AeroElectric-Archive.digest.vol-ot
January 14, 2019 - February 09, 2019
      in case the ALT-2 is OFF and the ESS BUS contactor closed, so that the feed to
      the ESS BUS reverses;
      Least resistance to the ESS BUS will go through the ESS BUS Contactor when fed
      from ALT-1 or battery (ESS BUS will be fed through the diode only if ESS BUS Contactor
      open);
      -will I need to have a circuit protection right after the ESS BUS Contactor facing
      the ESS BUS or is the circuit breaker at the ESS BUS sufficient to protect
      the wire?
      thanks,
      Igor
      Igor
      RV10 in progress
      http://forums.matronics.com/viewtopic.php?p=486978#486978
Date: Jan 14, 2019
Subject: Re: Basic Elec. Diagram -critique pls
Since they can be displayed as separate gauges, you will be able to set up your alarms as you wanted in your OP. On Mon, Jan 14, 2019, 16:04 supik > > cluros(at)gmail.com wrote: > > Please post the picture and your install manual. > > > > On Mon, Jan 14, 2019, 15:38 supik AeroElectric-List message posted by: > "supik" > > > > I have just received a picture from G3X Expert. Apparently it is > possible to label the indicators.. > > > > -------- > > Igor > > > > RV10 in progress > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=486975#486975 ( > http://forums.matronics.com/viewtopic.php?p=486975#486975) > > > > > > > > > > Attachments: > > > > http://forums.matronics.com//files/image002_511.jpg ( > http://forums.matronics.com//files/image002_511.jpg) > > > > > > > > ========== > > - > > Electric-List" rel="noreferrer noreferrer" target="_blank"> > http://www.matronics.com/Navigator?AeroElectric-List > > ========== > > FORUMS - > > eferrer noreferrer" target="_blank">http://forums.matronics.com > > ========== > > WIKI - > > errer noreferrer" target="_blank">http://wiki.matronics.com > > ========== > > b Site - > > -Matt Dralle, List Admin. > > rel="noreferrer noreferrer" target="_blank"> > http://www.matronics.com/contribution > > ========== > > > > > > > > > [/quote] > > Carlos, the picture is uploaded in my previous post.. You can download the > current manual directly from the Garmin website. > > -------- > Igor > > RV10 in progress > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=486977#486977 > > ________________________________________________________________________________
Subject: Recommended wire gauge for battery
Date: Jan 15, 2019
Here is a question about what gauge of wire the list would recommend for extending a battery installation on an aircraft. Parameters are that a 24V battery needs to move from behind the baggage compartment to the firewall, for balance purposes. The aircraft has a Lycoming O320 engine. The battery is 24V 11AH and rated at cold cranking amperage 200A. It needs to move about 5 from its present position. I can re-site the ground terminal (to the airframe) to the new location, but Im unwilling to move the battery and starter contactors, as an alternative Id prefer to run a heavy 24V wire back to the original battery position where the contactors are. My certification engineer says hes willing to sign off the extended unswitched and unfused power line as long as its properly grometted through the firewall etc. What gauge of wire should I be considering? Anything other considerations Im missing? ________________________________________________________________________________
Date: Jan 15, 2019
Subject: Re: Recommended wire gauge for battery
Alec, I do understand wanting to keep the contactors in their existing positions, aft of the baggage compartment. It is a paperwork hassle to move them. Even still, I would reconsider that decision. You need BIG wire to carry the current for the starter. In my airplane with an IO-360 and the battery on the firewall, I used 4 and 6 gauge wire in the circuit from the battery through the contactors to the starter. I'll bet that you already have something BIG running from the contactor to the starter and you would want something at least that large to run from the battery's new location back to the contactor. -- Art Z. On Tue, Jan 15, 2019 at 7:33 AM Alec Myers wrote: > > Here is a question about what gauge of wire the list would recommend for > extending a battery installation on an aircraft. > > Parameters are that a 24V battery needs to move from behind the baggage > compartment to the firewall, for balance purposes. > The aircraft has a Lycoming O320 engine. The battery is 24V 11AH and rate d > at cold cranking amperage 200A. It needs to move about 5=99 from it s present > position. > > I can re-site the ground terminal (to the airframe) to the new location, > but I=99m unwilling to move the battery and starter contactors, as an > alternative I=99d prefer to run a heavy 24V wire back to the origin al battery > position where the contactors are. > > My certification engineer says he=99s willing to sign off the exten ded > unswitched and unfused power line as long as it=99s properly gromet ted > through the firewall etc. > > What gauge of wire should I be considering? > > Anything other considerations I=99m missing? -- https://CheerfulCurmudgeon.com/ *"Be kind, for everyone you meet is fighting a hard battle."* ________________________________________________________________________________
Date: Jan 15, 2019
If I understand correctly, you currently have battery box with master contactor and the starter contactor both behind the baggage compartment. That implies you are running a heavy cable for the starter and a somewhat smaller cable for the main aircraft bus, both from behind the baggage compartment. I don't understand why the starter contactor wasn't placed on the firewall to begin with, but okay. Presumably anything in the tail cone that is powered is getting power from bus on the instrument panel. I don't see any advantage of keeping the contactors in their current location. You can use existing wire, just shortening the cable to what is needed from the battery box on the firewall. No new cable needed, just cutting and crimping new connectors on existing cable. Only other wires to move are the master switch wire and the ignition switch wire, again just making them shorter. While you could do the calculations to the W&B for the battery move, you would be better off just re-weighing the plane. O > On Tue, Jan 15, 2019 at 7:33 AM Alec Myers > wrote: > > > > > Here is a question about what gauge of wire the list would recommend > for extending a battery installation on an aircraft. > > Parameters are that a 24V battery needs to move from behind the > baggage compartment to the firewall, for balance purposes. > The aircraft has a Lycoming O320 engine. The battery is 24V 11AH and > rated at cold cranking amperage 200A. It needs to move about 5 from > its present position. > > I can re-site the ground terminal (to the airframe) to the new > location, but Im unwilling to move the battery and starter > contactors, as an alternative Id prefer to run a heavy 24V wire > back to the original battery position where the contactors are. > > My certification engineer says hes willing to sign off the extended > unswitched and unfused power line as long as its properly grometted > through the firewall etc. > > What gauge of wire should I be considering? > > Anything other considerations Im missing? > > > -- > https://CheerfulCurmudgeon.com/ > > /"Be kind, for everyone you meet is fighting a hard battle."/ ________________________________________________________________________________
Date: Jan 15, 2019
The engine is on the front of the airplane, correct? As others have said, it is best to move the contactors forward near the battery. Weight will be less and safety will be increased. What is the reason for not moving the contactors, no room, more work, regulator? -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=486988#486988 ________________________________________________________________________________
Date: Jan 15, 2019
I miswrote, and in fact the starter contactor is already on the firewall. So I would have to move the battery contactor only, but thats not trivial in this airplane. Also I would have to keep or install a heavy cable from the external power relay back to the battery - the external power relay, connector (through the fuselage side) and external power control relay are all colocated behind the baggage compartment. I was really wondering what gauge of wire people use for a 24v starter... On Jan 15, 2019, at 10:26, user9253 wrote: The engine is on the front of the airplane, correct? As others have said, it is best to move the contactors forward near the battery. Weight will be less and safety will be increased. What is the reason for not moving the contactors, no room, more work, regulator? -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=486988#486988 ________________________________________________________________________________
Subject: Re: Internally Regulated Over Voltage Protection
Date: Jan 15, 2019
Bueller Read this topic online here: http://forums.matronics.com/viewtopic.php?p=486999#486999 ________________________________________________________________________________
Date: Jan 15, 2019
Most of the battery charging current will come through the battery contactor. Very little, if any will pass through the E-Bus diode. Another diode between the battery and E-Bus is not desired because it will drop voltage. Not good if the battery voltage is low. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487001#487001 ________________________________________________________________________________
Date: Jan 16, 2019
OK, nothing wrong with having a single heavy lead back to your remote power. The Master solenoid/contactor still should be as close as possible to the battery. Your starter wire is not going to change. The only wire you need to add is from the battery to the starter relay. You can leave the existing wire from the battery and connect it to the external power relay. Typically 24/28V wire can be one or two number sizes smaller than 14V wire for same current. That would likely put you at #4 or #6. On 1/15/2019 3:29 PM, Alec Myers wrote: > > I miswrote, and in fact the starter contactor is already on the firewall. > > So I would have to move the battery contactor only, but thats not trivial in this airplane. Also I would have to keep or install a heavy cable from the external power relay back to the battery - the external power relay, connector (through the fuselage side) and external power control relay are all colocated behind the baggage compartment. > > I was really wondering what gauge of wire people use for a 24v starter... > > > On Jan 15, 2019, at 10:26, user9253 wrote: > > > The engine is on the front of the airplane, correct? As others have said, it is > best to move the contactors forward near the battery. Weight will be less and > safety will be increased. What is the reason for not moving the contactors, no > room, more work, regulator? > > -------- > Joe Gores > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=486988#486988 > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jan 16, 2019
Kelly said something important: The Master solenoid/contactor still should be as close as possible to the battery. Is your inspector ok with having the battery's 'fat' wire running unprotected all the way from firewall to the back of the a/c? I know it's frustrating to get answers that aren't answers to your question, but sometimes that's needed. Charlie On 1/16/2019 8:36 AM, Kelly McMullen wrote: > > > OK, nothing wrong with having a single heavy lead back to your remote > power. The Master solenoid/contactor still should be as close as > possible to the battery. Your starter wire is not going to change. The > only wire you need to add is from the battery to the starter relay. > You can leave the existing wire from the battery and connect it to the > external power relay. > Typically 24/28V wire can be one or two number sizes smaller than 14V > wire for same current. That would likely put you at #4 or #6. > > On 1/15/2019 3:29 PM, Alec Myers wrote: >> >> I miswrote, and in fact the starter contactor is already on the >> firewall. >> >> So I would have to move the battery contactor only, but thats not >> trivial in this airplane. Also I would have to keep or install a >> heavy cable from the external power relay back to the battery - the >> external power relay, connector (through the fuselage side) and >> external power control relay are all colocated behind the baggage >> compartment. >> >> I was really wondering what gauge of wire people use for a 24v >> starter... >> >> >> On Jan 15, 2019, at 10:26, user9253 wrote: >> >> >> The engine is on the front of the airplane, correct? As others have >> said, it is >> best to move the contactors forward near the battery. Weight will be >> less and >> safety will be increased. What is the reason for not moving the >> contactors, no >> room, more work, regulator? >> >> -------- >> Joe Gores --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jan 16, 2019
user9253 wrote: > Most of the battery charging current will come through the battery contactor. > Very little, if any will pass through the E-Bus diode. Another diode between > the battery and E-Bus is not desired because it will drop voltage. Not good if the battery voltage is low. Awesome, thank you. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487023#487023 ________________________________________________________________________________
Date: Jan 16, 2019
Subject: Battery
After 35 years of hand propping my C-85 engine, I have decided to install a B & C starter. My plan is to use a light weight lithium battery for starting only. I have no electrical system whatsoever. There will be no alternator to recharge the battery. I would like to choose a battery that will allow me a few starts (perhaps 6?) before needing to be be recharged on the ground. Any suggestions on what size / capacity battery I should be looking for? Ivan Haecker ________________________________________________________________________________
Subject: Re: Battery
Date: Jan 16, 2019
Hi Ivan, recommend that you forward this email to Bill at B&C. He will know & he is one of the good guys! > On Jan 16, 2019, at 1:06 PM, Ivan wrote: > > > After 35 years of hand propping my C-85 engine, I have decided to install a B & C starter. My plan is to use a light weight lithium battery for starting only. I have no electrical system whatsoever. There will be no alternator to recharge the battery. I would like to choose a battery that will allow me a few starts (perhaps 6?) before needing to be be recharged on the ground. Any suggestions on what size / capacity battery I should be looking for? > > Ivan Haecker > > > ________________________________________________________________________________
Date: Jan 16, 2019
Subject: DIY Crowbar OVM
A couple years ago I ordered the parts to make an OVM for my friends aircraft. We finally got around to breadboarding it this week and we have a part left over: A 5 ohm 5 watt resistor, see picture below. Anyone want to guess what use this would be in an aircraft? Maybe I ordered it for a panel dimmer circuit or something? Also, my 0.1uF/250V capacitor https://www.digikey.ca/products/en?keywords=p10967 does not have polarity markings that I can find. The diagram shows a polarized cap. Is this just in case? If I can't find markings on my cap am I safe disregarding polarity? Thank you, Sebastien ________________________________________________________________________________
Date: Jan 16, 2019
Subject: Re: DIY Crowbar OVM
Whoops. Picture attached. On Wed, Jan 16, 2019 at 11:59 AM Sebastien wrote: > A couple years ago I ordered the parts to make an OVM for my friends > aircraft. We finally got around to breadboarding it this week and we have a > part left over: A 5 ohm 5 watt resistor, see picture below. Anyone want to > guess what use this would be in an aircraft? Maybe I ordered it for a panel > dimmer circuit or something? > > Also, my 0.1uF/250V capacitor > https://www.digikey.ca/products/en?keywords=p10967 does not have polarity > markings that I can find. The diagram shows a polarized cap. Is this just > in case? If I can't find markings on my cap am I safe disregarding polarity? > > Thank you, > > Sebastien > ________________________________________________________________________________
Date: Jan 16, 2019
no On Wed, Jan 16, 2019 at 2:13 PM Sebastien wrote: > Whoops. Picture attached. > > On Wed, Jan 16, 2019 at 11:59 AM Sebastien wrote: > >> A couple years ago I ordered the parts to make an OVM for my friends >> aircraft. We finally got around to breadboarding it this week and we have a >> part left over: A 5 ohm 5 watt resistor, see picture below. Anyone want to >> guess what use this would be in an aircraft? Maybe I ordered it for a panel >> dimmer circuit or something? >> >> Also, my 0.1uF/250V capacitor >> https://www.digikey.ca/products/en?keywords=p10967 does not have >> polarity markings that I can find. The diagram shows a polarized cap. Is >> this just in case? If I can't find markings on my cap am I safe >> disregarding polarity? >> >> Thank you, >> >> Sebastien >> > ________________________________________________________________________________
Date: Jan 16, 2019
Sebastien, Your capacitor is non-polarized; its orientation doesn't matter. Eric Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487039#487039 ________________________________________________________________________________
Subject: Switch layout idea for z-13
Date: Jan 16, 2019
How does this switch layout look to you guys for a z-13 system. Two 3 position locking switches next to each other. The first one is labeled Battery with the position of OFF/ESS/MAIN. The second switch is labeled Alternator with positions 1/OFF/2. I like the idea of the simplicity of this. Any other thoughts? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487042#487042 ________________________________________________________________________________
Subject: Re: Switch layout idea for z-13
Date: Jan 16, 2019
Break something in the design and then figure out what you'll lose when it fails, and determine whether your backup plan can still function=2E For exa mple, one of the switches comes apart=2E Will enough of the system still wo rk to get you safely on the ground? =81=A3Charlie=8B On Jan 16, 2019, 10:42 PM, at 10:42 PM, Av8rrob wrote: >--> Aer oElectric-List message posted by: "Av8rrob" > >How do es this switch layout look to you guys for a z-13 system=2E Two 3 >position locking switches next to each other=2E The first one is labeled >Battery w ith the position of OFF/ESS/MAIN=2E The second switch is labeled >Alternato r with positions 1/OFF/2=2E I like the idea of the simplicity of >this=2E Any other thoughts? > > >Read this topic online here: > >http://forums =2Ematronics=2Ecom/viewtopic=2Ephp?p=487042#487042 > > ======= m - any List utilities such as List Un/Subscription, wnload, 7-Day Browse, Chat, FAQ, > ============ B FORUMS - ==== some info to the Matronics Email List Wiki! onics=2Ecom ============== tribution Web Site - -Matt Dralle, List Admin=2E www=2Ematronics=2Ecom/contribution ====================== ________________________________________________________________________________
From: "H. Ivan Haecker" <hivanhaecker(at)gmail.com>
Date: Jan 16, 2019
Thanks Earl. I=99ll do that. On Wed, Jan 16, 2019 at 1:33 PM Earl Schroeder wrote: > > > Hi Ivan, recommend that you forward this email to Bill at B&C. He will > know & he is one of the good guys! > > > On Jan 16, 2019, at 1:06 PM, Ivan wrote: > > > > > > After 35 years of hand propping my C-85 engine, I have decided to > install a B & C starter. My plan is to use a light weight lithium batter y > for starting only. I have no electrical system whatsoever. There will be no > alternator to recharge the battery. I would like to choose a battery that > will allow me a few starts (perhaps 6?) before needing to be be recharged > on the ground. Any suggestions on what size / capacity battery I should b e > looking for? > > > > Ivan Haecker > > > > > > > =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Subject: Headset Plug
Date: Jan 17, 2019
--- MIME Errors - No Plain-Text Section Found --- A message with no text/plain MIME section was received. The entire body of the message was removed. Please resend the email using Plain Text formatting. HOTMAIL is notorious for only including an HTML section in their client's default configuration. If you're using HOTMAIL, please see your email application's settings and switch to a default mail option that uses "Plain Text". --- MIME Errors No Plain-Text Section Found --- ________________________________________________________________________________
Date: Jan 17, 2019
Not directly to your question, but to save yourself the hassle of hooking up a charger, you might consider adding a solar panel to your plane.=C2- For less than $20, you can get a 6"x12" panel that will deliver 100mA or so .=C2- If you're only starting a couple times a week, you'd probably never need to hunt down a charger. l.com> wrote: After 35 years of hand propping my C-85 engine, I have decided to install a B & C=C2- starter. My plan is to use a light weight lithium battery for starting only. I have no electrical system whatsoever. There will be no alt ernator to recharge the battery. I would like to choose a battery that will allow me a few starts (perhaps 6?) before needing to be be recharged on th e ground. Any suggestions on what size / capacity battery I should be looki ng for? Ivan Haecker - S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Jan 17, 2019
I would contact Bose, and ask if they can convert it to standard jacks (or LEMO if that's what you want). While they do that, they will probably also refurbish the entire headset at no cost to you. Jim Parker -------- Original Message -------- Subject: AeroElectric-List: Headset Plug From: Werner Schneider <glastar(at)gmx.net> Date: Thu, January 17, 2019 4:38 am I need the groups knowledge! I got an offer for a Bose A20 but is has a special plug, it's told it's a Bell 212 plug, but could not identify such a plug somewhere could maybe as well be a military plug (and then probably low impedance)? Any help much appreciated! Werner ________________________________________________________________________________
Date: Jan 17, 2019
On closer examination, I dont have to add any fat wires if I do move the battery contactor along with the battery. The heavy cable that currently (no pun intended) provides power forward to the engine compartment (and starter) will now be the heavy cable that feeds power from the external power connector. So its less work. There are just two wires I need to add through the firewall: 1. The battery contactor coil current, which goes from the contactor coil low side in series through the external power control relay (at the old battery location), a diode and then forward to the battery master switch. 2. Permanent power to the hour meter On Jan 16, 2019, at 11:20 AM, Charlie England wrote: Kelly said something important: The Master solenoid/contactor still should be as close as possible to the battery. Is your inspector ok with having the battery's 'fat' wire running unprotected all the way from firewall to the back of the a/c? I know it's frustrating to get answers that aren't answers to your question, but sometimes that's needed. Charlie On 1/16/2019 8:36 AM, Kelly McMullen wrote: > > OK, nothing wrong with having a single heavy lead back to your remote power. The Master solenoid/contactor still should be as close as possible to the battery. Your starter wire is not going to change. The only wire you need to add is from the battery to the starter relay. You can leave the existing wire from the battery and connect it to the external power relay. > Typically 24/28V wire can be one or two number sizes smaller than 14V wire for same current. That would likely put you at #4 or #6. > > On 1/15/2019 3:29 PM, Alec Myers wrote: >> >> I miswrote, and in fact the starter contactor is already on the firewall. >> >> So I would have to move the battery contactor only, but thats not trivial in this airplane. Also I would have to keep or install a heavy cable from the external power relay back to the battery - the external power relay, connector (through the fuselage side) and external power control relay are all colocated behind the baggage compartment. >> >> I was really wondering what gauge of wire people use for a 24v starter... >> >> >> On Jan 15, 2019, at 10:26, user9253 wrote: >> >> >> The engine is on the front of the airplane, correct? As others have said, it is >> best to move the contactors forward near the battery. Weight will be less and >> safety will be increased. What is the reason for not moving the contactors, no >> room, more work, regulator? >> >> -------- >> Joe Gores --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Subject: Re: Headset Plug
Date: Jan 17, 2019
They will sell the audio cable, but it is in the neighborhood of $200, because the mike is part of the assembly. Check Sporty's for adapters. On 1/17/2019 7:43 AM, jim(at)PoogieBearRanch.com wrote: > > I would contact Bose, and ask if they can convert it to standard jacks > (or LEMO if that's what you want). While they do that, they will > probably also refurbish the entire headset at no cost to you. > > Jim Parker > > > -------- Original Message -------- > Subject: AeroElectric-List: Headset Plug > From: Werner Schneider <glastar(at)gmx.net> > Date: Thu, January 17, 2019 4:38 am > To: aeroelectric-list(at)matronics.com > > I need the groups knowledge! > > I got an offer for a Bose A20 but is has a special plug, it's told it's > a Bell 212 plug, but could not identify such a plug somewhere could > maybe as well be a military plug (and then probably low impedance)? > > > > > Any help much appreciated! > > Werner > > > > ________________________________________________________________________________
Date: Jan 17, 2019
Kelly, I've searched all over the Net, but could not find any adapter for that special 2 plug cable. Cheers Werner On 17.01.2019 16:41, Kelly McMullen wrote: > > > They will sell the audio cable, but it is in the neighborhood of $200, > because the mike is part of the assembly. Check Sporty's for adapters. > ________________________________________________________________________________
Date: Jan 17, 2019
Kelly, I found what you meant, that is a complete replacement for the cabling which you unplug, the one with BT is even 300$ and it would make the deal expensive again. Thanks Werner On 17.01.2019 16:41, Kelly McMullen wrote: > > > They will sell the audio cable, but it is in the neighborhood of $200, > because the mike is part of the assembly. Check Sporty's for adapters. > ________________________________________________________________________________
Date: Jan 17, 2019
Sometimes just the downcord pops up on ebay. Maybe you can set up a search alert. This is why we see so much variation in the price of used headsets based on their plugs. I don't know the A20 line, but note that in some of the X models the microphone was not interchangeable between helicooter versions and the others, so there's a chance that even if you found just the plugs it still wouldn't work. The days of Bose doing free refurbs seems to be long over. I've sent in several x models over the years, and the prices have climbed from $179 to $225, and the most recent one was to be $300. I was reluctant to do it at all, but the pile of parts wasn't worth anything otherwise. After all the trouble of packing it up and getting it to UPS, they sent it back without fixing it or charging me, saying that it was too old. The person on the phone took down the serial number before I ever sent it in, and at that stage it was not too old. All good things must end some time I suppose, but it is important to update the status of the Bose support situation. On January 17, 2019 11:21:39 Werner Schneider wrote: > > Kelly, I've searched all over the Net, but could not find any adapter > for that special 2 plug cable. > > Cheers Werner > > On 17.01.2019 16:41, Kelly McMullen wrote: >> >> >> They will sell the audio cable, but it is in the neighborhood of $200, >> because the mike is part of the assembly. Check Sporty's for adapters. >> > ________________________________________________________________________________
Date: Jan 17, 2019
How do you regulate the charge with these things, can you over charge a batt ery John Sent from my iPad ----x--O--x---- > On 17 Jan 2019, at 2:51 pm, Ernest Christley wrote: > > Not directly to your question, but to save yourself the hassle of hooking u p a charger, you might consider adding a solar panel to your plane. For les s than $20, you can get a 6"x12" panel that will deliver 100mA or so. If yo u're only starting a couple times a week, you'd probably never need to hunt d own a charger. > om> wrote: > > > > After 35 years of hand propping my C-85 engine, I have decided to install a B & C starter. My plan is to use a light weight lithium battery for starti ng only. I have no electrical system whatsoever. There will be no alternator to recharge the battery. I would like to choose a battery that will allow m e a few starts (perhaps 6?) before needing to be be recharged on the ground. Any suggestions on what size / capacity battery I should be looking for? > <; - The AeroElectric-List Email Forum - > http://www.matronics.com/Navigator?AeroElectric-List > http://forums.matronics.com > -Matt Dralle, List Admin. > http://www.matronics.com/contribution > > > ________________________________________________________________________________
Date: Jan 17, 2019
I like that idea. Of course, the sun never shines in my hangar, but it usually does when I=99m flying! I wrote an e-mail to B&C, but they only said that in general, they recommend Earth X batteries. What I really need to know is what size (capacity) battery I need, i.e., how many cca=99s, etc. that I need t o accomplish my intended goals. I guess I need to do a little research. On Thu, Jan 17, 2019 at 8:57 AM Ernest Christley wrote : > Not directly to your question, but to save yourself the hassle of hooking > up a charger, you might consider adding a solar panel to your plane. For > less than $20, you can get a 6"x12" panel that will deliver 100mA or so. > If you're only starting a couple times a week, you'd probably never need to > hunt down a charger. > > hivanhaecker(at)gmail.com> wrote: > > > After 35 years of hand propping my C-85 engine, I have decided to install > a B & C starter. My plan is to use a light weight lithium battery for > starting only. I have no electrical system whatsoever. There will be no > alternator to recharge the battery. I would like to choose a battery that > will allow me a few starts (perhaps 6?) before needing to be be recharged > on the ground. Any suggestions on what size / capacity battery I should b e > looking for? > <; - The AeroElectric-List Email Forum - > http://www.matronics.com/Navigator?AeroElectric-List > http://forums.matronics.com > -Matt Dralle, List Admin. > http://www.matronics.com/contribution > > ________________________________________________________________________________
Date: Jan 17, 2019
Ivan, you might also reach out to Earthx to see what they would recommend. Last I checked Bruce was running a total loss Earthx in his LSA and it was lasting a long time. Let me know if you want help getting in touch with him. On January 17, 2019 14:23:18 "H. Ivan Haecker" wrote: > I like that idea. Of course, the sun never shines in my hangar, but it > usually does when Im flying! > > I wrote an e-mail to B&C, but they only said that in general, they > recommend Earth X batteries. What I really need to know is what size > (capacity) battery I need, i.e., how many ccas, etc. that I need to > accomplish my intended goals. I guess I need to do a little research. > > > On Thu, Jan 17, 2019 at 8:57 AM Ernest Christley wrote: > > Not directly to your question, but to save yourself the hassle of hooking > up a charger, you might consider adding a solar panel to your plane. For > less than $20, you can get a 6"x12" panel that will deliver 100mA or so. > If you're only starting a couple times a week, you'd probably never need to > hunt down a charger. > > wrote: > > > After 35 years of hand propping my C-85 engine, I have decided to install a > B & C starter. My plan is to use a light weight lithium battery for > starting only. I have no electrical system whatsoever. There will be no > alternator to recharge the battery. I would like to choose a battery that > will allow me a few starts (perhaps 6?) before needing to be be recharged > on the ground. Any suggestions on what size / capacity battery I should be > looking for? > <; - The AeroElectric-List Email Forum - > http://www.matronics.com/Navigator?AeroElectric-List > > http://forums.matronics.com > > -Matt Dralle, List Admin. > http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jan 17, 2019
They would only output about 14V Max. They don't have enough power to damag e anything as I understood it, but that was with a lead acid battery. If yo u talking to the battery guys, ask them and let us know what they have to s ay about it. Sent from Yahoo Mail on Android On Thu, Jan 17, 2019 at 2:10 PM, John Tipton wrote: H ow do you regulate the charge with these things, can you over charge a batt ery John Sent from my iPad =C2- =C2- =C2-----x--O--x---- On 17 Jan 2019, at 2:51 pm, Ernest Christley wrote: Not directly to your question, but to save yourself the hassle of hooking up a charger, you might consider adding a solar panel to your plane.=C2- For less than $20, you can get a 6"x12" panel that will deliver 100mA or so .=C2- If you're only starting a couple times a week, you'd probably never need to hunt down a charger. l.com> wrote: After 35 years of hand propping my C-85 engine, I have decided to install a B & C=C2- starter. My plan is to use a light weight lithium battery for starting only. I have no electrical system whatsoever. There will be no alt ernator to recharge the battery. I would like to choose a battery that will allow me a few starts (perhaps 6?) before needing to be be recharged on th e ground. Any suggestions on what size / capacity battery I should be looki ng for? <; =C2- =C2- - The AeroElectric-List Email Forum - http://www.matronics.com/Navigator?AeroElectric-List http://forums.matronics.com =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jan 17, 2019
Might not be needed with a small panel but Ebay has solar charging modules specifically for charging 12 volt batteries. Bought one last year for 3 or 4 dollars. Optimizes solar cell output and won't overcharge. Ken On 17/01/2019 6:30 PM, Ernest Christley wrote: > They would only output about 14V Max. They don't have enough power to > damage anything as I understood it, but that was with a lead acid > battery. If you talking to the battery guys, ask them and let us know > what they have to say about it. > > > Sent from Yahoo Mail on Android > > > On Thu, Jan 17, 2019 at 2:10 PM, John Tipton > wrote: > How do you regulate the charge with these things, can you over > charge a battery > > John > > Sent from my iPad > > ----x--O--x---- > > On 17 Jan 2019, at 2:51 pm, Ernest Christley > wrote: > >> Not directly to your question, but to save yourself the hassle of >> hooking up a charger, you might consider adding a solar panel to >> your plane. For less than $20, you can get a 6"x12" panel that >> will deliver 100mA or so. If you're only starting a couple times >> a week, you'd probably never need to hunt down a charger. >> >> > wrote: >> >> >> > >> >> After 35 years of hand propping my C-85 engine, I have decided to >> install a B & C starter. My plan is to use a light weight >> lithium battery for starting only. I have no electrical system >> whatsoever. There will be no alternator to recharge the battery. >> I would like to choose a battery that will allow me a few starts >> (perhaps 6?) before needing to be be recharged on the ground. Any >> suggestions on what size / capacity battery I should be looking for? >> <; - The AeroElectric-List Email Forum - >> http://www.matronics.com/Navigator?AeroElectric-List >> http://forums.matronics.com >> -Matt Dralle, List Admin. >> http://www.matronics.com/contribution >> >> >> ________________________________________________________________________________
Date: Jan 18, 2019
Contact these guys; https://uflymike.com/ They have a great deal of information that may help you Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487068#487068 ________________________________________________________________________________
Date: Jan 18, 2019
At 05:30 PM 1/17/2019, you wrote: >They would only output about 14V Max. They don't have enough power >to damage anything as I understood it, but that was with a lead acid >battery. If you talking to the battery guys, ask them and let us >know what they have to say about it. Solar battery chargers are at best, unpredictable 'trickle' chargers. Their output almost never meets nameplate numbers. Output is subject to vagaries of the sunshine. Output is not controlled to prevent overcharging of the battery. My recommendation for a battery-only electrical system, particularly if the battery is a light weight and relatively expensive lithium device is to take it home between flights and put it on a charger-maintainer recommended by the battery's manufacturer. I had readers doing this with SVLA batteries 25 years ago who reported excellent performance and longevity from the battery. This was common to both sail plane owners and owners of powered ships with electrical needs but no engine driven power sources. Bob . . . ________________________________________________________________________________
Date: Jan 18, 2019
On Fri, Jan 18, 2019 at 11:26 AM Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 05:30 PM 1/17/2019, you wrote: > > They would only output about 14V Max. They don't have enough power to > damage anything as I understood it, but that was with a lead acid battery. > If you talking to the battery guys, ask them and let us know what they have > to say about it. > > > Solar battery chargers are at best, unpredictable > 'trickle' chargers. Their output almost never meets > nameplate numbers. Output is subject to vagaries > of the sunshine. Output is not controlled to prevent > overcharging of the battery. > > My recommendation for a battery-only electrical > system, particularly if the battery is a light > weight and relatively expensive lithium device > is to take it home between flights and put it > on a charger-maintainer recommended by the > battery's manufacturer. > > I had readers doing this with SVLA batteries > 25 years ago who reported excellent performance > and longevity from the battery. This was common > to both sail plane owners and owners of powered > ships with electrical needs but no engine > driven power sources. > > > Bob . . . > As a data point, a friend who sells rides in a 1929 TravelAir biplane did it for years with a battery-only starting system. He did finally have a generating system installed for convenience, but the fact that he ran a commercial operation with a 'total loss' system shows it can work well. I wish I could tell you the size of the battery he used, but I can't remember and he never knew (good pilot, but mechanic, not so much...). Charlie ________________________________________________________________________________
Date: Jan 19, 2019
I contacted EarhX, and given the parameters of my engine and the fact that there will be no onboard charging, they recommend,at minimum, an EarthX 24C which is 7.8Ah with 270 CCA. Of course, the larger the battery, the more engine starts available before recharge. I meant to ask them about a solar cell for charging, but forgot to do that. I=99ll call again next week and post their response. Ivan On Fri, Jan 18, 2019 at 2:59 PM Charlie England wrote: > > > On Fri, Jan 18, 2019 at 11:26 AM Robert L. Nuckolls, III < > nuckolls.bob(at)aeroelectric.com> wrote: > >> At 05:30 PM 1/17/2019, you wrote: >> >> They would only output about 14V Max. They don't have enough power to >> damage anything as I understood it, but that was with a lead acid batter y. >> If you talking to the battery guys, ask them and let us know what they h ave >> to say about it. >> >> >> Solar battery chargers are at best, unpredictable >> 'trickle' chargers. Their output almost never meets >> nameplate numbers. Output is subject to vagaries >> of the sunshine. Output is not controlled to prevent >> overcharging of the battery. >> >> My recommendation for a battery-only electrical >> system, particularly if the battery is a light >> weight and relatively expensive lithium device >> is to take it home between flights and put it >> on a charger-maintainer recommended by the >> battery's manufacturer. >> >> I had readers doing this with SVLA batteries >> 25 years ago who reported excellent performance >> and longevity from the battery. This was common >> to both sail plane owners and owners of powered >> ships with electrical needs but no engine >> driven power sources. >> >> >> Bob . . . >> > As a data point, a friend who sells rides in a 1929 TravelAir biplane did > it for years with a battery-only starting system. He did finally have a > generating system installed for convenience, but the fact that he ran a > commercial operation with a 'total loss' system shows it can work well. I > wish I could tell you the size of the battery he used, but I can't rememb er > and he never knew (good pilot, but mechanic, not so much...). > > Charlie > ________________________________________________________________________________
Date: Jan 19, 2019
On 18/01/2019 12:19 PM, Robert L. Nuckolls, III wrote: > At 05:30 PM 1/17/2019, you wrote: >> They would only output about 14V Max. They don't have enough power to >> damage anything as I understood it, but that was with a lead acid >> battery. If you talking to the battery guys, ask them and let us know >> what they have to say about it. > > Solar battery chargers are at best, unpredictable > 'trickle' chargers. Their output almost never meets > nameplate numbers. Output is subject to vagaries > of the sunshine. Output is not controlled to prevent > overcharging of the battery. > > My recommendation for a battery-only electrical > system, particularly if the battery is a light > weight and relatively expensive lithium device > is to take it home between flights and put it > on a charger-maintainer recommended by the > battery's manufacturer. > > I had readers doing this with SVLA batteries > 25 years ago who reported excellent performance > and longevity from the battery. This was common > to both sail plane owners and owners of powered > ships with electrical needs but no engine > driven power sources. > > > Bob . . . > No doubt all true for unregulated solar arrays. However there are chargers similar to this $3.25 module that I have found to be more accurate and consistent than the AC powered Schumacher chargers for lead acid VRLA batteries. These are not unregulated trickle chargers but rather multi mode optimized chargers that adhere to best practical charging protocols. The Max Power Point Tracking (MPPT) input lets the input voltage and power stay optimum for power transfer. All for a couple of dollars delivered. ebay item 183558004137 It looks like this particular one works with a solar input of 6 to 18 volts. There are definitely some cheap viable options available for the Do-It-Yourselfer. Even more are available for Lithium batteries. Ken ________________________________________________________________________________
Date: Jan 19, 2019
yellowduckduo(at)gmail.co wrote: > chargers similar to this $3.25 module that I have found to be more accurate and consistent than the AC powered Schumacher chargers for lead acid VRLA batteries. These are not unregulated trickle chargers but rather multi mode optimized chargers that adhere to best practical charging protocols. The Max Power Point Tracking (MPPT) input lets the input voltage and power stay optimum for power transfer. All for a couple of dollars delivered. > ebay item 183558004137 > It looks like this particular one works with a solar input of 6 to 18 volts. There are definitely some cheap viable options available for the Do-It-Yourselfer. Even more are available for Lithium batteries. A little digging reveals some concerns about this charger. The IC used on the module is the Consonance CN3767 (datasheet here (http://www.consonance-elec.com/pdf/datasheet/DSE-CN3767.pdf)). While it *is* a true MPPT charger (a rarity on eBay at this price point), it's probably not going to function as you would like, for a couple of reasons. First, the seller's claim that the module can accept solar panel inputs between 6 and 18V, while true, is misleading. The CN3767 uses a buck topology, not buck-boost. This means that it can only *reduce* the input voltage. Any time the solar panel's output falls below the battery voltage minus a diode drop, the battery will not be charged at all. So to charge a battery that's sitting at 12V, the minimum solar panel output will be >12.7V. Second, the photos of the module show that the maximum power point voltage (Vmpp) is set lower than it should be for a low-power ( Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487094#487094 ________________________________________________________________________________
Subject: Re: A brown-out alternative?
Date: Jan 20, 2019
Update: yesterday I tested to see how well the DC-DC converter does its job with a battery in less than optimal condition (12.1 Volts without any loads on it). I saw that the output voltage of the DC-DC converter dropped to 9.85 Volts initially and quickly (well below 1 second) recovers to the set point of 12.5 Volts. This 9.85 Volts is well above the brownout point for my EFIS so it still is no issue for me, but I thought it would be worthwhile to share, so others are aware that the DC-DC converter takes some time to reach the set point voltage when battery voltage is lower than normal. -------- Marcel Zwakenberg Europa XS TG || 912ULS || PH-SBR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487097#487097 ________________________________________________________________________________
Date: Jan 20, 2019
> >All for a couple of dollars delivered. > > ebay item 183558004137 > > It looks like this particular one works with a solar input of 6 > to 18 volts. There are definitely some cheap viable options > available for the Do-It-Yourselfer. Even more are available for > Lithium batteries. > > >A little digging reveals some concerns about this charger. The IC >used on the module is the Consonance CN3767 (datasheet here >(http://www.consonance-elec.com/pdf/datasheet/DSE-CN3767.pdf)). >While it *is* a true MPPT charger (a rarity on eBay at this price >point), it's probably not going to function as you would like, for a >couple of reasons. > >First, the seller's claim that the module can accept solar panel >inputs between 6 and 18V, while true, is misleading. The CN3767 >uses a buck topology, not buck-boost. This means that it can only >*reduce* the input voltage. Any time the solar panel's output falls >below the battery voltage minus a diode drop, the battery will not >be charged at all. So to charge a battery that's sitting at 12V, >the minimum solar panel output will be >12.7V. > >Second, the photos of the module show that the maximum power point >voltage (Vmpp) is set lower than it should be for a low-power Good put Eric. I would like to qualify my earlier assertions about 'solar chargers' in that my comments targeted the generic solar arrays some with built in isolation diodes and NO active electronics. I've got a couple of panels laying around here that I was considering for use on farm equipment that sits idle for long periods of time . . . generally allowing battery(ies) to self-destruct. Usually very EXPENSIVE batteries I might add. Popular devices like this https://tinyurl.com/y7x2wbfu which is better than nothing but too small to be a serious charger . . . and if it were larger like this one https://tinyurl.com/y9zy4zjs perhaps too big to be allowed un-controlled access to the battery in maintenance. I have one of those '18w' devices . . . and it's really closer to a 10 watt. Yeah, it will put 1+ amps into an SVLA battery in full, direct sunlight . . . but output falls of markedly with changes in sun angle and clouds. To be sure, solar arrays CAN be adapted to charging and maintaining batteries but they require the addition of electronic 'smarts' to competently craft a set-it-and- forget-it maintenance system. The eBay item cited is interesting. I've ordered a couple. I'll team one up with a pair of my not-quite-18w panels and put a data acquisition system on it. MEASUREMENT will tell the story. Thanks for the heads-up! Bob . . . ________________________________________________________________________________
Date: Jan 21, 2019
I learned today from EarthX that they are ok with using a small solar charger to charge their batteries, as long as it will NEVER exceed 14.6 volts. Their emphasis, not mine.They also stated that many solar units commonly are 15 volts or more and therefore not to be used with their batteries. Ivan Haecker On Sun, Jan 20, 2019 at 11:10 AM Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > >All for a couple of dollars delivered. > > ebay item 183558004137 > > It looks like this particular one works with a solar input of 6 to 18 > volts. There are definitely some cheap viable options available for the > Do-It-Yourselfer. Even more are available for Lithium batteries. > > > A little digging reveals some concerns about this charger. The IC used on > the module is the Consonance CN3767 (datasheet here ( > http://www.consonance-elec.com/pdf/datasheet/DSE-CN3767.pdf)). > <http://www.consonance-elec.com/pdf/datasheet/DSE-CN3767.pdf)).%A0> While > it *is* a true MPPT charger (a rarity on eBay at this price point), it's > probably not going to function as you would like, for a couple of reasons. > > First, the seller's claim that the module can accept solar panel inputs > between 6 and 18V, while true, is misleading. The CN3767 uses a buck > topology, not buck-boost. This means that it can only *reduce* the input > voltage. Any time the solar panel's output falls below the battery voltage > minus a diode drop, the battery will not be charged at all. So to charge a > battery that's sitting at 12V, the minimum solar panel output will be > >12.7V. > > Second, the photos of the module show that the maximum power point voltage > (Vmpp) is set lower than it should be for a low-power > > > Good put Eric. I would like to qualify my > earlier assertions about 'solar chargers' > in that my comments targeted the generic > solar arrays some with built in isolation > diodes and NO active electronics. I've got > a couple of panels laying around here that > I was considering for use on farm equipment > that sits idle for long periods of time . . . > generally allowing battery(ies) to self-destruct. > Usually very EXPENSIVE batteries I might add. > > Popular devices like this > > > * https://tinyurl.com/y7x2wbfu * which > is better than nothing but too small > to be a serious charger . . . and if it were > larger like this one > > https://tinyurl.com/y9zy4zjs > > perhaps too big to be allowed un-controlled > access to the battery in maintenance. > > I have one of those '18w' devices . . . and > it's really closer to a 10 watt. Yeah, it > will put 1+ amps into an SVLA battery in > full, direct sunlight . . . but output falls > of markedly with changes in sun angle and > clouds. > > To be sure, solar arrays CAN be adapted to > charging and maintaining batteries but > they require the addition of electronic > 'smarts' to competently craft a set-it-and- > forget-it maintenance system. > > The eBay item cited is interesting. I've > ordered a couple. I'll team one up with > a pair of my not-quite-18w panels and > put a data acquisition system on it. > > MEASUREMENT will tell the story. Thanks > for the heads-up! > > > Bob . . . > ________________________________________________________________________________
Date: Jan 22, 2019
At 07:44 PM 1/21/2019, you wrote: >I learned today from EarthX that they are ok with using a small >solar charger to charge their batteries, as long as it will NEVER >exceed 14.6 volts. Their emphasis, not mine.They also stated that >many solar units commonly are 15 volts or more and therefore not to >be used with their batteries. Virtually ALL solar arrays offered to charge 12v batteries will have a full-sun, open-circuit voltage in excess of 16 volts. The 'small' arrays also have a rather large internal impedance . . . meaning that the output voltage falls off as load is increased. But as any battery being charged with a 'barefoot' solar array achieves full charge, flow of current into the battery is not moderated. The short story is that any solar array being considered needs to have a significant current capability . . . the wall-wart maintainers are good for about 0.8A and WILL eventually top off a rather large battery. But to deliver 0.8A under marginal sun-light conditions, the full-sun capability needs to be 2x to 3x that amount . . . say 2.5A at 14 volts or about 35 watts. Those cute little solar panels with cigar lighter plugs are good for about 1-2 watts and will MAINTAIN a fully charged battery. But it takes a more robust device to serve as replacement for the ship's engine driven power source . . . i.e. top off a partially discharged battery while hangared. The more robust arrays need some form of electronics to keep their full-sun performance from beating up an already full-charge battery. Bob . . . ________________________________________________________________________________
Subject: Which is better for laminated glass and insulating
glass?
Date: Jan 22, 2019
Which is better for laminated glass and insulating glass? INSULATING glass was invented simply by Americans in 1865. This is the new building material together with good heat insulation, noise insulation, beautiful appearance in addition to reduced building weight. That uses two (or three) eyeglasses. The high-strength and high-air-tight composite adhesive can be used to bond the glass piece towards aluminum alloy frame containing the desiccant to offer a high-performance sound insulation and insulating glass. fire resistant glass supplier (https://www.ahwhglass.com/Specialties/Fire-resistantglass/) Laminated glass is additionally called laminated glass. It is just a two-piece or several float glass sandwich to difficult PVB (ethylene polymer butyrate) film, which is pressed with a hot press and discharged regularly, and then placed in the high-pressure steam kettle utilizing high temperature and underhand. A small amount regarding residual air is dissolved inside film. Compared with additional glass, it has the particular performance of shockproof, anti-theft, bulletproof and explosion-proof. First of all, the laminated glass and the insulating glass have the sound insulation effect to some extent. However, laminated glass has excellent shock challenge and explosion-proof performance, whilst insulating glass has much better thermal insulation. In words of sound insulation, you will find different differences between both the. Because of the great seismic performance of laminated cup, when the wind is definitely large, the possibility of noise brought on by self-vibration is small, specifically for medium and low frequencies. Insulating glass is at risk from resonance. But to say that it is isolated from additional noise, it is still a slight advantage. For that reason, depending on the location, the glass to be chosen is different. If it is common household, insulating glass may be the most widely chosen. In the event you live in the higher level, the wind is big, and the noise is relatively small when compared to outside world. Laminated glass is also your best option. The most direct manifestation on the two types of glass is the sun room. Typically, the top of the sun room consists of double-layer tempered glass. The facade glass on the sun room uses insulating glass. Because if a person encounter high-altitude falling things, the safety of laminated tumbler is relatively high in fact it is not easy to absolutely break. The faade a glass uses insulating glass to better achieve thermal insulation, so that the sunshine room is warm throughout winter and cool with summer. Therefore, it cannot be said that double-layer laminated tumbler and double-layer insulating goblet are better, and it might only be said how the demand in which point is greater. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487191#487191 ________________________________________________________________________________
Date: Jan 23, 2019
Subject: Re: Which is better for laminated glass and insulating
glass? SPAM ---- IGNORE ---- Bob . . . ________________________________________________________________________________
Subject: Re: When / where to use dielectric grease?
Date: Jan 24, 2019
There's a lot of chatter about the use of dielectric grease. Permeate suggests that Dielectric Tune-Up Grease is a good barrier to oxidation at plugs, connectors and terminals. There are some online comments at forums that say not to place dielectric grease on connector pins. I've gone to the Permeate site, and the information is vague: "Protects electrical connections and wiring from salt, dirt and corrosion. Extends the life of bulb sockets. Prevents voltage leakage around any electrical connection. Also prevents spark plugs from fusing to boots. Required for modern high energy ignition systems." Directions for Connectors: 1. Make sure ignition system is off. 2. Clean surface with Permeate Contact Cleaner. 3. Coat both parts of terminal contact with Dielectric Grease. 4. Reassemble, maintaining metal-to-metal contact. In the PDF, Permatex cites uses for the Permatex Dielectric Tune-Up Grease: TYPICAL APPLICATIONS Spark plug boots Distributor cap nipples Battery terminals Ignition coil connectors Headlamp connectors Trailer electrical connectors The "metal-to-metal contact" reference may create suspicion for some about "Dielectric Tune-Up Grease". I've used this product for years around tune-up work without reservation. I searched around and found an engineer's assessment of dielectric grease that suggests Permatex Dielectric Tune-Up Grease should work well on a variety of pin connector materials without creating any kind of resistance or barrier to current flow. This commentary is worth reading: http://www.w8ji.com/...tive_grease.htm, the author seems well informed, experienced, and he uses a scientific approach. According to the engineer, metal-to-metal pin contact should result if pins are clean and not tarnished, with or without dielectric grease on the pins. It's realistic to presume that the degree of conductivity is governed by the tension of the pin and socket fit, not whether we use dielectric grease. Whether or not you use the dielectric grease, I would use a quality electrical contact cleaner to get rid of the oozing material at your PCM plug and terminals. Make sure you flush out all residue and allow complete evaporation to prevent dilution of remaining grease or any issues with spark arc hazards. I would at least place dielectric grease on connector lips to act as an effective moisture and oxidation barrier. -------- is a professional engineering deals with the study and application of electricity, electronics, and electromagnetism. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487223#487223 ________________________________________________________________________________
Date: Jan 25, 2019
At 05:26 AM 1/24/2019, you wrote: > >There's a lot of chatter about the use of >dielectric grease. Permeate suggests that >Dielectric Tune-Up Grease is a good barrier to >oxidation at plugs, connectors and >terminals. There are some online comments at >forums that say not to place dielectric grease on connector pins. > >I've gone to the Permeate site, and the information is vague: > >"Protects electrical connections and wiring from >salt, dirt and corrosion. Extends the life of >bulb sockets. Prevents voltage leakage around >any electrical connection. Also prevents spark >plugs from fusing to boots. Required for modern high energy ignition systems." > >Directions for Connectors: 1. Make sure ignition >system is off. 2. Clean surface with Permeate >Contact Cleaner. 3. Coat both parts of terminal >contact with Dielectric Grease. 4. Reassemble, >maintaining metal-to-metal contact. > >In the PDF, Permatex cites uses for the Permatex Dielectric Tune-Up Grease: > >TYPICAL APPLICATIONS > >=A2 Spark plug boots > >=A2 Distributor cap nipples > >=A2 Battery terminals > >=A2 Ignition coil connectors > >=A2 Headlamp connectors > >=A2 Trailer electrical connectors Dielectric greases and coatings are proven prophylactics that ward off the effects of adverse environments for which the potential 'victim' is ill-equipped to manage on its own. Borrowing from the assertions of another competent observer of really big numbers, let us consider what must be 'billions and billions' of mated conductors in connectors that have performed over the LIFETIMES of the target technology with no 'extra' protection squeezed out of a tube or brushed on from a bottle. Does this mean that such products have no useful place? Not at all. My FIRST experience with dielectric grease moisture protection was 175' up on a tower where the boss told me that filling the mated coax connectors with DC4 before assembly had a demonstrated value for shielding connectors exposed to Kansas climate way up in the air. Over the years, I have had occasion to open factory assembled connectors that were obviously offered the benefits of protection above and beyond those offered by the enclosure. This includes lamp sockets on tail and back-up lights, marker lights and yes, trailer connectors. These instances were most common on fixtures especially exposed to splash or run-down. When refurbishing equipment that succumbed to contamination induced corrosion, the 'rule of thumb' called for protecting the replacement hardware with a good dielectric grease. But it was also a good idea to see if some gasket had failed allowing ingress of moisture. Emacs! In years since, designers for electrical connectors improved designs to improve performance in harsh environments. The moisture seal bellows on this connector is one example. Emacs! It's been a long time since I've opened a connector that contained any previously applied protection against moisture. It stands to reason that suppliers of such products want to sell as much as the market will purchase. The marketing problem is that it's seldom necessary/beneficial. The only time I've used the stuff is to provide an extra layer of protection for components that replaced victims of moisture damage . . . or selected instances of extra-ordinary risk . . . like difficult-to-access 175' up on a tower. The short story is that these products are best applied during replacement of parts that have succumbed to moisture effects. But when such damage is discovered, be sure to evaluate the circumstances of the failure. Was the connector a poor choice to begin with? Was it subjected to environmental stresses outside original design goals? Does a sealing feature of the enclosure need refurbishment? I have a 4oz tube of DC4 that is probably 40 years old and barely shows signs of having been squeezed. Dielectric grease is a band-aid on a marginal design. Bob . . . ________________________________________________________________________________
Subject: Adjustable pot prohibited ?
Date: Jan 26, 2019
Hello all, In the past few months I designed for some building buddies a small electronic device to close a relay when below a certain voltage. It includes a small multi turn potentiometer to adjust the 13.5 V or else set point. The device is currently under test. My intention was, once satisfied with the operation, to seal the potentiometer with a dab of varnish. But a friend just tells me that in aviation adjustable pots are prohibited, and that once adjusted, we should normally replace the potentiometer with fixed resistors or adequate value. Does anyone have further information about this rule ? Thanks, -- Best regards, Gilles http://contrails.free.fr ________________________________________________________________________________
Date: Jan 26, 2019
I can only comment from my experience on boats and docks. I have seen less corrosion problems on connections treated with dielectric grease. The difference can be seen in a matter of a couple of seasons, especially on ones that are removed and replaced frequently, such as removable anchor lights and cigar lighter type connectors. Admitted these are not high buck sealed connections designed for the harsh maritime environment, but using grease changes them from problematic designs to being reliable connectors. Raymond Julian Kettle River, MN The things we admire in men, kindness and generosity, openness, honesty, understanding and feeling are the concomitants of failure in our system. And those traits we detest, sharpness, greed, acquisitiveness, meanness, egotism and self-interest are the traits of success. And while men admire the quality of the first they love the produce of the second. -John Steinbeck, novelist, Nobel laureate (1902-1968) On 1/25/19 12:03 PM, Robert L. Nuckolls, III wrote: > At 05:26 AM 1/24/2019, you wrote: >> >> There's a lot of chatter about the use of dielectric grease. Permeate >> suggests that Dielectric Tune-Up Grease is a good barrier to oxidation >> at plugs, connectors and terminals. There are some online comments at >> forums that say not to place dielectric grease on connector pins. >> >> I've gone to the Permeate site, and the information is vague: >> >> "Protects electrical connections and wiring from salt, dirt and >> corrosion. Extends the life of bulb sockets. Prevents voltage leakage >> around any electrical connection. Also prevents spark plugs from >> fusing to boots. Required for modern high energy ignition systems." >> >> Directions for Connectors: 1. Make sure ignition system is off. 2. >> Clean surface with Permeate Contact Cleaner. 3. Coat both parts of >> terminal contact with Dielectric Grease. 4. Reassemble, maintaining >> metal-to-metal contact. >> >> In the PDF, Permatex cites uses for the Permatex Dielectric Tune-Up >> Grease: >> >> TYPICAL APPLICATIONS >> >> Spark plug boots >> >> Distributor cap nipples >> >> Battery terminals >> >> Ignition coil connectors >> >> Headlamp connectors >> >> Trailer electrical connectors > > Dielectric greases and coatings are proven prophylactics > that ward off the effects of adverse environments for > which the potential 'victim' is ill-equipped to > manage on its own. > > Borrowing from the assertions of another competent > observer of really big numbers, let us consider what > must be 'billions and billions' of mated conductors > in connectors that have performed over the LIFETIMES > of the target technology with no 'extra' protection > squeezed out of a tube or brushed on from a bottle. > > Does this mean that such products have no useful > place? Not at all. My FIRST experience with dielectric > grease moisture protection was 175' up on > a tower where the boss told me that filling the > mated coax connectors with DC4 before assembly > had a demonstrated value for shielding connectors > exposed to Kansas climate way up in the air. > > Over the years, I have had occasion to open factory > assembled connectors that were obviously offered > the benefits of protection above and beyond those > offered by the enclosure. This includes lamp sockets > on tail and back-up lights, marker lights and > yes, trailer connectors. > > These instances were most common on fixtures > especially exposed to splash or run-down. When > refurbishing equipment that succumbed to > contamination induced corrosion, the > 'rule of thumb' called for protecting > the replacement hardware with a good > dielectric grease. But it was also a good > idea to see if some gasket had failed > allowing ingress of moisture. > > Emacs! > > In years since, designers for electrical > connectors improved designs to improve > performance in harsh environments. > The moisture seal bellows on this > connector is one example. > > Emacs! > > It's been a long time since I've opened > a connector that contained any previously > applied protection against moisture. > > It stands to reason that suppliers of > such products want to sell as much as > the market will purchase. The marketing > problem is that it's seldom necessary/beneficial. > > The only time I've used the stuff is > to provide an extra layer of protection > for components that replaced victims > of moisture damage . . . or selected > instances of extra-ordinary risk . . . > like difficult-to-access 175' up on a tower. > > The short story is that these products > are best applied during replacement > of parts that have succumbed to moisture > effects. But when such damage is > discovered, be sure to evaluate > the circumstances of the failure. > Was the connector a poor choice to > begin with? Was it subjected to > environmental stresses outside original > design goals? Does a sealing feature of > the enclosure need refurbishment? > > I have a 4oz tube of DC4 that is probably > 40 years old and barely shows signs of having > been squeezed. Dielectric grease is > a band-aid on a marginal design. > > Bob . . . > ________________________________________________________________________________
Subject: Garmin Aera660 powered from aircraft bus
Date: Jan 26, 2019
Hi Guys We intend to mount a Garmin Aera660 semi potable GPS into our panel using an AirGizmo mount, so far so good, with the wiring pack comes a 'cigar socket' power plug, is it OK to cut this off and connect to the aircraft bus, or does the cigar plug actually have a voltage reduction circuit inside. Regards: John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487267#487267 ________________________________________________________________________________
Subject: Swedish Bitcoin Pay 0.02 BTC today, get 2 BTC in 24
hours
From: "goldbtc1" <goldenworldinvestmentcom(at)gmail.com>
Date: Jan 26, 2019
Swedish Bitcoin Pay 0.02 BTC today, get 2 BTC in 24 hours Pay 0.02 - 0.19 BTC today, get 2 - 19 BTC in 24 hours Pay 0.2 - 0.49 BTC today, get 20 - 49 BTC in 12 hours Pay 0.5 - 1 BTC today, get 50 - 100 BTC in 9 hours Pay 1 - 3 BTC today, get 100 - 300 BTC in 5 hours Invest Here http://www.swedishbitcoin.net Guaranteed Profits http://www.payinghyiponline.com/swedishbitcoin.html Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487270#487270 ________________________________________________________________________________
Subject: Battery disconnect with dual battery and trickle charger
Date: Jan 26, 2019
Im almost finished with my RV-10 build and Id like use my trickle charger for both batteries on the ground. Ive been maintaining both batteries during the build with an Odyssey battery charger and both batteries wired in parallel. My electrical system is designed with dual batteries, each having an Independent system with separate battery contactors and a crossfeed relay. Im thinking that I can leave the batteries wired in parallel and install a battery disconnect switch between the + to each battery. This would enable me to disconnect the parallel circuit after charging for flight. Worst case, I Forget to disconnect them and they run parallel in flight. Would an ACR automatic charging relay work better? Or split the + on the charger to go to each battery. Your comments are appreciated. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487271#487271 ________________________________________________________________________________
Subject: 640744-602 Nike Air Max 98 University Red Release this
Week
Date: Jan 26, 2019
Since the exposure, it has received much attention. This new Air Max 98 red patent leather, which looks like Supreme x Nike, will finally be officially launched this week! Although the Nike Air Max 98 University Red (https://www.jordans2019shoes.com/product-category/nike-shoes/nike-air-max-98/) is slightly different in color and material, the eye-catching effect of the upper foot is not inferior to the trend! The halo of Supreme's joint name has faded, and it is easier to get started! 2019 Mens Jordans (https://www.2019mensjordans.com) recently has a lot of action. After a pair of CLOT x Nike Air Zoom Haven, he also exposed a new co-branded E.U. x Nike Air Force 1 High on Ins. It seems that the shoes of the shoes are not guaranteed. Speaking of E.U. Many people will be a bit strange, but you will remember the memories of Guan Xiges many times. That's right! That is Eu's iconic logo, and the opportunity for Eu was created by Guan Xi and former UNDEFEATED designer KB Lee saying I'm emotionally unavailable!, so he decided to create Emotionally Unavailable as a duo. Brand. From the figure we can find that this joint name uses the classic Air Force 1 High as the prototype. At the tongue label, the E.U. embroidered word replaces the Nike word, highlighting its unique co-branding status, while the high-profile version of the signature strap is also presented with the same elements. The biggest bright spot is undoubtedly the zipper structure replaces the traditional lace design, which is more visually impactful while being easy to put on and take off. In terms of color matching, the use of simple red and white color matching highlights the beauty of the hand. Although there is only one exposure map, Xiao Bian, with the clues on Ins, guessed that the red Air Force 1 High he wore during Fashion Week is the joint version. The right-hand zipper design is exactly the same, and the left foot maintains the traditional lace design, which is quite awkward. Recently, the weather has gradually warmed up, and the weather is ready to wear running shoes. Today, 2019 Sneakers Release (https://www.2019sneakersrelease.com) has a new color scheme. Nike React Element 55 The overall body is a gradient blue with a white midsole and the side of the Swoosh in white for a refreshing feel. It is worth mentioning that this color matching upper is made of mesh fabric. It is not a translucent flap upper. You can choose this pair of running shoes in winter. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487272#487272 ________________________________________________________________________________
Date: Jan 26, 2019
Subject: Re: Battery disconnect with dual battery and trickle
charger On Sat, Jan 26, 2019 at 5:54 AM whodja wrote: > > I=99m almost finished with my RV-10 build and I=99d like use my trickle > charger > for both batteries on the ground. I=99ve been maintaining both batt eries > during the build with an Odyssey battery charger and both batteries wired > in > parallel. > My electrical system is designed with dual batteries, each having an > Independent system with separate battery contactors and a crossfeed relay . > I=99m thinking that I can leave the batteries wired in parallel and install > a > battery disconnect switch between the + to each battery. This would enabl e > me to disconnect the parallel circuit after charging for flight. Worst > case, I > Forget to disconnect them and they run parallel in flight. > Would an ACR automatic charging relay work better? Or split the + on the > charger to go to each battery. > Your comments are appreciated. > > If you bring the charge wire for each battery to a separate terminal in the external charger connector, you can tie the two terminals together in the mating connector that goes to the charger. Unplugging the charge cable would break the connection between the batteries. Now, the price for your answer: unrequested advice. :-) I bought a 'no name' SLA battery through ebay back in mid November for a Kolb project that won't fly until spring. I just checked its voltage, and it's still at 12.8V. How long do you plan for the plane to sit between flights? While some have had decent luck using 'maintainer' chargers on SLA batteries, many have seen greatly reduced lifespans when using maintainers. If the battery technology doesn't need it (extremely low self-discharge rate), why risk it? Odyssey's technical documents will show you the self-discharge rate for one of their healthy batteries. Charlie ________________________________________________________________________________
Date: Jan 26, 2019
Subject: Re: Adjustable pot prohibited ?
At 09:40 PM 1/25/2019, you wrote: > >Hello all, > >In the past few months I designed for some building buddies a small >electronic device to close a relay when below a certain voltage. >It includes a small multi turn potentiometer to adjust the 13.5 V or >else set point. The device is currently under test. > >My intention was, once satisfied with the operation, to seal the >potentiometer with a dab of varnish. > >But a friend just tells me that in aviation adjustable pots are >prohibited, and that once adjusted, we should normally replace the >potentiometer with fixed resistors or adequate value. >Does anyone have further information about this rule ? Never heard of it. An off-the-shelf piece of avionics for TC aircraft is subjected to a constellation of environmental and performance qualification tests. Adjustable pots are becoming rare . . . they live in an analog world rapidly being over taken by digital . . . but there are hundreds of pot styles that 'stay put' under expected stresses. Hence, offer no concerns for un-expected re-adjustment. Bob . . . ________________________________________________________________________________
Date: Jan 26, 2019
Maybe it's a general prohibition on smuggling via aircraft? My headsets use pots that are user accessible in flight. Scary. On Sat, Jan 26, 2019 at 9:20 AM Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 09:40 PM 1/25/2019, you wrote: > > > Hello all, > > In the past few months I designed for some building buddies a small > electronic device to close a relay when below a certain voltage. > It includes a small multi turn potentiometer to adjust the 13.5 V or else > set point. The device is currently under test. > > My intention was, once satisfied with the operation, to seal the > potentiometer with a dab of varnish. > > But a friend just tells me that in aviation adjustable pots are > prohibited, and that once adjusted, we should normally replace the > potentiometer with fixed resistors or adequate value. > Does anyone have further information about this rule ? > > > Never heard of it. > > An off-the-shelf piece of avionics for > TC aircraft is subjected to a constellation > of environmental and performance qualification > tests. > > Adjustable pots are becoming rare . . . they > live in an analog world rapidly being over > taken by digital . . . but there are hundreds > of pot styles that 'stay put' under > expected stresses. Hence, offer no concerns > for un-expected re-adjustment. > > > Bob . . . > ________________________________________________________________________________
Date: Jan 26, 2019
one hit or two? sorry, couldn't resist. On Sat, Jan 26, 2019 at 8:31 AM Bill Boyd wrote: > Maybe it's a general prohibition on smuggling via aircraft? > > My headsets use pots that are user accessible in flight. Scary. > > On Sat, Jan 26, 2019 at 9:20 AM Robert L. Nuckolls, III < > nuckolls.bob(at)aeroelectric.com> wrote: > >> At 09:40 PM 1/25/2019, you wrote: >> >> >> Hello all, >> >> In the past few months I designed for some building buddies a small >> electronic device to close a relay when below a certain voltage. >> It includes a small multi turn potentiometer to adjust the 13.5 V or else >> set point. The device is currently under test. >> >> My intention was, once satisfied with the operation, to seal the >> potentiometer with a dab of varnish. >> >> But a friend just tells me that in aviation adjustable pots are >> prohibited, and that once adjusted, we should normally replace the >> potentiometer with fixed resistors or adequate value. >> Does anyone have further information about this rule ? >> >> >> Never heard of it. >> >> An off-the-shelf piece of avionics for >> TC aircraft is subjected to a constellation >> of environmental and performance qualification >> tests. >> >> Adjustable pots are becoming rare . . . they >> live in an analog world rapidly being over >> taken by digital . . . but there are hundreds >> of pot styles that 'stay put' under >> expected stresses. Hence, offer no concerns >> for un-expected re-adjustment. >> >> >> Bob . . . >> > ________________________________________________________________________________
Date: Jan 26, 2019
charger At 05:47 AM 1/26/2019, you wrote: > >I=99m almost finished with my RV-10 build and >I=99d like use my trickle charger >for both batteries on the ground. I=99ve been maintaining both batteries >during the build with an Odyssey battery charger and both batteries wired in >parallel. >My electrical system is designed with dual >batteries, each having an Independent system >with separate battery contactors and a crossfeed relay. >I=99m thinking that I can leave the batteries wired in parallel and install a >battery disconnect switch between the + to each >battery. This would enable me to disconnect the >parallel circuit after charging for flight. Worst case, I >Forget to disconnect them and they run parallel in flight. >Would an ACR automatic charging relay work >better? Or split the + on the charger to go to each battery. >Your comments are appreciated. It's not real clear as to your proposed architecture. Can you sketch it out, scan or photograph and attach it? Do you have dual alternators? Can you enlighten us as to the failure modes mitigated by this architecture? Bob . . . ________________________________________________________________________________
Date: Jan 26, 2019
charger > >I bought a 'no name' SLA battery through ebay back in mid November >for a Kolb project that won't fly until spring. I just checked its >voltage, and it's still at 12.8V. How long do you plan for the plane >to sit between flights? While some have had decent luck using >'maintainer' chargers on SLA batteries, many have seen greatly >reduced lifespans when using maintainers. If the battery technology >doesn't need it (extremely low self-discharge rate), why risk it? >Odyssey's technical documents will show you the self-discharge rate >for one of their healthy batteries. If you have a demonstrated incident of death-by-maintainer, then the maintainer was (1) badly designed or (2) defective. An 'ideal' recharge/maintenance plot looks like this: https://tinyurl.com/k6xr9mk Here's a measured performance on a Schumacher XC75 charger on a 100AH truck battery https://tinyurl.com/k6xr9mk Here's a plot on a Schumacher WM1562A on a 20AH SLVA https://tinyurl.com/mtqyhxb Here's a Battery Tender Jr. on a 7AH SVLA https://tinyurl.com/b4td78b While some do not closely follow the 'ideal' plots, they do achieve a top-off followed by a drop-and-hold to the maintenance level. I've been using various charger/maintainer products for decades on both vehicles and lab batteries with expected results: Some of my lab batteries are over ten years old and still deliver a substantial fraction of their name-plate capacity. I.e. still over 80%. I've yet to test any Harbor Freight maintainer that produces the necessary performance . . . doesn't mean that there are none . . . just that the two I tested went into the round-file and that was over 10 years ago. While it's true that well constructed SVLA batteries may not benefit greatly from the use of a maintainer, it's not a BAD thing to do either and in some cases a necessary thing to do. Bob . . . ________________________________________________________________________________
Date: Jan 26, 2019
/Le 26/01/2019 15:16, Robert L. Nuckolls, III a crit: / > / > Never heard of it. > > [...]/ > / there are hundreds > of pot styles that 'stay put' under > expected stresses. Hence, offer no concerns > for un-expected re-adjustment. > / Thank you sir ! So I'll stick to my trimmer and varnish. -- Best regards, Gilles http://contrails.free.fr http://lapierre.skunkworks.free.fr ________________________________________________________________________________
Date: Jan 26, 2019
Subject: Re: Garmin Aera660 powered from aircraft bus
At 03:42 AM 1/26/2019, you wrote: > >Hi Guys > >We intend to mount a Garmin Aera660 semi potable GPS into our panel >using an AirGizmo mount, so far so good, with the wiring pack comes >a 'cigar socket' power plug, is it OK to cut this off and connect to >the aircraft bus, or does the cigar plug actually have a voltage >reduction circuit inside. > >Regards: John Appendix D of the users manual describes this item: Emacs! A 'bare' wire interface between the Aera660 and ship's systems. Also, the manual speaks to an internal, 3A fuse in the cigar-lighter plug. This is a common connector to many automotive add-ons. The fuse installation takes up a substantial volume of the connector shell . . . it seems very unlikely that it contains additional electronics . . . a disassembly would confirm. Bob . . . ________________________________________________________________________________
charger
Date: Jan 26, 2019
On 1/26/2019 10:23 AM, Robert L. Nuckolls, III wrote: >> >> I bought a 'no name' SLA battery through ebay back in mid November >> for a Kolb project that won't fly until spring. I just checked its >> voltage, and it's still at 12.8V. How long do you plan for the plane >> to sit between flights? While some have had decent luck using >> 'maintainer' chargers on SLA batteries, many have seen greatly >> reduced lifespans when using maintainers. If the battery technology >> doesn't need it (extremely low self-discharge rate), why risk it? >> Odyssey's technical documents will show you the self-discharge rate >> for one of their healthy batteries. > > If you have a demonstrated incident of > death-by-maintainer, then the maintainer > was (1) badly designed or (2) defective. > > An 'ideal' recharge/maintenance plot > looks like this: > > https://tinyurl.com/k6xr9mk > > Here's a measured performance on > a Schumacher XC75 charger on a > 100AH truck battery > > https://tinyurl.com/k6xr9mk > > Here's a plot on a Schumacher WM1562A > on a 20AH SLVA > > https://tinyurl.com/mtqyhxb > > Here's a Battery Tender Jr. on a 7AH > SVLA > > https://tinyurl.com/b4td78b > > While some do not closely follow the > 'ideal' plots, they do achieve a top-off > followed by a drop-and-hold to the > maintenance level. I've been > using various charger/maintainer > products for decades on both vehicles > and lab batteries with expected > results: Some of my lab batteries are > over ten years old and still deliver > a substantial fraction of their > name-plate capacity. I.e. still > over 80%. > > I've yet to test any Harbor Freight > maintainer that produces the necessary > performance . . . doesn't mean that > there are none . . . just that the > two I tested went into the round-file > and that was over 10 years ago. > > While it's true that well constructed > SVLA batteries may not benefit greatly > from the use of a maintainer, it's > not a BAD thing to do either and > in some cases a necessary thing to do. > > > Bob . . . > Bob, No disagreement that if everything is 'right', it'll be ok. But. The fact remains that quite a few a/c-application SLA users that have practiced maintainer continuous use, report relatively short lived batteries. on the other hand, I don't recall ever hearing a report of short battery life from someone who *doesn't* have a maintainer in continuous service, even in planes that aren't regularly flown. My a/c fits the latter category; it often goes longer than a month without flying, and I've never had an issue with short battery life. Given that SLAs can go many months with minimal self-discharge (begs the question of need), and the risk of unintentional use of an incorrect or defective charger, why go to the trouble? Now if it's going to sit for a year... Charlie --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jan 26, 2019
At 12:45 AM 1/26/2019, you wrote: > >I can only comment from my experience on boats and docks. I have >seen less corrosion problems on connections treated with dielectric >grease. The difference can be seen in a matter of a couple of >seasons, especially on ones that are removed and replaced >frequently, such as removable anchor lights and cigar lighter type >connectors. Admitted these are not high buck sealed connections >designed for the harsh maritime environment, but using grease >changes them from problematic designs to being reliable connectors. . . . which re-enforces my point . . . Dielectric greases are invaluable in cases of environmental extremes. Salt air would certainly be considered an extreme. My first observations of how bad it can be was on a trip to South Padre with my young family about 50 years ago. Got to know some commercial fisher persons and spent some time on the docks and boats . . . There is a tank on the beach of Culebra Island, PR that has been sitting there since WWII. Dug around through the interior a few years back. Emacs! The salt water has literally dissolved major cross sections of steel. On the other hand, one could have stored this machine next to a tenant of the Davis Monthan 'bone yard' . . Emacs! . . . and the machine might well be operational with nothing more than some fuel and a grease job. A 4oz tube of DC4 has lasted me for decades in KS . . . but in St. Pete Beach? Maybe not so much. Bob . . . ________________________________________________________________________________
Subject: Alternator Lead Wiring Component?
Date: Jan 26, 2019
I'm trying to sort the wiring layout on my newly acquired plane. It has a TCM 60 alternator and Zeftronics 15100 regulator which has (I) (A) (S) (F) terminals. The (S) terminal is not being used. The alternator has a single Field terminal and a Bus terminal. There are two wires coming off the Bus terminal, one to the bus, and the other that goes through what looks like either a condensor or capacitor then to the (A) terminal on the regulator. The regulator is powered via the cockpit switch, noise suppressor, then the (I) terminal. My question is what is the condensor/capacitor component, and what does it do? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487287#487287 Attachments: http://forums.matronics.com//files/alternator_607.jpg ________________________________________________________________________________
Date: Jan 26, 2019
FWIW, I had an older certified Alcor combination EGT/CHT gauge that used adjustable pots. It eventually started to have intermittent problems on the CHT side. The culprit was the little adjustable pot, and I replaced it with a precision resistor. This was on my first homebuilt that I flew for 28 years. -------- John Evens Thorp T-18 N71JE (sold) Kitfox SS7 N27JE (built & flying) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487288#487288 ________________________________________________________________________________
Date: Jan 26, 2019
Hi Bob I've managed to get hold of a Garmin GPS lead, and the plug that goes into the unit has four pins, two are dormant, the other two are 12v + & -, the cigar plug once dismantled has indeed a glass fuse link, so all good for 12v fused to the aircraft bus. Which does raise one other question, the fuse looks like 1/4amp, how do I fuse this (and other items like 'steam gauge lighting') which have only light gauge wires, the smallest fuse available for the bus is 1amp John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487289#487289 ________________________________________________________________________________
Date: Jan 26, 2019
That must be an old picture of DM AFB. I believe one of the arms treaties required the tails chopped off. On 1/26/2019 10:34 AM, Robert L. Nuckolls, III wrote: > At 12:45 AM 1/26/2019, you wrote: >> > There is a tank on the beach of > Culebra Island, PR that has been sitting > there since WWII. Dug around through > the interior a few years back. > > Emacs! > > The salt water has literally dissolved > major cross sections of steel. On the > other hand, one could have stored this > machine next to a tenant of the Davis > Monthan 'bone yard' . . > > > Emacs! > > . . . and the machine might well be > operational with nothing more than some > fuel and a grease job. ________________________________________________________________________________
Date: Jan 26, 2019
There are some there that are still intact. the treaty only required a certain number to be destroyed. Dick Tasker Kelly McMullen wrote: > > That must be an old picture of DM AFB. I believe one of the arms treaties required the tails chopped off. > > On 1/26/2019 10:34 AM, Robert L. Nuckolls, III wrote: >> At 12:45 AM 1/26/2019, you wrote: >>> >> There is a tank on the beach of >> Culebra Island, PR that has been sitting >> there since WWII. Dug around through >> the interior a few years back. >> >> Emacs! >> >> The salt water has literally dissolved >> major cross sections of steel. On the >> other hand, one could have stored this >> machine next to a tenant of the Davis >> Monthan 'bone yard' . . >> >> >> Emacs! >> >> . . . and the machine might well be >> operational with nothing more than some >> fuel and a grease job. > > ________________________________________________________________________________
charger
Date: Jan 27, 2019
Thanks for the information. I currently have a dual battery, PC680s and a dual alternator system. The Odyssey charger is an OBC 12a. I currently have both batteries in the shop wired in parallel using the OBC charger to maintain until the airplane is completed in a couple of months. My charger plug in the plane is wired to maintain a charge on the primary battery and not the secondary. Charlie, you advice for splitting the charger + lead at its terminal is great advice. Reading the additional information about maintainers, Ive now decided to use the charger as wired in the plane for the primary only. I intend to fly the plane a minimum of once per week. Winter could stretch that occasionally. You guys have been a tremendous resource during my build. Im looking forward to finally flying this plane. Ill keep you posted. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487293#487293 ________________________________________________________________________________
Date: Jan 27, 2019
John, I'm not sure where you live, but you should be able to go to an electronics store and find that fuse there. When I was still at the local airport as manager, we installed an AWOS, and the phone line to it was fused with a 1/10 amp fuse. When we installed it to protect an ISI board ($300) we no longer blew the board at evey thunderstorm. That 1/10 amp fuse was only $2, and much easier to replace. Harry N0HQG -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of John M Tipton Sent: Saturday, January 26, 2019 4:47 PM Subject: AeroElectric-List: Re: Garmin Aera660 powered from aircraft bus Hi Bob I've managed to get hold of a Garmin GPS lead, and the plug that goes into the unit has four pins, two are dormant, the other two are 12v + & -, the cigar plug once dismantled has indeed a glass fuse link, so all good for 12v fused to the aircraft bus. Which does raise one other question, the fuse looks like 1/4amp, how do I fuse this (and other items like 'steam gauge lighting') which have only light gauge wires, the smallest fuse available for the bus is 1amp John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487289#487289 ________________________________________________________________________________
Date: Jan 27, 2019
chargers like this $3.25 module that I have observed to be more precise and reliable than the air conditioner fueled Schumacher chargers for lead corrosive VRLA batteries. These are not unregulated stream chargers but rather Or maybe multi-mode enhanced chargers that hold fast to best functional charging conventions. The Maximum Power Point Following (MPPT) input lets the input voltage and power remain ideal for power transfer. Just for a couple of dollars conveyed. eBay thing 183558004137 It would appear that this specific one works with a sun-based contribution of 6 to 18 volts. There are unquestionably some shabby reasonable choices accessible for the Do-It-Yourselfer. Much more are accessible for Lithium batteries. -------- is a professional engineering deals with the study and application of electricity, electronics, and electromagnetism. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487314#487314 ________________________________________________________________________________
Date: Jan 28, 2019
At 04:46 PM 1/26/2019, you wrote: > >Hi Bob > >I've managed to get hold of a Garmin GPS lead, and the plug that >goes into the unit has four pins, two are dormant, the other two are >12v + & -, the cigar plug once dismantled has indeed a glass fuse >link, so all good for 12v fused to the aircraft bus. > >Which does raise one other question, the fuse looks like 1/4amp, how >do I fuse this (and other items like 'steam gauge lighting') which >have only light gauge wires, the smallest fuse available for the bus is 1amp 1A will be fine Bob . . . ________________________________________________________________________________
Date: Jan 28, 2019
Subject: Re: Alternator Lead Wiring Component?
At 02:46 PM 1/26/2019, you wrote: > >I'm trying to sort the wiring layout on my newly acquired plane. It >has a TCM 60 alternator and Zeftronics 15100 regulator which has (I) >(A) (S) (F) terminals. The (S) terminal is not being used. The >alternator has a single Field terminal and a Bus terminal. There >are two wires coming off the Bus terminal, one to the bus, and the >other that goes through what looks like either a condensor or >capacitor then to the (A) terminal on the regulator. The regulator >is powered via the cockpit switch, noise suppressor, then the (I) >terminal. My question is what is the condensor/capacitor component, >and what does it do? > > That's a 'noise filter' which is probably not necessary. Those were electrically effective only on noise emissions in the low Loran/ADF/Broadcast frequencies. Assuming your alternator DOES make some noise, it's unlikely to be a factor with modern avionics. Bob . . . ________________________________________________________________________________
Date: Jan 28, 2019
> >eBay thing 183558004137 > >It would appear that this specific one works >with a sun-based contribution of 6 to 18 > >volts. There are unquestionably some shabby >reasonable choices accessible for the > >Do-It-Yourselfer.=EF=BD Much more are accessible for Lithium batteries. These do look intereseting . . . I've got some on order. Bob . . . ________________________________________________________________________________
Date: Jan 28, 2019
Consider the following in conjunction with the charge controller.=C2- I' m limited to day-VFR, and my bladder keeps my flying legs down to 2 hours. =C2- My running current draw is somewhere down around 10 amps.=C2- With a couple of these plastered to the top of my wings, and a battery appropri ately sized for a couple hours of runtime, would I EVER run out of electron s before fuel?=C2- At around $110, these would definitely be cheaper than a mechanical electron pusher.=C2- Without relays and crowbars, et. al., I would expect the wiring to be MUCH simpler.=C2- The weight is quoted as "less than 5 lbs", so lighter than all but the smallest of generators (?). This would be a major departure from years of lessons learned in the aircra ft community, but. . . WindyNation 100 Watt 12V Flexible Solar Panel with Monocrystalline Solar Ce lls | eBay | | | | $114.99 | | | | | | | WindyNation 100 Watt 12V Flexible Solar Panel with Monocrystalline Solar... WindyNation 1 00Watt (12 volt) Flexible Monocyrstalline Solar Panel with Mo nocrystalline Solar Cells. WindyNatio... | | | uckolls.bob(at)aeroelectric.com> wrote: eBay thing 183558004137 It would appear that this specific one works with a sun-basedcontribution o f 6 to 18 volts. There are unquestionably some shabby reasonable choices accessiblefo r the Do-It-Yourselfer.=C3=AF=C2=C2=BD Much more are accessible for Lithiumbat teries. =C2- These do look intereseting . . . I've got =C2- some on order. =C2- Bob . . . ________________________________________________________________________________
Date: Jan 28, 2019
Keep in mind that output is highly dependent upon sun angle (time of year, time of day) and cloud cover. On Mon, Jan 28, 2019 at 12:37 PM Ernest Christley wrote: > Consider the following in conjunction with the charge controller. I'm > limited to day-VFR, and my bladder keeps my flying legs down to 2 hours. > My running current draw is somewhere down around 10 amps. With a couple of > these plastered to the top of my wings, and a battery appropriately sized > for a couple hours of runtime, would I EVER run out of electrons before > fuel? At around $110, these would definitely be cheaper than a mechanica l > electron pusher. Without relays and crowbars, et. al., I would expect th e > wiring to be MUCH simpler. The weight is quoted as "less than 5 lbs", so > lighter than all but the smallest of generators (?). > > This would be a major departure from years of lessons learned in the > aircraft community, but. . . > > > WindyNation 100 Watt 12V Flexible Solar Panel with Monocrystalline Solar > Cells | eBay > > > $114.99 > WindyNation 100 Watt 12V Flexible Solar Panel with Monocrystalline Solar. .. > > WindyNation 1 00Watt (12 volt) Flexible Monocyrstalline Solar Panel with > Monocrystalline Solar Cells. WindyNatio... > > > > > nuckolls.bob(at)aeroelectric.com> wrote: > > > eBay thing 183558004137 > > It would appear that this specific one works with a sun-based contributio n > of 6 to 18 > > volts. There are unquestionably some shabby reasonable choices accessible > for the > > Do-It-Yourselfer.=C3=AF=C2=C2=BD Much more are accessible for Lithium batteries. > > > These do look intereseting . . . I've got > some on order. > > > Bob . . . > ________________________________________________________________________________
Date: Jan 28, 2019
Thanks for the information. There is also a noise filter on the lead from the control switch to the (I) terminal on the regulator. They must not do any harm since the radio is clear. I'll just leave well enough alone. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487331#487331 ________________________________________________________________________________
Subject: Connectors
Date: Jan 29, 2019
Hi Guys I've been given a batch of these connectors, does anyone know any details, do they get squeezed (the metal connector is quit strong, but if so what squeezer is used) or they for soldering - the wire size is about 20/22awg. Regards John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487346#487346 Attachments: http://forums.matronics.com//files/thumbnail_img_1174_152.jpg ________________________________________________________________________________
Date: Jan 29, 2019
Subject: Re: Connectors
John Those are not connectors. The upper ones are crimping butt splicers, to join 2 wires by crimping them. The lower ones are heat-shrink splicers, to join wires by inserting them inside and apply heat till they shrink and hold the wires Regards Carlos Enviado do meu iPhone No dia 29/01/2019, s 15:09, John M Tipton escreveu: > > Hi Guys > > I've been given a batch of these connectors, does anyone know any details, do they get squeezed (the metal connector is quit strong, but if so what squeezer is used) or they for soldering - the wire size is about 20/22awg. > > Regards > > John > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=487346#487346 > > > > > Attachments: > > http://forums.matronics.com//files/thumbnail_img_1174_152.jpg > > > > > > ________________________________________________________________________________
Date: Jan 29, 2019
Like I said, our current systems are built on a lifetime of experience.=C2 - This is new technology that was not even thought of when many of the sy stems we take for granted were designed.=C2- Taking advantage of them saf ely will require extensive analysis of all costs vs benefits. One question that comes to mind is, "Is it acceptable to manage battery lif e in the same way we manage fuel in the tank?" l.com> wrote: Keep in mind that output is highly dependent upon sun angle (time of year, time of day) and cloud cover. On Mon, Jan 28, 2019 at 12:37 PM Ernest Christley wrot e: Consider the following in conjunction with the charge controller.=C2- I' m limited to day-VFR, and my bladder keeps my flying legs down to 2 hours. =C2- My running current draw is somewhere down around 10 amps.=C2- With a couple of these plastered to the top of my wings, and a battery appropri ately sized for a couple hours of runtime, would I EVER run out of electron s before fuel?=C2- At around $110, these would definitely be cheaper than a mechanical electron pusher.=C2- Without relays and crowbars, et. al., I would expect the wiring to be MUCH simpler.=C2- The weight is quoted as "less than 5 lbs", so lighter than all but the smallest of generators (?). This would be a major departure from years of lessons learned in the aircra ft community, but. . . WindyNation 100 Watt 12V Flexible Solar Panel with Monocrystalline Solar Ce lls | eBay | | | | $114.99 | | | | | | | WindyNation 100 Watt 12V Flexible Solar Panel with Monocrystalline Solar... WindyNation 1 00Watt (12 volt) Flexible Monocyrstalline Solar Panel with Mo nocrystalline Solar Cells. WindyNatio... | | | uckolls.bob(at)aeroelectric.com> wrote: eBay thing 183558004137 It would appear that this specific one works with a sun-basedcontribution o f 6 to 18 volts. There are unquestionably some shabby reasonable choices accessiblefo r the Do-It-Yourselfer.=C3=AF=C2=C2=BD Much more are accessible for Lithiumbat teries. =C2- These do look intereseting . . . I've got =C2- some on order. =C2- Bob . . . ________________________________________________________________________________
Subject: Charging System Capacitors
Date: Jan 29, 2019
Hi Bob et al. My '76 Cessna Cardinal has three capacitors in the charging system. I'm wondering if all of these are still considered part of theconventional wisdom, or how that has evolved over time. 1) There's an alternator output capacitor on the back of the alternator, such as this from Aircraft Spruce: https://www.aircraftspruce.com/catalog/elpages/lsAlternatorfilter.php?clickkey=21026 That seems harmless enough. 2) There's a capacitor across the overvoltage relay sensor, on the regulator INPUT line, between the 5 amp field circuit breaker and the alternator half of the master switch. Some Cardinal folks have reported removing that capacitor, in conjunction with removing the OV relay in favor of a regulator that has integral OV protection, increases the likelihood of nuisance OV trips of the regulator. 3) There's a capacitor on the regulator OUTPUT to the field terminal of the alternator, mounted on the firewall in a metal box. I'm not sure these regulator-field-output filter capacitors are now considered good practice. Here's some John Schwaner tips on charging system filtering. https://www.avweb.com/news/maint/182896-1.html What's the current wisdom on these three capacitors? They occasionally explode for a variety of capacitor-deterioration reasons. Paul ________________________________________________________________________________
Subject: Connectors
Date: Jan 29, 2019
John, They are a type of butt splice. See RS part no 712-2359 or TE Connectivity 6-1195131-3. If the stripes are red they are for 22 to 20awg (or possibly 18awg) wire. The heat shrink goes over one of the wires, then crimp on the metal part to each wire. An open side crimper is required, such as https://uk.rs-online.com/web/p/products/4445693/, but they can be expensive... They are smaller diameter than the conventional PIDG butt splice. Peter -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com On Behalf Of John M Tipton Sent: 29 January 2019 15:10 Subject: AeroElectric-List: Connectors --> Hi Guys I've been given a batch of these connectors, does anyone know any details, do they get squeezed (the metal connector is quit strong, but if so what squeezer is used) or they for soldering - the wire size is about 20/22awg. Regards John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487346#487346 Attachments: http://forums.matronics.com//files/thumbnail_img_1174_152.jpg ________________________________________________________________________________
Subject: BendixKing KX-155 repair help
Date: Jan 29, 2019
My ancient KX-155 quit suddenly and it's not just the display -- the unit went totally dead while in use. Opening it up I found a blown 10A fuse but replacing it did no good. The unit tries to draw enough current to blow a replacement fuse (but I'm limiting the input current to prevent that). The four large electrolytic capacitors look good (not physically puffed out) and there's no sign of a smoked component. IMO it's not worth putting more than $100 into it so taking it to an avionics shop is not an attractive option. But perhaps I can repair it myself assuming it doesn't need a part made of Unobtanium (like the display). I have a connector wiring diagram but no schematic or service manual. So my question is where do I go from here? Has anyone on this forum poked around in a KX-155 and can offer some suggestions? Thanks, Joe, Independence, OR -------- RV-8A Independence, OR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487358#487358 ________________________________________________________________________________
Date: Jan 30, 2019
Subject: Re: BendixKing KX-155 repair help
At 06:30 PM 1/29/2019, you wrote: > >My ancient KX-155 quit suddenly and it's not just the display -- the >unit went totally dead while in use. > >Opening it up I found a blown 10A fuse but replacing it did no >good. The unit tries to draw enough current to blow a replacement >fuse (but I'm limiting the input current to prevent that). > >The four large electrolytic capacitors look good (not physically >puffed out) and there's no sign of a smoked component. > >IMO it's not worth putting more than $100 into it so taking it to an >avionics shop is not an attractive option. But perhaps I can repair >it myself assuming it doesn't need a part made of Unobtanium (like >the display). > >I have a connector wiring diagram but no schematic or service manual. > >So my question is where do I go from here? Has anyone on this forum >poked around in a KX-155 and can offer some suggestions? I've not had the pleasure of adding the KX155 service manual to the archives on AeroElectric.com but there is a manual for the KX165 . . . have no idea how much similarity might exist between these two radios but you a welcome to dowload http://www.aeroelectric.com/Installation_Data/Bendix-King/KX165A_SM.pdf and compare with what you have in hand. Bob . . . ________________________________________________________________________________
Date: Jan 30, 2019
eFlightmanuals.com has the manual for the 155 for $104 as a download. On Jan 30, 2019, at 10:22 AM, Robert L. Nuckolls, III wrote: At 06:30 PM 1/29/2019, you wrote: > > My ancient KX-155 quit suddenly and it's not just the display -- the unit went totally dead while in use. > > Opening it up I found a blown 10A fuse but replacing it did no good. The unit tries to draw enough current to blow a replacement fuse (but I'm limiting the input current to prevent that). > > The four large electrolytic capacitors look good (not physically puffed out) and there's no sign of a smoked component. > > IMO it's not worth putting more than $100 into it so taking it to an avionics shop is not an attractive option. But perhaps I can repair it myself assuming it doesn't need a part made of Unobtanium (like the display). > > I have a connector wiring diagram but no schematic or service manual. > > So my question is where do I go from here? Has anyone on this forum poked around in a KX-155 and can offer some suggestions? I've not had the pleasure of adding the KX155 service manual to the archives on AeroElectric.com but there is a manual for the KX165 . . . have no idea how much similarity might exist between these two radios but you a welcome to dowload http://www.aeroelectric.com/Installation_Data/Bendix-King/KX165A_SM.pdf and compare with what you have in hand. Bob . . . ________________________________________________________________________________
Date: Jan 31, 2019
wrote: At 06:30 PM 1/29/2019, you wrote: --> AeroElectric-List messageposted by: "jdubner" My ancient KX-155 quit suddenly and it's not just the display -- theunit=C2 - went totally dead while in use. Opening it up I found a blown 10A fuse but replacing it did nogood.=C2- T he unit tries to draw enough current to blow a replacementfuse (but I'm lim iting the input current to prevent that). The four large electrolytic capacitors look good (not physically puffedout) and there's no sign of a smoked component. IMO it's not worth putting more than $100 into it so taking it to anavionic s shop is not an attractive option.=C2- But perhaps I can repairit myself assuming it doesn't need a part made of Unobtanium (like thedisplay). I have a connector wiring diagram but no schematic or servicemanual. So my question is where do I go from here?=C2- Has anyone on this forumpo ked around in a KX-155 and can offer somesuggestions? =C2-I've not had the pleasure of adding the KX155 service =C2-manual to the archives on AeroElectric.com but there =C2-is a manual for the KX165 . . . have no idea how =C2-much similarity might exist between these two =C2-radios but you a welcome to dowload http://www.aeroelectric.com/Installation_Data/Bendix-King/KX165A_SM.pdf =C2-and compare with what you have in hand. =C2- Bob . . . Thank you, Bob.=C2- I did download the KX165 maintenance manual and alas, the innards of the radio are quite different, especially in the physical l ayout and power supply area. I've come to learn there are differences in the various KX-155s out there t oo: KX155, KX155 TSO, KX155A, and differences by serial number. As an aside, the KX165 is newer than my KX155 but even so, it references DO S for software updates and a 68HC16 microcontroller.=C2- Takes me back! ________________________________________________________________________________
Date: Jan 31, 2019
> > >Thank you, Bob. I did download the KX165 maintenance manual and >alas, the innards of the radio are quite different, especially in >the physical layout and power supply area. > >I've come to learn there are differences in the various KX-155s out >there too: KX155, KX155 TSO, KX155A, and differences by serial number. Well . . . fooey . . . >As an aside, the KX165 is newer than my KX155 but even so, it >references DOS for software updates and a 68HC16 >microcontroller. Takes me back! Yeah. Cut my assembler teeth on an AIM65 (6500) which offered an easy transition to 6800 series devices. Wrote the code for a number of $killo$ projects on the AIM then moved to Motorola assemblers running in MSDos . . . those were heady days! I've still got a home brew glass-top eprom cleaner around here somewhere. Bob . . . ________________________________________________________________________________
Subject: Overvoltage protection and other stuff
Date: Feb 01, 2019
Bob et al. Im working with my engineering representative to modify a TC aircraft to replace a 28V Gill flooded battery with a pair of 12V Odyssey AGM in a different location. The new location while not sealed, is not provided with ventilation to the outside. Todays task is to demonstrate the new installation will comply with 23.1353(d) which reads: "No explosive or toxic gases emitted by any battery in normal operation, or as the result of any probable malfunction in the charging system or battery installation, may accumulate in hazardous quantities within the airplane. After conversation with Odyssey and after reading their and other technical material I am happy to argue that the only probable malfunction in the charging system or battery installation that could result in a release of a hazardous quantity of gas would be a prolonged over-voltage event (>30V for the two batteries in series). That would release some quantity of hydrogen. The aircraft charging system is based on a Bosch 28V automotive alternator; I dont have any technical details of whether it has any inbuilt over-voltage protection. The Approved Flight Manual indicates that an over-voltage condition has to be noticed by the pilot and pilot action is required to take the alternator off-line manually by pulling the c/b. So its probable theres no automatic protection included. To demonstrate that Im compliant with 23.1353(d) Im thinking of including in the modification the installation of a crowbar protection module on the alternator field coil. So to get to the question can anyone suggest a part number/supplier for a 28V OV module (30V trigger voltage)? Ideally one that is already in use on a TC airplane somewhere, which will make it easier to have that part approved as part of the modification. Or are there any other ways I could provide comfort with respect to 23.1353? Thanks for any ideas ________________________________________________________________________________
Subject: Re: Overvoltage protection and other stuff
Date: Feb 01, 2019
Check out Aircraft Spruce. https://www.aircraftspruce.com/catalog/eppages/zeftronicsreg2.php?clickkey=12338 -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487379#487379 ________________________________________________________________________________
Date: Feb 01, 2019
You could also check with B&C to see if this one includes OV protection. http://www.bandc.aero/alternatorcontrollerregulator14vhomebuilt-1.aspx On 2/1/2019 6:29 PM, user9253 wrote: > > Check out Aircraft Spruce. > https://www.aircraftspruce.com/catalog/eppages/zeftronicsreg2.php?clickkey=12338 > > -------- > Joe Gores > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Subject: 555088-160 Air Jordan 1 Retro High OG Sail Red
Date: Feb 02, 2019
It seems that this year's sneakers still can't escape the "Devil's Palm" of Air Jordan 1! Today, we just ushered in the release of the first Air Jordan 1 in 2019, and another new color scheme has surfaced! (https://www.2019mensjordans.com/product-category/air-jordan-1/)Air Jordan 1 Retro High OG Sail Red uses an extraordinarily vibrant white and red color. The white leather upper is complemented by red details and car lines. It also has a "two yuan" brush style! Flying wing logo, tongue embroidery label, this classic element is available, standard OG first year details. It will be officially released on March 16th, whether it is directly on the foot to cater to the bright sunshine in spring, or used for custom-made shoes, all of them are of good quality! Jordans 2019 Shoes (https://www.jordans2019shoes.com),Since the second half of last year, there have been a number of Foamposite foam materials to create the AF1 debut, and this time it is a high-top style! The Nike Air Force 1 Foamposite Cup NA Red is not only a unique bubble material, but also a dazzling all-red dress. Even the AF1 high-top shoe-shaped ankle straps are preserved. Although it is a pure red tone, the gloss effect of the upper and the matching of different materials still have a good visual level. In addition to the recent Tianjin spray theme, the Nike Sneakers (https://www.2019sneakersrelease.com/product-category/nike-sneakers/) brings us another surprise Nike Air Max 98, which is the white and red color. Similar to the Supreme sky-price co-branded style, this pair of Nike Air Max 98 is decorated with vibrant red in a white background. It is absolutely versatile and full of energy, making it easy to create a vibrant and energetic effect. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487384#487384 ________________________________________________________________________________
Date: Feb 02, 2019
At 03:43 PM 2/1/2019, you wrote: > >Bob et al. > >I=99m working with my engineering representative >to modify a TC aircraft to replace a 28V Gill >flooded battery with a pair of 12V Odyssey AGM in a different location. >The new location while not =9Csealed=9D, is not >provided with ventilation to the outside. > >Today=99s task is to demonstrate the new >installation will comply with 23.1353(d) which reads: >"No explosive or toxic gases emitted by any >battery in normal operation, or as the result of >any probable malfunction in the charging system >or battery installation, may accumulate in >hazardous quantities within the airplane.=9D There HAVE been H-O explosions associated with SVLA batteries. The only two I've been privy to were (1) an internal explosion on a 44AH bizjet battery that suffered an open, inter-cell weld in the top of the battery. The explosion cracked the case but did not cause damage to the aircraft. A second case was in a GlasAir fitted with a battery box behind the passenger seat. The battery contactor was inside the box too. The battery had been subjected to a sustained ov condition. The pilot was engaged in some exploratory, switch-flipping diagnostics that ignited the trapped gasses inside the battery box and blew it up. The WORST policy for dealing with an outgassing battery is to enclose it. The battery box was originally intended to conduct SPILLS over overboard. It had nothing to do with venting of gasses. The abused SLVA battery is LEAST likely to provoke a bad day in the cockpit by strapping it down to an open tray. Any dangerous gasses that do escape the battery simply waft away. Explosions occur when fuel is ignited within a tightly closed space. If 'fuel' is generated by an abused battery, the best prophylactic against explosion is to let it waft way. It won't explode or burn even if you ARE a smoker. >After conversation with Odyssey and after >reading their and other technical material I am >happy to argue that the only =9Cprobable=9D >malfunction in the charging system or battery >installation that could result in a release of a >hazardous quantity of gas would be a prolonged >over-voltage event (>30V for the two batteries >in series). That would release some quantity of hydrogen. Not the point. Proper conduct of FMEA considers ONLY one failure at a time. Assume that the battery WILL be abused as some point in the future. Then eliminate probability that the failure escalates into a more excited situation or propagation out to the rest of the system. Strap it down in the open air and you're good to go. >The aircraft charging system is based on a Bosch >28V automotive alternator; I don=99t have any >technical details of whether it has any inbuilt >over-voltage protection. The Approved Flight >Manual indicates that an over-voltage condition >has to be noticed by the pilot and pilot action >is required to take the alternator off-line >manually by pulling the c/b. So it=99s probable >there=99s no automatic protection included. > >To demonstrate that I=99m compliant with >23.1353(d) I=99m thinking of including in the >modification the installation of a crowbar >protection module on the alternator field coil. > >So=85 to get to the question=85 can anyone suggest a >part number/supplier for a 28V OV module (30V >trigger voltage)? Ideally one that is already in >use on a TC airplane somewhere, which will make >it easier to have that part approved as part of the modification. >. > >Or are there any other ways I could provide comfort with respect to 23.1353? Adding ov protection is called for by FMEA on the alternator irrespective of any other components on the aircraft. For decades, builders and some manufactures have modified internally regulated alternators to (1) remove internal regulators and (2) install legacy regulator/ov protection. I'll suggest that the confident fast-track is to do that mod to the alternator and install a regulator qualified for TC aircraft like https://tinyurl.com/yb6o5vtn or for OBAM aircraft https://tinyurl.com/y9tlkpyo Depending on your airplane's station in the aviation hierarchy. Both of these examples will come with OV protection . . . the B&C product also offers OV annunciation. Bob . . . ________________________________________________________________________________
Date: Feb 02, 2019
> Strap it down in the open air and you're good to go. It is (they are) going to be located under the seat. The airframe is composite, and the seat frame is part of the airframe, forming a well, but the seat top doesnt seal tight, so lets assume that that the seat void is adequately ventilated for lighter-than-air gas to the rest of the cabin. Being a modern airframe, the cabin is relatively leak and draught free. The bubble canopy seals well with a rubber cushion all the way around. When the cabin ventilation system is shut off, there are no draughts. The lower explosive limit for Hydrogen is 4%. Taking a factor of 4 safety, and assuming a cabin volume of 3m^3, a hazardous amount of H2 is 30 litres. Outgassing from all lead acid batteries during a significant over voltage event is 7.6ml H2 / cell / amp / minute. RG technology works great to reduce outgassing at low charge rates but isnt a lot of use at high currents. The alternator is fitted with a 30A breaker. The worst case continuous release of hydrogen would occur when the alternator produces a voltage sufficient to charge the already-charged battery with a current of exactly 30A. Any more and the breaker will trip. There are 12 cells between the two batteries. That means that the worst case production of H2 is 2.7 litres / minute. A hazardous environment would follow, for regulatory purposes, in approximately 10-15 minutes, assuming no ventilation. I am *not* permitted to assume that the pilot will take the appropriate corrective action within that period and shut down the alternator. If I want to claim that the level of cabin ventilation is guaranteed to vent hydrogen at a rate sufficient to prevent buildup of 30l of H2 in that sort of time frame, I will have to justify that with adequate data. Alternatively if there is an over-voltage trip that prevents the bus voltage rising above 32V, then the battery would have to be limiting the overcharging current to less than 4A. The time to a hazardous buildup of H2 in the cabin would be 7.5 times greater, or more than one hour. At a current of 4A, I can carry out an experiment with the proposed battery and a power supply in the actual aircraft in a hangar, in still air conditions, to measure the cabin H2 concentration rate of rise. (I dont think I could find a power supply with sufficient voltage overhead to force 30A through a lead acid battery, nor would I feel comfortable doing so.) Another way to satisfy regulatory requirement is to use a Concorde RG-11M that has a manifold and a vent tube. I can connect the vent tube to the original vent provided for the flooded battery, and the requirement is satisfied because all gas will vent to the outside. The disadvantages are that its a lot more expensive than two odyssey batteries. And at 27lbs, harder to mount. >> I'll suggest that the confident fast-track is to do that mod to the alternator and install a regulator qualified for TC aircraft like There is merit in this idea, but I am concerned about project creep. To the extent that the existing IR alternator passed certification, its not an absolute requirement to upgrade it. On Feb 2, 2019, at 10:36 AM, Robert L. Nuckolls, III wrote: At 03:43 PM 2/1/2019, you wrote: > > Bob et al. > > Im working with my engineering representative to modify a TC aircraft to replace a 28V Gill flooded battery with a pair of 12V Odyssey AGM in a different location. > The new location while not sealed, is not provided with ventilation to the outside. > > Todays task is to demonstrate the new installation will comply with 23.1353(d) which reads: > "No explosive or toxic gases emitted by any battery in normal operation, or as the result of any probable malfunction in the charging system or battery installation, may accumulate in hazardous quantities within the airplane. There HAVE been H-O explosions associated with SVLA batteries. The only two I've been privy to were (1) an internal explosion on a 44AH bizjet battery that suffered an open, inter-cell weld in the top of the battery. The explosion cracked the case but did not cause damage to the aircraft. A second case was in a GlasAir fitted with a battery box behind the passenger seat. The battery contactor was inside the box too. The battery had been subjected to a sustained ov condition. The pilot was engaged in some exploratory, switch-flipping diagnostics that ignited the trapped gasses inside the battery box and blew it up. The WORST policy for dealing with an outgassing battery is to enclose it. The battery box was originally intended to conduct SPILLS over overboard. It had nothing to do with venting of gasses. The abused SLVA battery is LEAST likely to provoke a bad day in the cockpit by strapping it down to an open tray. Any dangerous gasses that do escape the battery simply waft away. Explosions occur when fuel is ignited within a tightly closed space. If 'fuel' is generated by an abused battery, the best prophylactic against explosion is to let it waft way. It won't explode or burn even if you ARE a smoker. > After conversation with Odyssey and after reading their and other technical material I am happy to argue that the only probable malfunction in the charging system or battery installation that could result in a release of a hazardous quantity of gas would be a prolonged over-voltage event (>30V for the two batteries in series). That would release some quantity of hydrogen. Not the point. Proper conduct of FMEA considers ONLY one failure at a time. Assume that the battery WILL be abused as some point in the future. Then eliminate probability that the failure escalates into a more excited situation or propagation out to the rest of the system. Strap it down in the open air and you're good to go. > The aircraft charging system is based on a Bosch 28V automotive alternator; I dont have any technical details of whether it has any inbuilt over-voltage protection. The Approved Flight Manual indicates that an over-voltage condition has to be noticed by the pilot and pilot action is required to take the alternator off-line manually by pulling the c/b. So its probable theres no automatic protection included. > > To demonstrate that Im compliant with 23.1353(d) Im thinking of including in the modification the installation of a crowbar protection module on the alternator field coil. > > So> to get to the question> can anyone suggest a part number/supplier for a 28V OV module (30V trigger voltage)? Ideally one that is already in use on a TC airplane somewhere, which will make it easier to have that part approved as part of the modification. > . > > Or are there any other ways I could provide comfort with respect to 23.1353? Adding ov protection is called for by FMEA on the alternator irrespective of any other components on the aircraft. For decades, builders and some manufactures have modified internally regulated alternators to (1) remove internal regulators and (2) install legacy regulator/ov protection. I'll suggest that the confident fast-track is to do that mod to the alternator and install a regulator qualified for TC aircraft like https://tinyurl.com/yb6o5vtn or for OBAM aircraft https://tinyurl.com/y9tlkpyo Depending on your airplane's station in the aviation hierarchy. Both of these examples will come with OV protection . . . the B&C product also offers OV annunciation. Bob . . . ________________________________________________________________________________
Date: Feb 02, 2019
On Sat, Feb 2, 2019 at 2:04 PM Alec Myers wrote: > It is (they are) going to be located under the seat. The airframe is > composite, and the seat frame is part of the airframe, forming a well, bu t > the seat top doesn=99t seal tight, Alec, How about a low tech solution? Add a small vent from the well to the outside of the fuselage so that, whenever the airplane is in motion, low pressure on the outside draws air past the seat top, past the batteries, and out. -- Art Z. -- https://CheerfulCurmudgeon.com/ *"Be kind, for everyone you meet is fighting a hard battle."* ________________________________________________________________________________
Date: Feb 02, 2019
I love low-tech! I dont think thats definitive enough for the powers that be, however. And I dont think my structures person will enjoy me drilling holes in a composite stressed fuselage just for a look see. On the subject of over-voltage trips, I have discovered that both Carling and Sensata (Klixon) make circuit breakers with, for instance, a second coil that you can use to trip the breaker via an isolated circuit (that could easily be triggered by an over-voltage, in addition to the regular over-current coil. So one of those could be used to replace the b-lead CB. It will be a challenge to find small quantities of what is a very specialized part though. On Feb 2, 2019, at 5:42 PM, Art Zemon wrote: On Sat, Feb 2, 2019 at 2:04 PM Alec Myers wrote: It is (they are) going to be located under the seat. The airframe is composite, and the seat frame is part of the airframe, forming a well, but the seat top doesnt seal tight, Alec, How about a low tech solution? Add a small vent from the well to the outside of the fuselage so that, whenever the airplane is in motion, low pressure on the outside draws air past the seat top, past the batteries, and out. -- Art Z. -- https://CheerfulCurmudgeon.com/ "Be kind, for everyone you meet is fighting a hard battle." ________________________________________________________________________________
Date: Feb 03, 2019
Subject: John Deere Generator pulses
I'm using the pulses from my John Deere generator for my tack signal into m y EIS.=C2- Everything is working fine, and I've got a good solid signal. =C2- However, I'm not positive that I have it calibrated correctly.=C2- If someone with a JD generator that isn't mounted could tell me how many p ulses it makes for each revolution, I'd be very thankful. ________________________________________________________________________________
Subject: Narco Com-11 sidetone
Date: Feb 02, 2019
Anyone know if the Narco com-11 had sidetone? -------- Ken W. N804RV(reserved) RV-8 Empennage in work Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487398#487398 ________________________________________________________________________________
Subject: Re: John Deere Generator pulses
Date: Feb 02, 2019
What kind of engine? Is the generator gear driven or belt driven? How about using an optical tachometer to compare to the EIS? -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487401#487401 ________________________________________________________________________________
Date: Feb 02, 2019
Here's what they are:https://youtu.be/XD1JDk1tCj4 This is the crimper you need to do it right: https://www.skygeek.com/dmc-tools-gmt232-commercial-crimp-tool-ad-1377.html?utm_source=googlebase&utm_medium=shoppingengine&utm_content=dmc-tools-gmt232-commercial-crimp-tool-ad-1377&utm_campaign=froogle&gclid=Cj0KCQiAnNXiBRCoARIsAJe_1cqpHgVAOlO0Ex-17snk3-lP0mvnmXVpE2YwSNUGU0P1KG_mrkt7ougaAgj7EALw_wcB -------- Ken W. N804RV(reserved) RV-8 Empennage in work Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487403#487403 ________________________________________________________________________________
Date: Feb 03, 2019
At 01:46 PM 2/2/2019, you wrote: > > > Strap it down in the open air and you're > good to go. > >It is (they are) going to be located under the >seat. The airframe is composite, and the seat >frame is part of the airframe, forming a well, >but the seat top doesn=99t seal tight, so >let=99s assume that that the seat void is >adequately ventilated for lighter-than-air gas >to the rest of the cabin. Being a modern >airframe, the cabin is relatively leak and >draught free. The bubble canopy seals well with >a rubber cushion all the way around. When the >cabin ventilation system is shut off, there are no draughts. >The alternator is fitted with a 30A breaker. The >worst case continuous release of hydrogen would >occur when the alternator produces a voltage >sufficient to charge the already-charged battery >with a current of exactly 30A. Any more and the breaker will trip. B-lead protection should not be so small as to be vulnerable to trip from alternator output . . . b-lead protection is located at the battery end of the b-lead feeder and intended to mitigate shorts in the alternator that are fed from the battery . . . >There are 12 cells between the two batteries. >That means that the worst case production of H2 >is 2.7 litres / minute. A hazardous environment >would follow, for regulatory purposes, in >approximately 10-15 minutes, assuming no ventilation. Can't argue the numbers based on what I have immediately in hand. I need to dig through the archives and see what I gathered from some studies at both Hawker-Enersys and Concorde waaayyy back when. >At a current of 4A, I can carry out an >experiment with the proposed battery and a power >supply in the actual aircraft in a hangar, in >still air conditions, to measure the cabin H2 >concentration rate of rise. (I don=99t think I >could find a power supply with sufficient >voltage overhead to force 30A through a lead >acid battery, nor would I feel comfortable doing so.) An SVLA battery is also referred to as a 'starved electrolyte' battery. This refers to the fact that a design goal is to minimize the water it contains. The separators are tissue thin and about 90% saturated with electrolyte. If you disassembled a new battery and wrung out a separator with your fingers, you would be unable to produce liquid. Electrolyte is added to cells at Enersys by an automated process that injects precise amounts into each cell in order to achieve that 90% number. At Concorde, I saw cells being 'topped off' with liquid and left to stand for a period of time before the batteries were turned over and allowed to drain before the pressure relief caps were installed. Again, a technique intended to limit the amount of retained water. I'll have to find the data but I think there is so little water in the typical SE battery that risks from an H2 + 0 explosion in anything but the smallest of containments is essentially zero. Battery explosions I'm aware of and those cited on 'net are INTERNAL to the battery; a product of some external energy source combined with a failure internal to the battery. If we're going to mitigate that failure mode, then yes, a MECHANICALLY robust container is called for. An SVLA battery in overcharge distress is not limited too dissolution of the water into H and O. There is chemical conversion and I(squared)R heat generated. When an SVLA battery begins to vent, no doubt there will be some free hydrogen but other constituents that smell really bad. An alternator runaway in flight still has some system loads in addition to the battery's over-charge loads which reduces the alternator's ability to abuse the battery. A lightly loaded 60A alternator in runaway pushes the battery up into the 17-18 volt range whereupon the battery grunts the overcharge begins its death throes. The 20v for 1 second withstand rule for 14v avionics recognizes that it takes time for a battery-mitigated ov condition to evolve. Plenty of time for an ov management system to operate. But assuming that the fault is allowed to go to completion, it takes many minutes and produces noxious vapors. Many pilots who experienced uncontrolled runaways for batteries mounted behind the cabin report their first awareness of the condition by the smell that managed to get forward. I'm having trouble wrapping my head around the idea that the worst possible failure in the charging system would even begin to risk blowing up a cabin dangerously charged with hydrogen. > >> I'll suggest that the confident fast-track > is to do that mod to the alternator and install > a regulator qualified for TC aircraft like > >There is merit in this idea, but I am concerned >about project creep. To the extent that the >existing IR alternator passed certification, >it=99s not an absolute requirement to upgrade it. Not a requirement. Just a simple duplication of a process that was experimentally derived and repeated thousands of times over the past 30+ years. It's one of several recipes for success to meet the design goal. Bob . . . ________________________________________________________________________________
Date: Feb 03, 2019
At 06:19 PM 2/2/2019, you wrote: > >I love low-tech! I don=99t think that=99s >definitive enough for the powers that be, >however. And=85 I don=99t think my structures >person will enjoy me drilling holes in a >composite stressed fuselage just for a look see. >On the subject of over-voltage trips, I have >discovered that both Carling and Sensata >(Klixon) make circuit breakers with, for >instance, a second coil that you can use to trip >the breaker via an isolated circuit (that could >easily be triggered by an over-voltage, in >addition to the regular over-current coil. So >one of those could be used to replace the b-lead >CB. It will be a challenge to find small >quantities of what is a very specialized part though. I proposed an ov protection system that was based on the external trip feature for some magnetic breakers . . . I think it was for Swearingen Aircraft. The cost-benefit ratio didn't ring their bells either. Further, doing ov protection in the B-lead is less than optimum. That's a VERY HIGH ENERGY switching event that would continue to produce voltage and ultimately destroy the alternator too. Opening the field circuit has been the legacy approach since the first generators were strapped to aircraft engines. Bob . . . ________________________________________________________________________________
Date: Feb 03, 2019
At 10:19 AM 2/3/2019, you wrote: >At 01:46 PM 2/2/2019, you wrote: >> >> > Strap it down in the open air and you're >> good to go. >> >>It is (they are) going to be located under the >>seat. The airframe is composite, and the seat >>frame is part of the airframe, forming a well, >>but the seat top doesn=99t seal tight, so >>let=99s assume that that the seat void is >>adequately ventilated for lighter-than-air gas >>to the rest of the cabin. Being a modern >>airframe, the cabin is relatively leak and >>draught free. The bubble canopy seals well with >>a rubber cushion all the way around. When the >>cabin ventilation system is shut off, there are no draughts. If one is hard-over with out-gassing concerns, it's possible to add your own vent plumbing to most batteries. A PC-680 has a 'manifold" that just doesn't happen to have a vent connection Emacs! You could drill a hole though the vent gallery cover and bond a tube fitting to the lid. Then add length of Tygon or similar to conduct vented gasses anywhere else you wished to go . . . perhaps to the extreme end of the empennage? If there are two batteries, the tubes could be Y-ed into a single tube for remote disposal of the gasses. You might add some robust sealant around the periphery of the gallery cap . . . E6000 would be good. The collection of pictures at . . . https://tinyurl.com/blt9x3l illustrates some extreme effects of overcharge wherein excess energy produced effects in addition to generating explosive gasses. I'll keep digging in the library . . . Bob . . . ________________________________________________________________________________
Date: Feb 03, 2019
At 08:27 PM 2/2/2019, you wrote: > >What kind of engine? >Is the generator gear driven or belt driven? >How about using an optical tachometer to compare to the EIS? Agreed. There are a number of low-cost, laser tachs that are quite accurate. Here is one example. https://tinyurl.com/y76qb9w6 This one's sensing distance is rated at 500mm (about 20") but it can be a lot greater. Put strips of aluminum duct tape on the back side of the blades and use the tach on a dark ramp. I think you find that you can read the blade passes quite well. You only need to check at one speed . . . digital sensing is exceedingly linear! Engine idle would suffice. Bob . . . ________________________________________________________________________________
Date: Feb 03, 2019
Thats a possibility I already have an overboard vent from the original installation of the (flooded) Gill battery. If I go the $$$ route and install the Concorde RG version it has a manifold I was planning to run a tube to it. Do you have any data about what happened to that Odyssey? On the subject of over voltage tripping, I was looking through the technical literature for (eg) On Feb 3, 2019, at 11:49 AM, Robert L. Nuckolls, III wrote: At 10:19 AM 2/3/2019, you wrote: > At 01:46 PM 2/2/2019, you wrote: >> >> > Strap it down in the open air and you're >> good to go. >> >> It is (they are) going to be located under the seat. The airframe is composite, and the seat frame is part of the airframe, forming a well, but the seat top doesnt seal tight, so lets assume that that the seat void is adequately ventilated for lighter-than-air gas to the rest of the cabin. Being a modern airframe, the cabin is relatively leak and draught free. The bubble canopy seals well with a rubber cushion all the way around. When the cabin ventilation system is shut off, there are no draughts. If one is hard-over with out-gassing concerns, it's possible to add your own vent plumbing to most batteries. A PC-680 has a 'manifold" that just doesn't happen to have a vent connection <194a8106.jpg> You could drill a hole though the vent gallery cover and bond a tube fitting to the lid. Then add length of Tygon or similar to conduct vented gasses anywhere else you wished to go . . . perhaps to the extreme end of the empennage? If there are two batteries, the tubes could be Y-ed into a single tube for remote disposal of the gasses. You might add some robust sealant around the periphery of the gallery cap . . . E6000 would be good. The collection of pictures at . . . https://tinyurl.com/blt9x3l illustrates some extreme effects of overcharge wherein excess energy produced effects in addition to generating explosive gasses. I'll keep digging in the library . . . Bob . . . ________________________________________________________________________________
Date: Feb 03, 2019
I have designed and built an optical tach for checking prop speed, using a PIC, a photodiode, and a four digit LED display. You point it out of the window through the prop disc as you fly along It=99s the size of (and runs from) a pair of AA batteries. You can use it for checking a drill speed too if you put two pieces of silver tape on the chuck. Total part cost is about $7. It shows what you can start to do with a $1 micro controller. Do you think the list would like it as a build-it-yourself project? It=99s a good intro to SMT soldering. On Feb 3, 2019, at 1:17 PM, Robert L. Nuckolls, III wrote: At 08:27 PM 2/2/2019, you wrote: > > What kind of engine? > Is the generator gear driven or belt driven? > How about using an optical tachometer to compare to the EIS? Agreed. There are a number of low-cost, laser tachs that are quite accurate. Here is one example. https://tinyurl.com/y76qb9w6 This one's sensing distance is rated at 500mm (about 20") but it can be a lot greater. Put strips of aluminum duct tape on the back side of the blades and use the tach on a dark ramp. I think you find that you can read the blade passes quite well. You only need to check at one speed . . . digital sensing is exceedingly linear! Engine idle would suffice. Bob . . . ________________________________________________________________________________
Date: Feb 03, 2019
> I love low-tech! I dont think thats definitive enough for the powers that be, however. And I dont think my structures person will enjoy me drilling holes in a composite stressed fuselage just for a look see. Slightly off topic, but relevant to this thread, composite structures are very tolerant of small holes. Some airframes have reinforcing belts (uni-directional fibres, say 3" wide), as long as those are avoided a small hole for a vent pipe should be no problem from the structural perspective. Drag or aesthetically wise it may be a different story, but don't assume a composite structure behaves the same as metal! Peter -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com <owner-aeroelectric-list-server(at)matronics.com> On Behalf Of Alec Myers Sent: 03 February 2019 00:19 Subject: Re: AeroElectric-List: Overvoltage protection and other stuff I love low-tech! I dont think thats definitive enough for the powers that be, however. And I dont think my structures person will enjoy me drilling holes in a composite stressed fuselage just for a look see. On the subject of over-voltage trips, I have discovered that both Carling and Sensata (Klixon) make circuit breakers with, for instance, a second coil that you can use to trip the breaker via an isolated circuit (that could easily be triggered by an over-voltage, in addition to the regular over-current coil. So one of those could be used to replace the b-lead CB. It will be a challenge to find small quantities of what is a very specialized part though. On Feb 2, 2019, at 5:42 PM, Art Zemon wrote: On Sat, Feb 2, 2019 at 2:04 PM Alec Myers wrote: It is (they are) going to be located under the seat. The airframe is composite, and the seat frame is part of the airframe, forming a well, but the seat top doesnt seal tight, Alec, How about a low tech solution? Add a small vent from the well to the outside of the fuselage so that, whenever the airplane is in motion, low pressure on the outside draws air past the seat top, past the batteries, and out. -- Art Z. -- https://CheerfulCurmudgeon.com/ "Be kind, for everyone you meet is fighting a hard battle." ________________________________________________________________________________
Date: Feb 03, 2019
Date: Feb 04, 2019
I have the JD generator driven directly by the crank.=C2- One crank rota tion equals one generator rotation.=C2- I found a video of someone repair ing the generator, and it is obvious that there are 12 stators.=C2- So, s ix pulses per rev it is. Doing more tuning today, and got the engine running smoother.=C2- I've co nvinced myself that my tack is correct.=C2- :-) .com> wrote: I have designed and built an optical tach for checking prop speed, using a PIC, a photodiode, and a four digit LED display. You point it out of the w indow through the prop disc as you fly along It=99s the size of (and runs from) a pair of AA batteries. You can use it for checking a drill spee d too if you put two pieces of silver tape on the chuck. Total part cost is about $7. It shows what you can start to do with a $1 mi cro controller. Do you think the list would like it as a build-it-yourself project? It =99s a good intro to SMT soldering. On Feb 3, 2019, at 1:17 PM, Robert L. Nuckolls, III <nuckolls.bob@aeroelect ric.com> wrote: At 08:27 PM 2/2/2019, you wrote: --> AeroElectric-List message=C2-posted by: "user9253" What kind of engine? Is the generator gear driven or belt driven? How about using an optical tachometer to compare to the=C2-EIS? =C2- Agreed. There are a number of low-cost, =C2- laser tachs that are quite accurate. Here =C2- is one example. https://tinyurl.com/y76qb9w6 =C2- This one's sensing distance is rated at =C2- 500mm (about 20") but it can be a lot =C2- greater. =C2-Put strips of aluminum =C2- duct tape on the back side of the blades =C2- and use the tach on a dark ramp. I think =C2- you find that you can read the blade passes =C2- quite well. =C2- You only need to check at one speed . . . =C2- digital sensing is exceedingly linear! =C2- Engine idle would suffice. =C2- Bob . . . /9j/4AAQSkZJRgABAQAASABIAAD/4QPqRXhpZgAATU0AKgAAAAgACQEPAAIAAAAGAAAAegEQAAIA AAAKAAAAgAESAAMAAAABAAYAAAEaAAUAAAABAAAAigEbAAUAAAABAAAAkgEoAAMAAAABAAIAAAEx AAIAAAAHAAAAmgEyAAIAAAAUAAAAoodpAAQAAAABAAAAtgAAAABBcHBsZQBpUGhvbmUgNWMAAAAA SAAAAAEAAABIAAAAATEwLjMuMwAAMjAxOTowMjowMyAxNDoyMToxOQAAIIKaAAUAAAABAAACPIKd AAUAAAABAAACRIgiAAMAAAABAAIAAIgnAAMAAAABAKAAAJAAAAcAAAAEMDIyMZADAAIAAAAUAAAC TJAEAAIAAAAUAAACYJEBAAcAAAAEAQIDAJIBAAoAAAABAAACdJICAAUAAAABAAACfJIDAAoAAAAB AAAChJIEAAoAAAABAAACjJIHAAMAAAABAAMAAJIJAAMAAAABABgAAJIKAAUAAAABAAAClJIUAAMA AAAEAAACnJJ8AAcAAAD0AAACpJKRAAIAAAAEMTQ5AJKSAAIAAAAEMTQ5AKAAAAcAAAAEMDEwMKAB AAMAAAABAAEAAKACAAQAAAABAAABQKADAAQAAAABAAAA8KIXAAMAAAABAAIAAKMBAAcAAAABAQAA AKQCAAMAAAABAAAAAKQDAAMAAAABAAAAAKQFAAMAAAABACEAAKQGAAMAAAABAAAAAKQyAAUAAAAE AAADmKQzAAIAAAAGAAADuKQ0AAIAAAAjAAADvgAAAAAAAAABAAAAFAAAAAwAAAAFMjAxOTowMjow MyAxNDoyMToxOQAyMDE5OjAyOjAzIDE0OjIxOjE5AAAADtcAAANvAAAS7QAAB34AAA1QAAAGcQAA AAAAAAABAAAAZwAAABkG3QcVAmICZEFwcGxlIGlPUwAAAU1NAAgAAQAJAAAAAQAAAAUAAwAHAAAA aAAAAHQABAAJAAAAAQAAAAEABQAJAAAAAQAAAOcABgAJAAAAAQAAAO0ABwAJAAAAAQAAAAEACAAK AAAAAwAAANwAFAAJAAAAAQAAAAEAAAAAYnBsaXN0MDDUAQIDBAUGBwhVZmxhZ3NVdmFsdWVVZXBv Y2hZdGltZXNjYWxlEAETAACITTLK45oQABI7msoACBEXHSMtLzg6AAAAAAAAAQEAAAAAAAAACQAA AAAAAAAAAAAAAAAAAD8AABedAAF4av//rwkAALPM//9+owAAj1wAFfkKAAVVTQAV+QoABVVNAAAA DAAAAAUAAAAMAAAABUFwcGxlAGlQaG9uZSA1YyBiYWNrIGNhbWVyYSA0LjEybW0gZi8yLjQAAP/h Cg5odHRwOi8vbnMuYWRvYmUuY29tL3hhcC8xLjAvADw/eHBhY2tldCBiZWdpbj0i77u/IiBpZD0i VzVNME1wQ2VoaUh6cmVTek5UY3prYzlkIj8+IDx4OnhtcG1ldGEgeG1sbnM6eD0iYWRvYmU6bnM6 bWV0YS8iIHg6eG1wdGs9IlhNUCBDb3JlIDUuNC4wIj4gPHJkZjpSREYgeG1sbnM6cmRmPSJodHRw Oi8vd3d3LnczLm9yZy8xOTk5LzAyLzIyLXJkZi1zeW50YXgtbnMjIj4gPHJkZjpEZXNjcmlwdGlv biByZGY6YWJvdXQ9IiIgeG1sbnM6eG1wPSJodHRwOi8vbnMuYWRvYmUuY29tL3hhcC8xLjAvIiB4 bWxuczpwaG90b3Nob3A9Imh0dHA6Ly9ucy5hZG9iZS5jb20vcGhvdG9zaG9wLzEuMC8iIHhtcDpD cmVhdGVEYXRlPSIyMDE5LTAyLTAzVDE0OjIxOjE5IiB4bXA6TW9kaWZ5RGF0ZT0iMjAxOS0wMi0w M1QxNDoyMToxOSIgeG1wOkNyZWF0b3JUb29sPSIxMC4zLjMiIHBob3Rvc2hvcDpEYXRlQ3JlYXRl ZD0iMjAxOS0wMi0wM1QxNDoyMToxOSIvPiA8L3JkZjpSREY+IDwveDp4bXBtZXRhPiAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIDw/eHBhY2tldCBl bmQ9InciPz4A/+0AeFBob3Rvc2hvcCAzLjAAOEJJTQQEAAAAAAA/HAFaAAMbJUccAgAAAgACHAI/ AAYxNDIxMTkcAj4ACDIwMTkwMjAzHAI3AAgyMDE5MDIwMxwCPAAGMTQyMTE5ADhCSU0EJQAAAAAA EC/nVUT8Me1/JpeqWjiyf27/wAARCADwAUADASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAA AAECAwQFBgcICQoL/8QAtRAAAgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEI I0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlq c3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW 19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL /8QAtREAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLR ChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOE hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn 6Onq8vP09fb3+Pn6/9sAQwACAgICAgIDAgIDBQMDAwUGBQUFBQYIBgYGBgYICggICAgICAoKCgoK CgoKDAwMDAwMDg4ODg4PDw8PDw8PDw8P/9sAQwECAwMEBAQHBAQHEAsJCxAQEBAQEBAQEBAQEBAQ EBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQ/90ABAAU/9oADAMBAAIRAxEAPwDy HwzaSaX8MbjIKtqN7HH06rCuT+pqDeUiAJyBX0J8eNE0Pwr/AGF4X0Eg21vC0xYY+Yv3NfLt/qHl qUU5HrXp4eN6XtO+p21JNvU1Ptqt8o7VIkck1xDHCf3kroq465ZgK5+0lt2j3MxL+ld98P7aPU/H eh2ZG5DcLK/+7F8xrnqVEoyJSd0fQnxy+Hnji/udL1qCze5tVs4ouPmKlBzke9fKt1perWEhW7tJ IvqpFfXniP8Aa18RafrU2m6Rp0DafbOY1EnLMFOMnsKdbftQeFdTUJ4t8KQyq3BZFU/X0NeVTnWh BJwujeSi27M+MWMg74pWlkjJ3c7Bn9K+3l8R/sx+L8fabVtLmfvgrgn9K67wr8B/hD4g1VLvw9rY u0HzNF8rMR6Vt9agl76a+RPs5dNT3L9kLQ5NG+H1pI67XkhVjxzukO8/zr7BWR8DJrzn4d6PbaPo pgtF2RbyFH+yvAr0VRxXzdTWTZ1LRFlZX61Msj9OKgXpU4681gyiYSNUodgc+tQLyamUc4NIh2Jl kepFkfqahUY5qbrjFSYtIf5jdiDX59/tWa15/wARtF0nzABZ20TEH7p82Uu2enZBX6B4796/Mn4+ 3cepfGXWWOZPsMQiRB08yO3AXgjH3371jPRXPlc9f+yci6tL9f0PYPhFcyW1np8qIsjtbWClmyFI Iub9wffLrx9KT4reIZbbTb2wmuTFHPZhHZhgE32oxRb2Gc48uAnHcV0/gGwtdLiMuRF9nurrCj7m yyhgt8scccI/HvXz78arx7mCeIHaFWxjldsj57Wye5cA+73A9K+WU3Kvozvp0PZ4NQtrsfEuo3Nv 498a6zrWv332eESXF41wV3RxwpIWkIQdWZjhVz9eBWTcar8PPFXheXWPA93ePqWns/mmfAjfafmG zgqdnII4zx71a0+7i8KX0q6rGtxpdzbvbXyHaXSMEOSAeTknBAxn1rkfGOq+BfD7SeFfh7ZhhfAy mXoiwyqCcYOSewzxX3VL2LpqPVX/AOGOLC4DDfVpyrL3nv3vrt1Mt9TuAMMdxwP15rKk1pycM2P/ AK5q1D9n0i1jvNSXep5itud0pA6n0X371Rk8bag3+straTnODCvAHQVzc7+yj4HEZcruwHUZpVLK /Hr9aj+1MesnXPOOPSmP4jhK/Pp1s2cdFI9z0NZ0uv6byk2kxDoPldgDnnNVzy/lONZek9ToNMtd R12/TS9FikvLt85RBwqr1Zj2A9e1XvFHh7VfBKWsniKaKEXiFoUjcSnr8wbb9z6Guo8DeMItB8J+ M7Xw7pLw6rPCi21yrM0rRscsqhui84JXr37V8+6df+Ib/QZ5fF9280yNvTzvmdG3fIFz39PavQVK Hs4z5tXe67H3eF4foOg6lTe2muh2yag5y8b7R1q/F4m1i1b9xfTQ4/55yuv8jXnEOob920/KSfrz VmS8wqsvOO9ZwnraR+SY7CON3B2PWIPif47slAtPEWoxYGfku5hj3+9XoPhX9pb4zeGNQtr2DxPe 3McbBvIu5DNFKoOSpD5OD6g189aTfPG8ki27XKlCjBMgqG4J6Hr0rWN5c3Cw/akZEnuty7z91Rgb VHUAZ57V08sXLlcVY8CFfGUpKdKvJSXZs/om8KeKf+Ep8MaT4lgTy01K1iuQh52+YoJGfY8VtveS HIGOe1fnZ+wL8W5fFfw9uvCurzvLc2V3e3FmWJObNpyAgz0EZ6D0IxX319oGeuc14VSk4TcGf2HR k5U4uW9jRa7bkk/5FU5buTGCeKqS3GeD0qo0xOV9P880KJZba4ccccetUWuZAcZH5VE0mBmq/mbp AM9O9VyjLjTNjrzVGedxkg9auHLRjIrLnwQeeRxU2LP/0OY+KV5I99bwSuXe1tYYuTnkLzXz7qE6 4PzcjtXpnxA1T7Trd9JngOQPoOK8Ju5RLPgNjJ5FfQyh7Ogo+R3RV9WdRYMHAYHvzXu/wWgRfEWo avL93TLCaTPozDArwTToR5W4d6968Ar/AGb8P/FmsZw04jtUP15Ir5acua6NLanDm2tXs7nV7omV nkZURTgKTzuY1zpKkc0yS7lihkt42+STll9xWcHGMk/SvRsc19TsLXQvtWmyanDcIBHnehyCP6V6 F8EdR1Kz+JGiDT5mTzZSHAJwUCnINcdFdS2PhXy02Hzs5BYhl3f7Pf616f8Asz6M2q/E62cjK20R PPq5Arlr/wAOVzWL1R+3HhayWDQrNHHzGMMfqea6VYY6ybSPyYI4R/AoH5Cry57mvlGdxeSBKmWG Mn6VSXrzUynHSoIaZeSGOplgjz1qkuTUq5B60jFp9y6IY6cIk9KrDg8mng5NBg0+5P5adK/JnUtb t/HPxM8T6/oym7s7a+dppCVjWOGO5RCxLf7uPxr9TtavBp2jX+oMcC1t5pc/7iE/0r85vgrqGhQa beaTaaaz6lrizMiRgHaIyxkvJCcDd5gxGOSuCeOM/IZ5mNTCQj7KN73b9F81v0Ljl1PGWjVlZJr7 /uZ65F4oht/CzLeRR2sNzbXYISVZJYprmWV9si8Hfl9pxnHSvVPg98PdD1PRrnxP4itIdRlv765n gSaNWSFBth4UjliIhknp0GOa+TPHHwh0T4b+MvDVzPHc6lJdyWtrbLO+8RBc3FzKhxnIOfvHOT+N et/syfFi7js9R8F38Jv/ALKft9ukUitc+XeMZTGquQJApbPB3DkYPZcNYn2tepPE03G2iuv019L/ AHaandi6MacIRpyvft/SPrDUfh18PdTVo9S8Mabcq/UPaQtke/y15tffs1/s/XU0t1N4G0yKWT77 xReST6coV/Cus1D4r+ENMwdaN9pgwHLXFnMqhT6sFIA/Gqdr8Xfhdqym3svFmns7MM7p1jYYI4w+ PpX2OKxa15LP7jjjQrL4k7fM8d1z9jL9nzWC4TQ/s9yeQ6TuT7A5JJHtkV+afxv+FHwu8C+Kpvh9 cW1zoGvRp5tvKsnm2l7ExJUx7iSj8YKHv0PIr9lL3xX4WsN2tya7YR20e4tJ9ojYBBjAGG9M1+Fn 7U/xs8OfGT9oKGy8JxnUINJ8qGK4VsKpiO6Ri2cYAyTnp9a8rCValSo272R1xwtOS5ZJO/dan2Z8 Df2JPhh41+F+keKfFM169/qXmyM8MwRNm7Ee1cccDPXmvDvjT8M/2JvhbFq8V147vLnVtFlEF3pl lNDPeQyHGQYzj7o5bniv1Z+H1uvhn4T+HdMtwsawafEcrwFOzfnFfygeN7nVvHHizxrrbTp9p1bV NQmCzSCIsWnbBy+OdoGBXbhYOvWmudqK/wAzCOCpRjeVNPpsj7h0Afsk+OLq103w/wDE/XtCkvNs ayXlgUWMyckSMrFQDjBJ7dxX0W//AAT8+22EVzofxGju7GUtLE0kReNt/wDEGRmByOMivxu8P6Ve aJaGW92q53AASIx4UDnaT74r9N/2MPHvivSPC1to91PJJYPI0sSMSVAdiflB7V6eJwtSnDno1Pvt /kaqnQmvZ1Kenq/8zw34gfDRPhb45l8IalrNvfSW80aMse6P5Cobd82BznaBnOe1cjcJp2pssdh+ 7uCC3koSxCKcbj/Wofjz4guPEXxh8SamHMsS3TDPU/J/d9cYrxDw/r+rWWp3IhuWt96PC5ABcxkf MuecZ6V89mNLE80ZUalpJfe/P/hjmeV5fGlJVaV4yf3W7PdfefSPhjSL68VotOkd7idvs4SH5s7+ 5Bxn2xzWV4ouL3w5YM+qbvN062nkbd/C/wA2Bk9egxW/8MvMt42v3DqzKXYjtxx+FcleCLxL4l1i xk2zWxtn/wBZ8yBiMA4J9T+dGGzSu8SqEop93+B8JPhbBzdOpBtXe26snf8AQ+2v2Nr208CwWyT/ AOtOlQIWB4DyEPJ+LcZr9MtN8W2d8iuHHzdOfWvxg8FeIJLDUfJhbase1OD/AHRgfpX2h4L8XzMk aGQjGOpr7PE4Rylzn6FSrJLlPvVL+BwNje55qVpYSQATlhXhmka8ZY1AbOa7G21N3Y/MQeO9eQ6T idfPc9CzA3ANPgh3uhRhwec9x7VyCXeVAU4zXQ6UxdCx5NZSjZGiaOje2jrOuLeI7vQ1KWODk+1Z dw3HXiseU0R//9H5u8WXjTXE0zfxMa82j2yThvfFd54gmjYtkcnPauS00L9r9Qfavfx0/dsj0Y6I 66zQR2mSMV7HKTpfwbsYsbX1W8eU+pVOBXlEksaRbV79K9j+JRTTvDPhbRQMCK08w8d35r5Smm5L 1HJnhF0SvSoVDMFOfvValZDnJ6Va06ISXkMQIG5h16fjXrnKdv4iubhNHsbNnZ1KLySvOB7DNfVv 7FOhG78T3mpsmcOiA+yDJr5Q8YXTmS1hlj8sqO5yT2/AV+kP7D+jJB4dbUnXmZnkzj1OBXm4yVqZ vTWp9+op+tTqDxxU6yxcf4VMssVfMnYyJV9KmFSrImf/AK1TK8eOlIzciFRUyj2qVZI881YEkdIx lJ9iuBmpQD+FTBkNO3LRYwcvI81+Ld4dO+GfiW5ztP2KWMH3l+Qfq1fG/wCzno63XimW9uA0ltZa M7MxGGY3Vy0nsOBx+FfT37R+sLo/wm1ScoJPNkt4wh6N+8D4/Ja+cPh0k2nfCjx5d2kqwXVjZ2Gn +aBkbkjBlz0/icg4r4jMqDxGY06K25fzb/8AkT18O7UL9b/5Hhfxm/aWtfGGsx6nc2rW1ppt1cW9 mipufK/K7bvXaeTnHOBXhlv8VPAUF/FqMKzaRdW+As0SSlmwAPmAYrgAAdPfrXlnjWVZL94XfdBp VuoI7B3zLIR06s5r2/w3+zZHbx2E3xKmltT4itBcab9ilVkRl/1iS5U/vQMED7pXOOQa+8jQjOTk la5cqcVaLR0Gr/tJpcqyaN461CJZGwE83eoAHI8u63/qaxZ/iTLrCKz65YazPJjAvLG1YjPXcYzk fUVyHin9ki9XdL4T1m3vRyRFdoYZPpvG5f5V8z+Lfgv8RfCSyTar4euFhTJ8+BPNjAHU7o8gD64o +p0+y+47aUHtCTPrTUIYNd0mRdR8L6XNAcqz2zPAzEj0JIxz/dxXzhrHwz8baTHO/wAP/CccVu7K ZGjkSQ43A7XOQcdPlwoPfNeDjUdQs4gLS6mtyGz8kjoRjp0Iq5b/ABN8faUxaw8Q30IJGf3xYHHI yGz0ranQ5HeH6m9ehKUbSZ9tW37Xf7UHh5o7a48OXs8FuAixi0aTagGAPlQ5GOMiud1D9ud3eWPx v8PdLnkZWZze6chIb+7h0Byf8mvnTT/2o/jdom77D4mkyRgl4YmYg/7WzPPsRXVeGvi38Y9ej/t8 aDb67YJKUlnuLUtBuPB3YYcDvjp3qFl8Xq4L5M4faShpzGpf/Hj9mzxlffa9W+FulWszLuk+zRpb qeOyocbvbvXu/g/9or4MajNDZ6TZf2GYYtkQKfINq4UAKo/ACvnD466T4Y8SaZoup3Wi22l78TSy 6dCqMyEAONpwD2IyfxrnPiB+x1rfheDTte+HmsR+J9P1Ozt7+FkQ2s4juE3gFCxBYdDhuvau+jgF LSzflds83EYqpBX0t3PLPipHe+EfFmrySXEWpLdSiZZYyxidbgB8g4GSoJBHZuK808OWk93ceYoL NcuT74zk1f13SdWgjt9G1TzIZ4C3mpcsdyMx2qh3cjoa6rwXZ4vkMRICDauO4HHX3rxcTUjz1KiW qJrym6NOE+v67s+itAkuINJ82SNkYKgwvAIRenpzXmHhWQXF1rOoMMNPNHCD6DJdgP0r0zW7xrLQ nkR2iaKIgFsbW7YHvzxXm/hb9z4dinbgzyzTcjsPlWvn+H6XtsY5/wBf1qialouMeyZ3PhVma4af Od7k/rX1L4QvmiKc9MV80+FolRIyec819A+GpQmwdAMYr9nqQ0PMUtT6r8PaqwRAD6V6ppt9nBJ7 civAPDt+uFPfivXdK1CIr7V85VpnpwkemW1wWCnJwa9L0pStsDjqK8m0m5jkmRF5ORXuFq8McCL7 dhXjVtNDvh3IHBGSc1lT52nI59K35J4h2wRWfNLDjj69K5TdH//S+XNZG75RgEfrWfptmikOetaV 7kynaMiprcbFxt616WLlc6kzUsLX7bqVpZIMtLKi/mwr9JPHHwn+HfjHQ9KsNT1OLTdVtrdEQ7gD 06EV8E/DXT21DxppcRGQsu8/ROaq+PtVvtR8W6jdtM5KzMqnceApwAK8J0pSkuWVrG3Mknc9n8Sf sn+NLRXuvDtxFqsA5HlsNxFeFaz4D8ZeGJimsaXPblD94qcce+K0/D3xR+IPhhlfR9YmRV6IzFl/ WvoHw9+1d4geMWfjPSLfVoOjMVG4/nW/NXhulIi0H5HyUwutQuBCRJNMeBnLGv2x/Zd8PNoXgC0i lTa4iQHI5yRk188/DbWfgN8R9ejlttIXTdVT5thAUMevHrX3v4K01LXSMwKFR3JAHTHQV5uLrqaU bNM3hCzudeo5yanGTzQkLjpUywv1rybm9xVqdc0LC57VYWF88ikZykhoHrU6jFCwPzUyxMOtOxzy khFFTKB60gjbOaeFbFPlMG+x8q/tXCa/8L+G/DEALNq2swKwUEnZGCWOB6Zry57uDwv+zdruq6if Km8T6hdTeWRhxEjHt14VP1Fe8fEvN98W/h9pTZ2wC+ujj+9tWNc+3Jrxj9sl4rL4b6fafKjSJMAf TzGRTj8M18DHE1JcQSoKHuxhfmvs7rS3pLv8j3qVNKhC+8rv7r/qj8vLuxfxJY+IdZRsJd39naru GGYXMyoBgcfdHNfWn7UXiO40X4S2FvaSNBNAqNBKjFHjbzdqlWGCD9O1eE+EtCml0Lwqp4TU/E0Q KAdUs4TKffgmum/bQvJrbw/o+jDpIbbI75VC5/U1+kUX+6fr+VjolG9WPofOfh79pP4oaCUiub6P WIVAJS8QM2PTzF2t+tfXnwS/ahtPE/inS9CvPCs1xqd/MsENtDIkkFxLJ8oRjJt2q3ctwB1r8xlj YscLxX23+w94ZOrfH7wqzrlLE3N4wPYQwOFP/fbKamcndRXVn3GV4CjUVSpVXuwjKT/7di5W+drH tHiX9jjw74R8eXGt/Ea3hbT/ABCZZ7C0tJmS0t5mJaS2eQ7WZ0Ugx4wrAHA4xXknjL9jjwNqbSS+ GdVutIlbkRzgXMX5/K4H4mvuH/gpPrf2H4O6LowHz3+qrIPUfZ4XPH/fdfino3xj+Jvg9gmi+ILh IUPEEzefFgdtsm7H4YrqXuVHTXQdWlLE5ZQx8koufMrLb3W1f8Leqv1Op8V/si/FnRmaXR4bfX4F 72kuJMf9c5Np/ImsvS/jN4j+FPg25+F2teHZLXVraKa3Rp8xlEuMnc8ZGS2GODnB617V4K/bI8Vf a7bTNd8N2+p3V1IkMLW0jW5aWQhUDK25QCxGSD0q9+1z8H9eufBqfGTxZq8EmvwTw2ktrbR+Xax2 758uONj88jo3V3PI6ACvQjd77H5/XSTs9z5p0XxPN4w8Jvo16SdRslYAMfvoVwGA9iBkV+h2j7rb wroNlcOH+w6bZwk9sRQrn8q/JfwNHqV14m06HTpdszXEQB+rAH9OtfqF4+1VPCvw+1XVjj/iX2Er gDgZWMhcfjivcwDUXOXZHzWY3cYQ8z8t/iDqn9r+P9c1WCTdbS3DBUDErkHjnoec1seCLwJqqQ52 rLgYycZBzz615dpnnPDG1xlmfMjDpgtzXrPgPS/tN+lw2ODxn5v/ANX1r85xsVSw7c2aVKjq11yn pXjy5iTRDx/pDgBRj9Rj8qgitPsml2NgAF8m3ijI/wBpvmaqPjsLe6haaWj58x44jx03MBx611TR edfBV+75hx7Ko2iq4VpayqI3qvWT+R2OhW+1VJ5xXsGhjbtrzvRrUqq8V6jo0JBBxiv0+Sujzlue taFKVCd+ea9b0uTKg5ryLRopMg9RXqulRyYUDpivFrRR3QZ6/wCEUM99GCTgcn3r3eIgIB+ZryL4 f2LySNMRwOlezi3kAPvXy+Ia57HsU17pRk4+8etZlxt28GtmaCQcYrJuIXA6DFcxuj//0/micK33 QM12mmQ2yaDJO8aPIT/EDkfQ1hvZBTkDINdm9slt4YVo0Khz82e/0rsq2Zdzf+D0Qj8Q3Wokf8ed pLJ7DIwK8c1e8ae9nm6l3ZvzNe4fD0Cx8I+KdaxgiEQqfc189z/M5Jrlglzuxq37qCO4J4NX4pHJ Bx0rNhTMnHetmKIgYArZiPXfguk9x8QNKSA7HWTceewHSv3Y8NBrbRbSEjkRrn6mvxj/AGYNDOp/ EaGYruECZ9eWNftTbRiOFEH8IA/Kvn8c/fsdlL4TXSYntUyzN6VSQc1ZXrXlmxbSZvSrCzN6Cqag VYA70GTSLQnY9BUokJ7VVXOcmpl64FM52kWA5pwaoxTu1WmzBnzJ4ku/7S/aO0uw2qf7M0pGyWxt 82R2Y+52qK+dv28NYjgtdF0dOQFjA55+Ys3f2WvSZbLxL4g/ag1W/wBGmEdrZKtrISpYDy7devPq 5wCMZr51/bav7XV/FBi88pJpcsUaxkZEvyckEcKF3d8kmvzXLGpZzjat07yil3XLG0l/6S36q9uv 2Dg1TortD85PX8T55+Ferx3Xj/wfo+p3cdpYWzXbo0zBI1nnjCZZjgD5c8n0qz+1s19421i31DwZ aT6zo9o0iyX1rE8loWUBAqSAYfaByy5XnAJxXztqV2u94BxjuRnpyOD1r6Z8MftY6XZ29vYeK9Le BolWPz7Ih0woxkxHBA9lJ9hX6jSUbcrZKbUuZHwKzywy7JV2kdvSv02/4JxaYNQ+KOr6sy8aZpDK D6NcTIuPyQ1YjuvgJ8Y3Cv8A2dqF1J2OLW8B/wDHGJ/Ovof4MaJ8M/2XDP4t1LVRZaF4qK2by3b7 pLS4tsvGnyjc6ShiAcEhgo71TilUg29Ez7DCYtrB4ijTi+ecHGKXW+6/8BvbvstTxL/gqF4kZNS8 FeGFb5Y4Lq7Ye8jLGv6Ka/Ge8uTuYdzX6Uftwp46+LnxBTx14c8OahJ4dt7KK2tnaL96VQszO8Kk ugZmJUMAduCQOlfmhqNtd20zR3ULxyL1VlIIx6g8itoxbqSl3Z3YqtGjl2FwSetOGvk23Jr1Tdme j/BKxbWvi54T08jcgvkncYz8sAMh/lX3h+3XrQsfgP4ZsicT67rM0hHrFaRAf+hPXyj+yPpf9pfF tr3GV0vT55c+jSlYh/6Ea9S/4KB+KYDqHw88IQHzBpWly3Uy+kt3Ox599qCvQ191LufmlZ3qNnyJ 8CrN9Q+J2ixdFiZpT/wBTgfma+1/2nL+W1+E+o2cPDX7wW3/AAFnDN/46pr5Y/ZosP7S+Jy3qrtS 1gd8dgTgV7R+1lq7QeH9J01Xw888kpAPaNcD9Wr1o+5has+9l+n6nzeKfNWpx7Xf9fcfDESyLA8k i5BIA56d69k8Fv5VrEB8qtznODn1/OvLrG+a906ZJlB2Dg/h/Wuy8F6ur39rYyjYWIUOOfzFfnGZ 81SEo21X+RlTqKE077nYtPLfeN7GNidtuWkO4huEU+nHU112g7rlxMy4yWPXOQWODXLaTC7eIdXv mbcbeJkViBnLZOSPoK9C8MWTRhEPRVUZ9wK+l4apKOGv3Oqq/dv3Z6XpkWFAA9K9K0gEBeMj6VxW nQ/dWvQtLhK7R6+tfbyRxJ2Z6DpDEFeK9P0uZsrkYrzfSYiCvvXpmiwlpEHXJryayR102fTXgBWi 08MQMnnmvRvPYfw9PSuW8MWgt9LhHqBxXSODXxlXWbZ78dEiCa4z94YNZdxcNg4GR/Orsnf2NZM4 znjA/Ss0jRH/1OT8SfDTxb4XlaPVdPlVVP3wpK/nXCXU10sItWkbYP4fSv2wuNIsdUhaJ9k6sMFJ RmvGfE/7PvgnXLhbqax+ySg5zGPlP1Arhp4//n4jtdD+VnwNa25034K3MzfK+oXWOe4FfPjw/MSS a/Tb4vfAm+vPA1tpXgsCU2TFzGOC30r89td8IeJPDkjW+s2EtvKp/iU4/OuihWjJtp9SJxatc5u1 sxI4APU4/Ouzv9A/sxIiZt5kXJGCMVy2m3ElrdpPgMUOdp6H611Opay2qyKxj8kD+EEkfhmulvUz R9q/sZeHhc63eaky/KHCg47KM1+pqW44wa+Cv2N9HNp4c+3dDLufP1PFfdiM+eSa+bxLvUZ6FPSJ ppCOOasJAp71QR27mrKu3TNchTuXVgHc1YWAetUkZvWp1Zv71UYST7loQgdzUoiAqspY45qYMxHW rVjmdyYIKXbTAT61Fc3C21vLcv8AdiRnP0UZrROPYzPmv4YLLceJ/EevWNutxcX+tXgMjHGyCOQx /wAlr8z/ANpm/wD7U+KWrrHKTb29zMi7hg5Dnt68V+jf7OWvaZeafItpPHLLITLcEONyyTyPJtI7 fKSa/Lb45TxX3xX8Q/YiZITdSOACf4iTnv61+H8FYadbE4vMJybcqtXRq1leKVu/Mkm23so7WPuc S+Sfsu0Y/kfO+soodyhPXH1Fee3gIPL1714e+G/irx5exwaTEsNrcNKiXd1vjt3lhG5o0faQz+w6 cntXIeOvgr8SvB/mXGpaRK9ovImt/wB9F9SyZx+IFfu0YNK7OWEle1zxabcJAwYhl6EcEfSrd94g 1/VooItT1S6uorT5YRLM7iIdfk3E7fwrKufNSRgT359qoBZEjLcgdf8A69a2PXpSlHVH3L4G/a5X TNMstK8dWE1zJbxrGb62cGRwowGeNsZOOpDc+le1QeJ/gF8ZEFvdzafqE8vHl3aC2ugT6FtrE/Rj X5KX1zI0h5IB6ViyXEgfcTux2rqin3PPr2bufrhY/Czwp8AvE8fjPQVePw3rqrY6g877xYuW3Qy7 z/yxZvlck/KcHOK/Pb9qnxnpXjr4xalqOhXiX2nWkcNrDNGdyOIUwxU9xuzz3rye78d+NJ9BbwtN rt7JpDsGa0ed2hJXplSe3p0rid59eTxiumEGnds8Woz7a/ZB0h2vtd1hk+RI44Vb3OWIrA/avvvP 8VWGldRa2oYnHQysTj8gK9i/ZS05rL4f3OoN1vbhmH0UAD+VfJ3xz8Uz618SdeQYMNvMLdW9oQAf bkivSxN44SCXV3+7+kfMzkniJuXRWPMoI1j0uYxrsEjADPP866nwTp4n161Ut8sX7w/8B5rmrhSm mW0SknzCWPtiux8Eb4Li6vGbaIYH/MivznGT9ypK+9/8jm0dWKfkek6FCZ7XUbsg/wCnXRQf7q7V /wAa9e0GxCoD3JJrzrwxB5WmaTbN9+aJp24/vsT/AFFezaPb4UAivvsnpezwsF5I9Oq9EjrdNtSx XknH6V6Fplr91RkDvXKabA3B7n0rvdNiLHjNfQyWhxXuztNKtcYz2r1rwrp32i/gQE8sK8z02NgF xk17h8PrQy6hGx6CvExOkWz0KOrR9LWFikdvGnI2gD61Ye1XBAbp1psXmBAOeaZKxAPNfHOLep7t yrLaoeM1lXNqgByTV6Z2P8ROR3rJuGlPybsUcrHc/9X9R4zt5rUt7yaMBc7l9DzVdPJz2q0PJzji vmUz1S6r2M/+sTyWPdelZWreDdI16Bob+1gv4mGMMo3VpJ5IwBircbxIcqQCO4rJrU0TPk7xr+yd 4H1svPogbSLo5PqhNfNWqfsq+PNIvfJQpc2jHAlTsPUiv1biv1K7Jwsq+9TrYaJqBCPujz1UHANd EMTVi97+pDpwZ5j8BvCbeFfCkdk45iCx59dvU174uDzRaWtjaQrBboEjToBV1RF7VhKTbuzS1hic cVbTPWlUw+1Wk8n2pIzbsRr1qccjJqVfKz2qceV7VRg5eRAvoKsCnjy89qeNvarSOdyEFch8Q9RG k+BPEOpZwbewuGB9/LIH612XFeP/AB6vUsvhRru44NwkUA9/NlVT+majEP2VCdRvZN/ch04804x7 s/LrQLnU9L8PWtpazSQyatq7uxU7SRbKsYGRg4Clv++jXjJtIdY+JuqyXsgWIJcXEjcEARxsw/QC vcLGS6nuPDFrFtlC/wBpXZQH5tm87mz6gIMV81trFrOnibWraMwrNaPEgzk5kAj6/wC0Tmvi+GU3 gubq/wDJH1tRfvmux9geEbiPSf2XNOjuyUe3iS/icHmK4KvKrj6Z59QSO9eAeEf2wLOVUg8Z6S8G 75Tc2J3ofcxPzz7Ma9l+L89v4Y+AUOmowRkt1iVfdYlQZ/I1+XkRVFVeNvr1r9IqStJpF4TDqors /UHS/D/7PPx1nRG+wzXM5UPJD/ol2me5X5Sce4Ir4v8AEv7MvimT4mav4J8EbNZ06ykZ4tRLiO1e 3zhW8w8Eg/KQmcNkVH8CvDMPiv4o+FdDlQSR3+p2kUinvEZVMn/jgav2g/bD1Kw+HXwmtfGWi2kE OoaLdw29kuwLEI58iSEquPkKrnAxggEdK5VJy5p9In3lLL6dKrhsNO7lXuo7WVtm+93p0srvXY/n 58ffBjx/4HeR/EWhzwQg8Txr50B/7aJlfzxXi09qyEgEN3r9SvD/AO2N4Pv2Fn4z0uXSXf5Xlg/0 m3P1T74H4NXZzfDP9nX44QvfaYtjLPINzXGmyrbzr3y8Yx077k/Gu+E1a58jjqDpzcJI/O3TPgHL rHwom+I41ZUnSCS6Fts/diKNipUyZzv4zjGO1fMyo8j4Uc5x+J6V9EfGvQT8M9evfBng/wASTa14 VdgySROxtzN/y0iYr+6aSM/e2k9s815B4V03+1PEeladjJurmJenUbhmu6L05j5icbOzP1N+HOl2 PhP4eadawgYtrffKw/iYLljn9K/KvW786tq93fyN+9ubiWU98+Y5Iwfoa/Tnxlrn/CP+C9Z06C2d ItP0ti05wsfmTDCovOSTkk4GBX5eRJ52opGxBBYKOOgHtXRmM+RU6b6Rv9//AAx8pa7nLvL+vzNK +GyaGEn/AFcaj2BPNdloUPl+H7yReGuGWEcf3jiuRvGFxfPs5VGxn6V6pollGbfRLLr9pu1kYf7M fzf0r84xK5owpr7TREPeq3XT/hj17SrVTeRiMALb28UQ/AnP/oIr1nTLfAUjp715t4XX7U9xc9AZ ii+4jAXP55r2XSIASBjrX6/haaVOKR31pas6XT4QSu3j0rvdMgBK7V6Vz9hAo2gd++K7zTYkGBjm uyexwJ6nSaZCTg4/Ovoz4a2GGMxGCOleI6XbpxnmvqnwBZQQ6eJGH3q+dxrtGx6+GV5HbKNq4NV3 ABPqK22EXQYqrIIEHFfNWPYuc5MeoI4rHuBnIHNdVMsPIOOayLkQEY4p2C5//9b9RY8iragZpqwv xweasrEwGdpr5g9QEY5xVpOxNRLDJ6dasxwuccGpZRKmfzra0td9yuO1Y6o/TaRXR6NA+9nxnFSU dMnFWF6cVGsbY4WrAjf0NAySPpVuPGM1AsbccVZRG7igTZOgqwOKjRXx0qwI3x0qznkxy4BzUy80 1Vb0qVVPcVokc8mKK+Z/2rNQW0+HFtaHreahCpHqsavIf5CvprFfG/7XN0XtPDmlqM/Nd3DfREVA cfV6+fz+r7HK8RP+6/x0OzAQ58TTj5nwPqJfT4ILyFvLNt4fml4JypleVh+YNfMWhXEL29tp9y4j hurqzSVm6BFlUsSfTHWvpz4qxQ6fZa+2nszLHo+mWRJ6CV0QOq/TNfHG941wwypBzU5DTUMDTse9 /wAvJXPuT9sSS2tPAOl6BYTR3V24jmmjgYSvCjksGmCZ2AjAG7Gc8CvzUt3bYInGCO/Svub4T/tC +FvCegW/hTxPpjWyR5D3luiyLNk8NMnDFscE/NmvU7r4cfAz4x28l9oH2YTyDJm0x1jkUnu8GMfm or6xxTV7nq4Sfs2k1oeQ/sPaBFrPx/8ADLj5ksftN4fQeTCwH6uMV9rf8FLPEAsPhf4f0DzAv2/U HlZfVbeIgf8Ajzisn9lb4Ey/Bz4kjxbqGpR32i39vNptpLs8t4ruVkcJKCSBvRSFYHBbjgkV4P8A 8FL/AB5pmu+NPD/hfSLyO7TRrOYzmFw6x3E8mGjYjIDqsakjqM81zxVqE49W/wDI/Q6GJhXzzB14 6wo0ZNvon+8t8+aUT8m79z5pKmuh+G2kP4g+IPhvQu2oX0MMoBYb4i2ZFbbg4KggiuSu3YtzxXvX 7K+lNqXxo0qbZkaZb3V2T6EJsX9Wr1aMdrnwma1lKUpI+r/23otG0v4IeH9OsrCC2gOq+XZpFGsa xJFES4jCgAAgqDivz6+AuktrHxN0mALu8lnlz2G1cAn8TX3B/wAFEdYFt4f+FvgeMAOlpe6rN65u pREmf+AxZH1r5p/ZX0+SPxPqutsuEsbNxu9C4/8ArV3Uf3jSfV2/Gx8RUfJByXRHrvxk11k8IeJL i4mkeK+v7ezgjwoTy4sk7QOSfl5J/IV8SQW8Vlcy6hcr+8kOYk749T6fzr6P+N96dI8H6BpsbyTS 3txcXcjSsC+7iPJxwAOQAOlfNSzyXIEjjkAD8B6Vx5s3PES7Ky/X9T5pz5aaSFtwzzmTB+cn8zXu WiJFbajbSSAv/Z1lJMB/tvwteO6XbvcXUcYHVgK9i0YpPqd1agHfczQ2i+6KCz/pnJr5OnHnxtKH Z3/yIwS5qjf9dz2jwZp01jpVlbztumEYaT3eQl2/U17XpcK7QccjGK4XSIA0xwDjOMD2r1PTLc4G F/pX7RThZWHVndnR6dAcg9q7rTrcAjC81zenW+AMg/8A667vT7dlIwOvalNGEWddosAeWMY5J6V9 Y+GbUW+mxLjHy185+GLF5r2FVXPIr6rsLZ4rdF24AAr5PHbpHvYba5Iw+XGRzVSQAjjkmtJ43x90 9KpyRt0xnFeQono3MebjgVk3A9K3pomJOAayriJyCADnHStOUSep/9f9WUuBjOKsLcj0rPTkDFWF A79q+WVj1Ll8XPONtWEnHcGs8LmplHPNQ0Vc1UnQkfLXUaS6iJnC4ya4+JckH0rstOTbbIB35osV c2VuGHQZFWFuxnlSDVFQeKnHXOadgNFZwe1WEmAPQ1QQHFWUosS0jSSYAdKljkwMH5qpRirC+taI 5pRRcEgPanhqripRWqbMGiSvg79qfVXfxtpmlwEebHp21Qf793PtGPwSvvDtX5r/AB/ivfEnxwl0 nT5AJkFtax88+YIGkUD/AIG9fHcVtTyyVGW05RX/AJMn+h62V3jiFNdE3+B8m/F7V7ZfDuuPbNmO 81jyEOdwMdspAKn0JGcivju+vAi8A4Hevob4rSQw+E/CmnxAK8hmlcf7aqIyfzryXRfAHibxgbuT SLZvsVi0X267dT9ntFmYKrysMkDnJwOnJwOa93KqbWFpxt0PSk7Svc8lk1MwyvK3IjGT3r0fxD8P viN4C0Cz+I1zD/Z9rcSKiS21wBNG7gMAwQhh1HTIzxnNdD47/Zv+JnhaK4vEs01mwjUl5rJt5x0y Yzhx+AOPWvL/ABR8VPiF4i8K2XgHxBfmXStLl3xxtEiyBgAPncKHbGOAx4PPWvfcLHfTqNtcrOp1 j9pH4u6z4TPgvUvENxLpcjK0i/KrylDlPMkUBm2nkZPBr6o+HP7QXwj8X+DNN8F/EWGzsby3iELx 3Vuos5CON6SAYRnHLZ2nPc1+b0jAgZOB3PX9KzFSe8mjtbWJprid1jjRBlndjgKoHUk1pCmr3SPT nXn7L2bem/8AwT9L/GH7KPw28X2x1TwRevo7zAtGUYXVm5PpzuA+jH6Vz3wC+D+ufB34nX9p4vaF 5dX08pps8Lbo5xHIGmAyAVdRtJU845r4ti1b4ufBLU4Fiub3w5LMN6xlswyLnnMZ3RtzwffrXpvi X9r/AMc6/wCFbbR77T7NNZsLmK6tNWg3RywvHnLCL5kywJVudpBIK11qLWx85Vk5aNh+3D4zm8Uf G17FmzF4f0+z06NR0Xy03t+JL81ufs4w2+k+A/EPiG5R5FkbyxHGMsxyFXH4nHpivjPXNb1TxLrF zr2vXLXt/eyGSaZzl3Y9Sa++fhHaDR/g7plkyL9o1y6UxhhnkyBuRx2A/GvVwVP95FHz+Nn+6keC /tHyk+K9N0byhCdOs4d8KHcFeUmVwD35OM14krooAIxnHSvQ/jNrsmqfEjWZFBKvcMoyMsBF8nXr 2NecR7OrjAHp1r5jFVnOUpd2/wA9D53ELlSXkvyOv8NmGTVI5FDHb8zbgMZAz2r1P4a2AutbfVpU ByrsrEdDJIen1Va8u8O5S3vLsgARRMRxjrxXv3w1smhtpi3WNI0/EKAf1Jrz8po+3zFSe0bHRgpc lKc/J/joe7eHoycOOpJ6+9eoaZFkZ71wugWmEGFwBXpmnwgDGMV+0KNkebKdzqdOQEjAzXe6YvTP f0rktPgwRxXd6dDlhzn9MVx1EaQZ654Dtw98rlfu19GwybY1GMmvF/h7ZNzKePSvZwABxz/Ovj8X rUsfSYd2gK86E4INVZJ1PGMfzqRlBzuqnKtcSgjquVZJuDkc+9ZVxODnjn61oSg4OevpWVOOueg7 +la8hHMz/9D9XktWx1qwLVgOtQRyv0B5qyJZK+VSZ6dxRbOMHNWUtm9ahWSQ9DUyyygdaTuVoXIr ViwGetdzBalY1XPQVxNk8jzoD613CSyAYzSHoWVtj61MICBkVCsz+tTiV6eoyeOByBuPNWltz61W WV+MGrCyvTRDuWkgI71YWHA61USV/WrKyv3rRHPK5MI8d6ftxUauTxUma2jYwY7H61+a2q+FdS+J vx413TdHuktZIr25dp2faUVE8pNvUlvlyAOcAnjFfpOWCKWbgDk/hX5kfDfwv4r8Yx+NPH/hi7CT WWtpIUKfNLCPMedEJ4zslByeoGOtfI8Q0nWhRpQjf3ua3flT66nqYCahKTbtdW+8+Of2itIsNJ8f WnhPR2P2PSI/Jj3NvbDSMCSwxk/LXuf7LFvDYeCfGt5cqJrXULi6hkQjKyRwxpFtPqCSRXy78V9S F38VtVELEQW8wVec/LGo/UV9QfCGSXw/+znPrLHY1xBLdHPfzppJR+O1Vr67CR5KVn0SO+etl5ng uj/tP3vhPUZdB1Oy/tXTbK4kgiljYx3UcEbFUBJykhAGMnBNew2r/s+/tABba8+znU5RjEn+h36k +jcB8f8AAhX5gG9e4uZbgHHnOz8/7RzXceFNOl1PU7Wzh/100saJj++7BRg/U1rUqckbs+0yjKfr uIhQi7OTsd98WP2bte8L/Fa5+H3gQv4lSRUmtmgwzLE4yRNjhGjPDZI7HvXh+u+EfHXwu121n1rT J9I1CxmSaFp4yFLxnIIP3WH0PSv6MPj74e8NfCv4Cz614csLeyufCCwzWQRdiySMyxSLIV+ZhKpO /JyTg5yK/ODS/wBqP4Y+N7dtC8fWQ0rzvldLtBdWTE/7eMr/AMCUfWtYylCXLLfc6ZUaWJwCxuFT 5OZwd7Xbik76dGpJ9bO6v1f57fFT4y+KvizBouma5Bb2tnoKzCCO3THzTsGkZmbLHJUYBOB2rlG+ Fnja68Gnx5BprnRQC3nblzsB279md2zPG7GK/RrxL+yd8L/iDa/2z4AvhpD3GWR7Vxd2Tk/7OSV/ 4C34V8gfEbxF8VfglY6l8BdbntZbXyFVZ40y7Wk53gIxwQpOeGXcORXfBraJ8NWjbY+WRCSwVepO APev06sLeDRdM8KaU8YJ0S0+2OzKCRtibdj0579a/OTwlp82q+JtK05Pma5uoUx9XFfo98ULnT9C 0LxDPZjbeQ6aIZCpLY8whI0JPTILED8fSvVoz9nGpW/li3/X3HzOMs1Gn3f9fmfnFezS6n4gvtSk ky0jux+rEnj86Ty/lxnkmqlorefcuudpYj1zir2HaTC8gDr9a+Iq6RS7Hz+Kldtnf6PaFNCY5/4+ pkj54yM5P6V9LfD+1LaU1xgL9okB498t/WvA9Hspp4dLs403kCWdh6BVxu/DOa+pvBlgE0yyjUhg xZxxjjO0fyr3OFaXNUqVPP8AL/hzobUML62/zPWdGtgqruGAK9D063zj0rldKt2woP0rvtPiPHHN fqEjyOZXOl063ZsEdK7/AEy0Llff8q5XTomGK9D0eFzMij+LFedV2uddPc998D6Y0dismME16ALc gYOMCsLw8j29lGB1IrfMkmME4r4yreU2z6eDtFIga2wetVJIWOQTVtnkIB9KqyO45BBz0qVEq5ny wNkkGsu4t2GewrUlkkznOazZ5JCDk4rRRJ5j/9H9ZRakxiaBhLEejLyKaF5xX4e/BH9tz4g/DNoN K8QOde0gYGyU/vVX/ZY9fxr9cfhR+0L8JPjJaRtouoJaakQN1rMQkgJ9j1rxquFqU9d13O2M4yPV 1BBqda1JdO8o7vvqe4qIRRV51zYtaVHuuB/s811yDPOKyNGgi3PIe3FdOsUXX+tK4ysFyanAPerC RR9asLFHmmgIVHFTL0qZYkOKnWKPNNEuRGMVYWnrFHU4RAOlapGEpoYvWpKcFA6UxeJGBOehrVIx MPxZqH9k+FtY1TOPslncTf8AfEbN/Svin4HfbNI/Zx1HUbZvJ/ta+u2eTglkDCLg+rbdvfAr6i+O F8mnfCjxLcO21WtfKJHXEzrGcfgxr4Qht9Z0bwQmq2Gp+Z4Xs4JbiKxRs/ZlulaQPIOoZiMgZI5z xnFfIZrX9njqFFXu09VsrtLX1SaPWwdLnhKd1pbTq/Q/NDxVqj6h4p169Xh7ie42+gJYqP5V9lWn iix8Vfs3weA/hvZXWqeITZxQTRJCUitTHGEPmTuVj3/eKopJOQeBzXwXcTBi903DzMWbnuxzXX+B PjV4l+F9xMmhmK4s7pw89rOCY2YDG5SMMjY4JHB7g19pH+XoejFXtY8W1jw9r3hS+bS9fsJtOu0y DHOhRvwz1+or3f8AZu0b/hIfi94N0fbn7Tq1nkYzlY5BK36Ia+o9G+PvwY+LFlHoXxDsYtPmk4Ee oqJIMn/nlcD7n47a9e+F/wACfh/8NfH+j/GXw/fP/Yuizedc2zusqJDOrRfaIpRyyQlwzg5O3Jzx WVezWp+g5Djfq9Rza95KXL5ys+VfN2R7r/wUO8RJo3wCOn7sSatqNvCB6rGGlb/0Gv53NQlLysc1 +w3/AAUm+Juh+JtP8M+G/Ct/Hqdvp0lxLdzWzebAkzhFRDKuU3hdxK5yM81+Nl0yF2zwfrXVbmrS kdFKX1XIMNhZK0m5Tae6bdl98Yp/M734S614wtPHWi6H4W1i70j+2b2C1lNrMY8pI4D8crnbnBxk V9aftnfD74feFPhtoGp6Fp32bVJdSljF0ztLcXCGPdIZ5ZCXkbO0gk8ZOOtfP/7MGjrq/wAbdAZv mTTxcXjexiiIU/8AfTCvof8A4KEamlvp3w28KIRuFpe6lJ65uJhEmf8AgMXFelHSy6s/McTLmqHx v+z9pLax8U9EUKSto73DH0Ea9ePfFfTvxy1yJfAl3cWoMcerX6JnbtDmHczv784XPfHoK83/AGR9 GWfxNrOtMhYWVqqKfRpG/wABXV/tXX6eVoukLwqJNMwH+0Qo/ka6qz5cHU/vNL8Vf8LnzGIn+/iu yb/M+MbV3WE7lwSSSK0bUNI6+p71d0zSWvbFJRJ3IGT09jV620e5huF80ADcF6jP4V8XXqxblFPU 8GtF8tz1rw3H5SX12Rj7LZRxD2aZsn9Fr6t8NWf2aG0tj1ghjX6HFfN3hixW706SM53X+oxRJ3yk W1T/ADNfW2i2qm7dyMjOPpX3XCtK2F531NsX7sIRO80yDlSOw7V3enW/I21hadb7goFd/pdmpIIF fczPIW5t6fb8AivTfDdm011EoXPI6VzWn2SALxzXrngzTklvF44Xn6GvGxE7RbPRoL3kj1uyh8q1 RRxxVojgA8VeWGNRjt7UrxR4PrXyR9JcyiCOlU5Bj3rZaFM54zVOWJNpGcf/AFqtCbMVwRx3/lWd KBgnGT3rekijxz3rPliiweOK1sZn/9L8tLZleZAfWvoHw/ZeTbQ3lrI9tcxAGOaJijqR6EV4Bpab 7yNR0Jr6S01RBp6/7ore7Wxzu59OfCz9uXx58NLuLQ/HGfEWjxkL5h4uEX3P8WK/Uf4Y/HT4V/GO xS58K6tGLsgF7d2CyqT2Kmv5wfEkm+8f1BrM0nXNY8PX0ep6HeS2V3EdyyQuUYEe4rGrhKVXyZrT rSW+p/WPp9u1rGQxzk9a1lOK/DL4Jf8ABQ7xl4R+z6N8Tbc63p4wv2hOJ0HqR0P4V+t3ws+Ovw2+ LunR33g/V4biRh80BYLKh9Cp5rwq2EqUtWrruelGpGWx7QvoOlWFzmoFXPPNWVU+lcZqToTxU61C mfSrCg4wRTJZMuR9anU9jUKA+lWFz3rRGDY8HHAqPOLtR6qamAqDBN4v+yh/U1djNdT5z/az1E2P weu4lkEbXdzBHyccKTIen+7XzZ8dtRtfDn7Pfh7w9Yvs8vQ0llxld7XEKRqX9/nJGe1eyftlNc3P g7StJtYzK0k01wwAz8sSBP5yV8sftf8AiXTb/QJZdFvYriyuYrGGBoz8oQKGK/UBeR26V8s5qebu KesYxT/F/qjvopqK/ryPy3vjtRowM9cfSuKnZjIcg19RfB74Vn4u+NrbwbPqbaVFJaTXDXAQOVYF UQEHoCzcn0BwM17Zf/sweCfFmjvbaLNL4c8RaSzWd7Ezm5hFzDwxcH5wJPvqwOCrAgV9nCLtzHqw qJOx+c7SspIHIrXtvGPifT9Km8P2eq3Vvpc5Blto5nWBiPVAcV6J8QvgV8Q/h673GtWBn05TgXls POhI7ZIwV/4EBXiskaMflJBOeW4BrTlTPdw8mveiz7f+DP7S3hnSPCFr8OvibCxsrbdHBc+Ss9uY GOQk0QGQVyfmAOR155rtfE/7Nnwi+KVg3iD4d6hFprTDKy2Li4syT2aPOU+gI+lfmvM7dGz6VoaB 4w8R+D75dU8L6nPpd4p+/A5TcPRh91h7MDW8U+hz4qbbcm9T7w+APwa1/wCEXxbu7Txg0JfUdNlX TZ4W3R3G2VTMFJAKuqhSVODg5GQCa8D/AG2/E8niD42S6az7o9AsLOwQDooRPMP6yHNP1r9rvx1r Xha10rVdPtJNc0y6iu7HVogY5YZI+CxiGUYupKt/CVJyOlfLviTxBrHizW7vxNr92bzUtQkMk0jA Asx74AAx2AFdEIy5ryPnqr3fc+5P2RdKkg8J67q5XKXVysQb18peR+bV5L+01qhufHEtmvzLZxRw nHqRls/Wvqf9nnTv7H+EOjKwAa6Mt0xxg/vX4/QCvhT4s6g+tePtWZHDs1ywHocfdH5V145cuGpr +9f8GfHVql8RUflb8jn7G2vYYEvNOZfLlBJQAlfpg5P55+tddoUj3FtcS3ESxbcDqevXIFcb9g1a xywlZeAcLkdumK7TS7i7l0G5+0KQ5ICtjBYkYx71+aY9OUHLR6/PcmL95Kx7b8PbMyXPhuzKD5Y5 b5zjJy+5lOffK19UeHbNnYkjgmvIfhtom7WNReNQV0+3htY8dsAAj/x2vqbwv4dn8tD5eK/bMlpq ng4L+uxy492q8nZWNnSLFnUAD2r0/S9N2Y4zmptG8PtGiblwBXa21hxwMYr06lVPRHnxj1IbK12/ MR1r2XwTZbMzkZrhLSzOcAZr2jw3Z+RYq2Mb68TFz92x6+Fj71zd2Dr0phBA9Ks7SD6ioip+hrxE j12yk/OfSqbjBwetaDBvTrVSRT1rVIhszZAeq9/zqjN0AB7fWtSRcn0qhInHGTWvKRc//9P8yvDi JJfqGHcV9GfJHZY9BXgHhOFG1BCxGQRXut/NFDp5y44HrW7OeTPHNZlR7x+3JrALqD9au6hcRtcu 24VjPPCDjcMVqyEmWDIAeK2fD3irX/CeoRax4cv5tPvIjlZIXKH8cda5Z54iOW70wSIwJVs9qak1 saJn6t/A3/gpL4m8Om30P4tWn9r2Ywv2yEYmUerL3/Cv1u+GXxz+GXxb01NQ8F61DdlgC0O4CVD6 Mp5zX8mq75TtjUsenFej+B7vxt4a1OLV/DN/Ppl1GQVkhcoePXHWuGrhqM9fhf4HTGrJbn9cSyx9 e1WFlSvxV+D3/BQHxr4RFvo/xf086vYjC/brYfvVHTLp3/Cv1Q+Gvxk+HXxX0tNT8FaxBehgC0YY CVD6Mh5BrxqmGnT13Xc6VKMj2JZUA4qQSLVFB78VOtYIlxRa3LUELrJJJIOmdo/Cl68etPjVUUKv AFa3ZmfNP7S1nd33hO+awsBfT2tqApDYeHzpQTKACMhRFk1+Vfx1vUXwD4VtmcNLdyyyvgjOFXHI H+9xX7C/Ff7O/h3xBbXMgVpLJ32Eld8UUTZ59N7Y47/WvxT/AGhJY11DQtLi4W2gB59W4P8A6CK8 6jQi8TUrOKv362scOGlUePceZ8vLt0vff7j0T9kaFG8fazqZ+5Z21lbggdC7tK36JXzz8aviJrtp 8cNb1zQNSn066iaKMSQOUJ2IPlcdGA6YYEYGK+sP2SNNZPDHinxCRs866nAY90ggWFT+DSNX5y+O dTGs+Ndd1Mf8vN7M3P8AvEf0r2W0rLyPtcPHmmz7E+HX7XV7E0em/ETTBfQuArXdmoDkH/nrAflb 32kH2rT+Lv7P9r8TNR0X4i/B/TDYeHtZ8uC5u5oDa2Au3YhXjBG4hvuttXbv4Bya+KtBhXzt2Pug nFf0Lanp9l4G/Y5NlexLjT/C0ZYEfduGhVgw91lbcD2IBrm1lKVnayufpmHwlDDUcPVlDmlVqKml e2j3fqrq3TXU/CD4ofs1/EbwB5t61oNX05Mk3VkDIqj/AG0xvT8Rj3r5fuQUJVs5/lX6BeFv2wPE ejXAsvHtmNYtlO03VviK6UerL9yT3+6fc16nc+Bf2ev2kbd77Qp4rfV2G55bPFteIx/57W7cPz1O D/vV3Up6XZ8zm+Glh606T6No/NRfhf40vPBR+IFtYh9HXd84kUybFbYX2ddgbjP9K4I2UgvFtMHM jBV6H72AOnWvon4p3Pjf4I3Gq/BK08QW+raHKgdXjVC4in+ZoyQWaI5B3pn3HBryP4aaT/a3jrQN OChvPvIVOeRjOSfw616kXdXPhqm9mfqVpNqug+BrGyjAiNpZogB/vKuB196/K6/lXUtZvb9RxPNN L7YLkj9MV+qHxOu0sPCWoTO2z5CMjtgEg/mBX5q2OgRSFkhYyM0Z3AcMD1Jwev510ZxeFGEbbb/g fmX12m8RKLkk5bfeXLb7ULO2XPmFgdwcZOD0rtYrYnUND0qMf8fN1bjb/vSAn9AaoaVZRyIu5sJC ANzcHA9c11vhWOG8+JmjRJG222d7gqQCB5aYVgenLGvyCpapiIQtu/6/M+poLVPvY+3PgF4dTVp3 dlwuqai/Xn5Y+1feFp4TsbEDy06e1eCfsweBLspbazNuNhpkUm3IwJLy5JZiMdo4ztx6mvs97ADo v/16/badW0IxW1jlrq9SUn3OETT41GQPwxVyO0Vccc11H2EAnjFL9jAOMV0KZzcpn2dqnmIMdSK9 ctEjhhSMfwiuM0uyDXCfLxnP5V3W3jiuDEO9kd9FWQvmITzULSLgilYdqiYEc1zKJ0uRG0iYJI59 qqSOmMjrU7g44wapuoOOK2USHIgd4z2x+FUZWAq3IF6A1RmU46Vpyk82p//U/KjS9dl05y6x5P1q 9qPje7uINjIR+NfqX4y/4Jd3nhfwvqevp4sFw9hbyTbDEAGKLnFfj5qMciSNCBkoSvHrmtlqGhLJ rcr87ahTV5HYKygA07T/AA9qmoMuyIgGvSdG+HLZWW7HA55olUit2NROYt7C9vcfZ4ywbkV3vh/w Jf3DhrkbVP4V6xo2i2NnbII4wxHf3rpo2KHgAVzOs38JHLY5vTvBtlZAFk3MOfxrpI7NYVCxqBit Esx5AppJPNZcze4LQrfZyRggEHtTNLXWfDOqJr3hDUZtF1GM7lkt3KZPuBwau7iB0pnmt3qozlF6 Afd3we/4KA+LfC7waH8Z9POo2Ywo1K1Hzgesid/fFfqZ8Ovit4B+KWlR6t4J1mDUInGSiOPMQnsy 9Qfwr+b9pgQQwBz69KTQdU1/wdq6a94I1KfRdQjO7fA5VWI/vL0NOVKnU1tZ/gaKb2Z/UaIzTgp7 V+P/AMHv+CiWvaM1vofxr077TDwg1K1HOPV07/hX6i+A/if4I+JWlJrHgzVoNSgcAkRuN6+zL1Fc U6MofEV6HZ3lhZ6hbtbX8CXELjBWQBgfwNfit+1h8Pobn4neKNXtZhpttpCxmCFgWEpCZYIR05JP OfSv203E8V8M/HL9l3xB4w8Q694u8J6mk0euw5udOuARiZIwm+CQcfMFGVYDnkGpUYu9jWi1GfMz 81fgD8QL7Rby98Eah4mfw9omrq7+Yixq0jybVeHz5A3krIOcqMkjgg1Z+IX7H11Er6r8Nr8X0b/O LO6cCUg/885vuuPTOD715L43+FHxB8EO41zRbi0hXKkPGdgx0GeVI/GqHgn4y+Pfh5KLfR77zLJT 81jdZkgPrtBO6M/7pH0NCWnmfQ0Z63izH8LeCdfh8ZWHg3WdPns7++u4LUwyoVf99IsZwD1GD1Ff uL+3BraeFf2a9Zs4CE+3PaWCDplS4Zh/3yhr4R0D9p/4T+KdMNx4zgbQdd0sLcWUjw/aTDdRENE9 vIoyQGHKNtypIPrXS/Hr4peK/wBrr4R6Z/wr/SobW1026Mt1FLdL5891HHsZY0AwqruJXewZgQcD vjFP301q7H6dh8V7SeAqzsoYecpvVb+642W7u420vbrZH5HX84knfIBLGpvCel3WqeLtE0yxkeC5 v723tkeN2RwJpArAMpBGQSODVfxLo+t+HNTl03XbKWxuoiQ0cyFGH4Ht7ivTv2dNPbWvjR4ZUjcl lJLeOPTyImKn/vsrXp0oWSPjc2xiq1JTXU+of2zfCfgfw38J9Bt9C0e102aPVHW2aCMI3l+WTKGY fM+75CSxJyK+Rv2bdI/tb4qaSGXcLNZZz6fKnevo39u3XC3/AAhfhtWz5cFzeSL6GVxGh/JTXD/s c6O03iDXtcdMraWqQq3o0jZI+uBXoUFztebPgsVU9nRnLsmfRXx4u2g8IyWacfaQVPqQWRCP/Hs/ hXxLHYuszGCPeuMFTjJB+h/l0r66+Pl1vW0sV6ApnJ7hXc/hh1r5q+z73VfLLhMFgvXHevSxs7zs fyfm2ObxvIulkJoxe2uQssrG2b/WIy+YMdwGHIP5V618M/gl8UPihNcX3wf0yIXsDC0mvZ2CJaxz 8GUZ43BcnHJ4zzXnWlW0qCaVyuUVirElWBHb+9k++RX7MfsE+Hf7I+Ddxq7JtfV9QkfPqkKhF/DJ NfOSwWGlVVeUE5Lrqvvtv87n2PCuZYyrj1hud8ii21o+y0ve2/Sx9KeDvA1h4K8Lab4V0pP3GnQp Fu7yOAN7se5dsk1vvp7DkjrXSyZ+9jpUD5xwK9NNn7VKKOXNgwJyKZ9hYHp1rojuzgAVHhsgEYrp jJmLiiLTLNkJkxzW0YXxiktt0ceccnmpWlYktisZNtm8bJWKrQvzjk1AYnBq00jdhzULSv1wMU0m JtIpPG3eq5ifkHrV1pD06+tV2c55AroVzO6KDwv0AqhPC4XgVqSS46CvI/jT8SLL4T/C7xN8QtSI EWjWUsyKTjfNjbEn/AnIFXZgnd2P/9X9tfH+mrqngzWrHHM9pMo/FDX8tk3w50+x1K6SddzJLICM dwx9a/rDvrNZrSaE8h0YfmK/m5+JGkDS/HWvaf08i9nUD/gZqKkrRuhR1Z47b6PZ2oAgjC46VbNq B0rXMKjoaaYVPU1573NLFezXAZB35q6I8e1JBEiygk1omJAOtaqxNhFXKD2ppBBx1qeNVCnNQOUA PzVqjJkTMBknrVKSTrUrEMeDUJQHqa0SJuRkluR2pQDT0QA9an8ocGrGNWNZF2OAQeoPNbfhbWvE /gXVU1vwNqs+kXiEH905CNjsy9DVBBu2jpirsEQZuKXO0arQ/SP4Pf8ABQC6tfI0T4yWBzwov7Ze D7uv+FfpT4P8eeEfHumpqvhPVIdRt3AOYnBZfZl6g/Wv51Le0ilG2RdynqDyK73wbqXibwRqMere DNUn02ZCCVRyqtjsR0/OuWSg/I6klI/oI1fw/ouvWz2msWcd1E/VZFBBr5E+Jf7DHwd8fPPd2MD6 FeSD5XtcBQfUr0PPtWH8JP2tG1C1i0/x7EHnjADTRDbL/vGPow9Sp/Cvs/w74q8O+LLFdR8OahFf wHqY2BKn0ZeoPsazhaT0E1Upan4d/Fb/AIJ3/F3woJL7wXNB4mso/m2x/ubjbk/wsdrH6EH2r5Z0 HxT8W/2fdUuI302bT47lx9os7+BhDMY+Mg8FWA43Kfrmv6i8CuO8T/D3wT4ztZLLxNo9rqEcgIIk jUnn3xXWo9zup5hUiuWWp+HOlfGj4KfG6xj8OfEaxi02/f5US9I8veR/ywuhgqfQNt/Gp/C3wT0D 4JfEzTPF2nXclzoevRy6ZE020taXNxteIO44ZJgpVW4+bAPWvs74r/8ABNv4TeLYZbvwU0ugXrEM VjbMbDuNjfLz+H1r4/1H9j/9obwfBJ8PofEUl54SvHjaaDkuqRuHURbgxjYsowUIA69RVcjvaLG8 TCWrPlD9sm91LU/izNmKQafYW9vYxyEEI0kaeY6g+qtIa9x/Y/8ACd3pfhLWdduFdE1WaFUB6MkS khvzY10fxA+H9rpMN1o/j/WdFtVMSxtbXlyxnhGPlCqAXVh13Yye+cmvuv8AY++CmhQfC/T7SSYa tpMzG6WdlKmVJPuKuQGAI5yMZGCOor2cPT9k1KeyR87mV69CVOnvLRHwj8bJ9O1XVrKzsdsjWULr cEDjznboT32oAPbpXgd1YZdcKYyq7Sw75zkke+a/Z/x3+w94E11pbzwfqVxoVxIS3lyf6TAWPP8A EQ4/76P0r4t8efsh/GHwk7zQaUNes1z++09vNOB3MRxIPyNZVakasnLY/k/Osgz/AA2IqYiVHni3 vD3lb0+L52R8dpbuLZ/MjD79oDA/dI77TyCcV++/7OvhoeGPgp4R0sptkNkk7+u6cmQ5/wC+q/GH w38PdY13xlpngsWM0eo3t1FbmGRGSRdzDcWVgCAoyST0Ar+gbT9Mt9N0+202DiO1iSJR/sxqFH8q 5pLl0PuPDqFStPEYqpG1rR/Nv9BGTtVdoweAc4rUMKk9aiMCgnmmmfvLMsxgDpUQjycVqmJSMU0Q Ju71qpGdiDgLgdqaf7v41baJfWozEDlgetJNAyky549aiZQTgVcaLB9qiaNexrZMhme3Wq5AzWkY 15HOTVVo1z71umZmfIuM+lfkb/wVC+JZi0bwz8GdOlP/ABMpTq+qBT921tSVgVvTfLkjPXbX67ze XHG7yvsRQWZieAoGST9K/lo/ae+LM/xV+LHjLx9ayu9rqV1/Z2moCdpsLJvLi49Hcb8e9bRV2a0l rc//2Q= ________________________________________________________________________________
Subject: Fwd: DATALOG SCANNER
From: Lapsley R & Sandra E Caldwell <selrcaldwell(at)earthlink.net>
Date: Feb 04, 2019
I have an RV12 with D180 and D100. I use the Datalog capability. I written Excel macros to allow me to graphically scan through the data. It works in an animated fashion or in steps. The current version supports D180, D100, D120 , Skyview and Advanced Datalog files. If you would send me a request to at my email /91827364(at)earthlink.net/ I will email you a copy of the "DATALOG SCANNER" program. FLY GUY 91827364(at)earthlink.net ________________________________________________________________________________
Date: Feb 04, 2019
Subject: Re: Fwd: DATALOG SCANNER
Fly Guy, I just finished my plane and performed the first engine start this weekend. I have the SkyView DX system and downloaded the logs after the run and fou nd them very complete but almost unusable due to the incredible amount of d ata. Your logger spreadsheet sounds like what the doctor ordered and I would gre atly appreciate a copy. Just one additional question, do you use the temperature and air speed in t he Celsius and Knots form as stored on the log files or convert to Fahrenhe it and MPH?=C2- Thank you, Robert ReedKIS Cruiser N247BR RobertR237(at)att.net On =8EMonday=8E, =8EFebruary=8E =8E4 =8E, =8E2019=8E =8E09=8E:=8E07=8E: =8E06=8E =8EAM=8E =8ECST, Lapsley R & Sandra E Caldwell wrote: | | | | | | | | | | | | I have an RV12 with D180 and D100.=C2- I use the Datalog capability.=C2 - I written Excel macros to allow me to graphically=C2- scan through th e data.=C2- It works in an animated fashion or in steps. The current version supports D180, D100, D120 , Skyview and Advanced Datal og files. If you would send me a request to=C2- at my email 91827364(at)earthlink.net I will email you a copy of the "DATALOG SCANNER" program. FLY GUY 91827364(at)earthlink.net /9j/4AAQSkZJRgABAQEASABIAAD/4RAMRXhpZgAASUkqAAgAAAADABoBBQABAAAAMgAAABsBBQAB AAAAOgAAACgBAwABAAAAAgAAAEIAAABIAAAAAQAAAEgAAAABAAAABgADAQMAAQAAAAYAAAAaAQUA AQAAAJAAAAAbAQUAAQAAAJgAAAAoAQMAAQAAAAIAAAABAgQAAQAAAKAAAAACAgQAAQAAAGQPAAAA AAAASAAAAAEAAABIAAAAAQAAAP/Y/+AAEEpGSUYAAQEBAEgASAAA/9sAQwAGBAUGBQQGBgUGBwcG CAoQCgoJCQoUDg8MEBcUGBgXFBYWGh0lHxobIxwWFiAsICMmJykqKRkfLTAtKDAlKCko/9sAQwEH BwcKCAoTCgoTKBoWGigoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgo KCgoKCgo/8AAEQgAYACAAwEiAAIRAQMRAf/EAB8AAAEFAQEBAQEBAAAAAAAAAAABAgMEBQYHCAkK C//EALUQAAIBAwMCBAMFBQQEAAABfQECAwAEEQUSITFBBhNRYQcicRQygZGhCCNCscEVUtHwJDNi coIJChYXGBkaJSYnKCkqNDU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6g4SF hoeIiYqSk5SVlpeYmZqio6Slpqeoqaqys7S1tre4ubrCw8TFxsfIycrS09TV1tfY2drh4uPk5ebn 6Onq8fLz9PX29/j5+v/EAB8BAAMBAQEBAQEBAQEAAAAAAAABAgMEBQYHCAkKC//EALURAAIBAgQE AwQHBQQEAAECdwABAgMRBAUhMQYSQVEHYXETIjKBCBRCkaGxwQkjM1LwFWJy0QoWJDThJfEXGBka JicoKSo1Njc4OTpDREVGR0hJSlNUVVZXWFlaY2RlZmdoaWpzdHV2d3h5eoKDhIWGh4iJipKTlJWW l5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uLj5OXm5+jp6vLz9PX29/j5 +v/aAAwDAQACEQMRAD8A9x8GeMNa13UpbbU/Cd/pUSQGVZZd4DMGUbPnRRnBJ69q7R5GXfiGRtqb hgr8x5+UZPXjvgc9aidISx3RMWJGW2kk4bI59AelOjZI87Vk5JJJDE8knqe3J47dqSuTCLirSdxk d1K6OWsblCpACs0eW5xkYY9OvOOD68U+KaRo1L20iMYw5Uspw39zr1Hr096f5w/uv/3wf8KGlAIG 1zkZyFJxTKGxTO6oWtpYyzMpDFcoBnBOGPBwMYyeRkDnDZLiVFlK2c7lCu1VKZkz1xlh075x04zS vcbSMRSuCQPlXp7nOOBTVuiZNpt51H98rx1Pvn36d6AEuHm/fI1s7xlW2tDKAx4GByVwxJbGDjjO RnhkcIiYhIbtg4WMlpywAG4Z5fj1JHJyOpHFnzh/df8A74P+FHnD+6//AHwf8KAGG0jN0LjdPvA2 4859n/fOdvfriktrOO3YGNpzhSv7yd34Jz/ETz71J5w/uv8A98H/AAo84f3X/wC+D/hQBJRUfnD+ 6/8A3wf8KPOH91/++D/hQBJUF9ax3tlcWs+fKnjaJ8HB2sMH+dP84f3X/wC+D/hR5w/uv/3wf8KA OW8C+AdI8FNfNpDXBN4Ilk8zYB+73bcBFXn5zknJPFdTMzxx5ijMrbh8u7HBPJ59Bk49sUecP7r/ APfB/wAKPOH91/8Avg/4UAV47WGOYXU7I9wDsWUjBGcDaPqQPxxXOfD3TfFunLqC+MNUs78SMrW3 2YAeXksXz+7TqSvr07V08BZITw8hMrDsCAXPsvA/PA/i6mbcf7jfp/jVqdouNt/60IcLyUr7EZtY DZ/ZPKQW3l+V5QGF2Yxtx6Y4qVlDjDAEZB59RyKTcf7jfp/jRuP9xv0/xqCx1AGOlN3H+436f40b j/cb9P8AGgBdoPbnGKqStqCqWijtZDkgRtIycbuDuwf4e23rxnHNWtx/uN+n+NG4/wBxv0/xoArx Nc7NzQQpITll8w/3fXHPIHbpzweKsRRpEpWJFRSxYhRjknJP1JJP40bj/cb9P8aNx/uN+n+NAAqB Ywg3YA28sSfz6/jSSxJKoWVFdQwYBhnkEEH6ggH8KXcf7jfp/jRuP9xv0/xoAR4kkaNnRWaNtyEj JU4IyPQ4JH4mlKKZFcqN6gqD3AOM/wAh+VG4/wBxv0/xo3H+436f40ALgfpijA3E9yMUm4/3G/T/ ABoXduJJGzAwuOQec85+lAFWyieO32xFE/fyO2VJyC7E/wARweeufwHQXKhgG6I4OP3jcqP9o+3+ fXvU1ABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABTcP5jEldmBgY5B5zzn6dux9eHVGvnfaJAwj8j Yuwgnduyd2R0xjbj8aAIGkUbVmhkdGcnOzcFYONvGSepznGBjJ28VNmP+4f++D/hUEUCNItwqI08 ZkjVs4wrOCw4H+yD9R16mq8v220gdyslysSBgts6h5WLHcMSnCgDaQd/OTwMDMyk47K5UI82ly3c XFtbQmWb5EBAz5Z5JOAAMckkgADkk4qBrmRxci2sH3pGrQvP+7jmYg8ZAZlxxnK9+M80tpFLcXCX s/2uA+WUW1kkXCZwSSEyC3y9dzYGcYyRV7HuaSbfkV7sfP8Ar+v61M4i984Pm1MRdCYvIcELtww3 55OcEHaOBjHO4OhuZZvLI054RuXzBOQCFKZJXZuBIYhSCR0YgkAbrJs7dmRnhR3QAK7jcwx05PND wxXSK4dypGVMcrKCP+Amp/eWen4/8AfNF7r8P+CZ6RaoLlme7sDb78hBp8gYLzxu83GenOPw9LUt x5MhMtsTASio0SM7ZJwdyheADjkE9STgDNOmhtre2YzTSRxcZd7hhjsPmJ4qpcXEOntbSReZMk27 rcs5ZQpb92hJLtgZwP4Qx6gAkVVulZfe/wDL/IJVIvWX5Jfl/wAEuW1za3UPm2zpNESV3xjcMgkE ZHoQQfcVXs79Lu4fyoU+y7AY5DndJz1C7fuejZ55wMYJx7of2xqASazlntkibzY0EsSzEA/u92VW TG4KY5FCku2DlHUdN5MTQmPYhibJKkZBzyfrmqkqiYlKk43jr+n+f4FWBbgXUzXEkD2xx5UaWrK6 +u5ixDfgBTL23kuFKpeS2g3qyNbwLvwByp3qwIPsAas/Y7RFAFvAo6D5AKqNqWn2+h3OqWbwz2MU ck5e1KsrhAd2COCflI/ClFTejX4v/IOezuvyQuk3NrdwzXFuJCHndH3BmAdD5bbc9BlO3uepNXcx /wBw/wDfB/wrDtpJrTxNcWdlbQ/ZTFFcXHBDs0jSLvDHhiPLGQcEqcg/KFboVIYAggg8gjvVpvZ7 ktLdEWY/7h/74P8AhTkJ3HCgR4GD0Oec8Y+lVtavRpuj318wBW1gknIPoqk/0qwDMbiQFIxCEUo+ 8li2TuBXGAANuDk5yeBjmrO1yLq9iGw8027eblX86TG4H7vmHHUnqMfn0A4FUabcXdmYtanguXEm 9TbRyW6FcYCuvmNvHJyCdpzyOKsW6+XakXP7rM7EfvAM5kO3lcdeOPfByc5n3w/89R/33/8AXov0 C3Ux7N/7IBszKVQThIvtsrYlEjAjZKxYuwHmfK2WLD+FStWvteoZljFnaNcDBRVuztCnPLkoCucH GA2SO3WruYNwbeuQMA76XfD/AM9R/wB9/wD16G0xJNaGNcRX+pyx2t/aaZ9mBDyxmVpwVzxlSqg9 CACCM/NkFArWLmwvWgurezmtLWGQEJ+5YsSwYu5KOhDFmB4OeCc5b5dHfD/z1H/ff/16N8P/AD1H /ff/ANehO2wON9zKXR53ntjdXm+G2MojWNXDlWUKu52diWC7suMMSeCoLB9S2tYbZV8pTuWNYvMd i7sq52hnOWbGTySeST3NLvh/56j/AL7/APr0b4f+eo/77/8Ar0OTegKKWo6aGOdAk0aSKGVwHUEB lIKn6ggEehArFg0e5KG3luXhs4tnkRxeUypsZtoCmEYwBGRycEYGNuW2N8P/AD1H/ff/ANejfD/z 1H/ff/16E7DcbmJF4Ztlilhkjs2iuYpYbpktyssyNgAebuLdAdxJZmJzlas6rp15eXNtGl2q6Xgx 3VsY1YzIVOQzMGyD8owNpwWO7oK0t8P/AD1H/ff/ANejfD/z1H/ff/16akxOCK+qLd+TnT4YZJmI BMk5hwByCCEbPPYjHJ+lY7W2uOkkguVsZS4aSC3IuBKAvJiaQKI2buCCuVB43MT0G+H/AJ6j/vv/ AOvTWMDjDujDIOC+eRyKhrqty02uun9fP8TNmtk1XStVsxezTiUS2zrKiqYiVI24Cg4wQQT1BBBI INa25jIybHChQRJxgk54HOcjA6jHI684zb61idfNhMUtzEuITJO0bD5lbaZFy20lF3DndjByOKsa TdPd2UTSKnmeWPNaOQOglBIdAQScqykH+fXApSkrSE4wTvESxl8mxmlumRFSWZmYswCoJGwSXxj5 cE9v7vGKtxSxzJvhdZEyV3KcjIOCPwIIrlbvXLTSWlFxrNrbNKZESCQw/IxndRKAGBx13A5+6Pus G3QQ+LbK28hZ/EOnXmxV81lkhQS/fzgeZ8pyU9eBx1OGB2EM8U+/yZUk2MUfYwO1h1B9D7UJPC8r xJLG0sZw6BgSpwDyO3BB/EVyE3xE0mNWKGKcgvgRXluM7TgffkXqOR24PPTM6ePdFa4aP7TbKodl 8w3kG0gAnd9/OCeBxnJ6YyaAOoaaJJo4XkRZZASiFgGYDrgd8ZH50skscbRrJIiNI2xAxwWbBOB6 nAJ/A1kL4r8PlQTrmlAkZI+2R8frS/8ACVeHv+g7pP8A4GR/40Aa080dvBJNPIkUMal3d2CqqgZJ JPQClhkSaJJYXWSN1DI6nIYHoQe4rHfxX4fVGYa3pbEDIUXkWT7ctXPQ+I/D9tLbpFdTupmYl31y JwnyoNzbrjJU44AB5DHAzlldXsNRbO2tbiG7t0ntZo5oJBlJI2DKw9QRwaWO4hlmlijljeWEgSIr AlCRkZHbI5rjl8TaBH5kS3jFLXHlOdZiPn4yRgmfJ54+fGcjPA40tL8U+H1s0U6tZwY/hudRikfk ZOW8xs4JI69uOMVTViU7nQebGZTEHXzQAxTPIBzg49OD+RolmjhCmWRIwzBFLMBlicAD3JrJ/wCE q8Pf9B3Sv/AyP/Gj/hKvD3/Qd0r/AMDI/wDGkM1bm4htYWmuZY4YV+88jBVHbkmnyOscbPIwVFGW ZjgAeprH/wCEq8Pf9B3Sv/AyP/Gj/hKvD3/Qd0r/AMDI/wDGgDWiljmQtC6SKGZCVORuUkEfUEEH 3FG4mR0MbBAoPmHG05zkdc5GB1GOR15xk/8ACVeHv+g7pX/gZH/jWFqXxG0m28Tado1qDfm9aNBc 2sqPHGXcrgkHqMZ+hFXCEpu0SZzjBXkf/9n/2wBDAAMCAgMCAgMDAwMEAwMEBQgFBQQEBQoHBwYI DAoMDAsKCwsNDhIQDQ4RDgsLEBYQERMUFRUVDA8XGBYUGBIUFRT/2wBDAQMEBAUEBQkFBQkUDQsN FBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBT/wAARCAJY AyADASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAAAgEDAwIE AwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJico KSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZ mqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6 /8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREAAgECBAQDBAcFBAQAAQJ3AAEC AxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNE RUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmq srO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEA PwD9U6KTNGaAFopM0UALRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUU UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQBwUPxMWxUXWrRLFY3l00Fl9ljeR0VJvJ Z5j0UbynI6bhmrGg/FzQPEVwkFu11DOyeYYrm2aNlTy/N3EHoNhQ5/6aR/3hU918L9BuJnmMEu8z m5VPOYxpIW3HCZwAXwxXoWAPUVW8J/C3TPC1xZSQ5mFtp7WRMw3PIX8sO7MeTlYo1x0AUDtQBlSf Fz7fdav/AGZZSiHT9Ke8b7bA8R84lTGp9AUIb1IYEVm6x8aL7SbiTSXt9P8A7cgtbySZTI3lGSJD LFtGdxV0jmz3BUDvXcWfw50Kx0+8s4rZxFeQm3nZpWLuh7Fs54GAPQAAdBTI/hl4djsZLU2AkSTH mPI5aRz83JYnJJ8x8nvuNAHHWvxxWObWLW7gt5rrScPcraOSCn2aaQ4B5B8y3lXB7FT3q5b/ABM1 WHVhpWowabZXdrdRx3s292hMcnkFBHzneTOF54yuehFdFf8Awu8O6itv5lkyGEvhoZGRmDsSwYg/ MDlgQexI71EfhT4fW1t4ooJIpLeXz0n81mdn+TaXJPzgeXFhWyP3ajsKAM7VfH2rQ+KrrQbW2s0v JLuK1sVut43Kbd53mbHVP3UiDbzuU5rmfEH7Q0ekwarNBZw3Uen319ZSskhITyIHZWb03Sps9gQa 7uT4a6bfNJcanNc6hqUjRub4ymN0ZAQpjCkCPhmB24zubPU0XXwr8MX2nyWU+mRyW0lp9hdCT88W 1lOfU4dvm685oAfdeMTp3jCXTLt7SOzaBGil3kOkzuqRxvnjMhLbQOf3bVjx/EydPDtpcNb2tzqj XkUU1vBNhRbvefZxcLu5KnqPXNdTF4VsYdW1HUVM4n1BQs6ec3lnCqm4JnAbaqjIGeKbp/g/TtP8 P22ios01hbNG0a3EzSMNjh0G5jnAZVx9MUAeb3nxwvbfwyl+thb/AGv+2V0x4mD7VDWxn2nvvH+r PYMCelXND+MN/q/iCzsjpsCW80iyM+87hbysqwYH9/5iW7DFdtJ4D0aaxNrNbtcRtPJcs0zl3aR4 miZix5P7tyo9AAB0FV7H4Z+HtOv4L2Cy2XEE0k8bb2OGcgkdeVBUEDoCMigDAk+J19JoHii/htLe NtDTZJ5m9lM6vJ5iYXn7ghYf9deelM1z4qX+m3et/ZtKiu7bT7cuP32GLJDBPIxPTaI7hcY5JQ+o rrZ/BWlTWep2qwvBFqVwbq6+zyNG0shCgkkHPIUA+wqGP4e6HFLfSLZ83tubWZS5KtGQFIx2+UKu R2RR0AoAw/Enxc0zw94rTSZlmPkMqXRWFiVaQxLDtx1DNJjPba3oa0PCfxS0bxnqj6fYJexzrCbh TdWzRLJGCmWUnr/rE/76FPvPhb4evry5u57WR7q5wJpvObe4G35Sc9MIBj0yO5rR0fwXpGg3cNzY 2ggmhgNsjAniMiMFf/IUf/fNAFHxf41j0fwnf6tpslvdvb3MdoSxLRpIZ0hYNt5+Uscgc8Vi3Xxw 8PaVaXEl811mzzHdyQ2rmOORTGpX8WljAHUl1rtNc0O18Q6XNYXiuYJCrHy3KMGVg6sGHIIZQcj0 rnJfhD4amWQNazbpSzSyC4cNI52nexz8zZjjbceQUU9QKANHwD4pTxp4aTV4wvkzXV1HEVBGY47i SNDz3KoCfcmuiqlo+j2ug2K2dnH5UAeSXbkk7ndnc59SzMfxq7QAUUUUAFFFFABRRRQAUUUUAFFF FABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAV+Nn/BTjB/ay1YE4H9nWOf8Av1X7J1+f/wC2 V+wb49+PXxwu/GHhzUNLh0+4sreEJdOVdXjXaf5A/jQB8P6l8BRqV5IdAu/KsGmljtLi+lVvtarb xTKybOm5Xc89MBetZFr8EryXWr/TH1O0/cWX24X6t+4WNZJEkLd+GhlXjqQD0NfY2hfsL/tAaNLq k8viDSdQub22kt0kmvpVEBeIRFwoOGOwKAG4G0Vyy/8ABNf46o0rL4o0wNLA1s5+0t80bM7Mh56F pHP/AAI0AeV/sH6bNov7ZnhHT7kAXFpd3lvKFORvSGVWwfqDX7XV+dn7L/7APxI+E/7QGheOvEuq 6XdWlnLPPcmGQtLI8kbrn6lnzX6J0AcH4i1HxIuuNDpl1FHavdLa7WgDGP8AcrIXJ7jJ6fX0rsNH mluNJs5Z2DzPErOyjALY5OKr3vhvT9QuTcTQ5lJ3FgSOdu3P1xx9K0IIUtoY4olCRxqFVR2AoAkr PXWFa8Nt9luw2ceYYGEf/fXTFaFFABVbUpXh066kjbbIkTsrYzggHBqzTJolnieN13I6lWU9wetA GPpP2yDUFiuNQa9SS38zDRIm1sgfwj3rbqhp+h2elyNJbx7XZQhYkk4Har9AH52f8PHvHP8A0Lei f99S/wCNH/Dx7xz/ANC3on/fUv8AjXyZXq/hLwLo2uaNpY8qH7fPo19dyvJLJuEi/aUibH3QAY0P 4GvOVSo+p+bU8wxtV8qqM9c/4ePeOf8AoW9E/wC+pf8AGvff2SP2mtf+P+seJbTWdLsNPTTIIJYm sy5LF2cEHd/uCvzs8ceGR4O8U32jrdR3otSg86MggkorEcdxuwfcGvrP/gmj/wAjN4+/687P/wBD mq6dSbmk2d2X47FVMZClVm2tbr5H3tRXlnxG+JWr+C/Ed4sNk93pNpZ2l3M0ewFMtdmReeSXEKAY 6Ee9Uv8AheV7HrFtZtosc0BuLe2nuoJwy7pbkwbk9VGN3413H3Z7BRXK/DTxs3xA8KQa01jNp4md wsUylSVB4bn2/UGtPxfqE+k+E9avrVglza2U80TFdwDrGzA478gUAa9FeM6j8fbjRvtH2rRmKQyX cayo27zPKkaJOB0Lsjt7BfUitzwD8StV8Z6/YpNp8Wm6dcWl5IIpSftHmQywISR2X943v0oA9Koo rxXxd8XtW8CeNNee8jlvdAhuobOC3WBVKsbeGVvLYDLHDuTu4GVA60Ae1UV5R4V+Nk3iTxVDof8A ZeJGiaSS6tm82FRsdlO4ccbCCPVhjvWVpv7QLqujWT2g1O8utMtpHnh+UG7kjhIQjoNz3EQ46ZOa APbKK8U1T9oCZdJvRaWNvHqWJRamSYNExFsJ1zj+6rAMOxVq9mtZDNawyMVLMgY7enI7e1AEtFcp 8QtT1TTbPSF0iRo7i51S3t5CiIx8pid/3+Og+vpzXCN8er64s4JrPRI5mkjkm2mcY2iGOZVz/e2y 4b0ZCKAPZScdaWvEtd+O7JYW8b2/9nXQntZZvmDYi+2rFKAO4Kqwz7113wt+KB+Iy3TNZfYTBFE4 ViSX3ZDMPbcrDHXjnqKAO/opK8Q174zXvgfUNdu729XWLSB7k/2ekKq9oIpVCLuUZJdPOILd4vrQ B7hRXmfwz+K1x4w1+60K9hhF/ZwNLPLbZ8sOHUFOf9mSM/nXplABRXhusfGPxB4X8e6/psljNq8M uoW9jpNnHGi8tCzuwZeSAVAJboWXtSzftIJb3ME8ek3d1pt0st2snl4ENpFHE8kjY6HEhbB/ukUA e40VzPw78ZN488MxaubJ7ASSPGIZDlgUO1s/8CDD8K2tYF42k3o09lS+8h/IZgCBJtO3IPbOKALl FeCQ/tD3lrNDM2m3Op2+pJJdWqRRACG3hIjkJIGcs4ZwTxtH0r0/4b+O1+Iehy6pHaPZwidokWQ/ MQMcn86AOsoqC+laCyuJE++kbMPqBXh1h8cdS8Pra212ZPFRnjjuHvreBY1gzGhlibYNoMe9XJP8 LeuKAPd9wyB3pa8Lufj1e3niGzt7fS5LOKOaGNpLo7IZDPa+agZzwAu9CcehqzH+0YZjbGPQZpRd PbCKGFvMlQSJuIkUfdbA4z1wfSgD2uisjwjrMviLwvpWqzRLBJfWsd15SnIQOoYLn2BFVfH+sXnh /wAH6lqGnp5l5AgaJOPmO4DHPHOe9AHQZA60tfPl3+0Bq1tI1pc6VNFc2l/MZ5GwsaoL6WBIWcfL 9wLz/sMe9e1eEdebxL4ft9QeNYndpI2CNuQskjIWU91JXIPoRQBrsyxqSxCgdSaSOVJlDRurqejK ciuS+Kqxf8Ii73iGXSI7iGTU4x/FaLIplz6oAMsO6Bh3qt8L7Wzt4/EP9ixxweHjqLLYRw48kbY0 SYxAcBPNWTgcbg570AdxS14N4k+KXiDRtB1ax864vL9ZL4rqK2yxrAkd1PHGPlG37sGDnklx711/ ir4r3XhXVrqE6X9qsbWIySSRt+9O1YSQq9yTcIB/ut7UAelUleXar8ZptI0PRbyfSJRJqccu1eV2 urBEGDz87vGB/vVhw/GrVYba00r7NB/bO6KOSWXcY/mWCUOSOxjlYH/aX0oA9uorzrWvirLpniG6 0lbBTJazBJZJHwpUoJAF9WKEYHqG9DVaX41W8PhG019rJjbSSwxzBXB8gPbrO5b/AHFLA/SgD06i vGpPjrfXUd5FaaUiXEMbMWlJxGxWJUUjqSJZMHHZeK2NS+Jmp6LqaxTw2k8LaXbXw2MVJYiYzAE9 SRGu0fXNAHplLXlPib4qXei+NLuyjiheC0ikiEckm3dIEil3t/dXYxVfVjXqNrP9qtYZtpTzEV9r dRkZxQBLRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQ AUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFACbgOpxRXOeN7q0s7W wa/ufsunvdBLmTeUG3y32gkdt4SsyTXL1vh7Hf6TM9w/WOXAklMAkI3AH7z7BnB5J96DNzSbXY/H n+zbz/n0n/79t/hUqW+pRjCw3ajaU4Rh8pzkfTk/nX7S6hqWl6S0a3s9tamTJTziq7sYzjPpkfnU 9nJZahbrPatDcQtnEkYBBwcHmuX6v5nyn+r3X2n4H4oz2uoXUzSzQXUsrcs7oxJ/Gvsj/gmvbTW/ ibx4ZYZIg1pZ43qRn55a+6/JhLFdke4dRtFPSFIySqKv+6MVUaKi73OrC5MsNWjW5728hJLWGRy7 xIzHGSygnjOPyyfzNQRaPYwxxpHaQokYUIqoAFwcjH0NW2YKpJOAOSaAdwBHSug+lIrWzgsYfKt4 khjyTsjGBknJ4+pNSSRrLGyOoZGGCrDII9K5/wAY/ELw98P4LabxBqkOmRXLFImmOA5AyQPwpng7 4jeHfiAty3h/VINTW2KrMYWzsJBIz+RoA2JNFsJm3PZwOcMMtGDw33h+OTmpYNPtbXy/Jt44/LUq m1QNoOMgfkPyqxRQAVVutMtbxSJreOT5/MBZRkOBgMPfHGatUUAYPhvwVpPhW1jgsrc5RnYTTuZZ SXxuy7cnOB+Qpz+C9GM1nJHYRQG1mWdBANgLLnbuA6gE5APcA9hW5RQBR/sPTvlH2G3wpcr+7HBf 72Pr3q4irGqqoCqowAOgFOooAZJGkm3eobadwyM4PrVdNJso1wtpCoyzYCDqxyx/GrdFAFJ9GsJJ A7WcDOF2BjGCcZ3Y+mefrT7PTLTTt/2W2it9+A3loFzjp0q1RQAVRbQ9Pk8/dZW7ee4klzGPnYcB j6mr1FAFW20uzs55JoLWKGaQYd0QAtznk/WrVFFAFWbS7O4kWSS1ikdW3qzICQ3HI9+B+VNbR7GT Zus4DtBC/uxxkbSPy4+lXKKAGRQxwLtjRUXJO1RgZJyafRRQBTbR7GQRBrSEiI5TMY+Xgjj8CfzN WIbeK2XbFGsa5zhRgVJRQAjAMCCMg1Rj0LToooY0sbdI4SzRqsYAQtkMR6Zyav0UAUZtE0+48zzL KB/MAV90YO4AYAP4Eiq9n4X0yza6ZLOLdc3H2qUsuS0gxhvwwMela1FADI40hjWONQiKMKqjAAHQ CiSJJkKSKHU9VYZFPooAydU8L6XrFvLDc2UTpLgOQoBI37+v+9z+JrSghjtYUhiRY4o1CoijAUDo AKkooAp6zpNvr2kX2m3aeZa3kElvMn95HUqw/Ims/wAE+E7bwP4V03Q7SR5obOLZ5sgAaRiSzMQO MliTx61uUUAVJNJsppA8lrC7gMNzICcMcsPxPJqRrG3kk3tDGz9dxUZ7f4D8hU9FAFWPS7OKCKFL WJYYv9WgQYXnPA7c0yTRbCR97WcDPtKbjGM7SACPyA/KrtFAGZD4dsI7i5naBZpridbh2l+fDqoV cZ6AAcAdMn1qwuk2Udu8C2kKwuzO0YQbSTnJI98mrdFAFRdKs0aRltYQ0jbnYIMseOT+Q/Kmtoth J5W6zhbyQojyg+Tacrj0x2q7RQBSm0axuZJHltIZHkCh2ZASwByM+uCBVzpS0UAFFFFABRRRQAUU UUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRR QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAULzSo729iuJfn8qN40Q/d+fGW+uBj6E+tZ9j4 K0q00aTS3s4rizkleZoZlDKSXLDj2yPyrfooJ5U9Wjy34lePF8E/Ebwin9myalLqVlfW0aJKkQVv MtSCWcge341r/BXxRH418Bxa7DbyWkV/eXUywSEFkHnuMEjjt2rsrrTbW+KG5t4pymdpkQHGeuKk t7aK0hWKGNIY16JGMAfhWznF01FR17/ebcy5bW1OC1zSL/w9qmt68NaaBZvLaCJgCHYAgQkH1PTH 9413G65aa3YbEhKkyq33s8YA/WpZ7aK52ebGsmxg67hnDDoR71LWJmcf4q+1atrD6PHqBsI3sjJH GAM3TksGXJ7KAMgf361ND0m/0Xw3p1j9qW4ubdESSWXJBAPOPoOn0Fa8ltFNJFI8as8ZJRiOVyMc VLQBxfxC0/RtSuNKj1q2s7qEeaUW8xtDfJyPfFQfDvSLHTbu5k0zTbLT7S4t4ZP9D/iY7zhvcDH5 13EkayqVZQw6cis/Q/DemeG7doNLsYLCBmLtHAm0Fj1NYyU3OLW3U0i48rT3I/EUeqvDaf2S8KSf aY/P88nHk5+fGP4sdK16KK2MwooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooo oAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiig AooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAC iiigAooooAKKKKACiiigAooooAKKKKACiiigCCS+t4XKPPGjDqrMAab/AGlaf8/MX/fYpsKgtNkA /vD29hUm1f7o/KgBv9pWn/PzF/32KP7StP8An5i/77FO2r/dH5UbV/uj8qAG/wBpWn/PzF/32KP7 StP+fmL/AL7FO2r/AHR+VG1f7o/KgBv9pWn/AD8xf99ij+0rT/n5i/77FO2r/dH5UbV/uj8qAG/2 laf8/MX/AH2KP7StP+fmL/vsU7av90flRtX+6PyoAb/aVp/z8xf99ij+0rT/AJ+Yv++xTtq/3R+V G1f7o/KgBv8AaVp/z8xf99ij+0rT/n5i/wC+xTtq/wB0flRtX+6PyoAb/aVp/wA/MX/fYo/tK0/5 +Yv++xTtq/3R+VG1f7o/KgBv9pWn/PzF/wB9ij+0rT/n5i/77FO2r/dH5UbV/uj8qAG/2laf8/MX /fYqxWZ/aVjcXV5YxXEMl7bxh5rdWBeNWB2lh2B7VYuLr7Hp6y/LxtH7xgo5IHU/WgC1JIkKF3YI o6sxwKg/tK0/5+Yv++xS3v8AqR/vL/MVS1jVE0a3S4lh32+8LK6gfuweN2O/OKALn9pWn/PzF/32 KP7StP8An5i/77FNt5BcQpJ5ezcMgEDOO1PbYgy21RnGTigBP7StP+fmL/vsUf2laf8APzF/32Kr 2l9Fe3FzHEmVgbYZMcFu4H0q1tX+6PyoAb/aVp/z8xf99il/tC127vtEWM4zvFcn4E8XHxZJqUkj QxotxIlvaldsyxo7IWYHqDgEH1JHauiRR/aL8D7vp9KALP8AaVp/z8xf99ij+0rT/n5i/wC+xXPa p4vWx1y50i30u6vr6Kx+3IkaBVmG8JsVmwN2SM9hnmsjTfi3pOpafPeLZ3cUMOkRavmSHG9X3ARp /efK7eO5AoA7j+0rT/n5i/77FH9pWn/PzF/32K4nVPixpekafoF7PZz/AGXVLeK6aRVH+jRyNGiM /rl5o149c9Aay0+OukLHvudNu7VIWC3pYKfsm8IYN2Dz5gkjxjON4zigD0r+0rT/AJ+Yv++xR/aV p/z8xf8AfYrzi++M0enWKXk/hy9S3DzQ3DebFmCWOJ5ihG7JzGm/I4wfrUknxktLdZGuNJkiWHST q8zLcwybIsyBQNrHfnyj8y5AyMmgD0P+0rT/AJ+Yv++xR/aVp/z8xf8AfYrziH41WM8k6LpE4aG1 jndfOiLeZJMYI4gM5bdIMbx8vI5rb8O/EK28RatZ2SadPb/arJruOWTbjKMqyRkDkFWYDPQkHHQ0 AdZ/aVp/z8xf99ij+0rT/n5i/wC+xTtq/wB0flRtX+6PyoAb/aVp/wA/MX/fYo/tK0/5+Yv++xTt q/3R+VG1f7o/KgBv9pWn/PzF/wB9ij+0rT/n5i/77FO2r/dH5UbV/uj8qAG/2laf8/MX/fYo/tK0 /wCfmL/vsU7av90flRtX+6PyoAb/AGlaf8/MX/fYo/tK0/5+Yv8AvsU7av8AdH5UbV/uj8qAG/2l af8APzF/32KP7StP+fmL/vsU7av90flRtX+6PyoAb/aVp/z8xf8AfYo/tK0/5+Yv++xTtq/3R+VG 1f7o/KgBv9pWn/PzF/32KP7StP8An5i/77FO2r/dH5UbV/uj8qAG/wBpWn/PzF/32KP7StP+fmL/ AL7FO2r/AHR+VG1f7o/KgBv9pWn/AD8xf99ij+0rT/n5i/77FO2r/dH5UbV/uj8qAG/2laf8/MX/ AH2KP7StP+fmL/vsU7av90flRtX+6PyoAb/aVp/z8xf99ij+0rT/AJ+Yv++xTtq/3R+VG1f7o/Kg Bv8AaVp/z8xf99ij+0rT/n5i/wC+xTtq/wB0flRtX+6PyoAb/aVp/wA/MX/fYo/tK0/5+Yv++xTt q/3R+VG1f7o/KgBv9pWn/PzF/wB9ij+0rT/n5i/77FO2r/dH5UbV/uj8qAG/2laf8/MX/fYo/tK0 /wCfmL/vsU7av90flRtX+6PyoAb/AGlaf8/MX/fYo/tK0/5+Yv8AvsU7av8AdH5UbV/uj8qAG/2l af8APzF/32KP7StP+fmL/vsU7av90flRtX+6PyoAb/aVp/z8xf8AfYo/tK0/5+Yv++xTtq/3R+VG 1f7o/KgBv9pWn/PzF/32KP7StP8An5i/77FO2r/dH5UbV/uj8qAG/wBpWn/PzF/32KP7StP+fmL/ AL7FO2r/AHR+VG1f7o/KgBv9pWn/AD8xf99ij+0rT/n5i/77FO2r/dH5UbV/uj8qAG/2laf8/MX/ AH2KP7StP+fmL/vsU7av90flRtX+6PyoAb/aVp/z8xf99ij+0rT/AJ+Yv++xTtq/3R+VG1f7o/Kg Bv8AaVp/z8xf99ij+0rT/n5i/wC+xTtq/wB0flRtX+6PyoAb/aVp/wA/MX/fYo/tK0/5+Yv++xTt q/3R+VG1f7o/KgBv9pWn/PzF/wB9ij+0rT/n5i/77FO2r/dH5UbV/uj8qAG/2laf8/MX/fYo/tK0 /wCfmL/vsU7av90flRtX+6PyoAb/AGlaf8/MX/fYo/tK0/5+Yv8AvsU7av8AdH5UbV/uj8qAG/2l af8APzF/32KP7StP+fmL/vsU7av90flRtX+6PyoAb/aVp/z8xf8AfYo/tK0/5+Yv++xTtq/3R+VG 1f7o/KgBv9pWn/PzF/32KP7StP8An5i/77FO2r/dH5UbV/uj8qAI4PvTf9dD/IVLTZNPtpnLvCjM epIpjabZqMmCMD6UAS0VB9hsP+ecP6UfYbD/AJ5w/pQBPRUK6dZP92CM/QU7+y7T/n3j/KgCSio/ 7LtP+feP8qP7LtP+feP8qAJKKj/su0/594/ypP7MtB/y7x/lQBLRUf8AZdp/z7x/lR/Zdp/z7x/l QBJRUf8AZdp/z7x/lR/Zdp/z7x/lQBJRUf8AZdp/z7x/lSf2XadPs8f5UAS0VH/Zdp/z7x/lR/Zd p/z7x/lQA2SCNPOlCKJGTDOByQM4BPtk/nTpLc3VkkYdo8hTuUc8EH+lH9l2n/PvH+VWQMcDpQBB e/6kf7y/zFQXmnx30kBlyyRPv8vsxwQM/TNXJYkmjKSKGU9Qar/2Xaf8+8f5UAFrbi0t0hUkonC5 7DsPwqLVNPTVLGW2kLKHHDKcFSDkEfQgVN/Zdp/z7x/lR/Zdp/z7x/lQBHptjHptjDbR8rGuC3dj 3J9yaNSN0thObERtebD5QmJCFu2cdqk/su0/594/yo/su0/594/yoA5fwP4EXwkXuHuWuLua3jgl 4+UbWd+P+BSv+ldEn/ISf/d/+Jqb+y7T/n3j/Kl/s212hfITGc4xQBxPjLwf4g1zWrm80rVrfTVk 0uTT43KMZY2d1YuCOn3cD0zms1vhXfXtxax3N/BZadBp1tZJDpoaNo2gk8yMqcfdBxx7CvR/7LtP +feP8qP7LtP+feP8qVgPMR8Hb5rHQbGfWluLTTYre2cSQ5aaGFreVVJ9TLbnP+y5HaqVn+z/AGUI s98Gkr5d62oyiKzAHmbUEccf92P91Hu7nafU163/AGXaf8+8f5Uf2Xaf8+8f5UwPPPDnwl/4R2G2 8ia1ikhW8lWGG3At0uJwihwn91I0MY9Q7E9azb/4L3+paatnLq1vCn+kTloLYAiabzNyD/pjiQgr 3545r1T+y7T/AJ94/wAqX+y7T/n3j/KgDyyH4M3KWdpazXGm3VpaW8yQ2kloPK3SE5iPcwqDwOvA 9K1fB3wq/wCET1zSbtLmA2+m6a9jGsMAjd97KzBiP4AwZlHYufQV339l2n/PvH+VH9l2n/PvH+VA ElFR/wBl2n/PvH+VJ/Zdp/z7x/lQBLRUf9l2n/PvH+VH9l2n/PvH+VAElFR/2Xaf8+8f5Uf2Xaf8 +8f5UASUVH/Zdp/z7x/lR/Zdp/z7x/lQBJRUf9l2n/PvH+VH9l2n/PvH+VAElFR/2Xaf8+8f5Uf2 Xaf8+8f5UASUVH/Zdp/z7x/lR/Zdp/z7x/lQBJRUf9l2n/PvH+VH9l2n/PvH+VAElFR/2Xaf8+8f 5Uf2Xaf8+8f5UASUVF/Zlp0+zx/lS/2Xaf8APvH+VAElFR/2Xaf8+8f5Uf2Xaf8APvH+VAElFR/2 Xaf8+8f5Uf2Xaf8APvH+VAElFRf2XaH/AJd4/wAqX+y7T/n3j/KgCSio/wCy7T/n3j/Kj+y7T/n3 j/KgCSio/wCy7T/n3j/Kk/su0/594/yoAloqP+y7T/n3j/Kj+y7T/n3j/KgCSio/7LtP+feP8qP7 LtP+feP8qAJKKj/su0/594/yo/su0/594/yoAkoqP+y7T/n3j/Kj+y7T/n3j/KgCSio/7LtP+feP 8qP7LtP+feP8qAJKKi/su0/594/ypf7LtP8An3j/ACoAkoqP+y7T/n3j/Kj+y7T/AJ94/wAqAJKK j/su0/594/yo/su0/wCfeP8AKgCSiov7LtP+feP8qX+y7T/n3j/KgCSio/7LtP8An3j/ACo/su0/ 594/yoAkoqP+y7T/AJ94/wAqP7LtP+feP8qAJKKj/su0/wCfeP8AKj+y7T/n3j/KgCSio/7LtP8A n3j/ACo/su0/594/yoAkoqP+y7T/AJ94/wAqT+y7T/n3j/KgCWio/wCy7T/n3j/Kj+y7T/n3j/Kg CSio/wCy7T/n3j/Kj+y7T/n3j/KgCSio/wCy7T/n3j/Kk/su0/594/yoAt1z3iPV1VZ7KM5byJGk Pp8hwKlm8XacI22TPvxx+5cjP5Vwuva5Y6Lpt/qMtxNeSeWyCKK2k3SO/wAigZGOrCgTaSuwvrxN Ps7i6mYiKCNpXOeygk/yrD+H/iefxZ4ZhvbpY4r1ZJIbiOF9yqysQMH3Xa3/AAKq2t319relXmnz eFdeSK5jaJytvztPBH5VW0JZPDb3w0/wdrVtb3UqzG3jtsIjBFQlR7hRU82pzOp76s9D2XwaxOmy 55/en+QrfrifAOuySaZcG70vUNOfzuI7i3bcRtHPA6f4V07azBt/1dyP+3d/8Ko6U+ZXRn+Pdcn8 NeC9c1W22m4srOW4j3gkblUkZA69Kx/hT4wvPGGkahJeSxXElneG2FxFC8Pmjy43yY3AKkFyOnO0 HvWl4kks/Enh/UdKke6hS8t3gaVLdyyBgRkcdRmqPg+yt/C8F4Z72+1S+vJhNcXc1syliEVFAUDA AVR+p70WYuZdzs6jm4hc/wCyf5VQ/t61/u3H/fh/8Kij8RWeoWbyWwnmRtyhkgcjIJUjOOxBH4UD unsbFFUP7Yg/553P/gO/+FH9sQf887n/AMB3/wAKBnL+Kde8SP4kbSfDcFjJJZ2kd/c/bWIMweR0 SFMdCfKkyx6Hb6mu2XlRXBeMvCdl4uvBcfbdV00yQGyvFtInUXVsSWMbccclsMOQHb1rrl1eBVAE VwAP+nd/8KANCmf8tvwqn/bEH/PO5/8AAd/8KZ/a8XnE+Vc424/4939fpQBpU2RtsbN6DNUv7Yg/ 553P/gO/+FI2rwMpUx3OCMf8e7/4UAcV8NfF3iDVrixh102cy6lp39pW0lopUxgMoaNgR23oQR/t e1ei1594F8I2/g2QSy6hqWrSxWwsrZri2ZRBADnYoA6kgZPfaPSuy/tiD/nnc/8AgO/+FAF+mQnM MZ/2R/Kqf9sQf887n/wHf/CmW+rRJBGrRXIYKAf9Hf0+lAGlXnvxb8a3/hD+wksbmOz+3XMkUk0l q9xtCxM4ARATyVHNdn/bEH/PO5/8B3/wrmvGWjjxQ+mTWuoX2kXlhK8sdxDZs+dyMjAgjHRqAOq0 uaSfTLSWVxLI8KMzqpUMSoJODyPpVqsjT9QW0sbeGZ7q5ljjVHma2cGQgAFiAOMnn8asf2xB/wA8 7n/wHf8AwoAuMf3ij60+s1tWi81D5VzgZz/o7/4U/wDtiD/nnc/+A7/4UAXq838L+N9T1z4la3pM l5CtlYTvCLQWj7iAiEN5uNuct0zmu6/tiD/nnc/+A7/4Vm6PFY6LJqDxJdM15dNdOWtn4ZgoIHHT 5RQB0NFUP7Yg/wCedz/4Dv8A4Uf2xB/zzuf/AAHf/CgC3Ccqf95v5mpKzYdXhVCDFcg7mP8Ax7v3 J9qf/bEH/PO5/wDAd/8ACgDL8da9faHpdqmlxwyapf3cdla/aCRErNks7Y5wqK7YHUgDvUHw58TS +JtFne4vtP1G5tLqS0luNMlDxOVwQSP4Wwwyp6H2xUnimzsvFWkmzmN9bOsiTwXNvC6yQyocq6nH r19QSO9VvBuk2fg+xuollvr66vLhru7up7dw0spVUzgDAG1EAA6AUgOvpkh+7/vCqf8AbEH/ADzu f/Ad/wDCmSavC23EVz94H/j3f/CmBpUlUf7Yg/553P8A4Dv/AIUf2xB/zzuf/Ad/8KAOA8TfFtfD /iq/0Jlb7Ws+nx22IHZCs8m19zgbQQM4ya9NrjtR0HTdSutQnk+2B7yW1lfFs/BgcMuOO5HNdH/b EH/PO5/8B3/wpAX6Yv8ArH/Cqf8AbEH/ADzuf/Ad/wDCmLq0QkkJiucHGP8AR39PpTA0qRulUf7Y g/553P8A4Dv/AIUf2xB/zzuf/Ad/8KAKXgvWpvEHh9L24VVlNxcREL0xHO8Y/RRW5XP+H1s/D2mL ZQLdvGsssuWt3zmSRpD29WNaP9sQf887n/wHf/CgC5LxG59qcOgrPm1eFonAiuSSCB/o7/4U7+2I P+edz/4Dv/hQBfrC8aa3N4f8Py3tuqtKs0EYDdMPMiH9GNXv7Yg/553P/gO/+Fc14u0G08XXWmST XWpW0NpKsklvBC4S5VXSQI/HTfGh+mR3oA7SiqH9sQf887n/AMB3/wAKP7Yg/wCedz/4Dv8A4UAX P+Wyj/ZP9KfWadXh85T5VzjaR/x7v6j2p/8AbEH/ADzuf/Ad/wDCgC83avN/hH8Srr4mxz3iiFLK zijt5gud73ZUNJgHoighQe53eld0dYh/553P/gO/+Fcp4X8K6Z4Rvba4sWvVEenx6fLGbZ9swjYm ORuPvDc4z3De1AHdUVQ/tiD/AJ53P/gO/wDhR/bEH/PO5/8AAd/8KALcPMan2qSs2HV4liUGK5BA 5/0d/wDCn/2xB/zzuf8AwHf/AAoAo+KNbn0VtHEKq32zUIrR93ZWDEke/wAordrkvGWnx+KtNgt4 ru+0y5t7lLqG6htWZkdc44IweCa1tN1AWdhbwTyXd3NGgV53tXBkIHLEAcZoA16jk+/H/vf0NVP7 Yg/553P/AIDv/hTJNXiZ4sRXOA2T/o7+h9qANKiqH9sQf887n/wHf/Cj+2IP+edz/wCA7/4UAeV6 f8ZNUu/ENvpL2cCSv4oudLLbjn7FGXRZcf3jIu30+Vq9iFeZ2/w10K28SR60r6h9qS5a52+Q+0sb i4n6Y/vXLj6AV339sQf887n/AMB3/wAKFsBfpkfQ/wC8ap/2xB/zzuf/AAHf/CmRavCobMVyPmJ/ 4939fpQBpVyfxQ8Taj4P8F32raVaLqF/A0XlWrHHm7pFUqPcgnHvit3+2IP+edz/AOA7/wCFZviB bTxBp4tJhdxoJYpsrbvnKOrjt6qKAK/w/wDGKeN7C/1C3dJbEXIW1lT+OJoY5FY+/wC8rqa4/wAF 6DpXgW21O306O8W3vr+bUDG1u+I3lILKvHC56Dtmuh/tiD/nnc/+A7/4UAXJjhR/vL/MU+s2bV4W QARXJO5T/wAe7+o9qf8A2xB/zzuf/Ad/8KAL9ea+LvHWv6Vea/f6fBZNoPhoI2oJOzefP+6WaXy8 DA2ROpGerZHSu7/tiD/nnc/+A7/4VxniTwVp3iLWJrtrzVLWzvPLGo6fDE4hvRH93eMcZACtj7yg A9KAPQV6UtUP7Yg/553P/gO/+FH9sQf887n/AMB3/wAKALi/6x/w/lT6zU1eESSExXOCRj/R39Pp T/7Yg/553P8A4Dv/AIUAJ4gvn0vQdRvIseZb28kq7umVUkZ/KuJ+D/ju/wDGtvem6vbHVoYY4JE1 DTgREWkUlovQsmBnH94ZrrtUurXVNNurORLpY7iJomK275AYEHt70mmz2Wk2NvawQTrHCioNtq4z gAZ4HtQBs02TiNj7GqX9sQf887n/AMB3/wAKbLq8LRuBHc5IIH+jv/hQBoL90UtZ66xDtH7q5H/b u/8AhS/2xB/zzuf/AAHf/CgDmPFuveI5PEEejeGUsftUNn9vuJNQLBWBYrFEu0fxFJMt2Cj1rovC 2ux+KPDOk6zCjRw6haRXaI/VVkQMAfcZrkfiB4OtfHSpJFqes6DeCFrZ7vTY3R3hZlYoeOoKgg9s n1ro/DrW3h/QNN0tFuJEsraO2VltHQEIoUHaBgdOgoA36Yf9cv0NU/7Yg/553P8A4Dv/AIUw6vD5 yt5VzjaR/wAe7+3tQBpUhqj/AGxB/wA87n/wHf8Awo/tiD/nnc/+A7/4UAeY/Cz4pap4x8XXum3E sF1FHFNLIkVtJG1ntnMcYZiArhwr4IPVDXrtcRovhnS9B1CwvbU3qzWtvNat/o7/AL1JJBJhuOdr Zx/vH1rqP7Yg/wCedz/4Dv8A4UdALxpsX3PxP86p/wBsQ/8APK5/8B3/AMKo6T4t0/U1u1tjcSm1 uHtpsW8nySDBK9PRh+dAHmPja9v9N8Iazd6Y0SX1vaSyxNMCVUqhOcDrjHA9aZ4okaTw1G5OWaez J+v2iKut1DwVeajY3NnPbiS3uImhkUSAZVgQR19Cay/E3g/VZND8mG0zslt2/wBavCpMjMevZVNL uYzi3f0PVaKKKZsFVdU/5Bt12/dN/I1aqrqn/INuv+uTfyqo7omXws/EXUPF1xp8k6z6jqryLB9o yl24D5k2BRz1yR+dZ8PxEldd73+o+WZHjzHqW8qQjsN4DZXOzHPrT9Q0qz1K6immmnikhDRlFiJB +/8AngsG+qiqzaDazWL2c9/JJb4dYwlpsZNysMlh94jdnn0r+gXCba5FG3T4fx6n4PGULPncr/8A b34W0NpfEF3eW9x5Wp6pG6wzOGN4/wDA7J6+q5r9c/2aWZ/gT4MZiWZrHJYnJJ3tzX4+w20Gnx6g 63M1wZYXSKMwkbNxZiM98s2fyr9gf2Z/+SD+C/8ArwH/AKE1fE8XKKoUNFe7va36H2PCnN7atdtr S17/AKnp1FFFfmR+khRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQBDeXkGn20lxczR28EY3PLKwVVHqSegqKDVrO6sReQXUM9oQT9o jkDR4HU7gcVwP7RdvFd/BvxDBcKslvKLeORG6MpuIwQfYgmvD/iV4O0qz8L/ABz0Tw7PLpPh7ToN O1A22lzGOMXnlyNLEcdFKrbMy98+9AH1j9vtzdNaiaP7SqeYYd43hCcBiOuMg8061u4b6BJreVJ4 XGVkjYMrfQjrXw/8aWvrTxZ8RvEEBt4bKaXV9NF1DKw1FWTSYvNVx0FuqRySLj5gxU4Awa9VsdYk +HfgX4qW/hWWLTNNsvGVnpWkzKgeCwiuo9MjuJUBOCsc1zcuRnGVYHGKAPo2G4juAxidZFVihKkE BgcEfUEYpfMXaWyNozk/TrXxVoPxN8R+B9mmWHieTU5rXxZejUGgs4/JlW41+a3LzuxCrkblVEy2 5TxgCoPBPxM8SeE/D3gXRrfxHd6nbK8FrfxPaII1F3cXK4mlYglyFGxU3EbCTgGgD7chmS4iSWJ1 kjdQyupyGB5BB7ildxGpZjgDkk18P+F/jR4w8H/BXw1rNjrtuII9Mt9Ch0me3VhaeXpMMovXbOW2 sfMYHjYw5r1C81S+1z4I/FzRfFfjKK4TTtZk0OPXWt9qJG0drsWZY8/LvmKSN2UuTjBoA+iLXU7S +WJre5hnSZS8bRyBg6ggErjqASPzq1Xw3HLrnhfxRqsGhLY+Btf8N6Vruq6hb6PJ9u02dlt9LlRb cPgxq+2MupAYHccYfNdV4k+M3jpryOew8SW9sNf1m90SDTvsiM+lLbX8FutyDnL7lckhsDNxF6DI B9cLIGJAOccGnV81aDqut+APhT4tVfEzXWs3XjRtPi1O+jXNqk+oQWsk2zOCEEpfHQEgdKxL74le O9P8bLokfi6PV7RrW40mz1LT7WFo5NSEd8VS5Td5kcmbeMqwUxnypBu5oA+sKK81+A/jy9+KHhfU fFUzg6XqGoSLpcSjHlwQokD/AF3TxXDA+jLXpVABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQ AUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFcP8L/ APXeM/8AsYrn/wBAiruK4L4ZyyJceMwsLSD/AISG55BA/gi9TQBc+LE+mW/g2eTV55orLzYwYYJf La5csAkO7PG5io9O5wM1c8P29zZ/D/TYL27W/vIrCNJrpX3iVwgDMG75PfvVrxZFpEmizN4hNiml RkPJJqDqkKEHglmIA5NSSwLbaH5VqIVtFiAjWL7oTHGPbFAGvRRUN5cfZLSefy5JvLRn8uJdztgZ wB3JoAmqtqVjDqen3NncLvt7iNopF6ZVhgj8jXi6/tNxSWVvdL4ful+06Rb6rBbSOqySCSBLiRFJ O1jGj4bBOGx2INdx4T+LWkeItH1rVbyWHRdN0x97Xd9OkcRtyMpOXJwqnDfeIxtoAzB+zf8ADjv4 Vsf++KP+Gb/hv/0Ktj/37rvrXXdNvraK4t9QtZ7eVBJHLFOrI6kZDAg4II71J/aln/z9wf8Afxf8 a09pP+Z/eZ+zh/Kjz3/hm/4b/wDQq2P/AHxXd+H9BsPC+j22l6ZbraWFsuyGFOiDJOB+JNT/ANqW f/P3B/38X/Gj+1LP/n7g/wC/i/41LlKW7uNRjHZFqiqv9qWf/P3B/wB/F/xo/tSz/wCfuD/v4v8A jUllqiqv9qWf/P3B/wB/F/xo/tSz/wCfuD/v4v8AjQBaoqr/AGpZ/wDP3B/38X/Gj+1LP/n7g/7+ L/jQBaoqr/aln/z9wf8Afxf8aP7Us/8An7g/7+L/AI0AWqKq/wBqWf8Az9wf9/F/xo/tSz/5+4P+ /i/40AWqKq/2pZ/8/cH/AH8X/Gj+1LP/AJ+4P+/i/wCNAFqiqv8Aaln/AM/cH/fxf8aP7Us/+fuD /v4v+NAFqiqv9qWf/P3B/wB/F/xo/tSz/wCfuD/v4v8AjQBaoqr/AGpZ/wDP3B/38X/Gj+1LP/n7 g/7+L/jQBaoqr/aln/z9wf8Afxf8aP7Us/8An7g/7+L/AI0AWqKq/wBqWf8Az9wf9/F/xo/tSz/5 +4P+/i/40AWqKq/2pZ/8/cH/AH8X/Gj+1LP/AJ+4P+/i/wCNAFqiqv8Aaln/AM/cH/fxf8aP7Us/ +fuD/v4v+NAFqiqv9qWf/P3B/wB/F/xo/tSz/wCfuD/v4v8AjQBaoqr/AGpZ/wDP3B/38X/Gj+1L P/n7g/7+L/jQBaoqr/aln/z9wf8Afxf8aP7Us/8An7g/7+L/AI0AWqKq/wBqWf8Az9wf9/F/xo/t Sz/5+4P+/i/40AVvEnhvTPGGh3mja1Yw6lpd5GYri0uF3RyqezD0rJ0X4X+FPDnhafw3pmg2NnoN xu86wji/dSbuu4d88dfSt/8AtSz/AOfuD/v4v+NH9qWf/P3B/wB/F/xoAxZPhz4Zm8SXniCTQ7KT Wry2NncXrRAySwkYKMe4I4+lO074e+HNJ8It4Ws9Gs7fw60TwtpqRjySjklgR3ySa2P7Us/+fuD/ AL+L/jR/aln/AM/cH/fxf8aAOMh+A/w+tv7M8rwjpcf9mbvse2ADyd0nmEj3L/Nz35p8fwN8Ax6t Fqi+FNLGoRSNKlwIBuV2kMrN9d5LfUmuw/tSz/5+4P8Av4v+NH9qWf8Az9wf9/F/xoA4fXPgj4Zv NN1MaRpllomsXWkHRodThtld4IBHsRNp4ZVUKNvdRjpUPwp+DGm/DvwFqHhu4is76HVLma6voYbY RWzGRVQxrHk4QIiL74z3rvv7Us/+fuD/AL+L/jR/aln/AM/cH/fxf8aAOa0X4R+DfDukjTNN8Oaf Z2AguLbyI4QF8qfZ5yH1D+WmfXaPSpV+FnhKPWb3Vh4fsBqV6IRc3PkjfL5TK0eT/ssiH6qPSug/ tSz/AOfuD/v4v+NH9qWf/P3B/wB/F/xoAwbn4Y+FbyTUpJ9BspX1ITC8LRZ8/wA5Yll3eu4QRZ/6 5r6VDpfwl8H6Lq2k6nYeHbC01DSrX7FY3EcID28PPyKfT5m9/mPrXSf2pZ/8/cH/AH8X/Gj+1LP/ AJ+4P+/i/wCNAEWh6HYeG9Lt9N0u0hsLC3G2K3t0CogJJIAHuSfxq/VX+1LP/n7g/wC/i/40f2pZ /wDP3B/38X/GgC1RVX+1LP8A5+4P+/i/40f2pZ/8/cH/AH8X/GgC1RVX+1LP/n7g/wC/i/40f2pZ /wDP3B/38X/GgC1RVX+1LP8A5+4P+/i/40f2pZ/8/cH/AH8X/GgC1RVX+1LP/n7g/wC/i/40f2pZ /wDP3B/38X/GgC1RVX+1LP8A5+4P+/i/40f2pZ/8/cH/AH8X/GgC1RVX+1LP/n7g/wC/i/40f2pZ /wDP3B/38X/GgC1RVX+1LP8A5+4P+/i/40f2pZ/8/cH/AH8X/GgC1RVX+1LP/n7g/wC/i/40f2pZ /wDP3B/38X/GgC1RVX+1LP8A5+4P+/i/40f2pZ/8/cH/AH8X/GgC1RVX+1LP/n7g/wC/i/40f2pZ /wDP3B/38X/GgC1RVX+1LP8A5+4P+/i/40f2pZ/8/cH/AH8X/GgC1RVX+1LP/n7g/wC/i/40f2pZ /wDP3B/38X/GgC1RVX+1LP8A5+4P+/i/40f2pZ/8/cH/AH8X/GgC1RVX+1LP/n7g/wC/i/40f2pZ /wDP3B/38X/GgC1RVX+1LP8A5+4P+/i/40f2pZ/8/cH/AH8X/GgC1RVX+1LP/n7g/wC/i/40f2pZ /wDP3B/38X/GgC1RVX+1LP8A5+4P+/i/40f2pZ/8/cH/AH8X/GgC1RVX+1LP/n7g/wC/i/40f2pZ /wDP3B/38X/GgC1RVX+1LP8A5+4P+/i/40+C+trqR44biKaRAGZY3DFQcgEgdAdrfkfSgCeiiigA rh/hf/rvGf8A2MVz/wCgRV3FcF8M/O+0eM9hXH/CRXP3v9yKgDU+JVzb2fhO4lubeaZAyhZYbM3Z t2PCzGEcuFJBwAah8E289p8LNDguIHtpodMhiaKTO5dsYA3Z5zgc5roNXvrXRdMu9Qvrk29laxNP NMzcIiglifoAaqm4g1TQEv7aeWS2uIFnjYkjcrKGBIPsRQBs0UUUAeYXX7O/hW8sbS0eTVBBaWC6 dbqt4R5MQjjjbbxwzpEise4FdPoPw/0fwlpusW9nC8sF/K88sd03mqMrgRqCMBBjhegya6iorr/j 2l/3D/KgDj/g7BH/AMKr8Kfu1/5BsP8ACP7grsfs8f8AcX/vkVyXwc/5JX4U/wCwdD/6CK7GgCP7 PH/cX/vkUfZ4/wC4v/fIqSigCP7PH/cX/vkUfZ4/7i/98ipKKAI/s8f9xf8AvkUfZ4/7i/8AfIqS igCP7PH/AHF/75FH2eP+4v8A3yKkooAj+zx/3F/75FH2eP8AuL/3yKkooAj+zx/3F/75FH2eP+4v /fIqSigCP7PH/cX/AL5FH2eP+4v/AHyKkooAj+zx/wBxf++RR9nj/uL/AN8ipKKAI/s8f9xf++RR 9nj/ALi/98ipKKAI/s8f9xf++RR9nj/uL/3yKkooAj+zx/3F/wC+RR9nj/uL/wB8ipKKAI/s8f8A cX/vkUfZ4/7i/wDfIqSigCP7PH/cX/vkUfZ4/wC4v/fIqSigCP7PH/cX/vkUfZ4/7i/98ipKKAI/ s8f9xf8AvkUfZ4/7i/8AfIqSigCP7PH/AHF/75FH2eP+4v8A3yKkooAj+zx/3F/75FH2eP8AuL/3 yKkooAj+zx/3F/75FH2eP+4v/fIqSigCP7PH/cX/AL5FH2eP+4v/AHyKkooAj+zx/wBxf++RR9nj /uL/AN8ipKKAI/s8f9xf++RR9nj/ALi/98ipKKAI/s8f9xf++RR9nj/uL/3yKkooAj+zx/3F/wC+ RR9nj/uL/wB8ipKKAI/s8f8AcX/vkUfZ4/7i/wDfIqSigCP7PH/cX/vkUfZ4/wC4v/fIqSigCP7P H/cX/vkUfZ4/7i/98ipKKAI/s8f9xf8AvkUfZ4/7i/8AfIqSigCP7PH/AHF/75FH2eP+4v8A3yKk ooAj+zx/3F/75FH2eP8AuL/3yKkooAj+zx/3F/75FH2eP+4v/fIqSigCP7PH/cX/AL5FH2eP+4v/ AHyKkooAj+zx/wBxf++RR9nj/uL/AN8ipKKAI/s8f9xf++RR9nj/ALi/98ipKKAI/s8f9xf++RR9 nj/uL/3yKkooAj+zx/3F/wC+RR9nj/uL/wB8ipKKAI/s8f8AcX/vkUfZ4/7i/wDfIqSigCP7PH/c X/vkUfZ4/wC4v/fIqSigCP7PH/cX/vkUfZ4/7i/98ipKKAI/s8f9xf8AvkUfZ4/7i/8AfIqSigCP 7PH/AHF/75FH2eP+4v8A3yKkooAj+zx/3F/75FH2eP8AuL/3yKkooAj+zx/3F/75FH2eP+4v/fIq SigCP7PH/cX/AL5FH2eP+4v/AHyKkooAj+zx/wBxf++RXAaH8vx+8ZqOFHhjQiF7f8fer9q9Drz3 Q/8Ak4Lxp/2K+hf+ler0AehUUUUAFcP8L/8AXeM/+xiuf/QIq7iuC+GcHmXHjM+Y6/8AFQ3PCtj+ CKgDS+JnhfUPGHhWXTtNvo7K4MscpM0IlSQId2xlJHBIH5VL4b0+70n4d6TY3+031tpsMM+0ADzF jUN+oNR/EbxZb+A/C8urSwJMVljhSN5AilncKMsenXP4Vdgkh1TwxDfCOMGe2WYeVIHT5lB+VhwR z1HWgDdooooAKiuv+PaX/cP8qlqK6/49pf8AcP8AKgDk/g5/ySvwp/2Dof8A0EV2Ncd8HP8Aklfh T/sHQ/8AoIrsaACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK KACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigA ooooAKKKKACiiigArz3Q/wDk4Lxp/wBivoX/AKV6vXoVeV2OjG8/aa8RaiL69g+x+FdHT7LDNtgn 8y61UZlTHzFdvy8jG5vWgDsD8SPDC3rWja5ZrcrObcxtKAQ47fmCM9CRjrxWvo+s2XiDTYNQ065j vLOYExzRHKtgkH8iCPqK8F8Wfs+eJvHWoX9zqNzpOny3GpRutzp9zMGFjDOk0EJQxAE7o8sM43Su 2egPsHw38N3vhTwnDYaibY3zXN1dSrZljCrTXEk21CwBwPMxyB0oA6euH+F/+u8Z/wDYxXP/AKBF XcVwXwztYprjxmXQMf8AhIbn/wBAioA3vGWn3mr6P5Wmz2kV7HKk0f21N8TbTkqw7AjuBxUOi6TF 4Y8E2eji6W4a0tVhMgwu8gckDsM9B2qh8V/Fk/g/wzFc2mEurq7itI5Ps7XBQuT8wjUZc4BwP5Vp 6TqP9ueCbPUWaCV7mzSZpLcERklQSV3AEDPYgEd6AOhqC9me3s55Y4HuZI42ZYIyA0hAyFGSBk9O SBzU9FAHz/8A8NRC6tNPSy0eCXVLjw9b65LaSXgHlPJEJng4BOVjI+bGCWUeuO68K/Fm08QeG/EO rahGum2On5lWXLPutmUlJGGMhjhsqM4x71avfgj4Q1DTbSyl0tRFa2CaZG0Z2v8AZ12gIWHJBChT 7EitvR/Bek+F7HVorC2VI76V7mdH+YFioGAD/CABgUAYfwZ1izk+E/hJlnBVtMgYHB5BQV2X9q2v /PYfka5f4ORp/wAKq8KfIv8AyDYe3+wK7Hy0/ur+VAFb+1bX/nsPyNH9q2v/AD2H5GrPlp/dX8qP LT+6v5UAVv7Vtf8AnsPyNH9q2v8Az2H5GrPlp/dX8qPLT+6v5UAVv7Vtf+ew/I0f2ra/89h+Rqz5 af3V/Kjy0/ur+VAFb+1bX/nsPyNH9q2v/PYfkas+Wn91fyo8tP7q/lQBW/tW1/57D8jR/atr/wA9 h+Rqz5af3V/Kjy0/ur+VAFb+1bX/AJ7D8jR/atr/AM9h+Rqz5af3V/Kjy0/ur+VAFb+1bX/nsPyN H9q2v/PYfkas+Wn91fyo8tP7q/lQBW/tW1/57D8jR/atr/z2H5GrPlp/dX8qPLT+6v5UAVv7Vtf+ ew/I0f2ra/8APYfkas+Wn91fyo8tP7q/lQBW/tW1/wCew/I0f2ra/wDPYfkas+Wn91fyo8tP7q/l QBW/tW1/57D8jR/atr/z2H5GrPlp/dX8qPLT+6v5UAVv7Vtf+ew/I0f2ra/89h+Rqz5af3V/Kjy0 /ur+VAFb+1bX/nsPyNH9q2v/AD2H5GrPlp/dX8qPLT+6v5UAVv7Vtf8AnsPyNH9q2v8Az2H5GrPl p/dX8qPLT+6v5UAVv7Vtf+ew/I0f2ra/89h+Rqz5af3V/Kjy0/ur+VAFb+1bX/nsPyNH9q2v/PYf kas+Wn91fyo8tP7q/lQBW/tW1/57D8jR/atr/wA9h+Rqz5af3V/Kjy0/ur+VAFb+1bX/AJ7D8jR/ atr/AM9h+Rqz5af3V/Kjy0/ur+VAFb+1bX/nsPyNH9q2v/PYfkas+Wn91fyo8tP7q/lQBW/tW1/5 7D8jR/atr/z2H5GrPlp/dX8qPLT+6v5UAVv7Vtf+ew/I0f2ra/8APYfkas+Wn91fyo8tP7q/lQBW /tW1/wCew/I0f2ra/wDPYfkas+Wn91fyo8tP7q/lQBW/tW1/57D8jR/atr/z2H5GrPlp/dX8qPLT +6v5UAVv7Vtf+ew/I0f2ra/89h+Rqz5af3V/Kjy0/ur+VAFb+1bX/nsPyNH9q2v/AD2H5GrPlp/d X8qPLT+6v5UAVv7Vtf8AnsPyNH9q2v8Az2H5GrPlp/dX8qPLT+6v5UAVv7Vtf+ew/I0f2ra/89h+ Rqz5af3V/Kjy0/ur+VAFb+1bX/nsPyNH9q2v/PYfkas+Wn91fyo8tP7q/lQBW/tW1/57D8jR/atr /wA9h+Rqz5af3V/Kjy0/ur+VAFb+1bX/AJ7D8jR/atr/AM9h+Rqz5af3V/Kjy0/ur+VAFb+1bX/n sPyNH9q2v/PYfkas+Wn91fyo8tP7q/lQBW/tW1/57D8jR/atr/z2H5GrPlp/dX8qPLT+6v5UAVv7 Vtf+ew/I0f2ra/8APYfkas+Wn91fyo8tP7q/lQBW/tW1/wCew/I0f2ra/wDPYfkas+Wn91fyo8tP 7q/lQBW/tW1/57D8jR/atr/z2H5GrPlp/dX8qPLT+6v5UAVv7Vtf+ew/I0f2ra/89h+Rqz5af3V/ Kjy0/ur+VAFb+1bX/nsPyNH9q2v/AD2H5GrPlp/dX8qPLT+6v5UAVv7Vtf8AnsPyNH9q2v8Az2H5 GrPlp/dX8qPLT+6v5UAVv7Vtf+ew/I0f2ra/89h+Rqz5af3V/Kjy0/ur+VAFb+1bX/nsPyNH9q2v /PYfkas+Wn91fyo8tP7q/lQBW/tW1/57D8jR/atr/wA9h+Rqz5af3V/Kjy0/ur+VAFb+1bX/AJ7D 8jR/atr/AM9h+Rqz5af3V/Kjy0/ur+VAFb+1bX/nsPyNH9q2v/PYfkas+Wn91fyo8tP7q/lQBW/t W1/57D8jXCeHpkuPj94zeNtynwvoXP8A296vXonlp/dX8q8+0MBf2gPGgAwP+EX0L/0r1egD0Oii igArg/hlPHHceMw0iqf+EhueCwH8EVd5XC/DFFafxnlQf+Kiueo/2IqANzxd4ei8VaWtpJPc2UsU qXEF1akCSKRTwwz+I+hNJaabb+HfC8OlWkcv2a1txCjSHLEAYyx7k9TVH4rSPb+AdXuIru/s54Iv MhOmzCGaSUf6uIMQcb3Kr071oadp1zo/g21sb29l1K8t7RYp7yY5eeQKAzn6nJ/GgDdooooAKiuv +PaX/cP8qlqK6/49pf8AcP8AKgDk/g5/ySvwp/2Dof8A0EV2Ncd8HP8AklfhT/sHQ/8AoIrsaACi iigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK KACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigA rz3Q/wDk4Lxp/wBivoX/AKV6vXoVee6H/wAnBeNP+xX0L/0r1egD0KiiigArgfhnceXceMx5bt/x UVzyo/2Iq76uH+F/+u8Z/wDYxXP/AKBFQB1Oq2UGoWZivooZbZXSUiViFDI4dD+DKp/Cm6kZ/wCz 5/lj27Tn5jn+Vcd8cvn8DrEzwRxSX1sskl4zLbKvmAkyleQnGPqRWh4Ekkk+E+gmXzDL/ZcKs0ud zERgZOeecZ555oA7KiiobySWK0neCLz51RjHFu272A4XPbJ70ATVFdf8e0v+4f5V8/XX7QniW20b w/eNpOnJJrXhxdahXz2KRypDFNNCW2+kjAEgYARudxA7jwj8W11rwv4l1jWLdrOy0/8AfobWGWeT 7My5XMaKWMgw2VUHt60Abvwc/wCSV+FP+wdD/wCgiuxrz/4M63aSfCfwk6tLtbTIGGYJAcFAem3i uz/ti1/vSf8Afl/8KALtFUv7Ytf70n/fl/8ACj+2LX+9J/35f/CgC7RVL+2LX+9J/wB+X/wo/ti1 /vSf9+X/AMKALtFUv7Ytf70n/fl/8KP7Ytf70n/fl/8ACgC7RVL+2LX+9J/35f8Awo/ti1/vSf8A fl/8KALtFUv7Ytf70n/fl/8ACj+2LX+9J/35f/CgC7RVL+2LX+9J/wB+X/wo/ti1/vSf9+X/AMKA LtFUv7Ytf70n/fl/8KP7Ytf70n/fl/8ACgC7RVL+2LX+9J/35f8Awo/ti1/vSf8Afl/8KALtFUv7 Ytf70n/fl/8ACj+2LX+9J/35f/CgC7RVL+2LX+9J/wB+X/wo/ti1/vSf9+X/AMKALtFUv7Ytf70n /fl/8KP7Ytf70n/fl/8ACgC7RVL+2LX+9J/35f8Awo/ti1/vSf8Afl/8KALtFUv7Ytf70n/fl/8A Cj+2LX+9J/35f/CgC7RVL+2LX+9J/wB+X/wo/ti1/vSf9+X/AMKALtFUv7Ytf70n/fl/8KP7Ytf7 0n/fl/8ACgC7RVL+2LX+9J/35f8Awo/ti1/vSf8Afl/8KALtFUv7Ytf70n/fl/8ACj+2LX+9J/35 f/CgC7RVL+2LX+9J/wB+X/wo/ti1/vSf9+X/AMKALtFUv7Ytf70n/fl/8KP7Ytf70n/fl/8ACgC7 RVL+2LX+9J/35f8Awo/ti1/vSf8Afl/8KALtFUv7Ytf70n/fl/8ACj+2LX+9J/35f/CgC7RVL+2L X+9J/wB+X/wo/ti1/vSf9+X/AMKALtFUv7Ytf70n/fl/8KP7Ytf70n/fl/8ACgC7RVL+2LX+9J/3 5f8Awo/ti1/vSf8Afl/8KALtFUv7Ytf70n/fl/8ACj+2LX+9J/35f/CgC7RVL+2LX+9J/wB+X/wo /ti1/vSf9+X/AMKALtFUv7Ytf70n/fl/8KP7Ytf70n/fl/8ACgC7RVL+2LX+9J/35f8Awo/ti1/v Sf8Afl/8KALtFUv7Ytf70n/fl/8ACj+2LX+9J/35f/CgC7RVL+2LX+9J/wB+X/wo/ti1/vSf9+X/ AMKALtFUv7Ytf70n/fl/8KP7Ytf70n/fl/8ACgC7RVL+2LX+9J/35f8Awo/ti1/vSf8Afl/8KALt FUv7Ytf70n/fl/8ACj+2LX+9J/35f/CgC7RVL+2LX+9J/wB+X/wo/ti1/vSf9+X/AMKALtFUv7Yt f70n/fl/8KP7Ytf70n/fl/8ACgC7RVL+2LX+9J/35f8Awo/ti1/vSf8Afl/8KALtFUv7Ytf70n/f l/8ACj+2LX+9J/35f/CgC7RVL+2LX+9J/wB+X/wo/ti1/vSf9+X/AMKALtFUv7Ytf70n/fl/8KP7 Ytf70n/fl/8ACgC7RVL+2LX+9J/35f8Awo/ti1/vSf8Afl/8KALtFUv7Ytf70n/fl/8ACj+2LX+9 J/35f/CgC7RVL+2LX+9J/wB+X/wo/ti1/vSf9+X/AMKALtFUv7Ytf70n/fl/8KP7Ytf70n/fl/8A CgC7Xnuh/wDJwXjT/sV9C/8ASvV67X+2LX+9J/35f/CvNdJ8TWEP7S3iPTna4F1qHhXR3twLWUoR FdaqX3OF2p98YDEbucZwcAHq9FeKeIvip4s0vVL1ba206e0sr4pJt3kPEkUs88QbA+eOKJSSARvn VOCrY9G+HfiK78UeFYr2/iiivUubq0mWAkoWhuJISy55wfLz+NAHS1wXwzab7R4z2KhX/hIbn7zE H7kXtXe1w/wv/wBd4z/7GK5/9AioA6DxLqWn6Po89zrNxbxacMLJ58e9TkgAbecknHGKdcP9o0Uz W9xFJayRB42jUFWQjIIIPTFYPxasprrwmstss5ubS7huYmt7Zbkqyt1MTMocYJyMg9+1S+CtKu9D +F+kWF+GW9gsEWZWxlW25KnHHHTjjigR19FFFAzi5/g14KuYRDL4etXiFtHZhPmwIYwoRBzwAEQe 4UA5rc0vwzpfhm11L+y7OOy+2TSXc/lZ+eVgAW/QdOOK2Kiuv+PaX/cP8qAOT+DvPwr8KE/9A6H/ ANBFdjXHfBz/AJJX4U/7B0P/AKCK7GgAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACi iigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK KACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigAooooAKKKKACiiigAooooAK890T/k4Hxp/wBixoX/AKV6vXoVee6H/wAnBeNP+xX0 L/0r1egDa0j4Y+F9BnvJrHR4IJLuaaec5Zt8kufMbBJwWyc49a2NB0HT/C+k2+maXapZ2FuCI4Y8 4XLFj155JJ/GtCigArgvhmkrXHjPZIqD/hIbngpn+CL3rva4f4X/AOu8Z/8AYxXP/oEVAG1r3iaw 0DUNJsruaVbjVJzb2yoCcsFLEk9gAOp9QO9ZPhvxlY+O9Bv7uxS8t1gbYY7tQrMrIskcgAJyjo6s D1weQCCK0/F2itrTaQYzEDa3qzSM5wfL2MCB75I/KuT+G/hfU/C/h3Uk1o2iXbR29pEtpMZFMMEC RI5JA+ZiGYjHGQMmkB6bRRRTAKiuv+PaX/cP8qkzUd1/x7Tf7h/lQByfwc/5JX4U/wCwdD/6CK7G uO+Dn/JK/Cn/AGDof/QRXY0AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFF ABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU UUUAFFFFABRRRQAUUUUAFFFFABXnuh/8nBeNP+xX0L/0r1evQq890P8A5OC8af8AYr6F/wCler0A ehUUUUAFcF8M7fzLjxmfMdf+KhueFOB9yKu9rhPhjKiXHjMM6qf+Eiuep/2IqANfxN4kfQdU0CzT TZLtNUu/sz3CkBLcbC25u5JIAAHv0xVbw/4iPivw9qd3Jpr6a1vd3FoIZsF8RuVDHHTcBnHvWpr2 mR6w2mv5zRGyu1uwAhO8qrDb7fe6+1VLPT4tF0vVIxO0purma65jI2mRt238PWkLqdJUN4062c7W scctyI2MUcrlEZ8fKGYA4BOOcH6VNRTGfNVx8dPF6+G9H1GO50bzLrw5b6peAW7GOyuHtkmVXYuM iXbcAKPuKqsSdwB9A8DfFK91zwr4o1XU7RrhbBjLHb2EOZVjZMiEruO6VcHPTO4cCus/4Vd4U8yV /wCw7XMsUcDrtO1kjChFK5xgBFHToMdK2LXR7LRrW++w20dr9od7ibyxjfIw5Y+5wPyoA5H4M6sk nwn8JMLe4AbTIDgpyMoOtdl/ai/88Jv++K5v4O/8kr8Kf9g6H/0EV2NAFL+1F/54Tf8AfFH9qL/z wm/74q7RQBS/tRf+eE3/AHxR/ai/88Jv++Ku0UAUv7UX/nhN/wB8Uf2ov/PCb/virtFAFL+1F/54 Tf8AfFH9qL/zwm/74q7RQBS/tRf+eE3/AHxR/ai/88Jv++Ku0UAUv7UX/nhN/wB8Uf2ov/PCb/vi rtFAFL+1F/54Tf8AfFH9qL/zwm/74q7RQBS/tRf+eE3/AHxR/ai/88Jv++Ku0UAUv7UX/nhN/wB8 Uf2ov/PCb/virtFAFL+1F/54Tf8AfFH9qL/zwm/74q7RQBS/tRf+eE3/AHxR/ai/88Jv++Ku0UAU v7UX/nhN/wB8Uf2ov/PCb/virtFAFL+1F/54Tf8AfFH9qL/zwm/74q7RQBS/tRf+eE3/AHxR/ai/ 88Jv++Ku0UAUv7UX/nhN/wB8Uf2ov/PCb/virtFAFL+1F/54Tf8AfFH9qL/zwm/74q7RQBS/tRf+ eE3/AHxR/ai/88Jv++Ku0UAUv7UX/nhN/wB8Uf2ov/PCb/virtFAFL+1F/54Tf8AfFH9qL/zwm/7 4q7RQBS/tRf+eE3/AHxR/ai/88Jv++Ku0UAUv7UX/nhN/wB8Uf2ov/PCb/virtFAFL+1F/54Tf8A fFH9qL/zwm/74q7RQBS/tRf+eE3/AHxR/ai/88Jv++Ku0UAUv7UX/nhN/wB8Uf2ov/PCb/virtFA FL+1F/54Tf8AfFH9qL/zwm/74q7RQBS/tRf+eE3/AHxR/ai/88Jv++Ku0UAUv7UX/nhN/wB8Uf2o v/PCb/virtFAFL+1F/54Tf8AfFH9qL/zwm/74q7RQBS/tRf+eE3/AHxR/ai/88Jv++Ku0UAUv7UX /nhN/wB8Uf2ov/PCb/virtFAFL+1F/54Tf8AfFH9qL/zwm/74q7RQBS/tRf+eE3/AHxR/ai/88Jv ++Ku0UAUv7UX/nhN/wB8Uf2ov/PCb/virtFAFL+1F/54Tf8AfFH9qL/zwm/74q7RQBS/tRf+eE3/ AHxR/ai/88Jv++Ku0UAUv7UX/nhN/wB8Uf2ov/PCb/virtFAFL+1F/54Tf8AfFH9qL/zwm/74q7R QBS/tRf+eE3/AHxR/ai/88Jv++Ku0UAUv7UX/nhN/wB8Uf2ov/PCb/virtFAFL+1F/54Tf8AfFH9 qL/zwm/74q7RQBS/tRf+eE3/AHxR/ai/88Jv++Ku0UAUv7UX/nhN/wB8Uf2ov/PCb/virtFAFL+1 F/54Tf8AfFH9qL/zwm/74q7RQBS/tRf+eE3/AHxXDeHZhN8fvGbhWXPhjQuGGD/x96vXo1ee6H/y cF40/wCxX0L/ANK9XoA9Coqo+rWUcio95bq7S+SFaVQTJgHZjP3sEcdeasQzR3EayROskbDKuhyC PUGgB9cJ8MYke48ZllBP/CRXPUf7EVd3XBfDO6jhuPGYYkH/AISG56KT/BFQBp+MtY1fSdU8NpYJ b/Yru/8As948rHftKMUVBjuw5OeAOhzxk+A9V1vUtD8QR63e2+pSWt2YIry1h8qN/wBzG0iqMnIS VpEDd9vtz1msabDqq23nxyZtphcRlCAQ4BAP5Ma5/wAL+D7bwH4Ym0uxl1G6tAMp9ukWQxjAGAQB x35yckmkI7SiiimMKiuv+PaX/cP8qlqK6/49pf8AcP8AKgDk/g5/ySvwp/2Dof8A0EV2Ncd8HP8A klfhT/sHQ/8AoIrsaACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigA ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACi iigAooooAKKKKACiiigAryyxttTk/aZ8RzW19BDpsfhXRxd2klsXknY3Wq+WUk3gRhSGyNrbtw5X HPqdee6H/wAnBeNP+xX0L/0r1egDyLxJ4B8Va7r2pajpPh7VdHvzqfkWgllh+yiESYe5f94zMzxv cMGG0qxgXGFJr234R6TeaL4FtLa9s5dOl+03cyWc7Bngie5leJCQSMhGUcE4xiuyooAK4f4X/wCu 8Z/9jFc/+gRV3FcF8M5mjuPGYETv/wAVDc8rj+5F70AXPHpvYdV8KTQX721mNTCXFvGv+v3RvtBP 90YJx3OPTB5z4U3yS6P4stIL+TUrO3vhJa3D3P2jdDJbwuDvwPmZi7suBtL46Yr0e+jjbyDOIWKy gxeZj7+DjHvjNZNvptlpOlXtvpdtZ2kO9mmjtVCjzCASSB3xjr2x2xSEdHRRUN4J2tJxbFFudjeU ZASobHGcds4pjJqiuv8Aj2l/3D/Kvm24+L/jOHwXZahcanYQPceFdJ1T7SlsQFupYrp5iwLfdd4Y lCjkAkZJIx3vw9+I2sax4W8WajfWNzrE1jKzx2GnRoZ1JTJtVDMFLofUj74oA6n4Of8AJK/Cn/YO h/8AQRXY15/8GdUdvhP4SY6fdoW0yAlWVcj5Bwfm612f9pP/AM+N1/3yv/xVAF2iqX9pP/z43X/f K/8AxVH9pP8A8+N1/wB8r/8AFUAXaKpf2k//AD43X/fK/wDxVH9pP/z43X/fK/8AxVAF2iqX9pP/ AM+N1/3yv/xVH9pP/wA+N1/3yv8A8VQBdoql/aT/APPjdf8AfK//ABVH9pP/AM+N1/3yv/xVAF2i qX9pP/z43X/fK/8AxVH9pP8A8+N1/wB8r/8AFUAXaKpf2k//AD43X/fK/wDxVH9pP/z43X/fK/8A xVAF2iqX9pP/AM+N1/3yv/xVH9pP/wA+N1/3yv8A8VQBdoql/aT/APPjdf8AfK//ABVH9pP/AM+N 1/3yv/xVAF2iqX9pP/z43X/fK/8AxVH9pP8A8+N1/wB8r/8AFUAXaKpf2k//AD43X/fK/wDxVH9p P/z43X/fK/8AxVAF2iqX9pP/AM+N1/3yv/xVH9pP/wA+N1/3yv8A8VQBdoql/aT/APPjdf8AfK// ABVH9pP/AM+N1/3yv/xVAF2iqX9pP/z43X/fK/8AxVH9pP8A8+N1/wB8r/8AFUAXaKpf2k//AD43 X/fK/wDxVH9pP/z43X/fK/8AxVAF2iqX9pP/AM+N1/3yv/xVH9pP/wA+N1/3yv8A8VQBdoql/aT/ APPjdf8AfK//ABVH9pP/AM+N1/3yv/xVAF2iqX9pP/z43X/fK/8AxVH9pP8A8+N1/wB8r/8AFUAX aKpf2k//AD43X/fK/wDxVH9pP/z43X/fK/8AxVAF2iqX9pP/AM+N1/3yv/xVH9pP/wA+N1/3yv8A 8VQBdoql/aT/APPjdf8AfK//ABVH9pP/AM+N1/3yv/xVAF2iqX9pP/z43X/fK/8AxVH9pP8A8+N1 /wB8r/8AFUAXaKpf2k//AD43X/fK/wDxVH9pP/z43X/fK/8AxVAF2iqX9pP/AM+N1/3yv/xVH9pP /wA+N1/3yv8A8VQBdoql/aT/APPjdf8AfK//ABVH9pP/AM+N1/3yv/xVAF2iqX9pP/z43X/fK/8A xVH9pP8A8+N1/wB8r/8AFUAXaKpf2k//AD43X/fK/wDxVH9pP/z43X/fK/8AxVAF2iqX9pP/AM+N 1/3yv/xVH9pP/wA+N1/3yv8A8VQBdoql/aT/APPjdf8AfK//ABVH9pP/AM+N1/3yv/xVAF2iqX9p P/z43X/fK/8AxVH9pP8A8+N1/wB8r/8AFUAXaKpf2k//AD43X/fK/wDxVH9pP/z43X/fK/8AxVAF 2iqX9pP/AM+N1/3yv/xVH9pP/wA+N1/3yv8A8VQBdoql/aT/APPjdf8AfK//ABVH9pP/AM+N1/3y v/xVAF2iqX9pP/z43X/fK/8AxVH9pP8A8+N1/wB8r/8AFUAXaKpf2k//AD43X/fK/wDxVH9pP/z4 3X/fK/8AxVAF2is241pLO3knntp4YY1LPJJsVVA6kktwKLbWlvLeKeC1uJYZVDpIgUqykZBB3cgi gDSoql/aT/8APjdf98r/APFUf2k//Pjdf98r/wDFUAXaKpf2k/8Az43X/fK//FUf2k//AD43X/fK /wDxVAF2iqX9pP8A8+N1/wB8r/8AFUf2k/8Az43X/fK//FUAXaKpf2k//Pjdf98r/wDFUf2k/wDz 43X/AHyv/wAVQBdoql/aT/8APjdf98r/APFUf2k//Pjdf98r/wDFUAXaKpf2k/8Az43X/fK//FUf 2k//AD43X/fK/wDxVAF2iqX9pP8A8+N1/wB8r/8AFUf2k/8Az43X/fK//FUAXaKpf2k//Pjdf98r /wDFUf2k/wDz43X/AHyv/wAVQBdrz3Q/+TgvGn/Yr6F/6V6vXa/2k/8Az43X/fK//FVw3h2YzfH7 xmxieL/imNC+WTGf+PvV/Q0AejUUUUAFcP8AC/8A13jP/sYrn/0CKu4rgvhn532jxns24/4SK56/ 7kVAFj4iaV9q1HwpfpHNPcWWpgxxoxC/NE4JYD6YyeBuNcx8GYdZt/DPiwa9p0un6lLqsk8wlfeH d4YWcqf7obIHsK9H1XWrHSLixt7q98ie+l8i2jYjdK+0sQBjsATWTo/ifT/GWg3l9pd1PNaxu0O9 4ygZgATjIGRyORxS6iOroopKYylJoWmzW4gk0+1kgCJGImgUqFQ5RcYxhT0HanfYbaxtbv7NbxW/ nF5ZPKQLvcjljjqTgcmrlRXX/HtL/uH+VAHJ/B3/AJJX4U/7B0P/AKCK7GuO+Dn/ACSvwp/2Dof/ AEEV2NABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFJQAtFMMmASeAOprkvFHxg8F eC7Yz614n0uwjU4O+5Vm/wC+Vyf0qJTjBXk7I3o0K2IlyUYOT7JNv8DsKK8c0P8Aa8+E3iHWotLs /GFn9qlbYnnK8aMfTcwA/OvXobiO4iSWJ1kicbldGBDD1B71NOtTq605J+h0YvL8XgGo4ujKm3tz Rav95LRSUtanAFFFFABRRRQAUUU0tzigB1FN3flVGbxBplvIY5dRtIpB1V50BH4ZpFRi5fCrmhRX Ia18XfBfh65FvqPinSbWYjPlvdITj8DxU+gfE7wn4pl8rSPEemahMTtEUNyhcn2XOTUe0he3MrnU 8HiVD2jpS5e9nb7zqKKbux1FG6tDjHUUgO6loAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAC iiigAoprNto3dKAHUVHJMsKF5GVFHVmOBXOaz8TvCfh6Nn1HxJpVoq9fMu0yPwBzUylGO7sbU6NW s+WlFyfkrnT0V4rqn7ZPwg0m48mTxlaTP3+zo7gfiFrHk/bm+GCuRFNrF1H2lg012Rvoa5ZYzDR3 qL7z3ocN51UV44Opb/BL/I+gqK+dbj9uj4fhP9D0zxRqcv8AzxtNIdm+vWn2P7c3w6kbGp2viDw9 76rpbxD65BNT9ew3/Pxfea/6q54lf6pP/wABd/u3PoeivLtF/ad+Fuvw+ZZ+NdLYYyVkkMZH4MBT PEX7UXwt8MWyz3vjLTirHCrA5lY/goNbfWaNubnVvVHnf2NmftPZfVp83bklf7rHqdJur561X9t/ wE0fleG7bWPF+oP8sNvpdi7Bm7ZY/dHvisqGP9pXx1H/AGjHceG/BFnMd8GnTI81zGvZZT03fSsH jKTdqV5vy1/HY9SPDOOhHnxzjh49Pavlb9I2cn62t5n01up1fLeo+Lvjh8DY18Q+NJdH8ZeD4nX+ 0m02Jo7qzjLAGVR0ZQDk/TtX0xpeq2utada31jOl1Z3USzQzRnKujDIIPuK2o11VbjZprozzcwyu pgIwqqpGpTldKUHdXVrp3SaautGlo7q55D+0LpNx451zwV4FF/cWWma5NePfratteaOC3Mipn+6X 25rof2cdTOq/A/wg7HL29n9iYn+9A7Qn9Y6q+Jx9r/aL8DQ9Ra6LqV19CWgjB/8AHjUH7OP/ABL9 B8V6H0Gj+JtRtkX0jaXzF/PzK6TxT1qiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK89 0P8A5OC8af8AYr6F/wCler16FXnuh/8AJwXjT/sV9C/9K9XoA9CooooAK4f4X/67xn/2MVz/AOgR V3FcD8M4DJceMyJpE/4qG54UjH3IvagDX8Z6C+rXnh+6htlmuLHUFl80gbooyjBiD2yducVyXwk8 M3nhnwrrNvLplxolkXRbbT7m5M7IUhRJHViT8jOpKjjgZwN2B2HibxTY+G9Q0ezuY5Wl1OdoYmQE qm1CzM57AYA9yR71leEPF9v4+8LXWqQWUtnCGxF5kyv5iFFdX+VjjhxlTyCCPegR2d4ZhazG3Cmf Y3lh/u7scZ9s1y3gVvFKyXEPiLypY1ghkguI02M7NuLoy5OGTheDg4BrrmUMpB6EYNeFfs9w6lpf ijxRp20S6TbSPC8jiUvFMkhCoHknk8xTG2d4CZKk45wAZ7tUV1/x7S/7h/lUm4etR3JzbTf7h/lQ Byfwc/5JX4U/7B0P/oIrsa474Of8kr8Kf9g6H/0EV2NABRRRQAUUUUAFFFFABRRRQAUUUUAFFIzY qnf6xZaUge9vLezQ9GuJVjB/M0r2Gk5OyV2XaQ8CvHfGn7Wnw18F3bWUmu/2vqKnBstHiN1KP++e P1riW+PHxU+LDNH8M/AP9k6YflGt+KyYVPriIfMMfjXHLGUYvli+Z9lq/wAD6Whw5mVaCrVKfsqf 81R8kfvla/yTZ9L7qqahrFjpUZkvby3sowMlriVYx+ZNfOS/BH476sN2pfG0WSTcy21jpMeI8/wq 5OcVe039ibwpeOtx4v13xB4yvGOZv7Qv2EEnt5a9B+NR7evL4KVvVpflc6P7LymhricwUvKnCcn/ AOTqmvxZ0Xin9sD4YeFrqS0Ovf2vfR9bbSYWuHz6ccfrXJN+1H438aKYvAfwk1m7EvEN/rLi1iUf 3mQjOPxr2nwp8JPBnge1jt9D8M6bp8cf3THbqX/76OW/Wus2ij2WJn8dRL/Cv1d/yF9eyTC/7vhJ VX3qz0/8Bhy/dzM+Zof2e/iV8Tz9q+JXxHurC3mO5tC8MjyIoh/dEp+Y/iK7Twt+yB8K/Ct0t3H4 Zj1K9Uf8fWpytcOfc5OP0r2baKWqjg6EXzSjzPu9X+JjW4lzSrH2VOr7KH8tNKEfuja/zuzifEXw V8C+KtFl0rUvCmky2UgwUjtUjI9CGUAg/jXiF14b8afsoXh1Lw9Jf+N/hhndd6NO/m32mL3eFv40 A/h9gPevqWmNErZBGQetXUw0J+9D3ZLZr+tV5GGDzrEYdOjX/e0ZfFCTbT811jLtJWfqtDn/AAL8 QNE+JHhu01zw9fR6hp1wMh0PzIe6sP4WHoa6OvnXxx8CPEPgDxJeeNfg7fR6XqE7edqPhi4H+g6i RySo/wCWbn26nHStTwH+174O8RXUOkeIvtHgnxLnyptO1mIxKJRwypIeGGe/FZwxPI/Z4j3Zfg/R /puddfJHiabxeUN1aXWNv3kPKUVuu0l7r8noe7Uhrjtf+MHgvwzo9zqeoeKdJitLddzsl2kh/BVJ Jrxm6/aY8XfFOVtN+Efgm8ut3B8QeIIzbWcQ/vBerg9iDWtTFUqbs3dvotX9xxYPI8fjU5xp8sFv KXuxXq5WXyV35H0nPcxWsTSzSJFEvLSSMFUfUmvIfiB+1d4A8A3f2AahL4i1c9NN0KI3c347eAM+ 9cZa/sn6942lS6+J3xI1nX3b5n03THFnbL/sfL95R07V6/8AD/4K+CfhdbiLwz4ds9MbvMqbpT7l 2y361jz4mr8MVBeer+5afieh9XyPA61q0sRJdILkh/4HJcz+UF6nj5+N3xt8Yr9o8K/CiLS9Pb/V za9eYeQeuxcEU3/hHf2kvHrb77xF4f8Ah/bdAmm25uZfqd5xX0xtFG2j6pKXx1ZP52/IX9v06P8A umCowts3Fzf/AJO5J/cfNcf7JfiLxAxPi34veJtVz95LBltB+ma0I/2Gfhv5Y+0y6/fTfxT3OqOz t9TivoTb3paawOH6wv66/mTLirOXpDEOC7QSgvuikeL6L+x38JNGt2jPhK31GRjl7i/leWVvqc1W 8R/safC3WbfNhoTeG9RTmHUtHneGeJvUHJH6V7jRV/U8Pa3s19yOVcRZxGftPrdS/wDjl+V7HzR/ wzX8T9Dynhv436raQ9BHqFklycfUmmL4X/ac8Lt9l07xR4T8VW45+2avA8Ex9tqcV9M7RSBQKz+p U4/BKS9JP9bo7P8AWbF1P94pUqn+KlC/3xUX+J81Dx1+0npZzc+A/DepJHwy2d26tJ7rk0v/AA1t 4n0r/Rta+DviW11GPiWO2KzR59QwHIr6U2il20/q1WPwVn87P9A/tnA1f94y+m/8LnD/ANua/A8W +G/7VXhjx7r8fh++stR8JeIZATHY65B5HnY6iNzwx/KvaFbNcV8VPg94a+L2hHT9fsy7xnfbX0Db Lm1kHR436gj8q8e8N+PvFP7N/iC08KfEi9fW/B17IIdI8YMvMBP3Ybr0PYN9PXifa1MO7V9Y/wA2 33rp67FSwGDzaDnlScKqV3Sbu2l1py05vOD97s5dPpiioLW6ivIY5oZY5onGVkjYMrD1BHWp69E+ Q8mFFFFABRRRQAUUUUAFIaWua8ffELQvhn4bu9c8Q30djYW46sctI3ZEX+Jj2AqZSUVzSdkjWlSq V6kaVKLlKWiS1bfkaWv+JNM8K6XNqWsX9vptjCMvcXMgRR+J7+1eG6x+214HEhtfDFlrHjTUGO2K LSbJmjZvdz0Hvisjwv8AD/V/2mtfh8Z/EWxlsfBULF9B8JSkr5gPS5uRxliOQvbj3z9E6P4Z0nw/ AsWl6ZaadGq7QtrAsfHpwK4FOviPeptRj0urt+dunzPq5UMqyl+yxkZV6y+JRkowi/5XKzcmuvLZ J6Jvc+fP+F1fHfVudO+DkdjFNzC9/qKnYp6bwMc03/hOP2mO3gfwt/4FSf419LbRS7RVfVZvetL8 P8iP7cw0dKeX0UvP2j/F1D5o/t/9p3WgbeLw94P0Vj1up5pXCj2APWk/4Ut8fb4efP8AG6Oylk+Z re30eNo4z6KSckV9MbRSbRS+pp/HOT+dvysH+sdWn/u+Gow/7hxl/wCnOf8ACx822/7HD+IGFx41 +JPirxDdscyC1u/skLe2xQeK6bRv2MfhHpEglfwsmpXA/wCW+oTySufr82P0r23bS1ccFh468ifr r+ZjU4nzmouVYmUY9ovkX3RsjktL+EngrRYPJs/Cujwxf3fsUbfqQa2YvC+jQRhI9JsY0HRVtkAH 6VqUV1KEI7Kx4NTE16rvUqN+rbKltpNlZyb7e0t4H6boolU/oKZqGhadq4xfWFrejp/pEKyfzFXq KqyMVOSfMnqeda1+zv8ADXxFN5t/4L0iaTOdywBP/QcU7w/+z38N/C101zpngzSbeZhtLNbiTj6N mvQ6Kx9hRvfkV/RHpf2tmDp+yeIny9uaVvuuZum+G9K0ds2Gm2dicYzbW6R/+ggVobadRWySWx5k pSm+aTuyvfWEGpWc9pdRJcW06NFLDIuVdSMEEdwQa8B+DN5d/BP4hXXwk1aR5NDuRJf+E76U53W4 OZLQnu0ecj/Zr6GryP8AaY8D3Pij4czaxo5aHxR4Yf8AtvSZ4/vCWIbmjHqHQMuO+RXJiItJVobx /FdV/XU+hyetCcpZdiHalWsr/wAs/sT+Tdpf3XLrYs7jeftNR/8ATn4TJ+nm3eP/AGj+lN+GijTv jF8V9PXiKS6sNQRfQyWqq35tGT+NYPwi8W23xE+Lmr+J7Qq1tP4V0gJt5C+Y00xX8C/6VreC9Stb j9o74gwW1xHOw0nTPNEbA7JFacFT74K8V1xfMuZbHz9WEqFR0qitJNprzW567RRRTICiiigAoooo AKKKKACiiigAooooAKKKKACiiigArzXSdQtbf9o3xZaS3MMd1ceFtEaGB5AHkC3Wrbiq9TjIzjpk V6VXmel6XZ3X7R/iq9mtIJby18LaKsFw8amSIPdatvCsRlQ21c464GelAFfXfjxbeGdSurbUtDvY Iba6jhluAysqJLvETH0ZjGx2HkIVbJLBTrHxhrvinwnpWo+HLGO2vZr+a2uoL1fMWEQmZJFJDDGZ IggfnG8HaelULj4B6NfrexX+sa1qFpeakdTntbieLy3k8xZFU4jBKq8cRGTkCNRnbkGh8S/DbeDf hJFpWjzazcXK6hG8d1bbZLhpZbgyPJIAUDAl3JUYzkAYzQB6R4Xvb3UvDemXepWjWN/PbpJPavjd C5UFkOCeQeOvaub+F/8ArvGf/YxXP/oEVbfgXd/whWg7pGlb7DDmR1KljsHJBZiCfTJ+prn/AIZ2 sc1x4zZgSf8AhIbnoxH8EVAG94s0H/hIodPjEqokF2s0mT95NjqQPf5q5D4Y/D+b4deFtTs7mWy3 S+Ukcdinlx7YoUiDkZPzvs3MfUj0yem8W69d6Lqnh+1tbBJ4dRvPs89y5wIF2MRx3JIA+gJrH8E6 lrmraP4gbXZdNuja3slrbXGn2rQLIsaqHYqzvz5m9ev8Oe9LqB39cd4V8E2XhebxM2ime3vL6ff5 l4u+ON/LBUIBglF3dM5zkZrr5lVoXD/cKkN16Y9q87+DE3gw6TdReENQvNTWPy1uri8muJHZsHBP nHgnBJ2gCmB4fN8U/HEfhrRpZ9ev4bufw+lxeSLap+6lWztZUmC+WfmlmllQr36AAjNetfDjxh4l 1Pwt4uu7q3m1jULWZjFZSMsWyUpl7VW2/dTjDEE/MeTivVf7PtSMG2iIwo+4OinKj8Ccj0olhjht bjy0VNwZm2jGSRyT70AcP8Gby7b4T+Ei1iUY6ZASvmA4OwcdK7P7Zdf8+Z/77H+Fc38HP+SV+FP+ wdD/AOgiuxoApfbLr/nzP/fY/wAKPtl1/wA+Z/77H+FXaKAKX2y6/wCfM/8AfY/wo+2XX/Pmf++x /hV2igCl9suv+fM/99j/AAo+2XX/AD5n/vsf4VdooApfbLr/AJ8z/wB9j/Cj7Zdf8+Z/77H+FXaK AKLXl0Bn7H/4/wD/AFq89+Kn7QPh34Q28Q1tnl1G44ttKsf311Of9mMc49zWL8aPi/ren6/ZeAPh /axan461OIyvJMf3Gl2/Qzy+/wDdXv1+tr4Q/s66R8O7uTX9ZuZPFnji6+e717UBufd12xL0jUHo Bz71wzrTqSdOh03b2X+b/pn1GGy/C4SjHG5o3aWsKcdJTXdv7EPOzb6K2p56bz4/fGpm1LSZ7b4V +HnGLaC4hW5vpF/vuDwPYVZ039jfR9Wc3XjzV9e8dag3+s+2Xxjt899sa4x+dfTG0UbRUrBU5a1b zfm9Pu2/A1lxNjaa5MAo4ePT2cUpW85/G/nI8/8ABfwk8I/Du3WHw94M0/TgvSRVDyf99sC3612f 2q5/58z/AN9j/Cr1FdsYRgrRVkfNV8RWxU3VrzcpPq22/vZR+1XP/Pmf++x/hR9quf8AnzP/AH2P 8KvUVZzlL7Zdf8+Z/wC+x/hR9suv+fM/99j/AAq7RQBS+2XX/Pmf++x/hR9suv8AnzP/AH2P8Ku1 DJcJCMvIqD/aIFS5KKuwIPtl1/z5n/vsf4UfbLr/AJ8z/wB9j/ChdXsmbaLy3Lenmrn+dWRJuGVI I9RUQq06nwST9GNxcd0VftVyf+XM/wDfY/wrmPGvw98P/Eaxks/Enhaz1eFxg/aAN4+jgBh+Brsx TquUYzVpK6NaNaph5qrRk4yWzTs180eGaP8AsjfCfQdSt7+0+HlmLm3bfGZbiWRQR6qzEH8RXsNu ZLWFIYdPWGJBtSONgqqB2AA4FaVFRTo06X8OKXorHVi8wxmPaeLrSqW25pOVvS7KP2q5/wCfM/8A ff8A9al+2XX/AD5n/vsf4VdorU88pfbLr/nzP/fY/wAKPtl1/wA+Z/77H+FXaKAKX2y6/wCfM/8A fY/wo+2XX/Pmf++x/hV2igCl9suv+fM/99j/AAo+2XX/AD5n/vsf4VdooApfbLr/AJ8z/wB9j/Cj 7Zdf8+Z/77H+FXaKAKX2y6/58z/32P8ACj7Zdf8APmf++x/hV2igCl9ruv8AnzP/AH2P8KyPFHh+ z8aaDeaNreix6lpl2hjmtp2BVh/Q+45FdJRSaUlZlwnKnJTg7NaprdM+XJvgN8Qvg9cPqHwm8STy 6bGd7eFNel8+B1H8EcnVOOg/WtfRf2wItN1S20z4heD9T+H1zMNqXWoESWruOo8xR8vPSvovaPSs vxF4V0fxdpkmna1pttqli/3oLqMOv1Geh9xXB9VlS1w8uXyeq/zXyPrFnlHHLlzigqr/AOfkfdqL 1a92b/xpvzKui+LLbxJZreaVLbalat0ltbhZF/TpWj9suv8AnzP/AH2P8K8C1v8AY/stF1B9T+GP ifUvhzfscmCzYz2bN/eMTnr+NZdx4o+N/wAB/wDiYeKvsnxK8JoQby702Dyb61ToXEY4YDrjrR9Z qU/41NrzWq/z/AFkuExv/IsxcZSe0JpwnftfWDfa09ex9JfbLr/nzP8A32P8KPtl1/z5n/vsf4Vl eBPH2h/Ejw9ba34e1CLUdPuFyHjPKnurDqrA8YNdFXdGSkuaLuj5WrSqUJypVYuMlo09Gn2aKX2y 6/58z/32P8KPtl1/z5n/AL7H+FXazdf8Qaf4X0m81TVbyKw0+1jMs1xM21UUDJJptpK7IjGU5KMV dsg1bxAND025v79EtLK2jaaaeWUBURRkknFfPfgXRrv9pTxzF8R/Eelu/grTWMfhfR7k4WYg4a9l U9SSPlB7eveBrjxF+2BqlvGbK58PfB23m82Vpsx3OvFT8q4/hhyOfXHvx9DX+q6V4L0eBCqWtvCi w29rAvOFGAiKPQCvHrYilKLxFeSjRhrd6J+foundn2TpyyKm6ENcZU0dtfZxe8br/l5LaX8sdN27 XxcXAxiyP/fY/wAKd9ruv+fM/wDfY/wrklvvF/iL95aww6JaNyrT/PKR646Uf2H4zsf30XiCC/Yf 8sJ7cIp/Ec15v9vSqe/QwlWcP5uVK/opSUn9x859TUdJ1Yp9rt/ik1+J1v2y6/58z/32P8KPtl1/ z5n/AL7H+FcnH8QLzR5BF4g0qa09Li3HmRn/AAro9N8UaXrCB7S/hlH93cAfyNd2FzvAYyXs4VLT /ll7sl/27KzMamErUlzON13Wq+9Fn7Zdf8+Z/wC+x/hR9suv+fM/99j/AAqyJN3Q5HrShjXuXOQq /bLr/nzP/fY/wo+2XX/Pmf8Avsf4VcFLTApfbLr/AJ8z/wB9j/Cj7Zdf8+Z/77H+FXaKAKX2y6/5 8z/32P8ACj7Zdf8APmf++x/hV2igCl9suv8AnzP/AH2P8KPtl1/z5n/vsf4VakcRqWYhVHJJ6CuR vviZp8U7QWMNxqsqnDfZkyo/4FXm43MsJl0VLFVFG+3d+iWr+SN6VCrXbVON7HRteXQ/5cz/AN9/ /Wrm9U+Jun6VdPbSI808Zw6W/wA5X68VUuPFmseJVGn6Zpdxpss3D3dz0iTuR7+ldNofhew0Kxjg hgRmA+eZ1Bd27kn614f9pYnNZcuUtRgt5zjK1/5YxfK2+7ei2V3t1+wp4ZXxKu3sk197evyMzSfi BY60wS3ZBKf+WUj7WH4EVsyXFxNGyPZbkYYILjkH8Kpa14L0fWoz59lGsv8ADNENjqfUEVzzXGve A0bzt2t6MnPm5xNCvv6gU5Zjjst1zOmpU/56aen+KDu0vNNpdbAqNKv/ALvK0uz/AEen42Pk34e3 Hij4c+OvHfwt8HKh8U6jqAhtLyY5j03TkV3EvuVWVVA9cV6T8CfA6fCf9ozxR4etWuL+Sfw5bXtx c3Uu6S4m87EkrH3LdO1cEbHWLDx747+O2gSyXcOg+Ins7rT4xn7XpoRRcEDuVVo3H+4fSvYNC1qz 1b9rjT9W0+dbjT9Z8EebbzIeJF+0Kyn8q+2p4mnGh9ToqyUU3/eu1Z37Jafe+pxY3B169VZ1iJcz qzmv8LWsk13lpK/VO3RnvH2y6/58z/32P8KPtl1/z5n/AL7H+FXaK5jIpfbLr/nzP/fY/wAKPtl1 /wA+Z/77H+FXaKAKX2y6/wCfM/8AfY/wo+2XX/Pmf++x/hV2igCl9suv+fM/99j/AAo+2XX/AD5n /vsf4VdooApfbLr/AJ8z/wB9j/Cj7Zdf8+Z/77H+FXaKAKX2y6/58z/32P8ACj7Zdf8APmf++x/h V2igCl9suv8AnzP/AH2P8KPtl1/z5n/vsf4VdooApfbLr/nzP/fY/wAKPtl1/wA+Z/77H+FXaKAK X2y6/wCfM/8AfY/wrhvDsjyfH3xmzx+W3/CMaF8uc/8AL3q9ejV57of/ACcF40/7FfQv/SvV6APQ qyfFWlw6xoN3bzvcRIAsyyWePOR42EiMmQRuDKCMgjI6VrVw/wAXx4a/4ReCTxVe3dhpcd9A3m2c s0bF92ApMPzbWBIPbBz1AoA6rQ9Ng0fRbGxtVdbe2gSGNZPvBVUAZ9+K5P4YyItx4zBZQf8AhIbn qf8AYirp/DMljN4d0t9LLtprW0ZtjIWLGLaNmS/zE4x97n1rl/hjEj3HjMsisf8AhIrnqM/wRUAd LrWlRaw1g8nmo1ncrdJtA5YBhg+3zGqdjpcPh/w3JYQ+dIoMsnmSAZLO7OSfxY1U8b32q6fqnhhr K6jtrCbUPJvVZNzyKY2Kqp/hGRk8dgOK4/4J+KNY8T+Ddbk1u6uLm6SdJIjdKgfypLeKQEbAB5ZZ pCmfm24ySaXUD1yvDvgNpok8b+Mb5LiUJa3ElmIS0pEitJ5ivIHcgSj5gQgUYbGOBXuVQwWcFq0r QwxxNK2+QxoFLt6nHU+9MCaobv8A49Zv9w/yqaorr/j1m/3D/KgDyj4UfELT9L+H/hyyv4riz8ux hVZnjPlsNo5zXpmn61ZarGslpdxTof7jc/lXM/CW1hvPhP4USeGOZP7Oh+WRQw+6PWrF/wDDbRrq YzQJLp8xPL2khTP4dK+Yqf21hZuVJwrQvs7wkl2v70XbzSO+P1WokpXi/vX6P8zrqK4UeH/FWh/L pmsR39uPuxXy/MPbcOtH/CX+I7Hi+8NSS4+9Layjb9cGs1xBGjpjsPUpP/C5x/8AAoc342K+puWt GcZfOz+52O6orhx8UrRDtn0vUoW/i/cEgfjVlPijoBUb7mWI/wB2SIg1rDibJ56fWYr1dvzsJ5fi l/y7fy1/I6+iuWj+JXhyRSTqkUftICD/ACqK6+J2gQgeTdPfMf4bVC5reWf5TGPO8VC3+Jfle5H1 LE3t7OX3M62vK/jt8Xpvh3pdjpOg266r4412T7Jo+m5zlz1mf0jQck/hVjxN8eNE8J6BfavqVpqF tY2cRkkkkh2jjt9SeB9a8n+Cdv4h8SeIdR+JWtaHNdeLtaGzT47pdsOk2P8ABGuf4mHLHrzXnVuJ cvnBLD1eZt292Mm/kktX26dz6TK8odOMswx0P3cNotpc8+kb3+FbzfbRayR6n8D/AINL8L9Ovb7V b1td8Y6y4uNY1mYfNNJ2RP7sa9AB/wDq9NaRVOCyj6muK/sbxdrTbb7VYNMgPWOyTcxH1PSnr8LL KRcy6pqkr92+0Y/pVU8xx0oqODwMuVdZyUL/AC95/fY8vGTWMryxGMrpzl2V15JbJJLRJaJaHY+c v99fzo85f76/nXH/APCqNN/6CGp/+BP/ANaj/hVOm/8AQQ1P/wACf/rVp9dzr/oDj/4N/wDtTh9j hf8An6//AAH/AIJ2inNOrhV+Ht9atix8SX0EQ+6kmHx+JpR4Z8XwfMnilZz/AHZLZQKP7Wx8P4uA n/27KnJf+lJ/gV9Wov4a6+akv0Z3NJXEf2P41/6Ddr/35pP+Ec8XXnyXHiKOCPv5EA3EfXtR/bWJ ekcBVv8A9uL8ecPqtPrWj/5N/kdhc3kNqpeaVIUHUuwFc1qPxI0y3byLHzNVuycLDarnn0Ldqgt/ hjprOGv7q81RupW5lJX8hXT6bo9lpcYS0tYrcf7CAH86nmzzGaKMKEX1v7SXyWkV97D/AGOn1c3/ AOAr9X+RyefGXiAY/wBH0G2b+L/WTAfyp8fwtsHwb2+vr5u/mTnBP0rtsCirjw5g6j5sa5V5d5u6 +UVaK+4X16rHSlaC8v8APf8AE5Fvhb4a2/Lp4R/76yNu/nVU/C+JTiHWtUgj7Is/A/Su4wKK0nw3 lE9sNGP+Fcv/AKTYUcdil/y8b9dfzOH/AOEL1zSzv0vxFMxH/LK8UOD+NGfHlvzjS7gDtlgTXcYH pRWX+ruHp/7vWq012jUlb7pcxX16cv4kYy9Yr9LHDf2r44TltK09wOySNk/rS/8ACxLzTxt1bQb2 3kH8UK+Yp+mK7jAoo/sjG0taGOnf+8oSX3WT/EPrNKXx0V8rr9WcUvxW0nH723v4T6NbGpo/ipoL cvNNAP8AprCRXWtDHJ95Fb6gGopNPtZv9ZbQv/vRg0fVc8jtioP1pP8ASYe0wb3py/8AAv8A7U5n /haHh3/n+/8AHDT4/iZ4ckbB1FY/d1IFb/8AY9h/z5W//fpf8KbJoenSKVewtmHvEv8AhT9jn6/5 fUn/ANuS/wDkw5sF/JL/AMCX/wAiZ1v460C5z5eq27Y/2sVZg8T6VdPiLUbdz6eYKhufBuiXWPM0 u2OOm2ML/Kqk/wAOvDtwuH0uEem0sCPyNK/EEelGXzmr/g7fiL/Yn1kvuf8Akb32+3PS4h/77FI+ o20almuYVUd94/xrlz8LNB7RTD/tq1C/C3QAwLW8sg/utK2D+tH1jPtvq1P/AMGS/wDlY+XBf8/J f+Ar/wCSNS78aaHYt+/1S3Q+m7P8qr/8LH8N/wDQYt/zP+FWLLwToVjxFpduBjHzLu/nVv8A4RnS P+gZaf8Aflf8KFHiCWt6K8rTf43X5B/sS6Tf3L/MxT8T/DqkgX+fcIaT/haHh3/n+/8AHDXQjRdP UYFjbgf9cl/wpf7HsP8Anyt/+/S/4U/Y5/8A8/6X/guX/wAmHNgv5Jf+BL/5E5x/iloCrlLmSY/3 Y4iTUDfFKxl+W0sNQun7BYCB+ddZHpdnC2UtIEPqsYH9KsJGkfCqqj/ZGKPqmd1PjxcI/wCGm/8A 26b/ACD2mEjtTb9Zf5I4geONcm/1PhK7Kn7rPMo/MYo/4SDxjPxFoVvAfWaXI/Su4o2j0o/sjGz/ AIuYVH6KnH8oB9apL4aEfvk/1OF/tLx1/wBA3Tf++2/xpGv/ABwylW0vTWB4ILMc/rXd7RXlHxm8 ba4up6T4F8GvHF4p1tXke8kG5dOtF4ecj1zwoPU0v7Drf9B1b74//Ih9cj/z5j9z/wAzx/xd8GvG ngvxJceLfhwjeFNVuG8y8063PmabeN33RH7hPqPwxWpoX7Zl34ZX+z/iX4H1nRNUjGDdaXbNcW03 qw7qPYk16V8BfEmppb6x4G8TXTXfibwvN5D3UnDXtq/zQXH4qcH3X1r1Wa1huFKyxRyr6OoI/Wnh cpxmCm3TxblF9JRT/Fcv5H0z4ioYylGlmmFVXl0UlJxml25ve5l5STt0seHJ+2t8JpNPe6/4SPbs HzQNCRKD/d2+vtXmV34j1f8Aaf8AFVldax4e1Ox+F2myfaINJdCkusSg/K83pGOu39a+jbr4M+Bb zWIdUl8JaO19E29ZvsaA7vUgDBP1rs441ijCIqooGAqjAFa4jA5jiYOm8Soq/SF9O2rHDNspy+9X LMPP2rXxTmnyX/l5YrXtJ6rpZ6nBW3jS+S1is9K8LXERjQRxRthI41AwOMdB6VpaB4TuG1D+1tdk S81NuI4wP3duvoo9feutowKmjk05VY1cfXdZx1imlGKfflitX2bvbofLzxas1Rhy33d22/m/0DFG KWivpjzxkkSSIUdFdT1VhkVzmqfD3QtUk8xrJYJv+eluSh/TiumpMVwYrAYXHR5MVSjNeaT/ADNq dapRd6cmvQ4hvhfCvEOt6pCnZRP0/Sm/8K2lh+aHxFqaydi8m4flXc4o2j0rxf8AVjKelK3pKS/J nV/aGJ6y/Bf5HDf8IHrH/Q03f/fAo/4QPWP+hpu/++BXc4opf6s5b2n/AODKn/yQ/r9fy/8AAY/5 HDf8IHrH/Q03f/fAo/4QPWP+hpu/++BXc0Uf6s5d2n/4Mqf/ACQfX6/l/wCAx/yOG/4QPWP+hpu/ ++BR/wAIHrH/AENN3/3wK7mij/VnLu0//BlT/wCSD6/X8v8AwGP+RwsngfW7zFvf+JprrTm+/AsI RmHpuFdfpmlWmk2qQWlvHbxqMBUXH5+tW8UtehgsnweAm6tGLcnpeUpSduycm2l5LQwq4qrWSjN6 dkkl9yE2j0paKK9o5RD05rEs/EmjeKNKv5dPvrfUbaBpLe48pwwRlJV0b0IINamoXkWm2NzdznbD bxtK59FUEn9BXxTY28vwV+F/h74iWpuIl8UaTewazCrkxtdzRSS2s23sd4CE+jCk4qSs+obao9k/ ZHSxv/g7JbyQhje3t3dTxyDIljmkbaT6goAPwryf4b+EdT+EH7XOieFbqUyeHlsr1dBmkPP2WQPL 5GT3Rwyj8PXA9w8CaGfh34B8C30SEQW+lW1nfqB/AUUhz7qx/WvL/wBrrwvqvij4ofDGPw/ffYNa ljvH0+6U8efEFljB9mYAH2avFwNaUqtehVX7yleyXWD1jb5Ll/xRZ7VKfuRwzmo0q0oXb15ZJ25v ld/9uyZ9Yilrzj4I/Fy0+LXg9L3yzY67aN9m1bS5OJLO6Xh1I64JBIPcGvR69inONSKnHZnn4rC1 cHXnh68bTi7Nf1+D6oKKKKs5QooooAKKKKACiiigAooooAKKKKACiiigArz3Q/8Ak4Lxp/2K+hf+ ler16FXnuh/8nBeNP+xX0L/0r1egD0KuD+NlvdXPgG4W2v49NjFzbNczSQSSjyRMm4YjZWA6EkH7 oYd67yk69aAMLwHI03gjQJHUK7WEBKqGA+4OgYlgPqSfWsD4Z3Hl3HjMeW7f8VDc8qM/wRV3tcP8 L/8AXeM/+xiuf/QIqAOp1DT4dR+z/aLdZTbyiaLc5G1wCAfyJ/OsLR/COl+DdEvrXRdPSztpnMkg Fw8h3YC9WJIACgBQcADAAqD4g2c8uqeE7mK+uLdYtTCNBEQI5d0TgF+Mnbg4GcZPOeK4X4Cy3beF PEEMhWS2gkgRJku3uVml+zRGaQOwBG9iG29ixHXNIR7bRRRTGFQ3n/HrN/uH+VfNnxm8QeLNO+IO t2+n3d/HpIsZJJZbQsTC3lQ/ZFVdpAJm8zkE7tzBgAoruPhnrXimbwr4xnktm1bVYbl/Ks72c26f adg8yFZCp2xg7cHBHJoA8t8HeLPjD8KvDml30Ogr8SPBl5aRz29vYsIL3T1Kj930IZR64ya9K8B/ tYfD/wAaSpY3Oot4a1zO19K1pDBMrdwM8Ee9dT8GbjUP+FT+Ei9jGr/2ZBuUXGQDsGRnbzTfHPwj 8MfEqJ08S+D9M1RmGDNIwWX/AL+KA361wSpV6bcqU7rs/wBHv+Z9VTx+V4qEaeYYflkklz0nZu2n vQfuv5cjfVneWtzDeQLNBLHPE/KyRsGU/QipeK+YJv2V/Fvg2eR/hp8QtU8LWn3k0y+kF7bqf7qh h8q1Ovxk+Nvw7T7N4t+F48VxxDB1Tw5chVYD+JlYHk+1L61KGlam15rVfhr96NP7BpYrXLMVCp/d k/Zz+6dov/t2TPpg4PXpVeTTbOVsvaQO3q0ak/yr560r9uLwNMwh1q21Hwvdg4kh1a3aMIf97HNe j+E/jx4N8cOV0LxHo2ovjO2O+Ct+TKKpVsLiNOaMvu/U8/E5Hm2BTlXw04rvyu33rT8TtJvDumXD Zk0+1fHrCv8AhUtro9lp+Tb2cEJ/6ZxgVjXHjq0t/EGm6I8lr/amoxyzWtuLkEyLGAXIwO2f5+le e/tCfFbUvCuh23hjw/HG3jrxK/2DSreOUO8W7h7hhjhUUk5PfFROhhaF6/s43XkrnJgsNiMwxEcL Tesu+yXVvsktW+iRzHiCQ/tL/F0eHIHZ/h14PuVm1WVT+71PUF5S3B7pH1b349K+jY1CqFAAA4AA rhvhV8P4/hP4H0zw3plmjxWqZluGm+e4mPMkrHHLM2TzXXfaL7/nyj/7/wD/ANat6FNxTnP4pb/o vl/wTpzXGUsROOHwulGlpHz7zf8Aem9X2Vo7JF2iqX2i+/58o/8Av/8A/Wo+0X3/AD5R/wDf/wD+ tXUeGXqKo/aL7/nyj/7/AP8A9aj7Rff8+Uf/AH//APrUAXaWqP2i+/58o/8Av/8A/Wo+0X3/AD5R /wDf/wD+tQBdoql9ovv+fKP/AL//AP1qPtF9/wA+Uf8A3/8A/rUAXaWqP2i+/wCfKP8A7/8A/wBa j7Rff8+Uf/f/AP8ArUAXqKo/aL7/AJ8o/wDv/wD/AFqPtF9/z5R/9/8A/wCtQBeoqj9ovv8Anyj/ AO//AP8AWo+0X3/PlH/3/wD/AK1AF6iqP2i+/wCfKP8A7/8A/wBaj7Rff8+Uf/f/AP8ArUAXqKo/ aL7/AJ8o/wDv/wD/AFqPtF9/z5R/9/8A/wCtQBeoqj9ovv8Anyj/AO//AP8AWo+0X3/PlH/3/wD/ AK1AF6iqP2i+/wCfKP8A7/8A/wBaj7Rff8+Uf/f/AP8ArUAXaKpfaL7/AJ8o/wDv/wD/AFqPtF9/ z5R/9/8A/wCtQBdoql9ovv8Anyj/AO//AP8AWo+0X3/PlH/3/wD/AK1AF2lqj9ovv+fKP/v/AP8A 1qPtF9/z5R/9/wD/AOtQBeoqj9ovv+fOP/v/AP8A1qPtN9/z5x/9/wD/AOtQBeoqj9pvv+fOP/v/ AP8A1q8b+K3i7xT428T/APCtvBk0el6i1v8AadY1hX3/ANnwNwqDgYkft6DmgD3KivnXwf8AtO6f 4N0ceHPiBK1l4r0eRrG7Zg2LjZwkykA8OuD9c1d1D9qqDxBcW+mfD7QZ/F+tzZYxxkxwwIOrSMRx 7CgD3m4nS1hkmlYJHGpd2Y4AAGSTXkHwBsT4quPEfxKvULXXiS6aPTy/WLTojshUem4hn98iuRuv hb8QvjhcT3/jfU73wfpwQwWuhaHe+WSp4d5mwd+7pj0r3XQtOk8OaLY6VY6fHFZ2UKW8KCYcIqgD +H0FAHm/xz0S88K6lpnxR0GNn1HQV8rVLWP/AJfdOY/vFI7sn3x9DXG+JPGXjT4heOtU8TfDXU47 nR/C1jb4098mHVnmXzpI+vDLH5eD1BOOMmvYl+IWj6j4svPBzXFhNrsduJZ9Ma4G8xOCOhHOR29D Vf4Z/Diy+E/h+bR9C0/ZaS3Ut0fMuAW3Oc4zt6KAFHsKqUZRtzK1yIzjO/K720+Zs/D3xvY/Ebwf pniDTsi3vIg5jY/NE44eNvdWBH4V0dfPfiT9nvXdF1nUPE/gHXr/AEXVmuWvo9Gkuw2mySNzIhi2 8b+ec8E1a039oHxT4c1rTrL4h+Cj4bs9SkW3ttUiuN9usxIAWQ4O0Eng1JZ71RVH7Tff8+cf/f8A /wDrUfaL7/nyj/7/AP8A9agC9RVH7Rff8+Uf/f8A/wDrUfaL7/nyj/7/AP8A9agC9RVH7Rff8+Uf /f8A/wDrUfaL7/nyj/7/AP8A9agC9RVH7Rff8+Uf/f8A/wDrUfaL7/nyj/7/AP8A9agC9RVH7Rff 8+Uf/f8A/wDrUfaL7/nyj/7/AP8A9agC9RVH7Rff8+Uf/f8A/wDrUfaL7/nyj/7/AP8A9agC9RVH 7Rff8+Uf/f8A/wDrUfaL7/nyj/7/AP8A9agC9RVH7Rff8+Uf/f8A/wDrUfaL7/nyj/7/AP8A9agC 9RVH7Rff8+Uf/f8A/wDrUfaL7/nyj/7/AP8A9agDkfjzrP8AYPwY8aXudrLpU8an0Z0KD9WFebfG 7Q1t/gN4N8BrCjX2r3WlaLCrDmNgUMkg/wB1Ucn6mul/aQe71L4dw6M9qijWdWsNOIEuciS5TcOn oDXFeBfEHi747/Ejw34ru/DcWneDdDe+n02f7Rk3kjfuI3PHZRIf+BV6GDpKTdaduWGrv1dnZed2 jzMdWcVGjTvzz2t0V1d+Vkz6Il023m0s2BQG1MXk7P8AZxjH5V82fEa6ltfiZ8F4Llv9K0vXrjT3 Y9WR0j2N+Kj9K+kvtF9/z5R/9/8A/wCtXzp+1JanQ/Enw08VSxLB5HiS3hl2yZDZViD07BTXzdXD zjjKWNp/ZUoy84OLf3xkk/Ry7nrua9i6Uuri163X5r9DW+MngnU/hr4wj+Lfgmykur2ECLxHo1uM DU7TvIB/z1TqD3H6+s/Df4kaF8U/DNvr3h68F3Yy5Vgw2yROPvRuv8LDuK2Yb27miWSO1idHG5WW fgg9D0r508Yfaf2aPibN42tNO8v4f+JGSHXrW2OU0+6HCXYAHCsDhuPf0xT/ANnftoP3Jb+V/tLy 7/f3Pq8O1nlBYKov9ppq1N/zpf8ALt95JX5Hv9j+W305RWVY6rNqFnBdWsMFzbTIJI5o7gFXUjII OORU/wBovv8Anyj/AO//AP8AWr0j5Fpp2Zeoqj9ovv8Anyj/AO//AP8AWo+0X3/PlH/3/wD/AK1A i9RVH7Rff8+Uf/f/AP8ArUfaL7/nyj/7/wD/ANagC9RVH7Rff8+Uf/f/AP8ArUfaL7/nyj/7/wD/ ANagC9RVH7Rff8+Uf/f/AP8ArUfaL7/nyj/7/wD/ANagC9RVH7Rff8+Uf/f/AP8ArUfaL7/nyj/7 /wD/ANagC9XkPhHxVeah+0t4/wBEe6kew0/SNNaK2LfIjt5jMwHqQ65+gr1D7Rff8+Uf/f8A/wDr V82fCXW7m+/bK+MOyFXb7HZx+X5uAvlxxIcHHPOfzr1MHSVSniJNfDC//k0TycdVdOrh4p/FO3/k sj6hrz3Q/wDk4Lxp/wBivoX/AKV6vXafaL7/AJ8o/wDv/wD/AFq820m+1ZP2lvEcSaZC9hN4V0c3 d19rw9uy3Wq+WFj2fPvy2Tkbdo6548s9Y9Xor50k1zXdS1jVrrw5rmpS29trVxbNYTRktJKljene xZBtjMohCqvH7hWz85FerfB27uL74f2UtxPPdA3F2sE90D5kluLmUQs2QDzGE689KAO1rgvhm8q3 HjPZErj/AISG55L4/gi9q72uH+F/+u8Z/wDYxXP/AKBFQB0Gra1p2n3thZ395aw3V3JttYph80jj +778/r71Q0++0zUNFvW0WexktI5ZI5fsaAKJM5cHHfJznvnNcx8UpLe68WeGdMfTZnluZVlbVI7f zPIWOaN0jDfwl5AhJ/uofas74NaXdWPhbVmm02fSl8q0tjDPEIy80NrFHNIAOoLLtz32UgPX6KKK YBUV1/x7S/7h/lUtRXX/AB7S/wC4f5UAcn8HP+SV+FP+wdD/AOgiuxrjvg5/ySvwp/2Dof8A0EV2 NABSUtFAGTqvhfR9cB/tHSrLUM/8/Vukn/oQNeceLf2Vfhd4wUPdeErSzuVO5bjTc2zqfbYQP0r1 2uc+I3iyPwL4F13X5CMafZyTqD3YKdo/FsD8axnRp1Pjin6o9HC5ljcFJSwtaUGv5ZNfkz4f8RfA S2tbHx34p8P694gh0jwpqSWFtIl8zTmJCovWjkPI27iFxx8rZzmvqD4Mfs8eG/hvey+I4NW1Txbr F9Aoh1jXLj7RNHARkJG2OFOc+vNXfAPw0k039npPC92u7UdR0mc3rN1NxcIzSZ9wz4z7VrfAHWjr 3wX8G3bHL/2ZDC/rujXyzn8VqFhqKcZKPw7eR0zzrMKlOrSlWdqjvLvL1e/46nfjpS0UV0nihRRR QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUVS1rWLTw/pF7qd/MttZWcLzzSucBUUZJ/IV8+w/FX 45a54fk8S6N4N8NpoE0T3dol9PMt01uMlSyhsbioBx70AfR9FYXgXxTD428G6Jr8ACxalZxXQUHO 0soJX8DkfhW7QAUUUUAFFFFABRRRQAUUUm4evtQAtFeP/ET4wa+ni4+Dfh3o1r4g8TW6Ce/kvnZL OyjIyFdlOd7cYHbIrE/4ST9ov/oU/BX/AIGTf/FUAe2a7rVn4c0e91TUJ1trGziaeeVuiooyTXzT p/jL4h+HIB8Xr+eSXwdq1yHvPDkiEvY6eWCw3Cc/eC/Mw7g5+m/eeE/i58W7zTtD8e6foGjeEFuV udQXR7iR5btU5WBtxPyM2M49K96vNJs77SptNuLeOWwliMD27L8hjIwVx6Y4oA8q+OOsXPiez8I+ ENA1OazuPFd6hOoWEm2SKxjUSzSow6ZXYAfVhXU/Cv4T6X8J9KvLeyu7zU7y+nNxd6lqUvm3Nw2M LvfHIUDArnvhf+zrovwt8RNrFrrOsaxLHatZ2cOqXAljsomYErEMDaPlA+gqDxp+0l4Z03wfq2oe G9QtfEWtW14NKttLhfLy3rNsSMjrjOSSOwNb0qFWu+WnG+349+xz1sRSw8earK3/AAOx6beeG9I1 K4ae60uyup24Mk1ujscdOSM15p4n+O/wu+FHiG40e7vrPTtTRVM8NjbAlQc4DlB19jXGN8Mfi98Z Z1Hj7xBH4F0m2GY7PwfcMs08n995WyQB029DXpfw7+BPhT4eaG1hDYLrFzLI09zqWrItxc3Mh6u7 sOT9K7/YYXD/AMefO+0f/krW+5M836xjMT/Ap8i7z/8AkU7/AHtGx8Ovij4Z+KWmTX/hvVI9Qghk McqjKvG3oynkZrQ8d+LLXwJ4O1rxDeEC2020kuXB/i2qSF+pOB9TXl3xI+Buo2fiCPxr8MJ7fw94 shQJcWJUJZanGOkcqjgH0Yc8/jXK6x4b+N/xak0zw9400bwzpHhOS/guNSk0u5kaaSGJxJ5eGJBD FQKuOFw9SUasKiUOqb95d15+TX4Gc8ZiqUHSnTbqdHFe6+z8vNMXwz+zOnjL4d23iDV7640v4man cHXDr1sSJrSeQArCB3jVdqlT6HGKvaD+0s3w4e48NfF6JtI8Q2IHl6lbws1tqUXaZMdDx8w9fSvo iNBGoVRtUcADoKoap4f0zWsf2hp1pf7QVX7TAsm0HqBuBxmpePVduOKjzRvdW0cfJOz08ti1lzw6 jLCS5ZWs76qXm1da+e4ug65YeJNItdT0y7ivtPuoxLDcQtuR1PQg1R8c+DtP+IHhPU9A1OMSWl9C 0RPdGI+V19GU4IPqK+evGvwjtf2eda0fx14c1zWrXw/BrcCX+gNdltPgtZ38uRkj7YZw3Oa+oRja Oa5cRQhTUalGXNCV+lnp0fnqvvOvC4ipUcqdaPLONr63Tv1Xlozzj9n7xJqHiH4cwwavL52s6NdT 6Peyd3kgcoGPuybGPuTXpNeTfC9f+Ef+LnxQ0HkRT3drrcC+1xFtkP8A38iavWa4j0AooooAKKKj aeNZAhkUOeikjNAElFFFABRRSKwYZByPagBaKK434gfF7wp8MEtj4h1aKykuCRFCAXkbHU7Rzj3o A7KkrF0HxjpHiXwvB4h06+judHmhM63Kn5dgzuJ9MYOfpXyd8R7jxJ42+GWq/FLWPFOsaFZzN5Xh nQdCnMBlDybITKers5w30zjANXThKpJQgrtmdSpGlB1JuyR9l0tcL8DfGh+IHwm8Ma5JJ5l1cWaL cN3MyfJIfxZSfxruqg0CiiigDwT9rzxJ/wAI14Z8MXSttkg1OS9X6wWdxIp/77CfmK9A+Bvh3/hF fg/4N0srta30q33rjozIGb9WNeFftw79d174a+FoW+bWLua2ZR1HmPBED+TvX1dHGsUaoihUUYVR 0A9K75e7hIr+aTf3JW/NnnR9/Gyf8sV/5M3f8kOr52/bgUQfCrRL5hlLDxFZXDfTEi/+zV9E14j+ 2dpf9q/s6+KABlrc29yp9Nk8ZJ/LNYYeKlVjF7PT79DoxLcaUpLpr92p3HhW6fw9qX/CPXUhaBl8 3T5m/jj6lPqv8q6jWNJs9e0u506/t47yxuo2imt5VDJIhGCCK5PSrL/hPPhr4av45PJvZdPtb22u R1R2iVs/Q55rZ8JeIJdVjuLW+iFvqlm3l3EQ6HPRx7GvjsDJ5bWWWVfgf8J+W7g/OK27x80z2qjd ZfWqbtJfFbv/ADL1/B+p4L4T1i8/ZW8ZQeDfENzJcfDTVpiugaxOS39mSMc/Y5m/u5+6x+lfTKSL IqsjBlYZDKcgj1rE8ZeDNI+IHh2+0PXbGPUNLvE2SQyD8iD2YdiORXgfhDxfrP7M/iS08DeOLubU PBF5J5Xh/wAUT5Jt89LW5b1HQN/jx68X9UfLL+G9n28n5dn02PoakI8Q03XpL/a4q8o/8/Et5x/v /wA0ftfEtbo+maKZFIkkasjB1YZDKcgg96fXpHxoUUUUAFFFFABRRRQAUUUUAFfJH7PeZP2rPiHf k5XUG1RVPqIbu3QflmvrYmvkn9nP/kqmgakT/wAhex8SzZ/vEarEB+iGvdy/TD4jzVvwcv8A20+e zLXE4ZdpX/FR/wDbj63rz3Q/+TgvGn/Yr6F/6V6vXoVee6H/AMnBeNP+xX0L/wBK9Xrwj6E9Cooo oAK4L4Zib7R4z8towP8AhIbn7yk/wRe9d7XD/C//AF3jP/sYrn/0CKgDQ8SeNNP8NaxpenXQvGl1 BwiyQRb44cusatK38IZ3RR6k0/T9esPFGh315pt09xBBNNas2MAyRuUcD1GQRmsnxzZ69qXijw3D Z6ZDe+Hop1ub+Q3iwyLIjqYvlKncq/NIQCCSiDPXOjomkPoei6zDKIoxNe3NxEsbDHlu5K/TjtQB 1VFFFABUV1/x7S/7h/lUmaiuTm2m/wBw/wAqAPAPh/8AtNfD7wr4H0LSNR1eSK+srOKGZFgchXCj IzjmtTVf2vfAy2Eo0WW713VmAS1063t2DzyE4VQSOOT1rrfhL4Z0e8+GPheafSbGeZ9OhLSSWyMz HaOSSOa7G38M6PZzJNBpNjBMhyskdsisp9QQOKAPBo/2i/G955fhWHwG8PxLZ/mtLjcNPSHGfPMg OduOMZzn8q6TwX8ctW0/xQnhT4naVa+F9fuTusLq1dmsb0H+FHY8OPQnn8K9k+zxed53lr5u3Z5m Pm25zjPpmuf8efD3QviToEuka9YpeWr/ADKx4eJuzo3VWHqKAN77Zb/894/++xXkXxwuR4y8QeCv h9ausqavqAv9S2HO2ytSJGB9mkEa+/TvWV/wx74U/wCg94m/8Gj113wz+Avh34Wa1d6tp0+o31/c W4tvP1K5M7JHu3FVJ6AkDP0FAHo+5VwuQPQV5V+zrJHp/hfXdBLqr6P4h1GySPIyI/OMqDH+5Ite a/F3UPGPi74l+JdZ8G6zJYQ/DfTll+z8mG/upB5ssLrnnEKqPUFhjFO8Z+DLOLwvbfHLwtPfxauw tPEN1p8dyfs00RVPtClB38vdk/7Jrur4SVCnCo3e+/ldXV/VannYfGRxFWdNRats+jSdm16PQ+oK Kp6Tq1rrWn217ZTLPb3ESyxspByrDIP5VcrhPRCiiigAooooAKKKKACiiigAooooAKKKKAEPSvCN S+JvxX8TeKvEUHgDw/4cv9B0m9OnG61aeWOSSZFUyY2tggM236g16h8SvH2nfDXwbqWu6jPHEtvE xhjc8zS4+SNR1JZsDj1rF+Avhefwj8KdDgv939p3UR1C+Zx8xuJ2Msm73BbH4UAeez+Bfir8Yry0 0v4ipo3h/wAJQyCe6tNBnd31AggrE5YnCZGTjrXv0drFDbrBHEqQqgQRqPlCgYxj0xSx3UUxIjkV yOu1gcUSXMUOPMkWPPTewGaBXR5R+zrnQdJ8T+C5WPmeGdauLaJW6/ZpW8+A/isn6V65Xg/xM8SR fBH4u2fjW5trubw74gsDp2piygaZ0uITvgk2jrlS6/Qe1J/w2j8P/wDn18Rf+CiSgZ7zRXz9d/tY 23ioJpXw+8Oatrnia4bbBDqNk9tbxjvJI5/hHcDmpv8AhIv2jR/zKngf/wADZ/8A4qgD3l5FjUs7 BVHUscCo/tlv/wA94/8AvsV4DJ8Ofij8Y76G2+I15Y+F/D1p+8Fl4WunEl5J2LuSSAvp3zVqT9jv wu0biPxD4oikIIWRdUfKnsfwoA95zXlviT9pr4d+FdaudKvdeR7y2bZMtvG0io390kcZ/wAa4hvB vx1vbEeC7nWdIj8O7vIk8Uwuw1J7cf7GcByPl3de+a9Y8H/CPwl4H0C20nT9EtGgiGWluIVlllY9 Xd2GSSaADw/8XfCfirwpd+ItM1iC50y0SR7ht2Hi2AlgynkHArwvwLZ/GldLHjfw3cadqyeLGl1C bRNdldY7AM5MLREHODHtG3pXo3jT9lvwP421qfUnt7rSZbhQt1FpU5t4rjHd0XgnHFd74q8WaB8L /CUup6tcxaZpFhEFH0AwqIvcnAAAqoxlOSjFXbIlONOLnJ2SMX4N/Dt/h14VMeoTC98R6lK19q99 1M9y/Lc/3V+6B6D3qj40/aN+H3w/18aLrPiCGHUcAyRRgv5WTxvI+7+Nebap+0FrHxvZfDHwo07U LK4uBi/8QataNBHp0RPLIrfecjOP8mvQ/CH7Ovgzwn4PudDOlxarJfRst/qN+olubpnBDOzsCQeT jHSvVWFp4XXG3u/sq1/V9vJbvyPHeMq4p2wNml9p3t6Lv5vZeZ6bDPHcwpLE6yROoZXU5BB5BFZ/ ibxBZ+FfD2pazqEgisbC3e5mf0RFJP48V8+aBpn7Qvw50qHwzoml+FPEGi6YWtrHUdUu5VuZbcMf L3hWAyFwPwpNe8N/HX4sW1v4Y8YaP4W0jwreXUJ1O40m7ka4a3Rw7xqGJHzbdp+tUsvgp3lWjyf4 le3pve3QTzCo6do0Zc9v5Xa/r2v1K0Piz9oj4leEkksPDvhfQtL1y2zDe/aZRd20Mo4k2liN4U56 da9G8J/sw+A/CWreGNXtdIT+2NDthBHd5x5z7cebIvRnyWIbqCfYV6vBClvCkUaLHGihVRRgKB0A HpUlY1MfUknCilTi76Rvr01110NqWXU4tTrt1JK2srO3XTTTUQcCloorzD1gooooAKKKKAOW+KXg xPiH8O/EPhtyqnUrKSCNm6JIVzG34OFP4V4no3xt8ffCBtLtPi/4fsbPQ5IVtodb0RnuAkqKB+/y eCwHUAc5r6VqtfafbalbtBd20V1C2MxzIHU45HBrvoYmNODpVYc0W79mvR9OnRnnYjCyqTVajNxm lbun5NdevVHhmmfEbQ9a+M/g/wAX6JeLeaB4o0650BrheNl1DJ50aOOxx5igH+9XvlfJHxo+Htx4 J+IX2Tw2iwWvignWNMs0G1LfWrICX5APuiaIOhHcmvo/4f8AxA0v4g+D9L1+ymVIryIM0UjAPFIO HjYdirAj8KzxNKNOSdP4ZK6/yfmndGmFrTqxcaqtOLs+3e69U0zqK4T4gfG3wf8ADDUbSx8Raqtl dXMZmSPYWIjBxubHQZz+RrrdQ1zTtKsZ7y8vre3tYEMksskgCqoGSTXjnwg0vT/ihrHjD4h6tZQ3 2n6xcfYNKW9hDKthACocBhwJHLt/+uuQ7TrPF/7QHgPwTb2MuoeILdvtsXnwJa/vWePH3sL0H1rx y3+FniX4oeGdS+KQ1PVNM8X3cp1LQ9LS4ZYIoIyDbxPH3LqvPrvr1vwP8D/h58P7i/n0vSrFpLxy zNdMsxjXORGm7O1R6Cu51DXtJ0DS57y7vbWysLWMvJI0iqkaKOv0AFUotuyRLlFK7Zg/C/4naV8T vCFjrNnPHHPIgS6s2YCS2nA+eJgecg5HvXLfFP4keMdO8Z6Z4T8AaVper63JZyajejVZHSKCAOET lSPmZt3X+7XGWPwz+GH7RAvvF3hHV7/SLuZmjuJNHuDbETrnbJJH/e6EHuDmug+HHhXVPhBpvjXx p8RNYi1PUSih9RiX/lxto8Jx2ZjuJXucdzVSpVIz9nKLUtrdTONanOn7WMk4736WMu9m/aH8TWr6 Vcad4T8PW93+6l1SxuJZJ7ZCfmdFYkFsZxWFoPjzx18K5rv4V6ZpFx4v8T2twZNK1LUWYW7WD/MJ J5BzlSWTAPUegxXa/Br486l8SfGWo6Tq3h2Xw3BNYpqmjLc5866td5RpGHY7tpwOgYV7MII1mMoj USkbS+PmI64z6VpXw9TDT9nVVmZ4fEU8VD2lJ3X3Hg+n/tJ3nge6utI+LOkJ4c1hF862uNLR5rS7 jP8AcJydwPBBNX/gn4Bg8UR3vxG8WabHdeIPEUjTW8N6gkFjZH/UwqrcA7QGJ9Wr1/UNL0/VPLW+ s7e825KLcRK+PXGRxXlfx18Qa5cXfhv4f+EbxNK1nxI0omvguWsbKJMyyqOx5VR7tSoUXXqKmnbz 7Jat/JFYissPTdRq/kt23ol82cZ4o+E/j7RrjxP4Z8AS6UfA3iR/MnW4uCs2lNJxOIAOMMMsAe5/ GtzWNHt/FXxs8F+CLKMDw74HsE1i6iUfKZ8eTZxkf7IDuB7VjXH7OPif4UzWuvfC7xHeahrMX7u7 0zxJdtLa30Z65P8ACwPOR9K774F+BvEfh2HxH4g8ZpZp4t8Q35ubtLFy8MMSIEhiQnnaFB/P1r04 wo4aMq9KqpaWXR3ej07JXafp1PJlUr4qUcPWpOOqb6xstUr+bsmvXoYfwBuLbwp41+I3w+jYRx6X qX9p2MPTbbXKhyqj0R8j/gQr3Cvk34kSeIfAf7WVz4o0DS5NZQeHYrq+06Ftsk9sJDFIU9WUiNse 1dXH8aPiv4uhl1/wf4Bs5PCcXKJq8jxahdqv3jEgIAz0GR1FeZWpum15pP71/merQqKrF+Ta+5/0 z6Hori/hj8V9E+KmiteaW7w3cDeXeadcDbPayd0df6968b8R/Hv4mfZvE3iPQNI8Jp4H0q9ntItQ 1i6ljllEJ2s2A2DlgcY+lZRi5NRirtm8pRinKTskN+LGnf8ACUftkfDDT8b4tMsJNRdewIMpB/NU r6ZHQV8ifst+NNb+OPxs8Q+O9e0uPTpNO0ePTokhhkjjzJJuBXeSScI2ef4hX12OgrqxMZ0uWjUV nFberb/Kxx4WUK3PWpu6k9H6JL87i159+0Fpn9sfBLxta7dxbSp2A91UsP5V6DWV4r03+2fC+r6f jP2qzmgx/vIy/wBawpS5KkZdmjorR56Uo90ziP2atSOrfAXwRMTnbpscH/fvMf8A7JW74ssrnSb6 HxFYRmSS3Xy7uFes0Pr9V614x+wp4vl1L4WyeHbw7brSXEsSnq1vMWZW/B1lX8K+lHXcuOtedmmX rEwnhpPllF6NbxlF6Nej+9aPRm+DxKtGtHVSW3dMraZqNvqljBdW0glglXcrD0rO8ZeDdI8e+Hb3 Q9dsY9R0y8QpLDKMj2I9COoI5FYEm/4eas0gBbw7eSZYDn7JIe/+6f0ruI5kmUPGwdGGQw6EVwZf jXjISw+JjarDScenlJd4y3T+T1TO2cZYapGtQk0t4tbpr8mv+CfMOg+NNb/ZS1eHwv43nutY+HMz 7dH8UOC8liCeILkjsOzen4AfS+n6la6pYwXlnPHdWs6CSKaJtyupGQQfSotY0Ox8Qabc6fqVpDfW NwhSW3uEDo6nqCDXzXPp/ir9kW/mm0q2uvFfwjmkMj2EeZLzRMnJMfd4vbtx9a6fewe+tP8AGP8A mvxXofTONHiJXglTxfbRRq+nSNTy+GfS0tH9R0Vz3gfx7oXxF8O2ut+HtRi1LTrhcrJEeVPdWHYj 0Nbsk0cOC7qgPTcQK9CMlJKUXdHyFWlUozdKrFxktGno0/MkoqD7dbf8/EX/AH2K8p8aftSeBfBH iC40a5n1DULy3wJ/7Ls2uUiY/wALMvAb296oyPXaK8Cb9tj4coxVk11WHBB0xwf51XvP2zvCupQm 08MaVrOs69OfLs7GSzMKyyHoGcnAHf8ACnqK6PoWivh/xd+2z8SvBviC60e58N+G7+7tSFnOlrc3 Mcb4yULK+Nw7isb/AIb/APiL/wBCZpv/AIBXf/xdelHLMbOKlGk7PyPMlmmBhJxlWjdeZ936lN9m sLiXOPLjZ8/QE18sfA6D7DrXwKlxj7doWsyZ9fNmWf8ArmsPwj+0l8Z/i9o2uLpPgrRIbK2tZPtN 3dJcQKo2HIUs/LY5AxXYeC7ePT9U/Zk8k5ibRryHJ/7B6t/MV1YVSoKph6qtJpu3pCf+Zw4qUcRK liaTTgmlf1qQ/wAj6drz3Q/+TgvGn/Yr6F/6V6vXoVee6H/ycF40/wCxX0L/ANK9Xrwj6I9Coooo AK4L4ZweZceMzvZf+Kiufun/AGIq72uF+GLqs/jPLAf8VFc9T/sRUAWvGXiy78M6lpUcWiG+0+5m jhubzzFQQGSVIkCrgl2JfJHGApNVvCfii48V6TrX9o6KNFvrCcQPbmRZcboY5lJYAYbbKAR2IPNO 8YeHda1nxV4fv7DUdNi07T2Z5rK+t5JN8hIAkUq6gMq7wu4EAvnGQMV/A+h6p4W8KXllrmoafqN9 JI8rXVjbyRGZmwWeTe7ZcnPTAAAAAApAd/RRRTA+ZPjBp/i+b4jeIZbEa3JpD2Dp5Wnyyrtfy4Ps 7IQ4GTMHACgHiTcWBAHdfDWHxdb+FfGPmBv7YNwxh/tYyNC1zsHmFfmyISduApAGGxXsFRXa/wCi zAf3D/KgDwT4T/HzwzpnwjhbUNZs7Kbw3Zw2+owzKyOsmwY2KTlgx4UjrVJf24vA7Yxa6/8A+CSX /wCKrc8D/AfwX410HwF4r1fRYLvV7HTYdrsPklwo2mRej7e2a9s+yRbQBGgx/sivUU8DGK9yUm99 Uremjv36djyHDMJyfvxilto3f8Vbt17nE/D/AOLGkfE7QV1bQtRtZbfcY5IpwYpoXHVHQnKmum/t KX/n5sv++/8A69eY+OP2VfBXjjxHca44v9Gv7kD7SdIuWt1nYfxuo4Lc9awf+GK/Bv8A0G/E3/g0 en7PAy95VZR8uW9vndX+5EqrmMfddKMvPmtf5WdvvZ7Z/aUv/PzZf99//XrG8ZeOY/BfhTVtdvLm zNtp9tJcOqvy21SQo56k4H415Z/wxX4N/wCg34m/8Gj0+3/Yt8Ex3MEk2o6/exRyLIbe61Fnik2k EKynqMjpTjRwCacqsmv8P/2wpVsxlFqNGKffn/8AtTofgD4O1bRfhmt3rMcL6x4kll1nVFlU58y4 +byz/uoVXHbGKofs429zN8J7nwrdLBcJoV9faBNHMCd0ccrBQR6GNkP0Ne1quyMKOAPSvAtc1Nvg D8ZrnV76Yp4D8azL9pmb7mn6kqhQ7HskqgAn1WnCcsb7WH2pPmS81fRfJu3pYmdOOA9jU+zFcrfk 7av5pX9blJf2fvFPwnmt9X+F+stNcxjyptE1y5d7S5j7DOcoV7EfSt7wb8bvEVr4ri8I/EXSbHwz 4hufmsbm3Zmsb0f3Ucnhx6HrzXtccizRq6MHRhlWU5BHqK5X4m/DfSvij4VudG1SIZYb7a6UYltp h92RG6gg46da8g9w6D/iYf8ATv8Akf8AGmySXsalna3VR1LZA/nXgHh39qS0+H+nDwz8Q7HWB4r0 ljaXU9jp7zxXIXhJlYcfOuCfcmpLfQ/FH7TV0uoatPf+EPh4jFrHT7dzDe6ge0sp6qvcL/hQB7zH c3czERyWrkddpJ/rUn/Ew/6d/wAj/jXhl5+zHeeDvL1f4feLtW03X7c5WPU7k3FtcL3jkU9j69qf 9j/aG/6CHhX/AL9NQB7h/wATD/p3/I/41yWqfFbR9F8dWPg+91Szt9evIDPDbvkArkgAtnhjgkDu Aa88+x/tDf8AQQ8K/wDfpqu6B+zfZ694Z1h/H5j1fxTrd2L271K2JR7Zk4iSBuqKg9OuTmgD1z7f P/z8Wf8A31/9epw1+wBBtyPof8a8U/4Y98Inj+2fEn/gzeqlr4D+NXgVW0fw14m0zWdBgY/Y59cQ tdJGeiMw+9j1oA92/wCJh/07/kf8aP8AiYf9O/5H/GvD/sf7Q3/QQ8K/9+mo+x/tDf8AQQ8K/wDf pqAPcP8AiYf9O/5H/Gj/AE//AKd/yP8AjXh/2P8AaG/6CHhX/v01VtS8P/tBa1YT6fNrHhu0gukM MlxbxsJI1YYLL7gHigCfQbB/jt8VLvxLexw3nhTwrM1hpMEgJgurwH99c4z8wU/KueOprtfjj441 L4ffC/W9VthC2otELSwjjBLPcykRxADPJ3MD+FZPjjVoP2fPhBpejeGLZJ9WZodI0a1cZNzdScb2 9f4nY+xrA8L/AAj+IHjTxhpOufFHXrO4tNDmW60/RtJXbBJcDpLL/eKnoPUZr08NQilHEV5JQT26 yt0S/C55OLxE5OWFoRbm1v0jfq3+NjnNO/Zx8b/Cmz0vX/AXiSXUPFEUSpqGm65dvJZ32QN4JzlS GyQRzVpf2ffGnxfvLjW/ihr0mmXmPJs9H8OXbx21qg6tuzlmY889K+l8fLihRitP7UxL97Tm/mt7 1u1/6002M1lGFXu68n8t3y3727/rqfOfg7x14r+DviTTPAPj8rqml3UottD8VyKSs5/ggn9JOwY9 ePWvT/iV8SNL+E/h3+2vEBjjtWlWCOO2gMs0sjdFRAcscAn6A1pfE74eWHxO8E6l4e1D5EukzFcL 9+3mBzHKp7FWANeWfD34S+PtV8baNrXxP1aw1aDw5bsmlQWacPOwCtcSju4Uce7cd83fDYn9/Vai 1fmS05u3L0V3v0W67GdsVhf9npJyTtyyevL3Uu9lt1ez7ndfC/4uaJ8WtNnvfDdzC7QN5c9rcQmG 4hPbehORnqK5n4ofFjxlp/jOx8G+ANK0nXPE7W7X16NQd0t7O36KXZSMMzdB7VL8VPgPPrOtR+MP A2p/8Ip45t12/aolHkXqf88506N7N1+uBW98G/hCnwz0/ULq+1GXXfE+ryC41TVrj780gGAq/wB1 F5wtTbB0068XzdoPo/Nq10t11fZFN46rbDzXL3muq8lrZvZ7pd9jzK3/AGv/APhE2l0n4heGtT0L xNatsnh0+wkureQdpI3B+6ewPNeofDj40aJ8VNHn1HQ7+ER27mO4t71DBNCRz86McjI5HtXoDW6S HLIrH3ANeUfEX9mHwZ8SvED6zex3mnX80YiuX0ycwC6UdPMA+9xkfQ1PtMDW0lB033T5l9zs7fN2 K9nmFDWE1UXZrlf/AIEr6/IyLf8Aa68C3Xi5fD6ao3mNcfZV1FrRxYtJ0wJs45PH1qr4q+PnibWv Fl14V+F2iWPinVrFsX+o3bsmn2pHWMup+Zu3B4NelXnwg8JXngM+Dn0S1Xw95PkraKmNo7MD1DZ5 3Zzmr3gD4e6J8M/DNroWgWaWdjAO3LyN3d26sx9TR7XAwXPCm3JbKTuvV2t934i9jmFR8lSolF6t xVn6K9/v/A8Qj/au1PwDcTaP8UPC91ouvRnckmi2kl3aXMZ6OjZyMdOT1qLwvMf2pPiND4kubGYe A/DIC6fZalbtEL2+YZaV4yeRGMAZyMn619KtCknLorfUUscSx8KAo9AKPrlGCcqNLlm1a99Ffeyt pp5u1x/Uq03GNerz0072tq7bXd9fu1sUY4LyIYRLVB32qR/WpP8AiYf9O/5H/GrtFeSeztsUv+Jh /wBO/wCR/wAaP+Jh/wBO/wCR/wAau0UDKX/Ew/6d/wAj/jR/xMP+nf8AI/41dooApf8AEw/6d/yP +NH/ABMP+nf8j/jV2igCl/xMP+nf8j/jR/xMP+nf8j/jV2igCl/xMP8Ap3/I/wCNH/Ew/wCnf8j/ AI1dooApf8TD/p3/ACP+NH/Ew/6d/wAj/jV2igDxf9pmx1CDwDaeKIkja88J6lb63F5SncUjfbMP p5bufwFY9x+zD4T8ZXU3iCw1C/srbVm+3LHpl68dufMAYsig4AOc/jXvN9ZQ6lZz2tzEk9vMjRyR SDKupGCCPQivmjRfiNP+yjdXHg/xdYanf+D1kkl8O6tYW7XLCEtn7NIo6FMnB9Mfh6tGnLGUFRp6 zi7pd097ejV7eb7Hj1qiweI9tPSE0k32a2v6rS/ku5vQ/se+GFnia7vtW1K3V1ZrW7v5Hilwc4YZ 5FV/ivqlz488RaV8HPCt3Hp6OFuNduNLzH/Z9jHgiIEcK8hwoA7fiKpa/wDtoaDrmlT6b4K0nXb/ AMV3mLbTYLrS5IojO5CqWY9AM5/CvU/gv8JbT4VeFUt2YXuvXp+06tqknzS3dw3LMW67QSQB0ArS FCWXr22Ijaf2U+/8z8l07v0ZlUrxzF+ww8rw+012/lXm+vZeqPM/+GK/DnbX/EI/7iUn+NSW/wCx b4VjuIXutQ1jU4EdXazvL+R4ZcHO1xnkV9E0tY/2pjf+fr+83/snA/8APlHgXxA+Deu+E/ECePPh lFZ6dr0Eax3uhxjy7TVIF6IyjgOB0IxXEeJPjHL+0U+gfDa30XU9F1C+1GNtft7y1dEt7aA+bLH5 nRtxRV49RX1mRmmCFA+/au7+9jmrp5hyqLqw5px+GV9V2v3tuvztoZ1ct5m1Rnywl8UbaPvbtfZ/ 5nh3x+tdR8GXXhT4k2NvG/8Awi1w0eoRW4OW06Zdk3HcIQj49s9q67xx8bNA+Hnhe317VtUtms7o KbWO0UzTXO4ZAjQHLcHP0rvdS06DVrC5s7qJJ7a4jaKWKQZV1YYIP4GvKPh/+yz4I+HfiGLWbOC6 1C8t0KWn9pTmdLQH/nmp4XjA9sVFOrh6lKMcTe8L2t1T1tfpZ31s9/IqpSxVKrJ4W1p2vf7LWl7d brpdbHkWqeP/AB38QtYufi54XjvIvC3hQiG20OeJ4n1SEjN5IUPQgFduc/c4759E+DFp4j+IXjbV /ihrWk/2NBd2UWmaJY3WfNjtAxd5GH8JdiD9BXuqwKowqqB6AcU9V2jFXVzBTpunCmo6WT6qOjt5 tvVvzfQijl0oVVUqVHLW7XRy2v5WWiXknuVP+Jh/07/kf8aP9P8A+nf8j/jV2ivJPbPEvHDXOh/t GfDvU3aCMalpmpaXI5yF+QRTIDz3O78qvfFz4qa/4UuND0DwhY6brfi/WpmW0tLh2EMcSLuklkKn IUDA+pro/iv8G9E+MOn6faa1JdwCxnNxBNYzGKRGKlT8w7EGsn4X/s7+GPhRrV1q2mSX19qM8Itx calcGd4487iqE9ATjP0r14VMK6cJ1LuUVblto9W1d321106HhTo4tVKlOkkoTafNfVaJOytvppr1 PnLxT448a+FvHj65eeEINA+ItnZyy3kOklmstcsThWdOcmSJmVvXg9hium+Gfw9ufiTqmjeGL+NJ fB/gJEF7byZ8vUtZkHmy7xn5ljZ24Pc16d+0PdR+Ddb+HHjiQ7LfR9b+y3b44FvcwvE5PsDt/HFX v2W9Plj+ElnrF0MXniG8utbmJ7+fMzIf++NldL5aVH69SjyuStp0k27tf9ur5cxzLnq11gK0uZRf M77uKSsn/wBvP58p6XDbXduoWKO1jUcAIhFS/wCn/wDTv+R/xq7RXz59LtsUv+Jh/wBO/wCR/wAa D9v/AOnf8j/jV2koGfHngr4ceJ9A8YeJbTwbqEFj4t8I3jJBZ3hIttT0u4dp4Uk/3WaRdw6bfpXp P/CRftHf9Cp4G/8AA2f/AOKrc+Lfwf1rWvEtp418Ea2dB8YWkAtWWQbrW+gDFvLmX2JOD2/KuV+x /tJf9BDwn/37avZqUoYyXt1VjFvdNtO/Xp1evzPBpVqmCj9XlSlJR2cUnp069Fp8ixd6t+0RfW8k E/hDwJLDIpVka8nIIP8AwKueh8RftAfD2xjin8PeEZbKSXZG0t5MywZ6DIYEL9c1s/Y/2kv+gh4T /wC/bVDeaP8AtF6hayW9xeeEZYZBtZGibBFePi8lVV/WKFamq0U1GTb69HZap/hutTup5q4+5OhU 5HurL/M0k8TftGSKGXwt4FZW5BF9Pg/+PUy48SftErGfO8K+AxGflPmX02Dnty1ci0f7QngGxt4H 1Dw41gz7RMyM6wZ7H0Fblv8ABHx78XrmK4+J3i4R6Tbrm00/wxKYElc/8tHccnA4ArTCxo1G6WIr wVSKTlGLcmr9tFddnoiamKraOjh5tPZtKK+bu7Hmdp4A+MXwz8X6p460HS/CugWzRPPqOhabqLGy uyoJL+Ux+V+P4CvSuLh+P+gfF7Um1P4j69r9ndhNlnoPhq0lWGBOpfIfc5b36V9If8MU+CJMCfU/ EN1CSN8E+pOySL3Vh3B6Vs/Ez9l3w34yhsb7w+zeC/E+mRiPT9X0hRGUVRhUkUcOnABB5xxmt3Tw ODg3Ri6jfTSCX/pWv3I9eniMdnNeMczrKikrKdvaPTZSS5XZdX70rbJ2sfMKeD2+Jl59k+E+l+JN SEI3XWo+JL2ezt4/RAN2Sx65zXqfgvwX8efBXhn/AIR3RfCvgjRIJy3naql1LNch2PzTEsx3uM55 9K6Pwj+0Xqfw51a38JfGPTf7D1Hd5Vt4kt4/+JffjoHJAxGx4z2zxX0Ta3UN9bx3EEiTQSAMkkbB lYeoIp0c0w81ahRjp0ldyT89V+VjnzDh3H4GSeMrSal8MoWUJL+69fnrdPezPnG1/Yn0ma3STVvE +vahqbjfc3QvnQSSHlmCg8DPapl/Yl8NKcrrmvg+o1F/8a+kKK3/ALUxv/P1nlrKMDb+Ejh/h/8A DHTfhn4cg0XQ7G1htYzueSRS0kznq7seWY10v2O5/wCeNn/37rTorzpzlUk5zd2z0oUqdOKhCKSR hava3jaNfxKlsqvBICFUjqpFfN/hOa5/sv8AZlnzHlDcWqnB/wCfJ0Of++a+qbhPMt5E67lI/MV8 o+G5Nvgb9nyf/nh4ouLP9buPH/jtdmB/jW7qX/pLOLH6UNOjj/6Uj6lH2/8A6d/yP+NcN4d83/hf 3jPztu//AIRjQvudP+PvV69FXpXn2h/8nBeNP+xX0L/0r1euA9I9Corib34yeE9Pvri1m1NRJbXz abcMFO2GdVhJVj25uIVz/ekUV0XhrxFZeLNFt9U092e1mLqPMXaysjlHUjsQysD7igDUrg/hlDHJ ceMy8asf+EhueWUH+CKu8rgfhndRQ3HjNXcKf+EhueP+ARUAWPHus67o+raA+mzWqWM13FBPbyoW luS8iKQmD8oSPzJCf9ke+avgfxBqusab4ntNamhnvtNvmtvMhhMQZDDFIDtJPy7ncKe6qDWn4j8E xeIPE2j6219qFpPpisscNuV8uRXZS4YEHqEC5GDgkdzUPh/wfY+CdH1CCzN7cG5IZ5rxzI4VUCIm 4/wqqgD8T1JNAjs6KKKBhUV1/wAe0v8AuH+VS1Fdf8e0v+4f5UAcn8HP+SV+FP8AsHQ/+giuxrjv g5/ySvwp/wBg6H/0EV2NABRRRQAUUUUAFZPijwvpnjLQ7vR9Zs4r/TbpDHLBKuQQe/sR2I5Fa1FV GTi1KLs0TKKmnGSumeB/BXxmPhrr158JPFN8Y7/TZSdAu7tsf2hYNzGoY9XTlSPYele9iuA+M3wl 034seELqxmiSPV4UMumagBiW0uByjq3UDcBkdxTPgb8RZPiN4Ctrq+T7Pr1jI2natanhobuL5ZBj 0ONw9mr0cQo4iH1qCs7+8vN9V5PX0fyPLwrnhqn1SeqteL8l0fmtPVfM9BMatyVBP0oJ29q8R8Vf tifD7wj4j1HRbltXvbqwlME8mn6c88IkH3lDrwSOh9xXO3X7Sms/Fy6g0P4Q6PdNqPMt7qmvWb29 vaRDpwfvMx4FEctxUkpShyx7vRW73HPNMJFuMZ80trLVt+h9IbqN1fO/9nftJf8AQV8K/wDfk0f2 f+0l/wBBXwr/AN+TT+oL/n/D73/kR/aMv+fE/uX+Z9Ebq5n4j/EDTPhl4Pv/ABDq7MLS1UYjjGZJ ZCcJGg7sxIFeL3k37R2g276jKPDeuRWv719Ot0KyzqOWRD/eIzj3pfCd5rf7S3jbQ/EGp6FPoPgD w/L9qtrO+GJr+/AwHZcfcjO7HqRWkMAov2tScXTW9n+He76f8AynmMpr2VOnKNR7cy/HtZbv/glR viB8d9JsU8aaj4c02bw3n7RP4et8m/htj6Hu6rhiPrWov7cnw62jNn4lBxz/AMSaWvoTbx1pPKX+ 6v5VH1rDVP4tDbblfLp56O/r95pHB4ql/CrvXfmXNr5aq3oeVfDP9prwX8VvEbaHo7ajbal5DTpF qVk1t5qqRu2bvvEZBI9K9W3V5p8bvhjf+ONN0nU/DlzFpvjDQroXemXki/Lz8skT+qOp5HsK4L+z v2kv+gr4V/78mm8PQxCU6M1DupPX70tUxfWsTh26dem59nFaW81fRo+iN1DNtFfON7d/tG+G7Z9U uE8O69bWn72XTbVCktwgPzKh/vYzj3qnrH7Rmo/G7T/+EQ+Guiapa65fxmLUNR1O1aCLSoiMSOGP 32GSBjvRHLKstYTjKPVp6R9dgeaUopqcJRl0TWsvTc6TwWw+Nnxqv/GTky+FfCTSaXogPKXF4eLi 5HqF+4p+pr3cLiuf8BeC9P8Ah94P0nw9pUfl2WnwLCnq5H3nb1Zjkk+proa5MVWVap7nwx0j6f5v d+bO3CUZUad6nxy1fq/0Wy8kFFFFch2hSYpaKACiiigAooooAKKKKACiiigAooooAKKKKACiiigA ooooAKKKKACiiigAooooAKa0av8AeAYehFOooAjFvGrAhFBHfFPpaKBWS2CiiigYUUUUAFFFFABR RRQAUUUUAFFFFAHBfHT4dt8VvhVr/haORIbi+hXyJZB8qSo6uhPtlRXU+F9Fi8N+GdJ0iAAQ2FrF aoAP4UQKP5Vp0Vs603TVG/up3+bsv0MFRgqzr295pK/krv8AUWiiisTcKKKKAEo20tFACbaNtLRQ BBcWsd1DJFKiyRSDDIwyCK4hodQ+HczPbJJqHh5m3NCOZLbPp6rXfUxo9wweleNmGWxxjjVpycKs fhmt13TXWL6xf4PU6qNd0rxkrxe6/rZ+ZU0nWLTWrNLqzlWaFujL29j6VdBzXF6r4Vu9Dvn1Tw4V jlc5nsGOIpvcDsa0/DfjG11xmtmRrLUY+JbSbhgfb1FcmEzSUaqweYrkq9H9mfnB9+8XqvNamlTD pxdWg7x6916/57FrxN4S0jxlotxpOt6fb6np867ZILiMMp9x6H3HNfO03hLx/wDsuXU0/g6Cbxx8 Nd29/D8shN7pqnr5DH7yD0OcAetfT6tuoK5r2qtCNVqSdpLZr+tV5Hbl+bVcDGVCUVUoy+KEvhfm usZdpRs/locF8Kfjh4U+MWnPcaBff6VDxc6dcjy7m3b0dDyK71W3V438WP2adH8c6kniTQbybwf4 2g+aHW9M+QyH+7Mo4kU988+9chpH7Qvij4P6hFoXxo0kW0LnZa+LdMjL2dx/11A/1bY5PYVisROj 7uJVl/Mtvn2/LzPUllFDM17XJpNy60pfxF/h2VRelpd49T6VorN0LxFp3ifS7fUtJvYNQsLhQ8dx buGRge+RWlXemmro+SlGUJOMlZoSvknS2+z/AA3+FK97H4lyW59g1zef/FV9b18kXQ+zeAYs8Lpn xX6/3Qbo/wDxz9a9DAf7zFd/1VjzMw/3ab7Wf3NM+thXl1hoVrfftMeJNTl88Xdh4V0dIdlxIkeJ LrVQ26MMFc/KMFgSvOMZOfUV6V59of8AycF40/7FfQv/AEr1evPPRMHx9+z9D461C+ebUFt7W91e PVJUjRg4CQ2aqgIIBzJZIx3AjDHjcAw7/wABeGp/CfhmHT7q5ju7sz3F1PNEhRGkmneZtqkkgAyE DJPAroaKYBXD/C//AF3jP/sYrn/0CKu4rgvhnceXceMx5cjf8VDc8quR9yKgCt8TJHj8ReGWg1e5 tr0XAeLT4JdqSxrIjXEkg/jURBkAPG6QY5wRl/BzxpL468M+KdQnunnk/tOQrE6lfs0bQxOkOD/d DYPvmu31zwvoerazp2oalZWc2p2pxZzTY8xCGDYT8Qp49BU7rB9hv5LQ27CRy07QtnL7QCTg9cAf kKQjcooopjIGvbdJGjaeJZF5KFxkZ6cUTyJJaz7GDbVYHBzg46V4d8Zvh1fa5rGva1YaPNcTixis YRZjbLcF1lLvkYJ2yC0wT93y2I6nOz8NvD3izR/CvjCIlLLV5rhjBNqcbPDLcBMPcbQQTGx28Aj7 poA674Of8kr8Kf8AYOh/9BFdjXn/AMGY9SHwn8JB5rUv/ZkG4qjAE7BnHPSuz2ah/wA9bf8A74b/ ABoAu0VS2ah/z1t/++G/xo2ah/z1t/8Avhv8aALtFUtmof8APW3/AO+G/wAaNmof89bf/vhv8aAL tFUtmof89bf/AL4b/GjZqH/PW3/74b/GgC5XgvxI+Enjux8catr/AMMtXsdH/wCEgtli1aG8TK+c gKrcR+j7TgnvtBr27ZqH/PW3/wC+G/xpPL1D/npb/wDfDf4104fETw8nKCTv0aun8jkxOGhioKM7 q2qadmvmc/8AC/4cad8MfBOneH7EGRbdN09w/L3EzcySse5ZiTXVrEq5xxVXZqH/AD1t/wDvhv8A GjZqH/PW3/74b/Gsak5VZOc3dvU2p0oUoKEFZLQubRRtFU9mof8APW3/AO+G/wAaNmof89bf/vhv 8ag1Le0UKoWqmzUP+etv/wB8N/jRs1D/AJ62/wD3w3+NAF2iqWzUP+etv/3w3+NGzUP+etv/AN8N /jQBcIzRtFU9mof89bf/AL4b/GjZqH/PW3/74b/GgC3tpBGFzjv1qrs1D/nrb/8AfDf40bNQ/wCe tv8A98N/jQIudKWqWzUP+etv/wB8N/jRs1D/AJ62/wD3w3+NAy7RVLZqH/PW3/74b/GjZqH/AD1t /wDvhv8AGgC7RVLZqH/PW3/74b/GjZqH/PW3/wC+G/xoAu0VS2ah/wA9bf8A74b/ABo2ah/z1t/+ +G/xoAu0VS2ah/z1t/8Avhv8aNmof89bf/vhv8aALtFUtmof89bf/vhv8aNmof8APW3/AO+G/wAa ALtFUtmof89bf/vhv8aNmof89bf/AL4b/GgC7RVLZqH/AD1t/wDvhv8AGjZqH/PW3/74b/GgC7RV LZqH/PW3/wC+G/xo2ah/z1t/++G/xoAu0VS2ah/z1t/++G/xo2ah/wA9bf8A74b/ABoAu0VS2ah/ z1t/++G/xo2ah/z1t/8Avhv8aALtFUtmof8APW3/AO+G/wAaNmof89bf/vhv8aALtFUtmof89bf/ AL4b/GjZqH/PW3/74b/GgC7RVLZqH/PW3/74b/GjZqH/AD1t/wDvhv8AGgC7RVLZqH/PW3/74b/G jZqH/PW3/wC+G/xoAu0VS2ah/wA9bf8A74b/ABo2ah/z1t/++G/xoAu0VS2ah/z1t/8Avhv8aNmo f89bf/vhv8aALtFUtmof89bf/vhv8aNmof8APW3/AO+G/wAaALtFUtmof89bf/vhv8aNmof89bf/ AL4b/GgC7RVLZqH/AD1t/wDvhv8AGjZqH/PW3/74b/GgC7RVLZqH/PW3/wC+G/xo2ah/z1t/++G/ xoAu0VS2ah/z1t/++G/xo2ah/wA9bf8A74b/ABoAu0VS2ah/z1t/++G/xo2ah/z1t/8Avhv8aALt FUtmof8APW3/AO+G/wAaNmof89bf/vhv8aALtFUtmof89bf/AL4b/GjZqH/PW3/74b/GgC7RVLZq H/PW3/74b/GjZqH/AD1t/wDvhv8AGgC7RVLZqH/PW3/74b/GjZqH/PW3/wC+G/xoAu0VS2ah/wA9 bf8A74b/ABo2ah/z1t/++G/xoAt7BWF4k8H2XiFUd91vex/6q7hO10P17itLZqH/AD1t/wDvhv8A Gk8vUP8Anrb/APfDf41x4rB0MbSdDEQUovo/60a6Poa06k6MlOm7M5O18WX/AIVlSy8Rwlos7Y9S iX5HH+0OxrtLe8iu4llhkWWNhlWQ5BqlcWN3eQtDMbWWJhhkeMkH8M1yb+CdT8OzPeeH7tI26tYP uML/AEyeK+etmOUaRviKK/8ABkV+U190v8TO39xid/cn/wCSv/5H8vQ74jIxVPVNHsdbsZbLUbSG +s5Rtkt7iMOjj3U8GuU0nx5PcXYsdSWPSdQzjy50bax9mzXUp9vYZEtsR67D/jXt4LMMLmNNzw01 JLRrqn2aeqfk0ctSlVw01zKz6P8AVP8AyPnzXP2dPEnwv1i41/4L6yNJ85zJc+FdRcvp9wT12Z/1 ZPqPwxWt4H/as046t/wjXxG05/AHiuMhfJvsi1uM9GilPBB9DXt3l6h/z1t/++G/xrnPGnw30r4i aW2n+JNL03V7UggLcQEsmepVs5U+4NU8PKk+bDO3k9v+B8vuPpo51Rx8VTzmn7TtUjpUXq9pr/Fr 2kjqre7iuoVlgkSaJxlXjYMp+hFfK/iqEp8IvjY2Pn0rxk2qLjsI5rafP5Kamv8A4SfED9nK3vNZ +GesJrfheCN57nwrrUjMkSKCSYJCdy4APy55qLwVqE3xQ+G/xsmjjjt49ato9QNuwJK/aNMjl2g5 9x+Vehl2Jf1qCqR5ZRaflv0Z4eeZTClgZ18JWVWlNNJ7STte0ovVP0bT6Nn1TazC4t45RyHUMMe4 zXBaH/ycF40/7FfQv/SvV6t/CnVr7xF8MPCOqLLARe6RaXB3Ic5aFCQeeuTVDw6JR8fvGfnMrP8A 8IxoX3AQP+PvV60qR9nNwfTQ8mnNVIRmuquejUUUVmaBXD/C/wD13jP/ALGK5/8AQIq7iuC+Gfm/ aPGezZj/AISG5+9n+5FQBh/Fm78Nnx14MsdQeCLX5rhZbK4uNx8iOOaJmEfYSSMEj7EqW7A1Q+Ac cFn4H1uzspo73T4Z1KXy2KWjzTNBGZhIqKNzq+VLHLcYJJXNek654s0jw/qWm6dqGppaXmpOY7WJ sZkIIHp6so+rCqumeKNM8YaNe3Wkamt/bwO0EjRqMbgAcdO4YHPoRSA6miiimAVFdf8AHtL/ALh/ lUtRXX/HtL/uH+VAHJ/Bz/klfhT/ALB0P/oIrsa474Of8kr8Kf8AYOh/9BFdjQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFF ABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUm0UtFAGdrWg2OvWjW97bLPGemeq+4Pau U/4R/XfCeZdFvG1GzXlrG7OWx/st/Su8pMCvDxuT4bGT9vrCqtpxdpff1Xk7ryOuliqlJcm8ez1X /A+Ry+i/EHTtTkFvcM2nXwOGtrobTn0B710yPv5ByKzta8N6br0JjvrSObjhiMMPoeormB4d8QeF ju0S+GoWfX7FenJHsrV5/wBazTLdMVT9vD+aCtL5w6/9uv8A7dN/Z4ev/DlyPs9vk/8AP7zd8cxC TwX4gT+9p9wP/IbV89/se26Xmi6/Zv8AcvNC0FyPZtNSM/8AoNev6x8QLO68P6tZapDJpF81pKhi uBhSShHDV4P+zB4y0jwPcaHDrl4umJrng/R5LOe4+SKZ4Y5EkUMeNwG3ivRweYYXMKyqYWalZO/d O60aeqfk0elOhUpZRUjVjb95D53hPZ9dj2D9lW8a4+Bfh22kP7/TjcadIp6qYZ5EAP4AVs6H/wAn BeNP+xX0L/0r1euX/Z91C2h8TfE/RLK4jubOHX21S2eFgyGK7jWU4I7BxIPwNdRof/JwXjT/ALFf Qv8A0r1evqcd/vM5LaWv/gWv6nxWXv8A2WEXvFcv/gOn6HoVFFFcJ6IVw/wv/wBd4z/7GK5/9Air uK4L4ZxSPceMyszIP+EhueAAf4IvUUAU/ictzqHiDQdJj0e9ms7pxJc6naW3meUUkRoY2YfdXzMS E9hH71mfBXQdX8O+B9QstUhvrdIVhhij1CQvJuS3jSYqT/yzMitsHQDpgYFdh4q8YweGNV0uzksb 25S8dUkuYc+Xb7pEiQuf9p5FGPqe1U/DPiqTxdputtPpV1pE2n3BtXjnn3h2CK5wRwQN4B9wR2pA dxRRRTAKiuv+PaX/AHD/ACqObUbW3kZJbiGNlALK8gBAJwCfxokuI7i1uPLkWTaGVtrA4IHIPvQB y/wc/wCSV+FP+wdD/wCgiuxrjvg5/wAkr8Kf9g6H/wBBFdjQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUU UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABSYHpS0UAYPjbTLXUvC+qLc28c+21lK71B2nY eRXk3wL8CeH/AIjfsy/Dyw8RaVb6pax6ZEUWdclGXIyp6jp2r2jXl36JqC/3reQf+OmvMP2Sn8z9 nXwN/s2bJ+Urj+leXyQjjuZLVxd/OzR9FTk3klZX2q0/xhVPLPg3oCfBP9q7xT4QjJg0TXtNF3pU bEkDY5dYwT/dDzj/AICK9f0/WBZ/tMeJLA2d3N9s8K6O32qKEtBDsutVOJH/AIS275R3wfSuE/bA 0y68N2/hL4m6XGWv/Cmoo06p1ktpCAyn8cD/AIGa7T4d+KNM8afGLxPrGkXcd5YXXhTQZI5I2Bxm 61Y4PoRnkV71WTqQjUe+33bfhp8j5KjFU5zprZ6/fv8Ajr8zJ8UeOfGNvqWuR2uoQW8ul6/LFHaw 26utxYR6bBeFXLAkOSxTKkcyj0r0P4X69e+I/BsF5qE6XV2t1d2zXEahVmEVzLErgDgblQHjjmui /suz8+Sb7JB50jFnk8sbmJVUJJxySqqv0UDtS6fp1ppNlDZ2NtDZ2kI2xwW8YREHoFHAFcp1lmuH +F/+u8Z/9jFc/wDoEVdxXBfDO3WW48Zlmcf8VDc/dcgfci9DQBL410vXdW8T+HDaRWs+g2sv2i8i mlKu0oZfLYeoQb2x3bb6Vf0HSG0Hwrc288kb3Us1xcSuh4ZpJWf+TD8qreOPEGq+H9S0b7HYWc2l zXMUF3JOxEpMkqRqsQH8Q3M5J42oe5rE+F/xAf4leE9Xv57e0je1umtwbTJX/VRybTnnehkMbdty NjikI9NooopjPm/4r/CXxP4i8ceIL+00yHVrC7tZEVJTEm/dDDHEgYjd8siu5ycDapGCa7P4c+A/ EPh/wt4us5Lr+xtQu5m8i+jRJTJIEw12VIwS/HDA/cr12orr/j2l/wBw/wAqAOE+DNneL8J/CQa+ LMNMgBby1GTsGT0rs/st3/z+n/vhf8K5v4Of8kr8Kf8AYOh/9BFdjQBS+y3f/P6f++F/wo+y3f8A z+n/AL4X/CrtFAFL7Ld/8/p/74X/AAo+y3f/AD+n/vhf8Ku0UAUvst3/AM/p/wC+F/wo+y3f/P6f ++F/wq7RQBS+y3f/AD+n/vhf8KPst3/z+n/vhf8ACrtFAFL7Ld/8/p/74X/Cj7Ld/wDP6f8Avhf8 Ku0UAUvst3/z+n/vhf8ACj7Ld/8AP6f++F/wq7RQBS+y3f8Az+n/AL4X/Cj7Ld/8/p/74X/CrtFA FL7Ld/8AP6f++F/wo+y3f/P6f++F/wAKu0UAUvst3/z+n/vhf8KPst3/AM/p/wC+F/wq7RQBS+y3 f/P6f++F/wAKPst3/wA/p/74X/CrtFAFL7Ld/wDP6f8Avhf8KPst3/z+n/vhf8Ku0UAUvst3/wA/ p/74X/Cj7Ld/8/p/74X/AAq7RQBS+y3f/P6f++F/wo+y3f8Az+n/AL4X/CrtFAFL7Ld/8/p/74X/ AAo+y3f/AD+n/vhf8Ku0UAUvst3/AM/p/wC+F/wo+y3f/P6f++F/wq7RQBS+y3f/AD+n/vhf8KPs t3/z+n/vhf8ACrtFAFL7Ld/8/p/74X/Cj7Ld/wDP6f8Avhf8Ku0UAUvst3/z+n/vhf8ACj7Ld/8A P6f++F/wq7RQBS+y3f8Az+n/AL4X/Cj7Ld/8/p/74X/CrtFAFL7Ld/8AP6f++F/wo+y3f/P6f++F /wAKu0UAUvst3/z+n/vhf8KPst3/AM/p/wC+F/wq7RQBS+y3f/P6f++F/wAKPst3/wA/p/74X/Cr tFAFL7Ld/wDP6f8Avhf8KPst3/z+n/vhf8Ku0UAUvst3/wA/p/74X/Cj7Ld/8/p/74X/AAq7RQBS +y3f/P6f++F/wo+y3f8Az+n/AL4X/CrtFAFL7Ld/8/p/74X/AAo+y3f/AD+n/vhf8Ku0UAUvst3/ AM/p/wC+F/wo+y3f/P6f++F/wq7RQBS+y3f/AD+n/vhf8KPst3/z+n/vhf8ACrtFAFL7Ld/8/p/7 4X/Cj7Ld/wDP6f8Avhf8Ku0UAUvst3/z+n/vhf8ACj7Ld/8AP6f++F/wq7RQBS+y3f8Az+n/AL4X /Cj7Ld/8/p/74X/CrtFAFL7Ld/8AP6f++F/wo+y3f/P6f++F/wAKu0UAUvst3/z+n/vhf8KPst3/ AM/p/wC+F/wq7RQBS+y3f/P6f++F/wAKPst3/wA/p/74X/CrtFAFL7Ld/wDP6f8Avhf8KPst3/z+ n/vhf8Ku0UAUvst3/wA/p/74X/Cj7Ld/8/p/74X/AAq7RQBS+y3f/P6f++F/wo+y3f8Az+n/AL4X /CrtFAFL7Ld/8/p/74X/AAo+y3f/AD+n/vhf8Ku0UAUvst3/AM/p/wC+F/wo+y3f/P6f++F/wq7R QBS+y3f/AD+n/vhf8KPst3/z+n/vhf8ACrtFAFL7Ld/8/p/74X/Cj7Ld/wDP6f8Avhf8Ku0UAUvs t3/z+n/vhf8ACj7Ld/8AP6f++F/wq7RQBk6laXTWFyDeEgxMMeWvofavKf2SYbiT9nrwj5d0Y1VL lAuwHGLqYf0r2a6Xdbyr6oR+leP/ALH7bv2e/DP+zNqCflf3A/pXny/3yH+GX5xPoqP/ACJMR/19 pf8ApFY9K17wvF4o0e60rVXW90+6Ty5oJI1Kuvp0rxr9n74Vw/CH4v8AxE0W0uRcWM2k6TeWy7Nr RRyXerERk/xEYxn0xX0DXnuh/wDJwXjT/sV9C/8ASvV69NSai49z5pwTkpPdHoVFFFQWFcL8MZFW fxnlgP8Aiorn/wBAiruq4P4ZQxyXHjMsisf+Eiueo/2IqALHi3whd6/4o0PVotYuLKDTd+bBbZJI 5y5AZiWBKttDKGHIDtjrVTwZ4Hj8BaDqFt9uutTecRoJpoVTZFFEsUSYUAfKiD5jye9P+Il5rdjr Xh5tK1RIFkukiOmrArteZdTJuYjKokQkbK45xmsP4Q+L9X8T+G9cg1qW4uL2zaLfJc2wgZXkhR3i CgDIRywB7jHWkhHrFFFFMYVFdf8AHtL/ALh/lUtRXX/HtL/uH+VAHJ/Bz/klfhT/ALB0P/oIrsa4 74Of8kr8Kf8AYOh/9BFdjQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQBHMu5G+hrxr9j3/kgujp/zzv8AVE/8qFwf617O1eK/sgNj4NrF/wA8ta1V P/J2U/1rz5/75D/DL84n0OH1ybEr/p5R/wDSax7ZXnuh/wDJwXjT/sV9C/8ASvV69Crz3Q/+TgvG n/Yr6F/6V6vXoHzx6FRRRQAVwXw0uBHceMxskb/iobn7qkj7kVd7XD/C/wD13jP/ALGK5/8AQIqA L2v+CdP13xFpWt3LX8N/pqlIDa38kCMpZXZHRWAdSUXIYEEDFN0Xwrp/g7Qr200u1kihmdpZGluD Kxbaqj5mJOFVFUDoAoA4Fc38X7yKz1fwvLFeyRarFewmG1W5aMSxPcRRyEIDiRsuikHOFd/Ws34I 3jXPhPWAl7NqEBjtZnlmmaUrcyWkT3CgknHzMGK9i5pAexUUUUwMTUPG2gaVfXFleavZ2t3bosss MsoVkVmCqxHYEkD8atw6tZ6ta3v2K6iuvs7vBL5TBtkijlD6EZHHvXi3xU+EviXxR4s1i+0qCNrK 6tZI5IJ70+Tdu8KQxkxE4QxDzCSB8wKjrXS+APhrregeGfFGnTag2l3d7J5VtfW+yV8KuBckNxvb PIP90UAdH8Hf+SV+FP8AsHQ/+giuxrxHwX8E/HGheEtI06b4qaxbS2trHE0MVjaMqEDBAJTkVtf8 Ko8af9Fa1v8A8F9p/wDG6APVKK8r/wCFUeNP+ita3/4L7T/43R/wqjxp/wBFa1v/AMF9p/8AG6AP VKK8r/4VR40/6K1rf/gvtP8A43R/wqjxp/0VrW//AAX2n/xugD1SivK/+FUeNP8AorWt/wDgvtP/ AI3VCb4V/EUa9ZrH8V9WOkm1nNw5sLTzBOHh8kAbPulTPn3C0Aex0V5X/wAKo8af9Fa1v/wX2n/x uj/hVHjT/orWt/8AgvtP/jdAHqlFeV/8Ko8af9Fa1v8A8F9p/wDG6P8AhVHjT/orWt/+C+0/+N0A eqUV5X/wqjxp/wBFa1v/AMF9p/8AG6P+FUeNP+ita3/4L7T/AON0AeqUV414k+FfxHj8O6q2i/Ff VpdZFpMbFLiwtBG1xsPlhj5f3d23PtWj/wAKp8af9Fa1wf8AcPtP/jdAHqlFeV/8Ko8af9Fa1v8A 8F9p/wDG6P8AhVHjT/orWt/+C+0/+N0AeqUV5X/wqjxp/wBFa1v/AMF9p/8AG6P+FUeNP+ita3/4 L7T/AON0AeqUV5X/AMKo8af9Fa1v/wAF9p/8bo/4VR40/wCita3/AOC+0/8AjdAHqlFeOW3wr+Ih 1m+Wf4r6sNNEcX2Zl0+03l/m8zd8nT7mPxq//wAKo8af9Fa1v/wX2n/xugD1SivK/wDhVHjT/orW t/8AgvtP/jdH/CqPGn/RWtb/APBfaf8AxugD1SivK/8AhVHjT/orWt/+C+0/+N0f8Ko8af8ARWtb /wDBfaf/ABugD1SivK/+FUeNP+ita3/4L7T/AON1n+IPhX8RV0W8OkfFfVn1MRn7Os1habC/bPyd KAPZKK8r/wCFU+M+3xa1zH/YPtP/AI3R/wAKo8af9Fa1v/wX2n/xugD1SivK/wDhVHjT/orWt/8A gvtP/jdH/CqPGn/RWtb/APBfaf8AxugD1SivK/8AhVHjT/orWt/+C+0/+N0f8Ko8af8ARWtb/wDB faf/ABugD1SivK/+FUeNP+ita3/4L7T/AON1maT8K/iQ19rQ1D4raqlot4o05orC0LNb/Z4Sxf8A d8N5xnH+6FoA9noryv8A4VR40/6K1rf/AIL7T/43R/wqjxp/0VrW/wDwX2n/AMboA9Uoryv/AIVR 40/6K1rf/gvtP/jdH/CqPGn/AEVrW/8AwX2n/wAboA9Uoryv/hVHjT/orWt/+C+0/wDjdH/CqPGn /RWtb/8ABfaf/G6APVKK8c1b4V/EVfsX9n/FfVnzdILnzbC04hwdxX5PvdKv/wDCqPGn/RWtb/8A Bfaf/G6APVKK8r/4VR40/wCita3/AOC+0/8AjdH/AAqjxp/0VrW//Bfaf/G6APVKK8r/AOFUeNP+ ita3/wCC+0/+N0f8Ko8af9Fa1v8A8F9p/wDG6APVKK8r/wCFUeNP+ita3/4L7T/43R/wqjxp/wBF a1v/AMF9p/8AG6APVKK8c0f4VfERku/7R+K+rIwuZBB5Vhacw5+Qn5OuOtX/APhVHjT/AKK1rf8A 4L7T/wCN0AeqUV5X/wAKo8af9Fa1v/wX2n/xuj/hVHjT/orWt/8AgvtP/jdAHqlFeV/8Ko8af9Fa 1v8A8F9p/wDG6P8AhVHjT/orWt/+C+0/+N0AeqUV5X/wqjxp/wBFa1v/AMF9p/8AG6z9U+FfxFW9 0gWPxX1ZrZrphfmSwtAyweRKQU+T73m+SPoWoA9koryv/hVHjT/orWt/+C+0/wDjdH/CqPGn/RWt b/8ABfaf/G6APVKK8r/4VR40/wCita3/AOC+0/8AjdH/AAqjxp/0VrW//Bfaf/G6APVKK8r/AOFU eNP+ita3/wCC+0/+N0f8Ko8af9Fa1v8A8F9p/wDG6APVKK8rHwp8Z5Gfi1rhH/YPtP8A43Wf4e+F fxFfQtPbWPivqyaqYEN0sFhaFBLgbgvydM5oA9koryv/AIVR40/6K1rf/gvtP/jdH/CqPGn/AEVr W/8AwX2n/wAboA9Uoryv/hVHjT/orWt/+C+0/wDjdH/CqPGn/RWtb/8ABfaf/G6APVKK8r/4VR40 /wCita3/AOC+0/8AjdH/AAqjxp/0VrW//Bfaf/G6APVKK8cm+FfxE/tq0WL4r6udMMMpnY6fabxJ lPLA+TpjzM/QVf8A+FUeNP8AorWt/wDgvtP/AI3QB6pRXlf/AAqjxp/0VrW//Bfaf/G6P+FUeNP+ ita3/wCC+0/+N0AeqUV5X/wqjxp/0VrW/wDwX2n/AMbo/wCFUeNP+ita3/4L7T/43QB6pRXlf/Cq PGn/AEVrW/8AwX2n/wAbpH+FPjXY234ta3uxx/xL7Tr/AN+6APVaK8d0P4V/EN9D05tV+K+rx6ob aM3aw2FoUE2weYF/d9N2ce1Xv+FUeNP+ita3/wCC+0/+N0AeqUV5X/wqjxp/0VrW/wDwX2n/AMbo /wCFUeNP+ita3/4L7T/43QB6m1eI/sijZ8NNVi/55+I9VX/yZc/1rb/4VR40/wCita3/AOC+0/8A jdZPhz9nvWfBtrcWmg/EnWtMtLi5lvJIVtLZwZpG3SNlkJ5POOgrllTk68Ki2Sa++3+R69HE04Zf Xw0vinKDX/bvPf8A9KPaq890P/k4Lxp/2K+hf+ler1m/8Ko8af8ARWtb/wDBfaf/ABuq3gX4T+K/ DPxc1jxJqnjS917TbnRrGxWO4t4IzLJFNeuQ2xQQEFwhBHUu2egx1HkHot74w0TTbqK2utUtYLiW 4+ypG8oDNNtD+Xj+9tZTj0Iq9pup2msWMN7Y3Ed3aTDdHNCwZXHqCK8P8bfBPWtR1bW5NBSPTTqe um/W8humi8uOS2sY7gugOJPMFvOmDyC6t2r0/wCF+g3nhvwbBZ6hBHa3bXN3dPbxMGWHzrmWUICO DtDgcelAHV1wXwzkkW48ZhIt4/4SG553AfwRV3tcP8L/APXeM/8AsYrn/wBAioA3Nan0mPUtKTUm sRfvK32AXOPMMgX5vLzznHpTI7W1tdKvU06Kzhg8yQyrbLgeZn584/iz1rkviyvna14Vgh024nvz qFvJHdxWolXy0uIjJE8mMxDGJM8Z8nHrWn4I0VdB8M67aRwyQxf2neyIJMksGlLbsnrkknPvQLqd zRRRQMK8W+Ml54qj8Z6fFbjVLPwn/Z0qzXulTkMJ2dctIqfOFQKnzLyFeU9hXtNJj2oA+YvFWufE ufT/AA79nGorZLo7RX13HK8TJL51uJmlVf3hZYlcqy85kYjkV9A+BZru48F6DLfrMl89hA063BJk EhjXcGJ53ZznPetzA9KWgAooooAKKKKAEboe1fNmh678U49csZdYs77T7GPUtVkuZTdJPGm6J2hQ ovLRR4AUDqSD2r6UpMD0oA8x+AN1r114c1n/AISE3j3aaoyrJdySPkGCEuE8zkKshkXA+UFWxxXp 9JS0AFFFFABRRRQB88/GzUvidD4o8TJ4csNQbTP7BH2OWyvUjAdZkZ3VeolILKO+0cVk/FHxF4kv vE2rR6HqeswfZUZb1UkuIomDE+WsCxkEbCiBpF++02OgavpvA9KNo9BQBX02SWXTrV50aKdolMiP jcrEDIOO+as0UUAFFFFABXE/GibxDD8L/EJ8Kwyza41q6wfZ5RHKgI+Z0J/jVclfcCu2ooA+Ztb1 74pt4X+JSR2eoWurT2jNpUEdyrNHGLcLvgccJIAN5B5LuQOgr0P4K3/iS813xkPEEd5GPtSvClxL I6RAyTgRpuO0ERrAx2fKd6nqTXqu0elGPagBaKKKACiiigArxD44TeMJPFtta6fPqWl+GJNEuUn1 PTJjuhmaeAM5RPn3JGDtYdPMc9jXt9JQB4N4N1zxfffEbwl/aAv47KTT4kntN822BjaSvL5uTtkK yiJS7ZbLpg4LV71SbR6UtABRRRQAUUUUAeb/AB2uvFNr4Qtm8K29xPdf2haNcfY5xFKIFnQsFJ6h sBWx/CWryga9r+n+FbjTrrVvEH2qbXTFYX7PcIzs8SM0krE5WCF2lTyx8rNEoxkmvp6sXxh4s0/w Tob6nqCXEsIkjhSGzgaeaWR3CIiRqCWYkjgUAcX8AbrXbrwvff8ACQPdS3q3S7pLp5GO4wRGRR5h yoWTeCo+UEMF4Fen15s/x88NQzakJbXWoLew0tdYmvZdJnW3Nuyb1KyFdrMRkBRzuUjqKsX/AMcP Dtjq0unrb6veyqF2S2WmzTRTO0PnrHG6rh3MfzBRzQB6DRXnLfHjw8vhXRPEH2LXTZayjy2kQ0mc 3DRohcyNFt3Km0bgxGCCPWp4fjj4UuL4QJdXBjkmiggvDbOLa4d5o4MRS42vtkmjVsH5c89KAO/p G6VzXgz4jaF4+sVu9GuWmga3iud0kZTakhdVBz0OY3BHUYp3ir4ieH/BlxaW+rahHbT3cNxcQx9W aKCIyyvgfwqo6+pA70AeGvq3j6HxzLdaq+rWKQ63fNBZxzPLatbm2s9jHyztKRjzXCN1YvjmmaJr HxIb4rTDWIdTh04+Jj5MCXLtC0DWunjagQ7TEitcSEPxnzCPnFeof8L88Jqrb/7RjlWMEwPp8ol8 0uEW324z55JXEX3iGBxzXb6brtjqmhwaxBKv2CaEXCyuNuEIzk56YHXPTFAGlRXE6B8YvC/ibVNJ sdPvJJn1TT11K0mMLCF4WBZfnIwGKqzBeu1Se1JbfGPwxceE5/Er3ctppEU0cHm3ULRM7SFBGVUj LB/MTaRwQwxQB29FcfZ/Ffw3dr4ldrxrWLw7k6hLdRtGiIC4Mik/eTdFKu4cZjYdqk8O/E7RPFGs Nptk9x532VLxJJrd44pY2SN/kcjDFRKm4Dld3NAHWVwfxzn8RwfCjxMfCkc0muNYyiA2sojmT5Tl 4yf4wM475xjmp/Dvxg8NeKtS0yy065mmOpQPcWs5t3EMgRnUqHIxu/duwXqVUnpSJ8YPDNx4gTRo Lma6vTey6e5ggZ44po9gYOwGFG51TJ4LAjqDQB4xLrnjuSz8URXM+o2Jk1OFpC0tyRDCZpdyI6HK bYxAzGLAKuD1LV9D+Eprq48K6NLfRzRXr2ULTx3H+sWQxqWDf7QOc+9auAecUtABRRRQAUUUUARX TyR2szwx+bKqEpHu27mxwM9smvmbwJrXxFtfGVm3iV9TtVF7eLIss0k0QjMt0xfah8sxqfJjXIyo MWOCa+nqTA9KAPmv4P614k1Lx9ok7XuuXfhy5tt9tFqc87Sop+07zPuO0uNtuSG5Qyoq45r6VpAo HQYpaACiiigAooooA8R+P1947tta0RfDMN4ulfZr0XFxaXBQCQ28hXeqneQu0FSv8TDHIFcd4s17 4lSeH/BJ0tNS+zRoYb6ZJ3WQFtNmYmfJ8xgpVHDddzjPzqK+nsD0owPSgDmPhhPe3Hw/0J9Q883f 2ZVdrlmaR8ZAcl/mO4AN83zc885rqKSloAKKKKACkpaKAPnvQbbxnq3jTUpvEFxrejix8Q3V/F5N +7WjWiafa+XB5cZ2vH5sm7BHJSQdS1dh8BbzxDeWWuf8JC13JdC6DM1w8hVZDu8xED/dAIHyr8mC uO9ep4HpRQAtFFFABRRRQAV4d8Xk8aal41urGyXVbTRJtDntrG40u+MIF89xaKk0mwhxtMh68bFk 7E17jSY9qAPmf4oan4gt9Vl03QNa155rCzt47qRprhY5IBerGSuw7jKERzJKPm2sOcGvofw3JcTe HdLe7SSO6a1jMqzHLh9oyG989a0do9KWgAooooAKKKKACiiigAooooAK4H4Z+f8AaPGfl+Xt/wCE hufvZz9yKu+rh/hf/rvGf/YxXP8A6BFQBq+IPF+neG9S0yxvZLhZtQfZE8cLPGnKqDIwGEBZlUE9 SwFUtA8Y6Z450G+vNLmuTDA3lOtxC0Lcorq21gCVZHVg3QhgRVL4maTrutX3h+20zTlurKK9hu5r kXQiaBopUb5kJ/eKyeYMDOG2ntVf4eWusx+GdZu/EWitoutX1w1xcRm6inVv3aIoQxkgKqIqAHn5 Se9AG3B8UvCV1q2paXB4k0ubUtN3m9tEukMluEyX3jPy4AOc9MGpf+Fj+GB4gtdBOv6aNauhuh08 3K+dINobKpnJ+Ug/Q145r3wZ1288P3bCWa8kvvE94z2Doii3sbq4u4JWVhyR5V0JsH+4AKwfDHgL xZbXlvZ6h4bn/tbVJLSWTV12NFp5tbt1WQsf4vs8ULBe5bFSgPqXdXOQfEXwzdXmr2sOv6bLc6Oy pqES3KlrRicASDPyknjmuN/4Vn4m/wCEHk0U+IZG1ZtQE41w3M3n+Xn/AFmM4D4/5Zj9326V4prn wj8eeIPE3iDS7OyeeC8u7hJb3XovKsfLNylyjJ5XztvaFSewOB0NPqB9TSeM9Eh1i40h9Ws01W3W J5bJp181FkcJGSucjcxCj1JFaWn6lbatarc2c8dzbsWVZYWDKSCVOCPQgj8K+ZL3wD4y8TeGr7Q5 /DkmkeJLy7gv5fGEZRnQyXlm7eWOpaNYmBB6C2Q/xCvfvhpBdWfgPRLS901dJu7W2W1ls4/uRtH8 h2eqnbuB7gigRtXerWVhdW1vc3cME9ySII5JArSEdQoPXqPzp8mo2sUkcb3EKySOURGcAswGSB6k AZrxD9ojw++t+KdCSPw3fa1eTaTfWem3ttYvPHp9889m0M0kgBEIXy2fexH+rIzXB/FD4X+Ip/EG iroul6hI663rFzDP5BlCvNJAyu8x5hXb5rq+RuMYj6PigfWx9XWd5DfW6T280c8L8rJGwZT9CKmr zf4AaS2j/Di3iXR7jw/aSXdzNa6XdQmGS2haViqlDyueWx/tV6RTEgooooGFFFFABRRRQAUUUUAF FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAVx/wAVvC154x8HzabZ QWN1K00UpttRDCKUI4bG5fmRwQGV15DKprsKKAPHLz4Sa9qPhm00y71oSXEmnaVYX19lnkk+zzGS dgW6lwcAt6kmsf4c/s+6r4H1zRNSuNZbUG0m6+zxwyzO0Mlilr9mhcxn5RcqiR/OOxkHRq97ooA8 Y8WfAy+8VfD3wZ4fbWJtOuNE0p7KS6sZnjJlNoIVPB+aPcMsjcMODWRqPwP8S6z4Zl0WS40qxgsb a8k0p7ZXBS6nkWZNw7JE4IGOoCnrmvfqKAPHNH/Z/t/+EP8AGHhnUriGfTdX1Hz7f9wsnlQblm2M rjaSJmnI9mX0q/49+C6+JPAej+GLCaG2i0+xmsVmaPZ8hsZrdAAvQBpEJA7A4r1SigD5ws/2e/Et jJHJbzaRaxW+qxeIbayj8wRQ3MbRhbVfSHy4lweoJPavcPBHh1/Dfg7S9HuXSeW2gEcrKPkZurYz 2yT17Vv0UAeBWnwA1KDxJo19O2nXNvZ6OmmS7g25lCSK0QHTYWdJc9Q0SjvVjwb8C7/w94DvvD8s GkJNLDHFDNbo2EKeQN3PP7wwmRv9phXutFAHj3gf4QXvhvxd4r1S9j026h1icyIwDNIG8y6fzjng OVuI4iBxthHrWbovwl8VPNcWmszac9nDpFvpGl31vkzaei2wSSVEb5fMMu5txHQIOgr3OigDwfw/ 8EfEeit4Utbm90zVLTQUvNs8kHlSTCZ5f3LIo2bBvhf13QD1rO8M/s06t4Z8a6dqp1q31iK3u0kF 1dW4iuYI0ERymwYLyFZVdjyQwPc19E0UAIOgpaKKACiiigAooooAKKKKACiiigAooooAKKKKACii igAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigArgvhnCZLj xmRIy/8AFQ3PCn/Yirva4f4X/wCu8Z/9jFc/+gRUAXPF3ipvDOpaLD/ZRurS/uFtpboSKohZmVUA U8uSWJwvQKxqp4X8Tf8ACXaPrMlxpP8AZV3p901rJA0iykERxyA7l4ztkUEdiCO1O8d+Fb3xTqOi +RqFtBp1tcx3FzFMm6TdHKkiPE3ZvkZDnjbI3cCqHhfwzd+GNG8RS6pqFreahqMnmyNaJ5aNtiWM OV/56OE3MfU4HAFAHoXHrRxnrXNN945OOa+aP2d/iF4v8bftKfHOz8VWkukx6I+n2Om6azZWO1Bu CkoPRjIDvLDjkDoKAPr3cPWkOOcnivOfEBP/AAkfhXDEf6ZNnn/p1mql8XppIfhL43ljkaORNCvm V1OCpFvIQRQB6kVBH3qhvLoWsYcDdk4xmvnj9jrx74r+JX7OvhHXfGVlJaazNb7POkPzXkK/LHcE dVLgZwevXoRXpU2f+E+sRk4/su44zx/roKAOx/to/wDPH9aT+2v+mX618lWnk+NNW8Uaa3irXLqS 38SWrSzabrE8PkCW9niNs8ecwusYCmMYUgRsOtYHiLxh4w8WNrWl6bHq29tQn1jSkmv5rT7ZZJDP Hthkj+YqGt43APBacZ60Afao1r0h/Wl/to/88f1r4/8AFEEGg6NrmsSeO9WS2ll0tmvLzWbiC1mW SyaZgrg4t97gMp4BYKh+9ipLvx09xo3iH7L4g8QP4/1JJLFfD0UzO9pBJcwx2cyx9IpDA6yBh98t Kf4TS8gPrv8Ato/88v1rM0Xxk+qzaojWwQWd41suG+8AqnJ9/mNfOPwv+JGveJviHoRvZryOx1u6 acWrk7bSaDS2W7tW9NszRsAf4lkPavaPCpKyeJyCQf7Um5AyR+7j7UwO5/to/wDPH/x6j+2v+mP6 18f+B1/4TG08Pva+J9b1ae28QSQvdWOtztb3bnS7i48tgTlSJYY98LfcbcMYaqGo31/4p/sXSPB/ iTWvEk1/cwnVETXJIGttQNlfvJEZc5iCtHG7QjpsXjkUAfZ/9tH/AJ4/rR/bR/54/rXzF8ZPEmr+ FPFGkw22uz3HiSPQdlnpNvcvE9zd+XP+/SD7lwpZV3jlkCqe9Zb/ABLsNH1LwtF4M8Ra34t8NWup PdarqT3LXKQwyLDbgSSt96MSTyyf7LQOv8NHoB9YjWjnmL9ayvDHjOTXtJN49qsR+1XUAVW/hiuJ IlP1IjBPuTXjH7M/iLW9Z0/UrPXry6vb7TbLS4XluST5he3aUSgnqXjeIkj+LIPIrB+I+vJoPgvw 3PNrcukwrrmqyeRDeSWbXrreTbYklXhpeSViY4k+brtoA+mv7aP/ADx/Wj+2/wDpl+tfG+vapqPi LQ5rbw9r+r6141m1LzNZ0E6pPbpazJHfuLZHjOYSRGoEYwGEcbdDXLN41E2n6rLP8SdPmuGewiaa 58S3FrJ5JFvmaSIH9xG+Sd6/N84B6mgD7x/tr/pj+tH9tH/nl+tfE19401ax/tO0HjGRPDl8d9rr EN/NNawCO209ZV+0jLiFhKG83qm6Z+ME1Y/4WB4vuNL0+ew1KeLwu18sDXn2ySa9CjRZ3cq/3Xi2 oZlfOSwVqAPtJdZLMB5Xf1qDwTr7+KvCGjazJEsEmoWkVyYlOQm9Q2B+dfOHg7T7DXPF3hO80fxV rms+HYdfuLXT7tdYllhvIUsJJyrtnEyrOpG456be1e9fB7/klPhD/sFW3/otaAOwooooAKKKKACi iigAooooAKKKKACiiigAooooAKKKKAGs2KTdUGoW5u7SeFZWgaRCokjPzLkEZHuK5D/hXd1/0NOq /wDfYrx8bisZh5JYbDOqnu+aMbfedNGnTqJupU5fk3+R2N1fQWMLTXM0cESkAySMFAJOBz9SKzm8 YaKuqtpv9qWn25YZp2g80blSIoJWI7BTLHn/AHhXn/j34K3Xi/wvLpf9v3d0Wnjm23crIhC7gQSn zdGJ47qKxvg/8KdU0HxpqWrajZwW9pD9u0+NZFJmu45XtmEznoSTAcnod2a7MJVrVqSnXp+zl2un +K0M6kYxlaErrvsew6Dr1h4n0Oy1fS7lLzTr2FZ7e4jOVkjYZVh7EVeDE1g+FPDL+G/BNloTT5e2 tjB50I29jyPTrXhP/DIOusxP/C7vHIz/ANPC1pVqVIW9nDm+aX5no4HC4TE831rEqla1rxlK/wD4 Cna3mfR9xeQ2cMk9xKkMMalnkkYBVUdST2qhN4r0iDVLbTm1K2+3XDlIrfzAXZhGZMY/3FZvoK8L sf2VdZ0u11JZPif4m8RG5gWNLTV7giDcsscgJKfMP9XtyOcMat/Cz4M6t4T8byTPa28Vho620Frd TbmkuwsF4jZbuF+0RgH+6uDyKunKU43nHlfbf8jnxlGhQq8mHre1j/Mk4/g9T2fwr4s0zxpo6anp Nx9ps3YqHKlTx7HnBBBHqCD3rX3Zrkvhf4Z1fwt4Rjs9ens7vWpJZJ7u6sQ4jnkc5L4bkf7vQAAD gV5ZqX7Lut6hqV3dJ8YvGlok8zyiCO4XZGGJO1fYZxXdQp0qjftanJ8m/wAjxsRVrUreyp8/zS/M 9+kmWGNpJGVEUZLMcAD1rCtvHug3d0lrFq1rJcSXK2iRrICXlaIzKo9cxhmHsDXkGnfsw6xps0ss 3xU8Ua5G0EsX2HU5g1vIWQqN4HUAnP4VueGfgbc6J4q0/X3l0yO5jvHu7iGztzHGS0WwKgx/ACwB PJzk8k1NaFOnK1OfMu9mvzKw9SpUjerDkfa6f5HqOg+JNO8TW09xpl3HewQXEtpJJEcqJY2KSJn1 VgQfcGtLNYXhPw3/AMIzb6lEGRkur+e8VY1wFEjbtv1ry7XP2cdZ1nWr6/i+K/i7T47mZ5ltLedR HCGJOxfYdBWB0nt24DqcVzy/EDw810LcaxaGUyxQqolBLNL/AKsD13dq8s0/9mrV7K4aSf4p+K9U haGWJrW8mDRSb42T5h3A3Z/CrOj/AADu7HxFpmuyyaTFe29w80sNnblIyGmtnCrxngQNyerPn1oA 9U8P+LNM8TSajHp1x576fcta3A2kbXU4OM9RkEZHHB9K2K5D4f8AhnV9BuPEVzrUtlc3WpalJcxz We8HyPuxI4boVQKvHGcnvXX0AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFF FABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUjHApaa33TQB8s6l/wAFAvCml6ld2cnhzVme 2meFmV48EqxBI56cVX/4eH+Ef+ha1fP+/H/jX54/F7ULuw8daotvLIizz3kAC9FkaX5X/wCAjca4 m01W4bEkOoCa7W7dpIEuWeTYqzNtZDwoIUdPav2GWRZPCSpulJvr7z8tj8hhnWcVIOoqsUv8K79T 9Q/+HiHhL/oWtX/77j/xr1P9nHxRZ/EfwhrXiaG0MEGqa3dTxxTYLouEUA47/LX5E+E9We+vLaBr l5ZY7eR5o2OSu4wmMsPcFsfjX6l/sM3UMXwGtleREb+0LngnHcV89xFlWBwWFpV8JFpylZ3d+lz6 Dh/NMdjMXUoYuSajG6srdbHqfxA8Sap4Z1Dw7NavbpplxfRWd0ssbMzGR1VfmAwgALnJxlgq96yd J+Ij654D8Ya9ewLFZafLcG3C8M9qkKSI5z3ZW3fQiiivz5H3x5Uf2xvCJOfsVx/4FQ/41nw/tT+A bfXLrWItIkTU7qCO2nuVuIQ0kcZcopOecF3x9aKKYDNS/aw8K3+raNdLbTIljPJM6tcxZYNDIgA5 9XH5VZ1X9rLwRrWl3mnXumzz2V5C9vPE11Dh43Uqy9e4JoooAktP2uvBen2sNrbabLBbQIsUUUdx CFRVGAoGeAABVOT9rDwpJ4kt9S+zTCKKyltjH9pi3FmkjYHr0whoooAvr+2B4NUkrp0qljkkTwDJ 9TzyaP8AhsHwcMH+z5htGAftEHA9ueKKKAEb9r7wa6lG02RkPVWngI46cZpR+1/4NVt406UP/e8+ DPHTnNFFACj9sHwevTT5hzni4g6+vWszQv2rvCulyaq8ltM/2y9e5ULcw/KpVQAeevymiigDSX9r /wAGx/c06VOd3yzwDn169aRf2v8AwahO3TpVOdx2zwDn169aKKAHH9sHwczq50+Yuv3WNxASPoc8 U1f2vvBiKVXTZFU8ELPAB/OiigBy/theD0OVsJ1+lzCP61keGf2qPCWi6Ktnc2b3D/a7q44nhIHm 3Msq9T1CuKKKANYftgeDVYsNOlViclhcQAk+vXrUf/DXPghsn+yWO4YP7235/WiigB//AA194M27 f7Nk24xt8+DH5ZpR+2B4NAAGnSgDoPtEGOmPX04oooAdD+2D4NhKBdPmRVOQq3EAA+nNdh8M/wBo H4e6L8O/DWn3virT4Ly106CGaJpRlHWMAj8DRRQB0v8Aw0r8M/8AocNN/wC/tH/DSnwz/wChw03/ AL+0UUAH/DSnwz/6HDTf+/tH/DSnwz/6HDTf+/tFFAB/w0p8M/8AocNN/wC/tH/DSnwz/wChw03/ AL+0UUAH/DS3wz/6HDTf+/tH/DSnwz/6HDTf+/tFFAB/w0p8M/8AocNN/wC/tH/DSnwz/wChw03/ AL+0UUAH/DSnwz/6HDTf+/tH/DSvwz/6HDTf+/tFFAB/w0p8M/8AocNN/wC/tH/DSnwz/wChw03/ AL+0UUAH/DSnwz/6HDTf+/tH/DSnwz/6HDTf+/tFFAAf2k/hkf8AmcNN/wC/tH/DSnwy6f8ACX6b /wB/RRRQAf8ADSnwz/6HDTf+/tH/AA0p8M/+hw03/v7RRQAf8NKfDP8A6HDTf+/tJ/w0l8Mv+hw0 3/v7RRQAf8NKfDJf+Zw03/v7S/8ADSnwz/6HDTf+/tFFAB/w0p8M/wDocNN/7+0f8NJ/DL/ob9N/ 7+0UUAH/AA0p8M/+hw03/v7R/wANKfDP/ocNN/7+0UUAH/DSvwz/AOhw03/v7R/w0p8M/wDocNN/ 7+0UUAH/AA0p8M/+hw03/v7R/wANKfDP/ocNN/7+0UUAH/DSnwz/AOhw03/v7R/w0p8M/wDocNN/ 7+0UUAH/AA0r8M/+hw03/v7R/wANKfDP/ocNN/7+0UUAH/DSnwz/AOhw03/v7R/w0p8M/wDocNN/ 7+0UUAH/AA0p8M/+hw03/v7R/wANK/DP/ocNN/7+0UUAH/DSnwz/AOhw03/v7R/w0p8M/wDocNN/ 7+0UUAH/AA0p8M/+hw03/v7R/wANKfDP/ocNN/7+0UUAH/DSnwz/AOhw03/v7R/w0r8M/wDocNN/ 7+0UUAH/AA0p8M/+hw03/v7R/wANKfDP/ocNN/7+0UUAH/DSnwz/AOhw03/v7R/w0p8M/wDocNN/ 7+0UUAH/AA0r8Mx/zOGm/wDf2j/hpT4Z/wDQ4ab/AN/aKKAD/hpT4Z/9Dhpv/f2j/hpT4Z/9Dhpv /f2iigA/4aU+Gf8A0OGm/wDf2j/hpT4Z/wDQ4ab/AN/aKKAD/hpX4Z/9Dhpv/f2j/hpT4Z/9Dhpv /f2iigA/4aU+Gf8A0OGm/wDf2j/hpT4Z/wDQ4ab/AN/aKKAD/hpT4Z/9Dhpv/f2j/hpX4Z/9Dhpv /f2iigA/4aV+Gf8A0OGm/wDf2j/hpT4Z/wDQ4ab/AN/aKKAD/hpT4Z/9Dhpv/f2j/hpT4Z/9Dhpv /f2iigA/4aU+Gf8A0OGm/wDf2j/hpX4Z9P8AhMNN/wC/tFFAB/w0p8M/+hw03/v7UV1+0x8NY7eR 08W6fIyqWCLIMtgdB70UUnsB+a+ueG01XW9QvU1LT1juLmSZVaYZAZyRn35qj/whQzn+09NB9pRR RX2i4uzWKspLT+6j4x8JZXJ3cXr/AHmH/CFheRqmnA+0wr9CP2H7c23wLhiba+3UroB15VsMBlT3 HFFFeVmOd4zNIRp4lpqLurJI9XLskweVzlUwyabVndtn/9k ________________________________________________________________________________
Subject: Delphi Weatherpack Connectors Question
Date: Feb 04, 2019
Greetings, I seem to be a bit gender-confused when it comes to weatherpack terminals. I have just realized that the nomenclature of the plastic connector housings is referred to as a "tower" (long skinny thingy that inserts into the other stationary thingy) and the other side is called a "shroud" (stationary thingy that long skinny thingy gets inserted into). There is also official terminology for the metal conductor part and that is the "pin" and the "socket" Forgive me as I am old-school so I ass-u-me-d from a cisgendered perspective that the pin should be installed into the long skinny thingy (because it is doing the movement and the insertion action) and the socket should be installed into the stationary thingy (because the long skinny thingy gets inserted into this device) however after researching online I discovered that the "socket" should be installed into the "tower" and that the "pin" should be installed into the "shroud". (Yikes.this subject is very difficult to talk about in good company). In operation it does prove that the socket when installed inside the tower remains centered whereas if the pin is installed into the tower it will not be centered and it will flop around and the two halves are very difficult to "mate". [red faced embarrassed emoticon added for dramatic emphasis) I bought the B0040CRUNO yellow handled hollow tip tool however the ID of the hollow tip is 0.020 inches so this hollow tube is perfect for slipping over the weather pack pins however the weather pack sockets have a thicker OD and therefore the hollow tip of this tool does not slip over the socket. https://www.amazon.com/gp/product/B0040CRUNO/ref=oh_aui_search_asin_title?ie =UTF8 &psc=1 I am using 18-24 AWG wire and the associated pins and sockets Is there another tool available? Do these yellow handled tools must come in different sizes or are they gender specific? THANKS FOR SETTING ME STRAIGHT BEFORE I VISIT THE RESTROOM AT TARGET . Thanks, Bill Hunter ________________________________________________________________________________
Subject: Fwd: DATALOG SCANNER
Date: Feb 04, 2019
Fly Guy, Oh PRETTY PLEASE may I have a copy??? I tried to send you an email to the address you specified however I got an auto generated email back saying that it was undeliverable. Can you setup a DropBox link? My guess is that you are going to get hundreds of requests. Thanks, Bill Hunter From: owner-aeroelectric-list-server(at)matronics.com On Behalf Of Robert Reed Sent: Monday, February 4, 2019 8:44 AM Subject: Re: AeroElectric-List: Fwd: DATALOG SCANNER Fly Guy, I just finished my plane and performed the first engine start this weekend. I have the SkyView DX system and downloaded the logs after the run and found them very complete but almost unusable due to the incredible amount of data. Your logger spreadsheet sounds like what the doctor ordered and I would greatly appreciate a copy. Just one additional question, do you use the temperature and air speed in the Celsius and Knots form as stored on the log files or convert to Fahrenheit and MPH? Thank you, Robert Reed KIS Cruiser N247BR RobertR237(at)att.net On =8EMonday=8E, =8EFebruary=8E =8E4=8E, =8E2019=8E =8E09=8E:=8E07=8E:=8E06=8E =8EAM=8E =8ECST, Lapsley R & Sandra E Caldwell > wrote: I have an RV12 with D180 and D100. I use the Datalog capability. I written Excel macros to allow me to graphically scan through the data. It works in an animated fashion or in steps. The current version supports D180, D100, D120 , Skyview and Advanced Datalog files. If you would send me a request to at my email 91827364(at)earthlink.net I will email you a copy of the "DATALOG SCANNER" program. FLY GUY 91827364(at)earthlink.net ________________________________________________________________________________
Subject: Re: Fwd: DATALOG SCANNER
Date: Feb 04, 2019
I've been using the free analysis program from Mike Bush...https://savvyanalysis.com/home. The neat thing here is that if you ask, they will analyze any problems you may have and offer solutions...for a fee, of course. But the data uploads and charts are free. And they save them online as long as you want to keep them. Note that you can display up to 4 items at the same time, so you can compare what happened at the same instant (here, I've chosen EGT, CHT, Fuel Flow and Oil Temp).. Just by clicking on the menu, you can choose to display 41 different items, from engine performance to aircraft attitude and fuel and oil ...whatever your device can output. Harley ------------------------------------------------------------------------ On 2/4/2019 10:43 AM, Robert Reed wrote: > Fly Guy, > > I just finished my plane and performed the first engine start this > weekend. I have the SkyView DX system and downloaded the logs after > the run and found them very complete but almost unusable due to the > incredible amount of data. > > Your logger spreadsheet sounds like what the doctor ordered and I > would greatly appreciate a copy. > > > Just one additional question, do you use the temperature and air speed > in the Celsius and Knots form as stored on the log files or convert to > Fahrenheit and MPH? > > Thank you, > > Robert Reed > KIS Cruiser N247BR > > RobertR237(at)att.net > > > R & Sandra E Caldwell wrote: > > > > > > > > > > > > I have an RV12 with D180 and D100. I use the Datalog capability. I > written Excel macros to allow me to graphically scan through the > data. It works in an animated fashion or in steps. > > The current version supports D180, D100, D120 , Skyview and Advanced > Datalog files. > If you would send me a request to at my email /91827364(at)earthlink.net > / I will email you a copy of the > "DATALOG SCANNER" program. > > > FLY GUY > 91827364(at)earthlink.net ________________________________________________________________________________
Subject: Re: Overvoltage protection and other stuff
Date: Feb 04, 2019
The certification basis for this aircraft is FAR23 (amendments 1-32 inc.) and that includes: "23.1351(c)(5) Each generator must have an over-voltage control designed and installed to prevent damage to the electrical system, or to equipment supplied by the electrical system, that could result if that generator were to develop an over-voltage condition." AC23-17C explains the rationale behind this rule (introduced in 1977) saying "Explanation. Complete electrical system failures on both single and twin engine aircraft continue to occur. The electrical failure that causes this problem is often the loss of voltage control in the voltage regulator. This usually results in a bus voltage well above the capabilities of the electrical equipment connected to the bus. This overvoltage condition frequently destroys electronic equipment and boils the electrolyte in the battery.=9D Bill - you must have first hand knowledge of the introduction of this rule, am I right? When I look at the circuit diagram for the alternator on this aircraft installation it has the following: The connection leaving the exerpt at the bottom goes to the master switch. And one of the diodes on the generator relay is (I think) shown reverse connected. But apart from that I can see no overvoltage protection. Does the FAA consider that it is included in the design of the generator? (It=99s a BOSCH standard part.) Any thoughts? On Feb 3, 2019, at 11:26 AM, Robert L. Nuckolls, III wrote: At 06:19 PM 2/2/2019, you wrote: > > I love low-tech! I don=C3=A2=C2=C2=99t think that=C3=A2=C2=C2=99s definitive enough for the powers that be, however. And=C2=85> I don=C3=A2=C2=C2=99t think my structures person will enjoy me drilling holes in a composite stressed fuselage just for a look see. > On the subject of over-voltage trips, I have discovered that both Carling and Sensata (Klixon) make circuit breakers with, for instance, a second coil that you can use to trip the breaker via an isolated circuit (that could easily be triggered by an over-voltage, in addition to the regular over-current coil. So one of those could be used to replace the b-lead CB. It will be a challenge to find small quantities of what is a very specialized part though. I proposed an ov protection system that was based on the external trip feature for some magnetic breakers . . . I think it was for Swearingen Aircraft. The cost-benefit ratio didn't ring their bells either. Further, doing ov protection in the B-lead is less than optimum. That's a VERY HIGH ENERGY switching event that would continue to produce voltage and ultimately destroy the alternator too. Opening the field circuit has been the legacy approach since the first generators were strapped to aircraft engines. Bob . . . ________________________________________________________________________________
Date: Feb 04, 2019
Subject: Re: Delphi Weatherpack Connectors Question
At 09:52 AM 2/4/2019, you wrote: >Greetings, > >I seem to be a bit gender-confused when it comes to weatherpack terminals. check out this selection of videos: https://tinyurl.com/y93ftj5h and download this catalog: https://tinyurl.com/yd5ozdcc Bob . . . ________________________________________________________________________________
From: William Hunter <billhuntersemail(at)gmail.com>
Date: Feb 04, 2019
Bob, Thanks for the quick response and information. Like in the video I installed the pins in the tower part of the connector and the pin will move around a little bit and not be completely centered and therefore connecting the two parts together can be problematic. After research online apparently the socket is supposed to be installed in the tower and the pin is supposed to be installed in the shroud. Here is a picture of the tool that I'm trying to use and it's ID is too narrow to fit over the 24-22 AWG socket. Thanks, Bill Hunter ________________________________________________________________________________
Date: Feb 04, 2019
Just checked it out and it looks great!!!=C2- I will give it a try tonig ht. Thanks for the heads up. Bob Reed On =8EMonday=8E, =8EFebruary=8E =8E4 =8E, =8E2019=8E =8E10=8E:=8E05=8E: =8E59=8E =8EAM=8E =8ECST, Harley Dixon wrote: I've been using the free analysis program from Mike Bush...https://savvya nalysis.com/home. The neat thing here is that if you ask, they will analyze any problems you may have and offer solutions...for a fee, of course.=C2- But the data up loads and charts are free.=C2- And they save them online as long as you w ant to keep them. Note that you can display up to 4 items at the same time, so you can compare what happened at the same instant (here, I've chosen EG T, CHT, Fuel Flow and Oil Temp).. Just by clicking on the menu, you can cho ose to display 41 different items, from engine performance to aircraft atti tude and fuel and oil ...whatever your device can output. Harley On 2/4/2019 10:43 AM, Robert Reed wrote: Fly Guy, I just finished my plane and performed the first engine start this weeken d. I have the SkyView DX system and downloaded the logs after the run and f ound them very complete but almost unusable due to the incredible amount of data. Your logger spreadsheet sounds like what the doctor ordered and I would g reatly appreciate a copy. Just one additional question, do you use the temperature and air speed in the Celsius and Knots form as stored on the log files or convert to Fahren heit and MPH?=C2- Thank you, Robert Reed KIS Cruiser N247BR RobertR237(at)att.net On =8EMonday=8E, =8EFebruary=8E =8E4 =8E, =8E2019=8E =8E09=8E:=8E07=8E :=8E06=8E =8EAM=8E =8ECST, Lapsley R & Sandra E Caldwell wrote: | | | | | | | | | | | | I have an RV12 with D180 and D100.=C2- I use the Datalog capability.=C2 - I written Excel macros to allow me to graphically=C2- scan through th e data.=C2- It works in an animated fashion or in steps. The current version supports D180, D100, D120 , Skyview and Advanced Datal og files. If you would send me a request to=C2- at my email 91827364(at)earthlink.net I will email you a copy of the "DATALOG SCANNER" program. FLY GUY 91827364(at)earthlink.net iVBORw0KGgoAAAANSUhEUgAABAAAAAHMCAIAAADEbU28AAAgAElEQVR4nOzdZ3xTV4I//Nn97zMz OzM7O7OzU3ZnZnenhWJ676aY3juEGgIEAiG0UAIGY5tiY2zjXiRZrpJlyZIsW7Lce+9VllWs3nuX bnleKCHGEAKmm/P9nBfJ5er4XtXzO/ecc3+Eoij60UdoejqqUIACCiiggAIKKKCAAgooY7v86JsA kJ+PAgAAAAAAAAAw1oEAAAAAAAAAAAAfEBAAAAAAAAAAAOADAgIAAAAAAAAAAHxAQAAAAGDsQxCk p6eHRqMRXlx2dnZraysEQSMq7O7uplKpo6uwo6MDhuHhFcIw3NnZOboKCQRCXl6eTqcbcdZWq5XF YmVnZ4+uQqPROKJCi8XCZDJHV+HreBrb29tHVPgyT2N2dnZXV9eI1wUAAGBMAgEAAICxD4KgtLS0 J1u0z8PhcNBoNIVCMXyj0+lMT083m82jqNBut1MoFI1GM3yj1WrNyMiw2WyjqBBFUT6fz2AwRmys rKxsb28fRYsWQZDBwcGCgoIR28vKykbdRHY4HHQ6XS6XD9/ocrnS09NNJtMoKrTb7bm5uWq1evhG m82WkZFhtVpHUaHNZsvJydHr9aN4LAAAwPsFBAAAAMY+j8dDJpNH/fC6ujqRSDR8i81mo9Ppo66w oqJiRFPYaDQymcxRV4iiKIFAGLElOzv7Zfqzn6zwyS0vpL6+XigUDt/iDVejrrCqqkomkw3fYjKZ nswtz6+kpGREogAAABiTQAAAAGDsAwHglVQIAgAAAMDYAAIAAABj33MEANhisVgtFgh5yr+NNgB4 LBY7gqIwBFns9uH/AAKAFwgAAAAAbwUIAAAAjH3PDgCynmaJTsdk5hXm5ukdT9nheQOA3VRKxsek 0Ux2F4qiMCymM+tcKGrVavPq64fv+JwBQNlWEh0TSy7udD9HM/45AoDOnZXgSoiFxGa4luqKjnSz 6K7o+66o++7yRg+zaMQfea4AIMxEW0NRlQjVVaBtQegAE+0IRFsC0dYgtPUeKhcM3/d5AoCqJbvg 4RcV7BpE1VOSeIGdHF1NDmJEni5MulaYdL2QTEOGJbTnCQBWkaElrKshjmdFTJ3hPQ1RvV2pA3WB nXWRHJPaKmUKh0+dBgEAAIAPBAgAAACMfc8MAHZiZEQBp/vlA8BARQ6zTWmR1qdSK7saSynFeXRm XWtdIZlSTBlVAJBU5XdIYImE73ZDahGnsaacXdOjkXJr2OyyZuGInZ8jAAy5GDUoiiLcQie5BUFd kICPKhpcFXyku9YZneT5oQqfEgC4RagTRV1DaFs26kFRvQRF9ehgC4qiKGRBu+ko9N0BPE8AEFbn yqRWBPaUxfpLTA6nXayRW3vo6SLhgEFl4NITe83fVfg8AUDbouwRmlAY6k9uFIvcLotLqTANFnc6 jG67Sl12pmb46woCAAAAHwgQAAAAGPueFQDU3XkkZn5Zw8sHgLr8PIEHRVF3fsKDeGqxtJ3xICIe n1vVV81IZI4mAAyVEIkFDVRCep/OkI9PzmSW1xczM/DxeZU1mem5I470uQIAJhVqrndlZ3osrm+2 KRpcFXwURT0M2mgCQG8qKqpFuZmo6tsKvwsAdnSwCYW/67F/ngAgKE5qyKcO8UuLSaUe70MRpIee brI6Vb0V5TkUp+e7Cp8vACjqcwWiBk19xoDrmzOEB4s7HUbHUAWvOZEDAgAAAB8gEAAAABj7nhEA dN0VOezytJT0zJcOALX5+d6dKPdDqL1cGBZgg+8VdOksGim1ZnQBIJvIbO4rzWVWdeCwseGB9x7c CY1OzeRLVVX5dPnjOz9XAMCmQa31Lkou5HIjrSzXwxT4ZQNAGiquRwcoqAFBzU1oyz3U/G0AsPFQ mXT4vs8XAJIbmXSRsLA2v8OhGyzHfd3Yzu2hp5usLnVfZXkaXu1+8QBAFYobtQ10vttm7YvvaWGq Bos7rVxFb5VaSOaCAAAAwAcIBAAAAMa+ZwSA1pKUpPQsTFTInfSXDQCNBTk9ehRFNbjAUEorB4YH Em7eprVqTSoeuWLUQ4BQ1MbLjkknVlJr2ngoivZU5QvlmlEGAEYNisKeknT3kBNFUTeDBr1kAPAO AdKUoENqFEVRSRGq06ODLahLjw42j9j3+YcAwZCSmZbmgFCzuqemvqWHnm6yoiiKKmpiGwdGMwQI cXlaUnqcDtiptjSzpYPFnfzM5sKLLezDVVVUlfvbm4mBAAAAwAcCBAAAAMa+ZwSAohyixuLRC4uv 3khhvVwAMAw0JOPSMvDJ9U3dmVgMNT0xLjUnKTGRmJycyB5NABAUpsfi6ZWtfHxkSFVvZ0pCIo1Z WVlCG3UAcEY9dDPoMK/XFRfropKcodEvGwC649C+bNQgQDtC0P50tOXONwGAH4+2JaD8ChR5sTkA fNbDItyDjqZOPiWcRYysyAgqrmzpoacLWstrch/k3r+rRF70CoC8MqGvP08qqu6piRrsTOBUEiWD xZ0OgxtFUGEOVzRsVjEIAAAAfCBGBgCbzcZ959kfX1APAADg2Z4RAGwWK4ygEGRTqwxWiwV+mWVA YY9eJZco1BDsMetUEqXGanUYNAqZXGse1TKgLrNeIpGodBaTyeCGPGa9SiJTma0WtweyW60/2F5/ IgC4EaUUlkpQB4Qa1bBEBMtUqMeB2NwoiiJWy4hTf64A4FCi5iHU5UDdetQsQC1iFIJQtwN1SFGz ALWoUPTF5gC4zSqteECvNaJuq046qJHwLDaHy2Jy2XRa8YBe+9htep8nAEAOj1lkMUntEApZxBaj 0GIxuF02JwIjKIq6za7hTyMIAAAAvCi32/2228U/7Mkbro8MADwer7i4mPMOY7PZI35CAAAAng3c COyVVAjuAwAAADCCTqejUqlvu3X8LLW1tW1tbSMO+ykBoK+v7w0/dy+ku7sbBAAAAF4ICACvpEIQ AAAAAEbQ6XQ1NTVv+yieRSqVvlAAsLUUM8nfYA0ZbCiKmqW9tFwymUxt5ipQFB1sKf52BzKzvN7s Qt8AEAAAAHhREARlZWVZrdZRPNbhcNDpdIVCMXyj0+kkEomjG45ot9spFIpGoxm+0Wq1kkgkp9M5 igpRFOXz+QwGY8TG8vLygYEBBHnaqKZnQhCEx+M92ZIuKSkZHBwcRYUoijocjry8vBGxx+VyEQgE m802igrtdntubu6I9rrNZsvOznY4njaT44fYbLacnBy9Xv/DuwIAAHzr8QAAq7ktFDKZTGPxVWYU RWWcXonBLOltEmif0kpGYE9ndf6jtnRRfZdS3P/o/0tr+4xmKZtc5h2+47ZryxmlRsTaxC7w7lBY 3Wr3PFnrSC8aABRRX10qauHz+Xw+X2xxejTCyoDbyf0Dg/ze9sQH/sX9ZqNayue0hp49l9/OF8mU z3OvypcHAgAAAKPA4XCIRCJhVJqbmz2ex75lEQTp7+8fXW0EAqG1tRWCoBEV9vb2ZmVlja5CKpX6 ZNe1t809ugppNJpOpxtRod1up9Ppo6uQQCA0NTW9409je3v7iAoBAACebVgAgCV9Rbfu4riDvJ6W mug7gQ1iS0VKQnG/sDjhem6n4SkPRhCtXMTvqQ44e62smy9R6nrKku/G0L2Nb6nCoBqqOrt1B41j R1FU0UU9vOHCACyNuHC5pJXP5/NJ0bdIDUM/eIQvHACiL1+t6lUoFAqFWuf2WPIfhlaJv+nusqmH uDIjgqKoS4u57t/6enpMLBaLUqn0/rfRaPR2mIEAAAAAAAAAALwLvgsATjU2OLBZ5fZuV3ZQg+PZ pbhnBgAv61DE9RCuBUVRtK88OTSxUKFQKBQKvcWpGap6GPogPqnECTtqCbhblx4MwNLoqwH9WhRF 0Z7CeFzRY+P23W63WCz2Xqe12+3eQZIvHAAenDpxPz4tLS0tjVqs00qTb8aIUBR16fIzsJGRD3PL ujzI6w0AarU6Li5OpVIZjUYMBsPn81EQAAAAAAAAAIB3w3cBwMAPuvxA8u12s7r+xg1cEeaFA8C5 87fT0tLS0tLKOiWaoaqoOHYmNkIm6k8m0tNuPBiApfeOHblxNzIyMjIw4F6LxPxYTVZrXFycQCCw 2Wypqand3d3oKAJA7LWbvd8NUrUXxoaU8C0oinjcbj236Pq9HAf0egMAiqJGozE2NjY6OvrRDDwQ AAAAAAAAAIB3wXcBwG0gPAiqEH4z2UzeknM7uXQUVwBiCE2P/sUbAKopadlkQl55kzcARF250S13 uVwutwd6ckqW0+lMTk6Oiorytv7RUQSAyPPnyaUtXhKtzShvDrkRWdrQ2NJQkfQgOCqrwgW/9gCA oqhGo5HL5Y+mnYEAAADAi0IQpLW1NTc3dxTjwolEYl1d3YjB6wAAAACAPj4JWCuqv307rqmpubqE GXHvXqfS4Z0DUBR3NSK7oqWlpaWjR2d1j6zi8QAQEJrhbXt39Q9KeFVRcWxjf8npc9c6hpTeAPBo CND3MRqNIpHoUcv5RQOAo7+xtvRbXIUZRVG3QVJZXlZaWtrO+3ZBDNgl6O0xPHEurw8IAAAAvCgI gtLT081m8w/v+gSn05mfnz9i+RoAAAAAQJ9YBtSqHCwrKy2tqJPqbCiKaob4KrNNye34pj1dVa8w PrHaG2Tj9nIsHhRFUbNaWP1t27umuVNn1AzylajH3N/Ls3s8oj6uBbHzevpeaOHNFw0A7ygQAAAA eFGv/D4AAAAAAIC+6H0APNa6fGL0t+ISMmWjWU36xYAAAADABwoEAAAAAOB1eMEbgSFul9P+HQc8 mhurvJjnCgBSqTQnJ4fxDiORSOBaPAAALwQEAAAAAOB1MJlMRCLxbbeOnyU3N3dgYGDEYY8MAAAA AGPPowAAO20lxKbQiKY+taapjtvUJHi0j4kvDr1bFXynNjGm+m5obS6rN6+QZ0FQFEVLC4oJ+Rxs dHUkvsfifCO3PAQAAACA1wYEAAAAxr5HAUDe3p5drkD18qTUiozsOlpu6/DdtN0Cdre5kdo5iKKo TpoUU9Mnc6EomvY1IRTfx2qXaBt6yM3fv5QbAAAAALwPQAAAAGDsexQAeoo6O9UIiiLVeZUPMU8P ADWEBmw+t7OVQyb1VPeqULvC/zozPLWP1S4xtvQQ65+5+hoAAAAAvPNAAAAAYOx7FAC6izq7tCiK orX53xsA6nNaCnvVskF+eZGIUTYka+q5ndQantp9O5AdFt+msUBv5RQAAAAA4FUBAQAAgLHvUQAQ VLSVD1hRyMoglCdk/MAQoMomfQ29hVzWkcfs8l4BeDtHDwAAAACvFAgAAACMfY8CgFUjSYqoSoyo YrQPUrPrCFFFiYktDQMO727eAFCVUXs3saWQ3V7aZDG3dATjB0qKekEAAAAAAMYMEAAAABj7hi0D ijhsTqPJ6YFhl8vjtDmNUk1R4SCLNchiDXJlVjeEuJ1uo9Fhs7vdHgSBILsTqq2t5/KGXBBY/wcA AAAYC0AAAABg7HvWfQCcjoE+VVeXsqtLqTS6n7oLuA8AAAAAMJaAAAAAwNj3kjcCq62tBQEAAAAA GDNAAAAAYOyDICgzM9NsNo/isTabjUajKZXKV35UAAAAAPBWgAAAAMAHQSgUkkgkwovLzs7u6uqC ILD6JwAAADBGgAAAAAAAAAAAAB8QEAAAAAAAAAAA4AMCAgAAAAAAAAAAfEBAAAAAAAAAAACADwgI AAAAAAAAAADwAQEBAAAAAAAAAAA+ICAAAAAAAAAAAMAHBAQAAAAAAAAAAPiAgAAAAAAAAAAAAB8Q EAAAAAAAAAAA4APyZgKAW9BRSaFQuoYsKArJOQ25FAqjqFpngxUDjbkUCoVCa+YoUauikEal0Jj9 CuNrOg6LxdLS0kKhULKysohEYkFBAZ/PRxDkNf05AAAAAAAAAHjXvJkAgNiMPWe2+SUWSlGXtTjj YVFF9YWDB2Py2uuzgz/9KqpPqDCYjEXJ1075JyWHXDx5E2d91UdgMpkYDEZCQkJxcTGXy5VIJCKR qKuri0wmJycnd3V1eTyeV/03AQAAAAAAAOCd88aGAEkv7vBLLJR6/0fWVXjiyAlyM7e9IO7UFxfu hKf0DynDvtx5h1DHa0k/uOPiwCv92yqVCoPB1NTUmEwm5xPEYjGRSKRQKC6X65X+WQAAAAAAAAB4 57yFAGAUtJw8cTy3vOub5rZDcu/U/uuxhdEX9t5Kq+LUpOx7pQFAp9MlJiaKxeInm/6PWK1WJpNJ IpFgGH51fxkAAAB4a5BvPfVf3XaPqlMnqVNK6pTSBpXd4HjDhwcAr5tKZTUa7WCcM/BUbzoAwFZd 7OWDB8/fyS+p6BNr5Lz2ckbm6UOfphb3tzOijp2+5X/u+NWEfOh7auHxeMwXwWAw/P39u7u7R7T4 i1rcQrlrRAbAYrFxcXEvVD8AAGMbKQsf4X8SGxOan5//to/lTSAT0rMzUxiMvIKCgrd9LN8pKCgg pibHh14PvXjwzufrYwMDMbfwsacw8V9h8SEZRExOVlw25mZq7GlM3MGUxO2Z2LU5+OW01CX0tIX5 qYvyMGtzEnanxxzBxn6Ciz2QkrAnHbuanDavIHVGPn4aw1swG7IJKcR36qwB4GUQifTNm3H79ydn Z5PBG/sN6+7ufs2N6lfgjQUA1xCnV2lwIZBbwuf09vb29vbLtGaDcqi3t5czKLS7UNRl4fb19fYN qC2vrCemq6uLQqHY7fbhbX2d0XU6FkkrhhyOx1KBVqtNTEy0Wl/5BAQAAN4/KkFPWWpQ7LGZAat/ Fv/5QrlocMx3pBlVkqQvFj885JP85TJ62Jm6bAy3oVzB77GatG/l3GEYMmnlAw3M7KCPIw9OuLvl j7cXT42c+hVubip+DjVpIgE/h565mElaXUxcwU5fUICfm5e6mJGxsoC0s5DyaRH182L6uVL66RLS TnamHzNtISN1ESNtSR52HiF+QUz06pvBfntuLPO7tnDRrZnbkydlFV2qs5ltb/40AeB1YDK5c+Yk L1yIqa8fePYsR4vFCcOPfcDtdo9Wa/u+YjY7x/yX4YdgjC8Dmp6eLhQKh7fyHQ4nu9mz+y76ZTwi UT12EcDpdJLJZC6X+7aPGgCAtwpBRN01oTv+HLDm36JPL88MOXVz1c9Y2CC7fSy3Dj0uB+XekaCN v008vylyx/rIaReiJwdFTb0ev/AW6fRDtUz+Jn/yYcijlwtLsDdjPp1+c9XPbm/57/hTuxPW+idP JqYspCVuSbi5cPPlOdPvrt9EvJicd6mIFVRRiWtozGvtru3l9fMkEolSqdRoNFqtVqfTqVTqIY6o t4bTVtpMCg26tXXaxRX/ftH3p/4b/uv2Xp97h2be2vR/96bvxUzIbUntdjqcb+w0AeA1sVrdJ07k b9iAX7YMFxBQaDKZnrqb2w1VVw+dOMFobBQ+Cgl6vT0oqPLAAcr3lTNnCurrhW43WDrl/TbGA8DD hw9HTPw1mJyXscjO2+iuOyi1xjMiALS3t7NYrLd91AAAvE2Cjoq7W/8r4tPZVYW5QqFQr9dn3Nh1 Z9t/c9prx+o0IQRBmvKTr/n+KPWrq7RjJSlT8/BLaFkHGBk781J8c5PH5dADs4zG17VA83AwDIl7 6+nhJwPX/jJgzS/jzq4jh9zPu8TO8C1ImUGnXShqqW4e7OxsLcon+B8K3Pj7ayv+NfHihmo6XiER 2u12t9sNQRAMwyPiCuRx99cz407Ov77iJ+HH5pPjblazaQOcfqlUqlAouuuLb2/838h5X+FnMToJ HKcdLAgBvN8qKoTLlqVERbFu3y5esya1tZUPQSPHVhuNjtDQmnnzkhcuTD58OGdoSOX91MTHN8+b l3zqFOnKFfpTy+bN6YsXYxMS6q1W+9s4OeDVGMsBwOl0xsTEjGjil3e4d91Bd95Gd95GP49B9I8v CyQSiYhE4ts+cAAA3prBJvaDvX97cHh6Y3WpVqvxeDwIgkgG2u7v+Rv+6laz+ekdaaPjcTvNOoVe IYQ87ldY7SiIumvu7/qfyL3rcTPJacsY+TdL2woKBWyiqCSNy4jJXhOKmZlVn13zWpdKc1iNPZWU lIurg9b/6u6O/8OcP0K5lpG9Iz9lRl7qAgbpIKsKx+I+CFFvXWXastK8eYVmvW/fqjmUVX+/v+Rf A1b+7O7WP2DOrcgN+6wg5nxBzPli7M0mBqa/Lr+3iloQcz7qyNRba37x4PCMPHxYf2+3TqcztzSZ 7wdbL5+xnv3MeOIAefvka76/SPFLT5mWR99b0U3gmRVWMM4BeF/IZKaUlLb2dhkEQTCMnDlTsHVr WlNTZ0+PdMWK1Hv3Smw2GwQh1dWi0NDqO3cqAwPL9+0jL1uG9fenEYm1y5alBAYW2Wy2mhrRqlVp ly/ncjiDGo1Go9E+WTgcya1bRb6+uP37yUFB5XfuVD5Z7t6tYjI5ViuYW//uGssBQK/X43C44e17 jcF1Mw32tv533kb33EXz6j3DJwIoFIrU1NS3feAAALwdQ51VEQfGPzg0raaEodFovH1mMIRAHqgE Hxy47t/rCtLc7pdqrCMwZFSJm/ISCTd3Jny+4OHhSeH7PqqlJjje3vgii16Z/MWS2xv/gl+Tnr6C UUuuE9fTTNiVbtwUV8pER8r4wTuzU6YnpK+l8jp5r6NN7LAYeirIuC/X3175l9urfJKOnyYeS89Y no+fk5e1gZkfUNZEr+dkpEs/36vfPl97aqP81kHFvQOq+3tkF/eID27q3LSkYsnf0zZOCN/2f/d2 /uXerr/c2/WXO9v/HLTxt0Eb/zNow2/ubP9z7Bk/SnxAe1OtUqGwiYYcSdHWPRv1O9aqPjuoPHNM e2TP4KqZd5f+NPbEtuKw8pwdRfhZjLz9lcpBzVi95gOMGR4PXF0t2r2btHAhZtOmTAKhvaFBtHRp SkhIvlwud7s9X39dtGlTelPTYExM06pVaatXp2zalLZpU9revZmpqaU8nkCvN4aEVKxYkUKlduzb R96+Pa26us1kMiHfA4Zhvd6cldW8Y0eWt6ony/r1qcuWpfj7FysURvAhejeN5QAAQVBUVJRj2FTf 6i73xyHoowCw8zb6RSxiNH8XAAQCAYlEetsHDgDAW6CXC8P3/ePe7n9UsMhqtRryQJATUjRram52 9JL4CgE/5vjs0N1/lQkHRvF7hiCwx+2U9Dex4r+K2D/Of/mPb2/9Y8wXK/ABhyKOzAhc96vKnGiX 6y2MPkcQmJ10NXD9bzB7AjDjacUPC6Ul91yE2ZaUKZ0ZR1tIAS2kO+bsJeXH1yb6pOYcIGnUmleY ATxul6CtMv383rAF26MnByRMScROz8X60HDT6TmfsipSa/s6emTNNQbsafu9Ge4HE93YKR7iFIQ4 ESZORIgTPaSZxrw9ipwryuuHZGtmDB7c1HXjbFfwpa7gS23XTtWe2F68ez5r36L6h8H81ia1VGyq rbTHPrAd3W1et1B4/XxfCWtIyJfLpCr+oCbgMmPpH2+u/kVDCVUuUbQSu3GT6cVf15mNlld1sh8U yO3SywWel0vLgJdUapJKjRD0lK8dq9WFw7UtW4bfujUNjy8/dYo6f37yxo2Z69fjKytbvYua1NYK V6zAb9qUMWdO0qVLlOrqVi6XPzgo4POFKpXK6XSiKCqXGw4cIC9Zgl2yBJOVVaFUKn/wW87lcsnl isFBwVNLTw/vwYNyX1/s4cPknJyu6mrhKynt7TIw9+BVGcsBAEXRmJgYvV7vbdybrc7h3f+PSkHj dzMBGhsbS0tL3/ZRAwDwppk00vgTc4M2/76UnqlWqyEI6s3kU7eVYyfQUiYRcJPp1aEt7RWFtzf/ DvvVOo1C8vyNYBjyiHrq2IlXIg5MuL7s/wVt+j3m6q4yBoE7MKBUKrVarVzMT7m04YbfT0oyQl3O N50BuE2FN1f+JPbjQymz83I/ZwymbLThPhKEzGPgIru7uzUajdlsNnILDSmTMjfuxozPZV/KNOn0 L/93nVZTZxEp8+TFh1OvJI3PxkyhpW6m0q4UFUdUVWc2tNd1SkQCfTvdTvscwvnAWeP0mfNFOfuH mFcFlXH8hmxeK0vQUaqpCbPkbYOJPijhI5TwEZw+zoP7yI37yI37yIP/yJP+D3f6Pxz4f9jjxjlC JzqCp7tuTXIF+7ju+RhSV5kYex1Fhz0VJz01F6AGf2M7ZejK6bu+P445sXCI0+F2u+sjO1NnM1oz e17yms9Y8pxve5fdkhf+eeDaX9bnp4Jn7yVJpebNmwkrV6ZSqV12+2PfD2Kx8ehR+oIFyVeuUFpa OrVarUZjSE6u8/XFBgbmyWQy7zVMu9114QJr5UpcSkrJ4CDfYrFA33r0giII0tQ0tHRpyvXrVD5f +JyD/RAEgb6fw+GoreVu2ZIxc2biqyqzZycFBZXK5QYwPO/ljfEAQCKROBzON437fvfB+yNb/ztv o1ewiEr/zXJABAJBIBC87aMGAOCNMqolWf7bb637dWF2kkwmdZgdLZF9+Bn0rLkxBQs/aVq4iDnb P3VyTtGOhNKTuwNX/pwQfMigU//gL5DH5eA2FqZf3Ry0/td3tv9P/Ll1eSmhrfWVoiGhyWRyuVze uaoIgqilwrTrO26u/Ckbe8ti1L+x3zaDcijq8KSwnfNSlmSkr8hrzQo2JI3vur6cnYrl8/mPGgGQ 22VvvNt/zyd65lf4SWktcSS75aX6xZXcfvzH5xNnRiZPJGKXU4gX6GWUyr6ufpVcZBC3W3hsW2OI m7YKJkwx46ZycVvKyQ9b68uFAp43kNjtdu+lXbvNpldLldw6cXO2qDpOVBwsKPian3+Vn391MP8a p+BWP/Mel3Vbmndak7tTR1qtyV6jJW/WU3ca6LuNjD1Gxh5z3k4zfasrZ56TsUnS3VJ3Yuu9ZT8L 3z+hq4ph0pjyDlVmLWeKe2QfeGsDgRFhkYy2vYJ1tKY/V2AUmSHP992tB3VYDKQbx+7P2xI59WLC kWM6ne4Df/aeAYJgg8Exoq/daHS6XN90cp0DATgAACAASURBVNvtnqCgiiVLMIcPE319cdeuFXV3 KyQSo1CoJ5P7NmzI3LgRn5RUzOXyLBaL9/vEbndwOKKBAZ5l2IdUpTJ0dHDkcrnT+b0reHo80OCg dHBQYLFYXtVL5vFAIpGyurq7rKzt5UtxcWtUVPny5Sl79pCKigbEYoNEYnyrxeT5/g/Cu2+MBwA+ n5+VlWW1Wp1Op1zjah90P1m6+G6Txel0Ovl8Ph6Pf62z3ADgbfG4HCaNzOUYywtZjgKCwEPdNUlf LA7c8JvchECxWGzV21oe9uGnUqnzzjcvW9y/e1NnfHQfnck4loufTC6ccZG4+O+3/H5KjTxr1mu/ r1qnzTzYXJR5fVvwxt/c2/P3rPtfNlYWCoUCnU5ns9kcFqdFZtP2G4dK5d1pg62x/dIWpYTDJQQf Dtzwa0Lgfhm/5w20mVwOK/X+8QC/X2NXxqYuzCtLyFemLZGEzSjCxQ4NDY3ouHWZZGbGrsz9f42f gM2ZH8ejs0bds+t2OvIuxib7kFLWUnKC6LXF9QI+3yDpcjXdgdk7EPpyT+Y0e+JHsvszGsMPlJPi m+prpVKpzWbzdliOeGZgGPZ4PHa73WKxGI1G3TB6vd5gMBiNRo1GIx4S8PpaB3pahbx+iVgok4jk UrFcKlZIhxQSnqEzCyLP0TRjlZz+mltnwlb/5vbm3zWSkwbKBrOWsQpOVZn15g+2Fes0uFqj+tPn MxJmYVOXkfFz8khrilriexxPu2OPWanNvxYTOykMM5WMnUGNmfywqbgc/KqOYDNpFYIeldIUH9+0 fz+Fxeq32RwoijqdEJPJ/eQTakREjVptQhCERuv39cWFhOT39fEiIir9/PCrV6dt2ULYuDFr0SLs oUNZRUUNMpnM4XAMf39CEOTtX3i0BUEQl8v15EJAI3gf+Grf6jAMO51OxytitdoKC7t37iQsXYrb soXwdsvWrYSKCs77+/Ye4wEARdGcnJzS0lLnDzGbzTExMWKx+G0fLwC8SgiCaCWDDbT4rBs7Ig/6 5Iad1ClfYPjK2OZ22hqocXc2/+7Ojv/NS7nP4/EsemtjaDd+Sm7ujLMtKxZ0BF7rqSnVNGPMojq5 SF7kX4uZQMuefi9msc+NZT8u8T9mFg0hj/fewRDEay1Nv7rx1upf3N72p6zwCy11lXK53Gq1up1u VZeuPX6g6GQD0Y+Nm0jDjqNgx1Fw4yj46Xn5n1S1pHXlx9+6tfZXDz+ZyuushZ55756X11uVG7jm P+KWfo2bRmOFlwmYQc7Uj0rvfNbZ3v7kTxqCIHZRNTdyQtDsFZjxmcXrAuRtraOb28epKk2YlIhZ TywvrJBIJDarGRrMRgrWQVkTFaEz+Scn9B2YVn1uHzsN39HerlQqn9Fn+fy8Mxe9K4Q+yW03eIoP 2GnrdDqtUadrJePDNv/57upftZcV1sd0YCbQGuI6HbYPcT0Tu8ZRfKYRMy43cMqnZxf/V+KlffXE ptz9JSnT8+oetrtdw0IgghpFZsYnhcnjyUkrCNTwgnJ8FWYqIWtPjkz4Rm8i8Y74vlOGIU9+1Jmv N07Zvzdt4ULM+vWpixZhQ0IqBALtgwd18+dj1q3DL16M/eQTSnn54LZtxAMHMjs6eux2u81mr6jo DwsrCglhhYSw4uNL2tq69Xr9kzf5QmAIhn+oZxpBYMjzPr4uHo+Hy5UlJFR6n4e3WMLDC+vrO1/8 7rEI5PG43R7vtycCQ2632+32wAji/W+PB3ozL8vYDwB2ux2LxZaWljpG3Ph3GJ1OFx0d3dbW9rYP FgBesRpS+K01/3Zz1c/DDk1LvLAhYM2/RX06XdjbPLwrCEFgnZQ30FjYW03tLMnqr2M4bGN/4qPT aqLeP3p96T8nX93ZXFepUql0Q8aCwzW4iSTa1ONNa3270sLUpV9DuYtQwjhP7mLTUJ3Nauug9mUu ZWKmEu4v3npz8Y8bNs01pCQ6O1o8KiUMQUpBD+XeJ9d8fxS6bwIp+lpHa5NSqbSYrKoeXWcyl7K5 DDuRjhufnjExhDbtS/aMA9WzlzctnNuy0q901qfZk8Kx4yiZSwoyD8fe2zjj5sp/ZcReNKhfV8vJ btYnnlwSNmsfZjwt71Yxv6XUnjGPG76kjM00GAxPfQjkdthqb+AO/OL+1JMp44k1BwMMhhceiWtU ytK2hSRPpuQm0uVyOWwUIKUH4ezJqphFbTvm9i+b03nmeEsueWBgwGg0/mCH5auCIIhLWIQQfTTt mU6n0+1291axri39p5zPN4s5vPKbTSnT8tqzet/frr5RQtC62x2J47IuzVkacGBB7IXNN1b9PCfs tFQgKblSj51Iq4tu9+YiyAP3E4VZi1ixPskx+yIrKipkMpnVbM67iUkeR2FdqjLpzW/7ZN4oqdQU FdXAZPY/2To3KEVXd+2ZPyty0ew7EQ8Ig4ODEREVixZh5s9PXrQIExhI6+7uy8/v2LAhfebMxFWr cIWFDY+GUUEQZLVaTd8a0fHvpeYJCJ9fpX71oAFfyC3rNoiNHsfIhr5Rqq6KohCO3KsIp3HYHVad 7f1KAgiCOBwO0zvAarW+cD+I3cDGBK33O1xjtHnspsyw8xcCwhMT05sEQ4QHF059efbQwXPVgjdx 05X3OwDo9frOzs7S0tKCggI2m11TUzM0NPTkb4bFYiESiWQyWSAQ2O324U1/k8lUX18fHR3d09Mz 4lWEIEgmk9XW1jKZTBqNxmQya2trJRIJWNAKeC+4HLbytODA9b+K/3JzKSmnraSpv4ZTS82IODzl 7rY/UkKOVWaFNudjy1IDE08vurP5d0Hrf+VdMzFw7S+JwQeNOtX79ZPwQlx2Cz38ZMCaf0u/d5rL 6dOr9aJKOWVTGX4CPn/G/rp9u3ozA12keQ7SfFX+cUE1xpPr62TtNauFLpdrqFWad6QCO4UcOcU/ bO6UuuVThjYu4GxfWPTx3NDNvw/2/Unqigllu/a3Hv266/MHVXtSclfS0+cU4H3Ss6bcpfqeLN2x r+n4sfavL3aGh3RmZfRWlA+2NA+Wl3YkYipO3aYsiEj1SU+ekhU578tbvh9FH53TXprttL9oD9MP a6Rhwud/nDwxO+dzZn9rh5n+uQPvw06+IxAIntHsdhqGesN9Apf+Pmra3dSJ6R2JFNuL9H7BkKc0 MjHJJzXlMKmjrd0xVI4wN9iz5vQHbO1et2Bg18bedLxgYECv17vd7jf89vPYDZ6SgzbGdqNGgiCI 2+2KPzE/3O8/urNSdCod61RNxmJmD437ZHtuDJPWqtPnM+4uvJBLSOvr6ZJJRMzEazdX/SsLc1PO l5ZcacBNzqPvr8jbW5m9ogg7hXzP5/LdQwcry8sNBgMMeRC7Xdjbdn/Op9iplIakDucbn+D+VkAQ UlYm2LqVuGQJdulS3L17FXK5cfibubKgbOmc+2umRH/193sJO6M51YMmk6WwsOfSpTwCoVwoFHkH LXM40qtXC5KTSyQSyfB33fDlOB/7wwiq7TM2R3ZnLqUmTSAmTc5K8snCTcvNmM8kLCukbCnNP1hd er6p4usW5tGqjIWMJB9C0jRS4qRM7FRy5tL8Lsb7l2+/b5XSN2l0R27tZ23zO1xjtKmFZZ8d+Cy3 vLqxvWeIW3p829aiHlv81UNXk9iv9rl6qvc1AFgsFjabjcPhWCxWa2trb29vZ2dnVVUVkUjEYrFP xgAIgrq6ulJTU7FYLJvNrqurq6yspFKp8fHxLBZLpVIN3xlBEIVCQSAQUlNTq6qquru7uVxud3d3 dXV1ZmZmdna2VCp9s6cLAC/GYTEWxJy7tfaXCUcPZ2wmZ69nE1exCcsLGUcrq1NZ8af87u74c/Dm PwRu+E3Qpt8+PD4/6/6ZslxcNTW1lpScc33fzRU/yby5WyMbGvUX3A+CPC7I/XZ+bzxuJzPuYsDq X+ADPulq6hBUSSqutmbMy8+YGFW0YEPtxTM9jHgnZYmJsn6gPmdIMKjX621cBpS70Fpx0W4xQhCk lekbMR1ZK1kJPikJ0/wTZu0Nn73y7my/B7P3YKZdzfKJzPJJTpuUgZtKxs6lpq3EEXfeo30RWJqY 2MIs6G9vl4jFKpVKr9ebzWaHw+FyuVwul9Vq1SiV3JKy+q8e5C25nToxI8EHe3/60bsrZmX7nxb3 9LzCBYJsBgNmw+VkH2LmQXp7Q4ehBAulT+tL2FxfX2+3P+vWnggMm5qicAf+PcB3PGYOnrgwbaCq +/knA4i6GjFLQzFzKYU5BdrGOIi21JiysPPoSu7K+dzzp3oqy9Vq9SsZ8DMKCII4+UyE6KPrzPa2 hBroSUF+PyvZvVTJHdAM6ej7yjOXsgbYgsfGvYxdHgfEPFTz0Ccq6tJlHo/ndrthGDYbdYSg/YHr /r2MEKGRaoov1RHWs3L2FRKP5FybtfLrLdOLGGSNRgObTa7sDPuFz01FzMTT68KmnE1bmD9Q8pSb 0b7X1GprQ4PIMmwuhE5nT0pqWb4cv2dPBoFQGRZWumQJ7vhxWkeHxLt4pc3m+uIzwvyZ8TePR+EO pcdNxqUvZLSl9BlUJr1er9FoHrXCYRg2mcwajcbh+OGxZ3adsy22P3MJM24i7sGc4JQrKcWp5ezk UqJ/euyuoIil/hGzgyOn3n84OSLGJzZqasSDlYHpgRnFGWVlGeXZ/qnxU5Oy1jOEXaK38tH7AD0K ADIuZd+azfGpKUf3HAhPiT64bm+tBM26+9mFmDfRJn8vA4BarU5MTKyurvYG5RH4fH58fHxJSclT H6vX67u6umpra5uamgYGBp4aeTkcTlhYWHd394jLBV59fX3Jycmtra2v+SwBYPRamSk3V/0Md+mz tOV5KbPzKCfY+f5lrBsVGUvz8TMZrItVdcSaOlpxbUFeQymzn10oSsOpQoK1F77QHtqt2LGWuWqc v+8/Yc76cZqK3W4X+up+FRAEtuiUbYVp5LuHqPePK0WjWVP/ZUAed032g+tL/xnrv78ypYr2cTlu Eh0/IY00+VzZyjXVCbGDTfku+lpbzpKeBqZKpfK2bj0ej70tGsmebG566HLaEQRxuVwSjqzgcjl2 NhkzkYqZQMOMp2F9aPgltIxddPI5Zn5oMRtTVsGqamtr43A4IpFIp9PZ7XbvrYURBEFRBEVgxK6F NZ2Q+5tmNwRBBr1eUFvTEBRD9b2Hm0DEjKPET0xMnB9ZeLa8NrSxlzQgrlUo2rUajsEktbgdHhiC n943BSMIjMAQAnvg4cVtd1cElWAmUPEfk+vK63U1le7Yeab0WUU5SQqF4gdbAC6LqiPKN2j1/xex e2PKRAJpI03UKUbg53qHMK7EJfkQMi7kcGvSIMIkZfic5s0LBCvn99+9NdDZodfr324D0eNyQgUb 7Pk7jSoBgiAmnTJs79+TfH/DD7tts9mkXUrKjhL8LEYLptduHuvzARC0P1uI8SEHLN/FzqcNX0/G oFEknfW7u/1PfS0VZrNZJpMJBjnJV7ZdXfXrfCJGoVC4BTz7+ROWdUv0W1daNiyt+urAzaV/ip3y MGs5Syn44bWz3hd2u/urr9jz52P8/YtkMj2CoGKx8dSpgnnzkq9coTQ1dajVarPZkpfXuX592po1 qZmZrS6Xm0jsXDQvcf/iewwGQyTk4786HzLlNGYCrfBUrYave3JtpWd9PSKo92OuaNYWHKxJHk8N 9Pn00rIZaXEhfX19FovFarVqtVqxWNzd2VZCzyJjwrJig1Mj/TPj7laUlQgEAu+CWjqdLudKWNLE DNa1Sot57A/+fBc8CgCaoYaTuz8u7Wy88PGO4MScC4e3ZLGarn96IJLZ8gYO4/0LACqVKi4uTiKR PGNGr9VqzcvLYzKZo6i/s7MTg8FYLJZn1G8ymRITE7u6ul752QHAy3M5rImn5t/fOTdzbQF+Xl4l oU4mk+n1el1hvigqtnRlQOqEdMw4mrdgx1NHFPwEYsG0m6TFq+8s+dl133+6v+1PzPjLfWyCpq/V bXupoaJmrSzLf8cNvx/7+/3k7u6/B2363a01v2AmXNHKhW+mWYDAcCMt/ubKnyae30s7w0qZSkv1 iWXO2Fu/YknDxTONxUVKXhOUv95KXt7TUPDoTsBeLrvJUXMNJXxka7jtshpQFEUQxGq18ni8jvaO 9rqOlrK2ns4eoVCoUCg0Go3JZLLZbE+uvIE49IiiHulLhqtOIXkrvAvYu4sPOaR1j37sYRi2Wq0i Hq8lJYt9MIA660u8T0DMhLCY8YlJ47IfvXaYcTScD52wrJC+u4Kxv+qxsq8qd2sZYRk7ZWoedgJ9 RMGMo0VveljCKlbVVDr8l3kyJzaQbnI4nOcc32Ll5LIv/ulr3x9htx/F+2Smz89rjG636qzPfhFl XVzMtLTktYQKJtuSt1UXOr7Dbzrn6L4OVoFYLLa93FvrVXGIqpCcGeaqa97jKUy+Fuj7Ly2LJ6rK il1Op15tKP66HjuBVni6ViceyyuRm0TWrCWFt32+jLv11dDQ0IhmqGJoIOrItPCDPkrpkMNqzos4 5b/8xzTcfRGn34pLsG5art67uTcNx+vu1t++oV45J27pL4NXzMDOyMk/VqlXvGfPm0pl5XI1XK5m cFBjsXxzFQ6GkdTUjtmzk774ImfZspStW7OioupWrEjdsAGPwRQLBALvopwoikIQxOPJzp1jzJ+f fPZsvq8vbv3UB6EXQgUCAQzDOpUs7oxfwMzlSdPS0ubmF31R35XGlbdo7MbvvQ4Ge2AdxziYJ24M 7Sn8rC7brwjnQ09dkXtt2dILfr9lEJJHDBlCURRBEI/H43Q6vYtleZs3CILARgOk00I6raC5Mmrp l7hptLbc7g9qkNvb4lL14+IyBQ4Xiro5dflxcXH4HLbOhko6y+Pi4vAklvbVj/p8ivcsAHg8nuTk ZC6X+4zWubfb3mQyJSQkDA4OvlD9arU6Pj7eu+6Ew+F46hWG4RlAoVC8pjMFgFEbaGDeXvOnuPm3 U2bSy3DVUrHUZTI6U5MtO3zV21eKd29u232oeNdZxt6bufvDsw8nEU5nZV+iU64V0G6wGbeK886V ZPkxcZNI2FnxCbOvhs3YfWeO773Fs8LWTIvZMaP0xhFdU63H9mLLiSIIIuO2JXy+IHjVX+I/OUwN TCkIzC8IyInbtS1w2R9Cd/8l5+4nnSVEVUe9vqfF3Ndu7e/yFhunx6NWvaqrBF1lxLtb/xi5d13G utwUHyJlypfVfn6t1y62sphCHs+o5EKsbVaKH6eOrFAonvwRdZg11tpbcM5MR+VFu17q/YWGYdjt drvdbqfT6XK5PB6PdzXukc+Ay4zIyuG6Cyh9KUKebSctNOVuUrNODZWFyasjnPS1MGWeszHYbfym WgRBYBi22+0qiZhXzG796nz5xo35CxemzJzyYPqUwOnTrk2bcWX6/BtTNwVP/jTU56v7PlcfL1fu TTobNPnIjcnb/aduuDlj6625e4IWHPCWW0v3ZCckCPEY67F1cNJ4EXFHe1PN869l4XZaVIXn8Qd/ Ebju95RPv8jxjcX7ZFM2F3Xg+9R9OvcTMw5RFPU4PKwTpQlTM4gPs4cq46DMCW3HF9aFhw50duh0 unfnXlEet9PZdBcizzX05Ho8HnF/871tfyQu+x/Vno2Gpnq3220xWBriOzKWFFB2lIgaZWNsTIuX y+QuPdMUNx5/da1vZQnr0RsDcRohqwnWqN0CXhsdF7j+V8Q7n7Ix/rfW/hJ/68ggK19//nPTpmXS M8d66mqVQ732oQqTXKi7H9S8cuKtZT+N3XMyZTqdfa5W2a99L6bSORweGq1v2zbiihWp3vLpp9Ta WgEMw21t8vXrM44dyKhnthbmdhzYnz1vXtKxY8Ti4iaZTD5iJU0YhlUqQ2pqw/LlKUunxn6x6HIe je59VhEEEXM772z/n8BVMwiHs7I3F6YtYKTNKSAuZxeerGvHDHAZIl6BmFcg7sngN4R2l5xrpGwq y5jPTJ3LSF/OyN7Oop0uYd4tTrx08qvlPycn3pGIxSM+TY9dFfR4YKsVkojcJSz71S9tezfZdq+3 7V5v2rsxa+uSqEnBhLUsOfeH7wEMjA3vWQBobm5mMBhPXc/H4XDodLquri4+n+/dotFo4uPjn2f8 3CNUKrWlpcX7cIvF0tTUxOVyzWbzUzNAR0cHlUp9vzozgNcFQdxOu9Nqcjmsbqcdgt5mJwop+EDo 7G24aVTmgzLRkMihkjtx953nZ3miJirTDvOqWIKuTh6nn8fj8fl8oVAokUi8ndbeddP1Ov1Qt6Qu uZWyrzjTryBtISNlJj15CjHeJzl20oPI6ScIfmu5l85Zq8s95udaHB2GIV5LScSuaaFzNyfOTMDP yE2ZSEwZn5EyIQs/iZAwOSpqyuXw6SfCZx1IXHwYu+xT/PLjaX4n0/1OpvudzFh1In/fYcHNqyZy lqu3G1YpYasF+cEV7p6AIAi3sfD+9nEPFu/CziSmTkjIn7O/6ugnzZQcoVBoNBrdRjFcdsSRs7i/ OlMikTy1SYogiN1qNLfEeigLXewDdnnbs15oyIU69ahFjMgq4e4YpGQfnDPbRl4qKzjLr8Lw24uF g71yudw7E8Ao7TZV3YBIMzysnU4+C3LZh/9Rt9tt1OmkXR08Vn5f1IOO00cbt/kVr56Zu+iv2fP+ TFj414w10zEH/eIO+0UcWBx+cFH4ocXhn/g+/Gxt0sWPM4O+yI28yUwKK0qNKctKKstILEuLqwgP 5hzbp9vs6wqY6iTOaColqdUvMDYDQRCHmiNNWxGy7l/CP5lZkZJUdiGBMAeL9yFkLSlgHq1pS+oX 1yqMYovT4ILcMAIjg3lizMSc6H2hDdRMW9YK5cMZrIQo3uCg3W5/175CnUaph7XTSVtl1Micdhsh YM+d9b/lbllhOLbP1N0Jw7DD7uhn87LXsjOXsPoL+G7nu5JeXgnYA7fHcTBTSJenLE2+c14sFnlD DqJoR4oP2ZL3Go7tse7bojv1Sf6XWwNW/fzW6l8kHFvSHnJLvW21du+mfkwCr6/XNNQAlRxGSNPM TeFGpUIZFpyx/A8B6/4z90pO+qJ80rrigcIhh+WNTgFyuSCLxfWcxWx2qdXW4OBKX1/ckSOE+Phi DKY8IpS9cRV+pR8+4X71wb3kpdPjAmbH4xbn5mwqTlqfd2tdZimpTiVTPbUHHUEQi94adzD/3D/u 3jlxua+vb9jlPqitlBS8+ffJl7Z1N7T2lnPqU9vyL1YQ17NS5zJSZuV5C35uXtoiRtbaAvIn7MLQ yobclp76PiFvSKFQ1DPTb6z9ddKVndwBjt1uR6wWTzHLmZLgeBjiCPzacf3CN+XqWfvFU/YzR20H t5s2LVcf3CH2vzQUETIUEaI7+nHXqmkh82Yljs9iHKnU8HUgA3wI3qcAAEEQBoPRaDRPtsUNBkNb WxuDwSCRSH19fY+2JyQkSCSS56wfQZCwsDCtVut9rNlsZrPZJBKJzWYPDAw89WoAFovVaDSv9ayB dxnkdko5LS1MLDPuQsb1rbjzK9OubMi8saMg9oJG9oaGtYxg1srvrP57vE8CYX8+l8t1qKTu7LNw /ESU8JGeuAwiTnGy9poVnO/rqPaCYdjhcGi1WqlEOtAx2FrYWY1vZIdUkU+wcLPoyeNJKZPvVc09 qD7/ubWyzPNDk1MHG0uj1m6LnRSOGUdOnxCcP/3jwlWH805eK7iVlHstJ+MgFbuSkjyfnDyVghlP xYynPVbG0ZLGZ8dPDiDP3tmxZIFx13rrxc/t4XcdpExXY61HKYef44I15HF3lhDC1s2NnhKAGU9K 9wksWrWpMiqir7PDu4o2YuQh5Z9ApOm9FWlSieTZq2E4nU5TH81DWQhTFtj6CG7nYx3nCAIjynqk Nwmpu4gUbkNypqOEjyDiZH3uFl553EBXo0wmMxgMDofD+xI8esJtVouWU+ykr0NIU511/i7t4IhX B4Igt9vtHdcrE4kENVW8lOTBIH/h4V1yv3ly35lS3xmilfOHNiwb2rJqaOd60e6Nkr2bFR9vUe3b ot2/TXdgu2H/VsPuDYatKw0r5ij3blJF7PdkTeHSL4mGhC/aBw/DsJWb3+j/h4AV/xy652/UmMtt VEr1ZzdYs89kTnyIHU/BjKOlzS6g7iwvv9zcFNFDXMYOmxJEDLguCljnyZhQiv26t7f3hXpn3hgE QRziGjhnprnK3241clvKAlb/IuPYMsXGZYYTB81ikXdAhahdSt5WnDqbURfWYVKMnduECdmytFn5 wVM+v7jmv5vqq7/pqFaLEep6JOsjNOsjZeDSwTs3tAe2q1cvSPL77UO/P9SuWSBfOnPo/Oc9xWyp ROTgMRHaYidpnom6ESLN0AubLWpV980zQb7/gvPf15TbQt5ZnDIlj326TlAuddpeOAYgCOK2e8wy q5ZjULRppfUqVZfu2ZdibDb3w4cNn31Gf85y/Dht61biwoXJ1y6TK+gNraTu8uAm2pHSSF/S9smJ s2YmzpuVcGpFVMpJYuHtyrwzpYQtzIQJOdiZ1NLLjcoezZOtZ8gJtcdxMBOoN2YeI6en6KRSd12V q6zIxcpzlhQ6zKbyrAcBa34RfXw2p6XCarWYTCa1St1XN9DG7mot7Gwt7Oyo6Orv5AiFQqlUqtPp rFarQSMfbC2rJT+M2D8udN/E1sZas9kMScWOoK+tK+aY1vtqd65VHNwu/3Sv/OjH8qMfy47tl5w6 Ijl3UhDwdX8OcaCnR6FQeO+UZ+Dz1CcPpi35XeDMZZhJubSPy5UDY2e2BvB93qcA4HA44uPjhzfE HQ6HUqlsamoik8mkbw0PAI2NjeXl5c9Z/8DAAI1Ge/TYRwHAi8FgdHd3G43G4QGAzWa3t7e/zpMG 3jlOm1nYWVlFCEm5uCZ4w39c8/2nm6t+fnfXXx8eXxB/dk3sFysij80L3Piftzf9tjTtjs389CXV XxMEhsvTg8NnfIabQ6sk1xqNRqgw8d260QAAIABJREFUAE6fIEpfX83AcPr7dV0kT64vRFnk6Cd4 DMIf7OZBEASCII/H43K5bDab0Wgc4oqKIkqxK1OTxuXgfaKq5+6V7d9tjXngrK30iIXwE6s3DhQ1 Y30fYsblYscH0eZsKD91rI6a29fbK5FIdDqdwWBQKpSiIRFvkNfX29fa2trY0FhfV19fV19bW1tb W1tTXssMLUlfT8NMpGLGUTETU3Km3C+efqN61lfNc0+1zj3Z4Hu9YnNiyUF6xdWGujudzZG9PVk8 QZFE3qJRdepUnTpJvYx1mRAzOQQzjoYbH5e96EjR5QtNtbUKhcJptyLqVqTuIkqa4iTN7y9LlMtl z7MWnsfjMSoGLWVnEOIET8FmT3s4xCXAXALScBXNnY8SxjlJ8wyUTcr8E6KKcG4jndPb5Z0E7HQ6 n/GcQxBk1MqNjRFQzmyYPNvVEurScp+6v/d18V6o1Gg0UpFI2FgvzKcPpWKH4h+KH96X3A+W3Asc UcShwaLIEGFsxGAaTlAeB5Fmamj7+no6nr3yz/cercdjqfq6O+SvmKN/vbn65zdX/Szm5KKkA7Px i36fNv9/cHMWYeYdxsy4ip2HwU2nRI+PC1wws3nVFGfcuKHMTQ0NDbYXHEX2JkEel7M51EOaqRY0 Oey2IlzADb+fsL7ap920wnR4p3mg3xueDWpjWUBD6mxG+vyCpuhuk/ydiwHGIQvreG3JucaG+109 GbyhcrmWY3B8z/hyjx2SVquyFhfGzn/45cLf4UPOKRUKGIZhqdCD3+BIm1STdFZScA4lfKQt+1rB 61MnRss3Luv3m9d15ngXgy4QCEw6BdRyFyWMU+Ud6m0ukQt6PHlrHPnbTBqxWaPKPb0uYPlPy9Ii FBJl1YPmrNVM7ERa5hJWxbWWLjxXWCJVtmm9n1lVh07erJHUqIZK5YN54t5MfmtUf+XXrQWHa7JX F+NnMDATaMNnwmDG04h+7KaobkW7xmV/SpStqxMvXow9cCDriy8oTy0nPs0+uBG/c27iZp9Yb9ni E3vuH5Ghf8PEfZSN8aGm+uYRdhXQLxQzI0tDguh375JramrlcrnJZPLealrULy4Lbkj3LcBOpNP3 VrRjOapundPqQhDEbfPU3+nGTMi9MenjwE/8upoaLKFXrLtmGtcsMK1bYvWbZ9m1Xp+SWJcRFXF4 6o0VP86+fXigqcisU3o8Hve3XC6XWsLrraGXpQenf705dOf/Xl/6z9d8fxSw9pdhh6dXsihahcJJ J1u3rdLtWNubkszlcERDQ1KpVCGXKxWKb4pSqVarNRqN2WwevtIugiAWoaD7s+03lvy/iI8/TvXN zfRldhEHbPp37gId8Aq9TwHAYDDgcDhvy9tut8tksrq6OjqdTnrc8ADA5/NzcnKes/6ampq6urrv CwAkEiknJ6egoKCzs/PRVYKGhob6+vrXetbA2wV5PDajVivhCjsrm/ISyfc+idj3UfDG3wRv+e+I T2enBn6Sh40sz8orCmfmHisgbMrPWElNWUjCLEgKW7I3cOnfYk/MqyZFSjgtTrvlDXyT2ky6hIPr k8ZnZZ9m8AYGnS0lSPpUAX5DZUmBXC53uVxu1//P3nvHRZVnef/7/GbT7OwzPb8JOzuz88yzv92d tm2zIChZkQwqqJgD5rbbnDOKIIKiIjlnqEhFMhQ5QxELKlA55xzvvfX74/YwDMa2tbvt4f06/yhw 695bt751zvec8zlWHX/IXH/QgXKDqr2AlsMA9THAwoBCCijp+doUI6D95R2ZcGG60Wikj9HwSVUF /mW5n5eXLkmvWnm5zufYcNiR6Z3nGV89YMUVzWQ1sBCjfSmDJW7VmZ+l563cT961q7OkkD4xoVar 546ph48JT2mFv+fmYTQaeXReN6YfdRWZtzU7bV3qs6UpqYufpX2WmfZZ9rPPnj9d/OjJ4gdPFyc9 Xfw4dXFq+uK8vJVVxWuIpe7kUndysQsha3Fh9pKHhd5fVh8/14pCshgMo9EIGqXQ8AMI42ZE+fFr L9MHaoV83tsrYYMgaNQptUO5JtI2M2aDFeVhR7ga0RtlNV8yOks5kz2CGZpYJFSr1fCeBQAAb/MA QBBkMRlU7F5d83k72hPA+dq7rtl5TYBB9KqxnXAwYLPZLBaLyWTS6/U6nU6j0ahfhkaj0Wo1Bl43 gFmnwW6eHmrWaDTvnO63arim2t3KolX9BYcLb2x7fnxdysGVD3ctitv8u9uBn9z0/acbXv90zefX lz1+d8H1N6XrFolvulgqVg/V5XyjiqPvBbuaDSGWKrseGY1Gk0FXeCU8cesfex7dUO+M0B3epR/s g99Qg87I7ObUnOkodicigxsHMyZVbO0PpHzCbnQ0ftVXtAZfGVFbtpFc7EkscSeWedQg/Btw2yiN Z/p6Ekep2dPjpazJypnexHHs5paSNaTSYFxcZMCN8N8P9LSbTCZQxLVn7nSULu4tOt3f262SCU1d dyDkSkP3fY1CJh8ZZrY2cxh0tVptN6mggVhx7rrK2FOjQ30qlcput5lnGkDkSn1PosmoE9PHkyL/ z4OwX3eWPVMpVUKGaBgzTjrTWhlaW+JFLHb/+gM7ayXupJJ1pGIPYpEnoWQ9sTyUjNxRizvZRLrR QoqjPP2SkHKO0FrRM1hD7S4axB+hlHiRSteSsZHN9QlD5SXUcQpX0CMV9sh4PdILZ2r9PXOIWS2D uLEh3PgAeqwrf6jpUTfxKgURU1MYWp25tur5qvJU19LnPqVZoRX5O1GlX2BR10i1yS1t+T395CHa wDSHwZVIJHKpmMekjfW2jLYTB8gFXZjn7NEOnVLicDiMBiNvTNiROoDe2VjiQSxdV4PY2IDb3orb 1lqwEpfsef601yekqjxpI9l21w0qXCQpi2E2ogV1ZOWVM9rIAPXOcNb1M6iTwYmb//1++C+Ttv8x 55QPMm4vJvEQJvFQ9ldeD7f9R1zEr+Kj/pAS45J/PRqTfqsFXzrc3TI1MiDuatdfOa3f7C8898Vk XY1IJJrNMcLB6kvU60E7ZFHNllOCAKAeo1bvcr/p/09Fly4ho2uLXUno8KaB5xMKhvoH8kgv8H75 mAIAsVhcUVEBe94CgaC2thaFQiFfYG4AIBQKS0tL3/L4TU1Nw8PDrwkAYDAYTGdnJ5wKGBwc7Ojo +KBXvcB3Bgg4rGajUavQSHncsY5ORAo26UjR5ZDME+6Pd//pfsSvYkN/kRD5n+knI1DJcQ15yKan rbWX2rE7myrW1xauxJa4VFZtLEEEF6BCsivX5RUurshampOy6uSDNSGPQ/0LvoxG3/uSnHqtpTih C/2sn5Q30lTJnxowahSA473VEE911D5dfTp/HbYN16nhMB15m4wlK1sxz3k83txqE51KLJuoUbTG mvHhdpS7HenqQKxyIF0cSBcHcjWIdrN1XrZq+NBr96oNBsPEwAj+Pi43JC9/HSpvJSZ7SWXW4rLs z0qzPyvJWlSW+Vlp5mfFyatupG4/in/yeKy/H1a5fgfPDwRBq9WqVCo57JmOBhKxpAidkVOakJJz Pfb5hbNPzsQ8PB4Zvz8wdpvHzdDVN/xdb/p43vLwv+kZfNc38sGG3Y+jT5bGJXQQCfSpKZVK5XA4 IDXN2bzfjnQT1FxkjrQJBHydTvcO8hdWq1Uh4YlZw6LJFsEIeWayVygUzq3weTc3FwAAvU6rYLRp Wy7bMH4A0gUkh4FtJ8DeGyA1BZjMA+jlAAsLcGtBYRsg7QMVo6BybK4BijFQNgSIOgBeA8Cp+drY BICJAibznORQAyaA3k9UKF5SrvD2QBBklLNMlDO2qtWS1gQencpmTk+PDw93N3XWIuuqMhFptwsv 7cze7pK3xbX1Xoy5bIWQdIrFmPrhdP2+ChAEHY0HTMQolZQLQRCfTn20679Tj64ZRxVrDm7XHdiu 62oHHA4nnA7S6MbrpvFHKMVuRERwQ3/quGpGYzd/z2oqMzXCopXEumQKc5LFpLIn2qaHqsfa0npr rrSiDzRUhNWWeJOK1xKL3AhFawjFnkTkvtrG5+2k3MLrQb8uij8uEokAu92OSAKLPqOX7uzt7oAH P1uMGnPHZQDtpqHh4c04m80G2Q1Q/w0HYvXDL867umYTCANWq9XpdAIAYO284sCs0zCabDbbSDMu de/S+0E/r8+8pZQKrVarVqvlTvFpHfQh/FhX8UBHQV9HQV9HYV9X2UAvYqgfSx0ij4y0TEz2TDMn WHweXyKRcDjihw9bfHzyPDxyrl+vYTJFRqNRrVRPd7JaU/sfhlWHrCpwdc3evzI/cxWyyJXwwAXt 7ZK7Z3nq0xXFBa64Qld8wSpcgQuu0B1f7EkoCyYj9tZUn2tofN7RWz041j3BmpoRCoRSqVQhl0mF XOHMFIPa0UPIrcm8XHEnOu/M+ueHVyZF/+e98F/eDf3kbugnCZt/m37UFf/0KwGdajWbTSaTTCSj tTLa0/pJlyiY/Q2VEbVFB3Iu+v/++bnNzFGq7uZxMGOxEellR66xErfoGHVqiVjeXC+/fUmzNVgW vp662at+h0/xAY/Hm/6QGPqbxIh/T9z0+6f7V5XePlhflDJQh2UM9IqmaCoWU8dkGIf6jbnp+h1h yh3h9PSn9JERlUJiF/cCghZA3A3KqICOC5oVkN0AgX/e8geskJoG9V6F6rfZh1PsGjYcBgAOh3io N3Pbn+6H/aY2K62nbLA6prnIlYgMbeRTxSCwEAP82PiYAgC9Xp+bmzvroKtUquHh4ddnAOCqnrc8 fl9fX1tb2+sDgPr6eiaTOSsSClcpfNCrXuCD4rBbJazRMQqSUnIfm3Sk6HJo6sFl90J+fsP3725t +IeE7f/55MjanCtRlclnMMlJyIuFqP3kqojaUg9S/mJc3iJckTuubENhte+NluCDgyEBDD9Xjvcq rvdqjrfrkHsoacXFosUFeYuwcCF7xufPny279XjV8UTXiHtrV97y/M3N9f/4LGZ59aPj9IHGby8n YrMYMRfjcj6rrDyPZ03SzKWxUMmn1LLjoyPD1r8u04f7Sg0Gg1wm5dGHeOMU3hCe11/F7avk95aq Wm8DSBcAv9HCqHZYX6cMA4KgXq+fmZmhDlHrK+owyciy2ILCa+lZZx8+PX4t6dCphIMxaYn3Ojo6 ZDLZu7n+L+JwOCwWi16v12g0KpVKqVTK5XKJRCISibhcLo1GGxro62iuayAg68mE9vb2vr6+kZER eEsMAAAnCEDiDife14JaR2/JnJmZMRqN3+bmz62Sstvt71EWxuFw6PV6mYApGa5SN57RVkcYUH42 hAtYtRgWD303gyoXWZDraN3VUqn020v+QRBk0qsMnXehqsW22u2W8QKrXgYXLZjNZq1WK5PJ2CzW xHCvChWiQwdMj3TqdLr3cn8+NLbpSgdqjWyiBo7lhhoq74X9InnX//QUPVYc3a2PDtX0dM7eQIfD oVFrJhrpxJOtBcvwJW7kpnO9rAa+RWf5XnIdJrkFv621NBiHyUmUibgOhwOuJzEajTqdTqFQiMVi DpMzPcyY6KGNUibG+ya5XK5KpaqM2xsX+R89lFqj0QhMjNoSvS0VqzoaUGq1evZCLFqJrX6PHeur ldBBEIRMEqjrPFi1dAx9a2tkoYtL9qlTOIXi69+3aAQOUriVHKVTSR0OB2uSmn/U+6bv/8o64dlS msCithm1Kjj1ZzQaDQaDWq2jUnm9vTO9vTOdHTRKw0AjsY2MIpMQRDKSiCqtj4nBua95HuK6c4v7 pjUuafv2IqrK2qlUYX8/LyOjx9e3ICQk/8TxMs+1OYln0O1lPSd3Izf45WTEVbYUd3RXDnRXDvSg BwfrqGNdE/QJBpfLFYlEcrlco9HAur1KMYfeV9+Nfo59eDj7S8+Ezb+54ft3N3z/7k7QzxJ3/E/q l+sLbu1BpV6tq0zrasD1U4i1xUm5lyJu+f9jXPgv8c9OK8QcEAQdDofJZNJoNAqFQiQU5l7fcTP4 l12UOhUOZT6+DqxYTK3PlI1gLIQIELlSy2q1WCx6nU5MmxQX54lPHZGH+Ul8Xbgb19G3Bk/v3kLf v50Rs5N3ZI/kxAH1Fwd0R/cYYqKNuyKMwV5Gfzd9sBfn0umJtlaRSGTWK6Dhh07E0r985BFLQcJG oGk/2HUJHLwPjj51dp51olfbEK7q6i0AYjmI9bQNP7aZ1HAyljnQ+Tjq/yaH/GYMUSiXyUaqaWU+ NVXB9VKGfCEP8CPjYwoArFZrZmbmPE0enU43MTFBJpNfGgBQKJS3L9GRyWSFhYUvDQDQaDSFQuFw OPNGg+FwuOnp6Q961Qt8CDQSzmhjOSJu9/2IX91a/5PbAf98P/L3j/YvT/tqQ/71aOSTi/VVed3E 9p6q/rZnvbVn2isDa/OX4ApW4suCiJjtVaTtTxujr3dv2z2+fh3Dx4UV5sc8vJt57yYjP5uBQdIb 65ktTUwMYirr+fiV87179zb7bSev3ItZfr5yaVzJ4tT8RcV5i7C5i7A5y4tTVp9O8PC9H/hf9YVx JqP+21wUu78/xz01zwPdSenSUPBAxkp5qXdHa5NG87o+hFnndfapNpvNKu6gqXY/VLUEIAbZhh/b xX2gRf2ahAAEQVar1WQyzVbEwh45PPL2r7Z7IQAySSD5EMQlg2w8KOkB9XzQboEg8C+56W/BbDUR 7O7ML7wxS6H+W86qz+W43ZP9DRKJ+O1rfr4v/hyt6eUyqVgkEPC5XDZrhj45MzXEnuhkjzRxhkic fgy7DzXPZvqxM0M1rBHKzHgXbKzxHgZtmEmnsZiM+e/LtztDq8WiHq001u4DECtAtKu945ydgQKU NNBugSDICdhBajKAWDHdWSmTvTdR1w+NwyAB8Rs0Tef0er3T6XQ47FODrZmn1t/a8A9FJ9cz9oZp N/trKE32OY+Qw+HQ6/TsUU5LQk9laF3+EnzhCiJuB6X74Qizhq9h616c9PSB6EuaKHTBPzt04qLX /0qI/F1TcbxGLpr3+YL91NnYAAAANrX1TsBPSxO+EAgEgMViuXEEzPqMVbWXwWDMjWwhCDJLqEC1 t6luv5mOgYgBNuTaKUo2Bt3t51dw4EDVunW5FMokHB1BEGRhEkGUq6b3sdViAUFQLhJU34p54v+r ez7/cHP9T25t+Pv74b98vOfT9GOuj48Fbw994OaWs2bNrGWvcc12dc12dc2CzXvtg8PhmxKOB2Zc iryyO3Kj131X12z4l9etyzr1ZQGlmTI5TjsUgwoLK66vo3p55V+9jJiaHNeqlXqtWq9V69QKtUwo 4dBY1LYBUj76QUzGcben+z9Pjv7PuLBf3Nrw97c2/P3dsF8m71uafSEc8eRiPSJ7sLuVQZ/mcTkS sVihUMDRgtVqhfX1tVotmz6GTP4ifvNv74V8UngphFKaMN1bK2aNqCXc0RbE/Yhflz08JaBP64/s tMctNSI8xsdGTSaTXsG31u+3V/vpBFR47bLZbBq1WsTl8FoaBRlPBQ9ihXevC69fEF09J752Tnzt nPjGBVHsNUHCHV5KIjM/m47H0nu6uRyOXq8HVNMQ5RCAWCGoucgcquNQazkDWGF3lrz5hqbmsA4f ZcAEmVDeerQ/v+7G5EivSChQzPTpmi84KxepB/NmkzbUVkL8pt/c9fv7wpPrOzGZw7ieUk8yOrJJ MvVDr9xb4BvxMQUAIAiWlZXxeDzrX2OxWDQaDY1Gq6+vR6PRcwOAwsLCt5fqhyAoOzsbHgIwGwBg sdi2tjY+n//iaDCdTgePDPugV73AewQEHDLuZGPezeToP97f9Juk3Z8V3tlXU57aWYPrq2nuq+7s KuhpvNOJO9BSGVhb5lVT7E4q8iCUBRJRUYiaY1mdX90e3RrNCvfnhvlxIoM4R/cy4m9PVZYxOju4 UzSpRKLVao1Go9lstlgs8MgVjVotZc9wB/vp1eiJlIcjl84PHzzcG7W7LWh3recx7Iqb5Z9n5n9e lv7580SPiMq7xxUi7rutsCAAkM8gcpYhK+4jeUymJeOIvWxpFyqBz+e/w540AAA6lVg5UqGvO2rD eENoV4jgD9ZtBdu+tNMRdr34jSc5v97U6XRCACTrh9pPOgl+EGatA7nGjnQD0e4QzgciBjprwqC6 KKhxD0g5AnZ8BXZdBLsvg92XwZ5rjsl8h5wKmpXvoP4555IskLAJqttiQ3nwaq/RJ4aVSuXHNfIG /DNwwAZjsVjgh830MuCfzlu44EzFe/fCbTabVimS0ylqynULPtSOcoewHhA5FKQcATvOQBg3EekU lzNjfZNm1A8HEATtPTftGG8ZnzY71EkhEZKybyZu/2NSyK/aw1Yqt4fo0JX2OTE2nBEyGowipnik ZrIxvhOzr7Hcn1zsTqzwrsVtb22/PUyrmhEPKfRCo8P2QeIB2ai63Ku24mDl7chPHx92z70Yfn/T b57s+7w+9+YMtU2vkgIOO+CwAw6bzWI0ahRKAZPZX49NOpKw+TeJO//U3ULW63T2erL15Bpb2YrR hky1Wj3/5gAOEx1rLnc1V67RYUKnu5BCoTAhgRIUVNjSMhgQUHzlCkml+vq2OKxGW+dVALVGxRuB Y3KpUDJQjek5f7QhcFmV1++Lgv47Y9Pi00H+fm6x6/0yD+24euX4qdtnr9+/9iApLu3Z45LMDGx2 Nh62qgpsVzuFPcNSyGVc1nRHa2/mk8JLBw7E+LoccP/PC4G/u7/1/z7a9d/nglZ6rnmwwS9nnUvi 8Q1LE6L/K2XPp1/b7j893vlfD7f9IX7Tr+Mi/i1p92dpJ33zrkYV3NxVGn+0OjuulVQx3N08PUEV 8LlKpRKemGu3Wh0atYPPc0yO2fu6bA01VlS5pTDbXJhlKsg0lhUoezsn2mpQj756dtQtIeoP9yN+ lbDlt0nb/098xK+S9iwe7GhWF2Yboj2AnM+5+K9EIhH8cTZLxkDMWnNDjEEpmDsDxGazGQwGOM+p kMsVMhlscrlcqVSqVCq1Wq3T6YxGo8VisdusEL/BSdhgQm9gUDK5bKZer59dGXQ6nUoukYtmJNxJ MYsqYFLFIiGc+QQAwKRX22siTTW71Qox/H5ZLWZqO7no0rbkkH+76//PGSd9OooopZ5k0pE2lXj+ k7DAx8vHFAA4nU46nV5VVTVvG34WrVbLYrH4fD78TxaLVVpa+o2+4zs7OxsaGuCvTKPROD09LRAI 4ED/RZqbm1tbWz/cxS7wvgDsNpNOyRvvqs249Hj3/8QG/zz7UhS5MLML29Ke1ld/qRO/j4IKbyzz JBeuwhetI1RGkDHH62tu17cmE3rvZoyeOMnYuZkb6isM8xMc2cN4EEuvKme0UtgMhlQq1Wq1ZrN5 rqTjPGCPDQ4pVSqVRCjkTYzPdLZPk4m0gtyBC9fawr9Er0zK/6zyybKruYcP9uHK1BIB4LBDEAhB oNP5VvEAt4NTtAadtTm/o73T0N5if+yurfTq6Wp7Z6VFCIJsNptGrZSzemXdafLGy2rSQXN1IIBc DdRutU0W242Kt45VIKdVBY08gqq9LCgPEfkctzOXO4gWjhBFAxWS1gRZ/Vk5+ZiSeFCN36XFRRmq w03YIDM20IwNtGF8AKQrgFkL1m0FOi8AYxkArwFQjIIaFmgQQkbx12aSgBYlZNNDgOWv4wTI6TBD imGo6xyIXqPDhDI6SjjsGaPR+LHsQ39EwPqYer1eLmRKJuplHSmqmuM6XKQV46urjqRRu/VvNzji h4Nd0Aag3WT9BbNxCwRBFrN5rLM246TXvYCfoTf8fibQRXbphG6w12H5KzEl2IfT6/VyqZw1zBkm jLc87MbsbyjzJRe5EkrcSaiwpvqT3UNZU6J+uUFisuptoOM9PJMOk6PmUFepP6n41u3Lfv9Yh8wV CXgDzei8S2Fx4b+6v+nX6cdciy6HwJZ/zj/zhPvj3f9zL/QX8ZG/L7i9r70WLRIJHQq56fBOR+IS LTJwcqT/pYkys8mcdCHpzonb/a21UqlUrTZu3Vr15ZdIHo+XktIRFFTc3U3/eoYABFkV00C1r6Hx C71axuNpb9xofviQwmWy+Y11rBuXOJHBud77vd3So1xuFQZE9pw8On3r8syDu9wnSbzUR4LnKaL0 J5KMp7DJMp/pCrLMpfmWaoRlqN/M56oFfD5npqcBi06/VZ50uuT+kaI7e/Nu7T13+N6aNTnREXce nd2ef3N34e09sBXFHihNOF6Vcg6fF99eg5ig9gsEfJlMplAoYGkyg8FgsVjsFotDpwXlUgd1yFpV Yom/ZT5z1Hhgmz4yQBfmq41Yr93sr40M1EYFaqMCdZs26LcF685/IS/N53a2jjTiW9E55MJE9NNL ZfePNBY95Sff123y1130s1Wumm4vmf0sgCBgolUBaDdDT4LZqJv3AXmxf/cleyt2PTRdDGLctdhN 0z1YoVBoscwvPJurtTDv2wqCINtEgR29Tj7VNOsv2e12uVw+RkDjj4bGbfjnolu72tK6iteQujOG f/hZ0wXeko8sAHA6nVVVVV1dXS/1yOei0WjS09OVSuU3OrjFYikoKKDT6W88Pp/PT0tL+yEr2S3g dDq1csFwXTEm8dDT/YthxbSsC5G4pCLSJQpqS0PBckL+YnyJL6Eqmow729iY0tGNGRgfnGRPTgiq ykQXvpBEbFBtWCPdFsK+coZRkDPVSpmZmZHJZDqdzmq1OhwvV2V5PbMl43a7HZ5eJ2QxGenp7b7H ihcX5n6GfL40ITPoIi42oebJPeKzyzUZFyc7CGbj6zwn0AFVb21OX51XkV4kFovNcWfB7M+YyEMc znuYRQAAAFzMrVQqpVKpfKzaULMXrFoKkMIt/A7A8eYvA0jWC9VtAauWCcmnaUOtIpEIjprguiO9 Xq9WqxUKhUwmk8lkEolEIpEIZxHwxfQeaU+Guva4ARPoqFo2p5x9kROxBDYItQLEbwDqo4G2k+DA XXAiB2BhIXoJRH0IUY46USvyaaOaAAAgAElEQVQtyHXs+ripsX65XP7D70D92IGnI5tMJpVKJZVK hQI+lzOjVH4c81/nAlrUQN02HWmPTquZ+1ECAEAhE+NSL97e+E+xfj954vsvJYG/64g7qaHTXrzG WZkmeIaDkCecaJ/qLBiovdpeubkmfxkubxGuxJ2Mi6a0XR+awnDULO07VwqBDnAwlZa/FE9+RkqO WZO0fwWTyYQXK61WSx8bqC99lHdl87MTXrClndqYe3VrWcJxQsHDob4uoVCo1+sder01JcGwfS1U umiGfEMsFr/0jWtpYbu4ZK9dm5Of3242m7u6eOvXF+bnN6lUKgZDHhBQHBdXPztFGAQBy0QBiFhG yM3dtKli3bpcL688LJYK61Z1U0YC1+dtDU8jHD8+HrNTtGuTYluIestGbbivLuxV5mMIWGv0dzOG +hiO7jZkPjVOjus0Gq1WCwteqVQqPl+cnd1KIFA4HA68az4XWALfZDLNTYhBDgcg5Nt7u2zoSsvD u6YvY4yb/Y3+bvpgT+m+KN7Fr9jJ91klBQxCNZPSzOzvm6FNsqdo7Ckav79XkpepOLHfEOhhCPLQ Htqhjr2qzE5VoCtlGITk5EH1xrUzCXdUmGgDJpA+SZ27CtntdkvvPRC53Nxxxar5ZklgSDHq7DwF IZYKSV/SRvveLbHp0MxA1Z7q1tvzxoHb7XYZZwZ9KuyW3/9Dfhpbvb+xzJcspL85A7zAR8HHFwAY jcbMzMzW1tbXeOdSqbS4uPjdqvPVanVBQcHU1NRL5w3DTE5OPnjw4MWs6ALfLwalZJCcT0w9g3l4 uPzW1mcHltzZ+I+xQf/6cOeS9INbi0/EIw/jSrwI+Z/jSvyI6EN1DU/ah9qoM0y2gC+QsViqjlZt RZH25kV9ZIAu1EdyaCf3/i1aDZFBo4lFIq1WC3eRvve1D4Igi8Ui7euZPHysfvUBxNK4/M+Lchdh cj9D536Gyl5cmrUsK9vteVUkgnyonbi3HbeNgo1smWuIgIbszyof7b88ODhoGhm0HF1jL1k61pD5 +ur/d8Nut+u0avUExkyOhhDLrF3XbIqpVzp2gA2il0AYdz06cKITw+NyDAbD23iB4BwAALBYLFqt Wi4VCXgzvIlW3iCa11PK68zld2TAJmx/Jm++qan/QkvcacCGWFCeDsQqK9LdgPJXV0fy6mNpI90S icRsNn90PuiPAPhN/BidBgiCbOM5UOUixVTDi3GjxWKmDXWQ8uMLb+18uGvRLb+fPA/9994n14wi wWseMzglaLFYDHqDXCrnMfiDuNHmpG7CiZaKsJqCVYSCpYRyz1rcdkrT2b7e5LEpJFvQKVXP6GyG N7fR89ukxa4k3IUGYmHKnZD/F1+YrFKpZv8KVtPSaNQyqUQqEUslYqlEIpfL1CqVTqezWCwgCDrt dmvOc0OwhyYxwFzlXo9CPHhAuXuXcvcuJT6+raWFCW/qM5mqTZsqjh6tOnIEGRBQ1N/PiotrjYgo 6ukZtVqtIAjGx1M2bCjs6qLPliDK5br7X9zy8UjdFXGfhG86cgQbHl46Oso1GKxHjhA2bSomElu5 HI5ULBbz+UIuR8Bm81hMDoP+KmOPj3HrawQ56YqrZ9TbQ41BHoaje0wJt81lBVZKo31kyM6ZMQj4 GrHIptUABv1fTK0CBHzHNM0x2GdvrrchSi2pSaYb541H9xg3bzAGexqCPDWRgZKYHYIrZ2aeP56q RtNHRzgslkQshodwWSwWuJTOMQeLxaJWKEQjVH55keTOVfmRPcroMG24nzFgnXxv1GRFKY/WA6Jc BXXXJBLJvCfEalDoBp7ZMV4gxt069MguH32lFrPDAqqnIUETNPIYIgU5EUvMSM+ZxkQWi6HX699t fQNB0N55wYpdLxfNvJg6UIj4ucc8Evx/Rr54q2Qtoe5yp1H/OnGIBT4WvpsAAFAJWaOjo2KV1el0 WrWy0dHRcRrDYHE4TeqxsdHRiWmtyea06abGx0bHaVL9G6bSaDQaNBqNRqM5HM68+hyVStXV1ZWf n0+n01/8Q71ez2QyBwcHOzs7h4aGWCzWSyv4NRpNYWEhiUTi8Xjzji8UCkkkUmlp6du3FizwoQEB QMGbppTEpR5cdi/0Vwlb/vvhls8Tw5YmhazL2nmmKCqzwKu8yB1f5EYo9SdijzU053SMd09yZ7gK hcIol1mHB81Zz4xHdukjA1Vbg+UxO3h3r03jMOyxUalEYjAYbDbb69wXCIRsOsgogjQMSDXxtWlZ oOOb1ToDAKAR8DlFedMHdg96b6zz3Fm9LRZztAB9ilgZQyiJROf5lTxdnpC85MaTNbFp3g8yfJMz NzxJ80l86h6bvOrKTZfNVXlZUgHf8iDWdmOZHuFNG2yxfph6awiC7DabTsHXdSXYMd5gtTfQEuMY SwcEFFDSDUq6QXEHyCGCU4VQ2wkQvUZKOj493AxrgH6bF4X9SKvVChe2wpohs+h0OpVSoZDwpDya mDkonOrk0br4DKqIS5dIRAaD4T3q8yzwt4NdJ7LXbrcSt+gk0y96Vw6Hw2g0qtUqJm20tvjR471L 7m345/zdy/rLn8i4dOBNe7Gzj7TRaFQpVAK6kNbO6MweIF9qxR5srNpUV+5PLvYglq4lV/jUoUOb ag93Ui4PDD6njRYwJitmmGS+oFsmHVEpJjSKCQ2/XYrd1FKxiUztHUr/yid575Ix6uCLi8BsNcg8 kfivr7cGb4gK5N08ra0MIMXtCw/N37Ahf+vW0q1by0JCiv39i7Kyevh89c2bzevX59fV9fT3s7Zu rTx8GB0cXHrhAobH+7rpaHxcHB1dFRRUgsONGwxmGk1+7BjB1zfv5snYviQXMeFEd1N7RETZmTOE nJw+b++8jIx6kUgEp1Xntru8BrvdDt86nVIpmxiTlBbIL59SHdqh3hGmjQo0RAUao8OMe7YYD2wz zbN9UaZdEcZtwfqoIE1UoGp7iGJvlOzYXvGlU5wHscyCHGYtid3dyZucEAsEcA/AWwr7wlVwJpNJ o1bLZ2ZEoyOC3h5eUz2zp1ssFlsnSx2oNcxezItCWBAEWcxGNX/E0HzKgV4HYj1AcjjQcQYYSgSo jwHqY3AgDuw6D1FinDXhULWXA+1uRvkoiQdYlDTWaJtQwDObv9XQLjuvCUC5yoZKXwx0QRCcGe9/ sPU/nm38Ld7/ZuFywlQTcyGP+iPguwkAHGIW5ejmjdl1Qsiixzw6f+ZB0rkjh3MJA215d49fv3/t 9KFH5e0D+KdHT92PvXj8agbhjRksCIJGRkZKSkpyc3OJRGJbW1tDQ0NFRUVGRkZ9ff2Le/Mmk6m+ vj43NxeDwbS0tHR3dzc3N6NQqIyMjPb29hfDAJvN1t/fX1xcnJOTg8PhGhsb8Xh8Tk5OYWHhwMDA B/KrFvhGQCBo0Ru4w0PkB/ezwo8/djn4dPXZDPeEooCy0gBsiS++yJVQsBJf7EVE7qutSaD0YAbH +yb5fL5KpTIbDHapxEbGmS9/ZdgSoIkMEJw/ySjMpTfVz0xOwDUqc4dVzX1Vp8PstGkhsxwSd4AT Wc6us1DTbogcClb7Aph1sIE4P3vHOTuvGbBoIeht/U5YS0fFnhFVlAgO7xKEeAu2BvMvn+HUkpnj Y/0dFEz+o8TDnlcCPrm04WdXAj65GvTLy/7/+/LGn18P/W3q5Z2j1CHT5Jhx83pH9udS/AEuh/1B XV4Igsxmk4ZFUVJuGnBbANQaALECqFoOmwOx0o50saHWcRtiGbRRtVr9Hfjf8+pcZ3U5F3b9F3hn IBA08zsh5HJ9+02j4ZUCpiAIms1m5uQw+unFB5v/4+6Gf0rZ9Sfs4y8E00M2y1tVisJPL+w+wlJa Qq5wZoQz3kQbQI40JXcRTjdXRdWWeJKK3YhFawhFLoTCVYSClfhiN1KpB7nUg1zsSiz2ILSVd/U3 IO+GfoJMvSaVSt/88IMgZLNCBj3ImVGWlNWHH8JEnyl9nH/v4Glfz/R9+8rQ6I6pKRadzh4YoN+7 1+Dpmbd9e5WfX0FKSo1QKLTZbGj0qLt7rqtrdnl56+yXLwiCVCr32DGsn1/BqVOksLCysLCigoLG MeqQuC0JqFpuI23Ov5ew1i3Lyyv/wgUMjcZ454Yl558rFVUqlZg9Ixzs59fXCDAIfm6G8OE93r0b 84z74C477clMcT4bg5ipJc90dbDHRnkcjvjPCj/w8L5Xevygw+kwOa1qyMAHFVRQPQXquKBJBjn+ asTybAAD9+IDZhVUv12D3cyepr7KewYAQK9VKegUWXeauva4FeNrR7nBZkN7GrFBmuqtUuIxbnMS pw8xM9bO43GVSqXJZPr2egaAUQrURmprDs2rdps9sa7qnLjgn5d6/Kn882zcgRaFQPkx5vQWmMt3 VgIkvLhtY3ad0KCYPh29Edmnbcu5sfWr+FuHQzNraROYlO37r94+tyOurIPeU7R328WX7N6/Ar1e Pz093dfXNzo6KhQKX/pEcjiclJSUrq4u+FM9FzgwyMzMlEqlrzo+i8UaHR1lMpkfi3z1jx6NlDfW hGtJqqyIzM9alp23CJv3OS7fHVvoX122mYA8UFN9qpF0vaUxpaMHNzA1MS0UCpVK5Z/38h0Al21N TzHu2mQIWCs+vJuZnT7V2cHj8dRq9WvaeSGrGuQ3QsMPQMoRiBTiRC5zVn7qQKzQokOk+Bhh3RU+ 5RGvI5Pfmc3vzJZT7lqwG52VnwI1WxwD9x38JsCifcvlEu6+VSqVotZmyaME1a5NxsB1hnMn9KRq g1KhUqnGelta8cWNyKy6sqeNqJze1top2oRAINCKRObYK/o9Hs7yRcymp9+0AebdcDgcBoNBLpeL 2SMCKpE7gOEOYDiD1WxqA2u8h8WYEgqFJtPLc9kLLPBRAACAeeAxgHLVjlW83tOCIMhkMjEmRmuS ruaF//ddn5/EBv2s/Hb0ZBfZYvrGs8DnjpiABWHkcjmfy2dMMqeH6RPdtJGm8X4stbN4oC27F7Ye 3CCPy8m/GJS4809DPW1wlxrkcAB8rr29xVZDsOGQNmSptbLIWllkrSiyFmZbUpPMty6ZjuxSB/lc WXvZ1SXbxSXbxSXb3S3z7NmSnp5BuKwcVowxGIzl5f0BAUWHD1eOjdFgl91gsNy50xgRUTQ0NDnX iQcAQKXSPn5M8fbOj4mpaGnpk0qlNpvNZjWraUQjcZu6YMWlHWeCfBLaCq+oB3McnBpATgWMEhCw v7MoMOx2w8kBg8Ew2xIwD61Wq9frYdE2m80GX+CrXhGCIMiiBlWTIK8emsyBeq5CTXshvJ9zzkQO CLXS3nHeJux8eVuUwwT13wQQq6bbS9+ohAsAADxDQCwScdlMzgyDM8Ngs9k8Hk8kEslkMni+OJya fodb9KprtFOfAVXLJZyJlx7WYjZVxO665/v3OJdtBUsxfWUjCzuhHzvffQAweWr7RtSAviPvZtRX 928cDsmqm56sfhK9/+rNs9H3y7sYfSX7vkkA8EZoNNrz589FItFregZEItFrYoAFfgg4bDbByER/ Kan88K00j0s5S0tyF6NyfCoL91Ui4qqbCZRx6gSbyRHyhBKxVCFXqFQquNN0tsELMpscPR2W2MvG UG9ldBjnzlUaiTBDpysUCrPZPG/Jg0AHZJJBqgknrw4afQI2H3BiXEHkCjPKS4XfKas7x6M8YvRi GbRhPpcllYiUSgWsyGY2m81ms8loVEr58hG0ru64GeMPIpZD6NVgbSTQeR4YSwc4JFA+BOqF4Gs7 aB0Oh8lolAsEEkSZ6mSMIczHcHC7sRpplogtfwZWxLLb7aDDYc16pg/1Vj7ZZEG4M6mU77JDfbbN cfYzBe++fwi5yQUW+O6xGdX2xv12rLeW1//GRxqCIKPBwB0bHb57FRW8KNnnp3f8//FB1O+q7u3u JxVwJ7r1qrfYmH/FkeeOuYDdXHgdmGWyk3Bz/U+wWffEYrFDLDRfPWuKDjWGeOlDfbSb/dWRgcpt IcroMGV0mGhbuCh6k+zAdsmJ/YIrZzOPJLm5Zt29i6zLutx6zxWZ+5hKHXlRuMlut/P5UgaDDQ8G hv/TYDDR6Sy5/CWzosxmC4cjYLHYWq12dpl1OBxalVxOqxcQTw2nB/DyPUyVbgBipROxxIlcDqFc oGpPiOAPksPAmoivrW4r2LgXaDkCdJ0HBu8DY+kgAwEImkEFFTCI3uc6A4GQVQNqmBC/AaImgY27 IJynE7XCiVwGIlaYUV5aTLiCeFDccJ3Tms7tKeH2VfJ7CpSU25bqIAixHKiJcoykAsJWQM+HIxkn aIdGn0JVS5gNiXwe9+39ZnhdnWW2Xuu9XelfY1fSIdRqTftd0ysyXRLOVMqeT5/4/6ZsWWpVGIE/ /R5EJhb4HvmuAwDQrC2J++JKatb1k0eeVrXVpF45df9ZwuWj93LqWisTTlxKeXT71Lnkqld9Plgs Vs03AYlEJicnczic13j/s8X9cXFxWCz2Gx1/gQ8KkUBC5KKK75eXn6xERGGL1yGzl5TkrkYW+GAy Iovjjz9Mik3OyswqLS1FoVB4PJ5IJJLmQCaTyWRyDYFAys3ujr2uObbXEBkg3bWp5dTxgocPigsL 4b8ikUhkEpFcXUmuSm8uu8NAf6Ej7oJqNkHEAKja045yN6F8lOhNfQUHK55fKslMLCnKraioQCAQ GAwGh8PNvujXL/dnSCQSHo9HIioQhc/wuTeGSo+KUDtMuFALxseOcgex6yDCBhtpCx8T01t+gVzx jEjEv/wmEIk4HA5VWFBz77bgxH79Zn/VwejBaxeIKcnEqkoSiQT/WnfyA+3mjQPHd/PyfVlFgWVF OUQi8bt4kxZY4G8AMpnchE4zoAMMqPU1ZclEwss/rXMhEoloBKIiMaHlxJ760JWFXr9O9vlpXMC/ Jmz+bcqeT58fc0s7H5F2bX/63a+yH90pzn6KKC8i4HFz15B3AI9BJB9cHRv1X5nPU3CIKvapo5qI 9cMnDxEvni2JvV3yIL7kYWLpo+SylMe3TsRu93+8Myj5zrm44qysB/E5/v65W7dmFD67Iy9ZS80O z85Mx2KxLz0feHGbXXzg+wOvwK+6FQQCYd6h4D9BIypKc5+VZSeXZyVUZN6pzrxEyf9ysPjQeNl+ esUedtUuDmInbAJktAyzVYOLNOLCzNgAC9rXhlxnR60FMR4g3l+O29Naeo1YmU7CIV9zD8lkMpmI I+MQZEwxGZlDrkwjVzwjlz+uKU3orLg6jT6pxO911ERBpGAI5+NAuZtQvjLklrGSfa25x3AZZ8ue 3yjNelCan1ZaXFhZWYlCobB/BoPBIEvS20vOaaqjrGhvAO0O4debSVFszJEp5HE7cs1Iwbb83Kzq 6up3fW8/PCQ8C3XYUuVCKn340reSSCTkJZy9HfDTJ16RhcsQxfseopHI7/40PwrGx8c/sFP9HvjO AgDzSBeFJTE7nU6zgtdKobT3DKqNdqdO0tbaSunslWstTouqt62V0tbNVb230Vo4HK6/vx928SVK q1Bme9HkKpvFYrVYLA0NDW1tbe/rpRd4ZwAbaBCZphCclvMD6NCm3CXI7CVVGWtzs3cWIO/hagrq u5t6p6enZTLZizv3fwGCIIsFmJqwpiYb92/VhXhLThyg56TTe3vEYrHRYHBYjZBZAQqawbHnzu4L UNNuEL8eqFpuQ7ppsRFS4mFh/XVe27OZPiRrrIPHmZHJZHq9/g0NwS8DlgPX6XRKpVIi5IgY/aJR kqSvUEa5pybtt6G9AcQKEOdnGcu1W15ZJADrKmrlMhkJpzx3Qrdpg36Lv/HsMdOzJAui1ErEmqLD RF8dnm4jgMhVvKb4j2je6gILfBQAAGAQ9NsJIQ58gJFDARxv1QQJAIBOpRRSmmauX5gOdO/YsIQY 9HnBbreUHZ/Fb/q3uyGf3An62d2Qnyfv+P8yT7iX39raUnx/qqdGLeFZjDrAbnN+wx3W0eaq2KB/ weUlikUSW2ebMdyP8TSJz+Wo1WqNRq/XmwwGs0plRKHGAgOLAwMLAwIKQ0JKcLixL78kBQUVNjZ0 aRrPmJGeU714rfZtqxa/DbOb3HCl09fzEzUaWKlTMQe5XC6VSiUSiUjAEbInhYx+wUSzcBgj7s1T Nl2xYv0BxEoAvwFoPugYfuTgNYGSXlDSC4p7QF49yKgCJzKhoXio+yLUdgJq3gfVRUGkYBC3Hqz2 BrDrAOQqR9UKB9LVgA1V4PeJa87xmhPZvZXMsU4uhy2TyTTw7TOZ4Hqhl/YGgCBosVjUSpmU2ScZ rpJT7miJu2xoDwC5UknYOz3W98Ofg2HViYFqX1P9Qb3q5TInFpOh8Ep4XMgf8tZmVq7KnEFWWb9F 58YC3y8fnwzoN+LZs2cajQYOANIJwPZ454uWRQKMJissLZKRkbEw2fd7xKqzswj8plN9xS6knEXo lMVJ8a5fJe08m5/0qLmpYXJyUiwWw174K6duKeSOrjYbHm3NSzdf+soYsFa9NZh98xINj2WxWAqF wqxXApI+aDILohxxYtyclZ/akK5adIgMHyNsusvqqaJPDHG5XJlMplKpdDodvOK/LxFDOH0PJ+71 er1SqRSLhCJaq77hBFS11NbyhUVBf73j7nA4NBqNaGRYVFogO3dCsTNCF+pj9HdTbQum1ddqhnKd lZ9ODTTMk3NeYIEFvj0AABgkNBshBMR4GKexb1+BDbfKSHt7hPG3xTsiJL4u7E3+jItfjaQ96sZX NFSmYZ9fKbwZnRKz+k7Qv97w/bs7AT99dnBZ1b3dLSXxYxSUkEG1mt6sn2vSKrJPeiTvX5Gb2/Lo YctEzHHp3kja2JjJZKLTlXfutJw/X3vuXO3u3WgXl+zTp1EdHYN9ffTjx7Fubjmennlpzwji9idA xee8+jvvNkH8QzMrWDS7kNrtdrPZrNfr5TKJeIwkb4vTEHbZkGvmTAv51Fn5KVi12IZwMSJ9NOgQ JXabjBAjqTkjbrotan0oaH/K70jndBUxBmsZU+NcLlcikcCtwLMScN/0POFzg8c+iIU8Aa2DOTWm Vqt/+JsyEARZJstAlKtmOP9Vom0Cxsi9sE+ebdpTsATT4XdE2vwShdwFPgp+zAHAzMwMBoOZLfKh ceyHn0DzvP8DjyC2+C+Fy0gkks1mf98n/jeHRWPjt0s7blHLPWtzlyIfL46PddkduyMiJ/56I5lA m5yQyWQmk+n1qyfIZlmznhm3hxjCfNRRgfJdm8XH90/npE/194ime3X0Gjv1KdgSA2HXOhHLLEgP dfU2YcPtqR4Ma2qEz2VKxUKVUmkwGKxWK+zufze7X3DLmlGv1oxW2rHeIMbd3nXFJmh1WF/XMghL 42sUCgmHI6DTOf19rMEBKW8KqI9WYzfPsBgLwxoXWOBDAIKgQTplqdsLIlcZh9Nslm8QaQMAYNTr 5XyekNIseRCriNmhCfXRRKxXXj+nxCBk1CEhj8tmTvU144m594pu7nh6xDU+6g+xwf87NvBf4kJ/ kbT9j8+PrC44H1B8JeyllnF8zdWN/34k+s7atble7ulB7k/SrmbIGq5jUxJDArIDvJMOhV84FHHh 6Obzz65cojVlaabINkGHcqoh9VZy8pcn6Fke5vLlMvxBxnjfRzfjEoIgu91uNBpUCqmYz+KNNrKH yOwhMnu4hjnSyqINcxjjfDZdxGdLRDyZVKRUyDUajU6nMxgMcO+WxWKBRcPe4+IPH8put79m0+qH hsNqsrccs2P9VMKXD3gBQYD4/Py9oN/lemdULk3lbA5TN9d/exmiBb57fswBQFtb22z9j9VqNZut SUhwrvcfneBMxQEm8186ARobG0dGRr7vE/+bAIKcZqVV0q/oSRjDbm4pdK1OXZx2b2nMVR+vxCNR qMJU6vCARCIxGAxvGLgLOEAu25qWYty9SbPdX3T5ILPqGZecw2/IljQna1suWWu2A/gNANrdgvTU 4SLFdZdZnYXssVbezNTsTN/Z/qrv8AbMx2azankD2tZr1mp/AO0G1O9y0IocymnQMX+o+yyzO2E2 m81isTjYZADpwmx5rlQofuCJ5gUW+HgBQdComDG2XwNRLpaumxb1N2uFhGsC9TqdgskQNTeIHyeo D0ZrIwMMuyL0l08bUBWGkWEdn6dWKjtbBx/Hl8Veen7xyM0zO44kndyadT7k+QnP1GNrZy3lkNuZ IPf93oH7vAN3eUVscL/h65N799hzpN+WA/4PfbyzDoTd8fNK278jpTTp8nDRwen8MEaODz/PVVfu ZketBTAeDvQ6fdkaUZ4LF7GL3l40Mz36UexVvwq4pghO6c8CKyXApTtzpx983yf7A8Uq6gOqfSy1 u83SCRB4ye6+mD35eM+ix8FbCpZg2z2OyXdt1rRTfoApowVez485ACASidPT03M7fQfo9j1JfwkA 9ic7x2Zsc3+ho6Oju7v7+z7xHz8OM0DH8Ag72gpXEXKWlT9ceeXKKu/z3n98fH57LaZ0eoqmVCpt tjeNvQQcoJhrLXhsOhNsObfCdn+lKc/ThF5vR68DkKvBqmUAYrkVtU6J2yGou8rpKmSNUDhsllQq hWf6viGu+D4AQVCv1yt4Y4r+bANxK4BcCVR7O9pP2biNgEULQa/9SoYAiHLYgAmenhj+NnLaCyyw wBsBQdCk1+j7n4HIlfb6nRZ+x8vFH990ELvdrtfrZVyOuLFO9CRReWinPszXEBmgOxnTdTdta2TF Otd0L7cML49sd/ec3bsrGhqoQqFoFjabn5jY4Oub7+GR6+WV5+WVFxFelBFfRtsdxdsa3FZSknju 3nrv1MuXy5ub21ksllwuFwl5AsYgb7xZMEISDCAE/WX8vlJ+XylrAM9iTCmVSqvV+kNbGBf4jgEc VuMU2o71BXB+5skK+wtpLhAEGwvv3Vr/s7z1meVryqdDt2p2btJRhxZigI+LH3MAQKFQ4KFds+gM 1gdVf0kCPESC87SAmlARwhAAACAASURBVJqaqFTq933iP2ZAABL3K4i72guWEQqCypIiYs54/duF Db9Iu7q7tYHA5XK1Wu2bk4lWDThTBzZfdmSthEoWOSs/tVcuVyM2yqr3iuquCFqfcDtz2b0IxlAD kzEtEAjkcrler7darT9Ap/9F4A1ClUolnW5XtsebqoOdlZ8CpDDbyHOHhv3KbICkG8K4cZqT32r0 zwIL/IhQKIwMhmKe6fUvT52BIKRUvqGe8C2x2WwaGt6CD4cQyyx98XatYO4r2u0Am61+8cReNDpd TqNJRkZ4vb30DmQd5eajh/6XvFzTdrjeLFob0hEe3nX8ePnxu9v803x9C9LSuiYnJXS6vLOTe+wY wcsr7+JFdFNT/9DQ5NDQJK2tnXt4t2zzxglUlZg1ZEJ4DpZ/NTLyFzVPeIP8pRKiC5XcC8xit9vV wklT3UEQscLcecNsNs/7BaWE+zRmedJm7/wVaOKOMvHuSF10qK6vayEG+Ij4MQcALBYLjUbPc/GH GPadD5zb4537Hzl7afZ5P0WhUAs9AB8ICIDEfYqmM/1FK4lFG1Gpe85e2vi7q0G/zLq2s6u5hs/j 6vX6V7n+kMMEGYSQggrRy8DWY87qdWDFUm32Mlbx5hHkxcG63PGhLg6TJhbyFArF7HgXOO37vdf2 vDPwHACllC8fxerqj9nRHhB6ta37ml3UC9rnL8dQ+xcGTCBjrPvFlXqBBX6sWCwOFGoyPLzc27tg nh07hpNIXjKslEqVBAWV3rvXzOcrv30Y4HA4dHKOtjsBQK0B8Btsoxl2LQ+CICZTdfFi/Ytn9VrL 9/LK9/LK9/DI8/LKPXeusg6BHctK49+6LI7ZKdu0cWK932X30x5rMry98729Czw88gJdHuYcvUPL y1aRcUZKo6m5Tn/qsCoqaAKDFItEVhYBqvqM1o3+bvR8FviRAYKgUacy9cSBKBf1SJndbpv3035y 4Q2/n2Rvul3kRuhJISmP7dXvCNc21S30A3ws/JgDAAAA0tLStFrtvCRAXAW4Pd4ZVw5q9X/l/RuN xpycnAUVoPcOBEBajqHt2lC5V22xL67keE5ctPeVjZ88+yqgCVfKZs/M3/WHIMiidKonIQ4BHHoA UQ4567ZAxEAQvdaSt0iTsph5y7377r4mRE5/bxePx9NoNHBJz8fr678GOCGgVckVzA5N+x071gfE eID10cBAnINbDyrHQfU0JO50IpfzGu6KRO91IM4CC/xQgSCnQmG6fZvi51dw7BgiN7e5uLht1uLj a9evL0ChBuZ1wzsc4O3bLT4+eX5+BQcOYLq7OUqlSau1fBvTaMwSsYI7QJSg96tLPBRVW+rLKrZs qQwJKXrwgFRU1Db3xN7ScLjuqSkGLESj0WikTIaop4uPRU48TKw6fCU96nR6xImMkEOEoHBa2HrJ Jn9NZIA2MlC7ZaNyR/hUeYlQKLRZLVDvdTPSk0mfsi5MbF3gnYAgyKqTOhoP2qr9tRLmvC8Xo06T fzEoIfSzvHX5iM117LZezdnjup0RGlK1feGR+xj4MQcATqcTh8MNDQ3N2+ZvG7XvTXJ2T87f/u/s 7Kyvr/++T/nHhlVnnyiZqfJvKHInYC+Qim5fux72u9hNv0ek3pgcG1Gr1X9x/SHICVghDQMaT4Pq t4Go1WDVUhvSTYMMFz3y4pz+nH50Zc+ZqKbE2E4semx0VCaT/U2VqzocDqPRqOBSld1PtaR9dtRa ELEURKwE0Wsg1Goz0os+TFkIXxf4G0GjsRw+jPP1zY+Lw1OpkyqVyjAHqVS1bx/60CGUWq2Zu0RM TsqDg0tv3aqurh6Miir39y86cAB75Aju21tMDHb/vsqDWx/tD7/j65G6O+Q6Ijudy2bq9XrDOzG3 CQrWCjObzTqdTiKRMJnM6dGR6d6e6Y62mbZWDqWJ01DLqSFy8BhWU4NAILDZbJBJBtVEiAnHxGLx wqbAAu8MBEFm8TCIcjW0XjLp1fN+yp3sjwv/5eOQzQXLcE23e2S0KfXVs/qI9dryQptB/72c8AJv z488ANBqtfn5+RKJZK6jbzJb8+sAte6vvH+hUJicnLzQPfkegUCIR5HgtrfmL8WjYmobq/DPvvS/ 7v/T1K829rQ2iEQii+XPRbqQA1LTIFou1LjbiVhiR7jIcHvZrWn0LjytopB5dA9ng9v4FzG9GNT0 9LRUKjWZTB9FNf+H4OtZM2q1RMQXjdUKeosEnVnC9lR6D0YkFC7kXhf4G4FCYbu4ZBcWNvF4PJPJ NG81gCAIgRj18Mitrx+b+6FITOzYuLGgqalfr9ez2eLExKZz57Bnz2Leo505g4q9XjiQukGR/7mx 5Yz1TZM93oFZ+S+Hw2H/MzabzWazWa1WuAgbknQCqDUz7bkL9T8LfEtAwG6hPgeQqzQT6HmNIiAI UsqTYwN/lRl0p3AFYYJE14hFqqQ4o7+bNjneolR+X+e8wNvwIw8AnE4nm81++vTpvBjAYPor739m ZiY9PZ3L5X7fJ/sjwaq1cRtFNQc6i1YTK7bU1DwjI1Nvx235w/3I/4NKuzk1Of51zY/dACmo0Fgq VL/NiXaxIteq8Du5zY/owxReX6c0O015aKcq1EeyN2qyOJ85OalSqf5m/f55wB4APATHZDIZjUaj 0big/b/A3wgQ5ExM7AgIyJ+cnH7Vro1IpN2xA3H6NE6t/toDFgh0GzcWX7mC5XJ5sPKv0WiSyxUy mfw9mlQql0ikEt6UuifFhvWFMG62/nibcgoEvtPgHKImWZEejNHOhfqfBb49dqvJXr/bhg/UiGjz voINGmXBxeC7wb8vDi6r2Fg7080zatSqrFT9pg26a2eNnFcKVyzwvfPjDwAgCGKz2ampqQMDA7NT gWfRaDS9vb1ZWVl0Ov37PtOPHpPMImiX9cSPVUe1lqwllQbjsXfR+Oz/n737jooq+xcFP2vNzJo1 M++uu+ate+e+38yamffuuq+17baDGAEFJYsC5oyYFTBnUTGiSM6hgCKnIhZVJAmSo+ScCorKOacT av4om1bUbkWkBL+ftf+wqTqnvl1V59T57rP3d4cHnFh33+H/CDm3qaYkh06fUiqVmE6FT7/EK12x PFN19nph4X5ape9oe8nUxDB3dEScmSI7slPkbMW6cGooIWa0tYXD4fx5uwAA8H0Ti9VHj+afOZPJ YDA/VnUERTECodXUNK65eRhBEAzDY2Lara0TyORGiUQy8zT868AwTKVUCKc6pK9uI7lmWMFmpPaC boKCSCZx3ddfYwvT4aUuQvLhyUkaVGUBXw7HcfVUDZZnJq29P6vOBI7jE71NL/b+t4CdVvGrMwtd qwUMoVouF+VlSQ86S08elL9uRaHA1Ddp6ScABmKxmEwmR0ZG5ubmtra2DgwMtLS05ObmhoaGUiiU t38PwGfCUZ1GKRWO1Xbl764krMiNXpESsNrbx/agr5u1z8EVd63/d9+Dy/KiHw309QiFQp1OiysY ePMtnPSbLNdhouLFyOuXE+OjPB5PIZepG2qVl07LHTcxPE4MFOaPjwzz+XyVSgVjWAFYknBcz2BI lUrNZ2X3AwM8W9vk4OBSkUj0F/0C09Mia+ukq1fJTU0Tzc30bdvSPD2zR0bGF6zeJYZhCoVCMFon fuWlzt2MZ65AC7eg1WeQ7lCE1YyqhTii1mOIfr67NnBhH567ZqLCTyD4QB0kAOYARXTapnsoaY1w vGlWVokiSAs18e7m/zHEyTVhdX7F7SaFXKnVakUNtZIjO+W77aUvSxAt3In65nwvCYABgiAjIyOv Xr2iUCg1NTVjY2PGjmjR40z0RrubPrb4b5ErIkJXhN9cu/nCxv98dcs/3XX8h6/r7zHXnfOivLs7 2rhcrlarxRGVfpykzzfVZK0ZL3s62Peax+Op1WoURXGVUpsQpbBexz5xYCAtaXR0VCwWQ11qAJa2 zk62qWnc6dMFnZ30T++rzs7u27QprqSk+a+L3iIIFhRUv2ZNrIlJjIlJjJkZobCwQSwWL/A1MYqi CoWCy+GweosFrx5Ii/Zps9foM37AM1egZGu06jjSFYpw2tH3avvOFY53B2tIpuMdpUrl17/bAL4b WvEkWmSvKDksk8xOLHVaLTXG677tP0W6XE34pbDmWZtKrkJRVDIxLr50Rr7NQhroo+ZzIR39pnxf CQCYX1I+M/7S5scWy6JXRhOtc7PCs+qqyrvam/o6Wwd7OsZHh1gMhlAoVCqVGIbi0gm8/jyW/TuP 7DbQVsaYpiuVb5bjQQd61Tc8pU5bxn0eDLe18ni8v18GGACwyLFYsiNH8rZvT3R0TLa3T87M7FQq 3+kmRBBMo/lAL8C1a2U7dyYPDQ3/7ax3qVRRXd1LpbZSqa1VVa/p9GljTZXBcVyn0ynkciGXyab1 M7sK2XWBgvLL8qI9mhxzLMcEpW7XdQQg/F7s8xcVfueFlBw8bz2b6jFJG4eqAGAeYRiqHiJhmT+J utLeP46UClnmE9cH9v8W6/I4YWVhU0iXSqbCMEzO5wkig2XO1rJzRxX9vTAc6NsBCQCYI41Slu69 54n1f0SbhCdbkavzamk0mlKpnKlKYZhmh2GYHtXi9HJ9kZUqZxOt/OnoYJdYLDZM58W1Wl05Vem6 S7jXcZBImBgblcvlMGgVgCVPp8MCA5ssLOLT06vq6wcvXSqytCR6e1dMT4sM/QIcjsLXt87Tk9rS MvX2OUEoVDk5Zdy4kcdms/92cCCO4xqNZmax22/hgthQwEej0cjlcpFIxGNNccea+a0EackxJGc9 lr8Rqb2oo5WiciaOfv6lEo7gXf66rDVDbSVQ/wfMO0Ql1ZW7qsnbJIy+948+Ln0s5oLlA7t/I9gE Ja4iNwV3aZQaHMdVUqmwpEjitle+11FGStfCoOtvAyQAYC4QrZoSevGB/T9Fb70X/0tBVUoth8P5 8I+rVoJ3BeIkE1mu/VBTLp1On6nZh8vl2sgghb054/zJvtJiJpMJBSsA+AZ9jevIysqJzZsT793L p9FoGo2GxxOHhdWamsYdO5bb3Ezr7mbv20fauDHO0jLe2jopN7dboXhT7aepaXrLlsSkpOqlMXfL kA+o1WqRUMAbaxbUPlXnbcGzVqBkW6TxNjKUhgoGULUEQzR6DNHjf5fwSEbwfFNm8RX6FA2GUIKv Qc1sxUm/KaouK+SzD0Acx+nDXWEnTbxt/hFrGU78ndwa3avT6vR6PYIgouEh4VV3+TZL6b3rKqgO 9PkQrXy4q7GosLCkvGZKIMO++A2EBADMxWBDkZfF/0DwOEtcW5DrWTo5OfmBq38c1/M68PK9aOZK esnNgb7et5f9Qnu7VJ7HpY4WIy+eDPX2iEQi6PgH4BvU2srIyOhSKudzjRQeT7FjR+bhw2ltbT2G ceqGrvr6+uG9ezPWro3dsCFu587knJyazs6hW7eoJiYxN2+WTE3xcRyPjGy1tyfW1nYtvbq3GIap VCoBl8npKRJV3VTlWuMZP+ozfsAzl2F5ZmjZAbTxNtpPQDgdqO5DfSUYgjff1GWv6e+olclkcIEF vgYURVXdMShptaQ9+v1jEMMw9tRokNvK+zb/JcbGL255QUNwp0quNjwkk8kEWanS3Q5yh43yvCyd Qg7f0k8kYXR4ex60sX7D3mlfSG7DF6b4kACAz6ZVyVNuO704uDzrcF6yRVFLabtM9u6af6ga5zTh DZf1OSayXIeRGgJtfFShULy5Y4iiuhKycq8j/9COvqx0Oo3250MAgG+JUKhydc1fv55QUNA1Xz3K Oh16926ltXVCYWG9QCB4+9hHEGRkhPX0acXt24UtLZ08Hk+j0YhEUgKhwcEheffujLKywaNH89zc MsbHl2yBS8NsAblMKmCOsYbq6W2ZzNpgXsUtafFRRcE2DckMz1mNlO3T9caijDqc24rzO3B+J85t xUcz8TzTqeKbTOZHq6MC8OW0Kqn21UUsZ7WINrsikF6vxzFsargr9KSJt80/Im0fJfxKrvVplwsV hmt9jUol6u4U3rki275Zdt1T2dyA6pZaJv8VaBPunjx1ySs1r7Szd6C9oTI28MHRo6fK+4RfslNI AMBnm+pteOr8r/GeFxN+L6TcrZymT785BWjEuKAX74/Fq45heaYq0qbJsocjXbUsFmumij8uEmrj IuXOW6YvnhkoL2Gz2UuvGw+AJaO0dHTDBsL27Yl792b09dG/PFHHMLysbMzcPN7Xl0KjTX2wB1Eu l7NYbJlM9mZRWxxXq9WvXg0dPJhtZZW4fj3h+XMql7vEK4q8vdifTCYTi8V8PpdDH2IP1/ObIxSU /QhprS57LZKzHs01Q/PMkJwNSLaJLMd2oL1KoVAYO3ywlOE4rub2I0WO6pKDcgH9/SMRx3HaQHvs JWtv23+NtHtAXF1QdrmRPyE0PBNFUTmfz8/JlBzZKdvtIAt6pmFMY9/A/JxvFz7iffXpMEc280Zj OlVzfnRgQcuXnJEhAQCfLd/v9OOt/5a6MzN5S1FHbZdcLtfr9XoFE391Up+1Esv8WZTrNFH+eLCz jslkvj2pF6NPqm9fkluvG33qPdDRAcN+APiWKZU6d3eKi0tSUVGzhUXCrVvFMpn8C/fJYEh37Mg8 dCi1p2fgL65T3880UBSl0TgPH5Zv3BhHoTTNvuv4HTCkBAiCqNVqIZ/LGa6ht2bSm5MYTfH0BsJU Y+JkS/poZ9WnzI0G4AvhOK4cL8OzflLU3FTJPtAPjWEYhz6efHf3Xet/CnY4mbAqn7T9Jaufa/hy 4jiu1WqFw4M8/6cyRwv54R1yUrpOuhRm9XwNON4T6J8ne/dySTReGZ5dBwkAWDjsse7nO/8RefRo 3LKCkmfVLBYLwzC9koWX7dJkb5ioeDHQ1Tw5Ocnj8d5ZwAvHdZR8xS47/kHn/mSioV7Q+90GWi2q 0/19SqBS6b7wF04u1+h00N8AwF959Yq2eTMxLKyUz+cnJrZZWCRERdXTaEI6XTK3NjoquHSpxMaG WF7eNId6/DiOq1Sq8fFJJpMJM1xRFNVqtYYl7ZVKpUql0mg0Wq32W6h0BL4HiE6r7IjEs1bKmn3V qg+sOIHjuEKhIPmd9dryvzy3tyasTkkxpfZkDKtk6pknqFQqXk+34M4Vub2Z7Pg+eRkVgRFB78PF Ty67V/XSZ86YOiU/I8Q7oWrwS26DQgIAPk9p9M0nzv8laX9U4lpyT3OvQqHQK6b1FYfUJPPhGiKT MW2otff2TzsuFmliw+XbNzMunB6sKGexWO+X+UdRvKODdexY/tmz5JaWyY/dGVAotImJnXv2ZD17 VsPhzLHI3cSEyNk5Iz6+RaWaz3mNACwlGIZfvFjs4pLc0tKtVqtFIsWlSxRTU4KNTZKNTfLcmpVV kplZnJ8fhcFgzO06FcdxBEFmnWEAAEahVStUDffRnPXS7pQP5uQ4jsskoqqM4Od7/917y39EmvsR fy8su9jIGxHi2JtDGEVRmVDAK6WKLpyUO22R3b2qamtC/nKNv+9Qdbz33n2Hr93ziY6NjQrzv3Dy yMFTtwZ5X5TtQwIAPoNKLnq+8x/hp7el2pGz3Yqnp6YRBVdb7SFNXddTThgdGReLFUqlTqX6s2lo NPW9a9Ltm0f8no50dQoEQrV69tW/UqnLzu6ztU3eti3Jzi5x27bU7OxOoVDx9n6USh2TKbtzp2Lj xridO1MsLBLOni3o6ppGkHfXJEfxt7d6E4Pmz4NEKtVcvly6YQPBwSGpvn4YxiCB7w2O69Xq2cfI +62jg2lpSXz+nGq4y4fj+NgYl0CoCw19+SUtIaG6r29YrYbcG4ClQCPnq6s90ZwN0tFyBPnwfTm1 WjXYVh1+1vTuln8J2Hw6ziQ906ZsiDKhlr0pZmWY+C6epnPTkiQHneW77RUPb6s72tAP3VhY9DBE xGMzGBz1m4EMuELEY3OFOlSvkYsZDIbh37NoZOzUkPuuB/ftcHbeuXvvyQt3StvHv7AXBBIA8Bl6 KjMf2P2n7AdhxFXkysh6kUg01dXw9OTF0wdenDyZ7elZdPFi8azms8NnxMFuMDJkfHxcoVC0tzO8 vat7ev4sUsHjKW7ceGlmFn/6dEZtbXt7+8jFi4Vr1sQePZr79n48PalOTukWFvEBAdSurn4qtdve PsnOLik3t2em40Gl0sXHd1y6VDIrhnv3KkZG3gw9zMjoNTGJ8fWlODmluLpmczgCo72bACw4HMfr 6qYuX559jLzf9uzJdnAg1tR0zIzUxzBMoVBIv5hKpYL+ewCWBhzHVfwxHXUnkmsqn6j5WJ8aiqJc Fj0n4LyX9f/62HotYWNcwi/kimvNouk/7+QbagELRoc50SGS3Q5yx03yh7dUne1LrZ9OI2/ICtxm 7VYvUer1elTL8ffct//so5EpUfxTz+t37h47fL5i9ENXJjgm5TN6uzqHJqaV2nl4TyABAJ8Kx/GX 8fd8dv9X0unMxHXkzobu4uLBnc7JmzeF7NmTcOhQ2uHD6X+2Q2mHbAP3r75nuSZkl11kVmadQCDJ zOy1t08xMyPY2iYnJ7eLxcquLvb+/aQtW+J9fIp6egYkEolOp2OzhSEhNa6ume/s8HD6iRNZJFLN 5CRdpVJpNNrOTtqpU3mbNyc8elTJ4UjGx0W3br00M4vbvTvl7a0OHUq3tU3cujWFTO5raaFv357m 7p41ODhMInVaWiZERNRBZyT4TkilmtDQ5i1bEp2dk2YdXB9soaFl9JkaXwAA8CEYhirYfTqyPVJg Lae9+tgZA8dxuUzSQE7wP/Lzbct/DrW6Gr8qO9uhvDdrdOZWgF6vxzBMKZfzhod4EYHig85yZ2uZ 901lZzu6hKb9KAZLdhoSAFTTnB105vTpQx6P2jqqTu3Y8XJQE+t19GZ0yTsb4OP+N97nlVTTA5OA wUJAtOoUb1dPp903NyZ72WbfvUuxtkrYb3cn4uHt+vqW0dHJsbGpN214fDg5pW+7XePB/dEBGbt2 pVpZEU+cyLewSPDwyC4sbLxwodDSMuH48Twbm+Q9e1IyMl5NTEwqFG/qBBsmBk1OMv7c4djU2NgU jUbn8/kzdQMxDGMw+P7+1ZaWCUeO5Dg5pTs4EIODizs7B9/eanR0qqFh6PTpPAuLhO3b0xwciC9f tkgkErlc9ehR5aZN8fHxLYWFg0VFQ11d7xTPnp6Wvn7NkMvVf9FbqdOh/f3cwUHu+5OScVwvFKra 2hhi8QemO38NOI6z2fLXr5lyOSyo/C3CcT2NJuruZqlUfzXLTaNBurvZNJrwgzPduVxFW9u0QvHn RywSqauqJsjkob9uubn9np5US8uEa9dyGxo63zlgP9JYLLYKRuICAP4OhqHy6VaEbKcj28kna/+i 10Cr1UwMvE55cMjb/l8eWa6LWBtAXFVAPVlHb2RpVbq3dogpFAp+Xy83KkR8ZKdsl538sZe6sw39 UPmQRWcmAeAMUs+du54Sdv/AiesllaSjjvvqp/XpPqeuhr97TY4PXj/wvqOBlNZFlQDguFajUiqV SqVSpdbodBrDvzU6VI+hKqVSqVTpUChh9i1SycU3jl5abRK1dlX0+nWxpqaEW8eu1/hsaC5PFYlE 2AwE0RTmyFxsmMcP9FRXMZnM3t7J27eLrawSnj0r6u7uF4lEXK4oKqre3j7p9OmMurp2Dofzfjlw Q827WWYd+TiOy2SK4uIeJ6eUAwdSc3Lq6HS6Wq2etRWCICyW4PnzCltbYnR02cwqORMT/N27M0xN CRs2EDZsIFhZJaamvhaLlSiKv37N2rMn29Q07u7dcjpd+MEzjlqNEgivLS2JtrZJOTndcvmfdxIw DO/sZB8/XrB+fezly9SxsQ9kCPMLw/CaGtqBAznr1xO8vStYLBGGLfqz5FKCohiFMuzsnGFuHu/r +0oq/fDPGJ+vfPGifuPGhO3b0yorRzSad44LjQa9dq1s48b4J0+qGAwRjuNTU5LLl0vWrYs1fIf/ utnbE2NiyoaGRqVSKYqi7x9f71uotwcAsLhhGCafrEcKbJB8CwW9EUU/Oj/VsCRwfWF84NFf72z+ z76b9xHWpCatLaq+08obEmDIn6cdFEWVSiV/aJATHSre6yh3sZLfv6FqqkPkcv1iTgNmEgDpZH9Z WUnsiyt7jniQK5pundiVVFh7+4RreHnXu1uoGbT3TXIlX7Tix4InADpVSwkpISHh8vFdR++EV2Q9 2Xv0YkRsck3P1ERd8vFjl9xPuj3NrFmgYMDnEPEF2zbetvkl/Paa8OSo/PraZlqc+WTW/vGxkT8L eqCojpSmsDebvni6v6nRUOkfx3GlUjkxMclkMmeG/2o0GgaDTaPRZDLZF15nIAjC5fInJiaEQuHH SosY1hIaH5+anp7WaN70nmIYxmLxm5v7Ght7qqo6vbyK16yJPX+e/Px5rZlZ/IEDqd7eRZs3E52c 0l6+HKLRRHS6eKa1tzNPnSKbm8ddukS6dCnfxCTm1q3Sri4GnS4eHxckJXVt3pzo6Jj46BHFzi7R 0TElK6tzclJEp4sZDMnHeke0WpTBkLz9Kh9sDIZErX7nZqhSqQsLazEzi9+zJ8Xbm7JpU/zevZlV VSPf4OANrRZ9e062UWAYLpNp3r7+xjBcKlV/7Huo0SDvzzVXq3Wf3hElFKpevKgzMYk5fjzj1i2y uXnc0aM5lZUjU1N/fqxTU+Lm5ul9+0jm5oTbt/Pd3LLNzeN8fKp5PKnhhTAMT0/vWbMmxt09e9Om +J07M6KimhwcUhwciMHBJfX1XY2NPX/duroG2Gw2jHkDAHwNKIrKmV0a6m40Z618hPLXtXp1Oh2H SS+Oe/ho+/95Z/O/+Zkfj/0tLXFVUd3jDv6I6O2zMYZharWaT5vgEmOEbnsVVmvlJw8oUxO0kxOL tJNCyx9JT8iZfPM7jrOG6nPIVSKlntlXn5CQkFFQKZw9+ZmVHv6+6JKOL5oHbJwhQNKJuqvnLhf3 TjZlPTni/uBlGETorwAAIABJREFUY79MJo26eeR+QlV3RczhA7fHFzIa8Gk6m7vXmoQe/TE44Uj2 6MiocqxYm/HLaA1BIPhjtopGrU1LUGzdOHnr8nB7q1gsnjk4cRxHUXTW9aihb35ebucZigP+7a5Q FJ2VIRiWIzGQSGTJyS3btqWYmxNu3Mhtb+/hcLiNjSNubjnm5vGWlsS3m7l5vL09MT6+YmRkjMsV xMc3OjgkbdwYb2lJtLAgbtwYf+VKTm1tO4fD7eyknTuXv2FDnGHDLVsSr10rmZjgzzpz0Whid3eK pWXirBf6YLt4kTI4+Ga5n8FB/qlTZAuL+Pv3C5qbu3k8XkPDyKFD2Zs3E2NimkUixbdzw7S2dvLA gZxjx/LeL9+0YNRq5PHjGlfX3PFxzsxHUFg4tG1bWnR0k0j0ToeKTofV10/t20c6fbqwvZ1u+AKP jQlv3Ch3ckrPy+ud1UP/QS0t04cO5W7eHO/nR+nuHuDx+BUV/U5OqWZms79UZmbx+/alZmbWTExM stn8Fy+qNm9OOHo0p7OTjiBodzfHwSH1/Pns3t6hysp+V1fSunWxJ05klJc3M5lMtVqt/QSL9PcS ALAoYBgq50+pXp5Ac9erOsK0yr+q1o3juFqlHB/oSH/i5r31X29v+keA2XnC7+mpZsU13u2cXj76 1s8EhmFqlUo4TWdTCvg3L0h22StcrOSPvdSNdYjksxcVWVxwvOe0nf3W2Vye5DYYawiQRsCXzOk3 XJ3z7IJXRJEaxaU8em9zyfUTJyNyGl9c2P08s2miI/Xo7mvDc9kt+LoiAqlrVkXd+vfQouAyIY+N N1yR5dqN9bW86VDU6bSJMXJnK9q9myOdHVKpdNFdauA4rlZrOjtpVGrb8PCYTCYzJAxTU9zU1Mbo 6Mq3W0xMZVVVG5PJUqvVhtsLTU2jcXE1hkfT02v7+4ckEgmGYSiKTk/zs7NbDQ89eEDdsoV46FB2 RcWISKRUKLRisbq4eHTv3mw7O+LDh+RZL/R+e/asxMkpxdExtbh4ICenb9euTAcHYlzcy5GRMcPt FARBhodZDx+WW1jEX7xI6e9nyWQahUL7iU2tnt1Dr9Ohn775BxuPp4iP77CzS3FySnJySrazS87M 7OTz5YZH378ngCCzh3vNOQalUov+MaoQw/DCwiFz87gNGwg+PhUSiVyv14+MCFxcMhwciJs2xV+6 RBkYePN28fnKmJh2K6ukXbuS7e2TXFzSMjM7KyrGXFwy7OyIe/akWlom+PvXjI/zP/bSAoEyObnb 0TF1x47klJSqqakphUKBYZhOp+vvpycnN8z6ZGNjqxobO7lcruFKXSqVFxV179mTYWublJTUfvp0 4datxJqaNqlUqtPpaDROYWFbZ+fAX9z4AgCABYbjuFzIUFZfxEgm6rprahnnr6/OMQyTiIVdddSk e/u8t/6rl9ky/3UXon4mpm0qqfV+zerkaRR/lg7HMEyr1Ur4PG5TAyfkhfiwi2yHjcLjmDIzRceg Y++NJV4acLzH93Fcx+AsQwzhFy2I/iUJwHBMeN4HFoD+O6LRkt17TreOi/R6PYpo1cKhB6cPP0l8 VRhy+fzT1MywO8evhX9sPeixsbFiYAyFhcX79yVZ/xLweHl4+JOo8vxEfY7Jq8j9KSkpFAqluLi4 Mzpc6rSl6tCumIhwEolk+ONiVFRUlJubW1BQQKVSDX+hUqn5+fnZ78nJySGTybM2NDxEIpHy8/M/ uIfMzKxHj6KsrSM2bUo4fjzfw4Ny/HiBmVmctXXQnTu+iYmJWVlZ77/WLD4+sXZ2YRs2xK1dG2tn F3D3rl9ycvLbMVMolKwskrt7sJlZ9LZtqWfPFnl4UD6x3bhBTU8vnNlVQQH19u3yT9/8g+3AgZw1 a2JcXHyfPQsOCIhxdAwxN49zdc01PHrrFjU1tbCoiGJ4r4jEEi+vitjYosLCN29vVhb13r2yub20 pyfVz4+al1dIpVLT0qiOjsk2NkEHDwZaWMT7+mYVFpJPniSZm0fcuhVw7lyQubnh7SJ7eFAOHCCZ mcVu3/7c1zfE1zdq+/bQdesIpqZxVlaBN268iIggHDkSuH59rItLurv7h1/68OHcNWtitm9/8fhx YEpKSmFh4dsf0My35W25ublFRUUzXyoymRwSQnR0DFm/Pnb9+qhz5/xSU1MNT6BQKHl5efn5+Yv3 WAMALElUKjU3K6U2+qA2faWcsr+GHE+hFP31JmQyOSszM+Dh9Tt7frtl9Z/umP+7z69Ho5YnJa8p Kj5bT40sI+eRqZQ/f1LJZHJubm5qZCTJ82z3rq1yOzP5QSfRY6/XCQRKXh7V2GfF3t7ez786/igc 7wkLp3zReP8PMUICwBlqyqTUKzR6vV433FIcRyAkZ1M4Mr1eRs9MiCckpHXSoTT7N6e/n7vZgnBk +fPILWlDHcPaiWJ9xg9DrcUymUyv1+MiodJtD/v04aH2tpliPuBjUBSdnub5+1d5eOS4u5Pc3Ul+ fsWdnb2GKROfsgcMw0QiSWRkbXh4WU/PgFgs/uCGOp2uu5vm5UU1vMqntJMnszZujLt2jWKo/q7V ogEBjebmcSdOZH76Tt5vnp6kuLiXo6Nv7qtIpbLExCZPz1x3d9KZM9k2NkQHh2QSqUsmUyUldVla Es3NCaamcS9evOJyJW1tTBeXjE2b4o4fn0sMhw+nm5nFnTtXODjI9vSk2tsTS0sbp6e5x47lurik +vvXrFsXGxVVymQyNRpNT8/knTtv3i4PDxKRWDk2NiaXy1EU5fPFSUnNL16UdHf3GTrd1Wp1aWnv 1auFf/Hq0dHlQ0MjX3JDDMMwmUxOJDaHhpaPj4+/P10eAAC+QVqNRjxaheRtwnLXqfqSdJq/v4JF UVShUIwNdBXFPnzh+us1039+ZOIU+lNg3LKCXJfKDsKgiPbOudQwiFciFrNam7l+T0QHnRU262UH nRQxYZqeTlSzRArifYsJwNOLtwIjZoksbBxYOsVawR9iY9vXmwRfWXYzeX/+5PgU0hGozVozPtyr 1Wr1CKIOfi52senPz+HzZw9tBx+EYZhCoWSxuEwmh8nk8Hg8w+CQT9+DYdyRUChSKpV/sSGGYRKJ lMXiGF7obxuDwYmNbTIzi8vOfq3RaCsrx01N4x4/LhwaGv3EPXysCQQCw3ApQ2BqtYbL5Rseam8f d3cv2Lgx3sUlfdOm+OvX8169an/6tGLzZqKzc9rGjQlHjqTl59eNjdHm8Lp0Ois1tdXePsnaOsnc PC4kpITBYCAI0t5Ot7dPXrs21tMzu69vyFDvEkVRsfjPt0soFM7EbHjDBQLh22+4TqcTCESf/n89 Z2q1RigUKpdECTwAwHcCRREpo1tR6YGRVmsrT2kEYxj2951cGIapVErW9GRjSTrh5u4Hjv/da9U6 /5W3Yn5OTllPrbrROlXHUkn+LORgmASokMn4ExNMaiHv3nXRvm1ypy1yj2PKtETtYP8iLx6KsMca ytuG573v54sSgJsH9u3ZO8v+J6nVUGNiidFoEFfXPKtV158sf5Z3uYzDmsZqzglznRj0CRRBkOZ6 xTaLMb+nUxMT0D35Wb683uInntQ+peDjDD5f5u5OdnJKefly4NChnP37Uzs7++Ry+Wft5IPeD97w d8M0ibCw2l27UkNDS/v7hyUSiUQiLyjoOnw469q13ObmLh6Pp9Pp5va6KpWmvX38xInc69fz+voG Ddf6Wq2OSGzduze9vr5dLBa//Vsys+H7by+O4+/Xov2s/+s5m8ddAQDAwsAwTC7mSl9H6fLMkSJ7 9WAaohR94oZarVYkFPS11ZBCrvvsW3nX/Nenvx4K/zGKuDq/8MCrTsKgaEKiUyJvb6LRaKQiEbfz NTs5gX/hlHSHjWzvVsXls6o0onaoH5VJ8cV3IpVTwsPmc0TRH74oAQj3Teh+rzApWyRbdO8u+Gud newtmxN2/+4Q9ENiqf8rMWsEL3FhUT25XA4q4Ks8j3OO7h583S6Xy40dKZgHOI4PDbEtLROsrIgW FnEk0iuBQPC1rz4N/etTU9MsFmumVqxOp+NweFNTU19eKxZFUR5PODVFl0qlb9+FmJyk8/n8b7Be KgAALA04jms1GhGtVUndj2X/qqs4pub0YB9fKGAWFEVVKhWdNlqVExN+0f7Wpn94r7IO/OlB7PLs lA3U8gtNw0WTSpEKf2vpGxRF1Wq1gMdjNjUwCRG8c26yrRvl2y0Vl88qk+O0I0OYVrt4VhL4JhOA uc0BAIuOv3/DhlWPT/9qHvnfs+tIzfLpNizPlF4TLJFIdNUvZQ4b+7PShcIPL1wKFiMMw5KTX5ub x/n5UaamphasyMz7ne6G/vX5untrWJVi1ivC9xYAAL42DMOkUqmoK0VTYItn/ayrv6XldPzFemGz 4Diu0+lkMtnoQHdh7EP/k6Y3zP/fR7/uDl7hG7ssJ3k99dXddlo1Q6N4ZxiCIXkQiUTMvh5mcjzv yjmJk5XCZr385EFlfKSmsx1RzS65/+35FhMAZimlCbp8lzyJRGNlleS43vWOiSPhx7yu5h7VSBGa 9etoc45SKlV5XeG77h4ZHIDBP0uMQqFuaRkeGRlXKr/98yMAAIBFQKNRS9gj4gZfbd5mLHe9ruaC ltGAIp86W9ewppBKpeQw6d3NVekvLjw/uOGeucnTlW5hP4YSf88nbato9u9hveap350kYLgnIOZy Ob3dzPRk/vXz4n2Ocmcr+fH9yqhgTWsTwmFj32g95W8xAdB3VZA7GW/GcpEJj2/cuHHz1p2awU8a 3QUWBRzH09K6N24kuJn+8NzkLNGsYGx4XPs6UJe9ZqSvXdXTpdizddzfh8P5m0K/YDHSarUajQY+ WQAAAPMFwzCVSiWc6hQ3PNPmW6E563U1F7XMJlT7GV3KGIYhCCKXy2mj/Y2lpJRn7j67zB+Y2vj9 fC1yeXzyenLhgZrWkD52J18l0syMDvojf1CJ+Xz26zZWRgr3xgXpbgfZDhvFsb2KR3fUxYW6KRr2 bU0V0A42NbDf+yuilTC5EmOtBKxKCPYbZasM/xF5a7+tra2tnUNA/msYTrtkiMXq/ftJB/eEXrX+ v4J/uZu6g8ygM5DqM7J8x6mpKVVCtHCn3VB5qaFkJAAAAADA38IwTKlUCqb7hQ0vdDmmePavSPUZ 7VQ1qvu80QQYhul0OrlcPj01UUtJi/U6dNdqxf3f7fx+8opZnpGwsrBw/6uWoF52Jx9B0JnuLEMm oNFoREIhu793OieT9fiu4KCzwma93MVKcfmMkhCu6e5ANOpvdqqAmFsXk11nrJWAJ2KCUrnv3rfR cRsCCGVQBWjJKCgYNDGJCXr4/J71f438JSTvfBlnehwrsmVRPNiTk4qDztM3LkxOTsIcSgAAAAB8 FhzHNRqNgEUTtoSrChz1GT8gxTu1/UmIeOxzZ2cZioHK5XLGNL0yNy769j5vp1/urtro9/O1yOVx ccsL0jaWVN1sHcyjiSffWUzAUG5IJpPxuFxGWwuTEMG96iHe7aCwWivfZae4f0OVlart7kCkkm/q frhxE4DRcL8kruadV5dOVfjFlUMCsDSIxeoTJwr370/JCPF6aLmM8HtqmW+NmNaE5ZlNVgfyivJl WzcNZ6WJRDDoCwAAAABzgWGYWqUUcyb4nWkK6gEdaT2eZ6ar8dRNUFEZ47MyAUPdCI1GIxYJx4f7 ainp8V5uT3eZ3d9g6bPydMiKAMLKjHTzktIzDQOkCf6ASKvQzWxoSCGUSqWIw+YM9DMpBeyn9wWn D4t2O8hdrBRHdip9H6lfVSAsxqeXMJonkxEPZvO6fdXXeAmAJPTWuejcOr5YqtHqNCole7Iv/J5H MLkLeoOXhoqKcQuLhKiostibO56Y/xb/W35NUqN8KF9HWkdrSBd4XWG77R3reK1WQ8YHAAAAgLkz XLiL+Eze4EthzUNNgS1KWo1RHZGWBzp2G6YS4p+wiNisHWq1WolEMjrQVUdNT/LxeLZ/04PN5k9X HQ5Z4R+zIjXNglp0uLYtpI/VzlPwVKgWnVn20TBASCKRcGkTzKZ6Bimd/eCW+KCzzNlK7rZXee+6 OiNJ29uFLkwRIXzwxsHZ9u878Nh4CYC+uzh6t9O2Iyc9Hzz2eeB1/dAep637PHoF3+Y0avDZ7tx5 uX17Ultrx6Pt/xJkc4i4qrC9vFPVHqTMNh99mSl2tBgPeMZms6GKIgAAAAC+3JtlfRUKHmuS00US lXsi2av0mSvQYhek/ZmO2TSHIceGTEAul3PYrM7GysL458GeTvcs1nn/ut3vp7sxyzLjVxRmO7ys utY6lE+TcxRvD/UxzDZWq9USiYQ7Mc6gFLKf3ue77ZXZmSqs1gooBRrNp5Yw+gKoXDrb9FiFEYcA 6fW4urOS9ODGeVdXV7fjp7x8Itpp/C8IBnxDUBTbu5fk6Umqp6bd3fw/xTsHJpsXDQ+MaCtPSQuc R2JDJTbr+19Vw+JfAAAAAJhfM4X/OcxJdnuqpOysOneTPmMZlr9R1+KNTL1EFXMpP2ioByqRSOhT kw1luSm+F54ftbhntvnpymNBK3xjlmcl/FSYv6uqxb9nqpalFKrefglDSAqFgs/nM0dHJkupI/19 hqXlF55x5wDwmpp6lTimUUoZdBpTIFRpEUQ3RMpvWoBsCHxtLJbMwSH16RNyxvPTPrv/v0Tb5Mwd xfSpKSTfgktxn7x5kXPIZXxoEMr/AwAAAOBrMIzpV6vVUjGfN9XH7sgSl3uo86zQnDV4oQVae0E3 lIHyujAldw5TBQxzfxlTE10tNUWJgZFXjjx1tn68Zo/fz7fDf4wkrsrPsil/eam5J2mE9ZonYytR BJ3Z3DBGSKVSGWsQhFIy+LJx0FhlQGdWAkbbqFmdEoVer9dpOyJiS42TDYF51d7O3LIlMSayMODo rxEeDkmbCvI8ytgT3XjWzxM5txlHdtG8rrJZLBj/AwAAAICv7Y9x+WLuZDenk8SvuKUusEOyV6N5 pliJC9pwHRklIeIxXPN5VfwxDDMsDiAUCob7OqrJKcnPLvoe2Ppok/2z386F/hgYtTwpcXV+zvaK lxdbuhKGOb0CJU+FqBdwuDs+GXr3fQ/T6/qNdQdgJgFAatKjG4UyPSQASwiFMmxllRAfGn978/+c 8ehB8oai0mevBH35WNbPI2nPOI4Wo4lxEsm3VRULAAAAAEubYbqwTCbjc1msgSpOY6Sw7LwqxxLP WI6TViHl+9EOP5RegSr5n3uJMrOqAJvN7miszCf4hF7e5b3VzOv3jU9+PhH0o3/sspz4FYVZtuXl nk2dMUNyvnIBroJwvOek9fscHxhvCNDwi9s+mWQymVwQcP9GSAaJTCbn50U+hwRgSQgNbdq2LTHw 6ol71v9beXRZ0rqiupQWaXukJnvdyNML3K2bBhvqof4PAAAAAIzFMENXKpVwOSzWSBO3IVRackKd Y4FnrtBn/YwWOyNtT5AJMiocwpDPu2JBUVSr1UolEiaD0d3eWEgMiL596Ml+83umW5784hqw4mH4 j7HlEcULsBAqjveEhpGlKIqiMkpEaKdOh6KokFVjxDkAw1d3bX8vI7G9CQnAknDpUsnunbGPDq4K OmVWHdyQZEpuo3aomh7JSFtGj21nHj8wMT4O638BAAAAwLgMVfx1Op1SqRQLONzJXnZfGbfOT1bi ps6z0pHW4flmWIkz0uKNjBWg/G5MwcJQ7ad03htmCxjWBxCLRZNjQ53NryjJIYTbp3wPORSmxi/A Ukg43hMWTlHo9Xq9khoZ3o1hemNPApb3tjY3zNbYP8mFq8IlwNk5/fDOp15b/y0z+Ab1Qm2qTVF/ S4+25qIoecuY08aRJ/c5nLlMwAcAAAAA+EpmJvjK5XKRSMiZ6Gb3Ujn1QeLiY9qcjWj2KjR3A1a8 DXt1Bu0OQ5gNqIKL6xQ4/kmXrjMTBsRiMWN6isViLUAZUBzvDY+kKvR6vV7bX1/DwHG9Xi/hNSXm NxmvDChYopRK7Zo1sSd2uN+y+ecaSk7KBmq+58tp2jBSfpjnt3p068ah7HSpVGrsMAEAAAAAPsow rF+pVAqFQhZ9gtFTymqMFlTckOa7IJm/6jOWYXmmaIUr2voIHclG+L2oTv2JnZuGTONrx6/X6/V6 QU/vpO7dP6GIjCv6ojrskACAD+juZpuYxJzdav1k//KG9NaEnwprU5rE3EmsyI55+/fhnfYjTY0L svgFAAAAAMA8MAwTUqlUMplUwOMwJ4cZnYW8V48lxUeVebaGFcfwHBO0fD/S+hAdy8W4r1EFB8dQ I493wHvPbX2fy5PcBrgDAOZZQcGguXncJcdV/m7rqZdfJW8p6m3uV4noeI7JhMdvgx4npmg0mAAA AAAAgEXHMGfAsCiYTCYT8tk8+gBrqJ7VlsqvuielHFLl2WhJ67HcDTjZCivbjTbcQPtiUUYNJh7G 1MLPKjM6Hybj/YMjIiIiwsP8fB5c9Di9y8ne2mb7k7xGSADAfMJxfVBQ07ZtxKtblwUe3ZJuW5Ln Xj49Na0TDuszlg0e+Kk74DmfD0s+AwAAAGDRm5npq1KpZDIZn8dl03rZ/eXslgRu5V0RxVWdZ4Vk r0azfsPyN2Fle9CGq2h/HMJqQLTKhYlQqxJ11ZdGBj67dtH90IH97te8U/PLRzkSYy0EBpYmtRq5 cqXU1TX1psP/E7xnT9yygqqEepFIhE6/0mf80O38e3dRoVz+RSPPAAAAAAC+TSiK/lFgVCoQCNhs 9vRIB6Mzj1MfJCg+I8+1QzN/1mf8IOzOXJh66E35T5y3Ol+6/yKz8OUkV4LNx4gkSADAbCKRat8+ 0uULqfe3/9+hZleJawr7e/rVajU2nIan/dCyc/Nwc6NWqzV2mAAAAAAAXx2O4wiCaLValUolFgl4 rGnm5NBUV8n46JBKtRCl74ca0y+fcjtw5KRvTEpNYwdbqPjyQUiQAIDZmEyZhQXR52HKY8cfI34O yHSjTNOnURTFOv3VhGXNR3dNDPTDBAAAAAAAfG8M44VQFNVoNGq1ekEKAakZE6PdHW01VWUpMUEX z50+4+5571lY8xgHhgCB+dTRwTQxiYkNS3puu5nwc2ZpSJVYLMZxHG+8Kgr4ofWKO3N6eqFKXwEA AAAAfMfwgWsH3rZ/l8t2W2vHB8ZbCAwsTVlZvatXx1CzU0M2XkpYV9BU1aLRaHBEhVe5sR8sa/Z9 zOfzYQkwAAAAAICvj5kW9r6o4o6xxXUHQFked++Yx62g8LiGsWlaOfGE5+Wz7mezXw2yXue5n75y /tzZ0KLWhQoGfICPT62tbUJFflLEOp8kh4LBwUEURXEVDy9xmb62vDk1USaTGTtGAAAAAIDvAY5j H/CFPbFGSACKI6+dfRDTO8VRyoXPz+/yIzXWER8ecvcJuHfsdlRpc1HIYdf7UwsVDZhFp0M9PCiH D6dW5cZFrQ5O3lVAo9H0ej0uncAKt0y4/9RWValULlDdKwAAAACA7xo++sTjfZdiK7oW1xAghDnS UUmKO3n8Eqml46arTXzl+CAlfN+RmzfP73yR3ULrSXfbfW14oaIBs0il6qNH886fJ1VlR8b8FpN6 pJDBYOj1elzYi2at6fMw7evq0ul0f7sfAAAAAADwpfCBizt27Nixw8V5+1bH7Tve/HvXo0U5B0Dc d+XwkaD8usibrt4J1JyAy6e8YhNfeFx6QSLHPTji6S/4yHaTk5PV4Gsik186OSW6uUXFeF+K/ik2 ZCchNze3urq6uzwKSV5efsoyIzW1srLS2GECAAAAAHyLhoaGvsa1s4hd+yKs0DDyRzRWEbbIEgBE 3V6SFR4aHBGfy5Qhmok2/4AAv9CoHppAxx2ICgjyDwyvHmR8bGudTqcEX9PYGGfnzgxv74LC0BdR KwiZVwvpdLpSqVT1p+gSfqi6d2Z8bEyhUBg7TAAAAACAb9FXWitJKRy5efxQRGZRTU1F5KOrz/Kb F1UCAL5tNJrIySk9IKCU7P8i+kdi/qMSgUCg1+ux7iBN/I+VLx4KBAIoAQQAAAAAsJBwVF2XFbBz +1Y7O3vnAyfKezlfsjdIAMA7hof5W7emRERU5Hg/jfkxmRJcLhaL9Xo9Vn9NFr2yMi4GSgABAAAA ABgBpuptqX35sqKld0y32KoAgW9aby/X1jYpIaE646p3zE+pZbFVhit+rGQvJ3BVXTFFo9EYO0YA AAAAADB3kACAd7x+zdyyhZieXpd85k7sr5kVSTVKpRJH1HqK/cQzs7bWVgRBjB0jAAAAAACYu6WT AGi1qFqNQHu7oejs+SHvv0taLfL2mP7GRrqFRXxubmPCoWsEk+waUoNGo8Fk03iBRa/vtv7+fgz7 kjknAAAAAADAyJZIAjA9Lb13r+rKlVJob7eYmFaZTGW4vscwvLx8/ObNl7Oec/162eAga+ayvrJy fNOmOCq1JdrpQvy63EZKi06nw6ab8azVzRFnaDQazAAGAAAAAJgLlbg8Ky7AP35UpcU1smpSYkho SFJBnRTDxlqLg4ODo5PyObKF6GldIgkAnS5+9Kj8+PHMY8cyoBna/v1pGzYQTp8u6Oyki0RKf/+G 9esJ27cnvf2co0czTExi4uNrFQqF4Z0sKBiwtIyvquoIsTiXsDGvrfK1TqfDhsi6xJ8aUh+z2Wzj ftAAAAAAAIuXYrBkp7VbvUSplvKpOeSJ3rJde09m1ZRfdnXOLO/yPnXYv6h1AcJYIgkAjuMikZhO Z01NMaEZGo3GoFK7nZxSbWySnJ3TLS3jfXyK2tp6JycZM88ZG6OvXx/n718mlUoN72RqapeVVUJD Q5e/yVnilvzOxi4EQfDBdGX8T8254TNPAwAAAAAAn2smAdDr9Rgqo0Z7nfMKbm3Lct16oJGhz3h2 5mr4QlyTL5EEQK/X4ziOgXdptdr2dtrly0V79qQmJVWNj9PkcvnbT9BodDY2SQ8eUAy1PvV6fVRU q40NsaWXfEa4AAAgAElEQVSpNeDXS0n2Bb0dvSiKoiXu4gSTRkqaSqUy7qcMAAAAALB4zSQAqE5e ke57wStkjK0Q0uvO7nYp6RaH33D1Sni5AGEsnQQAfBCGYSKRZHh4nMvlvr80HYJgO3dmXL9eKBQK DX/x86u3t09sq38VvPJeinPh0NAQKqTjab+MxDo3Nzd9pcXtAAAAAAC+B4qhsn0OJxulSiG9zeOA 4/nbT8JjUnummLnhtz0vXjpx4kbT5EIsuAQJwHcBRVHsQ9V7UBRzc8tzd8/l8/mGv3h7Vzk7pzRV FoX97Je6r2BsdARt9tUmLa9I8Zuenl7YqAEAAAAAwPyDBOC7hqL4hQtUN7csJpNlKO9z7VrZvn1p tZT0yBXRacfyJ/ubMdKm0XCrxurymYnCAAAAAABg8YIE4LuGYfjduxUHD6aPj9MNtwjOni1yc8us JMXE/Jia4VnIqPTDUn+oDLk6OjqKoqix4wUAAAAAAF8KEoDvGo7jvr61u3alDgxMGBKAw4dzzp7N KkkKiFuWR7qazs3cyvX/pbyocGaWMAAAAAAAWNQgAfiu4bg+Orpt27bE16+HURTFcdzFJfPKldyC UJ+4ZQV5F+5xIn+ofXp0oL8fQRBjBwsAAAAAAOYBJADfu/T0bjs7YkNDH4IgKpVu27Y0L6+CHJ+n ccsKis7soQf/XBoXJRQKYQFgAAAAAIClARKA711h4aC1dUJVVbdOpxMKlQ4OqU+fFmXfexa3rKDU Y9OA74amujqo/gkAAAAAsGRAAvC9q6wc37IlobT0tVarnZ6W2tomBwZQM6/5EpbnVV0xef3Mtq+v D7r/AQAAAACWDEgAvnfNzXRLywQyuU2j0YyM8K2skiLDi9Pd/WJ/yqq98Xv9iwNjY2PGjhEAAAAA AMwbSAC+d729HEtLYnp6g1Kp7O5mb95MJMaVphwLiF2Z1HDr1+rwy3Q63dgxAgAAAACAeQMJwPdu YkJoZZUUHV0lk8mam6c3byamEIuT9gURfotuvLmyOsmHy+UaO0YAAAAAADBvIAH43vH5clvbZH// MqlUWl09YWVFzEwpSdgeFLcmsOHGytqMMIlEYuwYAQAAAADAvIEE4HunUukcHFLv3y8Si8XFxSPW 1kRSakm0pW+C6dPaW7/V5SSpVCpjxwgAAAAAAOYNJADfOwzDduzIvHo1XyAQ5OT029omFGSURqx7 lmRxv+7++gYqWaPRGDtGAAAAAAAwbyABAPqjR/POnMnm8XgpKV329kRK1suwX5+n2tyoeWDZVlcL awADAAAAACwlkAAA/fnz1MOHM9hsdmRk6/btSaXZL8NW+Kdv9ay479DT3Y2iqLEDBAAAAAAA8wYS AKD38qrYuTOVwWD4+tbt3JlckkaOWBGZ7uRWem/P6OgorAIGAAAAALCULHgCgGnaKYRnz/2fPA/r m5b3V6V43X8cEhZd/npSPtny7MHThw+fFrSOLlAwQK/X6/W+vnWOjkljY7R79yr27UulJmRFLU/M 3L2X8vD01NSUsaMDAAAAAADzacETAETT31Q1yRj2OnrIj9TSlPXkjFccV47iOkWGz9krgfllyU8P n3kOlecXUnR0q51dYlfX0OXLxYcPZ1BjkmKWZWXt20b2v8vhcIwdHQAAAAAAmE/GGQLUmB107Lx3 K4M/1VURG+Jz+vilwoZBH88dfqTWyd4Mt93Xhhcymu9eZmaPlVVCQ0PvqVMFJ09mFwZEEpblZ+7d UkwME4vFxo4OAAAAAADMpwVPAFBdVxHhyMVHQwwhZviLevq5x+F70eXJD0/dCCt6le13+MRj5ke2 FggEQ2C+xcVVb9oUm5hYtGtXqptbYtzFh4Rl+Wl71yeH+3d0dBg7OgAAAACARYPNZi/QRfUXWOgE AFGICE8uXbjpHRIeXdExMdBQGBHke/PWo8ZhsXCg4vY1r5vXbyZV93xsc7FYPA7mG4nUvGkTITa2 yMEh0d09LebUg7hlBakH1pCIsQMDA8aODgAAAABg0eDxeAtzUf0loAoQ0Le1MaysiOnp9dbWSffv k1POBMQtK0g5sa65ulKn0xk7OgAAAAAAMJ8gAQD63l6OnV1SXNyr9esJz55Rk91CYpdnpZyz6Gpt hVXAAAAAAACWGEgAgH5kRODomBoYWG5iEhPgT07aFxH9U3zi+e1DAwMYhhk7OgAAAAAAMJ8gAQB6 Ol3i4pJx506RiUlMkG96nGNo9G+hiZcP02g0WAUMAAAAAGCJgQQA6Hk8xb592WfPkkxMYgIehYVv 8CWs9U2+eZHNZkMCAAAAAACwxEACAPQymcbVNW///lQTkxjfa16BPz2MN72f8eyJSCQydmgAAAAA AGCeQQIA9DodeuoUedu2RBOTGO9DJ0N/DEmwOJ0fFyuTyYwdGgAAAAAAmGeQAAA9juOXLpVs2RK/ bl3s1Y07IlfEJ9vaV5YUq1QqY4cGAAAAAADmGSQAQK/X6+/frzIzI5iZRl1beSr2F0Ly1jUtzc1a rdbYcQEAAAAAgHkGCQDQ6/X6gICGtWtjzdcH3F/2ImbN/fQdG4aHhlAUNXZcAAAAAABgnkECAPR6 vZ5AaF+9OsZs1bOH/xEVu/Fg/v4dDAYDFgEAAAAAAFh6IAEAer1en5XVa2ISY/lr4JNloTGmVuVP HwoEAqgBCgAAAACw9EACAPR6vb60dMTEJMZ6ZfiTFQ9j7e2aq6vUarWxgwIAAAAAAPMPEgCg1+v1 TU10E5MY+5/DH/7sEX/ryvT0NHT/AwAAAAAsSZAAAL1erx8Y4JmYxGz7OfyehSs5O0uhUBg7IgAA AAAA8FUsnQQA12hwtQra3Nr4IGvtmljnnwO9XN07Ozth+i8AAAAAwFK1RBIA6Vhn5V3X4qt7oM2t JZ9zXbc60vH3u8HPA3k8nrE/TwAAAAAA8LUskQRgmFwTvzKZsDwT2txa4I/pG3+P3Wp1PzcnV6PR GPvzBAAAAAAAX8sSSQDELFFx9MtEz0yiRwa0ObQ49/Tbx+K87wX09vbC+B8AAAAAgCVsiSQAOI5L JBIOh8MGczU1NTU5OQnVPwEAAAAAvgqVuCwj5umTyCGlBsdUbSUpAf7+EYlFPLlusC7fz98/JCZz WowuQCBLJAEAAAAAAADgG6cYLNlp7VYvUfJodad373nZ2HLh6KHg9LxLh52zK3sfnjn8oqB5AcKA BAAAAAAAAICFMJMATL5K3ON0fgDDw6/vvfj4ievWg01Mfebzs1fDF+KaHBIAAAAAAAAAFsJMAsAa oBx1OdI4TvM+vdc7Iu7cHhdqBz/k2pH7SRULEAYkAAAAAAAAACwE5UiF6w6PFqlSpxKk+V+5cfX6 2asv+hiCotgHl65eO+dxr21avgBhQAIAAAAAAADAd2SRJQDt7e3hH3HhwoWPPfTtg+CN5dKlS6Gh ocaOYo5u3rzp5+dn7CjmyNvb+/Hjx8aOYo58fHzu3r1r7CjmKCAg4Pr168aOYu4W9QkHgjeWRR08 /E4Zy/379588eTKHDauqqox9vfz3FlkC8BfCw8ONHcLcQfDGEhsbq9VqjR3FHOXl5TGZTGNHMUd1 dXVdXV3GjmKOBgcHX758aewo5kggEGRkZBg7irlb1CccCN5YFnXw0dHROp3O2FHMUW5uLovFMnYU c1RbW9vd3W3sKL4WSAC+CRC8sUACYCyQABgLJABGBMEby6IOHhIAY4EEYHFY1Ic3BG8skAAYCyQA xgIJgBFB8MayqIOHBMBYIAFYHBb14Q3BGwskAMYCCYCxQAJgRBC8sSzq4CEBMBZIABaHzMxMY4cw dxC8seTm5i7eE2tVVRWPxzN2FHPU0dExPDxs7CjmiEajNTcvxEqNX4NEIiktLTV2FHO3qE84ELyx LOrgc3JyEAQxdhRzVFlZyefzjR3FHL1+/XpkZMTYUXwtiywBwDH0ZVZ0SHBQCqUTw9EmSnJwSFB0 diWGv3mcN1gXFBwURkid5CmRqc6g4ODAyIQhhti4YRvgONpUnBISHBSfU6fWob2v8oJDgiJSihQa 1PAE8cTryPCQkEhC/7SUP94ZHRaYQG4wbswzcBzrq80LDg6KSSsRKTHJQF1gcHBgTCpTqDQ8QcYc IsaEBoeGtY6JhFP98VHBISEhzSNC3Lhxv4HzB+uDgoPCCCmTPMX7XwyVcDojPiw4OLC6h6USsbKI ESHBgZSmkW8jeL14oiPqjy8Gyh4iRIYFhUe1jXANj+oUovzkiOCQwKLGYRzX6zG0KCkouahRZdyg /yBnDRNjQoNDQ1vHRKhgKj0uMigkpLpn2vDe4oi2NCMyOCQoo+w1hgmzIv2DQ8MIxBzWQhRB/ntv fzEwGY+cHBMUHFTUNIy/iR6tLyQGhwQRcl9hOE7vr4gKCQ2PiGwYYBs5br1e//YXo2EYU8srs+KC QoIzy1+/OVvi2GQjJSgkOCA+R6ERVGYnhYeHBwcGEEnV0m/glhiOznwx2jEMbSkgBoUEx+W9Qt8E jwt7XwUGBwfGpnHEKvlke0RgcEhgeO0A75s4ZnG0npw488UYaywKDQ4JjiEJ/njrdbT2wODgwCji KEuCTnUEBgUHhxGaJ7hGDtsAx6YaqX98MXTsnlfhwSGBEal0pcbwOG+0PTI0IInSrNfrUTEtJSoi KCSyoo9u1KD/gOPC3hrDF4MtVkpp7RFBIYHhxH6e1PC4mDGUEBkYnvlSr9ereLRUQlhIXL7EqCG/ BdfRXgcGBQdGEUeZEpQ/FBUUHBQa20J708ujEDDSY4P8Ewp0/z979x3XVnYmjD9v+yW72ZLN/rLZ TXZT380kmUmbSaZ393HHvYFpxmBcccc2mOaK6ZjeRO/qICQEoosiRBGoIdR77+Xe+/5xbYbBdWZs A/b5fp5/hpEvR/depPOce85zfJDTqKguykxLTSH08eAlcdMjPjknJys9JTN3RKB58MbwOi2kyru3 M8qEJjvstfdiMWlpaYU1VOPSaL1PKyrPz0pJT2eMy31WRVNJbkpqGn6Aj3bOYMhHr89LTi8YlRvQ H3DpDZm5VbKl8T31jS2vBAAWdJbuCjnLaMUHbtvXTKrd4x9B6CYd2bkD28uhNBGGpzgJh7em4Rnp Z0JPJ1dlnT1wtZRUdf1oeHytfbGbjiCIjIUPDAqj0btCt24rwzUdDgqs6+k8s9uvkDTYRSb2ccWZ J7fHFOMwN6OC4ysQBKm7dSQwrnSxW32Pbqb3SMAeYufIyT3bs5pI8ZEBqTj63dP7ou+Shnspbf28 8tigYzfLiEVX957J5vS3tfUP49Oj/M8XWJyL3XQE8ZhUCYe3puE708+iN4Z/bAmx6sbRw3EV4yx6 Sycbn35u/9n0Lmzq3sik0QEGjtpHyjp9PKnKuASeDcBed9ap7TFF2PKbUYGxZZXxIaduYVoKY3Ye y5rm9pAo/V3lt9YHxQ10FAWEnpuQm4QtuZs3bgiLxyyRb7XquOCjN0tJxXF7z2TV34kKPpfWj0vz C00cmRog4tvHyCVf7D/bwagJ9T/cxRuP2r6llrk0ukEIgiAI7e65fWfSunBpeyOTmnLjdwTFsBil u4POd48P4+sIkwzcDv9IchchYvceQt/ApYgIwtASmpHFrr+9Piiuv6M4IPQcriJzvd+JocHG4KAj raNj+KrGqfHBoweDMO30xNCtadhpD4L4nKqbh/dm4MeWQP8fUXSUfrH/DJ1RE+ofRmqu2Lg5jNZL OBYY0Dg0Q2+q7h8YiYk4mEnqzDi+K6agq6Ukdt/5Auy1I6dSmpbA5w2iH8bv9I8kdREidu0mdFLD d/sXEruTjuxMw/Z2tzZ19I2nnT6QUNFSnhB+NK6kIDE8KhXXWn0t4GjyUhipcspGjh4MKkNvDAzu QlhQcn1P1undcUVkZheJMjCDIEjVtbBDSRUI7CNnn4q4UkiuuLU98OpSGON164QxEQEZpM7ME7uv pNfcOht6paSjLC741I3y0SEagTHhhZC2/OitJ1PR13Mb7mzwv7Ik8nUE8dm06acPxJe3lCdGRMaV FCaFn0rB1meeDz6TPsHpwVGZNjcy2py6MijG6fEZlaNNpO5RQvr20PMizeJ3cGCfuyw2+ExKFSE3 eu/J7PrsU+GXC8mVt7cfjOXMDBFaOg12BBknrNpyuF9pdNlkzXWEwa6KoMNnJpVL4U8WIaSfOhSd 1d2YvC3selNJbOCR6wxyqd+e08zpYRKBrDQjiKBrz55Q/KQMQRCjtPfo/m3b95wYXwo3/bewvBIA L6MqJuRUqkAkvhjmFx1zxT/8skCovHNyfw5h1GQwKiR94X6r8GxfX8HlbZEJZ/xXlXTMTjSn7j9y aynMkxhtSw0KvsRRWK9HbomKiQ8KDB8W2suiA+JL2y1Go9HMO7V9ZRFNJcCmrwu/jiyxBGCGVX5w e9iICsm9sOd4fFZkgB92SMkouBR+pVBuNZmskrigTTdrJkw9lSsDLhptLqtgKPpwSGbLsHsJpPcm 1WD41pU4tq+/8Mq2yISz/quK6aIJbNr+iBsSu9lokWed9T+TSfdNtmz0PzExzW/CZJ8MPFTMGHP6 FrvpCOJ1z0btuHdjrA6NjwtdfatuUNFbuXnHmRmnxWhS1tw8FhRb5xP2BYZEYAmk6Ms37saGLpkE QBMfvOlG9bi5t2plwIXEI5vPZpNcPMrWrUeGVBqjQUMturL/dLZeOHkmIgTbN1hy6+ql06du5JOX wiA0ghhzzvufzmj3TbZu9D+ReHJ/4NUyRDEQsOtwK3fWoNf1N985cCROJJTdOH6g8G7eHj+/I6cv Hwk93DKphxa76QhibUg+FhRb6xX2B4ZEJJ477Hfijkc1cTo4rHJgyqAzCAZbDgaF9E/J669Fns9p sSOewca0oOhMg2MJ3PSIq7MUvTE4ZyKCEy+f3hwWo5Lwrh8Py6CwTAbd7CQz/OBOEkvVfvdcZHz5 yHBTRMDeLbsDif2CxW45giC+Efwd/yNxIqHs5vED128lb/OPGBYIG5JPnM0lakwGhVgYdWBNeZd0 tP52QERifV5MwInrOXEnt+48NqZb7LYjiJRFORgU0seRN1yLPBoVsy8osHVESCu9eCwBI7UYTVYX cj8BgH2e9KgdlwupKiFu/5qwicVuOYIgWuFIxMEdRJaKnnM+JOJS2KE95R3cIeLNwydShDaz0eKA kaWbANi0kqgDqzFdUnZD8t6DF6IitqZiR3nM4qB90RyHxWCyQfCXCQCCIB6DOPNc+JUsvNG5+N+y PrczNnh1ShNL0lm6ddeZmKgdlwraVDP4fasPsVw2o8nihb5MABCfc7ilJu784ctpzTrrEhhmQ5C0 U34X89psHNJWv6Px5w8cvlbpsPYfXBlAU6qNRqPH92UCANs1ubGXsvKTAkAC8GJBLEKq/5E4Fmv0 2H6/tOyMvSGnmGz2pZCdJXQBgiA2rfDMgXVlXaL6m8cPXkhLjPBLbR5iFMb4R2XpF7vpCILwekqD go4zJyXn/DcmZuSEBAa3jwlvHdl5u34QQRCfxxwXvC6lcbijOG7rqXRkiSUA8ilS6N4DnRxjUrjf lcyys4f2lNEnsTcijybVmBEEQdyZp3ZG51EmCJnrw+KVHOa1syfTG7oXf1wCQRAEsetmzh5YW8YQ Ndw6EXA+LTHCL6VpqKso9sCpTD2CIIin5lp4WGKVuKdyS/C5KYFYpTH1Vt48ePK2fAl0on0ec3zw ujuNQ50lcVuO38k8veNyfsskLmPTgVg1giCIj5Z/acepTNko0T/4cEpS7InzcVGB27cFX+iTLIHe BOLOitp5Mbd1gpC1/lB8zqXAiKRyVV/Vht2nOSYHgkBjzal+4QnTo4wjIcEtLDmCIDxGScDe0CHp YjccQRDEU3Mt4lBCpbincmvwudyEY7tPphonyLv2RnbN6hEEFnaU7Q49O8QeuRCyu6K8fP++YELn cMop/0sldNdiNx1BfO0Fl3eczJCNkvyDj+bdvvRFYIyG1xUeGNY0KkUQxMDtDgkMbmFO5J31jy3p UkrHzh/aXzMgXvyuBIIgCDSOTd16OGF6lBEZEpSfefOLfVHciYGLYYEFHTwEQayyyajQfZWMqfqE sBPxeamxJzJq2koTIiMuFS6Bb2RY2IHZHXoGvTGKSkv37w0hMNl50SExpR1OBHEZFVfD/TIJrPac 6MBzuQabbnR0uPzm6QORN5VLoC+E3hhk5kT+Of9LSRlhwUGl7ey6m0dOJzeY77/m3hMAyFsVH3wy uYHNKN2x5cRSyL2sMk5U6N4KxlRD4uFjF5LPHQ1IwQ635p+POJ8zNwi4ZBMAl1EZF+6XgWfRc6MD Iq8lnTsQU9LZ05gcEJIw93E4lwB4zOLShLNXspu09iUw2oAgkNeVdmr71WIquzFla0BsZkLIydv1 Y4zSHZuPf3lj3E8AIK9DrlDr2AT/wMO900vikS8mLujYzWoZA7Nhz9mcW8eCLtyd4ZB2rj80YLDd e8X9BEA/0Rp57MyVC4e3bNxTSJle1FZ/W8srAUAcWvHlk8Fnj4cdOp1nMCtvXzxy9NwR//A4lUpe V1TeL5R2V9wIPHE8OCicPCgSEHIPhB8LDg2u6eAvdsMRBEFcJtWdK0fOnIw8GH5TolWX3Dgbcf74 gcCzXJGUXFVBm5wdbc4OORoZFhJSQecjCNJw5/ihRMxit/oej81Ycivq5KkTASGXx+Q6Jib54ImT AQeDaSzhUGtdPXVsilp5KCI8MiwgG8fuzL/it90/ITkTg+tzLoWVSx5nT8XNezcGUyQg5B0IPxYS GlxDn+T0YKsJffy+lvCwQyeO+t/AdM2M0M6eOnc6ZG9cAcW2BPpxCAyNYrNDjkaGhYaUt/Ok9MrQ sCPh4UFZTcMidktlHXV2nBkZGhx1OvhSWpPFjSAIQrp19Mi1yiWQvCAIgvDb798YWLaCSTx6KPzo scCk0g4xt6u8rFkuEp4JDzxx5tDxmHy9Q16ZmRkXFRaVUKVfEo+FEcVwK3pjXC9jqCd7z4YeOnE6 9GJGo0zCwuSWiyWKa2fDj52LCDqapLab6m6ejzh+IXBvKEmoXgrfyRb+4NHQ4KjTwdGpjdpZTsyh 0BMXIo4n5Ck1fExmwbRUi02+HHrm5N6D4RyZi4fP2n342lKYgoKCNMKz4YEnzh46diVPr1XcPnoo 8lxk6OkkldmELcrqGpX2FN8MPHXKPyCEwZrtL7198OSls6EBNzCMJTHoYLp3YwRGJqntpvqbFw4f PXcgIGJEraLWFpF7BVzs3f0Rx4JCghu7uMJBUmbm7cjwwzUdnMVuN4IgCOIyzd0Yk1Jde9H10CPn Aw4EUnmz/aTKetoUgiA1N49E3KhCEFjJxkaGHD1yOPQqZmnse+qxzd0YneOSUdzd4LCzIQEB1X0T E4ymcsKgx4fQimJ2nslAX85rSt8SHLdEEgDE50ZvjOCQ4AYGV9JbGRh44nBwUCaxXzTcUtZItzgR Ni5j3aE4l8cn7C7ZvXFLdGJmXiVOZ10CD0xhSEzDBB+OPHw4KBfHUrJx6I0Ri6HJpzrLa/AaK4JM kL/YETmgMnnM4uvnTsRdiAg5e1tkXBJ/sqoBXOSh8MijgTfKu9Q8+rmwiOORh89kNUuFzEpMlcSA IMIef/9w4tS9SZ7cgaKQA6cnl8B4w7exzBIAAAAAAAAAAAC+DZAAAAAAAAAAAMArBCQAAAAAAAAA APAKAQkAAAAAAAAAALxCQAIAAAAAAAAAAK8QkAAAAAAAAAAAwOIzqcQDbMWCH5o1UpHC8Wx/EUgA AAAAAAAAAODbUnBZFFq/1m5g9TFonQNCIVuocer4bEbviNHrnRjsGpoUuRxSzuRUH4Pe0T9m1ova qR00eo9crRvsodN7JpSz/LZOzgiL77Gopic4w130/jGZQS7kzKjGBjq7hqZhBEEQ2Czl0Nro0zOK 8cFuejtdqHJPMDvaaXRGbw+1lSLUPLkEO0gAAAAAAAAAAODbUotHWqlDFsg8wexsaiTKrQJqe1fv IFsy1tPd1zvCkQ100pjd/UKrcbib2kygyeXjBMYEb6CDNSsb7e9saqZIhdOdfTxWR2v3yCBPrh1k 0IenlUo+q4+lHO/t6GdLYQRBECuzgyK2I04Fr6Of49Tx2kamOlsIPNEMqaWTP9E7yHvyNkYgAQAA AAAAAACAb8mnUwh721qGx7kUancrAS8w27qbK3qmdG6buBZTL3V6lRPtVdheq2SshdZHIrXM8Ifa hnh8ZkcPp4dCpbc0EyYnOJ1MiYE/gGmkG00WwcQIua1fyWf1jSjFPHZLG11vMym1Kh6TymBOK0TC TjpjvK+9c1LeTW2VicVtdKYUJAAAAAAAAAAA8EJAVqNWoVA73U6NSqVSqawOt8NkcHh9MAQZDEYY hg2ysV6OBHE7VEqVSq22W0wmm9NpNVscFo1SoVSpTRa72ep2m6fo/UKX26VVKTUGm8dps1gceo1K pTV5XQ6jxe5zWpUKhcnqtBg0SqXa4UYsJqPb5TKZrG67xep88n70IAEAAAAAAAAAgOfOadBYHJ4n v8ykMdieb0tAAgAAAAAAAAAArxCQAAAAAAAAAADAKwQkAAAAAAAAAADwCgEJAAAAAAAAAAC8QkAC AAAAAAAAAACvEJAAAAAAAAAAAMArBCQAAAAAAAAAAPCiuWeHr8VGp5S2mhHEw2VEnb+UmpZe2cJ8 Ab8aJAAAAAAAAAAA8MJBHnzyiSNxZToEcQ01rDxwRqGzwjD8An4zSAAAAAAAAAAA4IWblwB4pWO5 ubkRhw4WEcETgOcDhmGHw+HxPHknNgAAAAAAAAB4LuYlACjsrSMBF/Oe8y7ACPJKJQAOh4PD4TQ2 NmZkZOTk5GRlZeXm5ra3t6vVagiCFrt1AAAAAAAAwKsE8tCLr8VnY40IouP2ZWZmnj9zrrZ36gX8 5lclAZBIJKmpqXV1dVNTU1ar1eVyuVwunU7X39+fk5ODxWIdDsditxEAAAAAAAAAnrtXIgEYHh7O z0okUP8AACAASURBVM/X6/WuR+jr60tJSdHr9YvdUgAAAAAAgCUNfj4W+229Wl7+BGB8fLyqqsps Ns/v8etMLqvty/90Op0cDic9Pd1uty92exeNUAVPSrxer2+xGwIAAAAAwPMFeSCb2qGbMsl61Aqm Rs8zO/ROr8vrc/seGi6TWztpHCviE/27GtbTnnk0bmmnHO0fTJvk4cSzNMWCkPWqddMmm9rhsXvQ 9kBeCOQM38ZLngDYbLasrCylUjm/9+90unKIvhGe56s/dNJoNCqV+mreTy4Pkt8G32h0KDXGV/MM AAAAAMDy5XNDXqcPjUd9j7tMbsWgdrJC2B07Sg7sadzUXvlpS/GbuNK38dWftzb50QkHuoj+Dw/s zo7Kj8nFf8NVbiA1BLU2hlGebdQHtVatJ5d9QCj5K674TeyCKH0bX/lpS8MmGn4fA20PKbC7K2Zk rJQ32ymXMzULQsc1WpV2l9k9d058bpAwfMVLngBQKJTu7u4FE35mle6A28itOshmdy3IAXJycrRa 7WK3ehHYXHAqEbpaZZsRq3w+8BAAAAAAAJY6r8unmzYJiJKhNE776UFKZD8a7BKu3fSVlY0wjAhJ UtweRtHr2ILXmks/xFVuJzQep1BuMxjFA93Fg+23erGR1Jp95EdFbQCZGN/eTxwS8AUqlUrzHKhU Kh5bwKZMDuJYC6Kvcpie2oc/2V67vwVtT/UOUumHuILfNRe89pAo/D228hMydnfH3DmhnWQy70xw sbMShlI3ZdRNGfVck8PofGWzgpc8AcjPz1epVPN7+XaHq6jVtzMJCUxGxoRfeQjgcrkoFMrw8PBi t3oRmOxwQgN0qcLOFcpBAgAAAAAAL57L6NJNmzTjBs24QT2ml3QoOVUzvfFs2ikm9dTA/GgN761b 11b0Bq7gtebCN7ClH+MrtxBr95Br95CrNpMKX29u2kUX9ch8Xp9u2jRRKmzaSi98vblqO5GWy2AP jc0IZ+RyuVajNZvNDofD5XLZ7Xaj0ajVah/TQdfr9Q6Hw+d75BOGbwmGYZ/P5/V63Q/jcDhMJpNO p5trj1KhFEzNsChjTNzw/OirGeouYlISurGHabV7WtDTUr2dVPYJvvCPX00Vftdc+WkLdndHa2Qf emK7rrLGyvgimkI9pkcvhHbK6DA4IehlyxNe5gQAhuE7d+7YbLb5XXyp2h2aiuxIRHYkIunN0IIE YGpqqrm5ebEbvgh0FuRiJXwO45rkybxe72I3BwAAAABeEjAMu8xuk8hq4JkXhHbSKOlQjhXzGdHD uL2M6s9by98nYd69F2XvEko/wJWvwldtJlVvIc+Pmm3kprA2cnxHZ2nfCI09NTgt4s5KRTKZSC4V yFl1kzUbW8veJjRsopV/QC59D1+zg0wr7Jpic7VaLboVEgQtnBKz9NfpPtger9frcrkcD2OxWHQa nVyskInkMpFcKpQJx0RTvdzB5tGeKmZPFbO7nNme0oc/0V6/q23uxFauJZZ9iC99h4B5h4hehfL3 SFWftWJ3dbafHeyKZXXFsrqvsoazOIIWqXpUP3cprUo75FtONeVf5gTAarXm5ubO7987nK5quhft /e9IRA4mI0K5e/4LZDJZeXn5Yjd8EUj18MlSJKrUx56Sgi3SAAAAAODpwTDsdfpcJrdN5dBOGLiN s0NpnIHkiYHkif4b47QTTNzuztrVlKrPWhZExUfk4rdwxW/jyj8j1OwmY0+3taV2dRb0MwoHGIUD vTVDw63sqeFpEX9WLJTMD4lIolQq9Xq92Wy22+0ej8fn80H3ud1u6biCcr63aguJmNDOxA/zOHyt Vut0Ol+pjY9gGIbm8fl8Ho/H4XDY7rNarQaDQaVUzZ3YmcnZScb0cPNYd/EgehU6s/vJ0Z31BygV q4iYTwiYTwiYjwml7+GL38RiPiDOXUpyZLdOYVj0HOnpvcwJgNlszs/Pn9+/F6vcR7PguQRgRyKS R/I5nF++QC6Xl5WVLXbDF8GEGDpejJwoQZhjYpfLtdjNAQAAAIBF8+BIM+SDrEq7tEc1gRGM5nEX BPP2RNvRgSY/OuZdIjq3pPhNXMnbuJK3cSXv4jBr8bVBZEIMjZrcTb3zlWjP6OmuHmB1jvG5fJlM ptFoTCaTxWKxWq1Wq9Vut7tcLq/XO79zP+fxfU0Igmw2m1wuV6vVNpvN4/Eso77pC7YgT0DnINnt dut9ZrNZq9UqFIpZlGiWN8pnkca78pntKb3opeyuGJBLl9Mk6pc5AUAQJCUlBf37Qc0f/kdjz3Vk VvnlQ4Dp6emmpqbFbvUi6JqCTpQgJ0oQOlMM9kQDAAAAXm4wBKPVJL1Or0VuVw7rhETpcAaHenyg fiOt7B1i2dtfidK3CIW/xxb+Dlv8NrbkA9yCKP0MV7Wd2HSkrfVaJwPTx+pm87l80cwsGuJZsVKh 1Ov11odxOBxut9vr9T6/ifXP47CvoPl5AvowweVyoY8RUMtrAsVLngDk5+er1Wq0c6/QuY/dhRck ADsSkQKyz+64lwDQaDQmk7nYrV4E+CHoTJnvRAlC7JHYbLbFbg4AAMAig32w2+ZxWdzfINw2z8u3 ZHC58Ll9NpVDP22W92oERCmfKJkf0w2zzDsTlIj+ho20urXUurXUujXUqk9bMe8SS9/DlX6Cq9pI bAim4M/SiBfo84N0iU5NY/Q3D411T04P8rhD/K/ECH+GK1Lc7+Wjk+y996Hj96AjDiwpL3kC0Nra 2t/fj3buGWPeyCz4cPrCiC6B5Fo3uoikqKhIpVItdqsXQTkDvlxhO1GCNHTILBbLYjcHAADg+YMR n8vnMnlsaqdm3CBhKNHg4yVDaZPUY0zCgS78PsY3CIJ/V/vpwaEsjrBFeu+wXUqjyOyxe2CQGHxT kAfyOLz3wuZ1GlxmsVXeq0bP8Gy7YrJc2BM3Sg7ubdjUXvlxS/FfcEV/XlhOvvgtbOm7+MoNxIbQ 1uajbWiQYto78nuZzSNj3RNC7oxcLtfpdIYHGI1Gq9WKzsl5EOjlA8vLS54AWCyW3NxcnU7negqd nZ1YLHaxm7wIIAjOboGTanSnMVB5m9JkMi12iwAAAJ4XGILVo/rpOtHArYm2owONW9rL/kr4SmXA 3zYXv4XDrMdV7yQ2hLR+g6jeQS5fQyj6E3b+YUv+gicFdY0WcTUcg8cJJmQ/jsfm0U4YFEwNGkKy bCR7uvP8MDm0Bw3Cga6alRS0pP280u/NpR/hKncQmk+2tSV3dWH6mc0jI5Sx+cGijXFGp8RisVKp 1N6HLqWdG7Z/pZbJAq+slzwBQBBkaGgoLy/PYrE8vvc/Pj6em5vrdDoXu72LwOaEk/FwepPicpU3 n6QxGAyL3SIAAIBnzG3xyLrUfdfGalZSil7HFb+FK/scV72diD1Kbb3RySjvG2wZGW5jD7exR7vG uRyeWCRWKpRajfabhFqrlCnFQsl4Fwc95mAzq+NOf8OetpK/4YrewJW+SWjYQms51Nsa3tca3kc9 PsC8M85tEsmZGpPY4nW9tLWYXWa3nmuSdCo5FcKeuFHKkX70DMwFOaSnbl1byZ/xRW/gil7H3os/ Yks/wlVsJNTub6n3b633b20IaiWcb6dldfdhh9AzPExlT45wBDyhTCLTqrVobRy32+15mOdXyX55 gWHIZtLIp4dnx7rRmO4l9jdl41Ijyy5uLrvwQqPi8vaWnPND5BL+YNtcex4Tksl+o1riA4XLv6ll nwDAMOx2u9E/9Ydm7T6fr7OzMzc3V6lUPrTrb7PZmExmbm6uWq1+6D+3Wq06nc5isSyjxd1fi9YM JzbCxSTptQZPFt6g0+kWu0UAAADPhl3jVPRr+2+MN2yglb1DKPsU3xBCoeV2sWhjaOl0lUo1N2/b eZ/b7Z6b0fHNoMsE3W733DHtdrtaquH1C/swI61XGU3B1NptrTVbW2q2tlRvJJd/Tih9F495j1j1 aUvDxnZKZD8zZYKHEytHtBaZbdnUF4cRr8NrVdgNXJN+2qSfNuk4JnmfhlM50xM/SvTvqltLrfyI XPYeoeR9XPkqQvVmMnoG5qJ2e0vT4TZSHL2zsK+vYWigaWSgaWS4dXSilyOYEEpFUoVUoZAqFDIF WjDHZrPNnWF0cs7TVMh5NbkdVqNarOCP8gZaumruNN4MyTv60Z19/zdpy48TN//bvdj0o4TN/35j 93+nBL2ZGvzWi4yUg3++vvNXCZt/nLjpR1+259GRtPnfbu36ZVboW1UxO+uuBTwxmm6HddWkTPWR pNPDSgH7iaEWTZp1Co/7pR0XXsYJgMPhGB0draioyM7OLioqysvLy8rKamtr02g0CzIBCIJGR0dz cnJoNJpCoTCZTFar1WKx6PV6gUCAwWDKy8sXzHuBYViv1zMYjNzc3Pz8/NLS0oKCgpycHDqdbjQa X7Lng1IdHFMD1dHEaQT3nWaLWq0GH50AACxfsA92mz2qEV3/9fEmP3rp3/Al7+Dqgsjtud2sDrZ4 VqzT6Sxmo9WoM+tUZp3Colda9aqnCoPKZbfA3/QrAN23yOFwmM1mnU4nl8ulUqlUKpWIJLxh4Vjr ZH/5SFtST9PhtqoNpNJ3CMV/wZX+DV/3BbXz8rCoXWZV2x1ap0PrdOhdbqvH517kYWzIB3scXqfJ bZHbJQzlWDG/6zKLHNhTv4FW+TG54iNSxUek8g9IxX/BFb+JK/sQX72D3Hy8jXKb0VM1ONLGnhrh zopmpQ9QKBTonBybzWa32+12+1ydnKcvgvlq8nk9bofVbtLO3bEGhYg70NJde6f5dljRqZVpB/9w bet/xKz5h6tf/ODajl+kh39cHOvfnBdPqc5sq8luq8lubyrqb8dPsJji2YdcmudKPCuaHhscbMd2 NBWijXl8tFakVt86mnNy7e0Dr9/c85snxrXtP7v6xQ9i1/5D4pYfX/P76RPjxvb/ygx5s/Tc+ubk cELGiflBzDzZWXljshurlQnmPj2cVhMML6fO4XJNALhcblpaGolEEovFc2P5JpOJyWRmZmY2Nzfb 7fYF/8TlcvX09KBd+dzc3Ly8vPz8/NraWolEsuCVEARRKJSsrKyOjg6DwTD/+L29vXfv3qVQKC/T Rw9PCV+s9JK6RAVU9/V6q0SqfMkyHAAAXhGQF1IMaPuvjTdspBX+Dlv8N2xdMLn9bvdoP1sqlSpl EgG7d4RSQSuOrY3flxPx3rWt/xH/xT9/jVj/g9zIj2ilCZKpoW//TPihVQXRnYnUarWIO8tum+gt HSKe7iz7kFD4u+aSP+NL/0oo/Suh/H1S0zY69cQAM3WC2zyrHNU5zC6f14fGc/0Ah7yQUWSZpSvG SgRdV1jEg93VKylFb+AKXmsu+gO27DNc1W4i7iyNeqebntFLz+ilZ/V2Vw6M0Ed50zyJRKLRaOYv pf0G5e0BlMtmkXGHRykV9LIEalEMtSiGkh/dcD0w/9gnN7b9dO6Ovbzi/0R/8p0rK7+XtP0X6RGf lsYFNudepTYWD/d38vm8uZ0H5nKtuZ0HHrwuLwD6V4DW4H8a6EiuUql8yhxjYri3m1hJKruFL0zE Fzw+EhoyzpZc2Zce9v61Hb9M3PZf8yPB76dXVv199Cffufz5/45b90/oqS4884VGKYWWT/dp+SUA EAR1dHRgMBiz2fzQKT12u727uzs/P99oND70n6O3Fzqc8OALnE5nQ0MDHo9/1LIBm81Gp9Pz8/Pd bvfzf7svAksEn8N4OpgzVV2e+BobX7ScdrIAAOBVByMuo1vKUPUljtWspBS9gS39BNdwqLU9r2uS xZGIpXqdVjjWW38tMO6Lf45Z+d3Ytf+QtO1nyYFv5Z7eUH3rWENW9NNHXfrZnGMrEjb9OGbV36UH /ZlaEj/D7nbazM/+PcEw+m3lcrksZotcrGDhJ9rv9Lbd6mq71dUaz8BH0mu3t2A+wxe/hS3+A67k T/iSv9yL6hWt5NCensRRVt7UWDHvicHHixVMjUlsdZrcC8KmdmgnDLM0xVgRnxE9jN3TiXmHVPxH fPEfsaXv48q/wNf5txDOtbeld/XjhyZZnBmeSCaRabVadPwehfYpPR4P6Nx/M16PSy8TzIwyRqmV 1KKYisvbUgNej1v3j1dWfjd27T8l+f3XtR2/vLbjl9d2/up2wJ/unlhTcT2iIfMiesdiC5M6yXVj I4MCPlcqEWs0mrnVEc9v54EXbME2Xo+B7vA1fyfgxzMaDBq1UioWzc4IFoSQOzXYSSZj7jRlX0JP NaU2Ty4DCcDzNDQ0VFdX96jeP8rpdKKLer9uH93n8+FwOAqF4nA4HnN8h8PBYDCam5sfmkIsO/Rx 6EK5izkqwA64Y6rsE1wZSAAAAFjKPHavgW/mVIt6k9jkkN66ddSydwhln+AbQlpped1jPRNikViv 1+uUUiGro+n24et+P0nY8pPiGH8iJrWPimUzu3hT43KZVKfTmUwm89ehUck5w12tZTfvHv0sye8n iZt/nHbwjfLorS15F1nUKrV42uN+xpupo/0bt9uN7kiKMugN8hmFgCWa6JweqGFRr/eQr3aigTvW XrejtWIlsfQj/BOj5F1c6bs4zPvEqs9a69ZRF0TtqraKD8ml7+FLP8BVrCHW7WvFnaVSM7oGsMPj XZM8Nl86K50bQgZT8L89yOezm3U6mUA2NcimVrUVXamK2ZEZ8uatXb9I2vLj+E3/lrTtZ8kH/5R3 emPlrWPkioxeKpbNZHBGB9DgcdhSsVir1c6/q9FlEuilAdfla5m/nudB6IizxWJBz7PFYnG73cvo DC+zBMBsNmdkZDymrKfNZjOZTGgfnUgkdnZ2fq2LMT09jcFg0A8yh8Oh0+nmbyS8QGVl5eTk5PN7 sy9M0wB0udI5xRW2jbovVThYHNnLkdgAAPCSgBGfG3JbPU6DSzNumCgTtIb1VXxELvoztvQ9XOVW YuORVnpeD6uTLRaL9Xq91WKScUeoxbG5Rz6I3/DD+I0/Kry8v5uKk4jFRqMRnVD+jau2wzDs8/kc DodOqxkbaCcXXyu84Jcc8If4DT+MXfMPt3b/qip290hbpVEt9bidz683gHZNfD6f1+t1Op0Wi8V4 n8FgUClVwnERp3d6opvz+BijTY4Qx/vKhtuSuvGnabgo6vzAn6dR07v6aodY7WO8Cb5UurC7D8rp fGMwDPs8brfDajfrFIKxsfYaWnFsdeyu3CMfJO/9v/Hr/yVm9ffj1v/rrf2/v3tyXeWt40RMShep mtXfKeBzFQqFTqebG8uf3ysFvXzgKS2nBACG4ebmZjab/dDuuNVq5XK5FAqFw+HM/fDGjRtfq6p9 bm4un89H/63FYqFQKB0dHRKJ5KEPBFQqVWFh4fLa+fmhiulQQq1tdna2d8pzscLVz5a+BG8KAIDl DvLBuikTt3GWmTxJPTbQuKW99C1CwWvNhW9gKzYTCLG0ftIgd4orkUjUarXRaESHOZWCsbrEA1fX fD923T9nHPm8KS9hsKddIpFYrdZn/mzT6/W6XC6j0ahSqWYEvL7Wutrbkbf2vnbp0/+ZtOXH5Ze3 9zZkyvlst9P+gvtk6LDlQ/eretC9iUYWi8Fg0D/AZDLNzRgBncvH8LgcqplxHrN1up/0xGBRyqlF V2ri9t49/E7Chh9Gf/o/oj/9H3Hr/+V2wJ9yojZW3jxKLLvTTWkaZ4+IRCJ0VbTFYnE6naCGKfCs LKcEwOPx5OXlGY3GBR1xk8k0MTFBJBLr6upqa2vnJwCNjY1PP0hvtVqzs7PnhvwtFktra2ttbW19 fT2NRhMKhei6pflqampEItHzfNMvQgoBvtOgVygUoyLoYoWne0T20ixvAABgefG5ILPEpmBqh9On Gre0l/wZX/o3HGYFrnobqTmC2prY2VXez2KwhTyhRq2x2WxzM8v18pkxWnVx1KrY1X+ftP3n5TeO DHRRxaIZvV7vdDqf97RGdDDe4/HYbDalXDLCINbePpoa9Gbsmu/Hrv77hA0/zD7019qkgI6KG+Md 9XI+ywsGWZYhj9upV8yI2Aw2tYpWcrUydldR1OqiqNVFUauyw/6WsOGHsWv+Pmb138Ws/vsnxtUv fpC04xd3gv6ae3pjTfIpcmVmf0cLZ5wlEvIVcrlOp7NarXPlaNGnPYv97oGXzXJKAOx2e05Oztxg vNPp1Ol0Y2NjZDIZ7fqj5icAbDabTCY/5fHZbDaFQpn7t3MJAKqhoaGtrU0oFM5fftDR0cFkMp/r u37efD44rh7JwSm1Wi1XDl2ogOiDsldzQzQAAF4kyAc7TW6zxKYdNwrJsuFMDvU4s8mvo2Ylpfx9 Usn7uLr9LZQ7nUOtoxzm9Ax3Fh0HRQv2ezweGIZ9Xo9BIZrobKhL9E/e8+v4jf//jd3/XZYYNtBJ kUok6OYtMAwjEARZLJBC7uNNeRjtzrJCx7UYR9zFrxHXY53EZo9oBnI+eVYPDMMej8dqsUhFvJEu ckv5narr4TknV9/e/7ukrT9N2PSj69t+Whi1qrcxSzo9bFJLXA4r6N49pXtT5OUC2fTgGL2urfBy Tfy+qtidLyDKL23JPvTX23t+lbTlx/Ebf5To91/JB/6QcfgDNLKPrSpPCsMX3WQQq3spDU+M/nY8 m9nFn56QyaQLJvO8uo9ZYBi22yC1EpoR+ATc5RdKObSs1k8upwRAo9GUlZWhPW+z2cxisQgEQu0D 5icAs7OzFRUVT3l8Op0+ODj4qAQAVVdXR6VSeTwemocwmczlngCYbNDlagTTKtXr9WKN72IlTO6V PVhEFQAA4GuBvJDT4FYOaadqRf03xrsusxYE7cQgfl9XzSpKyVv4oj9ii9/EVawj1gaSCZdpHfm9 QxTWjHBGq9Xa7XZ02sP88ho+j0s2PViXFHBn/2sxq7+f5PefhVf2tdTksIf75XK51Wr1er2w2w1p VG58o+tajP1kmM1/m2XjZ5Z1H5o3fKrbv1V9cKfmqUO/Z5Nl/cfWXRvsl087SFiPWgW5nrzSF52E Y7fbTSaTVqsViwRjA5095OqmzAvJAX+IXfP9xM0/Sjv4h+Iza5uTw7vr0njMVqNa6nLYllEhkUeZ vyWaz+t2O2wOi8Fm0j0qjGqJYJjaW5+GTzvadPvQQ6PxVkhVzI7cyA9u7/l13Bf/HLPq7+LW/8vN Pa/dPvDGC4jkgD9lHl9Tfj2ChElhEKtG+ugCHk8+D7r0dv7GZI+3+LOqYBj2eGCnA7ZaILMJDd/s jKeT5sIUOu8kvei4Ees4E2kP2mXdtta6ZeWyC8O5YyaFfBn98S6nBEClUpWXl8/Nv+/u7q6vr398 AiCRSKqqqp7y+E+TANTW1uLxeDabjRYJHRwcpNPpz/NNP3cSLXSxEsF2is1ms8YEXa6G6+kyq9W6 2O0CAGAZM/DMPXHssr8SC15rLny9ueRDHGY1fkGUb8TXBZFJsXR6Xm8/YWhylINOd0Z3Xnc4HA+d 6wxD0MxoZ/XV3TErv5u0/eeFl/dR6vInxtnoJo9utxuCIEgm9WDrHdGn7Bs+ta75QOW/XRJ1ZPZW Er+scJpMnB4dFYlEMplM8fTkMhmDrky/rQ3Za1v5jnXT59aLJx1tZO/XmS05f5qQRqNhdVOIRdcq EkOyIj+7vvNXV1Z9L/qT71xZ+d2cIx9QS+Ml00NWo9Zm0tlMeq/btZSHhCHIZzff68cblLPCEToT l9Oaf5F89yz57lli5qmqmB2ZIX+JW/dPlz77n4+K6E++E/3Jdy6v/F7Sjl/c2PPao+J2wJ9yT2+q un2cWHaH0dIwOT46Ozsrl8u/xqX8FpRK5dzNOZeUzt/+ebEvxVOAYcho8E6wPS14d1G2M+6CPeyA beOntlXv3osVb9tWvmPatEK9b4t6v9+LDJX/dumxQ+JrsTP5d2cwxcsuuASsUg4SgOfDbrffvXt3 bgqQw+FQq9UDAwNYLPZRCQCbzSaRSE95fHQ20aMSgLq6OjKZPDk5aTab0S3HXS4XmjM813f9vHGk 0IUKH61fZLPZLA4ophbGtCq/1sppAABeWW6rx6pyoGGatSqHdAKilBE9jHmXVPohrimC0l3TP9Y3 zpvgiwWShSGUKKRfrm58zPwHvVw43l5DzDxVcmbtrZ0/u7r2H2/s+U1N6ln2MFMuk5lNJqda7Znm eHu7XOVF9rOR9k0rTFtWKkL3zqTc4FBbRdNTCqkU/UULSgA9Pa/Xa7fZdHK5rK9HkX7bELjTuv4T a3iAvYXgMRi+budvbktgk8mkUSkkIgGfw+6nNuHyruYcX5G45T+urv1+/PofoHF963/kRn7cePNQ V20Kpwcv4w4bVWKTRmbSyCw6pdfzjKuOPr7dVoNazmNx+0n9TVnNyeEFxz65se0nc02N++KfYtd8 P37jj67t/PW9Xvve36aGvJ1/bmtNShQ2L/5RgS+6TsdXsof7edOTs0Leo0I8w1fIZXMzwdB872td x2/vxZ3tbwq2mH0zAu/QgIeEdZUXOTGFTkyhMy/TcSnKHrDdvulz2/qPTVtWavdsUoYdkF84Jb6Z IMrNnCm4O1Nwl1dZxqW3C8bYUj5PLhS+0JgRKqUSrfbeTgXL0fIqoLKcEgCPx5Obm7tgEbDD4dBo NEwmE4/HP7gIGI/HT0xMPOXx7XZ7dnY2Wt1swSLg1tZWDofz4PrjqqqqBzcSXl6YAvhihbtnZNbp dHq8UFw9nEdQ6/X6xW4XAABLkc8DWaS2mVbZQPJE6+H+pi30urVUNGpWUMo/IJW8jSv7BI87S2W2 jIhnxWazGR0ufdTWPA/2qGAYcpj1OilfyhkYaSmrSwpA5/cnbf95avBfC6J3NeZcHeqly0UiK2/a 1ctwpt6wB++27Vxv3rra4LdaHbJXcOc6l0yYmRhXqVRWq/UZbkGFbs5ls1r1Qr4a12Q4EmjZusp2 aK89P8s1xvIZv0kmAN+v2ON0Om02m1opnxjsoGCS69PP1aWdrUs9g4kPyjryya29v0nc+h/o8fSB awAAIABJREFUEoI7+36TcuC3KQd+m+r/+5yI92oT/VvyLnTXpfY2Zs6PkZYyyeSATso36xQWvfIp w6yV6eUzKuH4dB+xH3sXPVRXTTI2JaLw5Iq0gNdvbPvPhE0/it/0b9d3/To9/KPCS7srb0TUpZ2t SzvbePcKtaGA2UEaH+qZHhuaHh+aHh8W8qYUCjmagD0Guuz1afagXRa98GcGXcGi1y0MjRoSz3hH Bl34JldTraup1lVf5cxOcVw84Qjda9uz0eK3xrB1lWHbWv3O9fqd6/W7N2qD90jPnxCm3OBVVwrb qTODAxLutPJ+RdG5C2G3210u10M3aX4xFvuMvyqWUwIAP7YMqEajGRkZweFwU1NTc7nB3bt3H7of 8KOUlZUJhcK5BKCtrY1MJnO53IfuCiyTyYqLi5dXwofy+BCFAbI5fTCM0MbhSxX24fFZdFHdTSyU 3qzTarWL3UYAAJYAGIG8kM/pc1s8Br6FT5DQTw/VrKQU/RFb8jdc5UZiQ1gr/gKNEE0nRNPJcR0d eb0DzcNjfRMSidRsNn+dHUVgyOf1uOxy7hC1OCb/2Cc3d/48Zs33r6z6XqLffxZe3t9amc3qahex R6XUVmV5seFOku3iSfveTdZ1Hxm3rZk9d1yQn8VvrON3tAumOCqVymKxoJ9pz+vEwLDb7TbI5erm es3pSMvGz6wbPrWdOGQnNnts32pRL3x/nwHTfUajUavVzgim2f10Bh5DLEqquhVZfu1w+bXDRZd2 Zx9bcX3nr2LXfP/BUjNXVv1d7Jrv39z5i4zgv2SGvvWUkR74x9t7fh2/8YdXVn73yqova9okbv1J aui7hZf2Nt6Nodbn97cTOOOjUqlErVYbDIa51qLPc9AtAuYXp3+GJ/9lA8OI1wu7nLDd5hVw3R1U dxvJ3UZytxJc5UXO67H2k4ft4f62w1+N4D3WbWstaz6wrPvI8sW9MG5dpQzZO3sxSph5R1BbyW9r me3rmR0emh0eEo2yZu9PsUPTclBi6BW3nBIABEHMZvPdu3f1ev1DcwCXy2W1Wg0Gw9z8HBqN9rWO LxAISktL0fTX4XDo9frHbAlcVlbG4/Ge0zt9Tkw2pGsKTsbDJ0uRTJJHrrHX9vriqiyTXDH6VZ1J hm7Vm9Rq9WK3FACAxQMjFolNgJMMZ0y1Rw02+dHRAvwFrzVjVuOxp9u6qvs5Y1NoAX6DwTC3BdVc iZ6nK7sJ2y0GCad/tK2iveRqbfz+9MA/Xvrsf8Vt+GH6kc+q70SRKzP62omc/l5JVbn60mnDvi2W 1e9ZP3/bsvYD7a4NsvCA2bjo6eryaTZbJpPNL1f/wjo0aBpgMpnk01PyyjLt0WDrmvetIXvthCaP RvNsmwFBkNfrdbvdDofDbDbPnXO9Xq9UKvlczjiL+dUYGO5uo9XlNKSfxcQdLIk58PRRnnQIV5BI x1cM9bSjR5tgDwsFgrmNwOxgZ4CvxeeD5FIvs9fDaPcwaF8JCtFdlOOIu2AL22/b+Jltxdu2FW/b VryDhnHzCmXADmlUpCT2ovRq9PyQJMbM5GZON9VP93QLWCMC1ohglMXncqVSqUqlMhgM6HQGj8cz t+ED2EAAmG+ZJQAIggwMDJSWls6vxflQk5OTxcXFX3dHWwiCaDQaiUR6/MHtdjuRSMTj8c+7tvSz xRLBcfXIeYz3Vr2+iKyKqfEk1HtuY7036kyiWSk6QlNMhxJq7XK5HHxMAMArxeeGLDK7mqXnVM6Q Q3sxfyOWvo0v+xRXuZnYeKiNHNdBL+wZorJ443yFXIE+FJ0bPnzM9Oi5/+V22XUywexY91h7La3k amXMjvTAPyRu+ter6/4xbsO/Jm3/efLBv+Sd2YQtvD5IwQvxTapqjDblhj4qwui3xrThU1XADsnl s4LsVC62kTfQP8uZlM/MaFQqdOv3xe2GomP2TqfTpFap21p0Jw9bNn1m27HOdvWCo43skUmh57C3 +oIzjy4vXsDtdjudTqvVajDodVrt1widDp0K4na75442191/ub8dHj35H4JtVp9Y5GMNeQf7FkZX h6uiyJF0xX4yzH489CsRGWTfs9G2eYV1w6fmzSsWhGnLKu2eTapDB+QXTopSbvBqKniMTuHwkHBk SDgyNMMelfK4SolEq9E8eI3mig7Nv+ivwjUCnonllwB4vd7W1taSkhK1Wj23GHc+i8XS399fXl7+ qMk/EAShK4ce+n/dbndra2tzc7NWq31o71+n0xGJRAwGswR3y4JgZGQG7uJ4VQav1/fl3z8MIxwZ ElsLX68zkhk8Ln9Go9GOC83XG90nS+H0Zr1CoUBPSE2P70qVSyyWgo8PAHjpwRBsVzukXaqeODZ+ N6NuLbXiQ3LpO7jKjSTCFVpf8+B4D4c/KZybNoCucoMgCN1pFoYgGPJ5XA6rQa2V8hQCtoLPUvBZ ksl+ViumNe9i5ZUdZec3lJ3fUHpufXbY28l7f5209d/j1v8wYetPbh94PefUF+XXI0iYtB5SzTAF O93eKmlrUSQn6UL2mvxWGzav1O/aoAndPxsXPd3cIBgZlstk6EMGtMezBKcL33sgoFSoqBTVjXjD wZ3mzSttB7bZEi45qS0ehQxapG+Np1nb+sRcbmn58g58WDjskE4LSWafqnw7n+vp7XJVlzlvxjui Tz0yzh1zhB2w7dts2bbW7Ld6QZg2rzBsX6f136Y6Gqw8HjY/FCcOi2MvCO6m8bGNM22tszTK/BDR qaLBAQmXq7hf/wqdg+C+7zEL1hf7GgDL2/JLABAEgSBocnIyPT2dRqNptVrbfWazeXp6uqCgoLGx 8cFClh6Ph8vlVldXZ2RkZGdnZ2Zm1tbWCoXCB58SQBDEYDBycnI6Ojq0Wq3VarXZbFar1WQydXd3 Z2VlMRiMr/ts4cVwepBbOPhkCXK1zlfT4+ErPA6Xz+NDhCr4Sg2SWGPsGZzSarVutxsdMZpVmDPw ttq2Gc39p9WEId+lSvc0X7zUvlkBAPhmYB/s80Bep9eqclgUdovCbpJYJQzleAm/6xKrYVN70RvY kr/hqrYT8Rdo7dk9A9jh6UmuUqm0WCxo/8Pn83o9bo/LYTWoBMO03oYMfNrRukT/ukT/2oQDmIub s0P/em3rv8es+rsrq753ZdX3rqz87uUV/9/VL35wa//rdwLfuhP41p2gv2YfX1Nx/Qih9HYHvmKk r1Mo4MtmZzVcrra63HDlrPFIoHnPZvO6j0wbP5MeO8TLy+JTyIKRYXTW8lx9z8U+l08FTQMsFota JJKTCcqkWMOezdY1H1j9/WxJV5z0No/BAC+rp8fPBgwjELQwfD7Y40FcTkiv86lVTwilwsub8rS3 uktynTfjnddjHx7XYhwXjttD91q3rbGu/cC67sMnxJoPrKvft6z7SL97ozJkryr04aEMOzB79rgg 5aagCjPTVL8gBHgsr6dnhsuVyWTKB6Az5dDc9cFRxQe3uQCAF2BZJgAon8/X19dXVFRUUFBQWFhY WFiYm5tbX1//4AJWCILGxsYyMjIaGhqEQiH6F2i32/l8fnV1dVZWFpvNfvD4Doejp6ensLAQPX5B QUFubm5nZ6frKfZ/WSw2F3K5Bs7AaotaDJcq3CdKkPOV0G2s72IlHFdl7hvi6HS6+dOWYBi2WCwq lcrhcKA/6ZjwXSj3jE6Kl2aGAwDAU4Jh2CqzcSpnOs4PY3d2YN4hoZP456LoTSxmNa4xorWztJcz xpHJZOgAJDq+jo4I2M06TjcWl3Kk8OSKmzt+htZrj1nz/Wu7fp188M9opIV9UBi9qyEzmlyRTqnO plRnU+vyBzpbpjiTEolEqVSqVCqVSqVWq3U6nVkus4yO2NtIjuIc+7mjtg2fWNd8oDy4S3LuuCj5 Oq+yjMMckEgk6FIutGO0fEc6YRj2er1Wq1WtUMja21Q34vX+26yr3rNuWWlLvORsI3lVype82wfD kFrlHR32tOBdhVnOjFsLwnE91hYZbN+6yrbynfvT358Q1lXv6retVR3cqQza86iQHQ0RX40W3k0T lRYKayufGFwygctiodtQqB5NrVbr9Xp01s2CTjw6V+rBSXFgtB5YspZxAoBCZ15arVZ0tuKDL3C5 XAQCobS0VKfTPfhH63Q6FQpFbW1te3v7Y45vt9vRsgbP+d18W0YbfKoUaWgXaTS6GYmWPqSooGrS cZY7jYZuJker1T500cL8z6ZBAXQO4+ljzS7H6kYA8CqDvJBN5dBOGMXtyrFCXsuhXsw7pJJ38OWr CfUHW4nR7bTM7o7c3o7c3s78vn780MQAhz8hkEvlJpMJ/XzTSKZZrRhKwaWWvIsteRdrEw/c2vnz uPU/uL77vzOPfFJ6NaApJ7aDWDXK7OZOsr8szS4SKpUKo9Fos9kcDrtNp7Vyp2zMPlsL3l6SZ8/P tOdn2vMybImXbIf22bavs2363Lx5pW7XBuWhA8JbiRxKi4gzqZTL5jYEeN6dftjnhG0yyCJ+ZNhV kM/9DNsAQZDH47GazbrZWQWdqrydpA/aZd68wrZ1te3gDnvsOUdJnntowGc2LfueIgzDJqNvoNdV kO24FGUP2Gb3W2Xd+JnJb7VmzyZ1wA7NV0MdvEcRdWT2ZsJsZoqwrOiJwa+pmO6kz4yOSnlchVD4 yBDPatRqdLGy4+m4XK75ixyW8eQoAHg6yz4BeDwYhltaWmprax9ax3P+soHm5ua+vr7l/rctUkMn ShBKD99qtaKpi8Vi0en0EplCr9c/zZLlSQl0DuPtGBQvwRUOAACgYAh227x2lcMotEi71WMl/M5L w4T9XfXraRUfk0vexpW8h6vcSMJfog3ghqaGuFKpVKvVms1m63wmg1Et00i4s+yuAWxO9dXdyXt+ Hbf+h4l+P7227WfXtv3s5p7f5F/YSa7KHmV2zYpm1Gr13BT8e0UeXU6vQe+Vyzy8KReV7CrOdcZd sB85aN+/1bJ9rWnzCsO2tYZdG9DQ+W+XR0XM3IjnlxYKWoiivh7xFAedaPTsVy763LDLCNtksH4S EuEgTqFvMs83mQcNxsG9p+G2XTBhLYxf9aiAiOsh6j5f/yXfNMarm4Rd5mfVMHQFmsVi0fJ5ijay LCtFcfGUPmi3aftaq99qW9h+e0G2a4zlM+jhZfFkwOuFNGpPX7ezusxZVeasKnNm3HIc2m/ZslK/ fa0mZK/0wklB2i1+bZWQShENDkjGx6QT4/NDMsWRy2QPuTkfDR3s8z0JKE8EAI/3kicAMzMzJSUl aJmIx7NarampqRqNZrGb/K2MzEAnShAmi+90Ouf//Ok/CvlK+GKFt6VXspRnOgHAqwhGIA+kmzKN lfC7r4ySg3vqvqCWvkUo/H1z4RvYsk/xVbuIzVEUampXd/XASDubN8VTKBRmk8npsHncTp/X7fO4 7Gb97ETvIKGAmHmy/OLmzNC3krb8+NLn//vy5/8nafsvimMPUhuL2UO9U+OsqXEWb2oCLa95r144 BCFeL+xweIV8D53iKs13xl+0Hwux7d1sXfehddV75vWfqg9sE0dFCO9cF2CK+SSCsK93dnx8dnx8 dmJcJBDI5XKtVouWLnkG9TphGIG8sNsCacegmWaIXwPxayBeNcxOg7tPQJRdEPZTuOYNuPp3cPXr aPiq/2itX6FpPiBruSCnxT80FLSrasppI26vo/4jqPp1qOFvPqq/h1PsMc5A3mf2XBSGYY/HY7Va 9Xq9SqGQDw/Jq8pUURHm9R/bvvjYGnHQnpvh7u/xKhWQ24X4fMiSygcgCHbYvQM9zuREe8B265oP rGveR8O0eYX4ZDgPUzzd242u35h7sIPWEQI9dQCBIQTyvoyxzBb2vOQJQEFBgUgkQrv4lCFPNd37 YLSzPDa7y+VyCYXC8vLyZT0jkzoGnSnzTk4LvvH4vVgDXan24bpkC1IIAAAWhdflMwotMxT5wK3J xi3tBa81F/0Ji1mDq9lPwp9rp2Z09TYyx4bGZ2Zm0O61TqOamWCy6Q2MmjvNdyLyj3+a6v/7lP2/ Tdn/2/j1P7j82f+K/uQ7V1Z+79qOX6Ye+qAwendDZnRbfcFQb4dAIFAqlei+uXOds3s9M4/HOz7q Ls61hwfY1n1kW/G2ddV7er81ipC90vMnRHdu8CpKpzvauVNTYrEYrUH+lQcFC4727XmssIIBDyfA +NVI9e+Rqt9A1a97q//krf6Tt/rPjtr39Q2b1YRDMmqcsKuQO0zlTU8I+DwBnycQ8EUikVKpRIsa PYZOp1MoFHLegKY3zULY46v5E1zzuq91t2c816vj+LzP+AEpBEEul8tkMin4XHkNRn3+hNFv9b0p 71tX2Y4G228lOKsx7r5ur+WZPY74BmCzyctod964atv5hW3FO+q9m0Ux56bqqzmjLAGPJ+DxBAKB RCJZCrVZgWcHhh06WDsCi0mwCPutQlALc/KhgUtQ216IsPYlC3f3Gbv5Ge/+8Vy9zAmA0+nMzs5G 98JwuVzNPd7d15AdiQuDOOCdWxpQVFS0rDfB/X/s3XV4XFeWKPo3/d137zd9577bMNMz3W+me3ru 68QO2THHEDOzzMx2jDFbYFuWLJPMtiRbYDGUCqSqErNKzKxSMTMznr3P+6MSRXGctEFgyfv37b9i pc5WkfbaZ+21yA3wSpqNJ3j7I7xKAwwhAVK5wmazDe7cEAR5HXaNU16v6U3j11zryN1dTVhQnDIj P3FKTtIcOml3YcnTqvaqLnYnu7Ouqj4/vbEwo7WU1FFOrsp8QAk/FH3y6/BNfw5b/fvQVb8NW/en 8O3jI47PfRG4KeHy1oTLW5Ou7SZHBJVkxbfWV/Z1tQl5HNX3ufv9hTV9f70g5gUigbe6wpWW4Lh5 1XFgm3XdIv2mFfLTRwQPbnMIqRxGpaC9XcrlqORyvV7v6/81+I1F3SaobYOCbNB6C1QcgoV+sHA9 LFyP0+dD8hQbaZ4m74i47BavNpXXyRCzmiTsZgm7WcxplwpZKqXMNzGn0zmwmP0vHNP8Ka/X63A4 jDqFmtekqXtkzd/hJs+ElKlY8TZP93OvjgmwwTwYBvv7CWi1KlafpLJcnJIgCw/TnD+u3b9Vv2mF Zc0C66719ke3ndUVXg4L02qAdwi7HeM4Dj0eoFFj7D4vo8wRHmrfsc6yZoFml58o2L+PnMnvbJdL pb7l/kt16IduSsi7Al7o0EBDL1TWQHnly0NIBR33QNUx32cNFq6H+Svx7FmQPMVDmuYmzXinQZzm IM6yUJYZ6Ds0hSe1hafG0pBUPlDJJaNoE3ksBwAdHR3FxcX9ST5yjftEJHxp9X8yCmqN7v6fodFo LBZrpCf+lgDA48vxGwS9RKp467egzgJuZoGUYtVP66giCDIUvE7MqXdZpDZFo7b2emf2uork6bmJ 0+kp83MJm/IIh7KyLpPoD9LzY5Krc8kdNQX1OfHpIdvub/9b6Mrfhq78XejK34Ws+G3o6n+5vemv T76ZnXB1Z3Z0aAUtuYmRz+xsFouEvvI7PgaDoT8f4xXZFy4XkEs9hTmOqxfsO9aZ1ywwbFiq271B dv4EJzaKXVEu4vEGtoga/PwN4IEuI26TQ10n6HyEF28BWV95Myc5SbPN1HW6nL3anH3anH3K3OP8 6jheV7VM9sPR4ZdW+YM4MV8LXrvdbtQq1Jxqbd0Da+5mjDQZUOe6m2+7dSyADXLJBF8k4Ha77Xa7 yWTSabVKDlvW1CCnUdRXL5q2rDKvW2zdssp2cJv9wgn7o9tOCsHVVO9hdnv6ejx9PV6xEOg0wGaF Lhf0eN5g2G1QpwUSkbelwUVOd96/4Th3zH5gm3XLKtO6Rbqta0SXL7CIGdyWJplUYjQah+HENvI2 IMAxN/QNjw13anGLCKoaASsZNAfj5XthwWpA/dpLmuYhTn1puDOnOEmzrNmrtN9/3DQ5B6XFVwQ1 ccJWuqSzSNr1TkPUwxBzOqUSkUaj0Y05drt9FH0cxnIAUFxc3NHRMTDRP7kUG7j633ILJzK8AysD VVRUtLS0jPTE35LDDZ8WwIcUtUKpfusAwOKAd+kwOkdtNBpH0fsYQUYdCKBFZu9J4ZecaMz2q0id mR83jpowhU7cn18WVd1Y0FyY/iI+eM+DQzPDNv41cOE/Bsz9VeDcXwXN+9Xleb+6ueHPsUFbCwlR lfSUSnoKIye1iVHU19stkUj6j+r6qpr8nfXZ96XZgVbjKc5zXrtk27jcuvgr7fa1vFvX2NlkTkMd n8uRy+V6vd5utw/Vag9C6DJAIQ2vPQOKN0PqHEj4BMucoMneIiwN5zdSuMx2sVikUCjU3zMYDL7V 5+BP5heniWGYw+HQa9XavkJD+UWQ+QWWPcfddMNtkgzdsV0IoS8IcbvdRqNRxeqT5tGkCTHS65dV R/fq/ZZZF39lWzS9f1hXfG3bs9F27qgj+KLjetBrj0D7pVP2vZttq+dbF023LPlKt3ml9Ng+YWgQ NzaKS6WwW1tkMpnRaPSl9wzRL/vhghCHAAceYJVhRv7bDAMHyBiwLx42XYa1Z0DNGVBzBlQchHkr IXkKzPgYZox3EmfqKH7yvG/FFQ8EdSnCJrKo+UeD35rL7W32VUTt/7j5Tmn77vL9tOH0m+qvtjTS z/iHbiwHALm5uUwmc2AAIFC4jz794SbAN09xpc498Aeqqqrq6+tHeuJvyWCFt6kwLk+h0+ne+qPl 8sDH+fBRllav16PPJ4IMLofWqWjScqjiuptdtM2V8Z/R4yfS0v1yqSdLckMKs+4kU188yoq6knxt x431fwqc+6uwdX96evTrlBuH6fF3yrLiK2jJFbTkmuJs1vf1c9wD+P6s/t05QKfDK+J76qvd2ZnO J+H2c0dtm1bYFk23Lp2l3LdFcO8GszCfx+OpVCrfUd0hWvRDhxZo2qE4H/ZEgcpDOPELQPjURF6p zj0iK73Oq45ndjSIxWLfQv89XDFgGGa329WCDmNloIc0DZAmuRuuu7XMYVgZ+0oJORwOk8mk0+kU CoWIyRSVFPHo2b4hSo5X3A1TXTihPLpH8c0bDNnpI6KbV3kvnrNy6azODoFA0N8E2rf4Q+v+QQAB dKiBkQOMHGBgQlUjFOfD3ueg7gIo3ABJE/GMj956wIyP3ZlTzeRlhuwNvqGn7VAWnhNXPOTWk9g9 rQI+Xy6XazQaX41U96ugPK4PxFgOAOrr66uqqgau7x1OV0LRdzcBNt/EU0qxl2oBFRQU9PT0jPTE 35LSCK8RQWapxGR6+2LSAMBnRfA20dDfGxhBkHfhtnr0fSZhibziXDNhfnHytLykr+gvZhGfzYl8 vj0s+tzpiG83hO+ZErLu/726/HfBK353fd2fwnd8EufvV5AR1dlSK+RzfdtvAyua+5Zif/cTCr1e oNVgXLa3ucFNIzke3raf/ca+c51twxLLukX6jcs1uzYoTxyQhAbxoiPZRQWCnm6VSuWLK951qQcB dJuhRQRNfGjiQxMPajugpAh0R4Kas7BwHU6bA8lTPaTpduLXpux1sqIgdiNNyOlSKr7L6nE4HO95 eonvhoDNatIIWkwVAR7KbJj1FVa238MmeA1sMNgHhV85gYE3B/rfHna73WKx6FUqlUioFAreYEgk vqWh7+zcwLr4Q/27jF4Qc0O76vv3+YCh64TqJiikgvb7WPMNrPkGVncJVB2D+atx6myYNR1mTYeU aTh5spc83U6aY85aacjdIyu6LKiMFNYmiuqS3nwk81pyBb0NEl6PUspTSfkqKV8pE/W/pgNjafSa ImM5ANBqtQkJCS81/xIp3fse4Jtu4N88gSyJ+6UAIDU1VSaTjfTE35JIg/unYjlVonc5vwshTKwA IRlmpXKst6hEkCECcZfJrek2dMawy84207dVpX9dmDiFnjCHnL6fQAh8/nTf/stLPvNf+qdLS35z ecXvb276z8dHZ8df3ZUdHVL5Xe5+i0wm689y+aW1PgDQbgN6HZCKvY11LnK6KynWlRTrinnqvHvd cemk/dB269bV5rULjWsX6resUh7fJ7rmz3v+lEul8Bnlwo52iVDYnzX09ut+zA1dRtyugIZeIMwB HQ9g9UlYvAnmLAH0Bb6BUWZ6Mie7iDPsWUt0OXulxZeF1THCFqqwp1rE71MqlWazeZRuPWIYZrGY tbxaXfVNB22VlzQFUOd7GoI9mu5hCAN+ji82eAuj7vkfchDD3RboUEOzEMgqATMOdD39bjRegeV7 YP6q/vd5/4BZMzDydA9hsos0y0352jds2Ss0OQekxcFiRoSkKlJSFSmqiRW2UIXdVSJut0wm8y3W rVar7W315/6h1xT5ZWM5AMBxPDIyUqPRDFzi2x2u57nYphv4s1zM8eO+wFqtNjo6evR2wO2VgPPJ WHkD/x0reJLqsKBUh0wmQwEAgrw+iEGL1C6uUNbf6KJvrUr4gh43jpqymJ6ymfh4RdCNFRtu7poT uumjS/P/R9Cif3x0dB7xaWAJKbapqojNYkokEo1GMzB3/6efPuj1YlKxp6rcnZ3pziK4swhuQrLr wQ3HhRO2PRtty2fbFk6zLZ5hXjHHN/QblsqO7BIG+/OinnDJmVxGBZfJfONDAq/8Td1WIC4CrCTA SgK9sbA9HNaeAUWbYPZsnDAez/jImznRRF6mpO6TFAfLKu/IKu/IKsNFVc94TVnc7noBnyeTyXwN AXxJCO/aEOD9gGGYzWbTqJWKnkJD2QUscyKgTPM0hHi0XdhgnxJGhgjEPMDIBZLC797erCTY+xw2 BsHS3YC+CCd+jmd8BDPGY4QvfMNOnK3N2ijPPyMtv/X9W/27Ia28K6yJ4zXncpltQj5HJOCKBFyR SNSfVWX5Xv+nAK3UkeE0xgOA2traoqKil7b5+0TuI48hS/yj7X+Hw0Eikbq7u0d6ym+vmgkupnib O7nv2MS3uAM7kwTZfNlb1xJFkA+HVekQlSoq/VsyFxUnT8lLnJiTMI0avzQ18eDTlNDLviiFAAAg AElEQVTQh9+suLTg9xcX/K+ra/4jfM+Xz86uJD7xryvP53FYWo2mv0jly9UzIQQmI8bneJvq3TlZ zqf37OeO2battq1ZYF0517h+sW8Y/JZotq9VfrNHFnSe//QBm5zJrqsRdHYIuzqFXZ3Cnm4pj6tS DEaZTohBuxrquqG0FDYGQdpcSJroJk53E6e7idMcxJlm8jJ9zk5l8SVBxWNOI5Xb2yLm98mlIq1W Y/yeb7nvcrkG1uIc9JdjxH3X4cts1PLqzeXnPKQZkDQJK9rs6X7u1XRiHseY/K1HE4hBuwrqu6C8 AkiKgaQYiAsgOwU0XwNluyB1Dk6eBIlfuonTfO9wF3GGlbzQSNukKTwlKbvDq03ndteJ2B3fDW63 VMRTqxQGg8H4E/1nJ7wDoAwc5D0xTAGAw6Rms9lcgdjhxnCHicNms3lCq9ODe2wCDofN4evtQ9J3 1uVyEQiE1tbWgWt9p9NV2uax2Ab+F2dLS0tsbOzo3f7HcZzeDALSPGwO7x0X7hKN1z8NZlXrbHb7 YM0NQcYS4AU2pV1coWQEtJKXlyZOoUVNjH06887DVWdDl64KnPtp4NK/BK34w+Vlv7u55W8vruwo JsW11ZVzmF0ymVSr1Vqt1oF7/NDpAHotkIi8Xe1uOsUZcc9x6ZT9wDbb1tVmvyWG9Yv129aoj+2T BPvzox5zaRRBRZmoqlJUVSmqZghbWyQcjlKp7M+bH1ht412rYbpNuIEJmLGwbBfMXQayZ3uJ0+zk eaq8Y7zqRHFXqaS7TNJdJu5miNntMqnYdxPjp6nGH+ZyB8Mwq9mo4dVr6x7acrd6yDOw7FlY6U5P T6xXxxz0yqEfGAiBB/ZXuvxuuKDLAK0SaOiFmlagbvnRkFcCZjxoCMRLt8PcZTB7tpc83UOa7iFN 9xCnuogz7JQFJvomRf5pUcV9fiNJ3FXy/du7QtzXJBVxVSqlr8Pdz33KfmqknyUE+SXDEgC4bLSn AQ+evti3/RC9jVObEHbg0rUzR/dEUBrbc58eOB7sf+rA1fiiIUo30ev1ERER3d3dDofD9SoOh6O+ vj4iIsJisQzNFIZJMgOEEOwikegdS+O5PCC2xHuD5JAoDCgLCEFwHMchjrkws9gqKJa1RfZVnGsh ryyL/YQSMynt0fyQq3MXn5v/H6fn/PeLC//ntfV/efjN3ITQA9kxN8qzE7vbm+Vyua9y4g+3+DEM mk3ernZ3TpYr8oEz6Kz9yC7bphWWZbMsy2cbNixVHN4lvHyRF/WYRyLwykt4nZ39HXb7a973V/4Z zN106MVdBqBqBpwM2HIdlu2ElGkY4QtDtp8s/5yo8pGwgcDubuw/n/DTaQzCHMYWX7EgnValYldp ah/Y6H5Y5gSQNdPdGOo28CAKA34KYjjoH27c64AONTCyMQML0/cCRQ3gpMOWMFhzClaf+NGoOgZL tgL6ApA5ARA+AYRPXxpY5hcO8jxd9lZp/jlR5RNhA0HcSpW00SRtNEFHiYDdOTBBbuDbu3+VP9JP DYIMpmG6A6DhNqdF3D504XYPjxd0YGV0EaszM3zznoDLp7feSK9jVr/YueUSd8iu7nQ64+LiUlNT JRLJj28FOEUiUVJSUlpa2hhofPs4H4aTdXK5/N3/DPeK3acT8ZJmrcs1JHdmEGS0gBjUdBnaIlm0 TZXxn9LiPqZGf552/5NboZ8fvDR9+rFp/+307P92fcv4+NBDhRmRHa2NfD7fl+NrMplerpwIAFAp POVFzpvBtvWLbQunWZbN1m5ZLTu2T3TNXxD1hEMhsupreVyuVCrVarW+3XRfzszQJgdDDFqlUJQD a89AynQ84yOM8JmNNF9D3S4qC+9rLReJRL6U/f48oqGaydj1XQMBvV7JbTQyrniJUyBpkqf6rEdc 5nV96F0XodsC9L1QXIj3RoPGIFB3EdRdBHUXQMlOSP0aJ4wbWOkSED6zkubps9YbqJt+PDarcg7J SkMEVbGCRqKwiTRw8Jtp7O5mgUAgl8sHVrV/qYouCmKRD8cwBQBel93ArT+9/1BUblXAvmVxpbwu yv2tewICTm26ndnArk/Y/fMBgEQiqX1nDAaDSCTevn37/v37KSkpJBIpOTn5/v37t27dIpFIDAbj 3S8xsiqr66+m20PjuvLy8t790RhV1VdTjSGpyryCknd/NAQZXWqqaxkF1WXJjJzAssxVhUmTciM/ jbvzeVDwnK3fTvvPb2f89tzCP/uv/zz04JLwi3uj7oWkJSfQabSSkpLKysqqqqrq6uqa6ur60pIW WnZXahIr6pEoJFB96pBl+xr7uoXGVfMEG5bXnTiUffM68fkzSnIyjUTModMLCwtLS0srKioYDEZ1 dXVNTU1NTc1Q/HIN1SXtlaTeijh+Sbii4Kw5Z6s3ex5OmeohfKlIntOSsIf+IpiUEkUhJNGySHl5 eWVlZQwGY8jm82GpqalhMBhlpcXFWXG9GQf0abO8mRM9WXOVud/wim70lEa3VRDrqstHeppDqL6m srkqp6silV0WIS66oss76KStxLNm4ORJHsKXxtSpiuS5spSFvsFPXtWetKsi4XRh4tXipODipOC8 xBvE5GcUQiKNQsjJJr08aNkFBQXFxcXlr1JRUfHdxxO9mZHh9QtbzG5ha9Cpg5fukww4rhPVnTt+ PPDksfC0mmEoHzY8KUCW/PinxcUF3+zeHUNvybp75kx49N1Lh4Kf5RYlBB8NjHwScur07fSfq1zj crlMg8RoNMrlcoFAwOFwfDsBg/XII04gMwVnYi/ofJFI9O6PZjQaS9us/inu4nqhb+cPQcY2nVov 7ZE3JXblnq5MX5eXNJ/+YhIlcnxc+CcB/hMWnpv5t/OL/nh13V+fnllFTbhXW5bf3dnO4/EkEolc LtfI5XoBX9/bo6ur1hBTVXdClccPqHes029Yali3yLhukX7LKs3BHeKg87wn9/uySL11NWw2WyqV qlQqnU5nMBh8JwgH63cx6hRGJccoaTdySgyNkXrGNT0jWM8INhYcNtK3WEgLHZlfuTKnujKnOUhz zdR1qrzj4tJbvPpMZnutb2Jqtdo3sUGcFdLPaDTq9XqlQibntqraicai467sRW7SDFfmVAdhhjFr jbbmro5Xa1DyjTrV6H4JDDqjgmUUNRl6sgy14YaCw2bKCjtxjitzmitzipM40561RJ+zW1oYIKx+ zmvK5raXcXqaeH0dvsFmMfl8vkQiUSgUyu/1vzlfqf/EOYK8P37prinw5Nw/fTw0WQes9McXjoSm tpYmHzj4bZdyaBbkAwzPHQBMxWsrKCgoq242OXDcICksLCgoq1IbHbhdXVFUWFBcwdeO7vz7ESfS gCsESGWIB+skg8HiDSGB6Hyz2WwelAdEkPcQwIBD7+LSJeVnmzMWFMaOo8RNTn88NTzksz3+E+ef mfFflzd+EXv9WG5aRHVxdk9Hi0QiMej1TovFazJ5mN3uQror5qnz2iX7sb22LSutS2dZl84yrVmo 3L9N5H+G//gej5DKLS7ktbUJhcL+o7qD0mYLBx4cc/UP6NQDVSNgp+MtYbDyMMhfA7K+8mVCe4mT vMTJXuJkN2m6kbJakXNEXHZTVJfEa83j97WKRCKVSjVoE0PehK+nr8lkUkm5ciZD3pKprgq30v1A 5heAPAUr3ACqjmNtd7yiIsxlxeHoybyCGO62AFk53hgEc5cB0iRA+ATL/MJGXqih7pAV+QsZkYIm Mr+rWsBj+3JyTANqwg6sYY9ycpAxrj8AcOrig45cjCkU9FYfO3SgSTTkVx7jZUA/HL0SGJTuLa4X 2gepdA+EMKfJE5Dm7eGqUcovMpZACC0Ku7xR3ZPMK/22KWlybuw48oPx4aGT9gQsmH5ixn8/O/fX 13dOTrp7jlFE5XK5Go3GtzTxuFyeznZX/DP7N7tsS2fZFk6zLpmp3bxScXiX5PJ5wdMHnMx0VhWD y+H4ThP6aoYMVhI/9NiAgQ0kJbDvBWi6DEp3Ato8QJ0DqHNg9iyc8DGe8ZGX8IWVNF9H3aosOCOp uM+rJ7C76vl8nuh7vt193+kClPf8/hjYzVev1yt5rZr6CEPxtybaJgdpDp7xEaDM8NSc83JJmLoF s6kheF+/k116KCmGdRdg1kyYMc5Kni/POy1kRHEaaWxmZ38VfN9Z9v6CsCM9aQQZOf0BAO4sibu6 J+B5DfnR3m8COYYhvzIKAMaIRi4MSHXVtArfsQnAQFyFNygdy6tXvWNnMQR5Hzj0LmmNuuF2N3ll aeqM/MRJ9GefJD0Yf/vqF5vPf/XFpeUfhW6fFHFmNeHRpdqyXE5fr0ajsdlsXq8XWC1YR5s7/rn9 8E7bmvm6zStlZ47yntznUDLZdbXCrk4pj6tSKHzL/YHLmjdusIW5oVUCtR1QVgbEBUBcAER5oC8B NASC4i04dQ5OmYKRpjiIs82U5YacHeqi86pif1Wxv6okQFTxgNtA5vXUiTldCqlAo1EZjUa73d4/ n36oQOF7DkLoOzFsMuq1KolKzFJ2F+rLLtmpKz3EaZA8CWbNAAXrPK13vYpGzGUa+VcTAmiTQ3E+ qLuA0+YC0mQzeami4Cy7Np3HbFPIZabvW0D4Or6N/IQR5P0BvM30+FhipQXHXVZh7P1b926HU2t5 w3ArFgUAY0RRB7yc5mjrEQ5iKwOjDYRTQWy+3my2oK9sZNTx2L1GvoWfL219wiw705S1tiJ+EiVi 3LN7nwRfnrgm6OtFt7Zujrh0khB9pzQno6mmlM3slsvlOp3OarV6PB7MaMD6et2J0Y4T+61+S/Qb lilOHWbHPedWMcR8vm8Xs78qztvvo0MAXUao7wbdT2HpDpi7FGTN8hCnuDO/Gy7iDAdlgYG+Q5Z/ Tlj5RNCUJeyqEHE6fHX3+1OfTSbTwPAD7euPARBCAACGYW6322w2a6QsRW+pvCVDxbhpztvtIc/C yDNAoR9WexbrisTERZieBW1y6DJBMMSdlSHEXSao7wE8Mmi7DRlHYO4yL2mqjbJAkf8ttzqZz2yW SSVGo9HpdKI9fgR5P6EAYIzIqAGhBBuLIxzEdB0MwMQKLIRgU6s1KDMYed9BHGAA82CYG5O18Vui 24qO1CVPy439mPL847SH4++FfXYyYMp8/2WTru+dk3Tfvzw/i8nsVSgUJpPJ19kHwzCAYdDjwXgc d1Ks4+R+28qvzSu+lh4/wIl71ldZ4auG6XA4fBuZbzVJgEMMYh5olQN5FehLgE1XYPEWSJyIET43 UVZKCwNEVZH8RqKoLU/Uni9qzxd0VfI5fTKZTKPRmEwmX2FQlLrzAfKlCTkcDovFotfrVPxWTWO0 MX+/jbIII3wBCeMhcQKgLwQl20HdRaw7ChMXYUYe5nHhwItDMAgDeKHXAXXdsOsJLN0GiRNhxng3 caqRslqee5JXk8LpaZHJZCaTCR0mQZD3HwoAxoioQhBOMUskksH92q3u9Z5OhEyubFT3SEbGMI/T Jaju7Upva37STt2bnTAnMebTjLiPqdEfZ9wdfy3oi5Xnp37mv+6zR5d2ZqfFNNTXstlsuVyu1+sd Dkd/tAwUMk9DjZtKdN4Ktu/ZZFs8w7h2ofjMUc6L6N6mRolE4ut79ZY9tiEGzXwoLYV9caAhCBRv g1kz8IyP8IyPPZmTTaTFavpeYcVjZnudWCzuv7EwsNXowLbBCOLjO0BsNBpVKpVMLJB0l8kaXmgq QowFRyzZq13E6TBjHJ7xESR9iRX4YZVHsaqT7zQqvwF5K3Hi53jGR67MaRrqTkH5w742BofzXdko s9ns8XhQUIogowUKAMaIG1kwkq5VqVSD+/0r1XrPJeP59YrBOluMIG8PQrtJp+B2yPs6pe194hpB eXBJxlJKwpdZzz9NjZqY+Hx2StyatJidz+PPRac/ekF+EUNPjynPI3e1t0ilErPZ7FvE+7KQoceD iQSeghyH/7f2Tcst6xbpNyxT794oP3+CFfeM3VAv5vP0er3dbn+bHAaAQYcG6nsgKwGW7sSzZmCk qQ7iLAtlmT5nh7LogqDiKbc5R9DbKOH1KGTit78Q8mHzvZcxDPN4PA6Hw2q1GvUajVygEHTJmFXy xiRV+TVTwUFLziYLfcO7DDN9ky7/iKQ4hFedwOmslgh5Op3OF6n6bkahty6CjC4oABgLMAD90/CE fLlOpxvcR7Y4wK1sLLbAYDSaBveREeR1AIC57BaTRiLqqC+Nupe469vYRWHxc2PipyfHfpEWPYHw bEFszDfR5MfkvGR6RX5pa0sLm83uT5ixWq2+Aj7frVHcbmg2AYXcnUd1Xr1g37HWtHahZu9m/p3r 3CwSv7Jc2NEuFYt1Op3dbn/dPB8Ica8dOrW4VQLVjYCdDppD8PJ9MH8NyJ7tyZxioq4Xl4QKmsjC rgoRp1MqFfd3+fUFJGjdjwyi/pMDvpDAbDbr9XqVQqKQCt9tiJRKhU6n8/XQffssOARB3g8oABgL zHZwPgUnlolNpkFepnsxmFyJ3STZxHItSkJAhhyEEAKAec0aGbuhoIb4kHr/aNK59ZGrdz7+8vyz T2LixlHjvqLErSImHSClXErLjExlVFay2WytVutLjvftR/7oAZ0OL4flLilwx0U5QwPtx/fZNiy1 LZqu3uXHvxnMomVxmEylUmk2m/tz619jngA6DUDVADhpeMt1yDgC8lZB8hQ842OYMc5J/EqXtUGe e0pccZfTlMPncdRq9cCym0P3/CHIK4HBgFb8CDKWoABgLJDqwPlkPK9GOFhdwAaqYXovJGMdfQp0 DAAZIpjHLe1rqqM8odw58Pz4zJtr/i141r9e/+qLO9OWP5pwMWZcetyn1PhFlPQTtLyEorbWNl8L XqVSaTQaXS7XK9YlmBfjsd2kNPupg/alM20Lp1mWztJuWSU/vEsSeFb4+F5vSRGfx/Oty98gcdlr h8pa2HoD5izGMz7GMz7yZH5pIS3SUbeqCs+JKx9yG0isrkY+n9/f2wjtlSIIgiDvIRQAjAV9MnAu GTJaBq0L2EAKvfdsEp5Xp0LHAJDBAjCvWadQ8Dq4LSUVyWHPj864seZfQpb86cacKfcnH3j22dPo 8Qkxn2W8mEZJWUannCkoTatsr+8QCUS+Ff+Pco4hBDYbJpNgPZ2eihJnUqwjNNB+cLvNb6nBb4ni 2F7xzWA2MZ1bVSnsaJNyOSq5XK/X+wp9vl6GD4B2FVTWgNZbeN5KQJ5qJ83V5B4Uld/jNVAE3bVi bqdcwtd8313LV4gTZUUjCIIg7zMUAIwFLXxwMcXb0C4Yio5dXgxcI4LofIPBMPSN6ZCxDHqcdqNa 3F1BygjZ8nT/xPBN/xG64vfXFv7h7vL5kYsuPZ8cGf9lVtIseubu/LzrZZVJdU25rb0tTKlU6svP 6U+egS4nUCncjDJXYowzLMh+8qBt9wbLhqWm1fONfkt1ezZKz5/gPrnPLswXsFkajeYNC/ZD3GuH FhEU0kHHA1h9AuavwUjTnKSZGvpeXuUzXkelRCT0RRGo7j6CIAgyGqEAYCyo7IWBqc62HvEgtgEe KLHcc4PkEEnVKH0ZeVNOm0nc29CSH1/w7HxK4NrwTX8OmvsPNzf+Jer0yqQz52PX3IyfnR43nho/ iUbYkVcaVd1W1SESiXzduHxnZH9Y9wOAyaWewhxniL9t0wrbwmnm5XPUO/1EZ77h373BS0lg5+Vw WpqEQqFCodDpdG+W3uO7hEMF2amw8jBOnuzL8DFRlivoB3mVUayOapFI5KsHOojdNhAEQRBk+KEA YCzIaYHB6dYetuQt65T/PTVMb2Cau7EbHQNAfonH5dRKOdzmkqacmPzIc4kXl4dv/svl+b8Kmvt/ BS/59c1Nf73nN/fp+t3JByKyDhWlfp0bN46aNItOPlRYHlPT3dYjlUpNJlP/Tj8w6Lx9PR5GmZuQ 7Lx51fbNbtvqebaF0yzLZin3b+XfCe0pyGOzWBKxWKVSGQwGq9XqOwT8pkV1oFMHtR2QlQTKduMZ H3szJxqy/CSlYcyWUi6HI5GI1Wr1wIkhCIIgyGiHAoBRDwM4oRaGEUxcgXyINiaFKuxyBsipVTsc jqF4fGQ0AgDTybiC9sqW/Pj8yPOJF5Y/3Pnx7fV/DFv9++tr//X2lv/v0aHpL4I2E+5dyr4bQbmU nrQk7cUkcsJUWtJsetqKPMrh4rLn1Z213RKhxGg0Op1OzOvF5DJvTYXzfpj92D77tjU2vyUmvyW6 TSs1+7Yozh4T3Q7lJsaxy0qEPd1KhcJqtfrq6rxFtj20yqC0DDRdhUWbcdo8SJnuJs4wZa8Xl9zg tBaJuD0ajcYXUfjCCZTegyAIgowl7xIAyApz66yDPSHkTXkw/EUZCCcbRBLFEO1QOtzYLSqIzEHH AD5w0OtxOcwGo0rcwyATw3Y+2PHR9VW/C1n+mxvr/vjowNRY/42kJ/4lpJi6UmpbdXV3dXd1RHP2 zrKU2XkJk2npq/NzQ8rqyc0dFd2cbq5UKtPrdHatxi0ReZrrXZQMx50Q+77N5tUL9FtWyU8fEdwO 4SW94OfSBbXVQiazv7S/r57mG7zVIQa9dtylx61SqKwFrGTYEAjzVnhJk52k2Xr6TllRgJARxW/J 4XN61Wq173ww2uxHEARBxrB3CQDY0RFZ+sGeEPKmXB78aQF4QtUplKohWrVACNOrvFczXBKZEm2F fpiManFl6k1CyNaoI1NvrPnnoHn/cHPDn+Ov7clPe1JXQmf2dInFYpVKpdfr1QJtW3xf/sGa5Km5 L8bTUlfm5F4rq81u5HK5KpWqf9vew+lzpbxwnD5sWzbbtnCadfFX2s0r+VcusjLTWR0dMpnMV0bT 18brjcvnQwhtSqCoAawkvDkYVByAucsg8XM84yOYMc5OmiPLOcarSWD1tEil0v4LvemBAQRBEAQZ pd4pAIi4/aJD8DKF3oK2zoaT3YXfzgax+RqNRjN0y5cWrvdiClbbgY4BfFgAwNRCZu6TU9dX/O/r q37/4MDUmEvriQ/Pl9PT2Kw+34LeqDDziiQN4V2FR+oylxTHf0qLn0RL98vNv17RWNoi4Av6y+0D h93b3eFOjrMf3GZbMtOwfrHs5EFuTCQrP5fd2SHg8ZRKpcViebMNfh8IoZENuQTQeAWUbIOUaThh PE4Y586cZiYv1dG2K4vOiyqfsBuy2T1tQj5PoVCYzea3uRCCIAiCjH7vFABc2rZ546aXbLmeUjH4 pSiRn2d14lcIMLVIbjAYhi4AkOvBtUxAqkDHAMY+4PUoeZ1V6eGkm3ueH51x2++PYWv/LeHqzuoi CpfVo5DL9Hq9xWKxGe3iSmVVUCtpaUnStJyk2XTC+gLqsdLCW4zmojZON1etVlv0eieP4yrKc0Y/ dgSeduzdZPVbot+4XH7qMCf2GaeaIeZwfOV6fF14X//8LgRu6NBAIxuq6gE7GS/fh2fPchOnW8iL TfRtysLzwopHvMZsQXe1mNshE/M1Gk1/nf43uhCCIAiCjD3vFADc/DbgYdRLntHr+tAW8XAy2uD5 FJxSIR6KNsD97C7wNB88zDbqDUa0chqrPE67kt9Ff3TizoZ/v7biN3e2/J+IEwuSww5VF2WLhAKT yeRLxXHbPPI6TcnJxuSpuclzcihHiype1HZWdAu4AoVYrJOIzSKhg9njzKc5QvxtO9aZV80z+i1R H9ouDjjLiY7glJcJ+Tzfuv8NcnsgxD02aOIATgZsCYOMw7BwHaDOxYiTPJmTLdmrhEXXeE1UPrNV IpGo1Wqj0TiwTj86yIsgCIIg/dAZgFFPYQCnE/H8ar7VOoRHsiGE1CbvpRSPVK5ERdDHHofV0F1J SglYc33F/xOy6vfx1/bWlefzuFy5XO6rh+P1enGI29SOnhRewYG6hAk5SV/TC8IrOpu6ZFKpnt1n zaPa4yLt14Nsx/faNiyxLZpuWzRdvdOPd+Mqi5bF7vrhkIDD4fCV7nnNuUG3BcgZsDsClu7EiZ/D jHEO4iwdZb0i76S4LFxQl8JrL+Pz+f0HDFBPLgRBEAT5ZSgAGPX6ZOB0Il7VxLPb7UN7Ian3dCJe 065wuVxDeiFkeEAIjGpxe0lqevCmsFW/DV786/Cdn6bdOd5YUyGVSHzb876Nc12fqSeFn7enOmFC TsJkWvqGvKIHjO7WLkVttSkl3nr6iG3ZLMuKOdotq5SHd0r9TwsfhbMzUllVDD6HrVap+uvqvO66 HAJok0NBNqg5DXMW4Zmf4ZnjXcTpWuoWYfn93rYqAY8tl0q0GrXv8K4vfQgt+hEEQZCxSF+V91OF rXzlu/zZe5cAwNRa29jV+zKxyohO1Q2nZi44nYi3dnGczqE9fGG0YVcIILVUax7KXCNkGHjdTkF7 BSls572tf72+6vd3d36aGLKvjJrc09GsUMgtFovX6/U4vHq2uTddULC/Jm12QdJX9Iz1eTkBeY2p hX3ZObK4Z7oT+y0blhn8lqiO7OY9DOeUFgtbmiSsPoVc7jsk4Cvg83oZPhB36aGuC4pyQecjWL4H 0ud7SNOslMXavEPikjB+XRq/q1IsYGm1Wrvd7kscQlk9CIIgyJgHYdfBRT+18hqx+l3W2+8SAHD8 t21Y8bJVQS9K0CHg4VTeDc4lgT4Wz+12D+mF3F74vNh7L9uqUOnRwmuU8rqd0r5G0o1dN9b8y431 f4q/urOUktDT0axQKEwmk9vtxjDMZXYLCmWFh+rSvy5ImERLW0bPuUCtvfa8++xp8ZHdqp3rDesX G1fNVR/Yxn18l1OYx2ex+svnYxj2Rjv9uMcCdR2w/S4s3gTJU7yECR7iNGvWClneGW4dgcdsk8lk er3ebDb7Du+iNx6CIAjygTG1VPmUPA4KTKlkVFVVFebEPR65AEBDjY+JjIx88jj0+PGAJ5E+UegQ 8DCjNcPAVCeXL/J6vUN6IQhhUbs3MM3dy0XHAEYlcW995vUdIcv+6fraf00LP/f8HywAACAASURB VNVSz5DL5QPLbmJuwKGKaVsYceOoqaty8oIKqkOimP5nhOuWqOdPVW5YJj5xUHjzGu/F877iQj6f r9FofOXz33gqEIOaFthxFxauxzM+8hCnqGm7pRV3uM053N52kUikUqksFgsqzI8gCIIg37PnRUV0 AoDjuFFdHT1yAQAOAQAAOGzNkXHFDvA99Ad7eKVWwZB0s1giH4aK5nyF51wyLGlSDnW6ETKIzDpF Xw0t/erGa0t+fWvzf6Xf/batqV6pUNhsNt97xmVxy2rUDXe6MxcWJ3yelTr9WeGu0K6TR8Wr5qsX z5RvWysK9mdSSNyebrlEotNqLRbLmx7k9YFOPVTWwfa7kL4IZn7uIM3W5uzjMaLZPS1SidBoNDoc jv6iPUPzZCAIgiDIKOWsJWdyAMRHPADwcTlaol4Uo2OhIwIDMKYE3s7UyeTKYQgA3B7sGhE8zzcZ jKahvhbyjtxOG7+tLCv84KPd48LW/POtzX/NeHCuubZMJpNarVYMw3CIO/UudpaIurEyZSo1cXwc 8fOrRVM2NS+Yx1k1X7p9rfCqfx8xg9/SLJNKTSaT0+l848x7rxM3cSGPBJpDYNluPHcpRpnhIM7W 5e7nM57zuqokIr7BYHA4HGjRjyAIgiC/CLocdl+yh8su7WDLRuoQsIr47OmDBw/uhgceOnLu7gOf h+SqHpQCNGwcbvgkHz6iqFUq9TAEABDC7Ab3lQxPF1eHsoDeWx6XQ9jBIFzbcn3lb8PW/THmkl9e yqP2xmq5XG6z2TAMw9zApnKwyaKcbVXxn5DTPg3Pm7KjZu7Spn3bm+/e7CWkcUoK+Z2dcrncYDC4 XK7Xfa0hwDEX7rHgDg3QtgNOGmR8A7PneDMnuEizDNkb5XnfChjPuO1lYrFYp9O93W0EBEEQBPmQ yJIe/NQTegt3pAIA9rkNq39yKnnJpZhC1Cp22JhsMJwGYnIUOt0wHcwVqz1XCCCt3DDUVUeRt2BQ ipro0QnnlwYv/h83N/w5/d6Z1qY6mUzmO+ALAPDYvFy6pPTbptQZeS8+pqR+ejd/xpbK3dsaH4S3 lxYLBAKtVmu1Wl0ul69w52tdFQJg5ABuJmy7DRhHYd5KSJyAZ3wECeMNlFXS4musRjqXw5JKpb52 vE6nE0WPCIIgCPI63sMqQG61VCL+CbXRhjb0ho3GDMMoILVYZjQOU4NeDAMplZ6rGW6xTDMM9xyQ vwtgXpWguz4rIv7Mwusr/nfIit882D+FHBHU2lijUMgdDofvZXLqXb1pAvKKsoRPycnjH2VN/pa+ 4XDJzZt1xYV8Nlur1b7xfjzmgtoO2PscFm/GiRO8mV9ayAsN1E3qgpPi8nBuXQans07EZ2vUapvN hvpzIQiCIMhbcSm+W2Kz0+6ElwlFYrG4p43+bATPALSWZLdLBrYCc7flpzaK0XGA4SPTw6uZgFIh sQxjbf4+qScwHeTW65yoI9jI8bgcaiGzITsq6eKKOxv//frqf3mw78v08FPVhWRWT5darbbb7b6l v13j7MsUZftVJH5OyPg0rHDGxurtO6oin3TW18nlcl+X39damkMMuk3QKsF1HaA3Fi/ZDrJmuohf GWibhaV3+K35IlaTVMhRqVQGg6H/oDCKEhEEQRBkMLwvVYBcCU/v81Q/qgajrs2IyOtCd/eHjVCN B6RhedWi4UzIsTuxiALvLbJdoxum2w5IP6/baVRJGunRqUHrbvn9MXjJr+/u+izl1rGqfCKrr7e/ eiYAAHiB2+phEoTUjZUJn5LSPr1dNG197dYN9REPu1ua1Wq171Dv378k8OJOPRTnw4YAWLoT5iwC pMnezImGbD9ByR1ua4GAx9ZoNDabrb+AD3pXIAiCIMhgc9bTsngA4jhuUtfGkWtHKgDgRz9M0/x4 C9ijrX+cUIYqRA6bPim8kOwta+APZ11OCGETx306Ea/rUg919zGkn17Ob6JHJ15YFrLsn64s+L/v 7p6Qce90VWEWj8tVqVS+Ply+lbfb4hEWy6svt2fMLXoxjpz+aVjRlLW1W9Y0xET1dnRoNBqXy/XL a3TodUIDC0iKIDMW1p2DlGmQMN5KXqCi7ZWXBAurolmtpXw+X6fT2e12lNCPIAiCIMPJ41RzJZqR OgTMfRqeoHL+KPww8ovvxKFOwMOnkQsupnjr24a8DfBLLHbv7WzsTpZTrLCg7d4hYtYpJL31vVVZ RTEBcd/OC1v129CVv32wfwrh/tmaEjqXzVSr1b59d99LYJXbRSUKRkBr2qyChAm0pM+ekb+4UDJj Ze3OrfUxkX2dHTqt1ul0vvr1Al5o5OLcDFB3ERZuwLNm4KQvMeIkB3G2OWulvMif3ZDFZ3cr5BK9 Xm+xWHwHedFLjyAIgiCj0bsEAJaIgCMPU4qkKp3d6bJbTQJm0+0LhyLyutF+4LAp6QT+qZ7OXt7b dGN9BwDCVo4jMB2LKnApNDa0EBwsEACzVs5uyM++e+jxnk9v+f3x+up/Dlv3p4f7J6WFn6oqILF6 O9VqVX/7XoBBq9IhrlBVXmohLStNmkpLmpBEXnCnZMaGxnkL23dvaox9xvw+4ecVLxPmhBYB5GZA xhFIm+cmTrNRlhhydsmLLgmrnvGbaaKeKgmvW6FQmM1mdJAXQRAEQcaGdzoE3FuWsN1v9fY9R/yD rvifO7V1w5q1u8+yDN5BniPy87IaQVCam8fje73D/bR7vd7KTktQOva8wKk3oRjgXUEI7CYtI+32 k/0Tgpf8Omzdv8Vc2kCLu1lBT26tK+NxOQPz+3EchwDa1c62KBZlVVn8J5TECWnEuXdK5u1tWrSI M38aa8+mztiovvY2jUbzqlx/iLuNgE+B1Sdg9myQ+bmFskxcEMBtzOKyumUymUajMZlMvuo96CAv giAIgowx79YJGLp6aui3r5zbv3//wSPHrj+M7/xRUSBkyCVVglCCTSQSjcgSzePxVHVbA9Kw+BK7 xWpHMcBb00o5lak372z896tLfh1xaklBemR3Z7tcLjcajQ6Hw7cK7396IYAGtrnpXm/arIIX4wiE z64UT1nT/tVEzvypnB3r+8Ku9ublcFgsrVb76lx/txmyU2DuEkD4xEhZJSm60teYy+NxVCqVL6EI LfcRBEEQZGx7twAAx3Ecet1Om81ms9s9XrRuGG6RhTCcZJDJZCO1+HZ7vDlNzrNJsLVPPfx3IUY3 CA0KQSM1Ku7MgrDVvwtd9fuoMyvK6Gk8DttoNLpcrpfybTA30DKNXQncnO1VyVNyE8anZk64XLBk a+3xI233b3dTMln1dcI+pkqhsFqtvnSdH13NbYGqBthxD89dghEnaWk72TWpAk7PwAPEKIRDEARB kA/BuwcAyIgBEN6h4U+y1Wq1egSnoTd7gjNBfJHRaBq+XgSjGgRAL+OVJ4Y+3DUudOXvHuz7Mv3u t9WFJA6LaTAY3G73wIU4wKBJYO1K5ObvrUmfU5AwLjl1wiPSvAt5+86VPn3aVlos4HJ1Op3VanU4 HP0HggdcDOI2BWQn40V+gDLDQZyly9nDqUoUcHr0ev1P4wQEGe0gxB1uXG+FOgu0uyAAKKxFEAR5 GQoARjG7C4ZRYDRdrtVqR3AaAMCseveVdHefQIcqQv4CCIHHZZcyGwuizt/f9l/Xlv2vqNPLyqgp bFZff37/j5f+wCKxNt3uTJ+dHz+OlPLZI8pX39L2nC15cL8uP7+vr0+j0Tgcjp99ziEGnTrYFw/z V4PMz3XULfzKCHZbuUgk0ul0L4UZCDIGQBxnySG5AY8shKFkeI0InuRjhBrQzvei+5MIgiADoQBg FNOawTUiTCuSGAyGkZ2JTOu+mAozKw3D2Y9sdDGpJaXxVx/uHHd53j+ErvlDrP+GynySUCg0mUw/ 3bb3GG1iak/1mcrkCdkJ49IyvrpK3Xep9PH92vIyLper0+l853p/dgXvUEMBFdaehZSpWOYXatoe di2Bz+fr9Xqn0/m6fX8RZLRRm/EQMgxMdd4naxIKFCnF6gi68Uq6MyANa2XpUQyAIAjSDwUAo5hE Cy4TII0htlhGOPcGw8CLMk9opksg1aGUkpdoxH0lcUHhG/89bM2/RZ9blZN4r7OlXiwS+Jb+A34Q AoNeU9FXd7qY+DU96XPyi8kpyeujKdcjGQVFbCazf7//lct36LZAEw8K6aDmNJ41AyNNMVOWywsv chqoIj7bYDC8IjsIQcaWkk54KcVbVscWS+VardZsNmt1hj6h/ibF84RuNZnN6COAIAjigwKAUYyj AEHpoKhObLPZRnoueKfQE5iO5TVoXC7X3//pDwAEmFElKor2f7Djb9fX/CHmkl9VIUXA5+n1+oHr eAgA1OvcrS3qx0nVmxLSJ2a8mJSZtPxFWkByfjKtqb5BJBJZrdZXbNtDiLv0UNMGup7CqhOw0A/S F3iJU22UxbLCi7x6ooDZ4qvfjwr7IB8CiwMPp8F7ZC2fL/ihWi6EGIaVdrgvpoD6bu0w90tBEAR5 b6EAYBTrlcLAdG9Zo8ThcIz0XHCHC3uc571Dset0+g98mw1CaNEryxJD7m75z2tL/yn6ol9FLkEg EJhMph/W8RDgLifW3e6MfKjef6xq+pXUT1LjJlAS9mZQoyl1dXW+n39Vpj7EgQfqe/CuR7BoA8z8 AsucaKYsU9EPSopDeXXpHGaHUqns79s1Ek8AgoyAZh70T8VoFTy9/uVq1Hqz5w4Ve0i16QzoJgCC IAiOowBgVOsQwcA0N6NF/J5sujex3RdSYF6D0eVyj/RcRoxRJS6KCbix5p9Dlv8m1n9jbVmeWCw2 m80/HNUFmLe7w/Uk3LZzvXzucsbky4njiS+mZacdpRZllTCZTJ1O9+p0HcwF1U2w/S7MW44TxrmJ 01S0ffzKKGZnk1gsVqvVBoOhv6DnMP/WCDLiHuXBm0RTD5Prdr/8/QMhbGA5TyfilW3an/4rgiDI BwgFAKNYMw8Gprpq2sTvyZ80m8P7otR9Od3LFhk/wHJAGjGzODYofNOfw9b+64vL26qLsgV8nsVi +eHooduFtTU7QwNtaxaI5/uVTw9J+TQtYSaVfLagOreOw+b4bhG89LDQZYLqRtgejuevguQpduLX 2tz9vIpIble9RMQ3GAx2u92XUITW/cgHi6uEF1IgsUSgVqtf+UGwObwP6J672Q652oTujCEIgqAA YBSrY4PAVGdDh/g9SWyFEMq1zuBMLCLPrtZbP5D1KACYb9f//va/ha35Q/TFdVWFWQI+b2B5H+hy Yj1dzuuBFr/lsoVryr6+lTohI2kWPet0YX1+k1AoNJvNP87yh7jLALXtsOM+LN4EKNOcxJla+h5e RQSvo0IsEuh0Orvdjur5IAiO414MT6+Gwem2lk7uzxUigxCv6PKdBFC/J1+YCIIgIwgFAKMYoxcE pTpaut+XAADHcQyAyi7HxRSQ32R6TxKThhK06FVlCdfubv7LtSX/M+aSX+VLuf4Q4gB4mxuct4Kt q+crlq4unxOWNJGUMImWdbawsaD55ewgHMchBvXdeOdDWLQRz/zMmzlRnb1NUBnR114pFou1Wi2q 44kgL9GYYUA6/iJPJpPJf+Heo9GKBabDjHKt1WodzukhCIK8h4YnAMDkffUUCiW3pMZgx3GdMCuL QskpVujtuE2Zn51FoeazVKahnMDYVNQOrqTZO3rfowAAx3Gv15tY7g5M93bz9GM4EcigFBbFBISt /n3Iit/GBmyuLS/wrea/y+HxeLCeTldijH3fZtviGeIlG0vn3o7/LDtxJo16obi5skUmk1mt1h+e n+/y++/BnCU4YZyLOF1N28urfMbsapFIJEaj0el0juEnE0HeRW4LvJDsrW9m/vLKHkIYUYCFU2wq lQaF0AiCfOCGJQBwWYtSHpcwqk/v3B2Z1ZBx88SFR0lPgo4EPM6mRwccD46LvnX2eGjSyFeyHG1o TeBahq2HJX7fGtywpO7LGSC3TuV0Okd6LoNPI+4rigm8u/kvA3L9uf05PNDt8jbWOi+fs61bpN+4 gut3qHDR45QJmYmzaDT/kubSNrFQbLFYfljNe+1QVgorD+LkKXbiHG3uAW5FFLe7zpff/wuF/xEE wXFcb4W3qfBxllIklvzdb8KCNs/ldE8XW4HCaQRBPnDDlwIk68w/vO9oWlmj/95lL8r43VkPtu7x 9z+18Q6xkdOYuGfLJe5Qz2DMIdaBUIKNxZW8b3/M9BZwgwKSitTmsdV5x+WwtuS9eLjj4+tr/hBz cX1VIVkg4H+X6+9xQ63GW1nivHTSum6RevPaznPX87alJs6gJc2mZ58tbipslYglP5wJBi7cJoei PJxxBJCnWSmLBSW3eO3lYrEI5fcjyOurY8GLKd7CGo7JZPq7H5leiTcwHStuULwnhRMQBEFGyjAF AEZ+0+HDh6lVPWaT6vLBlc8LWZ2ZdzbvDbhyZuv1tFomI27nzwcAer2eg7zKszzT1RR9WXkVi8Ua 6bn8CLOPfZNkv5Uua25uZrPZIz2dwdHZyMi4tu3yvF9d3zEpMfJOWVlZa2srk8nksFiK0mLn7Wv2 HWtti6Yr1iwoP3KOspuYOJUe+0VW9K4UUgyloqKitbW1r6+Pw+Hw2V2GzgxYexpS58KMj7UpXzES vy2gE2tqajo7O30/gyDI6+hj8+9S3ZcTFEXFJUwm8+/+fHMH52qG4wlZ2NHRMQzTQxAE4XA4v3Ak UsOqjYiIiIiIoFUzh2gF/nOGIwAAVu3TC7v2nL+dV1bZJ5BXxYUeCrh+4fjex8S6FtqjgydCL58+ dDk2/+c2sTUaTS/yKg+zjcEp2rKy8u7u7pGey8sicowBCXoGg9HT0zPSc3lXjVWlybdOhK37Y+jq P8SFHsmlUurr67u6uno7O7rTk8UnDpqXz9ZsWS28eKrU/3bizvi4LymJM2iZh3Oz4+jlpeVNTU1d XV29XW3MsmgZ9aCTOMObOcFKWiijHWmkPigtoFZXVbW2tr6HLyKCvOdyqwUXkz3PCM21tbWv81XT 09PzmGYJTNJVV1ePga8mBEFGhV9Ih+YUx6w7GipR6mzO4b4tOSwBAOaR8Fm9vb29vX0KnQ23G5m9 vb0snsXhwd0WDpPZy+RorWO+YszgiyoCdylmmUz2Hpa1zm/DLqZgQpH0fUtPen0QQpNG2pAd9WTf 56Grfhd5alEJJUEsFtntduBwYD2dztBA64Zluq1ruOFhrYSiosDKtAV5idPp2SeLG+jNAq7AaDR6 vV7otkJFFWQcwcjT7OR56ryjvOoEfk+9TCoxGo0ul+s9fPkQZFRIqIDX0q0tnZzXP25U3u29kIwx ub9ULwhBEGR4iBuyTp67cOV6eCtXM8yXRmVAR7GHueBRtlGhULyHyeItPOxcEmjulrxXFYpeF4RO m7mO/CTiwJfBi//xydGvi0mxrL5enU7ncTqxvh7nzau2tQv1G5dx7oS1Z5eUhNamzc1PmEwjHyms y24SCoVGo9HjskOHCnAz8MpDkDTJTprLL77F7qiRSqW+dT9afyDIu9BZ4KVUPCFPIpfLXz+KFqi8 F1NAYYPyA6hTjCDIqGB/7r/r5H3KMF8VBQCj2G0qiKDpfq7z5cgSq7ELKaCgTjrqCgHZzfo6ytP7 2//P1cX/GHFiYTH5BY/HMxgMbqcT6+1yhgTYls7UbV7JuXujJbeqJLg2ZWZewpf0rBNFDfnNIpHI ZDJ5DDzISQOVh3HSRED4zEBZwy++zexqUavVTqcT7fcjyKCoYsJLKZ7aZrbFYnn9/8tkB+E0EFdg NJks7+E3J4IgHxQ5sz4tLebwnp0pxZ3DfGkUAIxioST4PEet0Qz3baPXoTWDECLIKFOPop47VoOq hvjg4c6PQ1f+NvLUktLsJA67T6/Xu+12b2uTMzTAtnq+dvta7qO7zZmlJcE1KV/lJc2kZ58sqc9t FgnEJq3Mw6fDigM4ZYqHON2YtVZaHMxqKhDx+jQatcPhQEt/BBksHi8eXw5vEAwsruiNbjNiAKZV gdBMu1imQR9JBEFGlsdpMxgMBpPZiw331xEKAEYrCGFQxv/P3ntHx3XdeZ69u2d3Z3anp7vP7Jyd s2fOzp7ZnbHbcpRs2W7LoW1ZWbJs2ZYsWYESlRhB5AwQJMEAkiAAAiBIgKgcUCjknHPOoVA55xxf 1Qv33v2jKJqiQBIEQVYV9T7n/kECVa9+eHXfe7/vvb8AazstLpcr1rZsQyAMSzvAlQ6Xy+2J/2U2 isDls901B39W+MLfVx75bW/DVdnWhsvlivh85Ppy+ER24I3nHW+9qjh3crV9sC9/nPebbsZP2poP fhHrb9Pjqg4w8FfQ+LS/6SVdb6FirlUjX7dYLMFgkCCImJ8BiBAFYMzNoKHZll1Ew/kwVNgA6zpN Fqv1fv34aSmZzITLW6aEDFCMKRAiqQk6vAStnWhoEh1aACQqEMI0DmL2mDweT6xt2QaSgteHwFmR 12RxxPOjAkIY9Nj7anNOvvJPZ976bx3sMplU4nQ68TBGbm2ET+UFf/cb9xvPy8+d3BwZXenebHx9 oP7JtsZPeqaaZ9VqtcdpxTU9cGgfFD7hb3pRNVwm3Vi02WyBQCAe/H6EEIDIE4RDG5A/QXn9oXgw iYbmVvQO1DBFmZ33Fx0nNcIkBuoZl99X/E8Up49MZUHRiCMYpPtP3h/uAEzjoGu9IY83YbZ2aWho toUWAIlKhIApLMTrM8SnAIAQts1TOVxMpbvv9blHBhbwzLZUXXz7vxU8978zT3y0sjB7w/XfWMWK soPP/dTx5qvy88Ubs7PKZfVo4TzzyXbOc+3DnAmVSuV1OwlVK+z7MxQ84RW/pBy5ItvasNvt4XA4 fpxsmxeyR2EmF6WyQBIDjS7Z6cRHmriCAogxApMY6HxrRG+5j6D8ljmYwSY2NqW7yDIiKVA3QJwU RTRGV9zeneKTiS1wjAHT2dT0hoveP6GhSWhoAZCo+DCQwkKNw3qfzxdrW7ZnRk4lM8C61BiHzwm/ 0zwlrih7/4mil/6x4sC/9opqNWpVwO3GF2aw45nB3/3G8ZfX5JdKtiYnZNPyiXNL3Ge6mT9pb07q W5lZtRlVYXkz6HsLiJ70NP9eNVKp2FqJN9cfIUQBJJyC6SziWrthcEp+UkTUdHncnjidLTRfT+x+ mMaBl5odBQL8fEvE7AjuxCMPRmBZJywR2fQG443W2vfJuhbP4MDuWSctiXcOTqJrg/CEwJvHw8va gw7nvVsv09DQxC20AEhU7D4qmYVaR7W72AF/NKitVBIDDc/HUSEgCKHfZZnrqC3/8LtFL/9j2WfP dHLKtzbXnCZjaHEOO5ET/MPzzrdeU5ac2hodlc7IJ0qWhM/31v+wVfxp72TjrHJz1SdpIvvepkQ/ 8je/ohyuVEoWbbY4TfANE+hSJyxtcihUGo/X1zhFFgjCcm1cR2TRxBsQIm8IzSmhP4jvubcHIOpc hJlsfGpBOrXhyRdQlzvDFue9A9X0TpgnAPx+rcvt3p1VEZwq7SBLmkNWu5P2YneIzYsKGiCjW98+ 7c7iUiNLzt2pLxoamniAFgCJitEJkpmoZ1ITt2GsAQyksKB4xBInhYAgAJujTVWfPp37r//TpU/+ pZNTsbW57rDZsLVl7GRO8LVfu//wvLzklGRsTLWhmbywLPh1b/33Whs+6J4Qz6gVMvdGE973LhA8 4RO/qBoql20sxnlZz0AY5Qogu9fkdDohhBI9nsaGgws2esmTZocAgFa08GwLTGKgwSX3nit5dwCd boblzWatTo9h4ZmtQBob1PcHPb7Q3d84JYPpLGJkVo5h2K4/fVyCZ3GpyTU77cXukDklTGaCoSmp 2e690E6eFWNuTwLUeKChodkWWgAkKkoLSGaiodn4FQA4AU80Ute6nPGQpeBzmESn3it47t9e/PCH 3YIrSoXC5bCHFmexoqzgsz92/OVVxYUzG3OzyiX15Lklzr901f+gTfxZ71TbnEYl92wI8a7fQ8ET XvHLipEamVRit9sjkUicP/m0dpjEQF1jiugeEUlSJxqpyx0+t9sda9NoEgBnAF0bgGlseErgPi7A LrUG7I49vpDHJDCFCfontrxeL4SQJKnexVAaG7RM+u8uNuqG4HFBUC5XPIjv7vKTp5tBRbvf5/PF +bUcD0CIagdhIT+gUCgikciCIpLKhgMLdAwVDU2iQguAREVioJKZcHJRHQrdY7UsVlAAXemlLjb7 zRZ7DJ+vAZd1vv1a+QffLnrtP/IvpqwuzjqdTkyygZ3IDr7+rOMvr8nLSqTTk5pNzVzVGvfn3cyf tos/7Z1qmVNL1jxrArznz1/E+lcpt5bjMNb/TkxJQTITLq7eWCWFELbMEgV8XKKy0U2Iae6OMwAv dsAcboTXq1nflLfPBnO4xLJ0L2dOKIIudqAzDW6FUoXjePSHWBjnjWI5PGp01Xsn594XgkWN6Eqb 0WKxPMj+GwCwa5FIZYFNpY3eBLgnNi880QivtRuirSf9IbK8kyxtDdjpTAAamsSEFgCJyooGpLDA zIomfiLsbwNC1DhFnRCGFJrYFAIK+z0LnderP3u66OV/Kt3/9GArV6NWB+w2vLcz9M7vPG88ry4u lI6PGnVGzYyh86OJ+qfahH/tnmycVW6suDcaid6/kA0/8je/qhquiOdY/zvROA1zOSGF6m9tkrYM RA6P6p6hawHR3A2nH1X3wRxOpHNUpjcYQ6GQ3o7n8KFo1LWHyw3repTNo8SDKpfLdasH6fRGLnfh OTxqXhYMhqmvOpfLGpjNpTpGVV6v9wFtMDqIfCG42u13e+kKufdgUQWzOETPxI0dRQhh7zKRwSa2 VBZ6QYGGJhGhBUCiMisH6WxyYV0Xz87c6CaVw40sSUyPfIENGrbmGGnP5/zyf7j44Q9b60s21lac DkdYuhk+kRN8/meGIx9LeroMeoPL7Jmv2OT+rJv1i/besmH51pZrQ4z3J4Nq1wAAIABJREFUvQsF /+wTv6gcKpdtLEVj/RPLP8BJWNULzzbYDUbzTdESilDnW0FZq9e929RJmsceXwhd7UfpbLJ1cMto NEbX5gEAVT3U6caw2erYq5nDmwD5vNDKuuy2OxiEUGXGjjeQaSx4uYuclOCBEHnzQ3UOeKIR5vOC C2vKB7/1kRToXsCSmbB33hfPN9J4gDUKCvihdYn85oKC3kEmMVDvrC1uF6FoaGjuAi0AEpUxCchk R5Y3dTd3z+OQDT2VwQETy6ZHaSTmdw/WF5546R9O/+n/6eJVyaRbLrsdW1/BirKCLzzj/PPLsqpS uVxukpoXKiW8n3df/36r+POehZFpyzwn0v47IHjC2/SKYuSKXLaVELH+2+L0w+ImeL3T5HT+bXkV Qti5QKaxwbqCjgKi2QanH5V2wAw20TwgMxq/VMB3RkpkcsjxZeteVfUtboLlzQ6j0fjVXTUAgMPp 6Z5xnG8OprBADh80zxBKMzElA9k8dLrBMzwtsd5/A+BtwXGCPYxlcamJdR8dCHQnMBzlCWBNu8lk Mt087QQJipuoqg6v00WnFdHQJB60AEhUBtZgDgdbkxri+aFldFJZXNg2YX7YiQo+p3mh63rbpcPX k58t+fN/KXr5n+py354d67caDMH5Gex0fvD3zzreelVRclIyMiybk8+Urgqe7WP8uE20r2ec368c rPE0/4EQPulp/oNqpFopWUqgWP9t0dphNo9qGdbcluCotRG5fFDaGrbsrOA6zdcEAJHcAk+3wAJe sGVIrtXpbxPtdi95Sgxqu917UnXA4YOZXMTv0zqdzm1fACEMh8MWu2du017X683j49k8mMEBpWL7 3NKGw+HYw/ueyxcu6yAKheSm2ktfFNuyoYcZHNA9obw17ApCJJoijgswmcZOnzcamoSDFgCJStcS zOMGN+VxLQD8GMgVQHaf5cGjdbcFQhhwWeY6rlV89P3CF/6++A//ueyTn9Tlvt3FrZCvrbjmZ0Kn 8oJ/etH1p5dUxYWbw8PSWdl0+UrDi/31T7aJ9vWMMfrkQ9fdzW+E+U95m15RDVcoJUtxXtxzhywo YRqLHJ1V3LY7T5DU2EYonQ1qejDrDgquP35ECDSvALurak9QCDymZ2xOCQuE6ITAPzQlMZpMOH77 +aEowB0js7mEyWx78KtjWQMzONTwrPruNYIhhARB+Hy+DaWjadzF7jGurMs8Hs/e7l9BCGUG7ISI Km8P+fz30Y34awKEqH0B5nFDC2vq2+4nKxoykwPGV2xx2O2Rhobm7tACIFFpnoOFPL9UaYznWA4A 4HERvNphd7lcD+P4kvGWqk9/lPur/7F0/0862GUbq4s6nc5mszkX53zF+cHX/tXzu98oigs3R4ZV W+rpSyvC3/bVPdEieLtzTDihGKlzNf8Z53zTK35ROXxZtrmciLH+d6JlDmRzccmW/KsPZoIg+xf9 KSxY2xf+GuY+buphEgMJRv3B0P2VkA+EkXASDqziEfxx83W8QVjchI7z/VPzG3b7Hevib+mJFCYc WnzQVhIQoo5FmMcNLm1odhgcSFEUhmFutzsYDD6MGQsA6F+OHGPAVZklnpdUYgJBofIucEHsUmt0 tz1ufEEqXwiZ/a64bUhPQ0NzJ2gBkJAAiIRT8ITAK1eb4lkAQAjPt8GyFpfD4djbI3usOvG5j/Kf /V9L9z/d03BVKZM5xoeDTUKs8mLw8/eDv/2J888vK84Urc/N6hS6xbpN7s+66r/fKvqoZ1w0ohqr 9Ta+hHOf8DS9phi5IpdJHQ7HY5YCeLkHnhV5tFrtttODJMn+pUAGBwhHfQ/SSikR4U3AFCaVzqaW Za77cvVm5TCJgZKZ8GIbsa4Jk3e47vxhNCsHQWzv++Y+PMa3YBaH6J2Qu93uu6zuBzBQ2k5dbAk4 XA9UOJ+gUGUPON/o0mgN8XP7cvrIIhFV1+v1+uKicWH84A3BNDbk9Wnt9tsLOkMIrw+SJxrCRpMt gSY8DQ0NogVAgkIBxBkDpxs8ap05fp6g21LVC86J/Tabba8O6HdZppsqLvzl/y165f/gX0henhy2 9vd40w8HXv+N+/fP2d9+3fr5B8rSs1tjIwa9Xjdv7P18mvnDdtF73ROCfsXAFXfTH8KCp9zNv1eO VKskCVnh554EwvBkE7rSZrLb7Xd6DRbGuaORLC4l1zgSPd5p53iC8GwLLGuyFArJio6QzblTR5ak 0JU+eELg757SnWzEc/lU9wL2VdEIIRpYgylM1Dnrw7DEKI1CUPB8GzwrcktliruvxwMIR9fxFBZY 2Hyg7rmhCMrhw/ouo9VqjZ9Lj6Jg8wyRwyWkGmec31QfMUtqcIwBR2dl28ZrTUnJLA45u26ld05o aBILWgAkJASFrg+Bc41ureGBWuE8Apgj1MkGzGg0PeCTHkIY8jqXehjVn/7o+Ev/ULr/6f7G66rB Xmf2Md/rzzrffl1Zek7Z161eXNCp1Vaz1aZ2rLHk/F/1sn/Z3l3csdlT62r6Q5j/pK/pVdVwueJx ifXfFp0d5AqgeFBz9x7MagueL6BYA95AME57ye05W0aUxaVaRpT9i75MLuid9+wwBEVtQ7kCyO7R Wq1WjdFd1xfK5lErCvdtnmIgjC62wxQmOC7EpVpPQsyuTQNMY8OmIdVX13e/ijdI5ArA9T6v1+vf 9SeqbTCJgTpH5fEWN2JyEiksKB53B782V8Q9gRCJpmEeNySRqbfdJjU4qMIG0DBsv1OlhwiBAIgX mRdvuAJoQkLZvQRBPtxTBCGKEJCivwiaW6AFQEKCk6imD1xschlM8S4AxNNUAT+iUOsfxE4iHFrs ZlR/9uOcX/5d6UdPtzMvbq4smWurvG887/rjC/LSs5K5WYvFEgqFSJIMebA1hkL8ymDtN1uE73dM 15Ua+L/HmN/wil9SDl+Wbi7bbLYELe65Q5Y1MJtLDM3eo0s0QQLRJJ7BISXqr8uSZ9MMzOGEF1dl Hl+wopM40YBrTTtqidAyB3M44ckFeSgUAgBYnOFTYvJcc9jp/lLO6JYRprIgs9uQwaGu9/vvnuH6 MMBwGNquedadICl0fRge5/uX1hU7CQaDEIqn8Xw+vqly7HrODG/AVCa1tCaPt/rxAICaXuKkKKI1 uh7j+8N9EQjD0k5YKrYajKZt7+ERAlzupk6LArc1dEMIhSJwSgav9MF1DfY1ucPcL40zMImBcvmA N0bIjfjDO0tbRljTB4ST1ISE1Nsp+uugQbQASFDCOKzoAhWtLot1DypyPFR6V6hcXmRdqt/dHQfz uebbr15695v5v/23pR//tItfLdtYtw/2eZM/87/wjDb96Pr4mNlksimcy9XSgcOzjS8P1H+nrf77 rcJ3mkfLzqmu/8ZT/y1H42vKkWq5XOpwfC2a4HYuwjxuaGldfc/SHA4vnsMHtb0+t/fxj3uOEOiU GJY32/R6PUVRClMklw/K2jGP7x6Z0BiO8oWwstWq091IgoQQrquxNDYQjPgDwRt+MwVQ/TDM42IS iaR9NpjJoSbW7pFmQFJIZoJjEmhwkBT1oBfylhEVNqBcPmiZJdQWgiDvfUCzG6ayELdXa7HstJ+r 3o5n86BgxL272r4UQIwReILvUar1cRg0sqbBM7mgZ+5xSwraNQYnyuKCxkHtXboHzsvxdA4QjvmD oRuKzhtC4hmYzYdpLCqdTZS2hWyOh1IILqHxY/BcKywROZj9zkJBJIMDBpYCD+Oi8ATRmRaUw8GK BME0FpnCQmdbqJF1wukjaaH7dYYWAAlJKIIutoMrHY6d7NrHlsktKouDz63p7ve+5nOY5tqvVn3y w6KX/6nss591cso35qZsg33e7GT/75+zv/07Sf015eambsU4V7bB/1Uv48dtvFe6mvb3dGWLJ8rO ya++6Kj/vr3xdcVItXJrKbrqH+diaa+o6QenRT6lavsM4FuhAOiYx7O55LzEGYfemMOHvEGwVzNc ZoJZXNAyrHK73QghnKCGVkIZHMAawlxe7C6fMqeEaWzQM6G4NaSKICjheCSbS01veqNCy+SChQ3w WpvOYrHY3ZELbeTpxrDKGMAiFIQQQOQLQZMLqm03xoQUlnfBbB5MZ5P5Alg3QC6rCLUV3HzBnYbZ DcmvqAWFBZ1oRAW84OU2Zx4fz+VDxhChsWwz5zEc6h03DsWfgFkcfGFFtvPq/iQFrg8Sx4W4xrib rsDeECxphVWtZotlbzp57S0RnLrUQZ1rClnsj0+37AiB7D64u7M9uQVSWdTkvOwu2zXhCNk6jaWy 4MCSDwvjRhe80A6zuXhlq7V/UtY25czmkmOrzse1VCiAyBWAdh+40xm2eWEY3+Y+prDAHD4lHlTZ HU65zlXVjWVwwIbKS5I7XSzDSbSkQZd7YP0Q1b9KSo1UANtmA7BtAWZxiI4RmUJjWZWau2dspa3B LC55SgwW5ME4vPPTPBpoAZCQBMPoTDOo7bI5HLt5Bj9KVjQgk0OML+p3ePfHAh7d+lRvTebl/T84 /uK/L/3o6barp9d7O43Xr3pSD/lef9b51quKklOSkVHFknqyZLnh+f76p1obP2ydLC+RCZJMjX9x CJ/3ML/vaHhZOVSukCzb7XYMw+LQ1XhIUADmCODVDssOMyxdPvy4iLrS5fd4dxmQTVJIZYXjEsru IXcSyUpSSGZCXUugYwF0LIC+FbChoxxeKhiBX+pZZkclraimF3d6Ag8+ySG6Uct8bkV1M9YFC+M9 C4F0NhCMhjy+7QNgCBLV9MNTQs/Glvq2hAG3Dy9pIQobyDV1kCSpvlWYzcGHZ2TBYBAAMCcPp3Ng oZCq6AK8ccAYRufbYL4QZHKpLC6VxaXSWeQpoVfQpxpd0AuG3ceFkQwOmfXFb+8yCoRgcAXDwjcu KAiRwQmPi1AhLzA4JbNYLOsKh3DUnc/HC4TU8FrY5SMxHGI49ITQjAJW98EcPogeKo1FVbUY9Qbj fTkBqxo8m0d1Tu9mP83oQtk8IB7SeTye+Lx3zckiWVwgnvA+NpsAwxvwTDO1izZnECHmCCzghxQK 5d1v4L5ApKKTKBAQ7bOhE42okB/sGpOqNTqPx+Pyhs80U2VtQZf7cdgEABCFCRS9oIJhZHShlnl4 phmebAQSbfCrvrvWjoqbYPe8/6sKqncZZnEiU4vyaDaazoqdaSJKmiMGq/+r3xSECMORxAgH1yip kXL5KZMbssdgJhcU8oNFwmAmh0xjA+ZQxOn50pamwYXyhfByi1mhVOE4TpIkhmF2p3d63X5WHC5u jBgscXol0jxsaAGQkPjD6EQjZPZa7rItGydIjSCbS/bPGnbyNJVMtFZ/9uP8X//PhS/+Q+XR5ztY l9bEAmPqQfdLv/Q99y+WD9+SXzq3OT2lleomzy9zf959/Xutjfu7J1hNasFfvNe/EeA97RT/ztxx UDl6Vba5+rBj/YMRtO1yS2xR20AyE3WMKnfYfA1C2LMYyeKS85LdRHUHw6h5FmVwURID5QkAZ5SU G/E7lchECHmCUDSNUtkolUVlsiOZ7MgxJkxioHQOPNdKzUjD4QiJELL5YFEjyuQQ6WySO+x/8Io6 FEBnWuClZqdG+6Va5gRBtEwFMthANB7cNgheYYZpbMTv1dhs24TbKY3BkpZIFpcaWgmdEoPzYqdS qYwePxwh57Y83AFbabM7jxc8zvNdbjbz+/Vt4/quSV3XpG5oRimVKaI9p4PBoMHkGF40R391l9Ex YbjUGkhjg8aJUDgc8WNwZAMWNKAcTmhwastms5EkGa2av6Vx1XT7kxioQAgutIELbSCLB1OY8KTA w+7Rd07quiZ13ZPalXWZ/z67X4UiVHUvkcsn1Ib79innFCCVRY3NyeO2/iwWIdnDkXQ2JVHfnuSd iACALrTBJAYqacbu94v2Y/B0M7rcbDKbzff8os2O0GkxkcRAx/m+8dkNi8US1QwQwsE1PJ1NTa/b Em6xGcOhwQG0NqC1gXUdmJLBxmlY0X3jgjrVBNPYKINNXGy0FvDDhUJqSxu4dc7gJCrtgEkMdFIU 1puct5380k54VuRRq9XRtwAAFIZgBgdUdWEW59/2JCFERifsX4MlbTCZiZIYKImBMjgwjY2yODin W722ITWZzOsyY8OoJ5MD6gewQOBGeB4FUO0gzOOGphZkt+bcQwhJklxUYNk8SjTmCYcfE61Lc1/Q AiAh8WEoTwi5/aa4XUW7icYG8wRU56Tx7gl/Hou2rfRg/m/+l9L9P25nnF8aG9Q08s1HP3E//zPb O79Xll+QDA9qlEqHwyFpUYleHrj+3Vbx573TrcOa/rNe7o/9gp8phi7Lt9YNeq3dZvV4PDtx/SFE Tj+clKIxCZAagdNH7dyb8YbQ2VZYJKKWlaEbceEI6Z1wfAt4/LGsAd+7ArM54YU11c4zLO0eolgM qjr8fv+N0i42LxxcgysayuikMByQFIyOW99FUmhaDk+IYSYHv9auH5+TcQfdx4XhZBZqncECoW3O /7wSFghRFgdndGnWNmQarV6j1as0hulVQ9OouazVn8yEVd34hAQvbkaF/MDw9FbzpCeZCXvmfeHI jsr13Am5GR5jIvGg6qs96SI4LhwPZ3JB15z3tmVOqRkdF8GTAu/KmnTbkHcAgMURqO0LHWOgFCZo GVLcmgpJUVQgEHC63CazVaszWK02j8cTCoXCX0AQxK1nCcfx8A5wewMt0/4MDjglJjN5KINNnG1w jM7c8P5vtS0QDI2uuGp73NUdzuoOZ22XtW9iS65QORyOm2bsLjROZwsfF1FnmyIm+/3tz3DGYQ43 IpNt06IufnB6I6ebyLNNYYtjm7XYxEJjh9l8WNZkT2ODpglfCPuSq0dSaEoGNVZ82xSUdT3M5lGt I6qdrCZACBWGYMOwbX5Zclu3ZqePPNNMlbcFvL4EaLQciqBVLRROgpJWkMZBKawbI5mJMthEIc9X KnZEL6jqDqegX7ewItEbDAq994SIKGogN7WB6JwhKdS+ANNYVG2HMYtLds9+KbHE7IbZPMTp0dwa x0sBMLIWSmfDNDY620Ixhsmr/aBIBFNYKINNXBTb20fkGxLF+JKxccTK7LVOzm+azGYMw6IOfTgS GVgOZnIAeyikt4VlJtixAJOZSNinNJm2qRhOEBR/HE9jUzLN7nP6aRIXWgAkJN4QyuLChkF9vNXR +yomFyhsAOIR852CjAMuy1xbTcWH3y965T9wiw8sMmsMZ4673v+j97Xf2N57Q1l+QT47Y7VYPC6f VhkYvKJmPNPNe61juLZbNVRtEr+r5Ly1Lkwa6B+cXDFuaoIKM6m0UCoLpbaCu48tIxBNw+MimMkh sjiRHB51XATrBimlOULcKwQTwxFzBGWwiXx+uEBIjq0HnT6yaxkeF8FkJqzoJLTW2AQd4SSq6Ydn GlwK1X1kXQMAOubxNDa1JreTJOn0o7IulMYis7lkvhCeaoJnWuCZFljSBhsmSY0VD4aB0YWuD6Es LihpdPVPyjRaXSAQ8PsDSr2LNRTI5FCc4bDd86UGC2obyhOgEpFzYFKq0+mDwWB0rZqiKBzHg8Gg zentm/cUNeBpbJjDCQ9ObVmtVpcXqxuI5PCoifWg0kKprcDoBOQO0ltvxepBF9tRPi+4sCLf1o/3 +iN1A3gGByzLvTd9aIUFnWpCRXzf2KzE6bxjoSQAgMsT4o8Eylpcq5uq7ZoDQAAARVEA7E0+A4Qw GAoPr/qLRVhNu2loWi5TaFwu11ddagghQRBer9fxBV6vF8f3QKBSFFhWhjI5gDUUdHt3mj+gsaOC BljRbDEajfHsWAMAllVYOhuIxv+W2JqgDKzBHG54eFbJHsayuNSK3HNzhnuCqGEKprHhSRG5qQnc NsNdAXShHRbyAzNLih2uJlAU5ff7v7rPAADsX8FTWGBZ6tirTQASIIsHdS/B8i7YOkdqrARO7GZG QYgsXqS2QbUVqKygfw2ea0XZXKqAF7zU7GL16NvHNP0zmv4ZzeCsemZZtSnT6fVGu90evaCcTmf0 VgYA2NQETzUShUKqfxm3uMlNA8zhw6oW45Zcd7GNPNcUcrr+tmM/IYXZXGJ0TnVbrTAsQsxL3A3D 9op274kGrFjkr2qzCfo1kwtKhUrrcrmioj0YDHo8Hr/ff9u3hoXxvsVgBofKF4IcHpXNCV8U29Y3 71jjy+TEi0RUdVfAtReRljSJBS0AEhJXAKayUPOI9tHXGbxfHD5wUgzZfeabq8tRIIQhn3O5j1P1 yVPHX/j70v0/7rl2Tp6dbHj1OfvvntMnH5Qx6+Sz00aDyWryLfTbWXxvQW049TJWeNIoYrVvCT8b ZeWXM2ezGL40Fp7OJjPYZAaH2vlIZ1NZnEhli6lvSjm9ahict9T1OHP5RKGQ6lyIeAM4hiMMR6EI cvrRigb0rwKpkcQiFEnB/lWYzga8HuWKxFTdjWVwqDPNVAabqmixNo2YcnhUSQu+pQtFiG0ChAgK bRnhrJzyh/a+AoM3hPKFkNFl3DZe5S6YXURhA1Xf57W7Q+xRmMaimocUY4umplHLtU57Zau1stVa Ivbm8IgcPijrpI6LQA4nwutRrW3KnE7nzZVsiqL8Aaxjxp/DI8s6I7ovhFCYQBXdsJDnn5yXOp3b JxxDCCORiFznaRp39E1IrVYrSZIQQrs7fKYZT2ff+OLyBaBlJmL33s2LJUgUIWC0+rjDjyp7UCYb 7xrZslis2/rxEEKjPXymmTjbFFEaAwYnGN2ERY2ogBcYnJLabLa7qykIYSiE6Q0Wl8v1yPxaHCcM JpvRaPJ6vbftJGxrYZQ9NIAkqa75UBYXXO2NtM2D9oW/jf5VYPMQty0qkxSq7oV5vND43JbX641z b4OiKO5oJIdHLssSOBAIQlTWCc6K3HKlxu4KnhRRZ5rwSUnY6iaNTljZizI4BKNbf6oxUizGt7R/ 8yZ9GKrsgbm8cNeYzGzeg3aTDi9ZJKKqOgMO94M6mmECSU2QO44KG0A6mzguCGVziVw+VT9ErmuJ 4P2UwaUAWtPCwgZ087mQxiLPixwtw8qldYVer3c4HD6fL/gFGIYRBEFRFLyFvx2NotbVgbK2YDob nGgEhQ2wSOCfX94MBAKjG3gqC8xu2KIqHQB0fQicFHo3pdvUaiMIIhAIuFwutc6i0uhMJpPL5QoG g7dd5nf6M7FwZGDJy+4zdYypxxdUUrnG47ljTxKKAgMr4TQ2EE2ElGbCF6IIKq4vTJo9hBYACYnd B5MYqGNMvfPaHbHCj4FzrfBqu/XWaCU8HFzorK365Ic5v/y70o9/0l5/Ya3+qv7NVxVv/Ln69MQF lp7VaxtYcA8uhQSDkYLKwLFrVPK1UEH18qUKfn6NJJlBpDKwJAYs4liZHdLOcXXPpLZnSndfo3da O78sNRgMPp8Px3Ecx/1+v1LvutYTSGWBIhF1rhWcawWnmmAqGyUx0DEmPMZEpR2kYILM4sHqVoNC oQiFQi5PgDfsLxa624elCqXK5/Ntqj2nm/BsHlU7QPSuUOs6yuUno/dfhx/yJ1AKCyUxUEUnvqXf 440CiQEkMVD/pOw2uXVPKAo2zeAZHJI5EMzgUOxulcFguLnOdHP9WKm1icecp0X+0kbz+OyGyWSK 7j7fdrRIJDK14cvlkUUiUqINEgTVvYxSmKBteMtqvUftFwBAKBTyer03fQ4IodHmH5o3Rb84Rp8r jQ2KxeSkJIITtwsJkoKrWnh9CFX2UI3T1LiEKu1EmRy8ZUhqMpnuEnYCIVSZgllcKo0NjzHRMSY8 zvcNTG5Zrdtrhu3O4aNOCAHgjoVHHg1YGOeOhnO4kSxO+NZxjAmLRNTIehjHb5xwAFH/GkxnU01D SpPJlBAutc0dOSGiKjsD93s1xQ/eEExmIk6PxmazQQgX5Vi+gExioGQmTGPDLE6kcUCu1WqVBm+x mCgSEbPSkNJCSQxUVS/MZONdoxKDwbAnwVoAwNH1cAoL9sx57je72hOEKitQWiiZiRrZhKUdMJmJ cjmha+368TmJRqPZVFgbRpz5/HAKE5a0UH3LuCdwD0mMECIoNLgOM7nwnMjZPqaJ3l7G5+VKlcrp dO4uNA4A4PZ4l7Zs9X2eYqG3fVhit9sBAE4fWdxE1XR5vb4AhDCMwywerO0wWSx36+QT3TncxV0l Eol4PB6fzxcOh6PLKHd7MU6Ud+LJTHiMgXL5gDtKuLzhONfnNHsCLQASEr0DJDFQ31QCCACcBKUd 8FKzw+l0QghJPLzUwyx995uFz/+74v0vXqhomuYKDIc/dr3wjPyjT45ftWXUeLNLjCml7uTrVHJN OPm8Oe/8QPnJk61FP18+9w1jzbfWGW+KRC01Ler2/oUtqdzhcGAYtpPI6a8SiURuc0QAAIFAaF7i qu12X+10Xu101nbZRQOasVnp+pa6f95+oSWYziJLRI7VdVkwGIyuAIWwsNFkcThu1LmjKEpv8XOG vOfE/lxuOJUF0tjoZCOo7qWy+SiHG2Z3a7qmjKfFkXQOFE+F/cE9u9u2zMFMNi7Zku2igInNg2dx QTILXG03yBXKbY8AAAiHw3aH22Qy+3y+u7hxBEluaX2nxXgun2qcDGfz4ZVWo0qt3WHn3duAEN6M jw8GQ0syV1l7KIWFSlrIwVXC4CCNTrimg01z8FQTTGPBE3zvhSZPkSCYziKz2JHmIbl+B34MAGBR 7ucO2FpHVHPLUoVK43DEY3XUuCKEhfVGi0qjv3WsSC2VnaF0NijvJCYkhMIMJEaYxUWXW8xyhTre +n/dCQjhwEokk0NNryfqNBjfgqksampBHn1SkBRlsTmXNg3tE2ZWn21kRmo2m3EcBwAoDIHTYiKZ hVJZKIWFsjiRjuFNo9G4uwt2WwiCrBuI5AnIFcWOmmRHCLShh8xRkMVDqawbI51NnRM5m4eUK+sy k8kcbf5IURQWDputzuFFe0W7P4NNFTVQE5vhIPa3SlkRAoZxEMaNYskEAAAgAElEQVRBAIN6J1zW wOo+mM6mrrQZ19Y3PR7PzefCPT3me0KSZCAQNFlsVqv1xpI/hF2LRDqbWlM4QmFyWQ2OMVD/pCxO gnh9/qBcbRqaN7L6ndlc6nwrsaULxXOQHs2eQAuAhERhBkkMNDKnittKGjeBEFb1gjMij91utyjX Gk9/cOLlf7z0yU876s7VcleO1cPiUunwZwVTpyuKGbZj5+x5v+JdfJpz/l9F595oKfu0Upj1xtjJ 765d+Y1CuE/VlS+f5Cq3Vk0mk91u36to5q8SDZt2foHb7Q4Gg5FIJBwOW+3eVal1fUtzW/2l28K7 AQCBQMBgsm8qLNOrZvGIpardfUqEVbTYh6alOr0+EAiojV7+iC+DA4TjIY/vbnXodwiGw/JueK7B ZjAYd7HCSgHQOhu53OpcXLtHWZhoUPs9DaYooLf6q7uxVBYs4vuXViSBwN6EmZIkaXX4Bxedpa3B bC6ZLwD5QpjFJXK52EWxs2NUsS5R6QwWpc62vGWeW1HpDTv1Y0iS9Hq9Xq8Xw7BoXO+DW/vYE12n vBWCIBwu/8Ci53RjOJuL5/JBNh8W8IJzywkQ/HMrTi9xvo262BJye3wJZHaUCIlqB1GxwCVTaG+q XwAAQRDRTTafz3fz5yRJ6Sz+sSXj0Jx2aE47taTS6/V76P1H0dnCp8RkWTvmcN1+h4EIhQno8EOV FY1JAG8clLTBLB5VyAvWdRr7JpVRwyYW1TKFxul0Ytjt3YWjMYQOp29xy1HWHsriUlf7iFk50TYP qvvg2RZ4phmeaYbFTTBfCLO5RD43xOrWSrYUfv9DSfW+bYPO5iEyODBfQJ5phvlCmMcNrUm2X2d5 9NzIIQ6HfX7/vNR3UkQcb6DmZaF7psPRJDS0AEhI1nUgiYGml5QJsZbGGgEFXG8ft6z0r98seuU/ cE8fWuGzjMkHak8OZFaa82vNqQwilxs+Vu7Pe457/WPB4NWBmYaeZXaBvPqnhtofbXWflm4smkwm p9MZDdd5BE9i+GVu/TlBEDvcHY46RjiORwM6DSarTm9wu93R1UQAQCCItc8EMzhAPBkMPPA+gMkN CxsAp1cX3WzZxREwLGw0mu4SMHq/AADsrkDblLt/Uh7dCt+TwyKEIITRvYiZDTtnwCHo1w7MaObX VCq11uVyRb8giqKiT7UEXb5NaKKbNgaza27D0jNjYfXZesbvnU0Rb0AIxzcjyUw4uerYc2/4YePw ozwBZHYbdpgRBACIRCKhUCgUCn3Vvd4TAACTm1gGB1R3h5tnqZY5cHM0TMHKHnhSDDPYII1F5vPC pWJ744B6flVmNBp9Pt9NwwiCuMufE/Vl7U5/56ynQECksagsDlHc4L3cbK1us1a3WWvaLQ0D2qEZ zdK6Sqc3RDdy9/wv/SoUBUbWglc77FEzxINKo3EPkiv2HJIkJRp/SUskm0s1z0ScXjyaTEXz+EEL gIRkUQWSGGhxbafFGWIIHg7Wt+uOVhqP/PTvLn32i4HzBYqjnzh/87T57T+cr9jKq1LXH2gt+mAu 7bimOK2pi8lR9p/3du0L83+Ac79laX53c7bLZDKFw49DSGJ04fy2H0YikaapYAYHNE4GH/DbXFTB dBY5OH3Hgg87Yc8D2aOeejRRdQ8PexOSJKOJCqFQCMfxRx+IT3MXot5YJBLx+XwejycRlZg/RF5o I0uaMYsjwTYBZuTgGAOOzW7FVa2IUJhsmMByuVgOJ3TryOMGSkR2RrexfUw1vShTKlXR5Ndok6xd fFAkElEb3OOL2vVNmU6ns9lsNzd1o7eLaDrvnv+Bd4EgCI/HE7Uhuk7xKD995wAALA4/b8SXygKn m8jpLXoN5fGEFgAJyZQUJDHQxla8bCBuC+Z3L3Rdv7z/yYyjucdqsdoDby+994bxuZ+Z3359rehi z6WRvGuBtI9nK3/Mbfic2VORuXjlVXf9tzH+U+6m1wx9+dK5brVSdls96ccSDIu0TAczOIAzjLl8 9925LEKiUASGIpA9BvL54S2pIp4rrNPQJBYQwiVlOJUFL3dGtvS7SQyNCRECXemHxwV+lUoVb3sX ISysM1jUWuNtw2A0OxxOv98f3bV78LK50T2NaJLDtju6MSFOzLg70dy2ZZmrtBXLYIOrfbjOFt62 WQRN4kILgIRkeAMkM6FUpoy3O3uUgNu21MOsOfizopf+8eJfv1t+8mpyHdH//HOqN19fOlbc/kEj +xcd1c8Pp5UHT+V0Dl44qrn2c3v9k46Gl3W9+Yq5Vo1s1Wq1BgKBu2/1Pk74g+GOWX8ml6ruwXW2 na54AYikJlTejaJ1+jM4qLzZGucV1mloEo4ITg4u+U404PlCqnU2/NUKp3HIihZl8yhhv+rWPlPx A7Ude9Uog2aviGZbdc568/hkkYjqWwr7Q/Tq0uMDLQASkp5lkMYiFUp1fG3MQRgJ+VcG+DUHf1b4 /L8refufm7M/Wv7wzb792ceuk/wj55reE7D+pb3+R21NR3oaa+bTr/t5JUdMV/7Z3PSOfJylkK5b rVa/3/9oovzjDQwLDy75MrngTDPZv4JrbVQgTBEkvFP4JQBoSgYLhPCEIFDdZq5pt1zrMA9MSd1u 96M1nIbm8ScSiSj1HuaAP5UFi8VU8wxhsBPEfTake2TgJLrUCU81+Fc3ZPEfJkoTz0RjOKUad2Vn MIMD6gcjDs/jEJFLg2gBkKC0zoMsdkSt0cWPAMCx4HIf+8rnP8n55d9d+ODJlox9K5/8Vf+rH8pe fLP1/WtJ10Hhr5qu/aixJbV3tr3DMHR6XHA67bqnuTJ1dYSvUircbvfX0++/FYIglmTec83hFCZI YqBcPijvIkXT1IyMkhioLSO4OTb1oGkWJjFQqdg+v7xls9lcLpfL5UrQMGsamvgHABAIBBe3nDXd vkwOkcqGzGHc7NhpUJDNC29ev2YX9VC36aZkMINDNQ0q43P5nybhAAD4/IH+RW8WlzrbTKjNdJHQ xwFaACQkoimQywnq9IZ4iI/HfK7Fbsbl/T8ofO5/u/DCf2p5+9mFV59f+cXrUz86KHrqWv0TjVXP DRyrIy/miScZxXrxPj/3R2H+k23cunRmqLNnxOFw3LOP6dcHkqLsLq9UZRqcM3EGbGVtvhPCUCaH SGfD20Yai7rWrlvflEd7ZsV/UCkNzWMASZJef0ChtQtGPHl8okBI9S3jDi/hx4AfA2F8myAWgkKT UpjfgG5evBkcWDdArqgJf+jeOesECaMHjx7/Ti/DSRSt1oLhqLgJnhM5N+M7SYwm4YhE8EW5r0BA Hm8g19WBeHA/aB4EWgAkJJwxWMDzGQym2KrwoMe+1MO8euiZohf+/YVn/6Po198ZfuaFwac+F3/n EvsJTv3TzbzXWzpzuX1XGZn1XnZZobH2SW/Db01dyfKZxivt1nw+tiWV0SvWt/G3ksw+n93hUups ixLLxJJ+bEF765hY1ChVmkAgQK/E0NA8YiiKCoZCUo2nqiuYxaVONoJojfnSDtCzRFhcf4sOChOo bQFm8uCFRsfQjHJsQTsyrxMO2080RLJ51NkWUD9EDa6RUhNl84JgGAIAMRw5/VBjg6MSwB0HFztQ 9OBnmuH5NsgaoYbXSbmZsntBKAIJClo8aGANXGxHld2geYYSTYEUJugYle26HDANzZ0gSVKq9eXw QW2vN066mNHsGloAJB4QwroheFLgNpnMD+78kXiYIu8zkxhCHAusDQlrDv5L4bP/puSF/7Ph198a /MkrTd85wXiCV/edFvarTa3Zoonq83Luezb2M1rGs8frdVdqxasDdfLNRZPJ5PV6K7rIc41evV5P +693AUJ4s5g99hXonRMamhhCUZTbExhdcV3vsV/rtNR0WEvEvjQ2KBCC+iFKNAVEU+BKP0xng6oW 8/KaNNpgDsOwYDCoNTr65x3VHe7jgmAaG6SxQGEDKOukmCOgqgeeEIM0NkhlUvk87EKj7WqHOXr8 0mZXAQ9LY4NUFixsABVdVO0gKGyAqSyqWOg50+jN4hApTHCh0S5TqOnlf5qHAQDg2gB5ujFkttjo B1BCQwuAxIMC8Eo/PCN0mi3WB/Se7VrJtSO/bDj5nlm1ucMrOYIFlnqY1Z/9OOeXf3f+uf8kevYH /T96o+k7xXXfaKr/ebM4RTBZd1opfM9e/1SQ8d/dgmeNXSkro+IiQaCyWR9tLQkAoAA62QQrW602 m+1B7KehoaGJLTiO+3w+t9vtdrtdLte63MoZdJ8QBgp4/gKev5DnE/Yp5ErVbW2wo43SvF6v1WqV KozDCybhsK2y3XNS6DvfaGd0G9tHlXPLN8rhR/uRR7FarZtyw9C8SThsL291nRJ6a9v1Y7NbGo3G brcbjOb5Nf2GRJ5YHZdpEou+ZTKXh6/J4rGRGc3OSWwBQEUoIkTs1aCIxGghhJPwcg+80Gi37qy/ 47YAipTNdF98+/8r/uN/Kf79/3Xmj/95Qlzpd9sjWGDb4XdaNCuj/bW5Ze99r+jX//eZZ75X/8s/ N3w/h/Wt+uvfEjGfYbUdyF8o+7Px2lN+9vddDS+YutNkUyK1bN1iNlkdvksdZGWb02a/sSXtDsB8 IWL36F0u156eGxoaGppHza015imKCgRDRotDrTVFh8ViuVNvvuhbor3SgsGg0+U2mGwGo9nhcETL 4UdLId/WmJwkSRzHg8Gg3enWG61mizUQCJAkGW01GG1VnhDPMpoEZV1HZXPJkUUL3XMmoUlgAeDV ers+mGh5Y3ivRvs7o4Ppk9NlM8vc+RV+/I45/mIxy3+iQjp8dWCZN7e7g/SfZZW+9Oq5Z19oPsnp LGaVvvT66V/84urbH9W9//m2o/bNw+X/+lHp945c/vbZ6ieqa59g1X1XwPxJfcMfzgwee2v19E91 NT+wcn9j6ExWTAnUW4tmk8nn80UiEQBAhIBX+8GFJrfZYo8qFrUNZPNgx7jW7/fHeh7R0NDQ7DEA gFvL2+/wXVEPfufl8G++/gEspaG5b0wuUNgAGkdsD9J1nibmJLAA0C6vnv/VvtPfO1q8NyPp/HcL qr5dW/stce23mq7F8aj+YUfmaVfqp/OXvsG8+i3xro9T+0RL3bdb6r7d+sVoqXtiu/Gt5tpvimu/ 0Vj3TeH1J6pZT+U3vHio56O3x1JeWT7zE13VN0z1zyhbjsgmuPLNpWh8fzTO5+Y3RQHIGgXFDV6d 8caWxaoWZnPJkXktffugoaGhoaFJIDAcnGsFFa0ut9tN7zUlLgksAEgcl7Q39Zwv7DqXv1ej7XSu ODen4Vi+MCl+ByutJLvakpvfXvd5uiApb3cHaUg+3pZ3abTk+mwZd66cN1fOmyplj5ytHTp97Usj t3Tw7QMDv31p6Hc/m9j3rc2C/2qs/K+2a9+wMH9qELyu7UjbmhDKpJsWi8Xv99+pcS+EUDwNCvkB tc4SDRkclcAcDja7oqHT1GhoaGhoaBIICCF7lMznhy0WCy0AEpcEFgCUYgG7+Cvf2Sf3drhP/8BZ HNdDceaVomvqq6dKVPnfdTzAcVynf+A7+5T/y8P35eE/971QxTewa/8dq/+Gi/1To/gdSV/F5vyg Vr5q1CntNqvf74/G+dz9LtCzArI5YanSFBUA4hlQyA9sSOOokRkNDQ0NDQ3NThjZINNY1KbcSD/E E5cEFgCEUxnqesfX+LxX9NzXaiiFHxYyjIzKCwbWrz0P+bPcopf0jX+Vt2dJh6/JF/s1KoXT6QyF QgRBRGNbd6j+J7ZAGovckBkIgoAQXe0HZ0RelUZH1xCgoaGhoaFJLBRmMo0F+meN4XA41rbQ7JJH JAAARREEQQKIEEIQEET0f/CLfxPRFob3d0wA7Ha7QqGQf82YWtbkcCNXG1dWVlYewcdFq8tFK1hH O87uYgIsq6ljDLS0oY1EIhCiM83gcqvTbN6DPgY0NDQ0NDQ0jxKbFxxvoPiD1kAgEGtbaHbJoxEA pGaxd98fnj0rnEUUvtVc8fZnhz/c9x67f0M9znr/g6Of7nv/XOPk7g4Nv37o7CCPT7WM6KKFpR8B Dz4D5GYqiYHGF3UYhlEApnMgs9vkdDof/Mg0NDQ0NDQ0jxIsAi93U2UtbofTsydOAs2j59GFAJ3Y /+xZ4WzEZyv67HcVbSvTzKJ3Pj1+KuPdgvrhxe7L776bp3nYFjwuaGwwm0d1TugSaOvN4qaSGKh3 2hAKhVwBkMRATcMar9cba7toaGhoaGho7g8IoWiKKuCFdIbd9yOiiS2PWgCE3JaM95+7PqTZaCl9 673MjENvlIjmlQusD97MUNzhjQRBhGhuYV2DZbDJ9hGZy+WKtS07xeoMJDGQaEBjs9nWNVgSA3WP btrt9ljbRUNDQ0NDQ3PfDK8EkxlwcU3t9XpjbUu8cxeNBEHYrNPpdEZf5FF3VXvUAoDC3DVZH+TX tbJOHTx0gsU5f/jo2YaGiqwPUy/faTVYq9WO0NxCQ/dKcn2kktHV398fa1t2yuDQaAqTOls/19XV xWiTJDOIWpa4r68v1nbR0NDQ0NDQ3DctPTNJDFTJHqEf5ffkzpkS+PpwzQf7szI++6CQO/iw/O87 8OgEQK+ganBJhxBCFkl1dVXVdZ7G6kc+DetKddVV1pL+vsPBcRJt6uGS+ms3WuZAOoscm1fjOL73 39PDgaRgYQO42Oyd3AzWD8NcTnBTpqO7iNPQ0NDQ0CQiWATkCcDldt/0VjjmflE8DJWVIsn7LGwY sFakfljAGV2brN2/L33L9XC+qjuQAGVAt7a2mrZDJG4tPMeo4Q4k6Ci91na6omEXb6zmDFSy+thc oVgs3vbMPBrKy8tFItEOXyxuarrC7q1iD9RwB6rZA1XMTr4gxvaXlpbG8NMfEB6PV11dHWsrdk9l ZaVAIIi1FbsnoSePUCi8fPlyrK3YPdXV1TweL9ZW7J6Enjwikai8vDzWVuyeq1evstnsWFuxe+Jq 8ojFTTXsnuhjfYfj1CV++fXOmHtfux55Z+/mc17n94gatz9XHo9newfXZy5N/uCEYHJzhvnJR7QA +Ap+v990B86ePXunX8U/ExMTDQ0NsbZi95SVlalUqlhbsXsSevIsLCwwmcxYW7F7ampqNjY2Ym3F 7knoybO5uVlTUxNrK3YPi8VaWFiItRW7J6Enj0qlunTpUqyt2D0NDQ3j4+OxtmL3JPTkMZlMTCZz cXEx1lbsnl2f/zvGO1DBvusFn+TU1J45dqSYEXy0UREJIADuwuXLl2Ntwu6RyWR9fX2xtmL31NXV hUKhWFuxexJ68uj1+paWllhbsXv4fL7D4Yi1FbsnoSeP0+nk8/mxtmL3tLa26vX6WFuxexJ68mAY VldXF2srdk9/f79UKo21FbsnoScPQqilpcVgMMTait3zMM4/RVoHmpubm7tlTt+eH/zu0AIgZtAC ILYk9OShBUBsSejJQwuA2JLQk4cWALEloScPogVAnEELgJhBC4DYktCThxYAsSWhJw8tAGJLQk8e WgDEloSePIgWAHFGYguA6urqWJuwe+Ry+cDAQKyt2D0MBiOhBUBCTx6DwdDW1hZrK3ZPQ0NDQveB TujJ43K5hEJhrK3YPe3t7QktABJ68mAYVl9fH2srds/g4KBMJou1FbsnoScPQqitrc1oNMbait2T 6Of/NhJbACS0lAyFQi7Xo0353lPMZjNF3WfFq3gioSdPJBJJ6BV0q9Wa0EVgE3ryEARhtVpjbcXu cTgcCdQE/ask9OQBAJjN5lhbsXui3TNjbcXuSejJgxByOByRSCTWVuyeRD//t5EIAsBvKytITs05 djir3OXxCM5kH81J+/hYgSWaL0FGZkTlBzLSDh5MG10zavuYHyelHjh8pGNGG2Ozv8C+Ppp67Eh6 yqdlwmmnYvF40tG0rEMnr3WGokX8wx7+6eyknNSPjxVafWix7erHH33KmpTH2OibAFI/yP4kKfXg kcMtk3LLcuuRA2lHDx2q6V2M/j6gXrjxF9V2WbQreWkpJ7IPF1Q3BcJkbA2/QcTbdKHgSE7avkNZ Zm+wv/bM0eTcjz9JWrYFEUIIUZbl1sMH0o4eOnS1d8G12Z2eUZBy6PMLrdMxNvsLwm7ZpfSktIyM 9BKmyaWtP5WUlp57JP+yPhC9hwb7as8cTcn9+JOkZXsIociquOJPf/poUh8fJx8B21rnsYNpSUcO V7TPuE3j2YeSUo8kFXL7o78OexRlGUlpGRlp5xgGi/Fc2gfphSU1LJHJHSfuXWiEfeFIcu6nnxyZ MdoX+q4cPZR96KMDXXILQggh6DaNZR1MSj2SdJw7EPaYz+cnnS65VFXdYImx2TcgIlb22WOp6XmH c0oVTldrdXZaasah5BNLpujkx+d7q48ezj700YFuhWV5sOHy5fL8tM8+ST9vcMdFgxGvZSr/aFLa 0WPZ17uCTumZzCO5yUlJZ4QhiBBCFBFsqc5OS808lHxy2eibb6o8kJpx5Mhh8dideso/YojVkboj B7OP7P+8ZUNvWB9POnIw9+j+SvHqjUvXKT2dceMv8nhVZzIP5xakHc2ssgVhjA1HCCEEyEjHtby0 lIzDSQWzWs9YQ1lSSmrSodSBLXf0BR7lZMGR/ZmlrUECGTcnk44czDv6cYVoJU6cu5BbeT7naG7K sSOnOHa3rbo4NTs9+UBalTUSXbSi5HONhz74y+VWGULQsD6U9uk7J5iPug3TXbBIZ5OOHMhL+vgS f96pW89OOpSZdfDklY4vqsS4266d+Wjf/ikVQiFT9cmM43k5B9Iu6dzxceeHYKqpMik55dihY91r Tmk/+0hq8tEjh4SjqujvQz5JacaBA/lXHQGEWeUns9OPZx/KviB4xDVw7gQecNWey8jOSPk8pczg 8Y7Vnz+YlbH/8+Q17Y1mXqatkawD7+Zd7Y7+Vzfb9emH79eOSOLi0r0f4l8AQO0Y582PUmeXZtM+ /MvlK1fefPfAxOJ88cF3yjpGmxiM7uHJjA9eYY3KOScOfpJfWXzwj5da5vqqsvZl1d6h7Oojhmo6 f/ijQqZyjPPG/qy6Myl/Pnzettrx5l+P9CzNCK5fnejrevOvByYX54oPvlPeKSHNmykf76sZlsTa 7BsQAefZw3883zg9fDXv3cPnLuZ9mHWlZ6Lp4rv7CiZW+liNAy2V+W8euWBbbX/zr0eGpHK5Ur/c dvmtT7OVNizWtiOEkGtz4N33Ph2aXzx/+C9nL1/f996HgrGl63kf5tW2djcz2wZXavP2Zdf0Togv vPfhcYlZOjo1dj7jsxLBXKwNv4G8p+q1t9MV6pnP3tpfef38n17dv2CXpL//3pXm2WbW5emx/o/f /VA4tlSX+2F+3aBWNp2V+tHrz74xrImLxwAkMHbR/rTy1pnOyr+8lVZdkXLgeP3cHP+dP342OrvI 4DdNispefStVrpk78PZ+7thM/me/rxBP2zzxsj5HmpcP7fuQNbTMLvo4q7g8+ZN9Fzpm2qtTjhSx Z4Y7rol6O8tTDhxnzM3y3vnTp0LO5QPZFxckMq05XkKbHMstf3zp/RmrNHf/B+fqru576Y3eDdWF lA8K64b7RLWDw4N5H++72DHTXpVy9P9v707/ksr7Bo5ff8X9+P5L7kddr+u+ZrlnampqGieXdLJ1 Km3PytRUwB1zTc19Y1NQRJBFBRRRNncRRQUXRECR/XzvB5Y55pRSk1z0fb/Oq+zM4TcHZkI+nt85 J6V2wwW+zVXKnehC1pDnL29a/wURge7ie/GPiodU9F9+iKooJ8VcezGsEsec/qGtd+J1bcPIcGf0 Nz/xRvWU25EplWJe4cNrKdnJiddKhePHvesAAGA3pF29mE6XcsvvXUvKoT69EZfaMsarvHD14YCo q7CCyaOTYq6nD4+IYk7/UPa6JuLiHzKV6k7ED3X9ITFBwmkZiv3mVNvwJPVB7N38yoSfv6ni6+sz /rhMqhvi1NFFWjfY6dk3r6Y2bXodzaQ/Lj5vHu+uirzyYGIlJP7+DnPyYuKfjmhlcad/KCgri754 U66aTvj1+9rOvua6ugHDKsByysUfSE2jO9sX3v35XlHn8e7zHpv07ITIJ/UTPbVRlxNKSfd+up6t V7ZHXrwuEgvLqHXzPr9psjPu7BnRFIB7a3bWsDjJPfuvs/yZrePecwAAv89499w3JZxxWnZidMor Uvy36fW9oqrUH/7InZAwG1l9DvBIG55H3MpdcYDXsSwR97Xk3rtLaQiRfplVNF2MviLVzN/97fvc 143XL0a29msr7l94VMroYjaw+qYAoOxxxM1cJgB4tvSF96/9+NPZ/C4NBsBn5x9iUS5cS52fXcy8 eeHB4ydn425P6OfKH11Ka5Z7AayL0vhT/9uhI6Slj85cT0mI+Gdt36KGnh15I3v1uHcdAACsxfcj EwuExHj3D5E3U2/+Gp1cDWZF9Ln47pllAJgS1Z2NS5jUz5U9uvSiWe4NsQBwWs13fztRKZobay84 d+HenasnKTSFQVUX/fPdnYMUTaQrMc9rwDwYdS6eP7PsNA7fvxhTzBreDo2/yfp+2vnY69ppY83T S7fuJ5+OuiSbmOW8TLydx3IAeDfX066ezKINzapqo8/em95eFfPoz25eym6SHveOvyGpfv7tVRJB TN8/F5OSmvCvc/eXYIV89UIeSwcAFm33uahL8slZTmHi7bQiyvPHVYxXESd+4k+7QuGdyO/aJN84 lVbfvzDeGvntpaSk6ISC9rl50aXTEXITAEB/beq/L2cQxMzD8zEVMo2yr7s86+7VpLyF9dCox3Hx hehYkXaWV37/5o2H56NiauTjg/TM+PtFK04Ar6s2KTqRyp6bE1468ws5+8mPP8dkpz34OeL2TGj8 7MHEKzvx0+35wGr+7Zj7yUknT8Qo3d7atLh7LyUAAMbhy1ExtfLxQVpG/IPilS1itLM44nr2iis0 5vUF/C3JF29QWo0m2aUfzzx7lnjpQcmsZTEh4kSbOgAAloynmPUAABXtSURBVGH6yRMxwx5fTWrs fSp/oCYjMi7+3M9xdFVonB6wpL15MbpcMjrMzo5PvP8wPu5BiXBF1fFb/O3RBQcQBI+aGP+wdNay kBBxop6ve3Ij9sHje2e+OZHHUh/3rgMAOMY4p05ESe3bLZRr8Smp0f88ydY5hJVPfkvaPQN4NwDM L+/+fq9IsKrmXoi/pTU6jnO/3xKVPYy9nT9rX7t34cTDlNSYuKfjJnvGtZPF3N0TAEI5AFZKH8Yn FHStavnR8XFJN2JjnjX7Zgdj4y73jr6Zf/UuAAC2raaS1JuJOc3rR70N7d/D5x2++M8faUqLtC7t zJ3kxNMnSruWFjqLT8SmvP3G9C4AAj63SsrPf3TrCbVxNSTiETTCguio+6PLrqw/Tj1IL4yN/k00 usLJuZWQw9h8u83bACAYBUkFJfUJlyJzOMOh8JOTIwn9AIC1QcaZyBu8/s5r53+pb27+9Vwcu0/w KObMq555P4B7ffHp7ydfcmUFd2ITyLW5t39Nq+9uyrh+OaUpJFoYoPvl3Yi7BfKOwnNXnrcWJZ++ mDzaX3c2+o5ycRMANqeE58/Fcfr4j2LOVAiN/hALAL/TWnAn4vlrLi3rVtzDklcZl29l0dvLn124 RtmZgT7QmHE69vnOMxIrxY9jIkp40yHxJgQAAFv6vuhfYxkS4dOLJ4sb265eiCphS3NunctokLkB wLvZmH75djajvexp5HWyZkKmmJjl5t85nVhw3Dv+xnx/5amfrskUguhfL9XSyiO+/0UwprjyW3Rr /ywAwLr6+m9RpRxp9s1zz/PqqqtfUXMf/3ji25zmQWcoBJjfRc+6diO9obM6/XxsclNFUtx9Kr+z 5Mz52zsfEhZk1SdPXpENCS9G/N41bgIAg6zhbNSVYX1onBuzMXYnJprKklETf0kpqn12Lfp5vbAu M/5OFm3TCxDw9rx6/PuDQn5n8c+/3mLW58UmkhVy+m//d1KoP+49BwCA9UlexDdnunTKm9HRJa2t l3/8jiFWPL0alcUYAQDYNqZfjUqpF9VmXLqbTV+ZV92LOfdashAq38OIQG9NcmxCdo+g6uTpq20t RVHxj6U9tHOnzstNBAA41tSXf/yOKRl6ciXyRTX/3oXvaMqFqmcX49LqjnvXAQDAtZRzO/bx657m 7Cu30ytqKYnnH1QqWnOjb6YZbG4AUHNfRl1OkgpoZ0+dHzATALAx1nfh5KmexZB4+9x2TFw7+V0T X/7iZszzKubjyG8LaYPFjy4nlOx+VNgNABebevfc/VdDtLzoP1L0tpCYBDQqfBUdd1cmbv/l1C+1 tMaomCsiiezSTyfput0JeqEcAO6ukodnEkuGmYXR1562lqZ+F5sy1FsTGZugettX7wLAsVyYdO2P Qsbx7vFeAZ/lWfS3OY39lcnXr+W1vrz1U1I5i1bw4PzDV+8HgGtlit87rmKXRsbe0oXG2SWLas7F 6LiePuWV0z9WsjkJsdGVgv6cq6df1A7u/s/9NgDsnNqysjzShTMn41MqN4hQ+MnbEfwHBAD43Nz6 QhIlM7+6w+P1KpiVmRRSRnGTy7fWVlUl0S7ND3Wmk0mkvNIpk9050ZuWSUrPpmoMoXIgfmtZX06l kEgv2AMGz/piY3EuiZzeJFDb1qYaK0onTN5BRmUmhZRR0uT2AViNVS8LeLqQOdGEILYn+9MzSelZ BSMzqy6TOi+TnEnK4esMcypedSvfsrTQULTzjDQmbU9GcnJWLrWklrFqD4lpxBDwqtg1GRRSKrXW 5fVPiOnkTEoapWzRZRMzXrf3610mVW4GOYOUw9cZPQZFVnZ2ZmZ2l9pw3Pv9hn/bwqkqJJHJ5QyJ w2MT00pJZEphTafZZmFUUxV6y7iI9uYZuX0AsGXT5D0jaVdC4jMEAOE2awvJlExSdqfK4HXpK7Mp pIysZunY6oyyqoFuWjZ1VhWSyOQymthiW6e/puZkZbxmy7z+EHkb9c/0t1EyKS/IJYbN7YUJfm4G JT01X2PdmpSxy2hCr0tfkUUhZWQ1y8Z87pXGoqwscmZRY68nNF5+IrDVzywnkbMKKttWPS4Vv45M IucUNcytOXgt5YIRw7tntLFlWZQVZJaFyskjAADgdRlq8rJJGZQ6idbvWaOV51IySWUMuc00+bq2 QW+yqPi1ZBI5t6jRuLGtFtSRs7Mzs/IVkyFyCkbArBfnplMy0vKUq3b7sqE0L52SkdapWLaM9hZW sCyeVVpZDiWTVMYY8FsMtRUleVlZNd3K0HjfBILwaUUNFDI5m1pjsHr1Ci6FTMrKLR5f2n47BWhb 3lZR2trv8oFjZW7n2XUMmkIkIP0eC6syn0IilbT2uzxufnMxhZyZX8Vzri28nQK00VKYzuh/c7yo s5pSzR0+3n3ea3NtsSwvPSszrV264LKv1BZRyJT0xm6Vw6jZmQJkXRouyqLoTOA0TVApLzKycqjU 8tHlkKgvADAM87MpJEo2VbvoWZ2Q5mSTSVk5A1OWt1OAfBO9zXmVbNs2uB2r1YXkrMwXdVylNzTe OQM+j4heTiGT8io67C7vrISZTiGn5b5asa1K3k4B4tfnVrAH3jzAZqorKeCMhMp5p4f3nxAACCGE EEIIoc8EAwAhhBBCCKGvCAYAQgghhBBCXxEMAIQQQgghhL4iGAAIIYQQQggdP7/P49zef1M0n8e1 7f7MZ0ljACCEEEIIIfTJCIIgCOLt7ztfw4G//3nD3bXWxRnRoHHnmqK7Wzlta+Z199sN9/6b3j0c 9v/5IzAAEEIIIYQQ+lTTg6J23sCa06qSi1nt3LHRfsX0ukHZ18blL25uynrau3uH7ZZRhXJC3ido 75KsLGkaGtrYzPZJo1kpFbHZvYuzU91CbU+3zLaiH5IpBWz2oHbJPD0iG5nt7WrvH54kAAB8RrW4 vUM8NamXdHN7Otrkk1YJu4nF5rQymSx6y/Dcxy8pjAGAEEIIIYTQp9qyz/I7+AbLUm8Pn0HnLPmW u9uZwsFJm0HZweKojJvafh6nU7LomO/p4jHZgiWTtks+MT0oUkyPi/ldDCZvQT8hHtBPyvltAsnC xta0eoAvHTVPj8g06wvjSp5Y7SYAYHNQxJt3gss0JZKPuSxT3cPjkm7u/Nxcl0A2p5Mqpj5+UwgM AIQQQgghhD6Rd35cyeNwJw2G7i5+J4c9tWzTijp1Sw6v29rF4dt9fotByuCpvabJjk4Bp5OrH1f2 a+fmNAPD08quzs6ONo5KNzWoNrlMmqZ2qc26rujr4Yq0a3NjI+pFjVzSIZDarOZx/fzq1BCXK5yY nlf0Cnq6uNr5LaW0d3nJ1C9Xm6eGtXgEACGEEEIIoVBgmRnRGNc+upnDrB4ct/6tt9bGAEAIIYQQ QugrggGAEEIIIYTQVwQDACH0VfB4PFarde3o1tfX3e4DTqgKnQHX1tbsdvv7V34jCMLhcFgsllAY MPRfxvX1dY/n4xNnEUIoDGAAIITCH0EQHA6Hw+F0Hx2bzabT6U6nc++Afr+/vb29o6MjuAEZDIbL 5do7oNfrZbFYnZ2dQQzY3d1dV1c3Nja271kvLS3V1tYGMRqPx6utrZ2amto3oNFoDG7A7i/1Mvp8 vqBfxvb2dhaLdWBUIIRQmMEAQAiFP5/P19DQ4PP5gngsQRBisdhoNO5dub293dLS4vcHc2tGgiD4 fL7ZbN670m63MxiMQCDIk748Hk9zc/O+lUwm02q1Bjeg2+1+f0A6nW6324MbkCAIiUQyPz+/d6XL 5Wpubg76ZRQIBCaTae9Kh8NBp9ODexkJguByuWtrHz8/DyGE/tNhACCEwp/P52ttbQ364VKpdN8n V6fTyWKxgh5QJBLt++Rqs9k6OjqCHhAAGhoa9q1pamoKuigOHPD9NUcik8kMBsPeNS6Xi8lkBj2g RCJZWlrau8Zut3M4nKAH5PP5q6urQT8cIYT+U2AAIITCHwbAZxkQAwAhhMIDBgBCKPwdIgC8ExOj k9rR7YNmCQUXAARhGx2f8wN4nM7RPz8cA2AHBgBCCB0LDACEUPj7cAD0Nr2Szs53dLRx6W1W1wEb HDIAtua1pdRcci51aGoZAAIBI6tD6gHYsljaZLK9Wx4yAPQdlcmZha3dau8hPsYfJgB8vfXu7Gxv c6lHMgdOs6e+3EO663r4xNPa7KakeZc/MuABAWDqhaE0mBDCDB8AYIIO2hQQXgJlCiiSQcGCwLtL CR0mAJxryo782+x8srC9aXMbbH1FzdSU6tv/bkyPplFu1We+2NhzbaLDBIB3wzlYMCJL1/TWatwO n31pejBzhBcv7k7VLRls2iz59J7/DhgACKGvBAYAQij8fSgAvCstheVsterTA2Ckq3nQ6Pa5Zpvq W5rqSqllxXU0XlMVtSDvVY04mABYkLBVCz7loMi27dEIma8qy4uq2cN9bRUviwpqRfs2/ngAuOY8 bAnhBTDLPGIDbJk8bBGY5R6RHjY3vOyGoweAB6YEsHMK7zRv/6+EB6Z6YM8JvocJgBlRk2F+AwI+ Dat+0wk2afXoLKFj1VjWN73b25OcSr31aAGwPDg9M24H8E92qd0On21xZl5mmeseXbR5nIYlacbA 1J4BMAAQQl8JDACEUPj7QAAE5hWcTml7h5D9yQHQz2bvbNSW96JSqApYB7KfZzYIZ62zA1VdwQTA DOfVs4zCsoLC/jljQ3kZRyAb6W4rKC0ZnNRz6Yx91/f5eADMyz39JgAAs8yVlOzJSXYV094EAIBf xDx6AJhgevTNl9JLoEyBXirA2wAIOMGgOuoRACW7enUTIOAbpMbSs64zUiJ2AsC+5dAxs9ktHf49 Nyc4TAAsCkatJjeAf7JO3pekEj2VzuwEgNU1L5wdZ09hACCEvkIYAAih8PeBAJiVtaaSMpOeZJZ+ vgCgkcnten0gYHydQekaswY9BWhBwlYtAMxL2cy+msayoqzihgYag0kzmNYkbJbpzxsfKgAEEwAH HQEIOgDGh958+f4RgLVhWLPs3fowATDIoJo34P0jAPYtAL9L11I0tXG0IwDznRqL0fX+EYBplUkr X17pwQBACH2NMAAQQuHvAwHQx67VLqyOi2qS8mifGAA6QXPPmM21PlKRU9XAHw5YpJSUzHrBzPqM tKLzEwKA2KjKyGqRchkCJQDoJOwgAyCw5mlqIRyezxcABIy3gcsJ8F4AOBdgbv+NyQ4TAHP91erh uQOmAK1ue8E3zcpQLrx7RocJgLWRWbVk+f0AGJVOy5LVgngJv8zkfXv/XwwAhNBXAgMAIRT+PhAA A2KJ3U04LMNFL9vk4n6H54BtDhkAHssC7XVJbknNgtnEa35FrajmiQaZdUUvi+o6Vbq9Wx42AHoZ 5JzC1m41l9k0bV7sbq6glrf0yUVmi00l7bP8eePDnAQcGOV58sleRr13xAwui7d/GNZHvSNLAOAf kfjWPzLgAScBW7Uwkg4TQlgYBIB3v85Ww8ATUFZB4GjnAHidM5JXD9n5FHlvt9MNm1quYYmY7e0y ajo68q62vW5wHXEKUMDtHX2tk6VrFW0zXqd/a3VxWWc3Kwyrmz4AsCoXFvbc+AsDACH0ldgfAMvL ywwGoz2EMRgMfINGCB0J3gfgswyIlwFFCKF9Njc36XT6cX86/hAWizU7O7tvt/cHwMzMzNjY/uO2 IUWr1e77FoIQQh+GAfBZBsQAQAihfdbX1/v6+o57Lz5kcXFxeHh430oMAIRQ+NsJAGLPJeSPRCwW 7wuA7e1tFosV9IB8Pt9sNu9dY7fbPyUAvF5vY2PjvpU0Gs3jOWhKU7ADtrS0+HwH3SntcCQSydzc 3N41OwEQ9MsoEAj2BYDD4fiUAOByuRgACKEjCcMA2LYZaKUvSSRSRt5L5cyayzHRUCP0BgC8G6yS Zv2iKj+HkpJ07+adxyQSacCw9WWeBgYAQuioAoEAjUZTq9X6o9NqtQwGY2NjY++AXq+3tbVVq9UG MaBGo6HT6Q6HY++ALpertbV1dHQ0iAH1er1AIJBKpfuetU6n6+rqmp6ePupoMzMzfD5/YGBg34Bq tZrH483MzASxh1qtlslkWq1/unjpTphpNJogBtRoNAwGw2637x3Q7Xa3trbqdLogBlSr1XQ6fWvr C30vQwiFhz0B4JbUUh4+SyeRSCQSid43Ns6ruJeUuvPHqnbpYW7p+Hc4YgAQzraSdKZ8HgCsY91J GZXG5eEcMt0TAHCvlT8p2PkxzmxfI7lK/DftMUEQuz8Z2v0aAwAhFAS73T40NDRwdAqFwmw2v/9T apvNplAoghtwZWXl/QE3NjYGBweDGHBgYECn07nd7vef9cTERNADvn/0gCCIsbGx4Ab8q5fRbrd/ 3pfRZrMF9zIqFIrV1dWgD0cghL5OewLAxSl8zNbZ3v4Tv7IxtVy88IX3Z+/Mz52vjxgAFu3zJ0VL 3nebblmHEiNvvSwuKXmZcz3q6RcIgMXFRbH4zeAajUar1QIGAEIIIYQQCg17A6A953Zian5JSUlF A33R5lI2pl55RC4pKSmrqBpfPugi05/bzjTInc/9c3Nz/f39BEEcMQDW1M+elJjfzPb0eTyBLauS nFq3arXZVvWFD3O/QAB4vV42m83n8+VyeUNDg8vlAgwAhBBCCCEUGv50BID6qFlutNlsdsemL+BT NqZSO8ZsNpvNbvf4v8TRxUAgIBQK29raNBpNeXn5zpzGIwaA31af96JbYwYA57K6qLBq2vilpwAB gNfrZTKZdXV1m5ubO2swABBCQdje3l5aWpo7OqPRuPv+gxBCCO0VglOA+Hx+WVnZ7jlXRz4J2GZS 5aemkUik5LQ07qDBuaEuzG/3BAA8luoXJUYAAJiT0/Lq+//uZ+L3v7uVDAYAQuioAoEAi8Xq6emR HZ1QKKTRaNgACCGE3rc3ALrKU7lju1cm8KtolOq+pb985N8mEAjsvWIbXgYUIfSV8vl8jY2NQV8U XyKRGI3Gz7tLCCGEwkAYXgY0NGEAIISO6rPfCAwhhBCCcAqAvr4+UwiTSCQYAAihI8EAQAgh9HdY X1/v6Og47k/HH6JSqT4eAA6HYyjk4WRchNCRfCAACAK8PvD43vx64HUaMAAQQggdyO12H/fn4o+z WCz7dnt/ACCEUPj5QABsmKCmF9gKeN0DbUqYsh6wDQYAQgihcIIBgBAKfx8OAMUSeF0g0UHgLy7T jAGAEEIonGAAIITC34cDoEoMrCFoEEKrApYOulcjBgBCCKFwggGAEAp/eAQAIYQQ2oUBgBAKfxgA CCGE0C4MAIRQ+PtAAGxZYXod/F7QGeEvPv9jACCEEAorGAAIofCH9wFACCGEdmEAIITCHwYAQggh tAsDACEU/nYCgCD+ao7PR4hEIgwAhBBCYQMDACEU/gKBAJPJlEqlmqOTy+VMJtNutx/3k0AIIYQ+ j3/A1BT8939jACCEwtvW1tbY2Jju6MbGxiwWS9BHDxBCCKFQ8w/x//zj5X+dhu+/h+vXccEFF1xw wQUXXHDBBZfwXv4fUP+x54lo5mkAAAAASUVORK5CYII ________________________________________________________________________________
Date: Feb 04, 2019
Subject: Re: Overvoltage protection and other stuff
At 10:04 AM 2/4/2019, you wrote: >The certification basis for this aircraft is >FAR23 (amendments 1-32 inc.) and that includes: > >"23.1351(c)(5) Each generator must have an >over-voltage control designed and installed to >prevent damage to the electrical system, or to >equipment supplied by the electrical system, >that could result if that generator were to develop an over-voltage condition." > >AC23-17C explains the rationale behind this rule (introduced in 1977) saying >"Explanation. Complete electrical system >failures on both single and twin engine aircraft >continue to occur. The electrical failure that >causes this problem is often the loss of voltage >control in the voltage regulator. This usually >results in a bus voltage well above the >capabilities of the electrical equipment >connected to the bus. This overvoltage condition >frequently destroys electronic equipment and >boils the electrolyte in the battery.=9D > >Bill - you must have first hand knowledge of the >introduction of this rule, am I right? I had departed Cessna in 1969 (the second time) when someone began stirring discussions about adding ov protection. I did a prototype design that I shared with my former colleagues. The idea was adopted and became the Cessna C593001 OV sensor. Here'a a collection of documents I've gathered over he years on the history of the quantum-jump into ov protection at Cessna Pawnee Plant in the spring of 1971 https://tinyurl.com/yb4fljcf >When I look at the circuit diagram for the >alternator on this aircraft installation it has the following: It's a certainty that the system you've illustrated has no OV protection. It can be added in the form of a crowbar ov protection module on the field supply breaker: https://tinyurl.com/ya3azjhk or a DIY project https://tinyurl.com/joeopsn or by installing an alternator controller that features self-contained ov protection. Here's one set of examples . . . https://tinyurl.com/y7dscw4y There are many others. Bob . . . ________________________________________________________________________________
Date: Feb 04, 2019
Subject: Re: Delphi Weatherpack Connectors Question
At 10:59 AM 2/4/2019, you wrote: >Bob,=C2 > >Thanks for the quick response and information. >Like in the video I installed the pins in the >tower part of the connector and the pin will >move around a little bit and not be completely >centered and therefore connecting the two parts together can be problematic.=C2 > >After research online apparently the socket is >supposed to be installed in the tower and the >pin is supposed to be installed in the shroud.=C2 > >Here is a picture of the tool that I'm trying to >use and it's ID is too narrow to fit over the 24-22 AWG socket.=C2 This style of pin-retention is common to a constellation removable pin connector products. Amp Mate-n-Lock connectors found their way onto the single engine Cessnas in the 60's. I can't speak to the WeatherPack connectors specifically, I've not had occasion to work with them. But it seems that any tool that extracts male pins would work with the female sockets. The White Products catalog page 24 shows only one part number for an extraction tool. Emacs! So I'm assuming that the T-3 tool is designed to extract both types of pin. I'm skeptical of the 0.020" measurement you cited . . . those pins are much larger . . . did you 'zero' the caliper before making the measurement? Measurements aside, the single tool should work with both pins and sockets. You may have the wrong tool. Bob . . . ________________________________________________________________________________
Subject: Delphi Weatherpack Connectors Question
Date: Feb 04, 2019
> I'm skeptical of the 0.020" measurement you cited . . . those pins are much larger . . . did you 'zero' the caliper before making the measurement? Bob as always THANKS for the advice. Yes I zeroed the caliper however it appears that I do not know how to type (or proof read before posting) My super accurate and pre zeroed out Harbour Freight caliper shows 0.120=94 So I did find the problem=85It appears that the female =93socket=94 was opened up a little bit whilst I was trying to ram the tower into the shroud and because the pin was not centered in the tower it tried to enter the socket a bit sideways and loostened up the socket wider than normal so I could not get the tool over the socket. The use of the correct combination of bad words plus the use of a magnifying glass head light and a small screwdriver did the trick!!! Now my pin will easily insert into the socket and the connection is electric!!! =85 Thanks, Bill Hunter From: owner-aeroelectric-list-server(at)matronics.com On Behalf Of Robert L. Nuckolls, III Sent: Monday, February 4, 2019 11:16 AM Subject: Re: AeroElectric-List: Delphi Weatherpack Connectors Question At 10:59 AM 2/4/2019, you wrote: Bob,=C2 Thanks for the quick response and information. Like in the video I installed the pins in the tower part of the connector and the pin will move around a little bit and not be completely centered and therefore connecting the two parts together can be problematic.=C2 After research online apparently the socket is supposed to be installed in the tower and the pin is supposed to be installed in the shroud.=C2 Here is a picture of the tool that I'm trying to use and it's ID is too narrow to fit over the 24-22 AWG socket.=C2 This style of pin-retention is common to a constellation removable pin connector products. Amp Mate-n-Lock connectors found their way onto the single engine Cessnas in the 60's. I can't speak to the WeatherPack connectors specifically, I've not had occasion to work with them. But it seems that any tool that extracts male pins would work with the female sockets. The White Products catalog page 24 shows only one part number for an extraction tool. So I'm assuming that the T-3 tool is designed to extract both types of pin. I'm skeptical of the 0.020" measurement you cited . . . those pins are much larger . . . did you 'zero' the caliper before making the measurement? Measurements aside, the single tool should work with both pins and sockets. You may have the wrong tool. Bob . . . ________________________________________________________________________________
Date: Feb 04, 2019
Subject: Re: =?UTF-8?Q?Re:_=F0=9F=9A=9A_ORDER_UPDATE:_Replacement_Depo_441...?
VEhBTktTISEhIFdpbGwgYnV5IGZyb20geW91LCBhZ2Fpbi4gTWlrZQoKClNlbnQgZnJvbSBteSBH YWxheHkgVGFiwq4gUzIKCgoKICAKICAgIAoKCmJvZHkgeyB3aWR0aDogMTAwJSAhaW1wb3J0YW50 OyAtd2Via2l0LXRleHQtc2l6ZS1hZGp1c3Q6IDEwMCUgIWltcG9ydGFudDsgLW1zLXRleHQtc2l6 ZS1hZGp1c3Q6IDEwMCUgIWltcG9ydGFudDsgLXdlYmtpdC1mb250LXNtb290aGluZzogYW50aWFs aWFzZWQgIWltcG9ydGFudDsgbWFyZ2luOiAwICFpbXBvcnRhbnQ7IHBhZGRpbmc6IDAgMCAwICFp bXBvcnRhbnQ7IGZvbnQtZmFtaWx5OiBIZWx2ZXRpY2EsIEFyaWFsLCBzYW5zLXNlcmlmICFpbXBv cnRhbnQ7IGJhY2tncm91bmQtY29sb3I6I2Y5ZjlmOX0KCgoKCiAgICAKCgoKCgoKewogICJAY29u dGV4dCI6ICJodHRwOi8vc2NoZW1hLm9yZyIsCiAgIkB0eXBlIjogIkVtYWlsTWVzc2FnZSIsCiAg ImFjdGlvbiI6IHsKICAgICJAdHlwZSI6ICJWaWV3QWN0aW9uIiwKICAgICJ1cmwiOiAiaHR0cHM6 Ly9yb3Zlci5lYmF5LmNvbS9yb3Zlci8wL2UxMTQwMS5tNDM1MzMubDc3MTkvNz9ldWlkPTgzOTRh ODg2MDFjMDQyN2VhMDNlNzcwMzkyZTIxY2JjJmJ1PTQzMTg3NzgxMjY4JmxvYz1odHRwcyUzQSUy RiUyRnd3dy5lYmF5Y29tJTJGdWxrJTJGdm9kJTNGaXRlbWlkJTNEMzAyNDExNDUzMDAxJTI2dHJh bnNpZCUzRDE1OTg4MTQ4NTEwMjAlMjZxdSUzRDEmc29qVGFncz1idT1idSIsIAogICAgIm5hbWUi OiAiVHJhY2sgb3JkZXIiCiAgfSwKICAiZGVzY3JpcHRpb24iOiAiVHJhY2sgb3JkZXIiCn0KIApA bWVkaWEgb25seSBzY3JlZW4gYW5kIChtaW4td2lkdGg6IDYwMXB4KSB7CmRldmljZS13aWR0aCB7 CndpZHRoOiA1ODRweCAhaW1wb3J0YW50Cn0Kc2hvdy1pbi1tb2JpbGUgewpkaXNwbGF5OiBub25l ICFpbXBvcnRhbnQ7Cm1heC1oZWlnaHQ6IDBweCAhaW1wb3J0YW50OwptYXgtd2lkdGg6IDBweCAh aW1wb3J0YW50OwpvdmVyZmxvdzogaGlkZGVuICFpbXBvcnRhbnQ7Cm1zby1oaWRlOiBhbGw7Cn0K aGlkZS1pbi1tb2JpbGUgewpkaXNwbGF5OiBibG9jayAhaW1wb3J0YW50OwptYXgtaGVpZ2h0OiBu b25lICFpbXBvcnRhbnQ7Cm1heC13aWR0aDogbm9uZSAhaW1wb3J0YW50OwpvdmVyZmxvdzogdmlz aWJsZSAhaW1wb3J0YW50Owptc28taGlkZTogbm9uZTsKfQp9CkBtZWRpYSBvbmx5IHNjcmVlbiBh bmQgKG1heC13aWR0aDogNjAwcHgpIHsKZGV2aWNlLXdpZHRoIHsKd2lkdGg6IDU4NHB4ICFpbXBv cnRhbnQKfQp9CkBtZWRpYSBvbmx5IHNjcmVlbiBhbmQgKG1heC13aWR0aDogNDc5cHgpIHsKZGV2 aWNlLXdpZHRoIHsKd2lkdGg6IDMwNHB4ICFpbXBvcnRhbnQ7Cn0KaGlkZS1pbi1tb2JpbGUgewpk aXNwbGF5OiBub25lICFpbXBvcnRhbnQ7Cm1heC1oZWlnaHQ6IDBweCAhaW1wb3J0YW50OwptYXgt d2lkdGg6IDBweCAhaW1wb3J0YW50OwpvdmVyZmxvdzogaGlkZGVuICFpbXBvcnRhbnQ7Cm1zby1o aWRlOiBhbGw7Cn0Kc2hvdy1pbi1tb2JpbGUgewpkaXNwbGF5OiBibG9jayAhaW1wb3J0YW50Owpt YXgtaGVpZ2h0OiBub25lICFpbXBvcnRhbnQ7Cm1heC13aWR0aDogbm9uZSAhaW1wb3J0YW50Owpv dmVyZmxvdzogdmlzaWJsZSAhaW1wb3J0YW50Owptc28taGlkZTogbm9uZTsKfQpkaXYtbW9iaWxl LXByb2R1Y3QtaW1hZ2UgewphbGlnbjpjZW50ZXI7Cn0KbW9iaWxlLXRlbXBsYXRlLW1pbi13aWR0 aCB7Cm1pbi13aWR0aDogMzIwcHggIWltcG9ydGFudDsKfQptb2JpbGUtY3RhLXJlc2l6ZSB7Cndp ZHRoOiAzMDRweCAhaW1wb3J0YW50Owp9Cm1vYmlsZS13aWR0aC0xMDAgewp3aWR0aDogMTAwJSAh aW1wb3J0YW50Owp9Cn0KY3RhLWJsb2NrIHsKbWluLXdpZHRoOiAxMDNweDsKbWF4LXdpZHRoOiAz MDBweDsKfQpjdGEtYmxvY2sgYSB7CmRpc3BsYXk6IGJsb2NrOwpwYWRkaW5nOiAxMHB4IDA7Cn0K Y3RhLWJsb2NrIHRkewpwYWRkaW5nOiAwcHggIWltcG9ydGFudAp9CkBmb250LWZhY2Ugewpmb250 LWZhbWlseTogIk1hcmtldCBTYW5zIjsKc3JjOiB1cmwoJ2h0dHBzOi8vaXIuZWJheXN0YXRpYy5j b20vY3Ivdi9jMS9tYXJrZXQtc2Fucy92MS4wL01hcmtldFNhbnMtUmVndWxhci1XZWJTLmVvdCcp OwpzcmM6IHVybCgnaHR0cHM6Ly9pci5lYmF5c3RhdGljLmNvbS9jci92L2MxL21hcmtldC1zYW5z L3YxLjAvTWFya2V0U2Fucy1SZWd1bGFyLVdlYlMuZW90PyNpZWZpeCcpIGZvcm1hdCgnZW1iZWRk ZWQtb3BlbnR5cGUnKSwgdXJsKCdodHRwczovL2lyLmViYXlzdGF0aWMuY29tL2NyL3YvYzEvbWFy a2V0LXNhbnMvdjEuMC9NYXJrZXRTYW5zLVJlZ3VsYXItV2ViUy53b2ZmMicpIGZvcm1hdCgnd29m ZjInKSwgdXJsKCdodHRwczovL2lyLmViYXlzdGF0aWMuY29tL2NyL3YvYzEvbWFya2V0LXNhbnMv djEuMC9NYXJrZXRTYW5zLVJlZ3VsYXItV2ViUy53b2ZmJykgZm9ybWF0KCd3b2ZmJyksIHVybCgn aHR0cHM6Ly9pci5lYmF5c3RhdGljLmNvbS9jci92L2MxL21hcmtldC1zYW5zL3YxLjAvTWFya2V0 U2Fucy1SZWd1bGFyLVdlYlMudHRmJykgZm9ybWF0KCd0cnVldHlwZScpLCB1cmwoJ2h0dHBzOi8v aXIuZWJheXN0YXRpYy5jb20vY3Ivdi9jMS9tYXJrZXQtc2Fucy92MS4wL01hcmtldFNhbnMtUmVn dWxhci1XZWJTLnN2ZyNNYXJrZXRTYW5zLVJlZ3VsYXItV2ViUycpIGZvcm1hdCgnc3ZnJyk7CmZv bnQtd2VpZ2h0OiBub3JtYWw7CmZvbnQtc3R5bGU6IG5vcm1hbDsKfQpAZm9udC1mYWNlIHsKZm9u dC1mYW1pbHk6ICJNYXJrZXQgU2FucyI7CnNyYzogdXJsKCdodHRwczovL2lyLmViYXlzdGF0aWMu Y29tL2NyL3YvYzEvbWFya2V0LXNhbnMvdjEuMC9NYXJrZXRTYW5zLVNlbWlCb2xkLVdlYlMuZW90 Jyk7CnNyYzogdXJsKCdodHRwczovL2lyLmViYXlzdGF0aWMuY29tL2NyL3YvYzEvbWFya2V0LXNh bnMvdjEuMC9NYXJrZXRTYW5zLVNlbWlCb2xkLVdlYlMuZW90PyNpZWZpeCcpIGZvcm1hdCgnZW1i ZWRkZWQtb3BlbnR5cGUnKSwgdXJsKCdodHRwczovL2lyLmViYXlzdGF0aWMuY29tL2NyL3YvYzEv bWFya2V0LXNhbnMvdjEuMC9NYXJrZXRTYW5zLVNlbWlCb2xkLVdlYlMud29mZjInKSBmb3JtYXQo J3dvZmYyJyksIHVybCgnaHR0cHM6Ly9pci5lYmF5c3RhdGljLmNvbS9jci92L2MxL21hcmtldC1z YW5zL3YxLjAvTWFya2V0U2Fucy1TZW1pQm9sZC1XZWJTLndvZmYnKSBmb3JtYXQoJ3dvZmYnKSwg dXJsKCdodHRwczovL2lyLmViYXlzdGF0aWMuY29tL2NyL3YvYzEvbWFya2V0LXNhbnMvdjEuMC9N YXJrZXRTYW5zLVNlbWlCb2xkLVdlYlMudHRmJykgZm9ybWF0KCd0cnVldHlwZScpLCB1cmwoJ2h0 dHBzOi8vaXIuZWJheXN0YXRpYy5jb20vY3Ivdi9jMS9tYXJrZXQtc2Fucy92MS4wL01hcmtldFNh bnMtU2VtaUJvbGQtV2ViU3N2ZyNNYXJrZXRTYW5zLVNlbWlCb2xkLVdlYlMnKSBmb3JtYXQoJ3N2 ZycpOwpmb250LXdlaWdodDogYm9sZDsKZm9udC1zdHlsZTogbm9ybWFsOwp9CmJvZHkgeyB3aWR0 aDogMTAwJSAhaW1wb3J0YW50OyAtd2Via2l0LXRleHQtc2l6ZS1hZGp1c3Q6IDEwMCUgIWltcG9y dGFudDsgLW1zLXRleHQtc2l6ZS1hZGp1c3Q6IDEwMCUgIWltcG9ydGFudDsgLXdlYmtpdC1mb250 LXNtb290aGluZzogYW50aWFsaWFzZWQgIWltcG9ydGFudDsgbWFyZ2luOiAwICFpbXBvcnRhbnQ7 IHBhZGRpbmc6IDAgMCAzMnB4IDA7IGZvbnQtZmFtaWx5OiAnTWFya2V0IFNhbnMnLCBIZWx2ZXRp Y2EsIEFyaWFsLCBzYW5zLXNlcmlmICFpbXBvcnRhbnQ7IGJhY2tncm91bmQtY29sb3I6I2ZmZmZm Zn0KaW1nIHsgZGlzcGxheTogYmxvY2s7IHRleHQtZGVjb3JhdGlvbjogbm9uZSAhaW1wb3J0YW50 OyAtbXMtaW50ZXJwb2xhdGlvbi1tb2RlOiBiaWN1YmljICFpbXBvcnRhbnQ7IH0KdGR7d29yZC13 cmFwOiBicmVhay13b3JkOyB3b3JkLWJyZWFrOiBicmVhay13b3JkO30Kd2Via2l0IHsKbWF4LXdp ZHRoOiAxMDAlOwptYXJnaW46IDAgYXV0bzsKfQp1bnNlbGVjdC10ZXh0IHsKLXdlYmtpdC10b3Vj aC1jYWxsb3V0OiBub25lOwotd2Via2l0LXVzZXItc2VsZWN0OiBub25lOwota2h0bWwtdXNlci1z ZWxlY3Q6IG5vbmU7Ci1tb3otdXNlci1zZWxlY3Q6IG1vei1ub25lOwotbXMtdXNlci1zZWxlY3Q6 IG5vbmU7Ci1vLXVzZXItc2VsZWN0OiBub25lOwp1c2VyLXNlbGVjdDogbm9uZTsKfQpzZWxlY3Qt dGV4dCB7Ci13ZWJraXQtdG91Y2gtY2FsbG91dDogZGVmYXVsdDsKLXdlYmtpdC11c2VyLXNlbGVj dDogdGV4dDsKLWtodG1sLXVzZXItc2VsZWN0OiB0ZXh0OwotbW96LXVzZXItc2VsZWN0OiB0ZXh0 OwotbXMtdXNlci1zZWxlY3Q6IHRleHQ7Ci1vLXVzZXItc2VsZWN0OiB0ZXh0Owp1c2VyLXNlbGVj dDogdGV4dDsKfQoKCiAKYm9keXsgcGFkZGluZzogMCAwIDEwMHB4IDA7IH0Kd2hpdGUtc3BhY2Ut bm9ybWFse3doaXRlLXNwYWNlOiBub3JtYWwgIWltcG9ydGFudH0KQG1lZGlhIG9ubHkgc2NyZWVu IGFuZCAobWluLXdpZHRoOiA2MDFweCkgewpzaG93LXRleHQtaW4tbW9iaWxlIHsKbWF4LWhlaWdo dDogMHB4ICFpbXBvcnRhbnQ7Cm1heC13aWR0aDogMHB4ICFpbXBvcnRhbnQ7Cm92ZXJmbG93OiBo aWRkZW4gIWltcG9ydGFudDsKfQpoaWRlLXRleHQtaW4tbW9iaWxlIHsKbWF4LWhlaWdodDogbm9u ZSAhaW1wb3J0YW50OwptYXgtd2lkdGg6IG5vbmUgIWltcG9ydGFudDsKb3ZlcmZsb3c6IHZpc2li bGUgIWltcG9ydGFudDsKfQpkZXNrdG9wLXJlbW92ZS13aWR0aCB7CndpZHRoOiAwICFpbXBvcnRh bnQ7Cn0KfQpAbWVkaWEgb25seSBzY3JlZW4gYW5kIChtYXgtd2lkdGg6IDQ3OXB4KSB7CmhpZGUt dGV4dC1pbi1tb2JpbGUgewpkaXNwbGF5OiBub25lICFpbXBvcnRhbnQ7Cm1heC1oZWlnaHQ6IDBw eCAhaW1wb3J0YW50OwptYXgtd2lkdGg6IDBweCAhaW1wb3J0YW50OwpvdmVyZmxvdzogaGlkZGVu ICFpbXBvcnRhbnQ7Cn0Kc2hvdy10ZXh0LWluLW1vYmlsZSB7CmRpc3BsYXk6IGJsb2NrICFpbXBv cnRhbnQ7Cm1heC1oZWlnaHQ6IG5vbmUgIWltcG9ydGFudDsKbWF4LXdpZHRoOiBub25lICFpbXBv cnRhbnQ7Cm92ZXJmbG93OiB2aXNpYmxlICFpbXBvcnRhbnQ7Cn0KbW9iaWxlLWJhbm5lci1pbWFn ZSB7Cm1heC13aWR0aDogMzA5cHggIWltcG9ydGFudDsKaGVpZ2h0OiBhdXRvICFpbXBvcnRhbnQ7 Cn0KcmVtb3ZlLWZsb2F0IHsKZmxvYXQ6IG5vbmUgIWltcG9ydGFudDsKfQptb2JpbGUtaXRlbS1k ZXRhaWxzLXdpZHRoIHsKd2lkdGg6IDE4NHB4ICFpbXBvcnRhbnQ7Cm1pbi13aWR0aDoxODRweCAh aW1wb3J0YW50OwpoZWlnaHQ6IDQwcHggIWltcG9ydGFudDsKfQptb2JpbGUtY3RhLXJlc2l6ZSB7 CndpZHRoOiAzMDRweCAhaW1wb3J0YW50OwptYXgtd2lkdGg6IDMwNHB4ICFpbXBvcnRhbnQ7Cn0K bW9iaWxlLWN0YS1zcGFjZXIgewp3aWR0aDogNTBweCAhaW1wb3J0YW50OwptYXgtd2lkdGg6IDUw cHggIWltcG9ydGFudDsKfQptb2JpbGUtcmVtb3ZlLXRvcC1wYWRkaW5nIHsKcGFkZGluZy10b3A6 IDAgIWltcG9ydGFudDsKfQptb2JpbGUtcmVtb3ZlLWJvdHRvbS1wYWRkaW5nIHsKcGFkZGluZy1i b3R0b206IDAgIWltcG9ydGFudDsKfQptb2JpbGUtcmVtb3ZlLW1pbi13aWR0aCB7Cm1pbi13aWR0 aDogMCAhaW1wb3J0YW50Owp9Cm1vYmlsZS13aWR0aC0xMDAgewp3aWR0aDogMTAwJSAhaW1wb3J0 YW50Owp9Cm1vYmlsZS1pbWFnZS13aWR0aHsKd2lkdGg6IDExMnB4ICFpbXBvcnRhbnQ7Cn0KbW9i aWxlLXRhYmxlLXdpZHRoewp3aWR0aDoyNTBweCAhaW1wb3J0YW50Owp9Cm1vYmlsZS10ZC13aWR0 aHsKd2lkdGg6OTBweCAhaW1wb3J0YW50Owp9Cm1vYmlsZS13aWR0aHsKd2lkdGg6MjQwcHggIWlt cG9ydGFudDsKfQptb2JpbGUtbW9kdWxlLWhlaWdodHsKaGVpZ2h0OjYwcHggIWltcG9ydGFudDsK fQptb2JpbGUtY3RhLXBhZGRpbmd7CnBhZGRpbmc6IDMycHggMCAxNnB4IDAgIWltcG9ydGFudDsK fQptb2JpbGUtaW1nLWhlaWdodHsKaGVpZ2h0OiAxM3B4ICFpbXBvcnRhbnQ7Cn0KbW9iaWxlLW1v ZHVsZS13aWR0aHsKd2lkdGg6MjMwcHggIWltcG9ydGFudDsKfQptb2JpbGUtbWJnLWltZy13aWR0 aHsKd2lkdGg6OTZweCAhaW1wb3J0YW50Owp9Cn0KCiAgCiAgLS0tLS0tLS0gT3JpZ2luYWwgbWVz c2FnZSAtLS0tLS0tLUZyb206IGVCYXkgPGViYXlAZWJheS5jb20+IERhdGU6IDIwMTktMDItMDQg IDY6MTcgUE0gIChHTVQtMDc6MDApIFRvOiB3eW5haXJlQGNpdGxpbmsubmV0IFN1YmplY3Q6IPCf mpogT1JERVIgVVBEQVRFOiBSZXBsYWNlbWVudCBEZXBvIDQ0MS4uLiAKCgoKCgoKRVRBOiBGcmks IEZlYiAwOC4KCgoKCgogCgoKCgoKCgoKCgoKCgoKCgoKIAoKCgoKCiBIaSBNaWNoYWVsLCB5b3Vy IG9yZGVyIGlzIGJlaW5nIHNoaXBwZWQhICAKCgoKCiAKCgoKCgoKCgoKCgoKCgoKCgoKCgoKICAK CgoKCgoKCgoKCgoKCgogQ2hlY2sgb3JkZXIgc3RhdHVzCgoKCgoKCgoKCgoKCgrCoAoKCgoKCgoK CgoKCgogR28gdG8gc2l0ZQoKCgoKCgoKCgoKCgoKCgogCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoK CgoKCsKgCgoKCgoKCgpZb3VyIG9yZGVyIHdpbGwgc2hpcCB0bzoKCgoKCjI3NSBBc3BlbiBEcgoK Ck1vYWIsIFVUIDg0NTMyLTI5NDcKClVuaXRlZCBTdGF0ZXMKCgoKCgoKCgoKCgoKCgoKCgoKCgoK CgoKCsKgCgoKCgoKCgpFc3RpbWF0ZWQgZGVsaXZlcnk6CgoKCgpGcmksIEZlYiAwOAo ________________________________________________________________________________
Subject: Re: RE:_AeroElectric-List:_Re:_=F0=9F=9A=9A_OR?= =?utf-8?Q?DER_UPDATE:_Replacement_Depo_441?=
=?utf-8?Q?...?
Date: Feb 04, 2019
Not sure who this message is for, but my name is not Mike and I do not live in UT. From: owner-aeroelectric-list-server(at)matronics.com On Behalf Of wynaire Sent: Monday, February 4, 2019 9:31 PM Subject: AeroElectric-List: Re: =F0=9F=9A=9A ORDER UPDATE: Replacement Depo 441... THANKS!!! Will buy from you, again. Mike Sent from my Galaxy Tab=C2=AE S2 -------- Original message -------- From: eBay <ebay(at)ebay.com> Date: 2019-02-04 6:17 PM (GMT-07:00) Subject: =F0=9F=9A=9A ORDER UPDATE: Replacement Depo 441... ETA: Fri, Feb 08. Hi Michael, your order is being shipped! Check order status Go to site Your order will ship to: 275 Aspen Dr Moab, UT 84532-2947 United States Estimated delivery: Fri, Feb 08 ________________________________________________________________________________
Date: Feb 04, 2019
Date: Feb 05, 2019
> >So I did find the problem=85It appears that the >female =93socket=94 was opened up a little bit >whilst I was trying to ram the tower into the >shroud and because the pin was not centered in >the tower it tried to enter the socket a bit >sideways and loostened up the socket wider than >normal so I could not get the tool over the >socket. The use of the correct combination of >bad words plus the use of a magnifying glass >head light and a small screwdriver did the trick!!! > >Now my pin will easily insert into the socket >and the connection is electric!!! Excellent . . . details, details . . . always those pesky details. Fly comfortably! Bob . . . ________________________________________________________________________________
Subject: Re: John Deere Generator pulses
Date: Feb 05, 2019
This sounds like a fun DIY project. I'd like to try it if you don't mind putting together the instructions. Thanks! - Paul Fisher On 2/3/2019 1:23 PM, Alec Myers wrote: > I have designed and built an optical tach for checking prop speed, > using a PIC, a photodiode, and a four digit LED display. You point it > out of the window through the prop disc as you fly along Its the size > of (and runs from) a pair of AA batteries. You can use it for checking > a drill speed too if you put two pieces of silver tape on the chuck. > > Total part cost is about $7. It shows what you can start to do with a > $1 micro controller. > > Do you think the list would like it as a build-it-yourself project? > Its a good intro to SMT soldering. > > > On Feb 3, 2019, at 1:17 PM, Robert L. Nuckolls, III > > > wrote: > > At 08:27 PM 2/2/2019, you wrote: >> --> AeroElectric-List messageposted by: "user9253" >> > >> >> What kind of engine? >> Is the generator gear driven or belt driven? >> How about using an optical tachometer to compare to theEIS? > > Agreed. There are a number of low-cost, > laser tachs that are quite accurate. Here > is one example. > > https://tinyurl.com/y76qb9w6 > > This one's sensing distance is rated at > 500mm (about 20") but it can be a lot > greater. Put strips of aluminum > duct tape on the back side of the blades > and use the tach on a dark ramp. I think > you find that you can read the blade passes > quite well. > > You only need to check at one speed . . . > digital sensing is exceedingly linear! > Engine idle would suffice. > > > Bob . . . > > ________________________________________________________________________________
Date: Feb 06, 2019
Subject: Re: Battery
If. . . the solar panel is a low current variety, say 1 amp or less, I believe a simple zener diode across the output, at the right voltage, will just clip the voltage at what ever it chosen...Thus, no over charging of a full charged battery. On Tue, Jan 22, 2019 at 6:12 PM Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 07:44 PM 1/21/2019, you wrote: > > I learned today from EarthX that they are ok with using a small solar > charger to charge their batteries, as long as it will NEVER exceed 14.6 > volts. Their emphasis, not mine.They also stated that many solar units > commonly are 15 volts or more and therefore not to be used with their > batteries. > > > Virtually ALL solar arrays offered to charge > 12v batteries will have a full-sun, open-circuit > voltage in excess of 16 volts. > > The 'small' arrays also have a rather large > internal impedance . . . meaning that the > output voltage falls off as load is increased. > But as any battery being charged with a 'barefoot' > solar array achieves full charge, flow of current > into the battery is not moderated. > > The short story is that any solar array > being considered needs to have a significant > current capability . . . the wall-wart maintainers > are good for about 0.8A and WILL eventually > top off a rather large battery. > > But to deliver 0.8A under marginal sun-light > conditions, the full-sun capability needs to > be 2x to 3x that amount . . . say 2.5A at > 14 volts or about 35 watts. > > Those cute little solar panels with cigar > lighter plugs are good for about 1-2 watts > and will MAINTAIN a fully charged battery. > But it takes a more robust device to serve > as replacement for the ship's engine driven > power source . . . i.e. top off a partially > discharged battery while hangared. > > The more robust arrays need some form of > electronics to keep their full-sun performance > from beating up an already full-charge battery. > > Bob . . . > ________________________________________________________________________________
Date: Feb 06, 2019
At 02:57 PM 2/6/2019, you wrote: >If. . . the solar panel is a low current variety, say 1 amp or less, >I believe a simple zener diode across the output, at the right >voltage, will just clip the voltage at what ever it chosen...Thus, >no over charging of a full charged battery. Possibly . . . but what target votlage? If you're asking the solar array to mainatain a fully charged battery, then indeed a 13.0 volt zener would proably do. But this thread started as an exploration of using solar power sources to CHARGE the battery in an airplane with no engine driven power source. In this case, you need to clamp off at 14.5 for a top-off interval and the drop to the 13.0 sustaining voltage. Further, charging a battery probably calls for something larger than a 100mA solar array . . . Presumably, the solar battery smart charger module cited earlier will hat-dance to the right tune. Got on on order. Bob . . . ________________________________________________________________________________
Subject: Re: Slick 6393
From: "popo123" <kumarpuneetsunny1234(at)gmail.com>
Date: Feb 08, 2019
Make your mood fresh by playing xbox live.you don't need any subscription here https://freexboxlive.xyz .enjoy unlimited gaming......... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487486#487486 ________________________________________________________________________________
Subject: Arplast PV50 Propeller Motor
Date: Feb 09, 2019
The 6V Electric Motor on the Arplast PV50 propeller on my Europa has failed. Having researched the forums, there has been talk about replacing the 6V Motor with the 12V model, and I am putting together a MOD request to the UK LAA to do this. It seems sensible, as the aircraft provides 12V to the motor. However, I am not well versed in the skills required to compare the two models, so I hope someone here can look at the attached spec sheet for the motors, and let me know if they can find any reason not to do this. Conversely, any reasons why it may be a good idea would help with my submission to the LAA The current model is 2224U006SR, and I am looking at replacing this with a 2224U012SR I also wonder why the original Propeller manufacturer (no longer in business) would use a 6V motor on a 12V system (unless the 12V option wasn't available at the time)? -------- Bob Dawson Europa XS TG || 912 ULS || G-NHRJ || Dynon Skyview || PilotAware || SmartAss3 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487487#487487 Attachments: http://forums.matronics.com//files/en_2224_sr_dff_206.pdf ________________________________________________________________________________
Subject: Re: Arplast PV50 Propeller Motor
Date: Feb 09, 2019
January 14, 2019 - February 09, 2019
AeroElectric-Archive.digest.vol-ot
