AeroElectric-Archive.digest.vol-pa
July 07, 2019 - August 01, 2019
      > Crimping wires into contacts or crimp ferrules is a method for splicing wires
      together without soldering. When crimping multiple wires into a contact or ferrule,
      the total circular-mil-area (CMA) of all the wires must be calculated into
      an Equivalent Wire Size (EWS) in order to select the properly sized contact
      or ferrule.
      > 19.9.1 The following requirements apply for crimped splices:
      > a. The tooling verification process and the completed termination shall comply
      with all the requirements of this document for a crimp termination except as
      specified herein for jiffy junction devices.
      > b. The contact/wires size and crimp tool setting combination shall be developed
      and verified using the same requirements as for any machined contact (see 12.3.5).
      > c. The crimp ferrule or contact shall be sized equivalently with the calculated
      Equivalent Wire Size (EWS) or the next larger EWS if the calculated value does
      not exactly match a single wire size.
      > Dont twist the wires together, they should go into the barrel parallel. I believe
      when you double area of a wire, the AWG goes down by three. So 2 x 20 gauge
      wires would be 17 gauge.
      > On Jul 6, 2019, at 11:09 PM, Argonaut36  wrote:
      > I was wondering if the practice of twisting 2 wires together and crimping the
      resulting wire in a ring terminal can be considered acceptable, even for standard
      certificate airplanes, for making a Y splitter.  If so, assuming that 2 wires
      to be twisted together are size 20#, should a red or blue ring terminal be
      used?
      > Thanks
      > http://forums.matronics.com/viewtopic.php?p=490084#490084
Date: Jul 07, 2019
Subject: Re: Limiting Current to a Battery
Would it be a DC-DC battery charger? https://www.renogy.com/renogy-12v-dc-to-dc-on-board-battery-charger/?gclid=CjwKCAjwsIbpBRBNEiwAZF8-z-TrUeFYygbwZh7wrFUpKO_RhdCJkW-vJ-BFwYS_IZjlu9G8uAMNcxoCgBoQAvD_BwE On Sun, Jul 7, 2019 at 7:05 AM Jared Yates wrote: > I have a question that's only somewhat applicable to E/AB aviation, > apologies in advance. But I think it points out a hole in my electrical > understanding. > > The characteristics of the lithium iron battery I'm running allow it to > draw lots of current really fast after the engine starts. If it has been a > little while since the last flight, the alternator is at max output for > several minutes. The alternator puts out all it can give, and it's less > than the battery wants to take. > > Stepping out of the hangar, my tow vehicle circuitry includes a wire in > the 7-pin connector that provides alternator voltage to the trailer, > intending to charge a small battery for a breakaway emergency brake. If I > install a larger battery for other purposes, perhaps one like what is in > the airplane, and connect it to that line coming from the truck, it seems > like it would almost certainly open the fuse on that circuit during that > initial high-draw stage. > > These two scenarios had me thinking, what methods would one have to limit > a hungry battery's draw? I'm imagining some type of circuit that takes in > 12-14 volts, and puts out almost the same, but only at some specified > number of amps. Almost like a DC-powered battery charging circuit, rather > than just putting the battery on the bus directly. > > Surely this has been solved in some off-the-shelf widget, but I haven't > figured out the words to google yet. > ________________________________________________________________________________
Date: Jul 07, 2019
That device won't limit current pulled through his feed to the trailer connector. While that device might work for its intended purpose, one of its claims is nonsense: * Overcomes voltage drop caused by long cable runs Unless its some corollary of a perpetual motion machine. Charlie On 7/7/2019 12:02 PM, David Saylor wrote: > Would it be a DC-DC battery charger? > > https://www.renogy.com/renogy-12v-dc-to-dc-on-board-battery-charger/?gclid=CjwKCAjwsIbpBRBNEiwAZF8-z-TrUeFYygbwZh7wrFUpKO_RhdCJkW-vJ-BFwYS_IZjlu9G8uAMNcxoCgBoQAvD_BwE > > > On Sun, Jul 7, 2019 at 7:05 AM Jared Yates > wrote: > > I have a question that's only somewhat applicable to E/AB > aviation, apologies in advance. But I think it points out a hole > in my electrical understanding. > > The characteristics of the lithium iron battery I'm running allow > it to draw lots of current really fast after the engine starts. If > it has been a little while since the last flight, the alternator > is at max output for several minutes. The alternator puts out all > it can give, and it's less than the battery wants to take. > > Stepping out of the hangar, my tow vehicle circuitry includes a > wire in the 7-pin connector that provides alternator voltage to > the trailer, intending to charge a small battery for a breakaway > emergency brake. If I install a larger battery for other purposes, > perhaps one like what is in the airplane, and connect it to that > line coming from the truck, it seems like it would almost > certainly open the fuse on that circuit during that initial > high-draw stage. > > These two scenarios had me thinking, what methods would one have > to limit a hungry battery's draw? I'm imagining some type of > circuit that takes in 12-14 volts, and puts out almost the same, > but only at some specified number of amps. Almost like a > DC-powered battery charging circuit, rather than just putting the > battery on the bus directly. > > Surely this has been solved in some off-the-shelf widget, but I > haven't figured out the words to google yet. > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jul 07, 2019
Subject: Re: Overvoltage protection
At 10:25 AM 7/7/2019, you wrote: > >A friend is working on a Grumman Tiger in which the alternator field >circuit breaker was found tripped. Upon digging in the manual, he >found the overvoltage protection was simply a Zener diode wired from >the output of the field breaker to ground. The diode was found to >be shorted, which would easily trip the breaker. Yup. A stone simple ov protection scheme that made it onto a TC aircraft. Wrote about this for SA back in '93 . . . https://tinyurl.com/y38og7he Discovered later that the idea was not 'bad' as originally implemented. The design called for a GLASS, 1N4745, 1W zener tied to ground downstream of a 5A FUSE. The thing was designed to be a single event operator . . . IF you experienced an ov condition, the zener was expected to short, the fuse was expected to open. You would have to investigate and fix root cause of the ov condtion, then replace the zener and fuse before flying upward and onward. Emacs! I did some testing on various zeners and found that only GLASS enclosed could be depended upon to fail shorted . . . plastics would occasionally split apart and fail to burn the fuse. Emacs! This is why the zener could only be 'legally' replaced with the Grumman house part number to make sure that the part was GLASS encased. Some airplanes were modified to replace cartridge fuses with breakers but left the zener in place . . . risky because the I(squared)t operation numbers for the breaker are larger than a fuse. >I can only find a "house number" on the Zener. The diode was >removed, the old regulator was replaced with a Zeftronics with >integral overvoltage protection, the split rocker switch was >replaced with a new one, and all seems well -- except that one >electrical instrument is inoperative (possibly due to an overvoltage event). Once the regulator is replaced with one that INCLUDES ov protection, the zener should be removed. >My questions are as follows: can a physically small Zener diode >(similar in size to a 1N5401 diode) handle the amount of energy >required to trip a 5A breaker, even one time? Can the Zener always >be counted upon to fail shorted and not open? Good question but moot after the regulator is replaced. Bob . . . ________________________________________________________________________________
Date: Jul 07, 2019
>>That device won't limit current pulled through his feed to the trailer connector.<< If the 20A model was mounted to the truck, the feed would be limited to 20A. If it was mounted to the trailer, the feed would be limited to something more than 20A. >>While that device might work for its intended purpose, one of its claims is nonsense: - Overcomes voltage drop caused by long cable runs Unless its some corollary of a perpetual motion machine. << As someone mentioned earlier, long cable runs have been suggested as a solution. But since that's really just a resistor, you'd also get a voltage drop. This gizmo looks like it limits the current sent to the battery being charged without dropping the voltage. So it overcomes the voltage drop caused by the long cable run solution. I don't think they're suggesting that it makes magical energy. > ________________________________________________________________________________
Date: Jul 07, 2019
The only way to limit the current drawn by a battery is to limit the voltage. On Jul 7, 2019, at 2:13 PM, David Saylor wrote: This gizmo looks like it limits the current sent to the battery being charged without dropping the voltage. ________________________________________________________________________________
Date: Jul 07, 2019
On 7/7/2019 1:13 PM, David Saylor wrote: > >>That device won't limit current pulled through his feed to the > trailer connector.<< > > If the 20A model was mounted to the truck, the feed would be limited > to 20A. If it was mounted to the trailer, the feed would be limited > to something more than 20A. > > >>While that device might work for its intended purpose, one of its > claims is nonsense: > > * Overcomes voltage drop caused by long cable runs > > Unless its some corollary of a perpetual motion machine.<< > > As someone mentioned earlier, long cable runs have been suggested as a > solution. But since that's really just a resistor, you'd also get a > voltage drop. This gizmo looks like it limits the current sent to the > battery being charged without dropping the voltage. So it overcomes > the voltage drop caused by the long cable run solution. I don't think > they're suggesting that it makes magical energy. > P(ower)=V(oltage) / I (current) The only way to do what you suggest is...magical energy. To restore charge voltage *at the same current* after a voltage drop caused by a long cable run, you *must* increase current, to satisfy the power equation. How? --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jul 07, 2019
Thank you everyone for the tips, I have ordered a power supply circuit to test and will report back. It includes an adjustment for the max current. On July 7, 2019 13:08:34 David Saylor wrote: > Would it be a DC-DC battery charger? > > https://www.renogy.com/renogy-12v-dc-to-dc-on-board-battery-charger/?gclid=CjwKCAjwsIbpBRBNEiwAZF8-z-TrUeFYygbwZh7wrFUpKO_RhdCJkW-vJ-BFwYS_IZjlu9G8uAMNcxoCgBoQAvD_BwE > > > On Sun, Jul 7, 2019 at 7:05 AM Jared Yates wrote: > >> I have a question that's only somewhat applicable to E/AB aviation, >> apologies in advance. But I think it points out a hole in my electrical >> understanding. >> >> The characteristics of the lithium iron battery I'm running allow it to >> draw lots of current really fast after the engine starts. If it has been a >> little while since the last flight, the alternator is at max output for >> several minutes. The alternator puts out all it can give, and it's less >> than the battery wants to take. >> >> Stepping out of the hangar, my tow vehicle circuitry includes a wire in >> the 7-pin connector that provides alternator voltage to the trailer, >> intending to charge a small battery for a breakaway emergency brake. If I >> install a larger battery for other purposes, perhaps one like what is in >> the airplane, and connect it to that line coming from the truck, it seems >> like it would almost certainly open the fuse on that circuit during that >> initial high-draw stage. >> >> These two scenarios had me thinking, what methods would one have to limit >> a hungry battery's draw? I'm imagining some type of circuit that takes in >> 12-14 volts, and puts out almost the same, but only at some specified >> number of amps. Almost like a DC-powered battery charging circuit, rather >> than just putting the battery on the bus directly. >> >> Surely this has been solved in some off-the-shelf widget, but I haven't >> figured out the words to google yet. >> ________________________________________________________________________________
Date: Jul 07, 2019
Thank you, Bob. Mystery solved! You nailed it with this information and in the article you wrote for S.A. in 1993. But it's the first time I've heard of such a thing and was somewhat bewildered at a design depending on an unspecified parameter in this way. Thanks for the history and explanation. BTW, the diode we removed appeared to be plastic (like the one in your second attached image), not glass. But as you conclude (and we do too): it's moot after the regulator is replaced with one containing over-voltage regulation. Thanks again, Joe Robert L. Nuckolls, III wrote, On 7/7/2019 09:45: > At 10:25 AM 7/7/2019, you wrote: >> >> A friend is working on a Grumman Tiger in which the alternator field >> circuit breaker was found tripped. Upon digging in the manual, he >> found the overvoltage protection was simply a Zener diode wired from >> the output of the field breaker to ground. The diode was found to be >> shorted, which would easily trip the breaker. > > Yup. A stone simple ov protection scheme > that made it onto a TC aircraft. Wrote about > this for SA back in '93 . . . > > https://tinyurl.com/y38og7he > > Discovered later that the idea was not > 'bad' as originally implemented. The > design called for a GLASS, 1N4745, 1W zener > tied to ground downstream of a 5A > FUSE. > > > Emacs! > > > > > I did some testing on various > zeners and found that only GLASS enclosed > could be depended upon to fail shorted . . . > plastics would occasionally split > and fail to burn the fuse. > Emacs! > > > > This is why the zener could only be > 'legally' replaced with the Grumman house > part number to make sure that the part > was GLASS encased. > > Some airplanes were modified to replace > cartridge fuses with breakers but left > the zener in place . . . risky because > the I(squared)t operation numbers > for a breaker are larger than the fuse. > > >> I can only find a "house number" on the Zener. The diode was removed, >> the old regulator was replaced with a Zeftronics with integral >> overvoltage protection, the split rocker switch was replaced with a >> new one, and all seems well -- except that one electrical instrument >> is inoperative (possibly due to an overvoltage event). > > Once the regulator is replaced with one > that INCLUDES ov protection, the zener > should be removed. > > >> My questions are as follows: can a physically small Zener diode >> (similar in size to a 1N5401 diode) handle the amount of energy >> required to trip a 5A breaker, even one time? Can the Zener always be >> counted upon to fail shorted and not open? > > Good question but moot after the > regulator is replaced. > > > > Bob . . . ________________________________________________________________________________
Date: Jul 07, 2019
At 12:34 PM 7/7/2019, you wrote: >That device won't limit current pulled through his feed to the >trailer connector. > >While that device might work for its intended purpose, one of its >claims is nonsense: > * Overcomes voltage drop caused by long cable runs >Unless its some corollary of a perpetual motion machine. Don't think current through the connector was the problem . . . the 'high current' issue centers on the discharged battery's willingness to accept a replacement current greater than what is healthy for its physics. Hence, taking care of the battery calls for a constant voltage/constant current charging supply that is battery friendly . . . which is what this product would do . . . EXCEPT PERHAPS . . . that the specifications do not call out an 'adjustable' constant current range. It's basically a dc/dc converter with a full performance input range of 8-16 volts where the output would be held steady at specified charging/maintaining\ levels and a max current of 20A. The specs do not say that it's electronically limited to 20A although I suspect it would be. If the trailer battery is happy at 20A max charge current, then this critter would do the job . . . However, under a 20A output load, current through the trailer connector WILL be higher because of voltage drops being compensated for by the charger's electronics. Bob . . . ________________________________________________________________________________
Date: Jul 07, 2019
> Hence, taking care of the battery calls for > a constant voltage/constant current charging > supply that is battery friendly . . . which > is what this product would do . . . EXCEPT PERHAPS > . . . that the specifications do not call out > an 'adjustable' constant current range. Here's a less expensive device in the same power class. No "battery charging smarts" but it does have user adjustable voltage and current limits: https://tinyurl.com/y4qson88 Perhaps quite suited to the task . . . Bob . . . ________________________________________________________________________________
Date: Jul 07, 2019
On 7/7/2019 3:46 PM, Robert L. Nuckolls, III wrote: > At 12:34 PM 7/7/2019, you wrote: >> That device won't limit current pulled through his feed to the >> trailer connector. >> >> While that device might work for its intended purpose, one of its >> claims is nonsense: >> >> * Overcomes voltage drop caused by long cable runs >> >> Unless its some corollary of a perpetual motion machine. > > Don't think current through the connector > was the problem . . . the 'high current' > issue centers on the discharged battery's > willingness to accept a replacement > current greater than what is healthy for its physics. > > Hence, taking care of the battery calls for > a constant voltage/constant current charging > supply that is battery friendly . . . which > is what this product would do . . . EXCEPT PERHAPS > . . . that the specifications do not call out > an 'adjustable' constant current range. > > It's basically a dc/dc converter with > a full performance input range of 8-16 > volts where the output would be held > steady at specified charging/maintaining\ > levels and a max current of 20A. > The specs do not say that it's electronically > limited to 20A although I suspect it would > be. > > If the trailer battery is happy at 20A max > charge current, then this critter would do > the job . . . However, under a 20A output > load, current through the trailer connector > WILL be higher because of voltage > drops being compensated for by the charger's > electronics. > > > Bob . . . > Bob, his question indicated an issue with limited current capacity of his wiring in the tow vehicle ('feed to the connector'). As I read his question, the issue in his specific situation is not with hurting the battery, but with overloading the supply circuit wiring ('open the fuse on that circuit during that initial high-draw stage'). Hence, my recommendation of a boost/buck power supply with current adjust. Charlie --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Subject: Re: Y splitter
Date: Jul 07, 2019
Thanks to All for the very good information provided! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490122#490122 ________________________________________________________________________________
Date: Jul 07, 2019
>Bob, his question indicated an issue with limited current capacity >of his wiring in the tow vehicle ('feed to the connector'). As I >read his question, the issue in his specific situation is not with >hurting the battery, but with overloading the supply circuit wiring >('open the fuse on that circuit during that initial high-draw >stage'). Hence, my recommendation of a boost/buck power supply with >current adjust. > >Charlie Well fooey . . . got mentally snarled up in another discussion from years past . . . but I think I had this same discussion with a builder back in the Compuserve AvSig days. Not yet Dr. Dee and I were still running the airport . . . We fiddled with some current limiting schemes involving lengths of 10AWG wire (0.001 ohm/foot), a small contactor and a comparator to sense when drop across the resistor fell below a user adjustable level. The idea was to have additional resistance in the line to the discharged trailer battery that would be bypassed at some adjustable preset. That proved pretty messy. He decided to up-size his trailer connector to handle 6AWG battery feeders. I think it was this one: https://tinyurl.com/y48u7znv The mated pair of connectors was really cheaper than the bill of materials to do the fancy hat-dance with an electronically modulated current limiter. Since there was a battery on both ends of the feeder, I think he put an ANL35 on both ends. Thanks for the heads-up Charlie . . . Bob . . . ________________________________________________________________________________
Date: Jul 07, 2019
Date: Jul 07, 2019
> The mated pair of connectors was really > cheaper than the bill of materials to > do the fancy hat-dance with an > electronically modulated current > limiter. The link I offered for the connectors was to Waytek Wire who has a really comprehensive catalog of wiring products. Interested Listers are invited to download a copy of their catalog here: http://www.aeroelectric.com/Mfgr_Data/Misc/Waytek/waytek_catalog231.pdf Back in the days when we were selling a lot of materials, tools and supplies, we ordered quite a bit of stuff from Waytek. Bob . . . ________________________________________________________________________________
Date: Jul 07, 2019
Subject: Speaking of well loaded wires . . .
The a/c quit on the Barber Co homestead a couple days ago. Pulled of the covers and found a wire burned off the dual motor run capacitor. Emacs! The failure started in the Fast-On crimp and pretty well toasted the wire and it's mating capacitor tab before parting. I didn't think to save the carcass . . . While working the replacement, the wire fell out of the terminal on the FAN side of the capacitor! The terminal on the capacitor COMMON lead carries nearly the same current (~20A) as the COMPRESSOR side, but it was in good shape. HOWEVER . . . the other end of the capacitor COMMON wire attaching to the run contactor was starting to show stress . . . not in the crimp but on the Fast-On grips. Emacs! In the case cited above, the terminals were under-crimped. I'd replaced that same capacitor in years past but didn't see a problem with the terminals. But these were in service for over 10 years in a pretty unfriendly environment. This time, ALL the PIDG devices in the condenser wiring got replaced with a fine, ratchet-handled mash-tool. Even tho the catalogs offer a yellow PIDG for up to 10AWG wire, I think it prudent NOT to push this technology that hard in aircraft. 7A or so continuous in blue PIDG Fast-Ons have a track record of good performance. If you must push into yellow terminal territory, make sure they're 'real' TE Connectivity PIDG and use the ratchet-handled tool. Bob . . . ________________________________________________________________________________
From: Wayne Blackler <wayne_blackler(at)yahoo.com.au>
Date: Jul 08, 2019
Some current DO-160 qualified Lithium Iron Phosphate batteries often do not limit charge current. A distinct difference in next-gen similarly qualified LFP batteries is to enable the end-user to limit charge current by programming the battery management system. There are clearly implications. Particularly for all electric aircraft. A large 28VDC 40A-hr lfp battery might be good for 700A continuous discharge and could draw 600A if fully discharged on a charge cycle. If charged with a 400A starter-generator, this could put the generation system into overload, and the limit is reached in seconds. Even a 50% discharged lfp battery of this size draws huge charge currents for not insignificant durations. It would be interesting to see the effect of critical utilisation equipment hung off a bus with this issue. Thoughts? > On 8 Jul 2019, at 02:41, Alec Myers wrote: > > > > > On Jul 7, 2019, at 10:23 AM, Ken Ryan wrote: > ...But I think it points out a hole in my electrical understanding. > > . I'm imagining some type of circuit that takes in 12-14 volts, and puts out almost the same, but only at some specified number of amps. > > > Remember a battery is a two terminal device. It functions like you pick the voltage across the terminals, Ill pick the current, or, equivalently you pick the current, Ill pick the voltage. You cant pick both the voltage across the terminals and the current through the battery, independently. > > You could put some kind of negative temperature coefficient thermistor in series with the battery, and shunt that with a fat diode so as not to limit the current withdrawable from the battery? > > > > > > ________________________________________________________________________________
Date: Jul 08, 2019
At 06:16 AM 7/8/2019, you wrote: > > >Some current DO-160 qualified Lithium Iron Phosphate batteries often >do not limit charge current. A distinct difference in next-gen >similarly qualified LFP batteries is to enable the end-user to limit >charge current by programming the battery management system. There >are clearly implications. Particularly for all electric aircraft. A >large 28VDC 40A-hr lfp battery might be good for 700A continuous >discharge and could draw 600A if fully discharged on a charge cycle. >If charged with a 400A starter-generator, this could put the >generation system into overload, and the limit is reached in >seconds. Even a 50% discharged lfp battery of this size draws huge >charge currents for not insignificant durations. It would be >interesting to see the effect of critical utilisation equipment hung >off a bus with this issue. Thoughts? What goes around . . . comes around . . . Had some similar thoughts back in the hey-day of wet ni-cads finding their way onto airplanes. A number of airplanes suffered battery fires due to high rate energy replenishment after engine start. The same conditions contributed to root cause. Smaller batteries with lower thermal mass. Lower internal resistance translating into a battery's willingness to accept replenishment. The 'fix' was to add crew monitored battery temperature warning systems to the airplane. Here's an example . . . Emacs! The idea was that when the yellow light came on, the crew would disconnect the battery from the bus until the temperature fell to happier territory. Back in those days, I was participating in a series of design programs for alternator and/or generator controllers. In numerous design reviews I proposed that our product included battery temperature monitoring that would effect automatic bus voltage reduction until such time that the battery would again accept replenishment at the high rate. Some of the twin turbine a/c had DUAL 600A generators! The idea was pushed aside as in the 'too hard' pile. We'd have to re-qualify a fleet wide array of controllers. Adding the 'band-aid' to aircraft carrying ni-cads was a much simpler solution. In years since, improvements in lead-acid technologies lowered cell impedances to the point that RG batteries were subject to discharge/recharge overheat in a/c with large generators. So lead-acid batteries began to sprout connectors to carry temperature sensor data to . . . you guessed it . . . the cockpit mounted warning system. Emacs! So here we are again. Itty bitty LiPO4 cells quite capable of producing engine cranking power are similarly at-risk for reduced service life from a pair of stresses. (1) high temperature induced by extended current flows with I(squared)R losses dumped into very low thermal mass and (2) over discharge below some voltage threshold that trashes the chemistry. Folks like Earth-X and TrueBlue have built protections into their battery. Why? Because the primary instigators of risk to the battery (charging system and battery contactor) have no idea as to the battery's condition hence not configured to do the really simple job of mitigating battery abuse. In the OBAM aviation world, we have opportunity to take the next step in power system management and control. It would be no big deal to build alternator controllers that would take battery chemistry and size into account . . . totally eliminating the need for temperature monitoring. Similarly, a battery contactor controller could be crafted to simply unhook the battery when the voltage dropped below some established limit. Perhaps its time that the DC power system be treated as an orchestra of components that play well TOGETHER. Right now, the players are marching to their own tunes with nary a care for each other's limits and needs. Bob . . . ________________________________________________________________________________
Date: Jul 08, 2019
Mr N...as always I am in awe of your immense repository of knowledge...not that others on the group can't challenge you...but I am grateful that you make the time to dispense same on this forum. Often it is a topic that does not really interest me. Yet I find myself drawn inextricably away from the DELETE button! On Mon, 08 Jul 2019, 5:50 PM Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 06:16 AM 7/8/2019, you wrote: > > wayne_blackler(at)yahoo.com.au> > > Some current DO-160 qualified Lithium Iron Phosphate batteries often do > not limit charge current. A distinct difference in next-gen similarly > qualified LFP batteries is to enable the end-user to limit charge current > by programming the battery management system. There are clearly > implications. Particularly for all electric aircraft. A large 28VDC 40A-hr > lfp battery might be good for 700A continuous discharge and could draw 600A > if fully discharged on a charge cycle. If charged with a 400A > starter-generator, this could put the generation system into overload, and > the limit is reached in seconds. Even a 50% discharged lfp battery of this > size draws huge charge currents for not insignificant durations. It would > be interesting to see the effect of critical utilisation equipment hung off > a bus with this issue. Thoughts? > > > What goes around . . . comes around . . . > > Had some similar thoughts back in the hey-day > of wet ni-cads finding their way onto airplanes. > A number of airplanes suffered battery fires > due to high rate energy replenishment after engine > start. The same conditions contributed to > root cause. Smaller batteries with lower > thermal mass. Lower internal resistance > translating into a battery's willingness to accept > replenishment. > > The 'fix' was to add crew monitored > battery temperature warning systems to > the airplane. Here's an example . . . > > [image: Emacs!] > > The idea was that when the yellow light > came on, the crew would disconnect the > battery from the bus until the temperature > fell to happier territory. > > Back in those days, I was participating in > a series of design programs for alternator > and/or generator controllers. In numerous > design reviews I proposed that our product > included battery temperature monitoring > that would effect automatic bus voltage > reduction until such time that the battery > would again accept replenishment at the > high rate. Some of the twin turbine > a/c had DUAL 600A generators! > > The idea was pushed aside as in the 'too > hard' pile. We'd have to re-qualify > a fleet wide array of controllers. Adding > the 'band-aid' to aircraft carrying ni-cads > was a much simpler solution. > > In years since, improvements in lead-acid > technologies lowered cell impedances > to the point that RG batteries were > subject to discharge/recharge overheat > in a/c with large generators. So > lead-acid batteries began to sprout > connectors to carry temperature sensor > data to . . . you guessed it . . . > the cockpit mounted warning system. > > [image: Emacs!] > > So here we are again. Itty bitty LiPO4 > cells quite capable of producing engine > cranking power are similarly at-risk > for reduced service life from a pair > of stresses. (1) high temperature > induced by extended current flows > with I(squared)R losses dumped into > very low thermal mass and (2) over > discharge below some voltage threshold > that trashes the chemistry. > > Folks like Earth-X and TrueBlue have > built protections into their battery. > Why? Because the primary instigators > of risk to the battery (charging > system and battery contactor) have > no idea as to the battery's condition > hence not configured to do the > really simple job of mitigating > battery abuse. > > In the OBAM aviation world, we have > opportunity to take the next step > in power system management and control. > It would be no big deal to build > alternator controllers that would > take battery chemistry and size > into account . . . totally eliminating > the need for temperature monitoring. > > Similarly, a battery contactor controller > could be crafted to simply unhook the > battery when the voltage dropped below > some established limit. > > Perhaps its time that the DC power system > be treated as an orchestra of components > that play well TOGETHER. Right now, the > players are marching to their own tunes > with nary a care for each other's limits > and needs. > > > Bob . . . > ________________________________________________________________________________
Date: Jul 08, 2019
Look for a "poly fuse" in the aviation section of an auto parts store. These will limit current to the rated value Sent from Yahoo Mail on Android On Sun, Jul 7, 2019 at 10:01 AM, Jared Yates wrote: I have a question that's only somewhat applicable to E/AB aviation, apologies in advance. But I think it points out a hole in my electrical understanding. The characteristics of the lithium iron battery I'm running allow it to draw lots of current really fast after the engine starts. If it has been a little while since the last flight, the alternator is at max output for several minutes. The alternator puts out all it can give, and it's less than the battery wants to take. Stepping out of the hangar, my tow vehicle circuitry includes a wire in the 7-pin connector that provides alternator voltage to the trailer, intending to charge a small battery for a breakaway emergency brake. If I install a larger battery for other purposes, perhaps one like what is in the airplane, and connect it to that line coming from the truck, it seems like it would almost certainly open the fuse on that circuit during that initial high-draw stage. These two scenarios had me thinking, what methods would one have to limit a hungry battery's draw? I'm imagining some type of circuit that takes in 12-14 volts, and puts out almost the same, but only at some specified number of amps. Almost like a DC-powered battery charging circuit, rather than just putting the battery on the bus directly. Surely this has been solved in some off-the-shelf widget, but I haven't figured out the words to google yet. ________________________________________________________________________________
Date: Jul 08, 2019
At 11:14 AM 7/8/2019, you wrote: >Mr N...as always I am in awe of your immense repository of >knowledge...not that others on the group can't challenge you...but I >am grateful that you make the time to dispense same on this forum. >Often it is a topic that does not really interest me. Yet I find >myself drawn inextricably away from the DELETE button! Thank you for those kind words. I am grateful to my teachers and constellation of employers who offered a great spectrum of opportunities. Knowledge is like cash . . . the value of which grows in proportion to how much it CIRCULATES. We all have opportunity to stir the great stew pot of knowledge. I have been gifted with a really big pot and spoon to go with it. Your participation here goes toward refining recipes for success based on knowledge and science. Thank you for being here! Bob . . . ________________________________________________________________________________
Date: Jul 08, 2019
=81=A3Sent from BlueMail =8B On Jul 8, 2019, 10:50 AM, at 10:50 AM, "Robert L=2E Nuckolls, III" wrote: >At 06:16 AM 7/8/2019, you wrote: >>--> AeroElectric-List message posted b y: Wayne Blackler >> >> >>Some current DO -160 qualified Lithium Iron Phosphate batteries often >>do not limit charg e current=2E A distinct difference in next-gen >>similarly qualified LFP b atteries is to enable the end-user to limit >>charge current by programmin g the battery management system=2E There >>are clearly implications=2E Par ticularly for all electric aircraft=2E A >>large 28VDC 40A-hr lfp battery might be good for 700A continuous >>discharge and could draw 600A if full y discharged on a charge cycle=2E >>If charged with a 400A starter-generat or, this could put the >>generation system into overload, and the limit is reached in >>seconds=2E Even a 50% discharged lfp battery of this size dr aws huge >>charge currents for not insignificant durations=2E It would be >>interesting to see the effect of critical utilisation equipment hung >> off a bus with this issue=2E Thoughts? > > What goes around =2E =2E =2E c omes around =2E =2E =2E > > Had some similar thoughts back in the hey-day > of wet ni-cads finding their way onto airplanes=2E > A number of air planes suffered battery fires > due to high rate energy replenishment aft er engine > start=2E The same conditions contributed to > root cause=2E Smaller batteries with lower > thermal mass=2E Lower internal resistance > translating into a battery's willingness to accept > replenishment =2E > > The 'fix' was to add crew monitored > battery temperature warni ng systems to > the airplane=2E Here's an example =2E =2E =2E > >Emacs! > > > The idea was that when the yellow light > came on, the crew would disconnect the > battery from the bus until the temperature > fell to h appier territory=2E > > Back in those days, I was participating in > a series of design programs for alternator > and/or generator controllers =2E In numerous > design reviews I proposed that our product > included battery temperature monitoring > that would effect automatic bus voltage > reduction until such time that the battery > would again accept repl enishment at the > high rate=2E Some of the twin turbine > a/c had DUAL 600A generators! > > The idea was pushed aside as in the 'too > hard' pile=2E We'd have to re-qualify > a fleet wide array of controllers=2E Ad ding > the 'band-aid' to aircraft carrying ni-cads > was a much simpler solution=2E > > In years since, improvements in lead-acid > technologi es lowered cell impedances > to the point that RG batteries were > subj ect to discharge/recharge overheat > in a/c with large generators=2E So > lead-acid batteries began to sprout > connectors to carry temperature sensor > data to =2E =2E =2E you guessed it =2E =2E =2E > the cockpit m ounted warning system=2E > >Emacs! > > > So here we are again=2E Itty bit ty LiPO4 > cells quite capable of producing engine > cranking power are similarly at-risk > for reduced service life from a pair > of stresses =2E (1) high temperature > induced by extended current flows > with I(s quared)R losses dumped into > very low thermal mass and (2) over > disc harge below some voltage threshold > that trashes the chemistry=2E > > Folks like Earth-X and TrueBlue have > built protections into their batte ry=2E > Why? Because the primary instigators > of risk to the battery ( charging > system and battery contactor) have > no idea as to the batte ry's condition > hence not configured to do the > really simple job of mitigating > battery abuse=2E > > In the OBAM aviation world, we have > opportunity to take the next step > in power system management and con trol=2E > It would be no big deal to build > alternator controllers tha t would > take battery chemistry and size > into account =2E =2E =2E to tally eliminating > the need for temperature monitoring=2E > > Similarl y, a battery contactor controller > could be crafted to simply unhook the > battery when the voltage dropped below > some established limit=2E > > Perhaps its time that the DC power system > be treated as an orchest ra of components > that play well TOGETHER=2E Right now, the > players are marching to their own tunes > with nary a care for each other's limit s > and needs=2E > > > Bob =2E =2E =2E ________________________________________________________________________________
Date: Jul 08, 2019
Don't polyfuses simply open/close? With no regulation, wouldn't you just ge t a series of pulses? =81=A3Sent from BlueMail =8B On Jul 8, 201 9, 11:44 AM, at 11:44 AM, Ernest Christley wrote: >L ook for a "poly fuse" in the aviation section of an auto parts store=2E >Th ese will limit current to the rated value > >Sent from Yahoo Mail on Androi d > >On Sun, Jul 7, 2019 at 10:01 AM, Jared Yates >wrote: I have a question that's only somewhat applicable to E/AB >aviat ion, apologies in advance=2E But I think it points out a hole in my >electr ical understanding=2E >The characteristics of the lithium iron battery I'm running allow it to >draw lots of current really fast after the engine star ts=2E If it has >been a little while since the last flight, the alternator is at max >output for several minutes=2E The alternator puts out all it can give, >and it's less than the battery wants to take=2E >Stepping out of th e hangar, my tow vehicle circuitry includes a wire in >the 7-pin connector that provides alternator voltage to the trailer, >intending to charge a sma ll battery for a breakaway emergency brake=2E If >I install a larger batter y for other purposes, perhaps one like what is >in the airplane, and connec t it to that line coming from the truck, it >seems like it would almost cer tainly open the fuse on that circuit >during that initial high-draw stage =2E >These two scenarios had me thinking, what methods would one have to >l imit a hungry battery's draw? I'm imagining some type of circuit that >take s in 12-14 volts, and puts out almost the same, but only at some >specified number of amps=2E Almost like a DC-powered battery charging >circuit, rath er than just putting the battery on the bus directly=2E >Surely this has be en solved in some off-the-shelf widget, but I haven't >figured out the word s to google yet=2E ________________________________________________________________________________
Date: Jul 08, 2019
The battery manufacturer, EarthX, wrote: > Based on extensive testing, the maximum charge rating will never be exceeded using this simple and reliable diode isolation design. https://earthxbatteries.com/dual-bus-lithium-battery-design So why not try using diodes first before trying more complicated methods to reduce the voltage and current. An assortment of diodes with various forward voltage drops could be tried. Yes, it is trial and error. But so is finding the ideal voltage output of a DC-DC converter. By the way, it is physically impossible to reduce the battery charging current without lowering the charging voltage that is connected to the battery. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490144#490144 ________________________________________________________________________________
Date: Jul 08, 2019
At 11:36 AM 7/8/2019, you wrote: >Look for a "poly fuse" in the aviation section of an auto parts >store. These will limit current to the rated value No, these are intended to perform the same function as breakers and fuses. Placed in series with the power path to an electrical load, they present a low resistance at or below a certain temperature. Should an overload occur, they warm past the 'trip point' where the resistance rises rapidly thus mitigating the fault current. See: https://tinyurl.com/7vt49mw https://tinyurl.com/y2uh3byy The TC aircraft world flirted with these critters on several occasions where I participated . . . and there were no doubt others. There are several power distribution products offered to the OBAM aviation community that feature Polyfuses. One of the earliest examples is the EXPBUS Emacs! Greg Richter was a proponent of Polyfuses in his designs. One proposal for light aircraft power distribution took this form: Emacs! (We had quite a discussion about both products which have been archived on AeroElectric.com if anyone is interested. Search on expbus or polyfuse. But suffice it to say that Polyfuses are not well suited for protection of power distribution feeders in aircraft. They are well suited to protection of circuitry WITHIN an electro-whizzy . . . indeed, they're sold by the millions for that purpose. They've alos found utility on some automotive applications . . . like providing electrical limit stops for power windows. Bob . . . ________________________________________________________________________________
Date: Jul 08, 2019
At 02:23 PM 7/8/2019, you wrote: >Don't polyfuses simply open/close? With no regulation, wouldn't you >just get a series of pulses? close . . . the polyfuse maintains a low resistance state BELOW some trip point whereupon it reverts to a high resistance state. Current flow never goes to zero and the 'fuse' is held in the high-resistance condition at some current value well below hazardous. To 'reset' a polyfuse, you have to remove the current and allow the device to cool whereupon the magic molecules re-arrange to form the low-resistance matrix. Bob . . . ________________________________________________________________________________
Date: Jul 09, 2019
Subject: Re: King Molex connectors
VERY helpful Thank you. Michael Wynn -----Original Message----- From: Charles Birdsall <cbirdsall6(at)cox.net> Sent: Fri, Jul 5, 2019 6:52 pm Subject: Re: AeroElectric-List: King Molex connectors Michael,You can purchase the pins here:=C2-http://lane-pilot.com/25-pcs- BendixKing-tray-contacts-KX155KMA24KX196KN53etc_p_123.html as well as every thing else I mention here ...The extractor is a Molex PN HT-1884. You can m ake your own - I've done so using a cheap stainless 6" rule on the dollar s helf at the hardware store.=C2- I ground down one end so that it looked s imilar to the tool in the picture and then carefully sized it to fit into t he tiny little slot above/below the pins in the connector. Take a look at t he KX 155 Install manual, Page 2-6 - you'll see a picture of the removal to ol and the pins.=C2- The pins have a narrow tang that locks into place by dropping into a stepped slot=C2- when it's inserted into the rear of the connector.=C2- The removal tool simply pushes the tang up so that it dis engages from the slot. To use it, insert it into the slot above or below th e pin (depending on which row you're after) from the front of the connector , give it a little push to disengage the tang and either push the pin out f rom the front with a blunt tool or pull it out the back using the attached wire. Use finesse, not brute force. It won't come out if the tang isn't dis engaged.=C2-RF connections:=C2- Solder-in style is TED PN 9-30-10 (simi lar to the original).=C2- It takes a little practice to solder these well .OR you can go with a Delkin=C2- DBA 600 and not have to solder the whip at all.=C2- Make your antenna lead long enough to reach the back of the t ray and crimp on a BNC connector.=C2-One caution: One row of pins is numb ered, the other is alphabetical. The alphabetical row is missing the G, I, O,=C2- and Q. Forget that and you'll get the pins in the wrong place. Bee n there, done that.KX 155 install manual is here:=C2-http://aeroelectric. com/Installation_Data/Bendix-King/KX155_IM.pdf Chuck On July 5, 2019 at 3:07 PM Michael Wynn wrote: Hi All, I am restoring and re-wiring a 1977 Pitts.=C2- The radios are a King KY97 a and a King 76c.=C2- Both have wiring going into a rack and some version of molex pins in a plastic holder at the rear.=C2- When wiring my RV8, I was using Garmin radios that all use more standard Sub-d pins and sockets. I want to replace some wires and add a couple of circuits.=C2- I am reall y unclear about how to remove and replace these pins and where I buy replac ement pins.=C2-=C2- I also want to put new RG400 for the wires to the antennae.=C2- There is a right angle connector, but I am really unsure if I can remove the current antenna wiring and replace them.=C2- Anyone with experience dealing with these connectors? Regards, Michael WynnPitts S1-SRV 8Livermore, CA ________________________________________________________________________________
Subject: =?ISO-8859-1?Q?=D8=B4=D8=B1=D9=83=D8=A9?= =?ISO-8859-1?Q?=D8=D9=86=D8=B8=D9=8A=D9=81?
Date: Jul 08, 2019
(https://www.homecleaninc.com/) (https://www.homecleaninc.com/%d8%ac%d9%84%d9%8a-%d8%b1%d8%ae%d8%a7%d9%85/) (https://www.homecleaninc.com/%d8%b4%d8%b1%d9%83%d8%a9-%d8%ba%d8%b3%d9%8a%d9%84-%d8%b3%d8%ac%d8%a7%d8%af-%d8%a7%d9%84%d9%83%d9%88%d9%8a%d8%aa/) (https://www.homecleaninc.com/%d8%b4%d8%b1%d9%83%d8%a9-%d8%aa%d9%86%d8%b8%d9%8a%d9%81-%d8%b3%d8%ac%d8%a7%d8%af-%d8%a7%d9%84%d9%83%d9%88%d9%8a%d8%aa/) (https://www.homecleaninc.com/%d8%b4%d8%b1%d9%83%d8%a9-%d8%aa%d9%86%d8%b8%d9%8a%d9%81-%d9%83%d9%86%d8%a8%d8%a7%d8%aa-%d8%a8%d8%a7%d9%84%d9%83%d9%88%d9%8a%d8%aa/) (https://www.homecleaninc.com/) bed (https://www.homecleaninc.com/%d8%ac%d9%84%d9%8a-%d8%b1%d8%ae%d8%a7%d9%85/) . (https://www.homecleaninc.com/%d8%b4%d8%b1%d9%83%d8%a9-%d8%ba%d8%b3%d9%8a%d9%84-%d8%b3%d8%ac%d8%a7%d8%af-%d8%a7%d9%84%d9%83%d9%88%d9%8a%d8%aa/) (https://www.homecleaninc.com/%d8%b4%d8%b1%d9%83%d8%a9-%d8%aa%d9%86%d8%b8%d9%8a%d9%81-%d8%b3%d8%ac%d8%a7%d8%af-%d8%a7%d9%84%d9%83%d9%88%d9%8a%d8%aa/) . (https://www.homecleaninc.com/%d8%b4%d8%b1%d9%83%d8%a9-%d8%aa%d9%86%d8%b8%d9%8a%d9%81-%d9%83%d9%86%d8%a8%d8%a7%d8%aa-%d8%a8%d8%a7%d9%84%d9%83%d9%88%d9%8a%d8%aa/) . . ' . . . . . . e'er . Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490150#490150 ________________________________________________________________________________
Date: Jul 09, 2019
I'm no expert, but Bob's idea seems to have great merit.I have noticed, aft er starting my IO-390 using my two EarthX LiFePo batteries, the amps go to 57 immediately after start.=C2- The alternator is a 60A Plane Power, so i t is being maxed out.It could be that the EarthX monitor system is limiting the charge so as to avoid exceeding a particular charging limit, but I am not sure of that.=C2- I have little experience with the batteries thus fa r.I am currently installing a complete new panel and the new AFS5800 has in puts available for monitoring the batteries.=C2- I intend to connect them and configure the EFIS.Stan SutterfieldSpruce Creek Fly-In, FL From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Subject: Re: AeroElectric-List: Limiting Current to a Battery At 06:16 AM 7/8/2019, you wrote: > > >Some current DO-160 qualified Lithium Iron Phosphate batteries often >do not limit charge current. A distinct difference in next-gen >similarly qualified LFP batteries is to enable the end-user to limit >charge current by programming the battery management system. There >are clearly implications. Particularly for all electric aircraft.=C2- A >large 28VDC 40A-hr lfp battery might be good for 700A continuous >discharge and could draw 600A if fully discharged on a charge cycle. >If charged with a 400A starter-generator, this could put the >generation system into overload, and the limit is reached in >seconds. Even a 50% discharged lfp battery of this size draws huge >charge currents for not insignificant durations. It would be >interesting to see the effect of critical utilisation equipment hung >off a bus with this issue. Thoughts? =C2- What goes around . . . comes around . . . =C2- Had some similar thoughts back in the hey-day =C2- of wet ni-cads finding their way onto airplanes. =C2- A number of airplanes suffered battery fires =C2- due to high rate energy replenishment after engine =C2- start. The same conditions contributed to =C2- root cause. Smaller batteries with lower =C2- thermal mass. Lower internal resistance =C2- translating into a battery's willingness to accept =C2- replenishment. =C2- The 'fix' was to add crew monitored =C2- battery temperature warning systems to =C2- the airplane. Here's an example . . . Emacs! =C2- The idea was that when the yellow light =C2- came on, the crew would disconnect the =C2- battery from the bus until the temperature =C2- fell to happier territory. =C2- Back in those days, I was participating in =C2- a series of design programs for alternator =C2- and/or generator controllers. In numerous =C2- design reviews I proposed that our product =C2- included battery temperature monitoring =C2- that would effect automatic bus voltage =C2- reduction until such time that the battery =C2- would again accept replenishment at the =C2- high rate. Some of the twin turbine =C2- a/c had DUAL 600A generators! =C2- The idea was pushed aside as in the 'too =C2- hard' pile. We'd have to re-qualify =C2- a fleet wide array of controllers. Adding =C2- the 'band-aid' to aircraft carrying ni-cads =C2- was a much simpler solution. =C2- In years since, improvements in lead-acid =C2- technologies lowered cell impedances =C2- to the point that RG batteries were =C2- subject to discharge/recharge overheat =C2- in a/c with large generators. So =C2- lead-acid batteries began to sprout =C2- connectors to carry temperature sensor =C2- data to . . . you guessed it . . . =C2- the cockpit mounted warning system. Emacs! =C2- So here we are again. Itty bitty LiPO4 =C2- cells quite capable of producing engine =C2- cranking power are similarly at-risk =C2- for reduced service life from a pair =C2- of stresses. (1) high temperature =C2- induced by extended current flows =C2- with I(squared)R losses dumped into =C2- very low thermal mass and (2) over =C2- discharge below some voltage threshold =C2- that trashes the chemistry. =C2- Folks like Earth-X and TrueBlue have =C2- built protections into their battery. =C2- Why? Because the primary instigators =C2- of risk to the battery (charging =C2- system and battery contactor) have =C2- no idea as to the battery's condition =C2- hence not configured to do the =C2- really simple job of mitigating =C2- battery abuse. =C2- In the OBAM aviation world, we have =C2- opportunity to take the next step =C2- in power system management and control. =C2- It would be no big deal to build =C2- alternator controllers that would =C2- take battery chemistry and size =C2- into account . . . totally eliminating =C2- the need for temperature monitoring. =C2- Similarly, a battery contactor controller =C2- could be crafted to simply unhook the =C2- battery when the voltage dropped below =C2- some established limit. =C2- Perhaps its time that the DC power system =C2- be treated as an orchestra of components =C2- that play well TOGETHER. Right now, the =C2- players are marching to their own tunes =C2- with nary a care for each other's limits =C2- and needs. =C2- Bob . . .=C2- ________________________________________________________________________________
Subject: Re: WIFI Repeater/Booster Options For My Remote Steel
Hangar???
Date: Jul 09, 2019
There is an easier way, I can suggest you to buy one more wifi router and to connect it with an UTP cable that is long enough to reach the other router. My house is big, and I bought one more router because one wasnt enough for the whole house. If you want more ideas () it may be useful for you, it is telling you how to configure router to work on larger distance oar gives ideas how to connect 2 routers with each other. It may be useful for you and for others. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490152#490152 ________________________________________________________________________________
Date: Jul 09, 2019
What he said, Charlie.=C2- I had a part with threaded studs that was a 4 0amp fuse.=C2- I was under the impression that it acted as a current limi ter.=C2- It appears that I was wrong. olls.bob(at)aeroelectric.com> wrote: At 02:23 PM 7/8/2019, you wrote: Don't polyfuses simplyopen/close? With no regulation, wouldn't you just get a series ofpulses? =C2- close . . . the polyfuse maintains a low =C2- resistance state BELOW some trip point =C2- whereupon it reverts to a high resistance =C2- state. Current flow never goes to zero and =C2- the 'fuse' is held in the high-resistance =C2- condition at some current value well below =C2- hazardous. =C2- To 'reset' a polyfuse, you have to remove =C2- the current and allow the device to cool =C2- whereupon the magic molecules re-arrange =C2- to form the low-resistance matrix. =C2- =C2- Bob . . . ________________________________________________________________________________
Date: Jul 09, 2019
Before inserting a diode, I'd add a one ohm "sensing" resistor in the char ge line.=C2- You'd get the benefit of having a way to sense the health of the generator/alternator along with never being able to exceed the maximum charge current. rote: The battery manufacturer, EarthX, wrote: > Based on extensive testing, the maximum charge rating will never be excee ded using this simple and reliable diode isolation design. https://earthxbatteries.com/dual-bus-lithium-battery-design So why not try using diodes first before trying more complicated methods to reduce the voltage and current.=C2- An assortment of diodes with various forward voltage drops could be tried.=C2- Yes, it is trial and error.=C2 - But so is finding the ideal voltage output of a DC-DC converter. =C2- By the way, it is physically impossible to reduce the battery chargi ng current without lowering the charging voltage that is connected to the b attery. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490144#490144 - S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Jul 09, 2019
Adding a resistor with that high impedance would certainly limit the charging current! To only a couple amps or so... The idea would probably work, but the resistor would have to be much less than 1 ohm and would have to be a high wattage one. Dick Tasker Ernest Christley wrote: > Before inserting a diode, I'd add a one ohm "sensing" resistor in the charge line. You'd get the benefit of having a way to sense the health of the generator/alternator along with never being able > to exceed the maximum charge current. > > > > The battery manufacturer, EarthX, wrote: > > > Based on extensive testing, the maximum charge rating will never be exceeded using this simple and reliable diode isolation design. > > https://earthxbatteries.com/dual-bus-lithium-battery-design > So why not try using diodes first before trying more complicated methods to reduce the voltage and current. An assortment of diodes with various forward voltage drops could be tried. Yes, it is > trial and error. But so is finding the ideal voltage output of a DC-DC converter. > By the way, it is physically impossible to reduce the battery charging current without lowering the charging voltage that is connected to the battery. > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=490144#490144 > > > http://www.matronics.com/Navigator?AeroElectric-List > http://forums.matronics.com > http://wiki.sp; &= --> http://www.matronics.com/contribution > > ________________________________________________________________________________
Date: Jul 09, 2019
Steel Hangar??? At 07:29 AM 7/9/2019, you wrote: >"LecrameMark" > >There is an easier way, I can suggest you to buy >one more wifi router and to connect it with an >UTP cable that is long enough to reach the other >router. My house is big, and I bought one more >router because one wasn=99t enough for the whole >house. If you want more ideas () it may be >useful for you, it is telling you how to >configure router to work on larger distance oar >gives ideas how to connect 2 routers with each >other. It may be useful for you and for others. Just finished resolving a similar problem with my wifi system. A recent refurbishment of a deck at the back of my house offered an opportunity to move my main router to the highest possible point inside the house. Couldn't use the attic due to temperature variations but we added a power and cat5 cable conduit up through the walls to an upstairs bedroom. The router is now about 20' above terrain on the property. I can now remain 'connected' for up to 200 to 300 feet all around the house. Dr. Dee's system needed cat5 interconnect so I've been using an 'extender' at her desk. These don't have a WAN port, only 4 LAN ports. They listen-talk on 2.4 and 5.8G so you can set them up to become another wifi 'source' with their own SSID. I set up Dr. Dee's with a 5G SSID only because it let's me monitor her connectivity from my mobile phone. Other than convenience of maintenance, the extender could be radio-silent and only the cat5 ports active to connect up her office. I have another extender as wifi repeaters with independent SSIDs for the 'kids' wifi. It's powered through a programmable timer that limits their access. A third extender is kept on hand to supply a cat5 portal to the system for times that I'm working a computer that doesn't have wifi capability. There is a boat-load of extender products out there at really attractive prices. The key to good coverage is improving radio illumination of the property where (like in airplanes) ALTITUDE has a profound effect on range. Getting my main router elevated made a huge difference. Adding extenders in remote buildings (also as high and clear as practical) would offer both wifi SSID and Cat5 interconnection in the building. For your steel hangar situation, mounting a radio-silent extender in a plastic housing outside on a wall facing the house might do it. You could then bring cat5 into the hangar to another router that puts the hangar on the 'net with its own system. I've offered to try this for a friend out in the Gyp Hills with outbuildings a quarter mile away from the house. Will post the results as they become known. Bob . . . ________________________________________________________________________________
Subject: Re: Limiting Current to a Battery
Date: Jul 09, 2019
Suppose the battery charging current is 10 amps. The voltage drop across a 1 ohm resistor with 10 amps flowing is 10 volts. That leaves 4 volts to charge the battery. It will not work. A resistor of 0.05 ohms times 10 amps equals 0.5 volts dropped across the resistor, which is about right. A 16 AWG wire that is 15 feet long has about 0.05 ohms. Maybe the towing vehicle and trailer wires already have enough resistance to limit battery charging current to a safe value. Maybe we are trying to solve a problem that does not exist. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490156#490156 ________________________________________________________________________________
Date: Jul 09, 2019
Steel Hangar??? Folks, I want to add a few things to what Bob wrote. 5.8 GHz attenuates rapidly as it passes through walls. You may find that just two or three walls are enough to make the signal unusable. Play with the location of your WiFi access point. Moving it a few feet side to side or up and down can make a huge difference. 2.4 GHz doesn't attenuate as badly as the signal passes through walls, ceilings, etc. but microwave ovens interfere with it badly. If you are out in the country, as opposed to in an apartment building with dozens of other WiFi access points, you may find that 2.4 GHz gives you broader, easier to manage coverage. 2.4 GHz looks like it has lots of channels but, in fact, only channels 1, 6, and 11 are useful here in the US. They are the only three which do not overlap. See https://www.electronics-notes.com/articles/connectivity/wifi-ieee-802-11/ch annels-frequencies-bands-bandwidth.php When you configure your WiFi radio(s), make sure that you channels don't overlap, either your own equipment or your neighbors'. On Android, I use the Wifi Analyzer tool to display what is going on. There are similar ones on iOS, I'm sure. Many WiFi routers let you choose a maximum speed. In actuality, you are choosing the frequency bandwidth of the channel that you are using. Generally speaking, the transmitter power remains unchanged. If you choose a higher maximum speed, the transmitter spreads the power across a broader frequency range. You get more speed but less distance. By choosing a lower maximum speed, the transmitter focuses its power on a narrower frequency range and you get more distance. If all you do in the steel out-building is check your email, not watch Netflix and YouTube, you don't need much speed. Cheers, -- Art Z. On Tue, Jul 9, 2019 at 10:35 AM Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 07:29 AM 7/9/2019, you wrote: > > lecramermark(at)yahoo.com> > > There is an easier way, I can suggest you to buy one more wifi router and > to connect it with an UTP cable that is long enough to reach the other > router. My house is big, and I bought one more router because one wasn=C3 =A2=82=AC=84=A2t > enough for the whole house. If you want more ideas () it may be useful fo r > you, it is telling you how to configure router to work on larger distance > oar gives ideas how to connect 2 routers with each other. It may be usefu l > for you and for others. > > > Just finished resolving a similar > problem with my wifi system. A recent > refurbishment of a deck at the back of > my house offered an opportunity to > move my main router to the highest > possible point inside the house. Couldn't > use the attic due to temperature variations > but we added a power and cat5 cable conduit > up through the walls to an upstairs > bedroom. > > The router is now about 20' above > terrain on the property. I can > now remain 'connected' for up to > 200 to 300 feet all around the house. > > Dr. Dee's system needed cat5 interconnect > so I've been using an 'extender' at her > desk. These don't have a WAN port, only > 4 LAN ports. They listen-talk on 2.4 and > 5.8G so you can set them up to become > another wifi 'source' with their own > SSID. I set up Dr. Dee's with a 5G > SSID only because it let's me monitor > her connectivity from my mobile phone. > > Other than convenience of maintenance, > the extender could be radio-silent > and only the cat5 ports active to > connect up her office. > > I have another extender as wifi > repeaters with independent SSIDs > for the 'kids' wifi. It's powered > through a programmable timer that > limits their access. > > A third extender is kept on hand > to supply a cat5 portal to the system > for times that I'm working a computer > that doesn't have wifi capability. > > There is a boat-load of extender > products out there at really > attractive prices. The key to > good coverage is improving > radio illumination of the property > where (like in airplanes) ALTITUDE > has a profound effect on range. > > Getting my main router elevated made > a huge difference. Adding extenders > in remote buildings (also as > high and clear as practical) would > offer both wifi SSID and Cat5 > interconnection in the building. > > > For your steel hangar situation, > mounting a radio-silent extender > in a plastic housing outside on a > wall facing the house might do it. > You could then bring cat5 into > the hangar to another router that > puts the hangar on the 'net with > its own system. I've offered to > try this for a friend out in > the Gyp Hills with outbuildings > a quarter mile away from the house. > Will post the results as they become > known. > > > Bob . . . > -- https://CheerfulCurmudgeon.com/ *Pray as if everything depends on God. Act as if everything depends on you. * ________________________________________________________________________________
From: David and Elaine Lamphere <dalamphere(at)comcast.net>
Subject: Headset Conversion
Date: Jul 09, 2019
A few weeks back I purchased a Flightcom E-13 ANR Headset off of EBay. It was a really good price for a like new set. Found out later it was a Military (one-plug) headset. No problem, ordered an adapter (Pilot brand) to use it with a normal GA intercom. Well that turned out to be a problem - while you could talk and hear like usual, there was a great deal of static and loud white noise! I understand theres also a difference in impedance? Has anyone converted one of these military noise-cancelling headsets to a general aviation 2-plug set? Or is this just wishful thinking? David ________________________________________________________________________________
Hangar???
Date: Jul 09, 2019
I did something similar to this for a customer a few years back. They had a garage about 150' away from the office and wanted network access in the garage. Parking lot was paved so laying cable wasn't an option. We went with an outdoor wireless extender. Basically, two outdoor antennas (there were directional) that we connected to a wireless AP in the shop. Worked great. But costs about $500. Looks like prices have come down. Engenius was the brand. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490167#490167 ________________________________________________________________________________
Steel Hangar???
Date: Jul 09, 2019
On 7/9/2019 4:35 PM, donjohnston wrote: > > I did something similar to this for a customer a few years back. They had a garage about 150' away from the office and wanted network access in the garage. Parking lot was paved so laying cable wasn't an option. > > We went with an outdoor wireless extender. Basically, two outdoor antennas (there were directional) that we connected to a wireless AP in the shop. > > Worked great. But costs about $500. Looks like prices have come down. > > Engenius was the brand. > > Also, https://www.google.com/search?ei=ziIIW5XaA8zXzwKzr4dI&q=Ubiquiti+nano+station&oq=Ubiquiti+nano+station&gs_l=psy-ab.12..0i10k1l6.3555.99914.0.101253.3.3.0.0.0.0.230.649.0j1j2.3.0....0...1c.1j2.64.psy-ab..0.3.645...0j0i67k1j0i20i264k1.0.GvJK3J6l8As No 1st hand experience, but some linux guys who are network gurus recommended them. Apparently they can be quite long range. This one: https://www.balticnetworks.com/nsm5-ubiquiti-nanostation-m5-airmax-intl.html claims range to 15km. --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jul 09, 2019
At 12:02 PM 7/7/2019, you wrote: >Would it be a DC-DC battery charger? > >https://www.renogy.com/renogy-12v-dc-to-dc-on-board-batte ry-charger/?gclid=CjwKCAjwsIbpBRBNEiwAZF8-z-TrUeFYygbwZh7wrFUpKO_RhdCJkW-v J-BFwYS_IZjlu9G8uAMNcxoCgBoQAvD_BwE=C2 >=C2 > >On Sun, Jul 7, 2019 at 7:05 AM Jared Yates ><email(at)jaredyates.com> wrote: >I have a question that's only somewhat >applicable to E/AB aviation, apologies in >advance. But I think it points out a hole in my electrical understanding. > >The characteristics of the lithium iron battery >I'm running allow it to draw lots of current >really fast after the engine starts. If it has >been a little while since the last flight, the >alternator is at max output for several minutes. >The alternator puts out all it can give, and >it's less than the battery wants to take. > >Stepping out of the hangar, my tow vehicle >circuitry includes a wire in the 7-pin connector >that provides alternator voltage to the trailer, >intending to charge a small battery for a >breakaway emergency brake. If I install a larger >battery for other purposes, perhaps one like >what is in the airplane, and connect it to that >line coming from the truck, it seems like it >would almost certainly open the fuse on that >circuit during that initial high-draw stage. Had to come back and review the headwaters of this thread. Seems this is a hypothetical not yet validated by the actual blowing of the cited fuse. The WIRE from the ending compartment back to the trailer has SIGNIFICANT resistance in the battery charging world. As Joe pointed out, a 50 milliohm resistance in a 10A charging path would drop 1/2 volt. This would cause a significant reduction in charge current to the second battery. Can you offer us a schematic of the trailer battery system? Does the battery feeder also supply power for electric brakes . . . or is that a separate path? What size fuse is protecting the current wire . . . and what size is the wire? 10AWG wire is 0.001 ohms per foot. So a 20' run would 'ballast' your charging path to the tune of .02 ohms. A 20A replenishment flow would drop 0.4 volts. Again, a marked reduction in battery recharge current. When dealing with batteries having sensitivity to 100 millivolt differences and charging current in the tens of amps, you're working with a rather un-predictable set of circumstances, difficult to predict without more data and perhaps easier to test with empirical experimentation. Bob . . . ________________________________________________________________________________
Date: Jul 09, 2019
Steel Hangar??? At that kind of distance, you might consider building a couple of directional antennas out of Pringles cans. It works really well, believe it or not -- Art Z. On Tue, Jul 9, 2019 at 4:52 PM donjohnston <don@velocity-xl.com> wrote: > don@velocity-xl.com> > > I did something similar to this for a customer a few years back. They had > a garage about 150' away from the office and wanted network access in the > garage. Parking lot was paved so laying cable wasn't an option. > > We went with an outdoor wireless extender. Basically, two outdoor > antennas (there were directional) that we connected to a wireless AP in the > shop. > > Worked great. But costs about $500. Looks like prices have come down. -- https://CheerfulCurmudgeon.com/ *Pray as if everything depends on God. Act as if everything depends on you.* ________________________________________________________________________________
From: William Hunter <billhuntersemail(at)gmail.com>
Date: Jul 10, 2019
Steel Hangar??? My hangar is 40 feet away from the house period I first tried a pair of these NETGEAR PowerLINE 1000 Mbps WiFi, 802.11ac, 1 Gigabit Port - Essentials Edition (PLW1010-100NAS and that was unsuccessful probably because the house has a solar system and SunPower uses a similar adapter and I think they were interfering with each other. I did end up buying the Ccrane directional internet extender antenna and I now have internet in my hangar! Inside my house at a window pointing toward the Hanger is by Wi-Fi transmitter so I had to buy only one directional antenna . In your case I would recommend buying two directional antennas because of the distance. CC Vector Extended Long Range WiFi Repeater System 2.4 GHz- Extends WiFi Coverage to a Distant Location https://www.amazon.com/dp/B076KRTXQ6/ref=cm_sw_r_em_apa_i_WJxjDbEA8HY1V Research this webpage to get some ideas but make sure you always buy these contraptions in a pair from the same manufacturer https://www.google.com/amp/s/rootsaid.com/best-wifi-antennas/amp/ Thanks, Bill Hunter On Wed, Jul 10, 2019, 03:39 Art Zemon wrote: > At that kind of distance, you might consider building a couple of > directional antennas out of Pringles cans. It works really well, believe it > or not > > -- Art Z. > > On Tue, Jul 9, 2019 at 4:52 PM donjohnston <don@velocity-xl.com> wrote: > >> don@velocity-xl.com> >> >> I did something similar to this for a customer a few years back. They >> had a garage about 150' away from the office and wanted network access in >> the garage. Parking lot was paved so laying cable wasn't an option. >> >> We went with an outdoor wireless extender. Basically, two outdoor >> antennas (there were directional) that we connected to a wireless AP in the >> shop. >> >> Worked great. But costs about $500. Looks like prices have come down. > > > -- > https://CheerfulCurmudgeon.com/ > > *Pray as if everything depends on God. Act as if everything depends on > you.* > ________________________________________________________________________________
Date: Jul 10, 2019
Subject: Audio panel problem
Fellow builders.I need a bit of advice/help.I have a PS Engineering PDA360E X-R, which is the remote audio panel that is controlled through an EFIS.Thi s is a retrofit after removing an intercom.=C2- The intercom was mono and I am attempting to use the original shielded wires because of the difficul ty of running new wires.I called PS Engineering and asked if I could wire i t mono.=C2- They said yes by using only the left headphone connection.(No te: I have called them several times for information on their product, but they are very reluctant to provide support for their product.=C2- So, if you purchase any of their products, you can expect minimal support)I have p inned only the pilot headphone and mic jacks so far, so I cannot doa full t est of the intercom portion, but, so far, I do not have sidetone.=C2- I d id an audio test on the AOA, AF3400s, and GTN 650.=C2- In all cases, the audio has a hollow sound as if the speaker is in a barrel.=C2- Occasional ly, the audio is normal, but 95% of the time it has the hollow tone.Any ide as on how to solve the problem?Thanks,Stan SutterfieldRV-8A ________________________________________________________________________________
Subject: King Molex connectors
Date: Jul 11, 2019
As for an extractor for those pins: http://berkut13.com/extractor.htm From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Friday, July 5, 2019 10:07 PM Subject: Re: AeroElectric-List: King Molex connectors At 08:51 PM 7/5/2019, you wrote: Michael, You can purchase the pins here: http://lane-pilot.com/25-pcs-BendixKing-tray-contacts-KX155KMA24KX196KN53etc _p_123.html as well as everything else I mention here ... This ebay seller has a little more attractive offer https://tinyurl.com/y44o6gr8 Bob . . . ________________________________________________________________________________
Date: Jul 12, 2019
This link is too funny. Thank you=C2- Michael -----Original Message----- From: berkut13 <berkut13(at)berkut13.com> Sent: Thu, Jul 11, 2019 8:22 am Subject: RE: AeroElectric-List: King Molex connectors #yiv3212589577 #yiv3212589577 -- _filtered #yiv3212589577 {panose-1:2 4 5 3 5 4 6 3 2 4;} _filtered #yiv3212589577 {font-family:Calibri;panose-1:2 15 5 2 2 2 4 3 2 4;} _filtered #yiv3212589577 {font-family:Tahoma;panose-1:2 1 1 6 4 3 5 4 4 2 4;} #yiv3212589577 #yiv3212589577 p.yiv3212589577MsoNormal, #yiv3212589577 li.yiv3212589577MsoNormal, #yiv3212589577 div.yiv3212589577 MsoNormal {margin:0in;margin-bottom:.0001pt;font-size:12.0pt;font-family:Ne w;} #yiv3212589577 a:link, #yiv3212589577 span.yiv3212589577MsoHyperlink {c olor:blue;text-decoration:underline;} #yiv3212589577 a:visited, #yiv3212589 577 span.yiv3212589577MsoHyperlinkFollowed {color:purple;text-decoration:un derline;} #yiv3212589577 p {margin-right:0in;margin-left:0in;font-size:12.0 pt;font-family:New;} #yiv3212589577 span.yiv3212589577EmailStyle18 {color:# 1F497D;} #yiv3212589577 .yiv3212589577MsoChpDefault {font-size:10.0pt;} _fi ltered #yiv3212589577 {margin:1.0in 1.0in 1.0in 1.0in;} #yiv3212589577 div. yiv3212589577WordSection1 {} #yiv3212589577 As for an extractor for those p ins: =C2-http://berkut13.com/extractor.htm =C2- =C2- =C2-From: owne r-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-se rver(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Friday, July 5, 2019 10:07 PM Subject: Re: AeroElectric-List: King Molex connectors =C2-At 08:51 PM 7/5 /2019, you wrote: Michael, You can purchase the pins here: http://lane-pilot.com/25-pcs-BendixKing-tra y-contacts-KX155KMA24KX196KN53etc_p_123.html as well as everything else I m ention here ... =C2- This ebay seller has a little more =C2- attractive offer https://tinyurl.com/y44o6gr8 =C2- Bob . . . ________________________________________________________________________________
Subject: Garmin aera660 RS232 outputs
Date: Jul 12, 2019
Hi Guys/Bob The Garmin Aera660 GPS has two RS232 outputs, I have three instrument that require this signal, A/p,Transponder & Garmin G5 - can one of these devices share a RS232 signal - Regards: john Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490212#490212 ________________________________________________________________________________
Date: Jul 12, 2019
From: Henador Titzoff <henador_titzoff(at)yahoo.com>
Subject: Re: Garmin aera660 RS232 outputs
Try something known as an RX-232 Expander. It takes traffic from one RS-232 port and spreads it out to 2 or more RS-232 ports.=C2- If you have fast traffic, it will spoil your day if you try to divide that fast traffic port into 2 or more ports.=C2- Some ports want to see fast traffic with minim um latency (delay). Ask Garmin if they make one or better yet, consult with one of their technicians to see if the Expander is compatible with their t raffic flow.=C2- I know GRT makes an Expander and works well with their t raffic flow. I'm still trying to figure out why RS-232 is being used in experimental air plane applications.=C2- They should have gone with RS-422 a long time ago to avoid signal compatibility and integrity issues. Henador Titzoff eu> wrote: > Hi Guys/Bob The Garmin Aera660 GPS has two RS232 outputs, I have three instrument that require this signal, A/p,Transponder & Garmin G5 - can one of these devices share a RS232 signal - Regards: john Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490212#490212 - S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Jul 12, 2019
Subject: Alternator Dropping Off Line
The alternator on our O-200 intermittently died on a flight today. In total it quit 4 times, the longest for almost 4 minutes. After landing we wiggled all the wires, checked several for continuity, everything looks good. We have no cooling air going to the alternator at the back of the engine and it was a warm day and the engine compartment was very hot. Is it possible this is a heat problem or definitely wiring / regulator / alternator? Thank you, Sebastien ________________________________________________________________________________
Subject: Re: Alternator Dropping Off Line
Date: Jul 12, 2019
Not enough information is given. How many hours on the alternator? 13.8 volts is low. One possibility is worn brushes. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490233#490233 ________________________________________________________________________________
Date: Jul 12, 2019
That 13.8 is at the start of a failure cycle. Normal bus voltage has been 14.1 on the last several flights. The engine was recently overhauled, I'm trying to find out if the alternator was as well. It *looks* new. On Fri, Jul 12, 2019 at 6:35 PM user9253 wrote: > > Not enough information is given. > How many hours on the alternator? > 13.8 volts is low. > One possibility is worn brushes. > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=490233#490233 > > ________________________________________________________________________________
Date: Jul 13, 2019
Subject: [OT] IFR-certified GPS Suggestions
This is somewhat off-topic but I figure y'all know a lot about airplanes so you might have opinions about avionics, too. I reserved space in my panel for a Garmin 430 WAAS or a Garmin 650. Now that Oshkosh is upon us, perhaps I can save a few pennies on an IFR-certified GPS that will fit in that hole. It doesn=99t have to be a Garmin; that is just the size hole that I cut when I did the rest of the panel. What suggestions do you have, both for equipment and vendor? -- Art Z. -- https://CheerfulCurmudgeon.com/ *Love the stranger for you yourselves were strangers in Egypt. *Deut. 10:19 ________________________________________________________________________________
Date: Jul 13, 2019
At 12:12 AM 7/13/2019, you wrote: >That 13.8 is at the start of a failure cycle. Normal bus voltage has >been 14.1 on the last several flights. > >The engine was recently overhauled, I'm trying to find out if the >alternator was as well. It looks new. Okay, it sounds like this alternator has no known track record. Emacs! I put a 'ruler' on a piece of your data plot and it appears that alternator OPERATING is on the order of 13.7v, alternator OFF is 12.4v or battery only. you've got a LOT of on/off transients. Does this alternator have a built in regulator or external regulator? If INTERNAL regulator, the alternator is defective. If EXTERNAL reguator, you need to put a voltmeter on the Field terminal during a flight to see if the transient is upstream (in the regulator or associate wiring) or downstream (in the alternator). Bob . . . ________________________________________________________________________________
Date: Jul 13, 2019
Bob, what is a "transient" ? On Sat, Jul 13, 2019 at 7:39 AM Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 12:12 AM 7/13/2019, you wrote: > > That 13.8 is at the start of a failure cycle. Normal bus voltage has been > 14.1 on the last several flights. > > The engine was recently overhauled, I'm trying to find out if the > alternator was as well. It *looks* new. > > > Okay, it sounds like this alternator > has no known track record. > > [image: Emacs!] > > I put a 'ruler' on a piece of your > data plot and it appears that alternator > OPERATING is on the order of 13.7v, alternator > OFF is 12.4v or battery only. you've got a > LOT of on/off transients. > > Does this alternator have a built in > regulator or external regulator? > If INTERNAL regulator, the alternator > is defective. If EXTERNAL reguator, > you need to put a voltmeter on the > Field terminal during a flight to > see if the transient is upstream > (in the regulator or associate > wiring) or downstream (in the > alternator). > > > Bob . . . > ________________________________________________________________________________
Date: Jul 13, 2019
Operating is 14.1, not operating is about 12.7. Please see the link below which I should have sent to start with. I find it strange the way the voltage slowly drops rather than a sharp on/off drop. Maybe I'll try the switch to see what that looks like on the graph. I will place a voltmeter on the field line next flight. https://www.savvyanalysis.com/flight/3309601/fa4df24a-e512-4297-bf73-2a797c6ab36b On Sat, Jul 13, 2019, 09:05 Ken Ryan wrote: > Bob, what is a "transient" ? > > On Sat, Jul 13, 2019 at 7:39 AM Robert L. Nuckolls, III < > nuckolls.bob(at)aeroelectric.com> wrote: > >> At 12:12 AM 7/13/2019, you wrote: >> >> That 13.8 is at the start of a failure cycle. Normal bus voltage has been >> 14.1 on the last several flights. >> >> The engine was recently overhauled, I'm trying to find out if the >> alternator was as well. It *looks* new. >> >> >> >> Okay, it sounds like this alternator >> has no known track record. >> >> [image: Emacs!] >> >> I put a 'ruler' on a piece of your >> data plot and it appears that alternator >> OPERATING is on the order of 13.7v, alternator >> OFF is 12.4v or battery only. you've got a >> LOT of on/off transients. >> >> Does this alternator have a built in >> regulator or external regulator? >> If INTERNAL regulator, the alternator >> is defective. If EXTERNAL reguator, >> you need to put a voltmeter on the >> Field terminal during a flight to >> see if the transient is upstream >> (in the regulator or associate >> wiring) or downstream (in the >> alternator). >> >> >> >> Bob . . . >> > ________________________________________________________________________________
Date: Jul 13, 2019
Ford style external regulator wired as per AEC. On Sat, Jul 13, 2019, 09:14 Sebastien wrote: > Operating is 14.1, not operating is about 12.7. Please see the link below > which I should have sent to start with. I find it strange the way the > voltage slowly drops rather than a sharp on/off drop. Maybe I'll try the > switch to see what that looks like on the graph. > > I will place a voltmeter on the field line next flight. > > > https://www.savvyanalysis.com/flight/3309601/fa4df24a-e512-4297-bf73-2a797c6ab36b > > On Sat, Jul 13, 2019, 09:05 Ken Ryan wrote: > >> Bob, what is a "transient" ? >> >> On Sat, Jul 13, 2019 at 7:39 AM Robert L. Nuckolls, III < >> nuckolls.bob(at)aeroelectric.com> wrote: >> >>> At 12:12 AM 7/13/2019, you wrote: >>> >>> That 13.8 is at the start of a failure cycle. Normal bus voltage has >>> been 14.1 on the last several flights. >>> >>> The engine was recently overhauled, I'm trying to find out if the >>> alternator was as well. It *looks* new. >>> >>> >>> >>> Okay, it sounds like this alternator >>> has no known track record. >>> >>> [image: Emacs!] >>> >>> I put a 'ruler' on a piece of your >>> data plot and it appears that alternator >>> OPERATING is on the order of 13.7v, alternator >>> OFF is 12.4v or battery only. you've got a >>> LOT of on/off transients. >>> >>> Does this alternator have a built in >>> regulator or external regulator? >>> If INTERNAL regulator, the alternator >>> is defective. If EXTERNAL reguator, >>> you need to put a voltmeter on the >>> Field terminal during a flight to >>> see if the transient is upstream >>> (in the regulator or associate >>> wiring) or downstream (in the >>> alternator). >>> >>> >>> >>> Bob . . . >>> >> ________________________________________________________________________________
Date: Jul 13, 2019
adjective 1. 1. lasting only for a short time; impermanent. "a transient cold spell" * noun 1. 1. a person who is staying or working in a place for only a short time. 2. 2. _*a momentary variation in current, voltage, or frequency.*_ On 7/13/2019 10:58 AM, Ken Ryan wrote: > Bob, what is a "transient" ? > > On Sat, Jul 13, 2019 at 7:39 AM Robert L. Nuckolls, III > > > wrote: > > At 12:12 AM 7/13/2019, you wrote: >> That 13.8 is at the start of a failure cycle. Normal bus voltage >> has been 14.1 on the last several flights. >> >> The engine was recently overhauled, I'm trying to find out if the >> alternator was as well. It /looks/ new. > > > Okay, it sounds like this alternator > has no known track record. > > Emacs! > > I put a 'ruler' on a piece of your > data plot and it appears that alternator > OPERATING is on the order of 13.7v, alternator > OFF is 12.4v or battery only. you've got a > LOT of on/off transients. > > Does this alternator have a built in > regulator or external regulator? > If INTERNAL regulator, the alternator > is defective. If EXTERNAL reguator, > you need to put a voltmeter on the > Field terminal during a flight to > see if the transient is upstream > (in the regulator or associate > wiring) or downstream (in the > alternator). > > > Bob . . . > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jul 13, 2019
Wow, that is certainly an all-inclusive definition. On Sat, Jul 13, 2019 at 9:24 AM Charlie England wrote: > adjective > > 1. 1. > lasting only for a short time; impermanent. > "a transient cold spell" > - > > > noun > > 1. 1. > a person who is staying or working in a place for only a short time. > 2. 2. > *a momentary variation in current, voltage, or frequency.* > > > On 7/13/2019 10:58 AM, Ken Ryan wrote: > > Bob, what is a "transient" ? > > On Sat, Jul 13, 2019 at 7:39 AM Robert L. Nuckolls, III < > nuckolls.bob(at)aeroelectric.com> wrote: > >> At 12:12 AM 7/13/2019, you wrote: >> >> That 13.8 is at the start of a failure cycle. Normal bus voltage has been >> 14.1 on the last several flights. >> >> The engine was recently overhauled, I'm trying to find out if the >> alternator was as well. It *looks* new. >> >> >> >> Okay, it sounds like this alternator >> has no known track record. >> >> [image: Emacs!] >> >> I put a 'ruler' on a piece of your >> data plot and it appears that alternator >> OPERATING is on the order of 13.7v, alternator >> OFF is 12.4v or battery only. you've got a >> LOT of on/off transients. >> >> Does this alternator have a built in >> regulator or external regulator? >> If INTERNAL regulator, the alternator >> is defective. If EXTERNAL reguator, >> you need to put a voltmeter on the >> Field terminal during a flight to >> see if the transient is upstream >> (in the regulator or associate >> wiring) or downstream (in the >> alternator). >> >> >> >> Bob . . . >> > > > Virus-free. > www.avast.com > > <#m_-949200549652384023_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> > ________________________________________________________________________________
Date: Jul 13, 2019
Hi Ken, I highlighted & underlined what I thought was Bob's meaning when I read it; the 2nd noun definition. Perhaps the highlight/underline didn't show up in your email client. If a signal (or power level) is switching on/off rapidly, it's a 'transient' (short term event). On Sat, Jul 13, 2019 at 2:22 PM Ken Ryan wrote: > Wow, that is certainly an all-inclusive definition. > > On Sat, Jul 13, 2019 at 9:24 AM Charlie England > wrote: > >> adjective >> >> 1. 1. >> lasting only for a short time; impermanent. >> "a transient cold spell" >> - >> >> >> noun >> >> 1. 1. >> a person who is staying or working in a place for only a short time. >> 2. 2. >> *a momentary variation in current, voltage, or frequency.* >> >> >> >> >> On 7/13/2019 10:58 AM, Ken Ryan wrote: >> >> Bob, what is a "transient" ? >> >> On Sat, Jul 13, 2019 at 7:39 AM Robert L. Nuckolls, III < >> nuckolls.bob(at)aeroelectric.com> wrote: >> >>> At 12:12 AM 7/13/2019, you wrote: >>> >>> That 13.8 is at the start of a failure cycle. Normal bus voltage has >>> been 14.1 on the last several flights. >>> >>> The engine was recently overhauled, I'm trying to find out if the >>> alternator was as well. It *looks* new. >>> >>> >>> >>> Okay, it sounds like this alternator >>> has no known track record. >>> >>> [image: Emacs!] >>> >>> I put a 'ruler' on a piece of your >>> data plot and it appears that alternator >>> OPERATING is on the order of 13.7v, alternator >>> OFF is 12.4v or battery only. you've got a >>> LOT of on/off transients. >>> >>> Does this alternator have a built in >>> regulator or external regulator? >>> If INTERNAL regulator, the alternator >>> is defective. If EXTERNAL reguator, >>> you need to put a voltmeter on the >>> Field terminal during a flight to >>> see if the transient is upstream >>> (in the regulator or associate >>> wiring) or downstream (in the >>> alternator). >>> >>> >>> >>> Bob . . . >>> >> >> >> >> Virus-free. >> www.avast.com >> >> <#m_263918708704238526_m_-949200549652384023_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> >> > ________________________________________________________________________________
Date: Jul 13, 2019
Thanks Charlie. I think I understand now what Bob is saying. On Sat, Jul 13, 2019 at 12:02 PM Charlie England wrote: > Hi Ken, > > I highlighted & underlined what I thought was Bob's meaning when I read > it; the 2nd noun definition. Perhaps the highlight/underline didn't show up > in your email client. > > If a signal (or power level) is switching on/off rapidly, it's a > 'transient' (short term event). > > On Sat, Jul 13, 2019 at 2:22 PM Ken Ryan wrote: > >> Wow, that is certainly an all-inclusive definition. >> >> On Sat, Jul 13, 2019 at 9:24 AM Charlie England >> wrote: >> >>> adjective >>> >>> 1. 1. >>> lasting only for a short time; impermanent. >>> "a transient cold spell" >>> - 949200549652384023lr_dct_sf_subsen" >>> id="gmail-m_263918708704238526gmail-m_-949200549652384023_hAcqXbWIObmF9PwP8JOsMA21" >>> style="display:list-item;list-style-type:disc;font-size:xx-small;margin-left:25px;padding-top:5px"> >>> >>> >>> >>> noun > > 1. 1. > a person who is staying or working in a place for only a short time. > 2. 2. > *a momentary variation in current, voltage, or frequency.* > > > On 7/13/2019 10:58 AM, Ken Ryan wrote: > > Bob, what is a "transient" ? > > On Sat, Jul 13, 2019 at 7:39 AM Robert L. Nuckolls, III < > nuckolls.bob(at)aeroelectric.com> wrote: > >> At 12:12 AM 7/13/2019, you wrote: >> >> That 13.8 is at the start of a failure cycle. Normal bus voltage has been >> 14.1 on the last several flights. >> >> The engine was recently overhauled, I'm trying to find out if the >> alternator was as well. It *looks* new. >> >> >> >> Okay, it sounds like this alternator >> has no known track record. >> >> [image: Emacs!] >> >> I put a 'ruler' on a piece of your >> data plot and it appears that alternator >> OPERATING is on the order of 13.7v, alternator >> OFF is 12.4v or battery only. you've got a >> LOT of on/off transients. >> >> Does this alternator have a built in >> regulator or external regulator? >> If INTERNAL regulator, the alternator >> is defective. If EXTERNAL reguator, >> you need to put a voltmeter on the >> Field terminal during a flight to >> see if the transient is upstream >> (in the regulator or associate >> wiring) or downstream (in the >> alternator). >> >> >> >> Bob . . . >> > > > Virus-free. > www.avast.com > > <#m_1840038890319382137_m_263918708704238526_m_-949200549652384023_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> > ________________________________________________________________________________
Date: Jul 13, 2019
Subject: Re: [OT] IFR-certified GPS Suggestions
I=99m fond of the Avidyne IFD series > On Jul 13, 2019, at 08:05, Art Zemon wrote: > > This is somewhat off-topic but I figure y'all know a lot about airplanes s o you might have opinions about avionics, too. > > I reserved space in my panel for a Garmin 430 WAAS or a Garmin 650. Now th at Oshkosh is upon us, perhaps I can save a few pennies on an IFR-certified G PS that will fit in that hole. It doesn=99t have to be a Garmin; that i s just the size hole that I cut when I did the rest of the panel. > > What suggestions do you have, both for equipment and vendor? > > -- Art Z. > > -- > https://CheerfulCurmudgeon.com/ > > Love the stranger for you yourselves were strangers in Egypt. Deut. 10:19 ________________________________________________________________________________
Subject: Updated Z-12 available yet
Date: Jul 13, 2019
Hi, I=92ve read on the archives that Bob was working on an updated Z-12 archite cture, that included some of the features of the Z-13 architecture. Is ther e a final version available? Thanks, Michael- ________________________________________________________________________________
Date: Jul 13, 2019
From: "r.r.hall(at)cox.net r.r.hall(at)cox.net" <r.r.hall(at)cox.net>
I don't know if it is significant but it seemed to be offline for longer periods each time during the flight. Going by the download you linked to. > On July 13, 2019 at 3:16 PM Ken Ryan wrote: > > Wow, that is certainly an all-inclusive definition. > > On Sat, Jul 13, 2019 at 9:24 AM Charlie England < ceengland7(at)gmail.com mailto:ceengland7(at)gmail.com > wrote: > > > > > > adjective > > > > 1. 1. > > lasting only for a short time; impermanent. > > "a transient cold spell" > > o > > > > > > noun > > > > 1. 1. > > a person who is staying or working in a place for only a short time. > > 2. 2. > > a momentary variation in current, voltage, or frequency. > > > > > > > > On 7/13/2019 10:58 AM, Ken Ryan wrote: > > > > > > > Bob, what is a "transient" ? > > > > > > On Sat, Jul 13, 2019 at 7:39 AM Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com mailto:nuckolls.bob(at)aeroelectric.com > wrote: > > > > > > > > > > At 12:12 AM 7/13/2019, you wrote: > > > > > > > > > > > > > That 13.8 is at the start of a failure cycle. Normal bus voltage has been 14.1 on the last several flights. > > > > > > > > > > The engine was recently overhauled, I'm trying to find out if the alternator was as well. It looks new. > > > > > > > > > > > > > > > > > > Okay, it sounds like this alternator > > > > has no known track record. > > > > > > > > [Emacs!] > > > > > > > > I put a 'ruler' on a piece of your > > > > data plot and it appears that alternator > > > > OPERATING is on the order of 13.7v, alternator > > > > OFF is 12.4v or battery only. you've got a > > > > LOT of on/off transients. > > > > > > > > Does this alternator have a built in > > > > regulator or external regulator? > > > > If INTERNAL regulator, the alternator > > > > is defective. If EXTERNAL reguator, > > > > you need to put a voltmeter on the > > > > Field terminal during a flight to > > > > see if the transient is upstream > > > > (in the regulator or associate > > > > wiring) or downstream (in the > > > > alternator). > > > > > > > > > > > > > > > > > > > > Bob . . . > > > > > > > > > > > > > > > > > > https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient&utm_term=icon > > Virus-free. www.avast.com https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient&utm_term=link > > > > > ________________________________________________________________________________
Date: Jul 13, 2019
Yes I found that strange. Each cycle was longer both in duration and in time before the next one. Probably random though. On Sat, Jul 13, 2019, 19:44 r.r.hall(at)cox.net r.r.hall(at)cox.net < r.r.hall(at)cox.net> wrote: > I don't know if it is significant but it seemed to be offline for longer > periods each time during the flight. Going by the download you linked to. > > > On July 13, 2019 at 3:16 PM Ken Ryan wrote: > > Wow, that is certainly an all-inclusive definition. > > On Sat, Jul 13, 2019 at 9:24 AM Charlie England < ceengland7(at)gmail.com> > wrote: > > adjective > > > 1. 1. > lasting only for a short time; impermanent. > "a transient cold spell" > - > > > noun > > > 1. 1. > a person who is staying or working in a place for only a short time. > 2. 2. > *a momentary variation in current, voltage, or frequency.* > > > On 7/13/2019 10:58 AM, Ken Ryan wrote: > > Bob, what is a "transient" ? > > On Sat, Jul 13, 2019 at 7:39 AM Robert L. Nuckolls, III < > nuckolls.bob(at)aeroelectric.com> wrote: > > At 12:12 AM 7/13/2019, you wrote: > > That 13.8 is at the start of a failure cycle. Normal bus voltage has been > 14.1 on the last several flights. > > The engine was recently overhauled, I'm trying to find out if the > alternator was as well. It *looks* new. > > > Okay, it sounds like this alternator > has no known track record. > > [image: Emacs!] > > I put a 'ruler' on a piece of your > data plot and it appears that alternator > OPERATING is on the order of 13.7v, alternator > OFF is 12.4v or battery only. you've got a > LOT of on/off transients. > > Does this alternator have a built in > regulator or external regulator? > If INTERNAL regulator, the alternator > is defective. If EXTERNAL reguator, > you need to put a voltmeter on the > Field terminal during a flight to > see if the transient is upstream > (in the regulator or associate > wiring) or downstream (in the > alternator). > > > Bob . . . > > > Virus-free. > www.avast.com > > > ________________________________________________________________________________
Date: Jul 14, 2019
Subject: GPS Navigator
Art Z, Check out Garmin's new GPS 175. It is a stand alone IFR GPS navigator. About a 1/2 shorter than the 650. Also available as the GPS 375 which includes an ADSB out/in transponder in the same box. ________________________________________________________________________________
Subject: BNC connectors - Types of cable and installation tools
Date: Jul 14, 2019
Could somebody kindly answer the following questions: - Are BNC connectors for RG-58U wire and RG400U wire the same? - Can the same crimpers be used for attaching BNC connectors to both RG-58U wire and RG400U wire? If so, why you can only read 58 on some dye sets and not 58/400 or something like that? - What about TNC connectors? Do the same principles as for BNC connectors apply when it comes to RG58/RG400 cables and installation tools? Thanks Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490290#490290 ________________________________________________________________________________
Subject: =?ISO-8859-1?Q?=D8=B4=D8=B1=D9=83=D8=A9?= =?ISO-8859-1?Q?=D8=A7=D9=84=D8=A8=D9=8A=D8?=
=?ISO-8859-1?Q?=D8=A7=D9=84=D8=B1=D8=A7=D9=82=D9=8A?= =?ISO-8859-1?Q?=D9=84=D9=84=D8=AE=D8=AF=D9=85=D8=A7=D8?= =?ISO-8859-1?Q?=D8=A7=D9=84=D9=85=D9=86=D8=B2=D9=84?
Date: Jul 14, 2019
: .. 2/1 . . / . .. . .. . . : 30 60 () : .. . ( ) 5 . . . .. . / .. . https://beautiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%AA%D9%86%D8%B8%D9%8A%D9%81-%D9%85%D9%86%D8%A7%D8%B2%D9%84-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6/ https://beautiful-house1.com/%D8%AE%D8%AF%D9%85%D8%A7%D8%AA-%D8%A3%D8%AE%D8%B1%D9%89/%D8%B4%D8%B1%D9%83%D8%A9-%D8%AA%D9%86%D8%B8%D9%8A%D9%81-%D9%85%D8%AC%D8%A7%D9%84%D8%B3-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6/ https://beautiful-house1.com/%D8%AE%D8%AF%D9%85%D8%A7%D8%AA-%D8%A3%D8%AE%D8%B1%D9%89/%D8%B4%D8%B1%D9%83%D8%A9-%D8%AA%D9%86%D8%B8%D9%8A%D9%81-%D9%85%D9%88%D9%83%D9%8A%D8%AA-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6/ https://beautiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%AA%D9%86%D8%B8%D9%8A%D9%81-%D9%83%D9%86%D8%A8-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6/ https://beautiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%AA%D9%86%D8%B8%D9%8A%D9%81-%D8%A8%D9%8A%D8%A7%D8%B1%D8%A7%D8%AA-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6/ https://beautiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%AC%D9%84%D9%8A-%D8%A8%D9%84%D8%A7%D8%B7-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6/ https://beautiful-house1.com/%D8%AE%D8%AF%D9%85%D8%A7%D8%AA-%D8%A3%D8%AE%D8%B1%D9%89/%D8%B4%D8%B1%D9%83%D8%A9-%D8%AA%D8%B3%D9%84%D9%8A%D9%83-%D9%85%D8%AC%D8%A7%D8%B1%D9%8A-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6/ https://beautiful-house1.com/%D8%B9%D8%B2%D9%84-%D8%AE%D8%B2%D8%A7%D9%86%D8%A7%D8%AA/ https://beautiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D9%83%D8%B4%D9%81-%D8%AA%D8%B3%D8%B1%D8%A8%D8%A7%D8%AA-%D8%A7%D9%84%D9%85%D9%8A%D8%A7%D9%87-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6/ https://beautiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D9%85%D9%83%D8%A7%D9%81%D8%AD%D8%A9-%D8%AD%D8%B4%D8%B1%D8%A7%D8%AA-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6/ https://beautiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D9%85%D9%83%D8%A7%D9%81%D8%AD%D8%A9-%D8%A7%D9%84%D9%81%D8%A6%D8%B1%D8%A7%D9%86-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6/ https://beautiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%AA%D8%AE%D8%B2%D9%8A%D9%86-%D8%A7%D8%AB%D8%A7%D8%AB-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6/ https://beautiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%AA%D8%AE%D8%B2%D9%8A%D9%86-%D8%A7%D8%AB%D8%A7%D8%AB-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6/ https://beautiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D9%86%D9%82%D9%84-%D8%A7%D8%AB%D8%A7%D8%AB-%D9%85%D9%86-%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6-%D8%A7%D9%84%D9%89-%D8%A7%D9%84%D9%82%D8%B5%D9%8A%D9%85/ https://beautiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D9%86%D9%82%D9%84-%D8%A7%D8%AB%D8%A7%D8%AB-%D9%85%D9%86-%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6-%D8%A7%D9%84%D9%89-%D8%AC%D8%AF%D8%A9/ https://beautiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D9%85%D9%83%D8%A7%D9%81%D8%AD%D8%A9-%D8%A7%D9%84%D8%B5%D8%B1%D8%A7%D8%B5%D9%8A%D8%B1-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6/ https://beautiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%B1%D8%B4-%D9%85%D8%A8%D9%8A%D8%AF%D8%A7%D8%AA-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6/ https://beautiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%AA%D9%86%D8%B8%D9%8A%D9%81-%D9%81%D9%84%D9%84-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6/ https://beautiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%AA%D9%86%D8%B8%D9%8A%D9%81-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6/ https://beautiful-house1.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490291#490291 ________________________________________________________________________________
Subject: =?ISO-8859-1?Q?=D8=B4=D8=B1=D9=83=D8=A9?= =?ISO-8859-1?Q?=D8=A7=D9=84=D8=B5=D9=81=D8=B1=D8=A7=D8?=
=?ISO-8859-1?Q?=D9=84=D8=AE=D8=AF=D9=85=D8=A7=D8?= =?ISO-8859-1?Q?=D8=A7=D9=84=D8=D9=86=D8=B8=D9=8A=D9=81?= =?ISO-8859-1?Q?=D8=A8=D8=A7=D9=84=D8=B1?
Date: Jul 14, 2019
0532139113 , , : ( - - - - ) ,, 24 ,, : 0530242929 : 0551128002 https://beutiful-house1.com/ https://beutiful-house1.com/%D8%AA%D8%B3%D9%84%D9%8A%D9%83-%D8%A7%D9%84%D9%85%D8%AC%D8%A7%D8%B1%D9%8A/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%A7%D9%84%D8%B5%D9%81%D8%B1%D8%A7%D8%AA-%D9%84%D8%AA%D8%B3%D9%84%D9%8A%D9%83-%D8%A7%D9%84%D9%85%D8%AC%D8%A7%D8%B1%D9%89-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%A7%D9%84%D8%B5%D9%81%D8%B1%D8%A7%D8%AA-%D9%84%D9%83%D8%B4%D9%81-%D8%AA%D8%B3%D8%B1%D8%A8%D8%A7%D8%AA-%D8%A7%D9%84%D9%85%D9%8A%D8%A7%D9%87-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%A7%D9%84%D8%B5%D9%81%D8%B1%D8%A7%D8%AA-%D9%84%D8%AA%D9%86%D8%B8%D9%8A%D9%81-%D8%A7%D9%84%D8%AE%D8%B2%D8%A7%D9%86%D8%A7%D8%AA-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%A7%D9%84%D8%B5%D9%81%D8%B1%D8%A7%D8%AA-%D9%84%D8%AA%D9%86%D8%B8%D9%8A%D9%81-%D8%A7%D9%84%D9%85%D9%86%D8%A7%D8%B2%D9%84-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%AC%D9%84%D9%8A-%D8%A8%D9%84%D8%A7%D8%B7-%D8%B1%D8%AE%D8%A7%D9%85-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%A7%D9%84%D8%B5%D9%81%D8%B1%D8%A7%D8%AA-%D9%84%D8%AA%D9%86%D8%B8%D9%8A%D9%81-%D8%A7%D9%84%D9%85%D8%AC%D8%A7%D9%84%D8%B3-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%A7%D9%84%D8%B5%D9%81%D8%B1%D8%A7%D8%AA-%D9%84%D8%AA%D9%86%D8%B8%D9%8A%D9%81-%D8%A7%D9%84%D9%81%D9%84%D9%84-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%A7%D9%84%D8%B5%D9%81%D8%B1%D8%A7%D8%AA-%D9%84%D8%AA%D9%86%D8%B8%D9%8A%D9%81-%D8%A7%D9%84%D9%85%D9%88%D9%83%D9%8A%D8%AA-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%A7%D9%84%D8%B5%D9%81%D8%B1%D8%A7%D8%AA-%D9%84%D8%AA%D9%86%D8%B8%D9%8A%D9%81-%D8%A7%D9%84%D8%B4%D9%82%D9%82-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%A7%D9%84%D8%B5%D9%81%D8%B1%D8%A7%D8%AA-%D9%84%D8%AA%D9%86%D8%B8%D9%8A%D9%81-%D8%A7%D9%84%D9%83%D9%86%D8%A8-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6/ https://beutiful-house1.com/%D8%AE%D8%AF%D9%85%D8%A7%D8%AA-%D8%A7%D9%84%D8%AF%D9%85%D8%A7%D9%85/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%AA%D9%86%D8%B8%D9%8A%D9%81-%D9%81%D9%84%D9%84-%D8%A8%D8%A7%D9%84%D8%AF%D9%85%D8%A7%D9%85/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%AA%D9%86%D8%B8%D9%8A%D9%81-%D8%B4%D9%82%D9%82-%D8%A8%D8%A7%D9%84%D8%AF%D9%85%D8%A7%D9%85/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%B1%D8%B4-%D9%85%D8%A8%D9%8A%D8%AF%D8%A7%D8%AA-%D8%A8%D8%A7%D9%84%D8%AF%D9%85%D8%A7%D9%85/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%AA%D9%86%D8%B8%D9%8A%D9%81-%D8%A8%D9%8A%D9%88%D8%AA-%D8%A8%D8%A7%D9%84%D8%AF%D9%85%D8%A7%D9%85/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%AA%D8%AE%D8%B2%D9%8A%D9%86-%D8%A7%D8%AB%D8%A7%D8%AB-%D8%A8%D8%A7%D9%84%D8%AF%D9%85%D8%A7%D9%85/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%AA%D9%86%D8%B8%D9%8A%D9%81-%D9%85%D8%AC%D8%A7%D9%84%D8%B3-%D8%A8%D8%A7%D9%84%D8%AF%D9%85%D8%A7%D9%85/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%AA%D9%86%D8%B8%D9%8A%D9%81-%D9%85%D9%88%D9%83%D9%8A%D8%AA-%D8%A8%D8%A7%D9%84%D8%AF%D9%85%D8%A7%D9%85/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D9%86%D9%82%D9%84-%D8%B9%D9%81%D8%B4-%D8%A8%D8%A7%D9%84%D8%AF%D9%85%D8%A7%D9%85/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%AA%D9%86%D8%B8%D9%8A%D9%81-%D8%AE%D8%B2%D8%A7%D9%86%D8%A7%D8%AA-%D8%A8%D8%A7%D9%84%D8%AF%D9%85%D8%A7%D9%85/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D9%85%D9%83%D8%A7%D9%81%D8%AD%D8%A9-%D8%A7%D9%84%D9%86%D9%85%D9%84-%D8%A7%D9%84%D8%A7%D8%A8%D9%8A%D8%B6-%D8%A8%D8%A7%D9%84%D8%AF%D9%85%D8%A7%D9%85/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%AC%D9%84%D9%8A-%D8%A8%D9%84%D8%A7%D8%B7-%D8%B1%D8%AE%D8%A7%D9%85-%D8%A8%D8%A7%D9%84%D8%AF%D9%85%D8%A7%D9%85/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%AA%D9%86%D8%B8%D9%8A%D9%81-%D9%88%D8%A7%D8%AC%D9%87%D8%A7%D8%AA-%D8%AD%D8%AC%D8%B1-%D9%88%D8%B2%D8%AC%D8%A7%D8%AC-%D8%A8%D8%A7%D9%84%D8%AF%D9%85%D8%A7%D9%85/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%AA%D9%86%D8%B8%D9%8A%D9%81-%D9%88%D8%B4%D9%81%D8%B7-%D8%A8%D9%8A%D8%A7%D8%B1%D8%A7%D8%AA-%D8%A8%D8%A7%D9%84%D8%AF%D9%85%D8%A7%D9%85/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%AA%D9%86%D8%B8%D9%8A%D9%81-%D9%83%D9%86%D8%A8-%D8%A8%D8%A7%D9%84%D8%AF%D9%85%D8%A7%D9%85/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%AA%D9%86%D8%B8%D9%8A%D9%81-%D9%85%D9%86%D8%A7%D8%B2%D9%84-%D8%A8%D8%A7%D9%84%D8%AF%D9%85%D8%A7%D9%85/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%AA%D9%86%D8%B8%D9%8A%D9%81-%D8%B3%D8%AC%D8%A7%D8%AF-%D8%A8%D8%A7%D9%84%D8%AF%D9%85%D8%A7%D9%85/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%B4%D8%B1%D8%A7%D8%A1-%D8%A7%D8%AB%D8%A7%D8%AB-%D9%85%D8%B3%D8%AA%D8%B9%D9%85%D9%84-%D8%A8%D8%A7%D9%84%D8%AF%D9%85%D8%A7%D9%85/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%B9%D8%B2%D9%84-%D8%A7%D8%B3%D8%B7%D8%AD-%D8%A8%D8%A7%D9%84%D8%AF%D9%85%D8%A7%D9%85/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%B9%D8%B2%D9%84-%D8%AE%D8%B2%D8%A7%D9%86%D8%A7%D8%AA-%D8%A8%D8%A7%D9%84%D8%AF%D9%85%D8%A7%D9%85/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D9%83%D8%B4%D9%81-%D8%AA%D8%B3%D8%B1%D8%A8%D8%A7%D8%AA-%D8%A7%D9%84%D9%85%D9%8A%D8%A7%D9%87-%D8%A8%D8%A7%D9%84%D8%AF%D9%85%D8%A7%D9%85/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D9%86%D9%82%D9%84-%D8%A7%D8%AB%D8%A7%D8%AB-%D8%A8%D8%A7%D9%84%D8%AF%D9%85%D8%A7%D9%85/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%AA%D9%86%D8%B8%D9%8A%D9%81-%D8%A8%D8%A7%D9%84%D8%AF%D9%85%D8%A7%D9%85/ https://beutiful-house1.com/%D8%AE%D8%AF%D9%85%D8%A7%D8%AA-%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%A7%D9%84%D8%B5%D9%81%D8%B1%D8%A7%D8%AA-%D9%84%D8%B9%D8%B2%D9%84-%D8%A7%D9%84%D8%A7%D8%B3%D8%B7%D8%AD-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%A7%D9%84%D8%B5%D9%81%D8%B1%D8%A7%D8%AA-%D9%84%D8%AA%D9%86%D8%B8%D9%8A%D9%81-%D8%A7%D9%84%D8%A8%D9%8A%D8%A7%D8%B1%D8%A7%D8%AA-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D9%85%D9%83%D8%A7%D9%81%D8%AD%D8%A9-%D8%A7%D9%84%D9%81%D8%A6%D8%B1%D8%A7%D9%86-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%A7%D9%84%D8%B5%D9%81%D8%B1%D8%A7%D8%AA-%D9%84%D9%86%D9%82%D9%84-%D8%A7%D9%84%D8%A7%D8%AB%D8%A7%D8%AB-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%AA%D9%86%D8%B8%D9%8A%D9%81-%D8%A8%D8%AE%D9%85%D9%8A%D8%B3-%D9%85%D8%B4%D9%8A%D8%B7/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%AA%D8%AE%D8%B2%D9%8A%D9%86-%D8%A7%D8%AB%D8%A7%D8%AB-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%AA%D9%86%D8%B8%D9%8A%D9%81-%D9%88%D8%A7%D8%AC%D9%87%D8%A7%D8%AA-%D8%AD%D8%AC%D8%B1-%D9%88%D8%B2%D8%AC%D8%A7%D8%AC-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%AA%D9%86%D8%B8%D9%8A%D9%81-%D9%85%D8%B3%D8%A7%D8%A8%D8%AD-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D9%86%D8%B8%D8%A7%D9%81%D8%A9-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%AA%D9%86%D8%B8%D9%8A%D9%81-%D9%82%D8%B5%D9%88%D8%B1-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%B4%D8%B1%D8%A7%D8%A1-%D8%A7%D8%AB%D8%A7%D8%AB-%D9%85%D8%B3%D8%AA%D8%B9%D9%85%D9%84-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%AA%D9%86%D8%B8%D9%8A%D9%81-%D8%A8%D9%8A%D9%88%D8%AA-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%BA%D8%B3%D9%8A%D9%84-%D9%85%D9%88%D9%83%D9%8A%D8%AA-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6/ https://beutiful-house1.com/%D8%A7%D8%B1%D8%AE%D8%B5-%D8%B4%D8%B1%D9%83%D8%A9-%D8%AA%D9%86%D8%B8%D9%8A%D9%81-%D8%B4%D9%82%D9%82-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%AA%D9%86%D8%B8%D9%8A%D9%81-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6-%D8%B1%D8%AE%D9%8A%D8%B5%D9%87/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%AA%D9%86%D8%B8%D9%8A%D9%81-%D8%B4%D9%82%D9%82-%D8%A8%D8%AC%D8%AF%D9%87/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%B9%D8%B2%D9%84-%D8%AE%D8%B2%D8%A7%D9%86%D8%A7%D8%AA-%D8%A8%D8%AC%D8%AF%D9%87/ https://beutiful-house1.com/%D8%AE%D8%AF%D9%85%D8%A7%D8%AA-%D8%AC%D8%AF%D9%87/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%B9%D8%B2%D9%84-%D8%AE%D8%B2%D8%A7%D9%86%D8%A7%D8%AA-%D8%A8%D8%AC%D8%AF%D9%87/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%AA%D9%86%D8%B8%D9%8A%D9%81-%D9%81%D9%84%D9%84-%D8%A8%D8%AC%D8%AF%D9%87/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%AA%D9%86%D8%B8%D9%8A%D9%81-%D9%85%D8%AC%D8%A7%D9%84%D8%B3-%D8%A8%D8%AC%D8%AF%D9%87/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%B9%D8%B2%D9%84-%D8%AE%D8%B2%D8%A7%D9%86%D8%A7%D8%AA-%D8%A8%D8%AC%D8%AF%D9%87/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%AA%D9%86%D8%B8%D9%8A%D9%81-%D8%B4%D9%82%D9%82-%D8%A8%D8%AC%D8%AF%D9%87/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%AA%D9%86%D8%B8%D9%8A%D9%81-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%AA%D8%B3%D9%84%D9%8A%D9%83-%D9%85%D8%AC%D8%A7%D8%B1%D9%89-%D8%A8%D8%A7%D9%84%D8%AF%D9%85%D8%A7%D9%85/ https://beutiful-house1.com/%D8%A7%D8%B1%D8%AE%D8%B5-%D8%B4%D8%B1%D9%83%D8%A9-%D9%86%D9%82%D9%84-%D8%A7%D8%AB%D8%A7%D8%AB-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%AA%D9%86%D8%B8%D9%8A%D9%81-%D9%85%D8%B3%D8%A7%D8%A8%D8%AD-%D8%A8%D8%A7%D9%84%D8%AF%D9%85%D8%A7%D9%85/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D9%86%D8%B8%D8%A7%D9%81%D8%A9-%D8%A8%D8%A7%D9%84%D8%AF%D9%85%D8%A7%D9%85/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D9%85%D9%83%D8%A7%D9%81%D8%AD%D8%A9-%D8%AD%D8%B4%D8%B1%D8%A7%D8%AA-%D8%A8%D8%A7%D9%84%D8%AF%D9%85%D8%A7%D9%85/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%AA%D9%86%D8%B8%D9%8A%D9%81-%D8%B3%D8%AC%D8%A7%D8%AF-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%AA%D9%86%D8%B8%D9%8A%D9%81-%D8%AE%D8%B2%D8%A7%D9%86%D8%A7%D8%AA-%D8%A8%D8%AC%D8%AF%D9%87/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%AA%D9%86%D8%B8%D9%8A%D9%81-%D8%A8%D8%A7%D9%84%D8%AE%D8%B1%D8%AC/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%AA%D9%86%D8%B8%D9%8A%D9%81-%D9%85%D8%B3%D8%A7%D8%AC%D8%AF-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6/ https://beutiful-house1.com/%D8%A7%D8%B1%D8%AE%D8%B5-%D8%B4%D8%B1%D9%83%D8%A9-%D9%85%D9%83%D8%A7%D9%81%D8%AD%D8%A9-%D8%A7%D9%84%D8%AD%D8%B4%D8%B1%D8%A7%D8%AA-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%A7%D9%84%D8%B5%D9%81%D8%B1%D8%A7%D8%AA-%D9%84%D8%B9%D8%B2%D9%84-%D8%A7%D9%84%D8%AE%D8%B2%D8%A7%D9%86%D8%A7%D8%AA-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%A7%D9%84%D8%B5%D9%81%D8%B1%D8%A7%D8%AA-%D9%84%D8%B1%D8%B4-%D8%A7%D9%84%D9%85%D8%A8%D9%8A%D8%AF%D8%A7%D8%AA-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6/ https://beutiful-house1.com/%D9%85%D9%83%D8%A7%D9%81%D8%AD%D8%A9-%D8%A7%D9%84%D8%AD%D8%B4%D8%B1%D8%A7%D8%AA/ https://beutiful-house1.com/%D8%A7%D8%B1%D8%AE%D8%B5-%D8%B4%D8%B1%D9%83%D8%A9-%D8%B1%D8%B4-%D9%85%D8%A8%D9%8A%D8%AF%D8%A7%D8%AA-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%A7%D9%84%D8%B5%D9%81%D8%B1%D8%A7%D8%AA-%D9%84%D9%85%D9%83%D8%A7%D9%81%D8%AD%D8%A9-%D8%A7%D9%84%D9%86%D9%85%D9%84-%D8%A7%D9%84%D8%A7%D8%A8%D9%8A%D8%B6-%D8%A8%D8%A7%D9%84/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D9%85%D9%83%D8%A7%D9%81%D8%AD%D8%A9-%D8%A7%D9%84%D8%A8%D9%82-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D9%85%D9%83%D8%A7%D9%81%D8%AD%D8%A9-%D8%A7%D9%84%D8%B5%D8%B1%D8%B5%D9%8A%D8%B1-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%A7%D9%84%D8%B5%D9%81%D8%B1%D8%A7%D8%AA-%D9%84%D9%85%D9%83%D8%A7%D9%81%D8%AD%D8%A9-%D8%A7%D9%84%D8%AD%D8%B4%D8%B1%D8%A7%D8%AA-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%A7%D9%84%D8%B5%D9%81%D8%B1%D8%A7%D8%AA-%D9%84%D9%84%D8%AA%D9%86%D8%B8%D9%8A%D9%81-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D8%AA%D9%86%D8%B8%D9%8A%D9%81-%D8%AE%D8%B2%D8%A7%D9%86%D8%A7%D8%AA-%D8%A8%D8%AC%D9%85%D9%8A%D8%B3-%D9%85%D8%B4%D9%8A%D8%B7/ https://beutiful-house1.com/%D8%B4%D8%B1%D9%83%D8%A9-%D9%86%D9%82%D9%84-%D8%B9%D9%81%D8%B4-%D8%A8%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6/ [/code] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490292#490292 ________________________________________________________________________________
Subject: =?ISO-8859-1?Q?=D8=B4=D8=B1=D9=83=D8=A9?= =?ISO-8859-1?Q?=D8=A7=D9=84=D8=B4=D8=B9=D9=84=D8=A9?=
=?ISO-8859-1?Q?=D9=84=D9=84=D8=AE=D8=AF=D9=85=D8=A7=D8?= =?ISO-8859-1?Q?=D8=A7=D9=84=D9=85=D9=86=D8=B2=D9=84=D9=8A=D8=A9?= 053024
Date: Jul 14, 2019
0530242929 , , 0530242929 https://jant-mamlka.com/%d8%b4%d8%b1%d9%83%d8%a9-%d8%aa%d9%86%d8%b8%d9%8a%d9%81-%d8%a8%d8%a7%d9%84%d8%b1%d9%8a%d8%a7%d8%b6-2/ https://jant-mamlka.com/%d8%a7%d8%b1%d8%ae%d8%b5-%d8%b4%d8%b1%d9%83%d8%a9-%d8%aa%d9%86%d8%b8%d9%8a%d9%81-%d9%85%d9%86%d8%a7%d8%b2%d9%84-%d8%a8%d8%a7%d9%84%d8%af%d9%85%d8%a7%d9%85/ https://jant-mamlka.com/%d8%a7%d8%b1%d8%ae%d8%b5-%d8%b4%d8%b1%d9%83%d8%a9-%d8%aa%d9%86%d8%b8%d9%8a%d9%81-%d9%85%d9%86%d8%a7%d8%b2%d9%84-%d8%a8%d8%a7%d9%84%d8%b1%d9%8a%d8%a7%d8%b6/ https://jant-mamlka.com/%d8%b4%d8%b1%d9%83%d8%a9-%d8%aa%d9%86%d8%b8%d9%8a%d9%81-%d8%b4%d9%82%d9%82-%d8%a8%d8%a7%d9%84%d8%b1%d9%8a%d8%a7%d8%b6/ https://jant-mamlka.com/%d8%b4%d8%b1%d9%83%d8%a9-%d8%aa%d9%86%d8%b8%d9%8a%d9%81-%d9%81%d9%84%d9%84-%d8%a8%d8%a7%d9%84%d8%b1%d9%8a%d8%a7%d8%b6/ https://jant-mamlka.com/%d8%b4%d8%b1%d9%83%d8%a9-%d8%aa%d9%86%d8%b8%d9%8a%d9%81-%d9%85%d8%ac%d8%a7%d9%84%d8%b3-%d8%a8%d8%a7%d9%84%d8%b1%d9%8a%d8%a7%d8%b6/ https://jant-mamlka.com/%d8%b4%d8%b1%d9%83%d8%a9-%d8%aa%d9%86%d8%b8%d9%8a%d9%81-%d9%85%d9%88%d9%83%d9%8a%d8%aa-%d8%a8%d8%a7%d9%84%d8%b1%d9%8a%d8%a7%d8%b6/ : ! ,, 24 ,, https://jant-mamlka.com/%d8%b4%d8%b1%d9%83%d8%a9-%d8%aa%d9%86%d8%b8%d9%8a%d9%81-%d9%83%d9%86%d8%a8-%d8%a8%d8%a7%d9%84%d8%b1%d9%8a%d8%a7%d8%b6/ https://jant-mamlka.com/%d8%b4%d8%b1%d9%83%d8%a9-%d8%aa%d9%86%d8%b8%d9%8a%d9%81-%d9%85%d9%83%d9%8a%d9%81%d8%a7%d8%aa-%d8%a8%d8%a7%d9%84%d8%b1%d9%8a%d8%a7%d8%b6/ https://jant-mamlka.com/%d8%aa%d9%86%d8%b8%d9%8a%d9%81-%d8%a8%d8%ae%d9%85%d9%8a%d8%b3-%d9%85%d8%b4%d9%8a%d8%b7-%d9%88%d8%a7%d8%a8%d9%87%d8%a7/ https://jant-mamlka.com/%d8%b4%d8%b1%d9%83%d8%a9-%d8%aa%d9%86%d8%b8%d9%8a%d9%81-%d9%85%d8%b3%d8%a7%d8%ac%d8%af-%d8%a8%d8%a7%d9%84%d8%b1%d9%8a%d8%a7%d8%b6/ https://jant-mamlka.com/%d8%ac%d9%84%d9%89-%d8%a8%d9%84%d8%a7%d8%b7-%d8%a8%d8%a7%d9%84%d8%b1%d9%8a%d8%a7%d8%b6/ https://jant-mamlka.com/%d8%b4%d8%b1%d9%83%d8%a9-%d8%aa%d9%86%d8%b8%d9%8a%d9%81-%d8%ae%d8%b2%d8%a7%d9%86%d8%a7%d8%aa-%d8%a8%d8%a7%d9%84%d8%b1%d9%8a%d8%a7%d8%b6/ https://jant-mamlka.com/%d8%b4%d8%b1%d9%83%d8%a9-%d8%b9%d8%b2%d9%84-%d8%ae%d8%b2%d8%a7%d9%86%d8%a7%d8%aa-%d8%a8%d8%a7%d9%84%d8%b1%d9%8a%d8%a7%d8%b6/ https://jant-mamlka.com/%d8%b4%d8%b1%d9%83%d8%a9-%d8%b9%d8%b2%d9%84-%d8%a7%d8%b3%d8%b7%d8%ad-%d8%a8%d8%a7%d9%84%d8%b1%d9%8a%d8%a7%d8%b6/ https://jant-mamlka.com/%d8%b4%d8%b1%d9%83%d8%a9-%d9%83%d8%b4%d9%81-%d8%aa%d8%b3%d8%b1%d8%a8%d8%a7%d8%aa-%d8%a7%d9%84%d9%85%d9%8a%d8%a7%d9%87-%d8%a8%d8%a7%d9%84%d8%b1%d9%8a%d8%a7%d8%b6/ https://jant-mamlka.com/%d8%b4%d8%b1%d9%83%d8%a9-%d8%aa%d9%86%d8%b8%d9%8a%d9%81-%d8%a8%d9%8a%d8%a7%d8%b1%d8%a7%d8%aa-%d8%a8%d8%a7%d9%84%d8%b1%d9%8a%d8%a7%d8%b6/ https://jant-mamlka.com/%d8%b4%d8%b1%d9%83%d8%a9-%d8%aa%d8%b3%d9%84%d9%8a%d9%83-%d9%85%d8%ac%d8%a7%d8%b1%d9%89-%d8%a8%d8%a7%d9%84%d8%b1%d9%8a%d8%a7%d8%b6/ https://jant-mamlka.com/%d8%b4%d8%b1%d9%83%d8%a9-%d8%aa%d9%86%d8%b8%d9%8a%d9%81-%d9%85%d8%b3%d8%a7%d8%a8%d8%ad-%d8%a8%d8%a7%d9%84%d8%b1%d9%8a%d8%a7%d8%b6/ https://jant-mamlka.com/%d8%b4%d8%b1%d9%83%d8%a9-%d8%aa%d9%86%d8%b8%d9%8a%d9%81-%d9%88%d8%a7%d8%ac%d9%87%d8%a7%d8%aa-%d8%ad%d8%ac%d8%b1-%d8%a8%d8%a7%d9%84%d8%b1%d9%8a%d8%a7%d8%b6/ https://jant-mamlka.com/%d8%b4%d8%b1%d9%83%d8%a9-%d8%aa%d9%86%d8%b8%d9%8a%d9%81-%d9%88%d8%a7%d8%ac%d9%87%d8%a7%d8%aa-%d8%b2%d8%ac%d8%a7%d8%ac-%d8%a8%d8%a7%d9%84%d8%b1%d9%8a%d8%a7%d8%b6/ https://jant-mamlka.com/%d8%a7%d8%b1%d8%ae%d8%b5-%d8%b4%d8%b1%d9%83%d8%a9-%d9%86%d9%82%d9%84-%d8%a7%d8%ab%d8%a7%d8%ab-%d8%a8%d8%a7%d9%84%d8%b1%d9%8a%d8%a7%d8%b6/ https://jant-mamlka.com/%d8%a7%d8%b1%d8%ae%d8%b5-%d8%b4%d8%b1%d9%83%d8%a9-%d8%aa%d8%ae%d8%b2%d9%8a%d9%86-%d8%a7%d8%ab%d8%a7%d8%ab-%d8%a8%d8%a7%d9%84%d8%b1%d9%8a%d8%a7%d8%b6/ https://jant-mamlka.com/%d8%b4%d8%b1%d9%83%d8%a9-%d9%86%d9%82%d9%84-%d8%a7%d8%ab%d8%a7%d8%ab-%d8%a8%d8%ae%d9%85%d9%8a%d8%b3-%d9%85%d8%b4%d9%8a%d8%b7-%d9%88%d8%a7%d8%a8%d9%87%d8%a7/ https://jant-mamlka.com/%d9%85%d8%ba%d8%a7%d8%b3%d9%84-%d8%a7%d9%84%d8%ac%d8%a8%d8%b1/ https://jant-mamlka.com/%d8%b4%d8%b1%d9%83%d8%a9-%d8%b1%d8%b4-%d9%85%d8%a8%d9%8a%d8%af%d8%a7%d8%aa-%d8%a8%d8%a7%d9%84%d8%b1%d9%8a%d8%a7%d8%b6/ https://jant-mamlka.com/%d8%a7%d8%b1%d8%ae%d8%b5-%d8%b4%d8%b1%d9%83%d8%a9-%d9%85%d9%83%d8%a7%d9%81%d8%ad%d8%a9-%d8%ad%d8%b4%d8%b1%d8%a7%d8%aa-%d8%a8%d8%a7%d9%84%d8%b1%d9%8a%d8%a7%d8%b6/ https://jant-mamlka.com/%d8%b4%d8%b1%d9%83%d8%a9-%d9%85%d9%83%d8%a7%d9%81%d8%ad%d8%a9-%d8%a7%d9%84%d8%a8%d9%82-%d8%a8%d8%a7%d9%84%d8%b1%d9%8a%d8%a7%d8%b6/ https://jant-mamlka.com/%d9%85%d9%83%d8%a7%d9%81%d8%ad%d8%a9-%d8%a7%d9%84%d9%81%d8%a6%d8%b1%d8%a7%d9%86-%d8%a8%d8%a7%d9%84%d8%b1%d9%8a%d8%a7%d8%b6/ https://jant-mamlka.com/%d8%b4%d8%b1%d9%83%d8%a9-%d9%85%d9%83%d8%a7%d9%81%d8%ad%d8%a9-%d8%a7%d9%84%d9%86%d9%85%d9%84-%d8%a7%d9%84%d8%a7%d8%a8%d9%8a%d8%b6-%d8%a8%d8%a7%d9%84%d8%b1%d9%8a%d8%a7%d8%b6/ https://jant-mamlka.com/%d9%85%d9%83%d8%a7%d9%81%d8%ad%d8%a9-%d8%a7%d9%84%d8%b5%d8%b1%d8%a7%d8%b5%d9%8a%d8%b1-%d8%a8%d8%a7%d9%84%d8%b1%d9%8a%d8%a7%d8%b6/ https://jant-mamlka.com/%d8%b4%d8%b1%d9%83%d8%a9-%d9%85%d9%83%d8%a7%d9%81%d8%ad%d8%a9-%d8%a7%d9%84%d8%ad%d9%85%d8%a7%d9%85-%d8%a8%d8%a7%d9%84%d8%b1%d9%8a%d8%a7%d8%b6/ https://jant-mamlka.com/%d8%b4%d8%b1%d9%83%d8%a9-%d9%85%d9%83%d8%a7%d9%81%d8%ad%d8%a9-%d8%a7%d9%84%d9%88%d8%b2%d8%ba-%d8%a8%d8%a7%d9%84%d8%b1%d9%8a%d8%a7%d8%b6/ https://jant-mamlka.com/%d8%b4%d8%b1%d9%83%d8%a9-%d8%aa%d9%86%d8%b8%db%8c%d9%81-%d8%a8%d8%a7%d9%84%d8%af%d9%85%d8%a7%d9%85/ https://jant-mamlka.com/%d8%aa%d9%86%d8%b8%d9%8a%d9%81-%d8%b4%d9%82%d9%82-%d8%a8%d8%a7%d9%84%d8%af%d9%85%d8%a7%d9%85/ https://jant-mamlka.com/%d8%b4%d8%b1%d9%83%d8%a9-%d8%aa%d9%86%d8%b8%d9%8a%d9%81-%d9%85%d8%ac%d8%a7%d9%84%d8%b3-%d8%a8%d8%a7%d9%84%d8%af%d9%85%d8%a7%d9%85/ https://jant-mamlka.com/%d8%b4%d8%b1%d9%83%d8%a9-%d8%aa%d9%86%d8%b8%d9%8a%d9%81-%d9%83%d9%86%d8%a8-%d8%a8%d8%a7%d9%84%d8%af%d9%85%d8%a7%d9%85/ https://jant-mamlka.com/%d8%b4%d8%b1%d9%83%d8%a9-%d8%aa%d9%86%d8%b8%d9%8a%d9%81-%d9%85%d9%88%d9%83%d9%8a%d8%aa-%d8%a8%d8%a7%d9%84%d8%af%d9%85%d8%a7%d9%85/ https://jant-mamlka.com/%d8%b4%d8%b1%d9%83%d8%a9-%d8%aa%d9%86%d8%b8%d9%8a%d9%81-%d8%ae%d8%b2%d8%a7%d9%86%d8%a7%d8%aa-%d8%a8%d8%a7%d9%84%d8%af%d9%85%d8%a7%d9%85/ https://jant-mamlka.com/%d8%b4%d8%b1%d9%83%d8%a9-%d8%b9%d8%b2%d9%84-%d8%a7%d8%b3%d8%b7%d8%ad-%d8%a8%d8%a7%d9%84%d8%af%d9%85%d8%a7%d9%85/ https://jant-mamlka.com/%d8%b4%d8%b1%d9%83%d8%a9-%d9%85%d9%83%d8%a7%d9%81%d8%ad%d8%a9-%d8%a7%d9%84%d9%86%d9%85%d9%84-%d8%a7%d9%84%d8%a7%d8%a8%d9%8a%d8%b6-%d8%a8%d8%a7%d9%84%d8%af%d9%85%d8%a7%d9%85/ https://jant-mamlka.com/%d8%b4%d8%b1%d9%83%d8%a9-%d9%85%d9%83%d8%a7%d9%81%d8%ad%d8%a9-%d8%ad%d8%b4%d8%b1%d8%a7%d8%aa-%d8%a8%d8%a7%d9%84%d8%af%d9%85%d8%a7%d9%85/ https://jant-mamlka.com/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490293#490293 ________________________________________________________________________________
Date: Jul 14, 2019
Subject: Re: BNC connectors - Types of cable and installation
tools There is a difference between the 58 and the 400 RU B(T)NC connectors It deals with the fact that the 400 cable has 2 braided shields around the central insulated conductor. This makes the wire greater in diameter and thus needs a larger crimp collar(which holds the whole assembly together). You could probably get by using a 400 collar with 58 wire but a 58 collar wont easily fit in 400. The crimping tools should be the same. Rich The crimped Sent from my iPhone > On Jul 14, 2019, at 6:00 PM, Argonaut36 wrote: > > > Could somebody kindly answer the following questions: > > - Are BNC connectors for RG-58U wire and RG400U wire the same? > > - Can the same crimpers be used for attaching BNC connectors to both RG-58U wire and RG400U wire? If so, why you can only read 58 on some dye sets and not 58/400 or something like that? > > - What about TNC connectors? Do the same principles as for BNC connectors apply when it comes to RG58/RG400 cables and installation tools? > > Thanks > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=490290#490290 > > > > > > > > > ________________________________________________________________________________
Subject: =?ISO-8859-1?Q?=D8=B4=D8=B1=D9=83=D8=A9?= =?ISO-8859-1?Q?=D8=A7=D8=B3=D8=A7=D8=B7=D9=8A=D8=B1?
Date: Jul 15, 2019
(http://kenanaonline.com/users/mzlat/posts/1035857) (http://kenanaonline.com/users/mzlat/posts/1035856) (http://kenanaonline.com/users/mzlat/posts/1035855) (https://mzlatwswater.blogspot.com/2019/06/blog-post_9.html) (https://mzlatwswater.blogspot.com/2019/06/blog-post_6.html) (https://mzlatwswater.blogspot.com/2019/06/blog-post_46.html) (https://mzlatwswater.blogspot.com/2019/06/blog-post_70.html) (https://mzlatwswater.blogspot.com/2019/06/blog-post_26.html) (https://mzlatwswater.blogspot.com/2019/06/blog-post_94.html) (https://mzlatwswater.blogspot.com/2019/06/blog-post_22.html) (https://mzlatwswater.blogspot.com/2019/06/blog-post_15.html) (https://mzlatwswater.blogspot.com/2019/06/blog-post.html) (https://mzlat.home.blog/2019/06/26/%d9%82%d8%b1%d9%85%d9%8a%d8%af-%d8%a7%d9%84%d8%b1%d9%8a%d8%a7%d8%b6/) (https://mzlat.home.blog/2019/06/26/%d9%85%d8%b8%d9%84%d8%a7%d8%aa-%d8%ad%d8%af%d8%a7%d8%a6%d9%82-%d8%a7%d9%84%d8%b1%d9%8a%d8%a7%d8%b6/) (https://mzlat.home.blog/2019/06/26/%d8%aa%d8%b1%d9%83%d9%8a%d8%a8-%d8%b3%d9%88%d8%a7%d8%aa%d8%b1/) (https://mzlat.home.blog/2019/06/26/%d9%87%d9%86%d8%a7%d8%ac%d8%b1-%d9%88%d9%85%d8%b3%d8%aa%d9%88%d8%af%d8%b9%d8%a7%d8%aa-%d8%a7%d9%84%d8%b1%d9%8a%d8%a7%d8%b6/) (https://mzlat.home.blog/2019/06/26/%d9%85%d8%b8%d9%84%d8%a7%d8%aa-%d8%ad%d8%af%d8%a7%d8%a6%d9%82/) (https://mzlat.home.blog/2019/06/22/%d9%85%d8%b8%d9%84%d8%a7%d8%aa-%d9%84%d9%83%d8%b3%d8%a7%d9%86/) (https://mzlat.home.blog/2019/06/22/%d8%a8%d8%b1%d8%ac%d9%88%d9%84%d8%a7%d8%aa/) (https://mzlat.home.blog/2019/06/21/%d8%b4%d8%a8%d9%88%d9%83/) (https://mzlat.home.blog/2019/06/11/%d9%85%d8%b8%d9%84%d8%a7%d8%aa-%d9%88%d8%b3%d9%88%d8%a7%d8%aa%d8%b1/) (https://alroda.webnode.com/l/trkyb-swatr-alryad/) (https://alroda.webnode.com/l/trkyb-mzlat-alryad/) (https://alroda.webnode.com/l/swatr-alryad/) (https://khadmaty.tumblr.com/post/185858905484/%D8%A8%D9%8A%D9%88%D8%AA-%D8%B4%D8%B9%D8%B1-%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6) (https://khadmaty.tumblr.com/post/185858894429/%D9%85%D8%B8%D9%84%D8%A7%D8%AA-%D8%B3%D9%8A%D8%A7%D8%B1%D8%A7%D8%AA-%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6) (https://khadmaty.tumblr.com/post/185858885794/%D9%87%D9%86%D8%A7%D8%AC%D8%B1-%D9%88%D9%85%D8%B3%D8%AA%D9%88%D8%AF%D8%B9%D8%A7%D8%AA) (https://khadmaty.tumblr.com/post/185765859439/%D9%82%D8%B1%D9%85%D9%8A%D8%AF) (https://alroda54.wixsite.com/alroda/post/%D8%AA%D8%B1%D9%83%D9%8A%D8%A8-%D9%82%D8%B1%D9%85%D9%8A%D8%AF-%D8%AD%D8%AF%D9%8A%D8%AF) (https://alroda54.wixsite.com/alroda/post/%D8%AA%D8%B1%D9%83%D9%8A%D8%A8-%D9%87%D9%86%D8%A7%D8%AC%D8%B1-%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6) (https://alroda54.wixsite.com/alroda/post/%D8%B4%D8%A8%D9%88%D9%83-%D8%A7%D9%84%D8%B1%D9%8A%D8%A7%D8%B6) (https://alroda54.wixsite.com/alroda/post/%D9%87%D9%86%D8%A7%D8%AC%D8%B1) (https://al-roda.weebly.com/blog/3913728) (https://al-roda.weebly.com/blog/2600505) (https://al-roda.weebly.com/blog/2413164) (https://al-roda.weebly.com/blog/8740665) (https://al-roda.weebly.com/blog/7801012) (https://al-roda.weebly.com/blog/7907456) (https://alroda.hatenablog.com/entry/2019/06/26/180854) (https://alroda.hatenablog.com/entry/2019/06/26/180835) (https://alroda.hatenablog.com/entry/2019/06/26/180803) (https://alroda.hatenablog.com/entry/2019/06/22/230744) (http://kenanaonline.com/alrodaa) (https://marketingplus550.wordpress.com/blog/) (https://marketingplus550.blogspot.com/) (https://marketingplus3.webnode.com/marketing-plus/) (https://alrodaa.weebly.com/blog) (https://blogmarketingplus.tumblr.com/) (https://marketingplus.hatenablog.com/) (https://myseo550blog.quora.com/) (http://marketingplus.emyspot.com/blog/) (http://site-1643697-8902-1287.strikingly.com/) (https://unet.com/mzlatasteer/entries/) (https://alroda.hatenablog.com/) (https://al-roda.weebly.com/) (https://alroda54.wixsite.com/alroda/blog) (https://alroda54.wixsite.com/alroda/) (https://khadmaty.tumblr.com/) (https://alroda.webnode.com/) (https://alroda.webnode.com/alroda-blog/) (https://mzlat.home.blog/) (https://mzlatwswater.blogspot.com/) (http://kenanaonline.com/mzlat) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490297#490297 ________________________________________________________________________________
Subject: =?ISO-8859-1?Q?=D8=B4=D8=B1=D9=83=D8=A9?= =?ISO-8859-1?Q?=D9=85=D8=AD=D8=D8=B1=D9=81?=
=?ISO-8859-1?Q?=D8=A7=D9=84=D8=B8=D9=84?
Date: Jul 15, 2019
(https://justpaste.it/6k0uq) (https://justpaste.it/7higb) (https://justpaste.it/48a4g) (https://justpaste.it/3ggt5) (https://justpaste.it/56u8m) (https://justpaste.it/7pmjn) (https://justpaste.it/4mbho) (https://justpaste.it/2jmgv) (https://justpaste.it/5hoid) (https://justpaste.it/6n09f) (https://justpaste.it/3qhss) (https://justpaste.it/5vmg8) (https://justpaste.it/6auke) (https://justpaste.it/2qh5l) (https://justpaste.it/2lequ) (https://justpaste.it/4k3qg) (https://justpaste.it/5aqfj) (https://justpaste.it/4011w) (https://justpaste.it/7o7pe) (https://justpaste.it/69445) (https://justpaste.it/3lywr) (https://justpaste.it/7nxm6) (https://justpaste.it/4r4h6) (https://justpaste.it/5n35w) (https://justpaste.it/7e5n0) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490298#490298 ________________________________________________________________________________
Date: Jul 14, 2019
tools At 06:00 PM 7/14/2019, you wrote: > >Could somebody kindly answer the following questions: > >- Are BNC connectors for RG-58U wire and RG400U wire the same? > >- Can the same crimpers be used for attaching >BNC connectors to both RG-58U wire and RG400U >wire? If so, why you can only read =9858=99 on >some dye sets and not =9858/400=99 or something like that? > >- What about TNC connectors? Do the same >principles as for BNC connectors apply when it >comes to RG58/RG400 cables and installation tools? BNC and TNC connectors are crimped with the same hex dies. 0.213 for the shield and 0.068 for the center conductor. As indicated in this ad: https://tinyurl.com/y5poy9dc Emacs! All coax types listed are 0.195" nominal o.d. and will install on the same connector Bob . . . ________________________________________________________________________________
Date: Jul 15, 2019
tools
Date: Jul 15, 2019
Thanks for answering my questions! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490315#490315 ________________________________________________________________________________
Date: Jul 16, 2019
Subject: Ray Allen trim servo/control: actual wiring schematic
needed Anyone out there with an actual schematic of the Ray Allen relay decks, switches, stick switches, etc? Their on-line 'diagrams' are typical consumer-facing 'white boxes' for each component, showing nothing of how the contacts in the device are tied to the various colored wires. I can spend a day or two puzzling out how the internals are connected, but I'd love to avoid the waste of time. The guys at RA were less than worthless, telling me that it would be 'dangerous' to show the consumer (the people actually installing their stuff) what was going on inside each box on their diagrams. Gotta say, if there were an alternative, I'd just replace the stuff so I wouldn't have to deal with them. Problem: previous owner(s) have panel mounted rockers & indicators for pitch/roll, and a stick grip with the 4 separate buttons for pitch/roll. The rockers work. The stick buttons will make the relays click, but don't control the trim motors. As I said, I can puzzle it out, but I'd like to *start* with schematics of the devices, instead of having to create them. Thanks, Charlie ________________________________________________________________________________
Subject: Re: Ray Allen trim servo/control: actual wiring schematic
needed
Date: Jul 16, 2019
Do you have these pdf documents from Ray Allen? http://www.rayallencompany.com/RACmedia/instructionsG2grip.pdf http://www.rayallencompany.com/RACmedia/do-it-urself1servorelays.pdf Here is Bob N's circuit: http://aeroelectric.com/PPS/Flight/Trim/Stick_Grip_Trim.pdf -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490332#490332 Attachments: http://forums.matronics.com//files/trim_motor_control_13_157.jpg ________________________________________________________________________________
schematic needed
Date: Jul 16, 2019
On 7/16/2019 12:43 PM, user9253 wrote: > > Do you have these pdf documents from Ray Allen? > http://www.rayallencompany.com/RACmedia/instructionsG2grip.pdf > > http://www.rayallencompany.com/RACmedia/do-it-urself1servorelays.pdf > > Here is Bob N's circuit: > http://aeroelectric.com/PPS/Flight/Trim/Stick_Grip_Trim.pdf > > -------- > Joe Gores > Hi Joe, I've got the RA cartoon docs. Bob's type of drawing, showing the relay & switch terminals/internal connections, is what I'm hoping to find for the RA parts. Thanks, Charlie --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jul 16, 2019
schematic needed >Hi Joe, > >I've got the RA cartoon docs. Bob's type of drawing, showing the >relay & switch terminals/internal connections, is what I'm hoping to >find for the RA parts. > >Thanks, > >Charlie Check through the collection of drawings at https://tinyurl.com/y6yxkbb8 If you're a CAD-driver and can read .dwg files, I can supply originals for all/any of those .pdfs Bob . . . ________________________________________________________________________________
Date: Jul 16, 2019
Subject: Molex 4366 terminals for ICOM IC-A210 radio
Does anyone know a source for the terminals (contacts) for an ICOM IC-A210 card edge connector. I have the housing (30 Pin Molex 4338) and just need the crimp terminals (M olex 4366, Molex Part Number=C2-08-03-0304). The usual distributors (Newark, Mouser, Digi-Key) show these as obsolete. Thanks in advance, Peter ________________________________________________________________________________
Date: Jul 16, 2019
Hello Art If I remember correctly you have MGL equipment, there was a query on the MG L forum about this, the answer was that MGL was WAAS certified. Not sure if this was your question or whether you wanted something in addit ion to your system Keep well Mike From: owner-aeroelectric-list-server(at)matronics.com <owner-aeroelectric-list -server(at)matronics.com> On Behalf Of Alec Myers Sent: July 13, 2019 3:18 PM Subject: Re: AeroElectric-List: [OT] IFR-certified GPS Suggestions I=99m fond of the Avidyne IFD series On Jul 13, 2019, at 08:05, Art Zemon > wrote: This is somewhat off-topic but I figure y'all know a lot about airplanes so you might have opinions about avionics, too. I reserved space in my panel for a Garmin 430 WAAS or a Garmin 650. Now tha t Oshkosh is upon us, perhaps I can save a few pennies on an IFR-certified GPS that will fit in that hole. It doesn=99t have to be a Garmin; tha t is just the size hole that I cut when I did the rest of the panel. What suggestions do you have, both for equipment and vendor? -- Art Z. -- https://CheerfulCurmudgeon.com/ Love the stranger for you yourselves were strangers in Egypt. Deut. 10:19 --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jul 17, 2019
Mike, Yes, I have an MGL system and their latest GPS, the SP-12 <http://www.mglavionics.co.za/sp12.html>, has the necessary certifications to be an ADS-B source. Rainier has posted the details but they were so detailed that my eyes glazed over while reading them. The bottom line is that the SP-12 is certified but the GPS which is integrated into the EFIS is significantly more accurate. Go figure. I am seeking a navigation radio with a GPS receiver that I can use for flying IFR so I want both the necessary certifications *and* the database with approaches, SIDs, STARs, etc. And I want a proven user interface that someone else has already designed and debugged. I am willing to do a lot of experimenting but, when I am in the clouds, I want to minimize my risk and workload. The MGL SP-12 is only GPS receiver, though. It lacks a front panel display, database, etc etc etc, so it won't meet my needs. -- Art Z. On Tue, Jul 16, 2019 at 11:37 PM wrote: > Hello Art > > > If I remember correctly you have MGL equipment, there was a query on the > MGL forum about this, the answer was that MGL was WAAS certified. > > > Not sure if this was your question or whether you wanted something in > addition to your system > -- https://CheerfulCurmudgeon.com/ *Love the stranger for you yourselves were strangers in Egypt. *Deut. 10:19 ________________________________________________________________________________
Date: Jul 17, 2019
schematic needed On Tue, Jul 16, 2019 at 2:15 PM Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > Hi Joe, > > I've got the RA cartoon docs. Bob's type of drawing, showing the relay & > switch terminals/internal connections, is what I'm hoping to find for the > RA parts. > > Thanks, > > Charlie > > > Check through the collection of drawings at > > https://tinyurl.com/y6yxkbb8 > > If you're a CAD-driver and can read .dwg > files, I can supply originals for all/any > of those .pdfs > > > Bob . . . > Thanks Bob; the trim.pdf is a good starting point for me. Unfortunately, I haven't had the time yet to become CAD-literate. Charlie ________________________________________________________________________________
Date: Jul 17, 2019
No, hot GRT , Sent from my iPhone > On Jul 16, 2019, at 11:21 PM, wr ote: > > Hello Art > > If I remember correctly you have MGL equipment, there was a query on the M GL forum about this, the answer was that MGL was WAAS certified. > > Not sure if this was your question or whether you wanted something in addi tion to your system > > Keep well > > Mike > > From: owner-aeroelectric-list-server(at)matronics.com <owner-aeroelectric-lis t-server(at)matronics.com> On Behalf Of Alec Myers > Sent: July 13, 2019 3:18 PM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: [OT] IFR-certified GPS Suggestions > > I=99m fond of the Avidyne IFD series > > On Jul 13, 2019, at 08:05, Art Zemon wrote: > > This is somewhat off-topic but I figure y'all know a lot about airplanes s o you might have opinions about avionics, too. > > I reserved space in my panel for a Garmin 430 WAAS or a Garmin 650. Now th at Oshkosh is upon us, perhaps I can save a few pennies on an IFR-certified G PS that will fit in that hole. It doesn=99t have to be a Garmin; that i s just the size hole that I cut when I did the rest of the panel. > > What suggestions do you have, both for equipment and vendor? > > -- Art Z. > > -- > https://CheerfulCurmudgeon.com/ > > Love the stranger for you yourselves were strangers in Egypt. Deut. 10:19 > > Virus-free. www.avast.com ________________________________________________________________________________
Subject: ADS-B Preflight Requirements updated for GA
Date: Jul 17, 2019
Just saw this on AVWeb... The FAA will issue a Notam on Thursday that will essentially exempt general aviation aircraft operators from an ADS-B preflight requirement when the ADS-B mandate kicks in next January. The Notam specifically exempts ADS-B Out transmitters that use WAAS GPS receivers as a position source from the preflight requirement described in an FAA policy statement that was released earlier this month. The Notam reads: It is not necessary for operators of aircraft equipped with the Wide Area Augmentation System (WAAS) (TSOC145 or TSOC146) receivers to conduct a preflight availability prediction. Garmin spokesman Bill Stone told /AVweb/ the preflight requirement was always intended for airliners, most of which have early-generation GPS systems that are not as reliably precise as those with WAAS. All ADS-B units certified for GA aircraft for the 2020 mandate must use a WAAS GPS receiver as a position source. There are currently zero non-WAAS based ADS-B Out GPS solutions for general aviation aircraft, he said. For GA, its a non-issue. Stone said he suspects the WAAS exemption got lost in the extensive vetting process that policy statements like the preflight requirements included in the recent Federal Register Notice go through. The original intent of the policy statement was to codify exemptions from sanctions for airlines when GPS signals degrade after theyve done the preflight checks and the subsequent lack of compliance is beyond their control. Harley ________________________________________________________________________________
Date: Jul 17, 2019
Hi Art, I installed a GTN 650 in my RV8 when they first came out.=C2- Could not b e happier with the unit.=C2- It is simple and intuitive to use.=C2- Dat a updates are expensive, but that is the nature things aviation. Michael WynnRV8Livermore, CA -----Original Message----- From: mike <mike(at)vision499.com> Sent: Tue, Jul 16, 2019 9:22 pm Subject: RE: AeroElectric-List: [OT] IFR-certified GPS Suggestions #yiv6656459749 #yiv6656459749 -- _filtered #yiv6656459749 {panose-1:2 4 5 3 5 4 6 3 2 4;} _filtered #yiv6656459749 {font-family:Calibri;panose-1:2 15 5 2 2 2 4 3 2 4;} _filtered #yiv6656459749 {font-family:Georgia;panose-1:2 4 5 2 5 4 5 2 3 3;} #yiv6656459749 #yiv6656459749 p.yiv6656459749MsoNormal, #yiv6656459749 li.yiv6656459749MsoNormal, #yiv6656459749 div.yiv6656459749 MsoNormal {margin:0cm;margin-bottom:.0001pt;font-size:11.0pt;font-family:sa ns-serif;} #yiv6656459749 a:link, #yiv6656459749 span.yiv6656459749MsoHyper link {color:blue;text-decoration:underline;} #yiv6656459749 a:visited, #yiv 6656459749 span.yiv6656459749MsoHyperlinkFollowed {color:purple;text-decora tion:underline;} #yiv6656459749 p.yiv6656459749msonormal0, #yiv6656459749 l i.yiv6656459749msonormal0, #yiv6656459749 div.yiv6656459749msonormal0 {marg in-right:0cm;margin-left:0cm;font-size:11.0pt;font-family:sans-serif;} #yiv 6656459749 span.yiv6656459749EmailStyle18 {font-family:sans-serif;color:win dowtext;} #yiv6656459749 .yiv6656459749MsoChpDefault {font-size:10.0pt;} _f iltered #yiv6656459749 {margin:72.0pt 72.0pt 72.0pt 72.0pt;} #yiv6656459749 div.yiv6656459749WordSection1 {} #yiv6656459749 Hello Art =C2-If I remem ber correctly you have MGL equipment, there was a query on the MGL forum ab out this, the answer was that MGL was WAAS certified. =C2-Not sure if thi s was your question or whether you wanted something in addition to =C2-yo ur system =C2-Keep well =C2-Mike =C2-From: owner-aeroelectric-list-se rver(at)matronics.com On Behalf Of Alec Myers Sent: July 13, 2019 3:18 PM Subject: Re: AeroElectric-List: [OT] IFR-certified GPS Suggestions =C2-I =99m fond of the Avidyne IFD series=C2- On Jul 13, 2019, at 08:05, Art Zemon wrote: This is somewhat off-topic but I figure y'all know a lot about airplanes so you might have opinions about avionics, too. =C2-I reserved space in my panel for a Garmin 430 WAAS or a Garmin 650. Now that Oshkosh is upon us, p erhaps I can save a few pennies on an IFR-certified GPS that will fit in th at hole. It doesn=99t have to be a Garmin; that is just the size hole that I cut when I did the rest of the panel. What suggestions do you have, both for equipment and vendor? =C2-=C2- =C2- -- Art Z. =C2--- https://CheerfulCurmudgeon.com/ Love the stranger for you yourselves were strangers in Egypt. Deut. 10:19 | | Virus-free. www.avast.com | ________________________________________________________________________________
neede
Date: Jul 17, 2019
Hi Charlie, I have a bunch and have posted some over the years. Here is the Trim box. Eric -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490359#490359 Attachments: http://forums.matronics.com//files/tscmr_installation_manual_108.pdf ________________________________________________________________________________
Date: Jul 17, 2019
Subject: BALUNs and stuff
Got a VNA up and running on a laptop. Will try to get a Jim Wier ELT antenna fabricated over the next few days to see if a common mode choke is really effective/necessary. I'll also look at an exemplar Pawsey Stub and a legacy 'Aviation BALUN' featured in so many anointed documents over the past 50 or so years. By the way, I was curious about how well those little VHF/UHF 'rubber duck' antennas worked on contemporary VHF/UHF hand-helds. Screwed an antenna off my EMS talkie to the VNA and ran a 100 to 500 MHz scan which yielded the following plot: Emacs! Sho 'nuf . . . the little critter has SWR 'dips' that span the frequencies of interest. Pretty cool . . . Bob . . . ________________________________________________________________________________
Date: Jul 17, 2019
I had the IFR GPS from GRT but they didn't have the software updated. So I went looking for a GNS400W (or 400 that I would upgrade). For the same price I was finding them, Tim and Approach FastStack got me a brand new GTN625. Took me a while to get used to the different UI, but it's pretty nice. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490363#490363 ________________________________________________________________________________
Date: Jul 17, 2019
As Art points out, there are radical differences between a 'WAAS certified GPS' as a position source for ADSB, and an IFR certified GPS navigation radio. As far as I know, there are no experimental EFIS systems that are approved for IFR *navigation*. Perfectly fine to use them as flight instruments in IFR conditions, but until the FAA modifies their rules, you still need an IFR certified GPS navigator (complete with certified, up to date databases, approaches, etc) for IFR GPS navigation in the USA. I've seen some rumors that FAA might be considering an easing on that rule, so that non-certified GPS could be used for IFR, similar to non-TSO VOR/ILS receivers, but haven't heard of any official change. On Wed, Jul 17, 2019 at 7:12 AM Art Zemon wrote: > Mike, > > Yes, I have an MGL system and their latest GPS, the SP-12 > <http://www.mglavionics.co.za/sp12.html>, has the necessary > certifications to be an ADS-B source. Rainier has posted the details but > they were so detailed that my eyes glazed over while reading them. The > bottom line is that the SP-12 is certified but the GPS which is integrated > into the EFIS is significantly more accurate. Go figure. > > I am seeking a navigation radio with a GPS receiver that I can use for > flying IFR so I want both the necessary certifications *and* the database > with approaches, SIDs, STARs, etc. And I want a proven user interface that > someone else has already designed and debugged. I am willing to do a lot of > experimenting but, when I am in the clouds, I want to minimize my risk and > workload. > > The MGL SP-12 is only GPS receiver, though. It lacks a front panel > display, database, etc etc etc, so it won't meet my needs. > > -- Art Z. > > On Tue, Jul 16, 2019 at 11:37 PM wrote: > >> Hello Art >> >> >> >> If I remember correctly you have MGL equipment, there was a query on the >> MGL forum about this, the answer was that MGL was WAAS certified. >> >> >> >> Not sure if this was your question or whether you wanted something in >> addition to your system >> > > -- > https://CheerfulCurmudgeon.com/ > > *Love the stranger for you yourselves were strangers in Egypt. *Deut. > 10:19 > ________________________________________________________________________________
Date: Jul 17, 2019
Hey Art, Don't know your budget, but an IFR rated friend replaced his Garmin 430 with an Avidyne 440. Slide-in replacement for the 430, and he says that it's got a much better user interface and some really nice features that 'anticipate' the next segment when flying a procedure. At the time, they were offering a very attractive trade-in deal for 430s, which I suppose won't help you much. :-) Charlie On 7/17/2019 1:53 PM, Charlie England wrote: > As Art points out, there are radical differences between a 'WAAS > certified GPS' as a position source for ADSB, and an IFR certified GPS > navigation radio. As far as I know, there are no experimental EFIS > systems that are approved for IFR *navigation*. Perfectly fine to use > them as flight instruments in IFR conditions, but until the FAA > modifies their rules, you still need an IFR certified GPS navigator > (complete with certified, up to date databases, approaches, etc) for > IFR GPS navigation in the USA. I've seen some rumors that FAA might be > considering an easing on that rule, so that non-certified GPS could be > used for IFR, similar to non-TSO VOR/ILS receivers, but haven't heard > of any official change. > > On Wed, Jul 17, 2019 at 7:12 AM Art Zemon > wrote: > > Mike, > > Yes, I have an MGL system and their latest GPS, the SP-12 > <http://www.mglavionics.co.za/sp12.html>, has the necessary > certifications to be an ADS-B source. Rainier has posted the > details but they were so detailed that my eyes glazed over while > reading them. The bottom line is that the SP-12 is certified but > the GPS which is integrated into the EFIS is significantly more > accurate. Go figure. > > I am seeking a navigation radio with a GPS receiver that I can use > for flying IFR so I want both the necessary certifications > /and/the database with approaches, SIDs, STARs, etc. And I want a > proven user interface that someone else has already designed and > debugged. I am willing to do a lot of experimenting but, when I am > in the clouds, I want to minimize my risk and workload. > > The MGL SP-12 is only GPS receiver, though. It lacks a front panel > display, database, etc etc etc, so it won't meet my needs. > > -- Art Z. > > On Tue, Jul 16, 2019 at 11:37 PM > wrote: > > Hello Art > > If I remember correctly you have MGL equipment, there was a > query on the MGL forum about this, the answer was that MGL was > WAAS certified. > > Not sure if this was your question or whether you wanted > something in addition to your system > > > -- > https://CheerfulCurmudgeon.com/ > > /Love the stranger for you yourselves were strangers in Egypt. > /Deut. 10:19 > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jul 17, 2019
Charlie, I am definitely considering the Avidyne IFD 440. I have a friend with one in his RV10 and he really likes it. I am also considering the new Garmin GPS 175 and then add a second comm radio and call it done. (I already have a VOR/ILS/GS nav radio.) -- Art Z. On Wed, Jul 17, 2019 at 4:19 PM Charlie England wrote: > Hey Art, > > Don't know your budget, but an IFR rated friend replaced his Garmin 430 > with an Avidyne 440. Slide-in replacement for the 430, and he says that > it's got a much better user interface and some really nice features that > 'anticipate' the next segment when flying a procedure. > -- https://CheerfulCurmudgeon.com/ *Love the stranger for you yourselves were strangers in Egypt. *Deut. 10:19 ________________________________________________________________________________
Subject: Antenna Cable length
Date: Jul 17, 2019
Hello, I am about to cut my antenna to final length and want to confirm: a: if there is an optimal antenna length and b: if there is a minimum distance between radio and antenna. The radio is a MGL V16 remote mount I have 2 possible antenna position and want to test both, at the moment one is +/- 2 feet from the radio and the other +/- 8ft Thanks Mike --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jul 18, 2019
Subject: Re: Antenna Cable length
Mike, For a communications radio, the distance on a GA airplane doesn't matter much. You might, in a lab, be able to measure the difference in performance of an antenna that is 2 feet vs 8 feet from the transmitter. Similarly, you might be able to measure the difference in performance of an antenna on the top vs the bottom of the fuselage. In the real world, probably not. My advice: put your antenna where ever it looks cool. You will smile bigger whenever you see your airplane and that counts for a lot. What are you building? -- Art Z. On Thu, Jul 18, 2019 at 12:27 AM wrote: > Hello, > > > I am about to cut my antenna to final length and want to confirm: > > > a: if there is an optimal antenna length and > > > b: if there is a minimum distance between radio and antenna. > > > The radio is a MGL V16 remote mount > > > I have 2 possible antenna position and want to test both, at the moment > one is +/- 2 feet from the radio and the other +/- 8ft > > > Thanks > > > Mike > -- https://CheerfulCurmudgeon.com/ *Love the stranger for you yourselves were strangers in Egypt. *Deut. 10:19 ________________________________________________________________________________
Subject: New Smartphone Apps for Pilots
Date: Jul 18, 2019
Greetings fellow Aviators! As a long time, intermittent contributor to this forum, I thought this might be of interest: It has been quite a while since we started writing pilot apps for Apple smartphones and iPads. Our family of apps for aviation has grown into 11 very handy and unique tools for people who fly (or dream about it!). Here's a brief list of the Apps with links to the App Store for more information and a sampling of screen shots to see the apps in action. The latest App is Runway Finder. This app was suggested by a buddy, a retired Delta Captain who owns a Citabria. He does a lot of cross country flying and complained that it was hard to find a grass strip to use away from home base. This App maps out airports by runway surface and type (Turf, Paved, Gravel, Water, Glider, and Heliport). Runway Finder has a built-in list of over 50,000 runways/airports world wide. It is available on the Apple App store at: https://apps.apple.com/app/airport-runway-finder/id1471923024 Plane Registry. A FREE app to lookup US-Registered aircraft from the live FAA database. https://apps.apple.com/app/airport-runway-finder/id1471923024 Local METARS. A very handy weather app for local conditions. Just open the App and it will display the current METAR conditions at the closest reporting station. You get the option to look out up to 100 miles and sort by bearing from your location. No more scrolling and endless clicking to get the Wx you need for local flying. This app works with world wide reporting stations. https://apps.apple.com/us/app/local-metars/id1150644548 We also have a stand-alone version of Local METARS for the Apple Watch https://apps.apple.com/app/local-metars-for-watch/id1447757207 Civil Twilight Calculator. CTC is a self-contained sunrise/sunset calculator for use anywhere. No calling home to the Naval Observatory! It doesnt need internet access at all. Use it in flight! It can tell you accurately when Civil Twilight occurs where you are, or at an airport around the world, on any day 50 years. If you do have internet, you can give it a street address and see the calculated times. https://apps.apple.com/app/civil-twilight-calculator/id1163850946 We also have a stand-alone version for Apple Watch: https://apps.apple.com/app/civil-twilight-for-watch/id1448137376 Aviation Altimeter (aka avAltimeter). Not a GPS altimeter like most on the App Store, but a True and Accurate barometric altimeter using the built-in sensors in iPhones after iPhone 6, or iPads after the Mini-4. Has a Kollsman adjustment for ATC or METARs reports. Looks and feels just like the steam gauge in your panel, but with Smart features: Density Altitude, Oxygen Warning timer, and estimated aircraft Performance, auto-set at airport, etc. https://apps.apple.com/app/avaltimeter/id1120306812 The stand-alone version for the Apple Watch: https://apps.apple.com/app/aviation-altimeter-for-watch/id1434085253 VOR Navigator. Truly unique! A fully functional VOR and HSI navigator (using GPS, not VHF). Includes all current VOR and NDB transmitting stations plus a number of recently decommissioned ones. Also includes DME and ADF modes. The App will also home to all Large and Medium (Commercial) airports. Check out the Add Lightning mode for the ADF for a true vintage experience! This is a single hybrid App, which works on both iOS devices and the Apple Watch, each independently from the other. https://apps.apple.com/app/vor-navigator/id1451733763 Crosswinds Live. Another very unique and handy App. Crosswinds Live contains the runway diagrams for all registered airports world wide and will draw the current wind across the runways. The wind information comes from the METAR station closest to the airport. Also computes the headwind & crosswind components for flight planning. https://apps.apple.com/app/crosswinds-live/id1240254020 Sun Compass. Compass broken? Lost on a hike? If you can see the Sun or the Moon, this app for Apple Watch can help you out. The Watch does not have a compass built in, but, using the GPS and some fancy astronomy calculations, this App will point to North, and show you your direction of travel. For Watch only (iOS has builtin magnetic compass hardware) https://apps.apple.com/app/sun-compass-for-watch/id1448262474 Safe Flying! -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490378#490378 ________________________________________________________________________________
Date: Jul 18, 2019
Subject: [OT] IFR-certified GPS Suggestions
> > Hi Charlie et al- > It's been a while since I had my fingers in this stuff, but isn't the > requirement for certificated GPS only for terminal operations? IIRC, > experimental GPS is fine for en route, but some other means is required for > finding the runway. TIA ________________________________________________________________________________
Date: Jul 18, 2019
Subject: Re: [OT] IFR-certified GPS Suggestions
I'm not IFR rated, and it's been weeks since I stayed in *any* hotel, so I'm not qualified to answer that. But my layman's understanding is that you can ask ATC for a 'heading' to fly direct to your IFR destination, and they'd wink, nod, & give you the clearance. Many years ago, my airline pilot Swift partner used to do that with a VFR LORAN receiver. Wouldn't be the same thing as actually filing GPS-direct, but has the same effect. You could be right about experimentals; I just haven't heard about it. Charlie On Thu, Jul 18, 2019 at 8:15 AM GLEN MATEJCEK wrote: > Hi Charlie et al- >> It's been a while since I had my fingers in this stuff, but isn't the >> requirement for certificated GPS only for terminal operations? IIRC, >> experimental GPS is fine for en route, but some other means is required for >> finding the runway. > > TIA > ________________________________________________________________________________
Date: Jul 18, 2019
I'm IFR rated, but only in helicopters (thanks, Uncle Sam!), but haven't flown IFR in 35+ years. However, I do read a lot, and I probably have stayed in a Holiday Inn at least once in the past year... So here's the AIM section [AIM 1-1-17(b)(2)] that explains the rules: https://www.faa.gov/air_traffic/publications/atpubs/aim_html/chap1_section_1.html And here's what that paragraph says: Authorization to conduct any GPS operation under IFR requires: (1) GPS navigation equipment used for IFR operations must be approved in accordance with the requirements specified in Technical Standard Order (TSO) TSO-C129(), TSO-C196(), TSO-C145(), or TSO-C146(), and the installation must be done in accordance with Advisory Circular AC 20-138, Airworthiness Approval of Positioning and Navigation Systems. Equipment approved in accordance with TSO-C115a does not meet the requirements of TSO-C129. Visual flight rules (VFR) and hand-held GPS systems are not authorized for IFR navigation, instrument approaches, or as a principal instrument flight reference. Jim Parker -------- Original Message -------- Subject: Re: AeroElectric-List: [OT] IFR-certified GPS Suggestions From: Charlie England <ceengland7(at)gmail.com> Date: Thu, July 18, 2019 8:37 am I'm not IFR rated, and it's been weeks since I stayed in *any* hotel, so I'm not qualified to answer that. But my layman's understanding is that you can ask ATC for a 'heading' to fly direct to your IFR destination, and they'd wink, nod, & give you the clearance. Many years ago, my airline pilot Swift partner used to do that with a VFR LORAN receiver. Wouldn't be the same thing as actually filing GPS-direct, but has the same effect. You could be right about experimentals; I just haven't heard about it. Charlie On Thu, Jul 18, 2019 at 8:15 AM GLEN MATEJCEK wrote: Hi Charlie et al- It's been a while since I had my fingers in this stuff, but isn't the requirement for certificated GPS only for terminal operations? IIRC, experimental GPS is fine for en route, but some other means is required for finding the runway.TIA ________________________________________________________________________________
Date: Jul 18, 2019
At 06:06 AM 7/18/2019, you wrote: >Mike, > >For a communications radio, the distance on a GA airplane doesn't >matter much. You might, in a lab, be able to measure the difference >in performance of an antenna that is 2 feet vs 8 feet from the >transmitter. Similarly, you might be able to measure the difference >in performance of an antenna on the top vs the bottom of the >fuselage. In the real world, probably not. Agreed Bob . . . ________________________________________________________________________________
Subject: Re: New Smartphone Apps for Pilots
Date: Jul 18, 2019
Some of these sound useful to me. When are you going to port them to Android? rampil wrote: > > Greetings fellow Aviators! > > As a long time, intermittent contributor to this forum, I thought this might be of interest: > > It has been quite a while since we started writing pilot apps for Apple smartphones and iPads. > Our family of apps for aviation has grown into 11 very handy and unique tools for people who fly > (or dream about it!). Here's a brief list of the Apps with links to the App Store for more information > and a sampling of screen shots to see the apps in action. > > The latest App is Runway Finder. This app was suggested by a buddy, a retired Delta Captain who owns a Citabria. > He does a lot of cross country flying and complained that it was hard to find a grass strip to use away from home base. > This App maps out airports by runway surface and type (Turf, Paved, Gravel, Water, Glider, and Heliport). > Runway Finder has a built-in list of over 50,000 runways/airports world wide. It is available on the Apple App store at: > https://apps.apple.com/app/airport-runway-finder/id1471923024 > > > Plane Registry. A FREE app to lookup US-Registered aircraft from the live FAA database. > https://apps.apple.com/app/airport-runway-finder/id1471923024 > > > Local METARS. A very handy weather app for local conditions. Just open the App and it will display > the current METAR conditions at the closest reporting station. You get the option to look out up to > 100 miles and sort by bearing from your location. No more scrolling and endless clicking to get the > Wx you need for local flying. This app works with world wide reporting stations. > https://apps.apple.com/us/app/local-metars/id1150644548 > > We also have a stand-alone version of Local METARS for the Apple Watch > https://apps.apple.com/app/local-metars-for-watch/id1447757207 > > > Civil Twilight Calculator. CTC is a self-contained sunrise/sunset calculator for use anywhere. > No calling home to the Naval Observatory! It doesnt need internet access at all. Use it in > flight! It can tell you accurately when Civil Twilight occurs where you are, or at an airport > around the world, on any day 50 years. If you do have internet, you can give it a street > address and see the calculated times. > https://apps.apple.com/app/civil-twilight-calculator/id1163850946 > > We also have a stand-alone version for Apple Watch: > https://apps.apple.com/app/civil-twilight-for-watch/id1448137376 > > > Aviation Altimeter (aka avAltimeter). Not a GPS altimeter like most on the App Store, but a True > and Accurate barometric altimeter using the built-in sensors in iPhones after iPhone 6, or iPads > after the Mini-4. Has a Kollsman adjustment for ATC or METARs reports. Looks and feels just like > the steam gauge in your panel, but with Smart features: Density Altitude, Oxygen Warning timer, > and estimated aircraft Performance, auto-set at airport, etc. > https://apps.apple.com/app/avaltimeter/id1120306812 > > The stand-alone version for the Apple Watch: > https://apps.apple.com/app/aviation-altimeter-for-watch/id1434085253 > > > VOR Navigator. Truly unique! A fully functional VOR and HSI navigator (using GPS, not VHF). Includes > all current VOR and NDB transmitting stations plus a number of recently decommissioned ones. Also > includes DME and ADF modes. The App will also home to all Large and Medium (Commercial) airports. > Check out the Add Lightning mode for the ADF for a true vintage experience! This is a single hybrid > App, which works on both iOS devices and the Apple Watch, each independently from the other. > https://apps.apple.com/app/vor-navigator/id1451733763 > > > Crosswinds Live. Another very unique and handy App. Crosswinds Live contains the runway diagrams for > all registered airports world wide and will draw the current wind across the runways. The wind information > comes from the METAR station closest to the airport. Also computes the headwind & crosswind components > for flight planning. > https://apps.apple.com/app/crosswinds-live/id1240254020 > > > Sun Compass. Compass broken? Lost on a hike? If you can see the Sun or the Moon, this app for Apple Watch > can help you out. The Watch does not have a compass built in, but, using the GPS and some fancy astronomy > calculations, this App will point to North, and show you your direction of travel. For Watch only (iOS has builtin > magnetic compass hardware) > https://apps.apple.com/app/sun-compass-for-watch/id1448262474 > > Safe Flying! > > -------- > Ira N224XS > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=490378#490378 > > ________________________________________________________________________________
Date: Jul 18, 2019
There are more benefits to an actual IFR certified GPS. If you are flying victor airways you are stuck with the published MEA. If you go off-route, i.e. direct, you are limited to the controller's MEA, which isn't published. IF you have an IFR GPS lower minimum altitudes are published, often 1-2000 ft lower here in the West. You can't file to navigate IFR by anything but certified equipment...which means VOR/localizer in the lower 48 states in most cases. In the flat lands you can easily ask for a vector on a specific heading and usually get it. IF your destination, or any alternate you need to divert to has a VOR/LOC/ILS, fine, but all the smaller airports are limited pretty much to GPS, or VOR with high minimums. Most approach and departure facilities have strict routing in and out of the area, that they need you on. Usually airways on departures, and unpublished arrival "gates" in between airways. So, most anything works enroute, but in the terminal environment, when ever the weather makes them busy, they don't have time for hand holding. On 7/18/2019 6:37 AM, Charlie England wrote: > I'm not IFR rated, and it's been weeks since I stayed in *any* hotel, so > I'm not qualified to answer that. But my layman's understanding is that > you can ask ATC for a 'heading' to fly direct to your IFR destination, > and they'd wink, nod, & give you the clearance. Many years ago, my > airline pilot Swift partner used to do that with a VFR LORAN receiver. > Wouldn't be the same thing as actually filing GPS-direct, but has the > same effect. > > You could be right about experimentals; I just haven't heard about it. > > Charlie > > On Thu, Jul 18, 2019 at 8:15 AM GLEN MATEJCEK > wrote: > > Hi Charlie et al- > It's been a while since I had my fingers in this stuff, but > isn't the requirement for certificated GPS only for terminal > operations? IIRC, experimental GPS is fine for en route, but > some other means is required for finding the runway. > > TIA > ________________________________________________________________________________
Date: Jul 18, 2019
Bingo! On Thu, Jul 18, 2019 at 11:10 AM Dick Tasker wrote: > dick(at)thetaskerfamily.com> > > Some of these sound useful to me. When are you going to port them to > Android? > > rampil wrote: > > > > > Greetings fellow Aviators! > > > > As a long time, intermittent contributor to this forum, I thought this > might be of interest: > > > > It has been quite a while since we started writing pilot apps for Apple > smartphones and iPads. > > Our family of apps for aviation has grown into 11 very handy and unique > tools for people who fly > > (or dream about it!). Here's a brief list of the Apps with links to the > App Store for more information > > and a sampling of screen shots to see the apps in action. > > > > The latest App is Runway Finder. This app was suggested by a buddy, a > retired Delta Captain who owns a Citabria. > > He does a lot of cross country flying and complained that it was hard t o > find a grass strip to use away from home base. > > This App maps out airports by runway surface and type (Turf, Paved, > Gravel, Water, Glider, and Heliport). > > Runway Finder has a built-in list of over 50,000 runways/airports world > wide. It is available on the Apple App store at: > > https://apps.apple.com/app/airport-runway-finder/id1471923024 > > > > > > Plane Registry. A FREE app to lookup US-Registered aircraft from the > live FAA database. > > https://apps.apple.com/app/airport-runway-finder/id1471923024 > > > > > > Local METARS. A very handy weather app for local conditions. Just ope n > the App and it will display > > the current METAR conditions at the closest reporting station. You get > the option to look out up to > > 100 miles and sort by bearing from your location. No more scrolling and > endless clicking to get the > > Wx you need for local flying. This app works with world wide reporting > stations. > > https://apps.apple.com/us/app/local-metars/id1150644548 > > > > We also have a stand-alone version of Local METARS for the Apple Watch > > https://apps.apple.com/app/local-metars-for-watch/id1447757207 > > > > > > > > Civil Twilight Calculator. CTC is a self-contained sunrise/sunset > calculator for use anywhere. > > No calling home to the Naval Observatory! It doesn=C3=A2=82=AC=84 =A2t need internet > access at all. Use it in > > flight! It can tell you accurately when Civil Twilight occurs where you > are, or at an airport > > around the world, on any day =C3=82=C2=B1 50 years. If you do have inte rnet, you > can give it a street > > address and see the calculated times. > > https://apps.apple.com/app/civil-twilight-calculator/id1163850946 > > > > We also have a stand-alone version for Apple Watch: > > https://apps.apple.com/app/civil-twilight-for-watch/id1448137376 > > > > > > Aviation Altimeter (aka avAltimeter). Not a GPS altimeter like most on > the App Store, but a True > > and Accurate barometric altimeter using the built-in sensors in iPhones > after iPhone 6, or iPads > > after the Mini-4. Has a Kollsman adjustment for ATC or METARs reports. > Looks and feels just like > > the steam gauge in your panel, but with Smart features: Density > Altitude, Oxygen Warning timer, > > and estimated aircraft Performance, auto-set at airport, etc. > > https://apps.apple.com/app/avaltimeter/id1120306812 > > > > The stand-alone version for the Apple Watch: > > https://apps.apple.com/app/aviation-altimeter-for-watch/id1434085253 > > > > > > VOR Navigator. Truly unique! A fully functional VOR and HSI navigator > (using GPS, not VHF). Includes > > all current VOR and NDB transmitting stations plus a number of recently > decommissioned ones. Also > > includes DME and ADF modes. The App will also home to all Large and > Medium (Commercial) airports. > > Check out the =C3=A2=82=AC=C5=93Add Lightning=C3=A2=82=AC mode f or the ADF for a true vintage > experience! This is a single hybrid > > App, which works on both iOS devices and the Apple Watch, each > independently from the other. > > https://apps.apple.com/app/vor-navigator/id1451733763 > > > > > > Crosswinds Live. Another very unique and handy App. Crosswinds Live > contains the runway diagrams for > > all registered airports world wide and will draw the current wind acros s > the runways. The wind information > > comes from the METAR station closest to the airport. Also computes the > headwind & crosswind components > > for flight planning. > > https://apps.apple.com/app/crosswinds-live/id1240254020 > > > > > > Sun Compass. Compass broken? Lost on a hike? If you can see the Sun o r > the Moon, this app for Apple Watch > > can help you out. The Watch does not have a compass built in, but, > using the GPS and some fancy astronomy > > calculations, this App will point to North, and show you your direction > of travel. For Watch only (iOS has builtin > > magnetic compass hardware) > > https://apps.apple.com/app/sun-compass-for-watch/id1448262474 > > > > Safe Flying! > > > > -------- > > Ira N224XS > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=490378#490378 > > > > > > > > > > > > > > > > > > > > > =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Jul 18, 2019
Hi Guys, At the moment, all the Aviametrix Apps are iOS or Apple Watch. I am well aware of the size of the Android market. There are three reasons: First, the Google Play store is infested with Patent trolls who extort Developers with frivolous lawsuits. This why you dont see XPlane Or ForeFlight on Android. Second, in the Android world there is a huge variety of hardware and Sensors to support, and a lot of hardware would not have what is needed. Third, we are a small development shop, concentrated on producing fine- tuned, quality apps. Splitting effort for mastery of a new programming Language, new operating system and UI interface, and new dev tools, would significantly reduce our ability to produce excellent products. Even cross-platform tools like Xamarin are no quick snap to master. Things may change in the future. If so, we will make it known. Fly safe! Enjoy AirVenture! -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490403#490403 ________________________________________________________________________________
Date: Jul 18, 2019
Greetings all, On a different but related subject, Assume a Garmin GNS 430W talking to a Dynon Skyview through an ARINC 429 de vice, and ADSB in and out What, if anything is necessary for the EAB builder to get it certified for IFR (enroute and approach) use as well as ADSB certification/verification?- -- or can we just go fly in the system?Thanks in advanceRich -----Original Message----- From: Kelly McMullen <kellym(at)aviating.com> Sent: Thu, Jul 18, 2019 11:21 am Subject: Re: AeroElectric-List: [OT] IFR-certified GPS Suggestions m> There are more benefits to an actual IFR certified GPS. If you are flying victor airways you are stuck with the published MEA. If you go off-route, i.e. direct, you are limited to the controller's MEA, which isn't published. IF you have an IFR GPS lower minimum altitudes are published, often 1-2000 ft lower here in the West. You can't file to navigate IFR by anything but certified equipment...which means VOR/localizer in the lower 48 states in most cases. In the flat lands you can easily ask for a vector on a specific heading and usually get it. IF your destination, or any alternate you need to divert to has a VOR/LOC/ILS, fine, but all the smaller airports are limited pretty much to GPS, or VOR with high minimums. Most approach and departure facilities have strict routing in and out of the area, that they need you on. Usually airways on departures, and unpublished arrival "gates" in between airways. So, most anything works enroute, but in the terminal environment, when ever the weather makes them busy, they don't have time for hand holding. On 7/18/2019 6:37 AM, Charlie England wrote: > I'm not IFR rated, and it's been weeks since I stayed in *any* hotel, so > I'm not qualified to answer that. But my layman's understanding is that > you can ask ATC for a 'heading' to fly direct to your IFR destination, > and they'd wink, nod, & give you the clearance. Many years ago, my > airline pilot Swift partner used to do that with a VFR LORAN receiver. > Wouldn't be the same thing as actually filing GPS-direct, but has the > same effect. > > You could be right about experimentals; I just haven't heard about it. > > Charlie > > On Thu, Jul 18, 2019 at 8:15 AM GLEN MATEJCEK > wrote: > >=C2- =C2- =C2- =C2- Hi Charlie et al- >=C2- =C2- =C2- =C2- It's been a while since I had my fingers in th is stuff, but >=C2- =C2- =C2- =C2- isn't the requirement for certificated GPS onl y for terminal >=C2- =C2- =C2- =C2- operations?=C2- IIRC, experimental GPS is fi ne for en route, but >=C2- =C2- =C2- =C2- some other means is required for finding the r unway. > >=C2- =C2- TIA > - S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Jul 18, 2019
If the "Operating Limitations" document that was issued to you by the FAA (DAR?) include the IFR approval, you can just go fly. If not, you have to petition for a new Operating Limitations" document to be issued that does include that wording. Odds are that the FAA will want a DAR sign-off. But given what you have in your plane, that should be just a formality. (Assuming, of course, you already meet the VFR Day/Night requirements as well, since those are prerequisites to IFR approval.) Jim Parker -------- Original Message -------- Subject: Re: AeroElectric-List: [OT] IFR-certified GPS Suggestions From: argoldman(at)aol.com Date: Thu, July 18, 2019 3:10 pm Greetings all, On a different but related subject, Assume a Garmin GNS 430W talking to a Dynon Skyview through an ARINC 429 device, and ADSB in and out What, if anything is necessary for the EAB builder to get it certified for IFR (enroute and approach) use as well as ADSB certification/verification?--- or can we just go fly in the system? Thanks in advance Rich -----Original Message----- From: Kelly McMullen <kellym(at)aviating.com> To: aeroelectric-list Sent: Thu, Jul 18, 2019 11:21 am Subject: Re: AeroElectric-List: [OT] IFR-certified GPS Suggestions There are more benefits to an actual IFR certified GPS. If you are flying victor airways you are stuck with the published MEA. If you go off-route, i.e. direct, you are limited to the controller's MEA, which isn't published. IF you have an IFR GPS lower minimum altitudes are published, often 1-2000 ft lower here in the West. You can't file to navigate IFR by anything but certified equipment...which means VOR/localizer in the lower 48 states in most cases. In the flat lands you can easily ask for a vector on a specific heading and usually get it. IF your destination, or any alternate you need to divert to has a VOR/LOC/ILS, fine, but all the smaller airports are limited pretty much to GPS, or VOR with high minimums. Most approach and departure facilities have strict routing in and out of the area, that they need you on. Usually airways on departures, and unpublished arrival "gates" in between airways. So, most anything works enroute, but in the terminal environment, when ever the weather makes them busy, they don't have time for hand holding. On 7/18/2019 6:37 AM, Charlie England wrote: > I'm not IFR rated, and it's been weeks since I stayed in *any* hotel, so > I'm not qualified to answer that. But my layman's understanding is that > you can ask ATC for a 'heading' to fly direct to your IFR destination, > and they'd wink, nod, & give you the clearance. Many years ago, my > airline pilot Swift partner used to do that with a VFR LORAN receiver. > Wouldn't be the same thing as actually filing GPS-direct, but has the > same effect. > > You could be right about experimentals; I just haven't heard about it. > > Charlie > > On Thu, Jul 18, 2019 at 8:15 AM GLEN MATEJCEK > wrote: > > Hi Charlie et al- > It's been a while since I had my fingers in this stuff, but > isn't the requirement for certificated GPS only for terminal > operations? IIRC, experimental GPS is fine for en route, but > some other means is required for finding the runway. > > TIA > ________________________________________________________________________________
Date: Jul 18, 2019
Thanks, Somewhere in the back of my mind is that there is a procedure that you have to go through to verify that the adsb is operating correctly. Pla ne not flying yet-- almost done (15 years). Rich -----Original Message----- From: jim <jim(at)PoogieBearRanch.com> Sent: Thu, Jul 18, 2019 4:22 pm Subject: RE: AeroElectric-List: [OT] IFR-certified GPS Suggestions If the "Operating Limitations" document that was issued to you by the FAA (DAR?) include the IFR approval, you can just go fly.=C2- If not, you have to petition for a new Operating Limitations" document to be issued that does include that wording.=C2- Odds are that the FAA will want a DAR sign-off.=C2- But given what you ha ve in your plane, that should be just a formality.=C2- (Assuming, of course, you already meet the VFR Day/Night requirements as well, since those are prerequisites to IFR approval.) Jim Parker -------- Original Message -------- Subject: Re: AeroElectric-List: [OT] IFR-certified GPS Suggestions From: argoldman(at)aol.com Date: Thu, July 18, 2019 3:10 pm =C2- Greetings all, On a different but related subject, Assume a Garmin GNS 430W talking to a Dynon Skyview through an ARINC 429 device, and ADSB in and out What, if anything is necessary for the EAB builder to get it certified for IFR (enroute and approach) use as well as ADSB certification/verification?--- or can we just go fly in the system? Thanks in advance Rich -----Original Message----- From: Kelly McMullen <kellym(at)aviating.com> To: aeroelectric-list Sent: Thu, Jul 18, 2019 11:21 am Subject: Re: AeroElectric-List: [OT] IFR-certified GPS Suggestions There are more benefits to an actual IFR certified GPS. If you are flying victor airways you are stuck with the published MEA. If you go off-route, i.e. direct, you are limited to the controller's MEA, which isn't published. IF you have an IFR GPS lower minimum altitudes are published, often 1-2000 ft lower here in the West. You can't file to navigate IFR by anything but certified equipment...which means VOR/localizer in the lower 48 states in most cases. In the flat lands you can easily ask for a vector on a specific heading and usually get it. IF your destination, or any alternate you need to divert to has a VOR/LOC/ILS, fine, but all the smaller airports are limited pretty much to GPS, or VOR with high minimums. Most approach and departure facilities have strict routing in and out of the area, that they need you on. Usually airways on departures, and unpublished arrival "gates" in between airways. So, most anything works enroute, but in the terminal environment, when ever the weather makes them busy, they don't have time for hand holding. On 7/18/2019 6:37 AM, Charlie England wrote: > I'm not IFR rated, and it's been weeks since I stayed in *any* hotel, so > I'm not qualified to answer that. But my layman's understanding is that > you can ask ATC for a 'heading' to fly direct to your IFR destination, > and they'd wink, nod, & give you the clearance. Many years ago, my > airline pilot Swift partner used to do that with a VFR LORAN receiver. > Wouldn't be the same thing as actually filing GPS-direct, but has the > same effect. > > You could be right about experimentals; I just haven't heard about it. > > Charlie > > On Thu, Jul 18, 2019 at 8:15 AM GLEN MATEJCEK > wrote: > >=C2- =C2- =C2- =C2- Hi Charlie et al- >=C2- =C2- =C2- =C2- It's been a while since I had my fingers in th is stuff, but >=C2- =C2- =C2- =C2- isn't the requirement for certificated GPS onl y for terminal >=C2- =C2- =C2- =C2- operations?=C2- IIRC, experimental GPS is fi ne for en route, but >=C2- =C2- =C2- =C2- some other means is required for finding the r unway. > >=C2- =C2- TIA > - S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Jul 18, 2019
This comes up from time to time. Most operating limitations in the past 15 years require the 91.205(b) Day VFR equipment, and then state that to fly at night VFR you must meet 91.205(c) and to fly IFR must meet 91.205 (d) requirements. Of course you have to altimeter certified to IFR standards and static system that meets the leak down requirements. Everything else is dependent on the airspace you will fly in, what ground nav equipment you will utilize, etc. GPS certification is by the manufacturer and the manufacturer's instructions. Essentially, there is no airframe certification requirement, it is the certification of required equipment that is to be installed. ADSB is not an IFR requirement, it is an airspace requirement. You have to install ADS-B equipment that meets the performance requirements of the TSO. Certification is same as transponder, plus it is wise to get the email report that it is working correctly. As for sign off....none required, but because some of the equipment install may be considered "major" under your operating limitations, you may need to place a call to the FSDO to get how many hours they want you to do Phase I testing of the changed equipment. You will spend more than they required learning any IFR GPS. On 7/18/2019 1:57 PM, jim(at)PoogieBearRanch.com wrote: > > If the "Operating Limitations" document that was issued to you by the > FAA (DAR?) include the IFR approval, you can just go fly. If not, you > have to petition for a new Operating Limitations" document to be issued > that does include that wording. > > Odds are that the FAA will want a DAR sign-off. But given what you have > in your plane, that should be just a formality. (Assuming, of course, > you already meet the VFR Day/Night requirements as well, since those are > prerequisites to IFR approval.) > > Jim Parker > > > > -------- Original Message -------- > Subject: Re: AeroElectric-List: [OT] IFR-certified GPS Suggestions > From: argoldman(at)aol.com > Date: Thu, July 18, 2019 3:10 pm > To: aeroelectric-list(at)matronics.com > > Greetings all, > > > On a different but related subject, > > > > Assume a Garmin GNS 430W talking to a Dynon Skyview through an ARINC 429 > device, and ADSB in and out > > What, if anything is necessary for the EAB builder to get it certified > for IFR (enroute and approach) use as well as ADSB > certification/verification?--- or can we just go fly in the system? > Thanks in advance > Rich > > > > ________________________________________________________________________________
Date: Jul 18, 2019
It depends....if you are talking a new 1090ES transponder/ADSB, or adding a UAT ADSB to existing currently certified transponder. There is certification of any transponder, at install and every 2 years. Doesn't hurt anything but your wallet to have avionics shop do a ramp check and certify the transponder/encoder for VFR. ADSB is separate. You need to ensure that all of the parameter programing is correct, for tail number, aircraft size and speed. Then you fly in "rule airspace" which can be under/over Class C or Class B "mode C 3o mile radius" or just go up to 10,000 feet most anywhere not real close to mountains. Then request a report via email. You don't have to do it, but if you don't, and something isn't right, you will get a letter telling you that you aren't meeting requirements. On 7/18/2019 3:48 PM, argoldman(at)aol.com wrote: > Thanks, Somewhere in the back of my mind is that there is a procedure > that you have to go through to verify that the adsb is operating > correctly. Plane not flying yet-- almost done (15 years)Disappointed. > > Rich ________________________________________________________________________________
Date: Jul 18, 2019
Subject: Re: ADS-B Preflight Requirements updated for GA
Correct me if I'm wrong, I believe WAAS is a type of SBAS (Satellite Based Augmentation System), and reading AC-90-114a already says this: c. GPS Performance Prediction. Operators flying aircraft equipped with SBAS (TSO-C145 or TSO-C146) receivers do not need to conduct a preflight availability prediction because the FAA will issue a NOTAM whenever SBAS performance is not adequate. If TSO-C129() or TSO-C196() equipment is used for ADS-B Out, NACp and NIC availability prediction should be performed for the intended route of flight (route and time) using available GPS satellite information. So, my interpretation is: You need: 1. =9CAll available information concerning flight=9D (=C2=A7 91 .103) (the standard catch-all) 2. Check NOTAMS for SBAS outages. -Jeff- On Wed, Jul 17, 2019 at 9:23 AM Harley Dixon wrote: > Just saw this on AVWeb... > > The FAA will issue a Notam > > on Thursday that will essentially exempt general aviation aircraft > operators from an ADS-B preflight requirement when the ADS-B mandate kick s > in next January. The Notam specifically exempts ADS-B Out transmitters th at > use WAAS GPS receivers as a position source from the preflight requiremen t > described in an FAA policy statement that was released earlier this month . > The Notam reads: =9CIt is not necessary for operators of aircraft e quipped > with the Wide Area Augmentation System (WAAS) (TSO=88=92C145 or TSO =88=92C146) > receivers to conduct a preflight availability prediction.=9D > > Garmin spokesman Bill Stone told *AVweb* the preflight requirement was > always intended for airliners, most of which have early-generation GPS > systems that are not as reliably precise as those with WAAS. All ADS-B > units certified for GA aircraft for the 2020 mandate must use a WAAS GPS > receiver as a position source. =9CThere are currently zero non-WAAS based > ADS-B Out GPS solutions for general aviation aircraft,=9D he said. =9CFor GA, > it=99s a non-issue.=9D Stone said he suspects the WAAS exempt ion got lost in > the extensive vetting process that policy statements like the preflight > requirements included in the recent Federal Register Notice go through. T he > original intent of the policy statement was to codify exemptions from > sanctions for airlines when GPS signals degrade after they=99ve don e the > preflight checks and the subsequent lack of compliance is beyond their > control. > > Harley > ________________________________________________________________________________
Subject: Re: Z-13/8 inquiry
Date: Jul 19, 2019
[quote="nuckolls.bob(at)aeroelect"]At 05:41 AM 11/15/2017, you wrote: > > > This brings up another design goal for making direct > connections to batteries. The legacy design conventions > in type certified aircraft called for always hot feeders to > be protected at no more than 5A. The idea was to limit > the battery's ability to start fires in the event of > a landing that was really hard to walk away from. > > Bob . . . My Load Analysis looks like the electrical system will have less than 10A draw. 5.4A continuous, 10.5A when the Fuel Pump is on. So, simplification, reliability and weight reduction would demand dual buses with equal loads, and ditching the Battery Master Relay. Is that unconventional idea a bad idea? What am i not seeing? -------- Brooks Cone Bearhawk Patrol Kit Build Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490421#490421 ________________________________________________________________________________
Date: Jul 19, 2019
The pilot needs a way to quickly shut off all sources of electrical power at the source. This is important in case of smoke or fire or an imminent forced landing. A battery contactor will fulfill that need. A battery contactor can also be shut off if the starter contactor welds itself shut. Each circuit should have its own fuse. If a fuse blows, only one load will quit working. Dual buses are more complicated than a single bus -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490423#490423 ________________________________________________________________________________
Date: Jul 19, 2019
A battery contactor allows for easy connection to a battery charger, whereby the battery charging current is limited to the battery, without powering the bus/systems. It also allows for easy connection to a ground power source to power the bus/systems, without subjecting the battery to the ground power. On Fri, Jul 19, 2019 at 11:37 AM user9253 wrote: > > The pilot needs a way to quickly shut off all sources of electrical power > at the source. > This is important in case of smoke or fire or an imminent forced landing. > A battery contactor will fulfill that need. > A battery contactor can also be shut off if the starter contactor welds > itself shut. > Each circuit should have its own fuse. If a fuse blows, only one load > will quit working. > Dual buses are more complicated than a single bus > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=490423#490423 > > ________________________________________________________________________________
Date: Jul 20, 2019
argoldman(at)aol.com wrote: > Thanks, Somewhere in the back of my mind is that there is a procedure that you have to go through to verify that the adsb is operating correctly. Plane not flying yet-- almost done (15 years). > -- I used this to verify my ADS-B install. https://adsbperformance.faa.gov/paprrequest.aspx Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490436#490436 ________________________________________________________________________________
Date: Jul 20, 2019
Subject: IFR-certified GPS Suggestions
> > That's an interesting evolution. It used to be that the only bit of > equipment on an experimental that was required to have a TSO was GPS for > terminal ops. I've spent a little time searching, and can't find any such > reference anymore. The AIM does indeed make a blanket statement with > regard to having TSO'd GPS, which is curious as the AIM isn't regulatory. > (Of course, if one finds themselves in front of an administrative law judge > due to nonconformity with the AIM one will likely be in a world of hurt, > but that's a different topic...). So, I wonder if all the folks with > non-TSO'd GPS are grandfathered somehow, or just SOL... > > ________________________________________________________________________________
Date: Jul 20, 2019
Subject: ELT antenna, BALUNS and stuff
Got the VNA back up and running. Did some quick scans of a couple of BALUN configurations and got some amazing (or should I say consternating) results. At first blush it seems that conventional wisdom may have failed us. Need to repeat the experiments with more rigorous attention to process and calibration . . . watch this space. Got the elements fabricated for a Jim Wier ELT antenna. I'll be assembling those on a test fixture with opportunity to explore BALUN configurations . . . Bob . . . ________________________________________________________________________________
Subject: Re: IFR-certified GPS Suggestions
Date: Jul 20, 2019
There is an advisory circular on GPS install. I forget the first two digits, after the dash its 138a, which for most purposes can be considered regulatory. While you could get away with most anything if you declare an emergency, I wouldn't make a habit of that. I don't believe the FAA has ever "approved" of using anything but a TSO GPS. I believe you also have to have a TSO approved ELT unless you meet the exceptions like single seat. On 7/20/2019 6:48 AM, GLEN MATEJCEK wrote: > That's an interesting evolution. It used to be that the only bit of > equipment on an experimental that was required to have a TSO was GPS > for terminal ops. I've spent a little time searching, and can't > find any such reference anymore. The AIM does indeed make a blanket > statement with regard to having TSO'd GPS, which is curious as the > AIM isn't regulatory. (Of course, if one finds themselves in front > of an administrative law judge due to nonconformity with the AIM one > will likely be in a world of hurt, but that's a different > topic...). So, I wonder if all the folks with non-TSO'd GPS are > grandfathered somehow, or just SOL... > ________________________________________________________________________________
Subject: ADS-B - Garmin GDL-82 installation
Date: Jul 20, 2019
In my airplane there are at least 3 options for grounding the GDL-82: 1. Grounding to the avionics box that contains the electrical bus, the radio and the transponder. The box is attached with screws to lugs welded to the airplane tubular frame. Paint was removed where necessary to ensure good electrical continuity to the frame. 2. Grounding to a single screw on the firewall to which the radio, the transponder and the encoder are already grounded. 3. Grounding to a new screw on the firewall in the general area where the above mentioned ground screw is. What would be the recommended solution? Right now (before installing the GDL-82) there is some background noise in the radio, transmitting and receiving. I am concerned about the GDL-82 working properly and not making the radio worse. Thanks Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490457#490457 ________________________________________________________________________________
Date: Jul 20, 2019
Subject: Re: ADS-B - Garmin GDL-82 installation
I grounded mine to the common forest of tabs on the firewall. All tested well on ground and in the NYC airspace. Good luck. Hal Benjamin RV4 Sent from my iPad > On Jul 20, 2019, at 9:10 PM, Argonaut36 wrote: > > > In my airplane there are at least 3 options for grounding the GDL-82: > 1. Grounding to the avionics box that contains the electrical bus, the radio and the transponder. The box is attached with screws to lugs welded to the airplane tubular frame. Paint was removed where necessary to ensure good electrical continuity to the frame. > 2. Grounding to a single screw on the firewall to which the radio, the transponder and the encoder are already grounded. > 3. Grounding to a new screw on the firewall in the general area where the above mentioned ground screw is. > What would be the recommended solution? Right now (before installing the GDL-82) there is some background noise in the radio, transmitting and receiving. I am concerned about the GDL-82 working properly and not making the radio worse. > Thanks > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=490457#490457 > > > > > > > > > ________________________________________________________________________________
Subject: Re: Ray Allen trim servo/control: actual wiring
schematic neede
Date: Jul 21, 2019
On 7/17/2019 11:16 AM, Eric M. Jones wrote: > > Hi Charlie, > > I have a bunch and have posted some over the years. Here is the Trim box. > > Eric > > -------- > Eric M. Jones > www.PerihelionDesign.com > 113 Brentwood Drive > Southbridge, MA 01550 > (508) 764-2072 > emjones(at)charter.net > Hi Eric, Sorry to be so long in replying. Thanks for the link, and I really like the conversion to true servo action in your device. But what I was really looking for was *internal* schematics for the Ray Allen devices. One of Bob's drawings has the 'guts' of the servo shown, but no joy on the other products. I'll reply to my earlier post to detail what I found during troubleshooting. Charlie --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Subject: Re: Ray Allen trim servo/control: actual wiring schematic
needed (folowup)
Date: Jul 21, 2019
On 7/16/2019 12:00 PM, Charlie England wrote: > Anyone out there with an actual schematic of the Ray Allen relay > decks, switches, stick switches, etc? Their on-line 'diagrams' are > typical consumer-facing 'white boxes' for each component, showing > nothing of how the contacts in the device are tied to the various > colored wires. I can spend a day or two puzzling out how the internals > are connected, but I'd love to avoid the waste of time. > > The guys at RA were less than worthless, telling me that it would be > 'dangerous' to show the consumer (the people actually installing their > stuff) what was goingon inside each box on their diagrams. Gotta say, > if there were an alternative, I'd just replace the stuff so I wouldn't > have to deal with them. > > Problem: previous owner(s) have panel mounted rockers & indicators for > pitch/roll, and a stick grip with the 4 separate buttons for > pitch/roll. The rockers work. The stick buttons will make the relays > click, but don't control the trim motors. > > As I said, I can puzzle it out, but I'd like to *start* with > schematics of the devices, instead of having to create them. > > Thanks, > > Charlie Well, I found my 'issue', so I thought I'd detail it here for posterity. Here's the 1st sentence from the Ray Allen website description of their RS2 rocker switch: *This switch is designed for use with Ray Allen trim systems. It has a very positive snap action in two directions and returns to a _center off_ position. *(underline added by me) **Notethat thisis NOT correct. What they *don't mention* in the description is that the housing actually contains a pair of switches, and when the switch is in what they deceptively call the 'center off' position, it actually shorts the pair of wires that would normally feed the trim motor. The legitimate reason is to stop motor 'coasting', but failure to document that they did this, in both the description and in their wiring diagrams, leaves one open to wasting a half day or more just sorting out what's happening. One of RA's drawings shows a pair of diodes in series with the RS2 switch wires, but no explanation of why they're there. They're there to keep the switch from powering *both* relays in the RA relay block, if a 2nd control is installed, as with stick-mounted pushbuttons or hat-switch. That's what was happening with my installation. The builder failed to install the diodes, and when a stick trim button was pressed, the relay block would click but the servo wouldn't move. Both relays inside the relay block were activating (undetectable by 'ear'), which meant that the motor saw no voltage differential. I did have a couple of very pointed discussions with the RA folks. The 1st (before I found my problem) was to request devices' internal schematics, and the response was that it would be 'dangerous' (for RA, obviously) to give end-users 'too much information'. My 2nd, after discovering the RS2 switch issue, was with a different person, who did apologize and said that they had plans to update the website and their docs. When I asked the 2nd guy to tell me, tech-to-tech (I've had a couple of prior lives as an electronics tech), what 'center off' meant, I got what can be described as a 'pregnant pause'. Hey Bob, I know the AEC book is primarily about power distribution, but maybe you should beat us over the head at the beginning and end of every chapter, reminding us to *document* our work. The builder of my a/c had a printed copy of AEC in the boxes of paperwork, and did have a few hand-drawn variations on some of the Z-figures, but apparently failed to document anything beyond power feeds. Charlie ** --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
neede
Date: Jul 21, 2019
Sorry Charlie...the Trim box is on the last page. I couldn't find my file of the trim box alone. Attached is my file of the trim box and the bar graph. I have some others if I can find them...I had all my CAD files on a 32 GB flash drive for safety and ran over it with my office chair. Nothing was recoverable so I am checking old HDs. and backups. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490468#490468 Attachments: http://forums.matronics.com//files/rac_trim_box_and_bar_graph_166.pdf ________________________________________________________________________________
schematic neede
Date: Jul 21, 2019
On 7/21/2019 1:28 PM, Eric M. Jones wrote: > > Sorry Charlie...the Trim box is on the last page. I couldn't find my file of the trim box alone. > > Attached is my file of the trim box and the bar graph. I have some others if I can find them...I had all my CAD files on a 32 GB flash drive for safety and ran over it with my office chair. Nothing was recoverable so I am checking old HDs. and backups. > > -------- > Eric M. Jones > www.PerihelionDesign.com > 113 Brentwood Drive > Southbridge, MA 01550 > (508) 764-2072 > emjones(at)charter.net > Thanks, Eric. Impressive what you get for the money at RA, isn't it? At $119.00 for that display, it works out to about $109.00 for the little box & the label set, after buying the display, pc board, & misc components. I started playing with LM3914s about 40 years ago, before you could buy the 10 segment displays for 50 cents. Please don't do any more digging just for me; I've got my problem licked. Charlie --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
schematic neede
Date: Jul 21, 2019
Here is what I have for the display module. It is the LM3914 data sheet marked up with the additional components in the module. The part labeled "sensor" is the Ray Allen position sensor that works with the display. Dick Tasker Charlie England wrote: > > On 7/17/2019 11:16 AM, Eric M. Jones wrote: >> >> Hi Charlie, >> >> I have a bunch and have posted some over the years. Here is the Trim box. >> >> Eric >> >> -------- >> Eric M. Jones >> www.PerihelionDesign.com >> 113 Brentwood Drive >> Southbridge, MA 01550 >> (508) 764-2072 >> emjones(at)charter.net >> > Hi Eric, > > Sorry to be so long in replying. Thanks for the link, and I really like the conversion to true servo action in your device. But what I was really looking for was *internal* schematics for the Ray > Allen devices. One of Bob's drawings has the 'guts' of the servo shown, but no joy on the other products. > > I'll reply to my earlier post to detail what I found during troubleshooting. > > Charlie > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus > > ________________________________________________________________________________
schematic neede
Date: Jul 21, 2019
Thanks, Dick; got it. My problem was actually the RS2 rocker switch. Charlie On 7/21/2019 7:43 PM, Dick Tasker wrote: > Here is what I have for the display module. It is the LM3914 data > sheet marked up with the additional components in the module. The > part labeled "sensor" is the Ray Allen position sensor that works with > the display. > > Dick Tasker > > Charlie England wrote: >> >> >> On 7/17/2019 11:16 AM, Eric M. Jones wrote: >>> >>> >>> Hi Charlie, >>> >>> I have a bunch and have posted some over the years. Here is the Trim >>> box. >>> >>> Eric >>> >>> -------- >>> Eric M. Jones >>> www.PerihelionDesign.com >>> 113 Brentwood Drive >>> Southbridge, MA 01550 >>> (508) 764-2072 >>> emjones(at)charter.net >>> >> Hi Eric, >> >> Sorry to be so long in replying. Thanks for the link, and I really >> like the conversion to true servo action in your device. But what I >> was really looking for was *internal* schematics for the Ray Allen >> devices. One of Bob's drawings has the 'guts' of the servo shown, but >> no joy on the other products. >> >> I'll reply to my earlier post to detail what I found during >> troubleshooting. >> >> Charlie >> >> --- >> This email has been checked for viruses by Avast antivirus software. >> https://www.avast.com/antivirus >> >> >> >> >> > ________________________________________________________________________________
Date: Jul 22, 2019
Subject: connector identification
Can anyone name the connector in the attached picture? It is on my Optimate TM471 battery charger. The charger comes with two pigtails that can be plugged in (one with ring terminals, one with spring clamps). I wired the ring terminal pigtail to my airframe to allow for easy connection of the charger, without removing the battery. I would like to utilize the spring clamp pigtail for easy connection of a ground power source, but I need the matching connector to set up my power source. Thanks. Ken ________________________________________________________________________________
Date: Jul 21, 2019
schematic needed (folowup) > >Hey Bob, I know the AEC book is primarily about power distribution, >but maybe you should beat us over the head at the beginning and end >of every chapter, reminding us to *document* our work. The builder >of my a/c had a printed copy of AEC in the boxes of paperwork, and >did have a few hand-drawn variations on some of the Z-figures, but >apparently failed to document anything beyond power feeds. Used to have a segment in the weekend seminars on that subject . . . we've talked about it over the years here on List as well. Perhaps and article for one of the fly-rags would be in order as well as a Shop-Notes on AE.com . . . I'll put that in the hopper. Bob . . . ________________________________________________________________________________
Subject: Re: connector identification
Date: Jul 22, 2019
On 7/22/2019 10:56 AM, Ken Ryan wrote: > Can anyone name the connector in the attached picture? It is on my > Optimate TM471 battery charger. The charger comes with two pigtails > that can be plugged in (one with ring terminals, one with spring > clamps). I wired the ring terminal pigtail to my airframe to allow for > easy connection of the charger, without removing the battery. I would > like to utilize the spring clamp pigtail for easy connection of a > ground power source, but I need the matching connector to set up my > power source. Thanks. Ken The individual terminal looks like what's in typical tail/brake light connectors for small trailers. I googled 'trailer connector' & one of the 1st hits was this: https://www.delcity.net/store/2-Way-Flat-Connector/p_8873.h_84862.r_IF1003?mkwid=sGlFIIm7H&crid=38094426869&mp_kw=&mp_mt=&gclid=Cj0KCQjwvdXpBRCoARIsAMJSKqIW44OSVL3xnDBzqOwrt2abA-SpQW5cZU6ziMvTlMOP2wCO604p8awaAq2kEALw_wcB Anyway, that's where I'd start looking. Charlie --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jul 22, 2019
Thanks Charlie. We've got a couple of trailer supply shops so I will look there. On Mon, Jul 22, 2019 at 8:25 AM Charlie England wrote: > ceengland7(at)gmail.com> > > On 7/22/2019 10:56 AM, Ken Ryan wrote: > > Can anyone name the connector in the attached picture? It is on my > > Optimate TM471 battery charger. The charger comes with two pigtails > > that can be plugged in (one with ring terminals, one with spring > > clamps). I wired the ring terminal pigtail to my airframe to allow for > > easy connection of the charger, without removing the battery. I would > > like to utilize the spring clamp pigtail for easy connection of a > > ground power source, but I need the matching connector to set up my > > power source. Thanks. Ken > The individual terminal looks like what's in typical tail/brake light > connectors for small trailers. I googled 'trailer connector' & one of > the 1st hits was this: > > https://www.delcity.net/store/2-Way-Flat-Connector/p_8873.h_84862.r_IF1003?mkwid=sGlFIIm7H&crid=38094426869&mp_kw=&mp_mt=&gclid=Cj0KCQjwvdXpBRCoARIsAMJSKqIW44OSVL3xnDBzqOwrt2abA-SpQW5cZU6ziMvTlMOP2wCO604p8awaAq2kEALw_wcB > > Anyway, that's where I'd start looking. > > Charlie > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus > > ________________________________________________________________________________
Date: Jul 22, 2019
On 7/22/2019 11:31 AM, Ken Ryan wrote: > Thanks Charlie. We've got a couple of trailer supply shops so I will > look there. > > On Mon, Jul 22, 2019 at 8:25 AM Charlie England > wrote: > > > > > On 7/22/2019 10:56 AM, Ken Ryan wrote: > > Can anyone name the connector in the attached picture? It is on my > > Optimate TM471 battery charger. The charger comes with two pigtails > > that can be plugged in (one with ring terminals, one with spring > > clamps). I wired the ring terminal pigtail to my airframe to > allow for > > easy connection of the charger, without removing the battery. I > would > > like to utilize the spring clamp pigtail for easy connection of a > > ground power source, but I need the matching connector to set up my > > power source. Thanks. Ken > The individual terminal looks like what's in typical tail/brake light > connectors for small trailers. I googled 'trailer connector' & one of > the 1st hits was this: > https://www.delcity.net/store/2-Way-Flat-Connector/p_8873.h_84862.r_IF1003?mkwid=sGlFIIm7H&crid=38094426869&mp_kw=&mp_mt=&gclid=Cj0KCQjwvdXpBRCoARIsAMJSKqIW44OSVL3xnDBzqOwrt2abA-SpQW5cZU6ziMvTlMOP2wCO604p8awaAq2kEALw_wcB > > Anyway, that's where I'd start looking. > > Charlie > Got a Prime account? https://www.amazon.com/Hopkins-47965-2-Pole-Flat-Extension/dp/B0002Q80RW --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jul 22, 2019
If this has been posted before. Forgive me Have you considered cutting that connector off and substitute a different one more comparable with your needs? Rich Sent from my iPhone > On Jul 22, 2019, at 10:56 AM, Ken Ryan wrote: > > Can anyone name the connector in the attached picture? It is on my Optimate TM471 battery charger. The charger comes with two pigtails that can be plugged in (one with ring terminals, one with spring clamps). I wired the ring terminal pigtail to my airframe to allow for easy connection of the charger, without removing the battery. I would like to utilize the spring clamp pigtail for easy connection of a ground power source, but I need the matching connector to set up my power source. Thanks. Ken > ________________________________________________________________________________
From: "John Ciolino" <JohnCiolino(at)carolina.rr.com>
Date: Jul 22, 2019
Ken, That connector is called an SAE connector. You can order on Amazon or local trailer shops may have them. John Ciolino Bearhawk Patrol From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ken Ryan Sent: Monday, July 22, 2019 11:57 AM Subject: AeroElectric-List: connector identification Can anyone name the connector in the attached picture? It is on my Optimate TM471 battery charger. The charger comes with two pigtails that can be plugged in (one with ring terminals, one with spring clamps). I wired the ring terminal pigtail to my airframe to allow for easy connection of the charger, without removing the battery. I would like to utilize the spring clamp pigtail for easy connection of a ground power source, but I need the matching connector to set up my power source. Thanks. Ken ________________________________________________________________________________
Date: Jul 22, 2019
Search SAE 2 pin connector on Amazon you should find them for about $2 each if you order a 5 or 6 pack. Deems ________________________________________ From: owner-aeroelectric-list-server(at)matronics.com <owner-aeroelectric-list-server(at)matronics.com> on behalf of Ken Ryan Sent: Monday, July 22, 2019 11:56 AM Subject: AeroElectric-List: connector identification Can anyone name the connector in the attached picture? It is on my Optimate TM471 battery charger. The charger comes with two pigtails that can be plugged in (one with ring terminals, one with spring clamps). I wired the ring terminal pigtail to my airframe to allow for easy connection of the charger, without removing the battery. I would like to utilize the spring clamp pigtail for easy connection of a ground power source, but I need the matching connector to set up my power source. Thanks. Ken ________________________________________________________________________________
Date: Jul 22, 2019
Thanks! On Mon, Jul 22, 2019, 11:19 John Ciolino wrote: > Ken, > > > That connector is called an SAE connector. You can order on Amazon or > local trailer shops may have them. > > > John Ciolino > > Bearhawk Patrol > > > *From:* owner-aeroelectric-list-server(at)matronics.com [mailto: > owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of *Ken Ryan > *Sent:* Monday, July 22, 2019 11:57 AM > *To:* aeroelectric-list(at)matronics.com > *Subject:* AeroElectric-List: connector identification > > > Can anyone name the connector in the attached picture? It is on my > Optimate TM471 battery charger. The charger comes with two pigtails that > can be plugged in (one with ring terminals, one with spring clamps). I > wired the ring terminal pigtail to my airframe to allow for easy connection > of the charger, without removing the battery. I would like to utilize the > spring clamp pigtail for easy connection of a ground power source, but I > need the matching connector to set up my power source. Thanks. Ken > ________________________________________________________________________________
Date: Jul 23, 2019
E-bay Sent from my iPad ----x--O--x---- > On 22 Jul 2019, at 8:09 pm, John Ciolino wro te: > > Ken, > > That connector is called an SAE connector. You can order on Amazon or loca l trailer shops may have them. > > John Ciolino > Bearhawk Patrol > > From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelect ric-list-server(at)matronics.com] On Behalf Of Ken Ryan > Sent: Monday, July 22, 2019 11:57 AM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: connector identification > > Can anyone name the connector in the attached picture? It is on my Optimat e TM471 battery charger. The charger comes with two pigtails that can be plu gged in (one with ring terminals, one with spring clamps). I wired the ring t erminal pigtail to my airframe to allow for easy connection of the charger, w ithout removing the battery. I would like to utilize the spring clamp pigtai l for easy connection of a ground power source, but I need the matching conn ector to set up my power source. Thanks. Ken ________________________________________________________________________________
Date: Jul 23, 2019
Hi Kelley- sorry for the delay, but the trip to OSH and related wx issues have had me offline for a bit. *SNIP* I don't believe the FAA has ever "approved" of using anything but a TSO GPS. I believe you also have to have a TSO approved ELT unless you meet the exceptions like single seat. Believe it or not, such is the case. Right off the top of my head Blue Mountain comes to mind, among others. All non-certified and all used IFR. WRT the ELT, the salient quote in the reg is "meets the requirements of TSO -C91". It doesn't say has a TSO sticker on it. This is a fine legal point, similar to the part about experimentals having to address AD's, not comply with them. Now, I certainly wouldn't recommend scratch building a radio and expecting a fed to take your word for it's suitability, but the legal principle still stands. All of this was brought to my attention at the time by the local mx fed that handled homebuilts. Unfortunately, there is as much confusion on these matters within the ranks of the feds as there is at the average fly in breakfast, but a quick call to EAA government relations will likely get you a pretty quick and concise answer. Especially when it comes to recent developments, as the FAA has liaised with EAA on regulatory issues affecting homebuilts. ics.com> wrote: > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete AeroElectric-List Digest can also be found in either of > the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the AeroElectric-List Digest and can be viewed with a generic text > editor > such as Notepad or with a web browser. > > HTML Version: > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 19-07-20&Archive=AeroElectric > > Text Version: > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 19-07-20&Archive=AeroElectric > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > AeroElectric-List Digest Archive > --- > Total Messages Posted Sat 07/20/19: 6 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 02:26 AM - Re: [OT] IFR-certified GPS Suggestions (donjohnston) > 2. 06:50 AM - IFR-certified GPS Suggestions (GLEN MATEJCEK) > 3. 09:25 AM - ELT antenna, BALUNS and stuff (Robert L. Nuckolls, III) > 4. 01:31 PM - Re: IFR-certified GPS Suggestions (Kelly McMullen) > 5. 06:12 PM - ADS-B - Garmin GDL-82 installation (Argonaut36) > 6. 07:53 PM - Re: ADS-B - Garmin GDL-82 installation (Hal Benjamin) > > > ________________________________ Message 1 > _____________________________________ > > > Subject: AeroElectric-List: Re: [OT] IFR-certified GPS Suggestions > From: "donjohnston" <don@velocity-xl.com> > > > argoldman(at)aol.com wrote: > > Thanks, Somewhere in the back of my mind is that there is a procedure > that you > have to go through to verify that the adsb is operating correctly. Plane > not > flying yet-- almost done (15 years). > > -- > > > I used this to verify my ADS-B install. > > https://adsbperformance.faa.gov/paprrequest.aspx > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=490436#490436 > > > ________________________________ Message 2 > _____________________________________ > > > From: GLEN MATEJCEK <fly4grins(at)gmail.com> > Subject: AeroElectric-List: IFR-certified GPS Suggestions > > > > > That's an interesting evolution. It used to be that the only bit of > > equipment on an experimental that was required to have a TSO was GPS for > > terminal ops. I've spent a little time searching, and can't find any > such > > reference anymore. The AIM does indeed make a blanket statement with > > regard to having TSO'd GPS, which is curious as the AIM isn't regulatory. > > (Of course, if one finds themselves in front of an administrative law > judge > > due to nonconformity with the AIM one will likely be in a world of hurt, > > but that's a different topic...). So, I wonder if all the folks with > > non-TSO'd GPS are grandfathered somehow, or just SOL... > > > > > > ________________________________ Message 3 > _____________________________________ > > > From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> > Subject: AeroElectric-List: ELT antenna, BALUNS and stuff > > > Got the VNA back up and running. Did some > quick scans of a couple of BALUN configurations > and got some amazing (or should I say consternating) > results. At first blush it seems that conventional > wisdom may have failed us. > > Need to repeat the experiments with more rigorous > attention to process and calibration . . . > watch this space. > > Got the elements fabricated for a Jim Wier > ELT antenna. I'll be assembling those on > a test fixture with opportunity to explore > BALUN configurations . . . > > > Bob . . . > > > ________________________________ Message 4 > _____________________________________ > > > Subject: Re: AeroElectric-List: IFR-certified GPS Suggestions > From: Kelly McMullen <kellym(at)aviating.com> > > > There is an advisory circular on GPS install. I forget the first two > digits, after the dash its 138a, which for most purposes can be > considered regulatory. While you could get away with most anything if > you declare an emergency, I wouldn't make a habit of that. > I don't believe the FAA has ever "approved" of using anything but a TSO > GPS. I believe you also have to have a TSO approved ELT unless you meet > the exceptions like single seat. > > On 7/20/2019 6:48 AM, GLEN MATEJCEK wrote: > > That's an interesting evolution. It used to be that the only bit of > > equipment on an experimental that was required to have a TSO was GPS > > for terminal ops. I've spent a little time searching, and can't > > find any such reference anymore. The AIM does indeed make a blanket > > statement with regard to having TSO'd GPS, which is curious as the > > AIM isn't regulatory. (Of course, if one finds themselves in front > > of an administrative law judge due to nonconformity with the AIM one > > will likely be in a world of hurt, but that's a different > > topic...). So, I wonder if all the folks with non-TSO'd GPS are > > grandfathered somehow, or just SOL... > > > > > ________________________________ Message 5 > _____________________________________ > > > Subject: AeroElectric-List: ADS-B - Garmin GDL-82 installation > From: "Argonaut36" <fmlibrino(at)msn.com> > > > In my airplane there are at least 3 options for grounding the GDL-82: > 1. Grounding to the avionics box that contains the electrical bus, > the radio and > the transponder. The box is attached with screws to lugs welded to the > airplane > tubular frame. Paint was removed where necessary to ensure good electrical > continuity to the frame. > 2. Grounding to a single screw on the firewall to which the radio, > the transponder > and the encoder are already grounded. > 3. Grounding to a new screw on the firewall in the general area where > the above > mentioned ground screw is. > What would be the recommended solution? Right now (before installing the > GDL-82) > there is some background noise in the radio, transmitting and receiving. I > am concerned about the GDL-82 working properly and not making the radio > worse. > Thanks > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=490457#490457 > > > ________________________________ Message 6 > _____________________________________ > > > From: Hal Benjamin <halbenjamin101(at)gmail.com> > Subject: Re: AeroElectric-List: ADS-B - Garmin GDL-82 installation > > > I grounded mine to the common forest of tabs on the firewall. All tested > well on > ground and in the NYC airspace. Good luck. > > Hal Benjamin > RV4 > > Sent from my iPad > > > On Jul 20, 2019, at 9:10 PM, Argonaut36 wrote: > > > > > > In my airplane there are at least 3 options for grounding the GDL-82: > > 1. Grounding to the avionics box that contains the electrical bus, > the radio > and the transponder. The box is attached with screws to lugs welded to the > airplane tubular frame. Paint was removed where necessary to ensure good > electrical > continuity to the frame. > > 2. Grounding to a single screw on the firewall to which the radio, > the transponder > and the encoder are already grounded. > > 3. Grounding to a new screw on the firewall in the general area where > the > above mentioned ground screw is. > > What would be the recommended solution? Right now (before installing > the GDL-82) > there is some background noise in the radio, transmitting and receiving. > I am concerned about the GDL-82 working properly and not making the radio > worse. > > Thanks > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=490457#490457 > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Subject: AT-6C ballast resistor?
Date: Jul 23, 2019
QWxsLA0KDQpBbSBsb29raW5nIGZvciBoZWxwLg0KDQpXZSBoYXZlIGEgSGFydmFyZCAoQVQtNkMp Lg0KDQpUaGVyZSBpcyB3aGF0IGFsbGVnZWRseSBpcyBjYWxsZWQgYSBiYWxsYXN0IHJlc2lzdG9y IHRoYXQgc2l0cyBpbiBhbiBleHRlcm5hbGx5IGFjY2Vzc2libGUgZWxlY3RyaWNhbCBib3ggb24g dGhlIGxlZnQgaGFuZCBzaWRlIG9mIHRoZSBmdXNlbGFnZSBhYm92ZSB0aGUgbGVmdCB3aW5nIGxl YWRpbmcgZWRnZS4gVGhhdCBib3ggYWxzbyBjb250YWlucyB0aGUgY2FyYm9uIHBpbGUgcmVjdGlm aWVkIGFtb25nc3Qgb3RoZXIgdGhpbmdzLg0KDQpUd2ljZSBub3csIHRoaXMgYmFsbGFzdCByZXNp c3RvciBoYXMgZmFpbGVkIGluIGEgdGhlcm1pYyB3YXkuLi4uLiAocmVwbGFjZWQsIGFuZCByZXBs YWNlbWVudCBmYWlsZWQgYWZ0ZXIgYWJvdXQgMTAgaG91cnMpLg0KDQpXaGVuIHRoaXMgZmFpbHMs IG9uIGFjdGl2YXRpbmcgYmF0dGVyeSBtYXN0ZXIsIHRoZXJlIGlzIG5vIHBvd2VyIHRvIHRoZSBt YWluIDI4diBidXMuLi4uLiBvbmx5IHBvd2VyIGZyb20gYmF0dGVyeSB0byBzdGFydGVyIG1vdG9y LiAyOHYgYnVzIG9ubHkgYmVjb21lcyBlbmVyZ2lzZWQgd2hlbiBnZW5lcmF0b3Iga2lja3MgaW4u IEJhdHRlcnkgZG9lcyBub3QgY2hhcmdlLg0KDQpDYW4gYW55b25lIGVubGlnaHRlbiB3aGF0IHRo aXMgcmVzaXN0b3IgaXMgZm9yPyBSdW1vdXIgaGFzIGl0IHRoYXQgaXQgd2FzIG9ubHkgdG8gcHJv dGVjdCBvbGQgc3R5bGUgYXZpb25pY3MuIElmIHRoaXMgaXMgdGhlIGNhc2UsIHdvdWxkIGl0IGJl IHNhZmUgdG8gcmVtb3ZlIGl0IHNpbmNlIHdlIGhhdmUgbW9kZXJuIGF2aW9uaWNzIGluIHRoZSBh aXJjcmFmdC4NCg0KUHJvYmxlbSB1cyB0aGF0IHdlIGFyZSBoYXZpbmcgZGlmZmljdWx0eSBzb3Vy Y2luZyBhIGZ1cnRoZXIgcmVwbGFjZW1lbnQsIHNvIHRoZSBhaXJjcmFmdCBpcyB1bnNlcnZpY2Vh YmxlIHVudGlsIGEgc29sdXRpb24gaXMgZm91bmQuDQoNCklzIHRoZXJlIGEgbW9kZXJuIHJlcGxh Y2VtZW50IG9yIG1vZCB0aGF0IGFueW9uZSBrbm93cyBvZj8NCg0KSSdtIGxlZCB0byBiZWxpZXZl IGl0cyAxMjUgb2htLCBidXQgaGF2ZSBubyBvdGhlciBpbmZvcm1hdGlvbiB0aGFuIHRoYXQgKGFu ZCBpdCdzIGEgMjh2IGdlbmVyYXRvciBiYXNlZCBzeXN0ZW0pDQoNCkhlbHAgcGxlYXNlPw0KDQoN Cg0KDQoNCg0KDQoNClJlZ2FyZHMsDQpOaWdlbCBXaWxsc29uDQpGbHlpbmcgSW5zdHJ1Y3RvciAm IEV4YW1pbmVyIHwgQWlyc2hvdyBPcmdhbmlzZXIgfCBEaXNwbGF5IFBpbG90DQoNCg0KIFtYXQ0K DQpbWF0NCg0KTW9iaWxlOg0KDQorNDQgKDApNzgwOSAxMTY2NzY8dGVsOis0NCUyMCgwKTc4MDkl MjAxMTY2NzY+DQoNCltYXQ0KDQpbWF0NCg0KRW1haWw6DQoNCm5pZ2VsQGVhc3lwcGwuY29tPG1h aWx0bzpuaWdlbEBlYXN5cHBsLmNvbT4NCg0KW1hdDQoNCldlYjoNCg0KaHR0cDovL2Vhc3lwcGwu Y29tDQpodHRwOi8vZ3JlYXRicml0aXNoYWlyc2hvd3MuY29tDQpodHRwOi8veWFrZGlzcGxheS5j b208aHR0cDovL3lha2Rpc3BsYXkuY29tLz4NCg0KDQoNCg0KU2VudCBmcm9tIG15IFNhbXN1bmcg R2FsYXh5IFM5IC0gUG93ZXJlZCBieSBUaHJlZQ0K ________________________________________________________________________________
Date: Jul 23, 2019
Subject: Battery maintainers
Am at OSH and got the impressive presentation of Battery Saver #3015-LCD Maintains larger vehicles with up to two batteries Quickly charges weak batteries Pulse cleaning mode improves battery condition with continued use Automatically works with 6&12 volt lead acid batteries Built in LCD tester displays voltage, amp output and battery percentage bar I have two Oddessy PC-680 batteries which need keeping at peak for an electric dual EFII system. Anyone have this unit or a knowledgeable suggestion? Thanks, Ron Burnett RV-6A May you have the Lord's blessings today! Sent from my iPad ________________________________________________________________________________
Subject: Re: Battery maintainers
Date: Jul 24, 2019
Unless you only fly twice a year, plug your charger money into avgas=2E :-) =81=A3Sent from BlueMail =8B On Jul 23, 2019, 11:19 PM, at 11:1 9 PM, Ron Burnett wrote: >--> AeroElectric-List message posted by: Ron Burnett > > >Am at OSH and got the impressive presentation of Battery Saver >#3015-LCD > >Maintains l arger vehicles with up to two batteries >Quickly charges weak batteries > Pulse cleaning mode improves battery condition with continued use >Automati cally works with 6&12 volt lead acid batteries >Built in LCD tester displa ys voltage, amp output and battery percentage >bar > >I have two Oddessy PC -680 batteries which need keeping at peak for an >electric dual EFII system =2E > >Anyone have this unit or a knowledgeable suggestion? > >Thanks, > >R on Burnett >RV-6A > >May you have the Lord's blessings today! >Sent from m y iPad > ============= ic-List Email Forum - rowse rchive Search & Download, 7-Day Browse, Chat, FAQ, uch much more: eroElectric-List ================== - MATRONICS WEB FORUMS - he Web Forums! > WIKI - http://wiki=2Ematronics=2Ecom ==================== - List Contribution Web Site - support! >_ -= --> http://www=2Ematronics=2Ecom/contribution === ________________________________________________________________________________
Date: Jul 24, 2019
Subject: Re: AT-6C ballast resistor?
At 11:19 AM 7/23/2019, you wrote: >All, > >Am looking for help. > >We have a Harvard (AT-6C). > >There is what allegedly is called a ballast resistor that sits in an >externally accessible electrical box on the left hand side of the >fuselage above the left wing leading edge. That box also contains >the carbon pile rectified amongst other things. > >Twice now, this ballast resistor has failed in a thermic way..... >(replaced, and replacement failed after about 10 hours). Do you still have a failed part? Can you share a picture? >When this fails, on activating battery master, there is no power to >the main 28v bus..... only power from battery to starter motor. 28v >bus only becomes energised when generator kicks in. Battery does not charge. > >Can anyone enlighten what this resistor is for? Rumour has it that >it was only to protect old style avionics. If this is the case, >would it be safe to remove it since we have modern avionics in the aircraft. Do you have a wiring diagram for this airplane? Have you availed yourself of the documentation library on this aircraft available at: https://tinyurl.com/y4bclrc2 >Problem us that we are having difficulty sourcing a further >replacement, so the aircraft is unserviceable until a solution is found. There are no doubt dozens of suitable replacements. But without knowing the form, fit and function of this part, making a selection is impossible. >Is there a modern replacement or mod that anyone knows of? > >I'm led to believe its 125 ohm, but have no other information than >that (and it's a 28v generator based system) Does the failed part have any markings on it? Bob . . . ________________________________________________________________________________
Date: Jul 24, 2019
Hi Bob, Yes we have diagrams..... I'll send picture in next email, but the part concerned is: PART No: COIEK 125 Ohms 125 Watt Regards, Nigel Willson Flying Instructor & Examiner | Airshow Organiser | Display Pilot [cid:image002.jpg(at)01D5423F.D4696EF0] [cid:image004.png(at)01D5423F.D4696EF0] Mobile: +44 (0)7809 116676 [cid:image010.png(at)01D5423F.D4696EF0] [cid:image012.png(at)01D5423F.D4696EF0] Email: nigel(at)easyppl.com [cid:image018.png(at)01D5423F.D4696EF0] Web: http://easyppl.com http://greatbritishairshows.com http://yakdisplay.com> From: owner-aeroelectric-list-server(at)matronics.com <owner-aeroelectric-list -server(at)matronics.com> On Behalf Of Robert L. Nuckolls, III Sent: 24 July 2019 16:26 Subject: Re: AeroElectric-List: AT-6C ballast resistor? At 11:19 AM 7/23/2019, you wrote: All, Am looking for help. We have a Harvard (AT-6C). There is what allegedly is called a ballast resistor that sits in an extern ally accessible electrical box on the left hand side of the fuselage above the left wing leading edge. That box also contains the carbon pile rectifie d amongst other things. Twice now, this ballast resistor has failed in a thermic way..... (replaced , and replacement failed after about 10 hours). Do you still have a failed part? Can you share a picture? When this fails, on activating battery master, there is no power to the mai n 28v bus..... only power from battery to starter motor. 28v bus only becom es energised when generator kicks in. Battery does not charge. Can anyone enlighten what this resistor is for? Rumour has it that it was o nly to protect old style avionics. If this is the case, would it be safe to remove it since we have modern avionics in the aircraft. Do you have a wiring diagram for this airplane? Have you availed yourself of the documentation library on this aircraft available at: https://tinyurl.com/y4bclrc2 Problem us that we are having difficulty sourcing a further replacement, so the aircraft is unserviceable until a solution is found. There are no doubt dozens of suitable replacements. But without knowing the form, fit and function of this part, making a selection is impossible. Is there a modern replacement or mod that anyone knows of? I'm led to believe its 125 ohm, but have no other information than that (an d it's a 28v generator based system) Does the failed part have any markings on it? Bob . . . ________________________________________________________________________________
Date: Jul 24, 2019
Bob, Here is the picture of the resistor.... Regards, Nigel Willson Flying Instructor & Examiner | Airshow Organiser | Display Pilot [X] [X] Mobile: +44 (0)7809 116676 [X] [X] Email: nigel(at)easyppl.com [X] Web:
http://easyppl.com http://greatbritishairshows.com http://yakdisplay.com> Sent from my Samsung Galaxy S9 - Powered by Three -------- Original message -------- From: Nigel Willson <nigel(at)easyppl.com> Date: 24/07/2019 16:56 (GMT+00:00) Subject: RE: AeroElectric-List: AT-6C ballast resistor? Hi Bob, Yes we have diagrams..... I'll send picture in next email, but the part concerned is: PART No: COIEK 125 Ohms 125 Watt Regards, Nigel Willson Flying Instructor & Examiner | Airshow Organiser | Display Pilot [cid:image002.jpg(at)01D5423F.D4696EF0] [cid:image004.png(at)01D5423F.D4696EF0] Mobile: +44 (0)7809 116676 [cid:image010.png(at)01D5423F.D4696EF0] [cid:image012.png(at)01D5423F.D4696EF0] Email: nigel(at)easyppl.com [cid:image018.png(at)01D5423F.D4696EF0] Web: http://easyppl.com http://greatbritishairshows.com http://yakdisplay.com> From: owner-aeroelectric-list-server(at)matronics.com <owner-aeroelectric-list -server(at)matronics.com> On Behalf Of Robert L. Nuckolls, III Sent: 24 July 2019 16:26 Subject: Re: AeroElectric-List: AT-6C ballast resistor? At 11:19 AM 7/23/2019, you wrote: All, Am looking for help. We have a Harvard (AT-6C). There is what allegedly is called a ballast resistor that sits in an extern ally accessible electrical box on the left hand side of the fuselage above the left wing leading edge. That box also contains the carbon pile rectifie d amongst other things. Twice now, this ballast resistor has failed in a thermic way..... (replaced , and replacement failed after about 10 hours). Do you still have a failed part? Can you share a picture? When this fails, on activating battery master, there is no power to the mai n 28v bus..... only power from battery to starter motor. 28v bus only becom es energised when generator kicks in. Battery does not charge. Can anyone enlighten what this resistor is for? Rumour has it that it was o nly to protect old style avionics. If this is the case, would it be safe to remove it since we have modern avionics in the aircraft. Do you have a wiring diagram for this airplane? Have you availed yourself of the documentation library on this aircraft available at: https://tinyurl.com/y4bclrc2 Problem us that we are having difficulty sourcing a further replacement, so the aircraft is unserviceable until a solution is found. There are no doubt dozens of suitable replacements. But without knowing the form, fit and function of this part, making a selection is impossible. Is there a modern replacement or mod that anyone knows of? I'm led to believe its 125 ohm, but have no other information than that (an d it's a 28v generator based system) Does the failed part have any markings on it? Bob . . . ________________________________________________________________________________
Date: Jul 24, 2019
At 10:50 AM 7/24/2019, you wrote: >Hi Bob, > > >PART No: COIEK >125 Ohms >125 Watt > > Hmmm . . . I seem to recall that COIEK is a old-line resistor manufacturer . . . Emacs! A resistor of that size would look about like this? 28 volts applied to a 125 ohm resistor dissipates only 6 watts. I'm having trouble imagining how a resistor of that size gets overheated in a 28v system. Bob . . . ________________________________________________________________________________
Date: Jul 24, 2019
Qm9iDQoNCkxvb2tzIHJpZ2h0IHRvIG1lLiBBbmQgSSBhZ3JlZS4gRGlmZmljdWx0eSBpcyB0cnlp bmcgdG8gZmluZCBvbmUgb3IgZXF1aXZhbGVudCB0byBwdXQgdGhlIHRoaW5nIGJhY2sgdG9nZXRo ZXIgc28gd2UgY2FuIGZhdWx0IGZpbmQgZnVydGhlci4uLi4uLiB1bmxlc3MgeW91IGhhdmUgc29t ZSBvdGhlciBpZGVhcy4uLi4uDQoNCg0KDQoNCg0KDQoNClJlZ2FyZHMsDQpOaWdlbCBXaWxsc29u DQpGbHlpbmcgSW5zdHJ1Y3RvciAmIEV4YW1pbmVyIHwgQWlyc2hvdyBPcmdhbmlzZXIgfCBEaXNw bGF5IFBpbG90DQoNCg0KIFtYXQ0KDQpbWF0NCg0KTW9iaWxlOg0KDQorNDQgKDApNzgwOSAxMTY2 NzY8dGVsOis0NCUyMCgwKTc4MDklMjAxMTY2NzY+DQoNCltYXQ0KDQpbWF0NCg0KRW1haWw6DQoN Cm5pZ2VsQGVhc3lwcGwuY29tPG1haWx0bzpuaWdlbEBlYXN5cHBsLmNvbT4NCg0KW1hdDQoNCldl YjoNCg0KaHR0cDovL2Vhc3lwcGwuY29tDQpodHRwOi8vZ3JlYXRicml0aXNoYWlyc2hvd3MuY29t DQpodHRwOi8veWFrZGlzcGxheS5jb208aHR0cDovL3lha2Rpc3BsYXkuY29tLz4NCg0KDQoNCg0K U2VudCBmcm9tIG15IFNhbXN1bmcgR2FsYXh5IFM5IC0gUG93ZXJlZCBieSBUaHJlZQ0KDQotLS0t LS0tLSBPcmlnaW5hbCBtZXNzYWdlIC0tLS0tLS0tDQpGcm9tOiAiUm9iZXJ0IEwuIE51Y2tvbGxz LCBJSUkiIDxudWNrb2xscy5ib2JAYWVyb2VsZWN0cmljLmNvbT4NCkRhdGU6IDI0LzA3LzIwMTkg MjA6MjcgKEdNVCswMDowMCkNClRvOiBhZXJvZWxlY3RyaWMtbGlzdEBtYXRyb25pY3MuY29tDQpT dWJqZWN0OiBSRTogQWVyb0VsZWN0cmljLUxpc3Q6IEFULTZDIGJhbGxhc3QgcmVzaXN0b3I/DQoN CkF0IDEwOjUwIEFNIDcvMjQvMjAxOSwgeW91IHdyb3RlOg0KSGkgQm9iLA0KDQoNClBBUlQgTm86 IENPSUVLDQoxMjUgT2htcw0KMTI1IFdhdHQNCg0KDQoNCiAgSG1tbSAuIC4gLiBJIHNlZW0gdG8g cmVjYWxsIHRoYXQgQ09JRUsgaXMNCiAgYSBvbGQtbGluZSByZXNpc3RvciBtYW51ZmFjdHVyZXIg LiAuIC4NCltFbWFjcyFdDQoNCiAgQSByZXNpc3RvciBvZiB0aGF0IHNpemUgd291bGQgbG9vayBh Ym91dA0KICBsaWtlIHRoaXM/DQoNCiAgMjggdm9sdHMgYXBwbGllZCB0byBhIDEyNSBvaG0gcmVz aXN0b3INCiAgZGlzc2lwYXRlcyBvbmx5IDYgd2F0dHMuIEknbSBoYXZpbmcNCiAgdHJvdWJsZSBp bWFnaW5pbmcgaG93IGEgcmVzaXN0b3Igb2YNCiAgdGhhdCBzaXplIGdldHMgb3ZlcmhlYXRlZCBp biBhIDI4diBzeXN0ZW0uDQoNCg0KDQogIEJvYiAuIC4gLg0K ________________________________________________________________________________
Date: Jul 24, 2019
The pic shows multiple taps; looks like some of the individual segments could easily be as low as around 20 ohms. Those are some really fat looking conductors attached to it, too. Charlie On Wed, Jul 24, 2019 at 2:28 PM Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 10:50 AM 7/24/2019, you wrote: > > Hi Bob, > > > PART No: COIEK > 125 Ohms > 125 Watt > > > Hmmm . . . I seem to recall that COIEK is > a old-line resistor manufacturer . . . > [image: Emacs!] > > A resistor of that size would look about > like this? > > 28 volts applied to a 125 ohm resistor > dissipates only 6 watts. I'm having > trouble imagining how a resistor of > that size gets overheated in a 28v system. > > > Bob . . . > ________________________________________________________________________________
Date: Jul 24, 2019
No. They are not multiple taps, just a connector sited beneath the resistor .... Regards, Nigel Willson Flying Instructor & Examiner | Airshow Organiser | Display Pilot [X] [X] Mobile: +44 (0)7809 116676 [X] [X] Email: nigel(at)easyppl.com [X] Web:
http://easyppl.com http://greatbritishairshows.com http://yakdisplay.com> Sent from my Samsung Galaxy S9 - Powered by Three -------- Original message -------- From: Charlie England <ceengland7(at)gmail.com> Date: 24/07/2019 20:40 (GMT+00:00) Subject: Re: AeroElectric-List: AT-6C ballast resistor? The pic shows multiple taps; looks like some of the individual segments cou ld easily be as low as around 20 ohms. Those are some really fat looking co nductors attached to it, too. Charlie On Wed, Jul 24, 2019 at 2:28 PM Robert L. Nuckolls, III <nuckolls.bob@aeroe lectric.com> wrote: At 10:50 AM 7/24/2019, you wrote: Hi Bob, PART No: COIEK 125 Ohms 125 Watt Hmmm . . . I seem to recall that COIEK is a old-line resistor manufacturer . . . [Emacs!] A resistor of that size would look about like this? 28 volts applied to a 125 ohm resistor dissipates only 6 watts. I'm having trouble imagining how a resistor of that size gets overheated in a 28v system. Bob . . . ________________________________________________________________________________
Date: Jul 24, 2019
Date: Jul 24, 2019
At 01:42 PM 7/24/2019, you wrote: >Bob, > >Here is the picture of the resistor.... Hmmm . . . that's in no way a 125 ohm resistor. When they are wound with ribbon wire on edge, it's more likely to be 12.5 ohms or even 1.25 ohms. Will need to see the wiring diagram where this device is incorporated before I can be of much help. If the last replacement lasted only a few hours, then something is broke . . . need to figure out what this resistor is supposed to do. Bob . . . ________________________________________________________________________________
Date: Jul 25, 2019
past input to this forum suggests that 680's [and all of that brand] live longer with only charging from the engine running. a flight even every 6 weeks should be enough. a constant charge seems to more often shorten the life and is not needed. i shortened the life of my 625!. bob noffs On Wed, Jul 24, 2019 at 7:52 AM Charlie England wrote: > Unless you only fly twice a year, plug your charger money into avgas. > :-) > > Sent from BlueMail <http://www.bluemail.me/r?b=14874> > On Jul 23, 2019, at 11:19 PM, Ron Burnett wrote: >> >> >> Am at OSH and got the impressive presentation of Battery Saver #3015-LCD >> >> Maintains larger vehicles with up to two batteries >> Quickly charges weak batteries >> Pulse cleaning mode improves battery condition with continued use >> Automatically works with 6&12 volt lead acid batteries >> Built in LCD tester displays voltage, amp output and battery percentage bar >> >> I have two Oddessy PC-680 batteries which need keeping at peak for an electric dual EFII system. >> >> Anyone have this unit or a knowledgeable suggestion? >> >> Thanks, >> >> Ron Burnett >> RV-6A >> >> May you hav http:on">http://www.matronics.com/contribution >> ------------------------------ >> >> >> >> >> ________________________________________________________________________________
Date: Jul 25, 2019
Part dux- I got a chance to talk to one of the avionics guys here about the current state of things. He did say that TSOd GPS units are mandatory for IFR and ADS-B inputs. And so it goes- ________________________________________________________________________________
Date: Jul 25, 2019
At 06:39 AM 7/25/2019, you wrote: >past input to this forum suggests that 680's >[and all of that brand] live longer with only >charging from the engine running. a flight even >every 6 weeks should be enough. a constant >charge seems to more often shorten the life and >is not needed. i shortened the life of my 625!.=C2 >=C2 bob noffs Generally true. Consider that even before the era of SVLA batteries, it was not uncommon to have a battery in a vehicle run for 3 years. Of course this assumes regular use with a properly functioning charging system and no extra-ordinary abuse of the battery (deep discharge, freezing, hot storage, etc). The SVLA battery's superior reduction in self-discharge makes still more likely that a well treated battery will have a long service life. The 'well treated' battery gets 'parked' with a high state of charge in a relatively benign environment. If one anticipates a long storage then there is but ONE externally applied benefit comes in the form of a MAINTAINER which is simply a voltage source tied to the battery and adjusted for a few hundred MILLIVOLS greater than the battery's nominal resting voltage. This cannot and does not charge the battery. It simply offers an energy source to shoulder the very small self discharge currents that exist in all batteries. A few weeks ago I purchased a Battery Minder Plus charger/maintainer. A Lister supplied me with a near end of life SVLA battery as a test article to evaluate this new product from Battery Minder. This product claims to have added desulfation technology for even better performance as a battery maintenance device. I've looked at the charging output on a 'scope and yes . . . there are some spikey pulses coming out that must be artifacts of the Battery Minder approach to 'desulfating' the battery. I'll have more to offer on this product later . . . it takes WEEKS to evaluate the efficacy of this process. Suffice it to say that I'm not impressed nor did I expect to be. A cruise through the library of YouTube videos yields a constellation of bad science offered up as practical techniques to work around the laws of physics in batteries, energy sources and weight loss. There are dozens of PATENTS for battery desulfation schemes with a common thread suggesting that the lead-sulfide crystals can be electrically 'hammered' back into useful chemistry from outside the battery. The whole battery desufation thingy has proven to be in the same class of products as strapping magnets to your incoming main to 'soften' the water . . . and little 'turbines' installed under your carburetor to boost gas mileage. I am saddened that legacy battery maintenance products like Battery Minder have found it necessary to emulate their competition's ventures into smoke-n-mirrors marketing but hey, it's the nature of things. Just look at all the brands of laundry soap . . . I buy what's on sale . . . works just fine. A battery charger-MAINTAINER will top of the battery one time and then revert to a maintenance mode that is only capable of offsetting self-discharge currents . . . and can only enhance battery service life. Emacs! As for desulfation . . . ask to see laboratory test results that prove efficacy of the product's performance claims. But if you fly regularly, even the well crafted maintainer will be of no demonstrable benefit. Bob . . . ________________________________________________________________________________
Date: Jul 25, 2019
I think this is slightly misleading... The Blue Mountain device is an experimental-only EFIS that happens to have a VFR GPS included in it (just like Dynon, GRT, or the Garmin 3X-series) but it was never intended to be an IFR Navigator on it's own. The FAA considers these devices to be "VFR-only" GPS navigators, and the GPS capabilities are supposed to be used for situational awareness only. The FAA DOES allow EAB aircraft to fly in IMC with those experimental EFIS systems, but they STILL require a certified IFR GPS to file "/G" in the system, and to use the GPS as the primary navigation source in IMC. EAA has lots of articles, Q&As, etc. on this topic. In addition, my local DAR (also our EAA Tech Counselor) tells me they hammer away on this point EVERY time they have DAR recurrent training... To save some initial cash outlay, one might use one of the older IFR-certified non-WAAS GPS systems (like the TSOed Garmin GNC-300XL) which are FAA approved for enroute and non-precision approaches, SIDs, and STARS). Or you could go whole hog and get one of the TSOed WAAS navigators that allow all of the above, plus LPV, LNAV/VNAV, and LNAV precision approaches. Or for that matter, you can use the experimental GPS for situational awareness as you fly the VOR Airways with a TSOed VHF Nav radio. But you cannot file "/G" and use the GPS approaches without an FAA-certified GPS. So, flying in IMC with just a Blue Mountain EFIS and it's included GPS --- not allowed per the FAA's rules. Jim Parker -------- Original Message -------- Subject: AeroElectric-List: IFR-certified GPS Suggestions From: GLEN MATEJCEK <fly4grins(at)gmail.com> Date: Tue, July 23, 2019 7:38 am Hi Kelley- sorry for the delay, but the trip to OSH and related wx issues have had me offline for a bit. *SNIP*I don't believe the FAA has ever "approved" of using anything but a TSO GPS. I believe you also have to have a TSO approved ELT unless you meet the exceptions like single seat. Believe it or not, such is the case. Right off the top of my head Blue Mountain comes to mind, among others. All non-certified and all used IFR. WRT the ELT, the salient quote in the reg is "meets the requirements of TSO-C91". It doesn't say has a TSO sticker on it. This is a fine legal point, similar to the part about experimentals having to address AD's, not comply with them. Now, I certainly wouldn't recommend scratch building a radio and expecting a fed to take your word for it's suitability, but the legal principle still stands. All of this was brought to my attention at the time by the local mx fed that handled homebuilts. Unfortunately, there is as much confusion on these matters within the ranks of the feds as there is at the average fly in breakfast, but a quick call to EAA government relations will likely get you a pretty quick and concise answer. Especially when it comes to recent developments, as the FAA has liaised with EAA on regulatory issues affecting homebuilts. ics.com> wrote: * ======================== Online Versions of Today's List Digest Archive ======================== Today's complete AeroElectric-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the AeroElectric-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 19-07-20&Archive=AeroElectric Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 19-07-20&Archive=AeroElectric ====================== EMail Version of Today's List Digest Archive ====================== ---------------------------------------------------------- AeroElectric-List Digest Archive --- Total Messages Posted Sat 07/20/19: 6 ---------------------------------------------------------- Today's Message Index: ---------------------- 1. 02:26 AM - Re: [OT] IFR-certified GPS Suggestions (donjohnston) 2. 06:50 AM - IFR-certified GPS Suggestions (GLEN MATEJCEK) 3. 09:25 AM - ELT antenna, BALUNS and stuff (Robert L. Nuckolls, III) 4. 01:31 PM - Re: IFR-certified GPS Suggestions (Kelly McMullen) 5. 06:12 PM - ADS-B - Garmin GDL-82 installation (Argonaut36) 6. 07:53 PM - Re: ADS-B - Garmin GDL-82 installation (Hal Benjamin) ________________________________ Message 1 _____________________________________ Subject: AeroElectric-List: Re: [OT] IFR-certified GPS Suggestions From: "donjohnston" <don@velocity-xl.com> argoldman(at)aol.com wrote: > Thanks, Somewhere in the back of my mind is that there is a procedure that you have to go through to verify that the adsb is operating correctly. Plane not flying yet-- almost done (15 years). > -- I used this to verify my ADS-B install. https://adsbperformance.faa.gov/paprrequest.aspx Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490436#490436 ________________________________ Message 2 _____________________________________ From: GLEN MATEJCEK <fly4grins(at)gmail.com> Subject: AeroElectric-List: IFR-certified GPS Suggestions > > That's an interesting evolution. It used to be that the only bit of > equipment on an experimental that was required to have a TSO was GPS for > terminal ops. I've spent a little time searching, and can't find any such > reference anymore. The AIM does indeed make a blanket statement with > regard to having TSO'd GPS, which is curious as the AIM isn't regulatory. > (Of course, if one finds themselves in front of an administrative law judge > due to nonconformity with the AIM one will likely be in a world of hurt, > but that's a different topic...). So, I wonder if all the folks with > non-TSO'd GPS are grandfathered somehow, or just SOL... > > ________________________________ Message 3 _____________________________________ From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Subject: AeroElectric-List: ELT antenna, BALUNS and stuff Got the VNA back up and running. Did some quick scans of a couple of BALUN configurations and got some amazing (or should I say consternating) results. At first blush it seems that conventional wisdom may have failed us. Need to repeat the experiments with more rigorous attention to process and calibration . . . watch this space. Got the elements fabricated for a Jim Wier ELT antenna. I'll be assembling those on a test fixture with opportunity to explore BALUN configurations . . . Bob . . . ________________________________ Message 4 _____________________________________ Subject: Re: AeroElectric-List: IFR-certified GPS Suggestions From: Kelly McMullen <kellym(at)aviating.com> There is an advisory circular on GPS install. I forget the first two digits, after the dash its 138a, which for most purposes can be considered regulatory. While you could get away with most anything if you declare an emergency, I wouldn't make a habit of that. I don't believe the FAA has ever "approved" of using anything but a TSO GPS. I believe you also have to have a TSO approved ELT unless you meet the exceptions like single seat. On 7/20/2019 6:48 AM, GLEN MATEJCEK wrote: > That's an interesting evolution. It used to be that the only bit of > equipment on an experimental that was required to have a TSO was GPS > for terminal ops. I've spent a little time searching, and can't > find any such reference anymore. The AIM does indeed make a blanket > statement with regard to having TSO'd GPS, which is curious as the > AIM isn't regulatory. (Of course, if one finds themselves in front > of an administrative law judge due to nonconformity with the AIM one > will likely be in a world of hurt, but that's a different > topic...). So, I wonder if all the folks with non-TSO'd GPS are > grandfathered somehow, or just SOL... > ________________________________ Message 5 _____________________________________ Subject: AeroElectric-List: ADS-B - Garmin GDL-82 installation From: "Argonaut36" <fmlibrino(at)msn.com> In my airplane there are at least 3 options for grounding the GDL-82: 1. Grounding to the avionics box that contains the electrical bus, the radio and the transponder. The box is attached with screws to lugs welded to the airplane tubular frame. Paint was removed where necessary to ensure good electrical continuity to the frame. 2. Grounding to a single screw on the firewall to which the radio, the transponder and the encoder are already grounded. 3. Grounding to a new screw on the firewall in the general area where the above mentioned ground screw is. What would be the recommended solution? Right now (before installing the GDL-82) there is some background noise in the radio, transmitting and receiving. I am concerned about the GDL-82 working properly and not making the radio worse. Thanks Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490457#490457 ________________________________ Message 6 _____________________________________ From: Hal Benjamin <halbenjamin101(at)gmail.com> Subject: Re: AeroElectric-List: ADS-B - Garmin GDL-82 installation I grounded mine to the common forest of tabs on the firewall. All tested well on ground and in the NYC airspace. Good luck. Hal Benjamin RV4 Sent from my iPad > On Jul 20, 2019, at 9:10 PM, Argonaut36 wrote: > > > In my airplane there are at least 3 options for grounding the GDL-82: > 1. Grounding to the avionics box that contains the electrical bus, the radio and the transponder. The box is attached with screws to lugs welded to the airplane tubular frame. Paint was removed where necessary to ensure good electrical continuity to the frame. > 2. Grounding to a single screw on the firewall to which the radio, the transponder and the encoder are already grounded. > 3. Grounding to a new screw on the firewall in the general area where the above mentioned ground screw is. > What would be the recommended solution? Right now (before installing the GDL-82) there is some background noise in the radio, transmitting and receiving. I am concerned about the GDL-82 working properly and not making the radio worse. > Thanks > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=490457#490457 > > > > > > > > > ========== - Electric-List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List ========== FORUMS - eferrer" target="_blank">http://forums.matronics.com ========== WIKI - errer" target="_blank">http://wiki.matronics.com ========== b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution ========== ________________________________________________________________________________
Date: Jul 25, 2019
Subject: Re: IFR-certified GPS Suggestions
Since I started this thread, I figure that I ought to let you know that I purchased one of the new Garmin GPS 175 units. That and a pair of VAL Avionics COM 2000 radios and one NAV 2000 VOR/ILS/GS receiver comprise my IFR panel. -- Art Z. Sent from my phone. Please excuse brevity and bizarre typos. ________________________________________________________________________________
Date: Jul 25, 2019
=81=A3Sent from BlueMail =8B On Jul 25, 2019, 10:35 AM, at 10:3 5 AM, Art Zemon wrote: >Since I started this thread, I f igure that I ought to let you know that >I >purchased one of the new Garmin GPS 175 units=2E That and a pair of VAL >Avionics COM 2000 radios and one NAV 2000 VOR/ILS/GS receiver comprise >my >IFR panel=2E > > -- Art Z=2E > >Sent from my phone=2E Please excuse brevity and bizarre typos=2E ________________________________________________________________________________
Date: Jul 25, 2019
I am very pleased with the COM 2000. Haven't used my NAV 2000 yet due to a wiring glitch. I did need to turn up the mic gain in the setup menu but other than that, it works like a radio. One small thing: turning the decimal from .975 to .000 increments the integer. E.g., turning from 127.975 one click gets you to 128.000, not 127.000. For a guy coming from mechanical dials, this was unexpected behavior. On Thu, Jul 25, 2019, 11:22 AM Charlie England wrote: > > > Sent from BlueMail <http://www.bluemail.me/r?b=14874> > On Jul 25, 2019, at 10:35 AM, Art Zemon wrote: >> >> Since I started this thread, I figure that I ought to let you know that I >> purchased one of the new Garmin GPS 175 units. That and a pair of VAL >> Avionics COM 2000 radios and one NAV 2000 VOR/ILS/GS receiver comprise my >> IFR panel. >> >> -- Art Z. >> >> >> Hi Art, >> >> Please send us pireps on both the 175 and the VAL 2000. The val 429 has a >> great rep, but some reports on the 2000 aren't as positive. If you have >> good luck with it, I'll seriously consider the com/nav2000 pair for my >> plane. Much cheaper than even a used Garmin SL30. >> >> Thanks, >> >> Charlie >> > ________________________________________________________________________________
From: "skywagon185guy ." <skywagon185(at)gmail.com>
Date: Jul 25, 2019
Ron, For reviews check Amazon as the carry them. Read the "minus" reviews first. For my use, the Battery Tender works well and is about 1/2 the cost. I have 5 of them on various vehicle batteries and have not had a failure. However, there is a potential flaw in most of these low cost maintainers. If you power the unit from your normal wall power that is controlled by a GFI, that is were the problem lurks. If the GFI trips for any reason, storms, power outage, etc., etc., and the unit looses power, it will still draw a small current from the battery that it is affixed to. Not a problem if you catch the problem in a few hours, maybe days. However, if you are on a trip or other long away time, the maintainer will discharge the battery flat. They should install a diode in the battery line to prevent back current flow, but, few do. One could install their own diode however, its forward voltage drop now means that the charging voltage will be lower by 0.5 - 0.6 volts. Not good, in the 6v or 12v charging arena. It would be nice if one could open up the maintainer and tweak the charging voltage to make up for the diode's voltage drop.... D On Tue, Jul 23, 2019 at 9:20 PM Ron Burnett wrote: > ronburnett(at)charter.net> > > Am at OSH and got the impressive presentation of Battery Saver #3015-LCD > > Maintains larger vehicles with up to two batteries > Quickly charges weak batteries > Pulse cleaning mode improves battery condition with continued use > Automatically works with 6&12 volt lead acid batteries > Built in LCD tester displays voltage, amp output and battery percentage bar > > I have two Oddessy PC-680 batteries which need keeping at peak for an > electric dual EFII system. > > Anyone have this unit or a knowledgeable suggestion? > > Thanks, > > Ron Burnett > RV-6A > > May you have the Lord's blessings today! > Sent from my iPad > > ________________________________________________________________________________
Date: Jul 25, 2019
Art, would be interested to hear your experience about the NAV 2000, will you couple it with any EFIS? Cheers Werner On 25.07.2019 17:26, Art Zemon wrote: > Since I started this thread, I figure that I ought to let you know that > I purchased one of the new Garmin GPS 175 units. That and a pair of VAL > Avionics COM 2000 radios and one NAV 2000 VOR/ILS/GS receiver comprise > my IFR panel. > > -- Art Z. > > Sent from my phone. Please excuse brevity and bizarre typos. ________________________________________________________________________________
Date: Jul 25, 2019
At 12:23 PM 7/25/2019, you wrote: >Ron, >For reviews check Amazon as the carry them. Read the "minus" reviews first. >For my use, the Battery Tender works well and is about 1/2 the cost. >I have 5 of them on various vehicle batteries and have=C2 not had a failure. > >However, there is a potential flaw in most of these low cost maintainers. >If you power the unit from your normal wall >power that is controlled by a GFI, that is were the problem lurks. >If the GFI trips for any reason, storms, power >outage, etc., etc., and the unit looses power, >it will still draw a small current from the battery that it is affixed to. > >Not a problem if you catch the problem in a few >hours, maybe days.=C2 However, if you are on a >trip or other long away time, the maintainer will discharge the battery flat. >They should install a diode in the battery line >to prevent back current flow, but, few do. I just checked the back-flow into one of my Battery Tenders. Measured just under 1 milliamp. It would take 20,000 hours (2.3 years) to toss off all the energy in a 20 a.h. battery. The voltage sense circuitry could indeed be calibrated to wash out the voltage drop of a diode but the risks are pretty small. Bob . . . ________________________________________________________________________________
Date: Jul 25, 2019
On 7/25/2019 1:56 PM, Robert L. Nuckolls, III wrote: > At 12:23 PM 7/25/2019, you wrote: >> Ron, >> For reviews check Amazon as the carry them. Read the "minus" reviews >> first. >> For my use, the Battery Tender works well and is about 1/2 the cost. >> I have 5 of them on various vehicle batteries and have not had a >> failure. >> >> However, there is a potential flaw in most of these low cost maintainers. >> If you power the unit from your normal wall power that is controlled >> by a GFI, that is were the problem lurks. >> If the GFI trips for any reason, storms, power outage, etc., etc., >> and the unit looses power, it will still draw a small current from >> the battery that it is affixed to. >> >> Not a problem if you catch the problem in a few hours, maybe days. >> However, if you are on a trip or other long away time, the maintainer >> will discharge the battery flat. >> They should install a diode in the battery line to prevent back >> current flow, but, few do. > > I just checked the back-flow into one of my > Battery Tenders. Measured just under 1 milliamp. > > It would take 20,000 hours (2.3 years) > to toss off all the energy in a 20 a.h. battery. > The voltage sense circuitry could indeed be > calibrated to wash out the voltage drop of a > diode but the risks are pretty small. > > > Bob . . . > Any chance that due to the seemingly endless variation in designs among brands and even within brands, everybody could be right? For example, Odyssey says that *their* charger-maintainer can be left connected to their batteries indefinitely, but there are a *lot* of 1st person accounts floating around describing very short lived Odyssey batteries "even though I kept them on a maintainer" (brands unspecified). There are relatively few 1st person accounts (that I've seen) complaining about short lived Odyssey batteries when no 'maintainers' were used. Charlie --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jul 25, 2019
I would be reluctant to trust unverified third party reports on this. I have found that "battery literacy" is quite low. For example, many people think a "trickle charger" is the same thing as a battery maintainer; many people have no idea how bad it is to fully discharge a battery, etc. Then there is the "cause or effect" problem -- i.e. are people with already bad batteries more likely to resort to using a battery tender, and then when the already damaged battery dies, blame it on the tender? I myself have a lot of experience using battery maintainers, all of it good. Based on that, I completely agree with Bob that it is impossible to damage a battery by using a properly functioning battery tender. On Thu, Jul 25, 2019 at 12:10 PM Charlie England wrote: > On 7/25/2019 1:56 PM, Robert L. Nuckolls, III wrote: > > At 12:23 PM 7/25/2019, you wrote: > > Ron, > For reviews check Amazon as the carry them. Read the "minus" reviews firs t. > For my use, the Battery Tender works well and is about 1/2 the cost. > I have 5 of them on various vehicle batteries and have=C3=82 not had a f ailure. > > However, there is a potential flaw in most of these low cost maintainers. > If you power the unit from your normal wall power that is controlled by a > GFI, that is were the problem lurks. > If the GFI trips for any reason, storms, power outage, etc., etc., and th e > unit looses power, it will still draw a small current from the battery th at > it is affixed to. > > Not a problem if you catch the problem in a few hours, maybe days.=C3=82 > However, if you are on a trip or other long away time, the maintainer wil l > discharge the battery flat. > They should install a diode in the battery line to prevent back current > flow, but, few do. > > > I just checked the back-flow into one of my > Battery Tenders. Measured just under 1 milliamp. > > It would take 20,000 hours (2.3 years) > to toss off all the energy in a 20 a.h. battery. > The voltage sense circuitry could indeed be > calibrated to wash out the voltage drop of a > diode but the risks are pretty small. > > > Bob . . . > > Any chance that due to the seemingly endless variation in designs among > brands and even within brands, everybody could be right? > > For example, Odyssey says that *their* charger-maintainer can be left > connected to their batteries indefinitely, but there are a *lot* of 1st > person accounts floating around describing very short lived Odyssey > batteries "even though I kept them on a maintainer" (brands unspecified). > There are relatively few 1st person accounts (that I've seen) complaining > about short lived Odyssey batteries when no 'maintainers' were used. > > Charlie > > > Virus-free . > www.avast.com > > <#m_3655902431514137369_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> > ________________________________________________________________________________
Date: Jul 25, 2019
On Thu, Jul 25, 2019 at 4:00 PM Ken Ryan wrote: > I would be reluctant to trust unverified third party reports on this. I > have found that "battery literacy" is quite low. For example, many people > think a "trickle charger" is the same thing as a battery maintainer; many > people have no idea how bad it is to fully discharge a battery, etc. Then > there is the "cause or effect" problem -- i.e. are people with already ba d > batteries more likely to resort to using a battery tender, and then when > the already damaged battery dies, blame it on the tender? I myself have a > lot of experience using battery maintainers, all of it good. Based on tha t, > I completely agree with Bob that it is impossible to damage a battery by > using a properly functioning battery tender. > > On Thu, Jul 25, 2019 at 12:10 PM Charlie England > wrote: > >> On 7/25/2019 1:56 PM, Robert L. Nuckolls, III wrote: >> >> At 12:23 PM 7/25/2019, you wrote: >> >> Ron, >> For reviews check Amazon as the carry them. Read the "minus" reviews >> first. >> For my use, the Battery Tender works well and is about 1/2 the cost. >> I have 5 of them on various vehicle batteries and have=C3=82 not had a >> failure. >> >> However, there is a potential flaw in most of these low cost maintainers . >> If you power the unit from your normal wall power that is controlled by a >> GFI, that is were the problem lurks. >> If the GFI trips for any reason, storms, power outage, etc., etc., and >> the unit looses power, it will still draw a small current from the batte ry >> that it is affixed to. >> >> Not a problem if you catch the problem in a few hours, maybe days.=C3=82 >> However, if you are on a trip or other long away time, the maintainer wi ll >> discharge the battery flat. >> They should install a diode in the battery line to prevent back current >> flow, but, few do. >> >> >> I just checked the back-flow into one of my >> Battery Tenders. Measured just under 1 milliamp. >> >> It would take 20,000 hours (2.3 years) >> to toss off all the energy in a 20 a.h. battery. >> The voltage sense circuitry could indeed be >> calibrated to wash out the voltage drop of a >> diode but the risks are pretty small. >> >> >> >> Bob . . . >> >> Any chance that due to the seemingly endless variation in designs among >> brands and even within brands, everybody could be right? >> >> For example, Odyssey says that *their* charger-maintainer can be left >> connected to their batteries indefinitely, but there are a *lot* of 1st >> person accounts floating around describing very short lived Odyssey >> batteries "even though I kept them on a maintainer" (brands unspecified) . >> There are relatively few 1st person accounts (that I've seen) complainin g >> about short lived Odyssey batteries when no 'maintainers' were used. >> >> Charlie >> >> <#m_4055673255306501323_m_3655902431514137369_DAB4FAD8-2DD7-40BB-A1B8-4E 2AA1F9FDF2> >> > Ken, That was my point. The percentage of pilots with both the qualifications *and the equipment* to verify that their particular 'maintainer' does what it claims is likely not much better than the percentage of drivers who meet both criteria. And,it's a pretty safe bet that the pilots who have short lived SLA batteries have normal lived batteries in their cars. That's likely because they don't think about the car battery, and just leave it alone. "If it ain't broke, don't fix it." (Especially if you don't have the quals & tools for the job.) The battery doesn't need to be 'maintained' on a half-way frequently flown a/c, any more than the owner's car battery needs to be 'maintained'. So why risk hooking it to something when the owner isn't qualified to judge its suitability for the task? Charlie ________________________________________________________________________________
Date: Jul 25, 2019
"Why risk hooking it to something when the owner isn't qualified to judge its suitability for the task?" -- Well, first off, once the knowledge of the distinction between a battery maintainer and a battery charger has been acquired, the owner is pretty well qualified. Next thing to consider is that even a single complete discharge can severely damage a battery. And the final ingredient is the observation that although we plan to fly regularly, sh@# happens, and it is easy for time to pass. All of this makes me wonder why anyone would prefer not to put the battery on a tender, unless of course doing so is difficult and time consuming. But if the airplane is set up for it, that will not be the case. (And there is nothing like a fresh, fully topped battery for spinning that engine.) As to the comparison to automobiles, I really don't think that is fare. Most people drive their cars daily. A better comparison would be to motorcycles, where owners quickly learn (because of the cost of battery replacement) to put their batteries on tenders at the end of riding season. On Thu, Jul 25, 2019, 14:13 Charlie England wrote: > > > On Thu, Jul 25, 2019 at 4:00 PM Ken Ryan wrote: > >> I would be reluctant to trust unverified third party reports on this. I >> have found that "battery literacy" is quite low. For example, many peopl e >> think a "trickle charger" is the same thing as a battery maintainer; man y >> people have no idea how bad it is to fully discharge a battery, etc. The n >> there is the "cause or effect" problem -- i.e. are people with already b ad >> batteries more likely to resort to using a battery tender, and then when >> the already damaged battery dies, blame it on the tender? I myself have a >> lot of experience using battery maintainers, all of it good. Based on th at, >> I completely agree with Bob that it is impossible to damage a battery by >> using a properly functioning battery tender. >> >> On Thu, Jul 25, 2019 at 12:10 PM Charlie England >> wrote: >> >>> On 7/25/2019 1:56 PM, Robert L. Nuckolls, III wrote: >>> >>> At 12:23 PM 7/25/2019, you wrote: >>> >>> Ron, >>> For reviews check Amazon as the carry them. Read the "minus" reviews >>> first. >>> For my use, the Battery Tender works well and is about 1/2 the cost. >>> I have 5 of them on various vehicle batteries and have=C3=82 not had a >>> failure. >>> >>> However, there is a potential flaw in most of these low cost maintainer s. >>> If you power the unit from your normal wall power that is controlled by >>> a GFI, that is were the problem lurks. >>> If the GFI trips for any reason, storms, power outage, etc., etc., and >>> the unit looses power, it will still draw a small current from the batt ery >>> that it is affixed to. >>> >>> Not a problem if you catch the problem in a few hours, maybe days.=C3 =82 >>> However, if you are on a trip or other long away time, the maintainer w ill >>> discharge the battery flat. >>> They should install a diode in the battery line to prevent back current >>> flow, but, few do. >>> >>> >>> I just checked the back-flow into one of my >>> Battery Tenders. Measured just under 1 milliamp. >>> >>> It would take 20,000 hours (2.3 years) >>> to toss off all the energy in a 20 a.h. battery. >>> The voltage sense circuitry could indeed be >>> calibrated to wash out the voltage drop of a >>> diode but the risks are pretty small. >>> >>> >>> >>> Bob . . . >>> >>> Any chance that due to the seemingly endless variation in designs among >>> brands and even within brands, everybody could be right? >>> >>> For example, Odyssey says that *their* charger-maintainer can be left >>> connected to their batteries indefinitely, but there are a *lot* of 1st >>> person accounts floating around describing very short lived Odyssey >>> batteries "even though I kept them on a maintainer" (brands unspecified ). >>> There are relatively few 1st person accounts (that I've seen) complaini ng >>> about short lived Odyssey batteries when no 'maintainers' were used. >>> >>> Charlie >>> >>> <#m_-6971088048238445844_m_-716638392855206128_m_4055673255306501323_m_ 3655902431514137369_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> >>> >> Ken, > > That was my point. The percentage of pilots with both the qualifications > *and the equipment* to verify that their particular 'maintainer' does wha t > it claims is likely not much better than the percentage of drivers who me et > both criteria. And,it's a pretty safe bet that the pilots who have short > lived SLA batteries have normal lived batteries in their cars. That's > likely because they don't think about the car battery, and just leave it > alone. > > "If it ain't broke, don't fix it." (Especially if you don't have the qual s > & tools for the job.) > > The battery doesn't need to be 'maintained' on a half-way frequently flow n > a/c, any more than the owner's car battery needs to be 'maintained'. So w hy > risk hooking it to something when the owner isn't qualified to judge its > suitability for the task? > > Charlie > ________________________________________________________________________________
Date: Jul 25, 2019
>Any chance that due to the seemingly endless variation in designs >among brands and even within brands, everybody could be right? > >For example, Odyssey says that *their* charger-maintainer can be >left connected to their batteries indefinitely, but there are a >*lot* of 1st person accounts floating around describing very short >lived Odyssey batteries "even though I kept them on a maintainer" >(brands unspecified). There are relatively few 1st person accounts >(that I've seen) complaining about short lived Odyssey batteries >when no 'maintainers' were used. > >Charlie > >Ken, > >That was my point. The percentage of pilots with both the >qualifications *and the equipment* to verify that their particular >'maintainer' does what it claims is likely not much better than the >percentage of drivers who meet both criteria. And,it's a pretty safe >bet that the pilots who have short lived SLA batteries have normal >lived batteries in their cars. That's likely because they don't >think about the car battery, and just leave it alone. > >"If it ain't broke, don't fix it." (Especially if you don't have the >quals & tools for the job.) > >The battery doesn't need to be 'maintained' on a half-way frequently >flown a/c, any more than the owner's car battery needs to be >'maintained'. So why risk hooking it to something when the owner >isn't qualified to judge its suitability for the task? But given the cost of suitable instrumentation is so low . . . Emacs! . . . there's not much standing in the way of checking things out. One can easily measure the parasitic leakage of their favorite maintainer. Then there are practical design goals. That 1 mA of current I measured suggests a voltage sense impedance on the order of 12,000 ohms. As a general rule, one doesn't want components in their design to dissipate any more energy than necessary to meed operational design goals. 1 mA is not out of line . . . modern electronics could probably build a maintainer with 100 MICRO amps of parasitic powered-down draw. I would be surprised to find one that sucked 10mA in the powered-down state. But even 10mA would give us 2,000 hours to total suck-down. It seems unlikely that this condition would ever exist. But if someone believes their maintainer offers such a risk, it's stone simple easy to find out. I mentioned earlier this week that some MEASUREMENTS of certain qualities in BALUN design have caused me to re-think what must have been ASSUMPTIONS on the part of certain authors . . . assumptions that I adopted along with countless others. So when in doubt, go measure the thing . . . Lord Kelvin would be proud of us! I'm doing some experiments here that I will share with learned authors on the 'net for validation/verification before an article devoid of assumptions will be crafted to share results. Bob . . . ________________________________________________________________________________
Date: Jul 26, 2019
At 01:42 PM 7/24/2019, you wrote: >Bob, > >Here is the picture of the resistor.... > There are companies that still make this style of resistor: Ohmite and TE Connectivity. The trick will be to first identify specifications for the failed part and then dig through the catalog items for nearest if not exact replacement. Are the failed parts still on hand? I've got a 4-wire ohmmeter that might let me measure segments on either side of the failure to deduce it's original characteristics. Bob . . . ________________________________________________________________________________
Date: Jul 27, 2019
what i have ''learned'' and practiced for years with snomo., motorcycle, lawn tractor, anything with a sealed lead acid battery is that every 6-8 weeks put the battery on a tender for a day or 2 off season. they always test about a full charge before i charge them. if they don't they are probably running something in the machine with a minute elect. draw. bob noffs On Thu, Jul 25, 2019 at 5:34 PM Ken Ryan wrote: > "Why risk hooking it to something when the owner isn't qualified to judge > its suitability for the task?" -- Well, first off, once the knowledge of > the distinction between a battery maintainer and a battery charger has be en > acquired, the owner is pretty well qualified. Next thing to consider is > that even a single complete discharge can severely damage a battery. And > the final ingredient is the observation that although we plan to fly > regularly, sh@# happens, and it is easy for time to pass. All of this > makes me wonder why anyone would prefer not to put the battery on a tende r, > unless of course doing so is difficult and time consuming. But if the > airplane is set up for it, that will not be the case. (And there is nothi ng > like a fresh, fully topped battery for spinning that engine.) As to the > comparison to automobiles, I really don't think that is fare. Most people > drive their cars daily. A better comparison would be to motorcycles, wher e > owners quickly learn (because of the cost of battery replacement) to put > their batteries on tenders at the end of riding season. > > > On Thu, Jul 25, 2019, 14:13 Charlie England wrote: > >> >> >> On Thu, Jul 25, 2019 at 4:00 PM Ken Ryan wrote: >> >>> I would be reluctant to trust unverified third party reports on this. I >>> have found that "battery literacy" is quite low. For example, many peop le >>> think a "trickle charger" is the same thing as a battery maintainer; ma ny >>> people have no idea how bad it is to fully discharge a battery, etc. Th en >>> there is the "cause or effect" problem -- i.e. are people with already bad >>> batteries more likely to resort to using a battery tender, and then whe n >>> the already damaged battery dies, blame it on the tender? I myself have a >>> lot of experience using battery maintainers, all of it good. Based on t hat, >>> I completely agree with Bob that it is impossible to damage a battery b y >>> using a properly functioning battery tender. >>> >>> On Thu, Jul 25, 2019 at 12:10 PM Charlie England >>> wrote: >>> >>>> On 7/25/2019 1:56 PM, Robert L. Nuckolls, III wrote: >>>> >>>> At 12:23 PM 7/25/2019, you wrote: >>>> >>>> Ron, >>>> For reviews check Amazon as the carry them. Read the "minus" reviews >>>> first. >>>> For my use, the Battery Tender works well and is about 1/2 the cost. >>>> I have 5 of them on various vehicle batteries and have=C3=82 not had a >>>> failure. >>>> >>>> However, there is a potential flaw in most of these low cost >>>> maintainers. >>>> If you power the unit from your normal wall power that is controlled b y >>>> a GFI, that is were the problem lurks. >>>> If the GFI trips for any reason, storms, power outage, etc., etc., and >>>> the unit looses power, it will still draw a small current from the bat tery >>>> that it is affixed to. >>>> >>>> Not a problem if you catch the problem in a few hours, maybe days.=C3 =82 >>>> However, if you are on a trip or other long away time, the maintainer will >>>> discharge the battery flat. >>>> They should install a diode in the battery line to prevent back curren t >>>> flow, but, few do. >>>> >>>> >>>> I just checked the back-flow into one of my >>>> Battery Tenders. Measured just under 1 milliamp. >>>> >>>> It would take 20,000 hours (2.3 years) >>>> to toss off all the energy in a 20 a.h. battery. >>>> The voltage sense circuitry could indeed be >>>> calibrated to wash out the voltage drop of a >>>> diode but the risks are pretty small. >>>> >>>> >>>> >>>> Bob . . . >>>> >>>> Any chance that due to the seemingly endless variation in designs amon g >>>> brands and even within brands, everybody could be right? >>>> >>>> For example, Odyssey says that *their* charger-maintainer can be left >>>> connected to their batteries indefinitely, but there are a *lot* of 1s t >>>> person accounts floating around describing very short lived Odyssey >>>> batteries "even though I kept them on a maintainer" (brands unspecifie d). >>>> There are relatively few 1st person accounts (that I've seen) complain ing >>>> about short lived Odyssey batteries when no 'maintainers' were used. >>>> >>>> Charlie >>>> >>>> <#m_-7102905767685230837_m_-6971088048238445844_m_-716638392855206128_ m_4055673255306501323_m_3655902431514137369_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F 9FDF2> >>>> >>> Ken, >> >> That was my point. The percentage of pilots with both the qualifications >> *and the equipment* to verify that their particular 'maintainer' does wh at >> it claims is likely not much better than the percentage of drivers who m eet >> both criteria. And,it's a pretty safe bet that the pilots who have short >> lived SLA batteries have normal lived batteries in their cars. That's >> likely because they don't think about the car battery, and just leave it >> alone. >> >> "If it ain't broke, don't fix it." (Especially if you don't have the >> quals & tools for the job.) >> >> The battery doesn't need to be 'maintained' on a half-way frequently >> flown a/c, any more than the owner's car battery needs to be 'maintained '. >> So why risk hooking it to something when the owner isn't qualified to ju dge >> its suitability for the task? >> >> Charlie >> > ________________________________________________________________________________
Date: Jul 27, 2019
I want to add to what Bob N. said. The proper title is "carbon pile regulator." These use a variable resistance load composed of a pile of carbon disks (usually with an alignment hole in the center), compressed by a solenoid that pushes them together harder as the voltage increases. Very common WWII regulator, and pretty reliable. There is a good site for these at: https://www.industrial-electronics.com/aircraft_6.html And you can get more data if you Google: Images "carbon pile voltage regulator." You'll probably see yours. As Bob alluded to, the resistor should not have failed...and I can surmise that either something is wrong with the system, or somebody put in the wrong part. There is lots of AT-6 information online. BUT: It is entirely legal to put a substitute resistor. A schematic on your regulator is a very good idea. I can't find the resistor manufacturer online. Perhaps Thomas Index of Manufacturers has them...but maybe the part info is hard to read. Good luck, -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490552#490552 ________________________________________________________________________________
Date: Jul 28, 2019
Subject: Connect 12V Power Pack to Airplane
I was at AirVenture this week and spent a lot of time in a chair next to my airplane. I took a door off of the BD-4C and people stopped to ask questions. It was great! I got the idea of lighting up the EFIS screens. I have a Jackery 167 watt/hour portable power pack . I borrowed a little Black & Decker 2A battery charger/maintainer . I hooked it up to the airplane and powered it from the 110V inverted on the power pack. That was all good and it gave me a few hours of power with the watt meter on the power supply reading around 30 watts. Running the 110V inverter used 4 watts and a bunch of the battery maintainer's energy was being dissipated as heat. My power supply also has a 12V DC output which measures 13.3V with no load. Could I have hooked that output to the airplane instead of the battery maintainer, without damaging the battery? -- Art Z. -- https://CheerfulCurmudgeon.com/ *Love the stranger for you yourselves were strangers in Egypt. *Deut. 10:19 ________________________________________________________________________________
Date: Jul 28, 2019
Subject: Re: Connect 12V Power Pack to Airplane
Art, I cannot answer your question directly, but on my airplane there are a couple of easily accessible places to clip on where I can feed the bus without turning on the master switch, leaving the battery out of the picture completely. Doing that also eliminates the current draw of the battery contactor. On Sun, Jul 28, 2019 at 6:00 AM Art Zemon wrote: > I was at AirVenture this week and spent a lot of time in a chair next to > my airplane. I took a door off of the BD-4C and people stopped to ask > questions. It was great! > > I got the idea of lighting up the EFIS screens. I have a Jackery 167 > watt/hour portable power pack > . I borrowed a little Black > & Decker 2A battery charger/maintainer > . > I hooked it up to the airplane and powered it from the 110V inverted on the > power pack. That was all good and it gave me a few hours of power with the > watt meter on the power supply reading around 30 watts. > > Running the 110V inverter used 4 watts and a bunch of the battery > maintainer's energy was being dissipated as heat. > > My power supply also has a 12V DC output which measures 13.3V with no > load. Could I have hooked that output to the airplane instead of the > battery maintainer, without damaging the battery? > > -- Art Z. > > -- > https://CheerfulCurmudgeon.com/ > > *Love the stranger for you yourselves were strangers in Egypt. *Deut. > 10:19 > ________________________________________________________________________________
Date: Jul 28, 2019
The aircraft battery normally gets charged with over 14 volts. So 13.3 volts are not going to hurt it. The lithium battery will discharge into a lead acid battery connected in parallel. So it is best not to connect the two batteries together. Ken's suggestion is a good one. Connect the lithium battery downstream of the battery contactor, which remains off. According to the Amazon ad, the lithium power supply can output up to 7 amps at 12 volts. So it should handle a 2 or 3 amp, 12 VDC load. Your idea to eliminate the inverter and charger is a good one. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490565#490565 ________________________________________________________________________________
Date: Jul 28, 2019
I think that you have hit on the best idea, Ken. I actually have an old fashioned cigarette lighter plug which I planned to install but never got around to installing. That will give me exactly the connect that I require and, coincidentally, my power pack came with exactly the cable that I need. -- Art Z. On Sun, Jul 28, 2019 at 10:51 AM Ken Ryan wrote: > Art, I cannot answer your question directly, but on my airplane there are > a couple of easily accessible places to clip on where I can feed the bus > without turning on the master switch, leaving the battery out of the > picture completely. Doing that also eliminates the current draw of the > battery contactor. > > On Sun, Jul 28, 2019 at 6:00 AM Art Zemon wrote: > >> I was at AirVenture this week and spent a lot of time in a chair next to >> my airplane. I took a door off of the BD-4C and people stopped to ask >> questions. It was great! >> >> I got the idea of lighting up the EFIS screens. I have a Jackery 167 >> watt/hour portable power pack >> . I borrowed a little Black >> & Decker 2A battery charger/maintainer >> . >> I hooked it up to the airplane and powered it from the 110V inverted on the >> power pack. That was all good and it gave me a few hours of power with the >> watt meter on the power supply reading around 30 watts. >> >> Running the 110V inverter used 4 watts and a bunch of the battery >> maintainer's energy was being dissipated as heat. >> >> My power supply also has a 12V DC output which measures 13.3V with no >> load. Could I have hooked that output to the airplane instead of the >> battery maintainer, without damaging the battery? >> > -- https://CheerfulCurmudgeon.com/ *Love the stranger for you yourselves were strangers in Egypt. *Deut. 10:19 ________________________________________________________________________________
Date: Jul 28, 2019
Art, you may want to use a "Powerlett" receptacle and plug. Cigarette lightets are not good at any where above about 3 amps for continuos usage. Burned a few on my RV7. Have han no issues with the Powerlet stuff. On Sun, Jul 28, 2019, 20:10 Art Zemon wrote: > I think that you have hit on the best idea, Ken. I actually have an old > fashioned cigarette lighter plug which I planned to install but never got > around to installing. That will give me exactly the connect that I require > and, coincidentally, my power pack came with exactly the cable that I need. > > -- Art Z. > > On Sun, Jul 28, 2019 at 10:51 AM Ken Ryan wrote: > >> Art, I cannot answer your question directly, but on my airplane there are >> a couple of easily accessible places to clip on where I can feed the bus >> without turning on the master switch, leaving the battery out of the >> picture completely. Doing that also eliminates the current draw of the >> battery contactor. >> >> On Sun, Jul 28, 2019 at 6:00 AM Art Zemon wrote: >> >>> I was at AirVenture this week and spent a lot of time in a chair next to >>> my airplane. I took a door off of the BD-4C and people stopped to ask >>> questions. It was great! >>> >>> I got the idea of lighting up the EFIS screens. I have a Jackery 167 >>> watt/hour portable power pack >>> . I borrowed a little Black >>> & Decker 2A battery charger/maintainer >>> . >>> I hooked it up to the airplane and powered it from the 110V inverted on the >>> power pack. That was all good and it gave me a few hours of power with the >>> watt meter on the power supply reading around 30 watts. >>> >>> Running the 110V inverter used 4 watts and a bunch of the battery >>> maintainer's energy was being dissipated as heat. >>> >>> My power supply also has a 12V DC output which measures 13.3V with no >>> load. Could I have hooked that output to the airplane instead of the >>> battery maintainer, without damaging the battery? >>> >> > > -- > https://CheerfulCurmudgeon.com/ > > *Love the stranger for you yourselves were strangers in Egypt. *Deut. > 10:19 > ________________________________________________________________________________
Subject: Repeated alternator failure
Date: Jul 30, 2019
The alternator in my Lycoming AEIO-360 engine is a Kelly Aerospace ALY 8520 formerly known as ALY 8420. The alternator fails every 80-100 hours. Replacing the brushes and the brush holder (P/N 08-13833) brings back the alternator to work. The alternator does not fail suddenly. There is a period of time prior to each failure during which the alternator works intermittently, sometimes it is on and sometimes is off. Then it stops working completely. On the removed brushes there is a black fluid (engine oil plus brush dust?). I dont know up to what extent this is normal. Any advice on how to proceed to fix this problem permanently? Thanks Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490620#490620 ________________________________________________________________________________
Subject: Re: Buy Discount adidas Yeezy Powerphase on 2019mensjordans.com
Date: Jul 31, 2019
Now surely what does customer service mean to you (https://www.realinteract.com/what-does-great-customer-service-mean-to-you/) will be simply its helping effectively with good manners, then the results of good customer service is Read this topic online here: http://forums.matronics.com/viewtopic.php?p=490621#490621 ________________________________________________________________________________
Date: Jul 31, 2019
Subject: Re: Repeated alternator failure
Argonaut, I don't know much about alternators but I have never seen one that needs (or is supposed to have) any fluid inside, including motor oil. I would look for, and eliminate, the engine oil leak and see if that preserves your alternator. Now I'm going to sit back and see if my guess aligns with what the truly knowledgeable people suggest. Cheers, -- Art Z. On Tue, Jul 30, 2019 at 10:59 PM Argonaut36 wrote: > > The alternator in my Lycoming AEIO-360 engine is a Kelly Aerospace ALY > 8520 formerly known as ALY 8420. The alternator fails every 80-100 hours . > Replacing the brushes and the brush holder (P/N 08-13833) brings back the > alternator to work. > The alternator does not fail suddenly. There is a period of time prior t o > each failure during which the alternator works intermittently, sometimes it > is on and sometimes is off. Then it stops working completely. > On the removed brushes there is a black fluid (engine oil plus brush > dust?). I don=99t know up to what extent this is normal. > Any advice on how to proceed to fix this problem permanently? -- https://CheerfulCurmudgeon.com/ *Love the stranger for you yourselves were strangers in Egypt. *Deut. 10:19 ________________________________________________________________________________
Date: Jul 31, 2019
At 10:43 PM 7/30/2019, you wrote: > >The alternator in my Lycoming AEIO-360 engine is >a Kelly Aerospace ALY 8520 formerly known as >ALY 8420. The alternator fails every 80-100 >hours. Replacing the brushes and the brush >holder (P/N 08-13833) brings back the alternator to work. >The alternator does not fail suddenly. There is >a period of time prior to each failure during >which the alternator works intermittently, >sometimes it is on and sometimes is off. Then it stops working completely. >On the removed brushes there is a black fluid >(engine oil plus brush dust?). I don=99t know >up to what extent this is normal. >Any advice on how to proceed to fix this problem permanently? >Thanks > I there are no obvious sources of oil external to the alternator (engine leaks) then the next best guess i the rear alternator bearing. These are normally sealed and factory loaded with the appropriate grease. If the seal is leaking, the grease can migrate out and onto the slip rings. Bearings come in all manner of pedigree but verifying seal quality and sometimes type of grease can be problematic. Next time you replace brushes, replace the bearing too . . . and let us know how it goes. Bob . . . ________________________________________________________________________________
Date: Jul 31, 2019
Date: Aug 01, 2019
Subject: Marking Wires
I am going to be making a bunch of harnesses next week and would like to find a good solution for marking wires. I need to custom label very clear and specific markings on many wires to make it easy for the customer to install so I was thinking of getting a DYMO Printer and using their 1/4" Heat-Shrink. Has anyone used this system and would it work for 22 gauge wire? I'm afraid it either won't shrink down far enough to be secure on the wire or won't be readable once it does. Thank you ________________________________________________________________________________
Date: Aug 01, 2019
Subject: Re: Marking Wires
You're right; it won't shrink enough for 22 AWG wire. Shrink some small, unmarked shrink tube on the wire. Then shrink your label over that. -- Art Z. On Thu, Aug 1, 2019 at 10:45 AM Sebastien wrote: > I am going to be making a bunch of harnesses next week and would like to > find a good solution for marking wires. I need to custom label very clear > and specific markings on many wires to make it easy for the customer to > install so I was thinking of getting a DYMO Printer and using their 1/4" > Heat-Shrink. Has anyone used this system and would it work for 22 gauge > wire? I'm afraid it either won't shrink down far enough to be secure on the > wire or won't be readable once it does. > > Thank you > -- https://CheerfulCurmudgeon.com/ *Love the stranger for you yourselves were strangers in Egypt. *Deut. 10:19 ________________________________________________________________________________
Date: Aug 01, 2019
Is that really a disadvantage? Once bundled, the label won't travel far. And I've found that my labels that can't be moved a bit often are difficult to read because the printed area happens to face into a bundle, or has another wire's label in the way. Sliding them along the wire an inch or two, and being able to rotate them would be an advantage, for me. Charlie On 8/1/2019 11:06 AM, Art Zemon wrote: > You're right; it won't shrink enough for 22 AWG wire. Shrink some > small, unmarked shrink tube on the wire. Then shrink your label over that. > > -- Art Z. > > On Thu, Aug 1, 2019 at 10:45 AM Sebastien > wrote: > > I am going to be making a bunch of harnesses next week and would > like to find a good solution for marking wires. I need to custom > label very clear and specific markings on many wires to make it > easy for the customer to install so I was thinking of getting a > DYMO Printer and using their 1/4" Heat-Shrink. Has anyone used > this system and would it work for 22 gauge wire? I'm afraid it > either won't shrink down far enough to be secure on the wire or > won't be readable once it does. > > Thank you > > -- > https://CheerfulCurmudgeon.com/ > > /Love the stranger for you yourselves were strangers in Egypt. /Deut. > 10:19 --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Aug 01, 2019
At 11:06 AM 8/1/2019, you wrote: >You're right; it won't shrink enough for 22 AWG wire. Shrink some >small, unmarked shrink tube on the wire. Then shrink your label over that. Another option: Emacs! Bob . . . ________________________________________________________________________________
Date: Aug 01, 2019
The labels that I had would slide freely up and down the 22 awg wire. That's why I had to put a smaller sleeve underneath On Thu, Aug 1, 2019, 1:06 PM Charlie England wrote: > Is that really a disadvantage? Once bundled, the label won't travel far. > And I've found that my labels that can't be moved a bit often are difficult > to read because the printed area happens to face into a bundle, or has > another wire's label in the way. Sliding them along the wire an inch or > two, and being able to rotate them would be an advantage, for me. > > Charlie > > > On 8/1/2019 11:06 AM, Art Zemon wrote: > > You're right; it won't shrink enough for 22 AWG wire. Shrink some small, > unmarked shrink tube on the wire. Then shrink your label over that. > > -- Art Z. > > On Thu, Aug 1, 2019 at 10:45 AM Sebastien wrote: > >> I am going to be making a bunch of harnesses next week and would like to >> find a good solution for marking wires. I need to custom label very clear >> and specific markings on many wires to make it easy for the customer to >> install so I was thinking of getting a DYMO Printer and using their 1/4" >> Heat-Shrink. Has anyone used this system and would it work for 22 gauge >> wire? I'm afraid it either won't shrink down far enough to be secure on the >> wire or won't be readable once it does. >> >> Thank you >> > -- > https://CheerfulCurmudgeon.com/ > > *Love the stranger for you yourselves were strangers in Egypt. *Deut. > 10:19 > > > Virus-free. > www.avast.com > > <#m_9019167577042916761_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> > ________________________________________________________________________________
Date: Aug 01, 2019
July 07, 2019 - August 01, 2019
AeroElectric-Archive.digest.vol-pa
