AeroElectric-Archive.digest.vol-or
November 14, 2018 - December 29, 2018
      t your expensive electronics by playing around with varying
      >these outputs
      =94-
      >John
      >Sent from my iPad
      >=C2- =C2- =C2-----x--O--x----
      >On 14 Nov 2018, at 3:11 am, Charlie England
      >wrot
      e:
      >Thanks, to Richard, Earnest and Bob=2E Looks like I need to go a
      head &
      >pull the trigger=2E I'll report when it comes in=2E
      > Charlie
      > On 11/13/2018 7:47 PM, Richard Girard wrote:
      > Charlie, this is t
      he one I bought on Amazon=2E =2E=C2-
      >https://www=2Eamazon=2Ecom/Dr-mete
      r-Single-Output-Switchable-Alligator-included/dp/B07D4FQ4CP/ref=sr_1_17?i
      e=UTF8&qid=1542159852&sr=8-17&keywords=bench+power+supply
      >  Ri
      ck Girard
      >On Tue, Nov 13, 2018 at 6:29 PM Brian Lester
      >wrote:
      >A bit more expensive but I got this from amazon
      =2E DC Power Supply
      >Variable,0-30 V / 0-10 A Eventek KPS3010D Adjustable S
      witching
      >Regulated Power Supply Digital
      > https://www=2Eamazon=2Ecom/dp/B0
      73TW8H2S/ref=cm_sw_r_cp_api_qY16BbT9P9Y2P
      >But honestly the stuff on e
      Bay looks about the same at a better price=2E
      > -Brian
      >On Tue, Nov 13, 2
      018 at 6:44 PM Charlie England
      >wrote:
      >  Than
      ks, Ernest=2E Anyone else?
      >On Tue, Nov 13, 2018 at 5:18 PM Ernest Christ
      ley
      >wrote:
      >Looks very much like the onei bough
      t from mpja=2Ecom=2E mine works
      >perfectly=2E
      > Sent from Yahoo Mail on
      Android
      >On Tue, Nov 13, 2018 at 5:56 PM, Charlie England
      >wrote:     Anyone have experience with the recent ebay offerin
      gs for
      >cheap lab supplies? Example below=2E I tried searching my old AEC e
      mails,
      >but the most recent reference I found was for a much more expensive
      >model=2E It'll get  minimal use; just final checkout of my project's
      >wir
      ing and then rare uses after that, so don't want to spend
      >$hundreds=2E=C2
      - 0-30v/0-10a bench supply
      >  Thanks,
      >  Charlie
      >=9CBlessed are the cracked, for they shall let in
       the light=2E=9D =C2-=C2-Groucho
      >Marx
      >|  | Vir
      us-free=2E www=2Eavast=2Ecom  |
Date: Nov 14, 2018
Subject: Re: Cheap bench supply?
I have been thinking of getting one of these as well but a 30V 20A model. I have used one before but I'm not entirely sure how they work. What is the function on the amperage dial? In what situation would you set it lower than the maximum output of the power supply? On Wed, Nov 14, 2018, 04:06 John Tipton What=99s wrong with a =98cb=99 type radio power supply, 13.8 volts, 3-5 amps, > why do you need something giving variable volts/amps, are you really goin g > to test your expensive electronics by playing around with varying these > outputs =94- > > John > > Sent from my iPad > > ----x--O--x---- > > On 14 Nov 2018, at 3:11 am, Charlie England wrote: > > Thanks, to Richard, Earnest and Bob. Looks like I need to go ahead & pull > the trigger. I'll report when it comes in. > > Charlie > > On 11/13/2018 7:47 PM, Richard Girard wrote: > > Charlie, this is the one I bought on Amazon. . > > > https://www.amazon.com/Dr-meter-Single-Output-Switchable-Alligator-includ ed/dp/B07D4FQ4CP/ref=sr_1_17?ie=UTF8&qid=1542159852&sr=8-17&keyword s=bench+power+supply > > Rick Girard > > On Tue, Nov 13, 2018 at 6:29 PM Brian Lester > wrote: > >> A bit more expensive but I got this from amazon. DC Power Supply >> Variable,0-30 V / 0-10 A Eventek KPS3010D Adjustable Switching Regulated >> Power Supply Digital >> https://www.amazon.com/dp/B073TW8H2S/ref=cm_sw_r_cp_api_qY16BbT9P9Y2P >> >> But honestly the stuff on eBay looks about the same at a better price. >> -Brian >> On Tue, Nov 13, 2018 at 6:44 PM Charlie England >> wrote: >> >>> Thanks, Ernest. Anyone else? >>> >>> On Tue, Nov 13, 2018 at 5:18 PM Ernest Christley >>> wrote: >>> >>>> Looks very much like the onei bought from mpja.com. mine works >>>> perfectly. >>>> >>>> Sent from Yahoo Mail on Android >>>> >>>> >>>> On Tue, Nov 13, 2018 at 5:56 PM, Charlie England >>>> wrote: >>>> Anyone have experience with the recent ebay offerings for cheap lab >>>> supplies? Example below. I tried searching my old AEC emails, but the most >>>> recent reference I found was for a much more expensive model. It'll ge t >>>> minimal use; just final checkout of my project's wiring and then rare uses >>>> after that, so don't want to spend $hundreds. >>>> 0-30v/0-10a bench supply >>>> >>>> >>>> Thanks, >>>> >>>> Charlie >>>> >>>> > > -- > =9CBlessed are the cracked, for they shall let in the light. =9D Groucho Marx > <http://www.goodreads.com/author/show/43244.Groucho_Marx> > > > Virus-free . > www.avast.com > > <#m_-7689733828043912502_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> > > ________________________________________________________________________________
Date: Nov 14, 2018
For my purposes at the moment, the current setting would be used to minimize risk of catastrophic failure in a device that's polarity sensitive, such as electronics, or possibly external stuff around a DC motor that might get hooked up backward. The way I'd use it is to set voltage to zero, and current to some relatively low percentage of a given device's max current draw. Apply power to the device, and slowly increase voltage while monitoring current and the device 'waking up'. The current limiter may well reduce the voltage below set point, to control current, if there's an 'issue'. If everything's nominal at normal 12-14V, then current limit can be raised to the device's normal operating current to check operation. I've used simple variable voltage supplies for decades when troubleshooting or checking devices (mostly audio gear), but without the current limiter, the operator (me) becomes the detector/limiter, and may not be perceptive or quick-reacting enough to avoid damage. I'm getting lazy in my slower response time old age. :-) If you decide to roll your own LED landing lights, for example, a variable voltage/current supply could conceivably be used to experiment with various high power LEDs before buying a dedicated LED driver board. As I mentioned earlier, the only thing I can think of that would be tougher to test this way would be electronics with 'switcher' power supplies. The switcher will try to draw as much current as it needs, to make full output, and may tend to be either full off (inadequate supply current) or full on, so the current/voltage monitoring technique may prove meaningless with some of those devices. Even with those devices, we can at least check that we have polarity correct and on the correct pin(s). Charlie On 11/14/2018 9:55 AM, Sebastien wrote: > I have been thinking of getting one of these as well but a 30V 20A > model. I have used one before but I'm not entirely sure how they work. > What is the function on the amperage dial? In what situation would you > set it lower than the maximum output of the power supply? > > On Wed, Nov 14, 2018, 04:06 John Tipton wrote: > > Whats wrong with a cb type radio power supply, 13.8 volts, 3-5 > amps, why do you need something giving variable volts/amps, are > you really going to test your expensive electronics by playing > around with varying these outputs - > > John > > Sent from my iPad > > ----x--O--x---- > > On 14 Nov 2018, at 3:11 am, Charlie England > wrote: > >> Thanks, to Richard, Earnest and Bob. Looks like I need to go >> ahead & pull the trigger. I'll report when it comes in. >> >> Charlie >> >> On 11/13/2018 7:47 PM, Richard Girard wrote: >>> Charlie, this is the one I bought on Amazon. . >>> >>> https://www.amazon.com/Dr-meter-Single-Output-Switchable-Alligator-included/dp/B07D4FQ4CP/ref=sr_1_17?ie=UTF8&qid=1542159852&sr=8-17&keywords=bench+power+supply >>> >>> Rick Girard >>> >>> On Tue, Nov 13, 2018 at 6:29 PM Brian Lester >>> > wrote: >>> >>> A bit more expensive but I got this from amazon. DC Power >>> Supply Variable,0-30 V / 0-10 A Eventek KPS3010D Adjustable >>> Switching Regulated Power Supply Digital >>> https://www.amazon.com/dp/B073TW8H2S/ref=cm_sw_r_cp_api_qY16BbT9P9Y2P >>> >>> But honestly the stuff on eBay looks about the same at a >>> better price. >>> -Brian >>> On Tue, Nov 13, 2018 at 6:44 PM Charlie England >>> > wrote: >>> >>> Thanks, Ernest. Anyone else? >>> >>> On Tue, Nov 13, 2018 at 5:18 PM Ernest Christley >>> > wrote: >>> >>> Looks very much like the onei bought from mpja.com >>> <http://mpja.com>. mine works perfectly. >>> >>> Sent from Yahoo Mail on Android >>> >>> >>> On Tue, Nov 13, 2018 at 5:56 PM, Charlie England >>> >> > wrote: >>> Anyone have experience with the recent ebay >>> offerings for cheap lab supplies? Example below. >>> I tried searching my old AEC emails, but the >>> most recent reference I found was for a much >>> more expensive model. It'll get minimal use; >>> just final checkout of my project's wiring and >>> then rare uses after that, so don't want to >>> spend $hundreds. >>> 0-30v/0-10a bench supply >>> >>> >>> Thanks, >>> >>> Charlie >>> >>> >>> >>> -- >>> >>> >>> Blessed are the cracked, for they shall let in the light. >>> Groucho Marx >>> <http://www.goodreads.com/author/show/43244.Groucho_Marx> >>> >>> >> >> >> >> Virus-free. www.avast.com >> >> >> >> <#m_-7689733828043912502_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Nov 14, 2018
Yes. You can turn the current down so that no matter the voltage, you only get a set amount of current. Sent from Yahoo Mail on Android On Wed, Nov 14, 2018 at 10:58 AM, Sebastien wrote: I have been thinking of getting one of these as well but a 30V 20A model. I h ave used one before but I'm not entirely sure how they work. What is the fu nction on the amperage dial? In what situation would you set it lower than the maximum output of the power supply? On Wed, Nov 14, 2018, 04:06 John Tipton wrote: Thanks, to Richard, Earnest and Bob. Looks like I need to go ahead & pull the trigger. I'll report when it comes in. Charlie On 11/13/2018 7:47 PM, Richard Girard wrote: Charlie, this is the one I bought on Amazon. .=C2- https://www.amazon.com/Dr-meter-Single-Output-Switchable-Alligator-includ ed/dp/B07D4FQ4CP/ref=sr_1_17?ie=UTF8&qid=1542159852&sr=8-17&keyword s=bench+power+supply Rick Girard On Tue, Nov 13, 2018 at 6:29 PM Brian Lester wro te: A bit more expensive but I got this from amazon. DC Power Supply Variable,0 -30 V / 0-10 A Eventek KPS3010D Adjustable Switching Regulated Power Supply Digital https://www.amazon.com/dp/B073TW8H2S/ref=cm_sw_r_cp_api_qY16BbT9P9Y2P But honestly the stuff on eBay looks about the same at a better price. -Brian On Tue, Nov 13, 2018 at 6:44 PM Charlie England wr ote: Thanks, Ernest. Anyone else? On Tue, Nov 13, 2018 at 5:18 PM Ernest Christley wro te: Looks very much like the onei bought from mpja.com. mine works perfectly. Sent from Yahoo Mail on Android On Tue, Nov 13, 2018 at 5:56 PM, Charlie England w rote: Anyone have experience with the recent ebay offerings for cheap l ab supplies? Example below. I tried searching my old AEC emails, but the mo st recent reference I found was for a much more expensive model. It'll get minimal use; just final checkout of my project's wiring and then rare uses after that, so don't want to spend $hundreds.=C2- 0-30v/0-10a bench supp ly Thanks, Charlie -- =9CBlessed are the cracked, for they shall let in the light.=9D =C2-=C2-Groucho Marx | | Virus-free. www.avast.com | ________________________________________________________________________________
Date: Nov 14, 2018
Charlie, I bought two of these units back in June from a different Ebay vendor. The only issue I had was an intermittent connection in the line cord at P/S end of one unit. It uses a standard computer line cord, so I just replaced it with one I had laying around. It works as advertised and its a good value. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=485014#485014 ________________________________________________________________________________
Date: Nov 14, 2018
On 11/14/2018 12:11 PM, MMiller wrote: > > Charlie, I bought two of these units back in June from a different Ebay vendor. The only issue I had was an intermittent connection in the line cord at P/S end of one unit. It uses a standard computer line cord, so I just replaced it with one I had laying around. It works as advertised and its a good value. > Sounds good. Thanks for the 'PIREP'; I've got one on the way. Charlie --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Nov 14, 2018
I am careful about buying electronic equipment like battery chargers and power supplies. The very inexpensive stuff Is built from inexpensive parts which may fail fairly quickly. It this kind of equipment fails in the max voltage mode, it can FRY some very expensive equipment being powered or tested in short order. A battery charger that fails in an over voltage mode can COOK a very expensive battery quickly. I have wondered the streets of some of the third world countries and seen some of the "SURPLUS" electronic parts that often go into cheap test equipment. This was a real eye opener experience. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com <owner-aeroelectric-list-server(at)matronics.com> On Behalf Of MMiller Sent: Wednesday, November 14, 2018 12:12 PM Subject: AeroElectric-List: Re: Cheap bench supply? Charlie, I bought two of these units back in June from a different Ebay vendor. The only issue I had was an intermittent connection in the line cord at P/S end of one unit. It uses a standard computer line cord, so I just replaced it with one I had laying around. It works as advertised and its a good value. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=485014#485014 ________________________________________________________________________________
Date: Nov 14, 2018
The current adjustment sets an upper bound on the current the unit will supply. If you try to draw more current than that, the output voltage falls far enough that the current stays at the limit you set. You can use PSUs with a current limiting facility in either of two modes. Either constant voltage, which is what is normally used, or constant current mode. There are not many circuits that need a constant current drive, but I used to use one for charging NiCd batteries (in the olden days) where the current would be set at (say) 5x the one hour cell capacity and I could charge four or more cells in series. The terminal voltage would start low, and automatically rise as the cells charged. >>In what situation would you set it lower than the maximum output of the power supply? When you have a circuit that needs a constant current supply, or, as someone suggested, when you have a circuit which, should a fault develop, you want to limit the maximum power your supply can generate. On Nov 14, 2018, at 10:55 AM, Sebastien wrote: I have been thinking of getting one of these as well but a 30V 20A model. I have used one before but I'm not entirely sure how they work. What is the function on the amperage dial? In what situation would you set it lower than the maximum output of the power supply? On Wed, Nov 14, 2018, 04:06 John Tipton wrote: > Thanks, to Richard, Earnest and Bob. Looks like I need to go ahead & pull the trigger. I'll report when it comes in. > > Charlie > > On 11/13/2018 7:47 PM, Richard Girard wrote: >> Charlie, this is the one I bought on Amazon. . >> >> https://www.amazon.com/Dr-meter-Single-Output-Switchable-Alligator-included/dp/B07D4FQ4CP/ref=sr_1_17?ie=UTF8&qid=1542159852&sr=8-17&keywords=bench+power+supply >> >> Rick Girard >> >> On Tue, Nov 13, 2018 at 6:29 PM Brian Lester wrote: >> A bit more expensive but I got this from amazon. DC Power Supply Variable,0-30 V / 0-10 A Eventek KPS3010D Adjustable Switching Regulated Power Supply Digital >> https://www.amazon.com/dp/B073TW8H2S/ref=cm_sw_r_cp_api_qY16BbT9P9Y2P >> >> But honestly the stuff on eBay looks about the same at a better price. >> -Brian >> On Tue, Nov 13, 2018 at 6:44 PM Charlie England wrote: >> Thanks, Ernest. Anyone else? >> >> On Tue, Nov 13, 2018 at 5:18 PM Ernest Christley wrote: >> Looks very much like the onei bought from mpja.com. mine works perfectly. >> >> Sent from Yahoo Mail on Android >> >> On Tue, Nov 13, 2018 at 5:56 PM, Charlie England >> wrote: >> Anyone have experience with the recent ebay offerings for cheap lab supplies? Example below. I tried searching my old AEC emails, but the most recent reference I found was for a much more expensive model. It'll get minimal use; just final checkout of my project's wiring and then rare uses after that, so don't want to spend $hundreds. >> 0-30v/0-10a bench supply >> >> Thanks, >> >> Charlie >> >> >> -- >> Blessed are the cracked, for they shall let in the light. Groucho Marx >> >> > > > Virus-free. www.avast.com ________________________________________________________________________________
Date: Nov 14, 2018
At 04:00 PM 11/14/2018, you wrote: > >I am careful about buying electronic equipment like battery chargers >and power supplies. > >The very inexpensive stuff Is built from inexpensive parts which may >fail fairly quickly. > >It this kind of equipment fails in the max voltage mode, it can FRY >some very expensive equipment being powered or tested in short >order. A battery charger that fails in an over voltage mode can >COOK a very expensive battery quickly. > >I have wondered the streets of some of the third world countries and >seen some of the "SURPLUS" electronic parts that often go into cheap >test equipment. This was a real eye opener experience. I can't speak from any documentable source but I believe your concerns are becoming less significant if not non-existant. The ability of industries to fabricate and utilize perfectly acceptable parts has been falling exponentially for some time. The handling $COST$ of processing sub-standard parts into products can easily exceed the cost of 'good' parts. Ergo, for the vast majority of examples on the market, I've found that the offerings are of good value. Out here in the hinterlands of western Kansas, my FIRST choice for on-line shopping is eBay, not necessarily because it has proven to be 'better' than any other source . . . only adequate to my needs. Vendors with high percentages of satisfactory customers over hundreds if not thousands of transactions have proven to be very low if not zero risk. Bob . . . ________________________________________________________________________________
Date: Nov 15, 2018
Subject: Make Sure You're Listed! List of Contributors Coming
Soon! Dear Listers, There's just two more days left in this year's List Fund Raiser and that means the List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: Writing your thesis paper
Date: Nov 15, 2018
Essay writing and thesis writing are of different level. But, thesis cannot be written as an essay. It needs good research and much data to support the findings. So, it takes much time to complete writing. The results you will get from your research should be unique and must be discussed in the future as well. Your professor needs such an output from you by writing a thesis paper. However, it is not easy. Arranging the information for different sections is a time consuming task because, it should be done with care. A tiny mistake will mislead your writing. Once you got all information, you should prepare a great draft of your paper so that you will never go beyond the topic. You need to take much effort and much time to write a thesis paper. If you think that it is unmanageable for you, then you can ask help from cheap thesis writing service (https://essayschief.com/service/Dissertation/Thesis_Writing) experts. The experts are well trained writers and especially the thesis writers have a degree not less than a Ph.D. So, your thesis paper will be safe if you choose a writing service to write the assignment in great quality and professionalism. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=485111#485111 ________________________________________________________________________________
Date: Nov 16, 2018
Subject: Re: Writing your thesis paper
Hi Steve; And the relevance of this to building aircraft electrical systems is.....? Cheers! Stu. ----- Original Message ----- From: "stevencarter" <toressjohn(at)yahoo.com> Sent: Thursday, November 15, 2018 9:58:24 PM Subject: AeroElectric-List: Writing your thesis paper Essay writing and thesis writing are of different level. But, thesis cannot be written as an essay. It needs good research and much data to support the findings. So, it takes much time to complete writing. The results you will get from your research should be unique and must be discussed in the future as well. Your professor needs such an output from you by writing a thesis paper. However, it is not easy. Arranging the information for different sections is a time consuming task because, it should be done with care. A tiny mistake will mislead your writing. Once you got all information, you should prepare a great draft of your paper so that you will never go beyond the topic. You need to take much effort and much time to write a thesis paper. If you think that it is unmanageable for you, then you can ask help from cheap thesis writing service (https://essayschief.com/service/Dissertation/Thesis_Writing) experts. The experts are well trained writers and especially the thesis w! riters have a degree not less than a Ph.D. So, your thesis paper will be safe if you choose a writing service to write the assignment in great quality and professionalism. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=485111#485111 ________________________________________________________________________________
Date: Nov 17, 2018
Subject: Reminder
Dear Listers, A quick reminder that November is the annual Matronics List Fund Raiser. The Lists are 100% member supported and all of the operational costs are covered solely through your Contributions during this time of the year. *Your* personal Contribution makes a difference and keeps all of the Matronics Email Lists and Forums completely ad-free. Please make your Contribution today to keep these services up and running for another great year! Use a credit card or your PayPal account here: http://www.matronics.com/contribution Or, by sending a personal check to: Matronics / Matt Dralle 581 Jeannie Way Livermore CA 94550 Thank you in advance! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 17, 2018
Subject: draw.io shapes
Hi, Has anyone already added to the draw.io program shape library with some shapes like Bob's? Should not take too long, but if I can save a couple hours of work it would be great. The format for doing the shapes is pretty easy. https://support.draw.io/display/DO/Editing+Shapes Here's my battery that looks like the one in Z diagrams: I just took the one they had and made it a three-cell instead of two. Thanks, Mickey Mickey Coggins ________________________________________________________________________________
Subject: Re: Wig-Wag wiring
Date: Nov 17, 2018
Hi Bob - Further to your diagram (2-10, Off-Both-Wig-wag) you have a permanently live lead (terminal 2) going to the wig-wag unit, would it not be better (good practice) to put this lead on terminal 1, making that lead 'hot' only when the switch is in one of it's two 'on' states - Regards: John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=485205#485205 ________________________________________________________________________________
Date: Nov 18, 2018
At 05:38 PM 11/17/2018, you wrote: > >Hi Bob - Further to your diagram (2-10, Off-Both-Wig-wag) you have a >permanently live lead (terminal 2) going to the wig-wag unit, would >it not be better (good practice) to put this lead on terminal 1, >making that lead 'hot' only when the switch is in one of it's two >'on' states - Regards: John > The artifact you've cited was left over from Eric's original drawing, but your suggested modification sure wouldn't hurt . . . Bob . . . ________________________________________________________________________________
Date: Nov 19, 2018
Subject: LOC
Dear Listers, Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its sort of my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take a moment and assure that your name is on that List of Contributors (LOC)? As a number of members have pointed out over the years, the List seems at least - if not a whole lot more - valuable as a building/flying/recreating/entertainment tool as your typical magazine subscription! Please take minute and assure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by popping a personal check in the mail to: Matronics Email Lists c/o Matt Dralle 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Email List Administrator ________________________________________________________________________________
Subject: For Sale [30 Pieces] Apple iPhone XR New 128GB $5,970CAD
Date: Nov 19, 2018
2 Year International Warranty 100% Guaranteed Lowest Price Free shipping worldwide via FedEx. 110% Guaranteed Money back in 5 days We ship same day and delivered in just 3 days.Buy from us with confidence Pickup is 100% Permitted. All products are 100% Unlocked Original. No Refurbish Company Name Esellibuy Located in Canada Price: Canadian dollar Tel +16479468649 Website www . esellibuy . com Email info (at) esellibuy . com ==================================== Price are Canadian dollars.We Located in Canada Buy 5Pieces Apple iPhone Xs New Max 64GB $4,495 Buy 5Pieces Apple iPhone Xs New Max 256GB $5,245 Buy 5Pieces Apple iPhone Xs New Max 512GB $6,245 ==================================== Buy 5Pieces Apple iPhone Xs New 64GB $3,995 Buy 5Pieces Apple iPhone Xs New 256GB $4,745 Buy 5Pieces Apple iPhone Xs New 521GB $5,745 ==================================== Buy 5Pieces Apple iPhone XR New 64GB $2,745 Buy 5Pieces Apple iPhone XR New 128GB $2,995 Buy 5Pieces Apple iPhone XR New 256GB $3,495 ==================================== Buy 5Pieces iPad Pro 64GB WiFi 12.9 inch $3,995 Buy 5Pieces iPad Pro 256GB WiFi 12.9 inch $4,745 Buy 5Pieces iPad Pro 512GB WiFi 12.9 inch $5,745 Buy 5Pieces iPad Pro 1TB WiFi 12.9 inch $7,745 ==================================== Buy 5Pieces iPad Pro 64GB WiFi 11 inch $2,995 Buy 5Pieces iPad Pro 256GB WiFi 11 inch $3,745 Buy 5Pieces iPad Pro 512GB WiFi 11 inch $4,745 Buy 5Pieces iPad Pro 1TB WiFi 11 inch $6,745 ==================================== Buy 5Pieces iPad Pro 64GB WiFi + Cellular 12.9 inch $4,745 Buy 5Pieces iPad Pro 256GB WiFi + Cellular 12.9 inch $5,495 Buy 5Pieces iPad Pro 512GB WiFi + Cellular 12.9 inch $6,495 Buy 5Pieces iPad Pro 1TB WiFi + Cellular 12.9 inch $8,495 ==================================== Buy 5Pieces iPad Pro 64GB WiFi + Cellular 11 inch $3,745 Buy 5Pieces iPad Pro 256GB WiFi + Cellular 11 inch $4,495 Buy 5Pieces iPad Pro 512GB WiFi + Cellular 11 inch $5,495 Buy 5Pieces iPad Pro 1TB WiFi + Cellular 11 inch $7,495 ==================================== Price are Canadian dollars.We Located in Canada Buy 10Pieces Apple iPhone Xs New Max 64GB $6,990 Buy 10Pieces Apple iPhone Xs New Max 256GB $8,490 Buy 10Pieces Apple iPhone Xs New Max 512GB $10,490 ==================================== Buy 10Pieces Apple iPhone Xs New 64GB $5,990 Buy 10Pieces Apple iPhone Xs New 256GB $7,490 Buy 10Pieces Apple iPhone Xs New 521GB $9,490 ==================================== Buy 10Pieces Apple iPhone XR New 64GB $3,490 Buy 10Pieces Apple iPhone XR New 128GB $3,990 Buy 10Pieces Apple iPhone XR New 256GB $4,990 ==================================== Buy 10Pieces iPad Pro 64GB WiFi 12.9 inch $5,990 Buy 10Pieces iPad Pro 256GB WiFi 12.9 inch $7,490 Buy 10Pieces iPad Pro 512GB WiFi 12.9 inch $9,490 Buy 10Pieces iPad Pro 1TB WiFi 12.9 inch $13,490 ==================================== Buy 10Pieces iPad Pro 64GB WiFi 11 inch $3,990 Buy 10Pieces iPad Pro 256GB WiFi 11 inch $5,490 Buy 10Pieces iPad Pro 512GB WiFi 11 inch $7,490 Buy 10Pieces iPad Pro 1TB WiFi 11 inch $11,490 ==================================== Buy 10Pieces iPad Pro 64GB WiFi + Cellular 12.9 inch $7,490 Buy 10Pieces iPad Pro 256GB WiFi + Cellular 12.9 inch $8,990 Buy 10Pieces iPad Pro 512GB WiFi + Cellular 12.9 inch $10,990 Buy 10Pieces iPad Pro 1TB WiFi + Cellular 12.9 inch $14,990 ==================================== Buy 10Pieces iPad Pro 64GB WiFi + Cellular 11 inch $5,490 Buy 10Pieces iPad Pro 256GB WiFi + Cellular 11 inch $6,990 Buy 10Pieces iPad Pro 512GB WiFi + Cellular 11 inch $8,990 Buy 10Pieces iPad Pro 1TB WiFi + Cellular 11 inch $12,990 ==================================== Price are Canadian dollars.We Located in Canada Buy 20Pieces Apple iPhone Xs New Max 64GB $10,980 Buy 20Pieces Apple iPhone Xs New Max 256GB $13,980 Buy 20Pieces Apple iPhone Xs New Max 512GB $17,980 ==================================== Buy 20Pieces Apple iPhone Xs New 64GB $8,980 Buy 20Pieces Apple iPhone Xs New 256GB $11,980 Buy 20Pieces Apple iPhone Xs New 521GB $15,980 ==================================== Buy 20Pieces Apple iPhone XR New 64GB $3,980 Buy 20Pieces Apple iPhone XR New 128GB $4,980 Buy 20Pieces Apple iPhone XR New 256GB $6,980 ==================================== Buy 20Pieces iPad Pro 64GB WiFi 12.9 inch $8,980 Buy 20Pieces iPad Pro 256GB WiFi 12.9 inch $11,980 Buy 20Pieces iPad Pro 512GB WiFi 12.9 inch $15,980 Buy 20Pieces iPad Pro 1TB WiFi 12.9 inch $23,980 ==================================== Buy 20Pieces iPad Pro 64GB WiFi 11 inch $4,980 Buy 20Pieces iPad Pro 256GB WiFi 11 inch $7,980 Buy 20Pieces iPad Pro 512GB WiFi 11 inch $11,980 Buy 20Pieces iPad Pro 1TB WiFi 11 inch $19,980 ==================================== Buy 20Pieces iPad Pro 64GB WiFi + Cellular 12.9 inch $11,980 Buy 20Pieces iPad Pro 256GB WiFi + Cellular 12.9 inch $14,980 Buy 20Pieces iPad Pro 512GB WiFi + Cellular 12.9 inch $18,980 Buy 20Pieces iPad Pro 1TB WiFi + Cellular 12.9 inch $26,980 ==================================== Buy 20Pieces iPad Pro 64GB WiFi + Cellular 11 inch $7,980 Buy 20Pieces iPad Pro 256GB WiFi + Cellular 11 inch $10,980 Buy 20Pieces iPad Pro 512GB WiFi + Cellular 11 inch $14,980 Buy 20Pieces iPad Pro 1TB WiFi + Cellular 11 inch $22,980 ==================================== Price are Canadian dollars.We Located in Canada Buy 30Pieces Apple iPhone Xs New Max 64GB $13,470 Buy 30Pieces Apple iPhone Xs New Max 256GB $17,970 Buy 30Pieces Apple iPhone Xs New Max 512GB $23,970 ==================================== Buy 30Pieces Apple iPhone Xs New 64GB $10.470 Buy 30Pieces Apple iPhone Xs New 256GB $14,970 Buy 30Pieces Apple iPhone Xs New 521GB $20,970 ==================================== Buy 30Pieces Apple iPhone XR New 64GB $4,470 Buy 30Pieces Apple iPhone XR New 128GB $5,970 Buy 30Pieces Apple iPhone XR New 256GB $8,970 ==================================== Buy 30Pieces iPad Pro 64GB WiFi 12.9 inch $10.470 Buy 30Pieces iPad Pro 256GB WiFi 12.9 inch $14,970 Buy 30Pieces iPad Pro 512GB WiFi 12.9 inch $20,970 Buy 30Pieces iPad Pro 1TB WiFi 12.9 inch $32,970 ==================================== Buy 30Pieces iPad Pro 64GB WiFi 11 inch $5.970 Buy 30Pieces iPad Pro 256GB WiFi 11 inch $10,470 Buy 30Pieces iPad Pro 512GB WiFi 11 inch $16,470 Buy 30Pieces iPad Pro 1TB WiFi 11 inch $28,470 ==================================== Buy 30Pieces iPad Pro 64GB WiFi + Cellular 12.9 inch $14,970 Buy 30Pieces iPad Pro 256GB WiFi + Cellular 12.9 inch $19,470 Buy 30Pieces iPad Pro 512GB WiFi + Cellular 12.9 inch $25,470 Buy 30Pieces iPad Pro 1TB WiFi + Cellular 12.9 inch $37,470 ==================================== Buy 30Pieces iPad Pro 64GB WiFi + Cellular 11 inch $10,470 Buy 30Pieces iPad Pro 256GB WiFi + Cellular 11 inch $14,970 Buy 30Pieces iPad Pro 512GB WiFi + Cellular 11 inch $20,970 Buy 30Pieces iPad Pro 1TB WiFi + Cellular 11 inch $32,970 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=485308#485308 ________________________________________________________________________________
Subject: Re: A brown-out alternative?
Date: Nov 20, 2018
I like this approach very much for all the reasons Bob mentions in is opening post. I would have expected a relay 'solution' could be even simpler than that: I would expect no more than what I have drawn up quickly as in attached schema. I am however struggling to understand the way Bob has wired the S704, so please enlighten this not-so-electro-savvy-person: what is/are the fundamental difference(s) between Bob's schema and what I have come up with? I suspect it has to do with the timing aspects mentioned, but don't see why 'my' lesser-component approach would not take care of those. -------- Marcel Zwakenberg XS TG || 912ULS || PH-SBR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=485340#485340 Attachments: http://forums.matronics.com//files/screen_shot_2018_11_20_at_141613_843.png ________________________________________________________________________________
Date: Nov 20, 2018
At 07:25 AM 11/20/2018, you wrote: > >I like this approach very much for all the reasons Bob mentions in >is opening post. > >I would have expected a relay 'solution' could be even simpler than >that: I would expect no more than what I have drawn up quickly as in >attached schema. > >I am however struggling to understand the way Bob has wired the >S704, so please enlighten this not-so-electro-savvy-person: what >is/are the fundamental difference(s) between Bob's schema and what I >have come up with? > >I suspect it has to do with the timing aspects mentioned, but don't >see why 'my' lesser-component approach would not take care of those. Yes . . . timing. (1) You want the e-bus to be 'boosted' BEFORE the starter current begins to flow and (2) remain boosted until AFTER the starter current is interrupted. We're talking tens of milliseconds here. The working hypothesis: the S704 wired as shown will offer a substantial drop-out delay (instigated by the catch diode on the coil). Hence it provides the necessary physics for condition (2). I'll confirm this with an experiment on the bench but I think the hypothesis is sound. Bob . . . ________________________________________________________________________________
Date: Nov 20, 2018
Marcel, You are right about the timing. The purpose of the diode between the downstream side of the start switch and the DC-DC converter is to conduct instantaneous power during the time that it takes the relay to close. The purpose of the relay is to provide a delay opening the circuit to the DC-DC converter. If you want to simplify the circuit, leave out both the diode and the relay and connect the DC-DC converter in parallel with the starter contactor. As soon as the start button is pressed, the DC-DC converter will be energized. The pilot is not going to let go of the start button until the engine starts. Once the engine has started, even for a second, the battery voltage will be above 10 volts. Thus brownout protection will be no longer needed. What do you have to lose by trying it? If it doesn't work, no harm is done. There will be brownout just like before experimenting. I suggest that the E-Bus switch common pole be connected to the E-Bus so that either the DC-DC converter or battery is selected, but both can not be connected together at the same time. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=485344#485344 ________________________________________________________________________________
Date: Nov 20, 2018
At 07:25 AM 11/20/2018, you wrote: > >I like this approach very much for all the reasons Bob mentions in >is opening post. > >I would have expected a relay 'solution' could be even simpler than >that: I would expect no more than what I have drawn up quickly as in >attached schema. > >I am however struggling to understand the way Bob has wired the >S704, so please enlighten this not-so-electro-savvy-person: what >is/are the fundamental difference(s) between Bob's schema and what I >have come up with? > >I suspect it has to do with the timing aspects mentioned, but don't >see why 'my' lesser-component approach would not take care of those. Yes . . . timing. (1) You want the e-bus to be 'boosted' BEFORE the starter current begins to flow and (2) remain boosted until AFTER the starter current is interrupted. We're talking tens of milliseconds here. The working hypothesis: the S704 wired as shown will offer a substantial drop-out delay (instigated by the catch diode on the coil). Hence it provides the necessary physics for condition (2). Oops, hit the send too soon. The diode around the S704 goes to condition (1). The diode in series with the output from the boost module goes to our lack of knowledge as to how well the boost module tolerates 'back feeding' when not being used. It may not be necessary but it doesn't hurt anything either. The extra diode is already part of our old friend, the diode bridge rectifier. I'll confirm this with an experiment on the bench but I think the hypothesis is sound. Bob . . . ________________________________________________________________________________
Date: Nov 20, 2018
Depending on the architecture of the DC-DC converter, a diode in series with its output may or may not be needed. I assume that the converter changes supply voltage to AC, transforms it to a higher voltage, then rectifies and filters the AC to change it back to a higher voltage DC. The rectifiers should block reverse current flow. But assumptions can be wrong. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=485346#485346 ________________________________________________________________________________
Date: Nov 20, 2018
Thanks Bob and Joe, thanks for your (very) quick replies ;), much appreciated! So, let me rephrase to see if I understand the workings of Bob's schema correctly: - the diode across the coil makes sure the relay opens tens of milliseconds later than opening up the start switch, hopefully by then the voltage on the battery by then has gone above brownout voltage (and you can replace this diode by a capacitor to increase the delay if so required); - the other diode in the line providing instantaneous power to the DC/DC converter is there to make sure no electrons can reach the starter connector after the start switch has been opened. Joe, thanks for pointing out my oversight of connecting the DC/DC to the E-Bus Switch common. And for the two diodes: will any out of the 1N... series do? -------- Marcel Zwakenberg XS TG || 912ULS || PH-SBR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=485350#485350 ________________________________________________________________________________
Date: Nov 20, 2018
Which would then be integrated in my schema as shown below. Any flaws with that? -------- Marcel Zwakenberg XS TG || 912ULS || PH-SBR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=485351#485351 Attachments: http://forums.matronics.com//files/screen_shot_2018_11_20_at_162946_965.png ________________________________________________________________________________
Date: Nov 20, 2018
The main purpose of a diode across the relay coil is to short out induced voltage being generated by the collapsing relay magnetic field. Without a diode or other voltage snubber, high voltage can arc across the contacts of the controlling switch, eventually damaging it. I would not replace the diode with a capacitor. Any arc suppression diode capable of conducting 1 amp or more will do. The diode in series with the DC-DC converter should be rated at least 10 amps. There is no need for two separate circuits and fuses. Regardless of one or two circuits, the fuse(s) needs to be able to handle the DC-DC converter current. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=485353#485353 ________________________________________________________________________________
Date: Nov 20, 2018
At 10:39 AM 11/20/2018, you wrote: > >The main purpose of a diode across the relay coil is to short out >induced voltage being generated by the >collapsing relay magnetic field. Without a diode or other voltage >snubber, high voltage can arc across >the contacts of the controlling switch, eventually damaging it. Actually, a capacitor COULD be used to effect drop-out delay per the t=rc constant of the capacitor + coil resistance. But you would still need a series diode to isolate the coil/capacitor combo from the voltage source. A diode will do the same thing per t=l/r but MAY prove to be too short. The bench testing will deny/confirm the hypothesis. Bob . . . ________________________________________________________________________________
Date: Nov 20, 2018
user9253 wrote: > The main purpose of a diode across the relay coil is to short out induced voltage being generated by the collapsing relay magnetic field. Sure, I did not mention that as that seems obvious to me, but good to add as a clarification. Thanks! user9253 wrote: > Any arc suppression diode capable of conducting 1 amp or more will do. Okay. user9253 wrote: > The diode in series with the DC-DC converter should be rated at least 10 amps. Yes, I can see why... (an even higher current rating might be required though, depending on used DC/DC converter type and battery voltage drop when starter engine spins up) user9253 wrote: > There is no need for two separate circuits and fuses. You are right, having thought about it a bit more I even think it is not a good idea to use two fuses as there is no way of knowing during preflight checking if one of the two fuses was blown, so you would not know that the circuit can only carry half the design current. Better to go with an XOR type of design... user9253 wrote: > Regardless of one or two circuits, the fuse(s) needs to be able to handle the DC-DC converter current. Sure enough (as do the wires ;) ). Thanks again Joe for further explanations. -------- Marcel Zwakenberg XS TG || 912ULS || PH-SBR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=485361#485361 ________________________________________________________________________________
Subject: DC - DC Converter
Date: Nov 20, 2018
Anyone have a recommendation on a 12VDC to 5VDC converter that is too noisy? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=485375#485375 ________________________________________________________________________________
Subject: Re: DC - DC Converter
Date: Nov 20, 2018
Check with Steinair=2E =81=A3Charlie=8B On Nov 20, 2018, 8:44 PM , at 8:44 PM, Rocketman1988 wrote: >--> AeroElect ric-List message posted by: "Rocketman1988" > > >A nyone have a recommendation on a 12VDC to 5VDC converter that is too >noisy ? > > >Read this topic online here: > >http://forums=2Ematronics=2Ecom/ viewtopic=2Ephp?p=485375#485375 > > = = (And Get Some AWESOME FREE Gifts!) s the Annual List Fund Raiser=2E Click on elow to find out more about fts provided otstore=2Ecom -> http://www=2Ematronics=2Ecom/contribution your generous support! lle, List Admin=2E =================== - The AeroElectric-List Email Forum - res Navigator to browse cription, Photoshare, and much much more: =2Ecom/Navigator?AeroElectric-List so available via the Web Forums! ics=2Ecom ================ EW MATRONICS LIST WIKI - iki! = for your generous support! , List Admin=2E ========= ________________________________________________________________________________
Date: Nov 20, 2018
I bought this $25 wonder from Aircraft Spruce. https://www.aircraftspruce.com/catalog/elpages/eadualusbpanel.php I have not flow with it yet but I expect that it will be just fine. Big plus for me was that it installs in a round hole. -- Art Z. On Tue, Nov 20, 2018 at 8:02 PM Rocketman1988 wrote: > Rocketman(at)etczone.com> > > Anyone have a recommendation on a 12VDC to 5VDC converter that is too > noisy? -- https://CheerfulCurmudgeon.com/ *"Be kind, for everyone you meet is fighting a hard battle."* ________________________________________________________________________________
Date: Nov 20, 2018
Thanks. I am really looking for a 5v supply to drive some servos. There are plenty of switching regulators out there but I am curious as to the effect on the radios... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=485381#485381 ________________________________________________________________________________
Date: Nov 20, 2018
There is a thread on VansAirforce about 5 volt USB ports. http://www.vansairforce.com/community/showthread.php?t=87369 -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=485382#485382 ________________________________________________________________________________
Date: Nov 20, 2018
Not looking for a USB port. Looking for a 5v power supply that will power some servos and have minimal EMI for the radios... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=485383#485383 ________________________________________________________________________________
From: Gerald Champagne <gerald.champagne(at)gmail.com>
Date: Nov 20, 2018
You could use something like this that's specifically designed to power servos that are sitting right next to a radio receiver: http://home.castlecreations.com/becs http://www.castlecreations.com/en/accessories-5/cc-bec-010-0004-00 They're small, they're cheap, they're RF friendly, and the output voltage is programmable. I've used them on several RC projects and they work great. Gerald On Tue, Nov 20, 2018 at 9:33 PM Rocketman1988 wrote: > Rocketman(at)etczone.com> > > Not looking for a USB port. Looking for a 5v power supply that will power > some servos and have minimal EMI for the radios... > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=485383#485383 > > ________________________________________________________________________________
Date: Nov 20, 2018
Or try Max Products Inc's rc regulators. On Tue, Nov 20, 2018, 19:54 Gerald Champagne You could use something like this that's specifically designed to power > servos that are sitting right next to a radio receiver: > > http://home.castlecreations.com/becs > > http://www.castlecreations.com/en/accessories-5/cc-bec-010-0004-00 > > They're small, they're cheap, they're RF friendly, and the output voltage > is programmable. I've used them on several RC projects and they work great. > > Gerald > > > On Tue, Nov 20, 2018 at 9:33 PM Rocketman1988 > wrote: > >> Rocketman(at)etczone.com> >> >> Not looking for a USB port. Looking for a 5v power supply that will >> power some servos and have minimal EMI for the radios... >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=485383#485383 >> >> >> >> >> >> >> ========== >> br> fts!) >> r> > e.com" rel="noreferrer" target="_blank">www.mypilotstore.com >> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >> -Matt Dralle, List Admin. >> ========== >> - >> Electric-List" rel="noreferrer" target="_blank"> >> http://www.matronics.com/Navigator?AeroElectric-List >> ========== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> ========== >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> ========== >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >> ========== >> >> >> >> ________________________________________________________________________________
Date: Nov 21, 2018
If you want to run your ow, I have very good experience with Traco Power DC-DC converters, they come in all kind of varieties, also high power once, they are clean and work perfect since over 15 years in my plane Mouser does sell them Cheers Werner On 21.11.2018 03:51, Rocketman1988 wrote: > > Thanks. I am really looking for a 5v supply to drive some servos. There are plenty of switching regulators out there but I am curious as to the effect on the radios... > > ________________________________________________________________________________
Date: Nov 21, 2018
Subject: Please Make a Contribution to Support Your Lists...
Dear Listers, Just a reminder that November is the Annual List Fund Raiser. Please make a Contribution today to support the continued operation and upgrade of these great List services!! Pick up a really nice free gift with your qualifying Contribution too! The Contribution Site is fast and easy: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 21, 2018
Subject: 12v to 19.5 dc converter
There are dozens on Amazon, to keep my laptop charged, just wondering if s omeone has had good experience (quiet, robust, reasonable output) with any particular brand.=C2- Thanks, Skip ________________________________________________________________________________
Date: Nov 21, 2018
At 08:51 PM 11/20/2018, you wrote: > > >Thanks. I am really looking for a 5v supply to drive some >servos. There are plenty of switching regulators out there but I am >curious as to the effect on the radios... > Unless it's an off-the-shelf device specific to aviation, there is little to be known about their emissions and even then, they may not have been tested in the lab, only operated in one or more airplanes and found to be compatible. Pick any down-converter that meets your performance needs. Adding filtering is generally not a gut-wrenching experience should your particular selection prove 'incompatible'. Bob . . . ________________________________________________________________________________
Date: Nov 22, 2018
One question as there's too many different types of diodes and I'm having trouble finding what I need: any suggestions for what type of diode is needed for the arc-suppression high-current rating line ? If you could provide one brand and item number to point me to the right type that would help me on my way big time. Thanks! -------- Marcel Zwakenberg XS TG || 912ULS || PH-SBR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=485512#485512 ________________________________________________________________________________
Date: Nov 22, 2018
How about 1N5400 Mechanical strength of the wire leads is more important than other characteristics. Arc suppression diodes are connected with the banded end towards positive. The only time that they conduct is for a split second when a coil is de-energized. Even a 1N4148 would probably work if they were not so frail. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=485513#485513 ________________________________________________________________________________
Date: Nov 22, 2018
Thanks Joe! -------- Marcel Zwakenberg XS TG || 912ULS || PH-SBR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=485514#485514 ________________________________________________________________________________
Date: Nov 23, 2018
Subject: Just A Few Days Left...
Dear Listers, There are just a few days left for this year's List Fund Raiser. If you've been putting off making a Contribution until the last minute, well, this is it! The last minute, that is... :-) There are some GREAT new gift selections to choose from this year. I personally want at least three of them! There's probably something you can't live without too! And, best of all it supports your Lists! Please remember that there isn't any sort of commercial advertising on the Lists and the *only* means of keeping these Lists running is through your Contributions during this Fund Raiser. Let's make this a "Black Friday" for the Lists! Please make a Contribution today! http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 23, 2018
Subject: Adding a Fuse Block
Hi Bob I have been flying my RV6A for nearly ten years using your Z-11 wiring system.. This system has worked extremely well. I am currentlyin the process of adding a second radio and audio panel, but have run out of useable tabs on my main & endurance busses. I have a four fuse fuse block that I would like to add to the main buss. If I mount the extra fuse block within six inches of the main bus, can I power it from the main bus power terminal via an unfused #16 wire? The alternative would be to free up a tab on the main bus, run a fused wire from the tab and then move that consumer to the new fuse block. Appreciate you advice. Thanks, John RV6A Sent from my iPhone ________________________________________________________________________________
Subject: Re: Adding a Fuse Block
Date: Nov 23, 2018
> can I power it from the main bus power terminal via an unfused #16 wire? Yes, that is what I would do. Just make absolutely sure that #16 wire has no chance of shorting out. Support it well near the terminations and double insulate it if it will help. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=485599#485599 ________________________________________________________________________________
Date: Nov 23, 2018
Why not use the same size wire that feeds the main bus? 16 ga significantly limits the total carrying capacity of the added bus, and could bite you or future maintainers if a couple of high load devices get added to the new b lock=2E =81=A3Charlie=8B On Nov 23, 2018, 10:05 AM, at 10:05 AM, John Crate wrote: >--> AeroElectric-List message poste d by: John Crate > >Hi Bob > >I have been flying my RV6 A for nearly ten years using your Z-11 wiring >system=2E=2E This system ha s worked extremely well=2E I am currentlyin the >process of adding a secon d radio and audio panel, but have run out of >useable tabs on my main & end urance busses=2E I have a =9Cfour fuse=9D fuse >block that I w ould like to add to the main buss=2E If I mount the extra >fuse block with in six inches of the main bus, can I power it from the >main bus power term inal via an unfused #16 wire? The alternative would >be to free up a tab o n the main bus, run a fused wire from the tab and >then move that consumer to the new fuse block=2E > >Appreciate you advice=2E >Thanks, >John >RV6A > >Sent from my iPhone > =================== -- Please Support Your Lists This Month -- Some AWESOME FREE Gifts!) Raiser=2E Click on bout y: >_ -= List Contribution Web Site: cs=2Ecom/contribution ============ List Email Forum - se ive Search & Download, 7-Day Browse, Chat, FAQ, much more: Electric-List ================= - MATRONICS WEB FORUMS - Web Forums! ========= I - p://wiki=2Ematronics=2Ecom =================== - List Contribution Web Site - port! = --> http://www=2Ematronics=2Ecom/contribution === ________________________________________________________________________________
Date: Nov 21, 2018
Subject: Off line until 11/24
The truck is packed up with tables, chairs and probably too much to eat. We're headed out to the ol' homestead in Airplane City. Be back on line Saturday. Bob . . . ________________________________________________________________________________
Date: Nov 24, 2018
At 04:48 PM 11/22/2018, you wrote: > >How about 1N5400 >Mechanical strength of the wire leads is more important than other >characteristics. Arc suppression diodes are connected with the >banded end towards positive. The only time that they conduct is for >a split second when a coil is de-energized. Even a 1N4148 would >probably work if they were not so frail. In fact, ANY of the 1N54xx series is fine. 5400's may be harder to find than say, a 1N5406. Bob . . . ________________________________________________________________________________
Date: Nov 24, 2018
At 08:56 AM 11/23/2018, you wrote: > >Hi Bob > >I have been flying my RV6A for nearly ten years >using your Z-11 wiring system.. This system has >worked extremely well. I am currentlyin the >process of adding a second radio and audio >panel, but have run out of useable tabs on my >main & endurance busses. I have a =9Cfour >fuse=9D fuse block that I would like to add to >the main buss. If I mount the extra fuse block >within six inches of the main bus, can I power >it from the main bus power terminal via an >unfused #16 wire? The alternative would be to >free up a tab on the main bus, run a fused wire >from the tab and then move that consumer to the new fuse block. Yes . . . just tie the two busses together by-the-bolts with a short pieces of wire. #16 would be okay; you really won't be tying much load onto the new bus. Bob . . . ________________________________________________________________________________
Date: Nov 24, 2018
At 03:50 PM 11/23/2018, you wrote: >Why not use the same size wire that feeds the main bus? 16 ga >significantly limits the total carrying capacity of the added bus, >and could bite you or future maintainers if a couple of high load >devices get added to the new block.' Recall that except for voltage drop considerations, 22AWG under Tefzel doesn't get into trouble at 20A. 16AWG is 4x the cross section of 22AWG. It would be quite sufficient over the distance cited. Bob . . . ________________________________________________________________________________
Date: Nov 24, 2018
Subject: Ford Voltage Regulator
Z-11 shows the S wire of the Ford regulator tied in to the A terminal. Our Hartzell alternator has a dedicated Sta terminal so I'm guessing that the S terminal of the regulator should go to the Sta terminal on the alternator instead of being tied into the alternator switch going to the A terminal? Can anyone please confirm if this makes sense or not? ________________________________________________________________________________
Date: Nov 24, 2018
Subject: Re: Ford Voltage Regulator
Nope, dont do that. The Ford regulator doesnt use the stator terminal. PlanePowers regulator does. Paul Sent from my iPhone > On Nov 24, 2018, at 7:18 PM, Sebastien wrote: > > Z-11 shows the S wire of the Ford regulator tied in to the A terminal. Our Hartzell alternator has a dedicated Sta terminal so I'm guessing that the S terminal of the regulator should go to the Sta terminal on the alternator instead of being tied into the alternator switch going to the A terminal? Can anyone please confirm if this makes sense or not? ________________________________________________________________________________
Date: Nov 25, 2018
At 09:18 PM 11/24/2018, you wrote: >Z-11 shows the S wire of the Ford regulator tied in to the A >terminal. Our Hartzell alternator has a dedicated Sta terminal so >I'm guessing that the S terminal of the regulator should go to the >Sta terminal on the alternator instead of being tied into the >alternator switch going to the A terminal? Can anyone please confirm >if this makes sense or not? The "s" terminal did go to the stator winding in cars . . . but is best paralleled with "a" in airplanes. Ignore the aux, n or s terminals on the alternator. http://www.aeroelectric.com/Reference_Docs/Alternator_Data/Legacy_EM_Regulator_(Ford).pdf This is because the solid state replacement for the Ford E-M regulator is NOT a strictly functional replacement. The "S" terminal does not behave in the same manner as it did on the E-M products. Bob . . . ________________________________________________________________________________
Date: Nov 25, 2018
So for any VR166 regulator and Ford type alternator combination wire as per Z-11. Thank you Bob. On Sun, Nov 25, 2018, 08:46 Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com wrote: > At 09:18 PM 11/24/2018, you wrote: > > Z-11 shows the S wire of the Ford regulator tied in to the A terminal. Our > Hartzell alternator has a dedicated Sta terminal so I'm guessing that the S > terminal of the regulator should go to the Sta terminal on the alternator > instead of being tied into the alternator switch going to the A terminal? > Can anyone please confirm if this makes sense or not? > > > The "s" terminal did go to the stator > winding in cars . . . but is best > paralleled with "a" in airplanes. > Ignore the aux, n or s terminals on > the alternator. > > > http://www.aeroelectric.com/Reference_Docs/Alternator_Data/Legacy_EM_Regulator_(Ford).pdf > > > This is because the solid state replacement > for the Ford E-M regulator is NOT a > strictly functional replacement. The "S" > terminal does not behave in the same > manner as it did on the E-M products. > > Bob . . . > ________________________________________________________________________________
Subject: Re: B lead circuit breaker
Date: Nov 25, 2018
Follow up on field Cb: Now the 5 amp Field CB blew after take off yesterday and could not be reset. A few days before it blew shortly after takeoff and reset and I read 16 co lts briefly. I removed thePlane Power alternator and will send to Montgomery for exchange (hopefully) or repair. It was purchased from Vans in December 2014 but not flying until August 2017 with less than 120 hours. Hope it is under warran ty. Will call them tomorrow morning. Ron Burnett May you have the Lord's blessings today! Sent from my iPad > On Oct 9, 2018, at 8:32 PM, Ron Burnett wrote: > > Bob is correct in that it is the 5 amp Field CB that pops. First time was a year ago, once. Then 3 times on an 8 hour 4 leg cross country. First ti me Wig wags and strobe was on. Turns wig wags off, left strobes on, repoppe d a few minutes later, reset and landed. This was at the end of nearly four hours of flight. > > Four days later took off with strobes on and CB popped. Turned strobe off and flew 4 hours home with no issues. Will check connection on Field wire t o CB. > The voltage regulator is obviously built in the alternator. > > That is all I know, which isn=99t much. > > Thanks, > > Ron Burnett > > May you have the Lord's blessings today! > Sent from my iPad > >> On Oct 9, 2018, at 8:02 AM, Ken Ryan wrote: >> >> Do circuit breakers trip due to high voltage, or due to current overload? >> >>> On Mon, Oct 8, 2018 at 10:30 PM Ron Burnett wro te: >>> Art, >>> >>> Yes, the volt meter shows 14.2 to 14.3 range in flight, unless it spikes I guess? >>> >>> Ron Burnett >>> >>> May you have the Lord's blessings today! >>> Sent from my iPad >>> >>>> On Oct 8, 2018, at 8:51 PM, Art Zemon wrote: >>>> >>>> Ron, >>>> >>>> Do you have a voltmeter in the plane? I am guessing that the circuit br eaker is popping because the voltage is going too high. Maybe a voltage regu lator problem. >>>> >>>> -- Art Z. >>>> >>>>> On Mon, Oct 8, 2018 at 8:34 PM Ron Burnett wr ote: er.net> >>>>> >>>>> I have a Plane Power Alternator on my RV-6A and lately with the Aero Fl ash strobes on at some point the B lead CB will pop. It does reset. Today I flew a 2 leg cross country for 4 hours total, all with the strobes off af ter the popping event 2 minutes into the flight. How would I determine if th eir is a problem with the strobes that might cause this problem? >>>> -- >>>> https://CheerfulCurmudgeon.com/ >>>> >>>> "We do not see the world as it is. We see the world as we are." ________________________________________________________________________________
Date: Nov 25, 2018
Subject: Coming Soon - The List of Contributors - Please Make
A Contribution Today! Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Please take a moment and assure that your name is on that List of Contributors (LOC)! As a number of members have pointed out over the years, the List seems at least as valuable a building / entertainment tool as your typical magazine subscription! Assure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 25, 2018
Not an expert on =9Calternator facts=9D but my understanding is t hat the alternator can put out large voltages and it is the purpose of the V OLTAGE regulator to in effect regulate the output voltage to that useable by the plane, boat or auto. It does this by controlling the field through the p rotective breaker, which, in your case, seems to be breaking. The increased voltage you temporarily saw might be perfectly normal if your v oltage regulator was in its death throes and not regulating properly after w hich it gave up the ghost and would only blow the field breaker All of this is to say that your voltage regulator may be the culprit not the alternator. Keep us apprised about this breaking news Rich Sent from my iPhone > On Nov 25, 2018, at 2:15 PM, Ron Burnett wrote: > > Follow up on field Cb: > > Now the 5 amp Field CB blew after take off yesterday and could not be rese t. A few days before it blew shortly after takeoff and reset and I read 16 c olts briefly. > > I removed thePlane Power alternator and will send to Montgomery for exchan ge (hopefully) or repair. It was purchased from Vans in December 2014 but n ot flying until August 2017 with less than 120 hours. Hope it is under warr anty. > > Will call them tomorrow morning. > > Ron Burnett > > > May you have the Lord's blessings today! > Sent from my iPad > >> On Oct 9, 2018, at 8:32 PM, Ron Burnett wrote: >> >> Bob is correct in that it is the 5 amp Field CB that pops. First time wa s a year ago, once. Then 3 times on an 8 hour 4 leg cross country. First t ime Wig wags and strobe was on. Turns wig wags off, left strobes on, repopp ed a few minutes later, reset and landed. This was at the end of nearly fou r hours of flight. >> >> Four days later took off with strobes on and CB popped. Turned strobe of f and flew 4 hours home with no issues. Will check connection on Field wire to CB. >> The voltage regulator is obviously built in the alternator. >> >> That is all I know, which isn=99t much. >> >> Thanks, >> >> Ron Burnett >> >> May you have the Lord's blessings today! >> Sent from my iPad >> >>> On Oct 9, 2018, at 8:02 AM, Ken Ryan wrote: >>> >>> Do circuit breakers trip due to high voltage, or due to current overload ? >>> >>>> On Mon, Oct 8, 2018 at 10:30 PM Ron Burnett wr ote: >>>> Art, >>>> >>>> Yes, the volt meter shows 14.2 to 14.3 range in flight, unless it spike s I guess? >>>> >>>> Ron Burnett >>>> >>>> May you have the Lord's blessings today! >>>> Sent from my iPad >>>> >>>>> On Oct 8, 2018, at 8:51 PM, Art Zemon wrote: >>>>> >>>>> Ron, >>>>> >>>>> Do you have a voltmeter in the plane? I am guessing that the circuit b reaker is popping because the voltage is going too high. Maybe a voltage reg ulator problem. >>>>> >>>>> -- Art Z. >>>>> >>>>>> On Mon, Oct 8, 2018 at 8:34 PM Ron Burnett w rote: ter.net> >>>>>> >>>>>> I have a Plane Power Alternator on my RV-6A and lately with the Aero Flash strobes on at some point the B lead CB will pop. It does reset. Tod ay I flew a 2 leg cross country for 4 hours total, all with the strobes off a fter the popping event 2 minutes into the flight. How would I determine if t heir is a problem with the strobes that might cause this problem? >>>>> -- >>>>> https://CheerfulCurmudgeon.com/ >>>>> >>>>> "We do not see the world as it is. We see the world as we are." ________________________________________________________________________________
Date: Nov 25, 2018
> > >All of this is to say that your voltage regulator may be the culprit >not the alternator. PlanePower uses the stock, INTERNAL votlage regulator in their automotive->airplane conversions. So in this case, the whole alternator assembly needs to be returned for evaluation. In this instance, it appears that the PlanePower added, crowbar ov management system was doing its job. Bob . . . ________________________________________________________________________________
Date: Nov 26, 2018
Thanks to all who replied. Much appreciated. John ________________________________________________________________________________
Subject: Bitcoin Financial Freedom - 8400% after 48 hours
From: "goldbtc1" <goldenworldinvestmentcom(at)gmail.com>
Date: Nov 27, 2018
Bitcoin Financial Freedom - 8400% after 48 hours We offer a stable partnership that will help you to participate in the greatest world trades and get good income from your investments. The funds you entrust us with will become a part of our investment capital which is managed by skilled professionals and guarantees stable income for at least another 10 years. There is no need to submit the source of income or to disclose personal details, we do not require you to do that. Normally such is required for investments from at least $1M to $10M. If you invest with us, your money becomes a part of a huge pool of funds. Invest Now http://www.bitcoinfinancialfreedom.com Guaranteed Profits http://www.payinghyiponline.com/bitcoinfinancialfreedom.html Read this topic online here: http://forums.matronics.com/viewtopic.php?p=485745#485745 ________________________________________________________________________________
Date: Nov 27, 2018
Subject: What's My Contribution Used For?
Dear Listers, Some have asked, "What's my Contribution used for?" and that's a good question. Here are just a few examples of what your direct List support enables. It provides for the very expensive, commercial-grade Internet connection used on the List insuring maximum performance and minimal contention when accessing List services. It pays for the regular system hardware and software upgrades enabling the highest performance possible for services such as the Archive Search Engine, List Browser, and Forums. It pays for narly 30 years (yeah, I really said *30* years) worth of online archive data available for instant random search and access. And, it offsets the many hours spent writing, developing, and maintaining the custom applications that power this List Service such as the List Browse, Search Engine, Forums, and Wiki. But most importantly, your List Contribution enables a forum where you and your peers can communicate freely in an environment that is free from moderation, censorship, advertising, commercialism, SPAM, and computer viruses. How many places on the Internet can you make all those statements these days? It is YOUR CONTRIBUTION that directly enables these many aspects of these valuable List services. Please support it today with your List Contribution. Its one of the best investments you can make in your Sport... List Contribution Web Site: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you for your support! Matt Dralle Email List Administrator ________________________________________________________________________________
Date: Nov 27, 2018
Subject: A slice of history
https://youtu.be/ncUdqT8AxY0 Bob . . . ________________________________________________________________________________
Subject: Re: A slice of history
Date: Nov 27, 2018
It was awesome being at AirVenture and watching their formation flights. That video is a great find. Thanks. --Rick On 11/27/2018 10:21 AM, Robert L. Nuckolls, III wrote: > > > > https://youtu.be/ncUdqT8AxY0 ________________________________________________________________________________
Subject: Need help with some Z-14 electrical system troubleshooting
Date: Nov 27, 2018
(the Z-14 has 2 buses, 2 alternators and 2 batteries - B&C alternators and regulators, Odyssey batteries) I regularly fly with the 2 buses not interconnected. At cruise I've been seeing between 14.5 and 14.7 volts on both buses. I've been running like that for over a year. On my last flight I noticed the voltage on bus 2 dropped almost 1 volt. It was jumping around between 13.4 and 14.0 volts. I removed various loads to see if perhaps I had a malfunctioning component but this had no effect. I engaged the cross feed to connect the 2 buses. Bus 2 remained at 14 volts or less but was less jumpy staying closer to 14. Bus 1 remained at 14.5 to 14.7. With the cross feed engaged and Bus 2 switched off, the voltage on Bus 2 dropped to between 12.4 and 13.7 With the cross feed engaged, I pulled the CB on the bus 2 regulator taking the #2 regulator/alternator offline. Bus 2 voltage was between 12.8 and 13.5 (bus 1 was 14.5) I don't have a load tester but the bus 2 battery seems okay (12.78volts with no load at 50F). It would seem that I'm getting some current from the alternator but there has been a distinct drop in bus 2 voltage. I would have thought that both buses would have roughly the same voltage when interconnected with the bus 2 alternator offline. I'm looking for some advice on troubleshooting. Thanks! --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Subject: Re: Need help with some Z-14 electrical system troubleshooting
Date: Nov 27, 2018
On 11/27/2018 1:04 PM, Bill Watson wrote: > > > (the Z-14 has 2 buses, 2 alternators and 2 batteries - B&C alternators > and regulators, Odyssey batteries) > > I regularly fly with the 2 buses not interconnected. At cruise I've > been seeing between 14.5 and 14.7 volts on both buses. I've been > running like that for over a year. > > On my last flight I noticed the voltage on bus 2 dropped almost 1 > volt. It was jumping around between 13.4 and 14.0 volts. I removed > various loads to see if perhaps I had a malfunctioning component but > this had no effect. > > I engaged the cross feed to connect the 2 buses. Bus 2 remained at 14 > volts or less but was less jumpy staying closer to 14. Bus 1 remained > at 14.5 to 14.7. > > With the cross feed engaged and Bus 2 switched off, the voltage on Bus > 2 dropped to between 12.4 and 13.7 > > With the cross feed engaged, I pulled the CB on the bus 2 regulator > taking the #2 regulator/alternator offline. Bus 2 voltage was between > 12.8 and 13.5 (bus 1 was 14.5) > > I don't have a load tester but the bus 2 battery seems okay > (12.78volts with no load at 50F). It would seem that I'm getting some > current from the alternator but there has been a distinct drop in bus > 2 voltage. I would have thought that both buses would have roughly > the same voltage when interconnected with the bus 2 alternator offline. > > I'm looking for some advice on troubleshooting. Thanks! > Any chance you have an instrument error issue? If you put a digital meter on each bus, what does it say? If you verify low voltage, maybe a shorted diode in the alternator? Charlie --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Nov 27, 2018
Nice description. My Z14 does show both voltages the same with the crossfeed closed as you surmise. I'd want to verify that the buss 2 voltage is accurate with a separate meter. Next I'd physically disconnect the buss 2 alternator to see what happens. Or measure the current from (or into) the #2 regulator or alternator if you have a current meter. A DC Clamp ON ammeter is handy for rough DC current measurements. (under $20. on ebay). Ken On 2018-11-27 2:04 p.m., Bill Watson wrote: > > > (the Z-14 has 2 buses, 2 alternators and 2 batteries - B&C alternators > and regulators, Odyssey batteries) > > I regularly fly with the 2 buses not interconnected. At cruise I've > been seeing between 14.5 and 14.7 volts on both buses. I've been > running like that for over a year. > > On my last flight I noticed the voltage on bus 2 dropped almost 1 volt. > It was jumping around between 13.4 and 14.0 volts. I removed various > loads to see if perhaps I had a malfunctioning component but this had no > effect. > > I engaged the cross feed to connect the 2 buses. Bus 2 remained at 14 > volts or less but was less jumpy staying closer to 14. Bus 1 remained > at 14.5 to 14.7. > > With the cross feed engaged and Bus 2 switched off, the voltage on Bus 2 > dropped to between 12.4 and 13.7 > > With the cross feed engaged, I pulled the CB on the bus 2 regulator > taking the #2 regulator/alternator offline. Bus 2 voltage was between > 12.8 and 13.5 (bus 1 was 14.5) > > I don't have a load tester but the bus 2 battery seems okay (12.78volts > with no load at 50F). It would seem that I'm getting some current from > the alternator but there has been a distinct drop in bus 2 voltage. I > would have thought that both buses would have roughly the same voltage > when interconnected with the bus 2 alternator offline. > > I'm looking for some advice on troubleshooting. Thanks! > > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus > > > > ________________________________________________________________________________
Date: Nov 28, 2018
A rough guess would be that the alternator possibly has lost one of its high current diodes. On Tue, Nov 27, 2018 at 11:10 AM Bill Watson wrote: > Mauledriver(at)nc.rr.com> > > (the Z-14 has 2 buses, 2 alternators and 2 batteries - B&C alternators > and regulators, Odyssey batteries) > > I regularly fly with the 2 buses not interconnected. At cruise I've > been seeing between 14.5 and 14.7 volts on both buses. I've been > running like that for over a year. > > On my last flight I noticed the voltage on bus 2 dropped almost 1 volt. > It was jumping around between 13.4 and 14.0 volts. I removed various > loads to see if perhaps I had a malfunctioning component but this had no > effect. > > I engaged the cross feed to connect the 2 buses. Bus 2 remained at 14 > volts or less but was less jumpy staying closer to 14. Bus 1 remained > at 14.5 to 14.7. > > With the cross feed engaged and Bus 2 switched off, the voltage on Bus 2 > dropped to between 12.4 and 13.7 > > With the cross feed engaged, I pulled the CB on the bus 2 regulator > taking the #2 regulator/alternator offline. Bus 2 voltage was between > 12.8 and 13.5 (bus 1 was 14.5) > > I don't have a load tester but the bus 2 battery seems okay (12.78volts > with no load at 50F). It would seem that I'm getting some current from > the alternator but there has been a distinct drop in bus 2 voltage. I > would have thought that both buses would have roughly the same voltage > when interconnected with the bus 2 alternator offline. > > I'm looking for some advice on troubleshooting. Thanks! > > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus > > ________________________________________________________________________________
Subject: Noisy voltmeter
Date: Nov 28, 2018
Hi all, I have a question about a problem that i have with my new electrical system. I have a two way switch with 2 voltmeters, one for the main battery and the other one for the aux, still hot battery. When I set this switch on, i have a noise in my headset. And it's the voltmeter one. I wired all my electrical system with the one point ground bus to avoid this kind of problem. I set the noisy voltmeter on the ESS BUS, that is after the diode (my diode is set between the main bus and the ESS BUS. (I wired the Z19 diagram from bob electrical system) Do you have any advice ? (this week I will try to disconect it from ESS BUS and try on the main bus in a first time.) thank you in advance ;) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=485847#485847 ________________________________________________________________________________
Date: Nov 28, 2018
Here is the update on my Plane Power alternator. It was tested at PP and fa iled internally not related to the voltage regulator. A new replacement will arrive tomorrow under warranty. Thank all of you for your ideas and help during this process when the altern ator still operated but kept tripping the field, but would reset and operate normally. Ron Burnett RV-6A L 0360 dual EFII May you have the Lord's blessings today! Sent from my iPad > On Nov 25, 2018, at 8:28 PM, Robert L. Nuckolls, III <nuckolls.bob@aeroele ctric.com> wrote: > >> >> >> All of this is to say that your voltage regulator may be the culprit not t he alternator. > > PlanePower uses the stock, INTERNAL votlage > regulator in their automotive->airplane > conversions. So in this case, the whole > alternator assembly needs to be returned > for evaluation. > > In this instance, it appears that the PlanePower > added, crowbar ov management system was doing its > job. > > Bob . . . ________________________________________________________________________________
Date: Nov 28, 2018
Subject: EarthX Battery Tester
https://earthxbatteries.com/shop/optimate-lithium-battery-charger-lifepo4 The chargers EarthX sell will wait 30 minutes after charging and then check the voltage to see if the voltage has been retained. If it passes, it will wait up to 12 hours and then check again to check for excessive self discharge. Is this sufficient to confirm that the battery is healthy or would some sort of load test also be a good idea? ________________________________________________________________________________
Date: Nov 28, 2018
Subject: Garmin 335 Transponder Installation Manual
Does anyone have a current Installation Manual for a Garmin 335 Transponder that they would be willing to share ? Thanks ! Jeff Page Dream Aircraft Tundra #10 ________________________________________________________________________________
Subject: Re: EarthX Battery Tester
Date: Nov 29, 2018
Looking at the specs that "Lithium" model seems to be identical to the model I have for my Odyssey 545 battery, it also uses the same charging/testing strategy. Having a different model, my experience does not necessarily apply to this one, but I'd like to share it anyway as I had a similar line of thinking when I bought the thing couple of years ago: Mine does a good job of maintaining the voltage level the battery is at and can recover from small discharge levels, but not much more than that. Mine certainly is not capable of recovering from deep discharges. Given those 'limited' capabilities, I do a load charge test one year after bought new (I do this in spring-time), and replace it with a new battery the next year. I want to have a high level of confidence that my battery is capable to deal with a alternator-out situation and allows me to finish the flight as planned when this happens. FYI: I have a single alternator - single battery setup and do daytime VFR only) -------- Marcel Zwakenberg Europa XS TG || 912ULS || PH-SBR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=485865#485865 ________________________________________________________________________________
Subject: Stall warning through Radio
Date: Nov 29, 2018
Hi What kind of input do I use to in-put a 'Stall Warning' sound through the radio John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=485866#485866 ________________________________________________________________________________
Date: Nov 29, 2018
Hi Marcel; Hi All; It is for that very reason that I have two (2) twenty amp, internally regulated, permanent magnet alternators installed. Cheers! Stu. ----- Original Message ----- From: "zwakie" <mz(at)cariama.nl> Sent: Thursday, November 29, 2018 3:47:40 AM Subject: AeroElectric-List: Re: EarthX Battery Tester Looking at the specs that "Lithium" model seems to be identical to the model I have for my Odyssey 545 battery, it also uses the same charging/testing strategy. Having a different model, my experience does not necessarily apply to this one, but I'd like to share it anyway as I had a similar line of thinking when I bought the thing couple of years ago: Mine does a good job of maintaining the voltage level the battery is at and can recover from small discharge levels, but not much more than that. Mine certainly is not capable of recovering from deep discharges. Given those 'limited' capabilities, I do a load charge test one year after bought new (I do this in spring-time), and replace it with a new battery the next year. I want to have a high level of confidence that my battery is capable to deal with a alternator-out situation and allows me to finish the flight as planned when this happens. FYI: I have a single alternator - single battery setup and do daytime VFR only) -------- Marcel Zwakenberg Europa XS TG || 912ULS || PH-SBR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=485865#485865 ________________________________________________________________________________
Subject: Re: Stall warning through Radio
Date: Nov 29, 2018
If all you have now is a stall warning vane and switch, then that switch needs to turn on an audio oscillator which is then connected to an aux audio input on the radio. Search eBay for Assembled Audio Oscillator -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=485868#485868 ________________________________________________________________________________
Date: Nov 29, 2018
Marcel, what do you use for your "load" when you do the load test? Ken On Thu, Nov 29, 2018 at 2:52 AM zwakie wrote: > > Looking at the specs that "Lithium" model seems to be identical to the > model I have for my Odyssey 545 battery, it also uses the same > charging/testing strategy. > > Having a different model, my experience does not necessarily apply to this > one, but I'd like to share it anyway as I had a similar line of thinking > when I bought the thing couple of years ago: > > Mine does a good job of maintaining the voltage level the battery is at > and can recover from small discharge levels, but not much more than that. > Mine certainly is not capable of recovering from deep discharges. > > Given those 'limited' capabilities, I do a load charge test one year after > bought new (I do this in spring-time), and replace it with a new battery > the next year. > > I want to have a high level of confidence that my battery is capable to > deal with a alternator-out situation and allows me to finish the flight as > planned when this happens. FYI: I have a single alternator - single battery > setup and do daytime VFR only) > > -------- > Marcel Zwakenberg > Europa XS TG || 912ULS || PH-SBR > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=485865#485865 > > ________________________________________________________________________________
Date: Nov 29, 2018
kenryan wrote: > Marcel, what do you use for your "load" when you do the load test? One of these: http://www.westmountainradio.com/product_info.php?products_id=cba4 -------- Marcel Zwakenberg Europa XS TG || 912ULS || PH-SBR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=485870#485870 ________________________________________________________________________________
Date: Nov 29, 2018
ashleysc(at)broadstripe.n wrote: > Hi Marcel; > Hi All; > It is for that very reason that I have two (2) twenty amp, internally regulated, permanent magnet alternators installed. > Cheers! Stu. > --- Yeah, I have that on my wishlist too for that same reason but it is lower than what I am working on right now (upgrading panel to glass) as with the new panel I can last over 2 hours on battery only according to load calculations and battery specs ;) -------- Marcel Zwakenberg Europa XS TG || 912ULS || PH-SBR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=485871#485871 ________________________________________________________________________________
Date: Nov 29, 2018
Dear Listers, There are just a Two days left for this year's List Fund Raiser! If you've been putting off making a Contribution until the last minute, well, this is it! The last minute, that is... :-) There are some GREAT new gift selections to choose from this year. I personally want at least three of them! There's probably something you can't live without too! And, best of all it supports your Lists! Please remember that there isn't any sort of commercial advertising on the Lists and the *only* means of keeping these Lists running is through your Contributions during this Fund Raiser. Let's make this a "Black Friday" for the Lists! Please make a Contribution today! http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 29, 2018
> >Mine does a good job of maintaining the voltage level the battery is >at and can recover from small discharge levels, but not much more >than that. Mine certainly is not capable of recovering from deep discharges. > >Given those 'limited' capabilities, I do a load charge test one year >after bought new (I do this in spring-time), and replace it with a >new battery the next year. > >I want to have a high level of confidence that my battery is capable >to deal with a alternator-out situation and allows me to finish the >flight as planned when this happens. FYI: I have a single alternator >- single battery setup and do daytime VFR only) CAPACITY equates to ENDURANCE. This is what the e-bus is for. You can periodically shut off the master switch, close the alternate feed switch and then time how long your battery will support the e-bus loads. Not sure what a 'load charge' test would be. The classic load test at the lead-acid battery factory is to place so much load on the battery that its terminal voltage drops by 1/2. This means that the resistance of the load is equal to internal resistance of the battery. Typical test currents can be well over 1000 amps. This condition is held for x seconds whereupon voltages and currents observed must exceed some minimum value. A capacity test looks at useful energy available in chemical storage. The battery is loaded with y amps (endurance value) and time down to 11 volts (in lead acid world) is noted. This measurement speaks to sustaining battery only flight conditions and is only loosely related to results of any variation on a load test. Lithium internal resistance is so low that the classic Ipp (peak power load test) is impractical. Hence, tests for x seconds at z amps (cranking currents) are practical. Capacity testing remains unchanged. Bob . . . ________________________________________________________________________________
Date: Nov 29, 2018
Thank you Bob. On Thu, Nov 29, 2018 at 11:07 AM Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > > Mine does a good job of maintaining the voltage level the battery is at > and can recover from small discharge levels, but not much more than that. > Mine certainly is not capable of recovering from deep discharges. > > Given those 'limited' capabilities, I do a load charge test one year after > bought new (I do this in spring-time), and replace it with a new battery > the next year. > > I want to have a high level of confidence that my battery is capable to > deal with a alternator-out situation and allows me to finish the flight as > planned when this happens. FYI: I have a single alternator - single battery > setup and do daytime VFR only) > > > CAPACITY equates to ENDURANCE. This is what the > e-bus is for. You can periodically shut off > the master switch, close the alternate feed > switch and then time how long your battery > will support the e-bus loads. > > Not sure what a 'load charge' test would be. > The classic load test at the lead-acid battery > factory is to place so much load on the battery > that its terminal voltage drops by 1/2. This > means that the resistance of the load is equal > to internal resistance of the battery. Typical > test currents can be well over 1000 amps. > > This condition is held for x seconds whereupon > voltages and currents observed must exceed > some minimum value. > > A capacity test looks at useful energy available > in chemical storage. The battery is loaded with > y amps (endurance value) and time down to 11 volts > (in lead acid world) is noted. This measurement > speaks to sustaining battery only flight conditions > and is only loosely related to results of any > variation on a load test. > > Lithium internal resistance is so low that the > classic Ipp (peak power load test) is impractical. > Hence, tests for x seconds at z amps (cranking > currents) are practical. Capacity testing > remains unchanged. > > > Bob . . . > ________________________________________________________________________________
Date: Nov 29, 2018
[quote="nuckolls.bob(at)aeroelect"] > A capacity test looks at useful energy available in chemical storage. The battery is loaded with y amps (endurance value) and time down to 11 volts (in lead acid world) is noted. Thanks for correcting me Bob, and apologies for carelessly writing down he wording "load testing". I indeed meant to write "capacity testing", and the method that you describe here is exactly what I do. -------- Marcel Zwakenberg Europa XS TG || 912ULS || PH-SBR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=485955#485955 ________________________________________________________________________________
Date: Nov 29, 2018
> > >Thanks for correcting me Bob, and apologies for carelessly writing >down he wording "load testing". I indeed meant to write "capacity >testing", and the method that you describe here is exactly what I do. No problem. We're ALL interested in precise speech for it is a fundamental foundation of understanding. Bob . . . ________________________________________________________________________________
Subject: Alkaline battery holder for handheld radio
Date: Nov 29, 2018
Thought I'd post about my surprising experience with alkaline battery holders for my handheld radio. I have two of them and last week when I ran down the Li-ion pack and needed them (after a panel-mount radio failure), both were dead! Not just weak, but dead as a doornail. Both of them. The radio is a Vertex Standard VXA-700 using the FBA-23 battery case for two "AA" cells. (It's my understanding this same battery case is used with the VX-5R, VX-6R, VX-7R, VX-6E, and other radios). http://store.batteriesamerica.com/FBA-23AlkalineBatteryCaseforYAESUVERTEXSTANDARDHORIZON.aspx After landing I put two fresh cells into each and measured the voltage at the battery case terminals. Good: 4.5 volts. Wait, what? How can that be? There are only two AA cells. It turns out that the FBA-23 battery case contains hidden circuitry (a boost converter?) and places a small but constant drain on the batteries even when not installed in the radio. I measured about 50 microamps on the bench. So now my alkaline battery holders are kept without their alkaline cells installed. The cells will last a lot longer in storage if I install them just before use. -- Joe RV-8A Independence, OR -------- RV-8A Independence, OR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=485958#485958 ________________________________________________________________________________
Date: Nov 29, 2018
My new alternator arrived today and I was able to flight test it. The old P P alternator produced 14.2 volts while now I see 14.5. They also blessed me by sending the 70 amp while my return was the 60 amp. I feel that Allen at Hartzell/Plane Power treated me very well. Thanks to all. Ron Burnett May you have the Lord's blessings today! Sent from my iPad > On Nov 28, 2018, at 4:35 PM, Ron Burnett wrote: > > Here is the update on my Plane Power alternator. It was tested at PP and f ailed internally not related to the voltage regulator. A new replacement wil l arrive tomorrow under warranty. > > Thank all of you for your ideas and help during this process when the alte rnator still operated but kept tripping the field, but would reset and opera te normally. > > Ron Burnett RV-6A > L 0360 dual EFII > > May you have the Lord's blessings today! > Sent from my iPad > >> On Nov 25, 2018, at 8:28 PM, Robert L. Nuckolls, III <nuckolls.bob@aeroel ectric.com> wrote: >> >>> >>> >>> All of this is to say that your voltage regulator may be the culprit not the alternator. >> >> PlanePower uses the stock, INTERNAL votlage >> regulator in their automotive->airplane >> conversions. So in this case, the whole >> alternator assembly needs to be returned >> for evaluation. >> >> In this instance, it appears that the PlanePower >> added, crowbar ov management system was doing its >> job. >> >> Bob . . . ________________________________________________________________________________
Subject: Changes in education field and technology
From: "KennethAmpbell" <Kennethampbell(at)protonmail.com>
Date: Nov 29, 2018
Education is not the same as in the olden days now. According to the technology change the educational system is also in the path of change. Students now are growing up in the technology era so that they think and act more intelligently than the older generation. Smart classrooms and better education strategies are really doing wonders in the next generation kids. Students now are also getting help from online resources such as write my essay other than that of the olden time which makes easy for them to manage their curriculum activities. Students can also get educational tips and tricks such as how to succeed. Getting help from experts actually is a better option to achieve success. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=485960#485960 ________________________________________________________________________________
Date: Nov 30, 2018
Subject: [Please Read] - Last Official Day of List Fund Raiser!
Dear Listers, It's November 30th and that always means a couple of things. Its my birthday again - 55! :-) But it also means that it's that last official day of the Matronics Email List Fund Raiser! If you been thinking about picking up one of those really nice incentive gifts now is the time to jump on it!! If you've been meaning to make a Contribution this month but have been putting it off for some reason, NOW is the time! I will be posting the List of Contributors in a few days, so you'll probably want to be known as a person that supported the Lists! I want to thank everyone that has so generously made a Contribution this year in support of our Lists. It is your generosity that keeps this operation running and I don't ever forget it. The List Contribution Web Site is fast and easy. Please support our habit by making your Contribution right now: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you in advance! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 30, 2018
SSBwcmVzdW1lIHlvdSBtZWFuIG9uZSBvZiB0aGVzZToNCg0KaHR0cHM6Ly93d3cuZWJheS5jby51 ay9pdG0vQXNzZW1ibGVkLUxvdy1EaXN0b3J0aW9uLUF1ZGlvLVJhbmdlLU9zY2lsbGF0b3ItMUtI ei1TaW5lLVdhdmUtU2lnbmFsLUdlbmVyYXRvci8xNTMxNjUzMTIzOTQNCg0KUmVnYXJkcw0KDQpK b2huDQoNClNlbnQgZnJvbSBNYWlsIGZvciBXaW5kb3dzIDEwDQoNCkZyb206IHVzZXI5MjUzDQpT ZW50OiAyOSBOb3ZlbWJlciAyMDE4IDE1OjIyDQpUbzogYWVyb2VsZWN0cmljLWxpc3RAbWF0cm9u aWNzLmNvbQ0KU3ViamVjdDogQWVyb0VsZWN0cmljLUxpc3Q6IFJlOiBTdGFsbCB3YXJuaW5nIHRo cm91Z2ggUmFkaW8NCg0KLS0+IEFlcm9FbGVjdHJpYy1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiAi dXNlcjkyNTMiIDxmcmFuc2V3QGdtYWlsLmNvbT4NCg0KSWYgYWxsIHlvdSBoYXZlIG5vdyBpcyBh IHN0YWxsIHdhcm5pbmcgdmFuZSBhbmQgc3dpdGNoLCB0aGVuIHRoYXQgc3dpdGNoIG5lZWRzIHRv IHR1cm4gb24gYW4gYXVkaW8gb3NjaWxsYXRvciB3aGljaCBpcyB0aGVuIGNvbm5lY3RlZCB0byBh biBhdXggYXVkaW8gaW5wdXQgb24gdGhlIHJhZGlvLiAgU2VhcmNoIGVCYXkgZm9yIEFzc2VtYmxl ZCBBdWRpbyBPc2NpbGxhdG9yDQoNCi0tLS0tLS0tDQpKb2UgR29yZXMNCg0KDQoNCg0KUmVhZCB0 aGlzIHRvcGljIG9ubGluZSBoZXJlOg0KDQpodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20vdmll d3RvcGljLnBocD9wPTQ4NTg2OCM0ODU4NjgNCg0KDQoNCg0KDQoNCl8tPT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQpfLT0NCl8tPSAg ICAgICAtLSBQbGVhc2UgU3VwcG9ydCBZb3VyIExpc3RzIFRoaXMgTW9udGggLS0NCl8tPSAgICAg ICAgICAgKEFuZCBHZXQgU29tZSBBV0VTT01FIEZSRUUgR2lmdHMhKQ0KXy09DQpfLT0gICBOb3Zl bWJlciBpcyB0aGUgQW5udWFsIExpc3QgRnVuZCBSYWlzZXIuICBDbGljayBvbg0KXy09ICAgdGhl IENvbnRyaWJ1dGlvbiBsaW5rIGJlbG93IHRvIGZpbmQgb3V0IG1vcmUgYWJvdXQNCl8tPSAgIHRo aXMgeWVhcidzIFRlcnJpZmljIEZyZWUgSW5jZW50aXZlIEdpZnRzIHByb3ZpZGVkDQpfLT0gICBi eToNCl8tPSAgIA0KXy09ICAgICAqIE15IFBpbG90IFN0b3JlIHd3dy5teXBpbG90c3RvcmUuY29t DQpfLT0NCl8tPSAgIExpc3QgQ29udHJpYnV0aW9uIFdlYiBTaXRlOg0KXy09DQpfLT0gICAtLT4g aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbg0KXy09DQpfLT0gICBUaGFuayB5 b3UgZm9yIHlvdXIgZ2VuZXJvdXMgc3VwcG9ydCENCl8tPQ0KXy09ICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgLU1hdHQgRHJhbGxlLCBMaXN0IEFkbWluLg0KXy09DQpfLT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KXy09ICAg ICAgICAgIC0gVGhlIEFlcm9FbGVjdHJpYy1MaXN0IEVtYWlsIEZvcnVtIC0NCl8tPSBVc2UgdGhl IE1hdHJvbmljcyBMaXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0byBicm93c2UNCl8tPSB0aGUgbWFu eSBMaXN0IHV0aWxpdGllcyBzdWNoIGFzIExpc3QgVW4vU3Vic2NyaXB0aW9uLA0KXy09IEFyY2hp dmUgU2VhcmNoICYgRG93bmxvYWQsIDctRGF5IEJyb3dzZSwgQ2hhdCwgRkFRLA0KXy09IFBob3Rv c2hhcmUsIGFuZCBtdWNoIG11Y2ggbW9yZToNCl8tPQ0KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0 cm9uaWNzLmNvbS9OYXZpZ2F0b3I/QWVyb0VsZWN0cmljLUxpc3QNCl8tPQ0KXy09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCl8tPSAg ICAgICAgICAgICAgIC0gTUFUUk9OSUNTIFdFQiBGT1JVTVMgLQ0KXy09IFNhbWUgZ3JlYXQgY29u dGVudCBhbHNvIGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMhDQpfLT0NCl8tPSAgIC0tPiBo dHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20NCl8tPQ0KXy09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCl8tPSAgICAgICAgICAgICAg LSBORVcgTUFUUk9OSUNTIExJU1QgV0lLSSAtDQpfLT0gQWRkIHNvbWUgaW5mbyB0byB0aGUgTWF0 cm9uaWNzIEVtYWlsIExpc3QgV2lraSENCl8tPSAgIC0tPiBodHRwOi8vd2lraS5tYXRyb25pY3Mu Y29tDQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PQ0KXy09ICAgICAgICAgICAgIC0gTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGUg LQ0KXy09ICBUaGFuayB5b3UgZm9yIHlvdXIgZ2VuZXJvdXMgc3VwcG9ydCENCl8tPSAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgIC1NYXR0IERyYWxsZSwgTGlzdCBBZG1pbi4NCl8tPSAgIC0t PiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uDQpfLT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KDQoNCg0KDQo ________________________________________________________________________________
Date: Nov 30, 2018
Subject: Re: Changes in education field and technology
At 10:24 PM 11/29/2018, you wrote: > IGNORE . . . not a subscribed Lister . . . Bob . . . ________________________________________________________________________________
Date: Nov 30, 2018
Subject: Re: Fuse rating on AWG 20 wire with AeroLED strobes?
At 07:59 PM 11/29/2018, you wrote: >I found the Bussmann ATC fuse specs, looks like a 7.5A fuse should >be fine for brief pulses up to 8.5A from the strobes, and should >also be acceptable for protecting the wire notwithstanding the >AC43.13 table that says to use 5A fuse for AWG 20. So I think I >answered my own question with more research, but please advise if >you see anything wrong with this approach. 20AWG is protected at 7A in most TC aircraft. But keep in mind that UNLIKE circuit breakers, fuses can be "hammered" by short duration transients that exceed the fuse rating. "Hammering" contributed to the sequence of events that brought N811HB down . . . https://tinyurl.com/msfmldj There are no risks associated with up-sizing the 20AWG protection to the next level. I'd be quite comfortable with 10A for your application. Bob . . . ________________________________________________________________________________
Date: Nov 30, 2018
Yes, something like that is what I had in mind. If someone else has a suggestion, please post. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=486058#486058 ________________________________________________________________________________
Date: Nov 30, 2018
Joe, you might try searching eBay for voice recorder module. There are several variants that can record whatever you wish, and play it back when triggered. Prices start at $0.99. Eric ________________________________________________________________________________
Date: Dec 01, 2018
Good suggestion Eric. I have one of those voice recorders along with an airspeed switch on my RV-12 to warn of unlatched canopy during takeoff roll. - - John, search eBay for item number 332182973272, (Diy Kit 16-Tone) I used one of those to make a toy for grand kids. The description mentions voice, but there is no voice, just sounds. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=486064#486064 ________________________________________________________________________________
Date: Dec 01, 2018
Those do-it-yourself kits require that aircraft voltage be reduced, perhaps to 5 volts. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=486067#486067 ________________________________________________________________________________
Date: Dec 01, 2018
At 08:50 AM 12/1/2018, you wrote: > >Those do-it-yourself kits require that aircraft voltage be reduced, >perhaps to 5 volts. Emacs! How about this? Bob . . . ________________________________________________________________________________
Subject: Buy Apple iPhone Xs Max (Website www.esellibuy.com) $999CAD
Date: Dec 01, 2018
Buy Apple iPhone Xs Max Read this topic online here: http://forums.matronics.com/viewtopic.php?p=486084#486084 ________________________________________________________________________________
Date: Dec 03, 2018
At 10:40 PM 12/2/2018, you wrote: >When you say 'unlike circuit breakers'...what do you mean? Would >the CB trip more quickly than a fuse would blow, or would it be more >tolerant of what you're calling 'hammering'? Both devices operated based on temperature rise caused by current generated heating. Breakers are bi-metal 'thermostats' . . . they trip at a calibrated temperature which is NOT affected by previous excursions up to the edge of tripping. A CB is good for thousands of trip cycles with very little change in performance. Fuses are pieces of metal designed to heat up and melt at a predictable temperature. A characteristic that can be tailored to a current flow through the 'sensing' metal. But operating a fuse at its recommended 'limit' (75% of rating) produces SOME heating. This means that a fuse under normal load is already some way up the I(squared)R trip ladder when it is presented with transient 'overloads'. These little pushes into trip territory can cause mini-melts to occur in the fusible material which has the effect of lowering the fuse's rating. Repeated 'hammering' will seriously compromise predictability of that fuse to carry normal loads. When N811HB lost both ignition systems on base to the runway, the single fuse carrying BOTH ignition systems had been loaded to more than 75% on several occasions with short excursions to over 100%. Compromised fuse predictability combined with poor choices in architecture to kill the engine. >And your last statement 'there are no risks associated with >up-sizing the 20 AWG protection to the next level', do you mean >using a 10A fuse with 20 AWG, or are you saying to increase wire gauge to 18? '20AWG protection' is classically pegged at 7A. Raising it to 10A or even 15A in this situation will stand off the 'hammering' effects. It is not a risky thing to do. It will eliminate the possibility of nuisance tripping. Given that the lights do not represent a critical flight system, you could leave the 7A fuse in place and see how it goes. If you experience a nuisance trip, up-size the fuse. Let us know what you discover . . . Bob . . . ________________________________________________________________________________
Date: Dec 03, 2018
I did a little experiment on Saturday after having finalized the wiring on my strobes. Specs ask for 5A fuse, so I put a 5A fuse in and lighted up the strobes. Having read this post on Friday night, I was expecting the fuse to blow, but I was very surprised to see that happen so quickly (literally well within 10 seconds). A 7.5A fuse did hold while keeping the strobes on for more than 2-3 minutes, but to be safe I 'upped' the fuse to 10A and will 'up' the two short leads from fuse block to switch to the beefy wiring that a previous owner has put in to match the 10A fuse. I will also review the determined fuse-sizes for other circuits that (can possibly) carry transient loads. This was an educational experiment.... ;) -------- Marcel Zwakenberg Europa XS TG || 912ULS || PH-SBR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=486118#486118 ________________________________________________________________________________
Date: Dec 03, 2018
There are lots of ways to make an alarm tone. The Forrest Mims Engineer's Notebook (my favorite book) has some circuits. https://www.zpag.net/Electroniques/Kit/The%20Forrest%20Mims%20Engineers%20Notebook.pdf On page 55 is a gated tone source. Grounding a pin on a 74LS368 turns on the tone. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=486120#486120 ________________________________________________________________________________
Date: Dec 03, 2018
At 04:35 PM 12/3/2018, you wrote: > >There are lots of ways to make an alarm tone. >The Forrest Mims Engineer's Notebook (my favorite book) has some circuits. >https://www.zpag.net/Electroniques/Kit/The%20Forrest%20Mims%20Engineers%20Notebook.pdf >On page 55 is a gated tone source. Grounding a pin on a 74LS368 >turns on the tone. Boy . . . there's a classic. I've recommended that publication dozens of times over the years. An excellent learning tool. Bob . . . ________________________________________________________________________________
Date: Dec 04, 2018
Subject: operating a relay with a cell phone
I bought a GSM Gate Opener GSM Remote Switch RTU5024, figuring I would use it to control a DPST relay on the plug-in wire to my Tanis pre-heat system, allowing me to turn it on and off using my cell phone. It has two inputs for 12v DC (+ and -) to power it. The other connections are labeled NO COM NC. I understand that NO means "normally open" COM means "common" and NC means "normally closed" I am not clear as to how I would incorporate a relay for turning my 110 volt circuit on and off. If the kind soul who helps could include a recommendation as to the specific relay, that would be great! Please help this dummy. Ken ________________________________________________________________________________
Subject: Re: operating a relay with a cell phone
Date: Dec 04, 2018
On 12/4/2018 6:01 PM, Ken Ryan wrote: > I bought a GSM Gate Opener GSM Remote Switch RTU5024, figuring I would > use it to control a DPST relay on the plug-in wire to my Tanis > pre-heat system, allowing me to turn it on and off using my cell phone. > > It has two inputs for 12v DC (+ and -) to power it. The other > connections are labeled NO COM NC. > > I understand that NO means "normally open" COM means "common" and NC > means "normally closed" I am not clear as to how I would incorporate a > relay for turning my 110 volt circuit on and off. If the kind soul who > helps could include a recommendation as to the specific relay, that > would be great! Please help this dummy. > > Ken > > Hi Ken, If it's this model: https://www.amazon.com/Opener-Remote-Access-Sliding-RTU5024/dp/B07BT3N4QM/ref=asc_df_B07BT3N4QM/?tag=hyprod-20&linkCode=df0&hvadid=241942959786&hvpos=1o2&hvnetw=g&hvrand=9161805644825714517&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9013952&hvtargid=pla-458426103553&psc=1 one of the images on that page shows the relay as having 'dry' contacts. See the image the shows 220VAC feeding through the NO / COM contacts to run a motor. You can wire 110VAC the same way to your heater. *BUT* : you need to find the current rating of the relay contacts, to be sure you won't be overloading them with your heater. If the heater load exceeds the relay contact rating, you can still use it by adding a heavier external relay, driven by the relay in the opener. You'll likely have to configure the switch to be continuous 'on' instead of momentary 'on' which would be the case for a gate controller. Check back if you need a wiring diagram for an external relay. Charlie --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Dec 04, 2018
Here is a schematic diagram. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=486130#486130 Attachments: http://forums.matronics.com//files/tanis_heater_173.jpg ________________________________________________________________________________
Date: Dec 04, 2018
How many watts is the Tanis heater? If it is 400 watts or more, then a heavy duty relay needs to be added. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=486132#486132 ________________________________________________________________________________
Date: Dec 04, 2018
Joe, the Tanis is only 230 watts, but I'm reluctant to use the RTU5024 as the main relay. I was planning to use a separate heavy duty relay for the main relay, and use the RTU5024 to control it. Can you show me how I would do that (control a relay with a relay)? Also if you could give me a Mouser part number for an appropriate relay, that would really fix me up. On Tue, Dec 4, 2018 at 5:16 PM user9253 wrote: > > How many watts is the Tanis heater? If it is 400 watts or more, then a > heavy duty relay needs to be added. > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=486132#486132 > > ________________________________________________________________________________
Date: Dec 04, 2018
Charlie, yes I think that is what I need. A wiring diagram for using a separate relay. The RTU5024 is programmable to be on for a set period of time. It can also be programmed to only accept command from authorized numbers, etc. And supposedly I don't need a phone plan for it, only a sim card. If it works out as I hope, it will be really neat. On Tue, Dec 4, 2018 at 5:03 PM Charlie England wrote : > ceengland7(at)gmail.com> > > On 12/4/2018 6:01 PM, Ken Ryan wrote: > > I bought a GSM Gate Opener GSM Remote Switch RTU5024, figuring I would > > use it to control a DPST relay on the plug-in wire to my Tanis > > pre-heat system, allowing me to turn it on and off using my cell phone. > > > > It has two inputs for 12v DC (+ and -) to power it. The other > > connections are labeled NO COM NC. > > > > I understand that NO means "normally open" COM means "common" and NC > > means "normally closed" I am not clear as to how I would incorporate a > > relay for turning my 110 volt circuit on and off. If the kind soul who > > helps could include a recommendation as to the specific relay, that > > would be great! Please help this dummy. > > > > Ken > > > > > > > Hi Ken, > > If it's this model: > > https://www.amazon.com/Opener-Remote-Access-Sliding-RTU5024/dp/B07BT3N4QM /ref=asc_df_B07BT3N4QM/?tag=hyprod-20&linkCode=df0&hvadid=241942959 786&hvpos=1o2&hvnetw=g&hvrand=9161805644825714517&hvpone=&hvptwo= &hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9013952&hvtargid=p la-458426103553&psc=1 > > one of the images on that page shows the relay as having 'dry' contacts. > See the image the shows 220VAC feeding through the NO / COM contacts to > run a motor. You can wire 110VAC the same way to your heater. *BUT* : > you need to find the current rating of the relay contacts, to be sure > you won't be overloading them with your heater. If the heater load > exceeds the relay contact rating, you can still use it by adding a > heavier external relay, driven by the relay in the opener. You'll likely > have to configure the switch to be continuous 'on' instead of momentary > 'on' which would be the case for a gate controller. > > Check back if you need a wiring diagram for an external relay. > > Charlie > > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus > =========== =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Dec 04, 2018
I know that it isn't as much fun as building something cool out of a cell phone radio and a relay, but you can just buy a mechanical thermostat for next to nothing. Here is one for $27 at Grainger https://www.grainger.com/product/DAYTON-Line-Volt-Mechanical-Tstat-2E815 -- Art Z. -- https://CheerfulCurmudgeon.com/ *"Be kind, for everyone you meet is fighting a hard battle."* ________________________________________________________________________________
Date: Dec 04, 2018
You can buy a 30 amp relay at an auto parts store. Ignore the B beside the battery. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=486135#486135 Attachments: http://forums.matronics.com//files/tanis_heater__116.jpg ________________________________________________________________________________
Date: Dec 04, 2018
Art, my goal is not to regulate the temperature of the engine, it is to control the on/off switch via cell phone, so that I can phone in the night before and the engine will be toasty the next morning, ready for service. On Tue, Dec 4, 2018 at 6:49 PM Art Zemon wrote: > I know that it isn't as much fun as building something cool out of a cell > phone radio and a relay, but you can just buy a mechanical thermostat for > next to nothing. Here is one for $27 at Grainger > https://www.grainger.com/product/DAYTON-Line-Volt-Mechanical-Tstat-2E815 > > -- Art Z. > > -- > https://CheerfulCurmudgeon.com/ > > *"Be kind, for everyone you meet is fighting a hard battle."* > ________________________________________________________________________________
Date: Dec 04, 2018
Okay, so an automotive relay like we would use on our airplanes would be okay for this application, too. I have a few lying around. On Tue, Dec 4, 2018 at 6:52 PM user9253 wrote: > > You can buy a 30 amp relay at an auto parts store. > Ignore the B beside the battery. > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=486135#486135 > > > Attachments: > > http://forums.matronics.com//files/tanis_heater__116.jpg > > ________________________________________________________________________________
Date: Dec 05, 2018
Well it would work. But would not be legal or particularly fire safe as it certainly isn't rated for 120 volts. Definitely the kind of thing that an insurance investigator likes to find. Of course turning on any kind of heating device when no one is around entails some risk anyway... Ken On 2018-12-04 11:16 p.m., Ken Ryan wrote: > Okay, so an automotive relay like we would use on our airplanes would be > okay for this application, too. I have a few lying around. > > On Tue, Dec 4, 2018 at 6:52 PM user9253 > wrote: > > > > > You can buy a 30 amp relay at an auto parts store. > Ignore the B beside the battery. > > -------- > Joe Gores > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=486135#486135 > > > > > Attachments: > > http://forums.matronics.com//files/tanis_heater__116.jpg > > > > ========== > br> fts!) > r> > e.com" rel="noreferrer" target="_blank">www.mypilotstore.com > rel="noreferrer" target="_blank">http://www.matronics.com/contribution > -Matt Dralle, List Admin. > ========== > - > Electric-List" rel="noreferrer" > target="_blank">http://www.matronics.com/Navigator?AeroElectric-List > ========== > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > ========== > WIKI - > errer" target="_blank">http://wiki.matronics.com > ========== > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" target="_blank">http://www.matronics.com/contribution > ========== > > > ________________________________________________________________________________
Date: Dec 05, 2018
At 06:46 AM 12/5/2018, you wrote: > >Well it would work. >But would not be legal or particularly fire safe as it certainly >isn't rated for 120 volts. Definitely the kind of thing that an >insurance investigator likes to find. Of course turning on any kind >of heating device when no one is around entails some risk anyway... >Ken The S704 style plastic relays are quite suited to this task. According to the users manual, output from the device is a set of form-c dry contacts rated at 3A so a 'buffer relay' is called for. Consider a solid state device like this https://tinyurl.com/y9qh9wq4 You can use the n.o./common contacts of the receiver to control power to the SSR input. You can 'steal' power from the same supply that operates the receiver. There are no regulatory issues (aside from local fire marshals) for this project. If it's not bolted to the airframe, it's of no interest to the feds. I'd mount the receiver and solid state relay on the wall of the hangar and provide an outlet to an extension cord that powers the Tanis heater in its normal operating configuration. Risks (beyond failure to function) are zero. Bob . . . ________________________________________________________________________________
Date: Dec 05, 2018
Okay, when I started this I thought, like Barry, that a second relay would be required. But thanks to Joe I now understand that the RTU5024 is well rated (3A/240AC) to handle the power required by the Tanis (2A/115AC) and so I will wire it up as he suggested, directly untilizing the relay in the RTU5024. Makes the whole thing much simpler. Thanks Joe. On Tue, Dec 4, 2018 at 5:04 PM user9253 wrote: > > Here is a schematic diagram. > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=486130#486130 > > > Attachments: > > http://forums.matronics.com//files/tanis_heater_173.jpg > > ________________________________________________________________________________
Date: Dec 05, 2018
Okay change of plan, thanks much Bob. Ken On Wed, Dec 5, 2018, 06:58 Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com wrote: > At 06:46 AM 12/5/2018, you wrote: > > > Well it would work. > But would not be legal or particularly fire safe as it certainly isn't > rated for 120 volts. Definitely the kind of thing that an insurance > investigator likes to find. Of course turning on any kind of heating device > when no one is around entails some risk anyway... > Ken > > > The S704 style plastic relays are quite > suited to this task. According to the > users manual, output from the device > is a set of form-c dry contacts rated > at 3A so a 'buffer relay' is called for. > > Consider a solid state device like this > > https://tinyurl.com/y9qh9wq4 > > You can use the n.o./common contacts > of the receiver to control power to > the SSR input. You can 'steal' power > from the same supply that operates the > receiver. > > There are no regulatory issues (aside > from local fire marshals) for this > project. If it's not bolted to the airframe, > it's of no interest to the feds. > > I'd mount the receiver and solid state relay > on the wall of the hangar and provide an > outlet to an extension cord that powers > the Tanis heater in its normal operating > configuration. Risks (beyond failure to > function) are zero. > > > Bob . . . > ________________________________________________________________________________
Date: Dec 05, 2018
At 09:52 AM 12/5/2018, you wrote: >Okay, when I started this I thought, like Barry, that a second relay >would be required. But thanks to Joe I now understand that the >RTU5024 is well rated (3A/240AC) to handle the power required by the >Tanis (2A/115AC) and so I will wire it up as he suggested, directly >untilizing the relay in the RTU5024. Makes the whole thing much >simpler. Thanks Joe. Opps . . . the Tanis only take 2A? Hmmm . . . one COULD use the receiver's built in relay although I'd still tend toward adding the buffer relay with the following caveats: Current through the receiver's relay contacts is VERY low when driving an SSR . . . after some period of time in service, corrosion build on the receiver relay contacts MIGHT cause the n.o. contacts to go 'open'. Not likely but still something to throw in the trouble-shooting bucket if the critter quits. If you elect to use the built in relay, then contact 'cleaning' will not be an issue. I think I'd add a 5A fuse in series with 120vac power to the Tanis . . . if for whatever reason, current in that loop is faulted, it would be cool if the event didn't smoke the internal relay (probably not easy to replace). Hmmmm . . . only 250 watts to heat the engine? My propane 'dragons' on K1K1 certainly put out a lot more heat but they had to play catchup in minutes. 250W continuously applied over-night may well be enough. Learned something new today. Bob . . . ________________________________________________________________________________
Date: Dec 05, 2018
On 12/5/2018 12:45 PM, Robert L. Nuckolls, III wrote: > At 09:52 AM 12/5/2018, you wrote: >> Okay, when I started this I thought, like Barry, that a second relay >> would be required. But thanks to Joe I now understand that the >> RTU5024 is well rated (3A/240AC) to handle the power required by the >> Tanis (2A/115AC) and so I will wire it up as he suggested, directly >> untilizing the relay in the RTU5024. Makes the whole thing much >> simpler. Thanks Joe. > > Opps . . . the Tanis only take 2A? Hmmm . . . > one COULD use the receiver's built in > relay although I'd still tend toward adding > the buffer relay with the following caveats: > > Current through the receiver's relay contacts > is VERY low when driving an SSR . . . after some > period of time in service, corrosion build on > the receiver relay contacts MIGHT cause the > n.o. contacts to go 'open'. Not likely but > still something to throw in the trouble-shooting > bucket if the critter quits. > > If you elect to use the built in relay, then > contact 'cleaning' will not be an issue. I > think I'd add a 5A fuse in series with 120vac > power to the Tanis . . . if for whatever reason, > current in that loop is faulted, it would > be cool if the event didn't smoke the internal > relay (probably not easy to replace). > > Hmmmm . . . only 250 watts to heat the engine? > My propane 'dragons' on K1K1 certainly put out > a lot more heat but they had to play catchup > in minutes. 250W continuously applied over-night > may well be enough. Learned something new today. > > > Bob . . . > Probably using something like this: http://www.chiefaircraft.com/ez-440a.html?gclid=Cj0KCQiAi57gBRDqARIsABhDSMrkaMXwANnl_DM_XXVmvLX8YXFhCmJF86d9J7_YQdXyxxqLc23o_IwaAhVKEALw_wcB bonded directly to the oil pan. --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Dec 05, 2018
>> . . >Probably using something like this: ><http://www.chiefaircraft.com/ez-440a.html?gclid=Cj0KCQiAi57gBRDqARIsABhDSMrkaMXwANnl_DM_XXVmvLX8YXFhCmJF86d9J7_YQdXyxxqLc23o_IwaAhVKEALw_wcB>http://www.chiefaircraft.com/ez-440a.html?gclid=Cj0KCQiAi57gBRDqARIsABhDSMrkaMXwANnl_DM_XXVmvLX8YXFhCmJF86d9J7_YQdXyxxqLc23o_IwaAhVKEALw_wcB >bonded directly to the oil pan. cool! Thanks! Bob . . . ________________________________________________________________________________
Date: Dec 05, 2018
Bob, the Tanis is well documented to work extremely well. There are five bolts that replace engine bolts (one for each cylinder, and one in the engine case) that act as resistance heaters and there is also a pad to heat the oil in the Rotax external oil tank, so the heat goes directly into the engine. Here is a link to a short 11:19 video showing careful testing under controlled conditions: https://rotax-owner.com/en/videos-topmenu/product-reviews/149-tanis Ken On Wed, Dec 5, 2018 at 9:51 AM Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 09:52 AM 12/5/2018, you wrote: > > Okay, when I started this I thought, like Barry, that a second relay would > be required. But thanks to Joe I now understand that the RTU5024 is well > rated (3A/240AC) to handle the power required by the Tanis (2A/115AC) and > so I will wire it up as he suggested, directly untilizing the relay in the > RTU5024. Makes the whole thing much simpler. Thanks Joe. > > > Opps . . . the Tanis only take 2A? Hmmm . . . > one COULD use the receiver's built in > relay although I'd still tend toward adding > the buffer relay with the following caveats: > > Current through the receiver's relay contacts > is VERY low when driving an SSR . . . after some > period of time in service, corrosion build on > the receiver relay contacts MIGHT cause the > n.o. contacts to go 'open'. Not likely but > still something to throw in the trouble-shooting > bucket if the critter quits. > > If you elect to use the built in relay, then > contact 'cleaning' will not be an issue. I > think I'd add a 5A fuse in series with 120vac > power to the Tanis . . . if for whatever reason, > current in that loop is faulted, it would > be cool if the event didn't smoke the internal > relay (probably not easy to replace). > > Hmmmm . . . only 250 watts to heat the engine? > My propane 'dragons' on K1K1 certainly put out > a lot more heat but they had to play catchup > in minutes. 250W continuously applied over-night > may well be enough. Learned something new today. > > > Bob . . . > ________________________________________________________________________________
Date: Dec 05, 2018
Bob, I don't know about Tanis. I have a Reiff with a 50W band around each cylinder and a 100W pad on the oil sump. -- Art Z. On Wed, Dec 5, 2018 at 1:04 PM Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > Hmmmm . . . only 250 watts to heat the engine? > My propane 'dragons' on K1K1 certainly put out > -- https://CheerfulCurmudgeon.com/ *"Be kind, for everyone you meet is fighting a hard battle."* ________________________________________________________________________________
Date: Dec 05, 2018
I have the Reiff turbo system with 100W cylinder bands, TWO 100w pads on the sump and a 100W pad on the oil cooler. It's 700W. Last week I left it plugged in over night (28 degree low) and when I went flying in the morning the oil was at 121 degrees. If I plug it in before flight at that temp it's at least an hour before I'm comfortable with the engine temperature. The dragon can more or less do it in a quarter of that time. --Rick On 12/5/2018 3:11 PM, Art Zemon wrote: > Bob, > > I don't know about Tanis. I have a Reiff with a 50W band around each > cylinder and a 100W pad on the oil sump. > > -- Art Z. > > On Wed, Dec 5, 2018 at 1:04 PM Robert L. Nuckolls, III > > > wrote: > > Hmmmm . . . only 250 watts to heat the engine? > My propane 'dragons' on K1K1 certainly put out > > ________________________________________________________________________________
Subject: Bob Archer comm antenna dimensions ?
Date: Dec 08, 2018
Hi all, Some 15 years ago we ordered a Bob Archer comm antenna for installation in our wingtip, and have been very satisfied with it. Here is a sketch of our 15 year old antenna : A buddy of mine launches into another project and just received a new Archer antenna to install in his tail fin, but the dimensions and shape seem different, and the rivets prevent the upper segment from being swept up to fit into the tail. Although the antenna is labelled "Comm", we are finally not sure the model is a VHF one. Does any of you gentlemen have any information as to the shape and dimensions of the present time Archer comm antennas - or VOR antennas - so we could clarify the matter ? Thanks in advance, -- Best regards, Gilles http://contrails.free.fr http://lapierre.skunkworks.free.fr ________________________________________________________________________________
Subject: Re: Bob Archer comm antenna dimensions ?
Date: Dec 08, 2018
On 12/8/2018 11:46 AM, GTH wrote: > > Hi all, > > Some 15 years ago we ordered a Bob Archer comm antenna for > installation in our wingtip, and have been very satisfied with it. > > Here is a sketch of our 15 year old antenna : > > > A buddy of mine launches into another project and just received a new > Archer antenna to install in his tail fin, but the dimensions and > shape seem different, and the rivets prevent the upper segment from > being swept up to fit into the tail. > > Although the antenna is labelled "Comm", we are finally not sure the > model is a VHF one. > > Does any of you gentlemen have any information as to the shape and > dimensions of the present time Archer comm antennas - or VOR antennas > - so we could clarify the matter ? > > > Thanks in advance, > > > -- > Best regards, > Gilles > http://contrails.free.fr > http://lapierre.skunkworks.free.fr Pretty sure that if you could see side by side images of all the Sportcraft antennas, you'd see significant differences among the various antennas. IIRC, there are different models for RV-4-8, the -9, & -10 wing tips. The vertical fin would be yet another design. The VOR antennas would be yet another set. Did he make sure that the model he bought is recommended for his a/c, and for the location where he intends to mount it? Charlie --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Dec 08, 2018
/Le 08/12/2018 19:49, Charlie England a crit: / > /Pretty sure that if you could see side by side images of all the > Sportcraft antennas, you'd see significant differences among the > various antennas. IIRC, there are different models for RV-4-8, the > -9, & -10 wing tips. The vertical fin would be yet another design. The > VOR antennas would be yet another set. > / / > Did he make sure that the model he bought is recommended for his a/c, > and for the location where he intends to mount it? > / Hi Charlie, Thank you for responding. His project is a composite homebuilt that certainly no one knows outside our country. The antenna is to be located in the glass fiber fin, but as it is a small airplane, there no room for a 1/2 wave antenna. Provided the model is a correct comm antenna the actual question is, can we pivot the radiating element so as to match the fin, like in red in the following diagram Of course this would involve removing some rivets, but from an electrical point of view, would such a "sweep" be acceptable ? Thank you, -- Best regards, Gilles http://contrails.free.fr http://lapierre.skunkworks.free.fr ________________________________________________________________________________
Date: Dec 08, 2018
On Sat, Dec 8, 2018 at 1:42 PM GTH wrote: > > *Le 08/12/2018 =C3- 19:49, Charlie England a =C3=A9crit : * > > > *Pretty sure that if you could see side by side images of all the > Sportcraft antennas, you'd see significant differences among the various > antennas. IIRC, there are different models for RV-4-8, the -9, & -10 win g > tips. The vertical fin would be yet another design. The VOR antennas woul d > be yet another set. * > > * Did he make sure that the model he bought is recommended for his a/c, > and for the location where he intends to mount it? * > > > Hi Charlie, > > Thank you for responding. > His project is a composite homebuilt that certainly no one knows outside > our country. > The antenna is to be located in the glass fiber fin, but as it is a small > airplane, there no room for > a 1/2 wave antenna. > Provided the model is a correct comm antenna the actual question is, can > we pivot the radiating element so as to match the fin, like in red in the > following diagram > > > Of course this would involve removing some rivets, but from an electrical > point of view, would such a "sweep" be acceptable ? > > Thank you, > > -- > Best regards, > Gilles > http://contrails.free.fr > http://lapierre.skunkworks.free.fr > I'm no antenna expert, but I'd bet that a base loaded whip (like a 'rubber ducky' off a handheld) would work about as well as radically altering the tuning of the Archer antenna. Or maybe not. :-) Virus-free. www.avast.com <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> ________________________________________________________________________________
Date: Dec 08, 2018
Gilles, I used to be an antenna expert. The Archer antenna should work better with the radiating element unbent. I n fact, it would work best with the radiating element at 90 degrees to the base. But you might have a bigger issue. This antenna requires a mass of metal, like a wing, electrically connected along the base to serve as a gro und plane. Does the aircraft have a metal fuselage or stabilizer. Another issue is the rudder tube, if metal. If the distance from the front of the rudder to the antenna radiator is too short, say around a foot or t wo, you will have a null in your reception toward the rear. The problem is even worse if the rudder is also metal. A possible solution might be a bent 1/2 wave dipole. The 1/4 wave part fed by the coax center wire would fit up the fin from the base, essentially th e same as the radiating element on the Archer. The other half of the dipol e would be attached forward to the underside of the fuselage top. The shie ld of the coax would be attached to this other half. Sort of an L in profi le from the right side with the coax cable attached at the bend. I would u se copper sheet 1/2 - 3/4 inch wide for the elements. If this simple antenna is not possible for some reason then more complex ar rangements start appearing such as dual end coil loaded dipoles. This coul d be made to fit in the fin but then you are getting into the area of much tinkering and antenna analyzers, etc. Tom Kuffel --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Dec 08, 2018
Gilles, What model Archer antenna does your friend have. Archer offers a compresse d dipole (looks like a weird "3") model SA006 which is 26.5" tall by 12" wi de. At some $190 it is a bit pricey but should fit if your unbent wing tip mode l would have. Tom --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Dec 09, 2018
/Le 09/12/2018 06:26, The Kuffels a crit: / > // > // > // > /What model Archer antenna does your friend have. Archer offers a > compressed dipole (looks like a weird "3") model SA006 which is 26.5" > tall by 12" wide./ > // > // Hi all, Thank you to all who answered. My friend's model is the SA001A. He just mentionned the SA006 which could have been used, but he has already received the SA001A. Here are some info about the present project : It is a very small airplane, in the 100hp/140kt cruise category. The fuselage is carbon fiber, with the fin, rudder post and rudder intentionally made of glass fiber (shown in red below) : We will try to "unbend" the radiating element to have it more perpendicular to the base/ground element and fit in the tail fin, and as advised I'll borrow a SWR-meter to verify this does not harm the antenna efficiency. Our intention is to use the same principle as in our first project to connect the antenna ground element to the carbon fuselage. Concerning this first project, still flying - and transmitting - great after 15 years. At the time Bob Archer kindly answered our many questions, and here is how we installed the antenna with great success : The antenna is located in the right wingtip, intentionally made of glass instead of carbon as the rest of the airplane : saumon Mr Archer told us that would could "unbend" the radiating element to match the wingtip shape. He also gave his advice on how to connect the ground element to the wing carbon skin : http://contrails.free.fr/images/instruments/Alum_Foil.gif Thank you for your help, -- Best regards, Gilles http://contrails.free.fr http://lapierre.skunkworks.free.fr ________________________________________________________________________________
Date: Dec 09, 2018
At 11:46 AM 12/8/2018, you wrote: >Hi all, > >Some 15 years ago we ordered a Bob Archer comm antenna for >installation in our wingtip, and have been very satisfied with it. > >Here is a sketch of our 15 year old antenna : > >[] > > >A buddy of mine launches into another project and just received a >new Archer antenna to install in his tail fin, but the dimensions >and shape seem different, and the rivets prevent the upper segment >from being swept up to fit into the tail. > >Although the antenna is labelled "Comm", we are finally not sure the >model is a VHF one. > >Does any of you gentlemen have any information as to the shape and >dimensions of the present time Archer comm antennas - or VOR >antennas - so we could clarify the matter ? > Antennas come in a constellation of shapes and sizes tailored FIRST to be efficient at the transmission/reception of radio energy. The antenna you've cited was originally a VOR antenna designed to mount under the wing tip of an RV. [] The short, horizontal section riveted to the close-out rib of the wing. It's essentially a bent, 1/4 wave radiator with a 'gamma match'. Further, due to it's operational orientation wtih the earth, it's fundamentally a horizontally polarized antenna. https://tinyurl.com/ycxlsd4d Later in Bob's OBAM aviation efforts, he offered a slightly smaller (Comm frequencies) version (1A) https://tinyurl.com/y9xenkj6 but it too was intended for use on METAL aricraft with non-metallic fin/tip caps. When this antenna is installed on the wing, it's deficiencies as a horizontally polarized antenna are partially offset by attaching the base in the lowest practical orientation on the rib and deflecting the radiating element upward until flush with the upper, inside surface of the wing tip fairing. Many builders have reported good results with this compromised configuration as a COMM antenna. Nonetheless, this antenna is not suitable for use on a totally composite aircraft as it depends on metallic structure for a ground plane. Bob . . . ________________________________________________________________________________
Date: Dec 10, 2018
/Le 09/12/2018 16:24, Robert L. Nuckolls, III a crit: / > / > Nonetheless, this antenna is not suitable > for use on a totally composite aircraft > as it depends on metallic structure for > a ground plane./ Bob, Thank you for taking the time to answer. As mentioned in a previous message, we have had great success with Bob Archer's wingtip antenna, possibly due to the carbon fiber wing playing the role of the metallic structure ? We took special care to ensure good electrical contact between the antenna ground element and the carbon wing skin. Also our wingtip curves up to vertical, so the radiating element is nearly vertical, which may have helped. Our VHF range is currently 100/150 nautical miles @ 2000 ft QNH, and of course much more (though useless) at higher altitudes. -- Best regards, Gilles http://contrails.free.fr http://lapierre.skunkworks.free.fr ________________________________________________________________________________
Date: Dec 10, 2018
Subject: Re: Ford Voltage Regulator
Well it's working now but not the way I expected. I rewired everything to match Z-11 (except for the OVM, it's on its way) and started the engine, no juice: Battery volts only. Further investigation revealed that the builder thought the current limiter base was the actual current limiter. Installed the current limiter and everything now works fine. Which leads me to wonder, while the engine was running and there was no current load on the alternator, what were the regulator and alternator doing? I assume that the regulator seeing a constant 12 V would be driving the alternator to maximum voltage in order to try to raise the bus voltage. How high a voltage can one of these alternators produce at 2000 RPM? On Sun, Nov 25, 2018 at 8:53 AM Sebastien wrote: > So for any VR166 regulator and Ford type alternator combination wire as > per Z-11. > > Thank you Bob. > > On Sun, Nov 25, 2018, 08:46 Robert L. Nuckolls, III < > nuckolls.bob(at)aeroelectric.com wrote: > >> At 09:18 PM 11/24/2018, you wrote: >> >> Z-11 shows the S wire of the Ford regulator tied in to the A terminal. >> Our Hartzell alternator has a dedicated Sta terminal so I'm guessing that >> the S terminal of the regulator should go to the Sta terminal on the >> alternator instead of being tied into the alternator switch going to the A >> terminal? Can anyone please confirm if this makes sense or not? >> >> >> The "s" terminal did go to the stator >> winding in cars . . . but is best >> paralleled with "a" in airplanes. >> Ignore the aux, n or s terminals on >> the alternator. >> >> >> http://www.aeroelectric.com/Reference_Docs/Alternator_Data/Legacy_EM_Regulator_(Ford).pdf >> >> >> This is because the solid state replacement >> for the Ford E-M regulator is NOT a >> strictly functional replacement. The "S" >> terminal does not behave in the same >> manner as it did on the E-M products. >> >> Bob . . . >> > ________________________________________________________________________________
Date: Dec 10, 2018
Subject: Fwd: [FlyRotary] avionics minefields....
This is a cross-post; I also sent it to an alternative engine list where I'm a member. Hope it's useful. Charlie If any of you guys out there tend toward OCD and are currently wiring your plane, here's a heads-up. I probably know too much (or maybe not enough) for my own good about electrical stuff, including issues like electrical noise & ground loops. So when I created the wiring harnesses for my RV-7 a couple of years ago, I tried to make sure I avoided ground-related issues by carefully routing grounds *exactly* where they should be according to the avionics documentation, and making my best educated guess when I couldn't find any good documentation. Well, I laid a couple of mines, & didn't step on them until I installed the instruments to do a test powerup, prior to closing out the fuselage. The intercom wouldn't power up, and neither would my Anderson engine monitor. After spending a couple of days digging through my extensive (but not very well done) notes, I found the sources of my problems. The intercom has a 'floating' chassis, and you're directed to run the ground wire to the radio. I did this; running the ground to the power ground in the GNS430's tray. I also thought it would be smart to ground the Anderson monitor to the main ground point in the EC-2, so I tied it to pins 19 & 37, which are then grounded to the engine block. (I documented the power connections well, but the ground side...not so much.) So on my 1st real power-up test of the system, not wanting to put multiple high dollar instruments at risk, I only powered or installed a single instrument at a time. Anyone see the mines yet? Charlie Virus-free. www.avast.com <#m_-783036987977688554_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> ________________________________________________________________________________
Date: Dec 10, 2018
No personal experience, but from what I have read, an alternator can put out well over 100 volts when lightly loaded and field current at maximum. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=486212#486212 ________________________________________________________________________________
Date: Dec 10, 2018
At 11:39 AM 12/10/2018, you wrote: >Well it's working now but not the way I expected. I rewired >everything to match Z-11 (except for the OVM, it's on its way) and >started the engine, no juice: Battery volts only. Further >investigation revealed that the builder thought the current limiter >base was the actual current limiter. Installed the current limiter >and everything now works fine. > >Which leads me to wonder, while the engine was running and there was >no current load on the alternator, what were the regulator and >alternator doing? I assume that the regulator seeing a constant 12 V >would be driving the alternator to maximum voltage in order to try >to raise the bus voltage. How high a voltage can one of these >alternators produce at 2000 RPM? Without knowing the alternator's minimum rpm for regulation value, it cannot be predicted accurately . . . but it IS pretty high. A runaway alternator on a Lycoming (hi ratio belt drive) at cruise rpm can be spectacular. Probably over 200 volts. Fortunately, the only risk for no-load operation is to the rectifiers. If everything seems normal after the critter was properly wired, then the rectifiers are probably okay. Bob . . . ________________________________________________________________________________
Date: Dec 10, 2018
Subject: Re: Cheap bench supply?
On Tue, Nov 13, 2018 at 4:59 PM Charlie England wrote: > Anyone have experience with the recent ebay offerings for cheap lab > supplies? Example below. I tried searching my old AEC emails, but the most > recent reference I found was for a much more expensive model. It'll get > minimal use; just final checkout of my project's wiring and then rare uses > after that, so don't want to spend $hundreds. > 0-30v/0-10a bench supply > > > Thanks, > > Charlie > Well, I said I'd publish a pirep once I received the unit, so here we go. The unit seems to work just fine, with a couple of 'idiosyncrasies'. The controls are analog, as you'd expect from the pairs of coarse & fine adjustment knobs. The only frustrating thing is that current limit is set by setting voltage to some reasonably low value, setting current to minimum, shorting out the + & - terminals, and then dialing up the current knobs to the desired limit. Then remove the short and connect your load. At loads less than the current set point, the voltage display shows your set point voltage (actual output voltage). The current display will vary between zero and the current set point, depending on actual load. Once the current limit is reached, voltage (and the displayed voltage, of course) falls to limit current to the preset level. Behavior of the supply is as expected, but it is frustrating to not see the actual current limit set point while in operation, until you actually hit the limit. Since the knobs are unmarked, this requires going back through the limit setting for each new work session, unless you trust that the current limit knobs haven't been touched since the last session. The ideal supply would have both set point and output displays, but for my limited needs, I don't need to pay for ideal. :-) Assuming long term survival, I consider it a great value compared to the $hundreds required for lab grade supplies. Charlie Virus-free. www.avast.com <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> ________________________________________________________________________________
Date: Dec 10, 2018
Hi Charlie; Bought one. Haven't used it yet. Check back. Cheers! Stu. ----- Original Message ----- From: "Charlie England" <ceengland7(at)gmail.com> Sent: Monday, December 10, 2018 12:29:39 PM Subject: Re: AeroElectric-List: Cheap bench supply? On Tue, Nov 13, 2018 at 4:59 PM Charlie England < ceengland7(at)gmail.com > wrote: Anyone have experience with the recent ebay offerings for cheap lab supplies? Example below. I tried searching my old AEC emails, but the most recent reference I found was for a much more expensive model. It'll get minimal use; just final checkout of my project's wiring and then rare uses after that, so don't want to spend $hundreds. 0-30v/0-10a bench supply Thanks, Charlie Well, I said I'd publish a pirep once I received the unit, so here we go. The unit seems to work just fine, with a couple of 'idiosyncrasies'. The controls are analog, as you'd expect from the pairs of coarse & fine adjustment knobs. The only frustrating thing is that current limit is set by setting voltage to some reasonably low value, setting current to minimum, shorting out the + & - terminals, and then dialing up the current knobs to the desired limit. Then remove the short and connect your load. At loads less than the current set point, the voltage display shows your set point voltage (actual output voltage). The current display will vary between zero and the current set point, depending on actual load. Once the current limit is reached, voltage (and the displayed voltage, of course) falls to limit current to the preset level. Behavior of the supply is as expected, but it is frustrating to not see the actual current limit set point while in operation, until you actually hit the limit. Since the knobs are unmarked, this requires going back through the limit setting for each new work session, unless you trust that the current limit knobs haven't been touched since the last session. The ideal supply would have both set point and output displays, but for my limited needs, I don't need to pay for ideal. :-) Assuming long term survival, I consider it a great value compared to the $hundreds required for lab grade supplies. Charlie Virus-free. www.avast.com ________________________________________________________________________________
Date: Dec 10, 2018
> >Behavior of the supply is as expected, but it is frustrating to not >see the actual current limit set point while in operation, until you >actually hit the limit. Since the knobs are unmarked, this requires >going back through the limit setting for each new work session, >unless you trust that the current limit knobs haven't been touched >since the last session. The ideal supply would have both set point >and output displays, but for my limited needs, I don't need to pay >for ideal. :-) > >Assuming long term survival, I consider it a great value compared to >the $hundreds required for lab grade supplies. Your observations are typical of every knob-adjusted power supply I've worked with for decades. The only devices with pre-set current/voltage values are digitally addressed. I have one of these guys in my stable: https://tinyurl.com/ydxv9edb It performs as advertised but in my opinion, not nearly as 'agile' as the 4-knob, analog supplies. But I do confess to being functionally predisposed. Been using those critters since '63. Bob . . . ________________________________________________________________________________
Date: Dec 10, 2018
Subject: Wiring Harness Questions
Gentlemen (no offense to any women who might monitor this forum), Aircraft = RV-8 I have removed old EFIS, autopilot, transponder, and radio equipment and I am replacing it with newer stuff. The electrical system is 12 volt. I am installing: Advanced Flight 5800 GTN650 ARINC 429 Dynon Com 425 VHF radio Dynon autopilot PS Engineering PDA360EX remote audio panel Echo UAT I am building a wiring harness to allow the PDA360EX to talk to the GTN650 and Com 425 radio and AFS5800. I have called each of the manufacturers asking for information to correctly wire the harness. Of course, Garmin will not even talk to me. I called AFS and they say - you need to call PS Engineering. I called PS Engineering and they say - you need to call AFS. Same results with Dynon. Everyone points the finger at the other company and nobody wants to be bothered. So, I am here to ask if anyone has made a harness between the PDA360EX and a GTN650. If so, perhaps you can give me some guidance. Or perhaps you know of someone who will build the harness for a reasonable price. My local avionics shop wants $800. I understand it is not worth their time and they have to make money to stay open, but that price is too high. PS Engineering will not build a harness for me. AFS and others (haven't checked with Steinair) also want a rather steep price. But, if you know of someone who can make the harness for a reasonable price, I am willing to pay for it to be built. However, I am going to press on as if I am going to do the entire build myself. I have numerous questions about the connections, so I will ask about a few wires at a time then go and pin them and come back and ask the next question. Maybe, over time, I will be able to eat this elephant one bite at a time. 1. On the PDA360EX audio panel J1 wiring diagram, it lists connections from Com 1 (GTN650 in my case) as being Com 1 audio Hi Com 1 Lo Com 1 MIC Audio Hi Com 1 MIC Key On the GTN650, the P1001 connector has the following Audio Out HI - pin 4 Audio Out Lo - pin 23 And on the P1003 (Com) connector it has Com MIC 1 Audio IN HI - pin 5 500 ohm Com Audio HI - pin 7 Com MIC 1 Key - pin 11 500 ohm Com Audio LO - pin 18 MIC Audio IN LO - pin 20 I am familiar with the requirement to use shielded 2 and 3 wire cables and the requirement to tie the shield grounds together at the audio panel end and ONLY at that end. But, can I assume that PDA360EX Com 1 Audio Hi connects to GTN650 Audio Out HI? Can I assume that PDA360EX Com 1 LO connects to GTN650 Audio Out LO? Can I assume that PDA360EX Com 1 MIC Audio Hi connects to GTN650 Com MIC 1 Audio IN HI? Can I assume that PDA360EX Com 1 MIC Key connects to GTN650 Com MIC 1 Key? What are the 500 ohm Com Audio HI and LO used for, if anything? In advance, thanks for your help. I will digest these answers, do the wiring, and come back with more questions. Thanks, Stan Sutterfield Daytona Beach ________________________________________________________________________________
Date: Dec 10, 2018
For those of us who do not care about limiting the current, is there a cheaper way of getting 20A between 5 and 30V? On Mon, Dec 10, 2018, 20:49 Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com wrote: > > Behavior of the supply is as expected, but it is frustrating to not see > the actual current limit set point while in operation, until you actually > hit the limit. Since the knobs are unmarked, this requires going back > through the limit setting for each new work session, unless you trust that > the current limit knobs haven't been touched since the last session. The > ideal supply would have both set point and output displays, but for my > limited needs, I don't need to pay for ideal. :-) > > Assuming long term survival, I consider it a great value compared to the > $hundreds required for lab grade supplies. > > > Your observations are typical of every knob-adjusted power > supply I've worked with for decades. The only devices > with pre-set current/voltage values are digitally > addressed. I have one of these guys in my stable: > > https://tinyurl.com/ydxv9edb > > It performs as advertised but in my opinion, > not nearly as 'agile' as the 4-knob, analog > supplies. But I do confess to being functionally > predisposed. Been using those critters since > '63. > > > Bob . . . > ________________________________________________________________________________
Date: Dec 11, 2018
One can usually replace the analog current potentiometer with a multi position rotary switch and fixed resistors if preferred. I find that about 6 positions suits my bench supply just fine. Ken On 10/12/2018 3:29 PM, Charlie England wrote: > > > On Tue, Nov 13, 2018 at 4:59 PM Charlie England > wrote: > > Anyone have experience with the recent ebay offerings for cheap > lab supplies? Example below. I tried searching my old AEC emails, > but the most recent reference I found was for a much more > expensive model. It'll get minimal use; just final checkout of my > project's wiring and then rare uses after that, so don't want to > spend $hundreds. > 0-30v/0-10a bench supply > > > Thanks, > > Charlie > > > Well, I said I'd publish a pirep once I received the unit, so here we go. > > The unit seems to work just fine, with a couple of 'idiosyncrasies'. > The controls are analog, as you'd expect from the pairs of coarse & > fine adjustment knobs. The only frustrating thing is that current > limit is set by setting voltage to some reasonably low value, setting > current to minimum, shorting out the+ & - terminals, and then dialing > up the current knobs to the desired limit. Then remove the short and > connect your load. At loads less than the current set point, the > voltage display shows your set point voltage (actual output voltage). > The current display will vary between zero and the current set point, > depending on actual load. Once the current limit is reached, voltage > (and the displayed voltage, of course) falls to limit current to the > preset level. > > Behavior of the supply is as expected, but it is frustrating to not > see the actual current limit set point while in operation, until you > actually hit the limit. Since the knobs are unmarked, this requires > going back through the limit setting for each new work session, unless > you trust that the current limit knobs haven't been touched since the > last session. The ideal supply would have both set point and output > displays, but for my limited needs, I don't need to pay for ideal. :-) > > Assuming long term survival, I consider it a great value compared to > the $hundreds required for lab grade supplies. > > Charlie > > > Virus-free. www.avast.com > > > ________________________________________________________________________________
Date: Dec 11, 2018
Get some number transfers so you can set the knobs to the same settings you require. Set the top to 11 and watch "Spinal Tap" for a giggle. :-} Rick On Tue, Dec 11, 2018 at 6:18 AM C&K wrote: > > One can usually replace the analog current potentiometer with a multi > position rotary switch and fixed resistors if preferred. I find that > about 6 positions suits my bench supply just fine. > Ken > > On 10/12/2018 3:29 PM, Charlie England wrote: > > > > > > On Tue, Nov 13, 2018 at 4:59 PM Charlie England > > wrote: > > > > Anyone have experience with the recent ebay offerings for cheap > > lab supplies? Example below. I tried searching my old AEC emails, > > but the most recent reference I found was for a much more > > expensive model. It'll get minimal use; just final checkout of my > > project's wiring and then rare uses after that, so don't want to > > spend $hundreds. > > 0-30v/0-10a bench supply > > < > https://www.ebay.com/itm/10A-Digital-DC-Power-Supply-Variable-Adjustable- Lab-Bench-Test-Equipment-Tool/202435783331?ssPageName=STRK%3AMEBIDX%3AIT& _trksid=p2060353.m1438.l2649 > > > > > > Thanks, > > > > Charlie > > > > > > Well, I said I'd publish a pirep once I received the unit, so here we g o. > > > > The unit seems to work just fine, with a couple of 'idiosyncrasies'. > > The controls are analog, as you'd expect from the pairs of coarse & > > fine adjustment knobs. The only frustrating thing is that current > > limit is set by setting voltage to some reasonably low value, setting > > current to minimum, shorting out the + & - terminals, and then dialing > > up the current knobs to the desired limit. Then remove the short and > > connect your load. At loads less than the current set point, the > > voltage display shows your set point voltage (actual output voltage). > > The current display will vary between zero and the current set point, > > depending on actual load. Once the current limit is reached, voltage > > (and the displayed voltage, of course) falls to limit current to the > > preset level. > > > > Behavior of the supply is as expected, but it is frustrating to not > > see the actual current limit set point while in operation, until you > > actually hit the limit. Since the knobs are unmarked, this requires > > going back through the limit setting for each new work session, unless > > you trust that the current limit knobs haven't been touched since the > > last session. The ideal supply would have both set point and output > > displays, but for my limited needs, I don't need to pay for ideal. :-) > > > > Assuming long term survival, I consider it a great value compared to > > the $hundreds required for lab grade supplies. > > > > Charlie > > > > < > https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_ campaign=sig-email&utm_content=webmail&utm_term=icon> > > > Virus-free. www.avast.com > > < > https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_ campaign=sig-email&utm_content=webmail&utm_term=link> > > > > > > =========== =========== =========== =========== =========== =========== > > -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> ________________________________________________________________________________
Subject: Re: A brown-out alternative?
Date: Dec 11, 2018
I received the last bit today (DC/DC converter) and had some time to kill this evening, so I built the circuit and tested it successfully on the bench. I used a Ripca 2152C for the relay and this little critter as the buck-boost converter: https://www.ebay.ca/itm/6-35V-to-1-35V-DC-DC-Buck-Boost-Charger-Power-Converter-Module-With-AluminumSG-/123523715069?oid=112837380675 , along with the diode(s) previously recommended. It will be a little while before I reach the point with my panel upgrade to glass before I can confirm it really prevents a brownout. I will report back when the time comes (hopefully in 2-3 weeks from now). -------- Marcel Zwakenberg Europa XS TG || 912ULS || PH-SBR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=486241#486241 ________________________________________________________________________________
Subject: Re: Question on Grounding
Date: Dec 12, 2018
Good evening. Looking for a portable boombox https://freebears.com/tdk-boombox with a good sound. At the moment I have a boombox with 2 speakers, USB input, CDs and radio. I bought about 5 years ago. A lot of time has passed, and I want more quality. I watched jvc rv-nb70, but was discontinued. Sharp GX-BT9H - seems to be on sale ... Can you please tell me what are the quality options? Those two that I wrote above, like and externally, and fit the parameters. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=486254#486254 ________________________________________________________________________________
Date: Dec 12, 2018
At 04:08 PM 12/11/2018, you wrote: > >I received the last bit today (DC/DC converter) and had some time to >kill this evening, so I built the circuit and tested it successfully >on the bench. > >I used a Ripca 2152C for the relay and this little critter as the >buck-boost converter: >https://www.ebay.ca/itm/6-35V-to-1-35V-DC-DC-Buck-Boost-Charger-Power-Converter-Module-With-AluminumSG-/123523715069?oid=112837380675 >, along with the diode(s) previously recommended. > >It will be a little while before I reach the point with my panel >upgrade to glass before I can confirm it really prevents a brownout. >I will report back when the time comes (hopefully in 2-3 weeks from now). Excellent! Bob . . . ________________________________________________________________________________
Date: Dec 12, 2018
IGNORE - NOT A REGISTERED MEMBER OF THE LIST - IGNORE At 11:00 AM 12/12/2018, you wrote: > >Good evening. Looking for a portable boombox >https://freebears.com/tdk-boombox with a good sound. At the moment I >have a boombox with 2 speakers, USB input, CDs and radio. I bought >about 5 years ago. A lot of time has passed, and I want more >quality. I watched jvc rv-nb70, but was discontinued. Sharp GX-BT9H >- seems to be on sale ... Can you please tell me what are the >quality options? Those two that I wrote above, like and externally, >and fit the parameters. Bob . . . ________________________________________________________________________________
Date: Dec 13, 2018
At 12:12 AM 12/11/2018, you wrote: >For those of us who do not care about limiting the current, is there >a cheaper way of getting 20A between 5 and 30V? That's going to be a 600W supply . . . pretty rare in the constellation of off-shore offerings to hobbyists. Fixed voltage supplies in that power class are readily available, here's one example https://tinyurl.com/y6tw6k6o Adjustable supplies with that capability are more likely to be found as used, lab grade power supplies like this excellent buy https://tinyurl.com/ybgkh4ov . . . but trust me, supplies in this power class are capable of much smoke. You will come to LOVE that current limiting feature. Bob . . . ________________________________________________________________________________
Date: Dec 13, 2018
That excellent buy costs $92 to ship. It must be big and heavy. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=486278#486278 ________________________________________________________________________________
Date: Dec 13, 2018
At 12:42 PM 12/13/2018, you wrote: > >That excellent buy costs $92 to ship. It must be big and heavy. Yup . . . probably 40 pounds. They're rack mounted supplies about 9 inches high. I have one on my bench. Had it about 15 years and it was 10-15 years old when I got it. It's HP . . . built to last. Probably cost about $3000 new. Bob . . . ________________________________________________________________________________
Date: Dec 13, 2018
At 12:42 PM 12/13/2018, you wrote: > >That excellent buy costs $92 to ship. It must be big and heavy. Yup . . . probably 40 pounds. They're rack mounted supplies about 9 inches high. I have one on my bench. Had it about 15 years and it was 10-15 years old when I got it. It's HP . . . built to last. Probably cost about $3000 new. CORRECTION. Closer to 40 years old when I got it and they're 93 pounds. Bob . . . ________________________________________________________________________________
Date: Dec 13, 2018
Subject: star washers
Bob, In the recent weeks/months I "think" I saw what appear to me to be contradicting posts regarding the use of star washers. In one discussion I thought you said that star washers are never used in the current path on any certified airplanes. I think the reason was that they prevent the gas tight seal that will inhibit corrosion. Then, in a second discussion about bus bar construction using brass bars, I thought you said to be sure to use a star washer under each terminal. Could you clear up my confusions as to your approach to using star washers in an aircraft electrical system? Thanks, Ken ________________________________________________________________________________
Date: Dec 13, 2018
The HP stands for =9Cheavy product=9D. ;-) On Thu, Dec 13, 2018 at 12:03 Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 12:42 PM 12/13/2018, you wrote: > > > That excellent buy costs $92 to ship. It must be big and heavy. > > > Yup . . . probably 40 pounds. They're rack mounted > supplies about 9 inches high. I have one on my > bench. Had it about 15 years and it was > 10-15 years old when I got it. It's HP . . . built > to last. Probably cost about $3000 new. > > CORRECTION. Closer to 40 years old when I > got it and they're 93 pounds. > > > Bob . . . > ________________________________________________________________________________
Date: Dec 14, 2018
Subject: Re: star washers
Hi Ken; I think star washers would make good electrical contact, but I don't like them against aluminum, as they can initiate cracks. Cheers! Stu. ----- Original Message ----- From: "Ken Ryan" <keninalaska(at)gmail.com> Sent: Thursday, December 13, 2018 1:21:13 PM Subject: AeroElectric-List: star washers Bob, In the recent weeks/months I "think" I saw what appear to me to be contradicting posts regarding the use of star washers. In one discussion I thought you said that star washers are never used in the current path on any certified airplanes. I think the reason was that they prevent the gas tight seal that will inhibit corrosion. Then, in a second discussion about bus bar construction using brass bars, I thought you said to be sure to use a star washer under each terminal. Could you clear up my confusions as to your approach to using star washers in an aircraft electrical system? Thanks, Ken ________________________________________________________________________________
Date: Dec 14, 2018
At 03:21 PM 12/13/2018, you wrote: >Bob, > >In the recent weeks/months I "think" I saw what >appear to me to be contradicting posts regarding the use of star washers. > >In one discussion I thought you said that star >washers are never used in the current path on >any certified airplanes. I think the reason was >that they prevent the gas tight seal that will inhibit corrosion. > >Then, in a second discussion about bus bar >construction using brass bars, I thought you >said to be sure to use a star washer under each terminal. > >Could you clear up my confusions as to your >approach to using star washers in an aircraft electrical system?=C2 > >Thanks, > >Ken I spent a few minutes searching the term 'star washers' in the list archives. Generally, the use of star washers in the electrical path was discouraged. If used at all, they were for mechanical security (i.e. used under a nut). Couldn't look at all the search hits, but the few I found were consistent with the above. Just for grins, I checked a Brand-C parts catalog for battery contactor installations and found this image: Emacs! Here we see a lockwasher called out as part of the assembly. It's used under a nut that secures a terminal post to the 'wing' of an H6041 mil-style contactor. It doesn't have a numerical call-out meaning its not a cataloged spare part as far as Cessna is concerned. In fact, it's part of the contactor assembly as supplied by Cutler-Hammer (item 15). I'm not sure why the catalog illustrator chose to explode these parts off the as-supplied assembly. From an OEM service manual perspective, there was no reason to disassemble that stud. I also found some un-flagged star washers on vendor-supplied assemblies but in each case, the washer was under a nut . . . not part of the current path. As a factory policy, metal locknuts were the preferred anti-loosening technology for threaded fasteners. Electrical conductor pathways were made up with flat, clean and sometimes malleable conductors (crimped terminals) being brought together in gas-tight union with no intermediate enhancements. Sometimes a service manual would call out moisture proofing by painting the finished joint with some suitable coating . . . these were joints located out on structure subject to moisture incursion by drip, splash or condensation. B&C supplies star washers with the firewall forest-of-tabs ground block. All the circuit breaker manufacturers supply lock washers under the heads of their screws for terminal attachment. Again, these are intended to enhance mechanical integrity of the fastener outside the current pathway. An interesting aside . . . While cruising through the electrical installation data I found this image I had forgotten about . . . Emacs! Somewhere in my archives, I have a letter from the head-shed of single engine electrical systems rejecting my proposal for replacing the too-warm, panel dimming rheostats with a remotely mounted array of power transistors on heat sinks. This would have been about 1964 or thereabouts. He offered a litany of down-sides . . . A about 5 years later, the same idea cropped up across town on the light twins . . . a short time later, solid state dimming migrated into the single engine airplanes. We COULD have beat the twin engine line to this enhancement by several years. Oh well . . . Bob . . . ________________________________________________________________________________
Date: Dec 14, 2018
Subject: Poor Man's Battery Capacity Tester
Recently built the tester described in "Battery Replacement: A Plan for Throwing in the Towel". Then I tested it with a one-year old battery (PC-680). It operated 2.25 hrs. before the light went off. I thought this was pretty good. I read 12v. at the battery immediately after test completion. That surprised me, I had expected it to be lower...maybe 10 or 11 volts before the light would go out. But since the relay used was a 12v relay, I should have known a 12v relay would drop out at 12 volts! I learned something most of you probably already knew! Roger E. Have a blessed Christmas! Sent from Xfinity Connect Application ________________________________________________________________________________
Subject: Re: Poor Man's Battery Capacity Tester
Date: Dec 14, 2018
A relay will drop out at a MUCH lower voltage than its pull in voltage, perhaps one half or less. The battery tester relay drop out voltage is determined by the transistor base circuit. Very soon after the battery circuit is opened, the battery voltage starts to recover. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=486300#486300 ________________________________________________________________________________
Date: Dec 14, 2018
Thanks. I now understand how a star washer under the nut is not in the current path (a concept that had eluded me). As an aside, is there any preference as to inside vs outside teeth on the washer? On Fri, Dec 14, 2018, 06:02 Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com wrote: > At 03:21 PM 12/13/2018, you wrote: > > Bob, > > In the recent weeks/months I "think" I saw what appear to me to be > contradicting posts regarding the use of star washers. > > In one discussion I thought you said that star washers are never used in > the current path on any certified airplanes. I think the reason was that > they prevent the gas tight seal that will inhibit corrosion. > > Then, in a second discussion about bus bar construction using brass bars, > I thought you said to be sure to use a star washer under each terminal. > > Could you clear up my confusions as to your approach to using star washer s > in an aircraft electrical system?=C3=82 > > Thanks, > > Ken > > > I spent a few minutes searching the term > 'star washers' in the list archives. Generally, > the use of star washers in the electrical path > was discouraged. If used at all, they were > for mechanical security (i.e. used under a nut). > > Couldn't look at all the search hits, but the > few I found were consistent with the above. > > Just for grins, I checked a Brand-C parts > catalog for battery contactor installations > and found this image: > > [image: Emacs!] > > Here we see a lockwasher called out as part > of the assembly. It's used under a nut that > secures a terminal post to the 'wing' of > an H6041 mil-style contactor. It doesn't > have a numerical call-out meaning its not > a cataloged spare part as far as Cessna > is concerned. In fact, it's part of the > contactor assembly as supplied by Cutler-Hammer > (item 15). I'm not sure why the catalog > illustrator chose to explode these parts > off the as-supplied assembly. From an OEM > service manual perspective, there was no > reason to disassemble that stud. > > I also found some un-flagged star washers > on vendor-supplied assemblies but in each > case, the washer was under a nut . . . not > part of the current path. As a factory > policy, metal locknuts were the > preferred anti-loosening technology for > threaded fasteners. > > Electrical conductor pathways were made > up with flat, clean and sometimes malleable > conductors (crimped terminals) being brought > together in gas-tight union with no > intermediate enhancements. Sometimes a > service manual would call out moisture > proofing by painting the finished joint > with some suitable coating . . . these > were joints located out on structure subject > to moisture incursion by drip, splash > or condensation. > > B&C supplies star washers with the firewall > forest-of-tabs ground block. All the circuit > breaker manufacturers supply lock washers under > the heads of their screws for terminal attachment. > Again, these are intended to enhance mechanical > integrity of the fastener outside the current > pathway. > > An interesting aside . . . > > While cruising through the electrical installation > data I found this image I had forgotten > about . . . > > [image: Emacs!] > > > Somewhere in my archives, I have a letter from > the head-shed of single engine electrical systems > rejecting my proposal for replacing the too-warm, > panel dimming rheostats with a remotely mounted > array of power transistors on heat sinks. This > would have been about 1964 or thereabouts. > > He offered a litany of down-sides . . . > > A about 5 years later, the same idea cropped up > across town on the light twins . . . a short > time later, solid state dimming migrated into the > single engine airplanes. We COULD have beat > the twin engine line to this enhancement by > several years. Oh well . . . > > Bob . . . > ________________________________________________________________________________
Date: Dec 14, 2018
Inside or outside teeth do not matter as long as the teeth are under the nut. But some outside star washer diameters are big enough so that the teeth are outside of the nut circumference. For that reason, I prefer inside diameter teeth. Speaking of lock washers, what we know as split ring lock washers are not really lock washers at all. In fact, they allow fasteners to loosen sooner than plain flat washers. There is a YouTube video by Nord Lock demonstrating this. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=486302#486302 ________________________________________________________________________________
Date: Dec 14, 2018
At 11:00 AM 12/14/2018, you wrote: >Thanks. I now understand how a star washer under the nut is not in >the current path (a concept that had eluded me). As an aside, is >there any preference as to inside vs outside teeth on the washer? Given that the locking effect is really just a 'friction enhancement' it stands to reason that you want the greatest practical torque moment as measured from the center of rotation. It follows that external teeth would offer the greatest impediment to rotation. Bob . . . ________________________________________________________________________________
Date: Dec 14, 2018
At 11:16 AM 12/14/2018, you wrote: > >Inside or outside teeth do not matter as long as the teeth are under >the nut. But some outside star washer diameters are big enough so >that the teeth are outside of the nut circumference. For that >reason, I prefer inside diameter teeth. > Speaking of lock washers, what we know as split ring lock washers > are not really lock washers at all. In fact, they allow fasteners > to loosen sooner than plain flat washers. There is a YouTube video > by Nord Lock demonstrating this. Many, if not most joints on electrical system threaded fasteners are made up with only flat washshers. Given aviation's preference for fine pitch threads, taking a nut up to design specs for torque probably makes it as 'locked' as it will ever be. The #1 antagonist to make up pressure is rotational vibration imparted by the WIRE crimped into the terminal under the nut. This is why I've been partial to welding cable for fat wires. VERY flexible and minimal transmission of wire motion to the threaded fastener. Most of this is pretty academic. I've opened joints that had been in service for decades that took significant break-away torque to move the fastener. This in spite of no 'locking' feature on or under the nut. I.e. the original installer was paying attention. Bob . . . ________________________________________________________________________________
Date: Dec 14, 2018
Thanks. Although "academic" I have found the responses quite educational. Ken On Fri, Dec 14, 2018 at 9:39 AM Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 11:16 AM 12/14/2018, you wrote: > > > Inside or outside teeth do not matter as long as the teeth are under the > nut. But some outside star washer diameters are big enough so that the > teeth are outside of the nut circumference. For that reason, I prefer > inside diameter teeth. > Speaking of lock washers, what we know as split ring lock washers are > not really lock washers at all. In fact, they allow fasteners to loosen > sooner than plain flat washers. There is a YouTube video by Nord Lock > demonstrating this. > > > Many, if not most joints on electrical system > threaded fasteners are made up with only > flat washshers. Given aviation's preference > for fine pitch threads, taking a nut up to > design specs for torque probably makes it > as 'locked' as it will ever be. > > The #1 antagonist to make up pressure is > rotational vibration imparted by the WIRE > crimped into the terminal under the nut. > This is why I've been partial to welding > cable for fat wires. VERY flexible and > minimal transmission of wire motion > to the threaded fastener. > > Most of this is pretty academic. I've > opened joints that had been in service > for decades that took significant break-away > torque to move the fastener. This in spite > of no 'locking' feature on or under the nut. > > I.e. the original installer was paying attention. > > Bob . . . > ________________________________________________________________________________
Date: Dec 14, 2018
Joe, What about the Rotax split washers that have both ends turned the same direction? Rick On Fri, Dec 14, 2018 at 11:23 AM user9253 wrote: > > Inside or outside teeth do not matter as long as the teeth are under the > nut. But some outside star washer diameters are big enough so that the > teeth are outside of the nut circumference. For that reason, I prefer > inside diameter teeth. > Speaking of lock washers, what we know as split ring lock washers are > not really lock washers at all. In fact, they allow fasteners to loosen > sooner than plain flat washers. There is a YouTube video by Nord Lock > demonstrating this. > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=486302#486302 > > =========== =========== =========== =========== =========== =========== > > -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> ________________________________________________________________________________
Date: Dec 14, 2018
> Joe, What about the Rotax split washers that have both ends turned the same direction? I am not familiar with Rotax split washers. Where are they used on the Rotax? The prop bolts on my Rotax have wedge-lock washers, no safety wire required. Matco breaks also use wedge-lock washers. When wedge-lock (Nord Lock) washers are used, it is actually harder to loosen a fastener than to tighten it. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=486317#486317 ________________________________________________________________________________
Date: Dec 15, 2018
I love Nord Lock washers even though they're expensive. I used them on all the battery connections in the truck I converted to electric. I check them every 6 months and have never found one coming loose. --Rick On 12/14/2018 10:27 PM, user9253 wrote: > I am not familiar with Rotax split washers. Where are they used on the > Rotax? > The prop bolts on my Rotax have wedge-lock washers, no safety wire required. Matco breaks also use wedge-lock washers. > When wedge-lock (Nord Lock) washers are used, it is actually harder to loosen a fastener than to tighten it. > > -------- > Joe Gores > ________________________________________________________________________________
Subject: Transistor Dimmers
Date: Dec 15, 2018
Robert L. Nuckolls, III wrote: > Somewhere in my archives, I have a letter from > the head-shed of single engine electrical systems > rejecting my proposal for replacing the too-warm, > panel dimming rheostats with a remotely mounted > array of power transistors on heat sinks. This > would have been about 1964 or thereabouts. > > He offered a litany of down-sides . . . > > A about 5 years later, the same idea cropped up > across town on the light twins . . . a short > time later, solid state dimming migrated into the > single engine airplanes. We COULD have beat > the twin engine line to this enhancement by > several years. Oh well . . . There was that AD on 172s with those rheostats in the overhead panel... as the panel aged, heated, and deformed, the rheostat contacts would contact ground, and start a nice little fire fueled by the plastic panel and surrounding materials... Of course, those of us blessed with the transistor dimmers got good at replacing the 2N3203 power transistors (and later the RCA equivalent replacements), 'cause there was no current limiting, and even a momentary short, easy to do when wiggling a plastic overlay panel, would blow the transistor. A one ohm resistor in series with the load would nicely current limit so that the transistor wouldn't blow... not elegant, but it worked! :-) Paul ________________________________________________________________________________
Date: Dec 15, 2018
Subject: Re: Transistor Dimmers
> >There was that AD on 172s with those rheostats in the overhead >panel... as the panel aged, heated, and deformed, the rheostat >contacts would contact ground, and start a nice little fire fueled >by the plastic panel and surrounding materials... > >Of course, those of us blessed with the transistor dimmers got good >at replacing the 2N3203 power transistors (and later the RCA >equivalent replacements), 'cause there was no current limiting, and >even a momentary short, easy to do when wiggling a plastic overlay >panel, would blow the transistor. A one ohm resistor in series with >the load would nicely current limit so that the transistor wouldn't >blow... not elegant, but it worked! :-) Oh yeah . . . forgot about that. Same problem at Beech. Seems that the assembly line would go through a couple of dimmer assemblies before they cleaned all the shorts out of the post-lites installations. Got to revisit the dimmer issues for Beech while I was at ElectroMech. I designed a 4-channel incandescent/1-channel E.L. supply with all four outputs short circuit tolerant. I think they still build that for the Bonanzas and Barons. Electromech Electronics Circuit Board I found it interesting that all three of the featured products on ElectroMech's electronic products promo http://www.electromech.com/images/data-sheets/Electronics.pdf are devices I designed for Beech back in the 80's . . . Gee, I would think they had some something newer since I worked there! Bob . . . ________________________________________________________________________________
Date: Dec 16, 2018
Subject: lock washers for electrics
> > I stopped into the local hardware store a while back to get some > phosphorous bronze star washers for fat wire bolt ups, but the fella there > insisted he'd never heard of such a thing and that they didn't carry them. > About two minutes later I was in the checkout line, washers in hand... ________________________________________________________________________________
Date: Dec 16, 2018
At 10:27 AM 12/15/2018, you wrote: >I love Nord Lock washers even though they're expensive. I used them >on all the battery connections in the truck I converted to electric. >I check them every 6 months and have never found one coming loose. > >--Rick Those are a pretty cool product. There's a constellation of youtube videos on the technology at https://tinyurl.com/yb7h38kv This design is not limited by friction but by the relative hardness of washer and that of the nut and base surfaces. The outside faces of the Nord washer pair must displace metal and 'dig in'. I suspect that star washers, fabricated from steels on the same class as Nord washers would see a quantum jump in performance. Bob . . . ________________________________________________________________________________
Subject: Buy Apple iPhone Xs Max (Website www.esellibuy.com) $999CAD
Date: Dec 18, 2018
Buy Apple iPhone Xs Max Read this topic online here: http://forums.matronics.com/viewtopic.php?p=486353#486353 ________________________________________________________________________________
Subject: Re: Com transmit blanking out VOR CDI
Date: Dec 18, 2018
Don, Just ran across this post and am wondering if you ever resolved your issue? I'm 'close' to finishing up a Long-EZ and have a Garmin GPS unit for COM1 and NAV1, but was considering the VAL 2KR for COM2 controlled via a GRT HXr. I of course have the Jim Weir foil com and nav antennas as well, so again am very curious if you were able to resolve your VOR interference issue? Cheers, Wade -------- Airdog Wade Parton Building Long-EZ N916WP www.longezpush.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=486360#486360 ________________________________________________________________________________
Date: Dec 19, 2018
Subject: 2018 List of Contributors
Dear Listers, The 2018 Matronics Email List and Forum Fund Raiser officially ended a couple of weeks ago and it's time that I published this year's List of Contributors. It is the people on this list that directly make these Email Lists and Forums possible! Their generous Contributions keep the servers and Internet connection up and running! You can still show your support this year and pick up a great gift at the same time. The Contribution Web Site is fast, easy, and secure: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 And finally, I'm proud to present The 2018 Fund Raiser List of Contributors: http://www.matronics.com/loc Thank you again to everyone that made a Contribution this year!! Matt Dralle Matronics Email List & Forum Administrator ________________________________________________________________________________
Subject: what is the truth about gps antennas?
Date: Dec 19, 2018
I'm interested in hearing from an engineer who might know about what really goes on with my stratus esg gps antenna. they say to use RG400 cable, 10' minimum, and never paint the antenna. they also told me the strength ratings should run in the 30's. I have 3' of RG400 with a mechanical 90 elbow, I spray painted the antenna flat black and mounted it on the glareshield of my RV. my readings are all in the 40's. they told me this shows an overdriven condition. so why use low impedance cable then need 10'? my iFly740 and Lowrance 1000 gps's have antennas with much smaller cables. the iFly shows WAAS grade accuracy, using an antenna 1/4 the size of the stratus RAMI antenna. when does being overdriven prove to be a problem? is this a situation where I could add more mechanical connectors to increase impedance rather than more cable length? I get the feeling things get written and then forever repeated, such as never paint an antenna, without asking any questions. could I use a different antenna than the RAMI brand? should I not worry about any of this and just go fly? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=486450#486450 ________________________________________________________________________________
Subject: Re: what is the truth about gps antennas?
Date: Dec 20, 2018
Read this thread: http://forum.matronics.com/viewtopic.php?t=16766060&start=0&postdays=0&postorder=asc&highlight=&sid=4eec20ad70d380aa54524dd467494a91 While none of the postings were by engineers, their replies are based on experience. Stein owns an avionics company. He is the expert. Follow his recommendations. If shorter cable must be used, consider RG-58. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=486456#486456 ________________________________________________________________________________
Date: Dec 20, 2018
At 09:23 PM 12/19/2018, you wrote: > >I'm interested in hearing from an engineer who >might know about what really goes on with my >stratus esg gps antenna. they say to use RG400 >cable, 10' minimum, and never paint the antenna. >they also told me the strength ratings should >run in the 30's. I have 3' of RG400 with a >mechanical 90=C2=B0 elbow, I spray painted the >antenna flat black and mounted it on the >glareshield of my RV. my readings are all in the >40's. they told me this shows an overdriven condition. >so why use low impedance cable then need 10'? my >iFly740 and Lowrance 1000 gps's have antennas >with much smaller cables. the iFly shows WAAS >grade accuracy, using an antenna 1/4 the size of the stratus RAMI antenna. >when does being overdriven prove to be a >problem? is this a situation where I could add >more mechanical connectors to increase impedance >rather than more cable length? >I get the feeling things get written and then >forever repeated, such as never paint an >antenna, without asking any questions. could I >use a different antenna than the RAMI brand? >should I not worry about any of this and just go fly? Paint MIGHT degrade antenna performance but without laboratory grade testing, you don't know about YOUR paint. Hence, easiest way to deal with it is never paint. Now, if you have a painted antenna and the receiver is still got good signal numbers, then the 99% sure THAT paint is not an issue. OVER-DRIVEN? Never heard of such a thing in GPS receivers. RG400 has an attenuation figure on the order of 16db typical to 20 db maximum PER 100 FEET at GPS frequencies. Assume worst at 20db/100' for a 10' feeder cable, shortening it to ZERO feet would raise the signal by 2db Maximum, probably less. This is trivial. Color be skeptical . . . Antenna dimensions are only loosely related to performance. Physical and electrical things INSIDE make the difference . . . and the technology is now so old that manufacturing a good antenna is child's play. You certainly want to minimize connections but don't loose any sleep over it if you've added one for enhanced maintenance. I've got a GPS cable on my bench signal generator that is 20' long and RG174 style (relatively high attenuation) that drives the GPS disciplined reference oscillator . . . it gets stood up in less than 2 minutes even after being off for weeks. There's been a lot of hangar-lore floating around the aviation environs concerning things technical for over a century. Sadly, many 'field representatives' of major suppliers are not all that cognizant of foundations in physics for the products they sell. Stories not backed up by measurement and/or demonstration are suspect. GPS is no exception. If anyone encounters a 'factory representative' who offers less than comfortable advice, shoot me their name and phone number. The proof of the pudding is in the flying. You'll be getting error messages when an if the receiver is being improperly serviced by what's coming down the coax. Bob . . . ________________________________________________________________________________
Subject: Fuse-able link
Date: Dec 20, 2018
Two years ago I had an over-voltage event and the crowbar protection behaved as expected. It popped the 5amp breaker. I had the alternator (Plane Power 60amp internal) repaired and it has behaved normally since then. The alternator stopped working this Sunday. The crimp had failed on the 18ga to 22ga fuse-link. Closer inspection revealed that the insulation under the heat shield on the fuse-link was almost completely gone. Questions: 1. Should I have inspected the fuse-link after the over-voltage incident before putting the plane back in service? 2. Is it acceptable to solder the joint between the 18ga and the 22ga or is a crimp connector required? Thanks, john ________________________________________________________________________________
Date: Dec 20, 2018
Subject: Re: Fuse-able link
At 01:23 PM 12/20/2018, you wrote: > >Two years ago I had an over-voltage event and the crowbar protection >behaved as expected. It popped the 5amp breaker. I had the >alternator (Plane Power 60amp internal) repaired and it has behaved >normally since then. The alternator stopped working this Sunday. The >crimp had failed on the 18ga to 22ga fuse-link. Closer inspection >revealed that the insulation under the heat shield on the fuse-link >was almost completely gone. > >Questions: > >1. Should I have inspected the fuse-link after the over-voltage >incident before putting the plane back in service? > >2. Is it acceptable to solder the joint between the 18ga and the >22ga or is a crimp connector required? I would really like to have that fusible link assembly. Can you cut it out and fabricate a new one? When you say "gone" . . . is it melted, charred, evaporated? Was it Tefzel wire? That link normally carries 3A or less. I've demonstrated that 22AWG Tefzel will carry 20A indefinitely in the open air. Some combination of factors stacked up to cause this particular link to suffer damage. A good place to start is careful examination of the link. Bob . . . ________________________________________________________________________________
Date: Dec 20, 2018
On 12/20/2018 3:14 PM, Robert L. Nuckolls, III wrote: > At 01:23 PM 12/20/2018, you wrote: >> >> >> Two years ago I had an over-voltage event and the crowbar protection >> behaved as expected. It popped the 5amp breaker. I had the alternator >> (Plane Power 60amp internal) repaired and it has behaved normally >> since then. The alternator stopped working this Sunday. The crimp had >> failed on the 18ga to 22ga fuse-link. Closer inspection revealed that >> the insulation under the heat shield on the fuse-link was almost >> completely gone. >> >> Questions: >> >> 1. Should I have inspected the fuse-link after the over-voltage >> incident before putting the plane back in service? >> >> 2. Is it acceptable to solder the joint between the 18ga and the 22ga >> or is a crimp connector required? > > I would really like to have that fusible link > assembly. Can you cut it out and fabricate > a new one? > > When you say "gone" . . . is it melted, charred, > evaporated? Was it Tefzel wire? > > That link normally carries 3A or less. I've > demonstrated that 22AWG Tefzel will carry > 20A indefinitely in the open air. > > Some combination of factors stacked up to > cause this particular link to suffer > damage. A good place to start is careful > examination of the link. > > > Bob . . . > Sounds like the failure was in the joint, so... Less than perfect crimp, followed by years of increasing corrosion in the joint, causing resistance heating in the joint? I solder/heatshrink my fuselinks, but I trust my soldering skills (a couple of careers that required a decent skillset). Charlie --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Dec 20, 2018
I'll fish it out of the trash and send it to you. john On 12/20/2018 2:14 PM, Robert L. Nuckolls, III wrote: > At 01:23 PM 12/20/2018, you wrote: >> >> >> Two years ago I had an over-voltage event and the crowbar protection >> behaved as expected. It popped the 5amp breaker. I had the alternator >> (Plane Power 60amp internal) repaired and it has behaved normally >> since then. The alternator stopped working this Sunday. The crimp had >> failed on the 18ga to 22ga fuse-link. Closer inspection revealed that >> the insulation under the heat shield on the fuse-link was almost >> completely gone. >> >> Questions: >> >> 1. Should I have inspected the fuse-link after the over-voltage >> incident before putting the plane back in service? >> >> 2. Is it acceptable to solder the joint between the 18ga and the 22ga >> or is a crimp connector required? > > I would really like to have that fusible link > assembly. Can you cut it out and fabricate > a new one? > > When you say "gone" . . . is it melted, charred, > evaporated? Was it Tefzel wire? > > That link normally carries 3A or less. I've > demonstrated that 22AWG Tefzel will carry > 20A indefinitely in the open air. > > Some combination of factors stacked up to > cause this particular link to suffer > damage. A good place to start is careful > examination of the link. > > > Bob . . . > ________________________________________________________________________________
Date: Dec 20, 2018
I forgot to mention that this is a pretty faithful Z13/8 with dual pmags and an S700-2-10 for off/battery/alternator. john On 12/20/2018 3:11 PM, Charlie England wrote: > On 12/20/2018 3:14 PM, Robert L. Nuckolls, III wrote: >> At 01:23 PM 12/20/2018, you wrote: >>> >>> >>> Two years ago I had an over-voltage event and the crowbar protection >>> behaved as expected. It popped the 5amp breaker. I had the >>> alternator (Plane Power 60amp internal) repaired and it has behaved >>> normally since then. The alternator stopped working this Sunday. The >>> crimp had failed on the 18ga to 22ga fuse-link. Closer inspection >>> revealed that the insulation under the heat shield on the fuse-link >>> was almost completely gone. >>> >>> Questions: >>> >>> 1. Should I have inspected the fuse-link after the over-voltage >>> incident before putting the plane back in service? >>> >>> 2. Is it acceptable to solder the joint between the 18ga and the >>> 22ga or is a crimp connector required? >> >> I would really like to have that fusible link >> assembly. Can you cut it out and fabricate >> a new one? >> >> When you say "gone" . . . is it melted, charred, >> evaporated? Was it Tefzel wire? >> >> That link normally carries 3A or less. I've >> demonstrated that 22AWG Tefzel will carry >> 20A indefinitely in the open air. >> >> Some combination of factors stacked up to >> cause this particular link to suffer >> damage. A good place to start is careful >> examination of the link. >> >> >> Bob . . . >> > Sounds like the failure was in the joint, so... Less than perfect > crimp, followed by years of increasing corrosion in the joint, causing > resistance heating in the joint? > > I solder/heatshrink my fuselinks, but I trust my soldering skills (a > couple of careers that required a decent skillset). > > Charlie > > > Virus-free. www.avast.com > > > > <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> ________________________________________________________________________________
Subject: Need help with replacement connector pins for KT76A
Date: Dec 21, 2018
Can someone help me find a source for replacement pins for a KT76A transponder connector. I'm not sure of the name of that connector, but it is a 24-pin molded plastic unit, with two rows of 12 pins, and the pins are not cylindrical but flat. If someone has a digikey or mouser part number that would be fantastic! Jeff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=486480#486480 ________________________________________________________________________________
Date: Dec 21, 2018
Subject: Re: Need help with replacement connector pins for KT76A
The pins were discontinued by molex about a decade ago, but this guy still h as stock. He=99s probably the only supplier in the world, now. https://www.mikesarcade.com/cgi-bin/store.pl?sku=CECPIN100 On Dec 21, 2018, at 21:49, jjshultz wrote: Can someone help me find a source for replacement pins for a KT76A transpond er connector. I'm not sure of the name of that connector, but it is a 24-pi n molded plastic unit, with two rows of 12 pins, and the pins are not cylind rical but flat. If someone has a digikey or mouser part number that would be fantastic! Jeff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=486480#486480 ========================== ======== ========================== ======== ========================== ======== ========================== ======== ========================== ======== ========================== ======== ________________________________________________________________________________
Date: Dec 21, 2018
Well, apart from the eBay merchants at $1/pin, that is.... On Dec 21, 2018, at 23:06, Alec Myers wrote: The pins were discontinued by molex about a decade ago, but this guy still h as stock. He=99s probably the only supplier in the world, now. https://www.mikesarcade.com/cgi-bin/store.pl?sku=CECPIN100 On Dec 21, 2018, at 21:49, jjshultz wrote: Can someone help me find a source for replacement pins for a KT76A transpond er connector. I'm not sure of the name of that connector, but it is a 24-pi n molded plastic unit, with two rows of 12 pins, and the pins are not cylind rical but flat. If someone has a digikey or mouser part number that would be fantastic! Jeff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=486480#486480 nbsp; (And Get Some AWESOME FREE Gisp; this year's Terrific Free Incen tive Gifts provided * My Pilot Store http://www.matronics.============ ========================== ==============; - MATRONICS WEB FORUM"ht tp://forums.matronics.com">http://forums.matronics.com http://w======================= ========================== == ________________________________________________________________________________
Date: Dec 22, 2018
Eewww, *those* pins=2E My fix, at least for experimentals, is solder, wire, and dsub connectors=2E =81=A3Charlie=8B On Dec 21, 2018, 11:11 PM, at 11:11 PM, Alec Myers wrote: >The pins were di scontinued by molex about a decade ago, but this guy >still has stock=2E He =99s probably the only supplier in the world, now=2E > >https://www =2Emikesarcade=2Ecom/cgi-bin/store=2Epl?sku=CECPIN100 > > >On Dec 21, 201 8, at 21:49, jjshultz wrote: > >--> AeroElectric-L ist message posted by: "jjshultz" > > >Can someone help me find a source for replacement pins for a KT76A >transponder connect or=2E I'm not sure of the name of that connector, but >it is a 24-pin mold ed plastic unit, with two rows of 12 pins, and the >pins are not cylindrica l but flat=2E > >If someone has a digikey or mouser part number that would be fantastic! > >Jeff > > >Read this topic online here: > >http://forum s=2Ematronics=2Ecom/viewtopic=2Ephp?p=486480#486480 > > >== ======= >================ ================== >===== ==== >=================== =============== >======== = >====================== ============ ________________________________________________________________________________
Date: Dec 22, 2018
There=99s a reason many those arcade pins are cheap. They are simply brass plated tin (which is probably fine for some wires, but not for others). the =9Creal=9D pins are gold flashed (and silver), and as you noted discontinued long ago. Those of us who have some left do charge a lot, but that=99s because they just don=99t exist at the OEM level anymore. Whenever you see a solid silver or solid gold looking pin, be aware they aren=99t what you think they are. Cheers, Stein From: owner-aeroelectric-list-server(at)matronics.com On Behalf Of Alec Myers Sent: Friday, December 21, 2018 10:10 PM Subject: Re: AeroElectric-List: Need help with replacement connector pins for KT76A Well, apart from the eBay merchants at $1/pin, that is.... On Dec 21, 2018, at 23:06, Alec Myers > wrote: The pins were discontinued by molex about a decade ago, but this guy still has stock. He=99s probably the only supplier in the world, now. https://www.mikesarcade.com/cgi-bin/store.pl?sku=CECPIN100 On Dec 21, 2018, at 21:49, jjshultz > wrote: > Can someone help me find a source for replacement pins for a KT76A transponder connector. I'm not sure of the name of that connector, but it is a 24-pin molded plastic unit, with two rows of 12 pins, and the pins are not cylindrical but flat. If someone has a digikey or mouser part number that would be fantastic! Jeff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=486480#486480 < span="">nbsp; (And Get Some AWESOME FREE Gisp; this year's Terrific Free Incentive Gifts provided * My Pilot Store http://www.matronics.================== =========; <http://www.mypilotstorenbsp; -Matt%20Dralle,%20List%20Admin.%3c/============= =========%3c/span%3e%3cbr%3e%3cs> - MATRONICS WEB FORUM"http://forums.matronics.com">http://forums.matronics.com <="" spanp; &nnbsp; -->="" http://w====================== ==== <> ________________________________________________________________________________
Date: Dec 22, 2018
KT76A At 09:14 AM 12/22/2018, you wrote: >Eewww, *those* pins. My fix, at least for >experimentals, is solder, wire, and dsub connectors. > >Charlie >On Dec 21, 2018, at 11:11 PM, Alec Myers ><alec(at)alecmyers.com> wrote: >The pins were discontinued by molex about a >decade ago, but this guy still has stock. He=99s >probably the only supplier in the world, now. > >https://www.m ikesarcade.com/cgi-bin/store.pl?sku=CECPIN100 > > >On Dec 21, 2018, at 21:49, jjshultz ><jjshultz(at)cablemo.net> wrote: > >"jjshultz" <jjshultz(at)cablemo.net> > >Can someone help me find a source for >replacement pins for a KT76A transponder >connector. I'm not sure of the name of that >connector, but it is a 24-pin molded plastic >unit, with two rows of 12 pins, and the pins are not cylindrical but flat. > >If someone has a digikey or mouser part number that would be fantastic! > >Jeff Two choices: I may have some original, open-barrel crimp pins around here if you don't find them elsewhere. I belive the connector you are wrestling with is this one http://aeroelectric.com/Mfgr_Data/Connectors/Molex_Waldom/Avionics_Connector _Plug_15003.jpg and these pins https://tinyurl.com/y7nranof which are obsolete and rarely stocked. I do have some of these Emacs! Which you can purchase here: https://tinyurl.com/y98m7ph9 or I can send you one at no charge. I'll dig around to see if I can find the Molex KK pins. ________________________________________________________________________________
KT76A
Date: Dec 22, 2018
Molex never made a "brass plated tin connector. https://www.molex.com/molex/products/datasheet.jsp?part=active/0008050302_CRIMP_TERMINALS.xml Theyre a brass body, plated nickel for the wire termination, and gold at the mating surface. I believe molex did make a nickel plate all over version, but the ones that Mike sells at not those. I have some from Mike, and theyre definitely gold plated at the mating surface. On Dec 22, 2018, at 4:30 PM, Stein Bruch wrote: Theres a reason many those arcade pins are cheap. They are simply brass plated tin (which is probably fine for some wires, but not for others). the real pins are gold flashed (and silver), and as you noted discontinued long ago. Those of us who have some left do charge a lot, but thats because they just dont exist at the OEM level anymore. Whenever you see a solid silver or solid gold looking pin, be aware they arent what you think they are. Cheers, Stein From: owner-aeroelectric-list-server(at)matronics.com <owner-aeroelectric-list-server(at)matronics.com> On Behalf Of Alec Myers Sent: Friday, December 21, 2018 10:10 PM Subject: Re: AeroElectric-List: Need help with replacement connector pins for KT76A Well, apart from the eBay merchants at $1/pin, that is.... On Dec 21, 2018, at 23:06, Alec Myers wrote: The pins were discontinued by molex about a decade ago, but this guy still has stock. Hes probably the only supplier in the world, now. https://www.mikesarcade.com/cgi-bin/store.pl?sku=CECPIN100 On Dec 21, 2018, at 21:49, jjshultz wrote: Can someone help me find a source for replacement pins for a KT76A transponder connector. I'm not sure of the name of that connector, but it is a 24-pin molded plastic unit, with two rows of 12 pins, and the pins are not cylindrical but flat. If someone has a digikey or mouser part number that would be fantastic! Jeff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=486480#486480 < span="">nbsp; (And Get Some AWESOME FREE Gisp; this year's Terrific Free Incentive Gifts provided * My Pilot Store http://www.matronics.===========================; - MATRONICS WEB FORUM"http://forums.matronics.com">http://forums.matronics.com <="" spanp; &nnbsp; -->="" http://w========================== <> ________________________________________________________________________________
Date: Dec 22, 2018
Hi Kevin: You are 300% right to question Old Wive's Tails. The Paint Story is not without some merit. It stems from the idea of how the Color was produced. Black and Gray for example could come from a CARBON. Carbon is conductive, not highly so but conductive. After all Carbon Resistors are exactly that Carbon and Conductive. The old Green, Copper and Bronze have Copper and Bronze metals in them. White paint can have Titanium Dioxide in it and titanium is metal and slightly conductive. There are also paints such as primers which have Zinc in them. Well, you can see the thought process, that conductive paints can cause some problems. So, why take the chance... The industry makes a general Old Wive's Tail statement of Do Not Paint GPS Antennas. Of course the Pigment of paints have changed over the years, too bad the Old Wive's Tails have a stronger following than the process of common sense. What YOU can do is read the Ingredients List of what makes the paint the color (Pigment) and see if any of the above items are listed. ALSO, you can look up the MSDS for the paint. Next: - OVER DRIVEN: - We should be so lucky. YES! There is such a thing. It is also know in Receiver Theory as Front End Over Load. Too much signal is received and causes SPLATTER - Too much signal covering too wide a bandwidth. The 'Active" GPS Antennas do have amplifiers built into them. They usually range between 10 to 40 dB Gain. The rule of dB is every 3 dB doubles your signal. So, YES, in theory if you have a 40 dB gain antenna you could have 40/3 = 13 times the un-amplified signal. That could be too much for the receiver to handle. Of course there is a loss in the coax, loss in each of the connectors and an additional loss in the 90 Deg connector. So, if an engineer sits down with the slide-ruler the NUMBERS would say YES, there is too much signal coming down the RG-400. SO! Why not be smarter than the Engineer - Save your Money - Buy RG-58/AU and run the shortest length possible? Buy It - HELL! I have a 150 foot spool! But NOooooo.... Common Sense is over ruled by Sales Pitch and owners spend $4.00 per foot for RG-400 and they buy 10 foot when only 3 foot is need for the run. 10 Foot @ $4 = $40 Vs 3 Foot @ $0.75 = $2.25. So Kevin, you did VERY - VERY GOOD! Guess What! I did the EXACT same thing with the Stratus ESG coax situation as you. I also mounted it on my Glare Shield. But, I have a carper over the antenna so I did not have to paint the antenna. Works Great, Works Fine - FM! Barry message posted by: "kjlpdx" > > I'm interested in hearing from an engineer who might know about what > really goes on with my stratus esg gps antenna. they say to use RG400 > cable, 10' minimum, and never paint the antenna. they also told me the > strength ratings should run in the 30's. I have 3' of RG400 with a > mechanical 90=C3=82=C2=B0 elbow, I spray painted the antenna flat black a nd mounted > it on the glareshield of my RV. my readings are all in the 40's. they tol d > me this shows an overdriven condition. > so why use low impedance cable then need 10'? my iFly740 and Lowrance 100 0 > gps's have antennas with much smaller cables. the iFly shows WAAS grade > accuracy, using an antenna 1/4 the size of the stratus RAMI antenna. > when does being overdriven prove to be a problem? is this a situation > where I could add more mechanical connectors to increase impedance rather > than more cable length? > I get the feeling things get written and then forever repeated, such as > never paint an antenna, without asking any questions. could I use a > different antenna than the RAMI brand? should I not worry about any of th is > and just go fly? > > ________________________________________________________________________________
Date: Dec 23, 2018
From: Henador Titzoff <henador_titzoff(at)yahoo.com>
It's an old wive's tale that a 40 dB gain is 40/3 = 13 times power gain o ver 0 dB. The decibel is a ratio of two physical properties expressed mathematically using logarithmic base 10.=C2- When referring to power, below are the cal culated values using the equation dB = 10xLog10(P/Po): =C2-=C2-=C2- 0 dB = 1=C2-=C2-=C2- 3 dB = 1.995 = ~2=C2- =C2-=C2- 6 dB = 3.981 = ~4=C2-=C2-=C2- 9 dB = 7.95=C2- = ~8=C2- 10 dB = 10.0=C2- 20 dB = 100.0=C2- 30 dB = 1000.0=C2 - 40 dB = 10,000.0 So 40 DB represents a ratio of 10,000, not 13.=C2- If 0 dB = 1 milliWat t, then 40 dB = 10 Watts. Everything else you say below is correct except that RF engineers, as well as LiDAR engineers, refer to too much signal as saturation, not splatter. =C2- Maybe I'm hanging out with a different bunch of engineers, but we us e what the literature says. Henador Titzoff l.com> wrote: Hi Kevin: =C2-You are 300% right to question Old Wive's=C2-Tails.The Paint Story is not without some merit. It stems from the idea of how the Color was prod uced.=C2- Black and Gray for example could come from a CARBON.=C2- Carb on is conductive, not highly so but conductive.=C2- After all Carbon Resi stors are exactly that Carbon and Conductive.The old Green, Copper and Bron ze have Copper and Bronze metals in them.White paint can have Titanium Diox ide in it and titanium is metal and slightly conductive.There are also pain ts such as primers which have Zinc in them.=C2-=C2-Well, you can see th e thought process, that conductive paints can cause some problems.So, why t ake the chance...=C2- The industry makes a general Old Wive's Tail statem ent of Do Not Paint GPS Antennas.Of course the Pigment of paints have chang ed over the years, too bad the Old Wive's Tails have a stronger following t han the process of common sense.=C2-What YOU can do is read the Ingredien ts List of what makes the paint the color (Pigment) and see if any of the a bove items are listed.=C2- ALSO, you can look up the MSDS for the paint. Next: -=C2-OVER DRIVEN: - We should be so lucky.YES!=C2- There is such a thing.=C2- It is also know in Receiver Theory=C2-as Front End Over Lo ad.Too much signal is received and causes SPLATTER=C2-- Too much signal c overing too wide a bandwidth.The 'Active" GPS=C2- Antennas do=C2- have amplifiers=C2-built into them.=C2- They usually range between 10 to 40 dB Gain.The rule of dB is every 3 dB doubles your signal. So, YES, in theor y=C2-if you have a 40 dB gain antenna you could have 40/3 = 13 times th e un-amplified=C2-signal.=C2- That could be too much for the receiver t o handle.Of course there is a loss in the coax, loss in each of the connect ors and an additional loss in the 90 Deg connector.So, if an engineer sits down with the slide-ruler=C2-the NUMBERS would say YES, there is too much signal coming=C2-down the RG-400.=C2- SO!=C2-Why not be smarter than the Engineer - Save your Money - Buy RG-58/AU and run the shortest length possible?=C2- Buy It - HELL!=C2- I have a 150 foot spool!=C2- But NOo oooo....=C2- =C2-Common Sense is over ruled by Sales Pitch and owners s pend $4.00 per foot for RG-400 and they buy 10 foot when only 3 foot is nee d for the run.=C2- 10 Foot=C2-@ $4 = $40 Vs 3 Foot=C2-@ $0.75 = $ 2.25.=C2-=C2-So Kevin,=C2- you did VERY - VERY GOOD! Guess What!=C2- I did the EXACT same thing with the Stratus ESG coax situ ation as you.=C2- I also mounted it on my Glare Shield.=C2- But, I have a carper over the antenna so I did not have to paint the antenna. Works Great, Works Fine - FM! Barry messageposted by: "kjlpdx" I'm interested in hearing from an engineer who might know about whatreally goes on with my stratus esg gps antenna. they say to use RG400cable, 10' mi nimum, and never paint the antenna. they also told me thestrength ratings s hould run in the 30's. I have 3' of RG400 with amechanical 90=C3=82=C2=B0 e lbow, I spray painted the antenna flat black and mountedit on the glareshie ld of my RV. my readings are all in the 40's. theytold me this shows an ove rdriven condition. so why use low impedance cable then need 10'? my iFly740 and Lowrance1000 g ps's have antennas with much smaller cables. the iFly shows WAASgrade accur acy, using an antenna 1/4 the size of the stratus RAMIantenna. when does being overdriven prove to be a problem? is this a situationwhere I could add more mechanical connectors to increase impedance ratherthan mor e cable length? I get the feeling things get written and then forever repeated, such asneve r paint an antenna, without asking any questions. could I use adifferent an tenna than the RAMI brand? should I not worry about any ofthis and just go fly? ________________________________________________________________________________
Date: Dec 22, 2018
40dB is 40/3 = 13.3 doublings, or a ratio of 2^13.3, which is about 10,000 , as you say. On Dec 22, 2018, at 21:10, Henador Titzoff wrote : It's an old wive's tale that a 40 dB gain is 40/3 = 13 times power gain ov er 0 dB. The decibel is a ratio of two physical properties expressed mathematically u sing logarithmic base 10. When referring to power, below are the calculated values using the equation dB = 10xLog10(P/Po): 0 dB = 1 3 dB = 1.995 = ~2 6 dB = 3.981 = ~4 9 dB = 7.95 = ~8 10 dB = 10.0 20 dB = 100.0 30 dB = 1000.0 40 dB = 10,000.0 So 40 DB represents a ratio of 10,000, not 13. If 0 dB = 1 milliWatt, the n 40 dB = 10 Watts. Everything else you say below is correct except that RF engineers, as well a s LiDAR engineers, refer to too much signal as saturation, not splatter. Ma ybe I'm hanging out with a different bunch of engineers, but we use what the literature says. Henador Titzoff > wrote: Hi Kevin: You are 300% right to question Old Wive's Tails. The Paint Story is not without some merit. It stems from the idea of how the Color was produced. Black and Gray for example could come from a CARBON. C arbon is conductive, not highly so but conductive. After all Carbon Resisto rs are exactly that Carbon and Conductive. The old Green, Copper and Bronze have Copper and Bronze metals in them. White paint can have Titanium Dioxide in it and titanium is metal and slight ly conductive. There are also paints such as primers which have Zinc in them. Well, you can see the thought process, that conductive paints can cause some problems. So, why take the chance... The industry makes a general Old Wive's Tail sta tement of Do Not Paint GPS Antennas. Of course the Pigment of paints have changed over the years, too bad the Old Wive's Tails have a stronger following than the process of common sense. What YOU can do is read the Ingredients List of what makes the paint the col or (Pigment) and see if any of the above items are listed. ALSO, you can lo ok up the MSDS for the paint. Next: - OVER DRIVEN: - We should be so lucky. YES! There is such a thing. It is also know in Receiver Theory as Front En d Over Load. Too much signal is received and causes SPLATTER - Too much signal covering t oo wide a bandwidth. The 'Active" GPS Antennas do have amplifiers built into them. They usuall y range between 10 to 40 dB Gain. The rule of dB is every 3 dB doubles your signal. So, YES, in theory if you h ave a 40 dB gain antenna you could have 40/3 = 13 times the un-amplified s ignal. That could be too much for the receiver to handle. Of course there is a loss in the coax, loss in each of the connectors and an additional loss in the 90 Deg connector. So, if an engineer sits down with the slide-ruler the NUMBERS would say YES, there is too much signal coming down the RG-400. SO! Why not be smarter th an the Engineer - Save your Money - Buy RG-58/AU and run the shortest length possible? Buy It - HELL! I have a 150 foot spool! But NOooooo.... Comm on Sense is over ruled by Sales Pitch and owners spend $4.00 per foot for RG -400 and they buy 10 foot when only 3 foot is need for the run. 10 Foot @ $ 4 = $40 Vs 3 Foot @ $0.75 = $2.25. So Kevin, you did VERY - VERY GOOD! Guess What! I did the EXACT same thing with the Stratus ESG coax situation a s you. I also mounted it on my Glare Shield. But, I have a carper over the antenna so I did not have to paint the antenna. Works Great, Works Fine - FM! Barry message posted by: "kjlpdx" > > I'm interested in hearing from an engineer who might know about what reall y goes on with my stratus esg gps antenna. they say to use RG400 cable, 10' m inimum, and never paint the antenna. they also told me the strength ratings s hould run in the 30's. I have 3' of RG400 with a mechanical 90=C3=82=C2=B0 e lbow, I spray painted the antenna flat black and mounted it on the glareshie ld of my RV. my readings are all in the 40's. they told me this shows an ove rdriven condition. > so why use low impedance cable then need 10'? my iFly740 and Lowrance 1000 gps's have antennas with much smaller cables. the iFly shows WAAS grade acc uracy, using an antenna 1/4 the size of the stratus RAMI antenna. > when does being overdriven prove to be a problem? is this a situation wher e I could add more mechanical connectors to increase impedance rather than m ore cable length? > I get the feeling things get written and then forever repeated, such as ne ver paint an antenna, without asking any questions. could I use a different a ntenna than the RAMI brand? should I not worry about any of this and just go fly? ________________________________________________________________________________
Date: Dec 23, 2018
Alec: I did say "Rule of Thumb". I did not look up if the dB gain expressed in the manual is voltage or power, but I'm pretty sure it would be voltage. And the rule of thumb is the voltage signal will double with every 3 dB of gain. Ya got me... I did not sit down with my slide rule and work out the voltage gain, I am just trying to show a relative number that non engineers can work with. But, your numbers are incorrect. A 10,000:1 dB ratio gain would be more like 80 dB's not 40 dB's. See: *Common Gains and Losses Expressed in Decibels* http://www.sengpielaudio.com/calculator-FactorRatioLevelDecibel.htm Barry On Sat, Dec 22, 2018 at 11:31 PM Alec Myers wrote: > 40dB is 40/3 = 13.3 doublings, or a ratio of 2^13.3, which is about > 10,000, as you say. > > On Dec 22, 2018, at 21:10, Henador Titzoff > wrote: > > It's an old wive's tale that a 40 dB gain is 40/3 = 13 times power gain > over 0 dB. > > The decibel is a ratio of two physical properties expressed mathematicall y > using logarithmic base 10. When referring to power, below are the > calculated values using the equation dB = 10xLog10(P/Po): > > 0 dB = 1 > 3 dB = 1.995 = ~2 > 6 dB = 3.981 = ~4 > 9 dB = 7.95 = ~8 > 10 dB = 10.0 > 20 dB = 100.0 > 30 dB = 1000.0 > 40 dB = 10,000.0 > > So 40 DB represents a ratio of 10,000, not 13. If 0 dB = 1 milliWatt, > then 40 dB = 10 Watts. > > Everything else you say below is correct except that RF engineers, as wel l > as LiDAR engineers, refer to too much signal as saturation, not splatter. > Maybe I'm hanging out with a different bunch of engineers, but we use wha t > the literature says. > > Henador Titzoff > > > flyadive(at)gmail.com> wrote: > > > Hi Kevin: > > > You are 300% right to question Old Wive's Tails. > The Paint Story is not without some merit. It stems from the idea of how > the Color was produced. Black and Gray for example could come from a > CARBON. Carbon is conductive, not highly so but conductive. After all > Carbon Resistors are exactly that Carbon and Conductive. > The old Green, Copper and Bronze have Copper and Bronze metals in them. > White paint can have Titanium Dioxide in it and titanium is metal and > slightly conductive. > There are also paints such as primers which have Zinc in them. > Well, you can see the thought process, that conductive paints can cause > some problems. > So, why take the chance... The industry makes a general Old Wive's Tail > statement of Do Not Paint GPS Antennas. > Of course the Pigment of paints have changed over the years, too bad the > Old Wive's Tails have a stronger following than the process of common > sense. > What YOU can do is read the Ingredients List of what makes the paint the > color (Pigment) and see if any of the above items are listed. ALSO, you > can look up the MSDS for the paint. > > Next: - > OVER DRIVEN: - We should be so lucky. > YES! There is such a thing. It is also know in Receiver Theory as Front > End Over Load. > Too much signal is received and causes SPLATTER - Too much signal coverin g > too wide a bandwidth. > The 'Active" GPS Antennas do have amplifiers built into them. They > usually range between 10 to 40 dB Gain. > The rule of dB is every 3 dB doubles your signal. So, YES, in theory if > you have a 40 dB gain antenna you could have 40/3 = 13 times the > un-amplified signal. That could be too much for the receiver to handle. > Of course there is a loss in the coax, loss in each of the connectors and > an additional loss in the 90 Deg connector. > So, if an engineer sits down with the slide-ruler the NUMBERS would say > YES, there is too much signal coming down the RG-400. SO! Why not be > smarter than the Engineer - Save your Money - Buy RG-58/AU and run the > shortest length possible? Buy It - HELL! I have a 150 foot spool! But > NOooooo.... Common Sense is over ruled by Sales Pitch and owners spend > $4.00 per foot for RG-400 and they buy 10 foot when only 3 foot is need f or > the run. 10 Foot @ $4 = $40 Vs 3 Foot @ $0.75 = $2.25. > So Kevin, you did VERY - VERY GOOD! > > Guess What! I did the EXACT same thing with the Stratus ESG coax > situation as you. I also mounted it on my Glare Shield. But, I have a > carper over the antenna so I did not have to paint the antenna. > > Works Great, Works Fine - FM! > > Barry > > > message posted by: "kjlpdx" > > > I'm interested in hearing from an engineer who might know about what > really goes on with my stratus esg gps antenna. they say to use RG400 > cable, 10' minimum, and never paint the antenna. they also told me the > strength ratings should run in the 30's. I have 3' of RG400 with a > mechanical 90=C3=82=C2=B0 elbow, I spray painted the antenna flat black a nd mounted > it on the glareshield of my RV. my readings are all in the 40's. they tol d > me this shows an overdriven condition. > so why use low impedance cable then need 10'? my iFly740 and Lowrance 100 0 > gps's have antennas with much smaller cables. the iFly shows WAAS grade > accuracy, using an antenna 1/4 the size of the stratus RAMI antenna. > when does being overdriven prove to be a problem? is this a situation > where I could add more mechanical connectors to increase impedance rather > than more cable length? > I get the feeling things get written and then forever repeated, such as > never paint an antenna, without asking any questions. could I use a > different antenna than the RAMI brand? should I not worry about any of th is > and just go fly? > > ________________________________________________________________________________
Date: Dec 23, 2018
3dB is a doubling of whatever you measure. (Actually a factor of 10^0.3 = 1.995) Of course you have to say what you=99re comparing with, so we talk ab out dBA, dBV, dBm, for sound level relative to the quietest detectable by th e human ear, volts, or power (in mW), respectively. If you=99re talking about Voltage then 40dB is by definition a ratio o f 10,000 to 1. Which, into the same load impedance corresponds to a power ra tio of 10^8 to 1. On Dec 23, 2018, at 09:04, FLYaDIVE wrote: Alec: I did say "Rule of Thumb". I did not look up if the dB gain expressed in th e manual is voltage or power, but I'm pretty sure it would be voltage. And t he rule of thumb is the voltage signal will double with every 3 dB of gain. Ya got me... I did not sit down with my slide rule and work out the voltag e gain, I am just trying to show a relative number that non engineers can w ork with. But, your numbers are incorrect. A 10,000:1 dB ratio gain would be more lik e 80 dB's not 40 dB's. See: Common Gains and Losses Expressed in Decibels http://www.sengpielaudio.com/calculator-FactorRatioLevelDecibel.htm Barry > On Sat, Dec 22, 2018 at 11:31 PM Alec Myers wrote: > 40dB is 40/3 = 13.3 doublings, or a ratio of 2^13.3, which is about 10,0 00, as you say. > > On Dec 22, 2018, at 21:10, Henador Titzoff wro te: > > It's an old wive's tale that a 40 dB gain is 40/3 = 13 times power gain o ver 0 dB. > > The decibel is a ratio of two physical properties expressed mathematically using logarithmic base 10. When referring to power, below are the calculat ed values using the equation dB = 10xLog10(P/Po): > > 0 dB = 1 > 3 dB = 1.995 = ~2 > 6 dB = 3.981 = ~4 > 9 dB = 7.95 = ~8 > 10 dB = 10.0 > 20 dB = 100.0 > 30 dB = 1000.0 > 40 dB = 10,000.0 > > So 40 DB represents a ratio of 10,000, not 13. If 0 dB = 1 milliWatt, t hen 40 dB = 10 Watts. > > Everything else you say below is correct except that RF engineers, as well as LiDAR engineers, refer to too much signal as saturation, not splatter. M aybe I'm hanging out with a different bunch of engineers, but we use what th e literature says. > > Henador Titzoff > > om> wrote: > > > Hi Kevin: > > > You are 300% right to question Old Wive's Tails. > The Paint Story is not without some merit. It stems from the idea of how t he Color was produced. Black and Gray for example could come from a CARBON. Carbon is conductive, not highly so but conductive. After all Carbon Resi stors are exactly that Carbon and Conductive. > The old Green, Copper and Bronze have Copper and Bronze metals in them. > White paint can have Titanium Dioxide in it and titanium is metal and slig htly conductive. > There are also paints such as primers which have Zinc in them. > Well, you can see the thought process, that conductive paints can cause so me problems. > So, why take the chance... The industry makes a general Old Wive's Tail s tatement of Do Not Paint GPS Antennas. > Of course the Pigment of paints have changed over the years, too bad the O ld Wive's Tails have a stronger following than the process of common sense. > What YOU can do is read the Ingredients List of what makes the paint the c olor (Pigment) and see if any of the above items are listed. ALSO, you can l ook up the MSDS for the paint. > > Next: - > OVER DRIVEN: - We should be so lucky. > YES! There is such a thing. It is also know in Receiver Theory as Front E nd Over Load. > Too much signal is received and causes SPLATTER - Too much signal covering too wide a bandwidth. > The 'Active" GPS Antennas do have amplifiers built into them. They usua lly range between 10 to 40 dB Gain. > The rule of dB is every 3 dB doubles your signal. So, YES, in theory if yo u have a 40 dB gain antenna you could have 40/3 = 13 times the un-amplifie d signal. That could be too much for the receiver to handle. > Of course there is a loss in the coax, loss in each of the connectors and a n additional loss in the 90 Deg connector. > So, if an engineer sits down with the slide-ruler the NUMBERS would say YE S, there is too much signal coming down the RG-400. SO! Why not be smarter t han the Engineer - Save your Money - Buy RG-58/AU and run the shortest lengt h possible? Buy It - HELL! I have a 150 foot spool! But NOooooo.... Com mon Sense is over ruled by Sales Pitch and owners spend $4.00 per foot for R G-400 and they buy 10 foot when only 3 foot is need for the run. 10 Foot @ $ 4 = $40 Vs 3 Foot @ $0.75 = $2.25. > So Kevin, you did VERY - VERY GOOD! > > Guess What! I did the EXACT same thing with the Stratus ESG coax situatio n as you. I also mounted it on my Glare Shield. But, I have a carper over t he antenna so I did not have to paint the antenna. > > Works Great, Works Fine - FM! > > Barry > > > message posted by: "kjlpdx" >> >> I'm interested in hearing from an engineer who might know about what real ly goes on with my stratus esg gps antenna. they say to use RG400 cable, 10' minimum, and never paint the antenna. they also told me the strength rating s should run in the 30's. I have 3' of RG400 with a mechanical 90=C3=82=C2=B0 elbow, I spray painted the antenna flat black and mounted it on the glaresh ield of my RV. my readings are all in the 40's. they told me this shows an o verdriven condition. >> so why use low impedance cable then need 10'? my iFly740 and Lowrance 100 0 gps's have antennas with much smaller cables. the iFly shows WAAS grade ac curacy, using an antenna 1/4 the size of the stratus RAMI antenna. >> when does being overdriven prove to be a problem? is this a situation whe re I could add more mechanical connectors to increase impedance rather than m ore cable length? >> I get the feeling things get written and then forever repeated, such as n ever paint an antenna, without asking any questions. could I use a different antenna than the RAMI brand? should I not worry about any of this and just g o fly? > ________________________________________________________________________________
Date: Dec 23, 2018
>3dB is a doubling of whatever you measure. (Actually a factor of 10^0.3 = 1.995) I see this is actually true only for power quantities and power-like quantities. For field quantities and field-like quantities 3dB is a ratio of 10^0.15 = 1.41. So a signal ratio of 40dB is ten thousand times the power and 100 times the voltage. Thats what you get when you put the engineers in charge of defining units instead of the physicists... ________________________________________________________________________________
Date: Dec 23, 2018
> > That=99s what you get when you put the engineers in charge of defin ing units > instead of the physicists... > I TOTALLY AGREE! I have NEVER seen a more argumentative bunch than Engineers. They all went to collage. They all took the same courses. They all learned the SAME physics. <-- Well,they should have! They all learned the same electronics. Yet they disagree on more things than Congress. Three Engineers, an Electrical Engineer, a Mechanical Engineer and a Civil Engineer were discussing what kind of an engineer GOD must be. The Electrical Engineer said: He must be an Electrical Engineer, think about it: And consider the miles of nerve courses in the body. Consider all the nerve endings. Consider all the synapse=99s in the brain sending ele ctrical impulses all throughout the body. GOD is an Electrical Engineer! The Mechanical Engineer spoke up and said: He must be a Mechanical Engineer, think about it: And consider all of the bones throughout the body. Consider all the muscles pulling against each other supporting the bones. Consider how all the bones and muscles can reproduce as they become weak or damaged. GOD is a Mechanical Engineer! Then the Civil Engineer spoke up and said: He MUST be a Civil Engineer =93 And with that the other two engineers broke into a raucous laughter. Again the Civil Engineer spoke up and said: Think about it: Who else other than a Civil Engineer would put a waste dump right around the corner from a playground? Barry ________________________________________________________________________________
Date: Dec 23, 2018
There was a fourth person in the story, a politician, who went last. He said, =9CGod was most certainly a politician. The Bible says in the b eginning there was chaos. Who do you think created the chaos?=9D Lyn On Sun, Dec 23, 2018 at 08:18 FLYaDIVE wrote: > That=99s what you get when you put the engineers in charge of defin ing units >> instead of the physicists... >> > > I TOTALLY AGREE! > > I have NEVER seen a more argumentative bunch than Engineers. > They all went to collage. > They all took the same courses. > They all learned the SAME physics. <-- Well,they should have! > They all learned the same electronics. > Yet they disagree on more things than Congress. > > Three Engineers, an Electrical Engineer, a Mechanical Engineer and a Civi l > Engineer were discussing what kind of an engineer GOD must be. > > The Electrical Engineer said: He must be an Electrical Engineer, think > about it: > > And consider the miles of nerve courses in the body. Consider all the > nerve endings. Consider all the synapse=99s in the brain sending e lectrical > impulses all throughout the body. GOD is an Electrical Engineer! > > > The Mechanical Engineer spoke up and said: He must be a Mechanical > Engineer, think about it: > > And consider all of the bones throughout the body. Consider all the > muscles pulling against each other supporting the bones. Consider how al l > the bones and muscles can reproduce as they become weak or damaged. GOD is > a Mechanical Engineer! > > > Then the Civil Engineer spoke up and said: He MUST be a Civil Engineer =93 > And with that the other two engineers broke into a raucous laughter. Aga in > the Civil Engineer spoke up and said: Think about it: > > Who else other than a Civil Engineer would put a waste dump right around > the corner from a playground? > > > Barry > ________________________________________________________________________________
Date: Dec 23, 2018
Subject: Z-14 Switches Preferred...
My first post. I have to assume this has been checked out before, but could not find it... >From my fresh copy of AeroElectric Connection, I have found some surprises... and I am not accustomed to doing circuit design - I am a Mechanical Engineer. Firstissue: Page 11-21, Fig 11-22 is supposed to be an excerpt from Z-14 (which I plan to use on my electrically dependent engine IFR ship) showing a diode bridge for operation of the cross feed contactor; Appendix Z-14 in my book shows three 1N5400 diodes. Tracing the diodes in each case, these appear to be the same electrically, but which is the preferred set of parts for this system? Second issue. The starter cross feed switch on Z-14: In Appendix Z-14, the switch is labeled S700-2-7, with a Circle L, yet the drawing shows momentary-on the start side but stays on in the cross feed position. 2-7 is an (ON)-OFF-(ON) switch, not the (ON)-OFF-ON shown which seems to be an S700-2-5. Does the circuit self-energize and so does not need the switch to stay the Crossfeed position? If yes, does it disconnect when we turn off both masters? Then on page 17-10, Bob proposes the S700-2-50 for the combined starter and cross feed. So, which switch is the now current right way to build this circuit? Do I use a diode bridge or three 1N5400 diodes? Do I use the 2-7, the 2-5, or the 2-50? And "for extra credit", why do we go with each version? Bill Simpson ________________________________________________________________________________
Date: Dec 23, 2018
On Sun, Dec 23, 2018 at 12:01 PM Lyn Robertson wrote: > There was a fourth person in the story, a politician, who went last. He > said, =9CGod was most certainly a politician. The Bible says in the beginning > there was chaos. Who do you think created the chaos?=9D > > Lyn > But Politicians are not Engineers. For if they were, an engineer, they would have invented a better way to cover their ass, other than by rhetoric and at the people's expense. Barry ________________________________________________________________________________
Subject: Re: Z-14 Switches Preferred...
Date: Dec 23, 2018
On Dec 23, 2018, 12:10 PM, at 12:10 PM, Bill Simpson wrote: >My first post=2E I have to assume this has been checked out before, but >could not find it=2E=2E=2E > > >>From my fresh copy of AeroEl ectric Connection, I have found some >surprises=2E=2E=2E and I am not accus tomed to doing circuit design - I am a >Mechanical Engineer=2E Firstissue: > > >Page 11-21, Fig 11-22 is supposed to be an excerpt from Z-14 (which I >plan to use on my electrically dependent engine IFR ship) showing a >diode bridge for operation of the cross feed contactor; > > >Appendix Z-14 in my book shows three 1N5400 diodes=2E > > >Tracing the diodes in each case, th ese appear to be the same >electrically, but which is the preferred set of parts for this system? > > >Second issue=2E The starter cross feed switch on Z-14: > > >In Appendix Z-14, the switch is labeled S700-2-7, with a Circ le L, yet >the drawing shows momentary-on the start side but stays on in th e cross >feed position=2E 2-7 is an (ON)-OFF-(ON) switch, not the (ON)-OFF- ON >shown which seems to be an S700-2-5=2E Does the circuit self-energize a nd >so does not need the switch to stay the Crossfeed position? If yes, >do es it disconnect when we turn off both masters? > > >Then on page 17-10, B ob proposes the S700-2-50 for the combined starter >and cross feed=2E > > >So, which switch is the now current right way to build this circuit? Do >I use a diode bridge or three 1N5400 diodes? Do I use the 2-7, the 2-5, >or the 2-50? And "for extra credit", why do we go with each version? > > >Bill Simpson ________________________________________________________________________________
Date: Dec 23, 2018
While were on the subject. A mathematician, a physicist and an engineer are all asked to examine the hypothesis that all odd numbers are prime. The mathematician goes first, saying as follows: One is prime, three is prime, five is prime, seven is prime, nine ISNT prime, so the hypothesis fails by counterexample. Then the physicist, who says: One is prime, three is prime, five is prime, seven is prime, nine isnt prime, but well call it experimental error, eleven is prime and thirteen is prime. Thats enough for me. I accept the hypothesis as true. Finally the engineer steps up. One is prime, three is prime, five is prime, seven is prime, nine is prime. And heres one for the maths nerds amongst us: Q: Whats green and commutes? A: An Abeilan grape. On Dec 23, 2018, at 1:00 PM, FLYaDIVE wrote: On Sun, Dec 23, 2018 at 12:01 PM Lyn Robertson wrote: There was a fourth person in the story, a politician, who went last. He said, God was most certainly a politician. The Bible says in the beginning there was chaos. Who do you think created the chaos? Lyn But Politicians are not Engineers. For if they were, an engineer, they would have invented a better way to cover their ass, other than by rhetoric and at the people's expense. Barry ________________________________________________________________________________
Date: Dec 23, 2018
My crossfeed does close automatically during cranking if either (or both) batteries are available. I have an older version of Z-14 which also incorporates a little 30 amp automotive relay in the control circuit. It uses a simple ON -OFF switch that will close the crossfeed whether the battery master is on or off. (My crossfeed contactor is fed by both hot batt buss's and don't require the battery master to be on). I leave that crossfeed switch OFF at all times unless one alternator has failed. I think you are referring to a later circuit utilizing a 3 position crossfeed switch. It has a continuous ON, OFF, or momentary crank the engine position. I would leave that switch in the OFF position unless cranking or after losing one alternator. The 3 diodes insure that current from either side of Z-14 can close the contactor. Normally operating with the crossfeed contactor open insures that your low voltage warning devices will immediately warn you if one alternator drops offline. Ken On 23/12/2018 2:00 PM, Charlie England wrote: > > > On Dec 23, 2018, at 12:10 PM, Bill Simpson > wrote: > > My first post. I have to assume this has been checked out before, > but could not find it... > > > From my fresh copy of AeroElectric Connection, I have found some > surprises... and I am not accustomed to doing circuit design - I > am a Mechanical Engineer. Firstissue: > > > Page 11-21, Fig 11-22 is supposed to be an excerpt from Z-14 > (which I plan to use on my electrically dependent engine IFR ship) > showing a diode bridge for operation of the cross feed contactor; > > > Appendix Z-14 in my book shows three 1N5400 diodes. > > > Tracing the diodes in each case, these appear to be the same > electrically, but which is the preferred set of parts for this > system? > > > Second issue. The starter cross feed switch on Z-14: > > > In Appendix Z-14, the switch is labeled S700-2-7, with a Circle L, > yet the drawing shows momentary-on the start side but stays on in > the cross feed position. 2-7 is an (ON)-OFF-(ON) switch, not the > (ON)-OFF-ON shown which seems to be an S700-2-5. Does the circuit > self-energize and so does not need the switch to stay the > Crossfeed position? If yes, does it disconnect when we turn off > both masters? > > > Then on page 17-10, Bob proposes the S700-2-50 for the combined > starter and cross feed. > > > So, which switch is the now current right way to build this > circuit? Do I use a diode bridge or three 1N5400 diodes? Do I use > the 2-7, the 2-5, or the 2-50? And "for extra credit", why do we > go with each version? > > > Bill Simpson > > Hi Bill, > > > I don't have my book handy, but the 5400 diode(s) are rated at 3A, > while you can buy almost any rating for the diode block. The block > is also easier to mount, and easier to heatsink, if required, > while the 5400s must be soldered to some kind of support. Your > application would determine what is best for you. > > Charlie > > ________________________________________________________________________________
Date: Dec 23, 2018
> > >Appendix Z-14 in my book shows three 1N5400 diodes. > > >Tracing the diodes in each case, these appear to be the same >electrically, but which is the preferred set of parts for this system? Either works fine . . . your choice. >Second issue. The starter cross feed switch on Z-14: > > >In Appendix Z-14, the switch is labeled S700-2-7, with a Circle L, >yet the drawing shows momentary-on the start side but stays on in >the cross feed position. 2-7 is an (ON)-OFF-(ON) switch, not the >(ON)-OFF-ON shown which seems to be an S700-2-5. Does the circuit >self-energize and so does not need the switch to stay the Crossfeed >position? If yes, does it disconnect when we turn off both masters? > > >Then on page 17-10, Bob proposes the S700-2-50 for the combined >starter and cross feed. > > >So, which switch is the now current right way to build this circuit? >Do I use a diode bridge or three 1N5400 diodes? Do I use the 2-7, >the 2-5, or the 2-50? And "for extra credit", why do we go with each version? 2-50 and 2-7 are errors. The latest drawing on the website shows that the error was corrected when 2-5 was called out at revision P Emacs! Bob . . . ________________________________________________________________________________
Date: Dec 24, 2018
You have a better way to cover your rear than at other people's expense? com> wrote: On Sun, Dec 23, 2018 at 12:01 PM Lyn Robertson wr ote: There was a fourth person in the story, a politician, who went last. He sai d, =9CGod was most certainly a politician. The Bible says in the begi nning there was chaos.=C2- Who do you think created the chaos?=9D Lyn But Politicians are not Engineers.=C2- For if they were, an engineer, the y would have invented a better way to cover their ass, other than by rhetor ic and at the people's expense. Barry ________________________________________________________________________________
Date: Dec 23, 2018
Ernest: You are 100% correct. Sad but true, why do what's right when you can do what you want and put the blame on someone else. Why dip into your own pocket when you can steal from someone else. AND steal legally! Barry On Sun, Dec 23, 2018 at 10:53 PM Ernest Christley wrote: > You have a better way to cover your rear than at other people's expense? > m> > wrote: > > > On Sun, Dec 23, 2018 at 12:01 PM Lyn Robertson > wrote: > > There was a fourth person in the story, a politician, who went last. He > said, =9CGod was most certainly a politician. The Bible says in the beginning > there was chaos. Who do you think created the chaos?=9D > > Lyn > > > But Politicians are not Engineers. For if they were, an engineer, they > would have invented a better way to cover their ass, other than by rhetor ic > and at the people's expense. > > Barry > > ________________________________________________________________________________
Subject: Are you ready for Requirements For The Collection of
Glass
Date: Dec 23, 2018
The glass used for that glass curtain wall need to be safety glass, mainly like Building Tempered Glass, laminated (glued) goblet, insulating glass, fireproof tumbler, solar control coated cup and low-emission coated glass (High Transmission Low-E Glass). The specific selection requirements are seeing that follows: 1. Safety glass need to be used for the curtain wall. The thickness on the glass should not be below 6mm. The thickness from the full glass curtain wall rib glass can't be less than 12mm. COUPLE OF. The appearance quality in addition to technical index of drift glass used for heat-reflecting coated glass shall abide by the requirements of excellent products or first-class products in the current national standard "Float Glass". SEVERAL. The insulating double glazed windows (https://www.ahwhglass.com/Specialties/Insulatedglass/) belonging to the curtain wall should end up being sealed with two stations. The insulating glass from the exposed frame curtain wall should be made of polysulfide sealant and butyl sealant. The insulating glass of the semi-hidden frame curtain wall will likely to be made of silicone structural sealant as well as butyl sealant; the coated surface should be the second of the actual insulating glass. Or for the third side. 4, the laminated glass with the curtain wall should be processed by polyvinyl butyral (PVB) picture dry processing of laminated cup. The thickness of your interlayer film (PVB) with the point-supported glass curtain wall structure laminated glass shall not be not as much as 0. 76 mm. 5, tempered glass should adhere to the provisions of GB9963 "tempered glass". A FEW. All curtain wall glass really should be edge treated. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=486527#486527 ________________________________________________________________________________
Date: Dec 24, 2018
Subject: Re: what is the truth about gps antennas?
At 09:33 AM 12/23/2018, you wrote: > > > >3dB is a doubling of whatever you measure. > (Actually a factor of 10^0.3 = 1.995) > >I see this is actually true only for power >quantities and power-like quantities. For field >quantities and field-like quantities 3dB is a >ratio of 10^0.15 = 1.41. So a signal ratio of >40dB is ten thousand times the power and 100 times the voltage. > >That=99s what you get when you put the engineers >in charge of defining units instead of the physicists. The Bel (or its smaller descendant deciBel) was derived from concepts in physics. . . as were many other dimensionless numbers that described RATIOS of many quantities that do have dimensions. Look up dimensionless physical constants like proton to electron mass ratio, Plank's constant, Coulomb's constant, etc. Then there are ratios near and dear to aviation like Mach number, Reynolds number, strain, and yes . . . even deciBels. The Bel is always about energy ratios but is still valid for discussion power. While power is a rate function, it is proportional to energy when the rates are defined over the same intervals of time. It is proper to discuss ratios of power (like watts) and amplitudes (like voltage, amps) in terms of dB if one compensates for the effects of amplitude on power in the system. This is accomplished with application of formula that accounts for the square law effects of amplitude on power. Hence the constant for "deci" (10) has to be doubled to 20 when considering ratios of amplitude. Emacs! This was no shortcoming on the part of engineers vs. physicists . . . they've all been on the same page since day-one. Bob . . . ________________________________________________________________________________
Date: Dec 24, 2018
At 10:13 AM 12/23/2018, you wrote: >That=99s what you get when you put the engineers >in charge of defining units instead of the physicists... > > >I TOTALLY AGREE!=C2 =C2 > >I=C2 have NEVER seen a more argumentative bunch than Engineers. >They all went=C2 to collage. >They all took the same courses. >They all learned the SAME physics.=C2 <-- Well,they should have! >They all learned the same electronics. >Yet they disagree on more things than Congress. I cannot speak for your personal experiences except to observed that they are far removed from my own. But in any case, this line of thought does not advance the mission of this forum. Bob . . . ________________________________________________________________________________
Date: Dec 24, 2018
Subject: Relay sticking
We had a strange event last week with our O-200 powered CH750. After running the battery down during a fuel gauge calibration that lasted over an hour, one of our pilots tried to start the engine to taxi back but with the already depleted battery and a less than perfect start procedure they gave up after a couple weak start attempts. I walked over to the aircraft to brief them on a prop start and when I asked for the master on the starter ran. Shut the master off, cycled the start button rapidly a dozen times, master on again and the starter ran again. I could hear the starter relay clicking loudly each time power was applied so it does not seem like there was a physical failure of the relay but more some electrical short activating the relay each time power was applied. The build team inspected the relay and found a loose connection. Tightening it took the problem from continuous to intermittent; in their words "it's fixed but it did it again once". We have removed the relay for replacement, I still think the switch is suspect but they've decided the problem is the relay. Does the aeroelectric list think there would be value in cutting open the relay and examining it? Any suggestions on how best to do so? Thank you, Sebastien ________________________________________________________________________________
Subject: Re: Relay sticking
Date: Dec 24, 2018
I don't think you have a problem. I think that if the engine didn't actually start, the starter might not reach enough speed to disengage. Also, extended cranking at low voltage probably heated the solenoid a lot, causing sticking in it. After the battery is fully recharged, give it another try, without cranking more than 10-15 seconds on any try. It is likely to start, and the starter will disengage normally. You can test the relay on the bench, without a starter connected, just battery cable on input side and switchable 12V on ignition terminal, just activating long enough to see your multi-meter show voltage on the output terminal. On 12/24/2018 6:14 PM, Sebastien wrote: > We had a strange event last week with our O-200 powered CH750. After > running the battery down during a fuel gauge calibration that lasted > over an hour, one of our pilots tried to start the engine to taxi back > but with the already depleted battery and a less than perfect start > procedure they gave up after a couple weak start attempts. I walked over > to the aircraft to brief them on a prop start and when I asked for the > master on the starter ran. Shut the master off, cycled the start button > rapidly a dozen times, master on again and the starter ran again. I > could hear the starter relay clicking loudly each time power was applied > so it does not seem like there was a physical failure of the relay but > more some electrical short activating the relay each time power was applied. > > The build team inspected the relay and found a loose connection. > Tightening it took the problem from continuous to intermittent; in their > words "it's fixed but it did it again once". > > We have removed the relay for replacement, I still think the switch is > suspect but they've decided the problem is the relay. Does the > aeroelectric list think there would be value in cutting open the relay > and examining it? Any suggestions on how best to do so? > > Thank you, > > Sebastien ________________________________________________________________________________
Date: Dec 24, 2018
I say change the relay. (And have done, on two different aircraft, for identical symptoms.) If the relay sticks on a good engine start it will take the starter motor with it, unless you shut it down soon, and its hard to spot unless you have a starter energized lamp. In my case I was lucky, the massive current drain took the radio out before I took off, but I only worked out why when I heard the weird grinding noise of the engine driving the locked up starter when I took my headset off. That was an O235 engine, similar starter configuration to yours. Do you have a starter energized lamp? On Dec 24, 2018, at 21:04, Kelly McMullen wrote: I don't think you have a problem. I think that if the engine didn't actually start, the starter might not reach enough speed to disengage. Also, extended cranking at low voltage probably heated the solenoid a lot, causing sticking in it. After the battery is fully recharged, give it another try, without cranking more than 10-15 seconds on any try. It is likely to start, and the starter will disengage normally. You can test the relay on the bench, without a starter connected, just battery cable on input side and switchable 12V on ignition terminal, just activating long enough to see your multi-meter show voltage on the output terminal. > On 12/24/2018 6:14 PM, Sebastien wrote: > We had a strange event last week with our O-200 powered CH750. After running the battery down during a fuel gauge calibration that lasted over an hour, one of our pilots tried to start the engine to taxi back but with the already depleted battery and a less than perfect start procedure they gave up after a couple weak start attempts. I walked over to the aircraft to brief them on a prop start and when I asked for the master on the starter ran. Shut the master off, cycled the start button rapidly a dozen times, master on again and the starter ran again. I could hear the starter relay clicking loudly each time power was applied so it does not seem like there was a physical failure of the relay but more some electrical short activating the relay each time power was applied. > The build team inspected the relay and found a loose connection. Tightening it took the problem from continuous to intermittent; in their words "it's fixed but it did it again once". > We have removed the relay for replacement, I still think the switch is suspect but they've decided the problem is the relay. Does the aeroelectric list think there would be value in cutting open the relay and examining it? Any suggestions on how best to do so? > Thank you, > Sebastien ________________________________________________________________________________
Date: Dec 24, 2018
We do not have a starter energized light but we do have a Dynon Skyview so I'm thinking there must be a way of connecting it to a GP input to display a warning. Have not checked the Dynon install manual yet. On Mon, Dec 24, 2018, 20:50 Alec Myers > I say change the relay. (And have done, on two different aircraft, for > identical symptoms.) If the relay sticks on a good engine start it will > take the starter motor with it, unless you shut it down soon, and it =99s hard > to spot unless you have a =9Cstarter energized=9D lamp. In my case I was lucky, > the massive current drain took the radio out before I took off, but I onl y > worked out why when I heard the weird grinding noise of the engine drivin g > the locked up starter when I took my headset off. > > That was an O235 engine, similar starter configuration to yours. > > Do you have a =9Cstarter energized=9D lamp? > > > On Dec 24, 2018, at 21:04, Kelly McMullen wrote: > > kellym(at)aviating.com> > > I don't think you have a problem. I think that if the engine didn't > actually start, the starter might not reach enough speed to disengage. > Also, extended cranking at low voltage probably heated the solenoid a lot , > causing sticking in it. After the battery is fully recharged, give it > another try, without cranking more than 10-15 seconds on any try. It is > likely to start, and the starter will disengage normally. You can test th e > relay on the bench, without a starter connected, just battery cable on > input side and switchable 12V on ignition terminal, just activating long > enough to see your multi-meter show voltage on the output terminal. > > > On 12/24/2018 6:14 PM, Sebastien wrote: > > We had a strange event last week with our O-200 powered CH750. After > running the battery down during a fuel gauge calibration that lasted over > an hour, one of our pilots tried to start the engine to taxi back but wit h > the already depleted battery and a less than perfect start procedure they > gave up after a couple weak start attempts. I walked over to the aircraft > to brief them on a prop start and when I asked for the master on the > starter ran. Shut the master off, cycled the start button rapidly a dozen > times, master on again and the starter ran again. I could hear the starte r > relay clicking loudly each time power was applied so it does not seem lik e > there was a physical failure of the relay but more some electrical short > activating the relay each time power was applied. > > The build team inspected the relay and found a loose connection. > Tightening it took the problem from continuous to intermittent; in their > words "it's fixed but it did it again once". > > We have removed the relay for replacement, I still think the switch is > suspect but they've decided the problem is the relay. Does the aeroelectr ic > list think there would be value in cutting open the relay and examining i t? > Any suggestions on how best to do so? > > Thank you, > > Sebastien > > =========== =========== =========== =========== =========== =========== > > ________________________________________________________________________________
From: William Daniell <wdaniell.longport(at)gmail.com>
Date: Dec 25, 2018
Subject: DPSK Unlock on Dynon Xpndr
I have this "DPSK Unmlock" on my Dynon. The last time it appeared they changed the unit so this is the second unit to suffer the same thing. I am interested to know what it means and if anything in my system might be provoking it. My aircraft is a Europa with the Rotax Z16 (which you all helped me with and which is working very well) and I followed manufacturer's instructions with separating ADSB and Transponder antenna. I used ADVANCED AIRCRAFT ELECTRONICS HIGH GAIN TRANSPONDER ANTENNA (L2) from ACS for both transponder and ADSB. Everything worked normally (they see me on radar and I can see other traffic). When I get the message, I cycle the transponder and the message goes away. So is this something in my system or is it a manufacturing issue? Thanks and Happy Holidays to all Will William Daniell LONGPORT +57 310 295 0744 ________________________________________________________________________________
Subject: Re: DPSK Unlock on Dynon Xpndr
Date: Dec 25, 2018
This? http://dynonavionics=2Ecom/cgi-bin/yabb2/YaBB=2Epl?num=1508284062 =81=A3Charlie=8B On Dec 25, 2018, 8:44 AM, at 8:44 AM, William Da niell wrote: >I have this "DPSK Unmlock" on my Dynon=2E The last time it appeared they >changed the unit so this is the second unit to suffer the same thing=2E > >I am interested to know wha t it means and if anything in my system >might be >provoking it=2E > >My ai rcraft is a Europa with the Rotax Z16 (which you all helped me >with >and w hich is working very well) and I followed manufacturer's >instructions >wit h separating ADSB and Transponder antenna=2E > >I used ADVANCED AIRCRAFT EL ECTRONICS HIGH GAIN TRANSPONDER ANTENNA (L2) >from ACS for both transponder and ADSB=2E > >Everything worked normally (they see me on radar and I can see other >traffic)=2E When I get the message, I cycle the transponder a nd the >message goes away=2E > >So is this something in my system or is it a manufacturing issue? > >Thanks and Happy Holidays to all > >Will > > > >William Daniell >LONGPORT >+57 310 295 0744 ________________________________________________________________________________
Date: Dec 25, 2018
Be very careful with your generalizations. A Continental starter is very different than a Lycoming starter. There are no models I know of shared between those brands. So it is pretty unlikely that they are "similar configuration". Lycoming starters are on the front of the engine, Continentals on the rear of the engine, just for example. Some may have a relay (solenoid) mounted on the starter, some do not. You may be right about replacing relay, given the generally low cost. Yes, having a starter energized lamp is a good suggestion regardless. On 12/24/2018 9:45 PM, Alec Myers wrote: > > I say change the relay. > > That was an O235 engine, similar starter configuration to yours. > > Do you have a starter energized lamp? ________________________________________________________________________________
Date: Dec 25, 2018
Thats the one! But i was wondering if anyone knows why this happens.... Dynon just asked me to send the unit back last time this happened...this is the second unit with the same issue which seems a little wierd. Maybe it was a bad batch. Also without a transponder these days you're grounded. Certainly in Colombia you cant fly wiithout a working transponder. Will On Tue, Dec 25, 2018, 10:18 Charlie England This? > http://dynonavionics.com/cgi-bin/yabb2/YaBB.pl?num=1508284062 > > Charlie > On Dec 25, 2018, at 8:44 AM, William Daniell > wrote: >> >> I have this "DPSK Unmlock" on my Dynon. The last time it appeared they >> changed the unit so this is the second unit to suffer the same thing. >> >> I am interested to know what it means and if anything in my system might >> be provoking it. >> >> My aircraft is a Europa with the Rotax Z16 (which you all helped me with >> and which is working very well) and I followed manufacturer's >> instructions with separating ADSB and Transponder antenna. >> >> I used ADVANCED AIRCRAFT ELECTRONICS HIGH GAIN TRANSPONDER ANTENNA (L2) >> from ACS for both transponder and ADSB. >> >> Everything worked normally (they see me on radar and I can see other >> traffic). When I get the message, I cycle the transponder and the >> message goes away. >> >> So is this something in my system or is it a manufacturing issue? >> >> Thanks and Happy Holidays to all >> >> Will >> >> >> >> >> >> William Daniell >> LONGPORT >> +57 310 295 0744 >> > ________________________________________________________________________________
Date: Dec 25, 2018
On Dec 25, 2018, at 10:45 AM, Kelly McMullen wrote: >Be very careful with your generalizations. A Continental starter is very different than a Lycoming starter. There are no models I know of shared between those brands. So it is pretty unlikely that they are "similar configuration. For sure. I understood Sebastien had a Lycoming O-200, and the aircraft I was writing about has a lycoming O-235. If he has a Continental O-200 then theyre not similar. However the second engine wth which I had a sticky starter solenoid problem was a Continental IO-470, where the starter adapter is damaged within a few seconds of a locked up starter contactor, The starter adapter is impossible to reach without removing the engine from the aircraft. Lycoming - or Continental - I would take absolutely no chances with running either engine with the slightest suspicion of a sticky solenoid. ________________________________________________________________________________
Date: Dec 25, 2018
Sorry - I should be less ambiguous. Were talking about sticky starter *contactors* - regardless of whether the starter has a solenoid or some other engagement mechanism. A new contactor is about $100 for a PMA one. Princess Auto (I know Sebastien is in Canada) used to do an intermittent duty 12v contactor of identical dimensions for CDN$16. On Dec 25, 2018, at 11:55 AM, Alec Myers wrote: On Dec 25, 2018, at 10:45 AM, Kelly McMullen wrote: > Be very careful with your generalizations. A Continental starter is very different than a Lycoming starter. There are no models I know of shared between those brands. So it is pretty unlikely that they are "similar configuration. For sure. I understood Sebastien had a Lycoming O-200, and the aircraft I was writing about has a lycoming O-235. If he has a Continental O-200 then theyre not similar. However the second engine wth which I had a sticky starter solenoid problem was a Continental IO-470, where the starter adapter is damaged within a few seconds of a locked up starter contactor, The starter adapter is impossible to reach without removing the engine from the aircraft. Lycoming - or Continental - I would take absolutely no chances with running either engine with the slightest suspicion of a sticky solenoid. ________________________________________________________________________________
Date: Dec 25, 2018
Sorry, I didn't know Lycoming made an O-200, this one is a Continental. In any case we think the problem is in the relay or switch, not the starter itself. We are planning on replacing the relay with one of these: https://aircraftspruce.ca/catalog/elpages/starterrelay.php At $20 it seems a good idea. What I'm wondering about is how to best cut open the old one in order to see how the failure may have occurred? On Tue, Dec 25, 2018, 09:43 Alec Myers > Sorry - I should be less ambiguous. We=99re talking about sticky st arter > *contactors* - regardless of whether the starter has a solenoid or some > other engagement mechanism. A new contactor is about $100 for a PMA one. > Princess Auto (I know Sebastien is in Canada) used to do an intermittent > duty 12v contactor of identical dimensions for CDN$16. > > > On Dec 25, 2018, at 11:55 AM, Alec Myers wrote: > > > On Dec 25, 2018, at 10:45 AM, Kelly McMullen wrote: > > kellym(at)aviating.com> > > > Be very careful with your generalizations. A Continental starter is ver y > different than a Lycoming starter. There are no models I know of shared > between those brands. So it is pretty unlikely that they are "similar > configuration=9D. > > For sure. I understood Sebastien had a Lycoming O-200, and the aircraft I > was writing about has a lycoming O-235. If he has a Continental O-200 the n > they=99re not similar. > > However the second engine wth which I had a sticky starter solenoid > problem was a Continental IO-470, where the starter adapter is damaged > within a few seconds of a locked up starter contactor, The starter adapte r > is impossible to reach without removing the engine from the aircraft. > Lycoming - or Continental - I would take absolutely no chances with runni ng > either engine with the slightest suspicion of a sticky solenoid. > > =========== =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Dec 25, 2018
>Sorry, I didn't know Lycoming made an O-200, After checking, I guess they dont! Sorry for the confusion. ________________________________________________________________________________
Date: Dec 25, 2018
Date: Dec 25, 2018
Sabastien: There are three test you should do: 1 - Test the Relay 2 - Test the Start Switch 3 - Test the wiring for the Start Switch Test the Relay - Test 1: a> Remove the wires connected to the relay. b> Using an Ohm Meter read across the Contacts Without power applied to the relay you should read an open. c> Using an Ohm Meter read across the Coil You should read some value of resistance. The issue is: IS there one contact or two? If one, then the case is your other contact. AND one contact COULD BE off the INPUT side which would be your B+ d> Using an Ohm Meter read across ONE Coil to Ground (CASE) and then e> Using an Ohm Meter read across ONE (the other ) Coil to Ground (CASE) Start Switch Test 2: a> Remove the wires to the Start Switch. b> Using an Ohm Meter read across the Contacts With the switch NOT pressed it should read open c> Press the Switch. With the switch pressed it should read closed (zero ohms). If anything other than above replace the switch. Test the wiring for the Start Switch Test 3: a> Since you have the wires already disconnected from the Switch and the Relay you can do two checks a1> Across the wires that came off the Start Switch. They should read open. a2> From ONE end of a wire from the switch to the other end of the wire where it connects to the Start Relay. You should read a close (zero ohms) for each wire. IF you get anything other than the above - Replace the wires. OK - Are you ready to POWER TEST the Starter Relay? IF SO - DISCONNECT IT FROM THE STARTER MOTOR. Well, it already should have been done if you followed instructions in Test 1. Using a set of jumper leads. Run a lead from the Battery + to the INPUT side of the Start Relay. Run a second lead from the Battery - (Ground) to the Coil terminal of the relay. It should snap CLOSED. Well, it may not IF you have a relay that has two (2) Coil Terminals. Some relays use an independent + & - connections. IF you have a single coil terminal your INPUT Battery B+ will be readable on the OUTPUT relay terminal. Now, here is a TRICK - Step 1: Read the Voltage across the CLOSED relay terminals. It should read ZERO! If you have a voltage that means there is a RESISTANCE internally in the relay contacts. Throw the relay away! Step 2: While CLOSED, take a resistance reading Across the Input & Output. You should read ZERO Ohms. Why do I call this a TRICK? Because you are reading a Resistance while there is a voltage on the same terminals. YEAH! It is possible to read resistance. And, if you do... Throw the relay away. You want ZERO resistance. Last test: Does the relay have Diode across the Coil? 1 - It should be installed with the + side of the Diode on the Negative - side of the Coil. 2 - Check the Diode for Forward to Reverse Bias Resistance. There should be a Minimum of 10:1 Reverse to Forward. OR... Just throw it away and replace it with a New Diode. OR... Of course you could just replace the relay and diode without testing it. That way you know the circuit has a good relay - But, you have no proof that the old relay is bad. What about the wires and the Start Switch? Side Note: I always, well, almost always, use the above procedure ONLY because sometimes the R&R of the relay is way more time consuming and/or requires two people. AND, I hate being a Pull & Replace Mechanic. You would never know if it was the relay or just a bad ground. Barry On Mon, Dec 24, 2018 at 8:19 PM Sebastien wrote: > We had a strange event last week with our O-200 powered CH750. After > running the battery down during a fuel gauge calibration that lasted over > an hour, one of our pilots tried to start the engine to taxi back but with > the already depleted battery and a less than perfect start procedure they > gave up after a couple weak start attempts. I walked over to the aircraft > to brief them on a prop start and when I asked for the master on the > starter ran. Shut the master off, cycled the start button rapidly a dozen > times, master on again and the starter ran again. I could hear the starter > relay clicking loudly each time power was applied so it does not seem like > there was a physical failure of the relay but more some electrical short > activating the relay each time power was applied. > > The build team inspected the relay and found a loose connection. > Tightening it took the problem from continuous to intermittent; in their > words "it's fixed but it did it again once". > > We have removed the relay for replacement, I still think the switch is > suspect but they've decided the problem is the relay. Does the aeroelectric > list think there would be value in cutting open the relay and examining it? > Any suggestions on how best to do so? > > Thank you, > > Sebastien > ________________________________________________________________________________
Date: Dec 27, 2018
At 07:14 PM 12/24/2018, you wrote: >We had a strange event last week with our O-200 powered CH750. After >running the battery down during a fuel gauge calibration that lasted >over an hour, one of our pilots tried to start the engine to taxi >back but with the already depleted battery and a less than perfect >start procedure they gave up after a couple weak start attempts. I >walked over to the aircraft to brief them on a prop start and when I >asked for the master on the starter ran. The vast majority of starter contactor sticking events occur during an attempt to crank the engine with a weak battery. The fact that you got immediate starter action on closure of the master switch says your starter contactor was 'stuck' shut. > Shut the master off, cycled the start button rapidly a dozen > times, master on again and the starter ran again. I could hear the > starter relay clicking loudly each time power was applied so it > does not seem like there was a physical failure of the relay but > more some electrical short activating the relay each time power was applied. Contacts are welded . . . >The build team inspected the relay and found a loose connection. >Tightening it took the problem from continuous to intermittent; in >their words "it's fixed but it did it again once". > >We have removed the relay for replacement, I still think the switch >is suspect but they've decided the problem is the relay. Does the >aeroelectric list think there would be value in cutting open the >relay and examining it? Any suggestions on how best to do so? Go to a car parts store and pick up a starter contactor that looks like the one in the aircraft spruce catalog . . . it will work just fine. See if the contactor is marked "diode suppressed" or has the word diode on it anywhere or on the packaging. Emacs! Bob . . . ________________________________________________________________________________
Date: Dec 27, 2018
At 11:56 AM 12/25/2018, you wrote: >Sorry, I didn't know Lycoming made an O-200, >this one is a Continental. In any case we think >the problem is in the relay or switch, not the starter itself. > >We are planning on replacing the relay with one of these: > >https://aircraf tspruce.ca/catalog/elpages/starterrelay.php > >At $20=C2 it seems a good idea. Any similar contactor from your local car-parts emporium will do nicely . . . >What I'm wondering about is how to best cut open >the old one in order to see how the failure may have occurred? Send it to me and I'll conduct an 'up town' failure analysis and report back. Bob . . . ________________________________________________________________________________
Subject: Schottky Diode
Date: Dec 27, 2018
Dear Aeroelectric People, I'm in the process of designing an electrical system for a sailplane and am looking for some advice on selecting a Schottky Diode. My aim for this system is to avoid the pilot having to manage the battery power during flight. Ideally the batteries should be switched on before take-off and nothing more done until they are switched off after landing and removed for re-charging. It is accepted the batteries will need charging each night. The batteries cannot be changed because of the provided battery trays. The avionics are primarily powered by 2 x 7Ah gell cells. The equipment specs say the total current drain is 1.7A (including a transponder), therefore it is quite possible to run short of amps after a long flight, a 6 hour flight is not unusual, and longer is definitely possible. I suspect the power numbers are a little on the high side and are also somewhat variable, depending on radio usage, screen brightness and other factors. Until the system is in use its difficult to be sure of the electrical load. There is also a 4Ah battery in the fin for cg management purposes that is usually kept in reserve to ensure a flight can be completed with power in hand - its is rarely possible to predict exactly how long a flight will take. Often it is essential to keep a GPS logger running at all times for competition scoring purposes, it is desirable the glide computer is operating at the end of a flight to help with planning the final glide. This aircraft also has a get-you-home 2 stroke motor that extends from behind the cockpit to guard against an out-landing, known as a "turbo". A 15Ah gell cell extends and retracts the engine using an electric spindle drive, it is dive started and has no throttle or generator. I want to make the engine battery available as a back-up to the avionic batteries. The problem is to design a system that requires minimum management and provides maximum endurance. Connecting all batteries to the bus results in stronger batteries back charging the weaker and wasting power. Installing regular diodes to prevent the back charging drops too much voltage. Having to switch batteries in and out manually is bound to lead to increased workload at the most inconvenient times. I want to run on the main avionic batteries initially, keeping the engine battery to run the engine when needed and the fin battery in reserve. Theoretically Schottky Diodes, with only a 150mv forward voltage, on each battery line will prevent back charging with an acceptable voltage drop. It is possible to use a pair of DPDT switches to split the avionic system and use 2 batteries to power the 2 halves of the system, but allowing one battery to power all if one depletes before the other. However, if both main batteries can be connected directly to a single bus system management will be more straight forward. I know little about electronic components, and have only confused myself looking at the various tables. The maximum instantaneous current draw is around 4.7A on the avionics bus (3.2A for the radio plus 1.5A for other services), the engine can pull 8A instantaneously when it is raised. I have only been able to find one device that comes close to meeting what I think I need, https://www.mouser.co.uk/datasheet/2/205/L497-1110523.pdf, but this is quite expensive and is described as a rectifier, not completely sure it is suitable. This https://uk.rs-online.com/web/p/rectifier-diodes-schottky-diodes/1023567/ may be a candidate, but the forward voltage is higher than I would like, it seems that the temperature must be high (over 100*C) to reduce it to my 150mv target. Does anyone know of a component that may be suitable? Sketch of architecture below. Am I going to have to accept a small overhead in managing the battery power on a long flight? Regards, Peter ________________________________________________________________________________
Subject: Re: Schottky Diode
Date: Dec 27, 2018
I do not think that "back charging" is going to be an issue. There would have to be a large voltage difference between batteries before one would charge the other. Just connect the two 7ah batteries in parallel and let them both discharge simultaneously. A load will draw current from whichever battery has the highest voltage. Consider using discrete, through hole, diodes which cost 51 cents each. https://www.mouser.com/Semiconductors/Discrete-Semiconductors/Diodes-Rectifiers/Schottky-Diodes-Rectifiers/_/N-ax1mjZ1yzvvqx?P=1z0z63xZ1yuoc72Z1yuoc5bZ1yuoc76&Ns=Pricing%7c0 Or dual diodes are available in a TO-220 case for $1.50 https://www.mouser.com/ProductDetail/Diodes-Incorporated/SBR10U40CT?qs=sGAEpiMZZMtQ8nqTKtFS%2fNX0wTwLhSQZv372G1bq%2fbs%3d Insulate the mounting tab from aircraft ground. The stated forward voltage drop is for maximum current. The voltage drop will be less with less current. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=486574#486574 ________________________________________________________________________________
Date: Dec 27, 2018
I'm in the process of designing an electrical system for a sailplane and am looking for some advice on selecting a Schottky Diode. Hi Peter, long time no hear! My aim for this system is to avoid the pilot having to manage the battery power during flight. Ideally the batteries should be switched on before take-off and nothing more done until they are switched off after landing and removed for re-charging. It is accepted the batteries will need charging each night. The problem is to design a system that requires minimum management and provides maximum endurance. Connecting all batteries to the bus results in stronger batteries back charging the weaker and wasting power. This is a myth. Batteries cannot charge batteries. Any number of serviceable batteries can be connected in parallel irrespective of capacity. All energy stored in every battery is available to the intended task . . . there is no 'exchange' of energy between batteries. Installing regular diodes to prevent the back charging drops too much voltage. Having to switch batteries in and out manually is bound to lead to increased workload at the most inconvenient times. I want to run on the main avionic batteries initially, keeping the engine battery to run the engine when needed and the fin battery in reserve. A 'reserve' battery seems a confession as to lack of knowledge of the total energy needs compared to battery capacity. The only reason you need a 'reserve' is to carry out a near- emergency move because the system went dark unexpectedly. You should be able to design the unexpected event . . . Theoretically Schottky Diodes, with only a 150mv forward voltage, on each battery line will prevent back charging with an acceptable voltage drop. Diodes are probably unnecessary . . . pending further discovery . . . It is possible to use a pair of DPDT switches to split the avionic system and use 2 batteries to power the 2 halves of the system, but allowing one battery to power all if one depletes before the other. However, if both main batteries can be connected directly to a single bus system management will be more straight forward. I'm not so sure than ALL the batteries cannot be operated in parallel with no diodes. Further, if capacities of SVLA batteries prove marginal, have you considered a lithium system? More capacity in same volume and weight constraints. I know little about electronic components, and have only confused myself looking at the various tables. The maximum instantaneous current draw is around 4.7A on the avionics bus (3.2A for the radio plus 1.5A for other services), the engine can pull 8A instantaneously when it is raised. You need to do a load analysis that seeks to define your ENERGY requirements. A 15 a.h. battery JUST to raise and lower the engine seems huge overkill . . . that's a LOT of energy to supply a need that persists for mere seconds per flight cycle. Does anyone know of a component that may be suitable? Sketch of architecture below. Am I going to have to accept a small overhead in managing the battery power on a long flight? I think your 'cart' is overrunning the horse . . . I would advise some further research and perhaps experiments to ascertain real energy requirements. I'm 99% certain that a system can be devised that needs no diodes and may well offer energy reserves that far exceed your greatest expectations. But we need some real NUMBERS first . . . Can you share an equipment list? Are these equipment items in-hand? If so, what's the possibility of powering these items up on the bench and getting good current draw numbers? If not on your constellation of intended equipment, how about on examples installed on other aircraft? How long is an extend/retract cycle on the engine? Bob . . . ________________________________________________________________________________
Date: Dec 27, 2018
Bob, Cutting open of a relay depends on the design of the relay. If you are talking the standard hermetically sealed / rolled over edge type, you do NOT cut it open... You simply grind off the rolled over edge. This can be done very carefully so none of the metal filings enter the relay. If done carefully you may even find water inside the relay. That is what I found in mine! Next trick: If you replace the relay with the same kind (hermetically sealed) do the following: Get a pint of epoxy paint. Mask the terminals of the relay. Using a heat gun heat the relay hot enough that you can not touch it. Then totally submerge the relay in the epoxy paint. As the relay cools it will suck in the epoxy paint into the rolled edge and seal out any paint. NOW! You have a hermetically sealed relay. Not done yet... Next trick: Make sure you mount the relay so the edge of the rolled edge is facing DOWN. Now water and ice will not collect. Barry On Thursday, December 27, 2018, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 11:56 AM 12/25/2018, you wrote: > > Sorry, I didn't know Lycoming made an O-200, this one is a Continental. I n > any case we think the problem is in the relay or switch, not the starter > itself. > > We are planning on replacing the relay with one of these: > > https://aircraftspruce.ca/catalog/elpages/starterrelay.php > > At $20=C3=82 it seems a good idea. > > > Any similar contactor from your local car-parts > emporium will do nicely . . . > > > What I'm wondering about is how to best cut open the old one in order to > see how the failure may have occurred? > > > Send it to me and I'll conduct an > 'up town' failure analysis and report > back. > > > Bob . . . > -- Barry "Chop'd Liver" If you wash your hands before you go to the bathroom you may have the makings of a Crew Chief. ________________________________________________________________________________
Date: Dec 27, 2018
On 12/27/2018 4:43 PM, Peter Pengilly wrote: > > Dear Aeroelectric People, > > Im in the process of designing an electrical system for a sailplane > and am looking for some advice on selecting a Schottky Diode. > > My aim for this system is to avoid the pilot having to manage the > battery power during flight. Ideally the batteries should be switched > on before take-off and nothing more done until they are switched off > after landing and removed for re-charging. It is accepted the > batteries will need charging each night. > > The batteries cannot be changed because of the provided battery trays. > The avionics are primarily powered by 2 x 7Ah gell cells. The > equipment specs say the total current drain is 1.7A (including a > transponder), therefore it is quite possible to run short of amps > after a long flight, a 6 hour flight is not unusual, and longer is > definitely possible. I suspect the power numbers are a little on the > high side and are also somewhat variable, depending on radio usage, > screen brightness and other factors. Until the system is in use its > difficult to be sure of the electrical load. There is also a 4Ah > battery in the fin for cg management purposes that is usually kept in > reserve to ensure a flight can be completed with power in hand its > is rarely possible to predict exactly how long a flight will take. > Often it is essential to keep a GPS logger running at all times for > competition scoring purposes, it is desirable the glide computer is > operating at the end of a flight to help with planning the final glide. > > This aircraft also has a get-you-home 2 stroke motor that extends from > behind the cockpit to guard against an out-landing, known as a > turbo. A 15Ah gell cell extends and retracts the engine using an > electric spindle drive, it is dive started and has no throttle or > generator. I want to make the engine battery available as a back-up to > the avionic batteries. > > The problem is to design a system that requires minimum management and > provides maximum endurance. Connecting all batteries to the bus > results in stronger batteries back charging the weaker and wasting > power. Installing regular diodes to prevent the back charging drops > too much voltage. Having to switch batteries in and out manually is > bound to lead to increased workload at the most inconvenient times. I > want to run on the main avionic batteries initially, keeping the > engine battery to run the engine when needed and the fin battery in > reserve. Theoretically Schottky Diodes, with only a 150mv forward > voltage, on each battery line will prevent back charging with an > acceptable voltage drop. > > It is possible to use a pair of DPDT switches to split the avionic > system and use 2 batteries to power the 2 halves of the system, but > allowing one battery to power all if one depletes before the other. > However, if both main batteries can be connected directly to a single > bus system management will be more straight forward. > > I know little about electronic components, and have only confused > myself looking at the various tables. The maximum instantaneous > current draw is around 4.7A on the avionics bus (3.2A for the radio > plus 1.5A for other services), the engine can pull 8A instantaneously > when it is raised. I have only been able to find one device that comes > close to meeting what I think I need, > https://www.mouser.co.uk/datasheet/2/205/L497-1110523.pdf, but this is > quite expensive and is described as a rectifier, not completely sure > it is suitable. This > https://uk.rs-online.com/web/p/rectifier-diodes-schottky-diodes/1023567/ > may be a candidate, but the forward voltage is higher than I would > like, it seems that the temperature must be high (over 100*C) to > reduce it to my 150mv target. > > Does anyone know of a component that may be suitable? Sketch of > architecture below. > > Am I going to have to accept a small overhead in managing the battery > power on a long flight? > > Regards, Peter > Hi Peter, (edit: looks like others have made most of these points while I was 'distracted' with other stuff, but here you go, anyway.) I'm certainly no expert, but I'll take a swing at a few of the questions. 1. I'd prefer to have a single battery at 14AH, vs 2 @ 7AH, if it's physically possible to do it. Simpler, and you intend to have a backup anyway. 2. Gell is not the same thing as the currently common SLA, 'starved electrolyte' battery. Gel cells may still be available, but they're a lot more finicky to deal with than a common SLA battery. 3. I have not yet gotten excited about flying a powered a/c with a lithium-iron battery, but have you considered it for your 'total loss' system? Charging the battery outside the a/c removes a significant percentage of risk, and you could carry a *lot* more capacity in a much lighter package (for a price, of course...). 4. Since knowing your exact loads are a bit more critical than a typical a/c, rather than look at mfgr data sheets, consider directly measuring each item's current in actual operation. Most data sheets will show you a conservative number, to be sure the installer doesn't 'short change' the device's needs. 5. The Mouser device you linked is a bit of overkill (200A), and will be a bit of a hassle to mount. The mounting surface is also the cathode, meaning you'd need to isolate it from the air frame and for safety, from any heatsink you mount it on. The 2nd one you show has an isolated mounting tab. But there are hundreds of choices. Here's one: https://www.ebay.com/itm/Schottky-Diodes-Rectifiers-2X60-Amp-15-Volt-DIODE-MODULE-ISOTOP/273285163944?epid=1718397917&hash=item3fa110aba8:g:cbkAAOSwgd1axcQL:rk:4:pf:0 Another: https://www.ebay.com/itm/1-S20SC9M-SCHOTTKY-RECTIFIER-DUAL-COMMON-CATHODE-DIODE-90V-20A-MTO-3P/390680777077?hash=item5af6639175:g:az0AAOxyoahSXtlc:rk:9:pf:0 6. If you can go with one main battery (or parallel the pair of 7As), there'd only be one switch for the 4A backup. The switch for the 15A starting battery you will need, regardless of the rest of the architecture. Charlie --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Dec 27, 2018
At 08:02 PM 12/27/2018, you wrote: >Bob, > >Cutting open of a relay depends on the design of >the relay.=C2 If you are talking the standard hermetically sealed hermetically sealed implies absolute atmospheric isolation between interior and the environment. Contactors with rolled on caps are not 'hermetic', only very secure. > / rolled over edge type, you do NOT cut it > open...=C2 You simply grind off the rolled over > edge.=C2 This can be done very carefully so none > of the metal filings enter the relay.=C2 If done > carefully you may even find water inside the > relay.=C2 That is what I found in mine! =C2 Yep . . . been there a few dozen times. https://tinyurl.com/p2x7fbl https://tinyurl.com/kcc26jt Cessna attempted some DIY sealing techniques on the whisky barrel relays . . . right after the noise reducing, floating cowl was incorporated onto the SE aircraft. Virtually no help. You could not guarantee quality of seal. Liquid water sucked in during a cooling event had to exit as a vapor over successive atmospheric 'breathing' cycles . . . i.e. once inside it stayed inside. >Not done yet...=C2 Next trick: =C2 Make sure you >mount the relay so the edge of the rolled edge >is facing DOWN.=C2 Now water and ice will not collect. or cap facing down with a #40 drain hole added right in the center. Now trapped liquid had a place to get out. Bob . . . ________________________________________________________________________________
Date: Dec 27, 2018
> > >4. Since knowing your exact loads are a bit more critical than a >typical a/c, rather than look at mfgr data sheets, consider directly >measuring each item's current in actual operation. Most data sheets >will show you a conservative number, to be sure the installer >doesn't 'short change' the device's needs. BINGO! Bob . . . ________________________________________________________________________________
Date: Dec 28, 2018
Hello Bob & all, thanks for your replies. I am reluctant to go to LiPos as I have a ready supply of =91gelcels=92 (or whatever they are really!) I know it could be dumb to avoid spending a couple of hundred =A3=A3/$$ on a $100K aircraft, but if I can make the gelcels work I would like to. Getting the system working on the bench is probably a good idea, I have nearly all the equipment to hand so should get something running in a week or two. At present I am inclined to use a plain on-off switch on all the batteries, and to switch the 2 main batteries and the
November 14, 2018 - December 29, 2018
AeroElectric-Archive.digest.vol-or
