AeroElectric-Archive.digest.vol-oh
April 04, 2018 - April 25, 2018
      >>          retraction would break things.
      >>          This feature was built into the legacy
      >>          'bendix' drive. Starter motor acceleration
      >>          working against pinion gear mass would
      >>          drive it outward on the shaft by means
      >>          of a spiral groove on the shaft . . .
      >>          engine acceleration tending to over-run
      >>          the starter would drive the pinion back
      >>          from the ring gear with the same groove.
      >>         Emacs!
      >>          There have been some hangar-tales of starter
      >>          pinions 'sticking' and back driving starters.
      >>          There have been cases of contactor sticking
      >>          keeping power on the starter thus maintaining
      >>          pinion engagement. But no back driving could
      >>          have occurred due to action of the clutch.
      >>          Had the motor been driven backwards at the
      >>          pinion to ring gear ratio, it would probably
      >>          have slung wires out of the armature and/or
      >>          stripped gear teeth.
      >>          The same gear reduction of pinion-to-ring
      >>          allows starter armature to run at several
      >>          thousand rpm to generated 200 rpm at the
      >>          crankshaft. Okay, after engine start and
      >>          run at 1000 rpm, a back-driving situation would
      >>          spin the starter armature 10000 rpm plus?
      >>          Bob . . .
      >>       Blessed are the cracked, for they shall let in the light.
      >>       Groucho Marx
      >>       <http://www.goodreads.com/author/show/43244.Groucho_Marx>
      >     Avast logo
      >     This email has been checked for viruses by Avast antivirus software.
      >     www.avast.com
      >     <#m_-7793493755374373132_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
      >   Blessed are the cracked, for they shall let in the light. Groucho
      >   Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx>
Date: Apr 04, 2018
Subject: Re: Starter SURGES
Good to know I'm not the only one. Mine wouldn't start one day and I started going through the manual. Check the condenser with this method it said. Bad condenser. The guy at the NAPA store told me, "condensers never go bad, you need a coil". No, I need a condenser. HA HA HA, kid doesn't know anything about cars, does he. They all got a big laugh out of. Finally got them to sell me a damn condenser. Put it in, started right up, took the bad condenser back to NAPA and dared the guy to put it in his car. It wasn't until I was on my way home that it occurred to me, why do you always change points, plugs and condenser if the condenser never fails? Last time I ever went to that store. The manual also said to re-torque the head every 1300 miles. I found out the hard way it was because the head gasket would blow at 1305 miles. Still in all. I loved that car, I cut my teeth on it mechanically and I love Alfas to this day. If I ever hit the Lotto I'm going to blow part of it on a 1938 8C Mille Miglia. And a Tipo 51 Bugatti. The two most beautiful cars made before WWII. IMHO, anyway. Rick On Wed, Apr 4, 2018 at 9:46 PM, Charlie England wrote: > Oh, Lucus. You buried the lead. And explained all the problems in one wor d. > > Just so you know, it didn't get much better in the intervening 11 years; > the '70 Spyder I owned housed a demon who made sure I never knew when it > would start. Always turned over, but the bizarre and primitive > electro-mechanical injection had a mind (or demon) of its own. > > > On 4/4/2018 9:11 PM, Richard Girard wrote: > > Charlie, You're right, the starter was engaged and running but the minute > the engine revved over starting rpm the engine was driving it, too. It's > probably no surprise that the car had English electrics, a mix of Smith a nd > Lucas. Me experience with it was too many ghost problems. The horn began to > blow one night right as I was on my way out for a date. Disconnected the > horn, went on the date and tried to get the horn working the next day. > Reconnected it and nothing wrong. Never failed again. Then there was the > night the passing lights started flashing on their own. Pulled the whole > steering wheel off, went through it, couldn't find anything, put it back > together, worked fine. Never failed again. As much as I loved the car I > began to think of it as Mussolini's revenge. I didn't know about Lucas > then..... > > Rick > > On Wed, Apr 4, 2018 at 8:14 PM, Charlie England > wrote: > >> At 1st glance, I'd suspect there's a flaw in the analysis. If the switch >> wasn't releasing, then the starter was still powered, regardless of whet her >> the engine could drive it or not. That would mean it was running the ent ire >> time the car was running, and starters are not designed for that. Given the >> obvious lack of knowledge about the car and limited expertise of the peo ple >> working on it, with that many service operations by those people working on >> it I'd find it difficult to pick any likely failure mode for the stuff t hat >> failed. Just one thought about the failure of the regulator: uninformed >> installation of the battery, even once. >> >> FWIW, >> >> Charlie >> >> On 4/4/2018 7:49 PM, Richard Girard wrote: >> >> Bob, all, When I graduated high school back in the dark ages I had a 195 9 >> Alfa Romeo Giullietta Spider that had a nightmare starter system. First, >> the electrical system was positive ground. That alone made things >> interesting but the starter, or rather the starter switch was the flash >> point of failure. Why? Because it had no spring return. You had to >> physically turn the starter motor off or the starter would stay connecte d >> with the ring gear and the engine would drive the starter. I was warned by >> the guy who sold me the car and I only left it engaged once for a few >> seconds. The grinding sound was kind of a give away and I got away with it. >> When I sold the car to my best friend I told him what I'd been told, >> "Never, ever let anyone else drive this car". About four weeks after Dav e >> bought it, he let his step brother drive the car. He left the starter >> engaged for the entire 10 miles he drove it. The next day, the battery w as >> dead. When checked, it had internal shorts and was junk. Dave bought a n ew >> Die Hard, the new thing in battery advertising, if not battery technolog y. >> It lasted a couple of weeks and Dave took it back to Sears. The battery was >> tested and failed. He got a new one. It too failed in short order. This >> went on for FOUR batteries before the manager at the Arden Way Sears gav e >> my friend a full refund and refused to sell him any more batteries. >> Somewhere in the mess the starter failed and was replaced, the generator >> failed, the headlights would burn out on a regular basis and my friend >> almost became my ex-friend. He was a poor college student trying to fix the >> car with suggestions from his dad and some mechanics he knew. Finally hi s >> folks loaned him the money to take it to a garage that worked on Alfas a nd >> they determined that the voltage regulator was fried, too. This had gone on >> for almost six months before he finally had the car back in a dependable >> condition. >> So my take is, yeah, drive the starter and turn it into a generator and >> things are going to screw up in a major way. >> >> Rick Girard >> >> PS Probably the worst part came when Dave was finally able to enjoy the >> car again he took it for a drive on a beautiful day. A truck in front of >> him kicked up a stone that went right through the radiator. He pulled in to >> a service station and the engine rattled to a stop. The kid at the pump >> popped open the hood and started filling the radiator before Dave could >> stop him. Put a crack all the way across the roof of the number three >> combustion chamber. >> >> On Wed, Apr 4, 2018 at 4:37 PM, Robert L. Nuckolls, III < >> nuckolls.bob(at)aeroelectric.com> wrote: >> >>> At 03:46 PM 4/4/2018, you wrote: >>> >>> If the bendix gear is sticky, such that the engine is able to drive the >>> starter, I could imagine that it could push a fairly high (albeit short ) >>> number of joules back up the wire. Right? >>> >>> >>> >>> the 'Bendix' drive is gone. All starters >>> use direct engagement solenoids. >>> >>> [image: https://upload.wikimedia.org/wikipedia/commons/f/fb/Starter_mot ] >>> >>> >>> A return spring retracts the pinion >>> gear upon removal of power from the >>> motor. In fact, electrical power to >>> the motor is interrupted during the initial >>> retraction so there is no torque being >>> transmitted from motor to ring gear. >>> At the same time, an overrun clutch >>> >>> * https://tinyurl.com/y7prvn7b * >>> >>> prevents the accelerating engine >>> from back-driving the starter. If >>> this clutch were not present, first >>> motion of the engine during pinion gear >>> retraction would break things. >>> >>> This feature was built into the legacy >>> 'bendix' drive. Starter motor acceleration >>> working against pinion gear mass would >>> drive it outward on the shaft by means >>> of a spiral groove on the shaft . . . >>> engine acceleration tending to over-run >>> the starter would drive the pinion back >>> from the ring gear with the same groove. >>> >>> >>> [image: Emacs!] >>> >>> >>> >>> There have been some hangar-tales of starter >>> pinions 'sticking' and back driving starters. >>> There have been cases of contactor sticking >>> keeping power on the starter thus maintaining >>> pinion engagement. But no back driving could >>> have occurred due to action of the clutch. >>> Had the motor been driven backwards at the >>> pinion to ring gear ratio, it would probably >>> have slung wires out of the armature and/or >>> stripped gear teeth. >>> >>> The same gear reduction of pinion-to-ring >>> allows starter armature to run at several >>> thousand rpm to generated 200 rpm at the >>> crankshaft. Okay, after engine start and >>> run at 1000 rpm, a back-driving situation would >>> spin the starter armature 10000 rpm plus? >>> >>> Bob . . . >>> >> >> >> >> -- >> =9CBlessed are the cracked, for they shall let in the light. =9D Groucho >> Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> >> >> >> >> >> ------------------------------ >> [image: Avast logo] >> >> This email has been checked for viruses by Avast antivirus software. >> www.avast.com >> >> >> <#m_-5736806203088520134_m_-7793493755374373132_DAB4FAD8-2DD7-40BB-A1B8- 4E2AA1F9FDF2> >> > > > -- > =9CBlessed are the cracked, for they shall let in the light. =9D Groucho Marx > <http://www.goodreads.com/author/show/43244.Groucho_Marx> > > -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> ________________________________________________________________________________
Subject: Re: Warm Toggle Switch
Date: Apr 05, 2018
From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com > Subject: Re: AeroElectric-List: Warm Toggle Switch At 09:21 AM 4/4/2018, you wrote: > I went through several warm, hot, and/or shorted > switches that operated my strobes. Tried several > brands of switches all with the same results. > Finally trouble shot the whole system and found > a bad connector crimp on the positive wire that > connected at the strobe power pack. Repaired > same, and haven=99t had a switch problem since. What were your observations for condition of the materials at the failure . . . and do you recall whether the failure was related to materials, installation technique or perhaps both? You mentioned 'shorted' switch . . . were you the builder who was experiencing fuse popping when the strobes were turned OFF? Bob . . . =94=94=94=94=94=94=94=94 =94=94=94=94=94=94=94=94 =94=94- Bob, et., al., I did have a popped fuse or so, but I don=99t think they were related to the shorted switch. The shorted switch toggle itself was electrified when either on or off. On various switches, I found loose connectors, corroded and failed contacts, and in one case, the plastic switch case was partially melted from the heat. Failures were probably related to both materials and installation technique. I=99m not sure all the problems were related to the bad strobe pack connection, but fixing that seems to have solved the problems. Charlie RV-6A, N11CB San Antonio ________________________________________________________________________________
Subject: Starter SURGES
Date: Apr 05, 2018
Ah, Lucas, "The Prince of Darkness"... I had a '63 Austin Healy Sprite that was graced with his presence... Converted to 12v Negative ground "US standard" stuff when the engine was replaced... Cost some $$, but less than the ongoing Lucas part-of-the-week club membership - especially at "import prices"... Jim Parker -------- Original Message -------- Subject: Re: AeroElectric-List: Starter SURGES From: Richard Girard <aslsa.rng(at)gmail.com> Date: Wed, April 04, 2018 9:11 pm Charlie, You're right, the starter was engaged and running but the minute the engine revved over starting rpm the engine was driving it, too. It's probably no surprise that the car had English electrics, a mix of Smith and Lucas. Me experience with it was too many ghost problems. The horn began to blow one night right as I was on my way out for a date. Disconnected the horn, went on the date and tried to get the horn working the next day. Reconnected it and nothing wrong. Never failed again. Then there was the night the passing lights started flashing on their own. Pulled the whole steering wheel off, went through it, couldn't find anything, put it back together, worked fine. Never failed again. As much as I loved the car I began to think of it as Mussolini's revenge. I didn't know about Lucas then..... Rick ________________________________________________________________________________
Date: Apr 05, 2018
Good Find Charlie; Sure sounds like your switch did one of two things or maybe even BOTH: 1 - WELDED the contacts closed and/or, 2 - Mechanically Failed. The mechanical failure could also have been due to the contacts being Welded and when you flip the switch, the weld being stronger than the pivot points of the switch... Ergo, the switch broke! Question: Is the switch WHITE in color? Except for the burnt areas of course? Poor contact(s) ANYWHERE in the circuit increase current draw. The weak point being the switch. ARKENSPARK - - ARKENFARK Hope my original post was helpful. Barry On Thu, Apr 5, 2018 at 10:21 AM, Charles Brame wrote: > From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> > Subject: Re: AeroElectric-List: Warm Toggle Switch > > At 09:21 AM 4/4/2018, you wrote: > > I went through several warm, hot, and/or shorted > switches that operated my strobes. Tried several > brands of switches all with the same results. > Finally trouble shot the whole system and found > a bad connector crimp on the positive wire that > connected at the strobe power pack. Repaired > same, and haven=99t had a switch problem since. > > > What were your observations for condition of > the materials at the failure . . . and do > you recall whether the failure was related > to materials, installation technique or perhaps > both? > > You mentioned 'shorted' switch . . . were you the > builder who was experiencing fuse popping when the > strobes were turned OFF? > > > Bob . . . > > =94=94=94=94=94=94=94=94 =94=94=94=94=94=94=94=94 =94=94- > > Bob, et., al., > > I did have a popped fuse or so, but I don=99t think they were relat ed to > the shorted switch. The shorted switch toggle itself was electrified when > either on or off. On various switches, I found loose connectors, corroded > and failed contacts, and in one case, the plastic switch case was partial ly > melted from the heat. Failures were probably related to both materials an d > installation technique. I=99m not sure all the problems were relate d to the > bad strobe pack connection, but fixing that seems to have solved the > problems. > > Charlie > RV-6A, N11CB > San Antonio > ________________________________________________________________________________
Date: Apr 05, 2018
BARRY CHECK 6 wrote: > Poor contact(s) ANYWHERE in the circuit increase current draw. Generally speaking, this is incorrect. A poor contact increases resistance. Increased resistance causes a decrease in current through a circuit. The exception is an appliance using an internal switching power supply, which functions as a constant power device, drawing whatever combination of voltage and current it can manage to maintain the required output. This is most likely to be seen powering modern avionics and high power LEDs (i.e. landing lights and strobe drivers). For everything else lighting circuits, motors, pumps, heaters and anything with linear voltage regulation the resistance/voltage/current relationship must follow Ohms Law. Eric P.S. On Internet forums, the use of ALL CAPS is considered equivalent to shouting. If youre posting via email rather than the web interface where bold, italics and underline are available, consider sparing use of *asterisks* before and after words you wish to emphasize. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479127#479127 ________________________________________________________________________________
Date: Apr 05, 2018
I agree with Eric Page. Ohm's law rules. And generally speaking, a switch should not get warm. If it does, it is either overloaded, defective (high internal resistance), or its external connections have high resistance. It is OK to use AC rated switches in airplanes. B&C Aero sells AC rated switches. Hundreds of them have been installed in aircraft. Even if the DC rating is not marked on the side of the switch, every switch can carry a certain amount of DC current. Usually switch manufactures will test the DC ampacity of their products and the results are published on their datasheets. When a switch is already closed, it doesn't matter if the current is AC or DC. The issue is what happens when the switch first starts to open (or bounces open while closing). This is where voltage is important. When the contacts of the switch first separate just a hair, an arc jumps across the opening. Since AC current periodically drops to zero, the arc is quickly extinguished. But DC keeps arcing as the contacts spread apart. That arcing damages the contacts. In order to minimize arcing, the DC voltage needs to be reduced. Yes, switches need to be derated when conducting DC. But one way to look at it is that the voltage is derated, not the current. If two identical switches carry equal current, one in a DC circuit and one in an AC circuit, the life expectancy of the switches is equal provided that the DC circuit operates at a reduced voltage. If the AC voltage is 115, a DC voltage of about 28 will result in equal switch life. Most of home-built airplanes have 12 volt electrical systems. At that voltage, a switch can carry more than its 115 VAC current rating, provided that it is snap acting (opens quickly). -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479128#479128 ________________________________________________________________________________
Subject: Re: insulation support for crimps
Date: Apr 05, 2018
HI Bob >> M25036/T7928 What are these? A On Apr 4, 2018, at 11:40 AM, Robert L. Nuckolls, III wrote: At 05:18 PM 4/3/2018, you wrote: > Its not something youve specifically recommended: google for krimptite and youll see some examples of to what I was referring. > Okay. Found this .pdf that speaks to the spectrum of Waldom termnials https://goo.gl/XKMA71 The generic Krimptite devices are the bottom of the features ladder. No insulation grip, rolled, non-welded wire grips. Next step up through the product line adds insulation grips to the non-welded terminals. Next are uninsulated but more robust terminals specifically designed for solid wire and wire grips intended for facilitating 'pulls' of wire thorough a conduit. Stationary applications. Next step up are the AviKrimps . . . the Molex offering to higher performance vehicular applications (like airplanes). These are equivalents to Tyco-Amp PIDG, Panduit PN series and others designed to the spirit and intent of M25036/T7928 The next steps up the ladder are pretty self explanatory. There's a 'high temperature' version of the un=insulated ring terminals designed for use in products like heaters, ovens, furnaces, etc where even companion wires are expected to stand off extra ordinary environmental temperatures . . . temperatures too high for legacy insulation grips but un-necessary since the terminals are not expected to perform under vibration. One does not save much money with the use of terminals outside the bubble of M25036/T7928 products. The uninsulated Krimptite devises would reside outside that bubble. Here's a quick run-down on acme of terminal technologies with about 80 years of history on aircraft and similar applications. <973ee6.jpg> Bob . . . ________________________________________________________________________________
Date: Apr 05, 2018
Google is (sometimes) our friend: https://www.google.com/search?q=M25036&oq=M25036&aqs=chrome..69i57&so urceid=chrome&ie=UTF-8 Virus-free. www.avast.com <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> On Thu, Apr 5, 2018 at 4:20 PM, Alec Myers wrote: > > HI Bob > > >> M25036/T7928 > > What are these? > > A > > On Apr 4, 2018, at 11:40 AM, Robert L. Nuckolls, III < > nuckolls.bob(at)aeroelectric.com> wrote: > > At 05:18 PM 4/3/2018, you wrote: > > It=C3=A2=82=AC=84=A2s not something you=C3=A2=82=AC=84=A2ve specifically recommended: google for > =C3=A2=82=AC=C5=93krimptite=C3=A2=82=AC and you=C3=A2=82=AC =84=A2ll see some examples of to what I was referring. > > > > Okay. Found this .pdf that speaks to the > spectrum of Waldom termnials > > https://goo.gl/XKMA71 > > The generic Krimptite devices are the bottom > of the features ladder. No insulation grip, > rolled, non-welded wire grips. > > Next step up through the product line adds > insulation grips to the non-welded > terminals. > > Next are uninsulated but more robust terminals > specifically designed for solid wire and wire > grips intended for facilitating 'pulls' of > wire thorough a conduit. Stationary applications. > > Next step up are the AviKrimps . . . the Molex > offering to higher performance vehicular > applications (like airplanes). These are equivalents > to Tyco-Amp PIDG, Panduit PN series and others > designed to the spirit and intent of M25036/T7928 > > The next steps up the ladder are pretty self explanatory. > > There's a 'high temperature' version of the un=insulated > ring terminals designed for use in products like heaters, > ovens, furnaces, etc where even companion wires are > expected to stand off extra ordinary environmental > temperatures . . . temperatures too high for legacy > insulation grips but un-necessary since the terminals > are not expected to perform under vibration. > > One does not save much money with the use of terminals > outside the bubble of M25036/T7928 products. The uninsulated > Krimptite devises would reside outside that bubble. > > Here's a quick run-down on acme of terminal technologies > with about 80 years of history on aircraft and similar > applications. > > <973ee6.jpg> > > Bob . . . > > =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Apr 05, 2018
Ah theyre products? It sounded like they were a specification. On Apr 5, 2018, at 5:42 PM, Charlie England wrote: Google is (sometimes) our friend: https://www.google.com/search?q=M25036&oq=M25036&aqs=chrome..69i57&sourceid=chrome&ie=UTF-8 Virus-free. www.avast.com On Thu, Apr 5, 2018 at 4:20 PM, Alec Myers wrote: HI Bob >> M25036/T7928 What are these? A On Apr 4, 2018, at 11:40 AM, Robert L. Nuckolls, III wrote: At 05:18 PM 4/3/2018, you wrote: > Its not something youve specifically recommended: google for krimptite and youll see some examples of to what I was referring. > Okay. Found this .pdf that speaks to the spectrum of Waldom termnials https://goo.gl/XKMA71 The generic Krimptite devices are the bottom of the features ladder. No insulation grip, rolled, non-welded wire grips. Next step up through the product line adds insulation grips to the non-welded terminals. Next are uninsulated but more robust terminals specifically designed for solid wire and wire grips intended for facilitating 'pulls' of wire thorough a conduit. Stationary applications. Next step up are the AviKrimps . . . the Molex offering to higher performance vehicular applications (like airplanes). These are equivalents to Tyco-Amp PIDG, Panduit PN series and others designed to the spirit and intent of M25036/T7928 The next steps up the ladder are pretty self explanatory. There's a 'high temperature' version of the un=insulated ring terminals designed for use in products like heaters, ovens, furnaces, etc where even companion wires are expected to stand off extra ordinary environmental temperatures . . . temperatures too high for legacy insulation grips but un-necessary since the terminals are not expected to perform under vibration. One does not save much money with the use of terminals outside the bubble of M25036/T7928 products. The uninsulated Krimptite devises would reside outside that bubble. Here's a quick run-down on acme of terminal technologies with about 80 years of history on aircraft and similar applications. <973ee6.jpg> Bob . . . =================================== - Electric-List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List =================================== FORUMS - eferrer" target="_blank">http://forums.matronics.com =================================== WIKI - errer" target="_blank">http://wiki.matronics.com =================================== b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution =================================== ________________________________________________________________________________
Date: Apr 06, 2018
Alec: Here is a link to what they are: https://www.google.com/search?q=M25036%2FT7928&rlz=1C1GGRV_enUS749US749 &oq=M25036%2FT7928&aqs=chrome..69i57j69i58.1941j0j8&sourceid=chrome&i e=UTF-8 Barry On Thu, Apr 5, 2018 at 5:20 PM, Alec Myers wrote: > > HI Bob > > >> M25036/T7928 > > What are these? > > A > > On Apr 4, 2018, at 11:40 AM, Robert L. Nuckolls, III < > nuckolls.bob(at)aeroelectric.com> wrote: > > At 05:18 PM 4/3/2018, you wrote: > > It=C3=A2=82=AC=84=A2s not something you=C3=A2=82=AC=84=A2ve specifically recommended: google for > =C3=A2=82=AC=C5=93krimptite=C3=A2=82=AC and you=C3=A2=82=AC =84=A2ll see some examples of to what I was referring. > > > > Okay. Found this .pdf that speaks to the > spectrum of Waldom termnials > > https://goo.gl/XKMA71 > > The generic Krimptite devices are the bottom > of the features ladder. No insulation grip, > rolled, non-welded wire grips. > > Next step up through the product line adds > insulation grips to the non-welded > terminals. > > Next are uninsulated but more robust terminals > specifically designed for solid wire and wire > grips intended for facilitating 'pulls' of > wire thorough a conduit. Stationary applications. > > Next step up are the AviKrimps . . . the Molex > offering to higher performance vehicular > applications (like airplanes). These are equivalents > to Tyco-Amp PIDG, Panduit PN series and others > designed to the spirit and intent of M25036/T7928 > > The next steps up the ladder are pretty self explanatory. > > There's a 'high temperature' version of the un=insulated > ring terminals designed for use in products like heaters, > ovens, furnaces, etc where even companion wires are > expected to stand off extra ordinary environmental > temperatures . . . temperatures too high for legacy > insulation grips but un-necessary since the terminals > are not expected to perform under vibration. > > One does not save much money with the use of terminals > outside the bubble of M25036/T7928 products. The uninsulated > Krimptite devises would reside outside that bubble. > > Here's a quick run-down on acme of terminal technologies > with about 80 years of history on aircraft and similar > applications. > > <973ee6.jpg> > > Bob . . . > > =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Apr 07, 2018
Subject: Re: Charging Issue
I completed my RV-10 in July of 2015. I also have a Plane Power 60A main alternator and a 30A alternator as the back up. And I am having the exact same symtoms. Plane Power tells me I should be getting 14.3 to 14.5 volts on the main and slightly less than that on the backup alternator. Should the main alternator output drop below that of the backup, the backup will take over. Fact is The main puts out 13.4V to 13.6V and the back running by itself puts out about the same. Running both together might get me 13.7V. I bought a new 60A alternator and it did the same. I had both the new and the old tested at a starter/alternator shop and they tested to Plane Power specs at 14.5V. My power distribution system is a modified Bob Knuckles Z-13-8 System. I have noticed there are other RV-10 owners having the same issue. I am David Duperron 616-485-5555. On Mon, Feb 19, 2018 at 9:29 AM, mhealydds wrote: > > I have an RV-10 that is about one year and one half old and have had a > charging issue for at least a year of it. I have a Plane Power 60 amp > alternator (and back-up Plane Power 30 amp alternator) with a Advanced > Quick Panel System. Here is east has been going on.... > 1. My primary alternator never get adequate charge. It hovers around 12.5 > to 12.8 volts, sometimes to 13.2 or so, but never above 14 volts. > 2. The primary alternator makes an whine when on. > 3. The primary alternator shuts off intermittently (I see Amps of down and > whine goes off) and then will come back on on its own later or sometimes > will when I reset field switch. > 4. I can sometimes get full charge (14.2) on ground with only some of > avionics on (one EFIS, nav/strobes only). > 5. My secondary alternator does not do all this. It works indicated. > > Here is what I have tried and checked... > 1. Checked and adjusted belt tension on alternator. > 2. Added alternator filter. > 3. Checked continuity and tightness on all connections. > 4. Changed and checked alternator ANL fuse. > 5. Got completely new alternator and replaced it. > 6. Changed terminal plug on alternator. > 7. Been on phone with plane power numerous times and ruined through > trouble shooting and can't seem to find and issue with alternator itself. > 8. Have not had alternator checked but since I have two alternators doing > same thing and both are basically new, I doubt that is the case, but > possible. > 9. Volt reading on EFIS and multimeter at AFS middle same and same on both > EFISs > > Any thoughts on what else to check or fix. I feel like I am missing > something obvious. The plane with run with with the 12.8 or so volts but > that is not what it should be. Could it be AFS module (they don't thing so > at AFS), battery, do I need larger gauge wire (I have 8 now). I just don't > know know anymore and and stuck on my true amateur status. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=478108#478108 > > ________________________________________________________________________________
Date: Apr 07, 2018
How and where are y'all measuring the voltage? To begin troubleshooting, I'd get a decent digital voltmeter, and make up a couple of long clip leads. Clip the negative directly to the battery's negative terminal, and start testing with the positive directly on the alternator's B-lead. Crank the engine & check voltage. If normal, shut down, move the positive 'downstream' to the next joint, and repeat. Be sure to check every transition; for instance, the B-lead location should be checked on the stud itself, then on the ring terminal that's crimped to the wire, then, if possible, on the end of the wire itself. Then move on to the next joint. Charlie On 4/7/2018 7:15 PM, David Duperron wrote: > I completed my RV-10 in July of 2015. I also have a Plane Power 60A > main alternator and a 30A alternator as the back up. And I am having > the exact same symtoms. Plane Power tells me I should be getting 14.3 > to 14.5 volts on the main and slightly less than that on the backup > alternator. Should the main alternator output drop below that of the > backup, the backup will take over. Fact is The main puts out 13.4V to > 13.6V and the back running by itself puts out about the same. Running > both together might get me 13.7V. I bought a new 60A alternator and it > did the same. I had both the new and the old tested at a > starter/alternator shop and they tested to Plane Power specs at 14.5V. > My power distribution system is a modified Bob Knuckles Z-13-8 System. > I have noticed there are other RV-10 owners having the same issue. I > am David Duperron 616-485-5555. > > > On Mon, Feb 19, 2018 at 9:29 AM, mhealydds > wrote: > > > > > I have an RV-10 that is about one year and one half old and have > had a charging issue for at least a year of it. I have a Plane > Power 60 amp alternator (and back-up Plane Power 30 amp > alternator) with a Advanced Quick Panel System. Here is east has > been going on.... > 1. My primary alternator never get adequate charge. It hovers > around 12.5 to 12.8 volts, sometimes to 13.2 or so, but never > above 14 volts. > 2. The primary alternator makes an whine when on. > 3. The primary alternator shuts off intermittently (I see Amps of > down and whine goes off) and then will come back on on its own > later or sometimes will when I reset field switch. > 4. I can sometimes get full charge (14.2) on ground with only some > of avionics on (one EFIS, nav/strobes only). > 5. My secondary alternator does not do all this. It works indicated. > > Here is what I have tried and checked... > 1. Checked and adjusted belt tension on alternator. > 2. Added alternator filter. > 3. Checked continuity and tightness on all connections. > 4. Changed and checked alternator ANL fuse. > 5. Got completely new alternator and replaced it. > 6. Changed terminal plug on alternator. > 7. Been on phone with plane power numerous times and ruined > through trouble shooting and can't seem to find and issue with > alternator itself. > 8. Have not had alternator checked but since I have two > alternators doing same thing and both are basically new, I doubt > that is the case, but possible. > 9. Volt reading on EFIS and multimeter at AFS middle same and same > on both EFISs > > Any thoughts on what else to check or fix. I feel like I am > missing something obvious. The plane with run with with the 12.8 > or so volts but that is not what it should be. Could it be AFS > module (they don't thing so at AFS), battery, do I need larger > gauge wire (I have 8 now). I just don't know know anymore and and > stuck on my true amateur status. > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Apr 07, 2018
Measure the main alternator field current and tell us what it is. _ Is there an ammeter installed? If so, what does the ammeter say? _ Where is the shunt located electrically speaking? Does it measure battery current or alternator current or aircraft load current? _ The vast majority of electrical problems are due to bad connections. Check every connection in the alternator circuit. _ Have you verified that your voltmeter is accurate? -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479161#479161 ________________________________________________________________________________
Date: Apr 07, 2018
Have you determined the output voltage at the alternator, vs what you see at the bus? I have the same 60 amp alternator on my RV-10, and consistently see 14.3-14.5 on my Dynon EMS system. I'm suspecting you have some resistance somewhere in the system that is decreasing your voltage. I don't know if you have a voltage drop across your shunt (more than the infinitesimal amount used to measure amps)? You say you changed the ANL fuse. You need to know if there is any voltage drop across any of the circuit between alternator and bus. Does the lead from the alternator to wherever the first connection is show 0.0 ohms? How about the rest of the way to your bus? On 4/7/2018 5:15 PM, David Duperron wrote: > I completed my RV-10 in July of 2015. I also have a Plane Power 60A main > alternator and a 30A alternator as the back up. And I am having the > exact same symtoms. Plane Power tells me I should be getting 14.3 to > 14.5 volts on the main and slightly less than that on the backup > alternator. Should the main alternator output drop below that of the > backup, the backup will take over. Fact is The main puts out 13.4V to > 13.6V and the back running by itself puts out about the same. Running > both together might get me 13.7V. I bought a new 60A alternator and it > did the same. I had both the new and the old tested at a > starter/alternator shop and they tested to Plane Power specs at 14.5V. > My power distribution system is a modified Bob Knuckles Z-13-8 System. I > have noticed there are other RV-10 owners having the same issue. I am > David Duperron 616-485-5555. > > > On Mon, Feb 19, 2018 at 9:29 AM, mhealydds > wrote: > > > > > I have an RV-10 that is about one year and one half old and have had > a charging issue for at least a year of it. I have a Plane Power 60 > amp alternator (and back-up Plane Power 30 amp alternator) with a > Advanced Quick Panel System. Here is east has been going on.... > 1. My primary alternator never get adequate charge. It hovers around > 12.5 to 12.8 volts, sometimes to 13.2 or so, but never above 14 volts. > 2. The primary alternator makes an whine when on. > 3. The primary alternator shuts off intermittently (I see Amps of > down and whine goes off) and then will come back on on its own later > or sometimes will when I reset field switch. > 4. I can sometimes get full charge (14.2) on ground with only some > of avionics on (one EFIS, nav/strobes only). > 5. My secondary alternator does not do all this. It works indicated. > > Here is what I have tried and checked... > 1. Checked and adjusted belt tension on alternator. > 2. Added alternator filter. > 3. Checked continuity and tightness on all connections. > 4. Changed and checked alternator ANL fuse. > 5. Got completely new alternator and replaced it. > 6. Changed terminal plug on alternator. > 7. Been on phone with plane power numerous times and ruined through > trouble shooting and can't seem to find and issue with alternator > itself. > 8. Have not had alternator checked but since I have two alternators > doing same thing and both are basically new, I doubt that is the > case, but possible. > 9. Volt reading on EFIS and multimeter at AFS middle same and same > on both EFISs > > Any thoughts on what else to check or fix. I feel like I am missing > something obvious. The plane with run with with the 12.8 or so volts > but that is not what it should be. Could it be AFS module (they > don't thing so at AFS), battery, do I need larger gauge wire (I have > 8 now). I just don't know know anymore and and stuck on my true > amateur status. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=478108#478108 > <http://forums.matronics.com/viewtopic.php?p=478108#478108> > > > > > > > =================================== > - > Electric-List" rel="noreferrer" > target="_blank">http://www.matronics.com/Navigator?AeroElectric-List > =================================== > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > =================================== > WIKI - > errer" target="_blank">http://wiki.matronics.com > =================================== > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" target="_blank">http://www.matronics.com/contribution > =================================== > > > > ________________________________________________________________________________
Date: Apr 08, 2018
At 07:15 PM 4/7/2018, you wrote: >I completed my RV-10 in July of 2015. I also >have a Plane Power 60A main alternator and a 30A >alternator as the back up. And I am having the >exact same symtoms. Plane Power tells me I >should be getting 14.3 to 14.5 volts on the main >and slightly less than that on the backup >alternator. Should the main alternator output >drop below that of the backup, the backup will >take over. Fact is The main puts out 13.4V to >13.6V=C2 and the back running by itself puts out >about the same. Running both together might get >me 13.7V. I bought a new 60A alternator and it >did the same. I had both the new and the old >tested at a starter/alternator shop and they >tested to Plane Power specs at 14.5V. My power >distribution system is a modified Bob Knuckles >Z-13-8 System. I have noticed there are other >RV-10 owners having the same issue. I am David Duperron=C2 616-485-5555. What size is the b-lead wiring from altenrator to the bus . . . and where are you attaching the b-lead feeder to the system? Just for grins, try a temporary b-lead feeder directly from alternator to the battery terminal of the starter contactor . . . 6AWG or larger is good. The alternators in question SENSE 'bus voltage' AT THE B-LEAD TERMINAL. Modern internal regulators are quite accurate and consistent. As others have suggested, you first need to know what the alternator's output voltage is . . . given consistent results with two alternators, odd are that the alternator is fine and you're getting voltage drops in the path between b-terminal and your measurement point. Virtually all the Z-figures show 4AWG feeders from b-terminals via shortest path to the power systems FAT wires. The reason for this is to minimize losses in this high current pathway . . . a good thing to do whether the alternator is internally or externally regulated. Bob . . . ________________________________________________________________________________
Date: Apr 09, 2018
David: I don't think it is you, or even Bob's circuit. There have been issues with Plane Power. 1 - Look at the voltage regulator (ACU). 2 - Check the resistance of the FIELD. 3 - Check the resistance of the wires going to the field. 4 - If all those check out the next thing is to verify the voltage coming out of the ACU. If it is LOW the output of the ALT will be low. You can FORCE it high by applying a remote Field Voltage. This will increase the Output Voltage. 5 - I'm sure you know this by now - The ALT output should be 13.8 to 14.2 some say 14.5. Well, the 0.3 V delta is extreamly minor. What is important is the Minimum 13.8 VDC. 6 - Have you checked the accuracy of the meter you are using? 7 - NOISE - Plane Power has had many reports of NOISE. The easiest thing to do is put a nice big Electrolytic Capacitor across the output of the ALT. I find a 25,000 uF @ 16 VDC works. You can go higher in both uF & VDC. In this case Bigger Is Better. Hope this helps, Barry On Sat, Apr 7, 2018 at 8:15 PM, David Duperron wrote: > I completed my RV-10 in July of 2015. I also have a Plane Power 60A main > alternator and a 30A alternator as the back up. And I am having the exact > same symtoms. Plane Power tells me I should be getting 14.3 to 14.5 volts > on the main and slightly less than that on the backup alternator. Should > the main alternator output drop below that of the backup, the backup will > take over. Fact is The main puts out 13.4V to 13.6V and the back running > by itself puts out about the same. Running both together might get me > 13.7V. I bought a new 60A alternator and it did the same. I had both the > new and the old tested at a starter/alternator shop and they tested to > Plane Power specs at 14.5V. My power distribution system is a modified Bob > Knuckles Z-13-8 System. I have noticed there are other RV-10 owners having > the same issue. I am David Duperron 616-485-5555. > > > On Mon, Feb 19, 2018 at 9:29 AM, mhealydds wrote: > >> > >> >> I have an RV-10 that is about one year and one half old and have had a >> charging issue for at least a year of it. I have a Plane Power 60 amp >> alternator (and back-up Plane Power 30 amp alternator) with a Advanced >> Quick Panel System. Here is east has been going on.... >> 1. My primary alternator never get adequate charge. It hovers around 12.5 >> to 12.8 volts, sometimes to 13.2 or so, but never above 14 volts. >> 2. The primary alternator makes an whine when on. >> 3. The primary alternator shuts off intermittently (I see Amps of down >> and whine goes off) and then will come back on on its own later or >> sometimes will when I reset field switch. >> 4. I can sometimes get full charge (14.2) on ground with only some of >> avionics on (one EFIS, nav/strobes only). >> 5. My secondary alternator does not do all this. It works indicated. >> >> Here is what I have tried and checked... >> 1. Checked and adjusted belt tension on alternator. >> 2. Added alternator filter. >> 3. Checked continuity and tightness on all connections. >> 4. Changed and checked alternator ANL fuse. >> 5. Got completely new alternator and replaced it. >> 6. Changed terminal plug on alternator. >> 7. Been on phone with plane power numerous times and ruined through >> trouble shooting and can't seem to find and issue with alternator itself. >> 8. Have not had alternator checked but since I have two alternators doing >> same thing and both are basically new, I doubt that is the case, but >> possible. >> 9. Volt reading on EFIS and multimeter at AFS middle same and same on >> both EFISs >> >> Any thoughts on what else to check or fix. I feel like I am missing >> something obvious. The plane with run with with the 12.8 or so volts but >> that is not what it should be. Could it be AFS module (they don't thing so >> at AFS), battery, do I need larger gauge wire (I have 8 now). I just don't >> know know anymore and and stuck on my true amateur status. >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=478108#478108 >> >> >> >> >> >> >> =================================== >> - >> Electric-List" rel="noreferrer" target="_blank">http://www.matronics.com/ >> Navigator?AeroElectric-List >> =================================== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> =================================== >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> =================================== >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >> =================================== >> >> >> >> > ________________________________________________________________________________
Subject: Protection for Battery Master Switch wire?
Date: Apr 09, 2018
I plan on using Figure Z12 as the architecture for wiring my Bearhawk. In the process of converting the diagram to physical location for equipment and wire runs I noticed that the only wire that doesn't seem to have any protection, or is kept very short, is the Battery Master switch wire, 22ga running from the battery contactor to the switch? I could not find a discussion of this doing a search. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479193#479193 ________________________________________________________________________________
Date: Apr 09, 2018
Subject: Re: Protection for Battery Master Switch wire?
At 09:30 AM 4/9/2018, you wrote: > >I plan on using Figure Z12 as the architecture for wiring my >Bearhawk. In the process of converting the diagram to physical >location for equipment and wire runs I noticed that the only wire >that doesn't seem to have any protection, or is kept very short, is >the Battery Master switch wire, 22ga running from the battery >contactor to the switch? I could not find a discussion of this doing a search. There is no failure mode that puts that wire at risk. "Pull to ground" control lines on contactors have never benefited from protection. Bob . . . ________________________________________________________________________________
Date: Apr 09, 2018
At 07:53 AM 4/9/2018, you wrote: >David: > >I don't think it is you, or even Bob's >circuit.=C2 There have been issues with Plane Power. Can you point me to any discussions/narratives on PlainPower products? Last I looked over their product line, they were pretty much invested in modifying stock automotive to accept external control and ov protection while retaining the built in regulator. Aside from manufacturing errors, their business model seems to offer little performance risk. I'd be interested to know what kinds of problems builders are having unique to Plane Power. Thanks. Bob . . . ________________________________________________________________________________
Date: Apr 09, 2018
Subject: A bit of aviation history worth reviewing
https://youtu.be/F4KD5u-xkik Bob . . . ________________________________________________________________________________
Subject: Re: A bit of aviation history worth reviewing
Date: Apr 09, 2018
Wow! That was fascinating...I saw an SR 71 at the Pima museum in Arizona and took lots of pictures, but no one was there to answer questions and describe it as was done in this video. VERY entertaining! Thanks, Bob.. Harley ------------------------------------------------------------------------ On 4/9/2018 2:29 PM, Robert L. Nuckolls, III wrote: > > > > https://youtu.be/F4KD5u-xkik > > > Bob . . . > > ________________________________________________________________________________
Date: Apr 09, 2018
A friend of mine retired from Pratt (engine maker for the SR-71). He told me a story about an incident back before anyone knew the SR-71 existed. An airliner on a regular flight had a lot of panicked passengers when a huge black UFO appeared behind one wing. Upon landing, everyone on the plane was escorted into a room and 'read the riot act'; forced to swear out nondisclosure agreements that they would never reveal that they had seen anything. An SR-71 had descended for refueling, and joined up on the airliner instead of the tanker that was nearby..... On 4/9/2018 2:37 PM, Harley Dixon wrote: > Wow! That was fascinating...I saw an SR 71 at the Pima museum in > Arizona and took lots of pictures, but no one was there to answer > questions and describe it as was done in this video. VERY > entertaining! Thanks, Bob.. > > Harley > ------------------------------------------------------------------------ > > On 4/9/2018 2:29 PM, Robert L. Nuckolls, III wrote: >> >> >> >> >> https://youtu.be/F4KD5u-xkik >> >> >> >> Bob . . . >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Apr 09, 2018
Bob: One of the sites that discussions took place on was BEACH TALK. Barry On Mon, Apr 9, 2018 at 2:05 PM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 07:53 AM 4/9/2018, you wrote: > > David: > > I don't think it is you, or even Bob's circuit.=C3=82 There have been is sues > with Plane Power. > > > Can you point me to any discussions/narratives > on PlainPower products? Last I looked over their > product line, they were pretty much invested > in modifying stock automotive to accept external > control and ov protection while retaining the > built in regulator. Aside from manufacturing > errors, their business model seems to offer > little performance risk. I'd be interested to > know what kinds of problems builders are having > unique to Plane Power. Thanks. > > > Bob . . . > ________________________________________________________________________________
Date: Apr 09, 2018
At 08:20 PM 4/9/2018, you wrote: >Bob: > >One of the sites that discussions took place on was BEACH TALK. > >Barry Beech Talk? The Beechcraft Owner's Association? Do you recall the nature of issues discussed? Bob . . . ________________________________________________________________________________
Date: Apr 10, 2018
Yes, Bob and No, I do not recall. Barry On Mon, Apr 9, 2018 at 11:13 PM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 08:20 PM 4/9/2018, you wrote: > > Bob: > > One of the sites that discussions took place on was BEACH TALK. > > Barry > > > Beech Talk? The Beechcraft Owner's Association? > Do you recall the nature of issues discussed? > > > Bob . . . > ________________________________________________________________________________
Subject: Please critique my electrical design
Date: Apr 10, 2018
I've been working on the electrical architecture for my RV-8 and I'm getting close to a solution, but before I start buying and installing components, I'd like to get some feedback on my deign. I'm planning an IFR-capable RV-8 with a Titan IO-370, dual P-mags and a Whirlwind constant speed prop. Avionics will be the G3X system with G-5, GTN-650, GTR20, et al. I'm planning to use the Earth-X ETX680 battery as the main, and a TCW 3 Ah backup battery. The main alternator will be a belt-driven B&C BC-460H (60 Amps) with a gear-driven SD-8 backup ( Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479224#479224 Attachments: http://forums.matronics.com//files/load_analysis_156.png ________________________________________________________________________________
Date: Apr 10, 2018
Subject: Re: Please critique my electrical design
At 06:55 AM 4/10/2018, you wrote: > >I've been working on the electrical architecture for my RV-8 and I'm >getting close to a solution, but before I start buying and >installing components, I'd like to get some feedback on my deign. > >I'm planning an IFR-capable RV-8 with a Titan IO-370, dual P-mags >and a Whirlwind constant speed prop. Avionics will be the G3X >system with G-5, GTN-650, GTR20, et al. I'm planning to use the >Earth-X ETX680 battery as the main, and a TCW 3 Ah backup battery. >The main alternator will be a belt-driven B&C BC-460H (60 Amps) with >a gear-driven SD-8 backup ( > the very first example of Z13/8 to fly was in an RV8. Lost contact with the builders out in CT about 10 years ago . . . but the system had hundreds of hours on it then and the builders were delighted with the performance. The larger standby alternator suggests Z12 which has also been incorporated on a fleet of OBAM aircraft and hundreds of TC aircraft. With two alternators, why a backup battery? Bob . . . ________________________________________________________________________________
Date: Apr 10, 2018
Here is link to a poll taken on Vansairforce about alternator failures: http://www.vansairforce.com/community/poll.php?do=showresults&pollid=403 My interpretation of the poll results is that: 28 percent of Plane Power installations have failed prematurely. 20 percent of automotive installations have failed prematurely. 2 percent of B&C installations have failed prematurely. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479225#479225 ________________________________________________________________________________
Subject: Bulb replacement for my Sandel 3308 EHSI
Date: Apr 10, 2018
Here is one for the experts...I currently have a Sandel 3308 EHSI which uses T3 G4 30W halogen bulbs (4mm pins). These are getting hard to find and pricey. Would like to replace with LED comparable bulbs. Two questions, how do I ascertain correct bulb for socket and circuit? What are the considerations I need to know about when selecting a LED bulb as a replacement to halogen (if any?) Appreciate (as always) this "teachable" moment! [Idea] Dave Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479229#479229 ________________________________________________________________________________
Date: Apr 10, 2018
I heard back from EMAG today and they recommended the following: > > The P-mags should be put on the main bus because we only require a battery for starting. After 800 RPM or so we switch to running off our internal generator and do not require an external source. In the event of an internal generator failure we would switch back to the external power (main bus). Be sure to do the minimum cut-out test to see where the ignitions drop off and note it so in the event of an alternator failure you wont run the risk of the having to low of RPM for our ignitions to continue sparking. > > If you do put us on the battery directly you run the chance of leaving us on and draining your battery. > I've updated my design to put the P-mags back the way I initially had them and removed the Battery Bus fuse block once again. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479230#479230 ________________________________________________________________________________
Date: Apr 10, 2018
The main voltage regulator sense terminal (3?) should connect to the to the main power bus and not share a wire with the field current. The way it is connected now will eventually lead to overvoltage conditions due to increasing resistance as terminals and switch contacts corrode over time. The start switch does not need to be on a circuit breaker. A fuse on the main power bus should never blow. And if it did, there should be a good reason. And the plane will be safely on the ground if and when the start fuse does blow. There should not be 2 fuselinks in series going to the main alternator field breaker. One is good enough. The second one is redundant. Who knows if the aux alt 2 amp breaker will trip before the 15 amps fuse blows. Maybe increase the fuse to 30 amps? Consider doing away with the avionics switch. Maybe the trim indicator and fuel gauge should be on the endurance bus. They use very little power. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479231#479231 ________________________________________________________________________________
Date: Apr 10, 2018
Thanks for the post Joe, Barry On Tue, Apr 10, 2018 at 11:15 AM, user9253 wrote: > > Here is link to a poll taken on Vansairforce about alternator failures: > http://www.vansairforce.com/community/poll.php?do=showresults&pollid=403 > My interpretation of the poll results is that: > 28 percent of Plane Power installations have failed prematurely. > 20 percent of automotive installations have failed prematurely. > 2 percent of B&C installations have failed prematurely. > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=479225#479225 > > ________________________________________________________________________________
Date: Apr 10, 2018
> > > With two alternators, why a backup battery? > > > Bob . . . > =8BBecause what if the battery fails? G-5's can have the Garmin $150 TINNY battery or =8Byou can apply that money to a much larger second battery which will be big enough to start the plane and supply days of power for the G-5. I have not installed the G-3, but I have installed 2 planes with Dual G-5's (AI & HSI). With dual G-5's in a certified plane you are required to have dual Garmin batteries... That is $300 for a stinking 1 or 2 AH battery. Yea, I would be very happy to install a second battery - a small one - With just enough to start the plane in a 24:00 DARK stranded situation. Yea, happened to me one night. No Fun! Barry ________________________________________________________________________________
Date: Apr 10, 2018
At 03:01 PM 4/10/2018, you wrote: >=C2 With two alternators, why a backup battery? > > >=C2 Bob . . . > > >=8BBecause what if the battery fails? >G-5's can have the Garmin $150 TINNY battery or >=8Byou can apply that money to a much larger >second battery which will be big enough to start >the plane and supply days of power for the >G-5.=C2 I have not installed the G-3,=C2 but I >have installed 2 planes with Dual G-5's (AI & >HSI).=C2 With dual G-5's in a certified plane you are required to=C2 >have dual Garmin batteries...=C2 That is $300 for >a stinking 1 or 2 AH battery.=C2 Yea, I would be >very happy to install a second battery - a small >one - With just enough to start the plane in a >24:00 DARK stranded situation.=C2 =C2 >Yea, happened to me one night.=C2 No Fun! > >Barry Was this in spite of a considered preventative maintenance program? What was the battery's last cap-check value before the failure? A battery that is watched and maintained as carefully as tires, belts, propeller nicks air cleaners and engine oil is very unlikely to fail. Dual alternators virtually assures you of engine driven energy in spite of the loss of one alternator. The rule of thumb for battery replacement in the TC world is when it falls to less than 75% of original capacity . . . in the modern RG battery world, this means it probably still cranks the engine but is in substantial decline on an ever increasing slope to failure yet unlikely to go belly up away from your home hangar. Few light aircraft owner's manuals speak to affirmative-action maintenance programs . . . but I'd bet that top-billing in the cast of performers virtually all dark-n-stormy night stories that speak to battery failure is a beyond-service-life battery. Bob . . . ________________________________________________________________________________
Date: Apr 10, 2018
Not throwing stones..but this is a very unscientific poll dating back to 2005. My experience2 automotive alternators failed in less than 250hr. Can not remember how long each latested. B&C 8 amp..700 hrs and counting. PP 70 amp, I think it has been about 400 hours and counting Rene' 801-721-6080 From: owner-aeroelectric-list-server(at)matronics.com On Behalf Of FLYaDIVE Sent: Tuesday, April 10, 2018 1:36 PM Subject: Re: AeroElectric-List: Re: Charging Issue Thanks for the post Joe, Barry On Tue, Apr 10, 2018 at 11:15 AM, user9253 > wrote: > Here is link to a poll taken on Vansairforce about alternator failures: http://www.vansairforce.com/community/poll.php?do=showresults <http://www.vansairforce.com/community/poll.php?do=showresults&pollid= 403> &pollid=403 My interpretation of the poll results is that: 28 percent of Plane Power installations have failed prematurely. 20 percent of automotive installations have failed prematurely. 2 percent of B&C installations have failed prematurely. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479225#479225 - Electric-List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List FORUMS - eferrer" target="_blank">http://forums.matronics.com WIKI - errer" target="_blank">http://wiki.matronics.com b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution ________________________________________________________________________________
Subject: Car clock in an aircraft
Date: Apr 10, 2018
To the electrowizzards in this list. (This is not a rocket science aircraft subject, but I need your help on this) I bought one of those cheap (chinese) digital car clocks, with temperature indication, to install in the back of my RV-10, as a courtesy to the rear passengers. (please avoid any comments on this decision... :-)). As one could expect, the miserable instructions leaflet which came with the clock, doesnt have any information about the electric circuit, so Im in the guess field here. This critter has a 2-wire cable to be connected to 12V/24V, and also has 2 of those coin type batteries, so I suppose that the batteries are a backup to the ships power. But Im not sure... This leaves me with a doubt on where to connect the + wire of the power cable. Should I connect it to a circuit which is only powered when the aircraft Master switch is on, to avoid this critter to deplete the aircraft battery? Or can I connect it to the always hot bus, hoping that when the Master is Off, the clocks coin batteries will be powering the clock and only a very tiny current will be draining from the always hot bus, not depleting the aircrafts battery? Even knowing that without information on the clocks electric circuit it is difficult to know the answer, comments and suggestions are welcome Thanks Carlos ________________________________________________________________________________
Date: Apr 10, 2018
Subject: Re: Car clock in an aircraft
Carlos: You can do either. I would put it on a SWITCHED (On/Off) buss. The 'watch battery' is as you guess for a 'keep alive' circuit for the clock. The easy way of proving this would be to remove the watch battery while the unit is plugged into the planes power. THEN! Shut OFF the plane's power. Since the keep alive battery is no longer in circuit the clock should die and loose time (keep the plane's power off for 5 minutes just for S&G's. The clock should NOT hold memory and should either die or loose time... The 5 minutes. Why would I use a switched buss? Because if you do not fly for a REAL long time the clock and what ever else you have connected directly to the battery would drain the battery. Slowly for sure but, drain none the less. I just had a fellow tell me his 18 Ah battery was dying every two weeks. I checked the current draw on the battery with EVERYTHING Off. There was a 45 ma draw. When you work out the Ah and the hours in 2 weeks ... The battery would be dead! Problem identified... Problem solved... The plane had a CD player with a keep alive circuit. For what? The CLOCK and the play list memory. Pulled the CD player and the problem went away! The CD player was illegal for a certified plane anyway! Barry On Tue, Apr 10, 2018 at 5:40 PM, Carlos Trigo wrote : > trigo(at)mail.telepac.pt> > > To the electrowizzards in this list. > (This is not a rocket science aircraft subject, but I need your help on > this) > > I bought one of those cheap (chinese) digital car clocks, with temperatur e > indication, to install in the back of my RV-10, as a courtesy to the rear > passengers. (please avoid any comments on this decision... :-)). > As one could expect, the miserable instructions leaflet which came with > the clock, doesn=99t have any information about the electric circui t, so I=99m > in the guess field here. > > This critter has a 2-wire cable to be connected to 12V/24V, and also has 2 > of those coin type batteries, so I suppose that the batteries are a backu p > to the ship=99s power. > But I=99m not sure... > > This leaves me with a doubt on where to connect the + wire of the power > cable. > Should I connect it to a circuit which is only powered when the aircraft > Master switch is on, to avoid this critter to deplete the aircraft batter y? > Or can I connect it to the always hot bus, hoping that when the Master is > Off, the clock=99s coin batteries will be powering the clock and on ly a very > tiny current will be draining from the always hot bus, not depleting the > aircraft=99s battery? > > Even knowing that without information on the clocks=99 electric cir cuit it > is difficult to know the answer, comments and suggestions are welcome > > Thanks > Carlos > =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Apr 10, 2018
Set your multi-meter to read milliamps and connect it in series with a 12 volt power wire. Then measure the clock's current draw. Once armed with the numbers, a decision can be made. It is puzzling why a digital clock would even have a power wire unless it is for a back light. Most digital clocks are powered by internal batteries. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479240#479240 ________________________________________________________________________________
Date: Apr 10, 2018
How scientific do you want to get? A failure is a failure! And a failure ONLY hurts when YOU have to pull money out of YOUR pocket to fix it. Or when it cost YOU time. Barry On Tue, Apr 10, 2018 at 5:06 PM, Rene wrote: > Not throwing stones..but this is a very unscientific poll dating back to > 2005. > > > My experience2 automotive alternators failed in less th an 250hr. Can > not remember how long each latested. B&C 8 amp..700 hrs and cou nting. PP > 70 amp, I think it has been about 400 hours and counting > > > Rene' > > 801-721-6080 > > > *From:* owner-aeroelectric-list-server(at)matronics.com < > owner-aeroelectric-list-server(at)matronics.com> *On Behalf Of *FLYaDIVE > *Sent:* Tuesday, April 10, 2018 1:36 PM > *To:* aeroelectric-list(at)matronics.com > *Subject:* Re: AeroElectric-List: Re: Charging Issue > > > Thanks for the post Joe, > > > Barry > > > On Tue, Apr 10, 2018 at 11:15 AM, user9253 wrote: > > > Here is link to a poll taken on Vansairforce about alternator failures: > http://www.vansairforce.com/community/poll.php?do=showresults&pollid= 403 > My interpretation of the poll results is that: > 28 percent of Plane Power installations have failed prematurely. > 20 percent of automotive installations have failed prematurely. > 2 percent of B&C installations have failed prematurely. > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=479225#479225 > > > ======================== =========== > - > Electric-List" rel="noreferrer" target="_blank">http://www. > matronics.com/Navigator?AeroElectric-List > ========== > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > ========== > WIKI - > errer" target="_blank">http://wiki.matronics.com > ========== > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" target="_blank">http://www.matronics.com/contributio n > ======================== =========== > > ________________________________________________________________________________
Date: Apr 10, 2018
Bob: Let's get a show of hands... How many Pilots out there have a LOAD tester? I can't get owners to check their tires and you want them to load test a battery! Granted! This is a aero-electric email list and many are builders. So, if there are fellows out there that do have a load tester I doubt that would cover the rest of the BUYERS that only purchased the plane and did not build. What do you think would sell a plane faster: 'Oh, and this plane has Dual Alternators and Dual Batteries.' Or... 'And every year at annual I Load Test the battery." Barry On Tue, Apr 10, 2018 at 4:44 PM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 03:01 PM 4/10/2018, you wrote: > > =C3=82 With two alternators, why a backup battery? > > > =C3=82 Bob . . . > > > =C3=A2=82=AC=B9Because what if the battery fails? > G-5's can have the Garmin $150 TINNY battery or =C3=A2=82=AC=B9y ou can apply that > money to a much larger second battery which will be big enough to start t he > plane and supply days of power for the G-5.=C3=82 I have not installed t he > G-3,=C3=82 but I have installed 2 planes with Dual G-5's (AI & HSI).=C3 =82 With > dual G-5's in a certified plane you are required to=C3=82 > have dual Garmin batteries...=C3=82 That is $300 for a stinking 1 or 2 A H > battery.=C3=82 Yea, I would be very happy to install a second battery - a small > one - With just enough to start the plane in a 24:00 DARK stranded > situation.=C3=82 =C3=82 > Yea, happened to me one night.=C3=82 No Fun! > > Barry > > > Was this in spite of a considered preventative > maintenance program? What was the battery's last > cap-check value before the failure? > > A battery that is watched and maintained as > carefully as tires, belts, propeller nicks > air cleaners and engine oil is very unlikely > to fail. Dual alternators virtually assures > you of engine driven energy in spite of the > loss of one alternator. > > The rule of thumb for battery replacement > in the TC world is when it falls to less than > 75% of original capacity . . . in the modern > RG battery world, this means it probably > still cranks the engine but is in substantial > decline on an ever increasing slope to failure > yet unlikely to go belly up away from your > home hangar. > > Few light aircraft owner's manuals speak to > affirmative-action maintenance programs . . . > but I'd bet that top-billing in the cast of performers > virtually all dark-n-stormy night stories that > speak to battery failure is a beyond-service-life > battery. > > > Bob . . . > ________________________________________________________________________________
Date: Apr 10, 2018
It did not poll the populationonly a slice of the population that just happened to see it on the site. That is all I am saying. Applying failure rates to a random set of installations may be misleading to some and implies a certain amount of certainty. My experience lines up with the poll for the most part, but I am just one datapoint. Rene' 801-721-6080 From: owner-aeroelectric-list-server(at)matronics.com On Behalf Of FLYaDIVE Sent: Tuesday, April 10, 2018 4:57 PM Subject: Re: AeroElectric-List: Re: Charging Issue How scientific do you want to get? A failure is a failure! And a failure ONLY hurts when YOU have to pull money out of YOUR pocket to fix it. Or when it cost YOU time. Barry On Tue, Apr 10, 2018 at 5:06 PM, Rene > wrote: Not throwing stones..but this is a very unscientific poll dating back to 2005. My experience2 automotive alternators failed in less than 250hr. Can not remember how long each latested. B&C 8 amp..700 hrs and counting. PP 70 amp, I think it has been about 400 hours and counting Rene' 801-721-6080 From: owner-aeroelectric-list-server(at)matronics.com > On Behalf Of FLYaDIVE Sent: Tuesday, April 10, 2018 1:36 PM Subject: Re: AeroElectric-List: Re: Charging Issue Thanks for the post Joe, Barry On Tue, Apr 10, 2018 at 11:15 AM, user9253 > wrote: > Here is link to a poll taken on Vansairforce about alternator failures: http://www.vansairforce.com/community/poll.php?do=showresults <http://www.vansairforce.com/community/poll.php?do=showresults&pollid= 403> &pollid=403 My interpretation of the poll results is that: 28 percent of Plane Power installations have failed prematurely. 20 percent of automotive installations have failed prematurely. 2 percent of B&C installations have failed prematurely. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479225#479225 - Electric-List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List FORUMS - eferrer" target="_blank">http://forums.matronics.com WIKI - errer" target="_blank">http://wiki.matronics.com b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Apr 10, 2018
I do not know about what sells..but I have mine load tested at Batteries +. I have two batteries and two alternators. I have one battery that is 10+ years and the other is about 5 now. I had two battery failures.one self induced and the other was infant mortality. Rene' 801-721-6080 From: owner-aeroelectric-list-server(at)matronics.com On Behalf Of FLYaDIVE Sent: Tuesday, April 10, 2018 5:15 PM Subject: Re: AeroElectric-List: Please critique my electrical design Bob: Let's get a show of hands... How many Pilots out there have a LOAD tester? I can't get owners to check their tires and you want them to load test a battery! Granted! This is a aero-electric email list and many are builders. So, if there are fellows out there that do have a load tester I doubt that would cover the rest of the BUYERS that only purchased the plane and did not build. What do you think would sell a plane faster: 'Oh, and this plane has Dual Alternators and Dual Batteries.' Or... 'And every year at annual I Load Test the battery." Barry On Tue, Apr 10, 2018 at 4:44 PM, Robert L. Nuckolls, III > wrote: At 03:01 PM 4/10/2018, you wrote: =C3=82 With two alternators, why a backup battery? =C3=82 Bob . . . =C3=A2=82=AC=B9Because what if the battery fails? G-5's can have the Garmin $150 TINNY battery or =C3=A2=82=AC=B9you can apply that money to a much larger second battery which will be big enough to start the plane and supply days of power for the G-5.=C3=82 I have not installed the G-3,=C3=82 but I have installed 2 planes with Dual G-5's (AI & HSI).=C3=82 With dual G-5's in a certified plane you are required to=C3=82 have dual Garmin batteries...=C3=82 That is $300 for a stinking 1 or 2 AH battery.=C3=82 Yea, I would be very happy to install a second battery - a small one - With just enough to start the plane in a 24:00 DARK stranded situation.=C3=82 =C3=82 Yea, happened to me one night.=C3=82 No Fun! Barry Was this in spite of a considered preventative maintenance program? What was the battery's last cap-check value before the failure? A battery that is watched and maintained as carefully as tires, belts, propeller nicks air cleaners and engine oil is very unlikely to fail. Dual alternators virtually assures you of engine driven energy in spite of the loss of one alternator. The rule of thumb for battery replacement in the TC world is when it falls to less than 75% of original capacity . . . in the modern RG battery world, this means it probably still cranks the engine but is in substantial decline on an ever increasing slope to failure yet unlikely to go belly up away from your home hangar. Few light aircraft owner's manuals speak to affirmative-action maintenance programs . . . but I'd bet that top-billing in the cast of performers virtually all dark-n-stormy night stories that speak to battery failure is a beyond-service-life battery. Bob . . . ________________________________________________________________________________
Date: Apr 10, 2018
Quick load test on a battery ismags grounded or off and mixture pulled. Crank the engine and monitor the battery voltage. If after 15 seconds the battery voltage does NOT drop below 10.6 volts DC the battery is good. If not charge the battery and test again. Mark Moyle Platinum Alaska From: <owner-aeroelectric-list-server(at)matronics.com> on behalf of Rene Date: Tuesday, April 10, 2018 at 3:35 PM Subject: RE: AeroElectric-List: Please critique my electrical design I do not know about what sells..but I have mine load tested at Batteries +. I have two batteries and two alternators. I have one battery that is 10+ years and the other is about 5 now. I had two battery failures.one self induced and the other was infant mortality. Rene' 801-721-6080 From: owner-aeroelectric-list-server(at)matronics.com On Behalf Of FLYaDIVE Sent: Tuesday, April 10, 2018 5:15 PM Subject: Re: AeroElectric-List: Please critique my electrical design Bob: Let's get a show of hands... How many Pilots out there have a LOAD tester? I can't get owners to check their tires and you want them to load test a battery! Granted! This is a aero-electric email list and many are builders. So, if there are fellows out there that do have a load tester I doubt that would cover the rest of the BUYERS that only purchased the plane and did not build. What do you think would sell a plane faster: 'Oh, and this plane has Dual Alternators and Dual Batteries.' Or... 'And every year at annual I Load Test the battery." Barry On Tue, Apr 10, 2018 at 4:44 PM, Robert L. Nuckolls, III wrote: > > At 03:01 PM 4/10/2018, you wrote: > > >> >> =C3=82 With two alternators, why a backup battery? >> >> >> =C3=82 Bob . . . >> >> =C3=A2=82=AC=B9Because what if the battery fails? >> G-5's can have the Garmin $150 TINNY battery or =C3=A2=82=AC=B9you can apply th at money >> to a much larger second battery which will be big enough to start the pl ane >> and supply days of power for the G-5.=C3=82 I have not installed the G-3,=C3=82 but I >> have installed 2 planes with Dual G-5's (AI & HSI).=C3=82 With dual G-5's i n a >> certified plane you are required to=C3=82 >> have dual Garmin batteries...=C3=82 That is $300 for a stinking 1 or 2 AH >> battery.=C3=82 Yea, I would be very happy to install a second battery - a s mall >> one - With just enough to start the plane in a 24:00 DARK stranded >> situation.=C3=82 =C3=82 >> Yea, happened to me one night.=C3=82 No Fun! >> >> Barry > > Was this in spite of a considered preventative > maintenance program? What was the battery's last > cap-check value before the failure? > > A battery that is watched and maintained as > carefully as tires, belts, propeller nicks > air cleaners and engine oil is very unlikely > to fail. Dual alternators virtually assures > you of engine driven energy in spite of the > loss of one alternator. > > The rule of thumb for battery replacement > in the TC world is when it falls to less than > 75% of original capacity . . . in the modern > RG battery world, this means it probably > still cranks the engine but is in substantial > decline on an ever increasing slope to failure > yet unlikely to go belly up away from your > home hangar. > > Few light aircraft owner's manuals speak to > affirmative-action maintenance programs . . . > but I'd bet that top-billing in the cast of performers > virtually all dark-n-stormy night stories that > speak to battery failure is a beyond-service-life > battery. > > > > Bob . . . ________________________________________________________________________________
Date: Apr 11, 2018
I have a load tester. I leave it in the hanger though as superfluous weight (like for example 4 electrical sources) is a performance killer. On Tue, Apr 10, 2018, 7:19 PM FLYaDIVE wrote: > Bob: > > Let's get a show of hands... > How many Pilots out there have a LOAD tester? > I can't get owners to check their tires and you want them to load test a > battery! > Granted! This is a aero-electric email list and many are builders. So, > if there are fellows out there that do have a load tester I doubt that > would cover the rest of the BUYERS that only purchased the plane and did > not build. > What do you think would sell a plane faster: > 'Oh, and this plane has Dual Alternators and Dual Batteries.' > Or... > 'And every year at annual I Load Test the battery." > > Barry > > > On Tue, Apr 10, 2018 at 4:44 PM, Robert L. Nuckolls, III < > nuckolls.bob(at)aeroelectric.com> wrote: > >> At 03:01 PM 4/10/2018, you wrote: >> >> =C3=82 With two alternators, why a backup battery? >> >> >> =C3=82 Bob . . . >> >> >> =C3=A2=82=AC=B9Because what if the battery fails? >> G-5's can have the Garmin $150 TINNY battery or =C3=A2=82=AC=B9 you can apply that >> money to a much larger second battery which will be big enough to start the >> plane and supply days of power for the G-5.=C3=82 I have not installed the >> G-3,=C3=82 but I have installed 2 planes with Dual G-5's (AI & HSI).=C3 =82 With >> dual G-5's in a certified plane you are required to=C3=82 >> have dual Garmin batteries...=C3=82 That is $300 for a stinking 1 or 2 AH >> battery.=C3=82 Yea, I would be very happy to install a second battery - a small >> one - With just enough to start the plane in a 24:00 DARK stranded >> situation.=C3=82 =C3=82 >> Yea, happened to me one night.=C3=82 No Fun! >> >> Barry >> >> >> Was this in spite of a considered preventative >> maintenance program? What was the battery's last >> cap-check value before the failure? >> >> A battery that is watched and maintained as >> carefully as tires, belts, propeller nicks >> air cleaners and engine oil is very unlikely >> to fail. Dual alternators virtually assures >> you of engine driven energy in spite of the >> loss of one alternator. >> >> The rule of thumb for battery replacement >> in the TC world is when it falls to less than >> 75% of original capacity . . . in the modern >> RG battery world, this means it probably >> still cranks the engine but is in substantial >> decline on an ever increasing slope to failure >> yet unlikely to go belly up away from your >> home hangar. >> >> Few light aircraft owner's manuals speak to >> affirmative-action maintenance programs . . . >> but I'd bet that top-billing in the cast of performers >> virtually all dark-n-stormy night stories that >> speak to battery failure is a beyond-service-life >> battery. >> >> >> >> Bob . . . >> > > ________________________________________________________________________________
Date: Apr 10, 2018
I was the original poster and found my issue. I had a cracked firewall passthrough fitting (it was Blue Sea fitting a lot of other RV-10 user reported using). Anyway, it was in a spot not easy to inspect and never thought about it being cracked, just he connections on the fitting. Now a have a bad alternator noise I have thing to track down. Anyone dealt with that? Matt Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479250#479250 ________________________________________________________________________________
Date: Apr 10, 2018
Thanks for the feedback! user9253 wrote: > The main voltage regulator sense terminal (3?) should > connect to the to the main power bus and not share a wire > with the field current. The way it is connected now will > eventually lead to overvoltage conditions due to > increasing resistance as terminals and switch contacts > corrode over time. I just followed Bob's wiring on the Z-13/8, but I'll be sure to check that against the manufacture's instructions when I buy the voltage regulator. > The start switch does not need to be on a circuit > breaker. A fuse on the main power bus should never blow. > And if it did, there should be a good reason. > And the plane will be safely on the ground if and > when the start fuse does blow. I put the starter on a CB so I'd have an alternate way of turning it off in the event the starter switch failed closed. I suppose turning off the master would have the same effect though. > There should not be 2 fuselinks in series going to the > main alternator field breaker. One is good enough. The > second one is redundant. The distance between Main Bus 1 and Main Bus 2 was 6 feet, so I thought I needed circuit protection on it. Other builders advised me not to use a fuse for fear of nuisance trips. I've since moved the location of the CBs to the front of the instrument panel which has reduced the length of that wire run to less than 18". Does that length of wire need circuit protection? > Who knows if the aux alt 2 amp breaker will trip before > the 15 amps fuse blows. Maybe increase the fuse to 30 > amps? I have to confess I'm don't understand the intricacies of that set up as well as I wish. Bob also recommends 30A inline fuse and I'm not completely sure why I have it shown as 15A. The manufacturer recommends a 10A CB as the feed into the main bus, but I opted to go with Bob's design. Or I attempted to! :? > Consider doing away with the avionics switch. I know I'm in the old school here, but I want the switch function. > Maybe the trim indicator and fuel gauge should be on the > endurance bus. They use very little power. That's a good point. Thanks again, Rob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479251#479251 ________________________________________________________________________________
Date: Apr 10, 2018
Since it only takes around 5% of capacity to start the engine, that might not be the most reliable test. On 4/10/2018 7:06 PM, Mark Moyle wrote: > Quick load test on a battery ismags grounded or off and mixture > pulled. Crank the engine and monitor the battery voltage. If after > 15 seconds the battery voltage does NOT drop below 10.6 volts DC the > battery is good. If not charge the battery and test again. > Mark Moyle > Platinum Alaska > > From: <owner-aeroelectric-list-server(at)matronics.com > > on behalf of > Rene > > Reply-To: > > Date: Tuesday, April 10, 2018 at 3:35 PM > To: > > Subject: RE: AeroElectric-List: Please critique my electrical design > > I do not know about what sells..but I have mine load tested at > Batteries +. > > I have two batteries and two alternators. I have one battery that is > 10+ years and the other is about 5 now. I had two battery > failures.one self induced and the other was infant mortality. > > Rene' > > 801-721-6080 > > *From:* owner-aeroelectric-list-server(at)matronics.com > > > *On Behalf Of > *FLYaDIVE > *Sent:* Tuesday, April 10, 2018 5:15 PM > *To:* aeroelectric-list(at)matronics.com > > *Subject:* Re: AeroElectric-List: Please critique my electrical design > > Bob: > > Let's get a show of hands... > > How many Pilots out there have a LOAD tester? > > I can't get owners to check their tires and you want them to load test > a battery! > > Granted! This is a aero-electric email list and many are builders. > So, if there are fellows out there that do have a load tester I doubt > that would cover the rest of the BUYERS that only purchased the plane > and did not build. > > What do you think would sell a plane faster: > > 'Oh, and this plane has Dual Alternators and Dual Batteries.' > > Or... > > 'And every year at annual I Load Test the battery." > > Barry > > On Tue, Apr 10, 2018 at 4:44 PM, Robert L. Nuckolls, III > > > wrote: > > At 03:01 PM 4/10/2018, you wrote: > > > With two alternators, why a backup battery? > > Bob . . . > > > Because what if the battery fails? > G-5's can have the Garmin $150 TINNY battery or you can > apply that money to a much larger second battery which will be > big enough to start the plane and supply days of power for the > G-5. I have not installed the G-3, but I have installed 2 > planes with Dual G-5's (AI & HSI). With dual G-5's in a > certified plane you are required to > have dual Garmin batteries... That is $300 for a stinking 1 > or 2 AH battery. Yea, I would be very happy to install a > second battery - a small one - With just enough to start the > plane in a 24:00 DARK stranded situation. > Yea, happened to me one night. No Fun! > > Barry > > > Was this in spite of a considered preventative > maintenance program? What was the battery's last > cap-check value before the failure? > > A battery that is watched and maintained as > carefully as tires, belts, propeller nicks > air cleaners and engine oil is very unlikely > to fail. Dual alternators virtually assures > you of engine driven energy in spite of the > loss of one alternator. > > The rule of thumb for battery replacement > in the TC world is when it falls to less than > 75% of original capacity . . . in the modern > RG battery world, this means it probably > still cranks the engine but is in substantial > decline on an ever increasing slope to failure > yet unlikely to go belly up away from your > home hangar. > > Few light aircraft owner's manuals speak to > affirmative-action maintenance programs . . . > but I'd bet that top-billing in the cast of performers > virtually all dark-n-stormy night stories that > speak to battery failure is a beyond-service-life > battery. > > > Bob . . . > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Apr 10, 2018
Charlie, It would seem to me that putting a consistent load (turning the starter, similar temperatures) on the battery, and noting the voltage drop would constitute a valid test. It is surely not the most accurate, but if done in a consistent manner, it is seems it would be much better than doing nothing at all. Also, I don't see how the fact that it only takes 5% of battery capacity to start the engine has any relevance on whether such a rudimentary engine spinning stress test is valid, or not. Are you saying that it is likely that one would note the same voltage drop on a brand new battery as on a battery that is nearing the end of its useful life? Enlighten! On Tue, Apr 10, 2018 at 6:39 PM, Charlie England wrote: > Since it only takes around 5% of capacity to start the engine, that might > not be the most reliable test. > > On 4/10/2018 7:06 PM, Mark Moyle wrote: > > Quick load test on a battery ismags grounded or off and mixture pulled. > Crank the engine and monitor the battery voltage. If after 15 seconds th e > battery voltage does NOT drop below 10.6 volts DC the battery is good. I f > not charge the battery and test again. > Mark Moyle > Platinum Alaska > > From: <owner-aeroelectric-list-server(at)matronics.com> on behalf of Rene < > rene(at)felker.com> > Reply-To: > Date: Tuesday, April 10, 2018 at 3:35 PM > To: > Subject: RE: AeroElectric-List: Please critique my electrical design > > I do not know about what sells..but I have mine load tested at B atteries > +. > > > I have two batteries and two alternators. I have one battery that is 10+ > years and the other is about 5 now. I had two battery failures. one self > induced and the other was infant mortality. > > > Rene' > > 801-721-6080 > > > *From:* owner-aeroelectric-list-server(at)matronics.com < > owner-aeroelectric-list-server(at)matronics.com> *On Behalf Of *FLYaDIVE > *Sent:* Tuesday, April 10, 2018 5:15 PM > *To:* aeroelectric-list(at)matronics.com > *Subject:* Re: AeroElectric-List: Please critique my electrical design > > > Bob: > > > Let's get a show of hands... > > How many Pilots out there have a LOAD tester? > > I can't get owners to check their tires and you want them to load test a > battery! > > Granted! This is a aero-electric email list and many are builders. So, > if there are fellows out there that do have a load tester I doubt that > would cover the rest of the BUYERS that only purchased the plane and did > not build. > > What do you think would sell a plane faster: > > 'Oh, and this plane has Dual Alternators and Dual Batteries.' > > Or... > > 'And every year at annual I Load Test the battery." > > > Barry > > > On Tue, Apr 10, 2018 at 4:44 PM, Robert L. Nuckolls, III < > nuckolls.bob(at)aeroelectric.com> wrote: > > At 03:01 PM 4/10/2018, you wrote: > > > =C3=82 With two alternators, why a backup battery? > > =C3=82 Bob . . . > > > =C3=A2=82=AC=B9Because what if the battery fails? > G-5's can have the Garmin $150 TINNY battery or =C3=A2=82=AC=B9y ou can apply that > money to a much larger second battery which will be big enough to start t he > plane and supply days of power for the G-5.=C3=82 I have not installed t he > G-3,=C3=82 but I have installed 2 planes with Dual G-5's (AI & HSI).=C3 =82 With > dual G-5's in a certified plane you are required to=C3=82 > have dual Garmin batteries...=C3=82 That is $300 for a stinking 1 or 2 A H > battery.=C3=82 Yea, I would be very happy to install a second battery - a small > one - With just enough to start the plane in a 24:00 DARK stranded > situation.=C3=82 =C3=82 > Yea, happened to me one night.=C3=82 No Fun! > > Barry > > > Was this in spite of a considered preventative > maintenance program? What was the battery's last > cap-check value before the failure? > > A battery that is watched and maintained as > carefully as tires, belts, propeller nicks > air cleaners and engine oil is very unlikely > to fail. Dual alternators virtually assures > you of engine driven energy in spite of the > loss of one alternator. > > The rule of thumb for battery replacement > in the TC world is when it falls to less than > 75% of original capacity . . . in the modern > RG battery world, this means it probably > still cranks the engine but is in substantial > decline on an ever increasing slope to failure > yet unlikely to go belly up away from your > home hangar. > > Few light aircraft owner's manuals speak to > affirmative-action maintenance programs . . . > but I'd bet that top-billing in the cast of performers > virtually all dark-n-stormy night stories that > speak to battery failure is a beyond-service-life > battery. > > > Bob . . . > > > Virus-free . > www.avast.com > > <#m_6581499881476749600_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> > ________________________________________________________________________________
Date: Apr 10, 2018
If you look at B&C's wiring diagram https://www.bandc.aero/pdfs/LR3C_Installation_Manual.pdf the voltage sense terminal 3 is separate from the field terminal 6. Also look at Bob's Z-12. _ One fuselink provides protection for everything downstream of it. A second fuselink is not required. All the second one does is make an unnecessary failure point. _ The maximum of 6" rule of thumb for unprotected wires is not cast in stone. It all depends on what dangers the wire is exposed to. _ Circuit breakers are mechanical devices that take time to operate. That time could be longer than it takes a smaller fuse to blow. A larger fuse will be slower to blow in case of the over-voltage module shorting out. The aux alternator fuse protects the battery. It will not hurt to use a 30 amp fuse. Z-13/8 uses a 20awg fuselink which will probably carry more than 30 amps before the wire melts. The aux alternator output is self current limiting and will never exceed 10 amps or so. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479255#479255 ________________________________________________________________________________
Date: Apr 10, 2018
If the only use for the battery is starting, then it's a valid test. But if the battery is backup electrical power for the alternator and you need electrical power to keep the flight safe to its conclusion, then it isn't a valid test. It can be down to 50% capacity & still reliably crank the engine. But if the alternator dies and you need the battery to keep the engine running (electronic ignition, glass panel in IFR, etc), then you'd only have half or less the time you thought you'd have, based on the battery's rated capacity. It's the difference between power and energy. 400 HP Corvette with 1/2 gallon of gas, vs 80 HP Chevette with 15 gallons. That help? On 4/10/2018 10:06 PM, Ken Ryan wrote: > Charlie, It would seem to me that putting a consistent load (turning > the starter, similar temperatures) on the battery, and noting the > voltage drop would constitute a valid test. It is surely not the most > accurate, but if done in a consistent manner, it is seems it would be > much better than doing nothing at all. Also, I don't see how the fact > that it only takes 5% of battery capacity to start the engine has any > relevance on whether such a rudimentary engine spinning stress test is > valid, or not. Are you saying that it is likely that one would note > the same voltage drop on a brand new battery as on a battery that is > nearing the end of its useful life? Enlighten! > > On Tue, Apr 10, 2018 at 6:39 PM, Charlie England > wrote: > > Since it only takes around 5% of capacity to start the engine, > that might not be the most reliable test. > > On 4/10/2018 7:06 PM, Mark Moyle wrote: >> Quick load test on a battery ismags grounded or off and mixture >> pulled. Crank the engine and monitor the battery voltage. If >> after 15 seconds the battery voltage does NOT drop below 10.6 >> volts DC the battery is good. If not charge the battery and test >> again. >> Mark Moyle >> Platinum Alaska >> >> From: <owner-aeroelectric-list-server(at)matronics.com >> > on behalf >> of Rene > >> Reply-To: > > >> Date: Tuesday, April 10, 2018 at 3:35 PM >> To: > > >> Subject: RE: AeroElectric-List: Please critique my electrical design >> >> I do not know about what sells..but I have mine load tested at >> Batteries +. >> >> I have two batteries and two alternators. I have one battery >> that is 10+ years and the other is about 5 now. I had two >> battery failures.one self induced and the other was infant >> mortality. >> >> Rene' >> >> 801-721-6080 >> >> *From:* owner-aeroelectric-list-server(at)matronics.com >> >> > > *On Behalf >> Of *FLYaDIVE >> *Sent:* Tuesday, April 10, 2018 5:15 PM >> *To:* aeroelectric-list(at)matronics.com >> >> *Subject:* Re: AeroElectric-List: Please critique my electrical >> design >> >> Bob: >> >> Let's get a show of hands... >> >> How many Pilots out there have a LOAD tester? >> >> I can't get owners to check their tires and you want them to load >> test a battery! >> >> Granted! This is a aero-electric email list and many are >> builders. So, if there are fellows out there that do have a load >> tester I doubt that would cover the rest of the BUYERS that only >> purchased the plane and did not build. >> >> What do you think would sell a plane faster: >> >> 'Oh, and this plane has Dual Alternators and Dual Batteries.' >> >> Or... >> >> 'And every year at annual I Load Test the battery." >> >> Barry >> >> On Tue, Apr 10, 2018 at 4:44 PM, Robert L. Nuckolls, III >> > > wrote: >> >> At 03:01 PM 4/10/2018, you wrote: >> >> >> With two alternators, why a backup battery? >> >> Bob . . . >> >> >> Because what if the battery fails? >> G-5's can have the Garmin $150 TINNY battery or you >> can apply that money to a much larger second battery >> which will be big enough to start the plane and supply >> days of power for the G-5. I have not installed the >> G-3, but I have installed 2 planes with Dual G-5's (AI >> & HSI). With dual G-5's in a certified plane you are >> required to >> have dual Garmin batteries... That is $300 for a >> stinking 1 or 2 AH battery. Yea, I would be very happy >> to install a second battery - a small one - With just >> enough to start the plane in a 24:00 DARK stranded >> situation. >> Yea, happened to me one night. No Fun! >> >> Barry >> >> >> Was this in spite of a considered preventative >> maintenance program? What was the battery's last >> cap-check value before the failure? >> >> A battery that is watched and maintained as >> carefully as tires, belts, propeller nicks >> air cleaners and engine oil is very unlikely >> to fail. Dual alternators virtually assures >> you of engine driven energy in spite of the >> loss of one alternator. >> >> The rule of thumb for battery replacement >> in the TC world is when it falls to less than >> 75% of original capacity . . . in the modern >> RG battery world, this means it probably >> still cranks the engine but is in substantial >> decline on an ever increasing slope to failure >> yet unlikely to go belly up away from your >> home hangar. >> >> Few light aircraft owner's manuals speak to >> affirmative-action maintenance programs . . . >> but I'd bet that top-billing in the cast of performers >> virtually all dark-n-stormy night stories that >> speak to battery failure is a beyond-service-life >> battery. >> >> >> Bob . . . >> > > > > Virus-free. www.avast.com > > > > <#m_6581499881476749600_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> > > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Apr 10, 2018
A valid test needs to take the battery to lower than 75%. After that fully charge and then retest, I usually go the manufactures suggested low charge level. This will tell you if the bat is capable of 75% charge.If not, replace it. I do this and also replace my AGM Bat every two years. I have no steam gagues in my AC. On Tuesday, April 10, 2018, Ken Ryan wrote: > Charlie, It would seem to me that putting a consistent load (turning the starter, similar temperatures) on the battery, and noting the voltage drop would constitute a valid test. It is surely not the most accurate, but if done in a consistent manner, it is seems it would be much better than doing nothing at all. Also, I don't see how the fact that it only takes 5% of battery capacity to start the engine has any relevance on whether such a rudimentary engine spinning stress test is valid, or not. Are you saying that it is likely that one would note the same voltage drop on a brand new battery as on a battery that is nearing the end of its useful life? Enlighten! > On Tue, Apr 10, 2018 at 6:39 PM, Charlie England wrote: >> >> Since it only takes around 5% of capacity to start the engine, that might not be the most reliable test. >> >> On 4/10/2018 7:06 PM, Mark Moyle wrote: >> >> Quick load test on a battery ismags grounded or off and mixture pulled. Crank the engine and monitor the battery voltage. If after 15 seconds the battery voltage does NOT drop below 10.6 volts DC the battery is good. If not charge the battery and test again. >> Mark Moyle >> Platinum Alaska >> From: <owner-aeroelectric-list-server(at)matronics.com> on behalf of Rene < rene(at)felker.com> >> Reply-To: >> Date: Tuesday, April 10, 2018 at 3:35 PM >> To: >> Subject: RE: AeroElectric-List: Please critique my electrical design >> >> I do not know about what sells..but I have mine load tested at Batteries +. >> >> >> >> I have two batteries and two alternators. I have one battery that is 10+ years and the other is about 5 now. I had two battery failures .one self induced and the other was infant mortality. >> >> >> >> Rene' >> >> 801-721-6080 >> >> >> >> From: owner-aeroelectric-list-server(at)matronics.com < owner-aeroelectric-list-server(at)matronics.com> On Behalf Of FLYaDIVE >> Sent: Tuesday, April 10, 2018 5:15 PM >> To: aeroelectric-list(at)matronics.com >> Subject: Re: AeroElectric-List: Please critique my electrical design >> >> >> >> Bob: >> >> >> >> Let's get a show of hands... >> >> How many Pilots out there have a LOAD tester? >> >> I can't get owners to check their tires and you want them to load test a battery! >> >> Granted! This is a aero-electric email list and many are builders. So, if there are fellows out there that do have a load tester I doubt that would cover the rest of the BUYERS that only purchased the plane and did not build. >> >> What do you think would sell a plane faster: >> >> 'Oh, and this plane has Dual Alternators and Dual Batteries.' >> >> Or... >> >> 'And every year at annual I Load Test the battery." >> >> >> >> Barry >> >> >> >> >> >> On Tue, Apr 10, 2018 at 4:44 PM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: >> >> At 03:01 PM 4/10/2018, you wrote: >> >> >> =C3=82 With two alternators, why a backup battery? >> >> =C3=82 Bob . . . >> >> =C3=A2=82=AC=B9Because what if the battery fails? >> G-5's can have the Garmin $150 TINNY battery or =C3=A2=82=AC=B9 you can apply that money to a much larger second battery which will be big enough to start the plane and supply days of power for the G-5.=C3=82 I have not installed the G-3,=C3=82 but I have installed 2 planes with Dual G-5's (AI & HSI).=C3=82 With dual G-5's in a certified plane you are required to=C3=82 >> have dual Garmin batteries...=C3=82 That is $300 for a stinking 1 or 2 AH battery.=C3=82 Yea, I would be very happy to install a second battery - a small one - With just enough to start the plane in a 24:00 DARK stranded situation.=C3=82 =C3=82 >> Yea, happened to me one night.=C3=82 No Fun! >> >> Barry >> >> Was this in spite of a considered preventative >> maintenance program? What was the battery's last >> cap-check value before the failure? >> >> A battery that is watched and maintained as >> carefully as tires, belts, propeller nicks >> air cleaners and engine oil is very unlikely >> to fail. Dual alternators virtually assures >> you of engine driven energy in spite of the >> loss of one alternator. >> >> The rule of thumb for battery replacement >> in the TC world is when it falls to less than >> 75% of original capacity . . . in the modern >> RG battery world, this means it probably >> still cranks the engine but is in substantial >> decline on an ever increasing slope to failure >> yet unlikely to go belly up away from your >> home hangar. >> >> Few light aircraft owner's manuals speak to >> affirmative-action maintenance programs . . . >> but I'd bet that top-billing in the cast of performers >> virtually all dark-n-stormy night stories that >> speak to battery failure is a beyond-service-life >> battery. >> >> >> Bob . . . >> >> >> >> < https://ci5.googleusercontent.com/proxy/M2-ctzJ6_LQ91UgZhwqiad0T5NTuMKxW_Wy q6Hwe3O5NlmAAXUIN70IL704-sgeGK_EUk1emkSHFb89ojOgJMH73hkYFO_E705cCwjimC_9onv xtCWJ7EZN27-OVK4jjjO_ucLFuIks7qIMzuswpUsWNzJ_u=s0-d-e1-ft#https://ipmcdn. avast.com/images/icons/icon-envelope-tick-round-orange-animated-no-repeat-v 1.gif> Virus-free. www.avast.com > ________________________________________________________________________________
Date: Apr 10, 2018
Charlie, It seems to me that your response does not address that the test involves monitoring the voltage drop that occurs when the consistent load is applied. The test is not simply, "will the battery spin the prop." The test is, "what is the voltage drop caused by spinning the prop." It seems to me that if the voltage drops down further on a worn out battery than it does on a fresh battery, there is at least the possibility that this test could be quite useful. It does not seem to me that the simple fact the battery "can be down 50% capacity and still reliably crank the engine" is germane to whether or not monitoring voltage under a consistent load (in this case spinning the propeller for a specific time) can be useful as a way to determine whether or not it is time to replace a battery . I'm not saying that the spin-the-prop-and-monitor-voltage test is valid. But it seems to me like it might be. I just can't see where simply noting that a depleted battery can still spin a prop says anything about the usefulness of such a test. Sorry, but I just can't seem to make that connection. Probably I am a little bit dense :) -- it wouldn't be the first time. In evaluating the suggested test, as a starting point I would like to know if the voltage drop would be significantly different on a new vs a worn out battery. If the answer is no, the drop would be about the same, then case closed. Test invalid. But if it turns out the voltage drop is significantly greater on a worn out battery, then I think there is reason to believe that the test might be useful. On Tue, Apr 10, 2018, 20:04 Charlie England wrote: > If the only use for the battery is starting, then it's a valid test. But > if the battery is backup electrical power for the alternator and you need > electrical power to keep the flight safe to its conclusion, then it isn't a > valid test. > > It can be down to 50% capacity & still reliably crank the engine. But if > the alternator dies and you need the battery to keep the engine running > (electronic ignition, glass panel in IFR, etc), then you'd only have half > or less the time you thought you'd have, based on the battery's rated > capacity. > > It's the difference between power and energy. 400 HP Corvette with 1/2 > gallon of gas, vs 80 HP Chevette with 15 gallons. > > That help? > > On 4/10/2018 10:06 PM, Ken Ryan wrote: > > Charlie, It would seem to me that putting a consistent load (turning the > starter, similar temperatures) on the battery, and noting the voltage dro p > would constitute a valid test. It is surely not the most accurate, but if > done in a consistent manner, it is seems it would be much better than doi ng > nothing at all. Also, I don't see how the fact that it only takes 5% of > battery capacity to start the engine has any relevance on whether such a > rudimentary engine spinning stress test is valid, or not. Are you saying > that it is likely that one would note the same voltage drop on a brand ne w > battery as on a battery that is nearing the end of its useful life? > Enlighten! > > On Tue, Apr 10, 2018 at 6:39 PM, Charlie England > wrote: > >> Since it only takes around 5% of capacity to start the engine, that migh t >> not be the most reliable test. >> >> On 4/10/2018 7:06 PM, Mark Moyle wrote: >> >> Quick load test on a battery ismags grounded or off and mixture pulled. >> Crank the engine and monitor the battery voltage. If after 15 seconds t he >> battery voltage does NOT drop below 10.6 volts DC the battery is good. If >> not charge the battery and test again. >> Mark Moyle >> Platinum Alaska >> >> From: <owner-aeroelectric-list-server(at)matronics.com> on behalf of Rene < >> rene(at)felker.com> >> Reply-To: >> Date: Tuesday, April 10, 2018 at 3:35 PM >> To: >> Subject: RE: AeroElectric-List: Please critique my electrical design >> >> I do not know about what sells..but I have mine load tested at Batteries >> +. >> >> >> >> I have two batteries and two alternators. I have one battery that is 10 + >> years and the other is about 5 now. I had two battery failures .one self >> induced and the other was infant mortality. >> >> >> >> Rene' >> >> 801-721-6080 >> >> >> >> *From:* owner-aeroelectric-list-server(at)matronics.com < >> owner-aeroelectric-list-server(at)matronics.com> *On Behalf Of *FLYaDIVE >> *Sent:* Tuesday, April 10, 2018 5:15 PM >> *To:* aeroelectric-list(at)matronics.com >> *Subject:* Re: AeroElectric-List: Please critique my electrical design >> >> >> >> Bob: >> >> >> >> Let's get a show of hands... >> >> How many Pilots out there have a LOAD tester? >> >> I can't get owners to check their tires and you want them to load test a >> battery! >> >> Granted! This is a aero-electric email list and many are builders. So, >> if there are fellows out there that do have a load tester I doubt that >> would cover the rest of the BUYERS that only purchased the plane and did >> not build. >> >> What do you think would sell a plane faster: >> >> 'Oh, and this plane has Dual Alternators and Dual Batteries.' >> >> Or... >> >> 'And every year at annual I Load Test the battery." >> >> >> >> Barry >> >> >> >> >> >> On Tue, Apr 10, 2018 at 4:44 PM, Robert L. Nuckolls, III < >> nuckolls.bob(at)aeroelectric.com> wrote: >> >> At 03:01 PM 4/10/2018, you wrote: >> >> >> =C3=82 With two alternators, why a backup battery? >> >> =C3=82 Bob . . . >> >> >> =C3=A2=82=AC=B9Because what if the battery fails? >> G-5's can have the Garmin $150 TINNY battery or =C3=A2=82=AC=B9 you can apply that >> money to a much larger second battery which will be big enough to start the >> plane and supply days of power for the G-5.=C3=82 I have not installed the >> G-3,=C3=82 but I have installed 2 planes with Dual G-5's (AI & HSI).=C3 =82 With >> dual G-5's in a certified plane you are required to=C3=82 >> have dual Garmin batteries...=C3=82 That is $300 for a stinking 1 or 2 AH >> battery.=C3=82 Yea, I would be very happy to install a second battery - a small >> one - With just enough to start the plane in a 24:00 DARK stranded >> situation.=C3=82 =C3=82 >> Yea, happened to me one night.=C3=82 No Fun! >> >> Barry >> >> >> Was this in spite of a considered preventative >> maintenance program? What was the battery's last >> cap-check value before the failure? >> >> A battery that is watched and maintained as >> carefully as tires, belts, propeller nicks >> air cleaners and engine oil is very unlikely >> to fail. Dual alternators virtually assures >> you of engine driven energy in spite of the >> loss of one alternator. >> >> The rule of thumb for battery replacement >> in the TC world is when it falls to less than >> 75% of original capacity . . . in the modern >> RG battery world, this means it probably >> still cranks the engine but is in substantial >> decline on an ever increasing slope to failure >> yet unlikely to go belly up away from your >> home hangar. >> >> Few light aircraft owner's manuals speak to >> affirmative-action maintenance programs . . . >> but I'd bet that top-billing in the cast of performers >> virtually all dark-n-stormy night stories that >> speak to battery failure is a beyond-service-life >> battery. >> >> >> Bob . . . >> >> >> >> >> >> >> Virus-fre e. >> www.avast.com >> >> <#m_-615151073569806401_m_-960492680129280463_m_6581499881476749600_DAB4 FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> >> > > ________________________________________________________________________________
Date: Apr 11, 2018
Hi Carlos Do you have an 'off aircraft' battery/power sauce to run a test on this clock, as for aircraft power, any low current item (instrument lights) could share its power supply and fuse/CB I would imagine Regards John Sent from my iPad ----x--O--x---- > On 10 Apr 2018, at 10:40 pm, Carlos Trigo wrote: > > > To the electrowizzards in this list. > (This is not a rocket science aircraft subject, but I need your help on this) > > I bought one of those cheap (chinese) digital car clocks, with temperature indication, to install in the back of my RV-10, as a courtesy to the rear passengers. (please avoid any comments on this decision... :-)). > As one could expect, the miserable instructions leaflet which came with the clock, doesnt have any information about the electric circuit, so Im in the guess field here. > > This critter has a 2-wire cable to be connected to 12V/24V, and also has 2 of those coin type batteries, so I suppose that the batteries are a backup to the ships power. > But Im not sure... > > This leaves me with a doubt on where to connect the + wire of the power cable. > Should I connect it to a circuit which is only powered when the aircraft Master switch is on, to avoid this critter to deplete the aircraft battery? > Or can I connect it to the always hot bus, hoping that when the Master is Off, the clocks coin batteries will be powering the clock and only a very tiny current will be draining from the always hot bus, not depleting the aircrafts battery? > > Even knowing that without information on the clocks electric circuit it is difficult to know the answer, comments and suggestions are welcome > > Thanks > Carlos > > > > ________________________________________________________________________________
Subject: Re: Please critique my electrical design
Date: Apr 11, 2018
user9253 wrote: > If you look at B&C's wiring diagram > https://www.bandc.aero/pdfs/LR3C_Installation_Manual.pdf > the voltage sense terminal 3 is separate from the field terminal 6. > Also look at Bob's Z-12. I followed B&C's parts list, but when they switched it from a generic Ford regulator to the LR3C I didn't realize I should have used the Z-12 architecture for that component. Z-12 doesn't include a fuseable link or crowbar -- should I take those out? I put the LV Warn light back in my design for now like the Z-12 has, but I'm sure the G3X has an input for that, so a stand-alone light won't be required. I'll also have to figure out if I still need the Lo Volt Warn CB in that arrangement. > One fuselink provides protection for everything downstream of it. > A second fuselink is not required. All the second one does is make > an unnecessary failure point. That makes sense now, thanks! > The maximum of 6" rule of thumb for unprotected wires is not cast > in stone. It all depends on what dangers the wire is exposed to. I updated my design this morning, and removed the second fuseable link. > Circuit breakers are mechanical devices that take time to operate. > That time could be longer than it takes a smaller fuse to blow. A larger > fuse will be slower to blow in case of the over-voltage module shorting out. > The aux alternator fuse protects the battery. It will not hurt to use a 30 > amp fuse. Z-13/8 uses a 20awg fuselink which will probably carry more > than 30 amps before the wire melts. The aux alternator output is self > current limiting and will never exceed 10 amps or so. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479262#479262 ________________________________________________________________________________
Date: Apr 11, 2018
Well, the 1st issue is establishing what Mark meant when he mentioned that 10.6V limit. Because unless he's using a truly massively oversized battery, it will *always* drop below 10.6V during cranking. That's why old Kettering ignition (points & condenser) cars had ballast resistors in series with their points. The points actually run on around 6-8 volts, and resistor gets switched out of the circuit during cranking because of the battery voltage drop due to cranking loads. Dropping down around 10V (sometimes even lower) is fairly common during starting. Look back through the archives for all the complaints about EFISs rebooting while cranking the engine. So....I'm betting that Mark meant he's measuring 10.6V *after* 15 seconds of cranking, but with no/minimal load on the battery. Now, go back to the Corvette/Chevette example. If you accelerate the Corvette for 15 seconds, it'll still have 400 HP, but you may only have 3 seconds of capacity (gas) left. Mark's test is even less valid if one has chosen a Lithium chemistry battery; their voltage has much less decline until it 'falls off the cliff' at full discharge. The real test is monitoring *how long* voltage remains above the voltage that indicates complete discharge (which is around 10.5 V), while the typical load from the plane's required (endurance bus) electronics is applied. On Tue, Apr 10, 2018 at 11:24 PM, Ken Ryan wrote: > Charlie, It seems to me that your response does not address that the test > involves monitoring the voltage drop that occurs when the consistent load > is applied. The test is not simply, "will the battery spin the prop." The > test is, "what is the voltage drop caused by spinning the prop." > > It seems to me that if the voltage drops down further on a worn out > battery than it does on a fresh battery, there is at least the possibilit y > that this test could be quite useful. It does not seem to me that the > simple fact the battery "can be down 50% capacity and still reliably cran k > the engine" is germane to whether or not monitoring voltage under a > consistent load (in this case spinning the propeller for a specific time) > can be useful as a way to determine whether or not it is time to replace a > battery. > > I'm not saying that the spin-the-prop-and-monitor-voltage test is valid. > But it seems to me like it might be. I just can't see where simply notin g > that a depleted battery can still spin a prop says anything about the > usefulness of such a test. Sorry, but I just can't seem to make that > connection. Probably I am a little bit dense :) -- it wouldn't be the fir st > time. > > In evaluating the suggested test, as a starting point I would like to kno w > if the voltage drop would be significantly different on a new vs a worn o ut > battery. If the answer is no, the drop would be about the same, then case > closed. Test invalid. But if it turns out the voltage drop is significant ly > greater on a worn out battery, then I think there is reason to believe th at > the test might be useful. > > > On Tue, Apr 10, 2018, 20:04 Charlie England wrote: > >> If the only use for the battery is starting, then it's a valid test. But >> if the battery is backup electrical power for the alternator and you nee d >> electrical power to keep the flight safe to its conclusion, then it isn' t a >> valid test. >> >> It can be down to 50% capacity & still reliably crank the engine. But if >> the alternator dies and you need the battery to keep the engine running >> (electronic ignition, glass panel in IFR, etc), then you'd only have hal f >> or less the time you thought you'd have, based on the battery's rated >> capacity. >> >> It's the difference between power and energy. 400 HP Corvette with 1/2 >> gallon of gas, vs 80 HP Chevette with 15 gallons. >> >> That help? >> >> On 4/10/2018 10:06 PM, Ken Ryan wrote: >> >> Charlie, It would seem to me that putting a consistent load (turning the >> starter, similar temperatures) on the battery, and noting the voltage dr op >> would constitute a valid test. It is surely not the most accurate, but i f >> done in a consistent manner, it is seems it would be much better than do ing >> nothing at all. Also, I don't see how the fact that it only takes 5% of >> battery capacity to start the engine has any relevance on whether such a >> rudimentary engine spinning stress test is valid, or not. Are you saying >> that it is likely that one would note the same voltage drop on a brand n ew >> battery as on a battery that is nearing the end of its useful life? >> Enlighten! >> >> On Tue, Apr 10, 2018 at 6:39 PM, Charlie England >> wrote: >> >>> Since it only takes around 5% of capacity to start the engine, that >>> might not be the most reliable test. >>> >>> On 4/10/2018 7:06 PM, Mark Moyle wrote: >>> >>> Quick load test on a battery ismags grounded or off and mixtur e >>> pulled. Crank the engine and monitor the battery voltage. If after 15 >>> seconds the battery voltage does NOT drop below 10.6 volts DC the batte ry >>> is good. If not charge the battery and test again. >>> Mark Moyle >>> Platinum Alaska >>> >>> From: <owner-aeroelectric-list-server(at)matronics.com> on behalf of Rene < >>> rene(at)felker.com> >>> Reply-To: >>> Date: Tuesday, April 10, 2018 at 3:35 PM >>> To: >>> Subject: RE: AeroElectric-List: Please critique my electrical design >>> >>> I do not know about what sells..but I have mine load tested at >>> Batteries +. >>> >>> >>> >>> I have two batteries and two alternators. I have one battery that is >>> 10+ years and the other is about 5 now. I had two battery failures .one >>> self induced and the other was infant mortality. >>> >>> >>> >>> Rene' >>> >>> 801-721-6080 >>> >>> >>> >>> *From:* owner-aeroelectric-list-server(at)matronics.com < >>> owner-aeroelectric-list-server(at)matronics.com> *On Behalf Of *FLYaDIVE >>> *Sent:* Tuesday, April 10, 2018 5:15 PM >>> *To:* aeroelectric-list(at)matronics.com >>> *Subject:* Re: AeroElectric-List: Please critique my electrical design >>> >>> >>> >>> Bob: >>> >>> >>> >>> Let's get a show of hands... >>> >>> How many Pilots out there have a LOAD tester? >>> >>> I can't get owners to check their tires and you want them to load test a >>> battery! >>> >>> Granted! This is a aero-electric email list and many are builders. So , >>> if there are fellows out there that do have a load tester I doubt that >>> would cover the rest of the BUYERS that only purchased the plane and di d >>> not build. >>> >>> What do you think would sell a plane faster: >>> >>> 'Oh, and this plane has Dual Alternators and Dual Batteries.' >>> >>> Or... >>> >>> 'And every year at annual I Load Test the battery." >>> >>> >>> >>> Barry >>> >>> >>> >>> >>> >>> On Tue, Apr 10, 2018 at 4:44 PM, Robert L. Nuckolls, III < >>> nuckolls.bob(at)aeroelectric.com> wrote: >>> >>> At 03:01 PM 4/10/2018, you wrote: >>> >>> >>> =C3=82 With two alternators, why a backup battery? >>> >>> =C3=82 Bob . . . >>> >>> >>> =C3=A2=82=AC=B9Because what if the battery fails? >>> G-5's can have the Garmin $150 TINNY battery or =C3=A2=82=AC =B9you can apply that >>> money to a much larger second battery which will be big enough to start the >>> plane and supply days of power for the G-5.=C3=82 I have not installed the >>> G-3,=C3=82 but I have installed 2 planes with Dual G-5's (AI & HSI). =C3=82 With >>> dual G-5's in a certified plane you are required to=C3=82 >>> have dual Garmin batteries...=C3=82 That is $300 for a stinking 1 or 2 AH >>> battery.=C3=82 Yea, I would be very happy to install a second battery - a small >>> one - With just enough to start the plane in a 24:00 DARK stranded >>> situation.=C3=82 =C3=82 >>> Yea, happened to me one night.=C3=82 No Fun! >>> >>> Barry >>> >>> >>> Was this in spite of a considered preventative >>> maintenance program? What was the battery's last >>> cap-check value before the failure? >>> >>> A battery that is watched and maintained as >>> carefully as tires, belts, propeller nicks >>> air cleaners and engine oil is very unlikely >>> to fail. Dual alternators virtually assures >>> you of engine driven energy in spite of the >>> loss of one alternator. >>> >>> The rule of thumb for battery replacement >>> in the TC world is when it falls to less than >>> 75% of original capacity . . . in the modern >>> RG battery world, this means it probably >>> still cranks the engine but is in substantial >>> decline on an ever increasing slope to failure >>> yet unlikely to go belly up away from your >>> home hangar. >>> >>> Few light aircraft owner's manuals speak to >>> affirmative-action maintenance programs . . . >>> but I'd bet that top-billing in the cast of performers >>> virtually all dark-n-stormy night stories that >>> speak to battery failure is a beyond-service-life >>> battery. >>> >>> >>> Bob . . . >>> >>> >>> >>> >>> >>> >>> Virus-fr ee. >>> www.avast.com >>> >>> <#m_-6378004472635657997_m_-615151073569806401_m_-960492680129280463_m_ 6581499881476749600_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> >>> >> >> >> ________________________________________________________________________________
Subject: Car clock in an aircraft
Date: Apr 11, 2018
Hm. If it works without being wired in, why not just leave it powered by the button cell batteries? Seems like a "non-essential" item to me, and I would hate for there to be ANY possibility it might drain the battery over time. Jim Parker -------- Original Message -------- Subject: AeroElectric-List: Car clock in an aircraft From: Carlos Trigo <trigo(at)mail.telepac.pt> Date: Tue, April 10, 2018 4:40 pm To the electrowizzards in this list. (This is not a rocket science aircraft subject, but I need your help on this) I bought one of those cheap (chinese) digital car clocks, with temperature indication, to install in the back of my RV-10, as a courtesy to the rear passengers. (please avoid any comments on this decision... :-)). As one could expect, the miserable instructions leaflet which came with the clock, doesnt have any information about the electric circuit, so Im in the guess field here. This critter has a 2-wire cable to be connected to 12V/24V, and also has 2 of those coin type batteries, so I suppose that the batteries are a backup to the ships power. But Im not sure... This leaves me with a doubt on where to connect the + wire of the power cable. Should I connect it to a circuit which is only powered when the aircraft Master switch is on, to avoid this critter to deplete the aircraft battery? Or can I connect it to the always hot bus, hoping that when the Master is Off, the clocks coin batteries will be powering the clock and only a very tiny current will be draining from the always hot bus, not depleting the aircrafts battery? Even knowing that without information on the clocks electric circuit it is difficult to know the answer, comments and suggestions are welcome Thanks Carlos ________________________________________________________________________________
Date: Apr 11, 2018
Thanks Charlie. On Wed, Apr 11, 2018 at 4:41 AM, Charlie England wrote: > Well, the 1st issue is establishing what Mark meant when he mentioned tha t > 10.6V limit. Because unless he's using a truly massively oversized batter y, > it will *always* drop below 10.6V during cranking. That's why old Ketteri ng > ignition (points & condenser) cars had ballast resistors in series with > their points. The points actually run on around 6-8 volts, and resistor > gets switched out of the circuit during cranking because of the battery > voltage drop due to cranking loads. Dropping down around 10V (sometimes > even lower) is fairly common during starting. Look back through the > archives for all the complaints about EFISs rebooting while cranking the > engine. > > So....I'm betting that Mark meant he's measuring 10.6V *after* 15 seconds > of cranking, but with no/minimal load on the battery. Now, go back to the > Corvette/Chevette example. If you accelerate the Corvette for 15 seconds, > it'll still have 400 HP, but you may only have 3 seconds of capacity (gas ) > left. > > Mark's test is even less valid if one has chosen a Lithium chemistry > battery; their voltage has much less decline until it 'falls off the clif f' > at full discharge. > > The real test is monitoring *how long* voltage remains above the voltage > that indicates complete discharge (which is around 10.5 V), while the > typical load from the plane's required (endurance bus) electronics is > applied. > > > On Tue, Apr 10, 2018 at 11:24 PM, Ken Ryan wrote: > >> Charlie, It seems to me that your response does not address that the tes t >> involves monitoring the voltage drop that occurs when the consistent loa d >> is applied. The test is not simply, "will the battery spin the prop." Th e >> test is, "what is the voltage drop caused by spinning the prop." >> >> It seems to me that if the voltage drops down further on a worn out >> battery than it does on a fresh battery, there is at least the possibili ty >> that this test could be quite useful. It does not seem to me that the >> simple fact the battery "can be down 50% capacity and still reliably cra nk >> the engine" is germane to whether or not monitoring voltage under a >> consistent load (in this case spinning the propeller for a specific time ) >> can be useful as a way to determine whether or not it is time to replace a >> battery. >> >> I'm not saying that the spin-the-prop-and-monitor-voltage test is valid. >> But it seems to me like it might be. I just can't see where simply noti ng >> that a depleted battery can still spin a prop says anything about the >> usefulness of such a test. Sorry, but I just can't seem to make that >> connection. Probably I am a little bit dense :) -- it wouldn't be the fi rst >> time. >> >> In evaluating the suggested test, as a starting point I would like to >> know if the voltage drop would be significantly different on a new vs a >> worn out battery. If the answer is no, the drop would be about the same, >> then case closed. Test invalid. But if it turns out the voltage drop is >> significantly greater on a worn out battery, then I think there is reaso n >> to believe that the test might be useful. >> >> >> >> >> On Tue, Apr 10, 2018, 20:04 Charlie England wrote : >> >>> If the only use for the battery is starting, then it's a valid test. Bu t >>> if the battery is backup electrical power for the alternator and you ne ed >>> electrical power to keep the flight safe to its conclusion, then it isn 't a >>> valid test. >>> >>> It can be down to 50% capacity & still reliably crank the engine. But i f >>> the alternator dies and you need the battery to keep the engine running >>> (electronic ignition, glass panel in IFR, etc), then you'd only have ha lf >>> or less the time you thought you'd have, based on the battery's rated >>> capacity. >>> >>> It's the difference between power and energy. 400 HP Corvette with 1/2 >>> gallon of gas, vs 80 HP Chevette with 15 gallons. >>> >>> That help? >>> >>> On 4/10/2018 10:06 PM, Ken Ryan wrote: >>> >>> Charlie, It would seem to me that putting a consistent load (turning th e >>> starter, similar temperatures) on the battery, and noting the voltage d rop >>> would constitute a valid test. It is surely not the most accurate, but if >>> done in a consistent manner, it is seems it would be much better than d oing >>> nothing at all. Also, I don't see how the fact that it only takes 5% of >>> battery capacity to start the engine has any relevance on whether such a >>> rudimentary engine spinning stress test is valid, or not. Are you sayin g >>> that it is likely that one would note the same voltage drop on a brand new >>> battery as on a battery that is nearing the end of its useful life? >>> Enlighten! >>> >>> On Tue, Apr 10, 2018 at 6:39 PM, Charlie England >>> wrote: >>> >>>> Since it only takes around 5% of capacity to start the engine, that >>>> might not be the most reliable test. >>>> >>>> On 4/10/2018 7:06 PM, Mark Moyle wrote: >>>> >>>> Quick load test on a battery ismags grounded or off and mixtu re >>>> pulled. Crank the engine and monitor the battery voltage. If after 1 5 >>>> seconds the battery voltage does NOT drop below 10.6 volts DC the batt ery >>>> is good. If not charge the battery and test again. >>>> Mark Moyle >>>> Platinum Alaska >>>> >>>> From: <owner-aeroelectric-list-server(at)matronics.com> on behalf of Rene >>>> >>>> Reply-To: >>>> Date: Tuesday, April 10, 2018 at 3:35 PM >>>> To: >>>> Subject: RE: AeroElectric-List: Please critique my electrical design >>>> >>>> I do not know about what sells..but I have mine load tested a t >>>> Batteries +. >>>> >>>> >>>> >>>> I have two batteries and two alternators. I have one battery that is >>>> 10+ years and the other is about 5 now. I had two battery failures .one >>>> self induced and the other was infant mortality. >>>> >>>> >>>> >>>> Rene' >>>> >>>> 801-721-6080 >>>> >>>> >>>> >>>> *From:* owner-aeroelectric-list-server(at)matronics.com < >>>> owner-aeroelectric-list-server(at)matronics.com> *On Behalf Of *FLYaDIVE >>>> *Sent:* Tuesday, April 10, 2018 5:15 PM >>>> *To:* aeroelectric-list(at)matronics.com >>>> *Subject:* Re: AeroElectric-List: Please critique my electrical design >>>> >>>> >>>> >>>> Bob: >>>> >>>> >>>> >>>> Let's get a show of hands... >>>> >>>> How many Pilots out there have a LOAD tester? >>>> >>>> I can't get owners to check their tires and you want them to load test >>>> a battery! >>>> >>>> Granted! This is a aero-electric email list and many are builders. >>>> So, if there are fellows out there that do have a load tester I doubt that >>>> would cover the rest of the BUYERS that only purchased the plane and d id >>>> not build. >>>> >>>> What do you think would sell a plane faster: >>>> >>>> 'Oh, and this plane has Dual Alternators and Dual Batteries.' >>>> >>>> Or... >>>> >>>> 'And every year at annual I Load Test the battery." >>>> >>>> >>>> >>>> Barry >>>> >>>> >>>> >>>> >>>> >>>> On Tue, Apr 10, 2018 at 4:44 PM, Robert L. Nuckolls, III < >>>> nuckolls.bob(at)aeroelectric.com> wrote: >>>> >>>> At 03:01 PM 4/10/2018, you wrote: >>>> >>>> >>>> =C3=82 With two alternators, why a backup battery? >>>> >>>> =C3=82 Bob . . . >>>> >>>> >>>> =C3=A2=82=AC=B9Because what if the battery fails? >>>> G-5's can have the Garmin $150 TINNY battery or =C3=A2=82=AC =B9you can apply that >>>> money to a much larger second battery which will be big enough to star t the >>>> plane and supply days of power for the G-5.=C3=82 I have not installe d the >>>> G-3,=C3=82 but I have installed 2 planes with Dual G-5's (AI & HSI). =C3=82 With >>>> dual G-5's in a certified plane you are required to=C3=82 >>>> have dual Garmin batteries...=C3=82 That is $300 for a stinking 1 or 2 AH >>>> battery.=C3=82 Yea, I would be very happy to install a second battery - a small >>>> one - With just enough to start the plane in a 24:00 DARK stranded >>>> situation.=C3=82 =C3=82 >>>> Yea, happened to me one night.=C3=82 No Fun! >>>> >>>> Barry >>>> >>>> >>>> Was this in spite of a considered preventative >>>> maintenance program? What was the battery's last >>>> cap-check value before the failure? >>>> >>>> A battery that is watched and maintained as >>>> carefully as tires, belts, propeller nicks >>>> air cleaners and engine oil is very unlikely >>>> to fail. Dual alternators virtually assures >>>> you of engine driven energy in spite of the >>>> loss of one alternator. >>>> >>>> The rule of thumb for battery replacement >>>> in the TC world is when it falls to less than >>>> 75% of original capacity . . . in the modern >>>> RG battery world, this means it probably >>>> still cranks the engine but is in substantial >>>> decline on an ever increasing slope to failure >>>> yet unlikely to go belly up away from your >>>> home hangar. >>>> >>>> Few light aircraft owner's manuals speak to >>>> affirmative-action maintenance programs . . . >>>> but I'd bet that top-billing in the cast of performers >>>> virtually all dark-n-stormy night stories that >>>> speak to battery failure is a beyond-service-life >>>> battery. >>>> >>>> >>>> Bob . . . >>>> >>>> >>>> >>>> >>>> >>>> >>>> Virus-f ree. >>>> www.avast.com >>>> >>>> <#m_-3808612535981414965_m_-6378004472635657997_m_-615151073569806401_ m_-960492680129280463_m_6581499881476749600_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F 9FDF2> >>>> >>> >>> >>> > ________________________________________________________________________________
Date: Apr 11, 2018
At 06:14 PM 4/10/2018, you wrote: >Bob: > >Let's get a show of hands... >How many Pilots out there have a LOAD tester? not load . . . capacity >I can't get owners to check their tires and you >want them to load test a battery! That's a separate issue. Lots of folks fail to take their drugs as prescribed. >Granted!=C2 This is a aero-electric email list >and many are builders.=C2 So, if there are >fellows out there that do have a load tester I >doubt that would cover the rest of the BUYERS >that only purchased the plane and did not build. I don't design systems for marketability. I strive for failure tolerance and risk reduction. >What do you think would sell a plane faster: >'Oh, and this plane has Dual Alternators and Dual Batteries.' >Or... >'And every year at annual I Load Test the battery." If you've got an e-bus, then a cap test is easy. While doing other things on the airplane, set the cockpit up for endurance mode and see if the battery will run your electro-whizzies for at least 75 percent of time as when the battery was new. Failure to honor critical axioms in aviation present increased risks . . . you have to make sure that fuel aboard is MORE than sufficient to the mission. Some builders with e-bus structures will size the battery and endurance mode operations such that electrical capacity exceeds fuel capacity. The point being offered is that an electrical system can be configured and used in a manner that makes an electrical emergency exceedingly unlikely. I try to remind people that when 'standby' equipment is being installed, it comes with cost, weight and maintenance issues. Therefore, is it not useful to consider ways that standby equipment becomes smaller, lighter, less expensive and/or more efficient . . . if not eliminated all together? If one is unwilling to put a dip-stick into the energy contained in the ship's main battery . . . how is a standby battery going to be treated any differently? Bob . . . ________________________________________________________________________________
Date: Apr 11, 2018
At 09:26 AM 4/11/2018, you wrote: > >Hm. If it works without being wired in, why not just leave it powered >by the button cell batteries? Seems like a "non-essential" item to me, >and I would hate for there to be ANY possibility it might drain the >battery over time. If any accessory powered internally by a 'button cell' is fitted with an external power connection, I would wonder if external power isn't just for lighting. Button cell capacities are very low . . . digital devices that use them will have current drains measured in microamps. If the external power does indeed supplement the internal battery, then drain on that lead will be insignificant with respect to energy stored in the ship's battery. Similarly, electric clocks in car's used to be powered directly from the battery with no significant impact on the system's availability. If the external lead is to power panel illumination, then consumption will be much higher . . . but probably independent of electronics. Hence needs voltage only while the airplane is powered up. Bob . . . ________________________________________________________________________________
Date: Apr 11, 2018
> >I followed B&C's parts list, but when they switched it from a >generic Ford regulator to the LR3C I didn't realize I should have >used the Z-12 architecture for that component. Z-12 doesn't include >a fuseable link or crowbar -- should I take those out? The ovm14 can come out, that's built into the LR3. If your using a fused bus, then the fusible link and remotely located field breaker stays in. > I put the LV Warn light back in my design for now like the Z-12 > has, but I'm sure the G3X has an input for that, so a stand-alone > light won't be required. the G3x has its own low voltage sense, resolution and display feature. If you don't wish to use the separate light featured in the LR3C installation, just leave that terminal unused. > I'll also have to figure out if I still need the Lo Volt Warn CB > in that arrangement. YES! that is your bus voltage sense lead. Bob . . . ________________________________________________________________________________
Date: Apr 11, 2018
Bob, thanks for reiterating the difference between a load test and a capacity test. Is there any possibility of gaining insight into a battery's capacity by studying the results of load testing? On Wed, Apr 11, 2018 at 10:03 AM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 06:14 PM 4/10/2018, you wrote: > > Bob: > > Let's get a show of hands... > How many Pilots out there have a LOAD tester? > > > not load . . . capacity > > I can't get owners to check their tires and you want them to load test a > battery! > > > That's a separate issue. Lots of folks > fail to take their drugs as prescribed. > > Granted!=C3=82 This is a aero-electric email list and many are builders. =C3=82 So, > if there are fellows out there that do have a load tester I doubt that > would cover the rest of the BUYERS that only purchased the plane and did > not build. > > > I don't design systems for marketability. > I strive for failure tolerance and > risk reduction. > > What do you think would sell a plane faster: > 'Oh, and this plane has Dual Alternators and Dual Batteries.' > Or... > 'And every year at annual I Load Test the battery." > > > If you've got an e-bus, then a cap test > is easy. While doing other things on the > airplane, set the cockpit up for endurance > mode and see if the battery will run your > electro-whizzies for at least 75 percent > of time as when the battery was new. > > Failure to honor critical axioms in aviation > present increased risks . . . you have to > make sure that fuel aboard is MORE than > sufficient to the mission. Some builders > with e-bus structures will size the battery > and endurance mode operations such that > electrical capacity exceeds fuel capacity. > > The point being offered is that an electrical > system can be configured and used in a manner > that makes an electrical emergency exceedingly > unlikely. I try to remind people that when > 'standby' equipment is being installed, it comes > with cost, weight and maintenance issues. > > Therefore, is it not useful to consider ways that > standby equipment becomes smaller, lighter, less > expensive and/or more efficient . . . if not > eliminated all together? If one is unwilling to > put a dip-stick into the energy contained in the > ship's main battery . . . how is a standby battery > going to be treated any differently? > > Bob . . . > ________________________________________________________________________________
Date: Apr 11, 2018
> >So....I'm betting that Mark meant he's measuring >10.6V *after* 15 seconds of cranking, but with >no/minimal load on the battery. Now, go back to >the Corvette/Chevette example. If you accelerate >the Corvette for 15 seconds, it'll still have >400 HP, but you may only have 3 seconds of capacity (gas) left.=C2 The legacy LOAD TEST is an artifact carried over from the automotive world. Automotive load testers have a built in 15 second timer that drives a light or perhaps a beeper. Emacs! Emacs! Emacs! When testing a battery, one starts the timer and then cranks up the load knob to depress and hold voltage at 9.0 volts. At the end of 15 seconds, you get a light or a beep whereupon you read the current being delivered. This is a 'cranking amps' kind of current and a figure of merit for battery's suitability for continued service. >Mark's test is even less valid if one has chosen >a Lithium chemistry battery; their voltage has >much less decline until it 'falls off the cliff' at full discharge. Absolutely. The legacy lead-acid load test is not applicable to lithium. >The real test is monitoring *how long* voltage >remains above the voltage that indicates >complete discharge (which is around 10.5 V), >while the typical load from the plane's required >(endurance bus) electronics is applied. Exactly. The load test numbers can give you a rough idea of how the battery has degraded over time . . . and tells you whether or not it will get your engine going. But 8ut says NOTHING about capacity . . . i.e. an ability to power ENDURANCE loads for the interval you have established with design goals. When the e-bus first appeared in OBAM aircraft, a recommended design goal was to have electrical endurance exceed fuel endurance. Obviously, not a hard-n-fast rule but what every number the builder chooses, it's really a pretty cool thing to VERIFY that the number can be achieved. There's a secondary benefit for replacing a battery that fails to meet endurance requirements . . . it's probably going to be replaced before its cranking ability is seriously compromised. Hence, exceedingly low probability of an off-home-base failure of the battery. Bob . . . ________________________________________________________________________________
Date: Apr 11, 2018
At 02:12 PM 4/11/2018, you wrote: >Bob, thanks for reiterating the difference between a load test and a >capacity test. Is there any possibility of gaining insight into a >battery's capacity by studying the results of load testing? Only very roughly . . . even then it's something that needs to be conducted pretty often and results TRACKED with time. I've not conducted such testing so I can't offer even a rough correlation of capacity vs. load-test. But I'm guessing it is roughly proportional. If your brand new battery tested at say 600A, then it's probably reaching end of life when the load test falls to 400A . . . even tho it still cranks the engine. Bob . . . ________________________________________________________________________________
Subject: Re: Car clock in an aircraft
Date: Apr 11, 2018
Typically, Real Time Clock ICs will have two power input pins, a primary and a backup. For example, see the MCP7940N datasheet... http://ww1.microchip.com/downloads/en/DeviceDoc/20005010F.pdf ...where you'll see that Pin 4 is for normal operating supply and Pin 3 is for battery backup. Generally speaking, the battery is there only to keep timekeeping underway if primary power is lost. It's not uncommon for all other functions of the clock -- including time display -- to cease functioning when using battery backup. So, chances are good that if you power your automotive clock from a switched bus, the coin cell will keep the clock accurate when the bus is turned off. You'll know it's time to replace it when the clock doesn't keep time properly between flights. Eric Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479280#479280 ________________________________________________________________________________
Date: Apr 11, 2018
>> 10.6V *after* 15 seconds of cranking, but with no/minimal load on the bat tery Nope, The starter is the battery load tester. Continuously measure the vo ltage while the starter is engaged. If the voltage drops below 10.6 volts w hile cranking the battery needs to be charged and tested again. A health ba ttery will return to 12 +volts after opening the starting circuit. Another p iece of test gear is a an amp meter with amp shut between the negative termi nal and battery post... (which I like better than the amp probe I use with t he fluke 87) to test the health of the starter...say the load spikes to 250 a mps to overcome the inertial mass of the rotating parts then drops to 125-15 0 amps...starter tests good. The only other charging system health test is charging voltage... automotive standards were 13.6 to 14.8 VDC...aircraft with solid state voltage regulat or is 14.1 volts...I think. Sent from my iPad > On 11 Apr 2018, at 11:46 AM, Robert L. Nuckolls, III <nuckolls.bob@aeroele ctric.com> wrote: > >> >> So....I'm betting that Mark meant he's measuring 10.6V *after* 15 seconds of cranking, but with no/minimal load on the battery. Now, go back to the C orvette/Chevette example. If you accelerate the Corvette for 15 seconds, it' ll still have 400 HP, but you may only have 3 seconds of capacity (gas) left .=C3=82 > > The legacy LOAD TEST is an artifact carried > over from the automotive world. Automotive > load testers have a built in 15 second timer > that drives a light or perhaps a beeper. > > <27063fc.jpg> > > > <270642b.jpg> <270643b.jpg> > > > When testing a battery, one starts the timer and then > cranks up the load knob to depress and hold voltage > at 9.0 volts. At the end of 15 seconds, you get a light > or a beep whereupon you read the current being delivered. > > This is a 'cranking amps' kind of current and a figure of > merit for battery's suitability for continued service. > >> Mark's test is even less valid if one has chosen a Lithium chemistry batt ery; their voltage has much less decline until it 'falls off the cliff' at f ull discharge. > > Absolutely. The legacy lead-acid load test is > not applicable to lithium. > > >> The real test is monitoring *how long* voltage remains above the voltage t hat indicates complete discharge (which is around 10.5 V), while the typical load from the plane's required (endurance bus) electronics is applied. > > Exactly. The load test numbers can give you a rough > idea of how the battery has degraded over time . . . > and tells you whether or not it will get your > engine going. But 8ut says NOTHING about capacity . . . > i.e. an ability to power ENDURANCE loads for the interval > you have established with design goals. > > When the e-bus first appeared in OBAM aircraft, > a recommended design goal was to have electrical > endurance exceed fuel endurance. Obviously, > not a hard-n-fast rule but what every number > the builder chooses, it's really a pretty cool > thing to VERIFY that the number can be achieved. > > There's a secondary benefit for replacing a > battery that fails to meet endurance requirements . . . > it's probably going to be replaced before its > cranking ability is seriously compromised. Hence, > exceedingly low probability of an off-home-base failure > of the battery. > > > Bob . . . ________________________________________________________________________________
Date: Apr 11, 2018
Bob, Thanks for the corrections. nuckolls.bob(at)aeroelect wrote: > > The ovm14 can come out, that's built into the LR3. Okay, thanks. I've corrected that in the latest version. > If your using a fused bus, then the fusible link > and remotely located field breaker stays in. Just to make sure I'm following -- I'm placing the Alt Fld CB on a bus bar along with three other CBs (Main Bus 2). In this case I don't need the fusible link, correct? I've kept the fusible link between Main Bus 1 (fuses) and Main Bus 2 (CBs) because the distance is about 18". > The G3X has its own low voltage sense, resolution > and display feature. If you don't wish to use the > separate light featured in the LR3C installation, > just leave that terminal unused. > > YES! that is your bus voltage sense lead. Thanks -- I removed the light and I'll use the G3X annunciator for LV, but I left the terminal 3 feed with the 2A CB. Bob . . .[/quote] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479282#479282 ________________________________________________________________________________
Date: Apr 11, 2018
At 03:30 PM 4/11/2018, you wrote: >>>10.6V *after* 15 seconds of cranking, but with no/minimal load on >>>the battery >Nope, The starter is the battery load tester. Continuously >measure the voltage while the starter is engaged. If the voltage >drops below 10.6 volts while cranking the battery needs to be >charged and tested again. A health battery will return to 12 +volts >after opening the starting circuit. Another piece of test gear is a >an amp meter with amp shut between the negative terminal and battery >post... (which I like better than the amp probe I use with the fluke >87) to test the health of the starter...say the load spikes to 250 >amps to overcome the inertial mass of the rotating parts then drops >to 125-150 amps...starter tests good. >The only other charging system health test is charging voltage... >automotive standards were 13.6 to 14.8 VDC...aircraft with solid >state voltage regulator is 14.1 volts...I think. Meaningful data confirming battery condition is hard to come by. Variation in starter draw due to the modulated torque loads presented by reciprocating pistons produces a wildly unstable value on an analog meter . . . and can drive many digital displays nuts. I've done energy demand studies using fast data acquisition systems that sample several hundred times per second combined with 'integration by parts' software that yields very stable numbers. But just as in most vehicles, a flagging starter battery will make it's condition known because of how it sounds . . . and the bottom line for cranking demands only that the engine got going yet one more time. A battery that's demonstrating decreased starter performance may already have sagged below the ca[acotu for continued service as set by design goals. Bob . . . ________________________________________________________________________________
Date: Apr 12, 2018
Anecdotally: I replaced the 60Ah battery of the Ford Mondeo in preparation for a skiing trip. It wouldn't take more than an 18 Ah charge from empty. It still cranked fine. ________________________________________________________________________________
Subject: Diy AOA, anyone ?
Date: Apr 12, 2018
Hi all, One of my building buddies just challenged me concerning the following Pitot angle of attack (AOA) device https://www.thingiverse.com/thing:1121786 Of course 3D printing the device is the easiest part. But does anyone here happen to have implemented, programmed, etc. an AOA indicator, and with what success ? BTW, some years ago I had the opportunity to make a study for such a device based on differential pressure between upper and lower wing surface. At the time the study involved a University wind tunnel, hotwire profiles, several students, but nowadays my approach needs to be much much "lower tech" as I no longer have access to such facilities. Thanks for your inputs, -- Best regards, Gilles http://contrails.free.fr http://lapierre.skunkworks.free.fr ________________________________________________________________________________
Date: Apr 13, 2018
Subject: Re: Charging Issue
Matt: How is a crack in a feed-through causing a voltage drop? If it was shorting out a CB would pop. You did not give p/n so I do not know if it is a grommet feed through or a terminal type feed through. If it was a grommet, that would also mean the insulation on the wire failed. If it is a terminal type a simple thing like a poor connection could be causing the problem. Without seeing the setup I am assuming (I hate that word) that all is well with: Connections Connectors Crimps and Materials. RULE: You can not tell if there is corrosion on a connection unless you open the connection and clean the contact areas. Also, replace the Lock Washers with Star Lock Washers. Replace them every time you undo the connection. The lock washers have to cut into the faces of the mating surfaces. Alternator Noise is fairly easy to solve. I say 'fairly easy' because I do not know your wiring. I use 25,000 uF @ 16 WVDC Electrolytic Caps. <-- Only because I have a box full of them and they work. If you want to go bigger... Have at it! 'It's all good baby!' Positive to the hot lead. Negative to Ground. Put in very close to the B+ output of the Alternator. Keep the leads as short as possible. Second location for the same size Cap. At the ACU. Between the 'A' lead [the lead coming from alternator B+ to the ACU]. Again, keep the leads as short as possible. DO NOT STRAIN THE WIRES. Many alternators use a automotive looking/type Cap that has only one lead which goes to the B+ and the body of the Cap is mounted to ground. If you purchase this type of Cap from the auto store. <-- The value is no where near that of the electrolytic. It handles a different frequency. 1 - Make sure the mounting tab/clamp is WELDED to the body of the Cap. 2 - The mounting hole is a HOLE! Not 'U' cutout. This makes mounting extremely easy and pretty much eliminates the Cap from coming loose. If you have access to a O Scope you can hook it up to each of the wires: B+ Field Ground And see exactly which wire is carrying the noise AND what frequency it is. When even ONE diode in the alternators diode pack fails the noise becomes present. If that is the case you will hear the noise change in frequency as the engine is increased and decreased in RPM. It may even change in amplitude. If that is what you are seeing (O Scope) and hearing (Headset), then the Caps will decrease the problem but NOT eliminate it. Repair/Replace the alternator. Barry On Tue, Apr 10, 2018 at 8:48 PM, mhealydds wrote: > > I was the original poster and found my issue. I had a cracked firewall > passthrough fitting (it was Blue Sea fitting a lot of other RV-10 user > reported using). Anyway, it was in a spot not easy to inspect and never > thought about it being cracked, just he connections on the fitting. Now a > have a bad alternator noise I have thing to track down. Anyone dealt with > that? > > Matt > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=479250#479250 > > ________________________________________________________________________________
Subject: Re: Diy AOA, anyone ?
Date: Apr 13, 2018
I am about to embark on such a device... I do have a few sensors that I'm exploring - https://www.mouser.com/ProductDetail/NXP/MPXV5004DP/?qs=r8OyiFxb6Rd0SEc8C8FTtQ%3D%3D&gclid=Cj0KCQjwqsHWBRDsARIsALPWMEPR9lBEDtFAgUCnJAyuzfox0BoKwWSAPuJzr-_TL6mzXtmxLWp3dcMaAjfiEALw_wcB Looks pretty dang close for the pressure sensing. Do you know how much deltaP we are expecting at sub 200 knots indicated based on your previous work? I've got to finish my airspeed sensing for my engine monitor / air data computer first, then on to AOA. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479302#479302 ________________________________________________________________________________
Date: Apr 13, 2018
Hi Andy: I worked on an RV6A which had this AOA unit: http://www.aircraftspruce.com/catalog/inpages/aoasportsystemaluminum.php?clickkey=5477 It required and used sensing holes on the top and bottom of the wing. Maybe... If you give them a call... NOT ACS! They maybe able to answer the question. Barry On Fri, Apr 13, 2018 at 8:34 AM, andymeyer wrote: > > > > I am about to embark on such a device... > I do have a few sensors that I'm exploring - > https://www.mouser.com/ProductDetail/NXP/MPXV5004DP/? > qs=r8OyiFxb6Rd0SEc8C8FTtQ%3D%3D&gclid=Cj0KCQjwqsHWBRDsARIsALPWMEPR9l > BEDtFAgUCnJAyuzfox0BoKwWSAPuJzr-_TL6mzXtmxLWp3dcMaAjfiEALw_wcB > Looks pretty dang close for the pressure sensing. Do you know how much > deltaP we are expecting at sub 200 knots indicated based on your previous > work? > > I've got to finish my airspeed sensing for my engine monitor / air data > computer first, then on to AOA. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=479302#479302 > > ________________________________________________________________________________
Date: Apr 13, 2018
Agreed. And if it's needed, don't put it on an always-on bus. I had this situation with an earlier GRT unit that had an internal clock that required an always-on connection. Actually I had 3 units... the combined drain slowly but surely killed my AGM battery. They don't like that kind of treatment (there's slightly more to the story). But I would say "don't connect anything to always-on unless critical... then question why that product is in your plane". On 4/11/2018 10:26 AM, jim(at)poogiebearranch.com wrote: > > Hm. If it works without being wired in, why not just leave it powered > by the button cell batteries? Seems like a "non-essential" item to me, > and I would hate for there to be ANY possibility it might drain the > battery over time. > > Jim Parker > > > -------- Original Message -------- > Subject: AeroElectric-List: Car clock in an aircraft > From: Carlos Trigo <trigo(at)mail.telepac.pt> > Date: Tue, April 10, 2018 4:40 pm > To: aeroelectric-list(at)matronics.com > > > > To the electrowizzards in this list. > (This is not a rocket science aircraft subject, but I need your help on > this) > > I bought one of those cheap (chinese) digital car clocks, with > temperature indication, to install in the back of my RV-10, as a > courtesy to the rear passengers. (please avoid any comments on this > decision... :-)). > As one could expect, the miserable instructions leaflet which came with > the clock, doesnt have any information about the electric circuit, so > Im in the guess field here. > > This critter has a 2-wire cable to be connected to 12V/24V, and also has > 2 of those coin type batteries, so I suppose that the batteries are a > backup to the ships power. > But Im not sure... > > This leaves me with a doubt on where to connect the + wire of the power > cable. > Should I connect it to a circuit which is only powered when the aircraft > Master switch is on, to avoid this critter to deplete the aircraft > battery? > Or can I connect it to the always hot bus, hoping that when the Master > is Off, the clocks coin batteries will be powering the clock and only > a very tiny current will be draining from the always hot bus, not > depleting the aircrafts battery? > > Even knowing that without information on the clocks electric circuit > it is difficult to know the answer, comments and suggestions are welcome > > Thanks > Carlos > > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Apr 13, 2018
I cut the corner off a piece of 1/2" plate of aluminum. =C2-With it orien ted so the 90 degree angle is at the top right, I drilled a 1/4" hole halfw ay through from the top, and a 1/16" hole from the left that intersected wi th the 1/4" hole. =C2-I got the "homebuilder's pitot/static" from ACS. =C2-It's the one with two pieces of 1/4" tube tack welded into a base. =C2-I drilled a 1/4" hole through the base behind the others, then ran a 8" or so length of 1/4" tube through it and into the top of the triangle. =C2-Situated it so that the triangle touched the bottom of the previous t ubes, then buried the assembly in a peanut butter thick mix of micro. =C2 -Let it set, sanded it to an "airfoilish" shape, and wrapped it in a 9oz layer of glass. Works fine with my Dynon-100 AoA. On Thursday, April 12, 2018 11:17 PM, GTH wrote : Hi all, One of my building buddies just challenged me concerning the following Pitot angle of attack (AOA) device https://www.thingiverse.com/thing:1121786 Of course 3D printing the device is the easiest part. But does anyone here happen to have implemented, programmed, etc. an AOA indicator, and with what success ? BTW, some years ago I had the opportunity to make a study for such a device based on differential pressure between upper and lower wing surface. At the time the study involved a University wind tunnel, hotwire profiles, several students, but nowadays my approach needs to be much much "lower tech" as I no longer have access to such facilities. Thanks for your inputs, -- Best regards, Gilles http://contrails.free.fr http://lapierre.skunkworks.free.fr - S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Apr 13, 2018
An AOA probe can be made using only a single pop rivet with the mandrel removed. Connect the rivet to the AOA sensor with Tygon tubing. The sensor will compare the pressure differential between the pitot tube and the AOA port (pop rivet). Vans Aircraft uses this rivet probe in the latest version (iS) of their RV-12. The picture shows where I located the AOA rivet port in my wing. I drilled the rivet hole at the point where the 30 degree line is tangent to the wing. Although Van's tested different locations and determined that the optimum location is slightly farther down and and aft. Exactly where, I do not know. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479309#479309 Attachments: http://forums.matronics.com//files/angle_167.gif ________________________________________________________________________________
Date: Apr 13, 2018
Joe: Guessing: But, probably 3 hole diameters behind the high point (Max profile) of the wings profile. Three diameters is a negative pressure point in open end resonance. Barry Although Van's tested different locations and determined that the optimum > location is slightly farther down and and aft. Exactly where, I do not > know. > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=479309#479309 > > > Attachments: > > http://forums.matronics.com//files/angle_167.gif > > ________________________________________________________________________________
Date: Apr 13, 2018
How is =9Coptimum=9D determined? You would have to calibrate for different airspeed and AoAs and creative som e kind of algorithm or lookup table, regardless of location, no? On Apr 13, 2018, at 10:23, FLYaDIVE wrote: Joe: Guessing: But, probably 3 hole diameters behind the high point (Max profile ) of the wings profile. Three diameters is a negative pressure point in ope n end resonance. Barry > Although Van's tested different locations and determined that the optimum location is slightly farther down and and aft. Exactly where, I do not kno w. > > -------- > Joe Gores > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=479309#479309 > > > > > Attachments: > > http://forums.matronics.com//files/angle_167.gif > > > > ========================= > - > Electric-List" rel="noreferrer" target="_blank">http://www.matronics.c om/Navigator?AeroElectric-List > ========================= > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > ========================= > WIKI - > errer" target="_blank">http://wiki.matronics.com > ========================= > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" target="_blank">http://www.matronics.com/contribution > ========================= > > > ________________________________________________________________________________
Date: Apr 13, 2018
Hey Joe, Thanks for providing a KISS solution for a change! No disrespect intended to any lister, but sometimes it seems (to this neophyte anyway) that the more complicated the solution, the better it is deemed? Best... Bob Verwey 082 331 2727 On 13 April 2018 at 16:10, user9253 wrote: > > An AOA probe can be made using only a single pop rivet with the mandrel > removed. Connect the rivet to the AOA sensor with Tygon tubing. The > sensor will compare the pressure differential between the pitot tube and > the AOA port (pop rivet). Vans Aircraft uses this rivet probe in the > latest version (iS) of their RV-12. The picture shows where I located the > AOA rivet port in my wing. I drilled the rivet hole at the point where the > 30 degree line is tangent to the wing. Although Van's tested different > locations and determined that the optimum location is slightly farther down > and and aft. Exactly where, I do not know. > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=479309#479309 > > > Attachments: > > http://forums.matronics.com//files/angle_167.gif > > ________________________________________________________________________________
Date: Apr 13, 2018
Here is a link to the VansAirforce thread about AOA in the RV-12. http://www.vansairforce.com/community/showthread.php?t=34040 I do not know where is the optimum point to measure air pressure. All I know is that I looked at the angle on Dynon's AOA probe and thought that 30 degrees looked about right. I drilled a hole and hooked up some tubing and it worked. Several other RV-12 builders followed my lead and they are all happy. When Van's came out with a new and improved version of the RV-12, they used my idea. But they did flight testing to determine the best location for the AOA port. The AOA needs to be calibrated during flight by performing a series of stalls, with and without flaps. AOA is displayed on the EFIS screen. There is also an audio indication that starts out as tone pulses. As stall approaches, the tone pulses get closer and closer together until at stall, there is one solid tone. A stall can occur at any airspeed depending on wing loading. A heavily load aircraft in a steep turn will stall at a much higher airspeed then when the plane is lightly loaded and flying straight. That is why many planes have stalled and crashed while in a traffic pattern. The pilot keeps the airspeed where he normally does, not taking into consideration the higher wing loading in a steep turn. A wing will always stall at the same AOA, regardless of wing loading. Now that I have AOA, I use that instead of airspeed. The FAA should mandate AOA and eliminate the requirement for airspeed indicators. OK, I am ready to be flamed. LOL For aircraft without an EFIS, a Dwyer Minihelic II 2-5002 Differential Pressure Gauge, Range 0-2.0"WC might work for a display, although I have never tried it. I would also add an audio pulsing tone. To andymeyer, I think the pressure differential for AOA is about 2" of water. 0.57psi converts to 15.7 inches of water. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479319#479319 ________________________________________________________________________________
Date: Apr 13, 2018
i use the airspeed indicator as an AoA indicator - you just have to mentally adjust the scale for weight and load factor. A bit like those airspeed indicators that have a sliding scale for true airspeed. My airspeed indicator has a sliding scale (in my head) for AoA. On Apr 13, 2018, at 15:18, user9253 wrote: Here is a link to the VansAirforce thread about AOA in the RV-12. http://www.vansairforce.com/community/showthread.php?t=34040 I do not know where is the optimum point to measure air pressure. All I know is that I looked at the angle on Dynon's AOA probe and thought that 30 degrees looked about right. I drilled a hole and hooked up some tubing and it worked. Several other RV-12 builders followed my lead and they are all happy. When Van's came out with a new and improved version of the RV-12, they used my idea. But they did flight testing to determine the best location for the AOA port. The AOA needs to be calibrated during flight by performing a series of stalls, with and without flaps. AOA is displayed on the EFIS screen. There is also an audio indication that starts out as tone pulses. As stall approaches, the tone pulses get closer and closer together until at stall, there is one solid tone. A stall can occur at any airspeed depending on wing loading. A heavily load aircraft in a steep turn will stall at a much higher airspeed then when the plane is lightly loaded and flying straight. That is why many planes have stalled and crashed while in a traffic pattern. The pilot keeps the airspeed where he normally does, not taking into consideration the higher wing loading in a steep turn. A wing will always stall at the same AOA, regardless of wing loading. Now that I have AOA, I use that instead of airspeed. The FAA should mandate AOA and eliminate the requirement for airspeed indicators. OK, I am ready to be flamed. LOL For aircraft without an EFIS, a Dwyer Minihelic II 2-5002 Differential Pressure Gauge, Range 0-2.0"WC might work for a display, although I have never tried it. I would also add an audio pulsing tone. To andymeyer, I think the pressure differential for AOA is about 2" of water. 0.57psi converts to 15.7 inches of water. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479319#479319 ________________________________________________________________________________
Date: Apr 13, 2018
Here's an article one of the members of EAA Chapter 88 wrote for our newsletter a few years ago. Seems to be the same idea y'all are talking about. Rick Girard On Fri, Apr 13, 2018 at 4:18 PM, Alec Myers wrote: > > i use the airspeed indicator as an AoA indicator - you just have to > mentally adjust the scale for weight and load factor. A bit like those > airspeed indicators that have a sliding scale for true airspeed. My > airspeed indicator has a sliding scale (in my head) for AoA. > > On Apr 13, 2018, at 15:18, user9253 wrote: > > > Here is a link to the VansAirforce thread about AOA in the RV-12. > http://www.vansairforce.com/community/showthread.php?t=34040 > I do not know where is the optimum point to measure air pressure. All I > know is that I looked at the angle on Dynon's AOA probe and thought that 30 > degrees looked about right. I drilled a hole and hooked up some tubing a nd > it worked. Several other RV-12 builders followed my lead and they are al l > happy. When Van's came out with a new and improved version of the RV-12, > they used my idea. But they did flight testing to determine the best > location for the AOA port. > The AOA needs to be calibrated during flight by performing a series of > stalls, with and without flaps. AOA is displayed on the EFIS screen. > There is also an audio indication that starts out as tone pulses. As sta ll > approaches, the tone pulses get closer and closer together until at stall , > there is one solid tone. > A stall can occur at any airspeed depending on wing loading. A heavily > load aircraft in a steep turn will stall at a much higher airspeed then > when the plane is lightly loaded and flying straight. That is why many > planes have stalled and crashed while in a traffic pattern. The pilot > keeps the airspeed where he normally does, not taking into consideration > the higher wing loading in a steep turn. A wing will always stall at the > same AOA, regardless of wing loading. Now that I have AOA, I use that > instead of airspeed. The FAA should mandate AOA and eliminate the > requirement for airspeed indicators. > OK, I am ready to be flamed. LOL > For aircraft without an EFIS, a Dwyer Minihelic II 2-5002 Differential > Pressure Gauge, Range 0-2.0"WC might work for a display, although I have > never tried it. I would also add an audio pulsing tone. > To andymeyer, I think the pressure differential for AOA is about 2" of > water. 0.57psi converts to 15.7 inches of water. > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=479319#479319 > > =========== =========== =========== =========== =========== > > -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> ________________________________________________________________________________
Subject: z13 battery bus protection
Date: Apr 15, 2018
Hi. On the Z13 design the wire from the contactor to the battery bus is recommended to be 6" or less. I don't want to put the battery bus on the fwf but on a panel with the other fuseblocks which will require a significantly longer wire. Is it acceptable or necessary to protect this wire with a fuse link and if so what size wire should I use? Max potential load will be about 15 amps. Does the main bus wire require similar protection? I'm using a 4.5ft length of 6awg for it. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479345#479345 ________________________________________________________________________________
Date: Apr 15, 2018
Subject: Re: A bit of aviation history worth reviewing
Bob, Thanks for that video link. It was very interesting. Stan Sutterfield From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Subject: AeroElectric-List: A bit of aviation history worth reviewing https://youtu.be/F4KD5u-xkik Bob . . . ________________________________________________________________________________
Date: Apr 15, 2018
Subject: Re: z13 battery bus protection
At 03:59 PM 4/15/2018, you wrote: > >Hi. >On the Z13 design the wire from the contactor to the battery bus is >recommended to be 6" or less. I don't want to put the battery bus on >the fwf but on a panel with the other fuseblocks which will require >a significantly longer wire. Is it acceptable or necessary to >protect this wire with a fuse link and if so what size wire should I >use? Max potential load will be about 15 amps. A battery bus is located proximal to the battery, else it's not a battery bus. Fuseblocks on the panel? Why? When would you EVER find value in fiddling with fuses or breakers in flight? Have you read . . . https://goo.gl/ytEfZJ https://goo.gl/utXVam https://goo.gl/L6VpN4 >Does the main bus wire require similar protection? I'm using a 4.5ft >length of 6awg for it. Study the z-figures . . . no such protection is required or recommended for crew controlled FAT wires . . . i.e. they go cold when the master is OFF. Bob . . . ________________________________________________________________________________
Date: Apr 15, 2018
On 4/15/2018 5:40 PM, Robert L. Nuckolls, III wrote: > At 03:59 PM 4/15/2018, you wrote: >> >> >> Hi. >> On the Z13 design the wire from the contactor to the battery bus is >> recommended to be 6" or less. I don't want to put the battery bus on >> the fwf but on a panel with the other fuseblocks which will require a >> significantly longer wire. Is it acceptable or necessary to protect >> this wire with a fuse link and if so what size wire should I use? Max >> potential load will be about 15 amps. > > A battery bus is located proximal to the battery, else > it's not a battery bus. Fuseblocks on the panel? Why? > When would you EVER find value in fiddling with fuses > or breakers in flight? Have you read . . . > > https://goo.gl/ytEfZJ > > https://goo.gl/utXVam > > https://goo.gl/L6VpN4 > >> Does the main bus wire require similar protection? I'm using a 4.5ft >> length of 6awg for it. > > Study the z-figures . . . no such protection is required > or recommended for crew controlled FAT wires . . . i.e. they > go cold when the master is OFF. > > > Bob . . . > Hi Bob, Not to speak for the OP, but.... Note that he says *a* panel; not *the* panel. I can see the wiring logic in a single firewall penetration wire and multiple feeds on the cold side of the firewall from that battery bus. Perhaps there's a disconnect (pardon the pun) in how each of you is defining a 'battery bus'. I can think of at least one bus I'd want to bypass my master contactor: the engine bus for an electrically dependent engine that's using automotive style fuel injection. I fed mine using a fusible link to feed an engine bus switch, which feeds the engine bus. (With a switched alternate feed from the main bus.) 15 amps is a safe number for fuel pump, controller, injectors, coils, etc. Charlie --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Apr 15, 2018
At 08:52 AM 4/12/2018, you wrote: > >Hi all, > >One of my building buddies just challenged me concerning the >following Pitot angle of attack (AOA) device > >https://www.thingiverse.com/thing:1121786 > >Of course 3D printing the device is the easiest part. But does >anyone here happen to have implemented, programmed, etc. an AOA >indicator, and with what success ? > >BTW, some years ago I had the opportunity to make a study for such a >device based on differential pressure between upper and lower wing >surface. At the time the study involved a University wind tunnel, >hotwire profiles, several students, but nowadays my approach needs >to be much much "lower tech" as I no longer have access to such facilities. > >Thanks for your inputs, We had some discussions here on the List about various AOA sensor/display options about 15 years ago. During and since that time I'd collected some articles on the topic which I posted here https://goo.gl/5XdU1y One of the articles cloned a sensor mast that was popular with Piper as I recall. Don't recall the manufacturer off hand. Emacs! This probe was mounted under a wing on an inspection plate. Pretty easy to build. I recall that I offered to carve one out for a builder . . . but he never took me up on it. Something I've found quite useful before launching on any new development effort is to explore history of the practice. Patents are a useful place to lay foundations for refining the next generation . . . Bob . . . ________________________________________________________________________________
Date: Apr 16, 2018
Hi. I have no intention of messing with cbs or fuses in flight. The fuse blocks are mounted on a drop down panel between the main and sub panels. I dont want to mount the battery bus on the firewall but as this will require a longer wire does it now need protecting? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479352#479352 ________________________________________________________________________________
Date: Apr 16, 2018
Usually the main bus feeder does not have protection other than the ability for the pilot to shut it off via the battery contactor. As for the #14 AWG wire connecting the battery to the battery bus, an 18 AWG fuselink could be used. The 6 inch rule is a rule of thumb, not mandatory. The longer the wire, the greater the chance of it making sparks which will ignite gasoline after a forced landing. Protect it well. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479353#479353 ________________________________________________________________________________
Date: Apr 16, 2018
At 02:47 AM 4/16/2018, you wrote: > >Usually the main bus feeder does not have protection other than the >ability for the pilot to shut it off via the battery contactor. >As for the #14 AWG wire connecting the battery to the battery bus, >an 18 AWG fuselink could be used. The 6 inch rule is a rule of >thumb, not mandatory. The longer the wire, the greater the chance >of it making sparks which will ignite gasoline after a forced >landing. Protect it well. An extended bus feeder calls for fault protection . . . protection that needs to be very robust in comparison with the loads on the bus (and associated protections). Since you're using fuses on the extended bus (MUCH faster than breakers) and given that this bus is always hot, I suggest that the feeder be increased to 10AWG and that it be protected with a 30A Maxifuse; much faster than a fusible link in a fault condition and much more robust than any single feeder off that bus . . . you don't want a fault on a single distribution to open the feeder fuse and take down the whole bus. Bob . . . ________________________________________________________________________________
From: William Daniell <wdaniell.longport(at)gmail.com>
Date: Apr 16, 2018
In this scenario, is there any reason why an ATC fuse bus (20 slot bandc type) could not be fed from batt and alt straight into the buss through two of the faston tabs? (As opposed to the main bolt terminal) Each slot could have a 30a maxifuse? Will On Mon, Apr 16, 2018, 12:05 Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 02:47 AM 4/16/2018, you wrote: > > > Usually the main bus feeder does not have protection other than the > ability for the pilot to shut it off via the battery contactor. > As for the #14 AWG wire connecting the battery to the battery bus, an 18 > AWG fuselink could be used. The 6 inch rule is a rule of thumb, not > mandatory. The longer the wire, the greater the chance of it making sparks > which will ignite gasoline after a forced landing. Protect it well. > > > An extended bus feeder calls for > fault protection . . . protection > that needs to be very robust in > comparison with the loads on the > bus (and associated protections). > > Since you're using fuses on the extended > bus (MUCH faster than breakers) and > given that this bus is always hot, I > suggest that the feeder be increased > to 10AWG and that it be protected > with a 30A Maxifuse; much faster than > a fusible link in a fault condition > and much more robust than any single > feeder off that bus . . . you don't > want a fault on a single distribution > to open the feeder fuse and take down > the whole bus. > > > Bob . . . > ________________________________________________________________________________
Date: Apr 16, 2018
What's the goal? If you're trying to protect the bus, it's an unneeded failure point when inserted as a 'master protection device' (detailed in Bob's earlier linked articles). If protecting the wire, the fuse is on the wrong end of the wire. On 4/16/2018 2:40 PM, William Daniell wrote: > In this scenario, is there any reason why an ATC fuse bus (20 slot > bandc type) could not be fed from batt and alt straight into the buss > through two of the faston tabs? (As opposed to the main bolt > terminal) Each slot could have a 30a maxifuse? > > Will > > > On Mon, Apr 16, 2018, 12:05 Robert L. Nuckolls, III > > > wrote: > > At 02:47 AM 4/16/2018, you wrote: >> > >> >> Usually the main bus feeder does not have protection other than >> the ability for the pilot to shut it off via the battery contactor. >> As for the #14 AWG wire connecting the battery to the battery >> bus, an 18 AWG fuselink could be used. The 6 inch rule is a rule >> of thumb, not mandatory. The longer the wire, the greater the >> chance of it making sparks which will ignite gasoline after a >> forced landing. Protect it well. > > An extended bus feeder calls for > fault protection . . . protection > that needs to be very robust in > comparison with the loads on the > bus (and associated protections). > > Since you're using fuses on the extended > bus (MUCH faster than breakers) and > given that this bus is always hot, I > suggest that the feeder be increased > to 10AWG and that it be protected > with a 30A Maxifuse; much faster than > a fusible link in a fault condition > and much more robust than any single > feeder off that bus . . . you don't > want a fault on a single distribution > to open the feeder fuse and take down > the whole bus. > > > Bob . . . > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Subject: Re: Bulb replacement for my Sandel 3308 EHSI
Date: Apr 16, 2018
Am I tilting at windmills with the idea of going to LEDs? [Wink] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479386#479386 ________________________________________________________________________________
Date: Apr 16, 2018
At 02:40 PM 4/16/2018, you wrote: >In this scenario, is there any reason why an ATC >fuse bus (20 slot bandc type) could not be fed >from batt and alt straight into the buss through >two of the faston tabs?=C2 (As opposed to the >main bolt terminal) Each slot could have a 30a maxifuse? Recall that circuit protection is for WIRES . . . and that the protective device is installed as close as practical to the SOURCE of energy that puts the wire at risk. In this case, a MAXIfuse in an in-line holder taps power off the hot side of the battery or starter contactors. Energy is then conducted via the 10AWG feeder to the input stud on the fuseblock. What loads are being assigned to this bus? Bob . . . ________________________________________________________________________________
Date: Apr 16, 2018
In that case could a fuse link be used on the source end of the wire to protect the wire and then feeding the bus via one of the fast on rather than the main bolt terminal to provide fast blow protection to prevent the bus being taken out? Would 12awg feed wire with 16awg fuselink suffice, or 10awg with 14awg fusel-ink The bus is supplying the essential bus as backup max load approx 15 amps. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479390#479390 ________________________________________________________________________________
Date: Apr 17, 2018
A fast blow fuse will INSURE that the essential bus IS taken out. Do not use a fast blow fuse in series with the E-Bus no matter which end of the wire it is located. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479393#479393 ________________________________________________________________________________
Date: Apr 17, 2018
Will a maxifuse not blow as fast as a normal blade fuse? Is a slow blow blade fuse available? The endurance bus feed wire from the hot battery bus is protected by a fuse at one end and a fuselink at the other. Is it not acceptable to do the same with the feed wire to the hot battery bus from the battery? I would prefer to keep the simplest, most durable protection devices within the engine compartment, ie a fuselink. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479396#479396 ________________________________________________________________________________
Date: Apr 17, 2018
On the Littlefuse website, http://www.littelfuse.com/products/fuses/automotive-passenger-car/blade-fuses/299.aspx it says, "MAXI 32V Series - MAXI Slo-Blo 32V Automotive Blade Fuse" I assume that "Slo-Blo" means slow blow. The datasheet http://www.littelfuse.com/~/media/automotive/datasheets/fuses/passenger-car-and-commercial-vehicle/blade-fuses/littelfuse_maxi_32v_datasheet.pdf graph looks like the 30 amp fuse will hold 40 amps for several minutes without blowing. The reason that the endurance bus wire is protected at both ends is because there are two current paths. The wire needs to be protected from current coming from either end. A maxifuse is a blade type fuse, but it is twice as big as ATX and ATO fuses. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479397#479397 ________________________________________________________________________________
Date: Apr 17, 2018
Le 16/04/2018 01:01, Robert L. Nuckolls, III a crit: > > We had some discussions here on the List about > various AOA sensor/display options about 15 years > ago. During and since that time I'd collected some > articles on the topic which I posted here > > https://goo.gl/5XdU1y > > One of the articles cloned a sensor mast that > was popular with Piper as I recall. Don't recall > the manufacturer off hand. Hi Bob and all, A big thank you for your inputs, docs etc. ! We now have to do our homework. Nevertheless the project is still at the initial build stage, and we are still in the process of (slowly) reducing drag on our present 4-seater, so it may be some time til we are ready for the AOA flight tests. Thank you everyone ! -- Best regards, Gilles http://contrails.free.fr http://lapierre.skunkworks.free.fr ________________________________________________________________________________
Date: Apr 17, 2018
At 09:55 AM 4/17/2018, you wrote: > >Will a maxifuse not blow as fast as a normal blade fuse? Is a slow >blow blade fuse available? No . . . haven't got time right now to answer this question carefully . . . but I will soon. In the mean time, research the fault reaction time curves for the devices being cited . . . "Fast" and "slow" are un-quantified, squishy terms. Bob . . . ________________________________________________________________________________
Date: Apr 17, 2018
According to this chart: http://www.litz-wire.com/New%20PDFs/Fusing_Currents_Melting_Temperature_Copper_Aluminum_Magnet_Wire_R2.011609.pdf A #18 AWG fuselink will conduct up to 82 amps before it melts. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479400#479400 ________________________________________________________________________________
Date: Apr 17, 2018
At 09:55 AM 4/17/2018, you wrote: > >Will a maxifuse not blow as fast as a normal blade fuse? Is a slow >blow blade fuse available? No . . . and here's why . . . Let's go to the engineering data for a sample of fuses common to our designs. First the ATC10 plastic fuse that fits the popular fuseholders . . . and probably the largest fuse to be included on the battery bus under consideration: I have calculated a 'fusing constant' for this fuse based on numbers taken from the ATC fuse performance chart below. At approx 2x the 'carry forever' current of the ATC10 fuse, it opens in approx 0.4 seconds which produces an I(squared)T value of 270. If we cause the fuse to carry twice that value of 52A, we know that it will open in approx ONE FOURTH that time or 0.1 seconds. Double the current again to ~100A and we'll anticipate fuse operation in ~0.05 seconds. The chart below says it will be shorter still, so perhaps my fusing constant number needs trimming. Suffice it to say that the fusing constant calculation carries an AMPS(SQUARED) term in it suggesting that increasing current shortens the operating time by 1/4th each doubling. [] [] Now let us look at the 30A MaxiFuse. Note that it has a much larger fusing constant (again perhaps needing a tweak) but consider the operating time at 100A. From the chart we read something on the order of 3 SECONDS. Suppose a MAX30 were protecting the battery bus with a ATC10 fuse in it and you fault that fuse with a 100A load. The ATC10 will open many times faster than the MAX30 thus the integrity of the bus feed is not at risk. [] Now, if we were protecting a SWITCHED bus in a TC aircraft with similar distribution characteristics, we might choose to use the ANL35 current limiter. Note that its fusing constant is actually LESS than the MAXI30. At 2x the ANL's carry forever current, the fusing time is only 0.4 seconds. But when loaded with our hypothetical fault of 100A on an ATC10 fuse, the ANL35 is pretty close to a never-operates condition. [] A take-away from this narrative has several points. (1) 'Fast' and 'slow' are non-quantified, un-scientific terms for evaluating performance of any circuit protective device. You can say device A is faster than device B under some cited conditions . . . but that's about it. (2) The fusing constant is useful for making some broad predictions about performance between two styles of product. For example, in the charts about we see that Kf of 13K for the ANL (a mechanically robust fuse compared to the MAXI) is about 20x faster at the 2x overload point than the MAXI with a Kf of 44K. (3) I've not illustrated fusing characteristics for the 18AWG fusible link . . . we know it's going to be a BIG number. Now, considering that the design goal for upstream protection of the non-legacy battery bus is to MINIMIZE the potential for expenditure of energy in a hard fault condition, very robust devices like fusible links are not consistent with the design goal. (4) The design goal calls for selection of an upstream fuse with thermal characteristics consistent with maintaining bus integrity under a downstream BRANCH fault while minimizing energy expenditure during a FEEDER fault. (5) There is a significant simplification of the physics in this narrative that does NOT consider PRE- HEATING of the feeder protection due to normal operating loads. Pre-heating figured heavily in the demise of N811HB . . . https://goo.gl/hWQdE6 I think I read the number 15A as the max running load for this design. Assuming no branch fuse is greater than 10A . . . with most probably being smaller . . . I'll s stand by my recommendation for a MAXI30 or even a MAXI40 protecting a 10AWG feeder. Having said that, I'd much rather the battery bus was located near the battery. The 30 Series aircraft at Beech have had fuses on the firewall for decades [] Further, they were/are glass cartridge fuses (ugh!) with threaded fasteners (fooey) . . . but I'm aware of no problems with this design philosophy. Bob . . . Bob . . . ________________________________________________________________________________
Date: Apr 17, 2018
Bob, thankyou for your reply, much appreciated. Miller Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479419#479419 ________________________________________________________________________________
Date: Apr 19, 2018
Subject: Re: Double pole switch failure mode?
From: Mark and Kathleen Navratil <czechsix(at)msn.com> Subject: Re: Double pole switch failure mode? Bob, is <http://www.aeroelectric.com/PPS/ACAD_Architecture_Dwgs/>http://www.aeroelec tric.com/PPS/ACAD_Architecture_Dwgs/ where you keep the latest diagrams? I=92m planning to use Z-14 for my RV-14 and want to make sure I=92ve got the latest. I think it does almost everything I want as is, except I may replace the two battery buses with an essential bus fed by diodes from each battery and run the ignition & fuel injection off of that, so that the engine will run as long as at least one battery has juice left in it. I know that can also be accomplished with the cross-tie contactor, but don=92t want to have to add that switch to my engine failure checklist=85 Thanks for making the diagrams available in CAD format, sure beats using whiteout and multiple photocopies of my original RV-8A diagram from 15 years ago! -Mark Your welcome . . . Z-14 in an RV8? Sometimes I'm sorry that I ever published that architecture. I may delete it from Rev 13. It was offered for the very rare instances of larger airplanes like a Lancair IVP with dual efis, a/c, etc . . . Have you considered Z13/8? What's the failure mode effects analysis that drives the decision toward Z-14? What engine ignition combination are you using? What are your anticipated endurance loads for sustained flight with a failed main alternator? Under what conditions can you deduce a need to depend solely on a battery for continued flight? Keep in mind that the vast MAJORITY of bad days in the cockpit have roots in the pilot's poor decisions. Only a tiny portion of aviation mishaps are rooted in mechanical/electrical failures and MOST of those would have been easily mitigated with relatively minor changes in architecture and better attention to preventative maintenance. Like treating your battery with as much care and attention as you do tires, fuel tanks and reports for icing along your route of travel. The RV8 is probably the highest cost/performance ratio design in Van's two-seated product line. To burden this airplane with the weight, expense and complexity of a system like Z14 may be intellectually comforting on some level but I suggest it offers no demonstrable reduction in operational risks for your project. One of my first Z13/8 builders invested the saved weight and expense in his RV8 project by making improvements to cabin heating comfort and adding an oxygen system. The kinds of numbers he and his son enjoyed in the use of this airplane were nothing short of astounding. Before we launch into a discussion about how to modify Z-14, how about exploring the failure situations under which Z13/8 would not meet practical design goals for electrical difficulties en route? Yes, the latest .dwg files are at https://goo.gl/dPKjRi Bob . . . ________________________________________________________________________________
Date: Apr 19, 2018
>From a bit of reading it seems that my concerns would be physical form and equivalent wattage. Appears to be plenty of T3 G4 type LEDs with acceptable equivalent wattage. What am I not considering? Any comments or pointers appreciated!! :D Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479441#479441 ________________________________________________________________________________
Date: Apr 19, 2018
At 12:20 PM 4/19/2018, you wrote: > > >From a bit of reading it seems that my concerns would be physical > form and equivalent wattage. Appears to be plenty of T3 G4 type > LEDs with acceptable equivalent wattage. What am I not > considering? Any comments or pointers appreciated!! :D > Looks like the OEM lamp is an incandescent 20w lamp in a g4 envelope. No LED lamp in that same envelope is going to be a 20 watt device . . . it may approach the same total light output as the original with less than 20watts of energy consumption but I'm skeptical. Further, no LED replacement will have the same radiation pattern. Pattern can have a profound effect on the quality of the projected image. The LED products are less expensive and risks for trying one are low. Give it a try and see what the display looks like . . . please share your discoveries. Bob . . . ________________________________________________________________________________
Date: Apr 19, 2018
Bob thanks sorry for late reply. So in this case we are talking about your Z16 circuit diagram without an endurance buss. (I have eliminated the endurance buss. Following your dictum of no electrical systems which determine the safe termination of the flight I have Levil with battery back up for AI/flight instruments and a handheld radio). Since the battery and therefore the battery contactor is under the baggage bay of my Europa, the power to the buss comes from one of the through-firewall bolts which connects the 4AWG from the battery to the starter contactor. Following the Z16 therefore, in this case, there is no requirement for wire protection between the through firewall bolt and the buss. The cable run which is 10AWG is not more than 12". The buss powers a dynon system with dual axis AP, radio/intercom, Airmaster prop, flap motor, backup instruments, fuel pump, landing and anti collision lights (these latter are low consumption LED). The dynon ammeter shows 12A recharging and 8.5A normally with everything on. Will William Daniell LONGPORT +57 310 295 0744 On Mon, Apr 16, 2018 at 8:28 PM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 02:40 PM 4/16/2018, you wrote: > > In this scenario, is there any reason why an ATC fuse bus (20 slot bandc > type) could not be fed from batt and alt straight into the buss through t wo > of the faston tabs?=C3=82 (As opposed to the main bolt terminal) Each sl ot > could have a 30a maxifuse? > > > Recall that circuit protection is for WIRES . . . and > that the protective device is installed as close as > practical to the SOURCE of energy that puts the wire > at risk. > > In this case, a MAXIfuse in an in-line holder > taps power off the hot side of the battery or > starter contactors. Energy is then conducted via the > 10AWG feeder to the input stud on the fuseblock. > > What loads are being assigned to this bus? > > > Bob . . . > ________________________________________________________________________________
Subject: Z-12 contactor failure
Date: Apr 20, 2018
I know it is not a likely case, but I have experienced a contactor failure on a production plane in flight. It ended up that the root cause was a defective master switch - but the result was the same. Because there was no endurance bus alternate feed, it was a full electrical shutdown, in IMC no less! I would like to know if there is a practical way to protect for contactor failure ( other than battery only operation ) with the Z-12 design. It would be nice to have a second path to the battery from aux alternator to ensure stable power if the master does fail. The appeal to me of having an aux alternator is to be able to continue flight on one alternator. This is only possible if either a battery connection is maintained always or it is a guarantee the alternator will provide stable power without a battery connection. The Z-13/8 uses a relay with the SD-8 alternator to connect directly to battery. Is this design practical or even advisable with the SD-20 alternator? With Z-13/8 the aux alternator will provide power to battery bus and E-BUS if contactor fails. Thoughts? Thanks, -Brendon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479453#479453 ________________________________________________________________________________
Date: Apr 20, 2018
Subject: Re: Z-12 contactor failure
Brendon: If the Master Switch failed why reinvent the wheel? Since this was a certified plane you are forced to work with the design of the time. What I have found is 99.982% of certified plane owners and A&P's, NEVER address the Master Switch during Annual. It should be addressed every Annual and it is very easy to do: 1 - Spray the heck out of it with Contact Cleaner. 2 - Cycle the switch a couple of dozen times. 3 - Spray it with WD-40. Side Note: This also goes for the micro-switch in the Stall Warning System. On Experimental Aircraft you have a HUGE ADVANTAGE... Use a Heavy Duty Master Switch and a Separate Heavy Duty Alternator Switch. I use DPST switches and tie BOTH sides together. This DOUBLES the physical as well as the electrical rating of the switch. Want to go extra fancy? Look for switches that are Sliver Plated. You can also use switches that have a built in Dust/Moisture shield. OR... Install the dust/Moisture shield over the Toggle Lever. Side Note: On certified planes with the standard split Master/Alt Switch, there are four (4) failure points: 1 - The Physical snap action of the switch. 2 - The Electrical contacts of the switch. 3 - Fast-On tabs on the back of the switch. 4 - The Physical MOUNTING of the switch. There is a snap in bezel that holds the switch into the panel. This bezel fails as the ears either break off or loose their spring action. Then the switch vibrates forward and shorts out to the aluminum panel. The cure is to use two (2) sheet metal round head screws on either side to hold the bezel in place. If the switch vibrates out it will short out and take your Master/Alt switch and Starter Relay out of the circuit. If you are airborne - You loose even the ability to go to Battery Back-up. Or do an in-flight re-start. Scary! Barry On Fri, Apr 20, 2018 at 9:52 AM, bsvantho wrote: > > I know it is not a likely case, but I have experienced a contactor failure > on a production plane in flight. It ended up that the root cause was a > defective master switch - but the result was the same. Because there was > no endurance bus alternate feed, it was a full electrical shutdown, in IMC > no less! > > I would like to know if there is a practical way to protect for contactor > failure ( other than battery only operation ) with the Z-12 design. It > would be nice to have a second path to the battery from aux alternator to > ensure stable power if the master does fail. The appeal to me of having an > aux alternator is to be able to continue flight on one alternator. This is > only possible if either a battery connection is maintained always or it is > a guarantee the alternator will provide stable power without a battery > connection. > > The Z-13/8 uses a relay with the SD-8 alternator to connect directly to > battery. Is this design practical or even advisable with the SD-20 > alternator? With Z-13/8 the aux alternator will provide power to battery > bus and E-BUS if contactor fails. > > Thoughts? > > Thanks, > -Brendon > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=479453#479453 > > ________________________________________________________________________________
Date: Apr 20, 2018
Barry I can't see how applying a lubricant like WD40 can be advantageous to the contacts on the switch...surely there will be burning volatiles or lube which would affect the service or life of the part? On the moving parts yes but I don't know of a way to differentiate with a spray can. On Fri, 20 Apr 2018, 6:13 PM FLYaDIVE wrote: > Brendon: > > If the Master Switch failed why reinvent the wheel? > Since this was a certified plane you are forced to work with the design of > the time. > What I have found is 99.982% of certified plane owners and A&P's, NEVER > address the Master Switch during Annual. > It should be addressed every Annual and it is very easy to do: > 1 - Spray the heck out of it with Contact Cleaner. > 2 - Cycle the switch a couple of dozen times. > 3 - Spray it with WD-40. > > Side Note: This also goes for the micro-switch in the Stall Warning > System. > > > On Experimental Aircraft you have a HUGE ADVANTAGE... > Use a Heavy Duty Master Switch and a Separate Heavy Duty Alternator Switch. > I use DPST switches and tie BOTH sides together. This DOUBLES the > physical as well as the electrical rating of the switch. > Want to go extra fancy? Look for switches that are Sliver Plated. > You can also use switches that have a built in Dust/Moisture shield. > OR... Install the dust/Moisture shield over the Toggle Lever. > > Side Note: On certified planes with the standard split Master/Alt Switch, > there are four (4) failure points: > 1 - The Physical snap action of the switch. > 2 - The Electrical contacts of the switch. > 3 - Fast-On tabs on the back of the switch. > 4 - The Physical MOUNTING of the switch. There is a snap in bezel that > holds the switch into the panel. > This bezel fails as the ears either break off or loose their spring action. > Then the switch vibrates forward and shorts out to the aluminum panel. > The cure is to use two (2) sheet metal round head screws on either side > to hold the bezel in place. > If the switch vibrates out it will short out and take your Master/Alt > switch and Starter Relay out of the circuit. > If you are airborne - You loose even the ability to go to Battery Back-up. > Or do an in-flight re-start. > Scary! > > > Barry > > > On Fri, Apr 20, 2018 at 9:52 AM, bsvantho wrote: > >> >> I know it is not a likely case, but I have experienced a contactor >> failure on a production plane in flight. It ended up that the root cause >> was a defective master switch - but the result was the same. Because >> there was no endurance bus alternate feed, it was a full electrical >> shutdown, in IMC no less! >> >> I would like to know if there is a practical way to protect for contactor >> failure ( other than battery only operation ) with the Z-12 design. It >> would be nice to have a second path to the battery from aux alternator to >> ensure stable power if the master does fail. The appeal to me of having an >> aux alternator is to be able to continue flight on one alternator. This is >> only possible if either a battery connection is maintained always or it is >> a guarantee the alternator will provide stable power without a battery >> connection. >> >> The Z-13/8 uses a relay with the SD-8 alternator to connect directly to >> battery. Is this design practical or even advisable with the SD-20 >> alternator? With Z-13/8 the aux alternator will provide power to battery >> bus and E-BUS if contactor fails. >> >> Thoughts? >> >> Thanks, >> -Brendon >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=479453#479453 >> >> >> >> >> >> >> =================================== >> - >> Electric-List" rel="noreferrer" target="_blank">http://www.matronics.com/ >> Navigator?AeroElectric-List >> =================================== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> =================================== >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> =================================== >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >> =================================== >> >> >> >> > ________________________________________________________________________________
Date: Apr 20, 2018
Bob: Yup! There are all sorts of 'possible' possibilities, all without proof, but it DOES WORK! Many of our aircraft are 40+ years old. The original lubricants in the switches have long disappeared. They are NOT sealed switches. What has worked for many years are now failing. Just look Brandon's post. And, when it comes to the Stall Warning micro switch - Replacement with NEW is $1200+ used, about $600 to $700. All this can be prevented with a can of WD-40! Not needed on sealed DPST Toggle Switches. AND they are NOT 40+ years old. Barry On Fri, Apr 20, 2018 at 12:25 PM, Bob Verwey wrote: > Barry I can't see how applying a lubricant like WD40 can be advantageous > to the contacts on the switch...surely there will be burning volatiles or > lube which would affect the service or life of the part? On the moving > parts yes but I don't know of a way to differentiate with a spray can. > > On Fri, 20 Apr 2018, 6:13 PM FLYaDIVE wrote: > >> Brendon: >> >> If the Master Switch failed why reinvent the wheel? >> Since this was a certified plane you are forced to work with the design >> of the time. >> What I have found is 99.982% of certified plane owners and A&P's, NEVER >> address the Master Switch during Annual. >> It should be addressed every Annual and it is very easy to do: >> 1 - Spray the heck out of it with Contact Cleaner. >> 2 - Cycle the switch a couple of dozen times. >> 3 - Spray it with WD-40. >> >> Side Note: This also goes for the micro-switch in the Stall Warning >> System. >> >> >> On Experimental Aircraft you have a HUGE ADVANTAGE... >> Use a Heavy Duty Master Switch and a Separate Heavy Duty Alternator >> Switch. >> I use DPST switches and tie BOTH sides together. This DOUBLES the >> physical as well as the electrical rating of the switch. >> Want to go extra fancy? Look for switches that are Sliver Plated. >> You can also use switches that have a built in Dust/Moisture shield. >> OR... Install the dust/Moisture shield over the Toggle Lever. >> >> Side Note: On certified planes with the standard split Master/Alt >> Switch, there are four (4) failure points: >> 1 - The Physical snap action of the switch. >> 2 - The Electrical contacts of the switch. >> 3 - Fast-On tabs on the back of the switch. >> 4 - The Physical MOUNTING of the switch. There is a snap in bezel that >> holds the switch into the panel. >> This bezel fails as the ears either break off or loose their spring >> action. >> Then the switch vibrates forward and shorts out to the aluminum panel. >> The cure is to use two (2) sheet metal round head screws on either side >> to hold the bezel in place. >> If the switch vibrates out it will short out and take your Master/Alt >> switch and Starter Relay out of the circuit. >> If you are airborne - You loose even the ability to go to Battery Back-up. >> Or do an in-flight re-start. >> Scary! >> >> >> Barry >> >> >> >> >> >> On Fri, Apr 20, 2018 at 9:52 AM, bsvantho wrote: >> >>> >>> I know it is not a likely case, but I have experienced a contactor >>> failure on a production plane in flight. It ended up that the root cause >>> was a defective master switch - but the result was the same. Because >>> there was no endurance bus alternate feed, it was a full electrical >>> shutdown, in IMC no less! >>> >>> I would like to know if there is a practical way to protect for >>> contactor failure ( other than battery only operation ) with the Z-12 >>> design. It would be nice to have a second path to the battery from aux >>> alternator to ensure stable power if the master does fail. The appeal to >>> me of having an aux alternator is to be able to continue flight on one >>> alternator. This is only possible if either a battery connection is >>> maintained always or it is a guarantee the alternator will provide stable >>> power without a battery connection. >>> >>> The Z-13/8 uses a relay with the SD-8 alternator to connect directly to >>> battery. Is this design practical or even advisable with the SD-20 >>> alternator? With Z-13/8 the aux alternator will provide power to battery >>> bus and E-BUS if contactor fails. >>> >>> Thoughts? >>> >>> Thanks, >>> -Brendon >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=479453#479453 >>> >>> >>> >>> >>> >>> >>> ========== >>> - >>> Electric-List" rel="noreferrer" target="_blank">http://www. >>> matronics.com/Navigator?AeroElectric-List >>> ========== >>> FORUMS - >>> eferrer" target="_blank">http://forums.matronics.com >>> ========== >>> WIKI - >>> errer" target="_blank">http://wiki.matronics.com >>> ========== >>> b Site - >>> -Matt Dralle, List Admin. >>> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >>> ========== >>> >>> >>> >>> >> ________________________________________________________________________________
Date: Apr 20, 2018
Calling WD40 "a lubricant" is like calling a 1969 Chateauneuf a liquid! On Apr 20, 2018, at 1:41 PM, FLYaDIVE wrote: Bob: Yup! There are all sorts of 'possible' possibilities, all without proof, but it DOES WORK! Many of our aircraft are 40+ years old. The original lubricants in the switches have long disappeared. They are NOT sealed switches. What has worked for many years are now failing. Just look Brandon's post. And, when it comes to the Stall Warning micro switch - Replacement with NEW is $1200+ used, about $600 to $700. All this can be prevented with a can of WD-40! Not needed on sealed DPST Toggle Switches. AND they are NOT 40+ years old. Barry On Fri, Apr 20, 2018 at 12:25 PM, Bob Verwey wrote: Barry I can't see how applying a lubricant like WD40 can be advantageous to the contacts on the switch...surely there will be burning volatiles or lube which would affect the service or life of the part? On the moving parts yes but I don't know of a way to differentiate with a spray can. On Fri, 20 Apr 2018, 6:13 PM FLYaDIVE wrote: Brendon: If the Master Switch failed why reinvent the wheel? Since this was a certified plane you are forced to work with the design of the time. What I have found is 99.982% of certified plane owners and A&P's, NEVER address the Master Switch during Annual. It should be addressed every Annual and it is very easy to do: 1 - Spray the heck out of it with Contact Cleaner. 2 - Cycle the switch a couple of dozen times. 3 - Spray it with WD-40. Side Note: This also goes for the micro-switch in the Stall Warning System. On Experimental Aircraft you have a HUGE ADVANTAGE... Use a Heavy Duty Master Switch and a Separate Heavy Duty Alternator Switch. I use DPST switches and tie BOTH sides together. This DOUBLES the physical as well as the electrical rating of the switch. Want to go extra fancy? Look for switches that are Sliver Plated. You can also use switches that have a built in Dust/Moisture shield. OR... Install the dust/Moisture shield over the Toggle Lever. Side Note: On certified planes with the standard split Master/Alt Switch, there are four (4) failure points: 1 - The Physical snap action of the switch. 2 - The Electrical contacts of the switch. 3 - Fast-On tabs on the back of the switch. 4 - The Physical MOUNTING of the switch. There is a snap in bezel that holds the switch into the panel. This bezel fails as the ears either break off or loose their spring action. Then the switch vibrates forward and shorts out to the aluminum panel. The cure is to use two (2) sheet metal round head screws on either side to hold the bezel in place. If the switch vibrates out it will short out and take your Master/Alt switch and Starter Relay out of the circuit. If you are airborne - You loose even the ability to go to Battery Back-up. Or do an in-flight re-start. Scary! Barry On Fri, Apr 20, 2018 at 9:52 AM, bsvantho wrote: I know it is not a likely case, but I have experienced a contactor failure on a production plane in flight. It ended up that the root cause was a defective master switch - but the result was the same. Because there was no endurance bus alternate feed, it was a full electrical shutdown, in IMC no less! I would like to know if there is a practical way to protect for contactor failure ( other than battery only operation ) with the Z-12 design. It would be nice to have a second path to the battery from aux alternator to ensure stable power if the master does fail. The appeal to me of having an aux alternator is to be able to continue flight on one alternator. This is only possible if either a battery connection is maintained always or it is a guarantee the alternator will provide stable power without a battery connection. The Z-13/8 uses a relay with the SD-8 alternator to connect directly to battery. Is this design practical or even advisable with the SD-20 alternator? With Z-13/8 the aux alternator will provide power to battery bus and E-BUS if contactor fails. Thoughts? Thanks, -Brendon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479453#479453 ========== - Electric-List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List ========== FORUMS - eferrer" target="_blank">http://forums.matronics.com ========== WIKI - errer" target="_blank">http://wiki.matronics.com ========== b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution ========== ________________________________________________________________________________
Date: Apr 20, 2018
Not calling it a lubricant is proof you consumed too much 1969 Chateauneuf. I guess you don't call soapstone a lubricant either! On Fri, Apr 20, 2018 at 1:52 PM, Alec Myers wrote: > > Calling WD40 "a lubricant" is like calling a 1969 Chateauneuf =9Ca liquid=9D! > > > On Apr 20, 2018, at 1:41 PM, FLYaDIVE wrote: > > Bob: > > Yup! There are all sorts of 'possible' possibilities, all without proof, > but it DOES WORK! > Many of our aircraft are 40+ years old. The original lubricants in the > switches have long disappeared. > They are NOT sealed switches. > What has worked for many years are now failing. Just look Brandon's post . > And, when it comes to the Stall Warning micro switch - Replacement with > NEW is $1200+ used, about $600 to $700. > All this can be prevented with a can of WD-40! > > Not needed on sealed DPST Toggle Switches. AND they are NOT 40+ years ol d. > > Barry > > On Fri, Apr 20, 2018 at 12:25 PM, Bob Verwey wrote : > Barry I can't see how applying a lubricant like WD40 can be advantageous > to the contacts on the switch...surely there will be burning volatiles or > lube which would affect the service or life of the part? On the moving > parts yes but I don't know of a way to differentiate with a spray can. > > On Fri, 20 Apr 2018, 6:13 PM FLYaDIVE wrote: > Brendon: > > If the Master Switch failed why reinvent the wheel? > Since this was a certified plane you are forced to work with the design o f > the time. > What I have found is 99.982% of certified plane owners and A&P's, NEVER > address the Master Switch during Annual. > It should be addressed every Annual and it is very easy to do: > 1 - Spray the heck out of it with Contact Cleaner. > 2 - Cycle the switch a couple of dozen times. > 3 - Spray it with WD-40. > > Side Note: This also goes for the micro-switch in the Stall Warning > System. > > > On Experimental Aircraft you have a HUGE ADVANTAGE... > Use a Heavy Duty Master Switch and a Separate Heavy Duty Alternator Switc h. > I use DPST switches and tie BOTH sides together. This DOUBLES the > physical as well as the electrical rating of the switch. > Want to go extra fancy? Look for switches that are Sliver Plated. > You can also use switches that have a built in Dust/Moisture shield. > OR... Install the dust/Moisture shield over the Toggle Lever. > > Side Note: On certified planes with the standard split Master/Alt Switch , > there are four (4) failure points: > 1 - The Physical snap action of the switch. > 2 - The Electrical contacts of the switch. > 3 - Fast-On tabs on the back of the switch. > 4 - The Physical MOUNTING of the switch. There is a snap in bezel that > holds the switch into the panel. > This bezel fails as the ears either break off or loose their spring actio n. > Then the switch vibrates forward and shorts out to the aluminum panel. > The cure is to use two (2) sheet metal round head screws on either side > to hold the bezel in place. > If the switch vibrates out it will short out and take your Master/Alt > switch and Starter Relay out of the circuit. > If you are airborne - You loose even the ability to go to Battery Back-up . > Or do an in-flight re-start. > Scary! > > > Barry > > > On Fri, Apr 20, 2018 at 9:52 AM, bsvantho wrote: > > I know it is not a likely case, but I have experienced a contactor failur e > on a production plane in flight. It ended up that the root cause was a > defective master switch - but the result was the same. Because there wa s > no endurance bus alternate feed, it was a full electrical shutdown, in IM C > no less! > > I would like to know if there is a practical way to protect for contactor > failure ( other than battery only operation ) with the Z-12 design. It > would be nice to have a second path to the battery from aux alternator to > ensure stable power if the master does fail. The appeal to me of having an > aux alternator is to be able to continue flight on one alternator. This is > only possible if either a battery connection is maintained always or it i s > a guarantee the alternator will provide stable power without a battery > connection. > > The Z-13/8 uses a relay with the SD-8 alternator to connect directly to > battery. Is this design practical or even advisable with the SD-20 > alternator? With Z-13/8 the aux alternator will provide power to batter y > bus and E-BUS if contactor fails. > > Thoughts? > > Thanks, > -Brendon > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=479453#479453 > > > ========== > - > Electric-List" rel="noreferrer" target="_blank">http://www. > matronics.com/Navigator?AeroElectric-List > ========== > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > ========== > WIKI - > errer" target="_blank">http://wiki.matronics.com > ========== > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" target="_blank">http://www.matronics.com/contributio n > ========== > > =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Apr 20, 2018
Agree the certified electrical system is much weaker and I found first hand that master switches are not well maintained, but I will attempt to bring this back around to the intent of my original post... Not trying to reinvent anything. This will most likely remain a philosophical discussion for me as Z-12 is already quite robust as compared to the certified planes I fly in that E-bus devices will still be available on battery + internal battery backups, etc. I have found very little information specific to protecting for master contactor failure. So is the philosophy for Z-12 that it is not worth worrying about since E-bus will still operate? I can accept this, I just am confused when I see Z-13/8 that connects the alternator on the battery side. Can anyone explain the reason for the difference? Thanks, -Brendon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479462#479462 ________________________________________________________________________________
Date: Apr 20, 2018
Brendon: Here is the schematic of the Z-13/8 http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z13-8T.pdf The NOTES are not on this schematic. But, you can see the Alternator is on the LOAD side of Relay / Battery Contactor. So, the relay has to be closed for Alternator to function. I could not find a link for the Z-12 ;-( But, consider this: Many people like a Avionics Master Switch. The switch itself has a BACK-UP. It is usually a SECOND heavy duty switch either in Parallel with the main Avionics Master Switch <-- Used when the Main switch is the ONLY means closing the circuit. The other location is across a Avionics Master Relay. The Main Avionics Master Switch closes a Relay <-- Not the best way of doing things but it works. So, when the BACK-UP Avionics Master Switch is closed it bypasses the relay and applies power to the Avionics circuit. Using this same type of configuration you can use for the MASTER SWITCH. Put a BACK-UP Master Switch in Parallel with the Main Master Switch. The only problem there is you have to REMEMBER to Shut Off the MAIN MASTER SWITCH and Double Check that the BACK-UP switch is OFF. Totally doable on Experimental. Not doable on certified, not without a 337! Barry On Fri, Apr 20, 2018 at 3:18 PM, bsvantho wrote: > > Agree the certified electrical system is much weaker and I found first > hand that master switches are not well maintained, but I will attempt to > bring this back around to the intent of my original post... > > Not trying to reinvent anything. This will most likely remain a > philosophical discussion for me as Z-12 is already quite robust as compared > to the certified planes I fly in that E-bus devices will still be available > on battery + internal battery backups, etc. > > I have found very little information specific to protecting for master > contactor failure. So is the philosophy for Z-12 that it is not worth > worrying about since E-bus will still operate? I can accept this, I just > am confused when I see Z-13/8 that connects the alternator on the battery > side. Can anyone explain the reason for the difference? > > Thanks, > > -Brendon > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=479462#479462 > > ________________________________________________________________________________
Date: Apr 20, 2018
On 4/20/2018 2:18 PM, bsvantho wrote: > > Agree the certified electrical system is much weaker and I found first hand that master switches are not well maintained, but I will attempt to bring this back around to the intent of my original post... > > Not trying to reinvent anything. This will most likely remain a philosophical discussion for me as Z-12 is already quite robust as compared to the certified planes I fly in that E-bus devices will still be available on battery + internal battery backups, etc. > > I have found very little information specific to protecting for master contactor failure. So is the philosophy for Z-12 that it is not worth worrying about since E-bus will still operate? I can accept this, I just am confused when I see Z-13/8 that connects the alternator on the battery side. Can anyone explain the reason for the difference? > > Thanks, > > -Brendon > I *think* that what you're seeing in z13-8 is that the primary alt is connected conventionally, to the bus side of the master contactor. The *backup* (much lower current capability) alt is connected to the battery side of the contactor, so that in the event of a primary alt failure, you can shed the load of the main bus *and* the load of the master contactor (coil consumes 1/2-1 1/2 amps just to keep it engaged), and still have the backup alt available to sustain the battery bus and endurance bus. If it was on the other side of the master contactor, you couldn't shed the main bus and contactor loads in the event of a main alt failure. Charlie --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Apr 20, 2018
ceengland7(at)gmail.com wrote: > On 4/20/2018 2:18 PM, bsvantho wrote: > > > > > > > Agree the certified electrical system is much weaker and I found first hand that master switches are not well maintained, but I will attempt to bring this back around to the intent of my original post... > > > > Not trying to reinvent anything. This will most likely remain a philosophical discussion for me as Z-12 is already quite robust as compared to the certified planes I fly in that E-bus devices will still be available on battery + internal battery backups, etc. > > > > I have found very little information specific to protecting for master contactor failure. So is the philosophy for Z-12 that it is not worth worrying about since E-bus will still operate? I can accept this, I just am confused when I see Z-13/8 that connects the alternator on the battery side. Can anyone explain the reason for the difference? > > > > Thanks, > > > > -Brendon > > > > I *think* that what you're seeing in z13-8 is that the primary alt is > > > > connected conventionally, to the bus side of the master contactor. The > *backup* (much lower current capability) alt is connected to the battery > side of the contactor, so that in the event of a primary alt failure, > you can shed the load of the main bus *and* the load of the master > contactor (coil consumes 1/2-1 1/2 amps just to keep it engaged), and > still have the backup alt available to sustain the battery bus and > endurance bus. If it was on the other side of the master contactor, you > couldn't shed the main bus and contactor loads in the event of a main > alt failure. > > Charlie > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus This makes perfect sense to me. Now look at Z-12 - the primary and backup alternators are both connected the same way - to the main bus. If you turn off the master both alternators are isolated from the battery. This means battery only operation unless the alternators remain stable without battery. Why do it this way? The only difference I see is the backup alternator is the larger 20A vs 8A. To ask another way. Why not connect the larger 20A backup alternator in the same way as Z-13/8 ( with relay and switch )? Is this not advisable due to the higher current being switched or some other reason? -Brendon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479466#479466 ________________________________________________________________________________
Date: Apr 20, 2018
On 4/20/2018 4:13 PM, bsvantho wrote: > > > ceengland7(at)gmail.com wrote: >> On 4/20/2018 2:18 PM, bsvantho wrote: >> >>> >>> >>> Agree the certified electrical system is much weaker and I found first hand that master switches are not well maintained, but I will attempt to bring this back around to the intent of my original post... >>> >>> Not trying to reinvent anything. This will most likely remain a philosophical discussion for me as Z-12 is already quite robust as compared to the certified planes I fly in that E-bus devices will still be available on battery + internal battery backups, etc. >>> >>> I have found very little information specific to protecting for master contactor failure. So is the philosophy for Z-12 that it is not worth worrying about since E-bus will still operate? I can accept this, I just am confused when I see Z-13/8 that connects the alternator on the battery side. Can anyone explain the reason for the difference? >>> >>> Thanks, >>> >>> -Brendon >>> >>> I *think* that what you're seeing in z13-8 is that the primary alt is >>> >> connected conventionally, to the bus side of the master contactor. The >> *backup* (much lower current capability) alt is connected to the battery >> side of the contactor, so that in the event of a primary alt failure, >> you can shed the load of the main bus *and* the load of the master >> contactor (coil consumes 1/2-1 1/2 amps just to keep it engaged), and >> still have the backup alt available to sustain the battery bus and >> endurance bus. If it was on the other side of the master contactor, you >> couldn't shed the main bus and contactor loads in the event of a main >> alt failure. >> >> Charlie >> >> --- >> This email has been checked for viruses by Avast antivirus software. >> https://www.avast.com/antivirus > > This makes perfect sense to me. Now look at Z-12 - the primary and backup alternators are both connected the same way - to the main bus. If you turn off the master both alternators are isolated from the battery. This means battery only operation unless the alternators remain stable without battery. Why do it this way? The only difference I see is the backup alternator is the larger 20A vs 8A. > > To ask another way. Why not connect the larger 20A backup alternator in the same way as Z-13/8 ( with relay and switch )? Is this not advisable due to the higher current being switched or some other reason? > > -Brendon I'd bet that the reason is implied in the text descriptions preceding the drawings. With the bigger backup alt, there's no reason to turn off the master (except fire, in which case you want the alternators off line just like the rest of the electrical system). Note also that the larger backup alt uses an external regulator to supply field voltage, so the regulator would have to be moved to the endurance bus, as well, if you intend to shut off the master & keep the backup on line. I confess it's been a while since I studied the diagrams, but they've endured for quite a while with people prodding at them, so I suspect that the real issue is discovering the logic, rather than questioning whether there is logic. :-) ________________________________________________________________________________
Date: Apr 20, 2018
At 03:28 PM 4/20/2018, you wrote: >Brendon: > >Here is the schematic of the Z-13/8 > ><http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z13-8T.pdf>http:// www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z13-8T.pdf > >The NOTES are not on this schematic. > >But, you can see the Alternator is on the LOAD >side of Relay / Battery Contactor.=C2 So, the relay has to be closed=C2 >for Alternator to function. not necessarily so . . . some alternators need some help from the battery to get started but once excited and on-line, they will continue to function even if the battery contactor is opened Bonanzas and Barons are fitted with alternators that self excite . . . the alternator(s) and battery are on separate switches. The POH speaks to alternator-only operations which are permissable. The e-bus is a work-around for contactor failure. The s/b alternator in z13/8 will come on line whether or not the battery contactor is closed. Contactor failure in flight is exceedingly rare. A contactor that's going bad will offer some issues for getting the engine started . . . your FIRST and very valuable clue that it's time to change the puppy out. So what's the source of the heartburn over contactor failures? Bob . . . ________________________________________________________________________________
Date: Apr 21, 2018
Agree the certified electrical system is much weaker and I found first hand that master switches are not well maintained, but I will attempt to bring this back around to the intent of my original post... Not trying to reinvent anything. This will most likely remain a philosophical discussion for me as Z-12 is already quite robust as compared to the certified planes I fly in that E-bus devices will still be available on battery + internal battery backups, etc. I have found very little information specific to protecting for master contactor failure. Because it's so rare . . . and, with the carefully contrived architecture and preventative maintenance, it's failure does not represent a hazard to comfortable termination of flight. So is the philosophy for Z-12 that it is not worth worrying about since E-bus will still operate? The whole airplane will probably operate. Z-12 is simply an illustration of how the secondary, engine driven alternator was incorporated into TC aircraft. It was simply added to the distribution system as a second source with the ability to support plenty of electro-whizzies on the panel. I can accept this, I just am confused when I see Z-13/8 that connects the alternator on the battery side. Can anyone explain the reason for the difference? Sure. Z13/8 is a three layer electrical system. (1) Battery only. E-bus powered appliances, no contactor loads Endurance implications: "Plan C" loads tailored to known battery capacity such that battery-only endurance goals are met. (2) Battery + 8. E-bus powered appliances, contactor load optional depending on "Plan B" loads. Loads tailored to hold battery in reserve for descent and approach to landing. Electrical endurance essentially unlimited. Descent and approach to landing loads can depend on known battery capacity to supplement the 8A engine driven power source. (3) Battery + Main Alternator. Normal "Plan A" ops. No limits on electrical loads. The three-layer system is practical only on OBAM aircraft . . . the 337 or STC to convert a TC aircraft would be prohibitive and would not materially reduce risk. Bob . . . ________________________________________________________________________________
Subject: SD-8 Alternator Feed 30A Inline Fuse Location
Date: Apr 21, 2018
Bob, In your response on the Z13 Battery Bus Protection question in a very recent post, you reminded us that > Recall that circuit protection is for WIRES . . . and that the protective device is installed as close as practical to the SOURCE of energy that puts the wire at risk. A friend of mine asked me a question on my Z-13/8 configuration that stumped me, so I thought I'd ask you. In keeping in line with your statement above, in Z-13/8 why is the inline 30A fuse for the SD-8 wire connection from the battery contactor to the SD-8's S704-1 relay placed within 6 inches or less from the battery contactor, when the SD-8 is the source of energy? Wade -------- Airdog Wade Parton Building Long-EZ N916WP www.longezpush.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479470#479470 ________________________________________________________________________________
Subject: Re: SD-8 Alternator Feed 30A Inline Fuse Location
Date: Apr 21, 2018
On 4/21/2018 10:14 AM, Airdog77 wrote: > > Bob, > > In your response on the Z13 Battery Bus Protection question in a very recent post, you reminded us that >> Recall that circuit protection is for WIRES . . . and that the protective device is installed as close as practical to the SOURCE of energy that puts the wire at risk. > A friend of mine asked me a question on my Z-13/8 configuration that stumped me, so I thought I'd ask you. > > In keeping in line with your statement above, in Z-13/8 why is the inline 30A fuse for the SD-8 wire connection from the battery contactor to the SD-8's S704-1 relay placed within 6 inches or less from the battery contactor, when the SD-8 is the source of energy? > > Wade > I'm not Bob, but an alternator wire should be big enough to handle everything an alternator can throw at it, meaning the alternator can't damage it. But... The battery *can* damage it, so the protection is at the potential source of the damage. That help? --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Apr 21, 2018
There are two sources of energy, the battery and SD-8. The SD-8 is self current limiting. It can put out perhaps 10 amps at most. Its output does not need to be fused. The battery can put out hundreds of amps and possibly do lots of damage. Placing the fuse near the battery will minimize the danger. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479471#479471 ________________________________________________________________________________
Date: Apr 21, 2018
Makes all the sense in the world.... now that you guys explained it!! Crystal clear. Always good to learn something new! Thanks Joe & Charlie! Cheers, Wade -------- Airdog Wade Parton Building Long-EZ N916WP www.longezpush.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479473#479473 ________________________________________________________________________________
Date: Apr 21, 2018
> >This makes perfect sense to me. Now look at Z-12 - the primary and >backup alternators are both connected the same way - to the main >bus. If you turn off the master both alternators are isolated from >the battery. This means battery only operation unless the >alternators remain stable without battery. Why do it this way? The >only difference I see is the backup alternator is the larger 20A vs 8A. > >To ask another way. Why not connect the larger 20A backup >alternator in the same way as Z-13/8 ( with relay and switch )? Is >this not advisable due to the higher current being switched or some >other reason? The e-bus was conceived one evening about 1988 in conversation with a LongEz builder in California. This fellow did a lot of long distance travel over mountains. I don't recall if his airplane had a starter . . . don't think it did because I do recall that he was fitted with a pretty light battery in the nose. The design goal being pondered was how to create a battery-only endurance greater than his fuel endurance . . . which was rather long. At that time, his electrical endurance loads were as I recall, about 3 amps. A battery contactor draws about 0.8A after warm up . . . enough snort to run a couple of useful electro-whizzies yet this energy was tossed off as heat. His SD-8 would support normal flight loads including contactor. Emacs! His endurance loads must have been a bit less than 3A because I recall we decided that a new 18a.h. battery would carry his anticipated loads for 6 hours, hence his 4-hour design goal would be satisfied to 75% of new capacity whereupon the battery gets replaced. So the e-bus was conceived as a method for setting up a fixed, predictable battery-only endurance load with a simple re-positioning of two switches. Lots of Ez aircraft had only SD8 alternators on the drive pad, no other alternator and no starter. The B&C line of light weight starters and alternators encouraged the Ez crowd on to the next evolutionary step. Added weight on the extreme rear of the a/c drove a need for ballast in the nose . . . ballast that was best achieved with a larger battery as opposed to bags of lead shot! The 24 a.h. battery was the next step up. The SD-8 could be left in place on the drive pad for a weight penalty of about 4 pounds. Hence, Z13/8 germinated from the evolving goals of Long-Ez owners in the 1990 time frame. At one time, I did have a Z13/20 architecture which was discussed here on List and I think a few installations were made. I was never happy with it as it offered no particular advantages over Z12 and was un=necessarily complex. There was no pressing need to eliminate contactor loads on the much larger S/B alternator so it was removed from the 'Connection after a few years. Bob . . . ________________________________________________________________________________
Date: Apr 21, 2018
> His endurance loads must have been a bit less than > 3A because I recall we decided that a new 18a.h. > battery would carry his anticipated loads for 6 > hours, hence his 4-hour design goal would be > satisfied to 75% of new capacity whereupon > the battery gets replaced. Hmmmm . . . my recollection of details may be a bit fuzzy after 30 years, 4 hours is 66% of new . . . anyhow, this illustrates the thought processes for design decisions. Bob . . . ________________________________________________________________________________
Subject: Re: Bulb replacement for my Sandel 3308 EHSI
Date: Apr 21, 2018
Thanks Bob, my main concern was inadvertently trashing the Sandel somehow. If that is a non-factor I'm game to see what the LED presentation would be like. Will indeed report back when I've got some field test info! Dave Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479476#479476 ________________________________________________________________________________
Date: Apr 23, 2018
Bob: Yup There are all sorts of 'possible' possibilities, all without proof, but it DOES WORK! Many of our aircraft are 40+ years old. The original lubricants in the switches have long disappeared. They are NOT sealed switches. What has worked for many years are now failing. Just look Brandon's post. And, when it comes to the Stall Warning micro switch - Replacement with NEW is $1200+ used, about $600 to $700. All this can be prevented with a can of WD-40! WD40 can be useful in the maintenance of electro-whizzies with moving parts . . . and indeed, it was not originally designed to be a lubricant so much as a (W)ater (D)isplacer and cleaner. As a side benefit, it does have some degree of lubricity . . . as do many substances . . . but its service life as a lubricant is far outpaced by other products designed for lubrication. https://goo.gl/sbPhXj WD40 was major maintenance feature for the MQM107 target we used to build at Beech. https://goo.gl/otFkbp The engine was a very short service life device with minimal moving parts and INTENDED to become totally immersed in seawater during an offshore recovery. The first refurbishment move for the aircraft was to remove the engine and submerge it in a barrel of WD40. When the aircraft was ready to receive the engine, they hauled it out with compressed air and bolted it back on the airframe. Not needed on sealed DPST Toggle Switches. AND they are NOT 40+ years old. Obviously, a truly sealed switch cannot benefit from spray on remedies . . . I can't see how applying a lubricant like WD40 can be advantageous to the contacts on the switch...surely there will be burning volatiles or lube which would affect the service or life of the part? On the moving parts yes but I don't know of a way to differentiate with a spray can. WD40 is often applied to moving part for the purpose of loosening corrosion and flushing out small particulates while displacing any moisture present. The combustible VOLATILES are just that . . .they quickly dissipate after carrying WD40 'magic juice' to the intended surfaces. If the Master Switch failed why reinvent the wheel? Since this was a certified plane you are forced to work with the design of the time. What I have found is 99.982% of certified plane owners and A&P's, NEVER address the Master Switch during Annual. It should be addressed every Annual and it is very easy to do: 1 - Spray the heck out of it with Contact Cleaner. 2 - Cycle the switch a couple of dozen times. 3 - Spray it with WD-40. My first job at Cessna extended over 5 years in the technical publications department where, among other things, I wrote repair and preventative maintenance narratives in Cessna's service manuals. Emacs! The policy of the company was to 'replace on condition' meaning that devices like relays and toggle switches were considered and sometimes tested to see that they met service life design goals. If a such a device were to mis-behave, it was time to replace it. Hence no maintenance or refurbishment methods were offered or required. Side Note: This also goes for the micro-switch in the Stall Warning System. The basic switch used on the legacy stall warning sensor was a Honeywell BZ series commercial off the shelf device with very low operating force (measured in grams). Of course, as a component in a PMA/TSO product, the owner operator was prohibited from replacing said switch for $20 (and I wasn't allowed to write a procedure for it either). These are not sealed switches and they're mounted in one of the more hostile environments on the airplane. Depending on the mis-behavior mode, an application of WD40 may well free up things and restore normal operation . . . but a switch that was not working normally was probably pretty long in the tooth. Depending on criticality of the device, it may well be better to replace as opposed to refurbish the individual switch. On Experimental Aircraft you have a HUGE ADVANTAGE... Use a Heavy Duty Master Switch and a Separate Heavy Duty Alternator Switch. I use DPST switches and tie BOTH sides together. This DOUBLES the physical as well as the electrical rating of the switch. Paralleling contacts only doubles the CARRY rating of a switch . . . it does not double opening or closing ratings. Want to go extra fancy? Look for switches that are Sliver Plated. Silver plating or solid silver contacts are rare and intended for specific applications . . . which generally do not include switching DC power. Cadmium Silver contacts are used in the more robust designs favored by mil-spec designs . . . but I suspect the Carling style products used on hundreds of thousands of TC aircraft are not so 'fancy' . . . yet demonstrably adequate to task. You can also use switches that have a built in Dust/Moisture shield. OR... Install the dust/Moisture shield over the Toggle Lever. Side Note: On certified planes with the standard split Master/Alt Switch, there are four (4) failure points: 1 - The Physical snap action of the switch. 2 - The Electrical contacts of the switch. 3 - Fast-On tabs on the back of the switch. 4 - The Physical MOUNTING of the switch. There is a snap in bezel that holds the switch into the panel. This bezel fails as the ears either break off or loose their spring action. Then the switch vibrates forward and shorts out to the aluminum panel. The cure is to use two (2) sheet metal round head screws on either side to hold the bezel in place. If the switch vibrates out it will short out and take your Master/Alt switch and Starter Relay out of the circuit. If you are airborne - You loose even the ability to go to Battery Back-up. Or do an in-flight re-start. Scary! Can you cite any service difficulty report that describes such a failure of the mounting? These switches are used by hundreds of thousands for about 50 years. I find it curious that anyone would find them (1) lacking in design to intended task and/or (2) figuring significantly on the list of probable failure that creates a hazard to flight. I know it is not a likely case, but I have experienced a contactor failure on a production plane in flight. It ended up that the root cause was a defective master switch - but the result was the same. Because there was no endurance bus alternate feed, it was a full electrical shutdown, in IMC no less! Then it wasn't a contactor failure but a switch failure. How did it manifest in flight? i.e. how did you become aware of the failure? Did things simply go black? I would like to know if there is a practical way to protect for contactor failure ( other than battery only operation ) with the Z-12 design. It would be nice to have a second path to the battery from aux alternator to ensure stable power if the master does fail. You can move the aux alternator wiring to the hot side of the battery contactor . . . it's just that simple. The appeal to me of having an aux alternator is to be able to continue flight on one alternator. This is only possible if either a battery connection is maintained always or it is a guarantee the alternator will provide stable power without a battery connection. Batteryless operation is likely but cannot be guaranteed without testing on your airplane with your constellation of hardware. As I've mentioned, there are Beechcraft piston aircraft wherein battery-off operation is described and permitted as a matter of design and verification by flight testing. It's covered in the POH. For this forum cannot make configuration/operation recommendations without conducting similar investigations as to meeting design goals The Z-13/8 uses a relay with the SD-8 alternator to connect directly to battery. Is this design practical or even advisable with the SD-20 alternator? With Z-13/8 the aux alternator will provide power to battery bus and E-BUS if contactor fails. Exactly. If you wish, you can certainly wire the SD20 in a manner suggested by Z13/8. There are no 'rules' that would prohibit you from doing so. When I took Z13/20 off the table about 10 years ago, it was because it added a degree of complexity over Z12 that did not materially reduce risk. In fight contactor failure is exceedingly rare. Smoke in the cockpit probably has a higher degree of probability . . . in which instance you may wish to shot the whole system down anyhow. Any of you who have attended my weekend seminars may remember this slide: Emacs! The last 200-300 hours of my flying days were carried out with these three items in my flight bag. Since I flew nothing but rentals, I had little insight as to the history of electrical/electronics systems. I was prepared to continue flight to intended destination with the master switch OFF. Indeed, the performance of these $100 hand-held gps receivers so exceeded the panel mounted stuff that those last hundreds of hours were flown with DUAL gps receivers 'mounted' to the glare-shield and windshield with little blobs of windshield sealant. Never touched a VOR receiver or even the panel mounted GPS receivers again. As I describe in Chapter 17 of the 'Connection, system reliability has far more to do with pilot skills and careful crafting of a Plan-B than it does on any selection of system hardware. The carefully crafted architecture and pilot's personal bag of tricks strives for failure tolerance . . . not failure proofing. The later cannot be achieved. Bob . . . ________________________________________________________________________________
Date: Apr 23, 2018
Subject: Z12 contactor failure (CORRECTION)
In-fight contactor failure is exceedingly rare. Smoke in the cockpit probably has a higher degree of probability . . . in which instance you may wish to shot the whole system down anyhow. Any of you who have attended my weekend seminars may remember this slide: Emacs! The last 200-300 hours of my flying days were carried out with these three items in my flight bag. Since I flew nothing but rentals, I had little insight as to the history of electrical/electronics systems. I was prepared to continue flight to intended destination with the master switch OFF. Indeed, the performance of these $100 hand-held gps receivers so exceeded the panel mounted stuff that those last hundreds of hours were flown with DUAL gps receivers 'mounted' to the glare-shield and windshield with little blobs of windshield sealant. Never touched a VOR receiver or even the panel mounted GPS receivers again. As I describe in Chapter 17 of the 'Connection, system reliability has far more to do with pilot skills and careful crafting of a Plan-B than it does on any selection of system hardware. The carefully crafted architecture and pilot's personal bag of tricks strives for failure tolerance . . . not failure proofing. The later cannot be achieved. Bob . . . ________________________________________________________________________________
Date: Apr 23, 2018
Bob: You are going off on tangents - - - On Mon, Apr 23, 2018 at 12:02 PM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > Bob: > > Yup There are all sorts of 'possible' possibilities, all without proof, > but it DOES WORK! > Many of our aircraft are 40+ years old. The original lubricants in the > switches have long disappeared. > They are NOT sealed switches. > What has worked for many years are now failing. Just look Brandon's post . > And, when it comes to the Stall Warning micro switch - Replacement with > NEW is $1200+ used, about $600 to $700. > All this can be prevented with a can of WD-40! > > WD40 can be useful in the maintenance of electro-whizzies > with moving parts . . . and indeed, it was not originally > designed to be a lubricant so much as a (W)ater (D)isplacer > and cleaner. As a side benefit, it does have some degree of > lubricity . . . as do many substances . . . but its service > life as a lubricant is far outpaced by other products designed > for lubrication. > > =8BBarry - Nobody said it was being used as a lubricant, only you. It will work as a lubrcant to the contact areas of plastic switches and even the metal pivot points. How long will it last? I don't know... As I said in my post; A&P seldom address switches and many of these switches are 40 + years old. So, anything that one can do to extend their life or rejuvenate them is a good thing. Back to the WD... It is being used =8B =8Bas a WD and as a CLEANER! Oh wait... Can it be used as a cleaner??? DEFINITELY YES!=8B Do you have proof that it can't be? https://goo.gl/sbPhXj > > WD40 was major maintenance feature for the MQM107 target > we used to build at Beech. > =8BBarry - So!!! Who cares!=8B > > https://goo.gl/otFkbp > > The engine was a very short service life device with > minimal moving parts and INTENDED to become totally > immersed in seawater during an offshore recovery. > =8BBarry - Want more info on this subject? I did salvage and artifa ct recovery way-way back in the 70's and 80's . Who cares!=8B > > The first refurbishment move for the aircraft was to remove > the engine and submerge it in a barrel of WD40. When the > aircraft was ready to receive the engine, they hauled it out > with compressed air and bolted it back on the airframe. > > Not needed on sealed DPST Toggle Switches. AND they are NOT 40+ years ol d. > > Obviously, a truly sealed switch cannot benefit from > spray on remedies . . . > =8BBarry - That's why I said you CYCLE the Switches a couple dozen ti mes.=8B =8BWhy are you going off on so many tangents?=8B > > I can't see how applying a lubricant like WD40 can be advantageous to the > contacts on the switch...surely there will be burning volatiles or lube > which would affect the service or life of the part? On the moving parts y es > but I don't know of a way to differentiate with a spray can. > > WD40 is often applied to moving part for > the purpose of loosening corrosion and flushing > out small particulates while displacing any > moisture present. The combustible VOLATILES are > just that . . .they quickly dissipate after carrying > WD40 'magic juice' to the intended surfaces. > =8BBarry - You advertise yourself as an engineer. =8B =8BIf so, why are you so closed minded to other possibilities? =8B There are curtain things in physics that cannot be changed, but how a product can be used and to Great Advantages is sure out there. > > If the Master Switch failed why reinvent the wheel? > > Since this was a certified plane you are forced to work with the design o f > the time. > What I have found is 99.982% of certified plane owners and A&P's, NEVER > address the Master Switch during Annual. > > It should be addressed every Annual and it is very easy to do: > 1 - Spray the heck out of it with Contact Cleaner. > 2 - Cycle the switch a couple of dozen times. > 3 - Spray it with WD-40. > > My first job at Cessna extended over 5 years > in the technical publications department where, > among other things, I wrote repair and preventative > maintenance narratives in Cessna's service manuals. > =8BBarry - So what? Anybody can sit down behind a desk and write a ma nual. I have for a few dozen Environmental Test procedures. ANYTHING can be written. Ask the A&P and IA that is TRY to follow =8B =8Bwhat some paper-pusher =8Bwrote IF it is possible. Ask the plane owner who has to pay the bill why a simple thing like the Cessna Seat Rail Tracks has to be replace and WHY it is so expensive! =8B Or how to replace the Flap Motor on a Cessna.=8B > [image: Emacs!] > > The policy of the company was to 'replace on condition' > meaning that devices like relays and toggle switches > were considered and sometimes tested to see that > they met service life design goals. If a such a device > were to mis-behave, it was time to replace it. Hence > no maintenance or refurbishment methods were offered > or required. > > Side Note: This also goes for the micro-switch in the Stall Warning > System. > > The basic switch used on the legacy stall warning > sensor was a Honeywell BZ series commercial off > the shelf device with very low operating force > (measured in grams). Of course, as a component > in a PMA/TSO product, the owner operator was prohibited > from replacing said switch for $20 (and I wasn't > allowed to write a procedure for it either). > > These are not sealed switches and they're mounted > in one of the more hostile environments on the airplane. > Depending on the mis-behavior mode, an application > of WD40 may well free up things and restore normal > operation . . . but a switch that was not working > normally was probably pretty long in the tooth. Depending > on criticality of the device, it may well be better > to replace as opposed to refurbish the individual > switch. > > > On Experimental Aircraft you have a HUGE ADVANTAGE... > Use a Heavy Duty Master Switch and a Separate Heavy Duty Alternator Switc h. > I use DPST switches and tie BOTH sides together. This DOUBLES the > physical as well as the electrical rating of the switch. > > Paralleling contacts only doubles the CARRY > rating of a switch . . . it does not double > opening or closing ratings. > > Want to go extra fancy? Look for switches that are Sliver Plated. > > Silver plating or solid silver contacts are > rare and intended for specific applications . . . > which generally do not include switching > DC power. Cadmium Silver contacts are used in > the more robust designs favored by mil-spec > designs . . . but I suspect the Carling style > products used on hundreds of thousands of TC > aircraft are not so 'fancy' . . . yet demonstrably > adequate to task. > =8BBarry - YES - They Are! But, as the fellow whom had the failure w as talking and as I was saying: These switches have NOT been addressed during Annuals over MANY - MANY YEARS! =8B =8BThe Experimental Owner has Great Advantages over the Certified Own er by making small changes that GREATLY extend the life and as you are so vigorous to report on 'Reduction of Failure Points'. So, why shouldn't they look for the better switch. Silver Plated or CadSilver? GAUD! Which way did you part the gnat's hairs on that one? Walking into a electronics store, the Simple question: Do you have any Silver Plated Contact Switch? Will result in the SAME results! When I order Manure I don't care if it is horse or cow. Either one will work! > > You can also use switches that have a built in Dust/Moisture shield. > OR... Install the dust/Moisture shield over the Toggle Lever. > > Side Note: On certified planes with the standard split Master/Alt Switch , > there are four (4) failure points: > 1 - The Physical snap action of the switch. > 2 - The Electrical contacts of the switch. > 3 - Fast-On tabs on the back of the switch. > 4 - The Physical MOUNTING of the switch. There is a snap in bezel that > holds the switch into the panel. > This bezel fails as the ears either break off or loose their spring actio n. > Then the switch vibrates forward and shorts out to the aluminum panel. > The cure is to use two (2) sheet metal round head screws on either side > to hold the bezel in place. > If the switch vibrates out it will short out and take your Master/Alt > switch and Starter Relay out of the circuit. > If you are airborne - You loose even the ability to go to Battery Back-up . > Or do an in-flight re-start. > Scary! > > Can you cite any service difficulty report > that describes such a failure of the mounting? > =8BBarry - You must LOVE AD's! I found the problem twice. I fixed the problem twice.=8B =8BYES! The switches have lasted for many years. Does that mean the y cannot fail? And, as I said: It was not the switch. It was the mounting bezel. Just because a FAA 8070-1 report not exist AND I do not know if one does or does not exist, does not mean the problem does not exist. =8BJust look at the design of the retaining bezel and even you should be able to see there is a potential failure point. ESPECIALLY! When the switch is removed in tracking down a wiring issue. There are more things in Heaven and Earth Horatio than even Bob has knowledge on. Barry These switches are used by hundreds of thousands > for about 50 years. I find it curious that > anyone would find them (1) lacking in design > to intended task and/or (2) figuring significantly > on the list of probable failure that creates > a hazard to flight. > ________________________________________________________________________________
Date: Apr 24, 2018
Subject: Re: Z-12 contactor failure
Gee Wizz Barry, Many have taken on Bob N, and many have failed.... In all the 15 + years I have been a member of this forum, the thing that has impressed me most is the decorum of the participants....just sayin! Best... Bob Verwey 082 331 2727 On 24 April 2018 at 04:12, FLYaDIVE wrote: > Bob: > > You are going off on tangents - - - > > On Mon, Apr 23, 2018 at 12:02 PM, Robert L. Nuckolls, III < > nuckolls.bob(at)aeroelectric.com> wrote: > >> Bob: >> >> Yup There are all sorts of 'possible' possibilities, all without proof, >> but it DOES WORK! >> Many of our aircraft are 40+ years old. The original lubricants in the >> switches have long disappeared. >> They are NOT sealed switches. >> What has worked for many years are now failing. Just look Brandon's pos t. >> And, when it comes to the Stall Warning micro switch - Replacement with >> NEW is $1200+ used, about $600 to $700. >> All this can be prevented with a can of WD-40! >> >> WD40 can be useful in the maintenance of electro-whizzies >> with moving parts . . . and indeed, it was not originally >> designed to be a lubricant so much as a (W)ater (D)isplacer >> and cleaner. As a side benefit, it does have some degree of >> lubricity . . . as do many substances . . . but its service >> life as a lubricant is far outpaced by other products designed >> for lubrication. >> >> =8BBarry - Nobody said it was being used as a lubricant, only you. It will > work as a lubrcant to the contact areas of plastic switches and even the > metal pivot points. How long will it last? I don't know... As I said in > my post; A&P seldom address switches and many of these switches are 40 + > years old. So, anything that one can do to extend their life or rejuvena te > them is a good thing. Back to the WD... It is being used =8B > > =8Bas a WD and as a CLEANER! > Oh wait... Can it be used as a cleaner??? > DEFINITELY YES!=8B > Do you have proof that it can't be? > > https://goo.gl/sbPhXj >> >> WD40 was major maintenance feature for the MQM107 target >> we used to build at Beech. >> > =8BBarry - So!!! Who cares!=8B > > >> >> https://goo.gl/otFkbp >> >> The engine was a very short service life device with >> minimal moving parts and INTENDED to become totally >> immersed in seawater during an offshore recovery. >> > =8BBarry - Want more info on this subject? I did salvage and arti fact > recovery way-way back in the 70's and 80's . > Who cares!=8B > > >> >> The first refurbishment move for the aircraft was to remove >> the engine and submerge it in a barrel of WD40. When the >> aircraft was ready to receive the engine, they hauled it out >> with compressed air and bolted it back on the airframe. >> >> Not needed on sealed DPST Toggle Switches. AND they are NOT 40+ years >> old. >> >> Obviously, a truly sealed switch cannot benefit from >> spray on remedies . . . >> > =8BBarry - That's why I said you CYCLE the Switches a couple dozen times.=8B > > =8BWhy are you going off on so many tangents?=8B > >> >> I can't see how applying a lubricant like WD40 can be advantageous to th e >> contacts on the switch...surely there will be burning volatiles or lube >> which would affect the service or life of the part? On the moving parts yes >> but I don't know of a way to differentiate with a spray can. >> >> WD40 is often applied to moving part for >> the purpose of loosening corrosion and flushing >> out small particulates while displacing any >> moisture present. The combustible VOLATILES are >> just that . . .they quickly dissipate after carrying >> WD40 'magic juice' to the intended surfaces. >> > =8BBarry - You advertise yourself as an engineer. =8B > > =8BIf so, why are you so closed minded to other possibilities? =8B > There are curtain things in physics that cannot be changed, but how a > product can be used and to Great Advantages is sure out there. > >> >> If the Master Switch failed why reinvent the wheel? >> >> Since this was a certified plane you are forced to work with the design >> of the time. >> What I have found is 99.982% of certified plane owners and A&P's, NEVER >> address the Master Switch during Annual. >> >> It should be addressed every Annual and it is very easy to do: >> 1 - Spray the heck out of it with Contact Cleaner. >> 2 - Cycle the switch a couple of dozen times. >> 3 - Spray it with WD-40. >> >> My first job at Cessna extended over 5 years >> in the technical publications department where, >> among other things, I wrote repair and preventative >> maintenance narratives in Cessna's service manuals. >> > =8BBarry - So what? Anybody can sit down behind a desk and write a manual. > I have for a few dozen Environmental Test procedures. ANYTHING can be > written. > Ask the A&P and IA that is TRY to follow =8B > > =8Bwhat some paper-pusher =8Bwrote IF it is possible. > Ask the plane owner who has to pay the bill why a simple thing like the > Cessna Seat Rail Tracks has to be replace and WHY it is so expensive! > =8B Or how to replace the Flap Motor on a Cessna.=8B > > >> [image: Emacs!] >> >> The policy of the company was to 'replace on condition' >> meaning that devices like relays and toggle switches >> were considered and sometimes tested to see that >> they met service life design goals. If a such a device >> were to mis-behave, it was time to replace it. Hence >> no maintenance or refurbishment methods were offered >> or required. >> >> Side Note: This also goes for the micro-switch in the Stall Warning >> System. >> >> The basic switch used on the legacy stall warning >> sensor was a Honeywell BZ series commercial off >> the shelf device with very low operating force >> (measured in grams). Of course, as a component >> in a PMA/TSO product, the owner operator was prohibited >> from replacing said switch for $20 (and I wasn't >> allowed to write a procedure for it either). >> >> These are not sealed switches and they're mounted >> in one of the more hostile environments on the airplane. >> Depending on the mis-behavior mode, an application >> of WD40 may well free up things and restore normal >> operation . . . but a switch that was not working >> normally was probably pretty long in the tooth. Depending >> on criticality of the device, it may well be better >> to replace as opposed to refurbish the individual >> switch. >> >> >> On Experimental Aircraft you have a HUGE ADVANTAGE... >> Use a Heavy Duty Master Switch and a Separate Heavy Duty Alternator >> Switch. >> I use DPST switches and tie BOTH sides together. This DOUBLES the >> physical as well as the electrical rating of the switch. >> >> Paralleling contacts only doubles the CARRY >> rating of a switch . . . it does not double >> opening or closing ratings. >> >> Want to go extra fancy? Look for switches that are Sliver Plated. >> >> Silver plating or solid silver contacts are >> rare and intended for specific applications . . . >> which generally do not include switching >> DC power. Cadmium Silver contacts are used in >> the more robust designs favored by mil-spec >> designs . . . but I suspect the Carling style >> products used on hundreds of thousands of TC >> aircraft are not so 'fancy' . . . yet demonstrably >> adequate to task. >> > =8BBarry - YES - They Are! But, as the fellow whom had the failure was > talking and as I was saying: > These switches have NOT been addressed during Annuals over MANY - MANY > YEARS! =8B > > =8BThe Experimental Owner has Great Advantages over the Certified O wner by > making small changes that GREATLY extend the life and as you are so > vigorous to report on 'Reduction of Failure Points'. So, why shouldn't th ey > look for the better switch. > Silver Plated or CadSilver? > GAUD! Which way did you part the gnat's hairs on that one? > Walking into a electronics store, the Simple question: Do you have any > Silver Plated Contact Switch? Will result in the SAME results! When I > order Manure I don't care if it is horse or cow. Either one will work! > > >> >> You can also use switches that have a built in Dust/Moisture shield. >> OR... Install the dust/Moisture shield over the Toggle Lever. >> >> Side Note: On certified planes with the standard split Master/Alt >> Switch, there are four (4) failure points: >> 1 - The Physical snap action of the switch. >> 2 - The Electrical contacts of the switch. >> 3 - Fast-On tabs on the back of the switch. >> 4 - The Physical MOUNTING of the switch. There is a snap in bezel that >> holds the switch into the panel. >> This bezel fails as the ears either break off or loose their spring >> action. >> Then the switch vibrates forward and shorts out to the aluminum panel. >> The cure is to use two (2) sheet metal round head screws on either side >> to hold the bezel in place. >> If the switch vibrates out it will short out and take your Master/Alt >> switch and Starter Relay out of the circuit. >> If you are airborne - You loose even the ability to go to Battery Back-u p. >> Or do an in-flight re-start. >> Scary! >> >> Can you cite any service difficulty report >> that describes such a failure of the mounting? >> > =8BBarry - You must LOVE AD's! > I found the problem twice. I fixed the problem twice.=8B > > =8BYES! The switches have lasted for many years. Does that mean t hey > cannot fail? And, as I said: It was not the switch. It was the mounting > bezel. > > Just because a FAA 8070-1 report not exist AND I do not know if one does > or does not exist, does not mean the problem does not exist. > =8BJust look at the design of the retaining bezel and even you shou ld be > able to see there is a potential failure point. > ESPECIALLY! When the switch is removed in tracking down a wiring issue. > > There are more things in Heaven and Earth Horatio than even Bob has > knowledge on. > > Barry > > These switches are used by hundreds of thousands >> for about 50 years. I find it curious that >> anyone would find them (1) lacking in design >> to intended task and/or (2) figuring significantly >> on the list of probable failure that creates >> a hazard to flight. >> > > ________________________________________________________________________________
Date: Apr 24, 2018
=2E . . . Not wanting to venture into the dark side of some of these "conv ersations", I just want to relay what I have personally viewed on this subj ect of old switches and WD40..... Some legacy Cessna switches were simple pull-push, like a Master. I have r epaired 2 of them. If one is (very) careful bending the retaining tabs the switch can be worked apart and resealed. What I found in both was severel y hardened original lubricate. Hardened to the point that if a piece gets into the contacts, it can cause a faults. Cleaning with the usual sprays and re-lubing with modern electrical grease has fixed both and they are still working today.... but, it was the old lub e that caused random failure. These were master switches. About WD40, . . .I have used it on a lot to things, but this comment is abo ut use on guns. I have pulled rifles from several years of storage and not been able to operate the bolt action. The one flaw I see with WD40 is tha t once the lighter carry fluids evaporate, it leaves a strong, thick film t hat can almost seize close fitting parts. Other than that issue, it does g reat duty as a penetrate and shield from water and rust. . . . --------------------------------------------------------------------------- ----- --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Apr 24, 2018
At 09:12 PM 4/23/2018, you wrote: >Bob: > >You are going off on tangents I would like to think that I'm reviewing background that supports ideas and design goals for reducing risk. Airplanes are exceedingly unforgiving things . . . but they are well understood. We can climb into these machines and launch into hazardous environs with confidence when we (1) don't routinely push the 'boundaries of the envelope'. (2) build and operate with a degree of understanding that promotes failure tolerance. (3) pay attention to the failings that produce the vast majority of unhappy days in the cockpit . . . most off-airport arrivals with the earth have root cause in ignorance of or inattention to important things. There are no procedures in the legacy annual inspections for switches, relays, contactors, light bulbs, etc. Because these things DO cease to function with regularity that has nothing to do with the calendar. If things didn't break, FBOs would be out of business. "Replace on condition" is the mantra of those who endeavor to become licensed aviation mechanics and technicians. Certification follows education delivered hopefully by competent teachers. If you've read any of my works on the website or in the 'Connection, you will see that I try to lay foundation for both the physics and the philosophies I am reviewing. The materials and practices we've grown up with in TC aviation are a good place to start as we strive for 'self certification' . . . indeed, few folks bucking rivets on or stringing wires in an RV are 'qualified' to work for an FBO. Hence, the mission for the AeroElectric-List is to bring the best-we've-learned-how-to-do in 100 years of TC aviation into to the world of OBAM aviation. And then, because we are not burdened with the albatross of prolific regulation and bureaucracy, ADVANCE the art in careful, considered steps that do not increase risk. This thread was about contactor failures. Yes, they've been known to crap out. Cessna Service-Parts sells a boat load of new ones every year. Yet how many unhappy days in the cockpit are attributed to contactor failures . . . or switches, relays, etc? This suggest that they are a low risk failure in TC aircraft . . . and with careful analysis of failure modes, OBAM aviation is free to reduce those risks still further. The narrative of WD40 WAS anecdotal but I hope useful. The flags that arose in my thinking were about the notions you were citing about the lack of refurbishment and/or regular inspection intervals. Most devices give us advance clues as to their distress before they fail outright. I suggest that the FIRST time a switch, relay or contactor demonstrates an electrical infirmity, it is time to replace it. Some mechanical infirmities may benefit from a lubrication/cleaning operation . . . but hopefully, the decision is made from a position of informed competence. Bailing wire and pliers served my grandpa well . . . indeed, proper dress for my friends out here in the hinterlands includes a leather holster for a robust pair of pliers. My son gave me a Leatherman for Father's Day about 5 years ago . . . it too has become part of my 'uniform'. My friends also carry cans of WD40 on their trucks. They may be running re-grooved tires on their swathers. Some have no doubt dropped little doses of 'magic elixir' into the filler caps on a faltering battery. My point is that any refurbishment activity on a component of our airplanes is worthy of evaluation for return on investment, assessment of risk and, as we've learned in a century of TC aviation, REPLACE ON CONDITION is never a bad idea. Bob . . . ________________________________________________________________________________
Subject: Re: Double pole switch failure mode?
Date: Apr 24, 2018
Bob, I'm interested in Z-14 for my RV-14A, not my RV-8A. I was just pointing out that back when I built my RV-8A I don't think the wiring diagrams were available in an editable format, so I used ink and whiteout. The -8A had single alternator and one PC680 main battery plus a small backup battery dedicated to one of the elec ignition systems. I only flew it VFR. On the RV-14A, it will be full IFR cross country cruiser with all glass panel and I'm planning to use SDS electronic fuel injection and elec ignition. That's a lot of stuff riding on the electrical system, especially given that you need to have the high pressure elec fuel pump running at all times (no engine driven pump with EFI). I want to fly the airplane to Alaska, Caribbean, etc...some areas that are far from home and sometimes pretty remote. Having been stuck for a few days on a cross country in my -8A due to a failed regulator, I'd prefer to have more redundancy on the -14A not just for safety but also so I can dispatch and get somewhere after a failure. The SD-8 is pretty marginal for going long distances in an airplane with electrically dependent fuel pump, engine control unit, injectors, ignition and the EFIS system even if you shed the second display and lights and transponder and such. The engine systems alone will use up most of the SD-8's capacity. Therefore I plan to use the 20-40A B&C 410-H as my second alternator on the vac pad (it isn't much different cost-wise from the SD-8, main downside is a couple more pounds). Then there's the question of single vs dual batteries. I would like to take advantage of the weight savings of the EarthX battery, but I don't yet trust it 100%...obviously anything can fail (including a PC680), but EarthX has a lot of built-in smarts that I don't fully understand and among other things it can completely shut itself off if it isn't happy. With one battery, the importance of good maintenance goes up and replacement intervals get shorter (at least my philosophy is to replace a single battery every 3 years even if it is performing well). Furthermore with a single battery, the avionics and ECU/ignition system may reboot while cranking. Adding a second battery addresses these concerns. The TCW backup battery could be a solution for the second battery, but it costs more than an EarthX battery and has more limited capacity. So I'm thinking I'll use two EarthX batteries, each with their own alternator...two independent electrical systems with unlimited generating capacity. That alleviates my concerns about battery failure modes because it's extremely improbable for both to fail at the same time (I'll have them physically isolated). And I don't have to change them out every 3 years like I did on my PC680 in my RV-8A, I can pretty much run them until one of the dies or fails to crank (because the other one can get me where I want to go on that flight). Even though they are more expensive than a PC680, I think my long-term maintenance (replacement) cost will be about the same because I'll use them longer. Having two batteries keeps the display/EIS/ECU stuff from rebooting during engine start. And two EarthX batteries are still quite a bit lighter than one PC680. In fact, the all-up system weight of dual B&C alternators & regulators with dual EarthX batteries is almost exactly the same as a single Planepower alternator and PC680 that comes with the stock RV-14 kit...so it's break even with respect to weight. So...that leads me to Z-14. It addresses all my requirements and concerns in a way that Z-13/8 does not. The main thing I'm trying to decide with Z-14 is where to connect all the engine related stuff. Most of the parts are dual redundant (ECUs, ignition coils, pumps) so I could split those up between the two respective battery buses. The one part that is not redundant is the injectors. So I was thinking about running the power for the injectors off a bus that is fed via diodes from each battery. The diodes would keep the two electrical systems isolated while allowing the engine to run as long as either battery is providing power. Thanks, -Mark Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479518#479518 ________________________________________________________________________________
Date: Apr 24, 2018
At 11:15 AM 4/24/2018, you wrote: >=EF=BB >. . . . Not wanting to venture into the dark >side of some of these "conversations", I just >want to relay what I have personally viewed on >this subject of old switches and WD40..... > >Some legacy Cessna switches were simple pull-push, like a Master. Geesh! That goes back aways. I think some of those switches (automotive devices from the likes of Cole-Hersee) were sill in production airframes when I joined Cessna in '64. C-H still makes those venerable devices. Emacs! >I have repaired 2 of them. If one is (very) >careful bending the retaining tabs the switch >can be worked apart and resealed. What I found >in both was severely hardened original >lubricate. Hardened to the point that if a >piece gets into the contacts, it can cause a faults. >Cleaning with the usual sprays and re-lubing >with modern electrical grease has fixed both and >they are still working today.... but, it was the >old lube that caused random failure. These were master switches. Yeah, fortunately the enclosure alloy would allow opening and re-closing the tabs without fracture. But I would have been hard pressed to 'sell off' the procedure in a Service Parts Manual! I do recall an 'approved' disassembly, refurbishment and re-assembly of the OFF-L-R-BOTH-START switches from Aircraft Spruce when the electrically destructive nature of modern starter engagement solenoids was discovered. And that was, as Barry intimated, an AD . . . https://goo.gl/QV3gTF > >About WD40, . . .I have used it on a lot to >things, but this comment is about use on >guns. I have pulled rifles from several years >of storage and not been able to operate the bolt >action. The one flaw I see with WD40 is that >once the lighter carry fluids evaporate, it >leaves a strong, thick film that can almost >seize close fitting parts. Other than that >issue, it does great duty as a penetrate and shield from water and rust. . . . Absolutely fine stuff . . . there are probably a half dozen cans scattered around my shops and the truck-box. Yes, I've seen the results of WD40 used to lubricate Oilite bearings. They became clogged and totally un-recoverable. Had to cut new ones from raw stock on the lathe. Bob . . . ________________________________________________________________________________
Date: Apr 24, 2018
> Most devices give us advance clues as to their > distress before they fail outright. I suggest that > the FIRST time a switch, relay or contactor demonstrates > an electrical infirmity, it is time to replace it. Stubbed my toe here a bit. I do recall the electrical failure of a mil-spec switch in the overhead panel on a Beechjet. It was a spring-loaded, press-to-test switch that was seldom used . . . and carried a tiny fraction of rated current. Yet, the switch had gone totally open . . . The tech I was working with started the procurement process for a new switch . . . which would have taken several hours and exercised a lot of people. Pondering the range of possible cause/effect I hypothesized that the switch's failure may be the result of DISUSE. The 10A rated, silver-cad contacts DEPEND on some degree of electrical arc to burn away a thin film of corrosion. So before he put the requisition into the slot, I got a 5A, 30v constant current power supply from the lab and connected it right across the switch such that the 'failed' contacts provided a dead short on the supply. After a few dozen transitions of the switch, it became conductive and demonstrated a very low on-resistance (less than 10mv of drop at 5a). We were able to declare the switch 'refurbished' and put the panel back together. That particular application would have benefited from gold-plated contacts on the switch. Such contacts are designed for conductive longevity while working very low or zero-current switching conditions. Bob . . . ________________________________________________________________________________
Date: Apr 24, 2018
Hi Bob, Yes, you picked up on exactly the switches I was referring with my comments =2E If you come across replacements, please put a P in your memory bank to let me know where to obtain. Much appreciated. . Dave =EF=81=A1 --------------------------------------------------------------------------- ----- =EF=81=A1 ----- Original Message ----- From: Robert L. Nuckolls, III To: aeroelectric-list(at)matronics.com Sent: Tuesday, April 24, 2018 10:54 AM Subject: Re: AeroElectric-List: Z-12 contactor failure At 11:15 AM 4/24/2018, you wrote: . . . . Not wanting to venture into the dark side of some of these "conv ersations", I just want to relay what I have personally viewed on this subj ect of old switches and WD40..... Some legacy Cessna switches were simple pull-push, like a Master. Geesh! That goes back aways. I think some of those switches (automotive devices from the likes of Cole-Hersee) were sill in production airframes when I joined Cessna in '64. C-H still makes those venerable devices. I have repaired 2 of them. If one is (very) careful bending the retain ing tabs the switch can be worked apart and resealed. What I found in both was severely hardened original lubricate. Hardened to the point that if a piece gets into the contacts, it can cause a faults. Cleaning with the usual sprays and re-lubing with modern electrical gre ase has fixed both and they are still working today.... but, it was the old lube that caused random failure. These were master switches. Yeah, fortunately the enclosure alloy would allow opening and re-closing the tabs without fracture. But I would have been hard pressed to 'sell off' the procedure in a Service Parts Manual! I do recall an 'approved' disassembly, refurbishment and re-assembly of the OFF-L-R-BOTH-START switches from Aircraft Spruce when the electrically destructive nature of modern starter engagement solenoids was discovered. And that was, as Barry intimated, an AD . . . https://goo.gl/QV3gTF About WD40, . . .I have used it on a lot to things, but this comment is about use on guns. I have pulled rifles from several years of storage and not been able to operate the bolt action. The one flaw I see with WD40 is that once the lighter carry fluids evaporate, it leaves a strong, thick fi lm that can almost seize close fitting parts. Other than that issue, it do es great duty as a penetrate and shield from water and rust. . . . Absolutely fine stuff . . . there are probably a half dozen cans scattered around my shops and the truck-box. Yes, I've seen the results of WD40 used to lubricate Oilite bearings. They became clogged and totally un-recoverable. Had to cut new ones from raw stock on the lathe. Bob . . . --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Apr 24, 2018
At 01:34 PM 4/24/2018, you wrote: >=EF=BB >Hi Bob, > >Yes, you picked up on exactly the switches I was referring with my comments. >If you come across replacements, please put a P >in your memory bank to let me know where to obtain. >Much appreciated. . >Dave check through the offerings here https://goo.gl/4r9M3x you may find a suitable substitute if not exact replacment. the switch I illustrated is a Cole-Hersee 50047 which is probably available through a Coll-Hersee dealer. Bob . . . ________________________________________________________________________________
Date: Apr 24, 2018
Subject: Cole-Hersee push-pull switch
At 01:34 PM 4/24/2018, you wrote: >=EF=BB >Hi Bob, > >Yes, you picked up on exactly the switches I was referring with my comments. >If you come across replacements, please put a P >in your memory bank to let me know where to obtain. >Much appreciated. . >Dave This is probably the switch you want. https://goo.gl/3wLxKs The photo is wrong but the narrative is correct. The configuration of the 50047-01 part number is confirmed on the first page of this document. https://goo.gl/P9ptcT Bob . . . Bob . . . ________________________________________________________________________________
Subject: IS SD-8 OVER VOLTAGE PROTECTION NECESSARY?
Date: Apr 24, 2018
It seems that many builders load the Endurance Bus with more than absolutely necessary. If the combined loads on E-Bus total 10 amps or more, is it really necessary to have over-voltage protection for the SD-8? The permanent magnet dynamo might have trouble maintaining 14 volts, let alone putting out 15 or 16 or higher voltage. And even if the voltage were above normal, the battery should be able to absorb the extra current for a longer time period than it could if the main alternator was putting out too high voltage. Modern avionics are made to handle up to 30 volts. But if a Lithium battery is installed, over-voltage protection is important. Some pilots might leave the aux alternator turned on during normal flight. In that case, an over voltage condition will trip both over-voltage modules simultaneously. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479534#479534 ________________________________________________________________________________
Date: Apr 24, 2018
I lost track of which Bob was recommending annual WD-40 as a switch failure preventive prophylactic, and which Bob wasnt. Can someone advise? On Apr 24, 2018, at 3:21 PM, Robert L. Nuckolls, III wrote: At 01:34 PM 4/24/2018, you wrote: > > Hi Bob, > > Yes, you picked up on exactly the switches I was referring with my comments. > If you come across replacements, please put a P in your memory bank to let me know where to obtain. > Much appreciated. . > Dave check through the offerings here https://goo.gl/4r9M3x you may find a suitable substitute if not exact replacment. the switch I illustrated is a Cole-Hersee 50047 which is probably available through a Coll-Hersee dealer. Bob . . . ________________________________________________________________________________
Date: Apr 24, 2018
Subject: Magic stuff . . .
At 07:12 PM 4/24/2018, you wrote: > >I lost track of which Bob was recommending >annual WD-40 as a switch failure preventive >prophylactic, and which Bob wasn=99t. >Can someone advise? The short answer is "no". The longer answer is, check the engineering data on any line of switches or relays you might be considering for your project. You will find a constellation of styles and ratings. It will be a rare switch or relay that is rated for less than TENS OF THOUSANDS of operations at rated load. Now, consider how heavily you are going to load this device . . . pushing the ratings? Probably not. So from an ELECTRICAL perspective, the service life of this devices will be some factor greater than rated. Then we consider mechanical service life . . . which logically exceeds the rated electrical service life. Now, how many operations are you going to put on this device every year? Based on your anticipated service demands, how many flight hours will you put on the switch before it's at risk for end of life? Trust me, it's a BIG number . . . so big in fact that and end of life failure is exceedingly tiny if not zero. You cannot wear out that device during your life experience with the airplane. Hmmmm . . . switches and relays get replaced all the time. Yup . . . and probably for reasons unrelated to actual operating cycles on the device. Okay, what's the reason for premature failure? It's probably a combination of serval things . . . most of which you'll have no control over. Hmmmm . . . what's a poor owner operator to do? Can't tell you without going through the kinds of failure analysis that dominated the last 10 years of my career in GA. The analysis was expensive, time consuming and seldom revealed a cheap and dirty resolution. Some failures were one-of events usually based on some fabrication error . . . it took 5-6 weeks of pushing one poor customer's airplane up the chain of time, talent and resources before I talked the pilots into letting me tape a 37 conductor ribbon cable to the fuselage and past gaskets in the baggage and passenger doors. With this rig I was able to watch a constellation of parameters in the tail while we climbed to 41000 feet . . . one more time . . . in search of the elusive failure. Found a crimp pin in a pressure bulkhead feed through that was not seated. The wire bundles had to get cold and shrink enough to pull the pin back and cause the failure to manifest. That 10-cent error cost tens of thousands to chase down. What's this have to do with switches on your panel? It's but one example of how root cause for a mis-behavior can run the range from observable broken wires, dripping water or hydraulic fluid, temperature cycles combined with ozone concentrations, . . . all the way up to failures that would only manifest at altitude after consuming about as much fuel in one flight as my wife's Saturn consumed in a year. Go back and look at the engineering data for the device. I've never seen a manufacturer recommend any form of periodic maintenance . . . much less squirt 'magic stuff' into the device's cracks with some notion of improving service life or, worse yet, 'refurbishing' a misbehaving switch. Back in the day, we had several cans of cleaners, lubes, sealers, etc. on the workbench where we repaired radio and television sets. It was always gratifying to drive the mischief out of a rotary switch, noisy volume control or arcing flyback transformer with a squirt of magic stuff. But we're talking about airplanes now. We're talking about devices that have obviously failed to meet service life predictions. Okay, now what? What forces in physics are responsible? Will 'magic stuff' mitigate those forces . . . probably not. Will they 'repair' the effects or simply squeeze a few more operations out of a device that is close to gross failure? Finally, how do you KNOW that you've squirted the magic stuff into the RIGHT location and that it doesn't present a new hazard to functionality if it gets into the WRONG location. Finally, how hard is it to replace a $5 switch that's held on the panel with one nut and wired with a couple or three fast-ons? I used to recommend that my seminar attendees take a sunny afternoon and $50 worth of switches and replace everything on the panel . . . just for the hell of it. System reliability benefits far more from preventative maintenance than it does from magic stuff applied to a device that's already begging for help. One more example. One day at Beech, a sales rep came out to pitch a particular kind of magic stuff. I think it was called "Stabilant 22." It was reputed, nay, demonstrated to improve the quality of metallic connection between pins and sockets in our harness connectors. So, we piled engineering data, test reports, user testimonials, etc. etc. against field service experience on a fleet of thousands of airplanes gathered over 50+ years. Yeah, Stabilant 22 was pretty whippy stuff . . . but expensive and labor intensive with a risk for waste due to spillage and getting it on the wrong surfaces. I could just see the faces of our line techs when we handed each one a bottle of magic stuff with a requirement to properly apply to each connector before it was mated up. Then, there was the question, what's the return on investment? After some consideration, we deduced that it was a 'fix' for a problem we didn't have. So there your have the long answer. If any combination of components on your airplane is crying out for help, then replace on condition is the lowest risk and probably the lowest cost approach to risk management. WD40 is good for the kid's tricycle that might sit out and get rained on from time to time. Bob . . . ________________________________________________________________________________
Date: Apr 25, 2018
Mark, Many of the ideas you mention are included in this design I created several years ago.=C2- You would simply need to add a second alternator.=C2- This design contains a lot of things I want in my RV7: 1. Automatic fail-over2. No brown-out during cranking3. Source isolation4. Simple operation It is in pure schematic format for easier electrical analysis, as opposed t o a hybrid schematic/wiring diagram as are commonly seen on this forum. It may give you some food for thought, -Jeff On Tuesday, April 24, 2018 10:51 AM, czechsix wrote: Bob, I'm interested in Z-14 for my RV-14A, not my RV-8A.=C2- I was just pointi ng out that back when I built my RV-8A I don't think the wiring diagrams we re available in an editable format, so I used ink and whiteout.=C2- The - 8A had single alternator and one PC680 main battery plus a small backup bat tery dedicated to one of the elec ignition systems.=C2- I only flew it VF R. On the RV-14A, it will be full IFR cross country cruiser with all glass pan el and I'm planning to use SDS electronic fuel injection and elec ignition. =C2- That's a lot of stuff riding on the electrical system, especially gi ven that you need to have the high pressure elec fuel pump running at all t imes (no engine driven pump with EFI). I want to fly the airplane to Alaska, Caribbean, etc...some areas that are far from home and sometimes pretty remote.=C2- Having been stuck for a fe w days on a cross country in my -8A due to a failed regulator, I'd prefer t o have more redundancy on the -14A not just for safety but also so I can di spatch and get somewhere after a failure.=C2- The SD-8 is pretty marginal for going long distances in an airplane with electrically dependent fuel p ump, engine control unit, injectors, ignition and the EFIS system even if y ou shed the second display and lights and transponder and such.=C2- The e ngine systems alone will use up most of the SD-8's capacity.=C2- Therefor e I plan to use the 20-40A B&C 410-H as my second alternator on the vac pad (it isn't much different cost-wise from the SD-8, main downside is a coupl e more pounds). Then there's the question of single vs dual batteries.=C2- I would like t o take advantage of the weight savings of the EarthX battery, but I don't y et trust it 100%...obviously anything can fail (including a PC680), but Ear thX has a lot of built-in smarts that I don't fully understand and among ot her things it can completely shut itself off if it isn't happy.=C2- With one battery, the importance of good maintenance goes up and replacement int ervals get shorter (at least my philosophy is to replace a single battery e very 3 years even if it is performing well).=C2- Furthermore with a singl e battery, the avionics and ECU/ignition system may reboot while cranking. Adding a second battery addresses these concerns.=C2- The TCW backup batt ery could be a solution for the second battery, but it costs more than an E arthX battery and has more limited capacity.=C2- So I'm thinking I'll use two EarthX batteries, each with their own alternat or...two independent electrical systems with unlimited generating capacity. =C2- That alleviates my concerns about battery failure modes because it's extremely improbable for both to fail at the same time (I'll have them phy sically isolated).=C2- And I don't have to change them out every 3 years like I did on my PC680 in my RV-8A, I can pretty much run them until one of the dies or fails to crank (because the other one can get me where I want to go on that flight).=C2- Even though they are more expensive than a PC6 80, I think my long-term maintenance (replacement) cost will be about the s ame because I'll use them longer.=C2- Having two batteries keeps the disp lay/EIS/ECU stuff from rebooting during engine start.=C2- And two EarthX batteries are still quite a bit lighter than one PC680.=C2- In fact, the all-up system weight of dual B&C alternators & regulators with dual EarthX batteries is almost exactly the same as a si! ngle Planepower alternator and PC680 that comes with the stock RV-14 kit.. .so it's break even with respect to weight. So...that leads me to Z-14.=C2- It addresses all my requirements and conc erns in a way that Z-13/8 does not.=C2- The main thing I'm trying to deci de with Z-14 is where to connect all the engine related stuff.=C2- Most o f the parts are dual redundant (ECUs, ignition coils, pumps) so I could spl it those up between the two respective battery buses.=C2- The one part th at is not redundant is the injectors.=C2- So I was thinking about running the power for the injectors off a bus that is fed via diodes from each bat tery.=C2- The diodes would keep the two electrical systems isolated while allowing the engine to run as long as either battery is providing power. Thanks, -Mark Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479518#479518 - S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. JVBERi0xLjMKJcfsj6IKNSAwIG9iago8PC9MZW5ndGggNiAwIFIvRmlsdGVyIC9GbGF0ZURlY29k ZT4+CnN0cmVhbQp4nIy9Tc7sOtal189R3BFcSxRFUSMw4GZ5CLfhglFqGAY+I2fv2OT+WWuTJ6uQ SNyj513af2QoKAZF/T9/HX+f5a9D/mf/+Of71//2356//q//91/33+/73n/9f/86//o/fv//v/81 dH/9t//9X6XdXfT9qX/X5/nr+1d97ufvtzr5H//6PxcWquuqf9/lIpWxz62jKrNviQFV7f2xt4BH I6i6z5+to4PKiKiu637/PhqojFD0x93RkBzi3+2cWn7sbCaxQ5Gch9T5/NW5PEf9+zz/6sf5d+1V knzOZ5CfhzrjSkg0tSwaQqK5yfIU3Yu3SZ7+Lipj4e95GqiYReSsYvZ5xk+TQC14ZqC63lWlDKJH VRcGdehv+ZtLReSneI9xBhaKkWuoTIzcE6XPKOxg8oxCc5+LRlH4osQJfVYJ1rSHizOONxIIeZPW +2v748Xc399ZQKaKmaiedxCyxQxUGJUxqJLGQKVkJqoyz6NiMgNb5JEZ5EgqZhA9eLyOc6i87gZ2 ogjrOspSiMxEtQafmah+nWHxeFRuID8PmvE6fu3/u9RB8BOwKWY/1SnGO4eVmKgk6axiJipJOnt8 Jovg7TwM/pS0H+gRVzmIDFVioIKempl4lKyf5JGZqKSPZBWzLyJFj4mBCiuRGHikqjKD6FFVpNIU l5GdCuqlMWCOiYlqU4myVKI871KJS2rfUGUEK5GYqKRPNI4+MVGVd1UxG4OBaR17jjGIS0lpq0qZ qOSD9iNnDFIygxxRdQu74eNYbwRDwyg0lGBin5veqqILVuk2NzfPLaFXcHjLaZWCYhQacqeGMCjp H0nVjnlm9L92E5mq+08qDD0xUWkM2EsTE9X5rCpmX0RKHo/FoxLsy4mBR6oEM4geVY/05Qs9yrhM CEafmNiSpk6qxET1kPWperJHI5QjM/BIOTKD6ClHZl9kjR4f6U0FOqGCnQjCeiTQkhwyE5UEmlXM fqouDZs9Siekotp5WPpeXmRfEPRoLLq9DAQXW8xEpVmTipmoNGts7DGggmGlAxhSX6+0D45PrzHC 4tGnq6LfqK2dw40KbNXfUAkk9Te+ouQIiIl3hoP5JyaqZxPOs4SjBNs4MfBIBWBmcVNe50N/Lzys q0fDvOpvaJbyfrFF65muTwTs7+j/pIvqdAfXXQLj7rem+G68rE055dc4v7ekv7/4eZrhoP2znr/7 6+iO9bwvAFNDKDSc6DSEvlpbVFfpf78dbhbrb6w1CPhj9NOU98waRqJ5yPIUPdmbEmrixMIfNXRi ETmpEvs8Y2r0xECFTZMYeKSKMoPoUZUYVII8SrtSJYzsVBBX28TVclyXeEzdN7Gfqh7XIFgvYxGX ERg4ZiYeJeuHhoSZQY6oqhJXI4/1xBimipmoyswH+0RiYItyZCYqqWBWMfsiUmyhxMAW1j4xiB5V t/SvBh80BeQwMVGVGQKZYiYqSTqrmIlKGih7PK7UQHYeNtCthYhyNYnh5qImBipsxsREJVnf7DEx ievdxMXsi0jRY2KgokosjW3WqapvrqpFiqomlabojexUUIm2qUTLlWjPpqrPUlUl5HFVST7ZIzOZ uD6uxWNioOIZrTHd0y65KLQxVzXJ/Zx//+79SGVMVPeYmLrvF1TMRNXLqmImqnfj8V08vhTpnO85 X7ZlZKeKHK9jRsoqZqJqYzaplV8MqkECiuPNikHC0/02VyCJiEFx1kpezmvMo1G0iY25tWdVMRvz dDXn9LI3O4ackIQnjBhJRIwKJJ/nePeasp4EFNArMgNP0MMyg4hJxSwyJ4/lHfNVXp3Sx/wYVTmx MfP1rCpmoqpge2pq8qbH0RZEwhNUmkhEjAokn+cIbUEEFJvKQFuYXaxyYhAxqZhF5uTxusZcGFRQ yU4FcV11zJiRx8TGHN2zqpiJqr2rx3MwbxM9C1rteseEWSjmMVthJpNq0kNvjigxUYn3rGImqjqt Rxsr8ZhMURvYYSaqa0z03fLjpquYQX6k6kMFrVe1KvgpSSxUnN+0Bfndm1rddcyWeS++Xzieinev iM8KEVH0MZMGbUtkzGA+WYHki7jAS01e9Bj7R2LhiXNmFhGT6qljasmvM881ZtOoJRIT1fGsKmZj tg5sDw0RUESFiIQnqBCRiBgVSD7PEVqbCCiwyomBJ6ofM4iYVMwic/b4jkk3rLOSqODTx8QfWOrH g4RUXoFpB2uEBBRopdfp3dpCj3car2Rvb5wzFUhEMWNDBRJRLNH2FG3fRPu2MYHmmjEGPdEPEVFc JSuQiOIEm1NxJi96jO2YWHjieJmNGc+6qph9kWf0ZiURtSrw+p1Y1IeuzIlBfqCqBw1e6m/YSlcC Avp3zGmcHwnV4yrp7+31DlXP84Vc4dD+5m0Dh2PeD0dLcCgeO/Y/OPzUediMQ/sbtDQBtcuZdPyo jiDo7+XsMmEIxSr3mESieiYmqjamsuK6wAQUkSWR8AS5EgkbUH0ioMCaJAaeKHNmn9eCVdeZ6zPJ ThVxr5m9F+c+jzluZjJNdqxxJzamKPuqYiaqeqVaKvGYTIF26jmmp0LTzzieVpCMicmecicSNjAS JGOqsSUFkc/jovolBnYoI2YQManeMdflWdW7pbyJjAnGMRUKeRMJG5jVnbLqY8YIFUg+j4vzZgZ2 KCNmEDGo5NeDtxZZ+dfeW9au1ev311MmbctzNiRjbiQxUB2xnjCzsX7uFXK9D6iYfR4DqRITVe+r x+sY7Dzd492RTBUzVPWNqofqHKTcqCImqutZVcw+iLRvou9ZtcsRqjqtc1WZRfSk6se09RsSmOrX q5bWZiaq3vC8qWIWKo7reXOOap0q8eQ+oSqOXtZ6osN+3X+n2BmJpvS/U+SMXMO+ypniVssYtoog 7CliS29PEb2rN0JjwWCTKToSvfUQBp3KCHaXxIbq2dgiNqZX66piNhYf9mEdP17GIK5J0NZ1nDMu L+h1HBeeN1XMxoTum1WZxbQvtU5ioKJ6MQuPXAlmET3nyOyLrMHjdZRR1egR1/EbWACZKmahYo93 4Ur8VEsLZfb5eWxLPYJqZ6s1mbJE1ZzEZBUzVPWNKvpEH1Ok3CeYieq5VhWzDyLtm+h7VlELMQuP XC9mET2pzqOnuIygx8REdd6rLWaiKmVVMRtT1m1pIWMQ1yTXe/x9FxIp+nwJ7NWv0BCK/EDzc3xB POMQOzsB+ftV098ByN+rPLpAF/XMQAW9JDPzBV2EgMVKf29nNvHcqyNmovpdaN432WIWKmzQUJ2u 0higQTMbi0nqINDRMgtb7JFZ5MgqZpAjeiylphzL+Sz1SkxUx7WqmInHt61VZQYqqgSz8Eg5Jjai P1YVsw+yPtdKQI6TwEcuoagWfpwYRX6kucbtDnSHMteNcEjMUNU3qmjC393E21PjMBNVvVcVsw8i RY/MQEVdi1l45MZhFtGTShZai624yihh1bx5RtUkyVZJOV73sVTCVFF7U2EL/RzI7RtUopZnELSV 2Lh1vlYVs7h1ptonBiqsfWLhkSqRWETPKmZfZE0emX1LbfR2vOccJ2GPqora11bWejEbqldur5OK 2Fg5NBbtUFz374uJVUooLlNFXDKTmj0mFgt5WMVMVO1Y42IWKo5rTiugrd8N+uKRmSwmOcriMbFQ kUdXRSU0Bvx0JDYW8tRBsOckFrZ2OUIv1HxYxQxyRI+6BAgrMQnnqCqoRLnwvKliJqrrwPOmilmo 2ONG9awemYmq1tUjs1Cxx7tPlbdQ6w3JVDFDVd+owuPzrtEzG4uo7lXF7INI+yb6nlXU2szCI1eC WURPqvHsc//r//vXdcv9xW8sWrt+1zjp8LRwYuMn5XNVMRuq8bOtLGj0e87EUFU2qhKqaf03TAAV MYieVLIanVVqvUJcMvs6VIep2nUhmSpmqGoblXtsZc0xMVHJvVdWMfsg0raJvmXVXVeVMvBIlWAG 0ZOqLnEpoXoxE9W9scVMVO1dbbWlhZRgvZ7fley4sH/pwzHUVxMDFcZltiKu57pX1e8zdxRS3Rtb zECFLZTYF9ZJxexbYpiq/maVkmejgnq90xbVi1n8VE+qxET1G5tlj4mBCnNMDDxijolB9FSJd2kh rs0f6rWL/v6Nn3997updpyLuuw3wwlRLYqC6u09qmKXbLbWyaPrUtKoafVZO3et1pHBEstY5R5QY qO7VkkckP1ZmzZ293Rtv9+LtOaRjs4rZULVBMDtCqCmrprhmWv7x0CCCuFFD6Itkn2PJ/zmSZlOj O8eMml9Cgrxln7Pk3J9SOXf5nSZXMbGxAqisKmZD1Rd/hFBTVk1xTcm1ZgRxo+ZK7WHJQq0ZgeZe a3TnmFHTjlRrBX3VRO4yQVtSFZmJ6ndtWFTMxuVmrPEhf4RAM4MkTcStljE3QhA35d+yBgvyhxqt MfejcMz9WLNPDFT3askjkidUsuaeUXvr96sAmBpCqGmrxnpalwtvjpoZqCIi3zOoyCj8lLWP11jF +f2I/Lp4ORF5kVsV2bAnVHdbVXrmb0y62JqrNIfqPpQdbstIA9WVbSlhW22x1VZbMvExcpxM4vr9 a1HVd6rqa9EbmcNuUb2/E8rYGejnUZoggPyDNdev350dRdfvI36+Q3Uev6zLbSf+ROfvuBW05Bo9 D0Q7S6HaBJVO3IrO1uWf0cynPPcs68agmTNDVTRNZqGyJp2qNkoEtl4p2pM8mipsTYK2fo16jy5z v+OXptH9jkn6+I3ld/zo8S2/1JXabzz+53eG7JsDivswC+Nnm9+x+Ri/xf0zO/ToTPcYYky/8gO1 kPljz++46XHh41OtBJkPPfyOX/VjfuvGL8Uinf881Moxz/qN+tCqH7tfJxqZWyicr+Y2/NbfvcTv Y4H5yoZRFfL93XfN48LHka8Ry/fs49jyNR+Yr+zGBUz8lletzHzl5yyyasfh14hFZhYscvVB+Tat 0XWb3zu1753a917a907te3P76gWJ82U2LlvprIfb14/D78Pta58Ij7z9uX3hc1S0dexzdN16rJ+j euHxyPdghVbMPkdWU8rXPxXuV8n9du2NL386S/78JjKvC0fFWEZ/fZW0Gd11asZ932/ISlUrv/EZ kvmFVLTNXCUbpgDhWauwepveydkjA6t/qE6t79XWPCf7k4oZti56rIvKeiPaerR95pkfkLuuqoi+ a2+YO1dNFTNUocdF5Vdo8JgYqiDH341wit4JxJXYB218b9o9PF5ttcUMVbu4riOrJqERXP7CjK9Q 7HI2Bo6Oecljpgd3zHzmvpP7ky5ha3ysk+q5utq/3aOSeWH5HZ96PNdE6CSVHf8jd5I3K46XLdix XQCCPHPJllt4jnlsPuaxnGFRmMKiNAucxz//+u9zarFrxpadE42tnacez9jbceHxPzJ5e5PCq6gW oqqWnRONzS1o7O7Ds/MoTGFRqoWUh2b3lPn8zJhZ6Zzd+KrNk+/WI+yjFOTe9Jvb+82cS8IPSWao igvBTtX66pEZquIDd42vAbb19jUuZjGDRXElhirwGKrDP0ENCccFqmOSAjkyQ1u7HKOF3k0lmGH0 4LHVI1eilKVeiY0+tLZjYmgLKpFYzOex6spV9Uh30Xu9/DxsoSv3aI8UVXfuX07QI7Mx3b/x2BaP c6KPVcxiRi55XGpv52ELdb2yeb105o6qmhip2kZl7fgcbfGY2BdP3FFczD6MtG2ib1mFlWCGHrGq zDB6UOkEHcTlZKeKel2bSly5EjrVyCpmMSfItX/b/G6P6I2gLWYxm0VXzMREVY7FVmKowkqYR6+E qzYDmSIPO57yCJ0UcK4tPmUzXANjcMQINN0164ioXCfNcpGlnizJ9iuHblQ9phdecOd7EGBM6xza xt9V+zWf8P7dokxbTuTH3/bXJTejcvzOp7qv30VoPMuux//IM/0PEn8K3yz48fTxDzynf4/9Od3C 87uxl2Pzoce/MywKU1iUZiHlMUcMljE0TGpOrmcUXQlUPdf4+xfkFbaWOcl6FC45Af07mrjk572Z ijpaJAOc7QfqaX8fk0/Xcis3d26+n2uE6ls5302+U7U/9acnTTsGkO8W06idif6gIfS5YfL1Jo31 b7Dz3sesfukmsp1kLvgUMBPVVVYVs3gsw6xPFTNSlY2qZI8YPTPaG6et0YfKspbHDXIlJkPVUVfV UZNHrHxiED2pmGEl0ON8OASramSnirieTVzPElc/VhWzodrFVXIL9SO3o21WHarrOJfWzkxUZWnt zEAF0YPqMJXFEK2d2di9aFPVN1XVzyOPR6qq50MqZphjeLzGtYorcW08XjXnWDdVrUtV77Kq7rKo +lr7p82ddy6vhBGMnpmo+ph25OiZDVXfqHpW2e4/5PGYLKLX8yDHeH4T9s157Zulv5Pc8bWQ2Oe7 W7PqWVVkXVWLRyd1o1o8Xu/q8VqiR1VfVJb1BR6Zoaq8q6osHsumXmWJvmzqVZZ6gcfrmPv3RFWd 7FQel4w/JgmPiX2+E1BSvVlV6sajsrrYgna8rjer6kZVF9Wt1qEdE0MVRu8qt2UxXJu4QLXJkRna KhtbZcmxbHIsS47osS1VbZsc25LjQ+dN1bPYeja1f5ba903t3zkGhl5opGxUXq960IByDjKZDdW7 Ub1ZddaNR2V1sQU5yo9Yg3m9fHcp6BOJkerdqDzHa+OR2Rd3ERzXqtp4LIvHslYiMfRYNh6jqtdG dS9VvTfteC/1anXNsS222qYSbanEs1TC74zprsRuUuhXpzv96pSn6OfteP4JYDEUdzPn8+iP9bP9 PyAyQ6B32o/80M2q3yhwEBnL6s/3fuZkf1Ix+8A6eOxnVkl7ZFv9N/YZywPmmR+QGSmrPPouP1MK mTumTRUzVKHHVSU/tWaPzFCFOf5GSCl6IxgXM1G9dfXITH4dOtpiKzFU7eKSWRxWTUK99rz6/Xeh 1SROZjDn9Tzz+D7ncfsdX378z++Mm8gpz3yNY7Ngx9PHOENJMYVaOBv7mMdyhkVhCovSLHAec8Lj lOVI5cTsnGhs93XOY439LnT883yfSSGLitCCHXt2TjQ2t6Cxuw/PzqMwhUVpFjgPzU4u+zPnW7NL BI6H3f8CxV2m4jrmcRs/Up3yhQbHUvnfBxwVXmm1EJX3tnJyJ8U4/jfHfuXYz2dGdmuLz6/mU1ZJ jBocVufaXyS/uhet4qPHesb0ISsEThk2zr5ofqN3Xv5Ru1vN/aYeSNKF+GrDxj1u8afV1iaBdVSJ oerqoDqQieopq+od7QaXDCdto4q43jYJxsVM2uLoiyoxUc2+Qh4TQxVc8BJDj5BjYhg9VaItqmPx uNZrG31pWWVkp4ocf5fkpV7Mooezipmo7rUdE0MVVvVecjTrWFVmGD2qmH1Lbf5Ur130cgU5yZaR VlZVs683Wec2CNQrMVGVsthKDFXXJq77yKp781UpF+Mi+7HKSEnUDuqYRB82jZ3vmPgGlTwF76rj mKwPJqrap62j/y+oSjtCxeyD86622prsT3FxFGBLNgTOtpTtKxFXx/4reXnAqKyQHuB0dUI/zW+w kjWMfhr5BD9Us4RQU1ZNYV/lbdmXoogZNYw+T7S8R2gIgabXRWPN7Iafvvh6eooZNIwid/R15xre qx1DHvPvU1Ra4yImJqq+UfWs+n14BsFCJoYqCKu3bMsIJpjYT/WW1VZiouobVU+qV64+rVATO/O4 QhW2XrmysMrITuW1f69K5w1VYj9VPVZVXeKqzay3UDFDFcSly9Cj3ziB2mf2Uz2HErCVmKjaRtWy 6ndjs3i8u8blOdp5UAm/hPtqetkCf16c+7hwKZhXN0KhGb8YXaRRFNUATUJfdj7syHYzcnvvXykO JMe/Tnm15Dh8z3F44+FvBPwbFNPfpcnhbDsc1odcQdO/69my7hmsj0ORN/67xaZnU+x6S7I8m5BG 0v+Dx+Cm0u+PpHrHqNdr42Bmd8ld1OW5Xyceyl3IQX+XWXI42w+tNg5mdn72zN2tW23cu/7dYtOz KXatTUryyyOKkXW5LK57Zs0ADsXvf8Hfx8uEz1JmE9djyuVW1A+lTXvHv3sjzrOjTa0LOGD5OPw3 B3ylgO9nRFCfeTiHBmdpFx5L5Z+XFW8hA+8FDsZN3Hla3dRn9PTLCikz2dx9rgNAuoE7uxrwgc8p XySVBiCZgQquXG7Lr1ynvA82q0qdt36hMgJXrsxEJZe8i+NKTFTPsdpiBqptXPYNFKr4zotBsfWI GO8aka73I34VKb+P0Di+6RiuYq7Q1nQLeqw+4EJ2dlNMC6f0W/Chx3Atc4XFbRY4D/3I2uc4sjNi sdl1wGK3C0VkZ1cSU9iFxizYcWTnRGMzCxa7+YjsLApXWNxmgfPQ7OyTesrGtAU/u0rgeNiFy02R 9e8lrjel3PPDqxccPYYrjim8f6iFqLy3lZM7Kcbxvzn2K8cuz4+VuPCcTeusFx49hguPK/TC4xb0 yqM+6NITfqN3DkIXH+g3evVRwpefcspDjO2vctzX39d4qua8byWvkPELQmKiklfKZxUzUclVMaxP FTNU/eq2qCZDj/VcPU6G0aOK2QdZX3eomKGqXKuqLNGDqvzuZs8bLrE/UiaJIWRmopLtibOKmajk vvmmi2dmpCobVckeW1s9tpajRxWzD7KOOYLMUHXXVXXX7LH21WPtOXpUMcNKoMd25Lh6XaNnRqq2 UXklnr7WnpmoRJ9VzD6MtG2ib1m1yzGqataxXswwelCNr27qhWPAkvpqYqja2XKPtjyUVPqUXdR+ jHgrt1BipGobVXPVfIINa5+YqK6+qph9GGnbRN+yClooMfRIlSCG0aPqXTz2tkbPDB7hIhUzUbW+ 5sgMVZgjM/SI0TPD6FHF7IOswaM9wxi90MlOdYdq9ZjYeB6yrCpm8NQkeTxyVf08qL09SRlVtadj ScVsbEewtnZiXzy5ie2YGKow+rrUq27qVZd6WaSoYgbPj5JHZt9Sm6nS50chRyPo0ZhfJ+xZUapX X6r61lXFDJ4fpWu0fuvozSV888FcdRmz4qwyEnPL/g1zlfwNA7PjmcH1nlTM4LtDrdN3B3g0ctZV ddbsEaNnhtGjihl815JHZt9SG7quhi0nV1lVXonRCpVbKDH4hiFbzFAFObrHkr+tlNAVE2wZQVvG vIXsGkpxMRvX1QPP0+vqkW0ZQY8b1aYSfanEW1aPzFAFHu2KGbac7FRuy67tGFdicL3HuBJDFXpc VWXtX4nBtwJ5LLkdnaDHeqSeY9dC7DmJkaptVPkbhqJnBtd7UtXc2hHp+g0DHo3AZzsx9EiVIIbR o6rPp+TjU+sEPTKDbwW2RQy+FUjFDL4VyKN+D0G97Dyoqj3jH+1oz/hjaydGqrZRNVcdq0dmojrX PpHYh5G2TfQtq6ASiaFHqGpiGD2q6hJX3dgyFvVqm0q0pRKtbVS5He9nU4lq4wmPvk4V3jUlBjmS itkXu0rgPEBipCobVckeW1s9+rjQI0UVM6g93qclhqq7riof8bn12lePNfcJUjHDSqBHbW2ohJGd KuJq6xgzMegTZIsZqrBeG9U6jk5MVH2TIzNUQZ9o8kkp2L+cQP+S/bkHc4+yCw4QVnmfcFvQcxJD Fdq6lriMQI6Jff4AKNtiJiq5k84qZkPVNh41R+85fh5W9R3/xhzni71YxUxUT11tMRNV21S1LVVt m3q1pV7Ppl7PUi+LFFXMPsgaPMqDWYN5OzoBW878OqEvwqNKJCaqUlYVs6Hq2BqqIoaqiAuWLedf 92xTHPgpdZ2ENxFMwq+ruuLHRbe0LuqKnwHAki4csF0HA8BegYp818EguFfgxbsOnvJComzpSvsJ umhnKVSboNKJe5H+aB/ZGYDlDFcfS3breY6FdWPp6jFF1y3kvOaPMnrSz8YFh+Onrxf/Xp6HTi9N zU0H8ovMupGjNZeR//GvzZaQLpoAm3nVbFaH/Ac78buOLcEZD8IUefTxPebCJiMjtsRkAVHT8y75 x1QlFguI/icqty5r+1ryONkHkYLKbTWz5eTZqJ6e45JaqSox9IiqnlVOWltVHpcuiLpks3ZTJYYe wVZiqIIcE0OPEL1V9T5MpQvBjJCtsVqdPN7nWq9QBekbVW5HVFkLyZtYyk2qSaiqofLzanVVYqi6 j1U1GUZ/t/DIDOMClVVVNjmaKielrKri0ast2R7L42IG0ZOqZZVFih4Tg76KthKDnoOqxKAS6DEx VB11rcR5ZNV5rNGfuYXQo1eiHjn6eqzR18VjbWv0Nbe2bIS0qO6lqm3thcrQ1kb1HOMXemztPhbk sK3JsBJPc1ViGBfYSgxVb11Vk0FVNVKqakTvOYKtxFAF0XslrpYq8Zx9VU0GlZCNo3IllEGOaCsx VF3HqrqOXImrrZXw6C1HtJUYqiL6ZSlokV1uLhmrBPl9DV+8S/QYEF+4lXSRvXAu3gHazowdoNGW q/RMUO1shWoXVzpzr/Jlqp5jkI3KcwyCcV0pRxs2sq0rRe+qna1Q7eJKZ+5V8QqePpaXfEHG26Jv +Vodz/HWsbX177jeFx7/I0+Xj/2WXKHP2LsFO1Yf//wryDkWoriFW7bqfcKHHsuukBqFKTxutZDy 0CVauvSpvnOq4AMyJyx9YdtxnPP4pmNYXueKuWApLNjx9BHL6+o7f7YwC/VtbR7fdBzL60JhUZoF zoOX10F2TjQ2W9hmsdvSt8jOFseZQhfPuQU/9uycaGxqwWNXH5CdRhEKi9IscB68vO5Hb80uETge U1awvO44ylTo8rrj1DN0eZ0ew/I6U9hiObMQlW92hpM7Kcbxvzn2K8fexjbitryuygu1x/FcXmfH sbwuFHN5XVh4L/SBy+vAb/TOQfDOHvvNXF5nhG/DTnmX6bBRx086ks3ZJpmxDauJoWpufK6qA5mo SllVVeMJlZFaVtVkY3VvwZpNFTNRtbraYoaqXVzXkVWT0Jfk+OI4oc7jynueVGebLAKVXLGzys+8 3unZyO8O5w1bLauU/E9U27j4zD+p3j+o7uN+c/TGUFWXHFElm6EnW8/z4pmoesAWsz/YSux/2ZZn Hap1lzx5IlqNytydg2mT0Oe72x3lAQ0i0BzXojnY1+/6/SRfhj4LkDVztz2IZwDUxPRh6fOCfvRb J6qcvDrT9OjM1Hym3C9veiyXtzsp5sL5sGDH08c//wryqEItHPLlCT70eFxCk8KiNAuch+0LIF9o BbNzorFdcuktEbu8ZRmOx34LnJ0+qR4WWs7OicZ2pdjNR2RnUZjCo1QLKQ97jGadQl3n+1w1/nvi F5iSP0zsmi24RNgWWPV85pyf7TusYGgYheaScUhhkbHYXYtUiX05AP6w2qZXv6rppKuT8WU6M81s bKBVVhWzoeqTHB1UxEhVNqqSPB7yxH7yqAyiJ5Vsoscqta5ZT1U11WGqVpFMFTNStY3KPd6bHO8l R9nQL6uYfRhp20TfsqrXVdVr8siVaLlP3Gu96jGeckePc+sqjp7Z2IyrrDkyGxt7tTVHZqjCHJmB R8qR2VBt+gSzD7M+lkpE9K56ylqvp6R6Ha0t9VKGOYKqniV7VIKVSGyousYA7cgsNuNiFbOxzVZb K6EM4jIV2rq1T/h1QmbZgUwVM1DtbEFcbePxzS0kM+O5ryY2VB37uKp66vdOwGOo7DphMVC9mH2+ XzG3IzO0tckxKmH5cFxlUfXF411aqr2RnSriktl/+R4jj8yGqm9UPavm/mbJ49KOeh6143xdArbQ U1cVs89facoqZp+/loL7BDNUYfTMwCNVoi310khJxeyDrNEjs2+pzVS9S47vJi5j3lf1xRFUr8RE dR6ritnnr17g671+l9/yW/6D3+7376b2fJJqsrFtZ9PptBoqZjAGIFvMUDVjYI+y1pFVk9C3KHi8 yxoXM1ShR7MVlbg3cfXFlpGrrqorVDtbPXvUbyZSMYNvPvKo32BQVTsPam/fVlFV++7AqiZGqrZR NVcdq0dm8P3IcfVFVVaPzFAFlUgMPUJVE8PoUVWXuOrGlrGoV9tUoi2V0G9RVrWsejaV6DWr+tpz nEVc78bjmz3a9xeqEoPvNIwrMVRBXPadBrb0G4Y8MoNvK/LIDFXo0VVWCY8B+n1iX3wXYv9KDG3t cvT+5fmgihlGjx712yquOU52qoirbTy2xeOzqRcz+E4jj/pdCy1k50E72rdOtJB9M7HqyLbeTZ94 lz6h35jUJ5ihCqN/l3q9m3q9uV4eKagSg+9a9JjYt9RmqkrO0Ql6NOZ9VV/IxFWtuary2/6qyu2o Lz7CuMbP9v3+S1Yv1EdU4yf0fjoZqsRE1QeRrZpCxQxUT11VT/Yom1Zlj8Y+j5RUssqNo1eCqvFD vtj6dfapesaCr8fJUCWGqrZRNVPJD+1Cfh3PVYn9VEfT2oAqsQ8ibZvoW1ZBVTMDj1SJlqrqkaJK Fm5x9LWsOSb2U8kygVyvxMAW1j6xn+retNC9tJBFipVIDGxhjolB9KiSwf9zQf8ygv1eXs0+WNiS gT4QUkUlzBbWKzFQgS3dlS5EXfaD5PZJyHelIw2jn+boS0iZgQrKnln4w7gZ+W56pGH0RbLHkn/E raCVRdNKqtHv6612KtEkkBdIaq5QXbNS5N1Szs+VvnNr6D5+JEos9vaj9kgMVBCULcKJrmvLjPDC nlmoyJYx92hLgzCu9577xEUdbE84bLrMUNU2Kveou9dhvTL7fF86UiX2QaS76FtWQS/PDDxivRKD 6FH11hTXeRxjiR5Gn5mozrFED6PPDFTgMVRee4sBWygx2QGwr5VIDGztcvRKeD4UFzOIHjyexzWW OUZfNbJTRVynbJC9eLwWj3VTL2axESx7nD9dYQvpedSO7ciqtom+LdG3TfRtif7ZRP8s0c8f57C1 nUFcSsjWu/TCdxOXMu855/ipKlUisXiqg1Vnjussx9Lvz6tkj/dYO0I5JoaqtlG1UI01JxwXM1Fd mxyvJcdr/dQmBirsE4mBR6x9YhA9qeaOeBjXU9ccmYmq9bVezMAW1Z5Z7N3Hqr60kEZKlWAGtihH ZhA9qnSNEeSoK4yoEomhqm9UPVRto2p/UpVVFTmadaxEYqDCqiYGHlmVa59iENWy82CVLUfHws8g 7yC+KPGRpYEtli3qcSyNDIUuNnMLdjx9wNLI8Uxei6WRTZYGgg89hqWRrrAozQLnkZZGRnZONDZb lGix27LFyM4WNprCFj6aBT/27JxobGbBYjcfkZ1F4QqL0ixwHmlppC/azQSOh91YGvnLpkzFXBpZ 5eXx43gujbTjWBrpCqu0WYjKe1s5uZNiHP+bY79y7HMfPF8a2W6ts67r0WNYGukKXRrpFnRppPqg pZHhN3rnIPLxsLcMRb+xJ4ONDJW8IlAWwoHqWVV+5vUmW095Q/Usqud/SbWJK525V/nyT/hs6PJP VOn7HWAFkD7+yb+v6Zyi2xrvW0JD9AIm+zsuD7KlP+5oSsDLWm9YUs6OciD0K7L+Uh4ztf47vC8M youhYEkTFnrpJrmoFLa8MmLYciKvuNGlVpFcsc7kqviZzFY92pnjIeZ3tWUqSzFUO1uu2sWVztyr tkXfriK2KT2ZQKm9jkm+OY0lUyNC5lQgM1BVOa/ThKGxmHxE1XhuBVhMppEqMVDddVUp+8I6qhL7 lhjmFFIZ8xPg0cjvv1aJzGIKCeuVmUxatdVWYqDaxfW7edG4TKUEZ4jClhOoRGY+j4QOE/J5JNIw 8jkiCklRRKQA7cy3MkSdDGDQjHwGiO20FI/O9pAosZjbIXdzwgnCttOg6ex5xKc1U+lrFVCVWbzc gVSJieog61N1ZI9GMPjEwCMWIjGIHlWJxTOq6DGzb6kNTnJFjk7AozPP0Z7Lo9onFk/hkcfEQIUe V5VOvpHHxOIpPPKYGKjQo05fgS2dviKPicVEHnlMDFTo0VV2AfEY4NOaWUzRUWsnBrZ2OUbPsXwo rmNRtdWjTnLFJcLJTuVx2ft80GNmMWGWVC2r5oQZeey5Hf08aEebCovonegXLk6rocc5ycVxqcpb 221Bn8gMVGRrTkOh6ulr9MxiwoxVzGLyjeNqS/RKoKqZgUeKvi0tpJGSillMvpFHnZiKAZBN7eAX embjPqXieVPFDFQYl04mQSXMOtbLVBG9qcjWox699jpBQy2UWEwAsUdmoCKPpjo8Lo0BriaZxTQR 154Z2NrlCJXQfEjFDKJHjzr5Au1oBNtRp3bAlj4ORx5NFfUyW1jVxEBFtuZTNBjXfECOemFioNrZ gujnqzRY9UxVxHUdB5J5V3otqnlXSv0rMVGdfVUxG6qyemQGKmzHxMAj5pgYRE8qZl9kTR6ZfUtt pqouOSrBT0din78fk+NqS1xPWW0xAxXVvo95A1DpeyjJVmKoghwTG6oyCHpM7PO3VXJczD6ItG2i b1lFLcQMPFJVmUH0qKolx2Vkp4J6XZtKXLkS9eobVc+qulRieW8jPkN/EqF5k5gR2TwKtj55bNsZ 8rOu6bHZ/zCrYNvA1lfsjGdZdTtUI8NiYrFFKj7dmxmpykZVssejrR4nQ1vHsdo6jqQa77ROKmXg sfe+eFQW2+ay6jlyJZRsVRD9muN9tFQJ3eiU6pUYtjnaYgYqjCtUVi+PAaqaWGxiS1VNDGyRR2aQ I6mYYfToseZeaGSngrjqxmNdPN6bejGLjUHZ47W0o55H7fj0HP2z9tXEYptOjqsvcb1rL0xsqMYW lsljydHreRi9bpoJtozsVGFLN82kq0lisTkl22IGKszRPXpf9fOgR+tWkRC9EYwrMZixJRUzUdVj ErgWJkaqslGV7BE+24lh9Kh6WlY9G4/P4vHuq4rZUJXVIzNQYf9KDDxiOyYG0ZOK2RdZk0dm31Kb qepLjkrIFrPYu4DjYjb2QTgWW4mBCvvqTtUWj4mJ6lxrnxiosLV9Xwr/DHW5OqawCKGmrZrmmrlz AjojJJrrWDSEcOcMdFbyp8IIVYBZ+KNiEoq4SdNyTG21o5qo0bPm/+T8n75qetLoiA7SH28Sf/Ey NN4aHoRUkZqpMO7x/nS2pYRUTT16WEa2Ki/C2w88b6qYDVXbqFpWyXMNb6oEM1BBXNdRCuf4Iz3X KzNQsa3OHsN6RJ+ZqM6lEpmJ6qg5x8xABZ09M/BI0TMbqrZRtawq1LJTdS9VNXKCrbrYujdVVRXk eC+tnRmo0NYpTxF2UskTgz3Vnpmo5NnGrGImKnkesae4mIGKWogZeKRKMIPoScXsi6zRo+xVzNGf 17HkmNhQrTkmBiqqvasOU1kM0HMSG6qyib6ketl55JEZ5MhxHYtqbaHznpudRI82slNBXPIE5JM8 MhuqtlG1rJKnIrPHurSjnoftWOSJxAdbqBxloyImtt5jUSUmql7R+lQxAxVF35d6vZt6vbleFimq Evsia/SY2LfUZqpKztEIeTSV99Vybap65aqWq29UPavqUtXYAk1f3eR7sRdZ0RZgfAGe15gzCs35 vACG5pqvE/qh2+wokH2S/iqykG4evrIJe/l9NvD4H3lh4y27UbpC9kqfx8OAHw4HP70DWZL4V5wu v42A/XEo5i0A/buFp2dT+HMZX5EGnWlqTg40pLnw0CMer8htmNM5F9aFwgo3DUQdNScHMyo/fcbs 9i0nD2D+3cObZ3P4mtM1u0Udr6x5Oalj2X3Jm/6SEeN8E60SWX9mS5ESE1Vtk8haRH+rLTFQXTJt 8GfV3VePzEClkU7Vs9jqfY2LmajeusbFDFXo0VWHqZ6GhOJC1TFJhxyZoa1NjtBCfVMJZhg9eNS3 2kIlxlusU70SG11obcfEwBZWIrHP32jIKmZfRLqLPurl50ElEsPoUTXfogj9ywh5ZCaqe+PxXjy2 Y1Ux+/yNhsljyS3UqM2m6umpXvo2XKpqYqRqG5W349tWj8w+f2Miq5h9GGnbRN+yCivxLLXvm9r3 pfYaKar0zcAQl5GdCupVGp6nX4Qt25rvY2QVs8/fv8u1n285hOiNkK2+eHynLbxiJvb5uwrJVmKg okpYXF4JV0X/WscYvoLYBxm4iNi+REJl34aosi9q3/wxiCwqP2Okcci7Vs4YCegxjDRMYSMJs+DH tjFjkOeZNs3Cc7CPeQzDDVdYlGaB80gjjsjOicWmX/kWu40JIjsbNLjCqqgWoqqWnRONzS1o7O7D s/MoVOFRqoWURxp7nKUv2fmWY5vBx2Hv2wlyb/rN7f1GhxBj6ZSpmKHqav9JpcMK8sgMVWcP1bPY 0i9hiosZfDFTXMxQhR5ddfgnqCHhuEA1BxrjF2FXEUNbuxyjhfqmEswwevBoX99RCRscYL0Sg69v rFdiaAsqkRgMGEjFDAYf2+i9Xn4eVCIxjB5VOqyI/uUEPTKDwQfZuhePOmAgFTMYfLDHkluoUZvR F3PUy4YQWNXESNU2Km9H/fomj8xgKEAqZh9G2jbRt6zCSjxL7fum9n2pvUUKKhtWRFxOdqqolw40 MMfEYPBBKmYw+KDa65d89EJ9BTJdCxODocB4httUzEhVNqqSPUJciaEt6F+JoQraMTH0CLVPDIZh 1EJvSZVwslNF9GuOPnTyrZFh6MSDqfSVebQyngGThTzz9v64j0nkwztfm5cZquQyllWTfWD97K46 D72PDFu9IZm2mA2V3t3K4gZXEUNbGBczUb19VTH7INJ4gWBmaAtyTAyjx0qcOS55gjHHlRip2kZl lfCZGKhqYqIqZVUx+zDStom+ZRXWixl6xEoww+hR9SwebcYDo2eGMz2oYjZUZc2RGaowR2boEaO/ c5/wSCnHY1GtVfVZEI/L5yQgx8RwDgcr8S59wuZ+sBLMUIWVYIYeMUdmGD2oEsP5oF0l3GOqDc/h eI5O0KMx/6SVq+F5OnBr2ZYOc0jFDOeDMC5mqMK4bObCr9E+S3FDJZihCm0ZC49mHaNnhnNLqGpL JWxOCnNkhipsR2boEaNnNqIvm3qVrOrUsjSoieidHG1VefQ+7wKVSExU97GqmA1VQ+uqatmjEahX YugRKpGYqGpdVcywElivd6mEzepgjsxg/EEqZqJqfa0EM1RhJZihR8zxWXK0SFHFDIZk5JHZt9SG horxeaxnQ6Kq9icVxOW2PK5ayqqqB7baFwuGsR0TI1XbqKz2Vb6/Lm7HxERV1z6R2IeRtk30Laug 9omhR6pEbkePFFW6BBpq/9Y1R2aowqq+S1XNOo4L53g4XmViY+br7cVeeJIZqp5jVU32gfW7u0rH q2hrjobZI7MYr17jwUpXEUNbGBezGCGzitkHkba6Rt9qtgU5JobRYyXOHJeOmSmuxEjVNiqrhI5X qaqJxdiXVcw+jLRtom9ZhfVihh6xEswwelQ9i8fnWKNnFmNfVjGLcTTnyAxVmCMz9IjR37lPeKSU 47Go1qrqiBLi0rEp5ZhYjH25Eu/SJ3pfK8EMVVgJZugRc2SG0YMqsQ+y3lXCPaba4DgacnSCHo35 J01H1lxVZjHaZhWzGEdzXMxQhXE9yvwaraNHfClVZqhCW8bCo1nH6JnF2JdVbanEHDNzjsxQhe3I DD1i9MxitJ3qVbKqU8viOBqid1LbqvLodWRNlUgsxr6sYhbjaKpXYqiCeiWGHqESicVom1XMsBJY r3epRG9rjsxi7MsqZjGO5kowQxVWghl6xByfJUeLFFXMPsgaPTL7ltrgCBk+jzqOpk9tYqiCuNyW x6WjbVbVA1stxtHUjomRqm1UVnsdr1I7JhZjX1bV3Cci0raJvmUV1D4x9EiVyO3okaJqjoex9m9d c2SGKqzqu1TVrIfHWE+wrkfUWdyxUx3fILrGptlBw6eBHXjLV2YxuqJlCWwd3KGpxODWFifzcV80 fbb2ki0iiz6jq9u8nV3eGy63Jk5kh7K6/CSgF6g2lhTXeSEoSPRCUBZVn6R2UBEjVdmoSvZ4tdXj ZGjrOlZbk6Gq1FVVlhzPvno8PXqrDarmZR8rYWSngug3Oc5LIlbi3dTrzfXSnkK2EkMVxBUqr5fF gFVlNlTHWlVmaAsrwQxzRBUzjB486oUZau9kpyqhWj0mJqprUy9mceFkj2duRz8P2lEvkxi9EbTF LL5COC5mnz/zzSpmQ9U2HstkEb2dh9F3jcv7xH0WJEOVGKnaRmV9VZ/TJo+JxZcDx8Xsw0jbJvqW VViJvtT+3dT+zbX3SEGlT5BDXE52qqjXtanElSuhT5mzquZ21KfMufbtyCojUInEhmqTI7PPn+Zm FbPPnx/nntOXehk5y6o6XfVojgfkyAxzBFWTgXjBuJxAVRP7/Jlv+n5M7POnzNkWM1RBvdyj9wlX Rb18uDMGa7+v8vGQ5jV2etWtO4zggMcGAeNC9iKZrud+s6C6r/FqdVLZmbK1aC1kq4PqmWfer6uU yL6/proPVbktI2jLoghbHhfY0q8MY3EZZtWpsf4sqMpIe001vGMhzn6MaWMsRGao6htVzypNeqrk it7R1mbcFqqwpQRslbfe8kji2Z9rjgHtsdtTNrL8kd/xo8f3PG43Hv/zO+MprOhm4dVj81HnGeJ3 bhN8vmc1v0+f5NCznqbHhY7lMSnzq6Q/qnjVj/mtG78Ui/h9Ndpf1OOs92Krdhx+lXhkasEjVx+a 2/R7XH+fmG5/nwH0nP7e87DgYfg0oEHJRponZDqtU6LScShP+bBAmvLFClnqYSQ5gec4z/YUp3XK sGpVzts8XqlFr9Si19KiV2rRK7Vo3bQoM/Fb01l3atF7adE7teidWrT+sUXhg3PMNrHPzTlbzD4U 5cofm+vgj42Wyz82WlBK1j8E7tXIo277i1av40gf10zGZWA+tm9odM/ZW35f2zOZcyZruXFvQQve wW8E4sWe+g7RdVxE0g2n2fyJYHOB85EXMujlS2vuCnlq4Hf8G2VXzmyQvQJJtCN6KdpSLrE+F1be e7bDPO0LMGMjjYerWxCc/XcfwrsSKEIN+Fo0dsUFX4RAg3m9hTT2wD3YSSgewf8576FBRJqyakry 5XklhHZ+f8h2BkLNURfNkfKK3BP6ohhUn55qqGCniZhzXrEIUzfRhw/AXV4kIzTd8h5Ul3yzNVbJ ayiPGz6zQeYl6Xd86vE7j88Lj/+R18LepKi/Tz1a8GO/eDi5n2nTLNwH+5jH4sOiMIVFaRY4j/mE x1WPnJ0Ti+3g7K43Z3fJ93ADhVVRLURVLTsnGptb0Njdh2fnUajCo1QLKQ/N7p4vRz7lUpOzO9YL ofcI66zRReKDyujzN2njh5ARauJDuGrm+7fJFyHQwAdMX4UNdnpf4iEUb8umeAiBBn25Ri8K7jwu HIyG5pggLhyMwM4mr2iLvuZOCPMKX/qi68hd35iN9WE0uknL9WGEdiJ3RqIpddGUVEMPcBOz1cdO gtwZQcyoqdrbrf84AF+E4h0eZOfOvubbvUlDKN73zb5ynduxtMXTuT76Lm6sISPStFVj7fW2xReh eK84aQh9GGBbY25JA7k/uc59rXPPdX6XNr3PFI+BncbrU5bcGY03dpf5FQkaQvFWb6pzbxNZH2tH BTA0jOKt0ji4YUSasmpK8hXxMEI70X8YoSbaixH4gjoz+qIY2BZv4dwN7DQe85LXsn3sGBxff5hc su3S//MUVHzznc+j8x+XTuc4qRKm/pIlISdVPyaRQHXexG1N9icVsy+so0dpIVZJHbOtLj+Adj/z C6KRkiqi7zKzL0T6k6mYoQo9rqrnWD0yAxXlKD+dkmpsK5NsJTZUmo98YlxFjFRloyrZI+SYGNqS z82VbE2GKvnkZNVk4BErkdgXteF69VxVJVsVRL/kGJ8qGYIWml50cg1yXvKotBzXcx638VY1O5Z3 z91ETvnJcRybBTuePsYZSk5TqIVjhBg+5rGcYVGYwqI0C5yHvt9O5mbLidk50dju65zHGrvcTsDx z/N9JsVR2YIde3ZONDa3oLG7D8/OozCFRWkWOA/NTnfb/tFbs0sEjpsc/xcofkOSobiOeXzrGWfF Y6n820nhlVYLUflmZzhJZ8zjf3PsV479eEYN6j1bXGfaz/qMbQHs+Oen9hfJKUOfWcVHjy+t2jUj G+9zrNoXzW/0zssnt2UKO/WbeiBJXyO67/1533b5uVqbBCbWE0MVXMrcll/KdHd8Vs094eFi4OTe qCKut02CcTGLPfRJldjnb/Yjj4mhCi7qiaFHyDExjJ4q0RbVsXhc67WNvrSsMrJTRY5zv3yuFzPo 4aRiJqp7bcfEUIVVvZcczTpWlRlGjypm31KbP9VrF/3b5+c0bBm5y6q67ctZvloHgXolJqpSFluJ oaps4vp9tpNqkmmrD9W4uSjjhQR6dTCCV4yNSm6AskrZF9a3KunZqipIhqodx/QoV72hMoK2nEn/ nyp5D4mfNkWEhqavmp40ciVNIRECDQYklzfS3HXxRUg0dY255pjlsfQUDyHQ9LpoemVfFDOhoemr pieNJXrk3CFm1Txlqc9TuD4yrZDqowjyQk2fNfT+aOCAmJ8c83sseakmatjXdu+53fvS7s+R+o+C jSb66lOO3O6MhqatmpY0V8kxMwINxlNriqeNWzVq1MRI1TYq99fGc10cODNR3ceqYvZBoG2NvSUN 9H1G4I2KwAwiB1XcUCyrPje/1PlNuTyLceFLXsZTI9fDqkPu+PEVuuV4Bpmq+Ya8sdr1Gq8rH5t3 CPl9B7mtP6t+3yhmKy10iJW2tPQhnfmFdXkGLcelbB99/oXyW36emRMl+YedsdqWS8pJQ1Dn78tD y7Auq5mGKDs+7Q9ts6xKSUPm/8GDbVOpqf0wusv7hB5IQV+/Ws7mjhPyV72ShpG/MhY7REKoKaum JF+1Lb4mgphBw+iLRH/DDNcQAs1VF431YTdc+uKr9BQzaBhB7uDrzjW8VzuGPGZ97ywVMbF4hS2r elbJSvJBoJCJoQrC0nfFgi0nkGBi8kbZstpKLN47y6qeVK8MU1uhJg5mcQUJW/auWFA52ams9vbG V6xqZvF+V1LVJa7azHoLFTNUQVy2BtD7TZCofWbxtlWylVi8bZVVLatksJw96vtdIUc/LyoR32K/ bz154SF8QTm5BjlPmaKS43rO45uO/5EXaSZFPdiCHU8f4wwl5wg8LBxtHt90LGe0pLAozQLnoRNH sqvl77oM2TnR2GRXyHGssV8nHcskz8GK8lay4MeenRONzS1o7O7Ds/MoTGFRmgXOQ7Mbj7YMemt2 icBxk+P/AsVvpD8URVvi1jNkSi+OpfJy4wYKr7RaiMo3O8NJOmMe/5tjv3LsxzNyLnVMjdqX8Vna hcdS5+dlxVvYwnuhjzEtpm/iA7/ROweZ3+d3zf1mvojSSJoWO/u0EWMSfeUpfltnhqr4mIet4rbm y1JJpS8SBZWT+Jhn9vnrRimuxET1HKstZqjaxWWX61DFF4TtnRfTKfaIJk66ZBYPq+LkRmakKhtV yR7j14LM0Fb8IpIZquIXkczAI/yKkdkXtSFVOXIllGxVEP0mx/moLVaiberVlnrpcnayxQxUFJer vF4WA1aVWTzlxVVlBrbIIzPIkVTMMEf0+C690MhOFXG9G49v9mgL6FGV2OcPzLLHntvRzsN21Geu IHonYCsxWMZPcV1LXHXthYnFI63JY8nR63kU/XwyC/qEPoZKPScxUkVfTSyezGKPzOJZMFYx+zDS tom+ZRVWghl4pKoyg+hJ9S5xvRtbpvJ66dNUlGNi8VwZq5h9/mZPqsR9HVllBCqRWDyZRdEnFk9m sYrZ52/opJ7jLOK6rV5lUSmLp7zO+vsMhkdikCOq2jGeNILPY5OrNv/ckNlQtUngmy8xUpWNqmSP 0EKJoS2oV2KognZMDDxiCyX2RW1IJYvIuRJKtiqIfslxvemJ+TYn9yB+u3G0cx7fdAw3Pa7QYaRb sOPpA256ZCZsKtRCaexjHsNNjyssSrPAeaSbnsjOicZmtxsWu92QRHZ2y2IKu6UxC37s2TnR2NyC xu4+PDuPwhQWpVngPNJNz1FvzS4ROB524aZH9u8aCr3pOR49Q2969BhuekzhlVYLUXlvKyfpjHn8 b479yrGXZ0aiNz3HqXXWmx49hpseV+hNj1vQmx71QTc94Td65+XzuHbTA/1Gb3qU8E3P70ZgvJTg N7C/5lD/dwNxKnl9qJ8Yqk73HbZOjbBI388q3U1o7Ed26Ttgxt44Y/b64jeyGPt8K3hWMft8vySz PlXMSFU2qpI8wjx5ZhA9qZh9kHU/1kr0I6ueuqqemj22vnpsPUePKmZYCfTYjhxXr2v0zEjVNiqv xNPX2jP7fFclVjH7MNK2ib5l1S7HqKpZx3oxw+hBpdvpQy8crwFLfTUxUO1shUe9lWTVvCWE2uvN ErVQYqRqG1Vz1TEJ1D6xuF1mFbMPI22b6FtWQQslhh6pEsQwelS9i8fe1uiZxa0kq5jFbSnnyAxV mCMz9IjRM8PoUcXsg6zBo96EQi80slNFXLpVB3lM7PMbQlYxi5tX9njkqvp5UHu9gYKq6o0Xq5jF zSuram5tvXmldkwMVRh9XepVN/WqS70sUlQx+yBr9MjsW2qDN8KYoxH0aMyvE7qhB9erL1V966pi Nm5LjyUu+9bxyUr/loMpTdvVEFVGYrLSv2H8lx6/RsPEZ2ZwvScVM/jugN+WMkPVVVfVVbNHjJ4Z Ro8qZvBdSx6ZfUtt6LoatpxAJRL7fFMnaqHE4BuGbDFDFeToHm3SOVQ46axXTLBlBG0Z8xayayjF xezzrZm4XsxQhR43qk0l+lKJt6wemaEKPNoVM2w52ancln8DQFyJwfUe40oMVehxVZW1fyUG3wrk seR2dIIe65F6jl0LseckRqq2UblHvR5T9Mzgek+qmls7Im2b6FtWwWc7MfRIlSCG0aNqTqLCp9YJ emQG3wpsixh8K5CKGXwrkEf9HoJ62XlQVZ2shHbUyURq7cRI1Taq5qpj9cgspkdTXLlPRKRtE33L KqhEYugRqpoYRo+qusRVN7aMRb3aphJtqURrG1VuR93KiitRbTxh4xyd7qW7psQwR1Qx+3yDMJoH SIxUZaMqySOOYBKD6EnFDGqP92mJoeqpq8pHfG4dxnKJYfSoYoaVQI/a2lAJIztVxNXWMWZi0CfI FjNUYb02qnUcndjnm6Cxx57H0U6gT+jUNPQvI9i/dOobPOoCRorLVd4n3Bb0nMRQhbauJS4lmGNi n2+7xraYieo+VhWzzzdZSx41R+85fh5WVUY1J+Uo46MzqZiJ6qmrLWaiapuqtqWqbVOvttTr2dTr WeplkaKK2QdZg8dHRmkntqMRtOXMrxPPudYrMVGVsqqYDVXH1lBVTy3kJOJaH3qWQK/xiIoR+VBd
April 04, 2018 - April 25, 2018
AeroElectric-Archive.digest.vol-oh
