V5Jun/CX0h8ZkvE3E WR4jIcxwOZTwuW4jC5hXwddV6FOUcV7TD03Wp89Kq+WrXdqU58u7cW9f49/CXh/xR4412x8KeCPD ev8AjPxTqlzBZad4d8M6RqHiDXry4vZVhtYbTR9HtL3UpPPl+VZEtWVm3chVYn9gv2df+CEv7dfx y/s7VfiBofhz9nPwddi3nkvfidetc+MXs2uvKuIrT4d+HJL7WIb5LZHnhtfFWp+Dy5MSOyfMV/tU +Df7OvwJ/Z60OPw58EPhH4A+F2lJaW1lMng7wzpekXuowWm42/8AbOrwW/8Aa+uzxl3b7XrN9fXT vI8jzM7sx9mr+1qub15XVKKpptvmb55dNtFFOyavZ6Pvqfg9DI8PT1qzlUenux9yGnTRuTX/AG8v PQ/D79mv/ggf+xb8Ff7O1j4pW/iL9pLxhZmOeS4+IEy6L4BjvYLz7XBPZfDnw9NFZ3UaBYoZbXxf rPi+2nVCxiXzGQftF4Y8J+F/BOhaf4X8G+G9B8JeGdJh+z6V4d8M6Pp2g6FpkG4v5Gn6TpVtaWFn FvLP5dvbxruZmxkknforzalWrVfNVqSm+8nfXyWyv1sketSo0qK5aVOMElb3VZvbd7vbdtsKKKKz NQooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiisDxF4r8L+EbFtT8V+JNA8M6cgZn1D xDrGnaLYoqDdIz3epXFtAqovzOS+FHJwOaEm9ErvsgbS1bsu7N+ivz6+JP8AwVL/AGFfhh5kOpfH nw74qv42kU6b8N7TVviDOWiJV9134Ysb/SIQGG1WudThV2ztJAJH5/8AxI/4L6/DGwFzbfCL4C+P PF04maK01Tx3ruh+B9KkQE4ufsmlf8JfqjrIu1oreVLKVt2yV4HDAbwwuIqW5KM3e1m1yp3ts5WX XuclXH4OjfnxNJNdFJTfeyUOZ38tz+gWiv5E/iZ/wW+/bB8bW0mmeBPD/wAMfhAkjMp1TRtGvPGH iJImBASG78WXV1osb/MB5i+GncPgxsv3q+GfHP7Z37Y3xPtbyx8bftG/FnUtLvQy3Wlad4km8N6V PEx5im0/wvHolrJG4xmF43jIJGAuAOuGV4iTXPKFNO27ct3FfZTV9dubvfY8+pnuFi7U4Vqumj5V BNu1kudqWz3cbeZ/egGVgSpDAHB2kNgjqDjPI7jqKcDn/PT2PvX+fx8Mvjx8aPg7q8eufD74n+N/ C16H3znTfE+pxQXShtzJfWv2p7a6VjzIs8Tl+SSyg4/aX9mz/gtbrGnDTvC3xs1XwX4gu2mWD7dr Ot6Z4X12cqQhjivkKWFxLKT+7+2aaJDL+6lukUFgVssrU480JKqtLpLlknomrNtOze913sTRz2hO SjVo1KSa0nH97G6dnzcqjKKXfllprp1/pior5O+Ev7aPwI+LMNjFaeKbbwtrN8RHb6R4qurGxS8m J2iPS9bgubjQNVZiVCxWupG6JdVNqrnbX1ejrIquhDKwDKykMrKRlWVhkMrAgggkEHgmvPlGUW1J NNO2q0ut7PZ262bPYpV6NeKnRqQqRfWDTt5PrF+Ts/IdRRRUmohIHX1x/n/PPQc1+V3/AAUI/bm0 T4EeBdb0Tw1ewXXiO7tr7TYBHMcXd+ieVcwBoXWWPSNNMi/2zeRsj3c23RbJxLLcyw/oF8a/Euoe DfhH8SPFmlQzT6h4d8G+INYtY7eN5Z1ex024nM8UcYLu9qiPcqqgkmHiv485/Cfir9tr41atY+If EF7oPgXQoW1Hxlr8JWafSvC0N3JFpfhjw4r74W1fWZIpltd/mfZwNS1i4S5eJIJ/4m+mF4s59wlg Mj4A4eqVsrlxhg8djM+4gpudOrg8gwlSnh6+AwFWKvHFZjKpUp4mdJ+2pYWKowSeNUo/vXglwRlu e4jMuJs49nicLw/Ww1PB5Y/fljcyrRnVourSjebo0uRSjePJOam7qVKKl5J/wTv8J/GT4h/tXeL/ ANqi81XXbT4eeH4fEln4w1yaaeytviV4t1+Ew6b4Z09QYLLUpvDM0sXiS7ugjQaA9rp2mQyxT6h5 I/eHUfiRqcwZbA/YlKkeYi7rqYYC5lu5Q0zt/E5XycOxIG0ADzawsPDnhTw3oPgXwNoNp4U8BeE7 Iaf4W8M6crC20+2EssrO24yTTXd1PNNd3tzcSz3NzeXM11czTXU880nwx8T/APgoP+zz8Otd1vwd beIb7xz420HUb3S9X8KeCNOXU77S7rTlX+0LnVdR1G50bw7pmj2Ury2E2tX2u2umzatbXmkWk91q Vnd28H+dTy/iPxAzahhOFsgzbMqmDwWFwOBwGTZbXx2MpYLD1HTpYjHSwVCpUo+1rYjlqVJSjQp+ 1o4Z1ZqFNy/pedbJcgozzHiXFZdhqmIr1MQ5Y/EU6eHo86jJYelGtONKbhCHPPlg7zU5JJJNfetx qt5cM8lxLLJLIAS7yMzsp5O6RzvfJ5GXwduQMYFfE37dPx48Qfs+/APxD4n8GqX8Zatcp4d8PXGF ll0ie+tNQ1TU9Ytopop4Jb7TdH03UZtJtp42hbU2svNVoVaNrv7PP7Ynw4/aQ13xh4Z8G2fiPT9R 8I2Wl6p/xUWnQaeuuaRqKxxT6lpCQ3moBrfS9Tk/se7Mkvk3Vx5d7pE9/plxFdH0n44/B3wx8dvA WoeA/FRmitbqSK8stRt0jN7pGp2iypbajaRyg28jpHPcQzWsyPb3VtcT28ilZAy75Nw/Q4F8QOHc J4nZBj8HgMvzzIMx4lyTHYSpTxtXJalbC4+tGrhJJVKtPF5dO86F4Va9KpUoNwrTcVWO4gWfcM5p V4RzLC1cViMtzHC5PjsLUpyw0MwhSrYWi4VI3pxdDFQ5eblkqc4c/wBhM/nL+G/7a/7SY8K6DqPi f4v69e67d6cbe2sLqz0G80mK0vvt1taP4lbUdKuNc8W+JLORopzqMOu2AEVnEIlFxczmL+g/9j/x d418bfs5fCrxV8QNSuNZ8V6z4fubi+1m6ht4LvWLeLW9Vs9J1W6SygtrUz6jotvY3TvBBHG7SiTD bzn4t+DH/BGvwlB4s8P2ra34u+IHh/SLtn0fwD4c8KXWmWVzaiV7htO1DXZdY1u/sdNuHkc339nS 6YXheWO2vbRJZGX+h34YfsK+NJLDTrHXH0P4beG9OtbSwsNF0uG11G8s9NsrRLaysdO02waHSdLt LOCKO2gge6P2eKJQLVkAB/q3xiyTgjxhweS8PfRy8MqGY4x5pTzDPuM8k4TnwvlVGFOhjovLJ5nm OEymgnicRmE8ZjFVnQor6pg6UXXlChDD/jnh/m/EnA9fH5p4qcZVMPQeEeGyzIcfnEM4x0nKphW8 dHC4OrjqjVOjhYYehye0lL21eUlS5pSrfJ/nIowxGACNueMD5jliuAMjPVc49q7jwf8ADr4heP5U Twd4Q1jWUaRY3v47b7NpEJK7gZtXvGttNjBQZK/afMO4FUZmWv1N8DfsofB/whFE99oH/CZaokgl bVPFfl36+YuCvk6UiRaTDEpA2K9nNLkZeaQ4I+koLaG2hit7eNIIIUWOGGFEiiiRAFVI441VERQB tVQFXoABxW/An0D80xTo4zxF4spZdRahOeTcMxjjMdqrzo4jNsdRWDwtSPuxl9WwWZ05Pm5K6SjI riP6SFCHtKPC+UVcXP3ksfnEnh6F9FGdPA4ao69WDV2va4rDVFpzQd7L81fBX7Dnia+8m5+IHiqz 0K3ZY3k0rwyn9q6kTu3SwT6nfJDp8DY+Xzbezvxk8MQMn6u8MfsvfBbwwsDL4Qt9fvIASNQ8Uzza 5cSOd2Wa3uXGlr97AWHT4kUKoVRjNfQdUr3UtP06Mzahe2ljEBnzb25htIsDr+8uHjXjvzX9g8Hf R18GOA6MJ5bwVlOMxVJJzzfiOnHP8wnNOMnXjWzT29DBzuk2svoYOmre7BLQ/Dc98T+O+JJtYzP8 dRoybUMFlk5ZdhlFqypuGDdOriIpaL61UxE31kyhpfhrw9okXkaPoej6TAeTDpmmWVhGT0BZbSCE EgdyM5JJPOK3AMDA7fj+p5rxXxJ+0Z8C/CfnLrnxU8FW8sGfNtrfW7XU7tSOqC10tr24aTgjYI92 RjFeSXH7ef7MlvMYf+E4v5QGK+fD4U8TSQcHbuD/ANlqxQnoQvI5FfoOI4x4CyBRwuJ4n4UynltC OGqZxlOC5OW0VFUfrFNQUdFblilsfNUci4jzLmr0cnzrG3d5VoYDG1+ZtJ3dRUpcztq9Wz7FwPTp 09qK8i+H3x4+EPxSZIvAvj/w/rl60fmHSUuWstaC5wS2j6ilpqWFPDFbVlU9WwQa9cznn/J4zxX0 mX5ll2bYanjcrx2DzHB1VenisDiaOLw1RafBXw86lKW62k2utmmeViMNicJVlQxeHr4WvD46OIo1 KFWP+KnVjGa+aFopFZWAZWDKehUgg4ODgjIODx9aWu0xCimSOkSNJIyoiAszuQqqo5LMzEKqgclm IA6mvHvGv7RPwD+HETS+PfjR8LfCIQkGLX/HfhnTrkkZyEtLjUlupGGDlY4WOeMZ4pqMntFv0TZM pwgrzlGK7ykor720eyUV+aPjz/gr3/wT+8Ayy21z8eNP8T3cO7fb+CPD3ibxPGWX/lnHqNppSaTJ IRyAmoMBzk8Gvijx5/wcQfss6D9qj8E/DL4oeMJY/MW0m1ifwz4QsboqDskL/wBpeIL2GFmHRrAz hcZhByBtDC4idnGjUs9m48qfneVkl5uxzTx+DhviaTe1oS9o/ugpM/oFor+SLxl/wcn+PGluI/BH wE+HGmxYcQy+IvFXiTxHMp52s8em2/hiGTAxuRJRuJOCAMn4b+I3/Bdz9uTx5PP/AGR8Q9L8AWM5 kMWm/D/wboNgIEkztRNT1my8Ra0xThRIdS83GGCqWJHRHLsRK1+SN+jlzPp0pqfdeWquzllnGFXw RrVXpblp8qd/Oo4eux/eDnkdef0+teceLfjD8JvANvNdeOPib4A8IQQZ82TxJ4w8P6NtxnI23+oQ OW4PyBS5wcLX+dj8Sf8Ago5+1J49sZoviL+0f8UL3SpS/wBp0/WfiPqWlaS2RwH06G+sLLy8Ejyx a7TjBzxj4s1r9qLwu0shvfHNtqFyXYObKa/1x9/JIeezhuIldwGxvuELAk7scjeOV2t7TEQTfSKi vLec01d6LRp91sc0s6lJfucK29f4k3o/NU4yVtOkm30R/o5eN/8Agp3+wv4DDrqf7QXhPV7iPcWt fCVvrHiuX5M5Bm0LTryyQ5GMS3aZyOxBPyR4y/4LufsdaC88XhjTPiN4zkjVvLkj0jTNAs7hgCV8 qTVdU+2hGPV5dPQqMnZ0DfwNv+0bp964/syw8X6zuby99rYi1gJbbhXkuZxIBKxwu6PAOARgZrS0 v4heMtauGMXg4aZArujXGuai7zswHVba3iVeRtIw4QE4wVU466eW4K3M5VKqaTtzOyd07v2cE7b9 V87acs8zx8rP91RuvsxTa1t/y9m1rfdRfkf2KeN/+DhyzVbiHwB8EdNgl2n7LceKPE17qmCeI2lt NJsdK3k4JKreKo/56MBk/K2s/wDBwT+1F9uSbSvB3wpt7SCeJ2tLnQNXmguUVsvDJJ/b63kcEiZU SRSwzqcMr4Hz/wA0Vze+Orq4QJqenabpxVt0drYFrtCy5Gy5uZZUAUgH/UNnOGGzmq0dnqTzhtQ8 RareyRjBje78uOXOWU+TarBH5g+YqiqVxkEc10RweEi0vq0XdpN3vzOyf225JJa+75q/U5frmMla UsZO6V2oyUd2ltTUYu/Z3Svta5/oRf8ABPH/AIKqfCb9ub7X4EvtOj+Gfx30TTH1TUPh/daimoab 4n0q12Lfa94D1eRbebUrWyd1bVNEvbaLWdJidbjGoacG1EfqxX+WX8JPin4w/Z++J/gf4z/DLWp9 G8d/DnxFp/ifQL2KZx9slsZw11o9+G3G40rW7E3ejataOjxXGn3t1EyMXBr/AE1vgB8YPDv7QHwS +Ffxt8KPGdA+KPgXw340sYY5xciwbW9Mt7q80mWYKge50a/a60q7OxSLmzmUqpBA8PH4X6rWior9 1VjKVN3u04cqnDvaLmnG/wBlpatNn0uX4n61h3Nu9SlKNOs7JJuSbpyVrL34xnfRWlB7309eoorJ 13XtF8L6LqviPxHq2naFoGhafd6trWtateW+n6XpOl2ED3N9qGoX11JFbWlnaW8ck1xcTyJFFGjO 7ADNcR2mtXHeNfiJ4C+G+kT6/wDEHxp4V8EaJbxyTTat4s1/SvD9gkcQzIwutVurWJyoIG1GZ2Zl VFZmAP8AMR+3B/wXR8U+INV1n4b/ALGZTwz4UtZJ9PvfjrrGnRXPiPxF5ZaOaf4feHtVgnsfD+jS nP2TxDr9lea1fw4ubHSdFxb3U34Q+Ivib4k+IPiC68TfEnxZ4q+Ifie7la4utb8Y+ItS1+9ZpXE0 u281K4u7iGHzGZxBbSwQR78JGoG0elh8srVlGVRqjGTVk1zTs0ndxTtFWaerv5Lc8bF5zRoOUKUJ V5xdm4tKknppz63e60W6dmz+zn4q/wDBY79hz4aG+tdL8e638VNXs0IWw+Gfhq/1WxuLg8LBF4n1 n+wvCz4JHnSw6xOkQzkM+I2/OP4nf8F+fF1+97Z/BL9nnTdOgKGKy174la/eaxcLJjD3M3hzwzHp NkghyrJB/wAJZOHIDSOqZQ/zyW3i7w8N5gt7S2kiKrNPFZORCzEspe8nTYnCl97Tj5RxwRu5HXvj B4I0wyxXGqwzXECGTyYrhbi5O0nIiiV3kDyhV8uFUyxKyMxSQSD06eU4eLTleo1/NN8t7pO6goK3 q7ed7nj1M6xtW3s+Wmnb3YQUpK9raycnbV6pLbe5+oHxN/4Kn/t0/FEzwy/Gm+8B6ZdRtbHSPhfo ek+Do4Ek3GQR6xBb3vigTEEqZx4hJVeYCjjfXw54l1vxd4/vxrHjrxb4o8aakwx/aXjDxFq3iW/G TucRXGtXt/Ois3zbFdVLrkjPNfLV1+0PYRmaPS9Hub1iJTbyS+XbxCUEpEbl5SGVHTLA29tcHGI2 YSE+XxOp/G/x7qWRZRaVpUAg2KtvBLcXBd1YGVbqVoCXIP7mOO3CJgkMzkOOmFGjS0jCnHtyx95W fdJJt7avu+hw1J4us71qlRu6S9pObS2s+VtW9UrX2fQ+whp0UbrvkRVY85VQuACrgEnIOBubJXBH GQMjD1PxJ4S0JTJq2tafAd6xrDPe22ZJFcowigebzGYEESBVYpkluDmvhS+8TeL9aEUmp+I9XmRE eFQLya1i8s8yJts/I3j5s5kMgxy27cScIxWcA8xmhLDJdmkCSNk4Z8bS5JIGSSWBYFj1NW5xsrJ3 uk79Xuna8tJJ3ajrq3bdOVQeilNJtq6ir3+bt5q7Wi6n2Tqvx58E6cJF0qHUNYu1faqWtn5Vu53D e6X940MUihclWWPBHOedo89v/wBofXrlPK0rRLSynXYI2urproNHly7SRxpbYcARhFDlQQ7tITsQ fOgubRwweXKgNhB84IAZnbIGFVfnLFuAOCTyBp2he8YC10+7u/l3qtta3E/mbYncInkwMjFx9zLF clT8xODHtJSeqXRpRTctFd205pJvXolfY0VKmkrrW13d2Sdleyukr/ypbLrqdTq/xQ8fawsX2jX2 tEjlaRINKtbazQyuwYPuZJ7hni4MDC4BjY7lBcAjye78PQXTBnlv92QWkF3LI0pLBmMqzmYSHdkl n+fJPR2Jr1Sz8IeJ9Qk8uDw7dxF5xbxG+WKwEk7BDFEr301miCYSIkbM2zzV8pnV1Knox8K/FUh2 y3fhbSzHG8zpNqMuoSRlFU+SU02yulEiMYw3zsC0oTe5WTD9jVqWkoSnqrKacbKybd2lbtom7/It VKcPh5YJ2bi+vktnd+V9uqRQ+Fvx1+LfwWndvh14qk07SpXD3/hm+tYNR8L6l5fV7/RbpTb+a2AJ LyzW11BUBWO7QHaf2N/Zm/4LkfE/4UQWWleJtX1HwlZQhIZbW+8/4hfC9nMSRRyrot5cr4q8JRSS 7CINEvpLaJEBkeMHbX5DH4ItKguNU8V38MMYSSeOy0uysYGjYxxyRJcatqNrI6rI7FJFsS4jUtLB GVyubqXhH4fabPbwaXpCalJbz2/2u/1ScapJcwJ+/vVt1mUWymVMxpLHEFiLI0IG4bcauAdVXqWh pZqNntayta0rpK8k732HCuqbU6cpRmvt0lKD3WknaPP/ANvRkujXf+5j9nL/AILRfB/4i2un/wDC 3NN0/wAK6ZfPHBb/ABR8AajJ4y+G5lbykzr9rAJfE3g/MhlZxdW+sW1nGu6/vbRFaSv2S8NeKfDf jLRNP8S+Ete0jxN4e1a3ju9M1zQdRtNV0m/t5FDJLa39lLNbzKQRnZISpyrAMCK/y1bLV9X8L6+2 v+Arq+8GXjbfLXRrqWBZISqEW+qWpLWGpWzS5It7u1mjEMix/OVLN9p/Az/gp38ff2erfUtH0bxn 4v8AA0GvgpqWt/DhrD7FcziR4l1O/wDAniOG/wDDtxqMEUSPeaxpCaNrcome3to2hCV5OIy2pS96 DUopNtxTdkurj70tfK6uvPT2cHm0naFZc7sveSSnd2tfaD8/hsrvZWP9G+4giuYZIJ4o5oZkeKWK VFkilikUpJHJG4ZJI3RikiOrI6MysrAkH8cP2if2J/D/AMC21P4mfs8+EtWtdB8R3sr/ABD8H6N5 +rweHkjWJ9L8QeGtLSKW/ttEtGOpW+q6dbG9TTI7+3ubKG00q2uoof5jdJ/4KLftVaP4jT4x+Ef2 sPiZrd9HKjz3eq+L9T1vw/ceS4uW0zXvAniASeHILTASCbSp9As5FRmNgYWK3Kf0C/sr/wDBwH+y h8TPhVJd/H3Ur34b/G7wlLDpvjDwZ4c8M+IfEel+IY3Qm08ZeDrizhu47XQ9VeOSGfStZ1CLUNE1 OOSxea+tHsNSvfyTxV8K+GfFjhXG8NcQU4QqVqFRZXneGo0JZtkOLqeznHGZfVrQlKnJyo0liaDc KeLox9jUaXJOH6BwTx5mfB+cUc2yycoqnUg8ZgK86kcDmVBKUfYYpQtGTSqTdGbUp0Kj9pTT96Mv nPV9fv7ZLiJL+Wz1Ka0uTZi6laC5SWSKSOG6+zT+VNshuCrgLEV8yMJgsu0fyQ+LPhd8S/APj/xv oni7RNYt9U1W40e41bUb61eJLyXR59RtZGm1B5ohqlprL6m/iHTr6GOS3dnuBLObgW6V9Of8HAf/ AAUF+FP7YH7cPwY8Z/CDTfFsXhf4YfAq7+Hurr4lS08O6pJ4g17xZ4n1uTUbdNMvNba2t4NN1LR5 zHcsL2dYZoPLtzLHcQ/j8fHHxZvYH06G6jj0b+zZtVd9Q8Y3/iXToLCFf3eof2Bc3tnaw3cU/lmx ttX0a5je42D7JdFJdv4/9Hv6OGZ+Ama8Q4jD8c4firKeIsPgKeKwuK4cqZVmGFrZbUxcqFbDZhTz rNIOlOGPxMcVhfqlN15LDVI4ij9WcK/13ij4p4PxHweX0p5BVyjGZbOtPD16OaLGYWpDERoKpTrY WWCwU+a9Cn7Gsq0lTTrRdCfNTlD9q/2S/wBrz9l/9jTQ/iP438ceOf8AhYHxSvNJTRdN+Enwvm07 XNa0Dw9p19NqN+3izV7y9s/Cnh3WNZ1iKNINNm1i91HT7PTd9/ZW91qcVuKPjf8A4K5/tQfH/wAO 2mqfAUfB/wCA3hzWH8XQQw3fjbwbq/xbtIvB8qXV/catqHjq90TRPD323TJ7SbSTpvhxbjVrhr6z 0O+u7i2JP80l9dabfePrm40U311BqOo298smoxxSubvUPKm1VL4xwwQsk1815IqpClu9syRoQvyp 922kXg/UNUj0TTtB8PR3F/cG403RbDT4ImkiR5Gt2sopI5L+RFB+RZbqVtsYBZnjEi/pOL8BvD7i DjLMuPOK8ohxZxDmE8M4yz1SrZRgMPhKFPDYTB4LJaUFgHh6NCjCMf7QpZhiJVXOpKu5SkfJU/EX iLKcjwnD2S4l5Jl+HhUUp4BJY7EVKtX21etXxsmq8alWtOT/ANk+qUlG0VTSSP0+/Y0/4KW/tS/s +eIpfiD4e+OvibUvF1/4rvIPEdj4r8TT+NPBvxHsjcR7LDX9C1TUr22vrOArcWmkavpcmkalbxu8 ej31sJ4ZJf7iPgN/wVX+EnxP+Anwy+JXivRNY0fx54x8OnUNf8EeFrWTVtO0XUrbUdQ0udLPWtUl 05LjTr19ON/YMzSzJa3UcMrzSRNI/wDm1nX/AAr8KXNxf+F7PT9US0gsPDmkSaPAdQt9S1HUbK2F 7BIsET2Mdrbz39xfXJuI7uTTnuBCZpGyf6SP+CQPxu8PftEfAa88EXlhpkXxI+Ad5a+EPEzaWEtL DxZ4c1A3l74S+IGm6XiSW0g1iKO60zWoVklij17T7iYuhv44U/P/AKRHiJxj4KcGvP8AhPKMqjkW XYjAYPG4l5fOth8sp4516GF+rZZhp4enh8Nh8RTwuEqV5QdFVsZh6XsVdzPr/Czhzh/jvN/qOe5h jHmGKhiK9Ci8Uqc8VLDOnPETxGMqQqSqVKtOdStGmm6k6dCrPnXKz+mDXP8AgpLBIxj8HfCfULpM FY7rxDrsdpucn5T9j0+yuRsKkHP20EAEY5yPJdZ/bo/aF17zhoul+DfC8UgxEbXSLjU7uJGOB++1 S9uoXkUEMGNoFOSTEAK8d07wgyhVhsIwQBwUZwMepLoucdBjHbBIrqbfwnqbnCWgjJJOEhQEjkbl YgvxgZbjOTg1/mbn30zfGbPPaU8PxRnGHpzu4xyTLMFlllJ2XJXwmEo4nbZus3e/U/qvAeEHhtlL Uq2VYDETja7x2Lr4xSd1duniMRVpeTiqdrbroYOs/Gf9pLxYrxap8U/FUED/ADNb6PcRaFE3fbnR rexdlH3cPIVzn+LBryjVNB13XZ2n8Q+I9Y1m4O5Wl1TU7vUZPmGSB9quZ3UNuyVA6c4J4r6Ki8C6 hN/rcKCSyh3G3OdxypYgHBDHgEkYwSciwvgFlIDyW6gg7iq555OMKCUGTng5znntX4znPiv4pcRu U8xzPinMOa6cs2zXMK6blbeNeslFeV0u/S32WDwPA2VrlweAyjDONvdwmDw1O3T/AJc01Jp221/z +Vv+EG01FUbZZW6HCMFzjpyFVs4AYkHIHAPQzL4MtgMRaazN6uVHGOSAAxAwMHJzjg9gPqceDrCD Hn6jBEo7bU3KCMDaXdWOQDuyMgkgZA5lXRvDUON0t1Oe+3dGCckdI41wBjLAnOCO/NfFV824mrNy xWPwmC0u/b4yi6ivbo5152VusU/Pc9iObZLD3aGCqV2rWUMPVcU01bWUYQ8rc2271V/mC28MvZ3V te2tvcWN7ayx3FtqGnXElteWk8WJEubaePyZIpomAMbxujKwBUgjj2bxd8Zfjt4j0CLRtQ+JniS5 0iW3FhNFFNb6edRgEYQ2+pTWNva3d47RqfP+0zl7gkmcyFm3dldR6QkTR2elR7lUgTS/OTuHVQGc kqdxxIQQQuPfCv8AQYX0+URoYnnhUschgk8YDW9yoYfLLGwQtj5XXKkHAA+/8PfFrjXg3EY3Lss4 rx8srzjDTw2ZUcuxuKwlJS5XGhWpyp/VovEUakozhWhFOMFNe0lTc6b8HO8k4c4jeExOOyLCRxmE xEamEq4mhh6ktXF1ITjeq1TnDRxba53flulJfPGi3fxh+GBu/E/wC8et4I+IFnZXB0nSdUlub74X +L7pIZ3tvDvxH8GvKdMu9Kv5pXSPxHpcWmeK/Dl1NDqNjrL2VvfaTqH4j/HL/guH/wAFDv7R1GHx F8av+FVW0F5qek32laP4e8H+CZPD+saLf3ej+IPDl9dSaZc6jBrXh/V7S80rUFXVbgyT2y31lcS2 lxa3Mn9FFnpdtcEXLWSnesYlgJZVRwCkyM0bBiRKpjOAVfG8A5GP5n/+C2P7MugJ8QvDvjGz0m0s 4fi5YXniqSJRdw2138SvAdrY6DrxvJkObceKvCupeGTf3VnNFdG402XUCvnRtK/92fQm8feI8Xx/ mPhNxnm+KznB55hsbmHCGJzGrXxWLwWZ5bTnjMZgIYjEupKODzLK6eKxNOjzuGHxuBcaNNTx9Vn8 7/SM4CyijkuB4uyDBLLq+BrUMFnlDBxVGjiMNiWqdDFzo0pRTrYbE8tGdXlXPQxFNuTjSjb4I+JX /BTn4pePkuF+IH7T/jnxeLhneazuvHPjHxLDMxYBwbNbu6sWXv5PlhOmFr5ivf2ttFu5S9ld+L/E Fw4cubfT/s27JI3bryaF8H5ixCEsCNuSQT4hceBtd8R3MGjeHvgn4Q+HlpZvHFea7cTa/q0/mqds m7WPEur6wLgM2JBDpGnxZQKC4DFq9I074Fag4xr3jkR2yoqC30HS4bFcqTuOSYEQncACLc71wQqu OP8AV6DrK8IbaXSUkr+7peSgnJNJNOLa+Z/GsoYe16nvSXxOUlJtaWuoKd7rpzNvpfYhvf2h9ZvN zW/hTXFjJB36lqkcClWxt3xGNPLY9Cd/3Tn0ritT+OHjmZy+nWGh2KbcBLxL3VrolmAOI4roQsoV lKq8YL5YgMMbvZ7T4H/DWxSKTUG1XUJlYSytf6w8QuSxJEcq2qQbtwPzR71yOr54r0vS4fBGiL9n 0zS9F05ItwY29tA0zArHlZZHEk8hHyhjJIwJAAPy7j0Qw9SSbc4xvZ6NJpOzfM0lrrr09euLlSjb lpOSutVB2+zu3q+1rJ76s+GJPib8aNUuTFp2palmUuiw6L4WskQgMMNFJLZTyJwCA5OR1LZwR09h 4Q/aB8SyLJeX/iaOBxlzrGuvpsG2QMfltbaa23KBjbtiDBuijAx9fav4s0KwaUi9tgg3GORJYUiG 0opUcgkpITvVSvO07gAwri7n4s+GbGEvJqlrJk5WO2drmQk5DbxCjqAFAPAOc8ABgKaw8U7VcRPR 25eblSfuqybbunrqnv1KVWbjH2eGUXoovlV29LK1rp9Vt3WjOa0P9nx7jTnj1/XLeS7uB5vmwWf2 24R1wXze38jSSYbHUNGTyoAznsdP+CfgfS4jFcW1zqLkorPcXJijLDLMTHamFFDAYOQxVjxuBrmL X41wXUzxaLpWvamN0mxrLSp5RknChiI2QoBnJP3ce2BpjxV8QtQjX7D4MvU87b+81S9tbELg4yYZ JVlBO4n/AFTbgMBiCCNYrDON1eTUUouMZS3avdrfRatvfV76ZtYlu8pQp3louaKcbLzl9/a+7vZe tWMGh6Nbx2mnWFtaW1uF2xxJhVIymH48xyeTvJZiMkjGauPqkCsgjZQFOeNuc9uQVOQucgnbgYHQ mvMYNH8c3Iie/k0vTVmPmYWW5u5BwuVbEaQvlflGJG52ksOSelg8N3DgLealIxAyEt/LiLDBI2sQ zBSCAVyAD8wCmt4XbtGnKDlZ6xs3qnG6s2218S1s1fuYvRNyqxct5Wi5NOyTTs9NdbvSz6M6J9TW TP75AYwzqQXJxgg5Qfdyc7CQVUg84rDk1e2gXdPd28e52kZpZo0DEoMAeYQMhcEqMtg5IHSrMfhT SEdJ5Ibu5mB+SSe+u5VwcH/j3EggIB+cErgAE4GSa2IfD2ntIjQ6fZKEk3eZJBDlFAC/eZGfoFDK nPAOAOa1jSqXafLHTS++nK1ZOPXffVtteeblG8bylZuPM7JW9d2k2lqttdVc85vvFlg0jNaG7v3c gINOsLy+DE543wQPGfmUjLSoARyeeP8AQw/4IP8AiXUPEX/BMj4Dw6irK/hrUviT4Ztg4KuLGy+I XiK8tI2B6GCLURbbRgL5OwDCiv4KRozZkWGCMxpj5lQgD+9t3A5J4PQ49geP9FD/AIJV/BXVvgH+ wR+zx4E8RWUmneJbrwpc+N/ENjMCs9pqPj/WNQ8Xx2lzGQGiurPTdX0+zuoWAeG5gljdVZSo8XO4 cnsIuScvaVXZJfCoQUpPW6d3DSyava1tvosik5U8U0v3fLRim3d87k5RWmiahGpe3SS3vp+hVfyV /wDBbz9vvUvH/jTVf2O/hnq723w58C39sPjHqOnylW8a+OrMw3sHg1p4WDSeGvBjvGdasstDqviw fZrqMp4dRZ/6Zf2lfizF8CfgB8YfjBJGs8nw8+H3ibxNYWzFAt3rFjps50SzJk+TF5rD2NsdwIPm 42scKf8AOt8U3+qa7rOq63rd7Nqet63qV7rOsajcM8l1qOs6rdS6jqV/cSNhnmvL65ubmVjglpWx 94Vy5bh41JyrTScaTjyp6p1HdxbXXlScl5pN6IrOMZLD04UqcnGda7lJbxpwcU1pqudytddIzSOM luRBFJOzBI4UmleWVlRFRE3u0jMAAscYMjuWCBcltuzNeLzfFQ6kt22jaXcLb29w62GtX8kX2LU3 jaERXkOlYEslmrC4kh+13UaXbCCcxKoPnc/8WfGB1nUm8FaUf9A06SOTxNdo5eC+nuIH+yeF0gi3 tcxSRyDUNaVkKCA6bZ7XiuLxa4PTLXWtR8Saf4c0+Cw1DUJLZtQvk1e9/snw/o+j28kazXOtailz A9vbbVIC20qTscwQgyyx170XzNW15m4p2k7y0cWmrpLfVJKy6nzkYRS56iTaXNaT0Sure7zxTb0T Xns9GumvvEOp6y7WFzqWp6i07Of7Os/Pm+0yyyb989pYKDeSu+weZcJLIiCKNGWOKNV2tP8Ahv49 1BBNZ+DtRtIJIzLFPq/2fSUK7RgGO+eGXBUhgpjVgSAVDKK9T+GvxD0HVNM/4p2Tw74MW2Gy50yw tYW8SRyo8kUuZJV+039vhABdwtcRhiY5pIplZB3eo6lqM0c0lrJrcyuoxeagzR277vvEIBHExaQE BRMu0Dkrtbd108NTcIuVSU1dWaStfSUUpNOV09G+Zd0jB4hxlKEacYJPaXNa7sneMbQ+J2fV3aWz S8VsPhP4wDKdQvvDGjW7sI/MuL2W/lEZDbsW1lFkOjgAkyE5YbQcq57e3+FmiQKTq3jWeeYMAV0z SI7dPlB+R3nklkKoCHMiqpGflJ6Mn9t6aTtvtd0CwnV1E0FxrFnJLjfh9iQzPKWYgqFIYhSwIYLu qtceMfBcCKLjxLFcMwyFsbXUb+Q8qh3tbWrxYG1do84JIu1lKnLNpyUYW5owm2rvmnbXfe3V6RvF O/WzRPtK8raNabRpu6Ta15ney0XlYpXXw40Y6xbJb63qM1hEHEzXU1qkc28qI5InjRlieFlZc+XM Xd1bAESo/V2Xw5+H0F15kUVvqmJyIrLUNRu5IViWNI2E8kFzpf2h2mLSwpGkrJlVeIrtUcPd/EXw nE+LK38R6gBtBEFna2KlMkgSvd3UcgYDIy0LEfJlQQGND/hZNvljp/hK3XABjkv9VnllQrlXLx2d vboQcneVmyjYUBskjNulFttU03bRJz5V7vKvhkm0ubTW7em2g4137vvpWWl+VNrVOWqd/O3bTR39 fXTvD2n2lvb2jeGbOOzSJUkttDXUdSUwlQk0moSWZuLm5TYVkmkmd2yVkeRnZzY/tW1uMRT3mvam zAHZD5Nqu5ZMwlUYuY/nRCVSIuZMvkCQY8JvPiF4nu1lijTRdODDbvs9Oea6jQE7AJ9Tub9WKrtV maLACgqqnOcZte8SakfNufEWslyHUCC9msFaMkFovJ0/7FFh3XB3KpY8j5guYdaEYqKUreXupR72 unFpaXWrVrplRoyaV5Rez3cuW6WmjfS92m10Wu/0r/by6RFIYtJWyW3RTJeanqFvZwMibl87zD9n jKn+HbOvmMEV9z5FczL8QbQJcLF4o8L2XmASSCwljup2Ub3KRzWiXbSTb1SQIjku+flZ3JHznPar c3sk2oCW7lw2+W6eW6uQVYgIZrhpZJFGArsSxxtAOQoFWdYbSCSe5lhs7W2jJe4ZMpbwj78uQAWX YT0G5dhBUkEHN4m0bKFuj5pPmto9PejL3nq3fp5mscNHW9RPm1+Gyb0+BOTbt89tj17UPG3h6cmW 88QXuoXSuqQxpZ6hI3flprsW20rlVLdlYJjjI5ubx5oEMksdt4e169bexglnuILGOZWyFyXkuJCs jkJGwKYX5vkIVW774R/DHSfG0uoNLpFxLY2giew1W8nvNL07WASYp4rKz/0C9vbaKNX1CLWnnhhu 1ItorWQIZ299HwN8M2sivqMWlwWNrJE5tbKyit5Z5EQqv2u6uIri/a3EzhwUmUReS6SluHS0qsoL 4UpOyVpO66Sd3Z6PVLrcydTD0pONpTkrXSaUVs2rXu09tfy0fxjJ431aZjDpHhzSLM4Y/vpbrVrs KSQm5bQIFZAH3FgxwG4KrVC70v4i+ILcq0LwWrg3CSx6Ja6XCy5bbItxqAtWlQLKpYxzbdpVjhFG P0Jj0XwPaxNZ/Y7IwysHeGyF3BHMwtbexEk8cU7CdoYbdUttytDEJJ32GW4kc2oU8HxP5tr4chlu IUSON5bW3SRY4w7R7JCmURPMIO0b8ZRmYYp/V5ShedZtcrvGKtu03o7tJX0dr/pP1hQbdOhFXa5G 05a9L3aXzb6Lqfn3pPws+IUJmubfXrO1t5LE2+pafIf7Whl0+3jyRqNppkV3bPt3kwzT3aTLcsrR Tb3LCz4W+Hni1LjWrmyuLiPXvDmnavc+ENW1OC4sNF8TPJbzm10e8IsG1GSORnXS5LC+dEBiiv4b 6DMFzpv31ceI5FR4bay061iT5pFdy0RMDhoQ4UrGVQj5Wdy0WGZWB3Y5DUfE2gxp5F9cWKyvG8kg D3A+WNZA0shjn8tIlWJj5geMztti2ySgZ4auW4WpNTUVGaS95e7KScUrSa51b+84uSe0raHVDHV1 GzSs+WSjq7axvNK6tLlTW6TWnZn4W+Ln+Ifi7xfe654w0WPWNaFy9rPp40m6Uad9haa1lsFa2kik UWziWAwCe6CSozHfIqkei+FPhL+0X4hW5j8H/DuRY9QspdNTUb3wld2yw2MoZjFDPq2q6hHKVXEc cy6ejpsQhhiv2l+C3xH+F/h8eMrXXtG8M3GqWviq71DQtSm0vT1uptI11RfXAmTMyNNZ+IP7ZjWS KYyG1msGYnIB9P1r9qDwzZxuNKgscIQn+jwoD5hPBiUJwH3ZJBBCLjIXiuejkfPFyli4wT5tqcXN a8rXvTau0rXUH2a7a1c3nGSjDCSm1bebjFtcrtFRitr9ZJ3+K+jPwy8L/wDBN79oK7ubW/jtW0O/ t5YZob1/OEttKCZMmbcvUhll3EpIjFJEeN2U/Z/w7/Yb+J+lasuvfEK+8MajqKWs0Onajo2vroep abIxkEOY/wCx9TglgiEjxm2SSGZ4cbLtTHFt+q9R/ac1HUxKml295KdhLLa28spdt7pwYuA2QvC8 AyKCF25Hlt54/wDiHr80z2NnqcUTzSsLie2ubbMS5WORvOcviTIkBgD+WjIky5DV6+GybL6aSqVM RUnFXSjblbWtpRtGK5dktLe607pW86pmuZV5fDhqNPRXqp3aaV1G9RST1ve9tdUytoP7E3w90qK+ l+IPiSx1vVNRLNO0Gp6hqN7FBHMHitbTUdbLtYxoFX7Qmm29pHKXbzHkiKivqv8AZE1b4Zfsi/tF fC7x94PjisPD/iHWrP4T/FCEyb4r/wAA/EDUtP0q31SWKN4opbnwd4yTwv4lhkkSQppdvrMMESG8 LL8Uau/xC1MLc3N6loqnyzJJcPvLxgeYQAm8cgZVgBnrtAyeb1DwTr2u21xYXniKVpL60uFtngck RXZieO3ypYgMs/lsF2gFVSTaCAT8lx7wFk3GvB/E3DOPy/2uH4hybG5bOrWipOlOvRccNioRk+V1 MNiPY4mlK3u1KUJvmcWj6DhviHMcjznLMzhjVB4LGYfEzpUHKMZwhUj7an7kW1GrS56cu8ZNdz+7 ttV020JAhYSRyPAyRw4YPEzKzsRwoUrjJK/McsMg1Tl8QwuzCGFyWxjeQoY8kAAFiAByQuAcjpxj 5o/Z0+Jn/C2f2fvgn8Tr5m/tTxx8MPBuua4glSYReIptHt7XxLAZwqq5g8Q2mpxyEICHRg4VgVHs X26FQWCqQD8oJLZBBJOQRjHOcHkdPUf8xOfZhxHk2Y5lkuJlQweJyrG4rLsVGnRjzxxOCryw1dNt S5bTpysk30V7n+oGBy3B47DYfG0lWxFPFUKNelOc5crjWhGpG+usXGSafm9910smvXbn5DCiBeQE ZmDkjGTuI5GcgLkkkdMYoy3F7cnJmnPcg7lUEg/w8Kxwc8jaMHvk1gnWAvyqFQnBACgnrnrtAUY7 898AZzUD6u7AlXcEdQCDnJIAwem3PUAE9uevyNfG43EP99jsXWTspKMuSGttOVSUVd2suVa9NT2a WVOm4+ywtOm9NZJSfTsm9P8AE+2h0At5CDvIU4YfvGyxPVskAjrngAAkkdCaBDHGpzMvBBOMNgt1 P3mOcZPOPvAYPOeWk1BwCMl+duQw6kAl2Byc5yMrjgbec1D9tcjIJXJwCAR2GSfl3cDA3Y6EEgcm uanThdf7PObk/wDl5UlJtvryxjH3tX1aR1LAYh2vVUVdaRhrZb35ubTyfW+lzrHeyj+8+7vyzLnI B6A7Tn3yfwJzDcSq8ZKspV0BxgEZHQjAwcc8EYyMc8Vyr3EmQzvgYz87YUDvyScAdeeFHYdakWeQ xgeYqpwwIBO5TgkKT13DoQMHOTXsZdGuqkPZ4blj7SL92HK+mjcrWv5tJ2srFrBcjhJ1HKSau5Ws v8Kei+SQaRN5M93G54jum4bkiNx5qHd/tAlwy9iQT1FfmH/wWE0zS9X/AGafBms3F1aQah4d+Nfh O10aG4iJa/k8WaN4k0W/sbaReUlMMcF+8ZZUlh05lYM+xa/SNbxF1fUl3AYtNOTbg5BAufm2gkhm H3mHzbcYyAa/LT/grxq8X/Cg/hNpCwRu+o/H7w9fQltmY28P+BfH92ZER1ZX8p7qBi5BEZZSOcE/ 019HbAY+H0h/COrgqs6c5cXZe60k2pSwalWjjYtx3jVwKrwq6/BKas9LfAeMFGg/Dbi6vWp+5HJ4 uKbXLGu6mGVJpt/HGu4qNrO9tbWP5Qta8UfEq8nvV0qx1NLKK8dLXdpMMVvLbCR13L9pe1kkkCRu C4mOWJZWAG2kjT4tapGm3TNP0mI+WD/aOomSRshd0jLaiR1aT53ePzF2HYMHaM+9PiV3cQLNvDYY pvGHbO5Vy5J3ZKk8kEAYBxU32a+mEcVvaz5GQrFChCE7toLJkAgL3JGCM4+Uf9DHsnLlfNUtorK1 t7bqFtLWva7tvrc/zK9ryx92FO9vtNvTrKTesuttrbX6vwlPBXxDuh5d14l0e2G5Cwh025uX+6N/ lyXUsTJk4wAcY2gnjcd7SvhiiOJta8TazqDxncYredbC0D7sMfs0ZZZMbQMSF8Ekghq9ffSL6NQ8 zxxHOS7yoApzg5wxAIGRuJwMg4BwKv6b4Xm1aaO2sZ5L67l2Ktpp8E+pX0h5OFs7NHm3Z6Fo9zMd vpm4UVdu0u95zur3S967Seju3de7fQmWIaUrSjG1o+7a7b5bpPd3d1ePS+h5qPhv4EkQvLpr3bhi yfbLy6n5ySyNHJJ5XB3Nt8sIflwTjJ2bPQvC+lKBp2i6ZbNkLvhsrdGDYwBvCbgTxlsnkZJYmvtL 4cfsK/tV/FC0ju/h7+zZ8fPGNjK2F1Cz+Gfiaw0h2GduzVdasNO05cju13s2DPA+avvL4e/8EJ/+ Cg3jJ9Onvvg74Q+HtjdCIvffET4m+Gbe4tkfpNeaR4Wm8T6vC0at++tvsbTgqcKHwouU8PTf7yeH g7q95wTtptyvm0fVb7Ju2kQhiallCGKqLRpKnV5XtdN8qjZK2ruuunX8V4po4lCrEqoc4AiTeFLY AUlNwILdD0HBVeakVbiQkxQSFOTjY+cYwDvP3m4IIHXHCqdoH9RvgH/g2x+Lt/cpJ8T/ANpH4Y+E 7Mgu8Xw98C+IfGeoK5xiJbnxLe+DrVOpzP5Ex6Hymxgfbvw7/wCDc/8AZT0CBT8R/i98cPiNdq2c aZf+F/h/pjLkkq1ppmhatqXJwARrYwNwA5BXGWYYCnosT7TVXVOlUb5ly3fvRUPlKVlqk3d36YZX jp2TociVnepOCs7K+kZSlff001vc/iri0zUboIWjwoA++CsY2gb2XJxuAGXJJ6AcjdWtp+hi6mSy hu0nu3+VLSxje8umPHyiC2DTSH5SqBFJPyAkgAN/oN+A/wDgjv8A8E5vACWLWv7NvhzxTfWLROuo /EDXfFvjia4libcst1Za/rt3ospJwXjGlJC2ApiKgCvt/wAD/Ar4JfDJo3+HPwg+GHgKWKPyo5/B 3gLwt4buFjxtKfaNI0q0nKlcqQZDkEg5rKWd4eOsKNapJfzyjTW1tHFza9VZ+fU6Y5HiZJKpXo00 klaMZVZWTvvJQjf5Ox/nQfDr9jz9pb4oqZPht+zr8dPHEAZVa80b4a+KItNUlSATqt7ptrpw3mM/ O96kYwTuIHP3N8PP+CJn/BQjxtFZXD/BDSPAenXTI4ufiR8RvCekXdsrkZkutG0fUfEOsxMi5Lwt pscwUbTET8tf3nUVzTz7EtNUqVKnd3TfNNp6LRXivwOqGQUI/wASvXqaf3IdrfZm/XXrtfU/m3/Y w/4IMr8M/H+ifEP9qTxh4J8dWfha6sNZ0L4beA7fV5tD1HX7G5iu7Sfxlruu6fpFxqWj2M0KyN4f sdKig1WUR/2jfyWSz6fc/wBI6jaAPQAcDA4GOAOg9B26Djiloryq+IrYmftK03OSVktFGK7RirRi ursrt3bu22evh8NSwtNUqMeWF+Z6tuUrKLnJvVyajFN9krJWPzG/4LCXdzbfsDfFuG2mkhGpa18N NMuvLJHnWdz8RvDLTwPggmOURBZADkrkcgkV/Dx8UYz4T8F+KfFEcbSjT9Kvbq3UMd3mtCkNrEX6 Ze5dQpBXIdlXDBVr+3z/AILHYH7BHxPJONvif4WkD1J+I3htCB0xwxOfb3r+K740Wi6h8B/iCQgY r4du3GwBiHgkjkBGCSzKYQQCDlgF+U816mWP/ZsRa94ynd3STvTh1303d1ottzwM60xuDUleM401 a7X/AC+nvbo9N9PvPzg8JWguok1GfMt7e5vry4kkMzzXt0xeaUSFiV+YLEEXCxwxRxLhU4898SaT Le69q6TSq5la2AtxLIYzHBsa3WYAMB5O0yhPKZVlKzDLrXpvh6U2umRFFIP2OFUAHXZCpj44O8nd 1cBFHJCkleHhP2zV7i4Z3kaQu0u5I12hws0ag+WquNkilZHZklw7RjAxXptX5IP4Ve2rveKUXorK 9rJ3u7K6t18+M5OU29t7Ly669Wmr6/5FjwjrevQanF9ikg0240Zr65Gr2tlCdRupNStLXSILSWWV JIzb2trBcyW8jRNcLcXDPHOhSEjrLt73UZvN1fULzVXLyyM+qXl1fN5hU7Gi+0SyiIgbwTEqlz0G 0Vn2lrDDNKIki3PEvmr5n70lGZlkkCleCjYBwisfl2hlJrWdAd2GA2FSAG6hsgvk5LFjuyCVwBk4 ArSLd1FttRk7q7Vm0knZaNLTXW7V5XbuZtKL9yKtyx5t9rWWr95Wbd7WtsrLQpR21vCY1jjRDHuG 2JQEQ9QVwoCkkfNhs5Bz8wFTOvC4GfmO7cBkMegUtnBO4k5PBxgHBrRs7O+v5ZIdPtJ76WNZEdYI XmIJUYIMe4KQD2PlkMCq8gjasvBXijU5Ujh0xVJD4+03FvCDjDByrypMEYkbG8vczEKF64bjdqCv J3s42b3SvzaaLyTv1bexCn1lKy0vdpq+islZNX6NK2nU5dPugt8u3aOCNuSRtwTk9sHfkgchhwas xSBdzEsoHDHaWYZwSQR82Tu5xwSN2QTX6nf8E/f+CTnxT/b38QeP9P0f4rfD/wCFuk/DKLwnceJ7 nV9L1/xTrtzB4un19NPfQ9GsW0exnaEeHNS+0yahrViitJZLCs4knaH9Rvjv/wAG2mofC74B/Ejx 38LPjn48+OPxl8MaDHrHhL4b2HgPwv4Q0vxXcWuoWT65p8Jn13XNUutQXw8NWvNE06DUIrjUtWtb DTEeRroKeWri6NCbo1Z8lS654KNRy97llulJbNNaq3Vppo7aODxGIp+1pU+em+ZKftIpPlbTsuZu Wqtbldz+YCIJIWBGFDZGEHmLzwANoAY4BAA+YFtw5bN7ENrG8t3IlrFgl5p3SJRuA/ePM5VI/kzn LAYxjac5038OLZW1yLpb/wDtK01m80y+srx206/tZLQWsMlncaSiW17bXlvffbLe5jnCTJco8E0c bQOgkg0+xgtnhTRbCdgJeLvTjqWoTT/MTEwvkunbyiYmhgtwZVkWRpAERUMyxEVGN7PRWk5WTUkn rFKU9lyv3U9rWepjGjNpWa3Sa3a0UbO+l1o9Wn1atc811X4heAtHeSLUfFnh+3e3YRyebqdqzRZj eRQyRSTOSVX5k2OygEuqZJPDf8Jx8PPihHaQ6F4zsLqwtNfshqaQ3B08XFhHMrXTJFOYbqaxngSW CK5itntnl2piTJSvmv49x3dv4h1GxvYrqyu4w4ktbi1ns2SOSPzUkit7mKKSOGZWQwMFCPE+6LCE AfP2laDqnhC28K6w8RhsNXVtV0S7jcD7RZWOqmzvFRlLOj215HNBKrHjK5YhueWWMmpq9NOKcXOz mkk5RSb1T15kkmt2urR2xwlOdPnjUlzW9x2i07q9431ldaprTTfU/qv0jW/Dl/pfhbRNMVY4odI0 +Sw1SSR5rzT5jFCYprqYtHc3sIgkCTwTSlHUSiP54kz4h4i+JH9nX81hJpE897ZyzWeoSCS3igiv beSS3vIkW6uIrlVWSN9u6BcxNFM67maNfDPgZ8W9M8RzQTW11HDbzRQLa2wyjwW0USogVMlo3bEq yRZEQdHJjEhZj654si02517xDd5gmN3Pp+pRXMyQuJI7vTo7SUrMEJWNbzS7ogvgh5Q+50bC/TTq QrU4VISSbbi7PmXLo431suru9e7PnIU3TnKnJapLV3vfm2undLrbulvfXlbz4j+IbhsWkGmW0Yka VTGBdPsMg3IpZUUuAFBDZZioyGCBaz28S+MbiNnbUbiIjh5YYIYSSTkouXAR/kHygBuZAGOAFku7 jSrcuoYERxxvvLhJJVRhNGCVHzFUQszbPMRQ/wAoaNyZ59Z0aGFik8aDbIT+/UbVjnBkDchAshkd 2UkOGA2hA6pXK0/e95Pm22WlrWsnbS71eiv567xUW9IvW1tLu/bS9+i1776nHXdrrt4xjurvUGUq zCOS9m+zlixcEw20abGVd6qNzjed2Nhc0sPhcszysyMxAJEisZpQtuvDSSNJl4yjZ2hCrocjc2yj V/iBo9u8UnnxDIgMmWOxW2yQ5CrkHzHkYSKzFMhgnIbbzg+LWkIIFD/OiqCUViT5S3MbGVyxOGcw pHs2O0YaWRkWEOc3yJt88bu3Vd0nure7b1frtsoTa0i3vryqyv1aslbXt17LTotI8P6Nc+K9K07W Siwz6NqUiDz1iV59PuLWeaFV3NGN9qszMF2uQpZc5Un1XXtY+D3gS2Eur32h6cvkAqt3dRyTholH zqrGRt7uFPygsRxuDBjX5v8Ax3+M97o2lW+q6JdPFqthdTQRMGZEjg1G3lsJNrI6sDFHIjkEkedu BYgCIfnPrvj/AMSeKtRD3GoX93PO6xJDJdTSl5HZdsarIzgFn3MQGVVRt5fk45KmY08LzRp0lUqt 35nZqK91q+l04yUm7N3VtzrhltTFOMp1XCCioyVveb3utUtbJa3tZeZ+8h/bE+COgutjpsn9pXS4 3W+l6c8hkaRAS8LKI/tEYZFfzIiy7GEqnYSaRf2o9M1+U2fhnwvrWtahfTNFY6bY2aNf+ZtiFuYI YHunaSdw8ShFd5BG++HYNz/BX7M37OHib4gadf6rYwvaaRYxKvi/xXemC0SK6dbh7fw9ok83nzXM DxJCLxbaJpBFIHuraaIQ2l9+zfwF+GkvgfTrPT/AcfhnwjDff2jZ6l4+kmsrHxHeqkDxyQxXLzTa 1o9jcSQalHZajLPo9vqcmn6/AdYmfTINOTGlmWY1rVY1KOGotL97Ol7RtpKL9nCcrSl0bcoxbur7 mFTBZdQk6ThPF1abvy+1jBxUpc7dScU5QXWKjaXLbyPlDUfGvxGuNtlqfwv8V6BdzM0i2lyEjmkU 5zJ9klisrlowQwPyPgnDE52rwerfFTXtHnjtF8P6sL2E+V5DWTW5i2H94/nuoUlZFIchnHmggsDg j7FTxPaahulv5LjzyC1293eS38zT52tHLNO8krqjKqlyyyBRu2gKAcDX9H8O+LLOS2uRBHfYK288 IhEluSNwkST+OOMkbdyFHD7pg67q1rYjMqCUnjoYulJJSpewp06qjaMXKk6XLFytpGFSElLWLnF6 pwlgnyxnhJ4ezSU4Vp1IpuyUqkJJtwTdm4TUkr6S6fuj/wAEs/Ed3qf7DnwhSRW36ff/ABKsfLmO 2S1874leKtZexYAkL9juNUuLYAHAWIKowQB+hSTTyhRuC5ByN2SB24A+Yk8cEdTzng/mV/wTLs9U 8M/smeH9D1WNIr2z8f8AxRbEUm6Ge3u/F93e2N1FIu/91eWl3BdIqkGLzTDIokR0X9BotRf+HocM MkjDA4ODywwccnj074/5uPGvJKH/ABGDxQmp1Jxn4g8YST5VT93/AFgx9k0knC76WWmvmf61eH37 3gbhJRhGM/8AVrJG73kuZ5dhm3d3ckm7+drJnbLHkAGRs8ksgwCODyckBjwMA8nsOztsSnOdx+UH JJHTBzyFIUY5AJ4ORkmuVXUpBwSQMno57ngFsDPYjPtnI4qVb55PmDOw3clgVGck9ABkdRzzznJJ xX5rHJcOtVRTkrNpqd3prf112WtlvsfXeyq3s6is1stnqlbXW3le3Y6kSxoudgUnJYjgvgk9cYGM 7uo4LDBHIb9pB3HIAYggEk5PAXCnntgjKrkA4OQa54XDuCxOVHzcsMhs9CD125BHOACQRximC5+Z gXAUgBgHxgjgc/MMDI+UA8DOD1rpp5U4u8aCSVmny27Kyel7K2nRbsPYRSfNJK+urva3Le199Fr0 8tToDdK/y7lAHBI5z145JBOMjGDwehxVaW7JTarjr8xDBgSCB6bQeynIYHPGDxhm7TPzM3BXndhS D0JwuQoAJBxgdCuMY9K+Ffw61/4seKLfw74chkMCPHJrettEWsNA053xLdXTlfKkufKLHT7BmEt9 cCNdiwiaaP7Xg7gXOOKs9y7JcnwNbG4/MMTSw+Hw2GpuUpyqNLmlJJxjTpq86tSXLSpU4SnVnCEX JeRnWbZZkOXYrM8wxFLD4TB0Z1qtWq1GnHkirRvJPnqTk1Tp043qVKkowpxlOUYvyY6tbLqWqBnU SC4t7JYwVZ3a2iUOqbBvY+e7IqkElkIHJOPzW+KP7Nv7RH/BUz4z6v4O/ZofwmfhB+zOZvCmv/EX xprt/pHw/v8A4veKlk/4S5NHu9I0zxBceKtS8I6Np9p4ZaPRrGRNLu31d7y6gi1CzNz/AE8zf8E9 /wBlzU9GTR/EfgvXPEaTQtFrF1fePPHGn3PiBpW33b6svh/xBo9s6Xrlzc2trb21m8cklv5H2d3j b6l+H/w68BfCnwjo3gH4Z+DfDHgDwT4etltND8KeD9D07w7oGl268lLLS9Kt7W0hMj5lnlERmuJn eaeSSV3dv9XvAX6Ldbwz4yjx5xRj8qzHNMtwVbDcO5flsa1ehgMRjYSpYnMcZiMXh8N7TF0sNVxG Gw1KjSnSpvFVa/1hzpUb/wAW+KHi9R414ehwvlGEx2CwGIxVPE5ricVKlTrYuOHlz0MNQpUatdQo OsqdapKpU5pOjSjyJ3a/lO+Gf/BtR8TZsv8AFv8Aal8DeH0AQpafDP4dax4llY7sur6n4q1nwvGj BeFlGkTBsAeWoww+4PAX/Buj+x3odtD/AMLE+JHx3+JeoIQZ3XxJ4f8AA+kzYZCVTTvDvh1tQijf aysv9uuxRwN+9d1f0CUV/bEswxklb28kuqioxv5tqKf4n89wyzBQd/YRm+9Ryn+Em1+B+b3gD/gk T/wTl+HMthdaP+y14C1q/wBPKNDfeO7jxF8QpJJEHEs9r4z1rW9NkcnLEfYVjDHKooCgfbngn4Qf Cb4aqU+HXww+HvgJWjETDwZ4L8N+GN8a7dqOdE02xLqNq4DEj5QTkgGvRaK551atT46lSet/enJ/ mzqhQo0/4dKnD/BCMXp5pJv17hRRRWZqFFFFABRRRQAUUUUAFFFFAH5R/wDBaPWLXS/2DvG1tcMB Lrvj34WaRZgkDfcp4z07WXXkEnFnpF252jKhS3IUg/xj6rfNrHwc+MVi6s76X4d1RkGFeUxz2GpY VY2b5pA1nujDLsdnUkkNiv6yP+C+l9PbfsofDC1jd0hvfj/4f88qxAb7N4D+IM0SsBw37z51B6Mg IwwBH8n2k6FNffD34v2kbhZdd0GaxgdyGUp/ZGpPK2SdpVJLsq68IU3RkAnK+7li/wBixElq3Oo2 tFe1Knyq76XcXru1K2uh8pnsn9ewcW2klQd0tbPET5l57aK6bbSV9n+aOjTi50e0AKiOWyACna8g VodgEgi3Rb3xh40YmMk7yVQoM9IYkmE7qC9pDbRFYIjFbLGscTNGsDcI6HbIX2IxJdjG2zc/deCP DXhd/D2mXMfiax1eRdNjvbyx0y8sreGMW88i3MkTmGe6ltbq0iVFdkIhkLKvmOQIszxbpenaLcW9 5purLc6ZqYbybC6SG51XSb1YzbyW11dQW0EWq6fPcWN01nqdvLaTh5Ba3NipW3lm9dwkoQm0k3p0 la9rO0UlZ7KyffRWa4o1IOUoqUm02nzaJtOz0avflTdnZu1+UpWzA3Mj4C/KjKwXIYBpfkyFw7/P 8yjldwYhQQRNKxADbVAAbDnk7WBwcAB2BPB5HXDEZIrPWXbOVEiP/o8bsAyswLSSoFEoJD7hGCin MZC5yA4Wp3JeNCAuMFCOeWADZO0AjZkZUNy3LKRzUpbWtFNt6O3VLV6Lb9eglrJO6t7uz0tZa2vr ZWvaOl1oz3D4R6BqWq2U1yWS2tLzWNWt7S4jsri8klk0jTNEuJIUhs02RzvLfCK2S9u4GcRXUi/6 PA0h72Gy8U3/AIr0vwd4Tt7bxD4h8S+K7Xwb4RXQ51uLbxJq2qanFoulHRp7prVpIdSv7q2FndXB giIu4Hn8gKHCfs5atpGjeDdevLz+xrrUJfF+ttaadqNtrF5ceXB4b0g213BZaay2d1BcXMf2J5r8 2l1azyxXKTTWtvcIL3wo+OOj/Cj9qf4IfEzxbol7qukeA/ip4Z8eX+jaPPDBeazaeC/GGi+KdS8N 6K+q/ZYm1a50exkn0/7bBbm6gtJpXdYY5Gi0hJ30s3y86gk05SfK4JaXW0IqzWr3OfkTlJyUkuZx U5XtGF2pOKtrFL3npK3Lo7XP7hP+CQ3/AATz8XfsH/CTxxc/FbXtL134y/GvWNA8ReNLTRZjf6R4 L03w9pt1a6B4KstbkWN9cutPn1bWb/WtTt4YNMl1PUZbfTftlraR6ne/rqeATzwD0zn8Mc59Mc18 +/sz/tRfBT9rr4X6X8XfgR4ytfF/hLUJXsr6MxSafr3hfXYIYJr7wx4t0K5C3+g+INOFxF9psbpN k0MkN9YT3unXNreT/n9/wXQ+MfxE+Dn/AAT38fS/DDxXq/gTxL8S/F3g/wCEkvjLw7dSWPiTw/oP jGbUJPENzoF/E8cthqN7pWlXGkC8gkiuoLTUbp7Ke1vRb3UPyFadaviJyrJxrTnyyi1ycrsko8v2 Ukkknr1d5O7+2o/V8LhIui+bD0qblGSlz80dZOXMtG5O7drK7skkkl/LN/wWx8T/ALOnj/8A4KP/ ABVs/hdrnw41qa38H+EtP8Xz+CbvR72wn+KOnWetReMIdbTTzLpWqeJ7KRLKx8SzRNLqFnqUT22q TLqsEyR/n5+zfrGs+INX8U+C7ISXWo6BLpsX9vSI2oeINN0LUdPg1XRo4dRe6s55ms57i8sruWed 0vNKTSZdUeU6e8svwz4Z8CHwZ490K11zV7H+0tP1FbnQdM0Y3OoahfSTSSpbatdWVvBJeWukossk 9wZIsvsljuri28sPL9weB9W8KfDvWtb1TTINeFjq5a5v7ywkWPVr6+jsdMsBO1s08VubVbDTpLW0 sp7s21q19HfT2mqm2a2vPoMJTlClScnBunKcE3bm5eRtaXUl7zjFq/8AKndSaPmcTKVSrVcY8yqf vFo1CLu7qLaipWaUkk4ty+1ZXPgz9veCSz+PGq2OoarqOp3k3hLwoZ5dUFs1zpz/ANnSwPp0UGnw W9jFaQvA8lpFZxvAkEjBppZTIR8r6tZ3D/Cr4Z6nLqbXVtb6/wCP9B0+yMa7bC2tZdA1ZnjmwJHS 5uNWm3xv/q5oSVOGIr3/APbN8Z3vxD8c23iK+J+0ab4T07w67SQW63N21i9/cfaZTZ21nb+bIdRN vHbwQIILe2t44xJJ5k0nzh4jvYrbwt4B8LpOskuj2msa3qccUokht9T8T31vdS2ylQF+02thZWMF 5ESTHIoUgtuI8/ENe1rqL0dktdHaVOXTdLl0X3qx30FL2WHUk1KDfMn25JKTdnbmcpK/bzPpf4H+ Ib/TdNSS3uZYiQZrdVQ+TId0x/d4+bcZZJCY0IMiu0jNiJAPqU/F7WfErvbQWEls9hpWkR3Tzsph uLlLnWGiWOZShaBWOMSomArli43OfK/hr4a0pPBHg7yreITNoWnzXEkimMtNd26XMkzgM4MkhlxK inOPkDEYFen2uk2sLzvHtKTpZs4IUKpgM6qdwwR5ZbaFKqOBkEsSfVoynClShzKy5bJR196zaWu6 badvddkrXZ5dT2dSrObir8zSb+G143/7de+lu97syLnXfEd/G7u4TEJgJRmdpFVMOfMdy27hMMuy NoxtVQwbOK8Ou3oBkvZ0QiQkAsBudHJxwm1Gy2cHk7WVS+2vSYtOgRFJK7gpYAqCNxJ7Z5YjBBJI PzDOQBTFtLdgQpCgMQCM5AJJL5Zckgj5gSA2eCFwwrVppLRpu6d79dU3d3S0u21fRrUUZ047Qu09 0lzXXVK+ivfzt6nAR+FpJ9rTTSN03bizR8MXztbIJWTdtDdjyoOTVtfDNvANzKC2RhQOevAyoKMp VuByVIwRwXbuwsca7k5di25c7PMGNg2q5OcNgEqBwd+c8VQmCBMvhmPyg4wnA+bHzE5UlSx+bjdh SeBlZtttaKK1covole7b93RvXdJW6mqle/eXvPRf8Ona11fc+JPjloN5qfkaRYWj3F1ezX3kwRRG QSi1sZJ2cEMzebmPMJIYiSISE5UB/CfAfw81O28YaXY3+mz2upaluttKtZ4WEonkYQSXkKDeZDub ygSPlEszqHcKR95+NrTTobrT9ZuJUtmsJZkV8qGZ720mt1WLcQFdvM3cElkTjAznlfgo+kaz+1P8 OblLu2uodO0HxBqKxho5f+Jho9pq1zbR4PmfPLJKkqkqhzErDLEFfOq4dyqe9K0qlSnBLRpxlKKb stWknrbbveyOuFdxoza1Uac5uV+sUnbba9tXd79T9YPAGjeEPCXwpbSLs6j4c8O+A/DWl6ZY22nR wG98YfGXxHpUmoSWepTTktaW9v8AZrvVdcv0hnNpaWdnpdu0EuqQSLw58Qa3qOlL4ck1WeTR4ru6 vo7RmhhBn1GJoL0vcGIXbwyLLOHtLmeazjNzcvBbxyXlw0vReMIrKX4W/DqJdX0uWbUdV+IPifU9 OguTNdW09zqej6VE+pW8TL9nvHs9FhS3tbhmc26ecpeCYyN5VJcWkEtu1hOIpbYEtLHGzRFmYNx8 jCBAp2sOUYxnL7mFdlKnN80mpcqt7ODclCEYNQjFQSi4OKjpKLcpWbfvO55ShGzmneU2+acvedSb s5Ntu7fM7JP3YxS6ps6Cazm0+IYljlgbaqyRSM6OW3ZDxvhsuu5MlgDl2wh640t9OS0cFveXVwba fUJIrCGe6uLW0hIW5vp4rdJprSyt2y81xKIoEHLuqgk1bjWxs8wSKJt+7c4HzS5K5ZSqiQKu5t5V h97cW3HP7LfscfFL4X+Af2dfhf4o8A/H7wP8D9Y0Txx4ivv2uoJ5lv8A48fEgyareJo3gjwV4D1P wv4msvG3hPUvAUOhWfge30qzujaeJNU1oiCz1j7fqMWOZ4yrgsPTdPCyxVarOFKFKm56cylOc5yj CqoQio2Tmlec4Lm1R6WX4Wji6tSGIxNLCxhh6tRTqOym4uKjCKenPJySjrdvRRd1f0z/AIJ3arcS /s1aXDe3TXBs/G/jGG1lMiuGs5v7Hv4SrL/B5t5MFyXDMC+4k5H3PHq9tGWLSKFwASzgHOOeuOg5 4HYk54r6l/Zv/wCCV2haV8NfDd34j8a+K/AVr4ovfEfxCufhf4e8P6JpFz4JX4ieI9T8Z2vgm81O 7k1dTf8Ag3TNZsPCdy1vZLBE+iiC1L28MUjfaPhr/gnh+zTobGTU9E8V+M5CF58V+Mtamh+Xqfsm iS6HZncQCwaB1OAFwvFf5UeIv0SPFDxB8UeOOJsDT4Z4fyTPOJs0zHBVczzac69TDYjEyksT9Wyr CZg1LFO+I9nWlRqx9papGMk4r+5OEvG/g/hfgzhrJ8RLN8yzLLcly/CYuOCwEY04V6OGpwnSVbF4 nCJqk17KLhGpDlgnFuLifkBceMNFs2PnahbqSACWlRcZLEAlmAAJXaOcHbkVraVquq+IZ4bTwz4d 8TeJbqfiCHw/4f1jWHlyVG6M2FlcL1YKTuxyM4GSf3n8L/s7fAnwbEkXhv4SeAdPMbF0uG8NaZf3 octu3m/1KC8vmYNypa4JX+HAr2GGCG3jWGCKOGFAFSKKNI40UDAVERVVVAAAAGAAAOK9rIfoCSXJ U4l8RYqWntMNkmQ86/vKGOx+Optve054D1pnLmH0m7c0cp4Vcmr8lfMsxjHX7MpYbD4Wd3fVqOLW rdpW0PwT0T4E/tJeKGZdJ+DfiawRQB9p8T3GleFoMNgjYut6hZ3LgZG4x2zldpyo2mvYdB/YY/aH 1mGGbW9d+Hfg4OR51q+oar4iv4k4BLLp2m21g82MsAmpOpBUGUHNfscUBIJ7dP8APX9adX7Lkf0K vBvK+SWYLibiCceWUlmGcxwlCclulTyfC5dVjF21i8RPffS58DmP0g+P8ZzRwryjK4Svb6pgZ1qk b/38fXxcJP8Avezi/wBPzl8K/wDBPTRLa8huvHXxR8R+JbVFBl0jQtKsvC1tNKCMrJqDXOs6gbdx lWSB7WfBLJPG3Ffd/g3wP4U+H+iW/h7wfodjoOkWxJS2skbdNI2A9zeXMzy3V9dy4HmXd5PPcuAA 8pCgDq6K/feDvC/gDw/jUXB/C2V5JVqwVOti6FKdfMK1NWfs6uZYypiMfOm2lJ03iPZuXvcvNZn5 ln/GPE/FDh/b2dY3MYU5c1OhVqRp4WnPVc9PCUI0sLCdm1zxoqfL7vNbQKKKK+9PmgooooAKKKKA CiiigAooooAKKKKACiiigAooooA/In/gtp8Ob7x1+w9rOsabaTXV38MviL4G8eMkCtIy6ebi/wDC OqyyKqn9zDZ+K3uJGbCRCESswEeR/IjpRW08Ma1FIwTzdNukcjemM2sm4MOijj5gDnBzngV/oYfE bwH4e+KPgPxf8OvFlqbzw5418Pap4b1iBGCSmx1a0ktZZYHIIjubfzBcW0mD5dxFE+DtxX8Q37eX 7I3xB/Y+1fx1o2sWNxfeGH0bXtW8I+LrSB/7O8S6N9lm2XcCr5ps9Qsi/l6xpT75LC5GVMlnLaXM 3r5XWio18POWlS9SCezlyckl6tKDXmmfO57h5zlhq0ItpONGo0n7qVXng21dpOcrN2snGPVn84/h /Q4re3WJmWVEnnkhjYO0UUTXEzxmJXkcxkCRgdoKlmfCINoXpb2zE8C24RAqhWztKeWqvEfkCOhU 5ClFXmRwobzAGjNy0n0ry18mR5XMYkBMJREjPzALG7RkleAXchF2jcf3igVo9RSeeZLeMomwMSZF cymMBUed081FMb7YUgDcBvNR2IkavcTikopOyUVbomlG2nNZpq2tk7Jp9zy2rt+67uT1cWlZtXfR rV6tWdrjVZvNKjn5F+ZdoQiMyKFJY7izNndgsxO5twVgBOhZEY5LEqNxDFCeCRgllY5U8jlWyBkY JrOyVupA+FXyk5Qd98oVwg+T75BBQcqTxlji+pCjGVdyA24BGT92pztK54x0fggAFUJORVl8TVmr t6pWadtHddlb77IXk9e7vs7J97NtO/zXdHs3w68Y6ppHgfUNK0s2yCTxVql9K09raTzOkltpAWOd ZMx3tl/ouYrbUra9hhbzvIMaSyLLyHiuGy8YxagPFgOsLqVzDc3jtcSWlx9ugKSWd1Y3OnyWk+l3 9g0aCwn0uW0ayWP7PbGOFAlcD8LvG/gO4+P/AIU+E/xJ8exfCb4eeJb/AEfT/EPxc1Lw3qPiXw94 Ak1mP9zqmv6Ro93FqlxoUc5sk1m909nOkWU76pPbTWlncgf2cfCL/g2t/Z91C10bxR41/aw8e/E/ wvremWWrWLfC/wAP+C/Cuha1YX9ul3Y6jpPiO6u/iJ9t0q9gljuLO8sSUurZ1lgudkgYc88yw9GP JUk5Sb5ZRUHJc0fiTaS1aWqvFqSTVmk1eHy/E1pt042gmpxm6kYtqXvRtZ83Km2npuraXaPMv+DW qyn0PTf20dEttf8AE+raI2o/AzVobTxLrMetPZalNY/EzTp5rW4a1t7xWurDT9PiuTdy3ck32O3J nJjIr+kb9rL9lz4Z/ti/A7xb8Cfita3b+HfEi2l9puraZMbfWfCnirR5vtnhvxbok33Bqeh6iqXC QTrJaX1ubnTr2KW0u5424z9jr9hL9nP9hXwh4g8I/s/+FtT0r/hL7+x1Pxj4m8Sa5e+JPFniu80q G5t9JOr6rd+XClrpVveXcWnadpdlp2m2xu7uZLT7Td3E0v2HXzeLrQrYidWmpRi3Hl5neXuxUea7 cnuna7bto2z6nB4eVHCwoVbSaU1JXvFqcpNx+GKtaVrKK+erP83f9rv9iL49/scfF2X4P/EbwjqO v299FcXXgv4keCvDesX3hz4iaD9pSWDUNMubbT7i5jvrCW6EOpeHNQlmuvDWpPKkKXVpdWmoX3Oe E/2DP26PipY6fdeAP2T/AI+a1ps6LHDq1x4A1PwvpVzE+9PMi1Txivh2ymi28eekzp/HncSK/wBK oqpIJAJXJUkAkE8Eg9sjg4pf8/5/+tW8cxqxhCPJByguXmevMm1rKL0v3s9e3Q5v7LoqTaqTUHtB 2bjttJ6206pvzdtf8nn9sL9hr46/AL4qeFvBH7S3w41X4W32saRaeMbTRdSutL1E+JfDK3E9oW0v W/Duoapol0y39u1nrUVvqT3+kgrHf2kE1zbNL8lX/wCztoDajcT2Ooiw0hp3mj0yOAyvGru0wtbd jhYIEDFUEQPRQwO3aP8AVR/b7/4J/wDwV/4KEfB8fDP4qRXWheI9AuLnWPhj8UdBt7aTxZ8OPEs8 CwyX+ni5KQ6rompxxw2viXwvfSLp2vWUUQaSz1Gz03U7D+Bz9sD/AIJ6fHP9hz4hXHgv4y6fJqen 3sl2vgb4i6Np9yPAnjnSkfC6hoV67T/Z9XEZjOq+HtTaHV9GeRke2mtngvrjfDOnjJvnUVWsvdu0 pK8E3BdXZXcb819dVocOMpVcJyyUpuhZRTspcrte07Ky2dpPlT23PiDTRHY2lta26eXFawQW8UPG VggjWOJQMD94IooxknjCEkYJHS2m5/NeMcARRAj5j8u+Q7mYjI5BZSCF4ZvugVzlxZ3EVwsCo7M7 hY0K5dmZsKq8AAlucjjGecE56pEXTYEScpFhyJPNZYy0kg5Me7J3NwoJbgKoGC2D7EY2slfSK+HR bpt63vLfa+umh48pxsmt3rppdLl1VktOnV9L9rrD5GDFWVSOMMSccfKrEAbgcZwDzzg5FQFlGdp3 FVIyMDcR90HBbOBxgYHGcLxXpHgn4Q/Gb4qX0OlfDH4QfE34gX1zj7ND4N8AeKvEazEgAMsml6Tc wFQGAMjTJGNxLkcY+5fhx/wRv/4KWfE9Wl0z9mjXPBlorqHvPih4h8KfD8APlhIthresDXJUVG+b ytJkKMApG7IqXUpwac6qgr3lzTXVJWu396TbvutrqnRq1dIUqk9NOWLlra3RO726q9tWz8ziAwyA 3mAOeqqN/TKrhdvy7QwU7SBuOSSVpSWRnV8kKADtUyBcNhfMJYENkjIOMZAJPbP9Hnw3/wCDaT9q bxC+mXXxV+Pnwb+HNjcBH1LT/C1h4s+Iuu2KPy8Mfn2fgrRJrhBkMU1Oa2d87ZWUhq/SH4Of8G2f 7Jfg26tNQ+L3xV+MPxpntLq2uDpEc+h/DjwpeRQyLJLZahp+g2upeIbizutphnWHxVaSNbs0YdWI deaeOwcb++5aOPuRbutHrdKLfTe1rb2O+ll2Nnr7LkT5bc7jHRNNKS+L3bWVorTRI+DP+CIv/BIz 4A/tI/CHx5+0J+2X8CtK+KvhvxL4s0nT/gLpfjZvEFror6R4YttRg8XeM7TTNN1XTLLX9P1vXr1N As59Xtr6zV/C+oCyj8ud5H/Uv/gpF/wRu+BXxj/Zt0SH9kX4H/CD4L/HX4CeJI/iZ8Jofh74H8K+ ALbx59j02fTPFnwq8SX+h6bpy3lt4+8Ny3Fho9/rcs9vpPjC38PavdzRWkN+8n7b+FvC3h3wT4c0 Lwh4R0XTfDnhfwxpVjoXh7QNGtIbDSdG0fTLaOz0/TdPsoFSG2tLO2hjhgijUKqqOpJJ3yMgj14r wquInUr+2TcWpRcVe6ShblT6P4bvu27WufQ0sHThh1QklJuDhOdlzNyXvNOyattHslHex/mOWdlo fhTXvEvgn4neGvE/hHxPa6zdaHq41TT5bXXPDMsDGDUvDk2g6lZlvDvihLktp8up6jFeW+m2c8lw LO1mjsNZt+O8U2fhOz1Oew8K3d1e2ENvAZ5ppLOe3W8lZ3uYLC9gldLywts28UFxJLPP5nn28k0/ lrO3+gb+1z/wTF/ZN/bMv08T/EzwbfeHviPHBBbH4n/Du+t/DXjK/tbSJorW08QSy2Go6N4pgt08 uK3k8Q6RqN/aW0MdrYX1nbr5Z/Ki9/4NsvhbLczCw/ao+JNnpbzM8VpN8PPB93qEcW8lI31GPUrO 3nkRDt81tMQEgOIl+5XrRzKhJqc+eErWlG3NG7tdx5V8K1smlbueHUyvF0pclKMK1FP3GpQhKO2k lLW7ercW79elv5DpZ4XlG+dQgXDv8gjAyVP+tJGR2KkhiQRyAG/pd/4Ix/8ABLLxL418TeG/2r/2 ifCV9oPw58M3dp4h+DvgbxHafZbz4h69Glpc6V441fSpmNxB4J0SVftmjWGp29tL4l1eO1vvIfQ7 MNq/7A/su/8ABFL9h/8AZm1ux8ZnwjrHxq8f6dLbXen+KPjHe2PiKy0e+tgSt3oPg+w07S/CdlKJ SJobi/0rVtQtJkSS1vonUNX64AAZwMZOT9cAfyAH0GK48Rj3Ny9inDmjyObs58j+KKsvc5tpNPVd j0MHlvsmqldpyVnGnF80YtNO7k0uZ3S0Stondijgevuev40UUV5x64UUUUAFFFFABRRRQAUUUUAF FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABXgX7Sf7OPw4/ak+FniD4VfErTxcaXrFldxafqsE UTar4d1K4tZbWPVdKlcZWRY5niurYusF/as9tOBuSSL32imm4tNNprVNaNCaUk1JJp7ppNP1T0P8 xn9vL/gnn8ef2C/iVq/hL4jaBe3fgDU9RvF+HXxd02wnm8GeMtILn7I1vqaI9vpPiW0heGPWvDep GDUrW6DzQQXWnz217L8M6fb+SZkbO1suCrsjSyPg+fMQWZyYxG2WyHdWYFfun/Wk8YeCPBvxD8O6 l4Q8e+E/DfjXwprESw6t4a8WaJpviHQdSiVg6Je6Tq1td2FyEdVePzYGMcirIhV1Vh+WHir/AIIT /wDBL3xVq8+s/wDDNsfhq4unmluLPwZ8Rfid4Y0aSWdi7PHoem+L00myVGYmKDT7O0tYhhVgCAKP Uw2ZypxjGvGVRxWk4tXk+84u1mkl70Zq+rcdTy8TlcajlKhP2fNr7KacoJ3V+Sa95Rb5moyhJxvb nluf50F7MtvdsEzhoNoYkHaDLIBsyVIBAyq5wCRjAxVSe8ZFyX8pR91gyqOG3MpPGVUclc8ZG4jI r/QZtv8Ag3a/4JiRa5BrN38OPibqkMG4HQtQ+M3jxtGnUvvCTraajZ6m6IcqoXU0ypIYtubP054G /wCCOv8AwTH+Hl1bX3h/9jT4QXl5aY8q48Y6fq/xDYkBhulTx9q/iWGY/Mf9bEwzg4yAR1SzajdN U6k7PRPljpayT1n6Np6pHLHKcRazrU4bbJ1La7axhv3vouh/mM2XhHwj4k8S3N5d6Fq3jXW7y4tG h0XS9Yv1hdYLdLURHStCs31W7eULAQI7mMjYyqrb1Uf6Hn/Bux4a+K3hH/gnHomg/FDQfHnhWytf i/8AEuT4V+F/Hun69pU3h34VXT6Jc6JpPhPT/EoGsWvgWDX5fFEnhyC4LQxJNdJYEaetqq/sJ4A+ BvwU+FAI+F3wg+F/w3zGIWPgPwD4U8Is8Q24jd9A0mwZ0+RDtYkEopPIFepV52JxkcRDkjh4U3zc 7mmnLmbbevKnrfvbur6nfhMDLDT55V5VPccOWzUV8Nmk5SaemvfS+wUUUVwnoBRRRQAV5z8VfhF8 Mvjh4L1X4d/FzwP4d+IPgrWowmoeHvE2nxX9k8iq6xXdszAXOnajbiRzaapp09rqNm7GS1uoZMMP RqKabTTTaaaaabTTTummtU0xNKScZJNNWaaTTT3TT0afZn5E+Gv+CGX/AATd8O+Ib/xDP8F9Y8TN eTyzWuj+KPiL43v9D0aOViTaaXZWms6fILZFPloNQub+fy/ledskn7I+Hf7Cn7Gnwohih8A/sxfB LQnglWaK/b4e+HdX1hZlIKS/25rllqess6EZRmvmKHJUgkk/V1FazxGInpKvWaslZ1JNaeTdm/Np /izCGFw1N3hQoxfRqnC6ttZ2urdLFe1tLWxt4bSytreztbdFjgtrWGO3t4Y0UIkcUMKpHHGiAKiI oVVAAAAFWKKKxOgKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK KKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK KKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAP//Z /9j/4AAQSkZJRgABAQAAAQABAAD/2wBDAAEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEB AQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQH/2wBDAQEBAQEBAQEBAQEBAQEBAQEBAQEB AQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQH/wAARCAFkAZADASIA AhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAAAgEDAwIEAwUFBAQA AAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3 ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWm p6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6/8QAHwEA AwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSEx BhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElK U1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3 uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD+/iii igAooooAKKKKACiiigApCQOtLRQAAg8iikyOORz056/T1pN6ZI3rkdRuGR9RnNS5KNr31E79LfNX /VDqQkDqaaXUAEMuD0JI2455znHb1pjlShcsFVQSXzhQuMlg3IwAM7icAcmmndXs/mgvb4n9y/S+ o8yIMbmVckKNxC5Y9FGcZY+gyfal3r1JI5x8wK+3cDr29e3Q14B8Rf2mf2e/hJBcy/ET42/DHwk0 FtLdyWOp+MtCTXDFEC2+10K3vZ9bv/lD7Y7PT5nJBVQxwD+cfxN/4LgfsZ+DHktfA8vjn4wXX2ee SO88JeGr3TdGe4hIAju9Q8ULossAmZm8qVbaRSEkOVAG7WNKpP4YSettt/T+rmFTE0ad71YLWyT3 6b66b37WW5+zZZRgE4JOAMHJPXgYyeO4yKQSITgMG5I+X5hkdRkZG4f3c59q/lh+I3/Ber4za7DL F8I/gb4L8FwyCRLfVfHPiC517WYAdwW8Gk6XZvpkqqNrGGXUEJ6bmXp+eHxP/wCCkf7dXxZaWHxD +0BrvhzT7yN7S60T4dWNt4J0u7spgRIJYLOW7ef5Pl+aeJ24JwTz10stxVRcz5YJtK0r8y2u+zvf T0+/gr5zhKL5bynK124q8dbW1vfe6e+632P7dvGnxL+Hvw8tWvfHfjfwt4PtVjMvmeItd03Sd8a5 3NEt7cQvKBgjEYY5BGM1+enxR/4K6/sL/DKRoV+LM3xC1gpLHa6d8OPD+s+LILyeP/lgdbsLOfQb TJyBJc38MYJGXUZNfxh63d61r9+tz4o8Q+IPE9zcI91Fea9r+patqUlqzM00Ll53hgmY7isThXwR hSOKoW0EjhLS1jhtY5HZFJU7kKZJcskfljd0y0gByea6o5VytOpKV1a3I0u19ddL7eWr8/MrZ/Oe lCnBJfFzqT3s1Z3W3XTU/o4+In/BwHFuji+Dv7NetXFtvuo5dT+KHiXT9LiDqG+z3FnZ6DdX0ht2 OCYy4ZQCMLk4+DPiF/wWF/bx+Idubey8Z+Dfhbp90bhmt/h/4dsb7VxayEiCGHWNX2XsNxGufMnt CSPkZMncK/MRIpIxGQswVo5JFW4KyRythgDDBGX2KxHyqMn05IpNPhkmijE6G2jBkJlETLNbknJZ EI3fvOMrjKqATgV3UsDh4tXjzO32nd30vbzut106dTgqZliql7yUbu/uq3Z20dnqr63Z6D8Qfi38 XPi5NHcfFf4qfEP4mvDNJNE3inxNqOo6fZtJgSra2N25EMoEcYnWNNjBYguQorzW2gtbVHMdrCn2 qRo3vIIijiNicGVnCqrADACnHUnHGLixxRxuVWbPmbYgWJjnL53yOw+WN3wCVYgjAxTpBGCtsls0 DTFI5WMyyRqJDy2xSWDZA2sRgZzmtoexhePsoKT92Ltqnpyu/Vu7a0OKdWq7ydSXe19Omnn82VgS 0sQiwxCtBD5kCB2A4815CAQo+8WU9OR1zUy2izIqENGI2V3eMHDliAOegBJH04JHJq66STyqzOqS RFLeCJIypMKYVy/A27gvDHg496R7e7+yuNwhQiEZUjJIZSQMHqAM49hxW8Fpvaz6JeXkOm1N3mlq vPXbpdLa7tZ+fkoiJKxebbySxwmO3LMiiEgEskqOwaVsA/MARnvVKSSJka5eS7SFHxdxQhgpUcOi lTlFJBIDYIDAjINSRwSSShmQDzLhSLmSNkRVAP8AE4VQemRk57c1sCwJuGMjpFhcI7hY4frLCxBl ZuoIBzkY7VEFO+6+700v/wAD5mMacYt7vW+uvb7/AOvUoxLHMsBismgs5DI8cxWViISqBCwQHO5g 25scdTilUzDzfMFvCZI2td0SvIzRsW2srAHDck7RyMjcBitdkVY1QyeaWHluEkROOeY4shlU54XH r2FPjs44ZPJgVoFLQsXuGDyHO4jYp+br9cjjkDFVOLvF2Td7O+3Tbs9OpqlKPvaKPS26Xne/yXYx re1SBFWOPzrlojApuvMWLZFyTjBIY4+XAIB+9jFasMcYgaO5lM07vHNbtblECCE7mhdJSsrIdoBC KSwOFBJq0oAlEc0kcy+cdrNiNl3MVTBYg7C2RkYBORyRUU19aWyqGltbaVJJI3muCiRhWBXas7kR hjxglh830rV80rcsYpJJNa6NW3131X9IHOEtbydrLp92iffQalnlJDsd2ckpuRk2ZI7sB06EDOB0 qdbEJCyTqgIZSJCGLLwPvKAWAA6kjbjvjFDXkUITzZgd5BjCyRMXyfl8vDfMGzxjOevPWqc92ltb TX84j0+1ilWHzGnWFpJZCFVZBcmLYXJz82AT0Nc1WEouPNs30+Xl5/Ix+N3WiWz89On/AATTeGKN 3JdrhfJQzJZAzNN5hKxlpIwwQnaUIJBG35gMiqsiNBA0cg8uOUkG1RWFyIgVJI4zK0ZYtIybgoKl sCsOfWk03UYdI1OWx09J2hZ5JNQhEsgKGeKMppzXk7O6yIRHPFCzBl42sDXMTeLvD4GqXPiC6u7G S0e7i0nTksU097tsqIrxdR1SWxihQEHfIzebLGo2RMAM9FJpQ5WrK+6Wrem7/ryN05yXJ7rW+zT6 JdWd/JeNFGYkuzc28flIrSmM7IJP9cIJSdgaOMjL7sMwMakurLWdcX+nQXLyfargQ5jVEdku1MKE GKWQWpla3UuBnzQgUElgBkjwzVvjd4U09FsDqOgNdQsJr2eRrzxNfXbCJSiWa2NtJbQqjAq8M00a bskM2Tjyu8/aGi1LxDc6nJoPiySC2t4raOKxaw8N6NqMZYRlbgR3M8jRleZIxH5sikrtycHN8kG3 FvdvV6a9/wDJddBwpyg/dtro29bXsvL+vOx9bjXLG4bXItPkWePw1Yx6r4re6DWFnpdneKPsy3V1 dCKES3W4Ktsjm4O7hOleF3/7RfhCI2sem2OoavBb6uthqV5ZaWzQWluG/eXsMrxiKf7KmXRWYtKA AisTXzl4i8e+J9X8EQ+BvDCQeFfD+q+Lbnxr4yhmvn1O68Q37SmbTdM1fUJkhuJdItPlC2cQkWMY XZnCnzKMfEQx6qlx4n0hlvbzOmC00xrWLRYI42A+zQ7B9qIJG0uF8zOBz1wnVk/hS+fn13/XzOhU HNJydvTbpdd/63Pq/Uv2t/GOnXmq2vgLQ5b/AEu2Lva3Wu3NvZy35h+Y5tI3Ahi2EELKqFgdqg9K uaN+3j8e9DTSdavPCHwwmt9Qdk+zRLc2d0ssBC4lMCbVlWIxnc5CyEkqTzj4o1Gz+JQiY6Ze6Ffy G2USXE0T27SNK5jkOGQASsF3OgJKliDkAGqTN45s006HU9Di1CCwWSQR2U0XlT3ABAYAsCFIkUDc BkxnAIGawc5VWua2m9lb/P8A4Y6VTgo8vJF6WvbX17fK1vI/bz4c/wDBVjQ7aOGw+JvwR8S3J8lP K8QfD7VbSSaykRysjS6bfXEaXiPjAYI0hXAAIAFfcvwk/bW/Zk+Ml7HY+DPixB4c8V3UkgHgf4gi fwpr9tMItrrp7aklppU0kpJTNvO/mKcLnNfzIeHbvyxetdW97o16LKBZvtwkNt5mefsUiK8Ttk9E YnOc+tdVdaxbOtrDdL4d1t58IltrmkJE2FUETnU4HFyrKwHlsQu0hTk9DLoSqOSfwq1ns3ZKy/q3 zvpyzwtO75I2le9/u6Ky7frtc/r78P8Ajrxr8NtYl1fwl4l1XwdqUKwyw3uhtKqXbzsuJNUtoQbb Uba5iYoJmLxHfvDHivu34W/8FLvF+hzWul/GXwpY+I7CCIeb4r8IOLXVAHURxyXekZW1uXXh5fsf mTnkohkKiv49vgj+3z8ZfhBYadoHiDSbL4pfD61gEcOkXly8Oq+GbWPEXk6RqxWW4EaIT5cTowlR fLYxoTIv6dfC/wDa6+Avxjjt7TRPE7eEfE+I538M+N7uLRruSSXA+yWeoyFre8iaRhEil0L7hnaC SOKpRcPc5F35no9d0tdP8i6M8dhn7krUrqVtWunTTTya6N6H9g/wl/aE+D3xqtI5fAPjTTtUvzD5 tx4fuJzZeI7BgoMn2jSLzytQAj53SGExEAENjNe7K4IH3sngblIJwOTjH41/HpeW11ptzYavbwat pNzbLJe6be6fftYXkEwwUu7W4sZmWe17rLA9zKwxthJwK+wPg3/wUN/aB+GUtjo+vanZ/GLw5agP JZ+KJng8UWlsyqHFt4p2G8mMEY2W8N5p0SgKqvICWJ4nh3K7p9Fqm/Pp/Xzse1hs7hfkxTSeii4r d6J3u7Jba6vfTSx/SUssbhijqwQ7WKkHa3ocdCO4PI707cO+R9Qf8K/P/wCDv/BRH9nH4oG3s9Y8 UJ8LfFEm9ToXxHmtdFglmzsb7B4luJ10GSNiN8Uc+oxXUiOp8gPla+6NC1jSNb0+PUtE1PT9Y0yf 57fUtKv7XUtPuVKhme3u7OWeB1BODiQ5PI4IJ55RlGVmtLfjp/Wnf0Z7VLEUq0bwlf8Apf5+T8tD aooopGwUUhIAyaYZFGM8DOMngCgCSioDNHyN+OvJIA6Hvg49jz+NRxyfIrM+75FbdncAu0ZZ2+RW XIY79sS4BwMcUWfRX28t/l0/RibUfi93tfrt+rt1/Esl1BwWGef06/lim+bH/fX86+ffij+09+zx 8GbcX3xQ+MngDwbbv5oWHUvENlNeXbQrhxHYWL3N8XhcEMiW/wAzKd3fH5d/Ff8A4Lp/sv8AhRbu 3+EvhTx58ctStp44zeWtvD4G8EXPBDSweLdRh1m6dlYBWhXw7tLbf3hBIGkKNep8FKTvt0vtotPW 3ezMJYqhD4qkVayeqbV/JXf4ba7an7jeahOFYMcHCg8np29v602WREjeSVxCkas7vI2yNERS7vJI 2ESNUUlncqoGcmv5Evij/wAFwv2tPGsl5bfDXwr8NPhBpk1y72U9xa33jHxTbWYVlcXkst7pmmSe XlDBdR2UCSnc72wwFr85/iV+1N+0x8X2nf4oftG/FLxDHcSyzrp9nr8vhjSowxIENnZeFH0l5bFV d0aC8a7BVgryNgV2U8txE/iXs1a7dr2Wnp3t/wAE4a+b4alZRTqt7KLS7bvXuf2t/FX9tH9lL4Lx FviL8dfhx4euHjnljsotej1/UWFsSs0Q0/w+up3McxYbFikWFtxGSBk1+bPxM/4Ltfsy6Kk9j8If BHxH+L2rLK8dpJ/Zlh4U8PB4+BK+qazqUd19nZgHVjYhyp+6DgV/KA66T5++LTvPuGRllvpxEZmd jukea51Fbm6YuQWd0lWR3JJbOTTLjWNyxW88imEZAhELTjAJwC0ewMBxjPHTsK7KeVwVueopapu0 ba6Pr592lZO/n5VbPJvWFKUVF7Oabvprez1vfp6W6/tl8Tv+C4H7W3i+S4T4a+Dfhd8I9Jnt2t9l yb3x74m3uNou4dVmXQdOtpUJ3KkunSfMD0xivzv+Jf7X37VvxZWGL4pftJ/EfWUk3qdH0nWbbwpo JtZSS0Vzpug24u3GDsKi4wQT85yTXyy8V5K8AW3uylyjGzKRG0UDkgz7WnDNycNICe/NaNr4S8Q3 JRT5NoSPN+2X0sAPkEZAilMau6kdCwU+w799PC4WnJRlTXraN38PdN+ivp5anDUzLFVFZzdrW3dr el/+BvoWRDp8k8kpVdVuJDcTC91mS41N0mj2s6Qy6ld391C1wT8rtNGJiCFt4cEMedN5Ycor2bRN uLw/YsOSAbcQ8blg2jbJg53k4GSKY+mW+m8WN4l9LJIVvJW2MC6clUUDYVj/AOWbgbuSQQMVKru8 4hcvPbRoSWnJOHfHEeeSCRz2BA9RWskqcrU+VR5kotxV0nqrtfovkcsmp6znJtu796yTdtu29v8A hhku9pPLCgwi3QCNcJjPRt4H8OcYHUHJPFI0FuYY/wB5IxLCIxqc53HBUSD7p6nJIPXjgVK6yCSM xnMeWxGCS7AAgYzyVB7HI74q3BCQHQlUkaKGR3Kb4okBYksq4yxHB2kMTznim4uUk5Teysoq2nZ2 6/e/wvlyxiuWOq31s3r57/l2sR+VZxRqruUl6psy83fvz+PHf2pPLOfO8pVRfkKJIOd3XgY65wB6 1dhiSWOExyYm8wrNsRI2284K+ertj8eQPbi+tvEwKrbsxZt+MgFiOTxgZGBxjHsa0iqfK3ezVtJ+ 9zX3t2t8/u1abUbaW9Ou3n/X3GXFEwdQQyREDavLzr0OIhjO3nt3JI5qU2sh8zfJPcyy/JB8uxVR B9xuP9Yu75ycnkZ9RqF13uXCO4YCKOLHm24wBsZhySMcjP1qMCVHEjy3BLAq0gaNIo0P3QVKkiQZ wz/eYbck4qFFW5m1ZSSfnqtvL8du+k88fP5/1/ViiNPWNBLILeJEDKwlkd0DcebkDhZMbdmcZOQD kVH5NoUCiYygt+5ighk+0FOfMEzsBtTGCrHoDx7X0ESoZmgG6B2lmlkkSWJogCAzREBSx3EqSpJI 4PBpi3khQzpxE4FtFOsarIFLsXDKMMdwYKHPQEc4wK6aaoVYtK8ZpaP7vuVrO23m2rGiSavffo10 0/R9v8ySG2t3jli8qbIiY+S6ttU4OGNwBlgOu0Z7CmgNAsAWWzNvuO+PEksmc8j7vHBPXPXqKSeR 4UhguJ7WESuEhS+1OK1NzuP3VAAYl8gD5hg96ypNUs5LwWjtLPdRsI7xtLR5pYrrOITKht4rZbYc bpo5TuAyTzWKtFuO+u/TZf19wad393p5/wBWNsrAUm/eNKJm3F4xvbAwQDB/yy+uOB16ZppWA58q ONTCNzPcz5DkAAsufT2zgjA6YrjdR8R/2PcSrr00FnHbxNLda22tafpFs+nEf6swG1u5DOM4Yqd5 OSD0FeV658YvhxaGFLXxGmriRSktroenXmtXKAk4UaibvT7V2IYHzktVQEnKHaSZhFr4qiXlbXp5 2uvNfPoK0v5Xv57d9j6Ck1SGNokJtIDMxLSAS3CRr0Egjigc5OD8xlUcAYHeXbJPE9yXjnsY5Ezq E13Z2VqMkgt5TTyXUgjzyvlxlMjGS2B8Z6j8cQYLqx0Lwx4gdld/s93r2sWtnBPA4AWFobLTvNhh Xkg/azINzAthVNed3fj7xtcQGztLnS9FhmlV5LPTPP1Dy2kznN9qElwrMxXkLGuGXJJ4xrz04Ru5 e0bV9Eo2vbTre3fS700660Yyqtxk+VR0tbovu/rr1PvPVdd07Rft1rGkOptZRBI/s9q89leGQeb5 U89zcWaRBS3/AB8ecBD98JJyK8zvPi9pOlwJNe3Xg+0uH3I+i6jqgvUMRBDW9vDYWuoiSWZfkVnn jwzcyIOR8TXF1qN472+q+IdfvGuYhDPH9tmS3KSOyy5FrJFDjbgHchO3AGAOYoNGsraKK6js7S28 hisZiWO4upDGSYyzSqxQyEAMQepyScZrj+sy5+XllFaPdW+7y11v06aI2VCCe9l5J+Wu63877bd/ fov2g0gGpHQPB15BbGaT+xGEcaNIh5ufNur28MkJY5Nrm1XAwABVDT/i7pN/qeoX3jXwXr/iKwsk 02/03wu/iVLK21C9EjLOuqanHayGQRArILZLWNmVQocgFq8cHnIAZgrSTNvmKzI8ixDoBER5e9R/ sgg8Y6GmpJE8zQ4KrneGOBvbqGORjcB36jt6DSUudRcpWtqou2t7dXb8np95ooQilZK7VpaWT2a/ Fv7vQ1NZ8T+INb1W9vrbWLvTNPa6mubDR9OiVLfS7F33LYLdX5W7lkt8mNJXAkbG5QEKAc5eWsGp vHLc3t5qbl/OKX17evMqcAiSNg0e4MGORlSCADjmttIWu5oopGlmVW8wDdGAZx8qbnZSzIVAHzse fYCmXClZpVe2WGRwGmKSBgW5X5WUAImxV+QcA7jjLZKcpWcYx3a977unnt2Vm/SoxV/hX5W1Wv8A wChFaWNsFNvZwoEZ3EgRQSzjBXfjcSMDGT79c1LwIQrxFwCWCsfkBxkEDnJHbj2HNSKQJSpeMRLG rCN8h5GOeIgOGcYO7PY5xTZnASRZUeMNxGST9oCscEpHjaUx944yi/MMVhJT1bbSS7bfj59P0Zco +67Kzto77PTfv1+75FZYo4wA8bMJ2BCKOMk/Xp34/ACphFHHbqsyOZ4pTII8HPlE56dcYwB9fSmx xMVX7K/2hYgS3kFndSOfn3Z28ZJA6AHB71bMIlSLY5juUwxaYsq49CepCnnBJBI6dTRrGMZNe0T7 aP7+/nrfV+ZnFzX2r/L8tWl9xltKytlCsjyH/Wp/x7IpOdvBwZFGFbGPmB9Kd9ndy0a3DbU5OSc5 PzHnthice30q8sSqCqQrZ2l71mIDK0qH5/KTpGHbJDKBnI7ZqJUzM6SW7RSqQsOCxVlRMbjjht2N 2D6nuK0pxhf4kuyt1+/p3tb7i6dXnduVr1ad9N9Eu3kQMJQqwyCa5iwxGxUZY2wBuO85DAcj04ql NaxSfZRcW3mgJ965UADLDhGjydw4BB+UL0yauzvJCwYNJ8rfvkRcElup49BjPH40qfLjaJiJDkM4 3Bc5ztDZ2+vGPpTlL2Tb5009ktHslvd326d32snJ8snJSV9Onp1ureT7rr1xJoEgnmXTpJ7O4aJl EhaX7MsbKVmVg3ygvGXVM8h2BHNRXv2kQCRtPGpy2ccTQrDctbXSAHcZUulHnHbgsEjy5IAT5itb wtkVpC8ksjkEbWw6cgg/K24YUHIyOMZB45jMC2xWMMx85SyuygY7/eX5go6sVIKjkEECuaaU3quZ uzvtZff/AJdvIqNVzVnJWvta3bq+u3T8j3f4O/tjfGP4Tz21npPi2+1DRwqxyeAfiDONRtXgAx/x JtYdmuLZT0WCUKV4BANfpL8Mf27vgx8QWg0rxfHqHwq8YXEJhV9eEcvhCe5ZtuYtTtXLRiWTLR+a AoUjOMV+LU6aXLbsLyCxnGdkzXELska8AyR3BJlQ453qwbgEnOKpvY2UyOltdCGziRR9mKrqFjag /deVrsS4EgwwIG5c8YIzXLPC1Uk6c1dt3Si+6Svrpu7dPvMalKnKzcJJ663W+l7aarur9d1d3/pa UQato6XUk2meJ7GVN1vrelSWGq20jszGKWCeOScR+XDsjBmggZGTGWxuNrwb8Rvi18Hta/tz4SfE fxz4Sm3h5V0vVGvNPulVVV4bvSdRuJ9PuUBGHitUtAExiQtlK/m78IfFjx/8INStpfCXi3VdDDzp KtvBfXF94avGj/fh7zT55XiSAowV47dY1BBBB5r9CPhr/wAFCtL1SO1sfit4fMkrhpL3xb4ORfsA JkJWf+zGUvAR0ZI2VCo3Fd2a5pUWl78W9bN676dNuy87Di61NLkm4xut0/kr6LX/AIY/0lKZI/lj JGc8egB7ZqKS4SNyhI3KnmuCcFYVPzy4/iRenAPz4XrXF+OviH4L+HfhTW/GvxB8TaP4K8IeHrSW +1nxD4hvoNO07T7SJdxnup7h0VMYK/Z/9e7tGijcwrzU7vlSbfkm/wAu/wDXQ+2bSTbdkt32Oz84 H5QPMYkYGQoAzgkntgHv1JAGM5rwf45ftL/Aj9nHw9L4p+NnxS8HfDzRokd4Tr+rW8d/qMiRuws9 N0dGOo3lzIwjSJIo28yRlRSu4sP53/2xP+C8Ora1c6t4E/Yy0S303Q383TD8ffGmjzXJvGPnI974 B8L3aNBLG5VWsdU1u1nhmVWntwpCkfz9eL/FPif4h+Lrz4gfE/xH4j+JnxHv5PMuPEnjnVZ9c1ws ScS6XPeyTP4esgDtg07RjZ20CALFEqjFehQy+vWtJxtC/WST6dHfv62Z5eJzahQcowmnNLZppXbt 8XX0v07b/wBIHx7/AODgOxie60r9ln4K3HipfOnhtPG3xXmn8N6XeIirGl7p3he0lg1U2glEskTX eou9zFsKom4V+S/xh/4KQftsfHxbiDxx8eb3wvos8SY8G/CWxPgPT49+N8b69Y7PFUts2SGt77W7 mAhirRsCc/CbJNcKkZWUGWcK9s800yYV3kEpeRmP2j95j7VnzgFUF8CuksdGkn8wf2lF5KhY5YJI oEkhUH7z38i+dfHGSUWR9x7c4r1qeCoQsl70m9d1Z6abfl9ztc+fxGb1a2jdkm7NSbve29rvvv8A j0muYPtl0up6nFJqWovOZpNY1jUDrGoG4di7yJe3pnnjMrHdKLdo0kLHcpyankN/Ll2mjhBkOBHa R3DSgYCeWiRiK3CZ+Z/Lxg55OCNm2svDOnGOdY5tYcSHfHGixWiuM5bYw8xRnGEzx6cV1Fn4jt7U P/ZWk6cl2CwWaSS5GyKQgmHyBIIJdoG0+YjdK740GopxSil1Vm15W7Xvrb02PLeIqc/NdyurJa9W um11+CPPIdC8S3bFLaGPVgMm5hgR5BGZTmNGuLcwoWIVi8L5QYA2Yznpbf4c69En2q404admAyPe Xk9ta3EUSMgNvYCQPGryBgyx+V84jJb5gDXULrWrxwvZw38enWM5EkllYKtlC8jZ3ySC1EbSOuTs 8wkLucDG41gXRhk/fXJivjCwVJZ7eKS4IYn5C5XcYxtyxzuJIPWrUKkotKacUurs3qtLd9b6fgaQ m3rOCTaXL1a/Xe6t8/RY/D3hizM5vZpNXu9q7LfdNJJakgEzTSvI0EzBuPKgjj65HGRUvm2EMcMd lognZbjaRcvFCuz2W1SGfAPPzSZ6gnFQ+dbBXjt42igJW5kh2ySCGROBLbAEtGfQRkEAkdCasWts t2txe3l3DaadaP5k7wJBDft6JGZF8xg44YuSevSs1Tne1tfVfP7v6uZTd7rlldu+z7p9vP8AMiGp X8xEVtNDbQiMm4gsraCIQ4H3vPuIpXUDuInXtkVjyLGXDXM1xeRzDMk8kzyAE5zt5CqucYVFVevy jFabXUd1G0JjWC2Rv9HtrjEsvXOWlj+aUkYyJCVz2rOlWNjNGi+bJGyhreAq0aMTh1lijAaEx9fL wNuOfStJ06c5XbbTf2Lyetr6K/r2St82mm+W+v4f1/kxnkxYLQQRsikJEwVUIAPJITYCeSNzAsc/ Mx6UqgRTlpVDAbeX6IT3XbgNkYznOMCqFxcIPMhtJooGd1iJdJiqAffIZTtDg4OCMDvzzVY65a2U LG6v7N4kmEEUjOC1w4z5gz91Cp2hQy/MGPcZqJUnOX7vWMWrOXuuyS6Pr2Xl0E6TbfvRV29G1fdX 0v5v7jqJo3nkhdCk7pkweSsURhOCPMc7NjIoJ3h1JIYY6ZMfEUMsIkRo3YLOkEm6TzxgpJvILKqk fcQqh/uY4riP+E10uO5e1i824uWdUihiAYKzkgZCDdK5AJSOP7w6g8Ci88S+IdMtXv20KxsNP+0y Rxan4ikg8P6ftQAs8pvTHPIyZyTGcEHI71fsVKKlJ6L3ejtZLpZvr9/4OMHFW366arZaaHfpOiGF pGW5uXO0LIkXyqRgKVSNVyAOSVLYGcnrTZBKXMqPKqHKpIEDGLI+7tVUUnnHLZ79iK8I1D42+EdF mMOt/ELwzc6lGPNS1+H2lXWuKQeRA19dC6tjMvKtsOzIyvU15Bq/7Qmp60l9aaPo2v3Vt54kQ69q JsYvlOdv2HTXt7MocDKtFzyDUOlSXK5PR9l6XvZa7/dr1LVPmfvJra26vf8Ar+uv15N4g0zTJJIb y7iinjO+YXhSydopOBKqrHJJIR1/1oLDAJxWRZeL7XVpry30uw1DWrezJE1xZ2k8VvcMoDeULu5u JIYjHuBaQRBcMCVxXx9dfGr4hSlJbHTfBvhm2SI2sohsJtTur5SNu1vOMy23cgRhNpOTXnE+s6re C4tbzWdXht7t2uLi3sdQk0+2lnmI8wKLB4XOcLmGUkKAAVG45aaTtCClFK7UrLqk3q/uWvYv6sui dla+q62/ya7a+h9yeKviJpWmWM1r/bfg/wAMavJFlF1XXItUuoFiKtGktlpyW0Uj5JIjcMSRjJOa 8tn/AGg/DbyyG/uvE3jJtjW7xeGNLtdA0uOWNBbSGO5ngmm2XEsLMG3Zwf3bJXyxDYWAceVY2jOW +cSRhb2ThlSRrkATboizOpVssx+ckYq0YZYZZpILmR/KigibeVldQhJZmkl3PlySXUMEPTHFZRxM m5Q9lFP4U7rRt6W326dtvNawoQVub5/h/wAN16Hp+vfHG91BYW0j4eaTofkGQW1/4p1W88QXaKvC yLaiZYFkXGQDF14IINYeofEX4i68+b7xzqMUNta7Fi0RLDSrCeEji2eO0tIrmUKON0s7yAD7xNcj E27a5mEJRH2C3VopJmb+8seFZiTwGBBxyOKmgto5o5Jp/JLLnYgj2S7hgBmcfNuORkA464FXNOSt G3PbW+nbql+unQ19lR7P8PLy/Lz8jNks4bphLftc6jOr+ZK+pXV1e+U+f+X6G6mlgAOfljijROmV zV6JFhUvALeK2iXy2+zItukIJzshhgEcewbsj5D1NXxAs7N5ciTbMYttpjeFeM+cz8zj0aUuccgc VdEMKzxwObdQ6eZEVG6JYeMhmGVaQMWGenp0rBWqaSbXkr7W329beXk7gmntstDKV5UjXzJ0jjdi IHjj84SgjJE6nMYJOd24ZweoFWRHHbqF2xTyKzyvbIGSAcfI+3dtYscgqflHYCpDHG26O3X5Gmfz WLlQiYT5o0BADfh0x9aqhYtjLDOwMcnlgMXMxD8NtDEqemRjpyf4hWcqcYNPmau7Ja2e27Xb1s+u 9iFaM5q1ndLVat21110+dgdXeDfbJHE7uglhjRceWCWYFVAwRzhhyM8EZqJxcGUTqghgwoldYyS4 TnbtbIUkdwMk8kmrMUcYOyASSNG7LKwYxuR/FkqVHfpgA9KsmPY4c/aTHxsjaUtGZO25c5YZyCvc U+XVaataem/+Y/d153r0spPTTa3zuRvZxxrCZLaNonYSLIOJgTzncPmOfQnaOmOlENgk14tvPOkU cis6zxo0n2fbyEKoVB3Dg7s4PSrKRyTIsskrINrMFWN227egw4I6dfTnFS2/2dMyXIljWVWBEJ8o k5wDmIg5IGcZGPTOKtQ2c3bflV99VdW+77nbccVF/Am9r6PTtvr3+7UqxLucRwRO7yK6B5UMSuVY qGXcS6BsZHzE+nFRvaGFo1fh92yVQQyHHOCccsOmeuD97AAq3HLaBY4pZbloLi6FrBPcBxPDLtaQ rCWO67h2qQJU3YkYISMEVKYYzDGEldT9qkYpOjxS7QQimQONwLIiswB2nJx1p+0al7NW11SfbTrv 93/Dvmcdt/PRNXV9XoZhtmeWR2SE7Y28hn4MJQZLjbzlhxzngH6UJbyCNZnCymaPKspLyptJLFN2 SoYAqwHGDgYFalxBEu9hcQeY4VXhRsuqA53DJ+833T249TTJr21l3+Uy26W9usbhh85K/wAUQHVm I56jBpzUuW0lG01a6d2k+X5Lrpva99tUqk3o3Gz9L2fz3MjJs3uoo1itw6Iyrh42kZgMqzxlWO44 BO7jPar62Uxj8yQ28oljASJHZipx3Z2LYOO7c1KurI7Q3ISKS2ASOQSxM0vykAsFwMkjBPHXpTix YJIYH2jfJIoHkEdTEkavgoHH3mk+Udu1VyqMFyyjolu9Onz/ABXoUVpbZI4Gw0wddoii2+ZEDxuw ZN4GT3GCOxolS5hFpKUMMU7LbRtcAPBFPksZUkH71gd3SR2AIKgYwA641GeK1t0ZWzcRyOoCbwm1 sBZH9hxnOTjIOOKzI9TvpLaSO3UFZ/kje43P5U6gfNFE5KAYA6gZI461zOEXpDmT66P89F1/C+wl ZfCmtez307/1fYvXFvJDJJI0sEhKFXlQELkEliF6ckg5HOMAelUH8kqHW7LRBcMy4UBlBLKMjGcf Q+vNZss2oXMcwF2jzQpuuUjgYeUoJXfIq5LKSpJCYI7DFcy88ayW9nd3ty0TMZ1+x2c0jGZ9yBJL ZUNzDBjBE0vyO52JzSdJycU7rltftdW1XT+rWuaKnBvmnOKel02utrKV9tOis11avc6OfUba0ge5 8wQpIQsYkcuAP42JLEglScc8HoMc1nXmq23nBWvBLFFEqIyozKZJBkpkYb50DKRngHI5waozeEfE 13NPFpvhvVtVilVVMy2VyEto5CEVoVZcF5CQg8wFAWzjIFek6H8CvihqFjFfX+k/8I/a3V/C8cVy bX7WqRApG/lTA/IwYM4ZRyABwa6lQbinDW2ju7fn201RM5Yel7yndJK/Km1fy9He6v8APoeVrr0c l0bOK1kmZ/kUXCP9lCnswHJHuctgdQemWY/ENxFJFY2zW9tPK8ezZIjysXZVxGmEeJTE+zzFfKMu c9a+6/DvwSsdGlZdYltNQumiWYX8kAWJm/jgCRgASjkZI2E9eoq9/Ydrp0gW1Sx8m382S6luLePz 7cmVQqHK+WyqhOwxjeN3zE5p06U6bk6iVnZRtaW3p6/nbpeFXjVWj0je11Z69H06HxDZ/DPx5r1r aSrpw2QSv5UWfLHlSgb3kdQrIo7pkKMc55rpdG+EWp6dbNeX+oJaobe7hlt9Oci5mdN32eTfkr5M T4jIADO6kuWr1bxp4h1W31qOxtdRm8MWNnqKrNHaQS3Ta1aTBGVoHO5AjLJhwgyjqVGMce92+keF hBaeFnsdSuY9ZsodStdVuQlq8AMYkuMyYQCIT7xsY5IAJBPNW6CqN3S5bq+19LN/IznWqOPLK3Jf XVNqzVnbV979e5/fv+2z+3V8Ev2Jfh9beLfifezaj4v1sSRfD74YaLJBc+MfGmroPLWKztNzLYaP bzER6h4juxFp1gNz/aRJsU/xa/tb/tt/tB/tveMZta+LviJ9K8G2t1cz+Dvgv4auLmHwJ4W09Z0k inup28qPxB4mjKxibxHOr3CDfawN5D4rw74vfGf4qfH74ja/8YfjX4wu/GfxD8RRrZxTyo8Wh6Bp 4YJaaB4c0hDLa6RpWmwn/RBDIsu9EMwc7jXm8rJK8qzGeKLIE0cUhkV8jKLNMAAs0gDG4Kny2ITa 7da8nL8AoXq1YPmevK1qnZX3629fkld+3mOZuTnRp3sny80XdNJpJ3T0S10+e+8kUs7yJJHJdNOr rHFJEqBYIRnfJCAfJUqQiOVOZiwkf5kWtGNgpkBaR45HAkUKklw8mc+a0znMbFhyqNtAGB04zIZg JEjty6iPKhU4hhiJAKszY8yRmK4dQyAA5IyKkU3McrpC6gpOqSbigCswyBvY7TwDyGI7E56+tTkm m1D2cU+VJq22713Tvp/Tfz8oxnP945Sm9bxu1ZtWjfXVa9fP16P7fdQJGm9IFWf5WjGXKlQcNvxk 9Adp5JwKRNYZlmjLkhHx5boOnTNvGeY264wBj2Ga5q5u0keQCX7S8Eu6WOEkiPIwG3YCHBGflJwe egzUMd4x+dpI44kYJI8oAuTL/dDZKEk4+bds/wBoVELXd3Z3Tjd2vZK9u4pU6Ubezdl9rm0ey/yb sdvFeTuFEAn+YiZ1lZUkSNjuBbJAY7T1POeta63SSGFxu+QsWmmKwqR6ebkRMqngBWLDJDKDxXm1 1rNja2yi5uHhvEn3ST3FzCsTQs21Y3ZZCu3kBW3bSvK5HNWrqw1XU4WuYntWsbVS32hrpLXT7TA3 F3uZmjtZt33h5c0nmEfLk8V1KbhF+62mrLTu09NNdn997qxlUVktU/eTdtbJa3uu3y9dXb0xte0e NXF1qMcBQhWmjkUwrI/+rSRmbClsNgE8gHHep28U+GbaIR3fiG1gnC7Qqh5mfPzKojg3uzNtwGAI B4OCRXz9DdaFqGpR6bJqWueJtQZiV0XwzpUqCUIcFnv7lYIUjQ4VZEZ/MBZo9wQ16RbWT6Vp8t3b W/gz4eW0Uiw3d5rwh1bW3DKzlLmXVmsfIaTy1LmyW4lVl/dI67iudNSbcm2ore+itdb7JdOi3Gpc 1vZtSkrWS1ad7/fqnr3R2lr4pjv3V/D2heLdZChknvLXTJbeygVM7p57m4SNIbcjBMrMFXILEZqO 41yOK6t7ErZ2t/eo0sENtf2OuSrtzvGoiwmuIrdgSfklKsp4IBFfPvir42eHIpc3njfxT45k061l tbXwx4dt30jQhMSUWZtRdbYTRsCSUQSnAXC9K8r/AOFt6hpVo0XhbwJoGksd7NrmuT3Gs3ivISTG 1qE8pmw33jOFLcdqpVKfM25x5db+8tU3+Hq0/S5pGGKklzJa9Wuluqsn8tfW7Z9Vz+PbOaVrawg1 XXnt5TAwtIY0t3lB2gp5RM5UkDkIR17dUuNc8Tm3S6vPDGl+H44YruaK78T6zCifZ4o2aN4bW+lj cbgoKoinGMAc18T6p49+IurPbWk3iZ7K3VWaG10a0XSoXtnPJnihWTdIVJAzJuBwTjiuPm0qGcxv eLfajcQmNp3v7i5u3YzsQyf64ohw3IAwCQCAKUa1FO2G0aatzv0+69/6auCwtqkbtJXtq/S+7Xbv vpsfVEnxe1jWtGOqRT6MTb39xYXEb31lbR3NtZvsL2NnDKZ3LIzbZRHiTAKk4OOET4oeCbRL1tD8 Aa34g1m6eQFtd1FI9Esp+s17DbpK1ziFmDBWiUsNuzPNeNfY7OAFEtA7QXAEDQjL6aARkBmZFcfN wqhsdyc8ajRsZCHuGgRgd7bMXFyWH7ovsBUKPmyFJJDDcBxU1J1I2lP4pP32tm+uu1n1t8jo9hRv eV2+rSbTel9k38/u217aP4vfGWCzn0my8W2ug2FwGjtJ9C021h1JYZDl/s2oOEugkAHluspXflSe V44m40y91K7W71rUdZ1y4DyMJ9Yv2vjJ5yjzJntpJGiWctuK+XlQDjIxircFpJ9nmuVkt28nbAYy sglDS8pJGCvyIAp80njkdc1OqAiOVJ2dlKwuypKFjnbhRyo3k8g7cj371hOU5T5Vfk5U7rZNvVXt vtvb/JqEIq0YvlXVxdru1+np9+nnmW9hpdvbFIITalC0pihtVkAb+J0BGA7HnJOB78Grm+NiphgK tKfulAqggcFt2ByeTj+dakNsixKJHniLQHdJF5b5Jzn5VcuMk4wVGM47U+1lDiVEtxI6yGKN5WjV gy54ILBh9TwfUmkrq6k9L6Nvfvv8rr/gCla8bK2uuluq7pGY1heeV9v2j9y6qsMMgjAZjjfIFP7w A9eCew44qsYYVlJWNGZ2XzpJR5arcOGaQxqME4Cr87jJJHUA1vkfaNgf5FAjCxW5LiUqfmdtu4Ke 534yOeTUd3bos8vk5u7Y+U8kpRw1vIVlEibSodvLynzIrA5ODjOKUrfC7t2Wmujavtt6mqkrSV1d 289n+BlCOFiiySzMMMxnjGZUw2MBl4xkHBz0yehwbvkoYkYAhZGWJX2kKwbPzz5wSwA42555rR0+ 28hoYhYR3AkicqZ38jzVZnYBGlCKWUc7c7jwACSapTRRhTJ5a28AeZj88hKvBy0GxlBy+cBvusOV Y4qKi5bSWr3stVda2fZ308/W5DaSeqvZ9VuPjht1mCCZ447dMGVVUxl8ZB3E5C5HJI4B4708rNNI VjChYxkHKs8vupQlFz23EY4J61ErSyQPNZQIIxCzSrM6OjAL8xYgkqDg/KcHHTniqMl3HDI7RgxW 4hRrkRhySJCApR8bV3EjuDySQOapyvTXL7010WrvppZX38l+pClN6LV+SRsLbm8djuaYXAJDkCKc hQfkmiGHAPTIG0jnOKpGyVRNC7GC2gcsLZZFEsOBgLE8hCmLOW65y5GD0rIbXGku4WsjlmiZo4wC moSRjj94xAt4weMB5VY5BC81Xlvry+DG1tgl1t+eC8JLxQl1j3kLuwwZh8rEN8wbG3mspSUuXVx6 Xelm+3W+mmxUU4qz0d9E9HsuhsFmdYpISkBefyY7i5yqZwMIVUEkc8OPlJJAPHCtK0N6gl8k3ltI SyAZjkXAy8ZUEgOPulwORz3FZDQ6vdwzxOheRUht42VG2BIWZm8pQN28F23NtBxjJIxmGR4rWUef eqrLGwURq885eMDzN6xrIxKjb8mNwznGcUQ5Zac93F20ae1rtb/8DqW1Hnb5ldvr00X5/wBaavqv OtVZ5lYQvcO7yW7H5ycFgFI4Az6kZ9fWm9whLO+5Ex+5UvuZpMDaMrkDnnt61zks9nm2mu/7Sljc gi4hsb2QbHIXKeXblicfeVQzLzvAAzXSS+EdevjdW/hbw/4h1e5hSGd4Bp940caXGDEZZDCEiRy4 3bmDICdwXFVGnVnrGE5WbV0m/htppd6X2+7YEoOrZuPLyrVtWb063/q21imJtvlxMl95jWs8xKSs FQrkrEQpB8x+NpAI5Galib95CjSO0YAJ3ug2MRna2T17H1+teg6d8HPidqZWOW1s/Dt/IIZfst8k rSCNcfL+7jcc8ZGc4PIzW7H8BPENpNFp+qeLop5ryUxXAjspEazlPIGSikBQT84G3CjJBqfZ1pyU XGceXumm9m77durf5kqrTpynGLi1pa1vuWvldeT82jh9GdraTW5HTR083RLqP/id232yJjujaEaN IiSPa6lKQxhddsIWKXc6sQK5qC7kfSy97JaWu2ZUI85WvVTyYZPPmiQmSRZC5CMoJKqFPKkV7ppX wR8IaRq9j4f1vxXfa9carZ3l0l8jNbWOm3ln5gtYXkl8uMhg8y4UsCxx6VY074f/AAu8PIwu0XVN VvDIr3ss8j3Fq0bsistuAWNvHtAGE+Yq7LlSCd3gpyknrFpXvyva669+2zWmpnKtCTalFyi/5Vrf TZa31vtvffc+ere+0S/v7fTxdn7ZIVW3RYbgXN2w5Yxw7d7KgG44GSD071sWl1BPq0GkJpt5cXE7 +XFIbaSCOB0YDF5NOqRRgnoGIZxwoJOK+k9M0rwJpevafr1pp9nrWuadHus7yCHbFbwIMzOWkWOB ZRGQHSV1kYABVZhiupu9UsdUW/SLREkS/tftSzW1tDGpkWQurTOSrK6N8yImWkcBVDEgHanhFKLd Sonyr4b3k+VLRK/Wz+5JO6ZDrYdL3YTUrOza66deny19dUvmCTwp8Rp9Uk0608IXEu5yPPjRW08W /UsbmPMaFlPDBsqfmPrXf6T+z18R7+a81HxLrNr4YsY9Eur+zFrIdQk1yWBMxaXdMpeKBG4QMSGA 7Yr6U8IXXjOHwjBp+oaLa2cNxeSva3DmTzhHayAo5CRu5Yvt2rKUR+u7Zlhgat4iu9Lkew/4S+3/ AH0whXTIbae4ZZpjgpKwjZI1GcEFsDnritXRwvIk7qyi7PRp6dHtr0d/zby9rN/ak77aP5W0PEtN /Zp8Q3EcE+p+LktdOubFri6WxMjy2Kt8wt0DgbnwwUbMqAoycV2Gk/s1+BIZ2n13xXrl5YLpxGmk utqBqCEuReNvU8q4ACksABkADNbeqfaNRthZC+1i5urUFbdoI5be3W7DbzazFRiQMpBUrlAuMkYI roILCa2S30aC1EWo/ZpdY1Fru5ku4o7lLaAGBWjDw7mi8uTyVcv8+NobIHQ6VKKskmrRatZtqy7P y1+ZLq4ipZKcVbZuS6WWuur6u7/M43R/h/8ADDwJfXHiXS7WO+ugsNuNJ1DUF1fS9Sb70y3Wml5C Lht2BMsfEfljdkYrq5PEvhuC7nn0zwfpWjWN3Kknl2unwyzNdOFWK0giKecYDNhkRFby2OXCrzVz S/C12kaaobbShqNxGk6TTRMnlQzjB8uNlMROMt87LLkgbBwa0LubTtIlk+0X1rbT2MEMoVRBcT38 qy+YY0jRnlh8z7qyJGzKT8yhQSIfsrKLgov+Zq3a29lpd7We3ZWUrcqU25TSvKUU2pPfTvpp+HW6 ybXxj4t1C/ex0rw5qFxbwwifVJ7HTzHbJaJgRzPPHHtgW2nCeYzsq8EA5qPS5fH2oXniCFRpxtru 0W50q41S8iS4+w7xHczWdrO63Fwse7Hm2kciIwDlgBmob34iQWEerta6pczahrsFtHo1np7G20jQ vD0U8c1zDfKsfn3N75yLJIkka+bgohbdiuJu/GniCSGaTS9tv/abix/tSW3imli0sqyS2lgHkSSx guHKl9qZwDuxilycj5ers0uuun42/EI8vspLVLmvaWj6d9UvT8jrvEMniDRdKsVuvFFjcBGuLV5Y D/pLNJHviRvMwotlOIy5bzd2CorygS6jq4i0G2vGub+7vJVluryRLGz0y0eOEvePcTtGpt4WjcEO wZsgoGHNYd+Lm4sriaQtP5V2bCKCSR84ClkuVVsFgZf3eVGQG5GBWfNLFNbrGk8zXMwWC4s2RpIp ViRRLa3LxgsE3AshUldpAJBBFTJ2Wqb+Wi9fzN/ZLkg4tJu903rtHu+mvre73bEMEJ1S4eeBb+w0 0NbtNbXa3Eq3VpPIjXdi+4wPZXJXzxh/My7fLjk2J/EF/c3stwl1PIl5DJFbRXU0oht8J5arbZwQ fLA3JgK0mT05otZFtj/Z7WywF7dbkXZi8mG3iUFI7dwfkIAUog3FioVmAJIqsIopru2OqOLCzjuH ddyNIZZ9myPylt1lZYWAHzMAgYnJFc70u07v+Tr01sCpNavlat3Vm9rdtH+R7NLPIJpCCFSW4DTw OEH2cA48q3Ib54o/uxP95x8zAHo0FPJkIbEEjtmLzAJJY84ZyhO/jjbkfdLHOKhaVWEJkhXYWlTz CMEOjbVXPbHAx24PepIpBYSWtzJbpeTzfaYxAAGYRtC4BAPJwOeOKVSpGylD/l5Zqz6vt/nf8VYu SabT3vqNWZZtsZnWG32kRiNTvaBcFmdwMFgygYzk9hwadcT2bpHbWTNIHRpnkl+TLodm12Y4G4ZP ODioIm+eH92gAQymLH3W3N+6x6kHP1HXvVIvNOLqJTDAXfao27mXDbgAnOS+PLORwGJzxWHJWbcW 7x39G7bff5dtjJqanzR2at87f11X+dlXjjVFMb2USjdczIpkaQEYVsgcqSQQ3CncCTyDUN5fwWcM FsJrqbXbiRV0iwSzN0btscR3McO9o5cYLCQAgHJArjvF/jPSPAWnzX2q6laxylVkW0+0pKzqBkWF kjcXNw+8QomCEkRQVO015nN+054Z8YpoWmeF/hZ4z8JSeHLhodavL3U4Br2u3M/3pJLyO1At4tRz 5i3UGDarJ5YI2DGkVF6PRx7269LvXo7+vmaLDVHyydveve++lrXfpov+Aj2W1gtY7y51HxjbxXzO C7+HxFJJYWWoRf6h76GIkPb7QCD9qi3E/wCr4xXBePPiRoV6lv4csrnWbyErFItro8ataaXbkbvI t4JGt1iEwG1luJLh7ckcNjFch4h1rW/GNvFaz2sfhXw5bXEt0nhvTtSlbULiYlmmn8Q6xNi7lIOT DbRlYgcBFC4FYEMaW8SpYC2tISHkQsGkuJkc5DSTy/vHkbvvzjgECsqk5xScbtX/AB0tpr2Wmu/3 9Ko04xd7KTSv1XS63vpZ6ru9j0aP4ueLNH09NN8DWOn/AA800xLEdRCDVvEl3LGNrXE+qyrGlvJJ ljHbxWjKgZvnbANeW6qbrXLptT8Qajquu35f/SbjULpro3CuGyWjDW0MeTtIzFvUE4PLE3ViYQeY zCUyE5iY52y4HlyKPQYb8ep5qxG0aKCZIo5UXEylQ5vWJ+WLBB5Azhs5UrjvThVm1aV7O11tbbXo lor62Xczp0YUubltzS2+drO/RvfX5pIxfsQiht/JxGsM6zxQRrtMKqcchS28YOCCcEnk4Ap9yFku HdvORfNVfsgJZbhsA/TdjkDGeDnk4rRkEEFzAEn8iaVgzocTDHLeQeRsyR07Y4qot0l0ZII2SO9L NdySTOIUtYwSA/X5cjvjk498ac1Pz+9eXn11+/0tolWXVfN+n+X4saPKC3BDTefJEjW+QRtj4Py8 dD7d+Dg81KkgjZkkSaV1RZXMJVCTKAFEgb7zR5BYD7uM47nO/tNIWit7iSJzCSvmqQd1uR+7AY9c ntnuMVUuNRVIozdSiAPI3mQRRyvdSIcgHepO0MDzjAA9eDWM6ajUXJ3+T0W/z17v1Goc/Z6289e3 Y35BFCSZWJ89vL2g4BkQgliSfmJB5YDBIPPFSrM5kEbiOFY1DRSyEMCF+8S33RglcliByK5Iagwt 2lt7VztnkSJXLTl42K7AS53Qv1z0A4A71Xk1G4tLlYb4MDmN0sEje4byJc+eJHQ8gssRVW6EEc4r abb5Yu/Non5tJd+mlr+fncTjyvl7afcd/bpZNFK6tLJqBlSSKVW3QMqkHa6DO6Ns/Ngc8DpWjNOD cTXMhS1liWJJo4wBaPIUACIuf3MzZypkxkjjtXH2vh/XtYZp4I5NPt/KeWOJBMlxPaq0YWG2QcmV t25AOcI3XGK9T0H4Ma/qM8Ekck80CvD5kE4mD3pkGd0xbOZbcZALZxjJ5yK3WGnJJx20v3vpp66+ epnP2e06nK1ra/TT8dbb7djlBeaYDHtBSNoGMtw1wm0NgggZbGSc9D346YpqahYRW888t9b2wgiF xHcMvmNcSNnEbBScFgcYPUE+or3DT/2dbIzW6apb3j2EFtDN+5kJWWXg+WMfKcEEHtxwPT0ix+BP hu2Mk8mnaW+myxTNFHc3UhngNpzultyckLtAOcdCKtYKUvitptfTz/S33nOqtOm7xm536q91a1tf O/4I+NINfhvWVYbeW5mlhCRLYRyRHdg/Mcodw5GSAR261M15rITKabeJJEI7aSNkdY3W7YxpMw2l 22kHfIqlRxz6felv8NfDlje6k62VnNNDpSjTE0qOEjy9nz3MYOXC4LctzweTkVSbwl4cW10Z5rG5 vp7h5ooneaK3QrEFlKTsuGMaFWK9idwGTmtIYKzu0rW8tdvuCeJg1ZLW63/S/V7elz4V1NtUsXa1 ujZiW2hSJEtZpbm582QB93lhd3mRBtypGCzfMcYHOJpcsOqarDok2sMLm2he5E0zBBeM4y8bwkh1 dPujIBBXB5r7Lu4fDlr/AGg2hWGj6ddm4l1G5l1GA3d3IbRXgENpLKTt8wsyh0x0AJGBXkbeENM0 /TrldJ8N2rXXjCaCXV9WlmjuNV0mJbmSac2HmEfZBcK+DgjAAAB5JwqUVF8rW/b5adn2+8qE9OdJ Pl15e/l03uux5RdL4bjB05rvU7ZZ51iupbeN5txc4Zo41KmaLJGdrqmQQXWrjeGPENtZW+pWHhnx DHpbzyW1vcSsllHqS2/KPHDKtw7l9owF3FiflBr630y5g0PU0n02PR76CPTrXQrKK60zTblbPR5I 0jneeP7DI8uoTtuMUwnjk3tlXXg10niZ73WrOPTLsyRWWlTJeeHL6cxQXrXjnd9ntbC2Ij8lWOF8 5SQCOmMmoYf2S5+9+l9LLZ76vV9ttFdkxx8oT/g9LOy0tv6+b6Hy3afCj4patCt5pfhGdbGeJYft c01jFaxs5HN8WmW4tHQEnbMiM2MhcV6v4Z/Zoi1B5oPH3xH03RhbLGLnSdFia4vr2XYZvJgvkyjn KonGSTjjgZ9Y0Pw3r8mjya819aHStR1NZ9S067ur60I1dLW4s/NlBvMTWIE4ueflLRD0ArDbTvDG jX8003iS5lkEbFbrT0ee3hkOSVtomaR2dH+VWLliFByBgVoqOHgnzrz076f5b6d9OnPOrUn7+9rd bdVvfVfhppseWat8FLDwv4uttRS88Qap4E8uKC+0dJ4YL2VRvd5I55XV47hldBKCuCoQDvXrGi6b 8HNPS4m0rQbfTJoIpJ7cX8T3V67BSbeK6EyqGaRgwkmiLo3GSABWVcXdyjmV5ri4+12u2ylumM81 1GGcrJPZtkwTHdgv2TZ6CoU0fVdRuYrybTy9r/Z5Xy1U75XiLFgsxwQEyrPECNwIXFRenSm5QoqU ZNNStdva3dbrS3l1YRdScYzW0knqm38/y0/4bW/4SPw1dabbXFvpNnOLd7qU2KWccUcF0ATI/mqr HyjjK8eWQRkjisbTPHWteGF8UXmj3T6dN4ja0jlgVkdoYgVVVjVl3IrDGCAATyCeDSWnhPVpLhZb iIaWl0gMTwf6u6tI8GeGW1x+7cx8A/xY61bs/BcJkjnvp5J7ezeZp7uNPmnBJMMSKQQ723BVOmVw D2rVzqQftIQdOm0tO703066bbNFKTV4ydnf0vt9+q+/byqal4712/hsGv9UgGo5Xypy5jldcYCtI AELY4xu6jt0qgdYv2UMdTdtSkl+1+XCskk+1eP3k0oWNkYdQDk545FdNa+GLVJJZLb7M0hclbrUv INpbR5+UwxOMLNyCR161fS38PJqUF9Lc21zH9iiUW+5YI4GWQq0rHpIu4E7R24GKFJSi5Nrmlb71 a/3/AIj5ba/zfp/w/wDSsecanenV3muvsr3UlqsDXNsmIzMC/wAtzAiEuJA42yQpkkLvxhqtWkMg 1OJptEnvJ3uo51eIC3hD/Z0Jt55ZYm+QRLEXQEEszcbjz6I2veGbCBpLa80+5uVnZ7u+s7FXMi5P +jQRJnYdoCGcdCCc9ax5PFOk3EvnyxzWUIlM9k4YyR2ZAX5riLkTyyFTuXBKqVyM4rBxrp6J2bs9 WtHZa26X6IuG/wAiwulajc2Wnyw22koNXvJruTT7ESxHShbzNHnUZJoIFCXSoI40VmLsCVUqwJ6c XOsQtmOKxsmMog8m1tlcJ5JzbEq4UEiQKSc4wc4I6cDd/EVp5JPseltEyqRHNM3+i31wAFW4nQ8R A4BhjYnEgJHI5oS+PdTKL50ggK3ai5/cZkWdkGQx6iM5+U444NXGjKlrJau3VWu2lvpor7dN+ljC ey/4Gny/y0+89Ru9Oa4bz77UNUuHmiWRJrm+WztYprNCFVII8sI5V3FtoycdMnByDDoGiwBra70G zkIZjKiy6jeXF/LkqzOwyuxh14A/HA8p/wCEhvp0a51LUGEZuX+yBB55IJPHl5IXtkDoPxrJneVZ I4zG6TXEnm2yw/Os+enmMMiDqMjtzV+z5+nl67af1/ka094+n6HtH/CWaLYMttNdnUtQsJIZL/7M qW8LahdcRFw+MwpGBvYHYp4Yg1R1T4iXiJ5lvG1tb2DT29tbC3gddRvbkjzLppw5ma2hXbH5jL5f yYBIAry62guBe3UkFmlzA0Wy9EmHmc7RvCkjLCNgQO3y5xVaC3dIfMhnZjGzQIt2xAWB2MhjAIzh S5XAAGFA+irqTmvZp6abW0SX4aeTF7Pl176fr2XY2NQ8V39wo8zU5F+zwoZEglzG0IkYPNwcZSTf Gu3K7UHJ5AxZNUIh1G8ssXV95JmgvZV33MiKNzRRRuRgL1DgENnaDmpXsmslTbAtwyP5kVvEkWy7 VgA8DytyFU5IjBwCc9WJpbPSrOaW6Sxku0NwgkUXUahdOvt+ZLXzl5Nsy/Ki9A59RWUYVpzcW/eh q1fXZaa66XV+3y0DMgcyQ2YRlaXY0kx/dfN9qjIMVyA5YNG7AogHyuAGxSQ2xa4EJuZ50QOFijcL HG7A4IGeAmMkAkgA56g12S+Grd7ayEmnz2WpyS7JiFKwXT7v3UiNjnzJNuCOeRx0NZB0rUzMhjs7 SzJuJ4IZmuFV454UZpJ2jfCt5QHmFG+Vgu1vlJraClKacn8KS9UmtfXtt52E5RS5Xq73S020XX/g dDi7bTNTnvNPaI3F5qyXstvHp/IjmjldRFIygYPYl8YGSSRXUppesz+dZ6lLaaVJJPcrFeSQpGPM hUIyeahI2q6lPMzgleeeB0mry6Nplxo1z4j8SW2n6pNp+9ZoXgtWMbSCEXA+z7SAVIOR0ziuQh+I Pw/0u21u01bVI9RisBJFDKzyTm7kmZ5EFrzh3fO58dyc89JnUanKP9eV/wCt+1zZUqnJDs22n8o7 777+XXW5XNlqESQR3kts6yNDbT3MGbq1itUdt10UjBmY/wAWNoy2NueM2J/DdlKVlM2oarpZu2gT UIbaeC4jmB3Kz2ckYngtcMNjSogfAcEocnlB8aPDjaXeQWNnfyzMI3WLTLKOJ7W2hGxTNPcZBDFN z7ejErjNcxe/HPVNUTyNN01rS6glW4u7u7uXha6t44Vjiim2EJISAMYGBjA6cYcq5ubr/SNfq9Wc LRXvO34Nd+nnf/I+hFwBbLLFI4YEFSxKASDJl2Ekb0PRzzxnPOQ6NpmhlmLlJYxJHCR/rFRXVdys MMrHd1BBxxVkozTwzRgsTCIjbuSEVSuM7v7xHO7hh0FOeM2kNxM6xgrGVZSxZIIz87StknPTYg/j lManOcHCKSjFpq9k7W2aStr5WXQzm3eF92ot+to/Pcg8opJDHEfNnmCBUUqru5VmCea+VjLkY3uC pJCEZYVwvi3xJaeF9FvNfurhbayt5prMtlIdQ1nW0UG48P8AhxHBku5Vgkg+2agN8Fo7FYthlObv iHxJo2lNGdcu5tN0GGK2n8V6rAqtdWmjyvuWztYCPLk1vUXjS3sII1JhlkS5Kgw7h8X+KbzXPjp4 +j8U6jBdaR8PvDslzpPgLRUkb7Vpvh20dR5r7jm51jU22y63dXG+aWVYoYmEduqq5Sk6TbundLf0 3a3/AODqdEaaVql9bL3W7p2teytZd3tt6XwLiz1L4peJIdb1jTHsbbTp3m0vT5pRNZ6RYiQuiMVA SbV5GzI9wQZwWwWPOfZ7PShGqujuiopVrhLeN3aPdnyySmWQ8nYSUySSOeYrT7Bp8MAtorbSrFCs apcSxxySSCSWLznjTCtK2xckrndjuTUc2qndsgN/IHl+zptZ4AJU4ZkjjIR4mOTuIIAzyKmlNxta KfNJ3b12tp876u/Y6OerK3JaKj3bs72S9fOy9XsadxDHP573U4nechmkdds0kCn90z46TADoeQQc ECq8siRtaxSJIFlPlwsSHxKc/ZSxOSQwGZcnDHG7OKzdRvoYUH2i4SKRJI5PKjzJMokIJjduS+3O GLZzg/i3TNI8Q+IdTePQrG9u4IYpP9YJNpnmAKyxsfuhCONpG3OBVTUpVIJqyurJ7X36W8rPpcSc 43dZxcemq30trZ99urt0SLlxdyxw3MMDmdIHUXpiSFXS4IY7RIU3LGQCVCEDhuKyp9WuVjBSGMFU IRUKSXPGMt8oLrxwWzkEj1r3Xwt+zZrGt2kWpeKtZk0CBnX7Rb24Z5rlIw29nAJw4LIoYgsQa9y0 L4FfDnwzHazhL7VR+9M17e+XbxxHKmOKR4gkxDhWbDMUcA7hlRW9LA/vqntE3TmtU+i8rt97/gzm qYtxTUFfotFpta2ltd7NrU+GbOHxNrNvLLpOgSTYQiQqJnvpGYH5rWMEPJPk5UDJxuI9a9Q0X4A/ EPWNGtdU1S2kDTsVtNNjjRJJ42PCajcSh5CijnZI+0dABnNfeOnXnh7RrdI7Ox0Kw8pt9leWdrbm 8jdQQrrcFDMrgZ+dWBwTz81Y154x0+ISqb66u5pXwIsssIPUkKMKOc9Bk+vr2LCYKGjUu2u99NfX v879Tl+t1mn7r9bLy81p6ea6s+aNM/Ze1AQ2E+sahaaYZx5c0KSi6eNI/uN8xbaHAwOhzgZ716Hp /wADPC2n5u73UdQ1S7urcQpEkdvDb2q9MoY4lkAX+8X3HGSeK7m48U6OzNuuZGnciMWcRLDaMYAm JLLwPvBg2O/NZ97rlmrPI9rdW0uUIWK7hJdGx8zBiXU4PIb5h0JzmtY4enSp3i1LtezfRW17bbpb ERrV3H2iTXey67JO2nkY1p8PfB2hQzLHp9jeWszxxXczKbmVXyfNwoJl8wDG5ycE9OhrYtvD/gbT bKdNP8PRzm63wx3M2nxTzzrmNpI1mdftEBXAWMs7Fedm0Z3c+3iBraQ/2cnk/aZ3UztchbhSANu4 wFUZQTwCMnJ3Zqi+patHkSvDJdOtxKl5dPu2rmIExJnbuGBl8bhxyCTWEXzzXNFJRerS9PLrbpr+ Zn7Sc7Od1d99dd9b+ep6Fca74eW6E+neH7K1m0/T4IUsgqyX1nLaIc3JjkRtqOGLSTKQ4yBk0v8A wmF8q6fBbrFBDqRknF/alHaOW4t0KRMHDRodwOQy7dxPGea81Ooa3cyPI1w7wxxLLdT27Bt8caur CfqGgIfEuRkZXnIrJfYbJGildFE6GK1tmMkM0CEAqhkLLuKrj5vlLA5z22k1KfNCS5Ukvd01itnb z+dvwUoVG1ySXK7aPV301d3re6fW56xL4s1GxkFvPfPAET7VDBKiEzyKciOMwBAisB9wYBGOORVR vEUIS7LG6llSdjPqLoWbD5LRxxOCGiYn50A2uAdykcVw2rajp8V5aXGmK9zZ27Ry3AkjZLmIjHmJ HLINjKDkYHykZ44pdRuJpDDPbXzz6fNEJrSTy1hk3kgkThAvmckgl8juMdRPtoRlHnUpdFy3029e tvKyZVOFSKfO009rW3Vuzf5/I25vEl9cHTNWSXUbWeGWSGK90+CKGO8tOQEvoY0VY0cfK0LLtCgH bzVyHWtL8y6bXNIW81Jre5k0e2k1S6t9NEcoEs91N9kmhELosIEUQKqu91CjzGzw8lybiJ7LdcWr W7ku0cjrHcvjDSEgjzd2cEtn64qvE7AmKKCOFZIvLLsjtI2/cshL4KhX446gDOOaft4cz5IyT5be 98tGr67Jmll2/r+kjQuWiuf7KvBCkkclrczjAIjSIysUtlWTLbFC5EjljNuyxOAadZCw863lfQod l9JtuJp7h3QCLO1fKDDhguFGMDHAwar3MVzaRPb3DSLFOI0Ew8ud9qrtWNHwzxRIqgLGCF3EsBlm NRxz29pJCscMl39k/eK0zyxKmRyWETLv+9wrZU85GOa4nVnJyaSdtdba7eVreb0d/uT23av2dup6 LpPirTEm8+00i2htrSD5jb26oCqnZFLIuNkwiI3J5iuEIBAGM1Si8bWkF39qfTZ/7QlmJ026mht3 g8zJAMiPGU29eGAAA9K483NwI5GMgZHtwkMFsHSIW6Ev5MyqQs2T98yBtwJByOKwUtrjMjuyuksL vHCxP7uQD5WjPVSOPu44xXTOc/aUlb3Wl6O6TfRrTfXy8kRyx7v715eXp+B6dd6xJrUKrqd1ta6h eCz0t5iLeW9kPEnkwlI1t0Ukqu0LgYAFaMX/AAiqT20kV093IzWrq1hAIbNZoMRT2kO1RlxceUpf JZl3gk815JBE6xbWxHcIEETRqA6CM5UpKuHQ54bawLDhiea07KOfNnJNJJE1pc+bbLG7pCXJ++8a kK7MwySwJB5PPNZuonu728vP07obSj8L5ttfue293ovxT7+m2njDQtP1PXks7GA35EkMlzqcBll0 tolWV1LON20+bwVIGCFJIAxQuPHklxZ25gRYYUl80rbvJGsjNiNZVG7AikZDkKAGA5zWMbi61HV9 QvNe0y2uDdWawR3GnzJp1yAV8vz/ALKhS01Sby1UvG8UlxhdxJytUJNLjiltdPt9SttSgjhITy4/ s95CpywhubOfMsbxkkb2Xyyc+XjBqGor3otN6WXrurb9X/w2gkpNJ3cbrZbLy0Zv3PjzUXmJtLGA XUkXkyzyzSOkVvIMOY4942vswAykFW5zXK3fi3VyTa/aRbi2DskdvFIEkiYfvHxnaZipJV8bs4OT zV23sCJxC8NrIYmJHkPKbkLtyfNMJ8wnGBsztzkMMEA34NLv/tdqU07VHEsDea08CxQCZWB3CR1G Igudyk7MZLDHFaxqKcfZzdmnddmvdsrerb1/4fSF4r+bXdq/b8v1OOOpW0u37VJcT2cjbo1DSIVu P4mkVSAST3IOSOvWmvLDNdXQWS1+wCBbTTbRlkkieQ4Zy1y5Ll92cAt8pzjpiu3n0+w0xmmvb3RN Msb+N1nbWLy2FxBMMgvZwbgrYJyBtIPfIrz7VfH/AMLdLRceOLW9uo7lZF0nRNNFzBCVJUvM8ySL FIyg4Ee1SxOBWdV0pKEFKzi279XdJeu6+W1+pdnO9+lrdFra99/X5mhDCltE0cEyafImGuBDCA8d sxCTmIgb5UVijYZmPzM3HNTvZ6FBnSPFR1Xwtqklyl14e8XwMbzwfriSxxtbWV9EimXTtRaMKZyk scXlvGWQOXJy7v41/CWWNY9N0fxjeX1s0Ux1C4tUhXAVjNbCJY1jlik3AqGBG3aRyAazk/aB02C3 FrpnwobUbBxdyO2uXs7fPJ/q90LPwi4RkXGFB2DCgAT7SMVZ3cVbW99bq2nnp1vsKSrzShCNnpJS avorN6rr89fSxvXWk3dnI+nX13Cfts0N4RGhnhmiziN7aVT80RIDR5JYMSc7smuhtfDFzdSRtb2e om0eZmvJ594jk2LkDzZGyN2NoLZxnkY4Hg198bvife2tulnpfhLSLIlYFtYdMSe9tIlkcgee0Zkj AVsLtYAEHGK4m98S/EjU7K8OseL9dhtmvGMUGnSy2dslszHMZWBkL7hhQXyckYxQq1O61bd1a+v8 tt35R/A1jhcQ173KotWeiulaKb6u/wA+nzX1FqUHg/RLrZqev6PosHmxlLaTUorq5jfcCztHAVdU ycupPzDIPtzs/wATPg5pUSyQeJ9W1q8bz3uLfRtMQxK0JOFSaSJziQgcFu/PSvld/COmxH7Utub2 7Kedc3cmXunaT7m+RsvJhjudWYhvusCDitnT7EJCViS0iVTuMCoqzyEHONoGBn0HBz06VM8RvZ6v qnbZr7lt39epawsadtbpff0/yXke6H40eDPtcl1pfhvXzFNbvfR+bdxQfZWja3Ty7hRAu4TEsdhy q7jxmrtz8cvDDaU8TfC6/v8AVN7NC02oi3tCzsZA5kgERkTDLwSQOVA4rwaa1nV4Id0SvcJJHgSN mzidlY/2hHuAbdsXy9yjbwvQ8rDaC3KQEG7RgxR55HEgcMwJK5ICk8xgADyymRms44jEKLd46adG 2tPJ9972WhX1X+9/l+R6Tc/GTxS6RlPBPh6G2tz9pSzjuZXmU9BudpGYnCjODjHXvWZN8XvGWtq3 l6dovh+GR8S28EKGZ1j5RwDkOwYZJILZ5zyK4R576V5rO3t9jpGGaRUTaCCcZlwZFAUDKBgOSSOu YP7N1Foobq5vLKJQdskglUXESjGGVWOCzMccDcRnnHXnnWqR5ZPVuzbT/Xq9Fvdeite4038DSajo nZJ9L7Wv0636enT6z468Z6xDDJd+L7gpaMkKxWkf2aa1UMFUhY9qs2cbW27kbDAggGuVjubmZYft +t65NKJbh1ka7mPmRMjCfcCxBkkiLLu+82cEnNOlsNIhuojcaxmeWSMTi7m8tVQuhUiGFlV8npkc E54xTrW60OCQaVZm+1Wa6eSRZrKye78uQyBFWFmR9jZbaoGNzYODjNU1Ku1UUnFpKPKm76NPVX87 vtrqXGFOnu4tvulfSyttuunqYV3azai6ssF1qSR/ubdL53lmWDdkQo8xZo4t3JiUhMjIXdyIBYtc w29rLYLYxadeiVPLRWd5D/C8uN+1SSuC3A4HAAHqulaH441iO2TQfAOt3siSSRXbzJHaiwZOIJZm lQFpJ+vlk4zwAK3bP4Z/Ey/M1zf2GgaBbxSy+bPd3KOGCKF/0mCNgiOkgYOQoLMCPQl2nH4uuz6v rr+DHUxFPlUFZvbTpaz8rX/z1PJZNHv5oWiuLi2tY5LkMFj3FWQ/N5TMjKHEm4O8ZyvmMwIJNX4f DItXS6luYJvNjaFo5IXlhihQkyHDPiNliOUxkgkFcV1dz4CvbrULHw7aeJn1/VZ722itrXw/ZFEu b+QieVbNtuyRYI3VHTld6scZya7/AMPfCKDxP4xu9Ju5Lqx07TbiPTJH1y+lsjd3USLLf5CSReV9 lyR+7wshUxvkZWplSnJXi3dtNa92vP8AC3QiFeMfdbte+vXpordXb8+x7E0i3CATFobZWiiSUYzv CjcZM8KGbJXByfTpVX7Hf6lfWGiaFFHNrOs3a2VkJXH2WJVYPLqF+WO2HT9PhR7+5mfCL9mC5+bF SvLbpBPJd/u7S2jjunQZ8uR1IEUZdsKCiHzZRnaIw3zFvlPyv8ffixq3gzwk/hvQh/Z/xA+Ltksd 1cRu6X3hnwDHMhdLNogzWb+I5UiWSUES/YPtQCliiMc8bS5U03tvfokktU7fpexzxjKbi3qtG7K2 qtpp3v0/Dc4D47eMtI+J/wASbP4feCWuH+H/AML7i6tNQ1Wwl3S+PfFZUQ63q0k0hWN7W3l8yytU R2ihjk8yD5yQIhKtlbS20tzDpen2cVuLGKBzJOyAMGtMD78wIBDscITKwbc5rkvA/g238OaJYC+t 7k217uuGjiOVeEPFlWnQtKiO8jM8rqHlYqXUdB2clrovnZtLaVdQjmYIUkhuIZY5NvlW5SSVXDoo LtJs3fLgA5NOnGs6fvpVPeer07JKySWnT8Xvbplyp+7okktHdaLdav8AruZU8qqjmK0jkzEsqz3g MuMyNJlUOcElzg44IBznNaVvNrV75M0ZjieyTZEykCOK1GMtOXC/vHH8XbPy9q37Sx/eXEyW376Z VtIywOFkAJL+TIqExjJO5AxGD2NeZfEXxMNLhOiWAYvLbwtPLCxVbu4jIWS3Vo8uSxBwMY65wM4l 1owkoOioyl8L11typv8A4NraaamrjB2c5OKXm0nf8tvxPRtD8aeHNF1tdT160tNYgtm+xnQ2Cx/a YHjJa6tbo8u9v0iFwyi6AHl7ywr7A8DePPBniLwpD4k8HQppVtB5lnexOsEd0LgEhUKSMro5bCAS bcDkjOM/Ang/4b+IfjB4g0fTLXTpRb6W9m/iG0tIJo/7B0QSRw2zXFxKkZu726iKtbCEyrCGXc2Q a7n4n2eq/Bf4n6t8PvBcW7RLKDT57zT5mWaS4gdoy9zM+5XN2isxdiigtjnHJ74NKEZ1Y3ldWT3v o+i2vbR77tXOCqlWkoUaraXvWeqsrJvq+qX3bdPtbUfidDp09tHNcCK7uLEK9mzb4rOYsPLkumXc oa4ALRKuQVWQHkCuefxxq2tfaYIpAsaoj3IjtHVXeM7EZGCYMf707y5CD5ckcVxPhGDw98RIlTwJ c32q31vHDLe6HrMdpbaw0zpmZbUC5kjuYYzG4tz5qlQxDBS9e1afoOqWFmP7S8qztlxbvp13CLS8 jYZLRXTlTE6EqciKWTdhSOldDrTlF8j5ZNWvo7bO1uX+tOxx1XKm+WDfN337avp0ste7068x/Zni tpbSPWJILeO7hSXTGiZGSUMMKHeAsqSEHkTFV45PQ1tS+HNWtVV7m4hZbV8FYVEksgcDG/aDjB4y p6Vtt4i0XT7V7Yw217kGI2YM3mRKCDmJ0SRdgIHJdTgnA7Vg6p4sv7pBcWUC6WjyYEsDJJHLGuPl AnaNt4AwRjGBxWqvGnF1Vzysru/pbayvdt/1oqdfl0muZ7Nuy7LpZaeemgXHhs2AtrvVp4LG2vXK PswzRuOR9nKbnYHIyZQByOcVg381hp8l01tNeXWyNQkxZGgOzOAWLEjd3HUZPXiqg1icTLcWs8kh XfHNJcAXNs29SNojLMyTHJ+ZVKjru4xWc0awfvZrSaZcss8AK4eYj5mZSccscgJkdcGsoSesb6Wv b7i1VqU24c14Nq8bJbJNJPotH/VrSWWox6pG6TW8li0T748BXM7yEZLtIQyxkLldvOM1clMksog3 xq/lXEQVP3qBTswC0nKSv/yzVRtYhs9BXK30d1MXzbXNmuEkj2wz+asEGS5AEewogORhtzfwq3Fb unQXdwLdPsr3NowV4dQIaGQK4x5m1wsjuhXhduFzk7QVzsoTtZU009btvVMUnzSSUdnqk9/z9OxO lwlhFcRyWcl5Amn3LTWjSzW8haPZsac2+SVyciPJRwRu6DEdnIJdPstkTLczrHP9n8l/IjtHY/uV JGCcDhm5yeTjFbp8P3D7gJjfI7oGUSBZ7mMhtySOm5FlXI2IxCtzuYYFXYNBWG2aCzj1X7TEiPa7 IZJo1uEbcto7lNg3528Ns65YcVnOCpwskoNttxu3e9l9rXX/AIbVscpRg0lC+iu7y3bXn5a20tv0 RiKb6KJJWUwRW6NbyefEs1tKzZwY4WzvcejDHH1qW4hu44GuZoi0E2IlkEMwEK/LndFHGfKYgDGV xjnJ4rpl0W9vbqzE6tYTX1rc2dw0UkRs4L+zVvMmi86SPY6bT5gkCEncF3cU829rpEKXl7qvh6C7 itxIIzqFo0OqW5IBe6innjEUq5JPl7wOcHFSuWLpybSd3e/yt9z7dUm0JSlP4INWte13va1732t+ e9nbmW0yRRFcFFktJg8cSvIEaOBVGx8ZEjMzZyrqpHHSnWllb3sSRDVJLRgSn2VkZo2YBzG0bhdr PKwCkMflwD1IqTWfF3w80hRJd+MdDUusUUdpppl1DyrhjmWLMCSRKqnqxcIMn5q5m/8Ajb8Mrec6 bDd6pqkhQ+WtlpyQxpOoQxyJNM8at91wzKzD7oXPOFV9+olCSWnl0tdbPXr0dlvYtKTS010v0077 enZHRxaVqV3YytKE09rbcZXdcmVonKxKQ4yQ6/OSckFjgYyajhsJ2e5kii+1StbLl4ZolKkjDptd 1XZgDJ++P4R2HAXHx48N4LWHgLWr7Fyhe51i7gtoHKqquB5c0qurkZAOMfxbc4PO6p8f/Gkha30r w34b0SCS4E0JCLdTGJAcJuQsCxBySxCDAyRmlJwpJRsrySTl6pb9NOq07u+5fsKk9b2XZpK6dvn8 9Oq62PZ7DSPtCzQww30t3FGzsFS5k2oBlwgjR0k2f3ckHGO9dQvha4SKxmg0qG9EkD/Z2uJ5LJpZ s8xzJJsCAHqV5wcda+Q7j4sfGC+Fuf8AhK/7PEC3AlhsLKG2R1kzsU3AY/KAQG27pBglVJAFc2Z/ Ec3lHUPF/iO9zvlK/bCAk8h3fusugEYY5GQD0GKh4qMbc0eZxsk+2qStbVX8lf5Mn6tP+vl5+evo +x9wwf2ZaySTaxcaNpFqiHzzLeWr+WRwVUNIHbkDkrnqcGuQvvH3wu017hdQ1m42qSbeS3tDLY3a gkh7WdFLPExBUMDjKsB2FfJMWgQ3Lt9tkvb6ebLNNfXbFBjnmNJWB64568Zz21AJ0a0sWSKa2tLf yY444ldEjVnIVQ+Mck/dLc55zWUqyTv7CLTfeV23bzuvnrr5abxw6ja2jVu3S3k/u7n0VefGz4TW dkk0fh3xTr024L/xLI1jVwCCo8+Vo5YjnJbZ2IBPaud1H4/JM6nQfhbBYZWJLe4v7t2u5VOQPPNv 5mHT7xcnLlsHOOPHIobRjMFgmVWQB4RIsSKQTl1JwAcYGPQcUiiAMLdJiqQlWiURuku4k7gJQCku AoOA3HJ7isfbpy0puDu/lZW807q2qvutTShQSnUlWanFtuMf/Ae1tvz9T0O8+NvxJ1BWh06DQvDU ys0CXEVgskqpjD/vXjDu7Lxknnj3rz691fx3rMq3OsePNYuVeWfdHb3DW1sjuhQxiKNgDEM5PAzz xjpYSKbdG3nMLhTK0avGXRo26vJx1jXJyMn60x90kKNHsMNsX+0N+7TzJMHEkQL4KLkFt2044x3q ZSblzPey120dna22lrba9fK7U3dRilr3fRLz89/+AYMukWFxMDPcz6uYImdXvrqScvkfvHVHYqm3 oAhwf4ua17bTbC2jtZLbTwQkTSbRBHJlif8Als5+aUAdC5+UHjgZp7pGXRY7SOWcFUUeYiKkEn3j KQ4GMd1J7ZGeK1ntp4ZZgz+STAI/LiZvL2nb9zeoPToehPPSs5wc/eu1bfzvZJfh021FGNm72fb/ ADMmaNYXjuJAAqozqkSB0RpiFxclQSrIFyg6EH0wKvXEcJtZJsTQ3DiJlkJA8xQqgtGq/L5THIBP zbtwPAGbkUUFuZILN7hRNEBfCVI5opZgc7S4dtpZNoG0EdOeDVV5UcS3DWwS1tv3RRd77SoGC3y4 XJbOMkY5zxQ5OUfZRXNNvS9+jV35dr/8OaxaT129PNPVrW3zMyaS7domQRvHIAHSViUA2gfLkcMG GeMZAwTTUihaby1tPIlVoFVpEw02XAcxbMsylchyBwD9a0JY3S1ieVLby7hna2Uzr5uCuATEhLqD kBSygZGAc5AjtbVk8hbpZp92+TzRJGs1oI1MiLEWbbsfG1yTnHQE8HP2dZa8qstXa7sv6/EHOaT5 W7LpbRpaW2etrfO1yWC1jia4WZrgzpcunlrG4WSNEZ1UNtGGBAC54J5NZ7GNBcu88c2yHzI7aBAL 4Oz7THggKQM9Sckjmtg3EDlnuZpBAJJZ0kV2LsDGQIyAmN5OM5OzrlsZrLuLeWyV23xsqiJsxoTJ LGzhwI2KjJHGdxAz3I5rSFN1ft2tpstPyWy/phFe01k7XS8n0tsvvtq+2pHHIZrsT3UdwJvKRVMM UYjK7AFFxvw8rKMBs5CsDtzxUdxP5UbRRFTe3Mh2TGaLKfwjMRfzF4AGCowOnGCdKWNHZrprtJVC rtlAkQKWUfJsVCGZT8rZ4JHBpjhYo0nvLiQJAUZpIIlWZ/MYkKW6IQMfeIwuCT2rG1k1d2vrdvV+ d/T/AIBcuWP969urtayf+SI9HtoJWvTdajIbi28sTtDENqxz5SNVBAV5DKG3dTs296seFtP8IeKf GUfhDxH4iudNnlkb+zbRtGnP9psrbcW0gi/ezbhgJGzAABmwOnWX+l6LaeCr3xpr3iaxsvDltcQM ltYSvd6nNdow2LcssKiMN8qLFG0vzKWOAxNcl4o+LcPjO28KaJ4O0+00bWfDWoWt14Q8QPYNLq2p CVl8yOR/LRoWM5dGkclSuVyMZrphTnKMedU3SS93lleata11fR3v07X31551ZRgrNxW6ta6Vkr3d 323b29UfSWq/CHwL4Tn0m8u7BNVdL6O2aJojPfyRmZIla+s4Q728fltvUqu7zQgbCZI73TJfDdo/ iKy8L+GTp9potpJcNrC6K+3zhG032Z5pYQsLsUCpIjbkJDnBFafwK8H+KPDejavB8RdRtvE3jXWI jeaTbtpc01zoNlOjXN7LdXsXmxy3DICYkP3F6EMFU+maZ4aluNPvoVljg0x7lGucQyKuozJJudZI 1Rp/MXBCq8axFsb3VcsOyEKCj+7hO6esqmjvZXstE4vuzglXm+unnv8Ah/TPKUvPEWr6doV/pGkz NZa9BHq1gmqTpplzPLaXC26zTrAR5kCzeYV3n54l3t1NcTc6d4w8RQfEdrnUNC0Wx0JLSz1OeVnI u9TvXlmih00RBlkQKQs0g+bqRnpX09qHhqwA0+8vbp73yLaeLTrVlEEVjFGn+j2SC3Z1iVpGkd9x UFyOT1D7TwhpFrplvdaZpdumno8V7qcd35s7G+HmM3np5bCU73xD8xGwYJHApTg2o9Vd2XZ6b/1a 2/Qz5ne60d76X8vPyR83fDr4XadJrmhaZ4x+JywWfhiS08VrdeFtPMd5D9qR5LjS4b4xpJO65CFp G8wMSMABa9T0vS/Behzvf2XhX+07bUdd1RZoNW+06tq6QXzST6VfxNeruVbySRJLtQdke9ghOMV7 FGYI1st+m6HZS3jDzIZI4Laee3VSDNApOEULtby5XjYybsKFINZcTi0jilLzedCs1vFdNCjTT2+5 kibH+rQQKAseWByufukGqivZx5rbaXtft3+Xa4Ocnq229tPl2+9/efE/irWbK4NtorSeTo0dvJqm tyKSFTS9IU3mqwtJgMsk9tDLEjYIJYKpYkCvz0sb+/8Aid8RfEnxR8SG4mS+ldNKskT/AEO10zTn Nvp9tEr4aO0jiwFWNCMsWYDjPr3xe8TX9xp+peGNIjke98V28Gm3l7FcMk1ro0l1HJqMiRoGZCUV 4SQMsjNngmue0Pw9/Yul2cBSZYrODEXkyA+cpKjbMWGGiLAGRFO5uT14ryKFqjlKTs4v3UtunR33 Ttv3fp7kIqCsuitfZ9NdLdr+upo3s8lwxt7eK5liufJmnjhl8u0shGrKlukjAHy5mZdyxggsoJYY rrdG0REKS3cUdtLNCZnWBfMaCeIHylkmZgA7x5IMSyDI5xnhttp4jt3VUdlVorm7WRlCyM3+qhsg cMISrEuMH5gv4bktv5dlIZZWVGdJFtlYo0MfTG8c56Djkk475HdSftIuTnKHK7csbJO1rPbW63/R GfKlJxu7PZ7u7t3v+VjN1C9kt7OXUJDLLDY2rG3uXURzmRtyYRUyrBeMltpwN1fMmn2y6trkSy3n 9o3MWrQwCC2+crPdyhkLPIFjwEcMDv2hTyQcge0/EWSaHS9P0+0yo80zzqbsqfJbojLwx5OWTAOM jGTx4tpgvdON9Mps1uGmiZBYxuDiBRGJg5yAy7QVOewxmueVSM60UvecL6tJu75bWSXW2t/K3U2a g4ODje6s291bt6q598n9on4f/Aqwv/CngzwmfFHj+6sreTWfEEt4FsrW6jRVuVuDFGcvHIC0EGHE ZUA4xXzB8Rtc8UfFjxFF4y0KwsdDvJNIsdL1A/aGuL/XLpWVzPFK6rGjOiu7iV41UIVyScV5GbCK EzSl7iea7ZppzGzPLeXDndK08rA8s+d4U464rtvCd5FaSKZEllKyLsthO0cTuG8sRYAChowzK7ZA PXtWixDrRlCoowjGSUeRauWiWstut369EcnsVQ5qlJXb0ab2i3Ha3VW7bL7qWm6rcaXfQXmmX2ox eKbN4Lc6tplxJaGxaBnM0QjiBSYFsee8mFDqqozbiK+ofDHxc8S+L7xPDniqS61DUI4SLO+eRkS4 khELCOR402NclJN2GI+Ukk5bFc18F9O8L+LfGF5pQ8PW76pql3LYW+lGacJGIIpJrvU7qdAxjs7V f9IkclYpGjWPfkgHiz4p0yw+Odlo97qwbRvA0mrzeKre1s/sltfXAdYoX014wZZfNt4oI0d+WMTM o5zW9GXsnFVb2bSjbfvrfT593ppvzzVOpRrVKavUjBySlsn7q0S5Wlrvd+bPr3T9M1C4v5Jik+np 9k8g5t2kFxKwwqRkBsuxztIG3rlsgV1lh4B1oBY9Q+y2UExL2/8Abl3b2ITcc+ZHHNMjurA4zGh4 68HNeEaz+0f4m1YW6fD3w4vhjS7YNDb6lrA+13c0e9/LntoZFVWl2/MokAUDk84rwbXtQ1rxZetf +K9Y1jxDfTsw07UptVvIFs5P44obG3CxKgI2jdwBj0rtliqcVy2urbvR6Lydvwvo/lFPDOVKM2k5 Ldb9FfTo9dPJX8z7ou9M8FeHm1J9X8d+E9Fn0wGQxNqC3SS24PP7uzW5LzYBC4B54+nnl38XvghH sNl4g8TarLI5WS30rRUmgu5ckM8Nze3liyxOwJR2iRsZyoxXydb+H9Ogsy13a2rT3CpLHcTefLcu MglG3yEZ9FIB5PTPPQQ2VnNLFFJHBaWm3ehhhw/AzgkAhST6dCfz4YYpy1gou+mt/J9H2+7zNFhY walNyutbaWtZO2qavtt5Hq2rfHTw9p7XFn4f8C69Od6Xtveazq6RxG5TJET2UEV4RajH79UuW3qf uLjnEl+NfjS9ha70nw94U0cvG9zdv5k9w0UhwrG0haVV8lwvKkKQw+ZOa4KPToYZ5pbezkk+0CaC 2vpbhitsyYDs0P3MSEgAnBOCCBSvF9jVIbdoDIYR5v8AoqOLeXcNp3Kx3/avmJyMjyugyabxFa7t NpX+FPReWuttP+GOiEKcW2ou0tdWtL2v07rQ73/hefxIOnottf6Zp0bwv9qh0vSIhPcgkLvW5luZ vKmP8CtEmRuy6jrly+M/iLqWnKtx4v8AFNvIZg0cNj9hTylf5lF0Y1JAPOX8wKueWBrmwsAMpkEk EJSJL8RwKqLK+4RzLjLBUI+ZR1JyemauWyAFQl3MjwRNEXt8LFfQycpHPvyeVI3bcEFe1Q5Tqq8p yclom3slbyY0qSuuVc2j95pvp2S3ab8mVWm1WSNWk1jxDdjzHaa2fUJkBuZT/pc8jBQwN0d/EW4Z f05rNk0S389ZLy5uHCIbeMXEk92sMRGMMBKo/P1OcVtW482QSQXUsjRuQ0zKFWD2wVG7HqM+tTpJ I0V0xCxPkhoGwxPOcr1JyAeRyD9eM71EoqcmtXytPW2l+jvbyX5a3FqCaVOCT/utdvPy6WvpfZGA mlaXbqBZRKohY+ci2o8u8lkGGWZpZHMcQGPmi3Ng8c1oR20aBDHb2+YCqrEpBhXeThIZPL8woCSB uAw2c44NWIzAC0jC4I8nyzHwEEo/ugc7c8qTyOeaW3hZmjlETrMVc8f6nbAAyMc5G9txzg844xjF KLl7S0pyUFFyT0vdWt0e99rJ6PXQFJXvyxfqn/n5FSSHzjLALqaK1LgPaqvmQLKBlkZm8t0HzA5U HdnGflBq4LSBkBDQhoh5SwxFVLI4+YsXcMF6b9oJHbpUglWWPD/KzsZJvIjBKljtAl3nplSeuepI 5GYhE8rv5kAVEePynCKjuAQSdwJyv94AY9SM8vmVSVpN3TXa99N+6/LT5qUnbpFa7ab233v5X/UU 28b7YY8sFYNLApPkogxvZZDhiw64IxjPtUpEsV0iZhmhABEC7vNxx1O3GR6Z7ce6xTTFZvLRV+cQ rjliDxxjtx1H506GMAiZZiJVyAAMjPXbxnn25OO/atKai52klbXf/g2X4Epw/mf3x8v7q/q/bQIW DaoglV5RuiDOTvj3csNu4KBz97HAPbmtIoot08tW+0KQoCnJCnk5LY4HXnJ9M84pW0wBbLyeZPbn ZnDCPb1Ax0PoAB9KtAxpDsjZ5ZnUEB8q+cdWUgEc9DgDGD3rL3qbfvylbWztbbba/lv0Jk3p7OTf rZ9tdErfP52J2khhjZphHO5RUMgDiGMZICtsUs0gJJYqpGCOcVHNOWCr5yfZ1AWMiLaqyHG8Ruyq 7NgKDuAGCOeafbyBEDuhSSAo7xLtcOpOFfqf4lweSeDSBmeT/SSiqtxJNHBNGW81ZVVQqgfd2bPv HAOeOlXCpGafNFJp3/BfnrZJdN9DOEVJyc5TUldtLZWa0tbtfrbfyESQLJ5RvFG6Fw24AsA4zjIJ A3Z4GQewzimSwKIo1jCNHLmGQEv5m2TKFwgAyRnI3EA8+5q4trEftQex3SzbTAI5ANm07vMxnP7s fNjv04qtFsg8wh5ZrpQXklIykcYBJBX2G75sdeeO0yuoc9+vKk+2nn5sqCi9Yt2Ta9bWb9Vrr6oQ wrG9xE1wXh2xsZ4oPnZV4MQ+bdleR93BxkHjNXFWKUrN50stuQEdZgd4cDCrhfmGVAxxhR3pFgaS WECQQ+XiaS4cja6E57nDADgjJPPepbZo0DRxF7a2Fs9z5067p7h1fBVDjC7v4QRkA9hUrmaT2Wjl pft/wba9fU0crcqstW9eutt318vu8yaDckcTwKEtmDZt2OZW+dlEzFuSM8LznAUY4GUb7J5M0Agl a8e7y8qyFFliaOPbF5LqFbDK5D7gDnHGKkfyol8w5wYo/Lt2ObiItl9rbT8zncHAHIVlBGetfZK0 yy3DggyxBFYESKgQYTjHAJPUZznOalte0tFyWl79el0+lnp0/ETbvbbS9/n/AF3uVbiwglWSeZ4k khSMROQyuQrlRCFUsGZWHIUEevGMCAffubWV0aJyx3MojKpmNiDh2VmAB2qeCdw4q4qmImQWpliL SKzSsC6EyNta3Ax82eWJBG3BxRJZI8RU3V087KQEkZW2q4wQhUAYUHj/APXVPmejnNqzVm1ZppLt 5f0tDSMnHZJ631/4cpsAfldRbusa+em1WjFvMQOBuxucHCkZIJGcDkPSSK48nc7SpGjhhsyISg/d rI4+XJ/3iB1JA5qdUs2ZYp4LiaSSICQI3zMsGDtyOA7YAUEg7jxkipr2T/UJDDHbWq4/dRYIIxgr dkkljjhsYzU2V7KUk12e1vlv/wAEzqSbta0b3+FW7d7meNtuu1/3QYFnmlXFvj7wABJO7kc4wc8E iuR8RarNNo95Lp99YR2Oigz6tbM4W8vkJcEr5gUFVXYMRs2FxjngbOr3LLBcwOFgilieSV0kMxUK DsMaSYABBGduVUcZODXyT4oa71C8naW5kHnMttHGp8kXC7tilo0Yq2UUfdznksOawlOKUOXVykk7 9NUn27try+53TpSWrcpK3X9fXu+z7n0D8FfhP4/+Lml6vHYavZ2PhldbjnsbKaRp+ZmRzfTxS4Hk 2yMNy88g7Qx+WvvnSPgRF4G1m9+wafF4ou7SwsYrTX4YENlbXIZHkayQhWd5Zy2ECAqCGbAryL9m H4e6vYJYTR3zQ2j2lrJexW87KnklgTFNHGCWJz8xwG2sMgDBr9VdPS00tJvN06CGO3tlntJIRNcQ ORGNsoTejLOSPndty7RwoxmveoYaj7Km4pqq4puSd3d6p8rum1oldWt0vqeVicTavUp2SUZJab7L XyvrbbufONhcXvhu5gvtPae8u7iGCWW/ubvyLx77zY0utLisWR2cBGeIBzFHg4V26H2K51N9WWIW 5NxpVxawXciw2os7+0u2kSO6hkXqzIWIAZVDkfK23JGZ4s8E2GveX4k8OuLbWrRo4dQiaKVpS0jK 7XdrGZ2i3RKDLyjFtuBya53SH1ZLbW7e/utQLXsCySXPkxQ3c1/ZuHMULHasUbQiVvu5JAA5wKqr +7VqjdSbtaUkk1FW920WvW711scsrSV0/e0snqvlbW3n3OhmuNOW88qCIJZPCy3EMjAyR3CA7XuB Jt2tIevlb8VzY1tLaLYWhhjnnZlV7iQW3mQsVWGQeWfMMgX5QgcdNzCsq/hhnihS0gvby5ZR5scj MLhmPVWlUBNx46kHngVnSwq1zBaGyVY7Jo5Wsbli8tnJsBeTzQSrGRiWxkkdxnIrGMUkpvmfN0uk tLeW/TbotNTSnGyvK+u6Xf5+X5q5Z1PU9I1OaC/fSi9xbZaRbqe4NtaRl2j86R4VYq7yxv8AZ4wv 3Cm4KOKwDq+oX0srrBdRW+ZmWWRyrRJAzRFPJQMWHyB1wMkHlc5q9HJdvDfubRreyuFkCWKhftN2 YLiU/aJpGBVVDZ8tByY9uOuTDOl6dOmkmmj81LiG7t4EIt/KtcCSa5llHzPMGzCLfo6puI3GnK84 qEdNtd9F933msXFO7V/J6rpvaz76qzsfjbpF9f33iBtWleNrq8vIYJZw/wA9jZzAHyo+SdrqT5oH ct9K9hKwT3P2aUsY0fbFAG225aJcRtFNkBJHDEttOSeeuCPFPBUFvGt7c31vPB5czrC12m2S4Kth fL3YKsf7wIJ6817Tb2pkSwU26Q27yCRYpJPMUEgkSSocgPxlSRnGea8ilBxjB3Wyb87pX/X00trq verSUKkl3k7Lba3p38tfU3LG0iluQ3lz/ufma3mcmbzF4VkkJyYgC2AM/wAJPIzWlMsZhmnkt3WV yIrYSPu8t1YFSV/iAxkdT074pbOGV3R1lhd43ZjI+ABGpA2jIBbkgBOmBnB4q+yk20sriCd4XeVV EaQSc5UbCACzANkEcjGfeuiNo+9KSSb+Hr8/Xzvay0aOOpL99yq+yu+nSy38/wDM8I8aRm81LyrC ynvdQ8sO1zM5jgjuBgFA54XgYGSM5weOnKppN7IpN1CyXUMuP7Os7gBEhzg+ay8SrgdDweR2r1zx P9ngsIIZy8QuJzI8pj8ycvuHymU5c56EkkYPfFeYxRomoXCN9tTc2+1jgKq8KgkhZSmMrxyp+XjB GazahTqQlTXM5ppqNtLOP3b9vmmdMU0tXva3l/XYp6h53nsLVpYfssSG1tEtEaMtjFwv3OQOcE5y Cee9Z7pevCZxOsWYn2QJEseDnk/LgbmJ+buf4vbu7R73zjc29qt9IkckLJIi7cSg4cblA3EY+Yc5 5HSsW+ijKL9js7yMorx3kMkmbeCZZEE0jcklWJOAOFHTiiELc6lG12prayatZet3f7+gT2XZyV/T 9DK0TxDrvhu4vLvQdY1LR9S1LSpNOv7zT5PLuzpsvE0aXI+eOF3WLzI1IDnaxztBq38OPD1wf7d8 XapcLqGq6/Olol5eTSTTxWkG5ElmDsVMhMRKyYyCWAIB5wNQhS2LzuLScRlgfLXzoJY22fupo3DI VRyGRMBSVzgkDHrnh20GmaDZ2UUyzRSKLti42R5mDPHaqBgbEyxSLGxfmwMnNTSnKpeVT3nTs4eW y66b/dvu3dVYUkoxoxcFLSa0tJaaadPvsl16a6W8zkSLcYhiQRFJX2xzN0DhCfmVsgDucdxVeG38 uZY9twxEl2x8uQxR8ljxyB6Y6jrV5Wkla0zDbqkKM6l4klEjq3CLkNxtzgdPQdalkYyXIjUGSI3J lkDINqRMo3xrxxGTnKD5TxxW1lPyvZtNu/d7flfv0MY1JQfLo1otu9vNsoX1r9puIWMMt3BBZIyW 1tN5UouuC0skg/1oU5LDPXJB7VetRLAsnlSrNaKgjxKNxSYAAqCerAkjPtzUbuFWaK3tw7RW8cFt PCuxY343ugH3WPO5lwTzmpN8Atpoo3laa3lkaaJR+7VPIdi6ADG8HB3Abi3PUZrWn7OnRajHml0a tb/h9flv5KormjzTba7ddbWS+b3+d+1ZHiiMhYsvm5RcvIAk/f8Ac5EZHTDbct3zVi3F0qfZ4twZ 3WSS4FnDEuxQduZAgLcMRnJP51JvilT7QxmaDY5WByQ4dQuZGz3brnnp1pn2z9/CT5P2cpFtjnYh sZKuQR2J27ye+09eaxinLTbS78tvyMFduybS6Xb29L726X+ZGLhFkuAvOFO8+Y5LuvrGW2YOTztB 9DVt0cx2sNssTyzHPlsQDFn5t5/ugHOefx61U23CrLGHs3jimaYwq5MskUmcN8xO5I8ZGc4yAAKm e1eYRxW6R+ZIPM87zNsmAf8AUtMGDCJum3dtI4IxWkv3dO902306bb3/AK8iuTrf3tNf076f13JA 7ySBvMiSSEFXITbbZH9+LP7w7sjdj39QYrobWgUAeZIoZmTGQAck98cd/fBzTmUIyTTLK0jAwiNJ WlERBI3qMsFPuB1/DDB5sNv5mwM7N5YfAJQHgAHqO+R0x1FZSVRqE5Ti072jZprZt9tn52vsm7pc 0ofE3JN6JJu22ru+3l0XcYiNI8hiXdsQtKWkOZ1BwY1BzknkYA9u9QvLIpinV54oIwsEtoZpEkj+ 1kpHJsVhhINhbJHBY59ppId8tuoYQ5LZZDsKtjPJGCCOoOeO9TKjRPLG10RJJbKTJJF5vnKzOBGJ mUncMdAeCRwM81GUYttrTlt0Xb8L/iaRfMr/ANdB6CBJYoIo1kjRZIJJfNd3upQFYzMGJzgOqgjq QfQYakccbKJnkO1miRNxIRZMZX2GOD7dTjiq6Qp5UQgDNOjMXjmba8K4HKk8hX5AAwMD89BSFDOk MXzjDl9rMr4x8pbJ9yRgj6VC5Lu2721u7u39aL7h6ddupVQrD5srExQRt8vkj5255UYxljkcepIx xUsazQiNopItkrb7XYQcSHn98exBPIPbNQxbJBIjbo2DGQGJjGryDOASpGSOufSo5iII1CRJHErb iFjDgtnJYkDk89TzxVySlFJSUWrbp91f+npu+jC0Oz/8l8vL1/ra4IofLRnE0MrvkeU7Hkd/xOcd O3SrYS4NwZYo2jnuEVVvLp/NaaDAUsVbPl5IIx2xk5zzVJCOiKw3MP8ARUGAxGOST/eIPXpnpSyS ywRSMgkle3hkcfMTMclAUmc/M4TLEbicAjHalpO/vbq34JPX79/LvpMo31h7r/DpppZ9/wADZjaO KGS3aOIvIvkLKDkl0JfepzkD5+F6cZ4GKr4eNwJYZiSqRvcCUkMiMSqpzztySeO4qkheWExrChyk cokUhQrsgZs4xhxwGb7zcAnA4uh23xFxCEhTEYUB2MjDDnyuQ7kBckgkZzXLNOE1aa3Wmvl06X11 f63JSjTTck5OSd2r67X738unkO/ceZE26QRq4Xds/fK78J83Xbu4c5OV+laQg2xRhEjkkYyiV1bD yxkNujJ/hLD5fUZyO9V4ZZUdZbiPy1TdtgB8wzluI3defKC/e24GehGMVGnn+Y8yOWtGfLiGPbLH ITnbHtwNp6MvQgnOa7Z2lSSWlnd9eqWnz/z3CnazsuVXej9EPlaN/I8n5RDFJ5kM43xqQPfPGeM9 uDnoKtiOG4gtpFFxHJI85ZdxOR5YACgYGCMY/wBkgdsU2O0MEUQkSeZEczMgWOOWeNjkxyNgF1IO CrEr7VJBKx2Hy5JJfIle0XmMDLYO4jHzBSFz14wKxtNwajo47vo10tr0WztvZaBUdnF2b16fItK1 tAzS+Q7GNFjhyMv9tIGZjxkFU289RwOmKrTQxNGDNLOQsgMsqAltxAZgMemfzGafFLNNHYRRxtDK JpCwkd3kkuFH7zzJCctCY9oGSVyOO9RSX0ZZ08wpFG0wuNrC2SML1eSRysLAPuB3fMVA/hIpw5VB udoy095vu1f18tVd6+ZS5m7qLta1no1s79vx6bjWWAgSRXLGOEDyVJxJIxOJFPcAIPz6cUXE0UMs TCRIUnRjCMZLSAZJ2k844J446npXm2v/ABM8F+E5LSLUvEfhyTULuR4rW0guraeaUEjCyLCxSNl/ jdgC4OM5XFc94l+M/wAK9AaOTWvF9mL6K2kn+yaSovNQgWeMhba2h+a1DXAPluSnmIrboiHG4HPS 0vUjbq1202776dNPW2vs5tX5Xtfbc9kLlT5J2lJMztcQNt/fJ80YYA4JDdQRn8aiuYyroZQNsq5h FuQyyTEf8tsdMnrn05zXy3qn7Wvwt06z+2Wfh7xPeqvlpEZo5dMiSXI2veGXYkiu2C7RAsFyUIOK 8c1r9sjXNa1GNPC1hpmiadFDJtsyn2m7MoBxcyyfOXQnnkk4OB0FcfPRjVc3iE16S8t+2nfcqOEq 1UrRcWtk1ve3Xy77eml/vzUNKtpIILy7kKDY8jxsd+IUG17QZ7yZLbRz7HBrwPxD4X0K51jQtWsb 5ru1s9WUXWnRKIprbe6t5QxgsAOTx3I+mn8M/iz4H8V6Xb2U/jS3v/EMkDXOo2upRrptvHcEAkWk zeVmQMxRcHcQMCuo0fWPDVl4lK6noYlja5ja3EDeZ5rbEY3pBJQjBALAfPtyck1tTdCpKnBW0lzX 77W2/wA/LXciSrUqcoNNvRXt6LW/Ttt5XP05+A2o2VpplotvplraWzZfzrdFS98o20K/vwBufLKd zHjHB+7X0z4h1lVspLi2vnjuJ47Wyt4UBKSJMqhlLD7hZSRyeTX5/fs+/EA694w8YXFtGo0rRbC1 srW3dI44nRstLJHCoCZJJR2xlivzZr6RPic6jm4zPHYu0rm1gI8sTRxmVECMCqCA48rYAUIAU4HH 0ilTjTpyglrFW116Ja/Lfrp3R8/Ug3Wnzq83JKT72S++y3bW9+2nc6b4rn0+41NrKEwPO8CCC4O9 4pLJ1Mk8DHkKApd1HDoGXqeaPivwlq3irwfrXiXwn/a/iz4ixTreaR4JsdQbTbDVra3PnXUzzDK2 mI42EjFSFGXKnkHznQ7qVWaSWR7mKeeW5tbn7XMby2eQsJIJF34ZTngMDtPK4Ir23wdqw0a9juLG 6ltpriB4Z542ZbiNLhPKkljcHd5iq7MOeWAJzkirlGE6V5R5paJNLp7rttfvd9vTW4pRqK70tFWe 1k7df8vyPILLWL0aFpGqTX+jafqF3mz1PQbfXEv7rR9ahwJNOuViETSNHJlDOwGTyMGue1DW51N1 c3V1p1vJAC0oa+ihjncEbgVRlZ9rEksxLE5LHOSeH8T2V58P/G/i3wrrWi6FrGr3nh+HxNoGuiVb abUdC1HUpTJ4guX1NjLNqwm8nTZLWwIkRJTMqgAGvE7vwVosmpm9v4rlb2+BdIX1C6k0+BnJcqkL SFFcFtpbAYkZPJzXlzk9I6q3TbdLt22OxuCcfd5ovZdVa3mtHfvbazse06t43smtLK4vPE8MZe5B FppMxuFZEkKF5RuZlCAAFmPbjjFZWsfEXS0uDDpFhqOqwyREXmoXV5J9n3BflSFAcBjwd3UNkZ4N eVQeHLG1uXbTYoLW+ihc3McwEiSwbjuZpGyZCUwQGJ2ghBjGBcWPTbUuqSzW0UtuHhWCGM2j3IYq 0bIV2qxYbgABkENjkkqM5Rd7v7/87lKNNq/Jd6e6rX3W3ffyPi3QYor3Urpr6+vCqGDEbKsyNInL +UHI2Zbrt49M9R6vEssl59qtoLpYovKUrgMWfBAkEQyrbI9wKng7s4rzLwOvmXmxLdZmaPh3XLpM oxJ527Cou/O1txyvOM8H1S1jdwGvP3ZguB5y2UzKZCVIjAIHK4J3bc7TxzmuNWiop6aWVvI7cSpu o3u1JuTb2Vlrp1t+P3rsgkLtKLZPtMewPDMw+yvFc8b0MC4DqBuO4gkYwOtEl5aOFRpFMiI4Mzti Np1U4hVukRZxsBHQnGear24eEQQRyeU7s8kc0g8yRY2UkK6rnOWCpk4OXz1ABq6i0vnnS4zaxW4W KW5kaORglw+XLeYYxk/Jnk5yx44qKlJc3NUfLGyXXy7J+fls/XGzlUUkvdUYxvp0aeq7pLe3kef+ KWlvbmFZhNAtpZNd3Vlcs1s9uOQskLrzdKwAbBzxz/FXB2MU8Ez3nlSyNOh8m5MUJi8nGSJAT8x2 8bjz3PfG7qh1zV9amsNOY6vdI262aSaERrbAYMN5cSyRpBECDsBLEjjbzWa+j3+n3lu2qtFbjywf lkeWKNsf6swW4ljZT0yXB6jFKilCV4tyh/N6W6Pdvr9z1O1aRTelkr+Xy3/A2I2t/s8Z03UdztLG bm2muIbVlmY5QQHzA3lIw27cYOMHipZbNpmm89fLmMipcyRIkouCCGIYQF2jTcAFYAEjPPJq1blD H5sptXkMYMaBBGYbYEKt0VUFowhO6NGG8rguqnitWTTY0HnvqaxTwmNldpHtmuJoh8wW4gjnM8Tk gJHJHHsGQWOc10yk56Jb2btpsktdfLy6W6GLr05SUIt83MtHFrbs7Pq+n62PPLuzeRJlhkj3CU+b DMipFEwKiHylODIGUv5qyYO5UAzmvU4Lp7G0tbaa3t75jaRkOLdPIilKqFKovymRAzbF92J464es mK6guYLrS2e5kSGaO8t4ghC8h/MOVEg+6Vk4PJyBkVq6dLEIDDbxTSFYYvMgk586FQRIqSDJjcZD Ky5IwcA54ygoxlFN6Skk32imt+j/AKv0NKj5OSUtFe6/Dt39b+mhPDKRcR6fgvHFE120iJtkgc9c qONg+7s6DOccVKD9pEheQxNKPKRYsmKFVPLXMo5UsMAZ6ducU4Hdi3aEpbMBNbPG3+kIoA3LdzAb 2hU8HIyR264lMs0DXc5tVaORFjhFqPMWUgYzJExQEjGS4YnqSKpwnGblb3HazvfVW3W+m2290crT cuZbXVn6fiR7o444jCWDhW2pGJnChupdSuGz2JGRioYNkSf6MZhITh2dW/eIyMp3bhyArHg4wcEd KnhM6zwlrtS7QN5q25l24wPukwjJ/i6evSoZHEIUmSW5jdMbRxLGDkjeQMlx945UH1GKui+SPLu7 eXl8m+nYItuDVve7abaXtrbvuyUyFUH2iGSS3kd0cxAbtp2ggMvKBR6dOTjNREW7xzRwxeWXiMdv JcFzhA67y0gBKkZXDHBIJPYU2JxGfNt5ZfJUHfFKC5WR+CzL2RuMNg9DxjNWle52TAQosipueWGQ zKVkIaPZGyIGI2NvXPy7gMnitHtdb222s+3b7n9xnGFW+u3qvw10t93Yr+WfLWW6NvKsDrbAwSsu QFTZvmYgOfmbKk/OCMj5c1PNDHbNI2875TGQybJUiibbu+QMQxK9zzkkgnmoYLrySAUgupJWaTyZ s/ZwTtAV4lU7ZRtJRs5X5hjBzT5GMk0vFqEk2s7ohCwlAB5Sclmz67QeuVOAKSjJxbkrpPuvLs/+ H2Kanu4t93ePp1a+bJGUpJ+6eJIpRKsQZism9A2G45A4GR0P4moJrkWsUoZ0kaIh5bYZLTRtwrRv klAvBJHJ6GlUskz4ltVuJFkNvIyyypD5gbJ2lAMjI67c8g0wlizKqx7o8meTYjXEakcROhYLt77w xI/unpWcmtEn8K/O34u2v+Y6bi21JNaaXjfX/g+q21ILiBl2qFkkLsWlkUssUUrAEqjA/MoBA+oP Oaez7GghWWXYEKxyZYrHJGMsWU5BIyMk5B47dHRTRtAqr5szpI0k43MsRdM5Ck4JVhjkKcds06OV pozPiFGfeI1T5lVehUK4V2cADJ24bIAJwcS4Np9rXumtla/+XqactmmtmrWTv710lpv5X+/dDfMY Mk0oModMCbbsMrjO/AA6AFccY5PrUhZZpIz5ix8GNIwm3BcdWIHzYxkE0w3EdxsSOVYLeCLaTKhj lMxOWBiZQih8FUcvs3AbioIJie6tRGQZbV7lGR9jzLGyDJZRJLgWztsIDrbzzFJRJG33QTlDldpq Wl1bmXLqrO2vm7b/AHdXdXlHW8dWkm7L5b/InU5EClDIVd0KDjzJFJ29Mnb2K9CBUgcsIlhcATGJ XQICYndlVsnqRgnAOMHBHTjCm8S+HbYJct4i0uF4iUhtxOJ557okEoqQrIxcPwqqCW6AZ6+qeHfh T8ZvGU9sPh78Gvi/4sfV5La302XQ/hl411LT7tSVY3EWq2miS6SoPZZL5AQM5rRqlNe9UjdpvfTW 19vJ69PuKjGUvhjJ7fZatd26rvocjHuWGSMxszq3Egj+dQDg7GIyvHXHXpUq/MDLFFIkhLwhpJGJ laRVWTchxlCAPnOduMjBr7q+H3/BLX/go18T7xtO8NfsofEjR0Yq39s+NLnw14a0uQEBsq93rq3I Xj5ibcEDtuGK5X9rH9gP9qv9iPRPh7rP7RHhjwloV98S9R1rR/C2n6b4ut9XmtodFhtJrkao2npP FG0gvE2zW73C/PGM7uBgqmHg0nVj5JNN7Lt5Pfp9444bEyg5qD5Vu7pJXa89PTfsj5CRolilhJRf IXY6718wTAZKpkguoXbh+ctnrtOIojbt5BTzY2ZmaN0XzLvcgBZYIwCGDZAlZh8i7SvLGnW2ieJZ Fe7gv9C023iaJFt7m2u7y7dWD+cd01vEGVZAAjZO5WDEiun8BeEbfX/HVvo2v+IdXuNLn0fWNSuL LQEi0a4uX0+NHEKTo1w7RI7OH+VCRzzyA41MJKU2qknNW+xNq6Svq0lbtq7ry3hQatzq935O21+v 5djJSK58l7mfFok/WaaRYUCRnLMzzMiSOwxuBO5D93vnNk8RaNHJ5EuvWACwukcNk5mdvlI8yQw7 xlTkluobOOa6O78J+EhILlrZtRQXMq28WoXM07W9kWIeK7YlAJZBlA6o25gTxnh2nWel2Qm/szQd IsZpt0drtsY38uM5CgSu25g3UMQCM5APOcXiKnPaMbx9Ldtr97P/AIZG8cOmlLSz20Wu3Tfb9Dhr Px3BqLT/AGTwn4hvksy0NjeQ2sjRahMo6HzgCseRw3GeCCc1swWPxl1RbZ7TwVo3h1ZI5Y7mXXtc F1LZhyDbulrYyTswYfMyBSwzsIyMD0CxuNT+3Dy4oiTbsJoFKRW67R/BGiYRjxhgSwya2F8bQXF1 Fodtcsur25Mkl9KqGCP7OpxbLvdZZt7ukRZogUzuUN0qJ1KtRxUZ+ztfmeisny2fnqndIiVPkty6 /wA1kla1t77636aJannesfCHx/q0GqDVvjdpPhWDUbCysJNI8L+E7rUdYt4XZjPcaTqV7apHFKTk tK0iyDJToBXk3jX4B+FdK0Y22rfEP4o+NtMtJo42hk1N9Gt7yMqivNqaWMhzOxVlkRs5RUPevpGG 6aGUiaaG4a6kLzxyO6NJJuZizSMA+E3bQgCghU9TXi3i7VI7YapbfPJZySyxTOv71jcK/mGGC3Lq jAJImWLjg7u+Kzq0G1dVua7Xu3a101vfSz8+vS+vTh4yqNNRvZX1slpa/pp09bJq58leJPh78LdE um/4R7wrGDFAm17qSW/dl6kSTzg7mDEncDkE+g58kv7WxFzMmm6fZ2GVbeBaxnzSvODKeVOBmIk5 RsEV7x4vDol68bNa5hhKW2AVKOoO5iWzDKOSUAYY4BwePANSAiXyow0obdJI7syNvAyMHByAeMjt 6dK5Jw9mlzu/Wyk3fZW3+Wummmh3U3FNJpXutHLtbTX9N+2rPNfGEzJot8PsyRs8ckcgyC0mEYK7 d3xnOcc4x04ryXwiVt73CeZbOsf7qQ53zE4+VnPzNGST8hG0cY9a9W1hA1peXF229cyKsTsyoF2N 8xIBJAABxjJAwSc1xclv9kvLWVC0oVYPLZIx9mDsR5qvKrFgsceWDbCXYBSB1rmqqMXFOGs/hd9e /fTr5HXGcr+7Beum+m3W9r/gdZDFH9pV54g6JgAqSjo5IYkOuGDb8kHnGe1eveH/AB7remX2g29/ f3k+k297BvLzM1wsMjFFh88nzBEAo/d8jH1JPlKsGWVk5M20x8bQcYJYcH1yOmRVxpoVhEk00ivG 6y7wm9HeADajLkFFz8rOM4IPHNaUanLKFSUnyyaUXrvorW/zOevFSi5KKttdd7bffb/Lc/Xv9mrU J2l+JmpaPG8txb6SJNIs40SGz1DUpiTBbXMxI8tUj2sx3Zct83Q4+qZvEdtqsHhfRYYrnR9Z1aGO 61GG6YC0tdYQA38NtcbvnglcSbAx2IpVFyBivjH9mTVLmy+HFheW15ZXc2uyS3EsWwK63kCBUgMo O+WNIFjOCqncxzk17Fa+Ik8SRyxFQmpWt0VuoJWMLW1yJMyQWkoy6pvPL7QSDgjAr6ulUnKFOCu+ VWeq/PZ312el/v8AlsXBe2qcqV7p2+Sv5dbn1Tptw1lM/wBoikto4rmOAWyHfFNIxEfn+aMkqT84 AyAcY4xXr2m3unLO9zJJPAkNsyuUjEq+aUOxmz91A2C2eCoOeM186eHtXu4Iha3jJPIkUE0ayOz/ AGYsVCKSEZpt5YLvYKR94AkYr13SLnfavLDMovTIhurVY5JoguRyN6IJBjO5SFU8gsATXsYeUXHk m7aKyttot7J9fnfXuzzqqjZOTs09Fr5df8u3pbiP2ltMsf7H8CfEFhe2lxoHimHw5NPDKrK2j+I7 fMd3JMGLfZ4LyyiWGFvkiknBUZNePS+HtTiaWH/hI7ae+in3TW1xC8rfZJDviZXdTtl8sqzsp5Yk 85NfQXxi0K78SfCLxdoWmBG1BtPGtQxyoJIzcaJPDqsKW8ZbAeT7O4KKR5a5ALZrzLSddm8UeHvD +u3YtbF9Y0TSJZFigjE8U0cL2M8c7DJVjd2jAEZXbJh2VlwfPqRXt6qSvFKLV7NdOu19vP5nbDkV CnK7vK6200S69v8Ah9t/PpvD+pKtzLHdwX263dxIECyiBWZXL9GUxurIqkDeqqehqlLolhHaadLc XUksV/N5cSuDGgYIFZlSMF1YOCFJAQgDJ5OfR7m0ntp7uCRodl3bruEbqZHuAikwRgEOVX7rjYAz 7yNy4Y4sWlRanp0swd0lWVLODKvDLbXSgOEhRlw0LnAYjjeSc54MuMUtVp8/L+v+HZUJTpyVSMU0 rrVrW9tbP7v+GPg7wzOZlur4iPyJ1hPkwuUJZlxIRIoLKCT0wOfQjNekWKG1k81keSF499tGxVlh B4kVXUsZGZ9rZkVCMYHB4848MQabZ3s0Wl+Y1vFEPNF0T9nkMYy0kQ+8Fc5ZCVB5x1r0nTofPRzb ArLcK1w1uj7wEg+UNH5hG1SrEkA/MBkivNunClK6cmotpPVOybT8299Nz08VrVqtbNtr5pO3yuac IEQbzImuRKvnNIGLSxoGTESIXiG4Zzt3n5FY4wM1z3ia+jsYlWxMM00Nwk1/cL55iKTKDDGjsxDP GiusqlNqMVUFskjZaVLeKJ7YpfXDSF9lw7IkLFTE5Uqp3SqHJWM/KRvOflxXO+LtV0rRdAitbm3v r6fUftEV5DYW4kuLZ2kjaOdSq/dTLkF2H7tWzirk1P3X2vq1rsna/V9rd/V4U02nZN69E30XY5i7 LLZCG3l02GLV999qekRtOmp3+lRn7kd0wheK5ZgzxQx7lK4PmEnacuCe23QPpljrEVg0YL2t66rd sxHDoJ2aQqCTk7cjsvpNqeiweJY9I1PS9Qk1jW7W0RLdYVEMNlBaL8iXUqbVDuVHykkkjHB62LdJ b+30u78Sa9p9tfx3EyvAqsk2xScQG4VAA7HKr8hzn886T96UbbcttHrv/wANp+h1WaWqtp2dvS1v wNyBXgijNvE9pK80czKlzFdy70ABeQSW0ZEEo+doTwrHaOBk6DksZnWK4m2hhdST7ZDMj/6t4Y0Q CFmGdwUHacYZhisyxuI7aImPRkWW6ZplubrUWklktSSQAoU4dV++CAwIxgV0drG8G2VJI7AXgjFt PPKssNxJIPkgQt8xZcYKlV29ua6I6PXTTrp27mMnTbVo2mne7SXy87O3X/gZ8tlrer2t3aeFNKl1 Kez0yW91MSX8EZ07Rrfa19eyGcw/JH8iqib5CzIqrjJF22jCQWsVuypAbKGSzuAXEkwmA82QsVCl YyCpyc/MMKwJNYmuPqMcF4jw2ttNcvHbyzWdzPbNOiyoWXUJI2TFkwG2SBQ6zO0e4HbkbEIM1tDF Ki4WKMwL9peMwzsQHhWMRELCqRI8QDEMshY8kVjN/C97Nv8AJ/j/AJCqNyjrfRaeb029XbZF+38t L8RJI7CNBB5sYaQTeYCzxyiRUQAsSfvYwAQRwC0yuEuIYZC01pPsQQhhneckgOoUqAecMR2xVkyz z+cYraOGGONIfJWQkvKq4M7tsGEHUncDz7mlSS4i/cbIJ1EJm2KoUyTZ5j8wYcsAPYcA9a1pzctJ RaitG2tOne1/u+ZMFpG6dr66NaX79COGSEHyWa5fy7cukqCNd5dcDDHAbsTt6DOOahmgjtghd2gd NqSyZ8xZJWIGXb5eT67R1PsKLaWK2uI55YVnjjLQNa3TGOG3jwQstu0YZpCOMBgR9OlJLtuo7ptr yIvlzAHqTuyMAgfgMVUE77Pbt5ohpw1SevftdW+T2v8AqSqt0GkaKLYsagSSOgEN0pGVjR2Cq0jf 8s1BJzwQtV1lZVHk3Hkxlx5a4G+GRs+dDIASAR+7PzHAByuecSyXc92IIrq2EttCxFvbtcvAEun2 rDdIiKfN8o48wO4XLAYHWoNJtJNR1a30Uz5ur2SdoVMCxi6mh5nYMrOXVF2qG+UcNjOa0lpG8Wm9 mlun1012f6b7i5W1e687vRX/ACfl5DzhJJGQRQyIAx2AyCZSQGPzKqeZlgVUOCcHGcU8WN7LdLbO kCgNHOHaXyJR5g3K7Iw+dRnBCGQgjAU9T6fpXg3S5EZNX1C5e3dJYHgshHGu4HG9bmWCQrIjoVA2 Z3H7wwSettPA/gFtPW5udLvZbmFmtUfU7y8v7lZSxEDMlncWAUMMFPm79Rk45r1J3Ub6aNat9NbK +nS+zJlV9lpKMmrXUteXtZO3Sx88yfuJvs5lWKF3IuGnuYDcw4OQyxxGR1jJ5DEDg/dBqx/Z2oSx XE40uaSF5wm2NmXaw+7KzlQ0kfQ8qD225r6MtdL062tZ1g8LWCSySC1+3GwjuZZD0WIQ3JkuS5zw ftDDnJJzmtQ3V+7Iklra2cLbYJMWCCMKmMSNhjwcYyQevPFVSoSk5Sk0rWWrsr+d7a2f9aXmddJR cIt82jaW1rO3bZ77HgWkeD/FuteVb2fh69vpZvNMAtkSJbeIKdrytK0SMgwTkMS3pXa6d8HNYurC a81nWra0MSx2Etla25e+sHR3Cvn5Ymdi+HO84wMFuAPf4H1CFbW7l1CMwXAFnbWunMLZI4AMRPO8 eGTzTkYBOT1I61dmsIbO1v4ruWRY7wDzQ84WSC4XLqmQGZww+ZZATuGc4Iruhhly35ouNk24tNX0 067dTB1ZQcZa7puNtbO1nbfS35nhWqfB/wANaNosuq3E2qaxqlusUFulzItvDczTskcMe+PzvLid ypmcxycIpyvO7+2P9k7/AIIj/wDBOXT/AITfDPxr4m/Zz0nxt4u8Y/DPwH4q8Qv441/V9as7fxJr /hnS9X1ptNtrKbTYIbWTU7u6li3NcfLJgxqACP4yPiJ4i02x8M6hb2Egklj0hTHPFctcMJA5WRHy qmNt6xgOMspOcqATX+j7+x1LNc/so/s03NxHJHNL8BvhNJIkkpmcSP4E0Iyb5mZjKdxzk5HZWK7c +Jncl7Kj7FuHLNc6Tab2fe629D28mk69ao50tLKzlFuOm9m1s3bVO+iXUyPhn+xF+yX8HLKTTvhn +zn8IPCNpI6SE2fgrRr+5D53Oy3OtWmpzqQc4KyKTxn0r6OsNCsdGgFpoun6ZpNoIyiW2lafZ6bD EcYBSO3txHwOAAqAD+HoK3ByAfUClr5tzb3lJ9Nb+WmvTbyPqYw5dFGCXkrduiSWy/4JRKSYYmRm GOUPzggf3f8AV7Cf90+wzxX82P8AwcX/ALM/xN+Lvwd+Dfxl+H3hjUfF2j/AvV/EknxE07SoZNT1 LTvDfiOKyih1n+zoALi4tdNvLOFtRlt0aW0hlSd42t0mli/pZKkA7epGOf8A9YGPwz7+mTc2EV1D dW93DDdWd3DcWl7ZzW8U1veW12nk3MN1DMskNzFLGQjJNE6PCZYpA6SECE4wnFy55J6OOrW6v00b 6/oKcIyg4KOj0221W99ben6H+Vhpk8k+nWxkkhuPsvmedLaMTFceY7fZ1PmKytIu2ONz5yxgIRne rgbHw3P2/wAaeH9TtC0dxDHrem6iqIsTRNljNCZPMIO9WWYMm6N4ZIzu3llX+h7/AIK9/wDBHnU/ hDe+Iv2ov2UPC1xqfwqvdRuNe+LHwh0CGSeX4eTsJLibxf4SsIyZ7/wq0zXFzrOjR7202ed5bWP7 I6xW385+neJ4fBl9YeJINIvdZiuEmjurPTfJhE0t/HGHYLMreQlvGUk2582NZFSQErgezg6kG3ZN 6WV172y/r8j5jF0J0Ksm4vl5lZpO1tOuvo/PuWdZsEie9SSASTSXN3BLGJEjhSNJXeKYS7gjttII ztYncFVjxWB9rhhkuRFG2xUhit3nyIlwQJcOgfJznbjOSBkin6n8TPDFvNcWWpfCT4iGK5kST+07 C7sNQgPmtujkFs6RtIMnqHQrjrVLwxrfw38Z3k2g+FfGq22tiRjL4X8VQHw5q9uQwDG1S+a4h1Bk /hjgliEhAUSLwa63U5al3CVratp26Lrv+Hl5qFVSS0strvRbbrTbsbEE7ROsqwSOoH2eV4XYkPJw rkuEBTnluDnscVaWy0XSr2S8j09jLNJDLPeMrXl5LGyPJNHAo8mNH3xJsYtgDdk8GtDU/DfiGBxa IXt4ooWW+knjWNY2XiKQ7WIKuSCjrvU9d2KV7J7GeS6S+IhhtFR7dwr28hWCXzCkz4CMM5+Yg8jb nkVzVJurO0bLXp1va1ra7Lov0KcoJq7Vn8W2m2rey36mbcSW9naebrVtNDE7Pc2Yx5tyYZJGeNJX Qgea27GOgGF3HGT5p4htLG6sdQ1RrSbT4Et3ltxIr+Z57cCQoFKm6ZQgZCwURiNhJliB7v4S8A+M fizaaho3gDwZ4w8YC6dIbS40jTJZra2mhEbvEdVn8myjUOSWZrhQAw2k7Sa7nUP2KPi3aW8k3xE8 bfCn4Y2c1six6b448eW1rqME7hIUWezszeqZjhF2CRjvOMYAJTo1W1F80W7PVNbWu9Ur/pv1YVsX Qo0k6a9r70U1TtOSvZN2gm+X+Z20vdq5+UHiyZbh5JJCw3CON26lmWFSskinGxmyQV6AdCea8R1u SKRoAd0ZTz4gFAJlbaQC3IGB1PUjJOOcV9fftS/ALx1+zl45/wCES8XXGl6lHrem2HiLT9W0e6+1 WGpaXfQo1vNYy7hvgdNsiNhCVblRjFfGl8Ak7uUdrZZm2sxy6swwMck7d2NxAxjNZ14OK5d3otHd 3uvx9F69Dei6VSmqsFPmt2d77We1ndbdrdWzjNZa3S023SxhF3DfgvtbBKu6AfMFOMgEkjIGc8Wf DvhibxUkVpp+m3CXFhYqss8Gx4bmNZRJDdOocmJXICSGQKVUkc5qnrcq21m8lxB5oa7Ro4Xba00I ZSyq3zFdykjdj5c5xxivXP2bWjuvivD4fvDJFaa9o99abon8u3SKztZNQIdMsbpkit5GyChYIQOo FTShGtiacZOySTvta3Lq9t1+Onmdk5+zpKezfK7W12TtrrZddF6dDynV9H1XQNWudJ1ON7e6svIP kNDjMdyrSJMg5Jg2owLYHbA5zVUxptLRSYaVngYMoMOx1GWCnkENnHHI5HWvpj9rrQYtN+J/hvWN Lid7DxJ4HsUt7lJ1W2uZrGaa3meLjIeJDF5gcAoJFXk180BImaLC4ZWG7DbkARFiyWO3IJUnOCQc +horUnSxDpcrUaa502rK/wA9NNL67WtqjOm+eD16dfTa73au2fWHwZ8bT2XhnTfCalft1vqBGiNZ sy3F0z4MyBTtTeqkF/n+4V6jAr6v8LeIbaXXtQluYnEmmxPcai8as4E+wmeVyMbgJdylguc4z6j8 1fCupXOlyQXyLPBPZ3ksljcQrl4sxos0kTdAxj+UcqQOevX688J6xqTaUs1hey20uqxKRcbYpZL2 xkk/0iCcEnc0rFgWxuXORgCvTweOfJTune3VWd+iatq9vlZb2Z5eJw9nN23aezae1teq79Ez9APB +sJdSPeXUnkO9kssuWUtHA4Bt1ODIomkJUJGCevzFcHH0JoF/I62iQs1rMyxsjnZumgZgCZyRhfl OSMnockdvgHwX4iglFrZ2/mWmpxWxi1i0n8xoWKEeRc25kUFy6AqoB2qzAggAGvp/Qda8+F2truZ mtbdECSH94WAyV2k58vjBAOcZAxxXvUKzdqji43srtW6X3st7/etrbeFWptu0otLTdba7X2f/DaH 0leGcxDTHeMT6nb3lqJWljEdst3GbfzlYNlnMUspVSoUtt+bqR8zfCDS5NL8EyeGdRkae48J+N/G ngy2v7pS897oUz2mu263AIAEiz6nMLS4BJREZVGFyfUrHXJ7p4Lu+t7dV2IUQqxYtCDhVCyZHmEc AgY+tedWN+P+FlfGKwmuVhiiu/B/ieSxi4FlDe6Y1k88SgbV842yJIRli8R3DvUYhX5Zxa95u/XR W02/X7rihU92MPiUdmtVrb1Sva611f3mpGmnXGoSabJeQyS/ZHbTNQIZJoblV2L5rbjmOEgQmXYS xUOV+Y1nRLdQ6ObC4uHXV7K+DXAUrLcAEmSN9uEXcWwQMn92Q2c5UZ2rX0Vm97dLbI+oW82yONMI Z9MIBZIASoNzMNsgGRknJOTWLFfubyylQzySXiu/2iQnfJsBJExJDF06DgLtwASeKSqe6oWbtror 22v82+vZ26XN+VtXVn5dfuPiPw7cwve3EsEccs8qkMxOFLbgGTaONsXIyBg+oFenI0bTrGXjEkUU TP5RwIztY+VlTghxknGRlcHBNeZ6BBoGmkLour/aViguLX+0podxljkYkRwu43EgEJtzwTgY4rtb eWeRIZ9PeG2VYGhWOWxVJbxFdfOlNyEBt+cKAHXcG3D7tefTVP2cJNauMW9t2l1svLrdLyPSqy5q tRO9+Z3T6dHa2n6nQJPJEJIYI43jlkEwEYJkWRQyiKPPOXDMeOOATXPeIZooUtRcW97bSXFwkb2t kCbm7V2ClbmQhvKQg72Ybc4K85NaDTyxJcRzm5spz5QtGs7VZ5BIx4m+1lC5jA3bl3EFip7U3xAm uCwWDTdQsrs3nlpd3eqTeXchlCy7YICQJJcptVNp6k4JFVyxnrFXWiTv6Pvf+uxlTXLV5XU5LJPl bXW3VaXelndrSxY1G00q2tbew0i5ijlacJJFo6CGdJCgfbeW+CsuWOJGbAPJNea3dprMt7LLLbxW jyTKy2WptaeTezocvcaeRENqk5IPCkYHY10Vnpd7rVjK7wy6ctvNuuLSI/Z77V7xcgB5jtKQtgYB ONrDAx00I7a3ubYw+INHtdOvreJFik8/7bqMcSD93FBbbnV4icKCEIPvQqdpwdrWv89v6v8AebXU ZP33Uva77WX599fx0K9lKk9292+nxmVSLfyLeMRJBcy8PdTSphWVmY8qAp7YrXWG0u4J4ZbKInTr lYt0M7yqLhzlZ7Vy3MjdSucIRgAZqiqX9mTPPNbQwzgeXayAWNw8ZPyhrePywzlcAqVIyCMY4q+L qa6tGihjeFIpC6vEotppp442KR4G3coJIVuSw5znNaTvK0N9Lr0X4WT7vqhTjZxkrW5437a6aeu/ 5aaGLra2d3aeUssssUMsRmS53Ldfao5oigLLj5CC3U4PfNb9xJdFll2yMsccbuUUCOBEjRQnA5Zs nnn7p5rn7xtQksJppIY0g+zQtNDuBn8xZG3GZh95hnIznqfY1vku8dssU7sJYrMtCSdgjVZN6jnG c4x6jOPSoVPb3barXe22u/8AWvdirJtJLduy3fVdF6f1sahkElsqWkzH7SAJQy888sM9R0HTB449 RUjNuzGYb7Z4sK0jEkOfu4AJI56A/XPtJv8ALOUG1N3lpGOCHxjOAOh5OB9O9VjskWMSLHNGWJKM ed2cjPfaD157g5qr83uO2m63emmi1s7ff+BhepK1PWy2W/Rbq2yt31HtFELhCZYod6M/k4JuScHO 3qCT2x3x3qKRA24J5qOywysZRhyhYH94BwGxyRgYHeh3CxHeiRjcWP2Q7XtnXGI4QOfLJzkjjrmo DPLi52o0cky5lk6tIpPMe7oW4A4J65FZwnUuuyf36pq3fZdLdLmi0X7y9vxtstev6lkeR50007SP J5MkMcMcxREgZQ/mrECAXVoxtIyWyTjINa/gO505fEupSKgvPEPhfT7aWOCXFuttaamswt5SykCZ 7jZJv3gsnkjHU1zAt5f3ELtFeQloLiGB8Jc2rKkqFwxxkZkBQdOPwq18L10+Pxd8U8PbNNa/2K11 I4Bk2xw3AW3nHV5pWnJtxjnY4HXndK1pS3nZ/elbb83/AJmVSPLQnKOzndPrZd/TTurtvuz6H05n mtJIoyHvHdpJg8u6KIOBKwVT1b5vlPpnB61s6ZNM87WtuI5Yr22k8zaP3iTRDAaPPR1IyB3xxXNa JbanrOr6Zomg6Xfa54i1GZLHTdJ023kN9rM7BZbfTo4VXctwkRcxuwwApzya9h1z4MfHnwrpF34j 1j4Q+MNO0q2kmuLnUobSKdLO0jC7xfxW6mZHtmDK8rfdwckDo6a9nOpJdYK9+t9Ff06WtbXe5zuT rKNBfEoRb+avt52+9HLhHtLqwvZbq4QW1k8k0+AY4rkFgm9QNpYDAHGc85qpZamkaC4dJ7hbhXjh gnH30O4FgccYB3ZyMZxxXF3WpLLM8cby28a/61ZbllWafgNFLEWBVgc7hjPGKuw6qt1CliSYorWM hZIMpv8Ap0656flg1a5fYx5tedu1knsleyVu617Cp0qlKThUva115bXW/TS6tp9x2tnd6bpMCtdZ hjaBnjIuHmaJJN3ksIWYhWVicoBkcccmuJ1TX765jml1DUpZrCzjeG1trS2WLU76cnzFRyBkR+Uo WNiAc7iM4xXPS6hd+fBbwbJr0mSG2Fyf9FsbeUqIbm6B4a88vzCSeeB6VlWENzc6sI49JvNc8W6z ewadYWmn2093q3ibWJJkttM0jQrOMO13qF1I/wDoUNmjXEKxyyPiEPW1CE1TcdoaTb/up7W/yfbq kjKvJKevXliumr29f66nqP7Mnwy1z9pX9pL4CfBS20ldK8J/E/4r6HoniErdNN4gl8MWrte6/axI 5IimuorEx5VRi3lujjKgj/Tz8KeHtD8IeHNA8I+GrKDTfDvhTRdL8M6Dp1uG8nT9H0Oyg03TLGIs STHa2NrbwJklj5ZLEmv5nv8Agjx/wR+8afBzxl4c/bH/AGsLGDR/ijYabLJ8Jvg7BKszfDePWohH P4p8cSQMbOXxjPaMIraztQsmmrPdLcL9raYD+ne2XYAhLELv2hzukyZHZnY5JKFiVi7BRx3x8tnW Ko4ivGNBq0Pj5dm21fS2ysrN6NN2emn1+R4Sth6EpV952cPJWTVr33v722y6vW5RRRXkHuhSEAgj Awev/wBelooAzbmzimSSGaGO4t5opYbi3niinguYbhHjmieKVHjw0e+ORWUxzJMY5VkXAX+FH/gu 5+w/8IP2ev2jvAus/BiZ/CNl8cNC8Q+M9U+HKgxeH9L8QQ6jcQXt14ZTIWwt9SnjaefTQWitJneO zWGxFvbQ/wB3Uq7wykgKVG4HvySMHt0P+Ffxt/8ABy7Nv/aC/ZfhWSMSwfCnxDdmJxl1WbxNrFvE 0S9Q7m3IV8ZUrmt8NU5K0et3a3R6rf521Wpw5hCEsLVcrXVm3a9vhtb1v523sfzC3fhu8NzbLqq6 tpE2mKqyMXYWl3yRHE8uPkSUjAdT8mc561B458MeEfG2kxvq+mf2jqcQW20PV9NzBqugSJ8onttS hMcl0sLDzBHKX3FQMtzXveka1c3KW9tqCx6lBDbMG03VT5rqAnymWQkh9uAYADkMBgdRWH448PWe n2PhbX9NilibUdNmubmGzfZFaXlleiJoyoI6Ip4x2weev001CpGMHZPkT63tpbR63t+W+yPl4VlL lUbWSS08nZ21fXpd/ovJPg78Vde0PxXp/wABvjXfRzNq+22+G/xLuMBdReciO10XX3+VTHEWCNIS GO3GRwK+yvhj4M+H958S7zRPi7qVhaafoul3l94c8P63qE2g+D/HvjC3It9P0LXtat3hn0/w88c8 t1LqCSozLEse/DV+evxp0G28YfDZNSSC6s9a8F6ja3VleQvmbbdSZW629R9guTDMzEELsyc4NfTW h+N7b4wfCD4beMbi7DatNHH4d8XyIYp5UuNBmtob+SytL7ejXF1ZOCo2Hc/Y5rOlRpxm1GbjPTkS oqs2/L95Dktt1v0tYuorcsdL1E7d3a3+a37n3F4sn+KWu2I0f4lftq/AL4A/DZA1lB8Jv2c1a5sL O3jSPybNX8Pmy1nUruO3KA3WsajfS3U7SSvIUZETzXT3/Zg8G3qv4T8HeK/2gfElpOjWnxE+MJMH hnS7xLeIS6jaeGIjB/abqyxzwnW/7RiO8AxlkZinwr+GP7JvxD+Jnhb4V6NqPx5XXfE9tq19peua zbaLoukS3Wjaa+pTafYNZ20Es8krRT2tlFcMyySvxnOK9L8MfD/4J6RaXGsfEzwd49+Gnh6HVZ7S 1uPHvjO4bxxqy2VzPAraX4F0a7W+mW68vNtP9jNv5bqZjsXFds+ZxUa05Tq2fu/VlS91W5vf9rN3 1WnL03vdGHNUoN028RyOEnacsN7NPTW0H7a+uj813Pxo/a/8ea58RviBHqWv35uXtoW0+LyzBDZ2 sCSvHbJYWVvHFBZWMcQjiht4Y0hQIAqA818b3tsYkaN0Mt1bT7Y5Qco0dx+7YsvQlQQQex+ma/Qb /goHY/DcePvDOs/C3wP4k8CeF20iSKO18Z3b3WoeKwLqUv4hRHJW2SYHdHBEqRocKV8wMR+el7Os 9wPLkudskQ3NuK7iybpxOD/yzifdgHqVwK8SvC1To/eu/vi9PTzfyPTwMk8PzLX3k3Z/4Xa/e99b eepwXiWNRZyJIQ08TZRcnnIyAOxycDI/I9a6P4Z66fB/xK8EeKFge8l0fW7SAWAODd/2rBLYNA3I 3KRcFWzkY4JBqvf6eLmxlukgXUZrWCMRO4xbqnmoSI4yPlkABAYDhsH1rEjtpINT0nUSsxNpruhu 8xY5sftOoWsQEZyfuk4xz71xxXs6nO0r3SXW700fS1v+G6HZV9+nrdtLTbW9t7v7/wDg3Pqf9qfx HpfiSLw1Ha2H2M6FfatGkhLB0g1GbTpVtwc52xzpcoFHAAOMACvldWZpFRvs/lxB1Pnghcb2IMfQ nIIPfnNfeH7VHwsbw38NrPxnFdGWV/EWiQRXzrut5LXVbBpJFVMcSloSGbqWBNfDDpbhwwWWHbGS TdHzY5pVOAY152ggAqMcdBxWuK9q8UufZxV9/wCVbael9PVbGNCyox20krb9ZJfh/TsdNo/ky2d1 btLcSRSYZI4h+7Xs5U/eB2rxzk4HvXtvhLUPtvh+70fTGFsY1FtY3EQY3cOf9aUmY5gCrubcMbj8 nQ4rwrQ0lNzbPFNJ5s0cpnQHbCkeCMFOx4yBgHHNeteEZyIGj5aS0MkyBMooiDYlkB/ieNAXjHXe OB0p0OX92o2veL203X/A2sPF/Cvl+SPsHT/HOvatZeHotQ0/TWl8M6VFo9nqenWkdpd3scG0vc6p MoH26V1Qruk3Mu4txjNevaB4kkvJLeS5aKIMYyEsG23DuGBAZSRubPGMHJ4NfMmmRzWGmRXP2lJ4 Ly0OpWNkhy4ixma8uiMlLmSMlGRjuZWIwc11VxeSWpt9VEiSCFI5ra6UFRBLJG2yAJjh3faivxgk HPevpeWTpQdSpyvlWnVrSzfp8vXU8CtTVRuLV2vLa3r8u3Zpn3Lonim0itxBbpJJqEhPF0MXCMc8 DgDrzwOMnPtxt9fW2l/F74vqLgrc3vw68E3bgkH50m1EsCD0CsSOeB7Dr5N4T+KZnj06PWY7OKZU eOK7LD7QhJHWUk88dSe+cniuF1HxXYy/GTx1cW+oSXV/eeC9Fsri8nfzLOaNZrsRwInI3osqrkcF gSDyazqWhCn+853zNW7O0dXouvrrfszGjQ5JyTdnZX37+p7VrXiFNQ1jT283dFKImnYg7GkSJFUJ t/hKhc54JzWdfeJTp+qzXFnBc3cpja3KysDDbiMedOYAOFS3g23bHjcWxz0rza31XVre23h1T7Ir 217IjYNtZoSqmVMkyKVUMoGdqkLgYrkv7Y1eMXnlzRpY6hEwjuY4RI0sbyGKSXdgvEojAUoSMkbg MGpvOceWDfM7aa66q7VtDqWGs+fV26Jd9P8AgvXX1PONIss6mG8XzPFFp+YdM0DTrM21u8u7EFzd SKqpKGGHTJJQfLwK9ze8jhuZIfI+w2w06JTKW3RmVh8rRsBtBXo/OSSM8ivCtPm1qfUJbrVb/wDt OGJHXEMXkwfaosh/LVws00UTY+bYFk+8hIIr0zQZr6bStSZ1ivjZrHOPPVoo2Wd1jSPMoXYI3ZMo pYMO4yK5qNWhyRUk00kt3ZOyvbfrq7fhqlvVg1LR6uV21s3+G51guIhAs832i9vopI/s4RmXzotj kxNKD8iYUEsflyqjknFU9XuUlsLO/trNJplu0eCW/QtHaXin7qxHLFolLFZguHYKucOauNJcebcB 7Mqq2tvC8Fkofa8gDSEDIOxW8rkYI5HejUoNTvILLyrZ47DSyn9oXbuts/mNyka5zkAEBkALMe47 dU3D2cXTuo3d9072V79fu226EThS9onNNytHVX1Ss1rprbf8WY/iO/vJrCKC9uNRure6nS5unhtp IbrU0IC+UoRQdLjiAISWLBcDJ7GmWVnqUQcaXZWmr2sUCvBd3V2j67YWxyFtbiaYiW4gjUj91kgA Ywa0NQg/tW9img8Vy2E1ra+QIvIWS2s1AJygOAJDyC5Zi3YelO90rWItOtUZLDVY4yk95qNnK8Wo pBN/y0aFCGMaAn5SuAB9cZXe99e5ThSduW8e9+vw269LenXpcj1WKe3fTbm7hto5ngmaK+QK0Nww PyxSQKcW8qgBTIVAHJFLazxyfuplub4eZNdeWIfIgspEGN0Ex2+ezZ+baWyOmQac1jcwWLWdxBdT 6VBcSjTdZghErTozkpaXVu0u8AA43MEK85zjFS2wgfy3vpDb28HmyMJZgZUMBAjhiiUHyhNkbF3M cZBzjNChFXc5S5eVpNNrV2a1T/HT5W0lpRVlJtXWmumm+re39a3Rn6kt7/Zd6dDe2e8dI2eS93Mj wy3ESTh0kGN9uCPKbtvJro7aWKOO3kkdAbVbZ5Bkok+EKMIscYVhuRemXY9TWVKZ3iv0hEmppNbG S1DhVSKOT53ieTKZYGNEU4OHdSelXoEla2sUuYorViYrmRQVdLVVjcG2kkQuxkOwHYVXczhuMCpj Gn71SnKo5QScU3Kzas0rN20Vt0180S7tWu/W7bW3mXzMss8kqQgQ7TdRh52DMwABWMtgA4zzwOpF QxoF3SCyVmJJFnMNsjjnLRSnAOcDAzzn0PMZu5ZopLjdE9s8y20cTbpDOXJxFHFsXa8Srlm3AHK+ +XLHLsMklyHiknCQCckGDGDgNweOnJxxjtmmpylZuPLomrdNvJMnkd78zv36/mJDboXdm8yNnUtH I7bJYkAOYljbBwBxtxyfzqFWARioKWkyqqozgSQyRj/j4t485hExHIwMgnjnh8vnSXTOSLqZlFws ifO32XrtUj5d/q2M57emfc3UUkkg2J9sYlHDZVo7aH5olC9Fm+X964yX5yBmr5I6e95Lfy89On4+ Za1lFPb/ACcenl0JB5k0rzOEupbdvNVQ5RxaNFICWAGDLHMISG6/N0xxXvP7LXg/wrbeJv2hPjD4 48IN4q8JfC2TwXK/hqxnBi8SeLbqx1O40o+LCp8w+H7ZVY305VlU+Qj4DDPgf72YRm3uIoWmVZ5U jnCyeWjqrAjaSUl3bmH8TKp4Iwff/wBjbVvHnh74i/tA33hn4u/DP4b2lq3hBdTs/ilaX2p+HvFl rdWmo7LaTTbOxvBfmBYZI7ppBEyrNbCNW5xlNSulzScbrq9FZd9bdeyaJxlOKo4l8ziv9lsl0viK SbXVOSTTfVNrqej/AAn+MWg6Z+0f4B+Mfje58LeFNCtvFreItX0/QvstvpekWMum3dtFZ6dplqxu LqC0EkKWsNtBJcamwkbYwhJX134Fab8XH+K/iv486V418V+Bv2fdB8Ua14l13xp41a60Pwp4y0S4 v7u7j8LaL4d1o2154in1m3nS3g0/TLO7hsyV88xHIHcaX4/1PXdZs7Hw34p/YjXxDey7F1Pwd8A/ iX4t1y3mWR0BsrWz8L3EZkZo43hDRi3gdd0k0YbB0PiN8HfGHiyOLxP+0D+2b4cmaxAfw94V1rR7 uxvdKU8SzWfhHTbTbYwlQFjsdRtortUARkVlNa1ZyjFQ11S1e9tH11Xp0v0ZjCFFVlOM0pK0eVVO SzSVrLkk/vloui3fx14kfSvGvj/xf4r0LR5tG8Nax4kutQ0ewmVIk0+1ub2QxibYd4MSMGeDblYh sIAFZ2p6cuj6HrOp3txb2semeY32WQDz33ts0wRdw91ctCkoAyyMcg9K7qbS9O0+W7j0jVYNSj0u aR7TWYkNvJ4htpciXVhaEsiyMCSYrkwOR1UZrybxvrOlXLeFPD1xeJPqurXmo+JZ1mRmlNnpavb2 sd1bZAW2W9aCdY2JBVMZA5q6aUYw1bUpaJ9L22XnfX1K9rzzfNqkrL3/AGj6a35IL89+lzm7e2uJ ZtMiQq2o6vqek6Vp0t7PmLUdR8RXsGl29xcEk3Ei6JNexSLZ2iSzSKWjWMliK/vT/wCCb3/BIz9n 79jzRfDvxR1+JPi/+0Rquk2eqyfE7xXYRSxeFhqunW88+lfDrQrpWPh62gSaSCW9EMGp3yuDciMI sdfxIfBnw1p2sfGj4EeHrqzS4S7+Nvwkt2Ej+Y1zG/j3QCsO/BBjlJAdQo3KApPFf6fVjax2trb2 6qESGGCKJFI2xrBbwwqkf91QE2hfQc1x57WnTVKlCcoKUdeWTjzJKnbaztZ6rZrdbHoZFh4ValWt UjGdmuXnSlbrpfRO6Vnrbox4tkfqGTBDKCckBs9Qfun7/HQbzxnNSxRJEQqqFCpsXA6IGyqj0UEn A7ZqYADpx7f1/HvS18t1b6vd9X6s+uVkklololt20/BaeQUUUUAFMc4VjnbjueB/+o0Mx25UjPGT 2HrXjvxt+Ofwy/Z4+GHjH4xfGXxfpXgf4ceCNLbVNf8AEmrNIsVrFtcR29rbRJLc6nqNzIqwWGn2 ENxdXVxKiJFsDuoTKSjb+lp3/wCGZ1/ijxn4d8E+H9c8Y+NvEGj+FfB/hnTbrWPEHiXXr200vQtI 0uwj828vtU1S/lgtNPt7SM7/ADpZUEu4qpLqoP8Anm/8FnP+CnXwU/bJ/ax8I+K/hBouvav8F/hZ 4LuvhhpvxXnxb6X4w1aPxDrWrajr+iWpIuYPD7DU4rDTJNQit7q+NnJqcET6fe2c8vhH/BW7/gsx 8b/+Cj/iLUvhz4Rv9S+FX7HGja9P/YHw80qd7DXPibHayolp4j+KV5C4muobmKGK+0jwzFts9Giu pWu5Lu7upYrT8fppfJ0aSxBS40OSERR6erA2K7U2xxwqFVQYCTLhRlGc8kMAu8KTi4VO9n99l5fg tPxflYuuqqnRVrJ+9fZ2aW/Xt31t5L7W0bx54Zv7dbvRdWhkCmX/AEWYLJfKsfzLMHY5CtnIbnAP evSfFl0kfg7wTPerLFFc/wBrOk0Gy4a9Se4dmd1ViTKjNvTcMhwMYr8vJpW8MPZ3NvI5trvTo5Hm imLmKbJAgmC4+WQAIFwCCK/QHwHLZa3+z18OvE+r/aFZNQ8TwrJuZyzQapNBCqI7YVNgA2kgFsHI r6DCS9u407XlTXO315bWSve9rLX7z56tQWHXMr2bTsnqr2v/AJaP7zitdiuLXwT8QL2GzF1awaXq E00l6fs7LaTOoCKR0U7hlR36cjNZ37Hms3XiH4BavZW7QCKy+J+rWWn3UjWrXMDy2aXV9PDGZMEQ xW6R2rEg+cyfxCsz4v6zL4S+FF8BfS/aPFci6bDbCF3mmsm3XIuWhYLGkdyYFgUGVhDv3EnGD6L+ yD4ai8LfALwRYC3Lf8Jrr/ifxh9nl2ieW2je1hspUY7USF2FyrwrK5n24BXFKnOf1+U46JpRVtLO L7aferX21aV9KlWjGlSnV5m5J8jV7pxUW72s+sV3dmfqV8Mfh18X7rSbfUP2ffhHpvwC8OwaQi63 +0h8Z7mPVviL4gjuEK6nqHgzS7kyS6Ja3Ennx2DaZkOUDsfnauh8M/BHxBFqOpah4C8Fab8WfH9s Fkf40/tCeLdMn0qa5YAXWoReE7e+vUC2QxJbNrMVqotxECQRXmlt40/Zs0+30tviN4v+PHxf8YRr bJ4f+H2hWuor4btdaMaI+lWOl2Uj3OrppkAiYxrAkdx5ohG0w+Y3f+JPB3in4kWsUT/Bj4waZ4Na zd7Pwt4s+J/gn4I6W1sQhDweHbzxFceJblL4uUIurSFogrZXOVHfGcqk6nO20tpOWt1Zr/Ky9V3O B+3qScuSHsuWT5uVc7tZ7pN2Wj31e9z8pP8AgpvqPxAXxN4E8P8AxK+KvgP4u6rp+kXcdnrPw7ks 5NB8LqLyZX8OxLany7eOyUBEgiJtUxmOQsSK/Ka8llimu5HuBM8kIUPE2JN2chmI6hXGWxxjnpxX 63/8FDvglpHhnwt4avbT4bWHwAufBelBR4Ol8Wjxvc/EL+0b6U/2ppPiS2j+x34jVw0scEsssT7m kVV5r8i79EU7F8uADcFGXaV1BKIkjFQFaVfmAySysO5zXkYuKUrqT02tfT4dPm9H6ff7OBm5YSEO VJ3SurJ9OvZrXXW99SpqOrX8Gi6jqDRywRTSRaZbT27FIW8y4ihICgfeKk7sA9T0Gaoy3SCzs7VD M895qWjB3lYtGZE1C1aNyDnLRNyhPIIyPWqPiCW5t7DTrAs00U99HN5ayfuYHeeNi0kJHzMCuUyR zxzVm1gkuNY8L2KyF/t3ifQbRD5W5VH9p2wnyOOSCCvXZtNcW7Xqt9e3ff0PTdo0ldJ6W2t/nvb0 t6a/qt+11dMP2Z47aW4Ek1rq/g0tGDlYSNLlAeBf4WJmBbGTyT1Jr8s8yDy0G9ZBGkplJG4MAMjP +119yTnmv0h/bM1WKz+GGheGrCazvIJdZ0db+5+Yu8ttZAkeYBwsREalQrc5GeSa/NqSQsxYsNjS MC6tlGkJwvlqQCsY6FOmQT3p1m3X1bfud27fD3OHBQlHDJybd6ml3feV92/O3b8lqWNw0dzCXb9/ fl4gVwNgVRjcc9X5BHp7GvbdFtpbey05m8zMkbSiNFysLHK5ZQCQGx3PJOc+nhMQ8y8sULr5wu0R VVMMZHCBCnX5SCAV78k19k6R4Ylt0WS6LoXtYGK5KgIY1baFKnOZCeR2wvrTwlGVRJpuySe9ldNf 5b90kViOVt3l2T300jp189Vba1tLq/4bnl8u/SUyeW1tCfLjUiJ/3ikFlPy5GNwzjGCD2rsLx7u5 hlQpcyxy28ccsjhWBQAKCxz0jUnB7DOO1ZC6RcXhP2W7WHM0drDbyQeXFNaFfmeSTcMyIwDq54JU LjnjpIrYrbx29ohkiMv2WaSfcFMkbDzNkhYgqQMAY5z75r2KUny8k5N2enM73VlZXe/oecoxcrxe i0v10d7fc77s4WfZcGLToFVmhO2O3VDFHKDxhpSADvzySTnjnIJqj4IsZpPiTrLtapd3kGnwRXPk kJGkEKKYoZFz+9EB4BOcsCw55Pq39l28FnLNdbVuFb9zF9lzGyg/KDOGGzgY3cdKreA9L8jxL4l1 GS3jiluNPik85ZgzCEfIQABx0G05I696U4y0fM7Rd9/Tz8uhrFxanom1bor66PWz8tPy3OleCaSe BLdJoV1UyW8l15AmQw7y07GLJKlJd6ZIG4qW71Un0/So3aGBZZWjcwLdgC3cgAI8bICCY3OWJwRk ntWzeQSF0t45JxLIuYLqzBciP73lzsDiBj90tt+YDcOWolhh2RmODF6NpmQoZAyKu3IOR+8Yglm6 8njOa1cZS5ZxbVmtm0946aO/ZdbdDnSck48zWid0+zXz/H1ueC6HewDX5IX1FPE3ivXGzoGj2qtD BZ2zShNv2kKIp1iUnZGbZGUAK8jn5q9y1fwz490ltF0/WNMCyeJrr7Np9hDLHDLK1qhMnnoibYYY 5DHIXklGfLCgclhb8YeC/CF14x+DOteEtF1Hw/cXOg6HYRQQxsi3fiJLVZNQW3nRCZy0ykXxUkW8 5MRDAZr7P1iHXF1bS7zVPCFrqFqiQx6jYMWbU7HdbyQIy7HLwi7Z1Z5ImG0Asy5wDeHw8pUU1q4O zlZbKzs+j209fJEYzFXrUowXKmk7PXeyT1W6tpt2e58p3PgPXrDw/rt/4z1WHwjrmiXtlpmnm1dr u31aOZo2yLiFRAsuWgURtK29yFLrXeaL8GY9b0z+x/EHiybTtZ1ONbq3EsgtrnSpWiVrO/v7dma1 eOePzDHE1ypK4YZxiupttPgtItStbi4Fv4WvdSukh0XxDOl3bi8M0FxCqyzJJcCaOSLEWJVK4Vf4 +OS1u1vtHs/EF1rOpNJF4qMemakkcw1K50udttvouoWzQ+XdWtraxFhNEGZY1Kghw2R6Co04RjKs lOEkvdvJWbtd3TWrv5LcxniK/wBma5lK2sYvRNd1p113eu55d8ePhxrvwp8F6RrF/r+r3+mWutWd nquqaLptpc6XqNrd7JLef+1YmLxiNTsuU+zlY3ypkY1yYiu9Tn0/WvDF9LaXeoWyRNBLPAss1myB t5sZniCxxqcbleRiM/ISRX2h4R8QappOjn4e+MtJ0/xZ4Gk0m00qVFQX1tfugJmeKOd45rXUbkus xOGMalWDHpXzb8Ufgno/hbVNV8f/AAsubrWbKxWCfxF4Q1Npr+fw/ZIoW4bQ72CeEN9mUM08JiKo i5JOMHgrUqtGbkkpwqu9OF/gS5U1zLV7p66ee50U6yrpQnrOKd7e7e9ndJenXbvrZcBLqEmhx/bh NJqN1HKsGqQx3hWwkkbAeQRmMhJHYk71Xk8gDFWLRre4SXUbaG3lhnllR7EyNK1veZBR7mYhfKjC 7nj2xSCXbtxHmobDWtJ1PTmtre9WS0n3SG7fT7dEhZPmtVaVlJnK4Ad2CsTnIqTTZknikuy5vxCB aT3NlaLa20EqBmLzJHtS8C7QgcqhVWOc9aE5yjyuPKtNb6rayd07b376PsFRwp8qW90ndt6Pv223 6LohupSz2OnrLFf2a+eFYRzkwIsZfc0mVZiAXjQpGcbghGRvyLsE9qLeGeGQzC4aKWVoYyVnvPum UK7ttj4XcoJzs6/McM1LyBoUs+oWkFxZtLFdGN4hj5t4SKF9wYxZUs6cBCwAJzkSWSC8soLxLeGG A7RBaxSeU8ShGAIUKdyjguSRjI+lOmpJpKSs9/hd07eXn/V0VJLk91pSaTT+JJ92m7NdDSmM4a5k O37NF+8R12Rs1zKB5skcAUhXbCqMOdgy3OcFIwgGyaKQMyC5lhcGYW5ycYfKb93DH5VIz3NVXS4t xDCYjJCoMtwTIZArE/Kc4+6McnHBI4qVFdQ3mNMivLuMz8hrcD7hbGfUAY57exb32pW/q1ldW6fL 7wpxk0uZprppG+yT6WS0t2VtNwuQ0L2pgniXEcp8yHALRR5AhK5OOn3yTjstNEhSB3MFvczgEbyn zyGX5Sjtk/MoPLfxY6AcU8wRyQJPaw7p2SYMu/8Acqsm4gqx5JA6jA6bSTxVMqJx5Ea3cUxYNHHB Dv8ANMPzSSSMXQJG2Dtck7uyilGmm1re7WnM/K99dbX266a6kpOnJSm+ZK3o1p2W99xn2cuU+zta xXMUZW7zDl1hLq0UUQ8xTIThgw42YB5r0P8AZkuPh1a+OvjLefFP4WeMPi34etNd8PWWn6Z4avX0 uCbVnsppbTT7z7Ppms3l1NO6kW0ECRDbHP5j8rjza6jiUR3iiVUBD5QZuPtJOHQIG+dTt+YFsIOm a+r/ANgGw+OOveOP2idD+Bd9o2jm71Pw/P4n1PxDc6JbWeg2w02VP7UgvNbtLmS0vY/McwSacFu0 /eBJFJVqVOUXieSSbjH06Wt1e1/P7zDFy58PUk/hnKPN2XJKM4xc7csbSinZp9rn3jaa1O3h62u7 D9nfwx+zp4RSJVvdQ8a/EBfB94LICV98lnpfh/VvFNxMsbhWijFhJMf4l6r5daeP/gfrl/N4f+Cn 7NVx+0R8R5ljhk8TSf2+ngmyUSyxXV1JeareXBvrOCRJHe71HVNGmZACYo/umz47+BGs6VONW1Hw l8Rf2k/GxntYpNS1TxFb6J8OrmczssgF1da9eavqMaFXAuElsPNQfJHGpArq/wBo3wH+0bf614Z8 G/A/wTe+HfhPL4C8Pt4i8K/DrVvDvhbTLDxdeWiT69p99qtvfJ4h1eFLp5E/0vWnW4ABKpnFVN81 /wB3zJStG99lbtdK13b56amVKEJcs+WUZyUdeaVumqSdmrdVZbq2h8ReKNV1K08RarY6pY6bpOqx 6rcx3ui6bKjaTo99b7vL03S54HmjePKiOSGSaQDn96wHPnPiO/S9+Juk6Vd6XZ2X9l/CDSjHqaMl zfaxDqt/ZvPqZc+R9l3IWhMSiYZk3mbK7W29c0HUvC2o33hHX7D+yNb0W+KarpzTfbJTPKQbi7e7 M9y0t3CSTI/nvyCdxFeHePfER0v4wfCPUNRaxgs/FngfWvhwru8kSLeaawl0NLhixSITeQjRyFmY 9kzzWtuSMJuldJrVyfdd2rfKyvdp6HQ6clu27q61WjVttb636n27+yto9/r37V/7LOk28bJdQftC fBy8jsWcyte6bp3jvQ7jUMPEHQfZ7SN5zG580qpMiIPmH+mqJPnZSeRI2MbmwNxKjO0LnOcqCdpG DX+Vx4V8Y+JvAPifwn8RPBWq3Xh3xn4J8Qab4h8M65abGu9H1zRJ1ezvza3KTWbtEwKlrmC4gvYJ HW6gkfy5I/7Uf+Ccv/Baz4cftIL4X+Dfx/1XQ/APx1uootJ0rxLHNHa+APiHqqQx+dbRSTyKdC8S zKpuJ9Pmc2M0rs1pcwgrbnys9pVqs6VZU2qcYcqtsr2dvklq/wDI9LIsZRpKrQqLlm5JqT0vbpLt v33bvrv+/kchcsCpXbwd3DE85+XGNoGMMCQSSOCDUgJycjA9c9fwqlbSKsa7nU7yFiYFTvjI3K4I LZRiWZWDMpQowPzVYjkDscEkZcDII5VirdfRlZfqDjjmvmmpJ76aO1ltps+t9T6hOM7SXy3VmvJk 1FFFMohOMMFIJIYYJwRtBBPQ5Gfp+Nfw0/8ABx9+0XqH7Sfxns/2SfAfiq6sfDv7OMJ17xDo8E9z bad40+Lmp2okh0TW4kmW3vrTw/o/mLDBMjrFcavJcAJJEm7+5XDBwxOVAI5PUu6gY9RjPpycHrX+ bJ+39qr3n/BQn9sHU8owb48eJ123AyZ3TTNItWRJeTbvNGpxKNxiEalVO840w0VXlbs7eWjXX57d V87edmNaVGjBxdm5JN2T6x07b2/4bR/hLeW8qGexv7STTtb0y58rUtLn3xyW1ydvnyzMVKz2oI2W zogDwxop5VmOgLhY7MW5Nt5cc++C2wIvNYoPMdIwZCokGACSd208A19rfEj4R6f8RYba/wBOkTSv Ftlvj07C4l1l1R5YbK9lwFuY4zvhW4m2Z3x5DFjj5x8NfBPW/F/h7xR4l1Oax+Htr4G1m20TxVN4 gu/KvbjUL6SRfs2i2Plu92zRQiZTCVWFJ4nBIk49X2VT93BUlKMbKLS0ez8vx8tzynWVubdyV27W u+9vv322PNvDuj6l4o1iDw34e08Xs16xt7g3GfsmlmRiRdX05R0t4LbPmF13kgcKCePt3Q9M0jwv 8PfC/wAM311/Elz4Z1DUp7mXToHSyvtR1e+a6gsbGAu0l2sM8qwXUkRGyFXn25Hl1xfhiy0vT9LG jeC9Pl0vRYV3apr14vkajqaKxW4vJpZSWNllWIUyLiPqCeK9g+Gd54RvbqbxHe67p/h7Q/CcNxD4 l8bz28V486s7QPpHw50dGjGueJNbUtYxXCFV0+ecTHf5eD6+CoRo1oOKVOpKKVVXbvT00Sd+7tJa 76nmYurWqpKEOana/b3vzsnp3vtuWvH/AMJW8U+ALXXr+/trq1v7uT4e+GtMa1OzWPEt26rr2p6Q 6sZPsHhSzW5W5cjyhNtxcIRXW6pa2uhWVnp3he2ig8O/D/w5p2k2emA/PFLaWtwXkswjK8az3pae WQST9OUOM10Hir4hya+dKvrXQE8NR6PbSaP8PvDdtIJrXwn4TuY2i+06pbmImTxJ4jLLNqt2zRTO 7kFxiuCsbK6+Q3jtAkbtE8ckv72aOUP5nmkBhICGOxW5Awu7gVpXpQp4pSw9owb1teSbbV9ZN39O /wCCoqrUjCNSPJGL91PXdra6v+Wye+h9b+LPE/jH9lf4TeBdU+FugPf/ABP+L3hw+JtV/aMXw7P4 sk8EaJeOYrjwR4QEdtJpuhazCkckn9qyxXd5PJd7BHCIAW4P9oD4aDw/4r+FK2Gv+M9fufil8NfC 3i+9134m+JNXutStfE/iW4vodVvr+a4a3OmacggSVraGzMdsgVo1LSELzHg347fFn4YaTL4f8I/E C5sfC4kkuV8M6pBpWu6LG8TMPNtrXWLG++ws6yL+6t2RA6lxyWrx7x18V/HfjvV213xtrtz4n1mI G3tb24iVhbWBDSRafaWkBjgt7KFZgIo4oxEzGRFjXYSylJxqXk702nzK9m27Jaq1tVrra3bqToVv bKNGbhFqSeiellfR3311STSt2OX/AOCiGoeHtC+GPwW+CHg/xnP8RIfhlqOuah4j8Zu73tmNf1qJ XuNI8L6hcySXs+i2Suqw3FwfKZ1YRwRkGvyWv5GSGO3MjgRnfE08aSmZootiGacbCSgUMoC4LAZP evtf4pXbXEMsEyRvHG8KSq0SbhvjR2FtEGCRxpIx3LsDg5LSOCFHyPrmnRWslywPnxXMh8hgQ5hz kANGo+QOflBBI5+leJinzVVbbmV++60t5Xu/lZ6Hp4aEqFJRveTt02bsrv7tUtvU8r1iZEktUm2S M95AplVym59+5HClWACkD5NxHqeK9C+FOjnxD8WPBWlpK0tnbasNZvyUAjt7bTIJpWlLFsYuLprd dxI8s7SC4OK8/wDEUnmx2jR28YRdQTzJXAj2BSASwPzKQCSDt6DOe1fR3wB8MGO31vxlO89rcXdy 3h/RBs2pcWuwzXUok3Fo1LQxhG2/OM8r0rnpXdVqWsNrabppu7/Tfa9tTrrSfsUne+mm2llo/O+n pc6r9pvXjfP4c0tbyd4S2panJbjaFcSSrbwOx25/d+SwRud+7Py4wflNzb74yZHKqoBXaT+9Awfu kDIYHOB179q9S+LWvJ4w8Z3j2t1DHBoVrDpEMaMPLkW1HmSfNjO8z79w5wckmvMQjiZf3WFJyoUB o8n5juY7cfMTkY6nr6ub5pOT1e1/LTa3ey1Q6cVGnGCVo6O2+ujvd67+i8rHZeBtOfVfHvgbTjGr tea7bmNnwvnRxEPIjIeAMY5Zjnpgd/0rvrS0a4+0GFDFExeSHZtcQElFRFGd5SQEbcDI56ECvgf4 LiK++I/hLTbizzKdUN7BqKPiazNvErNDHGo5jfAJcsAWZlwcE1+hENzaxTyMxCSSyF3klUyGI43K iIcDYRhix6Pxg8E+rgI+zo1JukpJfC7tO2lrK9m76rrv8/Kx7d2oOzur6vy76Lfpva/a+GtjEodP sj3INuYbEkLCFlnkG2WVAHaMRqR1JGPmPA21NDYWVvHZ6YhZHtVea+dh9oggu3BKNA2Y/P5IBBKg e45rRu182dZIrtC0oA3RSbhIjkIYzHtAVnBKDBJUnI5ArStNJSXdb+Z9n8lWISc7AZCp2QrMQxka VjsBYDBYDPOa6IOM48zpuEm9Fd/e9Ve/ockHJU7Rdnd3210X3dexjvYzLvzOPskylXjli8xLgY5Z PmzBuHTBfGc+lZuh2iWus6zPb2qwQSwWtssUkzSMVBxIUXy1BVmBIU4wOM121uSttMkEiO8A2+WY /OCSAY8qPJAkcHgqDgn1qjZLIb+WZIooVazCXEch3S+eHZi4Uj932OOShyuPl5mU94q1ur7/AIbX /FJo0jJxjvq/i06aNLtv27E+1I5ZfOd7YmTyYoo1WIOTjZJKdzlgq4wmBlQPmyRVYp5U0y+cGmiX /j7RMRfN824oSQrr0Ee87vv7huwNOWG3Mkj8ShEWSUtKzybyuQYU2fPjPOGGOnaiOFWiRQIzG1ws zLJmN2JQKqyLhjt24JOTjkdatSlGn7rtovxtcd4paXUtE39z76X/AK6Hzr8SPF/j7wj8XvCumnxT dnSvAOpa5B4Z02UR2lvpc+rTyPd+W5Qm5m3uTHK7MQcbSMcetQ+OPHfhq6bUrXxTqz3d6UDPf3Ta jMgmDXbHYQ37qV4lSEkfJuwvBwOG/aS0W/1H4k+NTZCF57O9iuBJtAMClQzMv+03JOMZJycVy+k6 hq7W8NyupNbn7JHB9qeQELIkDjG1vvHOVDYwM4zU5fiajpzi4xSm763b2WltPxWm3VGmPoSqzpVo RprRNJXXKny977bWvfrc+j9I+L3hK5j0TT/HvhzX7ttN1CbxBdHTnEdzq2oN/wAe8U0cySILRirP JGu05CbSORS6j8TfDE/iDUfFWkWGpaVBfW/2K6sUsYZUjeW4hkhnRXjYFrWKEpKygbd+elePy2+p 6ymmC8a0a6S2jQtNIokv4DuYzSKDlYQVX5x/GUUHJq/b6fbziRki+zw25ENzNITvzGfmAQ/KbYgY D9yRyM13U67b9+zWyXTa17d1q+3zZxwwrhVc6lT4oxfLdOOy/wCGtptsj1zw7438OwfEa68Tam+u Xul6jtjZZIZXWxuorXyze2lgm2Ix3MDw+XIFyZELD0rlbzxTcWd9Jo9lqmp6Z4cv7fUNLt7xITBf Xs+p3twZP7Z3g4R7KSMAvgDqMZrOjmbZdxwW8aHba/Z7ll+X5FLuc44DRGIZHbNQ3MLXmnqJEjke SIqJWAFrDct88b78/KQhGPYYNZTlzttTklG1krNa2vvp02WmuvWzVHlquULyV0+jXfor3v52+Wi8 304S2F3qWk3tvI3h+Ke7+wtp8Xn3l1FbSEC5XaP3kPGWdRjHOK7nSNQvF0yeyjNomlX8ZktJyixT ZVlGy6GBsfYTu3DJG49cGuc1eITHStQt9UntbPS/tsVvZ2EQeW4mkkZftAIB8yxcnMRJKlCCK6LS IriWO4SVbKaHKtNtO2ONuDuByMTSHBlXI2k4OKmClNWnN2Wqdl0aVvmn+Ol7FzhGrPWTjJK+m267 669r3W9yl4inmGkRN5b3McFxHa4gG+28rIxMGAwY85yxBwfxraAnEFmsflRyJbqLeOEgidJFDMEw ACw2jI9QeaoalNHKHtrVQ10ITE1ncmZII48qBLb+XgPgDLswJ6YwM5v+YTHZxzzWyy2qRoIo2mxI hjcuJzJlUhUhCxGCCVGRyKj34TjKPvNNOzVr6fJ9766fek3HWKurJq79NgR5W85nmeJpIxFIrAfI xbClg3Y44ODzSBrhJRGt2ZwFJaJ1BAGPTHcZwO3fNDSyGCSYRWwldIESaV8Tryx2IvG62bBw+M5P J7UitM0sTxWsdpLKpDRucm5AHLLnOARkjBx05waOZN3qe63ul30va/lqKUXd2k32tp27fP8Aq97p FtcQ2s1is7yOpxFkpGcdyRjg5JwTwMnGerBbajJFJJueL7PMsctogAilhY7SguRlgcE8BuO/NM05 IJFhAnu0WSJh5JUC2Tgj7/QAZwef1poEkaEW7MsMLx2hcMWjllRsF0PdT2Pfuc0UlCo1yTqK7teo kraLayi3vo+ut3vanrvr66lG6ikWXdCCdlykVssBMwtwhXcJB0JJJyx6n3Feq/BA6dPd/GVbWSa5 mn8V6DHcSP8AaNPS1mj0uRhMkls8HnOCjhIpfMjY5Ow4GfOZIpGkkimuI4izglgCP3URRrlwB/Eg 2DPbORzX0n+w5q3gvVYfjnJ47Oh+CvEEHiCzsvhz4j8ZaHqHiDwVPdJAJDqmuafp0cjyXVvHCTp7 zAwqJLgyda2VP2VRTg1UntJRhOd2rfy6vTTfXyuY1Z8lKWl7S0b3irfZkveimtEk9HbXVnb6J8H/ AIyfEW5CeD/BnjHVtLaaYXGrahqVzoWipbxw28j3keq3s0VnLGWcAtFCHg+YIy5bMupfsu+PtDgn Hjf40/A7wVCrSzLaar8Z7i8u4xeSGWG3vbHTb+Au8O7Y7HlSv3hjFeneMtC03xiGl+M37dmla9aQ ho9N0fwRoPinV7eG3SIAWGk6NbmXS9MIjO2GJYEjAT98uSteTwQfsX+CY47/AEHwH8Sf2hPEdpbo lnL8QJj4J8CSuWbMuo2WmfYtf1PyZP8AWWEpks5U+WSMrkUexjUnadWvTk3zKMabppXtry1I8zv3 u07LbUcq75IONKCvGN3rdt2u731b7vVtK55t48+F/iX4Zw6V4n1HWfDfi/R/F93qR0Tx34V16TxP 4c12XT5JLfVrfT7t5HkMkUscsDxsSUdSuSQK8M+JfgmX4mfD3xD4TEMVvr6i28UeCNaXCX2k+INI dZreGJs70hnVDayIu3c8oTq1e6ePvH/iP4l6hZS67Z6L4W0fQ0aDwv4I8D6bbaL4K8FW/nNIYdHt NPjgilOozEm91LYbuR5HeWUtyfORcXVkitOtvJLPebrIRt/pbpjzzJGMk+WPLyVIwQTmtfYwVOpT dau5aezXKvefVvSy2WyvZ73E6yjKlKV3pJOLvZX5fy9eifkeKfBX44WnjfTB4P8AFsA0D4xeD2k0 vxXoOs/6Bb+IUjxbx3OliYKZ5nKpIFRmySSMggn1bV9N0+5incXlzpuoW1zDHIbZJbK8jliZZYhD LbNFKXgLACYu2SySqQ0QYeYfHn4GW3xxn0DxFYa/F4Q+IPhfSRpukeINOhFvbX1tajzLU6jHAE8v UWfCSajLz0Jfjn5tPjf9rb4Riz0zxn4Gm+IVmrxW2n6kumya/Jfxo7qsr6rZRTXzHYqkJ522IMCo XJzi8eqdNUcZSbUU1F2d2k0k3q9V10t6bDqYWFZc9Co4VHODkr6W93m1sm73f4Lpc/to/wCCKv8A wVp+J8nxL+Gn7EH7RWuXPxD8N+Lba88P/CL4t6xdm+8c6V4jtohead4G8WXytHDqGhXNjFLb6Lqc 8DapBLafZbq+nh+yxx/2B27O2CTuOXEmTwGQ7cop5wCDExGAxTeRlyT/AI8fwj/bj8QfDT43fBnx 9P8AC24sdU+Gnxe8D+L57VNQ1WC/e0tdZtbPV7OztpJBPb7bS9a4mVlUNHb7T8oNf6/ngvxNp/jb wr4V8a6M5k0fxf4Z0PxNpj5b59P8Qada6xYyYPy/PbXsRZhz0AOBivm8yjRk6dWipJVNZRasotNe W7em/TfW59Hk8q3JUp1HBqGzu3KWnV66q610Uubq0dZRRRXmntEPAK7RkABcEf7Sk9e6gFvqK/zS /wBu9JdP/b1/a30K8fzNTb48eLb1oPLHm+UtrpMhZFI4VVmiySRjcoOc1/pZuwAJXBKhyvqZEHKn 3I59ePYiv42/+C6n/BL/AMceFPH3jX9u74IQ3niLwX4x1Gz1z46+FLW2e/17wrrbRxWM/iy2YCR5 /B+rRQWFvqeloClpqkdrNsRZgW1oPll/LdK9nbp/n8l9x52Z0PrGH3knB3XLbXS2t79F01T1Wx/P D5h+zmYXD+XPjzopAsM5SOXES2kxAAl81WAEyyxHBEaKck+DfHTxHrPw/TSfE6+AtY8d6R4nuntv theaDRNE8cRxxw2dvqskP+mTXN1p0NoIktpIUOxmUANge5vcLe2OnuY0v7kxTPamKTLBVWKSTzEB /dfZUZMQEAxZIKgmvTfCWuWWmaZqOp30jTappsVtqHhZpfNayg1iMOiX0tkP9EvJArGIG7jcRFQ0 WGd8+7Tk6kKajUacVpZK/Sy82kumm/ofNRmqdSnTldtrVO+iSW33/hfyPzXh8G/tL/HqyF82gDwb 4SuHlmstSvbmTwf4ShsYP3c1qt/cN9s1+QTpKfs8rv5hyu7DCvpv4f8Aw58IfDnTNKTR9bb4neIN OBt7TUta002PhfwxcPGZb5/BWhnbCJba43kaxcrcPK6l1IJFetXWpal4iuYLvW7zVNSeG3nULfSF 7eB5pXxDZhiRYose23khtgiSvGwcEYFcdfTR6XGmlxWMkVukzsl1FwsVxckhElIwTGHYF+cbc812 U4zpRlXc5TqOPJytJJJWs1bW75novn1ZvJ8ydnyapcsUrOyTvqnZu9r9dNNGXoLK8iN1qEc99Nql 9cQTXZaQKr20UoaVdTt2Bw6AE26psBABGKnm0wu4Rb26gnabzhHETPDLGVyf3hzt6gYyMYIIyMjY 0y6U2625tzcTBA00lthiU7ZOTkHpnnNY9/f2yRy/Zy7spIksk5UDn5tRc8xYwSAcE4GayhKUlBNv WUrvRbtJbWsrdPK5C5muWUm0rWasvXo30Wl/+DjXdtbrZXw4kkmkiXc0LSCEO7JKVfOCAFUsRgDc BXGataQ29udl428yRSK1ovkXDpDkLHHMx27XBwFK5JB65rrIdTa23ZaK6hniLhRyAclcDOeFI2g9 8A+tc1PGLoPPqXli1GXt7VTtlEhJ2yZ4zFjC4zt3KxA7VVWnJNJyk42vzWT1VrK22+7t+etwbg00 /K7tonv/AEz5l8b2k0s14zROqlpAj3Du925n+cPM4OxkQkopA4ccZ6V80a5bfY3ilVriIhxG7Byu 1ojuWVd24FSQCRjnJ6Z4+zPHVqUmlkbaWeJSohIIMY5UEDjI7npn0zXyj4xWULaMC8QnnuEJICja QwYk4A3bTjrknAGTXm14qClf3tOu+qXX5+Wx6NPlkott336bK2vbv8jxa+m8OPrVtd+MNcn0PQ4S zNqVtZ/b55b8I0ltFc2yqVEbsuX+TmPcfevUbP4w6dp+g/2N4Fv5tdghSdLzVHsDYQwm6UoDp8bB VN4inIABIPc97nwr+H13431zV7y9sIR4Q0XT7qC81a8037VDa6psaWO+dzGw2WkKSSuxPyqhzgVz PivwPq2g6m1hLBYvYNIx07WrKzCWt4JP+PeQqq7TjO/AzjnpnniU3GpTgl7sl8V7PZa9tb+u99Vr o1Tk9ZPW2l010Tt2XyfmcprWlzaRdLaXcqG8mdb4vG4LzRXUKS75SCQX3ORJk5D7uDiolwwiHmIW lUYVZOBgbT7A4HPOM1uxWkNjf6dfX1hDrX2K4+36po15Gy2OqvGvlxQT3H/LJBjzFUFQeOM0Nbf2 hey3senx2yy3TyR2FmuLbT452MsdvFxzHArhAe+3J61XPHs3t2+f/A/EV5/yr71/merfs82U0nxI N9BHI66LotzcmVfmWOSQuibiem4jA45x619x2rpcTglpp5ZHlUwGADKqhI2YAyT6Z+6AelfNf7O+ htYaj4t1SZpHDafHp8O2P5UkyZvKY46kShuvQjOa+oIZFgjkuRHCs6eXa7UALxtKAiyH0JYgZHOe M4xXo0faeyjacrTs2tLRS6L5J/1ZHk4lT9rN767au2i7Xt+PQvI67HVYEhaJI9qSrtkMqyqVI4JG xgGOMgAE9DV1JZLqN9yLNI6kzRltpZ+iOh4ICHBJBBAG4dKqxzyxF4w8AS2RYLqaUAgT5DDt1JXa CeOR3OalFw5VpofIlIBBZBwMAc8dgOv0r0G04xi3a0VfZPT19EcsE4u777fO62+4lspLiFkRXEUV rL56ThNzxTjnd1zcYbqDuyBnBzSrK66pFczsn/E2Yq27CklnYGbb/AZG+YKcYLEY4qtApjRGlZJV 80Tx7W/1shOfKPPIOcYPToaS2tNPbVJHnuJRKIo5rbT0JewjkeVnYGXJxIC2GHGCCOKzUFd2k2uu qdu1vXVsvq33+75G9Ms8FzPAiwxCJNsbsAd2fnYFud3LY6egX3ijkd5m8394+1CFiQFWKqM447dC MjFOmuZGujIRFAkLMPLlyWv+R8qeyEbFxkkLzxxRG4mkcx20cRmkCrFn97G4ALBec7SnPHBJ61uo was27aLz0t9+3l8jKS5LSTbd7Wf97S781r95518dtOk1Px74vnS/m0y9jvDa2d6gz54YESQzBT8o Byiswzg7hxiuQ0Wxii0e2tmkDkIY7hmU/vGQgSSJx905+b6j1r0T4oPd3njrxl5kcUUM9/KsKxsu ZZgSIpWHI3AY2sCDjtXO2MP2dLGN7iKFVtLiN4Qu/dLuEjPIR91iFIIONw5rPDwvCLjFrRO7W+3V d10+R1VtIxjKUm1ZaPT7K/pjY7O0SBfsk1ys6r5Vrvz5W5uW68jIU9McHHFaS28my1j+z7IxIrSp Ef3jXIBJkGTwuDkggA96dax+e8ESuMRhp8jAXYwIX5cccjI7Z4HBq0DImQ8cRbY7ZfdslAOAHOed vJB4+YDrW94u0Wmp31enltr1tZP8zKCbTjf3k78zXTTS+789rX06DvKVWEpLR7Z9uJPm4wvpnoMc fX2qreS3ItHhW6kktnfBtAV+YHIxkfljggVYhZ1t2dEDxbmaYXXMocjA8kE5x6d84PXmqlykKQRm NykzSArJnEMTg/6mbOcSn0/vDiicWoxUU9dX52t28u/WxUnJNRitrczXnttbpf7/AL8yaLUpFitr DUv7F062UM1rborSX1yFG+2uDjIAb5S3IzyOuauQIjoZIJXt545o/tcMYIt5X7BQ2MsCQWIyCe5r QvNL1WO2gvPIshdzIGQzSrv2N0KoOQQB3UEeuesE7yiGG4vJSzQyLGwQBmDrwybIwDtU9CwJPXJp 00tIO8W2vekmo326LqS4pJSTXM3qvK6387L8V6mbqH2iW1uVdbYoskZmmGA4Qyx7Y8+pGen09K0Z oDNKodLW5SNFMH70RSQRrGoIJyCTyMA8n8Kz9RVjpJuTAUjlvBIB5gctBEw3uyjlNjOhUPjOcjIB Bmhs0LSXSkSSusUoDuczRNgFnJO07QFUYAOD6805L3pxS5nBJ8yV18uunX9eruuVrq9n223699ky 3Mkcu+1jdA4FtIA84ZUO1zjbnkZHP5YqOPKRlbiaMo0BUKoyQy8DGCTx3x6dMcVOYWP79isW+R1m fCyGKCMKFIQYLhAW2qDnk896rPcSxQ7bPSbiWUcQXzxr9geyJy91JGWyJQQxB68Yx1rFxcmm073W tmu3+RUeVbtO6/lfk+q73Xf5FpWScRRpKdsXNwzDblx0XJHU8+/sRTpJXlMdtcOA1uoazEand5C/ cWQgYLdiT6nkmmJEfJcsRJCW2yFcZZj/AMteAMsDznsccU/CJJLApuZnitoiLneu7BH3XPGM5xjI 56ZreqozvzLov4Vk9Ld7Lp+OrepLi42vbUrBw6FVgSK4Mnnsl0Q0Vzb2k8Jni4zgy5HfnH4V6x8C 9RtJdL+LDW0y3L3PjLTmeJwFtdLjNhsigtMjBY4nMwGSuyMN1FeNh3t2LRXUK3C3kD4dGnnFrI/z 29uo4CTyiJJ15LKeoIr0P4M2k2jad4+h1Ke1NpeeL31GxWz8uEM1xZwKwdFkdvNiYbSsmAoPyrya KLcXCk51GnFcqnXqNJe7o4bLfaLtfSzRx4inL2b1SU2nr0ulZS66Oz9fNnpmrvZWJktrZ7F4g2Un iTMglnyZlOF4QFRuOQAcc9zxsrjiN43VM8ywH5WXnj2B4B9DzXTX1tDbeXIRKEeXdJFbspuJYpVb zBj5iVchd4GOg5FYN3abId0Kom4RSxRs/wC5WNmIZJx180rweeoHHFWnKjXsowltfe2tu6fm0/n3 KpWtGMne0Ur7JPtvpszIzAfkDkbpPIiEoPNuc7icA7iOx5HqamO0wyx28sEyIQfNUbXbsQu7B+mO uMdKWS9sbfTY7KO1Vb2K/DWOpOD9o8piBJbTuSR9kPZducd81EPs7KokjJYKWWRB8pbqCdpB647e g6dd5zqSlCo3Si4t8ujt9nmT93fb710IjD2s5X2VrXV7rr5/8H5kkMqwq4O37Qds0duAQ7tGwEBm PTcctnJwe/etiHXdQ0aZTpt/cwzLcPewNEqyPBK0aLPGd4ZTGCwC46c4Hry73ULxs8zq0pZY5TvX dLJHkIw5B4z8vQDniqKzeRLGFMivK0iQxz5YOWKmTcf+eZIQgDOCDjNOcqVWP76MZz5be5997NLR PW3n3NnSml7jSa1drrTd/j/m+qNrxHraahoGsXepWFi5aGVZdROmx3GpRksr31wjLETHKltLJLGd wLSRrjla/wBO39kUWB/Za/ZobSrq6vNKH7PfwYGlXN6oS6vdO/4Vz4b+x6hOhO9J7m28szK6hg+f fP8AmDX0UM2lX2n3s0ZiuYX3bPlVJ3aKPD4xuIBCqM8gHPWv9Qb9lK2Wz/Zh/Zws1AC2vwE+D1vH sAC7IPh14biAwMALlTtUDAHTHSvms6XJTw/JGKi5dL7e5fXa+un9J+zkVKalWqTcldLRu6b6/d+O h9AUUUV4J9KN3Bg2PQ8Hr0rB1fT7DVrDUtM1TT7bVtOvrK4sb/Tr2GK5tdQ0++jaC+sbm3nDRS2s kDHzoXRvtEYdVV8YrfwPQflTXRWUrgHODjpyDkUCaTVmk12Z/EX/AMFaf+CTHiD9mHXPE37R37OX hLVfEP7P+sXk2r+MvDmjbzqfwoub64knlOn6VF/pL+FjJM0sGoQxPa6ejSWmoS26ramT8LBrP2vS YdQcT3tlZGNY5NOX5CkgEqrM4xtcOzbrcbow4a4iLR3Cs3+pdrel2OtaZqOj6tp9jquk6nYz2Oq6 VqdulxY6jp93G8FxazxSLJFNHJEzxtA6bJBJhmXOR/GB/wAFYf8Agkbq37M+p+Jf2if2aPD2q+IP 2d9cun1Hx/8ADLRrCa/1f4Wa1PNJdTa1pUFr5s974Emmune7htonfRJI7iOUGBIpG7MNivY1Ic6k 7vSz02Vt7de3lZHk4rLI1aiq0uWLitYu923bZpO7abev4n4AWWum8cs9vcQbbkySPLgtHFH8wGMk ZbsD3xjJFadyZbfS03W/27fJIbW5Cjz1ETNKICOoZtu0Fv6Vx9jcSXE7HSGsvKnuLhE1GGf7XYai yruEkCP5Sxxwk7YQryTRTK3nRJgiulTXLWz09hqOtaVaanErFlur603STyEp50cMkqSeawbCiGOV 8nCRuSAfopVKVSmrVEk4q6b+/br08u/V+M6NelzuUXJc7SSvrpFXW62812tdWIdOuI4EW7E4icRS CWGBG2xnJOLkEAscdcAgj1qs93azxzXlldcuGWSJFKsc9cZAJ9B6ZAA4rX0Xw/8AEPxZrNvp/wAN vh98Q/iDe3MYYxeEfh74p1UOW6iLULLSp7Z1bJwR154719afC3/gl5/wUc+Maw3/AIT/AGUvG2l6 RJlEufHlzo3gWdi74a6uR4h1HT79Iot24otgzuuAqkkCvPc1B3jVgrd+ZN7LV2ejd93r3OiGHnUi mk4/4lu3bRWvsfBzq0VrGFeW1SVmaU7su6F2+9kkgnpjGcEDFNvprGO1V0hV7eIrsE0fmSFj/wAt bY8/vicqBnjAJ64H74+AP+DbX9t3xfexXfxD+L3wT+G2k3cNu15ZWL+JPFWuWZfPm2y2w0O00hp4 1wGNvq00DHDCUMWUffPw1/4Ni/hDp+i3Vr8YP2mPiL401WSeCTRp/CXhyx8H2+iW9u5e/t4m/tbU GvZb1G8qGadIGtljDxxysWUKWPpNKMpczTTutE1G39bp/fpbwVZq0d9GtGuq6uysvy+5fxX+Lre/ Rrme6tbyC1uY41g+0IGMy7+QNhbDkHJUkEAgkenzTr/g7XvFGo2Xh/QbQtc3928Su42f2favzd3E hbG0LAWZQSM4AGTX9V//AAWM/wCCQ+jfsIeHfA3xp/Z0t/FniP4A6xNp3hn4lQ+LNRn8U694A8WT yj+yPFEtw9taxvpGu+ZFbTzOYY4L5JI7jyITFK/4EWqPK1xcQJFb3N60SPdmJVuRtwksd3cAgCRj ult4IgwtyViLuFLVFWccXD3E4pJ8yet7NXsl3Vmu+j82qkalCPLOOrSt2V2ndtX0StexZ8C6Jovg DR9F0vwrelF0eOUy6k0RLaxc3yta6hdahGVO6Od5ns3RwQYJXZQRmuW8W+C4NS2tZadcSyFriTyr m3/0Zru4Jw9oP4I9x+UcADA9K7uOR0ypw8csTQHzlUzNLCMoSBj5XZRnpnOfQ1bmedozPFLIFiiH mx+XkHYBkAb+2PlI9OvWmqNOfs3Zpx35ra6LVW9NNV+hzXl/Ov8Ayby8vX003PlK6+F9xf3Fwlrc CCRYdtzp6IQgKnEjByMZ3Z5B4OK2bL4M6ZayWzTpqBkzBIjpOVUlQRt27hgbgw564zzmvpGGVZkk CRNLPIoExQpDFAp5G2c8EkEFlyTv9TVWe4uoQ6SGZikQeNmIeFBkoscoC5yuC4Ayfmz0NavDxjJR tFt9u+mm3fT5+lr5qn/PyP3vy6Pvr6aHJ+HdMg0TSvJS0ktnl1KUbpJfM85BhPNLAkDlcAZByvHW u0S5i3pFKG8uZTGJVk2RxvGm/dKScMpwAOeG5HGKxbSNyrWss8lyY3MhCw5giMmJPMj3MrbgXKkj PQfSr8kzJEtt5UaM7bY1MW15QR9/duOGI4LEYxwCSOOyhFU04yV7K2lmtdettddbaGM1Uk37yvfd X6Wtrr0vp6fLXLBzHI84P7pVc20wZJBGQ0e5CcsxKgZxnqTginWkgkSSX92k7qJIYrjhmu2IhK4x /wA8nY+2OagdQBDBMD5kKL5auFcyjOSu5ANu0Zbr2xyTUDCSSd5prWR5IszW0gkVNrqhAZRxjdyv IyFJ4oqX5kkr3V/d6K/Z2dtVtcy5JJNyab8vl5Lz/rbckuHjEoKQwToYvMVBksRnJUAdz6DucdaW xt3nu7idIWiimeMTupHG1Fwc5JXceeR6dKr+ZLi2uJoYo2k2F5AwkuRtO7Jx3ByRkc8dq0tHiY+e H+SO4eRwIOBIxYkSSdcORy2DjcTwMVUISSb27Xvb10Xd6rffR9M5RcrWtpff5Fgo7y+bK21VZjFM PmfEWYwWUDIxtwreij8Y0MZ87aqtJd3CDzmB3KFUL5ob+EdsjAJ49BU/2eUSLFCz5Kurt5g2yku2 C+fQDb0Gcc1ZExtrfyVFuqiPy7sBQ7ljISGDAHHykDjHPTipjFu8m01Z3T3vdK9yJQdr3WjT+5pn mPiRE1DXtauv30Yk1q4+xzOxkeUW8pjIYALlc9DxnqKaEEUkUcsEcFvuZllVxNNOZI3ilaXABj2b sRIQTg5JbGKtTFp7WOSRxHc/bJl+VNhSVpD5gKsW3qDkBwVDjkegni065XZOYEQS58yaUlUfy/lL qCxBI3HCrjJJ5z01ozlGnT5VdRhFO3ayt59Om6u+1+qu02mmt03dpfyt/ck38iC2UH7VJtVYlhW2 hmU4YqpZ1Zl53MQWJI25wowMczwB3jhmJWSOPcgR42dp+dzLhWDAjGQcN0PHHGi9rZabJbXV03mz s6vBbQvlJSVKgyJtbYRknaSSRznAqISIZmjAkUXEhlllt4mKQIQcxQkEeVKeBvzwpbK9BWrnRm+d S99WTioye1l8SVnb8d/TOEoxk7u10vNX+W23UrXkqxwCYtEwVTNMhMsjtCASqQRpEuyUMoB3FyBg EU3R7aS9BudQhNtb38C3NnA6FrZperSXUu4BLkH7sWAd3qavafYJie4u5LbyLUl7aySd4ryROSUM ssoSXB5fag+UtwetYl9qRnvrTTr1bqNDcPdKlhcBtNWEtlJZgkLsX4G3DouCDs5rP2sm7NW/lv5J X0W3o9b9XYfOrzkknCyu3pa11s1d3v8A0yxc2FjPem5gu57o2UqiRbkyQ+USfmJDMVlQZ42hQAOK iu7e6UTX1msKoblIfNlceWxEbuZBatlii7dhk8zDuwIA7vBmzfzC8tNRt/PWFMNtuGVW+e2MO1WU wAbWuWyr4LCNc4qrOyyutzM6vEWEAVFLLLbRggRKgkXY8D7SZiCJgCNqk5om5SUWlZRnFtq2y3Wv nZ9dkJJSh7SLbS93RPd62a3W29v+Blao4trMwpPbKL1YJbouxLp50u3yoULAGViuPLXHysCD8vOi f3glMa7U8pLaVEfcLZI0V4gkoAV5Jss0mFHklQDu35rJ1ZIUtWQ2kL3kk8I824faEVmLC4t15MMq Iu1C5lVQW+XJyNSKNoFSCORDkMyLAheINIqqQ8pkHzttDSSNlSQNqqM50p1bTqOOt42T7vTv811u LV3sm3bs/wDInSJitqVQ5RZJI/nIEshGNs2fvoe6jac9D3FlkK2UnnTvaMXwtsgkeJkPWJUV+ISe qg5yfvDtnSWzJMEM0kkltA0pijG2EknOGm3FVwDkkIfu471NHJLwVk+2SMpkVIXC7IhnLYdX3heR 2zjJ6VXtJvePle620/y/rS0Jzb5barfTbbt+ProWbdZMvIuFEWUcONkL9ckLknPHHzHHHqaasFwz TEtthzumVAVeTGSIkkJIYDgE7Dn3xU1pC8robiYQ2kcZLxXCfM7gZ3FlYAEEZwQcn3qEzu7yrBIZ I0cNCqqTGScYIGQWXngEk8damTUPhUpfKX3a3+Vrq2uhrFXV5Ky6+Xy1dn/WxTuoZfNUwRRqqvBc rsIEsKgOJPNmOQ2G2SMgVSuzIIqx4QbRrdPGLaZomo2clxrUUtxdSahJPHf3qW8Za6sYJFzFafMQ EjJ3SbyXIwBBeSIu8zJKqRhvNeJTHGZp18shgS5IKFgQDweQccHl9X8WHTNfisGniswsVs0UNqj7 rWySImISsxRZpLt/NbzVUbAm1lPFYNP28KsrqMV72miej1Wr2vte9kTKPOpaXVrJ26aW1S0032/I 99s790Ql1ur9vLhcTK2JrdufMXBVl2D+PpjK07UJxdIl5DB5McSrG9s7HdPsyVn2ggs5Y/eHBI6C uL8M6+uq2kdraySj7cbxrlkZJLpFhAfc7gxqIWAIYBd/3cbuo7ITRx2VjezT2SWskEQimuZ4yRHI uW3AMNs0SkGRSoYZGMggnplWocspc6Uru1009opNadH17X+fnKfvuEVJzv8ACovb3Vva2r6ddfO2 CIys8ckpaZYVPngsNuxs4VhgHIzjIORgc8YqazvXZLiRVRXkBRbZoiybT3TD5DADIOT244xVqPSZ b6Mz6XZaxrrzMRPZ+H9G1jW7l3ydsca6XY3gG7jl9uO4619LfDD9h/8AbL+LtxpzfDb9lX43a5pt 9EWi1e98NLomk+YeVR7/AFSaCWIMMEu1nhepHGK5Z4mi/iqpJfDu30vtf8P0PSw2GqzTUacubS91 bR7au3520+/5Rnso41tS9rIDLKArunmATZJ8xiJE/dEk4BA9CccGWGOd3lh2yPJHJJmSUINilQGu LY7z5cEGQZ/MPRh5fmEtt/Zf4bf8EG/+ClPxFgN/rPgH4dfCS2EqW0ln47+ISXmom3Y83MVtouk3 ALKuWMRaMbsIZQSDX6T/AAg/4NkpPtdpffHf9qS5ns2sl8/w/wDCfwZDomo2V6XRyV8UeJ9S8SWe oRrteMxzeGUhYYcIMkDL6/haXM1WUm4tK0ZO7dn27fPVNdDreW4yasqbhdX5m47aafFu7/g/n/LP 4G+HvjT4v/EHwB8Gvhl4d1Pxp8SfiF4n0zw54b8P6ZC0zXU9zqNm994g1WWNWGneGdM0v7Vczajd LEvmxrGFG8E/6lHwn8KTeAvhl8OPAc86XE3gjwD4P8IzzR/6uWbw14e07RJZUJHzJJLYu6cKQpGR zXxx+yD/AME0P2Vv2IWu9R+CfgEt451KyNhrPxR8XXQ17x1qcMvl/aUj1Dy7Ww0m3uGiBltdE03T bfB2rGEyrfoLFHsVQf4VCgegBOMnuxB+Y/xMWPAO0eLj8Z9ZVKMVdQaS7pe7d26WS9Xrfpf2cuwV TCwfPPVu7jo/K1131evZddpaKKK4D1AooooAieJXYMxbIG0AHA2n7wxjo+Buzz8o2lec07vTrS6s 7uwurSG/sr+Ce2vbK8ijubW7trmMwz29zbzI0c0EsJMMkLqUkjLCRXLMW0aTnjnHr70nFS8uz/ru F7dL33WltO+qv+P3H5Y+J/8AgjR/wTi8XeK77xhrH7MvhuLUdTu7m+vbPSdU1/SdEkvb0k3V1HpN jqENvavO7MzpaeRCpJKRKOK9g+G3/BND9g74QbZfh/8AssfCnS7geWxudS0SfxJcO8ZDpIZfEl3q pEgcBsoFGeAAOB93c9j/AIf4/rSFSerfhj/69VGU4rl55WT01a/X1JlCE/iivuTfrrfX57feclon gzwt4XSCHwx4W8NeHYI0EUcWh6DpWlJCm3GIlsbSAIuP4enqK6pUf+JiRjBz398cgEdsbR6g1IAR 1OcdOOlBBzw2PbANTrq9Xf00+bt5f02CjFKyWn+VrL8Pz7kfkx8HHI6HOMYz0Awo6noOc880NGp4 yRkggg8h+xHUfmD3/F+G/vf+OiggnGT056Dr2/Kp5U/s289E/wBbelvxHtZqOum1k0v+B6+h5r8V vhj4K+MHgLxd8LviP4Z03xf4B8faLe+GvFHh3VULWeo6TqUEkF1GxDCRLhRIZLOSExTx3KpJDc27 or1/m4/8FMv2AvHv/BPL9oC5+G+sxa1rXwe8XXuqa58APibPE0mm61pCyMH8IeJNQjSGCx8WeE4J Y7e7inWSXVLeE3llHKsqmv8ATXdC4xkYyDjHOQc5DZ4PuBkdiDzXzD+1f+yf8Iv2zPg54k+B/wAc /DVv4i8IeIIUkt72NY4de8J6/Am3TvFXhPUikjaXrGlykXNu7JPDMym3u4p7SSS3fpw1edGVm7Qb tJvVW0u7XvstVs7dzmxWHVem0opzUXyK9teivey19VfyP8tizvRdwmYnOI4xMHVmkjjVgi3Q4iMM UzkJGpVpG3BmCjpoSTp50csSIyJGPlMjxo+P+eoJbI67vu55r7g/4KDf8E0v2jP+CefxE1Gw8WaB q/jr4Ja3rHk/Dr406JZyzaLrNoX/AOJZpPidYBI+h+KYIXjS+gu8abcOPOtZowUNfnimrweWXmj8 /wC0O1tBbIsjXDsAR88SJmEGQ+WC/BJyjMK9vDOniXaDu9H1W9n17Xs9evo38zOiqVT2VT3ZrdO/ lbVK2vk+vodDPfRQxxW3lyRW5MjtZMcIrt8weRxsZ13HdGN44Io0+PUGtXvBIZEMzEwyjIlX/Vop TOSqhAF5A/iyQadp/h6/18QTXlvdWtjDcIlxFORBdzgDI2BgT5aEBApBLABs84rtZLWISJbRCSED dHCrRFTsjACu43YH3eOfm+9n5sDojGXtffUklbV69n59jJVU02re67P3tU15Wv8AgcnGJolldoHj PmrcC6mbdAkLDY1oUQRknepdWLcBwDnFTxhd04iRXuT5ckZmkPl+RI2P3ec9cnaFYFepJFS3FrKI blDK5ErjcH5RoUYqWWPIIO8MN2T0HHFVJ12NA8KA2ihQZGBeRHRchflZPkzySc7Rk84Arplyt3T3 30sS7v3raPb+vl2JxHPtYW0pSWF2yM7ww2neCx/urkjBGCMnPSnJO7CIyhpW2kiQklCozuVlBHJA OPm98dapySsiw+S6h7icsBuxFcRkYZLdz/rZCCcrhdvJyTUiSzIZkj2skTKWjLAC1Y4JE78gN/sg c8c55rJOfN8PnvFW2V27336267ji04Ss/tW+ej/LUuTJh0ETeWZIBMZiS0YZn2+WqZ+U47En0xiu zjja1s7WaJJHDxERIG8tvtBzzJuDF0Y5JAAznIOM1zun20EyuCXH2aWNQzjdBK5IlZw3BVF5BU5J zndXSnfJcLcXErOryKbeFGHlRBFA5AABDAZwNu0HHNaOpdWkmn6bv7vxT/BmM21ZJ27/ANfIlhSX eVlCIvlq8zKrFleQncI3D4AGehU8gjsajiKmOYoqBPtJiVTExknCZVXdt5yeNpwozzS+duM4eT5f JMrCIfKMTyBUGTkkjDZ6AkjHSpz5Nph2eQpHh4ZThYpJJl80ROoVipXcBvzg+g6VK9yPLLRtfqnb 8fX8TNydtW7ad32S2+X59zibY6FBei0nvRqEsRWWWPGwxlxu3B+VZCDlTjkZ+tXE1PT42Fq8Zvnk aWWztHnwkW05Dq54IU4JThicYOTXmVzpN7ZajfEXsYL+W9mTPHE8YIG6YhyGkjZ/mRTlUA24GcVM IJRugm+1Owkje81Y3SLFuWN9gghDBjHjIk2AqCV3ckVdJful091J3/wr/M9CvRoc8k3K7k72T7/k tNrXdtzu4tRRyr3SQ2kjzlBtVXeDAKi6dmBEca/6kgk5eZSDxVa98RfYNNSe20y4kZb8RCyMysbv EiI95IqqJBbsHONrAZIPaudtZ31GKK3ZpoVgduJVH9n6hbo65WZDl3Yvsk4BBWMt61Drl3OiacDZ a5rMkOoCOO70ydbfTLJJGRYraGNSuHxkgSDLKrYyainJKLg4Pm5m78rWnu2V13ezb3W3Q5/ZR+zF uOybun07u9vPa2vct+JrmW+Mgt9K0y9Md4rSi6vW/wCJDEyruZre38qWdXJPG/Awc1l6RqOhzte2 dz4oTTdQMLqlvoEYE4WHISOGC5WVpNxX5duMjB5FJrlxqg1K7in1afwwGMNtbppViJtQv5UVXI1G YxsMAAbyTyC3JJ5C1xqVxb6y2lIjpNHGdasrFBJfGEBCrIqAQ+ftLgkAncMVLa5o6q6vp1V0t1ur 6FRglGUWrKVrXe/437dmb2mR3skTzThImsoLpmvp7RBeXcMwbyvt6oqotzIrAtNtAZ+VABqtFBDa 2aMixy3DJGAZ3f5FuSXZVGdpeMAAgDdk8mr00b20ixefOZZSqX8JYyPdIv8Ax7xQKM+ZJENol28D DbhTJZi6SW8gbFsJLhRlIXEuclWDbWCrwB+OO9dEEnFp9/v2LipU4qEOVvmV7226Ws7aaffqYWoW 58hLswb2mk8kySbkjjNvwu8Ox+95rbCAMgHHHNXoEt4kWR7dmdYwZMzNDAwOAcRggsucfPnA6Y54 paosggDOZUeQQzJ5k6yrFvD7j5QYjoFIG3J9eKt28jG23C8a8CBZGM8XlTFQCpjhiIUyJl1bAB+6 CM9aVOHLzPbf77q6Wm3zJqyrRnTilHkk1z8uu9uq08/lZGiq/bJFjjktFeQeSIIN/wC7DKSJGcnE qAcMeRnAOTyZRJYQwwgWM8V5ZxtbSy2mXR4mJ+YlcfMTn5ewPfmqUTTwSPPNPbzzW9uRGTGLdY4n Iw0jYUZQHaSTnPtxSteW7wzyxoQ7Ebo4m3tIcgZQA8jr2wDk+9Xptov6/wCCiYp+1n2s+l73t9/f zsWZnMrkz+asm4Hy5k/dFec4YEDA+hyOppTKZIGNtAsci3McUZjlG1kJ+U7f4FPOCc4HWmGeI3Mc qsyrBblXSQ72YEY3kHOR6Hn+pRCDbCNARLKbRhLGvMSHpI4H3QfU4ycVNSriEleMVayv5Kz3t6X6 dNGOP8Nrrpp5e70/rUfPdPai5F1C0iSEu3lHe2xYnIwT8uQwyoxn6mvmP9oLxjFonjGw0tNPNzqN p4VsLkPPdRJmS6aZolZYVjJ2xoMiTcR93A5J+i5tr+Rp008iiW78kTuCHmdWUSxpkZYAMOO2a+M/ jXYf8JF8XPE18tzJusY9M02ArIAPs2n2oEpfJ+6zThVIAG4Eda4MbVxMIU5R5LTindWtry9dkvuT 9NDXBKLbU9Fd3v8A9u2vfpe++lzW+D/x3v8AwL438JeLPEHhTS/iF4L0rWLK98Z/Dz7bf6Tc+I/D ccqLrWk2muafc297pOoS2xD2F7bTwstzEkche3kmik/0h/8AgnL+zJ/wR0/a0+C/hH9pf9mr4J+C /F1pexWtt4j0Xx3fan4n8ReBPF1jDHFqfhfxz4N1nULrQ7bWNNlUQNcJo0MOq2ghv7R3tZ4tv+Zb puk21m8xMd2kUrYuIpiFWSIqTIyLn51+6+0ZVhwRgkV+hv8AwTg/4KIfE7/gmd+0TY/G/wCEkOq+ Ivh9r9vp+hfGb4M29+9tpHxN8LwkefqNtDIwtrXxZo6vJPoGrSKq2rBrJXEXmR15r9vVS53yySun zKKls7Xfft33VmehCFOnWVSFOMotR99pNqW17au15J6LorO+p/qxeB/g58HPhuSfhn8Jvhh4BRR+ 8PgnwL4Y8KzSXMfy+W0mh6bY+ZIhG2Qy7zvB3MTzXqojuc4MuEIB3AKZcgcg7gYsHp8iJzzmvjr9 iX9tf4Bft6fATw3+0J8AfEY17wprNuNP13RL6BbXxV4E8R2VukmseC/GGlrmXT9X0yQujK4+y6kh ivtPaaxuYJD9kQTJMu4KUJ7MMEjtj2/l0ry5xqxm7y5k3pfps3vq/wBd/M96EozhF8ii0tUlvqvw 0069LIRISDk8c5G3aCgwflLbdz+hJPPPWpgoBPA55Le/TuSegHenUUa9Xd9+5Sau0l/l0/zQc5Pp xj+tFFFAwooooAKKKKACiiigAooooAKKKKACiiigAqOUMY22bt4GUCsFJZeVGTleoHDhkP8AErDI MlBOPU/TrRuHoedeP/h14T+KPhLxD4A+IvhrRvGPgnxNp93pet+Hdct4ruy1Gzu4JI5/OSZSkEpZ xJZ3VmLe90+dUntriJ0Vh/Ff/wAFJ/8Agj/4p/ZK1zxH8Wvgz4ffxv8As/6neLeXtzp1lHc+J/hh 5soNraeKRHDJLdeHorgxW+n6xEsaQGSIXIZtxr+5GQfKxVSzbTtAO0k4OBuyAvOBu42nmsK80e31 KyvtN1CysLzT7+2uLG7sbqzW4tL2yvkMV9Z31rKjW88N7GzQXKeW0UkDSBgS2a3w2Jlh6icW7drX Wlv6/B7nDjcIsTC0UlU6T0TWq+/+tVc/y2tQh864X7RFAGkjkWF0V3WS4j5JiljZVcqpy7BQM5AH aucmtVUQoJVd5dyicHIRGTnczcqytxhskAfSv62f+Cin/BDmHVn8SfGL9jixS0vbq4n1DxF8FHkS CFzFE091N4AL/u1V5PMmbw7cjaWkVtNh39P5ZvFngfxD4Z1TUtG8Qabe6VrGlahPYatpmowzQajY XVsqR3EF1BMomieBhtdXUNHwrcg19VhcTRxVPRxU9E05Wd7Lpe/3Lva1j5avg6uD0alKL+0ldPZN 321v3uutm9fGLyBo44IX8uVYhIol3gCSIyuxBIHXcT15Ax6isS5i4cxALCSSyK2QyYyDyDnn7y9S OK9FvNNgjjjilaIfu2kiEjBUcF2I5PBZuijrgg5rmLzT5NsjeWbeIALIxUrGqZ+R1bgZYjGec9Pq 5RadrP7vT/M5o1b2Sd0tu2rW3r+N35HJbY3kUiJWkBCRBhtjVW4kazhIzbTIhY+Zk7yBxzy6KPfc tbW8bbPkZ5JeDKjZJa6U5aeRUVihyDuAGORV94FE0SxoSIRvEkg2NIVXKhNwBIYjbxnIPvXWeHtD nW1/tK4jjQ3TwhVnbYYGCygGQMQRglTg8HOMcis3CcpppNpLVWfdPp9+vfctzjTik5LX3rNpdtf6 TK8MaW4tVgBkeR3aTLbYV+QLFujPqcblP3ep6VaeElILeOQQTRuzTR43A7sk7GzgrkkrgjggDHFd Bc2MTJGZFjMedpkjxGsh4GEIxknqAM4OM8cVCsRjV2SOKSQDaZpGA2IDhRycAqo2knnPPatuVvl9 1rl3vFrt3XXX11MudN2006vrsref/DnPyQRWzriUuRkOpcqpQ/Ng5z8xLHCnkggjrTGYSBHWUl2m J8iT54gqIOHXoBt+62PbNWJViSYRCQ3EszKBbRo0s8k7AeXsRQWYEFQMZPp059h8Efs5/H34m3kd h4B+C3xR8YahcRui2/h7wtrE6lmjDRyqYrYxyNtICkk5AABwaVV04STk46dXJK7dl321X+XU0UZO zVOU1daKLd9VrontdM+ffiL4Tl0Dxl4n8P63atHq2kzXCSJu8u0Miz5aS3foYWwWi7bcYrzuOIvc S3mQYkRkhjuGK28LKBnY+Nrktzg9wPw/o8/4LC/8E1vFnwZvrf4vaHpmoaz4Yt2FvF4j0u3drW70 x0xGfETRxE6XqFqhCXc0qvHeTjfGxXkfzvXGlhI4bwMLhd0iXKoxZQGR/L+XAGFwcOR8+CwOBXkY LHvEP2bteD5X+Gtt7tO+y7n0ea4OeHarqzpVG5xt/K3tfXqrd0/naMW894bV5op7i7eGUJKbqNVW 3MTb0htEcuQBhxOV+XYFJG7nmtY1eDS57KLT5tT1TUbCKBbDTdPVnzM0h33lyB94wq0iAuOOCMHF ahgZ7pZY7mWIeQsOULA/Z3Ds6A84yyoDjBx161RFrjUdKGnwXERS4/00CMu9zbZO4LghiM/NwwHy +mRXqxnJRc9eVu23a17623atqtlc8uTu790n+HQpXvh6NtTikfTNTWfVLqO/n1S/vwDCxCmSIRs5 Kg/MuOB7569OXhSdrOzkbT9PtlLm3tm81/MX0HPQjA+hqosCW+oXJf8AtHUYjeNIbWSQXEcVttzn yVbegU5J64xzz1NIiDTz3Mck6wOxygUG3POcZPzEcjPqPTrUxhTk3K65pWs9H2/4F1536syqdPn+ hrO+p3dqJpJ7oxWwWWG8a3K3aRnlYgmMsu0gb+QTg570yaNngWcRzJNc7IWQDLSB8YuG64eYZYqe QR25rXuLkiFdiTARN+6vPIYxxgcGJVBw8a9FbacgdKiiZTA8sE7v5eX3bditOx/eAI2Cu1sY6AHG 3jitHGcUm9r6Ppf+u/UzOa1HcltJIqSm4jkhtvs8o5lRVbcyDv5ecN7t6CnWqoiJHBuIZlV494SS OVgWVdzEcZyCO/p0qTWxnSTNJCDdb9xkkYhlXcDlMHJ3dTnB9CapRTwhJlkuHCSW0b5AG1ZAVClW HO8AnHPOTnoKuNT2i2+HT8v6+W/fSLtFt7X/AMjTlkmWbMct0GGEkjEieWeRkOxOAuc5Pr68Un2t knkjljVxGmcNG05xtBP+qDYBz6+/Ss9oAVkuZ9qogje3cuc3DYwEkQE7VIJJ4Jz1oE6RBUWVwg+a RYAGI3cDJJBx0A/HpWE/tdHfftr+g+ePmvl/X9ImlltRNM1u0qM8KS2dvajzpIwCDiTAPHYg/XnN JdXfmSW897JclGEa7o7NwTO3+qhk2oACrAdD6Y56Vo9yXfzxwWduyvbuVbLLbgEIwPUZ9R17ntVW RoQ8SxeVmBUCSh3LzFziSRlJI3AHg9V7VVP3bU5SVdNpW0d72sns3b87J7E+0p+T+S8u/wAl8n2N iC6S1vD5dy83lT7r+3mgIa3lkK8RBgCrt8pJwCSQTx0+KfHsiQ+OPEIhjuWvr7UWaGyjWeW5mKrE Y4yIUdgkymRjuAG2PGDjj67mcGKe2Mc119okTyARtCyRSIQ7SA7m3E4JZu1ZYs7GPUrzxCuh6fce IrGW3kBmgWYgWbwlWRndAGCGQMnzGTvjFY4vDe1cIqfJslDW8V7tk+zS6WLo4iMHJqi5JO6dvJa/ lbsvQ+PzZeJrbTxrH/CKeIoNKmvLi3h1Wwsr+6sbi5CKs2ltL5BVLtn2eUqsZFVZcLwTXtvg/wCA /wAU/EEXhubVb3wH4L8M+IkgWXxRNqttrsWmXUrsLLStbsNIe81LSr24OwOupWttErOd7AV9o/8A C49P8PpaS/Drw22hS3+raXr/AIk+0W9nBpuqatb27wb1068e42qJHbdLBHGndxkrWFqXxt8fTW1z Zwr4d8OvNqE15c3Frp1vOZr5mLS3DBYREodWCxEqQh+ZSMU3lkIqPtqy9m0nG+2tv+H+7ZKw/wC0 J8/s4UHGKS9+217X1v01a18tzuf+Ce/7W/7QX/BJH9uLwHq48cabq/w2+IvjfwX4J+P3gzS7wH4e +LvCPijVLfSv+EjaWJmS18beE7O6/tSwmihMkJhS0vmjQSLX+qxpsqTWtvPFloriCG5Rj1C3EUcy DJ64VxnueDgYxX+Ph4h8L6D4jttVXV5bi7mnubbVFkvGc3VrqhuYn+0WOS2dzDKAMCo6AGv9fjwb n/hFPDAbOR4c8PjJOS3/ABLLTJJ7nPBJPNeJmGGWHlBxmpwkpKPdWs9fv7nvZbJyjUbq89+V8t78 l73V79f8zqaKQcgH1Apa849MKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAoPHh mOGVXZiBHtMkjgL+/M3/ACzKrlQGIBGQQeM/np+2R/wTR/Zw/bN065vvGehHwd8T47cjSfiz4Otr XT/E0UqhVgOsxwMlv4i05FUI1hfuACGk8xN43fo1TWxjGM8HtkD/AApwqVKVSM4O1rNNdNtb+uvV NdLXtlUpRrU3TmrpqzT1W1v6aafZn8H/AO0//wAEa/2tPgFcajquheE5PjD4IglcWfif4aWd3qGp SxFzie/8GRQnW7OdVw96bSwmsJZi89vcSq4avzpsv2S/2jte1htL0b4IfEzXdTeTyljtfhv4vlvb di2Cs9lJo6zWzq2VaWeOOI8orbhX+mcVYuCGKjgbQODz3GQvpwRzio4rC0gkaWO3tYpn+9JHbQRS MM5+Z0UO3PqxFess4qpJSpKTVryv8Wy/zu9Ovy8WeRUU7xqqKutLO3R6a27ro77pn+fD8Mf+CM/7 dfxBu7W5ufgjrGhWBcvHP4n1C08NtIxQsn2qx1Ge2uoURgpCeQeVCkYNfe/g3/g3p/ao8RkN4u+I Xws8ARqqeVHuvteljAwQHGnW9zE0qejPtYjBIB4/swaPcPvE/iRn8cnP5GkEQAIJGT9OT2zxz+Wa znnGIvzwXs7JKyerejv26eXXRM2WSYZ8rqSVRqy+Ss7bN9emjXnv/Mh4D/4Nu/AEMdlcfEv9ozxX e3sUqyahp3gzwvpthYXeOWMWp6hLFqVtuYceRbgDPDGvuL4f/wDBC3/gnz4Engvb7wD4q8eXw2Nc f8Jt411bVNLupAQGZtHd00794ys7x/O/zEdq/ZBVIz0J7f8A68f0p+B6CuaWZ4+rrKrKMXbZqLe1 vhUX576vR3Wh1Ry3BQd1RhJpqztfstpcyWnldLq9D5T+Hv7E37JvwtS1T4f/ALPfws8NmzZvs89p 4T057mA+Y0jMHuIHkDNIzMGDc53DgivpS30qxswsVnZW9jDGu1I7KGCzj2jjCxW8W4gDAHAAHAHF bH+TRwfwyP8AGueVSpUd51JT73bd9Fa7bfqvU6adGlTa5KSjZWTSS00007X/AA+7ifG/g/wx478N 6x4Q8YaHpniLw7rtjLp+p6Lq1vHPY31tOjJJDIsgKJKwY+TJgMjbNrZGR/Fd/wAFPv8AgiD8SfgH q/iL46fsm6JqnxI+B91Lcat4w+HWnW41b4gfD5TIWuJdE0pGtU8SeHoYpJWmjtZ01GzIjSK1uVZ5 F/t/niEqurLuDDgcffH3WIIOSuMrkFQQDjNVDaIfKPzgpn7km0DcCGJAHzbs/MvCt0KlSVODpSnU jOFSVLkdrU5cjm1yvXlab26u2vRnfSxFGnTnRxdKOIwc1adGacpuTaXNSkk6lKSbvGUX7ONvfhON 4n+TFfaYjRzT2hlu7OGaRdQtWgaz1DSDBvRrK802Xbd2V4krBZbG4HnxsjZPHOJbSiUGYyT7Et5b cYIiWJDyrCLAnE4wAcP90nA61/oX/tyf8EV/2Vv2tbjWfH3huxHwI+NepoTJ4/8AAWnW0Gk69qKr mG68ZeD40i0rVmZwGubzT49K1S4JaS4v5SX3fyf/ALV//BGP9un9nCTV9bvfhXJ8ZvBtl51yvxJ+ BsUuuiDTrZih1jxF4NuJo9R0hlQA3Npb3OpPhi0O4bTXs0M3ptRoYh1I8ujSh+7atvKpa/M7Nu7u t76XXh4jJFKU6uBrxlSbUoUJO+NinZqNRStRryS0U6EKUe8NT8g2tpo7WCXbdobvdA0qSKzeQH4R go80qe5LbuTluprQS2hR4WhMlv8AaSyp5JwkckY+9OrEqofABOAOT6VmazqkXhu7bTPEkOr+FtWt nliuU1vTdQ0eWGFGaN9RbTtVtIpIIdxMbWzyGXepKsRg07S7iK4FzHZ6hHdRNHE8Mwmhn+0d8bY2 UwK5+9lyQD14Jr16Lw04uWHqU4taytVc73asmnJ8ll0VvyPGq4XE01L22GrwUGlGVSDXOmtWpxUY NrS8VFSV/eu3p0D3BkELO8gVAGKRHMIlx85VeVIyPlzkY6DFJNJE8CrGsrPI7tgjb8wIJbCgcnrx xwMCkllmRGiSzgVkAeW3hmUOsbdrcMrj5R0VjJwM7mxVdyiJCJLqRnAlmjtIQqXUSvghbljvRsDP Kog+nQdEJzfuc0HG2idrX0Xn0bW97nC58vvSpz5b8u0ktdnbXz36aq6MnWlkOlzbVEkjSxRnzGxE Ixu3IxJzhhjbgjkHkcVjxbVhKC3i8oBI8YcSJNzskjy+DHHhiSQwJIPOOL2tLHNZiODz3wyTTSXG fIicElUm8vaxLDcVcEqgU7lO4AYkP2iZRcwsLqGHH2jZIGjtwuAQpCo0qHPOB7Hk5OTjVg2nKPLK /wAOj6bNX11evyNFJWdoTta7+JLovzdtuhsJF51xuGUVIQ0s6yAySbQThUfdGDjAOEHHvSKUPnYY 2jyWpuQJCrGRQSNhIHGcHpjg8CsxpRZkzP5LecGYGS4WGBU6kkSSBlAwckkjHAHNZ8WuaVO0jeY1 2r5jiNhHJdNKw4MUJQSAKpzkMGzg44NX7aio8r5bre973Vuu68+33XuEVN2VOfRLR76X3ttd6eW5 sARPFK7S8LHHEd29fMBPy/Kybph0/exgLjrkU92n3SxGNHjtnIjuCyuAsuFAVkVAwXcCCQTx+FaW laN8RvGC2zeHfA3jrxFHp0QsdOudB8E6rqRliYY8tTa6e8bqwO0tJG8nQhwen0H4E/YR/bp+J8EE vw6/ZC+OnieFsOjWHg+40+2d5eVaeTWLi0K265BUeWGXoxxWVPGYanHmTipeSSavbR2t16/8MV9Q x1lanBrTeK1Xu76+Vk3069vmSS5DObeFiHtUSNioKwMd2Q+Tk+Ycjd82MheOtVg8zNKBHGkyAymR yx82QgAOoBG8qqMCMFfm6ZIr9XPAX/BCz/gqr8RPs6Qfs96d4CS7lC3LfErxhp3hv7KFIDTOtrDq TYIcFVGS2xxgYr7t+HP/AAa8fth65q2nzfFb9oL4O+AtJ2Rvcx+F9M13xZq9lIAfNjjlmvdKs7zb kA4hiDnbhlBJrCWZ4Vybm25XfM2+umu701T30slvY6I4DHWVoxV1rZW39P6t5n820fkvHMzNLMk8 OGmCb0s3UnzDskdXjQswLujkJniM5G2nJe2Nooa9vbaJjGsEUdy8cNlNEn3JXld97smc42rngMSK /tY+Ff8Awav/ALPmlxv/AMLo/aT+L3j+RrrzxF4H0/w98P7OVMqTbXianZ+L55LaQArKkFxbSONp WVCuT+o/wc/4If8A/BMv4MtZ3Gj/ALM3hvxZrNkkSDXviHqniDxhdTvGOJZtP1LVX8P73Iy6xaPF ExJxGBgDKpmlJq0U5xsmlJX3tor9d3v6aHRSy6s0o1LRd9Un6dtEt9b+Tvc/z2/2av2b/il+1p8a vhz8FvhP4f1TUNT8a69p+nzeIYNH1C+03Q7OGaJ9V8V6trBgj0mHQ9Kt0kuLyNrtJJ/LfyPvAV/q 6aHaSafpOm6fMweTStOsLGV0wRK9raQxM49F3xl1Ge/XHXlPA/wf+FPwysIdM+HHw38DeA7KC1Sx ih8I+E9B8PhbNFVBbs2m2Fu8sZVQHEzSGTq5YkmvQUhSP7uRnr0+b/e4wa8nE4r6zyKySp3SXa9u 2myt8umx6eCwUcIptO8qlubsrX/z3/BEijCgZJwAMnr+PvS0UVyncFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAFFFFABRRRQAUUUUAFHWiigBAoByB+poIB5I/wA9aWigTSe6T9QAxwKCAevY5/Giigdk tlYKKKKLJ7q4rJbJL5BQBj8yfzoopWXZfcMTaOTjk5/Wm7cDjORyP8PxxT6KfzfpfT1sKyvfr36+ nppsV5YFlTY2fvBgVYqwI6bWGGB7ZBBwSM4JzEtmiuZEUKSQcAsFDAMN4RCF805wZSDIVOC3WrtF DvJWbbXa7t91/JAoxX2Ibp6xi9rW6dLaduh82fGL9j79mH9oG1vrX40fAn4W/EQ6lIst9f8AiDwZ olxrVxIq7EaTXI7OPV3KKFClr0sMA5yBj82/HP8Awb1f8EuvGupy6unwO1fwhczQiKWHwV8RfHvh +xZR3/s+18QrZZx1HkY9u1ftvSHkH6GphCNPmcFyOTTk4tpya2u73dulzWVarOCpzqSnTimowm+a ME91CMrqF93y2uz8H9O/4Nzf+CZWmW4hg+H/AMR3mVy63Vz8WvHlxIoJ4RY5tceFIwDgIkSqBwAB xXE+If8Ag27/AOCf2o3Ms2j3/wAYfC7Orj/iW+L01AKZARlX1m01BzjqUdmQHGxUGRX9C2MqAfQf gaj8pRyASfTOK3jXrQd41Jp+t/wd0c06NKceWVODjdStyparrpZ+vfqfzU6j/wAGyP7IV1bRwWPx 2/aE0cI5LPbP8Op3kib78DfbfBNwGUjALPvb0PPOd4f/AODXn9ibTtTkvvEHxm/aL8XWLEkaPdax 4N0C1RCV3ILnwv4U0e/5x0F2sZ3EtGzBCn9NGxTyU5XOBnOc/wAqURp12AEjB/Q4/MVbxWIk03Vk 2ttlb7lqCoUUnFU4WejVr3+b1PxM+Hn/AAb8f8Eu/ATpdS/A/V/HN0u35/HfxB8ba9E5AAYNZy64 tptbqyLCEyMba+3fh3/wTl/Ya+FkAg8D/stfBjS4hjat54L0rXmTbwCj69b6i6NwMsDknqTmvtba MAbB16enXnPen9KzdWo3fnlfunb77WuVGnTh8MIrrsulu/ocR4X+G3gDwPEYPBPgfwd4OgwVWDwr 4X0Pw7CqnjAXR7GzIOOOCK7FYQqqoeYhOm6WRicf32Lb3997HPepqKyaurXdvX+vn3LK7W6MGDFy GOTh5Bk98gNtIOAORz3zxUnlJkEAjaMDazpnp12Mobp3B+tSUUJWSXbvv83/AF5AReUoBA4ycnlj nHTOWOf5e1OCY5JP0BwPx9afRTAaVJz83B7YFOoopKKWwBRRRTAKKKKACiiigAooooAKKKKACiii gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK KKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gAooooAKKKKAP//Z ________________________________________________________________________________
Date: Aug 08, 2017
Subject: Re: 2 AWG crimping tool
Yes, I have one of those tools from Harbor Freight. I accepted the fact that the die markings are some fellows fantasy and simply select a die of a suitable size to crimp whatever terminal/wire combination I=99m using. It does a great job of crimping fat wires up to #2. I=99v e never tried to do anything larger so I can=99t speak to them. Blue skies & tailwinds, Bob Borger Europa XS Tri, Rotax 914, Airmaster C/S Prop (75 hrs). Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP 3705 Lynchburg Dr. Corinth, TX 76208-5331 Cel: 817-992-1117 rlborger(at)mac.com > On Aug 8, 2017, at 9:54 AM, Robert L. Nuckolls, III wrote: > > At 11:04 AM 8/7/2017, you wrote: >> I think that if you do your research, that preference for crimps has more to do with unskilled labor, quick training time, and quicker operations in a production environment. Crimping is without a doubt, much faster than solder, even if you have the skillset to do good soldering. Problem is, purchasing expensive tools for basically 'one-off' jobs. If you've got access to a press, or even a good shop vice, you could do this... > > I bought one of these Harbor Freight > tools a few years back . . . lots of > capability for the bux. Took it back > a couple weeks later . . . > > > > <93bcbd6.jpg> > > It seems that the designers for this > tool had a poor knowledge of the die > openings appropriate to installation > of terminals on wire. > > > > > <93bcc24.jpg> > As you can see in this excerpt, the die set > is labeled "0 AWG" . . . when in fact, the > hex opening in the closed jaws MIGHT just admit > the stranding on 2AWG wire and it's certainly > way too small to accommodate the terminal > appropriate to a 0AWG wire. > > I took some wire and terminals along with me > to show the manager . . . he didn't quibble > about giving me store credit for the return. > Sadly, this latest illustration pulled from > the website suggest that nothing has been > 'fixed' with the sizing of this products > die-sets. > > While this tool has the mechanical 'oomph' > needed to apply large terminals to fat wires, > the die-sets suggest capabilities not > realized. > > In the years since this article was published > > http://tinyurl.com/ct36xen > > <http://tinyurl.com/ct36xen> I have installed dozens of terminals on fat wires. > Although I do have access to some pretty capable > crimp tools, I've found that the convenience > and economics of this technique are very attractive. > > > > > Bob . . . > ________________________________________________________________________________
Date: Aug 08, 2017
Subject: Re: Questions for the alternator mavens
At 09:22 AM 8/8/2017, you wrote: > >Hi > >I am looking at options for my RV10 electrical system. I am keen on >preventing OV issues so I'd like to make sure I do this right. > >Here is my plan (for now): > >1. I plan to install an externally regulated Nippon Denso alternator >(60A) as a primary alternator. >2. I plan to install a gear driven (B&C) back up alternator >3. I plan to use a VP-X Pro to monitor line voltages and provide OV >protection. The VP-X would also ensure only one alternator was >online at a time. > >My questions is: Is there any reason I can't use automotive solid >state voltage regulators rather than *aviation* ones sold by ACS? >The *aviation* regulators are 4-10 times the cost of automotive regulators. The regulators recommended by B&C for their externally regulated alternators have built in ov protection. The regulator recommended for the stand-by alternator has ov protection AND automatic standby alternator management. When wired as suggested here . . . http://tinyurl.com/ag46m2f . . . you've got about everything you need for a capable, reliable, economical, failure tolerant electrical system. This architecture has been repeated in many hundreds of type certificated and owner built and maintained aircraft. If dollars expended to achieve the lightest, most economical, easiest to maintain system are part of your purchase considerations, you might want to review the VP-X Pro decision. What value does that product bring to your project that makes it superior to the field proven architecture shown in Figure Z-12? Bob . . . ________________________________________________________________________________
Date: Aug 08, 2017
Subject: Re: Standby Alternator Wiring
Hi Bob; I find your comments very reassuring. I have a low amperage system (day VFR) and have two identical 20 amp internally regulated permanent magnet alternators (dynamos) installed. I have them set up to run independently or in parallel via toggle switches on the panel. I was expecting to try it both ways to see what happens. Still will, but now somewhat more optimistic. Keep up "The Good Work." Cheers! Stu. ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Sent: Tuesday, August 8, 2017 9:06:34 AM Subject: Re: AeroElectric-List: Re: Standby Alternator Wiring At 05:56 AM 8/7/2017, you wrote: The main alternator is switched via one half of the master switch. Nothing will be damaged if both alternators are both turned on, although voltage regulation might not be stable. -------- Joe Gores Running two alternators simultaneously is generally not a big deal. The alternator with the higher set-point will 'hog' the load until it's capacity is exceeded. The bus voltage sags and the alternator with the lower set point picks up the difference. Figure Z-12 shows how a second alternator is added to a single-alternator design. This is done on hundreds of TC aircraft where the B&C standby alternator is offered as an option. The standby alternator is set approx 1.0 volt below normal bus voltage (0.5v in a 14v system) In flight, BOTH alternator field switches are ON. The standby alternator regulator 'sees' what it perceives is a too-high bus voltage and completely relaxes . . . s/b alternator field voltage is reduced to near zero. If the main alternator shuts down, bus voltage sags, s/b regulator 'wakes up' and the second alternator goes to work. The only thing 'magic' about the s/b alternator is the current sensor system that annunciates 's/b alternator active' and assists in load shedding to some value at or below the alternator's rated output. But even when the alternators are on line together and closely adjusted for set point, they're well behaved. Bob . . . ________________________________________________________________________________
Date: Aug 08, 2017
Are you saying the only problem is the jaw size (in AWG) are incorrect, mine has the measurements in 'sq mm' I do my own calculations John Sent from my iPad ----x--O--x---- > On 8 Aug 2017, at 04:54 pm, "Robert L. Nuckolls, III" <nuckolls.bob@aeroel ectric.com> wrote: > > At 11:04 AM 8/7/2017, you wrote: >> I think that if you do your research, that preference for crimps has more to do with unskilled labor, quick training time, and quicker operations in a production environment. Crimping is without a doubt, much faster than solde r, even if you have the skillset to do good soldering. Problem is, purchasin g expensive tools for basically 'one-off' jobs. If you've got access to a pr ess, or even a good shop vice, you could do this... > > I bought one of these Harbor Freight > tools a few years back . . . lots of > capability for the bux. Took it back > a couple weeks later . . . > > > > <93bcbd6.jpg> > > It seems that the designers for this > tool had a poor knowledge of the die > openings appropriate to installation > of terminals on wire. > > > > > <93bcc24.jpg> > As you can see in this excerpt, the die set > is labeled "0 AWG" . . . when in fact, the > hex opening in the closed jaws MIGHT just admit > the stranding on 2AWG wire and it's certainly > way too small to accommodate the terminal > appropriate to a 0AWG wire. > > I took some wire and terminals along with me > to show the manager . . . he didn't quibble > about giving me store credit for the return. > Sadly, this latest illustration pulled from > the website suggest that nothing has been > 'fixed' with the sizing of this products > die-sets. > > While this tool has the mechanical 'oomph' > needed to apply large terminals to fat wires, > the die-sets suggest capabilities not > realized. > > In the years since this article was published > > http://tinyurl.com/ct36xen > > I have installed dozens of terminals on fat wires. > Although I do have access to some pretty capable > crimp tools, I've found that the convenience > and economics of this technique are very attractive. > > > > > Bob . . . ________________________________________________________________________________
Date: Aug 08, 2017
> >My questions is: Is there any reason I can't use automotive solid >state voltage regulators rather than *aviation* ones sold by ACS? >The *aviation* regulators are 4-10 times the cost of automotive regulators. More specific to your original question, if you've provided for alternative ov protection, then any automotive alternator regulator will probably do the job . . . some are quite reasonable. http://tinyurl.com/y8tsebjz Here's how it's wired . . . Emacs! Bob . . . ________________________________________________________________________________
Date: Aug 08, 2017
At 12:36 PM 8/8/2017, you wrote: >Are you saying the only problem is the jaw size (in AWG) are >incorrect, mine has the measurements in 'sq mm' I do my own calculations > >John Yeah, the largest die set with the one I bought would do 4AWG but nothing larger. It had some smaller dies that would probably have worked down to 10AWG . . . but I didn't need a hydraulic crimper for wires that small. I considered modeling the dies and cutting larger versions on the CNC mill . . . but I didn't need it THAT bad. The since then I've put terminals on 2AWG wires with one of these guys! http://tinyurl.com/yakycxtn It took several minutes to get it up to temperature but the ol' 63/37 solder flowed right into the joint. Bob . . . ________________________________________________________________________________
Date: Aug 08, 2017
Excellent timing for this discussion. My 1 year old Odyssey PC545 was at 10V when I went to go flying today. Couldn't find any reason, started fine 2 da ys ago (I know, I know, that's not a good measure of battery health) Charged it for 30 minutes and then did an external start. Ammeter showed no current going into the battery. Leaving the alternator on and turning the battery o ff jumped the voltage up half a volt. So I think my battery is done, the loc al Odyssey dealer is going to confirm tomorrow morning. Anyway my question is on these automotive voltage regulators, is it possible to adjust the voltage high enough to keep an Odyssey battery happy? Thank you, Sebastien > On Aug 8, 2017, at 15:09, Robert L. Nuckolls, III <nuckolls.bob@aeroelectr ic.com> wrote: > >> >> My questions is: Is there any reason I can't use automotive solid state v oltage regulators rather than *aviation* ones sold by ACS? The *aviation* re gulators are 4-10 times the cost of automotive regulators. > > > More specific to your original question, if you've > provided for alternative ov protection, then > any automotive alternator regulator will > probably do the job . . . some are quite reasonable. > > http://tinyurl.com/y8tsebjz > > Here's how it's wired . . . > > > > > Bob . . . ________________________________________________________________________________
Date: Aug 08, 2017
Hi Bob Thanks for the advice and the info. I haven't made any firm decision on which way I will go so your comments will be most helpful. Regards Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471636#471636 ________________________________________________________________________________
Date: Aug 08, 2017
Did you verify that the alternator was actually working at a voltage that would charge the battery? (Should be at least 14V; 14.7V for optimum charging, according to Odyssey.) On 8/8/2017 5:40 PM, Sebastien wrote: > Excellent timing for this discussion. My 1 year old Odyssey PC545 was > at 10V when I went to go flying today. Couldn't find any reason, > started fine 2 days ago (I know, I know, that's not a good measure of > battery health) Charged it for 30 minutes and then did an external > start. Ammeter showed no current going into the battery. Leaving the > alternator on and turning the battery off jumped the voltage up half a > volt. So I think my battery is done, the local Odyssey dealer is going > to confirm tomorrow morning. > > Anyway my question is on these automotive voltage regulators, is it > possible to adjust the voltage high enough to keep an Odyssey battery > happy? > > Thank you, > > Sebastien > > On Aug 8, 2017, at 15:09, Robert L. Nuckolls, III > > > wrote: > >>> >>> My questions is: Is there any reason I can't use automotive solid >>> state voltage regulators rather than *aviation* ones sold by ACS? >>> The *aviation* regulators are 4-10 times the cost of automotive >>> regulators. >> >> >> More specific to your original question, if you've >> provided for alternative ov protection, then >> any automotive alternator regulator will >> probably do the job . . . some are quite reasonable. >> >> http://tinyurl.com/y8tsebjz >> >> Here's how it's wired . . . >> >> >> >> >> Bob . . . >> --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Aug 08, 2017
Subject: Re: Aircraft theft prevention?
I have a towbar switch that is in series with the starter circuit. =C2-If the towbar is not in place, then the starter will not engage. =C2-When I leave my airplane on the ramp, I do not install the towbar in its holder, thus rendering the start circuit inoperable.MikeLancair ES > wrote: > So with the understanding that most aircraft security is only good enough t o keep honest folks from running off with your airplane... But does anyone have any ideas on ways to prevent the engine from starting? Other that the big chain prop locks. Early on, I was considering second, hidden mag switches.=C2- But I'm wond ering if there's an alternative. Note: I do not have a keyed ignition switch.=C2- Just a toggle switch for each mag and a push button starter switch. ________________________________________________________________________________
Subject: Analog electric clock with a relay circuit for battery
capacity test
Date: Aug 08, 2017
Bob, Some time ago you posted a simple circuit for doing an approximation of bat tery capacity. The circuit consisted of an analog electric clock to measur e the time required to discharge a battery, through a light bulb, down to 1 0 volts. I would like to build one of these to use as an annual battery co ndition test. Can you direct me to where I might find information on how t o make one? Thanks, Roger ________________________________________________________________________________
Date: Aug 08, 2017
I have not checked the alternator yet but have been meaning to change the vo ltage regulator for some time simply because of age. I will put a good batte ry in tomorrow (either my battery if still good or a new one) and check the a lternator voltage. My question is does anyone know if these $10 automotive regulators can be s et to 14.7 V or are they only ok for regular automotive batteries? Sebastien > On Aug 8, 2017, at 16:20, Charlie England wrote: > > Did you verify that the alternator was actually working at a voltage that w ould charge the battery? (Should be at least 14V; 14.7V for optimum charging , according to Odyssey.) > >> On 8/8/2017 5:40 PM, Sebastien wrote: >> Excellent timing for this discussion. My 1 year old Odyssey PC545 was at 1 0V when I went to go flying today. Couldn't find any reason, started fine 2 d ays ago (I know, I know, that's not a good measure of battery health) Charge d it for 30 minutes and then did an external start. Ammeter showed no curren t going into the battery. Leaving the alternator on and turning the battery o ff jumped the voltage up half a volt. So I think my battery is done, the loc al Odyssey dealer is going to confirm tomorrow morning. >> >> Anyway my question is on these automotive voltage regulators, is it possi ble to adjust the voltage high enough to keep an Odyssey battery happy? >> >> Thank you, >> >> Sebastien >> >> On Aug 8, 2017, at 15:09, Robert L. Nuckolls, III <nuckolls.bob@aeroelect ric.com> wrote: >> >>>> >>>> My questions is: Is there any reason I can't use automotive solid state voltage regulators rather than *aviation* ones sold by ACS? The *aviation* r egulators are 4-10 times the cost of automotive regulators. >>> >>> >>> More specific to your original question, if you've >>> provided for alternative ov protection, then >>> any automotive alternator regulator will >>> probably do the job . . . some are quite reasonable. >>> >>> http://tinyurl.com/y8tsebjz >>> >>> Here's how it's wired . . . >>> >>> >>> >>> >>> Bob . . . >>> > > > Virus-free. www.avast.com ________________________________________________________________________________
Date: Aug 08, 2017
Sebastien, The symptoms that you described sound more like a problem with the charging system, than a bad battery. What is the electrical system voltage with the engine running above idle? -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471642#471642 ________________________________________________________________________________
Date: Aug 08, 2017
Adjustable regulators exist, but finding one on the shelf of your local auto parts store is unlikely. FWIW, age is rarely a factor in the lifespan of electronic products. Most are more likely to die an infant death, than one of old age. Getting past a few dozen hours of operation usually means that the device has no manufacturing defects, and will continue to live for years or even decades. Heat is the primary enemy of most electronics, once past the 'birth defects' stage. On 8/8/2017 6:31 PM, Sebastien wrote: > I have not checked the alternator yet but have been meaning to change > the voltage regulator for some time simply because of age. I will put > a good battery in tomorrow (either my battery if still good or a new > one) and check the alternator voltage. > > My question is does anyone know if these $10 automotive regulators > can be set to 14.7 V or are they only ok for regular automotive batteries? > > Sebastien > > On Aug 8, 2017, at 16:20, Charlie England > wrote: > >> Did you verify that the alternator was actually working at a voltage >> that would charge the battery? (Should be at least 14V; 14.7V for >> optimum charging, according to Odyssey.) >> >> On 8/8/2017 5:40 PM, Sebastien wrote: >>> Excellent timing for this discussion. My 1 year old Odyssey PC545 >>> was at 10V when I went to go flying today. Couldn't find any reason, >>> started fine 2 days ago (I know, I know, that's not a good measure >>> of battery health) Charged it for 30 minutes and then did an >>> external start. Ammeter showed no current going into the battery. >>> Leaving the alternator on and turning the battery off jumped the >>> voltage up half a volt. So I think my battery is done, the local >>> Odyssey dealer is going to confirm tomorrow morning. >>> >>> Anyway my question is on these automotive voltage regulators, is it >>> possible to adjust the voltage high enough to keep an Odyssey >>> battery happy? >>> >>> Thank you, >>> >>> Sebastien >>> >>> On Aug 8, 2017, at 15:09, Robert L. Nuckolls, III >>> >> > wrote: >>> >>>>> >>>>> My questions is: Is there any reason I can't use automotive solid >>>>> state voltage regulators rather than *aviation* ones sold by ACS? >>>>> The *aviation* regulators are 4-10 times the cost of automotive >>>>> regulators. >>>> >>>> >>>> More specific to your original question, if you've >>>> provided for alternative ov protection, then >>>> any automotive alternator regulator will >>>> probably do the job . . . some are quite reasonable. >>>> >>>> http://tinyurl.com/y8tsebjz >>>> >>>> Here's how it's wired . . . >>>> >>>> >>>> >>>> >>>> Bob . . . >>>> >> >> >> >> Virus-free. www.avast.com >> >> >> >> <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Aug 08, 2017
Normally 14V, this time 13V, 13.5 with the battery master off. Sebastien > On Aug 8, 2017, at 16:57, user9253 wrote: > > > Sebastien, > The symptoms that you described sound more like a problem with the charging system, than a bad battery. What is the electrical system voltage with the engine running above idle? > > -------- > Joe Gores > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471642#471642 > > > > > > > > > ________________________________________________________________________________
Date: Aug 08, 2017
That sure sounds like a charging system problem to me. The voltage should be above 14. If belt driven, is the belt tight? Are all electrical connections clean and tight? > Normally 14V, this time 13V, 13.5 with the battery master off. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471646#471646 ________________________________________________________________________________
Date: Aug 08, 2017
Bob, Thanks for explaining. I was going to build Z-12 for my plane but I did not understand *why* it worked without your explanation. Cheers, -- Art Z. On Tue, Aug 8, 2017 at 11:06 AM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > Running two alternators simultaneously is generally > not a big deal. The alternator with the higher set-point > will 'hog' the load until it's capacity is exceeded. > The bus voltage sags and the alternator with the > lower set point picks up the difference. > > Figure Z-12 shows how a second alternator is added > to a single-alternator design. This is done on hundreds > of TC aircraft where the B&C standby alternator is > offered as an option. > > The standby alternator is set approx 1.0 volt below > normal bus voltage (0.5v in a 14v system) In flight, > BOTH alternator field switches are ON. > > The standby alternator regulator 'sees' what it > perceives is a too-high bus voltage and completely > relaxes . . . s/b alternator field voltage is > reduced to near zero. > > If the main alternator shuts down, bus voltage > sags, s/b regulator 'wakes up' and the second > alternator goes to work. The only thing 'magic' > about the s/b alternator is the current sensor > system that annunciates 's/b alternator active' > and assists in load shedding to some value at > or below the alternator's rated output. > > But even when the alternators are on line together > and closely adjusted for set point, they're well > behaved. > -- https://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
Date: Aug 08, 2017
Belt was at the upper limits of tight 1 week and 8 flight hours ago. Before flight it felt the same when checked by thumb. I will check the alternator connections. Sebastien > On Aug 8, 2017, at 17:44, user9253 wrote: > > > That sure sounds like a charging system problem to me. The voltage should be above 14. If belt driven, is the belt tight? Are all electrical connections clean and tight? > >> Normally 14V, this time 13V, 13.5 with the battery master off. > > > -------- > Joe Gores > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471646#471646 > > > > > > > > > ________________________________________________________________________________
Subject: Re: Analog electric clock with a relay circuit for
battery capac
Date: Aug 08, 2017
http://www.aeroelectric.com/articles/battest.pdf Or an easier way is to turn on the landing light or "Clip a 55w head-lamp bulb across the battery and come back in 2 hours to check the voltage. If it's not at 11.0 volts or above, the battery is toast." Go to https://www.matronics.com/archive/archive-get.cgi?AeroElectric-Archive.digest.vol-lv and search (CTRL-F) for "toast" -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471649#471649 ________________________________________________________________________________
From: William Hunter <billhuntersemail(at)gmail.com>
Date: Aug 08, 2017
Subject: Re: Starter Solenoid Diode
Joe, This is very helpful!!! Thanks, Bill Hunter On Aug 6, 2017 2:33 PM, "user9253" wrote: > > Since no one else has replied, I will give it a shot. I do not know if > the EMS input needs protection or not. But if you want to add protection, > the attached pdf should work. The left diode blocks aircraft current from > flowing into the EMS input. The diode on the right shorts out any induced > voltage spike. The two 500 ohm resistors divide starter voltage in half. > The bottom resistor also provides a ground path to pull the EMS input > voltage low (to about 0.25 V) when the contactor is not energized. > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471555#471555 > > > Attachments: > > http://forums.matronics.com//files/starter_status_124.pdf > > ________________________________________________________________________________
Date: Aug 08, 2017
Is there a failure mode for regulator or alternator that would lead to a voltage too low to charge the battery but too high to discharge it? After start I turned on every load I could (not much, pitot heat, fuel pump, avionics, and lights) and the alternator supplied everything fine. On Tue, Aug 8, 2017 at 6:02 PM, Sebastien wrote: > Belt was at the upper limits of tight 1 week and 8 flight hours ago. > Before flight it felt the same when checked by thumb. > > I will check the alternator connections. > > Sebastien > > > On Aug 8, 2017, at 17:44, user9253 wrote: > > > > > > That sure sounds like a charging system problem to me. The voltage > should be above 14. If belt driven, is the belt tight? Are all electrical > connections clean and tight? > > > >> Normally 14V, this time 13V, 13.5 with the battery master off. > > > > > > -------- > > Joe Gores > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=471646#471646 > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Aug 08, 2017
At 05:40 PM 8/8/2017, you wrote: >Excellent timing for this discussion. My 1 year old Odyssey PC545 >was at 10V when I went to go flying today. Couldn't find any reason, >started fine 2 days ago (I know, I know, that's not a good measure >of battery health) Charged it for 30 minutes and then did an >external start. Ammeter showed no current going into the battery. >Leaving the alternator on and turning the battery off jumped the >voltage up half a volt. So I think my battery is done, the local >Odyssey dealer is going to confirm tomorrow morning. > >Anyway my question is on these automotive voltage regulators, is it >possible to adjust the voltage high enough to keep an Odyssey battery happy? Odyssey batteries are happy at that same levels as other svla batteries. The Odyssey manual calls for constant current charging until 14.7 volts is achieved whereupon the votlage is held at 14.7 until recharge current falls to 100mA -OR- 4 hours have elapsed. Nobody charges with that kind of precision in a vehicle. Any automotive regulator that comes on line at 14.3 plus/minus 0.2 volts is going to be entirely satisfactory for your airplane. WAAaaayyy back when, the regulators we put on Cessnas were stock Ford products with a 14.2 plus/minus 0.2 volt setpoing. Your battery only lasted a year? What is the nominal bus voltage for your airplane? Bob . . . ________________________________________________________________________________
Date: Aug 08, 2017
Hello Bob, I'm ashamed to say I don't know with any precision. My portable GPS typically sees voltages of 13.9-13.7 but that is after a couple busses and fuse holder and connector and such. The analog voltmeter bounces all over the place with the engine running but seems to read very approximately 13.5 to 14 normally. I remember putting a digital voltmeter on the main bus in flight when I first bought the aircraft to check why the analog one was bouncing and it was a steady something that seemed normal but I don't remember what. I should have checked it when I installed the Odyssey battery but it was never done. As you are fond of pointing out, "battery can start engine" is not a battery check so I was planning on taking it in next week during the annual inspection. Curious that you say the Cessnas were 14.2 +- 0.2. When I was learning to fly I seem to remember the green arc for voltage was 13.8-14.6. Don't know where that number came from or if I am remembering it correctly. I see the Odyssey literature states: Alternators that do not have a regulated charge between 14.0V and 14.7V (no lower than 14.0V and no higher than 14.7V) will cause early failure of the Battery So I guess an automotive one set to 14.3 +- 0.2, while at the low end, still meets this requirement. Perhaps checking the battery voltage at every oil change to make sure it's being charged to 100% might be a good idea? The local battery shop is going to test the battery in the morning after an overnight charge so I won't know until then if the battery is ok. After reinstalling it or a new one I will get a voltmeter on the battery with the engine running and see what the alternator is delivering. My home airport is a 25 minute flight away from my present location and the weather is good so I'm planning on flying home with or without the charging system working tomorrow. Sebastien On Aug 8, 2017, at 21:19, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: At 05:40 PM 8/8/2017, you wrote: Excellent timing for this discussion. My 1 year old Odyssey PC545 was at 10V when I went to go flying today. Couldn't find any reason, started fine 2 days ago (I know, I know, that's not a good measure of battery health) Charged it for 30 minutes and then did an external start. Ammeter showed no current going into the battery. Leaving the alternator on and turning the battery off jumped the voltage up half a volt. So I think my battery is done, the local Odyssey dealer is going to confirm tomorrow morning. Anyway my question is on these automotive voltage regulators, is it possible to adjust the voltage high enough to keep an Odyssey battery happy? Odyssey batteries are happy at that same levels as other svla batteries. The Odyssey manual calls for constant current charging until 14.7 volts is achieved whereupon the votlage is held at 14.7 until recharge current falls to 100mA -OR- 4 hours have elapsed. Nobody charges with that kind of precision in a vehicle. Any automotive regulator that comes on line at 14.3 plus/minus 0.2 volts is going to be entirely satisfactory for your airplane. WAAaaayyy back when, the regulators we put on Cessnas were stock Ford products with a 14.2 plus/minus 0.2 volt setpoing. Your battery only lasted a year? What is the nominal bus voltage for your airplane? Bob . . . ________________________________________________________________________________
July 11, 2017 - August 08, 2017
AeroElectric-Archive.digest.vol-nz
