AeroElectric-Archive.digest.vol-of
January 07, 2018 - March 07, 2018
          http://www.matronics.com/digest/digestview.php?Style=82701&View=htm
      l&Chapter 18-01-03&Archive=AeroElectric
      Text Version:
          http://www.matronics.com/digest/digestview.php?Style=82701&View=txt
                                 AeroElectric-List Digest Archive
                           Total Messages Posted Wed 01/03/18: 12
      Today's Message Index:
           1. 02:42 AM - Re: Re: Simplest way for a go/no-go 2-Stroke Engine Temp
      erature Ind  (Bob Verwey)
           2. 07:27 AM - Re: Simplest way for a go/no-go 2-Stroke Engine Temperat
      ure Ind  (user9253)
           3. 07:48 AM - Re: Re: Simplest way for a go/no-go 2-Stroke Engine Temp
      erature Ind  (C&K)
           4. 08:47 AM - Re: Simplest way for a go/no-go 2-Stroke Engine Temperat
      ure Ind  (user9253)
           5. 08:56 AM - Re: Tech Edge "MODA" Fuel Level Probe   (Robert L. Nucko
      lls, III)
           6. 09:38 AM - Re: Re: Simplest way for a go/no-go 2-Stroke Engine Temp
      erature Ind  (Robert L. Nuckolls, III)
           7. 09:38 AM - Re: Tech Edge "MODA" Fuel Level Probe (addendum)  (Rober
      t L. Nuckolls, III)
           8. 10:58 AM - Re: Tech Edge "MODA" Fuel Level Probe  ()
           9. 11:49 AM - Re: Tech Edge "MODA" Fuel Level Probe  (Rene)
          10. 12:13 PM - Re: Tech Edge "MODA" Fuel Level Probe (addendum)  (Chris
      topher Cee Stone)
          11. 06:05 PM - Re: Tech Edge "MODA" Fuel Level Probe (addendum)  (Willi
      am Hunter)
          12. 07:18 PM - Re: Tech Edge "MODA" Fuel Level Probe (addendum)  (Bill
      Maxwell)
      ________________________________  Message 1  ______________________________
      _______
Subject: Re: Simplest way for a go/no-go 2-Stroke E
ngine Temperature Ind Joe is the operating voltage not an issue? On 02 Jan 2018 8:33 PM, "user9253" wrote: > > Perhaps some kind of temperature switch would work? > https://www.omega.com/pptst/TSW-TT.html > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=477017#477017 > > ________________________________ Message 2 ______________________________ _______
Subject: Re: Simplest way for a go/no-go 2-Stroke Engine
Temperature Ind From: "user9253" <fransew(at)gmail.com> No, the operating voltage is not a concern. The switch is rated for 2 amps at 24 VDC. That probably equates to 3 or 4 amps at 12 volts. If an indicator lamp is chosen that uses less than 1 amp, it should be fine. The switch is avai lable as either normally open or normally closed. There is a 50-50 chance of getting it right. The original poster probably wants the normally closed s witch. Another concern is selecting the correct operating temperature. And there is the life expectancy issue when subject to the vibration of a 2 cycle eng ine. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477046#477046 ________________________________ Message 3 ______________________________ _______ Subject: Re: AeroElectric-List: Re: Simplest way for a go/no-go 2-Stroke E ngine Temperature Ind From: C&K <yellowduckduo(at)gmail.com> A tiny keychain size infra red thermometers for $12. might be more useful and less trouble to set up. No calibration issues and fairly vibration resistant. Remote mounting of the display might be possible. https://www.ebay.com/itm/Mini-Digital-Non-Contact-IR-Infrared-LCD-Thermomet er-DT-300-Black-UD6-LD/161818543747?hash=item25ad230683:g:SbkAAOSw0JpV7Yx U Ken ________________________________ Message 4 ______________________________ _______ Subject: AeroElectric-List: Re: Simplest way for a go/no-go 2-Stroke Engine Temperature Ind From: "user9253" <fransew(at)gmail.com> Is it feasible to mount the infrared red thermometer, suggested by YellowDu ck, inside of the cockpit and use a fiber optic cable to transmit the engine he at through the firewall to the thermometer? -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477049#477049 ________________________________ Message 5 ______________________________ _______ From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Subject: Re: AeroElectric-List: Tech Edge "MODA" Fuel Level Probe At 11:01 AM 1/2/2018, you wrote: > > >Hi All, > >I've been working like crazy on my project and am getting ready to fly soo n!!! > >One obstacle (among many) is a solution to my header tank fuel level >sensor. I have a 5 gallon fiberglass header tank that the two wing >tanks gravity flow into and then the engine uses this header tank as >its sole source of fuel so it is good to know if this header tank is >full. It had an ON/OFF float switch however that switch is no >longer working and I tried to unscrew the float switch to replace it >however it is so tight that I am worried the plastic body/hex nut >will break off so it is best at this point to just leave it >installed as a "plug" and pursue another solution. > >Has anyone used a MODA tank sensor kit from tankedge.com ? > >https://tankedge.com/accessories.html > >It is a sensor that attaches to the outside of a fiberglass tank >with dual parallel strips of aluminum and copper tape. Somehow it >measures the resistance between the two strips and determines the >fuel quantity on the other side of the tank wall. This is probably an adaptation of the 'capacity sensor' widely used on touch pads for manual controll inputs. It senses a change in capacity. The two electrodes attached to the outside of the tank form a capacitor in which the dielectric is composed of tank material and air. When fuel fills up the air space, the capacitance goes up sharply and the electronics senses this. For metal tanks, they need to penetrate the tank wall to get at the change in air-to-fuel capacitance. Bob . . . ________________________________ Message 6 ______________________________ _______ From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Subject: Re: AeroElectric-List: Re: Simplest way for a go/no-go 2-Stroke Engine Temperature Ind At 08:39 PM 1/2/2018, you wrote: > > >On 1/2/2018 12:26 PM, user9253 wrote: >> >>Perhaps some kind of temperature switch would work? >>https://www.omega.com/pptst/TSW-TT.html >> >>-------- >>Joe Gores >I like Joe's find. Still have to watch the max temp, though. Another option uses the Analog Devices thermocouple conditioners in a on-off switching mode. https://goo.gl/7ufeaL Here's a simplified schematic . . . Emacs! Instead of driving a heater control relay, one could drive an LED indicator light directly from the signal conditioner's output . . . This would let you connect directly to the cylinder head with appropriate thermocouple material. Bob . . . ________________________________ Message 7 ______________________________ _______ From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Subject: Re: AeroElectric-List: Tech Edge "MODA" Fuel Level Probe (addend um) >>It is a sensor that attaches to the outside of a fiberglass tank >>with dual parallel strips of aluminum and copper tape. Somehow it >>measures the resistance between the two strips and determines the >>fuel quantity on the other side of the tank wall. > > This is probably an adaptation of the 'capacity > sensor' widely used on touch pads for manual controll > inputs. It senses a change in capacity. The two > electrodes attached to the outside of the tank form > a capacitor in which the dielectric is composed of > tank material and air. > > When fuel fills up the air space, the capacitance > goes up sharply and the electronics senses this. For > metal tanks, they need to penetrate the tank wall > to get at the change in air-to-fuel capacitance. Okay, looking closer reveals that this is a capacity fuel gaging system, not just a level sensor. There is a whole new class of liquid level capacity transducer products out there. Recent developments in resolving capacity has spawned a variety of low cost instruments that will measure capacitance with good accuracy down into the picoFarads territory. There's a pretty simple methodology for using pic/arduino DIY processors to implement your own capacity liquid level measurement system wherein the sensor is nothing more than a twisted pair of wires with insulation impervious to the liquid being sensed. For the product cited above, the sensor is either copper foil electrodes on the outside of the plastic tank . . . or some analog built into the probe. This could be paired with a comparator that drives a 'tank full' indicator light. Bob . . . ________________________________ Message 8 ______________________________ _______ From: <jim(at)PoogieBearRanch.com> Subject: RE: AeroElectric-List: Tech Edge "MODA" Fuel Level Probe How about using this: http://www.beliteaircraftstore.com/bingo-liquid-detector/ It was designed for this exact purchase, and Jim Wiebe (designer/owner) created it to indicate when a specific "bingo" (low fuel) level occurred in header tanks and in-wing fuel tanks, as a backup to the fuel gauges. (He has some pretty terrific fuel level sensors, as well for the experimental crowd.) You install this detector at whatever level in the fuel tank you choose, and it alerts you when the liquid level drops below that point. The LED indicator is normally green when the level is above the "bingo" level, and if/when it drops below that point, it flashes red for 10 seconds, then goes solid red. Installation seems dirt simple, and it seems to work with just about any liquid. There's a video demonstrating it on that page also. Currently on sale for $69.95. Jim Parker ________________________________ Message 9 ______________________________ _______ From: "Rene" <rene(at)felker.com> Subject: RE: AeroElectric-List: Tech Edge "MODA" Fuel Level Probe I have a system similar to that in my RV-10. 1 in each tank at the 3 gallo n level. Only really use it when I want to run a tank dry. If the tank sloshes, then I do get some false alarms when it is bumpy. I use my float gages to alarm at 5 gallons left. Rene' 801-721-6080 -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectr ic-list-server(at)matronics.com] On Behalf Of jim(at)PoogieBearRanch.com Sent: Wednesday, January 03, 2018 11:58 AM Subject: RE: AeroElectric-List: Tech Edge "MODA" Fuel Level Probe How about using this: http://www.beliteaircraftstore.com/bingo-liquid-detector/ It was designed for this exact purchase, and Jim Wiebe (designer/owner) cre ated it to indicate when a specific "bingo" (low fuel) level occurred in header tanks and in-wing fuel tanks, as a backup to the fuel gauges. (He has some pretty terrific fuel level sensors, as well for the experiment al crowd.) You install this detector at whatever level in the fuel tank you choose, an d it alerts you when the liquid level drops below that point. The LED indicator is normally green when the level is above the "bingo" level, and if/when it dr ops below that point, it flashes red for 10 seconds, then goes solid red. Installation seems dirt simple, and it seems to work with just about any li quid. There's a video demonstrating it on that page also. Currently on sale for $69.95. Jim Parker ________________________________ Message 10 _____________________________ _______ From: Christopher Cee Stone <rv8iator(at)gmail.com> Subject: Re: AeroElectric-List: Tech Edge "MODA" Fuel Level Probe (addendum ) Texas Instruments has a chip level solution for liquid level sensing by capacitive sense: http://www.ti.com/general/docs/video/watch.tsp?entryid=4279163138001 -chris stone On Wed, Jan 3, 2018 at 9:15 AM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > It is a sensor that attaches to the outside of a fiberglass tank with dua l > parallel strips of aluminum and copper tape. Somehow it measures the > resistance between the two strips and determines the fuel quantity on the > other side of the tank wall. > > > This is probably an adaptation of the 'capacity > sensor' widely used on touch pads for manual controll > inputs. It senses a change in capacity. The two > electrodes attached to the outside of the tank form > a capacitor in which the dielectric is composed of > tank material and air. > > When fuel fills up the air space, the capacitance > goes up sharply and the electronics senses this. For > metal tanks, they need to penetrate the tank wall > to get at the change in air-to-fuel capacitance. > > > Okay, looking closer reveals that this is a > capacity fuel gaging system, not just a level > sensor. There is a whole new class of liquid level > capacity transducer products out there. > > Recent developments in resolving capacity has > spawned a variety of low cost instruments that > will measure capacitance with good accuracy > down into the picoFarads territory. > > There's a pretty simple methodology for using > pic/arduino DIY processors to implement your own > capacity liquid level measurement system wherein > the sensor is nothing more than a twisted pair of > wires with insulation impervious to the liquid being > sensed. > > For the product cited above, the sensor is either > copper foil electrodes on the outside of the plastic > tank . . . or some analog built into the > probe. > > This could be paired with a comparator that drives > a 'tank full' indicator light. > > > Bob . . . > ________________________________ Message 11 _____________________________ _______ From: "William Hunter" <billhuntersemail(at)gmail.com> Subject: RE: AeroElectric-List: Tech Edge "MODA" Fuel Level Probe (addendum ) Thanks all for your help!!! Good information. .. Cheers!!! Bill Hunter From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Christopher Cee Stone Sent: Wednesday, January 3, 2018 12:13 PM Subject: Re: AeroElectric-List: Tech Edge "MODA" Fuel Level Probe (addendum) Texas Instruments has a chip level solution for liquid level sensing by capacitive sense: http://www.ti.com/general/docs/video/watch.tsp?entryid=4279163138001 -chris stone On Wed, Jan 3, 2018 at 9:15 AM, Robert L. Nuckolls, III > wrote: It is a sensor that attaches to the outside of a fiberglass tank with dual parallel strips of aluminum and copper tape. Somehow it measures the resistance between the two strips and determines the fuel quantity on the other side of the tank wall. This is probably an adaptation of the 'capacity sensor' widely used on touch pads for manual controll inputs. It senses a change in capacity. The two electrodes attached to the outside of the tank form a capacitor in which the dielectric is composed of tank material and air. When fuel fills up the air space, the capacitance goes up sharply and the electronics senses this. For metal tanks, they need to penetrate the tank wall to get at the change in air-to-fuel capacitance. Okay, looking closer reveals that this is a capacity fuel gaging system, not just a level sensor. There is a whole new class of liquid level capacity transducer products out there. Recent developments in resolving capacity has spawned a variety of low cost instruments that will measure capacitance with good accuracy down into the picoFarads territory. There's a pretty simple methodology for using pic/arduino DIY processors to implement your own capacity liquid level measurement system wherein the sensor is nothing more than a twisted pair of wires with insulation impervious to the liquid being sensed. For the product cited above, the sensor is either copper foil electrodes on the outside of the plastic tank . . . or some analog built into the probe. This could be paired with a comparator that drives a 'tank full' indicator light. Bob . . . ________________________________ Message 12 _____________________________ _______ Subject: Re: AeroElectric-List: Tech Edge "MODA" Fuel Level Probe (addendum ) From: Bill Maxwell <wrmaxwell(at)bigpond.com> Interesting device. I wonder though whether a metal tank's contents can be measured as effectively by this device when mounted externally? On 4/01/2018 7:12 AM, Christopher Cee Stone wrote: > Texas Instruments has a chip level solution for liquid level sensing > by capacitive sense: > > http://www.ti.com/general/docs/video/watch.tsp?entryid=4279163138001 > > -chris stone > > > On Wed, Jan 3, 2018 at 9:15 AM, Robert L. Nuckolls, III > > > wrote: > >>> It is a sensor that attaches to the outside of a fiberglass tank >>> with dual parallel strips of aluminum and copper tape. Somehow >>> it measures the resistance between the two strips and determines >>> the fuel quantity on the other side of the tank wall. >> >> This is probably an adaptation of the 'capacity >> sensor' widely used on touch pads for manual controll >> inputs. It senses a change in capacity. The two >> electrodes attached to the outside of the tank form >> a capacitor in which the dielectric is composed of >> tank material and air. >> >> When fuel fills up the air space, the capacitance >> goes up sharply and the electronics senses this. For >> metal tanks, they need to penetrate the tank wall >> to get at the change in air-to-fuel capacitance. > > Okay, looking closer reveals that this is a > capacity fuel gaging system, not just a level > sensor. There is a whole new class of liquid level > capacity transducer products out there. > > Recent developments in resolving capacity has > spawned a variety of low cost instruments that > will measure capacitance with good accuracy > down into the picoFarads territory. > > There's a pretty simple methodology for using > pic/arduino DIY processors to implement your own > capacity liquid level measurement system wherein > the sensor is nothing more than a twisted pair of > wires with insulation impervious to the liquid being > sensed. > > For the product cited above, the sensor is either > copper foil electrodes on the outside of the plastic > tank . . . or some analog built into the > probe. > > This could be paired with a comparator that drives > a 'tank full' indicator light. > > > Bob . . . > > ________________________________________________________________________________
Subject: Re: EFIS/EMS Brownout/Reboot: =?ISO-8859-1?Q?=9CVoltage?=
Slump =?ISO-8859-1?Q?Eliminator=9D?
Date: Jan 07, 2018
Joe, I concur with you on Eric's Deslumpifier! Excellent workmanship... thanks Eric! I also noted output voltage in the same ballpark as input voltage. I've already installed it and tested out Phase I which is normal battery ops on the bench with power to my GNS480 via the Deslumpifier. And it's working like a champ so far. Of course Phase II testing will come much later (hopefully this year!) when I start my engine with the GNS480 powered up. I'm especially glad you recommended that I press forward with this design, Joe. I'm hopefully optimistic that my turbo'd version will work for the GNS480. I've included a pic of my quasi-installed Deslumpifier (the "UG" is part of a code I use for component ID in my wire labels). And yes, although it's 8 deg F, I'm very happy with this device! :D Wade -------- Airdog Wade Parton Building Long-EZ N916WP www.longezpush.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477147#477147 Attachments: http://forums.matronics.com//files/deslumpifier1_597.jpg ________________________________________________________________________________
Subject: Thanks for the 480 help
Date: Jan 07, 2018
Thanks to all who replied to my recent post on the 480-Navworx problem. While I dont have the problem solved as yet, the information provided by all the Listers was helpful in getting me pointed in the right direction. Before I get back to problem solving, I need to go out and fly since flying activity around here has been limited by subzero cold for at least 2-3 weeks and my annual inspection. Sheldon Olesen ________________________________________________________________________________
Date: Jan 07, 2018
We're here for you - fly safe! -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Sheldon Olesen Sent: Sunday, January 07, 2018 1:04 PM Subject: AeroElectric-List: Thanks for the 480 help --> Thanks to all who replied to my recent post on the 480-Navworx problem. While I dont have the problem solved as yet, the information provided by all the Listers was helpful in getting me pointed in the right direction. Before I get back to problem solving, I need to go out and fly since flying activity around here has been limited by subzero cold for at least 2-3 weeks and my annual inspection. Sheldon Olesen ________________________________________________________________________________
Date: Jan 07, 2018
Date: Jan 07, 2018
Subject: Re: AeroElectric-List Digest: 12 Msgs - 01/03/18
At 05:21 PM 1/6/2018, you wrote: >Please remove me from your email list.thank you. > >Get Outlook for Android You are subscribed to a number of forums on Matronics. Don't know if you're asking to be unsubscribed to one, a few or all. Go to http://www.matronics.com/subscribe/ where you can manage the details of your request personally. Bob . . . ________________________________________________________________________________
Subject: Re: Alarm souder with multiple sources
Date: Jan 08, 2018
Maybe a bit late, but... Lots of options and how smart you want this to be. Cheap and easy way if you know a bit of C might be an Arduino... Depends on your input voltages and what IO you need... It can turn on a bi-color LED - RED for bad stuff, yellow for alerts... Even do voice messages with the addition of an appropriate wav module... What do your inputs look like and what outputs do you need? (Voice, 1 LED, multiple LED's?) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477181#477181 ________________________________________________________________________________
Subject: Re: Engine Sensors to Arduino...
Date: Jan 08, 2018
Great call on the LM235 degree K sensor... I'll be using that on the front module for the air data computer side of this thing. Can't the ground for an LM35 just be biased up a volt or so to get the negative temperatures if the voltage conversion accounts for that 1 volt? I spent some time looking over the DAS system... Nice setup - thank you for the education seeing how these are really designed... I've got a EE degree from 20 years ago, but never got into circuit design. Always a development guy... Sensors and mechanical integration of the electronics, along with calibration and engine tuning. Now I'm getting into some fun circuit design and trying to relearn. On 3.3V vs 5V... My module driving my display is a Teensy 3.6 - should be able to grunt the display and ADC computations along plenty fast - 3.3V. For the engine side module, I have used a bunch of the SAMD21 Arduino boards so I've kind of stuck there. Using RS485 so I know I can use 5V in the engine compartment, but... (TTWWADI - I know...) Failure analysis... It won't be anything more mission critical than oil pressure... I can hear RPM... Everything else is bonus data from where I am today. As far as failure of this system affecting the rest of the airplane - pull the breaker and shut it down. Probably not exceeding physiological perception latency... I'm gonna have to remember that one. My CGR30P's in the other airplane record at 3Hz. Data gathered will be written to SD card... Probably won't store more than 10 hours of data, Estimating 3-5 MB an hour so pretty easy on GB class SD cards. Analyzing data... I do this with my CGR30's and dump it either into Excel or process it with a chunk of C code to grab what I need and get what I'm trying to learn that day / week / month / airplane. I already display the MP and Timing on a 3.5 digit panel meter - want to get rid of that. Filters pretty smooth. Planning on light filtering in HW to clean things up and help the AD's out, then use SW filtering to get where I need to be. Both are really cheap and good in their own ways. Getting closer on the circuits via my re-education in electronics... Open for any other thoughts or improvements... Anything I'm doing grossly wrong, or could easily improve. Planning on setting the ARef to 1.1V on the Ardunio. I think I have my voltage dividers and filters about right. I have the 10V, 1.5ms RPM signal coming in - I think the circuit I've put together will work for the digital Arduino input - interrupt SW works, but I haven't tested this circuit against it. Fuel Press and Oil Temp are the Westach 387-100 KV and 387-30 KV 0.5V to 4.5V sensors. EOT is a Westach sensor as well 2190 ohms at 90F (about as low as I need to measure) and 212 ohms at 212F. How can I improve the resolution at high temp without giving up the range at the bottom end? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477191#477191 Attachments: http://forums.matronics.com//files/untitled2_169.png http://forums.matronics.com//files/untitled1_120.png ________________________________________________________________________________
Subject: Re: Electronic Ignition spark advance signal boost
Date: Jan 08, 2018
Hi All, Quick question on hooking up the AD626 op amp board that Eric is so graciously constructing for me. I spliced a 22AWG ground wire to the main electronic ignition unit ground wire about 4-5" where it exits the case. My question pertains to the fact that the ground wire exiting the case is massive, about 12-14 AWG, so I'm thinking there's a good bit of juice transiting that wire. So, in splicing in my 22AWG AD626 wire (for V IN-) should I use a protective resistor or diode on it before attaching to the AD626? Yes, I'm still learning a lot of this stuff and would like not to be the one to fry up a nice piece of work of Eric's! :? Thanks, Wade -------- Airdog Wade Parton Building Long-EZ N916WP www.longezpush.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477192#477192 ________________________________________________________________________________
CORRECTION
Date: Jan 08, 2018
Bob, I missed this post earlier and noted your comment Re. this corrected diagram in the other thread. I'm hoping 4-5" from the case is close enough to tie into the ground wire for pin 1 input? As I mention in the other thread, for some reason the ground wire on this unit is massive, around 12-14AWG. Thanks, Wade -------- Airdog Wade Parton Building Long-EZ N916WP www.longezpush.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477193#477193 ________________________________________________________________________________
Date: Jan 09, 2018
boost CORRECTION At 07:38 PM 1/8/2018, you wrote: > >Bob, > >I missed this post earlier and noted your comment Re. this corrected >diagram in the other thread. > >I'm hoping 4-5" from the case is close enough to tie into the ground >wire for pin 1 input? As I mention in the other thread, for some >reason the ground wire on this unit is massive, around 12-14AWG. Exactly what parameter is being conditioned by the AD626? The is a DIFFERENTIAL amplifier which offers a larger image of the voltage presented to the two inputs IRRESPECTIVE of the common mode voltages. For example, you can tie the inputs of the AD626 to the two terminals of an alternator b-lead shunt that may be 28 volts or more ABOVE ground and endowed with lots of trashy noise . . . while seeking to amplify a 0-50 MILLIVOLT signal across the shunt up to a 0-5 VOLT signal for interpretation by the data acquisition system. This means that where ever the (+) input of the amplifier is tied, the (-) input is VERY CLOSE BY. What ever the (+) input sees in terms of voltages to be ignored, the (-) input must see the SAME NOISE. Can you scan a sketch of what you're attempting to resolve with respect to wiring? What's the sensor, where's it located, what excites the sensor? In all my many experiences with the AD626 and cousins, the DISTANCE between points sampled by the two inputs has never been more than inches apart and usually millimeters apart conducted to the amplifier on twisted pair of wires. One such application had the AD626 looking at a strain gage embedded in the core of a pitch trim actuator attach bolt. I needed to resolve MICROVOLTS of signal from 5 VOLTS of common mode at the end of about 40 feet of twisted pair that traversed the noisiest environs on the aircraft. This is a really capable device but unless applied with understanding, the results will disappoint. I'm unable to offer a considered answer to your question without knowing more about the physical layout of the system components. Bob . . . ________________________________________________________________________________
Date: Jan 09, 2018
Subject: Lithium: State of the technology
A friend just sent me an interesting assessment of the state of the technology for lithium batteries, the 2018 edition. You can find this document at . . . https://goo.gl/tD7VdQ . . . don't have time right now to sift the details but many of you have an interest in such things . . . thought I would get it posted for access as your interest dictates. Bob . . . ________________________________________________________________________________
Date: Jan 09, 2018
Subject: Interesting Product Alert
There's a family of digital laser distance measuring tools out there. Unlike the ultrasonic range meters these instruments take a reading on reflected light from the laser dot. They're offered with a variety of built in calculators for area and volume. Bought one of the least expensive examples here: https://goo.gl/d6Xmre I bought the one with 80 meter range for ~30 dollars. The 40m range is only 16 dollars and mailed to you from the US. In the "inch" measurement mode, I supported the device on my desk and measured distance to the ceiling tiles . . . the white surface was repeatedly reported at 65.629" A measurement to the bottom of a decorative depression in the tiles repeated at 65.747". From this I conclude that the depression measured was about 0.020" deep. I'll be using this to help level up some structure on a friend's implement shed without having to stand on any ladders, etc. Will report any disappointments/amazements as they present . . . when the weather gets warmer! Bob . . . ________________________________________________________________________________
Date: Jan 09, 2018
Subject: Re: Interesting Product Alert
>In the "inch" measurement mode, I supported >the device on my desk and measured distance to >the ceiling tiles . . . the white surface >was repeatedly reported at 65.629" A measurement >to the bottom of a decorative depression in the tiles >repeated at 65.747". From this I conclude that >the depression measured was about 0.020" deep. I failed to point out that the above experiment was a demonstration of resolution and repeatability, not of accuracy. The specified accuracy of my particular device is +/-2 mM or +/-0.078 inches. Still, pretty impressive in terms of slicing beams of light into millimeter chunks . . . ain't 'lectronics wunderful? Bob . . . ________________________________________________________________________________
Date: Jan 09, 2018
What is the angle measurement it mentions? Does it work as an inclenometer as well? On Tue, Jan 9, 2018 at 4:51 PM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > In the "inch" measurement mode, I supported > the device on my desk and measured distance to > the ceiling tiles . . . the white surface > was repeatedly reported at 65.629" A measurement > to the bottom of a decorative depression in the tiles > repeated at 65.747". From this I conclude that > the depression measured was about 0.020" deep. > > > I failed to point out that the above experiment was > a demonstration of resolution and repeatability, > not of accuracy. The specified accuracy of my > particular device is +/-2 mM or +/-0.078 inches. > > Still, pretty impressive in terms of slicing beams > of light into millimeter chunks . . . ain't 'lectronics > wunderful? > > > Bob . . . > ________________________________________________________________________________
Date: Jan 10, 2018
boost CORRECTION At 10:30 AM 1/9/2018, you wrote: >At 07:38 PM 1/8/2018, you wrote: >> >>Bob, >> >>I missed this post earlier and noted your comment Re. this >>corrected diagram in the other thread. >> >>I'm hoping 4-5" from the case is close enough to tie into the >>ground wire for pin 1 input? As I mention in the other thread, for >>some reason the ground wire on this unit is massive, around 12-14AWG. > > Exactly what parameter is being conditioned by > the AD626? My apologies, I got your particular task stirred in with another conversation on use of the AD626. I recall that you're simply wanting to put a small gain on the advance signal from the Electroair ignition system. I downloaded the Electroair experimental installation manual which is very UNCLEAR as to what all the ground connections are . . . and what kind of current flows in each wire. Given the dearth of clarity, here's my best recommendation. Use Pin 14 of J1 as the (-) input measurement point. And, of course, you already know that Pin 21 is the (+) input. Emacs! Sorry for what must have appeared to be a rather obtuse posting . . . didn't realize the struggle with poor data. Bob . . . ________________________________________________________________________________
Date: Jan 10, 2018
At 08:51 PM 1/9/2018, you wrote: >What is the angle measurement it mentions? Does it work as an >inclenometer as well? I don't think it calculates any angles . . . there is a bubble level on the face which assists the operator in making consistent measurements. Bob . . . ________________________________________________________________________________
CORRECTIO
Date: Jan 11, 2018
Bob, I should have been a bit clearer myself on the ground wire off that unit since --you're gonna love this-- it's not on the diagram! Yes, there is actually a separate ground wire that is not depicted on that diagram, and again, for some reason it's quite robust (~12-14AWG). So I measured the distance from the case that I tied into that big ground wire with my 22AWG lead for the AD626 (-) input at 4.5 inches. Sorry for the confusion and thanks for the help! Wade -------- Airdog Wade Parton Building Long-EZ N916WP www.longezpush.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477218#477218 ________________________________________________________________________________
Date: Jan 11, 2018
boost CORRECTIO At 02:02 AM 1/11/2018, you wrote: > >Bob, > >I should have been a bit clearer myself on the ground wire off that >unit since --you're gonna love this-- it's not on the diagram! > >Yes, there is actually a separate ground wire that is not depicted >on that diagram, and again, for some reason it's quite robust >(~12-14AWG). So I measured the distance from the case that I tied >into that big ground wire with my 22AWG lead for the AD626 (-) input >at 4.5 inches. > >Sorry for the confusion and thanks for the help! That may be the ground return for the 9A coil charging current cited in the installation manual. For your purposes, tying AD626(-) input to the same airframe ground as this wire may not be a problem but after you've got the system up and running, you may observe behaviors that prompt further inquiry and perhaps relocation of the instrumentation ground. Given the short length, you're probably going to be okay. Bob . . . ________________________________________________________________________________
CORRECTIO
Date: Jan 11, 2018
Bob, I'll take note of that and watch it during future testing. Thanks again! Wade -------- Airdog Wade Parton Building Long-EZ N916WP www.longezpush.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477225#477225 ________________________________________________________________________________
Subject: Need a device to send 12volts when all 3 green lights
are light
Date: Jan 11, 2018
Below is the landing gear circuit, I need a device or build one that can u se the 12volts coming from the gear down and locked switches and only send 12 volts to another device[for testing a led] IF ALL 3 lights (gear down an d locked) I thought use 3 NPN transistors in series but it seems on my test, if I sup ply 12 volts to the base of the npn it still lights the led (leak though ?) with no voltage on anything else I am using figure two of these examples http://www.rason.org/Projects/transwit/transwit.htm [cid:image002.png(at)01D38AE1.28EBC0D0] IDEAS ? [cid:image001.png(at)01D38AB2.2D717B60] ________________________________________________________________________________
Subject: Re: Need a device to send 12volts when all 3 green
lights are light
Date: Jan 11, 2018
On 1/11/2018 1:37 PM, Jeffrey W. Skiba wrote: > > Below is the landing gear circuit, I need a device or build one that > can use the 12volts coming from the gear down and locked switches and > only send 12 volts to another device[for testing a led] IF ALL 3 > lights (gear down and locked) > > I thought use 3 NPN transistors in series but it seems on my test, if > I supply 12 volts to the base of the npn it still lights the led (leak > though ?) with no voltage on anything else > > I am using figure two of these examples > > http://www.rason.org/Projects/transwit/transwit.htm > > > IDEAS ? > Look here: https://www.google.com/search?q=3+input+and+gate+truth+table&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwikuoCK2NDYAhVM1oMKHUrVDZgQsAQIKA&biw=1920&bih=987#imgrc=GMoqi5mBR2TtpM: Note that a quad input AND gate might be easier to find, and you can use it as a 3 input by tying the 4th input high. --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
lights are light
Date: Jan 11, 2018
On 1/11/2018 2:01 PM, Charlie England wrote: > On 1/11/2018 1:37 PM, Jeffrey W. Skiba wrote: >> >> Below is the landing gear circuit, I need a device or build one that >> can use the 12volts coming from the gear down and locked switches and >> only send 12 volts to another device[for testing a led] IF ALL 3 >> lights (gear down and locked) >> >> I thought use 3 NPN transistors in series but it seems on my test, if >> I supply 12 volts to the base of the npn it still lights the led >> (leak though ?) with no voltage on anything else >> >> I am using figure two of these examples >> >> http://www.rason.org/Projects/transwit/transwit.htm >> >> >> IDEAS ? >> > Look here: > https://www.google.com/search?q=3+input+and+gate+truth+table&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwikuoCK2NDYAhVM1oMKHUrVDZgQsAQIKA&biw=1920&bih=987#imgrc=GMoqi5mBR2TtpM: > > Note that a quad input AND gate might be easier to find, and you can > use it as a 3 input by tying the 4th input high. Here's one that works on 12V, & you get 2 spare devices in the package: http://www.ti.com/lit/ds/symlink/cd4082b.pdf --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jan 11, 2018
Subject: capacitor durability
So yesterday I received my shiny new 33000 micro farad capacitor, for use with my Silent Hektik regulator. Within five minutes, I had managed to drop it from a height of three feet onto my hardwood floor. The floor is fine, but I wonder about the capacitor. How likely is it that it was damaged? How would such damage show up? Ken ________________________________________________________________________________
Date: Jan 11, 2018
lights are light At 02:01 PM 1/11/2018, you wrote: >On 1/11/2018 1:37 PM, Jeffrey W. Skiba wrote: >>Below is the landing gear circuit, I need a device or build one >>that can use the 12volts coming from the gear down and locked >>switches and only send 12 volts to another device[for testing a >>led] IF ALL 3 lights (gear down and locked) Can you just hook all the down-lock switches in series? Bob . . . ________________________________________________________________________________
Subject: Re: capacitor durability
Date: Jan 12, 2018
Extremely unlikely to be damaged Ken, provided of course tthat the terminals weren't broken off. Bill On 12/01/2018 7:38 AM, Ken Ryan wrote: > So yesterday I received my shiny new 33000 micro farad capacitor, for > use with my Silent Hektik regulator. Within five minutes, I had > managed to drop it from a height of three feet onto my hardwood floor. > The floor is fine, but I wonder about the capacitor. How likely is it > that it was damaged? How would such damage show up? > > Ken ________________________________________________________________________________
lights are light
Date: Jan 11, 2018
Then I would lose each gear indication. This is for an audio alert device input if the gear is not down and locked (all 3) From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectr ic-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Thursday, January 11, 2018 3:04 PM Subject: Re: AeroElectric-List: Need a device to send 12volts when all 3 gr een lights are light At 02:01 PM 1/11/2018, you wrote: On 1/11/2018 1:37 PM, Jeffrey W. Skiba wrote: Below is the landing gear circuit, I need a device or build one that can u se the 12volts coming from the gear down and locked switches and only send 12 volts to another device[for testing a led] IF ALL 3 lights (gear down an d locked) Can you just hook all the down-lock switches in series? Bob . . . ________________________________________________________________________________
Date: Jan 12, 2018
The terminals are fine. How would one know that a capacitor was not working properly in a (for example) Rotax installation? I know some guys don't even use the capacitor. On Thu, Jan 11, 2018 at 1:18 PM, Bill Maxwell wrote: > Extremely unlikely to be damaged Ken, provided of course tthat the > terminals weren't broken off. > > Bill > > On 12/01/2018 7:38 AM, Ken Ryan wrote: > > So yesterday I received my shiny new 33000 micro farad capacitor, for use > with my Silent Hektik regulator. Within five minutes, I had managed to drop > it from a height of three feet onto my hardwood floor. The floor is fine, > but I wonder about the capacitor. How likely is it that it was damaged? How > would such damage show up? > > Ken > > ________________________________________________________________________________
Date: Jan 11, 2018
At 02:38 PM 1/11/2018, you wrote: >So yesterday I received my shiny new 33000 micro farad capacitor, >for use with my Silent Hektik regulator. Within five minutes, I had >managed to drop it from a height of three feet onto my hardwood >floor. The floor is fine, but I wonder about the capacitor. How >likely is it that it was damaged? How would such damage show up? If the case is not dented, the cap is probably just fine. Even if it IS dented, risk to functionality is low. Failure would show up as excessive leakage precipitating a venting event. Generally nothing spectacular. Bob . . . ________________________________________________________________________________
Date: Jan 12, 2018
Thanks. I will pretend nothing happened. On Jan 12, 2018 09:09, "Robert L. Nuckolls, III" < nuckolls.bob(at)aeroelectric.com> wrote: > At 02:38 PM 1/11/2018, you wrote: > > So yesterday I received my shiny new 33000 micro farad capacitor, for use > with my Silent Hektik regulator. Within five minutes, I had managed to drop > it from a height of three feet onto my hardwood floor. The floor is fine, > but I wonder about the capacitor. How likely is it that it was damaged? How > would such damage show up? > > > If the case is not dented, the cap is probably > just fine. Even if it IS dented, risk to functionality > is low. Failure would show up as excessive leakage > precipitating a venting event. Generally nothing spectacular. > > Bob . . . > ________________________________________________________________________________
Date: Jan 12, 2018
lights are light At 05:03 PM 1/11/2018, you wrote: >Then I would lose each gear indication. This is for an audio alert >device input if the gear is not down and locked (all 3) > >From: owner-aeroelectric-list-server(at)matronics.com >[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of >Robert L. Nuckolls, III >Sent: Thursday, January 11, 2018 3:04 PM >To: aeroelectric-list(at)matronics.com >Subject: Re: AeroElectric-List: Need a device to send 12volts when >all 3 green lights are light Okay, how about something like this: Emacs! Bob . . . ________________________________________________________________________________
lights are light
Date: Jan 12, 2018
On 1/12/2018 1:30 PM, Robert L. Nuckolls, III wrote: > At 05:03 PM 1/11/2018, you wrote: >> Then I would lose each gear indication. This is for an audio alert >> device input if the gear is not down and locked (all 3) >> >> *From:* owner-aeroelectric-list-server(at)matronics.com >> [mailto:owner-aeroelectric-list-server(at)matronics.com >> ] *On Behalf Of >> *Robert L. Nuckolls, III >> *Sent:* Thursday, January 11, 2018 3:04 PM >> *To:* aeroelectric-list(at)matronics.com >> *Subject:* Re: AeroElectric-List: Need a device to send 12volts when >> all 3 green lights are light > > Okay, how about something like this: > > Emacs! > > > Bob . . . > What's wrong with using a CMOS 3 input AND gate (linked in an earlier email)? Here's one that works on 12V, & you get 2 spare devices in the package: http://www.ti.com/lit/ds/symlink/cd4082b.pdf --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jan 12, 2018
lights are light >> Bob . . . >What's wrong with using a CMOS 3 input AND gate (linked in an earlier email)? > >Here's one that works on 12V, & you get 2 spare devices in the package: ><http://www.ti.com/lit/ds/symlink/cd4082b.pdf>http://www.ti.com/lit/ds/symlink/cd4082b.pdf Not a thing . . . just one of several alternatives. Bob . . . ________________________________________________________________________________
Date: Jan 13, 2018
It can be tested both for its capacitance and for ESR, for both which you would need the appropriate instrument. Hardly worth investing in these if your only use is on this application. If you know a friendly amateur radio operator, he or she should be able to do that for you, or know of somebody who has the test instruments. A simple test would be to put it across a battery and let it charge up, then remove it and measure the voltage stored in the capacitor. Should be close to the battery's voltage. Mind you don't touch both terminals though, as it is capable of dumping its charge quickly into your body, a trick I recall being often employed in high school physics classes. A capacitor is a relatively simple device. In this application, it sits across the DC supply from the alternator and regulator, where it smooths out any remaining AC spikes that might otherwise show up as noise in your radio or otherwise interfere with the proper operation of your avionics. On 13/01/2018 3:22 AM, Ken Ryan wrote: > The terminals are fine. How would one know that a capacitor was not > working properly in a (for example) Rotax installation? I know some > guys don't even use the capacitor. > > On Thu, Jan 11, 2018 at 1:18 PM, Bill Maxwell > wrote: > > Extremely unlikely to be damaged Ken, provided of course tthat the > terminals weren't broken off. > > Bill > > > On 12/01/2018 7:38 AM, Ken Ryan wrote: >> So yesterday I received my shiny new 33000 micro farad capacitor, >> for use with my Silent Hektik regulator. Within five minutes, I >> had managed to drop it from a height of three feet onto my >> hardwood floor. The floor is fine, but I wonder about the >> capacitor. How likely is it that it was damaged? How would such >> damage show up? >> >> Ken > > ________________________________________________________________________________
Date: Jan 12, 2018
Thx Bill! Sent from my Android. Sorry Steve. On Jan 12, 2018 12:45, "Bill Maxwell" wrote: > It can be tested both for its capacitance and for ESR, for both which you > would need the appropriate instrument. Hardly worth investing in these if > your only use is on this application. If you know a friendly amateur radio > operator, he or she should be able to do that for you, or know of somebody > who has the test instruments. > > A simple test would be to put it across a battery and let it charge up, > then remove it and measure the voltage stored in the capacitor. Should be > close to the battery's voltage. Mind you don't touch both terminals though, > as it is capable of dumping its charge quickly into your body, a trick I > recall being often employed in high school physics classes. > > A capacitor is a relatively simple device. In this application, it sits > across the DC supply from the alternator and regulator, where it smooths > out any remaining AC spikes that might otherwise show up as noise in your > radio or otherwise interfere with the proper operation of your avionics. > > On 13/01/2018 3:22 AM, Ken Ryan wrote: > > The terminals are fine. How would one know that a capacitor was not > working properly in a (for example) Rotax installation? I know some guys > don't even use the capacitor. > > On Thu, Jan 11, 2018 at 1:18 PM, Bill Maxwell > wrote: > >> Extremely unlikely to be damaged Ken, provided of course tthat the >> terminals weren't broken off. >> >> Bill >> >> On 12/01/2018 7:38 AM, Ken Ryan wrote: >> >> So yesterday I received my shiny new 33000 micro farad capacitor, for use >> with my Silent Hektik regulator. Within five minutes, I had managed to drop >> it from a height of three feet onto my hardwood floor. The floor is fine, >> but I wonder about the capacitor. How likely is it that it was damaged? How >> would such damage show up? >> >> Ken >> >> >> > > ________________________________________________________________________________
Date: Jan 13, 2018
Subject: Re: Testing Battery Capacity...
I said: "I've yet to test the battery I replaced it with." Bob N. said: "Would like to see that data . . ." I don't recall for sure but my best guess is the "new" (bought Dec '16) battery is a Duracell Ultra 18Ah. (whatever Batteries Plus was had as their generic 18AH AGM). I didn't removed it from the Longeze when I tested it today. It was 48 degreesF at the start of the test (and a few degrees colder at the end) and with my 3 Ohm load it ran for 3hr and 14 minutes. Steve. ________________________________________________________________________________
Date: Jan 14, 2018
At 08:44 PM 1/13/2018, you wrote: >I said: "I've yet to test the battery I replaced it with." > >Bob N. said: "Would like to see that data . . ." > >I don't recall for sure but my best guess is the >"new" (bought Dec '16) battery >is a Duracell Ultra 18Ah. =C2 (whatever Batteries Plus was had as their generic >18AH AGM). I didn't removed it from the Longeze when I tested it today. >It was 48 degreesF at the start of the test (and a few degrees colder at >the end) and with my 3 Ohm load it ran for 3hr and 14 minutes. Interesting. Okay 11.5v average/3 ohms yields ~3.8A for 3.25 hours is 12.4 A.H. According to the Enersys data on a PC680, the new battery supports about 4A for 3.2 hours Emacs! It would appear that your test article is pretty healthy. The only other variable is load dump ability. Given the cap-check data, I'd bet the load dump numbers are good too. Bob . . . ________________________________________________________________________________
Date: Jan 17, 2018
Subject: =?utf-8?B?4pyIRnc6IE1lcnJ5IENocmlzdG1hcyB0byBBbGwgYW5kIHRvIEFsbCBhIEdvb2QgRmxpZ2h0?
Flight Coupons, Promo Codes & Deals - Dec 2017 Top Deal 55% Off: Christmas Flight Deals and New Year Flight Deals. Call to Us and Get Discount Now 888-369-2751. (24/7 Suppor t.)
Enjoy Christmas Deals on American Airlines, Delta Air Line s, Southwest Airlines, United Airlines, Air Canada, JetBlue, Alaska A irlines, WestJet, Aeromexico, Spirit Airlines, Frontier Airlines, Vola ris, Hawaiian Airlines, Allegiant Air, Virgin America. Don't Miss These Handpicked Fares < td width="40%">Atlanta
Chicago-New York $175.01
Los Angeles-San Francisco$103. 89
Los Angeles- New York$175.20
Chicago-Los Angeles$325.56
Miami-New York $96.15
Atlanta-Chicago$100.09
New York City-Kingston$461.95
Los Angeles-Manila$654.18
-Orlando$90.25
Ch icago-Washington DC$195.94
New York City -Toronto$119.70
New York City-Paris$545.08< /td>
New York City-< /td>London$399.50
Call to Us and Get Discount Now 888-369-2751. ________________________________________________________________________________
Date: Jan 17, 2018
Subject: diode on starter contactor
My starter contactor's coil gets its ground through the contactor's metal case. Given that, does it make any sense to use a diode? If so, how would that diode be implemented and how would it remain effective when the case itself is the ground path? Ken ________________________________________________________________________________
Date: Jan 17, 2018
Subject: Re: diode on starter contactor
Wire it across the coil, so from non ground terminal to ground terminal, so its reverse polarized when the coil is energized. Then when power is removed, the magnetic field collapses driving current through the diode and avoiding a large back emf. If you put it the wrong way round, dont worry, it will just disappear. On Jan 17, 2018, at 18:56, Ken Ryan wrote: My starter contactor's coil gets its ground through the contactor's metal case. Given that, does it make any sense to use a diode? If so, how would that diode be implemented and how would it remain effective when the case itself is the ground path? Ken ________________________________________________________________________________
Date: Jan 17, 2018
An arc suppression diode should be connected directly across a coil. It is best if the diode is located at the coil. If that is impractical for some reason, then the diode can be located farther away as long as it is still connected in parallel with the coil. The banded end of the diode must be connected to the positive coil terminal and the other end of the diode connects to the negative terminal of the coil. If the coil is internally connected to the case, then the diode should be connected to the case or any convenient ground, assuming that the case is grounded. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477380#477380 ________________________________________________________________________________
Date: Jan 17, 2018
Alec, like I said in my original post, there is no ground terminal. Ground is accomplished through the metal case. On Wed, Jan 17, 2018 at 3:10 PM, Alec Myers wrote: > > Wire it across the coil, so from non ground terminal to ground terminal, > so it=99s reverse polarized when the coil is energized. Then when p ower is > removed, the magnetic field collapses driving current through the diode a nd > avoiding a large back emf. > > If you put it the wrong way round, don=99t worry, it will just disa ppear. > > > On Jan 17, 2018, at 18:56, Ken Ryan wrote: > > My starter contactor's coil gets its ground through the contactor's metal > case. Given that, does it make any sense to use a diode? If so, how would > that diode be implemented and how would it remain effective when the case > itself is the ground path? > > Ken > > =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Jan 17, 2018
Think of the contactor's mounting screw as the ground terminal (it actually *is* the ground terminal). So the banded end of the diode is connected to the control terminal, and the unbanded end is connected to one of the mounting screws. Or as others have said, any convenient grounded terminal nearby. Note that you can solder or crimp a short length of wire to either/both leads on the diode, and solder or crimp ring terminals to the wire, if the diode's leads aren't long enough to reach where they need to go. Just slip some heat shrink tubing, or even wire insulation stripped off a bigger wire, over the exposed leads as needed to keep the 'hot' end isolated from ground. On 1/17/2018 6:18 PM, Ken Ryan wrote: > Alec, like I said in my original post, there is no ground terminal. > Ground is accomplished through the metal case. > > On Wed, Jan 17, 2018 at 3:10 PM, Alec Myers > wrote: > > > > > Wire it across the coil, so from non ground terminal to ground > terminal, so its reverse polarized when the coil is energized. > Then when power is removed, the magnetic field collapses driving > current through the diode and avoiding a large back emf. > > If you put it the wrong way round, dont worry, it will just > disappear. > > > On Jan 17, 2018, at 18:56, Ken Ryan > wrote: > > My starter contactor's coil gets its ground through the > contactor's metal case. Given that, does it make any sense to use > a diode? If so, how would that diode be implemented and how would > it remain effective when the case itself is the ground path? > > Ken > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jan 17, 2018
Use the mounting bolt then, with a ring terminal under the bolt head. > On Jan 17, 2018, at 19:18, Ken Ryan wrote: > > Alec, like I said in my original post, there is no ground terminal. Ground is accomplished through the metal case. > >> On Wed, Jan 17, 2018 at 3:10 PM, Alec Myers wrote: >> >> Wire it across the coil, so from non ground terminal to ground terminal, s o it=99s reverse polarized when the coil is energized. Then when power is removed, the magnetic field collapses driving current through the diode a nd avoiding a large back emf. >> >> If you put it the wrong way round, don=99t worry, it will just disa ppear. >> >> >> >> On Jan 17, 2018, at 18:56, Ken Ryan wrote: >> >> My starter contactor's coil gets its ground through the contactor's metal case. Given that, does it make any sense to use a diode? If so, how would t hat diode be implemented and how would it remain effective when the case its elf is the ground path? >> >> Ken >> >> >> ========================= ============ >> - >> Electric-List" rel="noreferrer" target="_blank">http://www.matronics. com/Navigator?AeroElectric-List >> ========================= >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> ========================= >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> ========================= >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contributio n >> ========================= >> >> >> > ________________________________________________________________________________
Date: Jan 17, 2018
Thanks everyone. On Wed, Jan 17, 2018 at 3:35 PM, Alec Myers wrote: > Use the mounting bolt then, with a ring terminal under the bolt head. > > On Jan 17, 2018, at 19:18, Ken Ryan wrote: > > Alec, like I said in my original post, there is no ground terminal. Groun d > is accomplished through the metal case. > > On Wed, Jan 17, 2018 at 3:10 PM, Alec Myers wrote: > >> >> Wire it across the coil, so from non ground terminal to ground terminal, >> so it=99s reverse polarized when the coil is energized. Then when power is >> removed, the magnetic field collapses driving current through the diode and >> avoiding a large back emf. >> >> If you put it the wrong way round, don=99t worry, it will just dis appear. >> >> >> >> On Jan 17, 2018, at 18:56, Ken Ryan wrote: >> >> My starter contactor's coil gets its ground through the contactor's meta l >> case. Given that, does it make any sense to use a diode? If so, how woul d >> that diode be implemented and how would it remain effective when the cas e >> itself is the ground path? >> >> Ken >> >> >> ======================== ============= >> - >> Electric-List" rel="noreferrer" target="_blank">http://www.matronics .com/ >> Navigator?AeroElectric-List >> ======================== =========== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> ======================== =========== >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> ======================== =========== >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contributi on >> ======================== =========== >> >> >> >> > ________________________________________________________________________________
Date: Jan 17, 2018
I=99m trying to follow the diode and the starter sol. discussion. I mi ssed the reason for the diode. Thanks Bernie Sent from my iPhone > On Jan 17, 2018, at 4:38 PM, Ken Ryan wrote: > > Thanks everyone. > > >> On Wed, Jan 17, 2018 at 3:35 PM, Alec Myers wrote: >> Use the mounting bolt then, with a ring terminal under the bolt head. >> >>> On Jan 17, 2018, at 19:18, Ken Ryan wrote: >>> >>> Alec, like I said in my original post, there is no ground terminal. Grou nd is accomplished through the metal case. >>> >>>> On Wed, Jan 17, 2018 at 3:10 PM, Alec Myers wrote: > >>>> >>>> Wire it across the coil, so from non ground terminal to ground terminal , so it=99s reverse polarized when the coil is energized. Then when po wer is removed, the magnetic field collapses driving current through the dio de and avoiding a large back emf. >>>> >>>> If you put it the wrong way round, don=99t worry, it will just di sappear. >>>> >>>> >>>> >>>> On Jan 17, 2018, at 18:56, Ken Ryan wrote: >>>> >>>> My starter contactor's coil gets its ground through the contactor's met al case. Given that, does it make any sense to use a diode? If so, how would that diode be implemented and how would it remain effective when the case i tself is the ground path? >>>> >>>> Ken >>>> >>>> >>>> ============ >>>> - >>>> Electric-List" rel="noreferrer" target="_blank">http://www.matronic s.com/Navigator?AeroElectric-List >>>> ========== >>>> FORUMS - >>>> eferrer" target="_blank">http://forums.matronics.com >>>> ========== >>>> WIKI - >>>> errer" target="_blank">http://wiki.matronics.com >>>> ========== >>>> b Site - >>>> -Matt Dralle, List Admin. >>>> rel="noreferrer" target="_blank">http://www.matronics.com/contribut ion >>>> ========== >>>> >>>> >>>> >>> > ________________________________________________________________________________
Date: Jan 17, 2018
Bernie, As I understand it, when the solenoid is deenergized, a voltage surge peak passes through the circuit which ages the solenoid contacts. The diode prevents the passage of the surge current and lengthens the life of the solenoid contacts. The diode band end is connected to the positive side of the solenoid contractor and the other side of the diode is connected to ground at the solenoid. Bill > On Jan 17, 2018, at 20:49, Bernie wrote: > > I=99m trying to follow the diode and the starter sol. discussion. I missed the reason for the diode. > > Thanks > Bernie > > Sent from my iPhone > > On Jan 17, 2018, at 4:38 PM, Ken Ryan > wrote: > >> Thanks everyone. >> >> >> On Wed, Jan 17, 2018 at 3:35 PM, Alec Myers > wrote: >> Use the mounting bolt then, with a ring terminal under the bolt head. >> >> On Jan 17, 2018, at 19:18, Ken Ryan > wrote: >> >>> Alec, like I said in my original post, there is no ground terminal. Ground is accomplished through the metal case. >>> >>> On Wed, Jan 17, 2018 at 3:10 PM, Alec Myers > wrote: > >>> >>> Wire it across the coil, so from non ground terminal to ground terminal, so it=99s reverse polarized when the coil is energized. Then when power is removed, the magnetic field collapses driving current through the diode and avoiding a large back emf. >>> >>> If you put it the wrong way round, don=99t worry, it will just disappear. >>> >>> >>> >>> On Jan 17, 2018, at 18:56, Ken Ryan > wrote: >>> >>> My starter contactor's coil gets its ground through the contactor's metal case. Given that, does it make any sense to use a diode? If so, how would that diode be implemented and how would it remain effective when the case itself is the ground path? >>> >>> Ken >>> >>> >>> ============ >>> - >>> Electric-List" rel="noreferrer" target="_blank">http://www.matronics.com/ <http://www.matronics.com/>Navigator?AeroElectric-List >>> ========== >>> FORUMS - >>> eferrer" target="_blank">http://forums.matronics.com <http://forums.matronics.com/> >>> ========== >>> WIKI - >>> errer" target="_blank">http://wiki.matronics.com <http://wiki.matronics.com/> >>> ========== >>> b Site - >>> -Matt Dralle, List Admin. >>> rel="noreferrer" target="_blank">http://www.matronics.com/ <http://www.matronics.com/>contribution >>> ========== >>> >>> >>> >>> >> ________________________________________________________________________________
Date: Jan 17, 2018
Bill, That refinement to the traditional circuit makes sense. Is there any particular diode? Thanks, Bernie > On Jan 17, 2018, at 9:59 PM, Bill Bear wrote: > > Bernie, > > As I understand it, when the solenoid is deenergized, a voltage surge peak passes through the circuit which ages the solenoid contacts. The diode prevents the passage of the surge current and lengthens the life of the solenoid contacts. The diode band end is connected to the positive side of the solenoid contractor and the other side of the diode is connected to ground at the solenoid. > > Bill > > >> On Jan 17, 2018, at 20:49, Bernie > wrote: >> >> I=99m trying to follow the diode and the starter sol. discussion. I missed the reason for the diode. >> >> Thanks >> Bernie >> >> Sent from my iPhone >> >> On Jan 17, 2018, at 4:38 PM, Ken Ryan > wrote: >> >>> Thanks everyone. >>> >>> >>> On Wed, Jan 17, 2018 at 3:35 PM, Alec Myers > wrote: >>> Use the mounting bolt then, with a ring terminal under the bolt head. >>> >>> On Jan 17, 2018, at 19:18, Ken Ryan > wrote: >>> >>>> Alec, like I said in my original post, there is no ground terminal. Ground is accomplished through the metal case. >>>> >>>> On Wed, Jan 17, 2018 at 3:10 PM, Alec Myers > wrote: > >>>> >>>> Wire it across the coil, so from non ground terminal to ground terminal, so it=99s reverse polarized when the coil is energized. Then when power is removed, the magnetic field collapses driving current through the diode and avoiding a large back emf. >>>> >>>> If you put it the wrong way round, don=99t worry, it will just disappear. >>>> >>>> >>>> >>>> On Jan 17, 2018, at 18:56, Ken Ryan > wrote: >>>> >>>> My starter contactor's coil gets its ground through the contactor's metal case. Given that, does it make any sense to use a diode? If so, how would that diode be implemented and how would it remain effective when the case itself is the ground path? >>>> >>>> Ken >>>> >>>> >>>> ============ >>>> - >>>> Electric-List" rel="noreferrer" target="_blank">http://www.matronics.com/ <http://www.matronics.com/>Navigator?AeroElectric-List >>>> ========== >>>> FORUMS - >>>> eferrer" target="_blank">http://forums.matronics.com <http://forums.matronics.com/> >>>> ========== >>>> WIKI - >>>> errer" target="_blank">http://wiki.matronics.com <http://wiki.matronics.com/> >>>> ========== >>>> b Site - >>>> -Matt Dralle, List Admin. >>>> rel="noreferrer" target="_blank">http://www.matronics.com/ <http://www.matronics.com/>contribution >>>> ========== >>>> >>>> >>>> >>>> >>> > ________________________________________________________________________________
Date: Jan 18, 2018
Inductors (a solenoid coil is a good example of a large inductor) resist sudden changes in current flowing through them. When you energize the solenoid the current through the coil grows slowly to its maximum value. When you break the circuit with the switch you are forcing a sudden change in current, which causes a massive voltage spike. In the microseconds after the switch contact breaks the gap at the switch contacts is narrow enough, and the voltage rise at the inductor is big enough, to cause arcing and contact damage in the switch. The diode allows the current in the coil to continue to flow after the switch contact is broken by completing the circuit from the ground terminal of the coil back to the now-disconnected other terminal. (A diagram should make this clearer). No sudden change in current means no sudden voltage rise and no possibility of arcing. The energy to drive the continuing current flow through the coil after the battery power has been removed from the solenoid terminal comes from the energy stored in the magnetic field. As the field collapses the current drops to zero. On Jan 18, 2018, at 1:59 AM, Bill Bear wrote: Bernie, As I understand it, when the solenoid is deenergized, a voltage surge peak passes through the circuit which ages the solenoid contacts. The diode prevents the passage of the surge current and lengthens the life of the solenoid contacts. The diode band end is connected to the positive side of the solenoid contractor and the other side of the diode is connected to ground at the solenoid. Bill > On Jan 17, 2018, at 20:49, Bernie wrote: > > Im trying to follow the diode and the starter sol. discussion. I missed the reason for the diode. > > Thanks > Bernie > > Sent from my iPhone > > On Jan 17, 2018, at 4:38 PM, Ken Ryan wrote: > >> Thanks everyone. >> >> >> On Wed, Jan 17, 2018 at 3:35 PM, Alec Myers wrote: >> Use the mounting bolt then, with a ring terminal under the bolt head. >> >> On Jan 17, 2018, at 19:18, Ken Ryan wrote: >> >>> Alec, like I said in my original post, there is no ground terminal. Ground is accomplished through the metal case. >>> >>> On Wed, Jan 17, 2018 at 3:10 PM, Alec Myers wrote: >>> >>> Wire it across the coil, so from non ground terminal to ground terminal, so its reverse polarized when the coil is energized. Then when power is removed, the magnetic field collapses driving current through the diode and avoiding a large back emf. >>> >>> If you put it the wrong way round, dont worry, it will just disappear. >>> >>> >>> >>> On Jan 17, 2018, at 18:56, Ken Ryan wrote: >>> >>> My starter contactor's coil gets its ground through the contactor's metal case. Given that, does it make any sense to use a diode? If so, how would that diode be implemented and how would it remain effective when the case itself is the ground path? >>> >>> Ken >>> >>> >>> ============ >>> - >>> Electric-List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List >>> ========== >>> FORUMS - >>> eferrer" target="_blank">http://forums.matronics.com >>> ========== >>> WIKI - >>> errer" target="_blank">http://wiki.matronics.com >>> ========== >>> b Site - >>> -Matt Dralle, List Admin. >>> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >>> ========== >>> >>> >>> >>> >> ________________________________________________________________________________
Date: Jan 18, 2018
Heres a really excellent video by a guy named Alan Wolke (an applications engineer at Tektronix) that explains back-EMF in inductive circuits and the function of snubber or flyback diodes. https://www.youtube.com/watch?v=c6I7Ycbv8B8 As you watch this, keep in mind that Alan is using a small signal relay with a relatively tiny coil that operates on a few tens of milliamps. Then consider the typical starter solenoid: it should be obvious that the potential (pardon the pun) for large voltage spikes is amplified by the physical size of its coil and large current that it consumes in operation. Eric Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477413#477413 ________________________________________________________________________________
Date: Jan 18, 2018
I really appreciate the discussion on the theory. Also found this issue discussed in Aero Connection. I have an old Bonanza that occasionally produces a chattering sound when the master/battery switch in turned on. Now I suspect it is the master solenoid contacts showing signs of failure. A new solenoid is in order but the diode protection seems in order also. A little research shows diodes available in many voltage, capacitance and temperature rating, anything from .07 to $300. What are the parameters of an appropriate diode to protect a 12 volt master or starter solenoid? Bernie > On Jan 18, 2018, at 4:41 AM, Alec Myers wrote: > > > Inductors (a solenoid coil is a good example of a large inductor) resist sudden changes in current flowing through them. When you energize the solenoid the current through the coil grows slowly to its maximum value. When you break the circuit with the switch you are forcing a sudden change in current, which causes a massive voltage spike. In the microseconds after the switch contact breaks the gap at the switch contacts is narrow enough, and the voltage rise at the inductor is big enough, to cause arcing and contact damage in the switch. > > The diode allows the current in the coil to continue to flow after the switch contact is broken by completing the circuit from the ground terminal of the coil back to the now-disconnected other terminal. (A diagram should make this clearer). No sudden change in current means no sudden voltage rise and no possibility of arcing. > > The energy to drive the continuing current flow through the coil after the battery power has been removed from the solenoid terminal comes from the energy stored in the magnetic field. As the field collapses the current drops to zero. > > On Jan 18, 2018, at 1:59 AM, Bill Bear wrote: > > Bernie, > > As I understand it, when the solenoid is deenergized, a voltage surge peak passes through the circuit which ages the solenoid contacts. The diode prevents the passage of the surge current and lengthens the life of the solenoid contacts. The diode band end is connected to the positive side of the solenoid contractor and the other side of the diode is connected to ground at the solenoid. > > Bill > > >> On Jan 17, 2018, at 20:49, Bernie wrote: >> >> Im trying to follow the diode and the starter sol. discussion. I missed the reason for the diode. >> >> Thanks >> Bernie >> >> Sent from my iPhone >> >> On Jan 17, 2018, at 4:38 PM, Ken Ryan wrote: >> >>> Thanks everyone. >>> >>> >>> On Wed, Jan 17, 2018 at 3:35 PM, Alec Myers wrote: >>> Use the mounting bolt then, with a ring terminal under the bolt head. >>> >>> On Jan 17, 2018, at 19:18, Ken Ryan wrote: >>> >>>> Alec, like I said in my original post, there is no ground terminal. Ground is accomplished through the metal case. >>>> >>>> On Wed, Jan 17, 2018 at 3:10 PM, Alec Myers wrote: >>>> >>>> Wire it across the coil, so from non ground terminal to ground terminal, so its reverse polarized when the coil is energized. Then when power is removed, the magnetic field collapses driving current through the diode and avoiding a large back emf. >>>> >>>> If you put it the wrong way round, dont worry, it will just disappear. >>>> >>>> >>>> >>>> On Jan 17, 2018, at 18:56, Ken Ryan wrote: >>>> >>>> My starter contactor's coil gets its ground through the contactor's metal case. Given that, does it make any sense to use a diode? If so, how would that diode be implemented and how would it remain effective when the case itself is the ground path? >>>> >>>> Ken >>>> >>>> >>>> ============ >>>> - >>>> Electric-List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List >>>> ========== >>>> FORUMS - >>>> eferrer" target="_blank">http://forums.matronics.com >>>> ========== >>>> WIKI - >>>> errer" target="_blank">http://wiki.matronics.com >>>> ========== >>>> b Site - >>>> -Matt Dralle, List Admin. >>>> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >>>> ========== >>>> >>>> >>>> >>>> >>> > > > > > > ________________________________________________________________________________
Date: Jan 18, 2018
A ten cent 1N4001 is just fine. Voltage refers to a safe reverse voltage limit before avalanche breakdown: the coil diode is only reverse biased to 12V. A 1N4001 is rated to 50V. Current rating: somewhat irrelevant, since theres no sustained current load. A 1N4001 is good for up to 1A continuous, and 30A surge. Neither limit will be close to met in this application. Capacitance: refers to the junction capacitance when reverse biased. Irrelevant in this application. Physical package: anything big enough to solder easily will have enough thermal mass to absorb what little energy is stored in the coil magnetic field. On Jan 18, 2018, at 12:26 PM, Bernie Willis wrote: I really appreciate the discussion on the theory. Also found this issue discussed in Aero Connection. I have an old Bonanza that occasionally produces a chattering sound when the master/battery switch in turned on. Now I suspect it is the master solenoid contacts showing signs of failure. A new solenoid is in order but the diode protection seems in order also. A little research shows diodes available in many voltage, capacitance and temperature rating, anything from .07 to $300. What are the parameters of an appropriate diode to protect a 12 volt master or starter solenoid? Bernie > On Jan 18, 2018, at 4:41 AM, Alec Myers wrote: > > > Inductors (a solenoid coil is a good example of a large inductor) resist sudden changes in current flowing through them. When you energize the solenoid the current through the coil grows slowly to its maximum value. When you break the circuit with the switch you are forcing a sudden change in current, which causes a massive voltage spike. In the microseconds after the switch contact breaks the gap at the switch contacts is narrow enough, and the voltage rise at the inductor is big enough, to cause arcing and contact damage in the switch. > > The diode allows the current in the coil to continue to flow after the switch contact is broken by completing the circuit from the ground terminal of the coil back to the now-disconnected other terminal. (A diagram should make this clearer). No sudden change in current means no sudden voltage rise and no possibility of arcing. > > The energy to drive the continuing current flow through the coil after the battery power has been removed from the solenoid terminal comes from the energy stored in the magnetic field. As the field collapses the current drops to zero. > > On Jan 18, 2018, at 1:59 AM, Bill Bear wrote: > > Bernie, > > As I understand it, when the solenoid is deenergized, a voltage surge peak passes through the circuit which ages the solenoid contacts. The diode prevents the passage of the surge current and lengthens the life of the solenoid contacts. The diode band end is connected to the positive side of the solenoid contractor and the other side of the diode is connected to ground at the solenoid. > > Bill > > >> On Jan 17, 2018, at 20:49, Bernie wrote: >> >> Im trying to follow the diode and the starter sol. discussion. I missed the reason for the diode. >> >> Thanks >> Bernie >> >> Sent from my iPhone >> >> On Jan 17, 2018, at 4:38 PM, Ken Ryan wrote: >> >>> Thanks everyone. >>> >>> >>> On Wed, Jan 17, 2018 at 3:35 PM, Alec Myers wrote: >>> Use the mounting bolt then, with a ring terminal under the bolt head. >>> >>> On Jan 17, 2018, at 19:18, Ken Ryan wrote: >>> >>>> Alec, like I said in my original post, there is no ground terminal. Ground is accomplished through the metal case. >>>> >>>> On Wed, Jan 17, 2018 at 3:10 PM, Alec Myers wrote: >>>> >>>> Wire it across the coil, so from non ground terminal to ground terminal, so its reverse polarized when the coil is energized. Then when power is removed, the magnetic field collapses driving current through the diode and avoiding a large back emf. >>>> >>>> If you put it the wrong way round, dont worry, it will just disappear. >>>> >>>> >>>> >>>> On Jan 17, 2018, at 18:56, Ken Ryan wrote: >>>> >>>> My starter contactor's coil gets its ground through the contactor's metal case. Given that, does it make any sense to use a diode? If so, how would that diode be implemented and how would it remain effective when the case itself is the ground path? >>>> >>>> Ken >>>> >>>> >>>> ============ >>>> - >>>> Electric-List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List >>>> ========== >>>> FORUMS - >>>> eferrer" target="_blank">http://forums.matronics.com >>>> ========== >>>> WIKI - >>>> errer" target="_blank">http://wiki.matronics.com >>>> ========== >>>> b Site - >>>> -Matt Dralle, List Admin. >>>> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >>>> ========== >>>> >>>> >>>> >>>> >>> > > > > > > ________________________________________________________________________________
Date: Jan 18, 2018
Alec, That was a quick reply! Now I can proceed. Thanks, Bernie > On Jan 18, 2018, at 8:49 AM, Alec Myers wrote: > > > A ten cent 1N4001 is just fine. > > Voltage refers to a safe reverse voltage limit before avalanche breakdown: the coil diode is only reverse biased to 12V. A 1N4001 is rated to 50V. > Current rating: somewhat irrelevant, since theres no sustained current load. A 1N4001 is good for up to 1A continuous, and 30A surge. Neither limit will be close to met in this application. > Capacitance: refers to the junction capacitance when reverse biased. Irrelevant in this application. > Physical package: anything big enough to solder easily will have enough thermal mass to absorb what little energy is stored in the coil magnetic field. > > > > > > On Jan 18, 2018, at 12:26 PM, Bernie Willis wrote: > > > I really appreciate the discussion on the theory. Also found this issue discussed in Aero Connection. I have an old Bonanza that occasionally produces a chattering sound when the master/battery switch in turned on. Now I suspect it is the master solenoid contacts showing signs of failure. A new solenoid is in order but the diode protection seems in order also. A little research shows diodes available in many voltage, capacitance and temperature rating, anything from .07 to $300. What are the parameters of an appropriate diode to protect a 12 volt master or starter solenoid? > > Bernie > >> On Jan 18, 2018, at 4:41 AM, Alec Myers wrote: >> >> >> Inductors (a solenoid coil is a good example of a large inductor) resist sudden changes in current flowing through them. When you energize the solenoid the current through the coil grows slowly to its maximum value. When you break the circuit with the switch you are forcing a sudden change in current, which causes a massive voltage spike. In the microseconds after the switch contact breaks the gap at the switch contacts is narrow enough, and the voltage rise at the inductor is big enough, to cause arcing and contact damage in the switch. >> >> The diode allows the current in the coil to continue to flow after the switch contact is broken by completing the circuit from the ground terminal of the coil back to the now-disconnected other terminal. (A diagram should make this clearer). No sudden change in current means no sudden voltage rise and no possibility of arcing. >> >> The energy to drive the continuing current flow through the coil after the battery power has been removed from the solenoid terminal comes from the energy stored in the magnetic field. As the field collapses the current drops to zero. >> >> On Jan 18, 2018, at 1:59 AM, Bill Bear wrote: >> >> Bernie, >> >> As I understand it, when the solenoid is deenergized, a voltage surge peak passes through the circuit which ages the solenoid contacts. The diode prevents the passage of the surge current and lengthens the life of the solenoid contacts. The diode band end is connected to the positive side of the solenoid contractor and the other side of the diode is connected to ground at the solenoid. >> >> Bill >> >> >>> On Jan 17, 2018, at 20:49, Bernie wrote: >>> >>> Im trying to follow the diode and the starter sol. discussion. I missed the reason for the diode. >>> >>> Thanks >>> Bernie >>> >>> Sent from my iPhone >>> >>> On Jan 17, 2018, at 4:38 PM, Ken Ryan wrote: >>> >>>> Thanks everyone. >>>> >>>> >>>> On Wed, Jan 17, 2018 at 3:35 PM, Alec Myers wrote: >>>> Use the mounting bolt then, with a ring terminal under the bolt head. >>>> >>>> On Jan 17, 2018, at 19:18, Ken Ryan wrote: >>>> >>>>> Alec, like I said in my original post, there is no ground terminal. Ground is accomplished through the metal case. >>>>> >>>>> On Wed, Jan 17, 2018 at 3:10 PM, Alec Myers wrote: >>>>> >>>>> Wire it across the coil, so from non ground terminal to ground terminal, so its reverse polarized when the coil is energized. Then when power is removed, the magnetic field collapses driving current through the diode and avoiding a large back emf. >>>>> >>>>> If you put it the wrong way round, dont worry, it will just disappear. >>>>> >>>>> >>>>> >>>>> On Jan 17, 2018, at 18:56, Ken Ryan wrote: >>>>> >>>>> My starter contactor's coil gets its ground through the contactor's metal case. Given that, does it make any sense to use a diode? If so, how would that diode be implemented and how would it remain effective when the case itself is the ground path? >>>>> >>>>> Ken >>>>> >>>>> >>>>> ============ >>>>> - >>>>> Electric-List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List >>>>> ========== >>>>> FORUMS - >>>>> eferrer" target="_blank">http://forums.matronics.com >>>>> ========== >>>>> WIKI - >>>>> errer" target="_blank">http://wiki.matronics.com >>>>> ========== >>>>> b Site - >>>>> -Matt Dralle, List Admin. >>>>> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >>>>> ========== >>>>> >>>>> >>>>> >>>>> >>>> >> >> >> >> >> >> > > > > > > > > > > ________________________________________________________________________________
Date: Jan 18, 2018
At 11:49 PM 1/17/2018, you wrote: >I=99m trying to follow the diode and the starter >sol. discussion. I missed the reason for the diode. We've had several discussions on spike-suppression diodes on relays and contactors over the years. One of the first was prompted by a snafu over an airworthiness directive against the ACS/Gerdes off-left-right-on-start key switches. Seems the inductive spike fire generated by relatively high coil current of some starter contactors was eating up the start contact in the key switch. Here's one example of a OEM aircafter's response to the AD. https://goo.gl/1XvDtj This was the CORRECT way to install the diode . . . the AD also called for refurbishment of the start switch contacts within the keyswitch. Here's background on the physics for proper placement of the diode. https://goo.gl/WUS1Ya The problem would get potentially worse when lightweight starters started showing up. Still more stress on the switch was a function of a two-stage engagement scenario which impressed a much larger engagement inrush current compared to legacy starter contactors. Here's the background. https://goo.gl/opeqsM Later in the discussions, there was consternation about how 'inadvised' configuration of spike suppression would cause the contactor's points to open more slowly and exacerbate contact wear. The assertion was predicated on an article published by Potter-Brumfield https://goo.gl/iCrqch The author asserts that a diode connected right across the contactor/relay coil results in significantly slower contact opening velocity. This prompted a trip to the workbench to explore the physics: https://goo.gl/KNTr8y For our purposes, the diode was demonstrated to effect a DELAY in contact first opening . . . but once the contacts started to move, the AIR GAP in the magnetic circuit had a much more profound effect on opening velocity than did the slower decay of current in the contactor coil. The short answer is that adding a plain-jane diode across the coil of any relay or contactor in the airplane will not noticeably affect service life of that device. The diode improves service life of the SWITCH THAT CONTROLS THE CONTACTOR. Further, contactor coils do not propagate spikes onto the system looking for vulnerable solid state electronics to fry. Bob . . . ________________________________________________________________________________
Date: Jan 18, 2018
At 11:49 AM 1/18/2018, you wrote: > >A ten cent 1N4001 is just fine. > >Voltage refers to a safe reverse voltage limit >before avalanche breakdown: the coil diode is >only reverse biased to 12V. A 1N4001 is rated to 50V. >Current rating: somewhat irrelevant, since >there=99s no sustained current load. A 1N4001 is >good for up to 1A continuous, and 30A surge. >Neither limit will be close to met in this application. Absolutely correct. My personal favorites are the 1N5400 series devices, NOT for their electrical ratings but for mechanical robustness. Example: https://goo.gl/2CGXgf Bob . . . ________________________________________________________________________________
Date: Jan 18, 2018
On 1/18/2018 12:13 PM, Robert L. Nuckolls, III wrote: > At 11:49 AM 1/18/2018, you wrote: >> >> A ten cent 1N4001 is just fine. >> >> Voltage refers to a safe reverse voltage limit before avalanche >> breakdown: the coil diode is only reverse biased to 12V. A 1N4001 is >> rated to 50V. >> Current rating: somewhat irrelevant, since theres no sustained >> current load. A 1N4001 is good for up to 1A continuous, and 30A >> surge. Neither limit will be close to met in this application. > > Absolutely correct. My personal favorites > are the 1N5400 series devices, NOT for their > electrical ratings but for mechanical > robustness. Example: > > https://goo.gl/2CGXgf > > > Bob . . . > And, while I haven't priced the 5400 series, the 4000 series prices used to be virtually identical from 4001 to 4007 (1KV rating). Not that you'd need it for this application, but when I repaired electrons for a living, we just stocked the 07s because they work for everything at that current rating. --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jan 18, 2018
>> when the solenoid is de-energized, a voltage surge peak passes through the circuit which ages the solenoid contacts. The diode prevents the passage of the surge current and lengthens the life of the solenoid contacts. For an abundance of clarity, the diode across the coil terminals does NOT protect the solenoid's contacts. It protects instead the switch contacts of whatever switch controls that solenoid coil: the starter switch for the starter contactor; the master switch contacts for the master contactor. Paul ________________________________________________________________________________
Date: Jan 18, 2018
>> Bob . . . >And, while I haven't priced the 5400 series, the 4000 series prices >used to be virtually identical from 4001 to 4007 (1KV rating). Not >that you'd need it for this application, but when I repaired >electrons for a living, we just stocked the 07s because they work >for everything at that current rating. Astute observation. I've not confirmed this with a real diode-maker person but . . . I was working at a nuclear fuels manufacturing company in Apollo, PA where a colleague asserted that variously rated diodes were all made on the same line. They were screened for breakdown voltage looking first for devices that would function as 1000 volt devices. When the order for 007 parts was 'filled', the next screen was for the lower voltage part with the lowest breakdown would be marked 000. Over the years, production variability went down to the point where virtually all parts would make the cut for 1kV parts. But rather than upset the legacy apple-cart, they continued to market the lower voltage part numbers . . . which were in fact 1 kV devices. Somewhere around here I've got a 2 kV power supply. It would be interesting to see just how far one can push the modern LV parts . . . but that ain't happ'ng soon . . . Bob . . . ________________________________________________________________________________
Date: Jan 18, 2018
This subject has been discussed here for years. My opinion and what I have suggested for years is that the current best practice is to use bidirectional zener diodes. Regular diodes are problematic. See attached. You can use what I suggest or slightly heavier ones for better mechanical properties. (I am currently shipping the 5KE20CA parts). Eric M. Jones -Bought a 177RG Cardinal. ________________________________________________________________________________
Date: Jan 18, 2018
Eric, I see great marketing (FUD) in that document but no actual information. What do you believe to be the problem with a regular diode? On Jan 18, 2018, at 4:38 PM, Eric Jones wrote: This subject has been discussed here for years. My opinion and what I have suggested for years is that the current best practice is to use bidirectional zener diodes. Regular diodes are problematic. See attached. You can use what I suggest or slightly heavier ones for better mechanical properties. (I am currently shipping the 5KE20CA parts). Eric M. Jones -Bought a 177RG Cardinal. ________________________________________________________________________________
Date: Jan 18, 2018
Eric, is it okay to solder a wire to your snapjacks? On Thu, Jan 18, 2018 at 12:38 PM, Eric Jones wrote: > This subject has been discussed here for years. > > My opinion and what I have suggested for years is that the current best > practice is to use bidirectional zener diodes. Regular diodes are > problematic. See attached. > > You can use what I suggest or slightly heavier ones for better mechanical > properties. (I am currently shipping the 5KE20CA parts). > > Eric M. Jones > > -Bought a 177RG Cardinal. > > ________________________________________________________________________________
Date: Jan 18, 2018
At 03:38 PM 1/18/2018, you wrote: >This subject has been discussed here for years. > >My opinion and what I have suggested for years is that the current >best practice is to use bidirectional zener diodes. Regular diodes >are problematic. See attached. Emacs! Can you demonstrate this? "Excessive" is non-quantified. Was my bench top study flawed in some way? Bob . . . ________________________________________________________________________________
Date: Jan 18, 2018
Im trying to work out why a diode has *any* significant effect on release time compared to a tranzorb or similar, and if it did, why you might care. Also, why should it have any effect on relay life reduction ? My skeptical self needs help to get beyond merely more expensive therefore must be better. On Jan 18, 2018, at 5:01 PM, Robert L. Nuckolls, III wrote: At 03:38 PM 1/18/2018, you wrote: > This subject has been discussed here for years. > > My opinion and what I have suggested for years is that the current best practice is to use bidirectional zener diodes. Regular diodes are problematic. See attached. Can you demonstrate this? "Excessive" is non-quantified. Was my bench top study flawed in some way? Bob . . . ________________________________________________________________________________
Date: Jan 18, 2018
A capacitor opposes any change in voltage. An inductor (coil) opposes any change in current. When the switch is closed (Figure 1), positive current flows from left to right through the coil. The diode does not conduct because positive current can not flow against the arrow. _ When the switch is opened (Figure 2), the coil opposes any change and tries to maintain the current. The coil is no longer a load. The coil is now a source, like a battery. Induced current still flows in the same direction through the coil from left to right. But the polarity has changed because because the coil is now a source, not a load. The diode now conducts because positive on the right side flows with the arrow. Current always tries to return to the source, the coil in this case. It takes the path of least resistance, which is through the diode, not across the open switch contacts. The induced voltage is limited to the forward voltage drop across the diode. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477433#477433 Attachments: http://forums.matronics.com//files/inductor__213.jpg ________________________________________________________________________________
Date: Jan 18, 2018
Last year I put a lighter AGM battery in my aircraft and moved it to the firewall along with the master contactor and made some new diodes for the contactors (one was broken). Saved about 4 pounds in wiring alone! Only problem afterwards was that if the battery was even slightly down sometimes the starter would turn a split second and then nothing. Repeated attempts usually ended up with the starter eventually running fine until the engine started. Putting a voltmeter on the starter confirmed that the problem was a lack of power to the starter, not the starter itself. I had a battery problem later on and replaced the battery, no change. Thinking I had messed up the starter contactor while tightening nuts on it I swapped it out, no change. At this point I started to suspect my diode so I disconnected it: Problem gone! I suspect I installed it backwards. Going to make the new one with clear shrinkwrap tubing so it can't happen again. On Thu, Jan 18, 2018 at 2:37 PM, Alec Myers wrote: > > I=99m trying to work out why a diode has *any* significant effect o n release > time compared to a tranzorb or similar, and if it did, why you might care . > Also, why should it have any effect on relay life reduction ? > > My skeptical self needs help to get beyond merely =9Cmore expensive > therefore must be better=9D. > > > On Jan 18, 2018, at 5:01 PM, Robert L. Nuckolls, III < > nuckolls.bob(at)aeroelectric.com> wrote: > > At 03:38 PM 1/18/2018, you wrote: > > This subject has been discussed here for years. > > > > My opinion and what I have suggested for years is that the current best > practice is to use bidirectional zener diodes. Regular diodes are > problematic. See attached. > > > > Can you demonstrate this? "Excessive" is non-quantified. > Was my bench top study flawed in some way? > > > Bob . . . > > =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Jan 19, 2018
At 04:37 PM 1/18/2018, you wrote: > >I=99m trying to work out why a diode has *any* >significant effect on release time compared to a >tranzorb or similar, and if it did, why you might care. >Also, why should it have any effect on relay life reduction =85? >My skeptical self needs help to get beyond >merely =9Cmore expensive therefore must be better=9D. When mechanical contacts are opened, an electric arc forms in the air gap. With low voltages and currents, the fire may be small, but it is never zero. In one of my articles, I mentioned and experiment when a microswitch was biased up with a dry cell and resistor. The contacts were observed through a microscope in the dark (the side was opened up on the switch for the experiment). Even at these very low power levels, a BLUE arc could be observed. The temperature of blue is HOT. This suggests that no matter what the power level, every opening even will transfer molecules of metal between contacts. Again, not a lot of metal but never zero. As energy levels go up and particularly at higher voltages, the intensity and DURATION of the arcing event increases. This is an expected condition. Relays are designed to meet life cycle ratings at specific power levels and circuit characteristics by adjusting contact material, closing forces, opening velocities, opening gaps, etc. Conditions are important . . . switches and relays will have AC, DC and LAMP ratings applied to their service life limits. https://goo.gl/CPtPYJ If you've ever tried to do any stick-welding, you understand the need for (1) making initial cold contact, (2) breaking that contact to form an arc, then maintaining an optimum distance between rod and work-piece to achieve a SUSTAINED fire at a temperature conducive to the TRANSFER of metal from rod to work-piece. If the contacts of a switch or relay do not spread fast enough, wide enough and with sufficient thermal mass in contacts, then the TRANSFER of metal will exceed that which meets design goals for service life. This lays the groundwork for a notion that relay contacts will accelerate open at some rate which is a function of spring, mass and decay of the magnetic field which was originally applied to close the contacts. It's easily demonstrated that rate of decay for this magnetic field is strongly influenced by the choice of suppression for energy stored in the coil at the time it is de-energized. A totally open-circuit coil is the fastest, but transient voltage during field collapse is greatest. You can drive a coil with a current limited source and the throw a dead short across the coil, reducing its excitation current to zero thus initiating the contact opening sequence. In this condition, the field collapse transient voltage will be zero and time to decay will be a whole lot longer. Hence, there is a range of decay rates offered by the array of suppression techniques. I've have yet to discover a paper that describes the behavior of relay magnetic holding force in detail . . . many papers that jump to an 'obvious' conclusion that if decay rate in the coil is extended by factors of 10 or more, then opening velocity of the contacts is similarly depressed. What I observed (in 45 years of herding electrons in airplanes and conducting numerous relay and switch failure studies) is that as a relay closes, the CONTACTS CLOSE before the magnetic armature BOTTOMS OUT. There is a spring rate associated with this extra motion that sets the contact closed holding force. This leads us to the idea that as the magnetic field in the device decays, there is a period of time from first motion the of armature off the bottomed-out position until closing force on the contacts drops to zero and they begin to move. This means that there is a GROWING AIR GAP in the magnetic circuit holding the contacts closed. This air gap has a profound suppressing effect on that magnetic force. It's an effect that grossly over-rides the decay rate of the magnetic from the coil. Magnetic decay rate does indeed affect drop-out time for the relay . . . this was demonstrated in the data collected during my bench-top experiments. Decay rate adds a time delay between de-energizing of the coil and first opening of the contacts. However, by the time the contacts see first motion, the magnetic air gap is established and growing. The air gap has much more control over contact acceleration than does coil current. Hence, the duration of arc between spreading contacts showed only a slight difference between diode-suppressed and non-suppressed contactor. The case for 'supper suppressors' is further weakened by the fact that starter and battery contactors on our airplanes are considered very busy if they get a few operations per week. The average light aircraft flies 50 hours a year. If you install switches and relay rated for tens of thousands of operations, it stands to reason that benefits gained by going-the-extra-mile on coil suppression yields no measurable benefit. Then, there is the study of contact erosion during closure as influenced by the physics of the switched circuit. This is due to arcing that occurs during contact BOUNCE. Many closures and openings per operation . . . much smaller gap during the bounce . . . but exceedingly unfriendly to relay life under some conditions. But that's a totally different story . . . Bob . . . ________________________________________________________________________________
Date: Jan 19, 2018
At 07:09 PM 1/18/2018, you wrote: >Last year I put a lighter AGM battery in my aircraft and moved it to >the firewall along with the master contactor and made some new >diodes for the contactors (one was broken). Saved about 4 pounds in >wiring alone! Only problem afterwards was that if the battery was >even slightly down sometimes the starter would turn a split second >and then nothing. Repeated attempts usually ended up with the >starter eventually running fine until the engine started. Putting a >voltmeter on the starter confirmed that the problem was a lack of >power to the starter, not the starter itself. I had a battery >problem later on and replaced the battery, no change. Thinking I had >messed up the starter contactor while tightening nuts on it I >swapped it out, no change. At this point I started to suspect my >diode so I disconnected it: Problem gone! I suspect I installed it >backwards. Going to make the new one with clear shrinkwrap tubing so >it can't happen again. If your diode is installed backwards, it will conduct HARD while the starter button is depressed. Plastic diodes generally smoke for a few seconds and split, some will literally explode. I've seen a few cases where they simply fused short and tripped the starter control circuit breaker. If removing the diode cured your problem, then it probably was 'backwards'. Do you have a breaker or fuse on your starter control line? That shorted condition should have opened the circuit protection. Bob . . . ________________________________________________________________________________
Date: Jan 19, 2018
I'm confused. It seems like you are now saying that because the relays are rated for far more cycles than they will ever see, there is no reason to bother with diodes. Sent from my Android. Sorry Steve. On Jan 19, 2018 7:06 AM, "Robert L. Nuckolls, III" < nuckolls.bob(at)aeroelectric.com> wrote: > At 04:37 PM 1/18/2018, you wrote: > > > I=C3=A2=82=AC=84=A2m trying to work out why a diode has *any* signi ficant effect on > release time compared to a tranzorb or similar, and if it did, why you > might care. > Also, why should it have any effect on relay life reduction ? > My skeptical self needs help to get beyond merely =C3=A2=82=AC=C5=93mo re expensive > therefore must be better=C3=A2=82=AC . > > > When mechanical contacts are opened, an electric > arc forms in the air gap. With low voltages and > currents, the fire may be small, but it is never > zero. In one of my articles, I mentioned and experiment > when a microswitch was biased up with a dry cell > and resistor. The contacts were observed > through a microscope in the dark (the side was opened > up on the switch for the experiment). > > Even at these very low power levels, a BLUE arc > could be observed. The temperature of blue is > HOT. This suggests that no matter what the power > level, every opening even will transfer molecules > of metal between contacts. > > Again, not a lot of metal but never zero. > > As energy levels go up and particularly > at higher voltages, the intensity and DURATION > of the arcing event increases. This is an expected > condition. Relays are designed to meet life cycle > ratings at specific power levels and circuit > characteristics by adjusting contact material, > closing forces, opening velocities, opening > gaps, etc. Conditions are important . . . switches > and relays will have AC, DC and LAMP ratings > applied to their service life limits. > > https://goo.gl/CPtPYJ > > If you've ever tried to do any stick-welding, you > understand the need for (1) making initial cold > contact, (2) breaking that contact to form an > arc, then maintaining an optimum distance between > rod and work-piece to achieve a SUSTAINED fire > at a temperature conducive to the TRANSFER > of metal from rod to work-piece. > > If the contacts of a switch or relay do not spread > fast enough, wide enough and with sufficient > thermal mass in contacts, then the TRANSFER of > metal will exceed that which meets design goals > for service life. > > This lays the groundwork for a notion that relay > contacts will accelerate open at some rate which is > a function of spring, mass and decay of the > magnetic field which was originally applied to > close the contacts. > > It's easily demonstrated that rate of decay for > this magnetic field is strongly influenced by > the choice of suppression for energy stored in > the coil at the time it is de-energized. > > A totally open-circuit coil is the fastest, but > transient voltage during field collapse is greatest. > You can drive a coil with a current limited source > and the throw a dead short across the coil, reducing > its excitation current to zero thus initiating > the contact opening sequence. In this condition, > the field collapse transient voltage will be zero > and time to decay will be a whole lot longer. > Hence, there is a range of decay rates offered by > the array of suppression techniques. > > I've have yet to discover a paper that describes > the behavior of relay magnetic holding force > in detail . . . many papers that jump to an > 'obvious' conclusion that if decay rate in > the coil is extended by factors of 10 or more, > then opening velocity of the contacts is similarly > depressed. > > What I observed (in 45 years of herding electrons > in airplanes and conducting numerous relay and > switch failure studies) is that as a relay closes, > the CONTACTS CLOSE before the magnetic armature > BOTTOMS OUT. There is a spring rate associated > with this extra motion that sets the contact > closed holding force. > > This leads us to the idea that as the magnetic > field in the device decays, there is a period > of time from first motion the of armature off > the bottomed-out position until closing force > on the contacts drops to zero and they begin > to move. This means that there is a GROWING > AIR GAP in the magnetic circuit holding the > contacts closed. > > This air gap has a profound suppressing effect > on that magnetic force. It's an effect that > grossly over-rides the decay rate of the magnetic > from the coil. > > Magnetic decay rate does indeed affect drop-out > time for the relay . . . this was demonstrated in > the data collected during my bench-top experiments. > Decay rate adds a time delay between de-energizing > of the coil and first opening of the contacts. > However, by the time the contacts see first motion, > the magnetic air gap is established and growing. > > The air gap has much more control over contact > acceleration than does coil current. Hence, the > duration of arc between spreading contacts showed > only a slight difference between diode-suppressed > and non-suppressed contactor. > > The case for 'supper suppressors' is further > weakened by the fact that starter and battery > contactors on our airplanes are considered very > busy if they get a few operations per week. > The average light aircraft flies 50 hours > a year. If you install switches and relay rated > for tens of thousands of operations, it stands to > reason that benefits gained by going-the-extra-mile > on coil suppression yields no measurable benefit. > > Then, there is the study of contact erosion during > closure as influenced by the physics of the switched > circuit. This is due to arcing that occurs during > contact BOUNCE. Many closures and openings per > operation . . . much smaller gap during the bounce . . . > but exceedingly unfriendly to relay life under > some conditions. > > But that's a totally different story . . . > > > Bob . . . > ________________________________________________________________________________
Date: Jan 19, 2018
Does the risk not lie in having contacts that weld together or overheat? On 19 Jan 2018 6:49 PM, "Ken Ryan" wrote: > I'm confused. It seems like you are now saying that because the relays ar e > rated for far more cycles than they will ever see, there is no reason to > bother with diodes. > > Sent from my Android. Sorry Steve. > > On Jan 19, 2018 7:06 AM, "Robert L. Nuckolls, III" < > nuckolls.bob(at)aeroelectric.com> wrote: > >> At 04:37 PM 1/18/2018, you wrote: >> >> >> I=C3=A2=82=AC=84=A2m trying to work out why a diode has *any* sign ificant effect on >> release time compared to a tranzorb or similar, and if it did, why you >> might care. >> Also, why should it have any effect on relay life reduction ? >> My skeptical self needs help to get beyond merely =C3=A2=82=AC=C5=93m ore expensive >> therefore must be better=C3=A2=82=AC . >> >> >> >> When mechanical contacts are opened, an electric >> arc forms in the air gap. With low voltages and >> currents, the fire may be small, but it is never >> zero. In one of my articles, I mentioned and experiment >> when a microswitch was biased up with a dry cell >> and resistor. The contacts were observed >> through a microscope in the dark (the side was opened >> up on the switch for the experiment). >> >> Even at these very low power levels, a BLUE arc >> could be observed. The temperature of blue is >> HOT. This suggests that no matter what the power >> level, every opening even will transfer molecules >> of metal between contacts. >> >> Again, not a lot of metal but never zero. >> >> As energy levels go up and particularly >> at higher voltages, the intensity and DURATION >> of the arcing event increases. This is an expected >> condition. Relays are designed to meet life cycle >> ratings at specific power levels and circuit >> characteristics by adjusting contact material, >> closing forces, opening velocities, opening >> gaps, etc. Conditions are important . . . switches >> and relays will have AC, DC and LAMP ratings >> applied to their service life limits. >> >> https://goo.gl/CPtPYJ >> >> If you've ever tried to do any stick-welding, you >> understand the need for (1) making initial cold >> contact, (2) breaking that contact to form an >> arc, then maintaining an optimum distance between >> rod and work-piece to achieve a SUSTAINED fire >> at a temperature conducive to the TRANSFER >> of metal from rod to work-piece. >> >> If the contacts of a switch or relay do not spread >> fast enough, wide enough and with sufficient >> thermal mass in contacts, then the TRANSFER of >> metal will exceed that which meets design goals >> for service life. >> >> This lays the groundwork for a notion that relay >> contacts will accelerate open at some rate which is >> a function of spring, mass and decay of the >> magnetic field which was originally applied to >> close the contacts. >> >> It's easily demonstrated that rate of decay for >> this magnetic field is strongly influenced by >> the choice of suppression for energy stored in >> the coil at the time it is de-energized. >> >> A totally open-circuit coil is the fastest, but >> transient voltage during field collapse is greatest. >> You can drive a coil with a current limited source >> and the throw a dead short across the coil, reducing >> its excitation current to zero thus initiating >> the contact opening sequence. In this condition, >> the field collapse transient voltage will be zero >> and time to decay will be a whole lot longer. >> Hence, there is a range of decay rates offered by >> the array of suppression techniques. >> >> I've have yet to discover a paper that describes >> the behavior of relay magnetic holding force >> in detail . . . many papers that jump to an >> 'obvious' conclusion that if decay rate in >> the coil is extended by factors of 10 or more, >> then opening velocity of the contacts is similarly >> depressed. >> >> What I observed (in 45 years of herding electrons >> in airplanes and conducting numerous relay and >> switch failure studies) is that as a relay closes, >> the CONTACTS CLOSE before the magnetic armature >> BOTTOMS OUT. There is a spring rate associated >> with this extra motion that sets the contact >> closed holding force. >> >> This leads us to the idea that as the magnetic >> field in the device decays, there is a period >> of time from first motion the of armature off >> the bottomed-out position until closing force >> on the contacts drops to zero and they begin >> to move. This means that there is a GROWING >> AIR GAP in the magnetic circuit holding the >> contacts closed. >> >> This air gap has a profound suppressing effect >> on that magnetic force. It's an effect that >> grossly over-rides the decay rate of the magnetic >> from the coil. >> >> Magnetic decay rate does indeed affect drop-out >> time for the relay . . . this was demonstrated in >> the data collected during my bench-top experiments. >> Decay rate adds a time delay between de-energizing >> of the coil and first opening of the contacts. >> However, by the time the contacts see first motion, >> the magnetic air gap is established and growing. >> >> The air gap has much more control over contact >> acceleration than does coil current. Hence, the >> duration of arc between spreading contacts showed >> only a slight difference between diode-suppressed >> and non-suppressed contactor. >> >> The case for 'supper suppressors' is further >> weakened by the fact that starter and battery >> contactors on our airplanes are considered very >> busy if they get a few operations per week. >> The average light aircraft flies 50 hours >> a year. If you install switches and relay rated >> for tens of thousands of operations, it stands to >> reason that benefits gained by going-the-extra-mile >> on coil suppression yields no measurable benefit. >> >> Then, there is the study of contact erosion during >> closure as influenced by the physics of the switched >> circuit. This is due to arcing that occurs during >> contact BOUNCE. Many closures and openings per >> operation . . . much smaller gap during the bounce . . . >> but exceedingly unfriendly to relay life under >> some conditions. >> >> But that's a totally different story . . . >> >> >> >> >> Bob . . . >> > ________________________________________________________________________________
Subject: Re: diode on starter contactor
Date: Jan 19, 2018
For all intents and purposes the diode ONLY protects the switch that controls the relay. So it does improve system reliability. Ken On 19/01/2018 11:44 AM, Ken Ryan wrote: > I'm confused. It seems like you are now saying that because the relays > are rated for far more cycles than they will ever see, there is no > reason to bother with diodes. ________________________________________________________________________________
Date: Jan 19, 2018
I think y'all are a bit confused on what the diodes actually do. The diode across the relay coil is there to protect the controlling *switch's* low current contacts; not the relay contacts. Now, since TANSTAFL (there's no such thing as a free lunch), the downside (of questionable significance) to the diode being in the circuit is that it *can* slow the collapse of the magnetic field in the relay, leading some to think (evidenced by the link to back-to-back zeners) that it puts the *relay* contacts at more risk. Not to speak for Bob, but his latest post(s) address that slowing of the magnetic field collapse (of questionable significance), and tell us that his testing has shown that with most relays, the contacts don't actually start to separate until after that slowed magnetic field decay isn't having any influence. So....The bottom line is that the diode *is* needed to protect *switch* contacts, and its presence has *minimal to zero* real world impact on the *relay's* contacts. The takeaway is that you do need the diode, and nothing more elaborate than a standard diode is needed. Those of us who made our living playing with these components have an easy time seeing what he's describing. It might serve you well to visit some appliance/electrical repair facility & talk them out of a couple of open frame relays so you can play with them & see what he's describing. On 1/19/2018 10:56 AM, Bob Verwey wrote: > Does the risk not lie in having contacts that weld together or overheat? > > On 19 Jan 2018 6:49 PM, "Ken Ryan" > wrote: > > I'm confused. It seems like you are now saying that because the > relays are rated for far more cycles than they will ever see, > there is no reason to bother with diodes. > > Sent from my Android. Sorry Steve. > > On Jan 19, 2018 7:06 AM, "Robert L. Nuckolls, III" > > wrote: > > At 04:37 PM 1/18/2018, you wrote: >> > >> >> Im trying to work out why a diode has *any* significant >> effect on release time compared to a tranzorb or similar, and >> if it did, why you might care. >> Also, why should it have any effect on relay life reduction ? >> My skeptical self needs help to get beyond merely more >> expensive therefore must be better . > > > When mechanical contacts are opened, an electric > arc forms in the air gap. With low voltages and > currents, the fire may be small, but it is never > zero. In one of my articles, I mentioned and experiment > when a microswitch was biased up with a dry cell > and resistor. The contacts were observed > through a microscope in the dark (the side was opened > up on the switch for the experiment). > > Even at these very low power levels, a BLUE arc > could be observed. The temperature of blue is > HOT. This suggests that no matter what the power > level, every opening even will transfer molecules > of metal between contacts. > > Again, not a lot of metal but never zero. > > As energy levels go up and particularly > at higher voltages, the intensity and DURATION > of the arcing event increases. This is an expected > condition. Relays are designed to meet life cycle > ratings at specific power levels and circuit > characteristics by adjusting contact material, > closing forces, opening velocities, opening > gaps, etc. Conditions are important . . . switches > and relays will have AC, DC and LAMP ratings > applied to their service life limits. > > https://goo.gl/CPtPYJ > > If you've ever tried to do any stick-welding, you > understand the need for (1) making initial cold > contact, (2) breaking that contact to form an > arc, then maintaining an optimum distance between > rod and work-piece to achieve a SUSTAINED fire > at a temperature conducive to the TRANSFER > of metal from rod to work-piece. > > If the contacts of a switch or relay do not spread > fast enough, wide enough and with sufficient > thermal mass in contacts, then the TRANSFER of > metal will exceed that which meets design goals > for service life. > > This lays the groundwork for a notion that relay > contacts will accelerate open at some rate which is > a function of spring, mass and decay of the > magnetic field which was originally applied to > close the contacts. > > It's easily demonstrated that rate of decay for > this magnetic field is strongly influenced by > the choice of suppression for energy stored in > the coil at the time it is de-energized. > > A totally open-circuit coil is the fastest, but > transient voltage during field collapse is greatest. > You can drive a coil with a current limited source > and the throw a dead short across the coil, reducing > its excitation current to zero thus initiating > the contact opening sequence. In this condition, > the field collapse transient voltage will be zero > and time to decay will be a whole lot longer. > Hence, there is a range of decay rates offered by > the array of suppression techniques. > > I've have yet to discover a paper that describes > the behavior of relay magnetic holding force > in detail . . . many papers that jump to an > 'obvious' conclusion that if decay rate in > the coil is extended by factors of 10 or more, > then opening velocity of the contacts is similarly > depressed. > > What I observed (in 45 years of herding electrons > in airplanes and conducting numerous relay and > switch failure studies) is that as a relay closes, > the CONTACTS CLOSE before the magnetic armature > BOTTOMS OUT. There is a spring rate associated > with this extra motion that sets the contact > closed holding force. > > This leads us to the idea that as the magnetic > field in the device decays, there is a period > of time from first motion the of armature off > the bottomed-out position until closing force > on the contacts drops to zero and they begin > to move. This means that there is a GROWING > AIR GAP in the magnetic circuit holding the > contacts closed. > > This air gap has a profound suppressing effect > on that magnetic force. It's an effect that > grossly over-rides the decay rate of the magnetic > from the coil. > > Magnetic decay rate does indeed affect drop-out > time for the relay . . . this was demonstrated in > the data collected during my bench-top experiments. > Decay rate adds a time delay between de-energizing > of the coil and first opening of the contacts. > However, by the time the contacts see first motion, > the magnetic air gap is established and growing. > > The air gap has much more control over contact > acceleration than does coil current. Hence, the > duration of arc between spreading contacts showed > only a slight difference between diode-suppressed > and non-suppressed contactor. > > The case for 'supper suppressors' is further > weakened by the fact that starter and battery > contactors on our airplanes are considered very > busy if they get a few operations per week. > The average light aircraft flies 50 hours > a year. If you install switches and relay rated > for tens of thousands of operations, it stands to > reason that benefits gained by going-the-extra-mile > on coil suppression yields no measurable benefit. > > Then, there is the study of contact erosion during > closure as influenced by the physics of the switched > circuit. This is due to arcing that occurs during > contact BOUNCE. Many closures and openings per > operation . . . much smaller gap during the bounce . . . > but exceedingly unfriendly to relay life under > some conditions. > > But that's a totally different story . . . > > > Bob . . . > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jan 19, 2018
I am reluctant to get into another long discussion on the subject of coil suppression but I encourage Googling the various extensive resources on this subject. Note that there are many techniques tuned to specific application on this subject, but three things are true: 1) The use of a simple diode is contraindicated. 2) The use of a simple bidirectional zener is a good way to go. 3) MOVs are a good way to go, but they have a discrete lifetime...I was never comfortable with that. MOVs are usually what fails in surge-suppression computer multi-outlets. One COULD use a zener and a regular diode in series, but a bidirectional zener is polarity insensitive and stone simple. Kilovac and Gigavac both use bidirectional zeners inside their contactors for coil supression. What does these people know that you don't? Eric ________________________________________________________________________________
Date: Jan 19, 2018
Thanks Charlie. That does clear things up for me as to what Bob was saying. I am no longer confused (temporary condition I am sure). Sent from my Android. Sorry Steve. On Jan 19, 2018 8:26 AM, "Charlie England" wrote: > I think y'all are a bit confused on what the diodes actually do. The diod e > across the relay coil is there to protect the controlling *switch's* low > current contacts; not the relay contacts. Now, since TANSTAFL (there's no > such thing as a free lunch), the downside (of questionable significance) > to the diode being in the circuit is that it *can* slow the collapse of t he > magnetic field in the relay, leading some to think (evidenced by the link > to back-to-back zeners) that it puts the *relay* contacts at more risk. > > Not to speak for Bob, but his latest post(s) address that slowing of the > magnetic field collapse (of questionable significance), and tell us that > his testing has shown that with most relays, the contacts don't actually > start to separate until after that slowed magnetic field decay isn't havi ng > any influence. > > So....The bottom line is that the diode *is* needed to protect *switch* > contacts, and its presence has *minimal to zero* real world impact on the > *relay's* contacts. The takeaway is that you do need the diode, and nothi ng > more elaborate than a standard diode is needed. > > Those of us who made our living playing with these components have an eas y > time seeing what he's describing. It might serve you well to visit some > appliance/electrical repair facility & talk them out of a couple of open > frame relays so you can play with them & see what he's describing. > > On 1/19/2018 10:56 AM, Bob Verwey wrote: > > Does the risk not lie in having contacts that weld together or overheat? > > On 19 Jan 2018 6:49 PM, "Ken Ryan" wrote: > >> I'm confused. It seems like you are now saying that because the relays >> are rated for far more cycles than they will ever see, there is no reaso n >> to bother with diodes. >> >> Sent from my Android. Sorry Steve. >> >> On Jan 19, 2018 7:06 AM, "Robert L. Nuckolls, III" < >> nuckolls.bob(at)aeroelectric.com> wrote: >> >>> At 04:37 PM 1/18/2018, you wrote: >>> > >>> >>> I=C3=A2=82=AC=84=A2m trying to work out why a diode has *any* sig nificant effect on >>> release time compared to a tranzorb or similar, and if it did, why you >>> might care. >>> Also, why should it have any effect on relay life reduction ? >>> My skeptical self needs help to get beyond merely =C3=A2=82=AC=C5=93 more expensive >>> therefore must be better=C3=A2=82=AC . >>> >>> >>> >>> When mechanical contacts are opened, an electric >>> arc forms in the air gap. With low voltages and >>> currents, the fire may be small, but it is never >>> zero. In one of my articles, I mentioned and experiment >>> when a microswitch was biased up with a dry cell >>> and resistor. The contacts were observed >>> through a microscope in the dark (the side was opened >>> up on the switch for the experiment). >>> >>> Even at these very low power levels, a BLUE arc >>> could be observed. The temperature of blue is >>> HOT. This suggests that no matter what the power >>> level, every opening even will transfer molecules >>> of metal between contacts. >>> >>> Again, not a lot of metal but never zero. >>> >>> As energy levels go up and particularly >>> at higher voltages, the intensity and DURATION >>> of the arcing event increases. This is an expected >>> condition. Relays are designed to meet life cycle >>> ratings at specific power levels and circuit >>> characteristics by adjusting contact material, >>> closing forces, opening velocities, opening >>> gaps, etc. Conditions are important . . . switches >>> and relays will have AC, DC and LAMP ratings >>> applied to their service life limits. >>> >>> https://goo.gl/CPtPYJ >>> >>> If you've ever tried to do any stick-welding, you >>> understand the need for (1) making initial cold >>> contact, (2) breaking that contact to form an >>> arc, then maintaining an optimum distance between >>> rod and work-piece to achieve a SUSTAINED fire >>> at a temperature conducive to the TRANSFER >>> of metal from rod to work-piece. >>> >>> If the contacts of a switch or relay do not spread >>> fast enough, wide enough and with sufficient >>> thermal mass in contacts, then the TRANSFER of >>> metal will exceed that which meets design goals >>> for service life. >>> >>> This lays the groundwork for a notion that relay >>> contacts will accelerate open at some rate which is >>> a function of spring, mass and decay of the >>> magnetic field which was originally applied to >>> close the contacts. >>> >>> It's easily demonstrated that rate of decay for >>> this magnetic field is strongly influenced by >>> the choice of suppression for energy stored in >>> the coil at the time it is de-energized. >>> >>> A totally open-circuit coil is the fastest, but >>> transient voltage during field collapse is greatest. >>> You can drive a coil with a current limited source >>> and the throw a dead short across the coil, reducing >>> its excitation current to zero thus initiating >>> the contact opening sequence. In this condition, >>> the field collapse transient voltage will be zero >>> and time to decay will be a whole lot longer. >>> Hence, there is a range of decay rates offered by >>> the array of suppression techniques. >>> >>> I've have yet to discover a paper that describes >>> the behavior of relay magnetic holding force >>> in detail . . . many papers that jump to an >>> 'obvious' conclusion that if decay rate in >>> the coil is extended by factors of 10 or more, >>> then opening velocity of the contacts is similarly >>> depressed. >>> >>> What I observed (in 45 years of herding electrons >>> in airplanes and conducting numerous relay and >>> switch failure studies) is that as a relay closes, >>> the CONTACTS CLOSE before the magnetic armature >>> BOTTOMS OUT. There is a spring rate associated >>> with this extra motion that sets the contact >>> closed holding force. >>> >>> This leads us to the idea that as the magnetic >>> field in the device decays, there is a period >>> of time from first motion the of armature off >>> the bottomed-out position until closing force >>> on the contacts drops to zero and they begin >>> to move. This means that there is a GROWING >>> AIR GAP in the magnetic circuit holding the >>> contacts closed. >>> >>> This air gap has a profound suppressing effect >>> on that magnetic force. It's an effect that >>> grossly over-rides the decay rate of the magnetic >>> from the coil. >>> >>> Magnetic decay rate does indeed affect drop-out >>> time for the relay . . . this was demonstrated in >>> the data collected during my bench-top experiments. >>> Decay rate adds a time delay between de-energizing >>> of the coil and first opening of the contacts. >>> However, by the time the contacts see first motion, >>> the magnetic air gap is established and growing. >>> >>> The air gap has much more control over contact >>> acceleration than does coil current. Hence, the >>> duration of arc between spreading contacts showed >>> only a slight difference between diode-suppressed >>> and non-suppressed contactor. >>> >>> The case for 'supper suppressors' is further >>> weakened by the fact that starter and battery >>> contactors on our airplanes are considered very >>> busy if they get a few operations per week. >>> The average light aircraft flies 50 hours >>> a year. If you install switches and relay rated >>> for tens of thousands of operations, it stands to >>> reason that benefits gained by going-the-extra-mile >>> on coil suppression yields no measurable benefit. >>> >>> Then, there is the study of contact erosion during >>> closure as influenced by the physics of the switched >>> circuit. This is due to arcing that occurs during >>> contact BOUNCE. Many closures and openings per >>> operation . . . much smaller gap during the bounce . . . >>> but exceedingly unfriendly to relay life under >>> some conditions. >>> >>> But that's a totally different story . . . >>> >>> >>> >>> >>> Bob . . . >>> >> > > > Virus-free . > www.avast.com > > <#m_-9065681909408129575_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> > ________________________________________________________________________________
Date: Jan 19, 2018
At 10:44 AM 1/19/2018, you wrote: >I'm confused. It seems like you are now saying that because the >relays are rated for far more cycles than they will ever see, there >is no reason to bother with diodes. No . . . . I am saying that 'optimized' coil spike suppression has a perhaps a tiny benefit for contactors in heavy usage applications and no benefit in our airplanes (very low duty). Spike suppression is (and always has been) indicated for enhancing LIFE OF THE DEVICE THAT CONTROLS the contactor. E.g. AD against key-switch. The plain-vanilla diodes have been installed on TC aircraft for decades. See item 29 in screenshot of 1969 C172 service manual. Couldn't put my hands on my copy of the Beechjet manual . . . but the little critters are sprinkled about that airplane as well. Emacs! The diode has (1) no practical effect on service life of contactor and (2) demonstrable benefit on service life of the controlling switch . . . Bob . . . ________________________________________________________________________________
Date: Jan 19, 2018
At 10:56 AM 1/19/2018, you wrote: >Does the risk not lie in having contacts that weld together or overheat? Contacts 'weld' on closure. The risk of welding begins with deformation of contact surfaces due to combinations of age and service conditions (extra ordinary inrush current), low energizing current. Contact welding can also be a function of unanticipated behaviors due to aircraft wiring. See this study on 'sticking' roll trim relays on the Beechjet: https://goo.gl/QcfSYo Spike suppression on the at-risk relay/contactor has no effect on conditions that promote contact sticking/welding. 'Overheating' contacts are either too small for the service or so badly worn as to degrade conductivity across the contacts. https://goo.gl/1BJP7y Note that this victim of severe overheat still carries remains of its coil suppression diode. This contactor was used to control power to a 3 horsepower, 28v motor used in the air conditioning system of a King Air. The diode was there . . . but the contactor simply got 'tired'. Bob . . . ________________________________________________________________________________
Date: Jan 19, 2018
> >Kilovac and Gigavac both use bidirectional zeners inside their >contactors for coil supression. What does these people know that you don't? Not a thing I can see . . . the bidirectional zener performs as advertised. No reason to avoid it or to change it out in favor of an alternative. By the same token, there's no demonstrable benefit for any extra effort to steer clear of the lowly diode that has also performed as advertised in literally billions of applications for a very long time. My complaint is with publications that make sweeping assertions that are demonstrably short on physical evidence or experimental confirmation. Bob . . . ________________________________________________________________________________
Date: Jan 19, 2018
Subject: suppression diodes
on a similar subject to recent discussion, why dont we use a suppression device across the load of the starter contactor (i.e. the motor) to prevent arcing at the contactor contacts? ________________________________________________________________________________
Date: Jan 19, 2018
I was wondering the same thing Bob so I had a look, no fuse or breaker in that line. I guess the builder thought it didn't need one since it connects to ground 8(. I think I should install an inline fuse? Thank you, Sebastien On Fri, Jan 19, 2018 at 8:07 AM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 07:09 PM 1/18/2018, you wrote: > > Last year I put a lighter AGM battery in my aircraft and moved it to the > firewall along with the master contactor and made some new diodes for the > contactors (one was broken). Saved about 4 pounds in wiring alone! Only > problem afterwards was that if the battery was even slightly down sometimes > the starter would turn a split second and then nothing. Repeated attempts > usually ended up with the starter eventually running fine until the engine > started. Putting a voltmeter on the starter confirmed that the problem was > a lack of power to the starter, not the starter itself. I had a battery > problem later on and replaced the battery, no change. Thinking I had messed > up the starter contactor while tightening nuts on it I swapped it out, no > change. At this point I started to suspect my diode so I disconnected it: > Problem gone! I suspect I installed it backwards. Going to make the new one > with clear shrinkwrap tubing so it can't happen again. > > > If your diode is installed backwards, it will conduct > HARD while the starter button is depressed. Plastic > diodes generally smoke for a few seconds and split, > some will literally explode. I've seen a few cases > where they simply fused short and tripped the starter > control circuit breaker. > > If removing the diode cured your problem, then it > probably was 'backwards'. Do you have a breaker > or fuse on your starter control line? That shorted condition > should have opened the circuit protection. > > > Bob . . . > ________________________________________________________________________________
Date: Jan 20, 2018
At 09:12 PM 1/19/2018, you wrote: >I was wondering the same thing Bob so I had a look, no fuse or >breaker in that line. I guess the builder thought it didn't need one >since it connects to ground 8(. I think I should install an inline fuse? Not sure which 'same thing' you're citing . . . Fuse in which line, bust thru starter button to starer contactor or battery to starter contactor? The CONTROL line from bus to starter switch is classically protected. No protection is indicated for the cranking current feeder from battery to starter contactor. Suggest you browse the various power distribution diagrams (Z-figures) at https://goo.gl/kovZJX While these cover a broad range of applications, there are features common to all of them that illustrate both legacy and modern but field proven techniques for architecture. Bob . . . ________________________________________________________________________________
Date: Jan 20, 2018
Subject: Re: suppression diodes
At 02:04 PM 1/19/2018, you wrote: > >on a similar subject to recent discussion, why >don=99t we use a suppression device across the >load of the starter contactor (i.e. the motor) >to prevent arcing at the contactor contacts? Excellent question! Shucks, starters draw a lot of current. If one just 'tapped' the starter button and hit the contactor with the starter's 500-1000A inrush, doesn't that 'charge' the starter's inductance to astronomical heights? You betcha . . . Let's consider a turbine starter motor with a dc resistance of say 0.015 ohms. Let us presume further that the loop resistance for wiring, battery contactor, starter contactor and battery is also on the order 0.010 ohms. When the contactor closes, we have 25v/0.025-ohms or 1000 amps of inrush current. Terminal voltage on starter drops to 15v. Energy stored on an inductor is Joules(Watt-Seconds)=Inductance (Henries) x I(Amps)squared/2 Needless to say, 1000 squared is a pretty big number. If the starter contactor bounces during the first few milliseconds of the spin-up, the potential for arcing is considerable, but the air gap during a bounce is tiny; the discontinuity interval is short. Heat energy developed is relatively low and within the operating limits for dime-sized contacts. Any transient excursions for field collapse are impressed across the contact gap and do not propagate out onto the bus. Once the bouncing has subsided and the motor spins up, current draw falls dramatically. Here's a plot I found in some document out at Beech about a bazillion years ago: https://goo.gl/4cL4ff It's the voltage-current vs. time plot of a cranking event on a turbine engine . . . more specifically, a B400 Beechjet. Turbine cranking curves are interesting because the engine takes so long to spin up . . . it doesn't get to the 'light off' rpm for 15-20 second! We can readily see that starter current at light-off has fallen to under 300 amps, about 30% of inrush. At 300 amps across the motor's 0.015 ohms, we can see that the motor is actually RUNNING on Volts 300A x 0.015Ohms or about 4.5 volts. At this time, voltage applied to the motor is 18-19 volts. This means that the motor's COUNTER EMF or CEMF is 18-4.5 or about 13.5 volts. If the battery contactor opens at this point, the initial arc striking voltage is 4.5 volts and the current is 300A. A much lower value than the numbers during inrush. At 300A, stored energy on the starter's inductance is about 10% of that experienced during the inrush event. As it turns out, it's quite easy to build contactors that are tailored to withstand the inrush event. See https://goo.gl/RGGhgG The flimsy looking flat moving contact has very low area, high force interface with the stationary contacts. i.e. HIGH PRESSURE Further, its mass is low and spring rates are low to minimize bounce. The intermittent duty, high force solenoid offers strong reduction of contact erosion during the starter inrush interval . . . similarly, the light mass of the moving contact assembly offers rapid acceleration and good contact spreading velocities at de-energization. The design has TWO contact in series which means that during the opening sequence, contact spreading velocity is essentially doubled. This design minimizes potential arc damage to the contacts as the magnetic field in the motor collapses. Again, the energy is expended in the contact gaps and does not propagate out onto the bus. This last fact was not well understood by many in the vehicular DC power system world . . . it seemed only natural that this energy intensive event at the starter motor would produce massive 'spikes' potentially deleterious to vulnerable electronics in the vehicle . . . it has been proven not to be so. It turns out that ALL known and anticipated perturbations on the ship's bus for ALL operating conditions are well inside the legacy testing limits for aircraft hardware as described in DO-160. See https://goo.gl/6gSsSL Hence, the starter motor is not the big bear in the woods that legacy hangar lore would have us believe. It IS a high energy even easily managed by the starter contactor design and not a threat to the rest of the system. So if an avionics tech says you've got a $1000 repair bill on an in-warranty radio because a 'spike got it', you need to talk to his/her supervisor. Bob . . . ________________________________________________________________________________
Subject: Fuel Totalizer Circuit
Date: Jan 22, 2018
A friend of mine is having an issue with the fuel totalizer on his aircraft. Basically it doesn't work (is dead) and seems that it may have suffered from a voltage spike whilst starting the a/c from a boost starter. Fault finding would be much easier if anyone has access to a circuit diagram of the device. Does anyone on here know where to find one? We have the user manual - but that only shows the external wiring to the power and transducer. It's a Hoskins Model FT101A. Any help would be very much appreciated. Thanks for reading this. Stuart Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477495#477495 ________________________________________________________________________________
Subject: Re: Fuel Totalizer Circuit
Date: Jan 22, 2018
Download this pdf: https://img1.wsimg.com/blobby/go/5fd0aa27-961d-44f2-853d-76b9736fb4af/downloads/1bono4lcn_734052.pdf -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477496#477496 ________________________________________________________________________________
Date: Jan 22, 2018
Hi Joe, Yes, that's the one we've already got - but thanks anyway. The problem is there's clearly a fault on the circuit board somewhere - and I don't think I can find it without a circuit diagram. Cheers, Stu Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477499#477499 ________________________________________________________________________________
Date: Jan 22, 2018
Subject: fuel pressure sensor
I have a fuel pressure sender -- UMA N1EU07D -- for my Rotax 914. It is a differential sensor that senses fuel pressure and airbox pressure, and reports the difference. The wiring that comes with the sensor is a 3 wire shielded pigtail that is about a foot long. The 3 wires are 12v power, ground and signal. To connect this to my Dynon Skyview EMS module I will need to strip it back a few inches in order to accommodate a 37 pin plug, leaving about 8 inches of shielded bundle running from the sensor housing to the 37 pin plug. None of the wires on the pre-made Dynon harness are shielded. The Dynon manual makes no mention of utilizing the shield. The shielded wire would only be about 8 inches long, or less, from the sensor to the 37 pin plug. The remainder of the run (approximately 18 inches) is unshielded. I cannot see any reason to utilize the shield that comes with the sensor. Am I correct? Thanks, Ken ________________________________________________________________________________
Date: Jan 22, 2018
Subject: Re: fuel pressure sensor
At 11:21 AM 1/22/2018, you wrote: >I have a fuel pressure sender -- UMA=C2 N1EU07D -- >for my Rotax 914. It is a differential sensor >that senses fuel pressure and airbox pressure, and reports the difference. > >The wiring that comes with the sensor is a 3 >wire shielded pigtail that is about a foot long. >The 3 wires are 12v power, ground and signal. > >To connect this to my Dynon Skyview EMS module I >will need to strip it back a few inches in order >to accommodate a 37 pin plug, leaving about 8 >inches of shielded bundle running from the >sensor housing to the 37 pin plug. None of the >wires on the pre-made Dynon harness are >shielded. The Dynon manual makes no mention of utilizing the shield. > >The shielded wire would only be about 8 inches >long, or less, from the sensor to the 37 pin >plug. The remainder of the run (approximately 18 inches) is unshielded. > >I cannot see any reason to utilize the shield >that comes with the sensor. Am I correct? No reason to think otherwise . . . these signals are generally not vulnerable to electrostatically coupled antagonists . . . further, it's unlikely that any such antagonists will be found sharing the wire bundles. I think you can move ahead . . . Bob . . . ________________________________________________________________________________
Date: Jan 22, 2018
HiKen; HiAll; I am going to go way out on a limb here: I have a different fuel pressure sender, that is not shielded, provided by Swift that also makes gauges. There is a possibility that your manufacturer only used shielded wire because of its durability. Presuming that you have already tried to talk with the manufacturer and gotten no joy, I would try it without shielding the remainder of the run and see what happens. If that fails, you can buy shielding in flattened tubes that can be put over the unshielded bundle, connected to the sensor shield and grounded at the far end. I have some extra 3/8" ID if you want to give it a try; no charge. Cheers! Stu. ----- Original Message ----- From: "Ken Ryan" <keninalaska(at)gmail.com> Sent: Monday, January 22, 2018 9:21:24 AM Subject: AeroElectric-List: fuel pressure sensor I have a fuel pressure sender -- UMA N1EU07D -- for my Rotax 914. It is a differential sensor that senses fuel pressure and airbox pressure, and reports the difference. The wiring that comes with the sensor is a 3 wire shielded pigtail that is about a foot long. The 3 wires are 12v power, ground and signal. To connect this to my Dynon Skyview EMS module I will need to strip it back a few inches in order to accommodate a 37 pin plug, leaving about 8 inches of shielded bundle running from the sensor housing to the 37 pin plug. None of the wires on the pre-made Dynon harness are shielded. The Dynon manual makes no mention of utilizing the shield. The shielded wire would only be about 8 inches long, or less, from the sensor to the 37 pin plug. The remainder of the run (approximately 18 inches) is unshielded. I cannot see any reason to utilize the shield that comes with the sensor. Am I correct? Thanks, Ken ________________________________________________________________________________
Date: Jan 22, 2018
Thanks everybody. On Mon, Jan 22, 2018 at 8:39 AM, wrote: > HiKen; > HiAll; > I am going to go way out on a limb here: I have a different fuel pressure > sender, that is not shielded, provided by Swift that also makes gauges. > There is a possibility that your manufacturer only used shielded wire > because of its durability. Presuming that you have already tried to talk > with the manufacturer and gotten no joy, I would try it without shielding > the remainder of the run and see what happens. If that fails, you can buy > shielding in flattened tubes that can be put over the unshielded bundle, > connected to the sensor shield and grounded at the far end. I have some > extra 3/8" ID if you want to give it a try; no charge. > Cheers! Stu. > > ------------------------------ > *From: *"Ken Ryan" <keninalaska(at)gmail.com> > *To: *aeroelectric-list(at)matronics.com > *Sent: *Monday, January 22, 2018 9:21:24 AM > *Subject: *AeroElectric-List: fuel pressure sensor > > I have a fuel pressure sender -- UMA N1EU07D -- for my Rotax 914. It is a > differential sensor that senses fuel pressure and airbox pressure, and > reports the difference. > > The wiring that comes with the sensor is a 3 wire shielded pigtail that is > about a foot long. The 3 wires are 12v power, ground and signal. > > To connect this to my Dynon Skyview EMS module I will need to strip it > back a few inches in order to accommodate a 37 pin plug, leaving about 8 > inches of shielded bundle running from the sensor housing to the 37 pin > plug. None of the wires on the pre-made Dynon harness are shielded. The > Dynon manual makes no mention of utilizing the shield. > > The shielded wire would only be about 8 inches long, or less, from the > sensor to the 37 pin plug. The remainder of the run (approximately 18 > inches) is unshielded. > > I cannot see any reason to utilize the shield that comes with the sensor. > Am I correct? > > Thanks, > > Ken > > ________________________________________________________________________________
Date: Jan 22, 2018
Don't have the diagram, but I think I have a removed-good unit in my hangar... Paul On 1/22/2018 2:12 AM, sturs wrote: > > A friend of mine is having an issue with the fuel totalizer on his aircraft. Basically it doesn't work (is dead) and seems that it may have suffered from a voltage spike whilst starting the a/c from a boost starter. > > Fault finding would be much easier if anyone has access to a circuit diagram of the device. Does anyone on here know where to find one? We have the user manual - but that only shows the external wiring to the power and transducer. It's a Hoskins Model FT101A. > > Any help would be very much appreciated. Thanks for reading this. > > Stuart > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=477495#477495 > > ________________________________________________________________________________
Date: Jan 23, 2018
Thanks Paul. My friend already has a replacement - which took him a long time to find. Mind you hes rather unwilling to take the new one apart and use that as an example to check against the other! Thanks for the offer, though. Much appreciated. Cheers, Stu Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477507#477507 ________________________________________________________________________________
Date: Jan 23, 2018
Subject: SD-8 Alternator Question
When I bought my plane, which has an SD-8 alternator as the primary power source, it came with an inline fuse on one of the two leads from the alternator. The guy who installed it said it was an 8 amp alternator so he added a 10 amp inline fuse. But, I believe it provides 8 amps at 14 volts after regulation and the voltage where the fuse is installed is something like 20-25 volts AC. So, the max current there would probably be a bit less than 8 amps anyway, right? Regardless, it has never blown, but I am wondering if it is even serving a useful purpose other than to increase the number of electrical connections in my plane? Thanks, Ron ________________________________________________________________________________
Date: Jan 23, 2018
My chief engineer here at work always says the fuse is there to protect the wire.keeps the smoke innot the equipment at the end. I have the same setup on my standby and I think that is what they gave me in the kit. Rene' 801-721-6080 From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ron Springer Sent: Tuesday, January 23, 2018 2:37 PM Subject: AeroElectric-List: SD-8 Alternator Question When I bought my plane, which has an SD-8 alternator as the primary power source, it came with an inline fuse on one of the two leads from the alternator. The guy who installed it said it was an 8 amp alternator so he added a 10 amp inline fuse. But, I believe it provides 8 amps at 14 volts after regulation and the voltage where the fuse is installed is something like 20-25 volts AC. So, the max current there would probably be a bit less than 8 amps anyway, right? Regardless, it has never blown, but I am wondering if it is even serving a useful purpose other than to increase the number of electrical connections in my plane? Thanks, Ron ________________________________________________________________________________
Date: Jan 23, 2018
See this wiring diagram =93 shows a 15 amp fuse. http://www.bandc.aero/pdfs/504-500%20REV%20I.pdf Peter From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ron Springer Sent: 23 January 2018 21:37 Subject: AeroElectric-List: SD-8 Alternator Question When I bought my plane, which has an SD-8 alternator as the primary power source, it came with an inline fuse on one of the two leads from the alternator. The guy who installed it said it was an 8 amp alternator so he added a 10 amp inline fuse. But, I believe it provides 8 amps at 14 volts after regulation and the voltage where the fuse is installed is something like 20-25 volts AC. So, the max current there would probably be a bit less than 8 amps anyway, right? Regardless, it has never blown, but I am wondering if it is even serving a useful purpose other than to increase the number of electrical connections in my plane? Thanks, Ron ________________________________________________________________________________
Date: Jan 23, 2018
Subject: Re: SD-8 Alternator Question
Thanks! I didn't know that it was standard to include the fuse in one of the wires. The person I bought the plane from made it sound like it was his idea. The 10 amp size seems to work fine for the SD-8. The wiring diagram applies to three alternators, including ones that are larger than the SD-8, which is probably why it calls for the 15 amp fuse. Ron On Tue, Jan 23, 2018 at 5:43 PM, Peter Pengilly wrote: > See this wiring diagram =93 shows a 15 amp fuse. > > > http://www.bandc.aero/pdfs/504-500%20REV%20I.pdf > > > Peter > > > *From:* owner-aeroelectric-list-server(at)matronics.com [mailto: > owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of *Ron Springer > *Sent:* 23 January 2018 21:37 > *To:* aeroelectric-list(at)matronics.com > *Subject:* AeroElectric-List: SD-8 Alternator Question > > > When I bought my plane, which has an SD-8 alternator as the primary power > source, it came with an inline fuse on one of the two leads from the > alternator. > > The guy who installed it said it was an 8 amp alternator so he added a 10 > amp inline fuse. But, I believe it provides 8 amps at 14 volts after > regulation and the voltage where the fuse is installed is something like > 20-25 volts AC. So, the max current there would probably be a bit less th an > 8 amps anyway, right? > > Regardless, it has never blown, but I am wondering if it is even serving a > useful purpose other than to increase the number of electrical connection s > in my plane? > > Thanks, > > Ron > ________________________________________________________________________________
Date: Jan 23, 2018
Hi Peter; Hi Ron; The drawing shows a ten amp fuse for an SD-8 alternator. Cheers! Stu. ----- Original Message ----- From: "Peter Pengilly" <Peter(at)sportingaero.com> Sent: Tuesday, January 23, 2018 2:43:56 PM Subject: RE: AeroElectric-List: SD-8 Alternator Question See this wiring diagram =93 shows a 15 amp fuse. http://www.bandc.aero/pdfs/504-500%20REV%20I.pdf Peter From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectr ic-list-server(at)matronics.com] On Behalf Of Ron Springer Sent: 23 January 2018 21:37 Subject: AeroElectric-List: SD-8 Alternator Question When I bought my plane, which has an SD-8 alternator as the primary power s ource, it came with an inline fuse on one of the two leads from the alterna tor. The guy who installed it said it was an 8 amp alternator so he added a 10 a mp inline fuse. But, I believe it provides 8 amps at 14 volts after regulat ion and the voltage where the fuse is installed is something like 20-25 vol ts AC. So, the max current there would probably be a bit less than 8 amps a nyway, right? Regardless, it has never blown, but I am wondering if it is even serving a useful purpose other than to increase the number of electrical connections in my plane? Thanks, Ron ________________________________________________________________________________
Date: Jan 23, 2018
At 03:37 PM 1/23/2018, you wrote: >When I bought my plane, which has an SD-8 alternator as the primary >power source, it came with an inline fuse on one of the two leads >from the alternator. > >The guy who installed it said it was an 8 amp alternator so he added >a 10 amp inline fuse. But, I believe it provides 8 amps at 14 volts >after regulation and the voltage where the fuse is installed is >something like 20-25 volts AC. So, the max current there would >probably be a bit less than 8 amps anyway, right? > >Regardless, it has never blown, but I am wondering if it is even >serving a useful purpose other than to increase the number of >electrical connections in my plane? The SD-8, under some conditions, is capable of 10A of output. A fuse should be sized for at least 1.5 times the expected continuous load . . . 2x or 3x is not unreasonable giving the very fast action of a fuse versus circuit breaker. If the SD-8 feeder is 14AWG or larger, a 20A fuse is the better choice . . . 30A would not be out of line. Bob . . . ________________________________________________________________________________
Date: Jan 23, 2018
Subject: Re: SD-8 Alternator Question (OOPS)
At 08:06 PM 1/23/2018, you wrote: >At 03:37 PM 1/23/2018, you wrote: >>When I bought my plane, which has an SD-8 alternator as the primary >>power source, it came with an inline fuse on one of the two leads >>from the alternator. >> >>The guy who installed it said it was an 8 amp alternator so he >>added a 10 amp inline fuse. But, I believe it provides 8 amps at 14 >>volts after regulation and the voltage where the fuse is installed >>is something like 20-25 volts AC. So, the max current there would >>probably be a bit less than 8 amps anyway, right? >> >>Regardless, it has never blown, but I am wondering if it is even >>serving a useful purpose other than to increase the number of >>electrical connections in my plane? > > > The SD-8, under some conditions, is capable of 10A > of output. A fuse should be sized for at least 1.5 > times the expected continuous load . . . 2x or > 3x is not unreasonable giving the very fast action > of a fuse versus circuit breaker. > > If the SD-8 feeder is 14AWG or larger, a 20A > fuse is the better choice . . . 30A would not > be out of line. Hit the 'send' button too soon. The short answer to your question: That feeder should be protected. If you've not experienced a nuisance trip of the 10A fuse, then there's no pressing need to fiddle with it. If you DO experience a nuisance trip in the future, and upsize is indicated, I'd go for 20A Bob . . . ________________________________________________________________________________
Date: Jan 24, 2018
Bob, I believe you're referring to the fuse on the main connection to the battery contactor from the S704-1 relay? And Stu is referring to the SD-8 connection to the power bus, not the inline fuse depicted on one of the two alternator leads shown on the B&C diagram. I too have questions on whether this 15A fuse should be included, but figured since Bob depicts it twice without it --both in the Z-13/8 and Z-25 diagrams that include a bridge rectifier (that B&C doesn't) for self excitation-- then it wasn't required. Bob, can you confirm whether the 15A fuse at the actual SD-8 alternator feed is required or not if the self excitation feature is employed? Regards, Wade -------- Airdog Wade Parton Building Long-EZ N916WP www.longezpush.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477529#477529 ________________________________________________________________________________
Date: Jan 24, 2018
At 09:06 AM 1/24/2018, you wrote: > >Bob, > >I believe you're referring to the fuse on the main connection to the >battery contactor from the S704-1 relay? > >And Stu is referring to the SD-8 connection to the power bus, not >the inline fuse depicted on one of the two alternator leads shown on >the B&C diagram. > >I too have questions on whether this 15A fuse should be included, >but figured since Bob depicts it twice without it --both in the >Z-13/8 and Z-25 diagrams that include a bridge rectifier (that B&C >doesn't) for self excitation-- then it wasn't required. > >Bob, can you confirm whether the 15A fuse at the actual SD-8 >alternator feed is required or not if the self excitation feature is employed? Good eye! I'd forgotten about that fuse being added some years ago. It's a good idea. One of the failure modes for the rectifier/regulator places a dead short on the SD-8 output. The fuse keeps the dynamo from smoking. The RMS current flowing out of the dynamo is about the same as the DC output current from the rectifier/regulator. This is a duty-cycle switched series regulator with no energy-storage . . . Bob . . . ________________________________________________________________________________
Date: Jan 24, 2018
Bob, Thanks for confirming that fuse should be installed. I literally just bolted my SD-8 to the vacuum pad during my engine build yesterday, so now I'll plan on adding back in that inline fuse. Ron- Thanks for asking the question.... perfect timing! Regards, Wade -------- Airdog Wade Parton Building Long-EZ N916WP www.longezpush.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477557#477557 ________________________________________________________________________________
Date: Jan 24, 2018
No problem. Thanks Bob! Ron On Wed, Jan 24, 2018 at 9:06 PM, Airdog77 wrote: > > Bob, > > Thanks for confirming that fuse should be installed. I literally just > bolted my SD-8 to the vacuum pad during my engine build yesterday, so now > I'll plan on adding back in that inline fuse. > > Ron- Thanks for asking the question.... perfect timing! > > Regards, > Wade > > -------- > Airdog > Wade Parton > Building Long-EZ N916WP > www.longezpush.com > > ________________________________________________________________________________
Subject: Starter Contactor location on a Long-EZ
Date: Jan 26, 2018
Bob, et al. BACKGROUND: I was doing some research on Brian DeFord's Cozy that burned up on the ramp some years back due to an electrical issue with the starting/charging system (i.e. electrical wires through the firewall). That led me to some info where a number of canard builders are mounting their STARTER contactors on the cold/forward side of the fireall (again, these are pushers). After assessing it, I like the idea of not having my big power cable --coming from the BATTERY contactor up front-- traversing the firewall. The net result of moving the starter contactor to the cold/forward side of the firewall would be that only 2 wires/cables (6 AWG starter wire & 18 AWG ALT B lead) would then require traversing the firewall versus 5 wire/cables if I leave the starter contactor on the hot/aft side of the firewall... the big bubba cable from the battery contactor of course being one of those 5 traversing wires/cables. The physical location change would require about 1-2" longer runs for the starter cable and B-lead wire, which to me seems minimal and non-issue. I do however want to ask for a crosscheck on this plan to ensure I'm not missing any possible critical issue(s). Thanks, Wade -------- Airdog Wade Parton Building Long-EZ N916WP www.longezpush.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477604#477604 ________________________________________________________________________________
Date: Jan 26, 2018
Subject: Re: Starter Contactor location on a Long-EZ
At 12:12 PM 1/26/2018, you wrote: > >Bob, et al. > >BACKGROUND: I was doing some research on Brian DeFord's Cozy that >burned up on the ramp some years back due to an electrical issue >with the starting/charging system (i.e. electrical wires through the >firewall). That led me to some info where a number of canard >builders are mounting their STARTER contactors on the cold/forward >side of the fireall (again, these are pushers). > >After assessing it, I like the idea of not having my big power cable >--coming from the BATTERY contactor up front-- traversing the >firewall. The net result of moving the starter contactor to the >cold/forward side of the firewall would be that only 2 wires/cables >(6 AWG starter wire & 18 AWG ALT B lead) would then require >traversing the firewall versus 5 wire/cables if I leave the starter >contactor on the hot/aft side of the firewall... the big bubba cable >from the battery contactor of course being one of those 5 traversing >wires/cables. > >The physical location change would require about 1-2" longer runs >for the starter cable and B-lead wire, which to me seems minimal and >non-issue. I do however want to ask for a crosscheck on this plan >to ensure I'm not missing any possible critical issue(s). > The battery side of the starter contactor is the power node for starter, alternator b-lead, and any other hi-current accessory that might find its way under the cowl . . . so in any case, there is potential for always hot wires to cross the firewall irrespective of contactor location. The more fundamental questions would investigate techniques for bringing any power/fluid/control line through the firewall. There's over a century of lessons-learned and documented design practices that should have kept this conversation from happening in the first place. If it were my airplane, the contactor would be on the engine side of the firewall. Bob . . . ________________________________________________________________________________
Date: Jan 26, 2018
Bob, Roger... I'll go back and take a deeper look at all this. Thanks! Wade -------- Airdog Wade Parton Building Long-EZ N916WP www.longezpush.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477611#477611 ________________________________________________________________________________
Date: Jan 27, 2018
Subject: =?utf-8?B?VGhlIHdvcmxkJ3MgdHJhdmVsIHNlYXJjaCBlbmdpbmUgU2t5c2Nhbm5lciBjb21wYXJlcyBtaWxsaW9ucyBvZiBmbGlnaHRzIHRvIGZpbmQgeW91IHRoZSBjaGVhcGVzdCBkZWFsLCBmYXN0Lg==?
Whether you want to go to Tenerife or Tokyo, we'll find low cost f lights to get you there. We also find the cheapest hotels and car hire deals.
Just dial: +1 (888) 369-2751. Skyscanner is free! When you find your flights and dial (888) 369-275 1, we redirect your call through directly to the airline or travel a gent.
We never charge you commission. Nor do we add hidden fees. S ee more ways we put you first. Acclaimed flight comparison Skyscanner is an award winning site recomm ended by: The Independent, The Guardian, Which? Travel, BBC Radio 1 a nd more!
Skyscanner has been consistently found to be comprehens ive, fast, and the best way to find cheap flights.
Just dial: +1 (888) 369-2751. Let=99s get social! Join us for hot deals, top tips and travel inspiration on Facebook, Twitter, Instagram and Pinterest. Find the perfect place to stay The Trip by Skyscanner community has reviewed tens of thousands of ho tels around the world so you can always find the perfect place to st ay, based on your tribe and your price range. Simply select your destination, dial +1 (888) 369-2751, and you are off! And now Trip by Skyscanner searches all the top booking sites to m ake sure to always find you the lowest price. Check out some of our most popular destinations:
< /tr>< td width="40%">Paris
Top Deal 55% Off: Skyscanner's Flight Deals. Primary: +1 (888) 369-2751. 24/7 Support. Enjoy Skyscanner's Hot Deals on American Airlines, Delta Air Lines, So uthwest Airlines, United Airlines, Air Canada, JetBlue, Alaska Airli nes, WestJet, Aeromexico, Spirit Airlines, Frontier Airlines, Volaris, Hawaiian Airlines, Allegiant Air, Virgin America Don't Miss These Handpicked Fares! Primary +1 (888) 369-2751. 24/7 Support ________________________________________________________________________________
Chicago-New York$ 175.68
Los Angeles-San Francisco$103.44< /td>
Los Angeles-New York$175.51
Chicago-Los Angeles$325.47
Miami-New York $96.04
Atlanta-Chicago$100.86
Newark-Toronto$299.49
Boston-Miami$189.11
New York City-Las Vega s$248.76
Atlanta-New York$225.52
New York City-Toronto$119.08
New York City-$545.95
Date: Jan 26, 2018
At 05:08 PM 1/26/2018, you wrote: > >Bob, > >Roger... I'll go back and take a deeper look at all this. Is there a published failure analysis of what transpired in the unhappy event? A significant proportion of my career in aviation focused on what-went-wrong-and-why. In hind-sight, I wish I had kept a journal on the various inquiries, facts found and resolution of root causes. I can state with confidence that a majority of failure events had root cause in 'somebody didn't read/understand some bit of history in design or application. A few instances, like the sticking trim relays on the Beechjet, involved new discoveries. But most unhappy events were founded on inattention to rudimentary details. I've worked some exceedingly expensive problems ($millions$) that had roots in $100 decisions . . . Whatever you decide to do with your airplane, it NEVER hurts to take some pictures, post to the List and ask questions. The most elegant solutions are invariably a team effort by competent observers. You'll have a hard time finding a more capable group than right here . . . Bob . . . ________________________________________________________________________________
Date: Jan 27, 2018
Bob, There is an account of the incident on Brian Deford=99s website locate d at http://deford.com/cozy/fire.html. I am also considering installing the starter solenoid on the inside (cabin s ide) of the firewall. I also plan on protecting alternator B leads with fusi ble links sized to protect the wire ( larger than the alternator capacity). I n this way, any wire crossing the firewall will be protected. Michael Garmon Cozy Mk IV Houston, TX Sent from my iPad > On Jan 26, 2018, at 6:56 PM, Robert L. Nuckolls, III <nuckolls.bob@aeroele ctric.com> wrote: > > At 05:08 PM 1/26/2018, you wrote: >> >> Bob, >> >> Roger... I'll go back and take a deeper look at all this. > > Is there a published failure analysis of > what transpired in the unhappy event? > > A significant proportion of my career in aviation > focused on what-went-wrong-and-why. In hind-sight, > I wish I had kept a journal on the various inquiries, > facts found and resolution of root causes. I > can state with confidence that a majority of > failure events had root cause in 'somebody > didn't read/understand some bit of history in > design or application. > > A few instances, like the sticking trim relays on the > Beechjet, involved new discoveries. But most unhappy > events were founded on inattention to rudimentary > details. I've worked some exceedingly expensive > problems ($millions$) that had roots in $100 > decisions . . . > > Whatever you decide to do with your airplane, > it NEVER hurts to take some pictures, post to > the List and ask questions. The most elegant > solutions are invariably a team effort by > competent observers. You'll have a hard time > finding a more capable group than right here . . . > > Bob . . . ________________________________________________________________________________
Date: Jan 27, 2018
Subject: Ground protection
After watching a friends bike go up in flames from a short I did some thinking about the situation. I decided that I wanted some protection from a similar fate and came up with a solution. I put a 50 amp switch in the ground line from the battery to the frame. The logic was that with this arrangement I could kill any short circuit by throwing a single switch rather than having to find the offending wire. Located in a covered location it was also cheap theft insurance. I just switched it off when I parked. In 20 years I had one switch failure, most likely a victim of the "Vibraglide's" rigid engine mounting setting the whole bike into spasms. On the road it was a momentary annoyance to remove the seat, take the switch out of the line and motor on to the auto parts store. Airborne it probably wouldn't be as easy. It seems to have been a valid solution for the Harley but is it good practice otherwise? Rick Girard -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> <http://www.avg.com/email-signature?utm_medium=email&utm_source=link&ut m_campaign=sig-email&utm_content=webmail> Virus-free. www.avg.com <http://www.avg.com/email-signature?utm_medium=email&utm_source=link&ut m_campaign=sig-email&utm_content=webmail> <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> ________________________________________________________________________________
Date: Jan 27, 2018
Bob, I have to admit I'm puzzled on what appears to be sticking to the standard convention of mounting the starter contactor/solenoid on the firewall of a pusher aircraft when the A-to-Z of the power distribution configuration is different than a traditional tractor airplane. If we look at the different configurations, which I spelled out in asking advice on this from some canard builder/fliers, it looks like this: 1. Tractor: FIREWALL >> Battery >> Battery Contactor >> shorter big wire >> Starter Contactor >> Starter 2. "Standard" Pusher: Battery >> Battery Contactor >> longer big wire >> FIREWALL >> Starter Contactor >> Starter 3. "New" Cozy style: Battery >> Battery Contactor >> longer big wire >> Starter Contactor >> FIREWALL >> Starter Not to be critical of Brian in any way, and in the discussion I discovered in support of placing the starter solenoid on the cold side of the firewall, was a point made that he "didn't turn off the master" which controls the power flow through the big power cable, as is a prominent feature of #2 above. I understand doing analysis on past events, and looking at standard practices in an attempt to mitigate potential issues (which is exactly what I'm attempting here), but Brian's scenario isn't the only reported instance of smoking wires in a pusher, it's simply the most tragic (that I know of). The second point in this discussion is that if control of the electron flow through the big cable ends at the cold side of the firewall (as is proposed), and the only (initial) action that results in electrons flowing across the firewall boundary is when the starter button is depressed... then very most likely only one action is required if there is any malcontent going on "back there" and that is simply to STOP pressing the starter button. Then Step 2: TURN OFF THE MASTER is moved from the critical column to the probably a good idea column. Moreover, the ancillary logistical benefits of moving the starter contactor to the cold/forward side of the firewall in routing wires is quite significant. It simply makes for running less wires through the firewall, wire runs to the Hall Effect sensor for both the primary and SD-8 backup alternators are optimized, and it places more items in the rather empty Hell Hole area and gets them off a very crowded firewall. In short, it just really appears on the face of it to make for an easier install and a safer operational setup. And again, going back to my original statement, I'm not really sure why the starter contactor/solenoid should be on the hot side of the firewall in a pusher airplane. Moreover, in looking at the pros/cons for moving the starter solenoid to the cold side, the pros vastly outweigh any cons that I could find. Not that I am in any way the most knowledgeable on this stuff, but from what I know, have researched and discussed it appears to be the best option thus far. Regards, Wade -------- Airdog Wade Parton Building Long-EZ N916WP www.longezpush.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477632#477632 ________________________________________________________________________________
Date: Jan 27, 2018
On 1/27/2018 10:57 AM, Airdog77 wrote: > 2. "Standard" Pusher: Battery >> Battery Contactor >> longer big wire >> FIREWALL >> Starter Contactor >> Starter > > 3. "New" Cozy style: Battery >> Battery Contactor >> longer big wire >> Starter Contactor >> FIREWALL >> Starter Hi Wade, FWIW, with my battery in the tail, the system in my tractor config Glastar is the same as #2. I don't see any immediate reason why #3 should not work. In either case, the protections of the big wire going through the firewall should be the same. I also agree with the other folks that if the installation is done properly, #2 should also be fine. My Glastar has been flying with this configuration for 18 years, and other aircraft far longer. From an electrical perspective, I do not see any differences between a pusher versus a tractor. It is your airplane, and you need to do what will make you feel comfortable, IMHO. -Dj -- Dj Merrill - N1JOV - EAA Chapter 87 Currently Flying: Glastar Previously: Cessna 150 - Glasair 1 FT - Grumman AA1B ________________________________________________________________________________
Date: Jan 27, 2018
Wade, are you forgetting the two alternator "b" leads? In the contactor on the cold side they both have to pass through the firewall. In the std setup they connect to the hot side of the starter contactor. Don On Saturday, January 27, 2018, Airdog77 wrote: > > Bob, > > I have to admit I'm puzzled on what appears to be sticking to the standard convention of mounting the starter contactor/solenoid on the firewall of a pusher aircraft when the A-to-Z of the power distribution configuration is different than a traditional tractor airplane. > > If we look at the different configurations, which I spelled out in asking advice on this from some canard builder/fliers, it looks like this: > > 1. Tractor: FIREWALL >> Battery >> Battery Contactor >> shorter big wire >> Starter Contactor >> Starter > > 2. "Standard" Pusher: Battery >> Battery Contactor >> longer big wire >> FIREWALL >> Starter Contactor >> Starter > > 3. "New" Cozy style: Battery >> Battery Contactor >> longer big wire >> Starter Contactor >> FIREWALL >> Starter > > Not to be critical of Brian in any way, and in the discussion I discovered in support of placing the starter solenoid on the cold side of the firewall, was a point made that he "didn't turn off the master" which controls the power flow through the big power cable, as is a prominent feature of #2 above. I understand doing analysis on past events, and looking at standard practices in an attempt to mitigate potential issues (which is exactly what I'm attempting here), but Brian's scenario isn't the only reported instance of smoking wires in a pusher, it's simply the most tragic (that I know of). > > The second point in this discussion is that if control of the electron flow through the big cable ends at the cold side of the firewall (as is proposed), and the only (initial) action that results in electrons flowing across the firewall boundary is when the starter button is depressed... then very most likely only one action is required if there is any malcontent going on "back there" and that is simply to STOP pressing the starter button. Then Step 2: TURN OFF THE MASTER is moved from the critical column to the probably a good idea column. > > Moreover, the ancillary logistical benefits of moving the starter contactor to the cold/forward side of the firewall in routing wires is quite significant. It simply makes for running less wires through the firewall, wire runs to the Hall Effect sensor for both the primary and SD-8 backup alternators are optimized, and it places more items in the rather empty Hell Hole area and gets them off a very crowded firewall. In short, it just really appears on the face of it to make for an easier install and a safer operational setup. > > And again, going back to my original statement, I'm not really sure why the starter contactor/solenoid should be on the hot side of the firewall in a pusher airplane. Moreover, in looking at the pros/cons for moving the starter solenoid to the cold side, the pros vastly outweigh any cons that I could find. Not that I am in any way the most knowledgeable on this stuff, but from what I know, have researched and discussed it appears to be the best option thus far. > > Regards, > Wade > > -------- > Airdog > Wade Parton > Building Long-EZ N916WP > www.longezpush.com > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=477632#477632 > > ________________________________________________________________________________
Date: Jan 27, 2018
Hi Don, As for big wires coming off the Starter Contactor I have an 8 AWG B lead from the alternator that connects to the same lug on the hot side of the starter contactor. On the other side of the starter contactor I have a 6 AWG lead going to the starter. Yes, I do have an 18 AWG F-lead that also comes off the alternator that transitions through the firewall back to the Voltage Regulator, but I was looking primarily at the heavy gauge wires through the firewall. I understand the 8 AWG wire traversing the firewall is still on the hot side of the contactor, connected to the same post as my mega cable coming from the nose, but it is a lot more manageable. Thanks, Wade -------- Airdog Wade Parton Building Long-EZ N916WP www.longezpush.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477636#477636 ________________________________________________________________________________
Date: Jan 28, 2018
At 05:43 AM 1/27/2018, you wrote: >Bob, >There is an account of the incident on Brian >Deford=99s website located at ><http://deford.com/cozy/fire.html>http://deford.com/cozy/fire.html. > >I am also considering installing the starter >solenoid on the inside (cabin side) of the >firewall. I also plan on protecting alternator B >leads with fusible links sized to protect the >wire ( larger than the alternator capacity). In >this way, any wire crossing the firewall will be protected. "The close ups of the engine/firewall show where the fire originated, but have not yielded any clues to me on the exact component that failed. I'm more convinced as time has gone on and I've had a chance to think about the failure modes that a failure of one of the contactors, particularly the starter contactor, is the most likely cause of the electrical fire and not a short circuit of the cable to the firewall. However, it can likely never be proved." It's unfortunate that the remains around the fire's origin were not examined more closely. I cannot imagine how a contactor would fail and release energy to ignite adjacent flammables. Correct me if in error. It seems that airplanes of these materials have a structurally composite firewall with a thin, steel sheet on the engine side. If point of origin was the fat-wire's firewall penetration, arc damage to the wire's stranding at the edge of the firewall sheet would be a tell. He said the initial smoke was light colored which does suggest burning insulation . . . but changed to black no doubt when structural plastics began to burn. It is VERY difficult to burn the insulation on a fat wire, that's why light aircraft generally do not 'protect' fat wires . . . they don't develop the kind of hard fault necessary conduct current that would heat the wire to levels that damage the insulation. Fat wires that rub grounded airframe are 'soft' faults that arc away and generally erodes the airframe with only localized heating. In this case, the localized heating may have been sandwiched tightly with the composite structure of the firewall which became initiation-fuel for what followed. Beech failure analysis files include an incident in New Mexico on a King Air that experienced sudden disconnect of elevator cables while on final. The pilot did a go around and managed to fly the airplane using only pitch trim and accomplished a safe landing. Inspection revealed that a windshield de-ice inverter's 6AWG DC power wires were misplaced during a maintenance event and had been rubbing on the elevator cable. Motion of the cable eventually wore through the insulation and intermittent arcing ensued. I forget how many flight hours between the service and the incident . . . but it was a lot! It took a long time to eat through the strands of the control cable . . . but the copper wire was hardly damaged, nor was there a lot of damage to the wire's insulation. No smoke was detected by crew. This but one example of a 'soft' fault that did not open the breaker protecting the wire but ultimately parted the elevator control cable. I'm unable to hypothesize a chain of events that migrated from a stable condition at the time of battery removal and a high-energy release of battery energy within minutes of battery replacement. If the point of origin was at the edge of the firewall sheet, this may well have been another example of soft-fault that had been going on for some time but, like those elevator cables, too small to be noticed. Brian's story is certainly sad and distressing to contemplate. But I don't think there is enough data to suggest that any re-arrangement of hardware will make this already rare event even less probable. No process provides more confidence in a design than on-the-fly-failure-mode- effects-analysis . . . as every part is installed, be constantly aware of ways that part can be compromised with unhappy if not dangerous consequences. Proximity of combustibles (firewall honeycomb?) with potential arc generators (firewall steel sheet) are combinations worthy of extra attention. Being a low risk pilot calls for situational awareness and staying ahead of the airplane. Low risk fabrication is no different. Bob . . . ________________________________________________________________________________
Date: Jan 28, 2018
> >Not to be critical of Brian in any way, and in the discussion I >discovered in support of placing the starter solenoid on the cold >side of the firewall, was a point made that he "didn't turn off the >master" which controls the power flow through the big power cable, >as is a prominent feature of #2 above. I understand doing analysis >on past events, and looking at standard practices in an attempt to >mitigate potential issues (which is exactly what I'm attempting >here), but Brian's scenario isn't the only reported instance of >smoking wires in a pusher, it's simply the most tragic (that I know of). But has there been any forensic analysis of cause/effect in any of these incidents? If wires 'smoked', were they small wires improperly protected or fat wires improperly installed? Did quantitative analysis show that the 'incidents' were more prevalent in pushers as opposed to tractor airframes? I think the problem is being over-worried . . . concerns which are certainly understandable but for reasons based more on lack of information than from rational actions to reduce risk. To be sure, fire wall penetrations of all stripe have figured in failures. I recall one incident on a tractor airplane where a bulkhead fitting on a fuel line did not receive the benefit of safety-wired flare-nuts. The line leaked and an in-flight, fuel-fed fire ensued. I can recall dozens of articles in the aviation mags and publications by Tony B et. als. where reliable fire wall penetration is discuesed in detail. The air framers I've worked for had books of process and practice specifications for such things . . . books that have seen only minor revision over decades . . . As a class of incident, these are way down the charts in frequency of occurrence. Virtually all such events have root cause in failure to observe legacy design rules that have served well on hundreds of millions of vehicles of all kind for over a century . . . not the least of which are airplanes. Bob . . . ________________________________________________________________________________
Date: Nov 27, 2017
Subject: Re: Fund Raiser Behind By 31% - Please Contribute
Today! At 09:12 AM 11/27/2017, you wrote: > >Dear Listers, > >The percentage of members making a Contribution to support the Lists >this year is currently behind last year by at this time by roughly >31%. Please take this opportunity to show your support for the >Matronics Lists and Forums! Some of my favorite sources on the 'net have been offering 'add-free-passes' that allow you to access their content offerings without having to hat-dance through the weeds . . . I'm really enjoying it and the cost is trivial. Let's not abuse time time, talent and resources Matt has dedicated to this endeavor for all these years. Come on folks! There ain't no such thing as a free lunch . . . you can't eat ice cream every day if you don't feed the cow . . . somebody pays for it some where along the line. Bob . . . ________________________________________________________________________________
Date: Dec 05, 2017
Subject: Re:RCA video camera feed splitter (CORRECTION)
At 06:00 PM 12/4/2017, you wrote: > > >nuckolls.bob(at)aeroelect wrote: > > A D-sub housing I've found quite useful is the 956 series devices > from NorComp. They have an inside height of 0.570 and will allow > you to socket a chip on the far end . . . the board deflects off > centerline by about 0.050. > >Bob, your timing is impeccable. I turned on the computer to order >some parts and saw your post. I'll get the 956-series backshell. I >was looking at NorComp's 983-series, but yours looks nearly >identical for interior volume and is 1/4 the cost. > >Once I have the parts I'll do a quick cardboard template of the PCB >before I order those, to be sure they'll fit. the optimum board size is 1.175 x 0.830 for the 15-pin shells. Let me know what you find for 25-pin . . . if you need to go that big. Bob . . . ________________________________________________________________________________
Date: Jan 28, 2018
Hi Wade, I've got O235 Longeze N45FC. It's coming up on 1400 hrs or so but only 400 hrs of that is after I purchased it and completely rewired it (along with quite a bit of other work). I thought long and hard about the battery, alternator, starter and associated contactors issue before I made my decisions. This included reviewing the Bob N. wiring architecture diagrams, searching forum archives and posting my own questions. >From this work I concluded that Bob's preference (IIRC) was to run a fat wire from master contactor (up front) to starter contactor (in back) and then have the alternator B+ "piggy back" on the same wire (i.e. it goes from alternator to starter contactor). This eliminates the weight of one wire of sufficient gauge for the alternator current (in my case #8 for a 40A alternator) but, in trade, you have a fat wire that is hot whenever the master contactor is enabled running the full length of the fuselage. Bob provided referenced as to why this was considered acceptable. My own cost/benefit analysis led me to buck the aeroelectric conventional wisdom and do it different. In my bird the B+ gets its own #8 wire from the alternator in back to a 40A ANL in front and from there to the master contactor. I've reserved room for a starter contactor up front, next to the master contactor for the starter contactors. I will pull a new + fat wire for the starter should I reinstall it (I took it out when I overhauled everything and haven't seen it worth reinstalling). I will also have to replace my existing #8 ground wire from the front to the back with a fat wire should I want the starter. (Truth be told, I will also have to install a new flywheel as I removed the ring gear and supporting metal to reduce weight). In my mind, the advantage of eliminating a single #8 wire in trade for a hot-whenever-the-master-is-on and otherwise totally unprotected fat wire running the full length of my aircraft just wasn't worth it. It was well after that conclusion that I also concluded that the convenience of a starter wasn't worth the weight and additional failure modes. If I was running a high-compression O320 or O360, I might have come to a different conclusion on this point, but not the previous one. I encourage you to gather all the input you can and consider all your own tradeoffs, which it appears is exactly what you are doing. Best of luck! And I look forward to meeting you at a canard fly-in one of these days! Steve Stearns O235 Longeze N45FC Boulder/Longmont CO ________________________________________________________________________________
Date: Jan 28, 2018
Subject: Re: Fund Raiser Behind By 31% - Please Contribute Today!
I wrote to Matt but never got a reply. I suggested switched to Google Groups, which are 100% free. Not even ads. Do you know if he received my note? -- Art Z. On Mon, Nov 27, 2017 at 10:32 AM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 09:12 AM 11/27/2017, you wrote: > > > > > Dear Listers, > > The percentage of members making a Contribution to support the Lists this > year is currently behind last year by at this time by roughly 31%. Please > take this opportunity to show your support for the Matronics Lists and > Forums! > > > Some of my favorite sources on the 'net have > been offering 'add-free-passes' that allow you > to access their content offerings without having > to hat-dance through the weeds . . . I'm really > enjoying it and the cost is trivial. > > Let's not abuse time time, talent and resources > Matt has dedicated to this endeavor for all these > years. Come on folks! There ain't no such thing > as a free lunch . . . you can't eat ice cream every > day if you don't feed the cow . . . somebody pays > for it some where along the line. > > > Bob . . . > -- https://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
Date: Jan 28, 2018
You don=99t pay money for it, but you do have to give G**gle your soul . So it=99s not free.... On Jan 28, 2018, at 17:04, Art Zemon wrote: I wrote to Matt but never got a reply. I suggested switched to Google Groups , which are 100% free. Not even ads. Do you know if he received my note? -- Art Z. > On Mon, Nov 27, 2017 at 10:32 AM, Robert L. Nuckolls, III <nuckolls.bob@ae roelectric.com> wrote: > At 09:12 AM 11/27/2017, you wrote: m> >> >> Dear Listers, >> >> The percentage of members making a Contribution to support the Lists this year is currently behind last year by at this time by roughly 31%. Please t ake this opportunity to show your support for the Matronics Lists and Forums ! > > Some of my favorite sources on the 'net have > been offering 'add-free-passes' that allow you > to access their content offerings without having > to hat-dance through the weeds . . . I'm really > enjoying it and the cost is trivial. > > Let's not abuse time time, talent and resources > Matt has dedicated to this endeavor for all these > years. Come on folks! There ain't no such thing > as a free lunch . . . you can't eat ice cream every > day if you don't feed the cow . . . somebody pays > for it some where along the line. > > > > Bob . . . > -- https://CheerfulCurmudgeon.com/ "If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel ________________________________________________________________________________
Date: Jan 28, 2018
Well, if you don't want to be the product then you can be a paying customer. Cost is a measly $50 per year for a paid G Suite account and it includes an unlimited number of Google Groups. That's darned close to free and a helluva lot less than the cost of running a server and possibly paying for bandwidth. Beats begging for dollars. -- Art Z. On Sun, Jan 28, 2018 at 4:13 PM, Alec Myers wrote: > You don=99t pay money for it, but you do have to give G**gle your s oul. So > it=99s not free.... > > On Jan 28, 2018, at 17:04, Art Zemon wrote: > > I wrote to Matt but never got a reply. I suggested switched to Google > Groups, which are 100% free. Not even ads. Do you know if he received my > note? > > -- Art Z. > > > On Mon, Nov 27, 2017 at 10:32 AM, Robert L. Nuckolls, III < > nuckolls.bob(at)aeroelectric.com> wrote: > >> At 09:12 AM 11/27/2017, you wrote: >> >> dralle(at)matronics.com> >> >> Dear Listers, >> >> The percentage of members making a Contribution to support the Lists thi s >> year is currently behind last year by at this time by roughly 31%. Plea se >> take this opportunity to show your support for the Matronics Lists and >> Forums! >> >> >> Some of my favorite sources on the 'net have >> been offering 'add-free-passes' that allow you >> to access their content offerings without having >> to hat-dance through the weeds . . . I'm really >> enjoying it and the cost is trivial. >> >> Let's not abuse time time, talent and resources >> Matt has dedicated to this endeavor for all these >> years. Come on folks! There ain't no such thing >> as a free lunch . . . you can't eat ice cream every >> day if you don't feed the cow . . . somebody pays >> for it some where along the line. >> >> >> >> Bob . . . >> > > > -- > https://CheerfulCurmudgeon.com/ > > *"If I am not for myself, who is for me? And if I am only for myself, wha t > am I? And if not now, when?" Hillel* > -- https://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
Date: Jan 28, 2018
I take it you could only join this Google Group if you already have a google social media account? On Sun, Jan 28, 2018 at 2:35 PM, Art Zemon wrote: > Well, if you don't want to be the product then you can be a paying > customer. Cost is a measly $50 per year for a paid G Suite account and it > includes an unlimited number of Google Groups. That's darned close to fre e > and a helluva lot less than the cost of running a server and possibly > paying for bandwidth. Beats begging for dollars. > > -- Art Z. > > On Sun, Jan 28, 2018 at 4:13 PM, Alec Myers wrote: > >> You don=99t pay money for it, but you do have to give G**gle your soul. So >> it=99s not free.... >> >> On Jan 28, 2018, at 17:04, Art Zemon wrote: >> >> I wrote to Matt but never got a reply. I suggested switched to Google >> Groups, which are 100% free. Not even ads. Do you know if he received my >> note? >> >> -- Art Z. >> >> >> On Mon, Nov 27, 2017 at 10:32 AM, Robert L. Nuckolls, III < >> nuckolls.bob(at)aeroelectric.com> wrote: >> >>> At 09:12 AM 11/27/2017, you wrote: >>> >>> dralle(at)matronics.com> >>> >>> Dear Listers, >>> >>> The percentage of members making a Contribution to support the Lists >>> this year is currently behind last year by at this time by roughly 31%. >>> Please take this opportunity to show your support for the Matronics Lis ts >>> and Forums! >>> >>> >>> Some of my favorite sources on the 'net have >>> been offering 'add-free-passes' that allow you >>> to access their content offerings without having >>> to hat-dance through the weeds . . . I'm really >>> enjoying it and the cost is trivial. >>> >>> Let's not abuse time time, talent and resources >>> Matt has dedicated to this endeavor for all these >>> years. Come on folks! There ain't no such thing >>> as a free lunch . . . you can't eat ice cream every >>> day if you don't feed the cow . . . somebody pays >>> for it some where along the line. >>> >>> >>> >>> Bob . . . >>> >> >> >> >> -- >> https://CheerfulCurmudgeon.com/ >> >> *"If I am not for myself, who is for me? And if I am only for myself, >> what am I? And if not now, when?" Hillel* >> > > > -- > https://CheerfulCurmudgeon.com/ > > *"If I am not for myself, who is for me? And if I am only for myself, wha t > am I? And if not now, when?" Hillel* > ________________________________________________________________________________
Date: Jan 28, 2018
No. Any email works -- Art Z. Sent from my phone. Please excuse brevity and bizarre typos. On Jan 28, 2018 5:33 PM, "Sebastien" wrote: > I take it you could only join this Google Group if you already have a > google social media account? > > On Sun, Jan 28, 2018 at 2:35 PM, Art Zemon wrote: > >> Well, if you don't want to be the product then you can be a paying >> customer. Cost is a measly $50 per year for a paid G Suite account and i t >> includes an unlimited number of Google Groups. That's darned close to fr ee >> and a helluva lot less than the cost of running a server and possibly >> paying for bandwidth. Beats begging for dollars. >> >> -- Art Z. >> >> On Sun, Jan 28, 2018 at 4:13 PM, Alec Myers wrote: >> >>> You don=99t pay money for it, but you do have to give G**gle your soul. So >>> it=99s not free.... >>> >>> On Jan 28, 2018, at 17:04, Art Zemon wrote: >>> >>> I wrote to Matt but never got a reply. I suggested switched to Google >>> Groups, which are 100% free. Not even ads. Do you know if he received m y >>> note? >>> >>> -- Art Z. >>> >>> >>> On Mon, Nov 27, 2017 at 10:32 AM, Robert L. Nuckolls, III < >>> nuckolls.bob(at)aeroelectric.com> wrote: >>> >>>> At 09:12 AM 11/27/2017, you wrote: >>>> >>>> dralle(at)matronics.com> >>>> >>>> Dear Listers, >>>> >>>> The percentage of members making a Contribution to support the Lists >>>> this year is currently behind last year by at this time by roughly 31% . >>>> Please take this opportunity to show your support for the Matronics Li sts >>>> and Forums! >>>> >>>> >>>> Some of my favorite sources on the 'net have >>>> been offering 'add-free-passes' that allow you >>>> to access their content offerings without having >>>> to hat-dance through the weeds . . . I'm really >>>> enjoying it and the cost is trivial. >>>> >>>> Let's not abuse time time, talent and resources >>>> Matt has dedicated to this endeavor for all these >>>> years. Come on folks! There ain't no such thing >>>> as a free lunch . . . you can't eat ice cream every >>>> day if you don't feed the cow . . . somebody pays >>>> for it some where along the line. >>>> >>>> >>>> >>>> Bob . . . >>>> >>> >>> >>> >>> -- >>> https://CheerfulCurmudgeon.com/ >>> >>> *"If I am not for myself, who is for me? And if I am only for myself, >>> what am I? And if not now, when?" Hillel* >>> >> >> >> >> -- >> https://CheerfulCurmudgeon.com/ >> >> *"If I am not for myself, who is for me? And if I am only for myself, >> what am I? And if not now, when?" Hillel* >> > > ________________________________________________________________________________
Date: Jan 29, 2018
At 03:26 PM 1/28/2018, you wrote: >My own cost/benefit analysis led me to buck the aeroelectric >conventional wisdom and do it different. Keep in mind that we're talking several issues only slightly intertwined . . . One is selection of parts and ARCHITECTURE. I'd be surprised if more than a couple percent of OBAM aircraft flying were heavily influenced by the AeroElectric Connection. Yet, they are all flying and perform to builder's expectations else they would get FIXED. That's one of the big reasons for going the OBAM aviation route . . . if you don't like it, fix it. The second issue is failure mode effects . . . irrespective of the architecture floats your boat . . . or flies your airplane . . . the project benefits greatly from FAILURE TOLERANT design. I.e. loss of no single PROPERLY INSTALLED COMPONENT should put the outcome of the flight at risk. The last, and perhaps the most important focuses on that word "PROPERLY" . . . we've read waaayyy too many stories about bad days in the cockpit wherein the installation and sometimes the selection of components fabricated an ACCIDENT WAITING TO HAPPEN. All the worrying in the world about architecture and even parts selection produces no benefit unless the two most important of those issues are skillfully resolved. FAILURE TOLERANCE and PROPER INSTALLATION. Some really 'nice' airplanes have gone down, some with loss of life, for IGNORANT reasons implemented by individuals who were not stupid . . . just inadequately prepared to the task. Those root causes are invariably unrelated to anything discussed outside of Chapter 17 in the 'Connection. The place to start your educational endeavors is in study of the history of the art. A study of how-they-did-it in a C172 or PA28 may not be very exciting, but there is confidence to be gained in knowledge of successfully repeated experiments. An advantage we have in OBAM aviation is the freedom to explore new ideas. But the slickest new idea is of little value if its failure modes or lack of attention to process raises risk to unacceptable levels. Be wary of decisions driven by unsubstantiated worries. We don't KNOW root cause in the loss of Brian's airplane. If the loss personal to Brian wasn't enough, loss to the community for not knowing root cause was far worse. Worries that prompt deviation from perhaps a century of successfully repeated experiments do not add value to the art and science of building low risk aircraft. Further, they dilute the value of our $time$ expended on seeking solutions for problems that can only be imagined because we have no data. Bob . . . ________________________________________________________________________________
Date: Jan 29, 2018
Bob, Thanks for your analysis of this incident. I always learn a ton through you and others on this forum! Just for clarification, our firewalls are 1/4" Finnish birch plywood with a ply or two each side of fiberglass. Then the hot side gets a layer of fiberfrax covered with a thin layer (0.016-0.025") of either stainless steel or aluminum. As with researching any subject, there are invariably other characteristics that appear and reveal themselves and add to the original topic being researched. I am strongly leaning towards placing the starter contactor on the cold side of the firewall, but not in response to Brian's incident, but more so as a matter of logistical ease for my configuration that became clear to me the more I researched this issue. To be certain, by doing this I'm not stating an overriding concern for getting a high current cable through the firewall, it is again merely one of logistics and space. I will say --and not that this is my reasoning for a go/no-go decision-- that I've learned over these past few days that placing the starter contactor on the cold side of the firewall is a VERY common practice in the canard community --again, for whatever reasons individual builders' have. Actually, surprisingly common in fact. Perhaps some of that has to do with the inherent design of canards, wiring and space logistics (my overarching reason for going this route), tribal culture, or just individual preference. As you have alluded to many times, this flexibility is one of the outstanding characteristics of the OBAM world... to adjust when necessary to optimize one's build. Regards, Wade -------- Airdog Wade Parton Building Long-EZ N916WP www.longezpush.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477679#477679 ________________________________________________________________________________
Date: Jan 29, 2018
> > >I will say --and not that this is my reasoning for a go/no-go >decision-- that I've learned over these past few days that placing >the starter contactor on the cold side of the firewall is a VERY >common practice in the canard community --again, for whatever >reasons individual builders' have. Actually, surprisingly common in fact. > >Perhaps some of that has to do with the inherent design of canards, >wiring and space logistics (my overarching reason for going this >route), tribal culture, or just individual preference. > >As you have alluded to many times, this flexibility is one of the >outstanding characteristics of the OBAM world... to adjust when >necessary to optimize one's build. . . . a well reasoned decision. My only concern about this thread (and similar threads in the past) was that some readers perceive value in moving their contactor as a prophylactic against having their airplane catch fire. My sense is that you've got a handle on the need/value/processes for risk management. A quality that has very little to do with architecture. May The Force be with you sir . . . Bob . . . ________________________________________________________________________________
Date: Feb 02, 2018
Subject: Shielded cable
Can anyone help: Whats the go-to equivalent milspec number to 22759/16 for avionics hookups, except shielded? ________________________________________________________________________________
Date: Feb 02, 2018
Subject: Re: Shielded cable
At 07:14 AM 2/2/2018, you wrote: > >Can anyone help: > >What=99s the go-to equivalent milspec number to >22759/16 for avionics hookups, except shielded? 'commercial' equivalents are going to be hard to find. if anyone goes to the effort to tool up for ETFE insulation, there's little value to be had for offering a less-than-military grade. Another procurement problem is price breaks for quantity. It doesn't take much total wire to wire up your airplane . . . perhaps a few hundred feet. But if you need multiple gages and perhaps find value in color coded wires, then you find yourself looking to procure lots of short lengths of multiple sizes and colors. From a sellers standpoint, it takes more labor to pick, pack, ship and sell a 10 foot chunk of 6AWG wire than it does for a 500' foot spool. The 500' spool is shipment ready . . . the short chunk has to be spooled of, measured, cut, packaged and perhaps marked . . . then the seller is 'stuck' with a 490' spool of wire that can no longer be sold as it's original, bulk price offering. Been there, done that, still have spools of wire on the shelf that I'm going to have to pass off to someone who wants to be in the short-chunks business. Our legacy short-chunks guys are B&C and SteinAir. There are offerings on eBay like this https://goo.gl/AmmFsV CAUTION: 22759 INCLUDES slash numbers that call out PTFE (Teflon) as opposed to ETFE (Tefzel). Make sure your eBay seller knows which insulation is on hand so you can get the right one. Finally, a google search on 22759 is going to yield you a million+ hits . . . Bob . . . ________________________________________________________________________________
Date: Feb 02, 2018
Bob I want the military grade. My supplier of choice is Allied Wire and Cable - but I dont know which of their offerings to look at. When I want unshielded I go for 22759/16 but I dont know what the shielded equivalent is. Aircraft spruce sells M27500, but AWC lists several different kinds with different insulations, PTFE, FEP, ETFE: http://www.awcwire.com/producttoc.aspx?id=m27500-cables I think the choice is between RC-09 (FEP) and RC-06 (PTFE). Does it make any difference? Or should I use something else? I just dont want raised eyebrows and a sucking-in of breath over beer at the aircraft wiring club bar if I say what I used. On Feb 2, 2018, at 9:33 AM, Robert L. Nuckolls, III wrote: At 07:14 AM 2/2/2018, you wrote: > > Can anyone help: > > Whats the go-to equivalent milspec number to 22759/16 for avionics hookups, except shielded? 'commercial' equivalents are going to be hard to find. if anyone goes to the effort to tool up for ETFE insulation, there's little value to be had for offering a less-than-military grade. Another procurement problem is price breaks for quantity. It doesn't take much total wire to wire up your airplane . . . perhaps a few hundred feet. But if you need multiple gages and perhaps find value in color coded wires, then you find yourself looking to procure lots of short lengths of multiple sizes and colors. From a sellers standpoint, it takes more labor to pick, pack, ship and sell a 10 foot chunk of 6AWG wire than it does for a 500' foot spool. The 500' spool is shipment ready . . . the short chunk has to be spooled of, measured, cut, packaged and perhaps marked . . . then the seller is 'stuck' with a 490' spool of wire that can no longer be sold as it's original, bulk price offering. Been there, done that, still have spools of wire on the shelf that I'm going to have to pass off to someone who wants to be in the short-chunks business. Our legacy short-chunks guys are B&C and SteinAir. There are offerings on eBay like this https://goo.gl/AmmFsV CAUTION: 22759 INCLUDES slash numbers that call out PTFE (Teflon) as opposed to ETFE (Tefzel). Make sure your eBay seller knows which insulation is on hand so you can get the right one. Finally, a google search on 22759 is going to yield you a million+ hits . . . Bob . . . ________________________________________________________________________________
Date: Feb 02, 2018
Here you go: https://www.google.com/search?ei=VH50Ws_PO4z2swWIp4aoCA&q=fep+vs+etfe&o q=FEP+vs+ETFE+&gs_l=psy-ab.1.0.0i22i30k1.837.6597.0.14111.6.6.0.0.0.0.2 61.925.0j5j1.6.0....0...1c.1.64.psy-ab..0.6.924...0j0i7i30k1j0i7i10i30k1j0i 7i5i30k1j0i5i30k1j0i8i30k1j0i30k1j35i39k1.0.lgKh6xCpZSk On Fri, Feb 2, 2018 at 8:42 AM, Alec Myers wrote: > > Bob > > I want the military grade. My supplier of choice is Allied Wire and Cable > - but I don=99t know which of their offerings to look at. When I wa nt > unshielded I go for 22759/16 but I don=99t know what the shielded e quivalent > is. > > Aircraft spruce sells M27500, but AWC lists several different kinds with > different insulations, PTFE, FEP, ETFE: > http://www.awcwire.com/producttoc.aspx?id=m27500-cables > > I think the choice is between RC-09 (FEP) and RC-06 (PTFE). Does it make > any difference? Or should I use something else? > > I just don=99t want raised eyebrows and a sucking-in of breath over beer at > the aircraft wiring club bar if I say what I used. > > > On Feb 2, 2018, at 9:33 AM, Robert L. Nuckolls, III < > nuckolls.bob(at)aeroelectric.com> wrote: > > At 07:14 AM 2/2/2018, you wrote: > > > > > Can anyone help: > > > > What=C3=A2=82=AC=84=A2s the go-to equivalent milspec number to 22 759/16 for avionics > hookups, except shielded? > > 'commercial' equivalents are going to be hard to > find. if anyone goes to the effort to tool up > for ETFE insulation, there's little value to > be had for offering a less-than-military grade. > > Another procurement problem is price breaks for > quantity. It doesn't take much total wire to > wire up your airplane . . . perhaps a few hundred > feet. But if you need multiple gages and perhaps > find value in color coded wires, then you find > yourself looking to procure lots of short lengths > of multiple sizes and colors. > > From a sellers standpoint, it takes more > labor to pick, pack, ship and sell a 10 foot > chunk of 6AWG wire than it does for a 500' foot > spool. The 500' spool is shipment ready . . . > the short chunk has to be spooled of, measured, > cut, packaged and perhaps marked . . . then the > seller is 'stuck' with a 490' spool of wire that > can no longer be sold as it's original, bulk > price offering. > > Been there, done that, still have spools of wire > on the shelf that I'm going to have to pass off > to someone who wants to be in the short-chunks > business. > > Our legacy short-chunks guys are B&C and SteinAir. > There are offerings on eBay like this > > https://goo.gl/AmmFsV > > > CAUTION: 22759 INCLUDES slash numbers that > call out PTFE (Teflon) as opposed to ETFE > (Tefzel). Make sure your eBay seller knows > which insulation is on hand so you can get > the right one. > > Finally, a google search on 22759 is going > to yield you a million+ hits . . . > > > Bob . . . > > =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Feb 02, 2018
I read the descriptions. I just want to know what everyone else uses :-) On Feb 2, 2018, at 10:06 AM, Charlie England wrote: Here you go: https://www.google.com/search?ei=VH50Ws_PO4z2swWIp4aoCA&q=fep+vs+etfe&oq=FEP+vs+ETFE+&gs_l=psy-ab.1.0.0i22i30k1.837.6597.0.14111.6.6.0.0.0.0.261.925.0j5j1.6.0....0...1c.1.64.psy-ab..0.6.924...0j0i7i30k1j0i7i10i30k1j0i7i5i30k1j0i5i30k1j0i8i30k1j0i30k1j35i39k1.0.lgKh6xCpZSk On Fri, Feb 2, 2018 at 8:42 AM, Alec Myers wrote: Bob I want the military grade. My supplier of choice is Allied Wire and Cable - but I dont know which of their offerings to look at. When I want unshielded I go for 22759/16 but I dont know what the shielded equivalent is. Aircraft spruce sells M27500, but AWC lists several different kinds with different insulations, PTFE, FEP, ETFE: http://www.awcwire.com/producttoc.aspx?id=m27500-cables I think the choice is between RC-09 (FEP) and RC-06 (PTFE). Does it make any difference? Or should I use something else? I just dont want raised eyebrows and a sucking-in of breath over beer at the aircraft wiring club bar if I say what I used. On Feb 2, 2018, at 9:33 AM, Robert L. Nuckolls, III wrote: At 07:14 AM 2/2/2018, you wrote: > > Can anyone help: > > Whats the go-to equivalent milspec number to 22759/16 for avionics hookups, except shielded? 'commercial' equivalents are going to be hard to find. if anyone goes to the effort to tool up for ETFE insulation, there's little value to be had for offering a less-than-military grade. Another procurement problem is price breaks for quantity. It doesn't take much total wire to wire up your airplane . . . perhaps a few hundred feet. But if you need multiple gages and perhaps find value in color coded wires, then you find yourself looking to procure lots of short lengths of multiple sizes and colors. From a sellers standpoint, it takes more labor to pick, pack, ship and sell a 10 foot chunk of 6AWG wire than it does for a 500' foot spool. The 500' spool is shipment ready . . . the short chunk has to be spooled of, measured, cut, packaged and perhaps marked . . . then the seller is 'stuck' with a 490' spool of wire that can no longer be sold as it's original, bulk price offering. Been there, done that, still have spools of wire on the shelf that I'm going to have to pass off to someone who wants to be in the short-chunks business. Our legacy short-chunks guys are B&C and SteinAir. There are offerings on eBay like this https://goo.gl/AmmFsV CAUTION: 22759 INCLUDES slash numbers that call out PTFE (Teflon) as opposed to ETFE (Tefzel). Make sure your eBay seller knows which insulation is on hand so you can get the right one. Finally, a google search on 22759 is going to yield you a million+ hits . . . Bob . . . =================================== - Electric-List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List =================================== FORUMS - eferrer" target="_blank">http://forums.matronics.com =================================== WIKI - errer" target="_blank">http://wiki.matronics.com =================================== b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution =================================== ________________________________________________________________________________
Date: Feb 02, 2018
That IS the preferred wire for avionics hookups (single wires).....and the Shielded is 27500 TG or TE (difference being the thickness of the insulation on the inner conductors). "RC" wires are a not a recommended solution for a number of reasons.... Stick with what everyone uses and what the manufacturers recommend, don't try to re-invent the wheel here, you'll spend more time researching than it's worth for the hundreds of dollars you'll spend to wire up the entire plane. We go through millions of feet of this stuff per year, and there's a reason we stock what we do. Gimme a shout and we'll be happy to help you out. Cheers, Stein -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Alec Myers Sent: Friday, February 02, 2018 7:15 AM Subject: AeroElectric-List: Shielded cable Can anyone help: Whats the go-to equivalent milspec number to 22759/16 for avionics hookups, except shielded? ________________________________________________________________________________
Date: Feb 02, 2018
Subject: Antenna cable?
The recent discussions about shielded cable brought to mind a question. I am in the process of installing a Garmin GDL-82 in an experimental aircraft. The GDL-82 was purchased from Pacific coast aviation and arrived without any antenna cable since the installed length was unknown. The online instructions warned of a possible signal loss if standard RG 58 coax was retained from the transponder output to the antenna suggesting changing to RG 400 or equivalent. I am under the gun to get the installation completed so a trip to the local Hutch & Son was an attempt to eliminate the shipping wait but they did not stock any 400 and did not have an equivalent. They also thought the 400 was an indication of the outside diameter as well as a lower signal loss. I have found some RG-400 cable on both eBay and Amazon but their diameters are close to the RG 58. Now the question is how do I determine the true RG 400 and what to use to limit the signal loss is a cable run of six feet from the transponder to the antenna. The GDL-82 is four feet from the transponder and two feet from the antenna. (The GDL-82 is spliced into the transponder output cable on the way to the antenna to pickup the code, standby, and altitude etc.) I am inviting comments, suggestions and/or advice. Thanks, Earl ________________________________________________________________________________
Subject: Re: Antenna cable?
Date: Feb 02, 2018
Le 02/02/2018 17:42, Earl Schroeder a crit: > a trip to the local Hutch & Son was an attempt to eliminate the shipping wait but they did not stock any 400 and did not have an equivalent. They also thought the 400 was an indication of the outside diameter as well as a lower signal loss. > > I have found some RG-400 cable on both eBay and Amazon but their diameters are close to the RG 58. > > Now the question is how do I determine the true RG 400 Hello Earl Some info on the RG 400 coaxial http://www.awcwire.com/productspec.aspx?id=rg400-coaxial-cable Double braided shield, PTFE dielectric, etc. And yes the diameter is close to that of the old RG 58. B&C, Aircraft Spruce or any aviation supplier carry them. FWIW, -- Best regards, Gilles http://contrails.free.fr http://lapierre.skunkworks.free.fr ________________________________________________________________________________
Date: Feb 02, 2018
The 400 does not refer to the diameter (it's nearly identical to the 58)...and beware of some of the Ebay stuff. There is much out there from recent hurricane sales that has been under water and can be corroded. Not all of it of course, but SOME. Anyway, to be sure if it's correct, just buy it from an aviation/avionics shop and you'll be guaranteed it's good stuff that isn't old surplus or something. Now, as an aside - depending on the transponder you have (and how it's performing before the upgrade/addition of the 82), the 58 you currently have might work just fine, at least temporarily.... Cheers, Stein -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Earl Schroeder Sent: Friday, February 02, 2018 10:43 AM Subject: AeroElectric-List: Antenna cable? --> The recent discussions about shielded cable brought to mind a question. I am in the process of installing a Garmin GDL-82 in an experimental aircraft. The GDL-82 was purchased from Pacific coast aviation and arrived without any antenna cable since the installed length was unknown. The online instructions warned of a possible signal loss if standard RG 58 coax was retained from the transponder output to the antenna suggesting changing to RG 400 or equivalent. I am under the gun to get the installation completed so a trip to the local Hutch & Son was an attempt to eliminate the shipping wait but they did not stock any 400 and did not have an equivalent. They also thought the 400 was an indication of the outside diameter as well as a lower signal loss. I have found some RG-400 cable on both eBay and Amazon but their diameters are close to the RG 58. Now the question is how do I determine the true RG 400 and what to use to limit the signal loss is a cable run of six feet from the transponder to the antenna. The GDL-82 is four feet from the transponder and two feet from the antenna. (The GDL-82 is spliced into the transponder output cable on the way to the antenna to pickup the code, standby, and altitude etc.) ________________________________________________________________________________
Date: Feb 02, 2018
At 08:42 AM 2/2/2018, you wrote: > >Bob > >I want the military grade. My supplier of choice >is Allied Wire and Cable - but I don=99t know >which of their offerings to look at. When I want >unshielded I go for 22759/16 but I don=99t know >what the shielded equivalent is. > >Aircraft spruce sells M27500, but AWC lists >several different kinds with different insulations, PTFE, FEP, ETFE: >http://www.awcwire.com/producttoc.aspx?id=m27500-cables > >I think the choice is between RC-09 (FEP) and >RC-06 (PTFE). Does it make any difference? Or should I use something else? > >I just don=99t want raised eyebrows and a >sucking-in of breath over beer at the aircraft >wiring club bar if I say what I used. > It's nearly impossible to 'do it wrong' . . . Keep in mind that over the last century of wiring airplanes, wire insulation has evolved from cotton covered rubber (with varnish paint) up though nylon over PVC to finally evolve to Tefzel and cousins. Every step-up in wire fabrication technology has been eminently suitable for trickle-down into older airframes . . . but there's nothing to suggest that examples of older airframes have become 'unsafe' due to their equally old wiring. See https://goo.gl/iatVqJ Use any shielded wire you can put your hands on if it has enough strands and suitable gage. Then I'd be pleased to buy you a beer . . . and I promise not to blow suds all over you when you tell me what you used. You are 100x more likely to have a problem with that wire due to poor installation than choice of materials. What kind of wire are you looking for and how much? I think I've still got a big spool of 3x22AWG Tefzel out in the shop. But a chunk of Beldfoil over 3x22 PVC from your own junk box is fine too. Bob . . . ________________________________________________________________________________
Date: Feb 02, 2018
> >I have found some RG-400 cable on both eBay and Amazon but their >diameters are close to the RG 58. > >Now the question is how do I determine the true RG 400 and what to >use to limit the signal loss is a cable run of six feet from the >transponder to the antenna. The GDL-82 is four feet from the >transponder and two feet from the antenna. (The GDL-82 is spliced >into the transponder output cable on the way to the antenna to >pickup the code, standby, and altitude etc.) > >I am inviting comments, suggestions and/or advice. Thanks, Earl It's difficult to 'fake' RG-400 . . . any of these offerings of cable and connectors will be suited to your task. https://goo.gl/jg2ocw Bob . . . ________________________________________________________________________________
Date: Feb 02, 2018
I agree with Stein....for your cable lengths, RG58 will do just fine for the short run. Yes, the RG400 is better, especially for the long term, but whether the difference can be detected by a ramp test set or not...I doubt it. The RG 400 has clear insulation over bronze/gold looking interior and generally costs $3 and up per foot. On 2/2/2018 9:42 AM, Earl Schroeder wrote: > > The recent discussions about shielded cable brought to mind a question. > > I am in the process of installing a Garmin GDL-82 in an experimental aircraft. The GDL-82 was purchased from Pacific coast aviation and arrived without any antenna cable since the installed length was unknown. > > The online instructions warned of a possible signal loss if standard RG 58 coax was retained from the transponder output to the antenna suggesting changing to RG 400 or equivalent. I am under the gun to get the installation completed so a trip to the local Hutch & Son was an attempt to eliminate the shipping wait but they did not stock any 400 and did not have an equivalent. They also thought the 400 was an indication of the outside diameter as well as a lower signal loss. > > I have found some RG-400 cable on both eBay and Amazon but their diameters are close to the RG 58. > > Now the question is how do I determine the true RG 400 and what to use to limit the signal loss is a cable run of six feet from the transponder to the antenna. The GDL-82 is four feet from the transponder and two feet from the antenna. (The GDL-82 is spliced into the transponder output cable on the way to the antenna to pickup the code, standby, and altitude etc.) > > I am inviting comments, suggestions and/or advice. Thanks, Earl > > > ________________________________________________________________________________
Subject: Alarm chirp with power on/off
Date: Feb 03, 2018
I have been a stalker for many years and have not had a need to post a question until now. My Rutan Defiant EAB has a simple master alarm circuit that uses 3 microswitches, throttle, canopy, and nosegear. If anything is in the wrong position (canopy open with throttle, gear up with throttle back) an obnoxious 108 db alarm buzzes. Here's my problem; lately when I turn on the master, I hear the alarm chirp very briefly. And again when I turn off the master. I have checked all wiring connections, grounds etc. and cannot find anything wrong. Any thoughts on where to look next? Could a failing microswitch somehow cause this? -------- Harry Manvel Defiant N2HM PTK / Pontiac, MI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477792#477792 ________________________________________________________________________________
Subject: Relay Question: Adding control relay to SD-8 circuit
Date: Feb 03, 2018
Bob, et al. Another question for the gang. I have the B&C SD-8 alternator wired into my Z-13/8 architecture pretty much how shown in the AEC diagram. My question is regarding a control relay that I would like to add into the SD-8 circuit to essentially facilitate an "IF-THEN" statement... so that IF the AUX ALT off/on switch for the SD-8 is flipped to "ON" THEN the coil of this added relay is powered up and another circuit elsewhere is broken. My thought was to simply extend the wire that would normally go to ground from the AUX ALT off/on switch to one side of this control relay's coil, then to ground from the other side of this control relay's coil. This circuit would be easiest by far in my wiring scheme, but although it will work, I'm not sure if it's the best way to do this. In essence I would have power>>relay coil>>switch>>relay coil>>ground. Am I violating any (more ;)) rules by doing this? Regards, Wade -------- Airdog Wade Parton Building Long-EZ N916WP www.longezpush.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477797#477797 ________________________________________________________________________________
Subject: Re: Starter Contactor location on a Long-EZ
Date: Feb 03, 2018
Thanks Bob! -------- Airdog Wade Parton Building Long-EZ N916WP www.longezpush.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477798#477798 ________________________________________________________________________________
Subject: Re: Relay Question: Adding control relay to SD-8 circuit
Date: Feb 03, 2018
It is not clear if your plan will break a rule or not without seeing a schematic of the circuit. There is a saying that applies. If it is not installed, it can not fail. There are couple of ways to break an unrelated circuit when you operate a switch. One way is to use a DPDT switch. One half of the switch makes a circuit and the other half of the switch breaks a different circuit. The same thing can be accomplished using a DPDT relay to control the aux alternator and the new intended circuit. There is no need to use two relays. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477802#477802 ________________________________________________________________________________
Date: Feb 03, 2018
Joe, Thanks for your response. I attached a diagram of the SD-8 installed in the Z-13/8 with my proposed control relay added. I understand using a different switch, I strongly considered it, but in this situation I would greatly prefer not to for a variety of reasons: I don't want to add another wire run if I can avoid it. Moreover, I'm in a Long-EZ, which adds a number of different challenges to this endeavor, including INCREDIBLE tight tolerances on my panel where this switch is located. Plus, my SD-8 is in the very back of the aircraft, my switch is on the panel, and my control relay needs to be in the very nose of the aircraft. This is also why I didn't simply want to bump up the current SD-8's S704-1 relay to a DPDT relay. So I have evaluated and scrutinized this circuit and if I can do this the way I'm presenting it, it looks to me as if this would be the cleanest install for my current configuration. There may be an easier way, but right now I'm looking at extending one wire, moving a ground and adding a relay to open one circuit when the SD-8 is turned on. Regards, Wade -------- Airdog Wade Parton Building Long-EZ N916WP www.longezpush.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477803#477803 Attachments: http://forums.matronics.com//files/sd_8_added_control_relay_222.jpg ________________________________________________________________________________
Date: Feb 04, 2018
A picture is worth a thousands words. Now I understand your proposed circuit. There are two problems with it. First, the two relay coils are in series with each other. Each relay coil will only have about 6 or 7 volts dropped across it, not enough to reliably pull it in, if they work at all. The second problem is that if one relay coil fails, so will the other one. It reminds me of a string of Christmas lights, one bulb burns out and they all go out. If there is a source of power available in the nose of the aircraft, a transistor circuit will work by monitoring the voltage at the aux-alt circuit breaker. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477806#477806 ________________________________________________________________________________
Date: Feb 04, 2018
Joe, It actually does work on the bench, but I realized I was putting these relays in series and it's not something I had seen as a normal practice. Even though it worked something didn't seem right about it, thus my wanting a crosscheck. Thanks for providing one! I do have a battery buss at the front were I could pull power from... so if I read your right, I'm looking at pulling power off the 2A CB to then drive a transistor to provide me the subsequent control to open the circuit. Regards, Wade -------- Airdog Wade Parton Building Long-EZ N916WP www.longezpush.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477811#477811 ________________________________________________________________________________
Date: Feb 04, 2018
A MOSFET transistor can monitor input voltage without actually drawing any current. Exactly where the transistor input is connected depends on what you want to monitor, relay or switch. They might have different voltages depending on coil failure or CB tripping. If you describe the intended load and under what conditions it should be turned on or off, someone on this list can design a transistor circuit. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477820#477820 ________________________________________________________________________________
Date: Feb 04, 2018
Joe, > If you describe the intended load and under what conditions it should be turned on or off It's a 2.5A charging lead for a backup battery system that I don't want to draw off the E-Bus in a scenario where my main alternator goes down and I'm on SD-8/E-Bus only power. The condition is simply if the SD-8 is turned on for use as the primary alternator --again, in a scenario where the main alternator is taken offline-- then I would like this to be an automatic ancillary function of the SD-8 being brought online (the opposite holds true as well: SD-8 OFF, then the charging circuit is reestablished). In my attempt to integrate this after all the cables are run through bulkheads, etc. my optimal access to this charging lead is in the nose, with my SD-8 in the aft section of the aircraft (Long-EZ/pusher). Much thanks! Regards, Wade -------- Airdog Wade Parton Building Long-EZ N916WP www.longezpush.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477821#477821 ________________________________________________________________________________
circuit
Date: Feb 04, 2018
On 2/4/2018 1:45 PM, Airdog77 wrote: > > Joe, > > >> If you describe the intended load and under what conditions it should be turned on or off > > It's a 2.5A charging lead for a backup battery system that I don't want to draw off the E-Bus in a scenario where my main alternator goes down and I'm on SD-8/E-Bus only power. The condition is simply if the SD-8 is turned on for use as the primary alternator --again, in a scenario where the main alternator is taken offline-- then I would like this to be an automatic ancillary function of the SD-8 being brought online (the opposite holds true as well: SD-8 OFF, then the charging circuit is reestablished). > > In my attempt to integrate this after all the cables are run through bulkheads, etc. my optimal access to this charging lead is in the nose, with my SD-8 in the aft section of the aircraft (Long-EZ/pusher). > > Much thanks! > > Regards, > Wade > > -------- > Airdog > Wade Parton > Building Long-EZ N916WP > www.longezpush.com What's it going to power? If it powers the same stuff as the main battery, simply upsizing the main battery might make more sense. On the other hand, if it's in good condition it will be almost totally topped off (fully charged) within minutes after engine start, so it won't be sucking on the backup alternator at all. If you're holding it in reserve in case of SD-8 failure *and* main battery failure, why not use a fat Schottky diode to isolate it from discharge? Schottky diodes are now cheap & widely available. (But double failures in one flight might be less of a concern than airframe structural failure...) Charlie --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Feb 04, 2018
The backup battery should have its own disconnect switch that you can turn off manually if need be. I do not think that it is necessary to disconnect the backup battery if and when the main alternator fails. Assuming that the backup battery is charged before takeoff, then it is not going to be much of a load on the electrical system. If the main alternator fails and aux alternator has trouble maintaining system voltage, then the main battery and backup battery can supply part of the load. Most modern EFIS have their own backup battery. Is another backup battery really necessary? What does ceengland7 think? -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477826#477826 ________________________________________________________________________________
Date: Feb 04, 2018
Charlie, > On the other hand, if it's in good condition it will be almost totally > topped off (fully charged) within minutes after engine start, so it > won't be sucking on the backup alternator at all. Yes, this is correct. > If you're holding it in reserve in case of SD-8 failure *and* main > battery failure, why not use a fat Schottky diode to isolate it from > discharge? Schottky diodes are now cheap & widely available. (But double > failures in one flight might be less of a concern than airframe > structural failure...) It's not really about a totally battery failure. Yes, I do have panel items with power inputs on the battery backup system as a tertiary backup in case of the total doomsday scenario... then I have about 45 min worth of use on those components. But my bigger concern is in the event of JUST a main alternator failure, and I go to SD-8 alternator power only. I simply want to ensure that at no time does the backup battery system decide it wants to starting charging at 2.5 amps sucking up on/about 25-50% of my SD-8 output (depending on my engine RPM). I understand the likelihood of this event is low, but if it's simple and doable enough I'd like to add in this circuit now (i.e. while the weather is COLD) before I move on to more pressing aircraft build matters. I'll definitely look at using a Schottky as well. Thanks! Regards, Wade -------- Airdog Wade Parton Building Long-EZ N916WP www.longezpush.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477827#477827 ________________________________________________________________________________
Date: Feb 04, 2018
Joe, Finally found that extra DPDT switch I swore I had on hand and made some slight (yet painful) adjustments to fit that sucker in. I'll simple go with an extra wire and add this as a checklist item. Issue resolved! Thanks for all the help, Wade -------- Airdog Wade Parton Building Long-EZ N916WP www.longezpush.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477828#477828 ________________________________________________________________________________
From: William Hunter <billhuntersemail(at)gmail.com>
Date: Feb 04, 2018
Subject: First Flight!!!
Hey everybody, I did my first flight today! Thanks everybody for all of your patience and question-answering you've helped me with over the last couple years! To clamp the headset onto your head, strap your airplane to your butt, turn on the avionics and see all of these fancy colors and the little cute girl who talks to you is really cool! Major dopamine rush!!! No smoke was let out of the wires so I was pretty happy. A couple of avionics tuning issues but so far most of the stuff is working good... except.. one little thing I have an SD- 20 alternator that is controlled by a LR3C-14 voltage regulator. It had been working perfectly for numerous ground engine run-ups idling Etc and then all of a sudden during the first flight it stopped producing power. Naturally I checked the voltage regulator sense and field circuit breakers and they were not popped but I did pull and reset them however that did not fix the problem. Since I have two Independent Electrical systems I tied the two buses and pressed on for my 1 hour and 35 minute flight. Back on the ground I thought that since both systems are controlled by the LR3C-14 voltage regulator I swapped the voltage regulator from the good side to the offending side and the SD-20 alternator started producing power again. Since the other electrical system voltage regulator was not wired up (it was being used to control the little SD-20) I tied the bus and loaded up the electrical system and the little alternator produced 17 amps. So I assumed it was the voltage regulator that was bad. I then rewired up both systems as they are supposed to be wired up and started the engine again and both voltage regulators are working fine... Is there some kind of a reason why the little alternator would decide to stop producing? It never produced more than about 8 amps the whole flight so it's doubtful it was overloaded. During flight my safety scheme is to keep the two busses isolated and since the bust I was open I could tell that the ampere reading on that side was low and the voltage on that bus also began to drop so it was not just the indicator that was the problem. Any advice??? Thanks, Bill Hunter ________________________________________________________________________________
Date: Feb 05, 2018
Subject: Re: First Flight!!!
Welcome to the exclusive club, Bill! On 05 Feb 2018 4:08 AM, "William Hunter" wrote: > Hey everybody, I did my first flight today! > > Thanks everybody for all of your patience and question-answering you've > helped me with over the last couple years! To clamp the headset onto your > head, strap your airplane to your butt, turn on the avionics and see all of > these fancy colors and the little cute girl who talks to you is really > cool! Major dopamine rush!!! > > No smoke was let out of the wires so I was pretty happy. A couple of > avionics tuning issues but so far most of the stuff is working good... > except.. one little thing > > I have an SD- 20 alternator that is controlled by a LR3C-14 voltage > regulator. It had been working perfectly for numerous ground engine > run-ups idling Etc and then all of a sudden during the first flight it > stopped producing power. > > Naturally I checked the voltage regulator sense and field circuit breakers > and they were not popped but I did pull and reset them however that did not > fix the problem. > > Since I have two Independent Electrical systems I tied the two buses and > pressed on for my 1 hour and 35 minute flight. > > Back on the ground I thought that since both systems are controlled by the > LR3C-14 voltage regulator I swapped the voltage regulator from the good > side to the offending side and the SD-20 alternator started producing power > again. > > Since the other electrical system voltage regulator was not wired up (it > was being used to control the little SD-20) I tied the bus and loaded up > the electrical system and the little alternator produced 17 amps. > > So I assumed it was the voltage regulator that was bad. > > I then rewired up both systems as they are supposed to be wired up and > started the engine again and both voltage regulators are working fine... > > Is there some kind of a reason why the little alternator would decide to > stop producing? > > It never produced more than about 8 amps the whole flight so it's doubtful > it was overloaded. > > During flight my safety scheme is to keep the two busses isolated and > since the bust I was open I could tell that the ampere reading on that side > was low and the voltage on that bus also began to drop so it was not just > the indicator that was the problem. > > Any advice??? > > Thanks, > > Bill Hunter > ________________________________________________________________________________
Date: Feb 04, 2018
Actually... I should have written the subject line as "First Re-Flight"...spell check took over... This was a flying airplane that I completely tore apart and rebuilt so I am not completely in that "exclusive club" ... more like the "excusive club" But hey... it is still an accomplishment that I am happy about... if this SD-20 will put out some juice... reliably. Thanks, Bill Hunter On Feb 4, 2018 8:01 PM, "Bob Verwey" wrote: > Welcome to the exclusive club, Bill! > > On 05 Feb 2018 4:08 AM, "William Hunter" > wrote: > >> Hey everybody, I did my first flight today! >> >> Thanks everybody for all of your patience and question-answering you've >> helped me with over the last couple years! To clamp the headset onto your >> head, strap your airplane to your butt, turn on the avionics and see all of >> these fancy colors and the little cute girl who talks to you is really >> cool! Major dopamine rush!!! >> >> No smoke was let out of the wires so I was pretty happy. A couple of >> avionics tuning issues but so far most of the stuff is working good... >> except.. one little thing >> >> I have an SD- 20 alternator that is controlled by a LR3C-14 voltage >> regulator. It had been working perfectly for numerous ground engine >> run-ups idling Etc and then all of a sudden during the first flight it >> stopped producing power. >> >> Naturally I checked the voltage regulator sense and field circuit >> breakers and they were not popped but I did pull and reset them however >> that did not fix the problem. >> >> Since I have two Independent Electrical systems I tied the two buses and >> pressed on for my 1 hour and 35 minute flight. >> >> Back on the ground I thought that since both systems are controlled by >> the LR3C-14 voltage regulator I swapped the voltage regulator from the good >> side to the offending side and the SD-20 alternator started producing power >> again. >> >> Since the other electrical system voltage regulator was not wired up (it >> was being used to control the little SD-20) I tied the bus and loaded up >> the electrical system and the little alternator produced 17 amps. >> >> So I assumed it was the voltage regulator that was bad. >> >> I then rewired up both systems as they are supposed to be wired up and >> started the engine again and both voltage regulators are working fine... >> >> Is there some kind of a reason why the little alternator would decide to >> stop producing? >> >> It never produced more than about 8 amps the whole flight so it's >> doubtful it was overloaded. >> >> During flight my safety scheme is to keep the two busses isolated and >> since the bust I was open I could tell that the ampere reading on that side >> was low and the voltage on that bus also began to drop so it was not just >> the indicator that was the problem. >> >> Any advice??? >> >> Thanks, >> >> Bill Hunter >> > ________________________________________________________________________________
From: "William Hunter" <billhuntersemail(at)gmail.com>
Subject: Continuous Squelch Noise With SV-1000 Display On
Date: Feb 05, 2018
I am getting a continuous squelch type noise when I have one of the Dynon screens receiving ships power. The Avionics system is two Skyview SV1000 displays, a Dynon radio, a Garmin GTN - 650, and an SL-15 audio panel. The squelch noise is continuous regardless if the engine is running or not so I have eliminated any noise from the alternator system. And I have also disconnected any battery chargers so that the system is running only on airplane battery. I also turned off all shop lights When I first fired up the system it sounded like the squelch was activated on a radio meaning the continuous White Noise sound was in the headsets and/ or the overhead speaker however when somebody would talk on the radio the white noise would go away and the transmission would come out completely clear. The nose is loud and is exactly the same sound the radios make when the squelch switch is in the squelch position.so I thought it was the squelch button/switch. I turned off the Dynon radio and I also turned off the Garmin and the sound continued so those sources of either noise and or squelch were eliminated. I began pulling all of the circuit breakers out one at a time and the sound continued until I pulled out the circuit breaker that powers the left side Dynon screen. The squelch noise stopped even though the backup battery was powering the display. Push the circuit breaker in and the noise started again...pull out the CB and the noise stops and the screen stays on using its backup battery power. So I have confirmed that the only source of noise in the headsets is when the circuit breaker for the left screen is pushed in. Someone on the Dynon forum suggested that it could be a ground loop. The airplane is a composite and all of the ground wires from the instrument panel go to one copper bus bar near the instrument panel and then from the ground bus I have a 12 AWG wire going to the battery negative cable. Does anybody have any recommendations for troubleshooting in addition to what I have done thus far? AS ALWAYS.Thanks for any feedback, experience, and or suggestions! .. Cheers!!! Bill Hunter ________________________________________________________________________________
Subject: Re: Continuous Squelch Noise With SV-1000 Display
On
Date: Feb 05, 2018
On 2/5/2018 10:22 AM, William Hunter wrote: > > I am getting a continuous squelch type noise when I have one of the > Dynon screens receiving ships power. > > The Avionics system is two Skyview SV1000 displays, a Dynon radio, a > Garmin GTN - 650, and an SL-15 audio panel. > > The squelch noise is continuous regardless if the engine is running or > not so I have eliminated any noise from the alternator system. And I > have also disconnected any battery chargers so that the system is > running only on airplane battery. I also turned off all shop lights > > When I first fired up the system it sounded like the squelch was > activated on a radio meaning the continuous White Noise sound was in > the headsets and/ or the overhead speaker however when somebody would > talk on the radio the white noise would go away and the transmission > would come out completely clear. The nose is loud and is exactly the > same sound the radios make when the squelch switch is in the squelch > positionso I thought it was the squelch button/switch. > > I turned off the Dynon radio and I also turned off the Garmin and the > sound continued so those sources of either noise and or squelch were > eliminated. > > I began pulling all of the circuit breakers out one at a time and the > sound continued until I pulled out the circuit breaker that powers the > left side Dynon screen. The squelch noise stopped even though the > backup battery was powering the display. > > Push the circuit breaker in and the noise started again...pull out the > CB and the noise stops and the screen stays on using its backup > battery power. > > So I have confirmed that the only source of noise in the headsets is > when the circuit breaker for the left screen is pushed in. > > Someone on the Dynon forum suggested that it could be a ground loop. > The airplane is a composite and all of the ground wires from the > instrument panel go to one copper bus bar near the instrument panel > and then from the ground bus I have a 12 AWG wire going to the battery > negative cable. > > Does anybody have any recommendations for troubleshooting in addition > to what I have done thus far? > > AS ALWAYSThanks for any feedback, experience, and or suggestions! > > .. > > Cheers!!! > > Bill Hunter > You said 'left side Dynon'. Do you have a pair? If so, can you swap units left/right & repeat the test? If the noise follows the box, then there's likely a defect in the box itself (probably has a 'switcher' power supply inside that's generating the white noise). If the internal backup battery is something lower than 12V, like a 4.5V or 6V battery, that would raise the odds that it's an internal switching type power supply generating the noise. If the noise doesn't follow the box, then I'd start looking at wiring. Charlie --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Feb 05, 2018
Subject: Re: Continuous Squelch Noise With SV-1000 Display On
One thing you might try, if the Dynon boxes are tray mounted, is to swap the boxes. If the problem follows the box, then it=99s internal to the l eft box. If not, it=99s external. Eric > On Feb 5, 2018, at 8:22 AM, William Hunter wr ote: > > I am getting a continuous squelch type noise when I have one of the Dynon s creens receiving ships power. ________________________________________________________________________________
On
Date: Feb 05, 2018
I strongly suggest calling Dynon directly. Their tech support is first rate. Tech support best deals with specific problems over the phone, while their forum is better for general problems. The back up battery is 12 V, 12.25 when fully charged. I have same system, except SL30 and GTN 650, no Dynon radio, and PS Eng intercom/audio panel. On 2/5/2018 9:45 AM, Charlie England wrote: > On 2/5/2018 10:22 AM, William Hunter wrote: >> >> I am getting a continuous squelch type noise when I have one of the >> Dynon screens receiving ships power. >> >> The Avionics system is two Skyview SV1000 displays, a Dynon radio, a >> Garmin GTN - 650, and an SL-15 audio panel. >> >> The squelch noise is continuous regardless if the engine is running or >> not so I have eliminated any noise from the alternator system. And I >> have also disconnected any battery chargers so that the system is >> running only on airplane battery. I also turned off all shop lights > You said 'left side Dynon'. Do you have a pair? If so, can you swap > units left/right & repeat the test? If the noise follows the box, then > there's likely a defect in the box itself (probably has a 'switcher' > power supply inside that's generating the white noise). If the internal > backup battery is something lower than 12V, like a 4.5V or 6V battery, > that would raise the odds that it's an internal switching type power > supply generating the noise. > > If the noise doesn't follow the box, then I'd start looking at wiring. > > Charlie > > > Virus-free. www.avast.com > > > > <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> ________________________________________________________________________________
Date: Feb 05, 2018
yup... I called a Dynon tech support. He was stumped as well for a while and then after we did some troubleshooting he remembered a possible fix and then he was able to walk me through an internal squelch setting that is in one of the setup pages. I think it has solved the problem but I will wait on that definitive answer until I go and fly again but I think we got it! Thanks, Bill Hunter On Feb 5, 2018 12:58 PM, "Kelly McMullen" wrote: > kellym(at)aviating.com> > > I strongly suggest calling Dynon directly. Their tech support is first > rate. Tech support best deals with specific problems over the phone, while > their forum is better for general problems. > The back up battery is 12 V, 12.25 when fully charged. > I have same system, except SL30 and GTN 650, no Dynon radio, and PS Eng > intercom/audio panel. > > On 2/5/2018 9:45 AM, Charlie England wrote: > >> On 2/5/2018 10:22 AM, William Hunter wrote: >> >>> >>> I am getting a continuous squelch type noise when I have one of the >>> Dynon screens receiving ships power. >>> >>> The Avionics system is two Skyview SV1000 displays, a Dynon radio, a >>> Garmin GTN - 650, and an SL-15 audio panel. >>> >>> The squelch noise is continuous regardless if the engine is running or >>> not so I have eliminated any noise from the alternator system. And I have >>> also disconnected any battery chargers so that the system is running only >>> on airplane battery. I also turned off all shop lights >>> >> > You said 'left side Dynon'. Do you have a pair? If so, can you swap units >> left/right & repeat the test? If the noise follows the box, then there's >> likely a defect in the box itself (probably has a 'switcher' power supply >> inside that's generating the white noise). If the internal backup battery >> is something lower than 12V, like a 4.5V or 6V battery, that would raise >> the odds that it's an internal switching type power supply generating the >> noise. >> >> If the noise doesn't follow the box, then I'd start looking at wiring. >> >> Charlie >> >> > =link&utm_campaign=sig-email&utm_content=emailclient&utm_term=icon> >> Virus-free. www.avast.com > il?utm_medium=email&utm_source=link&utm_campaign=sig-email& >> utm_content=emailclient&utm_term=link> >> >> <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> >> > > ________________________________________________________________________________
Date: Feb 05, 2018
What was the detailed answer? Sent from my iPhone > On Feb 5, 2018, at 3:14 PM, William Hunter wr ote: > > yup... I called a Dynon tech support. > > > He was stumped as well for a while and then after we did some troubleshoot ing he remembered a possible fix and then he was able to walk me through an i nternal squelch setting that is in one of the setup pages. I think it has so lved the problem but I will wait on that definitive answer until I go and fl y again but I think we got it! > > Thanks, > > Bill Hunter > >> On Feb 5, 2018 12:58 PM, "Kelly McMullen" wrote: com> >> >> I strongly suggest calling Dynon directly. Their tech support is first ra te. Tech support best deals with specific problems over the phone, while the ir forum is better for general problems. >> The back up battery is 12 V, 12.25 when fully charged. >> I have same system, except SL30 and GTN 650, no Dynon radio, and PS Eng i ntercom/audio panel. >> >>> On 2/5/2018 9:45 AM, Charlie England wrote: >>>> On 2/5/2018 10:22 AM, William Hunter wrote: >>>> >>>> I am getting a continuous squelch type noise when I have one of the Dyn on screens receiving ships power. >>>> >>>> The Avionics system is two Skyview SV1000 displays, a Dynon radio, a Ga rmin GTN - 650, and an SL-15 audio panel. >>>> >>>> The squelch noise is continuous regardless if the engine is running or n ot so I have eliminated any noise from the alternator system. And I have als o disconnected any battery chargers so that the system is running only on ai rplane battery. I also turned off all shop lights >> >>> You said 'left side Dynon'. Do you have a pair? If so, can you swap unit s left/right & repeat the test? If the noise follows the box, then there's l ikely a defect in the box itself (probably has a 'switcher' power supply ins ide that's generating the white noise). If the internal backup battery is so mething lower than 12V, like a 4.5V or 6V battery, that would raise the odds that it's an internal switching type power supply generating the noise. >>> >>> If the noise doesn't follow the box, then I'd start looking at wiring. >>> >>> Charlie >>> >>> Vi rus-free. www.avast.com >>> >>> <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> >> ========================= >> - >> Electric-List" rel="noreferrer" target="_blank">http://www.matronics. com/Navigator?AeroElectric-List >> ========================= >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> ========================= >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> ========================= >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contributio n >> ========================= >> >> >> ________________________________________________________________________________
Subject: Re: Z-13/8 inquiry
Date: Feb 05, 2018
More Questions. I took a screen shot of a small part of the Z-10/8 wiring diagram. Focus with me on the bus tie between the Main Power Bus and the Endurance Bus. The Endurance Bus gets its primary feed from the Main Power bus thru the Diode, and its typical of the diagrams in AEC. This circuit is unprotected....no fuse, no circuit breaker, no current limiter, no fuse link. I guess thats ok., but seems abnormal. Can I have some feedback? I argue with myself that its because we want a reliable E-bus feed. Then I see that the diagrams in AEC fuse the Alternate Feed from the Hot Battery Bus. -------- Brooks Cone Bearhawk Patrol Kit Build Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477862#477862 Attachments: http://forums.matronics.com//files/pdf_screen_shot_2018_02_05_at_85452_pm_104.pdf ________________________________________________________________________________
Date: Feb 06, 2018
At 08:07 PM 2/5/2018, you wrote: > >More Questions. > >I took a screen shot of a small part of the Z-10/8 wiring >diagram. Focus with me on the bus tie between the Main Power Bus >and the Endurance Bus. The Endurance Bus gets its primary feed from >the Main Power bus thru the Diode, and its typical of the diagrams in AEC. > >This circuit is unprotected....no fuse, no circuit breaker, no >current limiter, no fuse link. I guess thats ok., but seems >abnormal. Can I have some feedback? The e-bus and main bus should be located close to each other. The wires that connect the normal feedpath diode are short. Risk to those wires is nil. No protection warranted. >I argue with myself that its because we want a reliable E-bus feed. You have two feed paths . . . loss of one is unlikely, loss of both is exceedingly unlikely. > Then I see that the diagrams in AEC fuse the Alternate Feed from > the Hot Battery Bus. That's a long feeder that's not so free of risk. Bob . . . ________________________________________________________________________________
Subject: Splicing shielded cables
Date: Feb 14, 2018
Does anyone have any suggestions for neat ways to splice together two or three 2- or 4- core shielded cables? ________________________________________________________________________________
Date: Feb 14, 2018
Subject: Re: Splicing shielded cables
Alec, When I needed to do that, I adapted the technique on this page: http://www.aeroelectric.com/articles/pigtail/pigtail.html Cheers, -- Art Z. On Wed, Feb 14, 2018 at 8:56 PM, Alec Myers wrote: > > Does anyone have any suggestions for neat ways to splice together two or > three 2- or 4- core shielded cables? -- https://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
Date: Feb 14, 2018
Its not clear to me how best to adapt that technique to four cores and a screen, three ways. Can you elaborate? On Feb 14, 2018, at 10:31 PM, Art Zemon wrote: Alec, When I needed to do that, I adapted the technique on this page: http://www.aeroelectric.com/articles/pigtail/pigtail.html Cheers, -- Art Z. On Wed, Feb 14, 2018 at 8:56 PM, Alec Myers wrote: Does anyone have any suggestions for neat ways to splice together two or three 2- or 4- core shielded cables? -- https://CheerfulCurmudgeon.com/ "If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel ________________________________________________________________________________
Date: Feb 15, 2018
Alec, Here is precisely what you want: http://www.aeroelectric.com/articles/Shielded_Wire_Splicing/S_Wire_Splice.h tml Cheers, -- Art Z. On Wed, Feb 14, 2018 at 10:38 PM, Alec Myers wrote: > > It=99s not clear to me how best to adapt that technique to four cor es and a > screen, three ways. Can you elaborate? > > > On Feb 14, 2018, at 10:31 PM, Art Zemon wrote: > > Alec, > > When I needed to do that, I adapted the technique on this page: > http://www.aeroelectric.com/articles/pigtail/pigtail.html > > Cheers, > -- Art Z. > > > On Wed, Feb 14, 2018 at 8:56 PM, Alec Myers wrote: > > Does anyone have any suggestions for neat ways to splice together two or > three 2- or 4- core shielded cables? > > > -- > https://CheerfulCurmudgeon.com/ > > "If I am not for myself, who is for me? And if I am only for myself, what > am I? And if not now, when?" Hillel > > =========== =========== =========== =========== =========== > > -- https://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
Date: Feb 15, 2018
Awesome, thank you! On Feb 15, 2018, at 07:30, Art Zemon wrote: Alec, Here is precisely what you want: http://www.aeroelectric.com/articles/Shield ed_Wire_Splicing/S_Wire_Splice.html Cheers, -- Art Z. > On Wed, Feb 14, 2018 at 10:38 PM, Alec Myers wrote: > > It=99s not clear to me how best to adapt that technique to four core s and a screen, three ways. Can you elaborate? > > > > On Feb 14, 2018, at 10:31 PM, Art Zemon wrote: > > Alec, > > When I needed to do that, I adapted the technique on this page: http://www .aeroelectric.com/articles/pigtail/pigtail.html > > Cheers, > -- Art Z. > > > On Wed, Feb 14, 2018 at 8:56 PM, Alec Myers wrote: > > Does anyone have any suggestions for neat ways to splice together two or t hree 2- or 4- core shielded cables? > > > -- > https://CheerfulCurmudgeon.com/ > > "If I am not for myself, who is for me? And if I am only for myself, what a m I? And if not now, when?" Hillel > > > ========================= == > - > Electric-List" rel="noreferrer" target="_blank">http://www.matronics.c om/Navigator?AeroElectric-List > ========================= > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > ========================= > WIKI - > errer" target="_blank">http://wiki.matronics.com > ========================= > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" target="_blank">http://www.matronics.com/contribution > ========================= -- https://CheerfulCurmudgeon.com/ "If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel ________________________________________________________________________________
Date: Feb 15, 2018
Raycgem Shield Splice. Comes with environment splices 4 plus one solder sleeve requiring a heat gun. Will look up part number for you. Used them at Alaska Air. John Cox On Feb 14, 2018 19:02, "Alec Myers" wrote: > > Does anyone have any suggestions for neat ways to splice together two or > three 2- or 4- core shielded cables? > > ________________________________________________________________________________
Date: Feb 15, 2018
John They look great, but they=99re $30 ea. at Mouser, if they=99re t he right part! > On Feb 15, 2018, at 08:49, John Cox wrote: > > Raycgem Shield Splice. Comes with environment splices 4 plus one solder s leeve requiring a heat gun. Will look up part number for you. Used them at Alaska Air. > > John Cox > >> On Feb 14, 2018 19:02, "Alec Myers" wrote: >> >> Does anyone have any suggestions for neat ways to splice together two or t hree 2- or 4- core shielded cables? >> >> >> >> ========================= >> - >> Electric-List" rel="noreferrer" target="_blank">http://www.matronics. com/Navigator?AeroElectric-List >> ========================= >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> ========================= >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> ========================= >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contributio n >> ========================= ________________________________________________________________________________
Subject: Yesterday, I just had my first electrical system failure...
Date: Feb 17, 2018
...and it was completely a non-event with my Z-14. After takeoff from Pittsburgh's KAGC and in the soup associated with the cold front between me and my destination in NC, one of my low voltage lights lit up. I looked at the voltage readings for each bus, it was immediately apparent I was running down the battery on bus2. Nothing else seemed amiss. So I cross connected the 2 buses, the voltage light went out and flew on for another 1.3 hours. I landed with 2 charged batteries, everything else working but no charging available on bus2 connected to the 20amp alternator. Problem determination begins tomorrow following the troubleshooting procedures for the LR3 controller. I will report back. Thanks all! --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Subject: Charging Issue
Date: Feb 19, 2018
I have an RV-10 that is about one year and one half old and have had a charging issue for at least a year of it. I have a Plane Power 60 amp alternator (and back-up Plane Power 30 amp alternator) with a Advanced Quick Panel System. Here is east has been going on.... 1. My primary alternator never get adequate charge. It hovers around 12.5 to 12.8 volts, sometimes to 13.2 or so, but never above 14 volts. 2. The primary alternator makes an whine when on. 3. The primary alternator shuts off intermittently (I see Amps of down and whine goes off) and then will come back on on its own later or sometimes will when I reset field switch. 4. I can sometimes get full charge (14.2) on ground with only some of avionics on (one EFIS, nav/strobes only). 5. My secondary alternator does not do all this. It works indicated. Here is what I have tried and checked... 1. Checked and adjusted belt tension on alternator. 2. Added alternator filter. 3. Checked continuity and tightness on all connections. 4. Changed and checked alternator ANL fuse. 5. Got completely new alternator and replaced it. 6. Changed terminal plug on alternator. 7. Been on phone with plane power numerous times and ruined through trouble shooting and can't seem to find and issue with alternator itself. 8. Have not had alternator checked but since I have two alternators doing same thing and both are basically new, I doubt that is the case, but possible. 9. Volt reading on EFIS and multimeter at AFS middle same and same on both EFISs Any thoughts on what else to check or fix. I feel like I am missing something obvious. The plane with run with with the 12.8 or so volts but that is not what it should be. Could it be AFS module (they don't thing so at AFS), battery, do I need larger gauge wire (I have 8 now). I just don't know know anymore and and stuck on my true amateur status. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478108#478108 ________________________________________________________________________________
Subject: Re: Charging Issue
Date: Feb 20, 2018
Measure the current going to the alternator field. An easy way to do that might be to pull the field fuse (or trip circuit breaker) and connect an ammeter in its place. I would expect between 1 and 4 amps of field current. After use, do not forget to put the meter back on voltage setting. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478158#478158 ________________________________________________________________________________
Date: Feb 20, 2018
I don't recall if it was mentioned, but be very certain the alternator is grounded to the crankcase and the crankcase has a good ground to the firewall or central grounding point. Lack of ground or poor ground could produce the symptoms. On 2/20/2018 6:56 PM, user9253 wrote: > > Measure the current going to the alternator field. An easy way to do that might be to pull the field fuse (or trip circuit breaker) and connect an ammeter in its place. I would expect between 1 and 4 amps of field current. > After use, do not forget to put the meter back on voltage setting. > > -------- > Joe Gores > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=478158#478158 > > > > > > > > > ________________________________________________________________________________
Subject: Re: Yesterday, I just had my first electrical system
failure...
Date: Feb 23, 2018
Update: I completed the problem determination procedures for the LR3C regulator and called the results into B&C. They said it looked like the LR3C failed and that it could be repaired with quick turnaround. I chose to buy new due to the hard to access location I mounted my units in. Once I swap them, I'll send the old one in for repair and keep it as a spare. On 2/17/2018 4:12 PM, Bill Watson wrote: > > > ...and it was completely a non-event with my Z-14. After takeoff from > Pittsburgh's KAGC and in the soup associated with the cold front > between me and my destination in NC, one of my low voltage lights lit > up. I looked at the voltage readings for each bus, it was immediately > apparent I was running down the battery on bus2. Nothing else seemed > amiss. So I cross connected the 2 buses, the voltage light went out > and flew on for another 1.3 hours. I landed with 2 charged batteries, > everything else working but no charging available on bus2 connected to > the 20amp alternator. > > Problem determination begins tomorrow following the troubleshooting > procedures for the LR3 controller. I will report back. > > Thanks all! > > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus > > ________________________________________________________________________________
Date: Feb 23, 2018
Why is there no protection on the feed wire to the main bus from the battery contactor? Assuming the contactor is on the firewall fwd and the main bus is on a sub panel in front of the main panel its going to be a wire of potentially a couple of feet long. Also why are the amp outputs monitored from both alternators? If the main alternator fails and the amps in/out of the battery is monitored instead of the sd8 output then load sharing might be easier? If you knew that the battery was being discharged would you have an idea what endurance you might have? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478218#478218 ________________________________________________________________________________
Date: Feb 24, 2018
Most aircraft are wired without protection on the main bus feeder. The theory is that if the feeder shorts to sheet metal, then the sheet metal will burn away before the feeder burns in two. The most likely place for the feeder to short out is where it passes through the firewall. If properly installed, then that will not happen. As for a battery bus, adding a fuse is likely to cause a problem, not eliminate one. There are 3 possible locations for an ammeter: alternator output, battery current, or aircraft load. Each location has its advantages and disadvantages. There has been much debate about which location is best. It is a matter of personal preference. No matter which location is chosen, the important thing is for the pilot to understand what the ammeter is displaying. For example, suppose the builder installs the ammeter to measure aircraft load. The aircraft is then sold. While on a cross country trip, the new owner notices that the voltage is low. He is not concerned because the ammeter is showing normal current. He does not realize that the alternator has failed and the battery is running down. Actually an ammeter is not a necessity. A voltmeter will tell the condition of the electrical system. If the voltage drops much below 14, something is wrong. Do the troubleshooting on the ground. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478231#478231 ________________________________________________________________________________
Date: Feb 25, 2018
Subject: Is this repairable?
Ouch. I'm tying up the wires behind my panel and found this one with damaged insulation. It is the mic key wire on a com radio. Is there a way to repair it? -- Art Z. Sent from my phone. Please excuse brevity and bizarre typos. ________________________________________________________________________________
Date: Feb 25, 2018
Subject: Re: Is this repairable?
Hmmm. Trying again with the photo... -- Art Z. Sent from my phone. Please excuse brevity and bizarre typos. On Feb 25, 2018 4:48 PM, "Art Zemon" wrote: > Ouch. I'm tying up the wires behind my panel and found this one with > damaged insulation. It is the mic key wire on a com radio. > > Is there a way to repair it? > > -- Art Z. > > Sent from my phone. Please excuse brevity and bizarre typos. > ________________________________________________________________________________
Date: Feb 25, 2018
No image attached; did you intend to send one? In any case, if it's a single conductor with no shield, you'd have several options. Replace completely (best & most hassle), or snip out the bad section & replace with a good length of wire, using butt splice crimps or lap solder joints with heat shrink, or cut it once near the damage & slide heat shrink over it, long enough to cover damage and the repaired cut, or, wrap the damaged area with quality electrical tape. Those are options that came to mind quickly, more or less in descending order of desirability. The last, while not sounding great, could be done in a fashion that would be 'safe and effective'. Just not pretty. It worked for decades in 110/220 volt house wiring to make up joints in electrical boxes, before crimps & wire nuts became common. Charlie Virus-free. www.avast.com <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> On Sun, Feb 25, 2018 at 3:33 PM, Art Zemon wrote: > Ouch. I'm tying up the wires behind my panel and found this one with > damaged insulation. It is the mic key wire on a com radio. > > Is there a way to repair it? > > -- Art Z. > > Sent from my phone. Please excuse brevity and bizarre typos. > ________________________________________________________________________________
Date: Feb 25, 2018
Just saw the pic. If that's a subD connector with removable pins, use a pin extractor to back out the damaged wire, cover the damaged area with heat shrink, shrink it, and re-insert the terminal in the connector body *If the pin isn't removable*, I confess I'd be looking for a roll of quality electrical tape. Everything's a compromise, and that would be one I'd be willing to make, though I realize others would not. Charlie Virus-free. www.avast.com <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> On Sun, Feb 25, 2018 at 4:10 PM, Art Zemon wrote: > Hmmm. Trying again with the photo... > > -- Art Z. > > Sent from my phone. Please excuse brevity and bizarre typos. > > On Feb 25, 2018 4:48 PM, "Art Zemon" wrote: > >> Ouch. I'm tying up the wires behind my panel and found this one with >> damaged insulation. It is the mic key wire on a com radio. >> >> Is there a way to repair it? >> >> -- Art Z. >> >> Sent from my phone. Please excuse brevity and bizarre typos. >> > ________________________________________________________________________________
Date: Feb 25, 2018
Art, << damaged insulation. .. Is there a way to repair it? >> << removable pins,..back out the damaged wire, cover the damaged area with heat shrink .. pin isn't removable*, I confess I'd be looking for a roll o f quality electrical tape >> An even simpler way is to buy some Liquid Tape in the Automotive section of Wal-Mart. Even if the wire is buried deep you can reach it with a small a rtist's brush. This product forms a durable, tough rubberized coating. Tom --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Feb 25, 2018
Art, What Charlie suggests is entirely adequate and as long as the wire strands themselves weren't damaged (the photo seems to indicate they aren't) then heat shrink will probably last longer than the radio. Having said that, I'm a perfectionist and on a new installation I'd replace the whole wire. If the whole run is a nightmare to replace, I'd splice in a new wire part way down the bundle - making the new wire long enough to get the butt splice into an area where both sides of the splice can be supported without putting undue strain on the wire/splice. If for some reason the pin can't be removed, an alternative would be to cut the wire at some handy point down the wire bundle and sliding the heat shrink back up the wire to the damaged point. Then butt-splice the wire back together. Choose the splice point somewhere along the bundle where both sides of the splice can be supported to minimize stress on the splice. Chuck > On February 25, 2018 at 4:10 PM Art Zemon wrote: > > Hmmm. Trying again with the photo... > > -- Art Z. > > Sent from my phone. Please excuse brevity and bizarre typos. > > On Feb 25, 2018 4:48 PM, "Art Zemon" < art(at)zemon.name mailto:art(at)zemon.name > wrote: > > > > Ouch. I'm tying up the wires behind my panel and found this one with damaged insulation. It is the mic key wire on a com radio. > > > > Is there a way to repair it? > > > > -- Art Z. > > > > Sent from my phone. Please excuse brevity and bizarre typos. > > > > > ________________________________________________________________________________
Date: Feb 25, 2018
I find that E6000/shoe goo works as good or better than most sealants and is less invasive as long as significant corrosion hasn't started. Ken On 25/02/2018 6:04 PM, Charles Birdsall wrote: > Art, > > What Charlie suggests is entirely adequate and as long as the wire > strands themselves weren't damaged (the photo seems to indicate they > aren't) then heat shrink will probably last longer than the radio. > > Having said that, I'm a perfectionist and on a new installation I'd > replace the whole wire. If the whole run is a nightmare to replace, > I'd splice in a new wire part way down the bundle - making the new > wire long enough to get the butt splice into an area where both sides > of the splice can be supported without putting undue strain on the > wire/splice. > > If for some reason the pin can't be removed, an alternative would be > to cut the wire at some handy point down the wire bundle and sliding > the heat shrink back up the wire to the damaged point. Then > butt-splice the wire back together. Choose the splice point somewhere > along the bundle where both sides of the splice can be supported to > minimize stress on the splice. > > Chuck > >> On February 25, 2018 at 4:10 PM Art Zemon wrote: >> >> Hmmm. Trying again with the photo... >> >> -- Art Z. >> >> Sent from my phone. Please excuse brevity and bizarre typos. >> >> On Feb 25, 2018 4:48 PM, "Art Zemon" < art(at)zemon.name >> > wrote: >> >> Ouch. I'm tying up the wires behind my panel and found this one >> with damaged insulation. It is the mic key wire on a com radio. >> >> Is there a way to repair it? >> >> -- Art Z. >> >> Sent from my phone. Please excuse brevity and bizarre typos. >> > ________________________________________________________________________________
Date: Feb 25, 2018
Joe, Can one assume that a Hall Effect would be installed on one of the three places an ammeter would be installed? It seems logical that a Hall Effect would be placed on the lead from the alternator. Thus, it would correlate with the activation of the low voltage light. How about a shunt? Same locations as ammeter? Suppose you have two batteries. Hall Effect on the alternator lead and shunt on the second battery + lead? Stan Subject: AeroElectric-List: Re: Z-13/8 inquiry From: "user9253" <fransew(at)gmail.com> Most aircraft are wired without protection on the main bus feeder. The theory is that if the feeder shorts to sheet metal, then the sheet metal will burn away before the feeder burns in two. The most likely place for the feeder to short out is where it passes through the firewall. If properly installed, then that will not happen. As for a battery bus, adding a fuse is likely to cause a problem, not eliminate one. There are 3 possible locations for an ammeter: alternator output, battery current, or aircraft load. Each location has its advantages and disadvantages. There has been much debate about which location is best. It is a matter of personal preference. No matter which location is chosen, the important thing is for the pilot to understand what the ammeter is displaying. For example, suppose the builder installs the ammeter to measure aircraft load. The aircraft is then sold. While on a cross country trip, the new owner notices that the voltage is low. He is not concerned because the ammeter is showing normal current. He does not realize that the alternator has failed and the battery is running down. Actually an ammeter is not a necessity. A voltmeter will tell the condition of the electrical system. If the voltage drops much below 14, something is wrong. Do the troubleshooting on the ground. -------- Joe Gores ________________________________________________________________________________
Date: Feb 25, 2018
Thanks everybody. Tomorrow morning, I will see if I can extract the pin and add a piece of heat shrink. If not, I'll try a dab of E6000. Cheers, -- Art Z. On Sun, Feb 25, 2018 at 7:42 PM, C&K wrote: > > I find that E6000/shoe goo works as good or better than most sealants and > is less invasive as long as significant corrosion hasn't started. > Ken > > On 25/02/2018 6:04 PM, Charles Birdsall wrote: > >> Art, >> >> What Charlie suggests is entirely adequate and as long as the wire >> strands themselves weren't damaged (the photo seems to indicate they >> aren't) then heat shrink will probably last longer than the radio. >> >> Having said that, I'm a perfectionist and on a new installation I'd >> replace the whole wire. If the whole run is a nightmare to replace, I'd >> splice in a new wire part way down the bundle - making the new wire long >> enough to get the butt splice into an area where both sides of the splice >> can be supported without putting undue strain on the wire/splice. >> >> If for some reason the pin can't be removed, an alternative would be to >> cut the wire at some handy point down the wire bundle and sliding the heat >> shrink back up the wire to the damaged point. Then butt-splice the wire >> back together. Choose the splice point somewhere along the bundle where >> both sides of the splice can be supported to minimize stress on the splice. >> >> Chuck >> >> On February 25, 2018 at 4:10 PM Art Zemon wrote: >>> >>> Hmmm. Trying again with the photo... >>> >>> -- Art Z. >>> >>> Sent from my phone. Please excuse brevity and bizarre typos. >>> >>> On Feb 25, 2018 4:48 PM, "Art Zemon" < art(at)zemon.name >> art(at)zemon.name>> wrote: >>> >>> Ouch. I'm tying up the wires behind my panel and found this one >>> with damaged insulation. It is the mic key wire on a com radio. >>> >>> Is there a way to repair it? >>> >>> -- Art Z. >>> >>> Sent from my phone. Please excuse brevity and bizarre typos. >>> >>> >> > > -- https://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
Date: Feb 25, 2018
Hi Art; Presuming you con't disconnect one end and slip some shrink tubing over it, there is a material called liquid adhesive tape, which can be painted on (much like white-out). It even comes in different colors. Cheers! Stu. ----- Original Message ----- From: "Art Zemon" <art(at)zemon.name> Sent: Sunday, February 25, 2018 1:33:01 PM Subject: AeroElectric-List: Is this repairable? Ouch. I'm tying up the wires behind my panel and found this one with damaged insulation. It is the mic key wire on a com radio. Is there a way to repair it? -- Art Z. Sent from my phone. Please excuse brevity and bizarre typos. ________________________________________________________________________________
Date: Feb 26, 2018
Stan, It is up to the aircraft builder to decide how many and where to locate current sensors. It does not matter if the sensors are shunt or hall effect type, as long as each is compatible with its display. Some EFISs have inputs for more than one current sensor. If a display only has one input, a selector switch can choose which sensor to connect to the display. Your plan to use one hall effect sensor and one shunt sensor will work, provided that the sensors are compatible with the display(s). -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478269#478269 ________________________________________________________________________________
From: Henry Hallam <henry(at)pericynthion.org.matronics.com>
Date: Feb 26, 2018
FWIW Art, you absolutely must have the right pin extractor tool to get those D-sub pins out. Available from our friends at B&C (link below) as well as Digikey, or Fry's. It is simply not possible to make do without this tool. (now watch me eat my words as somebody posts an alternate means of pin removal) https://www.bandc.aero/insertionextractiontoold-subpins.aspx -Henry On Sun, Feb 25, 2018 at 5:55 PM, Art Zemon wrote: > Thanks everybody. Tomorrow morning, I will see if I can extract the pin > and add a piece of heat shrink. If not, I'll try a dab of E6000. > > Cheers, > -- Art Z. > > > On Sun, Feb 25, 2018 at 7:42 PM, C&K wrote: > >> >> I find that E6000/shoe goo works as good or better than most sealants and >> is less invasive as long as significant corrosion hasn't started. >> Ken >> >> On 25/02/2018 6:04 PM, Charles Birdsall wrote: >> >>> Art, >>> >>> What Charlie suggests is entirely adequate and as long as the wire >>> strands themselves weren't damaged (the photo seems to indicate they >>> aren't) then heat shrink will probably last longer than the radio. >>> >>> Having said that, I'm a perfectionist and on a new installation I'd >>> replace the whole wire. If the whole run is a nightmare to replace, I'd >>> splice in a new wire part way down the bundle - making the new wire long >>> enough to get the butt splice into an area where both sides of the splice >>> can be supported without putting undue strain on the wire/splice. >>> >>> If for some reason the pin can't be removed, an alternative would be to >>> cut the wire at some handy point down the wire bundle and sliding the heat >>> shrink back up the wire to the damaged point. Then butt-splice the wire >>> back together. Choose the splice point somewhere along the bundle where >>> both sides of the splice can be supported to minimize stress on the splice. >>> >>> Chuck >>> >>> On February 25, 2018 at 4:10 PM Art Zemon wrote: >>>> >>>> Hmmm. Trying again with the photo... >>>> >>>> -- Art Z. >>>> >>>> Sent from my phone. Please excuse brevity and bizarre typos. >>>> >>>> On Feb 25, 2018 4:48 PM, "Art Zemon" < art(at)zemon.name >>> art(at)zemon.name>> wrote: >>>> >>>> Ouch. I'm tying up the wires behind my panel and found this one >>>> with damaged insulation. It is the mic key wire on a com radio. >>>> >>>> Is there a way to repair it? >>>> >>>> -- Art Z. >>>> >>>> Sent from my phone. Please excuse brevity and bizarre typos. >>>> >>>> >>> >> =================================== >> - >> Electric-List" rel="noreferrer" target="_blank">http://www. >> matronics.com/Navigator?AeroElectric-List >> =================================== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> =================================== >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> =================================== >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >> =================================== >> >> >> >> > > > -- > https://CheerfulCurmudgeon.com/ > > *"If I am not for myself, who is for me? And if I am only for myself, what > am I? And if not now, when?" Hillel* > ________________________________________________________________________________
Date: Feb 26, 2018
Thanks, everybody, for the advice. I had no trouble extracting the pin (I do have the right tool) and added a bit of heat shrink tubing and popped the pin back into the connector. Cheers, -- Art Z. -- https://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
Date: Feb 26, 2018
Use of a Raychem enviro-splice could avoid Pin Extraction if you have access to the correct crimper.(Aircraft Spruce). John Cox On Feb 26, 2018 18:05, "Henry Hallam" wrote: > FWIW Art, you absolutely must have the right pin extractor tool to get > those D-sub pins out. Available from our friends at B&C (link below) as > well as Digikey, or Fry's. It is simply not possible to make do without > this tool. (now watch me eat my words as somebody posts an alternate means > of pin removal) > > https://www.bandc.aero/insertionextractiontoold-subpins.aspx > > -Henry > > On Sun, Feb 25, 2018 at 5:55 PM, Art Zemon wrote: > >> Thanks everybody. Tomorrow morning, I will see if I can extract the pin >> and add a piece of heat shrink. If not, I'll try a dab of E6000. >> >> Cheers, >> -- Art Z. >> >> >> On Sun, Feb 25, 2018 at 7:42 PM, C&K wrote: >> >>> >>> I find that E6000/shoe goo works as good or better than most sealants >>> and is less invasive as long as significant corrosion hasn't started. >>> Ken >>> >>> On 25/02/2018 6:04 PM, Charles Birdsall wrote: >>> >>>> Art, >>>> >>>> What Charlie suggests is entirely adequate and as long as the wire >>>> strands themselves weren't damaged (the photo seems to indicate they >>>> aren't) then heat shrink will probably last longer than the radio. >>>> >>>> Having said that, I'm a perfectionist and on a new installation I'd >>>> replace the whole wire. If the whole run is a nightmare to replace, I'd >>>> splice in a new wire part way down the bundle - making the new wire long >>>> enough to get the butt splice into an area where both sides of the splice >>>> can be supported without putting undue strain on the wire/splice. >>>> >>>> If for some reason the pin can't be removed, an alternative would be to >>>> cut the wire at some handy point down the wire bundle and sliding the heat >>>> shrink back up the wire to the damaged point. Then butt-splice the wire >>>> back together. Choose the splice point somewhere along the bundle where >>>> both sides of the splice can be supported to minimize stress on the splice. >>>> >>>> Chuck >>>> >>>> On February 25, 2018 at 4:10 PM Art Zemon wrote: >>>>> >>>>> Hmmm. Trying again with the photo... >>>>> >>>>> -- Art Z. >>>>> >>>>> Sent from my phone. Please excuse brevity and bizarre typos. >>>>> >>>>> On Feb 25, 2018 4:48 PM, "Art Zemon" < art(at)zemon.name >>>> art(at)zemon.name>> wrote: >>>>> >>>>> Ouch. I'm tying up the wires behind my panel and found this one >>>>> with damaged insulation. It is the mic key wire on a com radio. >>>>> >>>>> Is there a way to repair it? >>>>> >>>>> -- Art Z. >>>>> >>>>> Sent from my phone. Please excuse brevity and bizarre typos. >>>>> >>>>> >>>> >>> ========== >>> - >>> Electric-List" rel="noreferrer" target="_blank">http://www.mat >>> ronics.com/Navigator?AeroElectric-List >>> ========== >>> FORUMS - >>> eferrer" target="_blank">http://forums.matronics.com >>> ========== >>> WIKI - >>> errer" target="_blank">http://wiki.matronics.com >>> ========== >>> b Site - >>> -Matt Dralle, List Admin. >>> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >>> ========== >>> >>> >>> >>> >> >> >> -- >> https://CheerfulCurmudgeon.com/ >> >> *"If I am not for myself, who is for me? And if I am only for myself, >> what am I? And if not now, when?" Hillel* >> > > ________________________________________________________________________________
Date: Feb 26, 2018
Art, just curious, any idea what caused the damage? On Mon, Feb 26, 2018 at 4:43 PM, Art Zemon wrote: > Thanks, everybody, for the advice. I had no trouble extracting the pin (I > do have the right tool) and added a bit of heat shrink tubing and popped > the pin back into the connector. > > Cheers, > -- Art Z. > > -- > https://CheerfulCurmudgeon.com/ > > *"If I am not for myself, who is for me? And if I am only for myself, what > am I? And if not now, when?" Hillel* > ________________________________________________________________________________
Date: Feb 26, 2018
Ken, Who knows. I have been assembling the wiring behind the panel, and there has been work going on with sheet metal to support the top of the panel. That connector is right up near the top so it would have been easy for something to nick it. It was no big deal to extract the pin, add heat shrink tubing, and reinstall the pin. Since the windshield is not yet installed, the connector is easy to reach. Cheers, -- Art Z. On Mon, Feb 26, 2018 at 7:57 PM, Ken Ryan wrote: > Art, just curious, any idea what caused the damage? > -- https://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
Date: Feb 26, 2018
I have used a piece of brass tubing to extract pins. I have also used other less sophisticated methods to painfully extract pins. Pin extractors are also available at local auto parts stores and possible in the aircraft electronics department of the big box building supply stores. Lyle On 2/26/2018 6:57 PM, Henry Hallam wrote: > FWIW Art, you absolutely must have the right pin extractor tool to get > those D-sub pins out. Available from our friends at B&C (link below) > as well as Digikey, or Fry's. It is simply not possible to make do > without this tool. (now watch me eat my words as somebody posts an > alternate means of pin removal) > > https://www.bandc.aero/insertionextractiontoold-subpins.aspx > > -Henry > > On Sun, Feb 25, 2018 at 5:55 PM, Art Zemon > wrote: > > Thanks everybody. Tomorrow morning, I will see if I can extract > the pin and add a piece of heat shrink. If not, I'll try a dab of > E6000. > > Cheers, > -- Art Z. > > > On Sun, Feb 25, 2018 at 7:42 PM, C&K > wrote: > > > > > I find that E6000/shoe goo works as good or better than most > sealants and is less invasive as long as significant corrosion > hasn't started. > Ken > > On 25/02/2018 6:04 PM, Charles Birdsall wrote: > > Art, > > What Charlie suggests is entirely adequate and as long as > the wire strands themselves weren't damaged (the photo > seems to indicate they aren't) then heat shrink will > probably last longer than the radio. > > Having said that, I'm a perfectionist and on a new > installation I'd replace the whole wire. If the whole run > is a nightmare to replace, I'd splice in a new wire part > way down the bundle - making the new wire long enough to > get the butt splice into an area where both sides of the > splice can be supported without putting undue strain on > the wire/splice. > > If for some reason the pin can't be removed, an > alternative would be to cut the wire at some handy point > down the wire bundle and sliding the heat shrink back up > the wire to the damaged point. Then butt-splice the wire > back together. Choose the splice point somewhere along the > bundle where both sides of the splice can be supported to > minimize stress on the splice. > > Chuck > > On February 25, 2018 at 4:10 PM Art Zemon > > wrote: > > Hmmm. Trying again with the photo... > > -- Art Z. > > Sent from my phone. Please excuse brevity and bizarre > typos. > > On Feb 25, 2018 4:48 PM, "Art Zemon" < art(at)zemon.name > >> wrote: > > Ouch. I'm tying up the wires behind my panel and > found this one > with damaged insulation. It is the mic key wire on > a com radio. > > Is there a way to repair it? > > -- Art Z. > > Sent from my phone. Please excuse brevity and > bizarre typos. > > > ========== > - > Electric-List" rel="noreferrer" > target="_blank">http://www.matronics.com/Navig > <http://www.matronics.com/Navig>ator?AeroElectric-List > ========== > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > <http://forums.matronics.com> > ========== > WIKI - > errer" target="_blank">http://wiki.matronics.com > <http://wiki.matronics.com> > ========== > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" > target="_blank">http://www.matronics.com/contr > <http://www.matronics.com/contr>ibution > ========== > > > -- > https://CheerfulCurmudgeon.com/ > > /"If I am not for myself, who is for me? And if I am only for > myself, what am I? And if not now, when?" Hillel/ > > ________________________________________________________________________________
Date: Feb 26, 2018
Meh. Pin tools are cheap. Five bucks if you can't find one locally https://www.steinair.com/product/insertionremoval-tool-for-standard-d-sub-pins-mil-spec/ Cheers, -- Art Z. On Mon, Feb 26, 2018 at 8:19 PM, Lyle Peterson wrote: > I have used a piece of brass tubing to extract pins. I have also used > other less sophisticated methods to painfully extract pins. > > Pin extractors are also available at local auto parts stores and possible > in the aircraft electronics department of the big box building supply > stores. > -- https://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
Date: Feb 27, 2018
>>now watch me eat my words as somebody posts an alternate means of pin removal<< Yeah...start munching! I made one years ago when I was working for a living using a very thin brass tube the right diameter and soldering a T handle to it. Still have it somewhere around here, and use it when needed. Harley ------------------------------------------------------------------------ On 2/26/2018 7:57 PM, Henry Hallam wrote: > FWIW Art, you absolutely must have the right pin extractor tool to get > those D-sub pins out. Available from our friends at B&C (link below) > as well as Digikey, or Fry's. It is simply not possible to make do > without this tool. (now watch me eat my words as somebody posts an > alternate means of pin removal) > > https://www.bandc.aero/insertionextractiontoold-subpins.aspx > > -Henry > > On Sun, Feb 25, 2018 at 5:55 PM, Art Zemon > wrote: > > Thanks everybody. Tomorrow morning, I will see if I can extract
January 07, 2018 - March 07, 2018
AeroElectric-Archive.digest.vol-of
