AeroElectric-Archive.digest.vol-oj
May 09, 2018 - May 21, 2018
      As for antenna grounding, I would stick with the manufacturer's
      instructions. For example:
      >From COMANT
      Aircraft Skin Surface and Mounting Preparation
      The electrical bonding of the antenna to the aircraft ground is highly
      important. If this is not done properly, antenna performance
      characteristics may become distorted and nulls may appear in the antenna
      radiation pattern. This, in turn, may cause erratic navigational readings
      or signal drop out. The electrical bonding of the antennas to the aircraft
      skin is best accomplished by direct *metal-to metal contact of the antenna
      base to the aircraft skin*. To accomplish this, *the aircraft paint in the
      mounting area will need to be removed* and the surface alodined to protect
      aluminum against corrosion. An alternate method for providing electrical
      bonding is through the mounting screws, which attach to a backing plate
      inside the aircraft skin. Remove any interior paint in the area where the
      backing plate is placed to assure a good ground. Coat this area with
      alodine to minimize corrosion. To test the electrical bonding of the blade
      to the aircraft, a reading of .003 ohms between the antenna base plate and
      ground should be achieved.
      >From RAMI
      CLEAN METAL SURFACE FOR GOOD GROUND CONNECTION
      =8B
      On Wed, May 9, 2018 at 8:00 AM, FLYaDIVE  wrote:
      > I'm not  sure who asked the question...
      > You DO NOT remove paint from  the exterior of the plane.
      > You do need a GOOD electrical connection between the antenna and the plan
      e
      > to create a Ground Plane.
      > I have found many antennas be painted or powder coated which
      > reduces/elininates the electrical contact area.
      > My trick is to make sure the Mounting Hole Area of the antenna makes a
      > good electrical ground connection with the Screws.
      > To do this I remove the paint INSIDE of the screw counter-sink.  I do thi
      s
      > with a 100 deg counter-sink tool.
      > The next part of the trick to to make the through hole on the Plane a nic
      e
      > small tight fit so the screw has to be SCREWED into/through the skin.
      > As for the interior primer...  It is a Paint primer or Chem-Film Primer?
      > Paint - YES, it has to be removed ONLY in the area around screws.  NOT th
      e
      > entire area.
      > Chem-Film - NO, it does not have to be remove UNLESS it is VERY dark in
      > color.  Darker Chem-Film can be insulation.
      > Not sure which level you have?  REMOVE IT!  Using Scotch Brite.  Again,
      > you only need the area around the screw for the diameter of the washer/lo
      ck
      > washer.
      > You can do a simple check to the quality of your work by taking a
      > resistance reading from the antenna to a remote part of the plane.  ZERO
      > OHMS is what you are looking  for.
      > After you are all done with the mounting and testing you can paint over
      > the external screw heads sealing off moisture.
      > As for the area around the external antenna mount...  Do what the
      > manufacture recommends - gasket and/or RTV.
      > I like using RTV as a sealant even with a gasket.
      > Barry
      > On Tue, May 8, 2018 at 12:42 PM, Robert L. Nuckolls, III <
      > nuckolls.bob(at)aeroelectric.com> wrote:
      >> At 10:04 AM 5/8/2018, you wrote:
      >> I am installing two new antennae - one Comant 122 for comm and one
      >> standard ball tipped 3 inch transponder=type for an Echo UAT.
      >> I am retaining two older antennae - one comm and one transponder.  The
      >> real estate for mounting is limited since they are all mounted on the
      >> fuselage underside of an RV-8.  I should be able to come close to the
      >> desired one meter separation between all antennae.
      >> My question is - do I need to remove exterior paint and interior primer
      >> paint at the mounting location of the new antennae?  Or is the mounting
      >> screw contact sufficient to connect with the ground plane?  I will, of
      >> course, have a doubler for mounting each antenna.
      >> Thanks
      >> Stan Sutterfield
      >> https://goo.gl/skAS8R
      >>   Bob . . .
Date: May 09, 2018
Subject: Re: Faston / Aveo Tab Terminals
I have seen these referred to as "relay terminals." I think they might be categorized that way on Mouser. On Wed, May 9, 2018 at 5:35 AM, Charlie England wrote: > I've got (or had; not sure) a string of those in a junk box somewhere that > I bought when I was roughly college age & didn't know better, about 45 > years ago. I have no desire to locate them again. :-) Similar products I > found talk about 'low insertion force', which is kinda bothersome; makes me > question whether they will stay tight enough to avoid fretting and > corrosion if they remain loose enough to move under vibration. Plus you > need a dedicated crimper for those. > > Have you tried a regular Faston terminal on your widget? The specs > indicate that they fit a typical 1/4" blade terminal. If you can slip a > standard Faston in the body of your widget, and you properly support the > wire leaving the widget, there's an unmeasurably small risk of one coming > off, regardless of the 'latch' feature. > > FWIW... > > Charlie > > On Tue, May 8, 2018 at 10:22 PM, Art Zemon wrote: > >> Folks, >> >> Does Digikey (or anyone) sell these terminals? http://www.aircraft >> spruce.com/catalog/elpages/aveotabterminals.php >> They are regular Faston terminals but have a little tab on the bottom to >> keep them from slipping out of a plastic housing. >> >> >> Thanks, >> -- Art Z. >> >> -- >> https://CheerfulCurmudgeon.com/ >> >> *"If I am not for myself, who is for me? And if I am only for myself, >> what am I? And if not now, when?" Hillel* >> > > ________________________________________________________________________________
Subject: Re: New Antennae
Date: May 09, 2018
Excellent info. Thanks to everyone. Stan Sutterfield Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479989#479989 ________________________________________________________________________________
Date: May 09, 2018
Sebastien: So, how does my instructions differ from the manufactures? >From your re-post of there instructions their very first line states: "Th e electrical bonding of the antenna to the aircraft ground is highly important." Electrical Bonding! Of course the good physical bonding is done by the four (4) mounting screws . What you have to realize the Manufacture is ONLY interested in THEIR part and involvement and will tell you what is in their extreme in covering their ars! They don't care about your paint job! Also, many of the mounting bases come with a rubber gasket to keep moisture out. So, what happens to the BARE aluminum under the rubber gasket? Or better yet, what happens to the electrical bonding under the gasket? The answer is ABSOLUTELY NOTHING! Nothing electrical!!! Nothing since the electrical ground bonding happens at the screw holes. NOW! Let's talk a composite plane... There you have to make a Ground Plane. But, that is accomplished by a metal plate UNDER, which can be considered INSIDE the skin of the plane. SO! How does that differ from leaving the paint ON the plane, counter-boring the INSULATED screws holes on the antenna - Making the screws contact the skin by screwing snugly through the skin and finishing with a doubler, washers, star-washers and a locking nut? Oh, notice on the Manufacture's instructions they use a counter-sink washer? What is that washer made of? Steel. Why do they use the counter-sink washer? To cut into the paint/power coating. What happens when you mix Steel, Aluminum and Stainless Steel and Water? Corrosion. Add a little SOAP and/or SALT and you have Galvanic Action. What else happens when you have the SPACE between the Screw and the Antenna? You just created an access point for the elements. Take a look at older planes on the flightline. You will notice the BASE of the antennas; the paint/powder coating is peeling up? What do you think caused that? Read all above. Also, the Manufacture's last capitalized line reads: CLEAN METAL SURFACE FOR GOOD GROUND CONNECTION and is repeated again with RED underlining. It does NOT say the entire area under the antenna. Barry On Wed, May 9, 2018 at 12:54 PM, Sebastien wrote: > Barry, default text size setting should be normal, yours is set to large. > Normal is fine for most of us and for anyone that needs larger can do so at > their end. > > As for antenna grounding, I would stick with the manufacturer's > instructions. For example: > > From COMANT > > Aircraft Skin Surface and Mounting Preparation > The electrical bonding of the antenna to the aircraft ground is highly > important. If this is not done properly, antenna performance > characteristics may become distorted and nulls may appear in the antenna > radiation pattern. This, in turn, may cause erratic navigational readings > or signal drop out. The electrical bonding of the antennas to the aircraf t > skin is best accomplished by direct *metal-to metal contact of the > antenna base to the aircraft skin*. To accomplish this, *the aircraft > paint in the mounting area will need to be removed* and the surface > alodined to protect aluminum against corrosion. An alternate method for > providing electrical bonding is through the mounting screws, which attach > to a backing plate inside the aircraft skin. Remove any interior paint in > the area where the backing plate is placed to assure a good ground. Coat > this area with alodine to minimize corrosion. To test the electrical > bonding of the blade to the aircraft, a reading of .003 ohms between the > antenna base plate and ground should be achieved. > > From RAMI > > CLEAN METAL SURFACE FOR GOOD GROUND CONNECTION > > > =8B > > On Wed, May 9, 2018 at 8:00 AM, FLYaDIVE wrote: > >> I'm not sure who asked the question... >> >> You DO NOT remove paint from the exterior of the plane. >> You do need a GOOD electrical connection between the antenna and the >> plane to create a Ground Plane. >> I have found many antennas be painted or powder coated which >> reduces/elininates the electrical contact area. >> My trick is to make sure the Mounting Hole Area of the antenna makes a >> good electrical ground connection with the Screws. >> To do this I remove the paint INSIDE of the screw counter-sink. I do >> this with a 100 deg counter-sink tool. >> The next part of the trick to to make the through hole on the Plane a >> nice small tight fit so the screw has to be SCREWED into/through the ski n. >> As for the interior primer... It is a Paint primer or Chem-Film Primer? >> Paint - YES, it has to be removed ONLY in the area around screws. NOT >> the entire area. >> Chem-Film - NO, it does not have to be remove UNLESS it is VERY dark in >> color. Darker Chem-Film can be insulation. >> Not sure which level you have? REMOVE IT! Using Scotch Brite. Again, >> you only need the area around the screw for the diameter of the washer/l ock >> washer. >> You can do a simple check to the quality of your work by taking a >> resistance reading from the antenna to a remote part of the plane. ZERO >> OHMS is what you are looking for. >> After you are all done with the mounting and testing you can paint over >> the external screw heads sealing off moisture. >> As for the area around the external antenna mount... Do what the >> manufacture recommends - gasket and/or RTV. >> I like using RTV as a sealant even with a gasket. >> >> Barry >> >> >> On Tue, May 8, 2018 at 12:42 PM, Robert L. Nuckolls, III < >> nuckolls.bob(at)aeroelectric.com> wrote: >> >>> At 10:04 AM 5/8/2018, you wrote: >>> >>> I am installing two new antennae - one Comant 122 for comm and one >>> standard ball tipped 3 inch transponder=type for an Echo UAT. >>> I am retaining two older antennae - one comm and one transponder. The >>> real estate for mounting is limited since they are all mounted on the >>> fuselage underside of an RV-8. I should be able to come close to the >>> desired one meter separation between all antennae. >>> My question is - do I need to remove exterior paint and interior primer >>> paint at the mounting location of the new antennae? Or is the mounting >>> screw contact sufficient to connect with the ground plane? I will, of >>> course, have a doubler for mounting each antenna. >>> Thanks >>> Stan Sutterfield >>> >>> >>> >>> >>> https://goo.gl/skAS8R >>> >>> >>> Bob . . . >>> >> >> > ________________________________________________________________________________
Date: May 09, 2018
Yes the tin plated version works well in many nylon shells for relays and even older ND alternators. In the past I've purchased as few as 10 at a time from digi-key. Where feasible I prefer to toss the nylon shell and use PIDG connectors which I find easier to satisfactorily crimp. especially with the thin insulation on milspec wire. Ken On 09/05/2018 1:47 PM, Ken Ryan wrote: > I have seen these referred to as "relay terminals." I think they might > be categorized that way on Mouser. > > On Wed, May 9, 2018 at 5:35 AM, Charlie England > wrote: > > I've got (or had; not sure) a string of those in a junk box > somewhere that I bought when I was roughly college age & didn't > know better, about 45 years ago. I have no desire to locate them > again. :-) Similar products I found talk about 'low insertion > force', which is kinda bothersome; makes me question whether they > will stay tight enough to avoid fretting and corrosion if they > remain loose enough to move under vibration. Plus you need a > dedicated crimper for those. > > Have you tried a regular Faston terminal on your widget? The specs > indicate that they fit a typical 1/4" blade terminal. If you can > slip a standard Faston in the body of your widget, and you > properly support the wire leaving the widget, there's an > unmeasurably small risk of one coming off, regardless of the > 'latch' feature. > > FWIW... > > Charlie > > On Tue, May 8, 2018 at 10:22 PM, Art Zemon > wrote: > > Folks, > > Does Digikey (or anyone) sell these terminals? > http://www.aircraftspruce.com/catalog/elpages/aveotabterminals.php > <http://www.aircraftspruce.com/catalog/elpages/aveotabterminals.php> > They are regular Faston terminals but have a little tab on the > bottom to keep them from slipping out of a plastic housing. > > > Thanks, > -- Art Z. > > -- > https://CheerfulCurmudgeon.com/ > > /"If I am not for myself, who is for me? And if I am only for > myself, what am I? And if not now, when?" Hillel/ > > ________________________________________________________________________________
Date: May 09, 2018
Barry has the technique correct. I don't know why Comant even recites the paint removal method. Removing aircraft exterior paint for grounding is just asking for corrosion. Read their alternate method included in your quote. Normally one fabricates a doubler plate to go on the inside of the skin. Nutplates are riveted to the doubler. You can scuff the inside skin for grounding, or you can just use 4-6 rivets to flush rivet the doubler to the aircraft skin. Either way, the ground path is through the screws and the doubler should make good ground contact to the screws and the airframe. That is the technique I used for both of the CI-122s I have on my RV, and get excellent reception and no complaints on transmit. Kelly A&P/IA On 5/9/2018 9:54 AM, Sebastien wrote: > Barry, default text size setting should be normal, yours is set to > large. Normal is fine for most of us and for anyone that needs larger > can do so at their end. > > As for antenna grounding, I would stick with the manufacturer's > instructions. For example: > > From COMANT > > An alternate > method for providing electrical bonding is through the mounting screws, > which attach to a backing plate inside the aircraft skin. Remove any > interior paint in the area where the backing plate is placed to assure a > good ground. Coat this area with alodine to minimize corrosion. To test > the electrical bonding of the blade to the aircraft, a reading of .003 > ohms between the antenna base plate and ground should be achieved. > > From RAMI > > CLEAN METAL SURFACE FOR GOOD GROUND CONNECTION > ________________________________________________________________________________
Date: May 09, 2018
Subject: Re: Bus bar materials
> >That's good to know. I have a whole boatload of scrap aluminum. > >When you say "dope," do you mean dielectric >grease like this:=C2 >https://www.homedepot.com/p/CRC-3-3-oz-Technician-Grade-Diel ectric-Grease-05113/206843029 >? I checked the SDS on this stuff . . . it's a very close cousin to the Dow Corning product I mentioned. It would be fine. Bob . . . ________________________________________________________________________________
Date: May 09, 2018
Subject: Re: Anybody using Shorai batteries/BMS?
What did you have charging this battery, Allan?=C2- What sort of environm ent did it live in?Like any other technology, these batteries have their be nefits and caveats.=C2- Without more information, it is as easy to say, " Allan didn't install it properly" as it is to say "Shorai sux!" Two thing that are on the short list of not to do with a lithium battery:1) Install in a high temp environment.2) Charge with a source that produces s pikes larger than 16V. On Tuesday, May 8, 2018 8:07 PM, Allan Aaron wrote: For what its worth, I had a Shorai, lasted 6 months of light duty use then started bulging and died.=C2- Since it failed more than 12 months after p urchase, the vendor would not replace it.=C2- I bought an EarthX and it h as been great. I wouldn't touch another Shorai.=C2- Allan ________________________________________________________________________________
Date: May 09, 2018
Art: I have got to ask... Are you building your experimental to any specific specs? As an Experimental Builder, yes, you are allowed to experiment all different practices. But, I see no reason why all your wiring should not be the Best current practice. Those type connectors are very ancient and have all sorts of issues... Sharp Edges UN-INSULATED Grip Support of the wire insulation. No universal manufacturing procedures. Example Not Mil-Spec. Un-Acceptable Certified Design (FAA, AC 43.13) Yes, I know you are experimental. Why would you want to use something from the dark ages? Barry On Tue, May 8, 2018 at 11:22 PM, Art Zemon wrote: > Folks, > > Does Digikey (or anyone) sell these terminals? http://www. > aircraftspruce.com/catalog/elpages/aveotabterminals.php > They are regular Faston terminals but have a little tab on the bottom to > keep them from slipping out of a plastic housing. > > > Thanks, > -- Art Z. > > -- > https://CheerfulCurmudgeon.com/ > > *"If I am not for myself, who is for me? And if I am only for myself, what > am I? And if not now, when?" Hillel* > ________________________________________________________________________________
Date: May 09, 2018
At 09:34 AM 5/9/2018, you wrote: >Art: > >The term is Electrical DUCK Grease; it is just the opposite of >Dielectric Grease. We're talking different materials that serve two different purposes. There are useful materials to add to joints in rigid components common to high power technologies like submarines, sub-stations etc. These not only exclude moisture, they contain electrically conductive enhancements for crossing voids that cannot be closed with tension in the bolts. Then there are treatments intended to fill tiny gaps between mated surfaces to prevent ingress of water/oxygen that progressively degrades the joint. I have a tube of Dow Corning DC4 that has lasted about 40 years . . . it doesn't take much. It's used to thinly coat mating surfaces of DUCTILE terminals. Any DC4 caught in the squash on the two metals is simply extruded out. But the tiniest voids in the interface will remain completely filled with DC4. Other, non-reactive materials would work too. Axle grease is better than nothing. The CRC product cited is good. Bob . . . ________________________________________________________________________________
Date: May 09, 2018
>Also, the Manufacture's last capitalized=C2 line >reads:=C2 CLEAN METAL SURFACE FOR GOOD GROUND CONNECTION >and is repeated again with RED underlining. >It does NOT say the entire area under the antenna. Which is what the 'bonding circles' around the screw holes are about along with maximizing compression of the various layers at each joint. These make up gas-tight interfaces that will repel oxygen/moisture. Again, another good place for a bit of DC-4 around the hole before bolting the antenna down. Our readers don't have bonding meters and have generally done well without them. I used to offer one and we did sell about a dozen . . . https://goo.gl/1X6S6b They're based on this article I did originally for Raytheon-Beech field techs. https://goo.gl/grXUex To be sure, tens of thousands of antennas have been installed with the gaskets . . . but if you're interested in MAINTAINING mate up forces in the mounting bolts, sticking any 'squishy' stuff in the gap tends to degrade those forces with age. Bob . . . ________________________________________________________________________________
Date: May 09, 2018
educate me.... why is uninsulated bad? What=99s the problem with the wrapover insulation support? On May 9, 2018, at 17:11, FLYaDIVE wrote: Art: I have got to ask... Are you building your experimental to any specific spe cs? As an Experimental Builder, yes, you are allowed to experiment all different practices. But, I see no reason why all your wiring should not be the Best current prac tice. Those type connectors are very ancient and have all sorts of issues... Sharp Edges UN-INSULATED Grip Support of the wire insulation. No universal manufacturing procedures. Example Not Mil-Spec. Un-Acceptable Certified Design (FAA, AC 43.13) Yes, I know you are experimen tal. Why would you want to use something from the dark ages? Barry > On Tue, May 8, 2018 at 11:22 PM, Art Zemon wrote: > Folks, > > Does Digikey (or anyone) sell these terminals? http://www.aircraftspruce.c om/catalog/elpages/aveotabterminals.php > They are regular Faston terminals but have a little tab on the bottom to k eep them from slipping out of a plastic housing. > > > Thanks, > -- Art Z. > > -- > https://CheerfulCurmudgeon.com/ > > "If I am not for myself, who is for me? And if I am only for myself, what a m I? And if not now, when?" Hillel ________________________________________________________________________________
Date: May 09, 2018
These particular terminals are used in conjunction with some form of plastic housing that mates with other devices . . . like the skinny-wire connections on the back of an alternator. The purpose of the barb on the back is to retain the terminal in its housing. >[] > > These terminals do have both wire-grip and insulation support. On the downside, they are not plated hence prone to corrosion. If the terminals you're considering are made by AMP or similar source, they're probably a suitable alloy. Terminals of unknown pedigree may be thinner/softer which risks compromising the gas-tight interface with the mating tab. https://goo.gl/8hZ2ep These are, of course, applied with b-crimp tools as described. https://goo.gl/RJuZOf The AMP PIDG series of fast-on tabs have a stellar track record for fast-on interconnections. Further, they install with ratchet handled tooling. I'd sure stick with PIDG unless there's a compelling reason to do otherwise. Bob . . . ________________________________________________________________________________
Subject: Anybody using Shorai batteries/BMS?
Date: May 09, 2018
SSBoYXZlIG15IGJhdHRlcnkgbW91bnRlZCBvbiBteSBTYWZhcmkgaGVsaWNvcHRlci4gIEl0cyBv dXRzaWRlIG5lYXIgdGhlIGVuZ2luZSAobHljb21pbmcgTzMyMCkgd2l0aCBhIEImQyBhbHRlcm5h dG9yLiAgQWxsIEkgY2FuIHRlbGwgeW91IGlzIHRoYXQgaXQgc2F0IGZvciBhcm91bmQgNiBtb250 aHMgd2hpbGUgSSB3YXMgZmluaXNoaW5nIHRoZSBoZWxpIG9mZiB0aGVuIGxpZ2h0bHkgdXNlZCBm b3IgYW5vdGhlciA2IG1vbnRocyBiZWZvcmUgaXQgZmFpbGVkLiAgSSByZXBsYWNlZCBpdCB3aXRo IGFuIEVhcnRoWCAoZHJvcCBpbiByZXBsYWNlbWVudCkgYW5kIHRoYXQgaGFzIGJlZW4gcGVyZm9y bWluZyBncmVhdCBmb3IgdGhlIHBhc3QgMTggbW9udGhzLiAgU29ycnksIGNhbuKAmXQgZ2l2ZSB5 b3UgbXVjaCBtb3JlIHRoYW4gdGhhdC4gRXhjZXB0LCBJIHdvdWxkbuKAmXQgdXNlIGFub3RoZXIg U2hvcmFpIGlmIHlvdSBnYXZlIGl0IHRvIG1lLg0KQ2hlZXJzDQpBbGxhbg0KDQpGcm9tOiBvd25l ci1hZXJvZWxlY3RyaWMtbGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbSA8b3duZXItYWVyb2VsZWN0 cmljLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb20+IE9uIEJlaGFsZiBPZiBFcm5lc3QgQ2hyaXN0 bGV5DQpTZW50OiBUaHVyc2RheSwgMTAgTWF5IDIwMTggNzowNiBBTQ0KVG86IGFlcm9lbGVjdHJp Yy1saXN0QG1hdHJvbmljcy5jb20NClN1YmplY3Q6IFJlOiBBZXJvRWxlY3RyaWMtTGlzdDogQW55 Ym9keSB1c2luZyBTaG9yYWkgYmF0dGVyaWVzL0JNUz8NCg0KV2hhdCBkaWQgeW91IGhhdmUgY2hh cmdpbmcgdGhpcyBiYXR0ZXJ5LCBBbGxhbj8gIFdoYXQgc29ydCBvZiBlbnZpcm9ubWVudCBkaWQg aXQgbGl2ZSBpbj8NCkxpa2UgYW55IG90aGVyIHRlY2hub2xvZ3ksIHRoZXNlIGJhdHRlcmllcyBo YXZlIHRoZWlyIGJlbmVmaXRzIGFuZCBjYXZlYXRzLiAgV2l0aG91dCBtb3JlIGluZm9ybWF0aW9u LCBpdCBpcyBhcyBlYXN5IHRvIHNheSwgIkFsbGFuIGRpZG4ndCBpbnN0YWxsIGl0IHByb3Blcmx5 IiBhcyBpdCBpcyB0byBzYXkgIlNob3JhaSBzdXghIg0KDQpUd28gdGhpbmcgdGhhdCBhcmUgb24g dGhlIHNob3J0IGxpc3Qgb2Ygbm90IHRvIGRvIHdpdGggYSBsaXRoaXVtIGJhdHRlcnk6DQoxKSBJ bnN0YWxsIGluIGEgaGlnaCB0ZW1wIGVudmlyb25tZW50Lg0KMikgQ2hhcmdlIHdpdGggYSBzb3Vy Y2UgdGhhdCBwcm9kdWNlcyBzcGlrZXMgbGFyZ2VyIHRoYW4gMTZWLg0KDQpPbiBUdWVzZGF5LCBN YXkgOCwgMjAxOCA4OjA3IFBNLCBBbGxhbiBBYXJvbiA8YWFhcm9uQHR2cC5jb20uYXU8bWFpbHRv OmFhYXJvbkB0dnAuY29tLmF1Pj4gd3JvdGU6DQoNCi0tPiBBZXJvRWxlY3RyaWMtTGlzdCBtZXNz YWdlIHBvc3RlZCBieTogQWxsYW4gQWFyb24gPGFhYXJvbkB0dnAuY29tLmF1PG1haWx0bzphYWFy b25AdHZwLmNvbS5hdT4+DQoNCkZvciB3aGF0IGl0cyB3b3J0aCwgSSBoYWQgYSBTaG9yYWksIGxh c3RlZCA2IG1vbnRocyBvZiBsaWdodCBkdXR5IHVzZSB0aGVuIHN0YXJ0ZWQgYnVsZ2luZyBhbmQg ZGllZC4gIFNpbmNlIGl0IGZhaWxlZCBtb3JlIHRoYW4gMTIgbW9udGhzIGFmdGVyIHB1cmNoYXNl LCB0aGUgdmVuZG9yIHdvdWxkIG5vdCByZXBsYWNlIGl0LiAgSSBib3VnaHQgYW4gRWFydGhYIGFu ZCBpdCBoYXMgYmVlbiBncmVhdC4gSSB3b3VsZG4ndCB0b3VjaCBhbm90aGVyIFNob3JhaS4NCkFs bGFuDQoNCg= ________________________________________________________________________________
Date: May 09, 2018
Bob, Thanks for the info. I will opt for the CRC from the local Home Depot instead of paying shipping for DC4. Cheers, -- Art Z. On Wed, May 9, 2018 at 4:27 PM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 09:34 AM 5/9/2018, you wrote: > > Art: > > The term is Electrical DUCK Grease; it is just the opposite of Dielectric > Grease. > > > We're talking different materials that serve > two different purposes. There are useful materials to > add to joints in rigid components common to high > power technologies like submarines, sub-stations > etc. These not only exclude moisture, they contain > electrically conductive enhancements for crossing > voids that cannot be closed with tension in the > bolts. > > Then there are treatments intended to fill tiny gaps > between mated surfaces to prevent ingress of water/oxygen > that progressively degrades the joint. I have a tube > of Dow Corning DC4 that has lasted about 40 years > . . . it doesn't take much. It's used to thinly coat > mating surfaces of DUCTILE terminals. Any DC4 caught > in the squash on the two metals is simply extruded out. > But the tiniest voids in the interface will remain > completely filled with DC4. Other, non-reactive > materials would work too. Axle grease is better > than nothing. The CRC product cited is good. > > > Bob . . . > -- https://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
Date: May 09, 2018
That's exactly it. I am using these terminals with AeroRocker switches. There is a plastic housing which holds all six (or eight) connectors, making installation behind a panel much easier. I tried to buy some at the local electronics emporium (Gateway Electronics) and the owner opined that he could sell a zillion of those if only he could find a supplier. I searched DigiKey and came up empty. After I send this email, I will resume my search. Cheers, -- Art Z. On Wed, May 9, 2018 at 5:23 PM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > These particular terminals are used in conjunction with > some form of plastic housing that mates with other > devices . . . like the skinny-wire connections on the > back of an alternator. The purpose of the barb on the > back is to retain the terminal in its housing. > > > [image: []] > > -- https://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
Date: May 09, 2018
Ahhh! Finally found them at Digi-Key: https://www.digikey.com/product-detail/en/te-connectivity-amp-connectors/42282-1/A113676-ND/293293 Cheers, -- Art Z. On Wed, May 9, 2018 at 9:25 PM, Art Zemon wrote: > That's exactly it. I am using these terminals with AeroRocker switches. > There is a plastic housing which holds all six (or eight) connectors, > making installation behind a panel much easier. > > I tried to buy some at the local electronics emporium (Gateway > Electronics) and the owner opined that he could sell a zillion of those if > only he could find a supplier. I searched DigiKey and came up empty. After > I send this email, I will resume my search. > > Cheers, > -- Art Z. > > On Wed, May 9, 2018 at 5:23 PM, Robert L. Nuckolls, III < > nuckolls.bob(at)aeroelectric.com> wrote: > >> These particular terminals are used in conjunction with >> some form of plastic housing that mates with other >> devices . . . like the skinny-wire connections on the >> back of an alternator. The purpose of the barb on the >> back is to retain the terminal in its housing. >> >> >> [image: []] >> >> > -- > https://CheerfulCurmudgeon.com/ > > *"If I am not for myself, who is for me? And if I am only for myself, what > am I? And if not now, when?" Hillel* > -- https://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
Date: May 10, 2018
I found them on Mouser but I think you have to buy a roll of 10,000. Sent from my Android. Sorry Steve. On Wed, May 9, 2018, 18:31 Art Zemon wrote: > That's exactly it. I am using these terminals with AeroRocker switches. > There is a plastic housing which holds all six (or eight) connectors, > making installation behind a panel much easier. > > I tried to buy some at the local electronics emporium (Gateway > Electronics) and the owner opined that he could sell a zillion of those if > only he could find a supplier. I searched DigiKey and came up empty. After > I send this email, I will resume my search. > > Cheers, > -- Art Z. > > On Wed, May 9, 2018 at 5:23 PM, Robert L. Nuckolls, III < > nuckolls.bob(at)aeroelectric.com> wrote: > >> These particular terminals are used in conjunction with >> some form of plastic housing that mates with other >> devices . . . like the skinny-wire connections on the >> back of an alternator. The purpose of the barb on the >> back is to retain the terminal in its housing. >> >> >> [image: []] >> >> > -- > https://CheerfulCurmudgeon.com/ > > *"If I am not for myself, who is for me? And if I am only for myself, what > am I? And if not now, when?" Hillel* > ________________________________________________________________________________
Subject: Firewall Power Lug
Date: May 09, 2018
Hi I am looking for a firewall power lug similar to this: https://www.amazon.com/Battery-Firewall-Feed-Thru-Terminal-Connector/dp/B0038O2CIS What I would like though is something that is also fireproof or at least fire resistance. Can anyone point me in the right direction? Cheers Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480013#480013 ________________________________________________________________________________
Date: May 10, 2018
Subject: Re: Firewall Power Lug
Why not just run your cable through a grommet in the firewall? -- Art Z. Sent from my phone. Please excuse brevity and bizarre typos. On Wed, May 9, 2018, 10:02 PM kearney wrote: > > Hi > > I am looking for a firewall power lug similar to this: > > > https://www.amazon.com/Battery-Firewall-Feed-Thru-Terminal-Connector/dp/B0038O2CIS > > What I would like though is something that is also fireproof or at least > fire resistance. > > Can anyone point me in the right direction? > > Cheers > > Les > ________________________________________________________________________________
Date: May 10, 2018
Subject: Re: TyWraps redux
FWF I used a lot of flat lace along with some adel clamps and I'm really happy with the way it turned out. I have some pictures here: http://www.rv8.ch/fwf-wiring-photos/ I also did some testing with a good heat gun on the lace to make sure that I understood how it would behave if it got really hot - I was impressed. It basically didn't seem to care, and I could not get it to melt or change state in any way with the heat gun that will cause Tefzel wiring to finally melt and smoke. In parallel, I bought some Nomex lace, which also does not care about getting cooked by a heat gun, and will probably add this next to the normal lace in places that might be exposed to additional heat from the exhaust pipes. Will give some feedback in a few years when I'm finally flying. :) Not sure why, but working with the lace was very satisfying. Mickey Coggins On Wed, 9 May 2018 at 18:14, FLYaDIVE wrote: > Good point Bob... > > In general BLACK Ty-Wraps are UV and Ozone proof. The white ones become > brittle with time and exposure. > SOME - not all colored Ty-Wraps may also work. > > One might even find notes on the Ty-Wrap packaging as to UV & Ozone > resistant. > > Barry > > On Tue, May 8, 2018 at 4:32 PM, Robert L. Nuckolls, III < > nuckolls.bob(at)aeroelectric.com> wrote: > >> nuckolls.bob(at)aeroelectric.com> >> >> >> >> In a recent thread, TyWraps were discussed as a solution >> for wire bundle management. We had some discussions on >> these products about ten years back . . . >> >> In years since, I've had occasion to throw out stocks >> of unused TyWraps given that they had become brittle with >> age . . . the buckles would snap off in the ordinary process >> of applying the wrap. >> >> Be aware that not all that is plastic is Nylon 6,6. Evolved >> over the last 80+ years by DuPont. This material and its >> close cousins have found their way into all manner of component, >> many of which perform in under-hood environment of automobiles. >> >> When purchasing these critters, look for a 6-6, 6/6, 66 or even >> a 6,6 description of the nylon. The last time I was in Harbor >> Freight, many of their offerings bore such markings . . . but >> some did not . . . especially the smaller ones in assorted colors. >> >> All the wraps I pitched a few years ago were smaller sizes >> in various colors. Some had been in my Dad's inventory for untold >> years and were literally falling apart. >> >> My favorite bundle security uses Dacron flat lace applied >> like so . . . >> >> https://goo.gl/H3z1EQ >> >> Did a job for a rancher friend yesterday where the wiring was >> installed and initially held in place with some TyWraps he had >> laying around . . . after it was up and running, I dug out the >> roll of flat lace and installed a wrap adjacent to each of the >> TyWraps. Those plastic thingies MIGHT fall off in a few years >> but I'm betting the string will still be on duty. >> >> >> Bob . . . >> =================================== >> - >> Electric-List" rel="noreferrer" target="_blank"> >> http://www.matronics.com/Navigator?AeroElectric-List >> =================================== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> =================================== >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> =================================== >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >> =================================== >> >> >> >> > ________________________________________________________________________________
Date: May 10, 2018
Not only is flammability a concern for the Amazon feed-through terminal, but it also appears that the plastic gets compressed as the bolt is tightened. Many plastics will flow over time, thus allowing the electrical connection to loosen. Might be OK if tightened at each annual. Some switches also fail that have plastic being compressed by current-conducting rivets. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480022#480022 ________________________________________________________________________________
Date: May 10, 2018
On 5/9/2018 9:49 PM, kearney wrote: > > Hi > > I am looking for a firewall power lug similar to this: > > https://www.amazon.com/Battery-Firewall-Feed-Thru-Terminal-Connector/dp/B0038O2CIS > > What I would like though is something that is also fireproof or at least fire resistance. > > Can anyone point me in the right direction? > > Cheers > > Les > Search for 'ceramic insulating washer', 'ceramic shoulder washer', 'alumina washer', etc. You can roll your own pass through with a brass bolt & nut, a male ceramic shoulder washer, and a ceramic flat washer. Here are examples of what you need. *Not* the exact sizes (you'll need to decide that); just examples of what they look like. https://www.ebay.com/itm/8mm-10mm-14mm-20mm-OD-High-Temperature-Resistant-Male-Ceramic-Insulate-Washer-/232695504756?_trksid=p2385738.m4383.l4275.c10&var=532197640760 https://www.ebay.com/itm/15mm-OD-6mm-High-Round-Ceramic-Insulated-Washer-Fender-50-Pieces-Q5N9-/253489306817?_trksid=p2385738.m4383.l4275.c10 Charlie --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: May 10, 2018
Charlie: One thing I totally agree with Bob N. on is: Reduction of Failure Points. Yes, using this type of feed-through would LQQK nice but you have created three (3) failure points: One at each end of the feed-through and the freed-through mounting itself. Oh, wait, there are two (2) more potential failure points; The lugs that go to each end of the wires. Why not a un-broken run of cable and a better type of feed-through? I would look for a nice LQQKing feed-through fitting - Water Tight Fitting. Something like this: https://www.grainger.com/product/2HYA5?cm_mmc=PPC:+Google+PLA&s_kwcid=AL!2966!3!166591489617!!!g!81031653477!&ef_id=WuocMQAABn_Z5xGW:20180510175458:s They also come in S/S. Barry On Thu, May 10, 2018 at 10:40 AM, Charlie England wrote: > ceengland7(at)gmail.com> > > On 5/9/2018 9:49 PM, kearney wrote: > >> >> Hi >> >> I am looking for a firewall power lug similar to this: >> >> https://www.amazon.com/Battery-Firewall-Feed-Thru-Terminal- >> Connector/dp/B0038O2CIS >> >> What I would like though is something that is also fireproof or at least >> fire resistance. >> >> Can anyone point me in the right direction? >> >> Cheers >> >> Les >> >> Search for 'ceramic insulating washer', 'ceramic shoulder washer', > 'alumina washer', etc. > > You can roll your own pass through with a brass bolt & nut, a male ceramic > shoulder washer, and a ceramic flat washer. Here are examples of what you > need. *Not* the exact sizes (you'll need to decide that); just examples of > what they look like. > > https://www.ebay.com/itm/8mm-10mm-14mm-20mm-OD-High-Temperat > ure-Resistant-Male-Ceramic-Insulate-Washer-/232695504756? > _trksid=p2385738.m4383.l4275.c10&var=532197640760 > > https://www.ebay.com/itm/15mm-OD-6mm-High-Round-Ceramic-Insu > lated-Washer-Fender-50-Pieces-Q5N9-/253489306817?_trksid > p2385738.m4383.l4275.c10 > > Charlie > > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus > > ________________________________________________________________________________
Date: May 10, 2018
Nice LQQKing job OM. Would like to see more. Barry On Thu, May 10, 2018 at 2:14 AM, Mickey Coggins wrote: > FWF I used a lot of flat lace along with some adel clamps and I'm really > happy with the way it turned out. I have some pictures here: > > http://www.rv8.ch/fwf-wiring-photos/ > > I also did some testing with a good heat gun on the lace to make sure that > I understood how it would behave if it got really hot - I was impressed. > It basically didn't seem to care, and I could not get it to melt or change > state in any way with the heat gun that will cause Tefzel wiring to finally > melt and smoke. > > In parallel, I bought some Nomex lace, which also does not care about > getting cooked by a heat gun, and will probably add this next to the normal > lace in places that might be exposed to additional heat from the exhaust > pipes. Will give some feedback in a few years when I'm finally flying. :) > > Not sure why, but working with the lace was very satisfying. > > Mickey Coggins > > > On Wed, 9 May 2018 at 18:14, FLYaDIVE wrote: > >> Good point Bob... >> >> In general BLACK Ty-Wraps are UV and Ozone proof. The white ones become >> brittle with time and exposure. >> SOME - not all colored Ty-Wraps may also work. >> >> One might even find notes on the Ty-Wrap packaging as to UV & Ozone >> resistant. >> >> Barry >> >> On Tue, May 8, 2018 at 4:32 PM, Robert L. Nuckolls, III < >> nuckolls.bob(at)aeroelectric.com> wrote: >> >>> nuckolls.bob(at)aeroelectric.com> >>> >>> >>> >>> In a recent thread, TyWraps were discussed as a solution >>> for wire bundle management. We had some discussions on >>> these products about ten years back . . . >>> >>> In years since, I've had occasion to throw out stocks >>> of unused TyWraps given that they had become brittle with >>> age . . . the buckles would snap off in the ordinary process >>> of applying the wrap. >>> >>> Be aware that not all that is plastic is Nylon 6,6. Evolved >>> over the last 80+ years by DuPont. This material and its >>> close cousins have found their way into all manner of component, >>> many of which perform in under-hood environment of automobiles. >>> >>> When purchasing these critters, look for a 6-6, 6/6, 66 or even >>> a 6,6 description of the nylon. The last time I was in Harbor >>> Freight, many of their offerings bore such markings . . . but >>> some did not . . . especially the smaller ones in assorted colors. >>> >>> All the wraps I pitched a few years ago were smaller sizes >>> in various colors. Some had been in my Dad's inventory for untold >>> years and were literally falling apart. >>> >>> My favorite bundle security uses Dacron flat lace applied >>> like so . . . >>> >>> https://goo.gl/H3z1EQ >>> >>> Did a job for a rancher friend yesterday where the wiring was >>> installed and initially held in place with some TyWraps he had >>> laying around . . . after it was up and running, I dug out the >>> roll of flat lace and installed a wrap adjacent to each of the >>> TyWraps. Those plastic thingies MIGHT fall off in a few years >>> but I'm betting the string will still be on duty. >>> >>> >>> Bob . . . >>> ========== >>> - >>> Electric-List" rel="noreferrer" target="_blank">http://www. >>> matronics.com/Navigator?AeroElectric-List >>> ========== >>> FORUMS - >>> eferrer" target="_blank">http://forums.matronics.com >>> ========== >>> WIKI - >>> errer" target="_blank">http://wiki.matronics.com >>> ========== >>> b Site - >>> -Matt Dralle, List Admin. >>> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >>> ========== >>> >>> >>> >>> >> ________________________________________________________________________________
Date: May 10, 2018
I use the flanged stainless tube feed-through, with fire caulk & firesleeve, detailed in the 'Connection and elsewhere. Since he asked specifically for a bulkhead feed-through for a 'fat' power wire, I assumed he had made his choice of method and I was trying to give him an idea that would work and be fire resistant. Your option has the same vulnerabilities to heat as the original linked article. Charlie On 5/10/2018 12:57 PM, FLYaDIVE wrote: > Charlie: > > One thing I totally agree with Bob N. on is: Reduction of Failure Points. > Yes, using this type of feed-through would LQQK nice but you have > created three (3) failure points: One at each end of the feed-through > and the freed-through mounting itself. Oh, wait, there are two (2) > more potential failure points; The lugs that go to each end of the wires. > Why not a un-broken run of cable and a better type of feed-through? > > I would look for a nice LQQKing feed-through fitting - Water Tight > Fitting. > Something like this: > https://www.grainger.com/product/2HYA5?cm_mmc=PPC:+Google+PLA&s_kwcid=AL!2966!3!166591489617!!!g!81031653477!&ef_id=WuocMQAABn_Z5xGW:20180510175458:s > > > They also come in S/S. > > Barry > > > On Thu, May 10, 2018 at 10:40 AM, Charlie England > > wrote: > > > > > On 5/9/2018 9:49 PM, kearney wrote: > > > > > Hi > > I am looking for a firewall power lug similar to this: > > https://www.amazon.com/Battery-Firewall-Feed-Thru-Terminal-Connector/dp/B0038O2CIS > > > What I would like though is something that is also fireproof > or at least fire resistance. > > Can anyone point me in the right direction? > > Cheers > > Les > > Search for 'ceramic insulating washer', 'ceramic shoulder washer', > 'alumina washer', etc. > > You can roll your own pass through with a brass bolt & nut, a male > ceramic shoulder washer, and a ceramic flat washer. Here are > examples of what you need. *Not* the exact sizes (you'll need to > decide that); just examples of what they look like. > > https://www.ebay.com/itm/8mm-10mm-14mm-20mm-OD-High-Temperature-Resistant-Male-Ceramic-Insulate-Washer-/232695504756?_trksid=p2385738.m4383.l4275.c10&var=532197640760 > > > https://www.ebay.com/itm/15mm-OD-6mm-High-Round-Ceramic-Insulated-Washer-Fender-50-Pieces-Q5N9-/253489306817?_trksid=p2385738.m4383.l4275.c10 > > > Charlie > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: May 10, 2018
Nice one! Prolly put some of those certified boys to shame! On Thu, 10 May 2018, 8:21 AM Mickey Coggins wrote: > FWF I used a lot of flat lace along with some adel clamps and I'm really > happy with the way it turned out. I have some pictures here: > > http://www.rv8.ch/fwf-wiring-photos/ > > I also did some testing with a good heat gun on the lace to make sure that > I understood how it would behave if it got really hot - I was impressed. > It basically didn't seem to care, and I could not get it to melt or change > state in any way with the heat gun that will cause Tefzel wiring to finally > melt and smoke. > > In parallel, I bought some Nomex lace, which also does not care about > getting cooked by a heat gun, and will probably add this next to the normal > lace in places that might be exposed to additional heat from the exhaust > pipes. Will give some feedback in a few years when I'm finally flying. :) > > Not sure why, but working with the lace was very satisfying. > > Mickey Coggins > > > On Wed, 9 May 2018 at 18:14, FLYaDIVE wrote: > >> Good point Bob... >> >> In general BLACK Ty-Wraps are UV and Ozone proof. The white ones become >> brittle with time and exposure. >> SOME - not all colored Ty-Wraps may also work. >> >> One might even find notes on the Ty-Wrap packaging as to UV & Ozone >> resistant. >> >> Barry >> >> On Tue, May 8, 2018 at 4:32 PM, Robert L. Nuckolls, III < >> nuckolls.bob(at)aeroelectric.com> wrote: >> >>> nuckolls.bob(at)aeroelectric.com> >>> >>> >>> >>> In a recent thread, TyWraps were discussed as a solution >>> for wire bundle management. We had some discussions on >>> these products about ten years back . . . >>> >>> In years since, I've had occasion to throw out stocks >>> of unused TyWraps given that they had become brittle with >>> age . . . the buckles would snap off in the ordinary process >>> of applying the wrap. >>> >>> Be aware that not all that is plastic is Nylon 6,6. Evolved >>> over the last 80+ years by DuPont. This material and its >>> close cousins have found their way into all manner of component, >>> many of which perform in under-hood environment of automobiles. >>> >>> When purchasing these critters, look for a 6-6, 6/6, 66 or even >>> a 6,6 description of the nylon. The last time I was in Harbor >>> Freight, many of their offerings bore such markings . . . but >>> some did not . . . especially the smaller ones in assorted colors. >>> >>> All the wraps I pitched a few years ago were smaller sizes >>> in various colors. Some had been in my Dad's inventory for untold >>> years and were literally falling apart. >>> >>> My favorite bundle security uses Dacron flat lace applied >>> like so . . . >>> >>> https://goo.gl/H3z1EQ >>> >>> Did a job for a rancher friend yesterday where the wiring was >>> installed and initially held in place with some TyWraps he had >>> laying around . . . after it was up and running, I dug out the >>> roll of flat lace and installed a wrap adjacent to each of the >>> TyWraps. Those plastic thingies MIGHT fall off in a few years >>> but I'm betting the string will still be on duty. >>> >>> >>> Bob . . . >>> ========== >>> - >>> Electric-List" rel="noreferrer" target="_blank"> >>> http://www.matronics.com/Navigator?AeroElectric-List >>> ========== >>> FORUMS - >>> eferrer" target="_blank">http://forums.matronics.com >>> ========== >>> WIKI - >>> errer" target="_blank">http://wiki.matronics.com >>> ========== >>> b Site - >>> -Matt Dralle, List Admin. >>> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >>> ========== >>> >>> >>> >>> >> ________________________________________________________________________________
Date: May 10, 2018
At 01:17 PM 5/10/2018, you wrote: >I use the flanged stainless tube feed-through, with fire caulk & >firesleeve, detailed in the 'Connection and elsewhere. Here's a comic book I published a years back illustrating the methodology used on Bonanza and Baron aircraft at Beech. https://goo.gl/9vLwXF As far as I know, they still do it this way. A good friend and colleague of many years at Beech was a guy named Jack Thurman. He was dungeon and rack master at "Thurman's House of Horrors". The well worn admonition concerning new ideas for bolting things to Beech products was, "If Jack can't tear it up, it's good to go on a Beechcraft." One of Jack's more impressive toys was a propane fired burner (suitable for burning really BIG weeds) that would bathe a firewall mock-up with 2000 DegF flames. It's a certainty that Master of Mayhem Thurman sprinkled holy water on the techniques described above. At one time, members here on the list were fabricating welded, stainless elbows with flanges from the ends of COTS grab bars. Cutting the ends of of something like this would get you two elbows: https://goo.gl/6Q4jkC Unfortunately, these are pretty 'oversized' for our tasks . . . and stick up off the firewall quite a bit. One could consider fabricating from pre-bent elbows, a flange washer cut from stainless sheet and a short nipple of stainless tube. If you've got access to a talented TIG driver, you could probably come up with some pretty nice parts sized to the task. Bob . . . ________________________________________________________________________________
Date: May 10, 2018
Alec: In building or repairs it is always (in dreamland) the best case condition to cover the terminals as much as possible. Well, that is what we strive for. You might have seen rubber/silicone boots over such things as: Connection terminals on relays. Terminals on Alternators and even Terminals on Mags. Leaving terminals exposed opens up the high possibility of neighboring terminals to contact each other, or having something like a screwdriver or hardware drop on the terminal lug. When talking about the Why-Not of the metal rollover tabs. They Cut Into the insulation of the wire. This is a weak point and a breaking point of the wire MOUNT. It is best NOT to consider this rollover tab a securing point of the lug and consider it just a sloppy part of the electrical crimp. Consider why they are NOT used in certified aircraft. I hate to say this on a mainly Experimental Email Site but... Not ALL Certified Aircraft procedures are bad, or just done to satisfy the FAA, or are expensive just to line someones pocketbook. There was just a long thread on this email site that discussed Insulated Crimp Connectors. The insulated part of the lug Supports the insulated part of the wire. It gives it a secure holding point that DOES NOT cut into wire. Something else to view (look at Mil Spec Lugs) and consider: Lugs that are NOT insulated do NOT support the wire insulation. Over the decades I have worked in electronics I have see this type of lug you are considering fail as the rollover part cuts into the wire insulation. Mater of fact: The design of this type of rollover has changed. BUT! Has not gone away! Let the Ground Bound Clowns (Chinese Junk) that are penny pinching use them. You are a Pilot and a Builder, your plane and you are worth it. Barry On Wed, May 9, 2018 at 5:39 PM, Alec Myers wrote: > educate me.... > > why is uninsulated bad? > What=99s the problem with the wrapover insulation support? > > On May 9, 2018, at 17:11, FLYaDIVE wrote: > > Art: > > I have got to ask... Are you building your experimental to any specific > specs? > As an Experimental Builder, yes, you are allowed to experiment all > different practices. > But, I see no reason why all your wiring should not be the Best current > practice. > Those type connectors are very ancient and have all sorts of issues... > Sharp Edges > UN-INSULATED > Grip Support of the wire insulation. > No universal manufacturing procedures. Example Not Mil-Spec. > Un-Acceptable Certified Design (FAA, AC 43.13) Yes, I know you are > experimental. > Why would you want to use something from the dark ages? > > Barry > > > On Tue, May 8, 2018 at 11:22 PM, Art Zemon wrote: > >> Folks, >> >> Does Digikey (or anyone) sell these terminals? http://www.aircraft >> spruce.com/catalog/elpages/aveotabterminals.php >> They are regular Faston terminals but have a little tab on the bottom to >> keep them from slipping out of a plastic housing. >> >> >> Thanks, >> -- Art Z. >> >> -- >> https://CheerfulCurmudgeon.com/ >> >> *"If I am not for myself, who is for me? And if I am only for myself, >> what am I? And if not now, when?" Hillel* >> > > ________________________________________________________________________________
Date: May 10, 2018
My interest in this stems more from discerning myth from measureable fact th an trying to pick something suitable for aircraft, but I=99m afraid I d on=99t believe any industrial manufacturer would use them for anything at all, if they=99re even half as bad as you say. A penny saved on a t ermination is a false economy if it decreases product reliability, and yet h ere they are, in use in white goods the world over. Perhaps there=99s an issue with reliable hand tool application? On May 10, 2018, at 18:08, FLYaDIVE wrote: Alec: In building or repairs it is always (in dreamland) the best case condition t o cover the terminals as much as possible. Well, that is what we strive for. You might have seen rubber/silicone boots over such things as: Connection terminals on relays. Terminals on Alternators and even Terminals on Mags. Leaving terminals exposed opens up the high possibility of neighboring termi nals to contact each other, or having something like a screwdriver or hardwa re drop on the terminal lug. When talking about the Why-Not of the metal rollover tabs. They Cut Into th e insulation of the wire. This is a weak point and a breaking point of the w ire MOUNT. It is best NOT to consider this rollover tab a securing point o f the lug and consider it just a sloppy part of the electrical crimp. Consi der why they are NOT used in certified aircraft. I hate to say this on a ma inly Experimental Email Site but... Not ALL Certified Aircraft procedures a re bad, or just done to satisfy the FAA, or are expensive just to line someo nes pocketbook. There was just a long thread on this email site that discussed Insulated Cri mp Connectors. The insulated part of the lug Supports the insulated part of the wire. It gives it a secure holding point that DOES NOT cut into wire. Something else to view (look at Mil Spec Lugs) and consider: Lugs that are N OT insulated do NOT support the wire insulation. Over the decades I have worked in electronics I have see this type of lug yo u are considering fail as the rollover part cuts into the wire insulation. M ater of fact: The design of this type of rollover has changed. BUT! Has n ot gone away! Let the Ground Bound Clowns (Chinese Junk) that are penny pinching use them. You are a Pilot and a Builder, your plane and you are worth it. Barry > On Wed, May 9, 2018 at 5:39 PM, Alec Myers wrote: > educate me.... > > why is uninsulated bad? > What=99s the problem with the wrapover insulation support? > > On May 9, 2018, at 17:11, FLYaDIVE wrote: > > Art: > > I have got to ask... Are you building your experimental to any specific s pecs? > As an Experimental Builder, yes, you are allowed to experiment all differe nt practices. > But, I see no reason why all your wiring should not be the Best current pr actice. > Those type connectors are very ancient and have all sorts of issues... > Sharp Edges > UN-INSULATED > Grip Support of the wire insulation. > No universal manufacturing procedures. Example Not Mil-Spec. > Un-Acceptable Certified Design (FAA, AC 43.13) Yes, I know you are experim ental. > Why would you want to use something from the dark ages? > > Barry > > > >> On Tue, May 8, 2018 at 11:22 PM, Art Zemon wrote: >> Folks, >> >> Does Digikey (or anyone) sell these terminals? http://www.aircraftspruce. com/catalog/elpages/aveotabterminals.php >> They are regular Faston terminals but have a little tab on the bottom to k eep them from slipping out of a plastic housing. >> >> >> Thanks, >> -- Art Z. >> >> -- >> https://CheerfulCurmudgeon.com/ >> >> "If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel > ________________________________________________________________________________
Date: May 10, 2018
Hi Thank you everyone for the replies. My application is only for a power stud so my preference is for something similar to what I originally posted. I am sensitive to using plastics which is why I posted the query. I have heard that some commercial aircraft use studs of the type I am looking for. I just don't want the $$$ cost of "brand name aircraft parts". Cheers Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480043#480043 ________________________________________________________________________________
Date: May 10, 2018
Yes, Kearney; Piper uses studs on their battery cables and battery box. I curse them ALL the time! You could always make your own with Phenolic Board and Brass Bolts. You could also use a few nuts & bolts to hold the phenolic board in-place on the firewall and use the brass bolt & nuts to pass the power through. It would be a much better structure than anything you could buy. And cost you very little. And structurally, extreamly sound and water tight. It can be either single board or double board (both sides of the firewall). Barry On Thu, May 10, 2018 at 7:25 PM, kearney wrote: > > Hi > > Thank you everyone for the replies. My application is only for a power > stud so my preference is for something similar to what I originally posted. > > I am sensitive to using plastics which is why I posted the query. I have > heard that some commercial aircraft use studs of the type I am looking for. > I just don't want the $$$ cost of "brand name aircraft parts". > > Cheers > > Les > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=480043#480043 > > ________________________________________________________________________________
Date: May 10, 2018
Alec: They are at least twice as bad as I describe. If they were so Manufacturerlly acceptable why are they not being used or recommended by ALL the aviation manufactures and experimental aircraft suppliers such as RV? As for: " A penny saved on a termination is a false economy...", PENNY HELL! The manufactures argue tenths of a cent (1 mill)! Your statement of HAND TOOL is spot ON! Look at the many ways those lugs can be used and how many of those ways will NOT produce a proper crimp. Look at the cost of a Mil-Spec Hand Tool to do the job. There is NO money saved there. If as you say are interested in: "...trying to pick something suitable for aircraft..." why not go with what is an industry standard - A Proven Industry (Aviation) Standard? YES, I know in the Experimental Aviation world you do not have to follow a majority of the FAA requirements and you SHOULD and have the right to do better. But what are you comparing your experimental idea too? Hey! Just had an idea... If you want to prove your thought process and prove me wrong. Make a simple vibration test bench and shake the S#!+ out of the the lug you picked and the ones the aviation industry use. Barry On Thu, May 10, 2018 at 6:44 PM, Alec Myers wrote: > My interest in this stems more from discerning myth from measureable fact > than trying to pick something suitable for aircraft, but I=99m afra id I don=99t > believe any industrial manufacturer would use them for anything at all, i f > they=99re even half as bad as you say. A penny saved on a terminati on is a > false economy if it decreases product reliability, and yet here they are, > in use in white goods the world over. > > Perhaps there=99s an issue with reliable hand tool application? > > > On May 10, 2018, at 18:08, FLYaDIVE wrote: > > Alec: > > In building or repairs it is always (in dreamland) the best case conditio n > to cover the terminals as much as possible. Well, that is what we strive > for. You might have seen rubber/silicone boots over such things as: > Connection terminals on relays. > Terminals on Alternators and even > Terminals on Mags. > Leaving terminals exposed opens up the high possibility of neighboring > terminals to contact each other, or having something like a screwdriver o r > hardware drop on the terminal lug. > When talking about the Why-Not of the metal rollover tabs. They Cut Into > the insulation of the wire. This is a weak point and a breaking point of > the wire MOUNT. It is best NOT to consider this rollover tab a securing > point of the lug and consider it just a sloppy part of the electrical > crimp. Consider why they are NOT used in certified aircraft. I hate to > say this on a mainly Experimental Email Site but... Not ALL Certified > Aircraft procedures are bad, or just done to satisfy the FAA, or are > expensive just to line someones pocketbook. > There was just a long thread on this email site that discussed Insulated > Crimp Connectors. The insulated part of the lug Supports the insulated > part of the wire. It gives it a secure holding point that DOES NOT cut > into wire. > Something else to view (look at Mil Spec Lugs) and consider: Lugs that ar e > NOT insulated do NOT support the wire insulation. > Over the decades I have worked in electronics I have see this type of lug > you are considering fail as the rollover part cuts into the wire > insulation. Mater of fact: The design of this type of rollover has > changed. BUT! Has not gone away! > Let the Ground Bound Clowns (Chinese Junk) that are penny pinching use > them. You are a Pilot and a Builder, your plane and you are worth it. > > Barry > > On Wed, May 9, 2018 at 5:39 PM, Alec Myers wrote: > >> educate me.... >> >> why is uninsulated bad? >> What=99s the problem with the wrapover insulation support? >> >> On May 9, 2018, at 17:11, FLYaDIVE wrote: >> >> Art: >> >> I have got to ask... Are you building your experimental to any specific >> specs? >> As an Experimental Builder, yes, you are allowed to experiment all >> different practices. >> But, I see no reason why all your wiring should not be the Best current >> practice. >> Those type connectors are very ancient and have all sorts of issues... >> Sharp Edges >> UN-INSULATED >> Grip Support of the wire insulation. >> No universal manufacturing procedures. Example Not Mil-Spec. >> Un-Acceptable Certified Design (FAA, AC 43.13) Yes, I know you are >> experimental. >> Why would you want to use something from the dark ages? >> >> Barry >> >> >> >> On Tue, May 8, 2018 at 11:22 PM, Art Zemon wrote: >> >>> Folks, >>> >>> Does Digikey (or anyone) sell these terminals? http://www.aircraft >>> spruce.com/catalog/elpages/aveotabterminals.php >>> They are regular Faston terminals but have a little tab on the bottom t o >>> keep them from slipping out of a plastic housing. >>> >>> >>> Thanks, >>> -- Art Z. >>> >>> -- >>> https://CheerfulCurmudgeon.com/ >>> >>> *"If I am not for myself, who is for me? And if I am only for myself, >>> what am I? And if not now, when?" Hillel* >>> >> >> > ________________________________________________________________________________
Date: May 10, 2018
Subject: Re: Faston / Aveo Tab Terminals
On May 10, 2018, at 21:57, FLYaDIVE wrote: Alec: They are at least twice as bad as I describe. If they were so Manufacturerl ly acceptable why are they not being used or recommended by ALL the aviation manufactures and experimental aircraft suppliers such as RV? As for: " A penny saved on a termination is a false economy...", PENNY HELL ! The manufactures argue tenths of a cent (1 mill)! Your statement of HAND TOOL is spot ON! Look at the many ways those lugs ca n be used and how many of those ways will NOT produce a proper crimp. Look a t the cost of a Mil-Spec Hand Tool to do the job. There is NO money saved t here. If as you say are interested in: "...trying to pick something suitable for a ircraft..." why not go with what is an industry standard - A Proven Industry (Aviation) Standard? YES, I know in the Experimental Aviation world you d o not have to follow a majority of the FAA requirements and you SHOULD and h ave the right to do better. But what are you comparing your experimental id ea too? Hey! Just had an idea... If you want to prove your thought process and pro ve me wrong. Make a simple vibration test bench and shake the S#!+ out of t he the lug you picked and the ones the aviation industry use. Barry > On Thu, May 10, 2018 at 6:44 PM, Alec Myers wrote: > My interest in this stems more from discerning myth from measureable fact t han trying to pick something suitable for aircraft, but I=99m afraid I don=99t believe any industrial manufacturer would use them for anythi ng at all, if they=99re even half as bad as you say. A penny saved on a termination is a false economy if it decreases product reliability, and yet here they are, in use in white goods the world over. > > Perhaps there=99s an issue with reliable hand tool application? > > > On May 10, 2018, at 18:08, FLYaDIVE wrote: > > Alec: > > In building or repairs it is always (in dreamland) the best case condition to cover the terminals as much as possible. Well, that is what we strive fo r. You might have seen rubber/silicone boots over such things as: > Connection terminals on relays. > Terminals on Alternators and even > Terminals on Mags. > Leaving terminals exposed opens up the high possibility of neighboring ter minals to contact each other, or having something like a screwdriver or hard ware drop on the terminal lug. > When talking about the Why-Not of the metal rollover tabs. They Cut Into t he insulation of the wire. This is a weak point and a breaking point of the wire MOUNT. It is best NOT to consider this rollover tab a securing point of the lug and consider it just a sloppy part of the electrical crimp. Con sider why they are NOT used in certified aircraft. I hate to say this on a m ainly Experimental Email Site but... Not ALL Certified Aircraft procedures a re bad, or just done to satisfy the FAA, or are expensive just to line someo nes pocketbook. > There was just a long thread on this email site that discussed Insulated C rimp Connectors. The insulated part of the lug Supports the insulated part o f the wire. It gives it a secure holding point that DOES NOT cut into wire. > Something else to view (look at Mil Spec Lugs) and consider: Lugs that are NOT insulated do NOT support the wire insulation. > Over the decades I have worked in electronics I have see this type of lug y ou are considering fail as the rollover part cuts into the wire insulation. Mater of fact: The design of this type of rollover has changed. BUT! Has not gone away! > Let the Ground Bound Clowns (Chinese Junk) that are penny pinching use the m. You are a Pilot and a Builder, your plane and you are worth it. > > Barry > >> On Wed, May 9, 2018 at 5:39 PM, Alec Myers wrote: >> educate me.... >> >> why is uninsulated bad? >> What=99s the problem with the wrapover insulation support? >> >> On May 9, 2018, at 17:11, FLYaDIVE wrote: >> >> Art: >> >> I have got to ask... Are you building your experimental to any specific s pecs? >> As an Experimental Builder, yes, you are allowed to experiment all differ ent practices. >> But, I see no reason why all your wiring should not be the Best current p ractice. >> Those type connectors are very ancient and have all sorts of issues... >> Sharp Edges >> UN-INSULATED >> Grip Support of the wire insulation. >> No universal manufacturing procedures. Example Not Mil-Spec. >> Un-Acceptable Certified Design (FAA, AC 43.13) Yes, I know you are experi mental. >> Why would you want to use something from the dark ages? >> >> Barry >> >> >> >>> On Tue, May 8, 2018 at 11:22 PM, Art Zemon wrote: >>> Folks, >>> >>> Does Digikey (or anyone) sell these terminals? http://www.aircraftspruce .com/catalog/elpages/aveotabterminals.php >>> They are regular Faston terminals but have a little tab on the bottom to keep them from slipping out of a plastic housing. >>> >>> >>> Thanks, >>> -- Art Z. >>> >>> -- >>> https://CheerfulCurmudgeon.com/ >>> >>> "If I am not for myself, who is for me? And if I am only for myself, wha t am I? And if not now, when?" Hillel >> > ________________________________________________________________________________
Date: May 10, 2018
Barry I=99d be as happy to prove you right, as wrong. I might think about ho w to build a vibration test, somehow :) On May 10, 2018, at 21:57, FLYaDIVE wrote: Alec: They are at least twice as bad as I describe. If they were so Manufacturerl ly acceptable why are they not being used or recommended by ALL the aviation manufactures and experimental aircraft suppliers such as RV? As for: " A penny saved on a termination is a false economy...", PENNY HELL ! The manufactures argue tenths of a cent (1 mill)! Your statement of HAND TOOL is spot ON! Look at the many ways those lugs ca n be used and how many of those ways will NOT produce a proper crimp. Look a t the cost of a Mil-Spec Hand Tool to do the job. There is NO money saved t here. If as you say are interested in: "...trying to pick something suitable for a ircraft..." why not go with what is an industry standard - A Proven Industry (Aviation) Standard? YES, I know in the Experimental Aviation world you d o not have to follow a majority of the FAA requirements and you SHOULD and h ave the right to do better. But what are you comparing your experimental id ea too? Hey! Just had an idea... If you want to prove your thought process and pro ve me wrong. Make a simple vibration test bench and shake the S#!+ out of t he the lug you picked and the ones the aviation industry use. Barry > On Thu, May 10, 2018 at 6:44 PM, Alec Myers wrote: > My interest in this stems more from discerning myth from measureable fact t han trying to pick something suitable for aircraft, but I=99m afraid I don=99t believe any industrial manufacturer would use them for anythi ng at all, if they=99re even half as bad as you say. A penny saved on a termination is a false economy if it decreases product reliability, and yet here they are, in use in white goods the world over. > > Perhaps there=99s an issue with reliable hand tool application? > > > On May 10, 2018, at 18:08, FLYaDIVE wrote: > > Alec: > > In building or repairs it is always (in dreamland) the best case condition to cover the terminals as much as possible. Well, that is what we strive fo r. You might have seen rubber/silicone boots over such things as: > Connection terminals on relays. > Terminals on Alternators and even > Terminals on Mags. > Leaving terminals exposed opens up the high possibility of neighboring ter minals to contact each other, or having something like a screwdriver or hard ware drop on the terminal lug. > When talking about the Why-Not of the metal rollover tabs. They Cut Into t he insulation of the wire. This is a weak point and a breaking point of the wire MOUNT. It is best NOT to consider this rollover tab a securing point of the lug and consider it just a sloppy part of the electrical crimp. Con sider why they are NOT used in certified aircraft. I hate to say this on a m ainly Experimental Email Site but... Not ALL Certified Aircraft procedures a re bad, or just done to satisfy the FAA, or are expensive just to line someo nes pocketbook. > There was just a long thread on this email site that discussed Insulated C rimp Connectors. The insulated part of the lug Supports the insulated part o f the wire. It gives it a secure holding point that DOES NOT cut into wire. > Something else to view (look at Mil Spec Lugs) and consider: Lugs that are NOT insulated do NOT support the wire insulation. > Over the decades I have worked in electronics I have see this type of lug y ou are considering fail as the rollover part cuts into the wire insulation. Mater of fact: The design of this type of rollover has changed. BUT! Has not gone away! > Let the Ground Bound Clowns (Chinese Junk) that are penny pinching use the m. You are a Pilot and a Builder, your plane and you are worth it. > > Barry > >> On Wed, May 9, 2018 at 5:39 PM, Alec Myers wrote: >> educate me.... >> >> why is uninsulated bad? >> What=99s the problem with the wrapover insulation support? >> >> On May 9, 2018, at 17:11, FLYaDIVE wrote: >> >> Art: >> >> I have got to ask... Are you building your experimental to any specific s pecs? >> As an Experimental Builder, yes, you are allowed to experiment all differ ent practices. >> But, I see no reason why all your wiring should not be the Best current p ractice. >> Those type connectors are very ancient and have all sorts of issues... >> Sharp Edges >> UN-INSULATED >> Grip Support of the wire insulation. >> No universal manufacturing procedures. Example Not Mil-Spec. >> Un-Acceptable Certified Design (FAA, AC 43.13) Yes, I know you are experi mental. >> Why would you want to use something from the dark ages? >> >> Barry >> >> >> >>> On Tue, May 8, 2018 at 11:22 PM, Art Zemon wrote: >>> Folks, >>> >>> Does Digikey (or anyone) sell these terminals? http://www.aircraftspruce .com/catalog/elpages/aveotabterminals.php >>> They are regular Faston terminals but have a little tab on the bottom to keep them from slipping out of a plastic housing. >>> >>> >>> Thanks, >>> -- Art Z. >>> >>> -- >>> https://CheerfulCurmudgeon.com/ >>> >>> "If I am not for myself, who is for me? And if I am only for myself, wha t am I? And if not now, when?" Hillel >> > ________________________________________________________________________________
Date: May 10, 2018
Maybe an electric toothbrush? On Thu, May 10, 2018 at 7:16 PM, Alec Myers wrote: > Barry > > I=99d be as happy to prove you right, as wrong. I might think about how to > build a vibration test, somehow :) > > On May 10, 2018, at 21:57, FLYaDIVE wrote: > > Alec: > > They are at least twice as bad as I describe. If they were so > Manufacturerlly acceptable why are they not being used or recommended by > ALL the aviation manufactures and experimental aircraft suppliers such as > RV? > As for: " A penny saved on a termination is a false economy...", PENNY > HELL! The manufactures argue tenths of a cent (1 mill)! > > Your statement of HAND TOOL is spot ON! Look at the many ways those lugs > can be used and how many of those ways will NOT produce a proper crimp. > Look at the cost of a Mil-Spec Hand Tool to do the job. There is NO mone y > saved there. > > If as you say are interested in: "...trying to pick something suitable > for aircraft..." why not go with what is an industry standard - A Proven > Industry (Aviation) Standard? YES, I know in the Experimental Aviation > world you do not have to follow a majority of the FAA requirements and yo u > SHOULD and have the right to do better. But what are you comparing your > experimental idea too? > > Hey! Just had an idea... If you want to prove your thought process and > prove me wrong. Make a simple vibration test bench and shake the S#!+ ou t > of the the lug you picked and the ones the aviation industry use. > > Barry > > > On Thu, May 10, 2018 at 6:44 PM, Alec Myers wrote: > >> My interest in this stems more from discerning myth from measureable fac t >> than trying to pick something suitable for aircraft, but I=99m afr aid I don=99t >> believe any industrial manufacturer would use them for anything at all, if >> they=99re even half as bad as you say. A penny saved on a terminat ion is a >> false economy if it decreases product reliability, and yet here they are , >> in use in white goods the world over. >> >> Perhaps there=99s an issue with reliable hand tool application? >> >> >> On May 10, 2018, at 18:08, FLYaDIVE wrote: >> >> Alec: >> >> In building or repairs it is always (in dreamland) the best case >> condition to cover the terminals as much as possible. Well, that is what we >> strive for. You might have seen rubber/silicone boots over such things as: >> Connection terminals on relays. >> Terminals on Alternators and even >> Terminals on Mags. >> Leaving terminals exposed opens up the high possibility of neighboring >> terminals to contact each other, or having something like a screwdriver or >> hardware drop on the terminal lug. >> When talking about the Why-Not of the metal rollover tabs. They Cut Int o >> the insulation of the wire. This is a weak point and a breaking point o f >> the wire MOUNT. It is best NOT to consider this rollover tab a securing >> point of the lug and consider it just a sloppy part of the electrical >> crimp. Consider why they are NOT used in certified aircraft. I hate to >> say this on a mainly Experimental Email Site but... Not ALL Certified >> Aircraft procedures are bad, or just done to satisfy the FAA, or are >> expensive just to line someones pocketbook. >> There was just a long thread on this email site that discussed Insulated >> Crimp Connectors. The insulated part of the lug Supports the insulated >> part of the wire. It gives it a secure holding point that DOES NOT cut >> into wire. >> Something else to view (look at Mil Spec Lugs) and consider: Lugs that >> are NOT insulated do NOT support the wire insulation. >> Over the decades I have worked in electronics I have see this type of lu g >> you are considering fail as the rollover part cuts into the wire >> insulation. Mater of fact: The design of this type of rollover has >> changed. BUT! Has not gone away! >> Let the Ground Bound Clowns (Chinese Junk) that are penny pinching use >> them. You are a Pilot and a Builder, your plane and you are worth it. >> >> Barry >> >> On Wed, May 9, 2018 at 5:39 PM, Alec Myers wrote: >> >>> educate me.... >>> >>> why is uninsulated bad? >>> What=99s the problem with the wrapover insulation support? >>> >>> On May 9, 2018, at 17:11, FLYaDIVE wrote: >>> >>> Art: >>> >>> I have got to ask... Are you building your experimental to any specifi c >>> specs? >>> As an Experimental Builder, yes, you are allowed to experiment all >>> different practices. >>> But, I see no reason why all your wiring should not be the Best current >>> practice. >>> Those type connectors are very ancient and have all sorts of issues... >>> Sharp Edges >>> UN-INSULATED >>> Grip Support of the wire insulation. >>> No universal manufacturing procedures. Example Not Mil-Spec. >>> Un-Acceptable Certified Design (FAA, AC 43.13) Yes, I know you are >>> experimental. >>> Why would you want to use something from the dark ages? >>> >>> Barry >>> >>> >>> >>> On Tue, May 8, 2018 at 11:22 PM, Art Zemon wrote: >>> >>>> Folks, >>>> >>>> Does Digikey (or anyone) sell these terminals? http://www.aircraft >>>> spruce.com/catalog/elpages/aveotabterminals.php >>>> They are regular Faston terminals but have a little tab on the bottom >>>> to keep them from slipping out of a plastic housing. >>>> >>>> >>>> Thanks, >>>> -- Art Z. >>>> >>>> -- >>>> https://CheerfulCurmudgeon.com/ >>>> >>>> *"If I am not for myself, who is for me? And if I am only for myself, >>>> what am I? And if not now, when?" Hillel* >>>> >>> >>> >> > ________________________________________________________________________________
Date: May 10, 2018
Bob I like these rather sophisticated through firewall fittings but they all loo k permanent. Super Cubs have swing out mounts to access the mags and other a ccessories on the back of the engine. In spite of allowing extra length in cables some must be disconnected and ot hers allowed to move in the firewall. I believe Piper used a rubber grommet f or abrasion protection and then covered the whole area with a fireproof clay . It never gets hard and is easily replaced. I still get it at a commercial e lectrical supply. Any thought on this method? Bernie Sent from my iPhone > On May 10, 2018, at 12:02 PM, Robert L. Nuckolls, III <nuckolls.bob@aeroel ectric.com> wrote: > > At 01:17 PM 5/10/2018, you wrote: >> I use the flanged stainless tube feed-through, with fire caulk & fireslee ve, detailed in the 'Connection and elsewhere. > > Here's a comic book I published a years back > illustrating the methodology used on Bonanza > and Baron aircraft at Beech. > > https://goo.gl/9vLwXF > > As far as I know, they still do it this way. > A good friend and colleague of many years > at Beech was a guy named Jack Thurman. He > was dungeon and rack master at "Thurman's > House of Horrors". The well worn admonition > concerning new ideas for bolting things > to Beech products was, "If Jack can't tear > it up, it's good to go on a Beechcraft." > > One of Jack's more impressive toys was a > propane fired burner (suitable for burning > really BIG weeds) that would bathe a firewall > mock-up with 2000 DegF flames. It's a certainty > that Master of Mayhem Thurman sprinkled > holy water on the techniques described above. > > At one time, members here on the list were > fabricating welded, stainless elbows with > flanges from the ends of COTS grab bars. > Cutting the ends of of something like this > would get you two elbows: > > https://goo.gl/6Q4jkC > > Unfortunately, these are pretty 'oversized' > for our tasks . . . and stick up off the > firewall quite a bit. > > One could consider fabricating from pre-bent > elbows, a flange washer cut from stainless sheet > and a short nipple of stainless tube. If you've > got access to a talented TIG driver, you could > probably come up with some pretty nice parts > sized to the task. > > > > > > > Bob . . . ________________________________________________________________________________
Date: May 11, 2018
Subject: Re: Current Limiter Questions
Art: When you ask a question about 'are Elastic Stop Nuts being OK', you step out of the realm of experimental into certified. NO! Elastic Stop Nuts are not acceptable anywhere under the engine cowl. <--- That is per a Certified Plane. Which side of the fence do you want sit on? Not even with star-washers under them. Now! Is the Manufacture of the current limiter correct in supplying Elastic Stop Nuts? Maybe? Maybe they are just being nice supplying them. After all, they Do Not Know where you are installing them! The other question that comes up is the location of the 'current limiters' - Putting them in an air flow INCREASES the current limiting point of the limiter. What does the specs say about the safety range of them? What was the ambient temperature of the testing? Barry On Sun, May 6, 2018 at 10:07 AM, Art Zemon wrote: > Folks, > > I am installing the current limiters in my plane. The engine is a Lycoming > IO-360 with a primary alternator (the belt driven one that came with the > used engine) and a B&C Aero backup alternator. Here is the photo: > > > I tied the ends together with a piece of brass buss bar from B&C. Spec > says that it is .025 x .5. Is that sufficient to carry the load for this > plane? My analysis has these loads: > > Typical 19 amps, 29 amps maximum > > With all devices on, including pitot heat: typical 32 amps, 49 amps maximum > > Also, B&C Aero shipped the current limiter holders with locknuts that have > plastic inserts. Are those OK on the engine side of the firewall? I thought > that I should only use all-metal locknuts on the engine side. > > -- Art Z. > > > -- > https://CheerfulCurmudgeon.com/ > > *"If I am not for myself, who is for me? And if I am only for myself, what > am I? And if not now, when?" Hillel* > ________________________________________________________________________________
Date: May 11, 2018
> >There was just a long thread on this email site that discussed >Insulated Crimp Connectors. The insulated part of the lug Supports >the insulated part of the wire. It gives it a secure holding point >that DOES NOT cut into wire. B-crimp termination of wires on airplanes has appeared in the bills-of-materials on tens of thousands of type certificated aircraft for decades. I was at Cessna when the AMP Mate-n-lock products were incorporated into the wire harnesses. I too was skeptical of these 'new kids' on the block that seemed to dangerously ignore techniques and lessons-learned in the PIDG technology which was then already decades old. Emacs! The open-barrel, b-crimp technology now has a field-service record demonstrated in hundreds of millions of vehicular and stationary applications that makes them imminently suited to use on aircraft. The insulation grip does not have to 'cut into the wire' . . . as I described in the b-crimp tool comic book (and illustrated in this image from Tyco-AMP), the insulation grip should get a 'bear-hug' on the insulation without damage to it. [] These terminals were designed to be part of a harness connector wherein two or more wires were brought into a plastic housing as a female connector that mated with a switch, relay or other device. >[] > > There are hundreds of millions of examples of this technology in service all over the planet . . . including virtually all cars and trucks on the road today. B-crimp terminations probably outnumber PIDG style devices by several orders of magnitude. Emacs! My only concerns for the style illustrated were for the lack of finish and perhaps an unknown pedigree for the material's mechanical properties that go to maintenance of gas-tight electrical connection. But if these are found in catalogs from manufacturers like Tyco-AMP, Molex, etc . . . it is likely that those concerns are moot. If one wished to use these devices as mates to individual fast-on tabs, one could consider adding heat-shrink over the whole terminal . . . which offers more cover than the PIDG devices. Bob . . . ________________________________________________________________________________
Date: May 11, 2018
Subject: Re: Bus bar materials
Bob: The question that Art brought up is due to inconsistency in terms; you used the term 'dope'. >From Art's question I gathered he wanted to do two things: 1 - Insure electrical contact and 2 - Prevent corrosion due to the elements and dissimilar materials. I agree we, are talking two different products. Dow Corning DC 4 is a Dielectric Grease. By definition and manufactures recommendations it is used to COAT a joint in preventing contact by the elements. Dielectric means INSULATE. It does NOT improve the conductive properties of metals or dissimilar metals. It protects them from the elements. Which is a good thing if that is all you want to do. The product which has the industry nickname DUCK GREASE does BOTH - Protect and Ensure electrical conductivity, especially between dissimulator metals. Personally I think this particular coating process is just a bit beyond normal requirements. Why? Well, I would have to ask: Is the owner going to REPEAT the exact same process every Annual/Safety Inspection? Remove/open the entire connection, clean the mating areas, replace the lock-washers and re-coat the area [with what ever process he deems acceptable]? Human Nature and 20+ years working on peoples planes, says: No! Considering how DUCK GREASE is used, it does not require replacement and it is used between mating parts. BUT! I still think it is Belts & Suspenders and Shoelaces. Many of the certified planes out there are around 40 years old. They nBarryow have a history. Those connections were NOT opened every Annual/Safety Inspection. Yet! They continue to work! If the additional coating process extends the unknown life of the connection / plane ... GREAT! We will see in 41 years. LoL! And Art... If you want to obtain Dielectric Grease it can be purchased at Auto Stores, it comes in a Yellow Packet, packaged by Permatex. Cost: About $1.00. Duck Grease is not as easy to find. Electrical Supply Outlets - It comes in a squeeze bottle usually with a red label and white writing. Barry On Wed, May 9, 2018 at 5:27 PM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 09:34 AM 5/9/2018, you wrote: > > Art: > > The term is Electrical DUCK Grease; it is just the opposite of Dielectric > Grease. > > > We're talking different materials that serve > two different purposes. There are useful materials to > add to joints in rigid components common to high > power technologies like submarines, sub-stations > etc. These not only exclude moisture, they contain > electrically conductive enhancements for crossing > voids that cannot be closed with tension in the > bolts. > > Then there are treatments intended to fill tiny gaps > between mated surfaces to prevent ingress of water/oxygen > that progressively degrades the joint. I have a tube > of Dow Corning DC4 that has lasted about 40 years > . . . it doesn't take much. It's used to thinly coat > mating surfaces of DUCTILE terminals. Any DC4 caught > in the squash on the two metals is simply extruded out. > But the tiniest voids in the interface will remain > completely filled with DC4. Other, non-reactive > materials would work too. Axle grease is better > than nothing. The CRC product cited is good. > > > Bob . . . > ________________________________________________________________________________
Date: May 11, 2018
At 10:47 PM 5/10/2018, you wrote: >Bob >I like these rather sophisticated through firewall fittings but they >all look permanent. Super Cubs have swing out mounts to access the >mags and other accessories on the back of the engine. >In spite of allowing extra length in cables some must be >disconnected and others allowed to move in the firewall. I believe >Piper used a rubber grommet for abrasion protection and then covered >the whole area with a fireproof clay. It never gets hard and is >easily replaced. I still get it at a commercial electrical supply. >Any thought on this method? One of the venerable ancestors and gurus of OBAM aviation, Tony Bingelis, described a technique for fabricating grommet shields over firewall penetrations. https://goo.gl/1e84NX This was 'the way' to raise the lowly rubber grommet's rank to guardian of the cockpit by first shielding as much of the grommet's expose rubber as practical and finally, molding a bit of fire-putty around the wire or control cable thus covering the gap in the shield. I think ACS and other sources offer pre-fabricated shields . . . Jack Thurman would, I'm sure, approve . . . Bob . . . ________________________________________________________________________________
Date: May 11, 2018
What do you mean PROBABLY!!! Certified Planes are Production Planes and do not come anywhere near the quality of work done by most Experimental Builders. Again, GREAT WORK Mickey. Barry On Thu, May 10, 2018 at 2:26 PM, Bob Verwey wrote: > Nice one! Prolly put some of those certified boys to shame! > > On Thu, 10 May 2018, 8:21 AM Mickey Coggins wrote: > >> FWF I used a lot of flat lace along with some adel clamps and I'm really >> happy with the way it turned out. I have some pictures here: >> >> http://www.rv8.ch/fwf-wiring-photos/ >> >> I also did some testing with a good heat gun on the lace to make sure >> that I understood how it would behave if it got really hot - I was >> impressed. It basically didn't seem to care, and I could not get it to >> melt or change state in any way with the heat gun that will cause Tefzel >> wiring to finally melt and smoke. >> >> In parallel, I bought some Nomex lace, which also does not care about >> getting cooked by a heat gun, and will probably add this next to the normal >> lace in places that might be exposed to additional heat from the exhaust >> pipes. Will give some feedback in a few years when I'm finally flying. :) >> >> Not sure why, but working with the lace was very satisfying. >> >> Mickey Coggins >> >> >> On Wed, 9 May 2018 at 18:14, FLYaDIVE wrote: >> >>> Good point Bob... >>> >>> In general BLACK Ty-Wraps are UV and Ozone proof. The white ones become >>> brittle with time and exposure. >>> SOME - not all colored Ty-Wraps may also work. >>> >>> One might even find notes on the Ty-Wrap packaging as to UV & Ozone >>> resistant. >>> >>> Barry >>> >>> On Tue, May 8, 2018 at 4:32 PM, Robert L. Nuckolls, III < >>> nuckolls.bob(at)aeroelectric.com> wrote: >>> >>>> nuckolls.bob(at)aeroelectric.com> >>>> >>>> >>>> >>>> In a recent thread, TyWraps were discussed as a solution >>>> for wire bundle management. We had some discussions on >>>> these products about ten years back . . . >>>> >>>> In years since, I've had occasion to throw out stocks >>>> of unused TyWraps given that they had become brittle with >>>> age . . . the buckles would snap off in the ordinary process >>>> of applying the wrap. >>>> >>>> Be aware that not all that is plastic is Nylon 6,6. Evolved >>>> over the last 80+ years by DuPont. This material and its >>>> close cousins have found their way into all manner of component, >>>> many of which perform in under-hood environment of automobiles. >>>> >>>> When purchasing these critters, look for a 6-6, 6/6, 66 or even >>>> a 6,6 description of the nylon. The last time I was in Harbor >>>> Freight, many of their offerings bore such markings . . . but >>>> some did not . . . especially the smaller ones in assorted colors. >>>> >>>> All the wraps I pitched a few years ago were smaller sizes >>>> in various colors. Some had been in my Dad's inventory for untold >>>> years and were literally falling apart. >>>> >>>> My favorite bundle security uses Dacron flat lace applied >>>> like so . . . >>>> >>>> https://goo.gl/H3z1EQ >>>> >>>> Did a job for a rancher friend yesterday where the wiring was >>>> installed and initially held in place with some TyWraps he had >>>> laying around . . . after it was up and running, I dug out the >>>> roll of flat lace and installed a wrap adjacent to each of the >>>> TyWraps. Those plastic thingies MIGHT fall off in a few years >>>> but I'm betting the string will still be on duty. >>>> >>>> >>>> Bob . . . >>>> ========== >>>> - >>>> Electric-List" rel="noreferrer" target="_blank">http://www. >>>> matronics.com/Navigator?AeroElectric-List >>>> ========== >>>> FORUMS - >>>> eferrer" target="_blank">http://forums.matronics.com >>>> ========== >>>> WIKI - >>>> errer" target="_blank">http://wiki.matronics.com >>>> ========== >>>> b Site - >>>> -Matt Dralle, List Admin. >>>> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >>>> ========== >>>> >>>> >>>> >>>> >>> ________________________________________________________________________________
Date: May 11, 2018
Bob: You are mixing Apples and Apple Sauce and coming up with Lumpy Apple Sauce. Those are PINS not Lugs. The Pins are supported by the connector. The Lugs are hanging out into the air. No support! And that is why PIDG type Lugs are preferred! Barry On Fri, May 11, 2018 at 9:11 AM, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > > There was just a long thread on this email site that discussed Insulated > Crimp Connectors. The insulated part of the lug Supports the insulated > part of the wire. It gives it a secure holding point that DOES NOT cut > into wire. > > > B-crimp termination of wires on airplanes has > appeared in the bills-of-materials on tens > of thousands of type certificated aircraft > for decades. I was at Cessna when the AMP > Mate-n-lock products were incorporated into > the wire harnesses. I too was skeptical of > these 'new kids' on the block that seemed > to dangerously ignore techniques and > lessons-learned in the PIDG technology which > was then already decades old. > > [image: Emacs!] > > The open-barrel, b-crimp technology now has > a field-service record demonstrated in hundreds > of millions of vehicular and stationary applications > that makes them imminently suited to use on > aircraft. The insulation grip does not have to 'cut > into the wire' . . . as I described in the b-crimp > tool comic book (and illustrated in this image > from Tyco-AMP), the insulation grip should get a > 'bear-hug' on the insulation without damage to it. > > [image: []] > > > These terminals were designed to be part of a > harness connector wherein two or more wires were > brought into a plastic housing as a female > connector that mated with a switch, relay or > other device. > > [image: []] > > > There are hundreds of millions > of examples of this technology in service all > over the planet . . . including virtually all > cars and trucks on the road today. B-crimp > terminations probably outnumber PIDG style > devices by several orders of magnitude. > > [image: Emacs!] > > My only concerns for the style illustrated > were for the lack of finish and perhaps an > unknown pedigree for the material's mechanical > properties that go to maintenance of gas-tight > electrical connection. > > But if these are found in catalogs from > manufacturers like Tyco-AMP, Molex, etc . . . > it is likely that those concerns are moot. > > If one wished to use these devices as > mates to individual fast-on tabs, one could > consider adding heat-shrink over the whole > terminal . . . which offers more cover than > the PIDG devices. > > > Bob . . . > ________________________________________________________________________________
Date: May 11, 2018
Subject: Re: Firewall Power Lug
With all due respect to Tony, he overbuilt his dies. Place a section of thin stainless about the size of the palm of your hand o n a scrap of soft wood.=C2- A scrap of pine 2x4 will suffice.=C2- Place a=C2- larger size socket on it and whack it once good and hard with a go od size hammer.=C2- For a pretty job, you'll want to make two, and cut th em off-center, then attach so that they overlap.=C2- If you're not worrie d about appearance, cut one, install so that they overlap, and don't worry about the center not being circular.=C2- The same silicon used for cowl b affling can be used as a fire-barrier and is not as messy as clays and asso rted goops.=C2- Just cut a circle with a hole in it that will fit inside the depression. On Friday, May 11, 2018 9:21 AM, "Robert L. Nuckolls, III" wrote: At 10:47 PM 5/10/2018, you wrote: Bob I like these rather sophisticated through firewall fittings but they allloo k permanent. Super Cubs have swing out mounts to access the mags andother a ccessories on the back of the engine. In spite of allowing extra length in cables some must be disconnected andot hers allowed to move in the firewall. I believe Piper used a rubbergrommet for abrasion protection and then covered the whole area with afireproof cla y. It never gets hard and is easily replaced. I still get itat a commercial electrical supply. Any thought on thismethod? =C2- One of the venerable ancestors and gurus of =C2- OBAM aviation, Tony Bingelis, described a technique =C2- for fabricating grommet shields over firewall =C2- penetrations. https://goo.gl/1e84NX =C2- This was 'the way' to raise the lowly rubber =C2- grommet's rank to guardian of the cockpit =C2- by first shielding as much of the grommet's =C2- expose rubber as practical and finally, =C2- molding a bit of fire-putty around the wire =C2- or control cable thus covering the gap in the shield. =C2- I think ACS and other sources offer pre-fabricated =C2- shields . . . =C2- Jack Thurman would, I'm sure, approve . . . =C2- Bob . . . ________________________________________________________________________________
Date: May 11, 2018
Why are you installing "lugs" that are hanging out into the air? Me thinks the problem with lugs is caused by the problem of not following a nother good practice, which is that the wire should be tied down in some ma nner to isolate the crimp connection from vibration.=C2- You have to anal yze the whole system.=C2- Not just one connector style. On Friday, May 11, 2018 9:58 AM, FLYaDIVE wrote: Bob: You are mixing Apples and Apple Sauce and coming up with Lumpy Apple Sauce. Those are PINS not Lugs.The Pins are supported by the connector.The Lugs ar e hanging out into the air. No support!And that is why PIDG type Lugs are p referred! Barry On Fri, May 11, 2018 at 9:11 AM, Robert L. Nuckolls, III <nuckolls.bob@aero electric.com> wrote: - =C2- - There was just a long thread on this email site that discussedInsul ated Crimp Connectors.=C2- The insulated part of the lug Supportsthe insu lated part of the wire.=C2- It gives it a secure holding pointthat DOES N OT cut into wire. =C2- B-crimp termination of wires on airplanes has =C2- appeared in the bills-of-materials on tens =C2- of thousands of type certificated aircraft =C2- for decades. I was at Cessna when the AMP =C2- Mate-n-lock products were incorporated into =C2- the wire harnesses.=C2- I too was skeptical of =C2- these 'new kids' on the block that seemed =C2- to dangerously ignore techniques and =C2- lessons-learned in the PIDG technology which =C2- was then already decades old. =C2- =C2-=C2-=C2- The open-barrel, b-crimp technology nowhas =C2-=C2-=C2- a field-service record demonstrated in hundreds =C2-=C2-=C2- of millions of vehicular and stationaryapplications =C2-=C2-=C2- that makes them imminently suited to use on =C2-=C2-=C2- aircraft.=C2- The insulation grip does not have to'cut =C2-=C2-=C2- into the wire' . . . as I described in theb-crimp =C2-=C2-=C2- tool comic book (and illustrated in this image =C2-=C2-=C2- from Tyco-AMP), the insulation grip should get a =C2-=C2-=C2- 'bear-hug' on the insulation without damage toit. =C2- =C2-=C2-=C2- These terminals were designed to be part of a =C2-=C2-=C2- harness connector wherein two or more wires were =C2-=C2-=C2- brought into a plastic housing as a female =C2-=C2-=C2- connector that mated with a switch, relay or =C2-=C2-=C2- other device. - =C2- =C2-=C2-=C2- There are hundreds of millions =C2-=C2-=C2- of examples of this technology in service all =C2-=C2-=C2- over the planet . . . including virtually all =C2-=C2-=C2- cars and trucks on the road today.=C2- B-crimp =C2-=C2-=C2- terminations probably outnumber PIDG style =C2-=C2-=C2- devices by several orders of magnitude. =C2-=C2-=C2- My only concerns for the style illustrated =C2-=C2-=C2- were for the lack of finish and perhaps an =C2-=C2-=C2- unknown pedigree for the material's mechanical =C2-=C2-=C2- properties that go to maintenance of gas-tight =C2-=C2-=C2- electrical connection. =C2- =C2-=C2-=C2- But if these are found in catalogs from =C2-=C2-=C2- manufacturers like Tyco-AMP, Molex, etc . . . =C2-=C2-=C2- it is likely that those concerns are moot. =C2-=C2-=C2- If one wished to use these devices as =C2-=C2-=C2- mates to individual fast-on tabs, one could =C2-=C2-=C2- consider adding heat-shrink over the whole =C2-=C2-=C2- terminal . . . which offers more cover than =C2-=C2-=C2- the PIDG devices. =C2- Bob . . . /9j/4AAQSkZJRgABAQAAAQABAAD/2wBDAAEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEB AQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQH/2wBDAQEBAQEBAQEBAQEBAQEBAQEBAQEB AQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQH/wAARCAEjAZADASIA AhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAAAgEDAwIEAwUFBAQA AAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3 ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWm p6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6/8QAHwEA AwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSEx BhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElK U1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3 uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD++iii igAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAo/wA/5/z9KKDwRjnPX24z/wDW 7c0AJk7mGPlGNp4+bOc578cdfw9loooAKKKKACiiigAxn2/P+nNGAOhz+JP86KKACiigBicYH5/4 gUAFFO2N6fqP8aNjen6j/GgBtFBDA4wPz/wBooAKKKKACiiigAooooAKKKKACiiigAooooAs23+q H1b+dT1Bbf6ofVv51PQBn0UUUAFFFABPAGT6CgAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAopcHuCPcg/wCFJhieFJGcbhnH16fyz0oAKKfsbnIP6frkgj8qTbgFiy4AP8Q7fj/+ rvQA2kyB1IH40uUzgOhz/tqMn0ALcn2FRTz2ttFJPczwxW8EUlxcXEssUUFtbxIzyzzyyOEiijRW eWRyqRorO7BVJAJtLdpepJwQecDucgAenPQZ6e/SlIWNHkkkVEjVnkeRlCRxoCXkdmIVEUAlnYhQ ASSAM1+KH7WH/BbL4D/Ce/174e/s5aOn7TfxR0WSey1jVND1qDRfgh4JvbZjHO3iv4ptFdWmqT6d MqmbSvCMGrStloJNQspfu/hF8Yv2y/2gv2qrG+8RfG74oa34x+H8b3BuvA/g7xTqH7N37Inh5PNB az8QeK7O7X4g/GOe1JSKSyF7PFOyB4oGEz5fJUceeMUo6e/Uap02m0rxnKyk7uy1UW9Oe6aXwue+ IfD2S1ZYSFd5lmMeZPB4FSrezcbKXt6tKNTlUG0qsaFPE16N06lBQcpR/qX+NP8AwU1/Yo+Buq3X hTxD8atJ8Y+PLfzQ3w8+D9hqfxa8cJLE2HtrnSfA1vq8ekXQII8nWb3TWAy2AqsV/Oz4qf8ABefQ fDnnp8P/ANmfxP5Gx1t9X+OHxN8FfCtmmVuGPhLSB448UvCV2EfaYdMmyxUw8MR/NHoGt/E343+I Jfg3+yp4W8R/FG9D7X8IfsyeAX8G/DXSlYEPcax4gNsmsajHkMlxrfia8sVvSkl00srOVP3L8M/+ CBv7f3xPNvqXj64+EnwOtNQCzyReJ/FN14x8S2qSKJGa60zw1ZalC92zEFlbXkZXBWXyzuxrClRv H2+IkrrmiqMJJSXRvmipwba+Lms1s3Gzf5zX468SM+nJcK8ORpYeUrU8bUpQnBcrs4/Wq06uDqtb qUY0ZN3vCDWv0V4t/wCDiL9o1JpBoXgH9mHRIlkZVia/+Kfi+4x333MMOiWjmM5UyRqkZ6gYrzgf 8HGv7WFlOBceEP2b9RUEN5SeH/iPYq69lE516bbu6bwhUdyK+jPDf/Bset1ahvHn7Y1+l2wHmweE PhNaC2L/AMYW71nxh5+3IBBFqjcnNa+pf8GvHw5uIWOnftj/ABFtbwAmOW8+F3hm7t1c9A0MHiax dkHG3MxdOdrVtGOXpWlGs3pZ+1q9bXvafTy8/QUMu8dKzVSrmeGoXs/Zp5Omlu/dp3inbRp3T6Ws 0cX4B/4OXfFUU6R/E39mrwRrcBQCSf4d/E3U/D94mCqySLp/i3w/qVvcMPmKxDUIAxwFmBDGv0++ BP8AwXP/AGEvjFdado/ifxV4n+BHiHUGjgjt/i7osVh4ZkvJQimGLx1oVzrPhqJRK5EVxq15pETK u6VIS21fxI+KP/Btd+1x4OsbiX4I/tI/B/4rQIrCPw18SPC2peCL65QksBb6tbp4rsreeTasYEkq KGPM6KNw/Db9qD9kr9tb9iq9lu/j9+z14y+Hnh5p5IV8baIB4u+Fd+6ttEkXi/Rpb3R7Lzgystrq s2nXJDJEsLO22s3RwkrqFarS2d5NVqavbSSmnV9WppJO9rvTujmvizkCjUzDC4TOqMHerCWDhSco qzap4rAVGo2jv7anNLeMXZp/6fWh61onifSbDX/DWt6V4i0HVLeK60zW9C1K01XSdSt5hujuLHUL Ga4tLqGQEFJIJ5VYchyCANUDgEcjHBHII9cjg/Wv8zL9ij/gpp8ff2VfEdnqHwb+I17oumT3UUmu fDPxDLNrPwp8WKpLzW2o+F57kW+j3lwC8Q8Q+HTpmqweZ5gnlVVjf+4//gnt/wAFTPgl+3XocPhq 3jT4bfHrSNJS88S/CXWNRguG1C3t1WK+8QfD3Vm8oeLPDsUhDzxpFFrWkLIsWp2QUJeT41adSgoy ny1KUmlHEU03TbbSSmt6U5Nq0J6XajGUpqcY/a8LeIWU8RVv7OxFOeT53HSWW42cU6ztq8HWfIsR s703GFZJXUJR94/T6ikGf7pwejdj+eD056EdecjFLUJp7f15evkffhRRRTAKKKKACiiigAooooAs 23+qH1b+dT1Bbf6ofVv51PQBn0UUUAFKCQQRwRyKSigBSSxJPU9eg/lSUUUAFFFFABRRRQAUUUUA FFFFABRSZHOeMHBJ6A/7X90d8nA9DnisrV/EOg+HoBda7q1lpkRG5PtUypLKAcfubcbri4JOAFhj ckkADJGS+tur6dfuA1qDn0J9gMkfWvI774qSXBZPC/hi+vomJC6vrrnw/pG4D5ZY4p1k1K8QnDER 2cRC9CCcVxGreJvEt2PN1rxodHtOrWPhaCLSwML/AKttWv8A7XfyLxgyW5t2fkfKPlreGGrTjz8q hD+eo+Rb66Nc22qbVn0uQ6kE7Xu+y1fTt69D6Lu72x06A3OpXtrp9uv3pb2eK2Qc4GXmeNVyf971 9hxVx8TvBUDvHBqsmrzI23ytCsb3Vcso5AmtoGtjk9xcFeM7gK+d0fTtQuRJo3hjU/FWoEllu7iG +12YuTlnN5qrPbQknOTujAGeMcHrLfwh8VNXVVTTtO8PWj8BdSv4hIint9k0xZVwM5Ch1z/eFXKl QptKeIUna7jTje17Wd1zPTVaxSfRuzJUqkn7sEldaykouztbR2W129dNr3O8u/itPuI03wdqBhxx da5qumaIpOSSRb+be3BUDbkMkcnXKDGTy978WPEioS1x4Q0lQDxFDqmtzKCeMs0umw7gPunDIx55 U4pkXwN1u8IbW/HskIY5eDRNKijJHAIFzqMlwwBXgnyQTj1rTt/2d/h6pB1N/EWutnD/ANo61cRw yYzhvs9h9jReegBIxjI6is3UoRuoUZzl9mVSVovbVqLfpZxS892WozduapGK0vaLk13tdJX7Lbpf qeZ6h8YblEcX/wARLqKMBix03TvD+lsOnybnS6uFI6FvNBXOec8eaat8e/DFoGF544169xkKh8R3 RYnHTbpkcZyT2Ddeh7j7Dsfg38KdNeNrPwF4eZlx+8u7MXsuR38y8e4JLZ5z1Iye1dhbeHfDNggF l4d0OyMZCr9m0jT4iiqeFzHbKBnopBPQnFSsTUSXLQwsJdHJSm++ycVJqze9rdNLj9nSTTlOvNX1 Sah2s07yta38vV3W5+Xeu/tK+GYQ507wt468UTDIQ2Wl+OdZ8x8HAVkMkbA9NwwCcDPNeTap+0R8 UL6Rx4Z/Zn+Kt8pjIWR/h74r8sk9GBmjLN1zkk9iMZAH7WX+r6Zodi99qt/ZaTp8CjzLq/uLawtI FIyFea4aCBMYIGWGSCoyRX5Aft9/8Flf2ff2SNDn8L/DTUtH+Pf7RGs2o/4Rf4ZeG9Vb+xNAFwGi tvE/xO8R2qtb+HvDsEuJI9Ptpj4g1oqkFnb21vI2pQebWzKf1yjl0c1y+jmGJp1a2GwEadD67XpU XF1qtHDTxLr1adFNe1qQhKnTi06ltGZ43GZVlWXYjNcwhUo5fhEliMZWxM40ITn/AA6blTw6vXqN ctKhDmq1pNQhTnNpHxn8f/28br9mbw1YeLfj18MPEHw7stbuLiy8JaPq/hq5s/E3jfVraE3B0fwf od1cwXmq3hUqtzdmKHStMEiSahewKCT+B37Uf/BQT48/tUM2n+NdSl+DvwbjLzaT+z58O9Wls9S8 TWzZNpqnxl8ZQzRXuvHBWSTRlex8M2EzYt9Ev5M3sny5+0v+078RfjH8Q9X+Nfxz+Is3xR+LOtw/ ZV1m5t5YPDXw806e4eWDwT8NvDW+Sz0bT7WQpEkOnQvLeTBbu7nv76eW6Pmnh/4DfEbxzcJd+On1 DwNo926XZ0Gdv+KpvI5WDC416I4bSJZUIaOwuCL6GNh9pt4XJjEcRcU8PeHuQVs/44zyhhcNBpUl UpwVevV5edYPLcFhacsRj8ZK0m6dGFTlipVJOnRhKsfg081458aM/wD9U/DLKsZh8tvy4rFxqOnO WHcoxljMyzGbVDLsCuZRcJSgnKcKMvb16kMOvRvC/jHWfFskugfDXwbbeM18MQRXV3AIpNL+D/w6 sllWG21rxnqgjFvcoJgywvqhZrq9ja10rTdVvJY7avevAv7NMfxm8TW+qftCeP8A4wfGOKwmFroH gz4ceBPFPg/4WaRCgVXhjvb2zsbp7K3n3C2h06y8OGS3jSa6jYsQv0V8BtQ/Zn/Zd8Lyi+1HwDol 9dyW97qt/wCM/Ffh/T4pryzEpt7maDXtWgiuLmyM0rQXTWUk0LTv5DKcivTPEP8AwVO/ZT0OE/bf 2l/hTFFkRmy8OSeMPGt4MjBcQ+DPC+r2DEng4vlUYXGACa/z74s+mV4wZ7nVXDeD3gNxDxFl1GpU jhM0zXDZni6Fd8yVKtPCZVglShFw5W4xzZpJtOrJKPJ/VXBv0WPDfhDA0q3HnGWV184kqc8U6uNw mCw8KsYxco0KOOrOrioQqfwq2KwcJS5f3eFwzbpr9gv2Tvi9pH7MPw40jwH8PpvEPh/wvptvbwJ4 Xg+FfgzTLRWtYVjV767s9Dsdd1u8Kptm1TVdXub+6YtLLO7MWP2nY/8ABSXSNOKx634F17VYowC0 uk6RHpk0i44CR32sPAJSxyVYRxn1zxX8qWq/8FdP2RbeGSaH4r/ETxGwAZU8IfA/xBdmRXBwIZfF Ot+F1YHHLNGuP4iK8cv/APgtJ+zjFLJHD4d/aVv4wHC3D/D/AOFWlLIEODiG9+J8lxxwfnBdCQCu AWHm0fGT9oJnD9thfA3gHLaM1eFPE5TmWHxCTa1lUzHxAwadR3s1OjHr7t3G36FHh/6PeASo1PET EzdG1Plw+Pp4ilBqy5IwwmR1IxjFWioxvFKyWh/bNon/AAUX+BGpw51Kw+IXhqcBAbfUfC0d9hmA 3bZdH1G/TYh4LSeXk/dXGBXeaf8At0fs1XwIfx9caa6qSV1bwv4itHOAeAo05wSccAcnse9fx5fs 6ft1fs8/tPXf9gaJ4++Mnwx8a3Nw1vpWh/Ef4KSz+H9dBdVtxY/EHwP4h8R+FNPubh3WJLPxJcaB ErgkX5Yc/S3xHk8W/CzUptK8Q+IPEGlalGqstj4j+HOvaTI8Ugyk9tc2upaha3VrIozFcxSOkqfM m4Yz1f8AEU/p/wCVr2+Y+EHAWNoRi3KjRwOMqVmkk9HlnHOKaktU48ju7Wb1R24bhjwNzRShlvHG ZOTbipe1tGMrpR5pYjJabSbTs9L66Wul/RT4t/4Kl/sO+A5X/wCE0+Md14ctYneN9W1D4a/E59GR 0IBB1Sy8I3dmFBwQ7yhBnO/pVPw3/wAFM/8Agmh8co7vwJp37Wn7OXiyHXbSew1Lwl4w8TaTo9pq ttcDy59OvtI8dWul293HcB/KksriGSSVW8tYmzX8xOm/tIiO9TTbnWdGup5D5f2O5e80ya6y+wRL b61Y2sUiyttKgSPltqglmVSz4oeB/gT8VjNonx1+CejDWTHCkt1rXhZtA8VWI2qbaeHV7e1s9WgU o4eKQzmOYMM5iCissF9ODxA4XxUcL4s+BWa5XSjOMMZmnDWNxDVDmSadLJs6w8IVZaSbjLiKjdaw TacXWO8C1j6TrcI8Y5bi5cvNTwea4STVZLlvKeYYDFc9Gm3aHN/Y9Zpuzb2Prn/gph/wbx/Cn4z+ GNc/aN/4Jsz+HvB/xDFpca9dfBfRtZtrr4RfE7yY/tU8fw/1O3nu7XwJ4nu1B+w6dHdf8IfqtxJF bNDojSfbK/kw+E3xs+IPwf8AiWvh3xBP4y+Enxh+F3iuSzjkn+3+F/G3w+8ZaBcmJ7eVZo4bjTr6 0vEK3VrcRPbzws4eO6s7gib9ufDn7OHxV/Z5uR41/wCCef7Wfxd+CGvwyw3CfDvWvFZ1/wCG+sfv hLLDdWd7DNZpFIyKZIdV0jV4ZlcROqKxdvzw/wCCpvxJ+JP7Q+k6Z8Tv2lv2b2+Fn7bfgZtP0M/H X4R6ZbW/wm/am8IWS28N1pnxI0aS6SLQvH/hq1eO/wDCPjXw9dT2l5ZtdeF9a0e0t5dLl0/+tPCj 6R3hZ4tqGG4R4kw7zipF/WeEs7p/2RxC/dg6lP8AsrGaY6ahKUp1skr5rQgo1PrFdJXj/LHix4PZ 5lNCeOz/ACCtkeKwMliMFxZk1WWPyBVacouEq+ZYSlRxOVRcuVwqZzgcrSm42lz6r+2z/glB/wAF PdH/AG3fA5+HnxKn0jQP2lfA2kwz65p1rIltpnxN8NweXD/wsTwrbkhY597Kni7QYGkbRtQnS9tV k0i9geD9iV5Gc7s8ggYBB5XHttIPVuc4YjFf5O/7FX7VvjDwP4w8HeMfAfia78J/EfwBq0Gq+F9W DyRXVhqdgQt1pOp27AG60+/US6bq2nTo8N7YTz2rhwTs/wBKT/gnz+294L/bp+AWmfEjR4bXw/4/ 8PXMfhX4u+AI7jzpvBvje3gjlnFuZMTT+Hdet2TWPDeoOoWbT7n7NK32yyvFT9tnTVFwak3QrN+y k9eSejeHnJuUnKmv4bk1KVNWk51ITm/nOAOMcTm/t+H8+So8RZVCPPNuMVmuEjaKx1OKtaqvdeJj BKnL2lOvRSp1HCl9y0UUUz9NGBxvMbDDEFk/2kH3j7EHgjPvin0UUAFFFFABRRRQBZtv9UPq386n qC2/1Q+rfzqegDPooooAKKKKACiiigAooooAKKKKACij9foc+2D6HJAwec8YrgvEHxC0HRbl9MtR deIdeUHOi6IqXEsDcEHUbwstlpafd3fa7hJcHIt360K8mox96T2S1b7uyvt93mJtJXbSXd6I74Ak 8fljr2A9uSD0JOMAZIride8f+G/D8zWU91JqWr7QI9E0WI6hqjS4PyywQkpZRkgky38lsicgsxHP m2pah4u8RxSSa3qy+HNFOGbSPDs5inMPO5dU8RECZ8jAeGwhs0AIxJJ2i0PQ2kiNn4S0RI7Z9xuN SkVrPTyxIzLPezKb3UpWIVmIZjITkueK644ZQSniKiprdQjrNrtquVPuk35MydSTuoQbd7c0k1Fb ara/3/8AAt6j4q8aa6hWOW38E6WyyZjtWg1PxDKh2kGa+lQ6bpQIJBEEFzKCDi5RuK5SysbJ70vo 2k3/AIk1xmPmapK0uq325toYy6vfMYbaPcMnyHj2AEIgC167YfDy0wk3iG8l1mYMG+xRZs9JiYdA tvERLMFJ6zSFW+8RkEV6DbwQWcKW9pBDa28YxHBbxpDEo74VAMk4BJOSTzkkml9YpwSVClb/AKeT 5vaX+b06f5K7K9m38cnJ9e19Nk722/HoeL23w88S6q4k1rWLfRYDtY2Wm7b/AFAgMCQ15J+6hOfl cxxSkHJ3MRXZaZ8NvB2msszaWNVuxgtd6y738jOOdyxzHyU5z92IDnoDXd/45/H1+tBPIyeTwM8m uedWc9ak2773bUbu3TZ62tf8y4xUdkl52V7+u6+VhI1SFBHCiQxqMLFEixRqOwVECqMdsCnBmHcn jHJJx9P89zTNyg4yM5x9SOoHqR39O9eJfGD9o/4K/AuwW4+I/j7RdFvp2MdloMMsmp+JtRk4XyrH QNMS61KQ7mUGaW3ito2ZRNPGGXPkZvneTcP4Ctmmd5pluT5dQ1rY7MsZhsDhae+ksRiKlOnzPlly w5nKTTjCLlodWEweLx9eGGwWGxGLxNR2hQw1GpXrS/w06UZTa7u1luz3AIW5DEfjj+lZWra1pWga dc6vr2p6do2lWSNLe6nq19b6dp9nAoJea6vLx4LaGNAMvK8qRqDyRjNfk58W/wDgpLcx6NO3w+sN P8Bx3dmXstb8dW41TxKjtG5WaPwVbTQW+nzKxjdE1bUJwRgPbxnivyp8UfFb4vftQeIZdD0/RviZ +0prlzqcF5a6Zq9lPf8AgnQruKIJDLp/hXSorbwpo1hFI8lyx1ma72l/MMkXl5b+P+MfpueHGAxt TJPD7LM98R8+VZYWnTyvBYrLssq13LkdPD4rGYX69i6tOS5oexy1YLERjONLHuUoX/V8k8GOJMdS WMzqtheHsBFKdWeKnCtiIU1vKpTjOGGpRte6q4yFWFrSpJtI/oF+JX7cPwf8CadfS+GjqfxU1m0h ZodN8GCzi0qe4AP7ibxdrlzp/hy0RB88sy3lyY4wX8llZa/Nj4p/8FJPilr88lro2veEvhTp0qbB o/gyzj8e+OGnl2xiOTxZrUcPhmxlVmdN2k6DNLHOFZL19qeZ8tfED9ne++E3hqP4ift7/tPfDr9m vwbHGs1t4Ih1iHxV8R9XjKDy9M8PeEtFLpeX7hVjt7fSrXV3iLIkoEatLH+Xv7RX7b/wF8QeCtc+ F37BPww8b6JcXAl0r4gftVfGtbKXxhp2hzQNFc6X8K/CsUstl4V8S6+jyqde1GNtY0Gxlb7LZW96 0d3b/E4el9Nrxrk6Ptsl8HOHcdKKvTpV8szWlhZKLu4RnmfElDExSu516+VUa7ko0owvJGXEfE3g B4TYOti86zKXFmZYSmqksHh3Sx8qtXmcadKnCUsPllWlXqRaTjRxU6SjJyqwUJSez+1p/wAFHPEE V/qvgb4Waxq/jn4rRRy2nif4u/ETxBeeO7L4X/aN4uRptjqEq+HLjxkkcpktdNsNOh0rRGZJLiGe dBaJ+NS3viPxR4lg8MeD7DxL4/8AiL8QNTkLvEZde8b/ABE8R3oaS7u57y52yR25hR7nUb+4mttN 0rT7ea6vrqw0203w7WmeF9V8WXln8Ovh1ptgs9vaX+tapf6xqltomg6LounKLjxB8Qvij4x1J00/ Q/DWjQh73XPE2r3SoSxghjub+7tbefpPDfw1+LH7QX2/4Af8E8fg78aPj/8A8JbaN4c+Nf7QuheF r/wbo/xS8+dDfeE/D/jTV0s0+GH7O9rKscMuj3GqaV4m+KCQx6343uoNKktPCFl/Zvhl4W8LeC+T TweW1cXxDxdnFOlW4o40z2pLFcQcSYuFqkK+Y4ycpTwmW4epUn/Z2S4ebw2G5vaOVXH1Mwx+J/hH iXi/jP6RPEX9o5lTnw5wDlmJnRyLhzK4NYPCU4tJ0MBQjBQx2YThKNHH5nWpe7FJSWHwssJgn8m/ Ej492vwK16Dw18Cm8MfGr9om2uWj174n29hF4v8AhV8FLqMSI/h34LRGVtO+IXj+0lGzXfjLdW95 4Y0e5iOmfDey1SWJ/F4+bNd1n4/eM553+MHx78U6a19O00mgW2tyw6lI9zIzmNtA8NbLxnmMpXy7 54ZJXZS2CwY/1x/sk/8ABrJ8YNcsdM1X9sH44+Hfg34akEMt18G/2b7CG78QPABhtO8QfEPUFNl5 7REQzSWUWvx7lZo7hVCoP6Qf2W/+CPP/AATs/ZENnffCv9m/whqniu0UBvH/AMS4F+I3jKaZSWNy l/4kjuLGxuWfa3n6TpmnYwCqggAfR4zJMpzbH0c0zPKsDmWY4ePJhsdmOEo16+Eg5Rn7PBOtTqSw dNySc1hlS9pyU5VZ1akFUX7NkGXZvkeTrIskry4cyiT56+EwdaopYyfLyxrYxUpxWNr2ck6uNnKU XKap06VNxpR/zb/2ff8Agkr+1p+0zf22o/BL9k340fEi1uXXZ8RPHWnzeDfCbJJJsS8OseJZrWCa Fd6sGXUrl1A3SKDX7qfAr/g04/ar8XJYXvx/+N3wg+CemTGNrzw94L0zUPiT4lt0DDdE1xA2j+HE uQgwZo9TvIi4ALyYGf78YhHBDHBBFHDDCiRwxQokUUSRgKiRxIqxxooACqgVVAwoGKCxb736455z 29CM89+a9WNFRsvdUU01CMWoq1rW5pTlo0mtfRI7qXD+GvGeLr4nG1ErN1akoU7O17U6UovWyupz qLsj+az4Gf8ABrX/AME8fhsltc/FXxB8Yvj7q8bLJcDXvE8PgbwxckKAF/sDwTbWV3szn5bjX7lm U7HB5J/Vr4V/8Esf+Cc3wUNtL8PP2OPgPpt5axxxxanrPgjT/F2qkxoF859T8Xrrl41w+3c8wlDs xJz0x98+nsSR7E9SPQnv60YB6jNWoRSs/e3+LX5a9j1KOAwWHSVHC4eDSspKlDm7/G05P5yb89Dn tE8JeEfDFtDZeGfDHh3w3Z28YihtdB0XStJt4ogAojjhsLSCNFCqAAgUACuL+LXwO+FXxx8PTeGf ib4S0vxJZPDJDa3NxCsWq6W7qQs+k6lGi3VlPFkMhjfy/lzJG43A+qYHoPyFLV/1ppp2dt15bHUk lZpLS1tFpbb7j+aD9p//AIJjeHfhFez69f2F/wCMvg7f3Txp4ms4l/t/wQ9zI8cKeIooYzEbDMgj j1m3UQsXVrkW7gE++fs73GleGNL0f4O/tIWWh/H79n7UjaaX4C8f+NNNi1nxp8KZp/Lt9N0TxFrD A6pe+BpS1vZ6XrdvdrfeGJJEjvpjpMyDT/3Y1CwsNXsL3SdVsrbUdN1K2ks7+xvIkntbu1uAYp7e 5hlBjkhkiZwykE9McgV+NXxW+Erfs/fEhvCNvFLcfCrx2t9eeCDOXnj0yTCjWfB12zghxZLKjaW7 sWk0+TaVY2zEePmHDmU5u5SxGCwssVKk6MpzoUqlLG4d2c8FmVCrGdDH4SauvYYqFSMJWqUPZVYR qL08NmuOw0Y04YqtCnCSnTcako1cPNf8vcLWjJVMPUW8nSlHntaaady78bv+CRngbWPtevfs8eM9 Q+GWtESTQeF9eludc8G3crHcIobtGfWNKifftRpDqsQG1xHGAyn8gPjt8F/i/wDBKO78G/tI/CiX UvCV+j2h19LNPEngfWbRXjZiuqW3nRRIxW3doLhraWMKFmhhJeOv6bf2V/iI/iTwnd+B9Xumudd8 EJbwWU88nm3Op+FLsumjzszkyTSaYYn0m6c5ISCykmPmTMT6d8ZfhB4Z+N/w+1/4e+J5tU0y21a2 mGn6/oN42na74c1TyiLLWdIuo1cC4tJcSSW10sljfRM9ve2tzBJ5Y/l3xJ+h14WcbTlmuQ4Op4fc Txqe1oY/h1exwNPGQ5XTqTytSp0sM4VIxnTnlU8unFqFV+0lCFv0nh/xj4myqMcLm0ocRZdyuEqe Pk446NOSSkoY6N51LxSTWLjiFb3G1F6f5+nxN/4Jufs6fE65fx98EfFusfB/4iiVr5BZSWuveCdd kI8yCy1fQJxbX+niJkEUep6XqAuLeAMJ7W9CqF9h/Yf+NP7Q3/BM/wDaQ8I/E7x3o+oal8I9ZFr4 E/aBg8Ix3Wv+HvEnge6uiNM8a2UVtELiLxH4Iu3XWbSJ4WvBp8mq6c4aO8cJ8xftzfH744/8E5f2 n/G/wI/aV+E2m+PLXSrxNW8HfFv4VLF8NfFvifwXfGSbS9d1TwysF18PfFN3JbOqajPpll4RlkvE uY5/MmV2rsfgT/wUd+DfxfsRb6V4lj1JSkcN54e8WaaND8Q2s2MiG70+6Mun3rKV2iWzvbiKVlUw EZCD8io579K/6P8ATq4bOZR8ZeBaE3apmFTE4jNcFh6couNXD57To/2rg6iSU4rOYZphI3VOhS9n Konli+AvBPxSzDBZrkVWXh3xrgpxjRll1LCYOM6tTfCYnKJOplWPw9WMpxcMG8BjJRlpXjGKi/8A RX8P67o/ivRNH8TeHNTs9a8P+IdMsta0TV9PmWex1PSdTt47vT7+1mQlZYLu2lSaN142sAfmyK2d h9R+v+FfyI/BT/grv4R/Yl+HVjf+PviNplx8EtKjZNM+H3iPVZ7/AMRRxFmkXQvhfD5kuutcBpJT Y6OsN5oiFySunW6i6T5i8ff8HU3xJ+Kfxe1bQ/2XPhv4c8EfD7w5p/8AaOgad8VtO/tzxj8RBprl tTttZk0vVIdN8Ope2sm6wstEury5tWiV5dRnYyRV/V3hR41ZR4rcO187y7h3irJ8RgcVHA5hgM4y qWGprFuHNU/s3NXUeVZlh6bUoydPGU8VRfLHE4Sg50+f5rirgrMOE8whgMbjctxMatN1cPiMNiF+ 8pqUYJ1cI74rDVJN3UJwlTdpezrVFFs/uIPBI9KK/nt/Yh/4OJ/2RP2k5dH8HfG1Jf2bPiPdrBam fxHeHU/hnquoSZj8uy8WpDFcaEZZQBHD4ks7WGFm2SapLt3V/QDpetaLr2m2WtaDq2m63o2pQR3W narpF7banpt9bTKHhuLO+spJ7a6glQ7o5YZXRlIIY5Gf1zC5hhsXzRpzcKsFerh6ydKvTWnvSpTt J023aNWKlSnvCclqfJ1KNSk0pxsm7RkmpRk7XaUo3TkvtRvzR2kk9DRooByMjoeRRXbvsZBRRRQB Ztv9UPq386nqC2/1Q+rfzqegDPooooAKKKKACiiigAoooBGcZAPfPbPAJGRwD1zgevFACc5AAzn9 On5/SsLxD4m0TwrYnUNdvI7SAuIreHa813f3BGVs7CziDXF5cuMbYoUc4JZiqAsOR8YfEIaLet4b 8OWB1zxWII5ZIpHaDSdFhnjEkN5rl6qMFLRsJobC3D3NwmzDwo4mrg7Hw3Mb6HXvFF7ceI/FF8rC 1Y2/75VYhjaaHpeTDoumLxHJdMDLOwWeWSRgTW9Og5x9pOSp0rpObtzO+zhG/vX2u7JeehlKpZ8s VzTf/gK/xP8ATcsahrnjLx0XiBufBvhXYS9pBcJF4jvrf+KTVNUjIj0S3kBG60snN15Z2td8mOr+ geH40thY+GNNtvsgk/fX8iva6WkoJLPkr9p1e4JOTK5ck8liOa7yw8MGby59dWMKh8yDRLaR/sMJ P3WvpSQ+oT8AuZQUjOVUba65QEUJGqoiKFCRqqoigfdRVAVF9hjjrTlWVNOGHgqcXZSlvOVrauVr u9tVe3S1gUE9ZvnfX+W6t0Wmnnv1Rydh4L09JFutXlfW7xNjRi5VUsLYqOBbWKMYynP3pmkZiO3f ssAKEUBUAAVVVVC7fu7QoUKF7BQoxjjIJMSkLySAMnk8DccdCeMn0H4CpSM4+bGTgDcBk+wPJPNc 8pc0ryd5N6Xerb0svXsjXTb8PIX68nufWlAJ6DNeb+Nfiv8AD/4f4j8TeJ7G21FiBDoloW1PXbrP RYNG09Z78gkYE0lvHCOQ0gGWr4/+JP7ad3pjwad4S0O38Oy6jFdtp194uR77XdSNsgwml+FtMlEE E88zx21nJrerWsM9xLHF5Sy5ib8V8SPpC+EXhSq1Hi/jDL6Ga0oya4dyxvOOIpSUOdRq5Tl/t6+A hUi04YrNHgcG07zxMFe31GR8GcScRODyzK688PN2+u4hLC4JJNKTjiK7hGtyXvKGHVaqo2apu6Pv u/1Cz0q2lvtQurWxsrcbp7q9uYLO2hVTy8tzcyRwxqFBYl3UBQSSBXy/47/a++G/h1Lu28KxX3j7 VLXzEaXRitp4atpUXJ+1+J71FsmRSVEg02O/mTJARWxn8kvGnxX+L/xX16wh1i61vWZ7y4ljXw3O l7rmt3sZMez+yPBGh6Zb6dpLXEc7wJNNHBeadcQC5DXsZXb6V8JP2Avjx4osvJ8Uazc/DLwrqN5J qV9L4ivf+Ek8cXxnjSNli0O0ddJ0bbCiJHBNNA0LOzvbzShiP45zf6X3jB4t4nGcP/Rt8MMfiKvt oYaXEWa4ajmTwEKk5RnVx+LdSnwjw3i6UIxq06eOzDiWjWhUhGVOlU9oofq2E8LOGuHaFPH8e8S4 fD05Rco4Ki54dVmrc0aUHzZrj420ksJhMPOHMm5PmSOE+Ov7eXxq1681/RrbxBo3w60NJoYLS28G C8uNS1KEzJ9pgfX7hrW9nuJ7VXWGfTRa2on8mBRKXcj5z+D/AOyv+0R8aL681X4eeB9V0TSNb1E3 198Svibd3sRfe8jrNa6nrKSa1qLRQyOd2lQyea+0tKSsbJ+7Xwi/Yf8AgF8Ip7fVYPCq+NfF0RWT /hKfHZi16+W5RSpn06wuYv7K0sjdiI2tl5kYwRKz5dvgH9uz/gsl8Ov2f9Z1b4B/sw+H9O/aO/aj tbSaK/0bR76FfhT8H0tlxdav8UvGVtIumWw0hAJL3w9Y39vJaIhXV9T0cqqy+7w79EXxG4/xdDPv pE+KWbZxi6kITqcMcNY2tXjBSUJ1MO83x6nh8voc8U8Tl+S5bSyyDk54fEUubnlxZz4y8IcF4CrR 4MyDC4PDw5af9p5rRcZVqu0HQyzCOeNx+JajejLFYmtiZKPLUo1KbUHl+Jf2O/2N/wBjn4fz/G79 uv412eq6ZpmZJItb1CbQPDmp6gkf2hdF8P8Ahuxmn8UeN9UncbbfT7UNcXOVL2KRhmr8mv2l/wDg s38WPE3hZfBv7EHgrRP2J/2eb1pNI8PfFPxN4X0+b45fE6EMLdf+FSfCzT7eeTTHuHbEesTxapPE JFmuNa0ifdHX4nftJ/tfeLPjH8U7zxx8Q/iKP2q/2i5boQr4t1WOST9nX4GxyzuzaH8K/AckP9l+ Kr+1bbBa3i2Nvpb3QjeO21yfZfrlad8Mv2gNY+K2n/DlrfW7b44+P9F03xB4r8Z+PN8HjDwN4C1S 0W8g1fVbK4Lf8Kt0KXRNuo2GhiDTdabQGsry5gtoLmzSX+1PD3wd8PfDfBQwnB/CuUZAnTUJ4mlS dXMcbCNpv61m2M9tmWLp296qquIeEpuTisNKk7r+NvEXx14v4tqVqdXMsxlhoyjFwpScaVD2nu0X KlgqdPA4KpVtyUqWF/2qrUapxxrqP2Ertr4U8V/tCfFjxBZQ6t4y17xBp8Lax8X/AI+fGbxNN4y8 U+E9AHlz6jNeajLd31j4f8Q3qh7ez0HT72a8sLiZLZHjulaKL1jwR8KfGn7SPxI8Ifsqfsh+CbrW pbiaRbJrrdbWlrYQOkWufEn4i6wqTpo2hRMgvZ5Z5N9zJNDYWMc15eW1vN3+l+BtU8b6l4G/Yd/Y 80K98YN4o8TpHqviOJZI9T+LXjOzVU1z4heKb4gy6Z8MfCsSXd/ZtfXJgt7CKTUbpJ727CN/af8A 8E9v+CfXwy/YG+E0XhLw6LfxV8TvFkVjqfxc+KlzaomqeLvEEMIZbDTmcvNpXg3QpJJbXw7oiSBE iX7ddibULm4mH6lOt9TpxhShGNWcY8kOVJUo8sH7SULWp32p0GlyxSlU5pStH8Y4U4TxfiRm1Spi pVI8NZbX/wCFPHKal/aWLlJSlluCqwXs6ypwipY7H804yTjGnKVH2Dr/ADb+zH/wRH/ZB+D3wl0D wJ8U9APx08RXN7pXir4q33ip7iDwj8SvG2nBZtMOu+GIJkXWfBXg+5JXwZ4M1u6vvD1pPH/bupab f+IJft1v+vPhjwn4X8D6HY+GPBfh3QvCXhvS4Ut9N0HwxpGn6DothboFVIbPTNKt7Wzt0VFCARxD gDPPNbwVVyQACcZPc44GT1Jx3PNLXlKEVOdTWVSpJyqVZNupOT3lKbblfsr2jtGyP6zwOX4LLMLQ wWAw1HC4XDUoUaNGhBU4Qp01aCaTblK2spzcpzm5TnKU5NtSSTk0lFFUdgUUUUAFFFGM9+nPXr7e /XOPagAoozntj8MdOP160UAGOc+wH5Z/xr53/ap+HA+JHwZ8SxWVv5niPwkh8a+FpEBM66t4fje6 ltoioLY1LTvtmntGg+czx7g20V9EV8Rft8ft2fBj/gn/APAXX/jF8YLz+0GlS60nwV4Bs7i2g8Qf EHxJLbv5OiaYkp3R2MKskuu6wYZbfSbE+c8c0zwwSxOrGivaTfLGOrd7dYpJdXKTajFJNtu3UqEZ TnGEVzSk9FpbTVtt2SildybaSSbbPhzQ/wBpn4afsxaZpX7R3xf8a6L4A+FWjWj6T418Q63c/ZoJ NN122LWmn2FnEkuoa1r7X9vBeaXoOkW95qt8Yp1t7VgJni/mR/4KV/8AB0R8YPi144/4QX9i+XVf hH8A9J1RI9Z8UXcBsfin8TdKiujDeyy6jDIs3gPRL22E32LTNIuE1t4gJNS1SF3+yL+En7fH/BQj 43/tt+LNNbx1qUfhn4WeD7/U7v4bfBjwvPd2ngrwqt9PORrN3HLJJP4q8XNZzixbxPrMj3kNkhs9 OtdJtpZ7eT8270vLvJdSpU+YQR8yjcQrYPQDPycgHoM5rix8oY+alB1qWHlFOdF/u3WlZpOutZxS XL+6Ukp2tVTSUTppf7NpaE613ao/fVGN1bkVuV1HF3VTem7qFn7y/Qf9qL9of42/FHxtoUXxV+M/ iT4meF7eztbzwH4h+LGrav4wi8M+Gdd8u+S30vVp4tT1610VGO+TTLU3dnayI7xW4kaQyWvBmjfs kfCbW9A+IPxF+O/wW8WW1x9ju9e8K/Ag/Frxj4y1GO2nSdbiHTNf8DeFPCOl6ksyFTJqOuW0EMju FmYLtb5Tsbl/HPwXaC5uZZNX+GF4bPLl3nl8JaqWeDaxVnMWnTAwpGJWWBDGCqlgT80yrulwxK27 b4ZQ6iTZFIxVmjjddqsqStMAmP3kSHPBFYQpKMFTpv2dOEXCMILkjGL3UVGyhGSbuopJ8z0OKphs LOrVxFXC4erXrKMalWpRhKpNRcZRVSTX7yKlHmUanNaSTVme+/HP42eHPix8RNS1LwRouvaV4Yhu 5otC/wCEx1O31fxMmnmUTI9yLHGkabJKuXlsNM8yCF2IM0g68L4d8W3/AIT8R6L4o06RkuNDv4bx QAR5kSSILmIBTlhPB5yOuBHyAEAUCvJGtZtG1Ga1lGx7V5LcSNkCXbtkSQdwksLxSKDnlyQSDW7H dfaEIGTwNw7ZGTx6jDenc81cKVOlTjSpwhTpRVoU4RUYQX8sIxSUY9Wkkm9d9Tpq1ZznKc5SnUk1 KU5ycpNpKzcndy07vSytsrfe/inV00zxAmr6JMraB4mtYPFGhFWKotrqm2Wa3EnAZ7G6Sa1mUEiM lVYqeK/U/wDYK/4KyftV/sV65pifDn4hajqvw8FzbNr3wr8XXVxr3gbVLd3QXPk6Zd3B/sHUp4/N W21LQ57CSFwjTiSJWRvxT+Hetf8ACUfDDU/Dkrxvq/w5vRrmmKxLT3XhfWJTb6pbw/KSv9m6itve PBnasUspIG0mus8Par9mkgfexRgivsBILNkpmIZJAI78EYA4yDy4jCU68GppOdNvkqR5qdWnKySl SqRfPSlZtRnGzipO0Wm4vSnVcFdNuLs5wlZwlHaUZKV04y3d01fVLXX/AGPPgV8XPC3x8+Dfw0+M /gq5iuvDPxJ8HaF4s01o5fN+y/2rYRXF3p0z/wDP1pd+bjTLlD8y3FtIDngn1ev5UP8Ag2J/bLi8 e/CL4g/sheKtWD6/8NLtviJ8OIrqb99eeC9euVi8U6baiVidmheIJILtLeMHZDqlw4VEQ4/quzk8 HPBzj1+U/ngg/Q57125ZiZYnDJVZXxOHlLDYnRK9ai7Opyr4ViKbp4mCTa9lWptPUyr0406jUL+z klUpN6t05pOPq46wk+sovRbC0UUV6JiWbb/VD6t/Op6gtv8AVD6t/Op6AM+ipdqjk9PQnj9MH9aU CNgcA8A/dJznHHBJ9/8AIoE2kr77ba7209dSGija5UkA5B6HjHGcE4O36kHHv28n8f8Axy+Evwt0 651Tx74/8OeH7WzkFvc+ferczx3TErHbfZ7MTzi6nZWSG1eNbiV1ZY4XIOD/AIfvb16pebVvMd+v f9T1ig5ALEEAHkkH8ceuCQCOv5V8Q3P7YVz4unt7T4KfDDxP4xtLuPT7qPxhr0UegeFo9OvVt521 CNZpft2oQRWNwLmI2oX7RcRvYYinjmMVrxTJ4w8V2ksXiD4m6xpCi8t51tfC0dloenCG3u4biaym tgGub+z1GCOSymN9eyyrBcySI+5FzvHC152dlTir3c7Nu1rpRjeV1fryx1XvW1WUqsU7Lmk30im9 U0rOydr337XfQ+jfGHxc+HXgIiPxT4q0vTrlrm2so7EXCXF9Le31wlrY2a2sBeRLq9uZI4baGcQv K8ibQQ2RzviD4tyxrDpvhTw1e6jr97aWtw8WuSLo+l6SLp5UiTVJrc3d9NqDCGR20zTLe4uFjUGW W2zvHzt4Q+CfhxotLaz8IXfji70rVbzWtK1/xhBDeQ6bqOo363z3WnzXkFtZWwt7mOJ7IWtrO9jF FDFbSKqV9deFPC66Sst/rFnpE+vziGI3ltAk1xb2sG7ybX7bLEk8iRSSOYwCUR5JGTG41hjaElQc MNiowxLnC83G8I07WnyRav7TmaabbSSta7TWlCd5KVWneFn7l3GTejV97K172d30tueMaH8MvipD 8SJ/iLd+O9P1Gw8SaBpOj+KPBdz4eey0KzvtKkujpvifwrPNdTXsepafaXLWOo2epw3FtrUCWtwz wXNlGR9EaZo9lpaySxs017cESXF9cEyXU7H5trO24pDnHlwJhIl+VSwANag3t8wxwMA4+6MnOMDj OTk9eT2NVb69sdNtZbzUryzsLSJWea5u54baGJACzMZpnjjAVQWYfMVGOawpRlQoxp1K0506d3z1 Z3s5SUnq9o8zbS2Tb7jmueSajFNtXSik2lolotdNPMndsgEjJzgt69cADqc/p7Vz2u+LPDXhO1e9 8Ta9pOg2hVmE+q39vZBtq8rFHM6yzsewgSRieADXyP8AtM/GnW7DwnpN38LLrxbe6Vpni3Tbf4k6 34T0RpBpfgy/iurS91iHW7uLzbaDQ71rG9v7jSra6kewM7pIEic1816PYal4pv2m8L6FrHjXUpH3 tqsEN/4gleU/8tLjX9WLxQH/AG1e33ADaqgAD+NvpFfS2xHgtxJlvA+QeGuf8a8U55l9PH5PPDSk 8BjadWpLDyWWYLLKGZZrneIwWIhyY3A06eWVYKVP2daca1CdT9G4S4AXEOAq5ris1o4DAYevKjXi qaVWi4RhJvFV8TOhhsHCcakZUq0nXUlzfu24VIx+zfFf7UvhOwtZm8I6HqnibyVeRda1Ejwp4UjK ISZH1jWES7mSNd0jSWmmzrhcpI4NfEXxV/au8ea1Zaxa6Rqd7qd3pttY3UnhP4fed4V0yW11adIL GS68canDcarqtrJHIbnz9AQW81tHNKUCFdvf6T+xp8RvGuo6vffEXxN/Y3hvWmgZfC0kp1y+s7a3 +ySxwho5k0+BlmtxNCYpUkjlkc3Hmvuc/YHgL9mT4Q+CobRl8P8A/CQ39jHHBBe+JXOorCkQLItt prKumW8as7NGiWhCFmZTuZmP4Ssl+nH9INUnnOKj4QcH46MHWweIeI4QUsPUjF1qccnwFTG8e5hL lUqGKyviLG5PgKym5UMbC15faxxPhPwa1KjH/WbM6dpQ9nGGYxU420nja8aOUwUZ8yjXy+hVxEGk 7OMWn+aHwt8I/HHxvres6hovhO1ufD17DZppMlraSaPp9rI++XULzW/FesLLqmt3nmuYCEu5Y3jQ OlrHuKj6/wDC/wCxb/asyar8T/FrzzPAIpdB8IobCA2xkE62l1r06nULi2EqqxjtILNC6EiV8Bh9 4RwxQosUEaRRRjZHHEojREB4VFUAKvA+UACpFT04HfnPXpkkkk+mSfev13w6+gH4O8LYunnXHLxf ifxAo05SWcU1lXC1GtFQ55YXhfL60oV6VWUXOrRz7Ms9p1JzqTlBOdl87nfi/wARY9zp5NSw3D2G lH2fPhowxWZyppWjGeY16UeRpP48JhsLV0hzVZuCkcL4M+GfgL4c2otfBnhXRtAVVAlnsrNDf3ZU AF7vUZjJf3UhA+9cXMnJOABxUXxR+Lfw4+CHgTxF8UPi5400P4f+APCtk9/r/inxJfJYaVYwqcLG JXy11eXEmIbPT7RJ76+uHW3tLeadhGfl79uD9vv4D/sHeAh4o+K+rT6v4w8Qxz2vwz+EPhfyb/4h fEnWlxDDZaJpQcvaaUl1JDDqfiK/VNMsBIVDXF2sdlN/En+3z+3l8Tfj14rX4g/tdajb6hc6PdLf fCT9izw5qd3B8MvhtC//ACD9Z+LctpcQ3viDxNLGYZLiymlGr3sjvaStoOmGPT3/ALXyrKMuyjA4 fKcgy3AZVluDgqOHwWW4PD4LL8JCEYr2OGwmEhRoRlCNpOjSjTjFNOtOlGUXL+fOLuO8LlNWbxeK qZpnmKamqNbEVK1b3+Xlr43ET9tVp05XXsqfLPEYi0/q9KShVqU/0e/4KDf8FofH37RnhvXNH+CH iTX/ANlz9jK4uL3QdZ+O99bmy+Onx6+y+Zb6n4b+Dfh77RDd6TpF4pNvdahb3KXEFrKZ9c1fRkkO jXH8/Hwt8GftE/t8eNNP/Zm/Yx+Eer6F4Ekn+1a5p+j3U0moa3btc4m8bfHX4mXCwCWKTa0pS7ls 9DglIstG0ie7WLzPt39g3/gk/wDtYf8ABWDxlp3xn+Mupar8Lv2abOVbO38Z3OlDTU1HQrSZdnhP 4JeDfKg0yHTbXYbT+0I4oPD+nkFnk1DUI2ib+0jT/BP7Gn/BIH9kDxf4m8K+FNI+Hfwv+HGhRajr d3EtvL47+JviiTyrHRdN1LWLgR3viXxh4p1eW303TbeRltrWW8zbWljptvLs73KnQUvZ2q1F8ddp 1UmukWlzV5K/uwpqFCE5SjGlGrz+1+Ew2RZxxVOWc8R4ueX5bGm6q9pGFCosLGKqTWHpTcqeAwdo Oc6lWc6tS3ta0q9qdSn/ADr61+xf+z9/wRV+EfgPV77TPD37Uf8AwUv+NcR0D4D+EtT09NU+H/ww 1yVooNU+JVh4Wuo5JNU07wVczRiz8Q67bC48Qa+trpWkWunQre3Nr+efidta8DQal8IvDGo+IPit +0J8Y/FyzfH/AOJMRk1nxr8U/ij4l1Lzf+FYeGrwSSz3ljFqcqR63PbvHHf3CvYR+Ro9g0b9l45+ OXxE+IXjDx3+3N8dJ1i+PXx/gvdO+C/haW4eaz+BHwYsvPtbXUtItnH+hC102WTSPDMpWOXU9dut a8UTFneG5P7yf8EWP+CeSeENJ0j9s742eHpB448Waa5+BfhTWYXa48DeDNQgcS/ES/gugZo/Gfjq KVnsJJiJtK8NyRyx+VdarcJF6VGP1am8RX9+vUty05taVEv4a3i6eGfv1uX3amJk4RnywpuX5dj1 U8QeJcPwbwrTeW5Bg74jMMXTpP8A2LLJ2o1MfiHKLdTOs8jOdLBqtNV6OXzhGMYwr472X2H/AMEs P+Cb+kfsWfDqfxz8QLTTdX/aY+JemWknjnWICLuy8A6I6pcWXwv8JXbLhtP0xhHJ4l1W3WMeIdcR 3INhY6eg/WlQQqhsZAAOM44GMjPIB9CTjpk9aRQo3BM4zk5OfXHPfA49MYAp9cMm5ScpSlKUneUp WvJu127beSVklpY/qLJsny/IMswmUZXh44XBYKlGlRpRbe2sqlScnzVa1WblUrVp3qVak5zm25aF FFFI9QKKKKACiiigAooooAKKKKAHx/eB7Dk/T/Jr/Nd/4OT4f2jNI/b28c2Pxq8XX3iLwzdaPpet fBSG3iurDw1pfwt1JZIbDTdE0s3E9tDqFjqkGp6f4luone41HU4Wv7tjHc28UX+lACR0r+Z3/g51 /Yzh+OP7Gdn+0n4a0Y3fjz9mXUTf69d20cbTXPwk8STw2niQ3JJWWWHw3qf9na5GkJkkig/tJxG8 bkx8eMp88KdRauhUVXl3TXwybVmrxjJuLfwvVWdmuvCTSnOldJ1ockJfaU4tTST6cyi4WbtJyWjt p/mfapPL5jgrjG5SQD8pz0APQDtj8a57ruGec5+YDnr78/XHQ/Sut8QoqXcqKysrbyCoJUHe4+R8 DcuNuMZO3Bblq5GTIYZ++OM4GNuePxxjnqPyrJO6TWzV/v2M3Fp6Prrr6dOj3b7NtLQ9C+FviGHw 94wtYtSlYaD4ihn8Oa+uf3ZsdTAiiuJIifLJtJSkgcjKkAjvnifGHh6fwx4l1zw9cDa2mX8sMRY7 vOtn/eWkgZeGEsDodwPJJ5zWZJls84fAMbDIYSAgKVI6EV6149jXxV4K8IfEC1Ia+ghPhTxcS6b4 9U07Y1jdyIMMou7NEBcYwSCM8kFtW++/y2t/T/AUW2te55Z4nitdU8K6DrcO7+2tHuLjw7rr7Y1i uNNSBLvQbiVgwme8FvHd2mJFdXt9PULIZlYDjrGchmXdgjjk9TgdOM4I5H8sV2WjB55b7QHYeV4g thZxEAFItVh3z6LdbSMA/bD9k3Z4hu5FPy9fPF8y3l2SoUkiZ0lTo0cqMyvG49Y2Bjx22Y6CqjFK L30tq/7z1vvpfRWW77bTK0npa9o6q9rJJfJrS+nzu7Hs3wx8Yt4I8b6Nrsqedps0r6Xr1t/DeaFq YS01SJk5DMIGM6MR+7kjVlIyxr3rxDpyeFvFOp6OJg1rFJDcabcRs7RXmn3yC9sLhWQgMklpJEm5 ckMu37wbHyDFtngyFJYjAA4O5hgYyfU8+vbmvqrTdSPjT4YaTrzStPrnw9mj8K62uMy3GgXcjzeH 9Qy372QxTs9g5f7ibFU7emTsmm9pJp3fVuNm3fV7p3e21xpvlvHeKtrtpu7ap6X3R+mX/BMf9sfV f2O/2uvg78bbC4nXStE8RQ6V4z05ZCg1XwRrwXSvFWnvt++v9mXM19AkgbZe2sTry5K/6uHh7XtI 8U6DonifQL2DUtD8R6Ppmu6NqNs6vFf6Vq9lDf6fdxsuA0c9pPDJGSudjAZyDX+K3o+rCxukuBIQ Y3QnG/cQDncFPQ44IHJ7etf6YH/Bu1+2fH+0z+xZZfC3xJqq3nxC/Zynt/B8wmlVrvUPh/fme58G agSW8yZNNjS88PvIF2xRWNjG7F2FcNGf1LNYrVUMyiqMnbSOLw9OVShJ2dl7ehGrSqVZWbnSwlGK bqLl3lF1KD6zw7vZLR0ZNRm097U6jhJL4X7WpK6as/38opygE8+n+FSbF9P1P+NfRHGPtv8AVD6t /Op6ihAEa49/5mpaAPB/Ev7Rfwo8Nvc2h199Z1K1juHbTtFtLi9uS9v5ZkhVmWG3MiiaFmHnlUjm S4lZLdjKPIdW/aH+JmvzaZb+AvhTe6XpOq2/n3Xi7xdd20UOh2y3c9tLO+lo5W9uIorfz7a1hmuF vklgeObyCJGyfFxsPhJoU3irUPDenaJc6g8GmaPpgSG48W+L9ZaGKz0/RtOtbZbvUdQvriOO1glu blz5VrEkt5NJsjR+9+Enwr8fax4Olv8A446v/wAVL4h1LUdW/wCEY8O4sLHwzoV8lsmk+GZbw+dd Xd5p1tAz6hdmffNeXNwC524HWo4WEk5TlUcbO0b8stbtaNK3K1e+t76bGC9o9FBx03bVk9Nd29He yWmr3PEfHcGpeL9IuNO8VfFPxPG929u/mWWo/wBk28SwuGe2t9G0WbTophdLmKRblp/MU+VN9ojY qc/wf8CvC86MdA+Ft74ma6tNLsbnVvHEl3e6dcpo8huLCaWPxDM+no6Xh+2b9P08GZ/JeV5SuF+7 tD+HfhDw4wl0bw3p0FyBtGoTxreX5A4Be7vTPcnB52h1XIOFGa7IqcASMMjqABzjsODtHUADCiqe LjG/saEIa3vKKd0rWVlqv/Ar97ijQafvTlJK1km1ro73bfVJq1j570n4Qa5LBAmua/a6TaxIqR6R 4btEZYI0G1YVuJ0jtoVVAFAtbIRqSQpI5PpGjfD3whojLNBpKX16oB+3aq76ld7x/GpuMwQYOD/o 8MQ6gAZ57lwckKjADnlsnHuTnj6dBx2rzHx/8WvA/wAMLSO58V6vHBeXKMdO0GyRtQ8Q6uw4WPTN Jtibqfc+AbmVYLGIZae7iAOPBz/iPK+H8sxmd8R5xgclyfAUZYjHZnmmMw+X5fhKMLLnxGKxNSjR pxu4wh7Sd5zlGEFKUlF9uEweIxdelhMDhq2KxNefLSoYelOtWqzfSMKalOcnu7Jt6s9L3qAsOGxx sVUbAHb7qhUUYwM7R2GSQK8B+Jn7Q3g3wDcz+H9Ojm8a+N1UIfC+iTRuNNk42SeIdXZTYaBbx5DG OZm1Bl3+XZuduflfx78cfiH8SPNtrKeX4ZeC5FKTWOn30Y8XatbncrDWPEEbmDQraRdwks9HY3RR lRtQkDhRU+G3wi1/xPDHD4V0aLSNBLu8viHVIpobGZ5Duee2Rwb/AF2/Ygs91K7W8hwWlXAUf55e In02c24tzmp4efRj4VzLjTiTFqrQp8V1srrVcFSUJezrYzJMmxEaTrUKEml/b/EksuyLA1uWpisH j8HVp1X+uZT4bYXLcP8A2vxrj6GCwtJxlLLqOJhHdJxp43HxbpxlK9/quAliK9aClGniMPV5Ykeq ePviV4s1rT/EfibxZc6KLG5judC8LeFZ7qw0HTbtHZYsxxudU8W6guQplvT9glZiI4oYpXC/degW EXjfw9oGs+LtBMeoPbJJJpurW3lpFKB5LTvaM7kLe/8AHwkM3yoWZcLtD1T8B/CHwp4LCXqRtrfi EKom1/Uwk9xHJj95Hp8RBi06EEkBIAJQAN0mRXqwQDAyeM89D1JGSOTgEjByMds1+y/Rs8IPF/gn E8QcY+LniFjeIs84zo4erj+FKmMqZvgssxdOdOpSx1fMatSODpZhhqKqYKOW5BgcPlOEo1JYaGNz PCYfLvqfzPGPEGR5pHCYHJMrpYTDZc5QpYunRjhfaU2rVIUsPCHtJ06suWq8RjKssRWlH2s6VKrU rOtU+xWn2Z9OFrbCxaJoXshbwi1e3mjMc0DQBFieKRCYmSRXDIxBJFO0+ws9Lto7HTrS20+whGyG ysoIra2iiH3UihhVI41UYG1VAyD61bCgfXuT1pa/rRUKSqxr+zg60acqUavJD2kaUnTlKlGaipKm 5U4ScE+VyipNX1PheaXLy80uRvmcOZ8rkk0pON7cyTaUrXs2r2YUUU5AGYA9Ce1aiG8AEtkKMkn0 /wD19h1PTrxX5F/8FG/+CqPg39kO50/4IfBnw/D8dP2xfGtukXhD4UaTI93Y+Cl1FNun+KviVNYs 0un2IOLrT/Dsclvq2sRxNNLLpOlb9UHzP/wUj/4K3+IvDfivXv2N/wBguHT/ABn+0K4utO+KXxyu mtz8Kv2atIid4NYvL7WbpZNL1bx/psSyF7c+fpXhOVftOqLeahCumL/OHoLXfgm9u/h38B7nxx8d fj/8cNfvrbxl8a3e91r4wfHHxR4guGGraR4OmvA2peGfAkss23WPE12bW51Swt1ZJLDTbcwxKlSl inzKShhIqTqVuZwc3Tkk/Zys2qaek60fe5lyUVOUpVKP5Rx74j4bIYxynJ6scXn2Lqxw1KOGhHGV KFabUfYUMPBy9tj25RUYTjOhhVKNXGQlzUMNifP/AI8fFPxh4M+IPib4pfFD4i6z+0b+2/8AE24h 0bW/iAmdc0r4XvdXLLp/wk+BPhqzLaVbavp01ymny6xoNsbfRnC22itc3Ms19L+u/wDwS7/4N/8A VvGOsaH+1D/wUOsJpZLyePxL4O/ZwvJ5pLi4Fy4urbWPi5dlzP5s7stzJ4SgnMtw7uNemRi9jX6X /wDBL7/gjl4T/Zbn0n9oL9o+00D4hftQ3sEV1oNikUepeCvgXbXMSP8A2R4OhuYzDqPi1VLQ6r4u aNmjk86DRPJh866uP3jUHezDq3UE8dSSfXqffuQMkk3UlCUVRoRVPDxsvdi4OstHy2cnKnRb15Oa Upu7qS5pSbODuBcTCpHiLi6TxmfYlKssJVn7ejl/NyuMak3FLF4yyXta0owppctKEPY0qNKln6Np Oj+GdI03w/oWl6doeiaPZ22m6Po2kWcNhpem6faxiG0srGzto4rW0toIoxHHDEkcUaLgAKM1/HB/ wUx/av0j9vD9q7U/hbYarcP+xR+w7f3XiD4i6np90yad8Wfi7YynT57Sxmjc299BaXzv4I8I7t4W aTxR4iiAiNjKn7Df8Fqv27NY/Zj+CGm/AX4M3t1N+1J+1ELjwR8O7bRWLax4N8J30seleKfiAqRE z218iXB0LwrKELPrd1JfRkR6Nciv5b9K+FmqvN8L/wBiP4G2R8TeL9S8W6fa+Lr6zkkni8Y/F/VY jFqF1eXsas0vhf4d6Y99by3EjSRwvZ63qDMskiym8JQ9tVUm+Wlh9VKytGcOWUquq5f9njZwsv8A eJ0uVKVKVvn/ABm42eV4GPDeWwniswx8sPSq4Sgpyq4yvi6ip5Zk0YUlzSePrL2+MpqUZSy+jOgv fxlCNT7u/wCCdH7J+p/8FDf2odX+J/xO0mO3+BPwt1DRtY8UaNa27W2h6jeWKrJ8Pvgto8aIYV0j SrKC1vfE1rHgJoVtDZv5c2tIV/tIiSOCCG3gijggghjghghRY4ooYkVIooo0VUjjjRVRI0VVRQFA AAA+av2Rf2aPB/7JfwD8C/BXwh5VyfD9h9q8V+IEhEVz4w8a6lHDN4l8UXzFRI8moX6kWSud9lps FjYg7LVQPpZeg+g/l7U8RV9tVcorlpRShRgr2jSj8O+vM0rtu7d9db2+08NOC1wZw9ChiprE59ml T+0+Icc2pSxGY11zSoxnfXD4OMnQoKKhTbVWtCnB15JrRRRWJ+hhRRRQAUUUUAFFFFABRRRQAUUU UAPQKzBTnPt6dM+vXrjp1PFfwK/8FsP+C3vjPxP+0tp/wN8EeFdS0n9nT4B/E3XPDnxc8Ma4tza6 j8bY5F1XwB8SLLxPpqOpg8Mw+EdU8Q2/hnSHEs73s8Os3EXn/wBnx2v99Sfe9cDj2ORyPQ9sjBwT X+eJ/wAHR37IEvwh/a3sf2gNB0o2/gf9pLw7FrmoTwxH7LB8SfCkcOleLIZGACi61TTX0XW1jB3S yS3chcYynn5gpONH3v3TqJVY7Jtyi6bk9+WM0rx2cnFv4UjswajKVRK6qqHNTnp7sU+WqldO0nCX NzrWMITSaUmz+XH9oP4W3HwZ+MHxA+F0uoLrFj4S8QzDwxr8bLJb+JvAeuW9v4i+Hviy2lRmSW28 UeCNW0HW4ZFcqReldsZUonhEibCo42ncOCfvDqf8fWvrz4px3Hj74DfBn4pLbNLrHwxe5/Zh+It4 GQ+bBo0N94z+AmqXihjcPLe/D+68S+BYryaNIPL+GtlaJK7oit8kSoTtD4jI8xlU9cAEgYOCcjp0 +g7TC/Kr7q6fybX6ESa55Lq7vte71t83+KKDjLEHocZ+mOo+hxXqvwq2a6PFfw2umAHjLSJJtELO qrH4l0hGudPKbsKsl1EjW3JJ4B7jHlTck4OeATwR7Dr9KmsNUutF1HT9asJDHeaRfW+o2rqD5gmt 3Rl2+xAKMOMqzDvkV+aaafZpppr+u5g/dlp0tvr0X9aGLPHc200ltJuguraZ4nYEFoLmB3UglTkM kkRAZDuVyhB54seNrRZ9QsvEVvDItn4nszqMqjAWDW7aUWOv23yqI41GoKLuNAwZYL6J24JavTfi 9pcCa5aeLtOijTR/Hmmw+I7MRcRRXFwqx6pZAKqxpLb3kL+asYBUSAHnk8PCjax4c1LSBKrTWO7x DpUUrnBktoUg120gj+6XvdLWO7KsCZJNJAHzty4y1T6fp/X4g1FO2trJ39UmunZ9PvOGsJl3FDuG PUjHJ4+uT0P0GK90+CfiCDS/GJ0DVH26B46s5PCWrqzDy4jfkf2deMN4Aaz1BYJQ/wDcLgHmvA0c pK58zhdo2KPvhiqgocYChTn17jGa3Umkwsgc+bCyPHJnIRkdWhKgdGikCuHPIAOc5pTirtLRNqS8 7Wet73V93byEpNaL1t9x9B39rdaJqup6RfxfZ73Sb6W1uoSkitmKQhXAYl9kq7XUkk4cFeOT+8n/ AAQR/bab9kr9tn4dPr2sGw+GnxTuR8KPiCLicx20GjeKbuGLQ9augW8jPhvxAumXjSyqGWzN2obJ NfiD4uu08VaD4L+JtpGyPrdivh7xWyhvLt/E+gwxwyNIQzDzNRgC3Hz4DZZkJxiq3hHWbjSNYs7y Gcx4kSQOrOGRgwZWQIQSysqlATwwU5J4rgx1B4rBzp05qFWHLVoVWv4OIoyhVo1Nd1Tr06VRp+7L 2fLNSg5RfRhqqpVFzJuE04zgl8dOdo1IrtzQdlJaxdpLVI/2w7fayK6MjIUBVkYMrK21lZWGQysr BgwOGUhu9T1+Tn/BFz9s+2/bS/YU+GXirU9RW9+I3w0tIPhV8To5Z1lvH1zwza20Wj61P/y0KeIv DrabqAmkBMl39tQsXjfH3j8YvF3j74dXHh3x5oWkt4o+H+jxalbfEvw5YxeZ4ht9MupLGWz8XaEg XN0/h1be9/tGw34ubG7diiCH7XaengMWsbhKGJ5XTlOFqtOWro16bdOvQk1o5UK0KlKTW8oN6ppv KrSdGpOk2nyOyktpxaTjNPqpxamn1Urnu0X+rX8f/QjUlc/4V8S6D4w8P6V4m8Mapa6zoWsWq3mn ajZvvhnhcnIIOHimicNDc28qpPbXEckE8aSxug6CuwzPmb4YfC7xHrfiUfGj40JBdePriJ08IeE0 YT6J8LtDmy0VhYRsWin8SXETBtX1fDSJKzwQOMM5+lmZQD0IweBj8uOmc18x/DL4o+JdD8Tp8Fvj RJDbePIYpJPB/i5E8jQvijocJIivLGRgkdv4mtowF1bSSVkkkVpoULMyt9KEbQ3Tn0yPb1PrQAx3 Mg43KFyMqTx7ZHf0zye3Sue8SeKPDvhHSLjXPE2t6doek2gZrm+1K6jtoUABO1GkYPNO3SKCBZpJ GIVYnJAr55+Mn7SCeBte1H4eeDPD/wDb/j2x0zT9U1K41d20/wALeGrDWPtC6bqGp3G4Xmqy3Jtb g2unaXEWkeBopL22c7R8ZavL4h8aa9Z6h421TVfHvi2aT/iVaZFZk2tiJHyIvDfhaFWtdNhwVBvb 1DdSEebO8mS1fxl49fTL4K8JsVjOFOGsvr8eeINKusvlk+CdShlGU5jUmqNLC5tmSpVKmJxzryVG GUZPQxmKq4qP1HFYnKq9SlN/pPCvhvmOfQo5hmFX+ysoqRVanVcFUxuKopRqOphsPKUadKh7OUZy xWMnTpRpyjVhSxVNyie7+O/2oPFXikS6X8JtPm8N6PKGjbx54js2bU7yI7o/O8MeF5vnhjbll1fW 1CIu10sCdr14h4R8Ea34q127/sOx1Xxl4sv5i2s+JdWvZLuYOSFZ9Z1+cMlpErruj06yZUWMBIIQ AcfR/gP9m/VNYEepfEW4fSNNfbKnhXSrk/2hdgcBdc1aMDyVAALWljtxnYZEIMY+wtD8PaL4b0+D SdB0620nTbaPyobWxiSFFH8TswBeSVzy8sjNIxzuY5zX875J9Hf6QX0oc0wXF30jOKMy4N4OpVY4 vLOBMHRhgsxVKfM4xwXD1aOJwPDMalJ+zeZ8QxzTiqrQdXB4/AQpVKOJj9ZjOLuE+CsNPLeD8BQx 2OlF08Rj5VHVpSa3+tZlGSr5hqk3hcA8NlykualUjOMoPwPwH+zpomjm21XxtLH4n1iMxzQ6ds2e HNOmUhv3Nizf6bJG4JE12WUkFhHk8/SaRxxxxxRxpFFEoSOKNVSJFAACpGoVFUYGAFAGBindz7nP /wCv/Ior/RLw58KuAPCbJY5DwDw1gMgwTVN4uvRhKvmeaVqUFTjis3zbEyrZjmmJUU1GrjcTWdKM nToqlS5acfyDN88zXPcT9azXGVcVUXMqUJPlw+HhJ3cMNh4Wo0It6y9nBSqNKVWVSfvBRRRX6GeS FISB1peeMDOTivPfil8V/h18EvAnif4ofFrxfoXgP4feDdNm1XxH4p8R30Vjp2nW0S7lXLky3V5c t+5sbC0iuL2/unitLO3nuZY4mTaSbbskm23sktW36EylGEZTnJRjFOUpSajGMUrtybaSSWrbaSWr aR3dzeWVlbXN7fXdvZWVnby3V3d3U8Vva2ttBG0s1zc3EzJFBbwxI8ks0rpHGiMzsoU48jHx4+Ge reFrPxf8PfGHhv4o6frMt1ZeGj8PvEWjeJ7XX9TsnaO7tbfVNJu7vTbaGwkXOqX11cJa6bEjyXLq QIpv5Jv25v8Agox8TP8AgoDbaz4W8F6p4q/Z5/YITUH0q4vRBdaf8av2rby3ufKOjaRpERS+tPDE 8yK58NQSm1t4mt7zxld5KaLF0f8AwSD8VePfBf7Ufh74RfDP4eXN/wDCDWLO5tPib8PPD1nDcWPw 28Pbbu60D4lfEbxa/l2b+NTqy2sN1Z20tuupWc0ml2umJHZ2S2hVw+KqYavUoujRlFRVN4hyiotu 3NJqLSqSV3SotKacX7VQ5qan+X1PFjIY8U5bw9hqGKzKnjcRSwjxGX03iarr158scRRw8FeWV4dR c8VjZTU505TrYLD4vD4XFV4e+f8ABQP/AIJT67pmjW37Q/7Jfwy8beKfiz8Wvijep8Y/g94O1yaf 4WavpfxD8RS+IZPEN5pOq3dtfpZ+GNdnadrzTZhpEc1/Jqt7pQtLR4x+sn/BPP8A4Jo/DT9ibRZP GGsPafEP9orxLpkdt4w+Kd3ZoqaZZyKhk8IeAbSVpW0DwzalUguJoiNQ1swmW9lWExWkX6cABVCR gRqEQYTKrgD5RtGAFH90AAgnIz8wAMDqT/nrj19T3AHpWOGpVKGGWFlVqTpqUJcjlLlUowjGyu3J U1KLlCm3yU2/cilZH1kOEeHocRz4qp5bh4ZvLCQwkK0adKMKUFOrUnWp06cIw+tVlWlTq4l81V00 4wnGNSr7QfBDcZHYYz0xg49Rgc9eB6V518X/AIseBPgV8LfHvxj+JutweHvAPw38Nap4r8UavMy4 t9N0m3eaSGBNwa4v72URWOm2UZ8691C4trWENJKgPo3Hfp3xyce1fkl/wWK/ZW+NH7X37PngX4Tf CHxJodvbP8T9I1/x18PvEGv/APCI6b8RvDmjafdXlrFe+Klt72WwsvCuqLb69NYSWU9pqc0Nssoj mtrZqWJqxo0ZTnJQgnFTqNNqlGUoxlVaTTlGmm5yivekk0rHtZhWxWHwOLrYHCPH42lh6s8Lg4zj SeKxEYN0qPtJtQgqk+WLnJpRTb6H8rPjX4/+Ovj98VPin/wUK+KqXNj4w+Jl/q/gf9mDwfqTu0Xw 7+HOmRXFgmuWMMn7pIPDWi3c0S3ahEvfGus6pqCytt3L++v/AAQ1/Yml8HeFr39sb4n6OV8W/EXT 7nSvgzYalEJb3QvAE8y/2v4zl85N0WreObyHZZT/ACTp4dgDjdHq7k/lX+zr+xf45/an/bF8HfA7 x1pEOi/Dv4RabbxfFbT9DuIZNA8L/DvwHNaW8fg/w5qtmyx6g3j3WbyFIdVgVZry01HVNS2qbKTy /wC2TTNJ07QtO07RdHsrbTNH0jT7PS9K0yyhW3s9O0+wgS1s7O0gTCQ29tbwxQwxIqpHGgAGea9G WIofVaFLBzhUp1IQqTqwkpc1K6nRpcy+JycpYis7RUqs3L3pNpfzp4acJZvxBxnm3HHF2ExdH+w8 disBk2CzCk6c62dyjGOa5vKlKU6fJhVNYHAezdSjBU4qM3Wy+nN3ycnoB9P6+9JRRXMf0uFFFFAB RRRQAUUUUAFFFFABRRRQAUUUUAGSOhxX4t/8F7v2SP8Ahq3/AIJ4fE19H00X/jv4Gunxm8ImOEy3 stn4dt5k8a6VaFA0v/Ew8Jy6hK0Sf66axtl2syxgftJVPUtPsNX0vUtH1S1ivdL1axvNN1KznAaG 70+/t5LW9tpkPDxT20skUinhlcjB6VlXpKtSqU3pzxaUt+WW8ZW6uMlGSv1RrRqexrU6tm1CSco/ zRd4zj296DlG/RSdrH+Nv8CdDj8Y+Jfif+zpeyJE37Qfge60XwELlkW2tvjf8PZJvH3wWukdiI7a TxHqWm678N3lOZBB4/nT590dfDU5YqkkiSxM2HZJFzLFLz5sUwwCjxy745BhQGVvlBGB+vf/AAVX /ZZ8SfsLft0fFj4c6G9zo7/D34iWvj74Sa2iSQtH4futSg8a/DzVbWRn66cgs7V2Rz5d1ptzDvO0 gfEn7WHh/RIviYnxI8HW8Nr8P/2gfDGjfHrwbZ28Yit9Jfx292vxE8HwRRgRwp4B+K9h418KGyG0 W1tplqAoRoy/l0JNqDkuWTUoyj/JUg1GpFat7qO99ItptXa6MVTtUmlK6dnTk7+/TaTUm7WbldNN WTjbTRM+UzuZsqcryDg8Z44Iz7Gq7qEbdgE+mM9u2OPw49fWrTIVZgjKVyDwNpwep68gMcY989qr sNwYktx79cDP+fzGDXScbVm12/yPZvDqL45+EXiHw3Kok134cXf/AAlOgu+Wkk8N6mRBrmnoMlcW 9yYrscDagJAznPh9hdS2V3bXceA9rLHKqg7lfYfnjZeh3xZjkDDBEhRgQWB9H+FHiuHwd8QfDurX jRjSLy4bQ/EMU3zWs2ha2Bp9/wDaV2vmK3Sb7Ru2MyGIMoyKi+LPgC6+HPj3xL4YmB8izvmuNHvN ki22paRdFbywvLOWVY1uIZLOeJt8bM6k5ZB2lO0nHuuZfgn/AF+Y7OWu76+iSS/X7jy/xFpsGmah NHas0lq6x3di3GDp92omtFLHndGrNbzDPyvb8DdxVOyl8xBtcAr13DjnOevLFgMfgPaunv7Vb/QF nLxtNo1w6PsR1Y6ZfO7oSW2iRLS/DR5B2qbgEHaADx1ufKI6mVnVTCqkszZGyMYGC7BiVVASTwT3 qm72vbS34Jr9dfRCtdpLW619evY+mfgbfW+ux+KPhRqd8lna+L7Y6r4emuJCtraeLNGheW2MhYFU GoQM9u2AoYqvzFgorMR5rZZreeMwXtpLJHNHIDHLDLasUmR4+GVo5QykHBUBWbHymuz+F/wB8bXm n6j8R5vDXjC/svAtrZeKtW0zw1oGq6zqmheG3uIrf/hMtbj0q1vXsvD+nXLKdReaIQ2cGJL2aCGV Wr1ubw/4Y+JEzaqi2GrvrTmdvFPhi607SNQ0xizk3uueH7SBtNvoZpA7NLHbQxzESQNfW8sEpPOq 9J1KkIzhJxsqihKMpU3KKlFVFFtxcovnUWlJxlGduVpvpVKr7ONRpxg3ywm4SUXy2Ukp2avFtJ2T s7Xs7I/ok/4Nc/2w7z4V/tca38B9e1eS38BfHPwe9lcWlzIRZ2nj3Q9S01fB2qKrMI45bpb7UNDd ztJF9bKchK/0SnKE7cAggqVK8HOcqQRg5Gcg9R1GDX+Rx+wH4P8AH3w7+OL+NPD81xfadpfh7WLr SPEGnCSzuvtmk+I/CstrfQ2TsZykcqq4uLSW4RHUlJcDLf6k37HX7QemftN/s8fDz4sWtxb/ANp3 +jrp3jG1VlWTS/GGjxrZ69a3EY2iBZZ0XUIA4UmzvLd8BSAIwUo4bF1aEWvZY2TxVNt2tiYxhDEU km0k504060YQu5Shiqsldys696lKnNr3qSjRk924b05N2SfKlKDdlZezjrbXD8QeGtf/AGctd1D4 jfDfTLrWPhHrV1JqPxL+GenIZZvDM8hzd+OPA1pkLHHGoMuuaHFshaBDLEEgjSTTPqfw14m0Lxjo WmeJfDOp2usaHq9sl3p+oWj74ZonyCCDh4ponDQ3FvMqT206SQTxxyxug+WfEHiTXv2jdc1D4dfD jU7vRvhDot3Jp3xK+JenOYp/FE8Zxd+CPA13grJC6kxa3rkW+BYHMMRkgdI9U+p/DXhrQvB+hab4 a8M6Za6PoekWyWmn6fZx7IYIkySSSS8s0rlpbi4mZ57id5J55JJZHdvbOQ474n/DDw18V/DUnh7x Ck9vNBMmoaDr2nt5Gt+Gdbt/mstZ0a8XElvdW8oUugYRXMQaGYFSrLB8KofiLZ+E20n4oTWGoeJd D1S/0iLX9PwkPinRbRYG0jxFNAGP2a+v7eUpqFuVjKXtvOdnzbm9MpG6H6H+VAHzV8YP2ftH+J/i Tw/4407VLnwf458PxS6NJ4ksLRLs614SvZRJf+HdUspWjhult5ydS0O+ZvO0fUFkeBlgvL6Kb0fw B8MfCXw8t5ItD05n1GfJ1DX9RJu9Z1GQ7QWnv5V3pG2NyW1v5VtGhULHxk+j0V8DS8LuAKXG+I8S I8K5RLjfFYelhqnENTDKtjadOjT9hGphFWdSjgMZVw6p4bGY/BUsPjcdh6OHo4uvVpUKUIevPPs4 nlVHJJZjiXldFyccGp8tNxlN1FTqOKU6tGFWdStSoVJToUalarOlTg5tiBQOgx9P6+v40vPbH4jP 6UUV98eQHPfH4DH6UUUUAFAIJwCM89/Trn6YOfTBppYKQDnJ6Y557A9xuPAOMcHJ6A/l9/wUS/4K ffCj9hbQ7Xwhpmnj4s/tOeNrRT8NPgTod1/xNLqS9P2a08TeObm2Es/hjwfFMFCTOh1TW5IjZaLa zObm4tonPlS0cpOSjGKV5TlZy5YR05pcqcml8MFKcrQjKS5cbjcJl+GrYzG16eGwtCPNVr1XaEFo kr/alJuMYQjedScoQgnOcU/pD9sj9tL4E/sPfCi5+KXxq8T/AGT7S72HgzwRojW9948+IviEoTbe H/BugtIs19cPIYzfalL5Wl6NasbrUrq3jaMSfx0/tSftS/GL9ufx3pfxF/ajt59K8G6YZdY+Av7F fhrUr6LQtKsj5v2Px98bNShlt5rh5FjQ3Oo6jFZ6jewPcW/hmz0jSUkuH8W+JXxY+I3xT+LPiX49 /tF+MbH4kftFLiJtR1ZY5fg1+zVoU/7638KeF9FHm6dJr+jAwBNMt45DDqDi41afV9YnuLiH9HP2 A/8Agl54/wD2xpYvi18Y5/Ffw5/Zu1vUotXvLnURdad8Wf2lJA4Mk8d5Ii3ng74d3IU2638chvNU gPl6XEEg/tGPopYeMacMXi6jipSfsqNO/Noo6U3azqKVnPEqajSTX1N86jjZfz1xFxpn3G2c1+E+ E8BOdOCh7WVSVNUKHNP/AH7OpONSk6EIxvRyyScI1oqGYU8ZiJPKqPzt+yH+yR+0D+3l8Qpn8CXE eh+B9Dli8P8AxA+P9xpHleB/h9pUShbnwL8DfDoMen6nr9vaKLMRaaUttPzHd6xqiySP9o/sS/Ze /ZX+DX7JHwv0/wCGHwg8NjTbBHS+8Q+ItRIuvF/jjXmRRc+I/GWtMiXOq6pcvuKpJts7CIi00+2t bZFjr174f/D/AMFfCnwfoPw/+HHhnRvBvgnwvp8Wl+H/AAx4fso9P0rSrKEALFBBGoMjyHMtzczv JdXVw8txcSyzSyu3Xkk9f8/4UqlWdVxvaEIRUaNKFuSlFXtZ2vKXvSvJ66vrzOX6jwVwBlvCVOpi qlSWa5/jbzzLOsVHmr1alRRdSlhVKU3h8NdWlBSdSu4U3WnONKjGCk5JPc/5FJRQGCkY5bnC5AJ4 9/r2yep6Csz74+cv2qP2pvg/+xx8H9Z+OXxz8QXfh7wHompaPo0sumaXca3repazrt2LLTNI0XRL Qfa9Rv7iQmURW5JW3gurqUxwwSMPnDwJ+1N8G/2w9ctPCPwz8Wldd8QaTput3vhTxDa3nhLx94f+ Feyz1K51e58N6qLfUbebxRcXtuLZ7VbmSPT1tnma2SXa/wCEv/BWf9oPQv2uP24dO/Z3OrrP+zL+ wnp938TvjpeW8zNpevfFpYIDH4aunjwk8ulCTTvBVrCvmSx6trfiSJCvkk1Z/wCCLfwd8dftE/tn eMv2udcub3SvCnwiTXUzBvt7fWPGPj/SbjStJ8HW5Vin9i+GPCUr3t7p6gwxyHQo8IwRhjLAQzDC 1pYmpKnh1KMoxjGL9tBNQhSqXV/9ok6tS0JRlHDxpVo2VWEn+QZn4mZhhfEHJeEciy/C5msZj44L GupOpCphsPhqTxGdZnTrQnyqnl1Nwo0YVaMqeJxlPE4dVIVKTt/WZpmleFPD0sOnaXpulaXcyabD AgtrS3tru507SwttbpPdJEst3Hbb1VUuZXZZJc8tJk9A5JDdScY4wMBs4JIwQBy+RgkLwcZqheaX ZX4UXtuk2xTGBukUCMuGdMoyttdlVyoK4ZE5IFF3az/2dfQaW6Wl89jdQ6dcbQy292baRLKR1lEi SCC4Mb4kV1fADoRkEgqkXKLjBU0lycu9rWs42SVnotbNW2P192tfW+rfXXy238z5e8cft3fsZ/DP 4o3PwT+I37T/AMEfAnxVsorOe/8ABHiv4g6DoWsact/GJrOPUm1C6gs9LnuYWSaO0vbmK7MUkUhi 8uWJm+j/AA14x8H+NdPg1Xwb4q8NeLdMuoxLbaj4Y1/StfsLiI9JILvSrq6gmjIPDpIy45zX+K98 ZPiP8UNT+Mvxe1jx14v8Q674+1P4n+PZfHGua3fSX+oa34kj8VapBql5qTXZlEkzXUBVIiohgijj ggiihjjiSbwB+1j8Z/hbqMGp+D/G3iLQLq3kD/bPC/iHXPB+qoUJIaHUvC99pjgjPKzRSRHlXRkZ lOSniI2bVOWl2vfi7aac15K9v+na67sFqk+6T+9J/qf7Xp+XG75cnAzxk+gz3pCQBkkAAZz2xX+V b+z/AP8ABwF+378MTbQaN+118SPJi8mODw18YodC+KPh+5Ct/qI9X8TaZfX8EUoBUiO/spNpAEiM oYfs58Jv+DqL9rHRUtv+FrfBL4EfFbTGMLy6j4WvvFPw81l4QiiSRJYrzxTooeXlkb+zxGrnKYQb aaxDXx0Zx1esXCa09ZQnr/gVr7O2of3cAE9AT9KQkA4JAPoeDX8uPw9/4OoP2U9c01P+E+/Zy+PH hTxFHHG9xZeFrzwP450FIXlVBJDrkut+GblS5JeOG60mCacKzJvAyPuv4bf8F/P+CZ3xC+zpqvxV 8W/Cu6mjDNB8Tvhx4n0qCB8ZZJdU0O28Q6VGqnGJpLyOEght4GcWsTR6ycfOUJxjfS655RUbq9rJ vr2dg/aOivmn4X/tmfslfGoR/wDCqf2k/gp46kkSORbTQfiL4ZuNRCzY8sPpkmoQ6gkjZA8p7ZZF JAZRX0qpEkaSxfvY3UOskWJEZGGVdGQkSKwIIaMsCDkE1pGpTn8E4y/wyT7dr90AtFGRxg5JPTBB A9TuxgH/AD1pSMen5g/yqwEooooAKKKKACj8vxGR9SB1x1x3oooA/je/4Owf2O4/EPgj4Oftk+G9 LLX2hTP8HviRNHAWVtMv5J9Z8C6rfMqtzbXcetaMWcgFb6zTOVCn+JIRDxt+zV4j8OMjv4o/Zu8a P4/0MRp5slz8HvjBe6b4b+Ils83Eq23g74mWfgbX0iIMcEfjvXbrag+0yH/Xd/bq/Zu0f9rr9kn4 6fs+6rbxyzePPAOsweHriRFc6d4w0yD+1vCWoxA/MHttesrHJXBMLyoeJCK/yQ/Dwt/gj+0QdE+J dvcab4R1HU/FnwW+M+nSRnfZ+CfGpuPAPjN5IJSqSXvhKWeLxTpysymHVfDlixZPKD149Wm6WKmk 1yVI+3px6qUHGNZJ9FK8Wr7ym1e719GLVXCwm/elRl7Co3JJ8qXNRetrvkbgndPlglqkj4ulBUtk gEZwM89TnjAwN2fXniqUrEBSchZDt3HA5IO0J/eLAHAGTwcdK9J8YfDfxV4O+Ivij4V6hZtdeLPB 3irWvCGoQ2g8xLi90TU7nTxcQSKyxvp95HCl/bzOyxm0uI5oyySZP0NpHwl0/wCDui23j3xZ468E 6D4n064tL9dP8SaDa+LtFbSJrK6W7s7XTHj1Gy1bWrxiLNLC5s5ojDMz+baTxwzJpKrFcqV5OWyi m21p2Ttv1t1OXkculkpWb0vZdXdq34ni3gj4Y2t4o1bxfcR6XaNa/b9Mt53t3tZo4T5jNqO6WOPy HQFZU3brYFZJoplXA67Xf2htJ1W8bwfqPhRfiN4PaGKY32parLeW1gyj7JbX3hxZWW40qZLa3WNI 4biwuGRAsMU0GwD56+K/xN1HxuZn0qxtfD3hu/uHuX0zSbGPRY7wmQEXUmm2WLCxsmO4R6fp0Sad C6lXM0pDHr/2ffiX8I/BMk8HxL8H6l4ihaO/tIG0yBbq+tZdStnuLDWdGsopbJm8QQ3tja6IsWsX Nxpx03WbjUbNbfULNY7gjTlyuo/fk3ZJOzUdGr3sr9Va99FuhXje0VaO3NZu9mtbb9fvf3+k3Xw+ 8A6nfWM3gzxRe6Ppes2U1hcad4whuHtPtV2jLe21ndw282owmzAgntkntdQUSQb3vo943L8NfhFJ pmoxiTS5Nb8URSb/ALZK9mPDmnWC/PNMDcP9pt1a0jy+rXUMcduJUMUayEA+a+HPhz4h8XeIE8T+ PZrK2tljS9jsp9SFlYaYtyQyWNzJGqsl/beYqS6ahaV5AqXTkMUPT+I/GOl+FfGx0fTH1bVorN4o PFNz4Wv49AvdKuoSUu4rTUJxeWqT7QgubMtFZo7yWyyoxDpLb1jzXstbJWVktFJb/Pe/ZlpRXvWT Sunazavy626tLZPu9uvafGHxyPhfqWmeJPhh4z1bwr8VvC/9h2gvNB13UfNXSddsNQGsadFdo09j 4k0S5SIWmuWepwppt/YahaWstnfI1wsO18NPH/wv+IXg3VfGHiH4YeNPA/xa8NeLtIvLj4qfs7XU LxaxpupxJ9vsvEnwc15o/DcF+8VvqWqWuseFNV02Nr7dbXmkJp8ryxtuPhh4Z+M16un6N4R8Y6l4 l8SPHB4XufCWkWOkeJfFmsLYS3xF54PFzqdhq91Bp0E99d3FpBa3UypJPPqXkyeZXr3w81LwJ8O/ B39k6clj4e03wzrc6azqlvI9h461fUy72FzbavoGrC6t9Y1hHjuLKHytpsIzNFHNFEwJ8/F5fhMQ qdVwqUsXFwUcXh5yoYr2UZ86w86tP3quFUnJ/V6qnRUpTnyKXvL08FmWLwjqQU6VXDOMvaYTEU41 sLUk0oqr7Cp7ntUkuSpFQqJKK5rRVvob/gmd8UPF/wAav2lR8L/Cvw613WtWvvC2rWmhjSIG1PXt Ukk1vQLZrrXNKgiisba4vmlimnisGFtpzq8SC6hQTN/oR/sZfsQ/tBfCD4c3Xw78W+K4fCvhj4ua rL4u+Jul6DNuv/C2mabaWGn2HgvQ74ySiLV/F0FxdDxDcwNPBYWGlQQm6uZJntLj8Cf+DUzxz+zz D8YP2iPAVv8ADXwzo/xe8X6SPH/gnx9dwx3Xiu48P2WoiDxh4TgvZWk+zQia+0zWo4bAIwgt7mB5 ZIrVAv8Acm5bIBxj2J98duT+VaZdS+t4ieIm3Tp5fiZUqOHU6k5uqqNvb4ipNLWVHEP2NGk5w9nO NWrXqzm6VDkxVT2cPZqMHLERjUnVjGMYKLmp+yw8IJRhCE4KMpNOXuuMOSD97H8MeGtC8H6Bpfhr wzplro+haPapZ6dp1mmyGCBMnOSS8s0rlpri4lZ57md5J55HlkdzvVHF/q1/H/0I1JX0R5xR3t6/ oP8ACjcx7/oP8KbRQAUUUUAFFFFABTX3bWKcsOQBgkkEZAHOSeRjjrnIxmlyAeSBnaBnjkkgcnjk n146nAr+av8A4KXf8Fb9bv8AXfGX7KH7DXirTLXXtDiu9P8A2gP2rRcI/gz4KaUJHttb0TwZq+yW y1DxrCivZ3HiC3W7t9Eu5Rp+hw3/AIhKtp8Tk01GMXOck2opqOi+KcpS92nTgtZ1JaJ8sYqVScIS 8vN84wOSYSWMx9RwgpKnSpQi6mIxVeVuTD4aimpVq07q0U1GMbzqTp04ymve/wDgpP8A8Fav+FL6 /qn7LX7H8WkfEv8AaourK4h8V+JJ2t7v4efs86e1uZLvWvGF608enXvjDTrX/T4dBnmWw0CNBqHi aSKMR6bd/wAt76vPHqfijx23j7xN4++IXjTWHT4pftR6+8+ueKfG/ia9YpJ4J+CttdK9/ePczPHY ReItOt7ILatBp2kWtpphTzcHRNFtPEcWl/Cz4VeHfFnirR/G2trHpmjwW+oXHxf/AGmfHF/eC5fW vEgdX1bSfCEmoPPLJpl3M8Utu0l9rV1K/mSWv9aX/BOP/gk3o/wDPhn47/tIxaN40+P1vY28/hHw ZbRW118O/gNbTRAjTvDFgsQtNV8Y28LLBf8AiiZJI7K4SVdCCuX1O57IUYYWKq1/3tapFcsFezjJ xdpxbUqWGbUZqm716qUZYmLtCjT/AJ8q4/ibxRzqrg8qnLAZVgazWIzGMnUwWVRcYxdPCVISisfn NSlOpz4iEqapRajhPqlBrGYj5M/4Jx/8Eezrw8L/AB4/bE8J/wBl6JZyQa/8MP2ZdSVbi3gZnM9j 4z+NjMpGs+I71mGoR+FZWNpayzRrrKEodKh/phgtra3t4bW1gitrSCGKC2tYI0ggtreBBFBBBDEF SCGGILHHCipHGiKixqoAq0zEk8ccHcfvk4x82OMAcDHbrk802uecpVKjq1JOU2rdEkltGKWkYq2i X4n7rwzwtk3CeWU8syfDKlTXLPEYiajLF43EKPLLE4qsoxc6rV1GMVGlRhalQp0qUYwSYx6/mT/M 0tFFI+iCvhL/AIKT/tj6L+wx+yV8RfjZKYLrxvLar4K+EWguyNJ4g+KPiqGey8MQLC25pbPSZBP4 i1farY0nSLxR88kYP3Y2cEgFiMcYznnpgkDn0JAPc4r+ML/gpb+1B4e/bE/bt1LSZtSi1f8AZN/4 J9w3731va3I/sj4l/Hd7iODWYYZQ0ltqLQ6zbWng3T9m+MWuk+Ip4nK6g1Q4upKNGLadS7k46yjS ir1JRVn7zVqdPR/valPRrmt8pxnxFT4ZyDGY9zpxxU4vDYBVX7n1urGXLVqrS1DDU41MVXleypUJ puLcb/nDc+GfGPgb4S+Cfg1i/wDFf7QH7Svi3TvjB8X5dz3fiHW9f8a6jIfh14MvpGTzprzU73Wr jxPqEBbbHcalbiWOMxKF/ue/YU/Ze0f9kD9mj4d/Byxjgk8Q2mmr4g+IerQqhbXPiF4gSO+8TXkk gG6SK0uSmkafvJKaXp1kigEPX86n/BFr9n7xD+0z+1P43/bG+KVg974e+FurXF14fa6hBsNT+K+v RSjTINPjY7VtPh34X8uSBFBW2u7nSNgja3UV/XWxyxPXP+Fd+KkocuGilCNNRdSEXeKq8kYqCt9m hThClBNJ2jfyPybwQ4eli/7U8RMfCo8RncqmW5AsRFe1pZBhq/PWxstpRxGdZhGpi690klThOl7m InzN605Pvr2ww9Mdcc565zgY5yQe1NoIzj6j69e2epH3h9K4z+hD/GN/4KU+Bv8AhWf/AAUE/bf8 BRwNbweHP2qPjXb2cBGxl0/UPHGq61px2joHsdTgdefukY9/hl+rEjBwR9Oox+H6981+33/BxL4C k+H3/BY79smya1+xw+L9b8AfEe1/dmNZ4vGPw48N3M11GOkgmvrG8LyDhpt/fivef+CYv/BuB+0t /wAFJPgBD+0qfi98PPgD8LPEWoatpvw5k8W+HNc8Z+K/HUOkTS2F54gh0bRr/SLbQvC76rBc6fp9 zeX8mp6i9pdXkOmJbrFLPil7yi2k79WknZrRXavdbJJmcHanC921GMXZNttJReiT6rW9j+bl9ykk HjGGzjlTztxgAjrgEcetdz8OpvGV94hstD8H6hdW8t5JH9oj3GXTre1UgzXl/ZSh7doYh0JjBPOD k5r9SP8Agpj/AMETP21v+CZN5pWtfFfwzo/xL+DviTVbfQ/Dnxz+FB1PVPBLa3duU0zQPFdjf2tr rvgnW79l/wBAj1e0Omag5aCw1e6uAYh4J8Hvh1afD7RXnuXhuvEWpRpJqd3EwItiySSJpsRIIWO1 LbZlYndOp5+U06lo6OF3a6tK6e2sbJrTZtdVZ2d0VGUZJuLvZ2ejTT0dmmk09VuvPY9Y0Gwj0a0i USF7gBZ7u8UyRyXlzImye4kQOEjD5dbWGMKiRfKqAHnpvtbAOScpGTIrBHSRYvLUeXI6NlAeMqpw T1APBy5CixiGNWUyJtLSqqhm8uNgRt5B3A7XIwDg+1AMm3YFfCq24DO5ypjdN8mDuVmVl2gfO3Tn Ncut3e9+vf5lGzHdqxjnMUPnbwYrlowjxNncDHJGBJE27nMbAg4AwOK+k/hl+1j+0v8ACNSvwv8A 2gfjX4DCSQCO18M/ErxVYWJEXKbtKm1KfSZIoyoJiktHjKAZUqQK+WIwlwCoQiWNHkBZzhADyVHR nLkqqYB5JzjNaEE6QwOrRgziKRRGjkBTLt/hIG8onDOMjAUdeKmUIXs4ptW1svKy7+mtgP2s+Fv/ AAXc/wCClPw5jtobv446R8SbK38sPZfFDwL4V8QTXKwnGybVtIs9A1pFlQfvJxfmVzhtxbk/oz8N f+Dnv4tWot4Pix+zB8PPFPMLTXvw78Y694RuDEx2yOmneIrfxRbuxCllLalAgbK8g/L/ACfReYZB I0Yk+UAq4Mu1ggyAw2oGI27VO7GSByDjXEmFeZR5LYEJiKsrYO3ywhUrje28AHkkr0zUqLj8E6kP KM5cq2TtGbnBbXXu3Tbd3sB/d78Lf+Djz9inxg1rbfEPwH8cPhPfzyIk0t14c0jxtoVnG2Abm41D wxrD6qLfJJDroDMyqSE3fLX6CfDT/gqt/wAE9PiyYIvCf7Vnwstry4ICad4y1G88AX25gCitD4zt NEUAgkMwkIBB5Ar/ADUYrpQGP7zYxUKDJMrAryVkBb950IVVDAHryacdXCpJAUJkjLFQoikjBZg0 ewOhMbNg7wUxwWYgVanXj/y9U/8Ar5Tj0t1p+y7a3vd6u+wH+sh4Z8YeEPGunQ6v4N8VeGvFulXK s0Gp+GNd0rX9OmCjLfZ73S7u6glweCVLBcEMQa6Kv8rH4IfGD4vfBDxzoXxC+DnjbxF8OPGFkHvt O8S+HNStxd2nmpLb3cZ0IrPp92t7DuhlGrWU9re2krJ5DwqWk/tm/wCCHn7d37Qf7ZWg/HzQ/wBo LxnoHj3W/hLe+Ao9L1/T/Del+HNbjXxVZa3JfaX4gj0C2sNDvLi2/sm1uoZbTT7eWH7bJHcZchV0 p4ianGFWC9+fLCpCXut8raUoSalB+617vPB6PmUm4xD96KKKK7AFUgEEkgg5GPyPv37V/mff8HLX 7GEP7Pv7dHi3xv4f0f7H8Pv2idJ/4Wnoxih22UfiC+kOnfEDT4ljQpuXXg+oNCh3JBq0DMQDiv8A TAr+eX/g5P8A2SE/aE/YLvPitoulG78b/s2a4vjOCaCDzLubwJrSR6R40tWKr5jW9p/xK9a2sTFE NPlkUeYQRwZhF+yjWik54eaqXf8AI/cqq/8Agk526uC23O3Ay5qksO37uJhyL/r7FqdFr+9KS9nH Va1L62s/85DUPi34c8d3thqXi5o/A3xATwx4O8P6t47ngudR03xNc+D9A0rwjpuuapc6ZA+qaJql 3omkWR1SaO0u7a6v7eW8uJgbiZ25LxH8Ctf+Ib6RqWl+MtD8W6Pb3s8e4ie3mhS8mgTdDNYNe6Nr ECmOK8SQNpmszfaLiK4icozQeYeJ9LltrqW28uSQmd4Yo41LvJIZWVUVE3O7SYOxFXe4OQMV7j8L fhbc+DLjS/Efi/XNQ8Iaj4ltZz4X8Nxap/YH9t2zOkDXuq3krrY3GmLNIkMlvJcRrFJJGHfzZEib kk4wtOMrcy0Vk9OVNuLVnaz6Np3T7WdpTk4OCnaUdPeV27cqum9JJqyt5pnLfG6LwL4R0mP4MeCP CUnjTxRf2Fld6r4r13Tr62OhyR28cU91oou7ezlsbuEQrEFtbi48OWdkQJpL+8JnTzLwh4BsPBg/ tzXZoTeWNs9/9sulu4dOshDPHH/o09vG7o13LmzjvhtLTYFs6ttZfp/4j6pbtaG48U3N7Jp/hMxw NFPPdW9vbxXlxEEstJeYPK0RnP2uc2MV3Jfwotxa24gUZ4vxl4P0nxfpUaWOraFbW8/2G5tdQ0TU rbxfZa6g3Ti2/tPRbt5tIe0Mk1u1hqvh/TLq2uZo5bqQOc1Ma1oct5OMLKcua+tl8SurN3vyqK6W TdyvYSjyz5XeVpUuZNRauk3HSzUZLlclopdmmfO3jXx9f6tpV5baDDb2Gky6jI0l8tgiXmoLGPnN pc3AknsI1WUhFt2WaWPJlkSVmB4/wF47l8ISNBPolp4l025ure6TR7hjE7atCx+zagkiW1xJfXVv byzx2ljeiewmuJlee1ndVx9f6T4L8d6Hc+H/AAl8JPAGp+M/FPjC5tNLtJH0G08QaG7RNuGjvobR 3Mc887H7RJDeK4dXTZPNOUiX0m2/ZG1n4Momi/EDwrrnhn4kWha81E+JvD+oaTc2Fu4+0WkVr4c1 Kztdbt7ZVIgmuhCZrpVa6SBY2LVEsZhIONJzpe1nF1FSVSEakoK0eeVO6koJxdpuPLdWT3YlhsTJ yqctXkgn7SqqcvZxfWPPZw2kr3tv328Q0PQfFer+PrL4g+Pda1TTfEGntcXXhHw34c1OTRrrw088 X/EsgudU0R7RtPuxYPGJ49NMVyxjeO7cxf6GdfXPDf8AbN7Le3Op30GtebMizaq0E2napfS52WrT HybqLUbyRZXnuIBqImY72jG58dV4l+FGp+ItZS+0TXW02VrcS3Eur2Uus+FzqVukhsY7JbCy/tOz k1BzOjrf21yiT3CF7+OBXEPyl8QNP8fvq9nB47uL/ULi1sYm02WSJo7C2gl3OY7L9zFbAQzLPaPc p50ri3TZIyLAVqNRzk5XjCEYpRTvzJ30jytRaS1u0227K1tQnTVOELSnOc2otKFlHldk4zUnzc66 KCUYvd3R+t3/AATy/aQ+KH7D/wC0P8N/jholhcWsXhrxDplvqsrW0d7pGteHby6s5tc8PHUIhJaW 91qmlW9xAVkuI7yKMttjLO+P9Yv4cfEPw38WPAHgv4m+DNRi1Xwn488NaP4r8PX8JVludK1uyjvr QtgnbJGkwhmXqk0UiHkV/kW/sOeF9Z+LElr8KPh9rHxS+JfxP8XXkH/FtYrXV77Q57oSWNhYW2ka KZbmwvUNrKRLq2oTBFgRztsoULSf6eP/AAS4/Zw+Mn7K37IPgD4RfG7XrLUvFWl3Wr6nZeHtOk+1 WXw+0TWJYr218FQajvkF8dPuZLu6uHgkksre6vZ7Wyd4IFkbhwmKqLPfY0lOpTr4WSxcYp8mGdGa lhsRU91KCrOdfDqEv3tZypSpp0cLXnDfE0F9Rp1m4w5alqC5k3WjN2qwirXfsny1L/BCLcZNTqU1 P9HbckxDPqf51NUMHKE9ixx+QH8xU1fVnkmfRRRQAUUUUAFFFFAHC/EzwNpvxO+Hvjv4bavqWtaP p3xA8H+IvBl9qvh3UrnR9e02z8SaVeaPcahouqWbxXVhqdml6bizuopEaO4SI5K71P8Anaf8Mn/t f/s//tO65/wTs+KngnxZ4xu5PiDe6j+zHfaLob2/gv8AaD0bWnZ9F1/xB4strGO21G28KaRbSahq Eeu32/wjcQ6vb3a2suydv9ITAJBIGR0OOR9D2oaOBnile3heaDf5EzxxtLCZF2SGKQqXjMi/K+xl 3rw2RWcIzpYqniqco3jFwqU5x56dSN+aEkrxcKlKS5oTTcfeqKcJ3g6fzPFXC2A4syypl2MnVw8p 2UMZheSOLowlKHt4Uqk4TSjiKUHRqxlGUJwk41ITg5Ql+Wv/AATm/wCCaPgX9jXQH8eeN5dM+IX7 TPifT44PFfxBFqv9meELCaNWPgf4bW06b9I8P2aBba81IJFqPiCSMz3DRWZhtV/UvnAGScDAJwOn sAAPwFIOrfKBkk8Y5J6n/wDXS1rJuUpTk3KcneUnu2+/kvsraK0W7v6mU5Rl2RZfhsryrDU8JgcJ D2dGjTVrdZTnJuU6lWo/eq1akpVKs25zlKTuFFFFI9IKKKUbBkuwUDJJbgAAckt0AHJJ6AAk4GTR /X37B/X6fnoflr/wV6/bXvP2Lf2QfE+reDJ42+OPxhvV+EPwP0+I5vU8VeJreSHUvFcUIdZHi8F6 E91rYeNZCmqf2PBJE63JRv46r/4a674W8P8Awl/Yy8B2934h+KXjLxHoetfEYw5nv9a+KvjdoYtC 8PXzh5Jbz/hHLa//ALQ1m4laQrfXF9cTGM2shH3D+3P+1Hp/7Yf7dPxT+NRvxqn7Mv7C2nah8OPg 3DFIbjRPHPxfnv2ttW1615FtdprPiq2iNrdw5YeGvCsMq+YsxCfYH/BB/wDZZ1b4p/FXx/8Atx/E u0m1K08Malqvhj4cXGpI0zat8Q9bQS+NPFsLzqRJ/YGm3i6RaTIoEWpaperG26xYDpwSVGhUx09Z ycfYaJ3VnLCQd9HFxlPGzjezhOhe8qKR/LfiJiMT4i8a5bwNldaawVSrWwuOxFG0vquUYWtTfEGY rWUVUr1KP9k4Ny92dSlWp8sqeJ54/wBEX7Hv7Mvhb9kf9nf4b/A/wyyzv4X0kXXifWURFl8TeNdX xfeKNfuWChm+3apJMtuCQY7CGztx8sAFfTdGMcccH+R4656UVzPdttttttvdt9X5s/prBYPDZfg8 LgMFRhh8JgsNRwuFoQXLCjh8PTjSo0ore0IRUVdt6atsKaxKglRk+nc4GcD/AHsbfoT0606lBxn6 cfmD/Sg6nr+H4O5/mjf8Hdvw3fwl/wAFPPBfjwqUt/iz+y58P9S+0hSFk1DwX4q8Z+EbtQcENJDZ xaWZAuSkcsZJAYCuA/4N7P8AgtVdf8E/Pi3qvwK/aEu/Ffiv9lr4x/8ACOaVb3GnyXOt6j8D/F+j mfT9M8TaNoTyma68FalZXZsfFmkaMpvbR4LPXLKC7ktbuyn/AE+/4PRPh60eofsEfFy3swGkt/jX 8M7zUFTDSbE8IeLdLsJJf4Vj8nV5YkCk/vpn4UMy/wAZXwd+G0/ijVYfEl/Dcx6Bp0xaDyXaCTUr lM7UScMpWJWOGZSAcHsTXNUtzN6RktYSsrqVlqr2v2kno090RDZr+WU1/wCTOWt+ynFeiXc/sn/4 Lsf8FdND/bA1jTv2V/2YPFUWt/szeFNR0vxH8R/Huli4jtPjR45054NV0fRtJa4hinHgPwJdolzJ I8UA1zxnCskcf2LQLSW8/nHWziYvLEoRpSqsFwjSEMHjLJjYpQ/LkKBtODnqKyRQW8IVMoixRRGJ FCAADbGqABkCIqiNyq/KUUgHzCRa80zJGNoRWZ13ltpUB0TdIUQfKP7wQgAEgE5Bx96TTbbbteVv NXsk9EntZ20u9d7t+i+7YFRU3ZYuRIDuXcWAAIVSueVLYUEAKDyRjGL8chbk7ZJHCIqlTGQsUhkA IX5SU65AO7Oc1S2x70YM7DO1fmYnEiISAQAHAYMQCAQDyOcVbiyTEAJZRH5ixKFInJcYG35Q8YJ4 ztcSrhV2H5gS1b0a20fogLVukOSrOiksZCGaVcD5i7qyqnmea5AjiJ2sFfjIGL0asgjzI28LtBkQ p8rMSFChgULZK4JZVGCeKpw73WVgSVVGijiUuyuFBZC7MWZWVnywVv3XPADYq5L5sOJGlODDvAeS NzEVJDkEoVP3nO1yP3bKSCUAqdtu/Vt+vW+wD2PljZGhk8tlLIMyNAMlmyGcBBuJBkXJZRx6i9bh /Mlidt0fmLIQoZjG3TKgqzMPLY7ct8pBbrVFkj3ZVT1UBYVWVW3yhWR5XKttVBh2XOBnHcVqIWLK Nq7CpwmQdqpjG07ixVyPLJOCFJIHyqaYEkEQjyZoxKqPiTzEJkCLsJUq7DyyQxAOdo4Y1xfiHxJo miSLda3rul+HtLNwI7m7uXaZ41jjnmaO0srCK4uL66W3tppkh2EC4a0gHmPLtbptd1AWNo800kUK +Q5IzyqNCHYDzGUS/KD5km8hFBYgc5+RJvDes/HXVNXudLvoLTw1oQisbO/kjuduo3jXH2mUW0lv IowbnBlnzsTy44C5jRcUo3Td7Lvp+oH29rvxM+G/hX4Q3fxM8OeItA8WWdjqdr4a06y0q+8rV7jx NrFlvs9P1DT/ACrfUdKY2sFzfJc3GnpG8EMuJYT8tf13/wDBtRc6LYeOv29/D2mi7NxceJ/hfrE4 ZY/sFqbfwx5E1rZlFEkQ87UAzLMf3xVpYxxIx/gv8d/DLxB8OPBOk/D66urG91zx/wDETTPFHh2x sFt7nxBHpGhaJrGhyarqtu3kz2tld3mpyNpUO2FJYLWadZZ4HLN/eJ/wbCXNprV7+3j4jtJWvbS9 8ZfB620jUnkgMtzplv4GNvMZIrZnhjZtUtb1pBvZ0nE8LY8rFQ42qULtv98rPq7Ke/lo7W6X3sUt pei/Nf1t93X+sUcgH1ApaKK9EkK5Xx14J8P/ABI8D+MPh94ss4tQ8M+NvDOu+FNfspkWSK60nxBp tzpd/G6sDk/Z7mQxkEFHAdSGVSOqo9uoPUHofYjuKUoxknGSTjJOLT1uno18xpuLjKLalGUZRa0a lFqUWvRpM/yy/jl/wTv8d/srfG3xjoHjzwHr9ldWXjTX9P8ACPiPWdL1HS1n8OWmp3Uela54SmMb 6bqFzcaZHDcJevM9oXlS1laCR1Vvkb4hfAX/AITHxI95p1jrOgeOkSYSStPa+LGulh8u4nttR8Fa 39pt5beDzEe6Oj2lppdvJM0dzI/Br/W1+I3wz+HXxc8MXng34n+BvC3j7wtqKGO90LxZoen65p0q nPzLBfQy+VKpOUmgMc0ZyY5FOCfxH/aV/wCCAX7NnxQWfWvgX4i1f4IeJIo5jp2mXcV14u8HW8sl x9pWOyd9Q07xnoFtFMMxw6V4le0hjEcUViIURF+axGCx9KMoeyhj6CgoqMeSNRqyTVShXaozha6X LXbbX8C1pHt0cbQdZVqdWeBruSnzXmqdOSd06NehD2tHl0UbxTjFWlV6v/NB+Ofwv/aD13XE1/x1 fS+PbTQtOi0/TZfD+m2ul6V4X0PTlaBdP0zwTpNjYW/hzTbBorlXh0rS3tYZmmaRkYyivrD/AIJ1 /s0az+074t0v4P8AwH+EHjvxj8YdcezufEPiKC0sZNBtLMTLF5t7r8ckNj4Y8NWK+XKX1aJ2LiWV pLpXRYv6qpP+Dd39q/UviinhqbWPhzpvw5m86K++ITeJ73VtPt7HUJpW1C90nwwYrTxJJr06yzyX Y1Ema8nuQr6wsEfnD+o79if9hP8AZ0/YG+EmnfCf4A+BbDQYBHDceKfFdxBBN4v8da1sX7XrHiXW yrXVwZZgWtNOEps9PgCwWyAiSSTmh9exiWDwmGeBpw5VWxVbD1aFKglZOnh8NKNJYivLaNr4akm5 15ykqdCtVeeHozniK9dYzEVXzqMKsK86k3abqV8RzVUoOUnzrmlVqy0UEnOrS+G/+CZP/BGn4Jfs L6fpXxD8aWmkfE39pCeISXfjGe3Wbw54EkmhKTaZ4B0+8gR0njDvb3Xia8h/tK8JJsk063Bjb9I/ 2gf2Sf2cf2pNBl8O/Hf4TeEPiFbvazWlrqmq6ZAniTSVmRo2k0jxLarDremyANlfs96sWQN8TrlT 9D89zk+vqemfaivdw2VYLD0JUHRjWVWSqV6mIUa1XEVVFR9tXm4pVKiSSi1GMaUVGFKMIQjFeXPG 4qdWNZVp05048lJUZSpQpU/+fdKMWuWm7Xa+07ynzSbb/kj/AGvP+Da4OmpeI/2PviOkrRI0mmfD b4k3KadfWIjYSG10XxrYwJZ30b7I0trXxFYQIpOH1AqZGH4t+BP+CDv7bHxi+IOrfBjxP8CtT+HJ mMtt4k+JfipILHwboQvk3L4hXWLOS4tfEh05wL3TrDw9JO95dNJG8ZV3Cf6QGBnkA85PHX6/hx9K eWyu3GB6Z478YxiuSvknMksJja+Djf3rRjiJQj/1DyruTpTX2fa/WKUbfwXF8p1081kryq4ahWqp XjVXNSblpZVaUH7GcFbVQp05yVlKbsflt/wTQ/4JO/sz/wDBNP4bW+i/DPSY/FPxU1eyhXx38Ydc srRvEmvXYjCz2ekEQ7tC8PRyZW106F2neNVN7cTycL+ogUDHJ455JPOCOSSWOASBknA4HFOwPQc9 ffPX86K9LB4LDYCiqOGpqKu5znJudarVkkp1q1ablVrVppKMqtScpuKjBy5YpLz61eriKjq1p882 lFOyUYxW0KcUlGnCPSEEoq70u3ezbf6ofVv51PUFt/qh9W/nU9dZkZ9FFFABRRRSd7Ozs7Oz7Pow CiiimtlffqAUUUUAFFFFABRRRQAYJ6DP+H5GvyF/4LT/ALaV1+yJ+yJq+h+B9Q8r47ftEXN18Hvh BaWsn/Ex0yXW7Ro/GXjeONCJUi8KeG55/sl1GUaPX9T0SISx+ZvT9euSQASMkKSDg/Mcde3XJPUY 45r+DP8Abj/bC8N/tLf8FHfi746+IWu6fBof7M//AAl/wZ/Zx+DmtyvZavrHiPwfrc2g+Itfu9Gv UVY73UPGbPrmpicedJoFjodjtmhKARyqtWpYZXbqNzmlpJ0KTg60YX+3NThSTV+T2vtGpKDi/juO 8+lw9w5jcZS54YmrGWGw1aNOpOGGqTpzlUxdWUFJU44WjGpXi6nKp1YU6au5HzZ/wrzV2j+Bn7F3 wms/7c8Q3Wt6Ja6y9gn2qXxN8W/HLWkV3cX0480XNp4Z0+WOCaeVlFikeq3EqxKJCP76P2YvgP4W /Zj+A/w1+B3g6KJNK8BeHLTTbq8jjCTazr0qm88R69dkKpe61rW7i+1CSRssVnRc7UUD+dT/AIIN /smXfjL4g+N/20/iDYNcaf4ZudW8CfChr+E77/xjfRgePPGMTSAiX+y7OceHbO4TkXd7qwV1ktto /qjIAJx04HUnoB3JOfr1rvxc4qUaELctFWk4rljKtNJ1pKKbVoyXs4Loou0uVpH5z4IcN1KWX4/j bMKTjj+J3CnlkasbVMJw7hW1g4Ru20sfUisXUeir0qeDrWTbbT60Uh6HHXBxTux9cj+uf6Vxn7uJ R9cAdyTjA6k+5AyQMjPqKKQ4IwTjPc54HfgdTtyAOxwccUfgB/KP/wAHaHgj4cfEX9j79nHRde8a 6dovxG0X9oyDxF4N8GmF7nW/GHhf/hEdc0Px9PZvA3/Eo0vQ4tQ0O8v9bvDHZbnt9Lic6tqGnxt/ FFp+l22lWtppmnQrDbWq/Zra3tIhHEAFG7EMY2J22bdxCkruIGT+jf8AwcA/tB/FyD/gq1+054Q+ I+rza9ofgjVPBPh74c6NqULf2V4a+Gk3gXw7rmi6XoyowbT4rzVtf1jW9XuIs/2tqd49xeK5gt2T 8kdJ+Pfh9jFHq+k3tpIFLvcaVdQzN5qO3lFLa9ji8uMcBliuTI4z97pXG/aVG24pWdtE7W/mu297 bW0SQkkrtbt3fraMdPlFabaX3bPY2ixujMuBGxXa8ZaQudvy5IwuOTzj7h6g8WxBKNgZDsjBAdSu 7c6kEc7cpuw5ChiRkD5ua5LTviJ4I1babbxHBaTTS7/I1SJ7XDYAl8yZleAff433GxdxGQDmu/t4 Yr2IvZXNjexgHy5bK9t5Uxt8wufskkiSOVBAw5U5AyDk1NnflcrWae7302t63103GUkt5U2KFJRX TaMEvJJtPClA20EcgZDnspxV2KDJt/NK7VWVkQOodiRuI80YcsrEhV3bdo+UgcC5HZBRKHjZpHdk j3sNhBXgphWETqAWWYEPgYV+TVpI45grbiJCXCOyMnmROsSrFN+7EcbcMR5cZJAzxmp+9+b3dvv/ AK7ARRxxIz7Mosa7wN+8IRtjCO28cej7c/3yeKnjVyU8tTJFIrearxbyoIO35n2rJEXBG4Dk5AY4 Ap0QAZHZlKRIyPL5e4ZYxlGbcxWaPeGBOxlycEjAq27bijbgBI3zqzojgceSsYUfuwWDneFwrGMK rFnwLpezdtd99Nem/wDSWgEg3OylYCiyiRpIniBcOZURxAi/JFExlCRbi29iu0KeBWuGkgVZriWJ FA2QBCWLEbljIiKhiCDEJAFwi+ZISUjJoN8Y/OLNOMys+JWQFwjq0auSwXdEcNIqkBWPTO3PN3S3 eu3+maLYOINR1LUY7OOSYSP5NqEAuboRBllFnp9j5t1eyRurvaI8aSGSePNct1q0ttXddvw11fkt 02B5b4tuz4y8S6R4Fl1fSfD+m38N1qOpXep65peiXt/p8BjaXTtPk1a6sYbq6vna1jghNwpisDPN CkxJir6w03w3o/w+8Lvruo6bp9l4bgtpZ/PtyhttSsNN06O81aewOlkwyQ2UJjjeSN40e5m8ozmT zVHz5pX7LiXl7rM3jvU7LxhDeXW+0m01LqB9N0x7gxSLa6dfmaV7qfzlkn8jeiy+SjeWEjx7l8L/ AIcJoc2t/BbwB4X1jxRo/hjQNV8ZeKhdXTXVv4d1TxbcaXaeGvD0kBQtcyapY6fdX17o8TRTiGS3 nYKdSOScoqKXMklbmd7JXa1bdvtafevJtJydkm2+i1PnDwV4o1rxR8ZvHupeOPD8U+o+K/Bi23hb TdRtFuo/C1rruoeGb/R7uzuo5IJNFjXwbbalbX10kUkzNq72qRxS3Hyf3Ef8GyGlaVo/hz9qqz0i 1/s+3W5+FzT6YIjEthdM/jh5ECsiFTcBxdrCBi2imig4ZCi/yC+KPAnxN+HfxI0XV7z4SeNBf/Fb 4g/D3QtT8Qx+FNQ1TRvCvgvTrOxtNVtZdRsre507ShrDRqiG6ltykEc85lEdpGjf2K/8G3Gq6Xen 9rey0WK2i07S4Pgpbp5UUEV27/ZvHW6bV2huJzcarOqia8uZWWVpGcMihVLY+0U6+Haaa5+Z2akt YSgrWd17zvqlZKT3er1SaaabturbPU/qMooyDkA8jk+wyRk/iCPqDRXqEhRRRQAU4MRwD+gptFAD t7etNyT1OaKKACiiigAooooAKKKKALNt/qh9W/nU9QW3+qH1b+dT0AZ9FFFABRRRQAUUUUAFFFFA BRRRQAUUUUAMdSwABxhlJ6dAfmHIYcjI6A88FThh+W37Y3/BGv8AYI/bh8WwfEz4vfCZtB+L9vcx 3g+LPwx1m78FeNLy4ht/s8UuuPaR3Gh+JJREkMMt1rmi3l9NbwRQG6WFEjX9TKTGfX8yP5GsqtGl WSVSPM07wkpSjOm+sqU4uM6UnZXlTlGTsk20kRUp06sXCrThUhJNONSEZxaacWmpJp3Ta1TaTaTS bR4p+zp8CPB/7MvwS+GvwH8BS6hd+FPhj4Ys/DWl6nrT282vawLfdJda1r1zaW9rb3mt6tdyS32q XqW8JuryWSZlG/avtlFFaJW0/PVvzberb6tttvVtsVGjSw9KlQoU4UqNGnClRpU4qNOlSpxUKdOE UkowhBKMIpJRiklogooopmgUdeMZBIz243DjPON33enf8aKXGc+2CPqCMfkeaAP81H/g7D+Gy+D/ APgpzZ+NI4VSH4tfAD4W+LWlVVAe/wBBn8V/D+8UhR+8c2vhLTA27O1nQk/MK/l/K7JCR1Y58wsw fHUMAQVXYcAY5Y8dOa/t1/4PIfhyYfHX7E3xYhtD/wATLwV8V/h7qF9s3GQ6Hr3hPxFpMDN8pYwf 8JBq8hVS8hWfKoFVif5L/gP+z34O+NnhvxTf6r8ZtJ8A+KdB1W9Gm+ELjS9E1bUtf0HTPClx4ha+ 0yx1Dxf4V1PV9S17U4l8KeGtJ0G1vZJdc8pdVksI7m2aXGEW5SjF6OUrpyS3t8N2l32Xay7qcowg 5ybSTs2k5WWmtopysr3bs7LU+X45jGxCyzIcM5EaB1eUcqxBYDLkktxgEZAbPGxY+IdbspWltL+4 gn37zJHcywSZ2FWRniEce4jjYVJPAzxXRfFL4a6/8HviP44+F/iS6sbrXvAmuzaJqF3pckjWF3JF BBd2t9aiZUuIoL+xu7a6FrcL59rva3uMTxvGnnwLBzJI24ltu4sd2SfTO31/HviqkopK8U2r2vZ6 +dnZrbr6Ammk1qmk0/J6o9m0X48ePNJ8uCTV5r6CAE+VqUUOoR7AhQoXlhN1ghtoAuFUAZABxXrG kftIofKXW9CtrlAN2/TZ2t3iIG1QYrrzEchegLrjsQMV8fkebtT5N0qgZcfLkEEAkMu0HGCecDnH erCfccCJFLOrERgMIwXI3LJITuToANxz3rKUFs0rrquvX+tBn6J6R8bfhrqgMU+qT6XMYo7bdrNt OIQVQuheW2e4t0CKojViSxJDHDEkel2F1pOuw/aNLv7LVlU+asum3sM6wxmMmJ9iOZCGkZCVkRdo BI5OK/KNdwYsWYyecpGSIxkgDacgK2QOnBOOMZ4sW+p6jp5D2d3NDcRTCRWheaJ5V3xhXSZJQyhD uHyxknb1weJcI9G7drJdtevZ9vwA/VK/uoYi9lnyWficDaqldju8s7SDyoxZIfPuZFcgKochtmK1 vh1oD/arzxzrMEttNqenT2Ph20LndZeFDcQzvrMgVcw3njDyotRDzAPbaJFp0CqhEsZ/O7wH8U9f F9cW3ifXr++0a0t4rufTdSuPtdvqQTVdMEllDJcRvOsV2p+zXvl3FsRZyTBZBwrfof4D+OsnxQ8O fEXULbRND07xb4Y0G11HSmtUnjtb2W7N9Gxn06Zksre3tmtVmMEO7bOsNrGnku4qJLleidmkm+m9 vzs/6SA0bf4s2Wm+NPiT4U0DSZvEV/4C8Daf4ljtY2/dal4y1jXNO07QtCBVTLFBZ/boJtXnWQC1 e4hhYPJZMB+kP7CXwT1WG801bnUf7VvdX1u78ReP9bhltvs/ifxTcyXH9tX1zdyJcRrpejPFb6Po 0Jkhezezjt7AyKhr8Sf2KL65uvih42e9uby6vtZ8CpPNfTPEZptZ/wCEz027NzLDIDFNN9tupp0j lQxEvuMeEVR+13wF/am+IP7PWrSeFIdP8EeP9Fgm+3RWuueHbjwreWc8sty135V/4e1EwXUYc5t7 5tKMk8wkRrSOOEPNwY5VOVwpwUnaLmrtNrTXXSyvdbb79HvQ5VNOUlHor6Jvt67f1ZP+ii00iG1t razezgljewhgML2sEokAiaWKJgwEYVGkGLcxXERjAYuGO2uj8GXt78FLPxr8Sfh1qkXwlsrbSbLV fiR4t0S/0Pwzpt1DZF7XSpfFCX1oui6wLS6v3s7I3Vtd3YluJ1RAjmNfxfh/4LY/s3eEfG//AArv 49eEPFnw38S2cOn30954W1PTPH3h5YNTgWW3vNtz/wAI9q9iJ4laV7RFvLmJmg8uMByo+6PA/wC2 l+x58Wb2BtF+Onw5udWVIlfSPGtzf/DnVoItVEU9ta32k+LbbQIr+W4KvJ9kR9R2GeKVP3U0UteL KjWppNxq03ZSUrzjZK3vRlG6S66S030Vjt5qc9LxktrNp63Vlrv6ff0P1K8E/t9/GS10vR9ROrfD 34q6DqNib+11F7SC0fWLAttj1Ky13wpdx6fOjSLJGXXRSA6kPFvBVfrf4X/t/wDw68WXQ034i6RP 8ML1rZp49Sm1L/hIPDc8scipJaPd2thaX+nzqGMge+0yO1CK8f2tpFIP5B2+laPp2iWEXh/TtN0X wxF9sOn2Gg2Vj/Yu/Ur+W6nFtHpuzT2hvL65uLxVspJWY3AcLuJJ8911L3VfHlh4Pt2u7OPwkbLx P4vJuLqNzan5/DmiTLc7ZIm1u8to7l7chpU0rSbt2YW95bbt6WYYujG/1hzUFzThNucJdlzTbmm2 kruT6tecvD05tRUGm9E46W1V21e1krs/qO8MeOvBnjW1N74P8U6B4otFGXn0HVbLU1i5CkTpaTSS QMrEKVmRCWIUZc7a6sHIyOh/H+Vfib+xL4Z8RR/GjSNT0o29ux07ULnxBcDLlfCamJp4ruGOVIjL qF61raWzzG4e3mlS4hjQo7D9sR0H+JP8wD9cgY6YHSvocvxdTGUXVnTVO03FON3GXuxd1d6WbaaO OtTjSnyKfPpd6W5X2er16rys+otFFFd5iFFFFABRRRQAUUUUAFFFFAFm2/1Q+rfzqeoLb/VD6t/O p6AM+iiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigD+Tn/g7x+H02vfsLfAX 4hQRb38B/tENos0oLq8Fr44+Hnigghk+YK2peFtMDchWbYpyWWv4Xf2StP0S41Px5qNt8MvD3jj4 i+B4/BvxN8A6vq3xJ8M+B/Efgu28H6vczeLL/wAHWvjTX9B8I+IdYjgutM1tTq+m+MLGym0azsNY 8LahoGs6xdWH+kT/AMHJ/wAPB4//AOCQ/wC0TcJa/abv4f6/8JfiJZuF3NZjQ/iR4fsdTuhg5CDR NX1KCUjbiKZ8kgkV/m9fsc+FLP4j+K/iv8Irq28GXMnxY+Elz4V0678Raj4Q0Txhp+pHx14Nngb4 Ta1450+/8NWniyYyv/bunXc2j3GteCLLxNY6Nr2l6p5EsmcXy1n3ko289lby+fqZ1LunVV7KKi76 q2qd9Gr7aq6Ttqzyj9orwR4T+HfxV1Xw34Fn8b3Hh0eGfBWrG5+IWh22g+KpvEOveFdN1XxebnT7 B59NXSY/FE+qjQJtKvNS0mTSjbDT9Tv4VFw/hqxPKdhJKY3LuBGeOOCBweRkV+nfxA/ZK8M+NviR deFfhfoviK38Rr8HfA3ifwl/wh/hLw/4d+Gnxy1TR/H+q+BfjD490OC61o6P8M7XQ7Owh0q28Jar f6HH4m+IOmasbO40iG+sNNuvg/4teBovhZ8TPGvw6h8T6D4xXwbrkuhr4m8NXSXel6iy2ltdDyvL luY7bUNPe4bS9cs4bu8i07XbLUbCG9u47MXU7lGSaT25tGvOzf3fn8iaNWE4xjGbk1BaytdpKOra vHqk1e6d01dM8xV4oFwqOxywIJJjJYYyDkY8sncx6YGD2ywPtCNGA4DAMyE4zjk88kA+nHA7EVI6 hg8gibyIg0krqk0iWy8qstzKAywxNKQDJKVQsQo3E7TEksIiM3mIwUMGY7GQrLE4WVZAyjaCgwGE efbIFKS95t3UXpdd9P8Ag6fcbd99N3Z2+/bqi6IyYmAKuyqpjZlfO0qC3yfcVi27aeoHT30bXQNf 17TfEeq6Noeo6rY+DNIi1vxPe6fb/al0Dw++oW2lJrWqBSZINMj1C9tLW5vRG1vaNcwvdPDE+8c9 FKkxJgkWTlQDC4mATaW3AxsUZSx2FiwAYEAOc4/S7/glYvhx/wBp64ufEvjCDwvFaeA4zb2N94W8 I+JtL8aQaj488GaN4g8G6u3jO2bSvD+lX3hbUdau9Q1m31PQ9Ua3smsbG91CW5Gh6kQbnKMHtJqL cUr6ta6v+rmdWfs6VSpa7hByS1V2mtG0m1fZOz1teyu1+cvhoG7e7uYTPJbDR79gbfymjuVt7vTZ 3XfM6RNbrMsLyyQt+7kVDypyfpL4e+ILvw34H+M2oWcstssHgvRbe51C0gkubq1tr3xFaWVzqCLu NuxeKdI96ks7xbIvmyK9d/4KH6F428OftcX0fjuwtbfVvEnwh8EeINIsbJPFWmW1joWteHtXXw0Y 9C8X2dtqvhKRLPTQ914Nhlv9N05VkXSNWvLK6tynkfw40w6n4L+OuhO32ibUfhr4Zazs0gWW9neL x5ot0IbOVPMaIxbyVTIWUhS4YoMTWj7OUou/uuOttWk18vL9QpT9pThOyXNFSaTvZtXtfur2Z7V+ wjoGneKPGvi9tO163e3h8NjT3082uoW2sXM9/wCJNDTT4LZZbR7WZrpLeaWZUvBPDAsk3kFBz+mP iz4Z2XhjULrUri61DT72yuYbS/udOa6Niunrax3diz2OrWkzWoe1vjHulEUcyokixncAPNf2RPgv J4B1P4f2drawky6xpmveJbklhazXMEglmia4jkiaEWVnG9jawwnznm2iB5Lhlib6Y+K3xfvfhL+0 Jb+PtS12XRfhvZeMJIPGVvAzSQ2Ghzy6Qlrb3Oi3lveLdwjRVeR4HsnvVtma1lihvg6xeJjJyqTc acnF3ilZv3rwqe61s23FWTTvr0sdtHkT1Sd4tq6TtJd7q6jum097b9fyc+Pfwk+BPxO8f3fjXXPi 5478J+JtSt9LsLqVPA2m+LfCATQtPj0uxmu7XS9SsvElkXt4YmmeyW7Qy72RUGEH9Uf/AARD+PX/ AAT9+FWi/tN/D/8AaK+MfwC+IOh/GvxX8NNY8KeH/GXhqfU7ZbLwj4GtvCWoQeIPC3j/AECGax1O a7iS7t47e2vg0E6qLhriFgf5Bda1+21/VdZubVU/s6fVNUurBgH3DT7q8uHgEYUfuA8DRvHExLw5 COcqQP1f+Bf/AATS8DftCfsOfEb9rd/2vfh74S+L3hG01/WF+CXxC0XTdN0HXNM8Pte29jo1r8S5 /EcP2X4hatb6Fe/YdBu9DOXuNKMsZtdUh1WPocKyeHisU1UjJezVSFOcW403FQc+WElFpuCi6qTk k4rXRPktd000lq4uStrFc1+We3RKGut7an933wl/Y+/4JwDxdD8Vv2ZYvDHwy8XXmmarYWeo/A74 h6r4Y00f2ta3VlJqP/CtZ9QuPAsurWpnaXSbzUPB9xNp95HFd2YinhDVrt+wn40HxA0jW9d+N1h8 ZfCEd/CfEOl/GX4eafB8Rb/TLezuIbSGL4pfC+/8EPqVxZSy2sq/8JH4W1Izwwm386CKZJR/mMfD T43fGP4W3NtqXw2+KPxA8CzwKstquj+JdWs7SNzGJER7A3j2AIxGskZt2UZZG+cHH+kj/wAEUP2k /Gf7Sv7If9seOY7o614B8az+Bxc3Or6lrwubeHw9o+rF7XUtZe41Y2a3Gpyrb2N/qGpNpql7S3vZ LOG2ggUaUK1WFLF0MPebvGpQ56fNOEedqdO/xWpu95VIySadur96Kc6dSd4xV1UcZWi5RiuSSt1k tlFq7fQ/Sn4U/B3wn8JrXWf+EdsLe11DxDcWtzq81otxHAy2gnNtY2Ud1dXs1vY20l3dSqj3EjyT 3E8pwrRxx+tUUV69OnClCNOnFQhHaMUkld3eistW235s5223dttvdt3b+bCiiirEFFFFABRRRQAU UUUAFFFFAFm2/wBUPq386nqC2/1Q+rfzqegDPooooAKKKKACiiigAooooAKKKKACiiigAooooAKK KKACiiigAooooA+Cv+CpXw9b4qf8E4v23vA0aLLNqv7M/wAWLy1jdN6m88PeFb/xNZsFwf3i3WjR NHgbhIqlfmC1/kgfs5fDzTPi18YvCPgHWPBV18QtO8QWHi28ufBmn+NR8PPEGsQ+HvBut+KLyPwd 4jfStatLXxpDp+kXL+EdK1DTL2w8Ra5HY6JdW8MV+LlP9oP4ieGrXxp8P/Hfg2/hFxp/i3wX4r8N X1uRzcWmu6Df6XcQnIIYSQ3Tpt7byec1/i2+DIn8D/Hbwvpuraxq/hq48HfFfT/Dmoa/o2l2usa5 osum+I18N6tfWOkX9jqVpfX1qsdyv2K506/iu1VoWtJ2lEZhpe0jfbRv0TX/AMkvPVkyvaSi7Scb KzaaetndNPdrVNNWvdbn6aarqnw80P8AbK1D4bab4k8TWNr48/Z38BeBfij8Ovjx4T8C+DRaavo2 j+E9c8I/D7w5bS634H8F6d4mvI7LTPEsWuXkS6HrHja6ubmD+2b7Wry4X5D/AG0fAHxIuv2hvjJr d34O1povBcfgTTvE7p4V8H+Hte8PWS+DNKttL1TxH4U8BeM/HVgoudI0pH1nxraapf6ZqV+ov9Yk 0jU786fH9oftRab8UfCviv8AZ71XTLvxR8HvFtz408SaF4V8R/HP4ifDL4m+CPFvh7xDolzptt4x 8OfCvS/DnjX4sWnw9162tW0y5hvdE1f4fWkskFvZeGfDGpWjw23O+CIviD+z/wDFX4n6T8QvE3wR /wCFteJPhd8O/iZonxc+Gvijwx8L4tM0DStSv7LxDqWia94x+HGm+APFvxButI8Rabdaml7Nb6fd y6dH4X8Qb57m8fS9pRU3azSc001qlzJaW1lu9NLJdTgpzcEqkbOfsuVxk1eTU4JyTjaNuVyTveba ju73+Lf2W/G3irwh4D/bKm8AeIdU8N+JP+Gc/DvizTdZ0O5+z6hHZ+Dvjr8M7jVohKqlHtrnRdau U1K3mje1ubUSJcpLBvWu8/ZN+Muv6v8AtCfD7xF4x+EXgr4ht4FvtT8UeI/GfhL4NqvxL8H6PHpu o6NceOZ7X4YR6GviaDw5rOsaLcX1nrfhXxN5/mRsLG6uI4Qfrn4R/CP4NXvgT9t3xveX0114Otvi Z4g+CNz8YtWbRtP8SWHgP43weGLyK68Ux/DyTXPCNxp194lfSDFqHhmDUdL8NNbXF1pdvPZi4kjt eBfgp4D/AGXP2hPEt74A+GHxe+LGreFvjrffDnSbDQPG2ljxTD8KfiJ+zpL47j07U9J1XTrDQfFh gex8T3iX5uPDmu3TaTYjT/Mvla2kqNGUfZtSXKn72l+vM/d+18LVrNtL0HKvSk66UJOcoppJK93C mrOSknGSVSO/L6NJo+SPH/hbwnc/Alx+0L8S/hXYfGCx+Omj6X4V+Ivw3+Heia14617wddfDfxHe eItP+JnhDQF+Gnj1NAtfE9rpMw1/VfB2pa7p+rSQWDxTJdOD5p4Es/jZ+z9Y+LPj1+zh8cvCuqaZ 4X0LTtE+I2vfCXxTPaa1pPg7x54i07RNN0b4jfDXx1oOh6/N4X8QeJv7I0u5s59C1zTP7RFqz3Vv 5cVyv0z+3D40/aSj0r/hGvEvhPwHcfBD40Xnhj/hVEt54X03W/i3pT6Ze3GqeHdL1DVdasrD4j+E fiTq1pavZ+K4zaPY65ZxtY2V1It4YpPmD4Mafq+lfCn9vfwxrumazoGsr+zj4GvrvSNc0u90i/hf w1+1F8E7i6ju7HV4ba5E9rFdxu2yNXijkLlVikBMuNpxjFSa0SnZqTbaakneV1dpdVpraxpSlJ0X Ubi1OSfs9JwfM4QnGyiuWz5k1FaNWbb0PIfHnxU1/wCMfxJ0vx541g0i3106RZ6Penw9/bdnpV4d J0vWPst9BZ6vrWunSbieeWN5dP0d9M0GB9x0vRrASSBve/2OMSeOPGwkWFEuPh/NMy3BkKLJa67p MqTW0Ul1DyhU7ZFify2wViJwR8Y2gZtX063IkUzTmECMiaT7TIlzFaeXbyFIsNcvAszOT5cLySYJ Xafs39jGwbVfiZqFgEd573wPrKeWmyRttve6fPLFEgyzTu6iRQpAWLc2DsAPFVk3TlJ9YxTfk2nf V72T7HZCKjyxSSimko2slrtbofv34f1G28J/Ew63Y2scNpaaF4Ai0/wfp8V5p2k6w9/4R8N392sN 3bQRQCWX7RNd6m6X01xFcOHtrffPNIPGfFMWlfHPxJ46n13wbo3iHTdSnlOpaRdaq1rfRfZpdTee 8sPMuTeQ6faW82l29zqWpXS6hrmoSRR20+NNdDU8Z+MbTwr45sdN1HUZoLu8+GHh3X7UqJmtlHh7 4e6BYavIUaVPIazuJYbCSJUUyX2+NWJWTy/Z/wBnKz8CJ4dtdUv9d02fxFrV2Y57Oe4gnnghmhDa HpGmaTcGG2i00vdte6jNJI9tBci+uJZS9uFbwa8/Y0XOKvUmoqDV2+ZNe+2pK3KnuuvxaM7KUFKa TdopXem6stFvazezTvY6H9nD/gjr+zL+0drltaeKv2pdH/ZMnn1jxJZTeAvFuh6pq3i3VtMtdLsW 8LeIfDviLxNcaT4Cey1TVriePU9POt3l4dPjzaPZXoO71P4q/wDBrZ+2P4YtbzUvgD8b/gl8f/Dd 2iypZJrGr/DDW9UhHnC3jnguptd8IahJ5TYWabxFawsXJj8ld4b7P+EOm6fP4iN/q93pcti8Cxgi 4kmEo+3SXDvJbX2nGyNnItpLaRhGZJGjWSa4hR40P7G/BbWvDvhzQ7nxHpeuSeG9IsNLm1u71Wz1 e8063SxtAyzva2OnLbS6leKsLAW9jp92XhaMwxAMC3As5qUXGnWwc8S5y5VKjUn7WTbfLaDjUTaX Zx0s9NWdP1VSvKFbkilZqduSya0fvbXvrJL5bH8Hnxk/4Jc/t8/s93bn4pfspfGPStNhuVhGueHv DN18QfD8yiZY5XXWvAi+ILBIA21YpLkWqyB1Kh87j/dX/wAEF/g98RfhB+xfrVv8S/BPifwFqnjD 4ua94o0PRvFumXei6zdeGX8M+E9P07WW0u9jhu7Sz1Ge2vfsvnwQSS+RI7wqGBb7i8AfHHVfFHhX SvGHgnx3o/jzwnqkbSaZqc9tHf2V+kE0lpcwtd2q6fqNvc211FNBdwXQe8t7iJ4rmFHDIPcPCXxY t9Zv9M0bxNaWOgazrEs1roYOpFotavbeKe4nt7G3u4oblLj7JA1yIWMxEQJEmSBXfg83y7E4rDr2 1ejWjNxpUsRSUXKrKMoWdSEpwXuzlyqTi3JcvdS56mHxFKnO8YSg1rKD0UXKMk+Vu+vKtUmrN90e w0UdQD2PTIIPTPORjoR0Jor6g4gooooAKKKKACiiigAooooAKKKKALNt/qh9W/nU9QW3+qH1b+dT 0AZ9FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFADkxvQnscg56ZBB/MHFf4 3f8AwUe+HFx8Hv8AgoR+2j4Jt1+zHwX+1P8AFhrYQKymGC68cX3iHTZYCyPCqta39tLCro8e0qSk kfyn/ZCr8Wf28P8Aggj/AME/P+CgHjXxH8XfiR4P8V/DX45+J7eBNZ+Lfwg8TXHhzVfEF1Y2EWna XfeLfDGow6v4N8R3ljaW8Fs2oXOiQ6teW0UcFxqWyNCsTi3ZrdJ2v8rfkJ6NS5eZ2t0v8UZdbJ/D Zq60bP8AOe+IX7Znh7xj4F+Gp8Ip418KfEn4Z+JfCfi+5ufEcOnTXHjfxVoHifUb4a5p/wARvhzq PgW28HOmh6m2iXIX4axXGqW9hb3H26LVbu5M3pEf7WXwU+MvinQfDWuweIPhr8O9R+AvxB8N/FDw j4t13wxZw+PvHGqeOvDXjPQfAuifGBI9C1bwzpX9o+H7LX9B8TeI7qytdM1LT7jSZtHgXVdQmuv3 C/ad/wCDQD9oPwtHqGt/slftK+Avi/Z26PLaeDvi/pF18MPGUwLhVtbfxToSeIPCV/IIsKZdRtPD sOVXY0fAr+dj9pn/AIJb/wDBQH9kFb+X4/8A7KPxa8I6FZyNC3jfRvD0/jz4fSqhcG5i8a+Bv7b0 OBCqNJGuoSWFwY/nlgjAYg9vNPWPKvdu7e7pZaNdd9e3oYPD0baJxfvJWe3Pa6tZq12rWtytuz1P Kv2yXuNK+PPjK88MX3hXRfDnxO8HfD/xaulfCnxkdS8O6hpup+HNNVYfGlx4f1rUNDvvHk2saPca v41hhubnTf8AhKZp9X0yOGG7t9vsHwd+N/jPxR8P/i78XPinf+JvjDqvwn+Pn7Gfxg8VWWpulxrX ibwV4Nt/iX8NJba7mtbeG3aDSLfUvDVsl3qiGzJW1fVrmQPIZfzxWKDBFr9mwGZ5I4FRFDgssjvD GqhcFfmAQlCdpbcWA2fD/inxP4N1Eap4U8R+I/Cuq7DCdS8N61qehXxtyyu9tLPp13bG4tmkVJGt bxLi2kKJugDjcH7T35STSjJOy+Jaq2y+e6G6MXSjT0bjye9ZpyUZwk1e7lFSUFF2b0SWqR+lH7SH 7SPxttfFlp48vZNeX9kb9rGLSfGHhHwN4q0j4X61d3PgK11HwxJ4807w/aaQ+qv4A8Tx6npF1cac llqOlXlpbX1tqFoNOh1G5SP3z9sn9sD4K+Ov2WtY0X9nLx1od9/wm3iy08AeJPBPjrw5PY/FHRPA OvT67428SPoOk6zdX02h6dd6rpvgi01jxBoN7eaRdTWEGjWgt4LWGNPlD/htj4beLvgV4R+GPx1+ CV38Y/Hfh/R/GfhuLx/quoeHdMi8P2upWWof8If4n8J22m2NnqKeLdLvryxh120uJdK03UrLRbS6 uL3UrxzFH+cUKAwRpO489IVBnUIRK2wRysAEXDuyZIwodh5hClq39s1KTU1Pni77+6/d1StZJ281 daHPDDRlyqdN03Rm7OLhy1YxaUL8qvJqEYvnk0+ZX12Ol8F2Tah448E6aixyPqHi3w9YIlwrPGHu tRgicTAuvyKGJwzgEgZyoIP3p/wTvmsNJ/aU0a71VFTS4tD8fvqUlxJBLCujaTZXl9fSXAhCQRmC C0aaRnJUpbeaiupVT+enh25l03xN4bvzDBcNZeItCvhBcsyQXD22p2kiQzuEkKwybQkzKjMqFtoJ Ar7I/ZViST4o+K9OKIIJ/hx+0HYI2lM/kPbv4C8VzxfZgRmBIyoFsJAQY2US5K5XgrpSpVI7pws7 e7rzJNq3VJ3TR6Cdmno7NOzV07Pax9p/A74rWP7Qf7dEOseINNm/4QS88H+PdC8O6HcGa1dPBvh3 R4ZdOuZWQo9tqOrTWsmtSyLhre6vltk3ogYf09/s3/8ABAjV/jl8LtV+JHjPx34+/Z68W3Wr3Y+G /hXxH4c0vxLYX3hySziubDW9Whh1DSNdstN1Oa4iTTw1+97Hb28l/PZNJci2T8R/+DZf9j3wd+0Z +2YfGHjPxLrV7o3wq8Fw61B4T1TT1kTxBpV8lneOs2o3M0pNpPeWVlpkqWUZSexGpok8Ku8J/wBM hF2IqBUVVVFVY1CKFRQqqqjhQgG1QABsCrgbeeWGGp1sRNuN6VGEKUYNtLn5U56RataMoNPdttvq ae0lFKztJtu9tbPZa300bXr6H8aniD/gk5/wU/8A2ab+TU/h3H4M/aE8MafEsqt8PvG66L4jnsrK I7LX/hDviGulq7SoxRbTS9evne4DyRRl5RXs/wAHP24vip+y/rVpY/HXwp4s/Z98VSW40+5j+NHg PVvCOj3FrG6nGleI9V06bwjeRO5Tzf7M1tpA6vNOoj5r+saszWNF0fxFp1zo/iHStM17R72J7e+0 rWrC01XTr23lG2W3u7G/iubS4gdflaOSFlZeCMZBxr5LQm1Uo1KtCrHWEotS5ZLZq9pJra6kt3e5 rDFSjpKEJxatJNWuut9bNvrdH48+Bv2rfDHjWBdesrnSNUttcuvtsmqaJNpNzpV7c3CrvkSTRN9l ud1VjMih33KZCXOa94+FGmS/Gb9ofSvETR3tt4R+A2lLLEWWeO31Xx34m095JwsrCPz4rG0uIoop SrpJ9iuhhUngY+sab/wT+/ZC8N/FfR/jd4H+Cfhj4b/EnRrq9u11r4ayan4C0/VX1CzuLC6h8ReG PDN7p/hPxBAbe6laFNV0K6a1nEVxaNBPDFLH9c2OmWemIYrGBIY2Znf7zSSOxJaSSWRnlkdmYsPM dvLB8uMqmAOPB8PyoYtYmtXjVUZKSTUuepJ+9KdRttXUtFZv3W1sy6uM9pT9nGHKmrO7VklZJRSS tdLy2XY0BnnPqf0+UYHQDaAOPSiiivpttjiCiiigAooooAKKKKACiiigAooooAs23+qH1b+dT1Bb f6ofVv51PQBn0UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFB5/wDrUUUA JgZBPOM8Ekjn2Pf3HIyaR0SSOSGRFkhlR45YpFEkUscilJI5Y5NySI6Eq6urblJB4Jp1FAWv+Z+a X7Tv/BHz/gm1+1yl9cfGT9kz4Xz+JdQWVT488C6W/wAM/HkFzMAPtq+JPA0uhXF7dArlf7ZXUrfc zM1uzMTX87H7TP8AwZ2/DHWX1LWP2RP2rvF3gSd2MuneAvjx4dtPHPh6MF5StrF448KLoHiWztUz FHHLf6P4guQVZpJirAH+1SiocIu+lna11o+nW3kKy2Wnpof5RX7TP/BvL/wVY/ZkN9fX/wCzlffG zwnY+cx8Z/s861a/EqyltoY2lN3N4Tij0z4gWESwEFxceGpUEmQl0/3K/GHxH4Z1/wAG6zd+GfF2 ha74S8SafPJbX/h3xXpGoeHvEFjLGxRorzRtat7PUbd0ZSp822RtwYbeM1/uKA4ORkfQ4P5187fH z9kf9l/9qXR30H9or4AfCb4yac0Jgibx74J0PXNTso2Yuw0zXZrRdb0pi4DeZpt/ayb8EODlqhwm tYyT1W6tpfXVX/FNem4z/FZjhlF3ayIw3pd2rKXViuVuIyvDYAAIyoyMnjrX3r+xXp9rN+0Bpeja iXt7bWvDPxi069uokSFYrHVPh74q+0zKv3VaBWZk3bkAARjkCv7tv2mP+DT/AP4J0fFyPUNU+BOs fFT9lrxPMRLZ2nhTXx4++HSzIxkVLjwh45W/1W3glk2q0ek+K7CK2jybeDcMN8reFv8Ag1W8T/CH 41+CfiJ8O/2ovC3jrwhZXM9r4q8P+P8AwTqnhfXLDS9d0y50nxBceHtQ8O3ms6frM1vbahfnTdO1 Wz0uO4Bt47q9jKGQY1VU9nNKnJtxduWzu9LJJ8r37pbXSew42Uk3smr6X09D1T/g2L/Yp1jw18ON f/bV8W2N/wCGNN8bW7fD/wCAXhNR9hI+FmgWkWjS694hiRFbU5dVmt/t9kZm2Q6jealOmTtA/rYr hvhj8OvCXwi+Hngr4X+BdIt9D8H+AfDGkeFPDmlW0ccUNnpej2cFnBuEKIjzyrCZppAi+bPLLK4D Oa7mtqFNwh73xzfPU2+OSSautGoxUYJpK6jfdg3tbokl6JW289X87LYKKKK2EFFFFABRRRQAUUUU AFFFFABRRRQAUUUUAFFFFAFm2/1Q+rfzqeoLb/VD6t/Op6AM+iiigAooooAKKKKACiiigAooooAK KKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiiigAooooAKKKKALNt/qh9W/nU9QW3+qH1b+dT0AZ9FFFABRRRQAUUUUAFFFFABRRRQ AUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAFFFFABRRRQAUUUUAWbb/VD6t/Op6KKAP/Z /9j/4AAQSkZJRgABAQAAAQABAAD/2wBDAAEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEB AQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQH/2wBDAQEBAQEBAQEBAQEBAQEBAQEBAQEB AQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQH/wAARCAEpAZADASIA AhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAAAgEDAwIEAwUFBAQA AAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3 ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWm p6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6/8QAHwEA AwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSEx BhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElK U1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3 uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD++voA CAMEgHn5QMAdeT6jt060h55JyDkkn5gAfujI6DIOcetDY3YyMnJJHJAHXgcgk45z2P0oOMrgE5z0 GcEDBHGBnB7j3BoAbkDIUKME8DOORxg/7Xfr6YGBSk5yccDJGcdTyQc8AccevIpec8nIOOV6jkEn juCTyOxz60HGOeFJA5AwSM9R1565BJGDQA49NozkEZXPIJ6EHnGTxxxjPAppPYgYAII5HXr1/RlP Oee1IeOT16qBwMZ5OOWPtnv0x0oL8Kc4BycdSccdGweew6cdaAFPI+UFT6DrjOM8EkHBz6Hr0FIQ c8HgHAHfPY5/A8DuTSbxn2y3z4AHH8QOQR1x/dBB60mSuCcY7ZxkHOAx4BGQQMYwCSewyASYOOTu JxnAwMEEA8jg5980ZHHQkcgngDBwSQCR0Jwe5IHvUZ5PGe55BI3dMnoCAD045PvTyACRtGRhicZy B2Jz0B6DrjB60AKc5zjkDAJznn7xI5yB19OfYUHkkD5STtGDj8fTt2GeTQOFbOSMZGfrz3457Z6U gxz0AyVA+nVicYJJzjgEA9QKAEIBBJCnqQCMEKCOR13H9SQKM5ye2OCOueMHnuccng+1AB5x8vJG SMDIx1Oe5A6Z7470uenBJ6YHQ9R34JHGOvGPWgAH3uR6scEDHIPHcjnOR19DjlSerDkYBz1z6HAx znIz1A7d6TuRwWAA5AJA4PBGM8DPzfTnkUg64Geccnu3PGAMDvjt16dKAF6ckAnIA6EDdknJ4yOB gnmjByTztAyMeucZOOCRjqD7nriggdznPHGDkccd8Z5HvilOScYIOcEA4yMduTggZFACANkgEc9T ggEHnGOxx+VL3HoMYJA6HGMjjpg4PXH5031U59wDz1xnjOAOBzznGOMUoBz2PUnI9OBjJGMDAOQe ee3IAoPcDrzwSxJGRyR1Ucd+oIxQAVBBAxjdjk8k46n09vX8aQDAHYNjABxyDwOOB1yeuT174ViM A8E4wAeu7OBnjkA+w6E80AJyehzgAAdQCefu+wyBn6ik+UHgLkgjPPzEHnI6jHXGRzyDxSkDae+O DxjIPB468fU49MUcjByMZ5B4P5Dty2eOmOMUAJnIx/31+ByCPUjv6fhmnLgD0JJAGQQ2CeOOPr0J 9aQdDjPAySccZGCOR29DgY47ZpOMDpt/2Rg55PXt1B+X6ZI4AAvPAAxxnk5+UdOTwenQjIGcetHH QDHQ545LDPc9Oew4PIoAyCc4IGCPw4GTgYI5Ht2pcAE4GcA9gOCSTzxyRjByc/yAEwcDJIJG45BO cHpz046ZGQDjPNKAe56ZCjHOeMg5B4I6+gxyKTBOSM4HA5x14I5OOmADnp1pOozknjBOSQVPBA46 9QCTjOeaAHZABB6E/dyAfmzwMHJ6/dI7jtQQWGMA85PJCjHTafr14H6UmCQMheTwcAdBgdSefUgD nBAyaVevfjCnngYyAMc5z3PqaADd0JwDgknkdzx29MEmkx0DEEcZLc5YnIG4exGB0yKDgNgEcDJI 5znOFHpxnOcjkdaD97j0znHHJ/ADBHcAj6UANBAwABgHBAzxzyB2wOoHOTzkZNKee2eijoMjOOc9 xngfQ/VfUE59CvoAQOnTPAOSM9OQaDjjOBnkAgEZ49ACCPbIOe/WgBx5wF5wcYzyDjoT1IIzkZ5w MEU3OeSMrg4Hf5cnp1U57ZxjHakPHXII4OOAFxzwM57kkknHc9KdtHGTkdcdccg9D7c9OMd6AEwT jHGSNwHYH6Z445B46+tGCDkH6cEbcdc9cjn16DFHQAYPQkHgHPfODzn1x07UcrgHIJ/2upPYd8kj j8M9qAFxx2Jyc9MBsgkjOOoHIJx2PfJkdsZAAz3AI6AAnDcDjjOCabg8Y/AHJ69c/d64G3B4pcHJ OAMHBxjPIxng9vQng/jQAuDu3YAyQvOSdvuORk9Mn+vKZz3wM5IBxkDqPfOecYHFO424Jx0+8e3s cccZ9ehpq4I9M5wAOg7DnqSMZwR75oAQ4HLbcggk4IK9cYGD+Y9SaUHrwM8bew75BznA57d/SkGS OPlzk4PGeTkc855b6cc4xhRz65PHPToPm6dyDkgfUjGaABcAnIwFA5yBgnI5A5wMcA5HfHPCkkEn HU4Bzxk/TG3IwSen0pPXGCcnccDIxn0+U4z1Iz6juEA5wCQOSCST0xk59Rx39OfQAUcYBGScqTwM BcfQZ5ODQAeSSewXgkAEZzjgd8HGR260uBkdyT6A5xnHP5EjI69fRDljgA553DOOc9Ryepxx6UAG QTyOecYH3geMAZ+8dvfGOvejoc89cjOc45znHTPAB7nsOoBwMAAjhcDnkHrlT3z3wfUd6BnAypB6 kgAc5wBkE9RgDjBOOc5FAADnrkjBAHCsCQQQQcAcdPmpDgEEgZ4K4DEnqSTnPCjByAe+OtIR3HP/ ANc/LknHvnHHXGaQkk8BlKnsAWAycDGeRnnnAxye1ADSwLYIDbiAQuMrkHGQGBwcZU9zwa8U+M3x 58F/BKwsLjxGt9qOo6kzmy0TSxBJqL20Hy3F6yzTRxxQQZXLM2ZH/dxqx5ro/EPxk+F3ha7/ALP1 zxxoFhqAkERs0vY7q6idmZMywW3nyRfMCjeYFw3B6gn4L/bA+GPiDxtcL8a/h3cx/EDw1baNHY6/ oWkSLf6lp1taMX/tHRorct9rhKHfe2JVblGTzVVs7R85xBmeMw+WY6eRRw+PzTCwjN4SFSnWrU6f MvaVXh41FUqThT5pQo3i5ytuk4v2MqwOHq43CrNHWwuBqt/vnTnCFWS+GnGryuMVJ6OevKuqumfQ vgn9sr4U+M5I45INc0DzZBEj6haJLCpYkI101tK4t1Y4wzqwzgHjkfWNnc217bQXVpPFcW11Gs9v PEwdJo3AIdWTcpDZyNvTB3EV/OJaX1s0Cahpd/DE8yKyLuWJXUHmK8jclo2jcAuJNhjcFXXIyPqr 4Lftsab8NVXQPF2vWUujLOsLWd1fW6z2WDh7ixklmP7gLlijllYhQNpIB+O4a8RI4yq8JnkI4Osn FKt7KVGCbSX7yMpNJOV7uOkEm3dar6TOeEFQprEZVOeIpO/7uU1OTfaElFJNJaqbTbva17H7LgbG Y9cg8nnBHQkDPyt0B6YxwMYDwynOOOctgZBOBwCcYx04z1IIzXk/w2+Nnwt+LVmL7wB400DxHLtz PZafqtnPqMGATtns1ma4UgAg/uwB14BBPqwOQARuOCo2gqQASOpxzkY6jkHjpX6hTq0q0I1KNSnV pyV41KU41ISTSd1ODcXo09GfCzhOnOVOpCUJxbUoTi4yi1unFpNNeaJCcDbg/MBgYzyd34dF79yM d8A2kYAIJJwBxgcEAjOB68Zx1puB1YchjhScEknIOcjn2OM9ueKM5GCA3BDEDjBZskDPB5yQeR2r QkcDjPJ9yOQDjk8joScZAJ4x3o6gdzzkdiTjOAMHsCMgAc5NIxAGOckDjgA+5xngjp6kEcHikGRg 447HGMc8YHYgZB5HH1OABRwDxjPGMZ5HoT6A9+gOAOlA+hzkDII28jrkknbz9eoxxyY7heOuACf6 c5OeKU5G4/N0BOQMbsqc59eSMEevTuAHp909QT2PuTgcrySQc8njOaNueDwCeuPl4wQM/wB046n1 xzmkHJyOcjPJzhs+xx64Udeue1KTjoADgZ4PLDgccDAzu9jQAp5B5GOmR9TwD6dzzxjgYpvGAoAI wRjknJ5LBs45Pbqe2c04k85OQMA9BnPJK+uMcdecg9MloJGDjAByCQT14OMc5x1yOMH3oAXg56kg ccYGB6/5z27ilJBAyMjjk8YI+bk8ZAx2Gecd6CcjIHH/AI71GOM/U5ICk8dTSKNvA5I+Yk4LHIIA IByPbgj3BoACO4yBg9uvXG0Z5yecZH1FG7PGTjjPHX3Ukc8jnOMYx6UDPOUOOAMLzg9TyQc5x6kd gRnDfvHA6jHPXocZH+yV6Hnv6UAOIB7ZGTyckrnnsdvU8DPQ4PpSE4x0OByMAH6DkZYAdDgYzjJo HTBH4e+eCf8AaHA/TPHKgEZyDjBzgenPBI4yfXGaAD/x0DB+YjDZ9Bjnn8ScYowSDwBzx6j2A4zt HHIwB0NBONqknBGOcKeCcdzjt07dh0oGeMgY53ce5we+OOR6+vYAB0JbOO2CMEDORtHfrj07dM0H GVJ7YOM456jgYyc8kY4+lKCegOMA/KBk8ZAAz6Yzj3x70hzxnkkDGOvOSQR7ZwvTP5UAJ3yeoyNw HXPYqTx35PB6AmnDAIIyAQeT/h1x/nPFIGIyCBkkHGDnJ698E4HYjGRjigjccHI7n1xzwTkjGDyR n05IoABjP3cHGMDr65HPbdyT9AOKOnr0PAGeDjAPbJOTt5BxyR0Ic44UYPKgDIGBgcqSvb1x6gdK DgAZBHTOABkn72OTkg5OMDjOMjmgAznOSc4GCOMAEHkEA5yOcZ44HNIAA2cAY74JGDwSQfXp057m kA4yACOMjHGTnJz3BGP09c07r0BJA5PJJ9Py5xnt+VACDrjBOckbcZ+jDJwfQAYxzk45Xt1BJ5HQ svseO/IPqSe2aUA/L94EHsB0BGc5wcHJ5/n3aDux3IIBGR938Dx0OSeQOxoAXBznH4KN2DnJ7nBG Og45xSjjCgg4H1wOcMewI7Y69CelHOOQM54ODwp4yMdcA4Byc+2aMtgYPXJ4GAAOQpzzk9O3GfTk AaMDOO5BJPzZAPC4BO3rn278dAY6c8knaADgnJ4bvnj1B4xzRzzgcEYJ6qD1PuQO2M9OacGJ7c8Z Kgj3ORkHgduT6UAGcDGCcEkr14Hp0Htg8E0mBgbRyO4+6Mdi3qO5A9hmkA792+UZxhfdQSCenJHP 15p3JblcjnJ2nqMbfvEcfTHuRzgATJHAJHXBIOPYHrjOMggfN146AIBHAzx908jgk549yeTjjGBS HGcEHnBwcYGeox0zwCBn7uDmgZU8jsOe545H0PQ+46ccgB0GBgZIIyOPckk5xxgnJP05oHPQFSSR kkADH556ccnsfYGCMFQfbAJwDx6en6UpJXJG7AYYztwPvAkHPOf04/AAOp/hxjk9B/vZ468LxnOO mKMdM8Y5+YYBPPBP0bjuQPakHfbyOMHqcEcjrz78fLnvTs4OBhckc4J5PU89MY2g8de1ACH3OAev UjPTOezHOQvHGM0mQOuAFPGX3DH971AyM9Rz+VKMAMcgNxnHyqTxkjOPTnt+OaQ9zksp6cH7p7YA AI3ccdOTQA0vynDAKQ2Dx1BBBPTg88A8c98j4G/bv/aN/wCFReB7PwT4d1iOw8c+PDLAs0E3k3Wk eHYXEeo6jG0Z82KebJtICpDozSyDIUA/eks0FvFcXVzMkNvbQS3F1M/ypDBAjTSTM3K7I40ctnBU Ak5Ffxt/tL/tTzfHb9pLx34vF276Db69deH/AAzbs26C28O6NNJY2zQbgBGs7wSXUi8mR5iSelfG 8cZzLKMmqQoTlHF4/mwtBw+OnGSXt60WmnGVKk2oSTXLUnB80Wkz3uHcvWPx8eeMZUcMo16kXa0m pLkg7tJJyd2m0rRs0z7D8I+Kra6nktfD8kF14hF1NLJZajMJZtXjMaSyOt1N88k78sqlvMkYrsaQ ZFfXHw2+NWueDdSjv9BuJ7DUo4I01bw9fs1vpF4w25jvA2VCt/q472BllhYfMrchvyE8H6rcahrM V7byq9w6IkLRSspikjXEWCOpEA3blIIJG08VnftL/H7xJ4D8L+Gfhn4cvLrxB8YviRfwaB4Rso5C 1/o1lezLA+p3RiAldTJIYrHzzIHO+c7liYH+aMFXzHLMXDGYHEVaWJp1ZzVeNScJzjKpFwjUtBxn SlCX7xScr6K65df2KVCGZUlhatKOKhiHCiqcqcJU1JQ5pTuk1Fw5b88VGUI31vqftb+1v+z1+yj+ 0T+zbq37QF1ba38P9cn0Wae18Q+APEFx4ZvB4ihuZbJ7LVLKFn0vVn/tGKWF2NqZblCkhlw1fzC+ OPh9qfgzS4n8K+Pdd1iO1/dSDXrKy1CaYAny3uLkIJFJBbLKF3MCCFUYr+gTUfhYnhz9kbwF8LNd 8d6rr+oaDo0d1qWnRTL9gfWblWvb6b7KgMlxtvJnCu7vtUAoVIAr8aPGmg3Vhq1zpuyRbd3eNhNG 65Qn5mXdyHA6BtxB6HJr3eLuLcDxTiMNLAU/YVMLg408VJwWHlisXyp16jlSk5ToRnzU6Tk01FSn zXkhcL5ZiMjWJhWnDE0MRjJKlCcY11Twql7OnTTr01NScVz2soappyd7fJnw1/aJ+Kfws8aaVqlv LqFnNZalE1t4i8NXMun6hCxlRXeW3tHQvFhRgocOR5RQgHP9pX7Cf7Vl18evA2haf4vvor/xU2lR 3VjraQi0Ou20SL50d5bKFjj1W0BLTPFGkdzGd5VZFdj/ACr/AAu/ZH8UfGfxzBp/g64sLKwhtpNW 13UNRmSL+zba0dPtLW9u5V7m7zhoLSM7nByvev19+BeuXP7J/jvwte6/Y6hr2jeHt9lcXEarA89t dQNDPe2sCEJGwjIcRTPJkqVEmemXhxxtmWBzfD4HE11RyepUdCr7f2kkvfUJtJylNuk7SWISfNaU G3Ftrt8QOHsmxmXuvg6Ef7Yp0o1fZYWcJXhKnCVFuMb8k6iTjKjdJpqcYqa1/ovKjpg8dUOAGAI+ ZSMcrg8Z6UoIOMDcy5wAQhwQOTjPUAnORn0FcP4B+IHhX4meG7HxT4O1WDVNGv4FlEkZPnW8jKC9 rcwnL21zC2VeNgMEFlJB57bJAIDduAAM5Bzkn3yc8d/Wv6vhOFWEKlOcalOcVKFSElKE4tJqUZRb Uk00002mmfzrKMoSlCcXGcW4yjJNSi1umnqmuzFLhSe+TnPBOM5BOOqgnAHqeMigMBzzlju+bC8d Cp64HfkZbIHXGVGASSTwfukFuB1xnA+9np26UDHQnjBA4Iycggjj5dowPaqJFzySvXBPII74OB2w eCDnHcdguSB0IGCWOA2W4yOcfh2OR3zQeGxnjrknt1YZzxgHJz9e9B6E/wB4gjp06j9P5igA44PQ 9dwBx1xjGMf/AF8GkBIzx0OfqOcse+PQnBPOenAoHr3yecFewx7E9ffFGRx1PIycduTjrjOcnnP4 UAHXDADOMgqMEj0G7HY8nGQOlLwMc4OQCAAcEk4wTn6cZOfegEMMAkDJGCMZ5yOgyByOR+FNB78A c5xhflOOq5Jz97nn1yeKAHADB6nknABzjkAYPQjPc/UUf8CJ7Z6nB7EccDucenpSZ55G4DqQehPZ vXPBznI/ShcFgSAOpGBjHIOGPQ/Xrn05oAOO3IIznfgEjnbtIJ6DqPr9Gk7htGcEBcgcY9eTjavQ nk8HjnFL1Oc54wQD0YfdII4JxnPP59KXnHBBAPAx2HJz1wCePp9KADIPGOO2OTxxwD0BP8X8R7dq BkgDqvJPXse/HY9QOnXk07aDnB5GRnJ65yM9Mnjr29+yA8bRgZyMcA7gcsfXgfe9+MUAGSSA3BJP BAwBnGAwzz6HjOCcikPTgHJ/hwSeDjgnr06Hjr3obBOORgAHI5HBOfwHU+tLwBkHqRjHIIHQkfXq fXtQAbug4O7kZBOSAM4x1A9f15pAPbC9SOijnB75LEY69B05NGQOcHGV2jHQdfcj8MUreoIY5wCR kDnI9Bjg/Nzj25oADjBGeflx8uBz3JHtnk9/U0HHBBI9COnGBtPGT09OnX3TPuMZJGSCNueemcgc ccn2zSZ4+6ASep5UDjkD0OPqKAFOOhOB26457K3OTxz6cnFGcYOMHJAG7eRj+EY7sDgZJIz0oBUD ghctgjOBjnOAecc8D8hSYwOpyOhOTnn5ODgA4/TuaAAZzk54G1cjqSeNvclehzgAnjpilzkg9MkD /Zzzj5h1yeN3HPH0XuSTxwc44OCMgYHIOefcA+tDADBxlc885HUkHk+/Hv65oAMt1x8xOMjnCg9g cdDwRnIznnmgYYEnnnHTBGcjPHX25P4ZpQedx525BxzzyTwPQYB98UwDnrzjAHYkjJ/EDp70AKSc 8cgjGcY9cKB6+w4xz1FBO7qF64JweD05PTjPrSnA4BJ/u98EDrwegGfT8cUKRyASDgc7e/p056/X 16UAGO5yD1GQCTjOcjOBnt29KOCevVQM4wcnPIGMEYwOOPfNNPUgY4xg8Akk5ByTyNpOQOh6DpRn 0G7PbIz7kemD2OAfegB30z9DxtIzggdST2Gfr7Jx16nPPzbCM8kkHjPYjt+tISCegAGO2W65yCPT PQ8deopWwTgN0IwM9VwA2cZI4+nqKAEJwcAcg9huIx6njJYdBwOO9A+UY69c5HOWJIGOjMOm0dDz zS+oBxkdCMk9lGSSScd/pzxTlAOAevGOSD8pPoB1xkj1z9aAGjPO3rwOcg89D6c9uvoDQSRxghRg DgEHnnPpg9RjjBIzSg7Sc8YwSeOV5x1PQnAHvkUHgAHOScn06ev4j8c0AHA56HA55wcj9OnUc9cU gYgZPGBgg9gcdcE4J9Op64JNKAAOvTOexDHnH0x0H1pCRnPPfJxnJA474OBwePoTQAmfQ8Efp9Og 59OO/XNBBGOQOw+h9cHOP0B5pSD9W5JUfick9BnIx6np0Iox8wxgNtOAy/MfXkdR7YxnFAHlXxvO qf8ACmviwNDMo1dvh14xFh5JLTrctoV8IxCFwDKMnyyCdr7eCeK/g8vvh34g8OTT6hbvcXLrM73U bRs88bSMWDyqASd7FmmO4kHlmUAg/wCghPDHcxTWs8SzQzRSQzwyKSkkUyMkiNjHySRO6up659Dz +Lf7Rn/BO0wPr/iLwHpNvrOhyPc366Rbxqmq6ckpeSaKFSc3NvAzuVRAx27eDha/OfEHI8zzTD4L E5cnUeBWK9vQg7TnTqqE1KEd5uMqVnBJ83NdxklY+v4TzTC4CriaOJ914r2Sp1W0lGUJN8spN8sF dqSk19mzl0f87/g34vWfgCx1LWPEhjt7TQLWW/lkeV1d/s8JLDYobJkyI0RFDOSgyMYr0/8A4Jdr o37QHx0+KP7U3xega/h067uPCHwyjuW8600LU3QRi8tre5Yqq6JpbJZQYEYW9u55y5kAxB+1n+zm tt8JfH83hzTma803TYrq7smWW1uY47C8ie9t5CU82KQRLIXAU7ScHjBHffsIw22ofCWTSvht4XvL DT9DkvtcuLSGzMd3JbiOOTVtTvY1DPtjuYpneaUA3C+W65D1+CZtgas8kxdZU/Y1o4qlhqkZpwqU 4uKmpQgnT5ueXOnOygnTnB8vNr+sZRisPSzH2POrVsHOrQaVSSUvaQVX95rClO0vccpRlN1JKKdm j9ePFGnav4dlMUzRa3oupLi01a1CS25t5mCkuq5aCaEtmSLaAxwykx9Piz4w/C3SNX1ER6Pe2bTT p5jPKmRbuWJj894w7K8svKKCCsexmBGcyTftUxeDvDl20ksfiiwmikitLCaGQpLJHG5MyGNgyLAf 9cUZWjMZT+I1458MfjA3jW51XUYrywS91S8Sa706Zkhha3i+VRH5hLxzJGoCbXG4kK2cbj8JDBZp RX1uOGjVjh1GfK5ToyrUptWvCXNrL3mnKaSaWyTZ71XF4JThTVVyqVpShOdOEJ+wqpJwm9101imt U9FZ28w8I+Pfij+zd8WLSddIuNF0/Uybew1uVi9lqcxlWK5t2MqGN4TGRgqdyp8zBeDX6gX3xI8H fFPSrdZ9ITTdZuoUNxaidJRcrlYpLqwkf5GS6Z2MFmHViw2xjzTtPgUkVr410/UNB1bw6uv6fa27 yz216kc2oWdu4bfdWDsAE8vO5Lq0KOucs/ymvF9QtPFHwj/0+0N54w+GwlMtvqMTi58R+CGkV0hW 7WBFub2ysWMmL5UcIAovIzgTp81juI8wwWIozxWBWJyim37atgueGaZdGVTmU6tFSnHEYelebqzp RvKDT5oyionq0uH8FmkJPC4uWFzxqmqeHrVrYHNYwUYKnh63PzUMVJWaoVHyymuWFuZI+pvBHxj8 bfs3eORL4K8RR6lYXAF9f+FA811Y3GmSTBAb23AkFi+EZYJmEcwdGKBwJK/b/wCAP7S/gH4/aPFN ot5Hpnim2tYptW8JXc0QvrYvw09qpYNdWbOGKSAbwMbkUivwC+Hfj3w1dWRuiNOv4dUtbayGp2ts kjaxa6fCRDHq+N7wXkbPmGcPsGSuxwWYdff+GfEnhXU7Xx18M7jVtH1axcXyYL2l1aKEVvRWmtJF ZsHLwMvLEAgH954J8TKuW08P/tMc0yPEKM48tTmlTTTUp4ecrSTb+Kk1aTjJckJn5dxBwj9enUhV ovLc3wzcK0KsZRlLldv30FFOSk/gnFOVrNNq6f8ASyO4PAXhgCeOSCwOTgDBGV5znIJpVOB2IJ9S FJwDy3YjIHPJI6nNfmz+zD+3PZeMRZeB/jCbXRPFQC2lh4jVPs+m6vcRqg8rUFY7LC+fGPMQG2mk wAUZjj9IYpVkiWeN1kglRHjeM7kdHGY2Rl+UqVIYMCQe2cZr+lsrzbL85wlPG5fiIV6M9GlpUpzs m6dWm/ehNJ6pqz3i5Rak/wAix2AxWXV5YfF0pUqkdVe7jOPSdOVrSi+61TumkyUMeMrheRk4IOeP vEfKG9epI6YxSn+71GMHAPODgbe2Ap5PHTr2pCxUZJKscYyDk8cZC8gYGCT39qXkEMRkYHzEnGeA crjkc4znA/KvSOMcDz2IHGDgYHqpJyT35PHOCKU4fI7EgjsQeueCOODnn86aoJBAUgnqA3CnkEDp joMnqTxmjkdRjsT36EHA5zxxxnGB+IAHaM8bl6k+g5IHbdgjp179qDnGBjpxj1zwvbaCPz5yaccA ZB4428nk85yMcYx1FNCgY2kjdkkjGVxkZPr7E9gSc0AOyCfbHGRngHpgc5JPTrgH1pp65HGOo7A9 R7evXkdBkZwhJ4yO4PO7nOQCMED2HoD0pxwSRux0C8HkYPHr3HPX0oATBIycYPrgDg+3P5c+lHHT cOmefl9TnHsMAluv1pcDAzgENghgDz25HQccEdz170rdTnPJBGBxwOffocZ4GaAAj1O4jORyDnvt 69DSY9c5Uk4xzg8cY+9u6Fj39MUYOdoOOc9AQeDnr2/Dp0pQd2DuGBuz2z/CACQAB/OgBo/vdMA4 6k+mcHhmAwTnPJzinA4Ugjr0PGT6Ejtz0wMDtRnA24AOdxGSdoyADux1zyPT6UEEgEdMjvnOevTB zngn9PQACAxJJwxUZxkjjnOMkdDjkd+CaaMZHAU9jz932znb1xgj34p2BwDnJ6AjHUYIPXhuM46e 1NYDgMeuAQTn5j6jGCMZHPTr6UAKMg5PpjAxgNnjrwQRnLc8YzzQCMZwPfjoBnnPTk8gHqMDpRzz jOM7QB0I45HfjBGAenc0Kck4xnGQRu64xg5OM8EY7YoATnJGc5Pfv6deR1/p0pcYPJweO24kDnHc dOhbpxijAzkEnH3gO3QHnpwQSR19OKdgZbGM47DBwenTqMcA+v6gDR67x05OSSf8nAyOKCODj5vc fN3HVT1I646g884owOeuRjOR6DBxgY9OT+dGT94twWA6DOSADjAJz+XH40AIcDpzuOc87cHgk44y QCcdioPoKXkYA5Oc4xkE+jE/dxjoMcZ7UuM+jZJPXbtHAz0yenOev8zIY5A4I4PTOM4yCORn7v6j GMgC7hkYHYg9+OpAIP1x6e1N2hQuMnsAc9Rk53ZOMDjOcUbTkg/X1I47kEfXpnjvnlwAPT1O49OC OSPZiASKAG8Y+UADOMdx2Jx3x9eBkgZoBwADnOeckd+FY9SeCCe3qOabgZY9WAAA+vTBIBGRgEYI /OlORkHJ4wC2R94E7TtPvjn25oAU+g4444I3AYz7+vPRu/FAyeR2HsOPf14/+vS8FRyAOcnpgngH k+44/OkAHOe4JBI4I69G5zj17HjigBOBxuA7EdB3yM9TnjheBg44pccYLj2Hbr3PTOc/jgUvG0Hq uDnb0wfbvn0xx26U08dDjII6E8456+/oeP0oAXGcgjAYYAI4JyTjdjIx1A9cnmk+8cdBkddwJ9ye oU8Ht9456mnc8ruG7jt0z3IAwW4HfAz1pcgEnA+b5Rzu3E+3QDrmgBAeSx5HrwCCOw6ZH45Ix1FH DYzwAxIxn8QQD33ADGf0zRjI47AjrwMDjqAdvXA49zxwgAxk9+OnXpgjJ7EA9u4GaAADr1AyDg5K gcjg9TyMHB4znjikIwCo4zg5AIPPTnuM8nOOhzTsnOcnB6nHAPHBBPGM9efrSHGDkggnk5JIzx3I IHp+HtQBEMqVxnk5yWGQTwC2RwoKnbjIJ9ewQQDuOVwwY8kHPGD3YEE8dOxBHFPKsecLjocjqAAQ MdVJPv6c80jEbeckH5vkBIK5wCVJz1PPOB2OTQB8dftFfsi+C/jNpGrXGmWdpo/ii6sLuOVhFELD WDcwPC0WoRBFBeXcQ8o4/vcgY/mv+JmgftAfsVX3if4eeFWl8Gad4ljbTtQ1A6ZDLdX2jSOW+yWm qyxNH9hlBXa0YZgiBN25c1/Yrxkk9SpBbkFR0UDLZVTyRxy3XvXlfxS+C/w2+NOhTeHfiR4W03xH p7rJ5Ms8QS+spGXaJ7O+ixPBPHwyspC5UEqTk18VxVwbhs/w9R4WpDA42fxz5W8Pibq1sTTiry1d +eHva2kpK7X0mR8Q1crr0/rFN4vCxatCVnUpba0m2k0mr8knbRWaer/kg+HPgyPxX4aNpZEzXUUP m3Gn3I815provJeXAmc7gkrMzbVzGqNnHOK8P174H+L/AAbcXmueFdQnS6tbiQXOlP8AukldXY7I guVLImwwoQGKtk4BOP6XrT/gl18M/DusDUvBfj/xR4eto5vPgsry2t9UMYA+WGO6ZoX8pQDwyO2G IOTzXjf7TX7EGv8AhfSk8aeC71/EUFgpfX7aKxSCcvhF/tMWyPJuwozIAcY3Mw5G38qzHw/z7C4L E4uGFozr0E/awo1adWnXoJNc9OnN+1Uqak5OEYU3KEeWLg0fa0OKMqr4iOHjWlTo1LunOpTnTlTm 25ezqSSnG05t2lFvllJe81dn4vfCn9ou6ufL8MeJfLtrqBDDHcsfs+pWhkQRTEzIyPJBjcRHKrRs wGMHivsqa0is7O0v9J12y1rSriwjkn1LTY5TayvcKHn0/VbOcK8NzbrI8bOqPG38L4YEfGXxA+D9 jrF29xBHJpXiQvILXVLeBIopWgDhBcRwsAwkPyDKgErk9OPNPAvxe+Ivwi8QJovia2kEQvGj8+ZW ntb+2RhHujiceS0bp8shVtisNpXORX5BmGS0sVN1MJT9hiabm6tCMeWU5pKVqUpVIwtpaS5lJqLj FxaUj7LCZjVw6SnJzoVJqMZJe1V+X3aqcV8KjpzK8m7t30Pr/VPh5rmgw6h4y+DkNqcPHPqfg65d f7PvuA1z9mVN72M1ypMltJCGtxcLHvERLNX2l+xj8QdK+OOrah4A8c3EWlx6LpmoXJt/E8ctl4y0 e/t4226fHO5SG90oMss+2581biNEEJwQw5z4T+FLD4p6BB4w+GmuRaTri20p1bQbphJptyQGLpZB CXt5dpJEByhJCqWAIr8xv2pf+Civw3/Z/wDFGr+APCVnJffErw7rNzN4gm03Sk1DZqGm2jPJpNi1 mDfXxEwH9pxNKum2sRcuyyqoHx2DyPH4XFSlkuHpUsbPE054/LcQ5xwOLpe0g61ZRo+0WDxcaat7 ajFYeUre3Scrr6rEY2Od4eWCxsqtSrTounlub0FCWYYWXJejCq6iUcdhHJuMY1pRr09fZ1HZQPo/ 9uj47/Cr9kzM/jJYbfxV4iie+8N+HIL9Ld7iwaR0g1i7lGXsNNzGrTSKGO5vKi3Ha1an7Bv/AAVP /aI1XSI9Y1CzsfE3wlFysNjY+IrC/wBOd7AswL+EtfuJDfXsMAXEdxeQPaTANtUBQa/n+8LfAL4s f8FIfiVqf7UX7ZuteL9B8F+MZJYfCdjoEptIHs9KkS0todOhuEuEsvC+lx27WsMUUR867SVyWLO7 frP8XPjR8PfgD4M8GQXek+V4Vsre18GeGdZ0rT7dNLtrzSrO3itdO8T3STxQaTI2mGK+e++zfZ8r J5mZXG79VwmcZjw3DBUslzLETzupKMa1DCSjVwFCKs5Yao+WdDF1Y+7OcNYwfNyqXNyv5vGZRgce quHzLC06zglKc6rVOrGTinOUIrknS1dotuEpauUU3Y/by5/4KX/FDVNR8vw98NvCdvZrulWG7u9S vb14iCY1eaGSKAM4wSiRbwwGOK+jfhJ+3tp/iLVdP0D4reEJPh/e6mEFlqqNcPpNyznCb/tCqyBt pYmN3K8hgME1/PT+z58T/iH490ePxT4F8deEdH8O3tzIkOq+DdKTxbrkqxTMpB1nUYXs7F0O4kQQ HbwVZ1HP0Xrmkazrthbt4h8beNNfeOY3UP2rVQRHMspJeO38tYos+WXxHEi8lVAOc+zlfiRx1hsx nPMMZhMThlU5Z4fEUoRfL7vM2sNQi6dru0Ycri3e9kkeHjuDOHJ4R08PhatGsk1GrSnVdSE9PdqK rWalZ780ZXV+Wz1P6l7W6tr62hvbOaO5triJJbe4gkV4p4mAaN4pFO10cYYFTgZOckVMpOQTg9Ty p3ZOR6njOM9+M5wRj8kv2M/2gLrw5/ZvgDxP4ll1jQb0mDT31ydF1TRbnISJVnyqXGnMAVYKoMLt u3lDgfrVE8UiLLG6SLIisskZDo6sAQQ4Y7gV6HPGePSv6VyPOMPnmX0sdQXI5JKtRcoylRqWTcW4 tqUXe8JaOUdZRi7xX41meXVssxU8NWu7O9OpyuKqQ7pSs1JbTjbR7NrUfkfeOSSCTx93txnkAkEd 8DnjNAOPvgjGM4HU+g654I5Bwf5I2cjaW+9jgDkHjnPbB7Dt3NBIY4w+fmUY6EDBPTj0A6dyMYzX rnnjuFBPPy55Gc8/+PDgdOc4OMULtJBHJIxwSAWI6EHhc4xwMjPBqLBD8kKSR3OMgjGGYnqCVwOQ e/epTywIyABkjA6jPzEA8kEjjOOuc0AA+UgnGTkAgdQOvPUcd+5o3feIzkfKMH15AGQwJ7EnkdMD ilJDHuccD2JAJOOhI6enNN52noCDkd+SQe4w2Cc4yMdO1ADjkkEdSBgY3DHXB569jjH1pSeQCPlZ sbTj8T7c8jHp75pAQBz34wOD1JOBznPX8cUgPQck8YHPHJ7cZb0H50AKGzkFccYGCOMj6DBOc59x jilYAYGSoPJGcjj1HJOT3z2ppHJ2t1PHUY9iePlJ/hIOB0I6UpAB5wVzgk54OOmBjOfy6UAIBwcE AMTkrngZ4JY88nPGeB+VLkEEAdDknIBOMc568nt+HIpxC8DBxkYIzjnGcc+g6c0nQjO7GQQOOOMA EYzzjjJ/XNADQRkg5BGDwCoyO2Rxz+lLnBweSM8HGOecZ7HBznqenbk65IGSM5JyB6EY6+oAyCT3 9FHHX/ZxwDgZ4JHJ6cZznPXHFADQBgZ7E/ez1IBGO+CO+TgjFKTt3AEfLzx6/ePpn05J69OMU4HG evOSGP3e/wBCCeen4Ug444OeQ3U7uo68k8dOM/nQAgJyAM8rgZPQn5skn5snpjsaUDHQZGMKcc5H fOenPU+nWkA5J4AHzHIyAfYnG3b1x07ZIyaDjAz2x0zt5PfgHnPbPPpxQAFjknaCVONxx6Ent0BG fx9AcqMNjgjGc89Ce/8AtHjuMCkGGBGccDknnd2+mP1Gc0gHXngDHQgZ7ELzgHvj8AKABsHPIOTg BicexyPfnBpenJyQBgLjCsOxx0/T2JpQBn5gMjtySeB0OcAn0FLgEtgEE/oTnJOcgDGP6DNADTjr jAP0PA46eue/4UAjGVJ6AnORgL3wTj3x2xS5GDnOeMnrnpjpwMnpxjHrxSc8YGOpAPJ54PoMY6Zz zz9QBDgjvwckj7wxyRjq3HOSCDnpSkDknbnljnk8dOehz9O/GaXOQAD1C44+99CPwxn8cc0E7gB0 x1DEg8euDjB96AE3ZIzk9Wxk4yvP5c4xgAkdT0oGSBk9CfcsTkjgcYPQZH4UHkHgejAcdMEHIzgn OB1DZ6gUoGME4yecYIPyjvjOSuevfP0oAMlVzjBUHdgYB9MZzk+p/Xmk3YIGwBTgkAjuAemOQCem ep7DFGQD36ZOScnr34+U454/rQRwDnBxyBz9MHIIIH8WQcYyDnFADiAAWGQSTj5uTn8/y9qZgZ4I JAxnB3En27YGTkY7Uu0gD+I4yQSRx65659e+e1OAQA8Zz1K5GPc85HTr7UAJggZ57E9BtI77R3wf X69KbycAEnadpJOWJB5HO3JPHJwB0xyTSkBeAMANk56ZJGM8kn8unakJ6HGSPXkZIOeeCOg6DqPx oABhccY2/Lg8nPY5y3JPGTkLx1wKCMnAyCRgYOCu1gcBiD97p7dqTjLcjA54yx9Dzjnrx6j6GnHJ /wB44xyATkHGOoBGM8YJ4BPqANIwST1J54JJB4JAPB5546c4AFNC7ckAEtyABhmxxyTgE+gUcD1p 5PIX0I+Y8sMfeycfXac88jHqcA9ec4XkgYwSD2Gfcnk9RkCgCMoq5Yny9w5IALDAyMjHAxnjJJ6A VDJHE6PDKkckU0TJJHInmJIhDCTercPGySEOrZyGwQMVMQTnOcZy3TB5ySenfGDgH60oCNktg843 YXhTzgdeCcc4xnvQB+V/7V37Ep1mDU/HfwjsY1vI0kvtV8L2wAuHADvNd6GFGDPnLTWRZVKAmDDH B/GDxd4CGtJNpXjLRImjtpJI/wC0DC0V3ZXUbtEBcRkGWFy3MgcgeYS2ODn+u7AGeCpznCsy4JAL MpP3VIGMnOSffj49/aB/ZE8G/GO3vNa0SO38K+NXhYi+t444tO1uQENGNat41zvwDi6jxIM8iQZI /L+L/D6lmjlmOS8uEzFc9SdFNQoYipa6nC6caVZu/NJpqd9HTd5P7LI+KJ4RQwuYc1bDxaVOvq61 Fbcs5cylUpJbRbumktUlb+RD9pv4vfGH9gv4X6j4k8A+JryBfHtrdab4cv4lWSXSzNHOk9xhj8mo WlqJZrWVVyknlTD7vP4KfsY+I7z45fHaTwxr15Jdaz481G61Txv4o1SVru/svBljJ9pv9PFy4aZL jUZpGW8eFkuLu6uvMcsI8D+iH/gtl8C/HnhL4AaIPFPh3VY4/BXi4211epbSPpz2Wo6bfWkNzaSo 4geGS6ESxTOxYeZ8ydFr8E/+CdPg0+BrTx38RdR0+Sx1bWL5NE0u6vd4caNaIt1dKiBMkXd2ybnD KxKBcfKK/LoZP9Sy3OKOPwsqOZWjSj7VQhVraQUKaUoxcoKtzVmlGzUffnKz5f1PLMzhhacczwtW niLQtQerhQqVJNc6XK0pwirQT1ja8Y83NN/0W/GD4t/Dz4XfDP8A0DwnHFoXhzQhZWuj6bMsOn6W tpbPFYCIKwSCOXCO0SKkkzeYzs0rlj8WfBD4IX/7Svw/1XU/jHqfiS00X4qX8OjJLpUP27UPD3g2 6vRLe6roGlXB+yNrDRwR2tvJJHtMULB2ZXAr52+I3jnUviQnhz4PLeSqfG3jTSIbjbOywLptq732 oXJjJzJHa2EUhLS7kUMFAPU/vn+zxrPgXwfpnhuwMNi2k6TZ2NhCFCCKCG3RYkVYz94rFEEDsdxO 9jxzXzcsuocO5NKvU56mLxM5VqlSUeadGjRUX+6U3JRc5tuTi0vclvGR4WEzfH53m826sKdHD13S p8s0va1LxnKdVyjGUnDSKU7xcpO8W0nHwz9nX9nrxv8As6zan4E+H3jO5+LHwSsTP/ZbXHh5dC8d +DJyxWJde8NWarHqVrexxhpb/TZZvsc8bO8IjlKD1jx98WvAvw70/wC3eMvFem6RdoyGDTPtME+o 6jGZNpt7DTo5BeXk4IIeNI4g7YRip3tWf+13+0/4F+C/jC0+LXg3xHJoi2lt9hlmgAit57m3tJLm a1uYlwLma7EXkBFV3mEiZbBLD+Uv47eNde/aD+N3xC+LN1d33g6LxgyavaWVldXSTJrGpSSzXk1o 7ODYxpYQLceXbbFCvGcAN83kZRl+Ozmq8bipVqWDnSlVhipUVGrUScEqLilThVdTVwrwk7KMozp+ /c+3q4+hUksLBUJ42ThCvGFRJSk4rmq2j7aUZQfKmoxs27Jxur/17+D/AI06L4x8M2utfDb4BfEb x+s5kE+uiG0020sp2UFFU2lxNPYuDkmKdkYZQdATX1t+zr+3Z4x+H2tQ+Cvip4d8TaXozSItjpOr J/aV7p9rtDJ9mvIC9wxVDtEc0axSOMIcgrX4P/8ABOz4/aH8Av2YrnXPB/xA8Q6X/b+o6lbeJm8V SHWbKTUIo9sF3pdxqO6a91IRjy5GijlW3kWMu4UjO/8AC/8AbRs7f4rt43m1WfxmI9QWC4l8QTrc T3pkYviWQDygAiv5cCRr5akCMKQSP27w34I4iWInnUcZjMvynnUaUalSo8TmLi4w5VhMRF0KWFm1 dVqsJc+kqCs+dfm/Gmc5XR5srq4ehisbB3qaJU8MleTk6tOSm66i1J0oyjJc37yybjL+2DwT4+8P eP8AS4tT0CaZWMME0ljfRNa6hDHcITDLJbOS4hmXJik5Vj1w4KV3APTrg4HsDwGyTjB6ZwCO49K/ MD9nz4zaL8RfDVj8RfADwDWIbdY77w9HM7CFEUNNB5SMztazMCTuVzbtiWIBlyf0V8H+L9N8Z6PF rGnFwwPkXtrIrxvaXkY/fQskyqzKpx5U6qY50IkQlWBr9tvZuMoyhOLalCWrVlF3vs01OLfZvs03 +WThFWlCSlTlfld1e3mk3Z+TOtbJbGMZOATg54wD2wOOR1III4pmC2eCD/dJwCACCeOWVjgAdcnj BHHjfxE+N3hP4Y+L/h/4U8UpdWcXxBu7nTrHXwYjpmmXyNElnBqBYh0S9uJYrdbhVMcDupl+Rsr7 GSAd/VSoG4HJ2jB3E5GFwc4AAACkdhVNNJNqye3nbsRZpJtOzvZ9Hbe3p1EyRuCk5PzYbop4HUH5 QPrzkEEHNJgA/dPUE5Iw3Vc/eYgZ9s+4NOyCGOMjg5HUgY55IByeMf3csM5prEl14+/xjqCO20Fe DwAcnaM0hD2YHBzlhg4B2qNpKnoeAMng855yOlLkkZHG0DDMNxJHpg4PB6Yz1w1MyBx0HJB/iBUE kEnPGeOeBweKNxQYYH5tx6hiB1GAODjOGBXAByCQaAHqRw2RjP3iCOpxxyAvJI5BzjFPPZiMYJ4O MHHOc46nGPemZyF54wSc55IXPB7AAkhT2IORgClz82M5PHA25UckAE46445Pb6UAKSDgkkgEg89R wCB0IIOMEYz3o4GACME5BJwQfcY6knrketHGAMZwpznGQR0Ocg9T2z+tLwOgzkHLAHJGOg7Fs8D+ vIoAOTngk424zgnk5GecD344xg+pjGflz2wBuxnpjPXHfkDnP0TJAyB35ORnuT7n/dJ64GaUBTgH I7gc9T2LdzjGefSgAK8Yy3JPzA4K5GDtx059jjtknFNPz88kMMcEZOMjoSOmDlsjPtgAqflwBwAC Bk9+ScYJOenPrRxkED0AJ4wMgn5uucknp9cdKAD6DGcDB6jGAVB5Gcc5OfTg9A9QeT0I5IIIzwSc 5xjv1/m0evHBwMZJ5JIyT3yPmxxxkj1cRnjuSMgNg8EEkHP5gEc/oAJg4xnGTyMc56rng4yBtyOx 7HFKuVyCATxwMjIOeTuyWIx1AGeuOKCwJwSeM8jPT0PGMkgcZwQaQex5OeegGeAcdsdcAkUAOJ2b hk8nr3ycYzx7gZ4PHWkwCSD1zkZOcex9sjg4z3zSgcKecKcg8E/XgjG7II68fWk+U+gPIPy4zg4G QPXnn0oAATknPQgHBznsGOccZ68+vNLg4HHQE7s8KfbHU+/OD6CkJGAMEAE4HTgYPOfU9ByCAetH OcEYxjuCBgZLYGPwHIJOT0oAXGflwRgfewBnPQZ6hh7A/WkJwecgngLnIJbHJHQnjrwB6HnC4X73 JIO45GMHnsSAP157UgOM56jJ68huMZxkHH1459aAECjqQeMqGBBC7u/Xkjjt7jnilHp07cZ4JzkH +9nHrgenFIeBgADBGM5HOT1Az+BzkEjpQOMjqCASOQCOoweCDz2wc4zmgAxkdOpG7kkce3UDnnHX PT0NpPcHHYg4x2OFALZBxyRjAOOCKX7pLA5GAoOfk4JzkDkY7nk/XuhIPOSMnoc8DvjoQc5wQM4H IoAccMvsFB3cEH/Z/pg89DyaQnOVycgdiMDnAPIGckc5zwc5FHcYJwGOBxk56HnoFAJNBwucjJYg ngEHsT178noOOOKABjlhwCPmPXILAAA44HQ8c5z2yBQeSvsSDxnJ6jGec9eCTx2FAyeemecHGQTn kDnJxjg9OtKc/qMng57DABOACeoySRg+lAAeMkY6ZOCWHy4xnpjgYHX6ZpCSMDBPuemMn2zx26HB 46ZpoJB569CQdpIHTI5xtz6d+pOcOIwQcdQM8AgEcgdT68ke/J6UAIR1A6ZGQOeevYnPr/OlyABn GQPm56ZyCduMnHPHqOexpM4wcheeSMdPQjHGM8HOSBg8dVPGM8kE5JOScEnBGMAH+XSgBhJDDPvt GFAIIJwCc9Meh69KCMg8DBOGJJAPPOBzwScgAA8DtUmAMYHfqcZAORyOgAB/EfXFGR1+Xj7x3EHp 1Cjpn0JoAh5ckdVwQMqSoBPALMRkccgj1zxTDsZgCMYwFHGGIyeFLDICt39u9SkfPgbhgMOQCrbu cEDHfG1sk57YNBUlRjsOoB4HUglgcdTyBwPpQB5L8Zvgt8Nv2gfh34o+FvxV8M2Hirwh4r0y40nU 7G8hAljjnUqtzYzkeZa3lu7JNbzRMpSVEcHINfwX/tW/s1S/sdfFzx18BtIup9Q0vwdrN7daVezb JJbvStcf+0tEluJFC7Z/7PuLeG4Cr9+HKsScD/Qo4DhWBLE7TgZyMkA5GNoPGep+UHtz/Lv/AMFh vgc8v7SaeLm0qSax+IPgGxuo7y3iWRn1TQFbT5oQ7FAsqLHAWjEhYxSeYEHFfnPiVhYvJaWPhQjO rhMZQVSoopzjhpqdOzfK5OEas6do3XxOKa5mpfXcH4i2YTwVSbVHE0KnJByagsRFwnGSSaSbjGcX bWV0t7Nfy2/A3VdW1r47avq+oW32hfBOiXttpkeRDi71udbJpA2Bm4htkliVcgiItIcDr+m8PxI1 LTIrN7S6ltYxERLA5BWO4QhSZHBwWKnYinarc4LE8/Pf7PXwbudJ+L3j6yv7UreX9pHf2KSxrm6+ yy7FiWQs4BVJAzF9r5yW6c3vjpo/iDwZo+tXVtFNHcWxneLcylVKZONu7BAJ8sRjhSM98D8kzmvh 8yq4XD04wlTxOGw1OSbcqcEk00pKNrc7fNKTlbVXTTt9ngMG8Bg8S9I1Kc8VUs0ud+9dtw+JJ3sp O11pdt2PPf2k/E+ofHP4j/s9fBaK/drPVfEdz4p8RLPJH5VvaWd2v2x3MPmErJbw/ZvLuFVsyAKF DZP2n8GP2MvDmk/EDxjrnxJ8NaH4r0HxILOHw34bv44dV0qz0q4sts5nns2tnttSlhVYpUt2jayx GivIylj+OX7OHjxvE3x413xZ4obUrMWX9m+ENPayjja/tzeh7m/azlYPHG92sSQ3FxKkghjdnAJI r96PhD45GjwLbHUJpYIpI3jilk3CKM7V2o7rh4iDjIORgDgjNe5n1L+zMDRyijGjSpxw0m+VJyUq jjP2cKtlab/dpStdtOK5UfIcNrGRx88ylWnFOrOpzSVRxm69Tmg01OH8KEFpZqyi2ouyPzl/4Kk/ snfGP4eeDdJ+IPwNTVNN+DPhnTlsrvwN4f33Nr4PtoyWbU4ZFiSeewnyhmmuBJdwzMGmkmjBcfkj +zl8eb3RbLxgdYurhv7OutB1EC4kAeO5+3DT5CxJDMVW4IPVApLkGv7t/BPjLwl4x8Nz+HPEFlY6 npGqWc1hqOmX8cFxa3VrNEyTRukiESJJGxSQZzsPytuGB/KN/wAFTP8AgmhP+znrPi34ufAXS9Q1 X4T/ABD2R32iafD9on8G3wvBqN9pziFZJW0lXQTadfMAIlla0kfcq1+g+F/iTLHez4Qz3TGUJUIZ RjavvfW4UZ05U8JXbhB/WoQVqE7WqwvCSlVjGU8eL+GpKdXiDLZ+0ozhOWYUIyjJ03VptVMRBe7e EptyqxXNySvKFuay/Tv9iT9tu48BX2naraa39mtZns1njS4coBvQvhQyq6CNiWSThm+9ncRX9JHh 39t34cfDfwz4a8SabrOp/EDUfEElvca7YWFvbrdQ6deztK0t+ylLW1k06NnNlENs7xnyZkwAw/kO /wCCEX7CniP9qvxjLc/EPxBZ+HPDHg2K21u28NatcSDUfEKRylILaCzkZJJkfbueH7iRASOzA7R/ TL8e/wBkCX4bS+b4E06O3sYlZP7JihdYGOzeFRy2XyQ7FWYKzsQjAA4/Wc3WDpYvllUUKsbOTUVZ KcIfu5e8mk2oyStde7aS0t8flqrVcO5yTqKpH3IKStHl0dWF03bmvdNx6Rldo7j9u39o/wCHvxMl +ErfDzW7fW47W31LUNbjjR4tQ0kXMlskdrcqw8y0u49plOMgFAySEEV90fsUftM6b8b/AAJB4X1r UoV+IHhCxSzvbe5uEW+13RLRhb2evRwlvMlnREFtqgRSFuIxcfcnUj+fvXdLu94tLuwbTtXjysaz W7RAkEK4MqlCztkMqyeYpwu3nNY9p4m+InwfktfiB4AkvLLxB4dvTcPd6fI8Qu7FRvuLeZk8y4iy 6FZX8qeAoSk8Utu7V5mIaoWlUnbDcqkpO8nBSslzWsrp3u7u61ttfvp041owpQa9rzPl2969lrZa Xdkt2nbTof1+ZO3GOeoyAAeAOOuAV6jtk0vbO3p0GACcgA4xgjkdDuOMnPNfmh+xB/wUe+GH7Vdh B4W1e/tPD3xS08CxvdOuTBaWer6hFGpmgtlecG21I7y6WMihLyNTcafLOhMafpa2Cygg8cqASpUr xgAkE5Jx+PT0hNSjGcWpQmrxlF3jJd4vquzOaUJQk4TjKE4/FGStJeqf4d91oABC8jJAIIAVQCpA yScjawHUE+vTo4HgDgEYz2wB1/8A15wT3pMDBfG7aT1wVDYAznI7HGCCM8YBpDk4AAHUBwANvBOQ MnJByrAnGAfqWSKGI3A/eyDt5A6dcnIyRjkdutOyecYGMLkAE7jz1OOhJAI+uOKbzkEHewAwGOQO ShwoGTgg/jng9ad1Y8McDGONvykZYjHXPX06c80AOGWByCpIBOGBXg9yAcE9fu8Z5HFLyNoI5OMA ZKgg9ScgZHB6HnsetAxjk8574GD3GFByB054/Khj0PPfkHgYODj6+nGPegBMKMdhkkngKecdcdz6 kdDzyTTl69wOoz0I75x39/w9KQA8kYz6dRj1AJ4z0zznoABigsVwSSeo6EDPoBwex7Y4HPTIAcls gDGOBycZJyR0weB0zgc9zR1YE9COmO44PJ5xjqeSPWlGex47ZxlRgHp0wTnLE9CKQ5PTIznnqcnv weMgcL0IJJPegBSOuOhOeMsMsSD06HnPQ/gKQk5AI7clu5wMdOhPfkdsgdKQE88cnkgHG49MnnjI GMcf1peAcgZB56cE9MdcjH+H1oAQg4wucDOPTI47cHHSn5A6AD1Of6HkgnABzwD1HSmDgj5gu4YO NvJPQ8AYb2BweCRkUvoMZJHXJYk9OfQ8575P0oADngc5xgg4AxkAH6AnrSgZ2kZwQDhjjjB5GBkk DpyMdehzSYAxjgdMnDdBnJ5Bz2K9/pS8Zz8vpgNkknjB7AcjpnvwaAG43dRkZUEkcse2Mk529jx6 0cc9c54BxnH0x0PUde3QdTnn6dD69yBxg/mAB9RTsEYweP72Nx54PIyScnrgZx070ALngZ5yRjJI IPfnngHuPU01SQBkdep7knrnsT7EfQUbuSvORls8fKe2cnHfoMnNLzyDyPQEc89dxwc/3sdMcYoA RQMEHB7En5eQe3XJBAyOx7c0vPueMkYOTkYIJJx/DnOQemB2prZOc8g5BXGAc4PXIAwMYOfmAycd 1HzDB5yOpOevYcjGfXke4zQAnXORg54/vdcDI45OT2LZ6+lKOuWHB65z14A9u3I9B0pOvBA99wA7 dCecfUDOf1VecAtkAnIJAGCCRkgDpjjjkjJ5NADsnjAxjnAwTjkZH1JIxzjGfam9SAckHIXBGcHd 6dhgg+mfrQMHnHAzx0GcYwT3HGQeMn2peBnOPTDYX0Ocgn1x6nr0FACEAk5+8T25JXnGOnHBo6AA FuBjBGMZIwT6YJz7jg80d+gGOfm6HJHII7c4A6epyDSZ6kZPzZwWJUEcFemAAMEDnIzj3AAjsfvE kDb6jk8nBAIHQZAycYxS9Op4wccfrg4/An044pAMZG7dgcdMdeGPOSRnGOnOTnNHIyPf7pzk9Op4 65OACQMdTQA/GOA3XknA4GD1zn1H9fQtIJZuchsHg5IxjHy47fXGSPalKjkZI3EDAPTGMdyODwR0 INJk5IPPZcDGDn8hkjJP4UAGBg4ONwOR1xj3Hfp2yB1pTkDOM5IcgY5HocnPHHPI7dM0h5II6g5w Op57n1HXjqAQcdgDORxjqCevbOeflGcY68ZoATHTBIHbGDgk5YE8DqcHB44FIBgjGACSSV7g5yO4 6ckg5x160/OCTyeuc4xjuF6Ej35AHWjJJ6hiORxjHfrkE8Y49QTjgUAMKk5xk8jjAB2sc/L1PB7E 4AOc815f8VPg78PPjNoDeHfH/h211izAm+w3hTbqWkzyoUefTr1R51ozbl3hW8uTaBIGHT1Mk8na WByQDgHtwvJOO/AJ698CkIUg5OASCCDtPXHJ9BjqMk98VnVo0q9OdKtTp1qVSLjOnVhGcJxe8ZRk nGSfVNNFQnOnONSEpQnBqUZQbjKLWzjJaprufzm/HX/glz47+F/je3+JPwein8feGLRpY7/SECx+ Ibewu3IuUazRo/7QS2QKyyQkO7hdyYGa+Av2nP2bbzxF4O1rztL1PTLuUSwqLmyns1iuivS5t5o1 eNo2KJKCSwPQ4ya/srI5wCFGPmznJI42bjt4IySfUDj18+8e/DHwV8SNEvNC8XaBYapZ3kTK0j28 SXUTt8pmhuEQSRyAkjIJJIBbIIr8+zDw5yqvOdXAVZ4OpzKrQo1Eq+Fo1YSUoqnzWrU6UpL3qfPO Cv7qikkfW4Ti/GwjCljYQxUOV06k9Y1J0pWUvaJe5OSW0koSa0ve8l/nH/s7fsu6/wCGPHHjezvr WOeW18QLqV3JIhceQ1m1vFdW7kYAjmiEeDwPMBbPGftu60XWfCrebH5kYP7pozlVYgLlsngIduWH GFYDIYAV/QT8VP8Aglv4n0HxvJ46+DF3pOu2DxTR3vhzVrkaVfzWruGexSbabWfegzFI7L5c4VmG 1iB8wfG39j7x14X0U6xrHg7VdNtpFkSSO5jguRZyHdhZbi0aaA4PImBKzcdMgV+fZ3kvEsalatjM FOpDDW5q1KHPTlDpVjUhzxnSjZpxlyzjJRU4RvdfWZXmmTOFKhQr0o+0goRpzajNSSS5Zwm9JN2a lZp2+J7n5v8AhD4m3tiIdt08DBliCiQqshG3dnJKAArjnl1IABIr6l0r4gaP400p9F8T2MGt6bcW Uun3WmX2ySynguQjSeZBKsm+c+WoSQbTGqrgDINfAPxMhHw68QLaapZ3MFldFkXUY42aK2cPhRJC Az7BkZkjZvLGSVC5rS8PeMZbIwzR3TXFu6KbeeJ9yupI2qmCcJ/Gd+QNxDDgCvko0nXlGrh3OFej OMoyTnCvSrQkpXi6ShKnKM4OcZ80ZQlyuyaVvTr0K1Bu6Uqc0k4vWlUpy5U4e9dSi18UG7O8klZJ L0vW/C+rfs8+JYPHXwkudT0a3jvm1CzuNCeRNQ8PqJVl+z6hFbgmawaRdiymMwKhEb8jn9iP2aP+ Cpfgz4t6avwz/aSt7LR/ES2i22j+NRCE0+9uEQKr6mpK+TcM+Nrx7gQ2WA+avy88PePrHUI7e21T yJjPC0UoJVGEDIFcLkOkqEtmSF8LINxwME1y3xO/Z7sPFenPqPwzv47G9m/ey6TLJnB5M39nzowl RmXLCMnkHCMNqgftPDHH+Fx8aeT8ZYidLFJKOX582pxqqLUPZZk2pP2qbcvrMo8rUUqvs5c1WX5/ muQVaDljMlpxnC7lXy5yacNU3LDapqLXM/ZJp8qWkk1CP7NfE/wjp3xI8KavrOjaVDrGmqJlsfEW mpGLS1McTTGeG7hObhwqApCrumd29VCmvzns9OkgS4s9X1C4uTBKHJSd4njcY8hy4ICyRBeAh2tn DLzzr/su/tP+N/gB4Vuvg/r1jBr3gG73Wd5Pe4vru0vpU8u6ubBWkIt2QOyCIAuxyXJckV694o0P w58S7HU/F/gyWw0yeyb7LNocsqieZSyiG9EY53zAl5olZ3hXGB1I/U6OEr4RclaMq2Gq8sqVZNSp 1IVLcrkrSSUrqyj7jXLsvefzE8TSr+/ScadWnfnptJVIzjypronKLTejvfTR7/EN58FvBuifFqx+ Mfg/UPFmgeL7Z4xqg8H3o0mw11I9rKmq6YYmtJ5Q6+eL5Fgu4ZlE8UiSLuP78fsk/twS6zaab4A+ M2pJNeRQQ22keNbl0W9uQzlYbXxEEItzPbgLAdUjObkr5lwA5Zm/HS7uLzRJJrXV9LnivLGzeVZI AxaaGNX2bkKkSs+0QowyWLYwDXyPqX7THiiLUUm0HTbTw9IsxjkBczzqIZdu17d1VLeSUACTashW RyrActXFmuZ5RkVKnHGxlRnipTdCnhqEmpyio3s/do038PM6lWCs27O4XqYpRnGU6zjGyc5OUlTj tFNuUuWDvZJO8X0ikz+5eNkmjjmilWWGVfNjmSRZEdGGQ6MmUcOMFcMQeSvWpMlTlSSeP4PmOQQC QTkAA8HHrnrz/Od+xV/wVWbw02neAfjd5txoE/kQabrtuhlutIJkEX7xHYLcWiryyKwkiKkRoQQK /oM8IeM/DHjzQLHxR4Q1ux1/RNRiE1rqGl3C3ELqcZV8MWilAIWWCVUeJxgrXPg8wwmYQdTC1edK 3NCa5KsL2+Ondtau3MnKLaaUnZmUoyja632etvxSf3pPyOpOQcbtwAIKggAkseDjGTg4HI5Hak4X BK5K8AkY9ARxwBgYJbg465NAJXoMoMdcbmz0IPBJHTcckk88DNOJz8m4qewK855wQeR9QfXnHfsJ HBRycDnjdj5gTn5jzjuO49++W4BHGVPRsnJwOh74GT+JHQ0g7A8MByeuODjtgnnvjk9sClHLDByE XjHygEHGfr3IPY9e1AC5HI4zxzj5ySOM4yPz4+hpwxkHJH1A5PB5OM5B6nHT86QuM89OO3fPzDqM c+5PtxS5J7YwMEH7p546ng45GeufUUAIQCOc7jncAMnPv07EY4peeArHPAyRgKRn9SBgjoc5HTFI Oo4A5xhuuec8j72cenHam5zgAk9RksTgMOTnAGVI479OcUALgcDvjcMZxgcEE9Tgn0PQetL3wfYD jOPwyMH8MnPIpADyM5OQO2BnjjB5LepwBjjmgZ4HXn7vOcZIOTxkgDOT9PegB4GDjdwDknAx1GBz nnjr78c9GAHkH5gG3ZBDeuc8cZ6ZPIGcU7aOF3HqW9RkZ654II7diMikDH3z1BHHAzx6DAPGBz6H mgBcYHB6EN+OemQee+SBjPBPNByABjOM5C4AJI4Y5OQevUHJOfSk6kEY9CADgAg/MfXHQgcZIP1U dP4Rggj3HbJ9evGPSgBuB65UcDptKgcAkkccHn+dKO+eOP4QNpwOpHTg8YHBPelBIHfnqWxnqQDg c4BxzjnjFAJznhiOpAxgdDjnn1B6AH3NACfwgHkA/MOmBz1wOenPPFGAGzkgDIyBxg8dcn8P/wBd Bz3BOO5xuAJPJGSSFP4Y655wE4wOASRgqSpJxnB4OA3oMj8aAD5iRzxkDnqTjhiB6g7cHIOM0gAP K9O2f9ng45IAzznI5PHIpCCSecAE9ep3exxyp7fUfVT2P+7z16/xNjOc8Hb056igBcBh1xjqce+T znknp60rZK5zgkggEhSBk455znI65Hp1pAN2c+o+bOMk9V69R2wOenFHTLA8kgHI9PTuAR2BGCSR igAxnrxnBz1HA6j+9njGOmBil6nPB6Eg56LkDqSM85zzyOelGfbg8c9AQMHHf0wf8huCBgc85Ung HOM57ADGCO554zigBQeCMLjsM7Rx2zg5J68Z9PWjPfA55PcBunOegxznGCevs09T6nk4/LP0OOvH PvT8AkBVHYnJBGDngrknkd8UAIMAjGOAenToQc+vJxjBHTBzSscjoc9QcYBOOBk9AQAP1pvuVB75 6kdevvuwcHjHTkmnfKeCQDj+EgcHPUZB4PPBznFAACSe5wBtP3gc9fwyNuc4xz05pAcZY4PQHdwC TyccdcduaGBOR1IHPGS2RgEjqBjOQOpx2oK428ADHUDJIP8AD3IP90+3WgBxBJGOO3ODgD8O4z3I 57EUwMRgAdyu0jGcdcdDgcE47UuTwOoGOOSfz/HHp6UuTjHAyVJOAeOpOAB3AXvz39ABCCWyR0BA /h6nG4Hk428YOB680cEEccHAOctjPOBjqDkZ4BHQ03PYgnd0OfmHvkkFjxzjrwDThyCFIycZxnhu OcdcYxx0yeO1ACYOQcg8EZbBwRjnPPJHYZyKcckgcElQDyCO+c4GM9+PTikwSDnIzwVxjg9sDhj3 zwR29aRcE9+nbA7ep4xigA7jdjjn5u/YEddw6YI9ccUAKAeBnJ4A5zxnaCQAOSQD05xkml7ZwACc DJz/AOPA8qeDweopCeDhRyMcg7WBHrgYwc8Ljtg8HAB4L+1HrXjLw7+zn8btf+Heoz6P440T4a+K dU8L6rbQxz3Vhq9hpk1zbXdtDIHR54fLZ41KsN20sCeK/ki8K/8ABVT9vvwnCmk+LdR8OfF/RzHH 9p0rx74bthcX0M0QBSS+so7eZWm+Ys23cjkFW6Ef2k31hZanZXum6hEl1YajZ3Nhe2kgDw3FpdwN DcwPkElZIZHjbgYyR71/Od+0B/wS28b+BvFeu+JPhxFP4z8C3V3c6hpFra2h1HWvDttcTvKumXVg wZ7yK0V/IjuYBI0sQUum4GtqUoK6nTjUUnFcrTT1dmlKLi0ntJN8rW6auVGUo/DyXunaavF2a0dt V9+veL1PyB+Lf7T/AIZ+Oem61a+LvgvffDzxEive6dqHhy4OsaL9pOHeA2zRi9tog/AUs21SFDFs ivha+8X614V0q68R+Gyuvadptxu1vQrUM99b25dQ97FbOou7Uqr5dVi2EqSSOSv7DeJ/2UPiP4cW 5fXPAGp6e5d2M50fUrJ0M43RgqIPKcj7wACiMlvMj4rybU/gTpZtGn1rw4I9S2PFcXcMAtLswFWY oZoRCzAgxhlkAWTlHUhq+Pzbw/yDMp1KuGhWy3GT9/mw/wC+w8pXb1pyhGD5ndzkqqd2+Rcqs/qM o4uzLBU/qteNDF4RuUY0qqm3bRJUqsW5wavZScXyrVQbSv8AG/ww+NHhj4gWAvfDOqxXUkES/bdO Vh/aFnOGVZYZoAd8boxZWc4DAgDjOfqnw18W10S0e+e8MEdlCZm3Plw0YwokRusjEKgCklS2TXw9 8Uf2MdR0rXrz4jfDO+m0XXFWfY+jrNpkc7yfIJda0i3kNpq0EJVJP9HMFzvBcqysQfFPEfxT8d+H PDZ8MeObTTD4iiSQ3GraXcXS2l9b2j5YXEE0EN1pl7cuqIIpkkwpcliMV+f1/D7MqeZ4DCVoLFYX FYiFF4rCtyVCH7tzliaLUXS5aSqyU01CMt5TlaL+llxDlVfCYnG0pLC1sPSnOOExM1GcnZwth56x rS51G8ZONSMXfkcU7fpp4A+Kui+LvE9zDfqtv9r1OS4miLqBEZjjEwQ7kkIbeJQMhk5xnJ+t9T0H UfC9pH4s8Lah9rt1ie4Maudl1GkYkXaUJVirKoIK7iJDtzX4V/CnxjLpNtZalPJINTvmWS4t5UkZ oVkDTOVuWIBggVliXBBJJUjgCvp1v2rdejsrnwXp90Tot1EtjdyyzNJMsg3yS2tmyEGO3VSvzjc4 BIVlVSD/AEXj8Thcqy2l+8cYwpUqFCKbnKbpU1GFCEXG8VGME5Sdo62abaT/AB2MpTxMqlRtOrOc 5ST95Oq1N3et1q9vNXXT9Wrn9sH4Y3Xwc8Q6he+HbG/+IWkWssT+WY7yO3ESeXHII0KP5ksy/LHg tgtlP4h/Oh45/bA8U+IvjTHBe+GtH0xLm+MF49tb4hNt5gLXF7HaRMlu0cY2qyqZHIYlctur9C/h Voel+KJ7zTJJ7fSNL1Z3Fy1rFDPYtq1somSWbyeDDeD5TKQfMkyrYPI8vT9nPVdA8b+L9Y0bSPCu or4ou5pnnmt2a40+dXJK2K+ROFhDx+aqI6tlthYrjH5vmGYyr5bRw2IwCxlbE1Z2deEJyoU4NOnO EIOChOq+WMpxjGbhCSUnrf1pUq86lKeDxEMPRi25VVTjUfNCyu4ynFuMrq6bSabVloj2PWNFsG03 TNV020W2TUdA03WxBbX8OoRN9viV4pLWaJvlaQbWSIjzITmNhvNfU/7MP7XXxs/Zj1a1l0XxDJd6 HMwmv/C2ozyXul3NsMFLe5t3YrDeKpY+dHiZHCht2OfnHwV4Ls/BWirZ3szX15EzzGaYNEtrKWLe XBbBjEiQM+23VgBGg/dAZBrxv4t/GvwT8KtH1fxP4w1KLSNL02R4YJ5ysl9eXvMjw2Ngn7yd8kov zHLkEtgAny8tyuthKksbNToqV3ChTnKCpSlyqpNPep7seSnSu1fV0pSkrepUjDEU4ubip07ym48r crpXS5VyxTa05E9Uot9D+1T9l/8Abn+E37Sdjbadb3sXhbx4sAN74W1WZIUuHCgvJpV1KVS8jY9I Ti5U4GzqR9uNuwuFGMc5YDIJ42546HJHB5wOa/zo/wBnX9rXwP8AFS+tNV+FnxBa18S29yrxaK4l 0XWIJ7eUSblS4kW5eZiV2GCTDjBTd92v6O/2cf8Agph8afA+laZoPxW8Gah8QdEHlpb6sZkt/EVv DHjdF5xjWK6URK0kAu1EuQR5nJNfYU6uJh7mIoybVmqtGE6icGo2nUjCKUL3u3G6V7SUWmjz3Qbh GpCUZKXM3HmXNFLa/SV11VlutGj+h1s54wBjcWK4ViCe/rnpnpjPvTj8wAIKhvvZGAOTkFhwSccY z09xXhPwU/aQ+F3x50Yap4L1d4byEIuo+HtZT+z9b0+UgDY9tOyi5j37lW4tXlhYL94Hge6YKYPV c8gjAORk4zwpPZT1PIPJrqTUoqS1jJXTs7NfMw9dH27XV9fvJGIAKkDOPmB+bBP3SccEZyNo57nt QEJ5JPyEkICrKex4zwPT0Ge5qPeoYDIDfNx0+UkFztwdxyQM9snHFSAFTjrtPcEEdCuD3CAlcchv 0pgP6Z4XggjBxjGRkDBzj04/I0nOSCMZ9RxluvXgE8Yz1zx0pBgEZ5xyeD6Ae2Cc5ABPGTjFO4BP BAAJycEH05BO0g9CfTigBRgEkYGBgcHaORj3J49OoPahu3UEc88A888npjOR09O9NHGPk5655OAO m7I5yM8n8MDo7g55AIx90jGRgg4657Acg85FABk4Y8gjIBxn5QMgnp1znJ7jHsUXj0IY4weDx/d6 Z5/L1oYZJ4BweQBkZ6knuAeMDtyTQVwcEADGOBgtjoc9iO59D3oAcQT2AyCTxkkYxt6Dvjn8j6tV icDGQQOCvIGepHBwOR9TRkk56gdMZ4Prk89s8+hpSSQM8AMenoB8oBAGM5yDjtQA0AkkkHnA5IUj uc4yCC3Tdj2o+8B0H+0p+bA6EA4wCBznFJn+HBJ+9u9OhGQTkg9D1HWndht5AOcDJ7ncp47nIGen egBORzxk4IJGT9B9e+enU44pxOT0GDg53EnI5XsMc9eenpSEcc9M8jGOV5yB2x3PGe44xQuOcjOB nrjp7kj2oATIPJxnB6gbsnkkDr64PAIHWng4AHXvjB3dSR7Y6HBPT8KaQQM4XnJAPp6HsTydueOa ARz8qgYJIPHT0J55GPb046gATtLFc9MheAc5wRj0A5z05x7UNngDOMkYxznjkHv1J6Y59sBeACQc jHIJHIByDkcDHQDjI65NIFOTwCcd14PqB2xzx9BnrQA4dwACR8uQex9RzznqMe/FNORg46lgABnb 7H1BIPt2FAyoz35HTGB6YHBYdz0HHUmgFgCe/XPr0zgEHoCTx2NAATk4wQFPGB8+Tnpu7DPByc04 E5ywAAGDkck4znA7Y659OOM0AcsMjrnGCQD0znI3cEDnoR6im4ySQvCjBzkZ7tweo7c54zQAo5OA 3ByoBGOcZYjOCR0+n80xwwABPOMjHQ8k/wAXGeByOaTngHJKjnBwD7KTxyMDj8hSnAO7pyQuFzx0 J/Huc/8A1gBxAI9ckZKkA8D5d3Tr6dulN+br1IOBtzjaOQPccYJPB6DqcndsFgNoHcEEHLemTjnA PqB1NCtjrnHOBkkDHT5ufxXPHcUAKduRjJO08YBbjtgg475A4zg4oB6A+uVA65GCAdvAz6HqaQlm JIUkHH4DnoeD2PTnOB3penGMZA7cL0wR9B154NACYbdkgDI6ZHBJ6k/TgdOeQM0hxxjOAvUjg4PO SMc9s/n2pRhuc5IGeORgDgZ9c9ev55oGSPmPAI+6oHDdM9cAcEn8cUAA+UHjIXptHQ9ecckHufbi gHGTgnjLAY28jp65HqQB1Bo52ndjB9Dzx1GB9727YPanHAXcfm9cA5JHHrwOORjH50AJ0HOMg5G0 E59Ox55GccfhTQBg4ZSRwcdznnP4k+uM44GKMMME8Y5PqR/EB3z04yOB0OKUEnPcHBGTnByMLg88 gn0PB7UANKngjbg5Bzgjr8w4yMkdO4YHsTRyMlc9R1JCsODg4wd2OmehyDjAp/ygsMkAEnhcYPrk cnHt3xSN8qqWJOD6kZ9CCSAD7HqD69ACvNbW10jRXVvFdQuPmjngjnjyeu5ZUdWYg/MxyMcYxjHm Hij4I/CXxlDPBr/w+8Mags6yI8o0y1t5hv6kTWyROrcdSTjHQgces7/lxySQRkDHOCeMenQY5JIx 1qEKT/CAQCeAPmOMHAx1IzweQScHJpqUo6xbT7ptfkFl221Xk3uz8ofjd/wTP8N6/Bfaj8Jr/wDs q8kjZf7D1OXNmwUF1jguXGRlsR/OF3AkmTj5v58f2tv2AfE+kzX1v4n8J6rpOvw2tw8MwjH2HU1h BEkFtemNoH89GzayLJgy7Q6jJI/ttOBghtg+6pJ6nBxk5/A9MHqDXLeLvBPhfxxpE2h+LND03XtN njYPBqFqtwYuo328p/eQzDccSRMhJA6gYrohiGpqVRKbV0nrzJNctrp3sk3qrNqyurJistbq93fX Xpbqf5p+r/DfXfBkFxZumoXFoieXaSTL5eqWVs5Edwl1Aw3P5Ew8tpEUBNuQzDkfOKXd/peqzWkM 8l5FunntrqASOxZGMTxypnCSoA5d2KqQQ6+g/tQ/bo/4JaeHrLTfEfxO+G2nXeq6UllM+p6LbRTX HiDQ4iJWE+kR26s9/aiWUrNAitcgOocMg3L/AB//ABs+B/jX4OeOr0Xcep6eI5JbyC3urZl+02t2 zGeG6hK+ShVWxJEyB+GBGVzXnZ5VVajh3VvOlGpKVWqnO9KM1CMdYuycWueSn7jilFqVmyalCLSn CnzKmmoxTTqXslqvdi4666NLq1sd58Kfin4l8HvBPZTTJ53nebBfFTDJCsilbeKJi2HXG4SwkFQw DMVYgfqn8Kv2k/CWt6fY2mt6LptrcTqHvp3hEewKyqkcbL8u7fukfG13zgHFfz0x3utadqEFxHqD zRwvMEgZmjjtTIzSSxQbtwEascbFwpztOBX0h8PPiJcXU6WVxIYJ2eRQ8qmOOMBP9Y/zEjBGVZxj tnGKWWQwmLpxjhoVnOnGnCCcLYiSklF2UG4pOD9yzk3eTsrs4oYjEUVO7ai3GM4TjFxsnFN8qv1e lney1T6f0baR8B1+M/2W/wDAFlC8epKBBDcXMabrgJmeZdwCiOBArsGchGKopckqPrS1/wCCJ/wK +KfgfQtQ+MAh1X4keHtQ/t211LUibnw8txPEI20i80hHhivbaW3wZHbdPHPsaAlk2n8jP2WPjV4j 8PyWFzY6pei0tIzDGltdvPBNI7BftLMMhAxy2xSARkEkHn9sNH/a61Dw98N4dTht9S1vWtQ1OKxt m1C5mSG81SSHzLfT9Pg3BC4ZEluJMEQxEmTO7B9HHZTGGGr4ZwjWoV4+zr7xqOM0lyuUVCSXROnP mi0pRs3zHoYfGtVqdRy9lUU1UptQ+3HlS0qScG9FzXg0o6cqSPxO/as/4I0fCm41m70LSfD8/wCz 38W7U3t/4N8beE7u6j0zXILVpRZ77S3dLS/tH2RSJtRbuAr5cqiRcH8PNa/a6/4KBfsa63qPwx+I GtNq1t4cmk0/QfFGp2MGowapYRS7ImW7vLd52MqIGJaYyooKnAIUf1k/ET4W/tVftB3Mvjv4gw6s I54Jo4SJbm1sdK0uV1ZYLGOIxyQRlVBkniKtMQJC4bFfm1+1P4C0XUPD8/wi+M+l+HPi34I023kW y1fTp4tF+Nfgy8EASabQdZvkXS/F62Dusv8AY2tTW13dJE0VvqEjuMfm0sh4t4Qq1K3DuMxGdZPV vPEZPVxE8TmuXNe/OrgHVc3iqdrSeHThV1lCEKz1X32FzHIc+jChmtPD5dmEUoRx6hCng8XdKMaV eXJam+a9qtRKmrSlKpTj7q+Jf2Xv+CtHxO8c+I9N8P8AibSZhqU+TcT+EnuLHXZURXlkuNMsLOYr eCOLMr2kaLNJjEQyAD/RT8A/22v2gZdC0rxD8MfGs3xE8MPgHSNcjm1e4eOD5Lu1eF1a9sry2cMk 8ErLMjoWdAcAfwseNfhXqnwJ+I9p40+GXiefxR4R0vxAk2geK9OgudI13SLqGdHt7HxPo0vl3/h7 VIwFUeYJNPmeNvsV1PGa/qc/4J3/ALbfh/wQ+lfG64g0mbwz46Ft4L/aF8IW9vbxP4W+Iwgjg8I/ FPSbfaqWtl4vcHTPEEUaRwyamYrl2MsjivVyTjOOJxeHwGY041XjJKnhK8qbw9RV4tKWExdKcYuF XmtCL5YVIzcqdRdCM34VWHwbxuE/d08O0sTSdT2sLSUXGvSlFPng4xld3kre9z20X9M/7P8A+3Zo /wASdRh8N/EPR4fBuuvcJYm6jmkS0i1F/kW0vba5RZ7ITuFWCV9yMzYfaeR+gytyGG1ldQwKncCp GeCc5DAggj0zjBFfzHftAftDfC7xV458LeOdCsF01JTFpPihbGJLYahamVYoNQleEoiXtnuLxzkF vlK8ECv3Y/Zc+I8XjXwJZaNJqn9r3vhvTNMEGovKJbjUtDuoP+JZdTTFQXuYRE1tNKxZ5GRWPUlv tK0EoxqKnKjzOzpyd0nZPSV27tO/K+nofDS5W3ySjKKsnKD5le3daa3X+bPp5TkZAYHIxwd+FxgH PI4xkDrzjAOKeOd24YHbcMsOe+Bge2fm9aYqKQFLAgHODuUKoOSo5G4g/wAR7Z96XJLEjoc7eMcc AHHTA5JbGcDt1rnJHgBj1zwSMjLBQcDrhuST19fyB0yMZBUk8cDpnA5J470AHdg9uCM4yMDJwTnG Tu49KXgEZ6t/dHGOw+h9fp3NACkA4GB3YlSApb/a5BPHJ9s00buCckkHdtBwe3A6YweM8k89hgxn dgnGRgDI4wRg4I49T39+KUMRjOScA9Tjn36MMd+aAEJXJIG7p0AJwf72RnjtnoOMinZ6d2HKgdD1 GCR8vTp6daadx/hyCSee35YJHQY6Yz6Up4zxjHJOMY4PQ+h6A/h1o/r/ACD+v8huCNwIwDjkEZAx zg/3j1xk8dsUEAk9QOBgjAIIIyCO/c9vTvSkZBbOSO/UE57eox2/pRyQM9RkcAKuQMjdnOO4A/xo AM4UcAkcAgcehBA5A6kZoBxkAEg8H7u3JPUf1zjPHFBzgZIHIII5PsSvqD1J9KVsAcDJP3eD1Pcn J45zz06CgAPQAHD/AHflBIznryOgwevfmkI4ByDnKjgYIGRknkdu/wDSjBXnpgHOOSc8DpzgNyeT 16c0AcY7kgA8HAPXA7Y6nuM0AKOp4XaQCA3O4dSfTPoB9aMHOQCCxwwJycei4OB2JJ7YpOMEKTxk L8uBkn2HOfpjrQchhy2cDuTgY5wM/Mcg5GM8ZoAUcAhsgDIBOcfTnqOOB0PPXNICOMDtnJC7SOcg cZP0Hb8KXdkYAOT9fx4+nbjHpSAHJyuO2R1Iz2A4HPtkgZoAXPbpjG4DGCD3OM4xg5K+2abkYVlH XkdRkZxghhlfy5+mcOzkAYIOSBnABwepA469sfXtSYyRnkknkdAAODhs5PUKT09sUAC4OMg4AztY AAA98EkLjtt4P5mjPB7cEnAPc46EngjHIz6jimk5BHJwSPm5PA64AGP9nGSDzzmnMcZPPy5O4dx6 A9yMY6HGfTNABnBJJACg7ST8p7n9Oc5z2zjqLyxOBwDt6D5h3x1zjuTz1HSggAbs55zkg5zjoR9O ORnnnI4KDAI2jaWAyR15PBzyTjGNpxt6d6AHDAY4xwOc9AfQHkjGR/iaNxz/ABHA7AZGeRnsAcYB Of60E5G5ecYGc9e2SM8jOO/akOVPqPu5yD6HBHXrn6CgAP1wCDgHLAHpjHTtnp1656kxnGcsckdM 4HQ4zxzjqe/HFKAepBXsBknBxngcggn/AOv0o4IHUd8L/F9cYGPUcdOetACdsgDHI5I//WD34PJ6 UZBIzkhiNuQe4zgFQenQluhGD1pc4Ixk4xkADaSTgYJzjHc9+5pDnJx9Oee/T6deDx684oATPYAk E8Y5IIyOOhx/tA5+o5pwxgHAO48kjJI5zyvPHqe3amngMw3DBxkFcnpySQcL6dgB24pRyT2OOPfp x7j+6pGevUZoACc9fTIGPcDgk8ng8H8sc0hbCgcZ546lTx0HTjIwTwCc0cE7cld2SBgnuOGHQdcc 9MfSlIGduAc8EYPp1znvnGCecY7gAAQ9D1x1PPc9SSDjPbPGeo4peiAcDP0JI54IPb3yfahWAAJ4 A4C9Ac5wMYwCPTkUvIOM4AG4c8E9ByegznPHOe9ACcZGMgDBBIGfXPTkHOBj0PtTeRk5PJJIwMgM B0J/h74z1x6UFScqQSOflyPlHYjGPY4HNOAIwAASDgjkgjqDlskHGcjv6jHIBGwAPCA8Y5CsuGwG BypzxnPp06Gvz7/bD/4J0/A/9rXRrqbVNMtfCXj+O0mj0rxdpNlAfOlYM6Q61YRqkV/byMuGkHlz xE70Yn5T+hBUHJLcEMSewB6gZ7kAZB5GMimYI3D5jxuDEAccgAY7ck5OMdO+amUITi4TipQl8UXs 9b/ffVPo9Q1/rutvu8z/ADuf23v+CZfxk/Zp8S3qa54cuToonnGm69pEU13oesRqNyXFncopWK48 shmtpVSRWBUhtua/Prw54L1aLSPEGrawlxatocczzqxa1vFs7WFp5GBlEYlSQRsjOxwHADlS2a/1 HfG/gTwj8RvD154X8caDpviPRL2Jo5bLUraOZVZ8YlhdlJgkHBEseHXqCcmv5uv+ClH/AAST1H/h BvHnjX4FWU2t6bH4Y8R3c/hqztIV12136dcyC3tVt1ibUIi+1VZf3zFV3xsdxrDA4OGBxbxWHnKK jFuNB6x52pK8dote9K0Zr3dbN7tuFOro0oSk/fqay5tbq6fM1d7pPl7rofzqfsMfHgeNfh3N4k/4 R290vT7HXdR0uzd5DdNe2mnysBdzGJRGkgzloU3BAo+YowNfsDp/xJ8O2lh8FvHA1WTUtM0/XyqW qBf7NW5kuA2oXUoOBJdoVW3B2Yjj43c4P4i/sj6ppHwb/ZB8MXHii0az1jVfEfjiaeFVaO8tbnTf EN9ozaZe20qxvZ3UJsNssRDZMrKQuVJ9X8O/tBaV4/8ADV1oWmXU6yeG9SW7TSBClvdww3bFJbq3 i3JF5YkXa+TsY+W/DV89gOPpzx+YYbNqSp4PCY1YeOPhTlH2MbNSWIpxclFU502o1o6QTTqRTaPf xPD0KccH9VmpYyvg1V9hN8rrSjTg+WlLkjyc0U3GE1yyalyvY/ra+I37bPw7u/BF5pGnahBP9s0W 2gtmsZo4xHIVQiPgo3yv5m6MFQfvuD3/AJKP29vi1eaL4g1LVdRiuoBevLcWBfcPOiXdJHIJBgEs DvJG4/dBIJ4o+Ivirrej6Rca1bancXUVjDJOTK8gnCw581ZojvEQjCEM4QIwwCfm42fGWv8Ah79u L9kzxYxTSV+JPww0w3GmR28sNtf3+lCVjcGS3kcS3UkIIYyxdFAygUV+58J5Bg8xwtTFYXEqvVlT VaE+eNSFaEtVKDpyacY6XV3Zp3irM/L+Js9rZZWoU8RScacqio1UrqWHT5YqUlNq15PWE3F8tm+V NSPwduvj94hXxjLqhmN1HM0sLzCOGRrqx3O0lpcwyqYtRtpIgY2hu0YxhsxlGAYfZ3wI+NMXgnX7 pbyIReF/FtlbWWv+GI5pbS31LQdQaK78u1m/ePbS2cyx3Ok3glM9lfQRSIytGQfyv8Q6bc6Lrd5p l1GyXcVyYpI3ypCiRlyhOAHCkqCBtPDEY4q14h8c+NfBPiPwFr2saXqNz4IfQbfR47ieImC4jt7y dpo45IlWL7RA0pAEpSQqoYAgCvznxI4Py3GYBZlRhRwme0sTSjCvRkqNbFTipyUGo8iqVkoKVKT/ AHloWU1BtH6H4f8AFePwmLlgatWeLyivhajq0JuVWnQvKFqj91unSfM4yhG9NSkp8snFp/2q/AL9 kz4gfH/RbH/hTX7QPhPxZ4N1f/TbHRPjD9q0fxfokkredJpU/ijRYJrXWpLNmMMUt/YRTXa4eSZm YvX9TH7EH7Lviv8AZr+H72HjvxpZ+MvFepWNjazf2RDJDoWj2Fo008en2U1wBPqLrJcNuvZFhBjR I44wgzX8HH/BM39pDXdIGm+IfA994l8S2GsXy2eq+FdOjMlvoG1wlvLd3DyeVb2d7Gwa3mwWMoZB 8qkj+sX4XftkfFz4Wv4d8SCx1r4ifC652R+N/hkDDdeP/B0E2zzPEPge4lZTrdla/NLqPhq5nM+z 5tLlLH7PX5xw7xxOpUhkPEGJqfXaU3TwmKrqEFWhBxhy1Yy5ZQqxa5XUvLnVrt63+qz/AIVdOLxu Uwg8LUTqVMPTvzQnJKTen7uUWmuWUXZ3vJqTZ+8AIVWIyMKVZSPlBA6ZHIBzxjPfnrQWwuSDkKOg LDbtbGBjuOik8/xH0474f/EHwp8UfCGj+OvBOoHVPDutwGW0uDDJbTxSRsYrmzvLOdUms720mVoL q2lRZIZldSMjNdkM5OePlLEqOcZAIAOc7uQSeBjtX6Iv8vxVz4NpptNNNOzT0aa3TXRoUFSQR2A5 bpjkjqSQWzjb7YGKN3BBJUfKuDnghc9vu8g8j8T0piNyCo69cnBxu53EDOcY529M5OKcXGec5BHA HUE5BAzjHIz0B79aBDlJwTj2we4PU4zkc470g5GQACc4AHIB9u2ecjGRgEnmjaRjAwMcnA+YHnBw c54z6ADpzSggZCjaMbiwznI65yMHry24HPHOKAFU9egx64z9R6/TI/DubjznJ7HgDp2J7dc4HPp7 mdxyuPmxg88A8H05I+v170mW54zu9cfMRkDnjGOBn156UAO55Ab0xnJ64PHpxwDgYzwB2TAJBOSc fMSOQByBzwB3HOTS4xycgnJAzkgDqvORjHp06ijg+vA+6CdvPOWxwR34xj0oATOBkgY69QTx6d+P TnHejPIB+Y/MQSCMgd8qNoHPGTyPoaUH5sDJGdvQAA4yWDZ/QY74pOT06E855OB19hjjk9O3egBM 9Bg4GSD0wMAkE8Fcduob+Idi7gAcDuc4wTxwTtPGTxz1OOhpvQA4YbjjGVI6nlzgkk8+5yADmlB6 nB+nUsOe3Rm9+MDGRwKAAk9RksMADoeQehzz168n8eqMeAo2kgDHTIzkHk8A5B5I7dcnNAAJC5PG Djkg9eM9iMZPOfxzQQvIIyBk4x6HngnDZxnBzjPqCSAOIAUccY4x3Y9vx/ye1BJAGCB3OAOc468c dR06mkB45PUbQpORkY+boOnGeKXB+YemABnqG68nPboMDkUADfewMkk8Dse7EnHbp1ySeT6IQRgE 9uAcjIHGCeGGCQe314xQeWznpuzk5AU4+bnjAIPoT68UEfQ4Jx0PBGTtyeSAOR75yaAEx8zZABO3 GcnJOMdeMDO0+pHrmlAyMDoe+cEHBBA4xnPGD/8AqCQ2D2xlTncpJ/HIKnBPH0NIRzjnjBwTgEnI xweeo4znp70AKSQSc9wCOpPIx0446k9fXHSgZI6AAnJOMc+vHT3OPqaQ8kAnHOB3HHUZ4+Yd+2OQ TjFKOR8oJUABSCQDg4AOeoz1+p6igA4GRn1Cg9ARyByCMHAOe2KQE57HJyAQME9Mdu2TzS9RjkLz 12g5A6j+9g+oGR0zijsNwJBPGDwASCArDG7j/wCtigAOeTzxj26fw8k4POQfbn1pM8/xcAEjIPBJ z7DPQnIPbPNKepyPXAGAM+7Z5x2HHoaMk5ORzwckDAPbkc578Dn7uRmgBw5DDjjnAHfr7j2zg5xm mgEnIzwcZOc7u4wB0Gccgjjr6qOhxnjAB6HBP4557enfmkAGCQR1JUk8nJzwTySOmTnJPrzQAnUH HzcEcE9uq8dQcEZ55PUE4oAHHIAwAfqc7eTnHTB7E8ilBAPb5jwMhTuIBIODkHttyc9aAAecHuWG PmHTjOcHHPr14FACnOCfbB5HQ4ySDg5OO3X37tyeV4IIHYnjnA5ySR+fSgZ5bPPByx6Z4GRg9ee3 X2o4655BAAIOdxzwcE8+nbpzzwAOIJyTxjH1HQbh1yQD655+lJkdsdCpz1HcHOMnqW74Paj0yD27 5wf4QAexOc5xwBk4oOSc5w2fVc4GM8c5bAI28gg5zxQAZ647d8AkHGADjaOnp6jvScggfMPXBxjG ffnJG4fXHelP8Rwc+p6dc5IPGTxwOvOMDijOB3BIILYGQeOijt6cfUjFACLjg9QOcnnOeT16lj3P IA9KVyCA2eoycD72CMDIzjJ45JHXApT0K5HBBUZBOME84HHc55Hoe9DAHGMjIBHXnndjA78HuRxn twAM2lcnIU5BPUkNjjB/kPU9qjKhioKBlywdW+ZeRyoVsqc7sYO4cDJ5qVh1HUMORxgEH+I9sHjI 4yOgpDxwDnBAJB+7kZB6fd7fL35PpQB/P9/wUS/4JEeC/iBpvjD4o/ALwnZ2mqapeah4u8Z/DTSo fKttX1i6jD6pr3g+0jZIbPVNUdDeappVuI4r69Vru3VbmaRJP5S/FHjv9iv9kXxpZXHxU8YXekeN tJe5tNW8E3nhPX/t81tNJHBd2nk3llaW1xPay/PJFJOrpIj7SHAB/wBLMhguAOpbawwuFOSMnqAB wGADbsEV+KX/AAVn/wCCPPwK/wCCgfwv8T61beENI0j426bpNze6HrthaQ2h8S3lrbyvb2epvEqq upuVAsdVAMvn7YbsSwPhfm8dwflObYueJrV8bga1f/eJYavahiPdStWpTjOMHUSjGVaCVklKUW05 HtYXP8bg6MaSp4fExp2dGWIpuVWjaV48lRO7jG7cYyUlFaQsrI/mHsfCvwC/aO8MXPjb4B+PtA8U 6RrdrKbrStLvIYr+xaaHDw3mleb9tsJfvQy27ReUxUncxr84fHPwF+N37N3iPUPFnwsae60eQXA1 TQnlljEtldEpfWgTdmW3kiYiMbCYt4O4bWJ+KfCv7Fv7SHwF8eePNO8LeJtR8B698L/FY0jxA631 3oWopbyyS/2dql1bAxN5DywvaSbomiivQ8MwG4E/pP4E/aR/aG0bTrDT/inoGi/GHRLdYvM1GJot K8SLaxx+UH+3Qo2naqQuZFFyI2uJAWdgVBPz2CznP/DLGKOU5jGpllepd5Xj5TpxlJOMKnssQ5OF GtGycatLk9q3H2kJWaXt4nI8s42wl8Xg1HE0afMsdhpU1UipRSUp096lOMua8JpuyXLOMuY/OHxT 8FtQ+JPj2y1G30+fwpb3tz9q1FdUygjnmdWdEIR5JF3lv3m1UIbKjJWvpX4f/s4+JtMu5/C+s6Lp +veEvFMsUUll4l09NW0mJGdYZNT03zg3kXFuqnY9qY5i7LvfCkV93abrnwI+KDWl5p96/g/WbiRo LfSfFVodMlkv4pDutLXVQP7MvJYWYKY7e5LgoAIxkY9RsNA1HwrDPc6jbu9ppl4I4WVPOha3kZDa T20hMv7udmIMsbKi5Ksc4z5XFviJmXEkW8bh4YX2cbxwy540YVZJOOIT1qVqsHZxnCSUouShCPM+ boyPgunkSawmJknGUIzrK6rzowtzUbJu1CSnacdb2UZN20h+EP8AwT28Rfs1694c/aD/AGX9QN4N Pmtn8W/BjxbqN9/wgXjbTBEZLnSjqdk323QhKzM9p58dxb2l15RM0ccbiv1c+FHxx8NePNTudEgs NZ+GXjuwRP7S+F/jMRnxJphkVma7026iItPE+hTMCbPV9JknhMOxpY0cso+efgx+0a3hue30vxAn n6aqCOSzULumDbVRZ5EHlKsG8s4I3MDhiMgV9ealpPwo+IPh6W7fQ7LxFbi6gv8ASrvTbltD+JPg TVNzSprfgLxfbj7Tps0R3PcaPcpc6Jq0IEN7aOjFh/OOc4zMHXeIzCdapWhJewx1OSlOooybjTxE rKUnBpOLl7/vcrm4Wiv1rA4ig6FGnKMfZxSjGEIxjKKk1zJU7qM6d25Rh7so68s2m4v7n+Av7VXj D4Qzw+H72O213wVPL591ptx/ol7YyyyMbi606SNMF5yd7xNhZNrFvmHP7EfDz4o+DPifpMeq+FNX t707Y3utPaZI9RsnZAwjntg5kG1tyLIoMbgbhgsAf5f7/wATS+AfD4u/FF0/ibR4NRstN034r2yw 6XHai4IEWmfF3wkd0vgzWUkYQ23ibSvtXhLWnUyySabJI0Z9o+H/AMRvE3g7VbHxH4T1mfTLpAJo 9Qs7lZLC8tmKyPl4nNvNbTkgedH5kTrkoc4r9E4J8WcVl/scDm8qmOweseerNfWcNBP3PZTlL3kl /wAuK0pS6RqRufM8ScBUMdCWMy7kw+IlreCaw+IkoptSVrQqJ6OSUJXv7SGzf9LC8ZBABJOTnkrg 5yTgZwPlx7tzSqAAuCApLMApw3BGB1II+XJPY9OuB8P/AAK/bK8LePltvDvjwxeG/FI8mOK9lAGk aqxwiyxzEhLeSTJ3Idq7iCCFzj7dR45gksbrJG4DRyK8bxuHUMrRsrYdWXBUgnGMjdmv6TyvNcvz nCwxmXYmniaE0ruD96nKybhUh8UJxuk4ySfVaNH41jcBi8urSw+MoToVY9JJ8s1p71Ofw1I6r3ot rvZ6EhHVgRkknHozAjOc5G4ZAAGOpGDmlULwvtwT/EWPHrxnI6c1GcMcN8vykgEnDLjrjGcHPOME E4GakXJHCggZCYJUYHbbznAzg469RnFeicYZUEYIz15xjPPGCOoweh/nQDx0PHTOe+CSAAOnTGeT 6UzPRuCuTjdhSeQc5yfl6gkAhs8gingE4LcsOvLfnnABGD16YoAXJzkZIPIAOCSeOhJxtx07g0d+ Mn2JBHA4Hb5QeTg4PfpikXaNzYG49CAOnTOeMkHr1x2pynk8jac5JPzHg4BHXgY6HP6UAO5KnocH jAx+OOcdc8dPWmgE8jODnBJPzDuTxgZxkZA6/kv8Iz2OGIyOBknpz3JJ4P8AOkA2hSDyAOO57cDP f9fWgBDyp43A4ycnpnjgccZyO2F6kClwM9R7Y4+YAE9cnvwOv50AheAATyVCkAsAe2CMn1B6etGB gkZ4A5AAOcn1/AcZPHUCgAP5AnBGeAASR6MD646fyTJJwcMQQc46kAYIPXjpkH15oGQCRzk4POSc jJAHPOOQOO+TmgY4IOScgDBzjjd0PXsc4xyByM0AOIPUnBz24I657HhsAZGenemkjqOnBIwM5Xgj kc4AwCc55p3ORw2e3IJz1I5wMAYI5GCT3pBnII69WwQTjnoO+cjOfu496AE6DkE4wN3HUZJGOAep 4b8MmlBBAOeDzg9gDg8ADpjJII9Pelwc7cYBJPPJGeuAc/L0+bI/lSEk5HXDAEbcAkYOCTkYPtnj rQA37pJGQOenHcAYUDIzntweKceQO2O3HPHJJwOePbqMCkBHAUgAkkjOTs5AODnABOD0wPXGKU+o GCeMY6/QYPHHU9e3pQAnuMZUjqeM9R244zz78nFDEZJHbOTzghvrxx3P5cmnFgMnHC9sEZJ457Ae p5x3pOCSc49cNuHbGR0564BPA6c0ALu4PJG3H4gH05x1we59KOnO0ZHyqd3c9gMcAenYDJ6UZ+6D znI67snueDnAB9sDkk0nG3jI6EkEfe9cHnn1/TigBCVzycDkYPUdcf8A1hnnvjmnZGBkAHHG4BgS PoevHrgD0oGcnBBIGD3zjtkjqcE9OPfmgDBBH0ODu/Ht9M4GB9cUAJzu3ZAAznGM5xwOhABGOeen XkUmQCBgqThexwegIznH0Ax3zTsZBHBwedvUHjtxx7dKMnBY4AHXA3AjvyOTyOcAkdKAGnBB5z6c EnIPPOByMgk4yOmQKQHBx6dATkHkgEnoc/hz7A0pIJyRk/KASNuDycDocEZySR0AIz0UHOT95c4X AB+XHOCOpBGCckDrk0AIcdc5GSecA+pz9Onp+tLwM9MEA4yc8EEDpk8dxntmgHGcgEAdhnr0Gcfq M+g9jcOh6sC2SdoAOOATzxjnHTGCKAEBwc845YD68Ec4PtnoMgCnZP14BGTjGMggNjgknBJ6jNA4 xg9OcE9sn+I+vXBA4PegkHO4Zw2D+R4644wMjkjrk5oADxxjGME4OcMcYz07Zz9QcEkU0EZGME5P AIGQR7446cDk9xjqp4Oc445BIxzwDkAk9Qe365pQOAONvoSFx19j1HPXp+GQBCQM4x3zkAMOemen QnoOBQAQMN83JJC8ADGMg4zznqD7YHNLjCkZ4Bzk9Mc855P+HTNByDnAyRjrwfQjOcnphcc0ANBH c4A4OcdTypIGc9COSc57Gg8EcjgY44BycEHI5Yeg59adkqcZPQsPk5A74xkdeoOO2AaZwOgAYAAZ P8ZHynHcsOThSc9ehoAUkFTgEkkEHgk+g5Ax2x059KaVySWAB5/AbSDjGcnAPAGAc4PFSH37c5I4 Pcg+p7bRyPemnnAxtzj5gOnHP4E9D2oA/Cj/AIKmf8Ek7T9ql7r43/s/vZeE/j9aWJg1rSBJFY6D 8SLCJ1kmttSQmK2/teeOGNfNuWVLyVIXeSG5Uzv/ACLeOf2Tv2lPhv4mv/CPj7wH42+EepWt3cNe 3aaJqE/hzUREMRPLYXEAh3uwYyS6LdNauGD45Bf/AEwCQ+COADjO7DdecrjHPX65z6ipe2dnfx7L +0sr+E8Bby1trlUBABOyeORcHHJwQc8gVNajhMXTdHHYaGKotJcs+VqPL8MoqUJxU1ovaJKfKlG7 SVuihisThWpYevUpSUlNOEmldNPVJ6p2V47dT/M1+H/iHxX+zVr1/wCBfHHiH4cfEr4c+KDB4i8U fDH4ifDHx14o0N1uiJY9V0+fTdEe98Oa5LGCU1LQdUs5wSpZpMEH9EPg94i+EHxZ1G18IfAHwP8A GTVrDW40tLrwVL4B+IWvaD4fv7qTy47rw14j8Q6HbX8WjQyld2majLcR20SieO5j24b+6FvB/g6S Vp5fCfhh52jEfnvoGkNN5SAARtI9qWMcZ+7H91cgYrWtdPsNPXZY2FjZqeFFnaW1oAmMHcLeKJVX qAcnBwMc5HDj8myfH4H+z6mCf1fSynU9rUoqHwrD13BVKNt1FNw0s4uPunbhs5zHD15YlV5Ks3KT dJulGbk43dWHNONWWi95pSa6pbfwvfF79mP4kfCTV72HVvDut6FqIDyG11azljtrgNiSQ2Fw21Jk cAMCMsrbk25TNeYeBvixq3g/Uo7VZZ7W6tpgJYJ/MVGxIVJAfksu1VQKo4JJBHX+6f4sfBj4efGv w3d+F/iH4dsdbsp42jtrpokXU9OkZXVLjT7tQJreaIsXUqxVmB3KQa/mf/bm/wCCWPjz4YXGoeN/ hzBc+NfAqGWee7s1d9d0e1b7n9oWMCO862xJBuYtwaNMuEIyfwnivw8xmWwrYnBU3mmW2c5U/Zwn jcOlaUvbU4wUa1Fe9arTipRV+anC0XL9AyXijC5g/YYuccDjm06c78uHqTT6Sk/clLrCb961oybZ 494R+LPhfx9A0WqAWOrTwC1mc+WltcQGNjJFdRODDdwTcpNb3EciGMnahJxXb6ZZy+DVhvfBosLb SmMjah8N9UumtPCurNIxMlz4I1cJK/g3XJwVlTSLwyeGb+4Xy1TTZZQ9flUZPFXge9EOpRypFFzH dKrE4JZVaRAeJBhlbzDvGcMBivpz4cfH0CGCy8QbbzS3RkxMGLLtCoZGJyysm8lADt2rkHggfhuP yB0pKphpP2ceeXsqXNz03e9oLdKEk2oSi2lZpxT0/RsJmmIw7VOtepBqMJRqRUoSilpKTi7Tdm+W pF88Nb3TsfoFoGv2Otx3F3oTapaXFikcl/oms28uneJfD0skhUfbtOkY3MEMoXNtfQG4067TLWt0 8bA190/AX9sLxV8OZrfQvEzz+JvCo2RvBPJ/p2nQ5AMllM4Z22qdwhkDRuVKllPT8z/DOt2niTQ7 X7NcXVzZWW640/XdDmit/G/hF0xuOk6vIrpqGlTxhze+G9eF3ot9nAitZCJh22l+LrazSCfxrNp9 hbXksllo/jrSYnTQ9YvF2H7F4j0q5le68Da60Twu8d68ug3kpf8AsrUpB+6Xu4c4rzfhrHxqUcRV hGE1GpUVvZyjzR56WJhOo4tuKTamre9an7OULm+ZZNlnEWFdOVKLk5PloOzrxTV41KNVK9S0m1aP LJLlXLLS/wDTd4E+I3g74kaTb6z4T1i11CFwvnWwmT7dZyMqmSG4tw5eNk3beAY2KkqxPFdwvXJP AUKdpOCf94gHJznoB6Gv52vA/jvxN8NtZi1nw1qc+m38DRqFgkY2l3ExDxtPGuYpYZl6SHK42bCC xJ/Vr4I/td+F/HsdroPjF4PDfilvLhSeVlGl6hIcKHWRiq2zu6kAFiAxOQowa/qPhLxIyfiNU8NX rUsHmUrRVOU0qOJlZWdByfNGUtX7KeuqSnJ7/huf8IY7KZzq0IzxWEV3eEW61FWvarBX5l2nDfVu MbM+zAepORyVx1DADGM5yBzkgDoOSOwSTg7cE8KRhiVHPbrgZ49aRXVwjK6SK8eUeMh43VgG3K6k h1IOcggbcAE5JoIJA2kjHyj5l49QTgkDpnnnHtmv0dO+x8eDMo4LZLZKgqODzgYz8p5AKsFGc5Pe nbs9QFb0YZH3gOTnGTn1470ihSCQSck5ByVbOclTjIA65xxxx0p2MnnA4OMYwM9AScnPAJ4weeM4 oAbk8nOQflwASWJA4yRtBznjPI796NwGBuKnGSMc4GDjocZ47DrwaUjO3n7pO3GenTBGe+B1zjt6 UuQMN0U4BAG4k54567SOB9ORQAEDGM8nB46gf73QcjByMH60K3OD1HbqB0JwemRxjB/A5FBKg5bG cnOSAcAYIHsuB3AyT15oBB5bnOTlemM8dcfKBj5jgZOO1ABwOvI6eme3bof1/Sl4UEHBAOcAnJzk HgDPXnPQ880oPU7c5PGB369eOnfuccUmQQVPOMZYttznng9T1wCBgk0AIDj1OAAMccHkcnkeuSOc HtTiTk8buR1O04YDjOOnGSOpOOKBxjB54BBPPTjk43Y6Y4OfTNICDgnnrg9OfUHpjk8gccg5xQAo HGTk4wdpxuHTj5e2M8H8QaQ5O7OOTjGTgj7wIJIHQ4OOvek6ZHbpwcZ9CSDz6duOMUuDwMHuBnjP OQMnoevI9cYNAB1427dwJxx9ecDocE9cZx60jLjdnkE4yeozjpn36ds56UvOfu8c49MYwMk4OMc9 h2HIoORnORkHAHQ8HOMZwe/Q+uOxAHZBK4weeSeTjAHORxnp7nFNHLHBHOScY5U+n14waMlSTk87 cYw2QB2JIzkdTjryeuKTBx06nIyQMAdRwck57YwRmgBcdjgep75JBGc469PxxnmlUDOcAkg8Ejt0 AHOMDOMEj6Zpfl4JycnIBx39j7/T9KYFIySwI3HnjIBOAB25zg5IOM0AKc5xk8ZYAHhcDPOMsefl BxgHjk0dhxhcHp/9fk85OBzzntR6kFiBg8DGOc4AHOPrnHOR3oGMNnj5gTntjAzjkHjqeATnjpkA M7iOWJwTkbRgHB6HGfT8/rSnKgkAE4ByCQDg5IGO5HpjPXmkIAHTkdjgg8ng9s44wSue1JycYBJH uSOvp0FAC456buNo7HsQSCTyMAE9eOfSjaWBPIOCOPXIIAxjg8HjvmjB5wOeQM9Rk9MDk8Z5OOmD mlG4j7vPPJwPTpg47A5HqPegBAAGOcAgY9AQT3I/Tj8sUp5DZxycD355+ucfjg0nJwMnOGB5IxkD IxzuIHIGRjrz2QkkbQSSAAOAMEDGTknk5HHGD1oAUAkA9u3pjqc45OSOP/1ZPyGeCMgYBJORzkZz t4B4HtQOWxyMjbxgnI5ywBIHIzkHnjmhgCGCnByDuODn2ySPf19etADsYAwBxn5gQcc8DAxnI4A7 +1MHJyMnJOCTkZBGGGPlwM/oevZcYyC2M8jAz9D7E4x3GBgGkPAwc8rz6Ee3IBPOQBgg4OD1oAXO COqk57AjHXAHb6Hk9c0qjPTOCTwSpBGeoxyD2HoO4oOCe3QE89QDgnJx7A47n2pvAII6e/B+meCA fYEHgg0ALzkdAAuR1PI4IYZ/iDcE89OppOg+7jBwWyDnJJ46nI5x7/WlGcHg4Jznk4wfU9eMg5/S kweAB9cc8nvzgdMH5cnHfigBdhGD6A5Hbrn9eT6nn6UDhQF5zntzzyQOMY+hpTnqflGTkjn88HnH 6Un+1k8F++cZ67gcAY4Krz9TnNACHJOT1OP8RgevfihlOQcA8gfMcNj+LBGc5z09ec8UZJJbBIAw c4AJwACfm4Gc9MkfhTgBtOSeBgjPBI5GD37+vWgCMKFxggrzjJ+YnPUnPzEjoCCfTpQ3A3EcDsDy fQ55PPIIxjg96ewzyACNvC8DHXk4ye+emPX2aAWI59iu0HOMnJOcHrxjjg80AM6bio3E4HXBYDHI JwOOmTjIPXimyLDPG0EyLPFIhSSCVEZZFx8yyIwZWUr8rId25c5BUmpep9B82Mg8jOCH/EDavUnm k4IIz128gAkHPYAHG3JU8YXPPpQH/D/PuflL+15/wTG8AfGe21TxX8K4NN8FeO7nz7i50toUXw3r krozSGSBPl068mYgCeFDHvIZowMk/wAuPx0/Zv8Aih8AfEt/pPizw/eaDqllOWk026SRLa6ihleM XOnXRAgvraTClWhJYhxkDkn++fGR8vBBJ4O0Z7nGfmB4z1z6c4HjHxs+AHwt/aC8LXPhX4m+GLHW 7R0YWmoiGKHWNJkKlVudN1JU8+B4ixYw7jE+MOpFfnnE3AGAzd1MZlyp5fmL5pytG2ExUrO0a1KK /dSk9XWpLmT96UJttn12S8WYvL4xwuL5sXglpFN/v6CdlelUerSX2ZPRXUX0P4YPhv8AF7VvD80c FvLLagEJd2+99syhvnUcgYwDhSDjO3JUbq/R/wCF3jjwl44slivngsr2SFYhE8cElrdoocG1vrKc PDdwSnEbxzxyRMGKuACCt79tj/glr44+Cb6h4x8C2d54y8Dxu0sOq6XasdQ0uBmZo4dZsIRkrAm1 ZLxAwkwrPtJOPy30jXPFXge6hN2LuKISLEJvnhUFZFRVdiuYGj2jfuAyvy45OP5z4h4ZxWX4l0Mw wssJiYPlTcY+zrUnJKMqdSnPkrQkoq0r8q19pFzba/TsvzGOKorGZfiI1qCcNErTpOKi1GrBP2lK ouWXK7PWzbtdn7K6NFrHhC7h0/wvZRX3h2RrqfUfh/qN6BCzysZd/wAOPEuoyMumNEP3ieDdYuG0 maZ/K0u9tDthrtfDXinS9d+0Xfh55THplzLDq9hNbTafr/h68iPNtqumXKpe6fMCRtLK9rcAiS3u JY3Qj4i+G/7QcWpww6VrwFxFNtieYsCyAlQk0bEnhWXljt3qcAgZFfUi6Lp2rmx8TaHrd7ba9a2q pZ+K9DuU/tnTtOnAJ0rUrSQvaeJNCLqqz6RqkcyhQptJrZ1Dr+d1njsrqc1Cs4unJS5ZONnBvSKk 4vkd/c5eaC191PZ/R0cyoY1KhjIte6o+1k480nJpJVUrKokn/Ejea+0pX0/R74I/tVeJfAaW2i+I jJ4l8Kgwqiu5OpWCMNrMsjkhl5DCMuYyECgBgBX6heCPH3hf4g6RHrHhbU7bUYSB58IkQXVrKVy0 NzCSZInU4BcDy2wNp54/na8Na/GNmkeJWsdM1V2aCz8Y6fLKPB2u3mTILWYXio/hTX5EDBtG1rZb TS4GmX13Gy49t8J+MvFvw01W01Tw7qU+l30IjlmVXYW99GQrYu7TJjKSDazKGYHOV44r904F8YKt GFHA5zKWLw8H7JyU+bFYR+6rXlyurBLmfJUinFL3ZrSJ8LxNwLQqyliMutRqzcpxsnLD1420a9mn FSb054W1vzx5os/ekHoMkkbs+nJ6YwSOCOfqRx0bllYDovHzDG0EA4DA4Lc4GeR06Yr5F+Cn7Vvh vx95GheKjHoHiVmSBJ5isGm6lMRsAglYhIXcnKq52kEbDnFfXSlXCOGRlYbg0bbgd3OVOduxsfKQ fmBGMg1/SGXZngM2wsMZl2JpYrD1ErTpST5W1fkqR3hNLeMkn2umm/yTF4LE4GtKhiqM6VSPSS0k ukoyXuyi900/WzTSeOcgEkjh2yAM9OV4zkd8jPrSZZc4GDuAJ74IwSAT2POOmBwemV6E8c4GRjrn JyMHJKgEEdsZwc0mcknB6DuSScDsen047V3nKGM5+XnaCCCeNueoOcZ3HOeMdqUKpwSMZxnjIB5B B6dM/KBxt5ApByMeo4ZvQc4Kg4yDgHJ684z1VSwU/LhhwRycjPUrnOMHGcc4znpQAIODyNwzkDoN vQ8d+wPcccEcuOcDPcn9O34ZPFRjBZhlmOAeDgn5twG3uB1ZhxzgcCnDJPAOM9scDuvLYzjIycZ5 PWgB+DgE46d+mOij689/05whA5zgZ+8MgYwOnXoevIweOeaFwSeo7jBzwODuI6HHUA4zmgqDjBAA Yg5x8wwe/GccdvbpmgBGBGCeBz9R169+OOcHrjFPA5wcsAAeoIJ+hH5c/wCNNAJZjnJLAZwAwGOe uQAcEA4BJGDk4peFzw2QCVJHQdwcYABPAz657ZoAbj0ODjJAPJxxz26Z/AevNKCR0HGOecknnPHO B68emKXIypO057gYOMYUDjnk46/4UmOdp4DZzyAB3AI/+v8AkDQArAc5Hy8YI5znOQo7D157d6CB lfXAB4yATx25Dg9CeAAc44IA3qduMHCg8545GDnsR/Pg4AqkYHGWJIwTjrnrzyep6cfSgBCOcnjI yPX8c4PbOR1OKXHAPXleCdwyOB0zgcg8HAP1obdnGegPK/e56cd/UgUg3Z4yDj5s4JwcHPb6nGfw oAbg7sZI4OcY6DqcdxwBzjoQM91BGACBggbcZOV46jPrnjPp7ilIUHjJ4x16jryfbryD6HpQQeCW ByCMHB5znrnqBz7YoAFGR3JJHUDI92AJzkevTn8RQckZwcHgHk4A4B5HX1x9OKCPlYqSuRjjke46 8HJ65Gc5FGDjvjjbsxjOM7snJOfXJ785oAUjKjI5Y8kntzxkYOPTj1/Fvoc7gffj0/DjB7cY96dk cBeM56jPPfHru5HQ9CceqdQQAOvYdFHT0xnB9utACgkjDDnGRgjt2DevqckUADcMjnGWGOBkc5bo STgn1J60g9cDIJXDfN8vUEY6e/H8hQSpHJJzhuQSBzjIwOgI4Gcc56c0AAHXHc9xycg4LY4OMfLj oCCe+QAfT1wwGM5ycg9RkfU5p2MEsD+nBHGee/TJx9KbyfXHJIH3cdRk84I9OvPtQAFeuefu5457 gAcAEd8epwTTRnAOQxydoPQkA9CMY56jkdhmngdNxwOSoH9euce46ngU1cDABxjuT0BOccnnHXtn nigAODjGeuOmQAc8EkgY4yRjlh6UrA4JA6Y5454PI5x6DAI/DGKTAHBIJGecAc54zg89semcnpSk HIGcgKcKwzz7HPzHg4yCOMjmgAHIGCSCSDg4x6jBH1z0GOc0EDcei9AO3BHOMcYwMn+lLjB+YMc4 BzjluxGMZxyPQCkJyCeCRwARjnpuzzglenT6UAAJHQZbOCSeeh7dzn070484OODnd04wOCR3OeRg D+RppODuA44xjAJ9Tz1GDxxj19KXgfLnAJwGGQ3PPUZyc9T6dR1NACYUr9Txxg++R125znHPXHNB Gcegx7YBGQADjgdh1B7Dsvykk5wSuMkHnrjggZwc4AAJPPpQcgAAjB6Z4I5yf8n6cUAAGe/T3B4w AcDnoQMHqRxmmMMYIwucEY469ueQc84APTHFOwf9rOflLYHTtjv6ZyMnn2oIXqSS2ee+CPb26cED uKAEyVLYwRnBJ4O8AYB5x2IzwN2OaTCknHsRnGMEYwuMkk45yeTmlwTyCBgjjg8c545IGfYnn8aU AZGOOuMHJHXGRzkD0A468cUAMIIOScD+EEHgkDBwBkDJIIx1yfWnYJ5OSMYHI+UnAJBIGB1yDnIp FB5B55YsVUKeuMEZPXOcDsSadyM5PPQnrx1wT0GMH3yaAKc1tb3UM1tcww3NvNG8c1vPGssE0bLh 45opcq6kbgwKkc1+SH7Xf/BLTwL8VINZ8X/Bq3sfCXjC7We6vfDknl/8I7rVyw3NJaKykaZeuM7t rLBI7Bspiv155BO7BYhuQOufw6Bec55xjvTMjG0jjHOcEHJODkcgZxkc8HGe48zNcny/OcNLC5hh oV6bUuWTSVWjKUeX2lGrbnpzS0vF2a0kpLQ7MDmGLy6tGvg606NRNc3K3yzimny1IP3ZRuuquujT P4R/if8AAf4j/BLxNfeG/Emg6hoeo6XcHdY3UTiVooXJjngJJEtvMTvilhkfClcrXVfCv40az4Z1 CCK4uZo4YX3yQzkhS6AgIjKAcFTyCMAMNy7ua/se+N37PHws+Pvh+fQfH/h20urgRPHp+u28McWt 6TIykK9pf7DKEGSXt3ZonHUKeR/NT+17/wAE3viJ8Dry68S6DaXHirwMFma18S6NaSte2yISYItb 0+IsbdQBtknjBRguWZeM/wA68ZeG2YZVGpicKp5plXv3qqmnisJScVzfW6dOPvUoQTjLEUIqLWtS nTcnf9PyjibCZry0MQ44PGuyV5fu68vd/gznJRjJ9KUpJydkrrVdn4P+IvhzxdZ3VzbXlhaX+p2o tNW066t4bvTdZsNpWTT9SsZQ8NzCWZjhv3iAmRGDhWHYx3uuaPe6XZ6Nplxq3hq4XavgR7x7vVNM iZDlvBfii/dTe2MWTLbeFdala4t4z9l0zUHxHDX5B6d4n8T+D9QjWVLq3hRwiTwPgu8YG4upAAUM QBnPyZLHqa+5/hT8etN1K3g0vxI37oSxH7SshEiodq7g5J2rliAwK7T9055r8Ux/D9WnJYrDzlpT bp1o80nGUbScYt6SikruMr3aSTS0Ps8JmVfCN0sRB1aDbhKMopxd3Ft2Ti4Tuko1HGXKtLP3k/si DU9O1HT31Pwxete2cNwtvfQtHNa6loV+pXzbPU7CRFu9O1GDG0Q3CxkE5jLja5+vvg3+1t4i+H0l vovja7bxD4bnljtbUMWk1XT3CcLFPL+8eJYg8irMWQYPzg4z8MFLW/1B/Emh6hNa3ZjjgTxPpaCb UTbxlWjj1vT3kjsvFOmxrujay1MG5t4zvsLy3mO6tmTUne606PXf7O0W91FpV0rVo7lT4a8SXESM GjsbyQtJpGoTYDDQtWMF4DIUt5LuMBz63C/Gub8J4inWhXqQpyUVU/59VoxtHlrUJtwjBuD95NtS cuXl0ZeY5Nlee0fZzoqbtJq/8akmo8sqc4+89mrxu7pqcLXP6E/Bvjjwx4/0eDWvC2qW2p2cyBmW KRPtFu5XmK6hVi0cgyFyAVbG8MecdWGbkZGR25UrzgZYgjqCOSTgBuM1+AXg34ieNfhjrUN94bvp tHnS4iNxATIbC9QFS0MsO4RxqSMM65yDkDa5Nfqj8Fv2p/C3xHjg0nxI8PhrxSVCFJnWLTNQK5Ba 0uJNpjaRhkRv8rk/IzZAr+rOEPEfKOJqdGhWnDAZnOCbw1Sf7qq7K7oVnaLu27Qk0+kZT3PxrPuE sfk7lWhF4nB3VqsbOpTUkmlVgtbLVc8Vy2V5KKaPq8gKo3DjGSxwSTjA3AHnAH3iAOBxmkGcZbI6 kZOBk8heCeR059+B0CKyOi7GVoyFcYUvmM5OFOTxnkPzx17ClyGRCABtYg9gW64BIB7eh7V+jHyY /nk4AOSSBwQ2cZzkccZ6kcilwoLdhnpt6evIzk/eIHrz3xTBtJDnAIB6jOBjrj25U5HpxxSnqo+Z grADggjdk8Zxk4OT1OAepHIAvReMfkRk8HJH945AJ6DkcdAoAOQPTgZAweMemckY6dMUZ2gnIwSc jB6cgAdz1GTR/wB9EAcjI2g8dD369Bg49KAHDAJzjnoMAkjg8N/Ecnp700dfmyGJwvGAMdB68c/n S4x3GDgrjk57/NwME4PGMAd803nABIzj5iCwGRzkZOVx0Izk544zQAmCSAB9ACFK9yQeQwBJxjmn nOD0BySdwzn0APT/ACccU0EDByG46jAyw5IwAMcdhyaMY4BGMHaSvHUEggDjqcd/rQA4DJOT8zA9 ugXpkdM57ccZ56U0Bs4GQe44JAPfOcgHspGQeh9E5+YgZzleuFB6jBxxzjOQfpgU5RtLbsgEHOem PYckc9ScZ6igAA3E53Z4z0/qcntngen1XAzwwwM8dRwR1PfJ69gRgUD73PIwNvJHHbJAyOM5z6Um CTwwHGcgDk8jbz0Pv/jQAA8NwAQCNvOOnJy3A46/TFJwudvJzngBQMckE9i3Tjmlzk8joMNuBxzn kk+2Oc8fSlyAByR83AAySR79x7469TgUAIAOw5IPGSRxyCQcbjj68ClP3cJgkZGQv3fbA6H/AOvR jPBOGJOASME+oGOeeoB7dRSHOQcgkEFuCAeMcYwQS3OWyBnGelABwB8oPBwQeoODtOO/pgc4PTvQ ATngkdCQRg8jPy9QRjAz6mm55yWwOnPO4DtyDyM43YB9OKdnoM4IOexAYdunGQep60AKc5OCADwO Og4HzZwQP8ikxlRtyQDt9DweuT0HU4OcjGeeKQ8DqO4Ix82c9jjH5n+lIQSMY+6MZzz2IOD0xzzk AHBOaAHfNtzk4z2GAQe4GcY7YzjNKFAG7JHTBYjGfoM855x3PHToDooB+YA7QTnPrk4x+I4796B9 0DpnqT+OOMY6Y5HTNACHgZ4bnnOc4BPIx6ntwMmghSACRjkkkZJOQeh547t9B3oGQAckjuoA4+uO T0PXjtQO2QM9uzYOOgP3h6j3oAMgnGDj3OBx1O0ckMCeTngZFKMDBzhR3b5j145P3evHSg8lgCTy NwxgcdgTnk9upzn2owM5VhjkNn5jyOO2AQeec56cE0AB65IIQcjAwM+pPpjI47Gmnjp069fvcDbz /CcHGD2GRRyM88EgrjOcY6MOjZ5HHC9+lAwP4gcHkcHavQ8kfNz6kgduOgA4Agcgg7cDd8wGSSck DtnA7Y68UncFjnaeMDGSTjIx/D1JOD+fU6nOeMjcOuMfLnpzn1wR+FN5yCMEqM4UYBxnGR1/pxQA rAqePYDpz3wBwQR/eB57j0UglgGLfhjuPc469MA5IpoB3A478DIx14ycZPBxgA7T193nkgg5UsSf r37Zxj0PGKAAgD5Q2DxkcE9ePpjqPXnsKTgNg4A45GTuAxwe38+QaG5PUDnHrjI6nPXB4IPTp0oO ehyxzkHGcjn04x04/PpQAZAJJwW5+UAE9f72O3BOemMdqBjqQcjAzuOSQcHnoARgkAgfmaXIwx4A 2nJAyOfT0Oe3TPbijjuSBgAE4X6Z44BPTPp3NACjABBC7jztCgH0B/2gAOvpTceuS/JwcKD1zj04 OM/X1oIIBGQDzt4Pccbu5A56Y3ZxjikP+9jA65OAcYyM54P93np83agAGSSBu9eoUqAMDI7g46js c9TSMpGOQADnHG7J5JXPBIOAMe2TmnAjkZBBHUY5BGCSAM9T90cDqcUhHTJHG0gkdQM46Djpz+oO aAEAzuB4JwT6MSO3Jz8vGR0PvVO5s7bUrWewv7a3vLO5ieC6tbqOO4hljkG14po3UxyIyEgjZ14O eTVtQRn+IN6gDIHb5euR0A/LJ4UjgbiUHqcZAPIHqB2AJyMGiy7J6W1V9H0BaNNaNbNbr0Z+Pv7W P/BLvwl8Q49S8Y/BaG28PeIHM15e+EJtkei6nMwd3On7W/0KeQjasYKxFsYXblK/nf8AiN8GPHnw j1nULHUtJ1LRdS0+VkuNKv45Ipo2RpFyhKqs9uQpMM8JYMGyeCM/3PlTjO0FjnknGRgqMADJIyDt 5GT1718/fHv9mf4X/tDaBNpHjbR411SOF00vxJYxxQaxp05TEbJcqu+eEMP3lvKxTYWRSpOa/LuL PDbBZv7bG5O6eXZlJc0qT544DENJb06bX1erK38SnHkk/jppylUPscl4sxGDUMLmPPi8FzQ952li KKjouWUrOpBLVxk+bRcsls/4+/ht8fNW0CaC2u5rmBfMiaa2mkcIqltrbQ5wF4wVCfMW55r708Kf Evwr4vtIxHHZSyzxCG4068SN9Pu0uRsYXlrKRG8iM26O4jUXMDgPG8bKpXzL9sX/AIJ3/En4K3k+ u2NhLrfg0zGOy8WaVDLJFEpYeXHq0CMz2M3Q7zuhbLOHJBr87bTxB4r+H+qpHeTTjyUUBQGBAB2+ YJgFRvlPmkLyRnDHgV/OGd8LYvCYqrgsfhqmExUG4unXjH2NSlLlbdKScYVo1Hbkqxlb4mm2j9Jw eMpV6McXl9dTpO8ounOblTknH3WlJ1IVVFPmg1Hbm5bczf7F3niC40G1mjW3n8T6BZyQxT6PLcS3 mu+H4NjPcXPh+/uSH8T6bbREFtLv5Tq8Ski0uLxYzEMfxB8SvCfw88Lt8RdW8T6ZYeCeWGs3Wpw2 V1bSBsLaCzedL6G7TYStiIRKpABUAg18qfC/45rq0un6LfLFdyXMkcP+lTkbBuBWUlW81WYH5SGy NxwODX4/f8FSPg5+0R+0l+054K+Gv7MNhqGpa1/wiV7q3izWZb+G00DS/D2myR2NtPq1xGq2lvcK 6ywRXjRtf3oCqgl8qvL4eySrHPMHhq+YUMow3NWqVcbipShRw9KhHnm1OVSnGLk4Sinz1Gm4aaHp 4nOY1MDVSwVTGYqEOX2dKmpTrSlywtUSjKV4x56vNBbRk5bJn9aH7In/AAVA8CeLZbjQ7DxnD8QP Dli8EE91AJftujLKfkZmmjWSVQhxICzBSh5yCR+2Hg7xp4a8eaNb694Z1S31OwuESQGGZHeLcoKi aMEvEx75xnGM1/GD+yb8NYf2YP2e/COj+N9CTwzd6VpFvpPjTxbolmnie0v/ABnMyC/udavrFTq9 lBdzASW1xfW4jaJSsZwrEffXwG/aTvtF1tY/BnxFtfD+p6UHnK3d0H0LV7dgriCW3kGQZ13KiPGJ FLLgLndX7Jw74tTyzE1sBmcMXmWU4erUpU8yUfaYilSpzjFVG+a1anKD5405yjUUfhbXLE+Qznge ljIQxGDq4bB42rTVR4dycaVWdk5RUWnKMldL2kVKDm7W1Vv6biCNwYjk8ng8HqCMghsdAc9eaGPC spJ45zkYXOBuwDnOAMccg8jHHhHwB+N/h746eDodb0u809tZs1it9dsLKdJVt7tU2G4i5LfZrpkc xEgMmCrdifdACcYVuPQ88DBB/gT1zk56nlq/ofB4zDZhhaGNwdWFfDYmnGrRqwd4zhJXTV0mmtpR aUotOMkmmj8nxGHq4WtVw9eDp1aU3CcX0ae6fWLWsZLSUWpJtNMl3cKWPJ7KFIznrySeR1yfQkni pAAOc4JPBJB/IDg+nsOe1RkEgDOGyMjGSR36j+n5UpAwSMYIJAznleMei5x26ng9K6TEXPAXJJLH IPBxkYwOgAHbgZ7UgxgHnudo4JJHTHRiMZ57/kVYgtjJxlie2cDgA9CMnkc9OnPIR0GBySDz3B7E 9OO5OPbNACHJJHPBzk5wc5xwegByOMYPU80E5BYHA57E7SQcNxyckD0xj0pcd8Z3c85B2jBPX1wS R/jmjcARn72QAoJzwCAen5jBGec9RQAvbGF3DHOBtbPH/jpwSO2Bikwcgk8DAODwefbqCP4TnHGO 9I2O3J6gnO4e3THPTIzx69Q4AYBOcnt256A4yQec56YoATlgcjB9M4AwR8vPHQnjGfelIDE46g4x njGOw6A4FJu4PvkEc5wcnOfUdAfxpB+fOCAMlefp1J4PoKAHYUZGTnoc88MD8p5wcAE/QAUgYDCg 84xk5J68AE+vYduaQ9SO/PTAPGPmwBkEDIz6H2o/4F93GD15Ge+MZ5yOMY4zigBxU9c4AwABjgZ+ b5jggn2PX1prYYnPIJAz1AHPUe2Pzp44BOMDHUdRz045JPX3/Gmggkk5PJHfAUEAcZBB7ngDJ6eg AEnDYLZPPBJHYhAcZU88Aep56YQepH3gOO4HBH1A54z14JHdQM7geOoyOfocDB44OcAZHvmjpyFH GRnJHc7u2RnIP1oAOQRkg8FiCMbhxgg9AeTwB3PalPJyuAMDIOAecjb+GCSCMHJ+tICpyATj+8M4 JxwOQeMDBA/wwmMnAAAPXHTjq3ODyOvpwPU0AL8yjHU5Bz0wDnJA52noMDHJ445peASTj7uMEgEc 4PXJHy4PU0HAzgc5HXPHfB7EHH8vakJzwSMDODz0OM5ByeuAP/r0AG0cnJCjndnnkA89yDnBHfpQ duRyQBgjqCNwGRnn2JHfNGOD7AcleCCepyMZP8h70g9QcAZ5yMH0yQOcAgfQdcUAOB3dCDjoMYAz 0Y57nsMe9HK5y3JAx0AyT8xwO5PQkZ96b6cg5xnI4B6AnOeAOnPpnoKcxwoHIbGOBwMnbnjgHkkH I549iAN455I4AznBxgMSCM8dh9eR1pTkkAbsEEAEEbcZ/A5AOCc5HGOtHABwOR69xnB55B/Tnv3o xjDdcduSOoxyOOCCR7nH1ADGQAOoB6Dhh1A9sfr0OOlKpHcg5LYYDBUDON2eRjoDnOcU3IAIb5Ry ep5OMEDHryQexzwaUkHk8/7LZ9sEcenXPXHrzQAmGPcDo2BgYGM44OVxx8wODwDx1XJJxjjA59c4 DMenTkZOR7UijIJOeOOMH8foOM4Hf0p2cdOOAR157geoBzyDnH1oATAwFPXDHg8Ejk5xwe319OOF wB94kEgnGcgYGdwweOBz6nFN6nI65zt5Oeee3TOfpjFBwMehAPIAJyeQcjJDenofagBchcnPJIOD kjJ5PHYjk57inYLDg8dScAlv7pAIIAz09vSmY7FupJIPJAwR044Hfk8YGOlOXr2OOp4zjtjgHC8e /wCdACE8AZJwpJGcnOCc+mPTngcUDAxgngYAXnGTyxXpgbsE+mfbASC2PmIAyBzyScc9NwAHHfnG R2O4x0IznuD0PHXr0GT0OCM0AIM8E5+Unk55xg5GfVenQY4AOKD0yDjJAGQSF5GVPqCCeT69KUjG QBnJzzkEcnaOeuCRijcM99xzkKT8vTJ545AyMgY6Z6YAA5JwAAQTzj5eBncO/qMjkHvSEN97PoMd c9sccN1HzYyOc8CkOO3J/vdyPQ5AHvxjJ9OcuwFI4JOCfbjnhgeCMY57+mQaAGDDHDEccMTnllyc gcZ7cHGMcA0gXIzkknIYA4xtOfTjPqMHr1zTyQRgjAPB553duB68Anp/RMZAUEtuI5HIwM8EHGR3 PIyaAKGo6Zp2r2F1pWqWdrf6dfRPbXVnfW8U9vdQsuHWWGUMrjaQCx9Nw55r8av2wP8Aglh4c8eQ X/jD4IxQ6Xqu1ri78HzkraXcoWR2/su4cg2r90gLFMcKw6V+0O3cT0HABKkKfvYYDjHTBIJ6dexp 3fuNvACkDI44BwRjP3sdBk89/IznI8sz7CywmZYaNaDV6dRXjXoT356NWLUoSva6vyTslNSSVu/L 8yxmV144jB1nSmrc0bKUKkb3cZwl7sk/k1umnqfwY/EX4X/EX4K+Kp9O1vTL/SNS066Mc9pcWzwz RGN2C7ZnVfNjBwyvGCrHhGYBsy/DX4wXPh7W7u8jdbXULlEi1C9KD7de28EjzQwSzt87xLK7usTE R733KmSSf7Lf2jP2TvhP+0h4dm0/xjo1vZa4IZI9N8U6dBEmq2jMh2rLIFxd24lCuY5twAGYytfy g/trf8E9vjD+ztfXkw0ybUvDF406aX4v0KKeeyuI8sYLe8ZEll0y6jQhp459q4UNFI3Gf594q8O8 xyqftacZZnlLb5q8KaliKKcqdliqMU/hS1rQvTlZOSpyaS/S8q4kw2ZRfvfVM05XFUoy9nHEWV70 ajvrfem2pv7Lk7HzZ+0Z+1V438D+BvEGueCfE8s1lf3No/inwvFEs+mariYrbfbYVRg8sLO6qZVE aEsfMVck/mn4M+KHxb8I6j4e+Iut2t7F8M/GN9f29l4lPmm2s47eT99pmoyJm3P9lzyiOwuk2ma2 3RSlpIia5L4yan8XfDegal4VvbK+u9Nu0lSK58qSWaNJWK/ZZrlAC9tLJmVY5laQMFaNlIFebfBL xp8Q9ZtfD3wy8a3uuL4H0Q3tlYaNfy3N3ollp+q3f2rUIrSyELeW93cu8skrFpGBfy2XdXp5Pw5l +X5VWdOngqs69Oaqxk4TnXpRpe63FOMqdenUblTSk3FStdWu/lcXnOfVMwhSrwxLo4XERdKTpzjU px92LdKdKPNU9o5WmpcylFaxskz+uj/gj1+0Ddx/HbSfCb6uLzQ/H2jXdrHGJHmhnu0ga6tJYHDF GLGLMYPBGNh5Nf1SjOOeOcDlTkkDDE/xDHQdyOpr+Wz/AIImfsI+JbHWNH/aC12XUfD3w68Dalqd t8N9CvLK5trzxNLLbyIt8Hu1SV9DsZLh2tZGTdNmJIpDGjZ/qUHLbVwMjdgY4DAZ9DkkgDrz1Hev 1DgHBYrA5D7LERcKVTGV6+CTvzPB1VT9nJptyi5zVSbUvevJt3umcHEtejiMdSlStzwwlGniEr+7 Wi53g20ryjBwjL+VrlfvJoUMUKjnBHIOcrx2yCcDg4Jx9MHKjgZyASwBx19c4HQZOcDgcEUcBVwD kEjDcADuwDcg89sZYYwOKA2Sd3BxjrncSCF5xjJ5zg8EYNfbHzwuckEDIz1z0zkYLYPHAz65x2pS ATjqMggA4wfr3znO08DgijnB5xjjHAAA9mJxxnOcjjtRyFGSrZ4ByTuOePbByASeg9sCgAyASCcg jByMjnOSDweRwee1Ieoz3GQMjoO+cY5zwP09VI4yTjrgHgH1AGTyAOufwoOeh69eSOuPU/hx7dqA EHUY5BPIOT17gnPPZh05BApfUMcZyDgYUgdQDnnjgZ5zRtJGCM5+6MnoBkkEcDnGOvrQc5bPHpw2 M9wD05+lACj3bJ/ADngAHadxPQ8nn0oAIxjIxkknoPXLcbsnnpz3xRyRwev3eOhHoMAflnJPXHRC Rg/eAJAO5jgJ0yMcYPTB70AHQnGeQc9M8epwee5GPY5oHPbJIByDtBXjJPqeOpznqMdaMnIIK88h iSuc9O307c8g5PUHIC84I/jAI54GMAEH0yoHWgAyOQSACRyOMHHTA5I7enegHg5UDPPJAAzzkDHP fJHXHejHV+4+UHJOB36YA68EEjnoKCDkANnkHDMBuHcccnIxxwvqKADOOR0zhjnBIxgEADqSM7Rx 3oBzgdW5AOAGORyT2zxyAAffrQckkcZ4BIyccnHJI5PIPPHA5oxycHPUsM5I7kE9+oxx+eKAGjGP XtnJGSDzwMHntyOfanDJB6cEclcsQfY9G7HtxnvRyeRjP1A/TqPUmlwfmIHOME5YnIwenc5zjGPf rQAnXGCRjI56gfxDBznOBtHPIJxS4B6HIyCe556ErtHcDK9sZxxTfTnBPsQc+uCDgkc5HoOMc0pz 7k42nbwdw75Ptke/PpQAuDg5JwT0OB9SRzx7dyR0OKTngD3UAgYI642+vfOcdznFBwTgHsAoOSWH Vuo4ztAyO44IJ4QZ4HTnop+YHHoR0xnnIz3PoALxjOMAjqTn1zgdufTgdcCgnPHU4wVHzds5A6DJ AGB069qMkjPGRxk8Nz64z6fwknH4ilC7flBKgDPB6k9eSRkAdOnSgBCR6DODxkEt2yTjgjOScZzx zSZI4565A6grjowxgeowck0o3fMcqRx1bOPUEKMcnnAHPfJoxkZPAwDkccdQT65wMjHXjNAATxnt u5xxkt2xyQec5Ofbg4pD7dQDwSSDjnB7AE9DyQ2OaXkehzkZ7e+PTnkf1oAPJ/h5zznnsOOvJ9qA FORgngYB+VeeeOTxjP0wKMdctwT045J5bJwcAkZXpn3pCCu0YwOQcbmGMnBJGMAZyAeR60A9TnOM 5Hrn145JB4yRjJ4xzQAuDyRnJxgjByOoOcLtAPJH48kmkPBBJyw6E4P1x6Y9e5+hoHHXccA9CQrE /dHHPTGD0x2pOoBBB7E88N94845yT3zxnHI5AFHXkZ5I6/MD1xuGOM+mPU5zyucdgMA5GR+e71zn 0Ix05pMnk5JyQOMMnI9wCRjGT8x60bcnBAIHzYB79QQAOeuCCQfegAB5GBuHQHgAjg8k57k4B9Mj rR/u4J+YjkAA+hOOcYPzckHpQckZ3YznqQAD7ZyRg4PAyOxpTkbR8pOBgcnJwdx57HBIPVjjPNAC bhznp1+YZwRg4BOMjIyCQee2KQ/eOc54PXBA7DOOTxnjoO3ouOnPPGAT1HqBnjk+pz7Ue3HHHJA+ v1HX6Z60AAzkAAEHOM5OCPTOSVPX2II4zR7EnPB6BRnsRz6gc8cZz1pdp4yMsDnqeACAOenrkYPH FNyRnPGD3DD5c9Bu4IHXnr7UALjJzuy34Lk4yAPkJIxyDn+tLg+4AGORg4PYep9Se/PNB6DnPO73 29wOBwRnAA4Azk0mcAZJAyS24kkEcqB25IzgduKAEONpAHH3iOBzwPoR+Wabs6eo7dOGIwCu7b3w ep5zzjFO5GRwMAg8kE+uAQck84H0IHo7k8HPGD82M+vBwfTuB9KAIt2MBSB1IUYGQmDtwMHcecdw cHOKz9T0vTNbsp9M1jTrLU9OukMVzZ6jawXdtMsmVZZLe4R42Vg20ZGepzmtPYCQ55JOAeuONvUg YOO3PIzn0ChLYz0HTOCemCOfbnnjsO1DSaaauno09muzBNp3Ts1qmt0+5+dfxY/4JcfsgfFm/n1b UvALeH7673C6bQJ1gs3ZmBybCRJIFwfuhAqIBhVBFXfhB/wS/wD2MfgzqcGt+HvhDoes65ahXh1L xPFFq4hljcussVjcI1kNsg3ANFIquSQuAuP0HPJ4O49DjnLc8Z4A9cn360AEFjw2AQABzwcnGe4J 59e1ebHJspjXeJWXYP27lzOp9Xp35t27OPKm3q5JKTdnzaHZ/aGOcPZ/W8RycvLb200+X+XmUlLl /ut28inbWtnZWsFlZWtvZ2dtEILW1s4IoLeCCMBEht7eFUjiSMYCxIoRQAAoxVkAsuGVcZK8As2O oIAAAB9846dsU4KTnB3cHIJA9eeOmAR2Hqc5zSYDEMBgEqVIzxjIG3BAJ59wetelZLZWOMEAJBBI 69eTt5OMEEZySenQjvSgDGASME4wejdR8u0DJHcZxn3pT1IDEZ7jaGJXg59MnjsfrS5Jx6HlvYDO T0HUjt14/EAActwSex/wI6E88tnvSHjPPHGAqgNt6HBB5IPUqAOevo8/fP8AwH+a1EfvH6v/AOh0 AO5BywHBz1yS3oBgAAj+Inr05xQTx64444I9QFyM9Qcn73PAp8n3T/un+a1GfvP/ALx/kKAHkPzg jJ4U4xjjp1GCecHsaTOCc9fckgkY7fhgcdMnIJ5ceq/7zf8AoVMP31/3/wDGgBSeh7dDyG4yAAAf Unv04POKUbiCOTwAOm3HfGepHqPz4plSf8s/8/3qAG/KM5xgkjAySPc9cEccdMdOOq8DBxtxz6nq ByD09QT/ADoT7r/U/wDoC0q/e/4CP5LTat9yf3q42rfcn96uISo5yAOcMORweje44/H6Ugzt9Ofl LDeB274Jz6Dp9Kk/hb/gX8zUZ+4f+Af+jDRbfyV/xS/ULb+Sv+KX6iEnoORgE44G3v0J+YHHXJAz k96M4HOAc7mI+YAjjgnGSRznopz3pYup/wCBf+hUj/xf7j/+hikIUZJIHBwcH73scn1zyDgAj9Qh h3GAMEAkZY45JBOQe3QgZFC9fy/9CWl7P9R/M0AICP8AJwQc+vPGDgZPQdjxQCRn1HK9zj5h26kn sAemc800dG/3l/8AQacvb/eX+tACkEjJHGB949DkZyV5wOR398DOD5emMkdcZAwepzjGB0+n4Ckl 7/7p/rT36j6N/KgBoxz0GeRnGByRjPf27fjSEjoCc5+7nBBBxnIHI5IA79fenr9wfUf+hUN1T6/1 FO2qXe342/zHbVLvb8bf5jT16gcc5UZ3Y4JOQBnpg5Ofwwzk8kHBGPmJB2/xcDqQ3KjOcUP1H+7H /wChGpV+4PqP/QqGrfcn96uDVvuT+9XGbsnHqOh4HHAJI684O0EYBzmgAkA/wjJIIxz0z15x1HOC OOKZ/d+j/wDoZqT+A/Qf+hNSEN5GNxyeTkE4wT2Gehxz1wOADyCvUcdeMYOATnGcY647j26c0j9B /uf0NB6/gv8AIUAOBJxjODg8YHOByeoAJ7Zz7UmMdcA4yR1J5PQDIx0HHPrxjL06n6L/ACpiff8A +At/NaAF47Dg4wSeeT2HfHQ4/PrQSMZ+mccMD0Bx2H8uvajuP98/zWpO5+g/m1O2l/Nr7rf5jtpf za+63+ZECCTjLKRz6HHHQ/KMY698UmSMYIJJx8q7eTypIznb/e7H09Xr94/739GqJOq/RP5mi2l/ Nr7rf5hbS/m191v8xw46jnBA5JPP3s8DaAeQMZI6d6M5x35Azjn0Hy54AOcjk9/anv1H+9H/AOhG o06j/eP/AKEaQh5V+mRktnPcqD0Bzxjr05HFNB65HfuScjnODyQeck4HQYyMAPH3k/3R/I1GPvD/ AHX/AJCgB3f2IxyQTuwcemOOcnkYIxzmlGW7E885wAR6gHBGeeeM/jTKkb7i/h/I0ANG3ocHI425 OMdsnnJPBzz/AEUYyOMcYI69c9T2I7859OKB/q/xb/0M05er/X+pptW+5P71cbVvuT+9XGkgdwCc Y28hs5AwccHqPbrSc7R2P+0N2R1IHIY8fxce/bDz9z8F/pTG+6v+8P8A0WaQhMnJx2P3hgDkcEEZ GDjDZHTvmjOOOnX6Et1GT0GRjcc8YwDToun4L/I0xu//AGy/rQAuC2QvynjtxtPvk88YI698dqCG AJ4wMYAJ+U9x747HjPHvTk6/iP5NSfwf8C/pQAHBGMDtg8AjjucY6jJGcZ4yRSDPPrwCq+4HAPfI 5JIAGaQfdH+8/wDMU5PvD8f5GgD/2Q= ________________________________________________________________________________
Date: May 11, 2018
Subject: Re: Faston / Aveo Tab Terminals
At 08:56 AM 5/11/2018, you wrote: >Bob: > >You are mixing Apples and Apple Sauce and coming up with Lumpy Apple Sauce. > >Those are PINS not Lugs. okay . . . >The Pins are supported by the connector. yes . . . >The Lugs are hanging out into the air. No support! that's what double wall heat shrink is for . . . >And that is why PIDG type Lugs are preferred! preferred but not necessarily required . . . especially when using 'softer' fat wires for battery/starter circuits. Emacs! Bob . . . ________________________________________________________________________________
Date: May 11, 2018
At 10:29 AM 5/11/2018, you wrote: >Why are you installing "lugs" that are hanging out into the air? > >Me thinks the problem with lugs is caused by the problem of not >following another good practice, which is that the wire should be >tied down in some manner to isolate the crimp connection from >vibration. You have to analyze the whole system. Not just one >connector style. Agreed. Nearly all creative arts from cooking to building airplanes, building houses and certainly all engineering is a study in (1) properties of materials and (2) management of energy as a SYSTEM. Policy and procedure can be exceedingly helpful (as long as it is correct . . . remember the AC43.13 fiasco of about 15 years back?) but it can never replace understanding of the physics. Bob . . . ________________________________________________________________________________
Date: May 11, 2018
Both molex .062 type and AMP mate-n-lok connectors have wrapover insulation s upports on the pins, and manage well without further support from the back s hell. That is considered adequate, with appropriate wire support in the bund le. On May 11, 2018, at 12:34, Robert L. Nuckolls, III <nuckolls.bob@aeroelectri c.com> wrote: At 10:29 AM 5/11/2018, you wrote: > Why are you installing "lugs" that are hanging out into the air? > > Me thinks the problem with lugs is caused by the problem of not following a nother good practice, which is that the wire should be tied down in some man ner to isolate the crimp connection from vibration. You have to analyze the whole system. Not just one connector style. Agreed. Nearly all creative arts from cooking to building airplanes, building houses and certainly all engineering is a study in (1) properties of materials and (2) management of energy as a SYSTEM. Policy and procedure can be exceedingly helpful (as long as it is correct . . . remember the AC43.13 fiasco of about 15 years back?) but it can never replace understanding of the physics. Bob . . . ________________________________________________________________________________
Date: May 11, 2018
Subject: Re: Bus bar materials
At 08:14 AM 5/11/2018, you wrote: >Bob: > >The question that Art brought up is due to >inconsistency in terms; you used the term 'dope'.=C2 =C2 > From Art's question I gathered he wanted to do two things: >1 - Insure electrical contact and >2 - Prevent corrosion due to the elements and dissimilar materials. > >I agree we, are talking two different products. > >Dow Corning DC 4 is a Dielectric Grease. >By definition and manufactures recommendations >it is used to COAT a joint in preventing contact by the elements. >Dielectric means INSULATE. >It does NOT improve the conductive properties of metals or dissimilar metals. >It protects them from the elements. Which is a >good thing if that is all you want to do. That IS all I want and expect it do to . . . >The product which has the industry nickname DUCK >GREASE does BOTH - Protect and Ensure electrical >conductivity, especially between dissimulator metals. >Personally I think this particular coating >process is just a bit beyond normal requirements. >Why? Well, I would have to ask: Is the owner >going to REPEAT the exact same process every Annual/Safety Inspection? >Remove/open the entire connection, clean the >mating areas, replace the lock-washers and >re-coat the area [with what ever process he deems acceptable]? Yeah . . . AC43.13 used to have a paragraph or two about "inspection of bus bars . . . with recommendations for refurbishment on condition. If any combination is assembled to specs and remains tight, then there is no reason to 'inspect'. This applies to every rivet in the airplane, all the fasteners in the engine, etc. etc. >Human Nature and 20+ years working on peoples planes, says: No! >Considering how DUCK GREASE is used, it does not >require replacement and it is used >between mating parts. BUT! I still think it is >Belts & Suspenders and Shoelaces. When you simply twist two strands of freshly exposed wire together in the classic 'Western Union" telegraph splice . . . that joint is presently as good as it will ever be. The telegraph guys didn't solder them because tension on the suspended wires maintained gas-tight connections where the forces peaked on the interfaces. Solder was later used to enhance integrity from environmental stresses . . . an excellent encapsulation that protected the edges of the regions of gas-tightness. DC4 or any other material used in the interface of devices on threaded fasteners does the same thing. The day that the assembly is made up brand new . . . is as good as that joint is ever going to be. Now, if the fastener stays tight and DC4 (or other good stuff) protects the boundaries of gas-tightness . . . the join's integrity will not degrade with age. > >Many of the certified planes out there are around 40 years old. >They nBarryow have a history. Those connections were NOT opened >every Annual/Safety Inspection. Yet! They continue to work! >If the additional coating process extends the unknown life of the >connection / plane ... GREAT! We will see in 41 years. My point exactly. We did not use ANY goops, greases, magic juice or pixie dust in the assembly of production airplane. The goal was to create joint with a life expectancy longer than the airframe itself . . . with, what you have observedis a high degree of success. DUCK grease may well be belt, suspenders and shoe laces . . . but DC4 (or equal) is at least belt and suspenders and probably useful in the most exposed joints . . . like those ground screws on an antenna? Bob . . . ________________________________________________________________________________
Subject: Re: Authority to solder splice a wire
Date: May 11, 2018
I don't think shrink wrap was invented when AC43.13 was written :) -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480080#480080 ________________________________________________________________________________
Date: May 12, 2018
Ira I agree with you, I think shrink wrap was invented only after AC43.13 was published ... Carlos Enviado do meu iPhone No dia 11/05/2018, s 21:22, rampil escreveu: > > I don't think shrink wrap was invented when AC43.13 was written :) > > -------- > Ira N224XS > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=480080#480080 > > > > > > > > > ________________________________________________________________________________
Date: May 12, 2018
You might be correct about the original version of AC 43-13-1. However, the current version AC 43-13-1B was published Sept 1998, with change 1 issued Sept 2001. Most of the editing was done a few years earlier. I can recall using heat shrink tubing in the early 80's and probably before that. AC 43-13-2B (alterations) was issued even more recently. Those dates straight from the cover of my desk reference copy. Kelly On 5/12/2018 1:34 AM, Carlos Trigo wrote: > > Ira > > I agree with you, I think shrink wrap was invented only after AC43.13 was published ... > > Carlos > > Enviado do meu iPhone > > No dia 11/05/2018, s 21:22, rampil escreveu: > >> >> I don't think shrink wrap was invented when AC43.13 was written :) >> >> -------- >> Ira N224XS ________________________________________________________________________________
Date: May 12, 2018
------> Kelly -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480088#480088 ________________________________________________________________________________
Date: May 12, 2018
OK... I had to go look it up. Heat-shrink tubing was invented by Raychem Corporation in 1962. See https://en.wikipedia.org/wiki/Heat-shrink_tubing Cheers, -- Art Z. -- https://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
Date: May 12, 2018
Just out of curiosity, is there a way to get a diff of what changed in the current version of AC43-13? We always here that its a document written in the blood of others mistakes. =C2- It would be telling to know what new "mistakes" were incorporated, a s well as knowing what new materials and techniques the FAA considers accep table. On Saturday, May 12, 2018 9:57 AM, Art Zemon wrote: OK... I had to go look it up.=C2-Heat-shrink tubing was invented by Rayc hem Corporation in 1962. See=C2-https://en.wikipedia.org/wiki/Heat-shrink _tubing Cheers,=C2- =C2- -- Art Z. -- https://CheerfulCurmudgeon.com/ "If I am not for myself, who is for me? And if I am only for myself, what a m I? And if not now, when?" Hillel ________________________________________________________________________________
Date: May 12, 2018
echristley(at)att.net wrote: > Just out of curiosity, is there a way to get a diff of what changed in the current version of AC43-13? Look for a black vertical bar in the left margin. It indicates that the text beside it has been changed from the last revision. This obviously doesnt provide a comparison with the superseded text, but if you have the old version as well, it shows where to compare. Eric Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480093#480093 ________________________________________________________________________________
Date: May 13, 2018
At 11:20 AM 5/12/2018, you wrote: >Just out of curiosity, is there a way to get a diff of what changed >in the current version of AC43-13? > >We always here that its a document written in the blood of others >mistakes. It would be telling to know what new "mistakes" were >incorporated, as well as knowing what new materials and techniques >the FAA considers acceptable. > That was an interesting revision process . . . AC43-13 had not been substantially revised in decades. When keepers of the flame were about to release the latest upgrade, they sent a copy to the technical services guru at EAA . . . his name escapes me at the moment . . . and asked if EAA members could review the document and offer advice on "typos and syntax, etc. By the way, we need your input in about a week." I received a copy of chapter 11. Other chapters were sent to various subject matter experts in EAA. I think I spent 4-5 late night sessions on the keyboard and managed to get my contributions, about a dozen pages of comments, in under the wire. I've got a copy of the EAA submission around here somewhere . . . I'll have to dig a bit. In any case, the total suggestion package was substantial. The target for releasing the revision was pushed back several months . . . almost a year I think. When it finally did get released, most of what EAA submitted was incorporated into the document . . . but a few new toe-stubbers were added as well (sigh) . . . nevertheless, it was a gratifying experience. Bob . . . ________________________________________________________________________________
Date: May 14, 2018
Subject: Re: TyWraps redux
Thanks for the kind words - just doing it like Bob taught me via his book and many PDFs and images. Mickey Coggins On Fri, 11 May 2018 at 15:39, FLYaDIVE wrote: > What do you mean PROBABLY!!! > > Certified Planes are Production Planes and do not come anywhere near the > quality of work done by most Experimental Builders. > > Again, GREAT WORK Mickey. > > Barry > > > On Thu, May 10, 2018 at 2:26 PM, Bob Verwey wrote: > >> Nice one! Prolly put some of those certified boys to shame! >> >> On Thu, 10 May 2018, 8:21 AM Mickey Coggins >> wrote: >> >>> FWF I used a lot of flat lace along with some adel clamps and I'm really >>> happy with the way it turned out. I have some pictures here: >>> >>> http://www.rv8.ch/fwf-wiring-photos/ >>> >>> I also did some testing with a good heat gun on the lace to make sure >>> that I understood how it would behave if it got really hot - I was >>> impressed. It basically didn't seem to care, and I could not get it to >>> melt or change state in any way with the heat gun that will cause Tefzel >>> wiring to finally melt and smoke. >>> >>> In parallel, I bought some Nomex lace, which also does not care about >>> getting cooked by a heat gun, and will probably add this next to the normal >>> lace in places that might be exposed to additional heat from the exhaust >>> pipes. Will give some feedback in a few years when I'm finally flying. :) >>> >>> Not sure why, but working with the lace was very satisfying. >>> >>> Mickey Coggins >>> >>> >>> On Wed, 9 May 2018 at 18:14, FLYaDIVE wrote: >>> >>>> Good point Bob... >>>> >>>> In general BLACK Ty-Wraps are UV and Ozone proof. The white ones >>>> become brittle with time and exposure. >>>> SOME - not all colored Ty-Wraps may also work. >>>> >>>> One might even find notes on the Ty-Wrap packaging as to UV & Ozone >>>> resistant. >>>> >>>> Barry >>>> >>>> On Tue, May 8, 2018 at 4:32 PM, Robert L. Nuckolls, III < >>>> nuckolls.bob(at)aeroelectric.com> wrote: >>>> >>>>> nuckolls.bob(at)aeroelectric.com> >>>>> >>>>> >>>>> >>>>> In a recent thread, TyWraps were discussed as a solution >>>>> for wire bundle management. We had some discussions on >>>>> these products about ten years back . . . >>>>> >>>>> In years since, I've had occasion to throw out stocks >>>>> of unused TyWraps given that they had become brittle with >>>>> age . . . the buckles would snap off in the ordinary process >>>>> of applying the wrap. >>>>> >>>>> Be aware that not all that is plastic is Nylon 6,6. Evolved >>>>> over the last 80+ years by DuPont. This material and its >>>>> close cousins have found their way into all manner of component, >>>>> many of which perform in under-hood environment of automobiles. >>>>> >>>>> When purchasing these critters, look for a 6-6, 6/6, 66 or even >>>>> a 6,6 description of the nylon. The last time I was in Harbor >>>>> Freight, many of their offerings bore such markings . . . but >>>>> some did not . . . especially the smaller ones in assorted colors. >>>>> >>>>> All the wraps I pitched a few years ago were smaller sizes >>>>> in various colors. Some had been in my Dad's inventory for untold >>>>> years and were literally falling apart. >>>>> >>>>> My favorite bundle security uses Dacron flat lace applied >>>>> like so . . . >>>>> >>>>> https://goo.gl/H3z1EQ >>>>> >>>>> Did a job for a rancher friend yesterday where the wiring was >>>>> installed and initially held in place with some TyWraps he had >>>>> laying around . . . after it was up and running, I dug out the >>>>> roll of flat lace and installed a wrap adjacent to each of the >>>>> TyWraps. Those plastic thingies MIGHT fall off in a few years >>>>> but I'm betting the string will still be on duty. >>>>> >>>>> >>>>> Bob . . . >>>>> ========== >>>>> - >>>>> Electric-List" rel="noreferrer" target="_blank"> >>>>> http://www.matronics.com/Navigator?AeroElectric-List >>>>> ========== >>>>> FORUMS - >>>>> eferrer" target="_blank">http://forums.matronics.com >>>>> ========== >>>>> WIKI - >>>>> errer" target="_blank">http://wiki.matronics.com >>>>> ========== >>>>> b Site - >>>>> -Matt Dralle, List Admin. >>>>> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >>>>> ========== >>>>> >>>>> >>>>> >>>>> >>>> > ________________________________________________________________________________
Date: May 14, 2018
Subject: Starting the Engine Reboots the EFIS
=8B=8B Folks, I am *finally* to the point on my project of starting the engine. When I first engage the starter, voltage drops so low that my EFIS reboots. The EFIS immediately reboots, less than 1 second later, but it takes several seconds for the engine instruments to come back online. It is a 12 volt system. During engine start, the equipment is drawing about 5 amps (other than the starter motor). I need about 9 volts to keep the EFIS from rebooting. I am using figure Z-12 with very minor modifications: replaced the ammeter shunts with hall effect sensors and rearranged the switches a bit. You can see my modified diagram here: engine.pdf What would be the simplest way to fix this issue? -- Art Z. -- https://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
Date: May 14, 2018
Subject: Re: Starting the Engine Reboots the EFIS
Battery for the EFIS? Does MGL make a backup battery for your engine monitor? On Mon, May 14, 2018 at 4:51 PM, Art Zemon wrote: > =8B=8B > Folks, > > I am *finally* to the point on my project of starting the engine. When I > first engage the starter, voltage drops so low that my EFIS reboots. The > EFIS immediately reboots, less than 1 second later, but it takes several > seconds for the engine instruments to come back online. > > It is a 12 volt system. During engine start, the equipment is drawing > about 5 amps (other than the starter motor). I need about 9 volts to keep > the EFIS from rebooting. > > I am using figure Z-12 with very minor modifications: replaced the ammete r > shunts with hall effect sensors and rearranged the switches a bit. You ca n > see my modified diagram here: engine.pdf > > > What would be the simplest way to fix this issue? > > -- Art Z. > > -- > https://CheerfulCurmudgeon.com/ > > *"If I am not for myself, who is for me? And if I am only for myself, wha t > am I? And if not now, when?" Hillel* > ________________________________________________________________________________
Date: May 14, 2018
Sebastien, MGL sells the AvioGuard, a DC-to-DC converting power supply for isolating the avionics from the rest of the aircraft system. It supports a backup battery. Cost would be $450 + the battery. I am hoping for a less expensive solution. -- Art Z. On Mon, May 14, 2018 at 7:09 PM, Sebastien wrote: > Battery for the EFIS? Does MGL make a backup battery for your engine > monitor? > > On Mon, May 14, 2018 at 4:51 PM, Art Zemon wrote: > >> =8B=8B >> Folks, >> >> I am *finally* to the point on my project of starting the engine. When I >> first engage the starter, voltage drops so low that my EFIS reboots. The >> EFIS immediately reboots, less than 1 second later, but it takes several >> seconds for the engine instruments to come back online. >> >> It is a 12 volt system. During engine start, the equipment is drawing >> about 5 amps (other than the starter motor). I need about 9 volts to kee p >> the EFIS from rebooting. >> >> I am using figure Z-12 with very minor modifications: replaced the >> ammeter shunts with hall effect sensors and rearranged the switches a bi t. >> You can see my modified diagram here: engine.pdf >> >> >> What would be the simplest way to fix this issue? >> > -- https://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
Date: May 14, 2018
What about something like this? http://www.tcwtech.com/ibbs_integrated_backup_battery_system_3ah_6ah.html As long as the rest of your system meets your needs this will at least fix the voltage drop issue for the EFIS. On Mon, May 14, 2018 at 8:45 PM Art Zemon wrote: > Sebastien, > > MGL sells the AvioGuard, a DC-to-DC converting power supply for isolating > the avionics from the rest of the aircraft system. It supports a backup > battery. Cost would be $450 + the battery. > > I am hoping for a less expensive solution. > > -- Art Z. > > > On Mon, May 14, 2018 at 7:09 PM, Sebastien wrote: > >> Battery for the EFIS? Does MGL make a backup battery for your engine >> monitor? >> >> On Mon, May 14, 2018 at 4:51 PM, Art Zemon wrote: >> >>> =8B=8B >>> Folks, >>> >>> I am *finally* to the point on my project of starting the engine. When >>> I first engage the starter, voltage drops so low that my EFIS reboots. The >>> EFIS immediately reboots, less than 1 second later, but it takes severa l >>> seconds for the engine instruments to come back online. >>> >>> It is a 12 volt system. During engine start, the equipment is drawing >>> about 5 amps (other than the starter motor). I need about 9 volts to ke ep >>> the EFIS from rebooting. >>> >>> I am using figure Z-12 with very minor modifications: replaced the >>> ammeter shunts with hall effect sensors and rearranged the switches a b it. >>> You can see my modified diagram here: engine.pdf >>> >>> >>> What would be the simplest way to fix this issue? >>> >> > > -- > https://CheerfulCurmudgeon.com/ > > *"If I am not for myself, who is for me? And if I am only for myself, wha t > am I? And if not now, when?" Hillel* > ________________________________________________________________________________
Date: May 14, 2018
Ebay for a 'boot/buck switching regulator' sized for your needs (likely way less than$30), and an aux battery sized the same way=2E Create a 'mini' bu s for the items you want to isolate=2E If all you want is brownout protect ion, a little 2 or 3 AH battery shoul be more than enough=2E There are oth er commercial products available that do the same thing, but obviously you will pay more=2E =81=A3Charlie=8B On May 14, 2018, 7:45 PM, at 7 :45 PM, Art Zemon wrote: >Sebastien, > >MGL sells the Av ioGuard, a DC-to-DC converting power supply for >isolating >the avionics fr om the rest of the aircraft system=2E It supports a backup >battery=2E Cost would be $450 + the battery=2E > >I am hoping for a less expensive solutio n=2E > > -- Art Z=2E > > >On Mon, May 14, 2018 at 7:09 PM, Sebastien wrote: > >> Battery for the EFIS? Does MGL make a backup battery for your engine >> monitor? >> >> On Mon, May 14, 2018 at 4:51 PM, Art Zemon wrote: >> >>> =8B=8B >>> Folks, >> > >>> I am *finally* to the point on my project of starting the engine=2E > When I >>> first engage the starter, voltage drops so low that my EFIS rebo ots=2E >The >>> EFIS immediately reboots, less than 1 second later, but it takes >several >>> seconds for the engine instruments to come back online =2E >>> >>> It is a 12 volt system=2E During engine start, the equipment is >drawing >>> about 5 amps (other than the starter motor)=2E I need about 9 volts to >keep >>> the EFIS from rebooting=2E >>> >>> I am using figure Z- 12 with very minor modifications: replaced the >>> ammeter shunts with hall effect sensors and rearranged the switches >a bit=2E >>> You can see my mo dified diagram here: engine=2Epdf >>> > >>> >>> What would b e the simplest way to fix this issue? >>> >> > >-- >https://CheerfulCurmud geon=2Ecom/ > >*"If I am not for myself, who is for me? And if I am only fo r myself, >what >am I? And if not now, when?" Hillel* ________________________________________________________________________________
From: Stuart Hutchison <stuart(at)stuarthutchison.com.au>
Date: May 15, 2018
I can=99t help wondering if your primary battery is aged and below par Art, but I second the IBBS from TCW Tech. Installed in parallel with a decent Schottky diode (bought mine from Eric at http://periheliondesign.com/ ) it=99s a simple way to overcome voltage sag on the bus during start and provides alternate power (hardwired to essential items of your choosing) in an emergency. Cheers, Stu > On 15 May 2018, at 10:56, Brian Lester wrote: > > What about something like this? > http://www.tcwtech.com/ibbs_integrated_backup_battery_system_3ah_6ah.html <http://www.tcwtech.com/ibbs_integrated_backup_battery_system_3ah_6ah.html > > > As long as the rest of your system meets your needs this will at least fix the voltage drop issue for the EFIS. > > > On Mon, May 14, 2018 at 8:45 PM Art Zemon > wrote: > Sebastien, > > MGL sells the AvioGuard, a DC-to-DC converting power supply for isolating the avionics from the rest of the aircraft system. It supports a backup battery. Cost would be $450 + the battery. > > I am hoping for a less expensive solution. > > -- Art Z. > > > On Mon, May 14, 2018 at 7:09 PM, Sebastien > wrote: > Battery for the EFIS? Does MGL make a backup battery for your engine monitor? > > On Mon, May 14, 2018 at 4:51 PM, Art Zemon > wrote: > =8B=8B > Folks, > > I am finally to the point on my project of starting the engine. When I first engage the starter, voltage drops so low that my EFIS reboots. The EFIS immediately reboots, less than 1 second later, but it takes several seconds for the engine instruments to come back online. > > It is a 12 volt system. During engine start, the equipment is drawing about 5 amps (other than the starter motor). I need about 9 volts to keep the EFIS from rebooting. > > I am using figure Z-12 with very minor modifications: replaced the ammeter shunts with hall effect sensors and rearranged the switches a bit. You can see my modified diagram here: engine.pdf > > What would be the simplest way to fix this issue? > > > -- > https://CheerfulCurmudgeon.com/ > > "If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel ________________________________________________________________________________
Date: May 14, 2018
Charlie, That sounds like exactly what I need: brownout protection for one to two seconds. Is this the sort of regulator that I need? https://www.ebay.com/itm/DROK-High-Efficiency-Regulator-DC-4-5-30V-to-0-8-2 8V-12A-Buck-Converter-Const/152990560495 -- Art Z. On Mon, May 14, 2018 at 7:59 PM, Charlie England wrote: > Ebay for a 'boot/buck switching regulator' sized for your needs (likely > way less than$30), and an aux battery sized the same way. Create a 'mini' > bus for the items you want to isolate. > > If all you want is brownout protection, a little 2 or 3 AH battery shoul > be more than enough. > > There are other commercial products available that do the same thing, but > obviously you will pay more. > > Charlie > On May 14, 2018, at 7:45 PM, Art Zemon wrote: >> >> Sebastien, >> >> MGL sells the AvioGuard, a DC-to-DC converting power supply for isolatin g >> the avionics from the rest of the aircraft system. It supports a backup >> battery. Cost would be $450 + the battery. >> >> I am hoping for a less expensive solution. >> >> -- Art Z. >> >> >> On Mon, May 14, 2018 at 7:09 PM, Sebastien wrote: >> >>> Battery for the EFIS? Does MGL make a backup battery for your engine >>> monitor? >>> >>> On Mon, May 14, 2018 at 4:51 PM, Art Zemon wrote: >>> >>>> =8B=8B >>>> Folks, >>>> >>>> I am *finally* to the point on my project of starting the engine. When >>>> I first engage the starter, voltage drops so low that my EFIS reboots. The >>>> EFIS immediately reboots, less than 1 second later, but it takes sever al >>>> seconds for the engine instruments to come back online. >>>> >>>> It is a 12 volt system. During engine start, the equipment is drawing >>>> about 5 amps (other than the starter motor). I need about 9 volts to k eep >>>> the EFIS from rebooting. >>>> >>>> I am using figure Z-12 with very minor modifications: replaced the >>>> ammeter shunts with hall effect sensors and rearranged the switches a bit. >>>> You can see my modified diagram here: engine.pdf >>>> >>>> >>>> What would be the simplest way to fix this issue? >>>> >>> >> >> -- >> https://CheerfulCurmudgeon.com/ >> >> *"If I am not for myself, who is for me? And if I am only for myself, >> what am I? And if not now, when?" Hillel* >> > -- https://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
Date: May 14, 2018
From: Robert McCallum <robert.mccallum2(at)sympatico.ca>
Read the specifications carefully as the following statement from their specs might be an issue. "Please note: the negative of input and output wiring cannot be common ground." Bob McC > ---------- Original Message ---------- > From: Art Zemon <art(at)zemon.name> > Date: May 14, 2018 at 9:47 PM > > Charlie, > > That sounds like exactly what I need: brownout protection for one to two > seconds. Is this the sort of regulator that I need? > https://www.ebay.com/itm/DROK-High-Efficiency-Regulator-DC-4-5-30V-to-0-8-28V-12A-Buck-Converter-Const/152990560495 > > -- Art Z. > > > On Mon, May 14, 2018 at 7:59 PM, Charlie England < ceengland7(at)gmail.com > > wrote: > > > > Ebay for a 'boot/buck switching regulator' sized for your > > > needs (likely way less than$30), and an aux battery sized the same > > > way. Create a 'mini' bus for the items you want to isolate. > > > > If all you want is brownout protection, a little 2 or 3 AH battery > > shoul be more than enough. > > > > There are other commercial products available that do the same > > thing, but obviously you will pay more. > > > > Charlie > > On May 14, 2018, at 7:45 PM, Art Zemon < art(at)zemon.name > > > wrote: > > > > > > > Sebastien, > > > > > > MGL sells the AvioGuard, a DC-to-DC converting power supply > > > for isolating the avionics from the rest of the aircraft system. It > > > supports a backup battery. Cost would be $450 + the battery. > > > > > > I am hoping for a less expensive solution. > > > > > > -- Art Z. > > > > > > > > > On Mon, May 14, 2018 at 7:09 PM, Sebastien < cluros(at)gmail.com > > > > wrote: > > > > > > > > > > Battery for the EFIS? Does MGL > > > > > > > make a backup battery for your engine monitor? > > > > > > > > On Mon, May 14, 2018 at 4:51 PM, Art Zemon < > > > > art(at)zemon.name > wrote: > > > > > > > > > > > > > Folks, > > > > > > > > > > I am finally to the point on my project of > > > > > starting the engine. When I first engage the starter, voltage drops so > > > > > low that my EFIS reboots. The EFIS immediately reboots, less than 1 > > > > > second later, but it takes several seconds for the engine instruments > > > > > to come back online. > > > > > > > > > > It is a 12 volt system. During engine start, the > > > > > equipment is drawing about 5 amps (other than the starter motor). I > > > > > need about 9 volts to keep the EFIS from rebooting. > > > > > > > > > > I am using figure Z-12 with very minor > > > > > modifications: replaced the ammeter shunts with hall effect sensors > > > > > and rearranged the switches a bit. You can see my modified diagram > > > > > here: engine.pdf > > > > > > > > > > > > > > > What would be the simplest way to fix this issue? > > > > > > > > > > > > > > > > > > > > > > > > > > > -- > > > https://CheerfulCurmudgeon.com/ > > > > > > > > > "If I am not for myself, who is for me? And if I am only for > > > myself, what am I? And if not now, when?" Hillel > > > > > > > > > > > > > > -- > https://CheerfulCurmudgeon.com/ > > "If I am not for myself, who is for me? And if I am only for myself, what > am I? And if not now, when?" Hillel > ________________________________________________________________________________
Date: May 14, 2018
Here is circuit. A disadvantage is 1/2 volt drop across the Schottky diode. But if the aircraft electrical system voltage is 14.2 or higher, it should be OK. Diode part number: 747-DSA300i45NA If the voltage drop across the diode is not desired, normally closed relay contacts could be connected in parallel with the diode. Energize the relay with the start push button. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480130#480130 Attachments: http://forums.matronics.com//files/brownout_bat_efis_135.jpg ________________________________________________________________________________
Date: May 14, 2018
Check out TCWTechs stuff. They have both backup batteries, and a power stabilizer that they offer that would do the trick. http://www.tcwtech.com/ Tim On 5/14/2018 7:38 PM, Art Zemon wrote: > Sebastien, > > MGL sells the AvioGuard, a DC-to-DC converting power supply for > isolating the avionics from the rest of the aircraft system. It supports > a backup battery. Cost would be $450 + the battery. > > I am hoping for a less expensive solution. > > -- Art Z. > > > On Mon, May 14, 2018 at 7:09 PM, Sebastien > wrote: > > Battery for the EFIS? Does MGL make a backup battery for your engine > monitor? > > On Mon, May 14, 2018 at 4:51 PM, Art Zemon > wrote: > > > Folks, > > I am /finally/to the point on my project of starting the > engine. When I first engage the starter, voltage drops so low > that my EFIS reboots. The EFIS immediately reboots, less than 1 > second later, but it takes several seconds for the engine > instruments to come back online. > > It is a 12 volt system. During engine start, the equipment is > drawing about 5 amps (other than the starter motor). I need > about 9 volts to keep the EFIS from rebooting. > > I am using figure Z-12 with very minor modifications: replaced > the ammeter shunts with hall effect sensors and rearranged the > switches a bit. You can see my modified diagram here: engine.pdf > > > What would be the simplest way to fix this issue? > > > > -- > https://CheerfulCurmudgeon.com/ > > /"If I am not for myself, who is for me? And if I am only for myself, > what am I? And if not now, when?" Hillel/ ________________________________________________________________________________
Date: May 14, 2018
That one appears to be buck only=2E Should still work fine if you only expe ct brownout protection=2E It can't do full charge voltage, but can likely d o around 13-13=2E5v when fed 14=2E5 by the alternator=2E But if you're do ing that, it would be simpler and cheaper to just use a fat schottsky diode =2E Again, ebay for the best price=2E =81=A3Charlie=8B On May 14 , 2018, 8:53 PM, at 8:53 PM, Art Zemon wrote: >Charlie, > >That sounds like exactly what I need: brownout protection for one to >tw o >seconds=2E Is this the sort of regulator that I need? >https://www=2Eeba y=2Ecom/itm/DROK-High-Efficiency-Regulator-DC-4-5-30V-to-0-8-28V-12A-Buck-C onverter-Const/152990560495 > > -- Art Z=2E > > >On Mon, May 14, 2018 at 7:59 PM, Charlie England >wrote: > >> Ebay for a 'boot/buck switching regulator' sized for your needs >(likely >> way less t han$30), and an aux battery sized the same way=2E Create a >'mini' >> bus f or the items you want to isolate=2E >> >> If all you want is brownout prote ction, a little 2 or 3 AH battery >shoul >> be more than enough=2E >> >> Th ere are other commercial products available that do the same thing, >but >> obviously you will pay more=2E >> >> Charlie >> On May 14, 2018, at 7:45 P M, Art Zemon wrote: >>> >>> Sebastien, >>> >>> MGL sells the AvioGuard, a DC-to-DC converting power supply for >isolating >>> the a vionics from the rest of the aircraft system=2E It supports a >backup >>> b attery=2E Cost would be $450 + the battery=2E >>> >>> I am hoping for a les s expensive solution=2E >>> >>> -- Art Z=2E >>> >>> >>> On Mon, May 14, 2018 at 7:09 PM, Sebastien wrote: >>> >>>> Battery fo r the EFIS? Does MGL make a backup battery for your >engine >>>> monitor? > >>> >>>> On Mon, May 14, 2018 at 4:51 PM, Art Zemon wrot e: >>>> >>>>> =8B=8B >>>>> Folks, >>>>> >>>>> I am *finally* to the point on my project of starting the engine=2E >When >>>>> I first enga ge the starter, voltage drops so low that my EFIS >reboots=2E The >>>>> EFI S immediately reboots, less than 1 second later, but it takes >several >>>> > seconds for the engine instruments to come back online=2E >>>>> >>>>> It is a 12 volt system=2E During engine start, the equipment is >drawing >>>>> about 5 amps (other than the starter motor)=2E I need about 9 volts >to ke ep >>>>> the EFIS from rebooting=2E >>>>> >>>>> I am using figure Z-12 with very minor modifications: replaced the >>>>> ammeter shunts with hall effe ct sensors and rearranged the >switches a bit=2E >>>>> You can see my modif ied diagram here: engine=2Epdf >>>>> > >>>>> >>>>> What woul d be the simplest way to fix this issue? >>>>> >>>> >>> >>> -- >>> https:// CheerfulCurmudgeon=2Ecom/ >>> >>> *"If I am not for myself, who is for me? And if I am only for >myself, >>> what am I? And if not now, when?" Hillel* >>> >> > > >-- >https://CheerfulCurmudgeon=2Ecom/ > >*"If I am not for my self, who is for me? And if I am only for myself, >what >am I? And if not n ow, when?" Hillel* ________________________________________________________________________________
Date: May 14, 2018
Ooh, good catch! =81=A3Charlie=8B On May 14, 2018, 9:13 PM, at 9 :13 PM, Robert McCallum wrote: >Read th e specifications carefully as the following statement from their >specs >mi ght be an issue=2E > >"Please note: the negative of input and output wiring cannot be common >ground=2E" > >Bob McC > >> ---------- Original Message - --------- >> From: Art Zemon <art@zemon=2Ename> >> Date: May 14, 20 18 at 9:47 PM >> >> Charlie, >> >> That sounds like exactly what I need: brownout protection for one >to two >> seconds=2E Is this the sort of regulator that I need? >> >https://www=2Eebay=2Ecom/itm/DROK-High-Effici ency-Regulator-DC-4-5-30V-to-0-8-28V-12A-Buck-Converter-Const/152990560495 >> >> -- Art Z=2E >> >> >> On Mon, May 14, 2018 at 7:59 PM, Char lie England < >ceengland7@gmail=2Ecom >> > wrote: >> >> > > Ebay for a 'boot/buck switching regulator ' sized >for your >> > > needs (likely way less than$30), and an au x battery sized >the same >> > > way=2E Create a 'mini' bus for the items you want to >isolate=2E >> > >> > If all you want is browno ut protection, a little 2 or 3 AH >battery >> > shoul be more than enough =2E >> > >> > There are other commercial products available that d o the >same >> > thing, but obviously you will pay more=2E >> > >> > Charlie >> > On May 14, 2018, at 7:45 PM, Art Zemon < art@zemon =2Ename >> > > wrote: >> > >> > > > > Sebastien, >> > > >> > > MGL sells the AvioGuard , a DC-to-DC converting power >supply >> > > for isolating the avionics fro m the rest of the aircraft system=2E >It >> > > supports a backup battery =2E Cost would be $450 + the battery=2E >> > > >> > > I am hop ing for a less expensive solution=2E >> > > >> > > -- Art Z=2E >> > > >> > > >> > > On Mon, May 14, 2018 at 7:09 PM, Sebast ien < >cluros@gmail=2Ecom >> > > > wrote: >> > > >> > > > > > > Battery for the EFIS? >Do es MGL >> > > > > > > make a backup battery for your engine >monitor? >> > > > >> > > > On Mon, May 14, 2018 at 4:51 PM, Art Zemon < >> > > > art@zemon=2Ename > wrote : >> > > > >> > > > > > > > > Folk s, >> > > > > >> > > > > I am finally to the point on my project >of >> > > > > starting the engine=2E When I first engage the st arter, voltage >drops so >> > > > > low that my EFIS reboots=2E The EFIS im mediately reboots, less >than 1 >> > > > > second later, but it takes sever al seconds for the engine >instruments >> > > > > to come back online=2E >> > > > > >> > > > > It is a 12 volt system=2E During e ngine >start, the >> > > > > equipment is drawing about 5 amps (other than the starter >motor)=2E I >> > > > > need about 9 volts to keep the EFIS fro m rebooting=2E >> > > > > >> > > > > I am using figure Z-12 with very minor >> > > > > modifications: replaced the ammeter shunts with hall effect >sensors >> > > > > and rearranged the switches a bit=2E You can see my modified >diagram >> > > > > here: engine=2Epdf >> > > > > > >> > > > > >> > > > > What would be th e simplest way to fix >this issue? >> > > > > >> > > > > > > > > >> > > > > > > >> > > >> > > -- >> > > https://CheerfulCurmudgeon=2Ecom/ >> > > >> > > >> > > "If I am not for myself, who is for me? And if I am >only for >> > > myself, what am I? And if not now, when?" Hillel >> > > >> > > > > >> > > >> >> >> -- >> htt ps://CheerfulCurmudgeon=2Ecom/ >> >> "If I am not for myself, who is f or me? And if I am only for >myself, what >> am I? And if not now, when?" H illel >> > > > ________________________________________________________________________________
Date: May 14, 2018
Don't you want a boost converter instead of a buck converter? Ken On 14/05/2018 10:41 PM, Charlie England wrote: > Ooh, good catch! > > Charlie > On May 14, 2018, at 9:13 PM, Robert McCallum > > > wrote: > > Read the specifications carefully as the following statement from > their specs might be an issue. > > "Please note: the negative of input and output wiring cannot be > common ground." > > Bob McC > >> ---------- Original Message ---------- >> From: Art Zemon <art(at)zemon.name> >> Date: May 14, 2018 at 9:47 PM >> >> Charlie, >> >> That sounds like exactly what I need: brownout protection for one >> to two seconds. Is this the sort of regulator that I need? >> https://www.ebay.com/itm/DROK-High-Efficiency-Regulator-DC-4-5-30V-to-0-8-28V-12A-Buck-Converter-Const/152990560495 >> >> >> -- Art Z. >> >> >> On Mon, May 14, 2018 at 7:59 PM, Charlie England < >> ceengland7(at)gmail.com > wrote: >> >> Ebay for a 'boot/buck switching regulator' sized for your >> needs (likely way less than$30), and an aux battery sized the >> same way. Create a 'mini' bus for the items you want to isolate. >> >> If all you want is brownout protection, a little 2 or 3 AH >> battery shoul be more than enough. >> >> There are other commercial products available that do the >> same thing, but obviously you will pay more. >> >> Charlie >> On May 14, 2018, at 7:45 PM, Art Zemon < art(at)zemon.name >> > wrote: >> >> Sebastien, >> >> MGL sells the AvioGuard, a DC-to-DC converting power >> supply for isolating the avionics from the rest of the >> aircraft system. It supports a backup battery. Cost would >> be $450 + the battery. >> >> I am hoping for a less expensive solution. >> >> -- Art Z. >> >> >> On Mon, May 14, 2018 at 7:09 PM, Sebastien < >> cluros(at)gmail.com > wrote: >> >> Battery for the EFIS? Does MGL make a backup battery >> for your engine monitor? >> >> On Mon, May 14, 2018 at 4:51 PM, Art Zemon < >> art(at)zemon.name > wrote: >> >> >> Folks, >> >> I am /finally/ to the point on my project of >> starting the engine. When I first engage the >> starter, voltage drops so low that my EFIS >> reboots. The EFIS immediately reboots, less than >> 1 second later, but it takes several seconds for >> the engine instruments to come back online. >> >> It is a 12 volt system. During engine start, the >> equipment is drawing about 5 amps (other than the >> starter motor). I need about 9 volts to keep the >> EFIS from rebooting. >> >> I am using figure Z-12 with very minor >> modifications: replaced the ammeter shunts with >> hall effect sensors and rearranged the switches a >> bit. You can see my modified diagram here: >> engine.pdf >> >> >> >> What would be the simplest way to fix this issue? >> >> >> >> -- >> https://CheerfulCurmudgeon.com/ >> >> >> /"If I am not for myself, who is for me? And if I am only >> for myself, what am I? And if not now, when?" Hillel/ >> >> >> >> >> -- >> https://CheerfulCurmudgeon.com/ >> >> /"If I am not for myself, who is for me? And if I am only for >> myself, what am I? And if not now, when?" Hillel/ > > ________________________________________________________________________________
Date: May 14, 2018
Eric Page, who's on this list, created a device to protect against this using a large capacitor. He modified an earlier design by Eric Jones. I bought one from him. It works great on my bench. Should be going in the plane in the next week or so. His original email is quoted below: --Rick Im starting a new thread on this topic in case anyone who might be interested missed the recent discussion, here: http://forum.matronics.com/viewtopic.php?t=16768062 To recap, Ive adapted Eric Jones design for a voltage slump eliminator (a device to prevent EFIS/EMS brownout/reboot during engine start) and designed a circuit board for it. The schematic (.PDF) is here: http://forum.matronics.com/download.php?id=44878 An archive (.ZIP) containing the full design files can be downloaded here: https://preview.tinyurl.com/yajod9m6 So far one member of the forum has expressed a desire for me to build one of these for him, so Ive ordered a batch of circuit boards. If anyone else wants a complete unit, please let me know so I can order all of the components at once. You can reply to this thread or contact me directly. The cost should be about $35 each, plus postage to your address. Ill send a PayPal invoice, along with copies of my receipts, once I know the exact amount for each device and I have them ready to mail. Im happy to part with bare circuit boards as well; again, for my cost ($0.55/ea) plus postage. Eric P.S. For anyone seeing this in the future, you can contact me directly to see if I have any circuit boards on hand. The PDF schematic file contains a link to Digi-Key that will load a shopping cart with all necessary components. On 05/14/2018 07:51 PM, Art Zemon wrote: > > Folks, > > I am /finally/to the point on my project of starting the engine. When I > first engage the starter, voltage drops so low that my EFIS reboots. The > EFIS immediately reboots, less than 1 second later, but it takes several > seconds for the engine instruments to come back online. > > It is a 12 volt system. During engine start, the equipment is drawing > about 5 amps (other than the starter motor). I need about 9 volts to > keep the EFIS from rebooting. > > I am using figure Z-12 with very minor modifications: replaced the > ammeter shunts with hall effect sensors and rearranged the switches a > bit. You can see my modified diagram here: engine.pdf > > > What would be the simplest way to fix this issue? > > -- Art Z. > > -- > https://CheerfulCurmudgeon.com/ > > /"If I am not for myself, who is for me? And if I am only for myself, > what am I? And if not now, when?" Hillel/ ________________________________________________________________________________
Date: May 15, 2018
See my 1st answer=2E :-) Boost only woul not be a good idea; that implies a set point higher than alternator voltage=2E =81=A3Charlie=8B O n May 14, 2018, 10:07 PM, at 10:07 PM, C&K wrot e: > > >Don't you want a boost converter instead of a buck converter? >Ken > > On 14/05/2018 10:41 PM, Charlie England wrote: >> Ooh, good catch! >> >> Ch arlie >> On May 14, 2018, at 9:13 PM, Robert McCallum >> > >> wrote: > > >> Read the specifications carefully as the following statement from >> their specs might be an issue=2E >> >> "Please note: the negativ e of input and output wiring cannot be >> common ground=2E" >> >> B ob McC >> >>> ---------- Original Message ---------- >>> From: Art Zemon >>> Date: May 14, 2018 at 9:47 PM >>> >>> Charlie, >>> >>> That sounds like exactly what I need: brownout protect ion for >one >>> to two seconds=2E Is this the sort of regulator that I need? >>> >https://www=2Eebay=2Ecom/itm/DROK-High-Efficiency-Regulator -DC-4-5-30V-to-0-8-28V-12A-Buck-Converter-Const/152990560495 >>> >>> >>> -- Art Z=2E >>> >>> >>> On Mon, May 14, 2018 at 7:59 PM, Charlie Engl and < >>> ceengland7@gmail=2Ecom > wrote : >>> >>> Ebay for a 'boot/buck switching regulator' sized for your >>> needs (likely way less than$30), and an aux battery sized >the >>> same way=2E Create a 'mini' bus for the items you want to >iso late=2E >>> >>> If all you want is brownout protection, a little 2 or 3 AH >>> battery shoul be more than enough=2E >>> >>> Th ere are other commercial products available that do the >>> same th ing, but obviously you will pay more=2E >>> >>> Charlie >>> On May 14, 2018, at 7:45 PM, Art Zemon < art@zemon=2Ename >>> > wrote: >>> >>> Sebastien, >>> >>> MGL sells the AvioGuard, a DC-to-DC converting power >>> supply for isolating the avionics from the rest of the >>> airc raft system=2E It supports a backup battery=2E Cost >would >>> be $450 + the battery=2E >>> >>> I am hoping for a less expensi ve solution=2E >>> >>> -- Art Z=2E >>> >>> >>> On M on, May 14, 2018 at 7:09 PM, Sebastien < >>> cluros@gmail=2Ecom > wrote: >>> >>> Battery for th e EFIS? Does MGL make a backup battery >>> for your engine monitor? >>> >>> On Mon, May 14, 2018 at 4:51 PM, Art Zemon < >>> art@zemon=2Ename > wrote: > >> >>> =8B=8B >>> Folks , >>> >>> I am /finally/ to the point on my project of >>> starting the engine=2E When I first engage the >>> starter, voltage drops so low that my EFIS >>> reboots=2E The EFIS immediately reboots, less than >>> 1 second later, but it takes several seconds for >>> the engine instruments to come back online=2E >>> >>> It is a 12 volt system=2E During engine start, the >>> equipment is drawing about 5 amps (other than >the >>> starter motor)=2E I need about 9 volts to keep the >>> EFIS from rebooting=2E >>> >>> I am using figu re Z-12 with very minor >>> modifications: replaced the ammeter shunts with >>> hall effect sensors and rearra nged the switches >a >>> bit=2E You can see my modified diagram here: >>> engine=2Epdf >>> > >>> >>> >>> What would be the simples t way to fix this >issue? >>> >>> >>> >>> -- >>> h ttps://CheerfulCurmudgeon=2Ecom/ >>> >>> >>> /"If I am not for myself, who is for me? And if I am >only >>> for myself, what am I? And if not now, when?" Hillel/ >>> >>> >>> >>> >>> -- >>> https://CheerfulCurmudgeon=2Ec om/ >>> >>> /"If I am not for myself, who is for me? And if I am only f or >>> myself, what am I? And if not now, when?" Hillel/ >> >> > ======== orum - e many List utilities such as List Un/Subscription, Download, 7-Day Browse, Chat, FAQ, t ============= WEB FORUMS - ===== dd some info to the Matronics Email List Wiki! atronics=2Ecom =============== Contribution Web Site - -Matt Dralle, List Admin=2E ://www=2Ematronics=2Ecom/contribution ======================= ________________________________________________________________________________
Date: May 15, 2018
I would go for this Voltage Slump Eliminator first - a passive device. Switchers must be designed to generate little radiated and conducted interference - see the discussions on usb-charging. Jan de Jong On 5/15/2018 5:19 AM, Rick Beebe wrote: > > Eric Page, who's on this list, created a device to protect against > this using a large capacitor. He modified an earlier design by Eric > Jones. I bought one from him. It works great on my bench. Should be > going in the plane in the next week or so. His original email is > quoted below: > > --Rick > > > Im starting a new thread on this topic in case anyone who might be > interested missed the recent discussion, here: > > http://forum.matronics.com/viewtopic.php?t=16768062 > > To recap, Ive adapted Eric Jones design for a voltage slump > eliminator (a device to prevent EFIS/EMS brownout/reboot during engine > start) and designed a circuit board for it. The schematic (.PDF) is > here: > > http://forum.matronics.com/download.php?id=44878 > > An archive (.ZIP) containing the full design files can be downloaded > here: > > https://preview.tinyurl.com/yajod9m6 > > So far one member of the forum has expressed a desire for me to build > one of these for him, so Ive ordered a batch of circuit boards. If > anyone else wants a complete unit, please let me know so I can order > all of the components at once. You can reply to this thread or > contact me directly. > > The cost should be about $35 each, plus postage to your address. > Ill send a PayPal invoice, along with copies of my receipts, once I > know the exact amount for each device and I have them ready to mail. > > Im happy to part with bare circuit boards as well; again, for my > cost ($0.55/ea) plus postage. > > Eric > > P.S. For anyone seeing this in the future, you can contact me > directly to see if I have any circuit boards on hand. The PDF > schematic file contains a link to Digi-Key that will load a shopping > cart with all necessary components. > > > On 05/14/2018 07:51 PM, Art Zemon wrote: >> >> Folks, >> >> I am /finally/to the point on my project of starting the engine. >> When I first engage the starter, voltage drops so low that my EFIS >> reboots. The EFIS immediately reboots, less than 1 second later, but >> it takes several seconds for the engine instruments to come back online. >> >> It is a 12 volt system. During engine start, the equipment is drawing >> about 5 amps (other than the starter motor). I need about 9 volts to >> keep the EFIS from rebooting. >> >> I am using figure Z-12 with very minor modifications: replaced the >> ammeter shunts with hall effect sensors and rearranged the switches a >> bit. You can see my modified diagram here: engine.pdf >> >> >> >> What would be the simplest way to fix this issue? >> >> -- Art Z. >> >> -- >> https://CheerfulCurmudgeon.com/ >> >> /"If I am not for myself, who is for me? And if I am only for myself, >> what am I? And if not now, when?" Hillel/ > > ________________________________________________________________________________
Date: May 15, 2018
Art, I had a similar issue not sure it is related to yours, my grounding strap was connected to the engine case but I forgot to clean the paint of the case, this made for a bad ground (you could feel all the control lines to the engine heated up). Jump the negative pole of your battery to your exhaust and try again, my engine started immediately after that so I did know where to search. Again, not sure it is related to your case but an easy test. Cheers Werner On 15.05.2018 01:51, Art Zemon wrote: > > Folks, > > I am /finally/to the point on my project of starting the engine. When I > first engage the starter, voltage drops so low that my EFIS reboots. The > EFIS immediately reboots, less than 1 second later, but it takes several > seconds for the engine instruments to come back online. > ________________________________________________________________________________
Date: May 15, 2018
For a more DIY experience: DC/DC Converters | MPJA.COM | | | | | | | | | | | DC/DC Converters | MPJA.COM | | | | On Monday, May 14, 2018 10:09 PM, Robert McCallum <robert.mccallum2@sym patico.ca> wrote: Read the specifications carefully as the following statement from their specs might be an issue. "Please note: the negative of input and output wiring cannot be common gro und." Bob McC ---------- Original Message ---------- From: Art Zemon <art(at)zemon.name> Date: May 14, 2018 at 9:47 PM Charlie, That sounds like exactly what I need: brownout protection for one to two seconds. Is this the sort of regulator that I need? https://www.ebay.com/i tm/DROK-High-Efficiency-Regulator-DC-4-5-30V-to-0-8-28V-12A-Buck-Converter- Const/152990560495 -- Art Z. On Mon, May 14, 2018 at 7:59 PM, Charlie England < ceengland7(at)gmail.com> wrote: Ebay for a 'boot/buck switching regulator' sized for your needs (likely way less than$30), and an aux battery sized the same way. Create a 'mini' b us for the items you want to isolate. If all you want is brownout protection, a little 2 or 3 AH battery shoul be more than enough. There are other commercial products available that do the same thing, bu t obviously you will pay more. Charlie On May 14, 2018, at 7:45 PM, Art Zemon < art(at)zemon.name> wrote : Sebastien, MGL sells the AvioGuard, a DC-to-DC converting power supply for isolatin g the avionics from the rest of the aircraft system. It supports a backup b attery. Cost would be $450 + the battery. I am hoping for a less expensive solution. -- Art Z. On Mon, May 14, 2018 at 7:09 PM, Sebastien < cluros(at)gmail.com> wrote: Battery for the EFIS? Does MGL make a backup battery for your engine moni tor? On Mon, May 14, 2018 at 4:51 PM, Art Zemon < art(at)zemon.name> wrote: =8B=8B Folks, I am finally to the point on my project of starting the engine. When I f irst engage the starter, voltage drops so low that my EFIS reboots. The EFI S immediately reboots, less than 1 second later, but it takes several secon ds for the engine instruments to come back online. It is a 12 volt system. During engine start, the equipment is drawing ab out 5 amps (other than the starter motor). I need about 9 volts to keep the EFIS from rebooting. I am using figure Z-12 with very minor modifications: replaced the ammet er shunts with hall effect sensors and rearranged the switches a bit. You c an see my modified diagram here: engine.pdf What would be the simplest way to fix this issue? -- https://CheerfulCurmudgeon. com/ "If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel -- https://CheerfulCurmudgeon.com/ "If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel =C2- ________________________________________________________________________________
Date: May 15, 2018
Art: The simplest thing that would not cost you a penny is to: Turn the Avionics on AFTER you start the engine. But, I'm guessing that is not the way you want to go. Bob must have some reason why grounds cannot be common. Try his notes second if you do not want to change your starting procedure. Side Note: The 5 Amps you mention on draw are probably the constant current draw and not the peak draw. Just for S&G's consider the peak to be 3 times the constant. Now how would that affect your system? Side Note: What does the Battery voltage drop to when you hit the starter? Some starters post notes that if the voltage drops below 10 VDC the charging system or battery or starter connection should be looked into. The idea of a DC to DC battery backup would work but I do not see why you have to go that elaborate or anywhere that costly. A simple standby battery and a relay that is energized when the Starter Relay is energized just to supply power to the Avionics would work. If you think a mechanical relay would be too slow in transferring power you could use a solid-state relay. As a side benefit the battery could be used as emergency avionics buss power. All that would be needed is a desperate Switch to energizer the Avionics relay. Good Luck OM, Barry On Mon, May 14, 2018 at 7:51 PM, Art Zemon wrote: > =8B=8B > Folks, > > I am *finally* to the point on my project of starting the engine. When I > first engage the starter, voltage drops so low that my EFIS reboots. The > EFIS immediately reboots, less than 1 second later, but it takes several > seconds for the engine instruments to come back online. > > It is a 12 volt system. During engine start, the equipment is drawing > about 5 amps (other than the starter motor). I need about 9 volts to keep > the EFIS from rebooting. > > I am using figure Z-12 with very minor modifications: replaced the ammete r > shunts with hall effect sensors and rearranged the switches a bit. You ca n > see my modified diagram here: engine.pdf > > > What would be the simplest way to fix this issue? > > -- Art Z. > > -- > https://CheerfulCurmudgeon.com/ > > *"If I am not for myself, who is for me? And if I am only for myself, wha t > am I? And if not now, when?" Hillel* > ________________________________________________________________________________
Date: May 15, 2018
Barry, The EFIS is my engine instruments. If the EFIS is off (or rebooting) then I do not have an oil pressure gauge. -- Art Z. On Tue, May 15, 2018 at 10:44 AM, FLYaDIVE wrote: > The simplest thing that would not cost you a penny is to: Turn the > Avionics on AFTER you start the engine. > -- https://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
Date: May 15, 2018
Joe, Thanks. I think that your circuit will be perfect. I can add a small battery and it doesn't matter a bit whether or not my EFIS runs at 13.2 volts or at 12.7 volts. Cheers, -- Art Z. On Mon, May 14, 2018 at 9:10 PM, user9253 wrote: > > Here is circuit. A disadvantage is 1/2 volt drop across the Schottky > diode. > But if the aircraft electrical system voltage is 14.2 or higher, it should > be OK. > Diode part number: 747-DSA300i45NA > If the voltage drop across the diode is not desired, normally closed relay > contacts could be connected in parallel with the diode. Energize the relay > with the start push button. -- https://CheerfulCurmudgeon.com/ *"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel* ________________________________________________________________________________
Date: May 15, 2018
AHHhhhhh Got Ya! Art! Yea, you are right... Get the EFIS to boot and stay Up and Running! You got me thinking Art... I am installing a E.I. CGR 30P in a certified plane, it will be having oil pressure also... I have to solve the same issue as you. Of course I'll be limited with options, I'll have to try the Direct To Battery trick with a relay. Barry On Tue, May 15, 2018 at 5:03 PM, Art Zemon wrote: > Barry, > > The EFIS is my engine instruments. If the EFIS is off (or rebooting) then > I do not have an oil pressure gauge. > > -- Art Z. > > On Tue, May 15, 2018 at 10:44 AM, FLYaDIVE wrote: > >> The simplest thing that would not cost you a penny is to: Turn the >> Avionics on AFTER you start the engine. >> > > -- > https://CheerfulCurmudgeon.com/ > > *"If I am not for myself, who is for me? And if I am only for myself, what > am I? And if not now, when?" Hillel* > ________________________________________________________________________________
Date: May 15, 2018
Joe: I like your schematic, what program are you using to draw it? Barry On Mon, May 14, 2018 at 10:10 PM, user9253 wrote: > > Here is circuit. A disadvantage is 1/2 volt drop across the Schottky > diode. > But if the aircraft electrical system voltage is 14.2 or higher, it should > be OK. > Diode part number: 747-DSA300i45NA > If the voltage drop across the diode is not desired, normally closed relay > contacts could be connected in parallel with the diode. Energize the relay > with the start push button. > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=480130#480130 > > > Attachments: > > http://forums.matronics.com//files/brownout_bat_efis_135.jpg > > ________________________________________________________________________________
Date: May 15, 2018
Art, I have noticed on a couple dual Dynon installs that while the voltage drop kicks the flight EFIS into reboot, the engine EFIS does not. I would guess this is by design. Have you asked GRT about this problem? It's possible this is something that would be worth their while to patch. On Tue, May 15, 2018, 10:21 PM Art Zemon wrote: > Joe, > > Thanks. I think that your circuit will be perfect. I can add a small > battery and it doesn't matter a bit whether or not my EFIS runs at 13.2 > volts or at 12.7 volts. > > Cheers, > -- Art Z. > > On Mon, May 14, 2018 at 9:10 PM, user9253 wrote: > >> >> Here is circuit. A disadvantage is 1/2 volt drop across the Schottky >> diode. >> But if the aircraft electrical system voltage is 14.2 or higher, it >> should be OK. >> Diode part number: 747-DSA300i45NA >> If the voltage drop across the diode is not desired, normally closed relay >> contacts could be connected in parallel with the diode. Energize the >> relay >> with the start push button. > > > -- > https://CheerfulCurmudgeon.com/ > > *"If I am not for myself, who is for me? And if I am only for myself, what > am I? And if not now, when?" Hillel* > ________________________________________________________________________________
Date: May 15, 2018
Art Further to the best electric solution you certainly will find to avoid the b rownout, a belt & suspenders solution could be to install a small oil pressu re indicator. At least that was my way to solve the same problem, before I decided to go w ith the TCW backup battery. Cheers Carlos Enviado do meu iPhone No dia 15/05/2018, =C3-s 22:03, Art Zemon escreveu: > Barry, > > The EFIS is my engine instruments. If the EFIS is off (or rebooting) then I do not have an oil pressure gauge. > > -- Art Z. > >> On Tue, May 15, 2018 at 10:44 AM, FLYaDIVE wrote: >> The simplest thing that would not cost you a penny is to: Turn the Avio nics on AFTER you start the engine. > > > -- > https://CheerfulCurmudgeon.com/ > > "If I am not for myself, who is for me? And if I am only for myself, what a m I? And if not now, when?" Hillel ________________________________________________________________________________
Date: May 15, 2018
Joe Smart circuit, but will it recharge the backup battery? Carlos No dia 15/05/2018, s 03:10, user9253 escreveu: > > Here is circuit. A disadvantage is 1/2 volt drop across the Schottky diode. > But if the aircraft electrical system voltage is 14.2 or higher, it should be OK. > Diode part number: 747-DSA300i45NA > If the voltage drop across the diode is not desired, normally closed relay > contacts could be connected in parallel with the diode. Energize the relay > with the start push button. > > -------- > Joe Gores > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=480130#480130 > > > > > Attachments: > > http://forums.matronics.com//files/brownout_bat_efis_135.jpg > > > > > > ________________________________________________________________________________
Subject: Shower of Sparks
Date: May 15, 2018
I have installed a LOM engine with a Shower of Sparks, 1. How long can I safely keep the unit on (buzzing) while testing it 2. When I turn the motor over and ground the plug to the engine what type of spark or sparks should I expect. 3. Are there any other tests that I can perform. Thanks Mike --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: May 15, 2018
Subject: Re: Shower of Sparks
Mike: To test the Shower Of Sparks - Disconnect the Starter. You can do this easily by pulling the control wire to the Starter Relay. This way you can activate the Shower Of Sparks (SOS) and LISTEN for the BUZZ and SAFELY not have to worry about a spinning prop. You can also remove the spark plug wire from each of the spark plugs. Do you want to check out the Mag and the Spark Plug wires as well as the SOS? If so here is another TRICK! Go to a automotive store and get the Clear Plastic Spark Plug test light... It has a Neon bulb inside. You hook up the test light to the wires. Re-Connect the control wire on the starter relay and CRANK AWAY. You will see a longer time duration to the spark than if there was NO SOS. And, it will be a nice bright light. Again as compared to a standard Impulse Mag. On Tue, May 15, 2018 at 8:32 PM, wrote: > > I have installed a LOM engine with a Shower of Sparks, > > 1. How long can I safely keep the unit on (buzzing) while testing it > =8BBarry - I never had a over heating problem. I would guess and eas y Minute.=8B > > 2. When I turn the motor over and ground the plug to the engine what type > of spark or sparks should I expect. > =8BBarry - A standard Blueish Spark of Longer Duration.=8B > > 3. Are there any other tests that I can perform. > =8BBarry - See above. =8BBest of Luck,=8B Barry=8B > > > Thanks > > Mike > > > --- ________________________________________________________________________________
Date: May 15, 2018
What is being used as a "shower of sparks" for the LOM engine? On Tue, May 15, 2018 at 7:32 PM, wrote: > > I have installed a LOM engine with a Shower of Sparks, > > 1. How long can I safely keep the unit on (buzzing) while testing it > > 2. When I turn the motor over and ground the plug to the engine what type > of spark or sparks should I expect. > > 3. Are there any other tests that I can perform. > > > Thanks > > Mike > > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus > > ________________________________________________________________________________
Date: May 15, 2018
The standard LOM supplied shower of sparks module that is described on one of Bob=99s Z diagrams, I have it at the hangar so cannot remember the diagram number. Thanks Mike From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of John B Sent: May 15, 2018 7:50 PM Subject: Re: AeroElectric-List: Shower of Sparks What is being used as a "shower of sparks" for the LOM engine? On Tue, May 15, 2018 at 7:32 PM, > wrote: > I have installed a LOM engine with a Shower of Sparks, 1. How long can I safely keep the unit on (buzzing) while testing it 2. When I turn the motor over and ground the plug to the engine what type of spark or sparks should I expect. 3. Are there any other tests that I can perform. Thanks Mike --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus - Electric-List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List FORUMS - eferrer" target="_blank">http://forums.matronics.com WIKI - errer" target="_blank">http://wiki.matronics.com b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: May 16, 2018
Mike, the induction vibrator (AKA starter vibrator) wired to the left Magneto start circuit oscillates at 200Hz, so it simply causes lots of sparks (at a rate of 200 per second, rather than one spark) every time a plug is fired. The 22-25 deg advance breaker is grounded in favour of the retard breaker firing at TDC to avoid kickback. Its hard to harm the starter vibrator and youd be hard pressed to see sparks at a rate of 200Hz, but the engine (especially a six) is a whole lot easier to start when the circuit is working! Stu > On 16 May 2018, at 10:32, wrote: > > > I have installed a LOM engine with a Shower of Sparks, > > 1. How long can I safely keep the unit on (buzzing) while testing it > > 2. When I turn the motor over and ground the plug to the engine what type of spark or sparks should I expect. > > 3. Are there any other tests that I can perform. > > > Thanks > > Mike > > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus > > > > > ________________________________________________________________________________
Date: May 16, 2018
Barry, I used a program called Express.sch It is free and can be downloaded here: https://www.expresspcb.com The program has two parts, the schematic part and the circuit board part. Use teh schematic part: express.sch After drawing your diagram, click FILE, EXPORT SCHEMATIC IMAGE. The only choice for saving is as a BMP file. Open the bmp file with "PAINT", a program that is built into all versions of Windows. Crop the picture and then save as a JPG file. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480173#480173 ________________________________________________________________________________
Date: May 16, 2018
Carlos, I think the aux battery will be recharged. Normally it will only be used for a few seconds during engine cranking, so it will run down very little. A Schottky diode will drop 0.4 - 0.5 volts when conducting 5 amps. If the aircraft electrical system operates at 14.2 volts, then 14.2 - 0.5 = 13.7 volts. That is enough to recharge a battery, albeit slowly. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480174#480174 ________________________________________________________________________________
Date: May 16, 2018
Art, The Schottky diode 747-DSA300i45NA that I mentioned earlier is really overkill for this application. Smaller Schottky diodes are available for less than $1, although not as robust. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480175#480175 ________________________________________________________________________________
Date: May 16, 2018
Below is an untried circuit for someone who likes to experiment. Instead of using a heavy lead acid battery, it uses two flashlight batteries in series. Depending on the load, and considering that the batteries will only be used for a few seconds at a time, size AA or C or D can be tried. The alkaline batteries will add 3 volts to the aircraft main battery voltage during engine cranking. The diode prevents the alkaline batteries from being shorted out. The diode also keeps the load energized for the few milliseconds while the relay contacts are in transition. The normally open relay contacts connect the alkaline batteries during engine start. After starting the engine, the normally closed relay contacts short out the diode during normal operation to give full voltage to the load. If the relay coil or N.C. contacts fail, the EFIS will still get power through the diode. Before I get flamed, I am not necessarily recommending this circuit, just offering it to experimenters. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480176#480176 Attachments: http://forums.matronics.com//files/brownout_alkaline_bat_112.jpg ________________________________________________________________________________
Date: May 16, 2018
Joe: Thank you very much for the information. I'll give it a try. I hope it is as intuitive as much as I am software challenged ;-) Barry On Wed, May 16, 2018 at 11:08 AM, user9253 wrote: > > Barry, > I used a program called Express.sch > It is free and can be downloaded here: > https://www.expresspcb.com > The program has two parts, the schematic part and the circuit board part. > Use teh schematic part: express.sch > After drawing your diagram, click FILE, EXPORT SCHEMATIC IMAGE. > The only choice for saving is as a BMP file. > Open the bmp file with "PAINT", a program that is built into all versions > of Windows. > Crop the picture and then save as a JPG file. > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=480173#480173 > > ________________________________________________________________________________
Date: May 16, 2018
What would be wrong with throwing a big capacity directly across the power and ground as close to the EIS as you can? You gave 5A as the current draw for the e-bus, I doubt the EIS is drawing m ore than one.=C2- The cap will need to be large enough to make up the dif ference between the voltage required and where it drops to during the 15 se conds of cranking.=C2- Part of the caps electrons will back feed to the s tarter, but that path has the resistance of a lot of connections and thinne r wires.=C2- Plus, it won't be a direct short to ground.=C2- It has to compete with another source pumping electrons into the circuit (the battery ).=C2- The cap will get topped off as soon as you stop cranking. Just make sure to use a slow blow fuse and be done with it. On Wednesday, May 16, 2018 12:09 PM, FLYaDIVE wrot e: Joe: Thank you very much for the information. I'll give it a try.=C2- I hope it is as intuitive as much as I am softwar e challenged ;-) Barry On Wed, May 16, 2018 at 11:08 AM, user9253 wrote: Barry, I used a program called Express.sch It is free and can be downloaded here: https://www.expresspcb.com The program has two parts, the schematic part and the circuit board part. Use teh schematic part: express.sch After drawing your diagram, click FILE, EXPORT SCHEMATIC IMAGE. The only choice for saving is as a BMP file. Open the bmp file with "PAINT", a program that is built into all versions o f Windows. Crop the picture and then save as a JPG file. -------- Joe Gores Read this topic online here: http://forums.matronics.com/ viewtopic.php?p=480173#480173 ==== ==================== ========== = - Electric-List" rel="noreferrer" target="_blank">http://www.matronics.co m/ Navigator?AeroElectric-List ==== ==================== ========== = FORUMS - eferrer" target="_blank">http://forums.matronics.com ==== ==================== ========== = WIKI - errer" target="_blank">http://wiki.matronics.com ==== ==================== ========== = b Site - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/ contribution ==== ==================== ========== = ________________________________________________________________________________
Date: May 16, 2018
The little device by Eric Jones & Eric Page does this in an organized manner and with inexpensive parts. No switching, no batteries. Give it a try. Jan de Jong On 5/16/2018 8:05 PM, Ernest Christley wrote: > What would be wrong with throwing a big capacity directly across the > power and ground as close to the EIS as you can? > > You gave 5A as the current draw for the e-bus, I doubt the EIS is > drawing more than one. The cap will need to be large enough to make > up the difference between the voltage required and where it drops to > during the 15 seconds of cranking. Part of the caps electrons will > back feed to the starter, but that path has the resistance of a lot of > connections and thinner wires. Plus, it won't be a direct short to > ground. It has to compete with another source pumping electrons into > the circuit (the battery). The cap will get topped off as soon as you > stop cranking. > > Just make sure to use a slow blow fuse and be done with it. > > > On Wednesday, May 16, 2018 12:09 PM, FLYaDIVE wrote: > > > Joe: > > Thank you very much for the information. > > I'll give it a try. I hope it is as intuitive as much as I am > software challenged ;-) > > Barry > > > On Wed, May 16, 2018 at 11:08 AM, user9253 > wrote: > > > > > Barry, > I used a program called Express.sch > It is free and can be downloaded here: > https://www.expresspcb.com > The program has two parts, the schematic part and the circuit > board part. > Use teh schematic part: express.sch > After drawing your diagram, click FILE, EXPORT SCHEMATIC IMAGE. > The only choice for saving is as a BMP file. > Open the bmp file with "PAINT", a program that is built into all > versions of Windows. > Crop the picture and then save as a JPG file. > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/ viewtopic.php?p=480173#480173 > <http://forums.matronics.com/viewtopic.php?p=480173#480173> > > > ==== ============================== = > - > Electric-List" rel="noreferrer" > target="_blank">http://www.matronics.com/ Navigator?AeroElectric-List > ==== ============================== = > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > ==== ============================== = > WIKI - > errer" target="_blank">http://wiki.matronics.com > ==== ============================== = > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" target="_blank">http://www.matronics.com/ > contribution > ==== ============================== = > > ________________________________________________________________________________
Subject: Re: Starting the Engine Reboots the EFIS
Date: May 16, 2018
> What would be wrong with throwing a big capacity directly across the power and ground as close to the EIS as you can? That solution sounds reasonable in theory. The problem is that the starter motor would quickly drain the capacitor without a diode to block reverse current. Another problem is that one big capacitor rated at 15 volts or more would be impractically humongous. The solution is to use several capacitors, each rated at less voltage. Eric Jones & Eric Page have already done the engineering. Read this thread about the Deslumpifier: http://forum.matronics.com/viewtopic.php?p=477147&sid'd0d83508c5b8d07bf0ea2643e41201 -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480181#480181 ________________________________________________________________________________
Date: May 16, 2018
What Tim and others have suggested, TCWTech stuff, will fix it. I used the power stabilizer to fix this problem in my installation - I have (3) EFIS units. On 5/14/2018 10:13 PM, Tim Olson wrote: > > Check out TCWTechs stuff. They have both backup batteries, and > a power stabilizer that they offer that would do the trick. > > http://www.tcwtech.com/ > > > Tim > > > On 5/14/2018 7:38 PM, Art Zemon wrote: >> Sebastien, >> >> MGL sells the AvioGuard, a DC-to-DC converting power supply for >> isolating the avionics from the rest of the aircraft system. It >> supports a backup battery. Cost would be $450 + the battery. >> >> I am hoping for a less expensive solution. >> >> -- Art Z. >> >> >> On Mon, May 14, 2018 at 7:09 PM, Sebastien > > wrote: >> >> Battery for the EFIS? Does MGL make a backup battery for your engine >> monitor? >> >> On Mon, May 14, 2018 at 4:51 PM, Art Zemon > > wrote: >> >> >> Folks, >> >> I am /finally/to the point on my project of starting the >> engine. When I first engage the starter, voltage drops so low >> that my EFIS reboots. The EFIS immediately reboots, less than 1 >> second later, but it takes several seconds for the engine >> instruments to come back online. >> >> It is a 12 volt system. During engine start, the equipment is >> drawing about 5 amps (other than the starter motor). I need >> about 9 volts to keep the EFIS from rebooting. >> >> I am using figure Z-12 with very minor modifications: replaced >> the ammeter shunts with hall effect sensors and rearranged the >> switches a bit. You can see my modified diagram here: engine.pdf >> >> >> What would be the simplest way to fix this issue? >> >> >> >> -- >> https://CheerfulCurmudgeon.com/ >> >> /"If I am not for myself, who is for me? And if I am only for myself, >> what am I? And if not now, when?" Hillel/ > > 999 --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: May 17, 2018
The 2 attached (pilfered) figures aim to show when the EFIS reboot occurs in the engine start sequence. The deep voltage drawdown where the EFIS reboots is resolved as soon as the starter motor picks up speed. The "deslumping" only needs to hold up the voltage for a few hundred ms. Jan de Jong ________________________________________________________________________________
Date: May 17, 2018
Jan so would a relay then be fast enough to catch the lump? Looking at the figures it would appear that the big spike is of very short duration. Best... Bob Verwey 082 331 2727 On 17 May 2018 at 09:59, Jan de Jong wrote: > The 2 attached (pilfered) figures aim to show when the EFIS reboot occurs > in the engine start sequence. > The deep voltage drawdown where the EFIS reboots is resolved as soon as > the starter motor picks up speed. > The "deslumping" only needs to hold up the voltage for a few hundred ms. > > Jan de Jong > ________________________________________________________________________________
Date: May 17, 2018
It is a race with the relay and solenoid that enables the starter motor. A small relay will win I would think. But I would prefer the "deslumpifier" of Eric Jones that Eric Page elaborated. No moving parts, no active electronics, no batteries. Jan de Jong On 5/17/2018 10:21 AM, Bob Verwey wrote: > Jan so would a relay then be fast enough to catch the lump? Looking at > the figures it would appear that the big spike is of very short duration. > ________________________________________________________________________________
Date: May 17, 2018
Hi Jan, Which eric jones product are you talking about? I've been all over his site http://www.periheliondesign.com/ and can't find anything. I just bought 4 a123 18650 lifepo4 batteries and a battery holder I plan to wire into my EIS and EFIS, but if there is a more elegant solution from Eric I'm interested. Mickey Coggins On Thu, 17 May 2018 at 11:20, Jan de Jong wrote: > It is a race with the relay and solenoid that enables the starter motor. A > small relay will win I would think. > But I would prefer the "deslumpifier" of Eric Jones that Eric Page > elaborated. No moving parts, no active electronics, no batteries. > > Jan de Jong > > On 5/17/2018 10:21 AM, Bob Verwey wrote: > > Jan so would a relay then be fast enough to catch the lump? Looking at the > figures it would appear that the big spike is of very short duration. > > ________________________________________________________________________________
Date: May 17, 2018
Even though Eric Jones designed and built a prototype, he does not sell the deslumpifier. Last I heard, he does not intend to either. Maybe he would if the demand was big enough. Eric Page built a few that had more capacitance. He sold them to AeroElectric members at cost for the parts. That was really nice of him and he did a professional job. He probably has the schematic and parts list and gerber files that are necessary to order the PC boards. With that information, a person could order the parts and make their own deslumpifier. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480215#480215 ________________________________________________________________________________
Date: May 17, 2018
I do still have circuit boards available for this project. Ordinarily Id be happy to assemble another one, but Im just starting to build a house and my free time is extremely limited. If you review the first couple of posts in this thread... http://forum.matronics.com/viewtopic.php?p=477147 ...youll find all the information about it. A link to a Digi-Key shopping cart populated with all of the required components is given on the schematic diagram. A few notes: - This is a brownout/reboot preventer only; its not a source of emergency power for avionics. For that, the TCW units or a similar DIY setup are a better choice. - Youll need a fairly stout soldering iron to successfully solder the large diodes. A soldering gun would be a good idea if you have one. All other components are solderable with normal techniques. The diodes are installed with their ring marking (cathode) facing up. - Its a good idea to apply some sort of adhesive around the base of the capacitors and large resistor heatsink to provide mechanical support. I used Shoe Goo on the boards that I assembled. - Id recommend using the plastic box as a mounting base for the circuit board and leave the lid off. This will help to keep things cool while the capacitors are charging. Let me know if you want a PCB. Ill sell what I have left at my cost: $0.55 ea. + postage and PayPal fee. Ill include the M2.5 screws needed to mount it in the box. Eric Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480216#480216 ________________________________________________________________________________
Date: May 17, 2018
Thank you very much for the help, The spark plug test light worked like a charm, thanks for the good idea Keep well Mike From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectr ic-list-server(at)matronics.com] On Behalf Of FLYaDIVE Sent: May 15, 2018 6:05 PM Subject: Re: AeroElectric-List: Shower of Sparks Mike: To test the Shower Of Sparks - Disconnect the Starter. You can do this easily by pulling the control wire to the Starter Relay. This way you can activate the Shower Of Sparks (SOS) and LISTEN for the BUZ Z and SAFELY not have to worry about a spinning prop. You can also remove the spark plug wire from each of the spark plugs. Do you want to check out the Mag and the Spark Plug wires as well as the SO S? If so here is another TRICK! Go to a automotive store and get the Clear Plastic Spark Plug test light... It has a Neon bulb inside. You hook up the test light to the wires. Re-Connect the control wire on the starter relay and CRANK AWAY. You will see a longer time duration to the spark than if there was NO SOS. And, it will be a nice bright light. Again as compared to a standard Impuls e Mag. On Tue, May 15, 2018 at 8:32 PM, > wrote: ision499.com> > I have installed a LOM engine with a Shower of Sparks, 1. How long can I safely keep the unit on (buzzing) while testing it =8BBarry - I never had a over heating problem. I would guess and eas y Minute.=8B 2. When I turn the motor over and ground the plug to the engine what type o f spark or sparks should I expect. =8BBarry - A standard Blueish Spark of Longer Duration.=8B 3. Are there any other tests that I can perform. =8BBarry - See above. =8BBest of Luck,=8B Barry=8B Thanks Mike --- --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: May 17, 2018
Mike: You are quite welcome. Did you notice how long the spark lasted? Way longer than just a Mag spark. Easy test. Barry On Thu, May 17, 2018 at 11:19 PM, wrote: > Thank you very much for the help, > > > The spark plug test light worked like a charm, thanks for the good idea > > > Keep well > > > Mike > > > *From:* owner-aeroelectric-list-server(at)matronics.com [mailto: > owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of *FLYaDIVE > *Sent:* May 15, 2018 6:05 PM > *To:* aeroelectric-list(at)matronics.com > *Subject:* Re: AeroElectric-List: Shower of Sparks > > > Mike: > > > To test the Shower Of Sparks - > > Disconnect the Starter. > > You can do this easily by pulling the control wire to the Starter Relay. > > This way you can activate the Shower Of Sparks (SOS) and LISTEN for the > BUZZ and SAFELY not have to worry about a spinning prop. > > You can also remove the spark plug wire from each of the spark plugs. > > Do you want to check out the Mag and the Spark Plug wires as well as the > SOS? > > If so here is another TRICK! > > Go to a automotive store and get the Clear Plastic Spark Plug test > light... It has a Neon bulb inside. > > You hook up the test light to the wires. > > Re-Connect the control wire on the starter relay and CRANK AWAY. > > You will see a longer time duration to the spark than if there was NO SO S. > > And, it will be a nice bright light. Again as compared to a standard > Impulse Mag. > > > On Tue, May 15, 2018 at 8:32 PM, wrote: > > > I have installed a LOM engine with a Shower of Sparks, > > 1. How long can I safely keep the unit on (buzzing) while testing it > > =8BBarry - I never had a over heating problem. I would guess and e asy > Minute.=8B > > > 2. When I turn the motor over and ground the plug to the engine what type > of spark or sparks should I expect. > > =8BBarry - A standard Blueish Spark of Longer Duration.=8B > > > 3. Are there any other tests that I can perform. > > =8BBarry - See above. > > > =8BBest of Luck,=8B > > > Barry=8B > > > Thanks > > Mike > > > --- > > > Virus-free. > www.avast.com > > <#m_-3200137601015323261_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> > ________________________________________________________________________________
Subject: 1-10 (2-10) toggle switch
Date: May 18, 2018
Hi Guys I have a couple of (S700 series) toggle switches designated 1-10, from using my volt/ohm meter it appears to operate as a 2-10 - is this correct - in the AeroElectric Connection (my edition anyway) list of S700 toggle switches, it does not mention a 1-10 anywhere Clarification welcome Regards John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480223#480223 ________________________________________________________________________________
Date: May 18, 2018
I am glad to see that there is great interest in the deslumpifier, and that Eric Page has made these available. I don't intent to sell these. Too many other things to do. BTW: There are BIG Supercaps that help start diesel engines in big trucks, and could in airplanes, too. So it really is industrial technology. Eric M. Jones PerihelionDesign.com -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480224#480224 ________________________________________________________________________________
Date: May 18, 2018
Subject: Re: 1-10 (2-10) toggle switch
At 07:58 AM 5/18/2018, you wrote: > > >Hi Guys > >I have a couple of (S700 series) toggle switches designated 1-10, >from using my volt/ohm meter it appears to operate as a 2-10 - is >this correct - in the AeroElectric Connection (my edition anyway) >list of S700 toggle switches, it does not mention a 1-10 anywhere The "1" indicates a SINGLE pole switch that will have only 3 terminals. "2" is a DOUBLE pole device with 6 terminals. Emacs! Emacs! The dash-10 functionality REQUIRES two poles, hence there can be no such thing as a 1-10 switch. I suspect that your switch has been marked in error. Bob . . . ________________________________________________________________________________
Subject: Re: VHF antenna in the tail
Date: May 20, 2018
/Le 23/12/2017 01:26, Robert L. Nuckolls, III a crit: / > / > Can you describe the physical configuration of > the vertical fin vis-a-vis the empennage? Is > the vertical fin detachable? > > I presume the antenna, once installed, will > forever more be inaccessible for tweeking? / Hi Bob and all, Reviving the antenna-in-tail subject, as the project fuselage is now assembled. Bob mentionned a promising "bazooka" configuration for the antenna, as the tail is too narrow to allow for a regular ground plane. Here are some answers to your questions : The entire fuselage is carbon. The vertical fin is integral with the fuselage but is made of glass for the installation of the antenna. The fin height is ~ 0.9 m (35") while the carbon tail at the base is only 0.18 m (7") wide. The base of the antenna will be accessible via the tail cone aperture, and crawling into the fuselage will permit limited access. I was considering installing the radiating element in a plastic tube in the fin, so that the antenna may be easily inserted and removed. Any suggestions as to how to devise a reasonably efficient comm antenna in the tail ? Thanks in advance, -- Best regards, Gilles http://contrails.free.fr http://lapierre.skunkworks.free.fr ________________________________________________________________________________
Date: May 20, 2018
Giles: You solved half of the antenna issue by making the vertical stab out of fiberglass. The second issue is: What is the Torque Tube of the rudder made out of? If it is aluminum then you have a Blanketing issue as it will mess up the radiation pattern of the antenna. The third issue is you will need at least a 1/4 wave length Ground-plane made out of a conductive material... Aluminum or copper. >From the looks of the empennage you do not have enough area to have a ground-plane. So, what are your options: The most logical will also probably be the easiest - Install two home-brew antennas in the tips of the Horizontal Sab or the tips of the Elevator and co-phase them. Of course they will be horizontally phased as compared to most other antennas out there but, that is a minor inconvenience. Consider ALL those bent 1/4 wave belly mounted antennas that are bent over - - - they still work. Here is a simple co-phased feed line: http://www.jonfinley.com/hobbies/harness.html I would use BNC connectors as apposed to PL & SO connectors. I also totally dislike CRIMP connectors. The solder ones work better and do not cut into the COAX - - EVER! Just work out the math for the frequency you wish to use. Barry On Sun, May 20, 2018 at 7:43 AM, GTH wrote: > > *Le 23/12/2017 =C3- 01:26, Robert L. Nuckolls, III a =C3=A9crit : * > > > * Can you describe the physical configuration of the vertical fin > vis-a-vis the empennage? Is the vertical fin detachable? I presume th e > antenna, once installed, will forever more be inaccessible for tweeking ? > * > > > Hi Bob and all, > > Reviving the antenna-in-tail subject, as the project fuselage is now > assembled. > > Bob mentionned a promising "bazooka" configuration for the antenna, as th e > tail is too narrow to allow for a regular ground plane. > > Here are some answers to your questions : > The entire fuselage is carbon. The vertical fin is integral with the > fuselage but is made of glass for the installation of the antenna. > The fin height is ~ 0.9 m (35") while the carbon tail at the base is only > 0.18 m (7") wide. > > > The base of the antenna will be accessible via the tail cone aperture, an d > crawling into the fuselage will permit limited access. > I was considering installing the radiating element in a plastic tube in > the fin, so that the antenna may be easily inserted and removed. > > Any suggestions as to how to devise a reasonably efficient comm antenna i n > the tail ? > > Thanks in advance, > > > -- > Best regards, > Gilles > http://contrails.free.fr > http://lapierre.skunkworks.free.fr > ________________________________________________________________________________
Date: May 20, 2018
Here is a link to Jim Wier of RST Engineering information of aircraft antennas in fiberglass airplanes and fiberglass airplane components. http://www.rstengineering.com/rst/products/plasticplaneantenna/plasticplane antenna.htm I've heard Jim talk st Oshkosh numerous times. Tim Meyer On Sun, May 20, 2018 at 6:55 AM GTH wrote: > > *Le 23/12/2017 =C3- 01:26, Robert L. Nuckolls, III a =C3=A9crit : * > > > * Can you describe the physical configuration of the vertical fin > vis-a-vis the empennage? Is the vertical fin detachable? I presume th e > antenna, once installed, will forever more be inaccessible for tweeking ? > * > > > Hi Bob and all, > > Reviving the antenna-in-tail subject, as the project fuselage is now > assembled. > > Bob mentionned a promising "bazooka" configuration for the antenna, as th e > tail is too narrow to allow for a regular ground plane. > > Here are some answers to your questions : > The entire fuselage is carbon. The vertical fin is integral with the > fuselage but is made of glass for the installation of the antenna. > The fin height is ~ 0.9 m (35") while the carbon tail at the base is only > 0.18 m (7") wide. > > > The base of the antenna will be accessible via the tail cone aperture, an d > crawling into the fuselage will permit limited access. > I was considering installing the radiating element in a plastic tube in > the fin, so that the antenna may be easily inserted and removed. > > Any suggestions as to how to devise a reasonably efficient comm antenna i n > the tail ? > > Thanks in advance, > > > -- > Best regards, > Gilles > http://contrails.free.fr > http://lapierre.skunkworks.free.fr > ________________________________________________________________________________
Date: May 20, 2018
I would try a 1/4 wave antenna with ground plane. Of course the small diameter tail is not the ideal shape and size for a ground plane. But it might be good enough. Use 4 or 6 copper tape radials (or aluminum strips) glued to the inside of the tail cone. Or it might be easier to install a thin sheet of aluminum glued to the inside surface of the tail cone. If that does not work out, then try the bazooka antenna. No antenna is perfect. Be satisfied with good enough. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480242#480242 ________________________________________________________________________________
Subject: Radio or Television Tower Buzz
Date: May 20, 2018
When flying in the vicinity of radio or TV towers, I get a constant buzz or static over the radio. Sometimes I can hear the conversation or music from the station, but just barely. It seems to start when I'm within a 1/2 to 1/4 mile from a tower. Anyone else have this type of issue or resolved this type of issue? -------- Mike Bentley Joplin, MO N5498B Kitfox Model 4-1200 Jabiru 2200 #438 Rotec Aerosport LCH Heads Prince Prop (64 x 34) Ellison EFS-2 Throttle Body Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480244#480244 ________________________________________________________________________________
Date: May 20, 2018
Giles, There are a number of comm antenna solution that do not require a ground plane. They are produced by Archer and by Advanced Aircraft Electronics. These are center-tap, full-wave antennas of various styles, shapes and prices. See =94 http://www.aircraftspruce.com/search/search.php?cache=75660d9834ea34b12f c9146878e6443b&filter=&perpage=all&pageno=1 <http://www.aircraftspruce.com/search/search.php?cache=75660d9834ea34b12 fc9146878e6443b&filter=&perpage=all&pageno=1> They are hidden amongst the various other antennas on the page. In addition there are plans available on the net to craft your own copper tape/strip full wave antennas that could be used on the stern post. I have used both the AAE and Archer antennas in composite aircraft and I have built a copper strip antenna for use with a base radio all with excellent results. Blue skies & tailwinds, Bob Borger Europa XS Tri, Rotax 914, Airmaster C/S Prop (100 hrs). Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP, Hercules Prop. 3705 Lynchburg Dr. Corinth, TX 76208-5331 Cel: 817-992-1117 rlborger(at)mac.com On May 20, 2018, at 6:43 AM, GTH wrote: Le 23/12/2017 =C3- 01:26, Robert L. Nuckolls, III a =C3=A9crit : > > Can you describe the physical configuration of > the vertical fin vis-a-vis the empennage? Is > the vertical fin detachable? > > I presume the antenna, once installed, will > forever more be inaccessible for tweeking? Hi Bob and all, Reviving the antenna-in-tail subject, as the project fuselage is now assembled. Bob mentionned a promising "bazooka" configuration for the antenna, as the tail is too narrow to allow for a regular ground plane. Here are some answers to your questions : The entire fuselage is carbon. The vertical fin is integral with the fuselage but is made of glass for the installation of the antenna. The fin height is ~ 0.9 m (35") while the carbon tail at the base is only 0.18 m (7") wide. The base of the antenna will be accessible via the tail cone aperture, and crawling into the fuselage will permit limited access. I was considering installing the radiating element in a plastic tube in the fin, so that the antenna may be easily inserted and removed. Any suggestions as to how to devise a reasonably efficient comm antenna in the tail ? Thanks in advance, -- Best regards, Gilles http://contrails.free.fr http://lapierre.skunkworks.free.fr ________________________________________________________________________________
Date: May 20, 2018
What is happening is that the high power from the towers is exciting one of the oscillators in one of your radios. What is most common, especially with older 121.5 ELTs is for their transmit oscillator to be activated by the high power RF from the towers, generating a weak white noise signal that breaks squelch on your com radio. I used to have that problem with a previous aircraft, where there are about 15 high power towers on a mountain a few miles south of the Phoenix Class B and in line with the VFR transition through the Class B. Communications with approach control while flying that transition would become very difficult. Newer 121.5 ELTs and 406 ELTs are better shielded for that. Also, moving a com antenna from top of fuselage to belly can help isolate the ELT from the com antenna. On 5/20/2018 8:38 AM, mike>bentley wrote: > --> Avionics-List message posted by: "mike>bentley" > > When flying in the vicinity of radio or TV towers, I get a constant buzz or static over the radio. Sometimes I can hear the conversation or music from the station, but just barely. It seems to start when I'm within a 1/2 to 1/4 mile from a tower. > > Anyone else have this type of issue or resolved this type of issue? > > -------- > Mike Bentley > Joplin, MO > N5498B > Kitfox Model 4-1200 > Jabiru 2200 #438 > Rotec Aerosport LCH Heads > Prince Prop (64 x 34) > Ellison EFS-2 Throttle Body > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=480245#480245 > > > > > > > > > ________________________________________________________________________________
Subject: Re: Radio or Television Tower Buzz
Date: May 20, 2018
Thanks Kelli, I have a 406mhz elt with the antenna mounted inside the fuselage and comm antenna mounted on top of the fuselage. The elt antenna is approximately 18" below and 12" forward of the comm antenna. The elt antenna is much easier to relocate than the comm. Would moving the elt antenna farther away help? -------- Mike Bentley Joplin, MO N5498B Kitfox Model 4-1200 Jabiru 2200 #438 Rotec Aerosport LCH Heads Prince Prop (64 x 34) Ellison EFS-2 Throttle Body Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480249#480249 ________________________________________________________________________________
Date: May 20, 2018
On 5/20/2018 10:33 AM, mike>bentley wrote: > > When flying in the vicinity of radio or TV towers, I get a constant buzz or static over the radio. Sometimes I can hear the conversation or music from the station, but just barely. It seems to start when I'm within a 1/2 to 1/4 mile from a tower. > > Anyone else have this type of issue or resolved this type of issue? > > -------- > Mike Bentley > Joplin, MO > N5498B > Kitfox Model 4-1200 > Jabiru 2200 #438 > Rotec Aerosport LCH Heads > Prince Prop (64 x 34) > Ellison EFS-2 Throttle Body Flying within 1/4 mile of a tower? My solution would be the He Haw (TV show, for uninitiated) solution: 'If it hurts when you do that, don't do that!' Especially in the case of towers, just don't do that. Charlie (Your issue is not an uncommon problem within a few miles of high power transmitters, as someone else has said.) --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: May 20, 2018
We have several towers in the vicinity of our airport. It can be occasionally annoying depending on the direction you're going to or coming from. -------- Mike Bentley Joplin, MO N5498B Kitfox Model 4-1200 Jabiru 2200 #438 Rotec Aerosport LCH Heads Prince Prop (64 x 34) Ellison EFS-2 Throttle Body Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480251#480251 ________________________________________________________________________________
Date: May 20, 2018
Mike: Very Interesting.... Our plane radios transmit and receive in AM. TV video is AM while their audio is FM. AM land based radio shows are at a frequency well, well below our aviation frequencies. So... Something else must be happening if you are receiving and Hearing Voices. I can understand static and buzzing, just not the voices? Start Simple and work up from their. Simple: Check the GROUNDS on your radios and antennas. You CANNOT check Grounds by LQQKing at them. You MUST open the connection, Clean the connection and replace or ADD (if missing) an Internal Star Washer, then Tighten the connection. Getting a bit more complicated you can build a Band Pass Filter. This would work if the interference was a few harmonics away from from our frequencies. If you can: Drive to the radio/TV stations and bring a Hand Held aviation radio and see if you can hear them when right next to them. You - May even talk to the station engineer. And as a last resort, report the station to the FCC. BUT Only if your test with the Hand Held proves true. Barry On Sun, May 20, 2018 at 11:33 AM, mike>bentley wrote: > mikeeeb(at)gmail.com> > > When flying in the vicinity of radio or TV towers, I get a constant buzz > or static over the radio. Sometimes I can hear the conversation or music > from the station, but just barely. It seems to start when I'm within a 1/2 > to 1/4 mile from a tower. > > Anyone else have this type of issue or resolved this type of issue? > > -------- > Mike Bentley > Joplin, MO > N5498B > Kitfox Model 4-1200 > Jabiru 2200 #438 > Rotec Aerosport LCH Heads > Prince Prop (64 x 34) > Ellison EFS-2 Throttle Body > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=480244#480244 > > ________________________________________________________________________________
Date: May 20, 2018
I don't know if you would gain improvement or not, but generally I like to have at least 2 ft between com antennas, more if I can get it. The ELT is in same frequency spectrum as com, so interaction is mostly a function of distance. Before doing anything, the easy test is to simply disconnect the antenna cable from the ELT and go fly near the offending towers. You will know right away if the problem is reduced or not. Your com radio(s) may be interfered with independent of the ELT. Most broadcast towers are close in frequency, either below or above the com frequency band. On 5/20/2018 9:15 AM, mike>bentley wrote: > > Thanks Kelly, > > I have a 406mhz elt with the antenna mounted inside the fuselage and comm antenna mounted on top of the fuselage. The elt antenna is approximately 18" below and 12" forward of the comm antenna. The elt antenna is much easier to relocate than the comm. Would moving the elt antenna farther away help? > > -------- > Mike Bentley > Joplin, MO > N5498B > Kitfox Model 4-1200 > Jabiru 2200 #438 > Rotec Aerosport LCH Heads > Prince Prop (64 x 34) > Ellison EFS-2 Throttle Body > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=480249#480249 > > > > > > > > > ________________________________________________________________________________
Date: May 20, 2018
Subject: New toy . . .
For those of you who suffer from quantitative OCD like I do, there is a class of measurement tool that has trickled down in price to where us po' folk can afford them. GPS disciplined signal sources can exploit the extra-ordinary time-keeping features of the GPS system to produce accurate reference signals with accuracies/stabilities out to a buckets-full-of-zeros. https://goo.gl/B4hqTm I've been eyeing these for several years but finally yielded to temptation with this puppy on eBay https://goo.gl/zVviDZ With this device driving the 10MHz reference port on my 40 year old HP signal generator, proving legality of the radios on our emergency services hand-helds and trucks is a no-brainer. You may have to mount an antenna outside your facility with good sky view . . . beyond that, these things are plug-n-play. Bob . . . ________________________________________________________________________________
Date: May 20, 2018
A >The base of the antenna will be accessible via the tail cone >aperture, and crawling into the fuselage will permit limited access. >I was considering installing the radiating element in a plastic tube >in the fin, so that the antenna may be easily inserted and removed. > >Any suggestions as to how to devise a reasonably efficient comm >antenna in the tail ? Assuming my mental image of your configuration is accurate, consider the following. Terminating the antenna coax in a BNC cable connector. Then use a BNC chassis connector to make the mechanical transition to the antenna and "ground planes". The radiating portion of the antenna obviously needs to extend up the tube. I'd go for a chunk of RG400 with the outer jacket and removed from about 2" of the 'antenna' segment. http://www.aeroelectric.com/articles/Antennas/TailCone_Antenna/ Push shields back hard exposing center conductor http://www.aeroelectric.com/articles/Antennas/TailCone_Antenna/ Cut off center conductor http://www.aeroelectric.com/articles/Antennas/TailCone_Antenna/ Stretch the braids out and 'tin' the last 1/4" or so with solder. http://www.aeroelectric.com/articles/Antennas/TailCone_Antenna/ Mount chassis BNC connector to 'ground plane'. Suggest copper sheet, 1/2" minimum to as wide as you can fit into the tail cone. The chassis connector can be spot-soldered to copper sheet. http://www.aeroelectric.com/articles/Antennas/TailCone_Antenna/ Repeat on opposite side . . . http://www.aeroelectric.com/articles/Antennas/TailCone_Antenna/ If copper sheet is not readily available, aluminum can be used. If the aluminum option is selected, use the star-washer supplied with the connector to improve electrical interface with the ground-plane. The 'radials' are 1/4-wave (24") extending forward on each side of tailcone. http://www.aeroelectric.com/articles/Antennas/TailCone_Antenna/ If you have access to an antenna analyzer (MFJ259 or similar), you can survey the installed antenna for resonance. I suspect you'll find that it resonates a bit low in frequency due to proximity effects of the rudder post. Trim antenna 1/4" at a time until SWR minimizes at 126.5 MHz. If post installation evaluation is impractical or impossible, then shorten the antenna by about 5% . . . make it 23 inches. Does this look 'doable' on your project? The photos above have been posted at . . . https://goo.gl/9NaAK1 Bob . . . ________________________________________________________________________________
Date: May 20, 2018
Bob, it is not clear from the photo, but is the 23" antenna braid soldered to the center pin on the BNC chassis connector? I assume coax is used for the radiating element instead of a wire because the coax is fatter and will give a wider bandwidth than, say, a 14 awg wire. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480260#480260 ________________________________________________________________________________
Date: May 20, 2018
At 03:30 PM 5/20/2018, you wrote: > >Bob, it is not clear from the photo, but is the 23" antenna braid >soldered to the center pin on the BNC chassis connector? Yes. The center conductor in the radiator is not a participant in the design. > I assume coax is used for the radiating element instead of a wire > because the coax is fatter and will give a wider bandwidth than, > say, a 14 awg wire. The design goal is to make a flexure-resistant connection between the connector and the radiator. The dual-shield configuration on RG400 offers an attractive solution for achieving this goal . . . leaving it 1/4-wave long finishes out the radiator with a single soldered joint. Bob . . . ________________________________________________________________________________
Subject: VHF antenna in the tail
Date: May 20, 2018
Have you considered one of these? http://www.dolba.de/antennenloesungen/funk-antenne-bd5/ Fitted to many German gliders, bonded to the fin structure, most how have glass fiber fins to allow VHF, txpdr & flarm antennas all to be hidden inside. Peter From: owner-aeroelectric-list-server(at)matronics.com On Behalf Of GTH Sent: 20 May 2018 12:43 Subject: Re: AeroElectric-List: VHF antenna in the tail Le 23/12/2017 =E0 01:26, Robert L. Nuckolls, III a =E9crit : Can you describe the physical configuration of the vertical fin vis-a-vis the empennage? Is the vertical fin detachable? I presume the antenna, once installed, will forever more be inaccessible for tweeking? Hi Bob and all, Reviving the antenna-in-tail subject, as the project fuselage is now assembled. Bob mentionned a promising "bazooka" configuration for the antenna, as the tail is too narrow to allow for a regular ground plane. Here are some answers to your questions : The entire fuselage is carbon. The vertical fin is integral with the fuselage but is made of glass for the installation of the antenna. The fin height is ~ 0.9 m (35") while the carbon tail at the base is only 0.18 m (7") wide. The base of the antenna will be accessible via the tail cone aperture, and crawling into the fuselage will permit limited access. I was considering installing the radiating element in a plastic tube in the fin, so that the antenna may be easily inserted and removed. Any suggestions as to how to devise a reasonably efficient comm antenna in the tail ? Thanks in advance, -- Best regards, Gilles http://contrails.free.fr http://lapierre.skunkworks.free.fr ________________________________________________________________________________
Date: May 20, 2018
At 04:57 PM 5/20/2018, you wrote: >Have you considered one of these? > ><http://www.dolba.de/antennenloesungen/funk-antenne-bd5/>http://www.dolba.de/antennenloesungen/funk-antenne-bd5/ > >Fitted to many German gliders, bonded to the fin structure, most how >have glass fiber fins to allow VHF, txpdr & flarm antennas all to be >hidden inside. > >Peter Do you know anyone who has installed this antenna on an OBAM aircraft? It's not clear from the image just how it installs. The website had no links to installation manuals that I could find. The SWR plot is impressive . . . but SWR and efficiency are two separate things. I've dropped them an email requesting more details. Bob . . . ________________________________________________________________________________
Date: May 20, 2018
At 10:33 AM 5/20/2018, you wrote: > >When flying in the vicinity of radio or TV towers, I get a constant >buzz or static over the radio. Sometimes I can hear the conversation >or music from the station, but just barely. It seems to start when >I'm within a 1/2 to 1/4 mile from a tower. > >Anyone else have this type of issue or resolved this type of issue? Seen this and similar situations many times in the past. Powerful transmitters are strong potential interference sources. Effects are many and varied. Used to rent a Beech B77 at Mid Continent that would treat me to a 'buzz' in the headsets while awaiting clearance at the south end of 1R. The hold pad was about 100 yards from the ATC antenna dish. Every time the antenna swept around, you'd hear a buzz-burst at the PRF for the radar transmitter. Sometimes you hear a similar buzz-burst from a transponder reply when the antenna coax shield is broken and the leakage is radiating the cabin. Another rental a/p would drift off track if my LOC intercept path took me past the television stations antenna farm NW of KICT. After passage, the a/p would recover and correctly nail the intercept. Those transmitters have really BIG radiated power numbers . . . sometimes 200,000 watts. Since the effects are inversely proportional to square of distance from the source, they usually go away if you're more than a couple miles from the antenna. Best fix . . . fly around it . . . or simply be aware of it and turn the volume down until you are past it. Bob . . . ________________________________________________________________________________
Date: May 21, 2018
Thanks for the input everyone. My plane seems to be the only one this is happening to as I've flown the same route in everything from Cubs to Challenger 300's and no interference. I'll try what you all suggested and report back. Thanks again. -------- Mike Bentley Joplin, MO N5498B Kitfox Model 4-1200 Jabiru 2200 #438 Rotec Aerosport LCH Heads Prince Prop (64 x 34) Ellison EFS-2 Throttle Body Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480274#480274 ________________________________________________________________________________
Date: May 21, 2018
At 10:05 AM 5/21/2018, you wrote: > >Thanks for the input everyone. My plane seems to be the only one >this is happening to as I've flown the same route in everything from >Cubs to Challenger 300's and no interference. I'll try what you all >suggested and report back. Interference of this type is not a consistent manifestation. Characteristics of the victim and propagation modes can be significantly different even in apparently identical aircraft. The Hawkers had features in their annunciation sensing and response systems that were grand-fathered over from some rather arcane technology and design philosophies. A polite way of suggesting every ship had dozens of potential victims designed to be problem children. In spite of obvious vulnerabilities, the percentage of problem children was relatively low . . . but a pain in the what's-it to fix . . . and every fix was a band-aid. The fact that you're a solitary observer of the problem cited is not unusual. Further, fixing the problem COULD be time consuming and expensive . . . been there and done that on more than one program! As long as the effects do not present a safety of flight condition, I suggest that further investigation is more academic than practical . . . but we would like to hear what you discover. Bob . . . ________________________________________________________________________________
Date: May 21, 2018
Had a dentist appointment 33 miles away this morning . . . did some 'asphalt engineering' on this thread . . . I occurred to me that the design might be more easily fabricated, installed and maintained if the chassis connector originally suggested were replaced with a BNCF->BNCF bulkhead feed thru like:Bu https://goo.gl/XDTtod The feed line from the transceiver would be terminated in a BNCM cable connector as before. Instead of terminating the radiator with a solder joint at the connector, it too would be fitted with a BNCM cable connector so that it could be detached without disturbing the ground plane. This style of connector seems a likely candidate: https://goo.gl/VLjQXH Solder a short stub of 20AWG wire into the center pin to facilitate connection to the end of the radiator's 'flexy' section. Cover with heat shrink. With the pin fully seated in the connector, back-fill the connector shell with JB weld or other epoxy. The connector clamp ring, gasket and compression nut are discarded. By the way, the ground plane doesn't need to be tucked up tight against the bottom of the radiator conduit. Several inches of radiator could be used to jump a short gap from bottom of conduit to the ground plane without serious effect. Bob . . . ________________________________________________________________________________
Date: May 21, 2018
Subject: OV sensing in Z-12
Well, I'm starting to question my powers of analysis (or at least my memory). While pondering OV protection with dual alternators (using something less expensive than the B&C units), I perused drawing Z-12. Should I assume that the aux alternator must be left disabled until needed? It appears that having both alts on line would result in both OV protection circuits firing, if either alt had an OV event. What I'd like to achieve (alternative engine with auto style engine control) is both alternators (identical capacity) operating all the time, with OV protection taking out only the bad alternator. Thoughts? Charlie Virus-free. www.avast.com <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> ________________________________________________________________________________
Subject: Re: OV sensing in Z-12
Date: May 21, 2018
Charlie, I agree that both over-voltage modules would trip simultaneously. Options: 1. Like you said, only turn on one alternator at a time. 2. Insert diodes 747-DSA300i45NA in the alternator B leads and connect the over-voltage protection upstream of each diode. 3. Monitor the current on each B lead. In an over voltage condition, shut off only the alternator that is putting out the highest current. This option requires the design of an electronic circuit. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480281#480281 ________________________________________________________________________________
Subject: Low Battery Voltage Blows Fuel Pump Fuse?
Date: May 21, 2018
There is a recent thread on VansAirforce about the electric fuel pump 5 amp fuse blowing as a result of low battery voltage. http://www.vansairforce.com/community/showthread.php?t=160595 I would have attributed the blown fuse to some other cause, except that two pilots reported the same symptoms on two different aircraft. The fuel pump is Facet part number 40105. According to Aircraft Spruce, that pump draws 1 amp. I measured the current draw on my spare pump (same make and model) at 3/4 amp with a light load. When I connected a 6 volt battery to the pump instead of 12 volts, the pump quit working and the current dropped to about 1/2 amp. I do not have a power supply with adjustable voltage output. Does the current draw for a DC pump motor actually increase as the voltage decreases? And even if it did, which I doubt, the current would have to increase by a factor of 5 in order to blow the fuse. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480282#480282 ________________________________________________________________________________
Subject: Re: Low Battery Voltage Blows Fuel Pump Fuse?
Date: May 21, 2018
I called it a pump motor but, judging by the sound, the Facet 40105 is more likely to be a solenoid that operates a piston. It is advertised as solid state, which probably refers to the pulsing control circuit. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480283#480283 ________________________________________________________________________________
Date: May 21, 2018
At 05:25 PM 5/21/2018, you wrote: >Well, I'm starting to question my powers of analysis (or at least my >memory). While pondering OV protection with dual alternators (using >something less expensive than the B&C units), I perused drawing >Z-12. Should I assume that the aux alternator must be left disabled >until needed? It appears that having both alts on line would result >in both OV protection circuits firing, if either alt had an OV event. The B&C SB-1 controller features automatic enabling of the standby alternator upon failure of the main alternator . . . along with an annunciator system to notify the pilot of the event. One COULD use a more generic controller and forego up the auto switching/annunciation feature. You still need low voltage annunciation. If you get a light, you turn the main alternator OFF; the standby alternator ON. The B&C products do feature 'selective trip' . . . a circuit that deduces whether or not the client alternator is the source of the ov event. But with only one alternator operating at any time, plain vanilla ov protection will function as desired. >What I'd like to achieve (alternative engine with auto style engine >control) is both alternators (identical capacity) operating all the >time, with OV protection taking out only the bad alternator. Why two alternators ON at the same time? Making the transition from main to s/b alternator is not a 'tense' event. If the main alternator quits, you can finish your cup of coffee and fold the map up before you start flipping switches. The auto-change and annunciation were features that were more bells-and-whistles designed to tickle the fancy of A36 drivers and Beech engineers. It was easy to do as we wanted to monitor b-lead current on the SD20 and enable easy load shedding. If you're wanting to run two full sized alternators, then I would agree that the SB-1 if a bit of over-kill. If it were my airplane, they would be alternator #1 and #2 and swap back and forth in preflight. Bob . . . ________________________________________________________________________________
Date: May 21, 2018
At 06:25 PM 5/21/2018, you wrote: > >Charlie, >I agree that both over-voltage modules would trip simultaneously. >Options: >1. Like you said, only turn on one alternator at a time. I like that . . . >2. Insert diodes 747-DSA300i45NA in the alternator B leads and >connect the over-voltage protection upstream of each diode. >3. Monitor the current on each B lead. In an over voltage >condition, shut off only the alternator that is putting out the >highest current. This option requires the design of an electronic circuit. Achhh! . . . Joseph . . . go wash your mouth out with soap. You go to bed without your Oreos and milk . . . Bob . . . ________________________________________________________________________________
Date: May 21, 2018
At 06:54 PM 5/21/2018, you wrote: > >There is a recent thread on VansAirforce about the electric fuel >pump 5 amp fuse blowing as a result of low battery voltage. >http://www.vansairforce.com/community/showthread.php?t=160595 >I would have attributed the blown fuse to some other cause, except >that two pilots reported the same symptoms on two different >aircraft. The fuel pump is Facet part number 40105. According to >Aircraft Spruce, that pump draws 1 amp. I measured the current draw >on my spare pump (same make and model) at 3/4 amp with a light >load. When I connected a 6 volt battery to the pump instead of 12 >volts, the pump quit working and the current dropped to about 1/2 >amp. I do not have a power supply with adjustable voltage >output. Does the current draw for a DC pump motor actually increase >as the voltage decreases? And even if it did, which I doubt, the >current would have to increase by a factor of 5 in order to blow the fuse. Hmmmm . . . that's a strange one. Those pumps are strange creatures that don't behave like what we would expect of a motor driven device. The 'thumping' noise is a piston being magnetically driven to compress a spring. The piston is hollow and has check valves in each end. The 'power stroke' compresses the spring and reduces pressure on the inlet side. Fuel is forced past the inlet check valve filling the piston. At the end of the power pulse, spring pressure works to return the piston to its resting position, increasing pressure on the fuel which closes the inlet valve and opens the outlet valve. Spring force and piston motion pushes fuel out of the pump. Emacs! Output pressure is purely a function of spring force. Output flow is purely a function of how much flow leaves the pump at the calibrated pressure. The spring, piston volume and pulse rate are adjusted to produce the desired MAXIMUM flow at a pressure not exceeding that which is established by the spring. Hence, blocking the outlet off completely does not increase current draw . . . in fact, the energy consumed by the pump is relatively constant whether or not the device has fuel moving through it. To have one of these devices draw an extra-ordinary current value suggests a fault in the pump power feeder or a shorted winding in the pump's stroke motor. I would troubleshoot by (1) replacing the pump. I've measured energy consumption with agile data acquisition systems that deal with the very intermittent nature of current flow. It's difficult to get a 'reading' with ordinary hand held instruments . . . but you can get a general sense of magnitude with an analog ammeter. Bob . . . ________________________________________________________________________________
Date: May 21, 2018
I can handle the soap in my mouth. But I am NOT going to bed without my Oreos and milk! -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480287#480287 ________________________________________________________________________________
Date: May 21, 2018
Bob, Thanks for the reply and explanation about how the pump works. I had neglected to mention that the fuel pump fuse blows during engine cranking. I do not think that makes any difference to the pump, other than causing a voltage sag. I measured the current draw of my spare pump with an analog Simpson 260. I am as mystified as you. Unfortunately the plane is located hundreds of miles away. All I have to go by is second hand information. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480288#480288 ________________________________________________________________________________
Date: May 21, 2018
May 09, 2018 - May 21, 2018
AeroElectric-Archive.digest.vol-oj
