AeroElectric-Archive.digest.vol-ob
September 04, 2017 - October 05, 2017
Date: Sep 04, 2017
If I were buying a tubing printer, I wouldn't be overly concerned about it 'grabbing' the wire after shrinking. In fact, I wouldn't even worry about shrinking at all, in most cases. If the wire is in a bundle, the label isn't going far, and as long as it can't get past the terminator, it won't get lost. And there will be times when moving the label could have its advantages. Ex: when the printing is on the 'back side' of a wire in a bundle, or aligned with a half-dozen other labels in the bundle. On 9/4/2017 6:55 AM, Art Zemon wrote: > Ah! Google finally surfaced the answer: K-Sun's 1/8" and 3/16" tubing > will hold on 20 AWG tefzel wire. > K-Sun Shrink Tube Instruction Manual > <http://www.ksun.com/wp-content/uploads/2014-ShrinkTube-Instructions.pdf>gives > the wire diameters in mm that each tubing size will fit. > The MIL-W-22759/16 spec20 AWG tefzel wire that I got from Aircraft > Spruce is about 1.74 mm in diameter. > 22 AWG is about 1.34 mm in diameter so K-Sun 1/8" tubing will work on > that, too. > > Assuming that Dymo's 3:1 heat shrink tubing has approximately the same > specs as K-Sun's 3:1 tubing, it will not work as well in my > application. The 1/4" shrinks only to 2.31 mm which is too large for > 20 AWG tefzel wire. (According to the specs. Maybe it will work anyway > but I don't /know/.) > > -- Art Z. > > > On Sun, Sep 3, 2017 at 10:11 PM, Art Zemon > wrote: > > Of the label printers that we have talked about, will the heat > shrink tube labels get small enough to label 20 gauge wire? > > > -- > https://CheerfulCurmudgeon.com/ > > /"If I am not for myself, who is for me? And if I am only for myself, > what am I? And if not now, when?" Hillel/ --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Sep 04, 2017
Subject: Re: Magic marker "robustness"
Epson LW-PX700 On Sep 4, 2017 6:02 AM, wrote: > Don, > > Which Epson printer did you purchase? A model number would be great. > > *From:* don van santen > *Sent:* Sunday, September 03, 2017 11:16 PM > *To:* aeroelectric-list(at)matronics.com > *Subject:* Re: AeroElectric-List: Magic marker "robustness" > > Look into the cost of heat shrink tubing for the printers. I just > purchased an Epson printer that only wastes 1/2 inch of tube per label. My > old K Sun wasted 2 inches per label. If you label both ends of every wire > the extra cost of the Epson printer will be covered by 100 to 150 percent. > > On Sep 3, 2017 7:47 PM, "Rick Beebe" wrote: > >> >> The guy who built my plane in 2000 used blue marker on white heat shrink. >> While some are still legible, most of the ink has blossomed into illegible >> blobs. I'm going to be rewiring the panel this Fall and I'm going to redo >> all those label. I think the investment in a label maker is probably worth >> it. Plus my handwriting is terrible anyway. >> >> --Rick >> =================================== >> - >> Electric-List" rel="noreferrer" target="_blank">http://www. >> matronics.com/Navigator?AeroElectric-List >> =================================== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> ========== >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> ========== >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >> =================================== >> >> >> >> ________________________________________________________________________________
Subject: Re: Non-aero app: 120/240 AC through 24vdc switch?
Date: Sep 04, 2017
DNA What I absolutely love about AEL. Thanks to both of you, Bob and Eric, for piquing my curiosity, making me stretch to expand my knowledge and skill set. The forum is in every way the embodiment of the adage, "Give a man a fish and he eats tonight. Teach him to fish...he and his family eat for a lifetime" I've got some 47 , 3A NTC thermistors I'm going to try, with the idea that I could, inexpensively, make up a bunch of low tech field-repair devices that can be installed with two wire nuts by users. For unshipped units henceforth, I plan to use the AC/AC SSR's until I can find a suitable, beefier power switch. All good things, John [[/b] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472491#472491 ________________________________________________________________________________
Subject: Re: Heat Shrink Labels for 20 AWG Wire
Date: Sep 04, 2017
art(at)zemon.name wrote: > Assuming that Dymo's 3:1 heat shrink tubing has approximately the same specs as K-Sun's 3:1 tubing, it will not work as well in my application. The 1/4" shrinks only to 2.31 mm which is too large for 20 AWG tefzel wire. The Dymo 1/4" heat shrink will shrink down to fit over 24AWG wire. On 22AWG will, you will have to encourage it to move. On 20AWG wire, you will have to really encourage it to move. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472492#472492 ________________________________________________________________________________
Date: Sep 04, 2017
I am confused. K Sun sells many different diameters of tubing. Does Dymo only sell one diameter? On Sep 4, 2017 16:19, "donjohnston" <don@velocity-xl.com> wrote: > don@velocity-xl.com> > > > art(at)zemon.name wrote: > > Assuming that Dymo's 3:1 heat shrink tubing has approximately the same > specs as K-Sun's 3:1 tubing, it will not work as well in my application. > The 1/4" shrinks only to 2.31 mm which is too large for 20 AWG tefzel wire. > > > The Dymo 1/4" heat shrink will shrink down to fit over 24AWG wire. On > 22AWG will, you will have to encourage it to move. On 20AWG wire, you will > have to really encourage it to move. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=472492#472492 > > ________________________________________________________________________________
Date: Sep 04, 2017
1/4=9D 3/8=9D 1/2=9D & 3/4=9D https://smile.amazon.com/DYMO-RHINO-Label-Maker-1801611/dp/B005MR516Y/ref= sr_1_2?ie=UTF8&qid=1504450593&sr=8-2&keywords=dymo+rhino+label+mak er On Sep 4, 2017, at 9:28 PM, don van santen wrote: I am confused. K Sun sells many different diameters of tubing. Does Dymo only sell one diameter? On Sep 4, 2017 16:19, "donjohnston" <don@velocity-xl.com don@velocity-xl.com>> wrote: <don@velocity-xl.com > art(at)zemon.name <http://zemon.name/> wrote: > Assuming that Dymo's 3:1 heat shrink tubing has approximately the same specs as K-Sun's 3:1 tubing, it will not work as well in my application. The 1/4" shrinks only to 2.31 mm which is too large for 20 AWG tefzel wire. The Dymo 1/4" heat shrink will shrink down to fit over 24AWG wire. On 22AWG will, you will have to encourage it to move. On 20AWG wire, you will have to really encourage it to move. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472492#472492 <http://forums.matronics.com/viewtopic.php?p=472492#472492> ________________________________________________________________________________
Date: Sep 04, 2017
Got it. The Epson and K Sun ztaft at 3 mm. Guss I would not recommend the Dymo. On Sep 4, 2017 20:03, "Robert Borger" wrote: > 1/4=9D 3/8=9D 1/2=9D & 3/4=9D > > https://smile.amazon.com/DYMO-RHINO-Label-Maker-1801611/dp/ > B005MR516Y/ref=sr_1_2?ie=UTF8&qid=1504450593&sr=8-2& > keywords=dymo+rhino+label+maker > > On Sep 4, 2017, at 9:28 PM, don van santen wrote : > > I am confused. K Sun sells many different diameters of tubing. > Does Dymo only sell one diameter? > > On Sep 4, 2017 16:19, "donjohnston" <don@velocity-xl.com> wrote: > >> don@velocity-xl.com> >> >> >> art(at)zemon.name wrote: >> > Assuming that Dymo's 3:1 heat shrink tubing has approximately the same >> specs as K-Sun's 3:1 tubing, it will not work as well in my application. >> The 1/4" shrinks only to 2.31 mm which is too large for 20 AWG tefzel wi re. >> >> >> The Dymo 1/4" heat shrink will shrink down to fit over 24AWG wire. On >> 22AWG will, you will have to encourage it to move. On 20AWG wire, you w ill >> have to really encourage it to move. >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=472492#472492 > > ________________________________________________________________________________
Date: Sep 05, 2017
donvansanten(at)gmail.com wrote: > I am confused. K Sun sells many different diameters of tubing.Does Dymo only sell one diameter? They also sell 3/8", 1/2", 3/4" and 1". You were asking about heat shrink tubing that would work on 20AWG wire. The Dymo 1/4" shink tubing works fine on 20AWG. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472506#472506 ________________________________________________________________________________
Date: Sep 05, 2017
Better URL for the DYMO-RHINO shrink-tube: http://tinyurl.com/ydc642nj Jim Parker ________________________________________________________________________________
Date: Sep 05, 2017
At 02:30 PM 9/4/2017, you wrote: > > >DNA > >What I absolutely love about AEL. > >Thanks to both of you, Bob and Eric, for piquing >my curiosity, making me stretch to expand my >knowledge and skill set. The forum is in every >way the embodiment of the adage, "Give a man a >fish and he eats tonight. Teach him to fish...he >and his family eat for a lifetime" > >I've got some 47 =CE=A9, 3A NTC thermistors I'm >going to try, with the idea that I could, >inexpensively, make up a bunch of low tech >field-repair devices that can be installed with >two wire nuts by users. For unshipped units >henceforth, I plan to use the AC/AC SSR's until >I can find a suitable, beefier power switch. 3A? Try to pick an NTC with (1) operating current close to your measured running loads and (2) max applied voltage of 120vac or greater. See this for the nitty-gritty guidelines . . . http://tinyurl.com/yahtoncs Bob . . . ________________________________________________________________________________
Date: Sep 05, 2017
Art, If you go to Gateway Electronics in Maryland Heights, you will walk out with all the clear shrink wrap you need at very low prices. They also have thre e sizes of clear spiral wrap for under the panel work. It is in a room to t he right as you walk in and they cut it for you. Very inexpensive. They also have ready made molex connectors that come in nearly any count. Good luck, Ron Burnett May you have the Lord's blessings today! Sent from my iPad > On Sep 3, 2017, at 10:20 PM, don van santen wrote : > > I label #22 tefzel all the time with the Epson. > >> On Sep 3, 2017 20:18, "Art Zemon" wrote: >> Of the label printers that we have talked about, will the heat shrink tub e labels get small enough to label 20 gauge wire? >> >> -- Art Z. >> >> -- >> https://CheerfulCurmudgeon.com/ >> >> "If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel ________________________________________________________________________________
Subject: Re: Troubleshooting 200G/ Z-17
Date: Sep 05, 2017
All, Just closing the loop on this discussion- after talking with both B&C and Earth-X about this, I began to realize that what I was seeing was normal behavior for this type of setup. I made the first flight of the aircraft a couple weeks ago and now have about five hours of flight data (engine monitor data) to look at. The voltage does start out low but once takeoff power is applied, the voltage slowly climbs to 14.55V over about a minute and remains there for the duration of the flight. I have informed both companies of the outcome. Both have been excellent to deal with- particularly B&C who sent me a new regulator when it initially appeared that it was defective. Hopefully this will help someone else in the future. Regards, Jeff Point Milwaukee On 7/11/17 10:04 PM, Jeff Point wrote: > > All, > > The good news from today is that I successfully ran my freshly > overhauled O-200 today in preparation for a FAA inspection in a few > weeks. The bad news is that I am getting no alternator output at > all. The alternator is a B&C 200G PM dynamo, wired per Z-17 (no > master contactor.) Running the engine between idle and 1800 RPM saw > no change in bus voltage, which stayed at the same 13.1V as it did > with the engine not running. > > Troubleshooting so far- besides checking all wiring connections, I > verified that the OV relay is working and that I wired it correctly. > I verified that the alternator's raw output was as expected (15-25VAC, > increasing with speed.) I measured voltage at the capacitor (just > downstream of the regulator) and it was the same 13.1 and did not vary > with speed. Disconnecting the regulator I verified that there is zero > volts coming out of the regulator, although I understand from the > troubleshooting documents that it must have bus voltage applied in > order to output, so I'm thinking this doesn't mean much. > > Is this as simple as a bad regulator? I'm going to call B & C first > thing tomorrow but I thought I'd check here first. > > Thanks > > Jeff Point > > Milwaukee > > ________________________________________________________________________________
Date: Sep 06, 2017
Subject: Figure Z-35. Non-Cranking (Small) Aux Battery
> > > * Is there an architecture that comes close but > does not meet your design goals? YES. Z-30 and Z-35. What failure modes drive you to believe that you need two batteries? Electrically dependent engine? Do you plan to do preventative maintenance on your battery(ies), i.e. periodic load and cap checks? What will be your criteria for replacement of any battery? Bob . . . ________________________________________________________________________________
Date: Sep 06, 2017
Subject: Re: Non fading black ink
At 05:32 PM 9/3/2017, you wrote: >Most black dies are really dark, dark >blue.=C2 True black, like india ink, consist of >lamp black (carbon) in water or another carrier >and is not a dye but forms a layer of carbon >black on the substrate.=C2 We used to make >aircraft drawings on Vellum that did not fade.=C2 Jurgen Yeah, just missed that. We'd graduated to plastic lead on Mylar at Cessna by the time I started there (1965). Wonder how those drawings look today. Bob . . . ________________________________________________________________________________
Date: Sep 06, 2017
Subject: Re: Wiring PTT Switches
At 05:40 PM 9/3/2017, you wrote: >People often use single strand with shield. > >It's not ultra-critical and will probably work fine as a pair of >wires. The biggest consideration is reducing stress points so it >doesn't break from flexing. > >On Sep 3, 2017, at 6:16 PM, Art Zemon ><art(at)zemon.name> wrote: > >>Folks, >> >>I need advice on how to wire the PTT switches for my plane. Here is >>a bit of the wiring diagram for the PDA360EX audio panel: >> >> >>Clearly I have a shielded cable running from pins 33, 34, 35 on the >>PDA360EX to the microphone jack in the instrument panel. >> >>What do I run to the PTT switch in the grip on the joystick? It >>looks like an unshielded pair of wires to me. PTT wires don't benefit from shielding. Truth be known, there's probably not one mic installation in 100,000 that benefits from shielding. A twisted trio of unshielded would be just fine. You can extend your PTT wiring up the stick on a twisted pair . . . if you want to bring the ground back to the mic jack. If you want to ground the PTT switch inside the grip with other grounded controls, then a single strand to the PTT (tip) contact will do it. If the PTT switch is already connected to a common ground in the grip, then the single strand approach is fine. If you want to run the twisted pair, be sure to DISCONNECT the PTT grip switch from other grip switches . . . Bob . . . ________________________________________________________________________________
Date: Sep 06, 2017
At 09:55 PM 9/5/2017, you wrote: > >All, > >Just closing the loop on this discussion- after talking with both >B&C and Earth-X about this, I began to realize that what I was >seeing was normal behavior for this type of setup. I made the first >flight of the aircraft a couple weeks ago and now have about five >hours of flight data (engine monitor data) to look at. The voltage >does start out low but once takeoff power is applied, the voltage >slowly climbs to 14.55V over about a minute and remains there for >the duration of the flight. Sorry I didn't pick up on that . . . the EarthX battery is a much less compliant current sink than a lead-acid . . . hence willing to take on recharge currents that combine with your system loads to depress alternator output until the battery tops off. I'm working on some new regulator control and voltage monitoring philosophies for future designs . . . designs that I hope will be compatible with both lead-acid and lithium technologies and I've noted the effects you're seeing now. This will be limited to 'small' alternators like the SD8 and 200G and to a lesser degree with the built in PM alternators like Rotax. Bob . . . ________________________________________________________________________________
Date: Sep 06, 2017
In the first section of the article re selecting the right ICL, I'm asked for Capacitance. But neither the ballast nor the power supply list that info on their product cut-sheets. Is there away to deduce the capacitance from other supplied info? E.G., inrush current on PS is 40A @ 250vac. Ballast is 100A @ 120vac Power Supply and Ballast data sheets attached. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472559#472559 Attachments: http://forums.matronics.com//files/wh7_120_l_datasheet_214.pdf http://forums.matronics.com//files/meanwell_rs_100_24_spec_189.pdf ________________________________________________________________________________
Date: Sep 06, 2017
"3A?" The steady state load is about 1A, to keep the ballast happy. There's a user selected load of 1.5A that has a 25 second cycle to open circuit. Often the selection is repeated multiple times in quick succession. So the 3A was to allow a little headroom for motor surge (Does a PM motor have a surge?) and 2.5 steady state. I installed the 3A ICL yesterday and everything seems to work fine with the ICL temp settling at about 145 deg F on my meat thermometer held on with a clothes pin. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472562#472562 ________________________________________________________________________________
Date: Sep 06, 2017
No worries Bob and thanks. We're all still learning about this new LiFePo stuff. Talking with Nathan B at Oshkosh he said he was working on a new regulator design for the PM alternators (might be what you're working on.) I offered to be a beta tester as I have a data recording engine monitor and could possibly gather some useful data. I have data from my last 5 hours that I can provide if you think it would be of any value. It's interesting to look at the voltage rise vs. RPM. There is even a slight rise during runup that I didn't notice while running up, but is clear from the data. Jeff On 9/6/17 1:02 PM, Robert L. Nuckolls, III wrote: > At 09:55 PM 9/5/2017, you wrote: >> >> All, >> >> Just closing the loop on this discussion- after talking with both B&C >> and Earth-X about this, I began to realize that what I was seeing was >> normal behavior for this type of setup. I made the first flight of >> the aircraft a couple weeks ago and now have about five hours of >> flight data (engine monitor data) to look at. The voltage does start >> out low but once takeoff power is applied, the voltage slowly climbs >> to 14.55V over about a minute and remains there for the duration of >> the flight. > > Sorry I didn't pick up on that . . . the EarthX > battery is a much less compliant current sink > than a lead-acid . . . hence willing to take > on recharge currents that combine with your > system loads to depress alternator output until > the battery tops off. > > I'm working on some new regulator control and > voltage monitoring philosophies for future > designs . . . designs that I hope will be > compatible with both lead-acid and lithium > technologies and I've noted the effects you're > seeing now. This will be limited to 'small' > alternators like the SD8 and 200G and to a lesser > degree with the built in PM alternators like > Rotax. > > > Bob . . . > ________________________________________________________________________________
Date: Sep 06, 2017
Subject: Thankful for Clear Documentation
Bob, Just a quick note of thanks. With the wiring diagram for my audio panel complete, I was wondering how to terminate all of the shields. A quick Google search turned up Bob's Shop Notes: Shield Termination Techniques <http://www.aeroelectric.com/articles/pigtail/pigtail.html>, which is exactly what I need. Hat tip to you... and if we're ever in the same place at the same time, I definitely owe you a beer or three. Cheers, -- Art Z. -- https://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
Date: Sep 07, 2017
Subject: TE KILOVAC LEV100 Question
Hello Group! Quick question about the TE LEV100A4ANG contactors, these have two terminals marked A1 and A2, wonder if any one has used these and if there is a preference to use A1 or A2 for supply or load side? Tried calling TE support, but havent heard back from them yet. Also, is it recommended to use the diodes with these contactors for TV suppression? Thanks Hari ________________________________________________________________________________
Date: Sep 07, 2017
Subject: Re: TE KILOVAC LEV100 Question
At 11:26 AM 9/7/2017, you wrote: >Hello Group! > >Quick question about the TE LEV100A4ANG contactors, these have two >terminals marked A1 and A2, wonder if any one has used these and if >there is a preference to use A1 or A2 for supply or load side? Tried >calling TE support, but havent heard back from them yet. > >Also, is it recommended to use the diodes with these contactors for >TV suppression? A1 and A2 are interchangeable. Diode is suggested. The data sheet for this product excerpts as follows: Emacs! A 12 V across 26 ohms is .46 amps. This tells us that unlike some products of this genre', there is no consumption mitigation electronics for the coil power. Hence, a 'barefoot' solenoid winding. Any diode will work. I like the 1N540x series devices for their mechanical robustness. Bob . . . ________________________________________________________________________________
Date: Sep 06, 2017
At 07:58 PM 9/6/2017, you wrote: >No worries Bob and thanks. We're all still learning about this new >LiFePo stuff. > >Talking with Nathan B at Oshkosh he said he was working on a new >regulator design for the PM alternators (might be what you're >working on.) I offered to be a beta tester as I have a data >recording engine monitor and could possibly gather some useful >data. I have data from my last 5 hours that I can provide if you >think it would be of any value. It's interesting to look at the >voltage rise vs. RPM. There is even a slight rise during runup that >I didn't notice while running up, but is clear from the data. > >Jeff Absolutely! Thank you. I'll have a bench-test article that will not be mechanically pure to the production drawings but electronically identical and air worthy. I'd be pleased to exploit your offer. Bob . . . ________________________________________________________________________________
Date: Sep 07, 2017
Subject: Service loop length
See attached photo. For the wires running between radios in my radio stack, how much service loop do I need, 12"-ish? Less? Never having had to work behind the panel of a plane, I could use your thoughts. Thanks, -- Art Z. Sent from my phone. Please excuse brevity and bizarre typos. ________________________________________________________________________________
Subject: Re: Service loop length
Date: Sep 07, 2017
On 9/7/2017 7:24 PM, Art Zemon wrote: > See attached photo. > For the wires running between radios in my radio stack, how much > service loop do I need, 12"-ish? Less? Never having had to work behind > the panel of a plane, I could use your thoughts. > > Thanks, > -- Art Z. > > Sent from my phone. Please excuse brevity and bizarre typos. When you have to, you're not going to like it. Sit in the cockpit & try to imagine what you'll do when you're trying to troubleshoot the one in the middle of the stack. I left enough service loop(s) length to sit the panel on the spar (low wing), face down. Charlie --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Sep 07, 2017
At 09:06 PM 9/7/2017, you wrote: >England > >On 9/7/2017 7:24 PM, Art Zemon wrote: >>See attached photo. >>For the wires running between radios in my >>radio stack, how much service loop do I need, >>12"-ish? Less? Never having had to work behind >>the panel of a plane, I could use your thoughts. >> >>Thanks, >>=C2 =C2 =C2 -- Art Z. >> >>Sent from my phone. Please excuse brevity and bizarre typos. >When you have to, you're not going to like it. >Sit in the cockpit & try to imagine what you'll >do when you're trying to troubleshoot the one in the middle of the stack. > >I left enough service loop(s) length to sit the >panel on the spar (low wing), face down. Did a design study with some guys at Lear to produce one of Leon Davis's 'mini bonanzas' a DA5 if memory serves. We designed a radio module that would hold all the radios that was held into the panel with 6 screws. Take out those screws and all the radios came out together with the interface harness terminated in a D-sub. One could take the whole thing to the bench . . . or use an extension harness to operate the radios out of the panel. This approach let us take proposals from various suppliers or hardware to build the complete stack with only the airplane interface wiring dangling off the back. Installation time on the assembly line was under 40 minutes for the whole avionics package. Bob . . . ________________________________________________________________________________
Date: Sep 08, 2017
Charlie & Bob, Those are interesting ideas.... I had not considered the idea that I might remove the whole radio stack. And reading Charlie's message, I also thought of the situation where I want to add/remove a pin in one of the audio panel connectors. That would sure as heck be easier if I could pull the connector well clear of the panel. What do you suggest I do about the shielded wires for headsets? Connect them directly to the D-sub connectors for the audio panel? Or add another connector near the audio panel so that the whole harness can be assembled outside the plane? -- Art Z. On Thu, Sep 7, 2017 at 10:29 PM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 09:06 PM 9/7/2017, you wrote: > > ceengland7(at)gmail.com> > > On 9/7/2017 7:24 PM, Art Zemon wrote: > > See attached photo. > For the wires running between radios in my radio stack, how much service > loop do I need, 12"-ish? Less? Never having had to work behind the panel of > a plane, I could use your thoughts. > > Thanks, > =C3=82 =C3=82 =C3=82 -- Art Z. > > Sent from my phone. Please excuse brevity and bizarre typos. > > When you have to, you're not going to like it. Sit in the cockpit & try t o > imagine what you'll do when you're trying to troubleshoot the one in the > middle of the stack. > > I left enough service loop(s) length to sit the panel on the spar (low > wing), face down. > > > Did a design study with some guys at Lear > to produce one of Leon Davis's 'mini bonanzas' > a DA5 if memory serves. > > We designed a radio module that would hold all > the radios that was held into the panel with > 6 screws. Take out those screws and all > the radios came out together with the interface > harness terminated in a D-sub. One could take > the whole thing to the bench . . . or use an > extension harness to operate the radios out > of the panel. > > This approach let us take proposals from various > suppliers or hardware to build the complete > stack with only the airplane interface wiring > dangling off the back. > > Installation time on the assembly line was under > 40 minutes for the whole avionics package. > > > Bob . . . > -- https://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
Subject: Re: Aviation related: non electric
From: "weloveflying" <yourordinarybeing(at)gmail.com>
Date: Sep 08, 2017
millner(at)me.com wrote: > Find a VPN service that. Makes you appear to be in Switzerland... then download the video and share withDad > > Sent from my iPhone > > > > On Aug 31, 2017, at 8:40 AM, Janet Amtmann wrote: > > > > This is aviation related but not strictly Aeroelectric. My friend in Switzerland sent me link from Spiegel Online (german news magazine) with a video about the Horten brothers flying wing, the Ho229. I can open all videos except the Horten video, a red notice comes up "this video is not available in your country". Is anyone here on the list enough of a hacker to understand why this is, and is there a way around this? My father knew one of the Hortens and I would like to watch this video instead of having to travel to Switzerland to view it. > > > > Jrgen > > > > > +1 for glastar's answer. VPN service is the best way you can get around that. The said service is used by individuals who are looking to access something that is restricted in their country, and as long as you're not doing anything illegal in this case, there's none you'll be fine. There are a lot of companies which offer VPN services, and it is recommended to go for paid services rather than free services for security reasons. You can also consider TOR browser, a browser which lets you browse the web anonymously I haven't tried using the said browser, so I can't give you details about it. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472620#472620 ________________________________________________________________________________
Subject: Wiper motors question
Date: Sep 08, 2017
*Newbie Question/First Thread* I'm just wondering what kind of motors are used for wipers; are they servo motors, like this one: SM110 Motor Series (http://www.powerjackmotion.com/product/sm110-motor-series/), or are they just simply wiper motors, which are powered by a universal, electric motors? My hunch tells me that servo motors are the ones that are behind it, which is of course based on my understanding of a servo's function; nevertheless, it's just my hunch. Your thoughts are very much welcome! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472629#472629 ________________________________________________________________________________
Date: Sep 08, 2017
Art, I'll send some pictures later but on my BD-4 I have panels in the side of the fuselage forward of the instrument panel so that I can get at the back of the panel very easily and quickly. Also my panel is in three pieces: Flight instruments, radios, and right side. The flight instrument side has a small amount of service loop but if I have to take the whole panel out I usually undo from the back side first. The radio stack is all trays so no service loops. On Fri, Sep 8, 2017 at 3:49 AM, Art Zemon wrote: > Charlie & Bob, > > Those are interesting ideas.... I had not considered the idea that I migh t > remove the whole radio stack. And reading Charlie's message, I also thoug ht > of the situation where I want to add/remove a pin in one of the audio pan el > connectors. That would sure as heck be easier if I could pull the connect or > well clear of the panel. > > What do you suggest I do about the shielded wires for headsets? Connect > them directly to the D-sub connectors for the audio panel? Or add another > connector near the audio panel so that the whole harness can be assembled > outside the plane? > > -- Art Z. > > > On Thu, Sep 7, 2017 at 10:29 PM, Robert L. Nuckolls, III < > nuckolls.bob(at)aeroelectric.com> wrote: > >> At 09:06 PM 9/7/2017, you wrote: >> >> ceengland7(at)gmail.com> >> >> On 9/7/2017 7:24 PM, Art Zemon wrote: >> >> See attached photo. >> For the wires running between radios in my radio stack, how much service >> loop do I need, 12"-ish? Less? Never having had to work behind the panel of >> a plane, I could use your thoughts. >> >> Thanks, >> =C3=82 =C3=82 =C3=82 -- Art Z. >> >> Sent from my phone. Please excuse brevity and bizarre typos. >> >> When you have to, you're not going to like it. Sit in the cockpit & try >> to imagine what you'll do when you're trying to troubleshoot the one in the >> middle of the stack. >> >> I left enough service loop(s) length to sit the panel on the spar (low >> wing), face down. >> >> >> >> Did a design study with some guys at Lear >> to produce one of Leon Davis's 'mini bonanzas' >> a DA5 if memory serves. >> >> We designed a radio module that would hold all >> the radios that was held into the panel with >> 6 screws. Take out those screws and all >> the radios came out together with the interface >> harness terminated in a D-sub. One could take >> the whole thing to the bench . . . or use an >> extension harness to operate the radios out >> of the panel. >> >> This approach let us take proposals from various >> suppliers or hardware to build the complete >> stack with only the airplane interface wiring >> dangling off the back. >> >> Installation time on the assembly line was under >> 40 minutes for the whole avionics package. >> >> >> Bob . . . >> > > > -- > https://CheerfulCurmudgeon.com/ > > *"If I am not for myself, who is for me? And if I am only for myself, wha t > am I? And if not now, when?" Hillel* > ________________________________________________________________________________
Subject: Re: Wiper motors question
Date: Sep 08, 2017
A simple DC motor spins at high speed. It drives a worm gear that greatly reduces speed while multiplying torque. The gear train turns an arm or cam with an eccentric lobe or pin, which makes the wiper arm oscillate. Much cheaper and easier to implement than a stepper or servo motor, as no complex motor drive circuitry is required. See attached exploded diagram. Eric Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472653#472653 Attachments: http://forums.matronics.com//files/wipermotor_157.gif ________________________________________________________________________________
Subject: Manual intercom PTT
Date: Sep 08, 2017
Listers, My new Breezy is a high noise aircraft, to put it mildly. I have good a good ANR headset to control the noise but I'm struggling with the intercom (MGL V6) and even at the highest VOX settings, the wind noise overpowers the intercom squelch, resulting in a near-continuous open intercom. To address this, I'm considering adding a momentary switch into the microphone wiring to act as a sort of manual squelch/ PTT for the intercom. It will still be noisy, but will only while talking with the switch activated. Taken a step further, I might use a DPDT mom-off-mom type switch so that one position enables the mic (intercom) and the other enables the mic and the radio PTT (transmit.) Has anyone implemented such a design as a way of dealing with a high noise situation? Is there any reason why this idea wouldn't work? Thanks Jeff Point Milwaukee ________________________________________________________________________________
Subject: Re: Manual intercom PTT
Date: Sep 08, 2017
Are you certain there are no issues with the wind noise interfering with the ANR and making it more noisy? That could sound like an open mic, possibly. I invite others to comment on this, but I believe you could just ground the mic terminal to silence it. There is mic bias voltage on that pin that powers the microphone capsule, but it should run through enough resistance inside the radio that this should be no problem. If that makes you uncomfortable, shorting it through a capacitor should be fine as well. In that case, youd want a 1M resistor across the shorting switch to keep the capacitor charged to prevent a big POP when the switch is thrown. You could get some version of that done with a DPDT like you described. > On Sep 8, 2017, at 7:17 PM, Jeff Point wrote: > > > Listers, > > My new Breezy is a high noise aircraft, to put it mildly. I have good a good ANR headset to control the noise but I'm struggling with the intercom (MGL V6) and even at the highest VOX settings, the wind noise overpowers the intercom squelch, resulting in a near-continuous open intercom. > > To address this, I'm considering adding a momentary switch into the microphone wiring to act as a sort of manual squelch/ PTT for the intercom. It will still be noisy, but will only while talking with the switch activated. Taken a step further, I might use a DPDT mom-off-mom type switch so that one position enables the mic (intercom) and the other enables the mic and the radio PTT (transmit.) > > Has anyone implemented such a design as a way of dealing with a high noise situation? Is there any reason why this idea wouldn't work? > > Thanks > > Jeff Point > > Milwaukee > > > > ________________________________________________________________________________
Date: Sep 08, 2017
I don't have a particularly noisy cockpit but I do use a flight tech intercom which uses a full time microphone noise suppressor chip from the telephone industry to cancel mic noise in noisy and open cockpits. It seems to ignore anything other than my voice effectively and is the only intercom I've ever been completely happy with. http://www.flighttech.com/ Ken On Fri, Sep 8, 2017 at 8:17 PM, Jeff Point wrote: > > Listers, > > My new Breezy is a high noise aircraft, to put it mildly. I have good a > good ANR headset to control the noise but I'm struggling with the intercom > (MGL V6) and even at the highest VOX settings, the wind noise overpowers > the intercom squelch, resulting in a near-continuous open intercom. > > To address this, I'm considering adding a momentary switch into the > microphone wiring to act as a sort of manual squelch/ PTT for the > intercom. It will still be noisy, but will only while talking with the > switch activated. Taken a step further, I might use a DPDT mom-off-mom > type switch so that one position enables the mic (intercom) and the other > enables the mic and the radio PTT (transmit.) > > Has anyone implemented such a design as a way of dealing with a high noise > situation? Is there any reason why this idea wouldn't work? > > Thanks > > Jeff Point > > Milwaukee > > ________________________________________________________________________________
Date: Sep 08, 2017
At 07:17 PM 9/8/2017, you wrote: > >Listers, > >My new Breezy is a high noise aircraft, to put it mildly. I have >good a good ANR headset to control the noise but I'm struggling with >the intercom (MGL V6) and even at the highest VOX settings, the wind >noise overpowers the intercom squelch, resulting in a >near-continuous open intercom. Mic selection is tricky. Noise abatement falls into two categories: Ambient noise that equally impinges on both sides of the microphone's diaphragm and wind noise which is a manifestation of turbulence over the mic enclosure openings . . . which can NEVER be equal and opposite to each side of the mic . . . hence no noise canceling. Airplane radios of the 30's and 40's had a similar problem. The airplanes were very noisy and there was no practical way to do the dual-port cartridge to reduce ambient noise. Aircraft mics of this era typically had one or perhaps three small holes which served as a simple, noise attenuator. To be understood, you put your lips to the microphone's face cup. Those WWII movies with John Wayne hollering over the radio with a microphone 10 inches from his face were a bit laughable. Emacs! Intercom and radio systems in high noise environments often feature 'throat microphones' . . . a simple elastic strap that held two carbon cartridges against the throat, one on each side of the larynx. These cartridges had no holes . . . they literally converted mechanical vibrations to their electrical analogs. One of these products might be ideal for the Breezy application. Unless your fly with your mouth open to the slipstream, they'll pick up no ambient or wind nose whatsoever. http://tinyurl.com/yclr8szt Bob . . . ________________________________________________________________________________
Date: Sep 08, 2017
On 9/8/2017 7:17 PM, Jeff Point wrote: > > Listers, > > My new Breezy is a high noise aircraft, to put it mildly. I have good > a good ANR headset to control the noise but I'm struggling with the > intercom (MGL V6) and even at the highest VOX settings, the wind noise > overpowers the intercom squelch, resulting in a near-continuous open > intercom. > > To address this, I'm considering adding a momentary switch into the > microphone wiring to act as a sort of manual squelch/ PTT for the > intercom. It will still be noisy, but will only while talking with > the switch activated. Taken a step further, I might use a DPDT > mom-off-mom type switch so that one position enables the mic > (intercom) and the other enables the mic and the radio PTT (transmit.) > > Has anyone implemented such a design as a way of dealing with a high > noise situation? Is there any reason why this idea wouldn't work? > > Thanks > > Jeff Point > > Milwaukee Probably not what you want to hear (pardon the pun), but if the noise is bad enough to always break squelch, then all you'll accomplish is silencing the noise between uses. The intercom and transmit functions will still be useless. Might as well get a receive-only scanner radio & ditch the intercom. Any way to keep the wind off the mic? That's likely the problem; not overall noise. If not, extreme measures could be a throat mic. --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Sep 08, 2017
Oregon Aero sells a mic cover for use in open cockpit ac. They claim it helps. PS Engineerig also recomends it. I have not used/needed it so I can't speak to efficiency but it a cheep possible fix. On Sep 8, 2017 18:30, "Charlie England" wrote: > ceengland7(at)gmail.com> > > On 9/8/2017 7:17 PM, Jeff Point wrote: > >> >> Listers, >> >> My new Breezy is a high noise aircraft, to put it mildly. I have good a >> good ANR headset to control the noise but I'm struggling with the intercom >> (MGL V6) and even at the highest VOX settings, the wind noise overpowers >> the intercom squelch, resulting in a near-continuous open intercom. >> >> To address this, I'm considering adding a momentary switch into the >> microphone wiring to act as a sort of manual squelch/ PTT for the >> intercom. It will still be noisy, but will only while talking with the >> switch activated. Taken a step further, I might use a DPDT mom-off-mom >> type switch so that one position enables the mic (intercom) and the other >> enables the mic and the radio PTT (transmit.) >> >> Has anyone implemented such a design as a way of dealing with a high >> noise situation? Is there any reason why this idea wouldn't work? >> >> Thanks >> >> Jeff Point >> >> Milwaukee >> > Probably not what you want to hear (pardon the pun), but if the noise is > bad enough to always break squelch, then all you'll accomplish is silencing > the noise between uses. The intercom and transmit functions will still be > useless. Might as well get a receive-only scanner radio & ditch the > intercom. > > Any way to keep the wind off the mic? That's likely the problem; not > overall noise. If not, extreme measures could be a throat mic. > > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus > > ________________________________________________________________________________
Date: Sep 08, 2017
I contacted the manufacturer of the headset I use, describing a similar problem with the rear-seat position in my Citabria when I fly with the window open for ventilation. He suggested a leather "sleeve" over the mike, with three small holes (the size of a pencil lead) on the side of the mike that touches your lips. You put the sleeve on over the foam cover, and that eliminates a LOT of the wind noise that is breaking the squelch. Good luck! Jim Parker ________________________________________________________________________________
Date: Sep 08, 2017
Actually that's really all I'm trying to do. The transmit quality is acceptable (scratchy but readable as reported by tower.) It's just that the noise from the constantly open mic on the intercom is annoying. I do have the Oregon Aero mic muff and that hasn't fixed it. Those help in a high-noise environment (like my RV-6) but are overpowered in an extreme noise environment like the Breezy. Jeff ---- Charlie England wrote: > Probably not what you want to hear (pardon the pun), but if the noise is > bad enough to always break squelch, then all you'll accomplish is > silencing the noise between uses. The intercom and transmit functions > will still be useless. Might as well get a receive-only scanner radio & > ditch the intercom. > > Any way to keep the wind off the mic? That's likely the problem; not > overall noise. If not, extreme measures could be a throat mic. > > > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus > > > > ________________________________________________________________________________
Date: Sep 08, 2017
The ANR works fine- this is definitely an open mic caused by wind noise. What would be the advantage of grounding the mic voltage vs. just opening it up completely? It's s horse apiece to wire it either way. Jeff ---- Daniel Hooper wrote: > > Are you certain there are no issues with the wind noise interfering with the ANR and making it more noisy? > > That could sound like an open mic, possibly. > > > I invite others to comment on this, but I believe you could just ground the mic terminal to silence it. There is mic bias voltage on that pin that powers the microphone capsule, but it should run through enough resistance inside the radio that this should be no problem. > > If that makes you uncomfortable, shorting it through a capacitor should be fine as well. In that case, youd want a 1M resistor across the shorting switch to keep the capacitor charged to prevent a big POP when the switch is thrown. > > You could get some version of that done with a DPDT like you described. ________________________________________________________________________________
Date: Sep 08, 2017
> > What would be the advantage of grounding the mic voltage vs. just opening it up completely? It's s horse apiece to wire it either way. With the grounding method you could wire it anywhere in the system as an add-in, but if you break the mic connection you *have to* wire it in series with the headset. ________________________________________________________________________________
Date: Sep 09, 2017
That's an interesting idea, and for the price I will pick one up to play with it. Many of them also have foam earplug-type earphones ala Clarity Aloft... and are designed to fit under helmets anyway... now if I can just get the impedances to match up. Jeff On 9/8/17 8:07 PM, Robert L. Nuckolls, III wrote: > > One of these products might be ideal for the Breezy application. > Unless your fly with your mouth open to the slipstream, > they'll pick up no ambient or wind nose whatsoever. > > http://tinyurl.com/yclr8szt > > > <http://tinyurl.com/yclr8szt> > > Bob . . . > ________________________________________________________________________________
Date: Sep 09, 2017
The 'best' solution is to get a high noise intercom like the PS Engineering PM1200 or similar (that we often use in P-51's or B-25's, and other open cockpit aircraft) or other slightly better intercom that has a PTT (Push to Talk) that actually has two PTT switches (one for intercom PTT and the other for transmit PTT) as well as having a very powerful squelch circuit meant for high noise enviornments. The MGL would not be my first choice... Just my 2 cents as usual! Cheers, Stein -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of jpoint(at)wi.rr.com Sent: Friday, September 08, 2017 9:19 PM Subject: Re: AeroElectric-List: Manual intercom PTT The ANR works fine- this is definitely an open mic caused by wind noise. What would be the advantage of grounding the mic voltage vs. just opening it up completely? It's s horse apiece to wire it either way. Jeff ---- Daniel Hooper wrote: > --> > > Are you certain there are no issues with the wind noise interfering with the ANR and making it more noisy? > > That could sound like an open mic, possibly. > > > I invite others to comment on this, but I believe you could just ground the mic terminal to silence it. There is mic bias voltage on that pin that powers the microphone capsule, but it should run through enough resistance inside the radio that this should be no problem. > > If that makes you uncomfortable, shorting it through a capacitor should be fine as well. In that case, youd want a 1M resistor across the shorting switch to keep the capacitor charged to prevent a big POP when the switch is thrown. > > You could get some version of that done with a DPDT like you described. ________________________________________________________________________________
Date: Sep 09, 2017
I made a mic cover from a battery terminal cover and some porous foam. Helped with the wind noise in my trike. Rick Girard On Sat, Sep 9, 2017 at 9:59 AM, Stein Bruch wrote: m > > > > The 'best' solution is to get a high noise intercom like the PS > Engineering PM1200 or similar (that we often use in P-51's or B-25's, and > other open cockpit aircraft) or other slightly better intercom that has a > PTT (Push to Talk) that actually has two PTT switches (one for intercom P TT > and the other for transmit PTT) as well as having a very powerful squelch > circuit meant for high noise enviornments. > > The MGL would not be my first choice... > > Just my 2 cents as usual! > > Cheers, > Stein > > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com [mailto: > owner-aeroelectric-list-server(at)matronics.com] On Behalf Of > jpoint(at)wi.rr.com > Sent: Friday, September 08, 2017 9:19 PM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Manual intercom PTT > > > The ANR works fine- this is definitely an open mic caused by wind noise. > > What would be the advantage of grounding the mic voltage vs. just opening > it up completely? It's s horse apiece to wire it either way. > > Jeff > > ---- Daniel Hooper wrote: > > --> > > > > Are you certain there are no issues with the wind noise interfering wit h > the ANR and making it more noisy? > > > > That could sound like an open mic, possibly. > > > > > > I invite others to comment on this, but I believe you could just ground > the mic terminal to silence it. There is mic bias voltage on that pin tha t > powers the microphone capsule, but it should run through enough resistanc e > inside the radio that this should be no problem. > > > > If that makes you uncomfortable, shorting it through a capacitor should > be fine as well. In that case, you=99d want a 1M resistor across th e shorting > switch to keep the capacitor charged to prevent a big POP when the switch > is thrown. > > > > You could get some version of that done with a DPDT like you described. > > =========== =========== =========== =========== =========== > > -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> ________________________________________________________________________________
Date: Sep 09, 2017
My guess (based on having used one as a trim motor) is that most of them are dumb motors governed by external inputs like limit switches and timers....BWTHDIK Best... Bob Verwey 082 331 2727 On 8 September 2017 at 18:14, weloveflying wrote: > yourordinarybeing(at)gmail.com> > > *Newbie Question/First Thread* > > I'm just wondering what kind of motors are used for wipers; are they servo > motors, like this one: SM110 Motor Series (http://www.powerjackmotion. > com/product/sm110-motor-series/), or are they just simply wiper motors, > which are powered by a universal, electric motors? > > My hunch tells me that servo motors are the ones that are behind it, which > is of course based on my understanding of a servo's function; nevertheless, > it's just my hunch. > > Your thoughts are very much welcome! > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=472629#472629 > > ________________________________________________________________________________
Date: Sep 09, 2017
Subject: Re: Alternators - To Fuse or not to fuse - That
IS the question A few weeks (?) ago, Bob posted a link to a Harbor Freight 500 Amp Carbon Pile Load Tester: https://www.harborfreight.com/500-amp-carbon-pile-load-tester-91129.html I thought that this is what we would use to annually test the capacity of our batteries. I thought that we would connect the battery, set the amps to our expected load (for example, 12 amps) and then time how long until battery voltage reaches an unacceptably low level. But, upon reviewing the user manual for this tool, it does not look like that is what this thing is for. It appears to just load the battery for a short period of time and then extrapolate the battery condition based on how it behaves for that very short test period. What's the deal? How do we use this tool to check on our battery condition, annually? Ken ________________________________________________________________________________
Date: Sep 09, 2017
IS the question Ken, The device tbat would test the battery the way you thought is a West Mountain CBA. The carbon pile is set at a much higher amp rate and draws the battery down very fast. You still get capacity by comparing amps extracted per unit of time. On Sep 9, 2017 09:26, "Ken Ryan" wrote: > A few weeks (?) ago, Bob posted a link to a Harbor Freight 500 Amp Carbon > Pile Load Tester: > > https://www.harborfreight.com/500-amp-carbon-pile-load-tester-91129.html > > I thought that this is what we would use to annually test the capacity of > our batteries. I thought that we would connect the battery, set the amps to > our expected load (for example, 12 amps) and then time how long until > battery voltage reaches an unacceptably low level. > > But, upon reviewing the user manual for this tool, it does not look like > that is what this thing is for. It appears to just load the battery for a > short period of time and then extrapolate the battery condition based on > how it behaves for that very short test period. > > What's the deal? How do we use this tool to check on our battery > condition, annually? > > Ken > > ________________________________________________________________________________
Date: Sep 09, 2017
IS the question Don, Thanks for the West Mountain CBA info. One possible problem I see with using the carbon pile is that the algorithms used to derive capacity are probably based on lead acid batteries, not LiFePO batteries. Aren't the discharge characteristics of Li batteries radically different from lead acid batteries? Ken On Sat, Sep 9, 2017 at 8:42 AM, don van santen wrote: > Ken, > The device tbat would test the battery the way you thought is a West > Mountain CBA. The carbon pile is set at a much higher amp rate and draws > the battery down very fast. You still get capacity by comparing amps > extracted per unit of time. > > On Sep 9, 2017 09:26, "Ken Ryan" wrote: > >> A few weeks (?) ago, Bob posted a link to a Harbor Freight 500 Amp Carbon >> Pile Load Tester: >> >> https://www.harborfreight.com/500-amp-carbon-pile-load-tester-91129.html >> >> I thought that this is what we would use to annually test the capacity of >> our batteries. I thought that we would connect the battery, set the amps to >> our expected load (for example, 12 amps) and then time how long until >> battery voltage reaches an unacceptably low level. >> >> But, upon reviewing the user manual for this tool, it does not look like >> that is what this thing is for. It appears to just load the battery for a >> short period of time and then extrapolate the battery condition based on >> how it behaves for that very short test period. >> >> What's the deal? How do we use this tool to check on our battery >> condition, annually? >> >> Ken >> >> ________________________________________________________________________________
Date: Sep 09, 2017
IS the question The discharge characteristics are not dirrerent enough to cause a problem using the carbon pile. If you try the pile be careful, they get quite hot. I prefer to use the CBA, but it takes many hours to discharge to 10 volts. On Sep 9, 2017 10:42 AM, "Ken Ryan" wrote: > Don, > Thanks for the West Mountain CBA info. One possible problem I see with > using the carbon pile is that the algorithms used to derive capacity are > probably based on lead acid batteries, not LiFePO batteries. Aren't the > discharge characteristics of Li batteries radically different from lead > acid batteries? > Ken > > On Sat, Sep 9, 2017 at 8:42 AM, don van santen > wrote: > >> Ken, >> The device tbat would test the battery the way you thought is a West >> Mountain CBA. The carbon pile is set at a much higher amp rate and draws >> the battery down very fast. You still get capacity by comparing amps >> extracted per unit of time. >> >> On Sep 9, 2017 09:26, "Ken Ryan" wrote: >> >>> A few weeks (?) ago, Bob posted a link to a Harbor Freight 500 Amp >>> Carbon Pile Load Tester: >>> >>> https://www.harborfreight.com/500-amp-carbon-pile-load-tester-91129.html >>> >>> I thought that this is what we would use to annually test the capacity >>> of our batteries. I thought that we would connect the battery, set the amps >>> to our expected load (for example, 12 amps) and then time how long until >>> battery voltage reaches an unacceptably low level. >>> >>> But, upon reviewing the user manual for this tool, it does not look like >>> that is what this thing is for. It appears to just load the battery for a >>> short period of time and then extrapolate the battery condition based on >>> how it behaves for that very short test period. >>> >>> What's the deal? How do we use this tool to check on our battery >>> condition, annually? >>> >>> Ken >>> >>> > ________________________________________________________________________________
Date: Sep 09, 2017
IS the question Well, an single SLA has very different amp-hour ratings depending on the discharge rate. And 'consumer' SLAs (PC680, etc that were originally intended for watercraft, and others that some of us use that were intended for UPSs and/or electric carts, etc) are rated differently from the certified a/c SLAs, if I've read spec sheets correctly. The most common LiFePO discussed here claims to maintain its rated AH output at the AH number for one hour. The consumer SLAs most of us are using won't do that; they'll only go for about 40% of their rating if loaded to the max. Some of the early offerings for starting batteries using lithium chemistry wouldn't go for more than a few minutes at their full labeled rating. But maybe if all are only loaded for a small number of seconds, you can still derive useful info. Is that really the case? On Sat, Sep 9, 2017 at 1:21 PM, don van santen wrote: > The discharge characteristics are not dirrerent enough to cause a problem > using the carbon pile. If you try the pile be careful, they get quite hot. > I prefer to use the CBA, but it takes many hours to discharge to 10 volts. > > On Sep 9, 2017 10:42 AM, "Ken Ryan" wrote: > >> Don, >> Thanks for the West Mountain CBA info. One possible problem I see with >> using the carbon pile is that the algorithms used to derive capacity are >> probably based on lead acid batteries, not LiFePO batteries. Aren't the >> discharge characteristics of Li batteries radically different from lead >> acid batteries? >> Ken >> >> On Sat, Sep 9, 2017 at 8:42 AM, don van santen >> wrote: >> >>> Ken, >>> The device tbat would test the battery the way you thought is a West >>> Mountain CBA. The carbon pile is set at a much higher amp rate and draws >>> the battery down very fast. You still get capacity by comparing amps >>> extracted per unit of time. >>> >>> On Sep 9, 2017 09:26, "Ken Ryan" wrote: >>> >>>> A few weeks (?) ago, Bob posted a link to a Harbor Freight 500 Amp >>>> Carbon Pile Load Tester: >>>> >>>> https://www.harborfreight.com/500-amp-carbon-pile-load-teste >>>> r-91129.html >>>> >>>> I thought that this is what we would use to annually test the capacity >>>> of our batteries. I thought that we would connect the battery, set the amps >>>> to our expected load (for example, 12 amps) and then time how long until >>>> battery voltage reaches an unacceptably low level. >>>> >>>> But, upon reviewing the user manual for this tool, it does not look >>>> like that is what this thing is for. It appears to just load the battery >>>> for a short period of time and then extrapolate the battery condition based >>>> on how it behaves for that very short test period. >>>> >>>> What's the deal? How do we use this tool to check on our battery >>>> condition, annually? >>>> >>>> Ken >>>> >>>> >> ________________________________________________________________________________
Date: Sep 09, 2017
IS the question The first test (new batt) is the baseline. Latter tests let you see performance dropoff. So yes you an obtain useful information even though the device dors not perfectly match the batteries discharge characteristics. Again, I prefer the West Mountain CBA, even if it takes 10 hours per test. On Sep 9, 2017 13:29, "Charlie England" wrote: > Well, an single SLA has very different amp-hour ratings depending on the > discharge rate. And 'consumer' SLAs (PC680, etc that were originally > intended for watercraft, and others that some of us use that were intended > for UPSs and/or electric carts, etc) are rated differently from the > certified a/c SLAs, if I've read spec sheets correctly. > > The most common LiFePO discussed here claims to maintain its rated AH > output at the AH number for one hour. The consumer SLAs most of us are > using won't do that; they'll only go for about 40% of their rating if > loaded to the max. Some of the early offerings for starting batteries using > lithium chemistry wouldn't go for more than a few minutes at their full > labeled rating. > > But maybe if all are only loaded for a small number of seconds, you can > still derive useful info. Is that really the case? > > On Sat, Sep 9, 2017 at 1:21 PM, don van santen > wrote: > >> The discharge characteristics are not dirrerent enough to cause a problem >> using the carbon pile. If you try the pile be careful, they get quite hot. >> I prefer to use the CBA, but it takes many hours to discharge to 10 volts. >> >> On Sep 9, 2017 10:42 AM, "Ken Ryan" wrote: >> >>> Don, >>> Thanks for the West Mountain CBA info. One possible problem I see with >>> using the carbon pile is that the algorithms used to derive capacity are >>> probably based on lead acid batteries, not LiFePO batteries. Aren't the >>> discharge characteristics of Li batteries radically different from lead >>> acid batteries? >>> Ken >>> >>> On Sat, Sep 9, 2017 at 8:42 AM, don van santen >>> wrote: >>> >>>> Ken, >>>> The device tbat would test the battery the way you thought is a West >>>> Mountain CBA. The carbon pile is set at a much higher amp rate and draws >>>> the battery down very fast. You still get capacity by comparing amps >>>> extracted per unit of time. >>>> >>>> On Sep 9, 2017 09:26, "Ken Ryan" wrote: >>>> >>>>> A few weeks (?) ago, Bob posted a link to a Harbor Freight 500 Amp >>>>> Carbon Pile Load Tester: >>>>> >>>>> https://www.harborfreight.com/500-amp-carbon-pile-load-teste >>>>> r-91129.html >>>>> >>>>> I thought that this is what we would use to annually test the capacity >>>>> of our batteries. I thought that we would connect the battery, set the amps >>>>> to our expected load (for example, 12 amps) and then time how long until >>>>> battery voltage reaches an unacceptably low level. >>>>> >>>>> But, upon reviewing the user manual for this tool, it does not look >>>>> like that is what this thing is for. It appears to just load the battery >>>>> for a short period of time and then extrapolate the battery condition based >>>>> on how it behaves for that very short test period. >>>>> >>>>> What's the deal? How do we use this tool to check on our battery >>>>> condition, annually? >>>>> >>>>> Ken >>>>> >>>>> >>> > ________________________________________________________________________________
Date: Sep 10, 2017
Subject: Battery Load Testing
At 11:20 AM 9/9/2017, you wrote: >A few weeks (?) ago, Bob posted a link to a Harbor Freight 500 Amp >Carbon Pile Load Tester: > >https://www.harborfreight.com/500-amp-carbon-pile-load-tester-91129.html > >I thought that this is what we would use to annually test the >capacity of our batteries. I thought that we would connect the >battery, set the amps to our expected load (for example, 12 amps) >and then time how long until battery voltage reaches an unacceptably low level. > >But, upon reviewing the user manual for this tool, it does not look >like that is what this thing is for. It appears to just load the >battery for a short period of time and then extrapolate the battery >condition based on how it behaves for that very short test period. > >What's the deal? How do we use this tool to check on our battery >condition, annually? It is one of TWO tests, and the least $time$ consuming of the two. There are two qualities of a battery that described its performance. One is internal resistance, the ability to DELIVER what ever energy is contained to the outside world. This quality goes to getting the engine started and is loosely linked to overall quality of the battery . . . a battery whose internal resistance is rising is loosing active material . . . active material is directly related to the second quality of interest: CAPACITY. To capcheck a battery, you need to literally run it down with some load that approximates your anticipated ENDURANCE requirements. Then track how many minutes that load is supported. There are test sets that do this automatically and give you data plots. Here's one such device http://tinyurl.com/mas7ea9 I've had these in the shop for over a decade. Very handy. This tool produces data plots like this: Emacs! This was a new battery in installed in Dr. Dee's Saturn just over two years ago. With a 5a load, it produced just over 32 a.h. of energy output. I just replace that battery yesterday . . . it had suffered a couple of run-down- and-sit events . . . the worst thing you can do to a battery. The new one is sitting in the garage with a Battery Tender on it like my lab batteries. The HF load tester is the quick'n dirty battery evaluator. When you install a NEW battery. Make sure it's topped off (Go flying for an hour). After landing, put the load tester on, start the timer (15 seconds) and quickly crank the knob up until the voltage FALLS to 9 volts. Adjust the knob to maintain the 9v reading until the timer light goes out. Then quickly observe and record the CURRENT being delivered. Repeating this test at intervals will reveal a slow decline in that current reading. When it falls to 75% of new, then about 1/4th of the battery's chemistry has become inactive. Now, if you subscribe to the legacy notion of replacement at 75-80% of new capacity, then you know when to do it based on this admittedly coarser measurement. But if you'd care to do a ground check on ENDURANCE then you need something like the West Mountain Radio instrument -OR- you simply set up an ENDURANCE mode load scenario in the hangar and watch a voltmeter. When the voltage drops to 11.0 volts the battery is 90+ percent used up. If that TIME does not meet our exceed your personal design goals for alternator-out operations, THEN is when you replace the battery. Bob . . . ________________________________________________________________________________
Date: Sep 10, 2017
At 11:06 AM 9/9/2017, you wrote: >My guess (based on having used one as a trim motor) is that most of >them are dumb motors governed by external inputs like limit switches >and timers....BWTHDIK Correct, these are just DC motors with two or more speed select features (brushes offset from optimum torque position) or taps on series field windings (only in the nearly antique, electric motors). There are numerous articles on the 'net for using these motors in amateur robotics and other DIY situations . . . they are cheap and robust . . . but quite dumb. They have a servo-like behavior in their ability to 'park' the wiper blades but this is a simple limit switch mechanism. Bob . . . ________________________________________________________________________________
Date: Sep 10, 2017
IS the question At 12:35 PM 9/9/2017, you wrote: >Don, >Thanks for the West Mountain CBA info. One possible problem I see >with using the carbon pile is that the algorithms used to derive >capacity are probably based on lead acid batteries, not LiFePO >batteries. Aren't the discharge characteristics of Li batteries >radically different from lead acid batteries? Yes. You can use the load tester on LiPo but I'm uncertain as to the target voltage for the test. 9v may be too low . . . but certainly 10v would not hurt it. The load test for battery performance is a COMPARATIVE activity that looks as changes over time staring with the new battery. You won't find useful data or algorithms that equate load number to capacity values. This is like using a dip stick in the oil pan . . . you don't know the capacity of the pan . . . only how much it has dropped from full. Bob . . . ________________________________________________________________________________
Date: Sep 10, 2017
IS the question At 01:21 PM 9/9/2017, you wrote: >The discharge characteristics are not dirrerent enough to cause a >problem using the carbon pile. If you try the pile be careful, they >get quite hot. I prefer to use the CBA, but it takes many hours to >discharge to 10 volts. Yes . . . because these are entirely different kinds of tests. The carbon pile tester does get hot . . . it will stink at the end of your test. 5-600 amps at 9v is 5400 watts . . . enough snort to run your house. This energy is dumped into that little stack of carbon disks. http://tinyurl.com/ybcc9v9r Emacs! So yes, extending the test beyond 15 seconds is probably not a good thing to do! The CBA test gets you a whole different set of data. It counts electrons under a specified load (your ENDURANCE load) and measures the time that load will be supported. A much more precise measurement of the battery's ability to perform in alternator-out conditions. Another alternative is Z13/8. Here there is no plan B that calls for tapping the battery during main alternator out conditions. Hence, you replace the battery at first sign of sluggish cranking performance (the crudest form of a load test). This is why I've long suggested that Z13/8 is the lowest cost of ownership, highest reliability system you can install on your a/c. No test equipment, no preventative maintenance, run the battery 'til it wheezes. How much simpler can it get? Bob . . . ________________________________________________________________________________
Date: Sep 10, 2017
=C2- The HF load tester is the quick'n dirty battery evaluator. =C2- When you install a NEW battery. Make sure it's topped off =C2- (Go flying for an hour).=C2- After landing, put the load tester =C2- on, start the timer (15 seconds) and quickly crank the =C2- knob up until the voltage FALLS to 9 volts. Adjust the =C2- knob to maintain the 9v reading until the timer light =C2- goes out. Then quickly observe and record the CURRENT =C2- being delivered. HF has a slightly different approach to this test. Are there pros and cons of either method? Roger ________________________________________________________________________________
Date: Sep 10, 2017
IS the question At 03:22 PM 9/9/2017, you wrote: >Well, an single SLA has very different amp-hour >ratings depending on the discharge rate. And >'consumer' SLAs (PC680, etc that were originally >intended for watercraft, and others that some of >us use that were intended for UPSs and/or >electric carts, etc) are rated differently from >the certified a/c SLAs, if I've read spec sheets correctly.=C2 SVLA batteries have very significant internal resistance which wastes energy under load . . . a loss that increases with load. The battery's USEFUL capacity must be tied to the load. Here's the spread sheet on a PC680 Emacs! Note that the LIGHTER you load it, the BETTER the capacity. The PC680 is speced as a 16 a.h. device at the 20 HOUR RATE. But cranking your engine at 150 amps will get your only 2 minutes of operation with a 65% drop in capacity. The rest of that engergy will be used up getting the battery hot. Lithium's very low internal resistance produces very flat load vs. capacity curves. Here's an exemplar family of LiPo discharge curves. Emacs! Note that you get essentially ALL the capacity you paid for irrespective of load. Early on in the marketing of LiPo you saw the term "lead acid equivalent". This was a smoke-n- mirrors term created by the LiPo marketing that spoke only to cranking ability . . . fine if you owned a motor cycle or snowmobile. Totall bogus for airplane guys that had ENDURANCE requirements. I hammered EarthX about this and in years since you will see BOTH numbers. LAEQ and CAPAH. I'll have to back off on that 10v figure for using a load tester on LiPo batteries. The Significant load test for LiPo has to be select a number on a par with the real cranking current of your engine. Apply THAT load for 15 seconds then read the voltage at the end of 15 seconds. The most telling figure of merit is still ENDURANCE under anticipated load. Do that in the hangar or get the instruments that will count the electrons. Bob . . . ________________________________________________________________________________
Date: Sep 10, 2017
>At 10:10 AM 9/10/2017, you wrote: > > The HF load tester is the quick'n dirty battery evaluator. > When you install a NEW battery. Make sure it's topped off > (Go flying for an hour). After landing, put the load tester > on, start the timer (15 seconds) and quickly crank the > knob up until the voltage FALLS to 9 volts. Adjust the > knob to maintain the 9v reading until the timer light > goes out. Then quickly observe and record the CURRENT > being delivered. > > HF has a slightly different approach to this test.=C2 > Are there pros and cons of either method? One could debate that for a long time. This is comparative test . . . How much does test #2 depart from test #1? Then test #3, #4, etc. Use any protocol that pushes the battery to the edge of its performance capability and keep track of results. Bob . . . ________________________________________________________________________________
Date: Sep 10, 2017
That is clever, I'll try that. I've also been experimenting with using a tablespoon measuring spoon as a wind shield. The two together might be a winner. Jeff Sent from my iPad > On Sep 9, 2017, at 10:36 AM, Richard Girard wrote: > > I made a mic cover from a battery terminal cover and some porous foam. Helped with the wind noise in my trike. > > Rick Girard > >> ________________________________________________________________________________
Date: Sep 11, 2017
Jeff, early Extra 300s had an intercom system like you describe. The throttle of both seats had a momentary push button to open the mike for intercom and the stick had the radio PTT. That worked well for the pilot but not so well for inexperienced pax who took a while to understand the need to press the button on the throttle. Like Stein suggested I would install a good I intercom first (and I would go with his recommendation, he has some experience in this field...) before going down the intercom button route. Peter On 10 Sep 2017 3:34 p.m., "Jeff Point" wrote: > > That is clever, I'll try that. I've also been experimenting with using a > tablespoon measuring spoon as a wind shield. The two together might be a > winner. > > Jeff > > Sent from my iPad > > > On Sep 9, 2017, at 10:36 AM, Richard Girard wrote: > > > > I made a mic cover from a battery terminal cover and some porous foam. > Helped with the wind noise in my trike. > > > > Rick Girard > > > >> > > ________________________________________________________________________________
Date: Sep 10, 2017
Suggest contacting Sigtronics who designed an acceptable headset & intercom for their T6. They also added a 'glove' over the mic with a very small hole. It worked great in our Mustang II for years. On Sun, Sep 10, 2017 at 7:01 PM, Peter Pengilly wrote: > Jeff, early Extra 300s had an intercom system like you describe. The > throttle of both seats had a momentary push button to open the mike for > intercom and the stick had the radio PTT. That worked well for the pilot > but not so well for inexperienced pax who took a while to understand the > need to press the button on the throttle. Like Stein suggested I would > install a good I intercom first (and I would go with his recommendation, he > has some experience in this field...) before going down the intercom button > route. Peter > > On 10 Sep 2017 3:34 p.m., "Jeff Point" wrote: > >> >> That is clever, I'll try that. I've also been experimenting with using a >> tablespoon measuring spoon as a wind shield. The two together might be a >> winner. >> >> Jeff >> >> Sent from my iPad >> >> > On Sep 9, 2017, at 10:36 AM, Richard Girard >> wrote: >> > >> > I made a mic cover from a battery terminal cover and some porous foam. >> Helped with the wind noise in my trike. >> > >> > Rick Girard >> > >> >> >> >> >> =================================== >> - >> Electric-List" rel="noreferrer" target="_blank">http://www.matronics.com/ >> Navigator?AeroElectric-List >> =================================== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> =================================== >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> =================================== >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >> =================================== >> >> >> >> ________________________________________________________________________________
Date: Sep 14, 2017
Subject: Off line for a few days
Need to pick up an order of books in Denver this afternoon. Dr. Dee and I are tacking afew days on the end of the trip for some Rocky Mountain down-time . . . back Monday. Bob . . . ________________________________________________________________________________
Subject: Diamond RH77CA for MGL VH6
Date: Sep 14, 2017
I have a tube and fabric EAB aircraft that currently has no radio. It also has no convenient surface for mounting a traditional antenna, so it won't be a simple task. I want to install an MGL VH6 radio and a simple antenna set up. I've seen gliders rig homemade half wave length antennas that are taped to the inside of their canopies. Was wondering if the little 1/4 wavelength (2 meter) Diamond antenna that I just happen to have would work for this application, if I mounted it to the inside of the canopy rail in a vertical orientation. I know the antenna isn't perfectly matched. But, its rated for 10 watts/50 Ohms and the VH6 puts out 6 Watts nominal. Its gotta be better than a handheld with the short rubber-ducky, right? -------- Ken W. N804RV(reserved) RV-8 Empennage in work Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472877#472877 ________________________________________________________________________________
Subject: Re: Off line for a few days
Date: Sep 14, 2017
Yall have a great time away! On Sep 14, 2017, at 8:28 AM, Robert L. Nuckolls, III wrote: Need to pick up an order of books in Denver this afternoon. Dr. Dee and I are tacking afew days on the end of the trip for some Rocky Mountain down-time . . . back Monday. Bob . . . ________________________________________________________________________________
Subject: Re: Diamond RH77CA for MGL VH6
Date: Sep 14, 2017
The antenna is tuned for 146MHz. When operating in the lower part of the aircraft band (118MHz), the antenna will be way out of tune. The VSWR may be 2:1 or higher, reflecting a fair deal of the 6W back into the output stage of your VH6. Besides risk of damaging the output stage, you may observe 'weirdness' such as interference on instruments and headset noise. If you really want to try, get a local ham to borrow a VSWR meter and check. On 9/14/2017 8:08 PM, N804RV wrote: > > I have a tube and fabric EAB aircraft that currently has no radio. It also has no convenient surface for mounting a traditional antenna, so it won't be a simple task. I want to install an MGL VH6 radio and a simple antenna set up. I've seen gliders rig homemade half wave length antennas that are taped to the inside of their canopies. Was wondering if the little 1/4 wavelength (2 meter) Diamond antenna that I just happen to have would work for this application, if I mounted it to the inside of the canopy rail in a vertical orientation. I know the antenna isn't perfectly matched. But, its rated for 10 watts/50 Ohms and the VH6 puts out 6 Watts nominal. Its gotta be better than a handheld with the short rubber-ducky, right? > > -------- > Ken W. > N804RV(reserved) > RV-8 Empennage in work > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=472877#472877 > > ________________________________________________________________________________
Date: Sep 14, 2017
I'd hope that since the VH6 is a relatively new design, it would protect itself from damage (just about all modern radios do that). It would still be inefficient, but so is a rubber ducky. A better option might be to just roll your own. 1/4 wave whips are stupid simple to make, and the ground plane can be anything from nothing (poor performance) to 3 or 4 radial arms roughly the same length as the whip, to a disc of metal with the same radius as the whip. The whip can be virtually any metal object, but wider (fatter) strips will tune over a wider band than skinny strips like thin wire. A couple of adel clamps slid around the fuselage tubing and screwed to the metal disc can provide mounting. It isn't a sure thing, but many rag/tube builders have mounted the entire antenna inside the fuselage and reported adequate performance. If you don't need 50 mile range (who really does?), then build one, duct tape it in the back of the fuselage, and go flying to see how well it works. https://www.google.com/search?q=diy+aircraft+comm+antenna&oq=diy+aircraft+comm+antenna&aqs=chrome..69i57.8849j0j7&sourceid=chrome&ie=UTF-8 A half-wave can be almost as simple to make, but tougher to mount in a rag/tube fuselage. Antennas are a black art, but they ain't rocket surgery. You'd be amazed at what works 'good enough'. And better is the enemy of.... Charlie On 9/14/2017 3:48 PM, Rob Turk wrote: > > The antenna is tuned for 146MHz. When operating in the lower part of > the aircraft band (118MHz), the antenna will be way out of tune. The > VSWR may be 2:1 or higher, reflecting a fair deal of the 6W back into > the output stage of your VH6. Besides risk of damaging the output > stage, you may observe 'weirdness' such as interference on instruments > and headset noise. If you really want to try, get a local ham to > borrow a VSWR meter and check. > > On 9/14/2017 8:08 PM, N804RV wrote: >> >> I have a tube and fabric EAB aircraft that currently has no radio. >> It also has no convenient surface for mounting a traditional antenna, >> so it won't be a simple task. I want to install an MGL VH6 radio and >> a simple antenna set up. I've seen gliders rig homemade half wave >> length antennas that are taped to the inside of their canopies. Was >> wondering if the little 1/4 wavelength (2 meter) Diamond antenna that >> I just happen to have would work for this application, if I mounted >> it to the inside of the canopy rail in a vertical orientation. I >> know the antenna isn't perfectly matched. But, its rated for 10 >> watts/50 Ohms and the VH6 puts out 6 Watts nominal. Its gotta be >> better than a handheld with the short rubber-ducky, right? >> >> -------- >> Ken W. >> N804RV(reserved) >> RV-8 Empennage in work --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Sep 14, 2017
A com antenna should be somewhere between 22 and 23 inches long. Bob N has directions for making your own antenna: http://www.aeroelectric.com/articles/Antennas/DIY_Comm_Ant/DIY_Comm.html -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472893#472893 ________________________________________________________________________________
Date: Sep 14, 2017
What is the rail made of, any metal near? If metal you could ruin the output of the radio. Sent from my iPhone > On Sep 14, 2017, at 3:48 PM, Rob Turk wrote: > > > The antenna is tuned for 146MHz. When operating in the lower part of the aircraft band (118MHz), the antenna will be way out of tune. The VSWR may be 2:1 or higher, reflecting a fair deal of the 6W back into the output stage of your VH6. Besides risk of damaging the output stage, you may observe 'weirdness' such as interference on instruments and headset noise. If you really want to try, get a local ham to borrow a VSWR meter and check. > >> On 9/14/2017 8:08 PM, N804RV wrote: >> >> I have a tube and fabric EAB aircraft that currently has no radio. It also has no convenient surface for mounting a traditional antenna, so it won't be a simple task. I want to install an MGL VH6 radio and a simple antenna set up. I've seen gliders rig homemade half wave length antennas that are taped to the inside of their canopies. Was wondering if the little 1/4 wavelength (2 meter) Diamond antenna that I just happen to have would work for this application, if I mounted it to the inside of the canopy rail in a vertical orientation. I know the antenna isn't perfectly matched. But, its rated for 10 watts/50 Ohms and the VH6 puts out 6 Watts nominal. Its gotta be better than a handheld with the short rubber-ducky, right? >> >> -------- >> Ken W. >> N804RV(reserved) >> RV-8 Empennage in work >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=472877#472877 >> >> >> >> >> >> >> >> >> >> > > > > . ________________________________________________________________________________
Subject: Dual batteries
From: "robintaylor" <robintaylor(at)airteccc.co.uk>
Date: Sep 15, 2017
In the UK we can now obtain certification to fly home builds under IFR. There are quite strict requirements to achieve this. I want to install a second battery in my RV9 to improve redundancy in the event of an alternator failure. My current battery is a Concorde RG-25XC and I would like the second battery to be an Odyssey PC680. I specify these because I had trouble starting my RV and changed from the Odyssey to the larger capacity Concorde, but I still have the battery and battery holder in the plane. My questions are, Is it OK to run two different AH batteries in parallel. Is it OK to connect the second battery via another solenoid activated by the master switch or is there a better way. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472905#472905 ________________________________________________________________________________
Subject: Re: Dual batteries
Date: Sep 15, 2017
Just putting batteries in parallel doesn't do much for redundancy. If one develops a short, your backup will be toast too. You may want to consider a further redesign of your electrical system in order to have a true main and backup/essentials battery. Not sure if you are weight constrained, but you could consider an AeroAkku LFP-450D. It's identical in size to the PC680 and weighs 5kg less than a PC680 On 9/15/2017 5:13 PM, robintaylor wrote: > > In the UK we can now obtain certification to fly home builds under IFR. > There are quite strict requirements to achieve this. > I want to install a second battery in my RV9 to improve redundancy in the event of an alternator failure. > My current battery is a Concorde RG-25XC and I would like the second battery to be an Odyssey PC680. > I specify these because I had trouble starting my RV and changed from the Odyssey to the larger capacity Concorde, but I still have the battery and battery holder in the plane. > My questions are, > Is it OK to run two different AH batteries in parallel. > Is it OK to connect the second battery via another solenoid activated by the master switch or is there a better way. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=472905#472905 > > ________________________________________________________________________________
Date: Sep 15, 2017
Thanks for quick reply. I think I should have said endurance not redundancy. I am trying to do as little as possible and alternator failure is what they consider the main risk so battery endurance is what key. Regarding the batteries, I am light up front because I only have a wooden Cato prop but I will look at the batteries. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472907#472907 ________________________________________________________________________________
Date: Sep 15, 2017
Yes, it is OK to put two different sized lead-acid batteries in parallel. It is also OK to to install another solenoid. It could be energized via the master switch. But I would use a separate switch. You might consider installing a backup alternator (Z-13/8) instead of a second battery. Two batteries still have limited endurance. A second alternator gives unlimited endurance, maybe with less weight than adding another battery. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472908#472908 ________________________________________________________________________________
Date: Sep 16, 2017
Subject: Comm Radio Mic Cable -> Audio Panel
Folks, I'm hoping that someone here knows the answer quicker than I can get an answer from VAL Avionics, since it is a weekend. My VAL COM 2000 radio shows microphone connections for - Mic Key - Mic Audio - Mic GND - Shield tied to Mic GND (grounded at one end only) My PS Engineering audio panel shows microphone connections for - Mic Key - Mic Audio - Shield (grounded at one end only) What do I do with the Mic GND? Is tying it to the shield and grounding it at one end sufficient? -- Art Z. -- https://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
Subject: GFCI Breaker keeps tripping (Non Aviation)
Date: Sep 16, 2017
My current shop was built two years ago. All the 120 circuits have GFCI breakers. Specifically Siemens type QPF, 20a. About a month ago, whenever I went into the shop, one of the breakers would be tripped. The only thing on that circuit is a lathe and work light. I unplugged them and it would be tripped the next morning. I swapped the circuit with a different breaker and the same breaker kept tripping. So it would appear that I've got a bad breaker. I went to Home Depot and got a new one ($53!!! :x ). All good now. Except now there's a breaker on a completely different circuit tripping. This one only stays set for about an hour before tripping (with nothing connected to the circuit). I did a quick google and it appears that this is common and referred to as "nuisance tripping". Does anyone have any suggestions on how to resolve it without dropping another $53? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472926#472926 ________________________________________________________________________________
Date: Sep 16, 2017
Subject: Re: Comm Radio Mic Cable -> Audio Panel
Art, I talked to PSE and they said to either leave the mic lo disconnected at both ends or connect as you did at radio end and connect to the ground wire at the PSE end. The shield connects to the rest of the PSE shields. No double ended shield connections. Don On Sep 16, 2017 15:47, "Art Zemon" wrote: Folks, I'm hoping that someone here knows the answer quicker than I can get an answer from VAL Avionics, since it is a weekend. My VAL COM 2000 radio shows microphone connections for - Mic Key - Mic Audio - Mic GND - Shield tied to Mic GND (grounded at one end only) My PS Engineering audio panel shows microphone connections for - Mic Key - Mic Audio - Shield (grounded at one end only) What do I do with the Mic GND? Is tying it to the shield and grounding it at one end sufficient? -- Art Z. -- https://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
Subject: Re: GFCI Breaker keeps tripping (Non Aviation)
Date: Sep 16, 2017
Sure=2E $7 breaker=2E :-) =81=A3Charlie=8B On Sep 16, 2017, 6:14 PM, at 6:14 PM, donjohnston wrote: >--> AeroElectr ic-List message posted by: "donjohnston" > > >My cur rent shop was built two years ago=2E All the 120 circuits have >GFCI break ers=2E Specifically Siemens type QPF, 20a=2E > >About a month ago, whenev er I went into the shop, one of the breakers >would be tripped=2E The only thing on that circuit is a lathe and work >light=2E I unplugged them and i t would be tripped the next morning=2E I >swapped the circuit with a diffe rent breaker and the same breaker kept >tripping=2E So it would appear that I've got a bad breaker=2E > >I went to Home Depot and got a new one ($53 !!! :x )=2E All good now=2E > >Except now there's a breaker on a comple tely different circuit >tripping=2E This one only stays set for about an h our before tripping >(with nothing connected to the circuit)=2E > >I did a quick google and it appears that this is common and referred to >as "nuis ance tripping"=2E > >Does anyone have any suggestions on how to resolve it without dropping >another $53? > > >Read this topic online here: > >ht tp://forums=2Ematronics=2Ecom/viewtopic=2Ephp?p=472926#472926 > > =========== t Email Forum - Search & Download, 7-Day Browse, Chat, FAQ, ch more: ctric-List ================ MATRONICS WEB FORUMS - Forums! ======== /wiki=2Ematronics=2Ecom ================== - List Contribution Web Site - t! --> http://www=2Ematronics=2Ecom/contribution = ________________________________________________________________________________
Date: Sep 16, 2017
Any chance of condensation or water leakage? I've also seen tripping issues when mice get at the wiring. Ken On 16/09/2017 8:47 PM, Charlie England wrote: > Sure. $7 breaker. :-) > > Charlie > On Sep 16, 2017, at 6:14 PM, donjohnston <don@velocity-xl.com > don@velocity-xl.com>> wrote: > > > My current shop was built two years ago. All the 120 circuits have GFCI breakers. Specifically Siemens type QPF, 20a. > > About a month ago, whenever I went into the shop, one of the breakers would be tripped. The only thing on that circuit is a lathe and work light. I unplugged them and it would be tripped the next morning. I swapped the circuit with a different breaker and the same breaker kept tripping. So it would appear that I've got a bad breaker. > > I went to Home Depot and got a new one ($53!!! :x ). All good now. > > Except now there's a breaker on a completely different circuit tripping. This one only stays set for about an hour before tripping (with nothing connected to the circuit). > > I did a quick google and it appears that this is common and referred to as "nuisance tripping". > > Does anyone have any suggestions on how to resolve it without dropping another $53? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=472926#472926atronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Naa > href="http://www.matronics.com/contribution">http://www.matronics.com/contribution > <http://forums.matronics.com/viewtopic.php?p=472926#472926> > ------------------------------------------------------------------------ > > ________________________________________________________________________________
Date: Sep 17, 2017
Subject: Don Johnson
Hi Don- Tried to reply directly but the note bounced due to a full mailbox. So, are the breakers in question in the main panel or a sub panel? On Sep 17, 2017 12:20 AM, "AeroElectric-List Digest Server" < aeroelectric-list(at)matronics.com> wrote: * ================================================= Online Versions of Today's List Digest Archive ================================================= Today's complete AeroElectric-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the AeroElectric-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style 82701&View=html&Chapter 17-09-16&Archive=AeroElectric Text Version: http://www.matronics.com/digest/digestview.php?Style 82701&View=txt&Chapter 17-09-16&Archive=AeroElectric =============================================== EMail Version of Today's List Digest Archive =============================================== ---------------------------------------------------------- AeroElectric-List Digest Archive --- Total Messages Posted Sat 09/16/17: 5 ---------------------------------------------------------- Today's Message Index: ---------------------- 1. 03:43 PM - Comm Radio Mic Cable -> Audio Panel (Art Zemon) 2. 04:11 PM - GFCI Breaker keeps tripping (Non Aviation) (donjohnston) 3. 05:18 PM - Re: Comm Radio Mic Cable -> Audio Panel (don van santen) 4. 05:49 PM - Re: GFCI Breaker keeps tripping (Non Aviation) (Charlie England) 5. 06:23 PM - Re: GFCI Breaker keeps tripping (Non Aviation) (C&K) ________________________________ Message 1 ______________________________ _______ From: Art Zemon <art(at)zemon.name> Subject: AeroElectric-List: Comm Radio Mic Cable -> Audio Panel Folks, I'm hoping that someone here knows the answer quicker than I can get an answer from VAL Avionics, since it is a weekend. My VAL COM 2000 radio shows microphone connections for - Mic Key - Mic Audio - Mic GND - Shield tied to Mic GND (grounded at one end only) My PS Engineering audio panel shows microphone connections for - Mic Key - Mic Audio - Shield (grounded at one end only) What do I do with the Mic GND? Is tying it to the shield and grounding it at one end sufficient? -- Art Z. -- https://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________ Message 2 ______________________________ _______ Subject: AeroElectric-List: GFCI Breaker keeps tripping (Non Aviation) From: "donjohnston" <don@velocity-xl.com> My current shop was built two years ago. All the 120 circuits have GFCI breakers. Specifically Siemens type QPF, 20a. About a month ago, whenever I went into the shop, one of the breakers would be tripped. The only thing on that circuit is a lathe and work light. I unplugged them and it would be tripped the next morning. I swapped the circuit with a different breaker and the same breaker kept tripping. So it would appear that I've got a bad breaker. I went to Home Depot and got a new one ($53!!! :x ). All good now. Except now there's a breaker on a completely different circuit tripping. This one only stays set for about an hour before tripping (with nothing connected to the circuit). I did a quick google and it appears that this is common and referred to as "nuisance tripping". Does anyone have any suggestions on how to resolve it without dropping another $53? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472926#472926 ________________________________ Message 3 ______________________________ _______ From: don van santen <donvansanten(at)gmail.com> Subject: Re: AeroElectric-List: Comm Radio Mic Cable -> Audio Panel Art, I talked to PSE and they said to either leave the mic lo disconnected at both ends or connect as you did at radio end and connect to the ground wire at the PSE end. The shield connects to the rest of the PSE shields. No double ended shield connections. Don On Sep 16, 2017 15:47, "Art Zemon" wrote: Folks, I'm hoping that someone here knows the answer quicker than I can get an answer from VAL Avionics, since it is a weekend. My VAL COM 2000 radio shows microphone connections for - Mic Key - Mic Audio - Mic GND - Shield tied to Mic GND (grounded at one end only) My PS Engineering audio panel shows microphone connections for - Mic Key - Mic Audio - Shield (grounded at one end only) What do I do with the Mic GND? Is tying it to the shield and grounding it at one end sufficient? -- Art Z. -- https://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________ Message 4 ______________________________ _______ Subject: Re: AeroElectric-List: GFCI Breaker keeps tripping (Non Aviation) From: Charlie England <ceengland7(at)gmail.com> Sure=2E $7 breaker=2E :-) =81=A3Charlie=8B On Sep 16, 2017, 6:14 PM, at 6:14 PM, donjohnston wrote: >--> AeroElectr ic-List message posted by: "donjohnston" > > >My cur rent shop was built two years ago=2E All the 120 circuits have >GFCI break ers=2E Specifically Siemens type QPF, 20a=2E > >About a month ago, whenev er I went into the shop, one of the breakers >would be tripped=2E The only thing on that circuit is a lathe and work >light=2E I unplugged them and i t would be tripped the next morning=2E I >swapped the circuit with a diffe rent breaker and the same breaker kept >tripping=2E So it would appear that I've got a bad breaker=2E > >I went to Home Depot and got a new one ($53 !!! :x )=2E All good now=2E > >Except now there's a breaker on a comple tely different circuit >tripping=2E This one only stays set for about an h our before tripping >(with nothing connected to the circuit)=2E > >I did a quick google and it appears that this is common and referred to >as "nuis ance tripping"=2E > >Does anyone have any suggestions on how to resolve it without dropping >another $53? > > >Read this topic online here: > >ht tp://forums=2Ematronics=2Ecom/viewtopic=2Ephp?p=472926#472926 > > ========== t Email Forum - Search & Download, 7-Day Browse, Chat, FAQ, ch more: ctric-List =============== MATRONICS WEB FORUMS - Forums! ======= /wiki=2Ematronics=2Ecom ================= - List Contribution Web Site - t! --> http://www=2Ematronics=2Ecom/contribution ________________________________ Message 5 ______________________________ _______ Subject: Re: AeroElectric-List: GFCI Breaker keeps tripping (Non Aviation) From: C&K <yellowduckduo(at)gmail.com> Any chance of condensation or water leakage? I've also seen tripping issues when mice get at the wiring. Ken On 16/09/2017 8:47 PM, Charlie England wrote: > Sure. $7 breaker. :-) > > Charlie > On Sep 16, 2017, at 6:14 PM, donjohnston <don@velocity-xl.com > don@velocity-xl.com>> wrote: > > > My current shop was built two years ago. All the 120 circuits have GFCI breakers. Specifically Siemens type QPF, 20a. > > About a month ago, whenever I went into the shop, one of the breakers would be tripped. The only thing on that circuit is a lathe and work light. I unplugged them and it would be tripped the next morning. I swapped the circuit with a different breaker and the same breaker kept tripping. So it would appear that I've got a bad breaker. > > I went to Home Depot and got a new one ($53!!! :x ). All good now. > > Except now there's a breaker on a completely different circuit tripping. This one only stays set for about an hour before tripping (with nothing connected to the circuit). > > I did a quick google and it appears that this is common and referred to as "nuisance tripping". > > Does anyone have any suggestions on how to resolve it without dropping another $53? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=472926# 472926atronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Naa > href="http://www.matronics.com/contribution">http://www. matronics.com/contribution > <http://forums.matronics.com/viewtopic.php?p=472926#472926> > ------------------------------------------------------------ ------------ > > ________________________________________________________________________________
Date: Sep 17, 2017
ceengland7(at)gmail.com wrote: > Sure. $7 breaker. :-) > Thanks for the tip on how to void my homeowners insurance. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472938#472938 ________________________________________________________________________________
Date: Sep 17, 2017
yellowduckduo(at)gmail.co wrote: > Any chance of condensation or water leakage? > I've also seen tripping issues when mice get at the wiring. > No. Nice and dry with no rodents. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472939#472939 ________________________________________________________________________________
Date: Sep 17, 2017
Don, Thanks. Since there is no ground pin on the PSE J1 connector, I will just leave the Mic GND (what PSE calls "Mic Lo") disconnected at that end. Cheers, -- Art Z. On Sat, Sep 16, 2017 at 7:16 PM, don van santen wrote: > Art, I talked to PSE and they said to either leave the mic lo disconnected > at both ends or connect as you did at radio end and connect to the ground > wire at the PSE end. The shield connects to the rest of the PSE shields. No > double ended > shield connections. > Don > > On Sep 16, 2017 15:47, "Art Zemon" wrote: > > Folks, > > I'm hoping that someone here knows the answer quicker than I can get an > answer from VAL Avionics, since it is a weekend. > > My VAL COM 2000 radio shows microphone connections for > > - Mic Key > - Mic Audio > - Mic GND > - Shield tied to Mic GND (grounded at one end only) > > My PS Engineering audio panel shows microphone connections for > > - Mic Key > - Mic Audio > - Shield (grounded at one end only) > > What do I do with the Mic GND? Is tying it to the shield and grounding it > at one end sufficient? > > -- https://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
Date: Sep 17, 2017
A ground fault outlet could be used instead of a ground fault circuit breaker. A ground fault outlet can be wired to protect all other outlets that are electrically located downstream from it. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472941#472941 ________________________________________________________________________________
Date: Sep 17, 2017
Art, the ground that PSE was referong to is the two ground wires in the power and ground section. The audio panel will not funtion without a power return (ground). On Sep 17, 2017 05:02, "Art Zemon" wrote: > Don, > > Thanks. Since there is no ground pin on the PSE J1 connector, I will just > leave the Mic GND (what PSE calls "Mic Lo") disconnected at that end. > > Cheers, > -- Art Z. > > On Sat, Sep 16, 2017 at 7:16 PM, don van santen > wrote: > >> Art, I talked to PSE and they said to either leave the mic lo >> disconnected at both ends or connect as you did at radio end and connect to >> the ground wire at the PSE end. The shield connects to the rest of the PSE >> shields. No double ended >> shield connections. >> Don >> >> On Sep 16, 2017 15:47, "Art Zemon" wrote: >> >> Folks, >> >> I'm hoping that someone here knows the answer quicker than I can get an >> answer from VAL Avionics, since it is a weekend. >> >> My VAL COM 2000 radio shows microphone connections for >> >> - Mic Key >> - Mic Audio >> - Mic GND >> - Shield tied to Mic GND (grounded at one end only) >> >> My PS Engineering audio panel shows microphone connections for >> >> - Mic Key >> - Mic Audio >> - Shield (grounded at one end only) >> >> What do I do with the Mic GND? Is tying it to the shield and grounding it >> at one end sufficient? >> >> >> > > > -- > https://CheerfulCurmudgeon.com/ > > *"If I am not for myself, who is for me? And if I am only for myself, what > am I? And if not now, when?" Hillel* > ________________________________________________________________________________
Date: Sep 17, 2017
Yes, I understand that. -- Art Z. On Sun, Sep 17, 2017 at 8:38 AM, don van santen wrote: > Art, the ground that PSE was referong to is the two ground wires in the > power and ground section. The audio panel will not funtion without a power > return (ground). > -- https://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
Date: Sep 17, 2017
user9253 wrote: > A ground fault outlet could be used instead of a ground fault circuit breaker. A ground fault outlet can be wired to protect all other outlets that are electrically located downstream from it. Not here. Code requires a GFCI circuit breaker in the panel. Otherwisie I would have gone that route because the outlets don't seem to have as many nuisance trips as the breakers do. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472944#472944 ________________________________________________________________________________
Date: Sep 17, 2017
>From Electrician.com: Try to keep your circuit length Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472947#472947 ________________________________________________________________________________
Date: Sep 17, 2017
On 9/17/2017 4:20 AM, donjohnston wrote: > > > ceengland7(at)gmail.com wrote: >> Sure. $7 breaker. :-) >> > > Thanks for the tip on how to void my homeowners insurance. Sorry for the short, then delayed answers; I was on the road & fingering my phone. I certainly wasn't trying to get you in trouble with anyone. But your 1st post said 'every 120 breaker' which I guess means every 120V breaker in that panel. Unless the NEC has changed radically in the last few years, the only place GFI breakers are required is near water (over kitchen/bathroom sinks, outdoors, etc). I've seen a *lot* of CB panels, and I've never seen one where every 120V breaker was GFI. Are you in some country other than the USA, or some state or county with bizarrely draconian electrical codes? I know that if a contractor tried to tell me I needed GFIs in every slot, I'd be looking for another contractor. Having said all that, if I were getting random GFI trips with nothing on the circuit, I'd be looking for 'issues' with both the ground wiring and the neutral wiring. I'd probably start with the neutral, making sure that its 'bond' to the ground in the panel is secure. Also, you can buy an inexpensive GFI tester for <$20, if you shop around online. There's tons of posts online about troubleshooting the issue, too. Here's a link from a reputable meter mfgr discussing how to troubleshoot the problem. http://www.fluke.com/fluke/uses/comunidad/fluke-news-plus/articlecategories/grounding/chasing-ghost-trips Charlie --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Sep 17, 2017
I believe that the code now states that arc fault are needed everywhere. Gfci do not like anything that has a motor on it, like microwaves, refrigerators, dishwashers. On Sep 17, 2017 7:42 PM, "Charlie England" wrote: > ceengland7(at)gmail.com> > > On 9/17/2017 4:20 AM, donjohnston wrote: > >> don@velocity-xl.com> >> >> >> ceengland7(at)gmail.com wrote: >> >>> Sure. $7 breaker. :-) >>> >>> >> Thanks for the tip on how to void my homeowners insurance. >> > Sorry for the short, then delayed answers; I was on the road & fingering > my phone. > > I certainly wasn't trying to get you in trouble with anyone. But your 1st > post said 'every 120 breaker' which I guess means every 120V breaker in > that panel. Unless the NEC has changed radically in the last few years, the > only place GFI breakers are required is near water (over kitchen/bathroom > sinks, outdoors, etc). I've seen a *lot* of CB panels, and I've never seen > one where every 120V breaker was GFI. Are you in some country other than > the USA, or some state or county with bizarrely draconian electrical codes? > > I know that if a contractor tried to tell me I needed GFIs in every slot, > I'd be looking for another contractor. > > Having said all that, if I were getting random GFI trips with nothing on > the circuit, I'd be looking for 'issues' with both the ground wiring and > the neutral wiring. I'd probably start with the neutral, making sure that > its 'bond' to the ground in the panel is secure. Also, you can buy an > inexpensive GFI tester for <$20, if you shop around online. There's tons of > posts online about troubleshooting the issue, too. > > Here's a link from a reputable meter mfgr discussing how to troubleshoot > the problem. > http://www.fluke.com/fluke/uses/comunidad/fluke-news-plus/ > articlecategories/grounding/chasing-ghost-trips > > > Charlie > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus > > ________________________________________________________________________________
Date: Sep 17, 2017
Subject: starter contactor
Does anyone know if there is an automotive source or part number for the traditional three-terminal intermittent duty cycle starter contactor? ________________________________________________________________________________
Date: Sep 17, 2017
Great article! Sent from my iPhone > On Sep 17, 2017, at 6:39 PM, Charlie England wrote: > > >> On 9/17/2017 4:20 AM, donjohnston wrote: >> >> >> ceengland7(at)gmail.com wrote: >>> Sure. $7 breaker. :-) >>> >> >> Thanks for the tip on how to void my homeowners insurance. > Sorry for the short, then delayed answers; I was on the road & fingering my phone. > > I certainly wasn't trying to get you in trouble with anyone. But your 1st post said 'every 120 breaker' which I guess means every 120V breaker in that panel. Unless the NEC has changed radically in the last few years, the only place GFI breakers are required is near water (over kitchen/bathroom sinks, outdoors, etc). I've seen a *lot* of CB panels, and I've never seen one where every 120V breaker was GFI. Are you in some country other than the USA, or some state or county with bizarrely draconian electrical codes? > > I know that if a contractor tried to tell me I needed GFIs in every slot, I'd be looking for another contractor. > > Having said all that, if I were getting random GFI trips with nothing on the circuit, I'd be looking for 'issues' with both the ground wiring and the neutral wiring. I'd probably start with the neutral, making sure that its 'bond' to the ground in the panel is secure. Also, you can buy an inexpensive GFI tester for <$20, if you shop around online. There's tons of posts online about troubleshooting the issue, too. > > Here's a link from a reputable meter mfgr discussing how to troubleshoot the problem. > http://www.fluke.com/fluke/uses/comunidad/fluke-news-plus/articlecategories/grounding/chasing-ghost-trips > > > Charlie > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus > > > > . ________________________________________________________________________________
Subject: Re: starter contactor
Date: Sep 17, 2017
Alec, Go to Pep Boys and search on starter solenoid and there are a number of them to choose from. Prices range from $175.99 to $11.99. Surely one of them will tickle your fancy. Blue skies & tailwinds, Bob Borger Europa XS Tri, Rotax 914, Airmaster C/S Prop (75 hrs). Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP 3705 Lynchburg Dr. Corinth, TX 76208-5331 Cel: 817-992-1117 rlborger(at)mac.com On Sep 17, 2017, at 7:35 PM, Alec Myers wrote: Does anyone know if there is an automotive source or part number for the traditional three-terminal intermittent duty cycle starter contactor? ________________________________________________________________________________
Date: Sep 17, 2017
Hi Alec; Try Aircraft Spruce Part # 11-03162, which is a Unipoint Part # SNLS-135T. They must be having a weak moment and have it on sale for less than $10. Cheers! Stu. ----- Original Message ----- From: "Alec Myers" <alec(at)alecmyers.com> Sent: Sunday, September 17, 2017 5:35:27 PM Subject: AeroElectric-List: starter contactor Does anyone know if there is an automotive source or part number for the traditional three-terminal intermittent duty cycle starter contactor? ________________________________________________________________________________
Date: Sep 17, 2017
Or do the same on ebay until you see one that looks suitable, & either order it, or get the make/model of the car it fits to the local auto parts store. https://www.ebay.com/sch/i.html?_odkw=starter+relay&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR12.TRC2.A0.H0.Xstarter+solenoid.TRS0&_nkw=starter+solenoid&_sacat=0 On 9/17/2017 7:56 PM, Robert Borger wrote: > > Alec, > > Go to Pep Boys and search on starter solenoid and there are a number of them to choose from. Prices range from $175.99 to $11.99. Surely one of them will tickle your fancy. > > Blue skies & tailwinds, > Bob Borger > Europa XS Tri, Rotax 914, Airmaster C/S Prop (75 hrs). > Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP > 3705 Lynchburg Dr. > Corinth, TX 76208-5331 > Cel: 817-992-1117 > rlborger(at)mac.com > > On Sep 17, 2017, at 7:35 PM, Alec Myers wrote: > > > Does anyone know if there is an automotive source or part number for the traditional three-terminal intermittent duty cycle starter contactor? > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Sep 17, 2017
At 07:35 PM 9/17/2017, you wrote: > >Does anyone know if there is an automotive source or part number for >the traditional three-terminal intermittent duty cycle starter contactor? There are dozens . . . A partial list of cross-reference numbers includes F3914, SS-598, F496, 1M1517 They look like this http://www.aeroelectric.com/Pictures/Contactors/Starter_Contact and have the words 'DIODE SUPRESSED' stamped on the bottom . . . it will work Bob . . . ________________________________________________________________________________
Date: Sep 18, 2017
I just went through the same thing and ended up using the Napa/Echlin ST404 for about $30. Unfortunately, the bolt holes did not match the Cole Hersee that I was replacing. I ended up making an adapter plate. On Sun, Sep 17, 2017 at 10:38 PM, Charlie England wrote: > ceengland7(at)gmail.com> > > Or do the same on ebay until you see one that looks suitable, & either > order it, or get the make/model of the car it fits to the local auto part s > store. > https://www.ebay.com/sch/i.html?_odkw=starter+relay&_osacat > 0&_from=R40&_trksid=p2045573.m570.l1313.TR12.TRC2.A0.H0. > Xstarter+solenoid.TRS0&_nkw=starter+solenoid&_sacat=0 > > > On 9/17/2017 7:56 PM, Robert Borger wrote: > > >> >> Alec, >> >> Go to Pep Boys and search on =9Cstarter solenoid=9D and ther e are a number of >> them to choose from. Prices range from $175.99 to $11.99. Surely one o f >> them will tickle your fancy. >> >> Blue skies & tailwinds, >> Bob Borger >> Europa XS Tri, Rotax 914, Airmaster C/S Prop (75 hrs). >> Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP >> 3705 Lynchburg Dr. >> Corinth, TX 76208-5331 >> Cel: 817-992-1117 >> rlborger(at)mac.com >> >> On Sep 17, 2017, at 7:35 PM, Alec Myers wrote: >> >> >> Does anyone know if there is an automotive source or part number for the >> traditional three-terminal intermittent duty cycle starter contactor? >> >> > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus > > =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Sep 18, 2017
ceengland7(at)gmail.com wrote: > But your > 1st post said 'every 120 breaker' which I guess means every 120V breaker > in that panel. Unless the NEC has changed radically in the last few > years, the only place GFI breakers are required is near water (over > kitchen/bathroom sinks, outdoors, etc). The subpanel in my shop only serves the shop. The code (as I understand it) is that every accessible outlet in a damp enviroment, garage, workshop or unfinished area must be protected by a GFCI breaker. Now whether that has to be an actual circuit breaker or if the first outlet can be a GFCI outlet which protects all the outlets downstream, is something I'm not certain about. If a GFCI outlet can be used, I'm guessing that since I was installing the outlets, the electrican decided to go with the breaker in case I didn't install the correct outlet. I'm currently trying to nail down if Florida requires the breaker or if an outlet is acceptable. I've found the breakers online for about $40 so that takes some of the sting out of it. I do not have GFCI breakers in every slot. Only those which go to outlets. ceengland7(at)gmail.com wrote: > Having said all that, if I were getting random GFI trips with nothing on the circuit, I'd be looking for 'issues' with both the ground wiring and the neutral wiring. I'd probably start with the neutral, making sure that its 'bond' to the ground in the panel is secure. I would think that if there were ground or neutral wiring problems that the tripping would remain on the same circuit instead of moving with the breaker. ceengland7(at)gmail.com wrote: > Also, you can buy an inexpensive GFI tester for Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472981#472981 ________________________________________________________________________________
Date: Sep 18, 2017
On 9/18/2017 10:09 AM, donjohnston wrote: > > > ceengland7(at)gmail.com wrote: >> But your >> 1st post said 'every 120 breaker' which I guess means every 120V breaker >> in that panel. Unless the NEC has changed radically in the last few >> years, the only place GFI breakers are required is near water (over >> kitchen/bathroom sinks, outdoors, etc). > > The subpanel in my shop only serves the shop. > > The code (as I understand it) is that every accessible outlet in a damp enviroment, garage, workshop or unfinished area must be protected by a GFCI breaker. Now whether that has to be an actual circuit breaker or if the first outlet can be a GFCI outlet which protects all the outlets downstream, is something I'm not certain about. > > If a GFCI outlet can be used, I'm guessing that since I was installing the outlets, the electrican decided to go with the breaker in case I didn't install the correct outlet. > > I'm currently trying to nail down if Florida requires the breaker or if an outlet is acceptable. I've found the breakers online for about $40 so that takes some of the sting out of it. > > I do not have GFCI breakers in every slot. Only those which go to outlets. > > > ceengland7(at)gmail.com wrote: >> Having said all that, if I were getting random GFI trips with nothing on the circuit, I'd be looking for 'issues' with both the ground wiring and the neutral wiring. I'd probably start with the neutral, making sure that its 'bond' to the ground in the panel is secure. > > I would think that if there were ground or neutral wiring problems that the tripping would remain on the same circuit instead of moving with the breaker. > > > ceengland7(at)gmail.com wrote: >> Also, you can buy an inexpensive GFI tester for > I haven't read the NEC on GFIs, but it's difficult to understand the logic of including 'workshop' in the code. Plugging a drill motor or other tool in a 'workshop' outlet is no different from plugging it in an outlet in your house. I would have thought the only variable would be the damp/moisture issue. Some workshops might be damp, but most people want to keep their tools & equipment dry. I mentioned looking for 'system' issues because of your earlier email: About a month ago, whenever I went into the shop, one of the breakers would be tripped. The only thing on that circuit is a lathe and work light. I unplugged them and it would be tripped the next morning. I swapped the circuit with a different breaker and the same breaker kept tripping. So it would appear that I've got a bad breaker. I went to Home Depot and got a new one ($53!!! :x ). All good now. /*Except now there's a breaker on a completely different circuit tripping. This one only stays set for about an hour before tripping (with nothing connected to the circuit).*/ So from your narrative it sounded like you have more than one GFI that's nuisance tripping. --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Sep 18, 2017
At 09:18 PM 9/17/2017, you wrote: > >Hi Alec; >Try Aircraft Spruce Part # 11-03162, which is a Unipoint Part # >SNLS-135T. They must be having a weak moment and have it on sale for >less than $10. That's the 'whisky barrel' version of the modern starter contactors. The same general rules apply for selecting substitutions. If it looks like that and claims 'diode suppression' then you're good to go. Incidentally . . . it's easy to test a contactor for diode suppression. Use a couple of clip leads to apply voltage to the coil from a bench power supply or any 12v battery. Be sure to clip battery(-) to the contactor base, clip one end of other lead to battery(+) and use it to make intermittent contact with the "S" terminal. You should hear/feel some robust activity within the contactor as it closes. There should be very little or no observable arcing at the "S" terminal where you are applying power to the coil. If no diode present, arcing will be significant. You can still use this contactor . . . just add the diode externally; anode to base (ground), cathode to the "S" terminal. Bob . . . ________________________________________________________________________________
Date: Sep 18, 2017
On 9/17/2017 4:39 PM, Charlie England wrote: > Having said all that, if I were getting random GFI trips with nothing on > the circuit, I'd be looking for 'issues' with both the ground wiring and > the neutral wiring. I'd probably start with the neutral, making sure > that its 'bond' to the ground in the panel is secure. Neutral should not be bonded to ground in a subpanel; only back at the main panel. And also, make sure that your ground and neutral wires in the subpanel are on their separate and appropriate bus-bars. --Rick ________________________________________________________________________________
Date: Sep 18, 2017
At 06:39 PM 9/17/2017, you wrote: > > >On 9/17/2017 4:20 AM, donjohnston wrote: >> >Having said all that, if I were getting random GFI trips with >nothing on the circuit, I'd be looking for 'issues' with both the >ground wiring and the neutral wiring. I'd probably start with the >neutral, making sure that its 'bond' to the ground in the panel is secure . . . Wiring issues downstream of the GFI are certainly at the top of the list . . . and not hard to troubleshoot. A GFI is a specialized incarnation of the clamp-on, AC ammeters that are useful service tools. They let you measure current in a wire by detecting the magnetic field outside the wire. You can interpret current flow in the wire without having to break into it. The Hall Sensor devices common to DC current measurements function on a similar principal. Hall devices can measure both ac and dc currents, the familiar clamp-on service instruments are transformers GENERALLY limited to AC measurements. Measurements are made by running ONE wire in the supply loop through the instrument's measurement aperture. You could use such an instrument to detect wiring faults by running BOTH supply loop wires thorough the aperture. Emacs! During normal operation, the current flowing in the outbound wire (hot) exactly equals the current on the return (neutral) wire. Snapping the ammeter over a properly operating power pair will show a net current reading of zero. Now, assuming there is some leakage current from hot to a remote ground, there will be an imbalance in the hot vs. neutral conductors. If this current exceeds something on the order of 5 MILLIAMPERES, the magnitude of leakage is considered hazardous. Most service instruments are not sensitive enough to detect/measure leakage currents this small. A ground fault breaker is simply an ac ammeter built into the breaker housing. But in place of an observable display, the transformer drives electronic circuitry that (1) watches for imbalance in the hot/neutral pair exceeding 5ma and (2) unlatching the breaker's hold-closed mechanism when the leakage limit is exceeded. The illustration above shows how the leakage is monitored by passing both paths through the same aperture. Making this happen in a GFI breaker requires that both the hot and neutral wires pass through the breaker. Emacs! This illustration shows that instead of taking the neutral wire right to the panel ground bus, it goes to a terminal on the breaker. So not only will this breaker have TWO terminals for house wiring, a 'pigtail' routed the panel ground bus completes the neutral path. It's unlikely that nuisance tripping is caused by loose connections. You have (1)a real leakage problem out on the distribution wiring, (2) a leaky appliance plugged into an outlet or (3) a flaky GFI. Do you have more than one GFI in the panel? If so, try moving the hot/neutral pair on the problem circuit over to another GFI. If the tripping moves to the new breaker, then downstream leaking is indicated. If the problem does not move, then the breaker has a problem. Similarly, a wall-receptacle GFI can be used as http://s.hswstatic.com/gif/gfci.gif a test tool. You can wire your 'problem feeder' to the LOAD pair of terminals while using a pair of jumpers from the LINE pair to the panel ground and any handy breaker. See if the test GFI complains about feeder quality. Incidentally, a GFI does not need the safety ground wire to function as intended. It measures DIFFERENCE currents in the hot/neutral pair . . . the leakage MIGHT be flowing back on the safety ground wire . . . or to another current sink . . . it doesn't matter. Many appliances like hair dryers and pressure washers have GFIs built right into the plug on the end of the cord. Emacs! Note that many end-of-cord GFIs don't feature a third prong for safety ground . . . it's not needed to monitor and react to an IMBALANCE of current flow on the hot/neutral pair. There are other experiments that you can use to explore leakage on the problem feeder . . . but confirming proper operation of the panel GFI is the first . . . Bob . . . ________________________________________________________________________________
Date: Sep 19, 2017
nuckolls.bob(at)aeroelect wrote: > At 06:39 PM 9/17/2017, you wrote: > > > ...Similarly, a wall-receptacle GFI can be used as > > ...a test tool. You can wire your 'problem feeder' > to the LOAD pair of terminals while using a pair > of jumpers from the LINE pair to the panel ground > and any handy breaker. See if the test GFI complains > about feeder quality... > > > > > > Bob . . . Is this correct?? Sounds like using a pair of jumpers from LINE pair to the panel ground is going to make a lot of sparks and smoke. 2nd Question: In using a clamp on meter as depicted, assuming it can detect 5ma leak, will the meter show an absolute number? or will it show a positive value for leakage on the hot leg and a negative value for the neutral leg? That would be convenient :D John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473006#473006 ________________________________________________________________________________
Subject: Master Alarm beeper chirping
Date: Sep 19, 2017
I have a simple alarm system for canopy and gear warning in a Rutan aircraft. Microswitches on the nosewheel, throttle, and canopy latch. This has worked fine for years. Now I notice that when I switch on the master, and when I switch it off, I'm getting a very brief "chirp" from the warning buzzer. This system is not connected to anything else, (except for power and ground of course) so is standalone. Could this be simply aging of the microswitches? Any thoughts before I contort myself to access the nosewheel switch under the instrument panel? FYI - 12 volt system, master switch is a solenoid operated by a toggle switch. -------- Harry Manvel Defiant N2HM PTK / Pontiac, MI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473007#473007 ________________________________________________________________________________
Date: Sep 19, 2017
Just out of curiosity, is the wiring in metal conduit, plastic flex, or Romex? I have had to troubleshoot drywall nails/screws that hit the bullseye in Romex, w/o nail plates,between the hot/neutral and bare ground wire. A lot less likely in plastic conduit because the wires are free to be pushed aside...unless you were born under a bad sign. Metal self-explanatory. John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473008#473008 ________________________________________________________________________________
Date: Sep 19, 2017
On Tue, Sep 19, 2017 at 1:01 PM, jonlaury wrote: > > > nuckolls.bob(at)aeroelect wrote: > > At 06:39 PM 9/17/2017, you wrote: > > > > > > ...Similarly, a wall-receptacle GFI can be used as > > > > ...a test tool. You can wire your 'problem feeder' > > to the LOAD pair of terminals while using a pair > > of jumpers from the LINE pair to the panel ground > > and any handy breaker. See if the test GFI complains > > about feeder quality... > > > > > > > > > > > > Bob . . . > > > Is this correct?? Sounds like using a pair of jumpers from LINE pair to > the panel ground is going to make a lot of sparks and smoke. > > 2nd Question: > In using a clamp on meter as depicted, assuming it can detect 5ma leak, > will the meter show an absolute number? or will it show a positive value > for leakage on the hot leg and a negative value for the neutral leg? > That would be convenient :D > > John > > I think he's telling you to take your shop's wiring out of that circuit. Tie the neutral side (both ends) to ground instead of the neutral. Feed the GFI from a regular breaker. If your shop wiring is causing the problem (nail, screw, etc) then the GFI will no longer see the current imbalance & won't trip. If the GFI is flaky, it will still trip. ________________________________________________________________________________
Date: Sep 19, 2017
At 02:52 PM 9/19/2017, you wrote: >On Tue, Sep 19, 2017 at 1:01 PM, jonlaury ><jonlaury(at)impulse.net> wrote: >"jonlaury" <jonlaury(at)impulse.net> > > >nuckolls.bob(at)aeroelect wrote: > > At 06:39 PM 9/17/2017, you wrote: > > > > > >=C2 =C2 ...Similarly, a wall-receptacle GFI can be used as > > > >=C2 =C2 ...a test tool. You can wire your 'problem feeder' > >=C2 =C2 to the LOAD pair of terminals while using a pair > >=C2 =C2 of jumpers from the LINE pair to the panel ground > >=C2 =C2 and any handy breaker. See if the test GFI complains > >=C2 =C2 about feeder quality... >. . > > >Is this correct?? Sounds like using a pair of jumpers from LINE pair >to the panel ground is going to make a lot of sparks and smoke. Perhaps my description was unclear . . . Let's try again. GFIs come in a variety of flavors not the least of which is the NEMA wall outlets with built in GFI. These outlets have TWO sets of terminals: (1) a line/neutral pair that faces the distribution box and (2) a line/neutral pair that can drive a downstream load with the added benefit of GF protection. You can wire one of these devices to operate not unlike the GFI fitted to the end of an appliance cord. A l/n pair of wires connects to any handy breaker/ground in the distribution box. The Romex to be investigated connects to the l/n load terminals of the outlet. One could salvage a GFI cord of a hair dryer (thrift stores are have 'em for a few bux). Cut it at the dryer-end, strip back and add some alligator clips. Now you have a test tool that can plug into any 120vac source and clip to a feeder under investigation. This too, like the suggestion above, simply adds a 'real' GFI in series with the feeder under study. There is a caveat for using this methodology to find ground fault issues (milliamperes), suppose the breaker is tripping for reasons of hard faults (hundreds of amps). If I were to built a GFI test tool from a salavaged heater cord, I think I would put fuse holders in series with the alligator clips and populate them with 1 amp fuses. I do the same thing with my 'suicide cords': short line cords with that let me clip 120 vac to various articles under test. Both of these tests simply substitute a known-good GFI for the nuisance tripping GFI to see if the fault is in the wiring (test GFI trips too) or in the panel GFI (test GFI stays closed). >2nd Question: >In using a clamp on meter as depicted, assuming >it can detect 5ma leak, will the meter show an >absolute number? or will it show a positive >value for leakage on the hot leg and a negative value for the neutral leg? >That would be convenient :D There is no 'polarity' to an AC measurement so yes, a sensitive, clamp-on ammeter would only display absolute value of the imbalance. Bob . . . ________________________________________________________________________________
Subject: Re: Master Alarm beeper chirping
Date: Sep 19, 2017
The vast majority of electrical problems are due to bad connections like poor crimps, loose fasteners, and corroded terminals. Switches need exercising to remove corrosion. Not saying a bad connection is your problem, but it is something to check. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473015#473015 ________________________________________________________________________________
Subject: Basic question about contactors
Date: Sep 19, 2017
Now that Im looking more carefully into contactors, Im getting confused. The three-terminal Ford-type contactors on my Cessna - that is, the battery master contactor, and the starter motor contactor all work by grounding the third terminal, so the top of the coil must be connected to the 12v battery terminal, internally. The three-terminal starter contactor on my Luscombe has one end of the coil connected internally to the case (ground) and operates when the third terminal is connected to 12v. So just to make sure Im understanding this, there are two *different* kinds of three terminal ford-type contactors? And I guess you have to make sure you use the right one? And, surmising further, the benefit of the four terminal regulators is that they can sub for either, by connecting the second coil terminal either to ground or to 12v? I just want to make sure I have this correct - do I? ________________________________________________________________________________
Date: Sep 19, 2017
Subject: Re: Basic question about contactors
Alec, There are two basic types of contactors that are either 3 or 4 terminal. Long duration ( battery contactor) And short duration ( starter). Starter contactors generally have the coil grounded through their base. Generally 4 terminal contactors are for start circuits and the 4th terminal is hot when the contacyor is "on". I use this terminal to energise the starter solenoid as this eliminates starter run on. On Sep 19, 2017 17:32, "Alec Myers" wrote: > > Now that I=99m looking more carefully into contactors, I=99m getting confused. > > The three-terminal Ford-type contactors on my Cessna - that is, the > battery master contactor, and the starter motor contactor all work by > grounding the third terminal, so the top of the coil must be connected to > the 12v battery terminal, internally. > > The three-terminal starter contactor on my Luscombe has one end of the > coil connected internally to the case (ground) and operates when the thir d > terminal is connected to 12v. > > So just to make sure I=99m understanding this, there are two *diffe rent* > kinds of three terminal ford-type contactors? And I guess you have to mak e > sure you use the right one? > And, surmising further, the benefit of the four terminal regulators is > that they can sub for either, by connecting the second coil terminal eith er > to ground or to 12v? > > I just want to make sure I have this correct - do I? > > =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Sep 20, 2017
At 07:27 PM 9/19/2017, you wrote: > >Now that I=99m looking more carefully into contactors, I=99m getting confused. > >The three-terminal Ford-type contactors on my >Cessna - that is, the battery master contactor, >and the starter motor contactor all work by >grounding the third terminal, so the top of the >coil must be connected to the 12v battery terminal, internally. When you say 'ford type' do you mean the black plastic devices? >The three-terminal starter contactor on my >Luscombe has one end of the coil connected >internally to the case (ground) and operates >when the third terminal is connected to 12v. This is the legacy wiring convention compatible with off-left-right-both-start keyswitches. >So just to make sure I=99m understanding this, >there are two *different* kinds of three >terminal ford-type contactors? And I guess you >have to make sure you use the right one? >And, surmising further, the benefit of the four >terminal regulators is that they can sub for >either, by connecting the second coil terminal either to ground or to 12v? Virtually all manufacturers of contactors will offer all variants of coil termination. Here's a sample from the Stancor catalog on the 70/71 series devices Emacs! Note that all variants of coil termination are offered. I am surprised that your starter contactor is a ground-to- energize circuit. I'm aware of no Cessnas that left the factory that way . . . what year/model is your airplane? Bob . . . ________________________________________________________________________________
Date: Sep 20, 2017
You're absolutely right. I was misreading the mickey-mouse diagram in the PO H. When I refer to the wiring diagrams in the service manual it's much clear er. The starter contactor is indeed 12v-to-energize. On Sep 20, 2017, at 12:15, Robert L. Nuckolls, III <nuckolls.bob@aeroelectri c.com> wrote: I am surprised that your starter contactor is a ground-to- energize circuit. I'm aware of no Cessnas that left the factory that way . . . what year/model is your airplane? Bob . . . ________________________________________________________________________________
Date: Sep 23, 2017
Subject: Voltmeter & Ammeter normal ranges
I am doing the test flying on a friend's RV-6 and as part of the preparation I set up the engine monitor (Dynon 120) to display the following on the voltmeter and ammater: Voltmeter: Red below 10V, Yellow 10-13.8V, Green 13.8V-14.5V, Red > 14.5V Ammeter (wired to show current flow in to the batter): Red < 0A, Green 0 - 5A, Yellow 5-30A, Red > 30A. Battery is an Odyssey PC680 AGM. Alternator and regulator unknown, came with the kit from Van's 10-20 years ago. My guess is Plane Power. First Question: Do the ammeter settings seem reasonable? Obviously any discharge (<0A) is red as indicative of a problem that requires landing ASAP. Normal charge after a start has been observed to be < 5A within a minute after start, a hard start or low battery would obviously make this worse so I set green as 0-5A but don't have any good basis for this. Same for the yellow and red bands. I want the yellow band to indicate that a long time in this area is a problem, and red to be an immediate problem. Normally once the battery has been charged after a start the value should be zero so perhaps the green band should be 0-1A? What charge level going into this battery would indicate an immediate problem (red band)? \ After first flight the low current alarm was constantly going off so I changed it from <0 to <1. Second flight had similar but not as frequent problem so I was going to lower it a little more but then I was able to download the engine monitor data to Savvy and WOW is it fantastic being able to look at graphs of engine data. I have no idea what normal would look like but here is a snap shot of the second flight: You can see the battery amps wander between -2 to +2, with excursions to -3 +3 later in the flight (during large engine power changes). Second Question: Is this behaviour indicative of: A. Normal operation B. Sensor problem C. Charging system or battery problem D. Something else Thank you all for your input. ________________________________________________________________________________
Subject: Re: Voltmeter & Ammeter normal ranges
Date: Sep 23, 2017
My D-180 ammeter varies up and down to unreasonable numbers. I disconnected the shunt and put a jumper directly across the plus and minus input on the D-180. One would expect the D-180 to display 0 amps. But no, it still varies up and down, not as bad as before, but still plus and minus 15 or 20 amps. I believe it is a software problem. Maybe the Dynon 120 has the same problem. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473105#473105 ________________________________________________________________________________
Date: Sep 23, 2017
On 9/23/2017 6:09 PM, Sebastien wrote: > I am doing the test flying on a friend's RV-6 and as part of the > preparation I set up the engine monitor (Dynon 120) to display the > following on the voltmeter and ammater: > > Voltmeter: Red below 10V, Yellow 10-13.8V, Green 13.8V-14.5V, Red > 14.5V > Ammeter (wired to show current flow in to the batter): Red < 0A, Green > 0 - 5A, Yellow 5-30A, Red > 30A. > > Battery is an Odyssey PC680 AGM. Alternator and regulator unknown, > came with the kit from Van's 10-20 years ago. My guess is Plane Power. > > First Question: Do the ammeter settings seem reasonable? Obviously any > discharge (<0A) is red as indicative of a problem that requires > landing ASAP. Normal charge after a start has been observed to be < 5A > within a minute after start, a hard start or low battery would > obviously make this worse so I set green as 0-5A but don't have any > good basis for this. Same for the yellow and red bands. I want the > yellow band to indicate that a long time in this area is a problem, > and red to be an immediate problem. Normally once the battery has been > charged after a start the value should be zero so perhaps the green > band should be 0-1A? What charge level going into this battery would > indicate an immediate problem (red band)? > \ > After first flight the low current alarm was constantly going off so I > changed it from <0 to <1. Second flight had similar but not as > frequent problem so I was going to lower it a little more but then I > was able to download the engine monitor data to Savvy and WOW is it > fantastic being able to look at graphs of engine data. I have no idea > what normal would look like but here is a snap shot of the second flight: > > You can see the battery amps wander between -2 to +2, with excursions > to -3 +3 later in the flight (during large engine power changes). > > Second Question: Is this behaviour indicative of: > > A. Normal operation > B. Sensor problem > C. Charging system or battery problem > D. Something else > > Thank you all for your input. Well, here's my 2 volts... Current readings depend on where the sensor is located in the system. Assuming it's between the battery lead & the bus, it will show charge for at least a short time after engine start, to replenish the battery. After that, it should show more or less zero (with some slight variation) because the alternator has fully charged the battery (no more electrons flowing into the battery) and is supplying all the electron needs of the avionics, etc. It would show discharge whenever the alternator couldn't keep up with the load demands of the a/c, and the battery started picking up the balance of the demand. (Shouldn't happen unless you've intentionally undersized the alternator to save weight, and are willing to accept temporary discharge during very short term events like landing lights, gear extension/retraction, etc.) Other time you'd see it is if the charging system is failing or has failed. But I don't even have an ammeter on my current plane, & don't plan to install one in the plane I'm building. Alternator voltage gives all info needed during flight. Voltage: At 10 volts, the battery is effectively dead, and you might not see *any* indication from the EFIS engine monitor (or from the EFIS itself). If I were setting limits, I'd realize that anything under around 12.5 volts means the charging system is effectively dead (red). I'd probably set the red limit even higher; around 13.5, because I'd want to know instantly that I've lost charging. I'd only see the yellow band as useful to show intermittent excess demand situations, where it would go in & out of yellow as really big loads were exceeding the alternator's capacity. So yellow from around 13.5 to just under that particular alternator's 'normal' output voltage, which hopefully, is over 14.3 or so to keep the AGM battery fully charged. Red again above about 14.8 or so, since Odyssey says 14.7 is a safe level of initial charge voltage. Hope its at least worth what you paid... Charlie --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Sep 23, 2017
Subject: Unsupported coax length
Looking for advise on what the max acceptable unsupported horizontal length of RG400 coax might be. I have 23" between fuselage ribs and was planning on running the coax through a grommet in the tooling holes but then started questioning if this was good practice. So opinions are requested. Thanks Paul ________________________________________________________________________________
Date: Sep 24, 2017
Very interesting Joe, thanks for the reply. Did you try upgrading the firmware? Did you follow up with Dynon about this behaviour? In view of your experience I think I'll give them a call on Monday. Sebastien > On Sep 24, 2017, at 01:47, user9253 wrote: > > > My D-180 ammeter varies up and down to unreasonable numbers. I disconnected the shunt and put a jumper directly across the plus and minus input on the D-180. One would expect the D-180 to display 0 amps. But no, it still varies up and down, not as bad as before, but still plus and minus 15 or 20 amps. I believe it is a software problem. Maybe the Dynon 120 has the same problem. > > -------- > Joe Gores > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=473105#473105 > > > > > > > > > ________________________________________________________________________________
Date: Sep 23, 2017
Yes, the D-180 firmware is up to date. No, I did not contact Dynon. The ammeter function is not important to me. I agree with Charlie, the voltmeter tells me how the charging system is working. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473109#473109 ________________________________________________________________________________
Date: Sep 23, 2017
Hi Sebastien; Flow out of the battery is not abnormal and will happen whenever your aircraft consumes more power than its alternator can generate. It is not generally a signal to land immediately, but to reduce power consumption (like turn off the landing lights). Cheers! Stu. ----- Original Message ----- From: "Sebastien" <cluros(at)gmail.com> Sent: Saturday, September 23, 2017 4:09:48 PM Subject: AeroElectric-List: Voltmeter & Ammeter normal ranges I am doing the test flying on a friend's RV-6 and as part of the preparation I set up the engine monitor (Dynon 120) to display the following on the voltmeter and ammater: Voltmeter: Red below 10V, Yellow 10-13.8V, Green 13.8V-14.5V, Red > 14.5V Ammeter (wired to show current flow in to the batter): Red < 0A, Green 0 - 5A, Yellow 5-30A, Red > 30A. Battery is an Odyssey PC680 AGM. Alternator and regulator unknown, came with the kit from Van's 10-20 years ago. My guess is Plane Power. First Question: Do the ammeter settings seem reasonable? Obviously any discharge (<0A) is red as indicative of a problem that requires landing ASAP. Normal charge after a start has been observed to be < 5A within a minute after start, a hard start or low battery would obviously make this worse so I set green as 0-5A but don't have any good basis for this. Same for the yellow and red bands. I want the yellow band to indicate that a long time in this area is a problem, and red to be an immediate problem. Normally once the battery has been charged after a start the value should be zero so perhaps the green band should be 0-1A? What charge level going into this battery would indicate an immediate problem (red band)? \ After first flight the low current alarm was constantly going off so I changed it from <0 to <1. Second flight had similar but not as frequent problem so I was going to lower it a little more but then I was able to download the engine monitor data to Savvy and WOW is it fantastic being able to look at graphs of engine data. I have no idea what normal would look like but here is a snap shot of the second flight: You can see the battery amps wander between -2 to +2, with excursions to -3 +3 later in the flight (during large engine power changes). Second Question: Is this behaviour indicative of: A. Normal operation B. Sensor problem C. Charging system or battery problem D. Something else Thank you all for your input. ________________________________________________________________________________
Date: Sep 24, 2017
I'm guessing from some of the responses I'm getting that the picture I attac hed did not go through. The apparent current flow out of the battery is not f rom a high load. We're talking a 40-60 amp alternator powering 10 amps worth of instruments and radios. The load cycles from -2 to +2 amps at least 50 t imes over the course of a 1 hour flight and it's not because someone's hidin g under the floorboards flicking the lights on and off :). I'll try attaching the engine analyzer data again tomorrow. I did manage to c heck a few minutes of data from an identical analyzer in a different aircraf t and while it did cycle up and down a bit, it never showed negative. Sebastien > On Sep 24, 2017, at 04:50, ashleysc(at)broadstripe.net wrote: > > Hi Sebastien; > Flow out of the battery is not abnormal and will happen whenever your airc raft consumes more power than its alternator can generate. It is not general ly a signal to land immediately, but to reduce power consumption (like turn o ff the landing lights). > Cheers! Stu. > > From: "Sebastien" <cluros(at)gmail.com> > To: aeroelectric-list(at)matronics.com > Sent: Saturday, September 23, 2017 4:09:48 PM > Subject: AeroElectric-List: Voltmeter & Ammeter normal ranges > > I am doing the test flying on a friend's RV-6 and as part of the preparati on I set up the engine monitor (Dynon 120) to display the following on the v oltmeter and ammater: > > Voltmeter: Red below 10V, Yellow 10-13.8V, Green 13.8V-14.5V, Red > 14.5V > Ammeter (wired to show current flow in to the batter): Red < 0A, Green 0 - 5A, Yellow 5-30A, Red > 30A. > > Battery is an Odyssey PC680 AGM. Alternator and regulator unknown, came wi th the kit from Van's 10-20 years ago. My guess is Plane Power. > > First Question: Do the ammeter settings seem reasonable? Obviously any dis charge (<0A) is red as indicative of a problem that requires landing ASAP. N ormal charge after a start has been observed to be < 5A within a minute afte r start, a hard start or low battery would obviously make this worse so I se t green as 0-5A but don't have any good basis for this. Same for the yellow a nd red bands. I want the yellow band to indicate that a long time in this ar ea is a problem, and red to be an immediate problem. Normally once the batte ry has been charged after a start the value should be zero so perhaps the gr een band should be 0-1A? What charge level going into this battery would ind icate an immediate problem (red band)? > \ > After first flight the low current alarm was constantly going off so I cha nged it from <0 to <1. Second flight had similar but not as frequent problem so I was going to lower it a little more but then I was able to download th e engine monitor data to Savvy and WOW is it fantastic being able to look at graphs of engine data. I have no idea what normal would look like but here i s a snap shot of the second flight: > > You can see the battery amps wander between -2 to +2, with excursions to - 3 +3 later in the flight (during large engine power changes). > > Second Question: Is this behaviour indicative of: > > A. Normal operation > B. Sensor problem > C. Charging system or battery problem > D. Something else > > Thank you all for your input. > ________________________________________________________________________________
Date: Sep 24, 2017
Are your lines to/from the shunt twisted pair? If not, you may be getting loop current from elsewhere in the system. Not sure how much, but worth a check. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473114#473114 ________________________________________________________________________________
Subject: Re: Unsupported coax length
Date: Sep 24, 2017
No answers here, just what I did: I ran my RG400 through grommets but also ran several other wires along with it. They were bound together with the waxed thread stuff at roughly 12" to 18" intervals. It seems to me that combining wires in a bundle provided a certain level of support. I think some of the written guidelines suggest the same. My guess is that RG400 alone thru grommets is just fine as well. On 9/23/2017 8:58 PM, Paul Eckenroth wrote: > Looking for advise on what the max acceptable unsupported horizontal > length of RG400 coax might be. I have 23" between fuselage ribs and > was planning on running the coax through a grommet in the tooling > holes but then started questioning if this was good practice. So > opinions are requested. > > Thanks > Paul --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Sep 24, 2017
They aren't my lines but I'll check :). I'm also going through the install manual for the 120 and looking for documentation on the alternator and voltage regulator. Thanks for the idea Andy. Sebastien > On Sep 24, 2017, at 11:34, andymeyer <ameyer@mil-amax.com> wrote: > > > Are your lines to/from the shunt twisted pair? If not, you may be getting loop current from elsewhere in the system. Not sure how much, but worth a check. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=473114#473114 > > > > > > > > > ________________________________________________________________________________
Date: Sep 24, 2017
As long as system voltage is above 13, it is impossible for current to flow out of the battery. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473122#473122 ________________________________________________________________________________
Date: Sep 24, 2017
I did get the pic, but honestly didn't pay any attention to it. Just took a look. Note that voltage never drops below 14V. So the charging system is working great. My personal opinion is that you have too much of the wrong information, and not enough needed information. Where is the shunt wired into the system? Is it really a shunt, or a hall effect sensor? What does the current do with *all loads except the battery removed*? (Yeah, I know you can't do that since the monitor is embedded in the EFIS.) How about with everything turned off except the EFIS/monitor? A typical shunt has, IIRC, a 50 millivolt full scale output to the meter. Assuming it's a 60A shunt the output at the currents you're measuring would be wandering around a few thousandths of a volt. That is a very small signal, and as others have hinted, relatively easy to impress noise onto the lines. And the most minute variations in resistance of any connection anywhere in the sense circuit could cause large variations in voltage at the meter. I seriously doubt that there's anything wrong with the charging system. There *may* be issues with the sensor and/or its wiring, but if it were my plane, I'd almost feel like I was getting too much knowledge for my own good. :-) On Sat, Sep 23, 2017 at 11:14 PM, Sebastien wrote: > I'm guessing from some of the responses I'm getting that the picture I > attached did not go through. The apparent current flow out of the battery > is not from a high load. We're talking a 40-60 amp alternator powering 10 > amps worth of instruments and radios. The load cycles from -2 to +2 amps at > least 50 times over the course of a 1 hour flight and it's not because > someone's hiding under the floorboards flicking the lights on and off :). > > I'll try attaching the engine analyzer data again tomorrow. I did manage > to check a few minutes of data from an identical analyzer in a different > aircraft and while it did cycle up and down a bit, it never showed > negative. > > Sebastien > > On Sep 24, 2017, at 04:50, ashleysc(at)broadstripe.net wrote: > > Hi Sebastien; > Flow out of the battery is not abnormal and will happen whenever your > aircraft consumes more power than its alternator can generate. It is not > generally a signal to land immediately, but to reduce power consumption > (like turn off the landing lights). > Cheers! Stu. > > ------------------------------ > *From: *"Sebastien" <cluros(at)gmail.com> > *To: *aeroelectric-list(at)matronics.com > *Sent: *Saturday, September 23, 2017 4:09:48 PM > *Subject: *AeroElectric-List: Voltmeter & Ammeter normal ranges > > I am doing the test flying on a friend's RV-6 and as part of the > preparation I set up the engine monitor (Dynon 120) to display the > following on the voltmeter and ammater: > > Voltmeter: Red below 10V, Yellow 10-13.8V, Green 13.8V-14.5V, Red > 14.5V > Ammeter (wired to show current flow in to the batter): Red < 0A, Green 0 - > 5A, Yellow 5-30A, Red > 30A. > > Battery is an Odyssey PC680 AGM. Alternator and regulator unknown, came > with the kit from Van's 10-20 years ago. My guess is Plane Power. > > First Question: Do the ammeter settings seem reasonable? Obviously any > discharge (<0A) is red as indicative of a problem that requires landing > ASAP. Normal charge after a start has been observed to be < 5A within a > minute after start, a hard start or low battery would obviously make this > worse so I set green as 0-5A but don't have any good basis for this. Same > for the yellow and red bands. I want the yellow band to indicate that a > long time in this area is a problem, and red to be an immediate problem. > Normally once the battery has been charged after a start the value should > be zero so perhaps the green band should be 0-1A? What charge level going > into this battery would indicate an immediate problem (red band)? > \ > After first flight the low current alarm was constantly going off so I > changed it from <0 to <1. Second flight had similar but not as frequent > problem so I was going to lower it a little more but then I was able to > download the engine monitor data to Savvy and WOW is it fantastic being > able to look at graphs of engine data. I have no idea what normal would > look like but here is a snap shot of the second flight: > > You can see the battery amps wander between -2 to +2, with excursions to > -3 +3 later in the flight (during large engine power changes). > > Second Question: Is this behaviour indicative of: > > A. Normal operation > B. Sensor problem > C. Charging system or battery problem > D. Something else > > Thank you all for your input. > > ________________________________________________________________________________
Date: Sep 24, 2017
Exactly. Joe could you please confirm that the jpeg below is visible? If so it's obvious that while the voltage seems to be moving around a tiny bit, it never gets to the point which would allow the amperage shown. It's always above 14V. Also I checked some data with the engine shut down and while the amperage still wanders around it's 1 A or less (-5.5 to -6.5 A) On Sun, Sep 24, 2017 at 5:54 AM, user9253 wrote: > > As long as system voltage is above 13, it is impossible for current to > flow out of the battery. > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=473122#473122 > > ________________________________________________________________________________
Date: Sep 24, 2017
At 06:09 PM 9/23/2017, you wrote: >I am doing the test flying on a friend's RV-6 and as part of the >preparation I set up the engine monitor (Dynon 120) to display the >following on the voltmeter and ammater: > >Voltmeter: Red below 10V, Yellow 10-13.8V, Green 13.8V-14.5V, Red > 14.5V >Ammeter (wired to show current flow in to the batter): Red < 0A, >Green 0 - 5A, Yellow 5-30A, Red > 30A. Assuming you do monitor bus voltage and have active notification of low voltage, then there is no operational value for monitoring battery current. Battery ammeters in airplanes were a carry-over from the terrestrial vehicles where the minus-zero-plus instrument in the battery charge/discharge line was the simplest single monitor of system health during normal vehicle operations. The ammeter would be expected to show a heavy recharge rate right after cranking the engine . . . or after a jumper cable start on a dead battery. After some interval of normal operation, the battery accepts less and less recharge energy and the needle migrates toward zero. Under normal ops (votlage about right, battery charged) the needle would rest at or just slightly above zero. If generator output was insufficient (low engine rpm, high system loads, regulator voltage drifting downward, generator failing) the needle would present some value below zero. While truly an analog instrument, its BEHAVIOR was closer to 'digital' in that it was never intended to be READ so much as observed as a go/no-go panel instrument. Ammeters of all types are of little to no value as sources of operational data in flight. Ammeters in the battery lead are pretty much useless when compared to an accurate voltmeter paired with active notification of low voltage. Calibrating a battery ammeter with alarm settings will be an exercise in futility. Suggest you move the ammeter sensor to the alternator b-lead and eliminate any alarm functions from this reading. The ammeter is most useful as a maintenance tool for diagnosing why the VOLTAGE is low and/or the LOW VOLTS warning light was illuminated in the air. Bob . . . ________________________________________________________________________________
Date: Sep 25, 2017
Bill Thanks for your reply. I was hoping for a more definitive statement from one of the very experienced technicians on the list. Your reply mirrors what my intuition tells me. Paul On Sun, Sep 24, 2017 at 7:05 AM, Bill Watson wrote: > Mauledriver(at)nc.rr.com> > > No answers here, just what I did: I ran my RG400 through grommets but also > ran several other wires along with it. They were bound together with the > waxed thread stuff at roughly 12" to 18" intervals. It seems to me that > combining wires in a bundle provided a certain level of support. I think > some of the written guidelines suggest the same. > > My guess is that RG400 alone thru grommets is just fine as well. > > > On 9/23/2017 8:58 PM, Paul Eckenroth wrote: > >> Looking for advise on what the max acceptable unsupported horizontal >> length of RG400 coax might be. I have 23" between fuselage ribs and was >> planning on running the coax through a grommet in the tooling holes but >> then started questioning if this was good practice. So opinions are >> requested. >> >> Thanks >> Paul >> > > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus > > ________________________________________________________________________________
Date: Sep 25, 2017
From FAA maintenance doc AC 43.13-1B section 8 (downloadable for free, if you don't have a copy): /*a.*//* *//*Wires and cables are supported by suitable clamps, grommets, or other devices at intervals of not more than 24 inches, except when contained in troughs, ducts, or conduits. The supporting devices should be of a suitable size and type, with the wires and cables held securely in place without damage to the insulation.*/ That help? Charlie On 9/25/2017 10:07 AM, Paul Eckenroth wrote: > Bill > > Thanks for your reply. I was hoping for a more definitive statement > from one of the very experienced technicians on the list. Your reply > mirrors what my intuition tells me. > > Paul > > On Sun, Sep 24, 2017 at 7:05 AM, Bill Watson > wrote: > > > > > No answers here, just what I did: I ran my RG400 through grommets > but also ran several other wires along with it. They were bound > together with the waxed thread stuff at roughly 12" to 18" > intervals. It seems to me that combining wires in a bundle > provided a certain level of support. I think some of the written > guidelines suggest the same. > > My guess is that RG400 alone thru grommets is just fine as well. > > > On 9/23/2017 8:58 PM, Paul Eckenroth wrote: > > Looking for advise on what the max acceptable unsupported > horizontal length of RG400 coax might be. I have 23" between > fuselage ribs and was planning on running the coax through a > grommet in the tooling holes but then started questioning if > this was good practice. So opinions are requested. > > Thanks > Paul > > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus > > =================================== > - > Electric-List" rel="noreferrer" > target="_blank">http://www.matronics.com/Navigator?AeroElectric-List > =================================== > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > =================================== > WIKI - > errer" target="_blank">http://wiki.matronics.com > =================================== > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" target="_blank">http://www.matronics.com/contribution > =================================== > > ________________________________________________________________________________
Date: Sep 25, 2017
> >On 9/23/2017 8:58 PM, Paul Eckenroth wrote: >Looking for advise on what the max acceptable >unsupported horizontal length of RG400 coax >might be.=C2 I have 23" between fuselage ribs and >was planning on running the coax through a >grommet in the tooling holes but then started >questioning if this was good practice.=C2 So opinions are requested. I seem to recall that AC43-13 used to quote a 24" max, unsupported span . . . waaayyyy back when. But I don't find it in my latest copy. Unless you're into energetic aerobatics, I suspect that 24" is fine. Alternatively, you could add some 'bond studs' to the inside of the skin at the half-way points. http://tinyurl.com/hxczu3r Bob . . . ________________________________________________________________________________
Date: Sep 25, 2017
Charlie and Bob. Thanks for info. I'm right at the limit but don't think I will be doing energetic aerobatics. Paul On Mon, Sep 25, 2017 at 11:50 AM, Charlie England wrote: > From FAA maintenance doc AC 43.13-1B section 8 (downloadable for free, if > you don't have a copy): > > *a.* > *Wires and cables are supported by suitable clamps, grommets, or other > devices at intervals of not more than 24 inches, except when contained in > troughs, ducts, or conduits. The supporting devices should be of a suitable > size and type, with the wires and cables held securely in place without > damage to the insulation.* > > That help? > > Charlie > On 9/25/2017 10:07 AM, Paul Eckenroth wrote: > > Bill > > Thanks for your reply. I was hoping for a more definitive statement from > one of the very experienced technicians on the list. Your reply mirrors > what my intuition tells me. > > Paul > > On Sun, Sep 24, 2017 at 7:05 AM, Bill Watson > wrote: > >> Mauledriver(at)nc.rr.com> >> >> No answers here, just what I did: I ran my RG400 through grommets but >> also ran several other wires along with it. They were bound together with >> the waxed thread stuff at roughly 12" to 18" intervals. It seems to me >> that combining wires in a bundle provided a certain level of support. I >> think some of the written guidelines suggest the same. >> >> My guess is that RG400 alone thru grommets is just fine as well. >> >> >> On 9/23/2017 8:58 PM, Paul Eckenroth wrote: >> >>> Looking for advise on what the max acceptable unsupported horizontal >>> length of RG400 coax might be. I have 23" between fuselage ribs and was >>> planning on running the coax through a grommet in the tooling holes but >>> then started questioning if this was good practice. So opinions are >>> requested. >>> >>> Thanks >>> Paul >>> >> >> >> >> --- >> This email has been checked for viruses by Avast antivirus software. >> https://www.avast.com/antivirus >> >> =================================== >> - >> Electric-List" rel="noreferrer" target="_blank">http://www. >> matronics.com/Navigator?AeroElectric-List >> =================================== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> =================================== >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> =================================== >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >> =================================== >> >> >> >> > > > Virus-free. > www.avast.com > > <#m_1130766257584959573_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> > ________________________________________________________________________________
Subject: Re: Manual intercom PTT
Date: Sep 26, 2017
All, Thanks for all the responses on this thread. I wanted to post an update for anyone interested, as I've made significant progress towards solving this noise issue. The headset is a DC H10-20 that is nearly 30 years old. Around 12 years ago I installed the Headsets Inc. ANR kit but the mic is original. I'm not sure if electret mics "wear out" or degrade over time, but I decided to replace it with a new one, and after some research went with the Pilot Communications PA-9EHN, designed for high noise environments. That mic made all the difference. Wind noise only breaks squelch when I turn my head significantly, and in this environment I can live with that. The mic was $80 and I plan to buy another one for the pax headset. Also, and counterintuitively, I removed the leather cover over the foam and used just the foam cover. Oddly this really improved the resistance to wind noise. I read this tip online somewhere and tried it- glad I did. I found a software setting buried deep in the MGL V6 menu that changes the mic from "VOX" to "HOT." This controls how the mic responds when the transmit button is pressed. I'm not sure why one would ever use the "VOX" setting but it was set to it by default. To be clear- this has nothing to do with the VOX intercom, just the mic setting on transmit. Anyway, after changing it to HOT, and installing the new mic, I got the "loud and clear" response from a tower 10 miles away. So I've solved the two issues that I had- nuisance VOX activation by wind noise and poor transmit quality, and I now have an acceptably good intercom/ radio setup without installing an intercom PTT. At Bob's suggestion I bought one of the el cheapo ($10) throat mics and played with it. It did show some initial promise but was, well, el cheapo. The next step would be to order a better model (around $150 with great reviews from the motorcycling crowd.) Because of the success I've had improving the conventional headset, I've shelved this for now. Thanks again for all the help. Jeff Point Milwaukee > ________________________________________________________________________________
Date: Sep 26, 2017
Thank you all for your input. I've eliminated the warning function and chang ed the ammeter band to green only. No more annoying warnings! Well, we still have very high CHT warnings but we have a plan to deal with that. These rec ording engine monitors sure make it easy to test a new plane. You can concen trate on working the problem without worrying about recording which cylinder was the highest or lowest or whatever the issue may be. Biggest lesson learned here is that for future early flights only critical i tems will have warnings enabled. Today I went along with a friend for moral s upport on his first flight in his new (to him) Searey Amphibian after a year of repairs and improvements. The previous owner thoughtfully included a swi tch for turning on or off the audio warnings from the engine monitor. I turn ed it off for takeoff and sure enough, the bloody thing lit up like Apollo 1 2 but my buddy climbed straight ahead ignoring everything while I cancelled o ne spurious warning after another. Not sure he would have been able to be so disciplined if it had been yelling in our ears. Sebastien > On Sep 24, 2017, at 09:57, Robert L. Nuckolls, III <nuckolls.bob@aeroelect ric.com> wrote: > > At 06:09 PM 9/23/2017, you wrote: >> I am doing the test flying on a friend's RV-6 and as part of the preparat ion I set up the engine monitor (Dynon 120) to display the following on the v oltmeter and ammater: >> >> Voltmeter: Red below 10V, Yellow 10-13.8V, Green 13.8V-14.5V, Red > 14.5V >> Ammeter (wired to show current flow in to the batter): Red < 0A, Green 0 - 5A, Yellow 5-30A, Red > 30A. > > Assuming you do monitor bus voltage and have > active notification of low voltage, then there > is no operational value for monitoring battery > current. > > Battery ammeters in airplanes were a carry-over > from the terrestrial vehicles where the minus-zero-plus > instrument in the battery charge/discharge line > was the simplest single monitor of system health > during normal vehicle operations. > > The ammeter would be expected to show a heavy > recharge rate right after cranking the engine . . . > or after a jumper cable start on a dead battery. > > After some interval of normal operation, the battery > accepts less and less recharge energy and the needle > migrates toward zero. Under normal ops (votlage about > right, battery charged) the needle would rest at or > just slightly above zero. > > If generator output was insufficient (low engine rpm, > high system loads, regulator voltage drifting downward, > generator failing) the needle would present some > value below zero. > > While truly an analog instrument, its BEHAVIOR was > closer to 'digital' in that it was never intended to > be READ so much as observed as a go/no-go panel > instrument. > > Ammeters of all types are of little to no value as sources of > operational data in flight. Ammeters in the battery > lead are pretty much useless when compared to an accurate > voltmeter paired with active notification of low > voltage. > > Calibrating a battery ammeter with alarm settings > will be an exercise in futility. > > Suggest you move the ammeter sensor to the alternator > b-lead and eliminate any alarm functions from this > reading. The ammeter is most useful as a maintenance > tool for diagnosing why the VOLTAGE is low and/or > the LOW VOLTS warning light was illuminated in the > air. > > Bob . . . ________________________________________________________________________________
From: "Ken L. Thomason" <kenlthomason(at)hotmail.com>
Subject: Troll Avionics HyperVox 4-position intercom
Date: Sep 27, 2017
Hi, Can anyone help troubleshoot my HyperVox 4-place intercom by Troll Avionics ? I can=92t hear myself talk. Squelch is off. Passengers can hear me but I can=92t hear myself nor them. When PTT is down I can hear myself and other CTAF pilots hear me but I can=92t hear anyone on the crew side nor myself. Again, they hear me fine. Any ideas? Ken ________________________________________________________________________________
Date: Sep 28, 2017
Subject: Audio Isolation Amplifier Boards
Issued an invoice for boards that didn't get paid, hence I have 4 of these boards availble. This is a BARE board that let you fabricate one of these http://tinyurl.com/ngoo6hc Cost is $20 each, email me privately please. Bob . . . ________________________________________________________________________________
Date: Oct 03, 2017
Subject: Audio Isolation Amplifier Boards (SOLD OUT)
ALL FOUR ORPHANED BOARDS HAVE BEEN ADOPTED . . . THANKS GUYS! At 08:47 AM 9/28/2017, you wrote: > > >Issued an invoice for boards that didn't get >paid, hence I have 4 of these boards availble. >This is a BARE board that let you fabricate >one of these > >http://tinyurl.com/ngoo6hc > >Cost is $20 each, email me privately please. > Bob . . . ________________________________________________________________________________
Subject: Re: Dual batteries or dual alternators?
From: "Flying Patagonia" <tintiescobar(at)hotmail.com>
Date: Oct 04, 2017
Hello to everybody, does anyone have the best diagram for installing the dual EFII, with two alternators and single battery?? And second question, how would be the wiring with the bus manager using 2 alt and single battery Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473322#473322 ________________________________________________________________________________
Date: Oct 04, 2017
The best wiring diagram is the simplest one. Look at Bob's diagrams http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/ and pick one that is close to what you want. Then modify it as needed for your system. Save yourself $600 by NOT buying a bus manager. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473323#473323 ________________________________________________________________________________
Subject: Re: IVO Prop current limiter
Date: Oct 04, 2017
Bob and all, Did we ever finish this project? The message attached below was the last one I heard about it. I don't know if that means it worked, that it didn't work and we gave up, or everyone just lost interest. I don't have an IVO prop, so I don't need the limiter. I just wondered if the software that I contributed needs any additional refinement. Paul A. Fisher Q-200, N17PF RV-7A, N18PF On 7/21/2017 11:17 AM, Robert L. Nuckolls, III wrote: > Got the board stuffed. > > http://tinyurl.com/ycemckye > > <http://tinyurl.com/ycemckye>I need to get my pic programmer up and > running > for a couple other programs. I'll pop a 9023 chip > and see how critter works. > > Bob . . . > ________________________________________________________________________________
Date: Oct 04, 2017
It used to be that there were two versions of the bus manager, depending on whether the system has one or two charging devices. Robert Paisley said he had plans to modify the design so that it would work with either one or two by setting a jumper. I don't know if he ever did that or not. Sent from my Android. Sorry Steve. On Oct 4, 2017 5:15 AM, "Flying Patagonia" wrote: > tintiescobar(at)hotmail.com> > > Hello to everybody, does anyone have the best diagram for installing the > dual EFII, with two alternators and single battery?? > And second question, how would be the wiring with the bus manager using 2 > alt and single battery > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=473322#473322 > > ________________________________________________________________________________
Date: Oct 04, 2017
At 08:08 AM 10/4/2017, you wrote: > > >Hello to everybody, does anyone have the best diagram for installing >the dual EFII, with two alternators and single battery?? >And second question, how would be the wiring with the bus manager >using 2 alt and single battery It would help to know what airplane you're building and the engine you selected. Also, how do you intend to use this airplane? Mostly day, VMC fun trips? Any long cross country over sparsely populated terrain, mountains, at night? Any IMC ops anticipated? Bob . . . ________________________________________________________________________________
Date: Oct 04, 2017
At 10:46 AM 10/4/2017, you wrote: >Bob and all, >Did we ever finish this project? The message attached below was the >last one I heard about it. I don't know if that means it worked, >that it didn't work and we gave up, or everyone just lost interest. > >I don't have an IVO prop, so I don't need the limiter. I just >wondered if the software that I contributed needs any additional refinement. >Paul A. Fisher I've got the boards and parts to do a proof of concept assembly. Got two projects burning hotter than this one. Haven't forgotten it! I think I need to get a full time job . . . seems I had more spare time when I was gainfully employed. Bob . . . ________________________________________________________________________________
Date: Oct 04, 2017
Subject: Alarm output to audio panel
Hello I have an MGL Xtreme EMS that has an alarm switch output and I would like to connect this to the 360EX Unswitched input. Wonder if anyone has this combination of an EMS and audio panel, and if they have been able to get these connected? I wrote to PS Engineering, and they suggested I use a PMA8000G that has a feature called flightmate that can be programmed to play a recorded audio on an event, like a switch closure. Thanks Hari ________________________________________________________________________________
Date: Oct 04, 2017
Hello my friends, thanks for the answers. Here I give more details so you can help me with my wiring... Im building an RV-7, it is in the final process, I have just hang the engine, an Aerosport Power WildCat IO382; with full FlyEFII ignition and injection system, and dual Ecus. My avionics are one garmin G3X touch and Autopilot. I wanted an aircraft with dual Alternator and initially single battery, dual alternator just because Im going to fly in Patagonia Argentina, and here there are not much runways, and initially only one battery because I dont want too much weight, dont want to waste money in a second battery, dont want more complexity, and in my point of view I consider batteries super confident, I have never had a battery failure, but I have had an alternator failure 3 times in my life, 1 in the car and 2 in the aircraft... so I prefer 2 alternator, and one odyssey battery... may be later if I desire to make a very long flight, or a very difficult flight like going to the Antartica, then I would consider going there with 2 batteries and 2 alternators, but not know... first I have to put this machine in the air... Said all this, I saw AeroElectric book and the Z-12 diagram. And I already have all the components of that figure I bought everything in B&C, including the stand by alternator for the vacuum pump (40 amps). My question is if this diagram would work with my dual Ecus EFII, how would I need to modify this, does anybody have a picture of the distribution of the components into the aircraft, and the switches in the cockpit?? All you can show me to clarify my ideas is very welcome... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473352#473352 ________________________________________________________________________________
Date: Oct 05, 2017
I'm considering the Z-12 as well for a SDS EM-5 FFI system in my RV-8.=C2 - I found this on another popular forum.=C2- The link can be found belo w. http://www.vansairforce.com/community/showthread.php?t=118810 scobar(at)hotmail.com> wrote: hotmail.com> Hello my friends, thanks for the answers. Here I give more details so you can help me with my wiring... I=C3=A2=82=AC=84=A2m building an RV-7, it is in the final process, I have just hang the engine, an Aerosport Power WildCat IO382; with full FlyE FII ignition and injection system, and dual Ecu=C3=A2=82=AC=84=A2s. M y avionics are one garmin G3X touch and Autopilot. I wanted an aircraft with dual Alternator and initially single battery, dua l alternator just because I=C3=A2=82=AC=84=A2m going to fly in Patago nia Argentina, and here there are not much runways, and initially only one battery because I don=C3=A2=82=AC=84=A2t want too much weight, don=C3 =A2=82=AC=84=A2t want to waste money in a second battery, don=C3=A2 =82=AC=84=A2t want more complexity, and in my point of view I conside r batteries super confident, I have never had a battery failure, but I have had an alternator failure 3 times in my life, 1 in the car and 2 in the ai rcraft... so I prefer 2 alternator, and one odyssey battery... may be later if I desire to make a very long flight, or a very difficult flight like go ing to the Antartica, then I would consider going there with 2 batteries an d 2 alternators, but not know... first I have to put this machine in the ai r... Said all this, I saw AeroElectric book and the Z-12 diagram. And I already have all the components of that figure I bought everything in B&C, includin g the stand by alternator for the vacuum pump (40 amps). My question is if this diagram would work with my dual Ecu=C3=A2=82=AC =84=A2s EFII, how would I need to modify this, does anybody have a pictu re of the distribution of the components into the aircraft, and the switche s in the cockpit?? All you can show me to clarify my ideas is very welcome... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473352#473352 - S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. iVBORw0KGgoAAAANSUhEUgAAA6cAAAGcCAYAAAAlPtY3AAAgAElEQVR4AeydB5zWxbnvZ/sCSwfp sC9FOojYRaWoCGrsGk1UTDxqEtPOuUlukpNybsxJzrlJjJ9jjInR5BqNsTeiEeyogAhSBKWjVKXX Zfv9fZ95n92XZZeqCch/4N1/m/rMM/PUmcnavGlDdTjAcMAJVV7WAZb5SSerro6tysr6+Gt4MPAK 6Xp90u1P8k8gkEAggcCeIOBz5J7iJN+OXAgcCO08GNp4MJQ6weUjF0+TlicQSCBw6EIg+9CtWlKz BAIJBBIIJBBIIJBAIIFAAoEEAgkEEggkEDhSIJB7MA09GI3lwZR7uKY9GHgdjGb5cIVXUu8EAgkE Dj0IYBlLLE6HXr8czjU6GNp4OLc7qXsCgQQCCQQSCOwOgcRyujtMkjcJBBIIJBBIIJBAIIFAAoEE AgkEEggkEEgg8A+GQCKc/oMBnhSXQCCBQAKBwx0CB7Ku8HBvc1L/BAIJBBIIJBBIIJBA4JOHQCKc fvIwTkpIIJBAIIHApw4CCKiJkPqp69akQQkEEggkEEggkEDgnwqBg1pz+k+t+cdZOExWOr/d1lKx ay875XIlZNzGF3xOVoQ6LJJrAoEEAkcWBJI1qEdWfx9KrU1w71DqjaQuCQQSCCQQ+HggsEfhFKGL X3Z2NLBy78TAryatNVCX2ji1AhzvEPTIsaqqqiZv7nOyc0KlrhZHUiDvuLefi48uRWaml2yomupN VjoNRcR0VVWqs77QhioTIi0yUaNQqcfGjRuHnNwcpa0OuTk5oaysLGTnZFuabD1XUw+l51qqb4WF jSx9eVl52LFjex0YUbYKVABesQ3Z9i4Tjg7b2NZY35hqz38rKytDjurkgfQOJ3+XXBMIJBBIIJBA IIHA4QABaCEBWuY8BrTS6WdmGzwO7/w7cT0+753OehyuSUggkEAggUACgcMHAnsVThF8fOLPy8sL jZs0gSqIkiAgVeoXCctuTa4RzNKuX0Z4qixaFmmrdS9hUBKp3kmaUzkhm6veidhYGcTmPdKeBFdL kxUFZcuoSuV7XKsP6cvtk70PpKmIeRGPQN2trPhcJWFv/FNPhRkzZoQ2bdqEvLzcMHTocWHDhg1h /foN4b333gvHHTc0LF60ODRq0igMHDQoPDdhghHGDh06hDFjxoTiVHcy1o88ufIj6LladaT+JiLz Tu2xKgiuORH81WoHwu+ugTSZge9ZobKizITn8vJyqwPEml8SEggkEEggkEAggcA/GgIfB/1B6Qqf QV5V4g2yqkXT0nQNpXJ2ms7xDfpJPIRT/8GnuNKWfCoqKiyOx2sIJl538klCAoEEAgkEEggcGhDY o3DKxJ2bG6MgmL7//vthypQpoaSkJL6HiDTUDn2olqAJ0cnPzxPhyDULH9HJt6qyQs/xO4QBwuKE xr6niQ3v/BkC5ETE3/kz6f0dZVJvnvnu6bwM3hOHcNbZZ4dnn302PPnkk+GYY44J06a9ZcLoRx99 FNq2bRu27ygJTz35RFiwYGHIyc8Pw04/VfGfD0VNCsIFF1xgaebMmROWLl0aGjWSRVWB8giuwXXC WymCSX2wEBOHOnKF4BI3G8HbAZomwP5cURmJJ23o27dvGCQhmbSWTmm9TCs4+ZNAIIFAAoEEAgkE DgMIGA1LEzruyyvKRZ8rjD5KXDVvplwpjaGbFkQj8VqCrubk54QKKXednvMdWgid5Ud+SUggkEAg gUACgcMLAnsVTpncmeQRvKZOnRoQxHr16iULY560m3sQTtNwIG2+4iKISgI1YoGQFnIKaogHhAWC gtBI4B4hjLIzCQ3fyI/ggidpuefnhAirYqYgyj2BvAjEIw5p8iVwomU9+uijTehbuXJVmD9/Qdi8 eVNo2rRpOPGE48Mvb7vd0nVp21yW1Pl2n0qlTDBFwPQ62Qf9cYHe6+bvC/Ly7Zb4WUrHdzTCudl5 eq93qhfPsYUxFc8E0ybrHovu+PHjQ//+/a3+tImftz2mSv4mEEggkEAggUACgUMfAlA46BxLekRM Q46UtNnyoioqKjIvofXr14ePPvwwbN6yxWhtQUFBaNWqVcBzqbH4kjIJsizF4QdNJzhPYLQ2/c4+ JH8SCCQQSCCQQOCQh8BehVMmd4QorhCJE088MVxyySWxYbjV6n1DgTQIhk4oXJDi2YUp3vFMGQTi u7DF1YO/z0yrhLYO1PPNk6DJO6tTut45WCfTAix5+dpRzzdLgjMWU/JFAL/0kovDUe3ahRUrVpjQ +qGI4hWXXmRa215H9wqt5fr7wksvh5YtmhkxhFCef/75obS01LO0+lNffgi+/BBY89IWU6uHynPX I3/2DKjLbkGWZ/JbsGBBuPPOO2tgRDzgnIQEAgkEEggkEEggcLhBAPpdWRn5AGhfEy0dWrVqVXhG Hk0rV64M0FjeceU7vMK8efPC1q1bbW+IoccfH4499lijsXh1QSehicTll9DHww0jkvoeiRBgrH5S IZkDPinIfnL57lU4dYTJkjaTDuYHMWFjoCwT+uqvHHHQZGKZRBB1V2AnFrx3oZLvvMeaicDm3/y6 c+dOI0xYa11QplTSZeaxbds2Sw8ho2zyw/pJ2QS3aHoduBLvwgsvDCNHjrS2oZElX+rBNyyVvMvV hkm5snzmFeSHc88ba8SU7y1atNCmSDssf9I4YQROlEcZ/qOuvCeO1xuhlmd/R0bE9yvx7T6nUmUX WPuBAz++ed4WKfmTQCCBQAKBBAIJBA4jCKRJnAmgmzdvDg8//HBYu3Zt6Ny5c+jXr19o2bKl0Vks qQTo7vbt2402b966Jcx5553w+uuvh+HDh4eBAwcG+AWnoU4/DyNwJFVNIPCphYCPy09tA5OGfWwQ 2KNwiiAIMiE4Zcnq58KjC1ZZErbSctQuFSosLAxz584Nt956a2jWrJl9QwPKOkkIx8yZM8MNN9xg 1xNOOCG8/fbbYcCAAXKl3Rxefvnl0Lx589CzZ08TEhHe+DZixAgjShAb/yEMUkeEWOr5lDY2mqDN iiBmEDAEuA4d2ssVd0FopjzHnDPa6sWazWXLlpkr77Rp08Ls2bNNOKV8ymX96Lhx40L79u1DFxFI 3I2AQYXKKtN6mE6dOtsz8KD8snLt7ivhHcvrQw8/FIq7FZs19o477gjr1q0L/VX/hbJ4ZqcNnFvk nkR+p5xyiq15LVMb6yOime+sL9LlAX8CbeY9wnQSEggkEEggkEAggcDhBoEcbYrIRovTp083+o+7 7plnnina20V0u5nROWg9AVoHXeQK/YP2rtH+EIsXLw4vvPCC8RR4drki2+MfbjBJ6ptA4HCEAGPy UAwHU69MPvxQbNuntU57FE7pFP9VVUVBEGGxokJCqyBCh9eHixAGXIDRZiJorlmzxuCHGw5C6rsL l1ge72onXIjOY489Ebp3L7Z1lG+++abl26NHj3D33XeHlNZ2svFQjUCsAhHsEMpISx0gQLyDQL0j LSrl4QLUpUsXrZMt1UZOH8iKmRfee/fdUCLhmM2OHn/88XDuueeahvbpp8eHrl27Wn53331P+MpX vmICL9pZ8gUGWF9tR12thUHA5h114LugYPXIL2gc3pz6pn1Dg/vM+L+FfgO0NlTrbV+YMDFcdtll obi4OEycONGssaxztfW3aVg6ktUdSDwbzHX1/qDtWGZpexISCCQQSCCQQCCBwOEGAWgbS2+ee35i eHPK1HDGGWdoQ8LjQmGjwlAqOgutdWUstM7pnfMDHPXWuVMns7LCMzzzzDPh3nvvDRdffLFtaIiS OgkJBBIIJBBIIHB4QUC7+aSFm6za9Z3eBNsdLy2gZkvAOqpN61CoXfMqy0ujZlLWQtx9bXt3xFUJ a4puAhSCHRrQ73znOxI+HwtLliwJ3bp1k3Z0hm1+MHXKZLkGV4bXJr0WjmrbOsyR9ZKNk0bINWee hMi+ffuEs846S0JjN/2KRaRKRKTQnKocXIypttZhIiBWadv5wry4wdLYsWPNInr//feb9RJrqgnL GzeFSW9MDl06dgzz5r6jNaTZtrkTAuyYMeeYtZX1tB98sNwsmkVFzbSOdKcKlAsu7VKZlJujsiCQ WE1zsyXbq064/EYYqPGCU2Wp3JO1myACfM9UKrRu2SKUS6g/Srv/DtXamIULFxrh7Nm7d9gmay2E NlvlRNdpwCiLNEfspIVR8qTMLICrb2wYwfpVruxUSDl7CuzKr5QHFOQ4rHR7K+GAst5LIko+0Frv Oeu6wv+eY+/nV4D9zwpZnwy8UIh8UkGY/Ullvcd808PLxhoRM9vIWMt8rptRfd8y3zkDXTddfAar d8eRiOtxnJNXXYa8WuO+ijX+qhuBeY94VpbmCXA6ziN8j3F4Z7ueap6kSI6s+iQC9eBHeT62/J0r 93hOwqENgQPpIfo7pgOna/F6t6kozV/U4IcU3HgksQTnlUmvhtdeey1cfvnloZcUtkImUyLjqWS5 Cueh+7Zhkkrh3pW10Mkd6XWmnSSkXnXVVeHBBx8MTzzxRPjc5z4XGhUWiBbHjZLYlJG0KJl9Hwrb hDA9pqDphq+qF2eaV6lt0PwkJBBIIFALAR/DtW+SuwQCHz8E9mg5pbhachNMeESog3jYe1GlcjE8 JjgRl4lcVAnGCUH0+uuvD6effrpZ+DZu3Ghur2g5WTuCKw+5I8SeNmxYWK4NiHCBRUDkvmXLVmH0 6HO0ZrS5MV1YPhkUEJByEbYcCcmUiwWR647tO+Q2PFgutx1tN2GIDLsKt27dmmZYWqypojqhmdah pnr00OZCiyS45pqFlXWj1HncuGstD4hWXn5BKJXbEOessdkSQmNluY6Dyak2yyx1ARCU5S67qeLi 8Ky0t2tlnW2jsmfNnGWE8LjjjzOtMNbOxo0bGwzUMKu71y9bwi6CrrURwpymi2axFWF1WQ3Y10wQ MH0Q0SQcIhD4Z/VFZBEPESAc8tWA8WWHUMYRQh1jmCtCFNea8VVPS+r7lvku83735DZ6d3vtWEP5 zJ/k4flY/ainUsE0E5jz/KeINcJhFAI1P0t5ZTt/V+dqvoxeFp6fZVDPnwMVIDPzpa6ZgbmMembG yfye3B8ZEKD/3dOJsUZoKj4ATyfOGL/yyitDd9FkPJRQJtcEpQN/wE3yQAlcWQF+R/x3nOUbVlZo 6+c///lw1113mYB65RWXmyKaMUC5xEdY9fGunG18sKSH5TYsSeokBXYZeMyU6gOzpkLJTQKBBAIJ BBIIfNIQyNq8cVPkauuxnIo9MmtdtQhC06ZF4Y9//KNN3lgnWedZIYGJxEz0MFQIoKvkttuiWVMT vpYvX25CHGsxIRqEDXL3Xbdurbn7ttOuuO/JtRdBlDgQDrSgLbRmdKksrWWyPjZt2szyx52YDRKw dFImBioIEmneX/Z+WLBoYWik81SxTFIu7sNYbnH1wd1348YNoavS4wa0RM/dilMmdEKQ2mgHXuoO gYIQQqB2lJaZUM2RLQjTMF3G7ElAhci6UIz7crkE2JayjkJUqSf5bN60KWzSjzW3rVu3kkX2A9W/ i62tQSBn8yY2Wlq1erUJ/Y0aNdb6GVlcBcf2HTuEtm3a1hBT2ogmOk+C7fz58wNW4R/+8IdWVyf4 BtwG/hyM5bSBLP8hr+nfJBzeEAB3D8UAbmUKgf7M+CfsCffqfqvbxrrPu7YfS1MtXke7Uy2MbJ6h Dun6FUiJF/NLC6vpea9ScMUKVK3BzXfq5FeUaRVSoiGguiCABTVH8fcU9lTvum3OzId0ntbhx7zk 9fF3mWmS+8MfArvghHmMgJxGnXdrHJZ/VwaBtyint2zZGp56+qnQUkrcCy+6OGwVLRbSmOBJLmAr 4wE88s0FbXzoI2U7zsuHwMYyuA7eYY1l6c79f/lLOOG4oWGEFOTb0kt0fHyRJ4oTaD38AjQV+r1a 9PiWW24xWou3FOMsCQkEEgjUQmCXcV/7+lN757TtU9vAQ7Rhe7Wc7qneICnCFJ2HsMo5qHfc8Ztw tVxrmOQhFFgjIRQIihCNSa++qm3g59o3hD7eL1myNKRSKQlsW8NkrTs5/vgTwltvTQsdpcHs3r2n bSuPcIdl9M47fxuaKF1ZJW6zcucVcZk+Y7qVPVqbKCAE49LDhkfU6ec//3n4q9x8Jj73nCymRWGo 1rOw4RFCb5EEx1nanKljx05hm3b9mzlnXhg54vRQKAvrrHfmmqD5/e9/P1x00UVQQyOGhRKiEajZ fAHiRl5dunSWANtEa1vfD0OHDjXNK2tacVVizW337imDx86dpbaudvHSZUq3LPTt0zu8POn1cHSP bqFduw4SkDeFmXJvvvmrN5s7NEwdxJRycON1grynPjmcvh1pk9zh1DcfV1331sf/rImfceXjKfPe 2827hkLdNu13GzSXNBQY8zVWHcWjHrzDUoQrIhuv6UnWnnItbUCIjcIrcagH8VEm8mPtAwK4pdH8 wb4BBxr2Bg/qDFyIx497q3e6rfsNowOtaJLukIQAilXwwfET/Hj33XlhhQTDz372SvOgAkdsHwVw R/jkAT4C/MrVT1FClZ7BawL0eGdZqdF6FMPEwwsK3mGIjohbLr5hrTyyoMN8pw4e8KQiPopxyuXY OPgRninTcD6Nv54muSYQOJIhUJf2HQmw2Jc2J/Tt48eE2pn6APKGQOBm5owIQtSOHSU2yXNO6Dnn nBNOPfVU00gioEI0+G2X1ZANiBBgR4wYadvF5+Tkhmf//pylff75l2zd58qVq8zVF3ed9es3GEFC 4ITAwHA5MaNchFGOfWEzJKygbL7EDr+4Cn+od1hHsVQS96abbjIrLDvoLl68JDz1zN9l0SzS2tBm ZrEl7Q5pWimT+LQPd2a/55lyJk2aZOtbr732WrOusgEUZ5AuWrTIykcYR1jG2nnzzTebAL5mzYdh /LPPhXdV9qxZs8MpJx4vS+sWy7tAbsQVYjqBEbA14qh+ca1x3S6iHvySkEDgcIWA43BD10+qXcwh jCvmEC+bshh3/tzQtW6d6sar+73+Z+ynCMC7WmbIi7Vx1SxdkBhaQ/RUT+psyyo05As0D5Kc5QQF OuIqX/NngZY+wGyzVwBty83J0o8pXmlR5aXni4auNq8yt9bzaygN7wkseYChd3giRPAuCiO7ttES JH8OOQhg9ASf9uXHNoC7xDMckyIFPLU8uPIcf9XVWmMqhXKVfoUF+eZB9b5o9siRI5RTkKU/un+z YSGeRVukqF29YmVYLq+oldoHYvGChWGRfkvl9eSbJG3dvNXOIy+V0hf+ggA+uoB6iniPtWvX2d4S 8A3gJjiKhZTxwVjnhzDKd84Q52g46DzxkpBAIIFAhIDP/wk86odAAp/64XIwbw/ScoqWP2rLmczR TrLOE/dbdsl7+umnA0fFcP+uNjk66qh2ob2Odhl67JAw7rrr7KiZl1560QjItdeOC4tEePr376ej XebaodoIpwiU7GrLRgdYJhE8O2hdqTNtEBI0oFd89rPhtJNPDo89+ogRmu9+97umBf3DH/6gNaSd wje/+Y3Q7qijwm233RZuv/12bYI0NnRSPanfjBkz7epEq3HjRuE61Q/tLYyaM6y4y1WLceSZthYX F9uuxAiky5YtDV/+8pfDX+RKhJsQ9eaZNbe33vqrMH78eFvTQrmrVq9Rm3qF9RKmjx1yjIhhma2N 7dmzV+g/aIBtlgQBhmjaelcRUjZC8jYfTgOBuiYhgcChCAHGMQFmlvnLFV97w1kfh96mus97TC+l mn+PLr2eS7ySFz/cCdkACeGOOY46Mj/BuPPcVF4fuEbivosyzS1TWFixEOVrIxjiE9hoTrnK+0Jr 7nVtODQ8Vuu2MTOPWOdaSzSbu1EOm9Yw9/Pd25yZLrk//CBwIP1ImjVSRE/VTvxYP4cNO9VceqHn F16onfglsOYKb/OlnH133rwwdcqUsGnDRtsUKTc3x4TRTZs2a5nMxjB48DGizeNEf1vIg2leeOGl l8IoeUw998LE8J1vfdvGCfjGeMYz6yjRfJbZMEYgReyLwRmq8Awojz0wvjgTHaU56aH75qnsEZJr AoEjFAIHMuaPUFAZnWP+SMLBQ+CghFNUnlgwQV46pHfv3uH6L34xNNE28MOHDzeLIRM+55Sy7rNb t+Jw9lmjzDKIdRFBFvfak046WXH6m8CWL6LBzrwFBYVmdVUJRjQgNFgUYSBheCgT5hJGbOTIkcbE NdK3c887z7SiWEph7DjzjDq0kkb0o7UfycW2u9WV7erZgIG8IFysDb344otMgISpa9G6jUEXIkdZ EC/auFM7+KJdRegkDRs6fPjhGrnzHmvt5yzXEtUTiymbMbEmdciQIWbBvemmL5m70YCBA+w77cEt GVdgLMddunS1XXrLVCbBBW/KrdaaYOpRpav/gD/3Dn9LVO8fmE5+SdgXCOxtcgHeDYWDSdtQnsn7 jx8CJpiqH+lJxjjkhPEII8umK7ZTeQPF7s0auDf8IH19Y5ba5OTioVEWmsqTgw1jOAOateu4G04T cw/TTH13ak18n95H2xyHZwbv2rRqG8o1J65dt1ZLI44Pp512ms1tHMmBoi1uzL474bQ3zDH6NRjS sKrvO+0hUDebk9KKNOZH5jfm8CQcDhCg/xvGAaeBdfHbcdnxILOlcVOu6jB58hu2iy44sWPH9pBK pewImGZFTcPW7dvMA0uoH6q1Nnr2rJm29AccRmHLOIAWckxMu6PahOba06JRYX4oatpEPEC5CZmN tWcDY9qEyjQus4zmeG1EiLCLQJrq3kPH05SEv/71r8YToJgePHiwWV2XyYrL8W8s2eF9kQTXCsbD Hub6zHYm9wkEEggkEEgg8PFB4KCEUzT7aCKNKVGd0FKyYVGl1oDgNgNDxe57MD28h7ixBgRmiuNU WmrjI6yDS5cuUepqW48JMYDIwWxhga2sjMSSPMif91gLsqVR9XIRRC2oPmzcRHoX7CA+q1atCtPe eksWzQ9CcbHOU+3XT8RvXtgq92IEZDY9gsDCnBK4982eeIbo8S5XAmS17tnIibpQPgI5zCT1p45o ZCHIuDXPmTPH2tpIwjoC8ooVy024pk4IxQTSsC43Vy55uPPJPhrXl6kNDgfKUZa7BL45U8CVH4H3 Hvy9ihDPCByjEgErSmQaYlstvpJjFSZQHvmwbg0rSHwb41JfAnl7Wdz7e9Jy789c/R3xPG/y4Jun 9fc8+zeuPHsc+6A/ns6f9/eamd7vuXo9VUBNPWN9Ypv12sKudaWtvOZPuh88osWmPUCcr7rL6B/y IVC2JYlNt3f+h2+ZweHh7/w55rFrXI/DNbaj9o3Hr/u+Nkb9d16fXdKpjjzTSpqAtR+lFSG+izCI RyWl66hXMa/dG8178rM8de9l1vQP+WbEoRwfD9zXTed58a0mL8s/4ir54k7PsVNsZIYFh5qTjl6L ZZG6NtjRUemmeD/aO0WpknBG8LIAirfSvC+Ujm+eLuav8aTxxvxCsYMGDDSlFcovvEXYKO77//6D MHLEcKvfw088FYafcmIokPCHZwneGgMHDgpTdM4y6/PZ6A1mm/QoBpmPzd/SK2N1jw2w3cBVH9xw KZv6eP18jEfBxFplbYuw8fmG1sX1rijZKtMWX9KczXFg3VI1850lTv7sBgHHAYcrEbwP/J5nQmac us8exyI28Kdueo9mR5UJBzOD18vHHml5x8/fYc2nr1HIenzy4N7c0HUPjrLEB/dbaCNKIHbu57g2 +IiKilqazR4PI6VwBqdRHJ8gIRV6zrId8mSpTiqVMtpNntD/QcJ16kM9nF6Du2xCOHHLBHkcbANw 9p08UZrgzYQrL7wJVlTfwNDbADwixDMhktwnEDhyINDQXHHkQGD/W+pz5P6nTFJkQmAvwunuU7NP 3GRiR8fo6owhnYLQxboThEgCTBHWTtZoIpAuWrTQNh/CPQcBr6Rkp1kHIFpsSIA1E0KGoIhbmJdB XuQJAcpVOZxvRrkQLcqFKEFMPA6WVqyWb8ragPvQagmoxxwz2MqkDZ06d7LNkGDkIJYIqFg6KZc8 OUOVPCmPckjjHCb3vKMs4iDEUQeIM+18Ty7M7BYMsUMQ7dataxSQp72l96vCkqVL7QxWysN9l500 EUxNEBSfx8YnBPLkF2Gu9+lyYWIpO76HMSSyflRROyHCHPONuhvjCcOrz2Y90dWYUL7p3s5709UZ VN3KzkG5sTxuEKgsL16mA5hBfXjjablyFh2CL8Hr5/AjD9LRJnune9es80xZ5KmEJLcAfAmZ/cyz xefmAAL1IlAffuTFj3rxzNl4lAsT00R9yjt2V2YTGvC5SG7fMED8sLKTnysbCgsbSzuvjTmkPCEu +XpfoFTZLqsBeZMWRt77CiZOMdX+2CDb0CbeWnpuqTZp4y6tEQaAGtf6WjyJ+JJOutuFeASvF/ee lvv6At89jqcnnt2rUnZ+JrDTz/pc75BNDc4wu2lBNUuL0VCA0FbGNWywoG5FEpc6AWvyZTzQLtrL e+BlfWXlAdPYfyqlpm6AztMbLvoYAbZKYOXqnrGTS7lkol+eyihV37zxqs5a1NETuP9b3Wm31U71 VLzYHrnJFtDn9H+sL1GoJ9/9ByxIg1uirSHVvb1TXNsF1Pq/dpMzRdfmctrkqDziFMsGyJMwbdo0 Y8hbiwnHLXK55jNCkayrhcJFV/wxz7Ar+XtSvGkXdsM/vFZQ8lm9tCFSjnBSD1Y371PwSZ1kcbze rpjyeYYjt5TM4sT+iXjNS+DOO2DPM7Dn/p577gmr+vaTENG7ZnxQ7yTUwtH7gP7hnjkD2Pl8B+0E 9/27jxGHIe8zA9/3FiinvuBvPU/mJ68Hlse3354hOjkgzNQmgsx7eC2RFzQTJW0/KX2ZB3lHG8Ad 8Ilx1094AE1+5JFHbGd7duKfKa+AJrJ4nq1zxrfpKDiUvKni4tBTPAB4Gsd8ls2nKH1RtlAWyl4U 3NSprc4Opyw8mYAdafjFNlZr08OmqlNp+F0VUoEAACAASURBVPOf79dYeTwM7N/P+BEXSJ999lmj /Sz9SaVS1gYU5hHekV7VB6vkXQKBTysEGpofPq3t/STa5TD0ufSTKOPTnudehNPY/AMFMAQM4Qvm Ci0oQiDrnyAyEL3Z2pkW912EUdxq2O13jQRU1qeedNJJEiTbKV7cmQ8CBOGl0/kXiYfu9OyBo1jI n3dvyVIKAUPgpR648W7cuN7ekRfHtQyS4EhZlIuQisvvsTqKBkJYKsGYMvjBJBrRE3PHphFOsHnH 96IiCSQi1C9p/QvlcVQNhBiBl7i4CmGNod2zZs2yNqI5xgLLua4QVYj1ngKCemEBjKWOlMnJk9BU u14Ghh+BNVcMJAE4OZOCBatSPK4JnGJCabsz0g5T2uGMsLcZpgg4cqasEln+kYmlH2K7FSEyEFIU NFZ7c/KwOEXBGmY3BixoYpiAle5MkM2C6SYeV5gpwRmrjZghQrWY9Cy1sTYPNswotbLoS+pFPQ80 1MBG7XIY8A4YfCDGf/xTT1r/jRo10ja9WqZNOc4++yzrL6zwbHyF1X/QoIFhypSpVp9iMVW4rL2/ 7IPQSkqHlStX2PpA8uc9SgvinHLKKVJiNLKqw4Ah+CPk0He0yK1vme3ze+pI2xHsEB68HcCJcjxe fXDhG3H4kQeBd5n39aXzd8QjbWaw8snXaq5aIEzRL/r52PB6kd7Lq3lHfIUYF7wFJ+KYxrUf2AAj lCpKHZ+Fw8TKk9AXm0G92ASIM5DFDFMX/UfeMvgqLvlSBsIiZbO+rVoeGaS39qfrViSvi759+0bv DzHWRPCxAaMd2xCVAeAtTQVnmOPAS4cPcQn+7P2EGJcjDwmVXAMf6mDwUFvtqnoSgBXpmBuZP5s0 aRz+40c/0Nq9NWFlx5XhDDHjo8XUs1s6liuY7VQqZXi7deu2MGLkCFOsNNI8Eb08Yp+zTpV6kz+B NmXCHbxCKKEuJlwIkMQBR2kr98xpVleLy9yYiYsxT+J17NjJ8nKctgKTPw1CIMK5MsydO9c2CwTe 4BXw9uBx/Lnule97CnzP7PvMuIwd9bb1LXiPYoW4TaQEefHFF8PDDz8kV/HTDR87d+6kes4zmtlB +0gw9lgXun79OmUZ88AbgY2OXGiE/jMP4lFE3Kt1HikeTWPOP9/oAigJaUBBlyXcJx+UfX+85092 JFy34mLR0nfD6LNHm/L3sccetz0sPnPBhaFFq5ZGg50+MHbAUeZKaPMvb/sf5RZC+7atbaNE9oQA vy+77DJbaoPAjTISPqV9+/YR96FH6XGSCafkPoFAAoEEAgkEPlkIRGngIMvIJIgQgMi4VJvgh5AI oYMQsL07tBNhDTcaLIcwUrieQcBgDHFfw9KJVhTGbMiQocYQQaghlFifqsUwweg548h7GMR8xVkv l5+XXn7ZLF1YH3D5gXlls6WWLZqbhpe8NmjDBQRSBETqBjGDaLIWlrVa7Tt1NqhQBj9CbGdk6pz4 Ue95897VpkrTzZWOuvTs2dM0vAjHCHm8QytMPdrIKsNOm7jqYdmlDlhXe/U62pg8K6jOH8pFKM4R 5a6UZWXHth2hdIeENTHdZqmG4VY9yrLKdEC5tMZphnLXOkdm17P2PvIrDBDl0Faubgk0Aq9EMMEQ fphXBGnclMsqy7RTKBaV6jB92lQpG+YYcwxsLOi9MjOmIFqeEK6icES+xKM8r4MyilYXpdFLrZ+r FSC8H2gnoaYMe9q/P6Q1mKocz4dn8AJc+N3vfmcuY6+//oYsVmuNZeMc28t15AHu4JyDR/zeffpp PVRUTIBr1HHiCy+GYyS04s6+fMVyHSvUySzqM2fOMuXEb35zu45OWmL4QXnWb2kX72zaxgBqIABn r7dH8Weufualf+NKGgLl8HMhKsaP37g/0EBKGTgtAEv6kuDlcu/5887b4HEQQMEN4gB70mMNwdUd +FThMq9vsQiNo9IKc8njGz9lKAUKZ3qqXOE97XPrPfkx1kp2yiKpsZKfhzCsNut/FXNIuj5eJ58H sM6A/7j+0aeMDWBHvIgvkflG0OM737w9mbgFU0wduTpcclEkqTWkox45eXGNaZXmNcoDDplljR49 OozWrucGAH2rMlxR+QU6N7p8pwnsDj/Ssk7viiuvDDuFfyWaI6g7nhkGF5VJPSibeiFURmE04mHs J4RS4tFXCKJx3DNuWWIBmKNVGyGX8WNdYHkBPyoa+4b4UcDw3jMgJX92GQ8R5hEo9A14h5KTMcCc Al0D7wxfFC32WyY9qh1f5OJ4FnPc/W9meZn3xMxhbtY10qwgHCqTMoUxkxXa66izo4/uo/qUSlE3 2urZunXbUFxcLDwrUbk5UtixG34cwygyUXpgtWTJCmVtlCfR8uUrbGx37ZoyJW2joibCYai5gvIA p7L0LCxSsdXystoWlko5uEi76rN/xOrVH5rCdNDgIdqFf23oUtwt9BKfgGLa28P4YRyCj7SHOhPy 1Rbo7oYN6432AmP4k29961v2nXkfCzAKY+AYlSpx5rEIyZ8EAgkEEggkEPiHQOBjEU7r1hTigIXp ZQmJaO1x90H7D7FoIQHR3UQhxMRFgIQAQxCIwzoS3GLffHOarE4tTEilDCPMYpxgtnwnXdL5N9Jz jipC35gxY8L06dMtv2bNmhihhEmMG3SIr5NWF4YNCxhl+SZHrDuDYI2V9jRXRzQ4U2B1EwHMF6El QPxw/0HQgJlgrSsbG7GGhXIaidEkT9qIFQjLhx0Vo3QwHFjTEGLR2L7xxhsSYJqELp27hjLVyyiq lVL7J191oUzqD4wefuRh+8g7YABhpo7cOyyJAMxgQOGEHVZOxHkmPX0AE0t62sv3zHy555v/iMu7 Cy64wHZCZg3Qyy+/Ylbjzp0719TD60RcL5P8gTsCAHWjbA8eh2up4JYtWGe2iXikJXi/2MN+/iH/ TDg5HHhvG3jJwj1AVm/OyOU4pAsu+IxZ+a+8epwpPWgjm1w99viT4etfu9k07ig1Xnllku63h1de nRSuuvKztoPqYJ21B37B8CxatNjWWrF2ip8H2kif0kvZ2hUkk5l3mBCXeASvO9f4DHyxasXv9jL9 pzZOPEMQeAP3mG53nMhM6/cOHy+X99SLHy57wjBj5KgO72Bu+blQ5vWmbMYDAZwAj4jvOAAMEOq5 nn322aYgYKzgGuhpSPfkk0+akgDlFmVgheEIimPVJ1u2bDYvDODN2Fy0eGkYfsZpNh8wsBzWlAtD 7bjpdeCZOLhxc5YxCrI+ffrYelTqy1wFc4tgOkUbrRD/ZO0SjlWIpQmMCeYA3lP+Mer/ESNGWP1x yeU969kJZhXWNZfxoA2OfvOb39gYGjVqlFnOsKANP+MMw/XZs2eZcg8PE/JACECZh4cGc2sPzSXk j3WJcml/qkdPm0tysjXG0jCkbaSnL6MnRI71CTBFOcdczRFfzN/sGUCgP4YPHy78fsX6h/YyZ2F9 og9Ih2cK9WZei3nHcvDcoEzeAfMk7BkCwAm6Av6jzKWvgJvDtG5q3hPqXuvG82eP58+Z15pxJqUC fcY8Qd+jBD112LBw1jlna7znmNCMhbGlrJWM541S9LJ7dLeuUiil5y/ETetuVY8ymSfAK+gY+a5e s8raiYfUNtECxgSkACUs+0mwVW4jeZi8+MKLljdj4X0pcoukFGWOZtznaY5h3KKYIk/g5HTBrjwL fsxF544+K5RojB2j3fCJ6+1jHv79739v3lLM9WdovNEm4A6PERuRCaXkPoHApxcCyRz98fatz90f b65HRm61ksEBtLdeRBZBYOJHQIRwfOYznzGXIIgJgirrMNkko3OqV02J2zetD88//7xZTFlz+tpr r4Vrrrla6fOMoMGEQSSNAGEVrFQZYg5h4iFC1MN+yhFCd5527MW9FqEglUqpLutUjwtCx67FInrS 7itNyC3UGWqLw9MSRhE2sIjBDMBgYfEslXUQ4ZRgeatc3N0IEFt+vF+6dKkxaGyJzy6AMBbs1gsL PkwW2C7du+sOYaAqLJw311xCq9Mwgqm7/PLLA+teYG6LVdcsCd4Q9rqB8oAhlt6rr77arLTAg/fA gCtEGDhRLyzT9EMUBsQcCF5xvU5cL0kcAnEchuSBMEAezhQRj/cET0Oc++67L5ypLfxh2KkX622v v/760Fdr3IAveVI/FWBplUkk9Fz1/q9KP1wMb/vO3WQNKrE42WLSq5QflvSj1M72nbpKkVFhbcDV 2tuaWaeY+f79Jb23myv50t68/MIw/a03w+MS/LFocxwRffTccxMML7RA1IRjGPHvfe974XhdJ0yc aOkvvvhibU7TKBzVto08Buab8Aqu4wEAM4XCBesrygXiAmPK9R+wwjotnqwGzg5vv3o9qSshs+6A VSn5U29wQZBySEceXjYJuG8o7OmbUoYcpWU8koW1Q23D9TklfAYG4AY4gtCGqzt4iBDEWPG+oE7c IxThQgjcsGLwjh/4RBzwgF07+RFwwWPMvvjSy+bGihDH+rFHH33UmOhJmkvYIZyxQciEO9ZBw1G9 93oQh3qB4xPVtyiYEPwQHIHQqXLLfuKJxxU/2HzF/HbPPfdEwa28yhRbeH7gZguMUVwhzJmiSjDA dR2BDYuUQbxa7rJZcRz/6U9/CnPnLzLBr0WLltrBvJ/Kvd36BjwEdrS/WbPmtoZ+/vwF4f3lH4Th GkeUQ317aP5k7sMK1G/AoLBDijGEUHAL4cPhSJ9yT360lWO/HpKb5E3Xf9HeoWyBcWe3YOZRlmAw p6Ac+va3v23zHmUhHKNgY+zD2ANHcI25nzLosyTUDwFgVTcAM34oaVj64XHAJXDVv3s6vnsc3vm4 9u91r5lx/Zu/8ysCHTXjmfLKyuUho2Up7aWsAI8qNb6Lu6esLPq5q6yXJTt2hi1SzNHdrC2HVlIX 8iA/ucHIc6lVGDfuC+GZZ5+R0miRlkV0CCdoXlz30VoJpNGVXAkML1kigNA5T268PXr1DH21VpSN vcDFcgmP3UVXo3U2et9kzm+UC97BP2yWpRS+40c/+oHotHb6lTX6j3/8o+Eq4wVlCkqWYRK+GbO4 yHu9HT7JNYHApxkCPu4/zW38Z7YtE77Mp0nYNwgclHBat4jMToBowZBhXYDJgShAbC+9VEe7iKF5 /tmnjVmFYMBcwuT9/e9/N/dbGE4EVNajsuYEQuMEhzJ4xhUICsp7J9q49cFYYsGAYeJYF6ynN9xw g+rSPEx6caI9U+9+YvRGjhwVLr7s8vDIg381KwECCXV2Rpa8nZnDXRbtL2sjIaBWByEaa0lpGww1 TDhlQ+wukgWlUHV58bnnbCOoXiKw5i6stj39t78ZA4mgCXwoE3gZtwpXUA/+Ug8CZaBtBskd3nYV MddLi7NVcMbqA4MDQ7l69SqzKOEiCNOfktAAA40QjkCOAAvh54y387X+p0iMcZXcsWij/sR81WYB 2wTLUgkXL8sqDtwpm7oTlx1Cd6aJO7CjHQjaXleuMMMoAmD22ayKs2DbtmlrljcEN6w+P/3pT8NA 9d1Vn7/aBH/yoi27tNdaemB/vM5RcKc7Y38iQAEPmG/qyhphmHQsw8B853btHKljBrCQw9SMGTs2 sEkNDDsCKwIXgihwAA9x1+aefsYKBZ7T1wTSUAZt42ewFDxxJaM+mb/MVhKXdMS3/tFHnhkM9VlO PS1CGfE9jefDd97FPDz27te69bG6q1w2IVNqpVe9NCYbayzMkUDz29/+1hQvCJvgGwIQgur/3P6b cOklF4thbKtCYjvJCxyiTQiu4Dj1o8z6At+wUMJMgkPnnnuuKbEGDhxgR1agzEI4ps9gWt1ySV7e bpQ1fk85Pr6IQ32ACWkRzpbKWgkOYB0C7xnfKKWoP+7HrKMrkWDavk1Ls7gy32FRLC4ulqA5xdpE GjWI7CWgMn/F9lEH8DCWnx2+eO3Vshj3lKX2yTBEVteJEyYYXJgTEe5vvOlG5ZsKc6Xo2q5NZN6Y 8kYYOEACv8Ydro2V6odNW7aakoMNpTRhSacS+10yg/URbWMjNK786Bvq17p5MxM2sbqiGABnXPhk 7qatKPKYp/E44Rv9yzhh7nB40o/AkB8eKu52bI1P/tQLgbq4Tr8wJlzo4tnxMhNXyYz3Hoi3p5AZ 1+N52XxzK6T1pSKQM4IpccATcJh44JrVTzhSsR1FmzwmtFEY6UjFXBSFR+WgV7n6ViohFyXWFZ/7 fEhJuIVmVpoSOFdCb3TDZc8I3PSVkY2bEzWGe0gQZb5lLIJv4G4TeSp16apddoWDBIcPsKFeXPML 8sOst6cbfWbMtJWQyrFKWHAnaFwxT6BgAX+pN3MPwfHXHpI/CQQSCCQQSCDwD4fAxyqcZtYeYgYR w4IKgw5Tk0p118YFrcK9f/pj2LJ5izGtrP3E4sh6Epiid+S+AzOPqxrMvuQVIzxGQJWfkT7xXLB5 RkzT5fAdNzmuMFK45UFsIEC44k2ZMtmss+zqByGaPmOGCGxFOO+Ci20Dm5ZiqueL+SN9MwkYytya A6HyYEyBGHAIIe5NHC2DayDM5apVK0M7MZAw1kPZVEkVv//++42gt2nTWoLgAtts4bNXXhWZTmlt EWoR1HAdtPZ5QaqDl1/zijJ5r4B214kwjADabOpDu9goadasWeH2229XnVaHL3zhOm3q84oJRQhL P/zRf4QzR42wPLC2ILzizoQWGQUBm0LQPmtrunCHM/kDD4Q4ry9X4vKNe678qJftHGxglBCCxVuv Sb9s6bLwheuus/U/v73zt+Hmm79q2m3gCK7gMguThPXriiuusP5DOCUtQl9cyxb7h7oZY0Jduae/ qI/uVaLhCN95pk7ACeShrnnSrFN3rJXUmXv6Dxzh+06188RTh1m6EsGFOhUXF+s5WJ/DnI85/wJl q7VVqh+4Bs6B6+SV6tHD4qpSYfvmTcbQUw7wIxhuqV7UDCaUMyp5or6Uz88D7whWX6UhrccDBjQK XCTEZ7uloQYX3mX+qAfpcY0zQUlZSLwENIbXpIMBZd2Y12OXfMne6shV9dJYom65Yv7YYIzxh+sf ygYEdkIruQGiHIlrFmUpljWlSrAjH2ACUxlxJ8KGcimTOrBbLGshgRPKAXAEd1v6AKUGcwc704Lj bHKGRwLjHisiaVCKUD/yBHYwz3HNZRSMKdeWG+g9uy2jPCB/LDXkgWWQdrz00oth9OizbWwxzhgv l156qRjcQSoj3+oBE02dlkmo5VgM6o61h3KBML2lRulPhDdtpG5jx44xq/oACZs7S3aY4mrcuHHW T/M0LzbSWO0sgbyZhEiEQdbMsbkWnga9evWytXPde/UMb+o4mWaaWxAMURrQVut7XXHiiPfClzTc aStrVZmraTPzEvBgJ2ncS2HecT2mLxHS/11H2kydOsXmaZqCMM64Ac4GR7UHOBvOpvGOeEnYOwQc P+kj4Gc4k74HRxyHPSfikcYDz/sbPI3NkSqD4HlaPwpvoTEEd/3FGurW+DjXoqICo6HXKNniVRUW vjH/C/f0n7J2lmjHcnklMb+sX78hNNK6/Wo8mhRs/bjaQ7l8ZzwzdqB5gwYPsrFPPFfogLvgndeX b+Cgv5shOt9ZCkeUKRwTRfkjR460+GxOh5vwds3ZpKeOtC9CU0stmJv2H5xUIQkJBBIIJBDYDQLM Mz7f7vYxebELBPZJOI0TP1N2LRH0XJwoAHB+FktMEERjm84W69iso+2OycYkffr0Dovk8rh+7fow TOvAjj/hxLBJwukdd9xhjCyMEWv9YHbY5Q8msXHjNFEU41ohl1fqkCWLQK4IIO5FMHloY1W4ZIQY FwEHywXHx5x33rmybKwO74tRhAEbJVdUXHoRPD7U++2b1oWjxdCt/fAjc8clP2MAxNSJO1N5CAJY WXQr4lUtCcvP8SuvhPmrMIGkuTS75IeA0lE7AS9Zsjiskzsxgl/fvn1sZ8MnHn8irBaz21oCej/F Wy5XXoghAg2bSRBszY2uas4uASdma2P6LdaXqvhK8IDpFYMrYpqtDVYot0WLZiaksva1eyplzPxa WXUXLVwgV6f1xkTj/gjjzbq4ZbKknjFieGgtt1QsMsAAuOZqvRpMEn0L0wGjyw8Bo7KSSsJICP66 ZituDSOsT1XWLRIGVE8E0wIxJIvemx92iEkYoM01WFu0Zt2akN9Y7sjag3WHzrxrqX77+te/rvp8 EJZJuEH4gNmgv2EbPpKVCiEA5UaToiZm5UbgQWjF0r548aLQsX074U08uB2mGYY6fi8ICxYuVJ6k KzCGp1OnzsagqBu0CzIa9wpjYtYLB+2YHX0gD4Q4dmHGggVssDofLesSeA4DaYK1lCKNFBft/1wp HbCSIhSBz7hkkg9xEcIICNLWZ2oX/Q2cgDXt9XhcndkiDeX55Ob9wnfvA/CVAKzYBIi6WnkqQNmr U+KVHWu3bt1m7uQcar9dwiQCzTYJW1gFsXJw3FOxXPZoGyGdg93buFee1Fsiibmp5ufLjW7TRrOw /eu//quVTf/BXOISiKB31pmjZEHdGDZrjLLDM1Y92liJIKUagmP8yJcx5+3inlbhLnjpJZep/3IN tpfIRRpBEKtekYS3b37zm2GDXPk6qJ9gULt06WppSI87LS71rG/LEkICKfod5USlCixnzKsTKnRt 3rxpuFZWTPqOuiAIAu9hw04NwAuhb4e8QBCqYXxpA5YlcBMrOt4XKN5ovx1nIUEPIZUxk22DXP2s PGL75ErcpCh87Rtft7Xq9OeNN95k45j6b5ZiY/Toc6x/KjXnMPYGDhxsZZ16yqma3z40wbmx2k89 hg873RR1bFyWk6tdt/WPPCnP2kyD1HDwCEtrY42HcyQYn3zqyWahom+xmnItYB7ftt1gu3XbVlMQ MLeOHHmG8CrPcJr5lvhNmkSLd1y2oL6ivXQb5SWhBgJGJ9Pwr+8+k6Zyb/2Upm01maRvPG7d9wfy DC2iLHCDe4ROuwp3bO7QO/qSexSlKHM0KPTMPAAug2kKuo+XOM5ycqMC0+c26F1XWT37iAZOmDgh fE679rJRke2iTfFKDEXhVy4egHRs1lRWUhoqsuNRNT7nwScwxzkcwX9wkTkB+i+JM3To3EVjXMoo Q8OsMOz0M2zuIB3LgHitWcfmhmxNBlUanzZ/yt1ejYkw0V1NsHwAU/qm5kNyk0DgHwMB8J1xkYn7 8AaMCwLf/ce49LHHfRw7wnDdM148nl9Jz3u+EyjD02em5Ttp/EpcmzMYr0pPXL6T1uLo2RRafKfu Xleuygta6OV42XhjYdggHwYqaZiT4E1jfS0pRdeUR1pvF/nFeLGexHOY5UEbNcmUy0tQSYz/Um5W B+KZQi5dL57rBh/91MeD1dMf0tdMxR4KMNJRL1XMfrQRGYMAbfe2mbLQ3h6Zf/ZJOAWGdNreQm3H gGiRSMDgg1Awirjzvjl5im2c0LdfX2OWWrRuZUIjrjZo/2EwESbY3IM0MNYUbzvngQT6UY7xd9xT LeVPpzMYfEBQV9yKGLDrJLxgFcCtlc2J8vIrZZXtGzaJIK4RAWssoSZLGeH2VlEm90fd465oLVae 1cIbobsJxbB3WZK6cPOt5GgZVaRMQhVMqFlcVF8YU9aIDRg4IKR6dBczXBWKu3c3N+PFS5aY9pd6 4YrHIIL5N2Sl0gQvOz7Fv7ETarshDQdgw+CoUF0QdBDguxV3NTe9lASLVKqbhN+tVid2Sf7Ot/6X 7ZbMgGHtI0IWgxkhJEd1Ij8mA46rqVbbOHIjQsL7P04iDCJCnFBcoLDUlh8DC0sXOysbDdd9toSX +VpD9LLcuR596OEwWBbmG75yo9wlxeyLOdi4YVP4w+/v0rrNttrVuG0YKmUCcDWrqQRZIUH4r5/9 TBbqdmadxNUL/PpAQmyhziaFSWdHZlyr2ymPefPetaMCWBfaUgoBhAjwAEt1XBPZ3QQdGC3qq4tZ U7fu2B5+K4UJTDgKk4USaFk3iIUfAZONrMiHY2dmyErG+ifvR4RXXE1Zb4wF370CUADQxz7pcjVl C4XqP2sQgTuBeOSf6V4Ow4Xwg5AN7iD0+vc4EZMy9onlQVYS8niFBYw48b0YRfVFvuC1QH3/05/c EkaOGm6bN+HqTv1//evbTLDmTECbeIW/BhzV1etvmfFH+aOwqdCYydEvT8LZYLlk/+KXvzJBZ4cU VOSJOzSu3LjlXandZBGkqK3/jEqIUkRhDQIarcM8x3kl4h3toD333Xe/jeFHH31E1th1ZjU9S2vZ gX1vMb1vynr7ex1Bcax2Tv7qV79mc0u5NkQB71HqmBeCrpRP39s/xhhtVD9QDh4P4ADuyOPHjzdr JYz1DC0VQInxkeYVFBBnnXW2WWvZtGXuvPdCf80t7ADaV2c7IrzuEPHDy4J8s7DGpNtNmykfmOar P7HiPPfsM6aAYQOaR7UGlD5etnSpWYGpS4/uqXDvn/9s8MGSC+5hKUYgvvbaa0NTwbVIihmsTmax Ut4+L1MWAeHRrvoTFVshNNe46di5U7jt17fa3DFYZ0JPmjQpLJAyEcVFNwkTlDdkyLFyu79FY5Lz mavCl750YzhLluSd2rEVYdjKUva0yZgPikqXZ4Umf/YLAt53JNpt7O1XTvsW2cugXLrOy48YU5sH 8Tyuapbu4ohhllbfLS24YMlifOY2aDTWeebhv2mJy3IpIs1bSWOe+YbphpHJ5oPEVUb24xueL1a2 lak8yY/vCjY3KD5XPII4UxVXfIRgTgFgXasJ1MqHDfcsZGlc6kZFW3AB1sq0isfax6/xL3MFYfcv 8XvyN4HAJw0BxgBjiTHmeI/Q5cHHoI9RG4v6yJV0BL6Rxj2W+MY9fDfBeWnie97wHn7v7z0/4sOP 4cGYGXhPGuoZFc8YeKIyi3g2Lm0MoxSlDYxr+2t0GX7FylB9jS/QrvtE58d7myOsQN/pPrYzS3OF 15Wya4PONpdyG6GQ+pKHGVCUIfVi8fMS+QAAIABJREFUPol1ZW5hMmK8NzzaHba1+dfeeT95P9hV 7SA7+BhkDnKOAqrqWxWX5qhStZkcoXe7YlGDQKBzvJMajFTzgQ7AFa9RoQ6zVme78AWTh/YdSjZ1 8tQwb/57oWXzFrKWDgjTxIDB+H0owQKhA0snDPguyGedqq5UdST2gJn6rx11WcuickByBg9MFEww h9IjDLYRU4cFhPWdM2fNNFTrJQGD8rZJQFwn16Imci1C25oD4kuawqrFQK2ooN16xz+Ip3YjRKig jT7YYLTZTh8BCfcj8kVA6iRmb8rkyWG56tJRliPcDBEQcT9EcIEZdateDfDSN+LzrZ48gsB7Clhy GSAm8KpsrEhYHzlOori42CyjTDgISKwtw40JgS9aQEZaO/uyXlLugu4+awNO5fqgaqh8vtc/OMXc AENZT6rFnKM937Rlo9b69pWAOj9UvbdQuz+eo7VDzSR0aXfECgn5W0vCKceeGGbOmW2M7tixR4nJ ju6Q4MLs2XPCclnfFiycH6677gu2cQxwZi0vQva0aW9KsPp1ePCBB8L8d9+zd3/80/+TQNnI8IA1 yLgp9ha+zRfuccbeGWcM1+ZLR8V1TtbIarMcskkV1jL6CpdnBEPW4f1ZggECCWsen3jiCVsHiOWW PkeQpf9Zp/qt73xHLuxtzBXyOa07RjhjjSQ4w+SHZRLYYREGtxA+vQ8RSG699VZzdaZ88qdv6RvW adGPX/rSl6zffGz5OPG+APZo4LJVFpM33/nGz8/DBRcnaA3lps0bDIa9ju4V+soid1S7tqFnjx4h 1b2HjV3T9ild3cAbGytqA5rQcgknzYqahekSaB586KHQ52gsyznW7t79B9o6YtqPBwMEDEFxF/wS zps3gK4eqK/HoQ2cvYiljn7g23sL3guNGzU2JrU4lQo//D8/DWPOHhW+8Y1vhOIunW1dWiddyzVm 2Q8ZjwPIVMN4m/6mOHgQ+JhaqvmJfmfjstu1SdFntDZ78eIlYY5cal988aWwbNlyjbmvmrICTwks qJu3blE5Kk/1jqO5lqHw9vmVtjBGsfasVBlDhW9/uOsejeXOhoNs4oKnSCpVHBirrNWH8DJ/PPTY k8aM40rN3Feu+cD7nziAk/xVGS/OrplP4AiWdtwge6jv+4uh/8Pv7jYLche5qd/+m98qk8rQs9fR tuHU0cIVliQgHG+VFwOWs2wJ4DZd0mfKjzzpb++/XQpPHo4oCPj8BC7wQ2kDnuGe/pDOT/3m179h 7yITGy0oziSTFjwCh30us/kMnBXe8Y350xlR+AeUVHgFMU+j4GTOII3/iMu9Moj9YBpU3fqg8Kt9 rTv3+fMukY6o/kwa+8+FQOZYAJd5zpxnUYS6wMO3OK5qxxBjxgPfPC330DzGE+/qzt+Mv7qBND6u jNZpTEavOtFz6qUE5IVyKZaDEKY6i59mJFk5GovUU+RZeUWhmcGIEpjlV1gWKSNX3zg/Ga8d+BLK hm4Zr6OCzCtJ5VAum2mSjjHOPbRYn/QoXgujiwrnmfKrlCf5UYbD1j7WbWw9z8T3ENsX8+Qd8PL2 8VyTt+6BCzBxGFhcvaXvTM2gfD0/0h5pYR+F04bBArB3A6CgDaDRXtLBZlUUMWIdKcLiHAkZV1x1 hW1YsnHdBjumgTVVrBuDYcYK0EoCJW5iDBIGSxkCYRoJyBvtP+V6x1JD3oOsxqCJ0WsiV7np02eE drLCIWywTm3MmLHSmmDBmx9eFmPOES6ka6q4rHVtIuYOBpZ8OFMVRi+X3YGFtBRm56wqvh+RQLlo gT/YuMk2vYGJxVKENWO2hKwzZc3pJgKMhfbJV9nkqcAElSWCQ6p79yikinham5R/JqKTNwGGXaVH C6S9qf1j8FfdOOPVEB+rmNxne/boaQMWzRACqRN6ymkuJpv2INhgTTS4ATubVGrXj5rVmkGsSWRv wfoiY5ByizXQ1sLCPFSWhd/f/QdZ6xaGfr0HhC6pVGjXqVMoLJIrovr23Xfmha9/5WYJFKnQtGXz cM351xhcd8qtC5jRtkmvTdJ60NPCB1Jc0D8IjAj8wJu1fz179tLRAy8YU3LKSSeHDsp/k95jIYcJ oj0cmXGCXINJt3Xa9PCBBIFBWteEpQmYlJbuDG/JMnbzzTebUAjzf6wsvJQFM8U6aPD5l7/8pTHm rE9lEyUssdSRchAm7733XhNugS2KCJgjgk36KgecRkuHooNy+ZGe98vUPgRcjuuwMaR0wBclC8Iv 8ehDlA+ki7iDABoFAb5DVHjPhIuVEHj5OEX4RXmzYvmKcLM22Fm54gPb/ZZNtMolXYCvKC4Ki5qG HTqaJTOtNSLjj0ah6qN2aJx6ec8rnz69jzb39YkTn7eycJvFOsLGULSRuJavYXZGhhm3xOHnhJT4 tI05BUEfYXqjYMvmSlh9sXAXd+1sfYUgP2TwoNBfa0FbtGotS/RaG7/kBR4QyK++YEQj3R/eNygf Xn31VWsn1nNgyZjasHlb+KyEbfJk2cLkyW1snRyCbJYIKHGos48Pg5HSZgZrU/oFfbNEcwh9z4ZG MPFYJD9av1FW4AE2dzBnYQ3CTZo2dOvU3uCEcEo9ypQmW2lr8qU84JYRrE4Zz9SLd8yd4N8bOuO3 qEkjeYOUWN5YSrt07mBKDNrEOAAXEU7BbStLFnRwUEhn9QJ2hJp6ZJSX3H66IeB97nMOOANuO/4z XzCOhg8fHv76wF/DQw8+GC697LKaMWlzg/CWfMiDccs7xyn/bjRZcyjxwH3KYHM/xirrVVHUQht8 DiEOZRPIi3z2Fnzsery6z/4+uSYQ+EdBwMcXV/85XnJlXNhVFcrEcx8/XBkHjAfPy+P7mODZxyv3 ng/vCLyDljO2ScMY40d+fMukctzz3uN5/cxTQmnh5/lOGZ4ewVQPysuKs/qSbyxDvIEMGsTPEp9J nTAoed0QSqmmcjU+izwQYimHMqkHaS2G+Beru2DhbecbrXTel/QNBepLoG7eBo9LvtQJGBlMyIj4 xFUkeEDK4juwJPDZXHtpwBEcDlo4rQ92savY3CBa63ZKG0+nwzyibb/is1fIFe6sqN2QabuL1oTc IsvXww8/bIIAxIXNCrB2ko5BhAXWO5JOpsO9s1nriBCGmxnMHMID1hnyQTB76qmnw7jrrgvDRQhN 0BF+cCbburXrrMzPa83Lsg/et42KYPo/+GC5EAY3PBjZqK0FSRFqwVEYberlPxBr6HFDrTy0tggq CCjjvnCdufBCMLO0fu+oNkfZRkUvvvSSCUe4bnLECBpew9T4pz6Q2jusqZnBBrFeILTbLsKqnQ0G CahmJ9IOosAOphVBFNcmArBD6GEw2E+DUg220hkoNsAYVOQLnK3VlrTeP1YPBp0CfUJAeK9Q+eXl cmnMzw4frdsYZkhYnz/vXTG1JeHMkWeFxmKEt8uqivWtY6pTGHPxWLk1Ph9+9f1v28HqrAu2IzdU D4TDkSNGyGUxWuMpE2UDsGWCxaqJlnyFjtYYoX5mF91Yr2zDI9pL36MU4B4BbPAxx8qy1s0mhjjh gblZWhd5pgm8CDjADVzlHiUE5eBai/WSNbvkCQyxyBKXb9wj1LJOlXwvE9OFMAzcgScu66y3rRbe VAvejstMmhIvw5Q3JofrrrnWBNQs4d3bM9+2HTPZdfZY4RHHI2xcJ7dflYsFEiEGdxggzzPt5kdf VsiVlfy9fdyDD4WNCsMVl18h5URzrb8ukQC50vJA0O8toQ8vAjZx2mVSpWPrCfS5j4WtshaOlkWc HXSpH0dCgYMI8MBq4MABxpRWSfGjipkiqJ4s7RX50rcE8vc24fqPC2vXbl207vdorXPVWl/BvZEU HbeddaadearYYaBcU1u3bhu2yGMDJQmWWrPWCv51hpKVwR/KpBzqTKD9wAIlBPMX45sNkbZIKO7T p2+45LLLw7BTT7EdgXH3vuaaawwvUAoAa34+prj38WGZZ/yhTL4j9CHsUf5PfvIfwrkWwoPF4Rf/ /V8Bl95OWs/+odbHt5BSibgOFxR6COzUN5ZTW1bdMutrO+UjbLKG99258wzuuCajrFmxYmU4SYrD 9nKnx3LKfAU+o8BgvvUQ26o16oIh8wnlev08TnI9siAAXoEHNhcJp8ER5iLeMV9yZNiFF16oHfMf DI899pg8Ej4juhOZOY8LDkWcjnQfCDpumWucXPQIzMNswoY7L0IpHjWUEfEyKgCJxzPzCtcDDZSf hAQC/0wIgINOnxlnBMaWjRU9sz8DimMNqJArfgweFrTNx8NFYwoqGPdpieOTcccYKkvTPs+PK/SI ccg4zqRnPpYo374rT9aH4zkJkTVKq0KNj+RZdDiOHXGVqjLxRCnS8eKzXipe9JaoYrMS8qJ9qh/1 to0s9Y4RaO3TN/KoljAb160rLnXVd3hX2kWdsEgS2FPChXIsuJa34Eb9+QFDysdCS7t0u+eQngti DwBuwTmdgrbyTP3Yv4W6wBtQJt5c0aAQ20oSDGOso8+ujjziwcxRe670of/1oIRTJzzeTH8Wa2wd vEHushynwjljMHYgPkJn3A1VnVC2U4xMTkiJ6bpcDDzCpFvD2silkp17u3YtjggihCHYbqzqWAYL HW8DRYPO3kvXAdJxTAobE3GlTgOlQWVjIgQZBjOMK4wzxAtkxAKBC2e34mI7zw8hF4QCMXwwQgQp k/V1RlyFbrwjPYLocdpBFGspbYS5POecMSYgw9gSKBuBhh1x2WwHQRsrBTu7ks43RLLI+/CHdnnA D5+1r+bCoJfUm41pli2Lx8Us1xE51Jn1NwhMbKePNY+6FqvNCFwdJDy00G6qzF42SBEeNMIYVHbj hTVwpS8y66TRZy6lumhizBVT3Tn86pe/Ds/9bXyY+DdZsQf3D+3atAo7qtlOpyo00wZON3/1Jgnz xwj2MNjRJcMnEWDfvXsPrW3bFl595RWzwAF3mBCsjKmULK6CJ8InVisObEf4z8vjGIRYafKCAec7 eNim7VFyxy2xfgUWPhFg3YMBx1qGdp8rzDi7sJZK2OvUqaNZsFCe0Heko5/B3SaKjxXWJigVzLti wRg8ogzKf18MFJvkuCDBlWOM8lW/IlnFWrVoGTqqDHCSb+xOC5NFvbDigl+sQ0TYgxmjPVj8V2h3 5lYSWhCiWcNNenaqxJLuBAU8AEacK9ymtY7BkZBcyjhU/cwVX+MVazrrDdk5kzGC0OOwqa/76ff8 /AKtGd4YXpGnQq7aTd1QLuSpTeA+MMQzgXWZ770331ygi4tTIEd9Wdq7iFNRwOPeXHl05ZgVvBIK GkVLjAalwYf1zTPUD+AKygTgvVZKgvbtOmjd6VdD9x49DJ4Qhj0FvtJeygT+4A3H0jCn0BbGGZs8 obzyOMCae7w/SMs6zUIJ0cDVA3AC/ruOE/8ay8Rll7V4xGEZBAGhl3KVvRH5ZnKFR0FG3rSVHa1p KzBG8UE9SM+VUF95HscipP9Qb5ZYFEthwxxAnoQhQ2T1kns+aSo116DwIy5XxgC4DzGHJMMsVMnV w/GN9F4P7pNw5EHAcdHxwHEDxQZ4xgaCn9fZ3Q/89YFw9z132w7XrIE2rxvhWWQg0XdEhQ/5MY7A bpYo4MLOPMvu2S/LG4rlGxzbRd4Ei5seE4wXAvjLjzz3JdQ3XvYlXRIngcAnAQHHW6cnPPMD5xuL hmOwKBcPF79rnIjOI6hB04mXr5+PI9Jwz7IM49dE78B3xgrfoAOxvDjurJyMb7SP+LxnmVIVZbDn DONPgxTawJI78mLMGr+qq+0Jk1NgfLREW7KREj7SdOqjSlm+0F/GahYLwsmLPI02oYSP8wJlU1/o MrSSAI9N3TFcwe9TH8tXjQQupkRNt5P0lEEgjh2BpmfKVgnpdPZ5tz8+r/GBtP7jmTLggegPzjOv Eq9C2ZRFPO4tHnDTO4w6jWQ4oO9McaD0R2o4KOEUoMHIZXYGz2XSOHQSQ4vg8P90sDwMG4wpB71j /YGZgYkBIaI2J8uOSGDjGpDpGFnE2EgGCxfWARAO11ZHUpAuIk20qIB4IDy/kWeNCs88/TfbrIYN SV5/43Vb/8lOrsIFY64iMunIGDH1MOowdIMlOD6mNYQM7LE6vzLWETE7Djy0LhF5GOQaIMIprFV9 +/YxV+T7//IXE3hgvhcsXBROlFsp9cfyQH0ZOFi1OAriTbk3I0jhJnofaxglDPSUtapUcWhn3QB8 bZTX/ZB+Bn99gODCNHvmrPCW1tyw+yqbTKVSKXNtQqhhgsA9FEabNhJ/0muv2aTBmXKsNUQgw5pJ 403TgwBhdYjVQJvlv2otiJW+aZdnviHEa7gHiUWhVBsdbda6NA5nH3XysDBM6yixgK7WesEKJpUs 5VBVFgqVT7+uHcLOSjHw2pVUyGC4ZZOeYIegQH1v/5/bQ3sxNO9qXellOsbjgQceDCNHDje3yrv/ cJfBfeTIkXakSefOXUwgQqjjvEqEQCyebMI05tzzJcTstL5xRhxc2Lpti635XKb4KBNYZ/jlr3zF XHVfl7vjD37wfdusaabWf/7kJz8xIXDp0vcl1LWwOrDeCUUHAiWBvH+mjZwQPFDA3HLLLeH4E08w ax/9dt5554e77vpBGDRgoKyimxQ/1yzqWADAGxgt1poyjlAk4H7L+8997nNhvMYU1s5yFCrqRSa2 hcI/BJVevXqGG6+/wZg/hGqIAWHW7Nnh//7il+HcMWPCtDenhY2b1ut823NNMTN27LmmVJmlc4Jf EqOHkP41CXYcJcL42i0oSxRDWGIRlO+44ze2jnyd3PVnzJodTjlhqCmnsLJ9RTC8VZst0eZ2Wuf7 gx/+0PoxEgUIw66/uBsmBAr8Bo455nnx0doPZTm9JhSnBGPNNRBVcMPmE+Ep8GbM4EZ8v1wGH374 UVtbDtECbnEcK0MF6sIvM/Dscw1jgf7/i8Y3yq6auUtxojBGykhEqQPEBss0Y++W//yZ5e0EyMug bnXL9G+MT8pgQ7X//u//trHIM+9tHtC8qcQ2HP0dVmPcgP/lX/4l3HTTTVrPLMKWzpA0lk7Pu7bS S4wwoG+p/4OyYM2UEsbmAKWNfSPYi7nhe7nmPAJtYodV6vbd7343dNW8VqY6mlJG6RA86A8fV7Wl JXdHIgR8nDGuwFvHDe4RPlu01lKOcdeECc9NCHfedacpxVDS4AUFDnFmqY1bmEiNAXbKF6+n/RO2 20Z4KNNQ5uCxwRyZOcb83scCdfExcST2RdLmwx8CzL+ZNM/pCVdoNmsoURjjyQR9sOUWogosk4K/ YFxhhGHnfHhRxgPjjHFJvszfKLmh7dvkQcXYgqbBa0N/ELqwAG5Yt9YsfYxrFMIEToggD5TceVKM l8igAN9GmeQDbcGzbav4UWgI9eMbdVj70YeWBl6F98wP5MsVJTztRom+VXWC9lBfFKS0GwMCbaPN PFOnNVLSt27dyjzZGjfRqQt6hyKL95TJRoQYDFgqQ/ko1cmTQFlxnoAvaYB66nU6usXFQsz8pAel 0Ekc8hJUhY33x9DDDvZlpdB/BPECs55638FHIBchmDLXxfLhpflSX9g3xVp9KQ+HdwcsnNYnRHmD jYjIuoAgihDEhjKYqjkmhoEDMqEt3VGtjsuRNl4MD8wY6/U4igNG64wzzgi9+/S1XsESxe6iIIrl rZ7lSqfSgXxnYIEMLWR1ukxnHL6nXWHZAAmEJR7352sTE+tkkFCIz46eWHbbS3BmPSzWNLSu5Ema 2I6o0fCyaCP14BlNDFaMcePGmVWNdiJ8QhyXSbDB1ZeBiKBA/Up27DRh2Nc/InAgeAzUjqJYYcwV woGYvsbBkX6w8SHCqrarqVYPvjDgYOw5JmWCNt9B+3TiySeZO95UCUptBQMstGzYY/XQYGfNIS7W TEKcY0g5r0gYWaQ8EOywBMHIm3iub3sLtgBf8Rw2pEAYb6R2PfbLX4WXpBVv36qZjqZQfSX4si6u tExMiuBSma0ByE8C7cqdFaG0fbfwvf/8L+262t+YYfKkL9D+0TcoBR546NFQINxBECwv36lD1Z+T 1bKRTYpYVGkrk1ovuSGiMFi6dKlNkD7xwoxXGaPNJBbPbqWNTLofCUdZm8okhSBLyG9UlN7teacY oPPUuCgAMQG6pZX+o0yEUsqhzsDyFVl6wXnWOwBfzqXESo2LKL9WrduGVCqlXV77hfdkicUSDOyp M3mj5GByxu0dF+GZEhwRSHmHNZ5ytssC3L5jJx1PtNxcdCE6PXv2MKGReuGi4hpF0ChHk39R0yZm eVgnCzOKC/IBdmwuxWZdKDaAPW3B4l7fFGkoqThcGQ+syYaogVc7NemD+8AEgY0xAaxxx35NChEI VoesjkrpIeIZY4tyaV9UYsXxmFtQYBbfYsGKs4Rz5Wa/U27huODbRC5spQ0E2krZtIfNiehL/0af KeOaZy+dcv3n78gXizlE9Uc/+pERNtJCPBHYdWv1JD51Jv6dd94Z3tBGaPQhBJZyuSdvgrfPn+1l xh+IJ4oJXITpX+BAXAgvYx8oGf7qHgJN3WZL4YC1nL7GFZ7v1Md/tJ/7+srkPXj4wgvPGx4g4LrV nm+0Cb2G5amyeQdOIsjeeefvra+Jk6V6EigDgs87+sHhbh+TP0ckBMBhxp3jIM8Ex0vwlrFy4UUX mjJowoQJNm8yjyOk4r0BroNbO0p2mJfGqtWrwjtz5mpu3WjKPDadIw/mX8rx/H3sUz7pGYu8yxwL fk86T+vvyId7f28ZZ/zhvcfNvM+IktwmEPhYIeA0gUyZZ8E7rtDxe+/9cyjZzrFfFTYWWoges7M8 aVASMx8j6BHYUJK5HloMT1GisWVWO+U3Tnwtgiu8Mzy5jy2WkMArQ83uv+8+oz940UBvETY5jq5n z57hy1/+suhVZXj88ceN9kMzWZJyySWXhLPP/Ux4TOfYvyyekzrhXUn9339/WU19fNkIdYR/ZZd/ +Hn4KXb5RllPe+GH4LM5feJkLZNjA0r4Njzn4DPatGmrOup4uQ7wTHHJAF4WLDWCHzbFu6YLjGB4 SPHjPTCNs0gc/wawOn+AQebcwD0nf5ASwfwVbZaIQQK6DY3Fa5F8O7bvID7omDBddceaTX9QJgI9 dJy6DRw4IG3giHxDnaJ3K5d8P01hn4RTn3jrNtw6Jf3SOkUdQzBmRIAC2RDEQPJ3JQhN0iYFUyUQ QiSuuOJy64gdslyxo+2jQlSEJIRDrFWsH1O3G0OEfsAQRXl6XfzKewhNJHaxfATZQWLqGCCz3p4Z nnzqKbN6oSkZlBbEGGwMGvLBdZE1qhC/CuWH65q5Eik7dp0k1O14K1ft4yvNHnzsELOMTVa+nCfK AGFgj9b6Q3YTZdBOlCvl3/U+rt9qL4vZeSaMoxlh0ETtlhVX88fbyXE0+NobHASXHOEhrn2UjZFz ptYlTpkyNXRs196EoLfeniFX4+PCeZ85384qxEUKuDNhASvgTGDgM/lgFeIdQitMJ+s3YQjYCRnO 1OqhchwOPHNPXwN/ZwB4tjrqW74YhWWy4q554e9h1JY1oV+jklC9jTWm2drJVPmWSxumfs7KlkVG guaOxk3DhA1bwitblofS7XE7cxPE04w1kwjrKI47fqgJVc2bN7NJ9Rs6H3LRosUmQKEMYRJlMmNy YuKFuaHNDPwrr7rKJjQmY+qJsMQMhDuFJDabTIHFaacNUx5dbOJDWHj0wQeUVxub9MCTKmnumRjP F65erTXLP/7xj03xwiRD2SkJUBslNDA58g4vgk2qDwI71tYt27aa0IMAOmvmdFNotNXGPmgTEeRg 7lkLjfv1KrnrMvESFzizEzP1x1WeSb2J8BrC8Iw2/TpGeDhmzGgjNEyKq1ev0MZEAwQ33LWjdbFV qxbha1+72SyvTKNNmqDp1Pov5UUZ4ADlYvFHkCxqWiS8ieu+GNOOk97/iii4aRwKJ0aMHBG+OO66 8Njjj2mzqVVGTKgfsELgwt2V8Y5rP9ZT8CWOXXCLsYSyIG5Xb/OIzQHRU2L1yhXGuB6rOqHxLNFm PXQebkT201hQFhboI4TK9XLrPUdHSNkmQYIdwfBT5ToO80xgfNA+ykUgRwDD5R/viuHDh9t4oF8g slZZ1U2ZWP0Rwugb1hrTL51EXMgvM2/a6bCjPP/GvQcI1DL1wRpt2sWGLvSJM9PUMkuaVYREyiVw Vuxb2nWaAN4xj3D0lV3VLsqjXgTy8ToZDNLfiYOiZprmgVbaPIo+d6s/sLA0YjK4x0pNHenP5cuX S4HRw8qI5UTYeXm8y8QXq0TyZ58hULePMp/3OZNDJCK44OOce34eaBc4nSUFJeuywOMvfPELGrvr zSuJOQlvEWgo8Zj3mU/JAuVfV7mhg3PgGuOWUDd/3oH/BMdPe9AfLEDMXbqzMcktdSJePNoqjiPG RBw/NcPP4tGuGDet0LZ0UQgmH6+L50m5cW7jLgkJBPYfAo5L4J7TLMd/FNEIZ/f9+V4zfhSJx0I4 WydrY2ctFwKPn3zicVN8n6n9NRDUEIjmvjPH+I5+WtrBGGQsQe/gRxCW2GQMgwb8EIYn8gG3GZeO /8eIZj0lfpv0CIzkCz+RSqXCPffcY/VBuCXwjfrDr7HMiPO8yZfyWC7l5aPsRmBEeEbJjwcm/DW8 K3F4D63Gw4mldsQhX+gipx3c+bs/SN641Mbu008/YUp3FFnLpCzHKIYH2r1/vs/yg29wWUCNEj/B EsLaMUy9aauP3ygnxLnM6KP4SFybkSFY3oThiCM0mb9O02aeb705zfhSPIw6T+wcPlz7kdUVWELr sU4DF2Qg6D/zHfwGbsFVyg/VNP2siYeqWD2Yk+gHcII68CMOz4dz2Cfh9IAaqf7CIgp46KD+QhIs Mbg2Iohi4cEVDLdKmEgGCRoVXFxBCMrEaiJU2G/4ep8UNSnSgdun2xEWCKJ33323DRJlHFaI6QRB sUSh0QCZsfzgGrm/AWQQbhhWJ0BXAAAgAElEQVTDfOaZo0zIY8Ch3VksKxgCEhZj1tCO1OBjAwi0 QlZemtmMMBbSNRCoH0hIWdQfQdYnhHc0qWBB7NGjR2B9aZ6E83HXjjNhDIJcUSahRBIsAowhrfWK Kqx8cLemPjDgWH4Z6CD6M888Ey6VyywuwDs1AZhrgerKeY0mJGvQIPBSBwS7Ku3yytXWCanTc1Se ROkwY8IzIfv9BeHMdk1Do20bbKCVy+K1altJaNskP7QI2lBFE0pJTn5Yq6YVbNke2rZrE5rmyiVQ eVeozRyhAXzQOqFg+I6OaWEw0xascigBgA2TEueoAnvqNWrUmTYBD5GVDeEE4ZZvTK64b5TK6kbH 4YZhmjLBnt2ZEXB/LGETV3CEBMqiXCYPvvFusgQs+rSd3jFBfu9737PJkXwomzQIUJTFxI7Gj4BH QIEmQCx+KCeIR91RpLCr7hBteGRpJexskwCL6zLEg3yGS0Dq1o2ddNtYXxKP8mCuWHs1VJN+gazH uN6wLhIXHjXOLFv0KbgDHjFhM/EhNF+ttV7HaOMgBNmioqYSkrFU6LxhtRfhFIGe9jFJeqB94BUT LPeURT/0lhKgU4eONp4uufgSYyCn6Fxj3HzYTReGkrFAW1hTTh/QBvJGSUBe1FP/0/lGfEfQgvhM fmOyxm93s4pTfownYVlzhLUPlFZevC8Rri//QGt71Q7WU9u4UQNofywjTubeJv/ON5/vgO2CBQtM cfPFL37RYB7HXzof4T/PpAFGpAMv+qut4AiBd5RpBEXPmflbhIw/fCO4RwV4TVraSj58Ry5WLoa3 1G+jFB5Y2mEGGLvEzRHu1A3eJq7ef55nYWGjMG/uOxoj5TZ3kQdzBXjJj7YJsLEdQgPeMV8sE3Ef LpwEBrXYUdtGb0/duiTPRzYEHO8cCqA9dMOWzmisg/NsPtheilY8RzQjaNnDXeHnP/u5PERKw3/8 +AfhogsvklVem7eUI3DGMUu6/Q3wGHLYkZ4UXkU0UsdHMT4YW+Tn48bzZq5lDRtxUZQSl282NnVP fH68Z86ysZF+9m9+TcbH/vZWEt8hAH4RwCHwj2fmbWhqC21yyJ4jl8uD0Jcx/du//Zt5B8InplKp cOONN5oCGkU8PA3CLEvoOC0Duo6SFfoDvwSvCo2BRx+u+R5exowGKh/+AP4ZXOcYNOgGfCjKc4RM 8sA4gPfaDTfcEE/iYM+CndtDcXGxCa7wBPDhtGXevLlmJEJAhEehvrSLvPAQIn++YchCCcw9xhUC +eHRBi+FJyT1RIH6ja/fbLQKo9FVMk6geKddw4YNM54OGPEe/hHYAENgWi4erVD8VK6WtaGcB8ZO 7ynPxrH4jSrxusaPGx9cofqL/1RbCsU/wvMgpCOgN5HrMPXFALFZ8Jk6dVoYMKi/wRDLMxZhNohr LnhSb4RtjHvUhbLwiMJLFHgQEIwdD4iTGYh/uId9Ek73tZEODtEaAVM/LFF6wKWXb7gGnqN1bmfJ mog7wCOPPKzOOiHc+qtbQ8fi7mKkpakp2S5rXQS+l0t+ftZnFJJEjESQfE2ax6u9Rkac9ZDsVgoT /qWvfsOsXH+65x5jtv79+9/XjrC9xRzLvVSCS7kYLIhNQyEbc4QFBOYYaBP1icRR9/rHutFW8nH/ +r/+W/hIO6DedtttpuUZMXJk+MUvfhE6dk0JIGXSNslPXgKFaWwNkWhPLWMcSyDPGKILYWRQQTyQ EaEfIRuLKQLLMjGL7UXML7r4Ijtk3BlM2xlWeT/06CPm3vEv119v6/HKBRsCeTGg0VA9PX68DQ6Q /mXtKnyBmIAcbWhUWak+UWVgIDAXAw/cF1jHzkJv3pmAiqCg/BiYm5csCCvffD20kvt2oZiAbMGm WpPH9lIJFo0UL19n4FbJLbNaG1WF/LBpZ7kmn8rQpXF2kGhkFmEmAxh7v9ILTHjAijpisWKyYfJc JAGLtQgIB0yGCIe49fLMBEE/k86ZBpQDapDtkMa5o+TH4n0YfdaeIpwxcZIWmKOpYwJDWGQCw7WF ctD6UQZCH3VzmDLJe92pv09saDYpizzQ1JG3tU8JEeR2SFuJIoNJE7fUc8eOCWskCE+dOkXlr7fJ vnv37obHCOx58pXGotVSeOcbHoCT5J+lydMnKsqkHCZtYIYXA8oT6ojwxbrZOXNmK06lCYCsmyU+ wiRp89SnBCZH0tgu0aq75a9rMwm3nFu8UALd0qVLNcGuCBdKA8j716ZMpkpGFHB7Zy7A+oY7O2tJ Y0DQlbAtfKoWbiG0cp+ncbJ163a5Fk0JJ598sibzNraOhe3Ws1jfTMYKjhMsDUAjulIT/KjhI8IK aSJhKhkvjDcIK2tpaJun88mddhJgTiGG9AFKNQg0cKCMKo0F2s+YRHAmH9IhxOGOyG7NL2js8Iwg xzfvY9I3FIjH8UDTpr0V/vf/5pzcVqFUz26VJSXjkDyAW748DdBmU1cIOYJ+Q8Fh4+2LeQgWqj/L AGACWmjNNIocY3KEh5THOKB99AXlMEfSbygz0GZzxrMF8KBmttJUoWcPmff+LrkmEHAICJvtn20Y gqQoxNu+ZbvhIfMveM25hCedcJKNpwJtcrdjm5bKiF5pBtDZunEce377c2XmYTxXaqzCDMLwQh8Y H463dhU+M2dRF36Mf5ak5MjLQxEtro8xvjOfwOzjfcQzY8jGXDpf7pOQQOBAIQBO8nOcchqDUgd3 1w0frRXf29x4X/bbQMmT6p4yoRPPGHhieCZ4PuZ18JQ8iMvSHHCdfSewnBJYcoSQWVxcbGUSt6Vo 4udldUTxT3zOyIafGSle1y2u5D9GPD8CK3XFm41duYnHDxoCjeQbJyice+5Y41ug3/BhpFu9epXx DVgfyQ8+C+EXgY48aA80mvfbdWY79BJ+Fh6Jem7fvs34OOgaiiV4NfLF4ovhgDlmpbzTGK+M6+k6 ShCjTacunWwOqpThJVM2qOEVjDZGPnWb9lSBF8OFep6WbTVp0ljtyjN+ES+q4cOHmxde105dQs/T TjflLmelZ4u3QVBGuU8b3GvpJQmqKLrh0+hneDlgijIA/o0+q87RHKJv1If5BThy/bSEhqWxg2yh DZo00YHYgBQgCuZ6XGpBBATE9es3hjnS2r8xWef6CeDHDNGRK0IM1w5QDfLK4Hvq1Ezf6nwkPp2H qyJWPrQWTz/9O2MwGThoi3BPeHXSq6Z5hSHr26+/1Y+OtvK8XCq/j4H2xXpXhwXvzjPBBdfMc0af Y5YyCB+CDTuB4XLbtKC55QxSQZFhABsKCE0gHmWAfjxTFmsUgS21RONykaygMMXE5YeAZYvY9R1X CBD+oosuskFEXj7JIciC9CNl2eWsUAY+A2OGBurJp5wqwS4KUMSnXNNyK2+eKYdBTYhlSnBu3CLM fH1KWCdhZ0iHNmr/VjGyjUNVdmFYu35zKGyhtXgFWuvJGbJBC/erssOardt0tmJ+yFNehRKQNOps 4LHTG31C39j5TyrT4KBy6UcEITR+DOD+/bROWYEjRuZLSEIbhYUTzSCTEhMXQiowZ/O3CjHnuE2Q H8GsgcIn2uiWQeKzDpPfMikAmMyY/IAzkxzvERIQZNhQCi8BhCFcWCmPQH6UwQ+BBhMYbQJeBOrO pjPvaBOh93Ws0Vwd54FQjBv69pIdZgHsKqsp6ytQSLjGE2su4hluJJZXun+8LK68pyzKoE9Znwgj Rr1Zb43mFPfVgoJ8Iwh4MuBagnDKhIn2zhksry9Xas6akhwJlzCMSxcviTBSfyBgDxww0OCMtq9H KhWmz3hbGxGssf6C0PXSr6QsnpEGHjFm49iLjKHjFG2gfgjqs0W0UKqUSInFuI+bD8R+M1zWW/LB 4snOyRBVdm5GIMWTw2YLwR/XcuJTHj8nOFa+3kP0wCmEMMYwxIM4pDEBV8oW16Z6vcFFiCcED2yK bdGNgvdBfNr9b4ybFSZLiO/T52jDm7XCW8ojeL1MIae6Q/h2yi0eQgpuYyFGeCZ4GnvI+EMemfVg OQDrYhDiwYf+/fsZjnBMDjAnPl4L9IONPb1r3LjAxhXHZV0lxuQ14b31k+JmBodt5rvkPoGAQ8Bx FBwDxW18anwRGHtYDsZLUQodYtkNOA7TTToYbeIwp4KXnHN4MIHxy9hhbqc+zHk8kz9zJmXyHOl0 HMt8Yw0844fvPHMlvefl7ozQD74xTmze1FzE+EpCAoGDgQC4lolH8BrQyKefeFLHFrYxpXl3CaQn n3Sy6F5WeFs76T+gjf3gGeGZcIcvLu5mvATWvrVr/z979wH2aVXeif+Z3mkzQxvK+84MTUAEQSmW YRBExbo2NDGKiSXtcncv1+zfbOpeuyaamOwmms1aYzTGxIpdEFABsSAgHaZQBxjq9D7/7+d+3jPz TgVFyWreM/N7f8/vec5zyn3u+z53O+fcV57Nr3z1a1vkJNE4Tgu4OGtD0SFZQL2M8miUUXQgcztv 4B/84R9FIRzsXp3d47WD0oVuH8mziy/5VvfRj340x0bOqvfJVujpSZE9Dol3kTzDIG+jQ8ahd73r zypKjDL22fTnnCitzp/n9Ng7+3UIleV8cCTkokULo2g+XI6B2XMO665P/265+ZaK/nNCxc033Vw6 gH1ueFxtxvSUpxwfWfya7v3vf19Fc1544UXdzMhSc9J+tPzqV786tJ/lTrkePTqG+PS5JbScG708 EFrWjttjDFiYdlCoL4yz4v77H6j+mVN/EC+upU280TZiuuqaq+oM+OtuuK67OxFWZCGRVuqwtG4w SrXjJkVeGid8gwx73bXXZVnauVu8zAzL2lLtSePa3O43vljzcmv0L+D3z005rXCZjCfi2ZwBtvHQ w7FU/PM/fzKC/KXdvjOnd/dloB5Ztrw8PjdGUIak7/3rv+pmZYABt09bkWJ7+G7xmNSDXohzuWUC iJXfWrRLQlg2uGFJ4b18JB4RCHDPPUu6Jfcu7f7nu95VyimFwpTRBluJ5R1U6GNIlEuT1UMP3J9d S99Xgi2ryd133NmtzPo4MCDwso4gkslDCAQpvTs8bfuLGN63S9sIxxjRTSnr9ttu7wYCtzvvur17 1bmvqb5TmniGeHY2bMoGQ+t4RyaU1cVETJmVlNWIDqNAlCZmGwItzkRtDAj2xz75uBL4lYvhtHfb ZK0chNAE2trhLYR47Xcu79YtXdaN2/fg7r5sWjQpsFmxckMXn3G357h4DFMnL11E7W557t2zYn23 3/57d3dH6B5bikSvsBBcWp3rosxMmzqliFnoBqL2GRgYKGsXYqaAOaqFkjB50pTagAjzE4rIMojB 6gvlNE1PGtpYa8gijnHyCoIf6yJGjLGwtNmgQ78pBYQQSoG6eUyNbYUWRzGy4zRGBaZgDDaNeQjP iE6ecegNCAQggszVWTd8b/rCY3fQwVmzESZ9bcJcWMy8y7NlTSkl+MrkvTv4e0AYLkMH3KJ8qaeN g3GxLtm7PGD6YTMmbWR5xBQpH3a6FJpL2bLDHyVeG1gv1TWYyQfceE6VZawZPfSLkrRixbLu25n4 bl98W01KNuCaE/q6K2G116U+7wj9OToT0ZJ77ykFmxcazT85kwRvv/EAK3lrrEMP8E8fJBOW37dn HCekzlXZATBibRkQ5PCe560MOOF4J3Qi1DfmjX5r9lwLn9b2hvvKb/W6xgf0kcLGo8gQAUbgKqE/ 9aTIpB531H3BBRcmXOpNhQuUeam1v9GXfMMnjdaG1h44LSTL0gfveN8z/QCjsRkn/QX3++9fGuPe g7U+nBdc2S21ettv38rZEC8RK3B6r9PBm0ysGWPCBGPFRz784YIp/O+TkGWenxicQg+jMlGjCUIL +lInuFR9W97p4dn6NlTQyNcIBHaAAG87MoIrjS7geYtWYYxjgJs3b155NXntbSLY6AlOOrfwp01Q ttG+sswN5AT022iv0RIaHJsPusH7h0dboQN9QAva77nf3lW+a9+trJ+2vSPvjUBgOAQaz2+4ymnB yTA9Rp1ZmVefedozusMzf5H5xiYKaa899swOuw9kDh3f7Rcju2VEhx50SOEl54WlWeZ/+EqOgvMz c+Te3LmHFU3sGWVxRWjQnMEATIYYl80iF4ZOBwdnR25clNMfvl3z09rQkDWUBx98SC3rIT8ckE0b Dznk4DJ+MzCV8yR1MEIx4myMUGaOSQNKoWX8P/zwI7oFCxdVG/RdX/fLhkK8sAzfeyRay1Kp4iSZ 28zJ7q+NrLg6SiM5ipJqLe3YyKAUcbPbPvH8Ll+xsvvKV75WsrGwW/C0HwaDvTle6OzYLDlr9D2c xsm55lJHAKZVJZtcG5kJbwI7Bu0nxVnidAR8QcQYXsboZm3tgsjYDAVgSa7ULzKmuZVxHx/Sfw69 UvZjbFe/dhmXMpLndxv7xmfwsV8GXvO4lNMmvmRkdkiBmfHaAjjAJBTfeOPNOVLird0ncoTKxd/9 fvdbb3pjDRhEtgi4wmAiDO00pTzhvXYKFlHaUt8O4tbQ1dCAQQjHG9wbxeLJsfAcF4Xwgx/9x+6Z J5/YnTF/fh3pctzxJ5Sy6E0TUpsgIfhOU1Wc3Ns9rpqDXBLBmBflP77tbQnP+73ujgjtb/3t3yqP qZ1Rn/u8s7s9E1bRkKpnMArcrtAqrf+zbd6+rRDZml2IOGfO3PIMPxQYj4oAW8JnXCPWiIqUAgtI vXz5ivRza9y6dz1LY4oAeVAdKUPJIyAAKaVGOKX3tUPyPZwAXPsgHmO9OIrggvR7Rer+/u2xIq1d HWJa1y1fHW922jf5voRvZzCBc9OGWJTDlCaNi3dvfO8l3Zw2KQvxO+/JhO93/pSigGDVg8FRHljn tHn/bLJDaF6RIwYWL1pcTBJDwDAwi8/luKBjY51iDRwXpbDvTy9cNzi4tzrCxZXxDikTTvCWUpAw CcqkOtUNZ3gZtQ8z8QzTvDgGEesNKvQxcCSsYBr6AIRwlRJs7O2ofH1gPHZswplTB7iDtTUSylAm 2GLelFj9JkRpF2vakoSknPS0p3cDAwPF7HuM6f+qj0rF00U59658lE8KqlBXhpKMQsobF6bab+/e +kzpXhwm6nN61vAeGEuopO3ahLF+/etf6SaH4QsVwjAlnk4WSjDB4FdkEmD0cKQNpV3YjDDspUsf 6E7M2u+5h8/txzfvanON9dA1WIC/cbV+9OQsBVi1ekX1S21E05bf2jWK+ve//73u9jtuz66eDxYN gLmJGz0gM3jnnYbHPe4OlZPM6jS+4KUvYL8pim2lzQTRrFOLEcXkCm+8v3DhovKcKrPRSqujTW6F Y30pO/xV5qxM3j2c+hB0+OUd+COktzfUZEwz9vfcc2/hD9zuecgORfbNTXu2wCcCyij9AIM8pawa Y2VQxrXbR/5kqX5pg9xFQ2vWFn8z0TL8KWP7PrW62jd4jKQRCOwUAlAxuNbCx1seYfSORoJ7cBvv JMDhswyC0ta5ur31k3+PyVwkaYPy1NVoAE23Z9oh4ou3yF4Z1vePioHITvHehePoAI24bvTe2q4c 9/VDH1w3+qhKRv6MQOAngADcgZ8+cM63iCx0c9xxT+6uzGZAb37Lm2vvhXtjELbZ4iGHHpylSKdk 6UbCeqPQkR8dfzd9+j5lAH/OWWckNHVtd9aZz6n5nUEevgurnRlnEgPzjZFryVPWiC5b9kjkgtu6 xbfcmCVP93Z/8sd/mDn91lJaySwUtIcfeag2VDzqqCO697/vf1XIMBn4RS9+UbXbsWXmWWGwIiKm TZta9PHOiqp8oK5FTDBSkSXMUfpI5qJPoCf1UJLJZMsffrDmM3LT61//+pKd5MUzyCeMuPiI+ZxM 8fa3v70cD/SOkklieCVnFI0Gxv6hYTBuc7prn3IIhJY9n77X3sUXOL7kOy4yJhnSRqVClaflVA91 7hOv7+te96uRKe6uKMe93/D6kinxDrK5dfR4w7OyeZITE3hMyZzHHHtMbbJI2V+ztneKbFrfL39s 7Wr8UHt+GdLjUk4BoIS8ncge1owRGwlTgC0eGzIcc8zRtZsXIfO5855Z8egQeXlCIK1HdTahmHcK FglK6FlLStyayk5SwlHfCE/6zBDLILMWsZIcf8KJ3YfjEZgaAfvNv/6G7oR4a87KDp7Tp+/XnXjy SeVKXx2iDC5uN2lsrbE1ownfLL7bJwwDouwXy8fg4GDteit8efbAYC2+viOEBQFPOe3UajJBuqV+ gms9aHe3fmM+EBjiWZd4X7bkpqgcNOug+n7Na8/N9uH98Q1AX+eUDr2urT3C5giXKKZN4KW1NgVJ /T48aRMyBoODA0X8ixbfXoo0mCLIlipv2mJsh3+0EyCtl5uS8b4hm6xMXJY1i7m9YUwm/uzGOD4e uomb12UrpNQ3Jo01ThGSD5syITudpY+EBGGXeW69MqVCQnz3RmGzI7KQUEyG0sXDKcyjWasJ2xui EE3KYvYxqU/fKWKO5cDgLk4o4j4zZ0Qpe3LW+A2tIxyCr37FB9zdn3qE6tqkSyKYYFrq0A5KC2aH wTe4TMquzHfddWc3b968Uv6+lvWHLHDNC2D8wAqMNkTB4f0aFVj88Hvfr2iBU089uftKNqIyCSiT wUY9zQNLudQX9TMi6OerEkIjXMY6RaHp7YwveSgevIaYpL6cffbZxdi/+tWvlhVvUcqjnGLKQl7g BkPEA/H8o9XbMzGxOjo78O//z/8pZa9tLtTCq29dcEusfKu7c573gu6yjIW+2dTs4UwcdibeLxOO CUTbH8g9tI6pLw4tgu2VV11dO9lRdjLcRe/WgIVr9PiY/oKbCWz6jOm1MYJdkEPcgUUMFgYHKQ7h r7zWwEydOi1wn1IbShF8A/gygPhW0ebNMaQYj5RfOKuYEI5rz4JtZcGkuIt0EJazYUM2Bgo85cmr ZeEtLpAyRUwcmL7yPrI863NZNvPMmGknhVL7Wn1wrSXlCFEmWCxccGuFhu8TOOInLXS5Opry4I0C hRuJCOENN949jbcSd/zGB0oYTx/wZYq1CXPfCC7GH24+K6FbaEU7JWXW2t5cq089wuUdlWPNteS9 rSkNS7+2ubX14cjVCAR2gACjT2aionf4LsEfvAINF97nrxA/Bkb0UzSQd4Td9bKCt36yhPoKv4Pr aBEem/8yE25Do3AePYhq4F2imNrYcXo8Snhrw/7G27VCG73XyvVs+PVP1tKR3CMQ2BYC2/Jcz4K1 WSq0MnLBrbcuqDnji1/8QmSJPTNv7hOZdL8w8C4RZTlrNDLL0vuXloK38ooVZbBdluinU55+SpTJ R+rce+G6aBHN2elXiCsa+MQnPl6OChs7in76/Oc/VzREuUObL3jhOd2855zd3XTd1d33f/D9mq8/ /JEPperRKfvhLD2zDtbSlwO6E556Qi0lKfmOvBeasSEZJVvYrbnKHEoOOuvMM+v+wMBA0daxlk6F viqFANcmMrH2WMm8W5sr5dm60CaaE2q8fkiRe22W6NBF7O0wOXLIqXG6oFOeVjRL1jInkjud3GHu 480FbzJZzcfJJy9esCSG64MP3D9RoPdU/WQ3a3FFwB13/FO6l73y5Rma8d23vvm1RFLemgi047tn P+esbkMiv7558UWlGIMrGUxIr6Vb5DOymTBj57jvPX2vipJan71qSmlO3SuzoejoyBynnnZaNzgE E7ys8Srt+0VPY0uHTC8w6u0TpkugyQjnamu4oAGXfG29DnMHkNzMVQ1i8C0/w6BDNCYRAua55766 mDxLh/hxVhDnP+4XwR8SqZNYBLjKHh3lwnXfjjwrpaVXeFNhIb3NYOSp4UibTFy8GgozWE8P0R1w QEIsE+J68KyDujWrVtcmLS8450XdlD2j1AQRN27OGpK0s689k2WUh9GjI2DqTRDTNs6e8gIRXiGU T7VzCHqb8w4YCKl4YzaYsb7TjmDKQLwUqqeedGLFyUPy8oRkYyHlSPre0vbMJ00orzFBW2jfshD6 Lbfc3D0tXqRly2MBCxyXRWi3+RGiReDKAHufjMQQkWUn0xCm0Ik6WxSMxiLA9Cnljsk7qwKfJx93 fHfBNy7IGPTWYNYboRdtvLUTbNtHHxCHOvUNM5w1MNBdlnxTpmUdaSzMG6PbZulq6sgmNwTdjWlD mjYhHtSxCT1eti4W9AzbpvCcMZAHQIxr4C3McHz69kj6PZByTwocv5yY/P0T3iE8W2io44kmTt2r W7cy4ShTsgPz2lUh9K+Vtc1aQGGqvPOHRal/5MEw3BD3hijPDdfASMIQ878YBsH9U5/6VI2fkBU7 PD9z3rxq1+rAaVKUN69966KLan3rUxImc+E3L+xe8fJXlKULTHzgJCGsxiQvwAn4tiZRAjMzdkdm h9xLLrq4dkem8JpUXp9zLidFybo37Z0cRfspTz2puy3K4Oc//4VSWlnprK14etp0d7xoDY+qE4GX Oow9MJoQWEi/ccHXK6zmmmuuDl2c3J2evlBGWUHhvpAWzPmf/umfusGBgVJE7sr33MMOK3gZF/i/ OUq1z+QJk7qnRnm7I+tkWTKNzT0xnLzyVa8u5f3hhxxJs7GbP2dOKY3nf/H8Un5GpbYrf/DDHAv0 tO6arP0wvnDNOooySAVWKE4+42GTtCMOO6K76up+k4ZpU7NJ1dDzPlfPq9Cg83NtSnZ3LL5XXv2j hDUdnjEKXob+10ehbWPhHnze5qPUVIqOHXUzIwqxM5MpjcYbPlaj0q4ySiTz+ij16OmQTGwX5Ozi gcBA0g/tlyimPe0Yj6G76XNLfRjtqG4w79522+IyvEwOv1y3ngkn+SsvnpiwwVhOccQ9pmUzi9AE T6t17FOmTO37ot580JY64ZyPG6JOcqueNXzZO3TNkGfTLZO2TZjUsyk8UcZcbpmUhfXrt15YP6Os ZCoa0kYh06PRa1qo/FZH6+fI96NDoPiP8RqigRq7gvLQeOa6wO472Voy3tKwW/2NJ+Rva9FPXhlc Kr6YIqz/x4/7736uZRh69vkAACAASURBVKDz3OaF5kwh5gTG3liCH+26x4X/rfxATbmy40me+Shf 4l2ZEoPf+vAJG7yYd9CVzZgYdBmcGEEZoeD1htxjJANwY2ZQQiq9jOB+aF7aOr/0yrB76h1JIxD4 aSGAZmCQ+T0UUHzYXPBwlFMbE/FYXptw0je+8ddjIJ4VJccSrTuzZ8O13V133tXNS1jp4tvuqEgy 0Vr7HbB/loktKPnRiQCWlbT9E9DXLbfcWkopTypZ1u651pOaD9Q3MDBQayvt3xJRPrtrfzARVV+N cf7oki8ohwsXLiiZw1F2d9wRpe6gg8uIjD4QD2NxdSpzKWdRLy+FTvN7bWT00dmYE7GhnU2byW1R 1tBn+CQZ1t4kaHF5nDSWTBU9pkzP/SOrLovhtfhLdIYNub88ynDJx1hIAKoe8y3eYh7DK7xHpvWN 7n3jB07GsOznpCicotzujqLKoEa+lu/BKPXXBt4T8a8Uf9WVP+pm7DO9+24cHUKsr7n+2jr3XtTj 9+Jc+EiUeBu4Lo38dOmll1U5hzPaJ3EucEQ5YYKxnLHghsh+nAgHR+4wJzf5G3zU38O1Xv+F/LPV FbaL5teYpbOFPJFS6jK/hNf269nkyNM8kKtGMzMmq0cx4NyvNXx5SPC02REF1dbtJpgS3jMZTIvw 7BpA22RjbV5hW8qrf1VVBJ8QZGaAPCIEmRAg99Y8wblCTp5JG7ZotF1be6VtYzdlUjxrQa7yTKQj azasjVCVIlLamHgTa/e/1AHhM1N5kGS9Vggk9ZSylLK39LnP0Lc7bWJ14aV7mlDYCPpgQuCfnJCF WWMPKcuNhmufMvr+6lw1Yqi0bb+E5qbjWSuQ3qbvmwOzfqLe0A1GqectouTnfz79OGmn7ouJx0R4 9tQltFIexFlIrF7tSBXNir1HLGYrQmQmbG3HjIRzIEpltI9W6oNxM37Ky0V2Ih7fzdhvZryaebZh TTY4CjPJXB606DakbtfjUj+xYOyo9CXGhNWjN3b35aiADeP3SDnZ5TTPDHUqK0XOJSubBeg2ato3 hLng1lsqTFcMP6Xuyx//+JZwlWc/e173/Oc/vzz1wkFYpy6KEqlPtXNrylN2fVXv27WxZ/DYWCGd GJN1n7x7z5x/RnfND39Q55eCBa8ohc6HNXJNJofR6ddtUTAIU82QsSE7vvXjHHilLmdhbc49fTI+ 113z44T0Ti5vpbCx58RSyKv7qX/+VMFeGwYGBrJz7wvyeX7tCjt5yrTujqw5nhxFrayP6CFj4UOZ 883goK/S/Q8srbHkUZ110Kxu3rxnB1YP5Iyvj+Xcsy9kfGdks6yXdedmo5sXZic5FjzWReE9FM/D Dz8yCJLxCnMuBj9qY/BxbHfLogW1poPHFJxfkmNkpu+7f+3KJ2KBJ+75OXv112OwcTyR9dhHRBm3 8dLs2XO7SeMTtpz2EghLMAeh4BPYULAJh/o/d/acMPbL65DvvffaI7gd2gos/auUL1fJXoqajZru uPW22gXQ9ajg4uj1oeDQ/CZnl2FiQ/DyfvGsfLvNS0oQnTljZtYXf78moA1hEjZSghfew39UKBxb e0U0PJJduJ2tWsJqcIvyUDQxNFn0OACzG19Rc9JQXrgprYklWD3wv9hdcKWuvZoyTbjroqQemrXJ 1t/ed9/9oQPh2f1zsEu2LUm96X2hO3gVbvTEFbiPK2OS0CxWZRuowduexSqlp78QRerNgeGxvlvH JGRpSvCDwRCPl+C2Skb7wD/8YCT9RBCA8zV4NWbtMnCFc4V3Paxboca6EtBv+dFuPpHfP03lcFEb GThCV7C08FJX+/L6++Yma+LHhbYn1TNzVc1fob1dJc/hvrmpCZfyKpmgyoDM4yIP/nNsjtValrnu wYQeTpw0sYS/iZnLFi5YmCZurtDBdeHLDDi8JMWv0l78CV8kRxBwXavbp/WjaDB9ar931eaR+yMQ eDQImG98iscG12oODI5PiRFbtM+KFcszx2a+Dm++I8roYZlvrbE8+JCB7uRTTouHdWU3b9787ogj jyrZZsaMGcX3RQIsj6GaI8I8sCay35w5c4o+KF2uZ8+eXYZnNCUyzG9Ht1k6N3XqHpGTN+fYmTND b2OrHHKj0FqRXq7vzikW9rdYsuTerMmcUbSDTijQvRZhns18TP5Oz0T4hGiG5NU8yE/OrqKtOJDc 6Dli/iLspOZVrfuhT7fDLjwJSMDLZX/fZXvPpWd0m3aznyv7eQwNN1kXzHzIgEcH5ifFSXDJxReX nMmDLXrrwDhPxuf5oltu7iZFbt0n4b/OJh+VPh0ceZWDhGx+QvQFMvDEOCVmD87Ocq6BkrtEkRqL s886W9MSOZhNEtORvRO1Z2fg4TzNeEiNz9SPX+A/j6qc9n0zUMGIGrah0R/qdAHC0wwaQmFdXB9r P8RhRTfGzTJh62MWSwTAk1DWjWSgtG6K8gLQLADKhLxCPClRm+NdBHjlUAh65SsTQRQYbYKIo8YE idfZUS+Ipy25PyEC6fqUI21euzL30/a0IapQJo8+fJMwZZfgUiLS1npXvSEs7RsbVwNkLPk+/Sky 0Cdl5k8JA36rM0iv3/IjZG3VbhNVwSl5Vi1fUTCqfioveX1SUvq1LWyr3f4k8bLZqROBEQad7ybU UMjDvgkj5u4vhYpCmvK0I3bnoshx46JAJBRPyGFvkeqVmJpYU6eJtfKnrdV/3ty0mXFg4oSppRyZ wKVGANoqr7rUXeMz1P4SLgKLQ+Ox2v/A7NZ2313dHhOFsGYhd2icoqa/gFee9XyDY+zi3b3LAp+Z B2cn36wHHSpPPcldSb3wxHmmmCG8EzoN3rx9BAaWJWshLTx//RvOqx3lhONaC8xTL2+1PyXyJG2b UtdQZZTyttMvzzGlbXGYjHO1MCSTwK233lpWLetRX/CCc7q/ePd7aofYOzMhgKtwz6or9cBTHipj yEOdB6k662yj1FhIP2/+6eWptDEYJeXjUbS11aHVFG87PbNW6q/IA1Y7RpCb06ZZsw6q8Sg8S7mb gy9S+60tt9/eWz1tDmUHWlZHu9xd+p1Lywt//PHHlfBFwbZmA06YTO5P3/tQT/QbISzEgAY9R5MP xgstJJjyz+BiQb9NdC7IubkXXXRhd/q808vqZyowoT4tZ31df0O/s+2KlSsKz0ZFiTbKyjOmFZLs d2AmrY9Czbq7cs2qblXGUj596/kSPuGqx5MKz80z7bBWxW7gx2eNcSln1Ya8lvaHkobe7wfcOIHa 0K8KCzcO+r8xsOpxP0/RVvphLNFQCckpj4HgsLmHFU4Y9+JxyadQR1WUZXhYDalqm1RjlTKOOqrH Z2PGWKbdY8KvdFeEg6Rezw/O2uMrY5FlDDkxcJXQks/uUvVxKM/G8BCT4eJFiyKwL0so1z4xsFnm EF6GiwRhMxJVKH1cWDbew5prB0djsX11yjcmI+mJgwBwF9yfuCqH1VQYNez3Y70ceq8a3guA27+J hBiOGLNvT4QG/CRnoMd+rts1ovU8Irwhhbj2LTG2mg8Z0/B5IeqWiRCgrUszd7zsZS+LAXTfojl8 wDMfc4joCzQoGgwdKhu9lyCd8tv8UpWN/BmBwM8YAvCNHOSbnOlaQhcvfvGLSyYjo9j/As6SZYXK mlvMi/ZRILMMD5W3hMdO7cJ+GZqVuypKrHmA4uW3ud9yJqcckNHtdYEGyEfKUxfZ1Jmo9ttobUJv nCOMvuit0SHakWouNadnJuFQQj89N0P7mQH9zuRjjlUvq2+oOTMjmdwcuWseUBU8jj9gLPVtstdE 5vK0h/x3UNzEe8exBi54BEWS4mgPFJuh2oh0RU5bWJ159TlZyztrVnbyT96Vy5bXaQgzEplHZqX0 33HH7d1diQLkCBHiy3NtDD0nh9kMrh+TVaWcP/nJT8nRlAfX2IMnHNCu9mntfhxd/zd99TEqp9q4 4+RjcqCQAQLkoXgue2BZWTaXRwmzSy/Aer4+iG0x76qcV7ghG+BkqINYQbQInRAUcBGKMkvRSrkr UobfCM5zFoYNEYIh8BRhmxA7iLs6gvCabLgzdtzoWDQzcAkJ2CNrVXhE65zEIMP6WDuz5LEbMzmh nGMyUWW71FUrE2oanJ6cNiZjTVjjxk+M5VNsd8KQg1jjcsTJpLjQbegyZjwleKuXQL9qTs1f3wiM UI5YCe76JWRoRSy0EI0iSVENQOIZoYr1cAPd8dkIKLe3JAjWkAvZjYoViRemD3XoQwwQBEIXSuBa 3Lwx4Pnxx8YnEyaMzzE6X+je+96/ylbcP+re+pY3lUIDxq18lYKv39rtm/dXG4QPLA8hIQq/2/N2 3b7V75lU5YYJHTp7TrffwNwKJ5k1eWKGKkddpE3jeKd1ttxK8qevMTRsyPtLlsciHca3lnFgF/xG +T7CmClp+s+zhxE7eHrWwGC3JELM+eefXyEnzz799FIYbrnlllK6Fi5c2A0MDJQSpBx92JrSx4yx vlDIKacW6mMME6fsmTWZ36j7lDuMg3L4/ve/v3ZmPnj23CiaWScVJnV7du6FQzXeWGfKo3SVglKw 3lR4rV5Czep4WdVn4tAf14Qn9RwZZZRyA69Y+imrJoKiiayp1u+BwdlFooa+wQdOt98MDZUv/TaW 1uPqt345B2z27MFau2yjKX2KxaYYIoZr4yLvNFj1dN/jiTYAH+Vfu6fP2LeGlWfhoZzJag25s1nv ihBoDQhjKMX3sssu7QbSFky8WUYpomAB/gwT2l5RCirIjz0zCeAFvIreAct+UvI8GZIvV2HSMd6E T9g1OOjWXfmjq7s3vTlHF/nhjeTDr/zq/3irV/j0UVL+mCiYQqEJomgX8y/elEO51YXefW8OoqJP Hn2bMnw6m24JM0f7YAVGlT/f+OVuU8o7LvD/0Y+uTLnJH55GONA/BjRtUCaFEK1PTWivFlNOWa+L PvO778Vua6o8es4K3R8RMLrWBVsiUGNc3aR8px2hRzDp+T2+0G94wSJOYGg4B7Y+PRz76923YuTp Lw8EHgvW7by39Wb+wJ3tU9FPbjLMMTDeeONNPZ5XfnPWju+0MuAhmoDP5kr06zdh2lpt+wigKR6g I7Ob59oYvxg27ecgZM57aE8SQVLz+JBwjUf/OGVQat3HI5WFh1XqX+uvh/4Op5NtHoz8GIHATwAB OGwuhE9wlPwloZ/C6fwmH5OpyaHwnuLkHfkHBgbqPnwlo6MxH3l4AyW/ob751HvKKHrIM7gukUO0 RXnulfE0L6GNFi7vOfrwPhmmyS7a1c8TSIwMXQSduX9rn7zrGdmpJveQOqXUPfMiEhvlXv3Oxc8h NdgoGny1yYfHeFQ+EQSGYJWzmKOQg5EojJWR+9/97neXPBPNoTZntCTLea6WCFE4Z2bpkI0b8aPv xSim3AMPOqi7I8YDsuxJMTirU5nyGwd5NuS3KC5zMrhrY2sXWPwypJ9AOd2xuxMCqA0JeyWcrIi2 /973vrdiqGfMnF67fB0fIQuyOzzXQPp90UXfLCBi/AclfHFZFJ/vfPvbuTcmMe0nd8/P5ivvfvdf dK965ctL4OcdYo2xAQGrji2hz3nhS7o5sZ5C5rUJbXvH//dfulsW3NKdcOIJdU7kkxLDfezRT+o+ 86+fSRjxAYmvn9d94qMf647OmrVx06Z06zN3zNx7r+4LX/paNyEDec4LX5TNmJ7f/eVf/VXCDl/R fekrXykhjeVjU4TcI6IAXXzpd7r3/OV7OltpEwqlIt4ijxBplOH3ve9vsq7xmpqgHAhMqbHBjBAh fRCPL/SPoPuNeJXuzAQ4KWv23vGOt9fmPKuiQG9J6AzVSWkj4rR5C8+U0CYICymFXiByv+UrC1Ne cQRO3YpAfsMNN2YDkyuqKOsFWL4wMwjvA6mrrBBUI3LlKVdbCaLyeIaZ6bfnPu4hGPerDerOv/WZ wPcOk9s7MLwOrcQbm+154zZNG2NQSGcS/kq5cD9vRMDYlM+qjeu6DVE+1gbGxaxS/s6S23QNoSPa QIm0A28x4xgoWLfnRFGg4J0e5VSbW5LfZ2fJ/UboNb75re/gtDnGDkoYJjE54/lwxtXGT3AZM96c Betb3wG/wDfVsjLqC2XDoJRHyoOMkbLTkwrLxrzB3D2KpMX56MfmQsZrYGCguzhhI9ogL3j37/Oo UZR27FG7RTEbG4Wz8iWbcBF9Ne4YoLDkv/u7/9Od/8Uv1SZLmxLCbnOESVHA5VPXFi9wfqtMme5X BISw7fRvY2BgMlu5Yll3TLZRf84Zp5dAeUno/ozTn10WQfQgWkJbGryq5SnXPX1q7Va33z5gMGfO nIJNGQsSEZDGxYixdSzlr5TyhTHtH/q/e8l9slVbef5Kqa138mOIfr3TvLTK0K5NGT/eYN7Jpfc/ WJO+YStYREHdlMmBIMqzmLvVdvinf9YMV5n6Ak753pI0YmdpqF7CxRdjUHLG7ZixCXmWP2UwMPQq depKXmWKinBW3dKlD8YLdHeFcK+v9vTt3KaaWhuwzZ36AebF69LnJdnY4cgjjujim47xTAg3GCda ITQe5CxcoCTDy73Cgy+7/Hvdb7zpTQWT4SXXuGUQhfcW8Ic/HLkegcAuIABv0NfwVHwlOMqA0gzY BF+8y7yzu9SX1dMzwVn5be477bQ7s0/ARcW7RQGIgnneOS8IPQ3UZm1kFrzWEgzzCY8Gw+apWauP b3zkIx+pzfh4Wn/t136tjOfFD/F5adtu9PdG/o5A4GcAAXhv/Sc5oSl9cFtq3wzL5D04KT8+L6/k tznVb/Tlur3nu9GVd7w/3NuJfnwkeeVBJ645gzxz3eRS7/vd6lCn35J33Ucs5jbrZnMrclPkpTiu uuxPQr8wB5Jt7RBfEZnm7bpHNoisNVReFfpz+EPGlYb3qfoR2GmnPvo4BUFehmswI8NxKDhL/NY4 R3hEbXR05x131nn1B8XzecP1N2Qp0AN1zuvgnNndYGScKxPxJULP5or6DVoUUVGn6jE+/MX5sQWu YCmB/zZyVd39xfvzuJTT4AbYFDCseRSayDu1R9YkCRuonV+j2BwWJYFl0vozawCFCnzynz6ZHXpX lXC1dOn93R/90R/UGjeA/0qUw8k5f8/117/+jdodT6jm//7oR7u3vOUt3SEDWbcZIXhSlLQ1K9eX QnpNQvcIazdcd3235pGV3ZI7lmQzonk5SmZ997ULLuzOzHbO61ev7f7gf76r22PvqXXm5qjQ6Wtf fW6t1/rgBz7cOXx436yVu+7a6ytGXp9OikL5v//2b7qXverl3Z5ZyL39oCOpUFoEx7FbwoQgKOKj GFGazpg/v5RUZz5+PTu4EppZWDCPhxNWyZNEuem9EkMMZgiXan4LHHqiCLyDoPlfRG2yFIrBeyHU szwtgYEStJPCZwJ/zWteU5arP/6TP+n+8r1/3S3OTqm///vvzITbx/vLK/mG9Nrer7nclLDPCOWJ m9fWxqg8l9dv3363j3KMG68hBW7mwYfG+xPPU+4n8jqElsXkLGME+7R1Q5gPV9vmKDQ5jLLbGB6w Qvl+F7tS4o4JofLE88gJfYV3LH4ficBgFzkCPoOANvrtWx/AmYDT+rxjye5gpjkbNrgrrwkA/B9Y el9ZA+H2e3NerlBbQou+U1B5cjEs+D1jxswIM334cDF6xJLU4FQKavogCXNmvdRemwsIoVUnOH7o Qx/a0tZ+3fCkoi1jjwlR0ihQ+rerpE5IgVHec++SUixY6mak7RjplVdelQX4l2eCWdWdkbUiEi8n uGk7GKgHzBrcrHdWqLJZQ6dGiV0do8D99y/N2k6T15jg2aIy1jz80LIYlaaUUcREsij3D4iHmBdk VjZFaJMWGPsMx6ne+MA62J+xyzP5mc98psKF98xZtrR/ZoxtU1FNeTKvj2FmvwN674h6yqvBcDP0 zvA3TYKStws30xaGHPC10zZvKENDRSbkfTrg2OBxgwvvNi/rkeF1JpGiWXXC85SFplyXx7Vq2vaP tsjHqOX8Up6aMUNjqw6wqwlbncmsLDjIKs1ruzLWWDhTg71t0bv9pWxGP+O8JJtI8aTyXGunddFM K0J/W5IfLhrDG264OTiy4zQCL0yqhSM7jE8raeR7BAI7QgDu9HjcP2vClnvNq1PCWfDQMzz30RPh MbSdP+1DcJ8164B+7s19c8ryFcsrXA9tKVc98ptj8ALRMgzlQhTrWK/QnXkCH/VO48PVh500Slkj aQQCjwcCcAjefzk7+1OAzIkLEt3EI9k8+GRQ88c73vGOwkvvFE8OjppjfJQBd/HzhuuN1mqeyn3f 7knyDX/Xfc/JmK1sMqy65EMTviXP27d3Gv0qU0IW7teckXluXCLQPGvlbsp6zHoex0ZfVoy+mQdF ZDLUinLqS6rifi5/Wnv0D53rA+MtZxXdQ7saTGrpYu4xcEkHvvSliUBcVnIi5ZSjTXlkIJtnOolg 9pzZ3QPZREnZZ2bPETKsMSXrGeeKKkuZ6vdu7RmTNrTkvuR9z9vv9vwX7XtHqeIn6AEAQBjfhH7W E4RyaTT+/WfsE0/WCWUVWBxliPCNwTvupN9sINs4n3pa963vXEq7jRJ3Xw0AT+Ozn/3M2izFBjQ2 T4LgLA4vPOec2v2WoGsQOd1WZJD3zQ5Yxx5zbATIu7sZUaSOyHUWqXV3Rbh+ZGXCBrMRyoJ77uj2 ivA/+6jBWC7275Y/tDyhn3d0ty1dUkLZD3/w/e7Ep5/U/eia7Aa6emX3ml99TRSeG7unn3Zyd+G3 Lupe/upXlOdiY3Z3lQw8ZCwEgBP5QApK9I0J6QQXExmk0v7LL/9ud9ZZZ1X73RdyyFthzcveM/fr 1iQmnbXIe0V8yq6a+j92C/ZMHetDDAhfOQhkwc03dxvnzSsRkFVJ3hRSHh1EI1T0TfFuaNs73/n7 3f/9wIfq6JEPfeiD5YlSJsFZOxsjWsKrGwFUSKZw5unxhq8fWhdMXN0Yz+eG7OZpc5m2C6rv+Arr X0T3LlvNdvtlIf64ffbs7s8OupMyXpU/7dsYZS3DUuuKI/qmzWGY6YuxWh8Gl9POczcwDgNKT1wV IMDGhxXdN+/enTkz6juXXtrtHSH9BcERygSh/Z//+Z+7JdnFllJGgXcfDrYwlh6yw8YxN4wnWFir PGXK1GztPZC1dZdU+PAXvnB+1kreUAzdES5gr7xPfvKTWai+tHvo4Ue2rEN9Wqzr9+Ue2kiv67sY RhivseFd7EMzc6B7cMTW7XZ801ZCDyVV/ufleKWDEs4mjEMUAcMN5cUaDnlNQIfkkGtHMRVBIIrC nK2sGpyMq/d+8IMflKf0C1/4Qv22RvI3f/OtsdJdnj4e0c0LHoHBtxPNoHxKLMOHs8Tgsmc2DKvw 8SF8tJGSdRbWtKr7phiK5oQp/8qvvLa7+KKLwlxXJTrhnKrv/sDke9+9IluqH9ctuv22Evgy7eU9 HxZB+M+jz0uHyRIQe0uso2Mo0M/L5krWOjormCW1Jf2UQkVlqBkbpdla6x/88AcVlh+yKZpgeOC9 1xfv+JZ8F86lX+jIhD0tHtC1azd0fx+aAX8TsXFTE3oxmRbNot3gqnAeMLOGk7JLyavJK9/qQmt9 bVXllj99GHP6n+GrsKfk/cxnP1ebMhGaa2O31FrwT71gQrCoNgQP8c9JMej95Em78lbKOyDb+9ul 0RpWBgd1bd2MJpnyu2CUPuA/eNe0PfZKW3qDVqtbnjYWRqOA1R6OfI9AYDsI9Nx9W6oIpm3JFU5Z 67QYS9YNCanWy8uyNr8z827Ju/1FoXbwU3QHXC5aTSbl4wF4HD67Mvzzuuuvr7lV1BM6b7TlHQle 47sEf3QMx61pt7TEszY/o/vhhuZ6eeTPCAR+RhCAd3DztNNOK4cOXg2HLZERUUCZcW9e5nLzPlyW 8GnPfZvbyOzmebLS4OBgzcXKZuhHF94jMwhzZ5AfGBioJUWM595TVs2RkavJVOYj77i3MfLTtBiP lU0O8i6DtYgtht5p2RxUuTyD1m4yxv8o887U3OfQYezXTv1ktPcxr6qHLELuobxxenHKVHRR5t+f V9o6n22toSLjsoMNuh8bg7wlh2CCPzjiDezJ+OZves3+kT/xiRsjQzJuTTRfkyXCh1bEobF/8r44 x+vdeP0NVYY6/+xd7+r2ia6wKnLm6RlP8CKHlcwe+KTAGnt5tUP5jRftrM1bW////tXjUk6bUAKB eJB+53d+p1u0aFGE0td0q8LE90ro7Lxnz6twGWFgL3nJS7Kd8pXd0UGoF+ZID2cmviiLt51/6HiU 5z//eQVoiodjPwhArq0nhIivS+iMM0RXZv2nzZLs8Lnv9Bndr593Xnf9rbd0B4fAHsxOY1OybvSQ A2fFqn9dt2/OIDrsqMO7S77dH9PhfNO1azjE42W94fpuQhBk7tw53XPPPis7+h7W3XDtdVmLurK8 tTffmgN5Dzmo++3/+Lu1y3CbkAy+BBkggInSGjsCs224EZs2C0E00fGYUjKccYTovEORBz+/s6Cw kC1Sb/W/lZ+MhXzD6+IhIVzzcrDKUGiE/CJYhKtNdkJuG0OxKmEYwv8opy/O4ceXXXZ5HUGCOTAm SAi8MQNKqVAli7kRmPHdO4cHa3O1DQ/oQVDPMQZrh33rW4U9R1jfGI/onvtO76aGEEclbGFqQiFz YkzGOt/xyNjkaeKYEHdCfe2wyis0df2obnlJs1TSbeVaZfsgTke68EJrv11lWaXe+uY31/mQ+mN9 Ekbx9//3A/GyXVTboIOD9ZrXXHNNlSPf9inF1xgIWVU/Ji1E09rb70exU/9vB88bo4ETb069/+N/ /M8KUf8PL3tJ4S1FGF6AHZh5zwQyJp7jCgWNsOSe8VoRa/3cObNLgTaucMfmR//pP/2n8rC3cWmh ZTyHr3/968vDalMonkibEKSiNizbd6vGDoPXf0xeWZ+K8v6ic16UsOd5MZqc1jO30IUwFH2llEo8 DItjYNLXYoCBXzLz2QAAIABJREFUDEXMsTL6NHVqv0mIiIMZM2dk59/PVVicI26EphIqKW0PPnB/ 95lPf6YYtgnQMUu82S0kCK5ZI62O3jOb8Tcg6ss9cARPNIPGpuRg641Z4z2EikN5K3e1e+zEnHOb d27I5llNsfaA4EgJZGBRfl9HvVJ/SlhmDc27+rzP9L27897w+u61r31NGSO0RaVtbEsJDb6w5HrH RHT++V+sSUleH71Qluc+u0x5plwK6lvf+pudkN2qp2DQh2bBzLYbKLqdGDi8O5MYgUQdW4hzl5Vs +6Dak/dWhK+KbLGhhrEgZDAWMCRltEX3FqyNOcMYHn3BBRcWbFuJO/ZtN31tL418j0BgOwigyYZL taQlNNHTXegDjodOQln5Qg27xjH0UTSeXIyOyuzxOrSUZ/gC+oXThO5RmSfNE422K3ogdG2NmPOV zZnOfcSz8EVLR4RXym++0ca1aZ+9J8ZlzhhJIxD4eUAAvnLYCEVnIMH3GQudU80oT5YljxZ+R86U hIkysFrGQ7GF59/85jdLhrJvBtwlIzCUW3ZGsTTXMpYPDAxUfTbDYyAX3g7fGdH7iJslJeuSrSip 5g/zkVMBDs9JGV/+8peqnWQKdKb95EwywPh8awellGwiYouCTb5VDsX1nDgdnOcuteiJExLV6Nrp BmuiGDJv/zyStuIb5LDGk7bW08v/DF9kOzAhu4ElGNpRVz9nxfDrfWejGqerrrq6ljEuW7miZBny 1W/8xm9kmdjeFXkHjqLVOLpsRgUeZHy8S9rC01Kma+Nf94bkmeKVWxv5C3m1W+VUZw1Gz/qJV30y WBKADB84CqSzAQ+NQnd/lBGKE++GnbskiO/Mn5sDcMKXkFQWFO9AZEjNIqJcQquB4PbWBoNFESH0 W68mtE6LCPrPjcJ58OBAd22E0IOjvJ6asxN/fPVVWQc6oTs0YTtHRvkcHa/ejRGep44e3x16wIyc EXRzd1wUx3ETE4IYz+Ae0yZm8lmazWwSnjNmcs6AWpC+beh+lOMSjk6+KfECbooGBcFMTAhWexGT A3dnJXSQVcMGKtYkInyhFhTGV7/61dUP8KSkQ05ExXIF6T4XZWNMwgGFBEJIihXmAqmtd9kQxCcW ttABVinhGxgHRWJwcLD7YZQJijcLcHS9WgsDQUuPjBI4IUT+L//yr93f/K//3Z05f173X3/vHb0i F4Uw6B0Yp4okRoINWcd7W5iPNCP9aczAb+PNCm1MGA+aV8h1wxfCP0+YMMRRG9d0R00b1518aOCC kPLe2ljQ7n3owW7y+EndXhPHdxNTntFcnzK+s3Jdd0WU1wmEjrStiCxwk6zxG5s88ArjxJzgBTjY lGJg9pzyeKYh9d7hhx/RnX322cUstK3CH4N/mJ9QanWWFyyKhXFtBF4CSfLLZ3yNBY+j8dXvgaxp fvj+pdUm/fb8yCOPqPK/e8X3utNzRAvrWa2tDAzK0xhlPNgaT1++QnWO77AWUb0En2uvvS4htc/p /iVnqtop71k55How/aF0bsxaZGPPi8cj++PkXZPjgCZG+ZoePPrK175anrpaJJ9262ufohSrLnVI DpFnLGFAgjNo7X3vf1+t1d0vRpz1iQq45pofF17aFAlsWSbh+82hl6OOPrY8CzXOQ/hIwLsqzPgl L3lxjg7atzb/OuSgg7uP/8PH6ogfIf1oVPg1g8dAJpxxGfNx6yYWLZss0QjYm4jQjWTcwcYHzhEg wV4+giDasb6lMet6adgf70xJXhMhI4Gy0ZD7jn7xTaxVj/4ox7f61LMp91t+eUyAc488JksDstEb I0zyAK5ceaHerTbnuoTcjLu2WifaBGTl+uwuGWemM8YRhq7Djzi8LLLqkLRbqjHIPd8TpgjJtY48 bU+9jt5peTyXWj/rx3Z/Kk9oVtEzsjups9UYs2qXXu+nnt4yHYUgP435hCinogYuy5ltmtb61uoz RmCJPh6tz9s159/9T/CCO+2bdR2QGxx9N2NiqAIyFF54p+XdFRDhwa5SlTuELzvL08Z2Z88e7V5r +67yVaTN0MOtebfisW4WDubCEVBwLphY/G14u9q7rZ9++7Tf6AdeSrVWvECb57lHeW2KamXIn/Zu b0Cc052TPTGedGS8NXmGp/AgDQ4Obhkb5W+JpmiFjHyPQOBnBIGG35bMWXY2b968UhAZSk7J0YXm UgaU3/qt3yqegP/CffOqed/+L2RQiquEdjwXXUd5Fa1I8SQbkMnNi5Qi9dYcauPK1N2MMWRUMie8 974d9ckNhw4MJHBuSsk+K7OHyN12oc33Q3EekZuvSKQbGWdM5pliYeFxt8fI4+xQ8jOFt8392mmJ HP1BvYujyOmva6mWoRRFFlOoez/LP41fFH/doeBwgsCQPCCikTzceAhHgAhEsuD+++/XHZCdesGQ NxrMwV7UhWgMcpnrWN6q37UsMjA95dRTa1keT2wbB+9pi80SmzzQ+NsOzfsFvkFi+6mTQYO0Pqwb zi+cM2d21iLtl0Nlv19nJX7+H/6hhHbKQA1uAP6BD3ygjs9wHAGlgqdhVjxUjyQs0i6Vxx33lDqw F6ER/G/LTpQLF92WTVue3f3d+/8mAxuBpxcLayHjhCmTywt6aTY1MHnsOXVyd/ml3+luijf1wnjN Ppx1iD/8/jXx7L6tm3/yqd3M6TO6iKLdlJyVePOCmxJKMKXOdloTK8aGCLKUnX0Tavvt73w35zXO qJDh9/zZu7vxPDEhJojDKsJqxVJyShQGBPOJT3w8Hr2TSrlEtH/8x38a5XNFd+ZzzihvGG8VYqfo HJF+P5QjOBYsuLXqO+GpJ6YPN1bZlK7/9t/+W3dMvEPWL/Jc6G/0tUJGyInAKY08GBAT8T4lnlHr YiB4EQyiyTuUE+88EM+VNa4vS/z7qbGcEfDd935jeibW7//whyl3UhFDTkfN0ShHV7vHjc0agiiM +ADPWY1nrqX2fv+rqs9lHib0d498DsqhyQckRBMjWrtpfDdhfQwQo9d3e2UzpIkbs7FF+rh+1IRu cRTV6yNc5wCWEHkU8yHvlnKFvx6cENZjjn1yeU0pTsaK59S5nNrQGIiQUO2Fo3ZlhEeeO26G4oUZ 8BRRBkohCF5K8mB6PPa83Z/97Gd7xTfM9pJLLqkjBzbHKg5ujXliEBRfVsSzYyC49dYFNUGck+gA 7bNeclT6Arbew0K9Y4MrzOplCeX4eixqPJkUg94SGo9YJgdjs7G9l2/9ozBTGDHrjwS3WVCf8axn 1XhWJ4b9UY+NjN6YM0ZZJ7/0pS8VLG4MvrDqzZ9/Rk1EV/7wymyuNb4YJKXDGaRolnFIe14anDnq mKxrTvuVWe3KWJ1wwlOjkC5LaPM/F/49HJy+JyHUz87EQ7lnKcSsZ8ao5LiGhaET58GC72cC20MO ObR7aY5saGMApvpY4zKEY1BMvZL7UsEx14TKnSX5SuCMsQWM4eum4ETDER4XitzOkrKNkqfy+20C TKhGWaLRo9ZQDIaXACbGuLy02zzZWS07v0cpBV8wMMbOut2ZAl79H2rbhIn97uJ9iVrUw2rnNezi bsrSV3Wpd2MWfxcc0veCWfqci145Tdv0VT/7duxe4dlFjSO3f0IIgDW4++ZNLMw33EM441kQcPej n/d2lZS5fVJXS/BgV2l3z7wzvJydldGeK2f4dcu7bfnbtqP46lAd3kWVaKjeSfNRs9/1DA6DU1LJ L8FrfAK9MbrgFY0HeQcZE+wJw5+OEVm0znm/9vrulNNOrXyMyzxN3pPUqTxRFCNpBAI/Lwg02YPc Ya41T1NOGUt4I0W1kEkpouQIz8lLliBRWOE7B5G8lKNXvOIV2QjxlSUrMESTp9ALGZOTZWmUVQrr 6pXLa4NJ8i364Biym78IM8b4sYl8MoegMUqmkN5FixZ2L0/5s2YdVHK6jcm0+e67l2TZ1T0VlThv 3rw683NK1lpS0hh41acNnDVtY0v9tkTLM5GJnFXmq9rpP/JeXvh5gXyn5aJ3bdJOzhhnHPMO3502 8vyeGYcDowCYiB4bzL3BwcFyrKyJnLVXnD+WZBmT++I5JjOR6zhVzLe9/Jj9dQLvptSKKiP/R5qp erdv2La8cvunvzi/H5dyCjl9moKEUQu5vSdAnhjgPePZ82vNl8GhNBkA4S5r4pk7LoqUcFfhBZDL xHjBhRcFuTZ238k61Oc+98wSilll1sd7ZOHz6ihqYsvC/msC3pjdJ+3wunbj+iKwe+KdWSH05s67 gsD3RMnY3D0vRLbknocS0x0vXJSfGQccUp6U059zercgRDM+BLzgpoXdLQsXdofHU/GkJx1RlqCN qzd2E0JgFAgHFm+0vpJwG88rwkbQlFNEBtmuiNVoaixFFCW7w1IY5IOo4MJShRmwgOy5197d587/ cjYa2rd2AibkURQhMK8dePC2CaOjMpn4eMX0vCbYtMsxKwdHeVA3Ly6v9QUXXFBKRK+M9h4OYvSm 7JJrUyLtqR0/875rybcxhNAUbSFK12ftjfFCdPtlfe6EcVmcHoYyOh6n2Jf7Rpm304jR2YXXPd/t 4wxP9RITNm8OihFso4BWh1JPVIVu/LoooDnSZ1yU1NER+qN2JSwiv7ODb5ke0nmWbQID4QNstFH/ n5owh7mHze0uyc61+g7WFEOhvohZfybkaJ677lpSHj/Cg3y88a973eu25FGW1DxbTfAbF3irS/gL BnhprHzggkk6agVzxLQpsWAmHAWOU+asSWV9fFNCfUUGCDcZMyYwSHk+vMrWDxYDdytthRcve9l/ qPBcIcj6wPqoLhOOOowFr7pJB0PGnOENrzymhTmDVUtbGRSvV1eeNeGaJhoTWOszbyq6nJijfghh QlLUZ2IxuZnQXpj3HD1jjUWqqYlH+fqP4Z555lndMUcfE7r9Tvq7LhPi3mWcmpxJscKbM3ZC4u7O Zkx7CMUNLt2ViemlL3lZdsJN2Grww9pinnGfUZlk1ifPuuDmaBNO6oKnKIBT0HcQuXCs96Zs6XXy Dl3n21mvwtptWmBNCIXUOrPyfOY+etplghuhE/VszphtCm56Q/sqhRf066FTStrfl5SyizcxeERA HfrX6tg6Ju3OLr7hCkDrY+qr/iar2z3x4X+pQ3SBf3nQt7GHH+qT1NdwvG7s5A8KwGckPGUznlf9 TVnGJff1o+rLtzx2R255tK31vgoZ+fMzg4DxqzEcKrGNJ1owruhPaD3+2AQkAzY0nD9xO7y3I76k QEiQJMR7Vwk/2ZJxJ5kerU11BnneG56vXSPFNGybUsGipXbdclQf6kewNrjMywRGjkNSDnzG60QH NLgpw7xp7jAPtPvtd2/oGlPC/oOJ+nkwkTvmAbwSrxYdRgmQvx+flNMaOPI9AoGfMQSKF6RMPIDc Y+NEDhOGeEtePvGJT2xZ+mQOpvCQZyiRDC3kV3LlGWecUfiueSJvkNlhRx5V8klFK4UWDh4YTD12 9c1yNBFbU6Z2zzp9fvEKtHJgHAbSoYOz6x55QkILBxwwq5xN6Emb98+eMFK1P5WhldWr1kRWmpZz 4l9QNLMuOgJPLiW1aDfvkq3QMBnHdSuPHFXXybMj76qqfq5/9NFHn31rz5Q99+he8rKXdnfefkcd Z0jhpA9973v9sY/GY0L4htMANi9aWPM3boYz3RMPM8WcQ0ECJ+P28pe/vMqmJ4BDpe14Yn/zl+fv 41JOAY73gVcBku6f0NZDBwZyz2HZt3df/dIXigAoOiwk4uHt4HneG89L2MHvdH/7t39b8evc1W94 wxvKknJMQid/9KOram0chYLwi9jOPffcnJd5W22AM336fkGEiEWZbNZF6eEloQi84pWv6k6NJegj //CRbmrORHzrb/5mt+e0vbov/eu/dvvvuXf3zqwd/a+//1+79//t/+o+/8mPdSdEQX7beW/ovnfZ Fd3DsQgdNHuwW7ZqRSkaUydO6Y4/7vjurBc+L+tVvx0iEkJA0evd7pQTbnuT3Ac++IEosZtifXpl BP9LChYI/7WvPbc8VjylH/rgB0uhgWQWrs+dOychdDPDNKZ2NwlzHvIi/2qUJ6EAPKaQvSXI3ys0 Qcz8d6apI2UoZpQjSVscHv6CF5wTy0pCMhJGIVSpdvkcQmTIvS5namI2iFkdiJslRrgxy7C6eOeM G+VIHnkpQ/olv29jLu2UKVAuIzhtKKE+YxXlPuJBModJpVvCA9tnVLUtikhyuFbsKFv7ErI9yw1C gHbAOfXvFQXfumVeOm2m1AkF4e30vSrrOO2+7L5jUubPn1+WLH3D0JE33FWmfmCSkmvKS411mDHL o/UOlFNeR17Ef0g0wItSt3rAnneV0sdQweKIsYKJtoJr75Eg7EeoTz3qLoaarjnTS5sIfry7g4OD FUmgHhMMmGPSvil/n0rYrwkFI1ePcijTlDAQU/bO0po1/QHaysfcKaGXpjwT1ew5s+PZnNmtXrG6 NitgnCBoobl9w0gVqu0Ow5b0SwIr7dYnx628Ojtf35jQ+m99+1vZSXmP7qgjjiwcYlixC+ZdwWub IZyS6IVjjz0mkQgR5lL4WMcMJTW8Uj741VioJ7/buLd8xk1qntT60aTo/kneN759GLAxNcZC9dXT hOH+va1/W9+UL19LrU1p1lDaFaShbD/2/Yj02ev99upuvvXZB301GvO7TylxSJM0BH1bd90O7+z+ 6VCxw76UubWv6uv70kpqv7fmae0YVsjI5c8NAs0A1aJhjANcNS4+w3F2h0bkec+LdnhSN+CZ8oan YMOWn43mttzY5gJhbCGObZ48+o+tdRR+eSHtcL2rVPmG8qBrtE4R1Xw0oq3ut3zum7tb//QVrBjL 5XPtOQ/Flt8pg6F43KT+aIbZg4MlZOL1c8OTlYFnMxq2erQX3aKXnbVevuF5d9W/kfsjENgdBOAQ nIWDvKfz5s3r/vzP/7z2fenliTGlkDJ0k6/lsZcFGVJqOCivMuA8J1DPT+I4iLxFTqIcwmeRAKZD ON34gPeU413vtU+ro7WvKhx6zz1yqrzqVpalWuZxc7T9UnIrv4faqFLE6/3iB6nHvJ5r9Eph5nCR px5XzifuT6sTLPQJPCRHS24IrMmP/RKpq7vbFi0q2e3J0Ts4Xlav5HiLRzVyEBlu/MQsJ1xwSx2t eXeca/QepYGXMTAeymcy5tQgX/8yp8elnApvC2Z3q+MJ5c5/01veVEoVz4mw0fuW3FsKHAZPKeKF OvnUU7plyx/prshaM1sqn5CzKedHccDkHT4P+Kw6vLFnZndbg8KzZNKw7oMHZH0U0o1cKLScDFCG qpt3xlnlkZqYdaYvPfdV3Z7JP3blmu7Hl1zcHZT841c80J2w/x7dFZ/9RHfIhE3di088uttn2qRu ZhDktEMHuhXxCi6LojDvzDO6aVE6RmWNoPWee2Qt1zOf9ewQZn8u6ObsKis8l3eUJ44StzQ7ZVpz OiXhxCeddGJNaJ6xaFFqeH1tDS2U9+lPf3ohJCV17ZCCCDaIf/z4CVUmTyvmwGs8Nt9SYwgEfUop rIW0FBQKvbVfAwMD2TX2vrLWnBwF4OBYycgW69c7yKUrJcfGNxQJ/TGZgy/Fh8XN+j/Mo30oWyoa zoCUgwiHf9eP4X/SNkrX5lJMKZRGKEwkY4t2N0YrTTQv1TP4k2e5Nzo/NtRF8oTX8HBVPalL3/sa t9bdK2M5cHrWrO68886rjYMojX/9139dSqNzNuGITYWcfwqeGAECVx6Fh7W/PFy5xlxaKoYZuPDR SfrPM23BunG34cCf/umfFuyFs7NG/uEf/mHht3fB03rIejeMlAJXR5CkjmKwYFMKMGY21L/Ayrtg j5nxWPKEf+xjH6sx8gxN/P7v/371p42b+3BCuS2UrI1PNWDoj2fy+qhb6LjNiijvF33zolhLD+vu v+/+hJGuLQZ6ZBRLIdXrY5RRnnbxNNSElfq2TkxGMf1I+RnVWpc7N3R+6WWXdt/OhxcZ7V511dV1 /Su/8rpMlHuVQUt0gMlFX/p2gUvvEWrMXt3u+W5jZFKT3O8/9TN/+vFq78BdQitMC5Rz7EtwLL+c vYl98Dg2vGolbP+tfGmr1wj8quTcbe833NlaWoNPvaz+1FUvVo1b8/XPd/zr/VZGw5U+V6vLL+WY FIff63MVvDLOgVDd4N1tiq0b7g7pufXcH+9UO4fuqLf66k/w2TvNUy1fD/uhvqUdPUX39Q0VMfL1 U0Jg+DgML6IwBy7lw7PBoIf20Rh82dV7w8v4aa8bLezs/aEm7exR3dvdu9u/tH0ftv7eSjfqk5SL d2zN0+Nxj5u9gUtUiV293SsY5Xck24quYqQzRx+Y6BOGXIY6yxoYHRkW90nYXeNNDMjenxajrd3J yQH3h/+TTyRCuk/jsVtbW49H/oxA4GcGAXiIOTc8N8++853vrPmXp44nn2z4B3/wBxW517z87pFP mmIIV1tCQ+Z5EVJNwWz31AO31etaPml72vPMO40e23O/PSOztvfIEi0vWczsTY4YPS5lJ793yQZN +TXdKaM9S00m5prdh6a5KvuJ/AMeDSatr9q4Ng4gbWfIWpwINEvqHB8jUk105aJFi6P7nNBNimIq 3bb4tuIlx8Robz8V/IdiKyJv3rx5WXKV4xgjv5rPC7aRKYnLwPHLmh6XclqDMoSIrB92riMMrouy SvifO3tuPHz98RNTEgognHdBLAO33nJrgL+0vDYU11sX3Fqu7CdFyaJE7BNrJgKx2QsiwuQNuK2p 1ydMUh0VVhZvpUN7N63f3E1NWMCoLBBev2FNzlUd6MZkR72P/PmfdRd99BPdkVMnRdlcHaUoltD1 UQDS66nZBGnpujHdlasz3FP26hZHSbps6f3dP3z1/O74p8UjuirWnUhvUWW6A/e0o+jaXrEIwfAq CfHUfwhEOVwfz9SGhBdPmtQj28KFCwsp7Uo6EE8VyxVFxuYxQn1tGw0ePYGiMUPRC5lCMCC6UCL9 dt2EQvBpiXCCifCeKsc63zlzsuvr3fcM7cI2p0JE94tXzHvPjwdwXhBd+zEJC7URwW233VZrXdVr YvYRArrffvvGqOBwZe0bUrbyA3GotxhFa8zw7wxY2Q0CvzGJAxyTUN0x0UbHxUMWW3a3Xoh0KGtT durNowgOES5UkqRsO6xW/GBGvuASQaJXvnprW2NwcMOmSX7zYltHKrTF+V/zsynRC+LFtGW3/sij 7MZIhtN0wXoIlvoJrg3ujTF614c160lPOirwvag2ALDmQmi6tmD6ypKUIz88poBRgmsc8zy3Qx/O Gwsup4/VjygCqbbqVSdFlMeWYm3dJvyhGPPWCvuQjOPWcQnsShGrRzv8kY9llMIhfAe+qJcH9sij jixl8uAcCH3aqc+odttEaBQGONTvHn59n/Sj7qfBylUWBTnNLyWcQYV3F6zs7Kc/jt6hxK/PWFN4 HZo9hoYYfCiPRspSrrIwdeMkGQfX6oNz8qhT3+Xz/taEU/Q45D352rutPLwD/HeVGk6rr+GAvEIC GXOMpRo9H56Gt6K12fPKnax9/vwannF4AUPXDUdaO3jK+jr7F3nMpPZ86LVtvlrbt7n5GH94t9qa 6mwA1wNru77W7Z5GFFv1PcbyR7I9PgjAY2OPpoKQhZNGhxCEn8P5Gr+foprd4ZTi4OaukgiFbWlx 25yP3qYe17Zg2hB9+b2FZupHbuQ7WLpNBcovuQDepp3gM7y9foMdJR4vo5Bah2d+9i5FdP78+eXx uPmmm7u//Mu/rEiY8857Q3bvX1XepzvzjsTwTJ5x7vGF3/zmlmUiNSZ5Do41TpV72z+PDodt84/8 GoHAziAAt80F5kv4LImwIuvYq0XUkzmSTAIvyUbymUPhpo/UaMU1eUB5lD44jJd416enr/4dv6v+ zL8tn+fueUcZfrd8rRzf8kjqd+1bft/q1z7Js1Zm/x3CTsuUKZ9UfUg9dALGY/me+NTP6a2t6idr T0rkoj1SyKXPfOYzammR/XTs5WHJ4U3hMX/yJ39cY8YZ9fd///fdN+KMmD13dja9fHrtc3N05KdP /8u/VL9GxXE1KWNiiSHYgPtwY/MT3++ff40/vXIa4EROK8BRosYFuSBO/hfgaPmQaELWqrHs37Lg 1m7BrQuyBvCmKJSjQyxPzjEu2a01xzTYLnlx4rPvuPuurME8onaoHBXFBdKujaIKCX1q3WO8N+V9 CqJaSxYpt9/RNohp7Wk5Edav7pZee3V35xe/1L15zsHdYRHIx21Y3m0YnY1sRocQEMX6lDkqSufo ad3DCf29eNnD3a1Zx9etsa419W6ItzHKVVlysqaS9bUce6mnERkEgSiIIxeZtKZEybuz+kNYwBgI 6NbZzcwumItvW9xdevll3X2xouy778yEFZ+Qs47CQKL4Eu4heCkY6hgifPeKCIdgnSrT7nSbMJAB GBcYEO55ZCmXl8RT7BxX+X6YjY3Et9spTPiSCVibq7zgFmZ15513lqVmcDDH8CTsA8xflg1qWIVt 5IPQjLMCG8OAlo/GCHilaj3qpoSEbAoz2RRFuwYnRJWQ3fVZb7quvqPIxTAwOkrspqxP3RwPzago sWNG9cqAvuYNZuk8772SrX7NarjBImXDH4r/ubU78pLucznSxKZHQlsco2Ntpj7oUxF32lPCP2D5 aHPGeXMUM0yy5WtM1rsXXvjN7vLvXhEl7umlOAo9591UnkmBAinku4XR1jqnIXh5v9oe5j+aZzX9 p4jnvxxbxoXSZVMCih0486QaJ0q3zbhsJmQicr9wJnnGxNO8iSusygKZbZO6MfBNrAFJ3pNL6Mmh KU9Ug99wmQJbBSVP/pciDedHj97KLsC9D8XpmaQJLZ0JPCMEBmHW5Rvc3/CGNxS9MEKtDb6NHTsu OBt8iJFI4Zlu+n67DgwbboK55J62+7TJs1kWJ2bX35qYq9vV8b7/OpKfe6zao9aFLYsy34cC9RN5 KbXwbOiN4cUAAAAgAElEQVSVqmiornbtu9WNf02cMDllhmek7SIBGDD83lJG2lnHBKXM4cq1cgjS Be8dh8XjbVMKlFeECEF6YkJ9RoUWNLUMCzHAGSht06d+x1Febe3arkPblvyYfiln/ITQR/Hxvi3G vsKnUz6DimR38XFjcxYqAs19qFdgfyx9fEwtGcm0MwgYd5+27siYL4mB0ZIDNANnGp/Z2fuFtzt7 kHs1fsG04rfD86Q+aXflws0d3htWRs9Tht3Y6WVwGg77aE2Qqn7iNXVvJy+FjZgXGDEb7zCHWbqC N/RNF53hXPBJUeIX1p4KeFPxvGQw14nacrLA6iyFWZJ1X7xP1pUuW76iNmrB2xkFCZfPz9KRsfHu 2FnUnIoXmyu0sc0VRZ87ae7IrREI/CwgYI65Okt/yAOMJWTNRvvoQKg5OrCkiaG7eEbu4+USXJXP bx/P4TK5h5zG2VQyafLCaUv34DiaavnlbdfKbLjvWsIv1OHTeIf82yfPtaflV47U6Mm3pI2eyS/V /dxjbPfs3yJpA74H1tpgXK7NBq8PP/BgDF2Ta3w++KGP5kSPu7ovf+mLge+GCr0++ugnlcOhzdtO Ivnt3/nt7ktf+VI2jP1g94zTnlFOD5tGnXJKTmgI3+HMGpg9WOPQw9Rc8G/R6yemzq3S5qPW1yPI lmwGJYgCoQxQIUwgRdinxNkp1aJfTP6aH1/TLbnz7u7uu+7OmtRDso5t327RwkWxAqyKcjYpa+By lmk2Gbj22h93D93/QDaVua57ximndvsmBGFdFmDz4AQVU5egPJOXSSyIP8qOkiGK/BEiOCpIGrmq y4LD7sffvqjbf0VCiadM7PZevTy7v0Y4HtVPVhNCH2NT1KYQ14rxOQA35axNeO4BE8blaJPJqSfE lGrQwNgIhqWEF4EhmvQ79RUxpG6T7tQg4bJskX3BBd8oBW9x3PhCfShKvXX25hLuKEdHZCKzO/Ht i6cUTI5KniMTkkHhtti8pDx9jXRIIKR4Uph42noC7K3CvDhjIqhuDLJT0imSRyQUk0f3GxdcWO0w +ZpQbayzJpMuQsAcEJKEmfH8Ym7CPkyydm8zppSJxjRyo+5FVKix7tvRK4aGw4doss11+lPe0Cgp m6LUbJq0R5TReMa6WO8M0uTAcHJCbePBHp2x2TwufZ4wpbbj3hBltTyq3i3NOBJIiidYYU6UBTv5 tvbYhOvP//zdacjmrPn9ThkI4Oae8TLaQIgXb3BwsPfcYb5pmzRG+EhK2RxvXgAdpYlinLrzaUwX DDDhaRFOronX++Mf/3jWOef4lFjBhKrySmNINiiiAAvltpkQfgo3gEfihU8Py1M6Ovi7KYYUymIv ZFLAepxSr3F697vfXeNi8nG+lzGbPXt2bRb21ISD/Of//J/LMspSKsERde4q6bMPIa2n2fQ5KaNU Cg5luhdcjTG4gFGu8+U98G6TRxmF8tw6a7ASJptSgLD60zZbYiwaHWNQeb9TZinQVWpgXzQdsMcQ 0Rqu7+DdYN4mqTZeebVgayOyr3/96wmJmVATqvwmTePQT1iUp76sm268qZsUq+O0HLdSSwHUr38F rCGA6WrgPz6wyTSZf0nVpz7b6vAp4ft3x/Bk/Y5x7T2wyZl8QDXaWOZNfUDzxqUfD7Dp8zGupcTA CHx3nspYkUcP4oMmuQcfCb4FV1I6Kgvqp+5+Mq6q0xZrwxctXNjtmaOGikbQdx56rr6WhsOx3fNt jKW1oXk7pt+eECNtJJDgPwQVhTHQ1cY3uXb27223LeoeSLSJ97fWAn8IG/2n2tA3pK9k5O+jQqAE nuJ7O2YFZ8NVQxa4GlMROXiD3bBFVqwbMiDs+HZPnzu7X/eCsEPYv12WHkGM6a4Sg81wLNg+3+54 09a8KWMLXbbyhuindbwYEp5hTujbsxX3+pJ6PM97KQtftZv/+ux6bbd1S2fOOOM5Nc8tDM1cEmOu ZTUXxbC5Kkt8jn3ycd1ANmn74z/6o/DXSVkXtqqbtHd/buO60MPNt9xS8+TqlCcxCOPNeCP+0/NW Ldo5JOulkT8jEHg8EAhem2fMRUJE0f1NMWZThhyzBycPSGQe2Ud4r7xogfI5Nt7UzZFnzJfkGrIq 2Y8M2HB47Njx3QORxxlk9tlnesmCZEVKoDwSGWXPPDf/ozcf9bRreRo9uKd+9bk3PE+b791TdqOf Vo/nrpXdvpXtvtTK9v1vkVRL9iGfOzedN/vhOHn+JR7PZ0aWtlzui1/5WveSc15QkXCHDgzmJJCZ NRY//vG15TC5L7IFo9n8+acXjE88/qmR3x+qExycqnBUjin8x3/8h8jyK7r/8nu/1+1x4J7Fs4rH BK6/rOkxKqcAABkIHv0nWLH1GnTyG3oQtsdG2dsYRfKqK3/UXRnvHWGKJ4AS6miEhbcu7PaL4in+ HYEtSJivAT4qypHw2ftCLF8L0Q1mwn3KU46vTZGybafS+4/1eRGa4n9Lfdk9l2qUe+arcVECVoWw Lv/qN7pnTo/nYd3qOFfjUY0itz6KpnbaJSsrdDS22xDl6O5HHsoOZFHUssNr/AYRtpIvXU4tueZC SN5McvCAzFDCdwimzltNxuuvuzaKyo9KIUTkswcHSynk/WKVnT1ndiHT0vvuLaZw6EGHpJxN2aUs k+KFF9ZC6ZNPPjmbOkUxrlBHVeprmuEbrHOtvlLUoznXiOTZ6OzqVYSZG+vTrylTnat6bjEd505h QockXBNzkQj8CF1iXRMKJtzSRkLabr2vMZaqXP1On62/9bsxD3lcb8o3L2kxqWHXpaxGyVwT+N8S 4WmPFcu7fcfHyxxFcF3qX7GGlT+hpYHvpMAix81mzWlwZsW67q5xe0SJzUY2xjh19EoHYSRKx5CA 1CtE6U/a98iy5VH4r+/+4i/+onvPe94TQl/UvfnNv1EMlJItPJalHCykZn3bMPS7VDHjmnDTfG2B kf7ps75ihoRAG1jxjn7sYx8vpn3mmc+J4nJ/jb0QXxMDJkxYq027qkZNz9gFrBSYdLcweVPq61l9 n6nRlvbxYjNuaAMPOC+pdaIEKtbQgYGBLf3RtsKI5N0+6U9LyrdTbp8we0/7/tWz+t1y++7fBgP/ 1LM5OJafRR8NLoUgQ9kLZzJG+jp0K+PY6smd1NFgUS1JRuUQ8Hz03W84atzbpAQO4IpOeKbhbqbc 7v7AnicVjZlklz+Sne6yJltZwppOfOqJ5WmeOWPfoc0dJqQfhEiGpr5/+VF4Zkc9/KugmUfwfmIm 6v2DO5dGIf5CPPHK7ZXT4KvrwLMU9MBGG7VXqPxRRzkrtFfmChSqSt8LZkOwAZ/tk/Lg+FMiJF9/ 7XVlxCvYV8b+RWVI6vNxBNC0hBkeNmdO1eF9bTRI8vaGD28M9deT3N/SjFww1A0eOtBdeuel3de+ 8tVa44L+2ngYdEZAVTtnGT8h2Ow7fUZtEqPdtbu2WlJN4UjVgLOPpOEQAPuik9xs143PyFd0BieH 4A1+NVb5XfeGvSc/jwbcMlZw0WdXaXfPdv1WK603arZf23xzne82PXrpu3odjLamBo3+2zN8AFwa DBuvAJdpWQ5x/TX9fgoMfWdlHwuhdkLpyBY2JsQ3GHjMlwfsf2CWI82pMVAOmNoUxrcNFK39Ghwc rA0J70x5z3/+82v3857n9/OE8asx3NrokasRCPzEEBhOMS1SogoJrpNr5s2bV/IAw/j0OBkeiSxH zjE3kuXOO++88pryqvKeOo7F5pwMWCLtfH/605+uEHfLhkT7UWD3zOahMzPHPhxDpWPfDorDY1Le 33uvvXNc3FO2zM3PiFL8UI6RY7xEe1Kj1eG/27W5sV1vn69ezh90I8kryS8vWpSG368b+dPytN9P 6Ld+Z64VIcd4tyKyKH60R+RAjiFLvsBWNN8111zdnRaF9fwvfKHkufPjST0+Mt2tUUxFSjrRwD4g h809LBvK3hY5/lV19A9D+Np4TZW3PmPZz9zDeeIT2uMnrDIa32NIEA9yDCeX/jV3tgcTRfT2hbd1 X/v617pT4wFlYbn88stLUWtKUkNOxECgJ6izPlDYuLR5XK9I+OSBB86qTW/Uz+tTMlcqHZPJMLaa asRoXqncoxCMW5dDen94Vbfs9ru7PfbdJyeYrOlWb5jQrU0I5aaE5BE8N62z7i1CYATPlfHe3ZG6 Rk2f1k3OkSabN8RTG0JIrm16SwFLrYWIqaiQib68LhvIXJa+oannZaJypAwliOeUVxgxmdgQnR28 pkaIXBUFnWdlYGCgkFRIlomUh49FtqC8PWAjfGg7IUQoMGJtRAmWvQIXOOQa4+JBfc3rfo0kGY9P v74GcmsboZ3SLOR3epiZxq8L3NuzfmQRfcY8sCXs8gypg3AjX2MiydSyb/udptpReK+EjO73nDO6 h7Jp1MbAa2PKi34aRSNGhMAs6lI8W4FsFNONCQEeE53h2MOO6kYlZt+ZqsYIY21hhWBfH7UNMaw5 gZ3Niq644ooIHicVHF/xiv9QCp7daM9701tkpnX27xZD2UW7Wy/S18pvYNWTeu1cDC+Fdp1zzvNy bM+La9deO+saPxt4FSIMtasVtc239u8qqavU1q7OubXW1EZM73rXu0pRHRgYqMnnd3/3d2NsiQEo jGpM6i13mjKDG7tMj9am3bULvDz3STnNM1o4YBLZZdn6ups2aWwLC00ZxpggiEf0m4T1YXINvymD 4NzCmReFqQt9hpcm0UWLFhW8TM6MXvPnz6+PdvY421tf4bUyt58oNWc4XdV17tnc7ZCsG2/twKtC EskbnjLUd2Ux7KjH+h5hOoxyjVY8xwt4kXujgNp2TPqonre85S3VBxZq8FCOuooGwSp5/FYn4WP+ GfPL0o32wUift/YPLfeTvBq9Ozz5bfM1Eyl6ATt1qls5ynStvlYv4V4f5dem1k/5JfW1PhtXWLBt rZVt5M8uIPAoVLPjWwEueOPPvp/49ETV2bCo/2YQqSUu6TD6gp89nfW097mcTWrZkKUQb33rW7PB 0fT+qLjMBXCY/CFiyNxIQb03BuQDDjxgC/8By0ZLjoNjGITvEoMuQxkPkzm1N1z1RoLiMUPySWUe +TMCgccBge35J17sw9jyjne8IwrN3JKjyZV4MZ598jOe1W1YY7PNeE2nTKvoH0ud7NZ/ZDbnFOFl /oDXCxcurNYpc0mMLk/JPiarUwaDzdHZU4UMxpFhox/0Rca3RwxZtN8XQTTR1jnncXT1F/JVfMI8 BwbkXscXcr5JxmLp0vtKSf1YNu0UWUU/MHdGDemmZtkfHkJHslTAGafWtIM3rzhDw3PPem7GamVd G19joM5/G17/xAxRz2UfU13bTj7RMXphdSfvGiDejH3jrSBIfvH882swMG8TACVs6t4z8mZPcquX P9xdmJDYhbHcDAwOVviNQ4Hb1tcmg7V5t8+dkM4Q2+Z4MymnlMb8jaQIOaJPRLm78F8/303MwC1J mI6QuE0JfeVpi34VhYf+kMZTTies75aseLB7IIrRzL2yiHnpw8m3Np8IiDqY/+rso4d6BbhvQy/g sWZZowJ5nva0k2oNAMGQsKivzw2S7TfroBQQi7PG5d7l2VX3yhyVAzkJ07xjwkEpPUXc6ky5+dom YTAUREf0YDCERUk93mu/MRe/fXtHGh/vsHOT2kRLWWbpleRrn6oj726D8CEeCiqdqdbd5qf+Cf8z sVdLtXfoo8xK6e/yhEQd/KSjunP/+3/vxuQd5gTCxOg6+5RSY0yi7AT+An7Vsy7jNC4hmOMC0/E5 X9Wan2984+tbCFrbWh/bdW/t27NgiODtZnxZ4Kyd2vWPH/1wKT3a1WCgjF0l+AZGDR4NPhgCgYZ1 cloYivvWgconffQjH9lyvauyH8t95RlPtEJJUI+z9ISIEII++MEPbhGGWnmUnoBml2l3/VVf68Ou CoBnYAJ+TfiDZ4/l3V2V6b6zSOs75Sob40UXvMR+t2farz54qy3gwxjBaoyZv/GNbyx85MnguRSG i65MDNrbytFeZbV2N3zwW752f3g+Ewdvi3DiCxPpcGTCbGx85rd2KMOHR92E71o/fFp57kk9DOty p3881091KktfhG4NDAyUUNys22DQLOAEZL8p9L71o7VJ/cprv1Xa2jK8AerVF4q19/FvfIYRS2SF KJDWF+8RWOwQqSz1+m51qa996p3hFY1cPzYI9GSx07xg2pLL+p2L/rs9+ffxHcqD0IWzDc/1nNBt J/LF8e4LbYTX0vIYrsBJXrSCRuEuvuKD93vu4758kjmesCg/ukQjFFVzDD7T5vyG93jMzoQrZTZa qYJH/oxA4KeAQJMz8Wbzn826XvrSl9Z579/JuezPnjevu/BrXynePJC5A67j8W9/+9tLriBbUGTR xmGHHVbhpfCYvHF3luBNnTqtOzwKrGVKaME8YO5pNCGC78FHHu4OmLR/zafKHk43P0WXfmFfCUlv 6TtZ1NI4yjx5zbF8+MTnPvfZcjuAn+ivwcHBzpK+adnvxrF7++Toyxuuv64it8gV+Akvq+VaqyNz 2riSUZvii0/V3igq/iVOO+Ofj6m7jwYWgs6kbEDw3VgDCC+QG2O3CyyB8jMf/kA8enfVmkfEJSSS ErI4650IW441yZBXDDd3Oa9qpXg9isFnUrYutMJfo/xtGh3iCMFE7OzuWLK0e/ihVd2PWEazNES4 r7d5VyvCMO9Zbjhm3NruzlVdt/dBe3ZT95najX1gaZAsyk+eb0x9mxOWmstSbMeWkharaIRpE5PJ pzZLyuRFYbg28f0mJkomN77zLk1on/3XT8UqtaAmvbNj/RBOMTaKIsGaV8zusrycmM3uJq02SQpB IiiymEneaWn4df/M8yjhgctwb5F8TdgfLsi6Z9wwGWPV4O8YFN6y0Zm4y1KdNU3nvubcIkDeTTBq qTGo0anXGruxgeP4GTPjAc2GFOOygYqxiEeJos1LxiubVsaTHaVDMC/Cy3u11i31LVhwa+ECLw3B AZNVR8E//XCNMWK2iF679WlDPOBg6tO8cGCo7z7e21XyvOVVn+S3eowtXG7t8N1giGl4d3fp0Z57 V9uUBT/U2RKGpX59VG/DCdebGVQajbQXhn3vrr+ygeeuUnu34QwcAVf3G6x29a7nu+tzMKvCt4fX wZNBmNRPY67eBm/5fMDF2g3n3PIw23jMPUc0XXzxxdU+E6+k/jZGDW/cd9364He7dr89A2NtIOTa +MoGBVdc8d0IAT+IkLpfKYjCBRksKGstrFt9bXyU7bfyTTC+d5VaffLjk9Ybq1t0BUXV+MON66+/ ITsyvrq8Pu2ed5Xdym990P923eptedrvBmc4pm5HJeFl7quXZwk+2t2U5Z1n17dyhvd1+/Fuv3fd 49aCke+fBALgDrb/3hM4NFjA8YaLNqqDv5Z0HBPeQCltzxvM0EsZqnOj8e6Gr74bPeF31rijA3s0 MFDOi/BPSVUmJZhRlKekvdfqGPkegcDPBQIhfTzVvAjH/zFzkznokODh2ZGlbXToaD2yNJkR7oqM edvb3tbtE7x9KMZbOM8zpwxRYegIrq/L/hMr41iYPHVKL+PluUTparKU/QhEPXkXDXhP+vfGk8J9 mMe28BYwlMClfcgEnHTCrhm5zZsll8axtW5t9oyJM8XRgcdG5rk/EWAi8SwhOyl5L4osA9bgSjGV 7KfRj/4vN7x/auW0oLSTP22ywPRZGveKMAV5WWQceYKxf/7zny/LgGMyEM7nP/+57pXxlJ588ind 1VdfU95E4QSsQn2Y0pAQSX42GdkwJ2sVN0WRdKRMKohymofZxGPM+IndEU85sbvgyqu7B/Nock52 EQ6bvfxqPSdhuNZOBaPGZnJaO2Fttyrrz5atWd+thWWUUkJ+PhRdqlN5XZsgUGF5vbA8eoggKadX X3VlCP20OpaFkMrzIZ7/gawdhJgEzc9+9rPdr/7qr3aDg4PVb30HF5Oo/A2xdwLWErwJipCaV+nV 2So8GFv323smUwwHvOVDHO4FQIXctTYgz9xvTARTca0M77luk3LtBhpv5kZxuIFby0MAoAisWrW6 f6fIc7tWB5ZZ5puUMIe1lLbRWfNwQ/d/3/d32biq607KbrcsS4Zt1bIwwmlTu+NPfmp35hnzcy/r YgN7dA6HbCT1mte8JmVkWIakXG310SZt1o++/akxuNdvntUzjSZ4y+fat7y7S62vw7/bu01p8r5y 1CcfuGmj8neVHq1ez5VVE09gDNY+xsx9bQB711KfH1x4y3ZVq+dDgNtJlt21V3b1y6Ne37UuM31t YSw7KXLLrd31V1kbynjSK3LK92n4B86u2wcMGjw8EzrzyhxRw0v6ute9riZOIUr7ZfLda6+9u7mH zS1+09rg3UoAFXioH1Ra+a2f7vtI6pmQTVSEuqLhM4KfX/7yl7of33BL99ZnPLOURRsJMToRXIvm 8I8k5bbxTIFFJerb3bq/GqehcSQICEkkFHzyk59MyM8d3ZlvPLMs2DZKOOmkk8oApo7WR++3a31o 1761Z1eJ8QlMvO89Aveb3/zmqotiPG/evOJjDGPgThgHL/ymwa/VpYxWV8OZXdU7cv+nh0DhSmHw T1/GL8Ob6Ald4Y3w0dpxuGnemBYP0JrQEVj18Orp0rppOGpduHe86/lwHuQ5nEYPPCLmaev2zK08 SqIyzOEfzyZ55ifLZBrN+d5Zam3Y2bOReyMQeKwQsCv+uOAhHDXv8HraRJHHztnuVyfSirIqmsey IF5SkYgXR9mhiJI74SI6aTiubhuQOqKEwXNj5mZzEFyW18d7nA7jQw9r46Ro8/WjGV0fa79+0fKR kSOhlIFd28GywdRv40OGeE6iRcGx/V63Ps6fwNNvMFwTWHpXRCWjuncmZizXZNwab8LkbEy5Pvk4 InbFY9T7y5B+5sopoACa9aFCaxAQ4GLkPCJXXnllAf7srNeYffhR3cpHHsxGNu8pxs+iMDg4WAKe 3WVZ8RGEAYzIlU/+pmy+pH4NaO5sjhpD1sxn9MYx3fhoPnOf9OTuggnWTGXCSpju+HjpRoXQssVO BGoejDzIexTbPSeM75YnlvvBVTk+ZkyOTcmgj86zsSmr6ubqS92b8t3X2QtxaUolef5/9t4DzK7i yvetzkE5Z9StLBA5iGBAiJwN2BhMNrbf9WDG47Fn3vPn8Pl+tmc893ued+3xu/Y822DGM3AdxgkM g43BApFBQokglBMSEiir1X06vP9v1Vndp1vnnA7qFq3uXd377L1rV1y1qmqtWqtWIQFkryj1ZfUU dTueOdOU86aOO/HkcGCv1OR+/RtJXV4KV2qlC+kbVnSnTp1qTBorXPmcGdcRA6LsNJnWmWVBwoPY qoxgDq7HQgF/wuBvUmd1IPwYaIAlz8SjXegEvHPxzQcqOhjfeWfgiRJYGLv4Tt7AhSyVup7bXCwc qNMiGa1QWqhG/+RHPwi1NXtCxaDK8M1v/He178FwvFQbFr34cphUVRWmz5pqTKaEqKqYVuOUdpna h7oTFnVdt7hKWSEs6kVkmBVYGeCi/pQ3pXNvnWFkoE1JrdvqaFIr4YLCqbo5HWGxTIcjPathRjol UjfGQdRQf/IgPQurd8cNC9TmR0HzOr6zMkZaNuzpGcM0qhANbGeE0i5xgUFeDI7CY/IH4rlcvm/5 ykt6nEtK+oY7wFftoRnKBmGOC4owypVzvgoLD5WeT3DgHM7xEPiy6MA7bWb5qyD400YVAyrDR8Wc gh8RBhw1VBdmSpWc8Hv27Y1xVASz6K16mDVbqU8YMyZ40T9smwDpC65+sSqMK9Lemjrh1iSNTbOP OzY89POfa+VzUrjz9lvC5VK12a+tA0OHD9P+syvC8JEjFENjEm2i9Awu9D0Ssskkjh1x5RPPQ50x t1rVQSNh+Mjh4dzzzzWpDeefnXLaKeGyKy4zA1lDRwwNl115hRWTM4PV1ZrhYz0PmPGXhlsB6iAE yuUsnMJQTv198tOfDgufe1bEzoBwk7QksDxYNbnKjjRCOl1VVWVtAC56u5h2i5LwdvS9yZF1yJVx 4t9ZCNCmmY73tn6Z3/v6M30WB7HM/MSCF4Q1VottWw99UF1PM7iNFcV6L9BxdoxpwA2Cm37nC7U+ ntmcoUC8s0CEWiMLqjCizNcQ+iy0s3AV95i3zJ+MA4lLINBTEAAnmcvAW8ZgBBZLRG8iCOF9kvZY 33DDDYaXX/ziFw3HocERDkFXw8SC3zbfKB3HdfoD0zAGTW3RR2jsww13NNJgTuk/xfQhzSvEoTwN ItwwNtifxiLgxkDCnOfzHrBgAYt5EfhGmMYtYfgxzsCcQntE5lZ8ioRe0OzQ48Qnjp+G4nMsRkmh BVHpjXRwXDToKRz7oNPtVubUkdIAqzaLCBv3N/JcpNUWBngkoqiy1utMUVYKTjnlVJNKsPJIw0Gs 0tDW8IKQpav0cKh7QoZDZ7Ev1MktdZGgk0qkRloUxsgUfD0TlhiXcs4kEXNSILXfEphUmEx1Ilae JNsLBTorcb9O49ipY00PGnMamd2iBqXH/CKEaFDcBon4lLzSBBnjxAMxRtlcEgJigXxcrKhWVVXZ 6m197X5DViTHSCEcTk6UM2gAn7xOWRIeQpyLSRj4oLJLXPyYEEnbJYcQ7PWaoD2/zPQpI/G8vKQN 0c874Xmn0wH2mAcqHNQPximuOqOaCyRiKEK2XPRZcVmCjQYwddAy7Xt9Z/PGcOysGUbsb9myUeon l4TLL70srFj6evjIDdeHU0460ZgLmGE6qxEdqif18fqSt4qn8lF/6gA8WghzK7eVKuJPjBu/04KU K+IVJc/tSD/CKKpoUB5bHRR8iM934MQfcMfhb3mo/LlctrbwsLSHfVe6LITYIET91ResbQRvypRS 21BPJJfC1mgQxLLMXad8+ZJ/hImXpPWdb8SnnSPjlZZAyg/cd/xvHSu+KUheR30YwD1/8vEBnUGZ d+g3ROsAACAASURBVODCd8K64xkYNNogH8sRV5OjepHDh33SMIqAh0nVyqq0/BxhGCgMqmDogQOu 94qhhRm3cYa8gbPulOVCWWaeoLFr3Pix0ggZpLFrkK1IYxiCxaYDWuUkXy+bPSt/wxClYWfAUofc 6OHVi7BWzPPOP8+O3mIVnG0CaFicP+/8cNbZZ9lkVlNzwNK18U95xbGgZfU2wo28BT+NjTjqk83h zwWuXXb5ZWHCpIlmzI68KzR2l0uCfNddd1ldIXIYt6irp0de5I8mCXtWOYTcJm36L/lmyzTxSyBw mBBgXAL3DH/VB/Rg/RycY+y0/igcZL8O+MgYgB+LnYtfeVmq+ltMUoRWwIc//GFLhzHIiUIff9DQ WLNmjS3ywtBiVAZL6mgRsK0EZ+XQ3bbSmE/yk0Cg+yEA/vpYD64i2Wds5g4divXekZqTmIOQxMEs wZQiQYXGph/QX/iO8/TAX1Y8mRdJnzDgMuF4j0wXi+SaFxXP+pwWR5nWUjq7vFBajf1qpBcQzOCf 4AbsbKwBNoKbj0k2jgjewJ3vOHgHaI7iYgk65Ad8WTBAHRtncC2ttDGIdPjORXxO5VAAC2OB++hP h5hTAAnO4gx54yNvurKTHHQYGE9MrxOHwfw96b1D0PANFVf2L8Gkcm3atMmkiBs3bjT1Xwy8QOTQ GN44RVqVMWuXOq8UUSnNXCiiC6mmeCZ5Kaw6x6iqCWGgpA4HNmwKo9TRSmhIGEoR+khqONqiWO+o fhY0FoUKSXn3qmNx3qkysHCkS6KiZ8UowKBG5jGqNIrx0QfSYg8mdQSZqC91QmoKc8qExX64devX mjR14vgJBjm+AwfCo2oB0UnHz+tAYMEbAYjtraU6KiIEr7WAvvNAKpCC7MVV6XTnjRBpaY6eYHz0 b3DV8BOzVV1ZyTEXP2rfbXz1NrdjY5SaluzS+aQXCwQLG5NUB47pgWUlifpUlM7CQqWk2vuZez5r BxFT4v/rS18LU6dMD6eeelK4adXGcPWHr5Mayhhrm6IiGVoiAZUHKR0r4VYX+bUY0FHewEz1AxD2 XcW1o3aUvkm55W/rCMRLp0e4dp2S5KgfUADwRHhTb2DJ+oTyxZ909c5lTn4qkPybfaJ/q18L1MrH X2CkcX7ci+Wvd2tzGAtVxvJT9vQDHDjAZfAyn+w/3obZv+b39bTbpuHv/j1/Krm/Mni3daTtAznf DNZUNP3MPfO7vds41TpMlJDqazo90mUyAdI+2NN/GWvY5/HDH0rtXO3KN5yFB3fkmFyYnFmhNgmN cJ2wXIxp0TFJxXi8x6je5pSNZ3ppduf15A5+YxURtWLKwzuMI/Diu2uWeEr44VQC5SJcScPLsjSw xP7t4Txe2zvxyANCh2fyNniYv1Z9NaniYvqx/jZOK99UncqnMsO8QrwPlLEHxklbIPDytM0weW+G AO3mCyfmCS6pWR1+tB1w9zYE7iyggBvu15xYP3sAR2FG6adczLFsC2F+5Rm4cUGYs4f6iSeeCNu2 bDaCHbVIiHgkohg9+7k0JLAbcfHFF1ufxxAhe8eQRmFtk33mxK+urrZnGAKISxxdLfYHe01+Eggc NgR8BvGEwC8kp8wHOMZq6EmYT56ZeBgTwHefN5i7GNeJ4+MF6eDoE3yjD3FWp93Vh7h7n2F8sfFG 6do582mmFWObFl7xFVjx4yIQfYJFfRa0oZMbtOhLuUgD9WHuJuCQH3/QXPiRn/lYvLjQyn5L8qRf kw59DEaOhaYS8tU3X3TyOnPn8jStot39w/isPHCeL3ByWDEmYMzyX//1h+FECacQzDE3ojY9TYao TOAhemCXFnPf0hYeRg/aCSOIo8eMDRNkOZx24TLbL+k6kV9fH+8PpQqpdYazBm7bMzK+Zz4S1gHG M6v8dBaADfI++eSTdjAwzNmdd91lRk849uGRRx6RYZMtZlCEjkPjYfqdeN6JbMVTnUJNImRX51GD cpxMEY0lZoAJnDzr9TxwxJAweea0sEOGRFJS0RVZH0qF9KjKQRgiEdWrXWw2rtQ+1e0HasM+tH1B dIUhveh4IAXypvOwe1WrRCARHUl/EKZTpkwxBNInkwK//PLLYb0mNCaz4+bovErVH6npKy+/Es7U 8TpMdqgAsxprUmSl0ZwlieRzQn5zutHp6fBEjl2k9T22B+EjY+PJWljFs3s6YnPbEcjzoIaCa/Qi nRZH3Rkw/CoRk89AEaWZiiMgYhDJJK9iYM+ee5bOYpwp8baMZWkvEMmWSjX385//21AhCTZnRbFw YOyt8mfgglAz4lYDJuqQTUiucbR7ulyU1XyteBlldP90eLvx0xFH3LbpZ8ZTNumSyLflKQbJKENm nHafYzzP1tOiHM1to6z82ZNTUfuMa4a5apT5nFnBbP7u53cP3/bdYYe/T1qMORg3uffee23VmYkx X2dsnWYm8CMeeB5ehtZ38DY3c0qZcK3zaJ1Crjfi5MubfclddV6unPFBQuXPOE8ZuDMBQzA5AZUz bvKhFQTytWGrgOkX2r0r+JItraPNz2EFvrk0CEaUhWEWxJ+V5VLu3jegJwi3fv16M6Y2ZPAgI+ax qMl8DEEN3UJ6GJEhPM+kxzOL6Bhrg1hkARr8pgxcnjb4zlVS1vX+drS1Q1LeIwgB4RpzyDIZ4US4 wcIqsxB4Cp5Da5aIQQWfYYbwB1/BT/ASXPUxAz+eWeiEjuUZptecwhmjqxfC8Ux8jntkgb5Siz7k SxmIx+JNgejR/Xv3aU9qqYW3Mommg6msqYkqq/S/2FdRZy2yvEmfclEG4xfSd2ZU0uA7C3R79uy2 ohGGPBE4mTRYZYOlpXyExZEn+Vg48+n+H9IGBpSdcjJP8qyfCEvlj60KDKZOqa423oZtAE/95alw z2c/G4YP08KZFnvZy/6ytDhOlXo22+9437nzfZ27PCamp3xoc9cqjFut8s/33V/bI5tiXubUgKzy eAN40XiPZJj7HHoHQUAUP0OMd1RgQKS77747nCJjSLg6rbSzofvb//gP4fc6nBbrYZhfxgIZBwaT hiMnDWNqpTqKJDKjSkBlwYAOElPQBLRkMsIM9sb/ejzUwjCJgTqQktleOTsORdxpvcRRUuyRdVjF L9HRN+/tDvsGV9gKDGLAeukIIzGNFY37UKFYYbyou++nAkb7hUwYd2I/LQMC+1JgTj8rYpe9KnF1 SFaBZaSFlSQMKMybN8/qRjwYVCbU/M66gIIwcLC6FN+tbVzimT+BLn71fLNHj4Z4ZN1XqtP79h1Q h9plzCRAor3qpXZZor0J7D0t0CBVqYG0XjCrr9O5qoqzX+1bqYFm3y5J1Fk8EANaqPNo6zQ41ddj vl+m//lTW6QkiVVzGz5SmmZJb/aiJb4JBHJCgAkc0ThSVKT95Vr9nSz1PMNbTQKMM7kcPSKfyz82 Mkq1lwLFyJIKXnmidiTdfOXO9w3pfS5n8wHjsGCJ4x2igLG7rXQ3VxqJfwKBrkDA5j/1Y/aNo7AC mjZq7hiixc/LLr7E5lXmX77wDRw1mkLz+OpVqyWheNRw9aGHHrK5GmMxELXQEBD0jtvcq6urLT0M I+EwuPRrnaMKzRKJbeWhcvizBUp+Egh0MwTAYwQBLLywmFJVVSVcXmU4i0YAeLpYFl+R/CPkgfZm oeX993dqkWWIWV2HYXrwwQctPswt2+1c8o+W2xYtvAzW4uLJJ59k6b0socq0aVPFNK00Iz1osE2f OUNnBu+XduB/hXnzLrCz5uu0zeTrX/+61RitA/LhQgCDFVqYT44h46hI6H4YsV/+8pd2fBxlR3CF QVHu2G7hmBsYNbSa2NeN1hL9khM+Lr7syvDnPz4W7rvvvjBEYc+/YH7YI8YPuLBFEIN+MOfAqKcc /R2mGWfPGl/QqKDMWOBlHKEu8AUwpfA0lA1tVGOeVZd6bScibnlZuZ1M4dt3hg0bbmMJc+h3v/td 1XG4HRdUWl4ioU8cm3qqXr0h3bzMKQWEGYigj8X1wTrdHIfUwb8DeFRqMIiEVAJ1XRoKZGPTdgvT 2RSq1LmwKgbjuk7SThg2DCIxCTCZoMJY38h+SKnoqlPKhA8LJmkXFVNRK8WLvVUlhSVhyszZ4RER SPvFGMGcNmjvaZOp/8aSGyElZqkJ6Vw5DS0GVh2nTgnT8Sx5hYcRRE0TleFIMkaykfioIeAwEb1x 4wbblE7HYOWVlVg6GR3poIz5oIoAUp5//vmSqG40ZAQG7FeBkeWbww4aNJ8jXG9ytGupVA9/9atf 2Rm1LCZAW9u+G7WbST7VBrQD6tDy0eiqNlE9tJ03lIrRRvUDNWI2fJdKrRekK5R64MbNm6TmfaJ1 ZOBl+BibsDeBICnLUQYB2y8u/tOMO6BKIXdQRs3o1xg4o9/mcvS+fH3QJ6ts8duLyySFU4+weyaT Sp6UO5cjbL5yedq54ufzj0ty2UOQLpf1ewWBOIcggCg6nDyz55b4JhBogQB9jbkDoreouAUH6b9o 8TA3OW5yJzzqf0heRumIs6lTq21xGMIc4hEpEETwl7/8ZZtzyIl4pA9+Iz0Ct/Fjzoawh/jmGzQP zvqpxpFsszTfuIifuAQCXYEA+APtiRr6Y489FnZIuAGtzXjrRpFg/LBx4mPwv//7g+FH998f7rrt FsNt5jnU0xcvXmzSf2hVGEWOOikS47P4J/eZDYVt295VH6q0ow/R/AP/oc8nTT4mPLvwWRvrq6un mAVgmKrN778n6eYe6xsPP/yw2R6gL3L6Bn0RehdH3jCfaCJ4GXmmDDBzN910kwlx6FdoKMA8U7fq 6moTeK1YsSJceuU1Vm/i7VKeaxSGelEO0nFVfu9rwK27He0ATUsdyZs8yB+bC4wLGHnFH9VeYHfP PffYkXSMNczy9bIJgz91pk533HG7jUH/8i//YicQME6xsEB6mzZvCfPnzw/jBw02Oy4ssPdEnbob Rl1NLzcF5ilqDAUANGtHG5nBGyTi7EGkhCfoTmdhRYFOgMrBQSGTIyVZgagwaXQOmNRnn12o+CfY yg9MiTGCWr7nWcsGmmRgSuMAz1EvKqRS0aVBnzNKR02cFBrUGd5XWqEApqYupLRvFH7TziyVkE5z miEOVv7qi2QERYxvSlxuSh8QTMLwShnY9qvChppfGgGBBeUHediv8sQTf1Kn3GvlRX2ZTmgqbaSt CwQFgfGD6UZ1GVXgn/70p2byGwkrBkTac0caGYEqLkI6Pmf+MmkDiyuuuFyM93n2iU5D25SISFXP DfWip2E8gT18QKpJ7CmMgd4LBdQyHfQDhtXrmd2AZVhS1vKAyFuDOYQD+QA/BivgDjwTl0CgyxDQ eIHUlP2R4BP4RV/mzhgCAZvLge8+FmYLky8u4fPF9f4dR1yGtdblYPd1LtduuehwXXUMljmczQ8q J30SWPo7TCp+9Nm29ciRVOKdQKBTELB9Zuoi4BoOBpE+zOX9DBx0/KsXfoKjXDj2mHJByLKPlO02 HJUEIU0ajrsQh0h+sCmBNhj+WNtnDocY9byIE9PX3jvLIflJIND9EOAopKlTpxqd/fTTT4d3xcAg nYTO/tOf/mQqo2yrABehx6+66grZAJgpfK02bRZoKQRFSDFhbMF/+g59YdiQYTry8NZQWl5mjBL9 4pJLLjEBE4wU4WBAYY55hnlioYa8mENvvfVWo/Ohg6HXuehPMJHkSx9jTyU0PwtBzz//vKWH4IZ0 YNzQQkR7cp2EVQi3kEKS9ypJiCnPpTrLFS1Gvh133LGS4s4O+8SQooUHjwHz62MCfbLH6EWbnuPc xxhAnmiIUtczzzzTeBnGCgwp8p3xw7e6oD7NuET5WORCLXrt2rWWBnBwR/xqjTPr1623diIdFtD7 uss7fgIEIzQkjcTxbo5Xe47+0bPlFyTlKI558+bZJmCYUjoA5q6xjLdJ+z1orFp1GhqTVQ7E3Qz6 ICad6eabP26icFGQxrjox1ZIEVaiHloE5yiJJsZ4C5QfynJCESPdGpvEyEhVd0hFSThGRZ4AV6nG TFFbhS/Re2O9EEnP0H4HSzW5FZeGmjohsRhJ0sKRmtY29MQ70lXXI1eZlCfwKJU6IHtQqqurwjPP PGMqvRgC4XxCOhHfkPhSTwYUOld1dRwgmOyu1HEUMLJ8N1VDh7FybM/5hNteuJ7+TjmYoOlcOJNK Ca5Fklo3SnJqkm7Vy47sENxkXsWk06hOsupUhCErGkKqu/wVCE7WAbWYEI03xYUAOjGuGQ/tLflJ INAFCKhLg3PgkuGaJgBb+FJSTKCMYblcvm/EaQ8/88VvG7fte64y4Z8vXb53Ji3CZzr1znadj0de Dt55dv92E0gCJBDoAgQgPLnANfpwZr92nG9LnELwQVhz57gy4kF3kIanQxzCkAZpoqYIwYwWGPG4 oGmQ6qB6B2Hu5dDokrUmXp6sHxPPBAIdhEA8baLJNPFghj75yU+aMAimD1yEUQUvmctY3Ee9FcYT Og2HH8ccgt/gO7js/aa4sETS0dNMMEC/4BtGA7H/wTvpI9kZkF6U4bv3maFiOOeJ7sfddtttFhec h74lHuFwpAOzyR0L2ddcc429G52s9GCWYeJIG0c9SId322Oq8uzd+Z5pYR6r4wiL1feMfhRRTx7U hb5I+jx73SyxbvxBa6NATIgzwIwh1113nTHzqCmzqEV5MGqI4A0+iMWvhQsXmj9HbmLsibJWiy9w GhpmHC0O0kMlGGm1Kmiq1gixSBN49OXxpJhGi87v+VvOGjo98KblqVkjkCwaaKO0soF+OSsgf/zj H42BA7AYChqhzrJ9x/bwuPaGLliwIMy/8MJww/XXmyjcy4XUsViMI5I09i2a6E3x6TmwjmZRVowq rCk1aBJDI2FIKC9uCJPLi8LFMqc9Vep65fXaA1Wiox7EaBdIbaFYlnnFwxqTVDdwQFgp5K7bsDlU ag9sYVpdN60orIpExtc42wwwgRiO9HR29OBBqL/o/DNWVdmPghGfiRMniAHfHxY+vdD8qqdMtRUr Vq1sM7vSsQ6VFZK9w9OrHdn2ljKxcg0c6EQMIEg+MVaFVMo6kZ5xBQqHJUX2oZoFYXVorP9KdoXZ NQ1edPC6UKuxCEvDZg1OcVghAsYMWnRg8vLBkPecztSwc37tsQ+ojieu4xBoi08djyk86UzgNmFZ tcSCt00qwilPzEzotwnb9jWf2i5h2ytX3viUhTSE8511edMlzc4mmBE+W3kyJ0YfC+mTHpa791n3 y0gyeUwgcNgQoLcwdzIngGM8+1zhOOe4SRjmKCeAyZzuBgFLGOJy8exzDGHxg7hHRY/5GuKS72g7 vfTSS/bdiWnw3Qnpw+lvhw2YJIG+DQEhF/gNA4fEEaEP1l+xX/KJT3zC9jz+07f/KQwdNtRw15hQ CQLuvOtO2yuNQAjcdqYKvPV3kXA2bqs3WF+AiaQPgPOEqdT54uA2cXmnv3j/4Q4tBz3IM32BcMSF wWWLF/6kSfnxr1CfwmGclHwoC5JWvrPgQ/+079zlN0hMMQwdzzDMxsTqGUOplIfw3o+JRxl8LLCE uvMn3cmpE3Uh39GjR6ncE40HQLUX3oB2Wbx4kaTd0yQdXWNlFiBMIAWPQLkRXMHvAL+1kpLCkJqN G2kSjh07TrDTkXdYOVY86Gvq35ddXsmpVVwAiGwfA3lEQho6Ci7T3+Tf1pmXwoGkEHyoECBuZ/Xg Z//+s/Cd7/yzzgscJxPKu8J2qbl+9StfkxXbM61hSAvjN6l6MZpCaGGr2cu1TqNvGMKBf4TJ0ZSk 70J45VUgT1PxlV+jGJ1SGUEakNobhuic0QEpWRiTRK5eaRYrPdLQoyH37t21WgUaHIYoA3HrkuRp glPKLbXSEy+qBxazYKhgrDCkYk5+rKAQaMSIkeHGG2+USP+s8OOf/Dh8939+VxvQJ4Qanem6dvWa cP31N4RLpJLAJAdscCD0Ue/SOEB7IDl1KXCTnlHlpUMZoykYNWpRoFCq2XFwYjBCggpXKiiw/iCJ K3AWthlsGKy4gBMDAM89Ntgc9Q2RVKAjEEAiDz7ZIK/nQvaVC69sfzRjSRqfs6V1OGq7pNdefMIw mmQ6x/fDKVdmelmfybTNfOevtkIsmFAOL4OPW943eee7Eyzk4YQFYXBeD+/DpOV+FiD9k8s/M0yf fFYbWNsLjrndIdihNlG8tt65E+gzX4ASuAJBh2YShB7zhuOU9TXBkvkEwNK/3WHfoEmTkdEY8uRu RHw6DOky35AWUh8ul45CXJ977nmmGcU+spUr35ZhpFGWdCoFMS4aIm5BNT+aJl+LWqDkJ4FABgQc Z1BYb4s7aCYy3nJhxOt7Mpjzwx/8IMybNy+M0LnUr2mPo0bqMH7CJKmjLzHcRVX07bdXySjScBss wFGjvegxIug5PxMyDIYIuyD0JdQLrQ9p/CYvG5cVT+u66nNRw4jvjPnQeJweQVmRCMKUioVVHI39 Co9KPX20ROcLM1iRHncVwvoY6cXY8tM/39CuxEHfI9jAH2OZzNX0Sy76NEIntPBI0/usl9fnHkuo m38oB7wQsGSORAADAHyBCikvGqFf+9rXwjHapztcRo1SJnBj6xoGYXXEleKdfsYZYkZPMboZGM+d e6ZZQ35D+1CpBxeMKd+AK2Ocwa6b69ObkmufORUwDLlMEtXCLFAJYwh5EIJkOn8DkEJXazAmAtRv WW08WwfI/+53j4RHHn4kXDL/onDd9deFcunHpw7s0/lj+0JxmQ6rFaJCzoCPMLc4M6WsFFEDNQNF lEn/dBQ1s/aSwpxSLoXR/lSOmUnVHwipAjGm2nfa2CBEUkis+iHhko9ZiC0oGaDGp6yo8GhyU7x4 RA3tr32OJG+rSDBa6hQgIukIMaOLd1IA8TiPaOq06eHb3/4f4TkZSLpf+0pnz54Z/u4LfxdGjhsf avfv03mAUaVZJbEkgBUuwjT6mUf6x3JM5+dh+ZRJ5GWG767nWKrcqQF7SlvIYJkOxopbBBCS0Ugo 2LgiWFJN/FhdsLQFOgwjWQTDNT7FlHzQI1kGHBx1d8LDPHL9fEASTKtTrjIl/odAoENteUisjnlk 9pO2MRjsIwKCv8I/Gg6c1GQMNnLldOm+mut73rhEaic+QQ5JIx3nEH8Cu+tAuh402z1b3/L2ATz+ nTvwg/GEmHd/0oRIwTEueZ/1Mao5LcXHjzTw4yINXGZa2d4tUDocz56m+x8N97Z1psyZ9WeYbxTT ZIb4mFo0eNr4abOXwyiOkTYnal9/EYRRHxp8HB4daU9hkeClnpEGQNY+AoEsxzfDmXRYiElvD3CS fJ24JTxEJjjNXjAMvLCgjBQVLanRo8dKAlQRvvGNb9lRM2oZxQC3JQnRZbSIymV3pUs+hGC6s9br Q+0FrBLXvRCI2CSMEr60RRVoI6xQQ0txHAuWeX/2s5+Z8OfggRrtPR0Z7rz7k7L3coIdUVKvBZNX F70alix7PUyYVGXafGx/Y0gxxkoPhcL1Ro0l2HeJjKnGctFdfpwfeUJbl+roRfocaarD6B/GFAOX WsiRoEi77qK/0qM/0a9gqMD5EqSk9DHGfmNa9Uz9eFZ2Vmd9p5PAM8AHkIbVF0FV2pEFgeMoqEf1 Z+LSx8jvSDny43RDTgFRxiawKmAsEpwoN3Mk6tRVVVXasrhHAWWVt1ynggjGdeIVOAbTKq62LCnW kUBKj/HnpBNPChVDhoflS5cpimAFfyIYU2mvndf9SNX1SOfTPnMqYEXn95YixqG25T3zSW0QmVLi pycGJpBnnn0uPKcN0HNPOyPcfOPHwj4ZBvr9w7+XjnltKK8o1yrQ2WFY2bDmpGB+Mh2EZFOBGF2l yycM6lgWukeGVNnJAk+RGNGiRk0SMLIqDJ1HU02a8VFjO3NE8ciADib14ciMqsM4BhgqKA8Lox9l digk+KhPfEnXe6U2Pj/++OOhqqoqfOrTn9I+lU3hj088YSaxka7OmXNcqK6uthUfJI250owpH12/ zbBSsQ226d+2bem1yuXv35N7AoEEAh88BIy41ljqTKVLmphMIQicMeUdYgQ/JxRsMUBVIIwRGyJO uHtcakf6MANGyOg7jniehnmkf7wsmX5H8zP1wfn90LpovtNg2vxdwSNh0xIyfutLM0lL3XriCfzD aJ+rDmKoBfU7JB1oNjkegn+EYb5ep+1JfENy6m7KlCmGp+Aq+IxzfPcwyT2BQGcgYHRTuiuLL2lm SDwN8Mukk2J+wGP2XX7zm980nK3VuZnVVVVhxsxZEoKkwqXaK824i9FK3hlHuOOaxBlC6iLxZDGM Y/+grBl9zV93TpogUuQlozYkaZCvbnZvkrQVrUWYRBgyH/u5R+Y3pod1fKO9lRhba/gG/Vco9TrT ZCBfEiddLj0zrnHx3NscZYp1FGNufV8LZVbwOAY0jwmqK3vbbUxJh0MIQ93R+gDW9cBN6fkcKcjL FySItm1MwCf4AgsbX3ohPLqzfdpnTi03AAS6tp74UI3L5VjpMBE/KypCXAb0NWvXhn/X2UrrpE+9 8GkZD1q23FZ9Ro8ZbWeOzdIm4JNk+XZ44QjlZKxec/KeM750IrPWK0/kq6z0sKKDNJXuoh2l0vTV 1cBdfmJWG6UmbBZjUSElVXXGEi1pNipek1lVUqe01Q91TCESZ3GSmpaC9CvGVvXB3KyVKke1QRo2 ZoM4//w//5+wYeNGQzbOaNq6DdPZw2VSern2rBwfvvWtb4Xps2aHJq3EOrKB5LkcYXJ97Y2dNlc9 Ev/eCQHwq6+5fHVqr88Qt70wfQle2eqaCT+IblbQISiMiBB8wBjfW4QWCeMed2NS03ODMZuK6+m3 gqvCkCbfokpmy/4k4ll66XSywTqzfNm+9xU/4GN1tVV25iFqpjuPTFHxMb70gUo7rhyJqgBXDBdy BBzHOYyQjQoISIwewZAi9QD3x48fb0dDYGkfySmGZSDambPBUy7rI6IhwF3ckazHkYBVkseR+CH2 7gAAIABJREFUg4C6dLqfxzvv1v3xl4PR4aoT/uEYc8FFu+sZKRv7ShuFo7Xa4gZOMnaX6gg/cD7u bdTxfpJG8s43aHZfqGGMZ/tbsRgn9oqiEYhmIbR8jSSzjPPspcSJlBadCxOrfaXqM2gKEL9cRoDY 3tUgLZCBGDdSv0I1lfPt2VPqC0Aws9TNwqgMB6UKS3+iPpSNq7c7ymj9nblMMGJPLH7AHRhv1Z5g VHwZR2BAOSoTDQuk30hQS7UHoEywo/2wW7NLhpSmaxskcUGEehYI5EgTOMcXAd3mgvja1347yJx2 vto0FAjmwATo72lzMI129yfuCvffd3/YoPOL/upTn9Tm4IHGuF1x5RXSl9dkIGYTx6pCeg629/gD ouq79VQFMLzlXb7yIw5icFZiTP+bdyFAgaz30o2b1Mis7hQb0yzkEVIcVFnprKxcRJJLiKayw5TC 7ML4skptWVkG2TsLdaZDgTyYx/6bv/kbMwCFFV8seHEg8vtiVD8uK2kztTqLai+OeIbY9pb8JBDo GgToa4nrGAQ6AisP0x/6ptc1F/QYq1gdb5KaFWpkmkW1H6jWmEveic9fnSZgJudSESZ1+t4ka+bF mmA5sgdnqsAac2tSSs/mWyZ1rKIWW3i0SBin6/WdsTTuibKo/fonHw6213b9GnB5Kg9+vf32ysCZ gpwJyREY7NeDkOT8R/boYUnfj5nhvEUkpjCzWOIcPHiIEePQObiIr5GghihN2iUP8JNPXYYA4+WO He+JxnxWY2bKLLxypi/4xr7o/RypUjkgXHjhhUZXIpkbPHiQ0eMcYYjDL1qSbbCwe/bsNkYKxmj8 uHEyOjRIApVt5scJGkUanxvEVJbpeJnR6iPluq9Z9bap9prKrco0bORwM8yE8R7ofYwBwawydq1Z s8by5egY+hDfWOjh6BsMGlHu92XJtkQMN/nTl6gPcfONfZboB/jjfdz7O7Q/TKbXm7JTl9/97ndW D5jTUYLfzBnTw0C1CQwrYcWm2oLYOgnwOJqHsebKK64QE1+pRbP91g5mMAreSGkCXxOV9WGarweZ U2AoBGPgFiBZYZ86dWo4XkervKxjY7AwdowG/rtlApsziU448QQ7NwkixpjSNMJlJbfFcMKVYgCJ aaGRpRp80v5akNAO1PpwkEsvNWIsC4pQI1Mg/XAOapGiFBRh+r041CoRztgsEhFFGKz1QiAhYzX9 cWNMJWUlkzwOSTHqEujr33HHnXYuGh0PM98cGcMzdWUSZNUIRI4TWuc7oHdY7xx5ipV86iQEEph2 EmB9PLjjg/e5Pl5dq57XmRfqvV/Ey6OPPhoG6rioOhESo0W4c/YdbuXKt8w6JNbHIW6WL1tmB7gj dUIKxTjH6vtUESa8MyGTJhbNYQCYGzChD9GP4TwMfEBsMRazUKlR2PLpT/C3Crfz09xGgpHBhgWC rBNmOwn1os9Hqo0dXsJus146dOhQw+GTJQ0CX/mO1AIikGdUfsFdFpg545FFFjMIY/YnhJ/6Jyw0 APgMw1qshZzEJRDobgiAj+DoI4/8wQxyoZm3V1L/HWL25s6da7i5SWPpRRddKKamyJjQZcuXSiJ5 0GhwjnHcvGlT+I//+A/DUwyVcpQjjCJno+5UegPUD3bv2h1KxUjCTKElsHrV6nD2OWeHq6+6Orwj OvalF18wGzHr168L+5X/5KqqMFR7XTds+H245tprwmOPPWZHQ06XIGbV22/bmcBIczn/k+Mlf/Wr X1nfmz//QjFkW8PTC58xw0DXXnutzQf0IetHmgu8T3Y3LLsjPdqDsZgyMmaskBGjGp3OMUDSYaTL r7/+ukmKYfIflOboJMH/2GNnh0nHTArHas58V4z6G8tfN8b+ScHlFFnpRTvjDR1HSf1ZKFi7dl3Y uXunwbCMMYqF4qN9sG8H+Ic9ejrh0DYfh1vcxIvxjPowZOiwcPPHbwk7tK9jjI6YaZC0ErPUEyZO EAHSZA3JKoxG+Kgn0DZRe1dITQSwj8zDJi1N+0fmEZWFxnCwIRUOqHYHB5SHA9Krb0jVKJQYUB0h ExpYp4iqDCk18oFSHbhdMVhS3b3NNnpNUqqyIIVtEHOKrkKc93OzqEVSmaCeqdpU+MTdd9pZpyNG jpAK0CARW1Fk/3d//3/KMnBcxbJii1FGLUIZdQDZYgksXvKTQCCBQAKBHoBA20mPBbQKTYjr1q01 da4BWpXfuGljOPdD55jk9IEHfhp++9vfhn/8h3/QQe+zjfl8QgfBX3DBPNvasETWIqt1+PtTTz1l q+avLXktXH7Z5WGlpFYQRhNkzfyn999nK8ZX6hzJ8887T/kgZcWIhrRe0Bnrb07zQUecqVNrWmjb Zh2J29vDQPTheqJupIkhvhkzZ4S///u/D88995xJS5FaYLSR88lZQGYhBaaTPX1LliyxxRdwdvDg wbI+qmPO9AdRiuQE1TvU9MBX6IdGtgGxsA39oKoYBeF3q1nH2tiCJj/9FwL0b1AljS4YHhozdoxp 47FIwtmZaP0N0QILuMoRjZzJWyHGEiNHnIaBpuJeLap85jOfCdXTZ5lG3590tOOECRPCRi28wOBu lATvDFmNfWbB04bfG9ZvsBM16A/gN4uHK998KzRefqWl+e62d8NS9Yk9e/aaijHS3AsvviQsevUV HSE5MqxYvsyY5uXLloZBkhKOHzc2rF0jBldWrnft2hneevONsGnjBjFuUVBDf18iK8Mwr6jXI+Ul X5xLUu2lF/04YwoTiaO8m8T4U6+TpI3BoivjxsnarkgdOFaTdyTFf9DiQlV1dVj99ipbGOM80+t0 lOYwnRVLm7JQsEywmz59Zvj2//i2Cb2++tWvhYFDNPbUxD3DvQgU3V6Uw2ZOm3tMm6LBZNKXbLDW DmEGaJhG9l3avo6UVMI0kLNf1FW+LAk1MjrZrJfncnzJvGI4mLtYGlbbDyr3t6W3rWWgsDzVFAZD 7EhVW304Sk1VuLTmdkiV6Vyhgm1hk46TaZAJ7GbGl+nEmFISTpeIjHM42/sqqW2xpLXU6bQzTrPV VlTVOMaG/asTJx5jK6sgNSprsSY5EmzlnSfjVuGSlwQCCQR6AgIQtPTb/uJQN4LwxoAFe+zOOecc G8+WioBglR21pDVaTR8iQh2GkgPgiXPaqadoFXizETxjtOp+pbZrOIPx1ltvhUslcR0xYni4cNJ8 m4iRoELwwxAcK7sDrNKzfFiqIwcaNHewf8kX7/oT/NvDM4NpMi20B6a835FyItU/99xzDXeRbsCU on4IAcl3CE7U8ZBmAHMumFbU2lFRZNuPWSqFANG/dtkZIQIz6n8UgueWe/8ZR6zSyc9hQyCzq8MM nSec/Zfvf98k+TAyjL3LJbU7+aSTTE2dsbtRBC/aKbfecouN3dOmTjUtmOFigO68804b18FzmFoY XVTYP37rLRIejZHk7g0bn7EHgJClTJJA1INrteXimCpZ/JXmY01tlMayh7RO+0lrFP+/feb/MA3B ayU9RVsQFVX2c48aNUKM51w75nGqFisvu+zSMEXMGfUaqvKkpIWAFJE4lIWxnnLFOSiz9ocNym5L gHbgoqzcKetYqSWn0mPDgw/+bzGeb9r8hho14wpzIEbXGFtgRFFjXiUGtVqw2KftAow/tANbC37y k/vDF774t6axsVvaS3Ah5MMY1NfnwrzMqU1+akY4fogDAM9A3Qwca+LsSINkMg7kEQ+wrst77UGt hovYESupdNO602lgk48UXBVO2eVZLSeMjf5OKOqVCYJiErdWK5rDp80IH/3S10Lpnp2hTJ1mQHlx SGlxo0HGj8q1DworYdRHW1FDnSINr2sIZ006JgyZPDXUaC9Uk4498cmEhU8SpsxNmUtYsWrNv6gw UzaQBv38eqn4Uh5ctECG8QQ2lgNO/WoFLNPhn9MRXIl5RyCc5aM6cLf0ckbu+gfHga6nkDvm4ZS5 J8uVu8TJl/4OgbZ4dzg43JtgST18dZoxBqLgL3/5S6iurg6TJ08Ku9/fbau5rMijrgsxsnfvPgvH yvotIn5YEYax5Gy6S3WWM45wpIuqE4uSMLWzxYBCsCB9YrUYxpctH+tkCRXmAIIf9a/lKxaLoBkb JqsMduh6BsAob9u2yPjcqx8pu+NN5t39uTtBZn7p2nhYrzdtpFnB4GBzp82fvbrqOQvndcsM4PXM 9OuO58y8oBsghFHVBeZTpkwx/IM4jNN+lIzyjqNMqPdCB7naLu1An7GJnTCmChXDehzuOM870hHR L/lNINBZCHAUy0CNn+dpe9yCp/4SbvzYjSZpfOihh8IV2kLG4glbLFjYw9DQbEn+oS/B6VRtjS00 wswyrkaruRwh02TMESruJfp2plR4oWk5USPiuIwclZVLxlIgTZqKcP78C8K8C+cbM+njFeP3aGlF 7lTejOtCeEt/l/zpO6gI1+jISDQRjpk82Y5gwgAShvEOshAk2hxVWPqk9yvicXnf6SysDjc8eedy mWWjfMCBfeqjxczXql6oVWO46jvf+Y5ZAofhvPHGG6Wmu1YqzKfbHIhBWCSsaJO+/NJLdsrHe+/t FKxGalFsnObQynDvvX8dtr671eZTO/tVefV1l5c5pfIAH6QF6P7ujYC13lwIgz9tantOLabhqaVH Z8DiLs4Gdd1j+BYkyI0QcGmKQNo86pJQk5R0F6epFfeiwtIweNzEcPV/u0fWcA9IvaEobN+xPeyV zv3IkaPDti1bRUCltEIh087qqIOFGB8aMzGE0oFSAS5Qh5XKryz+ol4MQ8p/gVSD44N8cuGFTUqC F8VJOw9qcBBMYKBxhtRWkfje9rctXIETEyL+dFqIEV9dahu2bVrJewKBBAI9AwH6cV/pfzYmMWjL caTGm9rzYsRETa2sNcoCoVaDMeg2TwTRsuXLw5+lustE/Nprr4XVq1fbxIlaZEHBBmNkURF7SZPt ypUrw/z5883gA+MWxiEwQMOepOlaSf7yV75i4UkHierChQtt7w77/La8826YICKGeIyBlJFnL+vR CnvKTR2yubbf2r4TBz8uPTGZ9BkczAaPnvTzoxsg1JlPIeqbaRJlzFzLxV4y8A5pB87aTqB3usjb w8M7fhLH2k9zPRpUHo5j9XI0v6Wf/CQQyAcBaHIkmGecfrrt8Qd3MTDEQuFkjZdYm/43nXsKzQjj Y/tSJZW7QkZ25l1wgVnEJX3wHofROhxSS9TdESBhnAgcHSFGlDvDDXjN4kxK3weLicXPaFNpQeKQ GrJAiWoxaTiJyzxCXMrJvVyLlgPM4nVDGCQ1VcJV6h0REOlnjvGkG8c6nnqfo2yZ5R2KFFvM6eua Iz+krS933XWnMaMvvPBCWLRoUfj2t/8pjBwxzFSviTtKsOJc5Hs+93lxHY0mJb3++hvC2eedH1av fEPjT4lUfAdLcq3jrQRb4EcbAfHeDJfDbal2mVMqDx8J8Bl4cdzxF3zk7IeHVo7vxMEBzENdXA05 1D/tky1K8yf1CKWfZh3j+Ur6hiEjK6smATs6pkks5oDh4ZlXXwr/9z//s63CQ2CVS1w6SB1r5dtv qyPVhTukxnDFxdWhrElWJVkVZcKn3tb81IGc0iujSpvPWZ3i4Pg9pM5t4qSDWviO/ABzBgFrD0Wm A+Pnk2NH0sgV5pCy5grYzf4fVL7dXI0kuQQCRz0EmglyjS2M20g2kWpu3botLNckO0LqR2PHjg/r xDBOnTY97Hjv/bBKDGlZufbri3H9g4wlbdMeJFbNTz/9tLBe+5UefOgXInqKwiTtaxoyZKi0VjAY VydrkjVmIZKjtiq0f5VFzi3vbDVJLEY1fviDH8rgEumcISN1pabihIEOxjrK6YTAUQ/0bqgA84hP lcwNR5v7oMsMAV0ky/2UAwYUYh4HjkFI+4Iw1vcxbHLiiSeGU045xcJgKZV4GEDEGW5q647YWVEO OoZDxhbN9rRIB8+jqV7kt2mF0VbechY9+Ukg0AoCjh3ZejV4Z/SgjG5dIMNHP/x//5cxml/60pds AWXVqlXhj9pTynjMhTRy/fr1pl5r2+Y0jmZzjLFIRhHAYHTHXGsFv2bhTEoaipnO5E3mJ/q0TfqN npao41h2tADT8U2oo97Agk1mgkfo+XDoUOrijmcuYNigO+MJ8ygS5FmzZpnGEQsHv/71r8OCpxeG P//5SUmPJ9kxaizIvvT8C+Hzf3NvOPvss23urSgrMSNUkydXGb3PiSLKIM2bcGvJ28vQl+7tMqfG YEIQiBGyZ9W+uTHFdOZDpuZwaYhlvkfA5gFuzoTjh0Y6UDp/MzggxKZzYMG3QMQS+1k5QgYLZa+9 tjxUlg8KZ552ZvjC5/9aBFFpOFUi9XUijtauWRUu0x4ozoOSwkPQFnLViT91fhANZlR+5gogjuJj tt/WuOJ1y1mRbEnkRDjq6kSZM6QMTk6s9XVEzQqsxDOBQC+AgI9rR3MfpOxeD+5Moljn5TiCOXOO C3t2vh/+8Ic/2Mo7q+yofimYSTyHSVX3Ix/5qKnsIu1kfEK17Lg5x9v+GQiTzTqeo6qqyiSxqHi9 r/03f/VX99hK/T6pB6MqzBnRGzZsDHfedZeNazADw+XP5M4ZeTifg/zZy2wfe9FPPlzIhHVHiux1 9DtxWp59nmnxy5d3S7yO5NxzYfKVsedyzZ4ye6p9odcIfvUFygdjiiTpKzJCsn37u7JSemX4wQ9+ YFaqP/KRj5imAEa7UO8lHq4ZP9U3TL03fedcAVSIgT93iVGzFybxTSDQCQikdIYpYzX2AMZJagm+ siWC8RlDX+Cl4zF7Htk3zfdcY5C2+Bv1q59OO9AaPpMtfLld78H77hoLgSUXsLb+rYUtp9XxB97f 195gtq3cfffd4Zvf/GZ4R/PhsGEyYCWJabGY0I9JLfvGGz9q8yWMKnYYLrxwvi04sEiG4/QTs9Kb G7h96kte5hRAA3AdGcrM1zwAA3BbURQRwnM2R9xDcDQjKIDOFTdbeu4H2tMJIvrHFR6+CTWsYxQp U9Yr4SmxpqeF9zB+9PCwe8fWsO6tFWHq5HFh/gXnhRs+dlP4+X/+Oky47eZw88duEGGE0SLpuesP XrRJusKNSoRVfSwCk6PWV+1gYnsl0zauFbKn+dnmZSaFbWyzx7RNdHvN1rGBU4EmSlQ5QHpXLWJC 9cnQJ8dsabYqV7YAiV8CgQQChw0B+llXxrTDzrgbEqDsPpYwGaIKxvFXqO0iQX1fK+/nzrsgjNe+ /L37D4SqqdPCnZpo7VxSjUMVMuLA/lL2J9Vqfx4r9TCxMJWMVwdlOKNM+5U4ImaSVoIZr7AuiQYI q+xl2ldz6mmnmxGamVpl5pDyQZK2wvgybRAO2GZO+t1Q7S4n0Vva2aZf8E41secu1+jIROwtcKO2 wIs5FNwHvzAMg0VScB8/8BkjXwMHDgjDhk7X4syjdlTHiy++aH0CK5oQnp4GOA1dhB/7/WAWcPix YEPdvf75yHeLlPwkEEhDwHGFPu4O3MWgZgHGRoWrV199teEW28cQJE2ZNj3MOvY4+wbu4deou23R swShnTNT9JR19wwzvDr6SFTo897ugFl3uMx0nAZHYsqAzJiCXQX8WUDAlgJjDOMKC77sY2c+s7lQ qsBsL1y+dFkok1HWObLLUK+FL4wjeRgaxngAxhHFU+N2RxV6bRrtMqdsvEaOCKABIsBFtx0A45fZ OIfUMg084rd1GATIB1sG/NzOuoB9tpSFCKz44GDuSrUqiWnteq2IolM/57jZ4c7bPi7jR4U6X/UM 03UfK0MbV116pQ7dHmb7Yt99d5s6r1R0hFW2eiQO1JR5dfQMEJA41tSHi6S2YyufMbtO/TZ1gDn1 BH0S83e2vIKQTHoQjyAs8HdiLW87eCLJPYFAAoEehQD9sG3f7dEMuylxyuxjCM9MnJxbisOsfZkm SfaJMgfAbPI+cuQoe8cPAuiAtFQYb5mEcaSHoYtKTdYwosTjIHGeyYN43As01hOf8/cgohjfSkvL Aufj8Z14Fi4dh7R59/Ly3pdce/Wi7rgYTnCwv47RKh43G7zayzdbnI765cu3o2l0dzjoDzPOKHiC s0iVUIdEYk95kdi/+uqrZqmXefeXv457pdm/h2RD6Gt7VMF5YGdMgOZl8BX6hTNR8cPBoBLGcb67 65Kk1/8ggMTf+2yJpDBGo6MFIKa1SXgI7Q4elwi3oYcZW4vT/pm2YPob5Bxm3VFv4MtFv4YW59ng rr4+Tou6q8RwYocBi8lY/GZuY3xRwylOHBsYKzDQSps06T5WYWFwU8ypWqTlLFTarkF7jJ3eRzXb eB+l01ddXuYUoBULCCkxpAyyrARizAKrjAzmmEvO1dDZANc6LOqzaY4yC3RzSSfFGcI+xn2myoS3 KN3USoVLK3VmDGq9lIGVhgosjIkxbJIkldV80UcKLEZUjGeqqU5MbK0aHQRhk7EQxIrl+rtacSKl gihaL2wsVRE8o9YFBzHzucYmMjbI5Atm3zLToo6Y2absdAI2veOAp09+meHtY/KTQCCBQAKBTkCA MYQxhQmQ8Z13xpdHHnnE1MaQoPLOxMndx3O/Y30dwpz4XDi+ceFPPIzhQUT5N9IhrGni6P6SpFIY pbnoootsfxThiOdl83GONN3PEutjPw7T9qrFlCNQGCwcNu3FyfW9vfgdLVOu9HP5f5DtyHwKwQiO cbwDEg7qCe2D1IJzIH/5y1/aovxdd9wqtfMN2gt9erhe5xGOGDFSuHrQwkZ8h1CNEhPwGhVL0vL+ EHEdbSffk9cxWiAX3BL//gUBsMUpTF/koO9wIYjhCEW92Z5mmBnCg3MNGntxxE3p5ApUyuPpEeZ9 yI/ncciHDngcDkYfTr4dKFqPBPExk/ZgzOAdbSGxFzoeZ6jNY95WZgE8PW9xZExxsbYdHqyNc5+0 NLGrUCkbDggAmSNZ2C2V0dbCwhI7osfGX8WHM2F2BV6HA+8eAUg3JpqXOQXQAJazShnAT5YhAM6j wxBAic6gY1Y0+aKYNdRgbU+FIGaMJXf9sR/UJI16B7gGYL6gd2vgzV6bGC6mBbNImvEOUdLCnJIG zBuGeutRwyVVWz1iAohpMzk0iTFEclpvm65FDAURSmJOJRPWqWR1Zv2qSHtHiBubn46OI00lJMkp eRU0IhXQvbk8hJHz+vGY8S2z7Bwd4/DIdrdkFMG+kaDVm/qpbqQp+FEXJj0QGILO4qidHF7mkfwk EEggkECgkxCwsV7jS4nUitjiwFizV5Pov/3bv5mqIyu/fgZbXO2NDCrPjD/Ex/HMxfxBGhBIOO7u x+RrDKnCKLAxB6gDP/z731sYjqyBYdBHm/RJj/iZEijy7cvOYZhZx6x+mQGOomdw4QN1wikcCzE8 gb9ohEHYI2ninXMJL7/88vDAAw+EpVqUP10WqFF3t2MyFKdcxCQSEOZj8BECtFLWTSsrB5l6L4sy pA8uE47jl+y9XHREzJ4iJC6BQKcgAK2aMkkaY6ALKbTtTAbooFxTjN+ih1HlZQx2Wp4u5/2O3gcF b3jIWG3v/l2paDiHfuV77KrQojE876Cv0fjmF9/4JTDR7Me847uppMrb0yQIriWmxYqePfTL+Nmd LjM9xgvebWFA81uNGE80jJjfGBd+oUUuHOcqb9d5rsBwgwwHQs8jZb3hhhtk5XhUePW1xWHBgqfD /PkXhHNk7fdgrQyvaUEBvU5gWKB8yKvnodWdkOp8WsVIIXM5AIArQKqoe4kkkEM1GLuLSK7GELax LxOmzBEyEwGbEdU/6t4RFLF4GWkSPeYhT/1741haauncNaHEFipddBo6/lln0ze+eqeViDUdDk9d 9tF+FCZNEMXXlmQJB3K2xLQn3un0pBjL6xHtc+uf5rzk7cHSCYKU7ugA3jb4ZXYQD5PcEwgkEPhg IJDZH5vHlA+mKK1y1Uht79lGSp9Yi1jgE0HDhfGFBmnHVGghEsYRRzgYRO7Ujcvry3Mmw4g/l8PA 30kHgsnS0HNTOp+U9qUWaxI2plQG6ko0HoqdbR7rnAkmvufjaeN3qFMCNhEd+qV9H423Ntm0H7I7 QzAFUCeISurIOYVoBmH1la0w0dImMEVlGhiKMBUhhEoY4fPD4/BK2t1pO95QqpbZzefJjLLm0FRq DgEV3RUnuAqILXSDXlNYdJGGFXWtr6u3Izew0Pu5z30uPPPMM+ECHcOxRcZMFixYEE44/viwedMm U+Njrypn+KLCd9lll4XjFWfNsrcDx0eAz0hgaZ+lS5eGCeMnhHnSDBgqC9iuRdCV4idx+jYEGAvc ZT7jR7+HFkXjD9fcN3nXWMDefiyjF4Hj6l0FCl8qq9KGbwhv9Fzs44u08hBAwTTRJzUEq09I20VH iDEHlJaweBMXEH3cV0Abl5kLWDRkcYaugyvVwovYYWOoFM3yapCRUmhY8iQN8kGlnn2VVkKEQmmr 2TGVw//NHF8OP7X8KTCf4awdVDe2qsBM2gmUeqoTjF9d/Fp46623QnX1lHD9DdeFt958I4ybMNE0 IguLS8Oo0WNDqRbH9uzdH1a88Wa4+JJLBSMt7io9Abm5jfNJvfOX8uj6mldy2rYqIFWm8w4R18Uz v8Tntsjh4Q8NebT4RKIgV2nb1tfD5YKPf+/IPVfaHYmbhEkgkEDgg4EA/fZoGPeYXNO0hYiHyBhB pAwTAT1v3jw7xF0ViQSPJl4fj5qZTCOCOg9jiB6IE+YWDNGQV50InVJJm/aLuGJh1MvV+dT7ZgwD NUCTi7RnAqEIje77hR4sLpFpRS0AgOsQ4Ug8kYDAmHI8B8aSeJ4zZ47ttV66bJntF2N/2YF9+8Lq NWvsfEOY2Z27doZKGf06XgztK6++EiZVV4ezdGREwpx2X5v1t5RY7PBxmPt+GaPbpMUSxuRhgwfZ PkcWrtgONmBQtHjOIiPfN67fbJJ9turBXLKVgr3TaMzskTV1NAgwhtegLXJrNq42PCVu+bumAAAg AElEQVQcYViEQZ29TOegUgbiokmABBBmeaMsruNHX4FpJS2+c5EGZd2zZ4+lM0SGgJoZ3m5sQIdL NybZpaSoL/WDMb/uuuvCMo0RaB+tfGulbDicZOfPEgZLypve2SLLvWWhUm01bcb0UKOFYVspUM5H Aw3RJQDlidQp5jRPOt3+CeTqjQ3Sk0jfk2l3ewMlCSYQSCDQpyAA0QKLqkVsY3qYUFsMZ8SVcsIw mTI284w7nHEa/RVYK9KC8CFtjCahGgXhw3aGrjtF/gCkn10vb0vM1tUWJ2rMaLphnF2XJFVNZG+E Z/5oHa8lvd7+lOa1e1UxYfxRjQQPITC5mwqeCHokpKjmfejcc41pRf0dBhajXnvFmCIVHTFiRHhP hpQwAIZREwh2OtYIHY/Eog+4nrgEAl2BAH0dnPQxmDQ26mjEp59+OgwXbu0X83f7HbcbTsKwLl/x ehghpvLYY2cb7nF29ZNPPmn7rDFwCv6+o7OmS6Ulg20BmMbPf/7zYdfuPeEn991v6cBc7hNuY4GW o2rIm7NT9yqvez772TBce7BhRtEwwJAY4VeuXGnV46gwDIStXPm2tgbOMA2C22+/3VTkMTbG2I/B z0wNwa7ApbfFcZq+Ugz6PC28nqvxAk0KV/dnuyTzJ2MDKsB1YkjZ037WWWfZgoCNGb2tUkeoPMUO vFz5Abj2wuSK29afdDpDyHi+nYnTNs/kPYFAAoEEAgkE2ocAjCjHuhSKoUOFlHEXJhGCw7gjcT5M rEh7nEFljG5LJLWfU+sQEPUQOqRDek5wYfXQ8lU5EhchAHwcRnqM8ykPcnGePFrZ01i/7L9epyOL B5xTWiD1x+3btxszukaSUKRJnHEKwQ+RDpO5Q0wqUiKIccL6SQYnnXRSmDp1qjGvHK1En0GKCuE/ dPiIdL/KXuPEN4FAJgTo8zinhTMXTMArH4+xC4BRr5eff87GCcZWGMWvf+NbYe5pp4avfvUrtmjC IgtpvvLKK4aHjOmvLVkWTleYAcJjmES0VurEPCElLZWUdKQYrANiopavWNHM1MIQs4/6ZaWDgbDK AZVpyWqN9kzOtz6ydetWO6Jpx473wurVa8Lu3bvCmWeeGaZMmWJ5Uxfq1R2MqcMpE3Yf5DNzGWWC CaWevgCL9NTnTdrItrKooD4HEgd/3r3NP8h6fBB555WctgeUriACcUi3M3E9zgcBoM7k2Zk6dSbd JGwCgQQCCQR6EgKMXVzsOS0qZD9Q3NfJWM2Eaivb4g1Y8WWSZTKFIMK1N0/kK3eMGydv1CZ9QhaH GgmuorxTVL6k+/S35rlGbeLPdnc+ri/V3qXfXd4/3DVgIIdm7x5M6eLFi42QhyFFNbeqqqo50VGj RlmfgMBHosRRHhikoc9wLIQZSBGRyf5hmFXaCcOMiUsg0FkIgDuMmc7YMAb7wh6LI0ghWSgZrz3O jKUwRTCJJ554gt5L7Nxo8JTFFRhUpHTVUjF/5513bNFlivBzwcKF2mIx2OzMDBw8JJx06qk2FqOK C95ecOFFYjB3h/ETJ4Vbbrs9PP/88+Gtt1eFE09+N0ybUm0MKX2ERRj2a58t9XXKtHbt2nDHHeOt P33605+2/sHCJ/3EmTJVrrMgaQ7v42CzRy96YL5k3sRRTtrN2xI/3v27v9POvlCLX39zeWf+nmrs rqSb2ZBdiZ/ZsIdDTGWmkzwnEEggkECgL0EA2gBjG6xiM1k+/fQCk/Ysee01U1VEPckJIycoGE+7 OqYylmN0A8d+nIUijFCH3ChChn19dSKkVJzEZYWACNW0WnRLGwCsrgKs64Rh1uJ1wjMqd3uEWI5D a+E+R6achpsiGlFJhHjnzmkFwJpFGixo+vmStXqHkDRiUnrxMKT1MuqVEm4XCsdJi2+orMe2ihIV r3FyTyDQUQg4/cv4mzkGc07vrbfealsxMH6EYwyHSQR3ied7Qe+44w6LCy46UwROs2d07llnG36z hxUtgJtvvtniIv0nPowUjDB5w/yigoo/8THCdM4559hxh+C7M13k7WMUd9SIiUOY5m8at7yHdxQW Hs5h4u+97e51Z2GAsnI1L8SqsP6dcjfDQ3Dqzy4vc9qfAZOr7r29E+Qqd+KfQCCBQAKBXBDwCZHv EAhMlvg98cQTgT1JTz31VDhWhl+mShXL98kwuRIGIqWrjrgF6YkaFTMuVvJhVDnC46CIH5Wmq8n3 6XhGyGWAJs5N+PrlH61FOwgLj9PB4N0QDMYUHMCRe/OTXuKzfdLH9NsRlKDCgKKCx966119/PVxz zTVGzNM/OFsyJQbUjnng2A4WdcSMNkpqSt+wPXTCb/laf6qXFWB9xRSqiHKvbbpuyS2BQCcg4OMz fZ6LdxyMZoFwr0HHzPAMc+gOxsiZRRjDzHjEt7C61ymOLb7omTScAUZaSjgYShhXwjuD6mmB8wf0 jbs7Z0AJS7/AER5//HCxPjzYa5/6iXVraSevu/sDBy7aB79MraRcgPC4ub73Bf+jijmlUbvDdVc6 3VGWoz2N9mBJJ0pcAoEEAr0bArZ6rr4KYS3KwYgICIkZM2aKgNC4K/XasrT6FZOnExyZBEZXasj4 wLEDpIPKI+dKstLPXj4ma+NODmMIIX2uTCKNcrY3Lh3pcc3LY4QgDLvKTBlQEeWOv4dpvlMRfXMi ETD5DIlED+cEodff49rHQ37IM3oSzsqSTj9/vEhTNiExhNDiOKJ0SSg/R0awf9NwJu1P2rxz3jlW odnvjB9tbuGUr52FrvLA3rmL5Wh5d/8euatclAHYYYEX9d733nvPFmdQQee4H9qG0nCsB2e944p0 LIdKn4Yle+nkp7oCW+oWPxwGUlsuyU9/hoD3H2dAwavYdzheJo5v3n99/ABezhyC08TxvkY6HFEC LqPJwhjvfZ674bkQmDR59zvpeRqEUYqhuDzaJSA//8Yd5+XmnTxJi7LoZuNGZ/edkmdvdg5DykhZ eXeYAAucw5JvhHEY5aqbh7PIffjnqGJO+3A7HLVV8w531FYgKXgCgR6EQObk1IPZdEvSkMsu7YFg gEBhBR2VsE2y5MizMbEKZ4yj7k5gdLUAET6RUD9w4IDtg0KVjL1TnIl3OM7HJupCeZ0wI00IBCcO 8uXhBIITV/nCtv3mcdv6856JFzyTPneIM1RC3Y99ilCMHt7vRtCkE+bZ6ppOg+d9+/bqitKNQnF/ 8jKXr0xqTeUT9z9RHtqWhQLg5gRTOsssNzHS8uWoCiQnJEReMJ1kbS1MPfHXHwseMGzUl/MVaaMi 5YOU0vMjLmqGxG9VbpegZilFd3oVIKFV+RxPsDbKBVwM/8W4GsCsfDxGArxVGVRf6m4LPBEKFsfg YfHSDdMqUvKSQKB9CDSPGen+3+pd/cnfSYn+5Ywkz3zzfuZjCncbSxQ+jhlxawfxvQ94moRFg4Y0 cPiTLoOVhyUM/YQ73z0ufvQh+rT1I8WyvuOdggQ74FqNCR0I/0EEySxj5jMwwQET/P2b+/t7tjLn +5Yt/NHqlzCnR2vL9ZJye2fqJcVJipFAIIFAFyAAQQGBYIe2a7KEUcAP9a1Vq1ZJpTcauICYYELl m0+SjAH+3NmsiReZkEI7+27t2rXhvPPOC1idjFaCm1mbziatMkXmZsCAgVY+k2gpP8pbUKiprwnJ V+5k+ZZvfMtXZ6tXjsRzxXPijXMJIfwoHGGRvPnB65QntlW8O3FjdRK9g9Ryt45/+O1vf2uLCqWl ZSIAUxlEUO76khaONoboRPUPZvHSSy+1+LljpuGksnL2J9Zrx2i/MAsdtCFpUT4ninluCwMWIjZv 3hyO05Er8y+80AyoxMZRewFH/jtJvOYrb0e/AQsWZzheg/3QqDb6oo2KpHp1NKUkXAKB7oNA5hhM X6JvgZclnM0rpKxDW0H+zgT6OOHjN8aQ6IfOYLIwSH/FOFFxWbmlxzhjGgLpsZ65AD/ywR8jR6SB Ix++FSpf/FjIJC/8yYtn/InLM/lSPsqFH++pBkkS0+l1H6SSlI5WCCTM6dHacr243D5g9eIiJkVL IJBAIAMCEAn0W1QVcc48zJ07N/zqV78K42SZEUYFYgPiwgmLjCS69EieMMLcUeuFqFmyZImdfwex BMMME9AVhwR25co3ZU3yBSO2MsclnmFeRQ3lTBpVzcw4mQFj/Nwlg1DL5oAbV+Z3z4M7RNqObVvD 7FmzjFCD0GxQeI7VcUmy5x1zb2H0FEywKtCCwoFw4EBNmD37OFnOHCSYplT/SCh6XrnKRvs6E4kR oGeffTZcKGYRK7UQo7kc6XLsBAxmdXW1LHeeHA6K4AWvuHBed+5eDhhX8KlcbcUxKxxNYdJV1Rd1 YFVcYdUOxLdUjuwP5dvw9tthnM42xfALjPd+nfVYIeMwRkznwZ8jW9Ikt/4EAR8D6Ds+dtOvdu3a FV5+6aUwf9751scYZ+jTGDNibOWcUvyee+45u+OPcSL6LI4wm7dus+fhOheVhUmYR8KdIqu9GMTb onFhhc5JnTFjhqm5s4Vg9OhR1o937tgedu7cGU5VWOYL8sN+AMwvzzjSYvsGWzfYy02/nzF9ehgz foL1ceqRz7X3PV/c5NvRA4GEOT162qrXl9QJjl5f0KSACQQSCBwCgcg0iCEULwEBwzvMAoQERItb b6SfcxEG4v1wnFg1ETWorjYZkQTBAvGCWi/5HhRjpcy6lAXE0ZtvvmXSLo4zQIoHIefEDURbbkcd I1PlYTLHt8xn/555z/Xd8/Y7cTLD4l+hMwWxVIyKbFTxlURb5YZpJKwze5n5NT8rPvWCmZo2baoR iJmLCZl5NcdJP9CeDh/alQsYEoe88zn2lNKGELRYtJ0x69hQs3d3s9TU0yUd6khepIukhveissow tXpZ2COpL3Umb8LEs259EaE1HjgJ29o3Xyk7983qrTKAjxD9lJN2aYFHT+XcuXImofsfBHwBCVzk os+Dnxs2bDDL0i+88EKYN2+ejalLly4Nb2uBhfH0hBNOMI2IRx99NLz11lu26AT0TtZikp/dC/OJ BsOiRYukMTDOzk3dLqN4uzQmf/Smm8OSRa+GB376QBg8ZLDFq0/Vh1defSVMmDBRSzVNlg99F6u9 MLff+9737JnFLc4BhhnljFP6EotZlO1aGRq76toP6zzVsrxjDXVMXP+AwOFRFv0DRkkt80CAgTFx CQQSCBzdEHCmoUREDn0aIoB7vaRhy7VKXlY5wAggmAzCOjFEOA/bJQik4yM9xUEwweCwWu9lOpwx pq6u1qQCHzr3glBzYI+VlbRxEFC5iJ2YJ8xrJIbiu8Y63+9ovFhuQimzzG3zyMdcEg+jVDCm1N9U rdUmzszx3dNj5IW5b84LWOqPsDDixOfZ1e8I1xwWAGRxpE3bIsHljnSEdFiYcLhliaYFDansidH0 uE0NUtNTGp4O6Xq5ucPwQbjed999YYikspWl5WHzls2W13oR2LWyNkrZP37LLSZRj1LbIzvXUCeY ZOq/evVqW6ABruwDLlM/iPtIs0Ej8Usg0LMQ8PGXu48nnEMKg3mBzjVdsXSJMYL0M8bUX/ziF+Gi iy4y5hR8Jg4SUxYdObrrxRdfDNu2bbM+jhouVtnf1ft0MbRF6gf79+8L76h/agDUAtJu9eu6sEkL l1MkcWVsYJ/5Sy88H0bLcBgq8Cwusig2aNAgMyaGpevpko4ytqN9wPurr75q0lS2ccyVVgLjC30+ l/PxI9f3xL9vQSBhTvtWeya1SSCQQCCBQKchYIyLCBYcRABEAoTPpEmTjNjgHUbDnX+HWBGb596d v0s6WSArp6QH4UJ+EEy8Z5ap8wlH5hMijLTqUzVWfp5hWF0qmovgIe+mPJsc22PyKK+lrXT00OHi A02IQVxJqRj0esFW8cmP9oCwxHna7NeNZYUtpTVaGFCIQ+pLPJzDwl6y/JCmX+RDurQ5EpQzzjij OZ+2US2c8loudWwIXBYzxohAHTZ0qOVvZVUk0oTZoxyki7ElDAwZfPSN8qL+N15E6iBJZSj3UIXJ xLu2effkO9Jg6gYRj8o5lnrZc0p5DD+FH7GlOl8KUKvjWNH59JMYfR8C3o+407eQkMKcoo2AhHLB ggXh6quvNrX8U045xdRo6X/0qxNPPNFwGuklKvvgNtoWb775pmwANIQh6ruzZ80Uk7nT9peecPwc U+tN1ewLx885Tkzl5WJcp6vPsmWgMVx/3Yejyrv6b0qSVPKjHKQP84mBpTFjxlrep59+uvUpGFeY 2NmzZ4dpYoYP1NbFca3vN11Sww5AIGFOOwCkJEjXIOBEU9diJ7ESCCQQOJIQgNCGl4LFgYiBqdgk tavjTzg+1En1FubBCSGIc54hsQlHX++KszyVDmls3brViBmYFhgC0jfmy/LpXOpKzgx8cHeGjmNN cDAXJAmRlr/ckd0DHjirojGsVmp5HMqUG8Mh/6ZGZxJhGtPppJld0xZWEk2WoJhz4KcwCGUlNw2N qSgxJXWkc4WFMQVjNFVwYxyVli0lpMuj5QRxn0g9o5XdzHYCttSVe3uOeLQ9RONjjz1m587edttt RmiSfzZHuuzv3SEC98knnzRiFDVkHOl5PCzv+jsLEBgaOv/888Ov//M/jUGtqKwIZVIjrqnV3lYR sxDWGFbaL8NMtJNfXo/YKtlK1E1+ygCpEIwp0iT2Qs/SXmCIefpCUVGUwHdTbkkyCQQ6DAHGAPoB fYJnLpg8cBV3nBhLHGMdklEYT57RQKCv0u8YE3gmDfookkvwu1GG4kiPb4zDfIfRpE8fqNkfps2Y HqaktwzQP0iHC9coRhXmlPCkOXDgQFPp5Z29qZwDzBjARRzCMoewKNWUHp8toeSn30MgziD9HgwJ AHoCAk5E9ETaSZoJBHorBJyI5t6bnDE/OfgT+irERL2IC2Rzxhip+Nu2vxtqRNAMENPQJIKci8M9 iqmaCA0IiwJTdSVGjsT1JZfzfCFUWL3HmAYEDUQPBFKBGcXB0qPKJ6Kpvr5OSXEeJqvsLcwSOWde 8JNIvmBuMarTpAtjT4VNsg5ZjPopzHeUjra9N5o/jCLn9sE08kSuqAETR2u6jWIqxYBShias/uqZ eEBP8kqzLGvjH3XQOwwpzGiTjPvAeIVChREjmZLVYMkTlU9RKFEuRQ2Crb2JcW4S0VdYqruIOQhR wZt6FOm9CCNB+k68YhF69ala1a9OMItSPfJ2KYkTjlaeXA0hfycawVtUBFksgDhdsWKF6hgJYaJn 4rfhuMLDbELcnnTSSSa1QYKKRU/iWb5q3wIxvapeaERaLvgjKakWMT1dqsPrNqw3I0qnnHZq2CB1 QSSv1ZKm1KT3CZM2bQHOofYMDvKuqh+W87p4/aw+SrG53Co/RDp1oY7gJoQ2sFJr2FWgujWpTbnq aSPdC9S2QomcF/iUzTXnm+1j4pdAIA0Bx1te/RkmFE2EcePGhjFiRkfrXlgsBlDG0BhPYU4ZE7iQ WoLHOBZaSKMu3deKZeG7XNs4tPk7DBw8JJSWVwT8OOu6SX2XPsw79xJZ9i2C6dQoZ/7FZeorFRqH mozxrJfmx4AB5KX4ClOssZdFKoycEYZ+pIwYouM4QYEynPcH7onrXxBIJKf9q72T2iYQSCCQQOAQ CEAkQABwh1CByYGYufFjHwvf//73w8UXXxSOmTRR8ZrMSE6DCJpaU78VMa54zgAdknAHPbAmO3/+ fGNOYQbYHwXR5AxOnb6bhFFlw+GPg8DJ5vAlpMggqDd7VtH1rx+YQ3PZ4vKN8DCVcmIEIZ6UU4xr npEpbhLD3GTSU4VXUjCRhDUmSowqR9WUlci6sRhYi6FywCsXp+tQK/iK1TKGWayqiDvyUIBCsanG 8Cs5OR5JDkf5Gyl/2q9RaRnTa8RbS31oQ9rFFhzSxCd+7TkWBCBeWSQYKtU+9pxC2JJWZnx/xl8f Q0oM42QRxtdee2343e9+Z+qvpIMDN+pNRZamoOwsNMSyFRWVhuOOP8EWJk6SURbyRwL7oQ99KGDU hWvixIlWjndllAXVb4y1GHOosEYRmyi6vZpl/05+jvMOL8po/UGMJvtoeQeOfOeCUaZvoM6Iw6qw wYEXhSV8NOSER+ISCHQ/BBzfuDv+gqPgJJdQ0PqSfYMBFI4WiVFlwc6PiLJ+qbGBPoArE67blgrF L9MYTJ8Gz0mDy8cG8mRs5k4a3Onr3kf4xrv1A6XNFgrKw6CloHL0Ee42FFh8wrZ1pJu4/guBhDnt v22f1DyBQAKBBALNEIgMJgRECyE+atQoY1JG6aiAIjFa727bbkYsWHVHLVOiPSNCmhPp7IOIEsgS LPbCDGFMA1cxaHDYtG6tqXtRLvYewlTasTO6+2p/ZBwhd6LLT87wlQsm0mPEeC2/fNc3YzRVtkYR WYSXpBNJWFOBGEjUdi0dMSd6RxpLLYokTQ1B0ohmdV+YNhnQETwLispMitEkZrpRjHZho45PEdEG c2kSQHGgDUWRJW4oTBlDSnpFZGpFFYNk4UV02nsk7OoVv6FAhGGBjIko7yJJLnCRUI3qeRB+XPhB ZOZyEIN85077IjlF4oGqIH5cngbPOL+XKdxzzz8fHn74YTujFryhjSJBi6GTFiYwM3+I31mzZodN kpw+/vjjpopdNXlymDJjdnjggQfCunXrwuLFiy1fiGqYVqwBgxOkiQQmwicz1Y4/x3Qg5iNQeY91 kpRHkiLqix+OZxz1wrk/4amnp+HEvr9b4OQngUA3QgDc8r7sfRI/1HZrpRZfUaHxJs1Q0pdLyuOR TerBpgnAMVHgKXtCCYcaP8a+hstaOvfVsqCLdJWLd/Zag+f0CVTchwwdEsq1QMjeVvql5zV02HAZ O4vnmhKPsrGoxIIO8bH+TRmR8rLQRF8iLmVnAY5Fq8QlEAACCXOa4EECgQQCCQS6CQJHK0FKuSEk dJOLTArEN8wDd84cxSHJYi8i6o1f+MIXwqixYyyMfeziD3k7ccOzEfeiUbDmihQO4ubez342IFlD glokJg0pI3Hy0jKqi7WH0rR7unwxTntEEIAwYFgsag/P2SgmkpjGoBoTam/6KOkD+ekVNWAkgjCR dQ0HQwnqcGI0U7VSq5ORo0LxNrCzqH8K6OlcBH891ZvElTRb8lZr2LcGJQ4ziyM0B95LJmn3GJ5S RgaS+nK5RMMZKouc4ycyZfEj0lJUdI8//ngjYEmL705IOjwtjr6BJ+wbg/j0Mw1pR29XwnE5g0cu fMPBZHLUz9NPP23p3HH77dp3K7iJoL3qqqssDkaWsJgLLrzxxhtm0AW8TPOLlk5XfhxOEZeiJAhY YeilVHVh6YByIKnn4hmYImHy/kEa1kfSMKIcpJdZ11xlc7j697bv7p/cEwhkQsD7k/uBN+DbmjWr w0s653TmzOkBw0Pg6sqVK3VcyyrTQDhRWgeE+/GPf2zHhH35y182tfr7778/vKixHUNJ+3WcExMB cVmAXLtGi4Q1B0xlGMu/nH196623hn0K9/vf/NaMMO2SpsU2nXF6++13hosvvdT81q5da8znX/7y F1t4ZNsGjDKM8XXXXWdaFjCw9KlMvLcxxSuW3PstBBLmtN82fVLxBAIJBLoLAkyuR7NzgiAS1FGF E+aCC2IdNV7CnHvuuabmCeFhK+ZSE2PPY5QpdR4CRmQpWrEYDYghiPzInDYYc0QeSONQIcYVKL8G MTO4WObWcPe3yN6JQUszQBahUz/OdMZI7C9lfydqwqjRIsU0hhRm0JhUwaoQBlUMWaOs7Eriimon Krgi80Jpo6SaKhxwLNaeK6St2iEqBlWwVlbiM1UfMTnaecr+UphM6gL7qUSN0UVeiw/QLhEcCsWo lzaK4dVVBLOelnhDAOKiOh1MZYSVM4P2McuPM2gplRHpZFVVle05pV2ANUer2J/q7/ju7Ydl4QkT JphUhjMMTaquPCyewrOg4Kq8xCUvTwPryWU62/WTn/yklYryQ+yiIkyaMMpn6aiJffv2GUENfsS2 z1KJTnoZrikOeO+4Tv6UDWnRvr17jKBGzZl9uNwhpglbVlFpBpzI0plR0gGHD6d8DpdOViUJ3o8g AL55P+AZnMOxaMLiEOfy4g8eYqTsf/3g/wtXXXFFOOEbX9fe0joLBz4jxSwWPruU8/H/+q8wWFor f/WZz4jRXRMWLlxoUlUknZOl0UCf2Km0wdH31ReQorI/nPkAptP7DotVxCddysB48vzzL5gxMS8f 5aUvNfcdPOJ6FU+J6+cQSJjTfo4ASfUTCCQQODwI9AViEgLC6+GEDwQP5+RBQDjR8cgjj9hK/Bid Z2cMiIgU45m6CMLCdHzyJx8c+bPv8o9//KNJAVA9GyZ1M/xdAsjuTAuXI18YO5zXiTuX1VP+MEr+ zQJm/YEJjQwhHKT4SCWIBJAbOYjBknEkmMUGMW5R7ZfyF4Sy4pJo4ViMXX1KcVBrFXdaUsI3MXva 11UrSapYWjF9SKbFsMnAUaOpCKfztDLBDCs/ciNf3Yt0hxFlDy71gcGFlaUMSqiZIEQ9m/MICVOs /WYwTjzncvpsFjlpz8FS59ssY0hP/OmJcMedd4RK9qCJ4HQ4OuxIj3QxCnTZZZdZ3scee6wRsjCV Ho5FggKFI+yhLkpesSiKg2AmHkwuBDjWcWGQURXGj3KAB7H9gUjXHfk4TMA/ryMMOri+UerGlAvi G2J+s6xX844U6MSTTwlnn3OO9Q3qRXm8fp5mR0qWWYaOhE/CJBBwCIBn4A/9hD5C/wCPx48fa7jM GH7DDTeEefPm2XnCjCBoN6Aez7FdjKt16m8wjxPGj7czSTGA99xLL5r133s+99dhg84dRmK6Y9fO MHj4MFswYqtC9dQpYdGS14JWcML1N37U1HSHohas+JWyvM2xNiw60W8527S6erKY2YHKv8zy9j4T 6xDHtjzDk1c5ufcTCCTMaT9p6KSaCQQSCCQQyAcBiAXROWmiP5iUCGutED1IrWYDOoMAACAASURB VDg4HUkmql8wrayaQwg11mq3o4igOo4FgEHqhIMwgUGF2GelnfRY9V+/bq35QUBBOLE/CeIfwgrG hLNAkaAWIsHM5uDB4NWokLs05dMRxkGlMga0AcZPDKlYTzNexJP9iYlE+llsTKqkFjCVSC+15xOr l5vXvRFGjhsZaiXdLC+uCEXlRYLh3nBAdTt4YL+Yv4Fh0OChYjRVDxgtwZj6NUkXuMUYknJTmso+ LVAgd72oHiadA9bAX0eapLT3Uuy9Sonq9XOhquoYfUIKDRMHA0a0QxlD2pbLCESVpVjWg53JqpQl ziHsO6sYEDjm5WCNmEalBUwdrsSLRKYgpH20MJb4FZVVhnIRzIYfwiuZs7Jy03ZIdyCmyceYVtKD QVfZaTarGwWWQ6Jer7DOjBqM9I0y4/iGRLurjnpEvI8EPunjyiU9rRfsxmoRBoNMW7ZsMTVJVIph ANhrV6E+wKIN8TMddcuEUea35DmBQHdAwPqrcJe+4n2RPsIe0Tlz5iiLRuuL4CaLe+zlx1p53cFa i3PNNddYPwVXkW5efPHFoQI1duF/Sn6XXXlF3P+pvjb3nLOUXhynkLIyjjAWHJDGw7U3XK8+ILVc /dEX1bFDSv174sQJ4Vvf+kYcV9J9jD7rfR4GFo0J73s2SitcZFG7A0JJGkc7BBLm9GhvwaT8CQQS CHxgEHDC4AMrQDdlDJEA8QAzg9oVFnNhIp566qnw4osvhf1Sb/T9hxioWSdDNRjKgdhg/ylxR4wY KausGYS6ERvtF5A0yJO9Uuwt3LVrtxnm4FgE9rguWrTI9iiddtppplbGOaiDZZAjJ2PafpbthnAp qDHbUtuFbBIrJeaJ40IiE9/IcTJY1hUB59JN2KQNGzeFPz/xpzDt2BmhVmq+886/UHtkxbCVFoXf /u/fhK3vbAmzZs8KZ809V4fPzwz7D+61NEgfRrShXrmIRzKmGAYU5lj+JilNM+S79+yVkZOy0Chi 8yB7WWUUqUJHOCx65RWp4u6ztnLGkMoiEXRClvLiwF2OfOGKkk2xt5zdqSxpk23b3tU+z1Vh0eJF thDBPkzi8s3qrGfSILniYtQM603tloULLiSn5AluYa23UM+oB3LFeNSLisG3wv5z5z3ud+MDMmGA YahEOCu48ueu32JJqDMwznw780N+lIU6OVMJkQ/sLrnk0vDoIw+HP//5z1YujMbg//LLL5vk5+ST T1JcpKXxXEfScsbaie7OlCUJm0CgoxAAZ7nAM8dhH8PBZd8TzTfwGpzmWC0fE1hkxBEHnMXBpGJw LqUxpk7W2n18TQm/jflUGoViKAnP8TQcmyS1ELvDsFpaGjhLlQb9k4UqyuLl5Lur+bKo49/4jmvU GJG4BAIOgYQ5dUgk9wQCCQQSCLQDAZ9I2wl21H32ekEwFBVF1VAkRFVVVeFv//aLohyuDn/92XvD j370Y9EjKZNmviJGCGYSNUcOb7/qqqvFZNYYYWLMnYgRVtpFPRnhkgsoECwzdYA8+/nuvfdeqZMd F/7xH/8hPPvss8Y4kT55YSAJCRYHyNsh8iKC8jMmxvWkGRnlDhGksnCP5FCuEsmfcMYYQvwhEeB8 V6kVKzWIrEKd7SctXBkwIjlxkkUNtq+ybt/+sE1lHD12VKjZfyAsl7T5mPGTw4rX3wzVkgK/q3Nj YSo3bN4SJmzcEqZPnSOJBoSmmLdi0hbDJaKPM12xhGxHksCc0i4UVwUvkxTzueefC4uXLZVa3oiw ZfNWSUtOCFs3bwzPPrMwXHPt1fIfKik3xCFpx6MgaFsumEiqRz2WLl0qtb31YcLESaFe7YDDIidE Lcwo6axdu0pEbaktQBiRS2Q54oM3EKuki0PVm/YEL5wwtkUPFRyCmTjsJYVIhmjm4sxZ6mWp0kZy MLNpH2sv/Ow7P+kwRDI/PnbCOa4TJZOwd3/82OPM4kh1dbUtmjgxTV1Rc7zpppukbjzE6sRCjsc1 Al9hqGdnHPHJN3EJBDoCAccX8BFco1/ixzPaLpWVkoKm3/FjYQjmlIs4fpEXC1f0UbQUGH9gPMtL yzUGxf7Nt3ppxaC1UiQNh1oxqPQH8J64dp60UHeANCxQ3bdFNo0H5EsZKBv5gd/0e55JE+dltLFA Y17SBwwsyY8gkDCnCRokEEggkECgn0MAggFCARcJiWBHibBv6FoxO9UyhrFkyRJT9YI4rxLRzpEf GMEgPFJUmA+YFEhsVMiMSBGxI5LI0s31gxXU7ZLesa8PdTMIF9Qn2ae0U9IqyoVBHIxxsH8JNUv8 GnT8DOqwuPw55Mo5t3+hpKWFYhKxClzAMTJ6TulAeRUulKq8qqiIORkeqhMzKYJNJJoxjyUyksOh 87vE0M0//4JQ2qB9u00lYfiAweGAiMZjZx8rtbfGsHnjO2FgpaS/SqeyvFJslgg57UmtL6gLpVIl 1lvQVlVZ+IWwk6EoMZjFYjQh7oolIYUxe3frtrBXzDBqeA2FdeHhx38XTpt7mpiqSSqvDrUpjcdJ UEsY0ngup2SRklLS1CkRnPBDc+eeFU499dRQK2kKGOBEpcFYaUMwQjy6CqsRuyo333F856Iu4AJh IUgJVwScVGYMSLH4gPVlwnlcS6DbWy+mmuvXCeDWZWgdmprVSJp/7nnnmTp7VVWVMdXf+973bGGG uiz6zW+srmgOkCbHHZ0q6b7DonWK7b9RHi9b+6GTEP0ZAuCJ40vmM2PmQw89GC699BIbk+mD9Fuu BvVBFhaRaL744ou2fQJ/+iOaK/RVjB5h4OiNN94MAwYNMAvVWPsdI9XgqVOn2eLgWFlo36WxeMWK FTobtUwLhedJdXhMeOHZ58IOqbtTLtJEQ4K5ApVi+ggLN1yM36+++qppV+CPBW62ilRpMfQIDwX9 GYV6fd0T5rTXN1FSwAQCCQQSCPQsBCKBE1e7OXMUJogV+PEykvGpT30qjNQZpKh/slcIqSXEOYQP kkxW1DmjFMpCNJOIEz3CmIhR4W6MY+RjDqkEhAzhYDwxzoHk1NRM0wTOaWKasArJ3r8VkkJuFLFz haxOEodyou6KQ622e5wYNyUEY1qAtDQ9QxYJHuIOw/6GmrBz3/ZwsKFWBJjUTyXgZM9srZgx9msO KR0cCgeXhIMlDeGg/mbNmR6GjhkShk87OeyWanTFlvKwY+uuUC5GpnJ0Zdiwd60kEdp/JTW6xgJd oVbpSH0O1r6hIgyrHC2isSTs3qlzBkXYFSkvYDZeBN9dd9wVCrSv9D9+/mD48U9+Ei66dH6onlIl +G03UEB4ItnADZIFzpISzu2EqI0S1KamlPyQiEKgsjgh/ww4AmPwAkKTBQPam7zBDRz+fMdx5zt3 wvINBhVDSuxFI1/8wBXuMLDe9sThuSecly9b+v4tV74pSY4hnlkYwSAMizPssz5Hx948KXX3BZJS s1DxzDPPhGnTpoW5Z54Z5s2/SJaG3zMYUMfOOsrZXrk6m2YSvu9BwHEEHKM/gTdst+BImPfff08a EUukln5J+MhHPmKG5X7z29+H8845O9zy8Y+buv3Pf/5zYxzZIgF+s4e6VP360UcfNQ2Zn/30p8LD xjBQe1jLNI7MmXN8+Mm//siYWI59WrNmTdivvfPnYBBM495OxX9u4UItlu2zhUXsBhynY2vQqFmw YIEZV6IV2CaCBW7KDfPKHIM9A4yeVWuBk2HA69b3Wi2pUWcgkDCnnYFWEjaBQAKBBAJ9EAKZxDvE DgQCFnkhJDh/EqNEXJMmHWMMK/sJ2Q+6VAT79ddfr9X4uBcpMiiSOioNmBJjUI3xSHORbWBHPkhc PS8ILPI8QwQQhjyGiGghTYwxvSlpalVVlaX5/7P35tF1H9ed533YdwIkuIAkSICbKO6idlELJVmW LMuWbMvypniJ7Ux6xu4zaWfOyXRy0j2nk7Q7Pvmj55xJbCeTidPxkrRlW7EjW5ZsS7J2UbtIifsG 7iuIHXgA5vu59Qp4BN97JEFQIqVfkQ+/36/2ulX1+91v3Vu3SIf6cXQTB1LZ5QhQkoRSoBBoPSiQ MiSpZnlVsT38xM/tZ6/+3DprdNh9Ra/ioc5b4qfKVPSXW8kxpUzrKJKKUvvtA4/b5Mo625veZ8PN OiszXW21PXV2QkC8RAaS+l/rt74uHWA/TyqvdQIyAofDKQCx6NedsvrOKfb5275oUwcb7flHn7FL 5raKVj2u6lsihrGqps7mSZrx4jMv2iOP/sr+3e/9nkDsCdu6ZZvAUZCEwwQiKeF6zz33+BWaxT6G 9r29PS7RIA7thbaMhygJxz8sBsjglVw2UAX8AlbpI8AoUnDSc088xgD3KaF8rsTDReAbn93zPP6h TrjscX664lim6BbjzLmOnLGK1PRzn/uczZZ0ibbB/GOlGMkPKsBvaoz+7KcP2o2StsbyTldGrnDq eC7pc+WZ+L27KMAY4cc8Zg5xZYEQUPjaa69r7vbaJz7xCY8DAOSdw1mlzEHmNaCRxSsM0eHHT4PO psjw3KOyko6klHhIQmdJ0rlHGjQqyAHs+tffsNnNs22qwOX1167xKwuKbthOklveB5yxynsHSSn7 z7FyTR15z1Nv8uZHGAuTXZLcog3ir97MXH139VjSmrOlQAJOz5ZiSfyEAgkFEgq8yygQGGIkY0UC GAFs0ERYepiep59+2lWvlq++3Fs+RZI9jtZAnWvnjl0CGzDUQX00MtYRAHkC8F4O5wwWoEyJuWcl n1X5bVIlu3T5SqWgBkFdFMYJZglApKgCWoEpI9uYfYAg+JybQ0l3SKATSaJgnsrSOas6Bmb9wfX2 wol1NjBr2I7XnrD+Yh0iL0u51ZJyprf32/EnO61pfp3VTm+0LWpHsQSXZcvKrXZ2ow3tLbZjzx61 ARksmn/tXOtIn7CDOp6hVupzNqtU+ywB2ypZ2sIlh6Xue6Dabui5VWeZ6lga7fO6VJKIfgHJQc5V pZ9KK21STb1dufIKl0ysWLLMSrVXrGp51QgIhfnbvXu3n3UIjekTGFGu0Bvgyb0DSZUBHaEhDC97 ypB0wkQCJskLf+LCdAJE6QvycLVBXSNYJU/SURbllJSG8khHHuTHPYws4XHMjKfXziZtjEuZp3PE wWAT7UO6RBtRX8caKcz3FDHwPVqUWblihbeFcUt7Ik0L5X+ubS6UdxL27qcAcyiOoTivW1pa/Bxq LJtjoGzVqlU+rz7wgQ/omKfbXbODNMzr++67z0Hh/v37nVh+ZrXCMHq3Qeq6H/zQh9w4Etsqjrcf 97NRP/+FL/j9ifYTDk6Rtk7XkTV9egfUT5lsN99yiy3SXvpJMlaHJgFbPnj33Hzzzb5Fg20Yc1vm +nvjxRdfcq2KadOneRziI6nlG5K4hAJQIAGnyThIKJBQIKHAe5wCMNQwB7iBgVHQx3mgSEzbdu7y PUa/+MXDrnaLVBNmiPPstCPTLew2N891Zog8ACcYyuDoEXFRAjy5uQ4YKwxv4KhDa2urr7gfPnzE XnnlBy4tnSmDSDMlTUUNDGYHq6kRJIlHO8mNSFBP8h3HgwDgoNReMcwzqD2napAUbsUQ1pZZ3XxB 8xVqX03Keou6JWMVcOuptEN7D8sqiPYqqj21lcNWObVUEoEBmzSv0iYvr7djAyeUl6St+l+NOq1A ZPfSE1Z3ufZjTVZ8qcexVzcl40pVhyqsuq9KyFbnFwqcNjU126x5C7RnrMckcxCjKaMiKnfH1h1S M73aVl29yuob68VEDtr0shkjjCsAEofaHIwpDmDo4FRtItzvCdPP6arwTknGv/Od71iXJIf0C8CM Pt+xc6dN077fKTJ8hLSEfcLLBJo5wqJWZSAh2ak4GAyiL10iozLJFwewxeFPPWKdImj0wLfhTywv lp+rSMYsBmSQAKHejtSHdBwVxBFHKO1WVFQ6PaARaoyAc0A3+RbKm/IIj/XIVX7il1AgHwUYN/Ed 6O9aPTMG165da/fff7+2XQTVctKjis5YG9Qec94vzGXGM9J+jp0hH/LDIBJ5sCcU6+L4Lbp0sY4I C4tTerSZ2urAAgyWfOdofqP6znFZxF1x2Sq7bPVl/j5BY2K6gOeKlcs9PvOdOBhUws2aPXNk/K9a tdLnDXvnWXRLXEIBKJCA02QcJBRIKJBQIKGAmApAiwzxiBmBkYDp4Zl9d1OnNVrb7gBQUVuEsQEk YvACwzowPKThF5nyeCYmTH5eJ0zEijpMEVI6pHOs7KOetnnzZuNQ9yuvusr3RLHKj3+wOClVWjFc Qc6X+Zt59P2nBYrMW5esAEwSAa6HME4E0BBtRBHrVxldgqkijXWX6i7VraMXdATPsKSRU1K29I7F NnhIarDKa6EMfPQXDdix8nbr1dEvOvfF5i6abpNaaq1PoC9d228Ncxqsu7LPOgRyhwehHQycyhyu RLFYACgwlGkZY+oXSOpO96hOYvQkNeb80TfeeN0mS1LRMHmS9Q70CryKFioH2gCUovoc/SJPBSp/ MaE41PCIRxhnrUZgT9hegUz8MGbyve99zwEXkphVMlzyt3/3dw5CWSxAknhEqnwYsGIBgbwxroJF XsYEdcAN6zgKFj8IhxmOdQh7YD3KOfwR3fQvv1PbGQ+Z8cGV+GPWNU5NDn1KgzEqjg9ioQajMYwL dVV4FikBo9CQtkLPCMBPzfBUn0j/U0MSn4QC+SkQF5S48u5kTgEaI9isr6/zuc+45B3A1a3xKi6W v7Ed0KexynjmvUB6ZqpbB9d2CY6JKdVC0qDUgwGWRYNB84F7jppxTQu9bIjPGC7WNoI+vhtos+hZ //WTxou+Hz2y4O6LUYozoPck3wMMzPEOIC5Tk2/AsOKTLnEJBaBAAk6TcZBQIKFAQoEzoAAfYZy+ 826a31ecxagCwvBzplQ3SAJZWWb1GHAHA04EPuB8sAcGgmQlrniTb/zBRPDD4UcZXKM/H/Pxurgm PTQc78hJZQmVhPIFRsWYpGRhFlekfYLbt++QEaKdsixb4YzPxk0b7fEnn7Bmra5j4bVCQLJd6r2x nq7eK8ZfcNPz8JVymhOa5H6UFVxYsU+pzMpKGQrSuZoYlyGcc0Bnzppp63SmJIwU6mYAV/ZPBdCM eqqYspG8QhE8ZhfnR9qoMK7EBcaczgHStJvLmbjhYkEYqSynhEZKRDdBE+WjcwBlvKi/VMyZmC02 nBZXpGzKvAY79pSOiukQQBkus3ZZ2u0e7rVSpSubLCNJh7tkLOe4ziTVHi9Z7DXtO+3R3tWhJpUl I0r9Q11WKpXqtBjGfoGiHjFwaPoimZb5J51Wo32cbjgpMJidxzokxZNktqFRNKmwwd7+0I80kPoq HySsqCVj7XdY9Ir0GQRgaVGBtmJkiXj9GmvwqoBIpIQsUmDw6oYbrpexKqlUHz5k+yUtveeeu3X2 7MtuFRgVwldeeUX7LG/wMVCpPkI1G+NLMKEq1usEM1oiOpaI/NolJz/2yo1K64skNc5n1QoG13tN 9XQmVvkyvzx/BWANmH3BjBsAMerePocUBpDk6AuekRJ7TjRa/6EBoLNYZ6VSn6g5MKT00AlHGSxK 8HcIK8fURESirCLlw7hnPHpclYE/ZWX7e+CYP16/MX7Zj+QT3enixnhndoUoo3mfWZoYi4mh3zvg 3plSeQ9c2A5giovjLi6UMHz4jDCuCQvDSWNWGhs4xhT+gyFAETXGlcbjazyX6n3gc0zx2HvPTCBC Cecgyw1psYw5yxygb3xeUJ7ScvQWcwY/vUp8IUcfE8166kJqhfDN1FUzzRd5ZHbd60No4hIKQIEE nCbjIKFAQoGEAmdBAZeg6GOO0Rnfj6cPLyvDqP9hvRMJZJSiiHf1j274aOtDLYABMxsYhiDdYgWZ H4xGBF5Ux1es/WMfGImzqOJZR6Vcyh/m4E6YCjElR48ec4MZLa0tNnVyg9VW19iclhZ76Oc/F8g6 5nuaOHoAySr7T2FgSMc/jkUBmEIHji6JDDwVG2W2RRw5wAVqvNu3bbMW5Q/gYd/SvPmt9oPvf98O CrSiWoy6GZJTnNMdFVGqK5e5jFyD76h/fD7zq/pX4HwIIJnuF8BUe8RclUqCUGllAjVS5e1HpVnU En9YMlhu6c60dR3tsBmD06ztzcM2ublWIHTApg41WVGb9mnu6rfZjVNtcH/aDu84bp07JeG8oliS 1CmyilliOkXQivo0JoRI64YarK6oUoBUR9cI6KUkTS2WenGpWtgnIFZWUWOvb3zNz9qcObNZZ5qy 4IGir2itugJoYS7jYgY8YfiFvsUfyYhQlPcTFoO3b9+mPEwqq7Nl0bPT940BsurVF7N1DiqSbfaZ cZYpR/6g1ks4hoEYvwBZJN1TGqc4SHxj/etWXVXtfYYlZiTi9AgLNmHRBpzHAkzsvTy9IyITw89+ 1ZV24WB+e7o7ddxQMMLC2GAO4thDh6PMJUuW+P426sc4dOm7xuncllYhc0mHkPYoyzAHxC4z59Qu RXE/VLuxaKyoLk3mzEjcoMYFDhrgGNfkwW90jHtQ8iehwIRTIHuM8T2JLt5Hr/jssyzjGf1iGp/4 PCgb8iU8O//w9ghzbiRNyNDfKye9eLUHH8f84VupCTWSvSchkPwzcTzv0eoTmriEAgk4TcZAQoGE AgkFTkeB7I853/dBSbBgjksk9fPlYa0WI+HRkrKvButG/orhH3uiBHXKuNLMhx9JDQABZhaHGqW4 fGd2HbDKPwJWyvf9iJm4p6tvrvDAQscQmIYRVmGEEaEMXHlZqe0S019WVmLs+ayWZLNX6lmAUpjx Sy+91PcbslLPXjuASrHa4mXAaLhUKlh3pX3Z9PMC/A8RAwBgb2Of1M9QFwaU4zC8gapay9wWVyHG QvD8BQvcsiOgtzQjJSNuyEl05iGvc3ZIoYHeeaN5gNTcBD5QoVUxltKho/RPUfewVR1V+j2SDB6X gaBiWacVoC8t0h7Sdu0x7eiyI7KY2zR/hk2fPdU6uk9YbUWt7Zea7Jz6Jhs80WfHdJRMowBfdU2t dQz3WfURYKnKGKpwoKtBYFXtVVZ1pNLqBjj4XuefalGjX9LofvbCitkb0NjZvXePNU2bbQ1Sr+3q 6xQNtLgA0IvEKNBAxhd0hoaAzp8/9HMdl/KmvSJrye973/vsF7/4hfcFffvII4+4eu+f/umf+mID x1CQFrVu9rICVteuvVkWld/yeuJ34OABnftZr/2nO9T3Rb4PjvNfkakMM5ZVT/hWfsFR75GH6OnX 9IiqIP0G40y6YfVLub3wwhv2l//t6zJQdIXHZV8sKsaAUjQZsLS7QgaLaO+PHviR9sWqL6Qe3q2x 9Ltf+rJNb5qp+kjS6fvmmGNBasp4ZdwOaT6HAgX3Ne6Zfoo1Uj/Gp9Mxc43ANPd4H0l2VjfkdTJQ OKvkYyLnp/OYiBfU4xkM6Quqvhd7ZeJ4m8hxfLHTJKn/20uBRHL69tI7KS2hQEKBi5wCrPkCTEct 1Ib9MzBQrBQDOgGtMOAwqxx5kpYKZXRIrYgL0+034hcHUXtEkiXn+9o8H6XPMKbDAo3nk1GIzAh1 RZKUlnSuSaCUw9o3bnjTli651FV+kVgCDDFMdNttt9nsWc0OTgAF7DVU610SF/MLzHph1nJAQKe+ od4OCjS8KhXR1tZ5AkxYgu33M/kwsvPx+z7uqr09koy1trY6ragLR5ScD0f9UU9zMEQ/sdCgvaWt k1qs4a1a63y92yZV1VhKVjEBX25opLfCptc2WapcxoqqJQUVoJ1c3Wgdh49bQ2e9TSlpVHfLkMic +VZeXGHHS7rsaKrD0lulvruj38q1z1TE9z4v6pDEsqPK5lbOtKJOwWlJ6SWs1ZjR+Cgtt23bZSFZ KnpzZP0ScIQquavKCTwB8XLhvNAm2jUqGeGeBRCkiQC6K664wr797W+7Cnc0pIJUfNGiRT6W8SMu fbJS+08BqC+++KJdf/0Nrub75JNP2mOPPeYqtFjg3ClDWvPmzXNjShrKqiv7iwPIY7wD+KBfIRel vz6P1FYccwEtBNTBaf+PfvQjPyoHy9KofyOpRQUc4E05tBFVcY59QbrKPO3ROY2MTJfekicZs8Ak R/7U10G8xnsa+uqfL8Cozi4RUjzyxdEOaEldGPOk5zlxCQUuZgrEMXy2356Y7mJue1L3d5YC5+fL /s62KSk9oUBCgYQCE0aBsR9m9vKJ87QhV1kFjGXUJ8WQFgmQohaIoQiXhompTWtfIH5FMLjOiAvM CPhIU9NBDRvxUMfkX/ioI1nKSGeUJ4YsnGXWPYYqxuuErzJuVPKDR/SmbIqt8H1JkupKJfOaK6+y 559/3tVo2UvY2trq6p6AUYzhLFywyOsKDdjXWS5JYmTMYexpByA9FwDB+A90xIjGlPoGB0aA4V0y vNQ0Z641yios6rwV5RUuoQPssL81ghpY//PG/ovWKUnDbEjSU1kvLtX5LkM9w3bnVXfa9VdeY73F AjjqQC1LgEx0nIz6MF1slUOT9JiyvtK0wga091QgSnl478q/TPQpYU+v2t1bpDNGyyQRldEkFjwq 0pKiaw/rUJnKFIirHKiyqRUzbONrWxx4DkEvgacaSSD37jsgYFbtiwOo5KrnlCcASZ0QOzTT29kX VK1ZQBgBUEgw9VuzZo098suH7fqb1zgQBYS+8cYbPh6/8pWvWKck25yJiAo3Kr2AsGOSovNjTHDU EP1zww032J133un9hLEs9gojqdy+fbvHo1z6jzHC2Ih9ybjL51CjRc02AsE4HxlfqJX/yZ/8ican jEoJjJLfpz71KVczB0Cj3suiSW1tjav3ApRRG2eskxaptINfLTLgmGu0jZ/3GfNWCwOonrMoQ6wy aRXggKtIgelL8qNenk5X6kpbJ8rFOTVR+SX5JBQ4GwqE79LpUyTj9PQ0SmKcGQUScHpmdEpiJRRI KPAeo0Bkgk9qthhPJHalkjD6nj0FwmQTlx9qiyUysFIkP5jTeKyEW0MVi6xEIQAAIABJREFU4wyc QiLHvjmM35A2Mt0APJhbABdpYb4j0wtzHqU1J9Vngh8417FHh7XD1CMB5ogQ6oi0iXoiifrDP/xD Z/jZC1pZGc6+JI7XT8w+dKD+1B1/AFNOWmbUI93YUKn2VkrFlPgOKLo6vLwvfOELgVYCBxxvEvOl LpSH9PB8OO8DtQNpnbCbADTSSQHDVJXV6SxRFhRkE0RAUOXrpgxLP2w+Tcu4TkWZ9ep+WL8StQfD UiKAwhRfUbQ1VCI5JRa47WexQTQrk6GRCv0wG9KTkqi0VOOkRIBnWBJYP/+UMSGQVFRqB/YfsM7j HTZ3dqsvjPhRPBQvmtN/IjgV0+9UhwprHG8qwdVwe3R26tLlS6S+PcP7AEBJnNWrV9tTTz3lfX5Y FnkffPDBcISMyq+bVGfzBEoBeu3t7VK3XmhPPvGEqwnfcNNNNkmqvYA5+p1xwK/9RLvXij6O/sSh rrkWL7JrT78zN7jiuKeOVZJeY0UYA0yMG8YQcZg7SHiZf5RxQtaSGctIVa+77jpPj8S+o7PLF4gm SeIK3XZrTy3pp0pVmT4bxBKvykPtvEqAHWn+oYPHdL6p9pf7HlroTPvM80b6TPvi3KWuE+UizSYq vySfhAK5KBC/ObnCTudH2sQlFJgICiTgdCKomOSRUCChwLuKArnBVGgiVncPSBqEcRikiag9cm4c eyJxMM0wpzxzj0SJvWkcz4H126YZs1wSCMMPAIShRurDhx1JIZIe8katFskU4aSfLvBwbk5AERCT g38QPhKPLTAqyRgqklu3bnUpGeqRqPBu1bEuHMZOHTZu3Ohqm1hORSoKM47asnKXmm2QjMV60n7B Kgcj0S9ekeHhAAMAC0AEbUXS9uij2ufYNF2Wevvtlltu9WNKoGdk+gHyDsRiZplrbkg2JtIZPQpw OBgSuBTB0tpjXCJ1WoAUVm6H/fgYASW1lzLT2ptYJDCaLhJNBpGUyjiRiEr/9sk6s2SVAqACsurj YRlZSumH9VyMFw0PKA+NqfSQTlJ1zCrps9rnBoAkZAW4QeNSodrjx47at7/1bevr6bfr/tertVCC ASCk0wJ8Iie1Gda+VO8Lgash7jO/YUT1qjL7KqE5Rqt4xp/4ZVKlph+RPhYpbED1+8//139xA0d1 AnYf/OCd9rOf/UwGkhp8zG/cuMmBKxLSu+4q8XNwHZhqTrCYQj7RUV5Uc8/2Y8yfjp8NcYK0l7Q8 Azqx7MxYOaq90YxTyvv0pz9tlZL4M38e+NGPfV4BoAlHErxjxw43rIVUlXMYj8gQFxJU8mO/M3ku XLjQvvaH/4dtlmVqgDcOYM4RSrR1y5YtdkTqzBUCulXVVT5m29ra7EMf+pB97GMf88Ur6ljYMWrO frQmALUwVZPQiaFAHL+FvoMTU1KSS0KB3BQY/XrkDk98EwokFEgokFAgUkBMJ2qmMLkwrAAq9rlh FAbGneNV1m/YICulgWnFUijSRvbs/epXv7Jf/vIRu+uDH/J0zz33rIPUTklvpkqFtVcSrN/93S8q 3qP20EMPycjLVW5BlX1un/zkJ8VUz3LAhPosbG1kIAKPK5/IEHs4MeSlf5JL6W/GZW5iWvbbkS4C B0AEUlKM4iCdelkGchYLMH/zm3/jefw/f/PXDpppN6AJi7bRIcns56gTgR/ANMAU5gaJH/lHRscl S/ITXPGkHPHx2muv2a9//WtbvHixPfabx2znrh32T//0T7Zvr4zXCKyThjo7CPM8Vbaublw4ViDr StzYRryzn7mPdclKctKtoghgST1brS5O6cRR4Uo1S+AYlVQZJFJ9ihCBqjOgME2B1q4mqntonhLw 5DD7oPatDNRmHRgoesifPcYARGF3zvcbEq0lJKUrFEXSV6SlSG1RDlYYCwHFOm5hqDdtLzz9nNRs u+zzn/ucTU01Ks2QDFhp76XTHqm86kRGctnt9mfVERA34k/V1Rb62vtUybgGgFosCWmD7ZEK8QpJ U7tlEGvKFMob9jGA4SMWZgB+G996S3En+aIFUkbGPP0fASplAJxFPKc99I/j4/QgLUh7WZjAkSeL OT/96U9l5fmw6h/UcFnY2S71YeYc85M6tLa2+lE3+/btcz/SAUy5qiGe/iZJev/qr/5K8+1Ku/XW W31RpqZ+sreNfKDNpk2b7C21kUUUVJdZOEKSPyCJOhLVtGjWqTyJS764QmMsxPBoOf+IUgXdmaan KiJ1qBLkV64jaRXIWPaxMjasYOnjC6Ts8bqROo83g3NIB31iX3J1eim/7PtzyP6CTprd9gu6oknl 3nUUGOUs3nVNSxr0XqJA/HjENscPSHxOrgkFJooCGGLhWBP25cGcs48N4MkYxEDMjh07pfLY4lJQ QBrSQMYjKoVYFa1vqPN9nJetXuUGWnbt3mnTpjdK4lNhG9583Q4dPqj9llNsy9ZNLins6+sRAK4T U4mELKg2wqhjXIYy+QdAGQFuYjhhQXkGGHGPxHRYJv7xw0Wmw5lVRG6RUc2EARjZR7h/7z777WOP 2wJJkwACOJe6qdwIFmDIXTKmPEql0jxcHFhJysA/OIFU1Zn69AhYlcloELE8neoECHj66Wf8OJk6 WVS9QQZ22o8fU4wAMmN9Y9nk6W3xtvI06vAH+GCBNZcjryiB5T6XK+I4BEC1K9pK0imyFSnuoM4P hcV3YCq4heRTIbrSTrVPzyndA8XYI+rHnmQYWkC7PIRykaMSBwZXIF2oFOnlgM5OtTKppKradAnn qZZoLyR7Hr2cknJJ5QZt2aXLbc0N19rCxZdIvbRb4UHlVeJW1Sy0HeNI9CHthBY4HyuZuiiij4EY ViK1WIxuUUdogn+5xu0//Y9/CONI+TDWGfOMcc5BJR5gDbCI5BBKlAsQMh5ivvQF8RykKgJqsfhR L+qD2jQ0wEgSz8TVf92H+nLPeah6yqQLLEu/jui58cabNH5SUt89KtA8xa30PvPMM143rElv0CIR xpqYfwDua6+91vdJr1+/3q87d+50DQjq8rWvfc3riCYE83RY0m/ayBmuqAcDSGk3eUW1515JW7H6 26+8//1Xvup7ctmHzgIGjnmZz/ne4HyBpIUAeRwjEDrlctE/zjsWTKgHiyFx7kB/8vcFKUnI47nM +EfjU7nyPp9+hdpLuSwSFXKnS18obaRZoTjZYWGM6l2XWYDLDns33J8LLd8N7U/acGFQIAGnF0Y/ JLU4RwqM/cAUesGOjXuORZ/EKBQq91zLSdJfCBQQqyfGDlVXjMOwf41jVG6//XaXNiJpvO+++1ya um3bNlkr3el73RhzSFU5E5LzFpHcIH2BqUbiA5NPnLa2Pdba2irrp9f78R0AQtQSYZBhsCOogpGE UeYamU2Yz1xjGz8YVAAs4DAt4MEVAAOIAFYBayL7Rz74UxYqvnfccYetEpBGooqEOErWyHdAaqBu NVc0qajSfjv5kQ6/WDcAa5lUYsm3o7ND+3UDSEZ1NDLMfX39ktK+Yo233eLGefBvnb/QXlz3gltI hebkC2qBmQ50ACRm720NEg7iwjgWCTRFR/zRdoXjeyKAinFOvoqtR0UXVCqXkuQXHOp0dNwggKl6 AETdT8AUcDjkIDXmBN3lRNiMRq1oQmziyjMDaF1kyoZUVH3lP6z9ppjAUtcKVEgSrRtUSLuOt9tv ZQ33sisvtw995B4B0y5JjpWP2ouhrCJJVpFkUyZA8qEnHnJABv0xhOT1UE9TBn3oz6ozYUh5MYwE 7fjFPmZ80s/QCg0BwpDyA0CpF1JT/ABytAxDYBGclpeXKUw0kR9hQUpH7cI9wDJI1AOApULEDeFO OQFGAXeBeY1y79MQbjZr1kzNudu8rMk6gxcpKWrf9DHzgvp+/OMfHxlfynRkbgBSiQdgZi84Kr2k j+0mbpfoh5rv5ySdJm4cP8ThmTbS36SVl8os9zJ9jrl0Pcwt8srlXGNBdMjncs3jGJfyC4UTj3oS h3mQfQ/Qx588cGHuMjfC+4G2ED+/KxSWPxUhse8Kx8oderpSTxeeO9fT+zK9WLhhrkArfwcpGTQ6 l/acvuQkRkKB9zYFRr/e7206JK2/yChwuo9zoeYU/vgWShkYnLFlZz+fS96FS05CLxQKANJulCTl NgFSP+IFZlXMPszLnR/4gDMtr73+uh+fwV5UJDUwuqj2MlYAeBzZAXPDeIGRxj8ywfjzDAMcmUiu 7H9DSoN0h2eYccp0SY/iw5STjvxgSrknL2dQFR+IAHPVJ6nToCRDMNIp/YJELzCrHInCj/zZe7dg 0QIZfimTOvIv3fAMeVJn6gbo6evr9uNmYPRvE/Du6A4qnexL3ax9qldddZVNnTIVztSBwE9/8qCr Ky9YMF9eUllVe6j/woULbM21V1tdbZ0h/UJCd/dH73XAFJlAp4u4UACwQ0bd+7mePjACSOOW+lF/ AJG3USACF+mK3+BgYN49IOcf9QF7NYsoiTYrPwHLUC7ANADPIhm3crVcpNIqV0jPcadGBKV7zuBQ wCkuMNECFxwxPsxPdQMYKizkJWm45ER+dIkAA20hjH47cuSQ/fLXj9jylSsEYEusvy8AZvZ30l6k XsQvEUg9evio/cV/+Qv7y2/8pZ/ziaS2VAaXuPZqn6pLuAX6aBPAVDJfHzek54eDXowlp6X86PMY Thj3DtIUVxSHTF5XNwimOiDZx/iX56cy2MMqsqn/FI9GQSG/p/7RD1pzr7YpDMkq5bOYgtYA/cCY 27Zte5BUqh7Mp2XLljnYZBGHOuEX5wDpcdQ53gOieYauANPokDYDOGk3YTwD3JDs4kjPuCUM6ScG mXBIhGlPqRZhCAv08UZ6+Ng/kY5j/eMz6fM50oZ6jMZxGmcSQDsc9cDKMu8N5hNzjfOZaVvY7z7s cxz1bGgGrXHQP7ejv/IG5k6S5Ut9xutCzfKnzm5//li5QyK9coXyrnFaZyT7lEP8OI5ypUn8Egok FDh3CiTg9NxpmOTwDlAgfozidWwV8vkTr9CHf2w+uZ7HfpgKfdxypU/8LmwKFBo7sN+o7cFo98sC qHPQag5WOrFcmxID9rSkW29tfMtuktphjY6wYD/liy++JInTNI/HHkKAJYAOphF1V7fmK8YXxjEy P/iTP+OtWExyjYzSPC3ght/s2bME/rbYZZddZnWTBf7Sfa5aydhGsoVBGJhzGFLANAx4d0+f+2MA pnlOs2rtyCC0ISACOFq76dZbrV/7Xx/W0SKfuf8zXs8bb7jRfvzjH/teWCTD7AMtEjPL8SIc/8Kx MgcPHVAd6zxs27ZtrhLJ/r+ZM2a6oZ3NGJJR/GeffdZadD4nRUI3pMg/1x7bJUuX2lXa9wdD+Pzz z9lPfvjPtvbmW6xaNCyvrvLjPPwsz+zhI3BFPVKS/rFQkJYqr9NLtFVnOPDt6dGxL6JL7FcAjrc9 O58c94DKYu39VBGj0TO8eWD/yVNBbnBIwBXppGhKOsE6wT2FCz9w3AjSSsAnyVH3DfCaeqDSG+IA p9V0/5EvoQ4o9dDb12tTpk62O+66wybJIBGwZFAVCww/TypXP/amlsuC8YwZM+wjH/mIjw/GFOMA GgyqDjjAiAMSSSZZHCjS+KpN1Yl2gflmDBIfWiKBZk9spCF0jGN2JI5oreKVf0Zll7GsNJRNHiU6 fqVXAA5JaLHoT70Zl1xDvqPSQPKPfcXe6/Zjx7VoEaxGUy8AF1oLSGsZ/6+++qoDMPJ688033UgS 5TK34ruZK3lSlpepZ+qHpJnxxlwE5GOIiivpGWveVtU3qr5GukBDaKCk7rLzJm2kVQg99S/x+eVz pM/nYtrYtrHxYhvZl/zKq6/YXC2M4Qfd2tp2Sz35iBtpg4a8m9DMIDy2LX+9qG/+Oo+tx9hnxkE+ l7/MkCJfW/PlN1H+jOduabVcffXVvn2DecT44cf8SVxCgYQC54cCCTg9P3RNcn0bKFDog1bo407V CqU926pn5/VOfUTPts5J/FMpkN2Pp4Zm+SA9gHGVFyqyA+kBe/W1NyRxCSAIwykf/ehHnemD2b36 6mt979uWrdul2rtaTHm3M8EwxW9Iqnrw4EEHkjC1cfzAyMH8OO+reIBLxvQmSSR/JcNBvb19YpZa XB24rGydVw7pJnvjkKACDmE6AYNYNEWVeIokmHOam2WFdJPAy3Sl7XYmK7tMyqgWwHz6qSfsgMDm Jkk/n3zyaVt66WK3RPq9H3zfLRMj+e3s6HQDNJQJc//CC+vs7o983H77xK8dkNx7771u2XSyjMvU 19U7iLjrrrucFtu2bZUkeYED0x98//u+nw+V5//7r//GpkmVdObMGfbUM08LkApozZplT2o/KsAJ ppB+op70AJJA7mkD/vQJdOyTRFn6wPbySy/YatEcRzh0JRwmm/wKOY5wcc1blxbRE/EXUuE9qH2h QZhE2QGphGdJ5hRtBAcrHhJDVIGDdVzFR8WSCP7ThXDlAoRVNDmpyA726aK9p6Wqt1R8Dx89pONz OGcTtVRZ9VWZJZKISs4uOkhiLstNGE4C+B06fGhEakab+UXGGpoxTgAsLBYwTtIax+RBXxLX6ZlF szhOuEagwdWl0wLZUMAlkqo8eYz0E3nod1yqsu1STWaPbMw/pvf+VBzqh4tlsPAxdfIUa5zS6PVj TlBvztlF5RjJJurxSOqRACI5BWyz4EEZxKcMfpSBH4664RzSqz2olVNnNWAkDX3AGGGbMZLTYqmh kz7WjfN5uecXx1YELDF/LyTPH9KN141Nm/1MWykfiemL69bZnrY2pxkLYtBp2rRGNzyGkSjoVy/V bEAXafhl5zW2fmfSrrFp4jP0z+cKlUmacyk3X5ln4l8qC9avan6gAYPVdRx1hV5c36l6nUndkzgJ BS5mCiTg9GLuvfdw3fnQ+cdBDNFYF9jE0334SZcrTvTXNXPLJZ9DBsK/6CJjEJ+T68VBgbNhMpCC sVcOZrZYxn/a2vYLhG12aQ79jzEW9uehcosjHkzgrl077Zrr10hq2uFxsSyK5AIJJ1IeGNu4Ip8N wrhH1ZA8sAx68OAhB5utrS3OcMNkIoEkDj+MuGDMCMkIjDzAlDjXCCQDJLbv2G43r73J9yWKu/J5 FMYtEiKkbP22f99+Vx8+IinL448/7pIz9vABZnbIeBHxZ82c5cD3/vvvd4nVobcOixHe4WAb1ePL r7jKVZoBxxzZQX0AEqj6PvHE42L4mvzoDoARbWQ+PybjS3NnzxK4v9vbtv/AfqtSuo6uTgcG0JKy YQ6Rejk4FWCI6nfkw7sBWvb191mLaLRYhoP6dY8/Pwzw0H9gg3z9Lkq45HNY0klBMZ/hvh9U/emA RnQL54uGuY/abngfKQJOLw3Shf2kwEx5aQ8r9A95Kz2R1JbgMvXhXFMdOcM7JaW+YHwBTjtPHNOi xKP2Z3/2de0Bvt3m6IzT3bv2+LE2xQJ7qSIWMgQKRZPm2XNdqv6TB//V+589w7Qz0g6ABQ35IfHm 2KDjgEY1ItKIuIxh6Mh+6KgiGwFfHKuMSfxYJkCduLO7y6XErjYMgTOO8om3UmeSck85lB8cYzAj cVUYeRMHgN3S0mIfvOMD1rpwsRAiCw6aCwJZHOmCdJg8AKmAUsAY46u1tdVmS1qoQrwc8uI34tQ2 FTJSNsCTvotzTpFDmPy8T6lnxg8J8mi9YxZZedNm1VEJvfyRMt/OG+aS6sm74LrrrrXXtcUAcAVg 7+zskEGnpVLrPeIWiDn+ZsHiS0UPzpsNYzh/VaFj7LP8sfKF0Of53En9kyMS/VDInS59obSF8i7S XmLCeY8yHrmn/wulKVRWEpZQIKHAmVEgAadnRqck1jtEAT5J7Ilyh2hB/51dFLMwrFXtIkkU0ChD KoHoIX484SUAqZ6WdLofcfrA4ON5kY8/xBiZuOTlHKXyVlIYU0/gcUMayhgeEGMjPgfmmBKySqGE xF0EFBgPYwNzEploJBLNkkhyFAXMOg7GkHz5wcwAPmGgt0iqumDRfFdV5ExF0q1du9bzIl0cP0hc nQkSQ4caMGABNcQnn3rKvvzlL7nqLqBv9erVbjkYyRQqjn1ioFClxWAM47tRKr7sLwNoTJ86QxLe V62lpdnuuecjAeBp7yJADSBNeaVSv0Rllzz+6I/+o9R6P23XXnONIf383ve+Zxy7cdtt77MHHviR gOgelybA1CNVOCSQ+fd///e+/4/0nMGJhPWVl17RkTD7dE7mB10CjNox9ODoHa6f++xn7S/+63+1 9TqH8of//D2nwpNP/tbVoP/gP3zNKqTSi5QXESX0BMgwZzHk48yi/GgrYDEyj4ApQUHF135A7bGl TQ4MBaDYW4cULDezHHpApagvBB99vjtUlJQ0lOPSTtXS95gqFin4udEjj68HUuvFhGkj1HrJS4qk IaIqjwRVBJcv/kA7gkLZ3NEOLAMPC5g2yzL0pIZa2ycJ+2WXrbJLddxOnejWPHO2wKnUtmXN2QRO RQ4lLXIDXEgRGRPsvUT9FevStNeBJO2Q436pVKlXrljptAlvxdAAwPzDD/9SaacJzFzpABbjRyww 0Gf1yndAoBU12lqp3E6qm6QzWNv9HFxXs1ZfOXinSvxoq8rnnR37iPmDH6q+xArSyWIf6/gzHtlj 3amFiYGeDs0p9kmH+qGqigVa+pY6sZ+bhZPJqmOpgES7zgf2PbjKAxfThfET8kB9d4hvi+hBXB9P 6g3i8vO41EPjm/sw38ltVMLLE/7REU9ZhLnLTR4Xy8gT7OnzhcW2xCvxoDGlceXoKaTgfAtXrlzp 1oWhpRrlfRLGgNlavXfI4/jhQ94+4ngfyS/bkWdwzL9Az+hzVldoczE50aGq1hyUZleb/uadl7iE AgkFzh8FEnB6/mib5HwOFHDplNJzzEIKwyHiEsVaidUTE6aPRlr+QyXDtmnfW3aw94ANl2s1k71f QWNPqm/6iMroSelgsQ6v10eXYyXEGAW8KUCr72+FjFek+8k3sKJFOsqhiHIUhs3LUjEug0KePcWD 1pPqt3SJwoe032SwTAyLwIPCm8tn2szKJisprwyMlz5cF9kn+Bx66eJN6kzkeKuv8YGVWBYk2H9a KtVT8bACYwMuYQpMbACl3AP8WltbHbBi7OeZ51BRLbbGadNt8aVLdFYi6psBWEUJEvsnYTXh5zAs w3mZfVLlnds6z665bo1UFytdeiRvpUdlc8hmzW6GtXa1xkWShkRDOezDxEgNAxvJVVk550R2Zpj/ IAnC6i4Ogy5ILwFA9977cXvpxZcdZGKNdJrq+7GPfszVgy9ZdImkohsEOO9yCSyS29mzZskqb6mA bL1NaZhs3Spjvur7/HMv2GSBmcZpU/1cSJjgFQJE//Iv/6xzXX/XZjfPsU99+jNuGfjY4791elVr /+4n7vuk7drdpvk55NJA1KcdMKjR0I9nHH7MRQd6aiMqrr19ClMfpZjo+l+M6qsDHs74dMqKurkk IGH2+jtB4NL5abLQDSCSn5eZ8cNaL06PHsL7JbpQV/WrPP3Nw2qX6uTSWCXDX8NHaQVE+zEwJYZX 2aO+S4ZDevcAJKbOaLLmyrk2T/2/+JIl9srLr1tXd4fVT663GtFpzrxWLVxoMUR5UuaJ9g6p6R5W Hy6yT3ziPjd6w9459t4CRvTmCmBRfix8YOkXB33YD1pRWaGFg39THkf9ulhjafv2bV6XuXNbtCBy mQNCFjxeeullp9GuXbt9b94f//Ef+7sVo0vOwKsd8RgTJ5LewdQRx5UfiyOMCe7pG9JxpY8hCH2J am3sAwL7RRfSiYQUIMlWuRYzqnQ7ZH0CtL4fVGmVzB37RwOloWsYP4RBCwAzoSwT4MjX41NP0UOP Tjcop0qSjf5TV/pTCZQeujpwI1j3nhdh+Zznkz8CmDmv8zGkUMVB7Zj2eFuUp9PE6wfQZFwFDQPe HcRnIYD3BbSGukrqdPW4ktT70Ufqi2wXcsdHGVDvcbtCaWlBIVco7blVCxrkdN5HehNofmgty62M M76iOjdjlr4+1WWNu8yYOjVO4pNQIKFAIQok4LQQdZKwd4wCvPJdWulfaT6j+ihw1IKuMHqwE8d6 2+3r3/26Ha46ZOUzqqx3SMdxwMXAiOhXPlBh5d2yUNmlj25a0FZBldU1xiHxVWKm97XJgEtlnVQl J1ltTZ3197Q701deW227t2+3SbJSCiBNTdExA1NlxbFMewoFeIv7Sl1C1r73mN0974P25bVfspKh Shn8EIOpcvmQqfb8Sdy7kgLqYDGIDLOwgh6Y7Mi3OQAQ44IUwplAMdswMlgUbdA+0P0HD7j0qVnS H86S5LxEJKPE1SB3ZtgZQdEO3gdJCHmWAwAlJQKwdHZ12zSBFqzV9mcWROLRKT2SMEUmE1BbJAQE U8VxKFWSQpKehR49egEBECNBDdKq/fsOSAI1xT73xS/ZK+uetzfeWC/J6yRJQS/XtcFBzNVXXyPQ s8gloah98muSmuXvfOb+ANBRuxW4QNp76623ehtKJVVGgoamKkaZfud3PivJ3AxnltesuV4qmTO1 b/UFV1G+YvUVNkcWfX/8w/9pk7TncNasuao3iwHsvQx0DRIgGEEBA9ri844BB1jQXwcPwRMgStnu FAZDH9xIosxzuABE3BASj7mjCBCfHOjxFZd3E/8AZajcDmpxAgvIZS5Vlzq4pNXUHSzK+MF6sl5c SoihFdGnJKi0lpaxRIYULC2poMCe6j+39RJ74jdP2re++U2di1tlX/j8F2xm8wynP9L6X2s/8p49 e5yGCxct1LVCiyK91icgzxgbzoDpoJIcmOhIC2gIiGWhAiklv7KyCmMP9ZQpjfaDf/6Bg1LGcUdH l48F9kIjwW9vP2EHZU24XWqj7HXGMBhAhnc4e2Cdic/QMTL0Pt4DuR1IxWeAEos+dBHj2Me/KIER MiTixIN+5JNSvLBAoC+DD2hRXuMu9m4m+1B+9FX60H6+KnLKJ8CJYLBWAAAgAElEQVTzTFdrYpM+ 1jPkQb6ZBugySFmZhQ/aGevu5dLukCjv35PzzhUtU1aOIG+3L5zEenorvC203QGU6FWsBSniuuaF L6Bp+QbaMg6Ub+x3xl0qwwniP7Zk+mFi3LlkVDjtxNXx5JaqK/19x8IN1KbLmYe+UFKwUKhYuM4n l5Q8JRRIKJBNgQScZlMjub9gKOAfAdUGIGqSaGLh0r8MYiMGtXcL1zF41F5Prbfulh6rmFNm/SVS b5PUJDAuRTapp8GKNhXZrpd224y6aVZTVmPF3SW2/0Cb9eg4gklTJtvA8Z12YmOXzWpssnJ9tNsO 77PBGhncaG609oF227ZzlzUvV1irjGyUa9+bPkipXkkXSiusffiY7SrebX3FaaviA59hmoM+sFcx +fNupECGe4sMKeNtEMm8XPQD6AE8uIYjU/rhYW3O3Gab58eoSMIjMJGtIpaPYY3+XCkLB9gF8OBg lnAxnrNFALMMbzTirwpQHi6C4Qig8SNPfsH4kiS1UqdcunSZVANXeRu6dUxMl/xoF/HY8xfUZUeZ MNRJaRdglXiDfYPWoP2nMMIDAjs4Z+70jKopcSPQmCXJ67x589wqLwtIvdojB/AsFigAF5QIuLE4 Vewco1Tr1GyAtXeH//Hsw5/4LHAzXhezOPv0gR4cowIYANQUIblVm7ulAk6bkTTv2dMmVe9jLtlE Crlz5w43DDVVxn54btNeUFRWoRNp6avuE8ftqquvkhGbeu8n9jfHPgW4oU4d/d6QmjSLA/QVYVwH tA1hZGCMaRhjl9cs+3nXrl2rc2df9vN2qS9GhjAsRRzO62UPHn6MFTQDKrXoceToUZece5mKF+dA HH9jijvpkTj8qCNXxgTpuca6xwRxzCIdTQtIo+2Sr00xTb7rqTAyR697/rGIHOH5Mi/gH98TBaLk DWLMA65L1H7yQcAMTfwFA8xWfRl7Gng+d6AOe8lHwLVmjLdCace6XH11LnUdm//F/xzH2qm0u/jb lrQgocCFQ4EEnF44fZHUJIsCfD6RfGiNXL5cYVqAqpKAyK9I4pehcjGoUyV5aJUa1/xh6xnuUphi 6KNbOlRq6SM9dmJzjxhoGUOZLgmG0naLuZ40V/u33jxms1tqg5XKjj5rT8soi8Bpe7msPIpBWrho saxK9kpCKqnAQLdNb5XBGu3rGihDrUcff6noDUgigXQEsMzKarChmdWI5PZdSwEYtsi0wQjCMEYG OzssEEAARbwM/gAJJJuuQpkBeZEhjGA2Pp818QrxS+KpKBNQGp0ztHqI9cKfsjEw89JLL8qoziYH C4Q7CFT+AIUIJrkSBqDAxWusfwwb0nxh7yDMNIQgXgQfnlB/iAsoIn8cdSPeUe0dnK19uagvUgcv Q/WgDH6kK+xgJt9+F6RXoY6UXiwx6VEZofnJj35sO2RQ6tOf/rQsp77lRrJaWlocyP/jP/6jg1Ek vBgxYo8v+0U5uoc+ob0AQYzbtLa2Oi0AjvwirTmbFgn7Me3/dfooL8L4FySL+ekR8ghjlEWGNWvW OAiF5vQHElP6LS484Edd6IGU2jdTiwvUj36MLo7p0/UT4dQX5/XN9KsflaS6MG+87zPhlO1zSHVT Qk83vj/ZaQuNJeIVCj+70rPbmCsl7cvnoAO0iurS3Htfi2Yu0VVCj6NvoTSenZ7Qj7mPP32YuPFS gHGQPWbGm0+SLqFAQoFCFBjlVArFSsISCrztFBDz4R8BSUrEFAxrjymH1sNkoeolsyZS1RXTJMiJ 4ZWKHp0XmS63krRiixkukfrt4MFhm1RVZzNuFQMlnbuB7n6rl1pvTWOVlc+t0SH2fdZY1ejqhKhX Huo/bLNLq6y2us52H9hmNRWyslpTYrV11VZyuFTS0Vrrqeq1tH5WpP1b2uc1PNSnsxAFTIvFBQi8 uiXQt51WSYFvNwUCIx0Y1nAfaoA0E6NIkUGHCWXvXASFSBDdUIsYRdJFhhtmlF98ztceVHPzuYLG SsRXB6NemXqqLOpIvbLrgUXKa2QACelbbBfzLSUd1vjMFUAE8ABMRsY3htPmmC8qn/V1DVYtCSC0 IQwaADQBcLHNrmIoAIpRGvbIKoLPfgBtnSSvlIGLdI30DK25sP7SRiSLEQRQ5/LyCjce9G//9m8y UHVIKtKrBUSrHdwhHaXfsarMsTxvvrVJqrIHtKjWK0k1i2s9AqcBIKIii+MoIZHI+wDQJFKqzBLv F2gLSCTPOK7YnxvGVn6A5X0hetOP1D22gWd+gFLyiIATP+49vlRuhzlWR37EiWFn2jPEh26el8pG Irt9+3aXzFMvaEhYHC/eNsUDwpEuv2O+KG9diBVVtYNK9uhz/vRZIVFCm1GNzgoZ1y3tGY8DlGMo C9rrxtvFbOHdgFaBL0TIX0ri3mhoVorWAfMqFdSiz6Tc8dbvTPJO4iQUSCiQUKAQBRJwWog6Sdg7 SgG2mzpDkfmGF4kp4F+xrn6Q+6CY5gExwv0Cjl11dmTdLqsoqrCqchksEtO954VDMmpUYpNqJF0Q MO3X+ZIVMgZTdaLGGnSgfWdHtwCr9pQq/y4ZCymaW2SLVi2ywzsPW3fvUUt3UM6Qndh2xI7sPiq9 QqnFVaetclmZ1c+qsr7BE1Yhdb0SVAdlxKQIVSqvcZAkvaPESwo/vxRgTGbxxDDLMMmcr7lj505n qoMfUkDJ7BUOk6xIWsQYfe3COMIEkpZ7roWY7cLgNKtCOVpPOfyoCyqZqNFGP1T+KB8QADDAAiv1 AKQ40BQMIHf8sIqKVI+0SPY2bNhg1157rYOXtrY2m6O9tK2trR6PcxW7BbCWLVlmBw8ddOuxgHfK bpo5LUjElCd7uIpKpQadMQxFmdQn1ol6UDb+XGkDdeX+QnPQJYJp6geAp67sxfzqV79qh3R+7LZt 29zC7CoZqKIviPfJT35ShqJWSMpapn2eG52Oiy65ROrTTQ7oASO0e6TPlAb6sD8Th1EsymIxJNKL uKQhf/yKssZepBsUZHGAMUAcBz2eX6B5jEdZ5MWP9pEnfpShB/fnGX9crENMX+hKnsTH0QYsW6/X GcBImeOZptQL0B0ddcbPy4+eF8l1hG456gv9oEc+52EiMXMh0gRaQDccixMpndHLIlj2HKHMIeYM oDaPi31HcLy/GOmbp3mJd0KBhAIXCQVGuaSLpMJJNd8rFNDHWSDU5ada5sYaZ7FLjbR6jhRHxpHE GukLqqMTUjri4KgkM78UkNS/xqVN1ji/wY6mDlrtcI2VdMgAyQlJA9rF8Ipx26NzIg81HNExDCmb OmeqTZlRY4f3bLXq+VLdLUvb0RMHJemQdFbaaWVprTQrbcdAr01unWlHZSVzeMeQ1TRNsva+YzL5 q7yBzNpzCvhIFKbe/eMTKcWgpERIKFySJakEao0siLS3H7dv/d233KIp0jIHW0g1xCjC5PlxFTCJ +jnoi/diLCNIUERgrD9zPfkhMP5nTWUlU6ku1QVAIgX7g//9D2QArMsZ3FItsqAmyF426tnfwx5Z zTAkMAOSwYhZjlJhwCnnTPLjXElA1ze+8Q3PhzQcFcOZqJs3b3Z1VNZuvvnNv7bVq1bauuefs7c2 b/LjaD73+c974/pFAxjuAVllRfXUy9TCE7QCcAFaIiil3RHIFGLgifdOOvqX+kFL6s8z0ugllyzy 7uT4oQgCAffQbPny5a7W++EPf1iLZT1uzIh9lcrIDRU5DZAsSwoKjcpk8AZAOZCRkjJWhgU+cNnj i2cMLeUDGdGfvkvJmhtp1fkeP6X6U2FUjbFqK9mo+xdpvDuY1LiiHYCjkTJJIxfHfKSDe+b4E8Op B3kBfFkgQWUYcMVCSaQhcYlDXH6USTljHT6qccabxQ/dkr/PKt1nkmTDtECHMPc8vkc6Ne+JsCkQ +z5TwVMuudpEJPyxPB/mxuCIBgNjA7qFfFHNZi6F+R5pVKJ3DPOJhaB8Lle5kdaBPvlSJv4JBRIK JBSYOAok4HTiaJnkNKEU4AOqD7HEmm4MSYw1R72IzXB/FtlL0mVWd7zWSrbIqEq635bNu8Tatx6z 9mePW4lw48wSHfHSW2kH9xyxJp3xWNs41/o6pJI7a8iOdxyzhlmNMp8koNmlYwhKJXnd3GE22Wxq 11SbXFZnXX0nrPtIh/avCnzq+JjO413WX5G21klzrXpLpdXum2Ilk6vELEiaI8u+A5jr9+rlX/We UBIlmb0jFHAGUYxfZNp4dgZbnY9lTMDa7bff4UZvGA5ppBWK4z+NYFQKkW6kAV1itDmWCKaRcPKM jCtMJUw5vKS8dUVqlc1Oh+afKdOo3dGuqglofO6551Rbqb+LqcUBTDnj1BlZgRD3o36Z8LhHFgaY OBj08f2GqhxSLqzv7t692yWoSLoAXEhQV6xcYX/1375hc+c0e7qdMvrDcRYY6+k40eGGdABa5IkD BDmjLZqhilosM6I8RwATJXYeF8JcoC72Jf1He73+6mPaiYRrklSViYN08I/+6P+0j3zkHnvm6aft d7/4RdFwjZ/tSseTHtpHcEZfk86NASkMF0BHkHIyRuIYwqgSKtGUiQXenGrfyo8xOuKgqX5xTKUA tVowYKxmG96iDpRL3mgLMGZjH4UxG8Y7/jGvkTLG3MS+j+m9fRoHSJEB7YBTwvAnrxif51yO/cmK 7aqvMU2sO3Vzg1xKGPMiDj/qSvj5dpQV+5OyYh2zyx3bxkhDxs6b69+wHdu3u8Vv1PA5YxjDZEe0 z5h8Ucc+ceKE0+26665z2kXasr6LUb98jnIpK9aJa5TIRr98aRP/hAIJBRIKTBQFEnA6UZRM8jl/ FHCACmut1XCdM1o0rHMltX1mcmqG3TPzLtt5YpuvtFc0VVnR5FIZnJFV3VIBRTEpw0NlVjyr2Mq0 FF5RJHVf7UXVyX6WdskXUgYxi2K0VzdebV3D3QK1UpWqFADoHbZKqe4OTZUaGecOaq9OWr++UklB BlSXnb02r3++La9ZbeWltdanmaQTZiTd1e/8USLJeZwUgLGaKAejBxPHL+brkiOpdQ8Osr+w3Mcj 6ppBrc78uI29e/fZnFmztae5JmOp9binB3zBEJIuGrcB4HGPpVakSDCdAFOOihjrIuMa6zI2PD4P SUWdvCgHhjPCkpguMuYY/MIPIz7RwbjTXtQqAT3333+/15l8YIzZN0l9ueL3s5/9zC3vovaLFBWL vQAc1H+bmme75Fb4welTrKNVRhzgw9sKvADIB0AS6wbts12se7bfmd5HuhF/bD6EZYefaZ4xXqwn +TL0XNVSVUfDgnwB2YAI3H2fuNeefPJJHaOzzpYLkK1cdZmVa+xABxzxY/2yx5wHZsJjeYrs3sT3 PqYd8iHcQb+O1DrJUb+MR3abY3kAU1wEd5SPy45LvtGP60hddB/j41/IxfJiHJ75/eY3v3GLwYBU xlkEu5RPOdn1oOllWmDBBsHWzVt0LnCvLxbVakxy/i7jHgBHXwDqMICHZgP9wKISqubMt7hflz3a gXpQKFIp1rDwNdY/tj/OH+qM1Jwjk5gvvCPwY3zHNmWP9UgX8uFHnIPax/3iuhe8niwQrVu3zrUU 6O8XX3zRWlpaDENSzEXawpwnLUcYqXcKglNaRdxYX+qCVe64Bz3WJ1frqVviEgokFEgoMBEUyOIK JiK7JI+EAhNHAfaCwtmJDdE/jgyQ9FT/XEdL/hXF1fbVj/17GyoWgNTZgLBN4UxHGc+Q6hPGL9Ji BjmKokwfTmkCy4iRslRcfsPDMuoC+6F9WGmB3nh2GUxLul8SD6UtUrqhQe1HLZKUQPZ4h1ldBybL Qq+qYEO9JVaawgCO1CD5h9RpDP83cRRJchovBWCcCjFWZ5MvDBtqdZGpZG8XBkrU8xpgAehQHgAE qVda51g+9+xz9oPvf98aJVVtmdvijGlDQ4Pt27dPBnIO+97NuH9zp/asIjUCoP7+7/++M6TkR7k+ J8ZUNjKFp2uf2NsRJtjrBgjVP9LzG5vew2iQnNhiZ1phgGFcAQu0n3sAOI70/GBu7777bvfjz003 r3U6YFjJGWyPMyiwSq5KRx1GYnMTfZ2iCo0+J0UKD6p3QReyyBmFukR3SttVR/o1nztNqaGvPHnM Y5S+lEt59CcSaMAKlnC/9gf/wc8o5RWCYZsBhUNjfm4ER6Aq9le+egFoAZKkoRzKUOd69LzS03yZ vcP+jElAZBzfVCeO1Vg16IikFM0D9naX6oivnTv32Xe/912fKxjkQl36mWee0bybK7CGIalhqd+3 +yIL5+xCp1defdXed+ut9hXtCWY8E4c8UV8ej4v1pH7cM9+iBgAaBoBT+pyFHgBkBIPEpz6k4T7+ Yl8irX5ZlrSxpoxEGYDL+4J7QOjVV1/tktQDBw74WEJyCignf2Un9WvRSnnnc5Tn7zfFpw47tOcX 6f7KlSu9rHzpEv+EAgkFEgpMJAUScDqR1EzymjAKwNLx42Oa0q9YvxKt4mMQxj/8gFF9PN1ur6Sh fLzLpIKW1jEdMlEkwFip/aXaxyZGd7gI9UB98MWLlglklgp0woAMKr6iWgmWgAVa/aMtv1RaZTkM Vg2QhOmfq2ECSLUXrlT7UIelbljMcTbKKy1LlWIfrQzwCgMwYVRIMroQKYAq7hDWSTXmSrTvT6sX QVouZlYD0cco45SxCFNYKoM1JRqLLJJ06OxOmL3W1laDcQScbtu2zdXwqqurnem86667DOB6xRVX OHiBYSQfrNvmcoQzJ07nWNjBanWp5kBlWaWPcFRqmV+aJQEBjskEMOSOfd+gJj3DaFMmcy4bmAbJ XDjyg/pGBlvkkdPcZP4KoA4yXwTu2QdJPjhqz9zBZS6Ze6XxUH885Q91yOey88wVJ1N0Juhk+tHu XAsBMR+nxMkZxCCvLQsBdEnomxDE+yrmCR0AU5x7y1ExjANUoxcvXuygfVCLXeUCRg4UqIvoyT5C XCHQzDsM2vNz2qoO9AN0yqUSHmp24f4FZBd2sd9Qlw5jjmN3Lll0iR0QMJ06pdGqtQDAYhLWfxsm 19vt77/d9rXt8bHLAmatgN40Lba0zpvntK0QmGOupTTOfVqo03x++MjMHp35axb6PbOglJkrzBsk pTgkngBJruz/xtFPLP4QD0ce3oeZMPqQ5zq9J/bv22tNkmgy/6r0TJsPCpCSP7/9uiev+fPne74+ F5UPi7dDecYtZcb5BN2Zz4Dnozq/lnIjaCVe4hIKJBRIKHA+KZCA0/NJ3STv8VMAxk4/DFikBD79 OIsME416YrpIH2oB1KK02IaBwPS6VFRGlErEfA9rn6i+9fqokonYW/EUMOb8G+gnLSqSKR0n0y85 qJgagU4iDbMCryNhAmMty5ey9ouFy/7BIBklvEh5I9no7+vR6Tb6aCvPEpWbEmB1JiZyoONvfZLy AqYAqoAway7R0iBjnEWmjnGD4zmq08HUsf+SY0IWLVxkly6+1KUagFEACRJTjBQdOnTIvvSlL9nB gwcdlAJQYTBhQJGIlYppTkstM5QwhkCqT07/rGiAmshkUj/qxTNjNqpvZkU/6ZZmAW4AVKThRx4R hEZaxPyjhBXwCxgtFYjnrNMo1cvOnHyoewSn2WEY5CnUMsor6AoEx74i/WnzGVNIofgUORZU4Uca Xg0sdPm+SAEFJF+omr755pu+iAGYqKyqdmkaRfo+YI23QWmCsDeZfAC5+Rz9AT0ZM9yTgGfqA6kK JM2X5QXtT3toV5RKMqbpV+ZOvVTJW1ta3EjZnR+801Wn57XOE3irtOaZs3xBaOPmTdYoYPfVr3zF jmnvNJRFkl0pgBcXW8ZLgDhGyId6+ThX3eiX6BeBKOH0EeOB+sfxE/PAj/T8Wue12sIF873h+BOH 9PMXLPR92szTRZPqve+Zc3zz+NYRd1jfMWWet0nEwcU8uVIXxhN1juG5Moh1zRWGX6G0+dIk/gkF Egq8NymQgNP3Zr9fBK3mI6kPoy78hE6lostHVUyxPAYEUGHYq+SHVCotwCjxgqKJIdMzcQARSElh kHEugdXzrn17bNPWTXa865jSpa1l3mKttC+xMoWlkCRpVgwLyA45mBUDqbIHtd+0RB99dqwKLVMN 7eER0NUmU/7JbK8+4LrKX/8T9y6mAEwWDBtMJkyh2H9/jowmYZGpQ73umWefdiNJSEr6ZDQLlULS YhQIYArYIAz1XqQ7SFfZLwZYBeDu87NC6+yaa6+zSQ2TR8bz2ZIYxhbuOzLJ7LWjrrTndIwngMoT 6y9ti4wm7Yj5UR/8CQ/7+QJDXlRBHEmFdMRTTBvTxTRcczsmP7/cjvzyOU+ZP3ikDdnpR/JTYrdU mx045j7SYIy3Pwoi+TXSw6/4iA4A0xMdJxyUAkwxXoOa9J49e1yNder0aT5eWLzw+mghDXqRRxhv nnXOP3pjuj/qwpHGLAz0pjmCpQAxcuZ2cXhCE2jDOHzllVeCmvyM6dan48EOHDxgCwT4UaUlvEwA 6/iRozZLe0sBoUu0UMQ82y/ai9j2kM6h3SFV1sWyrMz+aB+vY8ZfHI2FqBn7nfmV/V6IfUid6R9c dp9yz1zM5aiLp9G1P7NARpswIuZVhAbex/pKKR/8BzXeMMhF2/w7qLEnYuXK/hQ/6k7+caGDuvMb rxuZW+PNoEC6c6lXgWyToIQCCQXeIQrkfgu+Q5VJik0oECnA/k8+tC6ElDot0tJBAU72gPqXWBJT pDBAgyKXjDqiVArtZZMIFf/y0nKrLpbREYHOdLHUePXBLpMUtEiS0e6OdnvsN7+WcZaZtqB1sVWJ IaiuLpPlSanO8bFHmjogiamkPhhPYjUa0c6Q9ulJ4OEfbT6ISHRL5I9aL9LYINUY/wdcBSfuQqeA +LvIuDEG2MsHQwnjCCPHHi9nSqUSvnXrFknFNjiziJQewPHUE7918FFRUSnV3mvtwQcfFCjp0z7N D3vLt27ZKvXDyQ5MAauviuF2aYnOvGyQmiJ74QI3Wog9PpWI1JV/1BPQjBEe6goDenoXJK2RoSYN bcRFpjMy2fE5MIyaCyz6aJ4EgJsp6UymCHH8BZA/8kl5ZrKOF5e5ngGJqG+oa0yp/pVfkFOO+mXf eVv9XRR8vaq6jVcpe3iexPOf6DUMYBCpe3TeMsZpjh075oZmAEFlAu5dJzrdinLb3jY3/oP0L9YN VU3GFi7S1x9O+qO3nyTrhBOXclmAQC4d+yJ/2pMyumge0IyhbRUV5b730q1Ad3boyKIX3AjSq6++ bFUC6mgr7BToPCHp6P/853+xefPn2fvf/343VPbUU0/ZlVKhr588xR76xc/d7+577rE1a64VDenR 2KuQJfv+zMhE/bLpzhxCswBHHxGOH1feI8wr7nHxSnp+PPPjnnjkE/PAj3x4JszTZPLDD+fTQfHy OU+TFR6fme+A7Djn86V/p/yp53hdpPF40yfpEgokFJh4CiTgdOJpmuQ4ERSQmmxgLsVaCUwOSo03 LUaEfael+lCWYcAI1V3tJ+0r1iq0Dq5HMprSR9hlmWKGe3t7bH/bDutJd9pAeTiaApXc+uo6u+uD t1lfutuWrVplLbNbbO+OzZYq18pzsSz5sidO4tP62qlWUyf1KElXWXXWDkN9/Pnoq2YCymnVkb2w xTDfkrIiEcEYZmArzp4I5/KR9DKzCg7f6lEPaDnKWI36Z9iVs6/shZICJo7GZjeJkSM/vFjAgGFz xkpXmD+OdoGpc4CleEgYwEAsiCBYIL+ebqlskwOZjCUd3ioXFVf2n9bI+u4WgVD8HAxoDJRoPFZV VgmENlpLy3zP4vCRw17utdessUoB0/r6STZl8lS75eb32W+feEJq4gN2zTXXWvOsua6WuHv3LuVf ahXllTavtVXqh1MFYip9LxxnWyInCY5KnsZ5fQODyVE3GIfZoiNlyrHkqTnje+zU7nwOtVKIEZlV ogI4s104S1Pbt8XEQucYF/6eo08ATJFpZr+uqO7J8457pz1/8rcvb9pMKk3PvG6U0c6VP2NBY4PU MZgH7uOVsGyX8fcydc/QDD+9O9ReHiI4nTptqvYMNqlf5/kCAeMNaeeSpUts67atkqoett4+DLEh FWNcaR8kAEP5siCWy1Fb1XqkL7HYymJIVMXOlSbbLzYz2+9M72n6O+EQ6LOdoqy0UvNjhs1pbnHN g77GXuvu7LZVK7V4qLG3Ytlym6swFgZuvGmtS0crq2oFQC+RlkKDjAjNs7Y9bbZ06TJrUZ+sXLFa /THJz5BlS0daC03qiKwm0gfZz1lBY27jmPcxkAnj6KYI9ng/Rcecif1M9ryDMqNw5J4xH8EscWMa f58xXrJcLJMrczK/A/Rq7qI+rvGVXWf8meuxzPx5jA3JTIiMN/WmrufTUQbvdn4sBvJOYjGvWAvY vkAGPeET5C8Pt+g89h0Se/V0NSXe6eKcz7a+O/MO1I9jnjbG/vD2+mJUaLmPpZEX/EmxQoSz+hv4 BdeW8U7Nld9ob2diewm5Yp5V0UnknBQo9LbKmSDxTChwphTgpR8ZwPgB4Bo/UNn3p+aZmfLi5ngl pACCsLMZzi8wwgrRhx2N3mFJS4GzxEb9tlwSg03bNtq/PfCgzZ7XLDXggcA0K6xOYEKoVsxfvwOC Des32JYtG2WJV+WUhHLT2pc6IIu993zko1ZWWRGqB4Mu9OJWHHXFyAZ79QKICWpTI+/KUxt0Tj7x teg0FRj2MpUjjATHJyB5iX4UFOhNW0gZGZzR5+gfrqQ4Ty7TjXlzjw3LG6FQAAxHkCYEnifTVpgO 9S0ArlvGRo4ePSK1yWnWc6Ld93O2tLTadgEAVGc5m7azp1tGgoqtV0Zouju7NC767EbtD63ycQL1 kEYFaQbloS7epWMtoCoGaOa0zLHn1j2vPWvHlKbOjh7psSOH+m2bztw9fkz5dldKjXCaLVq0yvbu 2WdXrLrFTrSrHJU9MNBn99z9ebv33i/aL3/5CxlHOuZMdvVzqJcAACAASURBVHFxjfX2H7Drb/iA Taqts0OHj9prr+62Sbu6BWrrrGnmNNUJ5VEZJ+L8IgeqIrbqk7NPVW9UbQGhtZO0OCMpLWOHccIP xjPOy1wUd4CjMc94J16Iq7J0j4OZYHGG4lnIQZU0MtkOYhWPcmIZfs0kD2M1V6lZfrFZY64O1EK3 h2afFJ49I7LyytyerlxSe+vIEzemHN5ttJe9oIwJ2g2gJXpk7odhhD1toI8iuabH3j17NTa7ZYxH AAhpp9QxeHdNbtSRKRq7lyHJ08IYUk/gBv0GwGDvYCZHcj3JhbryHgrvXeLDoJOGhYDTtfekzN7u Bx9XGr66QjCno2jJOAJcsngEsVnUCE6RGE8yQycDvLZx1z7r6erTOmKtdXZ02eWrr9Yc69D867QZ ssjbrzk9OFhj9Q3D9vH7vmBoJzz77IvKe7bNnHWZQJnyTlXb//bVr9lu5XX8SL89/cQWzZlimz5b i0iNFeoJLQhRP5VKNURWH/6RrmE8EB4c/jEs+nHFj+8YfcK3qn8os8/U56P62NuqvOlr+aESzwKS j3Ufk97TPpcoMwLQmHc2iOQeFxeLmMcq3tN6PTLzFz/yEoZTCaHe4Rur+qhC/JjfQZLsWZ7yhznt YzST56COYEPjiHLCImHYextpEt8F2W0gjGcc9zGue5Cv1zOMcfwYJzhPp/tijZe2tt22W7/lS5Zb d1enVddU+5X3bXEZak+m9+lh7YHvd6vokJsyoQF968CVstXJzCXqSf7ZbaNUDNyhNp3tiJepkrxP DsuOl9znoIB4Pd+Prz4oEn8GzwcFMQeC5hwnJCB6wAYIGmwpFh0wQikGkCGT0nEM8lUKzQn99Tvv Ar7goR/9W6SQtN7V9BNxJPJQudo6oTFeLD4yxTmFCvCtYUrv71vGgP4xBsRx+tyVwREFaiwSQkaJ m1AKJOB0QsmZZJZNgfhSx4+XP8yqf0R0P/ZDlp3O7/Wi4IPsLvOC8M+s7ocUNsy5MLxd+Ih4tPAC 4i3FqnSZ4nVqX1d7b4fdf8st/iHCMAsf/BIxgkgp+vr1MlPaBYsvsbopDXrFqJ7Kkn1JR7UX7F9/ +lMxPDKOIekSqsP+JtNbT681vaRC8bwInfHTy1FVOScXP9a5MuHdp2b7x5AXIS/Z8HItsvVvrLe3 Nr0lVcHRFXheudA6uvC5j0+6EkSmHiUfu5sVv8DtaCkFIuUJog0FXYHMkcb5GFNnEI3xFZiMYWtq muFSkLc2rLfXXnvN93RSFEdG7G1rswd++EO3hvu6wmp0DMMbomFtbY0tXbbUJgkwaPC5Fc3YJw60 lJ7zEGfOmm1XXHWVDNgUS8IajKdcfsXl9qzOqbz5pveLoSmzxx5bJ3CshRABjFkzl1pzc6PybrE3 q7bZWxu2aQxWivGusVQZxrcqtfdU4UuvkcXNYwKtQ9bZecJaW5fbwkXL/eO4Y9dxE59le/fu1RjY Ydetudya507ThxnGFuM3dGXY4+mrLLmIKgJoVKht+lBrnjhp1QH8cwpmjZdTkiueB3MlMMaNV3KG I5CDzmmBAR+geGCpbNyO3Lzio+MVLypx2iuRvLa6js/FYkgd77k6kwLRuRcNGCcOqDL0AHrgoC1j B+aceYu0jHtUSBtSjf4c1MI5qsq7xlpa5/s7rFPS1LEue05n1wdS4CgPR9iIExNH/fhlp4/hMW18 fruvvsAH0ye6UEdoyxjl17Zzlx0/eszK9A7m3FIAA2M3zvOSkgrbveOQPfrosza5vtEqJClunbPU 5sy+xCoWVtoLz79m+/Z2yghSuZWUNVh1lRjboXJrnnOJHTvK3t+wuNfeccyWrbhGIHSm1K2HrG3X AQHaIduw4XVbsrzJbrvzCvVVr8pmnIttEuNchF2DDCMLzbJpSxuoY6R7pCn+9I23lSZqbPBeB3iG /lGgOsTzUvtZ+KA3w/te/Qdd9JEinPw9v8x9LD9eCSNPHH7xXqXKJ4vWehKsCwx/KM7jMm5Jzm9Y H8qgQs8DCfhzsqO84CiTNw3vmdA2TyNfwDJzABfr7g/6E9of6hnbF9+7vn8284IhHotBOL4BVBA6 UiO1yo4dPmK/evgRO7j3gD3yyCP2sY/eY7969BGr1nse0MqZtxwh1CRLyXOamzUXUZ9XYlU2TF/V 3KevV97bEWkZ2+hvz1NJQJWc1oFI5EnG7x03OsbOts2MFjmNq7jX38Ep9POO1ddNGnQDGmPFAqcs 6uiwBPFvmgfMHc1DxhrTY1iL95oceofKT4l9YYVsmAP6xwkQKsjtjbAfWzlokVnq9PrmA1A1rfUc FiaGeSC+BgR8nzsWhRl+AsV+7njGOwQmfyeKAgk4nShKJvmcQoHsF1X8YMYPKi/5yGDEhNnx8QNI BhdZLjyDT8hPL44Rp3t/kYWPIuEcLTBNBmewlOrn5WU+9oRxoDtGIwb0ApvcOEVMjawz6kOHNJQX FKqPGCmhTr46q7SkYyW4yF9uIwX7jVdLfzCohHrohLtMPVQFOZiiQVcHxJjKyy+/ZIePHdaxFHPc MmqgTYgX63EqL5FNO+g7/jqPlhdLO/Pr2D4/85R092idIxODhAD10X7tHWZ8YVyI/ZWdnZ0CiM2e Bsu4GB/64QMP+FEJh3VUQpsMoixZcqlUXbfYJB2fQFzyhJGCUj4GVB4lbhDgfUFnDa6VeuCKFSsV Z0B7B5dob+lmz3fmrOm2afN6nZt4l82fN08VlRp6OVZAu216U4OMGq3SGCr1IyD4cFZUSjqkrdGX CrwuurTVGaSBgV59RPURTEm1U+Ny9ZWL9TEstaOHO+35deskDT5orfOmu7S3iBVjxiefz+yxmX2v ehMe3dn2WTatYx7Z1+z8RkZWGKzeD9lxz+o+Zha7esxVLAQNCy7nNXqeWupp26QkFBdziPdcGVuk Z4zAGKNGyDM/ABQ/GPEBjQ0vB2YXeujHu2+Ave3KiHskVIwvxpouLvFX7CxHidQjpM8KGKlbrKPH yY6QuY/943XJEf5OeiGRK5b6OrSEDtCWsz9RkV99+Wot9DzmR+3ccccdDjB4l0M32kTaEwKWPT0n 7KaPfEiSM5jKAWm7qB9SfVKTblG+sj8gcJvSPCyWZkyNJGl9UqG/9vpVCiuRVE3zJ9WjM037pRFx VOcLS1Ja36QjaCqss2u/FqA6tBWgX3VDtRWmV0yuf5u4AlJVluoS30HQmDac1oVuPSUaecXvI1d+ 7A2Pfecq8vpuAdDiOCQN4TEOmUY/rvGe8TUoFWUkoLwrqbOHaTCG7SynVOesPEJ9oIXUiDX++e6w JQBwzcJesRaGccSLbeM51ptrrG/0dz89MM+iBNj9qLvyKVOeKmpkrrUfb5fU/ITt0sLGW2+9aX/7 t4fU3+pfRdq4aZNvkWAMHZZGzS233KzF55kCKnrXy3YA9IGuHN3kkmrVH8k1b37K5Ee9/aryU5LU 4qgzDn9cfPaH5M8ZUEB0Ewmhc3QuLfXlBi1qaNuUaVHINQ4kSi3XiQxITQc1wACSLK6kBDABnpxb z7gAmpJHCfMeKYT6DVTJAoYvtFCkngeH2cIjrQv1YVo/cYABiDJ4tZ2MExo8XbGOgcr0/5CkuMPS WAJIOzge862NbUiu46dAAk7HT7sk5WkowEs8fqRHXugZPxi3sS/w7Of4IThNER4cPwgjcfUh5CPm 6lAqD/P8ABbqoINPnZEslxpstdQ6KwVKcexDHPSPp155Yjb4eMEgkTd1dSZUHzBen5nvkKfjT3b5 KoE3Hn9P8nePc/jjtPEPX8hbhSg3vVL10a3W0RMrVq6wVZevcjU+4hI6+prXvT6wJzs98/L1l2r4 6J4cfuZP2f2WK1U2fXKFj9ePPqWfcXGsMd6oD2EAhlXaU9zU1OTnCSIt55kD7JcuXaq9fdtsma4c 3QIjzJl+O2Q0BSueN9x4o58XSF5xDFAOebbt3WMvvfyKPf744zJgs844l5SFgRtvXGsP/+KXYm4n aw/p49Y0+9M2e06F1DfFbA6zb61PapzlMnZULNDcJRXeV1y6H9RtNTD1oSxR/g2yyNui/IqcYUey OmB1lWWS6JerTiW2s61GeVSKYZVxnR7UFZFwZKTI3vPUFJc9AgJDGPzP/m+hPoY+56uPQxPGjt3R +vuiwehjjruTaZAdoVCbiBdTxmu2X1T5y2aYXXrD3MuMmTRMrhLDAA0MBOusroFB3sIuaHgwXlEd pQz8PO1IyZQY0oe7d+ffOH7itwIaMK95vvPOO23WrFluxfqb3/ymsY/2mmuu8TDAfElpkU2eUm3T ZtRqrlU5cOzpbRfY6FQe0lwoE2qRyt4+WWjnh+TTVdTF2JYIaAKa2BNeV1ejV6GY0yH2/uqdr32s 1bUmw0kN1tXTKQAjybbqFb5j6mP1HfUsLhFYdfAVACltie8i/96Ms8toO++asGAhaaCMZ7Gg5jTS 9wkwNRacUp7XSd8rXJyTkb6hboPah1zpe+FjPSNA9f3y0nIYb71JRxmAdcY9QIP68EpiDgSpaXhn x7rhB8BXBC+Xme6wXhn4e03PfFOJz8IxeZGvf5N1T5n7Zc0cY2P1MiCmbnUQ3Nra6guHM2ZMtc7u Trvi8st9DJHntGnT7LgMYwFOMTpG2m4tXpZrMQKJNl95qs0CRCxTRXp9oH+wK6Ba0ciMi+3x9sov Psfw98L1XNuskSPCa8yIrIEtYTQAADUmULsdknE3zbUSXpQaCISG96gWsoq0uouaLdATcMr4874U D8p06NP71z31PWfe0r9KzFaMYgFQRVCfa8ylyCe8M9KDWtAgHwUX67SGYS0oY+hOS11iIzlGUOry GhgS6CbuPFAgAafngahJloECvKwC4xw+3Hxo+ZjE1c/4URwPvfgI8Mv1QuT9ET8SfEyIw8cMxwcf MPLMM8/Yb37zG9u5a5ex0rpixQpX9QXUYFzJP5pKR31jPfFzCRVvxTyO71UMzle/PElP6x0//kSM NNSr089C5COKUSa+5Hy8s2ngGfvbfrQIooYvAPFV41jp0ShnfseXPI8jJPZFrii5+i9XvFx+9C15 M668bzJjItKdxQUAZ2Njoy80EO8SWbxlDLS2ttr111/v6elf6EnfMw5IT1qukc5xHBOnSSphH77r g7Z583apVL9l/+MfvutWV2+99WZbvmyJrO/+xJ544mH7h/9vht1///02f/4C6+/pUj/x0dOXTETp 7+vSyv5WjcUDLhUJ+QMgU1I5nG2zmhp9PPLxVEX0kRwSQ3VQR108ag8//LAtWjzfPvvZT0s1bbq0 APr0wWWOseBDx2Z+DMYsFz7nWR5ncXsu/UTbzs3lH1/QK7+LtMgd43RtginK5xh7Lh3i/cK4ExCl Kv2SvpTKEi/gFZVMJEWh/T4T3K/E9+Nq0UFkYd+aVsV8+g3r6u+rwJ77+KP8MJvz1eRk/zHT/ORA 8hozJk6J8A54iHyikeaF6kb7nQa6h27MWcAo8/aFF16QbYAtfmVBaJmMHO3Z02Y//OEP7KmnnpbF XrPb77hF84bFRKmVixhDkrIMSyXvyOE27TPfqP7p834qLubor7S0F6TiKWBbUy2GV3NMXad3qKSk RX22cf12e/BffyjNi73aAnLIbrrpRr0PJCH3hT5etNQRQ0nqoQxdufLO4F09Xhfz8m+RvjkA03XS luCdhDZPn6S4SCEph3cZZREXevHOAjzFPLLrgF+3tiH0ydDW6tXaFtAcNIr82yhGHVoD3s/FUT5N p07kS19yHJbXTeOdOcV45spZ4QAEvqlOL6V1yTn++kdM8gPYFmmhwffAKu6ANhmTb60WFF58fp39 q6ydz9QCJLRBk+j11193bal1Lzyr82AX2kc/eo/TZMuWzbZy5Uq9m5/Qol6vTdI5uH//9/+v70m+ 5eZbvC87Ojo1JwO4YQ6n9K7HpgOSa+gNqGXxkjrVaftHpewSZFMMGlPn95LLNdbG037NfqaULw6I iJq+or+oy0iApCUCjSUYttLJCwO+8Ie2irQKtI8YmyMsGLmqrVBjmX4ptFYEPH2PqN6zGK7k+0g0 xlKvwtHYKNUCVzqt9zksYkoaCoM6317vjTLVJKUxwDgolcG1PhnhTMsOSbkWiWWWUHNQ4Q6eqWHi JpoCCTidaIom+Y1QIL6keXnx8YkfLD5UfFxw2S+27HvCYnruxzrijo0/Ng6MYSyXMD6WP9U+0k1S 7UFi9pnPfEbMYrEfQQBQvffeewUkwn4vPpLkzweJuiJVRZ2Le1f3UX7hA6p6Zl6gSuAqJtn1oA2n q2d2/EL3MR+u0BBHm2AqvJ16Yce9OIQVop+DUyLJORsACDrpM+tB5/yHuhaqh4ILukLf+UgHaEAZ 9E0sz/tMNEICHhk4wqAVTB4u9g20Q7pOX3NkR8yHODB9pMMvtIPelr/2Ky/UWGmdu8A2Ltjs6sDf /tbfSjraa+teeE6S2QXam9pg//2/f90+8clP2fVr1gTmT2ut7H2u0d64K7VPlfaXlsqYlTIl/15Z E62vr7UK9IDlxwebYzKOHz9q3/r232q/7H6N23vt1ddetG/85Z/bl3/vS7IsukJMZy8ZqJ4AYIga 5hdtCE6LLPF2HFfan89R70Cb3DHon/E7qM1vPM5Hdt6E9Gs+FyiYP5w6IWlDddHfBGJ+GEfl9KX+ IbVjYQHmajCj2gtDhJGuLklpqjXOYLQAZfgzb10NktwQB8iR/4hjgLijTvE+45V1CSv7WR5jbgv1 45iopzwW6uNCtDwlozEegBPew+QR32tEYdzgBxjAeNltt93mUrL1Oh/46aef1n7CR7Wf/A1beuky +3e//2V76KGf2XPPP2b/6T/9R+0f19E7mutYT0erYPElCwVCptJVPs/TkmSziIBKH2q+TBvmGuq7 7D1/6smn7Dvf+Z7AzOUyjnalff/737XNmzbb7335f3EbBH39Ui2mf3zvaegv6k59R98VYxp6No+Z LiY/3mG8hxYuXGhzZWUbg21sSQn7UbOBYLEDT953pBvbX9SrQ3YY1q9/w7c7jA336p00tE56OG3t eX+SJ8a7ouMorA0bNrhl6tWrVkN+7RfU9zQTh/nh/a/6Ipn2vbgkVtEuxVQ7AbFIuakN0kxf/FFc vtGHDx2UBspWmy7r15s2bfR3/YD6EL+9bXvsUi1qAC6PtR/18BkzZthLL73s3/zjx45rS0WFrV27 1m6QAbxfP/Rrl6SqEJUfAHPp5SUOrqEpIHuXFrPRrqHOGFS668N3a8tGOI4r0hPaRxf94vO77Zrd 1nNtWxhtcFWi/8i7L/PVoj/0b1inLnSVHmFwSPqpeat4KY4alCwTTTnpG6jv9N7QvCzW6QsMpCHt EUX110qxTC8eQN58IrFM3SfVf9TCUyV692hcpqWlxIkQOgBCIJhFQ70n0gKrjFwZyVQ0DAfoK66S 9H7q1/nRKb3HT3pXnyshkvROgQScJgPhvFGAF1f2hzqqw/DCJoyPWSFX6MWe66U46seqbViFowzK xa1fv94Pvn/f+95nS3TIOsYzYB8PHzrk5wuyOo0KaGPjZDuuj3iJ0hWJgSnWx61YV15mrKryEoxu tEz5qE1DYiJYaZtoRzmA4n6tGgcwxksbqS7AVMBZV+Lwi3TLrpvW1HNUSW9af1HDaPPWPQ/Oiy2Q d65qZVejQNIIeQCctDleI1iNiyCAUcbAUe0t/clPfiJjGNqrKYaPvafsRY1nfaLi9dnPftbpSxWg X2SWGcdOWxHMV/L13NNLX5e4VAfVw6LfFtmf/fl/ljSzUWcq7lI+Zlddfbk98MC/SCK7NIBQ9ZXY M9Wn2H78kx/KWNJsu+++Tzk4pow///P/n703Ac+zuu59l+bZsibPxvI8YWyMbQYDFjbYGMjAkJAE +gSSJmlomranNz3tuU+b2/Sce3Kf2/ace07aNLRJ26cNUwhjAgkEcLAxNtiMNp7neZItWdY83P9v 7W9Ln4Uky7Jlk6Btf/re7333u4e11157TXvt79iNNy1090X2Radqbw3n8r7x5htiirbrLNRP28pV y23cuDFi8Brt5ZdfdoWKuu/Wu1bdc7ckFvjTxlwZNCf6miJOdfd+Mq51l6dv90GQ7pGk53aBPN0j UE/v8pYzJN00mnfBs0bNdccL/UY4JUFzVr6+yt7R+bRYarD4gYPgJ8oPhK0lS5bY3LlzNe6NwrEw b1WAv0/wme4S9fYE62SlU1dl9NTnrvJfiHsIIbQLgSVDsMMi7WPerFHwoZe1TPRNHbdBRYNtwaKF NnLrVvunBx+0TZs2SfAZYW+8sdrmXztfgtB79uSTz9oXvvA5q6+DumNxy5D7fK0srE/Zpz79Se05 HONjtWkz+xG/b//Hn3xL9Ya5np6WJfffg/bmmtV26YzJcoHNsNdXr7DPfOZOCb/PaVyXW0VFhdNh Z2gZf/2L6xxjE2kG+NFVArewCrEfLn54z/EogesIYW5RJI/+ZeVk2eCSwTraLN+ymhU5WPCKXgPg XRxXXHZVVEiUyb/EDdqTKStTgQIDkWKbeT8qXJW9Heaeyf90P/868oQrymoVniNAbpUwv3r1KkMg 3KJxOllVJetzhZQGYbuM14sgLbLkrtaqO0QTVnuEEzxHUcN1i6zcCADgCvMLGDcoEvsw0fI777hd VvRLRWefkMtumQLaKWK6XKCL9I0wWaV62cJTXFJsq6U4nDFjuqzxV/o4x60eWOQJsnOF3MbrZVUl SB5j8PrqN+yHP/yhz1uU2VfIPRgFwRHxDC9LoR2FbHrv46dxGUhnDwGHmqycPptExPjnih/gKgER 9/0Tp6rsxy/8i71VvcLS87MtXZG500QjhB2aNYE+uNVb77dJAZyeJTdcWVQRXSmLQEltaO80H3DJ 5RjCJgUUzJBFNKM5S2VI0a81kvUdnGyW90QqAu/BVPvsgs/atZcvCPUJLymyVabWdLn7yr/j7Ds8 8MYZIdCzdHDG1wcyDECgZwhAsGHKWBhZZEjcw/WGKKo8i4tnfBa/Y35+d068k/xefM49mLscLXrs RXnv/fX24x//2Ot//vnn5c40266cf53VVh33oEiKC+Fun2ilv/KVr7gAM0ZHgxyR6+9aBb3Jyc0J 7pUsuvpgmcK1KyxBYhQhoqpTlfpz9iqWyY2UfsUE49BVW+Pz3nxTBtryAEfV58JHwh1Ov0K/e1NS ch56oTHhyzWVlHueUz8USQsdnlpEwKGf//znLmACG+4zTiTwh3swEBwthHKC/OPGjXOhFE34W2+9 pSNeJtk111zje1AffvhhV2B0xtfIcDqo1Kew1xHxJVg9OdP06LEjsnA0umD6waYd9v3vP2iLFlW4 G9n3vvc917y3cT4vrkU6ZmHtW2/IojNNdc8XUzXMLRrvvPu27du/21799SvKA2NG+c3C47fFTO1X X39mP/rX/7AF110j17URshBsFR7XCSflhISZyPGCeQbg+R1goQsxwmH+cX226Uz4G5njrsrt6VlX +U+/B8T59CUBAz5dp576xFs9CaeU6Eyz5mQsBxzBVfBaCUkwtDDG7EtGyUDasGGDffrTn3bmmiBd dWKuf6qgXHv27HHc4H3KxNLXOSXDMNbXOQ+/zyScxrnR1bsX815cBxA8fI7RF81b+u3rQILGkg8r FlbD7Tt2WJmiXD//i1/Yug3r7NalN+ts4SzBfJkC4tS4dRAuFA+aE9q68f7779nkSZNtbHm5C5dY Xtet+8D+8R//WUJbHtyqXO/lAlx5SC77Gz2i6ztvr7O33n3Pvv7VL4l2vGtV1celdFjrSoU25pPa hVUTge+BBx5oX896GqMOOHeP195v9dHhIdqMFZ7gWljrGqSgJOJ8qwYb2Bw6dNB+8pPH3eX5hhtu sKVLl4b3nA5GaALP4CaNogTY0kY+jscw81rX5NPYLlyHedd9Gzv60XFFWVilJNdJ8TbCrrv2OlfO XH311YntC4EXQFnIWNLP5HYwV6IyEQUi84lATXU6dokxJz/wTpfwW6BNweNFy6dOnexj/OUvf8nW rF1r+YotMOPz99iKl38lYb7A40ogoE6SFbVBfZ8jHqC0pNT369NyFEbr3l9nq+QavkrbfWgPwbeg t1u379AZuBNcIH3iiSd8bUCBSeIM4c6Jd2njxyHR1/OVKIl1ke9QKnRQOKt//lvK3Jrqk7Zs0yu2 c/gmy87It+ajclM/Um95soji3puZpbku40HtqXqNaY6dkhdSfqGOlhLuDNJxbAePHIVoy9ggl91B GXaqrdoKSvOs8Wid1e2rsyHFw+W622zH6nWcW3mZNRcqYGZNgx3fetjGjym3mVNnWIGOeGMeEg8C bw9wcyD1DwQGhNP+getAqQkIdDBcQaMMQYO5QCgoKSlxV6XIMCUvVNyL97sCZs8LgDTwYhwQSoYN O+paVRZCrKJocU9Vn5DWS4IejJC09CyCROf9xje+oe8iuVUW2mAtimhTR2iBxbLG+1BLtNloc5MX IdrCYrt69Wp75+23DQbBhaIkxpU+JL/TVZ/OfI89RZQT3JVhBDJk1fVzTqUR108lmA6+O9robdfC 7ouJGLCO5IX5T1wRf9MSZ0MeV1TGq+Zf627adDwsbKxBMI4wZLiNBU38EkXuXf3GG9J6H7bRI0fJ Yn5UmvC5IUrv1m1a0PLtk5/89Gl45+XpTzK/AXw51J2Il1hlsGbv3r3HXvjli87Y3X333Xai6oSY Mx1XMHyomJwj9nkxSzBBbWIoWdAIcnTPvXcLt7L9fn19nQK/DLe/+7u/0bOghID5zNBRGbgWLVs2 XJ9lOhP1DjGjx1T2cOFqoY0adYnd/+WvyWIP44mg1CHYEAkYfIguUmGZTx7/CzPiPc/VMC+6bwl9 6CtuMno+gt0X390TVcle0jOlSLPIxzXCRKHOkf3iF7/oSgloDvSDI4DuuOMOv0ZJQlAumNvFixe7 1Zw80MpQXscYnqn+zs/bkAp6SGcaix5eDfSjmwznEj/u4wAAIABJREFUUi5Fhn53tD2ZVgIX4OqC j2AMbcX6jEIId+iST5baS6/8SgLFYrnXb7YZl11qd3/hXqvTcUwoEzkTUWRA76UK7gWCd73Whmad d/oZVxaIPGgdwFKnY8Sy02Rpq9S+8Sd8v/rUqdNV3jRbsvRGBUY6Idq+0BZU3KQ95HKtVX4CmGFF e/TRR4PQpHYmC35cx75FhRf02OkSOAbNCgQ7vKfxi1sznIYJNh5PQHnifQLCcMYjbrB4Q6Tp90nR wX179tqRQ4d9Tyz3QH3q5sN6ByywPJJinRHONAHhlX23fU3QWQ8gpDqoi/3+4PWzzzxjJVpfi7Xe Ez0deKGQwVWb+RHgEWj0Cy+84G7APOM+yuR1cuPGawka6fASjKDfn/jEJ6R0zLLUuhDdGQUBiuFf SFnx+JNP2aSJE1xQPynvmPXrN1h5+TiV2SR6fMjKpAzMzg4wrVcU9XzRZvAMvuTmmxbbzu2KJ6Co 7J+8/Xb7wT//yHYLtr/3ta/YI4886keQEVRJgHW8jPAEzvGa7zjufrOLPzF/F48+0rci7pzPRnrM BPEmqRxaL2TUFlBtHxWOCx/hTdLTZf+Um219jqyZE7T/d3C2nTx6ynZtPaBAgdpjrQhHBCIkKvfu D/a5Rb2yptLGTi6w/euPWvaMHNu386ClDE6xYaOH6b3dVnZNiaVPzLO9yzRnaltt0hX5tl3vHpAw mjE917Ivz7XmU4pFsV0eMjmqX22Sjkj6LtEKtQvPJdipdq+D8wmQgbLkXzaQBiDQzxDoipihHcU9 BnecyJRFYs6iHBf17prWI2EXBcnXXhIW3MOHj7hrHQIozIEvhFqEeBjroH0spCx2pHQRH845xbpL dEgWSvhj8iPQwljwDm2I7UA45aB3tGqRmequ7X29T524GlE+Aj4frqmTfuHmxT1nvrSYIzhFF9Su 3XY7mMG+tulivud7ytR/FA6jdVyQj4caFBmwiFe00S0QGq9ROiIGzTuW1Aa5b4ETMFBXX6NAGLpG KeFMcBcdi9CinsA4tuncvN0KmvKEysu2O+/6tCJGDrZt23baHbffIQZstyxjz9h9933RxpZPUIm4 m+OmyxjK/ZaFVyseTDF8TZpC1RcOztdztrUIx9wKGlzxFi26Sfi40Z5+6nn7gwf+yB5/4icSVl+z //k//059H2tNssKpQC8nNB0c5VaHZrcn4TQZl8P7p/+NjPLpd3v3K86R7nJ3RR868sLwBaav415v rxwAvc18ej5V2ZNw2lWfIk0A766XBwW0A7zjPvMTPIMOLVy4MGERanYXc2Ab4cu7KJZ6Sj3BK7By 3b/d07vdvxWe9PRuV/A4U3ldPk8e6jjhlDHiJ/TN6bDmKsdF/ff/9l2bPWuOffn+r9pPn3hYx8pU yTX+vypoWYk1Fw9iEJ2hJF5A3JIR6ULRYJ1v6Uo8lAFhzWFuovjB5f/hhx4xLH733HOvrKt/r8i9 YyTsLNEcHSJlkNYPtS8zK9OVS9B/2gWM+MT2Jt8DB6AxfMiDUpFxJ2+2lFREb6ZtXoZaxpYDGF/2 qJfoXFysiFhMUagSXZ73wK/DEkibBQs/v1NCk+NTAuccxuCyfusFvRvWrmTY+zN/nKAZ7Q8ZAD69 S7S1XnSIPdbQWDwD6mQJnaotNAiltfpN3//93//dnpHASuR0hE/yASfmx7s6hxpXWxKCK9swduzY 4bzC66tWOr+Aq/zGDRs9kGGOFBQInMCCvZ/sTX355WX2pqKpf/0rv2s7du10RWH5mHKP+kxdBEMc O26cu/FyzvXxY5Xu+ouC+nYJo7t37nKrGN5UtBsPiI1btmhf89c8OBX3Ro7UNg71hXqBN/3lGvyE tyHRV+4NpF5AQGhGLC4Uqqx8hEVywdQVrOH9FI1tmw5XOJZRZbUFiieR32g54/IspyjPDm7ba+nZ Ov80rd4ahjTZ7uN7JUS22OZj26yhsMG26LtW+8uz5Q6cOlQ05JTmnN6tzK+y+sGNlq4I+nvTDtr+ poOWOiPFDhXu1yKc5h4RDTnaeiG3f9rlAdZ0HFWb2uLzps9rUy9g8jHPMiCcfswR4GJ1Py7KLMaB IQsMCBOehQqiHiZ/1y3sieiLv9CCERaGWAb5k+uiDmUKBEfXLCgsJgQsyZKbSKYCm4hbcIKZrWsY C84+49BldzVROykztiND9wmGguB6/lOAB3uxMtMyRYTl4iLG5bWVr/meHlxVhymq4AFZZ1jssUg3 o3VMuHERUEcsT2hrQjOuJfX0ZvZHs0+v4bz/ivBn7GD641jEMWeMYd74jgwDTCQfEswFgiwW9gJZ u8BJXIAio9ldgyVKuFtvlva0bNa+tbKyIquouEF73y6xCeOn2gsvvGw/eewpaeeL7fclSM6bN0fM C+7rCJ0wLmKJXQDFgsKCHBhWtcga6nEHh+Eh4igMjwI4aV9i4aAS+8bv/6H97OlfyIXvSQnBJbb0 5k/omaxtYl7r61Wu3KKcF/IFPeFu2kvhlL5GuHHdOUXYdr7fm99nereneoFF+PSmps55YHL49CHB KDkwz/7dgJcc2ZEnwcgHWMJHCJqCKzlCBsxsYKr1XG0EBuAfdCZEXD77enkDgam/Uk/jdKYx7qlN Pko90B8ekYd53FSvKLwkwWvcmHL7i//z2/b4T56x7/3vH9jNSxfaDQuvtWIdxVSlbRvpYih5h3Yz xwhiluqeBcBaFhEFOGHCxONlmHPkZxzmX1NhpcUjZCl7zNauec8+cdtnbNGN1ykYkiyvtRojuefD PNOySFu8XUl/4phG2IR2hDYxp+vlftii6J+tTaJPOmqKRN2sU9u3b7eXXnrJf3MPQW5o2TAJZRvk crzFBT4EJIShesFkxMhRijyc7+7LYdsAZYUI5KxrIcCfiA5EiP9895iSnydff/glnmbKJRir47PP /kwgbbHP3HWnt+2xxx5zryQUvdfIw2Xu3Hlyf/6GhMA7nc4igDIXaB/CJe7wO9T3adOmy8J5UP2e bZ9TQLlt27a6omDo0CESVncKFkPtrs98xutAAZuJBVWwWL5smd1ya4t98b77JLQftKLBxV5vEB5V R0aWgicNsw0fbHRh+KSspjfKe2GPlBHPPPO0uwETX+IRWcJnXDZD505Ptd/5nXvCFiCtvwiwwdVY tFvjBL6w9jBGwJn5y3Uc8w9Da+BOVxBAJG1hreKoJ2Vo0TcfBNY0KXDTFEE3RQoh7tUXNEk4PWbN 0+TiP0HeSAqINOiyQu1LFi+po/VKZhVZXluONTcoIJrOumef+vFDR6ysRcevlcjdN0tuviPknltQ b/UZisw9U3N5bJrtaaq0uivkoj8mz/nAhiYd0yecStH8TNN5yGk6ZiZVH46Fwxsj7IfWmguN6apT A/fOCQIDwuk5gW/g5fMFgcDQBQ4lLpx9JfC4O8EwRGGUbxcutQBSJuW7UAJJceYkLCY8c1dfNYOF h/fiAsQzfvtB7tJed079TZxoMwScvUfHj1fbgw/+QJazX2tRztD5d8fsxPFKMS4fWHn5WPuDP/gD mzJ1ihZUWQYlqbOA+v6ozo1O+q3iAcVvTPIxRLiE8RIz0JkhiM/5ZuwZu3ikQRjHgAsOm0THkxkM 3PW6TnpP8iOKghTOQ5QGdZAE27z8PAVIUmRgCb43L1kqzErX2aejbPqlUwVXmFmYXmAMY4zgifIA BlLtVx9w2QNvPRiDKm6WYApDDdOmVzz/yOGjZZ39rNzjhtjUaZO0/0xWAFkTSstKZREepQVV76g9 zn0quAMYoxv6hIGVrlfPeN516mm+AZu+pp7KpUzGqPtE2/uKmJTbU9nd18qTJKX9hzL21CdqxP0f 4ZPIGgi5jnOCYWBgRVd0LwhD+taYOX0KCOIKsA9VmHwjga/Jt+I1lr/+Sj2NU0/woD09veto2kOf 6BH77VE0kRxWekmQcyFGpzppT1mR3XvPFwVXzrSWsMCcknIObwXOOyS3hkIDwx/ovb64p/kBTUeg 8j1vwkXNULnrZtocBaw6dFBWGu3pvvnmm3ScSaPWlRAV21FWjDL97qrv9Ldzn/kNvSE4T62EotUK tlNWtsP7Qxmxf1gKcWVlGwCKMlzEL5FnSKraxB5lgkB9+9vfdlyiPM5FBia8P1RKSuqhf3jQQPNw 9w/T93TcOK2NdCgABcAk0un5492uvsFrXNcRnIcOKXXBj739D3z9AVmzqxW7IVdWqEJ/FfdbPEyY Ix4PQEKpGu3t/+rXvuaWVDxb6BPjiHK1XkpD6iAxl6BHHuVc/cebyM9K1bPJU6a4IM92nA2yrvKu Rlkf1nTGO1UBkWZ4PAoitI8fP8Fy8wu8HRwNU1paYm8rkNntd93hltuHHnnYXbnL5eX1f//379qX v3S/b0UiiCIpec3gmjbHNakrvPCXPuJ/OuPthWmu5hHzEDRkvJKIL5F3U9G6sbMK31p5trXkKqhW OeOuPcjNcvWVH3BbnQKmtcjz6JiCFe7T2cTpeXZKc2Dv/j3OBxUNLbS0nAzFhNguepFrx947YhmD FFhJR0/ZIAVFKpFrt5T/rekNlqV1meNlUutVB3VKGZUqBYx+CQHVTtZ/4RJBlno/Sy4MJH9bavkw l/3b0rOBfnzkIRAX9uTv2Gju9cQQ90j4tRI5gdWCx+JNOXHh4Jt7LMRoWmFEWEwoLy4stAFNK/fj osc93oUgdU7eft0MbXKup3OW3v2GMkPqnDB/uBy0w7gl/eu//qsiUj4pN+TbXHOMln1I2RAFeSix n//s575v8a++89c2TFppD8ai8gQJX6A7hBP0k8lJZDdBZXuEbfIrF+E6eeF0uGvcOn+TJ7kPjBvJ mR1dRyaHexEfyI8VAsaHj1u8yPChJO2tFkrcc8U5aXFSQBS5UHP2YKasKuwphf/FqpKufcAssqAM VgzKbRUTjOtSMzgopipNeWhvswIksdCmxv3E3gds9FhP1QgtgpzL1iQGK03trNM+16uvnmfvrXvX fvniL+3e37lXihUJvWKOVLC32s8slDIjMfAUok/ncfes/icZZh13w1Uy3Ds/O9ffPdV7bmUDuA/P o3Mrs3dvuzJIQmeEm89sjSnQp79ibSRw4eaNcCQmJ6Gk8Gc+4N3XAzPeXeo/WEb61l3NPd/vqV3e mx6GiUeRRgcaHJRCDjc9FBTlGSK6LjhKDtNvCZdcC47MPfDe951qzuH2yQQVuDUnsXrKAiavhlQ/ DoK8oRzcU9MUubdVAZVa27CWaIuE3qdsDZiOkeA+Qm2YT7F/jDcfH0fl5zviAOsONAjr39y5c6zq eFX7OkO+KHRhmWNPMhY5hNOjijyLxS5L7q4IoJz5Gi2OlI0XDYIhgXvIyxqxcaPcXhUEqLy83MaO HUvHXFhPbo/fPMs/PkwaMB+z+K5uQnfGjx8vYbtUFs8Dcoet9mVskATxweoL9MrXUsFf1FUeIhLy EynSZ7ZpEEOBIEbAgrGivdDKTG2b4JpE8Deu8UbBldg9hEQ/wZHhI0d5nlOyJo8ZN87z4c2UobMp wRf2GqMUGjFilNdBZhSFCKooDZbecqvdsOhGVyghUFcsXCSX7n90L4j/9f/9DxdMvU1qnwr0sWXd wCWZMuLYU27yNb87p4gXne/H37G/8ffH51vYxSIqSyp7UcE1vvXX2mQ9Ta+V4NiUZnUtddYgxS9W +0atqWmKbJ/WmG1HNhyywsosO7DjsLXq7OO8oYqQ3qTjqArKrPJIlaXub7O6k7KKNuTakX0nLHW8 ZNN58pwamiNLKkdE1VsWYyv6kJGiOQfN0Eerr2iKroXBacK/FK3lNO5M4/jxGbfz29MB4fT8wnOg tLOAAJM6Tuzk7ygwuBB5FuXFrE7GVLYvcFrM07SfJ1sLHOXygUHgWZo00WqAv8ZCgJaZdnBGIdrd yBAltzMIux3vxAUkfsc2nO9vaiSa4pYtOipB+3Bw6Roz5hLthy2w4yeq/feokSNs7LixtmLFa7ZM 7k13f+5zLnDR5rCsn+9WXdjyIo7EWuO4dL5PfwPTH5QTMR9jFD/gAXnAhZif696MY8QL9oKRUBpk Z3Mst5gp/YbpRXNfMChP+MQChsAL/oX2YC1og0FWGzZt2ihLeKXGKd2Z0SlTpgn3tFfOl+QwaqAo TBht47TSDKISqu0wc+yBe+TRh3TExQpbeMNCMedyH1Y+3vcvtSnA58wY0BmOKuS8pDPBtOd6w1zr e0PO3O++l931m/QHIQK8AqcirkFz+GAp9Y/Gn8Q9H1sNGGed8k5PyQPhdJEBSJ0J1l281utbPY3T mert+V1veI/tcBom+HTANrhUch+hw8k480SwbZGlAytopgQSPBAk9um+lDsSWN7buMEtdjK1aJ94 hiJ1T9Hcw3tB60UC7m0SYBA6mzQunIPZ6gypCtd/Z1RVntSXKidYW7vqe+wv8zSOb7xmLs+adbkH MqK9sW8RAAg7V111lUd6BhfWKgItguqCigoPoMWeTD4IodTNWsBzzhP9rIKxESzqRz/6kR97wrvf +ta3HG7gIZ/zvhg43NN8H+icK+b4mcxYmxFAiVZ9qvaUDZWidN5VV2ts8BgJAj39pP3MUDyZ6CsC HnBKTg4/3QCm/KMMxpvfLa7s61A4Ugb3GW+SC8Tavy/51Omv1BpSSMiNWPWRj/qZT8GThYjIsnzq GZ4zjVJQowi4/7777JCi9xN7AmUvgqiPOe+qLSgBUAqgUOBDe72tNPIcEmV0l7z+7h6e4X5P5Z7h 1X5/LBlTSfORj+ZxioTPVMHZ11BtVcqQAFpgbJeQ0oLdOVICp2l+ZioCb2qr9pLKtVehG2RFVd5c naxQmuHCaYaKaGittUoFKhw9bpSd2HZUJzpoHg3SdiCdh4rwm6G9pBnp4Ke+sZZKIZUm62ma0BVB lDgRzTo6Lo0I4FrLaSsKKvdO6nfIfPwqGBBOP35j/pHpsRNJEeBkYtnd9dk0WnTDQ82zz4tFY82q EB4eayiLD66SLDCo1Ru4JxdgFiMWRbTj2WJaWHBqak5621jwWAzCUnH6gkF7/RkLiRPWs2lp7/Oy 2DaLOK5b/75VnzhuX7r/i1ZePs6+9ad/Zu/qIPoSuUl973/9rZiXmzzK8NYtm+zo4UNy+VRIdFUD Mad5uM54coYrXPIXF7mYQs7466PyfTrcNXgam8CsMgYBb9RDOpn4zbjERRyGAZdbgoaQYOZiioxK YHRDWcl4GPOF7yD0+XNvEkc5HNIRA8dtzCVFwi1p0LVvdNTo4apPDJEWPDT8Dn8tgNRBfVg5Cf/3 3HO/1PFFh+WmO81eW7Hc7r77C7bg+ht8gWxqxj0RvPJOOYNVIKvC7CtmC38VMr/ulA0ZVmZXXXOl rXjtNRtTXm7jx01wd253dWOMBaMAkljO6b1J/hVhlXwvXkcY95Qn5u383T0sO+fs4rdgxlj3Lann gdvp2+vM6T4k4A2+OeD9ffAwMOUca4IruMMxUTzwcQZcCgysRB68LD5L7rsKZjSTx4Bs1EcCVNC2 9jvxAfe45lEid/sjbrUnz9D+62wuzjTGZ3weK/OGJRqbaA7v0md+xjlKdt11gaOlVYJQQ7WEjlN+ nESL5h/0LFUueqliaHEJzpIAelj08KknH9c5xMMkkLbZxk0b7S//8q901EiRyiWmgKCDNURvt0nJ U1tXZdMvm6JgQ/KO0PN0U1wCooYi8BKpU3W0tWnN8DdoUUc6bYx8TMIz5j7rkBwgNFg+mioPBVag O6w/jeoryq3PSdDkPkIoNOaogvsRXIiyEZKAC2vW8ePHPdAbnjMFEqB8HVMerKe4sMbf3gLd7y6F Mer+eXfvxXIL5RbLUSwyTNqtt97idI7AR5s3bbavPvB7agf7fBt8DBFMY6LPLWoX9aPUoX+MM3l8 Xuh3k36zJ5XfEQegcS0SPFOZ4+G/18n7DmfWbb2HoINHCxYvUprWAfJTDr1l3rSqbrwXeAZecR93 6GoFP2K/70a5Uj8ul2oUAUt1zAwwpb3A/scPPWTvKkr/n/35n7uFO449baCO/khhrPqj5ItVpvBf 65X+avwllgi2gXbDl4h2al+pnyfaoLE9qvHJ0T1ZRRkoN2CiBNa41zZVWf7obKttqbb82dmWUaq9 pXqWqT2rB48etMzSLLnvZllmnbzQGuts+CwdH5PWaE05ddak6L8pqXWWI4zJ0rDh3ZLRoLl/7KS1 6JxkhS+zLKLnS0B1HEthr7TacbFA9lte74Bw+ls+wBe/eywKHYlfEH8+viizL0hEJSZfmPit/33d P5WqRRDNbZXC6+fJNedFhaevkTaZa4RSBFQi7hGwpEALKsKpu2UqWEKWFkSWppMSTIuKS93VByEW pgUBEeKJZg3aqUu/prH882hyjbpK6k/sV28WExbJsNdCCyoaOWnu0Ax6VVqA0SofE4EtHpRlE8tH 2Vtr3ra33lmnMPiZdvjYCVv28qt2840VNmposfKetMYWuahI84hwhMsLBaXAJHvjozAq0ZUKfAi4 0M/23/7T+xauLt5fb1On6t2tTmNBCmOCJh2rJOODlUAadDEcuH05065nexR5EYYCJmOQ3OdiQsMu nsoZWTTnkQGKz/kO4yrgqE6s2FhaxlwyRtEcd9mqlats396DNmpkub0vZQF7xrKzM+36ivmGNYF9 pwCaMoLVTJZPBTMiMuhtt95ss2bPtSLc+WSxbxFjDPNDm9k7TXAueByiSDcT9EGcLUwagjB71+bO mSurxSZbuWKFjRg2QsoVCchigLHkCltVZ1LbkzvUxTV4GpmqAMfANAMPPjzrKgXYdPXkXO+x9Ae8 PPuSvONn/9o5vsH+qAB76g8MMHgJHUEh4fyqHhFgjd6Bp4g4KCKIvO2Mr0oQG67XA61MB+56p0Xj w3ExDm/9ZnCZGwRqI3+TPqJWbm1IFUFJczdxuRDzsp758UJ6J+imdI/b/keF+M2+wppy+phoRqIf dIa5y28EerwS2FcPXjLHucc1H44t2aW5t3r1q5qStTpC5GlbsuQmp9sEHmsW3YPep6WJ3UQpoPxX XzXPPqsjZBoaauxv/u5vHdacDxyEiCBwMP9TM4BDps5WlGVF4yl9ghqpNkgYQmjhKKnASqstar/r QOiDskUI0gfWuNAfCcmak4xthmiHOqKMKo9+6hsc4JYunAbprv/GQnpcysj1sopepgA9g4sHu3Cr nIk247mRqYizR+2D9esUlG2IjtjheKoc5WuUYFvbno+6I27xfmwn12pQ+Or0F0z2fyxOftV1Tta+ Q4dF/0aPFJ3iOJ4qK1YE/OESssvHjnW341qtwWkaS4TOSGPiWDo+0woHAmAINDj5d4RffEZTIz0K rRPMEjQK+ugeJOCLxj7QLtYCzQR1NSiLmHMMA28n+s946B8K6Rx5wxCBf4MEU46/uUSR3mPcAuAI btWrT1uk5GiQAoF9shpG73/A1a5hSrs/yonxTk4f7sWH7yTnP5frMIP0N1ahptAexixDQmtRfZHt eyPLcrawIIagcmlNYU3FqyFFebLlhl/cJgu2LORNB5jTWksV1KiksUwKjhxr265rK5PiONVOHVMA TImduRq7U++cNIXCtHTR6Gxcx1U30a0H7R9kg2cW6lm205BWPYCe457uuBPbei4dH3j3QxAYEE4/ BJKBG+cLAsxZiE0gdYHgcM2i4QuHhIZwnaiRBZp34OP4hiL1IoXFJSwyLBq4Nb35+koX5r76la+4 MMoB2hUVFTZr7lU642qTh5MfrcWG42x4Z9u2bU5ohg4bKo15ox2vrvLjZCp1eHupzk6Tyty1u/SI f/xnYQzCpNoNsyTXzNZaPaV/+h3bRRe4DgxQ1x2ipyh3IYjKSfGCDTcgrsBJQok+gwrSrbSw1d57 69eKzLvQrpoz21ateUuHRI+xiuuut8rDu+RxdkTnfWlPjVzXvA0cSyILnu9VQ8MoVjiwsKrFOSvq ZEyS2qaq21Mvx6E9/3m8iLD01UnlRpjSPFcVJGDNmKTLUtIimLWKsUBmxbUPwyPjRN/f1zEFuL4h rHKG3fULKvwYGgRAFxISY4bbGPX5+NJ37qu+MH7sbaFmjYeY32GKoDl75hW2UpGTX1v+sKztwr03 1mj/b5mY5BJ795137as60iADtyM4F5XHkRGUDZO7dfNGldOge+YHwdP2eXOukPVVVhrVQnRJhgUl A4IFB4yvffNtWUlHWOnMaXKZU5CW+ia78/Y77Yf/9M+2etUqD8iULdUvDBpMNQwb+2JT2Cfbi4T1 gndJwJ+2Yr2JLnOMAffbx6YXZZ5blmTEPNuSGLkLmxBbMtijKJEQWDVrzsHIEOmRwBqt2ueIokF/ hHfgmvZCaqwRZDifEjcyn/qCe4vGHcUYApMjtXCgRe/C/PJq6J2EIP1kn2uLlFnMBeiq3nCGrhHk krClXKCyy6BAlOdOa3ziC8fdusTdC5xok6p0Gko/vZHqg/7t3b/PDirqKhlQDoLL4B0CDsq6Xy/T sSGrX9cZh6U6hmSl7dyxyZbe+mnbsXWz3GHfVcCkafImGCfYp9kOHRGyeeNme/WVZcLvZtu/95DO B63x6K3V1SdVbmgHwESYzcnKt1Ub33cF0PUVV3p7MlJ1XInmf9wPmaa2xo8LqyoDcAaKoW/1hzHi TFS/omzRgWZf5EQT9D55orsrAfloKxZ0cKdRygqu03VkTboYaK49HoLaAAzIc1TnNpeWFtvMGdOt XIGTMjXpJ44b6+uV03WUIgJgmLNqk8bZFSjezjjWp/0IN4WEvuePb72DZQsgUaZ3ily0n7JF08ZP GCcL4wZX9uYrQByCqCOZXquVkKy3vL20A1qaTEdCUQGbuSYl0xeuSS50Uqc+JL65QiFDFhf2EUzZ v697KGVSsVBr/XMaCih8HrB3XznUbtw1nTbrPmsD/ABp165dsrYf9mOF2Nd47fz5fvQTz/DIQjl5 9KiEVik6y8VLrHvvXZs+ZbKdPKVjycQL+ASppTO7AAAgAElEQVRtBxRv/WaksL+zo60B8onfAnYC 9D4+HbnO/co9RhxLTt/WIEwRzitScn6p3V9xv23ZvcVSFcQoRd4QKBugpzQKbyTfW67Jlqn5i/s8 654ufE6yjvkaLnxmjaMf/lzjztxE3PQI3JqjaZqDePa2UtatWTZ3xjxLVcTeRgVfQtlECjgZ8PDc ez9QQmcIDAinnSEy8LufIXAaqUvUFe+d+0SHAGEV3bR5sy2+6SZf0DfIvekdReArlCZ3wpSpTqBw 11mzZo3viYmBDFjsh+rMzGpZXTmOZbsE1urqarvjjjt8UYaBoPz+SPScD0u/VlJ9+EVdwIbFWAum gj6UySVl1uWD7NVXH7JR5ZPs97/2e3bzou1aIEfb0JJC+5dn/1aHTDcpGBKMHMxxhhgpFnBsM3C9 LLyhJl0krsPVR/FvZ3h3ZkpYbNwCr8bDmASrR9jLBPOQqgULpjZdCxQ4sGvnTvvEJ2+1I5Un3CrJ AsM+P76py4UyykkwKLE+OB/KBpLkhUnOEsO4SsLg6tWrnWnhbMvly5erjFbHNaJo7tu3R/W+qyAf 7EkVsyRrBmURDZT2opEH73DHO6hAIpwLOHIkUX5nBAuD+oVQyGIKTrD48hsLapNbUXF2ahMjnW03 Cd+fe+551/YS3ZPIokHQFIOLsIn1vIdEv+hv/AYeXNM+Dp33o1H0u7Pg2g6jHsr+OD3CzTAFvFSn W6UwadbRA67EcthqTspFTZyOWCF5NYgRahHDk4ObtzCEqM3sr0rVvG0TM6RbsEzWICEltVnYB67q 9cBUCY9cUQLTLrzSPEfoYK8WAi0BgTIk6abItZX6EZA1wF4PuKTbHtijVc9cLqWyi5QiDvl8Fuz4 jZXqF7/4hQuh0GOEMlKkCdD5zZu3KgjPMFkXT2gfZr69sXqtTZ40VVGsX7d/+Zf/sFuX3mJLFi9R GY3uGstxWxsU1Rw4cD7oKy8tU6CUQb7Pm7qRGQlaRjROEtZHtgDggZHmSgEiMGucNG49JeYNCYiy bsQ5xT2uwzYLrScJ2sN9pzl6FhjoQI/oq/dX95n3JEpuRojimHrdx4KHdwXRZocOHeqwq9U+z+Wv rbQvffnL/gZztt2rhEL6kmi33usKS6CHnBWOknfvnl12z733OL3csWOH04/ZV1wRFCz+ds+w66lp EU+S8wBP3/unm9C7CGu+gweSxlIDixKAe1i98T7xeerwDfSfMimfPODaMik+9uzZY1/4whds+vRL 7ZTwDXdqoih72byr/IwP8MUVO/AICE30EXrKvP7NSr0ZHfrfbwntTlKCFWK+ZCso1sIrF9mNVy8O a7bu+dzQGGhAfF5GizhbJ5in4CVIS3t9q4vGylNsf/ytee5eKqz7lEeRvmZCc/HEq7V6HVPDHKUs xjnyCF53UnsHLs8PBETdBtIABC4EBDTbnV3rqq7TiVFXOXpzz4mGCEqhXCMvvfRSHcC9y4MaQGyu VIAJovEdlRZ+cFGR78XEZYeEdhTmu0z7M7GiDZJwykKDGw9WWMqFYXABQfkjc+4vn+WfrhZXigAC 0EQtn6KLIYowv2FNw28teE21ylRj8+YPtsy8HPv5z39gkyfOt2mTJ9jxyv325BM/sdKhh23RLVNs 74FqCTAwW2ivRVC9DqxhgcGg5JC0wAY+LN74SH0D++QUfwc4svjzYSUJQhx52xcNXcMk4FKbV5Dv AS3IuGfPXgXnuMaGjRjpblthgdMTFpwEo+HWTWlI3ZWbNjgAAxNEfTBDmbkFwpcm3wd2442K8ChG 5Jpr5kvQLJKFdoNbGxcp8uO99xJJl3exmKqd0vS6hUTjAhM0ffp0m3/dAlkX6jwQ13PPPWcjJVwO HaYzAMUYU1/Q7IMjWFOxmIR+hsVSwov2cl0qgZYzAGEQwWnc61ikiVBJagm+nH7d1R9g67DUw8hw 8ZtIoAi+kyZN8rkQ8yTn76q8j+09pEfhZZtcahv1YQanpYTAW5mZ0toLpo3NihaZrwiRGv9TtS2K OqngO5k5Vqh7x48fFvzlNq5z+rDAZOk4DIJ+5KRqk5W+WyUk5cgrooU9T/rdUKf90ygwlJfjE1q1 tQCeuEmurW0tRIHWBIfnEr61NgmnaQ+MnSTSNCxitDVNCJ6wul7ocQOf+IBPfMC9eI3yhrk1V8e6 QItJ4Dx5oMmXjB5nL7/wiuWNKNbvZh0nc58tvW2pXTZzts64LJW161q7bsENdqq6xoXS92TdWrJ0 sVxr0+2IrF45udmioz/XWZp3u9stczgjU5ZLaKfaQj7g6nVKadAsuHHNGcS4Tce50BlmsU8uaCba zLrBGsKzYEnv6LdutvcZ2qPBYMgCLPRNOSizdNuFLK6hHZytjQfQuzrres3aNVamSMATJ060E1Kq +pEtEhhJkC+YcydjrCt8OiX6211/XEBI5Oe68+sw6win0InHHn3EjmncRmoNHSZl7/xr5/vaS92h JYmCzvKru7ZRDAI6z2NAJcYImPnWCMETfOE5fYzBj8jDeERcIj95/D3lnzNnjkdF3rBhg+3bs9dm X365e1HBNzCWuFOjQOF8VxR3N+m8VBQITqv1PvX8JqYwTl233OVG/9P18/68C8zBecaIMSMx3igL gsKAOaJ56+0TLusfKkJRFf+HNVSLfBhjfTPOWiGlENT6qGt+N9Q1OI44TjBbVBc0AbyJCbwhxXud 50LMN/B9bhAYEE7PDX4Db38EIJC8qELAsrVPZ/bs2c6gs2iwQOLeRT4WIwTQyxXkgGcsahAlnnGN gFAt10wi85GX+zwnQRRjSr6O98jb98S7YswgiP5BK46lS3sfnJWRG4vckxpbDlvZoEN21+dG29q3 KhVs4nF78meVcucqshnzSm3GrBIrLKm17buO6X0IOFFdFQHRZzplqw+J+94bvw5Cq/u+KEfn1FVf k/OcW7+TSzr9Orne7urgPh8WJRajoLmm31hEwwLG+NWLgZ8wfryVl4/xZ74nqqTUx9SZRhYcleNW VDEVvIP3DsdMACePAtosllIghFlFKH35hefthRd+oYUy7LFasuRmj6B8112fse9973tiEidJMP0d Z2AapVgAvyggA/da4RIRfsEx6ucMNRZErDRh8WOcArMYGC3hhhZdUBAXW/YRY9FsVEh9b5Tuc57g okWLFJzpWDvzxN479jJiNVDzu03AkPqTYU5mfj/99NPuQZA8D7gfxyR+d1v4GR6cy/ud23uGqi7I Yw6KRyHS6ooBuenqGKE0Mci42mZL8Pn1r1+xI4cPqC1pNmnKdJsx+zLBPsU2rd9iK15dLgVTsc6y LVPgq3l2SrRo76ZdNlyKs53bt7u1L10WhBOnqt3BgkizM2fOlFv/eLmsbrMP3l9no0eNtD37D2gf 80wbPbxEbsXQvRzhhMaM8/pUM2IKn1a1tUXCq7uz+f0LAqLTKmEM+TAPkhk/7rHnknnDfYSBmI8e QL8X3nCjHd57wt56+y27485P2w0V11tNlQKbCLbDh4/w/FXaolGQk2cc0YLgiZURpQ00w+e+5iDz CUVUOJqEua8SNG/q5V7vFkuNHW74uA6G/eMiBAn3vtM6k/gRcdqZ3MT6EvuJEswtbnqfsv2+Wkyk bbYM4NoNXfA+a45n6tot5Cja2mmTRjFBzpnvHC1DxO/twpFBCpqGVRmGfb32vl9/fYWXpYp8zkLP +pJcKFWdVNs5odSjTgQ1tspwjBl94Agc6NVhCatXXHFl59d6/RsYdZWAc7Y8WCoFAwQXlMrA3Ldq CJ9CgDEs4B1CDc+BzQlZ21kHxmtdoHzoKc+cHusbpSHRegksdVDz6XUFexosHELxTV5oNc/Ky8s9 MjKKDGgkR0RlZAUFipr3W5JCRxDzukSAfu5lnE/MCa75MGYoB7Zu3erjEO/HpiTPPa4ZM3CR9yjH 13jNNQKc1UnxhVKH4FcduAaFDHSSNZ4U20F5eCNRjm623491D3yfOwQGhNNzh+FACRcBApE4dVU1 AgpMDee+EewIsgoxYXkjPDzEp5CQ78oHgUpHctNDBBMYnkGF0jYrD4wDzyNB4prUQbzCdXzuDzs9 j/fO9E3bYF49mq6sImj4tLlM3yLGesj+SUshqjCWtGNWVFpj1y5qs0nT2ySQcAZeiqzBsrwNalHQ pGoxoDpQWsXAbCGctMly4yZS3HpdIEWUC3Vy8VFZQzvDlt98IuyBY/vYC14wGURaJmEBCi66iTwJ Sz3v4+6D29vKlSv8ndlzhwWcEF5QXqsYTxhGcAK4wCDyW4X6cxgWrglMA+T4jYDK8RS0AeaHew36 ffnls+zb3/5LWRKK9YzAJEEbG5lc2gjAiWTJUQ8oTrCQg6Ob5Y6O9aFI1n0YrIBbQUGCkoK9iqU6 SzAvL9+PaqDfMMloixFwyB9d++g3bUpUpzxBLPF3Ov3hvVBXeMA17WHxHTJkqF/zm3HgE2Aa2sX9 5Hc7Ff2x+wlDQ4RIXGuFMb6HNEX4lSnBqF5eGTu3bXcBcf/uQ1Z7XMHZJEzJUdtKZHFf9errNvfK ubK8b7Er5O1RJ1eypx9/2g7IVTIvP8OjOu/bvV/7+bJt045tNmRkmQJuXaGgHooiWd/i+H3lNfO0 T+6g5eZlyno1X/M+4U4uepKuYCFOZxBIsagioHGtNmOFFTJd8PGKuBe/wS1SxLdkOgzugdOSA9zV rrCwxBYsWKS82YqiepMshqds5WsrbO3bb8ilfretX7/ejlUes2lSAjz6yGOKzKugdxJ2m+UmXXms UoJ8ud2wsCLguhhQWFH2HdIG9rkNKixSfikINR+oF++HDFm/3W1QrqHd4X2ce7gKRiUngif5w3El UjaKDKhAV3zR1xRos/ddQrnc9HE7xiMChprI88WiCTJuK+BRjtVKMCLRppKSYrcsb9QxOQhbqsLp x/RpI1QXeypFWzSPHb7qYaT15OOTALeX19c/KL/w1kBApTwEN4QBBEAs06PlCaIsDtdkmMWx7mu9 1HFYUYxXrlju9bOdASUGAgsBEI9obygBxKDRKKwRPoDHm2++6W7etJngeHGMaAdjAc7RB/iIufOu tM2KVfCQovIOk9v0lClTPA+4SH3l5eUO7+u0rYNtQK740DNgezHmE7X2S9Ia01M6X7jUdR2BJoA7 eEOx1gF/xgcFAe7jjC1jFnEqfjPeXDPGcZzZNwruwBcwUNBE1lvWO8Y/vsO6Cj7HNY9yuI6QIJ9v 9yFTIiXjd7w38H32EBgQTs8eZgNvfEQgABGIBOhDTRLxCsEkgnbLo2WSCaImysIeLoiTEx6VgwsO +7jQkPGcD0EzKJ8PixVEyzVlnSrrrg3c7z2hgrihDUf00bXqd4ESbkQJlqK1TYQXNpKIkfXVyl6j vaY5ljlKwlFLg/p7WG6g0ry3SphQ8BUCazgXjCUHRlQMc1gs2bsVzGheni861N9BYPWj16m7/lNA 7/v/4eri+LIYJJcV7zdJOPzVr37lLmMTJ4z382xhwli82G+KJYHoy3yzCBUWDpLgeLkzp4MlqGKN YEzh+Dg7lHJhXBE0M6Sw0BC421DEE1+0xOyBNJRZUbHAnn32GQkCe+wP//APZSUo8cWxQVF4Eeho dn19nVtaMwjWpD3DWD8pb42EUqwc7KXjNwPFQjdv3jx3J2sSPraoHyzCWGxoDNYcopdi9YdBbmT/ qtoeXZvZE6cuBKWLGGfwl/dVrC+o8uBU6nqMg2AbxssXbOXDLbhZ+xxxl2RRp//AyBdnKlLi90Dq DAHBGEWABJk0F1ARYsQgyYJaLwZo8OAiuew26QD4dVaWN8xSdLA8ewg37N0oi6k8H+Tau+/gfgiQ 4wTuubUN2vOkPcb79++13II8u3zuPDuI+69wLCdVc11NOKajUo5KEDt05Ki9uWq1TZk43gNqNcqK iyTEPE3nWklqN7VPQpYEolSd5YcFlX+gx4Ue0Ti/aR/X4FmkKXzH+zzjOjCQSHZSNspFvkb7wWpq 6636FDTSbOKUiXKVrpKA/66OUplu0y6daS/+8nk9a3HlI/OMhIIHt3tcYd3SJhoB/acOxqtOjO6s mcQoCOMQ62a+ASiszTCvXX0AoiuMFHQnU1G7abP3U/czsrTu6Jt7KK8on2mEUIPr9UkJOL/4xfMe vI3jzMrKhrhrM/Rr166d9r4E7klTp9k4CUbsUcZjgj1xBO7D44ftKZMnT7Hlit6N4gt4ki9VVvbQ NwQnaGr8gD1qQPvIx+suvp18cP/0RLkIxjU1NW7JhKbx4dxPaPTIUaMEMeoR5BJjenoJffuFIMpW BoRQBMPvfve7Psa33XablBKVrvwboiCHORJOKyoq3NJG7IFvfvOP7Nprr5HXwWWKtr7b28Qaz4dE uQi0PHtt5UoPsINXytjycheIiPgOXLG68k2ApAcffNBuueUWjzfgLthMpt+G5Pj+4TEPXQv3Ee4c fTS2TkT61O/u6gBnOgrEWyTQAu5BW1tl5Z5mNy+9VQrbGp/DgUfgvbCuRtzmOCOu4ffAVebg4KJS e/uN122VYkeUa3wZ41rwQP12V2CNI+VFusQ1NIRvVzR3NG3g6jxCYEA4PY/AHCjq4kEgEKMOCoZ2 muTCiohI+4LoVE5EUN8whGi2STBm7PXJFLHiXSc8qOeVIISBIQqLq9/swx/a0FPyyIhkINInCwLC JBZPJeTM9HS9L6EjBQsIQok407amk2KSZJmT4MMCkSbLSJoOAMMKIv2veqUPAVhUnt4My6XehTFB MA3rDu0KFlrqulipM3wYg8gsMAbJAhLX1ccr7ZcKmJIl156vf/3rzlA4HkjwzsiRi7asVG+sXmXv yNWM/U9Ll95so8deLeG+WcwoYejFdBJGU/UQmRFmhPqo6/DBQ44zuPqw1w2GsUGCBZpa3ARnXHaZ rRDz9+STsmpJGKioWOiBM1jAGhQ9d926t52p9GjQQptmjU9IwX3skMrH5Q3hFNzSADkzN1wu6NTP B0E5LIL87tAW48aXl69w+cWF7lokllzjKHxmmIVjuP4x0sAICxH3aBdujGB61wmmH+GA54Hxp+5g BZDFSO0BXqAwZZEol/tep2A4kDoggMeCz3bmpcCFE0SDlAW52g+fkpNupxqq7Pql1yuq6lSbIAGo SfN80wcbrHR4sQKv1NhlV1yqfK2WV5Zjn/vy5y1fOH5g7x4FzDqlvchDrWhoqWWX5lhdTZ0fidCc Vm9FowbZrZ+9zYr1LKcwyybMmCDaIOZMqNcm4TNV9E1YoL2qWNqFISjCNGxOKzR+WFBbnCB09ONC XHXGI/AO3GUug1/gG3Mk5uO3XwvPRQjVIyUBu1lnj4LDCKfLl79kr616Q8HjLreJk8bbj//9sLtp oqzi3QxFwUZwKigscGUURVAv+M0HdE6TYufI8ROuoBouC7UrcDisR22CfoLxUNUu/wmO7BU+oCBn L774oh9flSkLLAncUCEuMCIEsW8ORVCWrKXQIQSdoqLBTr9w173hhgU2apSse4p+Cz379nf+2v4v faZPmarxF20SvnygfZEZKuPKK4Pr7F7hClZLyoeBbhQe0l7HSb8KrfceiC4A647U8Yznp386cnW+ Qqm3YMECD+5GYDfKHDdunNNVopg7bRZwT6+rcym9/804Ulau9g3jKo3HCHuTwR36jksuY6yBs81b NnvwOdrI3thbdA4r7sDQdmCExY0UcCOcc/7www/7bxSaxVIojdBYAD/KIF8UZhkzhNhJqg83U56p Ye399YJ/o/8k48aHO+KKDmUBNihXQKW+j3H3dbF+4eUGeFnXqMPxW3jfKA+DZm2dQUkDrYgKVmhF 5CGYY62tBDcLZ5P/7d/+jbwr9tuNCxfZ8wok+Poba1xJ9Yd/8qc6pUZeUVrv8WRjWwZ1EUSL70h/ PgyJcCfiZXfPB+73DgIDwmnv4DSQqw8QcCLtJCtMas1sX+ooimfheR8KTrwf3+yqHJEQf8w3hAqS B/FEQIO68RteHXfZSFTTJQHCdyS3DWLU+TcFxzrjN/cgWuTnQ0p+Fu/F8jzDaX/0DgKn7nGwu7hJ /w0TpB/60B8YXhgrCRK6R9tTEVbl7stvvaA24B6KhVUCq4RWmWX0nDIDPMI+VnIG6wFXMKkhjLuK OM8pGQZ9KTrCi0X/Zz/7mUdXjsyrfHHbmda//s53ZBmA0QvHAqDBxj324IGD9sorr9hdd95pByUQ Vp2olCVTTIksLUVFJb64wWzisjVr1uX2/e9/X+eGztGewMO+VxnhkgBFRGx8T0FH0LYWinHE/fe4 GNeZM2fYTDGbJ3QWIUwi+9oYA1zN8vIK1GWUHixsKDgCzsMI4WL2c5WLVQHXw7d1iPtKaei3bdtm ZQrOVVRS6kxw7D9jSKqTBe399e/JTW6kLD4lGj5c9gKjFBZk8Ab8dkxynKQNsZxQStd/EUyjEEwO 8Bn84F0+lHN6GH2qCs/Jf6YUyjhTrrN7nlzmueLa2dXcfW5gz1gQY4iI2WnaY9ysOeY4IPf7osll 2uNUZ4UjSuxQiyydB2WZ0Zm1eWXZVjRIe0QPS4iVomTl7tc1N1NtUH6hNWSm2+BxJabdqC4WHWo8 bDmjciynOc921+7SeZ9brW2IXLp1zmWz8GHypMl2sPqgNexpsUtKx8i5GIFO3iFpEq4QWBWoqVW4 00Y0X8YWGpCgMd33rO9PGCfGJ9LIoPgIFpD4jNLJkzyOzE2eR4YwfnPPP251ZL8o7nXaf5iTaa+v WG7/8A9/b3v27rf/5//9O5smq8ptt91qjzzyqAS/Stu5e48zrCtWrLRLZTkjyjZ4Dm6HclHGmASN DLkMbnHvh9FjRugegXDk/eBgCFZW3+uuNpNoN+/7t+YSjPNORQfHdfTqq6925VNklCkDayaCFAqg Ou2Jf/bZZ/3d6667LpwLWrvXrYEfSGmB9RRFa5b2qd98881+HjJKMvY5YgGukTvtzp3BtZE2YEWk /iES2NpYlyRoE9WcZ2xXcDh7m6EXtL7n5PmVT6+fnnSDfxRB3/bu3evXpaUlNkNARNBGycZxPkEJ RxmnFxLhdnrBZ/5FOSgMy8vLpbjZ69s7sJgiPNIOYk2wv7heggveJgUKiteobRdDSsvsT//kP2ls N9kmuYReorOq3xX9TUExpzEhunaGYF0iN+rNW7b4medTFD+AdjaIdge6GOgjbsxvvPGGW62v0RgH zxutx+4Nc+Y+fBRzuGI8qWHJ6AEMSCgDoBggBOPAffAN4RA6h2ImJJSeUokxj4GvUsAX3XdhEf4G XU1QcpLX6SRrj6qibJ65RwOvqwyPo6CHBBXE+wmFfZq2TLB2RVzSa15vnG/MM2gO5fGhrddfv8Bd 5mdoD3GzlNWlWnfZZ7xq5XLfvjN+opR7tAtC7lhNS0ObqAd3Xizkvv0nPGr/G+HUfiPxXvJvrmlL TMnX8V5X5cRn/fndVb3xXlft7I+2DAin/QHVgTI7IAAxSxAEJ2tJk7Ej0/m/Om0iRYLqdCAQ11hj 4lH4mXgUcyRPwuRrMlN+vBfrSr7Hs+TnkfjGerv+jgIjlqvkqQkBFyFskfVAYqi7cXJHR0ZgBGWR QBmPGSSVCJ6pCKVogmUJ0F/WkJD0i2NqPMFQ8Lu9t4n7H50v4MmHRQWGg2ixuK2RWFw4Hubee+51 /DqlfVmNsuyxGME8jB071hk0Is2iRUcgJFjHxg3r3dI6dZoi5M6/rp1hQpvOsRFYz5eLuZ17xRxf mLCObtcewXUKLEI5MJr1snRUymVssdyIcMk7IRev6xdc79YOFlYS7rx8glsRY8JiGwYCy/yw4cPs U5/6lO97Ys8T7ryHDgVrLUL4p26/Q/uHpfVX0vroyWHhzLjGWcwTCdddSmVa8Tyk8A3+hXv8ThSS yNH5K+Iq9+N1FARi3o7yO/Ik54/5LtZ3R38vVgtCvcwrjoLhCKfmNvYby5VTbt1M0uM1x+3R5Y/b r3b9ygpGDxJKyK32RIpVf3DSCjNyrSA3z45IgVI6WfiYp0AdlQ1Ws7FBjHKhgnNJsJTLeNEg7YlX 2ceqKuXSWSd9kyqQ1bN4Yp6ljpSCJl0MlfAk/WiaTW2bYf/t979rmTqfExrU6oyW8EKvwCS24FUh 3KDNKa2iDVGJdZ5ByNggnEQ6CG5FPAuWjtPpZawenCNf/PAeZfi7QmtQHmVQfUONXglumcerK+2a +VfaqNEjJBAK7lIUEMRmyZITEiTetMsum+k0ZfPmLe5aT1Tb2bPnqEwUSFhaTvcQgCZ4ECPRG6zM CPlE8CQBN9rj/RE8aa8LrOT1spo9WBECMHmgT7SdveuhbW06n/VdeWG81h6VmP3mBw8eVHThDU5n eA/FGHuLsUxepw/Um3LYrpKXn+cWOyyw0Dvca6EP82RF3LNHgrhoRGhrgkYk0QmnDConwtkz9uFP HB+UiMXFRQouM8EZfyyKd9x5hyzIBx3mbIcgkT+ZnvShSn8FgTsnJ1fjPd/HAUsp5RIYCVdt1o4S CSZYPSPeNCv4Vaas0FPl+lwu5SOCKIIGQoaPo8YTCx0WtZlSWG7ZttUekhUVAXuWgo/hPRPxGMsr AjhuvvSVo+jaFC37Nzv13H4X9NhSomzEe4g4xLFq//Zv/2b33XefW/AjrrPFxnFe40Dy+3pZnvMO bz0ME1nPPPaDxoIyWUuZX9TDODM2jCf0grWSNXiSPJuItutH5ql8Hz+VxzeJ/LSX8Ypjxn2UyKy/ pFzFGWGP96TJE30dxj0bK/wUXOI196NClryn4azwhXaeS4rtBD7JKfYj+d6FvI7tSe7v+Zqzve1H 5FR7m38g3wAEfiMgcK5Eo7tOMlnjxE3OkzyJk+93vu45X6LVuPM62TudYLnASgRfZyCxlcJMBquw 2BS9Q/74gTjr42emijlJ1WJC8rJ1WwyWrwleVud6QtaPwl+INDDjg5sWH+7BDDSxn1MLFVHz6EGO LAgwdgiypOrqk77nau2aN23f/n3OeNv/iOQAACAASURBVLLINcq6ijBKVGffhylGcrGOAUDg/cu/ +Au3jrKgUSf7uNAGE5QEV7UcWS5Oyno6depUy8/NkoA7X2fOvmpPPfW0NPDl2uM2w5a9ssKDNKxd +5YLtIsX3ygNf62Xp6pcTqQP7A3jGAjKmnH5HLee8hs3QAJ3wehFNyXcj1MzAiycydJiSxASLN4I yNzD7TAZv3RH4x2F0rBYO2B6/AMk4+zhHa57+26PBX9sHgJBzqMNHhuCn5RI6Zq3RPCsq62xHQ1b 7djY49Y4HWuWBNcDKWJwD9qRg5qXEj5zp8gSNv64FQzLtf3rDlrlBgVROpJiw0plBdOxM+veWi9v Vh2dIctDSXmp1WWdskOHtecur9CKpxXa8axq4UGq5R/It32b91lNWo3lpilAGsyecCa1RYJzi1wh 5UpMWx0huWpXVPnN8/oHfOcDs8iHucY395KZxrOrVJasxjoJBKXykqhw2oYgdqUCSk2ePM5WLH/V Jk6YJI+I2W7RGqV9j0fkgk90Y+bM6tWvu9spexCvkOCH0g8YhXYGgVhA8d8orpBzcc1taiLoiqoT yFJEQPA8cddoVxbq2ulueJYuCzV5sJRnKCJ3cK3XMykXThw/4t4g0KkFCypEq6a74IOQOWLEqGAt lWXo4MED9r6iMJ+oqvbjzVwJp/b7OqQ20N7bdRb3VVdfZeO1956znYskIF4u7wysruTDwuOB40T7 aGGY0/EbLGCe803iOz5LfLv2U/c9K3/4dCToDjQSuok1FzhyDcy3bdXRVorW21+JscTTgH4COxLt Ab/49v6LPpIQbNi7j+cLzxE0m/SO01Q9d5gyuCoLuOJWXaIAdOPLy4VPK+wdWVjvvvvuoBxV/xCC R4wY6Vbv++4PrswIX5xHDEyx+F2MRD+S14JzaUMcaccQ8RvNLY0uLLrlUHDErfmXv/ylu1BPmDDB q0IxwBwHFsAZi3JsE3uRgS3Jx0jXQAmcQYGHcggXXDxOUL6Ci+Fd3PsVa0Flo1hCobNkyWLt09ca LV4At9uwLYU1kfHjiKEcvc+8RqgNgRN1I1FuWDeFuV5mqDfdjxUM7tmijOof6JAsoPJ+X1LExd6+ e77Gr7f1JefzeZB8I+n6bPuR9OpZXQ4Ip2cFroHMH2cI9D+xCAQ7wFhcK6tBe9IzFyS12OpeK5yR mCEisLLsiizrwz+eM63JL5IvpjhFKkrFovNcIsvhme54eQivzmWxCMRlSJcXOUEcQ6CgoGllMYtC J89++MN/tvWyJhC50s/80yJ4qSwif/zHf9zOkLA4Ev32XTGfaElzcnQm3do1LnDi7pUBg6yyKI9o koAbN14WJOqKzAugiL8ztcARaIvjZDjmA+ERBoW27tq1R3tQn5R1dosY5Ku1OKbbTx57zPdEETkV OKPlZU9omhhVhGosJAjcMbHIEwEy7n8F5/jA6MVEf2kz94GLo4n+sJdNt09P4Ey7gHr6o4Ff/QMB jZjPJD+eREwW86xBwYzgUznvNqs0w9IKJbCOYUw1hrpnu4TnysMczCzX0SmjpXQZrGNMhjZZ0VUF VpxVJFfzY9qTqoBJGcXWXN1q+dovWTy22KpkoTtacNyKJhZb2kipsPKhCRp3KjwkZk+uvOw5TVE+ 2Q/0RP/UpjbN/RZwI7GvnbYEGuAYdV6BA77CVDJPmEt4IeAFwf2+JlqJF0LBoHzN6eIgbEtQZC/3 5s0b7dHHfmILKxa6e31DXZNt2rTJBSjcAkmHFUAKl8yKigqf88wx5rxH7NZcQrDgjGA8IEgI9rxL i31eOgzFBEODRTOYi/SHbz+rVBn57RF7ZYnz+ap3EI5w5ceNl4A60CYsNZQRo40iZCFIsZ+ecQFu MO+NwpFGaIj++WipfBRtJerz1GlTRNMEX7kosg0hSxGdsRi3J+UNqsz2O+fnQv1EmcZ+V9yXj8mS WKXxbZOiDffiZcuW2X/+sz/zPtDHrhKw6Ssu+Lsql3GL8Ad21AXckr/Jy7pAIg9w5jfXjD/vxza6 8k/CWFXVCY/uy/1rr73Wz4+NSkPweO/ePfLqmejj4MKW4w440Xfc7gpGZ3svwpM+n69EWVhCUQrj 4kwkZqLlYq1HEYHCFY8f4En95EdpgQIIPAW/UQiQj9gJUaHBfejlBCmTOAoJXNfreh+BNCi1mAeM AZZy5iZjh7s7yeOE6Jv8gVfAmhre4zeBkGgP40Pyua1rxpxo3AjR0Cc+eDlQD3npB/XSlv5IEUbA KXmcuM/nYqfYhti2+PtCtKuD47kQtQ3UMQCB30AIxIkZm578O17H75jnbL8hpMiIgSLHt7khzZ0Y GhckXYiEmUyIo4TqlCsbrHAb+2UJpKSASFhLnawl8gVBVVrDZCEFxspCfoTXEHzp4hPD2HPgyeIA MWShCAuMmMXE4nLvvfdYU92dYd+HXiIfi16a3mvmHS02bWIkp02doj1n0xW1cY1dKddZXGjR4uZp ASQgFoIEdaUo0i2pQUyWbjkjz6JIVGfcvSgfRgeGJVMumrQJjf3jjz/uGuPy8nIXbLGC1J6SZlnP 6upqPZImrnbZCoJD1FsWu2bVwX4ZmBfcwjwpiioLJJrnW2+91fsShXHus5gSyAl3M44zyM3L9vJo O22hzQPpowEB5mO645TGWOPSImGESKnoiloUXVae95ZZm2p5NTpaRgxZamOKAvNIwJpWpH2qGXb8 WLUEt0HWJCtrcVaxZU7MtbySfDtx7KQ116ZY+YSJlq5v9shVK09GqlwUh0/UXEixmj0nLatEVlJd p5/QATOykGYxzzVv2vdGoSRxoRT6QYL2MPdBov5BJPCUOQQuMx9eeOEFF6A4uivOcVpyNskFNNHN jPSwv82t1V5Aqo6JqbItW3bYmEt22qTde61elksUQbjwpmss2DvKudGLF9/U7ubLfnVcbYETc5O2 lsgq40K0yuU3HirQBdrsbsAepyDA0eeh8vGM/pK4hzBK4l6WArXhovvLF1+wRTfd6NZNnjWqbGiG 0xjlc0GU+hrqVaMsgqJDGLZZCprBIeWhVOhitfae7pFLKf3C0kd7h2j/nOQqT62JvHF/3Hmn8moI 7YE2syXhpZd+ZV/+0pdkyb3ahVX202/QMTdEU01NCIChZefrL7gVBFMUjtUSlBAeUVJAX8M+0CYX ZhgbYIZgQ5sRmEjcR1CBPjNmfB9UMKuVclVtEm2efdksGz5suCtDoxBLGQS8ukpHPqFMxA171sxZ bh3HcqpqHI/OVy/7Wk4yPva2DHDN+ZH2F8CaQCNYA1e+vtLPZGZN/YT2+aKU3btnjyueduzYAUAd psAawZW4D8AKt2uUAYwJrrnkRUAlBkNBQaHgnu6CK7EdSHG8GBPKYsxYF/2IKAm3r732mj351FPu BbX0lqX+vKKiwhXGvBuVykHIDAqJKHTy3OvQXCdRB23BW4r3sKTimu/0UfWej0T7Y72UR1voV+wb 92hH8n3une+U3Iauyu78nN+0/UKmAeH0QkJ7oK4BCHQBgY5Jz+RPJgDRysk9NOUwKHJFEWPpbrno wXUdaQZBjyCzMG2eWGFIkauJ9/WeC6w8k9XEy+P6I5bigkSzuGZPDwsahJxw8uItBRPtZZMVMgpy m2QpbZUgd8lIuVtp/w/M6KFDB107CsMyZcpkWW2q/By8UQqEkS03XaDEYgDUnDGV1pb6IMgIkbCB 1Imlk8NjM9J1VqSYYhLMJC6BuNDV1zXYNddcI+bof+h9LEVNvo8My4iWSZWHEkD/VRFMFGekHj16 xMuWdOwM0bhx45y5hBEO57ei7RWj7EKzzj8UEzRr1kwxvJyzSoAWBN7ABEnkUPtDu7xxA38uCgTA oyA4+YXGhP2WGhuNU5YUG0372qyqUoLmgQZrEp6lNAvHJKAeaTpsuSn5dnjfcTu07ZAVjMmyyiod d5CXYsOvKrWiqdqL+OZhO7L5sGXVZ1huW7bVSAHSnCVhRS7fTbt0DvJgWQGym6ywpMjq9smVNHWS 9qqK2c4WY9eoNnjj1LpkzlP0wX8KN3ncX4ngMURA3bp1qzOnzB1SZ0aot/UH8QwFT63P//yCXJ+X tTX1NnXKNPuDb3zTj46aM3eONSoAGgzt5s2bNBbauS8muEQwGj9+nOafhFHBgP2Q0GI+CK+1iow8 VcotrKeyzbgiTNKV5naI2MtZyGJ3u2+uyomMJmXGayJ/jx8/waYqUBOMOnSJlCELDkGS2N8KTGCM oTtcR1rUXpnK4+xTLE7AFFfaLB1ZgwDw1a9+1YXq3Tob9wkx7rffeZcr5aBf0LmO9aa9tPNyQV9Q AGBVGzd+vPfr17/+taKkL7UdO3d63QinXaW+4kAsC9jSrxxZml9TnIDH5LFyh1ydX3zxV+76uVrH hFAHghKCCnBAMXL//fe7UpH1Iwgk4dgshNrHfvITnXNbaLd84lYbIiVFtvYlYi0kxfZiLSQuAbj1 wAMPqFwpFBJzzIl9bGAfvmMdnV+FE2Cm8re3ibJ6M+5nmv+UgTsvChbmM3EgsDZeIis5AboapWzb vm2bvIpqHEa4xyKQMtfJi9BJsCqsrWxhYdxQpjAWu3fvcmUCsHc8Yu1NzBvaz1wgPx8UDwQG27dv n+0UbhVKyYAXBNfci94IlBvHmzGPigWuKc/nF9TaBy0IrygamtSnOq2v1EWevibaH8vuqow4Joyl sranoEikXVGB2P7ovFz01CYqAByxbbFC3ul8Lz7rj++uKUV/1DRQ5gAELiAEnAnrY32+DzHxbn9O Rsrm4wRSEx8hxFPiyy2mbu0UgcL1zqPvsmcoLE1oxLGYBsImwkEgpDQR1LScsHRhRYV5wlQTrSNe Hu/rNkKqIvsGqth3Aqyi+iUBF4Q0mAasoixoy5crkp4WrWwxYs2+f4p+BxciFhIWyjQxEYtvXGSj 5G677v33XZM+ddJku3reXPvBgz9QRNwd9q3/8l9ccMVa4glY6n0NhphCgk7BwKL97mAOsV5i3WDf WIQWDBkMEYsJ72Bp+fM//3P78Y8f8oipFTdUqP0aEwmmCNS0HcpPWenu2tuqhfiQ7deCSvTf0WJ2 fDGkHjGqjA3/WNybW1LFjNZ5+PvBRfnS5A9xZgimM12WX/L5wPbLaAwU2lsIoAtCboGxwGM3BauO 9gwTNTWzNcOyT2RY3UuN1jCoyXKL5a6pf0VjdfZpSq0NGV1iqafy7MDR/ZbbnCsXyWrLqpEFFAFW 9CFP+NYkXEqrzrAjaystZVibjbp+pHA1yw4fO2rlpaNs74FdVrO12vKaVdclKD3UIKxyUl6lcm6t cAq1F+2ETgZaiZpHqZ9QiLnJfELZAwOJEiczk31owvE+JtrLnrKt27bYah0b8/nPfVZKH1gaCSk5 cnkuKtPzXAlLWZaak+Y05JQETphXPE5qTtW4AsldCAXbYOEMjCr7QzMz8mzzpt1yGWyQR8Mlgo/U P4m5Bqmg6cx55jRzlm9+tzN+CWaO3zDDfAODwOSpBWLkXammd6Afeiz6EhhSykqmP5RPGSSe4cJK pFrycP7m008/pYjNO23J4iUu8H7wwQeifetcaLrjrs+4Ag+4uFKNis5n8nYHgQHXXo47oj/QRrY8 EB8AS5nTtfNZr8oC3pSbprr0w+k/AiNbI15//XVZ7Ja5++jGjZu0v7hc+4zfsPLyMW7RxUJGirCO 8G2RxSxfQg1C/spVr/sxI9MVF2DSxMlWNLgwMX5h3AmUh7CF4MX6xLEzrbKohmPqWE56UF547b3/ o6npaxPCPzjE2si8Ys76ZPZvXfPdT4m1r01z5Stf+Yrt3rlLsRaecmsjLvJHtK8YpcT119/qcRRo Au1kT+r27du1Xg1zhStW0m9+85suqBJMEG8mzqmtOXnKpisI0WDFjWAs4lyiDPAJnHcipf4x5uAX MLjhhhucrowec4nDY5vqeuKJJ3x9J9BgeXm5yhxsOZk5XkZmYi4BO6ZCihR3rPnUQ70IxlznKtAY bTjXFPsRy0n+Tf3sr+Ubz4+QxHtojnOvv1LoFhV00T/dYisCvM756H9f+zAgnPYVcgPv9RECCSao j29fyNe6m5gQrviMa1K85wsli6U+cdrjBgMxcOEh0YFIDBGI6uVKQgYYrWSDhkiwcrP4yFqHm54I FuV7Xao2HgER6qEd8QPR5S7vc09aZX35Lf9NW5RHN7G8hgfkDyXp4iOT3LoiGMMwLL5psVsiXVCT VbJJLm/0Lz3BmLjAKDgSJIj8MH733Huv3XPPF1zrvXvXTmdGa7RXFKEURpBx9IUw0WNnooGxfnPN c+AdxxmLCwyq3tSCFvaxsN8FxhYLDDDMzs7THtbxYpAmaDHW/hjtU21qkeKgTa5CEjBTcQWUkJCh PWHFxcPttdfXyiVsh4KGHNbCvlgWkMHWKg19GEPGSCMpaSdPx2TUKyDOzh27bXTLCLtk1Gi1HaUF Lt0wrmovY+5j6tAIvcIXkJRQTIQfA3/7DQJCHnCL5Hgjhg4X0hRZx1MVEbegMU8HwuTZ0JwhlpOS oz2oEkYPHZDQKIFI7t+DGwrk5llkqXsbbazy5BfpbNTtwpsaKSj2NtvJ/TU2LKvMRs3WsTHZzZZd p6AfKjs3Jc8Orzxghen5dtmIUVZ7sM7SqkSLmqA/ag945PydrmV593NOkaKdOIDRCTwXzpMCvdI9 /6U/FKFHYS6QJ8wfboZ+Jn6HrFSXyItFIlV7IDNdAYSVb66smQjNTbLq+hETiTr1ylkl8L2lCaEx VUqiQZqDYvZkkM1IJ0J2ttz8sxUZN8satdWBuXbsaJX9+D8e01EfaYrYKc+K/DIJr3KRTwShg2Zw xAVzL1OC7v4D+91tduLEcs1BaHFUVqlmwQMFEswsCSZ8vJhzGGanW2oMwiN0OyZ+84ndZZ1oEaCw 2ob3eI5SMcWtSNCmGgVCqpN1mAi/6BlSpKgiQBPjw/BxZApW3gZ5YkyTEJWpst5552177NHHJIRd Y8OGDBWMghIuVUoslK+Mafu4xsb18J1Y5lQ5NObDCVqJxemzn/2s3f7pT7lFF1giOO+UEPOqlIrQ ZI5YiWsnpSRfJ/+O9Pb0mqDHEvY0n2KCga46XuXjUFg4SAqIXCNqLMLQ7fJYQThGAPr85z9n6yVI IjyXSShFGGJvLEIzZ2bihUIcgRhhuVHKJIJfsf+wTgrBtW+ulcDzU5up860Jekd/GS+2YYwdP07R iScqAvtwVxggwOFCnXYugilzDfwSkklN6cdS5Wj80xXtu+rIISlgc2zQ0BGa/yiihfOMiupt0d6B JvWnSdZ9+gJ+sjYxT9QqMMZhDh9BH2grW0WAdxAIwQvlSUKO5PF2y77yZmqSTZkyxSYI319+6WVb o20zi5cs1VjLQs66qfJJ4PeECROtvLzc7zHeQcGT7vtE+c1nguAnouRtoGrmCMnbpDIQ1lJBQn14 TpsIfsaRNezvbpFXCAqFOq2bUxXDYfzYcT53ieGAZZtI18OFC27Vl3cS6ykuvOAze2j55OZKeNV8 +4d/+AeP5vu7v/tlyxZOg7dAReDzvfua0R6cUN30/oW9zsHCCi2jPw5ftRUYo4CjvbSb9isD//3y ZHWt7Tt0whoV4K6F+8oPHwHcWPeDgpoXye8lePlejO45WVe+lvYgmtB4YCeaHIbAd2w5n8fvRBne AH4K5rQttJDHrZYtL58xwwptUF6WHkDzWBnIRfvULt9OFtqim/2WOqhmv1UxUPDHFgLCX1A/zgfN Oua3tIqasJqALJLhE2aRoz9zF7znRw8JAtBTSrZ+9pSvp2fJxCDmi/f45kM74kLl11oYmnEH0ULH c4gdzAlCKAsWiXwNcsdD04rWlfdZ3Pi4S1eCEAQg8I7e1QLSRFyOJhE+iKQTTAXmgemFiqlM16uz IIoR87q4VGaRSB57vYwICTc2UiQ6oS6/dUH/BIh0XXscYwi1GuqEEgYNi+myZcu0J2ifR7SN8B8h DeyiG2+UICiBTUwYzFH1CblPSpDFvXe3YH1QUU0JEY9LLUE7uA9OspgAGerkvchQUnZy4jcMEp9m WVSc0dMYAGWs2C0i3s262diYZscq6yRw1miBafQ9p5lZCqbUIG23BsoFTwkIixZ9UnuxPuNueSys jP+hwzW+wMPcwDyxmJ9UXTlZMGI11iABtUVuoBwtJMRQ48GBBCR98uia4Y2rU2LMHYbdCKj0O+I2 /e38OxkGZ3sdx1iFdvlqcr1dZujhZsSRmKW9rsSNrmuMufvn20EvtOHwdiYrkZbTcefVOLSKeVww d6ENLxkpV7RCucFJScKETte8FlNAgCLwhwBGso34N2PZnKo9ySdESwbLonalLPrKgwCEggncczho TreNVF165r/zzEaUjrRBElYl8vjwsxcVGLXDhXcCsugdPRFyMg8YE9foCx/JDx1jjqhkd2+P+AHT CJ7C4OO2juKFZ2GeSKEmOsi7MPIok3bv2G6TJ06wURztoXkm4Cg/yqD2FnU5KLQn4gntaL+GiRVM T1Y1SAipl0ApJU5eutw3xfTtPSTX/tGacy0SMBu1T7vUvvZ7f+Q0gy0QdbXNduqk9pnVwsiHarNk XWmo09E09Wpz0ymVU+19Q/lDnUHRSFvFROqdyspj9tOf/tTH4kc/+pH91V/9lcOJPrPeRTjF9gIX Z2ZFvznup01wE4CcBrEvmP3yjcoDk//mm2+6dalILoucV4qgtUVuyawZkydPci+NFgn3J3SkRoMY 7dqTNbZr5w4rv2SUjVNgtxvlPcK2BckosnZpb7PGCmaTtYFRpdYwul2C3JFEqBTWaMcCbgkGer+7 tG3bNnd9LS8v93F/9dXl7mqMAM1b9N8Fd10Do4grwMdpsGBGHlKEXbhOei6Bi6By0MbtO7bbww89 pHNfB/n2Cmjl/j27bf5VV9qO7dvdLffrX/ua6K+8W1THBOHemrVrrbSkWLgxVOdMv2hjyi/RGNMW 1an5ka6gUj5OKitLcywjLU9r83htDzlgb6590y5RfgLqsU/4Mp2fOufKeb7GwNN4gD3hMy7flBfH 3TvUyz96zXkgBKgmuV7USbGZr7Hb+8E62/78M7Zr1QrLKh5qcz9xlw2ZNU91as9y7Ulr0fzKL1NM BVn8UkVPNBXDuOsiHUFV+Xwea87AozTKwksALRqKZdIVnPAFcTIk2itSRIv8w1ynjA/Wb3BlDNHx r55/rc2Zd6U988wzwtk1NkuCYLq8InzOJ8Y4VcIs9fjYwssgxOmbRLu8Cv0FhlC+9gTyKmGJJgHP CFNX1gsuW3fscMXNbFmt2YcP3nA80PjysfbA137P97XicfXow4/a+g/kfv31r9udOvecc2zZipOp Msp0Li81Fwh2w4UXuMuzFufJKwoFMMpGAo2lCV5NDU12TOeYExfglLwXaAe46EKu+gse8z79x6XZ +RdwQeUx9xG86UOKlGJVJyvtwR8/a6nF4xWyUpGu1QbwVP99GIAFyivyt2qrgQutGgPoF8tGqoRJ SKBU8S7Mton/SG0RXDXmIoui5aKVBNpT5hQdMcZaxFgS6V3IrjYxrhpTxkBwgx7ntlTaJ6+bZEsr 5rrSJgSNZE0BoZiffFFO0jjp1/lOATvOd6kD5Q1AoFsIdIXQ8R4T5aOdIHx8SBBaCBGLLdcQHYIi 1GnPhAdaUD4WS4gyCQITF2AiR7Ifh8V8rs6jo4wD0tLjAtoGVfHFwF/TFWWnK6iHzlIT0zJ6hIRd q5U2UQug9kNBgGhTC4SGxUW/O94XbGE6+fBEX2QjV+KO3/8o/oG4kzhoG8KPGw/7rIgMCdE/VVPt CwP5gB/P+aRJOOcen1WrVttba9b4+WUsxgsXLnS3oU0aJyL0Mk4stnHBi989wwPo8Ukkhy3QDMsq FtW8gnwd4L7VDks739raIHenS2zCpHFyQdxhu3cdELMQcAZm6NLpl+o4jKG+4HNmnltntRjTJ469 AK/eVrRD3KmqtF+2rl74VTjY0YpFTBjp/0LttIO2hUXotHYmmjvw1f8QwCUfNy2t/5p0Yb9yEMFS 7Y7b7lRgHO0vFGOBcMmZixLxxGDwT8Ia89mbGHEszFRuOX5qrks89RxRvAjvi4GS4qZNlsSgEFP9 +of7qGvgeQMGw5Pwg8YhnKoar8EZK9Wu9lIPHwQZp3mUlKBj8Xn8Zp7xCCETOkg+nuHmt2fPHrcm DlWAHvZWMtdg9ojiSvkEIIJhgznqS8JyVihakJeXK0HjZe3hPiQLSalV6piW7/399+z66ypEY/fo HNRa0Y5MPRvitOC4lDzr398oQVv9ZxwE96LiwTb78tkKLrRf7+z0ebhVQZUmTx3jtLa1TdZK2gkM gZ1+AGeUWfQbqyn9pv/ARDf9mmehrx3rxF4dbfXSKy972/25mF/mOe9hgWUPI7QMwfQmKdyw1qkR tvzVV+2Rhx+x/6ytAwsXjlR+KeC016+8vFxupxOsVl4h+/but58qUNuUadPdOuTjBwerhAtzHEe/ cTZ/NF7qSGLdUPeT3oVWcY70MikNiQvAcStYGb/0pS9ZurZkkKorT7himv5GBj3iGc9pF8/Akc5t ZIxgooMShH4oSrMs5cBq167dfqbrytdWSuhqtN3CucpjlR546/Of/7zlyfpVrf2RWNBoPNY01l3g e0o4eeNNN9ldElaOCl9pF9tE2HOo6uTamW9var8qQZ1wRcdSCmk9qmA8PscEBOYIvjRx1tKXc0mg GIH9EHC9XNGSvPQsRX7/qa1/8O9t8YgiOyEr8K9WvGZDL5ttTRLgqg8flFJWwpW8dYbPvdJm3LrU 3pTymzGin2w9wWpNdFvWTmDBnMSauFbCOttmrrvuWuXF1b771oPfwBDh67nnnvOzRr/zne/YTAmG 98pLab7KyJfClzkR6QNjzJjGuRFL535MSZfxVrffsdw4r/gN/lFeMm5hGaXfuFxPmDDe1/p1Gz6w f/rnH3p+IgYDizIdFYTbN/u1mLL5nwAAIABJREFUt2zZ4nSrSHta98r9n/2vtDJYjDV3VBdKbYTw bFltUXIXl5T4HljWbvY086E9uI2DM8xN5nVsH+0ltcmjI11eVsPHTrbcMXMlXkqRBFn2iSWYaW5z LBTbMNi6g1IoBHyUBV1eV7opDywUa5pPijnAWuDCYyP0W/RavAVB8sQk+qeNoItiR/FiETPhbXAJ lnnFAChrmu6nntwpmixrsmgrLaVuhFG2nbVJGa7pQevD+/34d0A47UfgDhTdGQIgdPwkP+t/RE+u 7VyvI1GNRBLCwzX7XNAQQ7irxHw5UyDCQn4+yQsu1xwEzRECLHIECsjMLhGjKKLSDTggNjBFPEaD hhuIeBrXyDk9O41dONdeXvz3gakH8RBFhWmA2SUIA7ArLy+38ePKfTGKcG4RMBD6OTKDRQerKGHp 2Yd6QgvGYjF5uxRUaY8064sWLfID2JMZIergN+PRu8RIJA2WBg7rEcLl7Nmz7MD+A97+zEyiQuar 7EadwzpIK12wesXFNTeXg8ybxSwUKxokbm+4N4XIvpkZWmDkyzd65FB3RS4rK/KzXEeOHOZazVYt OCgxeSflNKtowIjQj9jG+N273p2vXMktOV9lxnL6s+xYR1+/fc4L5C60CS9w+cqV26GWeVnr5AYh hpvzLndu3y7XULn16jmeAanN+nQaqthPblMulg4CZoFDfBD8xk8cbyVDh0krLkZFzCFRXeE4UO7w DgkxLCQhjV9DnxJYrPqxUDjTrZvMB66ZE35EicrkN/PN20Bb9YER9X2bCHm0Tfdgznbs2GHPP/+8 ouFe5gq4kSNHutsn0Xph+kiU/f+z9yZweh3VoWf1om51q7UvliXZ7pYs2bIsG8vG4N3IK2AbAyEx TBbCFsgPwmQj72VeBuaRZCaESYC8TJIJkAwJ4ZEFA8EYbAsw2MbYeN+wrc3a933rVfP/n/qq++tW txZb7Y0u6et7b926VadOVZ06W1UpnA601sTLo/ijO+b0GVPTdddfnf7n//w3lFH3pEXnLsS6uAoL yFQEpbXppz/9MULIHqyP09iESFd7Xe/rUAhNplwsOsDdg8u9DLpLKMaNb04zZnJEBUifddIb0oxZ U4NZk7kD8Ri5ocHgSaFeV2XrK6P+B3/wBwFxmQ9ErG0jvkLo4epzW1sb64M3hcC0g3lCJlBlg66S umSaxs1iFPJkhsWVtG8KgoWulNM5V3MPGzxFXyCtFlU3X3vmmWc5L/UyBKqxKMfGBaN9BgKqbeb6 VIVb8yt94SjQ2y9JlFc6YuVNmavEgYKiDLl0Vxz4cxO7bVh23VjIc6BNF/sC0LeEo+DFe+strFqh 3AnXtMb53NXVEX3FdfrGd/pjXhg/bkK67NLLQonnjrGtreyaDn6fYL3tSSedHK7OOxHYFTLHYylb seq5cDNddM656bHHH8P6PBlX6AUcK7SZdnK5hWNpTwgywvRd+u8dd9wRux9v2bI5zZp5Uljeo/rA Zpq+n7Gy84EprgOQ5eujDObQg+JEBVZTDUrXrro0CWHmvIlT0mvpf/UNrJkGJxvuvzN1M96b+WEe Tg997+n040ceS9Pmz01///efh8cYh6C+NXbAVRB9/esviPHoMUZuKHQAPH/pS18KxYrrM1UWUaXo s4OBantYLRUxCne2hZsOeVasbXYK+Jce+LPf+77QC6/PNxQcS1eEoczbliMt9L3BMko/sm+55Eb6 Ytx17Crs5lzSH88m//KXvxw828UXXwSu/j794K570kc+9IE4fsm++9OfPhB5mrf52je9N1/5CI/C 0ZXd/q2yzSD/4b1lqfgWPj0d5O/Kt8JiHltQkD34BLsVjzmZvFk/W9OM4l2BMNPkbtq9VkMFhCZb jikbNabLP3piPxGUjnjU6KATwivfQcLD0moXdI8BT2LQYuqztP8g/cRmqMEaXwfdyfuaaDkVf7wH tlH0r1o8XjqlzRUBWb6Ut/FtZlBtS78ZvnC0XNjwQTCS8wgGXsYYGEhQy3MhMBIc7/050b33fe9j zOZB7jvXlvocwQFOOhkELar33HNPbM4hoVrAcSfzXcui5TQmuGpCDjFjUt63a0tactt9EJJlzIFO gvIbEBJcOZzE4gspTxXNEN7qnPxGuGKG8eFlHgq+Fca1Sv8UK6i4DiZZciuOxSdx7oCrVVW3LCfa 8847L63E0qxLj21w5eLF6aLLLqfGMEhshtIuw8N3WmWrNa/md/gg/qqQXJU4rDAwsePGNeE6Nj/Q bHadXRz0ze/kU2ak2W2cY0mbK4yodXcnXq9tWFd1pbQukT1tp7XXOi5YeBpQW080qrw/cIAdPtWM IojLNIfiojKpZXBodTnHALMCa+Ekq+AduR0eDDgM/Tn47MO2XeUx7rVyGD8ai8hdP7wbAWR3mool w/NHa1iPHExDFWhlHNig9g8F3mAKcQv2fECtZ5OnnJCmz8IiSxr1WAqUrscUCN3xvPMaQNlXIv9y zdG1cDrR/3iUycqCQRY0VKb5TsbN8aeQEUo1xp3rtbpg7O3Xjh/fy0BqOVi+fHn6q7/6qzhyw81L Lr/yqtTFOj4VTTGOqUulhwZEx/YHYZoxMHvOiem1552NpaSGo6NOS489Noo1cG/AzXVVeCa4hGIO 1pPXnL0gBMDxCKBTp57JuKNlQJZrgl3H2YlAr7A786QTY+zYhl0wcj0H2Rk7xiv0AuWSjJrD1LEo jrROKZyJH+tfaIhj17YTLwbfu9Po9dddH3JMuG5Ks/zGPuJyEPCr5dQNfVR03ovlzvwnT+MoE5jh c89dhBJ0WggDWkbM3/OZxaVCrDuk2lZ3330XdT41GORa2l0GtDD1x4bjo0ttudJa8XElikDPAL2b OW4fwrW7jO9GSNQN1rqID+G2LxVc+ew3MvTm5b1zqsK5SgjpqIo/+42D6UQUMfNZY6vArnV0MoKx rrwGLaG333Z79HfPt1Z5Y1qVlIsXL458f6HzFxyc4GpCehJ3T3f0/bM/+7MQsHURXY1Q8R+uMz17 YZT7xS/+Q3rHL+wNxaZ4pPmDNkeBjqdKW+fnF/a3E4HEPmYnqSNfRYsGupB7FzRyZu8YcDSWuf+E sbihY+VqJMl+rjvY+OsAawUxpKW58+am1zMPemyTfcPdhsW9QWuifUkFyGtoE9fWulFYa2sruG+u qlck7/1jG9mHlyxZEv1TJa+77UoLbMdCG8SFOLLcghff+f3zCX7nz77hXO3PYD8yfxV/lm95lmPZ hnjHe995b9/U+q0h4QyW99gv5L3sUy6rUqicPXt2WETzWIlsKDfTPGnF5s1b2Bn4fniM1yGgboky 7aeWrcCuEk4jhco5BfalS5dG/pZf6KO5rly9Id17/1PptEtPRP6sT/uh1aNYJ9/eBW3Bw6EeIRSg g+64XML+HwHPsPDU5ZtuhE90nQQWbkSHBE/2GRLrHqxFtJv8Ci8ANaJXoQhjLX4tWm3dgJ1L7F+R htsavLo8e1uOsgMFUL00RqGW/ldT4TOty3CHEeF0uDE8kv8rEgNDEdFCJCXQDlCfqwmiW80XgcKK F6Joegmq6SWefuuudZ6RZjBuN4d9lwkJMhDx+Q8TE8KphE4NeGjJnNwlNBIk8gw1fkxmPkrIqz5/ Bd9aF3GnBlRtrRZRcSVj7o69CvsG8Sledu1Ggwlh9rw/g2ti1GC2tbXFBHrHrd+OnftmzTo5LAxa LcpEZx6lLW23w4YQ9AYSaGGRpDtbHEwHOvbbQjSI/cSJmZUhXZxbiDBpO+d2IjVw536hBSrXpbxT lrC+e/eyPog+kNPpIoW7MxNGuOk5odDePfprDwyvAIHUOr3aQt4AKTNE9qtYf0rfsC3V9DueXefm mh/Xg157zZvSvDlzgxGR0aBFK7+MmWoUyeC4/mn7ju2xAcw4LFX3IMisWrchTT95ZvR3x4yWoFq0 5rHxUQwT+iKwVHKMPlh9pEzp8vZ9maOHcSVXsJw4gWNpECZPP+10XCZXhdCqUOq4kgZ5jvCCBfOD 1glbLjsLZOHJAPDWWyZNQUNBSsWRjHJp+wJVBbijuohXvwfa1LH/AOcYvwZmcW265Vs3Yx2VUd6X tuNK+jCL9VvGtOD6+RragfWkjEvd4jo7OYJGJUEIeLBsWLFlwLoVRtlQxvVZNXUylAqiKg2DC+Re r4ZRCA2538owa72UKXWM2nTioOBaxtmfuOniW3HhtQPlmJvRmFZ3vfjHVcWltE4G2jqqJFDw3bhu dToLN//XLDo3Nn7pwbtiNBvjKMTpproSRZzuv+JEmMY0jwnh1mfxa/7CYJ7HO5i3grSCojTaMhTc zzzzzGDgdSftpE9Zd9PpQmkarawG4RVOXYOth8y+eFFwsA95tI+WS4VT859+4vS0YP4ZaTRuqNLP bXyrdXTTpk2R/rEnnky7sWhde+0bQzh+DGFf90uPHHFtv8JyC7hQqFKxY5669bpuUusahaefcDTJ W2+8kf6CEgbh5a03vi3OcVV4CashShFhzqH/eH2hOHbtZZeKKloOUYHGQ3nCrvs99VjL6li/De0w 1IAXxIxUz3M7zIDnK4vjmWyW9/4PvD+1cpXP0NV0E/VbuPCsmON0d5afUCD1KDTr7731sUpDdRFp g328eD74LA5tK+usoFNdd+NVqKp07cNVxtix/PVb8/VnntV5qexvxq2/BquvDuQhbFmHkg6YHCvC 6vf2F2nPJW9Y3AvCO97xi7F5mLRJATZoIN97tSzLNIjbiRMnp5tuemcsrXHTqUb2krC/KuCKC3kO d6gWv3pAqGipDsIgz4GOIT357Ib0ldseSj0e81Wr1dr9QpgBRkHXaE8oBuuerbubYqqq4Ixe6qIA K/mRp2ii/DrSduPGXI+y0w0Y6yFkXSjb9pGZiqk4ZcD6QONUskGNoGbQX/+REX425CzNIh6BVaHX jSa7oYO6BevJRWGMC/IDn3433GFEOB1uDI/k/4rDQDXhGwh8IVLGZ8LbZy2Q6LkGQKKokFNN1AYS uUIk1dyZTqahr1wHfvXgd8LIxNly1Yrp5hQ8LGRGoUxy44TG5Ygh53XEZC95AnEGkqHI1B2iqMDZ 2toaE4RHJeieE8ww9bdObkF/IbtTig0nBnF8FeuJToAxUiDQqnAXmv1paNw98LuFCbkBQu63TjqW 5ze2XXU7H4oIJmHSKff1tlIIgUY4Sef2cGdAlZJatRUk3QwnNiSoWDoto04BQuaXOsh4xfbtwBF9 S+1p9CMnLiZ5AHFiML2TohNHXoslQw08BZpDBNLSKXqhPbRKL9uYAvvzBfDFr7N9yJ6hlr30I/tY KA/kKWEQ7BtwA8FEqPw+sGc/G30hsMCkH4SZyLWWMepfb/uozNPKVc+lP/7jP4ERmsRasYuw+Hwq LVu6LH3sY7+LC+25uJptz31axswxRB9U4IwxVfoJWVfkqygk3ONkPuhbjgctdwpPWhRWPrcy/Zhj NZ762VMxXp5jB1Z3PpUR27xtC4zvhuT5nebvt/Zb129Zb+Nkxt797nfHuPzrv/7rsAz+BhvVZLwA 38CK9q/20E/0dd3epYdjWhqBtS3d+cPbYd57gG12vHvmmWfSBz/4oTTzZHY3xTOluaUJBruRItlI iV1w3UBN0kmrxNX2E+2u5YqxTGMIJyO1Aq/jFXYOsD2b9Kyzz0qPPfFY3jmUxrS+jta8WRV30AT/ 2aheZTCjgSv5WpY0XJxFn6E/SL/MR+uWdMufu8xqHXSdJC/jvbCu5ygqv9elVji1hrnW9xJcfN2Z 3DRATCnHl93LfTQ3TTuM8CWXXBKu0VptnQuF33V4f/M3f5ve+973putvfGvA9v3vfz8sbx754pp6 +4tB2LXIWXf7ixbm22+/Pere0jIGa/ijYfHT6qcHzU6O3hqP+3Kh3eJxMt9oAb3ltiXpD3/3t9O4 iePTM0uXpnFsPqalbBcbXGndnXfaaVGeyhfnYF0zFYSdY9x92XGoRdE2+dOP//e0jP6+5LvfDldO 34tr5/k81gP84/qHLg18YBi67th1LeFBxmVeA446qw5eA2v/QfkA3iFbQEvwYKBPszsWSwVWpO4Z J6Wf0ffX0BfCZRdhQwGqra0tFEviTUHbYD0UsLy6YeVQQdqwdfvWtIv9HhZiUVZJEG7pCJ/2skxa cs9wboq1j9TFeU0vH/vF4YOteGgQLud6+5R52FcM0jYFwgefeTrGRCeKhwi89psYi9A952DnToNw OlcKt+8bUVRJ1xpRdMycNZNlFQh20ARpn2mslumMs1SVHNPYI0KexHrp4i8c0/B8UcliUFFl8Fll jLAYvCoYB6+IEDiWdauNEh/7krQBHIFKeAvwhTKiY8+OtGHL+jSuZXQa28RxYZzZfpDN9SZNm8Xm THiy8Onm1ZwbXdORWhBSO4BFS+fm7ftTwxh23J0ylbOy2c2asT92/BSKUekhLBYinRIT8Fc8u7ZV KmfrUzVgVDnHKRLgpR1lqCcc5DPerQi/YQ7Hl1oNM7Aj2Y9g4KXGQCGKEhl/5TnDJenSotW3Lqs3 TRAERjRXCZ1XCZoMoXkonIThiyyCyOcM46+kw7RqoqUJucwcJ4F0ZzonAuexV1MQd+IqXFahmBJ0 NbbiQre3ZUufCUY9cMO72W1z0nwYEJnNIP58L/Ny+ZXXBFru+v4dodGsAV872FhoJlpNcVm09uZj mU6Chwu2stOc10PkQFpIa6ftEu62Qfhd92J7ZSZMBrWBNSbdbsPHfQiYMBoKnQBEumwZjX7BN9bf idXv3aXP/hFXYHW+lclWyhD2HMq18hi9xnvLeyWGgfUZqg6mq65j9f1Q3wxPvH0pt19m9OKeyV63 WtuyG78sWYFRMEABpckAX4aoy05lW8Ya4lKHzFBpvevoOIAgNCotPOvM2Aho3PiWdPHFF2DZnIcF b2b68T33Yp1sDdcys3Es8PeIFRXGGHMwSB0wIu60qwvcONatTdw9EcFocpp3+rw4H1QaNxXGR2vL 2HEt8U46JPNs3T3iYTXrslzWYBp/Wve0bC3EmmaewqWi7fmGAq9afeHef6ADQfFMhObXhqX3vR/4 QPoK68rGsu5cfP3bV7+KBWlHOpm1iFoTXG93IevNXDcaTKZKI8ZSWbutq62m1C4EURnrOIcQfAqz ZYtT3U23bGfTM/498NAD6Y3XYXUjjcywDRu0nGwUVLv0mOCqVcI8Ik9pDjnFUg/qIE4UUN0wzTpF e5BWfLtsIcPJvME/LUTiWiur7eRRGp43qaVm5sxZWMPGh2VSWLXS14SwbWnHLxTlRhd1UnB2HtOq rnCpwKci5frrr08KogrMPmsRDqUh+y3IxCskWT9/ukK6kY3xClLWT1dw3d5fzw68WqIUDk2zaNG5 sZtuKChJJ9P/ExQq4uK/nUcfAI61KDA9pqQR117bW2XCtBNPSD998AGWwxzE1XhPrMFU2NyANVcY hFtXWK3ACs9vueE6YNkbddJjR4VMHlPRxMcPmVU5QSFY+6cPTp6TMAtCHHDJrcXjAqXkAeYBd8rW 5tWJUithdeuRtugaSuxahOkf/+R+9iqYGeNOBc0ddyxJr7/ggvTxj388cGtxCnYG+0gZT9GmhezE 274/9t0D0J/T5p+WrnnjNcy5s1EEdab9CMTFE8I+W/qxfdn2Na7MY325DbwbolCTAZ+0xXy8OjZL OXNPnUuND7JB4k7KZSTSF0KYrPSr+Bw4nJODl2AI5DGR93VQEaFiu7W1NayFPYzRWI6FYKY7rWO5 jNH4jvm584DzMuOPMpyRS36lRuI1+LxKhPf+7LePcfa6LuZNzeP4vgMFOfWGvrRTiEt8omzauAGv l23b16edm55LozqaaPOutHrlithXoG7iGGhaC3hvT88+zuZMdfvT3NaZaf3qZWnH1o1YVxvT9NaF 6eypjIMdG+Etm9id+AS8NcAdeODkLVkGIQ/cBv/AfdSUKJAb+Nq7a0/62ZpVaRY7gLsJY1au+93w hxHhdPhx/HNdQhAlCAsjgF8exA7Svvg+9BhnOgf6kbp/Tpu/zen78nkx7iyz/CwvwwP81o13urL4 j0TxkwhkgSVjIrZRh4jKk8qkFtx4mzcXyUKuhFbmK9aMcW+6YOpkBJFmLadbrSAELueSmUMZl0Ic RWuglK9LEPZqHJb4l9M1T3BMwkpg1NsNS5wA4erSWzjDroOt80fBQFsX0zaypqYZNzFdeNS+u0Pj 7bfflh57+JH0OtynPdduKQzyBJiPK664MoRQLQ6GggtxJs7Nc6hQcOc3TlxaUckg8qA1Al4nGGEK a5WTj8wqaSJf8rYMGc0SLE0hOY8Ny5f5zHAVUPreGV/gpp3NL0Co5F84RibZow2l/tXpS1w1Lkrd Tef70seqvyv3g31f3lVfS7rquKO9r4ZHy7OMkLgtCgbzNk2pQ3k2jaH63dGWabrDwTywLNPn8oRF roAuDNMTWnnFDDTorjX1n+7A0VdQn6upt8/4gcJU9Cf7Df1iyqSJ6fd/93+FmXbtVR3Pk6IuZ595 dvrsZ/8KAXBhOve8cy26EnI+pd4ltvoq3AU/lqWFSkHDeK1Ouq5qFdNlzXVmWgS818I1HW8Eg/SI 5LiljWY8NgWjP5l1WNvR3v+EHS5nzpyRLlu8mPMRTw0LYIwfcHI4fJpvgUtYrEN5VtDPYyVbLxi+ 6aKLLoqd0B984MFIe/FFF6CM2s6mRbfEESB/+zd/j+DGWbBnLUyLr1hsc5DOEShDFqWRp7QZvEfZ jlX6EG1g2VJa4bBN6lmb5bEibnDl+tqg8Yy7alwWi43XsKbahpSjIJzxla3LMWcIAJWIDUoYx+aX 44XLdAhxWM18L6iuCbNdFAZ145s4cUK02Tt/+VfSHexKq0By0SWXRhqVmwbHrD9hLHAW/Pts8Lng uDqdMAwWxImupvlzrVtuLHQAK+Z95JPSfQhKC7Aw60LqUpZMy1znmy1NCoXi9qabbgrrpH3K/mV/ 0318OwoA6buwKDxqUVY5IiJLHUKwZJOaM1B+vAa38R/ccQfr/qekSShVtOx6/IzzR7inozhxXpk+ 48TAzYoVKyKftra2UIDavxWi//0/bgaezSh7To6Ng9785jfntau4UltHlY71tFPBkbjx/oUGW0oa 79weawl5drMmRcndo6AN9LuD0IgW2rERV/UejiXpRHjt7Ma1k/lG2qG798koBYRH5dCUqVNCSbES t+niMu44NxTaEg+H+WM6hZTzzj0v5mP7iP06vC0oU0+kEALJw/bwPrxE6ANhYVVI5L70rSgKdMW4 YbwNiTk+ClphvuIXvHj0koLl6fPmspac/TqIK/St9K9SFecDyyy0w/fe5yvlxtjOHlexDCKE6ty3 FFAVRKXNBW7uyBo4gEWYxXEpu7r9zb/M6/Y9d32+6667QgnTMnZi2rrjAMJ+HYoIjQtYYQM/4sGx xBUhdTb7VLTv3ZrWPrcsjWuqSZPG1LL/yMY0qmliKMcnTGxJE+B7NmzfmPZ0QK8bOcN5zITwFGFi oY7QCXClAkmaJuT0pvirhdb5IxSh8COjQgnXnR4GzvoDG9PWzevTiudWpIsvvTi97rXnkx3zUM4g vh/OPyPC6XBidyRvMFDpyY7gcstAdpAPDGXgO7gHez8w/UvxPBCu6udClKDHQbT4EyBGTbmNq8SH 2Egi1SgBAs//CFS/cs03hdGW0EkK87NWOLSk7pLABioSRgmscdUw5ZxemX/Fpz+PwlAD6w57EneZ gjh+A0JqvBOm6dQkq5lUCymjeBquW7fe+p1067e+FcKqbjeLYYxHI+QqxIR2k0mrlDPY5DIU5tTA +l104xAscpPDPhLHJMNE6fvoAtzbLrZfqCuJdqKO9/EmeoZJou1yvjmutwxfRuBqtwiGyAgnXPtC ZjaNKf0uMswRR/xb+kzfhJ0n7oCZr8VXYWRMa7xpy3eDFdD7LnfjwZIcMS7nUep+aHLxIxxlnZBw haYevMgMKP+r3JFR8uc7FRelnuZY4CztcWgpxx5T8ipXWYLcNzKDJMMmU+cGPGoWZIjq2eCiowcm mmePlAoLnf2MtlUBYbuGcGubIwjs3c0ZutRda87eXbujTTo42mAsu7XuxZ1zO8xpMIZ8GWPEHBR+ +4W+xilsi68tdfac2bmP2uUoXybL8rSgCqP4LVaknWHlso6sp2Ujpgbe70KwfRrXXtO98U1vDguf rpPmtRtXSmHrcrOOFxjyVCJdzON/HsyqVrq/+PSn0w1vuSHNR2D//pLbGftXsCP2CSwH2ATOmsLl 9evf+EasSxTGWGNKm4R1UuYN0GgW8Kpngv1EvGQmVxrEQ1gptQy6JlTaIn7Etf2w9KuB1ZNm+XHk F+2qjJXxEAKsZfHeVEb7Lgvg5pnjxGH5LVu+PK2lvirvdH/VVXPeaXPpTwmX3w3QGpWXKjuyAC88 5VvvDcJa4oaCO6cUqsGDDHzUnXawv0pv29rmIKTi7QIN1D3cuUvvl1KW+PLeMenVb9xMpuDQ947Z Cax7Fi5/WlW9uimc44aH/A6wXJMrhLsQYC9GSdHB2G/Huk3m0Sbmq2DrWliDbe08sA7hTTddXZNb W0+J8hRQb7tjSfoWO9vuQ/mgUO284hyjssPvoh+Qj7CXcHj8lVSHv9obmCHiKBFEPOpInwKH3Qik u5nzl247kDbjKbBw2vjU1LMvdbHmumlsDQfMuYMrG2S1taZzWLoyhj4h3PYJ19nqZmtfdx2zGww6 fhVibRvvVQhAbiq9b3AY/d5f1JNqq1yzjYK+VhSs7hBu53UttYxNjAs7szwO7VU8xgJvPDtnZzfg wcs0Vq8Sg9/ajnHPd+JmP+fGx46ytKFwOf7M23vnWseVHSOPqvi06o/vnLMdU3mMxZRNakGjhzph k54roSvGo30n18NE1W3ufSnb9EUwNl7Fyiz6rx4ALS0TUl3T3vTMzs0IjsAtzSiEhlL12Jg0ZQIu u5zFiuXz5FnsxI6w2shqQa9yAAAgAElEQVSmbwe69qDN3hkb6s07tY0+fTCt3VCTprOrf1MjB1z3 1OP6Ow08sUM83gKNdWzaVkfbgjdU4KCbI4PoJ+4CzAwaOLXHHYSXUPj3eJ1TUM6MBuXbt2+LI8q6 WRfb6G7OpLcuDr3hDCPC6XBidyTvEQwcAwYyEyIRzhp1iZ6ELXZu4yrxD61ehTg74deqXaMMkr7q QpnwtQpLs62/GnUnOvHivFTunRyZESLeA6ZNa5rrrntzmt3amhZg+XHdlmtVTesB2meedXZqZpI1 j5hYiZfoHo6xDCQDjrBlGCgLbfEoLEW2hBvfyAQO1RwxOcZLW812yxNZ731lAoyXh/xBM6w11E97 C/Ch+lf9UW+i6shB762PePBq/b0veLCeCn8yJL4vaYTddNV1KJkbV0IwIuVhkOvgDENOqAtXVWUP +VpY2tnA5vFHH4+J3/6hO6DM2DasetEmdBTTuQZSlz/dIEtdqjM0zfEKJa/ADZlGzgUl1EnhLtw6 GcPz5s9LU06Ywpl37K7boQABQ9Xu2IbJB3aV2woYMkXm53duMCJqDsKsyDbRWGG50sXusssuSeNw Z5dBFI78DXTEcvs6TlSVt3GNLFCyVIfOA9mqVeJKmxbG0HitOQZhUuYyjX3CMaZFT4uN+HYDJDdd cWMWx5o0znxKP4tMnsefKE8EEVQKyVy24+Y4n81y3va2d3A9DVg6U2trGzTgLITJpvSpT30qBJH1 G9Zmpji+FhP8qI54ojqESn8IFFXjxvIY65QlPe5sl92znbQSFQY6vwt6LdPrz39cLcf/ZlspwcL6 BeOl71ISjwwSZyoHsmIlb1ZiGi2m4viWW24JnLtOcvbsOWkXfX/qCdPSf/mv/wXGN69hjfar9IfS lv0KPYqH0lsGg9u2NATzirWpAZrxhjdcHu1sP/ZoCuGXntgvbf9qIcJviyXV++rgTtAllOURIekI SKVOvnfzogjE7XWtHw/2ibjJb2J8efROBBLUN9RwrNCJbNi1PN3FWamusVuzdn3A+NYb3wKMCM1Y /7X63nvvvdGHFWSmn3BitMuhuASoXkSVm0rhR3mRzIfrN/WoYQOksIDFsg/OD957ID28mU21OJas pb4p7Ucx1Y0Ct2lfT5o1ZXzat78DYe1AuCuXXqsbqXTlKXatPsDmZrpZexTKkiVLYs2twv8VVywO IZVkMY6HArXQNt87L3zv+9+LzdM8Fk/vpCvZjftB3KZN5zpFlVVbOXdWenDttdeEQkelQJk7xF/p B3xy2GCfcSz4Tek/fqsHCVGMmb5x5p3tEF4pA/pAXyGMR8tkrJk+tyUfEeL7uGb6YpxlBIjlauRh gvn5ExcqM4r3l8drjZ0wNbWs3pLufvZewNQ6G2pIlGQIiBJTGw/eZ9PGTakTy2kDa1AbsZhvw4ug hrmhjg3dmseMpe4Nad2mrSjnoRXstDxu7My0j40hn374flx58S5g+VBX5960btvTbMLENkhjJqdx U+ek+uYpUYRzQk14joA/8Gu/m4er9FmvOTtt4OznzWxE5hFoCvgaQHSHV5iuYOIwtX9hr0aE0xeG v5GvjxEDZbAe42ev+uSZgOVqSmwl3hK0YEqC6YLAQLTUAkqUJboyJge72SmPZyfgIJqvIkyVCctJ zLqdc845sQZInMS7zJYHnsSJP7WnNZmzDEZIxs01SufBWIhPGSPPe2trmx0CSjDsTB7VTFGUR9rD BdPYHmrQH+dAdN2LdDOuU2gY8lvydPLMc1+/7G3/IwfYvvi4Oq1wlt+RczhcCvFTHXy2nkuXLg1r gTiPPgiexWMJZfKtfi73XmuDYaiOGXDfv9h+LwMv1dWteuukKkxaQpYvWx5reWS67AdLbl+SNrD+ roEdnVesWBlr79zJVGuIgqlCUrHWDFZvizlcm5S+WQXO0LfAH67fJQVt7Zj1EPcNG9enz3/hi2ke lotTEeLGIsC96YYbsOzlg+xjsxNcvqhpMC80SDAI/KnQCK16btaR4+1Gbae00h/Z1RtmqA4aoWAQ 69V52b+uhyK2MGQF1Opr/2+r34gr2pm2EGelj+g6aHu4I6v9SJybxvbx2V/55nB59y+p/1Owc+DC 9dodWKEVkg1ueHb99TcwMhinjMsTET4gnaBtFHiexz27f586h/HEsUwITB634PE94b4XQvpgShc7 asEZwhUCk8f1KJi6e7IeHu5kar26sWwHMwcEA/+VHALQQf6IC/HoGJOZ9czs+9g5VovdDKwu1sky suW5CwvHKemmd97ELrXPhPu1fUMcAwRzRF6vKn2zbuJ7uIIwl/ZUsFagtJ+X+AP0SWm39bOPWD/f CWu5Hxq2wYlELy4H0K6Sz+Bflbf0BxLYdtOwqF919dUhqBVYslU0jwiFMIOu7uJS92rX9BZByXfW JQdL9VeeK9HHeFHZwSgOl0/O8gg8aQlr7wR/DbVpE0q5KV3j06722tQ0pjmNHsMaRnDajSeVffEg cM7He8j9GVTM7sbTQoHUtd/ulqwiz7WoWlA9H/dzn/tcKJJU3Ko8GyxYR//Z/7y3LeVDdrAr9upV q8Nb6Ytf/GKc+3vxxRen73//B/TJ+aEU1D17+fKVeD89GK7n4q7QCvMQX/I9Q4UomzJtH4Nla4U3 3ze98c1xxqo03XQx9ngvrDZFWE6HyDjUHjZXJRROqmDAckqouq1EkaokLImqruXb0qcUUB955JHg SRpxvd22VwGenaOxSKJuDyWD55YzchivWEj3t6fNCPZd7bvSnm0b2BSJfofAuH0L60h37cBLZlzq 4FiYnSgBZuF6vm7jOjxbzkKgXJtWLH02NZ/B2ckoPJ968gGUl7tQgs5Ik06cmw60TGan67H0rdEI 9Co/JY4pFAkduztotx+lTcse5ozcjWnjpg3R16UroDbzN4cioqrWx+d2RDg9PngcyWUEA88bAxJT gxZSDz3egZvHhPETg/DqkjgNFwvdQeoQTFyzZPpRag/RYnlOVSi9+ujn84bj5fahE6DB+qJXDMZH 5kfm4Atf+AIE9wmEDbaQh2jqjqR2+Dc//OHYEMlJwA1EtNiccfr8dBqWU13vRsNkuCvhhAnjmOTA nXkz2VmWE0mUVXkeCh+2ky5guhFeeOHFoRXesH4DcOVNENzhLuDul4FCRI73rLCBofSBgfEDn2Wm +8+GgzW8cfwq5fXmMZhU3PsyT/Y+igvxXPCh25ebrLiZjcyE+BdnZeL1m+r7gXVxsh8MSr8zDEyf Y4/81+8sVzdABR/h1OXPI1AUQPfs2Z22rt4eFlMVG76XGZMpczzJ2Aysh6WWujxfuKohzyh3Ru9r cxklBcbmzua0bsN6zqPkPEsEKBn6Dey8uoYjYa6++ppgFBWAtDzb5rryytBhTgsrnUxRCEOmQaAy X62lISAUIMCRz0UJU6LzdWCrDHzun/qwT8Bi3yhtYlrbQKbTsViYWeMDvgpc4t/vCs59f0xBhgnh 0DOL7WRa53qIo5BgutQEub5f6xd3MPicB4mlE5GI9PxkAvkX3inAmukA0XyX7xXm/FXjRnrdxwD7 qowX61HqcjT9x5wM/XIHN7az/fM/cSlds3pNnEOp6+XWbVvTEwgTc2ZzVuMpJwUdUnB65OFH0rMo kVQG2F20rDtOo02CtimYuh4Q1z5gNwjf0cAYiQf8GQxu613aOXBQaeMQlPne/mAwTQnV+Cpxg10H eqNXDD2DJT0kzm+FtxrHJjIPx4XrM3V7njh5UpqIy7rjTbwonHpMiPDah6WBJ6MI8J2u3tZLgduQ 8UiGgZiBJUWSY/ojbKhbA76gnkR0dbLrdW0Tm/w1pWasowoxY+mzU2dO5YxTHnADpSrAXx/u0S0c i6IyTuWd5/w2N4+J3ZPtR86L7nisYNfW1hZ1cx8H6eeRzjm1IvYt29N+qtXeY62kw84RrlP/zd/8 zRCA3/zmN0Wexqkkns4utwrCztfSBtvfvAz22woCvekXoj9VYmwPx5tlS8cfffRR3NfXp7bZs6Md bIvcHrldqp/7ZVp5sFxpg6GUU743bqh73xk8T3SoIJz+igJGzwb70qmnzuW0gKlp9aZ9acODqyBF eWPLmqKokcYjNR6sacSFl7XRJ5yUxrOx274923lmjeqYibhpT0IBiUszXjbjp8xILRNPST2j6c+s P65tGpdmz1/EoKtLq9ctTeOx8vd0T00nt52aDrLLLyCw9II6Mw9VRHiu3BHXwF4BrXNPS+csPDnt dCd2BOE2PI7oWNBZFTND1fb4xo8Ip8cXnyO5HQEDRzsZHSGbV83rasIXAiezy+c++7l09VXXhGvM Lpjuq6++Kn3+859Pv/e7H05NuBwFbYAeSqTDalohrK8apFQqYl/RRVbmwp1DPeu0TEyLFy/Gfa01 /W9/+IcxAX/iE59gG/hZvYyEgqcTzpzZuK/AeDTCWMioOaE1cW8+ZdKyHCcQn7367nAh0lYSXHjh RTHRmrfxeuMEwFz6cqHF2Eggs0dAVXFDrGQRF2Eo8FTH97+H+esVMMuEWK7VKQWCX5RZFR/MeNVz 1a3ll1Bw4NVJVcHP89/61mn1bThUcGXawULgFFj6cj80VcmjvClprdlQ+ZrWvIXbyV6LgMySrqMy AK43diMU19z5XpeyNWvWxBEQ1sVf+b667r0wVNqjPA+8lvYaGF+eSx16hdPe3kBfo2/efPPNWKSf Te981zvTl//ln7D0tQRMB3DHW7NqbfreHUvSbayXvvLKK8LqoODZSN/V+hXKEfqQ7ld0VjbkGRW7 lmqtc7fHXZWddgNGALGeBnFZ7gucuU/2PT3fOwVrg8KmoQgkMp6Wa7y/Yq02rrTtYPiPTI7qDwyc /6hj7HpNfV2bp2VLi4B5Y8MLpqsHAb6OI2S0IsdmIxAWlUzuwhvrSqGsDgMF2Z7Yudc6Dd6vwWqk gcULKAs9KXU5FM9HVZlIFO1GfTxy5avsMPz7v/f76ULWDSo0PcWRGWtXr00zTpwV7qfuPrxs+bJ0 Nn3+teefH2tttbC6Dll3ShV3nVVWMHE1WJsLb4H96CHtn7J8b165ffM5ora771S0GkpfKOO+9IP+ uR3fpzIeB+Zayra/ev5pgbUoTBROS32sg+6ynVglFf6jvio9qG9fGKqkvhRHc2cuoVBBwag7rm1W NwrrLUKxxxjZrp7zPZr1hHtxu9yOhW06br66/ksPTmJHahaRxjhsa2sLQVAX2/PPfx2CK66eBPGv kGp/8dxWFRvOj46doYL4st5+K66su3TXNayuWTUvrf3ufixNVgD1G9+LY+ON81fav8ASR+cMVTDx 1e2gZVieQKFX7yjzFp4CX7RN5Rvvy/Og2YPsam8ny6lOb57927h/LmChf0TVk/kIm3g1D+chN9VS 0VGH5bJm9LZU/+g62lSl7z7OK4V+hkJSDwPaGAH01NPdlfog9B8vhK79sZdAE262jfQHlwkcMH19 M+WMSmOnjEn7Ow6mCVNnpdEzZ+F1sSnNxENnAhuL1bBF76i6Mag8OBqGtHXu8Mz3dt+aSpurqOFY VU4yOBnPkrnMJyex6dqBPO9IC6N7D13fqqq/4Nuhe+ELznokgxEMjGDgWDAggzcWTadCqm44Enpd zu688wehdbz7rrvYuc11HhzqfHA31hNdx6AWThZ8G3TjWAp8idJWE35BkNQV2GNiqMT5zgkHbjII vN/53jjXbJx80qzkOhcnQ3fobMF9UI2szL85Oim4XlXhxG90LzyltY24OgSuPFlG/uRr3k6WUX6l HMsfLJiuBiYguw/LJDRFWc3No7nKgEntFU5LrYCnIpxSA2JzGss6tgBj0punZcg8m0fJp5TnlV+4 J1qC+CBtpPd58FDqL0689+rELH5lJtTAGyfcZcL2vuCs5DqwXupmC2QlzfG8CtsFF1wQcMhU+iyD VgPz4jESMgb2BV3ySp2s30BGphqm0teq447lvr+lp7qNzMUze6ennz39FIoVGcq1nMM4Lp3AERe6 Quq6efr809MDrNv6y8/8RawDu/baa7GUnRz1cJdS+1msm7OZOWbC9Zb1uHDu3b8n/fmf/zkbu1ya rn3jtbzLrtixIU5FgRJ9o7RI6TpRuYFwHn2NxaVWqII3GdaisInxUhlTpW+VflOufvd8Qv4+jwrr aDa2NY2bR4ZCM/3eNYK+LBuVBSMcQqxjA5pCer6k3yPI+gzdCEEuvhfJWlnNow9HKgxMIwzWP3BA vzIca31KM1BC5KdQ7zmyMrH33X8fSpZ1afHli2Nn4HEwmvbx2OiFcmX8Pb/Zenv0ScG9uFaZoaeG V4UdYRTe6jDwufrdke7NSZirg2UUOlGHgCz9LuOtlF9w5ncvpPzqcg93b7PZBQYLwhQKC67iCYBi jgiY6TP2KVGm27jtmp/7+nrk2UtrByvh2OPqtWpxNqW7MqMGif6s1NDBMp72gyigcEVei/V0xthd bIwGn4AyZbxdj35hfVTAHgDQjsoaX13sDY3MVVZGQdwduK2P/cb2ivHKcyfrEodqk9Ju5b3fa21V sDWfIoR5b5z92DTuuixcPjtHF9pgur68+vfLALjyxzS2h/n30hMwY37m4bIa1xu7nMFxmTtl5he0 QEaUfaCSnzOSXmgloifGd3WJoimnFv6SLmhCdTKS+HqoEMov8omxSMK85pqjuoCzh7NJ97KRk2XX 0H5x9BzKB5cXMPviKeN8z5ExbHDnRkU97NJdP6o7ja3l3Hboazc0qlOcUH49SrKD7AVZ794X9I8u zrzdR6VrxtWmMeMmxNmoB7sbEDRZq4pw2tBI/aEH6DkiyEeqkJNnYLhijaWfgVOPypGu92AxlSYq MGc6P1SNj1/8iHB6/HA5ktOrEAOF7hSidlyryKCP/CEM/pOh3bp1e1h/anmYOfNECPnENAmN5JvY 7fKn9/0I4iZhhwDLPKHxl1DUMpHxF6JWoC1QVqAOoSS/C5c3Xg9LfUqxg12BUyouoZfoe81EP1uA etCEOnkVpgZ2EsLMVEAdQ0vN5xJ6Nzty5nGCk3H7Dc4ynILW1+8U5kNIr2z9Du1FIwnh5wsntNmz Z6fPfOYzYY398Ec/Wjk3MDNOBSbTmdeRQmzxHwyJmGRtMEyBZwn6fVhwLDNQLtOb42hhUgqPjK5M LZdjCuIkt2O0YC+jPDAj0/AbyDAdRjitrn+ZlHuZAAA1rvzEqQxBCWUC9tmeaDuXb62ktS4TfGCL 91H5ysV2rw6lGwfvUCm3+v3Ae/OWIbfdZDIVTC1fhqVWCwcfmEbGxnKth++th7BmWEyVQ8BauTdt efa+BONKfImrvg4UTkuf8BstWt++5bvpuTWrghneyIYXHuyusLmf3XZHgY/JUyeltrY2tNez05uv fzPrlB5Of/Tx/501SAfSpz/9qSyEAHJuh4Mh3HrclC6ep+PevpHD2h0Pzc0t9JnshieerWW0QV9V qsHudx/p+sUM/mA6f9XjpuDK+lpu6Q/SK4PxxpVvSvp4eQx/FDLNH/Yv2pVseeYPN5BI+oOCp2yO QrrKPF7JlMmBEUq7KOjlTapQyDD8Oztxf428TBRJB/9TeWd9rEP5DZ44x9oKpDxstubn8oPFixdH W7vpzPe+971QOFzKhld6g+xnx2OD54Auwm3dvqDngN8afHbpgYK346KHfToPUk96brx/Pn/8cih0 2J7W3/It2+foczxn/PQJqaW9yzW/Hyrn5wNp/28KTekfa/vnMlUIl2PFwjsB2mHfFK5M1xUwpFOZ jkSfi2+HB2bbSEtX9GWJCYjvRJLoQfCYgFX8BM5d3cwxJM2dSCTQ+XpcP2tZU1rDjr0H2Zm1E2HG nVj90H0QlMxVpioU5nGX922wnaxLr7BIm+WzfgfvI/baWE/NN0VQFIeOa/OS5oYHGOkUgM2lpPO9 acWY5bm7vjgWHoNtlLHps3eZJ1JYc+DW4sccayMr45uOHTsQ79i1M935ox+mhx97BDdXpC3yCfwh SBXYFFhjboqOkPEZkFgm5SuESSNyyFBUHnpxBoNVeW2t+M66WPcK/Pll/79RZ6L8Qjyv49xdryrS 92Hh3Lw3pcmnvi61ncyYUTYMpTf0CubBo2Vq69wdF9hpU9tTz6kedtrVWtptncgr4DcN814H33uc j8hsp04H2TCrFuVlO8u/6mqb89zo+eo1CsPigTqIJ6JUhNjFG1Dq9vA++C//otyyDVWIuiFSnP/s t8McRoTTYUbwz3P2MYQh7qGVojNzGwOiEMQYHFUIctBKk2KwO36q3h3P20JMtAQVAlNgskzXfTop qU3yWghoJrKSNAgEhFatnQTW+MgHIuU1tNRWluCz9TJ/y/XeSdC39WqVeS+hVrNPNBrPsem3P/rb EHnWoGFha2jAGgchcre0ubNnpXt//H+xUxrbJHDkRI1nnXHoti4p4Yoj/oKYeIHAQ6h0cSt47CMn mQh7ll+sf+RFtVsLXx9TKPmWcqo/FnfW3R3oRmPxXcdGDKtXrw4iGc3NJNqEa9IW1o7IWI0b55EB bjTCmW3g1w1idOd1Yp0yeWoI4OJUZkt3Gg/P9ifOnVSdvMAGbcfkC3VTkHcdWg156VKzEIvrLRwt 4xrRRedydAcTqO0sjLaj1pfQolfar7ouffdO9AhAfRFhlOyuuM1KwG1rJ8joF6RTKxlMcmhJaZfe SVkmPTN0kVYkDijb+BxIx7/+FtD4oPJ+wOUwwuiAlNEvLcf+bui9wghYF0U8f/JJMvb2Y+PzDqkI XNQnGBwkAplhenSMGxLEhKvg5H0E39Omjh0iA/fWrPTBUtsAJf/J3w3xt6SPHQQB33Uxosn6qPSg cwTsMlCCoHWsBtgVaE1jP3OXVd31ZEDlfcLdibJLPcNSRR8Rbu/9zt9QISsmylsypG+W9AewTHzs v/5BPHt0hvi0bwASV7Hs+jIVAIwDNsqYf/oZqfWU1rR+3cb0ub/+m/Tf/ujj6bdYW30S1hDduyax QcaaNWs5PmZ/em7Matzc1nPO6Zn05yywhy4EPFMgdWPsC47PA4IKFxkU62ywfQ2OC/uDeDL4niwi LuM05+t99TckMFF849X3Ebj3LoQA4iIvns01jmjiKpz2tYhjfMgQiRkGJ3EG7iM7ygxPhBxnEbnv wnDGvf3UhNbLNqDPUi/LAdv8qkYxcebmpjO9DHqUQbJgTMuDEPidQnHuZ4ET6mXZ/mzrghvvfV+u vu8ShlwBcjg0mNa+prLB9B6B09raGkqwJvPjE2k7LwMS3TLLPKXizm98Ng96KuCDQ57rwWsoZcCj 9+KYVxlH5Bf9o1LNwD/3XgtfLqRibrBgmf4Mwu+915AHhKHyrvQR35VQfV/iqq/9x1P1myPfH823 li/dsm8IVdxX6mAJWQki7cswa3UKTEATIvSjtbZsxsNQuMofDf2303mM8kfXNXGlnfmJPtuCA7xT 6wH2omiqS20cMzLhJN074WWwlm3eD19Cmh7ojTRHlQStwkf0E9pclDs/2Rbh7i09MED/+kZCrmN+ cehfFcSmUFiKlGZqgHaKt4zvXHPfOP9GH6BMLW+OOgER0ypLKl8TRb585r4KzMjUlfQIpirfY6xx Edxu3ttePQiivvmFd/xCuu4t1zPGyDbyNpZQqZtp46xS8jNPx65ZHvT4GPIy/7oeocq46EEIFrqy kZ/jJ/5FG9unzcNfBXfcDRXs6wp1eldJA9z3IMNTk1as25y+ueTe1IkwOAq+AMNoHPNiFwscEFGL MqIG2GoOZlEt4I72gy7rjUWjeZRPBskHLPxiFvCg2uDXjaZQuAkg8KvcEHItsWSKXsP24lrBy8Eu LLlY53tsq3rcgO0nB/iOuVE3audo6emRa26BLyyMCKcvDH8jX78MMOBgLxPf0YBjWr9ZtmxZTP7e +1ObtY2t0Mey852C0saNGyNfmVg3FvCICtPJrMmg6qrSDiOwqpLOZ98r6GjVkzDpxuGaPddjTEET LkPmgDfderRoHmKf18TNTDOmn4y14wBuWlvSqtXLYRS7sPadSjkT4pgImZ3drLGYMhXmGM2WpLgW nw4n1EyWJRlQNqlPhDLdSLJLZH+yItPh2+EKMrQSZTduUQjU/czdA/eh9d/MLnCjWbDfjYvLnLmn gquO2BzmtNNPZ8e5qWklGxi9/wPvT2vB0wQ2sbnxxrezIci2yEfh7iBCiJpa8S3j6ZTmlvJORCH8 qAaEjNaDIwXjJbffHgdge8TBfrbT1+VJLa/4N9hetovwHmtw8qoOtrNR2fUOuIJR7Eyj6Td1MDbC V8qhyKiD/SomHyOqQvRXXxjcBeNFDblc8WIQ1+VKcwYDbD1kgGT43QVyC2PI8eKGLtNxu4aLifZ2 R1kQDNuRx1BrW1uMpchwkD+WWHrtIK8PH8XHuncHZABqP5RZl/l2YyGPPLCNVJowyONQ9BNPPDG1 AdMGdjx89tnlafykyXEmnWPUse8xNCq0nm8odEdcTp48JWiLlq3gKGK6z/3VWsvE2acb2ZxCmtDU NCb91m99NP3au3897QCeO+64I/3e738sjrfQpdkNwpayK/G//NOX0kc+8pGgP9ZX+mPfc+xFn9MH jNC/h0UUcbnvFzjtj7Z3fEceJd7UKhaMty6Wo0Kn9A2fHUuWVMZ/6T+5pAF/yYMaZ8UQ5ZVypLHC HaEK4IF5Vb2qZDwwpvQi4yvCRG+S6nfRPSt5KExWbuPS74EY6G7lddQfuAtc1XgwzvoEPip1CXrD WAkaUV1E1X2MqUp629A8nYfEp+vTxE3JVxrmfWkP7wttiSwElBvvtcRZY9/7M9+ifCjwV4HRexvf 8PRiU59eAF6CG+ssTgu+tKCKLxn5LKyGmDUskKmMpfOzNpAlKSC9oZF+hGRax/w2EaXT9NEttB99 ef+W1MQ5rrUIKvs5cmZ7J4qupgnADNTQEIUJR1dUonTY4wTxoNmJrAFh4Nzo6/JtuSpNSatjvDh1 VgRLp70QrbSeKrZzIcgAACAASURBVERF3v41rfmguGdTxJaalniO15U0ZcqMvGMgwAsQaS7KYlk4 heZZNgJepsNQCIVTylIRUGcmpuVfVgozfwQyjfObeB3Xof44HmOsArDzYhmb00+Zk6a0zkv/+o0f pLr2HanJutLmPQjNPQfZMAoAGKHABu3l3NJoS/ISPgVKlxYJlnhTnLaMg3zjsTB9LsumIeMI+V4M 2H8NugZ3+x31V6VcX7s3NR60P6G4Jf+D9HmPzJIxiWPDmD+yAit/H5kM058R4XSYEDuSLRiIMZEZ 0qPGh9+EhsovyqA66q+PKqGTsQzCZz/72VizuGLFijgU2Y8lHhdfdGGaiKD5iU98InlovBOS26J/ 6UtfCoFUa4eHKL//Qx9O9952a/rLv/zLIAwexq5mTOZcAiQjoeb7doQi14z9+q//eqwlNU4m/utf /3ocf+HmLdddd306bR5bvW/Zmh59/OF06WUXISCPYUe9+9IbFl8BsapJP/nJ/VhINqTZrerEZE60 3nGWGwTJ9QqQ3qOq/4uZqBBm6B/NmdtTC6YM1/59uCEB95y2VuhnLevwpoGfrVx3sNaWg9HXrWWX wacQQLvTnr37wlVxFBtCRZ5kJ3l0MstCJQQbrEhQYad5A2NBu4WmtsK8qTBQAHHTGIVV21XGUqiq mbVj7nVB6PuItfDIPMrYyFC6Xk2LjfyGB2tv2rg1rVyZjzex7WUYe5wECUMxiDHxOBu/FCG4ACbK CjPrVUbN5hQu62twXD32yGPs3vitWG+khdzxs3LZ8ti4Yg19Xnw4fvz99u/8TljGh6tKZRJ1rAfT A6z2B93E//bv/i7GZ2tra7hNfvrTn04f//jHo93uvPOH6Z//+ctp8ZXXoBxqC9jvYr33O9/5zthF d+9eDkB/gcG+YbD/lSAuDcKqQOqmTe9617sijenF+2SUNJ65qKVMN3V325wzZ04oAlaB7zkI0NPp 4/tQDJR6F0+AIoSU8gZeFQTLmLIs72OsCVel75V+6MYZ5V3glrQKweV9WCf5zrgYYL0M0sBS82sI XK8AV/KwztJQ8xce4w3l2ptTju59fLFu6sQXsGWBJVs6hVc8OybCQlkBRvgjTqHd7yp1GQzWwCfv TVfqXWiKAq3vbVvfS9OK8sT195bte38llHvzyPjMSriSp+8tpwSfD8Fxeflzdo22os7ipOBRxt55 xhln+AJtgiCgIq1bKQmhdD9C6OZ9u9MGdnCdzNFH01pGo+zEYtrDchbmkPoGPH/YvVUPiFj28zJt x4LHatyJ03rna6rqewWmPCUinvWOb+lQiLD0T9vDGV+lGO2AhbAGgUoKptCp5bFv80A+I7+gNCGE 5pIdIZKlaEnyoteDR54r85nLpHqIEKYIcZPTCVM2EJBrwFRJM+Bi/4k+ZJ2on3XrHVtoHUZhqUz7 tqTunauBdztWbzZsoy21oeqGXytfZ/5YTukRpGHutT/w1vNGM2ymN676WnkiqsBvXfN9/k5cWV/d g5mJUDByVCGbMtWmPameI2eY5Ckb+HEtDkWupZi0gh/uhjW8/LjZYa3uSOYjGMgYcBKX+VOQdItz F/WvWrUqBEgFhnVr1gQRMU05l6oQFYnMs88+yxlQW0LI8mgKGUTXeCl0mrfbtEuIPN5EpsGjLJYu XRrn1cmQWqZpFWa1yjz11BPpyaeeZH3peDY+mRkWmilTTsCy9wwWxs0AXU/+e9mFsSUEAwmplhUo FVcJdYWZfJk1cAh/TgwQUplNhRV37HPtxfhxLWkcWs9n2YFSfCi0f/SjH+Hd+nQBGxz5fNc9d4fb rkdtrFi+nB1jF4broYyVeA7Cz32ZP/pXP09gHUzYnVi43TRJJYOCsbsaypDJrFWHwkRWM2vV74/m 3nYvwkS4iTHxFXi1ev0I67E7cdovfu3Xfi36oTx8KRuoBy0m97/B3w36wXGILNNduCgCl/9CMCVv XR+tl3AJuxNfC/2znG/pphyrnlsV2/3blgcYHyp1rHc7zLXf0nGPA5RDZ2FbGOwrBuFcvz57LNgH 7Z/u7nvJJZfEbsSmnzBhfBx3oKX0Gfqm8CpM+07LhfUt9Y5Mj+FP9NfD1Nn3Dhf12NKZsrZauH22 X5lGoeRqzmX0Wdyq/DLMgo6tho65iZXfGErdhT9wHrGH/hEsPRJ0bRZrlhd58OD5g+IqhM4KLDKH lm06+4dpM7ZpVtpW2KJsK3TYQJ157/fCV43bMsar4S5tWrIsZZbnF+uqe1vdqL4xIKwF3tJHquEW ruq6DQVn7gMZZ+LW+hbchLLLMQfuLUulyUMPPRR0TIWFO4HqpVNwVK6WZR4qZupYkuC9wTYymK9l GSx/JEiaHO+eZzouNtMT384djgMGSvT54cGTAox9RcUM49e5He+T/bTZuuaGtLxlUlq7bXdqQmHb jBOnu6vSSxBee9IazkDdMh7PKpYDDQylXct14PsX47m6Pw4sT1fSLHryxj7PJa+xpF+i4DWERVBq AV58b6o4RusgfTo2HTSO99GHwUqRzEjrrUKr6f2aVBVhTf4BuiMfRVxvUDglkbQ4son8FeiOXinh eLfO9h37jfyGY897FUxjGY+nTp/IJlf72MSoG+spHikU1sOyLbgTXO+poUBQtgp8hVMFd4NHC4Zr PykDIRFb/lCXUpmcPL/g3rqE/EtM1FnlOHmEMI/VdCybJc08YaKadARWYAfWWjx8pPexRIrvqrMs JR7v64hwerwxOpLfyx4DEgvdSrU8uOW+u7hqUZNJffDBB8Nd1Hc33nhjbDahe6Jblr/1rW9NKysW L61CTz3+aFhStYi6893Xvva1OENR4XbRokWZaYM4velNb+JIiCuDSF1++eUx+Zuf54M9/fTTMMMT 0zXXXJkWnLUgrV3FAdkbNjMhsrtdTQOCy6lp5Yo1vcxmrcQ1BBnduNSEM4FCWMJKVCFaL7cGCAYN Iie19DgSibPW0xXLl6afshOlu4xqadTF8Ud33xNt0dramk7Hvffiiy9FW6f2DhenA+7GB8HWpY08 8MmM72SszNM1g16dfPMkWIQmqbEENcfLUJNDoCksq+Rt+sKMO5EMZCoHxalUvv90FsmsS7FaSdBL mjxJsTkBDE5MTGPHBfx+JBwZZvN8+QXXGVmTGiYqz9LU3UeBRWY3cF6ZCbWoeaC9bTmO+s1pm53O OffctGbtGgSqptjkxXPpbAOZ6CJsVdf4uE18ZCRshenOZWTFwe9gtVU55JmoKpo8e0+Bz7Nqzz77 NemcRedxkPk2PBVWhwJp4cKzwsIa1n76l/nm9qqG/Nju/X4wRlGrjPhZvnx5nHP5nve8J5gZ07tu LPopAqRX+6k4lJ4J084dO9MnP/nJ9Pa3vz12MI5+TJfS5TrwcJjuFeTD/MhXuLSkav2zXNe+Guoc e+C1hufo48Cj21cj68ZlvPzOTcm0ZthPHCK25+HGkyAVi6AwFpxYH39+a3zALxADQsXpYEDs8D/a Fq4RltGsbkvvhdv1d773OQR1xkR5FokDWOFegE3vz1Dcd8PTBOWOFnHdehtpB5dH6M2jArW1tTUU Xn7nPDUYDRMmLfK2m21V8Gna8mx5IyFjwHZdt5YlJXgnqDyVRyiCv2uz7Zfi9PgHhQWFMeYz/tUw x3e3p7TggovS3DPmpCtfuyite2JZ+vY//2vaCo1oggNowNV39CQUaOMnpzmz56TOhqY+CyB9zVD6 VDy8zP5oA+0ClwqbWURFMRYzDmOhxj0EnH3ENT+ESwXRqJWWPQiA/wwhx1Ff85PyxBQdb/r+KKA6 J9dUCbO9QqyfmWeFTnpR8Gckc2f5xPA+n5HM4xFCoWX2lXLvJ95bgynjW9KvvONGhMRGduPFow8h HKqOUYJErA+to58Jbuzgq2AKjlATRqmjgKMu+Itc94js/VOpQO9z1Y3Cud/xUzhVUlUx4BmnKhVr mddroTEHmVe6xbP9Bzi0yIN4aHVVXsN4OyKcDiNyR7J+eWLASdm1Y1dddVWv5t84BVWtmKMYrDKH TvISlfe///0xoRftsoNVQh8MBxO7wTjd/kwThIeJzVCYbxkCJzvL8VsZ4V/6pV+KZ8uUOdvLRgdT p87AUtOGAOOuejVYodpivdmuXTvSZYsvS/f9+D7SPsI7rIH8PJ+qBq1hJpyDEakA4yX7Y13jH7DK mFl/cervlNbWdP+9P077O9tRjPak0U2jA88yxzJJWiY6WVcqmXU+ICsQzZX3wfyRRotWIzg3FEbB a5kMLN/2cFMp4yNNJY4XpHNjq2yFyO2jJeEwhD1KOvwfN0DQVVfi70Y7bsEuU6gCYUxzU2gin3rq qbCquyOnAVCivofP+cV/W/AnTsRpvopTLXII4Vi0VbCsYn2wVlE9BcYwthoaGmlvjjLg/L21uGcv PGth2rJ5S4yvszjuwvN7Fb5kjD1yQJS/MKz3x03Jy/yj/St9xv4nM2+9tIxqMfW9Fkp3Q7V/nLFg PnuO7GY95zkomc6p1NujJNhen/raT3IopfQv2yfb2jKOFEBjCIEKgt7HD7wp5IfQyVED7rapwBdt QV/yn/ceRyC9aaJPNTF22nH7W8eRI88sfZa12VvTuIkT7FQheLjBWITDwcS73Mawh5RJIcGsCMe2 bdvT/SiSXPbgGnqtdCohtnDGongRcpV44lKlkson13ZHR7FM8/I6WLDSUXOTWU/dneGAsPAJ95gW jlPAIu9ZxYaB+fBFxL/Yf6LtEApaOlgTbBv4Az8yddFWnEM4muOlou2AUQYYypdxTP8QV4MF43M7 5PnD/macNMMN5bSaNoPbr3/jG+nyyy8PherXvnZz+tSn/iz9wz/8Q3imSFdsF78r5QjTnj17YxfV U8fOCbhiJ1fAiI3kpFn8L/gF4gH/BoP21RsnD/BNPFw2blif7r333hj3V1xxRXhIMfPmuWSYqu98 54ZG4UfJWOhh595LL7sWAYaNEomeceJp6b2LLkk72JV7DLR2dCNr4Rta2FFxQupGstndsy/3wao+ Zj8obTtMYD//bB33sUGRHVDhk1+44DIWWFsbVj0FI9IpwuZ+mgVZ1fNubHSQdI4xRxk1BRbeB2kQ mY4//lYE03g2HZGll8cnPNfBdygMgnKslJTHWO0mI+U43sQ/887BmMOHarzL1zgHqQwK3gAer8fN 72pZKkKZWkq1iKqQqGW81rAMyFKtsP+EJTa7slRgddOsYw/SF2rtp7gWu5bZ2rjulGiwqYcF+w14 h4FEfkY+yXSjVOSb9nmVe2yQjginx4avkdSvAgw42ZfBJZEwSEC0PoQACgNaLAa+kzmTaXUDndiI pzIwRzEJ5HwY7BAcB7ShE6agszIpmK/fW6ZpdH8zTubDdH5vmW7iIyFoP+B7CQcWKnZLkzDpVjhz 5nQY+02sxdwfxMEd3Wo4RLmhdjTCdBPrKA+g2UK9yrcvp2D9/EkMdc0pwvszzzyTvrdkSZyndQKb H8nwPvnEz8Li/CRM2H/8x3+gFPgAjGkLZ3NV3JskmOIwhKSatHLVc7hWb2XzqNWxUdI5572Wdspt a3vltmGCQfCVsIPY+F43lcwE57awqfzBycfV+/LtoLiMtIO+iUgJucHdMLdu3hSW0jlY4m17GXiZ 7HOxJra1tQUDKRNkiDIDlpeOibD35OpV/oIMrW4hbIMfA6iNPqhL4+4tu9Ntt92WHsCN/YYbbkjL li9P373lVnYXnRobis077fS0c89O1kFOj3Wcjz/+eJpGf34OYXbu3LnpQx/6EDhnPICb4xmE3r6i 0sNQ3Z6lD3l1bKoosl1uvfXWGMO33f5djnTalv7fz38+GFE7RcYGGTG+on2JqIqNMqr/OAx9X11u 7/tSVdMM8pPB0lOgjs3CQrgB75npymzUqMZRsRzhi1/8YijUdJX/8pf/Jdzh3/72t6arr7kqrd+4 Pn3zm18P3ApDEaiL0BMVKnBUAAt2qxJnm+Q2R8EAnXL5wyOPPFzBVT7CxDx37NgeViXXil9wwYWh 1NMTxeUKtrE00fJDKdSLgP439i93rxW2ks68ZeSeZM15A4fIb2KcB73k0962qGQzKI77FzEsT+LH HSw3b9qUluIFcvuS2wPP4kv4R7OTsp4hbpRnmxmfj4dQMB0apFKfmHP4RoXAwoULA8+hZIC+1FO2 yyO0/juHeW6u3jyWpRuqfbq0ecGp/b0OeE+Z2Bpn6no0SSj/aJ9iMY1+ZqcklPvea4z6wwA+dJVe sW/E4Vb6nst+xK30wrHhP/Fa2ur4VlD8s6kf48HlOnUoQNx3oWsf9Ay6oNDkJjm1zRNT89xJ2auI Tw524zbajiDFeayYUongeriOdnyBft65ZdKvgIQyBZEooWyvY/1obbf+TfwjwcFa6wJdNHH8BxfO R9bPdlCwrUVJZt9FaItdeeGhatlIiEh+5qFqiPchoBrrfJ/7c96tNoucdVoLwbu7gNv3/So4MeJy XqQjm3Iftz4OEgb2jzIWja/BhTdbb1VmwSNSlv96YO4QzekBlqB9ldiAw6rhZmsdCLXBB8XtoH+G hstSqH3M63wa/TnQmOsFr9YhzxuCcC5bGq2+UFjy2buDFnlcI0eE0+OKzpHMXikYkDiUyVuYffYX k48WPu6D8DFwZZpiMsJS5ASfrTF+RWymWqFxcsCHuw/fFCIUxM9E8SNPy+HLsEGF9goHnogjhmdL Mg20oBemOByZ+DijjnjX/NXXjEXwYU3fsv1pz/b9adr0lM4816MxsiAtdNaHv/Evk2BjX9xQJnCV wMKQYWI3fA6OX75iRbrxLW9JP7rzzjRx8qSwSilIvu7882G01kRbmF7c82HgXujrENoVMNeuWRMa 7Y0wh7odnnv+62gycAgeDfFttIVlM2lLcJnI+tbH5XS2kWlL+vJsHmXysg/YX/xe92GD6X0uaXoF XrWvUHJ3cr7//vtj06sLL7wwXEdddymjr2Am874CHJx33nlhWY1yM5YiT/M/llDgLzj3uZrh15Lb L1Rn70RFH7U7a+lRAFNobmTjqOjcwKVngYywa6vD0kf+wiyTfN1114U76PInn0yts9twL92eduze xaHxHrrentxkaDtxppXZc5zJEJcxKKPvlJxHB0VW8B1rdh1/lOMEaXzuSbZNqY3tl+tWcKCbdAml fbw6fk1TcFSYcvPVCr969Sp2iV4Z1tynnngy1pLbX4rCIVxdK/AUWMVbcUulV4Bmx3G27ke9+N6Q tdUZziK0CXfO2zT2Qd5TzwKrCrPqIL6EWUFnE2vRGxp2xLKEHbjzupP1zTffHNZg1/2uYXwU5VvJ w3yr+0UfvkAmcBeUFpyV/uP63M2bt4RbvmPNZ11NFYJsX8tz7b1Cqf3Gq2vsizKqlD/Y1XYNugle rZ9lW675SCfKOn7rUtqtwG1+3r8Uwbb1p+eLmxK5Z4HBvi2c/qyDyzysj3DGGCPePjwU2Nbfbw1e xaFeCa2trTHuVHLaD2fMmJm+8pWvRF/QG+BnP/tZ+uAHP5hei5KgWwt/RVmqBZqddWLAdNJm7Vjc zdd+ZD8Ur6M41qwRC5xt6s8gvAXPpT/Ei5+TP477mTNnpM+w4eEZZ8wPAdWqS0NqGQPD1+8Y/5CB mth1R9qC6zg/3Ty7mFuEq4Z2a3dpBb8ahBmXV0g3kOdo60wbq9ustOPLremqcahAWI8nWD3r5T0+ pZHNgbQmJlxeD3KsSlgvnaPAQRxhRpXFh0p9eSTFNqWrIKEVwbQ2jlLJtcZJFY0xOENIVbis1zJL OR6r4g64SIfxbddeLIVYC7Wa9nBcX4zEoPm0BflSeJ57hMOs4TkOF0o7WFf7js/+YqM6DAxATNEe 5VPxuDA7LarU3TNK6XF2BmVuyuYPOIg9RqioMA4VKGXQV1L5vKGT78FfhV+KxJQdswD0IfhS177a BJFVngepRp7vBs39+EWOCKfHD5cjOb2EGDgW4iujYChEY+C9AzY0bA5CCYkTA0GaUYuAWt5FjJEG RnDkGgMXgpdjGeD5GwmQ+ZJdhKAHPiC1xXESjPg4D5aoSAs10L1VRrceC5WhqxvNu+eb8k1D3di0 5rld6Tvf2pZ69tency8YmxacA4FjApMxL0z/seAlCjnOf8SfjFBmzCVuWdBwfa+WFpm68bgfyoBN n3EizzsQYKbiWnkmx8lMCWu2IMnUBQallARdTWbBsMkAi6f5MA85WJ6TlxNIpWypKWni7DoS9VrF c1aRzm9Lf/BbQ68igvwacdHbhBDsO+Hr8LBvgvUpuM49RNLOZFOB0zS62AnnM7i/6sKqJcR6W2eZ e8vNfZLJzwnSjwgFnsoTl9yL8nPf3wKvV39F8PF7Gc+oh4J13ydxF5NdJS5vdGM3pq06ugPGxx57 LI5buu07t3KUz0SEk01pHoz2KSefBJ+k5Z9dj4F/8eLFIXQ+9NCDYTE94YTpIYDLpPvTZbaD82av xI3+lJNPiTbVUqnrp/BZd+EOgRdcMy9HMN5WD1TyPtb4UadwQeQqorzwNyZPlTaGcn6qeHTsRlK+ N3jx2bzFT8G9jPpZZ53N2aEnpXf9L+/CEjUDTwk08cJgUYzD2CxI/NAXLTyUIGRofqHRJ62MY+ln WVkRxUYfyYJo7i+duLLvZUMTrTH2V8d+MET0a2EWH/aP1tbWfnCam7jTrfaTn/zvoTBoam5J56PQ USBUcaBAZzt6/t+0aTNRyhyIdtDK5zjSZThwR7n+CzyjTIkeQrnCGWtGYYBDWKbMZ59dGm7PukIr jF188UUhMOmubrmtrW0oW/LmV67Nmz59err88ssD2fatwwV7dRyTEGVnPOe+UB8eFVdfczX7AZxL HTpCKWV/VoGilwSoD1wdLv9hewdjWMdOlh6J5R4C73vf+0LIy/2yglfaQUVCOXtUWGzbHIR+8FDS 2D8NjhN/xrtLsGdxqwz4xV/8xThGSE+Ut73tbaFguXPJHWFpVbEhnRE2g8+z58zGanpiKBc8Kk0r t545Ksxce91Kf/M5xoYdn2CZBZ6I+Dn4E/UHz+5xII1btmx5WK4dd9J7x7ljbLjwIoVprEUwUTiD 9thlYrQy96uA7bD/M1c0akEttIPj5VzmA4CZHsXo6Otvwlr608uhCfvjjrrUN8eyhFXb1iJ04tFS Mxpxkz6Iu24Hm0NpMUZ0TY0IbPJBHgzqOsiD1Dn2KELIVN6MfBEi4ZJMDS7gpcivC96otgkDBApT XYYbEVwberBK+28Ugj8DdxQ7IbdNbU0TsUrHDr8Ihc7IrnH1SB9y5wedryDQ2T7HVSIGXKrxXe6r 6+3SLFs2QpAF5yTaD6HVysQcw3PevZe60ifjPFi+sa6930YGR/fHeT9+JFfIVQjVhdg62bcUtn2y 6wkZd6aMfuizithSfx6HLYwIp8OG2pGMX7kYCCoxBPiHezfEJzG4h3pHvDOP2cI4yg/UQBAlvjEJ xutsLfFZAlfP9ny6qDSMzoLMmBYOaZ/uJj4yRJAV8yPIxJhehpTolyT0agopXVj8SZwVBt7whsXp T//kk8FQjRtbG+vaXFelde1dv/zL4cZnOpl0v9sH410YXTXJEsptWIvWs1mFDLNlFRwV4cOyumEw nMhd42E+bt4Sk3jBiBkNwI/k2f8h3DGBKKg89OBDIaRc9obLWePXHHUwvxAuSCNsRdFAZAgprm32 HEIFaNfn7cKaaBp3d/Z8ShlMBQrjhD+EAfJ8PkFYDDmfXKHoQwpN/ISzOvR/shtmJrQJmO+77770 gx/8ID2JJVTGde++venf/+3fYrflG66/Ic1FSFHwtH5aVGXAr7rmjbEe+Ge0YT2WhdbW1jT1xJkU yfTW1Y7w1YdkYfUbGbxyDY8A1xnSz91NOWDGSp7bkmyEj4vf+DM+T/QyXdkSVHBgvJOq1nLRktsp K226UfL4HGkquFFIdMfbxx57FC+Eqex6O4vdhdvDKigOe3fpJV9yi59ric3Hn7gIJRZtqBBrmWWD LmE1jcGrffqzn/0cee9PH/vYxwKObgVr3qlY8DzYThipaVOnpRtvuBF8sPumrl7U0avnzWltVGHS 2Q5T1bEjFAUTx09Ml11yWVrJpm1LcJn/16/8K8L2yemySy+Ndtq/Z3/AYL2FIwt4GY/SDSEsSpV4 JqLg+JRTWtMHP/xbqQuYxYehKBZc3tCBK+Hs2XOiLgrPCsjWs5Rleu8HCyW2vC/4ctzryntgH2cS s/ZWAc+yS/82nYP0xWCUBoPb0kfB1O5DydBF/fft2devzqU+fkuPFdTeUK0Y6o08ipvSbiYVHyoB FFDdsEcPDC2pjkfH7A9/+MOwaNsepnUzn/ls3Gf/efSRR2Mn7TVY1xugh2Oax9Bva9PTP3s6hFwV aipk6mCMhV2eNSuwctsfBaiv6CS2nXsbKLwvWHBGHAFnnPj3Z6hu3+GoLGIUNAFX3TrKBf+hALMg 5vka4nRFVbgIKcUzT01EW/k3bjOYfvGKCI2j69L37/tO+t7SH6b9LcwN0hmO0+nqZskSpk69cEYj bDZ2u7EY9a/lnHME825wNBoaWYPSrVNBHWunklUtFldssdAw0iJZdpG+qwYFv0r+vShgORu1qaYp 7Rm1N+1tYG0/LsA7n9mbfvWid6b3XvOriLYod8FxXvsK3aGcCLG2taLg0/nWNgjqeaxoBs6Qqm07 hVRbrnKp3Jpv3EL7c6Pm9yFEVpJG0SayvYe68qr3nfc8mLObSQVtgopGd7Hf586WU4Vlljh5S+kA iXpBixTD92dEOB0+3I7kPIKBY8CAwhPMHMyyFlIWXUBc+TwYOi0Zugm6U6ZWWaYtNIGTp9aniy45 JT37+F5cJfeSuCk2EKk/gDaM9GF5ldhEHi/NTFUm8JjYgbAwnjK9WhHf+MY3xo6pN7K76AOsz9I1 buFZZ6Uf3XVX2onWX3fBzISmEFrVYsugiifzOJ0NeLSUbUdILfEZcRn1ppGiBqOFBVqm+c47H8Ai syvwnVNV5G8pQgAAIABJREFU/ZX4gq8uXHe1NOkud+6ic9PjzzyOtZp1MA21wdR5luQ999wTTF8D 63ssuxP3xlFY1m0fy9Wtd8WKFeHa55ra888/LyzCHpWjC55HFLlLrAQ/mE4nACh/hfepAurwt9XM Us4ns+vWI/cbOlL0gf75lLYp34tn66ElrJwBfNNNN6WfsBmIbtennjon3fKtb6NQ+JP0mc98plco 9XvdF1cuX54effSxyEOhdckd30unnT4vzZ13KvjQMqiAXBdugwouBvHkukX7ddupc9OGtWvD2uMa r1EI7DEVArvaWgU300c7E1f6hXEFdutULEy6JLejVBAHfmsouBbm8r2w+427n8rQt7adkkZd3JCm TJ5KeSngVRAdRf+JehhJsCxhkflR4SEcCsn5muFTwFL4FgbrLByWZZkPPvhArBM8i/6utdHjXxRy e/a1w4fgPo57peNh/unzo09Fe9E/dL80v8An5VmPPbv2RLk7t+8M6/S7f+3d4VJuH/vC57+Q3nD5 G9JrznlNWF0LDhU8wiIsQwtTZ9BiquJHt3TLy33xIP1cd8+8Rt504s/3/nwnDN63c+83ut1Hu/Ag rKb3N1gYGOtz7w/ceth873PlnfkYR5H5xogXOVCj/E9hoeqfYPh8pPCCmDwqLs7FrZZR6YsCqmu6 3Tn+3//932McCYPWU62k73jHO1IzSjX7zdrVa9NdP4LG8p35+NP6vn7t+rR39940eSIbtQFgdidV 0aky8Mh1OlKdX0nvnT9PwNVfa6nKT+ceg/1YRZHBPn/8gzMI+YJulRja6SwFyoKxUGWBltsstNAL wpqWYXAMq0gYDpiOfy0LDTHnUDHVdab1u59LS/c/lZ5r35wmzmCZwOYdqWFqQ9p9AOVzQxdHr4xJ +9bvS2NHYxWFRh3AP3XMlOa0e9vO1L67O82YPSXt3r4vNY5vSHv3cJb6zvY0ZurotI89OdiiP02c OT5tWLkpNYytT1ObJqfNP9uR2pvY0GwRFtOJJ6WHUMYu2ryAo3gQjrtwK0YGjaNncLv1PNBoGYS3 Wq3UAbi4rmw25/OxhNAg4IEVAiAFkbuiYgih0YZgRf/jirAYfYJUNaTvbWHf+SAwh7vyui8N81bQ VD/I/SU+D3hy34tbIn1yEyq/DUsylvoIkSDfDtffEeF0uDA7ku8IBo4FAwx2XVV174M3DGKgkFqP QKT7ZD7LFKKEL0dXB0xldxNWoQ6YjJ1oybvSGQvHBvPc1c1RAxXGReLvfTDLkemxAHT80maaCZGr mtCd1LXkXXzRJWxqtB0r0QlpdtupuDlOig09/u7v/i7cYf/xH78EQ707vf71r0/vete7wtKoJSCE QZj8lViJZPhd12VcBwJCoM+6e0+c7ykqhIxvfvM/cW/bi9DZFoJAdS0HMs8+K2Rt3LQxBBetFIbH H328190rLGZRlu7XoyJPGb0QhmBmtPxouV3ADqbP4no3d95pYSn+p3/6pzj7Vvi0mmpl854Gjjmm Gq6jvY/2ps6Wn/GbmVfzb2BNGR1m0KwKnvymEauLVjcFVM9gvfvuu9PN3/xWakLIev/7fj1dfcUV 6Utf/uf0BEzwJVjkdL80WN+nqd9eLGvXcP5mE8fGrGVd4h133I7CpD61tbXBFKN0qaQVrwppCmyu KfwRjPIcXEefQxjTdXTevHmBS8eEeVs38eM37khqmh9g2dVKJFOty7WKBxl128R8X//6C9KFF14U wmEfbnD2YqMhBUrzs566XHvVsnQF9etkXD3zzLPp2bQ8NppxvZ9CgOnNR/xahviyTI+Q0vptGgVM Nyhavfq5UFwYL35956Y2nncsjOPGjQ1ly9NPP50eeOCBqM/pp58GbI0IF2dGWevXr4u2mD17dgiz CpJh7QyrgFrsLCCKH4VgYVKhojAsnl73utfFcVmeuXzX3Xel+396fyiDdNv0G+shbNbD4BoomRDj DaYx5HWI5En+Nnd4LcAY8mG0f85DJhqcUn6FvYm8FOMjd7tJ7ipmeUgYitfx2/hVYKz+sMBdHfdi 3lt+/HINe/E43DAEGmmj0hfFv23vkSfXX399jAUFUd3mFUrt26axf+tp4lpV+6H9xL6gYsR414JL Z/VcKWOz9DHzt//rAvjzErTciT/7ubgRj44NcVNj/6+Mv+HAR7QxqIYrUHwIIcVxBQABj7vOdmF1 08rVjaCKfRF4bJu83OSwg204AH6BeUpXOrHo17HrcCO0ceeWFal7E3tTwN9Mb56W9u06kE56zQyU l+vTmAlN6QDrQjcv2w1xSmnc1DGpZfIYXHI7086tO9PmdbtT4946PBnaU/dalNozJqb1zA/Ns5pS 86SmtO9hFGgnM9eOh/7jyZTY5HjC5AmpeeLYNHbSOGBoxMLagEJGZSI0H7jcfEjXV12LVQy4UZEW U8VJ/z2/4NcE53xu8vmrxtDSWsLxkondhUN4zZbVnN7WpU/woIoif5Fb3B4w2HMUU3lneXwd6Syr TxiW/kuxzYES4hUl2DjGS++4z2oRcxzeMCKcDi9+R3IfwcBRYyC0h0hRCpS61/VaHyCIseGBBCOE TC2o9Uyc+9JDj2x2jT+M5bRgULrd+ILvZSqCeeGqECjReskC8Ggx613rCSDCppVmwsRJCCKnpT/+ Pz6ZZrHe74O/+aH08EMPhoDqmah33XU36bpi8yDPpJSRUvCQKZSJ8vzY737nO8FctTGBFGaql3G0 bJiM0Vi2vnrz17AUbE833fROhFyPWigTecaM3w4MlqWLnJvlyJzZNq6Ntez5888gOQQbYi+MulFr lTD4XYdWJO6Xs5ZrAwLYli1b05f+vy+lE2Eaf+VXfiUsHDI7CjBuMhPlH7ahcptat8GC3wtjea9A ZP5r165Jt3772zA5tkMWXKu/N72CiOlHI1zd9aMfhaXAo0O++A//mDawE6vhLz79f6ff+shHUgvW l29wjMXmzZvjGxlfFQY1CMGXXbE4dljew7Pr28bcOybt0eU6mNssEFnOHXfcEQyfeJLx1Yr4yT/9 P9O8OXPiCCfXuwqXTSJ+C9zCqYVI4VYrke6KXrVsyEC6ydTVCMe2j/H7cAl96KGHQmjM+dkiCqYM KoLr8Fz/LPwKuWNhjCzvsUcfR2h1ndn69G+4M+veJ1NaBDZhthyt/9bHDYLKO62v27dvDeZf4fOa a64JwUB82Zdsb3dWtS8rOP6P//H/sNHQAly93b25k12qfyMES+tsOaU9hde4cjXe54Kbci1jwDrp rmz5K1Hi/OQnP0lf/epXQ6DXclu+L/l3ad0OnOd+Zjm6D2sleu1rXxteBDlOG04Ofus3ERx/lfTG 53cwnG7WQijlxEPVn0NHXdXLAbdD5TEg2av8UTqDNwBjR/d7+5i0UVdcPTFUmNhf7Y9lval0wX6n osqrihIt9vaZoGu0nRZWv3M824f8KcDmdqQ9X6VYtX7WdWDQO0ecKpTqyeF4dazH+CLxoV8MzOH5 Plfma6SDGO0ivjLGbIX4FxvkICyFNQ+FEbHMqKRTlDX4N9OKeHyZ/AncFXrRDybEa6QtxP7U2Uj/ Y8nS3h6WITRpvGQe43nn9t1YNDmWbTMeSl31KLNnpv3bUXi6uy8K+/2d+1MNBtLpJ01J23dtD4V0 0wy8nZD8xo0fkyafOD511ranupPo81Nq0jrWijfN5vinec1px55daWv9nsBiV5fjC28oTK1dLK9q AF4FU14imYZtk4uiU8yoXF/oyICGk0XoFqi/uSmc9tTJy/EQAiM48V8lXRZmfR0JiPda8jj0Wv2O t6Y0Kr6OqwCYG9GRY17QGskyXLkk075YYUQ4fbEwPVLOCAYOhwGogoJnkICDrDuDKXWx/wFc+8Y0 jWFChBDCEbouqK4BZn0UayRG704TT+D8RTb0bO9Gi8iKjGCQITBOohIZmY/YSbRwk4eDYVjfQXQr BLQw0cKoxWcBQuhDjzyczsBFdzxrMNXsX3/dDWnGzBkhpFqntbh7ynTJ4OtmZfBZy97SZcvSDtzT nPgyyYXAOqFQd68NMHHf/c53g0H3bFmtBbooFmGiMCYFPvMuk6gCiQzbokWLwtVX4t3ImZKB09A+ ZqJuXrq/jMLSHQxMZOJ5to1x7qPumQo9l1x8Cc9npLbZCiLZwmVZ0V5kZf5HCgW2wdIVxjImmArD Je4U4s4/79yoc3U9q/MQBi2RWgu2wajOxXo5ESFe4VTxovWU1jib9nF2sZ3HbsNnLjiDjY5cJ4sr LXWZOHkKbnAnBPMr7hVQ3WConc1btLjohqW2VwFNa+WlWF4VTrdv34YgOSktOmdRmor7sBZqfwpq eW1NZh4tx/QKhAatqwqlWjbFvxu6LF68ON57bx6ulfQ74ck/EZzzE1f2Icea1s6yxtGdS7U6bcdF VrxpZVIYLoKi+PdbLVEyrm5GozAsk68wsAC8jOVsTi3J7jyta7hpzqQMz1XdSxrxLDxafD0vdLoW rBnTEZL3Bf48Ssm+Zx8pgqT1sJ6WHX0MOIwrz977E1Zh1OLpO/NwjbMMtmu6tZL53l/BS6QDDyFc Ald10AVdfLa2tvZGqzwTBoM0SeWTz+ZjviVIt2IDDeLtk4OFvtSDvX1lxYn/4Q7iGCRHX7D/Or5t a/uL77Sgem/f1ZJvsG2MFzy9NGx3+1LMM7yzDXwfeccX+Rtvbc8GlGce6RUZVN6/mi62W3W/tW56 CrTS5y+48MKYA5w3xJc4CmXrMLZ1DziXVtYxIbiEUgHBEaQIatsrcI2yG5DINP544pv8nfcv1yCe yzgJnEfdqAzrQtvr9qYd47al5gWcBz6ugT7ckfSuHV2LkhPRdVzj5FS/DldeNoGcNpr+fABlC8fv 7Wrfk1pYnzoOC6rrOJs7W2KZTQu0sBZPman1U1Itnup7W/aHm68W0K6Ztal51NjU1ey5o7xDcN1f zxIF8tFLRVlfLVwNgppqAnGrMkD8G9wkyWCrBPrj6dj+uCuxIXIMIbTyvcwejV7OZS0CYiVlfOE3 0R+EIyyblYwAPTKsvhLVF0cf4UExO2/uRz4Vkh9wWBnc+OM4HhSWzsHWP3cx4DLfFyGMCKcvApJH ihjBwBExAAGI9WyQjLK+5+vfuJk1fI+m69/0ZtYuLsfl8MLQmHdx6Ht7+8E0+9SG9KvvYz1fx+g0 vmUXk+k21jxaUmY6vQuGUSYSYjNYCIIzjMRGJsjgTqQKFj47wcvI+/O+eUxzes973hPvOrBkaeX5 1re+hYXzl9JVWKf2IeRoBVKg1D21kzPfXOc5ZcrksLJ5LMu5CI+9ZcE8FCbLM//E4RNPPoGV9arU 1jqbycyNYYIMB2xloowH3zD5+DMPrdfd3Au7giaFmCDW82otZRqLida6SO5laKyx3xsn4+jarpvY tOSaa69JMxGkRrGRjfXJDGJul+7KZkEqMGVKjhTMfyDc4tI8jRdu74vAoGvoBRddjLUFBQj1KsFJ z7z8tosZeuyESWn7mrXpnm/fkurZhOZPP/FH6T9v/S465Jr09rdcx3qdFWnlgz9N111yMcqEBayL 5ExgytHNrROrcSfCqsKIVjg3FDkDgewW2tIyvN+K9fiHuOPqcqplXBwp/OhO+Lu/8/vp0cceDSHR o3cUTnvwBNDKWepl3RRIhff/Z++9w/0uzgPfOV1HOkcS6l1HBUlU0TFgDEbGBoMh2LjEJYmN401x nt0n9+4+Tzbeu3/cu8lNHDu7SdbJtYPjODZucbcxzRSDbYrBdLBQAwkJVVRPL/fzeefM0U/iHCEJ SUjijPQ73zbf+c68M/P2eUeBy6SyQmZcRt0AUzLlWoFkJscQJGjmzBnRl34rC3f9Ifupk0y96+4c Jz63/HYi0Brwyui9KhR8ZrIO3AjabD5hqxVK92cVGAXeJxB92rGyFSHQyMyuXXM/3kkIy1lAyIyw At7sOWy7Q73tn7mc246t23bg6vwSEUKXRbTkW/AMMHiWVlAFTYVoUxnj1ttve1Q4/upXvxqWTl3d hbvPhIlJmHvPdz3aDs/NIy7Qy8Br66Fgo6uvMNLC7Lixb32vpHiPMhw7ohHrEPUyD/fLt/zOUCme WOTQWYZ69Q15X9BGsBha7xhXcaB1WsteKFjoCxWbNeJKA23Rb6aurs7APaXPo5/olwz/3Kf2V1GG +I7zJfrYXPvoQ/Me60m4VI7tDJE8pgt+sI0xxsnrvBbPDpbEq5FKIYNl2tc9JmMIBJZjvbjavdYw C6duAWIkWoWIECQUIKhOpiEH++F9VerwPjPIY0c1yrlmPIlOrk27RhJl3OCQwhpJsZfovI7lGqya 6x7ckNbt3ABcxDeO4b7UOA+lXHNN2rJuU7jiIs2mDRtf5h1AOL43jZnYlDpGEz0ei2S3a0ZZy7qr u5WSjdNLwKW2ztSL4r+qVtzIc2hYHQDtQyC1B3SwjmBBnNsfJYk3DyqFlbviZb9FQe7ZujuV5zzh Q2Dq/qU0npu5f/wV6bJUa+9j5O0v1Wfwg8Fn9Fe+ZHc8MYLMED9GVr6OMcjn4p/tP/xpWDg9/DB+ A3+BIexgd2CH24DMEEMfBmfPVHHtLHGixegvU2bP3ENd7U1chsr3avdrREYgQRkzmYAyESVGJpnK wmzZFom8jKqEPLRMVFsLRGHmfObaPMvyPbVyMhgmr31exTMZCiO74icXVqY+GIsetNw3ff2mdP8v HmBd5SyC17Fmjih0VQRGqOK9iRPrUuPIEamHgAGxLxplWifL66MO2X4an9oDpP04KaPY0sCc7YD/ 7uv1AicbbF1CAOcFkVx5rzBEEn1/uqn94+e/EPs2LiS4xxiEAwWfESN1OaMU4KP3bAPrGrVo6p4W 1gIEJdFmuGwCgzrWfOoCqpvlIlxwzzib/URh0CA9/W0cYnzZJ3zDWkoAhJVr/biEYHGkLT4N7bl9 S4a+bloEvA3sY17XmToeXJd5GkKOVuHRCDBawtvbW6OeObgO5VCewl18g5Jd0xdwc6xEFfN4KUKr t2xBJSPFZW437wfpCDjRUgow+q1bIsioqn2PLVcooBoOymkpk9PNuhr3zEus/33+nntT1Yrn0saH f4nb0/z07uuuwjrfkdY983TqXPpsGvfCyvTITV9LVy+53Og8qY26qxVx7ZNfZ/QJnGiDVryLLroo PYOL7fe//R2seqPCnVlLpQKPbVC49KdQd/bZeS1cW5sBvgB5wMBeKKkvBD4BoyAafUT9zacl06MC YVg56ButtgVOKkhCaKaW/ve+rsjj2BrIOUwXxv1e+rCaiNijdH3lVmcoIchvB9j3fMPvexwxsjEt xrKaBbJcZsxn3ps6symUSb4zfsIkxnA3UY+NOAuDQZ90dbZFkJWVK59nO6VxWE67EATbQzhYuHBB CNUKk8uXL08KqB6tzx/94R+Gm7nftA3WwzmvUHE/rtjf/f73UgP1WsA6Z8dkbFfAi27BU63QwviK htqMOGOcx/jOuMxRb7k9zBXLrqO+Dfzq7FNA0KsFjTLMI2No8CbHks9MZR2y7Y5EGf1n+XqQv1GP komjrwruvX8W5D3zl+IHKW6/bxlsqTLZJlOGa8z+6CthXZQ6A2+QV3wPWOJYW6sSxaFBe8W9lcO2 8iOv8TxoBZFLmbTRlxvwdNCjxKBw1lM9lwy1Ci8hH9Zrm8V9lWd0UMCvm7zC0/bkO1yAELrYtsMk /uohBoIBeaBEwN2C49Fx88d+zuM4KzQLDRKOKsC0MrcyZ41GrUu0kDK/c5xuRgHnXIm7AZNcHnMt 4FYxFw4QYsw0Cs/zxvGeewjM6kfpCz+q1ct89kvcjqs8Pw7wc3tkVyg+2NQvMg35unOjMpVrcYe4 qg88Y6vboVfh1gsermOO6sZu1N4uAiB1vcxXdvSl5p3Eg1jNkpOFlEixo0Y0pW3rXiZ/dWrd0pHG N4xOG5dtS13bGc+QijHziECNO3BPDR4lusy6HQ2BknBUI6E4hwZWdTLPiZSeCIgEZ0WAN8Z+1I1a EYTS9jkNpHK9lZbOykbt7znvD4YixL+2JwTF/r7P/e6F/e4HBntzfz9sKaSKroigwbQp7tsDjF/7 IUfuNXMeE4x+L45IGhZOjwiYhz9ybEEgz1qFUC0CMn7+FBwl2IVwSYi8bxLJml/MJVGTYTM5lTMi gICAYIOSMe3F0aF15aFldvEswqODAI3GKd7THdX97Dq729LHPv47acXyFanRBaY8G1HXiDV1e/rl w8tYA1mdTl7QkKZMALlQnmtMg5niI/5zTRi3Ilkr0VrwGf338pPD/JeKCaOCD8t5WNmAsZZJrUIm XW/XYHH8n3/392najOnp//m//wd3dRvMFp7qOhkvhA4YCLc6cV2QVgPbJuyrq91+pg4LaXv68Y9/ HIKra1N9Zm/E5tfUx/4bMtlBpnLMV7n+wpO+9v1QNPAs1vX25/VcYe/pp5eG1Um3U/MuxcKhxXT8 +BOC6dEypaVLN1rr71rUIAKWw893rKLtFnLCqhDz/urscYj6+J53ORZoU0tghQKEo/9jjSCDIPZU RSiJNZ1Eox05YmRqX7Y89a58Ll00pjFt/emtqYPAPs9yHNkwKo0Bnr3PsIZy0glp2wbcrJ95IjWf d4FkOnX5USpr2H0JmCodGXeF9Om0a9yYsWzHYyTXHGRqoK5cCwevhY3jwJ/jt6S925z7kafMmb2f lXciD2XKmJdkj1bmL+cyPpXJupiKMqpc+z4F+FcwRnuFZbbEe2PohAN3fsjYUPGhu1YN7VTQ6FYw 9Js8s48LfjE6qC7Mjo1NmzamJxDwv/RvX0kvrlmT/vt//78Q6CdFXvOpBPA9cdSJCLa6VHeBO9wm JK8J3T1msxJkz7oKC8eBTFcgBx5bnkxRgWA/WAKGMZbInQFh9c1FO/rhs2fph+aq9NehKS2XEm2k YTGfY8za92Xm2BzOGR+OAeFYYGw/KaB4bR6fa2F2LHsPxABQBreqvdb62w/C2zr7rTMXn5HW4u1g HQJGZoDbF2vYRc7HkqJ7fE7a3UrP8x2fVMLZPJX5Ittx9Cf6ivYUfG7TSn96rx6Fj/hIoVVI3nXX XRHA7a1vfeuAK79l+JOOlz6Q3sa5BR5kKvMuK33sGQu1MMZWfxoQkOJ+uXvsHVWSBq7pqk5ja8al OuI1NNRDb9hPu7YTekL7uvp2pdGJwEej6tP6eqymgOGsi89MbeM6066enSjuq9PGXTvTzOmzWIba m9YuXZtmTZucRi4cmTZ2sZ66a0yq2wnNoLze2kZchXGZRvnQgSBWVTMyTW6dmHa1sUe0Pr8U3tmD EAv262Me2weIxaHMLbxTnjP9XXKwILcRFaly7llytmRWZDiEp3nI5O+/YvjsVa/X2MqDqvWwcHpQ YBt+6cAh4PB3Ou85GXM55d7hIeYHWlcFjkKgtEbo4ibxkVh5XpkUqCRC8SyEH9/NWleJVUkyMxI4 8xYCVsp1vV41lqdRTY0wlG7Y3pZefGEte9ItSueefzZMbE2aTDTbzRvWpfvv+wVghClCGujpYl+u zdSnqz7NmtyI60reN1IGRMbJ77k9TVuPFqrMQJX6HC1HBfoqmXQq5E83Sdfj/fmf/Vm4b37xi1/E pfHCiEKp8KL1p6a/LQZqEf4KIsK0MjnSdA12feMf/dEfxfMi/JY+qMx/oOdZc55hqibT/tWCap+O IMy9QYj++Z//Odw1DX5jQCUtG65lXLfuRdYaboxzg/joQvqxj30sTQMCJeKvc8UxaF9qjQ3g7Ecl o202fi94+KprYq1jLUf3x/NcYYSvhPbdz7RvXpcmdmxPLewJN5HFTtuXP5UmbG9NtbRvChb6qexH u4NAFc/XYjEl72g10L5IRd2kPDYq7+9Mta7+s39GYs0c2dQc/aDF2HvVbLsTDL/1taFY48J6GZUt rJkXQyfL31fac1TsK+fgz/YeV4PnOrC7YVVjfoozxCuF+RUmtsbtiHzmGCvfN4DXf/qP/zFdc801 aR3Blx566FdEOL43BNezzz47/cVf/EWsazWS8n/4xH8YWKsdeIuxsG8olfrTgXJeFcmryl/Fo3xq /sLI7PnqK7IejTey0OHwy2PVGVEYRKeQ8HeMVo4j57r37SP7rrIfS385nPd46RA23j4t9Mn1vqtZ z247puI27n2fD6f9g8Du/sqDVzgKQ+eetN9lGStXrgwlotua6YXjum3PXdNe+kJaX+as73pu2a+G n/avlkc2l2qNI52cYbGn7q7aVLe5PjWz9KWheQT0AHpaxXIaeZ6aJtbW1qSmvlFp9BS8ZEbhgg7P VN/XkMb2NqetKzanGTXT07id45izval5xhj2P8WYAH4aVTM69WyhN9hm5gQE0bq6JiysWGXRS3aQ FxE4jWxH8F3N96cQnJCFru4jG1bKbFaEXsLD9YPGw2436yMNrTfG93Zzz2+M9g63chgC+w0BiZQM owRLoeN+9nt0fZpug65705XUKJ0GZtE69stf/jLWmmm1M9CJQVJ0VzRoitERLUfteh1EbyfrzG4m gupDDz0U5VzxzivTmbg0bkaYeuRXj6Vpk6ejta1Bk9eaFp+xOIQftzR5af26NLcF117K6GTd6doX Uto2qpMop9RzvtO5PdzqFJCLRahodPe74Ucwo8RbuAxYdyAACpFagv7H//h/Ugfnf/VXf5VaWmaH +66WRvukMBWVzIQMgW2VYbwHJkL34I9//OPBZFimz03BNNC39u/BJN8vZZR6lHJd8+V3dAHz6FiR gXGvUMeDQWkMSKMALtOjO95Z7KPaSHt9V6uubbC+Mjk1KBcsp1h7D6bOMtym7KIDG2Cz+eXQ9TCz MiO0Kaw9Hbia4nY8saM1zSNTL1rkkxqxCKDaru9rS2MQRFfi7vlSz0j4BTY1R9BUXWP0aMs1qqEW bTc97+EG9D3cIXUnVOljf5l0ByVzwKb0Szw4wD+V8D/AV181+77K3tezVyvYPvR9j/7sZ5P3gtlF 6eJz/GGYAAAgAElEQVS9wuT6TBip4NCKah633xH3OKb8+UzcpAu8rsDiK3FNKaPgngJ/yxxOuyFQ +rMcfeKUKP0kzE3iFlPBQT6XFqg4E97Od93V7a9+PjbyH9o/2a20kzlkv7te+4c//GFaxVr92XPn xhzMyxIO7VeP59LKXLRfCw1RsfnFG7+YHiMSsuu3v/zlL8e6dj11yrjwWPBXGSNee3847T8EAloQ kgWTFqTbf/mztHUVAQ5H6sCM5xjKdT1C9DBx6dPLfexRDh0ymFB378aAfwPrUGt5331B11avw0WY c5Vm4FeXUYRXGtcd0iH7phqhFX/eVjycFEB7WWOaOrak0RvGpFmj5iKEspc07/pN66bgnFM/D8H9 SPGNfK8/w/DhEEFgWDg9RIAcLub4gUAhVDJyEhnd5hQwFSRlPGT8TDJ+BjJxz0WZRfc7PANB8rnn lqYPf/jDEajCdWJGJpVhNDCPof8tU43sY489lozi6jYNbp3x4K8eZpP0pjRn1vw0a+bcNH7imHT3 PXeyFQd7KGJRXbZsKQKMmvwOcS5rv9z0vh53zCZcYHQna2NNRV4nA1sVAo1WqqOZUHZS38IwuxZO a6jwbceC6l6Zn/3MZwiU86fps5/+mxBSx8EYdLD2xHzSmErm3v6wr4Sz24dce+21wbwZDEaGIRjG fiZTmLwWuPhdU2FIvFbekqEZiYVRJmcRa/78tlt5KFQ8i8Z9F25HV111dbzX0DAimB3XxRrURIFc xihbj5tDgC3tU4jvZQ3ZQdU5iC9CEBrgWAuN0BiBNAwXzzPXUobNDpgKnlpgU4/g2aRRFOnSYBSd jKMRWPB7duFqhSylxbUHLXY17uU1vJ8DOhUibW3pG39Sdt1V/Ue5BV6lHeVIrjdMKm22bx37wsR7 Kidc1+g8KPe8r0DkePLnO45jx9MnPvGJgXH9qU99Kp7NnD0rxo/vm8/kvDCV67gY/pMh4DwGxpV9 Iuwy/PAyYB2pSbibx5/PtG53dHak2267Laxp4pz//b8/l84hIvall14a+Ckr3PJnDuVfv29yvPwc wcn1ywYYU4EVtInxk2dfZBv+8yoQKPB0fghTr3XP/u53v4viZ3woThX8zznnnIi8bfRuabZjwXfK /PIzjhOT9+Os/zpuDv8ZGgIAq7O1O1371uvS5W+9KnWh3OxlO5XubrZ+YbgbZwPMGEJnO/eQLblC Gd2LkMlqIEgTc7U3tXXg5Qa9if14a4jdwZrV8LZiaYxLTVx2Qu9Al1AEI3B2SguhUXVE6K3qAGcS K7F5BNuJdUjfsIC7DRZ0kY7l+5nn0AXZZRmu30cNS3n+JHTD6VBCYFg4PZTQHC7ruICAhEUCVY5F I64gKjPifd16JEQSJi0WnueIftURudN3FDYUQj3qIqSw4rYSCiDuxyjTqWXVci+++C3pxBMXplWr VqeX1q5nv8kGBC23tJga+y2OxFV027YtRPLczFo4BNDOLKycdqpbWDTznVXptMVN1E23JJmr3euh Yi3ZgObv6Owi4Seid62OkScNRNGDIkDr9Kc//en0X/7Lf07/+q9fSp/85CdDE0p24NoYMFQgFb6W oaD38/vuCyvraQRKaqMM4S0j4XNTYSrK9YFCxPfKz3cVMOzLhx54MN1DJNqJE8eHskFruYF5TO5n 2YS11LraR64zHTWqmaA+J4Sg8RRrZ92XU8HUsfeRj/xutF0G2PrWwgznYD5R3EH9kbj6U3QsemDd e2V1e1jrLPlG2kRAcs0o66wYQ9WcK2AaVKm7k6BfXCuwVrG3HOwAP1xzKc+Ih9l1HBiH8JurGGuv FXCZJ8LMuaMroqTca10kOcmZj5G/lWPpYKpc8IrlmByfKqnEJfZ9XczhDBNh5PMimJrf98rP5zLU Tz31VLgZtsybu8czy/T9AnuPw2k3BAaC1AEXYSN0VODUwv2GIidmS+4D39Jd0P4TUd1y663pHz/3 uXTllVeG4NLc3JT++q//JhSY77rm2sM2rv1+DW719queGLezTZZLQ5qx2pqG+zjAsF9/yrwQfxda rjeL1vBHHnkkzZ87L+j5NpTTKhqlM6PYJmod+x+PGT2GfbrH5nGiZrI/OYpc7x3rsCVow2k/IACd QYA0qOPYxhNYypRxXhUReg3EVl/bgKBpgDqsmVhTDeaFbxKuudAh5yNm074aFKcIo9IkgI+QyiOE TgVcKZUuwQT3gI5RCh5JHSxk7eiPjNsAXSMMcKpiJ5pQ6EMUGxwT0LLwQgg6SYEIpXl7FwrUasrz kJj3o4XDWQ4MAsPC6YHBazj3GwQCMn8yhMGIwLToZulWDh/4wAdC2NRC5vpBLV66151MNNjrrrsO AteVLiFCq8FvTkIY1X1TQVbiJzPhlhMKM1OmTA53YN1U/Y0ZOya2VFl00sK0aMF8mHeQIustTjn1 pPTkU0vDwrZkyWUR9bS2hmAAVQoFVezxyTYCdZvTuRPQI2IZs75+x+/6zcIAH63dVurnUcJjmyQ2 Rq+1HQr+ukn/1//6Zwin/5ruu+9nsSWM/bH2xbUh5CnQuZ2MbVZ5YNRWA1Z0wEwUq6zt9xvRn5y/ Fgau8t3Kcy3rRg5+6qknQthQAC3fdZ2g0WWtq1avJUuWxDj63ve/H9ueGPhGbb2uyJdeemkEeQrG CRiYjPRqf0a0zbhzYH8QZxA2tR5j/VScBMzsNR4E1rh8vRBf19jUuLk4giciTxDpPik847XPoBFa XmHO62rZ5zURtIs8sO2MU1yQVW9bnIKp/2DWwm0YhiDuoHBQ8CJH/kU3+01F292MnWUcuuSXD23Z Zby+ljoKB/vWnwyvY8Z1bHpnRDIAFs8cq+V7XnteflrIfK5gqiJMTwMVXY4R4Wk+3zH5vcp5EDeH /wQEwm1PuApr7lTCuTsEjD3hp5KljoBsL7zwfLoV4VTFmcLM3/39P6Q/+eQfJ7dA0v3zVBRTLQg2 CjyHOtm3LtnogbGW9qj8rAH36b1zmsoIttkqSzoO9bePp/KcHTGHEDh3sMzmmWee5fd0KJR1l77+ ve9NTz35RDrjrMXhOq8C6NJzLk3PErFc5fKcOXPip9J54iSC6ewkCBn0vxbBihHFvGMOx6g6nqB2 +NqiAlbYdfYQdwPvKJWg9dIrYPryru0x1vtcCqJAiBdRDTsWNGBRrca9l9i+CKPsXV6DAGtEXrx+ qjGn9mE9VfHKxA6F7Pgx49KE8ZMQbg1RxxyqRamKYNrVyU4B9FVEzocmgUApB+UsfEhfPw2TFIpS pVih0qUeWlEz5Tt8cHmjljwsnL5Re3643YNCQAZFbbpRegNBca2LiHtxXnLpJdwSWUnWfFyFG+8Z oSXVzfSyyy4Lq6aat9MWu0diXzqd5zKP/hS2eAuhF6QIwzgKTfdoBF6TTIxWMnlpA/4YnQ7xgW/U 4BJ8Gm67Nez3uTYt+019ZkBBoF1EsmtorE7zidQ7a7a2sOwSq+BmABWFHYlvrm9mWC31aErCRDha R5UBJuucYeV5joKpBfK3f/u3wxXafTG3bd+W7rj9jvSLX/wihFIt1DLsMuG/fcMNUZZllrIt12t/ 5vF4sMn6Wa595jELXSmdDkP6KG52Csnvfve704oVK4Kpcf/N8887L9aaGkRDJYdrkhW8ZWxKUuEx e3YL2vnsRt6IZdjkePRbBT4l/4EcsbVASNE1s4ZUITSCFeE2FUfhApxjbzdIrXuhOppoWsCph/Ha jQBaz6BU8OmFKQ7YkkdRt4bASeatpYwapk0tAq4uyD0E7QrrAeM5BCTgJq8m6N0jVjg63k1hpbIe /GTsLJC/+Zp8ub8q+tP3zBa58vu9CHXlXuSPYvLYyu/z2IqWcvvP48Z+/Cnv7kfWfWYRFpblGLdf FU7dEsn+9Z4WBOsbdeYYgiX5swcEMCOVMRcwjDtYaxj/Rv22bMs1lXnkefmu54Ol0r4Cq+iaUo/+ F3xmPg4xFso7g5V3LNwTTsKwzGktkK4Ff+GF1Qj+tcBeWGbh3rYLQ/MqqLj/ssqkT3/6r9MTzzzH +XPp61/7Ssx5rW4nLlw00A/CosCqwPdg4VPe111RhYRrTleBa1R+yVyXftbKG9/kXnTYwX7wGHrP vrH9ZZxadedN3v4t90F57txQmbNyxfL00zvvTNu2bgv36Ouvfw9eLk2h+BmNNfxXDz8UStB3vvOd MU9VCLnGWFxvHArxvPNXTxlxfURwD3x6DAFur6oKP3/7opVlPJc5YRGem3xW+sLz0h8evV/Kj/tc G6m3z2Urwg3cYn/pvRAKTsb54489ke79+T3sFT0BmgU18zNYWRsQZl0KoTVVpoloHNyH/nCpS27N COJ8dLMVUFebFDAtnLcA48EUF42THRzp90SpKl/htSwr4iZwrjG8B0trMGPOIWlfoF9hI+3zTqYn nA6nQwyBYeH0EAN0uLjXFwIiO1NBnIPVpvJZyV/y+bZWKpGWCTQUR5lg10cOnUBiaNpL6u7M5x24 p5oiMml5GMxCvpDxLymQo0haTR+fBz8HY9Tb253cZKUbYVRiYdWqECy0onWy7rQBBCzBVLhQSM5b ReR6q+nXWhYFlg8dRcdCzKySRKuk6BdhAWGyF2S8582bH8z2TTd9NT237Ll02qmnJ9f/6Grlmi8t GZ9hjeoIhPLWtvYoyvILcfRGIYzx8CD/VNbZIryWyX3TBReEBbe5edTAd6yb1lKTI8qtQyS8MjG+ pyu4TNJ2hO28j151MD7NY9jblecSyxE8tw3RlgoYRaH7/UfCDROg+xLCqUOihzFkgInsjhu3GVdc awntY/83xz7fMxhEA/VwX916BNdeiH1vFZY73KCefebxtBkt9AiCJq1b82I6Zf6itGH9FqzXE1k3 PR+PAxQs8At9rJl2Xz4ZEFPshcm3S5/n7Xew6fIN4VG25rFuQJgC+D4D33ERDAT1ijESTIOwVcBw 7ngef+I7Wi+E3WBz3vcr78cL+/gT39vH8/19VNoc/UndVCb5M5XjQFkOmgq8MnB/HyfWs3yjZNvf tlbCQ6aeQRdw9r6MfGX9SpmHCi6lrkMdK+s2VJ4DvW+bnLv+xK1ash9++OH0PG7Wi08/jfssL3Ds U3CMRPBRfV09zG5nKBx3sWxA5ZFp9uyZMXad8+7na7LO/izfZL/Y76Z9tacSpnvn89px3g1tUTmq hUecIi507nRIU/rnR3k3+ipaEZ8+rv5keNg7u2Fa5pbPYm9qAGb/Ghyn7Ftcz/mzWEqlGwr5v/cn H4llF3oytREboL21Kp1DJOwLLnhT9JV43PEvLLXwuX+zkbJ/cstP0vfxgFFh+qbz3zSwtVSB/bEG bJUxISQCO1NA1gHXnxzDjmfbF/wI1557z1wxVyryl/fMUzmuvR8wIm98SVyN9FfrOk/fZxg34Mrb 1kmcj7ae9NZLl6TzLzw/dbj/MmM88DxiabjZUoeamhGprwv7J5bOahSkQb/Yeq9+BPQEafbF51en pc8uC8usNLCeJSz2JwZYIgFDw1W0ct8WWLY0xSUWtkpvo5zy0WxaVHOK2vefH9hhb3gc2NvHd+5h 4fT47t/h1g0BgaMRKcizKEKIGntQ/clwcBoIX2TKnitcQghwVakB6Vaxen/q5NFp5oyZ3N8M0+P2 HPmFIB60XUKy2+Jy8Eh0CDAextuSOQgE9VeTaRt073HrFYMdnQ7j2NLSktZv2BhrvLRWvuc974mg VDIMkyajHR2EQB6KChcG0zEkcZbASuRqIWS67La27gwGVMZXoVq3O/MKfRldz3U9thytZb4/Zky+ NpcWdXJFPh5G2Y4JYREE9yAaITR7KYvRwzjyygP1j+94leHtM/9pHe2J70n8+yJgBHJrEOoq3Bpj nNGWFU8/k+56jLVZJ85Jzzz+ZHpu5lPpltvuSFdcfV36T//pP8fedI5LXbZ6DTBBmYVJ8VhgKZw8 l7EXPruZywwjn3m/WLG8DmaIeybfF979syVg7f38DgwKyhtTKddznx316QhWscDDfjH1wgC617Jz S8Zct2PPzafyIMZzP5Na3jmc8Cz1O5TfiDFIew1eVIPyxDaNxwJ5LsFvzj73fNantUZ7tYbp4uf4 qScA3SO/uj/de/c9ad78+SjEPpt+/KObWdZxDa6H64jM/WC6bMnbYjy2s1+jsHK8OkYLvtjfNgwF V8sLrwQKsk4G6jNv+amUVICi8rg4YiUCN/mO7TxYHLK/dT7S+cqcdnwUGAtnr6N/Oe8FBk6lQhfr wAdP40rvPti6Yl966aWxvKYSjqXPLNNyLM9AWOUbXSig61n7+/73vj/9+pFfp2/9+7f4Tm+65JJL Ys2q7wwgoiMNlIP8nm1U+S3vkducLYkluFe0CVqsgtC2KaqpEAmvHt71PGgcz6WJ9oOpwK/0kdfC 1/zC03LCSwELqOO6FpqjorKzC/deAh1RIZ6z1ERdP8tOqugHRnMe37HkhD6mzF7ySeX6KLsVBcPn /+FzqXn0CNYOz0nfuOmbxPN4Kf35n9fTR29N7XiqaYWN8dOPz2SzrEveZs0+t+5cx12fFYTMTUMC Rwf7xnA61BDYbao41CUPlzcMgaMUAiLIoy6BFUG/IEOQHpYqnP4gpFm4LIyIWsVuiJ8Woq6uVqxu PWn7trZ0109XsIfmjkwIBtqWGS4Rb0aglHsUJnui8permO8EG0V7QouLy04dzNZjj/4aF+f6dPnb Lk/f+/4P0t/87f9Kn/lf/0CgqG3pvawRsm8NLCTRk8gFMe1vd+X5awWFfeLP5LdCMOLbEuRCdGXk 3VpCa4yWUo+jEFTNb78EoySN00JFj2vl63CdWz8TbFsk7t63GyNbfPHA/0hHe11/oz+UUiZl441L gCN+jj20wIbmd+2pRL4H2PUwzrr5GeW304BJ8BmEnVBXnZl5YYBr1eZ1m1JvWzfRfEek1WindS/c SvCuVS+uTNX1lCczw/cUZ3a3Kd8TVt4z2T8K4MFAc892y/REnpwDpQwMN/l8x/v+vPbdYHJivNs8 Rg8/4edPWAtz85fzQzkeonrHwZ8CG4+ml19+OVxXdVPVFd3k+AXCA/A9luGoBSbcqLEWac2vh+lV d9PeipVs1460HVfPVtYSun69bScCIM/uv+8ehNOH06mnnJq+8E//FAHYrrvu2nTnnXfFelO3FXvi iRyZvawJLnATVmVsem9faV9wLeV4LPmcRc4fx3vuI3spz6tQJpD3eE7CIfBBfyOFQ4GTeMNz8Yn4 xb2nf/KTn2AVvSAsoOJnx7zv22ceQ6kbuBE6whFMEp4fYJ2QYLyn51Nne2c6+5zz0nuue0/62d0/ S48/+nga1YjlXOAfY0kYNeDObiTaPj3IwJmMWIRC6BL3Ro7AK4Cgfp6rNAZKuL4ihDK06rF4qvA0 CT9/lmc/lHuOy9Iv3hMne20QRLcf604sbcIDzPJEM3X14Bn20u7DS0c60g296UM4rWZtaS/W0SrW nNZVjwDW9AWfllbpEdSJ94/+ZitWrUhr16xNG1/aEIEmd2xjTu/Yntaw1/i6TRugaSo0UdwQWKmK yL/2cp8uvZzRQoulbGiXbVW5aruhmfJixlug9vFt2zKcDi0EpDLDaRgCb2gIyCxUJhHq65Lca0tE yPdrQex47IIiRfTeU2dnPWHeYdpNs2eNQ0DdnB799Y705gtZi8HtyBP1l7nPWyK8Xs2JSr7qnwLr 3KbK7NEPPC4ETuahrW1XRDDevHkTwY/uSCMhpK6zu++++9INH/tY7DerdVVL3b7dsCu/dGDnZbyU o0KRKdbNAHMtFloAV65cGVsHGYlVpujUk0+GMO5g7fKlyQBIRoS0hyXOpfURkIEOKwRdV1/Xb8ZI KKDyYwecLAOqSsql9ZfJ90OIl+EypqFEuofAFBDq2mBO+DKPagyYhFt5HRrmOtyhoPzUqyqNnzw1 XXfte7BUj08njB3PmJyVJs+cCuHfjNtjK8wba62h3yoUZJz9uu6IMjxq6I243NttYCWeALsQimh/ lTCsJ+gS567X9jiiMW/RI0NovmBsKFxYW4CulqZaYebYZ0JoIRGWWkQsp/SZz2N8xRvDf4SA8ChC jUqWOpQkbcBM+DmnhKFKGJ9FP2GNM79j22uZ0WMt2ebCRFt3x4fX2bUxCyqlTTLQrnf/GXsou8bw hhtuSD/60Y/SD37ww/TTn/405vuHPvTB9Fu/9VvpDq4Nzia83EZMV1Fh5ff8xquNvX09d+warEkb kbhnYEzTB15LN0wquSwnFD5BM1A4vCYckss92v7aXwUGngufwZKwUPBUSWi/uQWcgfPsG8e4v9L/ ZR5Ib73nryi//IY4p+Ag8YrPFhNnQmWObsIGQWwAX2lFPKYS7Qz8DKxMpe3CTQ8g93KXbrl1EYMr 5n6Bm3igCtwbHl+8az/4fjn6vPSV9zy3T8wTXgAQmnqEzjyAVbL4fTzE2D6vq7eD29AJUIyxBWJ5 CO9iY415UE3wSNgkPHVc7mRQqvrUSJyQz3z2s6nZ9cMUduGbLkyPPPxIOu+8c1ljfHdqQom65PIZ 1I9ymBqZd1LypM40X46L2RPlCguF8ZzMSZ5yRd7jcFr1t+71OwwLp68f7Ie//DpDQKR41KQQPl3r IeOhyRTMLNIDYXd1wSBigXLdhOtRfS5S37HTPU3VXiYiRor4DbXOFc0K5pH7CjuGXVdzfnSi0ILW B++LYK7Ikol8H1Fsx8WasBMI4X/NNVelG7/0b9GFHyRYUltbazCIb7/88mDegmIMXmy8c7B/rFNh TGQ+vVYQ4kAf6T5XFcLyl770JTTq56SWOXPS7TAsk1jXpFVRxujNb35zbOze2toO0woz7FjkPdcM W3YZmz1hKe+3AEgQIb4Hlawfn7COgkSBUwspiuBIedxI6Kk/VtRagkrUMxZdZ0qDeIkXyatlvw73 qlo0ztu370iTTz0z1Y0bDyNWl64n6FMNbdhF8ImxRK9sHsV6Whk+hOuf//zn0S4ZubNh7CdMncYa oFXpB+wlKNMjs+Ja4bEEi5pM0Chh6jpij/PmzQuByAiZbsUjfE455ZTYOmXFsmURJMsth4yE7Rpe LXxhteZ81fMvRDAT9yhcuHDhgKtZgbHlH0+pjJuDbZPwsAwZTsfxBiJOa2XSpdeIwjLg5vG51gUZ zmM52VZ/Msr+HIdF4PO+46QIlY5dBQ8DWDl/DYpjkJy3ve1tsb+x6xbNa77LLluSWnHpvffee1NL S0vct2xh91rHnO871hVO6/ieW9gY/M5fE/Ons6Mz7epf527/6K6ssrMHpZCuyVTgWO6yV9TdfjJV Cj5eCyeFSJWGHe1tMVbF1waxUsHi/tMKpib72Z/PVcR4bnntWEXtN69LNGzLLR4ywtfvOx+855IS lZIqJt73gfennYyRYy05/h3Htsuj42rNmjUxlh3P4liDcJWxLnyElclzrdSWIcxMwkaYlfFf8nv0 G+WZSneFwRqUo67rvvWOW9Izy59JV17zDsiPPA/93IObPMubwmoJXXFP05ASkSZdW6yAGos79ITg u/UNo+gD3vGNhpGpjvEgbajGNLtu3dqYP214/Rh4Ka8ulS5GtYPkWSOT9fJvLDGiHv7jg/HM0+F0 6CEwLJweepgOl3iUQ6AQs6Ormgg8IGdxrZrLXhBffUNj2vryjjSabWbAszzvDOFVK6rbxqxfvw0G fidRXxOCmWsXXVcnkZCpyohTxH8spYLngxRQd1jlvGYKgqfgtoE1prrtar14++VL0vx5J0Z7Tzpp Ubrnnp+xJ+yy9DIAKa6yWRTLjMqhhENm3rNWXRhnOEuwqiLkvVGEDVYiYb/sssvSyUTlvf+BB2KL iSY2dNcF0IjKEycS1j40yroRZeIe9UQI1J25JLW4r2XcRv1wVwp4UEdlTdeS9kLN47sIvTIAOYpv vp+fk48h5RocByEjM3UYjIuh9tLL61Pvit+kUTNnpRdeXIeATdCqljnpueXPpTVrX8TSlrcDkIF+ /PHH0kMPPhSMioLiOeeek0Y3j07/+I//SKTpWWzlgKBLRGYZ/1OwNBm52sBXzU3NsZbYfr3l1lvS mwlCsnnzFvJOStPZyulpoqb+0z9+LoJlGfl45swZ6bbbb08biXy8+Iwz08pVz8ees5/61KdCoJWB FI4yoYU5KjB+ox+LcObYDuYUC4RRsBW2jDItI+840jISazA5z+O+YtweY0DckznOzLL3FMwdHwo3 tt/j0+xFrFBoVFaflZ/wEj7CwvElY66h8jyUNW4n9eCDD6bLUZiV9YyW7+9gkp4U27dvZd39I2nz xk2xt+lq8MmGl9bH3pAGXNN6NQPL3dTp06JOKihNCgvWq4agZsdTKrAU/vZJSfabipUOLP4zZkwP XOw9accVV1wRVlSvRyKsPEocA71v9GjR08Xxr0KmsXEkAmpHmjNnTuxna1+bTzdg+9yt5NxCzvvi cZVkKs7c11olWdPo5rD0lTod9UdgKB6wLUaVd867LvcBaJfW05aWlmijY0lFoT/zao32uWSil/Ev frVfAl8AG/P789ry/ZU8wsR+0+NI+dMxXkNZPdCrXz/6ZHrnu65Mi048keUn1Wkk3gu63bbjHmBX U2p803u1ePS4VrUHvKWgW8c470JR46BXGO3sbE87tr2cGgmQdP45Z+HauyF1tuGVgyEglp5kSiil hY5TKZS0CqcqceVDapy3RviN57QlzjK/xelwOsQQGBZODzFAh4sbhsDBQUAEqEWiNt11751Yp4w2 55YFT6eL3vLmtO7F50GqXWkUkXlrCUjThQZxyvQR6d3Xz0IjPgLiuQsCsQPNIBgbrCkRkP+JDaQ5 z9jWmnEz0Krn3n99k8RIgmZNrNkeKapnO4hIjCZ1+fIVEJiudPXV16Rn0H53EOZ9CoGPbOtDMIDu 8/fhD38oBJYlS5YQuKTxlWXu8YGDu5CQSlxNElwZGYFtPbVO3HLLLSGg/u3//J/pZgj7v2JB/SkG 1LsAACAASURBVJ3f+Z10FtE0f/jDH6a3sA+uAZEexsVIy0u4EEI8C/G2vB6Ir1ZNLZzeV0CMEXKw XQaQQ8AMSGMhUutLWZRMKywUxly3cu4b/dC1O643jT7xmiwKy6437UQ43dG1K3Vv3ZimNY9IZ513 VnqEPV7VRJ+8YGFav249jPwzMHozWWOLlpr+mYQl1a1ybM/KVSuxwJ1Ou7rT3Llz0rW4QX7nO98m ENTItGHjhnQK39iJ69jJJ50UVlPX78kkhRUWGO/YuSPd+7N72bJjPLCvSZctuSwtPHFhuvnWnyDU tgfzJIO5GdfiThilq6++OoKeyIgW5si+8jecdkMgcAaXCljBaAaDVxeC2fjxuGzPnh1jsUv3aTpS IUgYypz67rGWrLFCRRkLHg3C4txWqTSiaXR6+IFfhAV/woQJ6btY+Q26NgmhpBNm3LF19z33xDpy PVw2bdqYTmLMCqsmypiEskUGX8WK1lVh5Fw2HQy8fEcwW2dxzGQUWyoKnlu6NDUxz3QtXgyO+dWv H0vvYTsU177qcWJ+21oHDs2R3KMKx9Uf+06lgG11SYdwcv/Zf2JN8IL589JHPvzhGNPiBfH33Llz AxZaknX934Yg+p3vfCfGgtbP6dOnp6XA9YwzziJy8/OxJ7kKihCiwM/2qYLok088GduGiSjtH3HM KSzfWL5iRbr/wQfS1VddHUqJAwd2wU2ZzoiJ7cMglh4lnKTdlr2SP26/pj+Of+FZtsrxWi8B3Xlt nwJpmTO2WcFUAVaLs4GKvHfuuedCr5dHn7hlmt5exoxYtOgkcPEF/UtaJJsqgrLHQujVqXk9njl1 4PG161/CgjoirX9pU3r68UfTuKZRqeuMLvZ07marvrPTLuiHHkfuY1otLsKiGnvIQOvqKJMFqsxn BVPnuF4LzAG8lLpRfE6GHo2fMFmpOOqLqgmYannlaKJcZlqcxiXQ94k0WKj7P1tO7YHcR+Y70JS7 Mfed0ewjxSf0SyFlwp/vx/Xu0zIGKu7EabzHWVSx4mH+SsWNylOZMFP/uLKl+X3qwUl5PHBSPpLf Oix/h4XTwwLW4UJfCYEyVQYb1YPde2UJB3JHpFeSyLIy7X1d+Wyo81JeQaReSwglVqYBS8wA85G1 jyWPR98N5oR3g9gUZMT7rq0Ay8LzoR1EW6sbzRNPPpGmTpmWbiVww6OPPoKlKaXf/dDUQKY9PVqa utHmEnihWw2fa+wIJsBWB7qw1CHsyJKIXnvFLANIRyTM3X5ss5u42YrXIVEveyeqN1DN3F8GHegh PF8VgQ/qWH/4IJa3mbNmh8vcMraSuRsB5R7cjGrR0rqP6HXvvj5cr772tZtg2Jals2AyJKYSmirg IXXK7recV4yPA22148f+91c5llzj1dq6KzTvupB+8cYbY29W+/ymm25CcP5gesslF6eHH/pVuHtp hWnD3ayuAS2xRLIQSusGQBzBkF6+IYwkXJDGMqwHTiprn+E2QEjiEeXYXP8Fgc51r5LoWaruUDzX oqLw6jjSYhprnLlv0A+t8Y4hn+oVWE17GmEg5rbMSTNhNtp2taZp02cgUO5Mt91xZ+wFt2TJ5Wnu vLmx/tO9I3UH+w9/8IeO0nTB+RekaTOmpR1bd6Q//OQn0yL2g5xMlOMR7O/qmq3ZlDsV5vDU004P N+jHsLo6Jy5888URLfP8iy5MPZ2Mcxih0xefmU7DQm0AkiY8DLS0jmaitLcRPRm4ylS5/kvhQibK OVjmciXkjpdzI0bb2+EiZ7/Tr6Xf7ee8rZT3HFPyb1kYizzca4Dxboep68bi4LYb1dW1MOYL08kn 60Y9GfwlvnOtGAOBQWM5MZIovM9fPz6snBeHCraHukynklspZRxO3VG+OGa2wYT/9K670q8fexTr 5EbcQJ9N9973C5SDI9If/MEfMV9xLUcQ2gHT/ZMf/yiE0Casb27tdfdddxIN9FMhNIqVx+ICqYWz EzxUxl05Hmh7fM/+Godi6/RTTwsG30i8s+fMiSUDrod12cCE8WPT3Dm6EtN/Krlg4k219Gc3872g kLi51x/d9qNvuZ/HkIJDHkfWt9R9r9f263Jf774aLByfQ6VCg/PcVhh3fCbm/k6UWtsRROchvBOY Djz07LNL06mnLw7c0Q29dRboqTQBRcIVV12VRkBnxFdjRo9NV7z9itQyZ27ahWJs1cpVRH9tTWPA MS4zEK8sWLAgvYhC1DHknpoiPoWlJrYBa2SpwuoXVsfYqsQ5BQb7hiVzyrkKzepg2U5fNcsoVBQS rR75ifapZFBh6dgFh5sZOuE9lRUqIMTbfiMUm85R7nvtdnX0Ztz32vsxIHyHOW1Zrq1+GMvvZ//2 b9Pv/d7vRcCo2/FG+SV7uiqgO85WYa032J+KLBUyRvPWUmyUXL95//2/QFmzORQCTzzxRAik06ZN 57qW7dbmhSJFZYJ8k3Xwu530g2OzHpyjt40eAdOnTUm333J7+vu/+7s0ddJkFLsXp+XLVqQ//T// c3rzWy5JI1FoCiPHamdnG7gI9127wj6BxskH2UC/YcRqx383kf2CH5OGwi9J84S1NNi619UrYGvt 1ZPCLaaIYQAMVchlrJn/Biy57zP7tcC49DEfHrhfzj2W5OfFEcH72Ye0uctvMF+NwmB5xnXQgiut jjRA93lOn+ck1Ew5Tw5KxVwdeIVvOCEGkvnzLwRiM4rPSSqtnWl9wC72LQce3YZIdlww7qqJReH+ yvIIuQzfOjxpWDg9PHAdLnVICFROkpJpsHvl2dF1FPEUpF6IosdyX7Rla/y5zif2ZJQI8AvGrQKJ iQgtKwuwvMF812K6AyZ/9ZrVsW/e5k1bIAgj0xXvuJJIqE+l3zz3DFvHkLXKvTNbQcRu+g06cesP EKlfFw/lX1xFXUBPFYAEqQWRqrj1Op2KSIWVaQDv5itgyj3/iaRpYjsMs66wzbiDnoZQMnXGrPRO GESRuNs/TJsytX/t16Rg3IS/IXIqiUUUfYj+ZGK/m2HTsqgwreVTC4vRIL+E1fRjH/tYnP/bV7+C Bv8jqRF37b/8y7+MWrz9infA1NJ3IHyTZUZ97cO4w1HCVShN3K3sy/5MAwfeHzjPZ/71LrXj119q CKcwLPwbCPTgo/jxRn82yaLf1qU6grCgnK6hjrUQ+amTpqYJEyen7Z3d9MkYBJhT05YtWwhE0ZjG jDsh2hLbWCBEnnn2OSE4WpzBkTpgapqxPCzSZZ1+OvOsc+yoYPBtv32qpdS59aYLLoqyfNfytHQY FKNbIg5zY/sMkvS2t7098lt3rSda9CzLeaZLpfNM+B7PSTwjsy18HYfiBpmujvbWEGyKdUnLqAKV VgWfyZu0t7E1Bsy5/aOgJex0s9b6pyLFd4WpAm6MURhAk6OoDJjCqBW8VsZz5I/cB//nUJSx99eD 6WSs2QLHST3M98mnnBzWsqXP/iZtAf82ovhYt3YtlshZrFdrImMWaGXMZdCfYG20Lp6u/dR74wG8 OAwYY7Av12CL0yvHnf1SaMfe9Xm1a7okIgdf8fa3p7//h38I65TjeidWbV1N78GS+wHWOk7Cq0Dm 2rnKx6Pfgj7Q1tJXg30r91d+Ekw5TL9z0Xf8dmU7Bnv/YO+9lnIVwosyphc82mXgNvDCKPDQbxOL 4OwzzkYxhdcEQqt9dvoZi4MBD7pCn7dxbwqC00c+8jvh6fEyFkDxnUoA2z7N7cEQTEPwYy7Z5y5N cK38krctCfgqlCoUmxQExoL/NhG0zz5xjaPzZv8TfUZ5bkujCMIkpUwCX+HZUofgVsU2c1UIq+H1 orKBuircKZA6Ja27ApdJod42+DzGQz8OdMw4n4R78CaQHxVR4RJLyVqOl1x2WVq5YgW41l0BtuGJ sgmB+4V08cUXh2u77fd9lTa6rntuLAgj52uZFkYKsW77NmfOnFDyCLvx409A4L2A2lFn3vFnCkUo Y6zwU3oYiadeeukl+gJvBN49+eSTwiK+Y9eO9Pd//78IajUvvQMX7SbmZXuve5sXfor2U67jPzw7 cPlVmOxGgVBd2xACuHSvC1wZPAgwC8UesM51Emb2Qba+SoMV3vX2KfWWFglb4ejR9zy3/pXXQ+Et R0vga5Qk7mm+i7q0sTQLp+ZUx3d8FsKpY4B20Zsc+EXKCghP86iLp/Q69Qxhk2vet40Zuj6nflGG b3mekwqpnIujCg/ec8yhgkvNdQjy8JZu0dONQhgTC21zdW4OAtlfxGE5DAunhwWsw4W+EgL9k6sf ae75PCPSSjeKPZ8fPVcinoJMs1CZBVOJXiAkiLmWPFMNR/P7k/HxWBCZzy3HMvyJD3gcEUfPhpE/ ffFp7M/VHNrI0c1jg1Bu2rCctUZ/A5O5Ir7lGtRwl4H5Cc0y385IjLI481cQEKd7paGf7JXxsF4W xDn4R3J7CgybsIpJrHTtdU3KNAioP4mncNUy5lEiputRMJ6DF3xY7oaoB6LX5cs1p+9+97vTt7/9 7fQlBNSP//7H049v/lH60r9wfsPvpytx521F+26/UeUYC2VcvfbKCbdX9q+w3je8h/6ysJQu6iYl 4yMTI3HuxbVamMsANMKEzRt7AoQWIsv+dAqMMnSO7fHjJjC+c962jvawgPo1BSnnjfPDcmJOCRDL DCGgWPb4Pvlq6XfzCit/ulb6vhRaq5JlOF4cIx5LPgWCksxz6GBdSj06jgqiCpwrYCpdWyesFMxH jsyBpAwqJbwMBmOkUiMb//OXv0AQqkmsn1uR1qx+Ecvfn4ewpdeBQpd96/o7rSYm4RfJPshnYanw biVchX9JlffLvaPhGGOnoiLW0zWDi05alN6MUkTmXDgKE90cX3xxDZazueGRofvuVe+8KnC2jLpw fscVV4YglIusQjjZEePQ/TEdnwUOHgfgWPH9VzuVjRTnj0Vwuugi119vjrXt9pP1nDRpUlgKFap1 WbXP7D+/5Xl8dx8fER7m9R1/ZQ6FoqP0+z7e39ej0vbB8rwaLPb1ruUpSIg7Ch6x3ioTtGD++7e+ BWPNGN6xLQRKrcuOW9tnub4zAti4zZcjWsFMpdc3v/HNcGU3AFAvyK8Wi5ruqwbF0np6/fXXp2lo ip0nlmcb/K70aAoC7VrWa2tNNK/P/Ja/km9fbepzvaO8BIJ3T8KFnP12R8JW1Nd2p1a2Q2lAYVJX OyJ1gFNRFaIs1OWYiOgIUEgkRLZtiznpNzJcCIzFXBdVKpCZAtdSX9ssLBRkpEeOMdf/33DDDZmW EaHXeAkGQ3M5irTVgEiOed/TIv2+D3wgymtgqxmTzyxfC7P0WP5IYVMlVwOeBwsWLBz4foENnBAE hjoAzEocbyCqEoxqKnEGbNPLKEHFZVpxP/uZz2CNPTG9HYXNBOakeMj37QvnnD95sg6U27q2qzDQ Rd8549pjMoYyTmHQsrugaQUveK3iOAR/x795pIDCrX+ulPqbN+DIfc9NHn1emcp1UFIe9SEsP/7E b9I3b74n1Z0wMxQQNVjJ5Yf7EASFB7n4aVSgXXFON7u3mzAzYZgwoY6KtboSa+uZhVPOHX/W2/r4 i9wOFStAGSqrNcu7cAcB1f6aOrYxvecdF6apk0ez8wFeR4xFYUUp/W8f3sNuin14vzNc+jAEjgsI iGwC6YmUEYbU0Ip8RTgi4hEgPwmSz7Q4uHZJ4qVQJYEvSMv3XIPnuhgZP4nBvHknRsRZEfuy5WtC e38alosTRo8LLZrMkMjdb7l+AzUgyAKrG0y8iI5MQ8DY+wUdDZHlKLxdYC28JRaFYHhUS60rkQRQ eHQjpDTh+uk7EohKYeSINQ3CrvbVoBoG4jBCrcEyvve976UvfP4L6aM3/F76QfsP0te//rUg8uPI Z7eojdXSd7T0UNAr/lSOJs9rGHMKnlAx4M74A9b8j7rbEPuhlT5hRMIM6FTOXZgNNa2uU7RvzGMk RvtQBsJ+CkLPs3IeGmPyCZfCQHnk5Xi/vFvGh2XKMpTkdWWZ3vdeZdr7uvLZsXxeGG3Xh915552B Y2QK585tCbykFUfrdmYSG2A0iZCMBVs8tI09PZ97blk8dwwLI62lRk1W8NIaWOabMKqEoUyxYyHw UD8A7R/7qrKfjjbY2oYynhwzts9fHevXRk5sDI+MOXPmhLus6zx1O5e5bWjAEsPYdW2dgVwKjvK4 g31RZeCNHi5N0BXUb7jFha6FpkrYHQxM7F8FhIcffjiEH4Ov3Y/bpYGX9NgweJM0SEu4SiHXUV7H 2u6d7N9q0KShUmmHMLDf7H+jNCuUmXz+eqSI1DrEhwssra/JujsPtGJb/9WrVqfvfue7af2mjen/ /Yu/COWN75Q2+p7MuMdsdUzg7zUxf9wyKKziuOpOZ04ooGklPPuss1mzOGEAh0lzKr/dDE/ghFCI qkZwqqyj5/5KfePFij+2Iqxf7juNIqK6roct06rS6pWPp3vu+npatfzRNGumwth70ozZ86lDDUsr UBZiFezsZL1+e2+aNHU2QgbChGUFXCw1KzbiJn+EUYYDfElYBoUdOJ71ns5339MC6trpk1lHq3vu Y489FlvwhCKYsYDhNoS/ExecGPkdH/I28iSOO3kgYSMfJI/j93zXfjGvfeDPPFUU5rlzxXylLPtG ZZs8lHjLpKLFLZqmIaxaN9e3fuUrX4m5qYLmKly0p6IgsIyyRtZ3mppGxbXtM8iTMR9se79sF/lt t9/P7cgKJetV6uRz6xh8RrQ1C8LSL9/xeSnDulaee707MQ4QInv6GlJrD4qFhkmpvnkuLzSga/U+ P/BqL8KiQmn8oK0hrPKnl23fFE5VGofgCg3sxTpMrGXyQpfNSxn2ew1wUCQ1urF58ixWeCWrNLpf ONW7qoaYEjVtO1Jr9y7ouZ43fAVfab1wel3fi4X9SKQj85Uj0ZLhbwxD4AhBQGFUhu1zn/tcCBl/ 8Ad/AJKcEQR828tbYy3SvPnzB4ImiCB+93d/N4RQA7uIwIzyp9AiUj2TIBYKMfX1L8R6xWeX/oZo pritEm3RqH9vvuBiEFFP+iXCzsqVz+FOKZPQT9xAkrr/6LZTyRgeIVAckc8UYiAxldiYgrCKLCEE 2Tp3dDDCrvsJiwrEUSZRwmrffgvt/b/8843pd2/4ePoZkXpvvPHG9K5rrklqmqu66EMpThCSIwLS A/wIRA0i5pYUNazNUbsuc2GSAVIx4Bof+8Gf49B/oamv1TKRBQD70X4z2Y+FaCvYOH7LPZ/7rDAE npsK0+J88p75zeO5v3LffCV/5X3vZWIdj4/LP8Ij1szBFH70ox+NbS2ErcKMllKt+jKYq3C3U2DR srSA9dHtuPbWsLbN6KQKq5V9oRJNa10lnAWe1wPJ4bv3Pa6Fd/kN5D0KT4SbbTZ5DMbTsUWjnM8y ngr5n0fJZGCoM89cHHDWOqlqxMBzzgHHd2aCm0KIURHw7uveE4o0BR9hVr5zsGCQmXZNsN/RAn7f ffeFMKobpcy6QrQMuWv+vv/9r6FUODeEDL0fZDKdy0OlUrcyT2yrwdycU+XZUO++2v1S5mD59hhL g2SIdXmD3C+3fN/ySz3tT2GgB4vKg5Y5c0I4Nb/eAlrDwlLGtUy3SwjKu01YJR986EGsRV1pHUF5 2lEun33O2bEOUquqVryp06ayDr4xtaN0o1PjXb9ZaJSurpZZ8F2p5/4c7R7rZn10RXVdaU11Z7r9 tpsQpO5P7//IBNzMn0jf+t4vGIN14GWs4z1tWH9x0e8ckTZsGpv+4i+/Ql+Ppw16V6H8pBzxtrNU WGVlUoaZSm2HfvQPJ/Ina9asSV/8l38JYe/aa68NWqV10rX7LqlwPgDurHDpF9ByWxX0VSqCg/lO LAWhHT6L6O3gCeeKVampUZCTlmuFREilHvaN9bUuwtPkuBN/qVjzu5aVy2uNPja+wxz6V0XRn/7p /5E+f+MXQ/D8sz/7s1iP7fsBA95VYFVpoYJJgdlnwkMhzfmhccH0OIK42E06p6v/VKysLpXYinLK /OY1iNYMLOeuVw4vItqV26NQaCnxh360HRkPerck0EHqRAG7Zv269NLm7WnslLmpYcL81ME2bkA3 dVOYcIzghW4sboUi0X8Ik9UoI7wVa0xBVH7NCMes4uWc5/EX3hBRNAI9mYGP9lBuj/kReGvph2rq bVlaTnlCfdkpopVI1V0bUbaPCKWB36gh9kdRbO1rLkcVD8GfYeH0EABxuIg3DgQyYs+a1kceeSQ2 Y1dQvfvuexAsnyeq7tp0HkhSa+lLEDY3rdatR4biKba9kDGUaIogjRz4wuoXQruoNlbso3ZwEi52 urCqAXz00cciUqnCqVp4XYzMpzuj605EQCLKwIZixooUda24PtZOBwhHP3ETIQZhkKBE+NgiKGVG w/wSE/O8HsnvainU0iBD77pTA0msY83Mxz760fSv//ql9C9f+EL62Cf+MIh/R78GOb8nkcxC1ZFA /EPDx3owwmzLQKbMKEW9+kErA6Mb3HO09Rs3/yQiEcuszYB5mzVnNkQX4ZUCZCJc0yKjJbMhg2Q5 /rxnKt1V2l2OpR+jLuS3f00+9155v+Qv48Vn5VeelfeigOP4j90jlMQ5BirJSgThDcMBbvGeQqrw 8boNC4LrSh16Z7Hu1/E7kuAxhQFUsDVfN1r0AlPv5eQxjxK1/KbCUGr1luk0mrJeAdajsi8i81Hw Z/cYyooOx5D1lAnmJOBgu63/WCygRho1uFdz86h0IgpI8bKwMo9H2+9Pd0NxuozzlKlT2PM0e3nY 5NcKB4Vc55+KL7e1UYH5ENGytRbJcLe0tMR9FREzZkwPmqFL8s0338xygqvCDXMo0Nt+f7bB9ujF o1XWOvvz2cGmfbVb+O0rZcFq6Bw+twz7M9cxK7cUWO656x7w0gyWWVwXgqoCk+vW9eZQgWa9HNP2 cQOuuzt2bA/8nfev3RiR11s2t2C9W45wNjHy2e+OeL8p/TWAT0kKFAo/ljsaJVElzAoM9tVesBfv ijeBNcKGZr0aBIa6mvY0cWprmr9gC5bR9jRnrtvUjOW5W7ggbMFXrH6+i6B0L9Eu9wPN8AghPCrr On4FLgWQDO9Sf+uuokXrfj19rxB+6aWX4uXz9fCqkFbJexj53CB+Zd4oTJqK8EeFGTcqafI4Md/u IFv5WfQT3yplCEtrI48krAq8hJXnlu14jK1mKvrYOSqfpSVWRY0W7r/+9F8FbX2B/a21pD719FOs nV0SCqX/7/OfD8+QT/7xH0X7xrFnusoLyzeJ5yzTb65cuSLmr8o655SKhl3gSl2JXQOrAu/CCy5I zy2bkOay7lVDg3yd9TTlMWXbM17kDufxaOBPdV0VwdcIInjLXalp/ML0W7//31Mna057EAj1hVP9 m1W5/u23kEJLq3DDdS9y76o8S0bZ5+gps4Bjpt1aXasZOwqmgI37CLNa43mpu8bxm8uwB4MSR/3I C+7uQmHOrrCMIeCOIKyTnkMR0FAQX8ikm4vDl3bPqMP3jeGShyFw3EBAgi0yExn+8R//cbi/6AL3 tsvfke64/VaCAJwVAqjCyRlnnZGuftfVIYDqvnEuGuyzzj0rEFgXa+LuvufuEGREhotOMcT6xWn7 y1tAWNtDQymiPOmkRawz/XWsiRF3iNBF4lqoenX1ABGFtQokFBj+GIO0bkFDpcCVPBSxms9omv48 N5Kc2jzXcrnpvAQuIhgKB1C0zLHH3T8/5I9SLdDz8gGuDiZJGCypJImPG5BrWXfLGC2ml7OFhHtF vky/ugb1W9/69/TNr3011iTJXDqerEaODrjbOlXKPPJHWxQUaI9PB6MAkctb0KjXlVymtBXrjEz4 Dpixjbizv5M1d/MWzGerI9dzwQgFNcvMS2+sbZG2QTAh4sGUkMejybGdrawyZwoGWUgohN55UvKV e157Xu57DOYnmKLdzPS+mMF4+Tj5Yzv9iZ88yjAJn02bNoRyy2aKV7yni6owzVaOftwCm+LenL4b uIaj+2qqGFu9+vnAXQXellXO7QGN/75nslyfWYZ1cK2ajFvJH5kG/vhOfm/g1hE7yWNHgcWk0Gcd w1IX9bcteV20jPCb3nRePLvttttivafWJNcr0vCYy643/M3SpWG5URFwySVvSTvbdlIy7WP4iqtj rVr/WI6PHsQf+9Bkv+iaqMJBvCNtuuyyy6L/daN0XaqQ3cb8FP62wboOlSzXMkrfmU+hzX6tvDfU +/u6X8bGvvIM9ezVXAmtWynf5nEZP4Pnvf3tl0e0ZMehwtbWrS+niWwl4rjvxIU1bzUiTByzBKYh 4vqFF74pBBgtdiGQrHsJBcCD4Ur9trddBn0eH4HEqrHK4kzCexmHRWR1aNPGjesZD91hZRXHW7cC Q9tY6jpYe21LzMn+taPVrDOtqupE+KxlrPmxrdC/bWnceJcTKSgq1OmRNTa17mxOI9lurhuLaW9v Rxztd8f1LtzN5R0MHqRg3ok3RCNbEFnPjHtzPS1P3KAy3fvFxb8bnqWa5RpGtDaegEKvZbvO3ZRh bt11DbZMxgzE2m9WY3UzOfazYJwFUcuv02UUuIs/OkNhYLkZR4XAikWvG3dSqE8EfQxXWESzgFN9 ximdPewvTKAoFftTiPC7GM+Gi95yUWwlNGr0qDT6hNFp4uQJafnKFamxqTHWlCvUthMbwTmpV1BH Rxu4jkB9BDbbhAv4dDzXnFPiw/t/pfEguxM7ZmbOnE7E/R3xu/5970lzUMjap7txnOfMde5Zz0ET cOlkrr3rug+mR5/dkLYzNw2HpBApHqnC68hxBaSwbLpkCDhSVnj4Aisj7co95PL5Bs8NXtQHvuIx wAbmjjtO0TlGvmqYlhBWvcGD4jFMKVFFSo9/7hsbgdz4dhV9o1U7LN48tc8S/eH7hzMNC6eHE7rD ZR/TENgbqYhonJgiNS0TixYtCkIu8e7FUrRkyZJASJeicZQgmVdiL6Pmz3uGKVfzrTbu/RAUKwAA IABJREFUGtw61USW52AVNK1j02g09EZ9lZFwr7pRI5tBOlow5qVH0JLnoCeqrmDgYapqxDMgj4yI MjI6ZgBPtbXWDEashZ/BDMCqAUvz+JMA+CweAYN6YCoMzVfykC2QsX1Yyt67P8kR/31eULMYV0Jp H5niHQvbK8V94b7HM4UhIh3iWnf9e9+bvkfQBd3iDFTSjrb5T/7kk+njn/j99G0E1Ju++tXY31Om wTYWTfOe5e310df5MmApAYToOpY72C9u2uwTwy19PV4CjkHd1nVlHEGk0mA0cGkSesI3FCr2E7C1 v+xHibDJ/rTtug2b8pjIlldHdI6GmRkRv21d/FmG71meZZT75Z7Xlelohm9lPQ/2XNgAhAF4CZPN mzelLxGUS2uI1oECkwKLYExgWmKdG7DO9zOT6fviO+Hr+sa9UymLl/hmZu71ABDvWRctSCrqPv7x j4d7rLjyaErOV9sQY5E2lnHkUeWT94uw5rnwOI9tqzx++ctfRvBuRGA5n3WlY2Nv3gexYNrm9zL/ y3rUGr5hGbDlUX6Ort7P5PUDo8DRcsv5UHDSfVhOXibf/CNxdxw9egzvZYWACjJhr8XaiNbOANdH 2iYFgH0l89jOUgePfsPy4v295tO+ytr7WRlve9/3unxvsGfesw77SpZt/XI+z7OgpTu6qQHB1DHq cz2cTiCarufi33gHIClsKXTp6j537tyYB7qSKuTbfusY8AA+fivuCed+QUp3V79bA21XUafiwOBL 5ts7Wd8h20wfOZfIgGhgUCq3IVJA1XTFVk87ebenMeheR98WBBS3yKKf+U4NeaqxpN3/y18Qs6KP 748NQbOlpSUU4W5/4zrae6FJjQippxBJ9+f3/Tzmq/yL+CHawBhy3jqPbb8B5qI+jGMGSDQnCyvU M5J4gxHOT1pW5hMvxX3LFA7FO8j7pgwD+kvYAtN8r9zPR/vH8lS46ZYu7IoSyWf2ReAV4Fa+W+r9 3/7bf4v8vqOXgYoGvRlMpV8i4ntYe3MMBBUSa4nO7XPXzNp+AyfpRaDQbryPyeyvrhfcbOBqvXQX ruxPz/35XX8mjyWP9XT+dsP7TJg8N1U3rkp3PPRiquGbKsqghmxXBQ6qYUzTw7VEa+7BciuMRuAO LQ/YxbvVwgQa697kvfRNb1crQbOicdwDdzHhu1EK19bnYF9d7XgLgBdq6kYyxhxP1Ivs9g+dF+6+ EbWYusqD2tVVMJhRX9TRHer8j1AaFk6PEKCHP3PsQEAkUghxQSYiwYJkbEnJ4/3M8IFIQMwyCE5k f75rOeb1J8IsKbTRIIN4JpPBP+mRmMJ7lisCt4wTIHB1lNfWtj4jNxEfiEkmxXx5vYQvS8zyN8lI Of3nQQhEQZUEgTK4c7iT9feX25PbVuDiUZjYjnJufTwXBjJ0Ci+FEHlPuFbCNM5piHkbRtRFeb7v rxAftbWu0ZXgey6QAXkQc4GQrXiZMPoN36tFI2uZJgmFyWd5XHDBe8KvBJ2wfT7ns0HY3NfQtVoy sCoZ3ALneVyNjFSopeO5Zcsin3XxPYZOEHbr/XokahCtlPhJ+KyG9TJFnWwb/7KVPveb64TG47Lo urfGxhHstTgpxmK8Q94CLyHuHqYBVwijsDKYleNT7ax96jjweXmnk0jUoSDguS54CkilPr5vnbz2 WHnut02VYyTfeWP8DRj195swEFYylq6Te9/73hdzKY/hPD8UYJTC7Itufbfod/vDJFwLrO2bgtM8 95lMmSnmCd8U9/j9yn5SKXPTTV8bmP+VZcbL/Cn9V66HOpZyh3p+MPdtn+3xV9rqURiVn+U6PmVM ZW5XrVoVroOLTj4lhNImFIoy+jWsV1t85lnhBvnrxx5PL23YFHs6zp49K42Fye3pwtUZ4Sfg2D/v bXtJnvus4J1y/xVHkIXYCpRGAt7MkRB/RCKB5p2pMN8+5ZlJJjgecugfHnF/7z8FxpXH0mcFPnu/ cyiuy/cOtqwCR/vMVMaw190w3goCCpGL2IrEfabPOuPMUD5Is2XuzacnauxZSh9kmiEezOVVKRRR bvmO77lvrDNFnBnPnCN8p7OtPe0kSnMTVknXK7pPqmn3u7uFlHgwyJ8Q1px/zk8IvMKHEXyre0en p5/YnNav7U3z5o9KE2Z2pLrGnTEW+kIoZB6jNFy29Nn0/Gp5jmqE5Na0HldUFeKuM1fovP2OOxir Z6bxE8dHRHkDDflsEnuJCsLVq1+MPWHFG2tfXEcQpAWMJ8engYDE0wqJuyvOlAkYxsDrv+14MYXg w7H0Sdys+CNc7H9hXizQzgHv6WocPAKV0p3WpVAlFTxUaEe5X3mMuUb58hAGqnTJjUYFU6wXZz6U fjGv3xQWej3xhF9upG2xvRQ1kNw/25v7mq+WV8ov55ZjQCat140jmlNVPWtflf1jjgoLYMWfoMPi ZBQPNdVdadlzjxPYqDPNwAK8Dm+sXgITjZs6PY2bNCXo8vp1q9LKpU+l+bOnM2S600vr1qZWI/o2 jEknLjqFNbvNaekzj2Fxn5ymzDmTSM8EJrT9fDc+QxtRQQW8He/iKkRgvl8XnhcdXDc1jeM68woF GLbrcKTd3PLhKH24zGEIHAUQKMhvf6ti/oJYh3rHPIUQ5jwFCe0Wisq7A8ipH9Fl1iEjhXKekaCT nDsVGDCf53sSwfKsAkcGClXbJSqRmIosIoQ6GEeEm11cK98oNTv8R+tSkFepe4GtxEXhMweOAAlT Ra1vIXhLIUkKKCW/18LA5D2RJ5Jj3AvtYX+f+B2DEOQ1JHVhtVQAFhbifwVVkbIoNtyGLJN3MnHM TLcEx59lVCbv6XKUNcy5P/yebZQB8hvtCF6uQfngBz+Y3v/+96e/ZTNzg6qohTWC75o1L4b2WgJl ebDBtqjyM0fduaPHvoj+BG6O/Z1YBjpZM+Pa05GjRgZRryVPp1Z/XJabYdjVSq9ftx4GZy3EuDvW 7U2fPgNGaWREMxUWWvZcY60QLwNlREXdQJcuX8447k2jWOvkHns+E47CTW12EY6OOmAdhRUqc0il mGM0z5EsmDFVAva63snoOSYLQ1je851QqNE2t2Vw3tpf3pfx64DRio3eGSiWLRPru5zGcTCQlHkz 2LPB7pn/UKdcpPPWbTacg+Jv52PG57bP+8uXr4i1plu2bIaJPydddtkSXAXHBeMtvMxjXueHeM0x +hgC6l133RXz/k1EOl544okxhqMdAN29ZJ1Hviu8vV/K2pO2HOpWv7HKc/uQsEYB89ktc9LNP7o5 BDRjOmSYQ4e0eNJ/CpsKhlnwcey+kiZX0mppiWOn9OMocJ7BDvUgufCiN8e64IOBdrD7jAtJU3U1 1jE8SjpZB5jSWBR6Xenn96xPzzzVka5+X3Wa3oJyAvfPBtxtnSFGaJ47d0565tmnuO7FLXdmWP22 YxHcRFRuLestLS1Y25tD0aL7qgpG3VddS1kHnFQeXnrJJeksgmxpFVSQyzxFqEEGbZLfZtbE3z0z DHYv5xgQ/rnUcu3WKba90GtzSXdOYIsy59K6teuin+SbtFQHPernGcw7VDKfbZqFosgUPAbvO/fk I/y2qcy73RbeuB3jpBL9eB7GCOqxd978hs/7eY3oR3kFlVx5/23Xia9YsYr4JBeyxnQkPMFm+oX+ JVJuH8GJDJ4bOBiFhMuX3DZQr7uRjIPWnS+jbHg+zVt0GnhmRxrTOyEUY11dWNiRcrdv25waWc+6 7sXVqW/E6DRp5gTq4pjG+oqwqRXe81SFUAy0o8+Aew8KEADBkpycp5WIvStWLk29bU3p4UcfSW2Y Ta+46to0Blf5PpbcmITr4UrDwunhguxwuccsBJxwgzFC+zMRIyT3q7RcdDBYEuHmKZ+fFhcs8Mqr pnDrlacib9QfomkbRL5xvUfJr1rcIcsgwRfhS+ythz+vS90UErUoBCImT283yN5mUHetxSNYH2Iw BrXekq0u1pcqAPk8NN4ca2shyrTXNYpaf/zpbuc6pZ07t+cNukHcMoOCMogKwqpClXvR6g5V6ie8 LNv1Sa4JLdfWzzzhWoRbjYJWN3t/mdc2yYyMHdMc62dmolHVDegHP/hBuBJJ3F2/c9FFF8a60zuJ 1mugLAPRSBTVQncpaFM7v/f6p1eOT+spkxBa8H4mfO3q1amLqIYNtM+tSFpZ03Qq1qR1a15Km7Zs CuHF9U3r0Lz/9I6fpqVLl4ZLpAFWbLsBNn74wx/Flg0Gs9Adcs6cOQEzI6P+2799Ndzx3F9Q9zhh b7RIA5FplTavzPxw2j8IOFZNHv0JOxn3nTCtj/z6kWDSWneiMMEVVDgrYDl/s2dIX0T+dZmBLo+6 vZm0JholdvK06RGkLSYv952LMp5G7jQgClzPXj/rErOx/8jhdUgKF/6cw+FmF/NQYVWPGPcI7Ylg QwZBMqr6Bz/4ocAtCjuduMi5/l35RdxQiUNUpDjfDaD00zvvTN//7vdjHaPj2uA5rQj2uqrn+Z9x YiV+fB1AEWPi9fju/nyzjN195RV+g6UsQLr0I6FAG53OQ1Hw05/elT784Q/HHJAeGTk2ezOhVGHM 25cDtJN+Gix5G+wd9MSxLB2SLjz55FOB0xcuXETwKdb4HkSK2YHAjB2LwWW50MzEFiPVTenZZ9al pmaDm03EGoZrcn0rUVfZ1q7KNcfm64vlJDd87PzUDE0Sr7qOcuPGzdFe98g1Am8143A9a2M/+tHf C8+K7MrqRiQIvCwBMLjd3HlzY6y2MV4LfAejUVFfAJK7YDB4DXZvN2B86h7arv30O9HfmSQGjBef tjidtPCkuF++b55Sp1cbH74jPXdeumUNIGINZ/+6Vr5Z0hBdzeNXjq2c1/5/5TPLy+3oDhzoucHh HINuNbUBr4r2tg76ZFNq7apJL2+lD+sm8hJ8Ev1i/AxEZ3cdhd9xC0Jo4IQpBCdqTds2rUsNWEHb IH2t4Oq6l3eGm3rDqPHppNPPS+3bN6cO+J5Tz7oodaHYGD1xemoeOyGt37ARK/uYNGrsOCylCqp4 I/XhbQZv1W3FNGz4PYV9PWngmV58cX2q7iBiL/DayThai0v8hNMXE1F4MIgUKB6a47BwemjgOFzK cQSBgvTK8Whomsg7foPjwdD2grnDEmh91XSGFTIwqG++fknE7K+SqCjsuYajSqESJlltrkyC+Uye m1+L22OPPxb3li9fHuu4gtDABEQbya/7i9pFWh9CpUKMQXoUaHTlca+5Cy66KI0dPwGBqS0EYTXk S3/zbLjnqS3WEqfmWGZbjbp7z5aNv0t9ZOZ1iZKRWbBgIRaR0VFWFQLuKlz9nn7qCVyGFob22XLc h9D1proiGclWoWoaBH8OzP0XiNp7Iut/1Ia6N6hlvhqBDSAc9j/C/5WDLCzWBGjQquRm3FrjXVs6 AwFzGu0RzrZz8WmnE25/K3viPYlwg2UVZcKIere12BT75Nl3y5Yti35SqLG/FVZlGlzT6Dot1/wo FMlMkIE1M70RidH1X+61Z1nD6cAhUOZhmVv2he7YDzzwy7D2KGy5V6YWBueOaybdlmTFihWppaUl xqdMq+NU91bd47Seuv9jS8vcfoWNAq/772WBLZROMj5HcXKsmQpc4sg9cYrWGteW6eanQkXYdCJw 6CpaBXPru7pyKojH2vGKtirg2P53XnllWjBvXvrxj34Y8DIKrMqvYPj5rvkspwi3UZnX8Kfg0P0t 4ujAO/tb26HzDUWvhUfQTvpTLx3XXLrv9FMIkYsXnx4eIKVU54Q4J7xouPlKTAgdppySzG+/ec++ FscvB79df/17A7dlqjRYKaWEoY4qLvgOih23DcHRk3M8HhAd3afy+TWtaWTTpjT3pPlEz+1Na57v SC2z9FYYhYyxNRR5J5wwBdrYnXZRx6koj0aPzltE6bZqoB8yp5Y5LTHuFcz1SglvCMo3VoJJ5VLA j/Y5RivbHhn4473dENl9Vp5XHsv7g41RlcblW8VjyvxaNlWQOWdCgUD/HGiy7vbPQPn2M8m5bifz mT1SqeceN4e6GKI+llG+WdqrK6+KLWF94rwFBG26GCExpXseXp1u/sVS4uOiyMeyyf9QfCGxBl+D f34ae8LEEE6bsJDPntmCUAtsqvHsAm4jWQfbOJ7n+s+hgOlCoT9iZFOqhvb20lbx1dSJE1KzS5/I W1ffm9pYn1pTQ8RnP8Y6ZXFYHd9BhA4lxniWK7zz7eejpJiS1mJBvedn97LfLutVnSLUubRpKLC8 1vvDwulrheDw+8cdBJx0Iq1CdGygREgEd7gnpN8KPLmf+Ne8Giasr8jQeuqWJFLUsijDFIh2P8vz +4cyFYZLuHleCJyCjO5PS595NiwxJXCE+WyDx23btoXA4zoRCaqBSCKYQVASLB4ctULoYlhoi0RX YefWW2+NfUYVdnSn3fD976cxJ4wFwZ+ACyJR/QiI8XOsIQqPMiuuBz377LPYuufR+JZ1tR6+77cV ihSWWlpaINwt1A+CQNAfBaU6iMVLuBvd+7O7gbWBF04JK6EWJtel7Ni5Iy1EmH0KN78v3fhFmIom tNUfTZdcemmspVTo1Sq89zqeQ9kPr7Usx1B7OxbuehlxmBGUCs3AdTREVmFEN1w19G6rpGA/njW2 V155RZrI1gtrnl8Ta07nzJkTLmJXwqy7H6NCqAK8Ao9Mv8E6Nm/eHNudKKxefPHF0VejUQKo1bcf tLZeeOGFoUCwf4bT/kOg4C5xhfMwW0RTMKoK/uNPQPNOhFktpoWBPf/8NwUu0fqv0kcPAZMB4bZv 3xHWQZU7JudiLdE4dLdzTPs9v1VwU2Q6iv7EOGYsW89yXphYlUZ33n5H4IMPfOAD/e3NEW/Na4pA OBz1evCO2y5ocdUCYR7Hp3jEcb4QpdUo8MVXCYTm9iIXv+WSsJr6PRnuAq/SR5Z/JFJpy5H41pH4 hu2hO0m7CV4Imv3jkI4JxYvr/m8n4vI0xrWKSXEXHZIVurxtOVEW/WPfltL2hlehb86fdWwPZwT+ k1DazAP3b9+1M8qzNgea8N6UIlgR6BwKQQRV29GJUhabVjrl1NE8rU6PP7IlrXp+fdq1rS6ddvp2 dgSYBt3fgmfOA6w5fASl3qT0xJNPsEvAOemB+x9IJ7Pm9oaPfyLaq6dAbElH5WyX9E2eweScLclx 7M883q/Eu94rtNf8Cjj7kwocK/tKrxy9nXKZekIptmX3Vo/Wz29bhzJPzFvmr3mGSpZVeA/zl3ZE u2hB4SBKP1eWU9m+yvvlfF9UqLTBb/tNjwreKnblOdpQ3nb2su/92m3gE4RJ0QcW5Cyo5y/ADQWu aGct89YNq9PEMSPD8lnPWtWt2zalsdDEjpeJOlw3Im3Zuj3GygTiP7R1EpBu41rWtRpXwAFFu4ni vG0rUYFHbksjx+DWXuWyJQROFM/dervQB1Qg1bPOdOfWnennP/tlmjUZ+vvSutgmccGJ81GWOB6z wqfA4HAch4XTwwHV4TKPCwhUIr2CDI9EwwoyrESU5d7Q3zeHSAzk3Y/UM23rR97x4quXMnT5B/ek EA/fLgTCc5GzguAdt94WUY7V1JpXBO5PgUc3UAVUGTcFzAvYV0yNo2sdaagFphq0qa5r9B0DUWiF PZG1XTJ8N954Y5ozZ04IPd/45jfTBLYP8JmWyvbJIGbeUdiRMdE6dOaZZ4RgpUVXIqJQLNOhRVWh yzpqTVVglQhrHX0W4drofZYzZcpUXFG/kk499ZQQot3EXCbFgBj3s5/a2y+/HEF1Z3qAiJ4f+tCH wor6MoKcbTW4UHZ/PPJ9ZH+8aoIYObbq2ErAftLSffKpp6YJMN2bWHdq++fPn59WLFseMDr7/HNw D8prl4She76qKBmHEOv7CqNqwlUklHGhwFOYDwMgaa1yHWNZF+wz56H5/YVl9VUrPpyhQEC4C8MY bzIXXBuw6ORTTmZOtIab6oc//KGwnuie+PzzqwjedSXj/UMBa+eBwqnzwPVta1HIzJo1Mxhct9+Q LW3d1cZ8rM9MGN/ye8V6UOpxtBwdS/4KzrGujisFc+f7Qw8+lK4lorpKE/FQoQHxHshVd1Hd3xQe 5NANjibOLvksVxg7o1XYzMAlWnfKb3/722kSAtHCRSfFPCiMq9/3F+/w3uFOfufYSZXUcN+1tjti mUvJ1t9M+yNcqcG3p5xyStqCm+u///u/R5+4FEMlYqxFVFhhHJS+KMWoDN27Fva1+E3Pka9/7etp 7py5EfAuvGEcW3w7vNpLIft1ZJ7ynmVT4xAc+qo6KKtVAxr3a5ivNQRcwiqGu+eqVd1p3pzGNHXy TD5mkDKEDVw1Vf6Owa3X+Au333Ib+22vC5xrcCSVtAELlCkudxlor9Zah3P/uGV0I6uA+x3b1KeM bZtR8uxXk4bI5BCk2IGUZ0suu9z0O9Jz+09cUpl8Vurl+asl51rUm7xlfsZYKe9WVqYUVp6V672O r/ZV61epfFLJp/J1wwY8tTZvYK1nY9q1gyVCuGVjCk31VSPCK6wbi7njsZbB0NcNz7JjY3p+2RNp WxN91t6Kkms8Y68pLV/9dJpMUKTq2sb09NPP4bo7Oo3C6tlKIKzHfv1gmjN9YmpsqEkvPL8y7QBP 1xPfYXrLibicd6fmE/hWHWOGMaXyoxu8X4/7sZb6LpZYbdm2k+ue9OL6jWlEMwrMSeMH4LdHx+0F k0NxuWdPH4oSh8sYhsAxDoGM8NSMg8hA3qDkjEFFUvGjgSJx78fB+15VYNmDgEEu2gKz7389DKBC UG931pxF6flTryhdxBJV4on1D8YJxGadfCbSL8jbfAdOMF/xyf26IWKWCHiUsGTYViHAnRpuge9/ 7/sikuVoGELbL6GQUJp/OwyhWzMYPEDk/o1vfIN9Ay8JAVM3FUPZ616oIKPQM56gCeZ7hPWc7g2r hU0i8CRWT7d2OI8tH0So1qce1fTDlCuRlvBdc827sNKujq17XBf24po1sfZRYdYogQpXnmsp9Vot 7+OUe/ZZZ7IZ90XpwQfuh4nfkf6GTcBfxMq3CjffJZddFuPi2aefZl3fzrA8TcRleBLrK78FU2T9 zsRaK3Nge2UACsEUuK9tNO27eyzbkZaBPnjeksd89kvdQP1yfvfq7cat0wA5jqdRTaOAx1lufpDc d07CanLdk+t7jPRrFOMoj/b67RiT3PCosCkcPFczG+OAOajG2PsyFqYCI4/lXjwY/rNPCJS5Jyyd Uw8xt5xPna7HZg7MIYjKZMan26Isg7EV/gpSzlsFNplw++hJLDEGBlJhZDArmfZ72Y5iy5atafrM GelylDAKwJbpmPZ3tCbXF1q/HuZz4Epgo8LIZQEKpWfger4Va77jTDgIkzJmdW2vgj64fQdGrJhQ sSZb7p7kO0VwZXanHdu2p5NOPjm1PPwIrtQPhqulgcF09TOVsR/lx53D9+dIfOOQ1v4ACVbsrykC I4m7xBUm+1q8pKLtoovfjEtsW/ohsQHOhTacS1/rat2F23assSdv6RPHeEmBv7gQ7zWiiHnyySfD /X3GjBnp2nddk/fdhm47NipeK6/v55ERI/6Udvaxz2w1az75aTWFlOCps4O9sqvSYtw7L3/HiPTy hi2xjKKqajxtZOugcRNQkOIKylxWQXrm4jPw2BlJcLnm1E4bVbAqQI9iLWobnhLOeWHTIa7ln8Kt IO9DQBJWMbj7ax6QoGEZvecAgs5350YtdDVcg5kr/eAPfO9cUBmsUnJg7PVnKHSCL8VnhLkvhdDo lwWi1/yLb1g2ebxvv5Y+dQ6b4v042/3He+Yt40DvDrelsdy45zdJpZ8ryyDLQFsi015/Spl73Y7L 0lbraD6XxRixX6+gC1G2T5tCdOSaxnT3A8vSbQ+tps8REvnVYLnUyODa09o6FLEIp73du/BAwhNj +3qWytSiVCcK+4QFaWPH9tSxqwGaq/W1L01hHNbD92xjf+qpUycTc6MubVn/QrgENyJoTp06Kclv bWttT01jhKPjlPEGHitRvbtZlzuJ7XKueOvFqWUanmfwPR2dO/CuGc34cblNpsWVbS4wK22ufHYw 58PC6cFAbfidg4BAmeIFZVUWMdi9yuev/dwJUybPq5XmWqPMb4DQOFc8VfLLzAYMNUgmIlZyFLFK hPyXAy84afsZbBCSDJo/k+8XJBk3+v94Lya0YODcDZf9hkF0amvrcEGdFC5hhoqPBLE1v4KrIccl RiJur/HMiDK8E2XxTbVhmdDkPH7GbCbPD2cqbSvwr+wDNYiz57SEtTPoMExdBJT6/9l7D/g+iyvf +6jLki3ZsuWGi+RugwvF2IABV3oLhE6AQMom+8m+2bzJ7t7cJO9+kk323bvZ5O67d/cmGwgEQoBQ cukLxHQwphcb94Z7lbvV9f6+Z/7z119Cki1ZMsb8x/7reZ555ply5syZc+acOaP2oWXrJS3pxZde YiMkFBZLM/eITHPZrwjTmC9nJWu0Of+p/3pKe0ornHn+y29+U5PffsFtgUyFy3X4+jmuAZk4caJr LfaLEaG9LDogxE6ePEXOMU7zyY3yTj7lVPuijttgckUzRFr2TOIIJVt1BSlwNPDKq6/Ja6Bc7S/6 yAbIbArvdjl52TLTPdsGS5N0vZymTJHTje/9t/9mL86dq7Np37T+0pRsl9OgJcuW2sWXXGo7Knb4 XraTJJzSrzAA9dofRMcwkbGA4Pva1L/AzL1GqkI4jTh4SO3VkJ4zLP2ncsAVIYv+Cp/I0x91z7ln iqvnzDSyULloLknJY72YcVJkCw5ZmB6p3r4gAp7rHvzHfweTsN/rI5xuMIZwsiM0DEKA8iS4VlRj RzO2l0UcGO44Ao7zLIYDeBDIFzxy+CTy8BfpP21CAHhiJkZnc8V0evXqNdKsLBejMtCFrrvvvksO Yq63iy680BcQsBpgvCGMojFFMC0rK3PtOGMQU1WcJjGGi3sW6VD747Un6RXr1aep1DK+AAAgAElE QVS37yWH5kHvuAZaJXxJ9FmkBVQ69T71Pe94jt/GPuc5vvObw/hDXpwNiCljjhZPoAndZHr7jvY+ V+4/YHOu+KLt1QIZ6Zy51jXWyY9UYsyqOuw5RQuVIfzEWRtxXk8hM1pk8vVnjau9e/ZJU/cF+5// +q+2RDCeMuVUjf8gxDCXCMM9bcT5ps0LYyIxepq+aseT16Ud6Y+KpE5o2lET9UfAFGhOYLw1sXr/ QY+gK9l5OXahFiVfe+UVd8r2gfYWz5w9y/EcWhP2B4poMW4SNMgX6TQns1CxTguYLzz/vFsBYTVy IWNHCw30HYfMsFc+4nQ7aq7SAg7RAMzE6+oQTORYSfgTqHGtTZpcLvPhEfKcWqj9gLtt97ZMyyvT sSQqqLKySguFBTbtzBMkfO+z0TLV54xPaPDHa9e6I8Ae2loCnm/eusWdDLJFY8b06dZb81SDxix0 IvAMQZDXBOU8iQv2wEIFAV/Ke02LwWu0GDtYXoGxtjhdjsA453W/xhD7Gxk769au820EzMnd2O8q +ArRA1iUN/fMGcw0vpgQeR298rGg+nCmu49FjVcvWJ/TT5E2EBfmngRfBr3hP9dEZT09bfMIFa94 PeqqNAqk9c/CH4/jm5jcI1L/8BlpWwn+rd4BAwLPlNFL589SZh30kfcs8NIWPYGflZoTG1CfK8jt mpTh8s8hZ0b9yuUUSgu/OGurl1C5V1rtsglaYJS/gAY5zRpamm99+g+xas3RuT1KbciYEjkArrYq 7UUeNLZIAmydFiRKNF/nWF6PAsvLLWSXqkoRz6VLpsx7wbJM7WXl6Jjd+4VbuzNkGtxNWvccCckc LSM+NlTN65f6pzNpS1o4TYVs+v4IQKClgdxS3BGoSitFOOnSSK2uCxoFNuRjgoiQB7GF2cCkk1VJ TECr5HUNLRKHoW/cWOEmYOzRwpSL/SwQJlb8IKJx8EKgIuEizgmo6gOdZi8TGomf//M/2ySdm4f9 /0RNLidNHObaJ9IiiEK78DSbgQtyETpoKC7DnXiI4iLw+CRDulapaytA6KTo1LaRZWw/97SfVVxC xABWCkNEhlVqoocYjhg5Qpv7w2Ho7CkNeeobwWC+zGVxMjR40HFqK+03N2XqKxNe5lAEU0wU9/r+ H2ahUC6TLJN4A5MukXGiJAOFqsTqeYP6HkYEjR/7U3GQsmXzFjlHGW9jRo3QyqWONpHAOmHiBP+O Ph+u+nbXivTtv/61TZFTGeK2bd1mX7jsMhsnU6wn5RiFSWLYsOGOUzhLYuWZtsIUezuYLFVHzT8e OOeOifvQA2m9ZY2fKM/wL+CD5+btTcBc01K98Iev4o/0CJFoiXKAlV5kC7A4skLMxZSRw76FiM6U w1O4WbkSAlvXTCmd7wsGN5UX+SFsR4aPOJjyGPwu/mmM9tcB90NkHDPxu/S1dQhEj7ms3BdoLBXL 7IuD5CvkvApz9LPPnilLBXljlNZ/sLSfCJ6YoLI3GC0iGg/GAeOPYyewIMAcfufOCo1jMVRarJg5 a6ZbF4DLjG3Ss9ADvSSkjv3WaxrS0bexfyMNSe37tr5vzzsWhjCpBz9Z6NsvjRL7x1lM6i2nUNB5 6HZSY6rMnVnmqvR+nJWuDbRRV2dCNQYYRSJPEiqUv8ZdoP2BRneX4DBm1Egx7B/b8ePGaOznOgwD A9u4167ldrQwrltOeIzFNiMEB2tdCqkMuK/u0TdJHNRDtfosR5omnNKUCN/f1zaTJ594Qn2YaSOG D7fyYcOE/wPEmOfryww3+90uDSVCKT4IWHjp2bPYpmtR8vhxCILs+8t2SxjmXvozzvEHq27q+0CB RVPBS2lKfVFaOITTPDy+Vksg2blzh/Xdtdb2VBTb/FeW+CLL+Ak62iixCMixMT1LGqxf/4Ea0+uN Z0yP10o4Xb9+vS8uMX5x9sWYRzDFB8MYCbL5+XnCdyFvS0F0HQeEtK1G81V5WblT7vdkqYSQj/b4 kT/9H/vjHx/U4u/JshB4XT4FBjldQIB/Wg7WOBaMbSE+rlUGwhhjmxJD21sqOKXvWniNc0RgzmIa P/rGNamgjfqady0FyuOs7W4S9kjKOI20R1VSCHQoiTfNM1GiTDSwrYSYl7csicIqVfe+v1YLU6s2 bLd1O2ut/4jTlYvmYi2i1FFfaaGpVA3a68x86957sPUoHag0Wryow5JDx9KI74TeaulcdBZeRRYr wmv6L6cQ77/KQP/79SoLNFnpoNXZDTrjtF6WIK5tDsoT5nrmZe8D5m8RsIYMrF9Uq2rd650YYNE1 WYwon+ahVRg1T3iIz2nh9BABlU52uBAAnTVK/Nc8L+IJLaF8eHMk/wZX8g32wgsvuke/qadNdYFk p1bROcOSfY+bNm/SPrtiN49hwsjRoO0mQbWiYpebhv5RexwxA2XfXGBMAgFmAEPYIVoEJq/4jKOe bM610uoVBJZjG9599x3buHajrVqxwsaN/qabzTjBS8CRbOIEiCCKcAqRifkHuEXYBwhHaId3R+/f sOle5p7SXuYJvqkMInDEidKMGWdrohOhTZlUYJZdY6Mr5y9i/kubU7GL9MwQaAg9PtEfETbu7EQP IvO2QiaOb8kEEsacRQrO4TygvXerNdHjcTdPkzmmxdQJRpxV6atkrsxZp/fee6+bMOdLw8Q+tlu/ +hXXNv39T/5BE0mu4wyrzkuWLPE+5yB0BAM0kU0qrBZEJuvgPRZbEa9Nv0Du5Q14EsdjgEGI83t/ 3/idr2YLt9yJhiYnGAqXRtXeBjF4+u99UCu8zRGjgLCJ5rdGzDmaVl8kQRAQnH0S0xW8bYqnjeWl 7zobAqHvgDdaUDQpjB9wmh+OqTZuXO+CWk0Nh633sFmz54i+7ZU1wBCZ/h3w/dJoTE/Qfj0Y3E3S qGLRAGPYINozQfux88TkQbsYX4wF+trHWmc3pxPyAxbQ+oiDuRqjaIURSGfOnOk0BNpM/WlHTBfx Ft5RTRddkvaVBw8BzgyP8E2saIADaTGpnDL1VKcN27Ztd4dg1VWVKkd5qE7pcGQgAKQRtOqFr+y7 HjliuPbsLXQnfJslyKFlXCvrnF1aXMyVKWY/bcdgzOBIjKOvWIBmewrz/q5de1xIQfsFzoAj8RzO jrQGrRlzU72IdYO0WBkSWOp17EedBIZBQ9DaYlm1zIb0137CorDosaViuQ3L7OlpwKNSOcUZOLC/ bdNC92rNMcQhWIPnLDphyrto8WLrrfkGE18W1/tqDOdrsTTyFM3rDk5H/Gc+hhfCdwQCJwGBl8Us LJdwrIaQxPhhgZaxhYPATG0dIA/gRIhlYYHWUfyPNIY6QXdSeYX4zgtr4Q98BgJqDDF9HO/xGt+n XplHmU9bCzGv+B74xcBiA56W17y1wFZu3mOlI6Zo0ZdTCAQz5cleYSR21U4/Ca0y92VRvcG9Noc9 oYKi4jXfKt4aJPBzRqqEV2dvVFDkGUR2kiHM+0qrQhLKWV+UdnZAX7NMgKYewRQHSczmSiz8kzWB YItSAE/lgatKZtvpN4090ulZpzNMQ6AlCDQOzsa3LcU1vj3Sd6z4w6D8/vd/cM3AEDkA4UgFHIGw 8ojjFog7+xp3yKSUlUlWDFnBGjFilB85gGbhxRdfdKavrKws2QQIXSTGEC6e4zUSa1bA0Mqepj2J pSLovWf09k3qaC/8WxEu0rpXNxEYCBNET6T9Mxci4W+DvjsRjBjSSNyDIIh5y7p1693BCHnxPsI0 AiN+G5+5ksbLblZwTKvXEjpzXYONMyW0Kj/8+x/byqWL7U/ah8fkB1OPeXfMK9btI+0xnfvcXJ2J eJ099sij8nK3Xl4Sx9nLL75kf5CwetnlX7BLZK7MPlTyYSEDB1FMqmjacS7kukwx/JgPgh8hb2rX rMKpjWpyH1sSv+A5xMU3zXNikTUGcMnfE6cbn2TR3sohUm2VJi/F4YK+WqbS1ZpEczR/4Synd98+ Yr7FqCkur7AbcxpTpWuPgsY0aKEoJ/YV9+nQdRCIeEkJ4CraTJhrvCRH3MLUd+PGDWI033UzXhhX dZCbALPflOOVYMzBbRZPnpanU+gh+6Z5jxfRGhgvMZ0IpzFE2hafj7YrDFbEQ+qKCTMCOPSc8Ygg j5anRm0Cdk531U7aGOk1bWJvO/nwDfH8GNueRvf1WngMdF8LaXrOk0kp/cC497lD3oEZn67h0fvU PjvaYHYs1ocFA9h6tnBgbQMtYzHxf//Hr+ztDz50Wvj3P/zvbroLTjAe4BNIxy9DC9T0GQ751OmH 3X/KSdqzIKBk5nSTwMlCn2ooGlxSUitHTtU2ekRvm3TyQBt7QqEWR6slWMpEs17ngGs/4midCYow Dc6WlZXZci1ug8MspqLBJLwiTSf7w7FeGix8xzkdfAc42xr+ER/nO64Exgvf4SwQx2F4v+eYMHil m2++2YV5tLYsGEMvWOBlLPAjP59blI8LeYk8PeNmf2J5zaL9MeYR84z5RvrTWnv8Y9UhbplKLSPe t/mtMoiefluqV/O4Jnlp0bZGGtDRk6bYvPeX2JK1e61bhha52XcqATUDRQUm6QIMlkr8g0aouoiP ghe+KjTx8h84ArvkfeQZmteAZ4m6+pYrelLyREcPzqFpzXZtqs5dVRr8TLgHXy0yYNWWqYmeub1J O8iyC0JaOO0CoKaz/OxCAIKEe3WI7KxZM/2IDJgMHIfARECIIbIQXiYy4nCIwHesCq5bt8GFUlZX EWDRJPCOHwMa4gnB5Mc9TA4TI5rXHr2KoQ2+f4CVzu6aBK+++morKSoRcVLayq2eD9CNq3VuUieC 5KvuUK1jLbTQpEgYYe7mab/LJpnZXn755Q4b+ooAk6iIDkGD/GtqpB0UzDHbvuyyS+1DHQNz3733 SGOqvtLK86qVK9zx0YUqw52eqCTKpp9hXDCVev6553yivktMzhMyF+OcRDwGI+yS70CdPceeN86L BB9WrlzpE3lgDhqrTn1C3hLy9K+jAZyJeNNqHoI3ZdAOJi0C99QPLQPmyJnSFGflSqMkQfX1V1+1 91ausom+5/BFO+3Mafb6G/O1z2m0XXXtNVoZ1gqsvkN7TT4R/8mXPGNf8pwOXQsB4B9/UYCkDwjE //a3d9oLYliHDRlk3/3ud+3xxx/3xRJoHbgJfeMsWrSueNLmqCRwda9oIqMO81ieYz/DvMe8/eYo /AOuR5xkjKHtgXZjyok26VXhNzQG767MCZy1DCPOcUhrZZY7XpozjhB58qknnTkfJWuZ+fPnCwaZ TgfIe70WL8eNHSdhtNKWygpj5IiRdsGFFxiLnpTHoiMLmwTqwP73CLujEGTHVJWgP/SRjwu1DEET HC6R99OiotWaR2qsUP4E9lXhMV7OhYZrK4ZoNpYyBP9OeSAYBIur4DCL+MOhba6/Ur7a2B8EBzEG fp5uvbYPdZO315x9tvgjvJb3tjHjqxxvtJQpTW+lW+T0lyMcvPrWyNkZi0onCJ/BM478om60EyGS eQicY0EUWsCcGmmCN7DZH2DFD/wETnyLIMp9DHxPGhbAeM8zP+AB70TZ0fSfb5IzjRbaW5juY7Zt Xsk7Fd7cU6b3z8H6QmlTF2ZjQXxLSM03votX6otY17HAfJ5rg/qV2OB+vWz5yrWWV7ddiyT7ZXWE M8ywsJuFcOorFbJE0T/XljJHSx0K2IMJttqrB7T1zNttCZAsLNd528KiMXUn1wbhWhBOxfvU6RQB 26PjT+XwUGlr9eMT34rT0ea2E0hp4bSdAEsnP7YhACHCcQCC5Y033uhEl9VtiHgqoWMlECYFoj5t 2jQnujA1u7Rvi72MEG8YGMxeIMgQaQg4RBnhZpu+R2PG6mxZWZmb//YZ0N+WSDMxf95rElhGObOD kFoyvsS/ZZ8LzE1pP/YAiqBqAsCkjkmLuvnejZTuicQ1JeqYuI3tQtvDRMeEChw5jxAYxwm0rcbG Cac5neUZIhwZDVZ5Tz75FBsxbLgz6Lffdptfv/a1r7r5F0xKnUxX6Qf6lmfMvS7Rfr3n/zxX5sBv uSk45o+YT80+70Kb+/ST9uv//E/hxwXSLvZwkyf6Ga0UDAOTqqQ5r36c1HmgztStvYE2MSE1byv5 eHa80C9mjbiCuQ8TtjDLJ0naiK0REzF7Y9Gg5st5TJZWdzE5HyZBe7/64snHn7CXXn3JTt82zY9U wJEUQi3MOm2hb+g/xgPX0KZYMjVKh86GQBwvwBr4cwVXucJo0y/QK+hYXx2xNGniBPdIzTPnEXO+ MAHTPI5zQmBDexT3nWJBgIZfgyDZv4xD8kQIhv4RYj384Sj5k4qD1JNnGPhMLSpuWrXKhXHmAtoI kw+dYV8esPvlL/7FvvnNb6jNDTrHeJS3HQsbTD2XL1+mb8okzK60ObNne3q00hMk2GNxc9yg47Rf vY/TL8YC/cFoc18CwDIdjhgEHC/Vn4RIn+qrK33xhQXqZcuW2umnniKt31RptKQ1Ep6A1+A3DsGg b3g5BefBC/KjT7knriNBlpOi2Zi+4pkWzZY0WspIu7ht2dL9OkZGlj3ZOveyAgEaL7CMY/nEyOyF tOQ+E7IygwMhxjj4i4VD5EXQ9IPPkR6Qhjalzjet1Tu2iTLBWUKk57SdMsg3W9pkBCee+YZ3/Lgn jrIIwEkvfK7xiFb+eLpW3hFN3gTS+WJ94v5g3/nESB1SQuo31LO1GYqvUtOmZOG3sU48fDId/aoF hqr91lC5y/ZuW61ENXbAyaXOjJbpLH3pmlOgI00mR1e5jwc9N9QBQ3BNiRTYKw3cCZQbmkQNY+1T 7p1nRDgN+Mm8Dr6Rf5Y+rNF2jryiBi2CjKBzlYfwUPWprcOCxG2hKKZLQ1o47VLwpjP/LEGAAc1v 7cfr7U/a1D9AwiLCBqvbMA8IqQgeMCBf//rX7Xy5jf/J//Mj13xhBnzGGWfYBzpm4X0xMDgTmffa PPto0Uc2W8zJeeeeZ3Ofn+tOdVSIPMwGxwrLVyzXHq4TxPBrI/+9ddZfpjFDtdcU07mepb1tjVbt Ifw7dUwD+zn6SNitrl7sggMmYGilCKlEMEmLEsBXcaTQrykBTrz+bFxEMCNx5wpDCNP41a9+VeZO 4WzCEB800ywUxPSxgcCIicYJuGZ/iHdziPBMvOi8wxTY0+9LtTeH1fHvf//79s6779iK5WhO18t8 aowm4bAflnJUgi34YIGdcfoZdpG88t4vM95+chd/5bU32AdvvmG/u+03dsOXb5KAu8rrV6eVbdoB Q4xZFAseno/Kov6xDWGCjBOOJ+n0P7SdadgxxVWsAWfwoJwFvIRqddpcyr8amf5wDEN1Rq7MQwf6 JIlg06Okl8254Bzj3MtVYu7HjTve96SykstEyh6Y0C7Gmrc0OaH6U6KPYuO8j1SxCIcYn762BoFA Dxrf8syCAExzwCeuaISCybjeap9TdnamFuNucMYRWofgCTOLtgUGHPjDwLJYgwYRxpw43vmY8pEU yoLnDBYdMMzCKfU7dUDw4hpoUcCtMAJhUh0ZdD2yQayh43OkC+z1y5HJbb00VKXazzduvMzxX35Z 5ukNOm7qEp1RPN/GHj/GFi9e5F7DOZJn1KjRNnfuXNsqb9zf+ta3XHDHGmbkyFH28MN/clqOEym2 eTz00MNJixtMLdE6UzYMu9Ml4b97Agbx0+GIQMC1TJgyai4Fv++++243ecVCgHDRRRf5thHm/Xvv u8+PLbvllluSWke+RwaNAlqkVfRrRwNzO7/6apnzSmDJ65at488kotYfEH9QaRWjpXMT996nj8a2 zC05bsbw6ltfgM8axynfwyk0YrG9SvQ4R2MWPHMngGprpZz+UVcwDYdgwa8AI7H1scjWDIRO9j5W SZglT/8+wYfgrTq22xfQmVGUXaD7gY6HeZj5QPmA59Am1QEZi7xaD63XK35DWQhPzUPsk+bxPEOf nJdKjDnSppbk/hVa+jARh2Oj1gM0N7yF7sZAHAvAGvUuZI4bMcjKBl+juVLevZUO2GVlqL/0gS8U 65qhG8y6FcMT6Oow9L3NLmwmrEDUfu9ViqMhsdh4D4y0JUfbmBWUl/aq+jYd5e0CqtKjqe2WVW09 ugn/5LcjQ/uemfMzRBs5zcLJOJ93YWgLql1YbDrrNASOPggwhjlmBMdHv//97+0b3/gLF0xg0Ji0 YD5gyqIZ72oJlu+88457wYMZYV8hmk20qXfeeaczJZzDyYokhP+Uyado1X2MMyEIPBzVwFlbQ8uG 2rSzpknIPcG2b9nmxxcU9Sj21U6cGqBR41wqNIUNDQf8uIOsrAMiECJiEswC83f0wbNra9TgcMaR i8Dg/QLzDIPH5BIZheZ1IJ6AoNnWhBW/Z6KlP9mL9sMf/lCOjq50k8eTTjrZHnvsMbnsD96DPU+l zRVjj4A5V1rT7oXd7VrtO31c3nlfnPtnO2fWLFu5aqU9JI15uRxG7N69x8+YY1GDCZv6Uy5tYOKO bSFv7mEaMNXqSFBrNeMw+YRpl79MeuB8MiQF0mSM3zCnundeJnEmREnuOOZAY3D8yRMtv7Sf9e1V YlOEw9nap4tDjWoxPgjqlLMPawKf4DK1Ny9fvwLH2dhfMEz8CLSfBSFvr+qKJ1OV7u+aLMB4TPrP oUAAPMezZtSMODjVp7XiBsFvaBNpoHHQNwILJfQBFiNoORBYgX+MS8VXHyvghPCXfEAxXRSC0BWw jAiP5MVREyKeAQNoMc946kYrhFUGC0cIpU899ZTTfZyfQevffOct37O7UgJmnz6l7sF4mWg/powI 7+QDHo8ePdr32XFPXixaOr4L7ngGBt4RrjDBwC/W6agB0jFeEY6VYZEXL+QsaqJRZAsGdHnu3Get TPMznnhHjhztixLl5eVJwRQapqEheigqJcSn/+jfeN9x0Gke08d+rJ0PG2nIaoUfUlaeckp/GzW2 2MdYbvZ2bQ3RAocEmUwJNr5YHRcA9T1CCmOcfdNQUeZK8Au8I557F0wTNJj6+xpSKxUnf7a88C0L Uy64KY7xg4DHHBVoQKDZSuiav1iWN0V5+7PKopHc883B6APpWgteb8+DOTL8SBvyDX3T2rfERwE0 po/Xtr5JvvNyk09t3CRgohTQSO9AXVgILyoskJWd5jrFM7dyxaeIOxp0qPKRYIRwCp4J1vWY+oof YCEwLPyG9kZYA4eWgr5WVtozTzna84pOHr4AwbfOJVbRwgxZ+Om5pmqPLNOkwVcdszU25FnA5/2A TS3l3nlxaeG082CZzqk5BBLEwgea7hkrDBgIYgyRCDQScwgLxCoM0JiuM66U1dqAJX+GMowWGoOL L77ITdtgyhA2GPw9enR3gvyDH/zAZsw5155+4jFpRM91D2aYuj377LNOWGbMmOHeVyfrGJGt27Y6 swNzgjYUhze0H2ci5eXBox3EBPftfXr3tT69etu+3bssR3v6cIw0fPgw27ZphwhVrc2eNcfefe99 ZwKpL+3xVUzRLPIU5JzeOUwTdMknH+DdOl0nqy4LsV+50k7gS/2450r9nEFTDXjmR1p+vGPK8mNI UuKpLN+zordkyTLbLqdU7NuEoY6Trper7xGgMI1Cs71Y2k/2zuHwYoJM71Riq/gQcFDw1dEAVeo7 tNZjZc5H/8HkHzdokM6FvIGqeJtoF6vIMPIwqHhpxlvvLGnNz5X5LgLp08KPK6+91o+Sueuuu/y8 U5ghtFQIAVF4IA6mJ8KCMrw9zE08HHZIZARwU4PDH0ZDq9rOaOhesxJKBUyLfLVUzFGunLfg3XCR rAJ0aJ0NGjfetsjpU5Umswnah71oyWIdx7HB+veREx0JrZyD98JLL9m69evcdJSz7tiXC/P/3HPP 2RVXXOHtpb9Z7OG4ngKZDGMiP2bMWAkBg3zhBxP5iCNUOxU+qc34PN/7CrjjPJoJ9Z1wnLidwt8X Xn5Je+DFwCYABPxSA/ufoSEw17yjP8A7guM3XLgC78g74GTIg3JqNAZ8753esTjBIgR4jNl9LCqO +1h2zN8zPuJ/wvinTn5MWIJhh1ZQL8bkazqqKngfHeY0m7HKOGWf3Sky91+hvbcL5XMALRuLkywk QifwRYCQAyxvv/1299wOzccBzRvak7pP1jgIscwBzDHBzLFxkSbCp7NA0tn5dVa9Pu18Ig4n0Nwt BWZpEZG5HKdfg2UVgrlkYfcevlBNf3KGdewznhkbPvsqE3DJ8Ul4z/jhvv1BeKmVQ35YNSCgNkgQ qZMgceBAnjzjSqCUSW9RiYSZ2hwJDkUqgrKKJWTJrFbmnpjYs/iUHKtiABipQYhkbtUX4rF8XCYW PNHWEdqaY2hPxCW/KgNgyD8CdKBJBvBxxLMAwI2ShVIS6fTsb/zzmAsJPxliuZ98E2IiLSHdwdK2 lseRjEeDXeMLwgiHYVEsaEYFU1krIYuicU5ikO49ufaGAtUGvA1KWAwBAAbIJiLauAB70Wr6DkQI vebzRENmWLxHCK3Ve2GzjkdCaNZcomcqQNyhl9VGNQ7yKi2cHgRA6defHwhEojZIzPDf/t3fBYYB wquByWBkxZBJzAWJA/t9RZxJiknoMgkjtRJM8qQ1Qrj42U9/Jg1Svu/X4liSHDH0mAfD9HtQPsU6 +JofZIV9I2hoec85hHhCRduBN9ohMvPN0ap+zYFt7h02ugd3WsTHMVA5RSKg8SMEBjPUXyTb447k HybuOGEDX5/IVE/ifQJJ3PueNVUsTn68d8YhMcHHc9Ea88i0Des32AMPPOiORTCv+/a3v52clGg3 rSVfXP3jyOSOO+5wQZA+Kx9apgPMe/gE/Ql4qJ7RyRHn19L/aK2BLkxojvoXgZU+5R0ao9Q24q6f shFe75YGnsWKq666Sqbif7Jnn/4vu0i4snLlKte4s/qMVgbmFGdbpEXQJl8YH2AQ+pCFByaHT9S2 AxFkkoo4evS8w6Qe9lBh8Kj+IJ1gKHbIp6RsTaj1OmqEQ78RPPr07GXdWKAZi30AACAASURBVPWV o6f1Ol6pYs8u266zLzmK4a3X37S90g5z9t+KFcttzcdrHbcXLVrk2iiYeY4kWb16jb0pk2f6nH4C fuzb27Rpk4TVd2369BkOd2Ac8SkyIjynQyMEgAtw4gpOETjy6uKLLw70Re9iSEUlsIE3sIfEk0fA tQY/03GXhFuYcoRPArgIfrI3Gy+gsDho1AO+hnFOGhYZcaTEnjf6ynHYczga/gRYYaII0w7NZGGS enJ0DrBgPLL3lrYyVtGmAZf8PB3voX+TtBgzSvtNofl8zwIZsENLyjPbDliE4VvmDeLOOPNMv0IP 0NBBj9DUAlrGnsP+aADP56AOPk+oP5knMLtECwUOlJeX+0LDe1oMHqXzrCdMPNF+/ev/tFtu+bK/ g1bTb+CF02flAW5zT2Ac8OtQUF4+ljQEXQzBjFbC5oGqPC3GVohe1lle8XY74aS+1r93fwkZAV81 0rX/v1p8Btqw/ET5jeO1sT6McSrcodol29WesdzBojpWwcP8qj3tOsyiJBCGRQOREgWg1AgpzkdG FBR1Ujz3si5y6VQ4hvOilLR6UDh0fEPsxCkSdC9+F0puzANtKkKyCJJKgpYnk1JYl4e0cNrlIE4X 8FmDQKYmnVwxEbliUqJQBGFHg4cnRcYoB3jnShBFK8eEVCQhkiBxwol3vs5FYy9A956BKQuToA9x JzOeOPLVyhtNFGdCBm9raK8C88eKVYYOaqb8tpg7CCqMYJb2jlEWjCnCg5uvqrAwZXqpR/RPrLfX RUQuMs6RAYMZIzDJ0wbScU+gvZ5e97SJ+5gGTTZ57927x7UbCDq8Jx0/Aowg53LhdZMzY2+++WbX nKL1QAvujgTgyJsH5csiAWVRRrU0PzgqQkDF/X55ebn104o6iwmwD16vRLmUSfx92mt6yy232Bel FXzggQe8Lpdedpk9/NCD9oo0g+MnjFe95ExJbUSDgrYQBv5MMa4xUHZss25Vn/imM65kBgKGyciz 1i0OPxyOugfXMf1lQqRPMoVbDTIHysnC5EcLLjqnFVPQnr1kWaBkG3We3pLly+U4Z5fGSIa8HF+u PdT9bN78eVYlK4DjBg1x5h7P12iVMI/UzCeYvupCAAs1OJzBCoHzgvv3H2jTp890i4PY/8CLH7CJ eKJM0iEBAVAfmgSMWMQCHzEFHzZshMZFY3+3BjDgCt5DN/DMCC5s2rpNCvIedvz4CZ5v7AvgT/oo BEdcpWwsOlhgYTwTHKewKXRM8aij4k9gANVWwape9HdgP+3/Luplq1eu9kUitL4FeQUOEyqcLc+t tKlB6miOVgAWPbVfnDhg0UPjAc0q8cCvh7YEFOpcZGgNcUAAZ1IswCCwsmUghDAOufdvlVc6HBkI YM7NUWH1WgwG9tAlFg3ee/99K5O2+7rrrrV5r7+uhebJLriiHY++AVh44Ju+Awa6sEqNHT8Oh1ir Lq7FFLJkiNbWKv/9VWaTp1xg06acaWNH97MFy+bb3Bcf0bFeFfKmyr5ALZ50KxTfMspYXM9q0HFk ErbBovgTEgeA6prGrgCKT/MvvcEPyxboIksGGWiafeyzIExc7CnuENdIpTQIqaI/pGpvYN+wOEXP 32XTZAbk1VgelXMBVqXAuYa/Rw530sJpsmPSN2kIBAggMOGRj0kH4YYAk8dzFFhgtgLDETw8kgbm hIkpS6ucDGYC6Ql8y3u0qATiY17+TnGRGXQTSoiOKIfvQ1JepNFXfNpiYMUX8yPSwBwyaTrDpHp2 hYl0i5VoJZJ2s8oMzOLEDWNLm/hxT50JES6k5x0txtwwpqUfCDC/vaS1w0HVR4sWu2dkyqGMGMjL td3auIFmY/r06S4EoRWtrQqeDBuJcfyKfiQ2MOnkiWfDVatW2Z///Ge78UtfsmI5/eG4Id5RRqTn 3FNPNJ9nSQBDU3v99df7jz3MZ6v8K6+8yp6W9vR1mfbNmDnLv6ftHEvE/jTMXSNuYVYTBTD6l1/T yaSxzodzB4zBV660KUNCKEIqkimHemMqVqcZlEmN6RDPlDnC8dEjx9gAOfPaKYuC4pKeNiZvrC3k UHcJnlO0Jzc/J19TYKbMHMfZ+BMnOWxg6igDBh4m/Wtf+5oL8wim9DmCKxq6GOg3YAqM4o93AUYB Z2La9DXABXgxTuJYA95xfOm2SXD8TcQA05i2TrgX8+A1tIk8eB+FUsrhe+L48UwefBfGQli4iema FHw0PAjhY52pLxpUtl6w4MKROZjnsh0DvKR9BK60kZApWs75pTiGIY68eFYiwQq6psU2wYxFTeYU aH+dFgg4G5lFrrKysqQ3d/Lz8ef5BtpIXDp0LQToNxZiIo7GK/gwXbRormj+woUL3XoA/H/wwQcd t6FXLFyAH0W6v/mWW70vY23Jlzw6GgK+CSdFe/kxHk+YdIpla5FPk5edMF7bgkadY/t3b7Hu3XI0 R+k83pwiWW/l27YdEpgbZILPPKa2pcOhQ+Bw+uzQS0lJ6RpQ4SDCZvjvhACTXucrkjjE/AwvCu3h ZcAttJssIPN5koAkv1VcjNdt8l7v4W8CaoTEmQjFCp5Pkxvhn2cc3vtitafs+j9p4bTrYZwu4TMG AZzaMBFFJgRmDKIVGRCemcQIEH9+kXGDiWMwx2/5LqaNE1/8zjNI/MG8gn8iU/qroD8uVOoWLR6a wkBdeEnwVIkrDBMTGUy89gS6Exm+T9QZ+hMJFp8ewRDrEGFH0RFevPPJU1fgF98RjzaGa660C3ly P5gthhFNAzAMAhuCe72ObFjuzCT7PAmx3zChIy0EGAEHTQXvEI7YN1bau4/1wNTQAeOfJv+oWP8u 9iEmXBwB8f/96796GjSdvUv7OKypI+lhyCkThoX8Oeyc/X1/kAaVs2qv1jE3HB3EAsLFcrDy1tvv 2BodHwOjSp1gcqgvZdI+BEC6jDgPsbvDUwf/ktcnM6IcGO0s1aVB9aMnVLxWTWHcNCWC31oMqNa8 KJ2pO+VokHMOvPhmamU/WybotToHsDC/wCZLKGUxoaFGuCihtUEa1qLiIjfthcFCYKJNwI2AgArc oiDFNS5k8J50sR94R1/SjwHuCfwhYTokIZBKn2JkS3HxXbyG8RKEL+5jP3EFyeMYdvxM9CNx/OgP xnL8jrj47GM8FnI0XTUUaAuB+lN38BEz5DfffNPPL2Wfs7dfabjSloiTtaI/2bKYCTgdFpKiY5UM 0QNM9qDpGioS7jk0QleNMzTRH8vE/YILzvfy0NSRL874qiXUpsORgwB9Sv8hoOIQicDCGdYvI0aM sPd07M/tt9+mc2kvUlylzyN4VuecX5wasqAIPsR5h/x4Jg/GQMSvdrdIOFPPHlDN+9k58q+g7SUs Vipz0VRwVWMup9h66XzMDDS+8rhaWwPvoaOQNDehbY2UPnX8Ubd0aBkCRxo2oX9knac+CRYc9Fmi f7yfAi3g/FFiRV31A0dFm9GKi76IKvu7hGzrwiX5Nn+mxTGOe3JBd0pehOhJOEl9lD+L0aE6YFXA J+pJXcirq0NaOO1qCKfz/8xBIDIhCBzcx19sCBNRo3agUXtAOlaW/DBk7jU5MfFB9CIDx31zIuhx ogoqyYtw1/DaIK/ZUkRB8WKC6t32I0G4QqpEdVKpBBpKTFlrXODJS5iYUTbELEFpEt8dmUucnIED gYkS+FFrBE+EMwQzNyPUuwhrYIIGg+8+WrpYnm+DKRyORsgD4RWvmmgpi3Q4+sqVK31vGMILzB5C K/sWEXSoA16TcW5Cv7Gn6KLzL7BeWvFmr1fzQN1iP5Ee4bE/2jyVy75imNJqHFXomfqjRVwuT52k Za8ZgvBPf/IT+9GPfiTT1svsD3/4g33pxi/ZtdKi4hgJU3H2quFACWaD+lEG59iyfw1tMH1GedTD 8QpBMUvPydmjea3b/8wE45NMRCuVVSfcwWTd9zqxIKJ3TI37dcYaIV8/joVHy0Sf4aayADyTc6pK GCjhMGMgF2FXHv84Zke5en7ugl7fADd+tJsr7aOfCN5WtZ12x8A98IhpI47EMRjTpa+N8GPcAC/H IwEmwpCx11ogPYE0/OgTruQV4+gznskvNT33qeXFd+QX+5T7lkJqXi2978o46kaIcIIWnXzyybZa C0cc/XKtHJjhKyC2jSvf4LWU5SNg4XjMeGX8JODLHKCP/D3f0EYEFsx4n3n4YSsvL3fhJziLCrhO On7kGevTlW1P500XJbYHqH/oIxYIGoT33IMLs2fPst27dsox4XC3wgEv6P9bb73VcYStHmjFsa4h kF/EKfLg11ogbWsBM+MsHVFSoyONlKvmCsai5grdMw9IHBXtZq6XAFwvqyTdI8hqZlIK0eA28m6t TOITmNhWks/ku7b6obFBrfdHY5rOvJMCxCd0hD/1rIAvChD6wJ0dqSflPZfFCHqGVD5hN+HlPDbR b4daN9qpknzy1714TUog1jlOPYT9polSVR7mxn7equpFibCjfNOVIS2cdiV003kHCETMbwYPBkPL gQ+6GvVbLplYJheYg8hoEAdxiww095EpIS0/f8fEhLYIxl0aKDxABo1oY55MSJFQcgUGHueFqBwI gf45BFBf6T6pOeVb0ilAqvSh7qASfBOeqbNPenpkgiMg3CbL8JjUP+QY0qXGdtY95UYYAdPIeHHd oIl+hzxjsh/U26C0MHoR/pt0fAsOcp6fO1f7wIrdfOq4447zqqElLpTjKPaPcq4sTB5tR/Bkxft1 7RF66aWXrHzYMCsbPsL3c3IU0MaNG+28887zvWBxv2vztkaIoK2mfmvXfGw9xVT2k8ktK+oZ0iLC 0nrbVCZnuyEcY/5VXl7u+yoff/xx+/d//3c/9xDPvZj1Xn/Dje6t8667fudtnjL1NM8HgRrBNBwV ROmAI1yjANcY1/G+iu0Ce0IIefEXeAJ3x0m1G02qxGI7IIZ6l+TSrZJp8nIzbEB3OdpQ+930XSqh mgPSFO/cabn5EkRz8pQR05uYPDFW4Gi1hF1mXfLCVBgTxxgoi19S26QXQeBkvDQuAJEG3PG0XseE MAF+J+AU8/y8X4ERYwt6xAIOP2DHj+C0IQEk0qYG3sHU8n18xyLPqlWr5a16l8ZWkZ111pmOJyyw 4ESG/MGbuFDAPYG8yINrapmp5XEfy2kef0SeVb9Iaygvmt+yKHbipBPt0ccelWfdN2zqaVN9wYux CI2hzn70gq4IoUCRb4EBljNqvachHYtXBOhTL5m7o5FdIVpx7ZVftG4qh/3w5KsPvC5twcozSv/p dAh4n4G3+tG/cbxAE/PkO+KGG2+UA7wqp1MIpfQrNDtsPwhUtVJzPYsPsf8Yf3EsdKTCrE1rNMoq RTTTcUP3OmsyWy8y2WOaUS28Uwq9z+ScSk+vJigWaxfOyIyhPWMsLFYKfzs4zajoozMcpF4dbS+N 7XCboY1OPciD+wSN9ljmzxgQCKGrpA4KC3qaLiKGa7D/iOkPfg17TllAY/GDvENwB0ieY2PpCKZe sqLQ8taKP2h8G7/s/GsjBnd+3ukcP+cQ8EGjAVjHCp9M/7KE1D6YxMwzrCDAmpVlSggB5lmEl8GG hkjP7SGqnQ1qymaiiZNVFJqIixNQfBcZZ4+XUMrIdYbbmXw0Pgi6YvhorfJNBuXlphOJiDAfJAiF Jp0M9vsJTvLTIXBJmyGAoQENq2kIfSIWUlMxGQFX8q5L7BGsra1WYdVy4CFNSDWMjxgnFS1xgcx0 o6Gv/BqcOKlNvlKXrFmn3QAT6gX8gBMTNhM3guKjjz7q7vrZx4mpFEwxkz4ML1cEzI06koRjRXLy Su3mm29yE1DMavPycm3vvr3uARcB8rrrrvfvqfh0HQWAwPtP//RPNkpmV9/53t84c4hWE2EWZxe5 +t7PE2uhpcASRrNSDMmrctbzgLSdQ4cM1b7W85xJ9XVGtQs4OlOqdpVo/yteUb/3ve/ZT3/6U/vF L35hf/O3f+vt/sY3v2lfuPxK+9X//nd55N3rxwPddPOXfY9SpZjTkSNHuiCLOWEfnWtLb4I/lBDx hSu/gCMtVPoTUf51MtZxz79WXzPBKYI7grIFkZD4vL55ajvnmGEatlNLpEskne4VXvXKa7DBRdKd 4lhHJ8DnyDnMqy+/aI+//IrNmn6Wm52dMuVUP3bB8VR4z57tbMEKQQbBhz13jIeACwiqvIut0hWk FgRIC2x9vBGjeARW/1aV9zGnuIj3cQwqqYcAL90qnzheHX56bp42Cii8j/dkAliomTOZ+o6Q/Jb+ 4DmRP7QAJteT8UJf0lbOq6Xt5E3wevnbkD/A9zHi78QyKH1cKGDMePpEGr6P44n7lgL1i+2NdY15 xOeWviOO8Ucb4lilbjvk5Oq1V19x4XRA/37eFnToDWovZtqUxY/28x33wIsy4z15c988kOZTDapT phZa6Mh4tiDt3y0z/jHjxtqWbVvtKe0P717U3cZPnGR7RHdoJ4G+JXgb1A5aglVFEn8C4riVBXDv 1bPYPlr4kT395JN27jlz5KBqmI6TkWDqAq0SKw+fM1Sn2O9ewCf+fMow+0R9PgsRbcPM8VU4y1gm 8JdjWMKjcFv7PDlXUpTA+4Y0UGIsTBjbfB/xOxWnYxzp2xscH30MJb7kXrcsCnIWpbBENFzjTAvY dXKMQwuh6SwqUk+foxKfpl5i/dquW9vwSs3vs3N/NLaJ2Yte1VUXjnYJ2OezmvqQENMEntk7OfGN d7pSeMti81q7klV857mCIeRJCNeU1yE6+TdRR5WLg6TW0yU/6JSbtHDaKWBMZ9IcAo7ODDYIKC+F 1MzrEPPAxAnJIeqMSjHGutUQ4SpmVuasjD/R3E4PkTjHjFsi0jGOtDAWqYE4fjFN83c+o9H4RICB 84b4oNZ9yjuSBLYm3EF43PTRiQWTjxxx8IqDkbPFvOgBph/jScxKs9BSURe9z9QkhUBfL0afvU6B 4cfIUitjvh9V7QDWyQokCBIzmveQmEx/T4GdF+LEDbycCVB9ubLPkPNGMYeCUeM59o0z+ko/VYLO hnXr7P333rNKHd3z5z8/q28m6KzR/p7HAZnbYQ47UVqOBTprEE+3lPORtJDzdLbm1KlTPe8MwSY/ L8+FYgRbnEVFnIQpTA1AiKiamiBYDJfW9dzzzndzvNL+A6ynGFAYgiAoBXjm60iZlctX2HoJ0ld8 8Ys6d3WHPSDHGRwfw2r63XffbddJa3rZpZdKYP07K5XTFY6+QcM7tKzM99KeeuqpbjqGd0/QPuIX sIrB45pWN75qdqVeMTR+wETID+1mQAPE0xBbR5twtqFFlAyEKjwBykQ8Q4x5xZ7dJgtdH6csYmRi Cq1zeKuFd3v277O1a9faH/9wv/bSbba/+u5f6wzgc2TiK00DTJRmGMa5OG8JPzUuqAb39SpXVUEA zUycsxfwUOV49VVv/SdNFAjYC07AvI08YSb9yhhVpzk9oXn6DvM8bxPZkU6R8cp9FKa4B8YsmCCc xeDpE2M/LhTwPcIERwfxDcI75bCQgcDu5SPseBAtg4Cp3Q5j5cU3wXGZxrbSUIYHjVfgwCPtje1q 0Dek4YfAwvfJb8KXn/jrOKJY0nIfn/kuxn3io0REojaB5ul7lWg9ZE5fVyOtX7G89Y4bI0/NwaSw TitmGTI1hJZ7pRP1JKvUMuN9S2W29a6l9F0R522mMwLS+SVb4/lAVaWdefZZViVz9fse+KOfE8sY ZSsBHtUb+KnNLJa4dYwyot+yBB8hgvArLKZwFBgLaW9qoe1JCaYzZ86wqcqnUppU35dK0cKREPg2 3ieimlzApXRoLwQYf20FYOp4nEjkqemK+MyN8JxFvSQ1pp/U92wLBf+b98vBxilZt5WGqZihFeqg kn3Bvlpzg2L0353jeamiD6zyBxJIpmStJOHqD6l/EhVt9b1/pj+tfJ6aVUv3Hfyspaw6N655BzXL /SCvm6Vu9ngYH2Oo7UF8WBK3FNH4pDHfhG+LEBZWd7hc+hcugxLJrzGjkGcsI7xBiPVZLJGs4+Wq qHaEtHDaDmClkx46BEBvxNJaaUxFWUVoNZhYjYRp0pjIQpMqUgsj7INPGM+m7AwJqjWKR1BtOmwO vez2pAwMRuPgbM+3nZ02DnonDT7JiIAIJhyMzNSIqSTMa0NDMMXIqEO/Je2KM8ZMkIlJSjB2Zwo6 tLuuRsxkNSu+kfSFtvrB3jRAGlWnTY30qFObBUMMY+1FJe4RDHA8gmdWDqVHUxq1BfQH3yAQFHY7 1bZt2ewebPGOyJ5RhIgBctsPY8t5sJjL4dqfo2TQtmJ2i+kcToxulDkW2swaMZh8x3v2g2L6y95O rlHwSW00eUe8OP744/0YGepE2qh9iow16Vhwqaqqtrz8XDvttNPstttuk6Zpt6e/Ro6Qnv3zXLv3 979zx0h3/e5O+93v7rJ75SjpUgmrQ8rKvF7UlTII5Hl4IX4fr01zcxZXr8A3Ukgp6sxOAwyQ4hBG 6LFMOC+N29KSAtuo/Vd7xHRXaVEEnHQBVtcTdcTOis1brGLLVhs+eoSbsrvHUsEqW0InZ/1yLmpk wGkjMASWNDOaRTapIZWKIaZJwCR816iJB3eiYOlmlQwQBcrA3JopmHM4CbFfqUPEM+L4kS/x3PMt VwLx7A1G8PD9xcKjGr2vlHOUHOG1a04krGaLxqHVYF8O36OZr5GDEswByQPnUbHtCLLZEvyz5EyK YsAdDXDlJacmSkskZfEd9Yjjh/tDwY3maZo/e8Na+UM7vRy9B+Q495qlfXfs7WYhCE042mDkKdpJ V/li42HjbCsV+pSigRl7TWfOnOmLDy+//LLvW2d8l5eXO92pkaAK1UU4ZU+gexXXd4CCPfLAB3qD Z95l2pMOveOcVOgRCyfe+Z9S+9LFHv0QgH/y4IMMfEnU2W/jg+JEhz2kRCVSpi9HPQQaO425N4RE f8bHZMcnIw7/xstqXk5b2QbeoK0Unf0uLZx2NkTT+SUhwCpfncxRXbMgRhfBlIVlzPxypR1lFT5X P2faNDJdiyLhFA0Gk70T3cYRm8y3s28i8xYZ0s7O/9DyE2DUVlY0MfUVu6zPYFRZt9JVZrgZUp3m 6WxJGGI3lUSbIjmV/SXOUEqIdW2NvsQZjdWKAa6X0yGlh2Ni3TfMY+SPlgjNTJ5+iuc5TnKHVuFD SkW9Upl+7mPA4QQ/8AMhM8IfphyyWSVBE5PeCy+80HILurvGE4YPbSQaVxwfwUBulmA0S6a88R3C CoxgkYRPTPQK5JUXjSTpF+uoEwRTBNW2AnkRKIsfgfohKLiwkXgPrlL/scePk0v/k2yz9slSzo9/ /GN3hHTPPffYDTfcoCMJ5tr999/vXntvueUWN/1dv3691SpvnG1QZ2CDUyHGQSzPbzr055MTD/OR z0n80WuGVhxeaOUJtA8hCemDs3czpSHbu6/WKrSwpC6Q595QvyytvHbT+2oJWj1Liu38c2bZAO0H 3q9+RHNUKI0RmsSPl67Q9/tkAhw01417hoOASXmpGstQi8a/jE3gzi+OU64IpfQ9eIDXTBec0Gon 0jssK6stS1owzo8lnj6NOBbxMPZnbDvv6V/MrXsUdrd8x5Nw9M16aYh3Vuy03n16S/tdat2Emwhq 4Ad5Y+pZp/5DO79m9Uqd6zrIzxwMpsxhHFAuuLdT+3S3Cm85YxFz8/z8QvfI2S0/z/ZrTKChZfGE vCOMfL9zAhaNEGp6F2HUNPbQnigT4RT8Aw7sdccL9tvvvOVHKd10003KKPQH+FojnHCYQoc0DhIo dGiFfQZSAQPgzwIajthYHHvkkUcc11gMKx86xI9NAubsF2drAouq7pBNe+U5s7dCWw7AvytlUYGA v0dWG2jbgZub8X4G4JCu4qcEgVQSnnr/KVUnXWwaAkcSAmnh9EhC+3NVlphBcSvsoYLZwUyyIEvH gUj43CMzwe0Vu23b9p1igrPEyObbrn3yiKgJG4Y2GyEJRyowyUcwRMb2CBbZtKiEcOgMpt8LDqiZ FRBb6+WAprpS1zoEVGmes9jjhAMmsYySpWoEu4asXGltZBpaGxh6ibG+ib1B3lbDngZyk/Cj713r KumEvLtCMKUkmDCEDxh+mGyeI5x5hlknjuDtTnwDo4sWvVbCUX19laeBOUeDGvMpLCzwezfTFYNI PHnwIy1XmH/K5zuEGZhFjodAQIgCCmU3DzCmsW7k48x6op6kJc9YD55JEwVsnMjgEOlL2kt71113 +XmnN2m/7EsvvGD3/P4eOUa6wc455xwXUGg7sKFu5OF7m1R2S4E6KEmHAyjFzz1KJ65gFyv0aDkx UWS8wjzTdjz2VsnCYfuu/bZXHx3IUf91l5YIDavG5ztvvSHNZ448D0+y7Tu3W7ceBTZg4CB7+cWX beO6DTZdznNYRHlPZtnr5YgKIR5B7KyzznJGnvbS9rZCxB9gTdrYZ2ijVq1a5f3KAgfnw27atMkF BxYIMCHOEP0YPHSoa9UxG4/fUy75AU/iuPIjb4RdBI175WF5146ddsH557v5dW+ZYi9euMjeePMN LSaM8DMwOWt3rY4EIS805WO1TxFPy3+87z7Vp4/tkROhD9T2fv36qa8rHIehcexhW758mZczUAI9 wgvOvUp1BMS27Tsk4KNZk0mt4oFZHDN4kaXu1PVQA+kPOajM6OjHyxFeADfGF5YIwJuFHTw6g/8c i+Lwo06HXMhnJyFwjn3L1gMEVATOlStX6rfK1q5epb4w7cvdYU899ZRbWHA2qmuS9QL8wLLgpJNP 8UU2YMj4hk57F/qfzw480jVNQyANgTQEjhQEjiz3f6RalS7nKICAZm1JTQhEdRKA8vO6WcXmHfbM E0/Ze4s/sAWLFtjij5ZKo/SyjgA5y2bOnu3CSL1MVt1ETqvyLnQdYa6nvcxfpwIaNVZCGE2ylEnV FiVJeKnLtw1rqmz44J6C6zYxQjCJYrKl6arXNTOrh+3bnS1hB6EOQnnFYwAAIABJREFUjagECb3L QCJRQDhpYA8rJsAulKJVDcIh7zs7wOChZSFQnyiIcg/jx3O8h9EF/jDkXnfd4/U4vk9lytFoIND1 kdBQIA0XWo3Z4JDK40c+ca8gZaNpQ4DBw2I8uzAy/bxvHqgLgTQxHQw5IeII8ewtI1AmAgXX0tJS Qyv69NNPG2a97DnFqdI1Ou8Us83HHnvMj8nBaRNtIwALQjzflHxSQ/Pn1HeHck9uqUIpzy6s8jFl 6eclCj+oEz8wBrPbnoUBh4r1nKv6V+kNOLe3er8VKJNBZUNt0Yfv27oN66xI2qOVq1baG/Pm23p5 OR4ydLAvCCBMot2EQZ8/f35CuEv0c7O2UqUYgDU/4EOdcDozXHt1uUdYmjRpks6M/NhNLufOnet7 jN/V2YR9tABxqvYc79MiBcIEAiL9R170G8HbqOcYiGfRgjo+9vgTtmjxElv44QK76OKLbMaMGXJq 08uKZSZeIU3tk0884Vp/BGEEktXyPL1a9blURwe99dab9u3/669s6bKl9vzzz7smjbzBVbShaNbw Go0gi9C6Y0eFd8HAgcfZfz39jJ09c5aPmQ3aw0wdqRPad875BY+7LAgW4D3jD1jlyvS4RB5maTtC KgsLtTiHSfSHW3io79y0WfU8FgPwpg9YeAIHJ0+ebOw9fUM4/OifHvK+RFM+b95rWqDYqQWJ3dqv WuU4canOMx44aLDt3rvPdu3e47RB2Cz4aVwx5I5FgKXblIZAGgJpCHQCBNLCaScAMZ1FSxAIDGyt
September 04, 2017 - October 05, 2017
AeroElectric-Archive.digest.vol-ob
