AeroElectric-Archive.digest.vol-pl
June 07, 2020 - June 30, 2020
         declare an emergency.
         This scenario first assumes TWO critical failures
         during the consumption of one tank of fuel . . .
         about 3-4 hour window. Part 23 certs don't
         get concerned with dual failures at all.
         Part 25 and heavier will wade into the reliability
         quagmire with mountains of computer generated probability
         studies that get 'worked' on until somebody
         finally sprinkles the holy water and off they
         go.
         Ask Capt. Sullivan what he thinks about
         reliability studies . . .
      https://www.youtube.com/watch?v=HKJ1lIh2Cgk
         So we're left to our own devices which in reality
         are not so bad.
         The short answer is: A diligently maintained
         battery is the most reliable source of energy
         on the airplane. Replacing it when ability
         to store energy drops below some benchmark
         (generally 75 to 80% of new) means that it
         always cranks the engine and will provide a
         quantified option for dealing with alternator
         failure. Two batteries just doubles your
         preventative maintenance labor. Further,
         you need to decide if plan-b can reliably
         depend on the sum total of energy in two
         batteries . . . or will they be sized to
         independently step up to the task? The
         second option calls for 2X the battery
         weight and volume; the first option complicates
         calculations and switching operations for
         carrying out a plan-b that shouldn't ever
         happen. BOTH options still demand good
         preventative maintenance.
         Just as you KNOW fuel aboard when you launch,
         you also need to know Watt-Hours aboard
         no matter how many batteries you're carrying.
         If you have TWO properly maintained batteries,
         in all likelihood, you'll be carrying around
         $twice$ the hardware with virtually no value
         added to the ship's overall reliability.
Subject: Re: digest distribution stopped?
Date: Jun 07, 2020
farmrjohn wrote: > Has the digest distribution stopped? I haven't received one for some time now. This happened to me a couple if times over the years. It turns out the Servers that the Matronics list uses are a bit finicky about the other e-mail Servers they will talk to, and the solution was to change the e-mail address you use. Since I changed mine to a gmail.com address, I've not had a problem. Hope it works for you. -------- Bob Dawson Europa XS TG || 912 ULS || G-NHRJ || Dynon Skyview || PilotAware || SmartAss3 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=496673#496673 ________________________________________________________________________________
Subject: Re: DIY replacement for Rotax voltage regulator
Date: Jun 08, 2020
On 2020-06-08, at 01:25, GTH wrote: > Thanks for your offer. > > I was able to open the files with a free version of Eagle I downloaded last week, and converted them to gerber files that can be read by any CAD program - and any vendor for that matter. > But I'm not at all familiar with Eagle so I'm not sure I did it right. > So if you or anyone can provide verified gerber files I'd willingly publish them so one can directly order from a PCB vendor. Gilles - I have sent to Bob the (several) files that kind folk converted for me to be readable by the current version of EAGLE for Mac. I expect he will announce when they are loaded alongside the other files for the Miller regulator. I=99ve had a look at the export possibilities provided by my version of EAGLE (9.6.1) and the file format possibilities do not include Gerber - see attached screenshot. Maybe someone can say if one of the options shown would be more universal than a .BRD file. Or once the .BRD files are put up by Bob, folk can play with them and try translating to Gerber. in friendship Rowland | Rowland Carson ... that's Rowland with a 'w' ... | http://www.rowlandcarson.org.uk | Skype, Twitter: rowland_carson Facebook: Rowland Carson ________________________________________________________________________________
Date: Jun 08, 2020
Most if my AeroElectric emails go to the junk folder, have you checked there John Sent from my iPad ----x--O--x---- > On 8 Jun 2020, at 8:06 am, BobD wrote: > > > > farmrjohn wrote: >> Has the digest distribution stopped? I haven't received one for some time now. > > > This happened to me a couple if times over the years. It turns out the Servers that the Matronics list uses are a bit finicky about the other e-mail Servers they will talk to, and the solution was to change the e-mail address you use. Since I changed mine to a gmail.com address, I've not had a problem. > > Hope it works for you. > > -------- > Bob Dawson > Europa XS TG || 912 ULS || G-NHRJ || Dynon Skyview || PilotAware || SmartAss3 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=496673#496673 > > > > > > > > > ________________________________________________________________________________
Date: Jun 08, 2020
/Le 08/06/2020 13:04, Rowland Carson a crit: / > / > / > / > / > /Ive had a look at the export possibilities provided by my version of > EAGLE (9.6.1) and the file format possibilities do not include Gerber > - see attached screenshot. Maybe someone can say if one of the options > shown would be more universal than a .BRD file. Or once the .BRD files > are put up by Bob, folk can play with them and try translating to Gerber./ Hi Rowland, Thanks for that. If I recall correctly I tried the CAM option(s) to generate the gerber and .drl files. Will post them on the webpage for anyone to download. -- Best regards, Gilles http://contrails.free.fr http://lapierre.skunkworks.free.fr ________________________________________________________________________________
Date: Jun 08, 2020
Subject: Re: Physical construction of Z101 engine bus & battery
bus At 09:20 PM 6/7/2020, you wrote: >SDSEFI recommends 2 alternators and a battery. If you have a single >battery and alternator they recommend an additional battery that is >only connected to the ENG BUS for an emergency. The recommended >procedure is to charge that battery on the 1st of the month and load >test yearly. Not a particularly definitive battery management philosophy. "Charging once a month" whether needed or not? "Load test" is not specific . . . what kind of load and for discovery of what condition? Internal impedance (cranking) or capacity (endurance)? How would that knowledge augment the pilot's prospects for dealing competently with an alternator failure? How would these batteries be selected and configured in the architecture? What would the plan-b checklist look like? Recall that the ultimate goal for crafting a failure tolerant architecture is to prevent any single failure from becoming an emergency. That goal cannot be realized without first knowing the ENERGY requirements for the TOTAL constellation of hardware necessary to conduct a comfortable termination of flight within some ENDURANCE value determined by the BUILDER . . . not by some 'authority from afar' who will never ride in the airplane. Bob . . . ________________________________________________________________________________
Date: Jun 08, 2020
bus Bob, you said: "If you have TWO properly maintained batteries, in all likelihood, you'll be carrying around $twice$ the hardware with virtually no value added to the ship's overall reliability." Help me understand why the following statement is not correct: If you have TWO properly maintained alternators, plus a battery (sized for minimum endurance requirements) in all likelihood, you'll be carrying around $twice$ the hardware with virtually no value added to the ship's overall reliability. Ken On Sun, Jun 7, 2020 at 6:56 PM Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 05:26 PM 6/7/2020, you wrote: > > I am not speaking to any engine manufacturers recommendation (although th e > Honda Viking manufacturer does recommend two batteries. I just thought > I was applying logic -- if dual alternator=C3=82 + battery (triple power source) > is desirable for electrically=C3=82 dependent engines, wouldn't that reas oning > imply that if the second alternator is not practical, a second battery > could be used as the third power source? I could ask you a similar > question: > Are not two independent power sources (battery and alternator) sufficient > to meet the needs of the electrically=C3=82 dependent engine. Obviously y ou > saw value in adding the second alternator. Why no value in adding the > second battery? > > > Excellent question. > > It's a problem in energy budgets combined with > efforts to assure continued airworthiness. > > The airplane cannot do without a battery if > you're going to have a starter. Depending on > your planned mission profiles, you will want > to size the battery (1) for cranking then > (2) minimum endurance in alternator-out modes. > > This study gave impetus for the creation of > the endurance bus . . . a fast and predictable > way to economically tap known quantity of energy > stored in the battery's chemistry. > > Z13/8 was a small but significant amplification > of that idea . . . the second alternator's endurance > had no practical limits. Hence, energy on the chemistry > just might be held completely in reserve for > descent and approach to landing. > > Z13/20 (and the aux alternator option on > Z101) expanded the Z13/8 endurance opportunity > by a factor of 2.5 or better. > > Okay, suppose the drive pad isn't available. > We are still charged with identifying and the > delivering to energy required to comfortably > terminate a worst-case mission. > > This means that as a part of routine maintenance > the ship's chemistry needs to be monitored for > capability. We could certainly store that energy > on TWO devices but to what advantage? If we're laboring > under the notion that a battery can suddenly become > unavailable during one tank of gas, then we have > to assume that EITHER battery can roll over and > die . . . okay, how would that failure be > annunciated . . . how would remaining energy be > managed . . . ? > > I think that's the scenario anticipated by the > folks that crafted that battery manager with a > full-wave rectifier that -anded- two, completely > isolated batteries together. Assume the alternator > has quit and some time later one battery > craps out. How does the pilot become aware of the > problem and what kind of energy juggling issues > are presented when the available energy drops > to half? This assuming he really knows that the > two batteries were performing equally and has > recently quantified their condition, he now > has to come up with a new "plan C?" and perhaps > declare an emergency. > > This scenario first assumes TWO critical failures > during the consumption of one tank of fuel . . . > about 3-4 hour window. Part 23 certs don't > get concerned with dual failures at all. > Part 25 and heavier will wade into the reliability > quagmire with mountains of computer generated probability > studies that get 'worked' on until somebody > finally sprinkles the holy water and off they > go. > > Ask Capt. Sullivan what he thinks about > reliability studies . . . > > https://www.youtube.com/watch?v=HKJ1lIh2Cgk > > So we're left to our own devices which in reality > are not so bad. > > The short answer is: A diligently maintained > battery is the most reliable source of energy > on the airplane. Replacing it when ability > to store energy drops below some benchmark > (generally 75 to 80% of new) means that it > always cranks the engine and will provide a > quantified option for dealing with alternator > failure. Two batteries just doubles your > preventative maintenance labor. Further, > you need to decide if plan-b can reliably > depend on the sum total of energy in two > batteries . . . or will they be sized to > independently step up to the task? The > second option calls for 2X the battery > weight and volume; the first option complicates > calculations and switching operations for > carrying out a plan-b that shouldn't ever > happen. BOTH options still demand good > preventative maintenance. > > Just as you KNOW fuel aboard when you launch, > you also need to know Watt-Hours aboard > no matter how many batteries you're carrying. > > If you have TWO properly maintained batteries, > in all likelihood, you'll be carrying around > $twice$ the hardware with virtually no value > added to the ship's overall reliability. > > Bob . . . > ________________________________________________________________________________
Date: Jun 08, 2020
I've checked the junk folder, nothing there. I re-subscribed and got a confirmation email from Matronics, but no digest yet. Will continue watching both inbox and junk folder. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=496680#496680 ________________________________________________________________________________
battery bus
Date: Jun 08, 2020
Bob, Here is what the SDS EFI manual suggest. I didn=99t hit every point in my email to the group. I personally have the 2 ALT/1 BATT option. Backup Electrical Power Considerations Electrical power is necessary to keep the ECU, fuel pump, coils and injectors running so it=99s important to think about having a backup power source available. In the case of Lycoming engines, a small backup alternator like the B&C SD8, SD20 or BC410-H SD can be fitted to a vacuum pump pad. On other engines, a small second alternator could be fitted. If you don=99t have a second alternator, you should have a small backup battery. Sizing would depend on your typical/ maximum distance between airports. Current draw of the pump, ECU, injectors and coils would be around 12 to 14 amps. A 12 amp/hour battery should give you a solid 30-40 minutes of flight time, just running the engine electrics. An 18 amp/hour one, around 1 hour. We want to be able to sustain at least 10 volts to the electrics. We=99ve found the most reliable, simple and light way to get backup battery power to the engine electrics is a single 12 to 14 gauge wire running from the backup battery, through a 30 amp ATO fuse, to a heavy duty switch, to an emergency buss where all the engine electrics can receive power. Simply charge the backup battery every 30 days and load test annually. If you have the recommended check engine light fitted, it will warn you any time the battery voltage falls below 12.5V. You can monitor battery voltage in Gauge 3 mode. Jeff Parker > On 8Jun, 2020, at 11:18, Robert L. Nuckolls, III wrote: > > At 09:20 PM 6/7/2020, you wrote: >> SDSEFI recommends 2 alternators and a battery. If you have a single battery and alternator they recommend an additional battery that is only connected to the ENG BUS for an emergency. The recommended procedure is to charge that battery on the 1st of the month and load test yearly. > > Not a particularly definitive battery management > philosophy. "Charging once a month" whether needed > or not? "Load test" is not specific . . . what kind > of load and for discovery of what condition? Internal > impedance (cranking) or capacity (endurance)? > How would that knowledge augment the pilot's > prospects for dealing competently with an alternator > failure? > > How would these batteries be selected and configured > in the architecture? What would the plan-b checklist > look like? Recall that the ultimate goal for crafting > a failure tolerant architecture is to prevent any > single failure from becoming an emergency. > > That goal cannot be realized without first knowing the > ENERGY requirements for the TOTAL constellation > of hardware necessary to conduct a comfortable termination > of flight within some ENDURANCE value determined by > the BUILDER . . . not by some 'authority from afar' > who will never ride in the airplane. > > Bob . . . > ________________________________________________________________________________
Date: Jun 08, 2020
Subject: Exploring a Different Way to Wire Avionics
Background: Traditionally, all the inter-connections among avionics devices have been m ade via a carefully made custom-built wiring harness.=C2-=C2- Most avionics use DB-9/DB-25 connectors and the custom wire harness approac h comes down to connecting pin #1 on device A to pin #7 on device B and pin #2 of device A to pin #12 on device B, etc, etc.=C2- All this inter-conn ection is done in the harness. I see some downside to this approach: 1. Makes the harness more difficult to fabricate2. Possibly embeds splices in the harness3. Makes trouble shooting more difficult4. Makes subsequent m ods, updates, equipment upgrades more difficult Different Way? Create essentially a fancy junction box that has a bunch of DB-9 & DB-25 co nnectors, one for each device and connects directly to each device.=C2- T hen in this j-box, make all of the device A pin 1 to device B pin 7 inter-c onnections.=C2- This could all be soldered.=C2- It might make pin-shari ng/splicing easier. I'm aware that Advanced Flight Systems has a product that does something li ke this.=C2- I wonder how their inter-connection scheme works because of the multitude of interconnection possibilities with different avionics devi ces.=C2- It seems like all of the combinations/permutations would be diff icult to manage on a circuit board. Some advantages to this approach: 1. Harnesses are much simpler2. All of the "intelligence" is in this j-box/ switch-board which might make mods less labor intensive Some disadvantages:1. Requires more connectors to get the job done2. Adds a nother component (weight?) Any thoughts pro or con are greatly appreciated, -Jeff ________________________________________________________________________________
From: William Daniell <wdaniell.longport(at)gmail.com>
Date: Jun 08, 2020
Subject: Z16 and three position switch
Some of you will remember that I had two switches one for bat and one for ALT on my Z16 because I couldn't obtain a 3 position switch in Colombia where I built my Europa. I always operated the switches BAT only only and Bat ON/ALT ON but never BAT off ALT on. I also reported that every so often the amp reading on my dynon skyview would rise steadily up and off the chart at which point the red X would appear. Subsequently the amp reading would reappear and would fall from 72 down to normal (7-10 depending on the load) and remain steady thereafter. Volts remain stable at 13.8 throughout the rise and fall of the amps. The Skyview is stock using the Dynon Shunt and the Z16 is stock apart from the two switches. I have a Hall Effect sensor with a separate display on the + wire to the battery and this remains within what one would expect 4-5A after start up and then falling to low Amp once the battery has recharged. In the light of this and the absence of exciting sparks and smoke during the last 200 hours I therefore assumed that this must be some sort of Dynon glitch. I had on my list of things to do to check on the Amp reading by an independent instrument. So here is the question: I have now installed the 3 position switch recommended by Bob instead of the two separate switches and the problem has not recurred. Any thoughts? William Daniell LONGPORT +1 786 878 0246 ________________________________________________________________________________
bus
Date: Jun 08, 2020
The amount of redundancy desired all depends. Will the aircraft be flying long distances over hostile terrain or water? Will the aircraft be flying IFR or at night? Is the engine dependent on electrical power? Is the pilot willing to carry extra weight to avoid repairs on long cross countries? The important thing is to design an electrical system that does not have unexpected failure modes and that is resistant to pilot error. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=496686#496686 ________________________________________________________________________________
Date: Jun 08, 2020
Subject: Re: Exploring a Different Way to Wire Avionics
Approach Fast Stack has been doing this for years - buy a "Hub" and then a purpose build cable for each device. On Mon, Jun 8, 2020 at 12:48 PM Jeff Luckey wrote: > *Background:* > > Traditionally, all the inter-connections among avionics devices have been > made via a carefully made custom-built wiring harness. > > Most avionics use DB-9/DB-25 connectors and the custom wire harness > approach comes down to connecting pin #1 on device A to pin #7 on device B > and pin #2 of device A to pin #12 on device B, etc, etc. All this > inter-connection is done in the harness. > > I see some downside to this approach: > > 1. Makes the harness more difficult to fabricate > 2. Possibly embeds splices in the harness > 3. Makes trouble shooting more difficult > 4. Makes subsequent mods, updates, equipment upgrades more difficult > > > *Different Way?* > > Create essentially a fancy junction box that has a bunch of DB-9 & DB-25 > connectors, one for each device and connects directly to each device. Then > in this j-box, make all of the device A pin 1 to device B pin 7 > inter-connections. This could all be soldered. It might make > pin-sharing/splicing easier. > > I'm aware that Advanced Flight Systems has a product that does something > like this. I wonder how their inter-connection scheme works because of the > multitude of interconnection possibilities with different avionics > devices. It seems like all of the combinations/permutations would be > difficult to manage on a circuit board. > > Some advantages to this approach: > > 1. Harnesses are much simpler > 2. All of the "intelligence" is in this j-box/switch-board which might > make mods less labor intensive > > Some disadvantages: > 1. Requires more connectors to get the job done > 2. Adds another component (weight?) > > > Any thoughts pro or con are greatly appreciated, > > -Jeff > > ________________________________________________________________________________
Date: Jun 08, 2020
Subject: Breaker
Anyone need a breaker for their aircraft project? I'm taking a load to the dump. ________________________________________________________________________________
Date: Jun 08, 2020
Jim Weir wrote an article about a simpler(?) way to connect avionics. Personally, I thought it was about as easy to just develop some skill soldering D-subs and use the standard stuff. There are a few tricks to soldering them but once you have learned them, it is pretty easy. http://www.rstengineering.com/rst/articles/karmic3.pdf One technique is to strip the wire, apply a bit of solder to the wire end, heat up the side of the cup on the D-sub and simultaneously insert the wire end. It is pretty quick with the right iron and solder. -Kent > On Jun 8, 2020, at 1:34 PM, Jeff Luckey wrote: > > Background: > > Traditionally, all the inter-connections among avionics devices have been made via a carefully made custom-built wiring harness. > > Most avionics use DB-9/DB-25 connectors and the custom wire harness approach comes down to connecting pin #1 on device A to pin #7 on device B and pin #2 of device A to pin #12 on device B, etc, etc. All this inter-connection is done in the harness. > > I see some downside to this approach: > > 1. Makes the harness more difficult to fabricate > 2. Possibly embeds splices in the harness > 3. Makes trouble shooting more difficult > 4. Makes subsequent mods, updates, equipment upgrades more difficult > > > Different Way? > > Create essentially a fancy junction box that has a bunch of DB-9 & DB-25 connectors, one for each device and connects directly to each device. Then in this j-box, make all of the device A pin 1 to device B pin 7 inter-connections. This could all be soldered. It might make pin-sharing/splicing easier. > > I'm aware that Advanced Flight Systems has a product that does something like this. I wonder how their inter-connection scheme works because of the multitude of interconnection possibilities with different avionics devices. It seems like all of the combinations/permutations would be difficult to manage on a circuit board. > > Some advantages to this approach: > > 1. Harnesses are much simpler > 2. All of the "intelligence" is in this j-box/switch-board which might make mods less labor intensive > > Some disadvantages: > 1. Requires more connectors to get the job done > 2. Adds another component (weight?) > > > Any thoughts pro or con are greatly appreciated, > > -Jeff > > > > > > > > > ________________________________________________________________________________
Date: Jun 08, 2020
Subject: Z101 main alt wiring
Bob, Tracing the main alt field circuit from the main bus, I see the following wire sizes: - 16 AWG fusible link - 12 AWG wire to 5A breaker & then to power master switch - 20 AWG wire to regulator - 20 AWG wire to alternator field I don't understand the need for the 12 AWG wire feeding the master, which has only 20 AWG coming out of it to the load. Thanks, David --- David Carter david(at)carter.net ________________________________________________________________________________
Date: Jun 08, 2020
James, Thanks for the reference to Approach Fast Stack.=C2- That pretty much val idates the concept, doesn't it? on(at)vnet.net> wrote: net.net> Jim Weir wrote an article about a simpler(?) way to connect avionics.=C2- Personally, I thought it was about as easy to just develop some skill sold ering D-subs and use the standard stuff.=C2- There are a few tricks to so ldering them but once you have learned them, it is pretty easy. http://www.rstengineering.com/rst/articles/karmic3.pdf One technique is to strip the wire, apply a bit of solder to the wire end, heat up the side of the cup on the D-sub and simultaneously insert the wire end.=C2- It is pretty quick with the right iron and solder. -Kent > On Jun 8, 2020, at 1:34 PM, Jeff Luckey wrote: > > Background: > > Traditionally, all the inter-connections among avionics devices have been made via a carefully made custom-built wiring harness.=C2- > > Most avionics use DB-9/DB-25 connectors and the custom wire harness appro ach comes down to connecting pin #1 on device A to pin #7 on device B and p in #2 of device A to pin #12 on device B, etc, etc.=C2- All this inter-co nnection is done in the harness. > > I see some downside to this approach: > > 1. Makes the harness more difficult to fabricate > 2. Possibly embeds splices in the harness > 3. Makes trouble shooting more difficult > 4. Makes subsequent mods, updates, equipment upgrades more difficult > > > Different Way? > > Create essentially a fancy junction box that has a bunch of DB-9 & DB-25 connectors, one for each device and connects directly to each device.=C2- Then in this j-box, make all of the device A pin 1 to device B pin 7 inter -connections.=C2- This could all be soldered.=C2- It might make pin-sha ring/splicing easier. > > I'm aware that Advanced Flight Systems has a product that does something like this.=C2- I wonder how their inter-connection scheme works because o f the multitude of interconnection possibilities with different avionics de vices.=C2- It seems like all of the combinations/permutations would be di fficult to manage on a circuit board. > > Some advantages to this approach: > > 1. Harnesses are much simpler > 2. All of the "intelligence" is in this j-box/switch-board which might ma ke mods less labor intensive > > Some disadvantages: > 1. Requires more connectors to get the job done > 2. Adds another component (weight?) > > > Any thoughts pro or con are greatly appreciated, > > -Jeff > > > > > > > > > - S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Jun 08, 2020
Not just more connectors. Theres a huge bunch of redundancy to most of the pins on the back of a GPS or VOR receiver or transceiver; of about 300 pins on the back of my IFD540 maybe 50 are connected; which 50 depends on what else is in the system (CDI/OBS or HSI? Autopilot? Second GPS slaved to first?) so either your standard cables to your patch box are immensely thick and bulky and expensive, or you have to make up custom cables to the patch box. In which case, you might as well make up a custom harness. Honestly, its not difficult or complicated to make a harness; the complicated bit is working out what pin should connect to what pin, and you have to do that anyway. On Jun 8, 2020, at 2:10 PM, James Quinn wrote: Approach Fast Stack has been doing this for years - buy a "Hub" and then a purpose build cable for each device. On Mon, Jun 8, 2020 at 12:48 PM Jeff Luckey wrote: Background: Traditionally, all the inter-connections among avionics devices have been made via a carefully made custom-built wiring harness. Most avionics use DB-9/DB-25 connectors and the custom wire harness approach comes down to connecting pin #1 on device A to pin #7 on device B and pin #2 of device A to pin #12 on device B, etc, etc. All this inter-connection is done in the harness. I see some downside to this approach: 1. Makes the harness more difficult to fabricate 2. Possibly embeds splices in the harness 3. Makes trouble shooting more difficult 4. Makes subsequent mods, updates, equipment upgrades more difficult Different Way? Create essentially a fancy junction box that has a bunch of DB-9 & DB-25 connectors, one for each device and connects directly to each device. Then in this j-box, make all of the device A pin 1 to device B pin 7 inter-connections. This could all be soldered. It might make pin-sharing/splicing easier. I'm aware that Advanced Flight Systems has a product that does something like this. I wonder how their inter-connection scheme works because of the multitude of interconnection possibilities with different avionics devices. It seems like all of the combinations/permutations would be difficult to manage on a circuit board. Some advantages to this approach: 1. Harnesses are much simpler 2. All of the "intelligence" is in this j-box/switch-board which might make mods less labor intensive Some disadvantages: 1. Requires more connectors to get the job done 2. Adds another component (weight?) Any thoughts pro or con are greatly appreciated, -Jeff ________________________________________________________________________________
Date: Jun 08, 2020
Subject: Re: Breaker
LoL! Can I use that to turn-on my nav lights? ... Anyone need a breaker for their aircraft project? I'm taking a load to the dump. ________________________________________________________________________________
Date: Jun 08, 2020
I, too, have wondered how they accommodate various 'random ' avionics. It wouldn't be too surprising if they're doing the 'pin relocation' task for you in the custom interconnect cables for which you're paying big bucks. Charlie On Mon, Jun 8, 2020 at 2:07 PM Jeff Luckey wrote: > James, > > Thanks for the reference to Approach Fast Stack. That pretty much > validates the concept, doesn't it? > > kjashton(at)vnet.net> wrote: > > > kjashton(at)vnet.net> > > Jim Weir wrote an article about a simpler(?) way to connect avionics. > Personally, I thought it was about as easy to just develop some skill > soldering D-subs and use the standard stuff. There are a few tricks to > soldering them but once you have learned them, it is pretty easy. > http://www.rstengineering.com/rst/articles/karmic3.pdf > > One technique is to strip the wire, apply a bit of solder to the wire end, > heat up the side of the cup on the D-sub and simultaneously insert the wire > end. It is pretty quick with the right iron and solder. > -Kent > > > On Jun 8, 2020, at 1:34 PM, Jeff Luckey wrote: > > > > Background: > > > > Traditionally, all the inter-connections among avionics devices have > been made via a carefully made custom-built wiring harness. > > > > Most avionics use DB-9/DB-25 connectors and the custom wire harness > approach comes down to connecting pin #1 on device A to pin #7 on device B > and pin #2 of device A to pin #12 on device B, etc, etc. All this > inter-connection is done in the harness. > > > > I see some downside to this approach: > > > > 1. Makes the harness more difficult to fabricate > > 2. Possibly embeds splices in the harness > > 3. Makes trouble shooting more difficult > > 4. Makes subsequent mods, updates, equipment upgrades more difficult > > > > > > Different Way? > > > > Create essentially a fancy junction box that has a bunch of DB-9 & DB-25 > connectors, one for each device and connects directly to each device. Then > in this j-box, make all of the device A pin 1 to device B pin 7 > inter-connections. This could all be soldered. It might make > pin-sharing/splicing easier. > > > > I'm aware that Advanced Flight Systems has a product that does something > like this. I wonder how their inter-connection scheme works because of the > multitude of interconnection possibilities with different avionics > devices. It seems like all of the combinations/permutations would be > difficult to manage on a circuit board. > > > > Some advantages to this approach: > > > > 1. Harnesses are much simpler > > 2. All of the "intelligence" is in this j-box/switch-board which might > make mods less labor intensive > > > > Some disadvantages: > > 1. Requires more connectors to get the job done > > 2. Adds another component (weight?) > > > > > > Any thoughts pro or con are greatly appreciated, > > > > -Jeff > > > > > > > > > > > > > > > > > > > > http://www.m==================== > http://forums.matronics.com > ===================== > http://wiki.matron======================= > <http://wiki.matronics.com> > > ________________________________________________________________________________
Date: Jun 08, 2020
Subject: Re: Z101 main alt wiring
On Mon, Jun 8, 2020 at 1:47 PM David Carter wrote: > Bob, > > Tracing the main alt field circuit from the main bus, I see the following > wire sizes: > - 16 AWG fusible link > - 12 AWG wire to 5A breaker & then to power master switch > - 20 AWG wire to regulator > - 20 AWG wire to alternator field > > I don't understand the need for the 12 AWG wire feeding the master, which > has only 20 AWG coming out of it to the load. > > Thanks, > David > > > --- > David Carter > david(at)carter.net > Reasonable question; might have been driven by 'off-the-shelf' fusible link size availability. 22awg (minimum reasonable size to work with) link (sleeved with silicone tubing) to 18awg would get the job done. 20awg after the breaker because the breaker protects it. I've tested the silicone tubing trick on 22awg with a direct short on a 12v tractor battery. The wire vaporizes, leaving a smoky interior lining on the clear silicone tubing, but the tubing contained the 'event'. Charlie ________________________________________________________________________________
Date: Jun 08, 2020
225 Amp so it should be good. Aeroelectric said my picture was too big so here's a smaller version. On Mon, Jun 8, 2020 at 12:20 PM Jeff Luckey wrote: > LoL! > > Can I use that to turn-on my nav lights? ... > > wrote: > > > Anyone need a breaker for their aircraft project? I'm taking a load to the > dump. > > ________________________________________________________________________________
Date: Jun 08, 2020
Should be perfect for a *real* all electric airplane on a budget.... Seriously, did you try listing stuff like that on ebay? I've bought some 3 phase stuff there for my house & shop (yes, I've got Delta to the house), and I know some machine shop guys who watch auction sites for stuff like that. Charlie On Mon, Jun 8, 2020 at 3:19 PM Sebastien wrote: > 225 Amp so it should be good. > > Aeroelectric said my picture was too big so here's a smaller version. > > On Mon, Jun 8, 2020 at 12:20 PM Jeff Luckey wrote: > >> LoL! >> >> Can I use that to turn-on my nav lights? ... >> >> wrote: >> >> >> Anyone need a breaker for their aircraft project? I'm taking a load to >> the dump. >> >> >> >> >> >> ________________________________________________________________________________
Date: Jun 08, 2020
bus Hi Ken, I'll take a swing at it, but would suggest that it's not quite the right question. I get your point, but the answer 'depends'. If using electronic fuel injection, the current demands mean that a single PC680 style battery (in 'new' condition) will only buy you about 30-40 minutes of flight time after alternator failure. A 2nd PC680 only adds another 30-40 minutes. On an engine that allows two alts, either of which can keep the engine running and the panel lit, a typical alt (ex: 55A Denso) is lighter than a 2nd battery, not much more expensive (actually much cheaper than an actual Odyssey branded PC680), will keep the engine running to fuel exhaustion, and has the additional benefit of allowing a return flight (in some range-dependent situations) without the need of maintenance while on the road. Not something I would ever consider after an alt failure with only a 2nd bat for backup. Add to the mix, the fact that while a 2nd alt is pretty much an install&forget item (just a startup check each flight similar to a mag check), any battery is a constantly degrading item that requires regular capacity testing to ensure that it has enough remaining capacity to give expected duration if called upon. Now, with carb or mech fuel injection in a VFR environment, current demands might (likely will) be low enough that a single bat & single alt back up each other. In *my* opinion, that's where Bob's statement makes sense, and where your question, as framed, doesn't need asking. So, I think you really have to define both the mission *and the hardware* to pick an architecture. FWIW, Charlie On Mon, Jun 8, 2020 at 11:15 AM Ken Ryan wrote: > Bob, you said: > > "If you have TWO properly maintained batteries, > in all likelihood, you'll be carrying around > $twice$ the hardware with virtually no value > added to the ship's overall reliability." > > Help me understand why the following statement is not correct: > > If you have TWO properly maintained alternators, > plus a battery (sized for minimum endurance requirements) > in all likelihood, you'll be carrying around > $twice$ the hardware with virtually no value > added to the ship's overall reliability. > > Ken > > On Sun, Jun 7, 2020 at 6:56 PM Robert L. Nuckolls, III < > nuckolls.bob(at)aeroelectric.com> wrote: > >> At 05:26 PM 6/7/2020, you wrote: >> >> I am not speaking to any engine manufacturers recommendation (although t he >> Honda Viking manufacturer does recommend two batteries. I just thought >> I was applying logic -- if dual alternator=C3=82 + battery (triple power >> source) >> is desirable for electrically=C3=82 dependent engines, wouldn't that rea soning >> imply that if the second alternator is not practical, a second battery >> could be used as the third power source? I could ask you a similar >> question: >> Are not two independent power sources (battery and alternator) sufficien t >> to meet the needs of the electrically=C3=82 dependent engine. Obviously you >> saw value in adding the second alternator. Why no value in adding the >> second battery? >> >> >> Excellent question. >> >> It's a problem in energy budgets combined with >> efforts to assure continued airworthiness. >> >> The airplane cannot do without a battery if >> you're going to have a starter. Depending on >> your planned mission profiles, you will want >> to size the battery (1) for cranking then >> (2) minimum endurance in alternator-out modes. >> >> This study gave impetus for the creation of >> the endurance bus . . . a fast and predictable >> way to economically tap known quantity of energy >> stored in the battery's chemistry. >> >> Z13/8 was a small but significant amplification >> of that idea . . . the second alternator's endurance >> had no practical limits. Hence, energy on the chemistry >> just might be held completely in reserve for >> descent and approach to landing. >> >> Z13/20 (and the aux alternator option on >> Z101) expanded the Z13/8 endurance opportunity >> by a factor of 2.5 or better. >> >> Okay, suppose the drive pad isn't available. >> We are still charged with identifying and the >> delivering to energy required to comfortably >> terminate a worst-case mission. >> >> This means that as a part of routine maintenance >> the ship's chemistry needs to be monitored for >> capability. We could certainly store that energy >> on TWO devices but to what advantage? If we're laboring >> under the notion that a battery can suddenly become >> unavailable during one tank of gas, then we have >> to assume that EITHER battery can roll over and >> die . . . okay, how would that failure be >> annunciated . . . how would remaining energy be >> managed . . . ? >> >> I think that's the scenario anticipated by the >> folks that crafted that battery manager with a >> full-wave rectifier that -anded- two, completely >> isolated batteries together. Assume the alternator >> has quit and some time later one battery >> craps out. How does the pilot become aware of the >> problem and what kind of energy juggling issues >> are presented when the available energy drops >> to half? This assuming he really knows that the >> two batteries were performing equally and has >> recently quantified their condition, he now >> has to come up with a new "plan C?" and perhaps >> declare an emergency. >> >> This scenario first assumes TWO critical failures >> during the consumption of one tank of fuel . . . >> about 3-4 hour window. Part 23 certs don't >> get concerned with dual failures at all. >> Part 25 and heavier will wade into the reliability >> quagmire with mountains of computer generated probability >> studies that get 'worked' on until somebody >> finally sprinkles the holy water and off they >> go. >> >> Ask Capt. Sullivan what he thinks about >> reliability studies . . . >> >> https://www.youtube.com/watch?v=HKJ1lIh2Cgk >> >> So we're left to our own devices which in reality >> are not so bad. >> >> The short answer is: A diligently maintained >> battery is the most reliable source of energy >> on the airplane. Replacing it when ability >> to store energy drops below some benchmark >> (generally 75 to 80% of new) means that it >> always cranks the engine and will provide a >> quantified option for dealing with alternator >> failure. Two batteries just doubles your >> preventative maintenance labor. Further, >> you need to decide if plan-b can reliably >> depend on the sum total of energy in two >> batteries . . . or will they be sized to >> independently step up to the task? The >> second option calls for 2X the battery >> weight and volume; the first option complicates >> calculations and switching operations for >> carrying out a plan-b that shouldn't ever >> happen. BOTH options still demand good >> preventative maintenance. >> >> Just as you KNOW fuel aboard when you launch, >> you also need to know Watt-Hours aboard >> no matter how many batteries you're carrying. >> >> If you have TWO properly maintained batteries, >> in all likelihood, you'll be carrying around >> $twice$ the hardware with virtually no value >> added to the ship's overall reliability. >> >> Bob . . . >> > ________________________________________________________________________________
Date: Jun 08, 2020
bus Or I'll tackle it a different way: What are the sudden failure rates of batteries and alternators. I've lost a couple alternators in flight, I've never heard of a good battery failing in flight. On Mon, Jun 8, 2020, 15:49 Charlie England wrote: > Hi Ken, > > I'll take a swing at it, but would suggest that it's not quite the right > question. > > I get your point, but the answer 'depends'. If using electronic fuel > injection, the current demands mean that a single PC680 style battery (in > 'new' condition) will only buy you about 30-40 minutes of flight time > after alternator failure. A 2nd PC680 only adds another 30-40 minutes. On > an engine that allows two alts, either of which can keep the engine runni ng > and the panel lit, a typical alt (ex: 55A Denso) is lighter than a 2nd > battery, not much more expensive (actually much cheaper than an actual > Odyssey branded PC680), will keep the engine running to fuel exhaustion, > and has the additional benefit of allowing a return flight (in some > range-dependent situations) without the need of maintenance while on the > road. Not something I would ever consider after an alt failure with only a > 2nd bat for backup. Add to the mix, the fact that while a 2nd alt is pret ty > much an install&forget item (just a startup check each flight similar to a > mag check), any battery is a constantly degrading item that requires > regular capacity testing to ensure that it has enough remaining capacity to > give expected duration if called upon. > > Now, with carb or mech fuel injection in a VFR environment, current > demands might (likely will) be low enough that a single bat & single alt > back up each other. In *my* opinion, that's where Bob's statement makes > sense, and where your question, as framed, doesn't need asking. > > So, I think you really have to define both the mission *and the hardware* > to pick an architecture. > > FWIW, > > Charlie > > On Mon, Jun 8, 2020 at 11:15 AM Ken Ryan wrote: > >> Bob, you said: >> >> "If you have TWO properly maintained batteries, >> in all likelihood, you'll be carrying around >> $twice$ the hardware with virtually no value >> added to the ship's overall reliability." >> >> Help me understand why the following statement is not correct: >> >> If you have TWO properly maintained alternators, >> plus a battery (sized for minimum endurance requirements) >> in all likelihood, you'll be carrying around >> $twice$ the hardware with virtually no value >> added to the ship's overall reliability. >> >> Ken >> >> On Sun, Jun 7, 2020 at 6:56 PM Robert L. Nuckolls, III < >> nuckolls.bob(at)aeroelectric.com> wrote: >> >>> At 05:26 PM 6/7/2020, you wrote: >>> >>> I am not speaking to any engine manufacturers recommendation (although >>> the >>> Honda Viking manufacturer does recommend two batteries. I just thought >>> I was applying logic -- if dual alternator=C3=82 + battery (triple powe r >>> source) >>> is desirable for electrically=C3=82 dependent engines, wouldn't that re asoning >>> imply that if the second alternator is not practical, a second battery >>> could be used as the third power source? I could ask you a similar >>> question: >>> Are not two independent power sources (battery and alternator) sufficie nt >>> to meet the needs of the electrically=C3=82 dependent engine. Obviously you >>> saw value in adding the second alternator. Why no value in adding the >>> second battery? >>> >>> >>> Excellent question. >>> >>> It's a problem in energy budgets combined with >>> efforts to assure continued airworthiness. >>> >>> The airplane cannot do without a battery if >>> you're going to have a starter. Depending on >>> your planned mission profiles, you will want >>> to size the battery (1) for cranking then >>> (2) minimum endurance in alternator-out modes. >>> >>> This study gave impetus for the creation of >>> the endurance bus . . . a fast and predictable >>> way to economically tap known quantity of energy >>> stored in the battery's chemistry. >>> >>> Z13/8 was a small but significant amplification >>> of that idea . . . the second alternator's endurance >>> had no practical limits. Hence, energy on the chemistry >>> just might be held completely in reserve for >>> descent and approach to landing. >>> >>> Z13/20 (and the aux alternator option on >>> Z101) expanded the Z13/8 endurance opportunity >>> by a factor of 2.5 or better. >>> >>> Okay, suppose the drive pad isn't available. >>> We are still charged with identifying and the >>> delivering to energy required to comfortably >>> terminate a worst-case mission. >>> >>> This means that as a part of routine maintenance >>> the ship's chemistry needs to be monitored for >>> capability. We could certainly store that energy >>> on TWO devices but to what advantage? If we're laboring >>> under the notion that a battery can suddenly become >>> unavailable during one tank of gas, then we have >>> to assume that EITHER battery can roll over and >>> die . . . okay, how would that failure be >>> annunciated . . . how would remaining energy be >>> managed . . . ? >>> >>> I think that's the scenario anticipated by the >>> folks that crafted that battery manager with a >>> full-wave rectifier that -anded- two, completely >>> isolated batteries together. Assume the alternator >>> has quit and some time later one battery >>> craps out. How does the pilot become aware of the >>> problem and what kind of energy juggling issues >>> are presented when the available energy drops >>> to half? This assuming he really knows that the >>> two batteries were performing equally and has >>> recently quantified their condition, he now >>> has to come up with a new "plan C?" and perhaps >>> declare an emergency. >>> >>> This scenario first assumes TWO critical failures >>> during the consumption of one tank of fuel . . . >>> about 3-4 hour window. Part 23 certs don't >>> get concerned with dual failures at all. >>> Part 25 and heavier will wade into the reliability >>> quagmire with mountains of computer generated probability >>> studies that get 'worked' on until somebody >>> finally sprinkles the holy water and off they >>> go. >>> >>> Ask Capt. Sullivan what he thinks about >>> reliability studies . . . >>> >>> https://www.youtube.com/watch?v=HKJ1lIh2Cgk >>> >>> So we're left to our own devices which in reality >>> are not so bad. >>> >>> The short answer is: A diligently maintained >>> battery is the most reliable source of energy >>> on the airplane. Replacing it when ability >>> to store energy drops below some benchmark >>> (generally 75 to 80% of new) means that it >>> always cranks the engine and will provide a >>> quantified option for dealing with alternator >>> failure. Two batteries just doubles your >>> preventative maintenance labor. Further, >>> you need to decide if plan-b can reliably >>> depend on the sum total of energy in two >>> batteries . . . or will they be sized to >>> independently step up to the task? The >>> second option calls for 2X the battery >>> weight and volume; the first option complicates >>> calculations and switching operations for >>> carrying out a plan-b that shouldn't ever >>> happen. BOTH options still demand good >>> preventative maintenance. >>> >>> Just as you KNOW fuel aboard when you launch, >>> you also need to know Watt-Hours aboard >>> no matter how many batteries you're carrying. >>> >>> If you have TWO properly maintained batteries, >>> in all likelihood, you'll be carrying around >>> $twice$ the hardware with virtually no value >>> added to the ship's overall reliability. >>> >>> Bob . . . >>> >> ________________________________________________________________________________
Date: Jun 08, 2020
Dad says he's been listing it on Craigslist for years and never got a bite. We got $73 at the recyclers for scrap aluminium and a couple motors and the dump run cost $17 so not a complete loss. On Mon, Jun 8, 2020, 15:28 Charlie England wrote: > Should be perfect for a *real* all electric airplane on a budget.... > > Seriously, did you try listing stuff like that on ebay? I've bought some 3 > phase stuff there for my house & shop (yes, I've got Delta to the house), > and I know some machine shop guys who watch auction sites for stuff like > that. > > Charlie > > On Mon, Jun 8, 2020 at 3:19 PM Sebastien wrote: > >> 225 Amp so it should be good. >> >> Aeroelectric said my picture was too big so here's a smaller version. >> >> On Mon, Jun 8, 2020 at 12:20 PM Jeff Luckey wrote: >> >>> LoL! >>> >>> Can I use that to turn-on my nav lights? ... >>> >>> wrote: >>> >>> >>> Anyone need a breaker for their aircraft project? I'm taking a load to >>> the dump. >>> >>> >>> >>> >>> >>> ________________________________________________________________________________
Date: Jun 08, 2020
bus Thanks Charlie, I am convinced that 2 alternators + 1 battery is superior to 1 alternator + 2 batteries. I am less convinced that if two alternators are not possible, a second battery adds virtually no value to the ship's overall reliability. Bob did make a pretty good argument, but it is founded on the assumption that the battery, when properly maintained, is utterly reliable. I have two problems with that assumption: 1) we know from Joe's experience that batteries can fail and 2) even with the best of intentions, maintenance (including battery maintenance) is not always perfect. To contend that having a fresh battery available at the flip of a switch adds no reliability to an electrically dependent aircraft still seems like a bit of a stretch to me. Ken On Mon, Jun 8, 2020 at 2:49 PM Charlie England wrote : > Hi Ken, > > I'll take a swing at it, but would suggest that it's not quite the right > question. > > I get your point, but the answer 'depends'. If using electronic fuel > injection, the current demands mean that a single PC680 style battery (in > 'new' condition) will only buy you about 30-40 minutes of flight time > after alternator failure. A 2nd PC680 only adds another 30-40 minutes. On > an engine that allows two alts, either of which can keep the engine runni ng > and the panel lit, a typical alt (ex: 55A Denso) is lighter than a 2nd > battery, not much more expensive (actually much cheaper than an actual > Odyssey branded PC680), will keep the engine running to fuel exhaustion, > and has the additional benefit of allowing a return flight (in some > range-dependent situations) without the need of maintenance while on the > road. Not something I would ever consider after an alt failure with only a > 2nd bat for backup. Add to the mix, the fact that while a 2nd alt is pret ty > much an install&forget item (just a startup check each flight similar to a > mag check), any battery is a constantly degrading item that requires > regular capacity testing to ensure that it has enough remaining capacity to > give expected duration if called upon. > > Now, with carb or mech fuel injection in a VFR environment, current > demands might (likely will) be low enough that a single bat & single alt > back up each other. In *my* opinion, that's where Bob's statement makes > sense, and where your question, as framed, doesn't need asking. > > So, I think you really have to define both the mission *and the hardware* > to pick an architecture. > > FWIW, > > Charlie > > On Mon, Jun 8, 2020 at 11:15 AM Ken Ryan wrote: > >> Bob, you said: >> >> "If you have TWO properly maintained batteries, >> in all likelihood, you'll be carrying around >> $twice$ the hardware with virtually no value >> added to the ship's overall reliability." >> >> Help me understand why the following statement is not correct: >> >> If you have TWO properly maintained alternators, >> plus a battery (sized for minimum endurance requirements) >> in all likelihood, you'll be carrying around >> $twice$ the hardware with virtually no value >> added to the ship's overall reliability. >> >> Ken >> >> On Sun, Jun 7, 2020 at 6:56 PM Robert L. Nuckolls, III < >> nuckolls.bob(at)aeroelectric.com> wrote: >> >>> At 05:26 PM 6/7/2020, you wrote: >>> >>> I am not speaking to any engine manufacturers recommendation (although >>> the >>> Honda Viking manufacturer does recommend two batteries. I just thought >>> I was applying logic -- if dual alternator=C3=82 + battery (triple powe r >>> source) >>> is desirable for electrically=C3=82 dependent engines, wouldn't that re asoning >>> imply that if the second alternator is not practical, a second battery >>> could be used as the third power source? I could ask you a similar >>> question: >>> Are not two independent power sources (battery and alternator) sufficie nt >>> to meet the needs of the electrically=C3=82 dependent engine. Obviously you >>> saw value in adding the second alternator. Why no value in adding the >>> second battery? >>> >>> >>> Excellent question. >>> >>> It's a problem in energy budgets combined with >>> efforts to assure continued airworthiness. >>> >>> The airplane cannot do without a battery if >>> you're going to have a starter. Depending on >>> your planned mission profiles, you will want >>> to size the battery (1) for cranking then >>> (2) minimum endurance in alternator-out modes. >>> >>> This study gave impetus for the creation of >>> the endurance bus . . . a fast and predictable >>> way to economically tap known quantity of energy >>> stored in the battery's chemistry. >>> >>> Z13/8 was a small but significant amplification >>> of that idea . . . the second alternator's endurance >>> had no practical limits. Hence, energy on the chemistry >>> just might be held completely in reserve for >>> descent and approach to landing. >>> >>> Z13/20 (and the aux alternator option on >>> Z101) expanded the Z13/8 endurance opportunity >>> by a factor of 2.5 or better. >>> >>> Okay, suppose the drive pad isn't available. >>> We are still charged with identifying and the >>> delivering to energy required to comfortably >>> terminate a worst-case mission. >>> >>> This means that as a part of routine maintenance >>> the ship's chemistry needs to be monitored for >>> capability. We could certainly store that energy >>> on TWO devices but to what advantage? If we're laboring >>> under the notion that a battery can suddenly become >>> unavailable during one tank of gas, then we have >>> to assume that EITHER battery can roll over and >>> die . . . okay, how would that failure be >>> annunciated . . . how would remaining energy be >>> managed . . . ? >>> >>> I think that's the scenario anticipated by the >>> folks that crafted that battery manager with a >>> full-wave rectifier that -anded- two, completely >>> isolated batteries together. Assume the alternator >>> has quit and some time later one battery >>> craps out. How does the pilot become aware of the >>> problem and what kind of energy juggling issues >>> are presented when the available energy drops >>> to half? This assuming he really knows that the >>> two batteries were performing equally and has >>> recently quantified their condition, he now >>> has to come up with a new "plan C?" and perhaps >>> declare an emergency. >>> >>> This scenario first assumes TWO critical failures >>> during the consumption of one tank of fuel . . . >>> about 3-4 hour window. Part 23 certs don't >>> get concerned with dual failures at all. >>> Part 25 and heavier will wade into the reliability >>> quagmire with mountains of computer generated probability >>> studies that get 'worked' on until somebody >>> finally sprinkles the holy water and off they >>> go. >>> >>> Ask Capt. Sullivan what he thinks about >>> reliability studies . . . >>> >>> https://www.youtube.com/watch?v=HKJ1lIh2Cgk >>> >>> So we're left to our own devices which in reality >>> are not so bad. >>> >>> The short answer is: A diligently maintained >>> battery is the most reliable source of energy >>> on the airplane. Replacing it when ability >>> to store energy drops below some benchmark >>> (generally 75 to 80% of new) means that it >>> always cranks the engine and will provide a >>> quantified option for dealing with alternator >>> failure. Two batteries just doubles your >>> preventative maintenance labor. Further, >>> you need to decide if plan-b can reliably >>> depend on the sum total of energy in two >>> batteries . . . or will they be sized to >>> independently step up to the task? The >>> second option calls for 2X the battery >>> weight and volume; the first option complicates >>> calculations and switching operations for >>> carrying out a plan-b that shouldn't ever >>> happen. BOTH options still demand good >>> preventative maintenance. >>> >>> Just as you KNOW fuel aboard when you launch, >>> you also need to know Watt-Hours aboard >>> no matter how many batteries you're carrying. >>> >>> If you have TWO properly maintained batteries, >>> in all likelihood, you'll be carrying around >>> $twice$ the hardware with virtually no value >>> added to the ship's overall reliability. >>> >>> Bob . . . >>> >> ________________________________________________________________________________
Date: Jun 08, 2020
battery bus >If you don=99t have a second alternator, you >should have a small backup battery. Sizing would >depend on your typical/ maximum distance between >airports. Current draw of the pump, ECU, >injectors and coils would be around 12 to 14 >amps. A 12 amp/hour battery should give you a >solid 30-40 minutes of flight time, just running >the engine electrics. An 18 amp/hour one, around >1 hour. We want to be able to sustain at least 10 volts to the electrics. > >We=99ve found the most reliable, simple and >light way to get backup battery power to the >engine electrics is a single 12 to 14 gauge wire >running from the backup battery, through a 30 >amp ATO fuse, to a heavy duty switch, to an >emergency buss where all the engine electrics >can receive power. Simply charge the backup >battery every 30 days and load test annually. >If you have the recommended check engine light >fitted, it will warn you any time the battery >voltage falls below 12.5V. You can monitor battery voltage in Gauge 3 mode. A statement that is understandable and predictable. EVERY supplier of electrically dependent aircraft accessories has a vested interest in NOT having their product figure into the script for your bad day in the cockpit. Their "most reliable finding" focuses on their product . . . and while certainly critical for continued flight, it's not the only critical electro-whizzie on the airplane. All creative assemblages stand on the 3-legged stool of energy-management, properties-of- materials and refinement-of-process. It doesn't matter if you're cooking breakfast or building a space shuttle. I think I've suggested before that installation manuals for such products should call for, "Energy supplied by a robust, failure tolerant and competently maintained electrical system." To be sure . . . many of our brothers don't have strong interests or appreciation for elegant solutions and prefer the cookie-cutter approach. Nothing overtly wrong with that but it can generate systems with high costs of ownership, unnecessary weight and complexity. Complexity adds risk for lack of understanding and mis-application of features originally intended to keep a tense day in the cockpit from getting worst. We don't do gps receivers here . . . or engines, or auto-pilots. We do system integration with a goal of achieving the simplest, failure tolerant supply and distribution systems. A natural fallout of those endeavors is lower cost of ownership and weight. Getting back to the subject engine, what's the 'advantage' of carrying a second battery that may never be used as opposed to carrying one battery sized and maintained to meet what ever endurance goals are sought for the whole airplane? Bob . . . ________________________________________________________________________________
bus
Date: Jun 08, 2020
For me, it's not so much that a 'good battery will *fail* in flight', but that the battery's capacity is continuously degrading, whether it's used or not, and that introduces a 2nd variable in the backup plan. It's not obvious, but a tired battery may well start an engine with gusto, but if called on to supply a continuous 14A (just to the engine), it might go dead in 10-15 minutes. My personal comfort zone bends toward an alternator, if I'm going to install a backup. Again, this is driven by the relatively high current demand of the electronic injection system in my project a/c. If I only had to support an electronic ignition (1-2 amps) and a radio, I'd be a lot more comfortable depending on the battery as backup. In fact, my current RV6 with mechanical injection and one Lightspeed has one alternator & one battery. I'm a VFR pilot and not dependent on electron delivery to keep the engine running or keep the dirty side down. Charlie On 6/8/2020 6:05 PM, Sebastien wrote: > Or I'll tackle it a different way: > > What are the sudden failure rates of batteries and alternators. I've > lost a couple alternators in flight, I've never heard of a good > battery failing in flight. > > On Mon, Jun 8, 2020, 15:49 Charlie England > wrote: > > Hi Ken, > > I'll take a swing at it, but would suggest that it's not quite the > right question. > > I get your point, but the answer 'depends'. If using electronic > fuel injection, the current demands mean that a single PC680 style > battery (in 'new' condition) will only buy you about 30-40 > minutes of flight time after alternator failure. A 2nd PC680 only > adds another 30-40 minutes. On an engine that allows two alts, > either of which can keep the engine running and the panel lit, a > typical alt (ex: 55A Denso) is lighter than a 2nd battery, not > much more expensive (actually much cheaper than an actual Odyssey > branded PC680), will keep the engine running to fuel exhaustion, > and has the additionalbenefit of allowing a return flight (in > some range-dependent situations) without the need of maintenance > while on the road. Not something I would ever consider after an > alt failure with only a 2nd bat for backup. Add to the mix, the > fact that while a 2nd alt is pretty much an install&forget item > (just a startup check each flight similar to a mag check), any > battery is a constantly degrading item that requires regular > capacity testing to ensure that it has enough remaining capacity > to give expected duration if called upon. > > Now, with carb or mech fuel injection in a VFR environment, > current demands might (likely will) be low enough that a single > bat & single alt back up each other. In *my* opinion, that's where > Bob's statement makes sense, and where your question, as framed, > doesn't need asking. > > So, I think you really have to define both the mission *and the > hardware* to pick an architecture. > > FWIW, > > Charlie > > On Mon, Jun 8, 2020 at 11:15 AM Ken Ryan > wrote: > > Bob, you said: > > "If you have TWO properly maintained batteries, > in all likelihood, you'll be carrying around > $twice$ the hardware with virtually no value > added to the ship's overall reliability." > > Help me understand why the following statement is not correct: > > If you have TWO properly maintained alternators, > plus a battery (sized for minimum endurance requirements) > in all likelihood, you'll be carrying around > $twice$ the hardware with virtually no value > added to the ship's overall reliability. > > Ken > > On Sun, Jun 7, 2020 at 6:56 PM Robert L. Nuckolls, III > > wrote: > > At 05:26 PM 6/7/2020, you wrote: >> I am not speaking to any engine manufacturers >> recommendation (although the >> Honda Viking manufacturer does recommend two batteries. I >> just thought >> I was applying logic -- if dual alternator + battery >> (triple power source) >> is desirable for electrically dependent engines, >> wouldn't that reasoning >> imply that if the second alternator is not practical, a >> second battery >> could be used as the third power source? I could ask you >> a similar question: >> Are not two independent power sources (battery and >> alternator) sufficient >> to meet the needs of the electrically dependent engine. >> Obviously you >> saw value in adding the second alternator. Why no value >> in adding the second battery? > > Excellent question. > > It's a problem in energy budgets combined with > efforts to assure continued airworthiness. > > The airplane cannot do without a battery if > you're going to have a starter. Depending on > your planned mission profiles, you will want > to size the battery (1) for cranking then > (2) minimum endurance in alternator-out modes. > > This study gave impetus for the creation of > the endurance bus . . . a fast and predictable > way to economically tap known quantity of energy > stored in the battery's chemistry. > > Z13/8 was a small but significant amplification > of that idea . . . the second alternator's endurance > had no practical limits. Hence, energy on the chemistry > just might be held completely in reserve for > descent and approach to landing. > > Z13/20 (and the aux alternator option on > Z101) expanded the Z13/8 endurance opportunity > by a factor of 2.5 or better. > > Okay, suppose the drive pad isn't available. > We are still charged with identifying and the > delivering to energy required to comfortably > terminate a worst-case mission. > > This means that as a part of routine maintenance > the ship's chemistry needs to be monitored for > capability. We could certainly store that energy > on TWO devices but to what advantage? If we're laboring > under the notion that a battery can suddenly become > unavailable during one tank of gas, then we have > to assume that EITHER battery can roll over and > die . . . okay, how would that failure be > annunciated . . . how would remaining energy be > managed . . . ? > > I think that's the scenario anticipated by the > folks that crafted that battery manager with a > full-wave rectifier that -anded- two, completely > isolated batteries together. Assume the alternator > has quit and some time later one battery > craps out. How does the pilot become aware of the > problem and what kind of energy juggling issues > are presented when the available energy drops > to half? This assuming he really knows that the > two batteries were performing equally and has > recently quantified their condition, he now > has to come up with a new "plan C?" and perhaps > declare an emergency. > > This scenario first assumes TWO critical failures > during the consumption of one tank of fuel . . . > about 3-4 hour window. Part 23 certs don't > get concerned with dual failures at all. > Part 25 and heavier will wade into the reliability > quagmire with mountains of computer generated probability > studies that get 'worked' on until somebody > finally sprinkles the holy water and off they > go. > > Ask Capt. Sullivan what he thinks about > reliability studies . . . > > https://www.youtube.com/watch?v=HKJ1lIh2Cgk > > > So we're left to our own devices which in reality > are not so bad. > > The short answer is: A diligently maintained > battery is the most reliable source of energy > on the airplane. Replacing it when ability > to store energy drops below some benchmark > (generally 75 to 80% of new) means that it > always cranks the engine and will provide a > quantified option for dealing with alternator > failure. Two batteries just doubles your > preventative maintenance labor. Further, > you need to decide if plan-b can reliably > depend on the sum total of energy in two > batteries . . . or will they be sized to > independently step up to the task? The > second option calls for 2X the battery > weight and volume; the first option complicates > calculations and switching operations for > carrying out a plan-b that shouldn't ever > happen. BOTH options still demand good > preventative maintenance. > > Just as you KNOW fuel aboard when you launch, > you also need to know Watt-Hours aboard > no matter how many batteries you're carrying. > > If you have TWO properly maintained batteries, > in all likelihood, you'll be carrying around > $twice$ the hardware with virtually no value > added to the ship's overall reliability. > > Bob . . . > -- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Subject: Re: Physical construction of Z101 engine bus & battery
bus
Date: Jun 08, 2020
If the maintenance of the primary battery is not always perfect then isnt it very likely that the maintenance of the backup battery is also not perfect? If human factors are at play, then is it not likely that two batteries will get even more imperfect maintenance than one? After all, who needs to maintain their battery when theres a backup battery installed? On Jun 8, 2020, at 7:17 PM, Ken Ryan wrote: Thanks Charlie, I am convinced that 2 alternators + 1 battery is superior to 1 alternator + 2 batteries. I am less convinced that if two alternators are not possible, a second battery adds virtually no value to the ship's overall reliability. Bob did make a pretty good argument, but it is founded on the assumption that the battery, when properly maintained, is utterly reliable. I have two problems with that assumption: 1) we know from Joe's experience that batteries can fail and 2) even with the best of intentions, maintenance (including battery maintenance) is not always perfect. To contend that having a fresh battery available at the flip of a switch adds no reliability to an electrically dependent aircraft still seems like a bit of a stretch to me. Ken On Mon, Jun 8, 2020 at 2:49 PM Charlie England wrote: Hi Ken, I'll take a swing at it, but would suggest that it's not quite the right question. I get your point, but the answer 'depends'. If using electronic fuel injection, the current demands mean that a single PC680 style battery (in 'new' condition) will only buy you about 30-40 minutes of flight time after alternator failure. A 2nd PC680 only adds another 30-40 minutes. On an engine that allows two alts, either of which can keep the engine running and the panel lit, a typical alt (ex: 55A Denso) is lighter than a 2nd battery, not much more expensive (actually much cheaper than an actual Odyssey branded PC680), will keep the engine running to fuel exhaustion, and has the additional benefit of allowing a return flight (in some range-dependent situations) without the need of maintenance while on the road. Not something I would ever consider after an alt failure with only a 2nd bat for backup. Add to the mix, the fact that while a 2nd alt is pretty much an install&forget item (just a startup check each flight similar to a mag check), any battery is a constantly degrading item that requires regular capacity testing to ensure that it has enough remaining capacity to give expected duration if called upon. Now, with carb or mech fuel injection in a VFR environment, current demands might (likely will) be low enough that a single bat & single alt back up each other. In *my* opinion, that's where Bob's statement makes sense, and where your question, as framed, doesn't need asking. So, I think you really have to define both the mission *and the hardware* to pick an architecture. FWIW, Charlie On Mon, Jun 8, 2020 at 11:15 AM Ken Ryan wrote: Bob, you said: "If you have TWO properly maintained batteries, in all likelihood, you'll be carrying around $twice$ the hardware with virtually no value added to the ship's overall reliability." Help me understand why the following statement is not correct: If you have TWO properly maintained alternators, plus a battery (sized for minimum endurance requirements) in all likelihood, you'll be carrying around $twice$ the hardware with virtually no value added to the ship's overall reliability. Ken On Sun, Jun 7, 2020 at 6:56 PM Robert L. Nuckolls, III wrote: At 05:26 PM 6/7/2020, you wrote: > I am not speaking to any engine manufacturers recommendation (although the > Honda Viking manufacturer does recommend two batteries. I just thought > I was applying logic -- if dual alternator + battery (triple power source) > is desirable for electrically dependent engines, wouldn't that reasoning > imply that if the second alternator is not practical, a second battery > could be used as the third power source? I could ask you a similar question: > Are not two independent power sources (battery and alternator) sufficient > to meet the needs of the electrically dependent engine. Obviously you > saw value in adding the second alternator. Why no value in adding the second battery? Excellent question. It's a problem in energy budgets combined with efforts to assure continued airworthiness. The airplane cannot do without a battery if you're going to have a starter. Depending on your planned mission profiles, you will want to size the battery (1) for cranking then (2) minimum endurance in alternator-out modes. This study gave impetus for the creation of the endurance bus . . . a fast and predictable way to economically tap known quantity of energy stored in the battery's chemistry. Z13/8 was a small but significant amplification of that idea . . . the second alternator's endurance had no practical limits. Hence, energy on the chemistry just might be held completely in reserve for descent and approach to landing. Z13/20 (and the aux alternator option on Z101) expanded the Z13/8 endurance opportunity by a factor of 2.5 or better. Okay, suppose the drive pad isn't available. We are still charged with identifying and the delivering to energy required to comfortably terminate a worst-case mission. This means that as a part of routine maintenance the ship's chemistry needs to be monitored for capability. We could certainly store that energy on TWO devices but to what advantage? If we're laboring under the notion that a battery can suddenly become unavailable during one tank of gas, then we have to assume that EITHER battery can roll over and die . . . okay, how would that failure be annunciated . . . how would remaining energy be managed . . . ? I think that's the scenario anticipated by the folks that crafted that battery manager with a full-wave rectifier that -anded- two, completely isolated batteries together. Assume the alternator has quit and some time later one battery craps out. How does the pilot become aware of the problem and what kind of energy juggling issues are presented when the available energy drops to half? This assuming he really knows that the two batteries were performing equally and has recently quantified their condition, he now has to come up with a new "plan C?" and perhaps declare an emergency. This scenario first assumes TWO critical failures during the consumption of one tank of fuel . . . about 3-4 hour window. Part 23 certs don't get concerned with dual failures at all. Part 25 and heavier will wade into the reliability quagmire with mountains of computer generated probability studies that get 'worked' on until somebody finally sprinkles the holy water and off they go. Ask Capt. Sullivan what he thinks about reliability studies . . . https://www.youtube.com/watch?v=HKJ1lIh2Cgk So we're left to our own devices which in reality are not so bad. The short answer is: A diligently maintained battery is the most reliable source of energy on the airplane. Replacing it when ability to store energy drops below some benchmark (generally 75 to 80% of new) means that it always cranks the engine and will provide a quantified option for dealing with alternator failure. Two batteries just doubles your preventative maintenance labor. Further, you need to decide if plan-b can reliably depend on the sum total of energy in two batteries . . . or will they be sized to independently step up to the task? The second option calls for 2X the battery weight and volume; the first option complicates calculations and switching operations for carrying out a plan-b that shouldn't ever happen. BOTH options still demand good preventative maintenance. Just as you KNOW fuel aboard when you launch, you also need to know Watt-Hours aboard no matter how many batteries you're carrying. If you have TWO properly maintained batteries, in all likelihood, you'll be carrying around $twice$ the hardware with virtually no value added to the ship's overall reliability. Bob . . . ________________________________________________________________________________
Date: Jun 08, 2020
bus I see definite advantage in a second battery, IN ADDITION to a battery sized and maintained to meet endurance goals. The advantage is obvious, added protection. Joe had a sudden and complete battery failure, so we know that batteries can and do fail. But more importantly, although Bob has stressed the need to know how many electrons are in the battery is as important as knowing how much fuel is in the tank, unfortunately one cannot put a dipstick in a battery and read with certainty what is in there. And as I said, even with the best of intentions, maintenance does not always get done correctly or on schedule. Add to that the fact that the battery can easily suffer abuse, simply by experiencing problems starting the engine, or leaving the master switch on; both are events that can seriously degrade a battery's capacity. To me, it is not a stretch at all to believe that even a conscientious owner might take off unknowingly with a battery whose capacity is far less than what he believes it to be. Again, it seems the hesitance to endorse two batteries is primarily based on the assumption that batteries are very reliable and completely knowable. Do we want to bet our lives on that assumption? On Mon, Jun 8, 2020 at 3:39 PM Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > If you don=C3=A2=82=AC=84=A2t have a second alternator, you should have a small backup > battery. Sizing would depend on your typical/ maximum distance between > airports. Current draw of the pump, ECU, injectors and coils would be > around 12 to 14 amps. A 12 amp/hour battery should give you a solid 30-40 > minutes of flight time, just running the engine electrics. An 18 amp/hour > one, around 1 hour. We want to be able to sustain at least 10 volts to th e > electrics. > > > *We=C3=A2=82=AC=84=A2ve found the most reliable, simple and light w ay to get backup > battery power to the engine electrics is a single 12 to 14 gauge wire > running from the backup battery, through a 30 amp ATO fuse, to a heavy du ty > switch, to an emergency buss where all the engine electrics can receive > power. Simply charge the backup battery every 30 days and load test > annually. *If you have the recommended check engine light fitted, it will > warn you any time the battery voltage falls below 12.5V. You can monitor > battery voltage in Gauge 3 mode. > > > A statement that is understandable and predictable. > EVERY supplier of electrically dependent aircraft > accessories has a vested interest in NOT having > their product figure into the script for your > bad day in the cockpit. > > Their "most reliable finding" focuses on > their product . . . and while certainly > critical for continued flight, it's not > the only critical electro-whizzie on the > airplane. > > All creative assemblages stand on the 3-legged > stool of energy-management, properties-of- > materials and refinement-of-process. It doesn't > matter if you're cooking breakfast or building a > space shuttle. > > I think I've suggested before that installation > manuals for such products should call for, "Energy > supplied by a robust, failure tolerant and competently > maintained electrical system." > > To be sure . . . many of our brothers don't > have strong interests or appreciation for > elegant solutions and prefer the cookie-cutter > approach. Nothing overtly wrong with that > but it can generate systems with high > costs of ownership, unnecessary weight > and complexity. Complexity adds risk for lack of > understanding and mis-application of features > originally intended to keep a tense day > in the cockpit from getting worst. > > We don't do gps receivers here . . . or engines, > or auto-pilots. We do system integration with > a goal of achieving the simplest, failure tolerant > supply and distribution systems. A natural fallout > of those endeavors is lower cost of ownership > and weight. > > Getting back to the subject engine, what's > the 'advantage' of carrying a second battery > that may never be used as opposed to carrying > one battery sized and maintained to meet > what ever endurance goals are sought for > the whole airplane? > > Bob . . . > ________________________________________________________________________________
bus
Date: Jun 08, 2020
I confirm that my PC680 failed while in flight. I sent it to Bob. He opened it up and found a broken weld. I can not remember how old the battery was, probably 5 years or more. That battery cranked the engine just fine on that last flight. I did not realize the battery had failed until I reduced engine RPM prior to landing. The alternator had been supplying power up to that point. While battery failure is extremely rare, it can happen. If an aircraft has two batteries, a new one can be installed every other year. Worst case is that one battery will be 4 years old and the other one 2 years old. I am not necessarily recommending two batteries. Having two batteries will give some pilots peace of mind, even though heavier and more expensive. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=496709#496709 ________________________________________________________________________________
Subject: Re: Exploring a Different Way to Wire Avionics
Date: Jun 08, 2020
When I bought my Approach FastStack, I had them make the cables I needed at the time because it wasn't that much money. As things changed, I made my own cables. The nice part is when you swap out a device, you just make a new cable for the connection between the device and the hub. Most interconnects between devices are done in the hub. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=496712#496712 ________________________________________________________________________________
Date: Jun 08, 2020
On 6/8/2020 8:04 PM, donjohnston wrote: > > When I bought my Approach FastStack, I had them make the cables I needed at the time because it wasn't that much money. As things changed, I made my own cables. > > The nice part is when you swap out a device, you just make a new cable for the connection between the device and the hub. Most interconnects between devices are done in the hub. > Were all the connections 1-1, 2-2, etc, or did you have to rearrange pin order? -- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jun 09, 2020
I wonder if interference could be a problem, and the subsequent troubleshooting thereof? Best Regards, Bob Verwey 082 331 2727 On Tue, 9 Jun 2020 at 03:13, donjohnston <don@velocity-xl.com> wrote: > don@velocity-xl.com> > > When I bought my Approach FastStack, I had them make the cables I needed > at the time because it wasn't that much money. As things changed, I made > my own cables. > > The nice part is when you swap out a device, you just make a new cable for > the connection between the device and the hub. Most interconnects between > devices are done in the hub. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=496712#496712 > > ________________________________________________________________________________
Date: Jun 09, 2020
bob.verwey(at)gmail.com wrote: > I wonder if interference could be a problem, and the subsequent troubleshooting thereof? > Best Regards,Bob Verwey None that I tell after 5 years. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=496720#496720 ________________________________________________________________________________
Date: Jun 09, 2020
battery bus I agree that sudden complete battery failure is extremely rare. But that is not the failure mode that is of most concern. Of most concern is that between our yearly capacity test, something happens that reduces the battery's capacity, and we don't realize it. That sort of a failure would be much more common. Two things that I can think of that might cause a reduction in capacity are a hard starting engine and inadvertently leaving the master switch on. Given that we cannot put a stick into the battery to read its actual capacity before each flight, it seems prudent to have two batteries (if battery power is the backup for an electrically dependent engine). On Mon, Jun 8, 2020 at 4:21 PM user9253 wrote: > > I confirm that my PC680 failed while in flight. I sent it to Bob. He > opened it > up and found a broken weld. I can not remember how old the battery was, > probably 5 years or more. That battery cranked the engine just fine on > that > last flight. I did not realize the battery had failed until I reduced > engine RPM > prior to landing. The alternator had been supplying power up to that > point. > While battery failure is extremely rare, it can happen. If an aircraft > has two > batteries, a new one can be installed every other year. Worst case is > that one > battery will be 4 years old and the other one 2 years old. I am not > necessarily recommending two batteries. Having two batteries will give > some > pilots peace of mind, even though heavier and more expensive. > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=496709#496709 > > ________________________________________________________________________________
Subject: Re: Essential Bus Diode Voltage D-25 voltage drop of
2.3V?
Date: Jun 09, 2020
Folks, Thanks for the quick inputs. I will do some investigating on my Grand Rapids Technology EIS 4000 power and ground connections. The EIS 4000 voltage is sensed by the power input and doesn't require a separate connection...but good power and ground wired connections to the instrument are a must. Howard -------- Howard Plevyak GlaStar / Cincinnati, Ohio Read this topic online here: http://forums.matronics.com/viewtopic.php?p=496728#496728 ________________________________________________________________________________
battery bus
Date: Jun 09, 2020
Joe, Just to play devils advocate, if youre prepared to replace a new battery every other year, then if you only have one battery, the worst case is that its 2 years old. And youre not schlepping a 4 year old battery around with you. Your mean battery age with two batteries would be three years; with a single battery the mean age is only one year, an improvement by a factor of 3. \. If an aircraft has two batteries, a new one can be installed every other year. Worst case is that one battery will be 4 years old and the other one 2 years old. I am not necessarily recommending two batteries. Having two batteries will give some pilots peace of mind, even though heavier and more expensive. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=496709#496709 ________________________________________________________________________________
Date: Jun 09, 2020
I used Approach FastStack to do my panel back around 2009, first flew in 2011 and 1200 hours now. My initial panel consisted of (3) GRT HX units, G430, G327, SL30, TruTrak AP, CO2 detector, a PS audio panel with (4) place jacks and (2) place powered for the Bose. Using the FastStack service and hub not only made the panel easy to wire, but their detailed knowledge of exactly what needed to be hooked up to what to get the fullest possible function from this combination of components far exceeded my skill level. There were many connection options between the various piece parts from different certified and experimental avionic manufacturers. Put simply, they knew what I was going to want before I knew it. The FastStack hub is unpowered, dumb, and for the most part a standardized device. The few internal modifications required were made and documented before the original shipment and it's never required any further update. The custom wiring harnesses were of the highest quality according to my inexperienced eyes. Each cable is fully documented per avionics device. There is a one page avionics connection summary that is perhaps the most valuable bit of documentation for the entire aircraft. When I added the NavWorx ADS600b, they supplied custom cables and updated documentation at a reasonable price. Recently I changed out the G327 and Navworx for a Trig TT22 Transponder and uAvioni echoUAT. The lead time on new cables was too long so I modified some and added my own. The detailed documentation made this easy. If one is going to do a DIY panel, I can't recommend this 'approach' highly enough. I guess that does further validate the OPs thinking. Bill "flying the rust off and getting ready to go somewhere again" Watson On 6/8/2020 9:04 PM, donjohnston wrote: > > When I bought my Approach FastStack, I had them make the cables I needed at the time because it wasn't that much money. As things changed, I made my own cables. > > The nice part is when you swap out a device, you just make a new cable for the connection between the device and the hub. Most interconnects between devices are done in the hub. > > -- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
bus
Date: Jun 09, 2020
Alec, everything you wrote is true. Keep in mind that I was not necessarily recommending two batteries. Someone who has an electrically dependent engine with only one alternator might want to have two batteries. If the alternator failed a long way from an airport, would that person prefer to have one 2-year-old battery, or . . one 2-year-old battery plus one 4-year-old battery? Some pilots do not replace their battery until it will not crank the engine any more. Many batteries last 5 or more years. The nice thing about experimental aircraft is that the builder designs the electrical system the way that they want to. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=496732#496732 ________________________________________________________________________________
Date: Jun 10, 2020
Subject: Re: Z101 main alt wiring
Charlie, Thanks for the response. What type of silicone tubing do you use for this? Regards, David --- David Carter david(at)carter.net On Mon, Jun 8, 2020 at 3:30 PM Charlie England wrote: > > > On Mon, Jun 8, 2020 at 1:47 PM David Carter wrote: > >> Bob, >> >> Tracing the main alt field circuit from the main bus, I see the following >> wire sizes: >> - 16 AWG fusible link >> - 12 AWG wire to 5A breaker & then to power master switch >> - 20 AWG wire to regulator >> - 20 AWG wire to alternator field >> >> I don't understand the need for the 12 AWG wire feeding the master, which >> has only 20 AWG coming out of it to the load. >> >> Thanks, >> David >> >> >> --- >> David Carter >> david(at)carter.net >> > > Reasonable question; might have been driven by 'off-the-shelf' fusible > link size availability. 22awg (minimum reasonable size to work with) link > (sleeved with silicone tubing) to 18awg would get the job done. 20awg after > the breaker because the breaker protects it. > > I've tested the silicone tubing trick on 22awg with a direct short on a > 12v tractor battery. The wire vaporizes, leaving a smoky interior lining on > the clear silicone tubing, but the tubing contained the 'event'. > Charlie > ________________________________________________________________________________
Date: Jun 10, 2020
On 6/10/2020 9:26 AM, David Carter wrote: > Charlie, > > Thanks for the response. What type of silicone tubing do you use for > this? > > Regards, > David > > --- > David Carter > david(at)carter.net > > > On Mon, Jun 8, 2020 at 3:30 PM Charlie England > wrote: > > > On Mon, Jun 8, 2020 at 1:47 PM David Carter > wrote: > > Bob, > > Tracing the main alt field circuit from the main bus, I see > the following wire sizes: > - 16 AWG fusiblelink > - 12 AWG wire to 5A breaker & then to power master switch > - 20 AWG wire to regulator > - 20 AWG wire to alternator field > > I don't understandthe need for the 12 AWG wire feeding the > master, which has only 20 AWG coming out of it to the load. > > Thanks, > David > > > --- > David Carter > david(at)carter.net > > > Reasonable question; might have been driven by 'off-the-shelf' > fusible link size availability. 22awg (minimum reasonable size to > work with) link (sleeved with silicone tubing) to 18awg would get > the job done. 20awg after the breaker because the breaker protects it. > > I've tested the silicone tubing trick on 22awg with a direct short > on a 12v tractor battery. The wire vaporizes, leaving a smoky > interior lining on the clear silicone tubing, but the tubing > contained the 'event'. > Charlie > Hi David, I don't even remember the source; probably ebay or Amazon. I just bought clear 'food grade' silicone tubing in an assortment of diameters. https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2334524.m570.l1313.TR9.TRC1.A0.H0.Xsilicone+tubing+.TRS2&_nkw=silicone+tubing+&_sacat=0&LH_TitleDesc=0&_osacat=0&_odkw=silicone+tubing+assortment Charlie -- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
From: "Gerry van Dyk" <gerry.vandyk(at)eastlink.ca>
Subject: Z101 main alt wiring
Date: Jun 10, 2020
I would think model airplane glow engine fuel tubing would work well too. Gerry ------ Original Message ------ From: "Charlie England" <ceengland7(at)gmail.com> Sent: 2020-06-10 9:14:00 AM Subject: Re: AeroElectric-List: Z101 main alt wiring >On 6/10/2020 9:26 AM, David Carter wrote: >>Charlie, >> >>Thanks for the response. What type of silicone tubing do you use for >>this? >> >>Regards, >>David >> >>--- >>David Carter >>david(at)carter.net >> >> >>On Mon, Jun 8, 2020 at 3:30 PM Charlie England >>wrote: >>> >>> >>>On Mon, Jun 8, 2020 at 1:47 PM David Carter wrote: >>>>Bob, >>>> >>>>Tracing the main alt field circuit from the main bus, I see the >>>>following wire sizes: >>>>- 16 AWG fusible link >>>>- 12 AWG wire to 5A breaker & then to power master switch >>>>- 20 AWG wire to regulator >>>>- 20 AWG wire to alternator field >>>> >>>>I don't understand the need for the 12 AWG wire feeding the master, >>>>which has only 20 AWG coming out of it to the load. >>>> >>>>Thanks, >>>>David >>>> >>>> >>>>--- >>>>David Carter >>>>david(at)carter.net >>> >>>Reasonable question; might have been driven by 'off-the-shelf' >>>fusible link size availability. 22awg (minimum reasonable size to >>>work with) link (sleeved with silicone tubing) to 18awg would get the >>>job done. 20awg after the breaker because the breaker protects it. >>> >>>I've tested the silicone tubing trick on 22awg with a direct short on >>>a 12v tractor battery. The wire vaporizes, leaving a smoky interior >>>lining on the clear silicone tubing, but the tubing contained the >>>'event'. >>>Charlie >Hi David, > >I don't even remember the source; probably ebay or Amazon. I just >bought clear 'food grade' silicone tubing in an assortment of >diameters. >https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2334524.m570.l1313. TR9.TRC1.A0.H0.Xsilicone+tubing+.TRS2&_nkw=silicone+tubing+&_sacat=0&LH _TitleDesc=0&_osacat=0&_odkw=silicone+tubing+assortment > >Charlie > > >Virus-free. www.avast.com > ><#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> ________________________________________________________________________________
Date: Jun 10, 2020
Subject: How about Z102?
At 04:58 PM 6/9/2020, you wrote: > >Alec, everything you wrote is true. Keep in mind that I was not necessarily >recommending two batteries. Someone who has an electrically dependent >engine with only one alternator might want to have two batteries. If the >alternator failed a long way from an airport, would that person >prefer to have >one 2-year-old battery, or . . one 2-year-old battery plus one 4-year-old >battery? Some pilots do not replace their battery until it will not >crank the >engine any more. Many batteries last 5 or more years. The nice thing about >experimental aircraft is that the builder designs the electrical >system the way >that they want to. Let's harken back a few years . . . about 26 to be more exact when the OBAM aviation community was in similar discussions about second batteries. Then the triggering technology was a constellation of electronic ignition systems being offered to home built aviation. I wrote an article for SA that massaged some ideas for managing a second battery in a ship fitted with dual electronic ignition systems. https://tinyurl.com/y8cpo3wo About 10 years later, this product came into being offering a means for crew selected, manual or automatic management of a second battery installed to support flight critical systems in single alternator aircraft. https://tinyurl.com/nxmo3us The adaptation of an automotive engine to aircraft is unique and not well supported by the Z101 Tinker-Toy approach to system architecture. It would seem that neither the endurance bus nor engine bus are optional. Further, given the relatively high energy demands of some engines (10+ Amps), the term 'endurance' is no longer applicable. The idea of consuming all fuel aboard during battery-only ops is simply unrealistic. Sadly, it seems necessary to apply the term 'emergency' to an alternator-out situation; reversion to battery-only ops fosters a sense of urgency to get the wheels on the ground ASAP! I've massaged Z101 into a proposed Z102 architecture that offers a means for incorporation of a second battery with a minimum of $time$ expended on monitoring for continued airworthiness. I've posted the first iteration for the List to sift . . . https://tinyurl.com/ybgta8bb In this proposal, the aux battery is the same part number as the main battery. It is fitted with a robust contactor that permits large current flows to and from the aux battery for (1) discharge during cranking assist and (2) un-restricted charging from the ship's alternator. Again, all the buses are multiple feed path; all buses are hot any time the main bus is hot. This lends itself to single switch activation of the DC power system. Depending on flight conditions the aux bus may be re-configured for main battery only ops; the engine bus may be re-configured for aux battery only ops. As with Z101, no mis-position (aside from OFF) puts the airframe at risk. The aux battery is automatically connected to the main bus any time the bus voltage exceeds 13.5 volts . . . i.e. the alternator is running. As the most capable battery on the airplane, the aux battery is dedicated to engine operations. Preflight checks are simple: Select aux bus alt feed before engine start . . . observe items on that bus are energized . . . all else is dark. During engine run-up, select ENGINE BUS AUX feed . . . note that voltage on the bus rises by approx 0.7 volts while the aux feed is selected. With two identical batteries, the preventative maintenance protocol reduces to periodic replacement of aux battery with a new one while moving the seldom taxed device into the main battery position. A more modern incarnation of the battery management module is in the design phase. It easily fits inside the backshell of a 15-pin d-sub. https://tinyurl.com/ycr43882 Bob . . . ________________________________________________________________________________
Date: Jun 10, 2020
> >Reasonable question; might have been driven by 'off-the-shelf' >fusible link size availability. 22awg (minimum reasonable size to >work with) link (sleeved with silicone tubing) to 18awg would get >the job done. 20awg after the breaker because the breaker protects it. > >I've tested the silicone tubing trick on 22awg with a direct short >on a 12v tractor battery. The wire vaporizes, leaving a smoky >interior lining on the clear silicone tubing, but the tubing >contained the 'event'. >Charlie Those sizes are still 'in work' . . . 20AWG is the smallest commericial-off-the-shelf (COTS) fusible link wire I've found . . . and is just fine when extended with 16AWG wire. There is no benefit in 'fine tuning' fusible link sizes. I'm thinking we're going to find that the range of COTS wires will cover all our needs. I'd guess that 99.9% of all breakers and fuses installed in vehicles go to the scrap yard never having been called upon to do their job. Fusible links are probably an order of magnitude LESS likely to be 'faulted' into service. Z101 and 102 suggest some FLW as jumpers between contactors/relays . . . I've been pondering these choices and have just about concluded that making those jumpers short, robust and mechanically protected is all that's practical and useful. Bob . . . ________________________________________________________________________________
Date: Jun 10, 2020
>Hi David, > >I don't even remember the source; probably ebay or Amazon. I just >bought clear 'food grade' silicone tubing in an assortment of diameters. >https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2334524.m570.l1313.TR9.TRC1.A0.H0.Xsilicone+tubing+.TRS2&_nkw=silicone+tubing+&_sacat=0&LH_TitleDesc=0&_osacat=0&_odkw=silicone+tubing+assortment > >Charlie B&C sells fusible link kits that include a silicone over fiberglas sleeving to coral the destruction products of what ever wire you want to run inside. https://tinyurl.com/ya2nzddh You can acquire silicon/fiberglas sleeving in various sizes/lengths here https://tinyurl.com/ybwnk7md Bob . . . ________________________________________________________________________________
Date: Jun 10, 2020
Subject: Re: How about Z102?
On Wed, Jun 10, 2020 at 1:06 PM Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 04:58 PM 6/9/2020, you wrote: > > > Alec, everything you wrote is true. Keep in mind that I was not > necessarily > recommending two batteries. Someone who has an electrically dependent > engine with only one alternator might want to have two batteries. If the > alternator failed a long way from an airport, would that person prefer to > have > one 2-year-old battery, or . . one 2-year-old battery plus one 4-year-old > battery? Some pilots do not replace their battery until it will not crank > the > engine any more. Many batteries last 5 or more years. The nice thing > about > experimental aircraft is that the builder designs the electrical system > the way > that they want to. > > > Let's harken back a few years . . . about > 26 to be more exact when the OBAM aviation > community was in similar discussions > about second batteries. Then the triggering > technology was a constellation of electronic ignition > systems being offered to home built aviation. > > I wrote an article for SA that massaged some > ideas for managing a second battery in a ship > fitted with dual electronic ignition systems. > > > * https://tinyurl.com/y8cpo3wo * About > 10 years later, this product came into being > offering a means for crew selected, manual or > automatic management of a second battery installed > to support flight critical systems in single > alternator aircraft. > > https://tinyurl.com/nxmo3us > > The adaptation of an automotive engine to > aircraft is unique and not well supported by > the Z101 Tinker-Toy approach to system architecture. > > It would seem that neither the endurance bus > nor engine bus are optional. Further, given > the relatively high energy demands of some > engines (10+ Amps), the term 'endurance' is > no longer applicable. The idea of consuming > all fuel aboard during battery-only ops is > simply unrealistic. > > Sadly, it seems necessary to apply the term > 'emergency' to an alternator-out situation; > reversion to battery-only ops fosters a sense of > urgency to get the wheels on the ground ASAP! > > I've massaged Z101 into a proposed Z102 > architecture that offers a means for incorporation > of a second battery with a minimum of $time$ > expended on monitoring for continued airworthiness. > I've posted the first iteration for the List > to sift . . . > > https://tinyurl.com/ybgta8bb > > In this proposal, the aux battery is the same > part number as the main battery. It is fitted > with a robust contactor that permits large > current flows to and from the aux battery for > (1) discharge during cranking assist and (2) > un-restricted charging from the ship's > alternator. > > Again, all the buses are multiple feed path; > all buses are hot any time the main bus is hot. > This lends itself to single switch activation > of the DC power system. > > Depending on flight conditions the aux bus > may be re-configured for main battery only > ops; the engine bus may be re-configured for > aux battery only ops. > > As with Z101, no mis-position (aside from > OFF) puts the airframe at risk. > > The aux battery is automatically connected to > the main bus any time the bus voltage exceeds > 13.5 volts . . . i.e. the alternator is > running. As the most capable battery on > the airplane, the aux battery is dedicated > to engine operations. > > Preflight checks are simple: Select aux bus > alt feed before engine start . . . observe > items on that bus are energized . . . all else > is dark. During engine run-up, select ENGINE > BUS AUX feed . . . note that voltage on the > bus rises by approx 0.7 volts while the aux > feed is selected. > > With two identical batteries, the preventative > maintenance protocol reduces to periodic > replacement of aux battery with a new one while > moving the seldom taxed device into the main > battery position. > > A more modern incarnation of the battery > management module is in the design phase. > It easily fits inside the backshell of a > 15-pin d-sub. > > https://tinyurl.com/ycr43882 > > > Bob . . . > The irony here is that with automotive conversions it's typically much easier to add a 2nd full size alternator (at less weight penalty than a 2nd equal sized SLA battery), and less money, if you're planning on buying Odyssey branded bats. Very few of us are willing to add air conditioners in light a/c, so there's the hole (and pulley) for a 2nd alt. Charlie ________________________________________________________________________________
Date: Jun 10, 2020
On Wed, Jun 10, 2020 at 1:12 PM Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > > Reasonable question; might have been driven by 'off-the-shelf' fusible > link size availability. 22awg (minimum reasonable size to work with) link > (sleeved with silicone tubing) to 18awg would get the job done. 20awg after > the breaker because the breaker protects it. > > I've tested the silicone tubing trick on 22awg with a direct short on a > 12v tractor battery. The wire vaporizes, leaving a smoky interior lining on > the clear silicone tubing, but the tubing contained the 'event'. > Charlie > > > Those sizes are still 'in work' . . . 20AWG is the smallest > commericial-off-the-shelf (COTS) fusible link wire I've found . . . > and is just fine when extended with 16AWG wire. > > There is no benefit in 'fine tuning' fusible link > sizes. I'm thinking we're going to find that the range > of COTS wires will cover all our needs. I'd guess that > 99.9% of all breakers and fuses installed in vehicles go > to the scrap yard never having been called upon to do > their job. > > Fusible links are probably an order of magnitude > LESS likely to be 'faulted' into service. > > Z101 and 102 suggest some FLW as jumpers between > contactors/relays . . . I've been pondering these > choices and have just about concluded that making > those jumpers short, robust and mechanically > protected is all that's practical and useful. > > > Bob . . . > That was my conclusion, as well. I rolled my own for alternator 'field' feeders because it was easier to use on-hand wire & tubing than search for small fuselink wire. I currently have each injector and each ignition coil on a separate fuse; I'm contemplating replacing that arrangement with fusible links from the bus feeder. The only thing that gives me pause there is that if a device shorts and current is low enough that the link *doesn't* open, I'm stuck with the current drain until I'm back on the ground. I used #12 fuselink wire as interconnects for my 55A IR alternator relay feeders (posted a pic a few weeks ago). Charlie ________________________________________________________________________________
Date: Jun 10, 2020
On Wed, Jun 10, 2020 at 2:10 PM Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > Hi David, > > I don't even remember the source; probably ebay or Amazon. I just bought > clear 'food grade' silicone tubing in an assortment of diameters. > > https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2334524.m570.l1313.TR9.TRC1.A0.H0.Xsilicone+tubing+.TRS2&_nkw=silicone+tubing+&_sacat=0&LH_TitleDesc=0&_osacat=0&_odkw=silicone+tubing+assortment > > Charlie > > > B&C sells fusible link kits that include > a silicone over fiberglas sleeving to > coral the destruction products of what > ever wire you want to run inside. > > https://tinyurl.com/ya2nzddh > > You can acquire silicon/fiberglas sleeving > in various sizes/lengths here > > https://tinyurl.com/ybwnk7md > > > Bob . . . > I wish I'd been able to find that when I fab'd mine, but it's been a while. Pretty sure it wasn't available back then. Pure silicone is 'good enough', but the Fglas stuff there is no more expensive, so I'll go there for future work. Thanks for the link! Charlie ________________________________________________________________________________
Date: Jun 10, 2020
Subject: Brownout Booster?
Found this device on eBay, and wondering if it is suitable for use on the brownout bus on Z101? https://www.ebay.com/itm/WaterProof-DC-DC-12V-to-14V-10A-140W-STEP-UP-Power-Converter-Regulator-DC/391330544024?hash=item5b1d1e3998:g:0ssAAOSw7FRWVx3p There are very similar looking 12v-to-12v versions, but they are twice the price. Not sure why. --- David Carter david(at)carter.net ________________________________________________________________________________
Date: Jun 10, 2020
Regarding proposed Z102 thanks for taking time to developing an architecture specific to auto conversion engines. One comment I have after reviewing is that from what I have seen, many (probably most?) auto conversions seem to use denso alternators with internal regulators. I think it may be relatively uncommon that these alternators are modified so that their regulators are moved to the external, or replaced with more conventional aircraft alternators. I therefore wonder if the architecture might be more useful if it also accounted for this idiosyncrasy of using a single internally regulated alternator? Ken On Wed, Jun 10, 2020 at 10:06 AM Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 04:58 PM 6/9/2020, you wrote: > > > Alec, everything you wrote is true. Keep in mind that I was not > necessarily > recommending two batteries. Someone who has an electrically dependent > engine with only one alternator might want to have two batteries. If the > alternator failed a long way from an airport, would that person prefer to > have > one 2-year-old battery, or . . one 2-year-old battery plus one 4-year-old > battery? Some pilots do not replace their battery until it will not crank > the > engine any more. Many batteries last 5 or more years. The nice thing > about > experimental aircraft is that the builder designs the electrical system > the way > that they want to. > > > Let's harken back a few years . . . about > 26 to be more exact when the OBAM aviation > community was in similar discussions > about second batteries. Then the triggering > technology was a constellation of electronic ignition > systems being offered to home built aviation. > > I wrote an article for SA that massaged some > ideas for managing a second battery in a ship > fitted with dual electronic ignition systems. > > > * https://tinyurl.com/y8cpo3wo * About > 10 years later, this product came into being > offering a means for crew selected, manual or > automatic management of a second battery installed > to support flight critical systems in single > alternator aircraft. > > https://tinyurl.com/nxmo3us > > The adaptation of an automotive engine to > aircraft is unique and not well supported by > the Z101 Tinker-Toy approach to system architecture. > > It would seem that neither the endurance bus > nor engine bus are optional. Further, given > the relatively high energy demands of some > engines (10+ Amps), the term 'endurance' is > no longer applicable. The idea of consuming > all fuel aboard during battery-only ops is > simply unrealistic. > > Sadly, it seems necessary to apply the term > 'emergency' to an alternator-out situation; > reversion to battery-only ops fosters a sense of > urgency to get the wheels on the ground ASAP! > > I've massaged Z101 into a proposed Z102 > architecture that offers a means for incorporation > of a second battery with a minimum of $time$ > expended on monitoring for continued airworthiness. > I've posted the first iteration for the List > to sift . . . > > https://tinyurl.com/ybgta8bb > > In this proposal, the aux battery is the same > part number as the main battery. It is fitted > with a robust contactor that permits large > current flows to and from the aux battery for > (1) discharge during cranking assist and (2) > un-restricted charging from the ship's > alternator. > > Again, all the buses are multiple feed path; > all buses are hot any time the main bus is hot. > This lends itself to single switch activation > of the DC power system. > > Depending on flight conditions the aux bus > may be re-configured for main battery only > ops; the engine bus may be re-configured for > aux battery only ops. > > As with Z101, no mis-position (aside from > OFF) puts the airframe at risk. > > The aux battery is automatically connected to > the main bus any time the bus voltage exceeds > 13.5 volts . . . i.e. the alternator is > running. As the most capable battery on > the airplane, the aux battery is dedicated > to engine operations. > > Preflight checks are simple: Select aux bus > alt feed before engine start . . . observe > items on that bus are energized . . . all else > is dark. During engine run-up, select ENGINE > BUS AUX feed . . . note that voltage on the > bus rises by approx 0.7 volts while the aux > feed is selected. > > With two identical batteries, the preventative > maintenance protocol reduces to periodic > replacement of aux battery with a new one while > moving the seldom taxed device into the main > battery position. > > A more modern incarnation of the battery > management module is in the design phase. > It easily fits inside the backshell of a > 15-pin d-sub. > > https://tinyurl.com/ycr43882 > > > Bob . . . > ________________________________________________________________________________
Subject: Re: Brownout Booster?
Date: Jun 10, 2020
On 6/10/2020 2:56 PM, David Carter wrote: > Found this device on eBay, and wondering if it is suitablefor use on > the brownout bus on Z101? > > https://www.ebay.com/itm/WaterProof-DC-DC-12V-to-14V-10A-140W-STEP-UP-Power-Converter-Regulator-DC/391330544024?hash=item5b1d1e3998:g:0ssAAOSw7FRWVx3p > > > There are very similar looking 12v-to-12v versions, but they are twice > the price. Not sure why. > > > --- > David Carter > david(at)carter.net Might work, but note that minimum input voltage is 10V (not uncommon for starting voltage to sag lower than that), and 'soft start' is a half second; might be too slow to prevent the brownout issue. Charlie -- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jun 10, 2020
Bob, if two batteries are connected in parallel and one of the batteries develops a shorted cell, will the good battery discharge into the bad battery? If yes, would the rate of discharge be significant enough to quickly reduce the good battery voltage to that of the bad battery? Thanks -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=496759#496759 ________________________________________________________________________________
Date: Jun 11, 2020
Subject: Re: Shorted cell risk?
At 06:05 PM 6/10/2020, you wrote: > >Bob, if two batteries are connected in parallel and one of the batteries >develops a shorted cell, will the good battery discharge into the bad battery? >If yes, would the rate of discharge be significant enough to quickly reduce >the good battery voltage to that of the bad battery? >Thanks > >-------- >Joe Gores A maintained battery doesn't get shorted cells. This was true back in the days of flooded batteries and especially true of RG devices today. 'Shorting' requires motion . . . in the heyday of flooded batteries, active material 'pasted' into the cell grids was subject to degradation with age/abuse. Chunks would fall out of the plate and migrate into the wet space between plates. Most of the stuff would fall to a 'sediment space' under the array of plates. Plates were EXPECTED to shed chunks of expended material so there was a 'basement' for storing the dead stuff. But a battery left in service past its prime was subject to so much flaking of active material that adjacent plates could become electrically connected . . . i.e. 'shorted cell' An RG battery is a different breed of cat all together. Separators between cells is a pretty tough but thin, porous plastic or fiber. The plates are compacted with significant force before being inserted into the battery case. For 'motion' to occur in these devices, requires severe degradation of the cell's active materials. This happens when the battery has been allowed to self-destruct with age or when subjected to sustained over charging. Then you get swelling of the active material and risk of separator compromise. But even in extreme cases of AGM battery abuse, shorted cells are not a given. I've seen some pretty badly 'puffed up' AGM batteries that were essentially destroyed but had presented no shorted cells. A battery removed from service in an aircraft at the appointed time in its life cycle is not going to exhibit effects of severe ageing or abuse. Bob . . . ________________________________________________________________________________
Date: Jun 11, 2020
What is an RG battery? Without trying to continue mudding the waters, I would venture to say that most builders these days who are using an auto conversion engine not only have a single, internally regulated alternator, they are also probably running LiPo batteries. Does this apply to LiPo batteries as well? All of the experimentals that I am personally familiar (eight or ten) are now using LiPo batteries. On Thu, Jun 11, 2020 at 5:20 AM Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 06:05 PM 6/10/2020, you wrote: > > > Bob, if two batteries are connected in parallel and one of the batteries > develops a shorted cell, will the good battery discharge into the bad > battery? > If yes, would the rate of discharge be significant enough to quickly reduce > the good battery voltage to that of the bad battery? > Thanks > > -------- > Joe Gores > > > A maintained battery doesn't get shorted cells. > This was true back in the days of flooded > batteries and especially true of RG devices > today. > > 'Shorting' requires motion . . . in the heyday > of flooded batteries, active material 'pasted' > into the cell grids was subject to degradation > with age/abuse. Chunks would fall out of the > plate and migrate into the wet space between > plates. Most of the stuff would fall to a > 'sediment space' under the array of plates. > Plates were EXPECTED to shed chunks of expended > material so there was a 'basement' for storing > the dead stuff. > > But a battery left in service past its prime > was subject to so much flaking of active > material that adjacent plates could become > electrically connected . . . i.e. 'shorted > cell' > > An RG battery is a different breed of cat > all together. Separators between cells > is a pretty tough but thin, porous > plastic or fiber. The plates are compacted > with significant force before being > inserted into the battery case. > > For 'motion' to occur in these devices, > requires severe degradation of the > cell's active materials. This happens > when the battery has been allowed to > self-destruct with age or when subjected > to sustained over charging. Then you > get swelling of the active material > and risk of separator compromise. > > But even in extreme cases of AGM > battery abuse, shorted cells are not > a given. I've seen some pretty badly > 'puffed up' AGM batteries that were essentially > destroyed but had presented no shorted > cells. > > A battery removed from service in an aircraft > at the appointed time in its life cycle is not > going to exhibit effects of severe ageing or > abuse. > > Bob . . . > ________________________________________________________________________________
Date: Jun 11, 2020
I wouldn't make that assumption to "most". There are plenty of people using both AGM and LiPo batteries. I know many of both, and many of both types of alternators as well. So blanket statements don't really apply, but I do agree that it would be nice to see architecture that covers both types of alternators. Tim On 6/11/2020 8:27 AM, Ken Ryan wrote: > What is an RG battery? Without trying to continue mudding the waters, > I would venture to say that most builders these days who are using an > auto conversion engine not only have a single, internally regulated > alternator, they are also probably running LiPo batteries. Does this > apply to LiPo batteries as well? All of theexperimentals that I am > personally familiar (eight or ten) are now using LiPo batteries. > > On Thu, Jun 11, 2020 at 5:20 AM Robert L. Nuckolls, III > > > wrote: > > At 06:05 PM 6/10/2020, you wrote: >> > >> >> Bob, if two batteries are connected in parallel and one of the >> batteries >> develops a shorted cell, will the good battery discharge into the >> bad battery? >> If yes, would the rate of discharge be significant enough to >> quickly reduce >> the good battery voltage to that of the bad battery? >> Thanks >> >> -------- >> Joe Gores > > A maintained battery doesn't get shorted cells. > This was true back in the days of flooded > batteries and especially true of RG devices > today. > > 'Shorting' requires motion . . . in the heyday > of flooded batteries, active material 'pasted' > into the cell grids was subject to degradation > with age/abuse. Chunks would fall out of the > plate and migrate into the wet space between > plates. Most of the stuff would fall to a > 'sediment space' under the array of plates. > Plates were EXPECTED to shed chunks of expended > material so there was a 'basement' for storing > the dead stuff. > > But a battery left in service past its prime > was subject to so much flaking of active > material that adjacent plates could become > electrically connected . . . i.e. 'shorted > cell' > > An RG battery is a different breed of cat > all together. Separators between cells > is a pretty tough but thin, porous > plastic or fiber. The plates are compacted > with significant force before being > inserted into the battery case. > > For 'motion' to occur in these devices, > requires severe degradation of the > cell's active materials. This happens > when the battery has been allowed to > self-destruct with age or when subjected > to sustained over charging. Then you > get swelling of the active material > and risk of separator compromise. > > But even in extreme cases of AGM > battery abuse, shorted cells are not > a given. I've seen some pretty badly > 'puffed up' AGM batteries that were essentially > destroyed but had presented no shorted > cells. > > A battery removed from service in an aircraft > at the appointed time in its life cycle is not > going to exhibit effects of severe ageing or > abuse. > > Bob . . . > ________________________________________________________________________________
Date: Jun 11, 2020
At 03:12 PM 6/10/2020, you wrote: >Regarding proposed Z102 thanks for taking time >to developing an architecture specific to auto >conversion engines. One comment I have after >reviewing is that from what I have seen, many >(probably most?) auto conversions seem to use >denso alternators with internal regulators. I >think it may be relatively uncommon that these >alternators are modified so that their >regulators are moved to the external, or >replaced with more conventional aircraft >alternators. I therefore wonder if the >architecture might be more useful if it also >accounted for this idiosyncrasy=C2 of using a >single internally regulated alternator? > >Ken This has been an ongoing debate on these pages decades. I've sorta taken the tack that we should strive to publish and recommend the best we know how to do as opposed to becoming an echo chamber for concepts from other venues. To be sure, reliability of COTS alternators is very high . . . in fact, I've been told there are STCs now for adapting COTS alternators to TC aircraft sans ov protection. I've not seen any such documents but it wouldn't surprise me. We'll have to leave adoption of such variants up to the individual builder. For the foreseeable future, I'll continue to strive for as much failure tolerance as the technology and tools at hand will offer. Speaking of COTS alternators . . . Lister Graeme Coates did an excellent piece on ND alternator modifications published in Kitplanes last year. You can see a copy of that article here: https://tinyurl.com/yxmpw3on . . . along with other writings on the same subject. Bob . . . ________________________________________________________________________________
Date: Jun 11, 2020
Can someone please provide a link to a brownout booster that would be suitable for the Z101 brownout bus? I'm having trouble finding one that appears suitable, possibly because I don't really know what I should be looking for. Thanks, David -- David Carter david(at)carter.net On Wed, Jun 10, 2020 at 4:54 PM Charlie England wrote: > On 6/10/2020 2:56 PM, David Carter wrote: > > Found this device on eBay, and wondering if it is suitable for use on the > brownout bus on Z101? > > > https://www.ebay.com/itm/WaterProof-DC-DC-12V-to-14V-10A-140W-STEP-UP-Power-Converter-Regulator-DC/391330544024?hash=item5b1d1e3998:g:0ssAAOSw7FRWVx3p > > > There are very similar looking 12v-to-12v versions, but they are twice the > price. Not sure why. > > > --- > David Carter > david(at)carter.net > > Might work, but note that minimum input voltage is 10V (not uncommon for > starting voltage to sag lower than that), and 'soft start' is a half > second; might be too slow to prevent the brownout issue. > > Charlie > > > Virus-free. > www.avast.com > > <#m_-803626533076655720_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> > ________________________________________________________________________________
Subject: What is an RG battery?
Date: Jun 11, 2020
Recombinant Gas... designed to turn any liberated hydrogen/oxygen back into water, to avoid electrolyte depletion. Paul ________________________________________________________________________________
Date: Jun 11, 2020
At 09:32 AM 6/11/2020, you wrote: >Can someone please provide a link to a brownout >booster that would be suitable for the Z101 >brownout bus? I'm having trouble finding one >that appears suitable, possibly because I don't >really know what I should=C2 be looking for.=C2 What are your brownout bus loads? Bob . . . ________________________________________________________________________________
Date: Jun 11, 2020
eBay item 222626498012 claims to work with as little as 3 volts input. eBay item 224017421193 claims to work with as little as 8.5 volts input. The descriptions are written in broken English. Example: (please to ensure that output voltage above on input voltage) You could experiment with more than one type until you find one that works. A separate DC-DC booster could even be installed for each protected load. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=496777#496777 ________________________________________________________________________________
Date: Jun 11, 2020
At 08:27 AM 6/11/2020, you wrote: >What is an RG battery? Sorry . . . recombinant gas (RG) also known as absorbed glass mat (AGM) and valve regulated sealed lead acid (VRLA) and starved electrolyte cells. Lots of ways to describe the same technology. >Without trying to continue mudding the waters, I >would venture to say that most >builders these days who are using an auto conversion engine not only have a >single, internally regulated alternator, they are also probably running LiPo >batteries. Hmmm . . . 'most'? > Does this apply to LiPo batteries as well? All of the=C2 experimentals >that I am personally familiar (eight or ten) are now using LiPo batteries. As to cell shorting . . . we're told that lithium related fires are initiated by short circuiting the cell. In the 787 batteries, the shorts were internal. Given their energy density, the aftermath of a cell-short is almost guaranteed to be spectacular. The LiPoFe technology seems most sensitive to electrical abuse . . . a condition that gave impetus to rather elaborate battery management systems being folded into 'holy watered' products. I've been playing with my new West Mountain Radio battery analyzer. Did a constellation of deep discharge tests on some 18650 cells. I'll take a few of them down to zero . . . let them set for a day or so and then see what happens to their demonstrated capacity. Bob . . . ________________________________________________________________________________
Date: Jun 11, 2020
> > > Hmmm . . . 'most'? > I can only speak to my experience. I am personally familiar with 5 SuperSTOLs, 1 Highlander, 2 Zeniths and 1 Rans. Every one has ditched lead acid for LiPo. Of course these are all Light Sport Aircraft and weight is a big concern when max gross is 1320. I would guess LiPo has not been as widely adopted in larger aircraft with more weight to play with. Ken > ________________________________________________________________________________
Date: Jun 11, 2020
Dear all, Better not confuse LiPo with LiFePO4 (also called LFP). Important differences. A search with both terms will lead to some clarity I expect. Cheers, Jan de Jong ________________________________________________________________________________
Date: Jun 11, 2020
Opposite experience for me with only one out of six familiar local aircraft using Lithium. With the relatively economical older aircraft in my neighborhood that I'm not familiar with I'd be very surprised if even one out of 10 has converted. Ken L On 11/06/2020 4:43 PM, Ken Ryan wrote: > > > Hmmm . . . 'most'? > > > I can only speak to my experience. I am personally familiar with 5 > SuperSTOLs, 1 Highlander, 2 Zeniths and 1 Rans. Every one has ditched > lead acid for LiPo. Of course these are all Light Sport Aircraft and > weight is a big concern when max gross is 1320. I would guess LiPo has > not been as widely adopted in larger aircraft with more weight to play > with. > > Ken > ________________________________________________________________________________
Date: Jun 11, 2020
Subject: EarthX ETX680C support
Cross-post (with permission) from the Canard Aviators List: 3a. *EarthX ETX680C support* From: Tristan Vincent-Philpot Date: Wed, 10 Jun 2020 23:16:17 UTC I flew the family from KVGT to KSNA yesterday, an uneventful trip except that on 10nm approach into John Wayne, the battery fault indicator lit on my instrument panel. The light was solid, not blinking, meaning that a hardware problem had occurred and could not be reset. I prioritized flying the airplane to a safe landing while I switched the Alternator off to avoid trying to push more charge into the battery with an unknown fault. Once the dust settled and I had parked and unloaded the family into the air-conditioned comfort of the ACI Jet terminal, I set about troubleshooting. I took the rear cabin panel off and checked the condition of the battery itself. It was not hot, or smoking and there was no indication of any damage of any kind. With the Master switch on I checked the volts and amps and as expected the battery voltage had depleted slightly but otherwise everything was normal except with the fault warning light on. I re-read the operator's manual for the EarthX and it was clear that there was a hardware fault detected and the battery would need to be replaced. I then called EarthX and was put through to technical support (=98Reg =99) who was very knowledgeable and said that the most likely cause they have seen with this issue is that one of the dual redundant internal disconnectors had thrown a fault and latched the warning. He said I should try and charge it, and if as he suspected it accepted a charge normally, I should not worry about flying it home as the cells have been operating perfectly normally and take months to deviate from this practice. By lucky coincidence I had purchased an Optimate TM-291 charger as recommended by EarthX a couple of days ago and had it with me so borrowed a generator from the FBO and plugged it in. The battery charged completely normally in about 20 mins to full charge, then held the charge, didn=99t get warm or an ything unusual. Throughout this process Reg was engaged, looking for possible replacements in stock nearby, looking at my photos of the charger and other indications. Once charged, we left the airplane while we went to explore Laguna Beach (the reason for the flight) then returned in the late afternoon. Sure enough the battery had held its charge as usual and the engine started first time. I flew the 1.5 hours home to Las Vegas with appropriate monitoring of the electrical system behavior with nothing amiss except the warning light on. When I shut down at home base, the battery volts indicated full ~13.4V as expected, and again the battery was cool with no smoke or any other problems. Today, I went online to EarthX website as directed by Reg and filled out the online warranty form. He helped me find a couple of the parameters and pre-warned the warranty department to expect my submission. Within minutes I had an accepted warranty exchange and the replacement battery is shipping to me now. When it arrives I can then remove the old one and return it. Overall this has INCREASED my confidence in the Lithium battery system from EarthX and I was very impressed with the attitude and knowledge of the technical support on hand when I called. It could have been much worse. As an aside, I asked if there was any chance they were working on a venting system for the ETX680C model to provide added safety for cabin installations. He said no, there=99s no room in that form factor, but that it would be possible for the regular size ETX680 (non-compact model). I told him I thought it would encourage more in the experimental community to make the leap to their batteries as the TSO=99d ETX900-TSO is eye-watering ly more expensive but is the only option with a vent kit. He agreed - I guess we =99ll have to wait and see what transpires Also a shout out to ACI-Jet at KSNA, they were awesome all day, supplying a comfortable lounge for the family with drinks and snacks, a generator and cables, waiving the usual fees ($60) for a 10gal fuel purchase. I thoroughly recommend them if you find yourself heading to Orange County. Also the Optimate chargers are very nicely made and work well. A long yearned for family day at the beach was not really impacted and we all arrived safely home for dinner. And I learned stuff :-) Tristan N142LE ________________________________________________________________________________
Date: Jun 12, 2020
Subject: Speaking of LiFePo4
At 04:33 PM 6/11/2020, you wrote: > >Dear all, > >Better not confuse LiPo with LiFePO4 (also called LFP). Important differences. >A search with both terms will lead to some clarity I expect. An very important point. Not all 'lithium' cells are the same. While the energy density is higher for chemistries other than lithium iron phosphate (LiFePo4), the relative robustness and safety of the LiFePo4 devices has prompted a chemistry of choice decision for most suppliers to our craft . . . indeed most consumer motive power applications. For our purposes, when ever I refer to a lithium product, know that I'm referring to the LiFePo4 technology. Speaking of LiFePo4: I observe that virtually all the COTS lithium chargers in my stable, every one 'tops off' at 4.2 volts. These chargers were used to explore qualities of a bevy of 18650 cells laying around the shop. I've attached a plot for a constellation of cells. A plot of the as-found condition of a cell was followed by a plot of a recharged condition. Most of the 'weak' cells showed marked recovery . . . others did not. One interesting feature of this exercise is to note the starting voltage for the discharge plot of each recharged cell. Virtually all produced first delivery of energy at 4.0 volts or more. Hmmm . . . It seems this was related to charging top-off voltage. Okay, if one wishes to maximize exploitation of your ship' lithium battery, do you want to raise your alternator voltage to 4 x 4.2 16.8 volts? Hmmm . . . most of our electro whizzies probably wouldn't mind . . . but if you're carrying incandescent lights of any size, service life would be reduced by 50% or more . . . but they would certainly be bright! I've posted an article found on powerstream.com See: https://tinyurl.com/yazw9jnh By the way, check out the rest of this website. It's a treasure trove of data on DC power systems. I had the name of the author at one time but let it get lost. If anyone perusing this resource runs across the author's name, I'd appreciate a heads-up. The article illustrates some interesting numbers on LiFePo4 performance. First, there is little value in charging the LiFePo4 cell at it rated maximum. The writer demonstrates that charging at considerably lower levels does not significantly affect stored energy until charge-per-cell voltage drops below 3.40. Okay, 3.40 x 4 is 13.6 volts. I think we can live with that! In fact, we're told that the charge-discharge service life of lithium cells is improved by operating the cells between 30 and 90% of the chemical capacity of the cell. Okay operating the contemporary 4-cell array products at the legacy 14.2 to 14.4 volts (3.6 volts per cell) wont give up significant performance while extending service life. I'm going to repeat the experiment in the article cited. I will add features that explore system integration questions going to what may prove to be the 'next generation' of OBAM aviation electrical system architectures. Bob . . . ________________________________________________________________________________
Date: Jun 12, 2020
Subject: Re: Speaking of LiFePo4
Okay, 20 minutes with google reveals plenty of examples of COTS chargers, but no definition of COTS. Could someone please educate me on this terminology? Thanks. On Fri, Jun 12, 2020 at 9:27 AM Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 04:33 PM 6/11/2020, you wrote: > > jan_de_jong(at)casema.nl> > > Dear all, > > Better not confuse LiPo with LiFePO4 (also called LFP). Important > differences. > A search with both terms will lead to some clarity I expect. > > > An very important point. Not all 'lithium' cells > are the same. While the energy density is > higher for chemistries other than lithium > iron phosphate (LiFePo4), the relative > robustness and safety of the LiFePo4 > devices has prompted a chemistry of choice > decision for most suppliers to our craft . . . > indeed most consumer motive power applications. > > For our purposes, when ever I refer to > a lithium product, know that I'm referring > to the LiFePo4 technology. > > Speaking of LiFePo4: > > I observe that virtually all the COTS lithium > chargers in my stable, every one 'tops off' > at 4.2 volts. These chargers were used to > explore qualities of a bevy of 18650 > cells laying around the shop. I've > attached a plot for a constellation > of cells. A plot of the as-found condition > of a cell was followed by a plot of a > recharged condition. > > Most of the 'weak' cells showed marked > recovery . . . others did not. One interesting > feature of this exercise is to note the > starting voltage for the discharge plot > of each recharged cell. > > Virtually all produced first delivery of > energy at 4.0 volts or more. Hmmm . . . > It seems this was related to charging > top-off voltage. Okay, if one wishes > to maximize exploitation of your ship' > lithium battery, do you want to raise > your alternator voltage to 4 x 4.2 > 16.8 volts? > > Hmmm . . . most of our electro whizzies > probably wouldn't mind . . . but if you're > carrying incandescent lights of any size, > service life would be reduced by 50% or more . . . > but they would certainly be bright! > > I've posted an article found on powerstream.com > > See: https://tinyurl.com/yazw9jnh > > By the way, check out the rest of this website. > It's a treasure trove of data on DC power > systems. I had the name of the author at > one time but let it get lost. If anyone > perusing this resource runs across the author's > name, I'd appreciate a heads-up. > > The article illustrates some interesting numbers > on LiFePo4 performance. First, there is > little value in charging the LiFePo4 cell > at it rated maximum. The writer demonstrates > that charging at considerably lower levels > does not significantly affect stored energy > until charge-per-cell voltage drops below > 3.40. Okay, 3.40 x 4 is 13.6 volts. I > think we can live with that! > > In fact, we're told that the charge-discharge > service life of lithium cells is improved > by operating the cells between 30 and 90% > of the chemical capacity of the cell. Okay > operating the contemporary 4-cell array > products at the legacy 14.2 to 14.4 volts > (3.6 volts per cell) wont give up significant > performance while extending service life. > > I'm going to repeat the experiment in the > article cited. I will add features > that explore system integration questions > going to what may prove to be the 'next > generation' of OBAM aviation electrical system > architectures. > > Bob . . . > ________________________________________________________________________________
From: "Matthew S. Whiting" <m.whiting(at)frontier.com>
Subject: Re: Physical construction of Z101 engine bus &
battery bus
Date: Jun 12, 2020
It seems to me the real question is which is more likely to fail: 1. A single battery with an age of 0 - 2 years or 2. Both batteries simultaneously where one is 0 - 2 years old and the other is 2 - 4 years old? I am not aware of a good source of battery failure rates, but my auto experience over the course of 45 years suggests that alternative 1 has a much higher probability than alternative 2. I have almost always had at least four cars, trucks and motorcycles at any given time with battery ages between new and 8 years old. Even if I discount failures of batteries more than 4 years old (I tend to run my car batteries to failure), I have had at least two failures I can remember of with batteries less than two years old. My Current Chevy Equinox OEM battery failed 5 months after I bought the vehicle new in 2012. No charging system issues were found and the warranty replacement battery lasted 6 years. I have NEVER had two of my vehicles have battery failures at the same time or even closely spaced in time. That suggests to me that the probability of a single new battery failing is higher than the probability of simultaneous failure of two batteries: one new and one older. I realize this isnt exactly the same scenario since two batteries in the same vehicle could have a common failure mode such as a runaway alternator that fries them both, but it is the best I can do. Matt > On Jun 12, 2020, at 4:50 PM, Alec Myers wrote: > > > Joe, > > Just to play devils advocate, if youre prepared to replace a new battery every other year, then if you only have one battery, the worst case is that its 2 years old. And youre not schlepping a 4 year old battery around with you. > Your mean battery age with two batteries would be three years; with a single battery the mean age is only one year, an improvement by a factor of 3. ________________________________________________________________________________
Date: Jun 12, 2020
Commercial-of-the-shelf. Often used in the government contracting world & the opposite of bespoke. On Fri, Jun 12, 2020 at 4:12 PM Ken Ryan wrote: > Okay, 20 minutes with google reveals plenty of examples of COTS chargers, > but no definition of COTS. Could someone please educate me on this > terminology? Thanks. > > > On Fri, Jun 12, 2020 at 9:27 AM Robert L. Nuckolls, III < > nuckolls.bob(at)aeroelectric.com> wrote: > >> At 04:33 PM 6/11/2020, you wrote: >> >> jan_de_jong(at)casema.nl> >> >> Dear all, >> >> Better not confuse LiPo with LiFePO4 (also called LFP). Important >> differences. >> A search with both terms will lead to some clarity I expect. >> >> >> An very important point. Not all 'lithium' cells >> are the same. While the energy density is >> higher for chemistries other than lithium >> iron phosphate (LiFePo4), the relative >> robustness and safety of the LiFePo4 >> devices has prompted a chemistry of choice >> decision for most suppliers to our craft . . . >> indeed most consumer motive power applications. >> >> For our purposes, when ever I refer to >> a lithium product, know that I'm referring >> to the LiFePo4 technology. >> >> Speaking of LiFePo4: >> >> I observe that virtually all the COTS lithium >> chargers in my stable, every one 'tops off' >> at 4.2 volts. These chargers were used to >> explore qualities of a bevy of 18650 >> cells laying around the shop. I've >> attached a plot for a constellation >> of cells. A plot of the as-found condition >> of a cell was followed by a plot of a >> recharged condition. >> >> Most of the 'weak' cells showed marked >> recovery . . . others did not. One interesting >> feature of this exercise is to note the >> starting voltage for the discharge plot >> of each recharged cell. >> >> Virtually all produced first delivery of >> energy at 4.0 volts or more. Hmmm . . . >> It seems this was related to charging >> top-off voltage. Okay, if one wishes >> to maximize exploitation of your ship' >> lithium battery, do you want to raise >> your alternator voltage to 4 x 4.2 >> 16.8 volts? >> >> Hmmm . . . most of our electro whizzies >> probably wouldn't mind . . . but if you're >> carrying incandescent lights of any size, >> service life would be reduced by 50% or more . . . >> but they would certainly be bright! >> >> I've posted an article found on powerstream.com >> >> See: https://tinyurl.com/yazw9jnh >> >> By the way, check out the rest of this website. >> It's a treasure trove of data on DC power >> systems. I had the name of the author at >> one time but let it get lost. If anyone >> perusing this resource runs across the author's >> name, I'd appreciate a heads-up. >> >> The article illustrates some interesting numbers >> on LiFePo4 performance. First, there is >> little value in charging the LiFePo4 cell >> at it rated maximum. The writer demonstrates >> that charging at considerably lower levels >> does not significantly affect stored energy >> until charge-per-cell voltage drops below >> 3.40. Okay, 3.40 x 4 is 13.6 volts. I >> think we can live with that! >> >> In fact, we're told that the charge-discharge >> service life of lithium cells is improved >> by operating the cells between 30 and 90% >> of the chemical capacity of the cell. Okay >> operating the contemporary 4-cell array >> products at the legacy 14.2 to 14.4 volts >> (3.6 volts per cell) wont give up significant >> performance while extending service life. >> >> I'm going to repeat the experiment in the >> article cited. I will add features >> that explore system integration questions >> going to what may prove to be the 'next >> generation' of OBAM aviation electrical system >> architectures. >> >> Bob . . . >> > -- --- David Carter david(at)carter.net ________________________________________________________________________________
Date: Jun 12, 2020
Commercial Off The Shelf rather than custom made On 12/06/2020 3:45 PM, Ken Ryan wrote: > Okay, 20 minutes with google reveals plenty of examples of COTS > chargers, but no definition of COTS. Could someone please educate me > on this terminology? Thanks. > > ________________________________________________________________________________
Date: Jun 12, 2020
Commercial Of The Shelf. In other words purchaseable. On Fri, Jun 12, 2020, 13:14 Ken Ryan wrote: > Okay, 20 minutes with google reveals plenty of examples of COTS chargers, > but no definition of COTS. Could someone please educate me on this > terminology? Thanks. > > > On Fri, Jun 12, 2020 at 9:27 AM Robert L. Nuckolls, III < > nuckolls.bob(at)aeroelectric.com> wrote: > >> At 04:33 PM 6/11/2020, you wrote: >> >> jan_de_jong(at)casema.nl> >> >> Dear all, >> >> Better not confuse LiPo with LiFePO4 (also called LFP). Important >> differences. >> A search with both terms will lead to some clarity I expect. >> >> >> An very important point. Not all 'lithium' cells >> are the same. While the energy density is >> higher for chemistries other than lithium >> iron phosphate (LiFePo4), the relative >> robustness and safety of the LiFePo4 >> devices has prompted a chemistry of choice >> decision for most suppliers to our craft . . . >> indeed most consumer motive power applications. >> >> For our purposes, when ever I refer to >> a lithium product, know that I'm referring >> to the LiFePo4 technology. >> >> Speaking of LiFePo4: >> >> I observe that virtually all the COTS lithium >> chargers in my stable, every one 'tops off' >> at 4.2 volts. These chargers were used to >> explore qualities of a bevy of 18650 >> cells laying around the shop. I've >> attached a plot for a constellation >> of cells. A plot of the as-found condition >> of a cell was followed by a plot of a >> recharged condition. >> >> Most of the 'weak' cells showed marked >> recovery . . . others did not. One interesting >> feature of this exercise is to note the >> starting voltage for the discharge plot >> of each recharged cell. >> >> Virtually all produced first delivery of >> energy at 4.0 volts or more. Hmmm . . . >> It seems this was related to charging >> top-off voltage. Okay, if one wishes >> to maximize exploitation of your ship' >> lithium battery, do you want to raise >> your alternator voltage to 4 x 4.2 >> 16.8 volts? >> >> Hmmm . . . most of our electro whizzies >> probably wouldn't mind . . . but if you're >> carrying incandescent lights of any size, >> service life would be reduced by 50% or more . . . >> but they would certainly be bright! >> >> I've posted an article found on powerstream.com >> >> See: https://tinyurl.com/yazw9jnh >> >> By the way, check out the rest of this website. >> It's a treasure trove of data on DC power >> systems. I had the name of the author at >> one time but let it get lost. If anyone >> perusing this resource runs across the author's >> name, I'd appreciate a heads-up. >> >> The article illustrates some interesting numbers >> on LiFePo4 performance. First, there is >> little value in charging the LiFePo4 cell >> at it rated maximum. The writer demonstrates >> that charging at considerably lower levels >> does not significantly affect stored energy >> until charge-per-cell voltage drops below >> 3.40. Okay, 3.40 x 4 is 13.6 volts. I >> think we can live with that! >> >> In fact, we're told that the charge-discharge >> service life of lithium cells is improved >> by operating the cells between 30 and 90% >> of the chemical capacity of the cell. Okay >> operating the contemporary 4-cell array >> products at the legacy 14.2 to 14.4 volts >> (3.6 volts per cell) wont give up significant >> performance while extending service life. >> >> I'm going to repeat the experiment in the >> article cited. I will add features >> that explore system integration questions >> going to what may prove to be the 'next >> generation' of OBAM aviation electrical system >> architectures. >> >> Bob . . . >> > ________________________________________________________________________________
Date: Jun 12, 2020
Subject: Z101 with Rotax 915iS
This is my first post to the mailing list so hopefully I get it reasonably right. I am not sure if this best fits this list or the Rotax engine list, but will start here. For context, I am a retired CS/EE and about to start my first home built project. My RANS S-21 is scheduled to ship in July. I plan to use a Rotax 915iS engine and am looking now at electrical system and avionics. I have read the Connection book and perused some of the newer Z architectures at the web site. I am leaning towards a Z101 configuration as the baseline, but the problem is that the Rotax comes with only one generator (I know it has two, but I believe the small one is only available to run the engine and not available for ships power). Rotax sells an external alternator kit, but a quick tally of the parts shows the cost to be north of $2,000 and I see nothing yet in the aftermarket. So, I am curious as to whether anyone here has installed a 915iS and, if so, what electrical system architecture did you choose. And, is anyone aware of alternative way to add a second alternator/generator to a 915iS or is the Rotax option the only game in town? My second choice is a second battery to back up the avionics and engine should the unthinkable happen and both alternators fail and the primary battery not have enough reserve to get to a safe landing site. Id much rather have a second alternator than a second battery, but $2,000 seems a little steep for an alternator that likely will never get used and a second battery at least has the advantage of extra starting reserve on our cold winter days in northern PA. Regards, Matt Whiting Sent from my iPad ________________________________________________________________________________
Date: Jun 12, 2020
battery bus I think that when doing failure analysis, you don't really pay that much attention to odds; you play 'what if'. (Actually, 'when it fails'; the assumption when doing failure analysis is that anything we can back up *will* fail). You do have to take uncontrollable stuff out of the equation; we can't carry an extra set of wings, for instance, and most of us accept the risk of a single engine, in order to be able to fly at all. Once that's out of the way, then 'what if' starts. What if the alternator fails? It's taken off line and battery backs it up. What if the battery fails? It's taken off line and the alternator backs it up (contrary to popular internet lore). If the engine isn't electrically dependent and we're VFR with nav on our phone, we don't even care about backup at all. The what if of both failing in a single flight is considered to be so unlikely that most are willing to treat a double failure like a wing or other structural failure; we're just not going to go there. My personal choice with a high-amps-need engine control system is to not accept the limited and continuously decreasing duration (capacity) of a standard battery, nor to accept the weight penalty of a much bigger battery or multiple batteries, in order to keep the engine running to the end of the flight. For me, that only leaves the choice of dual alternators. FWIW, Charlie On Fri, Jun 12, 2020 at 5:09 PM Matthew S. Whiting wrote: > m.whiting(at)frontier.com> > > > It seems to me the real question is which is more likely to fail: > > 1. A single battery with an age of 0 - 2 years or > 2. Both batteries simultaneously where one is 0 - 2 years old and the > other is 2 - 4 years old? > > I am not aware of a good source of battery failure rates, but my auto > experience over the course of 45 years suggests that alternative 1 has a > much higher probability than alternative 2. I have almost always had at > least four cars, trucks and motorcycles at any given time with battery ag es > between new and 8 years old. Even if I discount failures of batteries mo re > than 4 years old (I tend to run my car batteries to failure), I have had at > least two failures I can remember of with batteries less than two years > old. My Current Chevy Equinox OEM battery failed 5 months after I bought > the vehicle new in 2012. No charging system issues were found and the > warranty replacement battery lasted 6 years. I have NEVER had two of my > vehicles have battery failures at the same time or even closely spaced in > time. That suggests to me that the probability of a single new battery > failing is higher than the probability of simultaneous failure of two > batteries: one new and one older. > > I realize this isn=99t exactly the same scenario since two batterie s in the > same vehicle could have a common failure mode such as a runaway alternato r > that fries them both, but it is the best I can do. > > Matt > > > > On Jun 12, 2020, at 4:50 PM, Alec Myers wrote: > > myers.com > > > > > > Joe, > > > > Just to play devil=99s advocate, if you=99re prepared to re place a new > battery every other year, then if you only have one battery, the worst ca se > is that it=99s 2 years old. And you=99re not schlepping a 4 y ear old battery > around with you. > > Your mean battery age with two batteries would be three years; with a > single battery the mean age is only one year, an improvement by a factor of > 3. > > =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Jun 12, 2020
COTS is what you slept on in the military. On 6/12/2020 2:45 PM, Ken Ryan wrote: > Okay, 20 minutes with google reveals plenty of examples of COTS > chargers, but no definition of COTS. Could someone please educate me > on this terminology? Thanks. > > > On Fri, Jun 12, 2020 at 9:27 AM Robert L. Nuckolls, III > > > wrote: > > At 04:33 PM 6/11/2020, you wrote: >> > >> >> Dear all, >> >> Better not confuse LiPo with LiFePO4 (also called LFP). Important >> differences. >> A search with both terms will lead to some clarity I expect. > > An very important point. Not all 'lithium' cells > are the same. While the energy density is > higher for chemistries other than lithium > iron phosphate (LiFePo4), the relative > robustness and safety of the LiFePo4 > devices has prompted a chemistry of choice > decision for most suppliers to our craft . . . > indeed most consumer motive power applications. > > For our purposes, when ever I refer to > a lithium product, know that I'm referring > to the LiFePo4 technology. > > Speaking of LiFePo4: > > I observe that virtually all the COTS lithium > chargers in my stable, every one 'tops off' > at 4.2 volts. These chargers were used to > explore qualities of a bevy of 18650 > cells laying around the shop. I've > attached a plot for a constellation > of cells. A plot of the as-found condition > of a cell was followed by a plot of a > recharged condition. > > Most of the 'weak' cells showed marked > recovery . . . others did not. One interesting > feature of this exercise is to note the > starting voltage for the discharge plot > of each recharged cell. > > Virtually all produced first delivery of > energy at 4.0 volts or more. Hmmm . . . > It seems this was related to charging > top-off voltage. Okay, if one wishes > to maximize exploitation of your ship' > lithium battery, do you want to raise > your alternator voltage to 4 x 4.2 > 16.8 volts? > > Hmmm . . . most of our electro whizzies > probably wouldn't mind . . . but if you're > carrying incandescent lights of any size, > service life would be reduced by 50% or more . . . > but they would certainly be bright! > > I've posted an article found on powerstream.com > <http://powerstream.com> > > See: https://tinyurl.com/yazw9jnh > > By the way, check out the rest of > this website. > It's a treasure trove of data on DC power > systems. I had the name of the author at > one time but let it get lost. If anyone > perusing this resource runs across the author's > name, I'd appreciate a heads-up. > > The article illustrates some interesting numbers > on LiFePo4 performance. First, there is > little value in charging the LiFePo4 cell > at it rated maximum. The writer demonstrates > that charging at considerably lower levels > does not significantly affect stored energy > until charge-per-cell voltage drops below > 3.40. Okay, 3.40 x 4 is 13.6 volts. I > think we can live with that! > > In fact, we're told that the charge-discharge > service life of lithium cells is improved > by operating the cells between 30 and 90% > of the chemical capacity of the cell. Okay > operating the contemporary 4-cell array > products at the legacy 14.2 to 14.4 volts > (3.6 volts per cell) wont give up significant > performance while extending service life. > > I'm going to repeat the experiment in the > article cited. I will add features > that explore system integration questions > going to what may prove to be the 'next > generation' of OBAM aviation electrical system > architectures. > > Bob . . . > ________________________________________________________________________________
Date: Jun 12, 2020
Commercial Off The Shelf Sent from my iPad > On Jun 12, 2020, at 6:25 PM, Ken Ryan wrote: > > =EF=BB > Okay, 20 minutes with google reveals plenty of examples of COTS chargers, b ut no definition of COTS. Could someone please educate me on this terminolog y? Thanks. > ________________________________________________________________________________
Subject: Re: Z101 with Rotax 915iS
Date: Jun 12, 2020
The Rotax 912iS engine has two generators. Generator A 16 Amp is for engine only. Generator B 30 Amp is for aircraft electrical system. If generator A fails, generator B automatically takes over engine duties, but no longer supplies the aircraft electrical system. If generator B also fails, the pilot may operate a switch to operate the engine using aircraft battery power. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=496806#496806 ________________________________________________________________________________
Date: Jun 12, 2020
It seems to me that, even though it does not allow you to strictly follow the new and improved Z101, the standard Rotax 915iS (two alternators + battery) offers good redundancy. What is it about that set up that you find lacking? Ken On Fri, Jun 12, 2020 at 2:54 PM Matthew S. Whiting wrote: > m.whiting(at)frontier.com> > > This is my first post to the mailing list so hopefully I get it reasonabl y > right. I am not sure if this best fits this list or the Rotax engine lis t, > but will start here. > > For context, I am a retired CS/EE and about to start my first home built > project. My RANS S-21 is scheduled to ship in July. I plan to use a Rot ax > 915iS engine and am looking now at electrical system and avionics. > > I have read the Connection book and perused some of the newer Z > architectures at the web site. I am leaning towards a Z101 configuration > as the baseline, but the problem is that the Rotax comes with only one > generator (I know it has two, but I believe the small one is only availab le > to run the engine and not available for ship=99s power). Rotax sel ls an > external alternator kit, but a quick tally of the parts shows the cost to > be north of $2,000 and I see nothing yet in the aftermarket. > > So, I am curious as to whether anyone here has installed a 915iS and, if > so, what electrical system architecture did you choose. And, is anyone > aware of alternative way to add a second alternator/generator to a 915iS or > is the Rotax option the only game in town? > > My second choice is a second battery to back up the avionics and engine > should the unthinkable happen and both alternators fail and the primary > battery not have enough reserve to get to a safe landing site. I =99d much > rather have a second alternator than a second battery, but $2,000 seems a > little steep for an alternator that likely will never get used and a seco nd > battery at least has the advantage of extra starting reserve on our cold > winter days in northern PA. > > Regards, > Matt Whiting > > Sent from my iPad > =========== =========== =========== =========== =========== > > ________________________________________________________________________________
battery bus
Date: Jun 12, 2020
I was simply addressing the question as posed, at least my understanding of t he question. It seemed to be suggesting that one battery replaced every 2 y ears was more reliable than two batteries each replaced every 4 years since o n average the one battery was newer than the combination of the two. I don =99t think that is a correct assumption. I certainly would take two alternators and one battery over one alternator a nd two batteries as well, and that is a scenario I posted earlier today in r egards to my soon to arrive S-21 kit and 915iS engine. Unfortunately, of th e two generators in the 915iS, it appears that only one is actually accessib le for non-engine power supply. So, that configuration actually needs 3 in o rder to have two available for pitot heat, lights, avionics, etc. However, I would take two batteries (alternated every other year) and one al ternator over one battery (new every 2 years) and one alternator. Matt > On Jun 12, 2020, at 6:55 PM, Charlie England wrote: > > =EF=BB > I think that when doing failure analysis, you don't really pay that much a ttention to odds; you play 'what if'. (Actually, 'when it fails'; the assump tion when doing failure analysis is that anything we can back up *will* fail ). You do have to take uncontrollable stuff out of the equation; we can't ca rry an extra set of wings, for instance, and most of us accept the risk of a single engine, in order to be able to fly at all. > > Once that's out of the way, then 'what if' starts. What if the alternator f ails? It's taken off line and battery backs it up. What if the battery fails ? It's taken off line and the alternator backs it up (contrary to popular in ternet lore). If the engine isn't electrically dependent and we're VFR with n av on our phone, we don't even care about backup at all. The what if of both failing in a single flight is considered to be so unlikely that most are wi lling to treat a double failure like a wing or other structural failure; we 're just not going to go there. > > My personal choice with a high-amps-need engine control system is to not a ccept the limited and continuously decreasing duration (capacity) of a stand ard battery, nor to accept the weight penalty of a much bigger battery or mu ltiple batteries, in order to keep the engine running to the end of the flig ht. For me, that only leaves the choice of dual alternators. > > FWIW, > > Charlie ________________________________________________________________________________
Date: Jun 12, 2020
Thanks! On Fri, Jun 12, 2020 at 2:21 PM C&K wrote: > > Commercial Off The Shelf rather than custom made > > On 12/06/2020 3:45 PM, Ken Ryan wrote: > > Okay, 20 minutes with google reveals plenty of examples of COTS > > chargers, but no definition of COTS. Could someone please educate me > > on this terminology? Thanks. > > > > > > ________________________________________________________________________________
Date: Jun 12, 2020
All accurate Joe. But I think there is a wrinkle. It is my understanding that if Gen A fails, AND the Emergency Power Switch is closed, THEN Gen B will operate both Engine and power the Bus. At least that's my understanding. On Fri, Jun 12, 2020 at 4:31 PM user9253 wrote: > > The Rotax 912iS engine has two generators. > Generator A 16 Amp is for engine only. > Generator B 30 Amp is for aircraft electrical system. > If generator A fails, generator B automatically takes over engine duties, > but no longer supplies the aircraft electrical system. > If generator B also fails, the pilot may operate a switch to > operate the engine using aircraft battery power. > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=496806#496806 > > ________________________________________________________________________________
Date: Jun 12, 2020
Yes, that is my understanding. My desire though is to have two alternators available for the aircraft electrical system. The question is: is there an economical way to do that? The Rotax way appears to cost at least $2,000. Which I probably will suck it up and do if there is no other way as I plan to fly IFR and I like to have good backup not just for a comm radio and transponder, but also pitot heat at least and that generally takes some juice. Although, I think the Garmin regulated pitot should be a fair bit more efficient unless it is really cold out. Sent from my iPad > On Jun 12, 2020, at 8:31 PM, user9253 wrote: > > > The Rotax 912iS engine has two generators. > Generator A 16 Amp is for engine only. > Generator B 30 Amp is for aircraft electrical system. > If generator A fails, generator B automatically takes over engine duties, > but no longer supplies the aircraft electrical system. > If generator B also fails, the pilot may operate a switch to > operate the engine using aircraft battery power. > > -------- > Joe Gores ________________________________________________________________________________
Date: Jun 13, 2020
At 07:38 PM 6/12/2020, you wrote: >All accurate Joe. But I think there is a wrinkle. It is my >understanding that if Gen A fails, AND the Emergency Power Switch is >closed, THEN Gen B will operate both Engine and power the Bus. At >least that's my understanding. You need to start your project planning with a load analysis: A comparison of system energy demands with energy supplies (gen a, gen b, bat a, etc) under the various phases of flight (taxi/t-o, day vfr cruise, night cruise, ifr cruise, and then decide what items will be shut off under which failure condition). Z101 is NOT applicable to the Rotax. That engine's design and energy supplies are pretty much cut in stone by the engine manufacturer. But your need to quantify and then organize your energy requirements is still the same. There are examples of load analysis in both Excel and paper forms at: https://tinyurl.com/9rt6ymn You first need to KNOW that there's energy available to power up your planned suite of electro-whizzies . . . you mentioned pitot heat . . . do you plan to poke holes in clouds? Each phase of flight has its own energy budget. The electrical section (24) of the Rotax manual is not very clear as to what the engine's energy needs are. I didn't find any mention of what power (if any) is available from the PM alternator-A under alternator-B failure conditions. Without that kind of information, you're not going to be able to define the 'dual alternator' opportunities of this engine. Bob . . . ________________________________________________________________________________
Date: Jun 13, 2020
At 07:19 PM 6/12/2020, you wrote: > >The Rotax 912iS engine has two generators. >Generator A 16 Amp is for engine only. >Generator B 30 Amp is for aircraft electrical system. >If generator A fails, generator B automatically takes over engine duties, > but no longer supplies the aircraft electrical system. >If generator B also fails, the pilot may operate a switch to >operate the engine using aircraft battery power. . . . if the PM alternator fails, engine ops revert to the pad mounted alternator leaving NO power for other needs? Bob . . . ________________________________________________________________________________
Date: Jun 13, 2020
Subject: With Flooded cells, at what discharge does damage start?
Greetings, This isn't a relevant question for modern aircraft but I think the membership of this list will likely know so I hope I don't bother anyone by posting here. If you have a rarely used car with a traditional flooded cell lead-acid battery and keep an eye on the battery voltage, at what voltage should it be recharged to maintain a normal life? My old jeep has a small load while parked so the battery slowly drains and it is neither convenient for me to disconnect the battery nor keep a maintainer connected. If I charge it back up with my smart charger before the (nominally 70deg f) battery voltage drops to say, 12V will I still get full life out of the battery? Thanks in advance, Steve Stearns O235 Longeze Boulder/Longmont CO ________________________________________________________________________________
Subject: Gerdes vs ACS key switch wiring
Date: Jun 13, 2020
I have the ACS 502 key switch and was wondering how to wire the center ground. B&C instructions for the GERDES key switch say DO NOT connect the center GND to any structural member in the cabin wheres the ACS instructions tell the opposite. ACS Note C: http://acsproducts.co/wp-content/uploads/2013/10/Wiring-Diagram.jpg GERDES: https://bandc.com/wp-content/uploads/2019/03/s811-1_contactor_501-3_fig4.pdf -------- Igor RV10 in progress Read this topic online here: http://forums.matronics.com/viewtopic.php?p=496815#496815 ________________________________________________________________________________
Date: Jun 13, 2020
Subject: Re: Gerdes vs ACS key switch wiring
At 10:00 AM 6/13/2020, you wrote: > >I have the ACS 502 key switch and was wondering how to wire the center ground. > >B&C instructions for the GERDES key switch say DO NOT connect the >center GND to any structural member in the cabin wheres the ACS >instructions tell the opposite. > >ACS Note C: >http://acsproducts.co/wp-content/uploads/2013/10/Wiring-Diagram.jpg > >GERDES: >https://bandc.com/wp-content/uploads/2019/03/s811-1_contactor_501-3_fig4.pdf There is no BENEFIT for connecting to ground locally . . . but there is RISK for damaging p-lead shields due to starter currents flowing in a ground-loop situation. Wire per examples in the z-figures where shields are terminated at the mags and NO grounds are added at the switch(es) whether a o-l-r-b-s keyswitch or toggles. Bob . . . ________________________________________________________________________________
Date: Jun 13, 2020
Subject: Re: With Flooded cells, at what discharge does damage
start? At 09:09 AM 6/13/2020, you wrote: >Greetings, > >This isn't a relevant question for modern >aircraft but I think the membership of this list >will likely know so I hope I don't bother anyone by posting here. > >If you have a rarely used car with a traditional >flooded cell lead-acid battery and keep an eye >on the battery voltage, at what voltage should >it be recharged to maintain a normal life?=C2 My >old jeep has a small load while parked so the >battery slowly drains and it is neither >convenient for me to disconnect the battery nor >keep a maintainer connected.=C2 If I charge it >back up with my smart charger=C2 before the >(nominally 70deg f) battery voltage drops to >say, 12V will I still get full life out of the battery? that would be a good milestone for initiating a top-off charge. You could probably let it go lower but keeping it above 12v will improve longevity. Bob . . . ________________________________________________________________________________
Date: Jun 13, 2020
Both Generator A and generator B are permanent magnet type integrated with the engine. The magnets are embedded in the flywheel. Other than the magnets, there are no moving parts. The two generators are just two stationary sets of coils. Generator A is for engine only. If "A" fails, Generator B will automatically take over engine duties and automatically disconnect from the aircraft electrical system. However as pointed out in previous posts, the pilot can cheat and flip the backup switch which will reconnect generator B to the aircraft electrical system. Doing that could jeopardize electrical power that is available to the engine. According to above posts, an optional external alternator is available for $2000. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=496818#496818 ________________________________________________________________________________
Date: Jun 13, 2020
Thanks for confirming Joe, and clarifying that "cheating" opens up the risk of starving the engine of necessary electrical power. While $2k for the THIRD approved (but not certified) alternator is tough to swallow, it's peanuts compared to the $37k price of the engine itself. I just couldn't believe it when Bob said he couldn't find any info on what the electrical current requirements are for running the engine, so I scoured the Installation, Line Maintenance and Heavy Maintenance manuals and I too couldn't find any information at all in that regard. Pretty hard to make intelligent decisions about important things like best battery size without that essential information. Also, if one is unlucky enough to suffer dual alternator failure, wouldn't it be good to know how long before the engine quits? What is Rotax thinking? Ken On Sat, Jun 13, 2020 at 8:27 AM user9253 wrote: > > Both Generator A and generator B are permanent magnet type integrated with > the engine. The magnets are embedded in the flywheel. Other than the > magnets, there are no moving parts. The two generators are just two > stationary sets of coils. Generator A is for engine only. If "A" fails, > Generator B will automatically take over engine duties and automatically > disconnect from the aircraft electrical system. However as pointed out in > previous posts, the pilot can cheat and flip the backup switch which will > reconnect generator B to the aircraft electrical system. Doing that could > jeopardize electrical power that is available to the engine. > According to above posts, an optional external alternator is available > for $2000. > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=496818#496818 > > ________________________________________________________________________________
Date: Jun 13, 2020
On Sat, Jun 13, 2020 at 11:48 AM Charlie England wrote: > On Fri, Jun 12, 2020 at 5:54 PM Matthew S. Whiting > wrote: > >> m.whiting(at)frontier.com> >> >> This is my first post to the mailing list so hopefully I get it >> reasonably right. I am not sure if this best fits this list or the Rota x >> engine list, but will start here. >> >> For context, I am a retired CS/EE and about to start my first home built >> project. My RANS S-21 is scheduled to ship in July. I plan to use a Ro tax >> 915iS engine and am looking now at electrical system and avionics. >> >> I have read the Connection book and perused some of the newer Z >> architectures at the web site. I am leaning towards a Z101 configuratio n >> as the baseline, but the problem is that the Rotax comes with only one >> generator (I know it has two, but I believe the small one is only availa ble >> to run the engine and not available for ship=99s power). Rotax se lls an >> external alternator kit, but a quick tally of the parts shows the cost t o >> be north of $2,000 and I see nothing yet in the aftermarket. >> >> So, I am curious as to whether anyone here has installed a 915iS and, if >> so, what electrical system architecture did you choose. And, is anyone >> aware of alternative way to add a second alternator/generator to a 915iS or >> is the Rotax option the only game in town? >> >> My second choice is a second battery to back up the avionics and engine >> should the unthinkable happen and both alternators fail and the primary >> battery not have enough reserve to get to a safe landing site. I =99d much >> rather have a second alternator than a second battery, but $2,000 seems a >> little steep for an alternator that likely will never get used and a sec ond >> battery at least has the advantage of extra starting reserve on our cold >> winter days in northern PA. >> >> Regards, >> Matt Whiting > > Have you been able to take a close look at the hi-$ Rotax option? If it's > a belt driven alternator, then the only high barrier to rolling your own > might be the flywheel pulley. Brackets aren't that difficult to fabricate , > and an alternator is an alternator. Integrating it into the a/c systems > should be a simple matter of consulting an appropriate Z diagram here. > > Charlie > > Followup; if this is the right option, looks like you could buy all the Rotax drive & mounting bits, and still save about $1000 on the alternator itself, by using an off the shelf automotive model. The image in that parts breakout looks like a very common Nippon Denso internally regulated alternator that's available in output levels from around 35A to over 55A. They're all basically the same external dimensions. Charlie ________________________________________________________________________________
Date: Jun 13, 2020
On Fri, Jun 12, 2020 at 5:54 PM Matthew S. Whiting wrote: > m.whiting(at)frontier.com> > > This is my first post to the mailing list so hopefully I get it reasonabl y > right. I am not sure if this best fits this list or the Rotax engine lis t, > but will start here. > > For context, I am a retired CS/EE and about to start my first home built > project. My RANS S-21 is scheduled to ship in July. I plan to use a Rot ax > 915iS engine and am looking now at electrical system and avionics. > > I have read the Connection book and perused some of the newer Z > architectures at the web site. I am leaning towards a Z101 configuration > as the baseline, but the problem is that the Rotax comes with only one > generator (I know it has two, but I believe the small one is only availab le > to run the engine and not available for ship=99s power). Rotax sel ls an > external alternator kit, but a quick tally of the parts shows the cost to > be north of $2,000 and I see nothing yet in the aftermarket. > > So, I am curious as to whether anyone here has installed a 915iS and, if > so, what electrical system architecture did you choose. And, is anyone > aware of alternative way to add a second alternator/generator to a 915iS or > is the Rotax option the only game in town? > > My second choice is a second battery to back up the avionics and engine > should the unthinkable happen and both alternators fail and the primary > battery not have enough reserve to get to a safe landing site. I =99d much > rather have a second alternator than a second battery, but $2,000 seems a > little steep for an alternator that likely will never get used and a seco nd > battery at least has the advantage of extra starting reserve on our cold > winter days in northern PA. > > Regards, > Matt Whiting Have you been able to take a close look at the hi-$ Rotax option? If it's a belt driven alternator, then the only high barrier to rolling your own might be the flywheel pulley. Brackets aren't that difficult to fabricate, and an alternator is an alternator. Integrating it into the a/c systems should be a simple matter of consulting an appropriate Z diagram here. Charlie ________________________________________________________________________________
Date: Jun 13, 2020
start? Would a solar trickle charger help?=C2- I got one off Amazon for less th an $15 that is flexible and tops out at 14.4V. ara.com> wrote: Greetings, This isn't a relevant question for modern aircraft but I think the membersh ip of this list will likely know so I hope I don't bother anyone by posting here. If you have a rarely used car with a traditional flooded cell lead-acid bat tery and keep an eye on the battery voltage, at what voltage should it be r echarged to maintain a normal life?=C2- My old jeep has a small load whil e parked so the battery slowly drains and it is neither convenient for me t o disconnect the battery nor keep a maintainer connected.=C2- If I charge it back up with my smart charger=C2-before the (nominally 70deg f) batte ry voltage drops to say, 12V will I still get full life out of the battery? Thanks in advance,Steve StearnsO235=C2-LongezeBoulder/Longmont CO ________________________________________________________________________________
Subject: Surplus Wire
Date: Jun 13, 2020
I have a bunch of surplus BMS13-48 ETFE wire, 5 nickle-plated 24ga conductors, shielded. Reading the AEC it seems an ok practice to bundle these conductors for larger currents, so I could use them together as a 18ga substitute from the table in Figure 8-3. I'm wondering what I should do with the shield though? Is it useful to connect it to anything? Any other advice/cautions about using nickle-plated BMS? My work let me dig through the scrap bin and I have hundreds of feet of this stuff. Thanks. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=496824#496824 ________________________________________________________________________________
From: "skywagon185guy ." <skywagon185(at)gmail.com>
Date: Jun 13, 2020
start? Steve, I am a strong advocate of clipping on a "Maintainer" type small charger to our lead acid batteries. They don't have to be expensive types. One brand Schumacher is low cost, good quality, and easily available. Connect it and leave it on. To answer your question, here is my personal opinion. After the maintainer charges the battery and gets to the point where it senses full charge, it switches back to the "maintenance" or float state. I believe the voltage range should be stabilized at: 13.2 to 13.4 volts. If the battery is aged, I like 13.2 best. If the battery is young, 13.4 is good. This is based mainly on cell water loss. Just a tad too high, e.g. 13.4 instead of 13.2, might make the battery gas a bit. So, the only way to check what the maintainer's float voltage is set to, is to accurately measure the final resting voltage. The 1st generations of these clever little units where adjustable for final voltage, but, alas, I believe the later generations are sealed. If your unit is 13.4v, use it with the knowledge that you might have to add a tad of distilled water every now and again. The newer sealed type batteries, probably never. On Sat, Jun 13, 2020 at 7:30 AM Steve Stearns wrote: > Greetings, > > This isn't a relevant question for modern aircraft but I think the > membership of this list will likely know so I hope I don't bother anyone by > posting here. > > If you have a rarely used car with a traditional flooded cell lead-acid > battery and keep an eye on the battery voltage, at what voltage should it > be recharged to maintain a normal life? My old jeep has a small load while > parked so the battery slowly drains and it is neither convenient for me to > disconnect the battery nor keep a maintainer connected. If I charge it > back up with my smart charger before the (nominally 70deg f) battery > voltage drops to say, 12V will I still get full life out of the battery? > > Thanks in advance, > Steve Stearns > O235 Longeze > Boulder/Longmont CO > ________________________________________________________________________________
Subject: Re: Surplus Wire
Date: Jun 13, 2020
On 6/13/2020 8:22 PM, BMC_Dave wrote: > > I have a bunch of surplus BMS13-48 ETFE wire, 5 nickle-plated 24ga conductors, shielded. > > Reading the AEC it seems an ok practice to bundle these conductors for larger currents, so I could use them together as a 18ga substitute from the table in Figure 8-3. > > I'm wondering what I should do with the shield though? Is it useful to connect it to anything? > > Any other advice/cautions about using nickle-plated BMS? My work let me dig through the scrap bin and I have hundreds of feet of this stuff. Thanks. I might be speaking out of the wrong orifice, but IIRC, nickel plated is intended only for crimping, and is not solder friendly. If you're only crimping, should be good to go. Just quite a bit of extra weight for the equivalent wire gauge. Have you thought about selling it off to other builders, to use for intercom wiring, trim servos, etc, and using the money to purchase appropriate gauges for various devices? Charlie -- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jun 13, 2020
>On Sat, Jun 13, 2020 at 8:27 AM user9253 ><fransew(at)gmail.com> wrote: >"user9253" <fransew(at)gmail.com> >Both Generator A and generator B are permanent >magnet type integrated with the engine.=C2 The >magnets are embedded in the flywheel.=C2 Other >than the magnets, there are no moving >parts.=C2 The two generators are just two >stationary sets of coils.=C2 Generator A is for engine only. They managed to squeeze a pretty healthy set of stators in there! Would be interesting to see the maintenance/overhaul data on those parts . . . but unable to locate same in documents downloaded so far. If generator-B is un-dedicated except in case of emergency, then it just MIGHT fold into a variant of Z101/8 sans engine bus . . . >=C2 According to above posts, an optional >external alternator is available for $2000. Hmmm . . . wonder if its the same AND20000 drive pad common to vacuum pumps like the on the 912/914 engines. If so, the B&C pad-mounted alternators may well perform well there for perhaps less money. You guys need to talk to B&C @ 316-283-8000 for confirmation/denial of compatibility. The Rotax documents are organized in ATA100 (Air Transport Association Spec 100) which speaks to subjects, formatting, language (many readers will not have English as their first language) and clarity of explanations. I've written numerous pages and sometimes whole sections destined to publish in a ATA100 documents intended for world wide consumption in the aviation disciplines. If I had submitted a work along the lines of section 24 of the Rotax installation manual, I think I would have reason to fear for my ongoing employment. After having read the thing a couple of times, I don't think I've got any more information about this engine's operations than I would get from their 4-color, marketing brochure. The wiring diagram is . . . well . . . I spent the day on the road and I need to UNwind . . . If these guys are aviation systems integrators, you sure couldn't tell it by their documentation. Bob . . . ________________________________________________________________________________
Date: Jun 13, 2020
Unfortunately I won't be selling it. I have harnesses for several things, so this will be at most two dozen circuits. Of which I can carry power and ground through one cable. So hey each one gets a wire for future use and a shield... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=496828#496828 ________________________________________________________________________________
Date: Jun 14, 2020
nuckolls.bob(at)aeroelect wrote: > At 10:00 AM 6/13/2020, you wrote: > > > > > I have the ACS 502 key switch and was wondering how to wire the center ground. > > > > B&C instructions for the GERDES key switch say DO NOT connect the center GND to any structural member in the cabin wheres the ACS instructions tell the opposite. > > > > ACS Note C: > > http://acsproducts.co/wp-content/uploads/2013/10/Wiring-Diagram.jpg (http://acsproducts.co/wp-content/uploads/2013/10/Wiring-Diagram.jpg) > > > > GERDES: > > https://bandc.com/wp-content/uploads/2019/03/s811-1_contactor_501-3_fig4.pdf (https://bandc.com/wp-content/uploads/2019/03/s811-1_contactor_501-3_fig4.pdf) > > There is no BENEFIT for connecting to ground locally . . . > but there is RISK for damaging p-lead shields due to > starter currents flowing in a ground-loop situation. > Wire per examples in the z-figures where shields are > terminated at the mags and NO grounds are added at > the switch(es) whether a o-l-r-b-s keyswitch or > toggles. > > > > Bob . . . Thank you! -------- Igor RV10 in progress Read this topic online here: http://forums.matronics.com/viewtopic.php?p=496830#496830 ________________________________________________________________________________
Date: Jun 14, 2020
Bob, I agree that the Rotax documentation needs improving. Something is lost in translation. Here is a link to the Rotax iS engine heavy maintenance manual. https://www.rotax-owner.com/pdf/MMH_915iASeries_ED0_R1.pdf Section 24-20-00 page 6 says, "The two 3-phase AC generators are physically separate power supplies which are integrated in the engine." But then in section 71-00-00 page 11 is says, "Integrated generator Permanent Magnet single-phase generator". So which is it, 3 phase or single phase. Looking at the picture of cable plugs, there are 3 wires, so it could be 3 phase. It looks like there are approximately 25 coils. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=496832#496832 ________________________________________________________________________________
Date: Jun 14, 2020
Oops, my mistake. The link I posted above is for the 915 engine, not the 912. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=496833#496833 ________________________________________________________________________________
Date: Jun 14, 2020
Here is the correct link to the 912iS heavy maintenance manual: https://www.cps-parts.com/cps/pdf/d05973.pdf It also has conflicting descriptions of the integrated alternator. Section 24-20-00 Page 5 says three phase. Section 71-00-00 Page 11 says single phase. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=496834#496834 ________________________________________________________________________________
start?
Date: Jun 15, 2020
Vic Syracuse has an article in this months Sport Aviation (June 2020) that deals with Batteries and Alternators. he says not to mistreat a battery by constantly leaving it on a non approved battery tender/charger between flight. Help me understand what an "approved charger" or what to avoid. Specific products will be good. May I assume maybe there are different chargers for different battery types? -------- Brooks Cone Bearhawk Patrol Kit Build Read this topic online here: http://forums.matronics.com/viewtopic.php?p=496836#496836 ________________________________________________________________________________
Date: Jun 15, 2020
damage start? At 10:57 AM 6/15/2020, you wrote: > >Vic Syracuse has an article in this months Sport Aviation (June >2020) that deals with Batteries and Alternators. > >he says not to mistreat a battery by constantly leaving it on a non >approved battery tender/charger between flight. > >Help me understand what an "approved charger" or what to >avoid. Specific products will be good. May I assume maybe there >are different chargers for different battery types? What Vic is referring to are 'battery maintainers' . . . which may also be a charger but with automatic step-down to a maintenace mode when the battery is topped off. If the advertising literature for the charger includes the word 'maintainer' then it's good to go. Brands like Battery Minder, Battery Tender and Schumacher are several choices to consider. A battery maintainer holds the voltage on a stored battery at JUST ABOVE it's normal resting point. This means that very small, self discharge currents flowing INSIDE the battery will be supported from OUTSIDE instead of from the battery's own resources. It cannot even charge, much less overcharge a battery. Bob . . . ________________________________________________________________________________
Date: Jun 15, 2020
damage start? >May I assume maybe there are different chargers for different battery types? Not really . . . there are some so-called, 'smart chargers' with front panel controls suggesting different charging modes for AGM, flooded and GEL batteries . . . but I've never been able to detect any useful differences in their charging protocols. If the battery is suited to run in a vehicle, then any charger suited to charge vehicle batteries is okay. CHARGING is not the critical feature . . . its what the charge does AFTER charging is complete so that overcharging damage does not occur and self-discharge currents are mitigated. Bob . . . ________________________________________________________________________________
Date: Jun 15, 2020
damage start? On Mon, Jun 15, 2020 at 11:08 AM bcone1381 wrote: > > Vic Syracuse has an article in this months Sport Aviation (June 2020) that > deals with Batteries and Alternators. > > he says not to mistreat a battery by constantly leaving it on a non > approved battery tender/charger between flight. > > Help me understand what an "approved charger" or what to avoid. Specific > products will be good. May I assume maybe there are different chargers for > different battery types? > > -------- > Brooks Cone > Bearhawk Patrol Kit Build I haven't read the article yet, but suspect he's talking about 'trickle chargers' that can output significantly higher than desirable voltage when the battery is fully charged and no longer loads the charger's output. This results in overcharging and shortening of the battery's life. Even with 'smart' chargers, if you don't monitor what they're doing, they could develop faults that would overcharge the battery. Here's the thing. With any current-tech sealed lead acid battery, or any lithium tech battery, their self discharge rates are so low that they will go for months, or even years, without being connected to a charger. Unless you only fly once a year, you're unlikely to ever need an external charge as long as the battery is healthy enough to be safe to fly with. I've had years in the past decade when family responsibilities kept my flying down to about 5-10 hrs a year, and I still rarely needed to charge the battery in my plane. My choice is to 'just (don't) do it', unless I've done something stupid like leave a load on the battery while I'm not flying. If it's not there, it can't hurt the battery. I'm uncomfortable with even leaving a smart charger connected to a battery when I'm not around to check on it occasionally, because a catastrophic fault could damage a lot more than the charger/battery combo. FWIW, Charlie ________________________________________________________________________________
Date: Jun 16, 2020
damage start? I let my fully charged EarthX sit for 12 months thinking it would be fine. It was not. It was completely discharged and would not take a re-charge. On Tue, Jun 16, 2020 at 8:49 AM Charlie England wrote: > > > On Mon, Jun 15, 2020 at 11:08 AM bcone1381 wrote: > >> > >> >> Vic Syracuse has an article in this months Sport Aviation (June 2020) >> that deals with Batteries and Alternators. >> >> he says not to mistreat a battery by constantly leaving it on a non >> approved battery tender/charger between flight. >> >> Help me understand what an "approved charger" or what to avoid. Specific >> products will be good. May I assume maybe there are different chargers for >> different battery types? >> >> -------- >> Brooks Cone >> Bearhawk Patrol Kit Build > > I haven't read the article yet, but suspect he's talking about 'trickle > chargers' that can output significantly higher than desirable voltage when > the battery is fully charged and no longer loads the charger's output. This > results in overcharging and shortening of the battery's life. Even with > 'smart' chargers, if you don't monitor what they're doing, they could > develop faults that would overcharge the battery. > > Here's the thing. With any current-tech sealed lead acid battery, or any > lithium tech battery, their self discharge rates are so low that they will > go for months, or even years, without being connected to a charger. Unless > you only fly once a year, you're unlikely to ever need an external charge > as long as the battery is healthy enough to be safe to fly with. I've had > years in the past decade when family responsibilities kept my flying down > to about 5-10 hrs a year, and I still rarely needed to charge the battery > in my plane. My choice is to 'just (don't) do it', unless I've done > something stupid like leave a load on the battery while I'm not flying. If > it's not there, it can't hurt the battery. I'm uncomfortable with even > leaving a smart charger connected to a battery when I'm not around to check > on it occasionally, because a catastrophic fault could damage a lot more > than the charger/battery combo. > > FWIW, > > Charlie > ________________________________________________________________________________
Date: Jun 15, 2020
Subject: KY97A connector
Strangely enough, this site, which caters to old arcade game restorers, has a compatible connector for most of the old card-edge units. https://mikesarcade.com/cgi-bin/store.pl?sku=CECM30 I bought one, in case I screwed up my own for a KT-76A, but noted that it will indeed fit with a slight modification of the width to fit the opening in the tray. Might be worth checking out. He also sells the pins a lot cheaper than most places, and yes, they are gold plated. https://mikesarcade.com/cgi-bin/store.pl?sku=CECPIN100 Best of luck "Let us disappoint the Men who are raising themselves on the ruin of this Country." - Sam Adams ________________________________________________________________________________
damage start?
Date: Jun 16, 2020
On 6/16/2020 2:07 PM, Ken Ryan wrote: > I let my fully charged EarthX sit for 12 months thinking it would be > fine. It was not. It was completely discharged and would not take a > re-charge. > > > On Tue, Jun 16, 2020 at 8:49 AM Charlie England > wrote: > > > On Mon, Jun 15, 2020 at 11:08 AM bcone1381 > wrote: > > > > > Vic Syracuse has an article in this months Sport Aviation > (June 2020) that deals with Batteries and Alternators. > > he says not to mistreat a battery by constantly leaving it on > a non approved battery tender/charger between flight. > > Help me understand what an "approved charger" or what to > avoid. Specific products will be good. May I assume maybe > there are different chargers for different battery types? > > -------- > Brooks Cone > Bearhawk Patrol Kit Build > > I haven't read the article yet, but suspect he's talking about > 'trickle chargers' that can output significantly higher than > desirable voltage when the battery is fully charged and no longer > loads the charger's output. This results in overcharging and > shortening of the battery's life. Even with 'smart' chargers, if > you don't monitor what they're doing, they could develop faults > that would overcharge the battery. > > Here's the thing. With any current-tech sealed lead acid battery, > or any lithium tech battery, their self discharge rates are so low > that they will go for months, or even years, without being > connected to a charger. Unless you only fly once a year, you're > unlikely to ever need an external charge as long as the battery is > healthy enough to be safe to fly with. I've had years in the past > decade when family responsibilities kept my flying down to about > 5-10 hrs a year, and I still rarely needed to charge the battery > in my plane. My choice is to 'just (don't) do it', unless I've > done something stupid like leave a load on the battery while I'm > not flying. If it's not there, it can't hurt the battery. I'm > uncomfortable with even leaving a smart charger connected to a > battery when I'm not around to check on it occasionally, because a > catastrophic fault could damage a lot more than the > charger/battery combo. > > FWIW, > > Charlie > Hmmm... From the EarthX website on the page dealing with charging. https://earthxbatteries.com/our-batteries/battery-charging Very first sentence: EarthX lithium batteries can sit on the shelf for up to a year without the need to charge it due to the low self discharge rate which is about 2% a month, compared to a lead acid battery which is approximately 30% per month. Obviously, you could have gotten a defective battery. Or, was it stored in freezing temps, or with a parasitic load, etc? I'm playing Luddite on the lithium in a/c issue for now, because I'm not convinced that enough has been *proven* about failure modes. Especially with stuff like EX's built-in 'black box' BMS. (No, I don't accept the FAA's word for it; they approved a bad crankshaft design from Lyc and *multiple* bad crankshaft designs from Continental.) The company is very active on the VAF forum, and their answers to some technical questions made it obvious that their public-facing rep is very short on engineering chops. One area that makes absolutely no sense is the claim they made over on VAF that their battery (actually a battery *system*, since the controller is built-in), can disconnect from a charging system when there's an overvoltage event, without disconnecting from the load. Impressive, given that there are only two terminals on the battery... It would be an easier sell for me if I had a separate BMS that really could block charge voltage and still supply the load, and that didn't auto-disconnect without operator control, and oh yeah, didn't cost roughly 10 X the price of my 'no-name' SLAs that last for 4-5 years on average. Anyway, SLA batteries can go a year or more without recharging, as well, as long as they're not defective, not stored on a freezing environment, and there's no parasitic load. Charlie -- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jun 16, 2020
Subject: Battery test
When I test my battery with a voltmeter it is 12.5 across the main posts. If I test the positive and move the negative lead to the firewall ground post, it is 11.7. Is this normal? Electrically challenged. Thanks, Ron Burnett May you have the Lord's blessings today! Sent from my iPad ________________________________________________________________________________
Date: Jun 16, 2020
Subject: Re: Premature EarthX death?
At 02:07 PM 6/16/2020, you wrote: >I let my fully charged EarthX sit for 12 months thinking it would be fine. >It was not. It was completely discharged and would not take a re-charge. > Hmmm . . . according to EarthX literature, expected self discharge rates are pretty much in line with other LiFePo4 products. What conditions was it stored in? Did you have any conversation about it with EarthX? Bob . . . ________________________________________________________________________________
Date: Jun 16, 2020
damage start? I agree. Based on published specs it should have been okay. But 12 months on the shelf in my heated shop and it was dead. I should have contacted EarthX, but I just blamed myself and bit the bullet. Just one experience, probably an anomaly. Hopefully. On Tue, Jun 16, 2020 at 1:02 PM Charlie England wrote: > On 6/16/2020 2:07 PM, Ken Ryan wrote: > > I let my fully charged EarthX sit for 12 months thinking it would be fine. > It was not. It was completely discharged and would not take a re-charge. > > > On Tue, Jun 16, 2020 at 8:49 AM Charlie England > wrote: > >> >> >> On Mon, Jun 15, 2020 at 11:08 AM bcone1381 wrote: >> >>> bcone1964(at)gmail.com> >>> >>> Vic Syracuse has an article in this months Sport Aviation (June 2020) >>> that deals with Batteries and Alternators. >>> >>> he says not to mistreat a battery by constantly leaving it on a non >>> approved battery tender/charger between flight. >>> >>> Help me understand what an "approved charger" or what to avoid. >>> Specific products will be good. May I assume maybe there are different >>> chargers for different battery types? >>> >>> -------- >>> Brooks Cone >>> Bearhawk Patrol Kit Build >> >> I haven't read the article yet, but suspect he's talking about 'trickle >> chargers' that can output significantly higher than desirable voltage when >> the battery is fully charged and no longer loads the charger's output. This >> results in overcharging and shortening of the battery's life. Even with >> 'smart' chargers, if you don't monitor what they're doing, they could >> develop faults that would overcharge the battery. >> >> Here's the thing. With any current-tech sealed lead acid battery, or any >> lithium tech battery, their self discharge rates are so low that they will >> go for months, or even years, without being connected to a charger. Unless >> you only fly once a year, you're unlikely to ever need an external charge >> as long as the battery is healthy enough to be safe to fly with. I've had >> years in the past decade when family responsibilities kept my flying down >> to about 5-10 hrs a year, and I still rarely needed to charge the battery >> in my plane. My choice is to 'just (don't) do it', unless I've done >> something stupid like leave a load on the battery while I'm not flying. If >> it's not there, it can't hurt the battery. I'm uncomfortable with even >> leaving a smart charger connected to a battery when I'm not around to check >> on it occasionally, because a catastrophic fault could damage a lot more >> than the charger/battery combo. >> >> FWIW, >> >> Charlie >> > Hmmm... > From the EarthX website on the page dealing with charging. > https://earthxbatteries.com/our-batteries/battery-charging > > Very first sentence: > EarthX lithium batteries can sit on the shelf for up to a year without the > need to charge it due to the low self discharge rate which is about 2% a > month, compared to a lead acid battery which is approximately 30% per month. > > Obviously, you could have gotten a defective battery. Or, was it stored in > freezing temps, or with a parasitic load, etc? > > > I'm playing Luddite on the lithium in a/c issue for now, because I'm not > convinced that enough has been *proven* about failure modes. Especially > with stuff like EX's built-in 'black box' BMS. (No, I don't accept the > FAA's word for it; they approved a bad crankshaft design from Lyc and > *multiple* bad crankshaft designs from Continental.) The company is very > active on the VAF forum, and their answers to some technical questions made > it obvious that their public-facing rep is very short on engineering chops. > One area that makes absolutely no sense is the claim they made over on VAF > that their battery (actually a battery *system*, since the controller is > built-in), can disconnect from a charging system when there's an > overvoltage event, without disconnecting from the load. Impressive, given > that there are only two terminals on the battery... > > It would be an easier sell for me if I had a separate BMS that really > could block charge voltage and still supply the load, and that didn't > auto-disconnect without operator control, and oh yeah, didn't cost roughly > 10 X the price of my 'no-name' SLAs that last for 4-5 years on average. > > Anyway, SLA batteries can go a year or more without recharging, as well, > as long as they're not defective, not stored on a freezing environment, and > there's no parasitic load. > > Charlie > > > Virus-free. > www.avast.com > > <#m_7123981709312888432_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> > ________________________________________________________________________________
Date: Jun 16, 2020
Subject: Re: Battery test
On Tue, Jun 16, 2020 at 4:06 PM Ron Burnett wrote: > ronburnett(at)charter.net> > > When I test my battery with a voltmeter it is 12.5 across the main posts. > If I test the positive and move the negative lead to the firewall ground > post, it is 11.7. Is this normal? > > Electrically challenged. > Thanks, > > Ron Burnett > > > I'll bet that if you measure from the firewall ground post to the battery negative, you'll see ~0.7V. That means you have enough resistance in that path to drop 0.7V in the path from firewall post to negative battery terminal. Is starter rotation sluggish? Charlie ________________________________________________________________________________
Date: Jun 16, 2020
It was on the bench, heated shop. I should have contacted EarthX but I just blamed myself. I am sure of the time frame because I had load tested it and made notations, and stored those notes with the battery. Ken On Tue, Jun 16, 2020 at 1:16 PM Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 02:07 PM 6/16/2020, you wrote: > > I let my fully charged EarthX sit for 12 months thinking it would be fine. > It was not. It was completely discharged and would not take a re-charge. > > > Hmmm . . . according to EarthX literature, expected > self discharge rates are pretty much in line with > other LiFePo4 products. > > What conditions was it stored in? Did you have > any conversation about it with EarthX? > > > Bob . . . > ________________________________________________________________________________
Date: Jun 16, 2020
No, that is not normal. Is the master switch turned on and aircraft electrical loads turned on during this test? I suggest taking apart all connectors between the battery negative post and the firewall ground post. Clean them and make sure the crimps are good. Then put it back together. You wrote "test the positive". Is the positive voltmeter probe touching the battery positive post and the negative voltmeter probe touching the firewall ground post? -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=496866#496866 ________________________________________________________________________________
Date: Jun 16, 2020
Subject: SDS CPI-2 internal crowbar
This thread over on VAF is interesting. I have the CPI-2 with their recommended small backup battery in my single-alternator, single-battery (for the main electrical system) VFR-only airplane. I'm planning an IFR upgrade with a full suite of Garmin G3X goodies, and want to follow the Z101 architecture. It seems that their internal crowbar & fuse leave me stuck with their backup battery. http://www.vansairforce.com/community/showthread.php?t=154648&page=34 -- --- David Carter david(at)carter.net ________________________________________________________________________________
Date: Jun 16, 2020
The master and no loads were on. I did have the probe on the positive terminal and when the negative probe was moved to the bolt head on the firewall with the forest of tabs inside the cabin, is where it dropped.7 volts. Will do as you suggested when I can. Ron Burnett May you have the Lord's blessings today! Sent from my iPad > On Jun 16, 2020, at 4:54 PM, user9253 wrote: > > > No, that is not normal. Is the master switch turned on and aircraft electrical > loads turned on during this test? I suggest taking apart all connectors > between the battery negative post and the firewall ground post. Clean them > and make sure the crimps are good. Then put it back together. > You wrote "test the positive". Is the positive voltmeter probe touching the battery > positive post and the negative voltmeter probe touching the firewall ground post? > > -------- > Joe Gores > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=496866#496866 > > > > > > > > > ________________________________________________________________________________
From: "Matthew S. Whiting" <m.whiting(at)frontier.com>
Date: Jun 17, 2020
Yes, exactly what I was looking at. I would probably spring a few hundred m ore for a B&C unit, but I suspect a car one would do the job as a second alt ernator. I am attending the Lockwood installation course in August, assumin g covid doesn=99t return and kill it, so I will know more then and be a ble to ask some questions, but it looks very doable with the Rotax pulley an d mounting rings. Although those pieces alone are about $1,000 as I recall. Crazy expensive, but then I own a BMW motorcycle so I am used to parts tha t cost 3X what they should. Matt > On Jun 17, 2020, at 5:13 AM, Charlie England wrote: >> > Followup; if this is the right option, looks like you could buy all the Ro tax drive & mounting bits, and still save about $1000 on the alternator itse lf, by using an off the shelf automotive model. The image in that parts brea kout looks like a very common Nippon Denso internally regulated alternator t hat's available in output levels from around 35A to over 55A. They're all ba sically the same external dimensions. > > Charlie ________________________________________________________________________________
Date: Jun 17, 2020
I believe Joe is correct and this is the reason I desire an external alternator. Even though the 915 has two alternators, it effectively only has one from the perspective of ships power. From page 3 of the Appendix to the Rotax 915iS installation manual. Engagement of the backup power supply system Generator B is done by the Engine Control Unit (ECU) in the case of over voltage and under voltage. If the voltage of power supply system Generator A decreases signifi- cantly or at all, the control transition of the power supplies is additionally done per mechanical means (relays drop out). These mechanism allow engagement of backup power supply under every probable circumstance. If power supply system Generator B is used to supply the aircraft electrical system (possible in common opera- tion mode) it must be noted that in case of failure this power supply system B is disconnected from the aircraft to serve as the backup to the EMS. > On Jun 17, 2020, at 5:15 AM, Ken Ryan wrote: > > > All accurate Joe. But I think there is a wrinkle. It is my understanding that if Gen A fails, AND the Emergency Power Switch is closed, THEN Gen B will operate both Engine and power the Bus. At least that's my understanding. ________________________________________________________________________________
Subject: Re: What is an RG battery?
Date: Jun 17, 2020
Hello....i didn't have good experience with RG battery. If you are having with your battery backup. If possible, try connecting it to a different outlet. If it is in a surge protector, remove it off the surge protector and connect it directly to the outlet. If there are still issues, it may be an issue with the unit itself. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=496883#496883 ________________________________________________________________________________
Date: Jun 17, 2020
$1,000?!=C2- For a pulley and some brackets?For those prices, you could have a machine shop design and custom build the pieces.=C2- Does no on in your EAA chapter own a lathe?=C2- No one around you does aluminum castin g? I mean, c'mon Rotax.=C2- I understand you've got to make a profit.=C2- But, you don't have to make it all off of one sale. ing(at)frontier.com> wrote: Yes, exactly what I was looking at. =C2-I would probably spring a few hu ndred more for a B&C unit, but I suspect a car one would do the job as a se cond alternator. =C2-I am attending the Lockwood installation course in A ugust, assuming covid doesn=99t return and kill it, so I will know mo re then and be able to ask some questions, but it looks very doable with th e Rotax pulley and mounting rings. =C2-Although those pieces alone are ab out $1,000 as I recall. =C2-Crazy expensive, but then I own a BMW motorcy cle so I am used to parts that cost 3X what they should. =C2- Matt On Jun 17, 2020, at 5:13 AM, Charlie England wrote: Followup; if this is the right option, looks like you could buy all the Rot ax drive & mounting bits, and still save about $1000 on the alternator itse lf, by using an off the shelf automotive model. The image in that parts bre akout looks like a very common Nippon Denso internally regulated alternator that's available in output levels from around 35A to over 55A. They're all basically the same external dimensions. Charlie ________________________________________________________________________________
Subject: Re: digest distribution stopped?
Date: Jun 17, 2020
Well, still no digest even after supposedly re-subscribing with the Matronics Email Distribution Tool and completing the email confirmation link. The tool shows subscribed to the AeroElectric list but I haven't received any digests like I had been. Is anyone else experiencing this? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=496886#496886 ________________________________________________________________________________
Date: Jun 17, 2020
start? Solar charger..... These are wonderful for certain applications, but, not for flooded 12v common batteries. A "12v panel", can raise to 18v on a sunny day. Even if it is only pumping out 0.1 amp, that will overcharge most lead acid batteries eventually, leading to "gassing". A cheap fix possible for using a low current panel is to trap the voltage output with a zener type diode or similar chosen to shunt current at some recommended voltage. On Sat, Jun 13, 2020 at 5:41 PM Ernest Christley wrote: > Would a solar trickle charger help? I got one off Amazon for less than > $15 that is flexible and tops out at 14.4V. > > steve(at)tomasara.com> wrote: > > > Greetings, > > This isn't a relevant question for modern aircraft but I think the > membership of this list will likely know so I hope I don't bother anyone by > posting here. > > If you have a rarely used car with a traditional flooded cell lead-acid > battery and keep an eye on the battery voltage, at what voltage should it > be recharged to maintain a normal life? My old jeep has a small load while > parked so the battery slowly drains and it is neither convenient for me to > disconnect the battery nor keep a maintainer connected. If I charge it > back up with my smart charger before the (nominally 70deg f) battery > voltage drops to say, 12V will I still get full life out of the battery? > > Thanks in advance, > Steve Stearns > O235 Longeze > Boulder/Longmont CO > ________________________________________________________________________________
Date: Jun 17, 2020
Subject: Re: SDS CPI-2 internal crowbar
At 04:44 PM 6/16/2020, you wrote: >This thread over on VAF is interesting. I have >the CPI-2 with their recommended small backup >battery in my single-alternator, single-battery >(for the main electrical system) VFR-only airplane.=C2 > >I'm planning an IFR upgrade with a full suite of >Garmin G3X goodies, and want to follow the Z101 architecture. =C2 > >It seems that their internal crowbar & fuse >leave me stuck with their backup battery. =C2 > ><http://www.vansairforce.com/community/showthread.php?t=154648&page=34> http://www.vansairforce.com/community/showthread.php?t=154648&page=34 This thread is a bit mystifying. OV conditions come from one and only one source(s) . . . alternators with failed regulators. An OV condition is not a transient event . . . it's a consistently rising voltage that will generally be limited by the battery(ies) as their chemistry gamely absorbs the excess energy condition. Hence the voltage does not rise quickly (i.e. volts per second) but rather sedately in electronic terms. For decades we have been designing, qualifying and integrating aviation electro-whizzies that are capable players in the wild and wooley world of vehicular DC power systems . . . matters not whether cars, trucks, earth movers . . . or airplanes. In 1935 some pretty smart cookies in the aviation industry got together in Washington DC and founded the Radio Technical Commission for Aeronautics (known today as RTCA). https://tinyurl.com/y78zvrt8 For 85 years these folk have been sifting the sands of physics in performance of electrical and electronics systems for aircraft. Their goal was to craft guidelines for the design and qualification of all manner of electrical accessory to (1) insure design performance under all anticipated conditions and (2) make sure that all accessories 'play nice' in the same sandbox such that arguments and spats do not put airframe or crew at risk. When it comes to ov definition, detection and response, the attached figures speak to 70+ years of design philosophy in aviation electrical systems. 14V devices are TESTED to withstand 20V perturbations for 1S and 30 (or 40) Volt perturbations for 100mS. Every device bolted to an airplane is expected to shrug off bus voltage perturbations between the high and low voltage plots for intervals of time laid out on the x-axis. When tasked with my first ov relay design about 1975, the rule of thumb was to design for a 50mS response to a step increase in bus voltage from 14.2 to 20 volts. While the electronics were solid-state, the 'timers' were pretty crude by contemporary standards. Today, micro-controllers allow us to start a timer when the voltage exceeds some lower discriminator, say 15 volts. If the voltage stays above that value for 500 milliseconds, we trip the ov protection system. If the voltage falls below 15v before time-out, the timer resets and the process starts over. This all but eliminates nuisance tripping of an ov protection system while offering robust but timely management of a recalcitrant regulator/alternator. Contemporary design recommendations are not difficult to accommodate . . . been doing it for decades. I've designed many products, some incorporating delicate silicon, wherein power was supplied directly from ship's bus . . . Often we were requested to qualify for indirect effects of lightning strike. Again, not difficult. I hope this lays foundation for consternation felt when I read about difficulties builders are having with the built-in ov protection on some product. It's even more difficult to understand how suppliers can offer what appears to be capable of producing really gee-whiz performance in some device but are unable to tailor electrical input-output ports to comfortably thrive in the aircraft environment. Adding any form of OV 'protection' to an accessory is completely redundant; i.e. unnecessary. Bob . . . ________________________________________________________________________________
Date: Jun 17, 2020
Subject: Re: Z101 with Rotax 915iS
If Gen A fails, the ECU will disconnect Gen B from the charging system (battery) and connect it to essential engine loads. Rotax does not want you to do it, but if you then close the Emergency Power switch, Gen B will also be re-connected to the charging system. In this condition, it would be possible to load the generator to the point where voltage drops to a level where the essential engine equipment fails. Because Rotax does not publish how much current the engine requires, it is difficult to determine what is safely available for running non-engine equipment. On Wed, Jun 17, 2020 at 5:37 AM Matthew S. Whiting wrote: > m.whiting(at)frontier.com> > > I believe Joe is correct and this is the reason I desire an external > alternator. Even though the 915 has two alternators, it effectively only > has one from the perspective of ship=99s power. From page 3 of the Appendix > to the Rotax 915iS installation manual. > > =9CEngagement of the backup power supply system Generator B is done by the > Engine Control Unit (ECU) in the case of over voltage and under voltage. If > the voltage of power supply system Generator A decreases signifi- cantly or > at all, the control transition of the power supplies is additionally done > per mechanical means (relays drop out). These mechanism allow engagement of > backup power supply under every probable circumstance. > > If power supply system Generator B is used to supply the aircraft > electrical system (possible in common opera- tion mode) it must be noted > that in case of failure this power supply system B is disconnected from t he > aircraft to serve as the backup to the EMS.=9C > > > > On Jun 17, 2020, at 5:15 AM, Ken Ryan wrote: > > > > =EF=BB > > All accurate Joe. But I think there is a wrinkle. It is my understandin g > that if Gen A fails, AND the Emergency Power Switch is closed, THEN Gen B > will operate both Engine and power the Bus. At least that's my > understanding. > > =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Jun 17, 2020
Date: Jun 17, 2020
The shield is sized for the combined current of the wires right? I'd like to use it for the other current conductor if I can. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=496895#496895 ________________________________________________________________________________
Date: Jun 17, 2020
On Wed, Jun 17, 2020 at 4:23 PM BMC_Dave wrote: > > The shield is sized for the combined current of the wires right? I'd like > to use it for the other current conductor if I can. > > > *In general*, that's not a bet I'd make, because shields are, well, shields. You don't normally see them carrying serious current, in the sense of actual power (RF transmission lines obviously excepted). Having said that, if we're still talking about 24 awg wire, it's extremely unlikely that the shield would be any smaller than that. If you're talking about using the shield for a single circuit's ground return, it sounds reasonable, but check for yourself by stripping a conductor, measuring approx. dia. with calipers, and then do the same with the shield 'drain' wire, assuming that it's a foil style shield. If it's braided copper strands, then the effective gauge might well be much larger than the combination of all 5 conductors combined. Just check it. Compute cross sectional area for a bare 24 awg wire, and do the same for the shield drain, using the basic pi * r^2 formula for the area of a circle. ________________________________________________________________________________
Date: Jun 17, 2020
start? I recently bought a solar panel that maxes out at 14.4V.=C2- It was adve rtised for that, but I tested it anyway.=C2- Given that it will output 0. 0V half the time, it's max output of 0.38A should be just right. It's flexible, and I attached to my canopy cover with velcro. 185(at)gmail.com> wrote: Solar charger.....These are wonderful for certain applications, but, not f or flooded 12v common batteries.=C2- A "12v panel", can raise to 18v on a sunny day.Even if it is only pumping out 0.1 amp, that will overcharge mos t lead acid batteries eventually, leading to "gassing".A cheap fix possible for using=C2-a low current panel is to trap the voltage output with a ze ner type diode or similar chosen to shunt current at some recommended volta ge. On Sat, Jun 13, 2020 at 5:41 PM Ernest Christley wrote : Would a solar trickle charger help?=C2- I got one off Amazon for less th an $15 that is flexible and tops out at 14.4V. ara.com> wrote: Greetings, This isn't a relevant question for modern aircraft but I think the membersh ip of this list will likely know so I hope I don't bother anyone by posting here. If you have a rarely used car with a traditional flooded cell lead-acid bat tery and keep an eye on the battery voltage, at what voltage should it be r echarged to maintain a normal life?=C2- My old jeep has a small load whil e parked so the battery slowly drains and it is neither convenient for me t o disconnect the battery nor keep a maintainer connected.=C2- If I charge it back up with my smart charger=C2-before the (nominally 70deg f) batte ry voltage drops to say, 12V will I still get full life out of the battery? Thanks in advance,Steve StearnsO235=C2-LongezeBoulder/Longmont CO ________________________________________________________________________________
Date: Jun 17, 2020
They don't publish how much the engine requires, but would it be difficult to insert a meter between the generator and the engine bus? l.com> wrote: If Gen A fails, the ECU will disconnect Gen B from the charging system (ba ttery) and connect it to essential engine loads. Rotax does not want you to do it, but if you then close the Emergency Power switch, Gen B will also b e re-connected to the charging system. In this condition, it would be possi ble to load the generator to the point where voltage drops to a level where the essential engine equipment fails. Because Rotax does not publish how m uch current the engine requires, it is difficult to determine what is safel y available for running non-engine equipment. On Wed, Jun 17, 2020 at 5:37 AM Matthew S. Whiting wrote: ontier.com> I believe Joe is correct and this is the reason I desire an external altern ator.=C2- Even though the 915 has two alternators, it effectively only ha s one from the perspective of ship=99s power.=C2- From page 3 of th e Appendix to the Rotax 915iS installation manual. =9CEngagement of the backup power supply system Generator B is done b y the Engine Control Unit (ECU) in the case of over voltage and under volta ge. If the voltage of power supply system Generator A decreases signifi- ca ntly or at all, the control transition of the power supplies is additionall y done per mechanical means (relays drop out). These mechanism allow engage ment of backup power supply under every probable circumstance. If power supply system Generator B is used to supply the aircraft electrica l system (possible in common opera- tion mode) it must be noted that in cas e of failure this power supply system B is disconnected from the aircraft t o serve as the backup to the EMS.=9C > On Jun 17, 2020, at 5:15 AM, Ken Ryan wrote: > > =EF=BB > All accurate Joe. But I think there is a wrinkle. It is my understanding that if Gen A fails, AND the Emergency Power Switch is closed, THEN Gen B w ill operate both Engine and power the Bus. At least that's my understanding . - Electric-List" rel="noreferrer" target="_blank">http://www.matronics.co m/Navigator?AeroElectric-List FORUMS - eferrer" target="_blank">http://forums.matronics.com WIKI - errer" target="_blank">http://wiki.matronics.com b Site - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jun 17, 2020
Well on the 912is since gen A is rated at 16 amps and gen B at 30 amps that's a big hint. But then I read that having both fuel pumps on might trip off gen A which just seems like poor design if true. Don't know if this is the same on the 915. Ken L. On 17/06/2020 10:07 AM, Ken Ryan wrote: > If Gen A fails, the ECU will disconnect Gen B from the charging system > (battery) and connect it to essential engine loads. Rotax does not > want you to do it, but if you then close the Emergency Power switch, > Gen B will also be re-connected to the charging system. In this > condition, it would be possible to load the generator to the point > where voltage drops to a level where the essential engine equipment > fails. Because Rotax does not publish how much current the engine > requires, it is difficult to determine what is safely available for > running non-engine equipment. > > On Wed, Jun 17, 2020 at 5:37 AM Matthew S. Whiting > > wrote: > > > > > I believe Joe is correct and this is the reason I desire an > external alternator. Even though the 915 has two alternators, it > effectively only has one from the perspective of ships power. > From page 3 of the Appendix to the Rotax 915iS installation manual. > > Engagement of the backup power supply system Generator B is done > by the Engine Control Unit (ECU) in the case of over voltage and > under voltage. If the voltage of power supply system Generator A > decreases signifi- cantly or at all, the control transition of the > power supplies is additionally done per mechanical means (relays > drop out). These mechanism allow engagement of backup power supply > under every probable circumstance. > > If power supply system Generator B is used to supply the aircraft > electrical system (possible in common opera- tion mode) it must be > noted that in case of failure this power supply system B is > disconnected from the aircraft to serve as the backup to the EMS. > > > > On Jun 17, 2020, at 5:15 AM, Ken Ryan > wrote: > > > > > > All accurate Joe. But I think there is a wrinkle. It is my > understanding that if Gen A fails, AND the Emergency Power Switch > is closed, THEN Gen B will operate both Engine and power the Bus. > At least that's my understanding. > > > ========== > - > Electric-List" rel="noreferrer" > target="_blank">http://www.matronics.com/Navigator?AeroElectric-List > ========== > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > ========== > WIKI - > errer" target="_blank">http://wiki.matronics.com > ========== > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" target="_blank">http://www.matronics.com/contribution > ========== > > ________________________________________________________________________________
Date: Jun 17, 2020
Subject: Z-11 ground avionics bus question
I hope the answer to this question is not too obvious; On Z-11 (and others), the connection between the instrument panel ground bus and the avionics ground bus is designated 5X20AWG. What exactly does that mean? - Do I take up 5 tabs on my ground buses with 20 ga wires? Thanks, Ben Glastar ________________________________________________________________________________
Date: Jun 17, 2020
At 04:12 PM 6/17/2020, you wrote: > >The shield is sized for the combined current of the wires right? I'd >like to use it for the other current conductor if I can. NO . . . it's for conducting the products of electro-static coupling. Essentially zero current. Run AMPs through a known length of shield, measure voltage drop through that segment. Compute the AWG equivalent from the resistance values in a wire table. Bob . . . ________________________________________________________________________________
Date: Jun 17, 2020
Subject: Re: Z-11 ground avionics bus question
At 06:57 PM 6/17/2020, you wrote: >I hope the answer to this question is not too obvious; > >On Z-11 (and others), the connection between the >instrument panel ground bus and the avionics >ground bus is designated 5X20AWG. What exactly does that mean?=C2 > * Do I take up 5 tabs on my ground buses with 20 ga wires? Yeah . . . 5 separate strands of 20AWG as long as you have the spares . . . otherwise . . . plan-B. The individual strands are easy. Bob . . . ________________________________________________________________________________
Date: Jun 17, 2020
Looking at the BMS13-48 spec the flat shield is tin coated copper, 0.0015" +-.0004 thk and 0.020" wide. I counted 16 strands in the braid I disassembled. So 0.02"x.0011"x16 is 0.000352 sqin area, which is between 13-14ga (13.6, apparently). So that's what, 20ish Amps conservatively? So the 5x 24ga conductors, slightly de-rated to 10A, seems the shield would be more than up to it. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=496905#496905 ________________________________________________________________________________
Date: Jun 18, 2020
What emergency power switch? I see no such reference in the 915iS installation manual. I looked at HIC A and B and X3 and I see no such switch terminals. X3-1 allows external power to be used in the event that both generator A and B fail together, but I see no emergency power switch. > On Jun 18, 2020, at 3:36 AM, Ken Ryan wrote: > > > If Gen A fails, the ECU will disconnect Gen B from the charging system (battery) and connect it to essential engine loads. Rotax does not want you to do it, but if you then close the Emergency Power switch, Gen B will also be re-connected to the charging system. In this condition, it would be possible to load the generator to the point where voltage drops to a level where the essential engine equipment fails. Because Rotax does not publish how much current the engine requires, it is difficult to determine what is safely available for running non-engine equipment. ________________________________________________________________________________
Date: Jun 18, 2020
n13en71(at)gmail.com wrote: > I hope the answer to this question is not too obvious; > > > On Z-11 (and others), the connection between the instrument panel ground bus and the avionics ground bus is designated 5X20AWG. What exactly does that mean? > Do I take up 5 tabs on my ground buses with 20 ga wires?Thanks, > Ben > Glastar Hi Ben, Have you seen Figure 18-17 in the Aeroelectric Connection Book? (and the accompanying text) Note that in Figure 18-17, "(Instrument) Panel Ground Bus" means forest of tabs aft side of firewall in the case of a tractor and in the cabin in the case of a pusher. The term "Panel Ground Bus" has been changed to "Firewall Ground Bus") on newer dwgs like Z101. -------- John Bright, RV-6A, at FWF, O-360 Z-101 single batt dual alt SDS EM-5-F. john_s_bright(at)yahoo.com, Newport News, Va https://drive.google.com/drive/folders/1u6GeZo6pmBWsKykLNVQMvu4o1VEVyP4K Read this topic online here: http://forums.matronics.com/viewtopic.php?p=496907#496907 ________________________________________________________________________________
Date: Jun 18, 2020
In the latest Installation Manual it is referred to as "Battery Backup Switch." On Thu, Jun 18, 2020 at 3:41 AM Matthew S. Whiting wrote: > m.whiting(at)frontier.com> > > > What emergency power switch? I see no such reference in the 915iS > installation manual. I looked at HIC A and B and X3 and I see no such > switch terminals. X3-1 allows external power to be used in the event tha t > both generator A and B fail together, but I see no emergency power switch . > > > > On Jun 18, 2020, at 3:36 AM, Ken Ryan wrote: > > > > =EF=BB > > If Gen A fails, the ECU will disconnect Gen B from the charging system > (battery) and connect it to essential engine loads. Rotax does not want y ou > to do it, but if you then close the Emergency Power switch, Gen B will al so > be re-connected to the charging system. In this condition, it would be > possible to load the generator to the point where voltage drops to a leve l > where the essential engine equipment fails. Because Rotax does not publis h > how much current the engine requires, it is difficult to determine what i s > safely available for running non-engine equipment. > > =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Jun 18, 2020
At 09:55 PM 6/17/2020, you wrote: > >Looking at the BMS13-48 spec the flat shield is tin coated copper, >0.0015" +-.0004 thk and 0.020" wide. I counted 16 strands in the >braid I disassembled. > >So 0.02"x.0011"x16 is 0.000352 sqin area, which is between 13-14ga >(13.6, apparently). So that's what, 20ish Amps conservatively? > >So the 5x 24ga conductors, slightly de-rated to 10A, seems the >shield would be more than up to it. Not sure about your numbers. 14AWG solid wire is .065" diam. 3.14 x (.065/2)^2 = 0.0033 sq" so I think your shield cross section compared to 14 AWG is off by a factor of 10? 24AWG is .02" diameter for a cross section of 3.14 x (.02/2)^2 = 0.000314 sq" x 5 strands is a total of 0.00157 sq". Working backwards I get a diameter of 0.0447 which is pretty close to 17AWG wire for equivalent resistance of the bundled strands. I get 0.00048 sq" total cross section for the shield which works back to a 0.0247" diameter wire - just a tad smaller than 22AWG. Keep in mind also that when the shield is a power path for currents in central conductors, temperature rise is promoted by BOTH current pathways under a single jacket. I've used shields as return paths for countless, low power or signal pathways but I'd have to think long and carefully about pushing that combination of conductor/insulation to its thermal limits. What application are you considering where you find an advantage in using the shield for this wire as a power-path? Bob . . . ________________________________________________________________________________
Date: Jun 18, 2020
Yeah I got my zeros mixed up there. The shield is equivalent to a single 24ga wire, so that kills the idea. Thanks. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=496913#496913 ________________________________________________________________________________
Subject: Altitude encoder output voltages
Date: Jun 18, 2020
I want to make a serial to graycode converter to replace the AK350 for input to Garmin GTX 320A transponder. I'd rather have the altitude come from the Dynon D-10A than the AK350 -- no discrepancy between what ATC sees and what I see on the Dynon (at 29.92 alt setting). I found the table on http://www.aeroelectric.com/articles/Altitude_Encoding/modecascii.txt I intend to use an Arduino Nano or similar. But my memory is real vague on the polarity and voltage levels. Is it correct that the encoder has open-collector outputs and the transponder pull-up resistors to system voltage? Does the transponder expect inverted inputs (0 in table no input and 1 in table pulling input to ground)? Finn ________________________________________________________________________________
Date: Jun 19, 2020
Subject: Re: Altitude encoder output voltages
At 08:21 PM 6/18/2020, you wrote: > >I want to make a serial to graycode converter to replace the AK350 >for input to Garmin GTX 320A transponder. > >I'd rather have the altitude come from the Dynon D-10A than the >AK350 -- no discrepancy between what ATC sees and what I see on the >Dynon (at 29.92 alt setting). > >I found the table on >http://www.aeroelectric.com/articles/Altitude_Encoding/modecascii.txt > >I intend to use an Arduino Nano or similar. > >But my memory is real vague on the polarity and voltage levels. > >Is it correct that the encoder has open-collector outputs and the >transponder pull-up resistors to system voltage? > >Does the transponder expect inverted inputs (0 in table no input and >1 in table pulling input to ground)? > >Finn Man! That goes back to the dark ages . . . I did some bench test sets for Cessna/ARC radios waayyy back when wherein I think outputs from the encoder were basically open collector with pull-ups in the load. Hence, the "1" voltage was what ever the load circuitry provided. You can't go wrong with open collectors. Lay out your board to allow adding pull-ups to a 5v rail should they prove necessary/useful. If I'm all wet and the polarities are reversed a simple bit-flip statement will fix it. Bob . . . ________________________________________________________________________________
Date: Jun 19, 2020
At 04:23 PM 6/16/2020, you wrote: >It was on the bench, heated shop. I should have contacted EarthX but >I just blamed myself. >I am sure of the time frame because I had load tested it and made >notations, and stored those notes with the battery. > >Ken Do you still have the carcass? Bob . . . ________________________________________________________________________________
Date: Jun 19, 2020
Subject: What's all this 'maintainer' stuff anyhow?
The Battery Tender Jr. (BTJr) saga continued . . . I let the BTJr recharged battery set for 24+ hours and this morning I read 12.74 volts open circuit. Recall that our BTJr charger-maintainer 'relaxed' to a maintenance level of 13.3V. Okay, I put the battery on a bench supply set for 13.3 volts. The test article battery immediately presented a 'load' of 25mA. Now, if this value represents the battery's internal leakage, then one might predict that the battery would self-discharge to less than useless in 12000mAh/25mA = 480H or thereabouts ~ 20 days. This particular battery is a Orscheln Farm & Home lawn tractor battery. I think it retails for about $35 and this particular subject is 3+ years old but kept on the same maintainer that were using to do the BTJr recharge studies. I'll leave it on the bench for awhile to see if the 'maintenance' current changes. The next step is to cap check the battery again to see how well the BTJr stuffed the energy back in. Watch this space . . . Bob . . . ________________________________________________________________________________
Date: Jun 19, 2020
How much does an Arduino cost. For about $70 Dynon sells a serial to greycode converter. On Fri, Jun 19, 2020, 07:38 Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 08:21 PM 6/18/2020, you wrote: > > finn.lassen(at)verizon.net> > > I want to make a serial to graycode converter to replace the AK350 for > input to Garmin GTX 320A transponder. > > I'd rather have the altitude come from the Dynon D-10A than the AK350 -- > no discrepancy between what ATC sees and what I see on the Dynon (at 29.92 > alt setting). > > I found the table on > http://www.aeroelectric.com/articles/Altitude_Encoding/modecascii.txt > > I intend to use an Arduino Nano or similar. > > But my memory is real vague on the polarity and voltage levels. > > Is it correct that the encoder has open-collector outputs and the > transponder pull-up resistors to system voltage? > > Does the transponder expect inverted inputs (0 in table no input and 1 in > table pulling input to ground)? > > Finn > > > Man! That goes back to the dark ages . . . I did some > bench test sets for Cessna/ARC radios waayyy back when > wherein I think outputs from the encoder were > basically open collector with pull-ups in the load. > Hence, the "1" voltage was what ever the load > circuitry provided. > > You can't go wrong with open collectors. Lay out > your board to allow adding pull-ups to a 5v rail > should they prove necessary/useful. If I'm all > wet and the polarities are reversed a simple > bit-flip statement will fix it. > > > Bob . . . > ________________________________________________________________________________
Date: Jun 19, 2020
No, sorry Bob. I used to ride motorcycles and it was not unusual that I would trash a battery letting it sit over the winter. So my mindset was that it must have been my fault (again) so I just got rid of it and bought a new one, vowing to keep it on the maintainer. On Fri, Jun 19, 2020 at 6:40 AM Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 04:23 PM 6/16/2020, you wrote: > > It was on the bench, heated shop. I should have contacted EarthX but I > just blamed myself. > I am sure of the time frame because I had load tested it and made > notations, and stored those notes with the battery. > > Ken > > > Do you still have the carcass? > > Bob . . . > ________________________________________________________________________________
Date: Jun 19, 2020
This was a number of years ago, before the model with the dual bms and warning light lead. I don't remember whether or not that model's bms was supposed to protect it from over discharge. On Fri, Jun 19, 2020 at 7:13 AM Ken Ryan wrote: > No, sorry Bob. I used to ride motorcycles and it was not unusual that I > would trash a battery letting it sit over the winter. So my mindset was > that it must have been my fault (again) so I just got rid of it and bought > a new one, vowing to keep it on the maintainer. > > > On Fri, Jun 19, 2020 at 6:40 AM Robert L. Nuckolls, III < > nuckolls.bob(at)aeroelectric.com> wrote: > >> At 04:23 PM 6/16/2020, you wrote: >> >> It was on the bench, heated shop. I should have contacted EarthX but I >> just blamed myself. >> I am sure of the time frame because I had load tested it and made >> notations, and stored those notes with the battery. >> >> Ken >> >> >> Do you still have the carcass? >> >> Bob . . . >> > ________________________________________________________________________________
Date: Jun 19, 2020
At 10:16 AM 6/19/2020, you wrote: >This was a number of years ago, before the model >with the dual bms and warning light lead. I >don't remember whether or not that model's bms >was supposed to protect it from over discharge.=C2 I believe their bms always protected from over discharge but it could not protect against self discharge. For example, a battery that has been 'protected' due to very low state of charge still needs to be recharged asap. Just because it has protected itself from external discharge, it cannot stand of effects of internal discharge. This MIGHT be what happened to yours. Bob . . . ________________________________________________________________________________
Date: Jun 19, 2020
Half of the emails from the Matronics list server ends up AOL spam filter. Several don't make it at all. Got this using the list browser: "How much does an Arduino cost. For about $70 Dynon sells a serial to greycode converter." I ordered three Nanos for $6. May take some weeks to get them. I have 74LS05 hex drivers and PC boards laying around. Then there's the fun of DYI. Then there's the fact that I can program it to accept any of the inputs from the D-10A. Not really needed, but there's plenty of space in a Nano for a table up to 67,000' or higher. Here's another question. There are several serial altitude formats: Format 1 Used By Dynon Encoder Serial-to-Parallel Converter, Garmin AT (formerly UPS Aviation Technologies) Baud rate 1200 Format #AL, space, +/-sign, five altitude bytes, T+25, checksum, carriage return Example message #AL +05200T+25D7[CR] Format 2 Used By Magellan Baud rate 1200 Format $MGL, +/- sign, five altitude digits, T+25, checksum, carriage return Example message $MGL+05200T+25E3[CR] Format 3 Used By Northstar, Garmin Baud rate 2400 Format ALT, space, five altitude bytes, carriage return Example message ALT 05200[CR] Format 4 Used By Garmin GTX330 (set on Icarus input), Garmin GTX327 (set on Icarus input), Garmin GTX328, Icarus, Trimble Baud rate 9600 Format ALT, space, five altitude bytes, carriage return Example message ALT 05200[CR] Format 3 and 4 apparently do not have an altitude +/- sign. So, what happens when you're below 0' pressure altitude? Do they reason that if you're flying that low there's no radar coverage anyway? Finn ---------------------------------------------------------------------- I want to make a serial to graycode converter to replace the AK350 for input to Garmin GTX 320A transponder. I'd rather have the altitude come from the Dynon D-10A than the AK350 -- no discrepancy between what ATC sees and what I see on the Dynon (at 29.92 alt setting). I found the table on http://www.aeroelectric.com/articles/Altitude_Encoding/modecascii.txt I intend to use an Arduino Nano or similar. But my memory is real vague on the polarity and voltage levels. Is it correct that the encoder has open-collector outputs and the transponder pull-up resistors to system voltage? Does the transponder expect inverted inputs (0 in table no input and 1 in table pulling input to ground)? Finn ________________________________________________________________________________
Date: Jun 19, 2020
Thanks Bob. Now that you have pointed it out, it seems obvious that the BMS could never protect from self-discharge! Ken On Fri, Jun 19, 2020 at 7:50 AM Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 10:16 AM 6/19/2020, you wrote: > > This was a number of years ago, before the model with the dual bms and > warning light lead. I don't remember whether or not that model's bms was > supposed to protect it from over discharge.=C3=82 > > > I believe their bms always protected from over discharge > but it could not protect against self discharge. For example, > a battery that has been 'protected' due to very low state > of charge still needs to be recharged asap. Just because > it has protected itself from external discharge, it cannot > stand of effects of internal discharge. This MIGHT be what > happened to yours. > > > Bob . . . > ________________________________________________________________________________
Date: Jun 19, 2020
At 02:19 PM 6/19/2020, you wrote: >Thanks Bob. Now that you have pointed it out, it seems obvious that >the BMS could never protect from self-discharge! > >Ken How long had the battery been in satisfactory service before it when t.u.? Bob . . . ________________________________________________________________________________
Date: Jun 19, 2020
It was never in service. It was for an unfinished project. It was about two or three years old, I think. It had been charged periodically during the first couple of years using EarthX recommended charger. Then at about 2 or 3 years old I finally developed a load test system and so I did a load test. I no longer have that record, but it tested as expected. Then I charged it back up and it sat for a year. That's when it was dead. I suppose it is possible that I did not charge it after the load test. But at the price of those things and having previous experience failing motorcycle batteries, that seems unlikely. On Fri, Jun 19, 2020 at 12:14 PM Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 02:19 PM 6/19/2020, you wrote: > > Thanks Bob. Now that you have pointed it out, it seems obvious that the > BMS could never protect from self-discharge! > > Ken > > > How long had the battery been in > satisfactory service before it when > t.u.? > > > Bob . . . > ________________________________________________________________________________
Date: Jun 19, 2020
At 03:26 PM 6/19/2020, you wrote: >It was never in service. It was for an >unfinished project. It was about two or three >years old, I think. It had been charged >periodically during the first couple of=C2 years >using EarthX recommended charger. Then at about >2 or 3 years old I finally developed a load test >system and so I did a load test. I no longer >have that record, but it tested as expected. >Then I charged it back up and it sat for a year. >That's when it was dead. I suppose it is >possible that I did not charge it after the load >test. But at the price of those things and >having previous experience failing motorcycle batteries, that seems unlikely. bummer . . . for years at my seminars I suggested that builders don't buy a battery until a few weeks before first flight. 'til then you can test with some jury-rigged car battery. I think I made that suggestion the first time when an attendee stated that he was going to 'cruise the booths at OSH next month to see if he could snag a good deal on a battery.' He asked for recommendations. He admitted being years away from flying. That was before lithium . . . also very early in evolution of AGM products. I suggested he would be money and risk ahead with a 'fresh' battery in his newly minted airplane. I think that advice still holds water. Bob . . . ________________________________________________________________________________
Date: Jun 19, 2020
Subject: Minimum length of fusible link wire segment
Bob, in a recent post you state that there is a 9-inch rule of thumb minimum length for fusible link wire segments. Could you explain the physics behind that, please? Pat ________________________________________________________________________________
Date: Jun 20, 2020
The Battery Tender Jr. (BTJr) saga continued . . . > Recall that our BTJr charger-maintainer 'relaxed' > 'load' of 25mA. > Now, if this value represents the battery's > internal leakage, then one might predict > that the battery would self-discharge to > less than useless in 12000mAh/25mA = 480H > or thereabouts ~ 20 days. After 24+ hours, the maintenance current is down to 19mA . . . which raises another question . . . what is the long term behavior of maintenance current for this battery? I'll explore that later. Now for the second cap-check. Watch this space . . . Bob . . . ________________________________________________________________________________
Date: Jun 20, 2020
You do know there is a specific process to =9Cre-activate=9D an EarthX battery once the discharge protection is activated, right? Was that tried? It won=99t accept a charge until that is completed. -James From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ken Ryan Sent: Friday, June 19, 2020 3:27 PM Subject: Re: AeroElectric-List: Re: Premature EarthX death? It was never in service. It was for an unfinished project. It was about two or three years old, I think. It had been charged periodically during the first couple of years using EarthX recommended charger. Then at about 2 or 3 years old I finally developed a load test system and so I did a load test. I no longer have that record, but it tested as expected. Then I charged it back up and it sat for a year. That's when it was dead. I suppose it is possible that I did not charge it after the load test. But at the price of those things and having previous experience failing motorcycle batteries, that seems unlikely. On Fri, Jun 19, 2020 at 12:14 PM Robert L. Nuckolls, III wrote: At 02:19 PM 6/19/2020, you wrote: Thanks Bob. Now that you have pointed it out, it seems obvious that the BMS could never protect from self-discharge! Ken How long had the battery been in satisfactory service before it when t.u.? Bob . . . ________________________________________________________________________________
Date: Jun 20, 2020
I believe the charger which I bought from EarthX has that capability. What exactly is this procedure? On Sat, Jun 20, 2020, 08:19 wrote: > You do know there is a specific process to =9Cre-activate=9D an EarthX battery > once the discharge protection is activated, right? Was that tried? It > won=99t accept a charge until that is completed. > > -James > > > *From:* owner-aeroelectric-list-server(at)matronics.com [mailto: > owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of *Ken Ryan > *Sent:* Friday, June 19, 2020 3:27 PM > *To:* aeroelectric-list(at)matronics.com > *Subject:* Re: AeroElectric-List: Re: Premature EarthX death? > > > It was never in service. It was for an unfinished project. It was about > two or three years old, I think. It had been charged periodically during > the first couple of years using EarthX recommended charger. Then at about 2 > or 3 years old I finally developed a load test system and so I did a load > test. I no longer have that record, but it tested as expected. Then I > charged it back up and it sat for a year. That's when it was dead. I > suppose it is possible that I did not charge it after the load test. But at > the price of those things and having previous experience failing motorcyc le > batteries, that seems unlikely. > > > On Fri, Jun 19, 2020 at 12:14 PM Robert L. Nuckolls, III < > nuckolls.bob(at)aeroelectric.com> wrote: > > At 02:19 PM 6/19/2020, you wrote: > > Thanks Bob. Now that you have pointed it out, it seems obvious that the > BMS could never protect from self-discharge! > > Ken > > > How long had the battery been in > satisfactory service before it when > t.u.? > > Bob . . . > > ________________________________________________________________________________
Date: Jun 20, 2020
Here is a FAQ from EarthX that includes discussion of re-charging an over-discharged battery. I have the Optimate charger and I tried it several times. https://earthxbatteries.com/faqs On Sat, Jun 20, 2020 at 8:22 AM Ken Ryan wrote: > I believe the charger which I bought from EarthX has that capability. Wha t > exactly is this procedure? > > On Sat, Jun 20, 2020, 08:19 wrote: > >> You do know there is a specific process to =9Cre-activate=9D an EarthX >> battery once the discharge protection is activated, right? Was that >> tried? It won=99t accept a charge until that is completed. >> >> -James >> >> >> >> >> >> *From:* owner-aeroelectric-list-server(at)matronics.com [mailto: >> owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of *Ken Ryan >> *Sent:* Friday, June 19, 2020 3:27 PM >> *To:* aeroelectric-list(at)matronics.com >> *Subject:* Re: AeroElectric-List: Re: Premature EarthX death? >> >> >> >> It was never in service. It was for an unfinished project. It was about >> two or three years old, I think. It had been charged periodically during >> the first couple of years using EarthX recommended charger. Then at abou t 2 >> or 3 years old I finally developed a load test system and so I did a loa d >> test. I no longer have that record, but it tested as expected. Then I >> charged it back up and it sat for a year. That's when it was dead. I >> suppose it is possible that I did not charge it after the load test. But at >> the price of those things and having previous experience failing motorcy cle >> batteries, that seems unlikely. >> >> >> >> On Fri, Jun 19, 2020 at 12:14 PM Robert L. Nuckolls, III < >> nuckolls.bob(at)aeroelectric.com> wrote: >> >> At 02:19 PM 6/19/2020, you wrote: >> >> Thanks Bob. Now that you have pointed it out, it seems obvious that the >> BMS could never protect from self-discharge! >> >> Ken >> >> >> How long had the battery been in >> satisfactory service before it when >> t.u.? >> >> Bob . . . >> >> ________________________________________________________________________________
From: "skywagon185guy ." <skywagon185(at)gmail.com>
Date: Jun 20, 2020
Here is a guess at the charging, or lack of, problem... from a guy that has never used the Xearth battery. Most Li based chargers, controllers, BMS, etc. have top and bottom voltage state sensors. Translating this.... if the battery voltage for any reason has fallen below the minimum value, the charge controller will essentially block any attempt to charge the battery as it believes the battery is unsafe to charge. The typical method to overcome this charging blockage is to trick the controller or bypass it for a very brief period of time. And, using a conventional charger attached to the battery in such a way, usually the battery posts, as to put a brief charge into the battery. Enough of a charge to get the cells voltage to rise above a minimum level. Once that is done, usually connecting the battery to the Li charger, it will sense that the battery is sufficiently at a safe state and begin normal charging... On Sat, Jun 20, 2020 at 9:30 AM Ken Ryan wrote: > I believe the charger which I bought from EarthX has that capability. Wha t > exactly is this procedure? > > On Sat, Jun 20, 2020, 08:19 wrote: > >> You do know there is a specific process to =9Cre-activate=9D an EarthX >> battery once the discharge protection is activated, right? Was that >> tried? It won=99t accept a charge until that is completed. >> >> -James >> >> >> >> >> >> *From:* owner-aeroelectric-list-server(at)matronics.com [mailto: >> owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of *Ken Ryan >> *Sent:* Friday, June 19, 2020 3:27 PM >> *To:* aeroelectric-list(at)matronics.com >> *Subject:* Re: AeroElectric-List: Re: Premature EarthX death? >> >> >> >> It was never in service. It was for an unfinished project. It was about >> two or three years old, I think. It had been charged periodically during >> the first couple of years using EarthX recommended charger. Then at abou t 2 >> or 3 years old I finally developed a load test system and so I did a loa d >> test. I no longer have that record, but it tested as expected. Then I >> charged it back up and it sat for a year. That's when it was dead. I >> suppose it is possible that I did not charge it after the load test. But at >> the price of those things and having previous experience failing motorcy cle >> batteries, that seems unlikely. >> >> >> >> On Fri, Jun 19, 2020 at 12:14 PM Robert L. Nuckolls, III < >> nuckolls.bob(at)aeroelectric.com> wrote: >> >> At 02:19 PM 6/19/2020, you wrote: >> >> Thanks Bob. Now that you have pointed it out, it seems obvious that the >> BMS could never protect from self-discharge! >> >> Ken >> >> >> How long had the battery been in >> satisfactory service before it when >> t.u.? >> >> Bob . . . >> >> ________________________________________________________________________________
Date: Jun 21, 2020
Subject: Re: Premature EarthX death?
i can't believe this conversation is going on and earthx hasn't been contacted. from my experience with them they really are the experts on this. no offense to anyone but THIS is their thing. On Sat, Jun 20, 2020 at 11:19 AM wrote: > You do know there is a specific process to =9Cre-activate=9D an EarthX battery > once the discharge protection is activated, right? Was that tried? It > won=99t accept a charge until that is completed. > > -James > > > *From:* owner-aeroelectric-list-server(at)matronics.com [mailto: > owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of *Ken Ryan > *Sent:* Friday, June 19, 2020 3:27 PM > *To:* aeroelectric-list(at)matronics.com > *Subject:* Re: AeroElectric-List: Re: Premature EarthX death? > > > It was never in service. It was for an unfinished project. It was about > two or three years old, I think. It had been charged periodically during > the first couple of years using EarthX recommended charger. Then at about 2 > or 3 years old I finally developed a load test system and so I did a load > test. I no longer have that record, but it tested as expected. Then I > charged it back up and it sat for a year. That's when it was dead. I > suppose it is possible that I did not charge it after the load test. But at > the price of those things and having previous experience failing motorcyc le > batteries, that seems unlikely. > > > On Fri, Jun 19, 2020 at 12:14 PM Robert L. Nuckolls, III < > nuckolls.bob(at)aeroelectric.com> wrote: > > At 02:19 PM 6/19/2020, you wrote: > > Thanks Bob. Now that you have pointed it out, it seems obvious that the > BMS could never protect from self-discharge! > > Ken > > > How long had the battery been in > satisfactory service before it when > t.u.? > > Bob . . . > > ________________________________________________________________________________
Date: Jun 21, 2020
Subject: What to do with a SB1B-14?
Hi, I'm planning to upgrade my RV-7A electrical system based on the Z101 design. I recently purchased a new BC460-H aux alternator & a generic Ford regulator. I then had the good fortune of having someone give me brand new SB1B-14 backup regulator. I currently have a Plane Power internally-regulated primary alternator installed. I'm looking for suggestions on what to do. Return the generic Ford regulator, keep the B&C regulator, and deviate from Z101? Put the SB1B-14 up for sale? Try to trade the SB1B-14 for a LR3D-14 to go with a new B&C primary alternator to replace the PP? Regards, David -- --- David Carter david(at)carter.net ________________________________________________________________________________
Date: Jun 21, 2020
The battery was discarded a couple of years ago. I see no point in contacting them now. On Sun, Jun 21, 2020, 04:58 bob noffs wrote: > i can't believe this conversation is going on and earthx hasn't been > contacted. from my experience with them they really are the experts on > this. no offense to anyone but THIS is their thing. > > On Sat, Jun 20, 2020 at 11:19 AM wrote: > >> You do know there is a specific process to =9Cre-activate=9D an EarthX >> battery once the discharge protection is activated, right? Was that >> tried? It won=99t accept a charge until that is completed. >> >> -James >> >> >> >> >> >> *From:* owner-aeroelectric-list-server(at)matronics.com [mailto: >> owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of *Ken Ryan >> *Sent:* Friday, June 19, 2020 3:27 PM >> *To:* aeroelectric-list(at)matronics.com >> *Subject:* Re: AeroElectric-List: Re: Premature EarthX death? >> >> >> >> It was never in service. It was for an unfinished project. It was about >> two or three years old, I think. It had been charged periodically during >> the first couple of years using EarthX recommended charger. Then at abou t 2 >> or 3 years old I finally developed a load test system and so I did a loa d >> test. I no longer have that record, but it tested as expected. Then I >> charged it back up and it sat for a year. That's when it was dead. I >> suppose it is possible that I did not charge it after the load test. But at >> the price of those things and having previous experience failing motorcy cle >> batteries, that seems unlikely. >> >> >> >> On Fri, Jun 19, 2020 at 12:14 PM Robert L. Nuckolls, III < >> nuckolls.bob(at)aeroelectric.com> wrote: >> >> At 02:19 PM 6/19/2020, you wrote: >> >> Thanks Bob. Now that you have pointed it out, it seems obvious that the >> BMS could never protect from self-discharge! >> >> Ken >> >> >> How long had the battery been in >> satisfactory service before it when >> t.u.? >> >> Bob . . . >> >> ________________________________________________________________________________
Date: Jun 21, 2020
Subject: Re: What to do with a SB1B-14?
At 08:56 AM 6/21/2020, you wrote: >Hi,=C2 > >I'm planning to upgrade my RV-7A electrical >system based on the Z101 design. I recently >purchased a new BC460-H aux alternator & a >generic Ford regulator. I then had the good >fortune of having someone give me brand new=C2 SB1B-14 backup regulator.=C2 > >I currently have a Plane Power >internally-regulated primary alternator installed.=C2 > >I'm looking for suggestions on what=C2 to do.=C2 > >Return the generic Ford regulator, keep the B&C >regulator, and deviate from Z101?=C2 > >Put the =C2 SB1B-14 up for sale?=C2 > >Try to trade the SB1B-14 for a LR3D-14 to go >with a new B&C primary alternator to replace the PP?=C2 >David Carter >david(at)carter.net Remember, the Z-figures are, first and foremost, illustrations of ARCHITECTURE . . . yes, there are specific component callouts . . . but there are often more than one, perhaps many alternatives that would perform as advertised without violating the spirit and intent of the architecture. I really down-scaled the price, weight and complexity of the aux alternator installation shown in Z101. That alternator has a low probability of ever being needed in distress. For the vast majority if not all of it's lifetime in the airplane, (except for pre-flight testing) it sits there doing nothing. I deleted low voltage warning and ov management because any time you have that system running, you're automatically in a state of heightened awareness. Low voltage warning is redundant. You turned it on in the first place because the main alternator rolled over. Probability of having two alternators go bad (fail to function -OR- go into ov runaway) during the consumption of one tank of fuel is nanoscopic. Hence it seemed quite reasonable to reduce the bells-n- whistles in the aux alternator system to a minimum. But that is YOUR CHOICE. If you already have hardware in hand there's not a thing wrong with going ahead and using it. You COULD install it with the same utility as the Ford regulator . . . leave off the lv warning light and alternator loaded current sensor. That SB1 current sensor was crafted to assuage worries by those-who-know-more-about-airplanes than we do in Washington. In retrospect, there were MUCH easier ways to annunciate the alternator's activation than hanging that Hall sensor on the b-lead. Further, there's no need to annunciate 'overload' by flashing the annunciator . . . the alternator is a 40A machine in an rpm-limited installation . . . overloading it simply means you get a depressed bus voltage which is easily detected on a variety of displays these days. I wouldn't agonize over the decision much. The SB1 has a rich and successful history of value and performance on a LOT of TC and OBAM aircraft. Go ahead and use it . . . trimming features is your option. But most of all folks, don't let architecture component suggestions drive expensive or impractical decisions . . . you done good David . . . we're talking about it here before you make any big moves. Bob . . . ________________________________________________________________________________
Date: Jun 21, 2020
Bob - thanks, that all makes sense to me. I assume there's also no need to swap out the internally-regulated PP main alternator? On Sun, Jun 21, 2020 at 12:24 PM Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 08:56 AM 6/21/2020, you wrote: > > Hi,=C3=82 > > I'm planning to upgrade my RV-7A electrical system based on the Z101 > design. I recently purchased a new BC460-H aux alternator & a generic For d > regulator. I then had the good fortune of having someone give me brand ne w=C3=82 > SB1B-14 backup regulator.=C3=82 > > I currently have a Plane Power internally-regulated primary alternator > installed.=C3=82 > > I'm looking for suggestions on what=C3=82 to do.=C3=82 > > Return the generic Ford regulator, keep the B&C regulator, and deviate > from Z101?=C3=82 > > Put the =C3=82 SB1B-14 up for sale?=C3=82 > > Try to trade the SB1B-14 for a LR3D-14 to go with a new B&C primary > alternator to replace the PP?=C3=82 > > > David Carter > david(at)carter.net > > > Remember, the Z-figures are, first and foremost, illustrations > of ARCHITECTURE . . . yes, there are specific component callouts > . . . but there are often more than one, perhaps many alternatives > that would perform as advertised without violating the spirit and > intent of the architecture. > > I really down-scaled the price, weight and complexity of the > aux alternator installation shown in Z101. That alternator > has a low probability of ever being needed in distress. For > the vast majority if not all of it's lifetime in the airplane, > (except for pre-flight testing) it sits there doing nothing. > > I deleted low voltage warning and ov management because > any time you have that system running, you're automatically > in a state of heightened awareness. > > Low voltage warning is redundant. You turned it on in the > first place because the main alternator rolled over. > Probability of having two alternators go bad (fail > to function -OR- go into ov runaway) during the > consumption of one tank of fuel is nanoscopic. > > Hence it seemed quite reasonable to reduce the bells-n- > whistles in the aux alternator system to a minimum. > But that is YOUR CHOICE. If you already have hardware > in hand there's not a thing wrong with going ahead and > using it. You COULD install it with the same utility > as the Ford regulator . . . leave off the lv warning > light and alternator loaded current sensor. > > That SB1 current sensor was crafted to assuage worries > by those-who-know-more-about-airplanes than we do > in Washington. > > In retrospect, there were MUCH easier ways to > annunciate the alternator's activation than hanging > that Hall sensor on the b-lead. Further, there's > no need to annunciate 'overload' by flashing the > annunciator . . . the alternator is a 40A machine > in an rpm-limited installation . . . overloading > it simply means you get a depressed bus voltage > which is easily detected on a variety of displays > these days. > > I wouldn't agonize over the decision much. The > SB1 has a rich and successful history of value > and performance on a LOT of TC and OBAM aircraft. > Go ahead and use it . . . trimming features is > your option. But most of all folks, don't let > architecture component suggestions drive expensive > or impractical decisions . . . you done good > David . . . we're talking about it here before > you make any big moves. > > > Bob . . . > -- --- David Carter david(at)carter.net ________________________________________________________________________________
Subject: Current consumption of Facet cube fuel pump
Date: Jun 21, 2020
Does anyone know the power rating (or current consumption) of a Facet 40105 fuel pump when operating at the low pressure end of its range (3 psi)? Thanks, Peter ________________________________________________________________________________
Subject: Re: Current consumption of Facet cube fuel pump
Date: Jun 21, 2020
Peter, Can't speak for the "low pressure end of its range" but I measured mine drawing 1.4A at 14V in a Long-EZ. Fed with 20 AWG wire and protected by a 5A fuse. -- Joe Independence, OR Peter Pengilly wrote on 6/21/2020 14:46: > Does anyone know the power rating (or current consumption) of a Facet 40105 > fuel pump when operating at the low pressure end of its range (3 psi)? > > > > Thanks, Peter > > ________________________________________________________________________________
Date: Jun 22, 2020
Subject: Re: What's all this 'maintainer' stuff anyhow?
At 10:40 AM 6/20/2020, you wrote: >The Battery Tender Jr. (BTJr) saga continued . . . I finished plotting and annotating some Battery Tender Jr. performance compared to a laboratory-grade charging profile with a bench power supply. I hope the plots are self explanatory: https://tinyurl.com/ybzv8t8n It's interesting that in spite of the fact that the BTJr wall-wart does not feature an oft recommended 'top-off' feature, the energy pumped into our test article battery was not substantially different than application of the 'lab-grade' recharging profile. I've got a couple BTJr C-Ms shepherding 100AH truck batteries out in the shop. They've been on maintenance for over a year. Just for grins, I'll go measure the maintenance current on them tomorrow. Bob . . . ________________________________________________________________________________
From: Christopher Cee Stone <rv8iator(at)gmail.com>
Date: Jun 22, 2020
The Battery Tender Jr. (BTJr) saga continued . . . Thanks Bob! Very illuminating info for the BTjr. Have you run same for Schumacher SC 13xx maintainers? ...chris stone On Mon, Jun 22, 2020 at 4:38 AM Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 10:40 AM 6/20/2020, you wrote: > > The Battery Tender Jr. (BTJr) saga continued . . . > > > I finished plotting and annotating some > Battery Tender Jr. performance compared > to a laboratory-grade charging profile > with a bench power supply. > > I hope the plots are self explanatory: > > https://tinyurl.com/ybzv8t8n > > It's interesting that in spite of the fact > that the BTJr wall-wart does not feature > an oft recommended 'top-off' feature, the > energy pumped into our test article battery > was not substantially different than application > of the 'lab-grade' recharging profile. > > I've got a couple BTJr C-Ms shepherding > 100AH truck batteries out in the shop. They've > been on maintenance for over a year. Just > for grins, I'll go measure the maintenance > current on them tomorrow. > > Bob . . . > ________________________________________________________________________________
Date: Jun 22, 2020
At 08:52 AM 6/22/2020, you wrote: >>The Battery Tender Jr. (BTJr) saga continued . . . >> >>Thanks Bob Very illuminating info for the BTjr >>Have you run same for Schumacher SC 13xx maintainers? Not that particular series . . . here's a family of plots I took on a variety of C-M products a few years ago . . . https://tinyurl.com/m3o6mtu Bob . . . ________________________________________________________________________________
Date: Jun 24, 2020
From the product description: Facet fuel pumps have low power requirements (about 1 amp at 12 volts) gaero.com> wrote: Does anyone know the power rating (or current consumption) of a Facet 40105 fuel pump when operating at the low pressure end of its range (3 psi)? =C2- Thanks, Peter ________________________________________________________________________________
Date: Jun 24, 2020
At 09:00 AM 6/24/2020, you wrote: > From the product description: >Facet fuel pumps have low power requirements (about 1 amp at 12 volts) > wrote: >Does anyone know the power rating (or current consumption) of a >Facet 40105 fuel pump when operating at the low pressure end of its >range (3 psi)? >Thanks, Peter The reciprocating electric fuel pump has a rich and what is now perhaps ancient history. Early patents on this technology date back as far as 1920. Here's a small sample of patents awarded on this concept over the past 100 years! https://tinyurl.com/knsz7y9 The fundamental idea was to have a linear solenoid compress a spring that pushed a piston toward the pump's outlet port. A pair of check valves would (1) allow the piston to 'suck' fuel on the magnetic stroke while compressing the spring and (2) allowing spring force on the piston to 'push' fuel through the outlet port. There's an illustrated narrative of this process attached. Earliest versions featured electrical contacts in series with the solenoid coil that would close when the spring was at or near full extension. This was a source of wear and radio noise. Later improvements added a transistor to reduce current in the contacts to milliamps offering very long contact life and virtually zero electrical noise. Still later improvements replace the contacts with a solid state timer that simply pulses the coil so many times a minute. If there is no 'demand', i.e. carb float bowel closed, the piston and spring assumes fully compressed condition until flow resumes. Outlet pressure is set by spring force. Therefore, energy required to supply this pump is constant irrespective of pressure or flow. "Average" current flow may be on the order of 2A but peak current will be higher. Given that fuses can be 'hammered' by repetitive pulses at or near the fuse rating, one should power these pumps from a 5A fuse or breaker through 22 or 20AWG wire. I've got one of these thing laying around here somewhere . . . I'll see if I can set it up to capture current traces to explore the energy signature for average, peak and RMS values of current. Bob . . . ________________________________________________________________________________
Date: Jun 24, 2020
I had them once measured on a 12V battery with 0.9A continouse and peak 1.2A Cheers On 24.06.2020 16:00, Ernest Christley wrote: > From the product description: > > Facet fuel pumps have low power requirements (about 1 amp at 12 volts) > > wrote: > > > Does anyone know the power rating (or current consumption) of a Facet > 40105 fuel pump when operating at the low pressure end of its range (3 > psi)? > > Thanks, Peter > ________________________________________________________________________________
Date: Jun 24, 2020
Thanks All, I looked all over the interweb for quite a while and couldn't find the answer! Peter From: owner-aeroelectric-list-server(at)matronics.com On Behalf Of Robert L. Nuckolls, III Sent: 24 June 2020 19:23 Subject: Re: AeroElectric-List: Current consumption of Facet cube fuel pump At 09:00 AM 6/24/2020, you wrote: >From the product description: Facet fuel pumps have low power requirements (about 1 amp at 12 volts) > wrote: Does anyone know the power rating (or current consumption) of a Facet 40105 fuel pump when operating at the low pressure end of its range (3 psi)? Thanks, Peter The reciprocating electric fuel pump has a rich and what is now perhaps ancient history. Early patents on this technology date back as far as 1920. Here's a small sample of patents awarded on this concept over the past 100 years! https://tinyurl.com/knsz7y9 The fundamental idea was to have a linear solenoid compress a spring that pushed a piston toward the pump's outlet port. A pair of check valves would (1) allow the piston to 'suck' fuel on the magnetic stroke while compressing the spring and (2) allowing spring force on the piston to 'push' fuel through the outlet port. There's an illustrated narrative of this process attached. Earliest versions featured electrical contacts in series with the solenoid coil that would close when the spring was at or near full extension. This was a source of wear and radio noise. Later improvements added a transistor to reduce current in the contacts to milliamps offering very long contact life and virtually zero electrical noise. Still later improvements replace the contacts with a solid state timer that simply pulses the coil so many times a minute. If there is no 'demand', i.e. carb float bowel closed, the piston and spring assumes fully compressed condition until flow resumes. Outlet pressure is set by spring force. Therefore, energy required to supply this pump is constant irrespective of pressure or flow. "Average" current flow may be on the order of 2A but peak current will be higher. Given that fuses can be 'hammered' by repetitive pulses at or near the fuse rating, one should power these pumps from a 5A fuse or breaker through 22 or 20AWG wire. I've got one of these thing laying around here somewhere . . . I'll see if I can set it up to capture current traces to explore the energy signature for average, peak and RMS values of current. Bob . . . ________________________________________________________________________________
Subject: WireViz
Date: Jun 24, 2020
I've become aware of a wiring documentation tool named WireViz. I think this might be a recent release as I find no mention of it in searches here or on VAF. An overview description can be found on this GitHub page: https://github.com/formatc1702/WireViz I'm slogging through the wiring of my RV7A project and at first blush this looks like a potentially efficient mechanism to document what I've done. I'm interested in hearing about any user experiences from folks here, or comments regarding gotcha's I should consider before embarking on a new learning curve. Thank you in advance. David Read this topic online here: http://forums.matronics.com/viewtopic.php?p=497028#497028 ________________________________________________________________________________
Date: Jun 25, 2020
Subject: Re: WireViz
That's fantastic! I wish that I had had that tool when I was designing the wiring for my BD-4C. I used LibreOffice Draw to make my wiring diagrams. It worked but was pretty time-consuming. Had WireViz been available, After a quick glance, WireViz seems better, since it automatically handles the tedious layout details. -- Art Z. On Wed, Jun 24, 2020 at 11:41 PM David Lewis wrote: > Davidlewisstart(at)gmail.com> > > I've become aware of a wiring documentation tool named WireViz. I think > this might be a recent release as I find no mention of it in searches here > or on VAF. An overview description can be found on this GitHub page: > https://github.com/formatc1702/WireViz > > I'm slogging through the wiring of my RV7A project and at first blush this > looks like a potentially efficient mechanism to document what I've done. > I'm interested in hearing about any user experiences from folks here, or > comments regarding gotcha's I should consider before embarking on a new > learning curve. -- https://CheerfulCurmudgeon.com/ *If I am not for myself, who will be for me? If I am only for myself, what am I? If not now, when?* ________________________________________________________________________________
Subject: RV10 Single Batt + Dual Alternator
Date: Jun 26, 2020
I think I am somehow close to the Z101. As the batt in the RV10 is located in the tailcone -with the ALT-2 connected to the ESS bus I tried to avoid the long always hot wire between the BATT and ALT-2 B lead. ESS BUS switch with ALT-2 is normally ON during normal flight. ALT-2 is set at lower voltage vs. ALT-1 I know I'll get crucified for the 2 AVIONICS BUSES..I plane to move the autopilot and its servos from the AVIONX ESS bus to the ESS BUS to avoid inductive loads on the AVIONX ESS bus. The 50amp CB between the MAIN BUS and ESS BUS is there to protect the diode and possibly isolate the MAIN BUS if ESS BUS develops a hard fault. Do you see any other potential NO GO issues with this setup or is it acceptable? -------- Igor RV10 in progress Read this topic online here: http://forums.matronics.com/viewtopic.php?p=497053#497053 Attachments: http://forums.matronics.com//files/diagram_om_ela_igor_v_034_536.jpg ________________________________________________________________________________
Date: Jun 26, 2020
Hi Bob, Thanks for the plot information...Maintainers and their profiles. Your details brought up a question. Would you have a suggestion for a simple setup for measuring internal cell/battery resistance, IR, of lithium based cells. Modelers use a lot of Lipo based batteries. And there is a strong need to keep track of their condition and it seems like tracking IR could be the best option. A practical way to run the tests is sorely needed. Your suggestions are always appreciated. D On Mon, Jun 22, 2020 at 4:38 AM Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 10:40 AM 6/20/2020, you wrote: > > The Battery Tender Jr. (BTJr) saga continued . . . > > > I finished plotting and annotating some > Battery Tender Jr. performance compared > to a laboratory-grade charging profile > with a bench power supply. > > I hope the plots are self explanatory: > > https://tinyurl.com/ybzv8t8n > > It's interesting that in spite of the fact > that the BTJr wall-wart does not feature > an oft recommended 'top-off' feature, the > energy pumped into our test article battery > was not substantially different than application > of the 'lab-grade' recharging profile. > > I've got a couple BTJr C-Ms shepherding > 100AH truck batteries out in the shop. They've > been on maintenance for over a year. Just > for grins, I'll go measure the maintenance > current on them tomorrow. > > Bob . . . > ________________________________________________________________________________
Subject: Re: RV10 Single Batt + Dual Alternator
Date: Jun 26, 2020
The schematic diagram is overly complicated. The utility bus can be eliminated and those loads can be powered directly from the Main power bus. Both avionics buses can be eliminated and those loads can be powered directly from the Essential bus. The two alternators will be connected in parallel whenever both contactors are energized. Is one of the alternators set at a lower output voltage than the other one? The two relays are unnecessary failure points. Eventually some other pilot will fly your plane. Will that pilot know what to do when some component fails? -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=497055#497055 ________________________________________________________________________________
Date: Jun 27, 2020
I would rethink what you are trying to accomplish. With all the monkey motion going on, it would seem you would be better served going with a Z-14 rather than a gummed up Z-101. Why an avionic bus at all let alone two? I would kill them both and their relays. A utility bus seems way over the top. If you wish to control a utility device just have a power switch for that device co-located with it. I would kill the utility bus If the motivation for the avionics buses is to avoid brown out of all the avionic devices not on the GAD 27, a Z-14 system will solve that for you. Most of the Garmin devices have a second power input you can connect to a second bus. You can use a bridge rectifier to enable dual power feeds to any device that only has one power input. When I wired my RV14 I first drew up something similar to the ideas behind Z-101. If the current Z-101 had been around I may have been more confident in using that kind of layout. I went with a Z-14 layout instead. When I get in my plane, I turn on batt 2 and all the avionics come up and stay up. I turn on batt 1 as part of my startup checklist and during engine start, no brown outs to the avionics occur. This is the only reason I didn't go with my sorta Z-101 back then. I can think of no other reason to choose between a straight Z-101 or a Z-14. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=497058#497058 ________________________________________________________________________________
Date: Jun 27, 2020
Version 35 -UTIL BUS eliminated / rebranded to MAIN BUS fuse block (non essential stuff) -AutoPilot head unit + servos moved to ESS BUS https://i.ibb.co/VwNhKK5/Diagram-OM-ELA-Igor-v-035.jpg -------- Igor RV10 in progress Read this topic online here: http://forums.matronics.com/viewtopic.php?p=497060#497060 Attachments: http://forums.matronics.com//files/diagram_om_ela_igor_v035_322.jpg ________________________________________________________________________________
Date: Jun 27, 2020
Subject: Re: Measuring battery internal resistance
At 07:27 PM 6/26/2020, you wrote: >Hi Bob, >Thanks for the plot information...Maintainers and their profiles. >Your details brought up a question. >Would you have a suggestion for a simple setup >for measuring internal cell/battery resistance, IR, of lithium based cells. >Modelers use a lot of Lipo based >batteries.=C2 And there is a strong need to keep >track of their condition and it seems like >tracking IR could be the best option. A >practical way to run the tests is sorely needed. >Your suggestions are always appreciated. Hmmmm . . . internal resistance can be measured 'instantly' as opposed to doing a total-discharge cap-check. The results of a 'severe load' test considers a combination of chemical potential (capacity) -AND- internal resistance (ohmic losses). An internal resistance test can be conducted at lower energy levels than the load-test. Of course, all three tests require some instrumentation and process. The hammer-n-tongs way to measure cell impedance is to load with some handy value resistor, measure the voltage then increase the load by say, double or tripling it and read the voltage again. Example: Suppose your battery under test puts out 12.35 volts with a 10 ohm load. Your base current is 12.35/10 = 1.235 amps Temporarily add a second load resistor . . . any practical value, let's say another 10 ohms. Let's assume the new reading is 12.220 volts. Okay, total R across the battery is now 5 ohms. 12.22/5 = 2.444 amps. So, for a delta current of 2.444A we read a delta-volts of 0.015V .015/2.444 = 6 milliohms One could craft a test box containing the necessary resistors, push-button and meter connections to simplify the setup but you'd still have to get out the calculator and do the math. I designed a direct reading battery resistance meter about 20 years ago. It featured a constant current load system that was switched with a multi-vibrator at about 10 cycles per second. It toggled between 1 and 11 amps. A pk-to-pk reading voltmeter would show the ripple voltage created at the battery terminals as the electronic load oscillated between the two current values. Internal resistance was nearly direct reading where 10 mv pk-pk equated to 1 milliohm of resistance. I've probably got those drawings around here somewhere. In my recent studies of on the garden tractor battery . . . http://www.aeroelectric.com/Pictures/Battery_Tender_Jr_Performance/03_BTJr+C CCY_Energy.jpg I was able to command the CBA IV battery analyzer to deviate between two accurately known load values while accurately reporting the battery voltage. That delta-E/Delta-A deduced a rather high internal resistance of about 60 milliohms. So there's three ways to go about it ranging from the hammer-n-tongs to poke-n-read. Bob . . . ________________________________________________________________________________
Date: Jun 27, 2020
Oops. For your example, the delta current is actually 2.444-1.235=1.209A. So the R=0.015/1.209=12.4 milliohms. You forgot to subtract the first reading. Other than the simple math error (something I do all the time...) the rest of the explanation is spot on. Dick Tasker Robert L. Nuckolls, III wrote: > At 07:27 PM 6/26/2020, you wrote: >> Hi Bob, >> Thanks for the plot information...Maintainers and their profiles. >> Your details brought up a question. >> Would you have a suggestion for a simple setup for measuring internal cell/battery resistance, IR, of lithium based cells. >> Modelers use a lot of Lipo based batteries. And there is a strong need to keep track of their condition and it seems like tracking IR could be the best option. A practical way to run the tests is >> sorely needed. >> Your suggestions are always appreciated. > > Hmmmm . . . internal resistance can be > measured 'instantly' as opposed to doing > a total-discharge cap-check. The results > of a 'severe load' test considers > a combination of chemical potential > (capacity) -AND- internal resistance > (ohmic losses). An internal resistance > test can be conducted at lower energy > levels than the load-test. Of course, > all three tests require some instrumentation > and process. > > The hammer-n-tongs way to measure cell > impedance is to load with some handy value > resistor, measure the voltage then increase > the load by say, double or tripling it > and read the voltage again. > > Example: Suppose your battery under test > puts out 12.35 volts with a 10 ohm load. > Your base current is 12.35/10 = 1.235 amps > > Temporarily add a second load resistor . . . > any practical value, let's say another > 10 ohms. Let's assume the new reading is > 12.220 volts. Okay, total R across the > battery is now 5 ohms. 12.22/5 = 2.444 > amps. > > So, for a delta current of 2.444A > we read a delta-volts of 0.015V > > .015/2.444 = 6 milliohms > > One could craft a test box containing > the necessary resistors, push-button > and meter connections to simplify the > setup but you'd still have to get out > the calculator and do the math. > > I designed a direct reading battery > resistance meter about 20 years ago. > It featured a constant current load > system that was switched with a > multi-vibrator at about 10 cycles > per second. > > It toggled between 1 and 11 amps. > A pk-to-pk reading voltmeter would show > the ripple voltage created at the battery > terminals as the electronic load oscillated > between the two current values. > > Internal resistance was nearly direct > reading where 10 mv pk-pk equated to > 1 milliohm of resistance. I've probably > got those drawings around here somewhere. > > In my recent studies of on the garden > tractor battery . . . > > http://www.aeroelectric.com/Pictures/Battery_Tender_Jr_Performance/03_BTJr+CCCY_Energy.jpg > > I was able to command the CBA IV battery > analyzer to deviate between two accurately > known load values while accurately reporting > the battery voltage. That delta-E/Delta-A > deduced a rather high internal resistance of > about 60 milliohms. > > So there's three ways to go about it ranging > from the hammer-n-tongs to poke-n-read. > > > Bob . . . > ________________________________________________________________________________
Date: Jun 28, 2020
Subject: Diodes - Ground Pwr/Battery Master Contactors
Hi - This is my first question for the forum. I am building RV8 w single aft battery/ dual alternator. Ground power contactor and battery master battery contactors are aft. Obtained both contactors from B&C with 1N5400 diodes. Total of 3 diodes (2 on the Ground Pwr Contactor and 1 on the Battery Master Contactor.) Diagram from Aircraft Spruce with the Piper jacks written by AeroElectric showed using 1N5402 diodes on the Ground Pwr contactor. Are there compelling reasons to swap out my 1N5400 diodes with 1N5402 or other? Thanks for reading and for responding. Drum ________________________________________________________________________________
Date: Jun 28, 2020
Subject: Re: Diodes - Ground Pwr/Battery Master Contactors
At 08:04 AM 6/28/2020, you wrote: >Hi - =C2 This is my first question for the forum. =C2 > >I am building RV8 w single aft battery/ dual >alternator.=C2 Ground power contactor and battery >master battery contactors are aft. =C2 Obtained >both contactors from B&C with 1N5400 >diodes.=C2 Total of 3 diodes =C2 (2 =C2 on the Ground >Pwr Contactor =C2 and =C2 1 on the Battery Master Contactor.) > >Diagram from Aircraft Spruce with the Piper >jacks written by AeroElectric =C2 showed using >1N5402 diodes on =C2 the =C2 Ground Pwr >contactor.=C2 Are there compelling reasons =C2 to =C2 >swap out =C2 my 1N5400 diodes with 1N5402 or other? > >Thanks=C2 for reading and for responding. The 1N54xx series devices are essentially identical for our purposes. The XX denotes reverse voltage rating that range from 50 to 1000 volts. See: https://www.vishay.com/docs/88 516/1n5400.pdf For our purposes, any of those devices will be operated within limits on a 14v aircraft. Bob . . . ________________________________________________________________________________
Date: Jun 28, 2020
On Sun, Jun 28, 2020 at 8:15 AM Drummond Grinalds wrote: > Hi - This is my first question for the forum. > > I am building RV8 w single aft battery/ dual alternator. Ground power > contactor and battery master battery contactors are aft. Obtained both > contactors from B&C with 1N5400 diodes. Total of 3 diodes (2 on the > Ground Pwr Contactor and 1 on the Battery Master Contactor.) > > Diagram from Aircraft Spruce with the Piper jacks written by AeroElectric > showed using 1N5402 diodes on the Ground Pwr contactor. Are there > compelling reasons to swap out my 1N5400 diodes with 1N5402 or other? > > Thanks for reading and for responding. > > Drum > > Same current rating. Voltage ratings of 50V vs 200V. http://www.datasheetcatalog.com/info_redirect/datasheets/newjerseysemiconductor/1N5400-1N5408.pdf.shtml When I buy diodes, I usually get higher voltage ratings because they typically don't cost much (if any) more in small quantities than lower voltage ratings. But if B&C shipped 50V rated diodes with their contactors, I'd be confident that 50V is good enough. (Even 1A current rating would be good enough for the shunt around the coil, but the 3A diodes are physically more rugged.) Charlie Virus-free. www.avast.com <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> ________________________________________________________________________________
Date: Jun 28, 2020
At 10:29 PM 6/27/2020, you wrote: > > >Oops. For your example, the delta current is actually >2.444-1.235=1.209A. So the R=0.015/1.209=12.4 milliohms. > >You forgot to subtract the first reading. Other than the simple >math error (something I do all the time...) the rest of the >explanation is spot on. > >Dick Tasker > Good catch! Thank you sir. BTW . . . I've been playing with my newly acquired CBA IV battery analyzer from West Mountain Radio. I've confirmed suspicions that not all 18650 cells are what they're 'marked up' to be. A few utility cells in the stable are marked with truing amazing capacity values like 3800 and 9000 mAh! While doing cap checks on the cells I'm noticing some common traits in LiFePO4 cells that contribute to and article/white paper on system integration of lithium onto our airplanes. I do have a couple of cells by Panasonic that were advertised as 2900 mAh devices. They are proving to perform as advertised. Just for grins, I conducted a quick delta-I resistance check on one of the cells last night. Snapshot attached. The CBA IV software has a 'dynamic' current mode that allows you to change the load current while the test is running. Pretty cool . . . I've got brand new Aerovoltz and Hawker batteries ordered on which I'll conduct and record a library of performance curves for comparison in the white paper. Bob . . . ________________________________________________________________________________
Date: Jun 28, 2020
Thanks Bob and Dick for the details of measuring IR.... I will pursue a simple test setup.... Dave On Sat, Jun 27, 2020 at 6:50 PM Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 07:27 PM 6/26/2020, you wrote: > > Hi Bob, > Thanks for the plot information...Maintainers and their profiles. > Your details brought up a question. > Would you have a suggestion for a simple setup for measuring internal > cell/battery resistance, IR, of lithium based cells. > Modelers use a lot of Lipo based batteries.=C3=82 And there is a strong need > to keep track of their condition and it seems like tracking IR could be t he > best option. A practical way to run the tests is sorely needed. > Your suggestions are always appreciated. > > > Hmmmm . . . internal resistance can be > measured 'instantly' as opposed to doing > a total-discharge cap-check. The results > of a 'severe load' test considers > a combination of chemical potential > (capacity) -AND- internal resistance > (ohmic losses). An internal resistance > test can be conducted at lower energy > levels than the load-test. Of course, > all three tests require some instrumentation > and process. > > The hammer-n-tongs way to measure cell > impedance is to load with some handy value > resistor, measure the voltage then increase > the load by say, double or tripling it > and read the voltage again. > > Example: Suppose your battery under test > puts out 12.35 volts with a 10 ohm load. > Your base current is 12.35/10 = 1.235 amps > > Temporarily add a second load resistor . . . > any practical value, let's say another > 10 ohms. Let's assume the new reading is > 12.220 volts. Okay, total R across the > battery is now 5 ohms. 12.22/5 = 2.444 > amps. > > So, for a delta current of 2.444A > we read a delta-volts of 0.015V > > .015/2.444 = 6 milliohms > > One could craft a test box containing > the necessary resistors, push-button > and meter connections to simplify the > setup but you'd still have to get out > the calculator and do the math. > > I designed a direct reading battery > resistance meter about 20 years ago. > It featured a constant current load > system that was switched with a > multi-vibrator at about 10 cycles > per second. > > It toggled between 1 and 11 amps. > A pk-to-pk reading voltmeter would show > the ripple voltage created at the battery > terminals as the electronic load oscillated > between the two current values. > > Internal resistance was nearly direct > reading where 10 mv pk-pk equated to > 1 milliohm of resistance. I've probably > got those drawings around here somewhere. > > In my recent studies of on the garden > tractor battery . . . > > > http://www.aeroelectric.com/Pictures/Battery_Tender_Jr_Performance/03_BTJ r+CCCY_Energy.jpg > > I was able to command the CBA IV battery > analyzer to deviate between two accurately > known load values while accurately reporting > the battery voltage. That delta-E/Delta-A > deduced a rather high internal resistance of > about 60 milliohms. > > So there's three ways to go about it ranging > from the hammer-n-tongs to poke-n-read. > > > Bob . . . > ________________________________________________________________________________
Date: Jun 28, 2020
At 03:58 PM 6/28/2020, you wrote: >Thanks Bob and Dick for the details of measuring IR.... >I will pursue a simple test setup.... >Dave What are the highest and lowest voltage battery packs you want to test? Bob . . . ________________________________________________________________________________
Date: Jun 28, 2020
Bob, Majority are 3 to 6 cell packs. The highest would be a 6 cell pack. Thus, 6 x 4.2 or about 25 vdc. The lowest would be a 3 cell pack. About 12.5 vdc. Dave On Sun, Jun 28, 2020 at 3:11 PM Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 03:58 PM 6/28/2020, you wrote: > > Thanks Bob and Dick for the details of measuring IR.... > I will pursue a simple test setup.... > Dave > > > What are the highest and lowest voltage battery > packs you want to test? > > > Bob . . . > ________________________________________________________________________________
Date: Jun 29, 2020
Subject: Teflon fuel line
Hi -This is my first question for the forum. I may use a Teflon fuel pipe with anodized AN fittings in an RV9 between the fuel tank and the Andair fuel selector. The anodized fittings don =99t seem to conduct electricity (even though the teflon fuel line has a metal-braid covered inside a plastic covering). I wondered whether this will be a problem/danger due to possible electrostatic charge from the flowing fuel. Thanks for any suggestions Michael Townley -- Mike Townley 0419393470 ________________________________________________________________________________
From: "prestonkavanagh" <preston.kavanagh(at)gmail.com>
Date: Jun 29, 2020
"I used LibreOffice Draw to make my wiring diagrams. It worked but was pretty time-consuming." IF WireViz is the new best choice for documenting cables, what's the choice for the schematics? I want to add details to a Z101 foundation. Absent software it will be pencil lines on a paper printout, and that's well short of the standard. What is the recommended software? Recognize that for me this is rare and occasional use - I'll give up some functionality for drag and drop simplicity. Regards, PK -------- PBK3 PA-12, BD-4, RV6a, gliders Read this topic online here: http://forums.matronics.com/viewtopic.php?p=497078#497078 ________________________________________________________________________________
Date: Jun 29, 2020
Subject: Re: Teflon fuel line
On Mon, Jun 29, 2020 at 3:38 AM Michael Townley wrote: > Hi -This is my first question for the forum. > > I may use a Teflon fuel pipe with anodized AN fittings in an RV9 between > the fuel tank and the Andair fuel selector. The anodized fittings don =99t > seem to conduct electricity (even though the teflon fuel line has a > metal-braid covered inside a plastic covering). I wondered whether this > will be a problem/danger due to possible electrostatic charge from the > flowing fuel. > > Thanks for any suggestions > Michael Townley > > -- > Mike Townley 0419393470 > Interesting question. When Teflon lined hose 1st came on the market, there were significant issues with static buildup due to flow in the non-conductive hose. Because of that, I suspect that you can't even buy Teflon lined hose these days without carbon impregnated Teflon used as the liner. So, while I can't answer your question with authority, I don't worry about it in my installation, since the carbon impregnated Teflon provides a static bleed connection along all components in the fuel system, keeping all the fuel at the same electrical potential. Thinking about it, if the anodized fittings were a problem, then you'd have the same issue even with aluminum 'hard line', because every joint would be an electrical break in the path. (The male taper of the fitting would insulate from the aluminum female on the tubing.) The old 'rubber' hoses likely had carbon in the liner too, and we never heard about static issues due to anodized aluminum fittings. Shucks, even the anodized fittings may bleed off the static charge, even though they seem to check as open on an ohm meter. 'Static straps' are usually quite high in resistance, so they don't provide a low voltage current path to ground (think about the danger if you're wearing a wrist strap & touch the wrong thing in a circuit.... https://en.wikipedia.org/wiki/Antistatic_device#:~:text=Antistatic%20mat, -An%20antistatic%20floor&text=Typical%20resistance%20is%20on%20the,line%2 0in%20an%20electrical%20outlet. I'd suggest checking with your vendor, to be sure that the hose you're planning to use has a carbon impregnated Teflon liner. FWIW, Charlie Virus-free. www.avast.com <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> ________________________________________________________________________________
Date: Jun 29, 2020
No danger from static for a couple of reasons. Fuel can only ignite if it is mixed with oxygen (air). Since the fuel line does not contain air, it can not ignite. And even if there is air in the fuel line, the ratio of fuel to air needs to be within a certain range to ignite. The mixture will be too rich. Even if the fuel air ratio is ideal for combustion, there is still no need to worry. A metal airplane like your RV-9 will keep all parts of the fuel system at the same voltage. No sparks will jump. Some fuel systems use non-conductive rubber hose. In that case, the danger is not from static, but from mechanical damage or kinking. Anodized metal fittings might not be good conductors of electricity, but will conduct enough to prevent high voltages from building up. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=497080#497080 ________________________________________________________________________________
Date: Jun 29, 2020
mtown52(at)gmail.com wrote: > ... I may use a Teflon fuel pipe with anodized AN fittings... between the fuel tank and the... fuel selector... I wondered whether this will be a problem/danger due to possible electrostatic charge from the flowing fuel. > > Michael Townley > Teflon should have an additive to make it conductive else the flow of a non-conductive medium, like gasoline, will generate an electrostatic charge that will
June 07, 2020 - June 30, 2020
AeroElectric-Archive.digest.vol-pl
