AeroElectric-Archive.digest.vol-pt
September 26, 2020 - October 12, 2020
      >> https://www.ebay.ca/itm/192243452240
      >> DC-DC Converter
      >> 5 Amps
      >> Input 3-35 V
      >> Output 5-40 V
      >> I'm trying to support ~1 A EFIS during start so I thought 5 A would be
      >> plenty but a closer look at the description says it's good for 3 A with a
      >> maximum of 5 A. Turns out the 3 A is on the input side, not the output
      >> side. With a voltage output set point of 10V and a ~1 A lamp connected, the
      >> lamp browns out (literally) as soon as the input voltage sags below 9V. A
      >> long way from the 7V minimum I was hoping for. I plugged it into a Battery
      >> Analyzer at 1.0 and 0.5 A and momentarily dropped the input voltage to 8V.
      >> Even when voltage is restored it takes several seconds to recover back to
      >> the set voltage with a 1 A load. A 0.5 A load is fine.
      >>   Good investigative work sir!  You're
      >>   on the right track. The up-converter
      >>   you have is a bit on the light side.
      >>   I'd go for beefy . . . and the up-converter
      >>   needs to be characterized in Watts.  A converter
      >>   that would support a 5A load at 14V would be
      >>   rated at 70 W or more.
      >>   The test articles I have on hand are, as I recall,
      >>   150 W devices. I'm hoping to put power to them
      >>   to see if I can characterize their dynamic qualities
      >>   before I send you one.
      >>   I'm a bit out of pocket right now. Getting ready for
      >>   some roto-rooter work on my back . . . got a leg
      >>   that occasionally says, "I quit". It would not be
      >>   a good thing to be loading a patient and suddenly
      >>   find yourself on the ground asking the patient
      >>   to help you up!
      >>   Doc says it's a quick fix with excellent
      >>   prospects for success but in the interim,
      >>   my forays about the shop are limited. The
      >>   up converters I have are, I believe, this
      >>   one:
      >> https://tinyurl.com/yxndk24a
      >>   Price is right, size is convenient . . .
      >>   and there is little risk for having
      >>   one that is too big. Thanks for sharing
      >>   your observations.
      >>   Bob . . .
      >> These:
      >> https://www.ebay.com/itm/DC-DC-Converter-10-12-15-20A-150-250-300-400-1200W-Step-up-Step-down-Buck-Boost/382219150784?hash=item58fe0965c0:g:6OwAAOSwisVZrgue
      >> Claim to be good down to 8.5V input. Various wattage versions available.
      >> Charlie
      >>  Virus-free.
      >> www.avast.com
      >> <#m_4222304353412265700_m_4819214867954981025_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
Date: Sep 26, 2020
Subject: Re: Brownout Step Up Converter
Very interesting Charlie. I was only using a 1A automotive bulb for load and as you say my converter looks like it's using the same hardware as yours so maybe the addition of the second power path makes enough of a difference? I would not have thought so but it's worth a try, I'll wire it up again and see. Also when dropping the voltage down to 8V I'm doing it as quickly as possible with the power supply fine adjustment. Were you slowly decreasing the input voltage or doing so suddenly? Mine was $10 CAD for one and those ones are $30 for 5 so the price is ok. On Sat, Sep 26, 2020 at 9:55 AM Charlie England wrote: > Hi Sebastian, > > Thought I'd share some rough testing on a 4A rated booster, that seems to > use the same inverter IC as the one you're using. I bought these: > > https://smile.amazon.com/gp/product/B07XG323G8/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1 > I used an automotive brake light bulb that measures 2A draw at 14V and > ~1.8A at 12.5V (about what a tired battery might be). > > My results with the booster in the circuit, set for 11V output, which > should be adequate to keep an EFIS alive. > (list is: supply V/A booster V): > > 14/2.1 12.6 > 12/2.0 11.1 > 10/2.7 11.1 > 9/3.1 11.1 > 8.5/3.6 11.0 > 8.0/3.4 10.5 > Supply V/A are read off my cheap Asian variable supply display, and > rounded to nearest tenth. Booster output V measured with Fluke meter, > rounded to nearest tenth. > After several minutes with the supply at 8V, the booster output starts > dropping a bit. I *suspect* that is because the inverter IC has no heat > sink and is beginning to thermal-limit to protect itself. In any case, the > booster should be loaded for only a few seconds during the start event. > > Note: One thing I did was to insert a 'fat' diode in series with the > supply that goes directly to the lamp (also shown in the Z figure). The > diode output and the booster output both feed the lamp. When supply voltage > drops below booster output, the diode prevents the booster trying to feed > back into the supply at the booster's set voltage (obviously impossible). > > Did you check your battery voltage at the battery terminals, or were you > using the EFIS to monitor battery voltage? My experience is that depending > on how the a/c is wired, the EFIS may see a lower than actual voltage, due > to diodes (or resistances) in the path to the EFIS input. Battery voltage > dropping to the 6V area when starting sounds like either high resistance in > the battery circuit, or a tired battery. > > My GRT EFIS has multiple diode-isolated inputs, so the next step is to > wire the booster from my E-bus to a spare power input on the EFIS & try it > out. > > Charlie > > On Sat, Sep 19, 2020 at 11:36 AM Sebastien wrote: > >> Now I'm getting confused. The converter Bob linked to has a minimum of 10 >> volts input. Charlie's is 8.5 volts. The only time we want these units >> working is below 10 volts, and they need to work much lower than that. The >> last start on my aircraft recorded a 7.6 from a fully charged battery and >> that's just what the EFIS managed to capture at 1 sample per second. >> >> Looking again I have found a couple units that claim to work at very low >> voltages: >> >> >> https://www.ebay.ca/itm/DC-DC-10A-Buck-Boost-Converter-Step-Up-Down-regulator-Module-for-LED-Driver-US/254169431168 >> >> https://www.ebay.ca/itm/DC-DC-Buck-Boost-Converter-Adjustable-CC-CV-Step-Up-Down-Power-Supply-Module/124260980594 >> >> I'm considering ordering one for further testing. >> >> Bob best wishes for a quick recovery but take your time. Get yourself >> fully in fettle before worrying about anyone else! >> >> On Sat, Sep 19, 2020 at 8:17 AM Charlie England >> wrote: >> >>> On 9/19/2020 9:26 AM, Robert L. Nuckolls, III wrote: >>> >>> At 11:02 PM 9/17/2020, you wrote: >>> >>> A couple weeks ago I ordered one of these off eBay: >>> >>> https://www.ebay.ca/itm/192243452240 >>> >>> DC-DC Converter >>> 5 Amps >>> Input 3-35 V >>> Output 5-40 V >>> >>> I'm trying to support ~1 A EFIS during start so I thought 5 A would be >>> plenty but a closer look at the description says it's good for 3 A with a >>> maximum of 5 A. Turns out the 3 A is on the input side, not the output >>> side. With a voltage output set point of 10V and a ~1 A lamp connected, the >>> lamp browns out (literally) as soon as the input voltage sags below 9V. A >>> long way from the 7V minimum I was hoping for. I plugged it into a Battery >>> Analyzer at 1.0 and 0.5 A and momentarily dropped the input voltage to 8V. >>> Even when voltage is restored it takes several seconds to recover back to >>> the set voltage with a 1 A load. A 0.5 A load is fine. >>> >>> >>> Good investigative work sir! You're >>> on the right track. The up-converter >>> you have is a bit on the light side. >>> >>> I'd go for beefy . . . and the up-converter >>> needs to be characterized in Watts. A converter >>> that would support a 5A load at 14V would be >>> rated at 70 W or more. >>> >>> The test articles I have on hand are, as I recall, >>> 150 W devices. I'm hoping to put power to them >>> to see if I can characterize their dynamic qualities >>> before I send you one. >>> >>> I'm a bit out of pocket right now. Getting ready for >>> some roto-rooter work on my back . . . got a leg >>> that occasionally says, "I quit". It would not be >>> a good thing to be loading a patient and suddenly >>> find yourself on the ground asking the patient >>> to help you up! >>> >>> Doc says it's a quick fix with excellent >>> prospects for success but in the interim, >>> my forays about the shop are limited. The >>> up converters I have are, I believe, this >>> one: >>> >>> https://tinyurl.com/yxndk24a >>> >>> Price is right, size is convenient . . . >>> and there is little risk for having >>> one that is too big. Thanks for sharing >>> your observations. >>> >>> >>> Bob . . . >>> >>> These: >>> >>> https://www.ebay.com/itm/DC-DC-Converter-10-12-15-20A-150-250-300-400-1200W-Step-up-Step-down-Buck-Boost/382219150784?hash=item58fe0965c0:g:6OwAAOSwisVZrgue >>> Claim to be good down to 8.5V input. Various wattage versions available. >>> >>> Charlie >>> >>> >>> Virus-free. >>> www.avast.com >>> >>> <#m_-413585332925668195_m_4222304353412265700_m_4819214867954981025_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> >>> >> ________________________________________________________________________________
Date: Sep 26, 2020
I re-ran the test, dialing back to as low as 7V as quickly as possible while using the pot on the power supply. No difference in characteristics. I then tried it with the lamp fed only by the booster; same result. At 7V supply, current demand is a few tenths over the 4A rating of the booster, and output voltage dropped to right at 10V. Below 7V the booster seems to shut down (light slowly goes out) and if V is brought back up to ~12V, it recovers within a second or two. Remember, I'm recording data with Mk1 eyeball & pencil. I'll report again when I get it 'breadboarded' in the plane. What's the exchange rate & border penalty in Canada these days? I paid less than US$8 for the pack of 5, shipped. (Sincere apologies if you're getting Trumped.) Charlie On Sat, Sep 26, 2020 at 12:44 PM Sebastien wrote: > Very interesting Charlie. I was only using a 1A automotive bulb for load > and as you say my converter looks like it's using the same hardware as > yours so maybe the addition of the second power path makes enough of a > difference? I would not have thought so but it's worth a try, I'll wire it > up again and see. > > Also when dropping the voltage down to 8V I'm doing it as quickly as > possible with the power supply fine adjustment. Were you slowly decreasing > the input voltage or doing so suddenly? > > Mine was $10 CAD for one and those ones are $30 for 5 so the price is ok. > > On Sat, Sep 26, 2020 at 9:55 AM Charlie England > wrote: > >> Hi Sebastian, >> >> Thought I'd share some rough testing on a 4A rated booster, that seems to >> use the same inverter IC as the one you're using. I bought these: >> >> https://smile.amazon.com/gp/product/B07XG323G8/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1 >> I used an automotive brake light bulb that measures 2A draw at 14V and >> ~1.8A at 12.5V (about what a tired battery might be). >> >> My results with the booster in the circuit, set for 11V output, which >> should be adequate to keep an EFIS alive. >> (list is: supply V/A booster V): >> >> 14/2.1 12.6 >> 12/2.0 11.1 >> 10/2.7 11.1 >> 9/3.1 11.1 >> 8.5/3.6 11.0 >> 8.0/3.4 10.5 >> Supply V/A are read off my cheap Asian variable supply display, and >> rounded to nearest tenth. Booster output V measured with Fluke meter, >> rounded to nearest tenth. >> After several minutes with the supply at 8V, the booster output starts >> dropping a bit. I *suspect* that is because the inverter IC has no heat >> sink and is beginning to thermal-limit to protect itself. In any case, the >> booster should be loaded for only a few seconds during the start event. >> >> Note: One thing I did was to insert a 'fat' diode in series with the >> supply that goes directly to the lamp (also shown in the Z figure). The >> diode output and the booster output both feed the lamp. When supply voltage >> drops below booster output, the diode prevents the booster trying to feed >> back into the supply at the booster's set voltage (obviously impossible). >> >> Did you check your battery voltage at the battery terminals, or were you >> using the EFIS to monitor battery voltage? My experience is that depending >> on how the a/c is wired, the EFIS may see a lower than actual voltage, due >> to diodes (or resistances) in the path to the EFIS input. Battery voltage >> dropping to the 6V area when starting sounds like either high resistance in >> the battery circuit, or a tired battery. >> >> My GRT EFIS has multiple diode-isolated inputs, so the next step is to >> wire the booster from my E-bus to a spare power input on the EFIS & try it >> out. >> >> Charlie >> >> On Sat, Sep 19, 2020 at 11:36 AM Sebastien wrote: >> >>> Now I'm getting confused. The converter Bob linked to has a minimum of >>> 10 volts input. Charlie's is 8.5 volts. The only time we want these units >>> working is below 10 volts, and they need to work much lower than that. The >>> last start on my aircraft recorded a 7.6 from a fully charged battery and >>> that's just what the EFIS managed to capture at 1 sample per second. >>> >>> Looking again I have found a couple units that claim to work at very low >>> voltages: >>> >>> >>> https://www.ebay.ca/itm/DC-DC-10A-Buck-Boost-Converter-Step-Up-Down-regulator-Module-for-LED-Driver-US/254169431168 >>> >>> https://www.ebay.ca/itm/DC-DC-Buck-Boost-Converter-Adjustable-CC-CV-Step-Up-Down-Power-Supply-Module/124260980594 >>> >>> I'm considering ordering one for further testing. >>> >>> Bob best wishes for a quick recovery but take your time. Get yourself >>> fully in fettle before worrying about anyone else! >>> >>> On Sat, Sep 19, 2020 at 8:17 AM Charlie England >>> wrote: >>> >>>> On 9/19/2020 9:26 AM, Robert L. Nuckolls, III wrote: >>>> >>>> At 11:02 PM 9/17/2020, you wrote: >>>> >>>> A couple weeks ago I ordered one of these off eBay: >>>> >>>> https://www.ebay.ca/itm/192243452240 >>>> >>>> DC-DC Converter >>>> 5 Amps >>>> Input 3-35 V >>>> Output 5-40 V >>>> >>>> I'm trying to support ~1 A EFIS during start so I thought 5 A would be >>>> plenty but a closer look at the description says it's good for 3 A with a >>>> maximum of 5 A. Turns out the 3 A is on the input side, not the output >>>> side. With a voltage output set point of 10V and a ~1 A lamp connected, the >>>> lamp browns out (literally) as soon as the input voltage sags below 9V. A >>>> long way from the 7V minimum I was hoping for. I plugged it into a Battery >>>> Analyzer at 1.0 and 0.5 A and momentarily dropped the input voltage to 8V. >>>> Even when voltage is restored it takes several seconds to recover back to >>>> the set voltage with a 1 A load. A 0.5 A load is fine. >>>> >>>> >>>> Good investigative work sir! You're >>>> on the right track. The up-converter >>>> you have is a bit on the light side. >>>> >>>> I'd go for beefy . . . and the up-converter >>>> needs to be characterized in Watts. A converter >>>> that would support a 5A load at 14V would be >>>> rated at 70 W or more. >>>> >>>> The test articles I have on hand are, as I recall, >>>> 150 W devices. I'm hoping to put power to them >>>> to see if I can characterize their dynamic qualities >>>> before I send you one. >>>> >>>> I'm a bit out of pocket right now. Getting ready for >>>> some roto-rooter work on my back . . . got a leg >>>> that occasionally says, "I quit". It would not be >>>> a good thing to be loading a patient and suddenly >>>> find yourself on the ground asking the patient >>>> to help you up! >>>> >>>> Doc says it's a quick fix with excellent >>>> prospects for success but in the interim, >>>> my forays about the shop are limited. The >>>> up converters I have are, I believe, this >>>> one: >>>> >>>> https://tinyurl.com/yxndk24a >>>> >>>> Price is right, size is convenient . . . >>>> and there is little risk for having >>>> one that is too big. Thanks for sharing >>>> your observations. >>>> >>>> >>>> Bob . . . >>>> >>>> These: >>>> >>>> https://www.ebay.com/itm/DC-DC-Converter-10-12-15-20A-150-250-300-400-1200W-Step-up-Step-down-Buck-Boost/382219150784?hash=item58fe0965c0:g:6OwAAOSwisVZrgue >>>> Claim to be good down to 8.5V input. Various wattage versions available. >>>> >>>> Charlie >>>> >>>> >>>> Virus-free. >>>> www.avast.com >>>> >>>> <#m_-2951286493721026940_m_-413585332925668195_m_4222304353412265700_m_4819214867954981025_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> >>>> >>> ________________________________________________________________________________
Date: Sep 26, 2020
Additional thought. Did you ensure that your bench power supply was supplying the additional current needed when the voltage drops? Mine has a current limit knob in addition to the voltage control; I have to be sure I've dialed in enough current that the supply doesn't hit the limit. Charlie On 9/26/2020 2:29 PM, Charlie England wrote: > I re-ran the test, dialing back to as low as 7V as quicklyas possible > while using the pot on the powersupply. No difference in > characteristics. > > I then tried it with the lamp fed only by the booster; same result. At > 7V supply, current demand is a few tenths over the 4A rating of the > booster, and output voltage dropped to right at 10V. Below 7V the > booster seems to shut down (light slowly goes out) and if V is brought > back up to ~12V, it recovers within a second or two. Remember, I'm > recording data with Mk1 eyeball & pencil. I'll report again when I get > it 'breadboarded' in the plane. > > What's the exchange rate & border penalty in Canada these days? I paid > less than US$8 for the pack of 5, shipped. (Sincere apologies if > you're getting Trumped.) > > Charlie > > On Sat, Sep 26, 2020 at 12:44 PM Sebastien > wrote: > > Very interesting Charlie. I was only using a 1A automotive bulb > for load and as you say my converter looks like it's using the > same hardware as yours so maybe the addition of the second power > path makes enough of a difference? I would not have thought so but > it's worth a try, I'll wire it up again and see. > > Also when dropping the voltage down to 8V I'm doing it as quickly > as possible with the power supply fine adjustment. Were you slowly > decreasing the input voltage or doing so suddenly? > > Mine was $10 CAD for one and those ones are $30 for 5 so the price > is ok. > > On Sat, Sep 26, 2020 at 9:55 AM Charlie England > > wrote: > > Hi Sebastian, > > Thought I'd share some rough testing on a 4A rated booster, > that seems to use the same inverter IC as the one you're > using. I bought these: > https://smile.amazon.com/gp/product/B07XG323G8/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1 > I used an automotive brake light bulb that measures 2A draw at > 14V and ~1.8A at 12.5V (about what a tired battery might be). > > My results with the booster in the circuit, set for 11V > output, which should be adequate to keep an EFIS alive. > (list is: supply V/A booster V): > > 14/2.1 12.6 > 12/2.0 11.1 > 10/2.7 11.1 > 9/3.1 11.1 > 8.5/3.6 11.0 > 8.0/3.4 10.5 > Supply V/A are read off my cheap Asian variable supply > display, and rounded to nearest tenth. Booster output V > measured with Fluke meter, rounded to nearest tenth. > After several minutes with the supply at 8V, the booster > output starts dropping a bit. I /suspect/ that is because the > inverter IC has no heat sink and is beginning tothermal-limit > to protect itself. In any case, the booster should be loaded > for only a few seconds during the start event. > > Note: One thing I did was to insert a 'fat' diode in series > with the supply that goes directly to the lamp (also shown in > the Z figure). The diode output and the booster output both > feed the lamp. When supply voltage drops below booster output, > the diode prevents the booster trying to feed back into the > supply at the booster's set voltage (obviously impossible). > > Did you check your battery voltage at the battery terminals, > or were you using the EFIS to monitor battery voltage? My > experience is that depending on how the a/c is wired, the EFIS > may see a lower than actual voltage, due to diodes (or > resistances) in the path to the EFIS input. Battery voltage > dropping to the 6V area when starting sounds like either high > resistance in the battery circuit, or a tired battery. > > My GRT EFIS has multiple diode-isolated inputs, so the next > step is to wire the booster from my E-bus to a spare power > input on the EFIS & try it out. > > Charlie > > On Sat, Sep 19, 2020 at 11:36 AM Sebastien > wrote: > > Now I'm getting confused. The converter Bob linked to has > a minimum of 10 volts input. Charlie's is 8.5 volts. The > only time we want these units working is below 10 volts, > and they need to work much lower than that. The last start > on my aircraft recorded a 7.6 from a fully charged battery > and that's just what the EFIS managed to capture at 1 > sample per second. > > Looking again I have found a couple units that claim to > work at very low voltages: > > https://www.ebay.ca/itm/DC-DC-10A-Buck-Boost-Converter-Step-Up-Down-regulator-Module-for-LED-Driver-US/254169431168 > https://www.ebay.ca/itm/DC-DC-Buck-Boost-Converter-Adjustable-CC-CV-Step-Up-Down-Power-Supply-Module/124260980594 > > I'm considering ordering one for further testing. > > Bob best wishes for a quick recovery but take your time. > Get yourself fully in fettle before worrying about anyone > else! > > On Sat, Sep 19, 2020 at 8:17 AM Charlie England > > wrote: > > On 9/19/2020 9:26 AM, Robert L. Nuckolls, III wrote: >> At 11:02 PM 9/17/2020, you wrote: >>> A couple weeks ago I ordered one of these off eBay: >>> >>> https://www.ebay.ca/itm/192243452240 >>> >>> >>> DC-DC Converter >>> 5 Amps >>> Input 3-35 V >>> Output 5-40 V >>> >>> I'm trying to support ~1 A EFIS during start so I >>> thought 5 A would be plenty but a closer look at the >>> description says it's good for 3 A with a maximum of >>> 5 A. Turns out the 3 A is on the input side, not the >>> output side. With a voltage output set point of 10V >>> and a ~1 A lamp connected, the lamp browns out >>> (literally) as soon as the input voltage sags below >>> 9V. A long way from the 7V minimum I was hoping for. >>> I plugged it into a Battery Analyzer at 1.0 and 0.5 >>> A and momentarily dropped the input voltage to 8V. >>> Even when voltage is restored it takes several >>> seconds to recover back to the set voltage with a 1 >>> A load. A 0.5 A load is fine. >> >> Good investigative work sir! You're >> on the right track. The up-converter >> you have is a bit on the light side. >> >> I'd go for beefy . . . and the up-converter >> needs to be characterized in Watts. A converter >> that would support a 5A load at 14V would be >> rated at 70 W or more. >> >> The test articles I have on hand are, as I recall, >> 150 W devices. I'm hoping to put power to them >> to see if I can characterize their dynamic qualities >> before I send you one. >> >> I'm a bit out of pocket right now. Getting ready for >> some roto-rooter work on my back . . . got a leg >> that occasionally says, "I quit". It would not be >> a good thing to be loading a patient and suddenly >> find yourself on the ground asking the patient >> to help you up! >> >> Doc says it's a quick fix with excellent >> prospects for success but in the interim, >> my forays about the shop are limited. The >> up converters I have are, I believe, this >> one: >> >> https://tinyurl.com/yxndk24a >> >> >> Price is right, size is convenient . . . >> and there is little risk for having >> one that is too big. Thanks for sharing >> your observations. >> >> >> Bob . . . >> > These: > https://www.ebay.com/itm/DC-DC-Converter-10-12-15-20A-150-250-300-400-1200W-Step-up-Step-down-Buck-Boost/382219150784?hash=item58fe0965c0:g:6OwAAOSwisVZrgue > Claim to be good down to 8.5V input. Various wattage > versions available. > > Charlie > > > Virus-free. www.avast.com > > > > <#m_-2951286493721026940_m_-413585332925668195_m_4222304353412265700_m_4819214867954981025_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> > -- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Subject: Can radials of home made ground plane be tapered?
Date: Sep 27, 2020
Hi Group I have a home made ground plane made out of aluminium for a Garmin GA-35 GPS / WAAS antenna. It has 8 radials 1" wide and ~7.75" long. I'm using the ground plane to support the antenna. It will be living under the ceiling of the baggage bay in a Europa. After cutting out the ground plane I find that it's plenty strong enough to support the antenna. Is it OK to taper the radials from 1" at the root to 1/2" at the tip? I could shave off some weight from the existing 8oz. Ron P. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=498564#498564 ________________________________________________________________________________
Subject: Re: Can radials of home made ground plane be tapered?
From: "prestonkavanagh" <preston.kavanagh(at)gmail.com>
Date: Sep 27, 2020
Others will respond on the radio theory aspect. I'll say that 8 oz is a heck of a lot of weight, and you can do better. I believe the Europa has most of the fiberglass work done at the factory, but I'm guessing you have some supplies around. Slice off a thin piece of foam, shape it to fit, inset a washer with ID equal to the antenna mount OD, one layer of BID on each side and you have something stiff, strong and light. Top it with super thin copper sheet (below is the one I like), and get a 2 oz mount and ground plane ready to attach to the airplane. Or find a friend among the composite builders! Let me know if you are close to Tampa - I can help. PK https://www.amazon.com/Conductive-Adhesive-Shielding-Electrical-Grounding/dp/B07R8BS843/ref=sr_1_7?dchild=1&keywords=copper+sheet+foil&qid=1601221863&sr=8-7 -------- PBK3 PA-12, BD-4, RV6a, gliders Read this topic online here: http://forums.matronics.com/viewtopic.php?p=498565#498565 ________________________________________________________________________________
Date: Sep 27, 2020
Hi PK I already had all of my antennas installed and the FAA now requires an ADS-B Out which I need to accommodate. For my situation the most logical position for my Garmin GA-35 antenna is below the ceiling above the baggage area. The ceiling slopes and is in a constant changing 3D equation where to lay up something or attempt to make a metal shelf would be a chore and not look very nice. My 8 radial .063" ground plane is not just a ground plane but the support for the antenna. It needs to support ~12 lbs. The antenna with screws is over 8oz. My Spider / Ninja Shuriken doesn't look too bad, it's honest. I mocked up a shelf and it looks mucked up. I was thinking about doing exactly as you suggest, thin glass, some thin foam and some thin glass and cover with copper foil that I have. The antenna needs to be close to level to the longitudinal axis which will put the front radial about 2" below the ceiling. Thx. for your offer, I'm in NY. Aeroplanes are compromises and I'm happy with Spider / Ninja Shuriken. If I taper the radials I think I can down to 6oz. The ground plane needs to stay below the base of the antenna which if mounting the antenna inside out of the slip stream negates ability to put on ceiling. If I mounted it on top in the slip stream then I could put copper foil inside but I would need to lift the rear of the antenna and build sort of a submarine bias cut conning tower. Ron P. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=498566#498566 ________________________________________________________________________________
Date: Sep 27, 2020
At 07:34 AM 9/27/2020, you wrote: > >Hi Group I have a home made ground plane made out of aluminium for a >Garmin GA-35 GPS / WAAS antenna. It has 8 radials 1" wide and ~7.75" >long. I'm using the ground plane to support the antenna. It will be >living under the ceiling of the baggage bay in a Europa. After >cutting out the ground plane I find that it's plenty strong enough >to support the antenna. Is it OK to taper the radials from 1" at the >root to 1/2" at the tip? I could shave off some weight from the >existing 8oz. Ron P. Where did you find recommendations/requirements for a 'ground plane' on this antenna. I've looked at some garmin docs and only find references to antenna/coax grounding to skin . . . no requirements for any 'tuned' or 'resonant' ground plane in a plastic airplane. Bob . . . ________________________________________________________________________________
Date: Sep 27, 2020
Hi Bob See page 2-5 of GA-35 antenna installation manual: https://static.garmin.com/pumac/190-00848-00_f.pdf See page 6-8 of GDL-82 installation manual: https://static.garmin.com/pumac/190-01810-00_06.pdf Ron P. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=498569#498569 ________________________________________________________________________________
Date: Sep 27, 2020
Subject: Re: How do you figure C-Rating of a battery?
On Mon, Sep 14, 2020 at 1:09 PM rparigoris wrote: > rparigor(at)hotmail.com> > > Hi Bob Thank you for your review. I will post schematic when it's > completed. A few points: I'm not too worried about LiFe batteries getting > thermal runaway, but I am about LiPo batteries getting to a thermal > runaway. You posted a link to: https://tinyurl.com/y4oulfy9 As far as > LiFe batteries go, I think mfg has done a reasonable amount of homework but > fact is there is potential for problems that Lead Acid does not have and > they can still fail opened. Good enough for me to use. I'm not worried > about soldered and crimped connection to aluminium wires, but the terminal > connections can get a high resistance. Keeping connections clean and tight > mitigate majority of problems, but not all. As far as keeping NiMh pack > charged, using one of my AstroFlight delta peak chargers (110D or 112D), > once or twice a year will give them a C/10 for ~ 15 hours to balance, then > delta peak charge the rest of the times. Unless battery is very flat, > peaking at 1C takes less time than a pre-flight. 1x! > a year will capacity test down to 1V per cell and fuel pump equivalent > load. BTW have you ever used an AstroFlight Whatt Meter (Whatt is correctly > spelled)? Pretty slick meter that shows volts, amps and watt hours. Pricey > though, here's an alternative that works pretty good: > https://hobbyking.com/en_us/turnigy-180a-watt-meter-and-power-analyzer.html?queryID=7b349d17e0c87dff11877b2ea51342de&objectID=42854&indexName=hbk_live_magento_en_us_products > Ron P Ron, I may have stumbled upon your solution. I know you don't want LiPo in the cockpit (I can understand that). But if you're comfortable with LiFe for your main battery.... This: https://www.harborfreight.com/lithium-ion-jump-starter-and-power-pack-62749.html?_br_psugg_q=jump+starter At 1st glance, I was sure that it was LiPo. There's nothing in the HF ad that tells us anything different. But I just saw a video that shows it's actually a LiFePO4 battery. https://www.youtube.com/watch?v=EbIQhskJho0&t=636s The video shows both the label on the back of the case and the label on the battery module itself, inside the case. Now, I'm not defending the 'installation technique' he used, but the video does show what you'd be buying. You can see the case at around 3:30 in the video. It should easily serve the dual requirements of running the fuel pump alone, or supplying an emergency jump start if you're off-airport somewhere. I'd find $85 hard to argue with.... Charlie Virus-free. www.avast.com <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> ________________________________________________________________________________
Date: Sep 27, 2020
Maybe you should call Garmin to find out if a ground plane is really necessary. Other GPS antenna installations do not call for a ground plane. Garmin G3X Support g3xpert at garmin dot com eight six six -854-8433 - 7 to 7 Central Time M to F -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=498571#498571 ________________________________________________________________________________
Date: Sep 27, 2020
tapered? At 03:41 PM 9/27/2020, you wrote: > >Hi Bob > >See page 2-5 of GA-35 antenna installation manual: >https://static.garmin.com/pumac/190-00848-00_f.pdf See page 6-8 of >GDL-82 installation manual: https://static.garmin.com/pumac/190-01810-00_06.pdf > >Ron P. Okay, my copy is rev B and doesn't speak to adding a ground plane. I'm a bit mystified by this requirement. The gps/waas antennas are active devices meaning that the rf samples from the 'ether' are non-resonant 'probes' that cannot deliver useful energy into a 50-ohm coax without electronic (active) augmentation . . . nor do they have the same capture area of a tuned and/or multi-element antenna. Ground planes cannot participate in the delivery of energy to the active antenna's feedline . . . only in shaping radiation (reception) patterns. We've got all manner of gps devices from wrist watches and little drones to telephones and cameras. All must depend on active antennas, in horribly challenging environs . . . no room for a really efficient antenna. Now we have a gps system on the backbone of an airplane, completely free of terrestrial noise and shadowing with an uncluttered view of the sky . . . yet the installation instructions speak of 'optimizing' performance with the addition of a ground plane under an active antenna? Hmmm . . . What's missing from these documents is any calibration on bang-for-the-buck. I.e. just how much do I gain with this optimization? There's a whole bunch of hocky-puck, gps antennas flying with no ground plane. It would be interesting to install both configurations on an airplane with an A-B switch . . . to observe just how much optimization is secured with addition of the ground plane. I'd be surprised if the optimization offers more than a little wiggle in the already more-than-adequate signal strength displays. Thanks for the update on the manual . . . Bob . . . ________________________________________________________________________________
Subject: Re: antenna analyzer? Antennas
Date: Sep 27, 2020
Finally got around to playing with nanoVNA and DDRR antenna. I don't see that it can be used for a Comm antenna (118-136MHz). Too narrow bandwidth. Tried different things like changing gap, tap point, height and length. Formulas seem to be off. Found needed smaller circle (circumference). Also tap location closer to 0.5" that the 2.5 to 2.8" calculated points. I used a relatively thin wire as opposed to the recommended 1/4" to 1/2" tubing, hoping it would broaden the bandwidth (according to this remark:"The larger D is the higher efficiency is"). Bob tried to answer that for me but I'm still not sure if "efficiency" is related to bandwidth ("Q"). Perhaps I misunderstood that and should try 1/4" tubing? With a whip antenna, the bigger the diameter, the broader the bandwidth. However, for an ELT antenna it will be perfect under engine cowling or on turtle deck. Saw SWR below 1:1.10 while fiddling with it. Some have installed their ELT antenna in their RV-4 under the canopy between pilot and passenger. Obviously without measuring SWR. A hand (much less a head or the rollover structure) severely affect SWR. Of course ground plane is very much in question in that location. I also tried a 3/32" brass tube originating at very rear of canopy (ground contact to turtle deck) extending forward and up along the canopy. Very odd frequency response and very SWR sensitive to a hand near the tip. At this point I'm looking at designing a streamline base for my 3/32" brass tubing in Solidworks and 3D printing it, mounting the antenna traditionally just behind the aft canopy skirt. Perhaps squeezing the tubing into a somewhat streamline and/or stepping down to 1/8" after the first 12" piece. Finn On 7/15/2020 11:47 PM, Robert L. Nuckolls, III wrote: > At 04:36 PM 7/15/2020, you wrote: > >> I ordered this https://www.ebay.com/itm/283898850600 >> ten days ago. Will probably >> be several weeks before I get it. >> >> You can get them a lot cheaper, but I wanted one that'll also be >> useful checking transponder (and ADS-B) cable and antenna. (1GHz) >> >> Still haven't given up on the idea of putting VHF comm antenna under >> the RV-4 canopy. Other than vertical polarization, ground plane will >> probably be the biggest issue (and impedance matching if I can't get >> the ground plane right). Got three 12" 5/32"OD brass tubes from >> Hobby Lobby. Should give a reasonably wide bandwidth. >> >> Finn > > Check out this article from a 1971 issue of QST Magazine > > http://www.aeroelectric.com/articles/Antennas/DDRR_Antenna.PDF > <http://www.aeroelectric.com/articles/Antennas/DDRR_Antenna.PDF> > > A 2 meter (146 Mhz) version of this antenna > is 6" in diameter and sets about 1" off the > ground plane. An aviation version would be > about 7" in diameter. > > It's bandwidth is probably pretty narrow . . . > you'd have to build one and sweep it to > see if it's usable. Would this fit on > the deck just behind the rear seat? > > I've got one of those analyzers but haven't > had time to make it sing, dance and do dishes. > I've been using the VNA Tiny which is a good > bit more expensive. It seems to work well. > Let us know how that 'baby' VNA works for you! > > > Bob . . . > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Sep 27, 2020
I can't imagine a smaller dia wire spreading the freq peak, but then I've never seen that style antenna, either. :-) Maybe 'efficiency' in this context means usability across more of the frequency spectrum (lower Q). Certainly seems worth trying with 3/8 or 1/2 tubing, or 1/2" copper tape wrapped around something. Don't know if you care, but most ELTs require using their dedicated antenna to be 'legal', somewhat analogous to the silliness in FAA rules for GPS for IFR operations. I don't worry about the FAA that much, but if you insure the plane, it could give the ins co an out after an accident. I assume you're using an old style 121Mhz ELT, right? The new dual freq models seem to require highly specialized antennas. RE: brass for antenna. If you're talking about outside the canopy, you might want to re-think it. My 1st RV4 had the stainless wire whip ELT antenna mounted there, until it didn't. It broke off at the stress riser where it entered the long composite mounting cone. Behind the canopy is a really 'dirty', turbulent area. Maybe you could silver-solder a length of stainless tubing? Or 1/2" copper tape wrapped on a 'glass arrow shaft. I bet it'll still need some kind of support a few inches above the skin. Have fun... Charlie On 9/27/2020 7:17 PM, Finn Lassen wrote: > > Finally got around to playing with nanoVNA and DDRR antenna. > > I don't see that it can be used for a Comm antenna (118-136MHz). Too > narrow bandwidth. Tried different things like changing gap, tap point, > height and length. Formulas seem to be off. Found needed smaller > circle (circumference). Also tap location closer to 0.5" that the 2.5 > to 2.8" calculated points. I used a relatively thin wire as opposed to > the recommended 1/4" to 1/2" tubing, hoping it would broaden the > bandwidth (according to this remark:"The larger D is the higher > efficiency is"). Bob tried to answer that for me but I'm still not > sure if "efficiency" is related to bandwidth ("Q"). Perhaps I > misunderstood that and should try 1/4" tubing? > > > With a whip antenna, the bigger the diameter, the broader the bandwidth. > > However, for an ELT antenna it will be perfect under engine cowling or > on turtle deck. Saw SWR below 1:1.10 while fiddling with it. Some have > installed their ELT antenna in their RV-4 under the canopy between > pilot and passenger. Obviously without measuring SWR. A hand (much > less a head or the rollover structure) severely affect SWR. Of course > ground plane is very much in question in that location. > > I also tried a 3/32" brass tube originating at very rear of canopy > (ground contact to turtle deck) extending forward and up along the > canopy. Very odd frequency response and very SWR sensitive to a hand > near the tip. > > At this point I'm looking at designing a streamline base for my 3/32" > brass tubing in Solidworks and 3D printing it, mounting the antenna > traditionally just behind the aft canopy skirt. Perhaps squeezing the > tubing into a somewhat streamline and/or stepping down to 1/8" after > the first 12" piece. > > Finn > > > On 7/15/2020 11:47 PM, Robert L. Nuckolls, III wrote: >> At 04:36 PM 7/15/2020, you wrote: >> >>> I ordered this https://www.ebay.com/itm/283898850600 >>> ten days ago. Will >>> probably be several weeks before I get it. >>> >>> You can get them a lot cheaper, but I wanted one that'll also be >>> useful checking transponder (and ADS-B) cable and antenna. (1GHz) >>> >>> Still haven't given up on the idea of putting VHF comm antenna under >>> the RV-4 canopy. Other than vertical polarization, ground plane will >>> probably be the biggest issue (and impedance matching if I can't get >>> the ground plane right). Got three 12" 5/32"OD brass tubes from >>> Hobby Lobby. Should give a reasonably wide bandwidth. >>> >>> Finn >> >> Check out this article from a 1971 issue of QST Magazine >> >> http://www.aeroelectric.com/articles/Antennas/DDRR_Antenna.PDF >> <http://www.aeroelectric.com/articles/Antennas/DDRR_Antenna.PDF> >> >> A 2 meter (146 Mhz) version of this antenna >> is 6" in diameter and sets about 1" off the >> ground plane. An aviation version would be >> about 7" in diameter. >> >> It's bandwidth is probably pretty narrow . . . >> you'd have to build one and sweep it to >> see if it's usable. Would this fit on >> the deck just behind the rear seat? >> >> I've got one of those analyzers but haven't >> had time to make it sing, dance and do dishes. >> I've been using the VNA Tiny which is a good >> bit more expensive. It seems to work well. >> Let us know how that 'baby' VNA works for you! >> >> >> Bob . . . >> > > > > Virus-free. www.avast.com > > > > <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> -- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Sep 27, 2020
>I used a relatively thin wire as opposed to the recommended 1/4" >to 1/2" tubing, hoping it would broaden the bandwidth (according to >this remark:"The larger D is the higher efficiency is"). >Bob tried to answer that for me but I'm still not sure if >"efficiency" is related to bandwidth ("Q"). >Perhaps I misunderstood that and should try 1/4" tubing? Or even a radiator fabricated from flat sheet? The larger the diameter, the greater the bandwidth. Efficiency has to do with ohmic losses (how much energy goes off in heat) and again, a larger surface area of the radiator has lower resistance. Recall that currents at these frequencies flow on the skin of the conductor. At DC, there is a substantial difference between say a 1" diameter rod and a 1" thin wall tube. At 100 MHz there is virtually no difference 'cause all the 'happening' is at the surface. >With a whip antenna, the bigger the diameter, the broader the bandwidth. Exactly . . . >I also tried a 3/32" brass tube originating at very rear of canopy >(ground contact to turtle deck) extending forward and up along the >canopy. Very odd frequency response and very SWR sensitive to a hand >near the tip. Interesting observation . . . >At this point I'm looking at designing a streamline base for my >3/32" brass tubing in Solidworks and 3D printing it, mounting the >antenna traditionally just behind the aft canopy skirt. Perhaps >squeezing the tubing into a somewhat streamline and/or stepping down >to 1/8" after the first 12" piece. Also interesting . . . let us know what you discover. I am pleased that you've availed yourself of this unusual piece of test equipment. You're gaining knowledge and experience in a manner that you will not forget . . . and will become valuable information source for those who follow. Bob . . . ________________________________________________________________________________
Subject: Re: evolution of lithium technologies
Date: Sep 27, 2020
On 9/21/2020 11:03 AM, Charlie England wrote: > > > On Sun, Sep 20, 2020 at 11:56 AM Robert L. Nuckolls, III > > > wrote: > > > I've been studying current options for lithium > cells on the market. Discovered some interesting > things. For example . . . this excerpt from the > engineering data sheet on an 18650 cell cited > as suitable for battery powered tools: > > [snippped] > What insults might these cells endure if > incorporated into a flight system? Any worse > than those cited above? Just thinking . . . > > > Bob . . . > > That got me thinking (and searching). > A wade into the shallow end of the data pool yields only damp feet > when it comes to actual *power* capacity. The highest 'continuous > current' rating I could find on 18650 cells is around 30A. That would > imply, at 1st glance, at least 10 parallel cells per link in the > serial chain. Many were limited to around 2A continuous. I couldn't > find any specs on peak current, either on the bigger vendor sites, or > on actual mfgr data sheet pdfs. Descriptions of, and differences > among, the various chemistries and naming conventions, are all over > the map, depending on which interweb 'authority' you choose to accept. > Obviously more going on than I can see in the normal data sheets, > since there are dozens of functional examples of starting batteries on > the market. > > I'd certainly be game for rolling my own battery, but picking the > right cell seems a task not suited to mere mortals. > > Charlie As a followup, Do LiFePO4 batteries used for starting have altered chemistry or cell size, as compared to the 'deep cycle' versions? What about charging profiles? If not, https://www.amazon.com/LiFePO4-Battery-Miady-Rechargeable-Maintenance-Free/dp/B07X7MD2JK/ref=sr_1_3?dchild=1&keywords=12V+LiFePO4&qid=1601260110&sr=8-3 Looks interesting as the starting point for the DIY battery idea Bob mentioned earlier. The terminals are obviously inadequate as made, but it would be interesting to see what it looks like inside. If larger terminals could be installed... -- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Sep 27, 2020
>As a followup, >Do LiFePO4 batteries used for starting have altered chemistry or >cell size, as compared to the 'deep cycle' versions? What about >charging profiles? Probably. The no-iron lithium products demonstrate performance all over the map. I suspect there are similar variations on the LiFe theme > If not, >https://www.amazon.com/LiFePO4-Battery-Miady-Rechargeable-Maintenance-Free/dp/B07X7MD2JK/ref=sr_1_3?dchild=1&keywords=12V+LiFePO4&qid=1601260110&sr=8-3 >Looks interesting as the starting point for the DIY battery idea Bob >mentioned earlier. The terminals are obviously inadequate as made, >but it would be interesting to see what it looks like inside. If >larger terminals could be installed... Interesting product. Q&A's seem forthright. He says it's got a BMS that current limits so upsizing terminals is not likely to let it crank engines. It sold with free returns . . . i've ordered one to shake out. Bob . . . ________________________________________________________________________________
Subject: Re: Z13-8 modification and LSE ignition wiring
Date: Sep 28, 2020
Thank you all for your replies to the questions. T Mikus -------- Flying Sonerai II with A80 Continental. Wittman W10 Tailwind under construction, O360, dual LSE electronic ignition, airframe complete and covered, engine hung, cowl built. Working on electrical, instrumentation, and other details. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=498578#498578 ________________________________________________________________________________
Date: Sep 28, 2020
I would have to agree. I've had the antenna for a GTN625 installed in a fiberglass airplane with no groundplane for 5 years and never had a problem with reception. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=498580#498580 ________________________________________________________________________________
Date: Sep 28, 2020
On Sun, Sep 27, 2020 at 3:53 PM rparigoris wrote: > rparigor(at)hotmail.com> > > Hi Bob > > See page 2-5 of GA-35 antenna installation manual: > https://static.garmin.com/pumac/190-00848-00_f.pdf See page 6-8 of GDL-82 > installation manual: https://static.garmin.com/pumac/190-01810-00_06.pdf > > Ron P. > > I'd be at least a little suspicious of some tech writer 'boilerplating' installation text from the last install manual he was working on. :-) Virus-free. www.avast.com <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> ________________________________________________________________________________
Date: Sep 28, 2020
I guess ideally a tapered carbonfiber tube (perhaps wrapped with copper table within another tapered carbonfiber tube). I wonder if the carbon material is conductive enough for our purposes. Finn On 9/27/2020 8:51 PM, Charlie England wrote: > RE: brass for antenna. If you're talking about outside the canopy, you > might want to re-think it. My 1st RV4 had the stainless wire whip ELT > antenna mounted there, until it didn't. It broke off at the stress > riser where it entered the long composite mounting cone. Behind the > canopy is a really 'dirty', turbulent area. Maybe you could > silver-solder a length of stainless tubing? Or 1/2" copper tape > wrapped on a 'glass arrow shaft. I bet it'll still need some kind of > support a few inches above the skin. --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Sep 28, 2020
At 08:43 AM 9/28/2020, you wrote: > >I guess ideally a tapered carbonfiber tube (perhaps wrapped with >copper table within another tapered carbonfiber tube). Can you easily conduct the experiment? Sounds interesting. >I wonder if the carbon material is conductive enough for our purposes. No. Antennas on our carbon aircraft at Hawker-Beech required a beefed up ground plane. We also had to add a distributed ground system for electrics . . . super pain in the you know what . . . Bob . . . ________________________________________________________________________________
Date: Sep 28, 2020
tapered? > >I'd be at least a little suspicious of some tech >writer 'boilerplating' installation text from >the last install manual he was working on. :-)=C2 Yeah, AC43-13 was a prime example of 'suggestions' offered up by folks who never touched an airplane. EAA was invited to comment on an 'upgrade' to the document ready for imminent release back about 1995. I was invited to comment on the electrics. I think a dozen or more EAA members participated in other areas. EAA sent a rather comprehensive data package to the FAA . . . the document release was pushed out 10 months or so . . . and they still didn't get all the potholes patched. I think I've got a copy of my submission around here somewhere . . . it would be interesting to review it 25 or so years later! That 7.5" radius figure from Garmin doesn't approach any multiple of 1/4 wave at the frequency of interest. Unless going for an 'infinite' g.p. then you'd think they would call out some odd multiple of 1/4 wave at freq of interest. Bob . . . ________________________________________________________________________________
Date: Sep 28, 2020
Hi Group FWIW I called Garmin and Stein Air and both said to use a ground plane. I also called Vans. On their RV-12 they install the GA-35 on a small bracket FWF. I called them and asked about a ground plane and they said that the lower cowl acts as a ground plane. Here's a post from a guy in the Vans Forum: "I can tell you this...originally I installed mine under the cowl with little to no ground plane. It worked.... Later I installed a bigger ground plane and the signal levels definately increased." It was posted in reply from a 12/30/2012 question in Vans Forum, he doesn't say what model plane he had, precisely what antenna or how large of a ground plane. I have now heard of several Europa's and a Long EZ using the GA-35 without a ground plane with good success. Ron P. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=498586#498586 ________________________________________________________________________________
Date: Sep 28, 2020
Hi Charlie Thank you for thinking of me! For back up I need something small to fit in headrest. The HF unit is too big and too heavy. FWIT here's my take: Harbor Freight in my experience has been less than truthful when it comes to specs and quality / reliability is an issue. I was working on a project a while back and they offered a 18aH jump start pack. It had a battery that was marked 18aH. It was a 12aH battery in a 18aH case! We took out the supplied chargers and I had a pile of them for a while. After 25 uses failure rate was 10 or 15%. Just awful. Since we took apart hundreds of units, workmanship was also awful. Northern tools isn't any better. For another project I needed 100 amps for a short time. I purchased from Northern Tools one of their 4,000 amp jump packs. At room temp it would put out 40 amps for 3 seconds. If it was cold out probably only 20 or 25 amps.:https://www.northerntool.com/shop/tools/product_200676383_200676383 Their# is 216-464-8131 Their 4,000 amp unit can put out ~ 40 amps for 3 seconds at minimum of 10.9 volts, after 15 seconds down to ~35 amps and if it were cold probably 20 or 25 amps. The battery is only 8aH. (I didn't test capacity but question that as well). Ron P. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=498587#498587 ________________________________________________________________________________
Date: Sep 28, 2020
On 9/28/2020 12:13 PM, rparigoris wrote: > > Hi Charlie Thank you for thinking of me! For back up I need something small to fit in headrest. The HF unit is too big and too heavy. > FWIT here's my take: > Harbor Freight in my experience has been less than truthful when it comes to specs and quality / reliability is an issue. I was working on a project a while back and they offered a 18aH jump start pack. It had a battery that was marked 18aH. It was a 12aH battery in a 18aH case! We took out the supplied chargers and I had a pile of them for a while. After 25 uses failure rate was 10 or 15%. Just awful. Since we took apart hundreds of units, workmanship was also awful. > Northern tools isn't any better. > For another project I needed 100 amps for a short time. I purchased from Northern Tools one of their 4,000 amp jump packs. At room temp it would put out 40 amps for 3 seconds. If it was cold out probably only 20 or 25 amps.:https://www.northerntool.com/shop/tools/product_200676383_200676383 > > Their# is 216-464-8131 > > Their 4,000 amp unit can put out ~ 40 amps for 3 seconds at minimum of 10.9 volts, after 15 seconds down to ~35 amps and if it were cold probably 20 or 25 amps. > > The battery is only 8aH. (I didn't test capacity but question that as well). > > Ron P. Yeah; if you watched the entire video, he shows the 2,800mAH battery in the 12,000mAH case. Unfortunately, finding truth in marketing, especially while discussing starting batteries, is a fool's quest. Having said that, can you really fit the same power *and capacity* in the same space, with nimh batteries? The battery itself looks to be less than a third the volume of the case. -- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Sep 28, 2020
Hi Charlie I already have my headrest fabricated and wired. If I were to do it again I would do things differently. Energy density of LiFe batteries is better than that of NiMh. My NiMh pack fits like a glove. You can see the cutout in the aluminium plate: http://www.europaowners.org/main.php?g2_itemId=27332 My requirement if I were to switch from NiMh to something else is to have ability for battery and BMS to fit in existing space.: http://www.europaowners.org/main.php?g2_itemId=30608 Capacity of NiMh is less than the HF jump pack (according to Mfg. specs.), but size and weight is a lot less. NiMh pack will weigh under 2lbs. Original old cells were rated for 2.2aH which would accomplish the task, newest cells are rated for 5.0aH. Ron P. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=498589#498589 ________________________________________________________________________________
Date: Sep 28, 2020
On Mon, Sep 28, 2020 at 1:46 PM rparigoris wrote: > rparigor(at)hotmail.com> > > Hi Charlie I already have my headrest fabricated and wired. If I were to > do it again I would do things differently. Energy density of LiFe batteries > is better than that of NiMh. My NiMh pack fits like a glove. You can see > the cutout in the aluminium plate: > http://www.europaowners.org/main.php?g2_itemId=27332 > My requirement if I were to switch from NiMh to something else is to have > ability for battery and BMS to fit in existing space.: > http://www.europaowners.org/main.php?g2_itemId=30608 > Capacity of NiMh is less than the HF jump pack (according to Mfg. specs.), > but size and weight is a lot less. NiMh pack will weigh under 2lbs. > Original old cells were rated for 2.2aH which would accomplish the task, > newest cells are rated for 5.0aH. > Ron P. > > Looks nice! Virus-free. www.avast.com <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> ________________________________________________________________________________
Date: Sep 28, 2020
Tried with bigger "tubing" (Did not want to spend $ and time going to local hardware store to pick up 1/2" soft copper tubing and elbow.) Size of wire or tubing does not appear to influence bandwidth. So, my conclusion is unchanged: good compact vertically polarized antenna for single-frequency use, like ELT or 144-146MHz "band". Not usable as wideband antenna. 118-136MHz certainly is wideband. (18/127 = 14%). Would love to have someone else experiment with it and see if they somehow could get 1:3 SWR over 118-136MHz. 118-137MHz, 1:4 SWR at top. 100-137MHz, 1:4 SWR at top. You can definitely tune it to much better SWR at center frequency, but that was not the purpose here. Finn On 9/27/2020 9:24 PM, Robert L. Nuckolls, III wrote: >> I used a relatively thin wire as opposed to the recommended 1/4" >> to 1/2" tubing, hoping it would broaden the bandwidth (according to >> this remark:"The larger D is the higher efficiency is"). >> Bob tried to answer that for me but I'm still not sure if >> "efficiency" is related to bandwidth ("Q"). >> Perhaps I misunderstood that and should try 1/4" tubing? > > Or even a radiator fabricated from flat sheet? > > The larger the diameter, the greater the bandwidth. > Efficiency has to do with ohmic losses (how much > energy goes off in heat) and again, a larger surface > area of the radiator has lower resistance. Recall that > currents at these frequencies flow on the skin > of the conductor. At DC, there is a substantial > difference between say a 1" diameter rod and a 1" > thin wall tube. At 100 MHz there is virtually > no difference 'cause all the 'happening' is at > the surface. > >> With a whip antenna, the bigger the diameter, the broader the bandwidth. > Exactly . . . > >> I also tried a 3/32" brass tube originating at very rear of canopy >> (ground contact to turtle deck) extending forward and up along the >> canopy. Very odd frequency response and very SWR sensitive to a hand >> near the tip. > > Interesting observation . . . > >> At this point I'm looking at designing a streamline base for my 3/32" >> brass tubing in Solidworks and 3D printing it, mounting the antenna >> traditionally just behind the aft canopy skirt. Perhaps squeezing the >> tubing into a somewhat streamline and/or stepping down to 1/8" after >> the first 12" piece. > > Also interesting . . . let us know > what you discover. > > I am pleased that you've availed yourself > of this unusual piece of test equipment. You're > gaining knowledge and experience in a manner > that you will not forget . . . and will become > valuable information source for those who > follow. > > Bob . . . > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Sep 30, 2020
> > >Would love to have someone else experiment with it and see if they >somehow could get 1:3 SWR over 118-136MHz. It's been some years since I built one of these (back in the days before vna's) and a similar interval since I reviewed the literature. Poked around on the 'net and my archives a bit and I think I can confidently offer an explanation for the fruitlessness of your endeavors. The DDRR is a vertically polarized antenna wherein the very short vertical mast is the radiator. All that other stuff is a loading reactance for the antenna . . . or 'top hat' in some circles. Given that the radiation from an antenna is proportional to the current flowing in the radiator then it follows that this diminutive antenna must have some bodacious currents. Further, where the currents are high, losses need to be low to minimize energy lost to heating. My assertion about larger diameters improving bandwidth was incorrectly applied to this discussion. L/d ratio as it goes to bandwidth works only in the resonant radiating portions of the antenna . . . in this case, the mast. All that stuff setting on top has a rapidly diminishing current flow and besides, that part doesn't radiate. More surface area (diameter) helps this antenna only in the radiator . . . the mast supporting the top hat. Increasing surface area in the loading portion goes to increased Q which means narrower bandwidth. The governing triad is profoundly demonstrated in the magnetic loop antennas used on the HF ham bands. There are very useful loop antennas crafted for the 80M (3.5 to 4.0 Mhz) ham band where the radiator is built from 1-2" copper pipe with soldered joints in 45 degree elbows employed to make an 8-sided 'circle'. The Q of these antennas is very high which means hi currents at the feedpoint, high voltages at the tuning gap. The bandwidth of these antennas is very narrow. The operator has to tune the antenna in lockstep with his transceiver in order to 'cruise' that band for contacts. http://www.oh2gqc.com/wp-content/uploads/2017/09/20170911_160930.jpg Several sages in the design and fabrication of antennas have noted, "one can strive for (1) efficiency, (2) size and/or (3) bandwidth with one overpowering caveat. Optimizing any two qualities calls for degrading the third. So pick two goals and live with consequences for the third." Therefore, your experience with the DDRR was predictable. Yeah, you can get a really useful, small profile antenna but because SIZE was diminished, bandwidth suffers. I thank you for sharing the results of your experiment. Bob . . . ________________________________________________________________________________
Date: Sep 30, 2020
Subject: Z101 with Garmin GAD 27 voltage stabilizer
I have attached a power distribution block diagram (not a schematic) that I have been working on. I'm trying to puzzle through how best to take advantage of the voltage stabilizer built into the Garmin GAD 27. The GAD 27 is Garmin's electrical system controller. It's a combo box that bundles several functions, including the voltage stabilizer, trim mixer, flap controller, wigwag control, panel light dimmer, etc. I'm focused on how to best leverage the voltage stabilizer function to keep things running smoothly during engine start, and how to build in additional redundancy by using the dual diode-isolated power inputs available in many of the Garmin boxes by powering them both from the GAD 27 on the main bus, and from the Aux bus. I will admit that the failure modes in Z101 where this redundancy would be used should be exceedingly rare. But the dual power inputs are there, why not use them? I have also highlighted 3 devices that have dual power inputs that I'm not planning to use. One of those, the G5 SFD, has it's own attached backup battery. I appreciate any suggestions this group can provide. [image: image.png] --- David Carter david(at)carter.net ________________________________________________________________________________
Date: Sep 30, 2020
"mast" Coax to ring or ring to ground plane? So increasing ring to ground plane to a maybe 3/4" piece of tubing would increase bandwidth? But probably not significantly enough to say 1:3 SWR over the 188-136MHz band? Finn On 9/30/2020 5:04 PM, Robert L. Nuckolls, III wrote: >> >> >> Would love to have someone else experiment with it and see if they >> somehow could get 1:3 SWR over 118-136MHz. > > It's been some years since I built one of these > (back in the days before vna's) and a similar > interval since I reviewed the literature. > > Poked around on the 'net and my archives a bit > and I think I can confidently offer an explanation > for the fruitlessness of your endeavors. > > The DDRR is a vertically polarized antenna wherein > the very short vertical mast is the radiator. > All that other stuff is a loading reactance for > the antenna . . . or 'top hat' in some circles. > > Given that the radiation from an antenna is > proportional to the current flowing in the radiator > then it follows that this diminutive antenna > must have some bodacious currents. Further, where > the currents are high, losses need to be low > to minimize energy lost to heating. > > My assertion about larger diameters improving > bandwidth was incorrectly applied to this > discussion. L/d ratio as it goes to bandwidth > works only in the resonant radiating portions of the > antenna . . . in this case, the mast. All > that stuff setting on top has a rapidly > diminishing current flow and besides, that > part doesn't radiate. > > More surface area (diameter) helps this antenna > only in the radiator . . . the mast supporting > the top hat. Increasing surface area in the loading > portion goes to increased Q which means narrower > bandwidth. > > The governing triad is profoundly demonstrated > in the magnetic loop antennas used on the HF > ham bands. There are very useful loop antennas crafted > for the 80M (3.5 to 4.0 Mhz) ham band where > the radiator is built from 1-2" copper pipe with > soldered joints in 45 degree elbows employed > to make an 8-sided 'circle'. The Q of these > antennas is very high which means hi currents > at the feedpoint, high voltages at the tuning > gap. The bandwidth of these antennas is very > narrow. The operator has to tune the antenna > in lockstep with his transceiver in order to > 'cruise' that band for contacts. > > http://www.oh2gqc.com/wp-content/uploads/2017/09/20170911_160930.jpg > > Several sages in the design and fabrication > of antennas have noted, "one can strive for > (1) efficiency, (2) size and/or (3) bandwidth > with one overpowering caveat. Optimizing any two > qualities calls for degrading the third. So pick > two goals and live with consequences for the > third." > > Therefore, your experience with the DDRR was > predictable. Yeah, you can get a really useful, > small profile antenna but because SIZE was > diminished, bandwidth suffers. > > I thank you for sharing the results of your > experiment. > > Bob . . . > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Sep 30, 2020
Subject: Re: Z101 with Garmin GAD 27 voltage stabilizer
David, Wow! That's a lot of busses!=C2- I count 4?=C2- What airplane is this g oing in?=C2- IIRC, you have an electrically-dependent engine, right? The block diagram is not super useful for circuit analysis 'cuz it doesn't show how it's wired.=C2- In other words, one could come up with lots of d ifferent way to implement what's shown on this Block diagram.=C2- For mea ningful analysis it would be easier to have a view that is "closer to the m etal". Do you have an actual schematic?=C2- That might be more useful to the gro up to analyze. -Jeff Luckey carter.net> wrote: I have attached a power distribution block diagram (not a schematic) that I have been working=C2-on. I'm trying to puzzle through how best to take advantage of the voltage=C2-stabilizer built into the Garmin GAD 27.=C2 - The GAD 27 is Garmin's electrical system controller. It's a combo box that bundles several functions, including the voltage stabilizer, trim mixer, fl ap controller, wigwag control, panel light dimmer, etc.=C2-=C2- I'm focused on how to best leverage the voltage stabilizer function to keep things running smoothly during engine start, and how to build in additiona l redundancy by using the dual diode-isolated power inputs available in man y of the Garmin boxes by powering them both from the GAD 27 on the main bus , and from the Aux bus. I will admit that the failure modes in Z101 where t his redundancy would be used should be exceedingly rare. But the dual power inputs are there, why not use them? I have also highlighted 3 devices that have dual power inputs that I'm not planning to use. One of those, the G5 SFD, has it's own attached backup bat tery. I appreciate any suggestions this group can provide.=C2- --- David Carter david(at)carter.net iVBORw0KGgoAAAANSUhEUgAAA6YAAALOCAYAAAC6Ug5oAAAgAElEQVR4Aeydi6/mRnn/z994pP1D VmoJJYugpydcs2wScmmawKbdnBWBclEI0KQBml7OUlrUXdSm4iZUFrJKpQTR0Bb0izo/zYzHfmZs j8cz84xn7O9KZ1+/9lwefx4fez4ev+85EfgHAiAAAiAAAiAAAiAAAiAAAiAAAhsSONmwb3QNAiAA AiAAAiAAAiAAAiAAAiAAAgJiioMABEAABEAABEAABEAABEAABEBgUwIQ003xo3MQAAEQAAEQAAEQ AAEQAAEQAAGIKY4BEAABEAABEAABEAABEAABEACBTQlATDfFj85BAARAAARAAARAAARAAARAAAQg pjgGQAAEQAAEQAAEQAAEQAAEQAAENiUAMd0UPzoHARAAARAAARAAARAAARAAARCAmOIYAAEQAAEQ AAEQAAEQAAEQAAEQ2JQAxHRT/OgcBEAABEAABEAABEAABEAABEAAYopjAARAAARAAARAAARAAARA AARAYFMCENNN8aNzEAABEAABEAABEAABEAABEAABiCmOARAAARAAARAAARAAARAAARAAgU0JQEw3 xY/OQQAEQAAEQAAEQAAEQAAEQAAEIKY4BkAABEAABEAABEAABEAABEAABDYlADHdFD86BwEQAAEQ AAEQAAEQAAEQAAEQgJjiGAABEAABEAABEAABEAABEAABENiUQJNievfuXYGfdAZbHXmvvvqqwE86 g63yh35BAARAAARAgJvAr371K4z1Mox3ufOE9kEgJ4EmxVRKza1bt/CTwEAy3OofpDRdSrfM31bH DfoFARAAARA4DgEpptevX8dYL2GsJ/nhHwi0RKBZMcXAPP4wM2IY30Jaza37T4t++9rgt30OEAEI gAAIgAAvASOmvL3st/W33npLif1+9xB7tkcCENM9ZnVhn7YWm637X8BT/Wbwqz5FCBAEQAAEQCCR AMQ0DSDENI0fam9DAGK6DfdNe91abLbuf1P4GToHvwwQ0QQIgAAIgEDVBCCmaemBmKbxQ+1tCEBM t+G+aa9bi83W/W8KP0Pn4JcBIpoAARAAARComgDENC09ENM0fqi9DQGI6TbcN+11a7HZuv9N4Wfo HPwyQEQTIAACIAACVROAmKalB2Kaxg+1tyEAMd2G+6a9bi02W/e/KfwMnYNfBohoAgRAAARAoGoC ENO09EBM0/ih9jYEIKbbcN+0163FZuv+N4WfoXPwywARTYAACIAACFRNAGKalh6IaRo/1N6GwK7E 9MHtU3FycjL5c34nFfADcXHlRJzefpDakF3//oU4nYg5ez+k163FZuv+CYomF8GvybQhaBAAARAA gRUEIKYrYE0UhZhOQMGq6gnsT0yvXIjM6tglkVNMT8XFfXKsdLKaLtOkTbK4tdhs3T9B0eQi+DWZ NgQNAiAAAiCwggDEdAWsiaIQ0wkoWFU9AYjp1ilSEuqIqWCS4G5ftxabrfvfOuWp/YNfKkHUBwEQ AAEQqJ0AxDQtQxDTNH6ovQ2Bg4lpJ3xn5+Tx2XNxSdnfOR8eBT47F+cnJ0LPXBJZ7GTy/Iw8Onxm tSKsx4p9s7hTYuqsuzw7ESekfdU2aVNtN48Dk/V0t+jy1mKzdf+URYvL4Ndi1hAzCIAACIDAGgIQ 0zW0xmUhpmMmWFM/gf2JqRE0+trLmpbLkxMjo937XvouiYiKXi6nxZTIohJJI7BCCCW3pg8hXLG0 DouurvvZWPoYr1vfElPZV79/uq+lz6duLTZb92/xb/AN+DWYNIQMAiAAAiCwigDEdBWuUWGI6QgJ VjRAYH9iSiRtzJ/MenYbLelzhFIIKqqkrjOjaZebkENVfhBVK65RW3Kr7tcIphWj6ITZ7Gc3w0tF 1mp/4s3WYrN1/xNImloFfk2lC8GCAAiAAAhEEICYRkAjVSCmBAYWmyEAMSWPyVozkSqFMWJqZmXd bwd2P0faHSOTYmrLp1dMZTOdnJpZ1yVJ3Vpstu6/md/OmUDBbwYMVoMACIAACOyGAMQ0LZUQ0zR+ qL0NAYgpEVP3EVwzczn9KC8VTSqwEzOmvtzmEFPSvv5s68zsbFdua7GZ6l/Jd/+INdmhzItz/bjy v9St5GxmtMdl9fFAPxc8LhO/ZopffGuoCQIgAAIgAAL1EYCYpuUEYprGD7W3IQAxpWJqPbq79BnT eTF1Bdcri5Niaj/Ka9fvZmS7R3nVNvNYrzyGnM+cTh1WW4vNuH+5v+fi/Ix8Tncq8OR18/1QMR0x nehXlp+dmZY5UF+c5b9BMNFs0Koxv6BqKAQCIAACIAACzRDIK6bdDeOpG+DmqTM6lmqG0nygENN5 NthSL4H9iSn90iOyrGe3yOdEu5xQIVGrzAnq5ESc3r4gX4ZE6o5kUp/wqKhomTSP81KJdQ4G1ZYp R177L2SS5c0JVW4/FRe3x194ZB7jVdvp30R1upNvtxYbt3/F6uxSf9kU44XB1w89DpbFVAuu/T3M BrQ+Ts7vkOPFbMr06vLL1CyaAQEQAAEQAIFqCOQX01NxemV8U1ld/+V4McP4g44ltgYJMd06A+g/ hsCuxDQGgL+OFBCPVPorV7t1a7Gx+zciJ4QYCf/4G42pNOqLCZmVVDcV5vIV2A+5MTF7kZJlrBsH JNVqH3RMNFZTwr1o0TKh+2PzMy3jFQRAAARAAAT2Q4BDTNWf+bOu33JscCrUeojpfg4e7EmzBCCm NHVEKuRqJQ1Tj33QOg0uby02Vv8Ocyln9LObPpGT6Ift41lrKzUr+qGyaLXRvZHbaYy0jKrbX/TG NzaGeHUtt69h+/z+WPxo51gGARAAARAAgZ0Q4BDTizsX4pSO6+TY4MqFuLx96syY6pvZw9No5Ca4 Gk8MT7iZp+XU9dw8qWeNA8ZlZYrk9f707FycZpqtddOOGVOXCN63QABi6mRJiYE5sexwtlTu7tZi Q/sfSZ6cjSR3LQdR04lyRc56zLm/EDhJ7W4yWDLp6WfcB21P3129mHxcerxNXXhuP+gbyLE/lF/f MBZAAARAAARAYEcEWMT0vhZOKpNybOBe99X7fkyh6+gxhF1fP+k1SKt9jaf1xk+FqbJUkjPnDmKa GSiaK0IAYloEc12dbC02Q/96VnC4Izm+q2if5O0/o2OoqguI9+S+rh/3AmX60a+yreEiZG2jjwH3 NzfkPg3lc+zPwM/qHW9AAARAAARAYDcEeMRUjyNcyVy+7punubRs0hvoFLh1jXee1JLl5HZzk9wq SxvJtAwxzQQSzRQlADEtiruOzrYWm75/Z9bS0KEna7ost48uHurEr7/QYPZznyv7GfVhApOvsq3+ LirdYF9whi32I7k59qfnN3SCJRAAARAAARDYFQEuMe3/egERx9F137rRrMcYRiiF6OTU3ICee8rL amO48W7GEO54IHfyIKa5iaK9EgSOK6bdZwSGE43B7Tx6YVZPvKoTmTkx0VdykpqoFrdKneCGmbe4 RnStrcXG9C9PymP+nfx1s4yasdlv904lzZUtgJRPSD/0AjG6QJHGZDnzCBBZ3X1z8vQXL43a7mdQ 4/bH8LP7xzsQAAEQAAEQ2A8BNjFVf+mg+8Kj7kazfd2nYwvJ031PGeuxhxnL0Ou9+5gvrSWXrbLu xgzvIaYZIKKJ4gQOK6byJKQ+dD6SSPsE5Dtx2Ccy5tztTUwvPihOZz/DS0/0elk/7kv/VI4rdUZo HTnsZlSnPxM69GPlubtpQR/B1dmVfTrtd2n3Hgsqd6Ze4v5U8Blh5iMdzYMACIAACICA4BPTTgpP hhvN9jW8G1+Yp6O6mU8tn/oaPtyg1mXNe2ssMRLaYcwh02uXzZ9wiGl+pmiRn8BBxVSeHKQouCcY CVyfZCbvfjn5sE9kzsbcb/cmpq++mpvQYdrDjOlhUo0dBQEQAIHDEuAUU/U4b//00sTHhDoZVTfF zy5tiexvXneP5xqBlZky9fpJDz3O7L9Lg5SFmB720MaOewgcU0zliaM7aYxPDIOYKvE0j+iSk4nh GSSm1gnMzJqZFoa7dubkN2yxt52fnVtfokPLrV3eWmy27n8tr9rKg19tGUE8IAACIAACuQnkFdPc 0dXfHmZM688RIhwTOKSYShk1M6LjzwAMYipxjcV1gGiJqxFYcgfO/CkT84iH/w6d3a9dVm8bP1o6 xLJmaWux2br/NaxqLAt+NWYFMYEACIAACOQkADFNowkxTeOH2tsQOKCYyscqzJfpSOha+np5zPko L5mZ1emlfdHlLvmk/EiI1eMhNO74A2Zrsdm6/3hyddQEvzrygChAAARAAAT4CEBM09hCTNP4ofY2 BA4nptOznCf9o71GVM2M6kgQSZ6WHuWd64t+gL7/3IE146ql1cSgulSPBENMCf7DLkJMD5t67DgI gAAIHIYAxDQt1RDTNH6ovQ2Bg4npxCyl5K6kz3z+05bCFDFVj+P2H4B3EzwTS1ds1O+hZkydLwsw 0j7xOV+Xatx7tz9zLKxpzT5uQmuO8hxQEWIaAAlFQAAEQAAEmiYAMU1LH8Q0jR9qb0PgWGI6O+tI pYIuB3zGdFY8ZUK18PSPCXdfhGTeuzOuSlJMe0pEB0FS26xHkOMPGE6xeemll8SPfvQjb3DL/Tvc VGt6nTWL7O0ldONEu9aNitB2wo8b2iLElNLAMgiAAAiAAAhoArxiqq/9w1Nrw3grnL993Q+tF3Pd D22blgsV0zfeeINWwzIIbErgUGLqOxnox27lo7LOiUYJIn3Ud8iXK5bDFrLUyag5+blipYWz+8px Rzzpo8Dqb64620kvqxaXxXBVc1ZhKaZXr14Vzz777KygLvc/Jab+mwRWEGvezEiozIubqzXN+o41 2k5oOVpnmR8tjWUQAAEQAAEQaI8An5i2d0M6JntLYiqF9OzsTFy7di2medQBARYChxJTFoINNsop NkZMpZzOCepy/1Ni6qwbCaWz3dxQUI8B++6ETlygaE5lO2YWW35V1u3T8Xv1iPFwQ4PeUDjpHz/W /ZgbFGbWXIvphbi4Ym5O+GLVgS3zozuAZRAAARAAARBojwCbmI7GD5pNzTekY7I3J6ZGSM04DWIa Qxd1uAhATLnIVtwup9i4YmpOfHQGdbl/W+KMzFkzmKMLCxVTuUwEz5HLUWosiT0RRhp1OdqWlM9T cXrFtK1lVJcfxFTWs2dC7W30M82qHIlVvSciPIpVCLHMb6oW1oEACIAACIBAOwTYxLT7mJU1pqBY nDFD9A1pNU4Z33TW44N1N6RpeKHLrpi6QmrGZxDTUKIoV4IAxLQE5cr6CBGbv/7rvxYxP08++aSa KTUnPPdVCurt27eVXM1joZJpSmm562cgF8X0RPRlTRMBr1oU5YVkSj4vxfmVC3F5+1TLq4rBfFOy LZ/6wnOpexzFOgRilZuYkR1KDksyf08//XRUfmJyijpxvwvgVi+34bfpmEu/+93vxL179/ADBlUf A9/97nfFI488wvNLyn5D2hnHqP70eEGPM8wYo7uRvXBDOgaCEdM5ITXjs4cffnjVcRATC+qAQCgB iGkoqR2VWxJTOaB+5plnosSHT0yFUN9ybD5nO5I95yLQ3RE1s61rJVVdOLoLhbpbKh/JlReWqVd1 bHjElFyQ3MMIYlqvvEAs95mbj370o+LBgwfur+Kh3r/88svixo0b4uLiAj9gUO0x8Pzzz/OJKfmN 16KY+YZ05us+CTd4UYrpJz7xCfWdH0ZCp16lmIaeC+SNAnlTC/9AgIsAxJSLbMXthoipHJTH/Mv5 KK/9SO1aMSXRK4l1H9HV23vpJMXlovXojqxPZ0ql9F65EBdntE2PmI4keugsVkxlDvEPBEBgPQEp ZEcX029+85tCzqLgHwjUTIDvUd7pvc55Q9oaQzjdxVz3nSaC3poZU1lY/rUE+cTalJiueZRXCizE NAg/CkUSgJg64NTJxPzdTPnaf3mNU9D31iMi89VssZkvl76lpJjSz5aayJf6H/2ZHVVR8xnyoWdI +8+IqLuTnSiO+Muyw2MzJg71qsq638DrtK1mX93Plsr35jFe2ZKdP/vCY2+j+2eXc4TYCnR4s8xv KIslEAABmwDEVAiIqX1M4F2dBLjEtMgN6UpmTK9fv24ld0pQIaYWIrzZmADElCRASymVDfdLbEhh 3yIVI7rsq+OIjbdo4sYlsTGPMMZ0Y2ZMp4TUtLfUvxG3/jFcc6PA+QyGdRPhTH+RQD/L2omqaaMX WBOE9apF1JSVr307XTklkOYx4tGXG8lCjnya/vuY7T5MPBBTKxF4AwLsBCCmEFP2gwwdZCHAJab6 Cwi5b0jra34/liBjwZjrfgxQOmPq1qeCCjF16eD9lgQgpoS+e7JQm9TJxJZVUmV5kZyM/IUdsfEX Ttq6JIapYipPeL5/S/376mIbvpUXxwAIpBCAmEJMU44f1C1HgE1M1S7YN4tZbkir8Z/5Vt7hhrc7 1lQ32fub2Pn4+sTU9GIE1bxfesWjvEuEsD2VAMSUEJyaMSWb9ecOyaO97slFvlczYb2M0hPf8Cip NdPXn4yMmF6IczNDSGboaBypy0timCKmIbEt9R/SxpHLgN+Rs499TyUAMYWYph5DqF+GAK+YltmH LXsJEdO18UFM1xJD+bUEIKYWMS2H/SOdvTR2hazZU/kFOKfitJdHKaGdfPZiKgT9m5WqFedzB4Pc mr7N7Gz3noiwFWrCmyWxgZgmwC1QdSl/BUJAFyDQLAGIKcS02YP3YIFDTNMSDjFN44fa2xCAmM5x p49g9HLoyOfZpbg862RUCqcRWY+YDiLqdmxmTIc/YzBf1q277v2S2EBM1/EsXXopf6XjQX8g0BIB iCnEtKXj9cixQkzTsg8xTeOH2tsQgJguce8E1XyA3TyuKx/HlY/tuq+quVkxHcvn0P14G8R0oIOl gQDEdGCBJRBYSwBiCjFde8yg/DYEIKZp3CGmafxQexsCENOeO5kN7dfJBf05USOmQs6M0plSKaHq G2GHz5Baj+9SSZ38NlfTGcTUkOB4VZLff3aX5GqhM3Mjwi6mjwn9yLd59NouwfkOYspJF23vnQDE FGK692N8L/sHMU3LJMQ0jR9qb0MAYkq4a3mxRWP0hUidaA5/w7L7rKl5jFe2R2WULsttzmdMVfuq LsSUpCLr4sBYNzvK6UxvRmbNn3YxxdT67vFuumy2c79CTLkJo/09E4CYQkz3fHzvad+2EFM9Phh/ k+4iV/pxLlLYjCOmvvWXFGNZhJiyYEWjzAQgpg5g96TUf260L6cFclg/FkpLTLu/b0lPSnYfRoTH 7XBJz5LY7P4zpu7Ngj63ZqGbEb1yLs6vTP+ts34GXbVlcmjq874u5Y+3d7QOAm0TgJhCTNs+go8T fXExdSYO9ERCwBNWqt7J8D0jJkW0PbpstjO/QkyZAaN5FgIQUxasdTe6JDYQ00txeUfmcHyzwL7p 4MyOF0r7Uv4KhYFuQKBJAhBTiGmTB+4Bgy4upiPGzke5RtuF0DOip+L87HQkpvbkgh5P9De1J9rK vQpimpso2itBAGJagnJlfSyJzd7FVF0s6KPXs/mZE1M6QyovXAF3VGf7WL9hKX/rW0QNEDgOAYgp xPQ4R3vbe9qEmN65VJDVk3DWuMIdP7jv+XMDMeVnjB7yE4CY5mdafYtLYrNnMdWPUYeK5MSFZPTo LsS0+gMeAYIAIQAxhZiSwwGLFRPYWkz1eIHeiJ6HNSemdIZU3hR3v7NivsX0LRDTdIZooTwBiGl5 5pv3eFQxnZJSvc580YF7AZoTUyK2i59XzZ/upfzl7xEtgsB+CEBMIab7OZr3vSebimn3uVEqlj7a EFMfHWwDgXACENNwVrspuSQ2e5wx1QLqiudSSifEVP35IFdM17a71K9/+1L+/LWxFQSOTQBiCjE9 9m9AO3u/mZhOSmn3pYjdn51zZz7nxHQoNzWe4M0FZkx5+aJ1HgIQ0ySu+kSzfEfNf0JLCiGi8pLY 7E5M1UWGyGQws+kLCf1CA7oc3GxiwaX8JTaP6iCwawIQU4jprg/wHe3cJmIaOV4Yi6n+YiRXTJfH i/kSCDHNxxItlSMAMY1mraWF/hmY6aYcuVGPfp6IkicnN64lsdmbmCp57O5yynyZn+UcOLnrQdIb DWVnS2UIS/nrw8QCCIDAiADEFGI6OiiwokoCxcU0YXw2JabW361Xwlt2vAAxrfKwRlALBCCmC4Am N3cnr5Ozc3F+slYy52RnsieWlUtiszcxZYG4YaNL+dswNHQNAtUTgJhCTKs/SBGgIlBaTPVHfoab 1+Ym9jDrOZ+YSTEV5s/J6DaXb4bPtx+zBWIaQw11tiYAMY3JwP1LcXlfVtQzZ6tONht8WY67i0ti AzF1idX1fil/dUWLaECgLgIQU4hpXUckopkjUFpM5+JodT3EtNXMHTtuiGlS/teI6fDo78mZ/rtX SV0nVF4SG4hpAtwCVZfyVyAEdAECzRKAmEJMmz14DxY4xDQt4RDTNH6ovQ0BiGkS9zViajrqBHVD OV0SG4ipyVWdr0v5qzNqRAUCdRCAmEJM6zgSEcUSAYjpEiH/doipnw+21kkAYpqUl7GYWl+0c+VC PJhqf4MPwdMwlsQGYkpp1be8lL/6IkZEIFAPAYgpxLSeoxGR+AhATH10lrdBTJcZoUR9BCCmSTkZ i2lIc3Mfkg+pm6PMkthATHNQ5mtjKX98PaNlEGifAMQUYtr+UXyMPYCYpuUZYprGD7W3IQAxTeIe Iqbut/DqOiHf8pYUmqfykthATD3wKti0lL8KQkQIIFAtAYgpxLTagxOBWQQgphaO1W8gpquRoUIF BCCmSUkIEVPZgS5nvnocX370qvpbnEnoD1wZYnrg5GPXkwlATCGmyQcRGihCAGKahhlimsYPtbch ADHdhvumvS6JDWZMN03PYudL+VtsAAVA4MAEIKYQ0wMf/k3tOsQ0LV0Q0zR+qL0NAYjpNtw37XVJ bCCmm6ZnsfOl/C02gAIgcGACEFOI6YEP/6Z2HWKali6IaRo/1N6GAMR0G+6b9rokNhDTTdOz2PlS /hYbQAEQODABiCnE9MCHf1O7DjFNSxfENI0fam9DAGK6DfdNe10SG4jppulZ7Hwpf4sNoAAIHJgA xBRieuDDv6ldh5impQtimsYPtbchADHdhvumvS6JDcR00/Qsdr6Uv8UGUAAEDkwAYgoxPfDh39Su Q0zT0gUxTeOH2tsQgJhuw33TXpfEBmK6aXoWO1/K32IDKAACByYAMYWYHvjwb2rXIaZp6YKYpvFD 7W0IQEy34b5pr0tiAzHdND2LnS/lb7EBFACBAxOAmEJMD3z4N7XrENO0dEFM0/ih9jYEIKbbcN+0 1yWxgZhump7Fzpfyt9gACoDAgQlATCGmBz78m9p1iGlauiCmafxQexsCTYvp3bt3BX7WM1gSm1Ji auLA66sihsE2pwz0CgJtE4CYQkzbPoKPE70RU4zz1o/zDLPr169nPWAuLi7EvXv3sraJxkCAEmhW TF988UVR68+jjz4q5E+t8cm4pAjN/Tu6mD7zzDNC/sTIYsk6c/nDehAAgXkCEFOI6fzRgS01EZBi WvM46vnnnxfXrl2rOkbJL+c/iGlOmmhrikCTYjq1IzWt4xY77n1tPf5UPq+//rqQP/gHAiCwPwIQ U4jp/o5q7NEWBN5++23x2GOPbdH1Zn1CTDdDf5iOIaYMqW5d7FqPPzWlENNUgqgPAvUSgJhCTOs9 OhFZSwQgpi1lC7G2QgBiypCp1sWu9fhTUwoxTSWI+iBQLwGIKcS03qMTkbVEAGLaUrYQaysEIKYM mWpd7FqPPzWlENNUgqgPAvUSgJhCTOs9OhFZSwQgpi1lC7G2QgBiypCp1sWu9fhTUwoxTSWI+iBQ LwGIKcS03qMTkbVEAGLaUrYQaysEIKYMmWpd7FqPPzWlENNUgqgPAvUSgJhCTOs9OhFZSwQgpi1l C7G2QgBiypCp1sWu9fhTUwoxTSWI+iBQLwGIKcS03qMTkbVEAGLaUrYQaysEIKYMmWpd7FqPPzWl ENNUgqgPAvUSgJhCTOs9OhFZSwQgpi1lC7G2QgBiypCp1sWu9fhTUwoxTSWI+iBQLwGIKcS03qMT kbVEAGLaUrYQaysEIKYMmWpd7FqPf21Kb926JT772c/2P5/+9KeF/KHrZBn8AwEQaJ8AxBRi2v5R jD3YisC///u/C/Pzve99Tzz++OP9e7N+q9hK9HtxcSHu3btXoiv0cVACEFOGxLcudq3Hvzal9+/f F1evXvX+yDL4BwIg0D4BiCnEtP2jGHuwFYGlscJzzz23VWhF+oWYFsF86E4gpgzpb13sWo8/JqVy RnTugoPZ0hiiqAMCdRKAmEJM6zwyEVULBL785S/PjhXkGOLHP/5xC7sRHSPENBodKgYSgJgGglpT rHWxaz3+NbkyZX2zppgtNZTwCgLtE4CYQkzbP4qxB1sReOedd2bFdO+zpZI5xHSrI+84/UJMGXLd uti1Hn9sSqdmTTFbGksT9UCgTgIQU4hpnUcmomqFwNys6d5nS2V+IKatHKXtxgkxZchd62LXevyx KZ2aNcVsaSxN1AOBOglATCGmdR6ZiKoVAlOzpkeYLZX5gZi2cpS2GyfElCF3rYtd6/GnpJTOmmK2 NIUk6oJAnQQgphDTOo9MRNUSAXfW9AizpTI/ENOWjtI2Y4WYMuStdbFrPf6UlNJZU8yWppBEXRCo kwDEFGJa55GJqFoiQGdNjzJbKvMDMW3pKG0zVogpQ95aF7vW409NqZwpxWxpKkXUB4E6CUBMIaZ1 HpmIqjUCZtb0KLOlMj8Q09aO0vbihZgy5Kx1scsd/29+8xvx4osvNvMj737Kn5ZilrFy/vvVr34l 8JPGICQ/YJzG2PDzsYaYHktMzTGB1zy/W3Mcfb9za7bNtV/j+jfffFN89rOfbe7a+P77769JiVUW YmrhwBsGAhBTBqi5xY4hRG+TueOXYnp2doGfcEQAACAASURBVCbu3r2LHyYGki/nv4ceekhcv34d P5EMJL+Qf9/97nfBOJKxOT6/8Y1veFFDTI8lpvK6Y44NvPKcw0PPb95fzG4jrjU8OTLHvuQLMQ05 ElFmKwIQUwbyucWOIURvk7njN2Lq7RQbowmU4Jtz4BG9o41WlIOAUH5STF955ZVG93T7sCU/iOly Hr75zW+KN954Y7ngDkpIMcVHM/gSueb8FhJFqjiF9HHkMql8MWN65KOnzL5DTBk45xY7hhC9TeaO v4Q4eXdo5xtL8A0Vq52jjtq9NQM3iGkU4r4SxLRH4V2AmHrxYOMKAmvObyHNpopTSB9HLpPKF2J6 5KOnzL5DTBk45xY7hhC9TeaOv4Q4eXdo5xtL8IWYxh9EawZuENN4zrImxDSMH8Q0jBNKLRNYc35b bk2op0tkm/jHQwBiysMVreYjADHNx7JvKbfY9Q0XWsgdfwlxKoSmym5K8IWYxqd+zcANYhrPWdaE mIbxg5iGcUKpZQJrzm/LrUFMQxillIGYptBD3RIEIKYMlHOLHUOI3iZzx19CnLw7tPONJfhCTOMP ojUDN4hpPGdZE2Iaxg9iGsYJpZYJrDm/LbcGMQ1hlFIGYppCD3VLEICYMlDOLXYMIXqbzB1/CXHy 7tDON5bgCzGNP4jWDNwgpvGcZU2IaRg/iGkYJ5RaJrDm/LbcGsQ0hFFKGYhpCj3ULUEAYspAObfY MYTobTJ3/CXEybtDO99Ygi/ENP4gWjNwg5jGc5Y1IaZh/CCmYZxQapnAmvPbcmsQ0xBGKWUgpin0 ULcEAYgpA+XcYscQorfJ3PGXECe5Q5dnJ+Lk5FxcevcufeNsP3fOi/Tv7kEJvhBTl3r4+zUDN4hp ONepkhDTKSrjdRDTMROsiSOw5vwW0kOqONl9XIrzk5lxgbpen4iTKxfigV1p8p267p/Fjy5qGTek 8sW38k4eHliZkQDENCNM01RusTPtlnrNHX8JcRJCXoDOxfnZiTi/w0nK0w8R0we3T4MveKnRluAL MY3P0pqBG8Q0nrOsCTEN4wcxDeOEUssE1pzfllvLPWMqr9en4vTKeFygRbGUmIaNG8T9C3F6ciou 7oeQiisDMY3jhlrlCEBMGVjnFjuGEL1N5o6/hDgpETy7FNxC6O0HYuo9ro66cc3ADWKadpRATMP4 QUzDOKHUMoE157fl1njE9PzsVJxYs50PxMWVU6HWB86YhsQ+VyZ03AAxnSOI9UciADFlyHZusWMI 0dtk7vj5xVReZLo7olN3HIkwqh0nZUaP16iyc3csA/tRbcjHh8LvxnoTsrCRn68eLCyEgc0zBNYM 3CCmMxADV0NMw0BBTMM4odQygTXnt+XWeMT04o6ciSQf85FjgCsX4tJ9skmNDbprt7x+E5mlj/Lq 5fPuMWFZfm7MIPc4cNygnvoyffvaC6E4XwYzpvNssKUOAhBThjzkFjuGEL1N5o6fXZzUxWS46MiL xult8qkRj5hKEMMFRz5uM37kp4e1oh/umds+JiEEO18BMaW81y6vGbhBTNfStctDTG0ec+8gpnNk sH4tgTXnt5C2U8XJ7kM/yntxn8ihVMXbp2qMYF+n7TLu7OUwTjDfZzHIo9o2N/O6Ytzg9mnvS553 qXzxGdM8eUAr8wQgpvNsorfkFrvoQCIr5o6fW5zMRabfXSmi9CKxIKb686ndnUpyh7Rvr1tY0499 wXNbyvuem6+MVl7M8C+OwJqBG8Q0jrGpBTE1JPyvEFM/H2wNJ7Dm/BbSaqo42X0YMR1klM5geq/T atzgyGc3PqCSKvvztbNm3AAxtbOHd8ckADFlyHtusWMI0dtk7vh5xUnPcqrHZtW375lHYcjM56KY dhcW+qjPiNC6fnwXqlHTiSt4+ergIKbxSVozcIOYxnOWNSGmYfwgpmGcUGqZwJrz23JrTI/yyi8T MjesyQyme51WwmnGEVdOrS8iojJKl+U+ue0M+7lu3AAxHchh6bgEIKYMuc8tdgwhepvMHT+rOJmL jbNH1oVjSUzVhUp/cx/9TInV5Mp+5i9UVqtZ3rDy7SKEmManas3ADWIaz1nWhJiG8YOYhnFCqWUC a85vy60xiqn6DGf3hUfdzKd1ne7GAf034jrv6ZiCLst9stqhO7ly3AAxpfCwfFQCEFOGzOcWO4YQ vU3mjp9TnOQFwvo8qdkzKqPqAjPMoKqLSP9lBfpzJboNfXdz6s/NBPVD+py9UJn4Mr5y8jVhbiem 3R1nzyPWJsZaX9cM3CCmaVmEmIbxg5iGcUoppa8zU9cnfc2RT/lMXWtGfTqCNNq+8Yo157eQULke 5ZV9K6Ek3K3rtDNO0GXTHuVdO26AmIYcISizdwIQU4YM5xY7hhC9TeaOn02cvBdsLTRGWs0FSQ4G Tm9fqL9tZr4QYfx51OFipECF9kPEVF9g5GPFw5cyeaEnbGTjS2LaTEwl0zP57Yf8HMnuZl1cM3CD mKahh5iG8YOYhnFKKaWlRz6JcyHIV/GJ4doAMZ3iyymm6nFeci2xxJSIq75pYN+oVmOINZ8xjRk3 dN/gG3zTYgrgwrpUvvjyowXA2JxMAGKajHDcQG6xG/fAuyZ3/CXEiZdI3a2X4LuNmJpvSaSz2nXn Yio6iOkUFZ51ENMwrhDTME4ppZT0qJtqzo3O/mZboJimBFGg7przW0g4qeIU0seRy6TyhZge+egp s+8QUwbOucWOIURvk7njLyFO3h3a+cYSfDcRU3XHWc+Uune2ZUrpHWz5fijTPSpHZirUNnKnvOQh sWbghhnTtMxATMP4QUzDOKWU0mJ6qc5T5skd2Z48b53fsWfjzHo5U6Z/iMzSmbfuqZzzM1Nu6lHh lKjX111zfgtpPVWcQvo4cplUvhDTIx89ZfYdYsrAObfYMYTobTJ3/CXEybtDO99Ygu8WYmoGdjp9 ciBHBmteMZU1yCwrHdhtcCysGbhBTNMSBDEN4wcxDeOUUqo/f0mZ7G+SyfOYvNnmiKlVxrnpRs9f SkyJjKr39nkxJeaYumvObyHtp4pTSB9HLpPKF2J65KOnzL5DTBk45xY7hhC9TeaOv4Q4eXdo5xtL 8C0vplIs7QGXnGlwZx7otyirgWA/ABTWZ7lovdKHw5qBG8Q0LTsQ0zB+ENMwTimlejFVEtp9Rr4X UEdMrY66Jz7MF76NxJR83p5us9oo92bN+S0kqlRxCunjyGVS+UJMj3z0lNl3iCkD59xixxCit8nc 8ZcQJ+8O7XxjCb7FxbSbGRgebTOPrg2DsvlHeYeEqzJUVodNxZbWDNwgpmlpgZiG8YOYhnFKKTWI qRZN+Q28w801R0yVYJpznPOny6h8qvPicA4s8S2uSwzWnN+W2pLbU8UppI8jl0nlCzE98tFTZt8h pgycc4sdQ4jeJnPHnyRO1gXbXLjlqz2b5t2hhI2u/CQ0xVY1iW9gVKXFdBjA0QDtwZybm9GMafeY 2+kVe6aVtlhiec3ADWKalhGIaRg/iGkYp5RSg5h2n3+3vgjJfy6zzm0Q07A0bDxWcL/xNyzo8qUg puWZo8d1BCCm63gFlc4tdkGdZiyUO/4kcaIXZbKP6sJdYCbMGiCQ/seL9kBjvJ1vTRLfwLDKiqlk OX3jgeZDDfz6LzTqHn/rjwmSj5ljKHDXk4tBTJMRBjcAMQ1DBTEN45RSiopp/ydips5P5vPyZpsR LDzKuw7/zHm+1FghXEzJtWndHmYpDTHNghGNMBKAmDLAzS12DCF6m8wdf5I4zVxsSj3CREXIC839 Mgt/4axbk/gGRlJSTEcznzTGbhb04r5cqS/w/bdY3jZfMtKtNwM78429vcTSBvmXIab8jE0PEFND wv8KMfXzybHVElP6ZWyqcUdOjIzKb+W9ciEub58OX5hEr4F4lHc+NZQTLTW3npbJsezmZrZNJ/ez 5Xg2QEx5uKLVfAQgpvlY9i3lFru+4UILueNPEqe5i8rEeiWR5uv2iZQobOqi0T0KrB6p6v6G3Kgd +6LhiqnVRz+r183WdX3LzxLJf3pGr+vT3A2XG1Sf58J85b8qL+OjZXQTQf8n8Q3qQX/uJ7AoijkE IKYOEMa3ENMwuBDTME4otUxgzfltubWEz5iOruVdbxPrZ6/NssrcWGF0c8H59mRHTNeMFfoZdTWG oE8LdZ9PPjvXf0ZIjmsSxgpy9yCmIUchymxJAGLKQD+32DGE6G0yd/xJ4jRxUZHBq5M+ETl7lk2f zIdvYrVl01yUlBCO2rfLWmLqXBCsbe6MqXWR6sTVyLLqM9/nHpP4eo+EYWPJGdOh130srRm4SbF6 5ZVX9rHjG+wFxDQMOsQ0jBNKLRNYc35bbi1BnEbXct2bO1ZwH7n1XcetscIaMV0zVnDGDrpP8wVX 3diBjHVCGPrKQEx9dLCtBgIQU4Ys5BY7hhC9TeaOP0mcOonzfTur+ZuVZqZS7Ry9MFiSKLcS+Rxd zMg2I8BGKC1qjmzSNqfq0RhGfVoNr36TxDewN4hpIKiJYmsGbhDTCYArVkFMw2BBTMM4odQygTXn t+XWUsWUfkGiWTaSp3uXIjrctB6eYLqUm+l1WhWn4wH3hrd/xnTYV/9YYW2fQ7txSxDTOG6oVY4A xJSBdW6xYwjR22Tu+JPEaSRx+kJhXVg6KZyTV3s2Ve46udjMtG8k17qbqsqai53zlf60zYk7q9bF Z9SnNx2LG5P4LrauC0BMA0FNFFszcIOYTgBcsQpiGgYLYhrGCaWWCaw5vy23liqm9DHYqbFCJ4nm Iz/9q67nHStMXNet8QGV2uCxQveRH2tGlIxPJvoMYegrAzH10cG2GghATBmykFvsGEL0Npk7/iRx mpK47qRv5HFyxpTuIb1gqPXkxD9qn2xzZj6ti5CzzZLd0TbnTuyoTxrs+uUkvoHdQUwDQU0UWzNw g5hOAFyxCmIaBgtiGsYJpZYJrDm/LbeWU0zNbGj3fRJd56MZUxqUb6wwIYnWmIDUtdaPxgP2GMO6 aa1iodvHs7Q03JhliGkMNdQpSQBiykA7t9gxhOhtMnf8SeI0I3H25zDGdx3VhaG/C0lP9MOXEmmx 1dv6GVh1cRkuZPQCY7XZyfFJ/5iv3Yd9sXEe5ZnZJ29SPBtT+L777rtC/sHsX/7yl54e9GDBW8Cz UeeK3snuCpMLuad685vWDNw4xFTzNzP95nUiH82TFgJiGpZEiGkYp6lS6jow8Q3f9FoxVW+v69ac 30IYRIvTzHXVHSvY12YzHjCP+9rXcXPuNDfBrTGAeVLLjAHI9cwqtzRWsJ62cuOBmIYcMyizLwIQ U4Z85hY7hhC9TeaOP0Wc5v8sjL6A0G+y1QMGM/A2F5puVzvhlI/7nt6+EOcng3yai496FPjsQlxc GbZZgw1zgZGP/7hf6W/uiqr2H6hOrXZ7STZ3cR0xkPHRMt4M2RtT+EoxvXr1qvrxCWr8jKm8sJ6K 87NT+3M9chfIhXw+z/a+5n6nchTJPTSWNQM3NjF19lEfm87vyMwO2YzsgdtMlc1WQ0zD0ENMwziN S8njX3+jupEVU4ZeK+zfGVOC/3WLfpfObz//+c/FzZs31TXmvffeW4SQW0zN00z0+qrPf2asMHEt 7h7xdccK9rfnnosL+Wd9JsTUKhcwVrDK99/2L1FNiGnCWEG2GM23y5wcJ9y7d28xjygAArEEIKax 5Dz1coudpyuWTbnjTxEnlh1UdyidixFPR0VaTeFLxdQnqNFiai6iVEINFbpu5m63Kcr1WmIgtzRw o/tWSkzX3AiwGUFMab5aXYaYxmVO/S6cXeo/Bebc7IGY2kypkJprC6uY2t1neifPd/sZK0goENNM hwaaYSMAMWVAm1vsGEL0Npk7/hRx8gYaulFJzzA7pO+WDu9Dm6m1XArfKTE1gwg6gxorpnKwph+T nhCaXkz1Nv3lVcMgQA30zJdTmLvS3cz06dm5OO1mrh90UitnZfsvwCLlzV3nfpt5DE/13901J4PM 4H4DD4gaxdSWTbkj3ePmhvcko6fEU1fMLMPwVIH+fRpzVDPiV87FuapzKj76B+ZY6MBJ/oR7IE5v McyYevH0GyGmPYoVC/p3RM2UTtxI68V08rxCz3HD747sXJ0j6fmsOy+av3Mtz1v9R01kBdX38Hto z9i5v4cr+l1BghZ1z29TQmquKdWL6c7HCjJvEFN69GK5RgIQU4as5BY7hhC9TeaOP0WcvIGu2GjJ xs7ugEq+H/zgB9VnRaVMrvkxj1iZgcPUq2zvAx/4wArapqgcFA2iaWYbzFbfo7y2ONmPM+lckhsL ZqBmZLR7bx61s/u127L7cT+rrAd1ZlA46rffEf+CO3DzlWabMe2F0wxoCT+ppfSRNOfxMZuRZmLY Wjk0j7ObPHQDdKssEVE1IL+tH3v3MVmzDWIaRgtiGsbJKuVIi3v8qvNDd+zbvzP2Ocd9WmF0Xul+ b8x5R/+OmfMokWMZnIrJbHPPX06/qt2h7Khfa2fD35jzm09IzXVFlnn77be9P/JaI9vc6p/mYs6T A6+t4sndL8Q0N1G0l5sAxDQ3USFEbrFjCNHbZO74axBT7w43vlHyvXbtmvjhD3+4+ufy8rL/jKkZ PNDXGzduiB/84AfqLutqTHIgZCRFVnYGdpbUWAMsZ/Al68q2OqmhA0AVk1VXrnHkSRUy/9my6R1A GmGb69c0ufBqBm4LxdRmNjElQqg6cgapdmw+RjZbmYt+AC0boTlWfVABlnXNQI8u272nvIOYhtGD mIZxoqXkucI61sk5SZaj5yXrvEJ/J7oG6e8Nrac2u783o/Mbicr5PR73a37fZB1bVEf9kmbXLMrz 2x/8wR8Iea2g146p5evXr4vHHnvM+yPb2lJM1+x7i2Uhpi1m7VgxQ0wZ8p1b7BhC9DaZO36IqRd3 8sYUvnOP8hohNcGtf5RXD4KGx2fNHWgiMnQAZg2+tPyM62rJGQ2orLoyYluetACb/vXfnzUDTGsg 59bbs5g6g9Q4RnM57gbDNL/dgdQPyGXOXFk2B1vCK8Q0DB7ENIzTUGrunDQ8lkvPS9Z5Rf0emPMP ee1u2tF6qj/398Y5v6ny5gmIK6fitL/Z48yYuu04v/OjfoedXbVEb7zJm5g+Qa3+Ud5Ve95mYYhp m3k7UtQQU4Zs5xY7hhC9TeaOP0Wc3ECti7K5OMtXdZG37wi7da3BgrvRSMiozYmCOVc5g46YplP4 umLqCqmJZ7WYqv2is2W6JSsHdOBkcdB57B8BNUF0r6MBlVVXFqJi6h4T9nsrHmfgJlui20f9OnHN vaUDt7kyZn2xGVNrX20m7swKZWCz7T4fN/c4Ls2v2UG5rvuWSnNzwGzK8QoxDaMIMQ3j1Jfqjlv3 wXN6TqDL1u/MzLnQtE3rqXXu7w09v9FlWdh5P+63zIype32YE9SSYqpY0Ou5WQ54AsbiaBJFXkdt 0yeDSLmsi06uY9uGmMaSQ71SBCCmDKRzix1DiN4mc8efIk5uoKOLuFXAHWBbGy3JsLd0AmK+8KXb 6O/LbSHyfYaLTQpfI6ZzQmr2yh14mPVzr+rCPXWxpvtLB2B0vSOEsg+Vi7kBhVPXlid9TPSPFKs+ h1lbdwBiv9eCawQq9nioUkwVBzNoXcOISr/zJ39M3szvEc1vf6AMM09zNx76ohELENMwaBDTME6m lPzdN+cBs069kmOcnh/s84h7XVo4r5A2VR/0/KaWnVnauRlT6+aT+V01v/P2o8fWPq184zu/uYJa XEw9T2XQfLm7bOfP3qq2mXNct8nXll074R09DhKagZgmwEPVIgQgpgyYc4sdQ4jeJnPHnyJObqD+ C4A7ALBr+y42k+2qC8F41s9uNfFdhotNCl8ppnLwsPRvnZg68mI1TiTIGoB168nfl1U5MXe5yUBg lKsRQ6d/1U/3CN3ZpfVZMD3jILcNebb6JXI96tfar/k3voGbW4ttxrTnODxKaInhCkaGjxmo64Ga aXcY+FqfISY7qusPvMmm5EWIaRhCiGkYJ1VqdH6hdQfJtM4Pqg49r+hy/ccTfOcV67w4nhU1v3+y rfM7zrluoV/6O2/FS3dp5XLI+c0I6h7EdJKb4s5zTuvT4T0O+1KLCxDTRUQosDEBiClDAnKLHUOI 3iZzx58iTm6gkxeFvpArpoPsnJycCvXnRGbuoE7dBe2blQujiwIdEJh+L8S5EQDSj475Qlz0f2qD XMD6dnUbdOCgYiIDGCse8iYnX9KstbhOTK2qh38TMnAzkDjE1LRdy2vocR0TL8Q0jBrENIwTSi0T WHN+W24t/c+ZmD7UeYZch81682qPJUqNFcxM9cx4oLspcSG/Jb0bS/Rjgn6sMPERClnPs69mn+Ur xJTSwHKNBCCmDFnJLXYMIXqbzB1/TnFSFxMjf+a1PyEbQdSfBLIvTN0d676si4BemE7GJ3lyUdA1 x2Iq5ffivtzatdVJpYnZXGDUexMHadcesOs2TB03Wvo+J1/aLl2GmFIa65bXDNz2L6bhx/U6yro0 xDSMGsQ0jBNKLRNYc35bbi1dnEwf6npqxgj963BTmIppubFCJ6buk0FmPGCeXDE3pNX7blxBxgr0 W+rl/sp9MU+wmP2fe4WYzpHB+loIQEwZMpFb7BhC9DaZO/6c4kQvJuOd0INefYKmy7qkffEZ1+7X qAtA92iiuUDQi4IqOCGmpqzc3t35vHQ+H6mq0rZGy92FU60fLqJ9bBMLOflONK9WQUznyCyvXzNw 27WYqmPafFHZMreYEhDTMGoQ0zBOKLVMYM35bbm1zGJqhG+i42EsUXKs0IkpjYuOAaiIqphJbLSc +oI/cyNcjkXM8sSOOqsgpg4QvK2OAMSUISW5xY4hRG+TueMPFiczcO3ubk7NFg4Xk6ldICdx65tZ u7LypE8vCFNN0HVdPCoO66IgC43F1LpjqcprsRzHTC4kVrs6ftWfjJWKLo3LWQ7m69Rb8xZiuoaW XXbNwG3XYmpjYXkHMQ3DCjEN44RSywTWnN+WWwsVU339NY+7WtferpOlG9HDdZley7vKbGOFTkyt azsZDygxtW9IyzjV/lljBTJLKtevGNdATEOOQpTZkgDElIF+brFjCNHbZO74c4rTcDGZ2gUqpnRZ l52/UJELg9UsuWA5F4UpMbVEklxgVMz0wkHbosvmW027L+iZEnMrvO5NTr5T7ct1ENM5Msvr1wzc IKbLPH0lIKY+OsM2iOnAAktpBNac30J6ShUn08f89V6XGMYSJccKuWZMu6eyIv70Virfi4sLce/e PYMZryCQnQDENDtSIXKLHUOI3iZzx59TnIaLydQu2BcYdWHqv21Vb5ubMVXt9mV123Z9Lan9nVkl nuZr+7u2+/rd++6uqG57eNRGvTei6ojp8C2xQ/mpPaXrcvKl7dLl3GKq2ZpvcjUchx7p9p75sHl+ idwQ6Aspxl1fhnu/US/o/sKZO9W9b9cM3CCmXpSLGyGmi4hUAYhpGKfspbrrhp7ps2fGhnP/xHcc mEC6c9mqc6Kpy/S65vwWEkKqOJk+1Dl95nwvy9CxhD7/m3xwjhW6fsmjt9Z4oDs++vyq9911yR0r dE9t6W9nNnu9/JrKF2K6zBgl0ghATNP4TdbOLXaTnTCuzB1/TnGiF5MxAn1B6U/q5uJjHg0+8z/K S2VIDRyci5q1/Ux/q56e1ez6PTsXp+ZLFkhdHfP58I29vcBOfduv/6I43mchcvKdal+uyyqmrjzS i6/sjF6A6fJccP16ffOA/ukX80VU+pgYHx+6qlyvv7WZHjt9s4kLawZuENM02BDTMH4Q0zBOWUt1 UmmehLHFiZ6b6LIdgaxzKq8z5Ppilyj/bs35LSS6VHEyfdh8zdrh1R1LqPfsYwUjxDPjge7aeH42 cdN24lqoYzZCPeybbymVL8TURxfbchCAmOag6LSRW+yc5tnf5o6/hDixQ/F2MD+QkNXcC6C3qa78 GkEqwTermI4AkEemzePMZOAl+YXwUIO2K/Jr9smF2r2Yyws/aVuFYtZ1gwL5hVU5/60ZuEFM08hD TMP4QUzDOOUspUTJ+mwhaT3kPNV/4Y19viStbLK45vwWEmCqOIX0sWUZ73hg5TXIe0zN7GQqX4jp DFiszkYAYpoN5dBQbrEbWi6zlDv+EuJUhsxcLznFVA461j1SWoJvSTF1L9zu+8ksyIGdFE73wr70 3roRwDPgWzNwg5hOZjd4JcQ0DBXENIxTvlL+awT9FnfVp3vekivluu6mWtA5MV/w3pbWnN+8DXUb U8UppI8ty3hzN5X32WD1MWVm4GeLORtS+UJMHaB4m50AxDQ7UnzG1EVaQpzcPsu+9w86vBciGqi6 KIXNDtJqJfhyiqm660tmOSUvOkMacldY1lEXaPfCTgZzipmamSAzqv0shCYa0hdlH7K8ZuAGMQ0h Ol8GYjrPhm6BmFIaJZaNROibX6PPmC6ep/STN/15cXQeK7EP032sOb9Nt2CvTRUnu7X63nnHA+71 ay58lf+4P72VyhdiOpcUrM9FAGKaiyRpJ/eMI2m6yGLu+EuIUxEwlXZSgi+bmKoLsf3lR6vFVLZh HpFzL+zyPX101x3Q0boyv+72DDlfM3CDmKYBh5iG8YOYhnHKV0qLKf2YgRIUc25aOk+pG2j0hpoR 3XwRxra05vwW0keqOIX0ceQyqXwhpkc+esrsO8SUgXNusWMI0dtk7vhLiJN3h3a+sQRfFjFVEmlL qUyVe0eZvlfL1hdMyQEaefRZtUkGcN73ZrA4fNGEnsmwZ2xTD581AzeIaRptiGkYP4hpGKd8pfS5 pp/xlA2rm2Dduct7nhJCP1UyPk9ZN93yBbuqpTXnt5CGU8UppI8jl0nlCzE98tFTZt8hpgycc4sd Q4jeJnPHX0KcvDvUCZCRjhou5t54V24swTe7mKqcEKEk++w+Titl1BrQkbLWn1gwwqpeu7bdGVDZ r5mlcLd17ar+TRnaV+TymoEbxDQSo65lKAAAIABJREFUclcNYhrGD2IaxilnqdF5jJ5/6LLslJ6n xMzsqKozfQ7NGfdSW2vOb0ttye2p4hTSx3wZ+qi1vBGwPd/5WOO2pPKFmMZxR61wAhDTcFbBJXOL XXDHmQrmjr+EOM3u+oQA5RaP2b4LbSjBN6uYqgHVeKa0x0UHXHS5L+BZUPkmM6bdoE6LrT1r4Qpw 3+raPvuK0wtrBm4Q02mGoWshpmGkIKZhnLKWcs5N9EkQ75+1Uucjek4zUdnnM7O29Oua81tIbKni FNLHdBktpdZN0MzXgul+y65N5QsxLZuvI/YGMWXIem6xYwjR22Tu+EuI09wOTUuovADt505oCb45 xVTlxJrd1I+o0QEBLUPXz+W5X+8M/tR6NbjoHoPrZ0L1IGT6Gw31gK//3GrfeNzCmoEbxDSOsakF MTUk/K8QUz8ftq3q/OSei7reJs9T44820Nj0eXJKWmkp3uU157eQSFLFKaSPyTIzEjqa6Z6s3M7K VL4Q03Zy3WqkEFOGzOUWO4YQvU3mjr+EOM3ukBoILEsoFaH+UU/ZaHexOj+Tfx+zG1CYL9qR2+lA YyS79mNB0xI0G3nwhhJ8c4pp8I7tpOCagRvENC3pENMwfhDTME4otUxgzfltubUtH+WdmDGdCDh6 rEBvPJy4TwyVGSvI3YGYTiQVq6oiADFlSEdusWMI0dtk7vhLiJNvh9QjU0YqyZ8l6es4s2zWI1bm YmJktHuvJVNeTIj0ynb6GTnnMatOcC/u971mWyjBF2Ian641AzeIaTxnWRNiGsYPYhrGCaWWCaw5 vy23li5OIX3MlrFuNLvyaG5EDzPU4WMFPR7ob06r8YBpp9xYQe43xHQ2+9hQCQGIKUMicosdQ4je JnPHX0KcvDvUbyR3JXuBdP4+nCxLLxojodRtDGI687fEaBtd/1yPBJXgCzHtD6LVC2sGbhDT1Xit ChBTC8fsG4jpLBpsWElgzfktpOlUcQrpI6TMcEN7uPk8uobT67x3rNB9PISMO/oYaBvdylE/feH0 hVS+eJQ3PQdowU8AYurnE7U1t9hFBZFQKXf8fOJERPPE882tIxa6Hv1CnP4x3X5mtbsYeS82smE7 hv5zic6d1759M/M6iil+BR/fISaI6cBi7dKagRvEdC1duzzE1OYx9w5iOkcG69cSWHN+C2k7VZym +7Cv02u+t0AJqhLKTi77MUL30R7z1NTiWMGpbyS14FhBsknlCzGdPsKwNh8BiGk+ln1LucWub7jQ Qu74S4jTNBp9Iegfn+kL6fXm4uS9O7l4sekb7WZau8d/Ju6CkpJZF0vwhZjGp2zNwA1iGs9Z1oSY hvGDmIZxQqllAmvOb8utpYtTSB9TZdRnRyduHKv1nURmGyt0N7TVGKTgWEHuN8R0KvtYVxMBiClD NnKLHUOI3iZzx19CnOZ2SH9RwfAojiqn7lCSdeq9+byH+WPm3XufmE5uM+3a8mtmVo0Mz8Ubs74E X4hpTGZ0nTUDN4hpPGdZE2Iaxg9iGsYJpZYJrDm/LbeWLk4hfUyWUddz98kr+nTV+DOmenwRMFbo RHS4SU5vmpcbK8j9hphOZh8rKyIAMWVIRm6xYwjR22Tu+EuIk3eHRo/KDBJq6ukLjPNojtw4KZ/k SxGctm3xtB8f6h/zNZ1mei3BF2Ian6w1AzeIaTxnWRNiGsYPYhrGCaWWCaw5vy23li5OIX3Ml3Gu 2aNvzzU3riPGCp34Tn+sx+l3YuZ2PuZ1WyCm63ihdHkCEFMG5rnFjiFEb5O54y8hTt4d2vnGEnwh pvEH0ZqBG8Q0nrOsCTEN4wcxDeOEUssE1pzfllvbWkxDImy7DMS07fwdIXqIKUOWc4sdQ4jeJnPH X0KcvDu0840l+EJM4w+iNQM3iGk8Z1kTYhrGD2IaxgmllgmsOb8ttwYxDWGUUgZimkIPdUsQgJgy UM4tdgwhepvMHX8JcfLu0M43luALMY0/iNYM3CCm8ZxlTYhpGD+IaRgnlFomsOb8ttwaxDSEUUoZ iGkKPdQtQQBiykA5t9gxhOhtMnf8JcTJu0M731iCL8Q0/iBaM3CDmMZzljUhpmH8IKZhnFBqmcCa 89tyaxDTEEYpZSCmKfRQtwQBiCkD5dxixxCit8nc8ZcQJ+8O7XxjCb4Q0/iDaM3ADWIaz1nWhJiG 8YOYhnFCqWUCa85vy61BTEMYpZSBmKbQQ90SBCCmDJRzix1DiN4mc8dfQpy8O7TzjSX4QkzjD6I1 AzeIaTxnWRNiGsYPYhrGCaWWCaw5vy23BjENYZRSBmKaQg91SxCAmDJQzi12DCF6m8wdfwlx8u7Q zjeW4AsxjT+I1gzcIKbxnGVNiGkYP4hpGCeUWiaw5vy23BrENIRRShmIaQo91C1BAGLKQDm32DGE 6G0yd/wlxMm7QzvfWIIvxDT+IFozcIOYxnOWNSGmYfwgpmGcUGqZwJrz23JrENMQRillIKYp9FC3 BAGIKQPl3GLHEKK3ydzxG3G6deuWwA8Pg7OzM29OUzfKi9lbb72Fn0gGoWJvxBSs4441iGnYb/oR xRS/U3G/UyHcQs9vIUcnrjV8eZK5lHzlzYTYfxcXF+LevXux1VEPBBYJQEwXEa0vkFvs1keQViN3 /FJM7969ix9mBmlZ99e+fv26qPnnQx/6UNXxSXYh/6RY1cxZ3gD5yEc+UnWM3/jGN7yob9y4IR48 eOAts/eNRxPTmn+n3Ng++clPihbOZ27cuX5n3HbxPv+1F2Ka62hFOxwEIKYMVHOLHUOI3iZbj9+7 c9i4SwJ/9Ed/tMv9qm2n3njjDSGlpuV/EFOhcihziX/1EXj77bfFY489Vl9giAgEhBCYMcVhwE0A YspAuHWxaz1+hpSiycoJQEzLJAhiWoYzdy9HmjHlZpm7fYhpbqJoLycBiGlOmmhrigDEdIpK4rrW xa71+BPTh+oNEoCYlkkaxLQMZ+5eIKbchOPbh5jGs0NNfgIQU37GR+8BYspwBLQudq3Hz5BSNFk5 AYhpmQRBTMtw5u4FYspNOL59iGk8O9TkJwAx5Wd89B4gpgxHQOti13r8DClFk5UTgJiWSRDEtAxn 7l4gptyE49uHmMazQ01+AhBTfsZH7wFiynAEtC52rcfPkFI0WTkBiGmZBEFMy3Dm7gViyk04vn2I aTw71OQnADHlZ3z0HiCmDEdA62LXevwMKUWTlROAmJZJEMS0DGfuXiCm3ITj24eYxrNDTX4CEFN+ xkfvAWLKcAS0Lnatx8+QUjRZOQGIaZkEQUzLcObuBWLKTTi+fYhpPDvU5CcAMeVnfPQeIKYMR0Dr Ytd6/AwpRZOVE4CYlkkQxLQMZ+5eIKbchOPbh5jGs0NNfgIQU37GR+8BYspwBLQudq3Hz5BSNFk5 AYhpmQRBTMtw5u4FYspNOL59iGk8O9TkJwAx5Wd89B4gpgxHQOti13r8DClFk5UTgJiWSRDEtAxn 7l4gptyE49uHmMazQ01+AhBTfsZH7wFiynAEtC52rcfPkFI0WTkBiGmZBEFMy3Dm7gViyk04vn2I aTw71OQnADHlZ3z0HiCmDEdA62LXevwMKUWTlROAmJZJEMS0DGfuXiCm3ITj24eYxrNDTX4CEFN+ xkfvAWLKcAS0Lnatx8+QUjRZOQGIaZkEQUzLcObuBWLKTTi+fYhpPDvU5CcAMeVnfPQeIKYMR0Dr Ytd6/AwpRZOVE4CYlkkQxLQMZ+5eIKbchOPbh5jGs0NNfgIQU37GR+8BYspwBLQudq3Hz5BSNFk5 AYhpmQRBTMtw5u4FYspNOL59iGk8O9TkJwAx5Wd89B4gpgxHQOti13r8DClFk5UTgJiWSRDEtAxn 7l4gptyE49uHmMazQ01+AhBTfsZH7wFiynAEtC52rcfPkFI0WTkBiGmZBEFMy3Dm7gViyk04vn2I aTw71OQnADHlZ3z0HiCmDEdA62LXevwMKUWTlROAmJZJEMS0DGfuXiCm3ITj24eYxrNDTX4CEFN+ xkfvAWLKcAS0Lnatx8+QUjRZOQGIaZkEQUzLcObuBWLKTTi+fYhpPDvU5CcAMeVnfPQeIKYMR0Dr Ytd6/AwpRZOVE4CYlkkQxLQMZ+5eIKbchOPbh5jGs0NNfgIQU37GR+8BYspwBLQudq3Hz5BSNFk5 AYhpmQRBTMtw5u4FYspNOL59iGk8O9TkJwAx5Wd89B4gpgxHQOti13r8DClFk5UTaFFMHzx4IFr7 efnll8XXv/71yo8Gf3g3btxQ3P2l9r0VYlpvfiGm9eYGkQkBMcVRwE0AYspAuHWxaz1+hpSiycoJ tCamb775prh27ZqQktTSz8c+9jFx9+7dyo8Gf3gQUyEgpv5jZMutENMt6aPvJQIQ0yVC2J5KAGKa SnCifuti13r8EynBqp0TaFFMb968ufOs1Ll7EFOIaZ1Hpo4KYlpzdhAbxBTHADcBiCkD4dbFrvX4 GVKKJisnADGtPEEVhQcxhZhWdDiOQoGYjpBgRUUEIKYVJWOnoUBMGRLbuti1Hj9DStFk5QQgppUn qKLwIKYQ04oOx1EoENMREqyoiADEtKJk7DQUiClDYlsXu9bjZ0gpmqycAMS08gRVFN4RxfR3v/ud oD/yC6xef/11a53cjn/bE4CYbp8DRDBPAGI6zwZb8hCAmObhaLXSuti1Hr+VDLzZJYFnn31W0B8p G/S9XK7p36uvvmrFJ+Odivn999+vKexdxnJEMf3qV78qrl696v2Rxyj+lSfwve99zzo3PPHEE5Pn hv/93/8tHxx6BAGHAMTUAYK32QlATLMjFaJ1sWs9foaUosnKCHzuc5/zDrJv3bpVVcRyNkrO6vrk 4PLysqqY9xrMEcX017/+tffYe/jhh8Xvf//7vaa8+v365Cc/6c3Pt771rer3AQEegwDE9Bh53nIv IaYM9FsXu9bjZ0gpmqyMwE9/+lPvQO4//uM/KotYCDkjNSemH//4x6uLd68BHVFMZS6/9rWvzR5/ mC3d9miXs6Zz54aHHnpIYLZ02/yg94EAxHRggSUeAhBTBq6ti13r8TOkFE1WSODzn//85GCuttlS g843a4rZUkOJ//WoYjo3a4rZUv5jLqSHuVlTzJaG0EOZUgQgpqVIH7cfiClD7lsXu9bjZ0gpmqyQ wM9+9rNJMb1//36F0eqQpmZNMVtaNl1HFVNJeWrWFLOlZY+/ud6mZk0xWzpHC+u3IgAx3Yr8cfqF mDLkunWxaz1+hpSiyUoJuLOmtc6WGnzyc3zuZ00xW2rolHk9spi6s6aYLS1zzIX24s6aYrY0lBzK lSIAMS1F+rj9QEwZct+62LUeP0NK0WSlBNxZ05pnSw3C1157rZ/pxWypoVLu9chiKinTb+jFbGm5 4y6kJzpritnSEGIoU5oAxLQ08eP1BzFlyHnrYtd6/AwpRZMVEzCzprXPlhqEctZUzlTJLzvBbKmh Uu716GJqZk0xW1rumFvTk5k1xWzpGmooW4oAxLQU6eP2AzFlyH3rYtd6/AwpRZMVEzCzpi3MlhqM ctYUs6WGRtnXo4uppC1nTTFbWva4C+1NzppitjSUFsqVJgAxLU38eP1BTBly3rrYtR4/Q0rRZCYC //Zv/ya+8IUvZP955JFHsrfJEadp8/bt2+LJJ59kizlTunbZTAkxvXbtmqj5R86W1hyfiS3HASgF 3PzetfL66U9/uqmYc97kaCVHKXHmOK63agNiuhX54/QLMWXIdeti13r8DClFk5kISDGVj95+//vf xw8Tg5s3b2bK1j6bKSGmZsZL/v1J/MQxkHKa45+UJvmDcw7POdfwzZEr2cb169d3navWz88Q01xH OtqZIwAxnSOTsL51sWs9/oTUoSozASOmzN0ctnnJt/WBD3fySokp937suX0p87nFdM+8ttw3DjF9 6623ttwltr73cH6GmLIdHmi4IwAxZTgUWhe71uNnSCmazEQAYpoJ5Ewzexj4zOxattUQ02wo2RqC mLKhzd4wxDQc6R7OzxDT8HyjZBwBiGkcN2+t1sWu9fi9ycHGTQlATHnx72Hgw0tICIgpN+H09iGm 6QxLtQAxDSe9h/MzxDQ83ygZRwBiGsfNW6t1sWs9fm9ysHFTAhBTXvx7GPjwEoKYcvPN0T7ENAfF Mm1ATMM57+H8DDENzzdKxhGAmMZx89ZqXexaj9+bHGzclADElBf/HgY+vIQgptx8c7QPMc1BsUwb ENNwzns4P0NMw/ONknEEIKZx3Ly1Whe71uP3JgcbNyUAMeXFv4eBDy8hiCk33xztQ0xzUCzTBsQ0 nPMezs8Q0/B8o2QcAYhpHDdvrdbFrvX4vcnBxk0JQEx58e9h4MNLCGLKzTdH+xDTHBTLtAExDee8 h/MzxDQ83ygZRwBiGsfNW6t1sWs9fm9ysHFTAhBTXvx7GPjwEoKYcvPN0T7ENAfFMm1ATMM57+H8 DDENzzdKxhGAmMZx89ZqXexaj9+bHGzclADElBf/HgY+vIQgptx8c7QPMc1BsUwbENNwzns4P0NM w/ONknEEIKZx3Ly1Whe71uP3JgcbNyUAMeXFv4eBDy8hiCk33xztQ0xzUCzTBsQ0nPMezs8Q0/B8 o2QcAYhpHDdvrdbFrvX4vcnBxk0JQEx58e9h4MNLCGLKzTdH+xDTHBTLtAExDee8h/MzxDQ83ygZ RwBiGsfNW6t1sWs9fm9ysHFTAhBTXvx7GPjwEoKYcvPN0T7ENAfFMm1ATMM57+H8DDENzzdKxhGA mMZx89ZqXexaj9+bHGzclADElBf/HgY+vIQgptx8c7QPMc1BsUwbENNwzns4P0NMw/ONknEEIKZx 3Ly1Whe71uP3JgcbNyUAMeXFv4eBDy8hiCk33xztQ0xzUCzTBsQ0nPMezs8Q0/B8o2QcAYhpHDdv rdbFrvX4vcnBxk0JQEx58e9h4MNLCGLKzTdH+xDTHBTLtAExDee8h/MzxDQ83ygZRwBiGsfNW6t1 sWs9fm9ysHFTAhBTXvx7GPjwEoKYcvPN0T7ENAfFMm1ATMM57+H8DDENzzdKxhGAmMZx89ZqXexa j9+bHGzclADElBf/HgY+vIQgptx8c7QPMc1BsUwbENNwzns4P0NMw/ONknEEIKZx3Ly1Whe71uP3 JgcbNyUAMeXFv4eBDy8hiCk33xztQ0xzUCzTBsQ0nPMezs8Q0/B8o2QcAYhpHDdvrdbFrvX4vcnB xk0JQEx58e9h4MNLCGLKzTdH+xDTHBTLtAExDee8h/MzxDQ83ygZRwBiGsfNW6t1sWs9fm9ysHFT AhBTXvx7GPjwEoKYcvPN0T7ENAfFMm1ATMM57+H8DDENzzdKxhGAmMZx89ZqXexaj9+bHGzclADE lBf/HgY+vIQgptx8c7QPMc1BsUwbENNwzns4P0NMw/ONknEEIKZx3Ly1Whe71uP3JgcbNyUAMeXF v4eBDy8hiCk33xztQ0xzUCzTBsQ0nPMezs8Q0/B8o2QcAYhpHDdvrdbFrvX4vcnBxk0JlBDTB7dP xcnJifNzKi7ub7rrRTrfw8CHG9SNGzfEgwcPWLt56KGHWNunjZvj/fS2u08PxMUV/XtwfofWmFm+ fyFOT+r4PalVTA1rc34ZM59hu+PV24nppTi3zvN1HLu+VO/h/Awx9WUY23IQgJjmoOi00brYtR6/ kw68rYhAMTG9ciHoMF0PKM/FZQALVbavrwc/QQP7gLa5i+xh4MPNaJdieuVUnPbHbEdQiSbENJc4 XZ5JlvQcos8NWeQ0000BFeNZyFku329ZLr4mouvXr4u33nrLvJ15nWDvMLTP4zPNzK122portnb9 Hs7PENO1WUf5tQQgpmuJBZRvXexajz8gRSiyEYGtxFSsGGjYAxqI6UaHClu3uxTTs3Nx7s523jkX J2r9iWjlxopJenUzpnPnD8nYklWzBytf59pf2cxhxHSGl9x/c6PAPo+vBDnT/spWRsUhpiMkWAEC IwIQ0xGS9BWti13r8adnEC1wEdhKTMeDlOExR/1YXjcTogaa3WPAV54ST3WPQsoy/eBeDVq6MlQG 1Ppzca5mVk7E+XPn4sSaxZKSy/u42R4GPlzHnml3n2J6KeigXO6rfH9+Z3xjRclL/wgkOR7pYLxb Pj8jj8UXnImrTUzH5w9zNLmvmrd51Lc/Zwh9vjk9OxenPXsz+0rrmHzMnJ+67lQ8pp3uHGOtM7kK PVeFPOrt7mr3vpoZUxqfdR43T8/MM1W/OyY3Vz4qPmjYkvO19Xtj+Mo+ZV9XzsW5ulaY/NFghuU9 nJ8xYzrkE0s8BCCmDFxbF7vW42dIKZrMRKCYmPYDCyOQZhCod0QN4vrBRTdo7D6jZw9C3YG9857O mHSDQHPHXghZlgxU1ADGDJIyAXWa2cPAx9ml7G8/8YlPiDfffDN7u7TB4p8xlceydXzJY08e8xPH K7lZogbb5vdgJKYn4sTaRm7O0J1lWK5NTC1Os/trn0dUPvrffyNF5jzUvbf4DucK3/lJt2va0Tcg TJ7sOO3ca3Ht6o3OVbM7tbhhGzHthJCc54ebADpk+zwuhI+pls6BqfuEjd3WVJ7Dfjf2cH6GmC7+ SqBAIgGIaSLAqeqti13r8U/lBOvqIFBMTMngW+25Eshh4GfT0AM4I5T2IMQe3NmDf9mKHqSoQREd 2HcdyAGPaZcu2/3ne7eHgU8+GtMtvfbaa+KRRx4RH/3oR8WTTz4p7t69O10wYe0mYqoktBtc95Lq HL/WPnnkaHQs+9qxGs3ypkkxHTGjAkOXNSJLIkd1KUb7/GTVo8W6WXIjqa7A6htlnUB5+3MaXXi7 mZiSuBQTJanDOd4+j5PCanGBqcWHnONNM/3vlxFkIrWmzMTrHs7PENOJxGJVVgIQ06w4dWOti13r 8TOkFE1mIrCZmJpH6cw3lypRNbOp8otjBoG0BzT2gFxtI3fpzSN7Sj6twUwHrB/AyMHNMGjKhHPU zB4GPqOdYlrx3nvvCSmpjz76qHjxxRfFf/3Xf2XraRsxHQbQw00Q+/jVM0H2cd+LDD1+6bKi4rST jdR0Q7WJqX1OmI55LIJURumyrm8Jpst79vw0bodGQ9scx0xy6PZHG1m5XIOYmpDV/tNHm+kNylmm 9qyzasvio7mZc/3wSm4CBX7OeA/nZ4ipOdrwykUAYspAtnWxaz1+hpSiyUwE6hBTd3Bnv7cHdGQw Jxn0ojkBxBrMmO2y/qm4uHMx/tZUUyTj6x4GPhlxBDd169Yt8eyzzwaXXyq4jZiaxxXpFyHZxy8V F7kP1nt6/NJltbN2O0v7n7q9NjF1H+3s949yosuqAD2v0GVde5a9exPNeW/V6wOZaFOJGJ3JIzkc xeo0tOLtFmKqztHmMWgSKz1302XzZIt5esV9P2Jq8dG5cx8V7rsdce63jBb2cH6GmI7SihWZCUBM MwOVzbUudq3Hz5BSNJmJwGZiqgYPZsZSDzT6mSK1LWzG1HocTjJRAxj/43Fq0CNnWScGUpmw9s3s YeDT70zhheeee0585Stf8fb67rvvipdeekm8/fbb3nJbiak5Hocv3SIyYkTUzCJ1x25/XNLBOF1W e2q34935DBtDxVTm4ubNm+LnP//5bK+5xEn/HlPRc84jjkDqGVT7nDOIkeemQNdOnxfn/OTOzFIB swXLzpkqZ2b2Rvmdxbe4YQ3f559/XvzsZz/zthn052K6Y5fyNOdms45yMSI6x9TmZs7rJnfdDR/z e+P+HkFMvfnERhBYSwBiupZYQPnWxa71+ANShCIbESgmphOP21p3vLvBnnos60x/o2k/aOkGPebP QBixNAOefvDf9WGvHwYzPeKuL6v/fmPeBYhpPM/f/va34plnnhE/+clPZhuRYnr16lX14xPUzcTU lSP3y4/6Y/tEfWP05e3T4ZujqazQZUXDlpxZQJk2rBFTk485QV0jTkvha7kzj0IPN7OGepqTedxz +J1fmDE1Mmq+/dt3fpKfbJd5689xRJZNPSNRNN/9FzGNxWuIf/3SGr7Xrl1Tvzuf//znZwU1SExV mDZryWPgbfZR5oo+ctvlzjnnj8TUzYeR0VnmJAcehHs4P2PG1JNgbMpCAGKaBaPdSOti13r8djbw riYCJcS0pv1VsajBYdjAJTX2PQx8Uhmk1P/Sl74kXnnlldkmqJgaIZoS1JJiOhtswxtixNTkwxXU NeLUMLLNQl/D14ipydWUoIaL6Wa7HN3xHs7PENPo9KNiIAGIaSCoNcVaF7vW41+TK5QtS+CIYqpm Nwo8xiszuYeBT9kj0u7tX//1X8UXvvAFeyV5NyWmZpBNBRViSqBFLKaIqcmHEdQ14hQR6uGrrOHr iqnJFRVUiGndhxTEtO787CE6iClDFlsXu9bjZ0gpmsxE4Fhi2n0GzTxKlomhrxnJ91Of+pSQM3/4 Wc9ADpDPzs5m2clv7zWD6blXKagf+MAHfGnCtgUCUkz/8A//UHzkIx/x/sg/9zOXB7Ne/t1aKU/4 x0NAsv3MZz4z+ztDz0MPP/ywN1+f+9znxMc+9jHx1ltv8QS7cat7uHEIMd34IDpA9xBThiS3Lnat x8+QUjSZicCxxDQTtBXNSL5PPPGE+MEPfoCfCAbf+ta3vPz+9m//1juw/uQnPym+973vCcyYrjho J4pKMf3Qhz4kfve733l/5Oy2EVD39fHHH1d/o3bNjN5EKFi1QEDyfeGFF4LONz4x/fCHPyxef/11 gRnTBeAbb4aYbpyAA3QPMWVIcuti13r8DClFk5kIQEwzgZxpZg935Gd2rcjqb3/72+LP//zPZ/ua e5TXCKmpCDE1JOJeUx7lNUJqeoaYGhI8r2v4Tj3Ka4T0/fffVwFCTHnylKtViGkukmhnjgDEdI5M wvrWxa71+BNSh6rMBLKKqfkGyv6bEodvy1TfxKi2R3zpkPVNlqTN4M+Jjr+Bkxlr3zzEtEcRtSAH XW+88cZsXVdMXSE1FVPE1P56lKLWAAAgAElEQVTG1alvfjW97Pc1RkxdITV01oiTqTP3ar6he/hG XPv8MP5217mWnPWp5xxVf+IbwZ1uON6u4UvF1BVSE9t6MR1/O6/Jj/UtvaaDidfovE205Vu1h/Mz xNSXYWzLQQBimoOi00brYtd6/E468LYiAlnFlO7XlIROraN15pYnB3l68NP/aZi5ump9uJgqCTF/ 2sHbZtjGPQx8wvY0fyn5tzCffvpp8d577802bsR0TkhNxVgx1eJDb6asOe5M79OveY41HU/ogH86 kuW1a8R0TkhNL2vEydQJeZ2Smal1IW3pP0HliuWK3E+es6Z7jo5xujn1+V3JOOSfFNM5ITX1Y8XU PSb1DR76u2R6GL/mZjLuQa/Zw/kZYjqXXazPRQBimoskaad1sWs9fpIKLFZGoKiYxu77zCAvz8De Dip3m3sY+NiEyrz7v//7P/Hcc8+Jy8tLb4dSTOVnSJf+RYnpzHEnYm+wOEHmOdbqElNnFyfflhTT yQBCVs7kPk/O7AByS9gavvIzpOaRXTuq4V0uMRXu3/Aduhgt5WYy6qBbsYfzM8R0LrtYn4sAxDQX SdJO62LXevwkFVisjEBRMXUH9GrwZx69c2cnCKjQQeJse3TGtFs+Oxen/SPH3V18FV8XT6ZZ0z0M fEgmiiz+4he/EPLbXW/dupWtvxgxDZcQLYfjxxXXHmu6vGlHPf5OCKh4zDGrjk+7fD9DNfd7oNaf i/MzfYz35Ukfc4uhM6Zz9en6NeJE6y0tT8mMu27McKbVwHPObHu0frd8fnYq+tx2H0Ow6gd/NGEm 5m51br6cYqryY45psv923uzjvP+9kOdr6zwtfw8915EJbHs4P0NMJxKLVVkJQEyz4tSNtS52rcfP kFI0mYnAdmLqzPS40kr3jw7y+vW6/vAor92eHvCZx8Y6Qbj9QAhhBjn2thM6ULQGO32HUQt7GPhE 7fjKSnLm84c//KES0j/5kz8R3/nOd1a24C8eI6b24HiufXpsCaFnU83geN2xpo7ZfnA+1a45ZoUY YrOPe3dWyvo9UL9HcZ+R3YWYOueYgeFEbkPOOVZ7Xa5N/mj9jrs5x+jHhE+EuTHgjWMitKVVtYqp dSzKM/HtUyKW9vFOmcz/Xshj3/yudb97K8/dezg/Q0yXfiOwPZUAxDSV4ET91sWu9fgnUoJVlRDY TExHd7v1wMQM1iw8ZmBn7qybVzMIlIWtQaJcQQfsdNBDl3Uvo0HQysGNFavzZg8DH2eXsr+Vf2JE /q1S+e278s/DvPPOO9n7YBNTKiAqanp80WW9S+HHmj5+zY0XWs+GQ4/zhd+DUax2S753exBTydDw VPuqeAyyb+1/wDlnlBN6DqKs6bLqxM7ZqB0rkPVvahHTfnbYnK+pRHY3CK3zPbkmzDMZ/16YnI7y G4BuD+dniGlAolEkiQDENAnfdOXWxa71+KezgrU1ENhKTPXdc/MY7/BqBhkWm9HAztqq3th33+Uq OvijgkCXdTt0EDRuZ9zXmjV7GPis2d+Yso8++qh48EDOZvP9ixHToGOByogKnx5fdFnvm/dYU22Z 34VTcXrFiNS4nYEUPc7dWShZimwP+D0a2rWX2hdTzdAvS2SfF1lN5IQeC7Q+XVZdkJzIDMlHq+lN NhJGzGItYjpIZ8fe2kfNYJwPfaPAYjL7e0FnSWUfZPY0ENwezs8Q08Bko1g0AYhpNLr5iq2LXevx z2cGW7YmsJWYqhnO0JnJ0cBughodFKrNdPBHB5F0WbdDB0FBMjLR/dyqPQx85vYt1/obN25UKabT 38wqhLV+dGzS44sua1rzx5pb1n5P69nc6XGOGVNX8Cg3uTx548sGqt+N8jouRNtWW+k5iNany6qg nbNRO+OuVq2pT0xl+HqfB/76+B7k1d7FgYn9e2A+ijG0I9s9FRd3LsRp6PWEdLWH8zPElCQUiywE IKYMWFsXu9bjZ0gpmsxEYDMxpTM5cl/U4G343JW1e6OBnbW1e2MP9pRgnpjH9Ojghi7rqsMgaGrG aaqv8HV7GPiE721cyWrF1Mxm9ceR3D99/AwC5BxPSk7MzI2zzbTXzRzZN0GcdrtZon4ATqXH+nye fdwbATADfuv3IOj3aDqH7c+YjqXdYuPudggrKydO/mh9uqz6sXNGzz9uGDHv6xRTw9/8bozPtYpD J5cDE4er+3thfqfk48LWjGwYuT2cnyGmYblGqXgCENN4drM1Wxe71uOfTQw2bE5gOzEdZNQ8ztUP wl0qo4GdW6B7r8oNj0Je3DflqCDQZb19GATRmIzUmjbiXvcw8Inb8/BaNYup3AstMOa4mpp106Jh jmMjhUZi6XHtPda6Qbdq5+xy9IinHcdwfKo2T0hcc78Hob9HE6nbhZiOcjlI0miXA1lZOaEzdrQ+ XVYd2WKqPx9/Qr4IaBTNqhXViqm5qUNu9JhjV//uOMe0Ec2F3wvDb/i9C8e1h/MzxDQ83ygZRwBi GsfNW6t1sWs9fm9ysHFTAmxiuule1dP5HgY+3DRrF1Pu/W+h/RbEtAWOJWLcXkxL7CXpQ4n/ILVk y+LiHs7PENPFNKNAIgGIaSLAqeqti13r8U/lBOvqIAAx5c3DHgY+vISEgJhyE05vH2KazrBUC0cT UzVrbWZXV0Lew/kZYroy6Si+mgDEdDWy5Qqti13r8S9nCCW2IgAx5SW/h4EPLyGIKTffHO1DTHNQ LNPGccS0+/wpeTR4LeE9nJ8hpmuzjvJrCUBM1xILKN+62LUef0CKUGQjAhBTXvB7GPjwEoKYcvPN 0T7ENAfFMm0cR0zTee7h/AwxTT8O0IKfAMTUzydqa+ti13r8UUlDpSIEIKa8mPcw8OElBDHl5puj fYhpDopl2oCYhnPew/kZYhqeb5SMIwAxjePmrdW62LUevzc52LgpAYgpL/49DHx4CUFMufnmaB9i moNimTYgpuGc93B+hpiG5xsl4whATOO4eWu1Lnatx+9NDjZuSgBiyot/DwMfXkIQU26+OdqHmOag WKYNiGk45z2cnyGm4flGyTgCENM4bt5arYtd6/F7k4ONmxKAmPLi38PAh5cQxJSbb472IaY5KJZp A2IaznkP52eIaXi+UTKOAMQ0jpu3Vuti13r83uRg46YEIKa8+Pcw8OElBDHl5pujfYhpDopl2oCY hnPew/kZYhqeb5SMIwAxjePmrdW62LUevzc52LgpAYgpL/49DHx4CUFMufnmaB9imoNimTYgpuGc 93B+hpiG5xsl4whATOO4eWu1Lnatx+9NDjZuSgBiyot/DwMfXkIQU26+OdqHmOagWKYNiGk45z2c nyGm4flGyTgCENM4bt5arYtd6/F7k4ONmxKAmPLi38PAh5cQxJSbb472IaY5KJZpA2IaznkP52eI aXi+UTKOAMQ0jpu3Vuti13r83uRg46YEIKa8+Pcw8OElBDHl5pujfYhpDopl2oCYhnPew/kZYhqe b5SMIwAxjePmrdW62LUevzc52LgpAYgpL/49DHx4CUFMufnmaB9imoNimTYgpuGc93B+hpiG5xsl 4whATOO4eWu1Lnatx+9NDjZuSgBiyot/DwMfXkIQU26+OdqHmOagWKYNiGk45z2cnyGm4flGyTgC ENM4bt5arYtd6/F7k4ONmxKAmPLi38PAh5cQxJSbb472IaY5KJZpA2IaznkP52eIaXi+UTKOAMQ0 jpu3Vuti13r83uRg46YEIKa8+Pcw8OElBDHl5pujfYhpDopl2oCYhnPew/kZYhqeb5SMIwAxjePm rdW62LUevzc52LgpAYgpL/49DHx4CUFMufnmaB9imoNimTYgpuGc93B+hpiG5xsl4whATOO4eWu1 Lnatx+9NDjZuSgBiyot/DwMfXkIQU26+OdqHmOagWKYNiGk45z2cnyGm4flGyTgCENM4bt5arYtd 6/F7k4ONmxKAmPLi38PAh5cQxJSbb472IaY5KJZpA2IaznkP52eIaXi+UTKOAMQ0jpu3Vuti13r8 3uRg46YEIKa8+Pcw8OElBDHl5pujfYhpDopl2oCYhnPew/kZYhqeb5SMIwAxjePmrdW62LUevzc5 2LgpAYgpL/49DHx4CUFMufnmaB9imoNimTYgpuGc93B+hpiG5xsl4whATOO4eWu1Lnatx+9NDjZu SgBiyot/DwMfXkIQU26+OdqHmOagWKYNiGk45z2cnyGm4flGyTgCENM4bt5arYtd6/F7k4ONmxIw YvrSSy+JnD9f+MIXhPzJ2aZs6y/+4i/UT+52ueKVcd68eXPTHNfe+Y0bN8SDBw9Yw3zooYfEhz/8 YfwkMLh27VqWHElxyv37y3lu4IhVtsl5zpGMc/27fv06S764uK5tt/XzM8Q015GOduYIQEznyCSs b13sWo8/IXWoykxAiun3v//97D9f+9rXxGc+85ns7X79619naZcrXsOWOY1NN19CTOWMH37SGeQ4 0MzvRO7XF154Qcif3O1ytSeFSP5wtZ8jV7INrvhqajcXqy3agZhuQf1YfUJMGfLduti1Hj9DStFk 5QTefPNNlpnCH/3oR2rwmXv3ueLNHece2yshpnvkhn2yCbz++utC/rTyD9f1VjJVd5wQ07rzs4fo IKYMWWz9AtB6/AwpRZOVE+ASPYhp5YmPCA9iGgENVUYEIKYjJFhxAAIQ0wMkeeNdhJgyJKB1sWs9 foaUosnKCUBMK09QReFBTCtKRsOhQEwbTh5CjyYAMY1Gh4qBBCCmgaDWFGtd7FqPf02uUHYfBCCm +8hjib2AmJagvP8+IKb7zzH2cEwAYjpmgjV5CUBM8/JUrbUudq3Hz5BSNFk5AYhp5QmqKDyIaUXJ aDgUiGnDyUPo0QQgptHoUDGQAMQ0ENSaYq2LXevxr8kVyu6DAMR0H3kssRcQ0xKU998HxHT/OcYe jglATMdMsCYvAYhpXp6qtdbFrvX4GVKKJisnADGtPEEVhQcxrSgZDYcCMW04eQg9mgDENBodKgYS gJgGglpTrHWxaz3+NblC2X0QgJjuI48l9gJiWoLy/vuAmO4/x9jDMQGI6ZgJ1uQlADHNy1O11rrY tR4/Q0rRZOUEIKaVJ6ii8CCmFSWj4VAgpg0nD6FHE4CYRqNDxUACENNAUGuKtS52rce/Jlcouw8C ENN95LHEXkBMS1Defx8Q0/3nGHs4JgAxHTPBmrwEIKZ5earWWhe71uNnSCmarJwAxLTyBFUUHsS0 omQ0HArEtOHkIfRoAhDTaHSoGEgAYhoIak2x1sWu9fjX5Apl90EAYrqPPJbYC4hpCcr77wNiuv8c Yw/HBCCmYyZYk5cAxDQvT9Va62LXevwMKUWTlROAmFaeoIrCg5hWlIyGQ4GYNpw8hB5NAGIajQ4V AwlATANBrSnWuti1Hv+aXKHsPghATPeRxxJ7ATEtQXn/fUBM959j7OGYAMR0zARr8hKAmOblqVpr Xexaj58hpWiycgIQ08oTVFF4ENOKktFwKBDThpOH0KMJQEyj0aFiIAGIaSCoNcVaF7vW41+TK5Td BwGI6T7yWGIvIKYlKO+/D4jp/nOMPRwTgJiOmWBNXgIQ07w8VWuti13r8TOkFE1WTgBiWnmCKgoP YlpRMhoOBWLacPIQejQBiGk0OlQMJAAxDQS1pljrYtd6/GtyhbL7IAAx3UceS+wFxLQE5f33ATHd f46xh2MCENMxE6zJSwBimpenaq11sWs9foaUosnKCUBMK09QReFBTCtKRsOhQEwbTh5CjyYAMY1G h4qBBCCmgaDWFGtd7FqPf02uUHYfBCCm+8hjib2AmJagvP8+IKb7zzH2cEwAYjpmgjV5CUBM8/JU rbUudq3Hz5BSNFk5AYhp5QmqKDyIaUXJaDgUiGnDyUPo0QQgptHoUDGQAMQ0ENSaYq2LXevxr8kV yu6DAMR0H3kssRcQ0xKU998HxHT/OcYejglATMdMsCYvAYhpXp6qtdbFrvX4GVIa1eRvfvMbIU/i X/ziF/HDzODP/uzPxDPPPBOVJ1+lH/3oR+KFF17wFYnaxiXSUcEcrBLE9GAJZ9rdFsVUHvu4HtV9 PX7xxRfFu+++y3TUpjcLMU1niBb8BCCmfj5RW1sXu9bjj0oaQyUpph/+8IfFP/3TP+GnAINf/vKX 2bMIMc2OdPMGIaabp2AXAbQmphI6rkX1X4sff/xxce/evWp/RyCm1aZmN4FBTBlS2brYtR4/Q0qj mpRi+sgjj0TVRaU6CEBM68hDziggpjlpHretFsX0uNlqZ89rF7/a42sn04h0jgDEdI5MwvrWxa71 +BNSl7UqxDQrzk0ag5hugp21U4gpK97DNA4xPUyqi+5o7eJXe3xFk4XOWAhATBmwti52rcfPkNKo JiGmUdiqqsQppnI2HZ/3mv+8F9dnrSCmVf2KNRsMxLTZ1FUdeO3iV3t8VScXwQURgJgGYVpXqHWx az3+ddniKw0x5WNbqmUuMZXx4/Ne/s97SXF/8OBB9lRDTLMjPWSDENNDpp19p2sXv9rjY08QOmAn ADFlQNy62LUeP0NKo5qEmEZhq6oSp5hWtaMVBsMlkFztVogQITESgJgywj1w07WLX+3xHfjQ2c2u Q0wZUtm62LUeP0NKo5qEmEZhq6oSxHS7dHAJJFe725FCz1sQgJhuQX3/fdYufrXHt/8jZP97CDFl yHHrYtd6/AwpjWoSYhqFrapKENPt0sElkFztbkcKPW9BAGK6BfX991m7+NUe3/6PkP3vIcSUIcet i13r8TOkNKpJiGkUtqoqQUy3SweXQHK1ux0p9LwFAYjpFtT332ft4ld7fPs/Qva/hxBThhy3Lnat x8+Q0qgmIaZR2Dat9M1vflPQn1u3bomnnnrKWie3419eAu++++6IseT+0ksvWeulDKz5x9XumhhQ dh8Ebt68KejP448/LuQPXSeX8Q8EUgjULn61x5fCHnXrIAAxZchD62LXevwMKY1qEmIahW3TSu+8 8464evWq9+e1117bNMa9di4l1Mf+2rVr4v/9v/+3eve52l0dCCo0TeCnP/2p9/iUx64sg38gkEKg dvGrPb4U9qhbBwGIKUMeWhe71uNnSGlUkxDTKGybV/ryl788OwB9+OGHxe9///vNY9xjAG+//fYs dznoXztbahgttYsbDYYUXpcIfO5zn5s9RuU2/AOBVAK1i1/t8aXyR/3tCUBMGXLQuti1Hj9DSqOa hJhGYdu8km/WFBLDm5652c3Y2VITLVe7pn28HoOAb9YUs6XHOAa497J28as9Pu78oH1+AhBTBsat i13r8TOkNKpJiGkUtioqTc2aYraUPzVzs5uxs6Um4rl2caPBEMJrKIGpWVPMlobSQ7klArWLX+3x LfHF9voJQEwZctS62LUeP0NKo5qEmEZhq6LS1KwpJKZMatzZzdTZUhM1V7umfbweg8DUrClmS4+R +xJ7Wbv41R5fiRyhD14CEFMGvq2LXevxM6Q0qkmIaRS2airRWVPMlpZLizu7mTpbaiJ328WNBkMG r2sJ0FlTzJaupYfyPgK1i1/t8fnYYlsbBCCmDHlqXexaj58hpVFNQkyjsFVTic6aQmLKpsXMbuaa LTXR03bff/99sxqvILCKAJ01xWzpKnQovECgdvGrPb4FvNjcAAGIKUOSWhe71uNnSGlUkxDTKGxV VZKzppgtLZ8SM7uZa7bU7AFXu6Z9vB6HgJwpxWzpcfJdak9rF7/a4yuVJ/TDRwBiysC2dbFrPX6G lEY1eVQx/Yd/+Aexlx/5u/D888/vZn9MXqIO6JlKps3cr0888YT4u7/7u+zsn3zySZZ2c+8/be9X v/rVDP3jrP7qV78qavq5efOmkD81xfSTn/zkOAfETve0dvGrPb6dHhaH2i2IKUO6Wxe71uNnSGlU k0cV04ceekh85StfwU+lDGR+cv67fv06cs2Ya8kXYirEs88+K/7+7/8ePzMMJB+Iac4z2zZt1S5+ tce3TdbQa04CENOcNLu2Whe71uNnSGlUk0cWU3x+L+qQKVKJQ0zfeuutIrEfsROIqc46xMt/9IOP n08rW2sXv9rjayXPiHOeAMR0nk30ltbFrvX4oxOXuSLENDNQNJeFAMQ0C8ZijUBMNWqIl/+QAx8/ n1a21i5+tcfXSp4R5zwBiOk8m+gtrYtd6/FHJy5zRYhpZqBoLgsBiGkWjMUagZhq1BAv/yEHPn4+ rWytXfxqj6+VPCPOeQIQ03k20VtaF7vW449OXOaKENPMQNFcFgIQ0ywYizUCMdWoIV7+Qw58/Hxa 2Vq7+NUeXyt5RpzzBCCm82yit7Qudq3HH524zBUhppmBorksBCCmWTAWawRiqlFDvPyHHPj4+bSy tXbxqz2+VvKMOOcJQEzn2URvaV3sWo8/OnGZK0JMMwNFc1kIQEyzYCzWCMRUo4Z4+Q858PHzaWVr 7eJXe3yt5BlxzhOAmM6zid7Suti1Hn904jJXhJhmBormshCAmGbBWKwRiKlGDfHyH3Lg4+fTytba xa/2+FrJM+KcJwAxnWcTvaV1sWs9/ujEZa4IMc0MFM1lIQAxzYKxWCMQU40a4uU/5MDHz6eVrbWL X+3xtZJnxDlPAGI6zyZ6S+ti13r80YnLXBFimhkomstCAGKaBWOxRiCmGjXEy3/IgY+fTytbaxe/ 2uNrJc+Ic54AxHSeTfSW1sWu9fijE5e5IsQ0M1A0l4UAxDQLxmKNQEw1aoiX/5ADHz+fVrbWLn61 x9dKnhHnPAGI6Tyb6C2ti13r8UcnLnNFiGlmoGguCwGIaRaMxRqBmGrUEC//IQc+fj6tbK1d/GqP r5U8I855AhDTeTbRW1oXu9bjj05c5ooQ08xA0VwWAhDTLBiLNQIx1aghXv5DDnz8fFrZWrv41R5f K3lGnPMEIKbzbKK3tC52rccfnbjMFSGmmYGiuSwEIKZZMBZrBGKqUUO8/Icc+Pj5tLK1dvGrPb5W 8ow45wlATOfZRG9pXexajz86cZkrQkwzA0VzWQhATLNgLNYIxFSjhnj5Dznw8fNpZWvt4ld7fK3k GXHOE4CYzrOJ3tK62LUef3TiMleEmGYGiuayEICYZsFYrBGIqUadW7wuz07EyYn7cyou7pPU3r8Q pyfOOrLZt/jg9qk4uXIhHvgKZdyWm0/G0NDUCgK1i1/t8a1AjaKVEoCYMiSmdbFrPX6GlEY1CTGN woZKzAQgpsyAMzcPMdVAc4uXEtOzSytbSiapiEJMLT54w0+gdvGrPT7+DKEHbgIQUwbCrYtd6/Ez pDSqSYhpFDZUYiYAMWUGnLl5iKkGWkJMZU9TwhqTUsyYxlBDndrFr/b4cAS1TwBiypDD1sWu9fgZ UhrVJMQ0ChsqMROAmDIDztw8xFQDLSWmllCOZkwvxTl5/Pf8Dk32A3FxxTwafCrOz5xHeVVbw3br kWHaTORybj6RYaBaIoHaxa/2+BLxo3oFBCCmDEloXexaj58hpVFNQkyjsKESMwGIKTPgzM1DTDXQ 3OI1OzN651ycnJwL9ZCvJaZaPE9vd58aVeWGz59aQis6ge0/Y6rf9yJL+8h0vOTmkyksNLOSQO3i V3t8K3GjeIUEIKYMSWld7FqPnyGlUU1CTKOwoRIzAYgpM+DMzUNMNdDc4rVaTC1JlTFRUaXLOl5L VKWI9pI61O1FVVdJ+j83n6RgUDmaQO3iV3t80eBRsRoCEFOGVLQudq3Hz5DSqCYhplHYUImZAMSU GXDm5iGmGmhu8ZoTU0soqYyOZjmpjDozojJkIqOqTfIIsPk24H72NcMxk5tPhpDQRASB2sWv9vgi kKNKZQQgpgwJaV3sWo+fIaVRTUJMo7ChEjMBiCkz4MzNQ0w10NziNS2mWjZPzLf1UjGlyyokKqZ0 WcdrCS6R1MyHR99cbj59w1goSqB28as9vqLJQmcsBCCmDFhbF7vW42dIaVSTENNpbGpAODF7cEL/ TMN01eW1o8HjcpWQEtMzHsPny0LaWFem+4yaGSD3lccD4H5T4MLuxVQdAyci52xUIFqWYhBTjTW3 eE2Jqf49J7/X1vnE+d1TM6hDWV23+2xq95jv8PiuM6PaHaN4lJflV6bpRmsXv9rjazr5CF4RgJgy HAiti13r8TOkNKpJiOk0tqkB4XTJiLXWQDKi/kwVa/ajK2MPRGcqxq6Wg96zc3FuvoSlb8ceHMew 3LuYyrycnp2LU+szfT3A5hYgpjplLGI6ukFmxLI7TEbnk+6GUVfPFUt60+38zPlcaSejHI/xymhz 82nuF2UnAdcufrXHt5PD4NC7ATFlSH/rYtd6/AwpjWoSYjqNLUamplsqt3ZKTMVo0JorHi2f53ds CdWt2+tiWO5bTKU4yFksZ4YqV2o2aAdiqqFDvPwHH/j4+bSytXbxqz2+VvKMOOcJQEzn2URvaV3s Wo8/OnGZK0JMp4Euy1QnX3LWq5/RsGcyRjMTZmaRymK3rP6eoGnHeTRWz3p2f1vQM8M2JabuOne/ 7O16n8xsSf8ZtilEKm69v3YbsvAgpmrbzH5NNWvW7VpMyWf53HyMbyQQeVXM6eO/Xb6c48UwLPkK MdW0IV7+ow58/Hxa2Vq7+NUeXyt5RpzzBCCm82yit7Qudq+88or4+te/Hr3/qKgJ/Od//qf44z/+ Y/H73//+UEik+Lz//vuz+0ylshc1KVi9BBiJMzLqSIL6bJezbVZMSbudfPSP31ntCDESGbIHlgQa GTR9duXc+lQq1bKzf30cpB+5aJc1M4Cm0CCmco3bpynle92zmEoe/WdLieArHur98JlA0f2tyT4P ZDvNnY9liW0QU00Z4uU/2sDHz6eVrbWLX+3xtZJnxDlPAGI6zyZ6S4tieufOHfHlL39ZPPPMM+Lj H/+4+pHLX/rSl4Tchn9hBO7fv6+YvfDCC+Kzn/2s+OAHPyj+9E//VHz+858X3/jGN8Svf/3rsIYa LhUkpr2kTe2oLV+yBOLpHX8AACAASURBVBUwuqxqU8EkcuGdIeva7CVGNuSKDAltUlRUv4PouHHR Omo56Mud5L4PbZp9H+K02bh9kpBnF/crplLizQ0Lufua1ZR4ajhkxrSjpfMkZ9DtHMzCLLABYqoh Q7z8Bxv4+Pm0srV28as9vlbyjDjnCUBM59lEb2lJTH/7298qkbp586a4vLxU4mTil4+iynVymxTU 9957L5rJESpKsZcS+pWvfEX84he/EPRR3h/84AdCntCl7H/729/eNQ5eMbXFTIGMElPdjjVjq2ZC p4WESuaQPDsWVxLdOoP0eMRH7Uv3aHE/MyvfG+Hy9znENr+0VzG1+RKG5hFtetNC4RmLqZlFHW4E zHMstQViqklDvPxHHPj4+bSytXbxqz2+VvKMOOcJQEzn2URvMWIX3UChinJ277HHHhNf+9rXrB6n 4pdlnnjiCSVcVmG8UQT+6q/+Sjz33HPi5z//eU+EiqlZeffuXfHUU0/tWk55xdSePVVco8RUtxMq IK5k6nz6JXG6jq6pJNYIkzk4pmZx1TYqUP4+SVOzi/sUU82lnx01e09llC6PuOoKOi+n4hQzpoZg Na9rxUvlsr+5495w0r9T9MbU1LlAt2FuClWDYjKQtXwmG8HKzQnULn61x7d5AhFAMgGIaTLCcQNT Yjcutf0aOXsnHzF1/83FL2dOZR38swnImdJHH3109FnSKTGVNd98803x8MMPN/eItJwxf+ONN+yd n3jHLaaCiqj5e4FmRpHKB11WcVLBE8Jup/tsp2nH2a9JyVRxDANePWNnBrFalMzfMVQDXPL4sipL 3uvuZHxDezSEoT7ElHLpl1WuDft+bf84r5YOnf9eQLrZ6V5myXE1mW/abMFlzJhq2GvEy82f/bvp f2x/SK08Xs7F+dmJ6I+RYWN1S2v4VBc8AuoJ1C5+tcfXg8RCswQgpgypmxM7hq6im5SPlj799NOT 9X3xyzr//M//PFnviCv/53/+R30e9x//8R9Huz8nprKg/IIpKfot/ZNievXqVXF2duYV1CAx7Wcy yCOXJ2YAaMuXZDSImSamZzJk3VNxcft8eNSVyihdVtUcMTVfNNTHMi2Fsqoe2NqxytkWe8Cq29ez MF1c/axoJ6p9X2OJcgfTek+7/3sJdth0cmUE2Koz82aPM6bu8UF3nUqJlcezC3FxpcuhK6nmhsfo 5gFtucwyxFRzThIv91wg893/bk7nUR0rZ5f6d3+h7HQLZdcm8SkbKnrzEKhd/GqPz4MWmxohADFl SJRP7Bi6i2pSnlxefvnlybq++OW39cq6+KcJ/PjHP1aPOE/x8ImpLP+Rj3xE/Pd///dU1SrXGTGV cuoT1CUxzb5zAYPM7H023OAexbThdCyGDjHViJLEyxFTI53z8PUNIHXjyanr1tE3RfRNDn1TSt50 ojep7JtQw0217sbafd2iXk/Kqpsl8zfL3DiS+LiN4f1mBGoXv9rj2yxx6DgbAYhpNpRDQz6xG0pt u/SpT31KvP3225NB+OKXdT7xiU9M1jviyu9+97uzf1pnSUzlQEKKbSv/XDGdE1RuMbUHld1MZAUz W63kEWLaSqZ0nBBTzSFFvJT0kVlPWw5PxrOnSkYHSZTl+0fAncNHt2UE0jwZYepqQe3rOjfRVF1y 7hrej5/ucLodvU3hM2oMKzYjULv41R7fZolDx9kIQEyzoRwakmInP7spv9G2xp/vfOc76jOOQ8T2 kk9MZckPfehD4m/+5m+q3LfSvOWXR/3Lv/yLDbB7tySm5nHe0jHH9iePGyOjU6/mEV9uMTXfnNp/ cQkZcE4mAistAhBTC0f1byCmOkWx4qUf3zbiKNtyb2a57/Wj+71MyiqOUNKDZpBJvdZ+r9u22uor j/u1zm1EWPsqnoVYPp4msWkDArWLX+3xbZAydJmZAMQ0M1DZnJxZkn9e5atf/Wq1P76/TbokprJu zftWMra//Mu/nJ15XhJT+a3I8tuOS8ab0tcXv/hFr5hKWZVfBMUvpgy/tAdqEmLaVrIhpjpfMeI1 ltKZ3KvHZu1Zzv7GV/+5cPcz5botW0Tdz8M7YqpmYs1n1U/F6ZUTceIIqI7ZxDIT78TqGD4TzWDV xgRqF7/a49s4feg+AwGIaQaIe2tiSUz3tr9c+7Mkplz9crU79yivEdJ33nlHdQ0x5cpAnnYhpnk4 lmoFYqpJrxWvVYJHZ0TpMkmyK6Bmk7vefm+Lqb3NlVjzbcHTwmr6m3tdy2euHazflkDt4ld7fNtm D73nIAAxzUFxZ21ATPMk9AhiKmdIjZAaannFlH6JiJlp0K/2N+Ka3hNerVkTux09yLX7VzMqwY8R 2wNUu/Wy76oSU2sGaeA7/ehjCqcMx5Hn+EiJbKkuxFQTWiVeKlf08V1K2f38pn5vjjkpj2aZ1nL/ vJTZ5pdN+/delTXnDHPs9zOmtKwbo+lt/nUVn/lmsGVjArWLX+3xbZw+dJ+BAMQ0A8S9NQExzZPR PYvplJAaahximl1CTbD01SMeSkzNgLKvYw9o+9WTC3TQOVmg2Mr6xNQRiG7Anjfn0wP91bNqM3/n ljN5EFNNd414KQEkj+Cax3KHY0ofD2Z9/zitOvac47FP7vTv+/9n711jdUvKO7/9BWkkhJCQhWVZ E0W2JpI10ljKaBLNeBQl0mg0o+RDvKPzITPO5UOkKIqcqLEzYGGD2WxoMAg3uAFzaY7H9D4yvtDc urGDGdJg72NELExo28LYDcfH9OmG5tYNfaEvFT1V9dR66rputdaq9b7/I+3zrkvVU0/9n1pV9Vu1 3vWOAVPFMEq+XblQl9dO7YuXTP/g/YRNEa6dU25jjD4uEzaaU6B18Gvdv+YCCodGKwAwHS3Z4WcA mNaJ8SGCaQlIWbXjAVP7+6YRsLIS8hNgKtVw20kQWEKrNJjyy2Y6YHGexRuFGxdx4npHAKZGS4BX uU1Bn7I+eznbOvi17t9e4gw/8woATPPaHO0ZgGmd0B8amA5VZX0w9Vc/QsjwVk/cY3OmNvLc+dm5 OsmsiKVXTFNgmvMlhC27QuJWdezLTjSoyRefmHRhnYbGIpVuHyum3apVuCLlxyLQMYhvV//hYGpW Ue1jxfKmQwCmsu2cnPj+eo+CUj5pp3Nq0BbA1MgE8Co3F+hT1mcvZ1sHv9b920uc4WdeAYBpXpuj PQMwrRN6gGkNHX3Q40fvuol/AHzBClwKYlxeDzQYcCQUdv77dvi48c3Zsz9D4fY9X3w/tT0HUfKc 2XYgGoEqlz39sz0w7b5byvF19VfxC2JkLFI6yrydSmkw1fnlzQivTQRly3MBbHrwnDjn2kTn0OAt gKmRCuBVbjLQp6zPXs62Dn6t+7eXOMPPvAIA07w2R3sGYFon9ADTGjqmgcJZToAbQYIBgQDyKJOA Bg8m+JyEFFeIXRl1q5sCpBxc8hs1fbANfUkDig+4ErbktnBn1mZ7YNqtNpqK+XqEcdKa2BVIA5Zh /pQ8xiaDb/fp5+3iZW3I9iXB1CvCtDP3PUVFZbFdue1lGrwDMDVSAbzKTQb6lPXZy9nWwa91//YS Z/iZVwBgmtfmaM8ATOuEHmBaQ0cDFOlVMAuaWWDMwQjBo1yltH5KCAlclzCkT2lIYfiwifUxAa3s l4bXoDwvrfl5CAetwg8CpWzdAx+H7rYPpv4j0iUwpTobOGXdg5g4UcJ2FMKktqQu6HclOW7u09qU YKpjxGnjn/dwgEvpZjzGS14BTE0QAV6uMSc3oE9Slt0dbB38WvdvdwGHw5ECANNIEhwAmNZpAwDT GjqGQBHYFBAXnCFk0aCRA7sQeHI/B0F2IzDlY3KFdYAvciXXgWgEyew31d1fgY3rOP7IoYGpVEDH NAmCqXZkjnVxMI/uyn1pW7aPsO2E+7wyT29dzdrzjOd3AKZGm2ngRddSd7NCxym84RBKX7yOw8R8 cyx9nVJ5ufhnV/sn3syYpk+iPji0qQKtg1/r/m0aPBReRQGAaRUZD8sIwLROPAGmNXRMAYW0ayCu m/z5sBECpZ6YMrgEq55m0pqeYIZ2jAem7O4RzpIv8lyQz66ednUQq4Dsq6zyzO32wTQRQwfoVjur i46ZeJxax0nsd1Jl2lHQBiR8Ul4DD7ZNiBVTrx1pkDlRXTugnKY8Wn3N3RjpfCtvAUyNPlPAi+LH 11V4DXux5RBwLF174xO5T45z3G+Y/iQHptSOT9X5WeefLEH6LY+XtqfoU7KHc9so0Dr4te7fNlFD qTUVAJjWVPNAbAFM6wQSYFpDxwxQeKZ5cmgfrQzAhCeI5hFNfwJpJqcm3+nZuTrNTEjDSa0rPoLK nC8STHmVpfM3BCz+vUOeVLvyKmy0B6b8SKz49GIoNT1VF9fkW24tqLpVMD++nVy5dsT5u3yyTci3 7XrQ6gAm/D1KUeIZ1aez250ZtwUwNXqNBy+KeUF/HcNuNZXjXno7dxg5ynN65TSIs22vV87V+ZUM mFK/QTdXxM0O33aP735ivTden4QRHNpcgdbBr3X/Ng8gHJitAMB0toSHZwBgWiemANM6Oh6nFZqY dpPmmho0BaY1K9aYLQ06HmBPcxBganQbDV4EfSX9QzC9Tt8855tGBaDlMFL+JFxeqsvrlCi4GcX5 7JumzU0nA7HxqrrJGx8XRoLN0foE+bHbhgKtg1/r/rURRXgxRwGA6Rz1DjQvwLROYAGmdXQ8Siu8 orJA5QGmC4gamRwPFpEJewBgaoQYC170FELpiQP9lELqUfnsKqYfIcqvwTGbPgem/k2n3A2M3HHf i25vrD5dTmy1pEDr4Ne6fy3FEr5MUwBgOk23g84FMK0TXoBpHR2PzYqeMC+0WkpaAkwXblH8mG9p tW6ECwBTI9Y48CrfGNDQl7vGsqApgkZpOL7Z9BkwlXnJpG4v8Qqt9jEFzsINuTlOH5kT2y0p0Dr4 te5fS7GEL9MUAJhO0+2gcwFM64QXYFpHR1ipqwDAtK6eS1sDmBqFx4FXHkyLUEpFZUGTI022xWP2 2fQpMDXH4p8kSqzukl2AKYt+NJ+tg1/r/h1NQzngigJMDzi4U6sGMJ2qnJ8PYOrrgb02FACYthGH oV4ATI1SNcDUQGm8OunFIguaNhWviLsXbvFLuwSs6qQJMB2xOooVUy8qR7PTOvi17t/RNJQDrijA 9ICDO7VqANOpyvn5AKa+HthrQwGAaRtxGOoFwNQoNQ5ME79Jq4EzhMdEFPrANMySTR+DqYZNfgRY 2tHA6vuWTSvzie2x+ois2GxIgdbBr3X/GgolXJmoAMB0onCHnA1gWie6ANM6OsJKXQUApnX1XNoa wNQoPBq8CBgFBJrvbvPqZvcZvfk2BZp0LPdYbSq9djkE09wbeCmxfcTX+Wv2I98KjW20PgVbOLWd Aq2DX+v+bRc5lFxLAYBpLSUPyA7AtE4wAaZ1dISVugoATOvqubQ1gKlReDx4EQj2PLa7dPCm2s88 8lsyN16fkjWc20qB1sGvdf+2ihvKracAwLSelgdjCWBaJ5QA0zo6wkpdBQCmdfVc2hrA1Cg8Bbzo cdjST8YsHbup9qf4PUWfqf4h33IKtA5+rfu3XGRgeS0FAKZrKb2jcgCmdYIFMK2jI6zUVQBgWlfP pa0BTI3C08CLHon1v7u5dLxm26fV0txjwwXj0/QpGMSpTRRoHfxa92+ToKHQqgoATKvKeRjGAKZ1 4ggwraMjrNRVAGBaV8+lrQFMjcIAr3JLgz5lffZytnXwa92/vcQZfuYVAJjmtTnaMwDTOqEHmNbR EVbqKgAwravn0tYApkZhgFe5pUGfsj57Ods6+LXu317iDD/zCgBM89oc7RmAaZ3QA0zr6AgrdRUA mNbVc2lrAFOjMMCr3NKgT1mfvZxtHfxa928vcYafeQUApnltjvYMwLRO6AGmdXSElboKAEzr6rm0 NYCpURjgVW5p0Kesz17Otg5+rfu3lzjDz7wCANO8Nkd7BmBaJ/QA0zo6wkpdBQCmdfVc2hrA1CgM 8Cq3NOhT1mcvZ1sHv9b920uc4WdeAYBpXpujPQMwrRN6gGkdHWGlrgIA07p6Lm0NYGoUBniVWxr0 Keuzl7Otg1/r/u0lzvAzrwDANK/N0Z4BmNYJPcC0jo6wUlcBgGldPZe2BjA1CgO8yi0N+pT12cvZ 1sGvdf/2Emf4mVcAYJrX5mjPAEzrhB5gWkdHWKmrAMC0rp5LWwOYGoUBXuWWBn3K+uzlbOvg17p/ e4kz/MwrADDNa3O0ZwCmdUIPMK2jI6zUVQBgWlfPpa0BTI3CAK9yS4M+ZX32crZ18Gvdv73EGX7m FQCY5rU52jMA0zqhB5jW0RFW6ioAMK2r59LWAKZGYYBXuaVBn7I+eznbOvi17t9e4gw/8woATPPa HO0ZgGmd0ANM6+gIK3UVAJjW1XNpawBTozDAq9zSoE9Zn72cbR38WvdvL3GGn3kFAKZ5bY72DMC0 TugBpnV0hJW6CgBM6+q5tDWAqVEY4FVuadCnrM9ezrYOfq37t5c4w8+8AgDTvDZHewZgWif0ANM6 OsJKXQUApnX1XNoawNQoDPAqtzToU9ZnL2dbB7/W/dtLnOFnXgGAaV6boz0DMK0T+mMG0z/+4z9W +GtTgyXAFLFeLtYAU9MfE3jdc889s/9++7d/W9HfXFu17Mz1g/MDTOuM21tbaR38Wvdv6/ih/PkK AEzna3hwFgCmdUJ6rGD6wQ9+UB3S3yte8YqDqg/Fpua/vcX6Va96lbr77rt3FdOvfe1rNUO2S1u1 bn688Y1vVB/60Idm3zirZadWvcjOl7/85V3GFk53CrQOfq371ymJrb0qADDda+QW9BtgWkfcYwXT Ouq1Y+UXfuEX2nEGnsxW4Fd/9VfVrVu3ZtuBgX0q8O53v7sKwNWys08V4fVSCrQOfq37t1RcYHc9 BQCm62m9m5IApnVCBTCto+PWVgCmW0egbvkA07p67s1aLaCsZWdv+sHfZRVoHfxa92/Z6MD6GgoA TNdQeWdlAEzrBAxgWkfHra0ATLeOQN3yAaZ19dybtVpAWcvO3vSDv8sq0Dr4te7fstGB9TUUAJiu ofLOygCY1gkYwLSOjltbAZhuHYG65QNM6+q5N2u1gLKWnb3pB3+XVaB18Gvdv2WjA+trKAAwXUPl nZUBMK0TMIBpHR23tgIw3ToCdcsHmNbVc2/WagFlLTt70w/+LqtA6+DXun/LRgfW11AAYLqGyjsr A2BaJ2AA0zo6bm0FYLp1BOqWDzCtq+ferNUCylp29qYf/F1WgdbBr3X/lo0OrK+hAMB0DZV3VgbA tE7AAKZ1dNzaCsB06wjULR9gWlfPvVmrBZS17OxNP/i7rAKtg1/r/i0bHVhfQwGA6Roq76wMgGmd gAFM6+i4tRWA6dYRqFs+wLSunnuzVgsoa9nZm37wd1kFWge/1v1bNjqwvoYCANM1VN5ZGQDTOgED mNbRcWsrANOtI1C3fIBpXT33Zq0WUNayszf94O+yCrQOfq37t2x0YH0NBQCma6i8szIApnUCBjCt o+PWVgCmW0egbvkA07p67s1aLaCsZWdv+sHfZRVoHfxa92/Z6MD6GgoATNdQeWdlAEzrBAxgWkfH ra0ATLeOQN3yAaZ19dybtVpAWcvO3vSDv8sq0Dr4te7fstGB9TUUAJiuofLOygCY1gkYwLSOjltb AZhuHYG65QNM6+q5N2u1gLKWnb3pB3+XVaB18Gvdv2WjA+trKAAwXUPlnZUBMK0TMIBpHR23tgIw 3ToCdcsHmNbVc2/WagFlLTt70w/+LqtA6+DXun/LRgfW11AAYLqGyjsrA2BaJ2AA0zo6bm0FYLp1 BOqWDzCtq+ferNUCylp29qYf/F1WgdbBr3X/lo0OrK+hAMB0DZV3VgbAtE7AAKZ1dNzaCsB06wjU Kf+5555TN2/eVLfffrv67Gc/qx5//PE6hmFlVwrUAspadnYlHpxdXIHWwa91/xYPEApYXAGA6eIS 768AgGmdmAFM6+i4tRWA6dYRmFf+V77yFfWxj31Mvetd71K/8Ru/oV75yleqd7zjHXr/rrvuUtev X59XAHLvSoFaQFnLzq7Eg7OLK9A6+LXu3+IBQgGLKwAwXVzi/RUAMK0TM4BpHR23tgIw3ToC08u/ //771R133KE++tGPqocfflgbko/yfvzjH1fvfOc71Xvf+171zDPPTC8IOXejQC2grGVnN8LB0VUU aB38WvdvlSChkEUVAJguKu8+jQNM68QNYFpHx62tAEy3jsC08j/wgQ+oO++8U9GKqfwnwZSP3333 3Xo1lffxebgK1ALKWnYOV2nUbIoCrYNf6/5N0Rx52lIAYNpWPJrwBmBaJwwA0zo6bm0FYLp1BMaX /+lPf1q9/vWvj6CULKXAlI6///3vV/RoL/4dtgK1gLKWncNWG7Ubq0Dr4Ne6f2P1Rvr2FACYtheT zT0CmNYJAcC0jo5bWwGYbh2B8eXT90n/6I/+KJkxB6bf/OY3FcX6L/7iL5L5cPAwFKgFlLXsHIaq qEUtBVoHv9b9qxUH2NlOAYDpdto3WzLAtE5oAKZ1dNzaCsB06wiMK5++K/ryl79c0Vt4U/9yYEpp adX0c5/7XCobjh2IArWAspadA5EV1aikQOvg17p/lcIAMxsqADDdUPxWiwaY1okMwLSOjltbAZhu HYFx5X/1q19Vb3vb27KZSmBKjwB/+MMfzubFif0rUAsoa9nZv6KoQU0FWge/1v2rGQvY2kYBgOk2 ujddKsC0TngApnV03NrKWmD6ve99T/3u7/6uBiOCI/xN04B+CuaDH/xgttmUwPTBBx9Ur3nNa6D9 Abe/1772terLX/5ytn0MPQEwHaoU0o1RoHXwa92/MVojbZsKAEzbjMumXgFM68gPMK2j49ZW1gLT L3zhC/qnTS4vLxX+5mnwgx/8INtsSmD61FNPQfsjaH/ZxjHiBMB0hFhIOliB1sGvdf8GC42EzSoA MG02NNs5BjCtoz3AtI6OW1tZE0xp0Me/ZRUogemyJcP6ISkAMD2kaLZTl9bBr3X/2okkPJmqAMB0 qnIHnA9gWie4ANM6Om5tBWC6dQTqlg8wravnsVoDmB5r5Jetd+vg17p/y0YH1tdQAGC6hso7KwNg WidgANM6Om5tBWC6dQTqlg8wravnsVoDmB5r5Jetd+vg17p/y0YH1tdQAGC6hso7KwNgWidgANM6 Om5tBWC6dQTqlg8wravnsVoDmB5r5Jetd+vg17p/y0YH1tdQAGC6hso7KwNgOj1gd999t+K/q1ev 6p+t4H3+vHnz5vQCkHNxBThO/Ek/PcLb/FnDiXvuuceze+eddybbS42yjtXGo48+6mlM8aN4vve9 7/WOf+YznzlWiVDviQoATCcKh2yeAvTSO/lH48BHPvIR7xidb+UfwLSVSByuHwDTw43t5JoBTCdL p2g15rbbbsv+/dZv/dZ048i5igJ33XVXNn4U23e9611V/Pj2t79dLIfKorfz4t88BWiSV7omX/e6 180rALmPUgGA6VGGvXql+/on6rv+6q/+qnq5Uw0CTKcqh3xDFQCYDlXqiNIBTKcH+/Of/3xxEnzr 1q3pxpFzFQX+5m/+phjDL33pS9X8oFXTHDS9/vWvr1bOMRuiR+pf9rKXZXXGaukxt47pdQeYTtcO OTsF+vqn97znPV3iBrYApg0E4cBdAJgeeICnVA9gOkW1Lk9u1RSrpZ1GrW/lVk1rrZZy/Uurplgt ZZXmf+ZWJbBaOl/bY7UAMD3WyNevd65/am21lGoOMK0ff1j0FQCY+npgTykFMJ3XDP70T/80uTqD 1dJ5uq6Z+6//+q+TMay5Wsr1Sa2aYrWU1anzmVuVwGppHX2P0QrA9Bijvkydc/1Ta6ulVHuA6TJt AFY7BQCmnRbYsgoATOc3hXDVFKul8zVd20K4alp7tZTrk1o1xWopq1PvM1yVwGppPW2P0RLA9Bij vlydw/6pxdVSqj3AdLk2AMtGAYApWkKkAMA0kmT0gXDVFKuloyXcPEO4arrEailXUq6aYrWUVan7 Ga5KYLW0rr7HZg1gemwRX7a+Yf/U4mopKQAwXbYdwLpSAFO0gkgBgGkkyaQDvGqK1dJJ8jWRiVdN l1ot5UrKVVOslrIq9T95VQKrpfW1PTaLANNji/jy9eX+qdXVUlIAYLp8Ozj2EgCmx94CEvUHmCZE mXCIV02xWjpBvEay8KrpX/7lXy7uEa2aYrV0WZl5VQKrpcvqfAzWAabHEOV168j9U6urpaQGwHTd NnGMpQFMjzHqPXVuFUyp07733nt39ffmN795V/6SvnP//dmf/dnu6lxqVwSLpfO1zv3e7/2eoslu LXt9dubGmfJ/6lOfWs3fvvoMPf+2t71tdz7XiBVs1FVgCJg++uij6qtf/Sr+FtagbmTHWasd37vv vlvRjbPadmvZo3b/h3/4h1X9G6c4Uh+6AgDTQ4/whPq1DKZnZ2d6MkwTYvzV14D0nfuPwPT9738/ 4tNwG6XJT41/dA1+7GMfQ6wXjDUBN/61p8BQML399tvVr/3ar+FvIQ3e8IY3bNo4qC89pvj+yq/8 iqK/mnXeNIAovDkFAKbNhWR7h1oH0+0VOkwPaEW6Jpgepkr7rxXdOKgNpvtXpc0a8Ip0m94dt1dj wPS4lVqu9t/4xjdUC2BKfSr+TVOAbmLjHxSQCgBMpRrY1goATI+zIQBMjyPuANP9xBlg2m6sAKbb xwZgun0M5noAMJ2r4OHlB5geXkxn1whgOlvCXRoAmO4ybKOdBpiOlmyzDADTzaTvLRhg2ivR4gkA potLvHgBANPFJd5dAQDT3YVseYcBpstr3GIJANMWo1LfJ4BpfU2XsggwXUrZ+XYBpvM1nGsBYDpX we3zA0y3j0FrHgBMW4tIA/4ATBsIwgYuAEw3EH2DIgGmG4g+sUiA6UThVsgGMF1B5J4iAKY9Au3g NMB0B0Fa2UWAkPnFvgAAIABJREFU6cqC76E4gOkeolTfR4BpfU1btAgwbTEqaZ8ApmldWjgKMN0+ CgDT7WMw1wOA6VwFDy8/wPTwYjq7RgDT2RLu0gDAdJdhG+00wHS0ZJtlAJhuJn1vwQDTXokWTwAw XVzixQsAmC4u8e4KAJjuLmTLOwwwXV7jFksAmLYYlfo+AUzra7qURYDpUsrOt7stmF6q85MTdSL+ zq9n6nTzQp2enKjTa7eCBLENbe/KhQpT+hmDfCL9rWunnk/sX1y2b3HqHsB0qnLt5AOYthOLVjwB mLYSiYb8AJg2FIwVXQGYrij2hkUBTDcUf2TRANORgq2YfDMwTYFm6pjVgmDx9OxcnQqANKcMYPpA e0tdXDlRJ1FaFtac70DTpj+75AT+5/VzdXJyrjJn/bQT9gCmE0RrLAvAtLGANOAOwLSBILTmAsC0 tYis4w/AdB2dty4FYLp1BIaXDzAdrtXaKbcB0zwI6tXKCCgJPk/Vxc0UhKaOkYq542mF0+WOt5O2 Xj4KMC3rs4ezANM9RGldHwGm6+q9i9IAprsIU3UnAabVJW3SIMC0ybAknQKYJmVp4uAmYKpXRgk0 B0pAK5YWVi/PTtSJt7KZA9BwVbRcVg5Mc8fL1sadBZiO06vF1ADTFqOyrU8A0231b7J0gGmTYVnc KYDp4hI3UQDAtIkwDHICYDpIpk0SbQKmIx+NJRh1j91qqJWP1ebAVKkYYnMSGxuuDJcsb9slqbAB MK0g4sYmAKYbB6DB4gGmDQZla5cApltHYJvyAabb6L52qQDTtRWfXt4QMP3zP/9zdffdd08vBDkn KdAGmNpHe91LkORqKsGhBFGTtvtOaR4eh4GpLTt6fFgpNRKgJwVAKQUwnapcO/kApu3EohVPAKat RKIhPwCmDQVjRVcApiuKvWFRANMNxR9ZdAlMCUjf/va3q9tuuw1gOlLXGsk3AdPSo7zBOf0orQNW 8QZfB5I5MB3yKG8BSpVSumzvseEaisc2AKaxJns7AjDdW8SW9xdgurzGuysBYLq7kFVxuE0wNZMn /tkB79NNsGZUf6E7+3rFIZoUytWLGT7PzAownSngitlTYCqBlKAUYLpiQERRm4CpskCYgj4PTE26 bnXUOu6lyYCpTnOioryu7gUfdBpzPn681xmotgEwrSblZoYApptJ32zBANNmQ7OdYwDT7bTfsuSW wTQ/SZqp2JJgGkweNazWgOmZVQaYzhRwxewSTFNACjBdMRhBUduAqVLKgqMPfnwDzz7Kq9OkboRJ aEyBqYXOQj/V34+RXflIcSBcxV2AaUUxNzIFMN1I+IaLBZg2HJytXAOYbqX8tuUeJZguJHnyO1oL QfDYKgBMxyq2XXoC09/8zd90j+wyiIafb3vb29R9992HvxU1eN3rXqe+/OUvFxvHo48+qm6//fZi mmknLUDKpzLEjbBk/2MLMo/4ErQyzIrHfMmesBP7lskjv8vqrcrGFmoeAZjWVHMbWwDTbXRvuVSA acvR2cg3gOlGwm9c7G7B1E6Ezs9OlXvU15tcyUncqdLpeEVAwqLdPqefVbATPn9Vwr6tkieDXhl+ 8FITQ/+YXLkweb3zdlWE/ai5Ygww9WPV8h6B6bVr19TVq1f1I7shkPI+gen999+Pv5U16Gs7y4Fp X8nHcR5guv84A0z3H8PaNQCY1lb0AOwBTA8giBOq0DKYMqDJTwdrDHEMinafz/u/p2fv+GfBVPy8 ggbV7pE0304MllJyDZkMsPzJZeqEcf4OTM059t88upd6LE+WOHwbYDpcq61Tykd5v/KVr2QBFW/l 3TpS6fIBpmldah0FmNZScjs7ANPttG+1ZIBpq5HZ0C+A6Ybib1h0y2DqIC2lj10x7X503sCnyRMD oAeYiRXTSy7DsxvAIqWhvB5scsb07wB2j9BRutivEExztrtSpm0BTKfpNjTX97//fUV/Nf5JMGV7 KUAFmLI6bX0CTJeNB8B0WX3XsA4wXUPlfZUBMN1XvFbxFmC6iszNFXKYYCoh1Ug+DUwHfLdKRLSD THHQfqcrB8x+HgOuboU4A8DS+tBtgOlQpaal+5mf+RlVa7KVAlP2SgIqwJRVaesTYLpsPACmy+q7 hvVafeUavqKMdRQAmK6j865KAZjuKlzVnD1MMI1XJqeBaWLFtKC8D5mcUEJy7Fc6D+U1+cLvu7LV sZ8A07GKjUu/FpiyVwSoAFNWo61PgOmy8QCYLqvvGtYBpmuovK8yAKb7itcq3h4GmGZWuPh7iKso OaWQ7fw+TDC1P/buVhytvrw/+FHe0I59XJftBKFOQab/KG+Y3/ql26fZ7h5fHgfFgSvR7m7A1H5X uBaQR0JMeitpbCU8sjaYhuVjvx0FFgFT3Welf2dU9zuZPsmpIvs8d3CfGwDTfcZNeg0wlWpgmxQA mKIdRAocEph2k3uqppnwD53o+nARwkIkW6UDqXLG+T3VkZbB1D3Syi8S0p/2hUDed0G7OHexN2Bn bJyri2un3XdD5SRNbpOZyG7wVl75EwmB6LrteL7Sm367Fynp5Ba8PL/4xol3ru8nHILCe3b3AqYE 8qdn5+q0b6LdU9/86WWuNYBpXvFjO7MImGbHsYHjhOznEn3cnmIEMN1TtNK+AkzTuhzzUYDpMUc/ U/fDBdP0S2kyMqh2wHSc37n69B1vE0z7vB5/Xq9cMgCOz777HPsAU5pkE8in4LFWCNK2/et+fFkA 0/GaHWqOZcA0fNrCqieBsySoTAcwLSk16Bw9Rk99Kv5NUwBgOk23Q84FMD3k6E6s2+GCaWIiqgfp +HcrzWOX9vjZR9XFlS6NW4nzVrXEapg+fq749zDPP3yhTr3VtdKjmQkf7R1yV66cWFCMw8mFVyfh V097OFQwJdDoVsmNvt1+jygHeHoXYEpt2K6URqAYtnd5fdhrsouvXS1P3ohY5loDmB7gRTOxSkuB qX4jePAERnideGOYfOrAjR+m/ZsnNrpxQttxT3t0x7UE9vrSea6cq/Mrsm8NnihJXnMThcxkw4pp RpgdHQaY7ihYK7kKMF1J6D0Vc0hgagbdDiq7CStFhAZmMfC6AdtEyx/ow0lssC/zZibHDiz1+dzv UsrJQsZvWRa5qu1xPRJ1kpOSQkM8VDA1+nRanqwwYSrIvPmpPYApXXvuWg2vF6+9k5zBtSjO68l5 tv0vc639dyu9lXfzhgQHehVYDExtm3fXSHgNeGNEcHNGnhPXiq4MnRPXiz8GGjuuTG2nu079ay1I 26vUtAQA02m6tZQLYNpSNNrwBWDaRhya8uKQwNTBoFY4GKAD1c0d5g4Y/UE5mPwGAzj/LqUuLxzs 6Vcr6XuNFojkduBCPMlO+S0nFnTeK89OtifA18GCaSzyUR9pH0ypDXfXoXdtRe2dDgTXJl9vetWH b9ikQh7n47L4WjUrU8KXAdcaVkxTWh/nseXANPh6RzAm+GOX/c1lvqZkWq89hzEKxssorYRPs+2N t9EYGdqfvw8wna/h1hYApltHoL3yAabtxWRzjw4XTIMBWtmB1z62dHrlVJ3w4E3T3TP50hl/Emsg VqzCsY1rtwJQtOHUg7qZ4JJdbwD3Iu6X407JyYTcpgTRhMHYcKvFAyEVYOrUPuiN1sE0d225lZxM e/evKXMNuNWdZESXudYApkmxj/LgkmAqb5r4Y5UERiu7HDPkdngt6X0e107VKX2FhccPmU+bleUE Y457FFjc1FmgBQBMFxB1ZZMA05UF30FxANMdBGltF48GTMOBNtj3B/tgEktpxSNPXozCwV6f5DvK ZKc0WAflsGHpm9ym88nybEY70fAn7WzU/2wCTLW/sT46FnayM6Qufs16NIoSDz/gt5EB+Ww8PGDS 8eTJYPgptfBvpERv+R1QPCVpG0z5OgkqI9u43NbJ4mtGx+XKqTqVj+oHJlMrrTqJvL7kNp2MyhZG bWx/8l/9jKo12frUpz6l7r33XlEINvekwKJg6p4UyLR/BkoSTLZjuR2057A/8/aDtPx0genLMtft wsECmC4s8Arma/WVK7iKIlZSAGC6ktB7KuZwwdRO7HnA1gM0P+rHk/4OBLxB2U0COJLBZMBOSjU0 RQO4yeNWgnJAq5MFdvWxwG9Zlnts0dYjKpvscR3Z9/Tn5mBq6yVXrbWnciIlt9PVSB+NdEknG3tU thEd32JszSPdxZ9AydbPtAsPaK1e3rEBFWgaTHWdumuwq465BkxdAy20ZuIpBKFhOSbLXGs/dQow 7eJ23FvLgql82VBwzYhrgAEyufIZ9Iu6P+M+zPYvLp99wsj1N/a64/3wWvNsLdQMhoLpF7/4xYU8 UGraW3lN3xONdeSl1TV74zuoiRyDglPlXY6vW902N0U5nuXM9c4CTOtpeSiWAKaHEsmK9TgkMHWP s3Lny4Ou1othlDrkU3Vxnd6eKyAuGCD0AHDSvezBrJ50K1yuQw8GexcaOxC4dO6E3OABq7Nr3oB4 oW6JZOwLnTu9duHDJ/tt61wurzO6JZgytJ+fnXuPU5N3/sBrYjZp1bSr6iJb4cQsLoRiS+0rBUQ2 tY5dMMmMNBCWM+lFimizZTD1Y+27btqI0Ybbi742zi70W7N1m7Btv2sfwU0dz+Qy1xoe5fVEPuqd pcHUQQzfbBVqe9eIHPe8PqMbA7ubqnbsuXKhLuVvPpNtCTP2upPjixyXktAl/Kux2QemBKR33nmn evnLX16juKSN6WBqHpXu+ipj3mkoY5YsWaRPxL+QxZxKzVNsfEOfem3NSAAwnSHegWYFmB5oYOdU 6zDAdI4CS+VlMFnK/jy7m4Lp9UsD3t6kiepjJk7d5Cfcj+ucnJDJQVhvi5/zuW5sJPNF5fug7EDK AlHqJoLzkNLYyYbL507ajaj+dLwAssVzoXGz3zKYpj3e11GA6b7itaS3i4Ppks732jZ98ZoQE7qU A1MG0ttuu03RX6tgen7WvRTR1I00PVX6+EAwDTUZvC/HRJepf3x1SSttAEwrCXlAZgCmBxTMWlUB mNZSMrAjwCQ408TulmDqBIjALJ78ENR1oOpymo0gvwNAOQjr7cBGLt9QMOVHqguTCc9vC8eXgfve d8H4nPSdj7nP8RMJgKkTb5ENgOkisu7S6GGBaXBjVfeZ4gmjDSIUgmkIpK2DqXlKSzwhQ319aqXa jkP6xqd+EqrL48Y492TNuTrnJ8TkE2BhfFLjSnBM2qbs+uatGOP0eS5LHA+LKu0DTEvqHOc5gOlx xr1YawLTt7/97eq+++5r6u+ee+5Rr3zlK4u+t3rSdODbDuJ92hwCmIYDqauzHHDltk2QzVcNTGlS 100meCU4Wm0IAFm7l/DX1SvhX3cuvQUwTetS6yjAtJaS+7dzWGBqwYRB5ER8r3ujUDGY5oBUgunN mzfVEn/vfve79QvlxknAkO/feCXwo5uuIQDqffe4rn8zUo5d4TxD7+eAUY8rwVeGgphK21Q/zy8a q4RtSpu9YVwQB2BaEOdITwFMjzTwfdW+//77VWt/f/AHf7BbMO3Tu4XzLYNpN+D5g7KvW+GchDu5 rQ0U8iXATw7WctsbtH3HzIAuJnTuzrcY2HWWFJgWH9ctPeYbOGF3AaZpXVo8irfythiV4T4dGpgO r/k6KQlMX/3qV6s3velN+pFdBtHwkx7lpZvtS/y96lWvmgGm9oV49DNzdqyhm5WlsYS/2sFjohyD 5DZFoGgnGgcphxlPUrYje3qsmn9zAmC6zrWyp1IApnuK1pH7WgucjlzGbPVr6UvgM3mwSYAZDbY8 UMrBO1WRcGB2aeQgLLdtgmy+KmBqwDdaHU34kXyU1z2iFT346/8MhKtseQNgWtanpbMA05aiMd4X gOl4zcbk4BVTyvO5z31OvfnNb04CaqvfMb24ad/CSzco9XggXu4mb1paCDQ3NM1Lk3hMlGOX3CZN xoOpn6fXnufXNEidPFcY01CQdlcKAEx3Fa7jdnYYOJk7frwiFcHAEAkTcDQkWzlNaVUunVMPConH P7lu4ScPVNpaMGB0r/xPl0VHh+mbz89naoOpB2t9sQnOu4FZQqDcZqdz+RgK3STBti/7WJUcuF1Z bJM/xYSDD5nPRJsI/OjS+3ey9XFtV0J7l7q0tT8wJZ3oMXijV9juS7/nqmPirVTLx6lZJWM33Vf4 8eYc9EmxT+eRqeZtA0zn6bd17tpgGrVn93jnyJqm+kBhouvXZB8lt0XiDTclmLIbKUBtGkz1KqV9 4ZGNpz+WhLr7+12s/BfzkR6+HVbIfmbagMwjbffZM20z1b8G5Qa7ANNAEOwqgCkawW4U6Acn02E7 CMt0vL0VzsJBb85CAjmYmMlueVJLacybY9PppD2/2NQAoQcYD3L9PLTXr2+cJ3WkOpgyHFrASOvR eWLqz9+dsQOlbAtyu8tmBnEHMWKA1ek7exf0EwoJMO1+SkHkZd8zE8goVsW2Z9u383Had5b3Bqak kXfTRcQsnDiJU3qTzufymrSdpsl2RfE4o5eJ+DE1ec01mljHDt2YvA8wnSxdExlrgmnUVyT6lr7r wYmS6QP5fGdHjjNym1Nu+5kCU/ZIAmrbYGqBUny/U8fa3Qy1fRSPIXqM6Pq1LlY1wNTMTbjP9Nuc 9cP65fsoVn45AAM/AaYDhTqiZADTIwr23qvaC056sE1NIFureT+Y6k7/7LJwxzMzSchOODLphTS9 +oq0pc1ZYFoyjHNVFNgXmBbgrwjxJJVp80ngpNN8w0GDZ2r1k/Pnrx26TnkSVyU4gRGAaSDIznZr gqkEECdDMOYl07jEYiM7Tog0ejPf9sOUW+yXwJT9YUDl/dqfc37HVD/KSw4FfVkS+viG5Nml99ve MuZym8xGdmTluf9ju/zJAKzTmrmKeUrlVF1ci1941D3BMu1GKcBUBgXbpADAFO1gNwr0gVOxE07W Una6YmIqBgnq6E/PztUpddruDmZ/Pl2cN/jzAP8FdXGFV99EmZ5/PCHmyXOqw2d79NKE7l9Jg9I5 stCnb1dKeQtgWtZn67O7AlO6Fr2JEquXbv981nzSdZq6dmyqm5fqkr7jlXu5lJj0Z68d8s/1C37p NfYApjVU3M5GTTDVbTC5cm/qZ87bsYWvGT2WdeONu4nCYxOBhgUSd85biZXXWbftlcVAI68DD3rE NWivqfMz41P2ptHAkA0B04GmJiebBqaTizu4jADTgwvp7AoBTGdLCANrKdAHTnqw5LuJdrDMD3zd IKv954GaX0ZgJwD6DqQ3GRiWL7LpvUTHgG3WNzt48yOCGo71W/uk0oEf9lR4x1TmCO/KeucApqEc B7u/JzBNt/14hSEZLG9yXJoIp69H7k+M7Rzk5o4nPRp9EGA6WrKmMtQEU34CgEEydUPE7/+Dtilu uLqnBRgm7bXCY1JnR44zclvKHF4/wX6iXAnB0tLYbYDpWMXaSw8wbS8mW3sEMN06Aih/sAKDwFR8 T8OAmLhbK0uSICqP07YYSLsB2iYamE+n9tLKQT0YuIPyaULsDdzkD08gXFppzx30HvHpjtotUa/o HMA0JclBHtsPmJo2zpNlGYzoupQneVu3d3H9h/ucLrliSmWLvHYVybsudf7yteyKmLgBMJ0oXCPZ 6oKpqJQFSQ2pvDrqrXSKtHbTrHLar7rY/PLaktdUty3HGbnN9hPHovHKpNFleWMi25j+CTCdrl0r OQGmrUSiHT8Apu3EAp70KDAITD2ASwyaXEYJ0sS5boC2GcU5NuU+w3PeICx9KU1mzTl3V5wfk5LA rQuU9pwHxe+U6ImJp0+Xj7b69PVT5/fwKG9emxbO7B9MxUR3lKDpayb5KK++lrtHILvrMfwO+1Rf hjkOMB2mU6upFgNTrnAAmP54Zdomt93TK6fqhJ/+8cYmY0w+IdDZkdeM3DZ5unTskP1eoxi3XPn0 1E+i3C7n+C2A6XjNWssBMG0tItv7AzDdPgbwYKACveBEk0kPvAqTxtIAKQAzGngH5tNV8tLKQb0A plEdjDiRH96jwUJAr0xxPJdeJOnVV6QtbbYBpqS3v+KlfU7q698MiFfFZG1NHL3Jljxtt3W8eBIo ztNxuUohTq22uXswzbbxPglz/UF8PVKc4nYQp0tCbZ8bI84DTEeI1WDSemBKbS/RnwWr/d44IcYx LY3cT1xDMm+3LcctuV14sU6yj7XBSZQ7J2wA0znqtZEXYNpGHFryAmDaUjTgS1GBfnAKJo5yII4s +4OsN8EU+boBmg0U8ulBtwMP8+gUTyZkvsBPNp19XNB/vNgkl/aEAX4TXwBFuh7BMT/XYa2YkvYR WOi4ypdYkQKBjkEMQ420ju7mh8kbgybFN/dTP+Ycf384tL/G/n7A1Pz8QTKOLgZ5xcInBMz1GK54 Uv7weqR9vm59+3F/kE/r55y2BzCdplsrueqBKf+kiN9+wzbttU/d33E7Nn2Vv2J60r1YLOj3Ojuy fxTbYoyMtQ6uJ2lbb7NPcc6xRwCmYxVrLz3AtL2YbO0RwHTrCKD8wQr0gymZMoOiWdHqGwBlWrFC IgbdboCWbmby8Xd87GNMp9cuxARXDOoinTfpLg7apswuvW9Peqe3GcL4kSrxPaQorT0wTN9c7u74 9iumpJU/gdNxPLE/Yl6EmpKuJgYeiJLOgbZ6slj4qR8638Wx022trT2Bqf6+d0rfZAxN7GR8zMSd H8nN9Qd+XHWepH2+QSTsUPxzaSsEFGBaQcQNTdQEU6qG357Dm2zcPvm4uR7cWHj9Qp3yDRceaya9 ldd/szw/PeKglxy1MMrnXH/H5eq3Yc8PDMB0voZbWwCYbh2B9soHmLYXE3iUUaAWOGXMH/3hWvpu DqYJWLy8btYoi9BBLaA4cfIBRjeYCEwEHOVsRXnWbXq7AlN9o8m/ybCuWuXS6IaHm3SXk046CzCd JFszmWqDaTMVa8QRgGkjgZjhBsB0hngHmhVgeqCBPcRq1QKnQ9SmRp1q6bs1mJZgIQ+mYnUhWKHr tLVp3AoZ5xHgpGG020/7QoArVt26AlbZ2heYmlWiJeFvuugUxy7W0+3kcwJM89rs4QzAdNkoAUyX 1XcN6wDTNVTeVxkA033F66i9rQVORy1iofK19N0WTMWKZaKueTDlxBY2s3BqVk3d43H6UbgOTsi+ B1HJ1dHEyisXv8Ln3sDUfA94O5DPhYRuOsjHhnPp5hwHmM5Rb/u8ANNlYwAwXVbfNawDTNdQeV9l AEz3Fa+j9rYWOB21iIXK19J332DK39PqYLMgWfDzPBJa+XuN5tMHmDI8l8qrcW5/YFqj1vu0ATDd Z9zYa4ApK7HMJ8B0GV3XtAowXVPtfZQFMN1HnOBlxd/ZhJhpBQCmRpf+VdVOP1o1cy8/Sq6O2rdp eiuwWDHtFMRWSQGAaUmd9s8BTJeNEcB0WX3XsA4wXUPlfZUBMN1XvI7a21rgdNQiFipfS99tV0wz PzFi6x1Dp1m97B6/NdDY7fuCed8ZJRAV3xX1zslsOp1cgaUytns0FSumMjhtbwNM245Pn3f1wNR+ xWDgW9Z1P8dp9afsf4zXJs12/VCfdkPOA0yHqNR2GoBp2/HZwjuA6Raqo8xJCtQCp0mFH0GmWvpu Daapnxjh8MVgSmeCR3Dl6ma0CuqndY/o5t7AqwsOYDeyyd6t8wkwXUfnGqUATGuouJ2NWmDqPZlh +6vczTOqbfYmmZOCQNf8fFbJjkve6AbAtNHAjHALYDpCrCNJCjA9kkAfQjVrgdMhaLFEHWrpuzmY HvlPjPS1DYBpn0LtnAeYthOLKZ7UAtOwbB9Uw7MDvsPON8eipzlCW23vA0zbjs8Q7wCmQ1Q6rjQA 0+OK965rWwucdi3Cgs7X0nd7MD3unxjpayIA0z6F2jkPMG0nFlM8WQZMzRMY7mmNyDE6X35Et1tR 7bHFT4Lot4+bF7nRCqt8VNhbcdXpxYvf+OkTe7xLax9N5vNRHYYdAJgO06nlVADTlqOzjW8A0210 R6kTFKgFThOKPoostfRtAUyP+SdG+horwLRPoXbOA0zbicUUT2qDqV4ppe+Mut9STngVwuFJ+LNG PrhqyMwBItvi83qF9cT9JJYBVP7+arBSq/MKQBb76a9UJOrScwhg2iPQDk4DTHcQpJVdBJiuLDiK m65ALXCa7sFh56ylbxtgetixmlM7gOkc9dbNCzBdV+/apdUGU/ZPA2oOTjU8CiBM7TNokkENjAyX XIL9FDCpj4T7pUeBw3KVeZLF/Qb0zaCsCbsA0wmiNZYFYNpYQBpwB2DaQBDgwjAFaoHTsNKOL1Ut fQGmbbcdgGnb8ZHeAUylGvvbXgpMDUwK+CxKY1YyzWO09hFa74293SO6kZkQRMP9AEzdiq5e1T1V p9EjxebR4e6R3qjEUQcApqPkajIxwLTJsGzqFMB0U/lR+BgFaoHTmDKPKW0tfQGmbbcagGnb8ZHe AUylGvvbXgxMAyAsKyMesdVgGa+OZh+tDUE03Jd+hOfCffu24JMrKWAt1yB3FmCaU2Y/xwGm+4nV Wp4CTNdSGuXMVqAWOM125EAN1NIXYNp2AwGYth0f6R3AVKqxv+1aYKpXIt3jt3bV0+37uoSQKb8H qrdT+RIQqa2Gx8P9CEy777Oa1VOxqivShj76NRi+BzAdrlWrKQGmrUZmO78Apttpj5JHKlALnEYW ezTJa+kLMG27yQBM246P9A5gKtXY33YtMDUvcxNvu/W+XypWRK1EBkY5PcNh6Q28GdgNQTTcF7BJ RctHec+vi/J0ug5aXX1SkDwizADTEWI1mhRg2mhgNnQLYLqh+Ch6nAK1wGlcqceTupa+ANO22wzA tO34SO8AplKN/W3XA9P91X0NjwGma6i8bBkA02X13aN1gOkeo3akPtcCpyOVr7fatfQFmPZKvWkC gOmm8o8qHGA6Sq7mEgNMlw0JwHRZfdewDjBdQ+V9lQEw3Ve8jtrbWuB01CIWKl9LX4BpQeQGTgFM GwjCQBcJTdJqAAAgAElEQVQApgOFajQZwHTZwABMl9V3DesA0zVU3lcZANN9xeuova0FTkctYqHy tfQFmBZEbuAUwLSBIAx0AWA6UKhGkwFMlw0MwHRZfdewDjBdQ+V9lQEw3Ve8jtrbWuB01CIWKl9L X4BpQeQGTgFMGwjCQBcApgOFajQZwHTZwABMl9V3DesA0zVU3lcZANN9xeuova0FTkctYqHytfQF mBZEbuAUwLSBIAx0AWA6UKhGkwFMlw0MwHRZfdewDjBdQ+V9lQEw3Ve8jtrbWuB01CIWKl9LX4Bp QeQGTgFMGwjCQBcApgOFajQZwHTZwABMl9V3DesA0zVU3lcZANN9xeuova0FTkctYqHytfQFmBZE buAUwLSBIAx0AWA6UKhGkwFMlw0MwHRZfdewDjBdQ+V9lQEw3Ve8jtpbBqePfexjCn/LaHB2dja7 jTGYLh2jD33oQ4r+li7nEO3ffffds+NMBgicDlGflup07733VokVjKyvAIPpjRs3FP6W0eANb3jD +oEVJVJfSmMe4jstvgBT0ZiwqRUAmKIh7EYBAlOaCONvWQ3mNggapNeI0bVr19Rb3vKWVcpaoz5r lzE3zpR/KZ/f9773qXe+852L2a/t91133bWovzViBRvrK0Bgeuedd1b/u+OOO9Qv/uIvVre7hK9r 2Fw/sl2JBKY16/iqV71KvfGNb6xqs3X/OjWxBQWUApiiFUABKLBLBb7whS+oi4uLXfoOp8sKfPrT n1b33XdfOVFDZ++///5d+duQdHBlggLf/OY31dYrhRPcRpYBCtCYRmNbq/9a969V3eDXcAUApsO1 QkooAAUaUgBg2lAwKrsCMK0sKMwdlAIA04MKp1eZ1sGvdf88MbGzSwUAprsMG5yGAlAAYHq4bQBg erixRc3mKwAwna9hqxZaB7/W/Ws1rvBruAIA0+FaISUUgAINKQAwbSgYlV0BmFYWFOYOSgGA6UGF 06tM6+DXun+emNjZpQIA012GDU5DASgAMD3cNgAwPdzYombzFQCYztewVQutg1/r/rUaV/g1XAGA 6XCtkBIKQIGGFACYNhSMyq4ATCsLCnMHpQDA9KDC6VWmdfBr3T9PTOzsUgGA6S7DBqehABQAmB5u GwCYHm5sUbP5CgBM52vYqoXWwa91/1qNK/wargDAdLhWSAkFoEBDCgBMGwpGZVcAppUFhbmDUgBg elDh9CrTOvi17p8nJnZ2qQDAdJdhg9NQAAoATA+3DQBMDze2qNl8BQCm8zVs1ULr4Ne6f63GFX4N VwBgOlwrpIQCUKAhBQCmDQWjsisA08qCwtxBKQAwPahwepVpHfxa988TEzu7VABgusuwwWkoAAUA pofbBgCmhxtb1Gy+AgDT+Rq2aqF18Gvdv1bjCr+GKwAwHa4VUkIBKNCQAgDThoJR2RWAaWVBYe6g FACYHlQ4vcq0Dn6t++eJiZ1dKgAw3WXY4DQUgAIA08NtAwDTw40tajZfAYDpfA1btdA6+LXuX6tx hV/DFQCYDtcKKaEAFGhIAYBpQ8Go7ArAtLKgMHdQCgBMDyqcXmVaB7/W/fPExM4uFQCY7jJscBoK QAGA6eG2AYDp4cYWNZuvAMB0voatWmgd/Fr3r9W4wq/hCgBMh2uFlFAACjSkAMC0oWBUdgVgWllQ mDsoBQCmBxVOrzKtg1/r/nliYmeXCgBMdxk2OA0FoADA9HDbAMD0cGOLms1XAGA6X8NWLbQOfq37 12pc4ddwBQCmw7VCSigABRpSAGDaUDAquwIwrSwozB2UAgDTgwqnV5nWwa91/zwxsbNLBQCmuwwb nIYCUABgerhtAGB6uLFFzeYrADCdr2GrFloHv9b9azWu8Gu4AgDT4VohJRSAAg0pADBtKBiVXQGY VhYU5g5KAYDpQYXTq0zr4Ne6f56Y2NmlAgDTXYYNTkMBKAAwPdw2ADA93NiiZvMVAJjO17BVC62D X+v+tRpX+DVcAYDpcK2QEgpAgYYUAJg2FIzKrgBMKwsKcwelAMD0oMLpVaZ18GvdP09M7OxSAYDp LsMGp6HAdgo89dRT6qMf/ai67777Nv27evWquuuuu7YTAiUvpsAewfStb33rptdDreuRru3HHnts sdjCcKzAjRs31Ji/L37xi+r8/Dw2hCOrKDAmVmPTvvvd71Z007XVfzTmfvKTnxzVXsdqsHT6VrWF X0YBgClaAhSAAqMU+PKXv6xuv/12df/992/+98gjj4zyHYn3ocDewJRUbeF6qOHD+973PvXBD35w Hw3lALz8zne+o1772teqt7/97YP/7rjjDnXvvfceQO33V4VPfOITo+M1JrZvetOb1Je+9KVmhfns Zz+ryMcxdWopLV1rFEP8a1cBgGm7sYFnUKBJBQhM6a4u/kGBpRTYI5gupcXadj/zmc+oj3zkI2sX e7TlEZi+7nWvO9r6763iBDUAm71FrfMX8eu0aHULYNpqZOAXFGhUAYBpo4E5ILcAptsFE2C6rvYA 03X1nlsawGaugtvmR/y21X9I6QDTISohDRSAAk4BgKmTAhsLKQAwXUjYAWYBpgNEqpgEYFpRzBVM AWxWEHnBIhC/BcWtZBpgWklImIECh6oAvQxF/r3//e/X3y+Rx2ibXoqEf1BgigL33HOPOjs7c3+/ /Mu/rOhPHqO3QeJffQU+9KEPeTqntKdrHv/qKSDb9Wte85qordP5J598sl6BsDRZgQ984AP6UWt6 3Jr+OHa8T5+UBv/aVIBiwzGjz1T/hvi1FTuAaVvxgDdQoDkFHn/8cfVzP/dz6rbbbsv+4UUczYVt Vw5961vfyrYtbnd/93d/t6s67cXZ7373u+plL3tZUf+//du/3Ut1duHne9/73qLeH//4x3dRj2Nw 8uGHHy7GivonSoN/bSpAL0jkMST3iZcothU7gGlb8YA3UKBJBWhFNNep//zP/7z63ve+16TfcGo/ CtCqaa6NYbV02TjSqmlOe6yW1teevg6R0/sVr3gFVkvrSz7LIq2o5eKF1bZZ0q6SGfFbReZqhQBM q0kJQ1DgcBUorZpitfRw475mzUqrplgtXTYSpVVT+k1B/KuvQG7VFKul9bWea7G0aorV0rnqLp+/ tGqK1dLl9R9bAsB0rGJIDwWOVIHUqilWS4+0MSxU7dSqKVZLFxI7MEs/EROuCmG1NBCp4m5q1ZRW S5944omKpcBULQVSq25YLa2l7vJ2EL/lNa5VAsC0lpKwAwUOXIHUqilWSw886CtXL7VqitXSdYLw 2GOPRd8lx2rpstqHq6ZYLV1W7znWU6umWC2do+i6eVOrplgtXTcGQ0sDmA5VCumgABTQb+flVRWs lqJBLKGAXDW9du3aEkXAZkYBuWqK1dKMSBUPy1VTfLe0orALmZKrblgtXUjkBc0ifguKW9E0wLSi mDAFBQ5dAblqitXSQ4/2NvWTq6Zf+9rXtnHiSEuVq6ZYLV2nEfCq6e///u+vUyBKmayAXDXFaulk GTfLKFdNsVq6WRh6CwaY9kqEBFAACkgF6LumWC2VimC7tgK0aorV0tqqDrNHq6ZHu1r6/A+Uev7J 4O8ppZ6nv6fFH6Wjv2e6v2HyRqlo1RSrpZEszR6gVTesljYbnl7Hfud3fkfRH/61qwDAtN3YwDOr wOc//3n16U9/Gn+NaPCJT3xC/fqv/3oT8aC3iU79Rytzd955J/4a1OCOO+5Qb3nLW5qIzZNPPjmp idHkZ4/t661vfat685vfvEvfp+n98+rOO/8bdeedP6LuvPNkxt9PTdbsDW94w+S80+pcr9+bdHEE ma5evare8Y537OKP+ib624u/pO2Uf9Tvbd22liifxpVWxpba9Zs6Vk1pH0vmAZguqS5sV1GAwPTu u+9WdCcff9CA28DZ2ZmaC6avf/3rFT2yiD9okGoDv/RLvzT5NyUJTP/kT/5E3bhxUuHvxerGjX+u btz4n9WNG7+sbty4S924cZ+6cYPsf6nQfr+ibtyQf4cUZ6rXn6kbN+5XN258RN248Zvqxo23Wn3+ D3Xjxv+gbtz41+rGjX+sbtz4cXXjxksrxKEUy58qxOGQdO/qQtfH7H/PP62uXj1RDzxwoh58sPbf j6sHH/xp9eCD/5d68MF3qAcfvE89+OAD6sEHHzyKvwceeEDNAVOKb6pfxLHuGmhFizlj1exruLIB gGllQWGuvgIMpvUtw+KeFagFpnvWAL4vq8CcwZ7BVD10onb19/A/VOrRf6PUd16t1OP/XqknP6nU 019U6tlbSqlnlhWcrNMjs89+Q6kffEmpJ/5vpR57p1Lfuk2pr/9LpW79WLtaPvJTy2vTWAm1wXTd 6+TvKfXQC5W69WKlbv2QUrdeqtStH1Hq1o8qdes/Mm3t4R9X6uF/YLb1MTr3w0rdeolSD71IqYfI RuH63rhN1ADTxpoc3MkoMGesypjc7DDAdDPpUfBQBQCmQ5U6rnTVwfT6uTo5u4xFpOMn5ypxJkp7 eXaiTq/RBL77d+vaqTo5ObF/GTs3L9TpSZxXqVvq4sqpurjZ2cPWegrMGewZTG9d49j7n+fXCxPa 0mQ3PHfd2L0Mj4v9yIezGWXriTlNzmkiz380sae/l4g/mvDbPz2Jp4n8C8UfTerp7wXir/OLrqXu uum2L252aYpQIOofpRugWZSnZI/OjYUQuuavXCjTW9B13tUx2Q+5Zt+X9lKdu/7mRJ1fdxm7jUr9 zdpgyhrJa4fbyek10y54P2w7pTw61jdPdB98wtcG7wsttU0+b9tDdG2J9Jdj20QXoSpb64Cp3948 3bl96/a2xDgWlr1EGSYU/jieGqvLIdPtMjW/KGcbfHbOWDW4kJUSAkxXEhrFTFfAB9NyRxR2HtxJ pgbnKO2QTsMO6Gz3hDteW73Iph2kZPk6TZDPVyeoYzGtn9PsZWCGACuwFfor/UxZdseysGZ9T2hJ HfNg+66g/EZdMCW/U9DIsUid833jCZEHpoFOOk0QA7JCcTg9OxcTVWHbm8CK49hcXIE5g70HpldO 1C0JNhaM5GR5NAixvR7I4omzBFczSaoAeOzDAp8pH7kus+G0R7NJsRgFIX4fberKt75Mn+P1I6Kl l9MaaHV5df8TT9Zr9Tdrg6kSsKjbM++L60vrc3KiZBthoOVjnIbGcXddsC0Gz3Cf2jgfE+Vxm/Su ZU53tu0q+ppgWhzbFwHTxHWySDlKmfYi5wBx2f51KS5Yu9l3Ps4x7sicsWpcScunBpgurzFKmKlA B6ZxZ6CCjigJfXpw9qHIAJnsaGznkwAq537Cju5sBGjky+8mB8k0rpBgYqFXzE7SK3kuj79B9t3E hE9Z3z0w1ceEBnq/85Ozxp8mDslVRLJxdl6APFFebHjUkZpgmtSMgfEKrXiW/LZ6XDlX51d67qSG musaU37S3dhJDfDUzlLHRwmGxKMVmDPYF8H0oROlJ7RigjsJhmiy3ANZZkIUQKidOLtJ+QJgObk+ 1pek3w+dmEkiw0NLfo8BU91PMojGzdLUPX9e5vDThn1IuE856/U3q4MpXzd0w/fsxK0ySyjUegRg ytdIclWV25KDSXuthPu2rYUgGu5zuzcw/FODnrSR8ay5fdBgGsz9WDeKfzT/4ZNTPjPlqGAs96/D uKC+83GOcUfmjFXjSlo+NcB0eY1RwkwFHJhmOgjZEeWgLzye7CS0/RyAhMDIlfIH/rAck8rPm07D 9uLPcenJH78Ouq4np+r87DRaMfVL8+vin+v2yJ/TJKyZep5f9+vb5bQrg8GjrvL8mO16YEr+JoCc 2gPddAgGoNjHS3WpH5fL15vzJNsd2bc3N5LnLSCXH+/jEvBZU4E5g30fmPJkWa788IoOTW7pcczU hJuf1nBpe8CUJ859EOo//tmBrGmT3b4H1Hbyfm4fu2V/uUztawDfuXJ4Qs+fYbl83CufYIEBwj6d UtKFYEHDSahZzoYEIbIf1EX7aMs9ufJT9rFcpfSkVdywDNsk5cvfaBrWDxubYdqgD0r1XRX7my3A lK8Nvg7co7fyhsYYMOW03AZyoMo3QWw6hlxu69z2uZ0CTEWrj+Zupt1yDMNrwbuusosFxkYWQqP5 nLk2XFn62uDH5xPjv3V/yPxLp+F+gPy1ZXf94oCFDyHXlM05Y9WU8pbMAzBdUl3YrqKAA1N9p7d8 NyzbiQQDtOlIfIArOht1rOnU6fL9yUI6TdoeHfXTU2ec70T1hCjoyC+vmzvvvp1UeeEkJ5GGdMjB mhgIsmWJSVHC+qhD1cBU+C0dcJPHoO3INP62H2fvnBsE49hROW5wzfjCA92wNRSvZOzMUGDOYN8L pnaCq0FKbtsJsAemBFICivTEjSfQIWTxBFp88qOMKVCkibQDNspj7THgeWUxqLEvwSRdT8oDf2R+ r5xEnXlST58ynzzO/jFoRzqJxzO9c7K8wEcvnTwnt0Of6BzrYM+567jY5vJ9uK6zBmD+7mneUClt 3znn58z+Zisw5TZA7ZnbAbcRrju3XzrO7Z+PuTT8/W+6lmz7cKAb7vP1FBxPgqlLczyP8jJkyk8H gbqd8dgXjJPeuXC+E6QNLwc3rhrAdOXpdCavO+a19eAaLMxLdFsJ5lShG7TvpdNliXE9PJ8yMPPY nLFqZtHVswNMq0sKg7UV6MDU3onmO1N6RcEvLQtEQednXirDd8togtEzERgIJ8nydV7ulMOO1/c/ 3jOw6CYScQLvCHWOubRJ30RufT5YbRWn9SbZ1x19Qg+d33XgQcfvDOWOuwSDN6qBaWpQomNcl0Rd 0072DKKUSdvq2oJ5rE7eIAkGUy4oar98Ap9LKjBnsK8Kpjwptp96oj0CTHnS7ibf1IdyfjuJ5kk7 T+R5RchMuMorpjJvmD4sW4KE6a862y5tCIGy/hIWAzhk33n1yvOF0nKdQxsJwCFbkX9WK10Ha4PL GvzyI2+CnG692u++Mclm9dMG40XUb9D5ev3NVmCq62znAU5/20bkOQlJURu1K6Wc/vxa5uVH3Ga4 DTroNO2WwVSWpbcp35jHu9NNYdbRJh/lTbR/ioGZtwwYQzOKcBxPxI17OSeR22bcHfYVKW2X5wKZ sumwly667oLzBTtTT80Zq6aWuVQ+gOlSysJuNQU8MBVWsx1RakBPdBTOlD5nITXXAQ2EEwN3Anjd 4OlKC1ZAu+Pxlumke6HZZcxAjT2vfUtpQ+d1/UqPl9k0rE+kB5Utgct0xDEkm4mTu4vpfB+/sRyY BnWJ6prz1egf11mm99Pk2ksc83pAL73BdlmBOYN9L5hKOErAobeKx5Nh25+c0htcecIs7HR9or+a J4FPb1t7elIv8nM6ubJpJlwdPHqP0ib8lnnZnv605SQn8DzpF59huWxLlp+DAoZqBnECSbLnIEbU WdrjMviTV9pCnx3kBHUa1K8lJuZRKyyNV2FimTbRVxkdxVMztg15dYrGhWH9TVUw/aQFQzdmdm2O 46E/A82pHuHNDjrmYiTaFNvRmnCa4Npy1xUf5+uM7djj3Ma4DXLb4jajzx8AmPpjlLypwQ1xwJge tdF4jmRuBA+wxcVmPnVsuT2La81c/zKTKctdBzy3kUmiJ9aCk2JXXmfhu08omXde5Ku1OWesquVD LTsA01pKws5iCuTAlAuUHVEWvhIDNud3n7oTy8CZ7FhdhngjW75IKtPkO30DMDGgCEPRpsmTmxzJ cr2sWptMvV1Csi3AM9TT2nCdvJv8hANZ2UdX3ICNxcDUtoO4LqL+Sf9M3cpgKgfejBaptpY6lvQB B2sqMGew7wNT02/Zt/UmAE+CqZnUdBN1b19AFk+85SfZSU3Snf1E2RIuvbIyj/JK+2F654stR0KE O8eTfvGZs6Mn/gwLVHfxOG3KHqUnaKD6urKlZnJblE+2yAcGkJRtecwAStjfJVqjvpZ70oX9a8KM OyTTym2bwOhIYFq/v6kKpg907VvqGm5THBk8GQodTPJKe6bNsy2tiUjD+7rP57Zl26u0Tfm5TAbR cJ9vhhgfj+dR3ty8QzdDOX4V2/+QMdQ0bD2fScCkP8/hNk/jbuGa0z5l5kDSd3fRKfs90m5O0F1n 8TnK5p2XdiptzxmrKrlQzQzAtJqUMLSUAgymQzoiv1PqPNKdAt9Fc28l7M6bLQkN4blch+kfz5Uv rfWnMTbdo6Qyc3GbO+F0omS5eiLTda7pnNzRJu5y2sdmSN8YyFJ6po5lSy2eqAamxYGSV5MLg5rz 0m8L+nAwUdQx4AEyW27CTjatKxwbCygwZ7AvgqmFIZ7c0oSXJtwOgoLzpv/yIdZNmAtgRXZ1Xgll YnLNoCZBlL+/x7DJE2+Z1sFgAmo5P6fX+S08euWEdU5AoaujPce+sG+sm9PR+uP2RV2dtmQr0MxB Op2Tdbr+w+rk5KXqUv9G6w+pW9deok5OXqIub71Y3br2UnVy5cXqFv9W6/WX9H8lRLdR6gP9PlfH yE2yy/1/Oa3pX11frPsNO+HO9iHT+5u1wZTjL9uFvlGRgEzZRqidyD++JmQaBl5nOwOmOp24GcI+ pdqc90KsBfqnPpNNPsprb5C4Nhq8OyScp/jtXdTYtu3ODp0L2j+veNLNDDf/4/mMvAbja1KUZPtQ OQeIr1HPT+2btA8wlXr2bQNM+xTC+c0VYDA1j0eEAOR3RGGnpp3XcODfDTMDk+xo7Hc/GRpStU7Y 8UCDO0HZASbsJH0U6bRvPTZEcm+T8voddXc6KldOWrpkw7Y84Mp36l5nrS3n0w4ruEtVDUz1QOkP Il0pKTDN1SExweM24VaQu3JibbpSk+3KTVy7dNhaVoE6YPoCvcLjr8D/kLq4+aNK3fqPlXr4P9Gf t64RBNmbP/anMNxklyfJeoJ1oi7ppS08OQ4gS07AeZsnz84+5xUTdjcxD94GTDbkuQtZtoQ4YSss jyE1tOUgQORln/X1wXqIT2lLp5XaSLhnmykfnWYvUOrWjyh1879Up6KM8+t/rdTzT+nGZa5FvinX Xb900vdRnKP+sdCHUz5/hclOdNkHL2/Y35TS8qSb/e3KWaK/qQOmP1BXr75APfDAC5R6iOLxw+aT tuXfzRfYGL1AXcrj1+31deUF+reCOSYSOrlN8WcqjWuz4Yopx4Q/+bxtX5zPXav2OANzbjxetucy 1tcEU9e3sE76086xIlCjNt210fAmPMdH2/SuhVC1wE7ivSPpeSOP650PfXHy+4HEPMvOD/V1H9UX YBpGrrQPMC2pg3NNKODAVHtT7ojCzsN0lmLCIGoUpS12gDajhTnXCQd5tM3gmChSb5bTxPUzZTFE 0/l0fbRx6hwzABOWG9XfDhSugy5NrnQnbHwK7Xr11emEvyWbXsb+nXpgam5KuHr3F71yCjMR9Sey K7twpMXVANNp0j2j1LMPKfX055V64l6lHnu3Ut95tVLf/N+U+sapUo/8Z0rRKh7Dl/f5QqVuvdRC 708o9ch/qtQj/0ypR/6JUg//I6Ue/gdK3fr7St16iZ34+6tJaZsNp6EVy4d/Uqmv/yulHv0flfrW bUp951ypx96u1PcujH5P/pFST39BqWe+otSz31DquceVev7paaGpkYv6wUw/XcP8PBvD+5sqYKqU unr1qiKImv2P4vqDLyn15H9Q6vF/b66ZR/97pR7+icy1slS7/ntKPfQipb7+X82u0hwD64DpHA/X yNszZ1rDhRXKmDNWreDeqCIApqPkQuItFPDBdAsP9lQmdcIMse35TXdCawFgTTCN347bkHZ0M6Tn ZkdD3h6UK3MGe36Ud3lBnlFK8d9z44t77jtKPf1FpZ64T6nH3qHUt/+dUo/+W/NGUYI+D3qXmsgX 7NIK2iP/WKlv/LRS336lUo9fVerJ+5V65qtKPf+98fVtIgfBn7hh14RP1okR/U1zYFrU8XmlFF0f zyj1/A/MjQlaFX/+SaWef8K0JQLb5x5T6rnvKkXXhfyjtqaPUxq6sUF5KO/TSj1P19+zSikqo51/ AFO7MnoE4+ecsaqdFms8AZi2FhH4EykAMI0kKR6gFcxa8FcsaPTJutBcF0ztANbcKkbDE9jR8d9f hjmD/XpguoKuegJOk3D+owk9/9HEPPyjiT/9EQTYPwfPPImniTyBAv/RpD78W6FuWxUxAgDXc3Fc f7MvMA1UdKur/49S37um1Hd/Ralv/axS3/hvlXr4H/Y/TfD9DwcG29s9djA1jwQ3egOocnOZM1ZV dmW2OYDpbAlhYGkFAKZjFR43uRhrfWp6GiRqPo5aHUynVgz5DlaBOYP9QYHpwUYYFZujQLNgqlc3 v2Ueh9eP9n7SrLTT4/CP/hvzSPvcJwEApnOaDvJWVmDOWFXZldnmAKazJYSBpRUAmC6t8D7tA0z3 Gbc9eT1nsAeY7inS8HWKAtuC6XNKPfuwUvT94cffp9S3X25WO+n703Ohc0h+gOmUJoM8CykwZ6xa yKXJZgGmk6VDxrUUAJiupfS+ylkPTOkR5JPEy0poZTq9CmweIRLf9bUvzUo9Ym1eQiXS6lfey31T jnvhln7z6C0vWLkXWUUr1PplVN2bCEtvDnUFeI8cWi34jYrF7+4MS2t8Tzxu1cALYuYM9kPBdEjs cmk4frnzUfxdUMWGjK9tp66tZR5tj9o3m2sgZuwKPpdXYBaY0qPe9u265q289DbeF5m38t76MfPC Iv3irn9qXvb18D/y3oLsvQXXvmVZt1v71lx+W65ry67PCn52iY/zZ/DW3SzkAkwnN7D46an+Mc4V VhhLTb8kxjcd08TY4ozRRmGcCsdL10b4d4H7bHsFLbozZ6xa1LEJxgGmE0RDlnUVGAym4aSKOxH6 DCdYYdpggq07uDAP/zxA4rhUJDvRlomwPVuB1cE0ehtyDkxpoDtX596jy3bgjdpO4ji1Tdce7aDp 5YuP6Tbn8lhp9aAqBs5wn3/KJsznRYb8YxvG1w6uE767vEPTGvvnZ+nvRccTGFfAKhtzBvtRYBrG IMzl0VsAACAASURBVIhVMr5CgeR5O6kqw6nR/+ImGTPtqktv9rt4c4F0PGzffM78LEJnozuOrcNT YB6YPu1WNq9ePVEPPFB4AZZdwZTgIX+XVh7nnyBiMPUAVq6E8s8MSRDlY4mfU4oAFWA6rUFTv9Qz nnFf5KczxVFfd3p2LsbIzo3UvE33jdHYzXmGjlM2vZ438nhof5op7LvZ9Mqfc8aqlV3tLQ5g2isR EmytwDgwFZ1GzvHEhE13aKKDSXVwZC53vCuqPNHu0mFrrgJrg+npldPgtwnNoBZOwvVAeHapQlgw A6RcCeXfHPTbLKVjGAjbpdNMt+HOVliWSecPuuk0BBl++a4M2ogmEd7ZqI7+WX8vWT7Zp+suqI/L 6UG6O7raxpzBfhaYBj9Cn9ROqJA7nzvusvbEN9XfaZuJ9u1sbhwz5wc2FldgSzB1v+P70Il+coX2 9W/RBiumo8D0oRPVC7QMtwDTCe3LzI/MjTCTfegYZ1Pb8Sq8iSZsedBbPm7O+v/n+0x/POVc5H84 B+Bza37OGavW9HNIWQDTISohzaYK1AXTdOfCd+i4g0lNyEiE3HEnUN9E2yXExlwF1gbT8+vhCpJp S9xmTH3EsdTd1eAHwONBkPIzKKYH35RusR1KFbR1DX9sO2UlPtY36KbLje1ob66FYG+uJwPhubrS 8XE+p0ufdnTOYN8CmOobC4Wfj+qLb9zfFdq3k3jbmDk3sLG4AluBKT2NQo/oXtw8Ucqucp7ST5Hp p6PMymsvYPLqqFwxJehke9d6VnABpuPbV3TTKtfvZ0zz/CozF4v7K2Nn7jilrejxs7sZzB5q2wkY 5vNrfc4Zq9bycWg5ANOhSiHdZgpUBdMQFjK1ynVwueNshs6XJ9qcEp9zFVgfTO0Kopvoi0k6V0a3 r27w6toDJTDpu8eTAnDUNmigtvkHtlVtOQF9Bkp8qNPt1z3i3vnJ7vuffYBhJhW8uuvnDfdSaX37 uQHe1zC0u+z+nMF+FpgGNxG0Ni5u/B2qLn7ZiVexDfn6R0rqvMFqQLF9dxa2jFnnBbaWVmArML24 Zq4BvRpqv196cb0umPIjwdEjvFgxndysoj6+2D/FxXj9StAXUWo9vqUgMQOViRL0+yTiMS01Vtvc CT9iu8sfmTNWLe/duBIApuP0QuoNFBgHpjxpk59icj6wg8p1cLnjRhZ/ohd1whtod8hFbgKm3uAX gynF3BvUqL2JR8Q9gEgNypSeB9bEed3+BKDwaq22K47zCz/4fNwODCjqdMI/L11xwLWQncvrGcqk lXWl9JnyytecV1D1nTmD/Sgw7Ymd124StcyeT7Qhlz2jtzlv2we3RZuJyim1b7a9ZczYB3wur8Bm YHrzxL6Q7sS9EOkyWAHlFVPuC/nTPdobpHcAmjvOQMqfWDEd3cCoX/D6j0T/lBvjzFNt3c04vtEr x7hsvzNo3pcZp6iWCT9d5UvnXKLlN+aMVct7N64EgOk4vZB6AwXGgamA0JSvgzqo/J23bMdHZQ2c aKfcwrHxCtQCU28gTIKWmaS7AVAPRLSSFIKpgL0ANPy8po2mYMKf+AflehL551K2vOTZHWPHmyxw Wl1PORHgE4UBnJO4z1xaezzQiSaPoS+6bgEgOfMLb8wZ7A2YvsdMoG09w7qR+0Ni15cme77U32Xj a9txpLk9noiZa982HlvGbOEmAfNCgapg+km74mnblwNIBsGHOgilR3jpjeje90oDoGQwTdnREBqk D8FUvlzJnRO+KICpaAnDNmms9ftAfxzzrfjndJ+S6Hvkjd/c/CzbP7oCc+OUTUD9aHJuQOfJz555 pytnuY05Y9VyXk2zDDCdphtyragAg2kvQAy5czUkTWGymOv4+O4d35WVn35HvKJwB15ULTDtl8kf ICm9GejO1bn8uZjM4OW3GTMAnl671BMrv23QOX+A03mTA6Lv09CBNwQIbre+H1aRJLjYATyClpSK hbRJ26zrhZI/huPrlypnuWNzBvtRK6bJGHf16otv7ny+/fAqQHjjwbSrZHsY1L6Nz1vGrFMNW0sr UBVMR7yVl8CUwdPczOq+G8qP4PL5sWDam4/hFGA6unlRvxD2Lfk+So5xZiyJxq9gPpfudwrjkK5B 3/n8QoXOHvgwWpRKGeaMVZVcqGYGYFpNShhaSgEG0177gzoI0wmFnWM4QU9P9HJ5c5O89ES7tx5I MEiBLcGU2wtNiniwTA26uiLBqpVuW/rOrw+h+nGhCFDM4Owe79UG7UAqyk63V19GU25QpvYtOOay Udn+ufwkwmVyG6W02pcU3Cau4ayurqTlNuYM9puDqY5t1z5jlcL4lido2TgE7ZvKyaaNncCRHSuw JZgq8dul8iVIc8FU/2Z17udibr1YqVs/qhT9zuqT/6H5yD3wwAPq6tWrk/x88skn1az4JkpN9/sD xjg9LoQ30agAf06mx5xgXEmOe8I3nScad0UCWwaP8/KM3s76FqVc9MCcsWpRxyYYB5hOEA1Z1lWg LpjyC2z8CZvpvETHpzub4O5eYRKf7nAZWP3J/brqHW5p24Jp0I4SQNUpbwZedzPEtq3o0SBqX8Gg yjb04CkfYwoGUt3+gmOc1/u0sNKt6Is27yU0O1RuNyDbCYT0Q2+zDQk6pbTmXGdXFhzCkbQp062z PWewXx1Mo7j09ztefLldhnaoXY1p34082rZOCznuUmaBy/PTf8dUg+hD9numDJHBo7m9K5+cPmzv Zy9T6rt3KPX931XqyT9S6gd/pdRz31FKPb+7YLcGpumbr0bW0hinz2XGRjl3i2x441MqfKVxitOX xiu7+JDxjS2s8TlnrFrDvzFlAEzHqIW0mygwDkzlS4/EdjhpDydh4XmqaZgmWD3qxCh1XOFEu8uF rXkKrAem8/zcde4CLK9SLyo/dW2uUrjSKwa0cjDl31AwnWK7Wp4l4rtxzKppA0O9CqwNpsnvevKj taVPWuF8+CeVeuSfK/WNn1bq2/9OqcfeqdQT9yn19BeVeu5bvXXdY4LmwFSvPvbfMNuP1mZ+l77J um4tAKbr6o3SjlyBwWB65DodW/UBpmtEnAbe7SYS3oreGtUNypgz2O8CTBeYKG4dsyCE2F1QgbbA 9IVKPfJPlfrWzyr12K8r9cQfmtXO558YqYBdGX3++0p5f08oRba8vyeVep7+nhJ/TytFq8Hu7wdK Pc9/zyj1/DNKKf57VinFf8+N9LM/eXtgmnhJZH812k1Bixcb3jiVwswZq6SdFraxYtpCFOBDUQGA aVGeoz0JMF0p9FsNvkus5o2UbM5gvw8wtU+G1JpcNRCzkSFG8hkKzAJTXe6zGuDoe5AEUerZR5V6 9mGlnvk7pZ75qlLP/K1Szzwo/r6q1LNfU+rZr5tVzuceN0Co4a5QEUpHtp7+M/Pd0O/9jlkx/c65 Ut/6P5V69N8q9fV/odTDP6Emr8qWVmyHnnvknxUqMf5Uk2Bqv4PewirjeEVljm1v2kpPaHvOWBXa 2nofYLp1BFB+rwIA016JjjIBwPQow75qpecM9rsB01UVRWGHpMB8MDVqODAdKs7z31Pqma8o9dRn lfr+R5V6/D1KfedMqW/970o9+jNKfeO/VuqR/9y8pGgoFLaQ7kjAdGiYkW64AnPGquGlrJMSYLqO zihlhgIA0xniHXBWgOkBB7eRqs0Z7AGmjQQRbiymQB0wfVa/OVavmNKq5g++pNTTnzcvHvr+PXZl 89VKffN/Uerr/3J/sDkGeAGmi7XVQzc8Z6xqTRuAaWsRgT+RAgDTSBIcUEqtD6bhG/z4bbRhOPrS 8flEfnoUkt4kOOTRyqEvmQkexZVvLiw/TmVf3CXfWpl4+6B5K2Lie6gH8FjnnMF+KJga/cSL2oTe 5fiE7S61b2Lo3gidSjLpWOmFb7HBro6JNh8nD47w9cIaJdpakGPqrv/9WFnuCL/1NSzTB9dR4hoi f/d4HVUB04dO1NWrJ+qBAb9jyo/Zyj7M/GTXiXsENzzn3kB+ZtLw23rdcXu9ZX/vVIAl/ZTM6bWu LPInVR6/NZj9vbjCbdd+8puE7U/euPS7BlN5vVA95TUgr8i+dHw+kX/A+OjHY7m+Qtaohe05Y1UL /ksfAKZSDWw3qcBgMI3eoisGg3AyEKYNQEB3bmEe+92I3E96xG/xNeXXnxQ2GabVnVoVTG17kbE0 E8lg8LTpPKCwg2l3jAbeU3V6Rf4Ui5HPDapBe4zEHTBAmzzB92DkpFluRwXQAePnxc3kSXvQ2D8/ O41+OF1b8H5upmSnzXNzBvtRYNoX78nytACmZqLZtf8xlTF55XVn+tkFJpx0PYg+X44BcrvsvfFX Tsr9vIn6aIP7vI7mg+lzGijHgCmDJYMkQx/DHfehvM9wyJ9hfjrOx0Lo5DwyjbSrf/P05ERdCnjl 8tk/yqvTWTCWNqNzewXTRsZHPSaLvjQ5Rpcv4N2enTNWtVZpgGlrEYE/kQLjwHTAhMVO6uVESQ8m okPzJxOdS7njOoXunIPyU6DSmcPWDAXWBNN03MNJf7jfVc4fMGlyeqoI5uRE2PxYuD0u2mJnxWxp Xzh/IZ1OXZhs84+Ty+vAK0u33QC8vQT2DYvkQw5yyUafj6HNhvbnDPZtgOlSYhrAyrYdr1jT3ss3 OLwM3U6qT7U3CD1Y7XJM3DJg2PkY1G/ItWBXPU+vnBZWi5RZYRMArB2m62eH19EWYGr6vxMlAVHC Xt95hlAJjpSfAVdCprSrz/NKp1gpzfnh8tpV0Rz0sr+63J2Cqa5D2Kb1G7/lb8GvMz56HUCm//DS HMjOnLGqNQkApq1FBP5ECtQF01zn6E9E0h1tZlLBHic7wVx5nAmfUxVYD0z9tpH1Nxl/m9o7Zyfq 1y/UqXzcidJcuVCX106Lj/JeXr/URn3YTXtF7biDh7AthvuBDZ4sB4flLtk3gJDTyNa1uOoqLba1 PWewrwmmpj86Nysv+tHD4AaYvjFgnxA5M+lM3GWM7fbZuTp1jwv7Nx7MCoO1U7yh4Mc7759Jx49N MkyOLYfzRa1DX1eyDqaOrs1LXbK/Q514M7F3vfJvWgeah87Y6zd7k0an93VjE3u9jrYEU2pTKSjU bTFzjmAxB6Z8PGVT3TzR14yES70KKkDVgahYPZXl8TVAnxJ+uVwNyrsE03Sb5rbtPsNryp0Iry+y d6ouJo6P0uxiT1d4hbSxM2esaqMGnRcA004LbDWqQFUwLXWOov5momUAQBxO3+3mBCnbqWOcHp+z FFgNTIfGUE+C5SRZVk8O3nbgvelPommyThPwIcBJlvvTcTnsh18eHe0mxJym+/TgQYNMWDffvk4f 3TUvl9GV1ubWnMF+FJg6UBRfPxBgaCbbHRjpfXdeti3+riLfkLAweu0WtRi7KsRxtPscs6D95vpA Eym/zDH+Ka+cwIdUM/DgkuvFCU1+B6L6WuX6+e1Tl+s04/zmM2q7nh1KE9jys+s90kD74dWvS2g0 Sn1/3Lcd+WJNUP4soHfFrLq1BZgyJDrQC+CQdU4C5gAwDVdSNXDaVU93zoLqSebxXAmpoT8R0MoV 1T2CaaPjI10IWvvMNb/qhbJCYXPGqhXcG1UEwHSUXEi8hQLjwFRM7Nxkr5vQ+ZOifG10h8YTNpEs d1wn0R10XL6bNAk72JyvwP7B1ECEmWx2E2w9MR0wmPamiybXXRmsPrXn3GQ3HNTDfX0tyWskKs+U Urxm2JFGP+cM9qPAtCfeoYZe7CMQktBoYi7bmIy3tEvb8pxZbWDICwMky4ifJPH801DXAaUsU1uN /A/L6vZ1Xt2vd326Lsu2Q7ltYPIkeFy+syW3+uvuw6PMq7epDnwt9NRH10HGW+YlYzu6jjYBU7si yd/vZEDlVciujfhjMYOqt0IpVjdzx+WqZwlMOT/7k4NW9o/9caBNkAsw9W4C0fUs+y6aS/l9S3Ql ugM6XekpCZfyMDbmjFWtKQAwbS0i8CdSYByYdhOWyBAd6Jk0cB49ePBEgw/yHbjEcZ1ETyjC8s0E zpvwCXvYnK5ALTDliYKeUMgJo3PNn4S7w+FGMv42kXdOTHKpPVKZYjI6auBN+ivLlGAhIYXShPth hYJ9rw4mr5uEuZtAAdzwym7umgmKaG13zmBvwPQ94vHbWBuq75B4h/2RzCO3jX6yvcoYy22b8ozB LRfPsD/jCMkyxoBp7MPQPplLpk+tB7d9ce3Qcf9GoPHTtdNMO6R8Xh/ttXWGxZwWVCdxrm+M8Wzn dA/84XaS8V9qs+Z2VTD9pHlclmPlIFDAo1yJ1Nu8cinelqvbRuVHeRk6pU/Ryif7yT5lVlPZ1l7A VPcvrn+X4wm3NL8v4KPRp9fug7PeObJnr6eJ46PxWVyTQXGHuDtnrGpND4BpaxGBP5ECDKY84GQB wuvcIjPmwJA0PAngiY8wpX3ITQ4ytuOJozCIzckK1ALTIQ7k4u4fT0y6rXG/DYiB1z4iKF+E5KfN e9ebTrdHfyJB/nYTcOOvP5HPl+et5CRsU86UT75GBfsNnpoz2O9+xbQYD38yGsbYbwfltCUw1XYS /a1vn9sxleO3d68Kus2G4GpS+NcFHZPXKINpxra1y0DVfWYmxhJcd34dVQXTET8X4wGqfBR2wEuJ GAwlZJK90suPUnn4mAPMgWCqrxUJzhJk97hiyjeKEtep3y+sMz7qvqHUD3idwuHszBmrWlMBYNpa ROBPpACDaXQiPKAH+cxkwKXNdY7+cX/iw5n9NHzUfWbKT9tyubAxUYE1wdRAmYQ6Xn0P2pudpHqw pyeickLsT3p5osJ5hraX/nR+OVpmOSmW21EMwrZu9vlxRV12YiJidPI1iSf9UWHNHpgz2K8GpsGj sjo2J9zeZBzltpHcmzgG7cHYycBYUKZnJ7pBQe2Q/eHrhu367SpqCPZ66m6mUApjTx7jOnu//xv1 x4nrwRaYas+yTnI78jE8EOjo5/XrmypXm4t8N6vEss5hsVvsbwGm/AgvP7rLgMigqfWW4MfAaD/D 9BpyA7j1wPehFyh1/e/r35c+v/6jSt2ivx/Rf8aXH1aXt35YqVsv1X/s38nZDyl16yUWeF+sLm+9 WKmHXmR/OuZFSj30QvN3/YXa9um1Fyr1yH9RNYwPPPCAunr16iSbTz75pBoc39R1qq8DfyzgcZTH Ou2YTif6h+CmEMeT8+hrJrFo0NkKypxU+/1lmjNWtVZbgGlrEYE/kQJ1wZQnRrIjtCs98i7b0I5W epuYTKQmUTILtqcrsCqYajfNhLhbEeHJdViHvnTBBDmYyBYHXlHUkHQ0qPOAzll5oKd6+OcCv9zL cux3tdxkwNTPz8vW/Yl3tPLEyXbyOWewHwWm7lE5/3txDCI6ZuJGQBR7O7mjmJ5euxAgKGFUbpsA JO06X0oTPL8NJO0U2ov2n8tx6XKNwpTVXXdhu+UVzeDGEZkTuhht6CVQiX/Ud0d+yHKDa53sRumt 3eB65kfmnf8un6+h79U+rqPB4OJXTuyN/x1TgkYHf7YNMZTSOe7fopXMAExdPJyNq0p9/yNKPfkZ pZ7+olLP/K1Sz33X+JqaD9hacHmePXGt8hzAnXfxNwb4Wkj3p0KqCZurgan2TV4v1I8F14zzvy8d nRd9T3A9RX2fs2sf8ed+RXwuoa0otonNOWNVExUQTgBMhRjYbFOBcWDqT+xygwHfucueJynsYOTS yM4yJVWU3vriDVKpjDg2RYH1wXSKlxvnoUF9y/ZXmsBvLM2Q4ucM9kPBdIgf49IEE7txmXeaem6d CQTFZLg1FRq9jrYCU39F80SpWz+m1Nf/tVLf/F+V+s5rlXr8vUp9/2NKPXWp1NP/n1LP/I1Szz6i 1PPfmxhZe6MggMqJxrxsBmxzEOclHb2zLpiOdg8ZKiowZ6yq6EYVUwDTKjLCyJIKDAbTJZ2A7eYU AJgOCcm2E26adO35bvWcwX41MNU3xLqJrVmB6faHtJLdp6kBblvfxCkEodXraBkwfZFSD/+4Uo/8 E6W+/i+U+sapUo/+T0p962eV+s7tSj1+Vakn7lPqqf9XqWe+OgM2C4InTi1zXdnVw4VuHgJME4E8 0ENzxqrWJAGYthYR+BMpADCNJMEBpRTAdGAzIHBZ4E5/b+kNT/R7fbcJ5gz2q4Epv3zEPbrW8Mrf UOFHpDMrTnXq3CQANnwdzQdTCvRz+nuQBFFt/zMQyY/XV/GVYtv3JNaMggCmM8TbWdY5Y1VrVQWY thYR+BMpADCNJMEBgCnawAoKzBns1wTTFaRAEVAgUqAOmKqdgGlU/eYPAEybD1E1B+eMVdWcqGQI YFpJSJhZTgGA6XLa7tkyVkz3HL19+D5nsAeY7iPG8HK6AgDT6dqtkRNguobKbZQxZ6xqowadFwDT TgtsNaoAwLTRwGzs1upgal9uNftRLv34lv0OoLY55TFE+90k9/imfdHWKo/smheBFHUIHj80j1sa H/PfObUvGAnrZB9147dXdi8jM/YiP7JxGv992zmD/VgwNRolvhuaayPBcamxp1H0/bVY53xM+CKn 9ibabKqdaX8S/rMJ/tTtPxM7ThN8do/Y+jEM20R/PfL5o3YU+NDtGv2S6XNtj46nNOuM7nJrKzDN Xitaxa6tpq+Jvv427Fv70rcbunXANNTLjkXure+F66Vd6Xbn2ZyxqrXKAkxbiwj8iRQYDaZ2cuAm Z2MmBBIa5HbklTlQHiAzmXC4igJrgylNgk/PzudPMGW70m11ysTHTAb8ibiZACz/Ft6+iUY3MdSB lvWV2wNagb6+IrCyGTO2inEaCQhzBvtxYGo0O0+9LCrXRoLjSa10GvkCqlQbSbWlIDhSN9I9jIkt J/8TEdae9FluB8X5u+QzXyOibYXx1/uczrfAe7ptXLM/GSPLl9ucOPPJMJwC01Lb88rO2N7b4W3A tHCtkIAUSzvmp64JE7/cDRRzLXixHdE2WovfmmDqj0VSib7xQqbF9lQF5oxVU8tcKh/AdCllYbea AqPAVE9O5ETM/rbVUDiVkx25naxNzwCZzIODtRRYF0wp1jTpNROX/CA8oHa97WqADf0j5H4717mq 2O4rvzzRCCfg/uTQ5B2kX7EuuTj0x4n8GVS+UvoH5umH5qf8GwOmerJ8dqn0Z9hX5SbGwXFf585j /3haNy6/y+VvyZjKbUql89LqyBm9yCU34bf2tM+chmPllxXtUR7WRG5HCdN165LReS7b+s127Quk PCDpMoot4/PplcRvpuprstRH+OULo7vd3AJMua3qTxE/FlG2T7/tc4pCOwmuKZfjLBVvPtvuJ8C0 3djU9gxgWltR2IMCBQWGg2luwlwYiArlmh9n7yYyYdK+ATJMj/26CqwKpgRJdhIUT3bidhem0fv2 EVVvAh9NhExb5dX+PEBl2nQIc9p+92hVt9JlfaYVYPfobNDWvbxyJSqubxdZOldKW8rbWVGqnC43 KdXXbDZOxj5ft7K03PacwX44mJq66lhH7YF/T1lqar0N0oZtjuvkHzdlde2AU6U/tVaufYh2dNJN 1G9dv1R6DTJse0mTpt0SAGZjyPm89ueXzdciJzWfmWuCE5F/YqXX18XewBTnOZv8pDzn1zNts9hH kBURZ2l0x9vrg6nQMGj/RkY6310rYYxNmlI76dpnKSzedSHhWPt0rujJB+rDzz98oU6Dt+76Ppny kv190P7zY0He0zbB1MSQ6yxvZhltLtTFFb7e/TFJn+f+SOqel+BozswZq1oTCSumrUUE/kQKDAbT 5EAVmdMHsgOLnFzJ7chM3wAZZcCBygqsCaY0ILrVFDv5uHT1MW3Bneef7+BJrteOeFC2A67XZgM7 Ol83yXLF6Y3U5Mra5nLDiXCirG5SEOYN7CfqIOvrfMtoIydVnpYuY7DhlRecy60Wh6tekS/WTu54 WMxaK6aBP5E++jxP1MLPrn3oSZuLvaxrsEIc2EvG0dOC2gaXI7e9RKrvRp5LrWN74m70uOOZDeqr 2Ue5HSY3fbo/kZVpQl3DfZ0/1E8aIN30ZNhcK+wTJ/HsBTHlNL1lcMKdfK4OpoGunuZaM+q3ujZA 5+XNCErS105MO+6uM9l36SKCvskrw15bXdsI24rsV4Nz2q68zsR1G9R7aPNYE0w70DTa5TTwrwFf A62l+25q8LQb6SNgNI79UFUOMx3A9DDjilo1qsBgMA0GjGx1vHSmY3SDlzwnt0NjwUCBTjIUaPn9 9cDUn+zEKx/+4Eo1l5MVua1Vke1KtyM7GZHbOmFst1PVTHDCyYAcuLu0dkuX6098usmD77NceTS5 jS9mklbwi8oQk4dYK1OOLDfyM9AvOi/18072xckmjnT2jHg7cwb7oSumNFHz9Ag1zPkbHNftjFcT xKdn26sdT9LNRDKagLu0Qlcq04uvSzQITA0UnKrzs9P+x36taapX1+64/YpyaVO3CU4XnNO7sv2a 82RXauNPmEMblJ/LTrV/oVGmPDqsy8jpFxa5g/21wbT3WqF2IG4upK8JjmO/wF3+Lk/YbvR3WhmG g2syirm8fqK0sl2Zbb8v7fc3TLEmmOb7D1mv0EMzjvF1qPWW14fUqPcaD20f1/6csao1pbBi2lpE 4E+kQG0w1Z2fGLy8O/2687N3XOV24FXvABmkx259BWqBaTf5SK/i6MmkmOg7GHQDaDzwdm0sPped yETtLZHXyWgG9PxkwCT063YqHiuLbXc++8Di6use34zzOreoDk4XOhqmDfddTrFh0uTqpuMhr1+b sz9OXARp1000+Wjqc85gb8D0PepctB2egHVlmThKjXnb1V9OzrqM5iUvoh4yfpTM6NGtHsms4XYu bVZT1xaEpaj9inO06Z03Maa2cpFY1dI5db27lSvWRX/KNqbtlqCUrMVtKtQr3Pe8pzJcm4vbcFYn 6SdrEB7zCtrXTlUw/eQbxdcKUvHsv1YoDvIaK8Z0hNTajo6bbbfimjbt0vYnyWu16288/7zrIZEW KgAAIABJREFUgZwJ21VQ1oR2UwNM/bad6k9MXFx/Feka1Mter6yb/L52HK9OO23Wy5tqI1HhR3Ng zljVmkgA09YiAn8iBRhMdafFA0Kqk04OCqG5oJOk03KAyG17ZvoHSC85dhZRoBaYlp0z7SUadL22 FrcpOcDKbV2WbGPSjtzWCWO7na99k4HEdxM9+7Ftz0/yMXWN9fmVyEd2u8liRs+uYhFwyVPx5I3P Zux6dbZpU8fYTPA5Z7AftGKa0Itc8GKR8zc47uWx9dDHZBwz5Xl9YKCBnEzL7SCZ349GJ1OrhdyP Fm4SUB3Zf7nN9qk+As75cPwZtw894XawWV7J1zry2CM/df7Yti4/iA8d02VyfWInd3ekKpg+8EC5 /pm227V7ioPflrpzZdN8NmwT3nEbN7LZ9Wecwn4mYk5nTJ5L378orWlHadvmWkmfC3wQuzXAVJjL bPaNRbJecpvM+fs6XvL6iDTqXNCx4pXq7vDRbs0Zq1oTDWDaWkTgT6QAg2l0Ijrgd3Ldaf94NFjp yU1ilVQe74yZCZjsPO25yK7Mg+3qCqwCpnpgTN0lTrQp1ybshJsnvcHkWbcTHlC9gde3aWDBn2h1 IvZNBhhMu7vKply2F5QVwlD4PU7tJ9uK8zq/UnrJ60huu0zBBqVxWgbn3JtPg+OpcnWShK/ZtIHN Fb5jSjFJTjalTtpfjpvwMTie7n/CCW3QNoVG3YqgKMO2C74xQ2Xwtp8quMEXnYzbo7JtjFZOkhqQ DdJBXke8Ted0/Qv+BD5EWkv95HaQL94N2pTO299HkJ0c+MRl7OPImmAaxY8l4muF4hD0G+lrgjMm PnUsw/YYXENcns3uAVKuHek84fddg3ak0/B1HvbvJm322ktUhQ61CqbeNS2ufx0vcaNJ79uYap1l fEkvuZ/R4FgOA0yPJdKoZxMKDAdTnhz5kxVv4KAaeQOL6fD9jjIBqUKJ3gFSpMXmcgqsAaaliY3X ruyExjyedK4urp12E2qekNqVFv1bqEkwJa0sONi0+YlIOHFJ62wGev4OocwTTIoiMO0m/qZOcrIW 5+1Kp3M8ueqO+n50x019/fTRBEQmz0z8BseJYyEBR9oPtucM9r0rppm6GBdMrDSw5dIFx3MamHYq +0Tb54mVvywY6hUNjk86tk4yr191R/0NnaZ7PFe376AeMgP5zr7JbUrD9eL2yZ+cXtrR21R2EHdp w89nNEpff+Ycp8/p3vnI0FqyGXm7iwOrgWmhjXCfeXr2iii+pdjkBfb7YGpXYTuQ7cZbsc/6Kfte WbJflleOttVdK2HblVZy2+2BKc+/bL3OLr2nQ0y8zsXXH/jaMTXU512/xf1SrvbHdXzOWNWaUlgx bS0i8CdSYBSYUu6wQ0/cVfMGFnleTq7kNnuVHXgogZhMcnp8LqbAGmC6mPMHbJiuLZ60t1fNcXAw Z7DvBdP2xDlwj6h/9ie6q1ZYjx0blr9AZVcD0wV8PwaT64BpPSWn3UioV/6eLc0Zq1qrN8C0tYjA n0iB0WAaWcCBQ1QAYNpqVDcGgJIsBAfyRlQp7QqP8vYUj9OVFdjypsmWZVeW0ZkDmDopmtwAmDYZ lkWcApguIiuMQoG0AgDTtC7HfhRg2nALSDw2ub23tFo67vGvOYM9Vky3j3jswfg2ENuYcGTkDZEJ JWySBWC6ieyDCwWYDpZq9wnnjFWtVR4rpq1FBP5ECgBMI0lwQCkFMEUzWFqBOYM9wHTp6MD+1goA TLeOQLn8vYFpuTY4W1JgzlhVsrvFOYDpFqqjzFEKAExHyXU0iQGmRxPqzSo6Z7AHmG4WNhS8kgIA 05WEnlgMwHSicDvMNmesaq26ANPWIgJ/IgUAppEkOLDmiql+CVb8Zkb/51z47YqJl5vY/L2vtg8e f5VvIPTe1piNfu7FPuwbv503NmBeBpZ4zPVAH0GMFUgfmTPYjwVTE+9E+7EvVeM2YGIl3tbJb6n0 vjtr2oJ7CZV+8Y58szLXl9pGHHfZ9lJvJeXc3qfXfmWbS9VJ5LS+8Vt1c28fzelDx1kbYRWbKyiw KphyP8rt3ftMtbHgGlhBj9aKWAdMzbWeuwb1dRu8DTupk45vKo7J1CMPDn2EX7YZsb2DcXDOWDVS zMWTA0wXlxgFzFVgNJiGEx1vwtbjjewc5XaQLT05jCd4QTbsVlRgzRVTE285aIaDsZngn16JJ8lu kl9sh5Rf2JdtT25n9TODaAwR9jhPDPS1EbZTSnOqzs/Sb9OlujvAyZZ/mCfmDPbjwNTE/zwJWX5b 020xaksmTRcnMami0Lg+UbQxHTLKJ9uDbS/Svs2bm3iayBv/L20zkJNRuW1Piw+/bvk3mxv7eX3C eokisLmYAquCqazFiD6xuyakgePYPiQwLfcj5XgOH8Nkvym3zc9TtdyW5oxVZfXWPwswXV9zlDhS gVFgqgcsHw50hyYnWqXy5YAnt4M8qcmhPibhIsiD3boKrAmmSv+eY/cD6fEgaSb4BHf+ig8Nbgb6 Sium4cDp2zcDZBYMGDrOzO+/een0uZ5JO7Vzuj6y7d2HjrpRbNvanMF+DJjqvuPs0vw2Z9RX+fCW 6ntIRf+4P6kyYHqq6MaJ3z5Nu724aeOQaQO+7ThmdL6btPn+mrJ72qAw6bd9c0KXn9Wn/UmjqN5B bbYNpgcl9aTKtACmgx3P9D2cP9Uv8Lny55jxS/abcptKGGOn7NESZ+eMVUv4M8cmwHSOesi7igLD wTTsSNi9YKLEh/s+Cx1lcqKmIUCuPvQVgPNzFFgXTLtVp9Mrp+okugFBbexUXVy/UKfyHLWJKxfq 8tqpgb9khandynYTtuNwPzBy81JdarCI23mynQbZacA3UBHnN0lN+R7wBjYOdXfOYD8cTIW+yT7E j0supv7xoM2wXd0+5Y07224tmE6b/FFZov1yWQy74X5PY4l96NNHKf1YfQT0PQXh9GwFmgJTGq+v nKtzuvminwKQ1wBvX6hzfgSY2otum/ax+EL70W1S5pPKSRvy6QN9/FzRKr9+kuXDNDaI64RQh87x 0yy8z+WI47K4MdstgGmpjudn591YaudbFzRWWg34Zpfu2wJdijGRIpHdUEtdVvd1CC6Hb0CbfW4z t6w10Q9J+41szxmrGqmCcwNg6qTARqsKDAbTERMgr6OTA5LtHPUjaXI7EMefBJqTqWNBNuxWVGB1 MOVVqWByYarEE3x/8KI2QYNcsW3YCQw/BsmDowRBGoS7wTMnog8wlEqXe3ZpJkB2YJd2zV3gbrLE 6cMScsfDdIe2P2ewHwymQfzjWPtxTbclk6ZrI8GkSvSNfn5ut7q1qIsrQ9pZEOXA/3iFVJYR5A13 tS0JznxDqFtxjfUhIyPKCMvE/mQFmgPTE9l25DVgtrsbiuZ6cU+xpNodq0LzADFH8NufseP6VDln sDaz12Tqu+OuHGO3y8vOjPtsDkylPvwUEt/I1edE/6P3u7GJdHeASeecVgbwc1r58SL9gr4i4ZOx JduP0b3lcXDOWDWuVS2fGmC6vMYoYaYCg8HU62AKhXrp7IDFd9TkObkdmNMdFN/Bc5/d5ClIjt0F FFgfTHlyIwZPV69usKO2IQc2mrT4MOAymQ1qZ2KQrQ6mcrKm23Q32OuVJm775E0IGdbVov9BdQ5p d85gPxRMu/ZilYvagz/51bFwfU53199N2rSZYFKl48pxl+e6dsvtLjfBy8Y19DdqQ7KMrBU7YRST T5u0Xx9K6GtUKgXn6inQHpjKMVi2c7lN9Q/3C+1H95kSeIV+Ydu3djWoetecyeP1o3Te9fuhPz1j hnChtNkamHpwSY5rbW3M5DadC/Tz8pZi4glidHU3DrxzZsf0p9xuZBzktkjrYpYwtuGhOWPVhm4n iwaYJmXBwZYUqA2mXgdHFZUdYm47EMQbYPiczsuTPz6Iz6UUqAWmuj3wRL8w6LiYJ+MsJt90nuyI CbrLmxKD07tz4YAY7ruEwUY8uYrLlbbMNj82JT8jOIl8DIo+0N05g70B0/d0jw6e5G5oCLjkdihv JgTQFcU02R5lnONJnunzqK8S7ZbwTq5KDI1p2DaCCWU4wUybNW3Xh2tKaY8LXbid+pNNU1//WLok HK2nQFUw/eQb1amIczGWus0zTNj6RMfkNSC3KX24H/ednkradnedsm/6WhQ+c9vU/Wd4HWiD3fVG ebt+Ni4/us49h4bt1ABTv46B5q5OGXD3+pRQ88Lci+wG+kV9UyYmvjKmTI6XOWeOuVh5X82RPspt a5XKLMwR/LLX3ZszVq3raX9pANN+jZBiYwUYTHsBIujI0m5nOhvvcZLMHTxhMD1oJGyLPNisq0At MB3kVdC2dFv0BqhuwsGPCskXIaXbiy05MdiR/W7SYtqVP7imvI4nNxpAPD////a+Htd23VjzDOwB PYcNnJk4aNjZxk46uCNw4OjcB7QH4MSdnusBeAaG0bGjG+qBRRZZVSzqZ1HSItf6gg1RFFk/X5FF fpK2lpBFPtUbDc9Wr86z4NXqehb7XU9MndgHDPUmTMfViwXVcQ6jIJhcZMZv0RE+mCVuptFmrx4T 6uadDXLlg5wLvMF0ZGY50b8y3vOF5v+OanzIG7oBsD1HhGwUuxE4lZj+85/77fHGaVUn54AsBzX2 XM+xNUPUXKvGvujpzLlwNeb2n/r/sit78MR0k5gKqFVMRD3HWeUFO07UuRwXshyFerlXqXviSc9a 9USzXdUgpi4sqBwJASam2zbViST20fXVpkYmplbZKPcTlNZjuuD0ZATuI6ZeXO1mWm/GaYyJp17+ eEmAeARx5zjUkHqbK1Mn5JJN8jVeFuZsqJptuc+LHnsW+z3ENG5S+eMaAkQRJ35qyJsrfyzFMVqe OJox68SU5cYPxbDuJEfdzLBjndumozN+ZY6VZdMzE4Rit26xD5/QR88/LQVnVyHwDsS0mm9hbub5 YfIrzYX09NCdc/yU0H9l3cp1b9YcCOYZT0y31RkMTAc1/1VeS7mGb6ipa3xDq9w0k3LWY6INqHII 6WG5xgZ1g8Dk0JCtwoeZvDVTq3zKWc9a9RSDV5SCmK6Ag0tjILCfmJakz5u44AElE05+oUIlwJSY ONnIa7JsoKgSY5bLCc90wOnpCNxDTNP4yBsR4QaND36FyWyMzdhxx0sWFXTU44YW4vSamBzP9VNQ FtTaIMT6+OoS62m1DbLMnEjnygZW+eLHnsV+k5i2Nq6EaYxP3JjqWDXHUhqPsU+MYd7YNnTF3Mhj ogRTjr0wbtZj741fOebM09JgJ8+ntJHn1+ryMVxv2BytlPiknM4yixsoXYzAOxDTAKGeD2a+mDG8 Nef4hpA3p5Qe3pN0xPBOYprnLr/anOYj+SR8KT5+LD9+rb/Kmz8CaOd/ym+cO4qc8Iq1iYnELPQT +vP6Rnbyl/S5v8ybshwExnMvblLds8o9a9WzbG7pBTFtIYP6YRA4REyD1Wah4EQmHYobsvQ/I3JD Q8kvbaRkWXbOZLf8zwkn5VGTljH/JU7vIab3QBXGY97Q3KNyvxaaT4Zc7O89dcuexX6TmE6NjDb+ 2eM3bFKHnT8aqpc6exoxfSkUr3PmHmLaYX/YY8n9V4eodtdwE+uE9WvwdbBnrWpj95wrIKbPwR1a DyBwmJgekI2m8yLwSsQ03kU/YfG8IJzPJh0XuLRbZM9i/07E9Lnj96SN5+5RgYaMAIgpIzHmcTRi Sg8E8tPL+ARSP828Bscz1rAzZFzjXZTas1ZdadcjskFMH0ENfW5FAMT0VrinUfZaxDS9jpgX7UHC EO4SX35HexBfHTN6Fvv3IqbPG7/haSneVHEG7w1VIKY3gNyhYjRiyq8x8xtm1z8tZfACCebXdbnu wHGCdbBnrTqAxC1NQUxvgRlKehAAMe1B73X7vhwxfd1QTetZz2L/dsR02ijD8EcRADF9FLl7+o1H TO/x+x219KxVo+EFYjpaRGBPhQCIaQUJKpZlATHFMLgagZ7FHsT06uhA/rMRADF9dgTW9YOYruPz Sld71qrRcAAxHS0isKdCAMS0ggQVtxLT+AXQ1uuC9H8z/CVCc+Q+/AVBPi8BjLLdrwrSx7fEB7aO vOa78uGuonurZL9KuNV+7bp5lYo+JOF8fMwRUePr/C9ukld9AKfzFayexf4oMY1jpO1bfv0tjzHz aprENLTxXsG2Y8pr48Tg9KpTxufpVj0ocMc8Cf6K+cv5IMS0zgnCDBtTIUO0Sl+NdcaO0Sv7nFG+ m5jWuSDmkILhjlg84vik4/UeYtpaH716Xu94XdM5zI+vbvNI+Hb1mTTG7FvPWsUyRjmCmI4SCdjR RGA3MbWLeN7A1b8ZtvXlXto4OJsArz4kU7UhtnYc2fzJ5CjLLjopyTt2yuZXJnsPD6n7yvJ9T0y9 BbZ4RvhuxDjg9PHd+Q00inFYpPXiG2OmN5qE9d6vC26OnWJ/u3TeJk/PESlXln1LCLtfnd/6FM1J /ueX+/+wWrfotKPYs9gfI6ZhjH0tX97/S1I+0eOjMj2No7JBTz9xIccltdFyaJzJNpXgiypOGZ/n 2daHw9YYjrHNP4MhfZflyh2bd+K5Wmuoz8rYST91IsdFpaaj4inE1I5XNa51LI6sT6tjYDVOHQDS 7+9u3JzoED8WMXXGr8ltXgyobu+6dwgrM792x9j0O6TzusY9a9V1Vj0mGcT0MdzQ60YEjhFTvfFy zaQEpBcDWsDEgtda0Lz6UJcX/h2yXZu4UiZHWebr8hiuf35tfgr9ymTv4SFNvLI8HTENxMkssCE2 H1Qvxq1ZrAuGetNV6p3S1thxutRVB/TVnUVN3Djnjbn1L9gq5p7ouPO344L8gF9rw2D0awWrZz2L /RFiSnP082f8zWWLhcWrsrgVJ42Hlwfix0jE2KtkX1Rxyvg8zzYfm73yW/jH/jTHxY0VnTNj37x+ bKjUfYv88DS26UMYP3ZMbejZe3kIYpp+X7Im7OnmzMaNW/a1iV9ocNl41XOUbTnrOBQxbeSxMKY5 dm4MGv36MTLY746x6ddvyCkSetaqUww4UQiI6YlgQtQ1CJxLTFubCJ1svA1A8K6uD/34ydY+2btR Wk2UvKFp6Sxarkz2NR5F79Wl6Yjprz+XH9/FTQzaUNkf+F7aG0z+/dw9m8xq7MRxUl4H5TEbo0Rj hN8wyPLN2CKZxX6KfdXHiXroJzeH1jZ7rkSE+bVBnEL/ZLM/HnmuKMG7TnoW+/3EVNjnbcK8Omn9 1nVuSzhvYMltw5Hl/vq18LgJG0g5VnhDyd3UmJAx59yZxsvXZ5Apx2DMv6xnnaittCWbvdcE01im m0B8PeknXFIdjaMUD7JRvG2zJVuQT8Zj4Tn+L65JduS29pzb+cd6fCdbfxPxyrpYxo45xE0PHscj pgVPOU5L/mmMnWoMGCDo+tfy49cPNRdkq7WxH4ktjzsmYtHWfWNeatpfHoqYpqfDNmdIb7y9ilcn +4RyC3s7X4osB/sUY30DlWPGedPpl26McBzLWLNWXnves1Zda9lx6SCmxzFDj5sROJWY8marWry1 Uzah8dWqPiQz3oDtlB1ktRKpujNrEyUbEY6kK26sSrKVDUrZu17X6YSrN42szyZpQ9TTxo0WngqL uCHgDWfE8QcRtZjQ5Sa12L5WGoqYMkGTx0zwIk55Uy/HS2hjsKrGmARhbUystKN4s177hMHILPrj mKB4mjY0Th3/pAlcDvLUZiTIEn3lWOY++ZjGVF70nf/JU/KpfT2WtP9Z+mahZ7HfTUyNzcqfYKGD QcCD55LKGRseUWzzGK1xUt1ZL48bGgMlloSpIJc6p8T5nuOuxg/nGtYvxln2lzeCyqL8BD3LJRu5 rc4x2j5fJ+dubXtqK8eoeeXSk51tkiab2EaiKmKX1gK3r5STcdF97dypxk6S0aq3Ko6eD0FMaWzx GNBjicY7j18373G/9RuCTCxznJRO21fbUL2VoOaCHrNH8d9qPxYx5SfPvI8wY5lvvOb8xO04T/je 6rmr846Ov42TwX4tLivXSL8ZYzk3+yZfUtuzVl1iUIdQENMO8ND1HgSOEVNOZvJYFp+9mzib0NhT Wx+Skl6s1pNokLOWSJV9KhmyBfGok2FIsMJH3VQ94SgbfG2nluctrGIREXZlPNQGkTfT0ia9CFA/ sbmmc7URNE44p0MR0w3bg380TgJOqW3G3GCXMXV8VuPDu851IkZcVY7ri3dpl8ZB+N9YQUDoOskX Y6J0MqUoQy3Uoa/Eq9q8CxGkR4wje06EQY5lR18154T8jWLPYr+XmIZxkHNIsMfFR2BgbSZMJAa2 gXcexwDlAxkL2dSMy0iChB1Kr80ZOs9VY1r2deKf54u0J5StTfK6lEn1MufU9kmbaC5mHOq29bxb l53NCjZluaG2Hp9NX7OQUEjxyhvgeHFz7CQZ0lcltvPkKcS0Ii4yD+nYKb+rsaPb6jFggLFjS8mq Y1rNYSGO9OR8KseRaHRScThiKvyi2FAsS05xY0DYlzZCRJ5PMn9KGSr+1TpgsJcxXp23ul+MZ8s+ be2VZz1r1ZV2PSIbxPQR1NDnVgSOEdONBCGTz4oXNqFxU10fFiShb5dsvRgGuTKRqg1QU57Ru3HX XclnR0i2sJ3r6RgTb072TTvSE9PvH8uHJcZq4Q5CdTInHOWGrWqvDHJPziKmZAtvdqRNWau2PVen gouvaRR0RDyDrIC72MwY39fkrV1TKm3M6Jxv1nwsH9/Znno8FjnxWvgwU2lfrsaxyjLl5lC0cTbi aoyHptZW2b0qa3sJD46dPNo4Bh22rpJdV/Qs9pGY/nn5EnblOZVVxbFVbhg5eJrxkbtyYes6t3OP UX9tl0MCrR4Vt3qOlLGqY0ZmkKxEptXYLP7z00xlttKprug8SpekTbUNMpcXW0PHuq2+Htqsy86W VePOyrbnuacoRF01HqlejC8eR+pGEK8xhtQKBQ8XTyWm/+//LB/CF+tDMLKOgzVd4yljXOcZ3XZV th13ai604sA3i6Iejg19BG8iYkq45LiwTxJ3jWO5IudIqbUlilHKzX4MWvKDpFqHlKHiX40f01fE WPtcclJZw/V6p9u39lXW83PPe9aqcy3plwZi2o8hJFyMABNTSjKcIL1NplosGkbtaVMlsCJLJ7qQ 2ESi3iXbJEOrSyTHeiFNdlCbkix5waueaqXmMlEXT0yyVzI1EfH7R0kxJrG92jhVWGi/NY5BVrh+ LKGfRUwLJq2Stt22WsOH2wZ/efNPZfkhJIuVPWchzoY5XzL4aZtMrI2cOhYsVfRr2hTbkj45F1iE R0xJlpg3Yex58znLkIVoU9y0yrJo49iq8RBtN4o9i/2uJ6YN31VMHH+02SJO6oKsb2BlxoLqbvXa c8oZHEepK0qRmCt/wmXZl+SyHGVBfWJtkC2kTKqX87a2T9okbfWIqbJ3h+xslhPfoJdzAevySFiU EX0o7bPk+sl6uiT94tZeHV/rOZ5KTP/5z01TdJy85jrOyu9q7Oi2q7Lt2FKyopxmDG1fdS7HqOdP X909T0w1jtlihVG6qeDcHJG4y3KWs5ajnGtShoq/3WtZUivjEsrNNWk9ZqSz2bd4dXapZ60625Ze eSCmvQii/+UIMDHdVGQSod++kURNgpPJrcgxfUPyUonWXM8dZb0sxwZKl02OzmY/JL56o9JOlkr+ LpuMjdKm3D8WSuI3+qtY6OtV8q7aG0XO6azENG5y7UdVNCmnmJnYE2amrsCiY1biElrEa3msUjzF GDLxLeNFyyz1zpOLIKOxGAdb9HiVcmW5eMMlqZM8oY+PJBJDY8YjNLVMkqPmKmtYP/Ys9nuIaY1N skfGZM/cSDGVm2PyWYyXeK7HWRyLpo4hsXrtubSxsenLcae2RY8eyzZeMVfkvmwPHf220W+dY7T/ tp/+/3hqm8dv3dY+mdmSnU32xqjETZZzJy5EO/K85ep03DV2ttoamUdPpyKmZo23Y1+PAYOEjZOZ C7YvjW8eT2rsp5jmeanHrNHafXoPMU3rgbmxrDAInhBmdi3Qc93iSAAo/GpIdB9HXsY6Yc9xWSOm 9lqy3csz5KdYW8gecV5bfE1Nz1p1jUWPSwUxfRw79LwJgXOJKd+t917FEJtcL4maBBkSktwIEhzU RtdTosrJ0W7qdSJVd+ZJlrCJFIT2ZYMnQ2ATJF/TiTvVKl/MBij5UDaG0cbsq1iUlU5lr+dXwYX6 CT/oPC8YbPn68W5iWp5Mp6fVyd4YX+8JdlmEg3978FQepzhkvVuLXRqzsb0ZN1LW58/q69LaB+4b x4W1m89jDNlvf0ySP0G3tV3aquIedeaxxoSH35SwY8bKTQDqOVfLVDivnPQs9pvEVMyj2gQxf1bb iZ4S04CXwjW1k+OAMOVYCzlctHrtOcnS/dWYMLGRYyz+RJLsG/3dN9Z1Wx6PZLbCQI5JO5Y1MeVN c3zrpG57VDZDGG8KSTviFYmTHOvqzRHlC8+zFFcbi6Iwv95YcAl41TaoLg+ejE5M803APBf02FHY Z7zluEzA2LHu4C9jqt9eiuMpju36K+zcr8TrwWA43e4ipkG1nN/ka8ZcGqbxD+1kDCoZKe/LNlIa lxlD0qvyjtT3sfwIXxgXdnE/wt6NcZl3Mj6qH9/4zWuUM37Y0AuPPWvVhWY9JBrE9CHY0OlOBI4R 05JI4kKQzkUyItvzItS4HhrZNmpxD4tNY7G3/azusHX4FHbKRCqToywnwClxO/LoMrWvbdqV7Klv sskhLhYLXijIj2x/WoDTudL7Gb/Aq/uF32BlHI4n8/uIaQIfhwcRCJuD4/F9UFndjebjY/p7FvtN YlpbipoXRCDkQbmpvd3FkNtba0anMXcT005z3677ncT07cAdzOGetWowVxYQ09EiAnsqBHYT06on KkZFQBPax6wEMX0Mt2f0eubmvEd3z2IPYvqMkTaizufemAm5lm8Ino0OiOnZiJ4rD8SOTZaQAAAa KElEQVT0XDxHltazVo3mF4jpaBGBPRUCIKYVJNNXgJhOH8KDDqy8YXBQ0qHm4Wlpx9OinsUexPRQ pF67cXhqmd8sudHVi/WCmN4YywdUgZg+ANqkXXrWqtFcBjEdLSKwp0IAxLSCZPoKENPpQ/gWDvQs 9iCmbzFE3tpJENOxww9iOnZ8zrSuZ606044zZIGYnoEiZFyKAIjppfBOKxyv8k4bumkM71nsQUyn CTMMfRABENMHgbupG4jpTUAPoKZnrRrAfGUCiKmCAycjIgBiOmJUnm8TiOnzY/DqFvQs9nuJKX8k rP5ATvma51X/I/jq8av906+UM/bhQ3k1/nVvqln7mFD68F0lq/OV8oYlT68GMX16CFYNuJWYtsa+ sJDelMofPGz873OSkz9eKf8VI8w98yVfFk+yZVu+UB3jl3r7cmrMzdU8r3TdV9GzVt1n5T5NIKb7 cEKrJyKwm5jahCYSYPX/PbatSWitV029+urjKhuyV6GkxJu+ICrLppNN8DGJr315VH42nb+EK35L 08g/dLpi5yE5BxuDmB4EDM0PI9Cz2B8ipt8/6v+FFXmkbxN12O2qg5f3qkanV5yxgdRGqVxN+Kav mMuy7qLP0sa49ZVbkv/5Vccy/ZzGSBtZ7dhjZyCmj+F2V687iena2M+/pS33WSm/qdyW5peso9wj +gU91fw7tAc5I6+AmF45hkFMr0QXsk9B4BgxrX8upTJiR/JrbcS8+lCXE+kO2ZU9skImWFmWbfjn ZszHNGwC1128ZBzrujdLK3ZqG849AzE9F09IqxG4jZh+hp9OMrkrzCuqF/mlNvGWGi/vXa/Yy1k9 WoO8cvPObnCDj2u5kDD49rF8fTobYzIryA8xbNmt9fd4MkpfENNRIuHbcR8x3Rj7jT2CnoMtsmfn Uzwvc9Ve97EotUfbl54jl3rWqtH8AjEdLSKwp0LgXGK6L/m1NmJ1fUhyvNnZJ7tysFXRSOaheW3H ssQfE2dbrFA/GbtybNet8xU7t7r2XAcx7UEPffcg0LPYH3pimn47uGy24hz/+q2etzRn89sghsyK p6zfvn8tX98L2YpzXf528EpfQZJp88j68s2waBe/bpdvzOXcFH+3uLzJIdvrHKXk5ycjMZda+X5b /s3pr+Ur/T60tCfHmYj+z3xqc589zw1T4edvsa/eTItWQX6y35cVfXJtE2JmKoKYjh2t24jpxtj3 54PBbu9bC6Gb2HM056MUT+35d9pjDpTzkOyrcpyzn8t662u+jGCEzH3mJqO0S+Rcafrecs9atVfH Xe1ATO9CGnoeRuBUYroz+bUSaVUfEgtv1nbKDkA0k1hOfDr5WvAqO1gm22I7pOQokzEnTFWnEmXZ 1LI4125p85I2lI0NmlpEGK9f4/+NhE2o3JizztYRxLSFDOrPQqBnsT9KTGmzlYlZ2MwEAhc3NXmO hrmW29gbVGazlOYyz6k4dwsZpfMsy9GTb7jt0WPk5k1WygdZVtTDNskNZoiZzmsHbKJcsp4/guys N+mS55SbmvmzjCiVw0o12Z7lkT2agIeme3UIsUMXQUyHDs9yFzFVc6sa+yYvtSBT+4hWo1If89fH 8pFzTbmmSzqP0BwU/6eq57O2VV+T+Wmtnbwmy3wDjXNlsIvLab+X87H2YM9Zz1q1R/6dbUBM70Qb uh5C4BgxFf8/yXfA7OTPm6S2OXqDVNrZ+pC48mZkZ2LVyW5lo7Yij+zI/iWfV5Na1MNPIPiYbScX nUQpsNJ2i4Sb7RR1CTIPr7yxTptJe5434QV2twRi6sKCyhMR6FnsDxNTIqGJzIQ5RfM5zlt/TsT5 1r4xpufj6lzM+hi82Jf1qr40b8WGKt2M4lyi2lZks7aJ+5FmtanVvge5zbaVTewHH7U/odbKo/z2 MDENtkoiWusLOnUOZdvmPYKYjh27e4jp1tjXc76JWN5HNFvoC2n/oHKCbhHPKrkyrzjzVOZClVdC W8570idZNgaofBavlbwT7cj523Q9etqzVh3VdXV7ENOrEYb8bgSOEVNOHA21VZLy29nNFbfS9TJR rT/h5P78EQCZTNVmRdony0UAlbQd8SLJUZsj2UkmY66PCbWVGLW8leRLdoaPt5iNY7UpNRuztLDw 5jdY5fnF1tojiKlFBOdnI9Cz2Edi+uflS9xAkvOebaV5RoQozrEwH8I8iG3NvE1zJt5YinMuz98q X+g5a+eWzDtxrtc39dhe1fegHtVXkdiUfwQ+7NePfwV0pO8bbdUGkpGVx4It12q79uceiRvLauGX b7pxw4Dd6g1EbjjHEcR07DidQUz12JY3X6Lv+rrIIWKc27nmorY5h20vmR/stXJez1eZC6IMvlFf jsXPYDvlwWBf9inKcHN0UZ1eORaYcK7LN8CM/lwvhewr96xV+zTc1wrE9D6soelBBJiYUnLjiZ0T hBC6J7HtabNyZ1sn2JBUSgJbdsmuk6lKnHLTJ8vCzVDUdvDFWjZf0Zu8UqtfpdObv4/vH8u37N+K bLLz26LbRx3WTuWrgxdd35mcQUxFHFG8BIGexf74E1N+1VN+CEnPOzuf1Hk1n+Tmqc4Zai5uEKYe PaqvIqaSgHvhq31noly1rny3LeRmNF6zuSbY2ZQvxCncqL6WTdWOTXVfIXjCIojp2EE7g5iue7hz 7Lf2Mqpe56uit1Wv80Npb0pKR7gm+zXslyJSbvwp345TeaxlH7+6K/aIUq4tU74w/4Nq26yc96xV K2KfcgnE9CmwQ+kRBJiYbvZxNgJ1n1YS0fX+BkK3IVKnSJS5npXLelmODZQumURlOcuKBb3Z44sy 4XIdHxvXpA5ZDt3UeW03S5btrF32XPnqJGLbPutwCiCmDiioOhWBnsX+EWIab259E0/V9Lyl+cE3 5dL8yU9M1WaJ528hW3ZuqbmoNmu8oSqbJN3X5ALKE+VNFd3WEmKvb9m4kU2tm2EqHyUSz2135P5g lyKeso8sb4wgjRtjVXwo3Y2vfMNTrRml9YwlENOxo3Y5MaV5s2fsx7mg3xaIuU3NSZrjJe8EdHVO kHjr3Civ6LLRY3TY+Uz5i3MsCYr9y036UKnntiuD5rlux6SYfK5yTtBT8qj2YfusZ63aln5vCxDT e/GGtgcQOJeYlg2bfIW0Sn6UNMxGxtmASRnkmkl6oc7K1knMS5op0ZMsL+nbzV4E1erRUEc92t60 WPBGSfmXrvHGj/0QCTtvQJWdWo+2KclkGQnjvLFO59pG7YU8AzGVaKB8BQI9i/1DxNRseHgjk+cE z5nw5sj3H0u4i682e/L6Z/wyLm/88nxNQOk8xASrvHbG/ah5ymtFV5zn/Opbts95m0PrtRs1zo+s V2/MqK/4KFrMJ05b8lv3rcZD8IFzncQgvYWj/E1xkH6xPIub9o9bxaOX/zyZutc8ZyCmY8fqamK6 f+xHnHg+e3kjIylzWMpz/z9flAW915BXqrKUmb5WLuehtqvec9V+1nlMyeA9Dhmic6XKQZxX3RxU ebFa0bNWrQp+wkUQ0yeADpXHEDhGTHnTYo4qUdSbsLLhErbJZEaJQ258QmKS5yv9rG7evKVkVCeq ncSU++djwx4yzSRH7qNsS8SRrn0sP377UX3xzk2+ipjyRpOTu9T7sfwIX+BlnWkzSb8LmOzRm0OB qVMEMXVAQdWpCPQs9nuJ6akGK2FxPssNmLr8dichF3FeeoLzlO+eqP8Cl0FMLwD1RJFXE9MTTYWo TgR61qpO1ad3BzE9HVIIPBuB3cT0bMWQdy0CiZjGD50cVwViehwz9DiGQM9ifz8xDcRL3JyiG0bi /JjrL9k6PME8cvPrTBCeqftMP6QsEFOJxnhlENPxYnKVRT1r1VU2PSoXxPRR5NDvNgRATG+D+l5F IKb34g1thxHoWezvJ6b8tkJ5WwRPS23IV950sU3PPA+5jt8UOVPuk2WBmD45ABvqQUw3AHqhyz1r 1WgwgJiOFhHYUyEAYlpB8hoVIKavEccX9qJnsX8GMX3hUMC1AREAMR0wKMKkM4jpL7/8suBvfAx6 1ioxZIYogpgOEQYYsYYAiOkaOu97Da/yvm/s7/K8Z7EHMb0rStDzLARATJ+F/D69PcR0nwa0AgLn IwBiej6mkHgyAiCmJwP6IuJATF8kkAO7cSsxNV9oVB9FMxjFr73K/x+VHy4rr/Ly1y+9/6usvzRp lJx2Wj6A5tlxmppKkHltl97QSNhsvVa72rb408Y3tTFfAQ4mBtxf5RVrENNq0A1VAWI6VDhgzE4E QEx3AoVmz0MAxPR52I+sGcR05Oi8hm13EVP9syIRu/gFbO8rrpFwha9Z+0QvklT/WonLbmLa+co9 +bZFBItZp5X0x4YkJrLsqZPXZTm1JTy8uAhZ4SbD51fjK8CBtG70F6JGLp5JTP/whz8s+Dsfg7/8 5S8jDyHYBgQqBEBMK0hQMRoCIKajRWQMe0BMx4jDK1txCzFtEj+HFAWwA+kJRI+esHoEp9Hv0UA1 7dsnkIip8+RwX+9HWxnyZ31gDD3xW23X+pK8iP/Xb+04aNLsGTFH3VnEdA5vYSUQAAJ3IABiegfK 0NGFAIhpF3wv2xnE9GVDO4xjdxDTtSeK3rXwpDM+DY2vi9avhbYJkQS2PDFN7T+/lg/+feP8RC+9 ksq/bfyvKIHs4rbyaSiRuq/l6zO+Mvu/Pz8Wft31G8ukNuJ1Y0Nam7IXacvG67CBPEq5lsTbcwmM vWbOyT4pW/YN5YTBzyV9JVniw22DTK+er09yBDGdJFAwEwhMhACI6UTBeldTQUzfNfLrfoOYruOD q/0I3EFMC0F07DWkaCFyVv631CdJjxHTTByX2D8TO+8JIpPM9D+Tui0T5+gP2ZhJWJSdyfRu2cYn 289AV8h7umCJoCCPpmt5Is0XTFuKF5PycMy+xQ46JoFMl3ixSBvHUj9XCcR0rnjBWiAwAwIgpjNE 6c1tBDF98wHQcB/EtAEMqk9DYDhiGgiWfFpnSFN03JC4BhqFENftyzV+AljIVUX6pA1ULm2Dak1M jTFEvEt7pVc2lTpSfWVHbm/Ib6g/jZhG2SUG3nnxJ6j27Ww97c5OTFEAMZ0iTDASCEyFAIjpVOF6 T2NBTN8z7lteg5huIYTrvQj0E9M/L1/i6Zr3QaI14qavJRIk5PFrslpubKfraiQKCazbl2uWmLZs SGRsBzEl2ezD94/lIz9RrO3IVhOBFa//cn9J0nPjKCc/lQ311F/8P649z30PtrWyW3aKJ8xRlWOj tGGSMojpJIGCmUBgIgRATCcK1ruaCmL6rpFf9xvEdB0fXO1HoJ+Y/mPbCIfMxU6GqDlPDUM7TV6p ZvnxXb9O6xlRyKfR476eW54Chn5N0uv4ouyz1815sclY3PDdtEqnDumz/QOBNK/gZllH2oZOQpaP jfd01KvLFkxTADGdJlQwFAhMgwCI6TShel9DQUzfN/ZrnoOYrqGDa2cgcAsxZXJpnqoRSRN1RPC8 J4SG3C3pf0Sb5DEBU0jgMWJqnz6SXWxnZYshznS9fLgo+lhIryubCKS1MRK7lo81QZT9ZdkbJfK6 LIe2llBKO0JZ+CJEF6y5st2WW8xwBDGdIUqwEQjMhQCI6VzxektrQUzfMuybToOYbkKEBp0I3EVM yUz7GqgioZYQScciebL/99gibdyzkCVLvuL/RVp54bVhfj02klF+tVaQsS1iyk9j06u4X7/VfmnZ 4vVb81XeYh97JI4BS4Ufv5KcbFZPS6P/7BtJSQSaXpVWbcPVaDO/Rs16yO6qbbKJYitwEk9ZhdXT FUFMpwsZDAYCwyMAYjp8iGAgiCnGgIcAiKmHCurOROBWYnqm4W8vK5BHSWrHAqR+ojuWfXutATHd ixTaAQEgsBcBENO9SKHd0xAAMX0a9EMrBjEdOjwvYRyI6bxhDE8wt54aP8e7sUnzEUxATI+ghbZA AAjsQQDEdA9KaPNUBEBMnwr/sMpBTIcNzcsYBmI6cyjDK7ri9dlBXAlPS9Vrw4PY9YgZIKaPoIY+ QAAIrCEAYrqGDq4NgQCI6RBhGM6Is4jpL7/8suAPGHhjAMR0uGkPgwZCAMR0oGDAFCDwIgiAmL5I IF/ZDRDTV47u476dQUz//e9/L/gDBmtj4Pfff39okP71r39d/vGPHT8X85B0dAICz0cAxPT5MYAF QODVEAAxfbWIvqA/IKYvGNQTXOolpieYABFAoIkAiGkTGlx4EQRATF8kkHADCAyEAIjpQMGAKT4C u4mp/MR/+jmC8En/Z38AQ//8Af/EwkD/ZxRwc37mYM+XI2vf6i9hxjbO/3o19PqjoK4FMa0xQc04 CICYjhMLWHINAiCm1+AKqUDgnREAMX3n6E/i+zFiaghQIqtXf2yi/CZgDSoRM0v87O/a1d1uqvE/ EEL+7CD12+Q1yv/69L+QGbB59MYBiOlNQwRqHkIAxPQh2NBpIgRATCcKFkwFApMgAGI6SaDe2cwu YrrEH09/lPzsxf0wMb3Jrk37qx+iTz8e//1r+fq+9bQ5YrtK+vmH5ImI109T44/Ve/Wbli8gptsY ocXzEAAxfR720HwPAiCm9+AMLUDgnRAAMX2naE/qaxcxpSem/lPU8Jrvt2/m2pKIWXoVWJGu9PQ1 9iuv4qrXWT9/Vii7T0wNMbXEVvVJpO7Hrx+L1M1PNUNdtpP9/fUrt10j5UFG7kuW/1x+/hYKewh9 wMrip90P8qP+iKvWVfTU9VqOdwZi6qGCulEQADEdJRKw4yoEQEyvQhZygcD7IgBi+r6xn8bzY8S0 /A+nJHHFWU2QIqnkJ3aGjBEhZOJlng4SAeR+y2KJZdG3LIpk8gUlu+6v+lBbJnhJniCjpJtfFWby bM594rdGLA0WbLc8si7x/7xaj5ZPPrWIu1MvVXllEFMPFdSNggCI6SiRgB1XIQBiehWykAsE3hcB ENP3jf00nh8jpkwk2b1IRPNTw/T0sTzXFESVnzb+i/tKchbL35jwcZN03CSmgrx5hNn2r4lpIcGL 8UG1TWRREkQrO5tObYXcfCEUpO/qQjkx5DraJfAP1yXhbOhT9hfpmyUQ002I0OCJCICYPhF8qL4F ARDTW2CGEiDwVgiAmL5VuOd0lokpESwmeB5BrIhl9FcSH1mOVwUxNYSvJmeJnDo2NMlfoHjhFVzP XhEO21/1sXaZc9XWwYCuS4LIehtEMaG2/Nj8H1MWxEdJZg1WjJn3QaXgzwY+rEEeQUwlGiiPhgCI 6WgRgT1nIwBiejaikAcEgACIKcbA8AgwMd001CFloY8ibobUxY/vpP+zrPpLomW16yexlljK1kq/ vCDKtr/qY20256ot+aD/b9TKzmovIqb0tLYhW9maDPHqso0rBRDTFXBw6ekIgJg+PQQw4GIEQEwv BhjigcAbIgBi+oZBn83lPmKqCaQiokxav/HrrIaIEgHkV1PFk1UCMLblV2ab5I91bDwRJHJm7MhP EQ0R3fMqb36F1iGqJf7BJ/av1MaSwcJedvySPlC5+ZRW62y2dXTKKhBTiQbKoyEAYjpaRGDP2QiA mJ6NKOQBASAAYooxMDwCx4hp/fGjTNLY00TW4v96apLExNX7P9BF9fum/3+SyOM395VUIl4bxFTr /Vh+hK/qcp/DxPRjCb8byj7k/69l/8UxEGom16I60E7nVV5NxkP7SEYZc8bSkngpOcooMallytZr ZRDTNXRw7dkIgJg+OwLQfzUCIKZXIwz5QOD9EAAxfb+YT+fxbmI6nWcXGEzkmQniDvmB9HpPNnd0 PaUJ2ctPrI9JBDE9hhda34sAiOm9eEPb/QiAmN6POTQCgVdHAMT01SP8Av6BmB4I4lFiSk9GDxDZ A6bsaRqeuK490V2TAWK6hg6uPRsBENNnRwD6r0YAxPRqhCEfCLwfAiCm7xfz6TxmYvr3v/99wd8G Bv/9x+W/vv3X8sf/3mgnsQx9/tcfl/8r6+4od+oFMZ1uKr+VwSCmbxXut3QWxPQtww6ngcClCICY XgovhJ+BQCCmf/vb3/AHDKox8J///OeMIQYZQOB0BEBMT4cUAgdDAMR0sIDAHCDwAgiAmL5AEOEC EAACQAAIjIVAIKZ/+tOf8AcMXnoMjDXrYA0QAAKzIwBiOnsEYT8QAAJAAAgMh8Dvv/++4A8YvPoY GG7iwSAgAASmRgDEdOrwwXggAASAABAAAkAACAABIAAEgMD8CICYzh9DeAAEgAAQAAJAAAgAASAA BIAAEJgaARDTqcMH44EAEAACQAAIAAEgAASAABAAAvMjAGI6fwzhARAAAkAACAABIAAEgAAQAAJA YGoEQEynDh+MBwJAAAgAASAABIAAEAACQAAIzI8AiOn8MYQHQAAIAAEgAASAABAAAkAACACBqREA MZ06fDAeCAABIAAEgAAQAAJAAAgAASAwPwIgpvPHEB4AASAABIAAEAACQAAIAAEgAASmRgDEdOrw wXggAASAABAAAkAACAABIAAEgMD8CICYzh9DeAAEgAAQAAJAAAgAASAABIAAEJgaARDTqcMH44EA EAACQAAIAAEgAASAABAAAvMjAGI6fwzhARAAAkAACAABIAAEgAAQAAJAYGoEQEynDh+MBwJAAAgA ASAABIAAEAACQAAIzI8AiOn8MYQHQAAIAAEgAASAABAAAkAACACBqREAMZ06fDAeCAABIAAEgAAQ AAJAAAgAASAwPwIgpvPHEB4AASAABIAAEAACQAAIAAEgAASmRgDEdOrwwXggAASAABAAAkAACAAB IAAEgMD8CICYzh9DeAAEgAAQAAJAAAgAASAABIAAEJgaARDTqcMH44EAEAACQAAIAAEgAASAABAA AvMjAGI6fwzhARAAAkAACAABIAAEgAAQAAJAYGoEQEynDh+MBwJAAAgAASAABIAAEAACQAAIzI8A iOn8MYQHQAAIAAEgAASAABAAAkAACACBqRH4H/TD7BffprVpAAAAAElFTkSuQmCC ________________________________________________________________________________
Date: Sep 30, 2020
Subject: Re: Z101 with Garmin GAD 27 voltage stabilizer
This will be going into a retrofit of a flying RV-7A, equipped for IFR, with an electrically-dependent engine. Dual SDS CPI-2 ignition, but mechanical fuel injection & engine-driven fuel pump. I haven't developed the schematic yet, but it is almost 100% Z101. The only divergence is the GAD-27 & powering several devices off of two of the busses vs. just one. Maybe that's overkill. --- David Carter david(at)carter.net On Wed, Sep 30, 2020 at 6:52 PM Jeff Luckey wrote: > David, > > Wow! That's a lot of busses! I count 4? What airplane is this going in? > IIRC, you have an electrically-dependent engine, right? > > The block diagram is not super useful for circuit analysis 'cuz it doesn't > show how it's wired. In other words, one could come up with lots of > different way to implement what's shown on this Block diagram. For > meaningful analysis it would be easier to have a view that is "closer to > the metal". > > Do you have an actual schematic? That might be more useful to the group > to analyze. > > > -Jeff Luckey > > david(at)carter.net> wrote: > > > I have attached a power distribution block diagram (not a schematic) that > I have been working on. I'm trying to puzzle through how best to take > advantage of the voltage stabilizer built into the Garmin GAD 27. > > The GAD 27 is Garmin's electrical system controller. It's a combo box that > bundles several functions, including the voltage stabilizer, trim mixer, > flap controller, wigwag control, panel light dimmer, etc. > > I'm focused on how to best leverage the voltage stabilizer function to > keep things running smoothly during engine start, and how to build in > additional redundancy by using the dual diode-isolated power inputs > available in many of the Garmin boxes by powering them both from the GAD 27 > on the main bus, and from the Aux bus. I will admit that the failure modes > in Z101 where this redundancy would be used should be exceedingly rare. But > the dual power inputs are there, why not use them? > > I have also highlighted 3 devices that have dual power inputs that I'm not > planning to use. One of those, the G5 SFD, has it's own attached backup > battery. > > I appreciate any suggestions this group can provide. > > [image: image.png] > > > --- > David Carter > david(at)carter.net > ________________________________________________________________________________
Date: Sep 30, 2020
Subject: Re: antenna analyzer? Antennas
At 05:33 PM 9/30/2020, you wrote: >"mast" Coax to ring or ring to ground plane? the ring to ground plane . . . >So increasing ring to ground plane to a maybe 3/4" piece of tubing >would increase bandwidth? no . . . that radiator is a fraction of a wavelength. It resonates based on the reactive (capacitive) effects of the ring. >But probably not significantly enough to say 1:3 SWR over the 118-136MHz band? Interesting experiement . . . it might get wider but probably way short of design goals. >Finn > >On 9/30/2020 5:04 PM, Robert L. Nuckolls, III wrote: >>> >>> >>>Would love to have someone else experiment with it and see if they >>>somehow could get 1:3 SWR over 118-136MHz. >> >> It's been some years since I built one of these >> (back in the days before vna's) and a similar >> interval since I reviewed the literature. >> >> Poked around on the 'net and my archives a bit >> and I think I can confidently offer an explanation >> for the fruitlessness of your endeavors. >> >> The DDRR is a vertically polarized antenna wherein >> the very short vertical mast is the radiator. >> All that other stuff is a loading reactance for >> the antenna . . . or 'top hat' in some circles. >> >> Given that the radiation from an antenna is >> proportional to the current flowing in the radiator >> then it follows that this diminutive antenna >> must have some bodacious currents. Further, where >> the currents are high, losses need to be low >> to minimize energy lost to heating. >> >> My assertion about larger diameters improving >> bandwidth was incorrectly applied to this >> discussion. L/d ratio as it goes to bandwidth >> works only in the resonant radiating portions of the >> antenna . . . in this case, the mast. All >> that stuff setting on top has a rapidly >> diminishing current flow and besides, that >> part doesn't radiate. >> >> More surface area (diameter) helps this antenna >> only in the radiator . . . the mast supporting >> the top hat. Increasing surface area in the loading >> portion goes to increased Q which means narrower >> bandwidth. >> >> The governing triad is profoundly demonstrated >> in the magnetic loop antennas used on the HF >> ham bands. There are very useful loop antennas crafted >> for the 80M (3.5 to 4.0 Mhz) ham band where >> the radiator is built from 1-2" copper pipe with >> soldered joints in 45 degree elbows employed >> to make an 8-sided 'circle'. The Q of these >> antennas is very high which means hi currents >> at the feedpoint, high voltages at the tuning >> gap. The bandwidth of these antennas is very >> narrow. The operator has to tune the antenna >> in lockstep with his transceiver in order to >> 'cruise' that band for contacts. >> >>http://www.oh2gqc.com/wp-content/uploads/2017/09/20170911_160930.jpg >> >> Several sages in the design and fabrication >> of antennas have noted, "one can strive for >> (1) efficiency, (2) size and/or (3) bandwidth >> with one overpowering caveat. Optimizing any two >> qualities calls for degrading the third. So pick >> two goals and live with consequences for the >> third." >> >> Therefore, your experience with the DDRR was >> predictable. Yeah, you can get a really useful, >> small profile antenna but because SIZE was >> diminished, bandwidth suffers. >> >> I thank you for sharing the results of your >> experiment. >> >> Bob . . . > > > >[] > Virus-free. > www.avast.com > Bob . . . ________________________________________________________________________________
Date: Sep 30, 2020
I did a bit of web browsing on the DDRR. This thread is about a 2 meter version (above our comm band): https://forums.qrz.com/index.php?threads/2m-ddrr-antenna-for-vehicle-some-questions.368057/ The thread contains this sentence: "The DDRR is an inverted-L. A 3" tall, 146 MHz DDRR has a radiation resistance of 3.0 ohms. The 2:1 VSWR bandwidth is 1.5 MHz." On 9/30/2020 7:27 PM, Robert L. Nuckolls, III wrote: > At 05:33 PM 9/30/2020, you wrote: > >> "mast" Coax to ring or ring to ground plane? > > the ring to ground plane . . . > > >> So increasing ring to ground plane to a maybe 3/4" piece of tubing >> would increase bandwidth? > > no . . . that radiator is a fraction of a wavelength. > It resonates based on the reactive (capacitive) > effects of the ring. > > >> But probably not significantly enough to say 1:3 SWR over the >> 118-136MHz band? > > Interesting experiement . . . it might get > wider but probably way short of design > goals. > > >> Finn >> >> On 9/30/2020 5:04 PM, Robert L. Nuckolls, III wrote: >>>> >>>> >>>> Would love to have someone else experiment with it and see if they >>>> somehow could get 1:3 SWR over 118-136MHz. >>> >>> It's been some years since I built one of these >>> (back in the days before vna's) and a similar >>> interval since I reviewed the literature. >>> >>> Poked around on the 'net and my archives a bit >>> and I think I can confidently offer an explanation >>> for the fruitlessness of your endeavors. >>> >>> The DDRR is a vertically polarized antenna wherein >>> the very short vertical mast is the radiator. >>> All that other stuff is a loading reactance for >>> the antenna . . . or 'top hat' in some circles. >>> >>> Given that the radiation from an antenna is >>> proportional to the current flowing in the radiator >>> then it follows that this diminutive antenna >>> must have some bodacious currents. Further, where >>> the currents are high, losses need to be low >>> to minimize energy lost to heating. >>> >>> My assertion about larger diameters improving >>> bandwidth was incorrectly applied to this >>> discussion. L/d ratio as it goes to bandwidth >>> works only in the resonant radiating portions of the >>> antenna . . . in this case, the mast. All >>> that stuff setting on top has a rapidly >>> diminishing current flow and besides, that >>> part doesn't radiate. >>> >>> More surface area (diameter) helps this antenna >>> only in the radiator . . . the mast supporting >>> the top hat. Increasing surface area in the loading >>> portion goes to increased Q which means narrower >>> bandwidth. >>> >>> The governing triad is profoundly demonstrated >>> in the magnetic loop antennas used on the HF >>> ham bands. There are very useful loop antennas crafted >>> for the 80M (3.5 to 4.0 Mhz) ham band where >>> the radiator is built from 1-2" copper pipe with >>> soldered joints in 45 degree elbows employed >>> to make an 8-sided 'circle'. The Q of these >>> antennas is very high which means hi currents >>> at the feedpoint, high voltages at the tuning >>> gap. The bandwidth of these antennas is very >>> narrow. The operator has to tune the antenna >>> in lockstep with his transceiver in order to >>> 'cruise' that band for contacts. >>> >>> http://www.oh2gqc.com/wp-content/uploads/2017/09/20170911_160930.jpg >>> >>> Several sages in the design and fabrication >>> of antennas have noted, "one can strive for >>> (1) efficiency, (2) size and/or (3) bandwidth >>> with one overpowering caveat. Optimizing any two >>> qualities calls for degrading the third. So pick >>> two goals and live with consequences for the >>> third." >>> >>> Therefore, your experience with the DDRR was >>> predictable. Yeah, you can get a really useful, >>> small profile antenna but because SIZE was >>> diminished, bandwidth suffers. >>> >>> I thank you for sharing the results of your >>> experiment. >>> >>> Bob . . . >> >> >> [] >> Virus-free. >> www.avast.com >> <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> > > > Bob . . . > -- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Oct 01, 2020
At 08:32 PM 9/30/2020, you wrote: >I did a bit of web browsing on the DDRR. This thread is about a 2 >meter version (above our comm band): >https://forums.qrz.com/index.php?threads/2m-ddrr-antenna-for-vehicle-some-questions.368057/ > The thread contains this sentence: > >"The DDRR is an inverted-L. A 3" tall, 146 MHz DDRR has a radiation >resistance of 3.0 ohms. The 2:1 VSWR bandwidth is 1.5 MHz." Fairly typical. Radiator height is 3/21 or 15% of the full size 1/4 wave. They cited a vswr 2:1 bandwidth of 1.5/146 or 1% . . . 3:1 would be a bit wider but still far short of that necessary for our VHF comm bandwidths. I'm still thinking I'd like to build one for our local fire/ems services where 1% bandwidth is plenty. The thing could reside under a plastic radome and sit on a dedicated ground plane held to the vehicle with magnets in each corner. Just one of many PITS (pie-in-the-sky) projects in someday bucket. This still doesn't solve Finn's problem. Remind me sir, what airplane are we talking about? Bob . . . ________________________________________________________________________________
Subject: voltage monitor
Date: Oct 01, 2020
hi all, i have earthx batteries and would like to install a voltage warning separate from my eis. the device must activate below 13.5 volts . does anyone have any recommendations? i would think something is out there but i haven't seen it. thanks, bob noffs Read this topic online here: http://forums.matronics.com/viewtopic.php?p=498614#498614 ________________________________________________________________________________
Subject: ADS-B and Transponder antenna...
Date: Oct 01, 2020
So, all this chatter about the ELT antennas got me thinking about the ADS-B antenna I made. I dove into the math, made some estimates, and designed two on Upverter and had parts made. I got luck in that my SlimJim ADS-B antenna has picked up airborne traffic over 100 miles away connected to a Stratux (I have both SDR radios tied into a single antenna - criminal - I know, but it works and it's small and light.) Attached are the layouts of the two antennas and links to the actual designs on Upverter. I had 5 of each made. Anyone interested in testing and sharing data - maybe make this a shared design as well. Cost is just a few bucks. Slim Jim: https://upverter.com/eda/#tool=pcb,designId=1d1c59be761e9901 DiPole: https://upverter.com/eda/#tool=pcb,designId=9eb3fbd043861e96 (Upverter is a pretty awesome cloud based schematic and layout tool that allows collaboration on designs, etc... Think Google Docs for circuit design.) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=498615#498615 Attachments: http://forums.matronics.com//files/20201001_093353_131.jpg http://forums.matronics.com//files/dipole_103.png http://forums.matronics.com//files/slimjim_164.png ________________________________________________________________________________
Date: Oct 01, 2020
Subject: Re: voltage monitor
On Thu, Oct 1, 2020 at 8:39 AM bobnoffs wrote: > > hi all, > i have earthx batteries and would like to install a voltage warning > separate from my eis. the device must activate below 13.5 volts . does > anyone have any recommendations? i would think something is out there but i > haven't seen it. > thanks, bob noffs > Hi Bob, A friend of mine has been using this for years, to alert him of alternator loss since he's using electronic ignition on his Lyc: https://www.tomtop.com/p-e1021.html It can be programmed to alert for both over and under-voltage and output fed to whatever you choose; light, buzzer, etc. I bought a couple, but they're still sitting in my 'toy box'; I haven't had an urgent need for one yet. FWIW, the guy who's using it has one of the nicest RV8s I've ever seen, and doesn't do anything 'half-way'. If it's good enough for him... Charlie ________________________________________________________________________________
Date: Oct 01, 2020
Bob, Here are two offerings with the ability to handle Lithium batteries, which actually run about 1 volt above AGM and standard flooded batteries. Both ar e small, rugged and inexpensive. https://gammatronixltd.com/epages/bae94c71-c5b6-4572-89a1-e89006e78fbe.sf/e n_GB/?ObjectPath=/Shops/bae94c71-c5b6-4572-89a1-e89006e78fbe/Categories/C ategory1 http://roadstercycle.com/Motorcycle%20voltage%20monitor.htm Per Shorai's web site, their LiFe batteries are fully charged at 14.34 volt s, as opposed to 13.2 volts for an AGM or flooded lead/acid battery. See we b link below https://shoraipower.com/faq >From that page, click on the question Q. Can I use Lead-Acid battery charge rs or charger/tenders? You will see Shorai's charging table. Charlie K com> wrote: hi all, i have earthx batteries and would like to install a voltage warning separa te from my eis. the device must=C2- activate below 13.5 volts . does anyo ne have any recommendations? i would think something is out there but i hav en't seen it. thanks, bob noffs Read this topic online here: http://forums.matronics.com/viewtopic.php?p=498614#498614 - S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Subject: Can I power ADS-B from Transponder switched output?
Date: Oct 01, 2020
Hi Group I have a Garmin GDL-82 ADS-B that draws .35A typical and .4A maximum. I have a Becker Mode-C transponder that has a 1A switched output. Is there a good reason why I should not use the transponder switched output to power the ADS-B? I don't have an avionics bus. Ron P. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=498618#498618 ________________________________________________________________________________
Subject: Re: Can I power ADS-B from Transponder switched output?
Date: Oct 01, 2020
Since the two units work together as a team, it is not an emergency if you lose both. On the other hand, best practice is to protect each individual load with its own fuse. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=498619#498619 ________________________________________________________________________________
Date: Oct 01, 2020
Hi User 9253 The switched output of the Becker transponder has a 1 amp fuse. Is that OK? Ron P. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=498620#498620 ________________________________________________________________________________
Date: Oct 01, 2020
Hi Bob I don't know what type of regulator you have, but I have a B&C LR3D that B&C calibrated the Low Voltage Warning for LiFe and also have a B&C AVC1 for Rotax 914 internal generator that you can select LiFe Low Voltage Warning. I'm using a Earth 680C. Ron P. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=498621#498621 ________________________________________________________________________________
Date: Oct 01, 2020
OK then, since the transponder DC output is fused and units are related, I think it is OK to wire them as proposed. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=498623#498623 ________________________________________________________________________________
Date: Oct 01, 2020
Subject: First peek at the HeatShrink Butt Splices
This application specific crimp too for heat-shrink butt-splices came in today. Thought I'd give you a heads-up on the 'first smash'. https://tinyurl.com/yywskeds The RED aperture for the 22-16AWG splices is ALMOST tight enough. About 1 in 4 splices on 22AWG wire would fail an 8# pull test. However, if one stripped the wire 1/2" and doubled the stranding back, all test crimps would pass. The downside is that the shrink will not close on small profile insulation . . . like 22759. Fully shrunk, there is no contact of the insulation on the wire . . . no tell-tale oozing of sealant from the ends telling us that environmental protection has been achieved. The upside is that they do seal on the 22AWG with the larger, irradiated PVC wire. The rectangular crimp die does produce less trauma to the insulation hence the finished joint looks better that those I've made in the past with 'non specific' tools. Watch this space. I'll see if I can do a Shop Notes on this tool/materials combination. Bob . . . ________________________________________________________________________________
Date: Oct 01, 2020
Perhaps not helpful to the antenna design y'all are pursuing in this thread, but I came across this paper today... http://www.jpier.org/PIERM/pierm78/11.18102701.pdf ...thanks to the guys at DarkAero... https://www.darkaero.com/ ...who are experimenting with this antenna for their all-carbon fiber aircraft. The paper describes an interesting printed circuit board antenna of meandering design. It looks very useful for builders looking to avoid long external antennae, and if the bandwidth shown for a ~160MHz design can be duplicated at ~120MHz, it should work well. Eric Read this topic online here: http://forums.matronics.com/viewtopic.php?p=498626#498626 ________________________________________________________________________________
Date: Oct 02, 2020
i ordered the tom top unit. for $5 i gotta see how it works. talked to perihelion and i believe they can build their 'idiot light' to my specs.this is a panel light with the electronics self contained. any more suggestions i would like to hear. thanks, bob noffs Read this topic online here: http://forums.matronics.com/viewtopic.php?p=498628#498628 ________________________________________________________________________________
Date: Oct 02, 2020
Subject: Re: ov warning light
> . . . warning is to protect 2 earthx batteries. Why do your EarthX batteries need protecting? Is your alternator/regulator system fitted with a legacy ov management feature? If the later is true, then an ov condition can persist for only a few tens of milliseconds and would probably never be noticed. Even if noticed, what relevance would it have to your next action in the cockpit? Bob . . . ________________________________________________________________________________
Subject: Re: ADS-B and Transponder antenna design...
Date: Oct 02, 2020
And I'm willing to send a pair of antennas to someone who's willing to analyze. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=498632#498632 ________________________________________________________________________________
Date: Oct 02, 2020
On Fri, Oct 2, 2020 at 4:28 PM andymeyer wrote: > > > > And I'm willing to send a pair of antennas to someone who's willing to > analyze. > Hi Andy, I'm creating a new SD card 'build' for a Stratux as I type this. I'm definitely interested; and what do you use for a combiner, and what cable and cable length will work? I need to get the Stratux off the dash, and mounting it between the instrument panel & firewall will be the easiest location for me. Assuming it'll work out for me, where & how much do I need to send? Many thanks, Charlie ceengland7(at)gmail.com ________________________________________________________________________________
Date: Oct 02, 2020
At 04:51 PM 10/2/2020, you wrote: >On Fri, Oct 2, 2020 at 4:28 PM andymeyer ><meyerkc135(at)gmail.com> wrote: >"andymeyer" <meyerkc135(at)gmail.com> > >And I'm willing to send a pair of antennas to >someone who's willing to analyze. > >=C2 >Hi Andy, > >I'm creating a new SD card 'build' for a Stratux >as I type this. I'm definitely interested; and >what do you use for a combiner, and what cable >and cable length will work? I need to get the >Stratux off the dash, and mounting it between >the instrument panel & firewall will be the easiest location for me. combiners? ADSB antennas? enlighten me please Bob . . . ________________________________________________________________________________
Date: Oct 02, 2020
=81=A3Sent from BlueMail =8B On Oct 2, 2020, 10:28 PM, at 10:28 PM, "Robert L=2E Nuckolls, III" wrote: >At 04:51 PM 10/2/2020, you wrote: > > >>On Fri, Oct 2, 2020 at 4:28 PM an dymeyer >><meyerkc135@gmail=2Ecom> wrote: > >>"andymeyer" <meyerkc135@gmail=2Ecom> >> >>And I'm willing to send a pair o f antennas to >>someone who's willing to analyze=2E >> >>=C3=82 >>Hi Andy, >> >>I'm creating a new SD card 'build' for a Stratux >>as I type this=2E I'm definitely interested; and >>what do you use for a combiner, and what cable >>and cable length will work? I need to get the >>Stratux off the dash, and mounting it between >>the instrument panel & firewall will be th e easiest location for me=2E > > combiners? ADSB antennas? enlighten me p lease > > > Bob =2E =2E =2E ________________________________________________________________________________
Date: Oct 03, 2020
> > >he described them with pics several days ago. Oh yeah . . . the pix didn't come thru here but okay . . . understand now. Bob . . . ________________________________________________________________________________
Date: Oct 03, 2020
I personally like the idea of a panel light that will make you aware of Under and well as Over voltage conditions. I have experienced an under voltage on start up. Caused by a defective main circuit breaker that opened, but did not show an indication that it had mysteriously opened. Luckily, before beginning the taxi, I noted the amp/volt meter was amiss. Tested the CB and could not get it to reset. Installed new CB and had no additional problems. On Fri, Oct 2, 2020 at 3:41 AM bobnoffs wrote: > > i ordered the tom top unit. for $5 i gotta see how it works. > talked to perihelion and i believe they can build their 'idiot light' > to my specs.this is a panel light with the electronics self contained. > any more suggestions i would like to hear. > thanks, bob noffs > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=498628#498628 > > ________________________________________________________________________________
Date: Oct 03, 2020
At 03:35 PM 10/3/2020, you wrote: >I personally like the idea of a panel light that >will make you aware of Under and well as Over voltage conditions. >I have experienced an under voltage on start up. >Caused by a defective main circuit breaker >that opened, but did not show an indication that it had mysteriously opened. Then I take it that your system was not fitted with active notification of low voltage. This feature is the FIRST if not the ONLY voltage sensing/indicating device NECESSARY for flight operations. Preferably, this light is bright (sunlight viewable) and located well within peripheral vision of the pilot. Further, it should flash at 2-3 times per second (a legacy value for optimal attention getting arrived at by numerous human factors studies ). This light has been a no-extra-charge built in feature of virtually all B&C alternator controllers. From day-one (about 35 years ago). It was B&C's mission that no customer would be without BOTH low volts and over volts management. Luckily, before beginning the taxi, I noted the amp/volt meter was amiss. >Tested the CB and could not get it to >reset.=C2 Installed new CB and had no additional problems. Yes, there was an element of luck associated with that experience. I'm pleased the event resolved without a tense-day-in-the-cockpit. Along with active notification of low volts, you should plan on independent management of an over voltage condition with a system that disables the alternator within 500 milliseconds of having exceeded 16 volts. Depending on design parameters of the designer, the ov event will be over very soon thus leaving you with a low volts condition that will be annunciated as cited above. Fit your airplane with those two features and all the other voltmeters, ammeters, beeps and squawks from the panel mounted goodies become mere icing on the cake. Bob . . . ________________________________________________________________________________
Subject: field current supplied from B lead instead of from
main bus
Date: Oct 03, 2020
Hi Bob, Someone in my sphere suggested getting field current from the B lead instead of from the main bus. This way if the B lead shorts to ground and the fuselink opens, the field will be de-energized. Marked up snip of Z101B attached. Comments? Thanks -------- John Bright, RV-6A, at FWF, O-360 Z-101 single batt dual alt SDS EM-5-F. john_s_bright(at)yahoo.com, Newport News, Va https://drive.google.com/drive/folders/1u6GeZo6pmBWsKykLNVQMvu4o1VEVyP4K Read this topic online here: http://forums.matronics.com/viewtopic.php?p=498646#498646 Attachments: http://forums.matronics.com//files/is_connecting_field_supply_to_b_lead_a_good_idea_210.jpg ________________________________________________________________________________
Date: Oct 04, 2020
since my first post perihelion design has let me know that their idiot light can be made to any high/low settings. pretty slick fix. 2 leads [i assume] and it all fits in a .55'' panel hole. light can be ordered flashing or steady. On Sat, Oct 3, 2020 at 4:11 PM Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 03:35 PM 10/3/2020, you wrote: > > I personally like the idea of a panel light that will make you aware of > Under and well as Over voltage conditions. > I have experienced an under voltage on start up. Caused by a defective > main circuit breaker > that opened, but did not show an indication that it had mysteriously > opened. > > > Then I take it that your system was not fitted > with active notification of low voltage. This > feature is the FIRST if not the ONLY voltage > sensing/indicating device NECESSARY for flight > operations. > > Preferably, this light is bright (sunlight viewable) > and located well within peripheral vision of the pilot. > Further, it should flash at 2-3 times per second > (a legacy value for optimal attention getting > arrived at by numerous human factors studies ). > > This light has been a no-extra-charge built in feature > of virtually all B&C alternator controllers. From > day-one (about 35 years ago). It was B&C's mission that > no customer would be without BOTH low volts and > over volts management. > > Luckily, before beginning the taxi, I noted the amp/volt meter was amiss . > > Tested the CB and could not get it to reset.=C3=82 Installed new CB and had no > additional problems. > > > Yes, there was an element of luck associated with > that experience. I'm pleased the event resolved > without a tense-day-in-the-cockpit. > > Along with active notification of low volts, you > should plan on independent management of an over > voltage condition with a system that disables > the alternator within 500 milliseconds of having > exceeded 16 volts. > > Depending on design parameters of the designer, > the ov event will be over very soon thus leaving > you with a low volts condition that will be > annunciated as cited above. > > Fit your airplane with those two features and > all the other voltmeters, ammeters, beeps > and squawks from the panel mounted goodies > become mere icing on the cake. > > > Bob . . . > ________________________________________________________________________________
Date: Oct 04, 2020
the rub with low voltage indicators is that they set their low voltage for lead acid batteries. this is too low and useless for earthx lipo. low voltage warning must go on below 13.5 volts. when i started this post i talked to b and c about a warning system they had. the voltage was not adjustable and set for lead acid......no good for lipo. b and c said that most electronics is adjustable today and there was never a market for a higher low warning. my system is adjustable but i do not want to probe my ecu with my computer just to make a limit change. earthx users....what's in your wallet? er i mean low voltage setting? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=498650#498650 ________________________________________________________________________________
Date: Oct 04, 2020
Subject: Re: field current supplied from B lead instead of
from main bus At 11:11 PM 10/3/2020, you wrote: > > >Hi Bob, > >Someone in my sphere suggested getting field current from the B lead >instead of from the main bus. > >This way if the B lead shorts to ground and the fuselink opens, the >field will be de-energized. > >Marked up snip of Z101B attached. > >Comments? If there is a fault that opens the fusible link, then the alternator is isolated from the ship's systems. While the field would still be energized, the resulting condition is internal to the alternator and not a threat to the rest of the airplane. If the regulator senses bus voltage through the breaker, then you will depress bus voltage by whatever drop occurs in the b-lead. Further, the b-terminal to field breaker lead becomes and extension of the bus and would need to get a fusible link at the b-lead. Presently, I see no particular advantage for doing this. Bob . . . ________________________________________________________________________________
Date: Oct 04, 2020
At 10:58 AM 10/4/2020, you wrote: > >the rub with low voltage indicators is that they set their low >voltage for lead acid batteries. this is too low and useless for >earthx lipo. low voltage warning must go on below 13.5 volts. when i >started this post i talked to b and c about a warning system they >had. the voltage was not adjustable and set for lead acid......no >good for lipo. b and c said that most electronics is adjustable >today and there was never a market for a higher low warning. my >system is adjustable but i do not want to probe my ecu with my >computer just to make a limit change. > earthx users....what's in your wallet? er i mean low voltage setting?' Not sure I understand this. Check out this family of discharge plots on 3 brands of LiFePo4 batteries including an EarthX. https://tinyurl.com/y4nsp8lr Looks to me like 13.5V is still a good number. Bob . . . ________________________________________________________________________________
Date: Oct 04, 2020
Subject: Re: Can radials of home made ground plane be
tapered? At 11:43 AM 9/28/2020, you wrote: > >Hi Group FWIW I called Garmin and Stein Air and both said to use a >ground plane. I also called Vans. On their RV-12 they install the >GA-35 on a small bracket FWF. I called them and asked about a ground >plane and they said that the lower cowl acts as a ground plane. Not one of those assertion suggest that there is any DATA to support the recommendation. > Here's a post from a guy in the Vans Forum: "I can tell you > this...originally >I installed mine under the cowl with little to no ground plane. It worked.... Not necessarily 'hard' data but certainly compelling . . . >Later I installed a bigger ground plane and the signal levels >definately increased." It was posted in reply from a 12/30/2012 >question in Vans Forum, he doesn't say what model plane he had, >precisely what antenna or how large of a ground plane. I have now >heard of several Europa's and a Long EZ using the GA-35 without a >ground plane with good success. Ron P. Interesting. I'm not suggesting that a ground plane under a gps antenna is not beneficial, only wondering if it's observably useful. I recall discussions on the amateur built forums in years past about adding a ram-air induction port to the airplane's cowl. I seems some builder made some valid measurements of available manifold pressure with and without such a feature. He opined there was value in fabricating one. I think the discussion died out when an engine guru reminded us that airspeed goes up the cube root of h.p. and the fractional improvement for the addition would be difficult to measure much less observe in actual practice. Methinks the GPS ground plane may fall into this category as well. There are millions and millions of GPS based appliances that perform as advertised with exceedingly 'deficient' antennas. It seems that somewhere between the least and the best, there is a demonstrable configuration that would save OBAM aircraft builders hours of no-value-added effort on their project. Bob . . . ________________________________________________________________________________
Date: Oct 04, 2020
without any mod the 'idiot light' comes preset to warn below 13.0 volts. in a lead acid set up this would catch the alternator soon after it went off line and a lead acid would have most of its charge left. when a lipo drops below 13 volts a lot of its charge is already been used. the goal is to catch the alternator going out, not to monitor system voltage. my engine needs a battery or a working alternator to keep running. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=498654#498654 ________________________________________________________________________________
Date: Oct 04, 2020
At 01:10 PM 10/4/2020, you wrote: > >without any mod the 'idiot light' comes preset to warn below 13.0 >volts. in a lead acid set up this would catch the alternator soon >after it went off line and a lead acid would have most of its charge >left. when a lipo drops below 13 volts a lot of its charge is >already been used. Can you confirm that assertion from the data offered in the three plots I've posted? >the goal is to catch the alternator going out, not to monitor system >voltage. my engine needs a battery or a working alternator to keep running. The testing I've done suggests that there MIGHT be a bit of delay in the LV WARN response . . . but it's minimal. An LV condition is not a high pucker-factor event. After the alternator quits you can finish your cup of coffee and sandwich, fold the map (if you still use one) and then proceed to implement plan-b. Conducting a lightning-fast response to the light would have no measurable effect on the outcome of your flight. This is true of what ever type of battery chemistry is on board. This is why I've advised against numerous schemes for automatic responses to low voltage. Such features only add complexity that demands pre-flight testing while failing to reduce risk. Bob . . . ________________________________________________________________________________
Subject: Re: field current supplied from B lead instead of from
main bu
Date: Oct 04, 2020
nuckolls.bob(at)aeroelect wrote: > At 11:11 PM 10/3/2020, you wrote: > > If there is a fault that opens the fusible > link, then the alternator is isolated from > the ship's systems. While the field would > still be energized, the resulting condition > is internal to the alternator and not a > threat to the rest of the airplane. > > If the regulator senses bus voltage through > the breaker, then you will depress bus voltage > by whatever drop occurs in the b-lead. Further, > the b-terminal to field breaker lead becomes and extension > of the bus and would need to get a fusible > link at the b-lead. > > Presently, I see no particular advantage > for doing this. > > > Bob . . . Thanks Bob. -------- John Bright, RV-6A, at FWF, O-360 Z-101 single batt dual alt SDS EM-5-F. john_s_bright(at)yahoo.com, Newport News, Va https://drive.google.com/drive/folders/1u6GeZo6pmBWsKykLNVQMvu4o1VEVyP4K Read this topic online here: http://forums.matronics.com/viewtopic.php?p=498656#498656 ________________________________________________________________________________
Date: Oct 04, 2020
On 10/4/2020 1:27 PM, Robert L. Nuckolls, III wrote: > At 01:10 PM 10/4/2020, you wrote: >> >> without any mod the 'idiot light' comes preset to warn below 13.0 >> volts. in a lead acid set up this would catch the alternator soon >> after it went off line and a lead acid would have most of its charge >> left. when a lipo drops below 13 volts a lot of its charge is already >> been used. > > Can you confirm that assertion from the > data offered in the three plots I've > posted? > >> the goal is to catch the alternator going out, not to monitor system >> voltage. my engine needs a battery or a working alternator to keep >> running. > > The testing I've done suggests that > there MIGHT be a bit of delay in the > LV WARN response . . . but it's minimal. > > An LV condition is not a high pucker-factor > event. After the alternator > quits you can finish your cup of coffee > and sandwich, fold the map (if you still use one) > and then proceed to implement plan-b. > > Conducting a lightning-fast response to the > light would have no measurable effect on > the outcome of your flight. > > This is true of what ever type of battery > chemistry is on board. This is why I've > advised against numerous schemes for automatic > responses to low voltage. Such features only > add complexity that demands pre-flight testing > while failing to reduce risk. > > Bob . . . > I think I see his point. If the 'stock' alert point is 13V, the EarthX chart shows that to be at about the 3 AH point of the curve with total AH capacity of about 11AH when looking at the higher discharge rates you'd expect from an electronic injection system. Not a big deal if there's a backup alternator, but being down roughly 1/3 before notification could be a big deal if you're depending on battery for backup. Charlie -- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
main bus
Date: Oct 04, 2020
Bad idea. How often do "B" leads short to ground? The "B" lead is not going to short to ground if properly installed. Adding an extra wire from the alternator to the instrument panel increases the chances of a failure. Suppose the alternator stops working for some reason. It could be a broken belt, bad brushes, broken wire, blown "B" lead fuse. The pilot will not know the cause. What action will the pilot take? She might cycle the alternator field switch on and off. If the alternator still does not work, she might leave the switch off to conserve the battery. I see no advantage to adding an extra wire to the engine. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=498657#498657 ________________________________________________________________________________
Date: Oct 04, 2020
Subject: Li-Ion versus LiFePO4
At 01:10 PM 10/4/2020, you wrote: > >without any mod the 'idiot light' comes preset to warn below 13.0 volts. >in a lead acid set up this would catch the alternator soon after it went >off line and a lead acid would have most of its charge left. when a lipo >drops below 13 volts a lot of its charge is already been used. Are you perhaps conflating Li-Ion with LiFePo4 chemistries? Check out this plot https://tinyurl.com/y6o5olae These curves are examples of the discharge characteristics of the wildly popular lithium cells offered in the vast majority of ads on the 'net. As you can see, the discharge characteristics are exceedingly different than for LiFePO4. To achieve 100% charge you must push energy into these cells at 4.2 volts or so. 3 cells in series would give us a 'bus voltage' of 12.6v . . . a tad low. Their end of service voltage of 3 volts would power our goodies at 9V . . . waaayy too low. Okay, 4 cells in series gives us a bus voltage of 16.8 volts. Yeah . . . I suppose you could configure a system that would run happily at that level. MOST modern avionics wouldn't care. But your battery contactors, light bulbs and legacy 14v accessories would care. At end of service we would see 12v . . . just fine but yes, it would make your existing LV warning useless. But are you aware of any BMS supported, engine cranking batteries offered to the automotive or aircraft communities that are fitted with the Li-Ion chemistry? LiFePo4 is a marriage made in the lab. A 4-stack array offers full charge and end of service voltages are quite compatible with the lead-acid world. That's why all those supplier are able to offer plug and play lithium upgrades to virtually everyone . . . including those who choose to cheat death in those funny kites with air-thrashers on the front. Bob . . . ________________________________________________________________________________
Date: Oct 04, 2020
Bob, I suggest to view Shorai's FAQ page linked below. https://shoraipower.com/faq Scroll down and click on the question: Q. Can I use Lead-Acid battery char gers or charger/tenders? View the chart on the right side of the page. Note that at 13.0 volts, thes e LiFe batteries have less than 40% charge left. Charlie K nuckolls.bob(at)aeroelectric.com> wrote: At 01:10 PM 10/4/2020, you wrote: --> AeroElectric-List messageposted by: "bobnoffs" without any mod the 'idiot light' comes preset to warn below 13.0 volts.in a lead acid set up this would catch the alternator soon after it wentoff li ne and a lead acid would have most of its charge left. when a lipodrops bel ow 13 volts a lot of its charge is already been used. =C2- Can you confirm that assertion from the =C2- data offered in the three plots I've =C2- posted? the goal is to catch thealternator going out, not to monitor system voltage . my engine needs abattery or a working alternator to keep running. =C2- The testing I've done suggests that =C2- there MIGHT be a bit of delay in the =C2- LV WARN response . . . but it's minimal. =C2- An LV condition is not a high pucker-factor =C2- event. After the alternator =C2- quits you can finish your cup of coffee =C2- and sandwich,=C2- fold the map (if you still use one) =C2- and then proceed to implement plan-b. =C2- Conducting a lightning-fast response to the =C2- light would have no measurable effect on =C2- the outcome of your flight. =C2- This is true of what ever type of battery =C2- chemistry is on board. This is why I've =C2- advised against numerous schemes for automatic =C2- responses to low voltage. Such features only =C2- add complexity that demands pre-flight testing =C2- while failing to reduce risk. =C2- Bob . . . ________________________________________________________________________________
Date: Oct 04, 2020
>I think I see his point. If the 'stock' alert point is 13V, the >EarthX chart shows that to be at about the 3 AH point of the curve >with total AH capacity of about 11AH when looking at the higher >discharge rates you'd expect from an electronic injection system. >Not a big deal if there's a backup alternator, but being down >roughly 1/3 before notification could be a big deal if you're >depending on battery for backup. Don't know where the 13.0 point comes from. Both AEC and B&C have used 13.5 for a couple of decades. But okay, let's assume 13.0 See tabular data text file. The ETX36 with a 5A load on it will fall to 13.0 in about 40 seconds. The image file is from plotred data of the same test: Kinda hard to zero in on the finer details of a couple hour run but it shows that at 67 seconds, the battery was down to 12.99 with an expenditure of approx 0.1 AH Keep in mind that voltage monitoring at the bus is always tens of millivolts HIGHER than battery voltage . . . with a similar departure to the LOWER side during DISCHARGE conditions. So assuming one had a LV reporting system that was not adjustable but accurate to 100 millivolts or so at 13.0, the resulting delay between alternator failure and annunciation is still timely and 'wasted' energy is trivial. Bob . . . West Mountain Radio CBA Test Report: YEAROLDETX36_1 Description: 4 Li-ion cells, 7.5 Ah @ 5.00A Started At: 01/16/17 16:42:53 Starting Voltage: 13.41 V Ending Voltage: 11.19 V Sample Rate: 1.000 Total Time (hh:mm:ss): 2:09:53 Time (hh:mm:ss) Voltage (V) Current Temp (C) 00:00:00 13.409 0.809 0.00 00:00:01 13.409 0.809 0.00 00:00:02 13.231 4.032 0.00 00:00:03 13.184 4.773 0.00 00:00:04 13.184 4.816 0.00 00:00:05 13.165 4.968 0.00 00:00:06 13.140 4.981 0.00 00:00:07 13.135 5.002 0.00 00:00:08 13.135 5.015 0.00 00:00:09 13.135 5.011 0.00 00:00:10 13.135 4.994 0.00 00:00:11 13.130 5.011 0.00 00:00:12 13.100 5.011 0.00 00:00:13 13.100 4.994 0.00 00:00:14 13.090 5.002 0.00 00:00:15 13.085 5.002 0.00 00:00:16 13.085 4.998 0.00 00:00:17 13.085 4.998 0.00 00:00:18 13.080 4.998 0.00 00:00:19 13.085 5.011 0.00 00:00:20 13.060 4.989 0.00 00:00:21 13.065 5.002 0.00 00:00:22 13.050 5.011 0.00 00:00:23 13.045 4.981 0.00 00:00:24 13.036 5.015 0.00 00:00:25 13.035 4.989 0.00 00:00:26 13.035 5.011 0.00 00:00:27 13.035 5.006 0.00 00:00:28 13.035 4.998 0.00 00:00:29 13.035 4.998 0.00 00:00:30 13.035 5.002 0.00 00:00:31 13.031 5.011 0.00 00:00:32 13.020 4.981 0.00 00:00:33 13.016 5.002 0.00 00:00:34 13.021 5.006 0.00 00:00:35 13.006 4.994 0.00 00:00:36 13.006 4.994 0.00 00:00:37 12.991 5.011 0.00 00:00:38 12.986 4.994 0.00 00:00:39 12.986 5.015 0.00 00:00:40 12.986 4.998 0.00 ________________________________________________________________________________
Date: Oct 04, 2020
At 02:18 PM 10/4/2020, you wrote: >Bob, >I suggest to view Shorai's FAQ page linked below. > >https://shoraipower.com/faq > >Scroll down and click on the question: Q. Can I use Lead-Acid >battery chargers or charger/tenders? > >View the chart on the right side of the page. Note that at 13.0 >volts, these LiFe batteries have less than 40% charge left. That's an open circuit, no-load voltage that speaks to state of charge. That's not a milestone voltage for a fully charged battery under load. Two completely different conditions Bob . . . ________________________________________________________________________________
Date: Oct 04, 2020
hi all, according to the graph posted bob is right about the very small current drained. this is not at all how earthx describes their batteries. earthx recommends that low voltage monitors light up below 13.5 volts. on the b and c web site they sell an over/under voltage sensor model bc207. the low voltage light trips at 12.5 volts according to their description. everything i have learned about the lipo batteries has said they hold their voltage while discharging. i have always seen a much larger % drop advertised.time for me to call earthx. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=498666#498666 ________________________________________________________________________________
Date: Oct 04, 2020
I simply carefully spliced the Coax. I tried a 1GHz mux with and without a terminating resistor and didn't find any better real world performance and it was harder to package. That's one of the reasons I'd like to find out about the analyzer performance of these antennas. Drop me an email as to where to send them. I assume you've got an analyzer? Let me know where to send it. I'd much rather have them dialed in at 978 as weather reception range is most important. If I can see 1090 traffic at 5 miles, I'm happy, but if I can only get 978 towers at 30 or 40 miles... :( I put my stratux back out of the way as well - talks great to my IFD540 via serial. I've only got about 3 feet of coax, but around the house, I had these hooked up to about 10 feet for testing. I'm flying with the Slim-jim, but recently found a better hiding place to try to di-pole if it'll fit in my spar well without sacrificing performance. I have 3 turns of coax at the base of the antenna for a BalUn. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=498667#498667 ________________________________________________________________________________
Date: Oct 04, 2020
On Sun, Oct 4, 2020 at 4:28 PM Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > I think I see his point. If the 'stock' alert point is 13V, the EarthX > chart shows that to be at about the 3 AH point of the curve with total AH > capacity of about 11AH when looking at the higher discharge rates you'd > expect from an electronic injection system. Not a big deal if there's a > backup alternator, but being down roughly 1/3 before notification could be > a big deal if you're depending on battery for backup. > > > Don't know where the 13.0 point comes from. Both > AEC and B&C have used 13.5 for a couple of decades. > > But okay, let's assume 13.0 > > See tabular data text file. The ETX36 with a 5A > load on it will fall to 13.0 in about 40 seconds. > The image file is from plotred data of the same > test: > > Kinda hard to zero in on the finer details of a > couple hour run but it shows that at 67 seconds, > the battery was down to 12.99 with an expenditure > of approx 0.1 AH > > Keep in mind that voltage monitoring at > the bus is always tens of millivolts HIGHER > than battery voltage . . . with a similar > departure to the LOWER side during DISCHARGE > conditions. > > So assuming one had a LV reporting system that > was not adjustable but accurate to 100 millivolts > or so at 13.0, the resulting delay between > alternator failure and annunciation is still > timely and 'wasted' energy is trivial. > > > Bob . . . > I think he's using the EarthX PC680 relacement battery. I used EarthX's chart for their PC680 replacement, here: https://earthxbatteries.com/earthx_manual.pdf and assumed ~12-14 A load, which is typical for full electronic engine control with electronic injection. According to EarthX the 680 replacement hovers around 13 V until around 3 AH has been depleted. You'd know a lot better than me where the LoVolts setpoint is with B&C stuff; that's why I said 'if'. :-) Charlie ________________________________________________________________________________
Date: Oct 04, 2020
Sounds affordable to me. I don't have an analyzer now, but I've been planning to purchase one. This will motivate me. :-) I'll send my address direct to your email address. Thanks! Charlie On Sun, Oct 4, 2020 at 5:12 PM andymeyer wrote: > > > > I simply carefully spliced the Coax. I tried a 1GHz mux with and without a > terminating resistor and didn't find any better real world performance and > it was harder to package. That's one of the reasons I'd like to find out > about the analyzer performance of these antennas. > > Drop me an email as to where to send them. I assume you've got an > analyzer? Let me know where to send it. I'd much rather have them dialed in > at 978 as weather reception range is most important. If I can see 1090 > traffic at 5 miles, I'm happy, but if I can only get 978 towers at 30 or 40 > miles... :( > > I put my stratux back out of the way as well - talks great to my IFD540 > via serial. I've only got about 3 feet of coax, but around the house, I had > these hooked up to about 10 feet for testing. I'm flying with the Slim-jim, > but recently found a better hiding place to try to di-pole if it'll fit in > my spar well without sacrificing performance. I have 3 turns of coax at the > base of the antenna for a BalUn. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=498667#498667 > > ________________________________________________________________________________
Date: Oct 04, 2020
At 04:50 PM 10/4/2020, you wrote: > >hi all, > according to the graph posted bob is right about the very small > current drained. >this is not at all how earthx describes their batteries. Can you point us to the download for information that gives you concern? >earthx recommends that low voltage monitors light up below 13.5 volts. B&C and I both have promoted that lv setpoint value for decades . . . > on the b and c web site they sell an over/under voltage sensor > model bc207. the low voltage light trips at 12.5 volts according to > their description. > That device was originally crafted for ultralights about 30 years ago. In fact, it was the first, stand-alone monitor device produced there. It was never intended for installation in 'real' airplanes. I really wish they didn't sell that any more but I think Aircraft Spruce shows it in their catalog. NOT RECOMMENDED FOR NEW DESIGN. > everything i have learned about the lipo batteries has said they > hold their voltage while discharging. And in what way does the data I've posted argue with that? The AeroVoltz plot shows a working range on the order of 13.2 to 12.5 volts. Miady 13.2 to about 12.0 EarthX from 13.2 to 12.5 Where are you going to find anything flatter for a discharge curve? All three deliver power within a 5% or smaller window. I have always seen a much larger % drop advertised.time for me to call earthx. . . . and ask what? Help me understand your question. Before you seek verbal guidance, let us examine data-in-print and data-measured so that disconnects can be clearly articulated. I'd be happy to call them myself if there are real points of contention. I've talked to both EarthX and Shorai numerous times but a considerable time ago . . . wouldn't mind renewing some contacts. Bob . . . ________________________________________________________________________________
Date: Oct 04, 2020
From: Technical Manual for Model No. LR3D-14 and LR3D-28 Linear RegulatorWith Over-Voltage Protection, Low-Voltage Sensing, And Field-Adjustable Charging Voltage "The LV warning light will begin to flash when the voltage sensed at terminal 3 drops to approximately 12.7V and below" Disregard if this is not relevant to this discussion. On Sun, Oct 4, 2020 at 2:26 PM Charlie England wrote: > > > On Sun, Oct 4, 2020 at 4:28 PM Robert L. Nuckolls, III < > nuckolls.bob(at)aeroelectric.com> wrote: > >> I think I see his point. If the 'stock' alert point is 13V, the EarthX >> chart shows that to be at about the 3 AH point of the curve with total AH >> capacity of about 11AH when looking at the higher discharge rates you'd >> expect from an electronic injection system. Not a big deal if there's a >> backup alternator, but being down roughly 1/3 before notification could be >> a big deal if you're depending on battery for backup. >> >> >> Don't know where the 13.0 point comes from. Both >> AEC and B&C have used 13.5 for a couple of decades. >> >> But okay, let's assume 13.0 >> >> See tabular data text file. The ETX36 with a 5A >> load on it will fall to 13.0 in about 40 seconds. >> The image file is from plotred data of the same >> test: >> >> Kinda hard to zero in on the finer details of a >> couple hour run but it shows that at 67 seconds, >> the battery was down to 12.99 with an expenditure >> of approx 0.1 AH >> >> Keep in mind that voltage monitoring at >> the bus is always tens of millivolts HIGHER >> than battery voltage . . . with a similar >> departure to the LOWER side during DISCHARGE >> conditions. >> >> So assuming one had a LV reporting system that >> was not adjustable but accurate to 100 millivolts >> or so at 13.0, the resulting delay between >> alternator failure and annunciation is still >> timely and 'wasted' energy is trivial. >> >> >> >> >> >> Bob . . . >> > I think he's using the EarthX PC680 relacement battery. I used EarthX's > chart for their PC680 replacement, here: > https://earthxbatteries.com/earthx_manual.pdf > and assumed ~12-14 A load, which is typical for full electronic engine > control with electronic injection. According to EarthX the 680 replacement > hovers around 13 V until around 3 AH has been depleted. > > You'd know a lot better than me where the LoVolts setpoint is with B&C > stuff; that's why I said 'if'. :-) > > Charlie > > ________________________________________________________________________________
Date: Oct 05, 2020
the link charlie posted shows a graph i am used to seeing with the earthx. i take this graph to mean i will give up 3ah of battery by using 13.0 as a setpoint vs. 13.5 volts. i have no second alternator so it is important to me to know asap when i have only battery power to keep the engine running. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=498676#498676 ________________________________________________________________________________
Date: Oct 06, 2020
New post Posted: Sun Oct 04, 2020 4:51 pm Post subject: voltage monitor <http://forums.matronics.com/posting.php?mode=quote&p=498671&sid=6781a385e9dbba117a35c9138433dbef> Reply with quote ---------- From: Technical Manual for Model No. LR3D-14 and LR3D-28 Linear RegulatorWith Over-Voltage Protection, Low-Voltage Sensing, And Field-Adjustable Charging Voltage "The LV warning light will begin to flash when the voltage sensed at terminal 3 drops to approximately 12.7V and below" Disregard if this is not relevant to this discussion. It is very relevant. Thank you. This is news to me but I've not been directly involved or plugged in to B&C design decisions for some years With that in mind, and given the number and variety of programs I've worked it seemed prudent to verify the hip-pocket archives. Dug out my AEC9005 drawings and the setpoint was 13.0 volts. All the data I have on early LR3 series regulators suggest that 12.7 has been the setpoint from day one. Just for grins, I plotted Time-to-12.7v for four batteries. An AeroVolts, an exemplar EarthX, a Miady 16AH device and just for the heck of it, a fresh Enersy 16AH battery. Plots attached. I've also included a test for a A123, 26650 cell where I deduce that a 4x4 array of these cells in a 14v system battery would fall below 13.5 volts in about 30 seconds. I suggest these plots show that a 13.5 volt lo volts warning threshold would be suited to all chemistries. Note that the SVLA falls like a rock to well under 12.7 when it looses alternator support . . . well, it IS a 12v battery while LiFePO4 devices are generally considered to be 13.2 volt batteries (although AeroVolts labels theirs as a 12V while the plots show that it has the highest alternator- out voltage of the lot). Hence, I stand better informed and agree that the legacy LR3 configuration is unsuitable for lithium battery management without (easy to do) modification as is our AEC9005 LV Warning Module. Sorry for ignoring you the past day or so. Been wrestling with some issues in a car I've got sold . . . along with a recalcitrant wifi router. Ever see the look on the fact of a couple teenagers when you tell them, "the wifi is down"? Bob . . . ________________________________________________________________________________
Date: Oct 06, 2020
At 05:52 AM 10/5/2020, you wrote: > >the link charlie posted shows a graph i am used to seeing with the >earthx. i take this graph to mean i will give up 3ah of battery by >using 13.0 as a setpoint vs. 13.5 volts. i have no second >alternator so it is important to me to know asap when i have only >battery power to keep the engine running. 13.5 is cool . . . Bob . . . ________________________________________________________________________________
Subject: Peer review, Z16 Rotax engine, Ducati Regulator
Date: Oct 07, 2020
Hi everybody Many thanks for all the help I received when I designed the electric system for my Jodel's friend. The plane is now airworthy and so far everything is working like a charm. I now start helping an other fellow aviator who'w building an Aero101. He is a professional carpenter and the airplane is a true beauty but electicity is not he's strong skill. I designed a very simple electric system, 90% inspired by bob's Z16. Once again Bob [and all the other members of this forum], thanks for all the knowledge you're spreading... My friend had 2 requirement that forced me to differ from Bob's design : - he doesn't want to use a battery relay (I personally don't neither the load on the bus is less than 5Amp and a simple switch can handle that kind of current) - he bought a rather expensive start key (see installation manual attached) that permits to turn ON the battery, select Ignition 1 and/or 2, and activate the stater. He don't want any other switches (unless safety mandates). Initially, the supplier doesn't advised to install a OV disconnect relay, but I used Bob's design to adapt one on his airplane. Please let me know if you see any flaws or improvement possible. Many thanks -------- 2020 contribution paid Read this topic online here: http://forums.matronics.com/viewtopic.php?p=498689#498689 Attachments: http://forums.matronics.com//files/loraviacom_regulateur_912_ducati_395.pdf http://forums.matronics.com//files/schema_electrique_objet_176.pdf http://forums.matronics.com//files/120883263_336407514294840_7206115166821084811_n_649.jpg ________________________________________________________________________________
Date: Oct 07, 2020
Subject: Re: Peer review, Z16 Rotax engine, Ducati Regulator
> >Initially, the supplier doesn't advised to install a OV disconnect >relay, but I used Bob's design to adapt one on his airplane. > > >Please let me know if you see any flaws or improvement possible. The crowbar ov module wires ACROSS the alternator disconnect relay DOWNSTREAM of the 5A breaker. See figure Z16. Bob . . . ________________________________________________________________________________
Date: Oct 07, 2020
The crowbar module will short out the battery. There is a long, always-hot wire connected between the battery and terminal 1 of that expensive switch. In an accident, that wire could make sparks and start a fire. A battery contactor can shut off power close to the battery. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=498692#498692 ________________________________________________________________________________
Date: Oct 07, 2020
Subject: Breaker then pump failure
I just had the Tyco switch/breaker for my boost pump fail. It made a bad smell, then became intermittent, then failed completely in the span of a few minutes. I replaced it with the same make and model. 2.5 flight hours later my boost pump failed. The new breaker never tripped. The pump just stopped running. The pump circuit has no resistance and I get full bus voltage at the pump, even with the pump still connected. So it's open inside. The new switch is working fine. The pump is from Airflow Performance. They're common in RVs. The pump and the switch had almost 2000 airframe hours since installed. I use it for take-off and landing, so the powered time is a fraction of the total time. The airplane had been sitting for almost a year, then flown about 15 hours in the last two weeks. Does anyone have an understanding of any relationship between these two failures? They seem too similar to be completely unrelated. My guess is that a faulty pump somehow overloaded a faulty breaker, then failed completely. I couldn't say that I noticed any particular fuel pressure issues before the failure. Everything was in the green. Thoughts? ________________________________________________________________________________
Subject: Engine Monitor P-lead question
Date: Oct 07, 2020
I'm installing an Electronics International CGR-30P engine monitor. For the tach function they have two leads that connect to the left and right P-lead on the ignition switch which are not shielded. The P-leads from the mags to the switch are shielded. Will this be an issue? Can those two leads be included in a wire bundle or should they have their on run away from other wires? Thanks, John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=498693#498693 ________________________________________________________________________________
Subject: AC 43.13-1B circuit protection recommendations
Date: Oct 08, 2020
Looking at table 11-3 in the 43.13, the table shows lower amperage recommendations for fuses versus circuit breakers in many cases. Bob has shown us how much quicker a fuse operates versus a CB so logic seems to suggest a higher fuse rating versus a CB. What am I missing? Thanks! -------- Flying Sonerai II with A80 Continental. Wittman W10 Tailwind under construction, O360, dual LSE electronic ignition, airframe complete and covered, engine hung, cowl built. Working on electrical, instrumentation, and other details. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=498695#498695 ________________________________________________________________________________
Subject: Re: antenna analyzer? Antennas
Date: Oct 08, 2020
Hi Group, Long time lurker here. Hopefully, as the OP made the title rather broadband ;) a general discussion on aviation / aircraft antenna design and using antenna analyzers for verifying experiments is welcome here. Otherwise, apologies for further dragging the discussion away from the otherwise fascinating DDRR antenna design... I recently bought a Rig Expert AA 230 ZOOM analyzer, primarily for helping to diagnose faults in antenna coax while doing the odd bit of experimental aircraft rewiring. Its been a great tool for quickly and easily finding poorly made BNC terminations for example (wire disconnected from center pin in a poorly made, screw-together style BNC connector) and checking SWR in a comm antenna epoxied into a composite aircraft is still acceptable years after construction. As for using an analyzer for antenna design, the interesting, very detailed paper Eric posted a link to, titled 'Airborne VHF Printed Monopole Antenna for Platform Constrained Applications' looks like it could be a fun design to experiment with - possibly for installing inside the fin of the Kitfox I'm going to be building - especially as the ground plane is incorporated in the same plane as the antenna. I have a basic understanding of antenna design, but its very basic - and with a few antenna issues and projects on the go, I'd be very interested in furthering my knowledge and doing some experimenting with the aid of the analyzer. What would be useful are some links to modern literature on aviation/aircraft antenna design - many thanks Eric for your post! I had a browse through the ARRL Antenna Book which is a great tome of info, however the vast majority of that material is aimed at ground station antennas. So I'm still unclear on such things as by how much proximity to The Earth the SWR of an aircraft (comm) antennas is affected. Maybe a flight vs ground test comparison using an analyzer might be interesting to conduct, even if it proves 'no significant difference', particularly for 1/2 wave dipoles fitted internally to composite aircraft. I've found some other recently published and interesting material with test results on (ground based) 2m 1/2 wave dipole designs that might be worth experimenting / adapting for aircraft use, but will save that for another post if there's interest. Cheers, Jim Hamish 'Jim' Mead Ledbury, UK Read this topic online here: http://forums.matronics.com/viewtopic.php?p=498696#498696 ________________________________________________________________________________
Subject: Re: AC 43.13-1B circuit protection recommendations
Date: Oct 08, 2020
Here's an image of Table 11-3. -------- John Bright, RV-6A, at FWF, O-360 Z-101 single batt dual alt SDS EM-5-F. john_s_bright(at)yahoo.com, Newport News, Va https://drive.google.com/drive/folders/1u6GeZo6pmBWsKykLNVQMvu4o1VEVyP4K Read this topic online here: http://forums.matronics.com/viewtopic.php?p=498698#498698 Attachments: http://forums.matronics.com//files/ac_4313_1b_table_11_3_301.jpg ________________________________________________________________________________
Date: Oct 08, 2020
Subject: Re: Breaker then pump failure
At 10:14 PM 10/7/2020, you wrote: I just had the Tyco switch/breaker for my boost pump fail. It made a bad smell, then became intermittent, then failed completely in the span of a few minutes. I replaced it with the same make and model. Do you still have the carcass? I'd like to have it . . . 2.5 flight hours later my boost pump failed. The new breaker never tripped. The pump just stopped running. The pump circuit has no resistance and I get full bus voltage at the pump, even with the pump still connected. So it's open inside. The new switch is working fine. Agreed The pump is from Airflow Performance. They're common in RVs. The pump and the switch had almost 2000 airframe hours since installed. I use it for take-off and landing, so the powered time is a fraction of the total time. I think that pump has a PM motor with brushes. It's not uncommon for such devices to suffer as much degradation from idle time as from service life. In any case, I'm betting that the pathway through the armature is open for reasons we do not yet know. Does the pump have a 'cure' value? If not, I'd be pleased to do a autopsy on it too. The airplane had been sitting for almost a year, then flown about 15 hours in the last two weeks. Does anyone have an understanding of any relationship between these two failures? They seem too similar to be completely unrelated. My guess is that a faulty pump somehow overloaded a faulty breaker, then failed completely. I couldn't say that I noticed any particular fuel pressure issues before the failure. Everything was in the green. Thoughts? I suspect they are not related. In theory, you can't damage a breaker by 'overloading' it . . . after all, its core mission in life is to protect from the consequences of such conditions including self destruction. Getting a look at the carcasses might offer more clues. Bob . . . ________________________________________________________________________________
Date: Oct 08, 2020
At 07:25 AM 10/8/2020, you wrote: > >Looking at table 11-3 in the 43.13, the table shows lower amperage >recommendations for fuses versus circuit breakers in many cases. Bob >has shown us how much quicker a fuse operates versus a CB so logic >seems to suggest a higher fuse rating versus a CB. What am I missing? I haven't a clue. I questioned this in the critical review we submitted through EAA many moons ago but the item was never modified or explained. If I were to WAG this one, the writer may have been comparing performance of fuses vs. magnetic breakers. In this case the breakers are faster than fuses . . . but TERRIBLE choices for general use in light aircraft power distribution. If one simply compares the fusing dynamics of the fuses vs. thermal breakers, the AC43-13 suggestion doesn't make sense at all. Actually, there's no reason to up-size the rating of protection based on the technology. Breaker and wire ratings are based on effects of the wire's natural self-heating and is concerned only with the wire's INSULATION. Long term heating effects are a function of NORMAL current flows, voltage drops in wire and temperature of the environment which includes both the airframe and adjacent wires in bundles. That's a real snarl of snakes to unwind for all but design goals of the most pedantic of program managers. For our purposes, the rule of thumb is, "if in doubt, up-size the wire and protection to the next step." Moving up can only reduce effects of NORMAL heating. Consider that 99% of all breaker/fuse events are caused by ABNORMAL current well above the NORMAL . . . like hard shorts or catastrophic failures in appliances. We are virtually never victims of a failed insulation condition . . . The short answer is: Your common sense questioning of the AC43-13 assertion is valid. Ignoring it based on your own study of PROPERTIES OF MATERIALS is not a risky thing to do. Bob . . . ________________________________________________________________________________
Date: Oct 08, 2020
On Thu, Oct 8, 2020 at 11:42 AM Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 10:14 PM 10/7/2020, you wrote: > snipped . > > 2.5 flight hours later my boost pump failed. The new breaker never > tripped. The pump just stopped running. The pump circuit has no > resistance and I get full bus voltage at the pump, even with the pump still > connected. So it's open inside. The new switch is working fine. > > Agreed > > > The pump is from Airflow Performance. They're common in RVs. The pump > and the switch had almost 2000 airframe hours since installed. I use it > for take-off and landing, so the powered time is a fraction of the total > time. > > I think that pump has a PM motor with brushes. > It's not uncommon for such devices to suffer > as much degradation from idle time as from > service life. In any case, I'm betting that > the pathway through the armature is open for > reasons we do not yet know. Does the pump > have a 'cure' value? If not, I'd be pleased > to do a autopsy on it too. > > The airplane had been sitting for almost a year, then flown about 15 hours > in the last two weeks. > > > Does anyone have an understanding of any relationship between these two > failures? They seem too similar to be completely unrelated. My guess is > that a faulty pump somehow overloaded a faulty breaker, then failed > completely. I couldn't say that I noticed any particular fuel pressure > issues before the failure. Everything was in the green. > > Thoughts? > > I suspect they are not related. In theory, you > can't damage a breaker by 'overloading' it . . . after > all, its core mission in life is to protect from > the consequences of such conditions including self > destruction. Getting a look at the carcasses might > offer more clues. > > > Bob . . . > The core pump in the AFP pumps I'm familiar with are Airtex brand in-line fuel injection pumps, available online for between $60 & $100. Like this? https://www.amazon.com/Airtex-E2000-Electric-Fuel-Pump/dp/B000C1KHJG/ref=sr_1_7?dchild=1&keywords=airtex+fep2000+fuel+pump&qid=1602176199&sr=8-7 Either E2000 or FEP2000. Note that the hose barb shown on one end screws off, allowing various other adapters. If the OP wishes, I can measure my FEP2000 to verify dimensions. Charlie ________________________________________________________________________________
Date: Oct 08, 2020
> >The core pump in the AFP pumps I'm familiar with >are Airtex brand in-line fuel injection pumps, >available online for between $60 & $100. Like this? >https://www.amazon.com/Airtex-E2000-Electric-Fuel-Pump/dp/B000C1KHJG/ ref=sr_1_7?dchild=1&keywords=airtex+fep2000+fuel+pump&qid=1602176199 &sr=8-7 >Either E2000 or FEP2000. Note that the hose barb >shown on one end screws off, allowing various other adapters. >If the OP wishes, I can measure my FEP2000=C2 to verify dimensions.=C2 > >Charlie Interesting. The specs speak to commutators and brushes. I also deduce that this style of pump is used on a lot of medium pressure EFI systems. It will be interesting to see if we can open Dave's dead one for a closer looksee. Bob . . . ________________________________________________________________________________
Date: Oct 08, 2020
At 07:53 AM 10/8/2020, you wrote: Hi Group, Long time lurker here. Hopefully, as the OP made the title rather broadband ;) a general discussion on aviation / aircraft antenna design and using antenna analyzers for verifying experiments is welcome here. Otherwise, apologies for further dragging the discussion away from the otherwise fascinating DDRR antenna design... I think we're done with the DDRR for now. It seems unlikely that a satisfactory fabrication technique for increasing bandwidth will be forthcoming. The antenna gurus all seem to agree that the perfect triad of size, efficency and bandwidth is like finding a way to to resolve cube roots with a pencil/paper. Unfortunately for the DDRR, the primary driver (size) put the kibosh on at least one of the other two, mainly bandwidth. I recently bought a Rig Expert AA 230 ZOOM analyzer, I've seen those tools on the web . . . they seem widely utilized with satisfaction. As for using an analyzer for antenna design, the interesting, very detailed paper Eric posted a link to, titled 'Airborne VHF Printed Monopole Antenna for Platform Constrained Applications' looks like it could be a fun design to experiment with - possibly for installing inside the fin of the Kitfox I'm going to be building - especially as the ground plane is incorporated in the same plane as the antenna. On page 2 we find this statement, "The major constraint in designing an airborne printed monopole antenna in VHF/UHF band is achieving compactness and wide bandwidth simultaneously, along with sufficient gain." This assertion pays homage to the SEB triad with the operative phrase being "sufficient gain". Figure 6 shows that a very satisfactory bandwidth was achieved while Figure 7 shows the sacrifices in efficiency wherein the two test conditions demonstrate losses of 6 to 15 dB over the bandwidth of interest. That's 1/4 to 1/32 of the radiated energy offered by the reference antenna. Sufficient? Maybe. Recall that all VHF comm is line of sight . . . you don't talk past the horizon and in any case, it's almost never necessary to have conversation beyond 50 miles or so. So maybe, just maybe an antenna with that efficiency profile would provide satisfactory communications for some if not all builders. The proof is in the pudding (I prefer vanilla-tapicoa myself). I had a browse through the ARRL Antenna Book which is a great tome of info, however the vast majority of that material is aimed at ground station antennas. So I'm still unclear on such things as by how much proximity to The Earth the SWR of an aircraft (comm) antennas is affected. It's not . . . but proximity to conducting aircraft structure (artificial ground) is. So ground vs. airborne testing is probably not useful. The flight test of intense interest would be with perhaps a software driven receiver (SDR) on board where you would fly 360s out 40 miles or so from a handy ground station and plot comparative azimuth measurements of your test antenna with respect to a more conventional vhf comm whip. We used to do a good bit of this type testing at Hawer-Beech . . . which requires another previously expensive but now not so much spectrum analyzer/receiver with signal strength display. I've found some other recently published and interesting material with test results on (ground based) 2m 1/2 wave dipole designs that might be worth experimenting / adapting for aircraft use, but will save that for another post if there's interest. Let's look at them . . . Bob . . . ________________________________________________________________________________
Date: Oct 08, 2020
Subject: Some new battery chemistries on the horizon?
While lithium products are the fair-haired children in the portable energy storage sandbox, there's a couple of interesting technologies being spun-up in the EV world: https://tinyurl.com/yy8cqwbe https://tinyurl.com/y2ptgrjz These MIGHT find application in aviation and consumer products with some dispatch. Contemporary EV batteries evolved up from the smaller, less energetic consumer products. These new kids on the block will enjoy immediate success and large scale production in a particularly battery-intensive market: EVs. It seems likely that they could 'spill out' into the consumer markets quickly. It's intuitively easier to evolve- down a product that's already enjoying high volume successes. We'll have to wait and see . . . Bob . . . ________________________________________________________________________________
Date: Oct 08, 2020
I believe Airflow Performance with do a rebuild at reasonable price. Might not get the diagnosis desired, but could be cheaper than alternatives. On 10/8/2020 12:08 PM, Robert L. Nuckolls, III wrote: >> >> The core pump in the AFP pumps I'm familiar with are Airtex brand >> in-line fuel injection pumps, available online for between $60 & $100. >> Like this? >> https://www.amazon.com/Airtex-E2000-Electric-Fuel-Pump/dp/B000C1KHJG/ref=sr_1_7?dchild=1&keywords=airtex+fep2000+fuel+pump&qid=1602176199&sr=8-7 >> >> Either E2000 or FEP2000. Note that the hose barb shown on one end >> screws off, allowing various other adapters. >> If the OP wishes, I can measure my FEP2000 to verify dimensions. >> >> Charlie > > Interesting. The specs speak to commutators and > brushes. I also deduce that this style of pump > is used on a lot of medium pressure EFI systems. > > It will be interesting to see if we can open > Dave's dead one for a closer looksee. > > > Bob . . . > ________________________________________________________________________________
Date: Oct 08, 2020
Charlie wrote: > The core pump in the AFP pumps I'm familiar with are Airtex brand in-line > fuel injection pumps, available online for between $60 & $100. Like this? > > https://www.amazon.com/Airtex-E2000-Electric-Fuel-Pump/dp/B000C1KHJG/ref=sr_1_7?dchild=1&keywords=airtex+fep2000+fuel+pump&qid=1602176199&sr=8-7 > Either E2000 or FEP2000. Note that the hose barb shown on one end screws > off, allowing various other adapters. > If the OP wishes, I can measure my FEP2000 to verify dimensions. > > Charlie > Between Amazon and the Airtex web site, my pump seems most like an E8445. There are a lot of models and I haven't ID'd it exactly. The E2000 looks the same but it puts out almost three times the pressure that I see. I sent my pump assy to AFP where they replaced the pump for a little more than the Amazon price. They did a great job, shipping back the repaired assembly within hours of receiving it. Bob, if I get the old pump back, I'll send it to you along with the breaker. BTW, I just became aware of an AD from 2008 to replace this type of CB switch in Beechcraft products. --Dave ________________________________________________________________________________
Date: Oct 08, 2020
Bob wrote: > Do you still have the carcass? I'd like to have > it . . . > Here's a picture for now. I broke in before I sent my initial message. Charred remains to follow. I'm almost certain that the braid broke when I opened it. The little barbequed U spring is missing most of its legs. I wonder if one broke off and shorted something to start the failure. The switch had lost it's "snap" after it quit. Here's a picture from a Beech website. These are serviceable and very similar to what I have. [image: image.png] ________________________________________________________________________________
Date: Oct 09, 2020
NO. The braid is the weak point. Where it's spot welded to the contact it's hardened. As the switch is turned on/off the braid flexes. Same as what happens when you have a soldered flexible wire that is not supported at a point where the wire is still flexible (after the solder penetration). It's a glaring design failure. Easily fixed by two molded pins in the plastic housing that would provide support where braid is again flexible. Why they haven't done that after the extensive failure history is beyond me. Do not use these switch/breakers for flight-critical items! Finn On 10/9/2020 1:50 AM, David Saylor wrote: > > Bob wrote: > > Do you still have the carcass? I'd like to have > it . . . > > > Here's a picture for now. I broke in before I sent my initial > message. Charred remains to follow. > > I'm almost certain that the braid broke when I opened it. > > The little barbequed U spring is missing most of its legs. I wonder > if one broke off and shorted something to start the failure. > > The switch had lost it's "snap" after it quit. > > Here's a picture from a Beech website. > These are > serviceable and very similar to what I have. > > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Subject: Z102 w/AEC9005
Date: Oct 09, 2020
Hi Bob, I'm building a Kitfox that will probably use an auto-based engine conversion. I like the look of your Z102 architecture for its redundancy in engine electrical supply, as well as the auxiliary bus for pre-flight ground activities. But, I have a couple of questions: 1. Am I correct in my understanding that: a) the auxiliary battery is normally paralleled with the main battery during engine start *and* during normal operation (bus voltage >13V) so that it can be recharged by the alternator? b) the auxiliary battery will be isolated to engine-related functions only, if the bus falls below 13V? 2. The Z102 schematic shows a START CMD signal from the push-to-start switch to an AEC90XX Aux Battery Management Module (ABMM). The only thing like this that I can find is your AEC9005 series of Low Voltage Warning and ABMM devices. However, the AEC9005 schematic in this document... http://www.aeroelectric.com/DIY/LV_Warn_Fab_and_Install.pdf ...does not include an input for the START CMD signal. Is there another ABMM design on the drawing board, or does Z102 contemplate an iteration of AEC9005 with the addition of the START CMD facility? If the latter, then is it safe to assume that START CMD is simply a gate drive signal to the FET, diode isolated from the comparator output? 3. On the AEC9005 schematic linked above, what is the purpose of Zener diode Z118? Is it to protect the FET against excessive V(d-s) in case the contactor's flyback diode fails to perform, or is missing? Many thanks! Eric Read this topic online here: http://forums.matronics.com/viewtopic.php?p=498724#498724 ________________________________________________________________________________
Subject: Wire stripper
Date: Oct 09, 2020
I would like to replace my wire stripper that has recently failed. I am interested in a tool that can strip wires in the range 10-22 AWG and possibly smaller wires as the ones sometimes used in avionics and instruments. I would buy 2 strippers, if necessary. Could somebody make a recommendation for a good quality, reliable tool? Thanks Read this topic online here: http://forums.matronics.com/viewtopic.php?p=498730#498730 ________________________________________________________________________________
Subject: Re: Wire stripper
Date: Oct 09, 2020
Argonaut36, The Ideal Stripmaster 45-097 from B&C (bandc.com) is an excellent wire stripper. As received it strips wire from 16-26 AWG. The stripper blades are replaceable and an adjustable wire stop is available for it. Im sure similar strippers are available at other electronics site. Blue skies & tailwinds, Bob Borger Europa XS Tri, Rotax 914, Airmaster C/S Prop. Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP, Hercules Prop. 3705 Lynchburg Dr. Corinth, TX 76208-5331 Cel: 817-992-1117 rlborger(at)mac.com > On Oct 9, 2020, at 6:33 PM, Argonaut36 wrote: > > > I would like to replace my wire stripper that has recently failed. I am interested in a tool that can strip wires in the range 10-22 AWG and possibly smaller wires as the ones sometimes used in avionics and instruments. I would buy 2 strippers, if necessary. > > Could somebody make a recommendation for a good quality, reliable tool? > > Thanks > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=498730#498730 > > > > > > > > > ________________________________________________________________________________
Date: Oct 09, 2020
On 10/9/2020 6:33 PM, Argonaut36 wrote: > > I would like to replace my wire stripper that has recently failed. I am interested in a tool that can strip wires in the range 10-22 AWG and possibly smaller wires as the ones sometimes used in avionics and instruments. I would buy 2 strippers, if necessary. > > Could somebody make a recommendation for a good quality, reliable tool? > > Thanks > Do you want basic strippers, or an 'automatic' version? Auto is faster (and a lot more expensive), but I find them harder to use when I need to strip an exact amount for things like subD terminals. Ideal makes automatic versions, if that's what you want. Klein can almost always be counted on to make good tools; just google 'Klein wire strippers' to see what's available. I've got an Ideal automatic, a Klein, and several other variations, but to be honest, my go-to stripper is one I bought from a surplus goods mail order company over 30 years ago. It might be worthwhile to take a few wire scraps to a local hardware store, or even a 'big box' store, & play with their selection of strippers. Pick one you're comfortable with & go with it. Charlie -- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Subject: Kinda slick demisting fan speed control
Date: Oct 09, 2020
Hi Group Figured would share a kinda kool speed control for demisting / cooling fans on instrument module. Fans are 12 volts. Using a DPTT switch. Either 2P2S or 4P: https://1drv.ms/u/s!Ah1S270Nwg9V3SVeUvEe3G84uKjR?e=HLzX1T Pic of fans: http://www.europaowners.org/main.php?g2_itemId=79733 Ron P. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=498735#498735 ________________________________________________________________________________
Subject: Re: On-the-ground power jack
From: "prestonkavanagh" <preston.kavanagh(at)gmail.com>
Date: Oct 09, 2020
I'm picking up this old thread because of the excellent walk through of the "why" of the circuit....Building a Z101 Cozy and adding a ground power function using Piper jacks. I need to find a suitable overvoltage protector. I don't see the OVM-14 on the B&C site, but I wonder if I can use a Lambda LMOV unit. Or am I better off mucking around with some MOS-FET's? Here's the Lambda OV protection I have in mind - comments? https://www.ebay.com/itm/Lambda-LMOV-2-Overvoltage-Protector-6-20v-dc/292566713401 The rest of the circuit would not change. Thanks for the help. Preston K. -------- PBK3 PA-12, BD-4, RV6a, gliders Read this topic online here: http://forums.matronics.com/viewtopic.php?p=498736#498736 ________________________________________________________________________________
Date: Oct 09, 2020
According to this pdf: https://www.mavin.com/pdf/LMOV-9.pdf The LMOV-2 shorts out the power supply in case of over voltage. So it should work. Another option is Perihelion Design's over voltage protection module $88. http://www.periheliondesign.com/lovm.htm It works by opening a circuit instead of shorting it out. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=498737#498737 ________________________________________________________________________________
Date: Oct 09, 2020
On 10/9/2020 8:59 PM, user9253 wrote: > > According to this pdf: https://www.mavin.com/pdf/LMOV-9.pdf > The LMOV-2 shorts out the power supply in case of over voltage. So it should work. > Another option is Perihelion Design's over voltage protection module $88. > http://www.periheliondesign.com/lovm.htm > It works by opening a circuit instead of shorting it out. > > -------- > Joe Gores > > Or the one I linked earlier, from Tomtop. -- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Oct 10, 2020
While lithium products are the fair-haired children in the portable energy storage sandbox, there's a couple of interesting technologies being spun-up in the EV world: https://tinyurl.com/yy8cqwbe https://tinyurl.com/y2ptgrjz A follow up on the two articles I cited above . . . Here's a more detailed description of the tab-less construction of the proposed cylindrical cell by Tesla: https://tinyurl.com/y4vv7ozl Some of you may recall a few years back when a start-up in Golden Colorado called Bolder Technologies was rolling out an improved version of SVLA jelly-roll cells. https://tinyurl.com/y42v9ztj We looked at these at B&C. Examples of the 'Start Stick' made appearances at OSH about that time too. Truly amazing performance . . . when they worked. Seems that one, and perhaps the most important process to master was how to achieve good electrical contact with the (-) and (+) plates on each end of the jelly-roll. You had to get hooked up to the entire length of the exposed edges at each end. Failing that, achieving a consistent. 2 milliohm cell resistance was not possible. Degradation of that connection resulted in rapid failure of the cell. The company folded in the US and I think the idea was sold . . . perhaps a couple of times . . . off shore. Haven't hear anything about them lately. Now, it seems that the smart guys at Tesla have a different approach to getting a grip on the edges of foils. This may signal a quantum jump in cell performance. Cells like that would allow folks like AeroVoltz to achieve really BIG cranking currents from their relatively small packages. I recall a conversation with Skip Koss (battery guru par excellence at Concorde) wherein diminutive cells with good cranking might be fabricated into a battery module that would fit right onto the back of a starter motor . . . zero-length fat wires in the cranking circuit. For our purposes, this would allow dual alternator systems to drop distribution wire sizes down to just system loads and take the battery out of the operational power loop. Interesting stuff . . . Bob . . . ________________________________________________________________________________
Date: Oct 10, 2020
Thanks to All for the help. I placed an order for the Ideal Stripmaster 45-097. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=498740#498740 ________________________________________________________________________________
Date: Oct 11, 2020
Thanks for your and Bob's wisdom... Guess we're always learning... I've taken into account the suggestion of the battery relay, explained the argument once again, leveled pros & cons but it still a no in this situation. Moved the crow bar. Should at least work as it's intended... -------- 2020 contribution paid Read this topic online here: http://forums.matronics.com/viewtopic.php?p=498742#498742 Attachments: http://forums.matronics.com//files/schema_electrique_rev_b_184.pdf ________________________________________________________________________________
Subject: Garmin 400 series memory battery low
Date: Oct 12, 2020
Hi all, After 16 years of sevice, our GPS 400 memory battery just died. All stored data are lost, so no problem preserving them. It seems the CR 14250 SE (3V) internal battery is soldered onto the mother board. According to some sources, replacement is straightforward, except some ESD precautions are mandatory https://www.ulimike.de/umhtml/gns_430.html Has anyone here already performed such a replacement, and could shade some light on the actual precautions (soldering iron, work table covering, grounding wrist band, etc.) ? Thanks in advance for you input, take care -- Best regards, Gilles http://contrails.free.fr http://lapierre.skunkworks.free.fr ________________________________________________________________________________
Date: Oct 11, 2020
Subject: Re: Garmin 400 series memory battery low
I=99ve done a couple of those. It=99s pretty straightforward. I don=99t recall taking ESD precautions but if I did it again, I would. =94Dave On Sun, Oct 11, 2020 at 16:44 Gilles Thesee <gilles@elixir-aircraft.com> wrote: > gilles@elixir-aircraft.com> > > Hi all, > > After 16 years of sevice, our GPS 400 memory battery just died. > > All stored data are lost, so no problem preserving them. > > It seems the CR 14250 SE (3V) internal battery is soldered onto the > mother board. > > According to some sources, replacement is straightforward, except some > ESD precautions are mandatory > > https://www.ulimike.de/umhtml/gns_430.html > > > Has anyone here already performed such a replacement, and could shade > some light on the actual precautions (soldering iron, work table > covering, grounding wrist band, etc.) ? > > > Thanks in advance for you input, take care > > -- > Best regards, > Gilles > http://contrails.free.fr > http://lapierre.skunkworks.free.fr =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Oct 12, 2020
Gilles, I would suggest you use Google Translate to translate the German instructi ons into English. https://translate.google.com/#view=home&op=translate&sl=de&tl=en Charlie K e(at)gmail.com> wrote: I=99ve done a couple of those. It=99s pretty straightforward. =C2- I don=99t recall taking ESD precautions but if I did it again, I would. =94Dave On Sun, Oct 11, 2020 at 16:44 Gilles Thesee <gilles@elixir-aircraft.com> wr ote: aft.com> Hi all, After 16 years of sevice, our GPS 400 memory battery just died. All stored data are lost, so no problem preserving them. It seems the CR 14250 SE (3V) internal battery is soldered onto the mother board. According to some sources, replacement is straightforward, except some ESD precautions are mandatory https://www.ulimike.de/umhtml/gns_430.html Has anyone here already performed such a replacement, and could shade some light on the actual precautions (soldering iron, work table covering, grounding wrist band, etc.) ? Thanks in advance for you input, take care -- Best regards, Gilles http://contrails.free.fr http://lapierre.skunkworks.free.fr - Electric-List" rel="noreferrer" target="_blank">http://www.matronics.co m/Navigator?AeroElectric-List FORUMS - eferrer" target="_blank">http://forums.matronics.com WIKI - errer" target="_blank">http://wiki.matronics.com b Site - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Oct 12, 2020
On Fri, Oct 9, 2020 at 12:24 AM David Saylor wrote: > Charlie wrote: > > >> The core pump in the AFP pumps I'm familiar with are Airtex brand in-line >> fuel injection pumps, available online for between $60 & $100. Like this? >> >> https://www.amazon.com/Airtex-E2000-Electric-Fuel-Pump/dp/B000C1KHJG/ref=sr_1_7?dchild=1&keywords=airtex+fep2000+fuel+pump&qid=1602176199&sr=8-7 >> Either E2000 or FEP2000. Note that the hose barb shown on one end screws >> off, allowing various other adapters. >> If the OP wishes, I can measure my FEP2000 to verify dimensions. >> >> Charlie >> > > Between Amazon and the Airtex web site, my pump seems most like an E8445. > There are a lot of models and I haven't ID'd it exactly. The E2000 looks > the same but it puts out almost three times the pressure that I see. > > I sent my pump assy to AFP where they replaced the pump for a little more > than the Amazon price. They did a great job, shipping back the repaired > assembly within hours of receiving it. > > Bob, if I get the old pump back, I'll send it to you along with the > breaker. > > BTW, I just became aware of an AD from 2008 to replace this type of CB > switch in Beechcraft products. > > --Dave > > Congrats on the inexpensive repair! The reason I'd bet on the E2000 is that the E8445 appears to have a fixed hose barb output, while the E2000 has a threaded fitting on the output, allowing choice of fittings. Note that both pumps are capable of much higher pressure (and volume) than Bendix injection (or even automotive electronic injection) uses. Both types require a mechanical 'bypass' style pressure regulator to set pressure, and excess fuel is vented by the regulator. In the older cars where these pumps were used, the bypassed fuel returned to the fuel tank. With the AFP pump assembly, that extra block of metal in the assembly is the regulator and routes the bypassed fuel back to the pump inlet. In later models, the same device functions as a check valve, allowing the engine's mechanical pump to 'suck' fuel around the electric pump itself. Earlier models had a separate check valve, IIRC. Charlie ________________________________________________________________________________
Date: Oct 12, 2020
That AD is rather controversial, in that the exact same breaker is used in many other plane models and brands, but the AD was only issued against specific Beech models. Kelly On 10/12/2020 6:37 AM, Charlie England wrote: > BTW, I just became aware of an AD from2008 to replace this type of > CB switch in Beechcraft products. > > --Dave > ________________________________________________________________________________
Date: Oct 12, 2020
Charlie, The one that came back looked identical. Same threaded inlet, same banjo outlet, same terminals. It's marked "Delphi FD0011". Delphi has a store on Amazon, and the description is for a solenoid pump. The new one sounds much different. I suppose it's a healthier sound now but it seems much higher pitch. AFP didn't send the old one back. --Dave > >> > >> Congrats on the inexpensive repair! The reason I'd bet on the E2000 is > that the E8445 appears to have a fixed hose barb output, while the E2000 > has a threaded fitting on the output, allowing choice of fittings. Note > that both pumps are capable of much higher pressure (and volume) than > Bendix injection (or even automotive electronic injection) uses. Both types > require a mechanical 'bypass' style pressure regulator to set pressure, and > excess fuel is vented by the regulator. In the older cars where these pumps > were used, the bypassed fuel returned to the fuel tank. With the AFP pump > assembly, that extra block of metal in the assembly is the regulator and > routes the bypassed fuel back to the pump inlet. In later models, the same > device functions as a check valve, allowing the engine's mechanical pump to > 'suck' fuel around the electric pump itself. Earlier models had a separate > check valve, IIRC. > > Charlie > ________________________________________________________________________________
Date: Oct 12, 2020
Very interesting Finn. That makes a lot of sense. On Fri, Oct 9, 2020 at 7:31 AM Finn Lassen wrote: > NO. The braid is the weak point. > > Where it's spot welded to the contact it's hardened. As the switch is > turned on/off the braid flexes. Same as what happens when you have a > soldered flexible wire that is not supported at a point where the wire is > still flexible (after the solder penetration). > ________________________________________________________________________________
Date: Oct 12, 2020
At 08:58 AM 10/12/2020, you wrote: > >That AD is rather controversial, in that the exact same breaker is >used in many other plane models and brands, but the AD was only >issued against specific Beech models. >Kelly I was on the team that worked that issue at Beech. The failure mode that started the investigation involved switch-breakers subject to the highest of ship's loads, i.e. electric prop de-ice. I know that same s/b was used on some Cessna models . . . but perhaps only on lightly loaded circuits. Root cause is a mechanical issue. The fine strand jumper wire starts to loose strands due to operational flexing of the jumper. In the incident switches, loss of that jumper caused system current to flow through the spring. For the smaller switches, 5-10A, there is no immediate indication of failure. For the higher current applications, the spring heats up causing smoke from the burning of the switch's housing. I read that the smoke rather jetted from around the switch's actuator handle. Here's my library of photos and illustrations generated to support my task at Beech along with documents speaking to field responses. https://tinyurl.com/y48y93rk I worked analysis of the carcasses while others researched affected aircraft . . . which was a whole lot! There was a potential for thousands of aircraft and tens of thousands of switches to be at risk. Cessna had a similar situation as cited in documents offered above. This was a tough one. Existence of the insulator did not stop mechanical failure of the braid . . . it only prevents smoke generation by the heavily loaded switches. With the insulator in place, the switch simply opens up. Replacing all the at-risk switches in all fielded aircraft was a really BIG deal. The Bonanza Society and AOPA did a survey of affected aircraft owners and came to the conclusion that the failures were rare, occurrences of spring failure and smoke were rarer still. They opined that these events were very low risk and that a more relaxed approach to dealing with the condition was warranted. The FAA agreed. Bob . . . ________________________________________________________________________________
Date: Oct 12, 2020
The 1st hit I got on Amazon shows what appears to be a clone of the E2000. (Or the E2000 is a clone of the Delphi; who knows? :-) ) The Amazon ad says 'solenoid style'. Not sure what they mean by that, other than it's a cylindrical container like the activator solenoid on a starter motor. The pump is an electric motor, driving either a gerotor or roller-vane pump, all inside that housing. The sound is a whir or whine, right? Not a clicking sound. The low pressure Facet 'cube pumps' used as carb boost pumps make a clicking/buzzing/rattling sound; they are effectively 'solenoid' pumps. Just to be sure you know...Try your best to be sure that the pump gets a prime (pumps fuel) quickly when you 1st run the pump, even if you have to open the output side so it pumps into an open container. Most pumps like these will self prime, but they will only survive for a few minutes without fuel flowing through them. Configured like the AFP 'system' with the regulator bypass back to the inlet, they sometimes *won't* self-prime because they pump air in a loop around the pump instead of sucking fuel. That can kill the pump in a few minutes. Charlie On Mon, Oct 12, 2020 at 10:41 AM David Saylor wrote: > Charlie, > > The one that came back looked identical. Same threaded inlet, same banjo > outlet, same terminals. It's marked "Delphi FD0011". Delphi has a store > on Amazon, and the description is for a solenoid pump. > > The new one sounds much different. I suppose it's a healthier sound now > but it seems much higher pitch. > > AFP didn't send the old one back. > > --Dave > > >> >>> >> >>> Congrats on the inexpensive repair! The reason I'd bet on the E2000 is >> that the E8445 appears to have a fixed hose barb output, while the E2000 >> has a threaded fitting on the output, allowing choice of fittings. Note >> that both pumps are capable of much higher pressure (and volume) than >> Bendix injection (or even automotive electronic injection) uses. Both types >> require a mechanical 'bypass' style pressure regulator to set pressure, and >> excess fuel is vented by the regulator. In the older cars where these pumps >> were used, the bypassed fuel returned to the fuel tank. With the AFP pump >> assembly, that extra block of metal in the assembly is the regulator and >> routes the bypassed fuel back to the pump inlet. In later models, the same >> device functions as a check valve, allowing the engine's mechanical pump to >> 'suck' fuel around the electric pump itself. Earlier models had a separate >> check valve, IIRC. >> >> Charlie >> > Virus-free. www.avast.com <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> ________________________________________________________________________________
Date: Oct 12, 2020
Subject: Trouble with Image Attachment
I'm trying to include a picture with a posting to the List by including as an attachment.=C2- However I get an error message from the Matronics serv er that says "Non supported enclosure type..".=C2- The file is a 3 Mb .jpeg.=C2- The error message lists .jpeg=C2- as a va lid attachment type. What am I doing wrong? -Jeff ________________________________________________________________________________
Date: Oct 12, 2020
Subject: Re: Trouble with Image Attachment
At 11:48 AM 10/12/2020, you wrote: >I'm trying to include a picture with a posting to the List by >including as an attachment. However I get an error message from the >Matronics server that says "Non supported enclosure type..". > >The file is a 3 Mb .jpeg. The error message lists .jpeg as a valid >attachment type. > >What am I doing wrong? Hmmmm . . . try resizing the image to 1Mb or less. Bob . . . ________________________________________________________________________________
From: William Daniell <wdaniell.longport(at)gmail.com>
Date: Oct 12, 2020
Subject: In line fuseholder
I have a Z 16 which includes the fusible link between the capacitor and the starter contactor. However in a recent thread I saw that the 16 awg fuselink must be 8 inches - mine is about 4 inches. Also In the same thread I understood that fuselink could be replaced with a time delay fuse. Can I replace the 16awg fuselink with a 30A time delay maxi fuse? thanks Will William Daniell LONGPORT +1 786 878 0246 ________________________________________________________________________________
Date: Oct 12, 2020
Subject: Cinch Box Termina Block
Are these "cinch box" connectors considered gas-tight.=C2- I have to imag ine they are since the terminal block is UL & CSA, etc approved. However, I don't see them used very much on aviation devices.=C2- Is ther e a reason for that? Please see the attached photo. Thx, Jeff Luckey /9j/4AAQSkZJRgABAQEASABIAAD/4QAiRXhpZgAATU0AKgAAAAgAAQESAAMAAAABAAMAAAAAAAD/ 2wBDAAYEBQYFBAYGBQYHBwYIChAKCgkJChQODwwQFxQYGBcUFhYaHSUfGhsjHBYWICwgIyYnKSop GR8tMC0oMCUoKSj/2wBDAQcHBwoIChMKChMoGhYaKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgo KCgoKCgoKCgoKCgoKCgoKCgoKCgoKCj/wAARCATIBmADASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEA AAAAAAAAAAECAwQFBgcICQoL/8QAtRAAAgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJx FDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNk ZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJ ytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQF BgcICQoL/8QAtREAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMz UvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3 eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna 4uPk5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD2Enj0pMZ68U7HrSdBXCdIm36Uc5peo5o+ lACEZGaXGaXGKMYJ60AN70elKR+FHWgBMYxijoaXFJQIXjFJnilA79aXApgJ6UbfSlx6UdKAE6U3 HI9aeeaTH1pANx6nNJinY4pKAG4/Kl7Ypf4RijpzQAmOeaXGMmlH40hHNABjmjFLj1pCB+NAwxzR ijFKPu0CG0hAxmnYHpSDrQAmMGk9acR6UEcCmA3rRjNO/Gg84oAbjAoAOadR0oENxQR9KXFHTrRY Bm0mjGO1SEU3HNADSMGjFOx6UUAMwM+1IQM0/bzxxzQw9aAIiPajH4VJjijGaAIwOaNuDUhFBGaA I8d6TFSY4/GjHzCgRGAc88UY7kH8KlxSEZ9aBkWDRjvUgHrRjrSAjxSfhUm2kIpgMpKkxSYoAZj1 op+2kx9aAG4pOlOIwKMGgBufakxzzUm2kxQAzHtSYqTbSY4oAYB6UYp+OR3oI4FAxgFBGKfj0oxQ BHig07FG2mBGRRUmKTHHNAEXOKXGDUm0UY70wIdvtSYxUzD2pNuBQBCRSYqTGeaNvFICLH/66b07 VOyimstAEJxRjvU22kK0wID1puOan20bPagLFdhTMY5qyy0wrQBBjrSY9anK+lJtz2pCIKTHNT7K QpTGQEU0rzU5X2oK/wCNAFYim4AqxtpCgPamBXxzmjHWpilGygRBjB6cUwj9aslOmOlNKUAViKTG BVjZQU46UAViuaQr6VZ2CkKUAVse2KMfSp9mKTbzQBBjJppGasbfUUhQY6UCK+31600r6VZ2Z7Um zGaYFYr1xTdvFWdnNNKA0AVtuOKO4BqwUwaCnegCvj64pu2rWymFPzoFYg2+2PSmEdO/arWz1FIy e1A7FUg4zSbec479KslKNmKAKxXk03H1qxs9RRs9OlAFYr9abjueatlB2pnl47YoArAc0HnrU5Qf U0bPQcUICv6e/rSY+b6VZKbqTZ/PNMCDHT3pPp2qbZ/OjZz0oEV8fWmkEY9elWtvtTGTjJ/SgCvj v1xxQRU/l+nH1pCnbH6UwIOhHt1pMc8jrU+wY/maTb05xSERADnp0ppHTtj2qbZx09zkUbOKYFfH FBGTyam2Z6ZA9aQr04NICJh+GeKXuMcVJjjGKNnBx0oAjwV7Ckx83IqVl9Rx15pjDnoaYEZHykjr 1prDB/lUypzyPzpxTB6YoEVxkjJHFJjGceuanZeg7UhXjmkBDxuPp6UYyD+dSsvHGfrSFfwpgQ7f 4iCfx5o2/MSePWpwvqB+dIR8oODkdTTEQ7SM0HjOcZ+lS7RjnJ/GjHPSgZCBk9M+9Lj0HQVJgZ46 UhAxzkjp9KQDCMCm7eeBwalIPufqKUp8ozkj0oAi24GOemTmgjJyO/4U/o3H0NGMA/pQAzacnH45 FNxx796mC8ds96awz0HQ0agMx83rzRj+VSKgznjFAUds/WmBGo5+Xv1NGcdRkdMkVIFBGAOaCozj kGkBEARypXB9RQV555x3qXbzkfyoxx2BBGKBEPT6dKMYwR2qTB6DJH1pSP8A9dMCPB7etGCzHdkf TvUirlcYpyr65ye3pQBDj9KTaew5x+dTFcD296Vh+FICL1BHGe9B5z1zUmMYIGR6UoXjHINAyH64 47UKPl6DmpVXg+o6nFO2cADB45oAh6cY7UKARz0qRlPoOmKXZ0IJ4GPY0CIiOp60bcevXtUqrnGO KcEx/nrQBEoweMnipCO/Y0qxnAz6dKcVxjvSGR4+g96Xbn/OKlC9yM89hTtvTPTpigZFtI/EUuOh PPHaptvy8+tKF5wM/lSKIMZ5HalAz0/EGplj45oCc8etICLHX+lO9c//AKql2Dd0x9KVY8dAfrTE Q4xgYxnvRtx9PerCx5IznNKIv/rUAQIv1608DqeRzU6x/n0pQn5d+KQyDbnrzSld31BqyI8+vH60 4IM0rAV1WnAcGp9g/wDr0KnHH41IyEL/AJzShcGp9mAc5pdntTGQ7R6fXNOxn2qXyzTwmW7AUhEC 07b+naphEB1pwjx/+qgD0HoKXgdKTmj8KRQUY7Uc0uKQCc5yaXv3o20YwKYCdqNvrTjR/FQAlJil NH8qBCY446UuBRikA/KgBT70D2pSQfWkoGHX3oIpDRg0wExRjNL0HP40oGKQhvTNHbml60mKACjH r0oJwKXNMBpoxR9KXHzc0ANI5pe9HPJGKX8qAGnrTsfnRij6/WmAYH40h707pSY4pAJj160cGlxT ST9KADjr0pepo+nPFL24oEIBnFGPSiloAbjNBHtTsUMKAG4BpMdKdijFADAKCvXNOxSEc0ANwaBS /wBaPwoAbSjvS4ooASjFL+dHegQlNxn3p+KMUAM20uM07+lHvQMZjikI46U8ikA780wG4oK/hT+K THfmkAzGKMYHBp/fNJxQAw0mKdjsKAKAGgUEc07GKPrQA0j1oxTsfjS4oGR470bfapPwoxQIjI9a Qj0qTbSY4oGR4oIxT8UYIoAjxS4p2PSggUwG4xSYp+PajFADMc0mOad+VLjnp0pgR7aTbUtNNAEZ WjZ0qTFGKAI9tN21KQKTFICHbk80EVLikx+FMCErmkK1LijBzwKAISvFJj2qbFG3tigCAr7U0rnm rBXPWk20AQYpNmKsbKTbSAr7PakKc1YI5pNtNgVtlNKelWttNK89KAKxT6YpNvHerOwd6TbyaYiu VpCmasbaNlICrtx70hSrO2mlM0AV9nzdc03ZVjbik28ccUwKwXFGyrBXpxSbaYits9aTb7Zqxs70 bOlICqVpuw+lW9lNKUAVtn+FGz2qxtpuzFUBBsppUelWCtJtzSAg20MnFT7cdKNnBxmgZVKUmwce tWdtNK0CK5Sk8v2qwV56UgX0FAEAjz0pClWNvqKGXBoAqsnA7U3ZzwKtFQRTdlMCuUpu3nFWdue1 IUpAV9nXj86CntVjb/8Aro2ZpgVtnc5puzI4q2Upuz/JpAVSnv8AlSMnPerO2kKfXFMRVMf0/Kk2 YNWvL4zjrSbB1x9aLgVduelJtP8AWrOzjkUmwZ6UAVimetIU/OrWzPYZpMcDg0AVfLxRt71ZZenX 3pu04HFIRXK56U3aONxJqztOR9OmKaUHemIgVeKcRnipducUFB2zTArleaQqMVPtB6Aj3o2/zpAQ MvzcfTik2jPA9+tWNvXv7+lNK8fSgCALmm4wOeO1WNueMUm3BximMr4x70oAHTrUxT6ijYTyRQBB jHTjmk2/41Y2f40m38BQIh785z70mCegqwqj3zRjbnHegCttzkYwOtG3j/CrG0c/TvSMvqOT6UAQ qufX0pCvGO1TbATj060FeehFO4EIGOf0oI7enNTBct6etLs9c5pAQEfLgjnvRjA96nVeeev1pduK QFZhluARSbT6fWrDID1z60nl5JznHXmmIh2Zyo4P86ULjpg89TVgJk/4UjDPYYoGV9p3Y6/Wjgck kVMFJ/8Ar0oRT2oGRYBoK+nNT7cHpkCmsmDyOKAIse3NIVO7jB9c1Oq5xjFP8vB9frSAqhOOf507 Z6HjNWAhHYUbOTQBX2fj6inBPQVY8s4pQhHagCuI8k7e1OVcn/Cp9nGfTvTgnYg/XFA7Ffy/yoCD IA9atBB/Sl2UCKyoPfj1pVQnpg1Z2YpVT2ANIZAsfr1pwTH4mrIj45FKE9aBlYJ+H0pVj/8A11Z8 v0pyp2xnFIRWEXrThHz3qyE9qcqY7UDKwTPOM/Q0vl+lWNnHTmlC49aAK2zpTljA6dzVnYPSkCe1 ICFU545p6p7VLs9e9O245oGQbKUJk1Ps+tOCDtSGQLHTtg+tWFj6Uqx8UgK3l+mafs9RVhUz2pdn FAFcJkcDpTtnT+VThevFKq89KAOvB5pRTad6VIxeDSD3o7nApaAF/WjHFAOOtHQZNMApelIOlKc8 UAJjPrTQKdzijAoEJgCk9acR35NGB3xQMbihhR06Cj8KYBn1o7+9GBQKAAdOaQcdaXOP8KWgBBSE /wD16B7GigQjYpRzzR2+tJ7GgApe/wD9ekFFACYyeKWlxzSDvn1oAXj3pKBScelADsfhSUp46U05 /wDrUAL2oJ60lFMA70tJg0fSkIVaWkH60v65oAAKKXpR9aYDccUY+tOx6ZpCOKQDT1pD15pxHFJy c0AJ9aB1oxz0o53UCDvRRijqaAACkx60vSjtQDEpe9FH1oAb9KKXHajtQMT2o+lLmkoAMelHSlx6 UYoAbSU/HSm4yKAGn2o/Cl6DpRjt2oATB70fypcUppgNpfpS0AfWgYYpAM06j6cUhDO3SkI6U/p1 pMUDE200in4yeRSYoAaaTBzTsUmMHmgBvsaXAI9KUCjFMBuO9GKdg/hRg0gGYop4FGKYDMZoxxzT 8ccUYzTER4pCKl20YpDIcUgGDUuPWkxxTAixz0NLtp+DRt4oAj20mKlxzQBQBFj1pNtS4oxQBFj0 o21LjijHNAEWKbt5qfHWm7fWgCDbzSlPepttIBQBAVpu2rG2m7eKBEG2jbVjbSFaAK22grzVgrx7 00pQBXK+1N288VY2elIy/pQBXK0m0VY285pu3PancCAr6gUhXsKn2eooZcUAV9lGzPap9tG0UCKx j9qaY6tFc03bzRcZWKUhTjpVkpSbOaBFfb1pNuasMvNNKc0xkBTHtTSoqyVpu3rQIr7OeKTZVjZx RtpDKu3k0Feas7PWkK0AVdtIV56GrW31pCgPamIrBc0FPXFWAmM+1G2gCrspQv41PsNN2fhSAg20 3Z61Y20m32pgQMmO1NCdqsYo20CK+z86Qp7VYKc0baAKwTNJ5fNWdnrTdlAyuVFN2+varOzjpSba YFbZnp1o2fL6GrG386NlIRWKdMdaTYas7PyppUfQUwK5UZzTdvPT8aslQD0pCmDxmgCtsznIoIz0 FWNmPwo2e3fFAirtycc/Sk2D6Va2+v40mzvj6UDK5XHam7farWzj3puygCuy8YGBTSvtVopnp+dJ 5f40CKzAZ7gUbOuB+dWimD+FN29yKAK+0DkdqTb/AJNWdnoKBHnP04oAqBeCBg0bKteXzjrR5eOx NAFbb1o2fN3NWSmRg0FPT8qBlXb+lBT0qxs9RSeWKBEAX/69KFHf8OKsbMLj8aPL4ApCK2zjOPzp RHgnirJjz9aXZ69e1MCvs+U/0pDHntVsJ680bOBQMq+X+OKFi6dqs+X3/nS7Of6UDIPL+bkflTWj Bq1t/WjYaAKqpnGMD6Uvl5PTNWQnTtSiPHPFAFYIR1ApSvynirRTucijZSFYqrH7mn7MYNT+XxnF KI6BkOzP0pQmfr71Y2c4xShM9uaAKwTHY5p+2p9nFATmgCEJTlj/APrVNsx1NOC1IEITFLs4qwF9 qXYCBxTGV9ntTin8qn2/NxRszxQBCFxQByKn8v060bMUARbeSaUIcdKmVMmn7D/k0hlcJQEz1q2E 5o2VIFYJTgvbrVgJ7U4R+ooAr7MU4JVjy/alCelAEITIp2zIGamCfhTgg6EfSgZAyen6U5U/Kp9n Tg04Jx04pDsQbO5Hejb+FWAvqKTYN1AWN3ilzmjjP1opAKoPJp2O/Wm57e9KDQAtHX88UnejPNMB f4qB0FNzQOnNADiM0Ck9uacPc0AIOaB2oPFJigBTSYoyB+FGO5pgJ6Ugpc80NTEJmlP5UYpKQwPa kz+VFFAg/i4oxQKPrQAAn3petJR2oAXpSfSlAxwaXvTATHFJ6UpFI3bNIA/rSYp30pMY9DQITOPS jPFB+lH1pjFpvene1N/CkIcO5pRSLR0pgO70GjP5UGmAGkozzzR61ICHmk7UtH0oASjgUcUHp0oA O/vRQBR3NAgx3pO1O7Uh96AE6dKSlo7UABpvpinDrRjnimMTHalxRjjpR9aADPrQQO1HajNIQ360 vSlagfzoGN7e1J2p/akA9aAEH60mKd6DpSnpQA3HNLjBFLijFAxPejH50fSlx6+lMQ3BoIpaKQCd KQ807HNJ04oAb9aTH1qSkxQMZRjmnUYoAbjFJinUfyoENA4pwoApcZoAbinbRQRSgUwG4oxS0tIY zHtSYOKeRRjjiqAjYetJjHTmpW/Om4z7UAMxk0uKdijFIBm30ox0p2KKBDMUYp+M0mKYxmKNvNSA UmKQEZFG3+VPxRimBHj1pNvNTYyKTFAEWM9aTHtUxFNxmgRGRTcc81Lt60mKAIttIV7VLijbmgZF t56U3b6VPtpNv0oAhxSFR3qbbSFfWkIgZaNtS7TQwpgQlfwpNtTY4pAtAEJTpSbeelTY5o2+tAFc Jz2o2fpU4Sjb60xlcpmm+Xx0q1gEYxSbaAK+wAdKTb7VZZRmkZOaBFbbSFfarJWmlPagCts9qTbV op2pNvrQKxW20m2rJTtSeXjPrQBX24PTim7OoqyU5puzmgCvsppSrRT2pNmRQBU2fzpQnFWCmKQJ igCsV5pdtWCnrSbKAK5TOKaUq1spCn8qY0Vtgpmyre31pNlIRU28mkK+1WylNaPOOKAKm00basmP mmlaYrEG2mlRVnbz60eX1oArbaXZVjZxSbfai4yuV9qTbVjZzQUz2oAqsuaCmOKsbe9GykIrFKNv tVjbgUmzvTAg2fgKTbirBXmgLQBX8v04o28VY2UbKAKxHzcCgpwKsbO3rRt9BRcCsUwTmk2+vpVr Z7UhT2ouBX2c9M0eWKsbOlLsz60mBW2fMCaUJyasbKUJz3phYr7M0vl+oqfZzilCdqBEGzrxQUHp VjZ+NGz/AOvRcZX2c859KNmOxqyEpPL9uaAK/l5pfLwf8asqmOopdnHOaQFby+fxoCcdKtCOl8v1 oAq7eaXZ0qxs9BR5ZxzTAr7OnanKnpU+ylCflSGQBKeEHpU238aNpoAhEdLs61YVKXZSArrGOOKU oOD/ACqxt/GlEee3HegCvsp6pVjZRs/OgCDYKdsqbYMU7ZQMr7BzxS7KsCOnCOgCuqe1LsqfZn1p 2ykBAFOKULmpwmelOCUhkAT0608R1Ps5pdn4UCsVwue3NLsx2qdVxTgueaQyDZ604IfpUu30pwHH vQBDtxS49qlAHpS45pDI9vrSbcAdamxzRjtQBo49aMUZ496B370AKPegHBox6UY54oAXp0PNJj16 UY55zQetMQe4pRTacO3pQAdKOTR9KD0oGH0oJ96TtRQIMcGgfrS55ozjk0AFJQT60fhVAL2pMfhS 8j3pD71IAabil6GgjNMBOlH50pFAoATtQKXg0fSmAAUtIBRSAXj680daT2pT7imA3saMUvFJmgQM M80nSlNIc0AIO9L2pfftSY9qAFHSj+dBpBQAuaOtFLSATrRjApRRQAdqKSlxTATvzRRjGKU0AJxn miilxSATH4UhHpTvakoATvRjilI96CKAExR7UdKKAEx0opaU0AN7UUYpKAFooFGKAE69adQKPpTA Q0oHNH0p1IBOp5pMYp3Sk+lAw/iFJTs0cUxDKUjNLigjnvSATH0pMfSnYpMcUwE+tJTsUY9aQDce tJ9ad60goGJSfyp9JigQmOKOKXGfaigBP8aXvzRRQMP5UY55oxxzS4oEIaCKXHFLQAzFGKdR9aAG YNG004igUwG4pMU/HtSEUANx+FGPSn9qWgYzFIRTxmgj2pCRHtoxipCKMVQyPHc0CpAvNJigRHj6 0AcVJjJoxQBHik29akxQRzQBCRSBamKgUm30pAR7aTbUuOKMfpSGREelNIqZlpmPWgCPFJjNS7fS k296YERGKMVLtoxQIhI7GjbxUxGaQrz0pgR4pCvrUuOaNtICHFG2pStLtxTGQ7aTFTlabtoAhC+t G3HSpivFIRQBCF9qRl56VNt4o2+lAFfZQV5+tT49aTbn8KYiDb7Um31qfbRt+n0pAQbfSm7farGy jZTArbO1GzFWdnSkKUgKxX2pAlW9nFNZRxTArFM9qNnPFWNuTRtx2oEVtmM0m31qwU9aNhIpAVSg o2cVZ2Z96NlAyps5pDHVvZ3pClAip5Zz0pDHjtVsp1pNmetMRUKUmz0q2UFJs+tAyr5Zo2cf0qzt o2igCoU4xik2VaKfWk2c0AVgnNBjFWtntSbOOlAFQpQE+lWvL9aXZ60CKuyk2Va8ujy6VwKvl0mz 0/WreykKUxlbZ6ijZk8Va2UgXOKLiKpi9KXZ7Va8v8qQIcdKQyt5fJ4NLsqyY8dqNlO4Fbb7Uuzm rHl0oT2oArhMUuzmrATPanbOlAioEpfLz061a2UBMUrjK6pj60bD6ZqyEpRH370wK/l4FL5fHIqx sxTgnrSAqFKNnPSrWyl8vNMCoI+KUR47VaEee2aXyxSAqlOOlO2cdKs+XS+XkdKBlcR80uzjpVgR 8U4JQBX8vHIFKqVYCe1O8vpUiKwSl2VPs9acFpjIAnHNOCVOUz1FKFoAg2fhSlP/AK1TY5xSge1A EITFLtAyelTFfwo20AQqtO2mpdtLt64pDIgvFLt9qkCkH3pwSgCIrxS7M4qXbnHrS7fSkBDj69aU L3qTZg9KULSGiLbQFqXGO1OC/wD1qAI9lAXjr0qTb60m3vQMs4o+opf1owc/SgQdc0fSlwR0pAP5 UxCd6QjmnH60dvegBoGaXtS+lFAAKTvS96OooGJjrQcdOaOtKtABRjHrSig4zTEJjpSmjHrR1/Cg BCMUdqO/40HgDvQAnUUdKMelKPpTAQ9aOlLRzSAbn+dDDmlzRigA+tGR0oopgHtRR2o6CgBKCM+1 BoPFIBAD9aPpR0pPrQIdjNFIOlGKYBx3peBRwaTjNAC9aMYoxjr0pTSAa2BRS0mKYBS9aMYo780A HalpPpSgUgAEGjrR70tMBMYpMUv6Uh60gDFJTjQaAGnNJ2pcc0YwKYCYoooxg0gEx+dGPWnfSkoA MYoNBHNFABj0pe2aSloAMUtJmlxQACig0gpgLyKQj1oPFLj8aQCd6WiigANFIKXpQAlJ3paTtQMT PpQfelxSUAIKXFHU0oosAdqKB+NLjmkIT6Unbml4NLj1pjEo60Uv1pCQmaKXFHSmAlGKWjFACY+p oxzxS4ox6UAJijHWnYxSYoATHNBFOAoIoGNx3pTRilpgNopwpMUAJ2oxilxRz6UAJj0oxTgKCKQD COaMA06jHpTAYRSdDT/zpcUAR0YxT8cUmKQrDCtJipMUYFAyPGKTGakIpMfrQBHjrRjNSYxRjvig CLFGKk20Yz2piI9tGKkwaMGkMjxRj2qTFGOlMBm30pMZqTFG2kBEFo21LtpMe1AEW3Ao21LtzS4p gQbaQr7VOVxTdtAEBXnpRtqbbSbaYEYWk21MBSYpICILzSbamC8c0bfWmKxFt9abtyan2YpNoqRk O38aTbgcVPgUhWmIg2560uzNThKXA70AV1T8qNo7VMVpCtICAp6daaycVZ24xTSKYFfbRtqcpQVp iK5T0poXnmrJSmlPY0AQMtNKY7VZ2cU3b2oAg20uzjpUwWlC0AQbD2pNlWNtLigZW2cDrRsqyVzi jZQIrbM9KPLzVjZnjpS7KAKpSjZVrbim7BQMriP0o8vnpVjbTtmeRQIrbKBHxwKsbaUKMfzoArFP ajy/birGynbOOlAyps7U4Jz0qcL/ADpdmOvWgRAqjqKds57VMF9sU4rxSGVtn/66PLOasbKXbz7U wK+zpgUbPbirG3nApdlIRAE604L7VLtx60uOfbtQMi284xSbfyqbbzSbaYEYXFG0fWpdtO20AQbf z9KXHNTbaULnmgCHbz0pQvrU+yl29fpSAi2+lIVqbbyO1LtHPFICDZ6Uu3161NtyKcEoAhCfhTsd qk25o280ARbeeaXbjpUm31OKNvpzQBGF570bcHoPapMcYpSKAGBfajHfFPA9aXHFIBhXqeaNuPpU mKMcc0DI9ucYp+M8CnbfQUYx14oAZjnvS7aeF/yaCOOc0AMx7UYyakx/jSbaLjGY+al2/wCTTsUY OKQEn4UuMD1oxtXmlHNMAIx1zRjr3o9qbQIKTHb3pxHcdKQ/SgBO/wBKDkUEcHGaP0oAQZ78etKB +NFGMdKBi49aPakxSjrQIXuKTvQc4pD9aAF9qCcD0pPrSfjTAUZ9f0pTxSDpxQMCgBaSj3oNABRS Cl7c0CDFGKKDQMSg0uOOKD70wE7UfWj6Uv09KQCY9qPfvSgCkpgIaTA6U7HXNGMUhAaO9JR+FAxT SUp54oPvzTEHfk0d+KDSUgFxR0oo+lAwxRij0oPQe1AgHbtTsfjSYpaAEx7UGl+tB/8A1UAJ9aTF LQaBiHpRQOaKBAfypKWjigBpFL6UppOlACd6B+dL2oxQAlBHpS96DQMQD8KKXt60lAgxgU6kHelo AO/tScUoooAQj1o70HpRQMCaPSjFKKBCfWj8qMUfSmAho60ppvNIYGjFGDig0IAo70vXrRjigBKd R2pOaQC9DR9aMCjGBTATPpS0YooAKO1LijHFACY9qXGBSjpRTuITBHSlpcUd6QxKTH1p1GM9qAG0 detOxxmjpQA3HpRTsc0lABg0UuMikH4UAIRjpQBxS4xQBTATHNFLR9aQCUlOx+FJigAxzTcU6jim A2il+lLikAmKMU7GOlAB70ANxSY5p+KTb60CGYGaMZp9BGaBjNtGKfj60EUAMxQR7U/FG3NIBmM0 Y5p+KWmBEV70Y5qTGaMUARgetGD61Jj2oApgMIx2pAPSn0CkBHtPNGKeRzQR60ARkZpMetS4pMel AEe3rijbx2qTANGMc9aAGbeKTHWpcUmKAItue1GBU23pRtoAhx7UFam20mKBEe2k21Jj1pce1AEO 0Zpdv51KBk0baAIWX0pCtT7aaRQBBt/GlAGORUm30oK0ARFRmm7asbec0m30pgQbaNv0qYrg96Qp 7cdaQEO2gLUu3v3pdtAEO2k21Y2YPQ0hX2oAh207ZUmOnFGKYEeKaQKn2nFNIz9aAItv1pNufpU+ 2k2+1MRBspQOalK+1G30oAjwM9KTH4CptvXFIF9qBkYFAXt0qXZ6Um2kBHtyaXZ7ZqUL9aXbg0CI tuO3NGM1NjnvSFeaBke2jbUoXPWjbQBFijb7VKV49aXbSAh280oFS7fwpNv50CGFc0YHepQnNLj2 oGRBM0bfapQv40oHFMCLbilC1JiigRHtyPxpcfLT1HpRj1pDG7aXbxxzTvwp2O1AEYX1pwUYp/Sk PIpgNxTcU/aOtJSAbj86Dz2pTxRQAmPWlxxSqOmadj6UAN59KD/LvTulAGKQxtGM5p+PQ0uCKQrC YpMU4cdaMEfSmMTGfyowCafxmm/SkA3FGOKfj1FOK/hQMjxzQB9adikwfxpDHLS/WgUD1NUSGPlp DS/WjHFAxMUYpcflS0ANxSetSYpCOOelAhg696XbRind/agBmP50EcnrTvwpMe1ADe1IRgHvS4o9 zQCE29TR3pcHHbFL1+lADe9HAzTsd6MUxCdetHXvRjil6CmA3FH0p2KX60gGfWg07HrRj0oGJig0 uKKYDaXHpSgY60e9IQmBRjH0p2OaSgYmMUhHrTqT60AIBSU76GkxxQAD2oH40gpe3SgQnejFOx0x R3pDE70lH407H+RVAN/CjmlxR+FIBRmjNJRnn2oELz1obrRn1pKADk0UcUGmMMUh6il+tA4HFAhC O1JjFOoxSASkpaXGKBjaWjpS9KBDSOaX60AUuKBjTij27UoFKaGIbSg4o9qKAQetH1oxkUuOaAE/ lR0p3SkNACc0YyO9OpMUAJRilxSYoAae1FLiigYgo7UtGOaAExS4pf1pSKQDRS8UCjFABzRnmjpR 3pgJS4peDRigBOc0uKAPSlAoEFFLS/SgAFJ3p2OlJQAYpMGl9/0ozTGJR3paPp0pAJiginGkz6UA NFL17UdOtKMUgEIox1paQjHJoAb+NFONJQAc0nalo7UwENJTsUYpCExR+lLjPalxTAbTsUo6UfSg BuOOaMHNLik+lAwNJjpTsetGOeKAExS4paMUANHvR2p+KQ0gExRjmnAYpcUANx6cUEc8U4UUAR49 DSY/KpCKQ98UARkUAU/aR6UEUAMwfSlxS0HP4UwG49KMcUuKXBoAZilx9aXHrS0ANAxSgUuMmgCg BMUpWnYpcZpAR4xSEcVIR+FNxmmAzFKBkU7HNLimIbjilxTttLikBHtppWpcUhFAEWKXHFSY49KM UAR7aTb6VKRRtoAjK44/Gm7al20YHSgCEr9aXb9akx2o20AR4/KjFSY4pMUgI8flSYxUhWjH50AR 7Tmjb1qQikIpgMAox/8AXqTHpS7cdqdwItvpRtqXaaNtAEQX0oAqXbRtNAEW360bfxqUrQV5oAjA xS4z1p+2gCkAzHrRipMUY6UAR4zS4/xp+KQdqLiG49aXb7c04ClxxSGM24o29xUm31pCKYDcUY9a fijbQA3HHpSY6inY44pQPWgBmPp0oxTsd6OlAhu2jHPSn4z04FGPegBijH0pcdu9P+tGKQDenFJj 0p2AaQjmmMbzSfzp+fX+VJx+NIBuOlGKeBRt7UDEAxjvS4yelOHv1FGM0ANx1pdvHTFKByaMGhiE x6Cl7ZpQOevFBHpSGJ7Glxz7Uf0pVX86AE6HOeKMc9KOaXA7/SgA6c8UnvTjz07Uf5NIBMDvxSEe lLmjnFACdBRigDv2pfpVDE6dKUdqBS9RzQAn+NLxmhcDmhRz+tAgPOc0deuMUv4UnSgYmCOtHT+l KfSigQlJ1zS9uaOBnFMBuM9aXA/yadiggZoAbjnpQen0p1J0oFcZ+tKO/GaXH+RRjOcUDE/yKXHH rRg0vrTAb1pcZ9KMUvv2pCE+npSHjtTiMe9J1oAbyDS9RS4HejPNAxMe1KtL9aMUCEPXjNGKXp27 UUwG4xTakppGfwpANPSjrz0pxHejHrQMbS9+3SlxSdOfwoEGMmj1peRRjnmkMTHSjFLR1piG/UUd KXvxQfagBtHfinY9aQCmAhFGPSnYpMUgEPail7Ue9UMSjFLj8aKkAx1pM+tLmlx0zQIbSAZp1AoA MfrS/WgcmgDFMBMUYp1FIBuD+NGKXpR9TQA3+LmjHJpcUnNIAHWlopdv1pjDvzRil78Uv6UCG0Uv WkI5oACMCmkU6kNMY2ginYopAJjigUoFGPxpAGPSkxTuaQ9etACYxRTjzRigBu2jFOxigCgBpFHp TwPWjmmA3FO7Ud6KBBRxR9aKBi59e1HTniij8qYCkCkxSijHFIBvegUv0pOAaACiil/lSASl+lGO aTvQAUdetLiigBMUlOx7UcUAJjngUlPpKAEOKOKdijFMQ3pRTsZox9aAEoxS+9GKAG4oxTsYFGMG kMbS46UopcUANxS+1LijFACUEcU7FGKAExxSj3pfSlpgNxjtS4/xpcfjRQA3vTSM0+m9KQhuBSY5 7VJikxQMZjtSEU/HXNBFMBvpij0pwFGOKQCUlOApCPWmAmPSnYFGM07GKQCY9aMU7FHfvTAYaNvX FPxRjHWgBmPxox2p2KMc0ANx70dadijFAhOKTAp2OKWgBuAfakx9afjmg0gGH8qTbzT8UYoAbjpR t96dig9KAIwOaNv1p+MduaKAG7aTbTwKMcCgCIilAzUhFGOKBke38qNvepAMClC+tMBm32pdo/Gn 460AfnQAxlpuPSpcUmD260AMA9qCo/yafijGKAGkYpMZqSkNAEZFGKfj0oxQA0LmindKMc/hQIZj NGPan4pcUgI9uDxS7adijGKAEYUmKfjmkwO3WgBMUY/nSnI6UuKYDcUYp2OOKMUIBhGOlLtp30oI 5pANC9fSkIJ604CjGP8ACmA3GKMYp1IaQhvQfyoxzxTsZFJj8KBjcYNLjmlxz+tHSmMQDvTuM8UY 49qCMc0hCd8mjGOacffpRQAxutL1HNLjkUuMUAJ2oxznoKMUtIA70UUnRulAw6GjNB4H1pM89qQD gaTPbrRjsaOnagA6+1HWjB/Ckb0NAB0FAoAOOcU/9aoYnHfrR1NLxnvR0BoAQ9Rml703FOHQfzoE J3oJoo96AE5zxSijA7jvS96YB70E5PQ0v1zSHsTSAAPWlpAfSjPrTQCUce9De9DGgBvXtS+1GMdK OopgBHHFBGcUoGPpS+1IQnQ0YpehoHfNAxOlHTr3pcCjg0CGnFLj2peBQTQMSlx69aUig+9ADcEU oFL70UANpPwp+PXijFAhmD9KAPSnkUhxQMbg4o46daWjFDENxS4pe/Sj6UhjcelGKdikwaYCY60m Kdg5ox6UANbrS/8A6qXbRigBuKMAdadjOKCKAEpOnWlPajFACYpvSnGjvSAbR2yetOxRj8qYhtL2 pQOf8aMcc0AAopcfnRgUAJnNFKMUdKBiY/Kg0vbigUgEox2paXGe1MQ3GOlH0pSOKUDpxSGH86TA pcUoFMBvSjFKcijAoAbR9adijbQA3HQ0mKdg0Y9KAE7UuMjvS4oxSAaRijFOI/KjpQJCYopcc5pc UDG0uKMUv8qAE+opMflTqKYDSKOMU7v7UmPwoAOvakpf5UEUAHaiiigAoo7UfWgA70nU0vSkoAMc 5paAOaMUgDPrRRj0ox60AGaBS4o/CgBBRS45o+tACUtLRigBMUoFLj1ooATFBp1IFoAaBS4p3FLi gQztzR+Bp+Me9IBQMTGO9GOafik+lACevek5/SnUY9KAExRilxS0AJ16UD3o6UUwFFJRQaQCE5pp pfrSH60AJ9aKKWgBAOKXGDS4paAGgUn0p+OKAKAGgUuKcBxSkc0AMA45paXFLj2oAQCjHNLiigBu M0dKcelGKYDQKTFP7UgFAgxSAU6gikA360uPTilxzRQA3mjBIp3NGPrQAmKTHJ607HOTSEUAIQe1 AGOtO60UCsNx60Ypwo+tAxoFH1pe1HXrQAnbiilxRjigENx9aWl20tADcYop1JjjpQMSk79acKXG enemA3HrS4pQKMUAN7E/lRzTsfrRjFAhqijHpTgPXNGDQA3bxSEelPxzSAHngUANxxxRjmnEcUGg BO9GMUvekpAFHbigDjilAoAb6igZ/CnUAYpgJjNJinADPNGKQDcetL1pQPWlxQAzGOP1pM80/FIR 0x1oAbjmjr0pSOtIRz+tAAQKCOvFLj1pM4oATH1oxil7cUc0AJj3oAp2PWgjA4oAbzQPelxg9qFG aADBNJjHelOf6UuDj/GkA2jn2p2OaTFMY05J6UvWjFLgUgG9KMcU7ApCP0pAHalHHWjB79KMY6Dt SGIc0fWnf4UEeuKAGlaVePej/OaBVgL+FJjPTmnYyRmloAZjHWl9P8KcfSgUANx9KUml2j60YoEN xmlFLjHFKP1oAaRxSYGOmOKdg0GgY3HpRjpTsUAc9KBDME0Yp+OaMc0wI8c8dKdjFOxg880YoAZj JpceopQOe9GKAE6UHtS4pcetADfTBFGKXFAGKBCe9KvSjFKBQMSjGe9LigfrQAmKKMU6gQ3FKaXm kxQMTn0o6Cl+lHSgQ0D/ABoxTuaMetADO/Slx81L3pcc0ANIoxT6SgY2k207FLQAzFGO9Ox1pMcC gBMUhFPx3oI9e1AEZGT0pQvFOxRjmkAzHTpRjrT6KYDMUEetPx+FGMGkAylH0p3biimA3GKSn44p MGgQ3FGOaXFOA9aQxuBSYp+KMYpgNoxilxS4NADcUtOx7UmKQCYpcUtLQA3FGPpTqPpzTAbj1pCK f3ox60AR49BS44p1BFAhtLjj1pQKAKBiYo2/hT8elGKQDMflR+VPpMUAMxQBT/rSYoAbS0tHSgBu PSl+tKKWgBh6UhHFPI/KjFADMUmM07rRigBO9FLijFACCjrTsUYoAb3xRTscUuKAG4ox6U7GKMc0 ANxRinYo2+lACYoxz0p2KXFAhtJzTiPrRTGJQKWgcZpAFGPWloxQAn8qCKd9KMelADfelpaSgQUu KKMUDCilx60YoATFJTsUcUANxzS0uKMUANpCPrT8cU0igBp+lJj8afijHNADMZoxTyKTHNACUoHS nY6UYFABRinYo/WgBuKMc8inEccUn1oAKKXFFACUEdqXpSUCExR1p2KKAG4pVHPNKOaXFADcc0Yp 2KX2oAZijFO+tGKAG44op2O1IRzQAlGOKXFGPyoAbilApcCigBuPSl6nvS0tMBuPyoIz0pQKXB9q QDcelAFOxzRigY3tR29adj0pMUANxR0p2KOnamJjMetO+lLjNLikMaBmkx7VJjijGKAGYoxn3p2K WmIaozR9acB0z0oI60hjcZwabjFPpOtADTRmnYpMdKAG9aXFOI/lR1oENxmjHNLijHrTAbil/Kl6 +tB+lIBv0opeh4o9DQAnSl7GlpQKAG46UmOadg4pDQAhGKTjninYxSYoAbijHFOwOlKB8vNADMdP elx+NOIoxQA2kPFOxmgmgBnfmjHOKdilANADMH0xTgPWnAfWgjI9aAI8f/rFLgGnbaUDml1GMxSY 564qTGTQVoAZtpMVJikx7UgGn60dqXGaDQA09aMAetO/CkIzxSGHQ80BaeaCOlWA3B70AcGnY9KU igBMZoxg+1KBS46UAJjigilx0ox3oEJj0puKk/Okx7c0ANwRSYHcU/HNGMfWgBmPzpcetOxgg4ox zQAgFFKf5Ug46UAJjmlIpcGlxTAZtoxTgPSjFAhMUBciloxQMYRSY44qTFNI5NACEe9AGKXGDQPf pQAnWk780uKXHNACYzS0v50DigQlIR607HtRz3oATFGKdijH5UANxRindc0dqBjAOaVadRSAbjj8 aCOPpTscUmMUANNJTscUYoAbilxn6U7FGPUcYoAZjmnYo+lLimA3FBFOIpT15oAjI6UYp+Oc0mKB IbimkZ+tSYoxSGMxRjnmnYp2PSgBpFIR+FOxilIoAZjNAWn49KCKAGY9KOvtT8Un1pgN20Y+tPIo oAbikxzT8UhFIBCKMUvalFArCYopQPwooGJigUvf2o7UAJjNJinAfNTsc0wGY6UtONGKQDcUYpcU UCsNxzRinYoxQMbikxTsc0uPagQzFJ0p2KXFMBmKWnYwKMUhiYpMU7FGKAGFeaNtPxRigBmMUu3P NOxS4x1oAZjFLilxRjFADcUYp2KXFADMcUuPanYpcUARhaXFPAoxQA0CjFOxS4pgR4zSYqTFLjik BHijbUmM0baAGYoxT8UUAM5pce1OxTaAEx7UY606m0AFLijFLQAYopRRigBCKSnYoxQA2g04jpzR QA2jHFOAoAoAYBzRin4oxQA3FJin4puPrQAmOKUUoFLQAUYpcUYoATHtSc07FBFADcUuKXFGKAEx SYp1LigBmKXFLjNGMUBYTGOKMdadiloAbRTsUmKEA3FGKeRSY60CE7UDmlxwKXFACAUhFOxQRigB mKQ4p+KbigBCKXGOtGPypcetMBMe1FO70Y9KQxuOlGKdjjNFACEUAetLilA4oAbt9aTFSY9KMcUA MxRipCMUmKAG9KTGafiigBmPWjGKd24ox6UANoOadRQA3GKMYp2KKAGH2pMVJikPWgBoFJjnnin9 aTHFAhuMUmOmadjilxQMb0pMU7GKCKAGY9qUCnY4owaYmJj1oFGDQPakAhH1oxxzTsYo6etADcZo x7UvTpSmgBoHtS49aXrS454oAZijHOafjmkPWgBuKbjtipKTFAITFGBTsE0uKBjeKNvGTTgOOaP5 UgGEfnRj2p2PWkI5oAQA0Y69qWjHrSAb9KXGeaX6UmKAExSY4pxHNGPXg0AMx8vNGM07AGPWkYet IB2OaMU/6dKMVZQzv9KX60tKBQIaKcOlOC5PNIBmgBDSAcdadjJOaMUAJSYyKWlA70CG4op2KSgB p696BTqTFMBKTFPxRj2pAJRj1pcUuMUAIBxRt9KXBpaYDSOlGMdaXH1pSPSgBmKTbin0mMZpgMxn 1oxin4oApAMxRjHTmpMZ44pMY7UAMpevtTsYooATGf8ACjHrS0YoEJSY4p2KKLjQ2ilpcUgGgUvB pcUYoAb3paUCgimA3FJj1p9JjFIBMZHNLj0pcUY5oGJim4qSjHpTEMpcZanfrQBxSENxSYp+KMev SgZHjmjFPxijFADMYpcUtOxQA3FG2lxS49KYDcUhHrUmO/ekxSAjApcU7FGKAG0EcUuKMUANxSEZ qTrSUAM5pcU8igCgBuKXFOxmlxQFxhHNGKdilxmgBmMUuOKXFLigBuOKMU6jFADcfWjGadS4oAjx zS4p2KTB70AJikI7U8ijFAEeKMCn4pMUAJikp5pMUAJRjmn4oxQAzFGKfikxQA3HtScZqTFJigBu KCKcBzS4yaAGYoxzT8UuPWgViOlxTsc0YoGNxS4p1GPagBuKXFLjNLTAbj0pMU/FGKQDQKCKdikN ADMUY4p+KMUANxSYp+OOKTFADKAOKfikAoAb0op+KMUANxzTsUYo4oASjH5U7FLigCPGOlHrTyKM d6AG4pQKWloAZijHNOxRjnNACYpuKkooAZilxTsUYoAbijFP70mKBWG4op+KTFAxuMUYp2OOgpcU ANx7UEU/FGKAI8UYp+KMUANxmjHoKdjmlA9aAG4oxTscUY570ANxn2oAxTxSHvQA3FGKd1pMY6UA NxzS/SlxS4oAYRxSYqTFJigBuKMYp2OKKBWG4oxzTsUYoGNoxTsUYoATHNGKdj1ox60AN470uKUe 1AFADetGKfj0NIwoAaKMU7FGBnmgY3FGMU7FBFAhhop+KTHTNAxO1IBTselKo70CGd6MU7HSj86A ExzTSKfik79KAGYpcU7FGKYDSKMYp2D6UY/nSAaBij2p+MGg8mgCPbRj0FP2mjFADMDFGKeRSEc0 wGgetGBilAoA9KQCAetLil+tHuc0XATHNGKX6UY5oEN6UYpcUuPSkMb0HFHelxx+NGPegBKMetLj FHSgBuKPrTqTHFACEYFJT6MelJgMx6UYp+KXH/6qAGEc9KCMYp1DHPWgBu386TFOxmg4+lIBcetL jilxwaAOtUMbijGM0uOeaXoaYBjrzR05xSmjrQAmOabingc0Y9KAG0U7FGAaGIaRSYqTFJigCPGf WjFSYpMUANxijHXFOxRjGcUAN6ijvxSkUY9TQISlxn2oAp2PWgY3HHFIAc46U76dKUdKAG4op+Oa TGKYWG4oxnkU/FGKAG4pDTsY+tFADD0pKeRQB+FADcUYzT8c0dKAGgYpMZp9GKQDMUuOlOxQaAGE UYNOI9aOlADcUYpw6Ud6AGEUY49afjPWkIoATvRS4pQKAExSYqTFGKAGY7UuMClxS4piGmkx60/F JikMaRSYp+PWlxQBHijFP79KQj0oASjFKaXHFMBuOaAKdikx1pAJRiloxQA3FGM07HNGKAGYpcU4 ClxQAzFKop+PWjHNADaMfSnYox0oAZgUpFLj2o20ANpadj1owe9ADaTHNP7UYoAaBRS4/GjtQAmK KcBmkxQAlGKdiigBuKMU+kNADMUuKXHFFACfSil70tADaTFPxRigBoHr+lLinbaMYoAYR6UmKfik xQAgFLSgZpcUANxRinEUUANxiinYooENxRinUYpgJijFOooGJijbntS4xS0gG49KTFSYppFADCOe BRinEUhFADcUYxT/AEpMUANxmkxUmKTFADcYpfwpaXFADcZoxTqXFADetJTqKAG0ClpQKAExRilx S4oAbj0oxTqCKAGYoxT8cUYoAbRTsUY9KAExRinYoxQA0D1oxzT8UEc0AMFLjjinAUpFADMUYBpw H8qMcUANx7UoFLinAUARkc0Y5pxFHWgBuOaMdaWigBPwo6U7tijGMd6AG4o+lOwPegigBoFJjin4 pDQAzFL0NKRzS4oAZj0oxzTsc0YoATH0FLilAyKMUAJSY4p2KXFADaBmnYoxQAmKMU7FJQAmKMel O6UAUDGYpacRzSYIouFhtHc06kxmgBMGkpxH5UGgBmKPWn4poFAhMelLj1pcUdaBjcUbc04DmlAz QIZijHrmn7aCKAG4ox6/SnUlIBMAUijBp1HXNMBMetJinYpCPyoAYRigc9aceKUD1oAZjml7YpxH Q0YpANAz1oIxTgOvpRQA0jOMUg9qfikwf1pgN6UgHrT6MYPSkA3FHenYwaTHtmgBv8qMU7FLigQz b2/GnY9R9Keo+Y0h6cdKQxuKBS0YwaAGkYpO3FSY7ikoAZjj3pCPapMdqQjj8aQw/lRUgFBXPSrG R96UDIp232ox+FAhBRgn/wCvTsfjRii4DcUuPajGDQOaAE44oxTgKCKAGkUmMCn49aTHrzQISkA9 aXHAxRigBKKXB7U7GT7UAR4oxzT8UY49KAGYxS04jpRtoAbilxTsYoxQA368UEUuMdRRigBKT+VO NJ1oAOKTFLijFACY5HpSkDNHsKCKAACkxT8etIBxQAhHWkxTsUnpQAYox60vfn8KB1/CgBuKT6U/ FJ9KAG4pcU7FGOaAEwe9Jtp1FADPpTvSjFOxQA3FFKB0pce1ADR04ox+dPwO1GKAG4ox607HtRig BuOKTp0p2KCM0ANxSEc0/FIRQAwilxTscUlACY/KjHvS96WgBvbNFOxSYoAbg0dDT6MetMBoGaU8 UoHpRSASjntSkUYNACYoxTsUCgQ3FFL0pelAxuKB707FJigAxRS4ooExtGKdQBQMTFGKdigCgBoF IR9afj0pMUAN/OlpcZpcUANpDT8elGM0ARnilpxHrRtoARaWl20uKAExzSH6U7FGKAGYoxingUuK AI8ZpR0p2OaKBXG4ox16U6jr2oAZilxTselAFADaWgilApjG47UqinYxRSASkxTsZoxTEJijvS9K SkAhFJTjSGgLjcUYpcUYpjExRilxSgUgExR2paWgBuKMU4igCgBuKTbUmKSgBmKXHFOxRjigBtAF PA9KMUARgc0tOx6UYxQAmKCPWlA4p2KAGgUYp2KKAEApelFLigBoFLS4ooASjFLRQAnSkxzTsCgj 0oAbS/Slx60YoAaRSYp/4fjQKYDMUAU/FAFIBmKXFOxRigBuPWinYoxQA2inAUAfSgBmKMHNPxRi gBhHNJipCKTFAIafpSZpxFLgUAhtBp2P5UYoGJ9aMU7GaMYOaAEHvSY4FOwc0oFMBuKMU7HHFJjn mgBOaTFO+tJSC4lIRzTsZFGKQDce9JinAUbaaAZjijFSAUYzSAjA/CjFSbaTGaYDcUu38qUClxQI bS4pcccUDpxQAwijHrTiOM4o60AMx6UtOP5UmOaAEPNBHtS4opANxQetOwaMUAN+tLjgUoGPal/W gBuOPTNNPNSY69aMUAMpKfijFADT7Un8VPxRj8aAGAZoxT+3FJtoAYBTucU4KaXFADevakxinc4z S4pARilxmn96RRigBppaXHNLj1oAbim4p+KTvSGOpcZFLijBqihuKCMdad3pDTJEGKOopcUuPWgB hGPzpOnSn4PejpzTCwzHPNFONGPSgBpHTFB6807FJikIbjk0Y6U7FGOaAEAxS+1FGKAEI7igClHF BoAMc0YpRwfeigBKAOaWg9KADFJilwc0Y9KAEI9qTHpTsUuOKBDMGjHSngUnWmMbjmkxinkcUmKQ DcetKelGOtLjPWgBuOtLTttJigBKMUuKKAGilx6U4DNFADMetL7U7FJigBtL2pQKXFADe1HT1pcc 0CgBMUoGKX+dKeKAExSfxU/rRigLDaTvT8UUAN+tNxT8etGKAIxRnmnY5oxxQAhpvvT8UdelADKU UoFGKAGgUYp1LihCG4oxTulGO4oATGaMc07FA60DG4pKfikIz0oAbS4pcUuKBDaMU7FKBQMbjjin YpcZo6UAMxigU7tRj0oAbj+VGKfj1oxQA0CjFPC0YxQIZijFPpMUANxRilxSigaG4oxTsUmD3oAT FGKWg5oAQilAoFFABiikpc+1ABS4pAKdQCExRiil9KBDcc0oFL1pcUAMxS44pcUYpjG4oxTsUgFI AoxzSmkoEJRSmm/hQAppOlKKKAG4JoxTqDQCGdKKdijFAwAoxS0UAJ+dGKdinY4oAbigCnClxQBH iinUuKAQzGKTFPxQBigBtOAoApQKAEwKMU6igBuOKUCl7UUAIRRilA9aMUANx6UuKXFFAWEpCKdi g9KAG0U6igBtFOxzRigBuPWjFOxRigBuDS4p2KTHrQAmKBS49KMUAFJTvrRj0oAbRilAxQRQA3Ga MUuKXFAkJSD3p2KBQMQ/SjGfanUEY5oGMx81LjilI5oAoENoxTsc0AGgYmD3ooxilxTAOKTHFLQR SGJikNOpMUEiEZpMU7FGMdKAGmj2p2PSjFIY0DFLmlxRTQCHvxRS9qAKQDc0dDTqKAG0p96PwpQP SgBKOlLiigQnSkxg06jFMBoHtSD3p+KKQDBz0pce1KRRTGJikIp9GPXilYQwDjmnY7U7GfpQBigB mP8A9dGKdj1oNADRQRS80Y4oBDMGlxTqQ/nQA3GDSgCnAZoxzmgQmOaXFLijHPAoGJjrSY4xTsUY 5oAYcYoxTiOaTHFIY3oaXHHHSlx2oxxSAQjPtSe9ONJtoAXHNL2zTugpMVYCUY+alxQBzQgEx/Oh fwp2KMc9KAG9KTrTjS7elADCPSjmndKCMdKAG4OKKdjnmjHegQzv0xSfSn4oxQAylxTulIRxxQAm KQD1p1FADcAdqKfjikxTAaOvFOoA54oPBpAJ09aX6UUfSgBP85pcflRSgUAJikIp2KSmwQlJ3pcU oGaQCYzRj1p2O1J3oATBxQB6076UAUANwaAKdijFADaWlxRigBvSinEcUmKAG44oxTvpzRQA3FFO xS4oATFL1xS4owKAExigdadjFGKAYlJ35pxptMVgppp/akxSGNIop2KCKAsN9aTFPxSAcUBYbilx S4pMUCDHFGKWjFAxCKMUuKTvQIMc0tHpS9qB3ExSYpaX680AxPpS0UtACYzS4pwFGKBDcUGnYoxQ O4zFHan4pMUCG0vrS4oxQFwo/Cj60UAJjNGKWigBtGKcBRjFADKWjFLigBMUYpQKX8KAG4pcUtH8 6AGn2puDT8UYoASlAoxSgUwCjFOopANoHFKaMUAJSYpaMdKBhQKXFLjFMQ3FJTyOaTFIBtNxUmKQ jHtQAz6UtKaDQA2jFOxSAUAGKMZpcU7FADMUYp+KTFACbfWlxS9KUCmAnQUYp1HTtSGMxRTsdKMU ANxzS0uKKAEopccUlACHpRSmjFABRRiloAToKOlOpMUDDFAGaXk+tAHNAhB70uKXjNFMBMUYpaAK QWExTcVJRigLDMUvQUuKTFADT14oxTvwox7UwExSHrS0uKQXEHWkxTiOKTFAWEoxS4oxQIKB+VKR TaADoaXHPrRRQUH60Y70DmloGNx9KUUtLQIaRSYp+KbimAmKMc0tGKQWExSY5p+DRigYzrRindqM UAJ9KO1LSUABoNFGPypCCjFLx2opjEAox9KUUY5pCExRilxRj65+tACUAe9KRz2ooEGO/FJiloIz QAY5oxQ3A4o68UDEI9M0lOoxQAnekAp2PrRigQ0j25pcdqdjmlFAeg0AUY5oaloCwlJin/WkPTig Bn1ppGTzUmKTAoAaKMfzp1AoAQD6UEU4D1pccUCGY+lLjmlx60tIaG0UvrS9abGNpCD0p2KMUhDc UYpwoxQA0ik+lPNJjikMTGeaXBpwpetUA3Hr1pO4zTsUh96YCY5pcUUY9qAEA4o5NOxR9KAG9qD0 paDQITpSfSncd6Tr0oASkx6ClxilxQFhAKTHpT8YNIaAGkUnWn4ppHpTAO1KO9ABpSKAEpMU7pR+ FIBuPWm4wafiigQ0ClHpS45oxQMTFJil7nNLigENxR0p2KAKAExxQOadijHPFACCgDinAelAFADc UU7FJQA3HFLjmlx60YzQA3FGKXHNGKAExSU7FFAXDGOtLjI4oHSgCkAmKXvS4opgGO9IRSmgigGN PFH1px60nagBKAKPWigApKcBSYpAIRSYp2PWjFACUUpFGKYhuMUvalxSYpAGKMUo460d6YCAUGlA paAG4oxzTgOaXFAMbigDNOoAoC4YxQetLRigBKWik+lAB9aKWjFA7iEetIadigjmgQwDFKaWjFAC d6MU7FJigBO9BpaMelACYoxS0YoAb3pcUuKXFACYpKcelFACYpMc06loAbQKWloEJRS0UAJTad0o oGNxS4p2KWgBtLRRQAdDRRnmlpgNpKd0NJSAbilxS96MCgBMUUtAFMBuKdilxRSAbRjiloxmgAAo xS9KKAExS0UUFBQKTFOxQSJjNJThS4oAZj0pNvNPxRQA3FGKWigoMYNJS0UAIRRS/hRQJAOtAzRS 96BiUUtB7UAJ+lL2oxn1paCRKd2pKKBg1IBSn26UtAxn0pcc0v1oxQJjcUuKXFGKAQmO9GKXHFBo GJiilxRQKw3FGKdRQAzFGOadRigYlKOlFLQAmOaDSkUY9aAG0YzS0tADcUYp3NGKAG96MYpxFJQI TFB6frS4ox6UhjOlFLzRimMTNGKdigDFACUd6dSUAJR06Uv1opCEpaKOlMYGkpemKMUhCGk706ig BAMUY6UvTNGKAEoAp31pBQAYo/nS9aXHrQAhGKMYo79KCeKAE6+9FGTR9aAD6UvAowKKAExzScU6 jFAthOKTFLijpQAnXpTu1FH86AsN78UvWlxRjikCEwMc0YFGOaXFAxDSYp1HrQA3FHUUuKKQCYxS HjpTqSgAFLjmk7U7tVAJSU76UUANPWjGBTv1pKYBTQCacaPegBKB7ilpMUAJ7UY59KWg+poAT9aP pS/Tik60CDB79KUCl6UvagYmPakIpaCKAExSelO5xR+FAhPrRilx1ooBjPwpelOx3ooEN96MU4ij FMBuPWggelKBzR39RSAT2opcUmMUFC0mKUUUCDFAFLSUDDFJ19qdSUCD2pKcaQ0DG9KQU6jvSEJR RRQACnUnWjFACrS0dKP5U2AlLRRjigBOtJin49qTFAxuKMU/FGOaRI3FJin0nX3plDcUtFAFACd6 KCOtFIQmKAKXGOlKKAGkUCnYooAMUn1petFAhMetL2pcUYpgxKPrS9KKB6B2o7UYooEJinAUoFAo AMZFJinCigBuKMU6kPWmA3HtRjpTqQ0gG0uKdikNADcUoFFKKAExRinUpFA0MxS4zil+lFAhMUYp 1JigBMUAUuKWgBpFFOxmigQwj2oxTsUUDG0AU8ikxQIRaWjFGMUxjcUY5p2KMUgG06il+lADcUUu KU0AMxRinUYoAaRQtOxRj1oAKTHFOoFADCKAKfSEd6AY3milFGMUDQmKWjFLQMTApcdKdiigkQD0 opRRQA0ZoxS4o+ooHYb1o69adjNBHqKBDaMU6kxzQDEopaAKAEoFOxSd6AuGKPrS4paB2G4oxTiK SgQlLj1op3SgBuKUCnUduKdhobikpwpKQBRS9qQe1AhMZpcCloxQMbilxS4oxQA00mKd9BR9aBjc UYp1JQFxMUtHej60AFGKXpQeKBCEUUvPalA9aChtH0p1GKBDfrRjjpRS4oATFJjmn80hoAYRzR0p 2MUmKBiUpxRilxQAnejH50uB0pMUEiUuKWjvQxjSKSnYoNIBpo69KU8CjFACY5paM9aO9ACGlHA5 o7Uv1oATHrS4pKd9eKQDcUtGcdKPemIOppMUvXmigAAoxS9KSgYYooo+lACdDRRzS9RQJiUmKf8A WkxQIT0xSjNC8UUhoXv7UGgfpS0ANI54oP8A9alpe1AxtJine1H1oAQdKbjJp/akxikA3p70UuKS gBBRnsKUClUVQxOlH1zTsYPNIBn60CCk9qd1pCKAG0dqXHtQKAAc0Un4U7pTATjApTSHPFFAABzz RjFJ2paAQvSjiilxj3+lMYmPeil9aQUhCGj6U7n2ooATANFBoA+lAB3pCKWhhkGgBKKQZFLn1oJs FJS0mOaB2CilopAJ2OaMelLjij60AFJSj3pKBi0nSnUY70xDegozS0YpAhCKMGnY5owaAGdTRin4 5oxQMZS96cBSY9KADFLigU7r0oAb9aAKdikwRQIXFJinfWkoAMUlOooCwmMCkNPxTcUBYbigCnGk zQFhuPSgClxS0CG4oxTqMUD6iAUYpfpS4oGMIo5p2KMUEiAUYpw4opgNxS4p2KMUANooIo/GgApa SlxxQAClox6UuKAEakpaKAG4opaTmgBKWiloAbinAUUUx7hS/Wij+dIBKUj0pVFGKBDfxoxTiPSm kcUDAe9LRj2pQPY0CACjFOx+VIaBDcUd6WlxQAygUpWkxQMMUfWlpcUwExzQPenY4ptAAOlGKAaO 9ABij60Ud6QBjNJS45oPSgBO1FFOAoAbSdKdjBpMUAL+tIRS0pFADcUY45pe9LjFADcUv0pTwKKA DFJTgKXFADcUnepMcUm2gBlFP+lJQFxuKCKdijFACYooFKRQA3FKBRSqKAExxSbcU/FIR2oAb+VF LS4oGFJjninEUUCDFGKO1FABSYpTnNFAxNtGKXtQM0AhAMUYpcc0dqAEIpMU6jr7UAJ7UlO+lJQA h9qSlPvSfUUAFFBNBzQMX8qO9GKWgLCUppKKADGKBR9aOtAAOtFLRQMTtRSmigBPXFFBpMUCDFGK Wj8KAExQBTqKBjTR3o78UfWgTDgUlL1o4oAQe3WkxS9KXFADRzRilxS4pANxSY4p+OOlGKBDMU7H rS4pfegY3FFOPSkoEJj8KOKWjt2pDG0vajHrS4zxTEJ1FAGaXFFAwx7UmKWkxQAYzzRilx9aXFAh uKUClx6Ud6QWDvSdznp2pelL3oEBXt1pNtO79KP5UDG0lO57UYHvQA0ihaXFGOaAAD1pMelOIzSM MUgGkU3FPPFJjikAlL+FLj8qMe1WMTvRilxzmjFACUn1px96SgBMDFHSgilxQA3H5UuPxpcDvR7U CEx9aMelO9KXrTGR4o7dafj1pPSgBCKDxSgd6KADpSZ4oIpcUAIKAOKX6UevFIBDzRQBQaADFJTq T3pgJjikFL3pO3eglBS45oozzSKCjFIaWgAHJoxTqOtADcUU6k60AAHFH1oo5oEHHpRS0lAXF70Y I6UdqM+1AwoIpaKBBRiigUAGKTHpTsUYpgIaBntRj60tIBfeko7880fSgQd6MZpcUtAxMetBFLRQ A3b3NIRmn0dBQAwikNSe1NxQFhtAGadilwB0pgNAoxTlHrTsUWAZigqakpcUIREBRipcCkxSAjxx 3oxUh5pMUAR4pQKkIpMUwGY6UY9KkoIoGR0tOxS4zQFiOjFPxSUCuR4oxTjSYxQDExRinUlACUtL Th0FADRRinYoAxQAgFKBR2opAFGKKWmhsSlFJQKBC4ppFPzSfzoAbilxinUduKAY3Gab0p1JigAA zS7eaXOKKAExTSOfrT+9JQA3BFJ1p3ejFMBtFOxS4pCG0EelPNJimgG4pwGaUCloAjxRtqSikMYB QRT8UfSgENC0EfnTxRQPYjApQKfjBo/CgQmKXFFH8NABijtR2ooHoJikIp9NNAhMUhFLS+xoAbil o/Ck5FIBcUn0ozR1xQAetFFFMBMUtJml+lAMP1oo6UooAMUYpaKAEpCM06jHFADQKdSgUGgBv+TR ilpCKChPrxRR0pR0oEJSYp2BSFaAExxzRilxjrRQA3FFO60UDQmPSjFFLigY00U7ApcetAiPvSkU /bxR/KgBuKDTqMUANpaUjNGOKBjTRijHNHNAB6ZpKX0ooASkpaKBCUtLR2oAT6UdqMccUA0gEo6U uaSgAp2OB0pPSl7UAH8qUjHSkz3paAG+1GDQaO9AAcUlLRxQIQdeaXHNJ3pQDSAAOnNHajvxSjmm AmKCKXHFBBoASjGKdggUAUgEAzS4zSjr0oyc02AnbikxzTqRhk0gE74FH0FLjBpaAAdqT6ClFOxx QA00Yp2KSgYmKTk07GaMYxQIbikx3p+KKQEZHpSH2p+AaCM0DYzmlpM+lO469aobCm+1LSGkIT6U uPWjtTh0piG0lLilGKBjcGlp2OaT0NAhP5UvSjPNKaAEPSkIyvWijtzQAAA0dOtJ/Klb3+lABz6U GkpaADPFJ3ozSUDFopPrS0AJn1oHvR0oJ/KmAhoPtS5pKBBRRS0gEoFL2pBQMXNH4UD2pKAHUlJS 0AHfJooHekpiQ6im/SjtQDF+tLTTS0hiij6Ugoz+FADqPrQKTOaYC96XNJRmkIUmjPTrSUUCCnCk zRmgYtBpM0E0AKDRmm80ZoBD80ZzUeaUGnYB+aOtNp1FhBRikzS5oGAp1Mo3c0APozjFNBpc0CHU lIaTP1oAXOKXOajz60goHoTZ4pKTPFJmgQ70opPSgmgBaKaDS0ALTaXtRQAhH50YoopAN70GnUUM Bop2KMc0vagLhRRmmk8UAL9KMim0vagBaSjNGadwuGaPwozR3zQAuTmgdKbSqaAHA0tJR2oEhO9F AFLigbYlGKWkJoAMUUmaM+tACUveil47UALSd6AeaWgQDmilooAWijGKKAEooHWjofWgYUUhoz+N AC06mClzxQA7NJ+NNzRmgBwpc0zNLnmgBx68UdqTNLQISlxSUtAxp4ooPNJikAneiig0AGKMUtJ1 oAOaKX60lMBRSClpOlAC0UZ4GKXrzQOwUfWj6GigLBS0goznpQMWiikoFcO9JSnikzigaFopM0Zo AXFJSE0maBDs0n50DNFAAaOoo9KO5pDClA9KTv7UoFAC0UlL3piClpKKBh1oHtQKToKAF5puaMYp KBinmjnvRRQCDuKKQmigBKWjGTS0hCHvS/Wig0AIaTHpTu1FADPSlxRz3o70AHahetGaUUALR+Ap OuaXHrQAhpKXtQRQAg4oxR0pevNIQgHNLjmg0oHrQAmKUD1paKAClo/nRjFAwxSUoFBoASjpS/jR TAQc0vekA96XvQAgpcfnS9OaP0pCAdKdjOKToKWgBCMGjGKWjNADO3pS/Slx+NL60ANoxilxRSAT tSEUtJ1+lAyDp06UoOM0DpS/SmAUnPvSjk0hNAApIpetJ0pfpTELjJo6UmfSl+lAxCaD2oNB5piC joOeaTtSE4pAOzSfWkzQeKBi0d6bmkyQaAH55pevSmA0ZpgKaQUhPpSCkA7NLmm0UALSfrQDSfyo AdmkNJmkPX2oAdml603NL60Ei5pBSZ+tGaB3HUZFIKKBhRSUdqAFzR3pKKBWFpRSZzRmmFhSaTOa Tr1pRSAM0vWk9eKTOKAHUtMzS5oDUXOKBSGimMdS02gH0oJHZozmm5oBoKFzRSZFJmgkfmkz6U3N ANAD6KbQTQA8HNLUYbFAagB+eaM/zpm6jdmgB9JmkFKTigB31pe1MzS5oAdSZzRQfahAhKXtTc47 UA0AOzSg00mjdikA/PvSE9jTSaTNMB1Hakz6UtAXFzmgnvTDSjFAC5/KlyO9NopAP4ozxTc8UhOa AH0Ypqml3UALjBoPSm5FGaAClzTf6UZpgOzxSZ5puaM0CHUdKQmm5oAeaB1pmc0ooAk7cUZ5puaC aAHZoJpmaM0DFopM0ZoAPWijNJmgB9JmmZNLn1oAdmnKc9ajzQGxQBL9KXNR7qUNQIkzSZpmaKAH UmfSkzTaBjzyKbSA07NACd6KXNFAADSikzR2oAdRTM0ucUCZJSGkBozmgBaM0h5ozQMXNJRnNJQA EUfWjP40mfWgSHUnalzSZoGBNIaTNLnvQADrSikpc0AGaKTNH0oHcWlFNzRmgB/aim7uKAeKBjs4 pKQmigTF54oPtSZoyKBXDtRSfrSZ9aB3FPSjp1pOKCaADpR1pPwp1ABml600iikMdSim5zRQA7gd KSm5pc0CFp2ajzSg8UDH039aTdzSFsUAK1FJmkzQA7NFJmlHFMAxml4pM9MUpzQMMGkxmijPNIQd KWm0ZGaAHduaO1NFFAgzR0pM+tBoGLRSUuaBC0D3pO3Bpc0AL2pOaM0dqADpRil75pRSATH6Uoop aAE/Cjv7UUd6AHUdKPrSUDCigcUd6YCY5oo60tAriH3o9jkUUuaBhS0maKAHH6UuKbS5pCClpuaK EA72oNJSUAO70hpOtFABmkozSYxSAh60ZPfoKT6UoNMYuaTIopaACjPpSd6PemAd6Xmkz7UZoADm k7UUp96AAGkPSijFADRRS9KQCmwDp70UtHQ0gDHrQaPrTTmgBSaSgc0HpQAppM8UmTR9aBC0Cjr1 pM0ALSUUfSmgF6UCk70ZpCF7UA802jOKAsPpCaTPNJmgY7NIaD+VAOetAAM5paSg8daBDqTnFJQD xTAXHNFGaKQB060lKe1JwKAFFA9aKOlMBTR3pM0A0DuLQDTTRSEPpPpSUtMdwzR1pMjtS0AwoxRR QIKKO9BpgxKOlKaSkAlApaKAFBpf1puaXPNADs80A0maSgQ7NJmkozQMXPrSg02gUAOpM0ZooAXN LTaOlADs0uaZ+dFAD80ZplLmgB1JmiigAozRQKAAGg84pKKQC0Zpv1paAFopM0oNMAopM0uaBCUt JSUDHUUgpaADNFJS0CEFO602loGGPwpe1IKWgBKBRRQAUhoooASiigUCFFLTe1KPSgB30paaOOaX tQAuaTtRmkoGKOlBNJRmgQuaXNNozQMdRmm55pRQIWjPSkxRQAuaXOKaKXPNAx2aTOKSigQoNKKZ R3oQDs0mfSjvSUAOoJptKOtAC9KSl/CkoAM4ooxR16UDCiijJoAM0Z9KSigB2aQmkooAAadTaXNA 0FFFFAgNFFFA0FFGaKADrRQBRQAtFJRQMKKTrRSASnUlH0oAXrRSDgUmaAHGjrTc5pR7UAL7ijHp SZoBoAKUe9JS/XNADqM00GjPNMB2eaSigUAJ2NFHNGaAEHWloxiikITFGKWigBOKKKWgYUfpQKO9 AC0Yo60e4oEOxR06Un070ucfSgBfSikBpc+tIAP/AOuiiigEL1pATnmjPFFMAoHtS0lAxaTPpR9K bmgVh2cZpMmgikz2oAd16UDtSUtAB0p2aSkFIY7gCj60dqKdgDpRmjOKTNIAPWkHpRRnnFFhBiij pRQMr4oHWl/SjOOtAC+9L+FMzk9aUDPNAC9T7UdaUe1IelMBD70E8c96GH401qAFzzSk4puaCaBD s4oz6U3tQvfNAxc56DpRRSY7+tMBw6UUnPoKM4oAOlJijPpQeaQB0pDxR2FIe1AgAxRRmkNAAaO9 GaM0C6BR+FFJ+NMEGfSjOOtFJihjFzSUvakpCFzRmkx1oAoGOpKTpS54piFBpM5NJmjPNIBxNApK KYDu9BNIDRnikAZopDRQAtHakpKYDqKbmlFAAKWk6UZoAdupCc03NHWgB340ZpKTNADwaM03NHag BwNLmmUZoAdmjNNooAdnikzzRSGgBTRSUvagBc0oNMFANAh2aM0maSgY4mjNNoJoAcDS5plLmgB/ 0opmTzmlyaAHUtMBpQaAHUE0maM0CQuaM8UzNLmgB9JmkpuaBjyaTNNJpO9ADyaM0maKBDs03NFG KADNKKbQKBjzRSUUCF7ilzTaXNAxcUUmaM0ALRmkzSZoEOzRuplFAD80ZpueKTNAx5NJ3pOtFAha QGiigBc80vam0uaAsLntSk0yigLD6OKZS0AOzSGkpKAFz6UZpKSgBwNKKbS55oGOzmlzim96M4oA cKKaDn1o5oEOzS0xTS5/OgBegpKTNGaAFpM0meaM0DFzmlHNNo7UCJKTNNJpO1Ax350opuaM0AOz +FFNzRmgB1FJmigBaKTvRmgBaM0maWkNB06UpNJ0puaYMfmk/Cm5oyaQDqO1NzxS9aYxf50UUfyo AKPxoooAKKKQ0ALRSUlABS0UUgExiiilFACUtFGfagBelApM+tLmgBaKB7UmaAF9qBSZooELRQD+ dGaADpR9aSloATFL+dFKKAENFKaSgBCeaXNIee1KKAF6CkGfwpcflRx6mgQZxR1oAxS/zoGA60Y5 pM0vai4BnrSZ4pR70MKTASnZ9abSdKYmOz6cUtJS0AHf2pDzQeDSfWgYZ6Ud6KQDnr9aBjs0Y4pp z2pc8dKBDqN35U0dfSlFADhS0maWgYUlBOBxSZoELnmj1pD70lIY7FB7UmeKTP6UAQ+1KeaKPrQA g4pc0YpKAHZ560UmaMZFMAFIaUdaOv1oFcbjjmkIwKXoeaXtQNidqTpS44ooAAaM9KMYpO1ACk4o 7UlBoEBPNFGKPwoAXNITRjNAGRQMTvQemKKOtAhv1o6AcUv1peuKBCU3FPAoYUwIyTnilz607FIR QMCKTpS4o+lAgpOnNHNIaQxaTFFFMQmPSjGKXNJ1oAUGnUgo70AL9KKM9KM0gEoo6daKBB2pO9Ln FIeaYwpc0neigBaDSYoxQFwpRTacKAA0mKUUlABR/FRS0AJR0FLTTTFYCeaXNJRSGLnNL/KmiigB 1LTcU7HFAgHrRRRQAUnelozQMKTFLSHNAC0ZzSUlADqKQUtABmjPNBpvNAEgyaQnHWhaGoEJSg0h 9qKYxc0hzSUZpCFFL1pKKYx2aAcU2nUCFzRTaXtSAKO9FAoGFLmm0o6c0CHUU0nijtQApozTSaMU AGaGOKTtRj86AFFLmm0UALmjNJRQA7P5U6mdO9GeetAD80mabzzTc80AS5oHtUYOacDQA6ikooAK KKM0wDvS5oopAHWjpSc5oxQAtApDQKAFzRSc80tAC0U3NLQAmaXPrSCigBaWkooAXNFJRQAd6Wko oASj60ZpKBjqQmkpaADNANJSigBwNLmm0uaAFoFNo5pgLmlFNzQKQ2O+tBNJRmgQUUUUhoKUU3NK DTuAuc0Cko5oGPFGaZyKM0gH02kpM+tMB2aM0nvR1oAUGgnigCigBCfWgcUuKSkAZpc+lNxS0AL0 p1NHNB4pgO60dabQaAHGim5pQaQBRzRmjvTAWl6immlWkAtHbikHWigQ7rSUDpRigApc0lFACg0U lBNAhc0YpufSnZ9aADNLSUlAx4pM0UYoASkpetFAC0fWkwaO3SgQd6Uc9KTGPypVoGIaKDzR060C Ep2KTrS8UDEA9KWj2oYc8UAL+FH1pM8UYzQAp/nRikx70uPSgBOtAoyKMe9IYvrSUH2pMUDI8e9I cnNKenGKMYoJsCilpM4NA60xAec0duaTFKfegoP84oHWjtxRQJCY96X0pe1ITTGGKb1PTmlyaMik K4ZpuOlKBxRQFxrcUoPrQBzS9DQITtS0YpKAFoprGjPrTBC4zQOKTPNLnNAwpcAdaOlLQITGaTvT u1HSgBpFJin4FIR6UANwBRS4oxQMb+FFOxSYoFcb0NHFLjNN5zQAEClxSAe1PxwKYDDx1pcelLRt pAJzTfapMcUYoERj0pcU/ApduKLDGEc0hFOPXmjbQIYaOlOPFFAxO1H1owKSgAzRS4pdtADaKdtp dvNADO1JUmzNHl0ANoIp+3FKBTERYJ6UbcVMVApOKQyLFI2c1KRTSBQAwH1pVOaCKXHFABiloHvS UAL+NJ3opfSgAoxS0dqAENNqQ0baBDKKkC0BPm56UDI6Km2Cl2CgREtGKkC46UmKBjcUmKdtpDzQ A00lLikoAKKUCjbQAUYoxSUCHDqKGoFLxQAgGRQBT8UYpgMxSYNSAUuKQyLHFHNPxzQRQIjoHHWp MUYFADOtFOCijbQA2ilHPWjFADRn8KWlxSYNAxKTpUgX1pdtMRH2o71Jtpu2kAnSlFKVpQhoAQUp pyoaXYaAGc0YqQpTdvNACUUUUAFFIaBQAtFFFACE4oHNBpRQAYoxS0DmgBMUAUveloAbRUmyjZQB HS4NOZTRj1oAZRTsUhGKAGUveiigYtJS0UANpQKXFFACUUtGKAEopwX1pcZpgNpB15p+KMUgG96X NLijFIoQ9KRqXFGKAGnmgcUuKKBC0Cm5pQaBi0UD3ooAMUu2kz7UuPSgBMUuKKWmIKSlooAQ9aCP WlpQPSkMZigCnkYNAFADRR70uKSgAopcYpQMUwGYzThS0UhBiikHWjGc0BcXH1penFFJQAv86Mc0 nWloAKKDRQIKKSloBh0opDRQOwtFLTT+NAhaPwNNU04mmOwdBRn8qM9KCKQCilpOlB4oEIfvUvFJ 39KTGKYDgetJSYyaQ5pAO60pzikzThzQFhO3NFFHbmgYdqXvTR1ooAd0GKXvzxTRQfagB3bim/XN H40cUAKPem55pfXtSY5oKQuaSjHFFAWIweKXqBTQOaUcHmgQUvTNJ6migBelGfWjP+FJ3oJFpoNJ x3paYNgTxRSHHGaQUDuhR370E47UdP8ACj60CAUhNHSigBwNJmm59aAfWgQ8nApoNIWHfpSeYvqK LAO7/jR+tM8+PHLCk8+L+8KYEmaKrtdRKfvj0phvYgPvCkMuZozWa2pRgnANH9pRkZ5pgaee1BPe s3+0oj0pf7SjoA0N3+NJuqkNRixk8Uh1GEdKQXL2aN3rVH+0YfWj+0IT3oAv7hSbqo/2hCuSWFI2 pQ+tMC7nnpQTg1nnUYRj5qDqMO7rQBfU+tOZu1Zx1GHbndVWTX7OKTbM4X3JoEbQNBYfSsdfEWmk 8XApBr2nscidfzoEbO8YpN4rJXXdPx/rl/Og6/p46TL+dFh3NbfjFHm1k/21Yn/lutA1mx7zLj60 7MVzVMgpd/FZP9s2AP8Ar1+uaX+2rFjxOuPrSswuawkBFJvWsxdUtO8607+07MdZ0osNM0ty0uVr NGp2f/PdPzo/tK1PSZfpmkBpb1pQyVmnUbbHMq/nQL+2P/LZPzoA0965pTItZn263J4mT86UXkBP +uT86YGl5q/Sk8wVQN5B0EqU4XEP/PVfzosF0W/NFL5gFU/tEZ6SL+dL58fd1/OgC2zg9KQNVT7V DniRT+NOWeI/8tF/OgCyWFG4HrVbzIx/Gv50vmL/AH1/OgCYMN3NOLDtVbzE4+Zfzpwdf7y/nQBP uFJkZqIMv94fnS5HqKBkoK0oINV9w/vD86A4B+8PzpCLHFOXAFVfM56j86VX9xTsBayoPNG9OcVX J49/rTcZoAsiVO+KDIueDVbpSb1H8aj8aALXmD1o8wVVDqTgMDSmkBY356UoaqynnrStkUwLANLx iq6k07dxz1oGSkCkxURY5pA1AifbkUFOKgDHPU0/zGweaAJNhpGTFR+a2aXzCRQA8LTgvSo1YikL mkBYwOlHGOtU/mJ607J7mgCwxpCc1Bk460ZNAEq0tQ5b1o3H1oAmHvS4zUCyEU5XNAE2KQqcVGZC TxSlyRTAftpfLqIOacJCe9AEmyjZUTSN2o81qBE3l0eXUQlbHJpPNb1oAn8unBBVUyv60izv0zSC 5bKijgGq3nH1pfMPXNMZY6U0k1B5hoaSgCcmmE81H53FN8wk0gJutNxTdxo5pgOIpQtRbqXf70WA kxQV/GovMNPEmaAHBaXYaZ5uOlKJjSEPCHtS7KhaVjTVdvWgCxilAxVYyNThITjJoGWQRSkiqxam 7jQIs5ppNQiQ0okyKBkh5puOKiLnPtS+YaYDwKXBqMSHBpd5NIB200YPegORS7qAE2ntS4pDJQH9 qBi7acBSb6QyYoAdinAVG0nApFlNAE2003bzUZlNJvNAExAoPSovMpNxoAlpKbuozQFxTSYzRnNG 4CgLjSuKMUu7NGaBoUDmlpCcdKTcBSEOxmnYpqtTtwpoYAZ7UoSm+bg8UvnelAh23FAFR+ac80GS gZJRxmot9G6kBNxSZqLdS5pgPJpOtN3Um6gY803PNGc0tBItIfagEYoHNACj8aUCkpc0AFLSZ9KC aQwox+lJS96BCig0lJigLi4zSHilxQaY7hkcUmaWkxigVxaDRR15xSAOlGKKBQAUo/HikPegH0oA XqKKTOKXNMAIFGPypOtANILAO9JjNKehpB1pgKB69KUU09ckUtIYd6Wk70c5oAUdKDSdeKM4FAC0 UnSgcUABpQMUdaKYwamilpKQBijOaCaKCiLPPSl+tJ3zzQRQRcUD0pe1NAxQT2NMVx36Unf3pB2p OlAA3WgnjrQx55qNnxQIdkGmlwq1E8wHeqstyoBBNMCxLeBPeqzakBnHWqE8+7NV+tFgua/9pZFR /wBq4JrL4A4pD7UWBsvtqLsvFRNfSk53EVUA45oxzTAtPeyngGozcyEnLGoaMfjQBJ57HuaZ5jBv vUmOaMc5osIfknljS5x0popQKLAKaQDimtx9acpzQAYoJx1pcfnS7aQxjkkdajwemamK+tJs54pg RbT6mjnHU1KUNNIoAjA9abjGal+tNKigVyI0nenmmkYoAbISEJ74rh/FN8QCrKV57Cu4qjfaZbXe RMoOaaJbPG5ruXk72HPAz0qpLfzjpK+cdzXfeIfCtnBbNIrFT1615nfbUnZUcNjvW8UmjJtk/wDa l3jHmvuHHDGkOqXQPE8gwP7xrMZ+ppry+hHoT6VfKieZmp/a92DxPJ+DU5tZvNp/0iT8WrFL4BOM 856YpPN+Yg9O1HKg5mbB1e9HS4k9znrR/bV6OBcSg9vmrI8wZ65xwKQvkkjbRyoOZm2Nf1Afdu5B /wACPNL/AMJBqA/5epOvGGPFYW8Yz2x0prMR0PHtRyoOZnQjxBqB/wCXuTPX71H/AAkeo8/6VLx7 1zxk+nXtxTvNBznGRwaOVBzM6EeJtTGP9Lk+mad/wlGpkcXTj1+brXN7uD8x/wAKaHCnOcmnyoOZ nSjxRqna6f0wTTv+Et1RGANy54ycGuZaT5z79KaTt4B6ijlQc7Oqj8Zatk4unNTDxpqy9bk5+lcb HIV6H8KVpt3T+dDS7BzM7P8A4TXVjyLgg44pf+E31cDPnVxRlzj09KBJ/OlZBzM7VfHOr4z5+fSn J4+1fd/rQtcT5oXn8elNMuTnPX9KfKh8zO9/4WDq3eT6c0f8LE1Zf+Wg+tcJ5g9c8Zpm4nqcYpcq EpM9AX4i6v8A3h6cmpV+I+rDqVP0JrzsuRxuP0pd52kD9KXIh8zPRl+JWqjg4/PFOPxL1QHqCPrX m6vz+HrTi4I56emaORC5meiD4l6vxu2nPvUv/Cy9SC5yvXFebtJj8+1RGTPP4Yp8kR87PTR8TtU4 GAfxpy/FHUlPMYGP9qvM95yOo9M9aDLlvwyaORBzs9QX4p6icAqAM4PzUn/C09SHKrn8a8u80joa d9qAznFHJEOdnqB+Kmojh1GOlMb4n3x6x8ezdK8yafdjPamCVm7445pckewc8j1JPihejJVDx71M vxWvV/gJHXrXlAkOeKXzMjgkH60ci7Bzs9ZHxau8cxH35xUi/Fu5A5gf868h83H3jnvT/MBAPOaO SIc7PXV+LtwV4hPHqacPi7c5z5OR7GvHfMwef5UeYR19KPZxH7Rnsw+ME/a3b86F+L0o+9bt09a8 aMuO9Hmd+DQqUQ9oz2f/AIW/ISP9HY+nNC/F2YYzbt74NeMrJt6/Sk8zHfij2URe0Z7aPjAQf+PZ j680f8LjAHFux4rxDzSDnPQUokwPU+9Hsoh7RnsrfF+4DFlh49CaX/hcUygbrcnPPWvGVkzknAJG acsmeB+tHsoh7Rnta/GKQ9bY9Oxp4+MIB+a3evDw3H+FKrjoT+lL2UQ52e6/8Lijzzavz6Y4ob4x RnrA4FeFb/y789aUzZ744yKPZRH7Rnuq/GCI9IXOeelOHxdhP/LFq8HWcnn0p4kLdDjjtR7OIe0Z 7uvxetunlOT7CpV+MFoOsbe/FeAM5HOcY44NOEpOOfxFHs4h7Rnv5+L9jn/VuPotOHxdsQeQw98V 8/GUg8keppBKe5z6Cj2SD2rPoZfi5px65/Khvi7p6jgMcelfPLy88dfalMu7HPA4peyQe0Z9Ef8A C3NNC8g5x6UH4uaZwDnnp8tfOwcnnPBP40eZhcc/Sj2UQ9oz6J/4W3ppH3WH4U1vi3puRgH8q+d/ NG09MdKcJgvbn0zR7KIe0PoX/hbmm5A2t+VPX4s6WeoI/CvndZ6QzYPUn8aPZRD2jPo1fitpQ+8c VJ/wtjSB0f8ADFfN4m46n270hf1xjrR7JB7Rn0kPitpHTcOab/wtfSSeSPyr5vSXAIzSrMSuMnrR 7GIe0Z9If8LU0ju4A+hpf+Fq6QP4x7cV83xy5OHPHQUPJt+7z+NHsoh7Rn0iPitpOeZF/EU8fFTS O8q+nWvmoSHHzHqfrQZDnI9fSj2SD2rPpgfFHRieZVHtTh8T9FHWVa+ZhNwRkDPNKHPUkdetHskH tWfTQ+JWit/y2A+vFOHxK0M9LhfXg5r5jLgnO4HuKPOBbg5z2Jo9kg9qz6d/4WRoozm4T86T/hZO inpOn518yeYV6nrQJ/myMHtR7JB7Rn08vxG0c9JlH1NKPiJpOPkuENfMPmbh1/Wk8/B5J596Xsoh 7Rn08fH+n9pY/wATTh8QNNUczR/mK+XzMf7xx7GhJs/MSfTOc0exQe0PqNfiDpJ6zR/nUv8Awn2k DrMn03V8tG4O3lz/APXpBOcjlvel7JD9qfUw8e6Qw4mT160f8J3pIHM6D8a+WTcHn5jjOc5oW4Y/ xMRjOM0/YoXtD6nXx3o56zpx/tU7/hONH/57pn/er5YE8gJyxI9M0hnbjc5/Oj2KH7U+qx400knH nr+dO/4TTSO1yn518qfanGAXPvzQbhxzuzz60exQe1Pq8eMtJ/57r+dJJ410lFLeeh+jCvlH7S5P J/Wka6fK8lfxo9ig9qfUT/ELSAf9an50J8QdIY/61B+NfMAmwxO8nNRmd+CGIxS9kh+1Pq6PxrpL jPnpj/eqVfF+lNz56n/gVfJ63kg/jb6ZNOF3KDnzW9gDT9ig9qfWH/CWaX/z3T86VfFmljgzL+df Jou5v77cehp4uZAD+8bnqd3NHsUHtT6w/wCEq0tv+W6/nTl8U6UT/wAfC5+tfJjXs2ceY2OxDGnr qE//AD0Y9hk9KXsUHtT6z/4SLTTj9+v50v8Awkemj/lup/GvlBL6cEYnlHY/Mad/aNxjAmkI+poV EPan1cviHTz/AMt1/Og+ItPB/wBev518o/2ncrwJ5PpuNPTU7o9Z5Mjj71HsUP2p9WL4gsD/AMt1 /OnjW7E9Zl/OvlP+07oDH2mT6Bqsf2teYGLmQHH96j2I/aI+pTrVjj/Xr+dH9tWP/PZfzr5Z/tm8 7XEnX1o/ti8D7luJR6YPWp9iHtEfVB1qy7TJ+dN/tqw/57qa+XBrV5jBuZMf71WbS+vLmZY/PkwT yQaPZB7RH0z/AG5Y5P75fzpf7bsf4ZVP4141p2mSPEpkuHOR61pW+mlWB85vzqXCw1K561HqNvLw rqalE8Z/jX8684t2aIYV2/OpjcSkYVz+dTylcx6F9oi/vj86X7RHj76/nXnyXE/8Tmn/AGiUfxt+ dFh3O/8APjzwwo8+Pu6/nXBi4k6b2H408Tvt++T+NHKFzuBcRZ4cfnTxNGf4hXCCeTPDH86BPKDy 7H8aXKFzuxJGf4l/OlMiDqw/OuE+0S9mbH1p32iXuzY+tPlC53Czx/3hSiZCMlhXEebJj7zfnThP KP4j+dFgO3EiEYDCnBhmuIW7mH8bVPHqVwn8WRRYDsc0pOK5mHWpAMNira6yCPnAFKwXNnntSgk1 nQapFJxkfjVpbqM/xCgCf60v4UxZlI4Ipd4PcUhjhR3pB70uaQhc+1Jnnmij6UALRj1pKQnFADqP xpM560Z5oGGeeKUDj3pMe9JQAv4Uvrjmm0vQ0AL/AProzmkNBoAXjtRnAo6DNGeMUAHaj9KMUHpz QAHtR1ooUUABOBRzSUo/zzQMPw5oPPNJ1PpS9qAGmloxS4oGGaAaaTSjNABQaWlwCKAE6UjcUvQ0 dqCrkX14pPejGAfSjBxQZgTScZp2OlNYfnTAa0g4xUbThabKCBVGbNAieS6A71Vlus+v4VXk3dGq LnPFAEskzGqzEseaVt3NNpoAxzSY5PpSjrSnr70wEwOtN6NT6bjnrQAd+nFJ3pc880o560xCcYoN GPwoHpigBe1JxQeFFJkjFAxcdcdKUUgFGT+FAhwGOvUmlAA7UwHPFOBIwKBkgxTscU3t1pyjjjig QhFGPSlJozjpSAbg0FecU7PNFMCPb6igoMc1JikZaBFdo+3rUbRkGrW3vjFNP4UwZSZD3qnqdwll bPNK20KM8mt6GNWPIFeP/FbW/OumsrMkRRZEhz1NVCPMzKpJRV2c94p8S3F9cMschWL65yK495SQ 2T1zn2qC8eSPqSWIyKqguckg8810KNjDm5ti6Zc4yc1G8mCecetVizcA559+1APX0+lMZOJSOuc+ tJuPHFQDocc/zpC3HU+n1oAsbj3Ixmk3noCKhLccLj0ppY9cA/jigZOX5yeOeQaN/wDs/jmoA2OC cg96Td69MY+tAFgyDgdvTrR5nAxjmq5bpjOaTdz74pgWS+ORxTRMN3496rSSbYznIHX61Wa7znrn uKLCuaDSZGAeM+lJu/n3rO+04YdTj3pVuMsD0pWA0PMAPf16UgcBecmqbShu3I75pyScEEnj2oGW t4K5Gev5UF+2cY9qqhsHjvSrJ9OuKALAkyec5HrxQG3c9/aq4fJ/zzS7jnrj6cUDLG/I4JpTITx/ Kq24g8fiM0m4EGiwi6HB9aZu57j+tVixzxz3oD/Nz/jTAs7+Tj+dKJMN05zmqjPk8f8A6qY0hByc kfXpQBfMuR1zSeYvfr6Vm/aAvU/hStcqTweM0AaJl565GaaJCW4HfgVSWZSOo60vmZ+6fr2oAttJ nkfgKZvPfAye1QeaMZz+tHmDJ+vpSAtqwz29qTeO/Jqr5n50vmcjt6CgZaaQY/xpPNwPeq2/Jx+N Ab9PWgRa3nvz6UnmYqtv9KN+BwRQBaEgHc9aXzeM8daqbuxNNMnFAFzzO3p1pfNx0OB61ReYDnPO KYLhTwSPx70xGg0mc8570wvjgenrzVP7Snd1pPtKdiOOKAL4fsen1oaUg/zqh54ONv405ZQR70AX PNzQXPP8zVTf9R9TRvHOaALPmEZwRS78jr9Kq7/f6Upkx0P1pDLXmnufYUeaB1wPxqoGyTnmjf6f hQBcD+9DPhsrnOPWqZfjHr3pfN7+lMC35mSc0okyTz+FU/N6d/SgPxxj8aBFsyf/AFzTvM5zVIy8 defcdKVZR3IxQIuZwOwpN4z/AJ4qqZMnA5o38cfWhgWTJ27fWnF+cBiMVTMnOfek8zpzikNloNgk d+1OL+/OMZqmX+UU7dmkBZ8whv8AClD5xkjBqqJMe9G/B45pgXC3zfLSb/8A61VRIexwPrSeZxih jLJkAHWl8zAODkGqobnt/jTd+aBFsP3Xj60vmZ6+nrVQNkdTil8wc8+5xTQrltXPbIx0pfM2qD19 KpiUdc0jSZosBa8wnjpmlaYkAZqmJMjtQ0gH0pMZbD9D+PvTi/fP581T83r/AEoEuBycdulAFsSk ZDNx70KxBz19s1UMnvnmlEpz+FAFsSckgg80eYA33hxzmqYl9OtHmc88UAXS4Pfg96bv564qn5mB 39qcJAfyxzTAueZxgN9BSq/X1FUQ57fjzShyO5osBfMgBH8jTVkCt+GPWqKzE980vnDqTj0zQgL3 mfLyeKTeRnJ/+vVMTD+8OtO80mgC35np3FHm9jiqbSYIPtxzRvz3wPWkBeEuYyPofrSBuOnfsKqL IdoGPxpfOJOQT+BosBa80fTHSgyAd/l+tU9/HU560eZxxwPeiwFwy574H1604TYXqPTOapCQk8Y6 Um49iRQMvCUnjse1BmxnPH61SL+pJo83PTpQBd83IyCBj9aVZNzZHCmqO8cnj+tO835/b1oEX1l7 lh+dSLJg8kEdqzTJ8uCfwNIJyMkH24psRpiQHp+Ip/mjGRjBrOWXuaeJuetAGh5meD+opfNz1/Cs wTfNwcZFPEmRnrRYZf8ANzhQeevNBk2nrxWesmPy7mgykDI57UgNJp27c45qaC8kiYFT3yPUGshZ tzfNwc1J5ncdetFgudVD4jvVwDOdvtXX+G/EsDDbdy4b3/nXlS3ATpz606K5IbIJHGOtQ43LUj6G trmG4QGKRSPY1Z6DNfP1nrt7aECCdl56E5rrNL8dXSMBMquB97JqHDsUpnqoYmn965zTvFWn3YVS /luezcVvwzrKuUYH6VHKaXRLzUi+9Rrk81IoJpWKHACndKULTghzzRYCMU5ak20oQUAN7cUflT9u KMetAXGilNL6UCgLjTxilBNLwRSYxUgOBIHBqRJ3Q5DGoaOmaALiX0o/i61bhv5DwGPFZAp6Nsbj NIo6i2uWcDNXVfdXOWl3j8K17W6U496QGiDmk4qNJFI+tPz2pAPHSjFMzxTx0/rQAAUmDnmgc07p 1FACYox6UvU0mKQDT7cUtOK000xh06UdaXAo6cCgBeopDx1opaQdBAf/AK1KelJil9+1ABRR19KP TNMdgx60Y44pMd6UdeKQABnrRjml988UopgNHtS0D3ooKExzS9aO1APNAgo70dKKB3DFIevFB5xS HpwaQdCLFL/hTcj0pykUECg889qOtJnmlHOaAEIzVeWEHNWv8Kbg9aBGTPbE5NUZIWTpXQtGG61X ktxgjGaYGDj1poHrmtKe3B+lU3iI+lMCE4ApcgjijH40lMBvPXuKQ9KeRmmgZFADStBwD/KnUbcn GBTEH5Uh4pcCk2+lAAOlB/yaQ570vpQAv40UAYoB4oACBQAe9OFFACdOlPV8dRTTntRQBLwaMd6Y ucUqtzQA4f8A6qWgEn3oz60AJjFLmg00HBpiAjgk8fjTMZNSYBA5p6Jnp+NAinqt1/Z2k3F0cYiQ sATjJ7Cvn/Ume48x3O52OWJ716d8UNSKxw6fGxz/AKxwO/oK8ykCqrscAKM5rso07R5jzsRPmnyr ocbrcgNx5a5BUfNn1rpPCvh6fWtGuLm1VXeFwhj7nI61yN8/nXskmQckkV3nwW1VLPxAbSViEvF8 oegccj/PvVyWg6W9jAvdOkhmdJoykicEMKz3tXXkpwTivozXPDVjq6nz02S9nUYNeXeJPCV5pUpZ EMtv/wA9FBOPrWKkjp5WefSRduQevNQFMvkDk8VvSwLndgE59KgktQ3I/AYqrkmT5RDc9qRlwT04 9K0GhbnjIFQMnyjg9fWmBUCnjFGCO3HqatunUc4z1qMJxzmkBBg988+hzTSufrVjy+2KjePoOo7U xFK6PyhF7+tVGXPTgVfuU3MTnpVd0GDxn3q0iHIrKOemKX+EHmpdhGO3FJICCOnXOc0mgUh0WcDO enFSDJzjPrUdsPlYAnGcg1Ow68c5qWaIbjjpzS1Jj6n8aaB9B6UhjSMH0+lH0/Cn7OB6dMUFCAen 0oAZzjpzSk88nOKdtwfSk28GgBM4wR2pOSSQccUrA+/1HFOx6cj2oAj/AIee/vUUwO0jFTsmOSM/ hUUoPv8A4UyWVMUYx0AqQqOMfTFG3IJH6DpVWIuNAwf/AK9SjPHXFRMPm/zzU4TC80jRApyRS849 PxpQvzHj8aRhntUgB6Y59OKcCe/NJ0PNB6/zIpDFycHr9KUn3pPx6UY6en86YC59cH3pMkDgUuD3 x+VHYdhQITPv7U0nA96d2P8AjQcH3oAqzjmoOc1ccZPFQ+Wfr71djPm1K7IO/SlVQMU5QSzYJPPa pkXAGfzpDuNU+9Sg4x1FIoBY9qcF9QfWkUKDjOcmlyc5PFAWlC4znmkMASaAeeaMc/jS45yPXtQA bvr+Ioznt/8AXowfy96MZPOe1IaAn8aO+PbJo2+xpByMEUwEJ9T0oJ65obpx1oxxk5BoEVXyMio/ m65NWnGQeBURXr054rRIzYxN2fvH86sKTgfzqNV5HQ1Ki+mOtJocWKX559OtOU/nSAdM0oHAwKks UN09qXcew70mMHml28ECgBd2Of5UZzjH50336ccUvTPrSAcCaaDnFGOB0ox+NAw3EZ4/Kk3d+/tS ke/bNNxn60CYjNgHbn86rszZJOcDpU7DPbt1qJkG7niqRDIfMkGcvUsbMGweh96TacelOVe9MEx6 lsD+dO3Z60BPan49sj1qGUhobIweadn88elJtJxx7U9V9f5dKBichR/OjP4UuPoaAMcCgAzSZ/Ti lwcjHHrQV9PWgBMnjvxTeBTyuOmMY/OkK5oGMzj8qZK529eaeR9aYw6HvimSVsvwQxpRI5JDEmpG TnIphXA4pk3AMyr94mpIXctywPrk1GB0wDUsSkD+eRRYLkyscCnh+mBznJpgHY9c9Kd9PxqSh+/P AoViBzzTRk0o/wD10DFB5/zzS7j/AJFJjJz/AFpMcd6AFJ6Z/nS7jjvSAHrRjOBgUBYTccgY9qTJ 7/pTvy9KNpwaAE3HGRniopJGHH51Kw9D+NV2G5u3SmiWNM8nOKcs7D+ppm0Z55/Cl2+lXYm5bgnL nBP0qwCfXH4Zqlaj95+NX1Ug8dakpBn1xmnD3B60iDrkDp6U8J26EmkMYAD370vU8cU7ad2M+1KF O70/WkIYpzkDp1B7Ucgden4VIIyeOcHkVIYD0Iyexx3ouFiIHPfIzwKBnuOnNWhBgn9KkW3YnBGc jsaLjRR2swORk9zmpUD7s8g+xrTisixA2Fs10Wl+GZ7qMyeSY4gOWZaBnFPcSxyqu8gds8V0nh3x BqtnOuyZ2QdVY5GKo+IrCO01KO3TJXPXFWbGArgsMHvVxipOzMatRx2PbPCOqf2xY+Yy4ZeG+tb4 XFed/De6NtI9uSNspz+Nejg5Gawqw5JaHRRq+0jdhtoxRS1kbBjNLiij1pDQmKDx9KRmI4puSaLg HFKKMUmKQC80360rGk6UAGaXNJ1oxTGOGaXNN7c0oOaQxyvt6Vct7hlPJqlSqDkYzUsEdBBdg45z V6O4BNYdnE5FalvEQeaQzRjYHGalzVdExipgKQDselLTe1Ln0oACKTGPrSgUufagBMfNk0fhS5xQ M0DEPtQaXGelIfcZNAhB7Uq8Ud8gUuM49KBiMKPWlo60gExig5pDQfSmAopMdqU80A49aBhwKO1F HTrQAv8AF+FGeeOKT+LPIoxQAmKXjNJ060vtQAZFApKTtQMUHmijNIeOKQEeMntRjFKRxRigkBjr 0pVxmjOMimkjtxQA/PpSY+WkBGKXAoEMPrSlcjnpS49KC3oKYyF4gT0FVJrfOavge9DKKBGDNbsD wOKrGMjqDXRtADVOe1B7UwMfnpTeO1XZLNicjJqq8TRnGDTAYfcUnennjrxSfTmmA3pRSgUZFAhA KQjvTwc0m30oAbznmlA9aXbTscc0AN5FLzSfSk/OgBcH6UvfmjtyDmg8UAKCMUAg/WkyCKCcdjQB IOKcMGod3NSZoJH49MUhHNKrr60uQf6UxjFGaJ5VtbeSeThEUsfwpwGelc38QNR+x6MbdSBJP8nu B1/pTiuaSRFSXLFs8x128l1LV7i5l6sxxznA9K5fxNcNa2myPhpDz9K3Xb5s5964zxJc+feuh58s 4GK9Ll5VZHkRd3qY0h5POff0qfSLl7HUEnhO14yJAw7Eciq3THuO/NCnGeh46dKR0o+srC5Goaba 3kQ+SeJZBz0yM08xhkKSKCp4IPeuO+D2r/2j4VNo7DzbKTZjvsPIP55rtyMdea4J6SaO2DurnE+I /A1veq02nbYZz/D2NeZ6rpdzp07RXURR1PJI4NfQGRVa/sbW/hMVzAkiHjkc01KwOKZ88tGMf1pj QrjjivRvE/gsW2ZtPDtD12HnbXDSQNG5WRCCpwR6VsmmZtWMiW2YDI9PWoGh5Hv+lbJUEnvUM0XX HGaLktGQ0XOT3pJU254xWg0Z6EH0zVa4BEXAznirW5MnZGPIvUDv+tRlOcnr/KrrKSTxj3qFoyMH BP8AWt7HI5albbz7jn0qtNkv9PyFaDIFBbHSs5slizGokaQY6zYeeAcYbir4T0X6GsxWKTKw7HNb qJuTdgjP41mzdMrCPOMjjHTNHlkZ47dM1aeLGCCP5UgjJ9M0irlVUA6UpTOARVkxDn34+lO8sdx/ 9akFyoI8noPegpjsatbMex/nSSLuHfpzigCptweO3rSbQfbNSngZIGRSDH09qYEZXJ6e31qF1O4j HTrVxcg/55qEoSxI7mrgrszqSsioUxjihRzwBzVt4uw5+vao2TGeM+ox2rRx0MFLUoPneSoq4qlg Djr6VWcfLwOvar9qpaBCR25rJnREi244PQ0BauNCBngn1oEIPpmoLKe3k8dacseeD17Vb8jbn2pN m08ZB9aAKuw9PU+lG1sEYPSrQTP86R4uCaLAVSM/pml2/wA+tS7M9TxQE4P+FFgIMf5xQV68VbUA AEY/OnNHkZ60xPYzWWm4+bkdParfl5IJ4PYYpkkeFJx07CtraHNzalOFM5PXJ6VLsAFOs1VrdSAc k89qnZNoJPTFJoFJ3KMS5Zuvr9an2YGOtNsxm4xn+Hirhj5OemKzOhFYqe3ApdvPIq15WBnt60eV n3HakUVNvPTpSgenTp0q4Igx6UnlDbn+tICqF9s0mzv/AFqxjHbmm49u/pSGiLbnpn0pCv4j6VOq 88dalC565zinYCljoT09qQg556Vc8vPv24prx5Bx+dNLUhvQoY9qXbk881MyY6j8MUeXnPrW9jl5 yFUBIzn1OacidelS4I/xNSxRblPPQ84FTJGtN3K/l96UJjGRVryc9DxR5X1rI2KwX/A0bOMmraRD pStDkdPegZSK8cY9KXbU+0DINMI54oAZtz/LikK/nU23BPpjtTxGSc9aAK230+gpNnXA71cEXrxn mkMXPI68/SgCkUYL68etRspyetX2i+U579KhaP249cVcdWYzdisV3UirjoO+KsbMnjB9KcseSDzV 8pmp6jVTP86UoQatCPC8CjYO3NYM6VsVQgGODQV9jxVsR88frSGLP+NAytsxSFf84qcjB5/Sm7ee Mf40DIiOTnGBSlKlC1KqfLn1oEVAOe4oCjirZjAzz3+tHljbkAZoApFPyqFh8+BWiY+vHU8f41Sl XEzDvTSJZEVFMZTtbn6Vb2Z6kmkaPK8jr61skc/NqVlGVB9qlRep4xSwrlMnr2IFTopPGKHHQalq RgHvx+FAU/nVmOHJyP171IsO1eVzWLOhFPb/AJNO2c8/nVryht6detJ5eG7UhkAj9BxSY9asqARj FL5RYjGDRYZV2Z+tKq+2eauLb9McDv8AWl8rsB2oEUWU9DmnBMnsPrVvy8nkZ7UCLHTk9KYmUWQ8 4GMCqikFyfwNat4nlW7EjnpWVHyQfeqRMh+0nt9KRQT0z9as7fT0o8vtWljncyOJSrA89ea1I4yR z161S2YHPPf6VtWkG9V47dazmramtOd9CqsWWPB9RipBHjpk81o/ZsryT78daVYOckcfzrM2M8R4 6cGpBBntjJrQjgx1UVKsAz9KAsZq2/IznpViOIDnHNXo4Metbel+GLvUDlE8uMnl2GPyFJuw+U5u OEMw+U89q6DRPC15qGxkjMcfd3rvNF8JWVgqtKoml6kt0BrpY0VRgAAD0HFZufYuMe5zmi+ErPTt ryfvpfU9BW1qkq22mycKARtGRxVsc/Wsrxmyw+F7uRv4Rke5oi22VJWR4N4jvFutanmjJYbzj8K0 tPn+0wo4xno1YE6hpM8Hnmr+iuY5WQdG5x3rtgrM82o7nc+FLgRazbGRsJuweK9iGCvHTFeCwsQQ wzlTkV7Zoc/2nSbaXOd0YrHEx2ZthJ7xL2OKPpSHijJrlO4XmmE80McnqaTrSYwpwptO49aACjFH PWj0oACMUmPSjPrRQAUYOacCe1HIqRjcYpMkGn8mrNvAW7ZpjII42cjFaVraZxmrVragYyK0oYNt SMigtwAMVdjj2jpTlQL0px6cVIBgUoFNzTh+tMYmOlLt9KT6U7kUhMMDv0peD0poNLnnNAC0n05o pRQMSj6UdetGQD6UAN7807d+VJkGjIoAUflSZx2oz9KTtQANS/4UNRn6UAFFJ19qXtxxQAmPSgji lxmgUDG55p3XrQfejOBxQAgHXPpxSjHpRjLUfhQMQ/zozR1oBoAaR9aQ9OtO5zRjJ68UgGZ9SaXr SZ+Xoc0vWkSIwpoHtTuvSjp1600A3/PWlzz0NIfypAfm5zQIdk4ozxTSfQ0oJoAUYNLQMYHrRTAT 6UAfnS0lACFATyKa9uj/AHgDT+R19aO9MCu9lE3aq76bGW4JFaAxmii4WMebTTxtOagfTplGflre xg5pSM9aYHMtbSoRuFNZGUdK6ZkU9Vpht4yOVFAHNHOelMPUV0clhG3YVUl0zpg9TTAx8ke4oVwe MYPvWi+mSY4/OqslhMn8BNAiHNKPbFIYnU4KkfWjOOtIB3PpQO2eKQEHkUH3GaYC469KRs0A4pc5 oAbyOtOB4pGPtS0CJVcBSc8CvJPGuoNe63NzlIztXBr0LxXdvYaHNJGcO3yivH2YvIWJJyc5Peuz CQ1cjzsbUtaCGTOsMbSyHCqM/WvOr6Tzrh5MYDEnOetdR4qnZBGnO189D6VyrD5uDjA9K6pHNBEC 5/DFDfiKXGMcfgDQSCuDyOmazN0zvPg9rq6R4jK3B/0a5Ro3JP3ehB/DH619BNhlDKcqwyCO9fI+ mz/Zr2GQc4cZr6l8KXP27wxYz9zHtHvg4rCtFbnTQn0L5pMEdafg5z+lG0muc6RjKWQj1HevOvG+ mOMyCzTrkyKK9J25B7UpjVlwwBHfIzTTaJaufO0y5bB45wQaQjtggCvfLnQ9NuFIks4G78oK5rWv AtnPCXs18mXuqdPyrRTRDizx+VMruA4+lZ9x8wx0xz1rtNS0WfTt3nxlVHU9q5K6XdK7ccngYxXR RV2ceIfKrGdtw3XGO2aQxk9OT25qz5fzAepzmnbTjovTHWuuxx8xlagRHDgHDE4GayNuB9BWtqZ3 TENg4PHHQVmMvA759TXPPc6qWxC43DArpNKHn2SHHI+U1zrgcDI54z6V0fhHBkngOMld4GetZmyL TQcDjmm+QT1H14rd+zrj0z7UCFc428/TrSKMF7dgDgdajMLDqOvBxXRGEMeR70n2df7o/KgZzjRk dRwenvTWhY5GRwOhFdG1mhYfKBjoRTXsAVOPrSA5d4XHUAj2NMAHbPXn3rpJrElSqrk9/es260qZ fmiUfTPFCBmaAx7jFP2Y/A9hT0t5hIVkVeOCd4JqcR7c5/nW9NdTkrSs7Ffb8p3cj2qCYBYjjqav BfSq95HheBz7VclZGcHeRjyKQ2K0tFjMsUi4HynpVOSM+nH1rV8Lrm6niI6puH51gdiLD27ZwBjv zTGtinUZ+vet5oBuBI7cU426uoFSUc95LdwPpmkeM9l4963xZp6EHPNH2JS3TIzQMwREcZPHb60j Lmtz7CmTjg0xdPODxQM5x0Ab05zTM5Oef51u3Ol7gccEHP41lzabeo+1IGcf7I60rCK+CPerG0hD u5yKdFZXRZd1u64P8VXJrbZDhkI5xzTjuTJ6GaY+nA/CoLxfLt5NvXoK0fLJPt05qG4t98KKAPmk ArpscHOVoYtkKoB0pJhiB/piru3DY6+1RXijyQoHB4NKS0KhK8jNsUAvowe5xz2rXER3Y25P0rOs 0231uc/xiuvNmgPQ5rBnYjBNsevvSeUAuD+tbzW67cD8qd9jU8gdutIs57ysc+/ekdAy4Het77Ep bOf0pj6d6DH0pDOYm+VwvOfek69MVsX2lttdx8pUZOemPrXLveiNiBg49KANFQSeMVaSFivzc56e tQ6Vm9IaLaQPvDNdBHZsy9McelMRkeV69cZpskOF9vet5bIj7+PqKivrRVtnI6jtjtTW5E3ZXOd8 vvg4xQ0eCew9etWniwARz9BSCPJP8q6lE85zK5jJ7ZzUtrGSrZGefSpkjyRwMfXNaWnWwKnPTdWV RWOmg7q5li3bsAcGkMDA8jtW+bJWGR1qI2RxnHI6VidKMgR4Xnn1qNk+XNaxsj/FxUUlthTwaRRi lfmOORmjb/jUtwDCxDIcZ64psX73G1SAfbFAwiXc3GM/WrSxccenNWLO0YKeOa0Etsrzke1AGOYj t54FKIiRjHP0rcFgmAeKctgG6Hn2oEYEkWYzx265qm0fAxwB+VdNcWuImJwWArGli6+nqK1prU56 790z9lOVfm6ew+tWjHnPBHehUyynHQ8Z7Vu0ckZXYCNhjjnFL5eFwO9bcdlvjB+U5HPGKa9gNw2k j1rkZ6SehjtCMDtTChUfr1rWayZT8o96rzWcmMlDnFSUY7Dk+nrQF44FQXd4lu5VmG4cHHOKmsZP tjAR4JHWgB4jJ6dT2q0sGFAGcnnmtC2sCANwJqz9iz22+naqEZAjyxOMY4PFJ5eBgZPvWyLA9eCO vB705bL6dKQGGYcdKzJlJmc8deldf9iJDHIrmJI8OTwcsfwqkQxsa5UZH1p+3cfmqWKI7fr6VL5W O3vjFdCWhxSlZ2KEMLKDnHXvzUyo2cKpODU0aEs42/d6GpVQjAxjinYcZajBEBnPHqMUEH1/EVdW BiAemepqC4Ty9xPAFczO5FViffHrSKeevX0qNpkHAOSasxRtJ91cjHpUFDFGetWo4zt9PqKswWZ6 spB+lW1sjySM9qoDNMeV49KGiyOc1qLZOVx0pTZN7Y70E3MlIuenGad5ODkDvWl9lbOAMGlFqQ3H B7igZzutgx26J/Cx5rJj6j69q1vEmVukjOcKM1louSMCqRmy+sW5QeQMcU/yuhGelSWw3wgjt61K 6EAdPc5rZI4pSs7EAj9s5GK2NLUm3UkngkEVnqvbg/j0rQsWKNg5C1NRaF0Z+9YvgY68eop2QTwM 8fSrNnFBcSASTBRnk4ya9A8O6NpBQfuGuW/vypXI2eio3POlXcQuO3FbukeG9Q1BlKx7I/7zCvUI NLsYmzFaxIfZRV1I8cKAMdAKhyNFE5rR/ClrYgNMPOk6/MMiui2BUAAAxxgVNtOKCnqam5SRAvFL inkCjA9DSAaq81w3xdvHi0uC0jkx5hLMAeeOlegQpuxXjXxM1BLrxBMoIMcIEfXP1rWiryMqztE8 /ZORk1c01vLuUIwM8dfWo2K7vl9c8UscgUhhzj0rrPPZ1UK59CPSvTPAeoiWz+yufmTgfSvLbKUy Rq2Tz1Ndh4Pn8nUIyx4PH1qq0OaBnQq8lQ9N3dqTJpo+bGKcBXmnsoD0pO/FOxz2pcUhjGFFPppo AT9aX60g96MUDDrQ2cYFPSN35UE1LHZTP/AfxqRlX8KlRGY4FakGlP8AxLzWhb6UEOc0DMm2tCxF a9rabR0q7FaqvapwgWkBHHCF4qYKAaPpSg564qQFHFJg0de1BNAABx60hB9KcuMUHjpQA3FLR9TR QMAKUdqTk96XHoKBBnBFFA6UcHrQAjHnpSc0Z5pcigYmTQDmlbkCjqfSgAAwaPrQOPpR1HFA7hig Z7mlpfTNAhgpTz2p3pSD6UAIBxTuM8frR69qbx3oAGpvSlJGOaD7UFADu7UDvS0nT6UCGnPp9aXH c07Bo680DGnIyTRjPNIxz1z0o4x1OaTAj5pQMCjB9sUpGKRI0mlz0oIo47igA96bjNLzQDTAZjHr Sgn8KceRx1pNpxxk0wFI+tLx700HA6Gj170ALijo1Jz6Uc+lAC5o9aQUuOOuKAEIAFHNLRQAA0Zo ox260AFL+NJS/nTuAm7J5oOc+1GDzyaKBC8DrRgHkikIB60gAFACMiHqoNRPZwyZ3Iv4VLkUo5NA WKD6VCfuFlP1qB9KcL8rA1rfhScmmBgtp9wP4ePWoWt5U6oR+FdMM9BQy/3iB9aYjlWyPvflQnP5 10bwRvnKofwqtPZ2qxvIfl2jJwaEri2PMfiRfHbFaA9Rk4rgAAFz0xzWt4juzf6xcSjPl7yEz6Vk 3D+TA4IyduBXr0ockEjwas/aVGzkPEVybq54XCpwprGYHH41v3A+YjaCCeciqbwKoY7QT1zjpSZt FWMVhjHp/Ko8/KTzgcjNX7iPEeSCR7Vny5VtvBB7VFiwB2twB9K9o+F/j2207RV0zVA7LExMci9g eoP414e8nr6/lVmwuinc4z1BpSgpKzHGbg7o+o08deH3zuumjIOPnQ81PF4x8PSNhNSh6ZwcivmF r2RlyGPp1o+0yYUE9sHHeo+rxNfrMj6u03UrLVYXl0+4juI1bYSh6H0/WpyMGvKv2e5jdavqNlJL tWS381Fx1Ktg/o1e3HSADzIT7YrlnHkdjrhLmjcxulKprY/sVezmnDRU/wCehzUXKOA+IzRp4ZuS QolYbUJHOa8LMfPPTp9a9g+NTLb/AGTT1cO3+sbB6eleTsuWz1/DGK9TCx9y54+NqXnZFMgjsOOK No8tuwwTmrZTK4YZqG7jLwMqHrxW7VkckG2zlbp/MlZj0J9KqsOOOR9av3duUxzg59KqPHjPfpmu WW56MNEVX5ya2PC1wsOq2284U/IT/vDFY0jfkDUe87lI654x2qTU9baAkZz+JPBoEBHXPpXm32+4 6ea57feNOS/uARieQfRjSsHMekGIAYHccimqm08/zrgbXULiK6ileWRgHBIZieB1r6B/4VteTRrL FMrI6hlI7gjNTL3dy4+8efbQfp9KTHAFehf8Kyvum+lHwwvv+ev9ajniacrPPRHuXkgDpk1x/iS9 N3M0EWBDEccfxH1r034j+FLjwz4caWW7RbidhHDGfvNz8xH0FeMzOVJD8sOM1S12JehZ8PwbZZXA wo4H1rcKDbkEEk1V0O3WCyLg8ykvV7B9OtdlKNonmYid5kBj5xx7VnXh2uQT9cVsqFPP+RXM6hIR eSbTxRUHQeo1x/EBz29KuaHIItWgJztPyHHvWU8r7eWbHUCq7XEqurBipyDnpXO0ddz1TZ04z2pP LBbiuDg8Q38f3Lgj1+UH+dS/8JFqMijdcYA4+VQKnlZfMdv5fTP14p2BnBB/GuV8KXVzqHirTLNp 2Iu51gKsflBbpj8cV7X/AMKz1TAyQMVMmo7lx97Y8/2L2FA7giu//wCFZan2YGlX4Zan3dan2kS+ VnnOoTJZWclxI3yr29T2Fec6jdXN1cF5JpN+f4XOB9K9G+L+jTeHptPsbo7jKhnIHYZ2jP615kcE kD5R2qt9SbF3Qbua21GAvPMY2YIylyQQTiu11hAsSKSfvZFefD5QOfxFdFpV3PfGQ3EzSsABz2H0 rSmrswrTUYlrHTP4U2ROIz1Ayxx9KtmHC00R4Hb6YrrseZzFRUz7VXvhgAHtWmq/MPlzXN6ozm8l KnIzgVE1oa0X7xJbr/pMbc8MDwe9d2I2dQ3TcM8V5a8si7gGOa0IdVulgVVuZsDtu4FczR3qR6GI SPWjyeenNcCuqXXe5l46DdU+mavfJqtriWSUSypCyOcghiF/rSsVc7XyiG5pVU7uO1d2fh1rGc7V /I0R/DrVjn5VFRzI15WeS+MLzybcWKMPMmGX9l/+vXESRgMa7L4kaRc6P4uvra5IMqrFkYxgFAa4 9xgk+tO4jX8Iypb6zHG/3LhWj9t3Uf1/Ou+8vHQAHpXl9ixa/stuFcXEe09MHcK9q8feHtV8J6KL +ZIyr3CwjOcAnJ/kDQJmL5efXFUtViJs246njmsdfEdz0wg4/u0+LVp76QQy42dRjitIrUwqy90h KsDg/jTSh9uvSrhUY5z1xTNoHY4P6V22PKIo0C54GPWtfTIwUcAd+KzpPkhdgvQZxWNaa7cxX0rx kENgbSOOK56y1O7DP3TthEVb8fypfLOfu/L9a52HxTO2d8Mf4DFLJ4olGNsERP4isLHZdHRCLOM0 97dDnKjpnpWv4O0DVfE2hx6na26iGR3Qc5+6cH9am8YeE9a0bwrqepeUB5EWcj+HLBc/rUNrYu3U 8v1rXJEuHSwESxqxXcUDFqq2fiC7jnQ3QieHd84EYUgeoIqgwznd2pmO386APS0hiYKy4KsMhvUU 7yATkfrU/wAN9J1TxH4daS0gLrbTG3LsOuACP0NdJd+DNYtrK4uJbYhYY2kPpwKLodmci0JJGOB3 4pyo2PX6VzieKZtoHkxk4707/hKZF/5Yxe1WkzPmRuXiGO2Zydp6c1z0kee3OfoDVHXtfkvEQbRG q8gA/rV7TpTcWaseWA61tSWpzYiXukTLgbcfjTlQ43HOM1aaNST64pyx46jp710tHBGWptwJmJOM nHan+X0yP61zv/CUPbfujbKdvGQagbxeyjm1GRnGG/8ArVwyTuetCSaOpVQG5qnrc32LTJ7gJvZR hQfU8CtvQNOvtc0m31GytJWhlBwMdCDg/qDWV8RdH1Cy8PK9zA8CG4UAsMb+DxWZqeWOASSeeSSf qas6Zc/YriOdVyEOWGeo7ioSpx8w60rDC8Ln15oGeo26JLCkkR3JINwIOcineWcY6/1pnguwurrw tYTW9tK0bKwBAJBIYg/qKuaop0qNZL2N4w3QMMbqLhYq7MH0pHiz0z+FYFx4rYSsIIoyoPBbvSw+ KZ2xvgi/MirSM20bTY8uUAgsinIz7VxvH1OM9abrmoi6mWaNfKc53FDjNUbabYoBwfeqSIbNq3+Z emO9WGXp9Kg0UmTd0FackOB6V1Q+E86q7SKCxHzH67T2qTbyN3T2qXymMvGQuKlVAO+O+adiVLU0 ba3VoVJHFZvifbZWKkJmWXIU44X1qWbWRYuIzAZF6nBwawvFGr/2itr5cZSNQ33jzu//AFCuSaaZ 6tOSktDn/wB513c5612vhK5iul+zyKPtEa7gem4VyEIywyDVyznksLqO5gxuQ52+o7iszQ9H8lQe R+FO2A4I/QVMgeaCKURMFkQPgjpmgRuD909emKYiv5WeR0pDF+Jq35Z6svTr2rNfV9PjfaZgccHA PFAFhYcHPX3IpVhz24qqdc00rxPnB7AmmTeIdOS3bY7ltpx8vHtTsK6OO1uXztSmP907Rn2qgpGc 4zSzT+dKzY+8c5pV7AfjxVEM09Lw6uMgd8Vd289B9aoaO26fAP4Vsqh7+ldEFdHnVXaRWVMc7Rnr xT5kb7PLtJyBkVMqZ6/nUyxllIwdpGOKc46CpTtNB4K1BIdSX7XZR3SHGfmIZR6jsf8A9VfQtlHb /ZYntQvlOoZSo6ivnTS7aaKdZo4nKA4BA/SvZ/BF7KIlsp1KjYXTJ6eorzJ7nuweh1OMUZHp+VKx x0puazLF/Sg9fWgD3qpqmq2WlbTeShNwzjrR6A9FdlraaUKfQVh/8JnoXGbsfkamh8WaI+P9OjAP rxV+zl2M/aw7mpfzCy065uGcJ5cbMD744r5u12d7i9leTlnYk44ya9Z8deMLCbRprSycuzuFY9AQ O9eOX88cn3WBbvg966KNNrVnNXqKWiIOu0kZGKfENzDr/WotwwMH0pySc85/xroscrZ0+jtui2g4 xXRaY+y4QA4OQa5HQZf37K2eQAM10kT+WysM8EGtLXicktJHstmS1vGT12jNS96qaLN9ssYnh+bj BwK2IdMuJMfLj615MtHY9+m7xTKW7nilzWxDojH/AFh/KtCHSIEHr9ak1OaVS33QTViKylk+6prq IrSKI/cB/CptoHQCpuOxz8Oju3LZFW49HiBBcZrWHFLn0pXAqx2UUY+VBVhYVxwBRS59KAFC8fjQ f0pA1Gc0gHZpM9c0Y/CigBRnNAOOgpPypc/lSAKOlNyKXPNAxc0Y9aaTyKXPrQAnSjNGaM9cA0AJ 06UqnNGaPSgQufX8KTPNGcj3paADoOKXPHSk/HNJkUDFJFL+ANJR6UDYfhgUv8qTd6j9aTd3oEOP NIB70ZzRQAtKPakzSD16UDFbocmgDA7GkJzRnjk9KAQYzS4pCeeDx60Zz370ALyaMetIc0UDF9KT g96T60UDAn1pD+VH40H86TEM5pMetGfrSjP4UhC9ulNJHHFLmkwaYgxnJNG30oooAG/KkH1pc+uK QDnmgBe4pfrSGl5xxQNCkUhHHNFGQfamAnQUZo60E4oEHHejjNJxmkx6cUAO7UUg/GlzxQAUGkzS Z9aAsLml+lJ1oFAC4zSZ5o70UAGTRmjNJnjigAz6mk/Sgnml+Y9aAFeQRxs5zwM15T408Y3CXRS3 ZkCkjHrXrDAFMMM8c189fEVAvie48vhV42jpXTh4KcrM5MXNwhdFtPGWoIv+uIPpmoLrxfqE0bIZ ztcYYZrly5/SomOfavUVKHY8eWIm9LmkL0N6ZqGW4RsgiqBYjP8AWjd3NaWOe5YZYCRuRc9cUNHa kHMK8/hVfIpCfcZo5Ux88l1JPIs2IDwg1XewsHBHl4+lOznvikJ/L6UuRD9pLuVzoWnFeUJz05p/ 9i6eMERgYqb6elG8jinyoPaS7kP9iachyqc/SkfRrBs4Qg/3s96l3A9yMmlVuKOVB7WXc1fC1yPD 2pQ3ticSR5z75GDXog+J0wXDR5NeS+Zz7U4PkdxWcqEJbo1jiqkdEz1xPig4/wCWXvU6fE85+aI4 Iz1rxsP68c8U4Ofz469qn6rTL+uVO50vizVk17Vnu3PVQoHoBXPmKLnsKg3nt0NNZyTkfWt4xUVZ HLKTk7ssiKMZ9eB1oZIWBU5znHFVN7Y/HrS5K5yc+1U0upKbWxBc6PayMMseOfrVZvD9tIrDzGCs M8VfZj759zTTIRgZxio9nEv2s11MeTwrat0kP1zTf+ETt88THHoK2d5OOcnvTvMb8/QUeyiP29Tu Yy+F4Nv+sI980qeGIR1mJ5rWD85yen5U4sSeeg/Wj2USlXn3MqHw9ED80hYZzXuXhH4hxaZ4f07T 7tGdraFYS5OcgcD9MV5DnnA/Kpd/rUToRkrMuGLqRdz3Jvifp46IT24FKvxPsj0iIx2xXhXmEZ54 FKJTxWf1SBr9fqHT/FLVx4u1yK5jlZIIIRFGnTbzkn8T/KvPW8MB2LGbFbTMT/8ArpNx9TWsaEEZ SxdRjk06OGGJVcHaKfHprtkjkHvUW89TnpVmz1GSLCkAj3rWyRzubbuyObTAkZH3WK8e1YcnhyST OXG716Zraub2SaT09qYJcjDZ/OlKmpDjWlHYwZPCksmQZhzx9KgbwbLyTMPXqK6USsDwTSmU45qP YxLWJmcv/wAIlOF4lB/EZp6eErgKP3q/T+ldGJGOM556804Slafsoj+szMzQNCuNO1qwvt4LWtwk wAOeVYGvqJvH2jyEnzNvOeTXznHIeu7FSfaX6E5FZVMLGbNaeNnDc+hZPHmkRqW3g/iar/8ACxdJ H3W5+hrwAzE9aFlP4VCwUC3mE+xs/GC4HjDxMt5aMFhhtkt0z/Fglifzb9K89/4Ra4zl5E9BjjFd O0hPPT8KaZ+2DWv1eNrGTxkznf8AhFZNq+Y4HfrWxoWiJZwT+bICWbI57YqyXPXcc9KRpG24yapU lHYznXlPcasDSuFjXdzitX+wBwZJQGx0AqLw46ebPJLjZEuR61VuNSluLppVJVc/JzQQ2Whosu5s MoHSsO48HzSzf65ck5rSbUbok/vSB6Cmm7nMgbzGLetDg2OFXlOcuPAuobz5cqEZySTimr4Kuuou AOfTmupbUrnytpcH3IquLmQ8O5654qfYGn1qRz48H3i/dlGfcdataX4Wnt9RtZppcrFMsnTH3Tn+ la4uZOME5z1zR9ofnJJyaPYCeLn0PouP4gaW4JaRfxOKcvxA0oZ+dPzNfOjTn+En8DTWuGB4Y571 n9Tibf2lNLY0Piha/wDCTeMtV1S2kIildNnoQqKv9DXGt4WmPR88dfeuka4bbjJ4460wTFc8sRit fq0TP6/MwIfC0yzxSM4/dsrZHsQf6V7n8cNetfFHg2zstPlR5vtccxAOcAI3+NeW/aG/vH3pBcMD yW4Gcmp+qxvcax87WZzv9gXueAuDwM1d0nQL2OZml2gYxnOa2BfupBB5qVtQk4y/bqBVqglqRLFO SsQHTJAOqmg6cwxkj8KVr6Xr1pPtzlupx71tynNzkOoWE7W7hApOOgPJrkrXw3qMl0Q0XkIf4m5r tlv34OQec9Ke+psy4GBnoR1FZTpczubwxDgrHPjwjdqpKyKfqMU2TwrcL1kzjsF61unUZsj5jg8m lN7I7HdnHbmp9gX9bl2PY/grqlpoXgGz0+8kAmSSVjk4+85IrZ+J2sWepfD3WrO2lUyzxoijrn51 P9K8ES7dfuscZ9acdRn2lSzH6t1rH6kr3ubf2g0rWOVbwzd7jhlwTkDBqGTw5fAn5FzjrmutW7YH dux605b2U5GR9cVo8KiP7QfVHqH7OG3SPDuoQ3kgjkeYME3dTlsn9VH4V61qVxbTaPfJ5isJLeRc fVTXy/b6vcWxIjkKg9dpwaujxbfhCnnOUI29eorB4K7vc3WZK1mjzGbTL5ZCI7ViO2PSoG0/UT96 1cfTBr0H7eoYkhB+FO+3qpJ2g+vvW/sGjB4xNnmk2mX74AtpM5x0rsNE0i6trBQ8ZzjnNb39oRgf KgB6dMZpTqeMfKCKqFNxd2RUrqSsjKa0lX+AjnkUptZe0ZPbpWidQBJ+UZNLHfqBnbwf1rSxgpI4 K9026FxJtgcjrnFVTp10/wB61l9+K9GF8oZsoCDSJdospZUUg9aydG51LFJHt/wLRrT4XaNBeuol AchSeilzgVlftIvDdeCLG0hw873odQgzgKpz/MV59Z+K72zgEUMjLEvRfSq2qeIZ9RVBdEuVHyk9 BXL9UlzXOr6/G1jyeTTr8uQLaZlz1Ck0iWN44+W2kDA8jbXpiX0SgjYCaa12gUZjGPc1p9WkR9eX Y9V/Zvv7Y+BTo10scd7YXEjbZBy0cjF1b82Yfh713XjLw1ofiLSZ01KGF5I4W8qUHDRnGQR+NfPW m6zLp90Z7MlJCu0n2rUbxjqToymY4YYPNZvBybujRZjG1mjyg6HfPI21FHJ6inS+H9QQBsbucdK7 U3BDZBx7UrXeVODn8etdCw77nI8Yux59PoeouvMQ49GqKHS76NlD28mM9QMivQxcMGyPx4qUXp6M q5+lU6NgWLv0OY020niuvL8p1JXoRxW9/Z8gXIB5q2t8Ax+Tt1pDqJDHKr14qlFoylUUnczHidMg qfyq1pGmSX10FXKjucdKnuL4SKMxjNbGh3KvCxhxle9DJ3MTxN4HupGEtpIh4GQTXO3ngvUk06Bm MRkMjcZ+6K7K6127WRhuyFPTHFVJtZuZM7yuPQ9qh0ebU1hinDQ4qXwvfwJlvLP0J5qt/ZN4d0Zt 3yR97tXbrfSN1Ix6VN9t3R4x8386h4c3WO8j33wPa6Pe+DdEnnhg89rOIShh0cKAw/MGtj+ytDDf 6m3/AAr57sfEF3a24ihlKLndjPU1Oviq+6+c478NWLwcr7myzCPY9o8X6ZpEPhPWJIIYhKtq4Qr1 DEYFfI17YXlqrGWF8ZPzbf1r1C48T3k9u0UsrNG3UE5zVB7+OdQksQCnqauGGlBETxsZdDygysPu g8HninFLjbgQyD3x1r0xrTTlUFIU3E9xmnrNbRdI1x2qlTb0JeIijymNJV6RSfiKtxxNtBO4HoQR XoMgtZJMiJeeDxVnydPePLxKD6EVfsGT9cicTptu63ETIMYPpXRCInnBB7cVpTG0G3y0VcdKTzU2 8fjWtODS1OWrUU3dGaVOOnfuOtTRr82OeK0BJHnnGPpSb4y2VxWnLoZqaTILDWo7KTyPJICt8zY6 mvSNBubRNQsLm6JEO75nQ5G0jHP5152whb7yAn6VqafqMcVsYMcZzmvOqYWV9D1qWNilZn0NBpNh dwpNbSebE4yro2QaV9Btg2Azg/WvF9A8aXGkq8UUhMTcgZ6GpZ/H17LKxWQY+tY/Vpm/1+keyLoV sB/rG/MV4l+0BH/ZurWkUL7leFZGBPI5I/pU/wDwnF+Ok3vjNc/4kvv+EguvPvyGfaEBHYCtaeGl GV2ZVcbTlGyPNlvJCxIbvnrTWvZCuGfBHYdq7f8As6wVseUv4ChdMsFyfKXdjvXXySPPdaJwdxdT OCp3FevTrVdZHLgBG47Yr0doLPA/crx6nNNWCzVg4iUHH50/ZsSxETh4IZGPKlMHnIxV2O1OcEEE jPtXZOLd+TGuKiKwBcbAMe1L2bL9vEybG28twQD65FdBDkYyOajjaPA+Uce1SrMpJ9qqMbbmU5qW x638I7qNrOeJzhg2RmvSiw9RjtXzdpmuy6Y++2faxHStqLx3qB/5aAD61xVcNKUro9Ghi4U4KMj3 QEZ4oxg15n4M8S3Wpan5Urds4r0tSQOcmuGpBwdmelSqKpHmQvNKM0lArI1HfzoptFADqKQGimAu KQn6ijNJn1oAXNLkYpvX/wDXSdqAHD8aM4pvPaikA4nNIDzSUd8g0AOyPejOB7U0HHJoz0oCwuc0 78abmkzjrSKHCgn1puevTFBP0pkjsjFAFNzS5oAWjPHSm5oyfWgB3J60dKTmkJ9cigBxo68HFNFB PPH48UADMQuUQsfQUIzY+ddv40ZweKPXPNMaH0nOOKbn0ApRz7Uhig89BS03tR6UAOGe1HPtSZ9q bn2NMQ8njPvRk9sUzJ70uaQxQfXmjv3pAaFNACjjrQOhpMjvQOlICPNA465pMg+9HWpEP/GkyaTv 0p2fwpiEzjpSZwRTunfNJ2oGLkdqQmmk0ZzwaYhf5UufTpSY9RScUDHZFJx6UAgUnUdqAHZx0pOv Wm/nSketAhetHI9ab0HHSjJ9TQA/NBJ/Cm9e9IaAHGjPNM4paYwpfpTRR+dIQ7rRmmg0D60wsOop KTnNAxW4oUntSHrTk60COT8ZeKn0K5WPaCrpketeM+I7xtQ1CW4YY8w54rsPjNLnWoEXqEBrhLn/ AFQz6cCvWwlNKCkeHjKzc3Hoiixx7Z60xjn19elObO7B+nWmn611nA9xpz6cUc80HB45z0pONvb0 +tAxfTOOnNNPvjmlPbA/+tQc9jkUEsToT60hJx64/Sgn5qMFs54qgEbqc+nWg89ce1A4UZ6ik3Z/ /XQAhz0NHXJPWggDoDn1o5Pf60AJyvXNBPzfKcDNJ9BS5OOeKBChjk/zFKW98im/5zSY6elAATjr zil9c/Wk9en8qaQMH1oAU8cdvShm6Dg96QcrkZ/GhsZANMBCcYwcGk5Kjnk+gpSPXntmj+HgmmAu c8/iPekJz3o79BQAcYGKZNhDx1oz6+vQ0Ffb9KRgR1570DQ4nI5P0peuO47032J+lHpgZoC48Hpn 0ozwPTFNxkfWjGM4/nQFxxJ2nPekU4NNOcZJz/SgHA7fjQIdn5eD7cUnA9+xpmM8j1oyRjp17UgF weM8GnEAc9Cf50KevQfhQBnr+QoAN2OvU0cGjt6UnRv5ZoGOGRzjmjnPPI9qQZOARQM++fpQA45A PWkySvU00H86cec0gFz1zjngU5WxjOaZkf1oUcYAA+tMB5J7U3OPSg898/jSEg5zkd6AE7nOcmkJ +XmkBz1/Sk/ACpYiWC5EMMsYyC4qBQFUdcU0p+8LEnFSKfl44xxwalblPYXOGBHf1oOQBn1pD0Oa Ufd56+/atEZ3Exk8frR68cUvptHNNJBJz+GaYrgD6HP40h+XvyfakX736daPu89qAFzj15pQ5PGc 460wNnGOPxpcDr+VAC7+mOnQUme545pMg4yKQkjrjr+dMQ7OeAcZ7A0ucjBHTpTMfMaQnAz3NMBx 7EZFL0IPTntSc4yOlKW5OQPagBWYdh+tJkEc4xSE9cfX1pD2+tIAyPQ4FJuBPQDBxQCCRjt60HkZ OKAF7n365NOBxjp71GvOD3p38I59vrTHcfuye9GQevp2qPJX0pRjb04oBscrfjijdjHsKYP9nt0o 59PrSFckZvX8zScAcYB96Z3A70cheeOaBNjycdMke9C9DjHWmEZ7jOaBxkrx7igRJkbePzoBNMOe 9J1B4HpQMlyBxjvSbsMMduaZ15H/AOqlPGTj25pDHAgAc8ClDY/GmHHH07UY5HPXjBGcUDJd/wB7 I46Hmmqwx1prc49T70oHXIzQMdnB/HinBqhI+meuKcvPuB70BcmVj9PpQW9R79ah6D17UoHTp/Kg CTcD1+n0pNwHXHFMbp/SjHUc9eaAJDKuADTs9+c4zVdhxxwT14p4JwRnPFA7kmRgflUT/L+Hp2pQ ccHNNb8uuc9KVgEkbj+WDWppcz2ttIV6uec/SsU57Yz1zWnFcJLa8khwMYxUSVy4srs5ZnJI570w AEZxS/hijJ49PbvVIkUEDHagH8D3yaWNVLAH6delTi2UkkEj196oRFuGcg9D3pS34evFKybeAe3p 0qJsAA8+uKAFZ8HBP/16a0nqAO2KT+Ec+9IRjnnHagVx+4r93p60bsAAn/61M7dfwoPXoOT1zQJM cTgdcD3NAI7Z4/GkbvxnFHYZHemGg/fxw2eMUu7nk4I469ajyOe/pSYwO/B45pDJSTinKx555qIE ZGc+/anZOeSMYoAl6c5PNCvjByf8KjJ45zQxPXn+goGTbyAfz4NJn5uKiGMexpc8elKwuhLvxkfy p27DA9cCoScDuPwpGPvx16Uxkgbngnk0u4ng5P41HznnrjijGeKLhYkz6ce1KrZH16Ypmf8ACg9Q Mj8ulILDwxCgZ/CgknA9eaYx4HQ49+lLu/zmkMkVsd6ejZPU4qA+x79qcMk/4UrDTJ1bLdQTnvUs cmDznHSqwOF6CpI8lxjOM0Az0n4UgPq5Pov9a9n/ADrxj4S8au/+7xXs2a8fGfxD6DAfwhc0Z9RR 1NHeuQ7hc0Cm4PPNLRcdgFLmkooCwtFNNA696Bi/jRmko3UCsL9KKTOaKkLC5oznpmko9qYrC/lR 1pO1J0+tAxwP50U2jvTAXGKDRSZpAOBpKTIFKTTBi84peaZuzSg5oEO5pOe+DRnOaT8qBimlpv60 YxQMd0Hek9MUmaU0CFpO1IDS0DFGPSjik+tBA9aAFzxRuJFIB60Y6YPFAwPTtSdaD7UGgQ7OP/1U H3FNNBHNFx2H44pv86Tp70lAiPNLn1NMz3peveoEPJ9KN1RjrzS+tMGP3emaTJxTcmj/APXQA9ST 1ozmmcmlPHSgB+abkmm5NGTigBzdeaOKbmk6+tMB2fSlzTOlLQCFzQWzSUnSgB27BpN3NIT7U00C H7vSl3elR/WgUASZozTeneigY/PvTe9JRmgBc4pM0H8KTtQIXNSRtzzUOaehIouJniXxcff4o291 UCuTucBVHtgV0fxOl3+LJgOoAFcvfE7a93Dr92j5vFP96yoe9OSIyt+7B/nUDHHf8av2F4tk6sFD r3BrexzjVsZ9uTE3PTimmwn4/ctt7cV1+n+KLIxBZIQT+FbVn4g03yUVokzn0pDtc81+xTDPyN+V KtnIOo/SvXI7yynibZBGc/7IqWzksCwEtqjAcfdFFx8nmeM/ZJQ3CHNAtn5DA5PpXuW7SF5azX/v gVnXMWlvM7raqFPbbRzofs33PHjC3YdO+Kb5L5+6R+FeorbacZG2269fSpIIdMikLTW67T7UcyJ5 JHlPkseqsR7UzyX2ng/SvU7pNLbPl26Z7HFYzx2iZLRDn2qk0yHGSOGjiyx3dDUcibGwDn8K666+ x4bEajjrjpXKXhAkO3OM46UWBN9SHvSYxkZzx3FML/NkY96DJnPGB2xQWPPvSbTjkcH1pu7aOnvT 4hvIzkDvmiwmxQhPsaVY2PP4jIrrdHk0TyI0uSu8LhiQetaLW2kOP3Ow8djzTRMtrnAeUcc5zRsO 7ofU4rtpLOzB+RB+dRNZ2o+7HyetaKKOdzkcj5Z6/rR5RJ4B9a6o2duT9zH0pPsdu3Vce9PkQvbM 5XyiWwfTmlEJxzXWpY2oP3efehrG3bqPyNHKP2rOQ8k9fSkEZwCeO9dY1lbhs4qNrK1OQAMfWiwv aM5by3ydo4x1oK8ciunNnbr0rO1OCOP/AFZ5z0qWjWMrmM/IPOOOAKCeD1p0hIPIAqFpOeAfzqTQ d3+6OetOIzUQfocjsOlPibLcmgQ9dwH/ANelCnnAPtVuxWNjiU4FbcVjbMoOevvVKNzKU2tjmvLL eoA4pdmewPH511P9mQlepph0yHd978qv2aMvbtHNeUynB6etOMZOCM9OcV0y6dD/AA9Pel/suIg/ Nx7Cl7ND9uzlfL4PH4UeU3HH4V1a6bAPSk/s2Lb1yfXvRyIPbM5XYxxnP+FLgjjBNdSNNgyOcmkf ToB7dzzQoD9s+hyuMnGD+VDJxzx/WumaxtTk4Gf5VXu7SFYWOQT9aTiVGpfc57JHH4Uxjknk8del SSghyAQMdqr7v1rJqxvB3DP7zGeMZqRT7gcc1AX2+uTUqOMdjSQ5DwAflH4U7yz7+hp9qwLgtjrW 7a28Em07h65rVI55yOf8lv7ppVh+Tn9e1dUNOiJz1+lL/ZsZPX8DV8hj7Vo5TyuvGR0prQtjvxXW tpUWR/LFN/stOQCAMY6Ucge2OS8tuuPxxQVxjscV1LaUq98/WmnSY+OnuKrkQvas5nyyee3tSLEx dcrgZ6+ldN/ZCDqRihtLQ9Xxj2pcg1W7nNzxbT8ufTpURXIOASa6STTU28tnnjFVn09VB5BPrRyD VbUw/mPp+NKBjGenSrl1F5QwMY61T8xQ3H6VmzeLuNz6fSgehxnvSb+eeeKcHyDng0ihD3z9aQAn nFPVvTpmtW3tFZcA9elNK5EpWMkA596XaQvAzxW+NL67TzTjpXAIq+QydZHOqrE9OP507HC5GM1v /wBlEnB9aU6S7DpjmnyC9sc9tPPGBShMDkY9K320phgEgjHbrTf7JYE4zk9aPZh7YwtuOAOB+tHT hR9RW4NKOeRzmhdKORwDnrR7MXtkYODz0z9KQgjPf2rebSiOgHrg006We+KXIUqhhqpAOfqaX3PT PpWldWnkr06Dg1nMcNjJAzUNWNYu4xv71Azgj3pNygjqKA+Bnk1JY4DgjgjHBpec9vWlz8v9Kngh MhHvTSJk7IiA/DvSgAnjp6etakemMw+bk+lO/spgwwOg5q1Ay9ukzIfjqOKUA9lrXXS27g5PQ5pw 0qTAAzn3p+zF7dGSVGMcYzmmBepwABz16Vrf2Y6vz/8Arp/9mMSMLkd+1Hs2H1hGPg9eo70FTxn0 z9a2G0uQ/dwD780p0p8HAO70pezYe2RjHPtn9aT+MA8cVtf2VJt4X603+y26kZpcjK9qjI5XqOB0 qGQg+5rZnsCM4U46Vj3MRidhj/69S0XGdyIHn278VYtQGjcjjnFVc47dfarFo5Eb7ucnjioaNosf gAZ6mlwflz+VR7x6mnowZxjpQkEpJbj8YOc/j3qRSduVP0q3HYM4HHXnPSrH9luAQG7VqoNmLrJG X15PUimlBzwcj3rXbS5Nvr60DTJASSo9eafsyfboxtnBB69QKTy/r+dbLafIV47jrio5NOcg7QfS jkYvbRMvZxwM+xodeMCtJtPkPIB9+KUafKDjbj60ezYvbIyivOefzpMbRWsdPkPRCR/Omf2dIOoO PT0o5GP2qM5QSeKACCe/frV9rF0wCrA1XnhMedwwPWpasaxkmQex6+ppwXK8EjvwKTcF+tRmUAD0 7VJZNjGM8570N1I9sU1ZR9OvbpTQ4YjBpWHcdxnijGR2JxjNTQxl+evep/sbsvqBxTszNySK2NvY fnSAH39M1aFpJj7vfvQbSReGU/Sq5WT7VFbHoee9HfGT6HBqybSRlwFPXFDWbAfdxjqTRyMXtkVv rj8qccj6+masLayHqDj+dSfY3DdAR70nFlKqmUhnHHP4UuD34q0bVyQNneg2r+lLlY/aIrAEetLG pz2qz9lkznBPHTFNaBl7EfWjlZXOhmePTHNOiwCfrz3ppXB5yaITlipOKVg5j0z4TH/ibHHTbXs3 OK8R+FcgGtY7kZr20txXjY3SofQ5a/3QoNGaaTxTS1cR6JJuo3ZqEvzShqAJc+lG7jvTFYgc0m8Z oAlzxSZxxURb0NLnv1oAeTSU3f6igGkA8HFBb2phPFGaAH5ozTM9aSgZITnjNH1NQsT1pRTES5x6 0mabmkzQBJ0x1pc8VEW9KTdx1oAl/Cjiow1LmgB+R9KMim9qbnHWkA8kdqcDUfB70UwJKM47VHuo zmgCTPtSZ9aZnrSg5HNMB3P0o6dzTS3FJuoAfn1oJ6Uzd6UZoKJCaUmos+lGaQiQ/XFH45qPdSlu OKAHnGKOgqMGjNAEmcdKM5FRknFIc+tADenelJpMcUYApCHZzSZ603NKDmgB31ptLSf0oAN3NLnF J3pdvoKADOaQ0v4UgBFMQfSlpOtFAx3XrSGm9qKAFoo7Ud/WkAZ9OlJR9M0EUwD8KCfQUnNJ09aB CjjrTs0zNGeaAH59aM5pv1o+lAwJz0o5HelFHWgBKlWmbaVTwT1wKESz598fOz+LLvvh8Vz187eZ jPbNbHi6TzPFF4Bk4lIzisO8yW5644NfQ0VaCPmKzvNlZT+PpUsv+rzwoqNQQ3YnPpT5QGi+UnH0 rUxKDytAxdADj9akXWETO5iMdR6VVu+EIOcAZrktQkPmZVieSevWs5vlNacOY7yPxdNbEbXwOQK1 NP8AiAIZP3xyO5PGa8oVpCdwYk9BzSqGAwPx96xdRnSsOu57lB47tJ8DzQOe46VsDVknVTHKuG5H NfO2XU7l6+nWrtrq15FgLK2M5HtS5inSPflmAzzj8aPNQ/fYY+teLx+J9QAXEgPPTHFSf8JTek8n 5u/tT5ifZHsMrIGGHX86qyrv44PHrXk//CSXhUYkIOceuKT/AISW73DBPB781amZuiz0LUSEjIJG DxXO3eBtxkc5PFYEeuXVxMiMcZYZHUCty7Hz5BGO4zWsZXRzzg4PUrNyxxwc0Zzz7cYpv9DwRQAO g5piH9V+vaprc/MDgGogqlc55qWDrxz7U0TIivflk3DnHOCaSHV/LbBJzjsaL3jPAyDyK5bW2dP9 UdozztNEpcqCnDndjso/EDR5IfcMZqzb+LIeBIy+9eVi4kDA7j+dIZW49+cZrL6wzf6mnuezW2v2 U6kh8H0NSLqcUjlYyM9ua8XjuZUbKO47cHFXrbVbiFmKk5PPWrWJJlgE9j15bok9KdJMxI7V51Ze J7iNUEoVlByx9qv/APCVfMOq8dOop/WEZ/UZI7IOWycn86ASOpH41x//AAlKkEleenApqeKMsN4+ X60/bIX1Ro7JmPXisi6k3yNhulZLeKIAMKrH8eBVizuRcRs4Xg89aampbCdGVNXZFPJyQdxqLrgi nSZZsqMCmrn+tDAToevvzUkeN3PXqKjHPNSxc4xn25oW4MtFM24bpxmoYL5oZApkK7s9anmciEED tXK63I8SEg8k8e1VJ8quRCHM7HVx6+YOsmccHPer0Pii1J/e8A/xV5L9pkGeW96Y0znq545znFY/ WDp+opntEOu2k2Ssg9eTVtdSif7rY4ya8QhupVbiQjvyc1qWes3UWfmBG7vTWIRLy/setNenIwOD UYuSejZ9s1wlj4lYRgSYJ6CrieIU2n5DjrnNaKsmYPCSR2AmYZOTSM7MOtco3iOJVOPX60jeJUHX 14NP2sRfVpHWAnn6VSv5duEXvyawP+EpjXOcfSltdTF9NvHRulCqKWwnRcdyW7YiRhwDVTJJIPJz xVi8I83IB9/eqwwB7d6mSLpgwwAR270qkDnseaR+Avf0o+uMVES56K5ftUBjOARmkjvPIlw7AD60 WZO056Vlaq5SN3HUdq1vbUwS5mb66qyLmNgQDnk1dtPECORvx6Zryv8AtSVGKknA7ZpjanMWAzhf as/bnQsE2j2hdYtmYfOvoee9SG/t2AKuGJ54rxP+0JuNrsuPQ4qxb6tcxDhi2Tk5NNYlEPL2ezm4 j2/eBqNrnPIHFeaWniWUZBGFx1FaC+JgRlt3pgdapYiJDwMkdy10SOh/Oq7XDNnk1yH/AAki5wSR +NKPEanGBgep7VSrol4KZ1bSEjrVW6mMaHufSud/4SGMZ7n16U2PVvtj/ISMcVXtE9iXhpQ1Zq3X zR72+vPpWWT2BGc+laFyQbUEjJPP0qgPvev0FQyooQ9TnmlXHcn3oIIHrzmkzgYB+mKRZJFzKOAO cYFXTO8PKkjmq1oNz5A5zTtQYrHnOOOKtOxnKPM7GrDqu0LkjB960IdSjk7qPbNeXTavJE5UYznH NINcl5wccYxS9ujT6jKR6/DPHIM5UDPHNShlP8Q/DmvH0166DDy2bb6E1oWviiWNCrE/jyaX1hCe Akj00uADzTTOB1IrhrLxKrnDtkA8+taP9sRO3DjkdKtVosxeEmjpWuFxx1xUbXAxwOe9c9/bEHZg f+BUraxFyMg8duaftYi+qyNszNuJH0przkL0/OsNdYh34Ljpnr0pk+sQuNkUgo50w9hJFy4m85iC ayZv9YcHn3FW4GG09frVS4wXY45zSZpFWIGPPU59qXdk89qRu3pSA9OfbiszQlU/d4zj1rQhcqis vJFZqffAz+OKvswW3LHpjimtCGr6Gla6kFXDjp61oQ6jC5UE4HevN77VjFcleynseKrjX5RyoAH8 6PbpFfU3LU9bjnjfG1x7c1JkbeuTXkKeIbjPEh69D3q7H4sn3DeW9B6U/rESHgZdD0/cp6kfiaa0 qKfvVw1n4mSXAJI47960E1aMgKHySOMmrVWLMnhZR3On+1IPSm/bFYEgVzf9pwnJ3gYHQml/tSDq rAcdM0/aIn2UjoDdHHA/WmmYk8Vh/wBsQhlywHrg0PrFvghGBOOBRzopUpGleXgjG3qT1xWHqIDR k9Mn8qRZvOl3M2cmlvlwozzj17VD1LStoZ3uMHnOalhyEIzxnI5qE8LwefWpY+N3PPbis3udMdhg wVGR9KsWY/fZ7VXBxz0PQYq3Y8MOTn27U4k1NTTt7toSAMke55rRXURjlccetcvqF8lnJl8de5/l Vb+34tvHB96r2qiQsPKep30N5GygE4PXirCur9DketeaTeItmSu0jtimp4rlQcbvbml7eIPBz6Hp 59jTWOOtefxeLHeQA4XHPXFXbbxEs33nwBVqrEylhZo7B5lHcVCbqPncfcVzx1ON4y28fTvTPt6H HzZHtVqaI9hM6I3qU1rwA5ABFYP22E/x5H86kW+tx1cDB6MaOZC9jI1ZrtUXLdOlZFxN54bPABxV W7u/Pb5W/d496kTDQ4Hcdahs1jFoz5DyeOOvXpUQ+pH1pZ+JGz0H90Ug4PFZs2iLn7wHXFOXPao+ C2cY9+9SRHBHvSQ5bGxZP5O0sOMdK2be5jZcMcVztzIIbUSNzgZrNGvQrtwfrk803NR3IVOU9j0C MxuvY0/aue1eeL4j2ElW6dxU0PjDZjcDj65zVKrETwszvhGnZfwzSEKrZwPSuTi8URS8F9p6Vbj1 oTf6uQdPWr9pEydCa3N8lOny5pd0YAJ2isAXJdc7jk980vn84LZo50Sqcjd8yMY6daTzY+mP0rH+ 0Ar1+pqSOYE/e7+tFyuRmn5ikDAyenSq11PEIyCPmFU7i8SFOvJ9+lZfm+awb16UmWtCS6JPIziq +4gjOPwqxP8AMg+nFVs5fDY/CpY+Y9C+Fr/8T5f938691/hFeCfC9z/bkYx1Br3ojivDx/8AEPpc r1pXA03OKdsNIUrhPTE4zQaNpx60bCRQAfjRSbDRtNAxaMUhBpMGgB2aM47U3ae1LtI60ALnNJmk wTS4b0pAH40UuDRgjtQITFL35owRyRRtyKABgPWhRSbSaTBHNACkUlIBnsadtIoAPalzTdhpyof8 aADv1o6dT1pCppNhHSgBd3/16XNJsY9KQq2aaAdu7cUhNIFNLtNAACc0uabg0u00ALmkzTSDml20 DHZ49qTd0xSc0Ae1MBSe9KG9aYR6ilx6ZpAOz60maMHPPNGD+NACqeTS5poFHQGkA7cM8Umfxpp4 pM/WmMzV8T6YQMTJ+dPTxHpzYPnKeeORXx/Hq1yMkXEvoBnrS/2zesRunlHuW61fszPmPsE+INO7 yr+BpP7f0/8A57IPxr5Aj1i8JyLiXvyGxT01u7QH/SJW9Pm6VXIHMfXY8QWHaZMfWpP+Eg08DmZc n3zXyD/b96UB+1S5x3c5pP7dvCcfaZskZ+9mjkFzH183iDT8f61fzpv/AAkmmAczqPxr5DXWr0KW aeQ89zzSNrV2G4uXC4wcNijkDmPr5fEGmnkXCHPvS/29p5wRMmPc18fx67eJkm4kz2w1P/t6/Kkr O+D33U/ZhzI+vTr2n8YmX86X+3tO/wCeyn6GvkD+3dQ/hu5j9GPNDa3qAOWupcf9dDS9mCkfXv8A b2nZ/wBcv50h8Qadz+9X86+Qxr16SD9qlx/vHmg69fYObqUDpgMaPZj5j68GvafjiZfXrTf7fsAf 9apHsa+RP7dvD/y8SDA4+bqaX+2709bp/f5uaPZi5j67/wCEg0/B/eoPxpv/AAkenDrMuK+Q/wC2 77bk3Ume2G7UNrt3uO+6mHHTceafsgUj68/4SXTB/wAt0/76pT4j03qJR+dfIP8Aa9yFLCdzntu6 VE2s3e3ieU5/2zzR7MOY+vm8S6YP+Wyj8aG8Tabj5ZVP418hf2zdMQftDgegbNJ/a9z1a4l+obr9 afskHMfXf/CUaZ085PzFIfFemD/lspH1r5DfVbg9JpOOgLU1tVuP+e8nHGQx5o9kgcj69/4S3Sz0 mT86aPF2l9p4/wDvqvkH+1LrcV+0SHjnJ7006lMEAaV2I75peyFzn1+3jDSx1nTH1qNvGWmbWCXE e7HHzV8ifb5QvEzA56E1Pp99M15Evmsdzgcn1NVGjqS56HoWuzCfxBNKMAO5PHf0rNujl8HHr1qa bi+AwelUrw7WHOBn1r3IqyR8zN3kwVuvXOadK2U5yB3FV4+Wxk5PQmpLgBUyMn1NUjNmbqB2pyQP euTuxznt0rp9QcGHkcVzN0dzu3GAfWsqp10EQjj8+vrS78ZP8jTCdoJHXNMLkKeB06etcx2CvIRk Z9sUhlYdDj6VG5ye2aaxPqcdeKQEomkPRufX0p4mYMe3qKqqfm/xqQHgdaLhYsC4cEcjHpThdPxn k+tVV69eB15o/HmmBv6DdiS8KyqDnBz6YrrLo5PGBXE+HGzqKqT16muzuW+c9xiuilsceI3RDn14 +lGePQ03Pzdc+3SjPoCPqa1OdC5Ibjpj1q1beq5+o71Uzxx/KrVsvDYNVEiZWvWyzEZHGa5XVSSx 6/SuqvvkJ55NcjqWTKwJPWoq7GmH3M3Gc459Kaz4zkDGKfznINVpHy3HIziuJs9VLQd53zEjGKWO U+9V29uwpY+W6UkyrF1Zzk+v1py3BHUCqy9eMYzSj7vbHvRcVi/BdRj/AFq855we1b/hiXQn1y1/ t2Ty9PDMZiASQNpwOOfvYrm7eEyxFtw+UkEUWdt5y7gwUYJyKVylE9Y1WL4fahp08Hh+eRtRCloQ qSLnHJ6jHTNYGj4SzIGMDpVPRLG2s4bqe2uWa7W3IJZOUJ/u/UZH41b0Zcadweelb4bqcmN2SHyc sevNM4HUgAU52O89M5pMnt0H611nniZxwck9OKkh7DPXpUOenPPXFSREbvxzzQiZF64/1YB9K5HX h1BHQ9q6q4JKqoU8jP1rkta+ZjgHk5wKmpsVRXvHPn5eT9aYJRjp9TUsh4Y5zx2qoDz0NcT3PWit CyHGBgY9aesoUevpVcds9PWl3cf0pFWNTT5YDIPOyo3gdeo716xpOj/Du40y2e81qGO6MYMiGbBD fQ145bwGSB5VdQqEls9auaTok2pSKsTJ8xHUdMnAzUSfmVFeR7MugfDQ/f1qD0yJxUmkfCjT9Y0m C+iuJlWTc6Zb7y7jtPHtiuI8N/D2O41BBql7G9ssgDJCPnKhufpxX0DZ6jbWGI0dVgCBUhHAXHcV z1JtfCzohTi90eN+NfhXJoXh271KO4MiwqHPbA71x/hoAeWCB1xivcvizrMUvgPUY45MF1VWTr3F eG+HiBJGpHQ124OTkryPOzCEY7G3d/exjvVRhjBPA7VZvD+86+1UnOcAfQc13SPLjuKxbocDFNBI HPHpmnEr+NN/h/oKmJVTY0bUfu+ORjOTWNrRHkyHsR6962rM/u+STjisPWsmEk+p4q5bEU/iOOkG Hbj2NR5qaTqcAj196rfn61wyPYjsSZ5rd8Hwabe67b2+tziCzd1DSFtoHPc9hWApz19akhUMx5HT qe1QXHc94Pgv4dZyNdtwP+vsc/rUcXw88JarqdvbaFqUc5ZZJJfInD7QNuPXHWvGbbTZpVwjxLkc 5/l0r034Ri28PrcXt848+5wkZRiCgXqPfOR+VYzXKtGdMWpPVHU/8KXsD1uZfwY1Xvvg5awWVzNF eTDyomk+Yg9Bn+ldQvjOH+C5Vu5DnIPsKuQ+Kknt3SRzHJjDx4GQD6VgqlS5q4Q7HmejeAdEk0L7 Tq+pBLzyfMK+aFAyMjj6Yrg9IVUmmRGDhSVBHcZq94n0G4jdGhZXJj5UPnKrwCPqMcVk6H8sjDoe 1elhm29WebjEuWyR1shHkAN0GPxqiQBz/nFXpeLcA+grPPOQfXsa7WeMgP3s9Pc07PbIx2pvfI+n SkyF5OSfpSKuWrU7ZMc8+1N1YjyX3Dt69qLb/WDPQc1Hq5xGQxwm3nim9iEtUcHeD/Sm4Oc96hZs ZY+nPvU9xzK2OnvVfjoep4Ga4ZbntU/hPYdP+EsFxYW87ax88kSuwXBUZGcdaZe/CjyhClvqQmkk kCAY5Ge9cTpGkeKtRt/O0+2vZ4QuQ0cmeOnr7fpXpfwx8IeIbPVI9S1p5Uihwywu+5m5788YrklJ xV7nZCCl0Mxfg9qKbybvjJ6R54pB8JdWkGY7o8HA3JjFfQ0NzGy71I2+pFTw3Ct91gfpWH1iZt9X p9j5s0n4a3twLtbi/S2kilMYVk5IHerbfC2dYXZNVjyFJ+5noK6P4yeG9futXS90Pe0LDa0cTYYE 968mvrHxPZoW1Bby2jORmWQgdK6YTlJJ8xhKlBO3Kc48x3sNx4JBrR0WQ+d84yOlYw9jWto7bXBP p9K7Kcm2edXgktDsrV8wn0/Wq82GkYtwfrU1mT5JxwfY5qCcgyEHjPPWu7oeS9JERUjOKOcjnp7U E5wMkgCl755zjjJrM0Hrw2elXJ+LVt3OBVJPvcjI9utXJSFtT0wBT6E9TgtXG26fp/LNUSQO4q/r AzO+PrzWRtLHgfrXn1HZnu0I80ScMpPWpdwAxniqQVjnC0/Y+OlZc5t7IuIduCDz2xU32qRRzIaz gj44BPFHz5PBJpqq+gnQXYv/AGtyP9acfXGaVb1gV/ec4wQKztrt/CaXym5yDxT9syPYR7F5759p UuTzxzVnTrh3uRubJPc1jMrKea0tMHlzRkke9a05uTMa1OMY7HcWhG1Sv+NWrxv3Y556VRs/4Cck 9j6Vcn+51ziu9bHjSWpQwSD2465qeMKYHHQ55/Koc5JyQM05MiNvfoRUS3NobEG47ufxFXrE4b8O tUiOee4q5aABhk988U4kT3MfxQOuOfT+tVNF8LavrNqZ7G1aSEcbsYz9Kt+JhumAHAY4Oa+hvhOk SeDbNdqJhQAOK8/FVXT2PXwNNTjqeBf8K78RBSfsnygZPzZxUEPgzVZ4Y5U+zlWXIzIM4NfWaCDG 0sBgnODzXyf40M2h+KL2wBLxwTMI3JPKk5X9MVzU60pux2zoRjqVrrwnqdpbmSRYigOMh81jsskD srEqw9DU76zcuoG8/NxncfzrNuJGaUszHJ5roUn3OeUIvoWftUqncHOf50fb5wMbyM+tUGJ9SaTd kYz+FWpsz9lEvi9m3ZEhPbrUkF3M0q5bPOOTWQJCMfWtC3b94vrmqjNtmc6SSOts3b5c5JxjIrah OI/XArDsc+WPm6Dj1rYtT+7/AJV2xeh5U1qUJuJOAMetRc4HBI6mpbk5kYtwc9M1HgbialjiC8c8 H+lPT72PXvTMYA6+1AOWHGc9cGhAyzrsRbSCFJ44NcVHZ3T8rE7cmu01iQ/2c3Ge45pl8w04pGcu rxq4K8BgRXNXbvoehhIrkOPaznQcxON1R+SwO0ow/Gtq6vwF/wBXjPYvmsue4Zzk4OeOvSsU2dNk RKskbEpuFWYLqeLOOvXPcVV89jhjjrxxmjzm25PPSmm0Q4J7mumr3Cryx60461cbh0z61ivIefm4 /KkWQnGDiqVRkOlHsbg1m4TnPGMdacuuzgBT9OtYoc96GOAO+farVRkOjGx1VncvcAM5Jz+laNuc Y6gViaMf3Y5xn+HHStqFiXVeijvXXB3Wp59aKiy7Lny6rpwQOv61PMcR9+lVVOT9KoxO08C38ema ktzNxGoxmvTR8S9EQbWuY/8AvqvElYDR7nkD5c8V5jcTs7ud3cjr715ONpqUrs+gyupanZH13/ws 7RM4W5iJ9N1A+J2idGuYv++q+QGnfd8rHPseaGuJAfvk8dM9a4fZI9TnPsH/AIWbofa6j496T/hZ uht0uoh/wKvj4Tt0JPPUZ6U5p2YZJLDpyaPZIOc+vx8TtCzgXMRP+9TJPifoY5+0R49mr5DEzEHL OP8AZzQZipzlsn0NHs0HOfXK/FLRDn/SI/xNH/C0dEB5njB96+RTOT6+lO+0OFHzHae1P2aDnPrn /haOiAnM6dcHrSf8LT0PJHnx8Hsa+RxM27knPbmmGVzyS3XHWl7ND5j68HxS0LPMyD8aVviloYwf OQD3avkJpe/JPXOeaPOOPXj1pezDnPrd/i1oQJHnoKb/AMLa0MniePpmvktZz746EZzgUec5A2k9 MYpqmg5z60Pxa0Pp58f503/hbehH/lulfJfmk7Qc4HGcGkLtgDpR7NBzn1o3xc0EH/XJ+WaQ/FvQ /wDnqD7ivkzzT/fP4DFKJgM4PP1o9mg5j6wb4uaIDy4GT3pV+Luhn/lsvsO9fJwmJ9aQSenrS9mg 5z61/wCFvaD3nT0x3py/FzQsjEynNfJKuQQehHpSmQ7jgsf+BUciDmPrj/hbOg4OZlz6ZpP+FsaG RxNGfo1fI/nNngHg9M9KXzs+oIOeDR7NBzH12vxV0LP+uTNKfiroHedOPevkTzzztLdfWk89kYnJ BHGc0cgc59fj4p6Dn/Xoo98inn4oaETjz4v++s18f+cdxIOT7Gk85sj5mC57mjkDnPsEfE7QT1nT 86UfE3w+f+XmM/Rq+PTIRklie49qXzCeCxAPUE4pcg+Y+xj8SNBGCZ4/++qePiJoPe5iA/36+NfO kyOW9ODTvtDDqxB9zmjkDnPskfEPw/jm7jHplsVIvj7QTjbdQn6uK+MTM7DIZs9uaPPcfxHPuM80 cgcx9pf8JxoXe8iHGfvij/hOdCGN15FtPQ7wK+L1urhVx5rqM54/lSreSo2RKcZwcHGaOQOY+0l8 baGf+XyL2+apf+Ew0Zul0n/fQr4oa8cfenbGckFqPtkhGFkYZHY0cg+Y+2k8WaO3H2pCf96pP+Eo 0YL/AMfkQ/4FXxI19P3nkzjH3j0oF9Mq4E75HcMcU+QOY+3R4k0dhxeR59AwNL/wkGlFQRdIB65F fEf2+6AGLiTHs3WpF1S9QcXcyH1V8ZqXAfOMEvzDqWx2pPNU5x16VUVxwOOOnagPge468VvYxuW/ MwBg5570iyYbGecDiqu/PYjsc9aTedwAGOCOvFFguWpJv3oIP6UvmYPBz6iqm7HGOKGc9eBzwAaY FtZufmI4H40CYMec+lU2bqDwOp4oDfLnnp09qLAXGcFh1445o80qD7DaeaqmTnIpGf0OPSgLlpZM rz6fSnM4AyOoPrVIuexAPB+tJncMgjk8UBcuCUq3BP0zQZvmOARx07VTDjPJHr/k0oc9OOvQ0WC5 aE5XHXH86PN+YfXoO9U9+OvHsfWl3njPAoC5daXgYIHem+dngkj8eapeYRyPfIp288EfiOtAXLRl yBnPXOKRn44H61V34IyCOOtNZwBwcA8igVy4JAeB27GlZ+e2faqPmHdndn6UjSk+uM9OlOwFzziC Cc4pTMeOn09aqCTqDzR53zcdueTRYC6r5ORxxSb+xIz3HSqnm59uPrSNL0JPy9cUWAul8dqtaLIW 1e3xxl8VjF2Yf4dK0PDh3a3Z7R/y0HbNXHcibtFnp85/0vocjNZ12QZGLYJq/NzM+7isq5P73p7Z 9a9VbHzkt7j4fvdv/rVNOMrx6ZqCA89T6GppDxgenFMkwNU+YMqnoc4rnn5b0781v6qQCVPytnrW DLwwHH9KxqHZQ0RDN06cdc1WznnPX2qac/KB7fpVc9uPaudnUgOeh9c800g+hyfene4B+gpvTJIF Iqwg4PIzing+nTp1pmQTwadk49cc0BYeOB/WkkPyj9KYMc5okOAOaBmr4VydXQ8/4ZruLrAcgfqK 4vwapfUs9hzxXZXR/enHWumj8Jw4n4yA9iKQjPTBzR0FJnNamAqnrkdKt2/Q+mKqYI5xVy3BKHNU jNlW/P7tjySPQVyF/wAvwc4rqtSA8rB71ydwMs2QSQe9Z1djbDrUpTcRHoTVMtn69Oas3pxGR64q l27etcUj1IbA34/QinRjB4J6dabj2/Gli57CpLsT59f5UZGAeopvTP0/KndOoxx1piJEkeNTtbA+ lT2HmMfkyO9UXYnpUsEzLGEJbjgHOKTLRtXd0TK4LlywGT610+ik/wBmDnkgc9a4vy4FjiY3SNIz H5ADx+ldtpGf7IXOB3FdGG3OLHbIbJ1+nrTedv8A9ekkJJ6DnmgZAOOma6jzhVPr27U+IfPxk9qi yc46etPjHzD/APVTQpPQvXJKov6c9K5DVSRNuJyc8muqumOwZ6AetcjqWPOIJOQetKpsVQ3Mm5AS Nsc1nx59j7VfuR+7bH5VRUfN0rhluetT2JU6Z/lSk+nPem4x6f40cn0NSUkWI5ittIgAx1xWnoOp yWLu8PBIGD6GsTdgHBNTQybffPp3qJI1idiPFE4RHjkaNwTkEcc9896cvi27aV5JpSzY2gjsPT0r nF2XB/1scYIxmQ8rU6w2aKoe9iJAxxxz9elZmiRrXviK5v7Nrd3ZoyOgAAp3hzmWMnnnrWRILUDb ayiQj0Oc1reGcmUDk7feu3Dbnm43Y2bo5kP5VVYgfjx6VYux8/A7/lVX0I65rskeZAQ53YxyOaG6 duOw6UNkyZP90U5QMZIGM1ESqmxetTiE89uaxNcwIzyR24rcsx+5OOcVga82Ywp9etXLYil8SOWm OFY1Vzweo/Grd0MRMAeapde1cEtz2YbDwe35U8SbVIBxuH1qLpnpinDOe9QzVI1jeyMBlu+c0+C6 kG2PzSijqSfu1mr6Y78AVcjtJiucxj2L4rJm0S+dXudhQTuwHCjPT6UDV7jzHcuyuRjrz+dVltCM A3EA3nHLdKf/AGefN+aWI4wchqi5VmaEerStEQdh/hB7/SmaPzMQCD756VktH5R++G5zkH9K09DO JTz7iuzDbnDjV7p1k64h79KobgeBtP0q9MT5XXqKolQPpXoM8UQA9PbpRnrzkYxxxQvqP8Kd+BwT 1pDJrXIb0HeotY/1fHIxyKmt+D6D0qvrTDys4wV6Ch7CgveRxVwMFvrVNj6cfhVy6+bJ7k1VH6Zx XBUPapLRHsfgLxbbaD4dhiRd0xiA4IHcnn861H+IksMDSOQWbOFB3V415xwnmMdw444NTQx3NwFa PfsHqeK43FHcmz161+JisrYBYrywYkDntV6w+JEbz7FSOPJ2qTL39K8a/sq4YEgrt6kk8Ypr6dcD Dg5IIIO7FTyRL5me4WHxJLTESwfOv3hnNUfiR4k03V/CpeByzAHdlcBT0/rXjVxdXSKqXC42nh+5 /Gi6u1fT2SSVyWbIXOR+NOMIp3RLk9jFU/NkAY61r6XkSLkcH1FZAGD7Vq6YSJRkE45r0KW55uJ2 Ozs8+Sff+KoZyC/v2xU9nzDzVefgnuR6V3HjtakIxkDvmlJ6E8DpSZIx784xQ3TjPcdakokU5I75 7D0q/KM2jZz09KzYzjB7+hrQkOLViMAAUdBJanGXkUf2o7+hOTz2rRt7HR5tiPIF7HmsnUZwbl8c gcHiobQGZXwOVPPvXlV9z6LCfCdPLoekRzBYpflIz/rAakHh7T3mUCY7QBk7sVzrb0UfKcjnFOhu XBbA6j0rmOs6G90bSoZhGkxYgZOTisqKxsnnIMgVVJHrVJpWDbm5JGOaq/akWRtvXvnvQB1Ufhy2 aMSLJw3PHOKgk8K5bEU4bd0JX/69Ztj4l+xWhjP7wfwgt0pU8YSI2UVVOd3B/SmrhoQ69oz6c2yQ gSDgjrxVaxUCRc84/lU2rahLql4bqZcblGBUULhHHGcV14fc4MUtDq7PkDDZ4wD0q9eEhQBzxg1m 6Yf3aAdWODWjfj90OgWvTT0PBnuUWOcgYA9KQZIOMjPQ9xQwHA/pRGCOvfjpUS3NYbCHjg49CauW P3+cZx61RwQPmByDmrtkQZOOvT61SM5bmT4gH79G6/MMLXS2PjGTS4ra0tzKwXn5WKgfSua8QH98 gOOv5VRWOd2LQBmI4yK8/FJN6ntYF+6ejx/Eq6hLDyE2EYyz5bPrnFYmteKrbV50kvIEdl6EjOf6 1x9xFdFfnicggjgVn+aV4lUqw4Ax0rkSV9Duk2WtReJp8oqhN+cAdBWZeMDcMEHGAKLiQvGBxjd+ dQuSeTzW8TGSD9PShjjgUmeKaT8vGKZBHk5GBnmtWJfmXBxxWVjDewPNaynCqTxVQ3M6ux0umFfL xz6n8K3bbJQtg49q5/Sc+Tzkn2rdsj+5bOfxrvjseNU0kUp8CQk5z9aj7ZGPWpJs72zg84FRY6E/ TNDJiKSe+MjtT4hlsdieD61FjI7damjyecCgp7E+oRGTTyu7HTmrMt7DqWn2trfGJxEoVWxhlx2B qtqzEaYxGB+lcDLK4nOHYEHsa4sTe56uAinE7LUtLsQyrHKg7cnmok8MJJEZVuV2njjFca80jHJZ iT+tOS/u418uOSQAnOATXJzM9HkXY6YeGB5jqblcqM8Un/CNfICbgDnnNc6t3cKysXmZvU5JpbjV Lp2BZ5cdsg0ueXcPZR7GvdaDIM+XMjkHHTFQHSJoowzshwM4FZi6tcrGACcZ54p51K4mkClzgnpi rVRmcqMSV12MMnjtzTwgKjJ/DNVLl8ydfwqezy0fPPGBmt4SuzlnGyN3R+Mbiw5wDW4i57dKwdKJ PBHHatuNvbFehT2PHxG5fl/1J47Zqpu46kVcmIaE54Pr6CqO/q3vwcVZzo1YR/xK7r12E5ryy5IS Z1HOCRkdK9VgJOl3GASNhryO6bE0h5PPPPHWvOxe57eV/Cw8wcHnFDPwf0x2qAt/nNJu446d64j1 iwz5I4569eBTfMwMhgfaod5IxSFixOeBSsBNvJ3AdOvBzTt/HBxx17iq5Y5/+vRvz/QUWAsCQE4H 5YoaQE/Sq+7HpRvHfrRYZY8w/iDxzSmQ4HbPPNV9x+n1pN5oAsGTnocUGXjtUG446/TijcelAE4k GPbP0pS4A5OKrA57UuT9DjHWiwFgvzxjH1o3/LjPSq+7tgDijcfz/WgCcuce9L5mTjjrxVfnBxz6 57Ubh1HToKLAWWYk8d+tAkHb+dVicjvzQD0ycH6UrAWN5z70bzuHYZxVfdjr27Um47hk/rTsBZZ/ 09+tL5g7/XFV84/lzTQdvQkccdqALIkKn8Dk0hYMeTjnv3qAPj8+9Lux/nNAE+8huCBR5nv/AIVA WyenT360Z4PAB+tFgJt/zcYz60CXn/aPTmoASwAPp+dKxLA9c9aVgLBkPTrjB4ODSeYW69R696rt 2Pv9aMnPf86LATq2CTjg5wM08THaM56461WU9OnBoBA9M07AWvNAPOcD1ppkDDOCSOgz0quWGew4 o3AsM4X1NKw7k7MDk9/WlDhc4HvUAf5iOSM80m/GByOKYrlgS47jnqc0b+evIPGKgVsdO1G49dxz 6UBctBuDxzSNJuBz0I9arbvX9KN54zjrngYpWGWTNnHOVxnmgyAYAP5VUz749zRuB45x7UxFnzOo BOO5PenNJubAIOOnNVBgL3PvmjPHoepoAtbuucetDEFc5z6+1Vd+M4OfTvS7/l6ng0AWl2545/QU ZH9MVVLHuSOfWkLYz370gLbE4X6d6Rm6847daq5z3PHvS5yD3qgLOc7jgY9zQ2CcDj61WJ68/jnF N3erc/WgC2Xyoxj6CgnLDPcetVN/pwKXedxpgWFYYHP/ANalY/w5+marCQ7s5/ClaRitICYvjkH9 acrcdunTPNVfMI6FeKC52kD8cUgLOecljxzSZB5P0HtUAfK/pSGTjFNATBsYBxxSg84qvv45IoL4 5xzTAnVs9v1oDDdxjGMVBuPr+FBcknpnt6UCJww44Oe+DRuLDnHt2qDfz1oDk9COPagCx254GPWt Twl8/iKzGSfm5HrWGWO3HWt3wKd/iWDP8IY/Tirpq8kZV/4bZ6UwBuJDisuf5pCOeOoNaQO6aQjg Hj8azrhiJiG6jk8cV6iPnmJAMMM8AdqmkzyScjqaihPzdgvXg5onlAZgeOOnrVEmBq7/AD4/OsiT luvb0rT1RyZMMQO54rMbJbn8K5Z7noUtiC67AY/+tVXBHLY4qedgHAYe4zTI4pLiTbAhZj0rFs6Y xuRZwcDrTM885wO2etakeg6lIMrbE8gDkVJJ4W1lOfsTEDnIYVPMu5r7OXYx8jnA4x1pd2P5Vor4 d1dskWUmB700+HtXDYNlLx39aXMu4ezl1KXYD3zUch+XjoB3rTHh7WGYYspPamS6BqqqC1jOS3ou RxRzLuHIzX8Awl5Lhv7vb1NdJdff/HJArB8F2l1ZTzCeCWMsONwxzW7PkyNke2K66L9083FK0yEg tkqCQOppuO3+RVqO4CWrxYAz61XbO7mtjnH7gevGPerMWWj4I/AVVAzxjParcX+rxyAPSqRDMvVc rFyT9K5mfqcmuj1liikjoex71zshyeegNZ1DfDoz73/Vdfwqge+fx4q/fjhQOBjnnrVPyw0gUng+ 9cUtz1KexEx9emepNOiPPv0r0Lw94UsLrTImubdjMRy+4jP4VojwTpgUM0UvHVFc81h7SKOlUZNH mIfg96dnnn8q9K/4QzSypIt5gM5A3GmR+C9MccQTD/gZ60e2iH1eR5m7ZyT0xUigiM4A3E46136+ CLZpPnjuQueD6fnVhfA1ljEnnj6kdKTrRGqMjkbTw1qkugw63GLV7BpWiO24USIytjlDgkH2zXYa eoGlrn09aZP4etrFI0j3+UpJGTknJzV5lENuAgO0dq7MLJSPNzBNWuZx+bd9cGkxz6fWhsHoMfWk 9efbFdh5ouMn6dqkRct2qMZB9T9KmtTlznk98GmiZkl9woH51yGoMDNx1znJrrdQP7sAcEDIrj7g HzG3Hvn6VMzTD7mfdHETZ/nWcpIPJ6e9aF8u2Js4xnvUnhvQbzX79beyC+rMzAACuKo0tWetSi2t CgGx2PFLkAEknjtXdt8LdZExUPbBPUyU6P4V6pyZbu2AHOd2TWPtYdzdUpHn7sPXH4VMhzjpxXa3 Hwxv4o98l5bYbgEMetSR/DudVj330IJHOORUurEtU5HKaH4f1nXluzo2nTXxtwhlWHBZQ5OOD1+6 elab/D3xiWLP4cv14Gcp/wDXrqtD8ISaXduo1OJPP2q2CV3AdjzzXS3NnNpr4/tOAZGMkk4/wrPn Rag+p5rceEfEGiWf2rVtHntLYnb5rEEZz0ODxV3wyMSZPGOtbPi2Ymw8lLrz97A7QTj+eKo6BbtG nmNgK3oc13YXU8zHKzLN0csT+lVv89asXJzI3HQ1X6tXdI8mL1GN97nkVIv3ecnPao8neT6GpQfU /lURNJ7F+3H+jnHFc5rmPlweO1dFCP8AR26ciuY1w/vF+UYAzwc1ctiKXxHP3nCH3qiKu3/MJx68 8Vnb8cY6VwT3PZp/CSbuPSndGweR061D5mRipI2XI3BT2rNmyRJPIUhG0ZYnAA5NX1mumZo2tGZt 4RhsOQ3pj1qtbxi61CwiQbDJcRpuz6uBX1JeajO99O/mlo2OQRwc+/FYSlY3jE+Z0m2kZsy//ATk fpUi3B3YayIHOcqRX0jDeS+YQHZeo3L/ABfpTodUkjyMMYw3zOwxg/Q1HMXY+Zbucedb4h8pmGSM EZHtmtfRiPPwec88da9A+N2opJpGh2YOV+0yTdBn7uPr/Efzrz/Rzi4BXJPpXbhe552O2OquP9UO T09KpKcZA9e9W5z+6XBB45qk3/669E8RC5/MUuT2/Ko8+nSjOOmcmgot2vLAe2apa9gQ7Tx3+tW7 X73HH0qpr/KAj0/Oh7Cj8Rx9wQB2/GqueMZOa1oYoGmxcAhcHoe9bC6VoZjQqXJx82WPWvNqzSZ7 tCDkrnKTSkR7mPIFFvczMUXMwJAwFBzzXXyaTpDKqoj4IxwT/hXe6f4gks9NtbXT0tWW3hWFZGiB bAHAyR6VyuaOxQZ4/JDMCVeG6PHI2MaRUnCjy4rzZ3Cq1ey23i2/SZZJGtwV4y0K9PTpUmoeNr14 jDG9uyyDDDyhjHpU8xfKeG3ks6QsJVmEanGXUgfnQr+ZbfNg5HOK9m1rxbc6loE+nXs9t5FwuyVV jUFgf89favPpNN01F8tZV29zv5q4yIlA5UYGM8jNa+m8SIeMntUV5YwJNiGQsoOOtW9PjxKoHYV2 0Xqedik0jq7FgIT69cmoLgncxHrwc1YswPJ6Y9fpUE33m7/0r0Oh43UrnjkZ46UuWx0680NyuBxQ OeMjrjipKH2qGRgDjrWlqChLXCc49azoztYBSau3T7tPcjcTjNPoC3ODvuZ3H1Jqfw3F5v2mTHy7 toPocVVvf9Y5+tdl8M7aLUvD81raW9qNRjuy8jySEF0K8cYxgV5OIPoMJ8JmTQsqh3X/AOvRDako XCEjONtetDwdpL2/lMzrdRr/ABvhWNOi8OaEIpXZLiGSJgjJ5mcn29a4zsPIpLI8ERk+ox0rl3wZ 5do/iIr6B1HQtOg029liUT+XbPIuHIIYAnmvnm1DPBLMSAVGauImU52JYj0qPHIp8oxK3TnmmHOR WhB0+i3olilE0QbYm1SB04qNPlI4/Oo/DZCLd55DIMVIrbsZwD1roobnJivhOo0ggqnU9vpWrd4K ZwO4rI0gjYvNad790V6S2PBnuUGOP59KUHgenT1pGIJpRtCED64qGaw2GHkYJ9sVcsx+9XnnsRxV L179au2TbpcZyKuJnPcx/EoK3CgdM8/rWY13PAc286J2IGK0/EpU3QH3gOTx0rs9F8L+E7vTY5b+ 1uJ7hgCx+1MpzjtjAxXnYrSR7GA+E83/ALcv0TPmxuc7iGFVdS1hrwJ58MJYk/MuQRXrv/CF+BGc o9pqMch5UC8wWPpzmuQ+J2ieF9Js7D+wbe9gvGlxKks29Nmw/wDj24Z/E+1cikeg0cDMQO2TTQQc 4/OkuDgc/X1pu7gc9a3iYyJPcc00j/64pA3fj3xTWbH1x+VMiw3Pzde9a8BOwc9OlY+c8ntWxbjE acds1cNzKrsdFo7EDjnjjiugtTmLOTt71zWkkfMOAM5xXS2x2xkH8K74bHjVtyjPy5BP3T61CeQO Oh64qxcDLk9M1ATnHfimxQ2EXoOOe3vUkWS2fXjkUxcZ7D37GnqeRjjmkNljUkZtNKjH+NcidJmd 2ZAjZ5zXW6qR/Ze4nHb/AOtXKSeYzHEjpjoAcZrhxW56+X7ECWEsYYOEznsabGbiBjuiUg/5zThE xzvmYknrmhUKk5nz6AmuQ9LqW31R4oNkdvGTjqe9Ph1uYJhrSJhngGqCwysCwfI9ajYFOS4z69qQ zbXUBLNlrWPDdqX7UAf+PeP5s5OawppZNgzLt981Clwx6y5A65OaEJj70K1wSOB6VLZDEfAJqvId 3zA5HrU9gcr6c5renucdRaGtpi4kAyeO1b8Sq39a521JBHPP54roLPdtXI7fSvTp7HiYhal6Qf6O AuMYwOKqEAL2+lXWx5POaosMHg4Nao5Wja08brC4X+HYT9K8e1AYvZeRnceenevXdOIWzuP9xs8d sV5BqbFruQnk7j+FedjN0e3lfwshJx0xQDj6dDTS3H/1qTI469a4j1hwP+FL06/zpmQO/Q0meaAJ B9P1pNw5zn2pitzxxRnt0pAPzjGetAP4/U0zd0yecUhOCBjJ6miwyQn8uxpdx/GmAj/61LnvSEOz ntSg4Y4NR54PtQD6fXAoGPB6/wBaM9MEn8KZuzQG/L0HanoA/wBeo9KPT+lRhiRk/lS8kH+lDAfn n/GjNR8ZAJpcgcUgHZyfxpScjrjB4pmenb0oye3pz70APye3+NBPp6U3dz7UmfWgB+eKM8D0NRls kfnTs59KAHA9uTSg455H9Kj3cdDmlU/ofyp2Afn8/U0Z5zyPoaYD3/Cjd3/CgB/Wk479M01SOnI7 UbvQ59eKQDvp+VOHPrUZPHpnpRkccfjQA/dx9T1FGcZ3U3PTjJIoB9APxoAeGwMgY469aAc8enHN Mzzyec/lS5z1PXjmgB/GMnd+VAPQ+2MA5pinBHHP1pOnfvjHSmA4k9vypQ2fTr09aj7jr6cmhTjP OKQiXOehz26U3PORkL7UhY8/TjmkbjpkjPWgZp/2VI+cOCMevU0n9lP3kAPQjPStQYHocc896Td0 IPGenrQMzV0t+P3icdSKWTS3wuDk/TFaWTzk/XjrQ2Tk84x3NAGZ/ZTuT8wXuOaadKk55XjoSc1p g7Rx0A6AUbjjtjt70CsZf9lS46j6nvS/2XJgfPHnHQVqZwOpI9jTd2OuM+g70AZp0tt2CcA0i6XI ehU4OOtaatgDHpQW6H8CaAZmf2W+D84A/PFH9lSEZUqeccnrWoeMY9elGQOpyOvpQBmDSmKkHA57 Gk/suTOcpjtg9a0+vHU/WkIzyR+VAGX/AGXN6gt2waDpr9fXng1p7u/IwOuaUtg5H06UwMsaY4A+ 6T2pv9my9ipPYVrF8Lzwe5FLnJPJFIDIGmzZ7deOaUadKccrWqSDnnFGSOAwHvnimBkNpswBxt/E 0v8AZsxPGOvc4rV3Yxg4J5FLyGyPyNAGP/Z82cZA7Uv9mTknLDj9a1m59OnPegt0OeMUIDJOmTZ7 YxzzSjTZdzDI29iDmtXd/gTmm9VGAO5xQBlf2dIOHK8dvSuh8BWJi1wyNtO2Mgf5/KqWeozn046V 0/giJZbi4ckbo48itaXxowxD/ds6BOfMzxWbIcs2Sc96vpwknfJqg4+YkV6aPnmPhGDx696Lzpk8 H3otx7c96S8IXcWOeOlNiW5zN4d8rd+1U5AcEDgZ64qeY/vG+uTzURz0GeOa5Zno01oZ9xgTc1r+ H7eSW4PksoHQfNisO6OGY8VseHlyrZbb3GDiuWpoj0KC1Othhv44iAc89A2cUrSapGxBMjnqADms 5450kUK8mDzw9DXl3Hn99IpAIwec1yXPRsaCT6ihy6SsvpjNNh1K5bcw3lVHy/LnFUV1W9U7vMDc YK7afBq81qhRNpDHPK5ouFu5bfVrxed+McHK4xUUmt3SrjeffjpTI9cmVsyQxkmp/wC3lcgPaQt+ HehNhoJpd9Ld3EhkOQB1xinTf6w9OTnmpLW7+1s58hIwB/CKikOCG6qSe1ethvgR89j/AOKyNj8w 45zSeoxyaDwCOnvSZP8Anmug4h+7DZGevSr6ZERzgcdjms7p7nOetaCsRESRx25pkM5/Wyx6nOOh rDPXkZFbGsMMjPHPSskjCn61lUOqgtDM1EkOnFVlxvBJ5qzqHDqM9+lMs0DXKAjnPftXHM9Omtj1 TSCyabAQJd20ZAHXirS3E6sSpmI9NuRVezuZLOxjVZcAKCMjNakd5vjU/ahg+3euCW56kdir594F wBJzyMrTlu7oniNsYGcjFSNOm7LXJwO4FSedA3W5yv0qRkH2m8YjIPtUitctjcpOPfFPWW3IISYU kcsDZ8yUjA9etJoDO1iOdbUS+XlQw5zk81Tkc/Z/m/H2rT1y5hjs0RZCSWB61myc2444616eBWh4 mablHG09sUnTHTOetI33uc/hR6Dn3z1r0DyQ69eeck1Pb/e6c9qr5y3Hfip7fdu9OeaaJkGrjELE r2wa5GZuT0x2NdZrbBYW3HPGPxrk34b2/lUTNqCKGo/6pQCPvcAmt/4evNHPK0RKnuR3rB1JQI1I 6e3etzwIWWeVE4cpuDe2f/r15+Ifus9jDLVHoST35H+tbBGME1HL9sUlC43E8c8VMhmVPnI6ccVA ZLlnHtxkDpXnHpWLcJfy9r4cZ70/zFU+WACOvHaqKx3R3AyZ54A4pqwXAbOTnHBJ70BqXZIo3fe6 KSO5H5VDNFFJhivzYpEjuSSC3y46E0jQ3Hln5kBPvTQGL4sRY7WPai9cjtiotEx5AVTnv1pviSG4 jWE3Dh13EU7RwVVulerg9jw8werG3gPnHjvUQ6qfzqW6LeYf15qJf09a75Hk002xhP7xsHvUi+x/ SoI23MSfyNTK4HP/ANepjuXU0RoR5MLYPG3muV1c/viC3T0rp4Ti3c9M81y2qljO2SOaqewqGsjJ cKFy3Iz0rZhn0KPTo5ZLVC/RlC5b61jzLhM4PWogkTuQM5PFeXX3Pdwy0OvhsdDvoFlhWJG7jgHN K+iWKMGSGFoz29a5T7OY1wjbOOanW4niQBZiFXn72KwOvQ6WOytba6guI7RN8Mqyrz3ByP5V1Unj G5lbdNDjA6rxmvNF12dTlsPz61BJq08+4KSueeD0qWmB6j/wsOFCQ6lGxxnsfrSf8LAtJZC0jOcL kAk8/pXkUrM7ncS3HfvTUJXJz29aOULnonjPXtN8RW9qzcXUJJVhx16isHS4QtwhXA6GuZUukygH qfWuq0k7ZVwASR9cV24bsefjNrm/MSEB74qm3TjPoc1dvPujsMYIqgT83se1eizwxCBt7j8Kav4e 3FOOT06Y5xSAHJ4x3pDLdko35GCcVR8RnEYJ6jp6c1esziQn9az/ABE2VO0gcCiWw4L3jn0ka3be oB9QRWhHrziMKIF49WqvZRW81xtuW2p7Vvx6LoxjL+e3B6lug9OleRX3PosL8Jl/23csvyxIuffN Oi1O73HayruOTgVtfYtFSNSznA43E44/Ko2/saM4jfPp8xrA6jMuLid1XMxweeOMVUVJd/8ArWwf frW00mjhQkjAAnGSxFNlksYmBtvmVuAwOf1pAZLW6O2ZJSM8E1G1vCvKFm7dKvyOBkFAcjjJp8Mh SLCxAk4+Yk1SBmHNEFJ255PFWbM4ZfrzinX3zNjYFOeDmlswAyA4/Ou3DnnYo6m1wIAcfjVO6HJz j61ds/8Aj3A7Dis6Y/vCK9NbHhS3GZx1A79O1KpIx1+tNPHp6UmT3OKkZOjdMn9atXh/0GQc5x09 az1yHB4NXbnJsG6Dim9hRfvHD3g+d/Y9PSvQ/guXttK1C4GZFa5ClMDAwvUH8a8+usmRs9c+tavh nV76zs5LS2LeWJGkx6E4z/KvKxG59Fhdj2Se8jd2kMhck/MCuOlU7i8WRyYgDuPzMRx+dectql65 3Nlj2I9Ksw61fJHsyAg5xjpXHynVc9BhV7qCezj2oZUP+sBIZscDivn+2XbHOuAvJGOvSvRYfEup QMgjuHVx8yuMZHpjNedMXO/d94sxY4755q46A2UHPzkiox97g+9SPwx7GmZ5/WtDM3tBkEdrcZUE kAZ9KkXG4e/pUXh0qbe6VjjgEfkalVScetb0NzmxXwnS6IcqOQcH8a1b7iMD37VkaGdwVduCDn0r X1L/AFYxwSetelHY8KfxGdyPvdfrSn+Lr6Cg/wCfrTF7A8461Ei4bDsDt9RVzT0DzYJ6c1R7cHH4 1d09R5mcfrVRJmZ3iZFW8GepGKmsfEsVlCI2QsQuOD0qv4mybpcA9K5W4DiZip47e1edildns4F+ 6dzN4ps2AP2aTeMNkjrTL3XtMv1Rby23qpBAZRxXELJcAFeDzio2aQZ3nI9K5LHoHZ3Enh8mPNmq gg4BFUzqPh+OUj7ACBxnaK5qTcRHvJIwdo9Kh8lnBO047UWA6trnww8ZK2x3Z4GDWX52lSSXWIiC UIjzWYtlIw3BCR64p0NuR8zJ9OOtVEmSViu8agkrxWjaqGhjwe3eqUo4Pb05rSsFzAuccD8a6qe5 xVdjW0j5ZRux0wQRmumt/wDV/WuX0zImX5sAeldRAPlPTp0xXfDY8estSlcDEjZI6/kKi6dMZqWf Bc89ODmoM59OvPtVMhOw4c89duPapUz3HfrUGcD5s+vPrTkbn5Rj/GpGyfWTjSSuO/WuNmLF889K 6/WgTpRAbODxWz4R+HMXiHShdy6jNHKyb0RIgecE4PPPbmuLFq2rPWy/Y8skbALf1rPMhJJBIPXN XVjaW2kc4IB2ke9UWUg4I4rjSPSuAmkVTtdlHcA0zzXLbixz060h/CkVdzAc0xJku8sRkk47ZpyI W6LxW7BoiC1Vi+WP8IqJrPB/h47jrRoDKloJECxlRhj+VXYMpkZPXnikjtirKSScUpysjA5HPQmt Ke5jVWhehzuyozxXRWjADPUAdMVzNseB1H866Cz5iXk9BkZr1Kex4WI3NVyvlZYDFU2PzZUYPNXH y0GcZ4qiwwQefbmtTlNjTcNZz57RkcfSvHdT4vp885cnPrXsmnvts5yMf6s4/KvGdSXF7Nj+8R9K 8/Gbo9jKtmV/Yc0Z9RTc4pWOcY/IVwnsC9M/40dKbux9T70Z9v8A61Ah272o/kPUU3d6Y/CgN+FA DselH/6+tN3enajP+RQMdnB49KM+gpOcdKCeSPegQvvSnI65zTd386TcKQxwPYeuaXk9vembu9AO aAH9evcY4oPv/OmZHtx70uc0AOzjI6GgHsM03OD9KXPGaQC9ufWlHQ9BTM469+cZpc/T8DQAuPT0 7UdOvpTf8mjPpj86AHZxyKX8T6VHkA9Cf6UueOaAHcfj60oJB9eKYCODxmk3GgCTdx0/pRzj/Jpm flyMcdM0pI9QKYDwcNnB+tB5/lTN2OlJu9cc+lICRemB3o/pURfPrg9OaXeAKAHj7owPxo5Hv9aZ uyOppc+n6mgBx4x2+lKODn8u2KZnr056UBsdRgGgB/OOPzo68jp04phOduAfTrRnOP8AGgB+fcfn S5yOAOO/rTM854B9qFP4mkA8c8Y680E4ByeM9KZnBHTigNgcUwOpUhsbPmOPWgDjjHpR/dwMkDv3 oPzMeDj0NIYAbgSDkHA68UfQAHoQaBjPP6UflwKQCdO31oyM8enrTeQPXPandfQ5H0qgFUc5Yc5y R6Ui/L2Bb6UmCQRgYpWX5s8nBzigQMQB2GOlIQOcYPrQDznbgdTzRnCgHGT6mgBDgnJHPqaXA5yc c8cUZBxnJ70mfzxyOtAABxwMn260HCjJ9fXml6jjr0zimjqR0GeKYCn3BpO/Jx68Udzn/wDVSqew 59D1FACHlfSgjI9D060nfp+XNJkYGcjvSAVj1GO/JFKScDOMH1ppOORwc5pMjbxznnI6UAOz7ULj gD+dJuzg55o5744pgGOe340HoTwe2aXPzcdM9MUDIJ9frQAH/wDVzQMjqeR3oxnHPbikweMYxQAN k9+OtdP4IyHu2IwNuOtcuRj06V1XggAR3rd8DNbUfiRzYp/u2bMhxGcdzxVJmBZiT34960JNr2gZ euazScqcEDnvXpo8Fk9vz16iq2pgqpIXIxzVm3B/u++c1S1qXYrBe45JoewRV2c/OAzZI+tMjgeT BAz2qQjcoBz0HSta1VI4wFA4HpWDVzuizmbrTbsyvthYqeQQK3/DNnDAzfbrdmBHGO1aaN27Y9Op p/mZUcAHvWUqKkjWGIlB3RdJsy42+YnYZFU7uyglYsJJF9Kfk7eMflR5mfbt0rL6ojb+0JlRtNXH ySnJHpSrpr71IkT6Y5q2JPl5/lRvBxnIxzR9UQLMJdigbCR2J2LnOMdjUDwSxtt8rHpitbdjr2qJ pDxkce1H1VD+vyF0+MxZyADjpmiXO5sin2bZMh6AYqK4f5jg49ea66cORWPNr1faT5mMIz3zk005 3fd6jk+lKD7YxRjJzWhgG3cwU59Kvgf6LjOPXjkVR24PGQRV7kW+cZ44zVEtHLalt85lyT+NUWBz tGefUVdu8NMxOcUtioMhJGf61jPc66TtE57UoZ/OU+W2Bx0os1ZbhGdCWB4GK7UBGI3xq496kAiI G5E4HYVlKmpHRHEOJ2Ph/TtP1PSVkdNjbeQTW/B4d0pbdAFDHud1edwXskEWIyV46A9KmTVLkYHm Nt9M1zPCNnUsfpZo9DHh7StyqY1B6KN/Wpl8NaZt2mBev96vOP7TuMhvOb5T8vPSpV1u+5Hnvt9C an6m+5f19dj0E+HNGtot7xptHUs2a57Vr7wtpx8sxBnXn5QTzXNTatcSLteeQqTkgNxVCYpIS0g3 HnqetUsH3ZLx/ZFG81611a+8qG0MCKxw3qK2LjAt0CA4xWZJHCAuyMKScEr3rUnO2FMZPyjFdtCk qaPNxdb2ruZzjc3z+tJkHnIPPrStnJ+tRkEEnt0roOQlPLccGrNtjdk8c9c1VQgrjJx71ZtyN3P5 etAmVddOFHGM+lc045P+NdHr5IjUDJOe1YMabp1HXPrWczajoZWqZ2IMZAPNb/w5/wBI11LTesXm qUViOBV5ba2ZMNED2Oe9T29vBBIJYowrg5DDgiuadHnVjup4jkadj0tPB0+PnvwwxwQuP60N4Hna ORBqLKGHBA6VyEWtXaLhbh+O2amXXr0Lj7TJ65zXL9Sl3Oz6/HsdPH4HuY4/+Qi27GASKjbwNdeX zqrn1wOTXNN4g1Ax5+1SZ9BxSr4hv+9y+cevIpfU5dw+vwOk/wCEJnVy/wDabnjgMM1mv4antYZZ tQ1NFSMEgD/69Zv9v35Xb9oc/Tis66uXudxnkdmI55zTWDlfUl46LWhzNxqj6hfTR+czxxt8hPpX RaSrLaknA/Ws6SCFEPloB+HSr+if8erqeQD37V6FCnynmYqr7QjuGDOcDGKYqYjzuHXOKdOcOfXs KibI4O4D6VtM5aZBHxnHr+dWFHAxxVePkYPHPFTxj5sdz1pQ3CpqjRhOLUknGAeBXI6h/rmA6Bjz 1zXW5ItGBGB3rlbpQZ8MAQTVTWgqOjMu5Vigx0z2qotvdcEIcdRx2rrobWAx7SoIxzV2OKJRtVQO +MVxTouTuepSxCgrHCF5BnzQQ59ahZ24Xmu9k021lbLxjOKQ6XaEH5R+VZ/V5G312JwkbgDDLjHr VmMw4JOc/XFdj/Y9l02fXmm/2NaAk7MGj6vIPrsTkAsbDOSMcU+CHzITKmSM4rqjotljhPr6VPDY QRQiMBQppfV5D+uRORVP9IDOBgGt7Tf9f9epIqWbSYOoPPUUafGVulAI6963o03F6nJia0ZrQ3r1 sRDj8az89+vtV28+Rdo6etUAc+4HtXazy+oAg+vNHXPPTmkJGePTNC9sZoA0LFAVUj731rJ17/Wf NgnOAK0bXlsg5xzWdr53SDgZ96UtiqfxHPzY2tnGOtbvgmG31Rmtprjy3zkAnHFUbe2EqtuON3FE egRiUSbwrZznJ4rzqlJzZ7NGvGmj01PAkNzDH/pWQOeDT1+HNoJS7SNk9TmsTw3rk+kR+UZGdB2Y 12UXji28tQ8TbiMkDtXO8PNbHUsVTZjt8MbRmz57nnPXNWU+G9uMAySEVfh8ZWsdwG5KHjOK2F+I GnBQPLb64qfYVC/rFLuctcfDOAMhFxIgHOM1R1DwVa2kDf6XtYDO48k11HiLxxbXVkVtQyPjHTGK 8w1iW81FtxuJVH90Pg044apLcmeKpo4rVL5o9QMBYYRsZ9a07QFtmMYz19Krv4aYz72fnrWhFClv tRsk9a7aVJxepxVqsZrQ6TT1MkeT0I6Y71TvIwrkpzn3q5ZNm2GMg9qo3mTJ8x5A7V3HjT3K7Z9+ uR7Uijd7jOBml4wMdKVRjpzzSAWMc+uOxFW9QH+gNt/EioIMk85wan1BQbA+tN7AtziLjks3cnvV 3Q5o7eF1lb5nkznHb/IqE2rzMdh57VJHplyozkZ6dK86tByeh7lCrGK1NaG5R3xG/A68Yp32iFPv uu7rgmsxNPugCVOPxpDpN3JyBn1Jrm9lI6frEC/cXdsV3vKoI4GK5S8IErhWyCScg9c1sPotwU7H 0qKTQbluAOcelUqM10B14dznZD85qPjNdA3hu5ycnGfao/8AhGbrnB71oqUuxn7eHch0Y7RMcZGM VcRskcHPSrWm6LPbpN5gGXxgU+SxaJBu6961pQcWc+IqRktDU0NsSbsjGOeK2b44T2FY+hq28A4r YvgPK5Geea71seRPczXKsxA/wprMCwxmpCPl6gc55pY485Zjn0qJblwWhCRk57Y61ds3xIu3vx9a qsNrEe9WNOOJwzDjBGaqOxnPcz9eXN2vJYkevArAljYS72jJXPBrqNcjD3SngcccUKu8KCi8Y7cG uHERbeh62EqRjHVnKzQhV4xz0AOKoytkHaCMdq9CjsrOUs0igSHpxT102zJ+ZUI+grk5JHcq0O55 urTFRtR2UdDjipFvn4jK8rwRivVVttLVAghj9BgVF/ZekTAb0VT7cClyS7Fe2h3PNf7QmUbSQBnp jrSx3RZ8KwKkcYr0STQtLwnl4wDyc1k6poduI5fsxUErheKqMH2JdaHc4ids5x+VaFicQKOenGO1 Rtot6MjaH+hq/b2UsFuoZSD34/SumEWclWcbaMs2IHnLhu+a6uzy0QbpXJ2eVcYAz2OK6qyJa3II wc8jpXbDY8mtuU7jiYjOT2qv0bsB69KsXCYc9T+NQP6Hr6DmqIQdicA9xTk4YDtTMHPcfUdKcmC4 GcZ7YzSG0TarzpTbh3616R8OdcsrLRdLd5VXYFWXccZ+YD+Wa861OMPpUiqOmO361gLLdxqixFiF OVXGRmuPGJy0R6eAmorUq+ILaCz1nW7ayx5Ed5MsRzkbAx2/pXMufmPI69cV093BczrLIUJkOScD rWO2j3ZYkIfbiuRRl1R6Dqx7mZkUR48wZOBV+TSbtWGYTk+tNXSrsSY8k4zVcjJ9rHudNZSA2aDK jHGKimePe23G2spba7VdpjfjtmlWC5IyyPnilysr2ke5eZsruz/FxVeRy0sh7Z5zTlhuEAzGwP0p fs827LRn5uBiqhF8xFSceV6k8JwuTz6Adq3tPGY+vSsJQUAyMY9a2tJJB+bIBr1Kex4eINsnMPH4 Y4qjt54575q6RiPt0xVGRiM9+wrU5GbGm/8AHtKeoKHr2rzTULaJryfj5ixyc969K0YDyJhn+HFe fagc30+R/GcV5+Mex7GVbMzGsYSO5PbmkawgzwMcdM1dC465pp6naPp71557JTk0+EN8oGKT+z4+ eSR0q6PYUY/MigCk1hBkcsPTFL9gi5z6dDVv2IGKX1AzTApDT4TnDMPbrR/ZsJGPMbP0xVrH3gSD 7ZpwHfr1xzSAoppiYz5hPfFOOmxHqxHTGKu4BbjP0pNuQT39qAKn9lw9fMPI6Ug0yPB+bHPfvVw4 HPP40vuCT7UAUv7Mj43OTk5zmlOlx7jh2APt0q4Omev05NLg+lAFL+y4m48w00aXHt4c5B5q8PbP HvSHjH045ouBS/stD/GcnjFOGlJ0Ltt9fSrmOBznHTNJ1wcAdqBlT+yoyDiRh6UNpUa4IkOfQirj ccd+4NKSMjvSuBR/sqMj/WH6UHS48jD8DqMVeHO0EDp9KQ+mcUAyiuloSf3mBjgYp39lRhf9Yau9 B6DGaOhxnJzQBQGkxg/NIxHUDFOGkxN/GVwaur97g+vGKOS2MDkc5piKLaTHnif60v8AZceD8+SP SruPmyfwFLzuGD1OPegCh/ZSEAK5/Kj+ykBwZfb0xV3G3vkelJ/D+vIoGU/7JRVG6Qk+uM0HSkxn zCRV7of4emMelAbj9cE9aYFE6UmcmY9sgUf2XGOrnp6Zq78o6bsmgnB5yKkCodJiJP70jsMCmjS4 wvMhz/8AXq6SMHrn36UYX5cbsfWgRS/suM8eaSe2eBS/2VFu4kI9RjNXdxK85PbmjOSx9eDjtRcC idJXnEpx24FKNJiAJMpY/SrwOfbpQWypyW6YyKLgUP7KjPSQinLpcbH/AFhYHjp3q4xA9+MZpCM7 uABnNAyx3yD1HFHc5zkjuc5pqkqOgGBnG7NLnGTyPYHmgBc85Xt2xSFixXORz6daOp9Qfaj2IYnp jGaADBJ9PUjmg7sYOPu9fSgrjpwcdBQDlcj1zzTELuIjyOAT+NJjtwe/0ox3CYyO3rSZ6gc5OOaA D+E5Jz1I9KTPyjPA6Dil5xnHSkGeMHvxQAHk49u1LgYG4cfypoIPXoDSYx1HseelAC9BznNLk4AG B2welIMDIyv59aO/Qg0wFyeOg7U3g+mPUUuTjK/rzTdpwcjPfj0oAXHUijJ9MnvzQRt4P+RQT6de mKQAD3PFB+UdTjpnFI302+hNH16A+tACHv15pWOAcnHOB60gOBxnvxnrS56EY9BTATscn0FKM5GM n09qTPA/PFH8OT0I5570AKe3pS9Oh4z2pufT6YFL0wMc9aAAkFieAe+DXX+DVJ0+5k7nAJz6Z4rj Xx2455rsvCPGizDH3nxW9Be8cWOf7s05GzabxgDnvVD3wOgrSmAFkgOB9fWs0ew+ua9FHiFmH0B9 zz2rL1yTduBxkDI561qWw3Z6DPf0rC1Vh9px1KnimyorUorlnXHrxjmtSDAwoPNUbdWMxMigqpwM HvWnEnzDIA45rA60SqCp5x6n608vjt+Rpv8ADknOeKcOB1yM8cUxMXOPvdT6UA8dvX8KdyOMfUij oufy4oJG54x78fSjIAPH5cYoHI6YB6DFIemO3rQIUtkGo5CNoz1p5PGevGelRSE9x1/OgZNp5URu Ofc4pJDzgflT7H/UyHtn8qa4O/qOnB/nWiMGtSNeG56Z/WnSOC3QZ6c8Uxee545pf4VJ5pgC/Mww eD0NXZmAtiD261TUZYY4z2qe7O21yxGGO38aYmc1dEiQ/NwOtTWHy9vr9arTA7mHHXBzirVmu1Rz 19etYyN4bGghznA96epP4euOlMXO3rjPepM4H0/WhFMepIPPGaXp05z2pF9+frS84JXFMVwI69/a l5C4znnHFJ2H/wCqjPHHPf1oAQ49M5608rnGc1H93BPPOM0SS/KR6HPFArkMhG4Z6Z5rRugdgJyR jnHasuQ/MNw/i6VrXWPLUHHTvVwMqpnlup9qaWG49elKR83TAph4H49aohD4j2I59jVq1GWBGc59 aqR89qt2o+YDNMTKGvf64KPTnmsq1GZlz90DPTpWjrbH7VtHO3qB3qnaEbvmz+FZzNqWxooQOmc1 KpHUngVDHwf161MvbrUo0bH5Bx3pwyBjk/hTfTp+FKDk8dcVSJbDp1wM9KBwOc/4UDvj6daM4OCB 9aBXFGcdSfrTOnTpT88cdfypvqPu4oGiGT3P5Vc0pc28mMZ3c1TlHBIq5pfy2kuOu45zVQ3IqbEM wBc+vpUZcYP6UsmQDjOe9Qtko2CRxinIiBFCWIJPBz6VaVsDBGT+lV4QNvXknk1KrfNjPftUxCex fBxatu9CT3xXMTZabIPBbr6V09w+LFjjjGK5lcNMMAdaqexNJampFxGD3xU0ZOMevWq8fHsP5VYU Dv8A/rrNHQyVTk8cDtUitx+VQj8+OmKdkd+3SmSPOP8A61NJAz6dc0hPvz6UDODgZ7HnpQgDPB5y OtBJK5HNHJ6qfzpvTgdqAEbkHp0x1qnagx3YYcgHFWnJyRVeFv8ASkxzz1qo7ky2Ni/wBhvSswj5 cHJ+gq9dZ745qkck+v4VozmuNGME8+vNPB9utM6HIJFOBOc5PNIotWgO7BBwaztZOZ+QAa0LX/Wc DrzjNZuscXDAjHHWlLYdP4hlpwgyB61dUnA561StB8g5q4v59ueKxOy5Ivck9vWngspBAH0zUeMc E+2cU7nrzTJY5XIGRx7Uhc84NISO+SMUH/PvQIdvJHvik3HIJP1pv8xx60dM0ANZyByfyrPumO/k 4/pWg3Xk4FULxQz8U0N7G5pzKbPAIyDjPrVK6fMuQfr71asTutRkADOenFU7oDzCTx6Vsji6kfT3 yacp9M579801ePr0pyk+vpzQMlTGM5xj0qxenbYnoQRVdeuOuTjrUupHFjwO/GDQ9gS1MWzH71uO vatFGI29ao2oxg/pVxeRzxXPY7VsShjmnBv/ANVRLweMZ9KkUeuRTQrskDNjn60u/wB/bNMH3eAP pS4HemFxwdjnHB+tBY4BJxxTOnTP40jbdx4FAhWfIOev1qjeHcv4561afJzyBVW5XIyc0mBa8Pqs s5B7cmtDUjgcHGD6daydJJS5XHGTzzWtqGdo4+tax2MJ7mWG45xx2pSflwcHsKQnr8uMHpUkUQbk n3pSHAjDfL6c5wKtWZwwxgnNVSuxyuehxzVnTzmcA8iqjsRU3INZOLuLAPTrTEYjgEep74p+sN/p SA4zjpmoUyccc9axludEPhJ0Y9skY/KpTIcfj061Bn1B2+1PH585PNKxY4y8kZBYdOKk3t1/rUWc d+OlKDt+Ydx3osK48vg8EZzyfShpCf8AaB98UzJ/AdaXHXtTsFwLt261XuMOOQelSnAPHHb3qtIN ykdOMZoAqwhQxGcnP510licwbiCMf4Vy8YIlXPrXUWZ/0YjAyOetaQZhV3KVwxLNxx78VB09R71a YB3IPFQzIqt8tMhDB07/AI85qRCC361CvHAxwafGPXjPegZcuv8AjzcngYwBWbC+F46+3etG45sX 9QOuKzIOEGCfTk8iomjajsW0b1xjrz2qRWwBjjj8aq5+YDPH1qRCwXBO41mbEjMOpx9D3pQyg4AH tmo1JK/Q45pcn6/1p2ESbhuztGT1pGZdwHHr0pjdDn8aCMEn+VAhS/TA+vvTWcZztGe3PShvYd+R TGOcA49qdgKN3HumBAP51b03Ctg/QDNQ3PXPpzxU2ngiTHJ9KunuY1Vobj8RgEAccn1rLk9umeOK 0pWAi45x1qgxAbccYz0zWxxs2NIBFvJnJG3IPtXn2pfLfTjIbD4OK9B0l/lbnJYHPNef6sB/aFx9 0fOcEHrXBjeh7GVdSsWyOcZpO4pMZ6YPtSkdMdcelcB7Imcg7T3/ACpcA9unrRwTzzR15wMUAGfS g8E9f8KB0HHHvSdvT0oAM46Ej+lL06+n0o6YJHf8aCMNgUgDHQA4HSjrkgY59KQ8Z7e9KOO59xQA i5POTzyc9aOSOetBwByMjPpml44zn3oGBwOSQD14pO/60ducj0FKWJAz/KgQduaPXA/Ckb2/KlI9 eT3NACEYYZHOOw5pSecED8KQHd689CKXvz16AetAwHGeAPXilOQx29AODSr+WKQZI460gA4555xQ P9k9u3alOec5xSdcZ9OuaAAj/Z4/Wj6Yx69zSDkZGcfWlJGWH6mkAdfx/SkJ+h7YFL0GOvHejPYg mqAQHBzwAe9Gc8nf7dqTI3Z/Cj39vzoAVs8ZYZ7cUnUgn/EUpOV9sflR0Jxyc9SaBCE88LgUcjrt H1PelbO7njHfNHAPBA/GgYLjp1GPWkyF79aM5/AdutL0/pQAZJI69OlHcgDOORR9enr9aOnX8KQB z3/PpQOueBg8n6+1AGOmME84FIcBWxg96Qhzfe7e2KGxtzuP50mDkkYPbB6UnTOB9BnrQApOWOOP T3o5I7E9OTilyQck+gx0prccn884oGTKM4wAeOc+lBBx068+tIwGOc89MnjFIx4xxycjFMB/UDau Fxg8cUmcAnJ/lSLj/H3oOQcnI9eaAFyCAOnamtj5vfv1oye3oOc0m4HknPOAQMZpiHHhv5YoAY9e O9MJ6AEn0peM/lnmgY5csc+nHWjqcjmkJJOG7+lGRt7Y9BxQIXpwTw1JnjB6YyR60KOmPTnikPHU HGexoAUc44B/CkbO7IyPY0dfX8aDnocnoM+tAB6HIPfGKMcDPc0gJ79frRux1x0z60ALyMe4/Kj/ AGs/1prHHPb1x1pdwA569uaAEwcZBIJ4HelI4xz+NISKB3yT7e1MAzzkelKwz9emBTc9Mcc4pMgE AYPbjigB2TjIIyeuKOevXPFMDenenEgc9u4oAcD9PTpQAcc/rSbuSeuKbzyeB649KAHMoxzXbeGV 2+HQ2c7nP4Vw7n044rvPDiEeH4AVOXYnr6104f4jhx79wu6h8tnHn0rMHTOMZrW1dfLto0J6Dmsc HsBhf513I8axaiJWNjnt61zlyXNwzEnk8VvmULbuW4GDmuec7j6j37ilJl01qTWy5J3d+Aa0k5Gc df0qlZr+7yTir6AehHfNQdF2PVcAYzj3xwac3zEA/r60jdG5Ppz3p3c5HTpkfrQINuG/XFGQRwOe tL/u98ijnpx+dAhp/vY59aXj5jzmlb29eTSd8DPfvQA0D/69RyE7fy6VJnb1x+FRSfof0oBk9n/x 6ycdTjFRPznB6e3Sp4uLbJ45xmoMfNg5HPr1rRGLEGTnoPTmhTzx1P401eFwc9evrRweRgdvSgQ9 GIOff0pb9sWOCO1J0PA7VFqzbYFUHqaYramI6gNgA46cjrV2zVmYEj9elVQAW+b+fStOBVXoM56m sTpWxKoxwe3QVKoX6HHFC5PI5OcmnD8OlOwgXjnJo4HbNKRz1xSZwfSmSIwAxwfoaBnGAPpSgZOR +VH8zzTC43j0zkVGwyf0qVufvD/69IeBng59aQFYgOyYAPPc1pXLcgH07VnMMSJgHG6r10Ru44+o 6VcDOoUyOcNnHbim+pPpzxTnY89ePU9KYSC3B47cVRA6Pjp/KrduCWxiqan5cAj8qtwtjA/nQBk6 tzdyDr25qGyh5BOPmpb87rls8596ktTuUD8qiRrT2Lapj8qmjXrj86avQgj3p4Hzc8/WpRQ4Dv70 Y4xxjPWgHjPegep478iquSHbg+3NLg9v1NKFpeQefxouAzb+PPeg57Dj3p5HBwDim8AgkY/CmNEM hIXoPw7VZ03ItH7bmJqvIM57fjU+ngfZCc9Cc85px3IqbEE5I49fwzURGAcjjHpUsuSd55GcVE2F GSuQPTvRImKIocKBxjt1qdF3dG4647VEzK7DyxjPapIxg9/xoiE9i1dMfsL464rAi5m+UDJPJrav mxYnHXt71jW6kT8cjv8AWiYUt7miucDB9iBU6YJ4qGNf09KnX35qEascc7f1FJg5zntSkcEn060o +9x3qhCf8C7d+9IBnkD86djA4xgdcDFJwcjGAOKBAScdD+dJ/npTuxwDignjPIoGQPgA/X86gtx/ pacMMtngVaY8c+nNVFOLhcHAB54oW4nsad4QFX6VTzkDvx3FWp/n9Pwqsw49Mda1ObqJkUKDj29z Sbj6jFHAAHAI60hlq1Hz9fesvUQftPqPX1rShbnrkGsm+Ja6Ocn0FJ7F09yS3JHHbNW0569KghAC gD05qdAP4c1kdA9DjHWnY4/xoXI/+v1pMjqTkd6BXFXHHtTuOvvk0mRnt+VLwfrVCE2496M45HJH 60fypWyW65FA0RNjqOapz4GelXWXHbAqrMCfXPb1oBmjp+fsQI+7VecfMcnrxkdqlsWxbD9ahlJZ jgVqcb3GqSGA4HH50gO1eOgpOx6ClJyvI46/SkMkiIDZIAxzUl9k2Z4J4yagXKjpx1qTUGItRnuM HFDKRnWwO3OMNirfOMg1XtxtXoPT61aXqM9RzWTOlbDwuQCemOKeCB0PsTmjBOecemad9eOKBCem BQTnJzj+lA9adnqelMBrDkZP49TTWHrxxUmP85puAB2HGKAI2xjtiq8y5HXPtVnb1yM5HWo5RhSe M+oFQxoh09cXKEDK555rbv2/ckcVh2WEuFBAPPXpzWreMrR4INax2Oee5n8AYyeRQxIXj9KP4uRn 05xmnCPzI+hGPekyobEY6/j37Vesm/eDOeOlUjyxwPxq1afe/A9KoiW5X1g/6UCB/Dyaao3Lk4o1 Alrs7sZwAM0gJC+49DWb3Omn8JLnjIBNOUf/AKqb2FPx25A6fWhDEA46fhTs8A8YPSmjA6dKccde nvQKwYLHLYzSEk9RTsfNhsnnFJz0HH6UxDTyDj8KhYEgkcHP6VKy/X04pkgHf1zSGjOKnzCF9eld BppJtjgVhTArISuOex4rb0on7KcnOOM1cdjOqMmJSQ569jUDEluR7c1JdH94eD6E+9QE9c59vagh C4G0duOafGMkHB49TTMEZx+vepQQOWwOMc0Aye4/5B78N0yfas2Fvl4wPwrQusNYuMZPXrWbAPly B79eaie5tS2LCn0GOOlPweAMimL93B6VIuCFxwPrUmoAdx0/KnEY69+fSk6DGe3GOaXgrzyBQQB7 56Z60nYc4p3pjnA7mkPA5+lMYzHXI6ds9aOnTP0Bpcndg01h1x+WcUAV7jjpkc0to22ZWBO4fhT5 BlMk++PWqkTYfLAYHGauG5nU2OkbJg4weKznXPbvV/71qhIzx69KpE47Hj161scJr6Ou1TgjgdD9 K4HVF23koJ5D9DxXfaS27ccZyvB9K4TWOL+Qdg+K4MY9j18r0bKRycY60cduuaOvaj+ECvPPaA4P rz7UhPrjp6Up788dh3pM9M9M+lACd+lK2eoP40h9sdaU9epznrigBWxj0/Gk/h7euaT19+KUDmmM Uj298560hPHBoxnn1/Cl7nHGKADHXNJjI7kDgUvXt04pCOPlyCRikAf/AKqX65PsKTOF9velA9B+ tIQnHIOOmM9KOB1wD/KlGccenWjPuMn+dMBMZwO5oYjbg0H8ucjFKQfUDP5UDDoOvTrml4C89PU0 mTx0z3zRn5eSRmpAOuRjBzxQRkE57+lHXgZoBwOc5pgGfm/CkHcYz7UE8cY/Kk5IPueKQDvQEgnu DTQcg9fb1pWwMZyO9Lnvjtx7VQB057n27UA4PXj6UDGePrnpSZPY8UgA+/X68UbRyc+3TNL0XgHG fTrSA5GeeeaAD2CoO570p44GPWkI9c47UgGM5BPPamAZBJPqe9C8dfqaCeccfXNLyeRx7UAJu7gZ b2NOJYDk9KRc8DHHSlHGMHOPUUgEx1zn5aXGFwee4pMkjPBx3NLx6jJ7etAg9cCjBbJ24PvRgk89 PrSMy8ZOB15PWgYH1OMdOaGUdTnnoMUvpxxjAOaTkt6mkBp6Xp0t2rOYXdAQDjrWbej7NeSRjdgH GDwRVfTvEV1p0rNZu0eeuTnNV5dRNzdPNOS8jck5xzTSAt+YTjJP9Ka0rHJP6+tVJrxZOiA9utN+ 0Ln7uOfWmIvCVhwMe/fmlWclOevbFUftYOe3alF0PQ460AXDPn5l9eaPOx26njFUBcqOo9sHvQLl e689OtAGh5pzwOnYmke5JXn/ABqh9pGSOeuKX7Rk9aAL3mkeg9O1AmJ/hzxzVD7SNzZBBA4wetK1 0O4Oc85NMRoCX1wD7cUCY7sc1nR3IA6c460faB34pAaImBwcdelJ5o6/lWf9oBIDdKcLmNcbgTxg 0DLjzHvz6YpRNnsD/WqLXKZ7/wAqcLhDgBicdeeKAL3nHvj/ABphlH1qmbhCOKPPAxg9+gFMC55g 28j9aUSgHGB781S+1Rjv7UC4Tnnk9AaALhkH1555oMvA/oKotOvPP6cUNcjbx2GD70gLwn3Dp7Hm lRy2RwPr2qh9pXb0PTgGpFuU9xQBYkfBIHIz2/nXpvhwKuj2BfBBwQa8na4VhgkAV65o426XYA5w FBx2rqw+55+Pfuod4gO28O04GM1jKOpySK0tectc8DgryKylYBQCcHoeetdiZ5LJLghbds4PHfjN YrL+8wvXtjnFaty2+EqBxngg1QjX5sMfmpSNKZdt8D1AGMrVlOwH86ZCvGB17VKqZ29fY0jUX9Qe 1KQSvv8AWlI46HOc4pcDkMMAdyaZNxuc5B5PUYpcADpz39qXII549PpRjBz3IoC4gBXGB24perDO KXHHoPyxQeCCTj15oAj7c8D2NRt8ydj36VM/XGDwO3aoWIZc9R37AUhD4eLfluc9KiyCffFKpxGO u33NRk/Mc81aZDQvcfzzQOM54HX2pjEHPT+dJ16EAY9KYrE0XPYDHPFRasdygdPenRvhuox61X1C TLkDOPrQIqQoGck8D+ZrSiTpkc1RtE3Sc9OxrURSuSx9+lQbrYTv24PSngYXjj6ilH1zxT/pzTIY zBLcdO1KRjOBS4+bI/SpEjJUnGMdOeaLBciwDxx07Un+TzSt9Rx1xQOM/rQIbj0OPoajcFVGanb7 hz9etRthlOe/f1pjRX++4xyRyM1aunOATnnjFVjkOpH0NPnbAyM9BQiJEDE7Tj0poy3r/hQWoXG7 0FURYmU4HYexqZOcn25wc1VXpgbcVYQjnpjH50DMib5piV6ZOM9auQJtjGe/Xiqjf63DDBz3rQjH 7sZNRI1jsPHXpx1qRQcdse45pY0OOQAT1p+MDg5/GhA2NxjrS8Z5PtRznv0z1pe4/OgkB68c+ppB xjinc/h7GjH4evemMavsc/SmHHrTyMYGKY2N3f0pgRyKWQ8cVJZcWpUnHJqOUHn7uMelLDIRbEEj r2ppGcmI7Ebhzx2qJuYmG7bxjNIz5OGz7Uu4eW4xxt7mkwi+hu6xFYwaLbeTs87AwQOvFYsZDLn2 z7VlrNI4GSWXoBnIFWQ+ANxzgYzTTJcXe5a1JwLXb0OazbI5kPTA7+tWbqQvCVzk+lRWa/Lkdc8Z 70my4aF9eOuORwaevOOO+MUyP1wAR6dqeoJXnJ70i2PzgYOBzyKX6DHtSAc8E+tKp9MZ9aZNwUex NHIz1p3TFAwD/hTC4wjjPQEdQaaal6DpjFMbpzzikIibGCD1qsG/fDPrgjpVp13HPP41UYAS8DvQ DL8jY7n6VWYjBB/Md6JJMYOMY4xUJkwOCQOtXcjlJcg9ulC8A461CHDAkDPvT/Mye34mi4+UsQsA fUjkVm3HzTnGauK49+faqr4aY7RyfU0mxwRYhHHt06dasquMZxUUKg+oGeamA+X0BqbGrEwSQMYp /XIPpgUEYx0pw9AKCLje57gjmhR3Hb0p+M9R9KTq3agdxD16A00+3I9cU/seT600j/ZpgNPGOmcY qtPwoweassTjpiq8x4HsKAuS2THy2/rTZcZweo9qS1kAiPBOCfwqOR9zVVzBx1HOf73Q+1Jn04/w ppOeQfxpAy4z+lFx8hOp+bn9KW+c/ZAoUnsTUStgg/oKbfHdbjA4z60NjSsRwEFRyTz0FW41zkfr Va1X5dxAA7CrigE8E561mbLYcv3c8+9KvTqD/SkC8DGM+/rTsHoCMYzTFcM9TRgHril9cYpMYznr QAue3XIx0xTTz7elIT68c+tKR7j60CGMRkk44HJqMg8jr6ZqQ/XHGKicEgdaVh3Kkfy3A5/i55zW rdN+77VljKz8gg59a0ZjujycdKtbGMtWVVJU4OOeKlz5cOcAcGq69M85zmpJCWhwRx3qWXHYYhzn I5q3Zf6zP41TXr96rVvwR2NWjOSIdQObodR68U1SwGM89RS3R3XRLfzpUAC8Y9Dms3udENIki9yO R+VPPC9+tMGOlSAgdc+/HSiwB3PIPfpSqRt+U/WmjIBxg5HFSdc+mOpphcQ+/PtTTznr6e1O7cce h96Tbg8DH0NAXGnk1G+OenAqVuh/xpsifXnNFgRnT8N1rR0pjscdc1QuxtbJ/Airem42vyO3FVEm ouo+4OCQpxzz3qHcOMk/SlnHz5B78+9MGdvJoM0OZsZAx+dSqfbjOMYqBT3B6jj1qVPXHsKBli4y tsdozzg1RgGF69ODxVyb/jzYA89AapxrhBjB55GKie5pT0RYQYx0Pan49M+1MQZxz+NSevU4H5VJ rcXB/iH5UmPrj2pQOfXHFIOmT3/Wgm4DpkEnA7/yoCjAz0+tKc8dOeenWkI+bkZ47UBcaxwSQO/G aYw79OPwqTcOOhPrTSME8YOOuaYETZbPTPWqrH5j1zVthuJ2n/PtVRg3mYOQDznNVHczlsbkDKbU dTxjpVZs7zkD1HvU1uwNrtGCB2NV5PmYleeOo7VqczRq6Nkvg8Z4571xniAbNVnQdQ3pXa+Hd/nB mAIPTPc1x3iZG/ti4ZiCxbP0rhxmtj08sXvMy/qPwpORxSN7emRQeM8d+ua4D2hSc54Hpz2oPqel I3fPPPFB6HH4UwFBBwQVI9aTtz/+ukPPQY+lLjr/AEpAH+137Y9aPpgH1NA6dM+lKDhfpQAh+nOK XJwPX68UnVQccYpc5U45GM0XATnHfFBGeoxn0NHRuQDj3pFxjP4dKAFb2OPXNLgE8dM0m3jpzzzS scn2/nQAZHf0x06UcE84HPr0oxwccUZ+btg9OeakYZz7GlI+YZ4xScYHp60Hjg5zx3qgFxk9cfh1 o7dcGg0nzdDjHXFAAOnP4YPWlB4x0PfFNx0PINGTk570mArYPIOR2NMJIz344px/D6CkGSeePamA q5weCOeRjBNGOeDx79qB7kE98HihQcYHXOTQIXjgjJNC8diBjPWk/THTilHGMZBx6dKQw4CgBgfe gfrSHBPOeenalAw3GQevXpQA3r1HGM0vAXPQnHOKXnDZBHYYo25wVyfxpgNP3gTkn6Zp4Pr6enWm 55HTHUgH0pxHIP5DNABgHBwcjsDSZxjAJ4xRxnqcn3pFGOeAAOpoAUn8fbPNHYnp6ZpO/bGOBjml 4XgkAY6UhApAJ+UA9jRkbjkfQ/j2pB8xO3r+lAIHUHjnBpDFOME9up5peOSAPTrTcfLwcc+lOxng 46UAYCLhuR24p7Rn+7nA7VsLFGG+UAfTtTVhQr16YxVCMkoy4LDr0IoMbcED8TWsY1IyMY7E9aRo hH2A7nFAGTtYLwvAPBNIAzHJBP41sGJT603yUBHQ8YNAGSUPcE8U1kYdutbHlgADp6ZFAhDYxyfT FAGSoOwHafX60YJ5wcd62PKVVxt2nrxSGFQPl45xj3oEZGCf4c8ZJo+YY+XFarRADjbwPSl8lFA+ vXpTGZHPoM0Y45x71riAY7Dv/nij7OM9uv50gMfad3bjpSYIY9R3rW8lT2A9OKGt8n+HPPB78UxG Tgg9/rRjHUAHrWu0A9BtpPIBH8IpAZHfp7/WlAyflUmtX7Ku3Axx3xmj7PhQDjjjNMDLxyQByaTH PQdPStRbcA54OOc+lP8AIXnOOufXNAzIwcj5QR1penbP0rUMAA/pSeR7fmc0hGZjgkjtilwR2PXH tWibbJIO3ntT/IGSFAxmmBk7TuzjOOvFexeG9R06bS7GD7QolVAuDxg15mLfHX8s1e0iF5dSgVOC HB+tbUp8rObE0lUjr0PUdS01LidC7kbVxkelVDokIO4T8dQDUl4sgVUDEYAHBqmqyEMdpI9Ca7Yp 2PFbQ6fSInGFkwfzzUP9gqrb/PyPQCpUV16gnnnHNS/vSACG6dcU7MakH9loFLJKeBjpQllyfnHH Tio8yk8bhzx6VNGHYnrjPX1osx86F+wBlBDnPX0pDp+3o+ecYz2pG3iTkE4zzmkaSUn7x46Zo5WH OhVgQN1yc80rWWcYemFn64P4UAynJTOTwDT5Rc6JhZK0fLEGoWsSNp3LnPSgMwHG7NDySYwM88da OVi9ohFssE5YE554qNtPbGSw8v8AWnZk77gRyKYWkcFtx9PapcWWpxIZrNSvyMR7npTY7AuT+8wK eY35AJzSKJV559CTRZhzREbThgjzPpmlj0xX5M23HahUlyVOeT1FKyMOoYegotIXNEjXTn37QVPv SyaJPcL+7Zcg8ZqTdIvOSHPvT4Z5kYkM3r1q0mRKURlpoUsagTOqnPOK6qx8I291ZiX7Y4I6AAH8 6537ZM/3zkdMUC7uFUhJnC+ininyNi9skas3h5I5wqXG4bsHipLnw2iXGxLkbcZGRzWOZ5QMGR2J 9Tmm/aZs/wCtkGOM56U+RkusjX/4R07WKz9PaoodEdpGRZlUdeRms9by4TjzZOeTzTfts4Y4kbOP zp8ge2RZn0mVZGQOh9PeibRnVR5bqTjvxzUAuJh83mHPck0i3U4IPmsTijkYe1Q9tLuivKqOMdah k0yUYyoz9elTtqNxtJ3/AKdKY19O21icY9DS5WUqkSlLZTrIPlAx7imSWNw7fdHPvVqS5kc4OARU bXMhYsv06UrMfNFlWPSbhuWccdak/sm4UArtIz/e4qTzZOzEZPpUgupsbd4HPXFKzE2ir/ZtynDB Twe/alS1mEZJGPqanW6uH4bkjvilM7kAPx6UWYJx6mS1jObkMEPIwcHPNaEVpOxwEPBxViOcr8v5 fWp7W5bzVBXvyadmPniupGNOuTkiE5o/s24HGxj/ALv9a07u+ktJwoUFSM5IqBdUl5+Vc+1NRYnU jsVDpt3hf3JA6ctTf7PuA3ERPGatvqs+MMATjsMU6HVZI3HmRgjoxz/KjlZPtI9yn9huOP3R+lB0 +6ByIWyfzq5cao7SZQAexpiatMrEFVOeafIxupFFI6feBuYGGP1ppsboceQwHvxWn/acmdxRTnrz SNqcjLyo68d6OSRPtUZc1ncrgGBxnpxxSwaTeSQnEZU9twxWtHqrc70+UVDNqs5GEUdc0rS7Fc0W jJ/sW9XC+S2TzyRT/wCwbwQlpFK5HTjirsmrXRwcIDjjvmh9WuSQrAYboalpscZJM5uSxmjmMYBy vXHFPW0lLDcDkj1rZn3M2849/eo9xLdOKcYMJzS1ZlSW8vl8Ic9Kfaxsq42cd+K1Mncd34e1OViE xs24q+Qy9siosZI5UipfJfoR71ZLlskjn0oDnIHGO9PkD26KojbptPHt1p3lNjkEe1WfMHUHj+VO MijI4JHv1o5CfbFTaQQNp+lCqQfmXB/lVhmPVRikD9eMetPkF7cgZSAcA0wg7Pun8Kt7wSeMDHHP WhZvlA+7z0o5GNV11M91Ydm9agkRjJ904rUkZS2McGouGU4HPvUuLRaqxexlTL2wfaogCByv4Vr7 VJIIJHpUPyqw4wKmzKU4rcy/mHTO3qTmjLZJIOAOBjpWuNmei4PNP3Jx8mPWnZh7SJkxhsgkMM9P pTWVvO6ZFao2bgdvzHpUkZXoBj1xRZj9pHuV1GBwPwqTG3Bxj61Zj2eYM/d71ZYx7hs474p8rD2s WUAhHBH6U4d+D+VXPMXHP5elKsgJ4GDT5WS6sUUsYzx0OMZpByfXHFXmZGHOOfamkRkNkDOKfIyf bIp4/EnpzTTxnggVbJwwIGCKjJGc9x60uQaqxZWZTtyevSq1x9w/1rQIGBnBpCFKcj8cUuUr2kTL jOV4/WoZGbt+Wa0/KQZx+HtSLEm8Nt5pagmmZW4kfxEZ7ik3Y5HGf1rcxEF+YKR7+tQPDCxb5Qe5 x0pK47ruZcbEsODx69qllO5emR396vLDGrHjr2PNSiGJ4wO/+z2p2ZPOkUrf7uMYHWrO7b6AE9D3 q1HBGg7HdxT444vMyRninyMftoldBjPGKUEA/T261eEcfUgY9O1IyxH7uM+go5WHtYlPHXb365pp GOSODVpkjZgAMe9OYRcYxRysn28Cn15BGMUAZXnGcfSrSRx9+T0pGSIDnBIo5WNVIsp7cfUevNMb IyDgVpLHERnpxTHihDdB09amzK5kYz/K/oc1LK2UXvmrxtIuuB60jQoTggbfpTsPQypHxJnkc8VZ tcyxMByw9ulWJbWIvwBsHXNatlLb2NiSrAuT2HQVDY0c6kbDIYEYNWIQFxjr7ip5JBJlscZyeKaA GCjr3ANXEhqxUm2vcZHPFOUEc9s9qvCGJ1yVwTUqxJggbSD6U+UamloUVI/u/jT8+ucYq1HGnpjt 06VOqRAY2r+PNDiwVRFALnv9M04rxg9uK0P3WMED05FR7I+4yP1pcrHzopBcemOmDQo+X+8PWrvl x9h+uaYyJnIBwKfKL2kUU2Ugcc/hTWPPr7AVd8tBxwPQ0ixx88/pRysaqxMi45X6H6U6zZVBAHQ1 oTWqMARnNRJBHHnGfXpSs0EpqRVmbLZyD9KiXGRxg1O8ee5HPQUzyjn69qBIbxt6Y+hpynDZIJGO cGnNCByCeuOtIsfoTwfzoAkkbMJxwGHSq8WCMDqOMVZWLcv161KlltxzjPPFS1cqLRGvKjAx+FPU fUn61MtsvQHn3qytsoP9aVmW5IoqCO2TnmkB7Njg5qzJC27jGPrU0cEZiORz/KgV0Z/3s4x6mlxz 689qttaAkEEY6Y9aWO0OGy31wKAuikT2wF+vam9icDGM1fSwBY7nI7moza7RhWyPYUCuUGGDnnr2 qvMv7zrweuO3pWp9jJxgkj1BqtNYzlzhlwfQdqpEt6Drb/U84yP50kjBWxnJHHHWiO2eMEHGT79a RoWJGc/4VZka+gygXEfXjgVyHjF9uuTdsjI7etdh4dt2S5Te3GelcX8QZBFr06jkqcZ61w4rc9PL tJMxzcenOOOTnNCXCn73Hes77T6jvTTOOw4NcR7Bpm5HoevX1pBcA9cVm/aF7fShbkDt9aANEz9C oB/wo+0/L93vjr1rP+0gjJBpVuV3AkZHvSAvifPbge9L5/THas77SpYbcqcdKUTjHf3xSA0hcADB HWmfaPXpVAXHrR5uRyeppsDQFxu64+uaUTjIyM8+tUlljA6/p1pjTqFyMntQBoGZT159vSlFwCcY z7VmfaR6ZpftOR2+lAGn5v3fl49TTfOIOazzdbcBc8cYNH2lQOM0AaInXqRgenrQZ1/hzn0Hes0T jAwT7Zpyzr70AX/P/u59R6ULLx/jWf8AakyBk9cChrodiMUAaIl7gDimmcBfukd8+lUBOvHU0C4G MD6mgLmh5wK9MdqDNgYI/OqC3Ctnt3p32hVzj9eaALwuMjJjGPX0pPtAJ+7z9aox3gCkYyPTHegX K85znrQBeM2fT5exNHnkDkZHcg1SS6j2YkBNNN2GOFB2/XpQBorcAjkDtjFNa4A4A7cEmqH2he45 z1oFwh6Y+g7UAaAuOc7RxzQbnqQpx39vwrP+0AHK+nelF0h44O3igC99oP8ADjjoccGlNw3HAFUF uRjj64pDcKuBg0AaHnnBOznqATSLOCxIXHbOOKoC5UZxnOOtKbpd2AGJxQBoCbrlT6DnmmtPhicH k1R+2gr9xi2cZz0pftQI3MpY4xknoakC+0hLdOgyOaBNlsdPfNUGvVI9fTAwaabpf7pz71QF8XGP 7wx1waDcBuinFZxuFPBHPpmnCdVySpI6YBxSA0+qnOOTR6+vfsaQfeHTk8807gDrg9ORmgBrDoRj 15oyQeg570qjuMY7mkI9AMUwAnqMnn0oB3EjOfp/WkHCnHTPUGjOMbievNAC8sckhT0yaCSrHk+1 GO+OeevpQBnAXJoANwIbsTz160H7vOOnBzSr93nnJ5pMdcDI6daAEYYXnJAPQUE8Acj1yOlKMN7D OSCKTjdjkH1xQAvIxjqPSkLHI9KUAZOT+JpFwE7dOeKAFyR2J9eKFJweSMd6Tnngj15zTSoxjrTA XBwpH5mlByDn9abjC9QAKXnqTkY4pALz1XGPQUhJJywz6D0ox0xxnik+9gjkUAKRnjt9aXc2BuyT TcA8ZIpcAjk/5FABjcpG3r74oHPbpknB6UAZxn3oOQRyPQ8UAO5xkhjikBGOuT/Kk5KkHv75pR3z 0zjFMQqtg/1q5pM32fVLZzk7WHaqSqAB6Yx+NSRkLIr9eQQAfSnHcmSurHv8Hh43kSSoDyAePeor rwrPFCXhjY+tbnw78SW91oVu0mwOF2sM8iu0t721mGN64PXNeipNLQ8KVNc1meX6P4VvdRkKx2zb ejHFdDZfDe+nZg8TAjkV6joN7awNgNHjHJFdLHqNmxws8f51lOtJPQ6aWFhJas8TPwtvNvzRNkc1 Xb4Y6iEOIWwevNe8/bbb/nsn50C8ti2BMmfrWft5m/1OkfP8nw61OEjdC34DNEvw51LLMYDX0Ebm DH+tT86jN5bn/lqn501XmQ8HT7nzufh/fj5hA2F5Jqs3gu+UfNE+31xX0c91bAYDx1lXklvkYaPG fWq+sS7GbwsEeI2/w9vJVDFGXjIyKhuPAd4gZgrcc9K90kvLdSoWRBgdiKhl1G0dSN6EY5q1WkZy w8DwJvClyn8BbHt0qJfDc+7HlH8RXuE1zZDnMfPbis26mtmbcDEPT3rWNRs5pUkjx4+HZkOdvzZz yKF8PyYG5OD14r1W4e1ZdxaPNUJLiEseUq+ZkcqPPF8NSM3yxtz3px8M3LDAjI+lelW95bIRuZBV tdQtQw+dB+FLnY+RHkUvheeL70LAd+1RNoMiK37sc8nIr1jU7m3m7qcViTSR5xuX6VadzKUUtjgP 7ELfeiPsaUaCwDFNxOOCRXc+ZGW5KmkLJn5SK0RDOEOjSJ97p9OtKdHY846+1dtJ5ZIyVzUTBO5W qJOIbRz/AMs0LUn9jliTty3U4ruVEaLyQBSMIic/LQQ0jiF0YrjjPfpSHRyeg9+ldwVib7208VHs Qf3cHpQI4saQ3I2gD+dN/shsY2Ejua7Zokx0UikMC9QBRYOY4n+yOeExzjmk/sU5YYx3HPSu0MKj naM0JEgbOB9aVhORxY0Yk4CN+VA0c5zsOcYziu48pT6URxKDwBTshczOGGjuGPy4z3pf7Jxxt4Hq Otdw6J6LUbRJ6CmkO5xf9jliMA9eB61ImlkEZUce1dd5S7gSB+VI0asOAKLCucncWO/aSp+U9CM1 F/Z+0HCHnpXW+SAemaQwjd707IXMzkP7Nzj5e/JxQdK5+VT7e1df9nXd92k+zIOi4p2QczOS/ss7 u+fUHrTX0h9uVU/nXYLboO1OMScKw6UWFzHGJpEn3WBHfjtTv7LfjcmCOc4rsPJUdutKIF6EZoHc 446W+7BGaRtKI6A/XFdp9njbgrjim/Z4+6g0WHzs4xtMDY+U56VFPpbJsO0/ertzboPurxRJaoyZ K8Z4qXEfO+5yTaWf7oIApv8AZvy8KQPSuxMS4Hy9qa1uhHAH0FCiJybORXTweCM96f8A2ftzxj2F dN5Cg8DFKIVbtVWRnzs5U6bk/d/AHrS/2WwHTjtXVG1U847dqd9mHcU7IOZnIf2bg4CnrSf2cwwP LAHqa677IpOVFNFn3xTsLmZyTacc/d9s0f2dnovbtXW/ZBvORxQ1qAMYI59KLBzHH/2Y+4jaoHua VtM+UAg57muuFrkdB+VJ9kUcFfeglyOQOnHrz7YFJ/ZjY5GQep9K6/7GDyOv0pRZqOTyaAUuxxv9 lENkg4pW0kDJ24yPWuv+ygHoDml+xA9R+FFiuZnG/wBlkEqFGMd6YNLYc46+9dp9kGelKbRSeg+l FhczOKOmHnIw3QUo0s9EHXnPrXY/Y0Hb2posgBx09TS5R87OR/s4hcjqRyKT7A+CORx+Nde1og6g HFILUFicCixPOzlIbDcvzfe+vNNWwYE+memK637AvX1oWxVV655phzs5E6edoClj3oNk688kZ6Ad K65rIAcDnPFKbJT1Gadg5mccLFiccjNINPfcc8j2FdktmuDwPrS/YYyMenSlYfMzjW019p+uOnao 2sWIPB6c12v2CMe+aYbNMjANHKhqRxv9n55Awe3PNDWOWJVPmHeuxaxQL6c5pv2NORS5UHtWcd9g YtnH5nIpP7Ofcf8ADrXYmwQ9QPWm/Y13YA46UcqF7R9Tkm03aRweRQumv1OR9a7AWgAKn0pDZKeM HpRyFe0RyBs5OgHPrStZSepz6CurFkgGB09PSlFiMcjNPlQuc5Q2khUIwIwPpSNavyM8+tdd9hTO cfNig2i9wD9B0osTznH/AGOUt2605bOT+LIrrxZLwfx6U37Cvp/9elYSZyRtZB6555pv2ORsfTnN df8AYOFCrS/2eAACvT3osVzHINZuOg4pfsbsOOTjiur+wAnJzTjYLtIGD6UuVDVQ5BrWTbuGScdM Uhs2ZvXNdd/Z5wDjmnjTgOwH0o5UUqrRxos3DYPIA6d6SSwdlUciuz/s5SvC4OfShrEBgD0HqKhw RrGqzkBpp5579cUh04gLjJ9WFdkbJQ3GOeaVrNMHIB98VaijKU33OOFk+Tjn+lIbNgCCCR7V18lm hzhR9RTRZr0xx6VXKR7RnJ/ZnGc+mMYpDbv9PausNkucn8qPsSn1FPlD2rOTa1kYjjODnNItu4Yd 8e9dYLFV4IzjpmmtYqvbA64pcoc7OVNu46EnNK9s49MeldQbFCwwoGRSfYFyS3OeKXKHOzkzBIG+ VSePwNBik3dDzweK677CoXgcdgO1N+xDJIXmnyhzs5M27PgMOhzim/ZXbHPH0rrn01WOSMH2OKjX TQeBnGelLlTKVaSOV+xPk+nTNNWxY9iwz2611z6acfdBpxsD6YHSl7NFe3kcgbRiBxk57infZXG7 oF/KusbTTtJGfxpkmmt2x+NHIivbSOUNu6jg/TjpSBHUDHUdea6k6Wdp+UU46Uu/IUY6fWlyITqy ZysaP/dIx3NSLGx9Rn3rpv7NAJ4+gNNOn9crT5EJTZzZicHI5PTFLskC5I/CuhOnZzhcHp9aRtL4 x0P6VPIilUZheVJtJGcA4qJd24ZDccDmuoFkUULmov7M3Nu/MUciH7RnPkP36dxmmsGXGMj3610X 9mhVYFQR9Ka2mbmyvYelHIP2hz5Y54prEjHUn1FdD/ZWG5+bPf0pp0shSduMe3SlyC9oznjufnBz 6dKQK3PH510n9m9mGPcUq6Vu429KTgUqpjaerGVSpIweCK868bpJJrU5CswDH5s5zXtVnpgVzlcD +deU+KyBq8+Dlc4OT09q4MWrHr5W25O5wzhscqw/Cm7Gx91vyro8ADkA0jFT257YFcB7ZzrBgfmU /lSc5yUJ59K6Ngv+yR24zikwg4KjntjpRcZz2Gx91s0FivO08V0O1SentwOlIVXIJXkDuKQHP5we hoORn5c10Cqg52D9KTYueVXIouBg8gjg5oyRhsHA7kcVutGpwMLx0GKeCEXgAc45ouBgBiccZ70m SAOCM9M963nRSw4XjpilIX+6vTHSlcDABzxgk/54pCSDjB9OldBhAwIReBw2KeQrLh0VvfFMDncn nAOfTFJzjofyrodkanKovoeKCi5IKjnii4jn1b5f5cdKTLDnBroQsa8hFGe+KGjjIBZEbt0pXGc+ DwPloBH0OMYrfMcR4ZUHvigRRcAIPwFO4GBu9gaAevAI9hW+YYS3MaE9yFpDbwdWjU+1K4GCGx9f pS8+nFb/ANnhxtESYz0ApPs0O37i5/LFFwsYG7b2waQNgk4PFdELaFTyifiMc0NFCesacHJyKLjO f56fzpM/mPeuilEciBTGh44PeohBCDlolOO+MUXEYWeecil3benetwwQOOI1znPSla1h2keWOOhx QBhfex+X0pNwAx0xW4baBcfJgY7GhbSDn5Acn16UwMTdjnt70bgVNbUllDj7qjP5Ui2Vvg/ux+Jp AYu4cdv604MRyR+dbTWkJ6ovFDWkS42p0Pc0AYjHgce9OWUexXHI9K2TbQ7fufXnpSfZYCPmQE9c YxQBjZz/AEoZsc4IFbH2a33Y2EZHABpFtYt2AnPvQBkZz1U56g0hB4wOOvNbLW8eBu6dT70Lawbc Y3DOQf6UXAmYkDJHI9RijIUc55GRxSkZYDnIIPrQw3ehP5YoAReOnBHHXigEfKc8Djp1oVl4bPQf maPlC52jPqaAHE5X5QT36Uxhxjrjt61JklOnbFMUEtjB9Dx0NMBDlV4wD0HPWjdgDIIzycdjQVPc /pQcLjHGfTmgBw5znkH1NJlg3PA/OgMDyOp6UmAQcknigYv4cd+1C9guOeTSY4OM8j0pMAN7gZ5o EOCg4YAelHXqcZPPPNKB655GSKFwG7njp0oAaWB9+eOetLjqFA64pcDH+z6Ujfd+U4YHjFFwsJzk g5I96RiSevJzxn+lJjkjIGCeQaBkYwffpQADr0z3xSHsAD07mlwe+B3pAw6Dr1PvQAhGDk8EjHXi ngjG4A59aF5z60hwPmHXOOtAhVOQMDOaM4JwOMcmlYevQ03JPXA/HpQMUDLY6H1FGRu9fXmhecdM dqM8jIHpjNAhyj0x79qUEgAAjqehzTQDnk9KcxIzjJz+VMDtfhtdyrf3Eanjy+Bj9a7YX9zHIdrs f8+lee/DeTbrEgbA/dnHNd3M/wC8YbMf1r0cPrA8PGO1UuwazfA/LIwH1qb+3tRXJ8xhVGBlFTM6 bcY9q25EZKbLa+I9RZsea4Pruqb/AISXU0H/AB8Nj1zWR5iE84xSyCFeQwI9PSp5EP2ku5p/8JLq Jz/pDHHXmkPibUVXPnNj2NZaBcHoBUEpUsoz09O5quRdg9pLubi+KNRJ/wBe2PY0HxDfk/69zz3a sJGGD2qQFTzxS5V2F7SXc1pNfvi3M7VCdZv2B/fPn/eqhww6gGlIUYw3tTshOb7l3+1L8qP359yT TW1C8I4mOfrVbb05+hzTbg7V4YE+gp2IbJG1G6LHMzdO1Rfb7hW4kY/U1WBB64zSPxyMCmQyyNQu d2N7ce9OTULgLzKd31zVFix+btQr4PzdaoXqXpNSuc/LKR6c1Eb642g+aST1xVZ5EA9+nNRMwPTj mixLLM1/dEYEhAA696I767HJlbJ7A9apM386N2Oc96pEl3+0LocFznH5ULqVyoGH/EnvVJiOvPTN NGQ2eOlO5Ni82pXR6yHI6+lINRu/+ejH0OOtU92V96cDj06ZouLlLX9p3wH+sz9RSDU7ogfvD+FV B3JoLYGPQ8UXDlLn9p3QyWkY80f2nd/MfMI9MCqe7pg5PejcSenX9KfMS4FwapeAcSbe5xxS/wBq XZ6v096pb6ar9euOuKLi5EaH9q3IIHmHHQ0HV7xQcPVDf833Tj1pN3r+HFFyuRF8ardHjzP0pyax c/3scVnlumOfajd09PTNFxciNA6zeZyWGetINWu92VYAenNZxYbuBzShuenA607i5EaI1e8bkNyP w4pV1i6DZyDx65rO3dCByBSZGO1HMw5Eaf8AbNyF5ZTzxS/21ddcjr1rMU9cY+lG4DqO/HtRzByI 0v7cusfKR75pf7buR3B49azM+nPPHFJjJ6DPpRzByI0/7ducnnHHrThrVyMn36ZrLGB1x/jQxz3p 8zFyI1RrlxgZwPqc0h1u43YdsAHORWXjP+OKNmByPrnmjmYOkmav9tTqOvfk5pZNemEbZOM8euKy D3HH5U1zhDgDnik3cagorQ021a4dAVcjjPPaon1S6P8AHk/lVID92CMHtSf4UByoujVLsfekYjpT pNWuNoIfketUCcAZ/lTHGe+cGncORGkNau+xGPSl/tq6BySMdgO1ZYOCeDg80dBnHvg0XJcUap1u 6HIYH8ab/bt2O+fTJrMahR+P1FO4uRGsviC7Cjg59PWlXxBchuR+tZGc9ucUmee454Jo5hezRtHX 7hSPY9KU+IbjIx1x61jf/qo45zjFCkHs0bH/AAkNz6c545pw8RXAP3T16isXhTx0oBGSOxo5hezN seIrgEfJuP1p3/CRz9QoHtnisHjnHpzS9BjjHXHpTuNQN9fEco6rSDxHJnCr+dYLH5uvt0ppA4Pa i4ch0P8AwkMpJyg/wpV8RNjDIM9BxXO/w4HNNY45OKLi9mjpf+Eh55j7c8d6F8QNgkIK51Rjr9Kc WAyRRcFTidEfEB2AlBnPal/4SE7seXg/Suc/l70mTjjOM0XH7NHTDxENxzGB9aP+EjjHIQ+5xXME c9ietAOB/jRzC9mdO3iNO0f40i+IV/iirmU5OPxp+fXqe1HMHsjpP+EiUDJjzx2px1+IEDAz9K5U nI6H1HOKbtGec7uowaLi9mdV/wAJBEf4MY9e9N/t6PGTFz7Vy5wTgfnThgZAOMc80cwvZI6Y+IIt pLLgfSn/ANvwA/cPrXKMQeOcdqcp44xx0o5h+yR1X9vQEZwOOx4pG12DAwMZ9q5PHqMn6U4H8/fn FPmJ9imdWNbtWPA6DPNKuuW2PeuVAwSelJt/H1pcwexsdb/bdsDzj3Jpw1q0OP8AGuQ2gfy60oAH bFPmD2TOwGs2wGRjHrSnWrTcM8e2c1ySgepB9OlKBtY96XMHsmdb/a9qO+fcUn9r2x/jH51yWMg4 IzSKfXg56UcwezZ166rbEE7hxz16ClGqWxyd2PfNcg2DyvHYmkz8uOvajmD2TOyGqWuODn8aDqdu D1GOnFccGxyOaDg57k0uYfsjsk1W1zw+cdx0qHUtbgSQCMhuK5WNscA/h61BdkNKqnHHXNHMWodD qf7fiBOV/LvTT4ij7qAD6iuXGRyOtIQAOTx6ijmF7JHVDX4T1X8h2pr67AB93GO3rXMtk8jNMPJz 1PWqUhOijrRrdt34o/tq2zxkn0zXJDGccYA/OlHUZPTqKOYXsjrhrdp3+vWk/tmzPQn8fWuRIyMk Umzgg465o5kCpnX/ANsWZHLcCn/2pa44JPfrXG5PC/pjtQXPBzyO9HMP2SOyGr2i9wOcdacNXs93 3/wricYyw+8Oc04dflJz19KOZB7Jnaf2raE/e+lOGpWZUfOM9s1xGW3AgZ46ZoyduT9eKOYPZnb/ ANq2ecbvm6DFSLqNpgEtjv1rhNxx15zQflIOevB45pcwKmzvRqNpjO/8OtIt/aZ4kz71wvO0cjn3 ozgduTRzFch3Yv7Rl4kHtTvtVuODIprgwWC9x6jNKsjY4JBz170cwcjO7+12p6yDp6UongbgOCM1 wjO4UbmJx1OetJvcc7iB14NF0LkfU7tZ4ADh1I75pxmgP/LROOetcIJ2VSCzYH6U0Xe44Uk8dzxR dBys75pIP760geL/AJ6LXCJPIGG1mBAzjPWnC5lyMyNzyBmjmQ+Vnd74iM71pQYyPlZa4X7Q68rI 2T17037RKp+V8E9/elzIXKzuyE7uoHXrS4jbPKkda4dLyTcAHYH1zUhvJD96VvwNF0PkZ2u1Scgq aXC5xuH0rhxezBTh2J7D0qSK8uGbiQ+uPWi6Fys7ieSO0sJpnZflUkDPU14DrV2brUZ5sKCzetei +L71ofDzb5Gy3H1FeWyYOeecZ4rysbL3rH0WV0rQ5xAxzk8A8c0EnuPyNIT744xSehPP9K4j1xdx 7DqeKXJ5zjnrTT6k8/Sk57kDrSAXJOcDG33pQcDJUimZHQcnHQ0ucnjGOlADs/NkAA/nSbsc+pzx TQ3AzjpTgSBnOT0+tAC5yeB34zSE5A4I+lI3IwR1OMU4NuYgZPOMUAAI9e9J1GT16U7jj69QKQ5I 5zj+dIA6DgZHrnApG5I6/hSk5P3famqcYzn8KQCt6Zx3NJkAnafoad24GR796UnLdBx+VMBhOeec 04HjFH3ly3XpzSbju4HJ4waAFB9STk9aM+rH3PrTQPl5H/1qeucYK9zQA1ZN3T6ZNAJ/iOeelKV+ XnjPAp/HIBxx1x0pAML4UEj3PNJuyfmPHTHTNKVBzkf/AF6MY+8M8YzmgBMgd+e+aTJB+9nmnKgJ /h/AdKcgHGAT74pAR5yTjGPSjknh8d+tP4JHse4600KNtMBBnvhgRxnpTgw3dSecGk2jnHHrmnHG eABQAoPy+mfSjJJbGT9F6UFdzBaSMEDknJ5zQMXcCASfzpm7LcEdP84pwPKknODxSBfm+4fQmgQ7 Lbep/CkDZyScc9etB+790fKOPb8KFAHqT04NACl/l5I4HSkY89cevNClTg9MDkYNA2hee/qKAGns W69MnmnMM4wccj73akJGOcj0pNuWJ7ZyaAFkJ28HvnPTFJk7R0NKANh2jG3oBS7QvUdu9AyQA+ny 9silH3s8A9/arrW6Nu25A9cU0WyjJDHNAFMNnjGTj9KXHyjK+496s/Z8cMSQODkdad5KKp45A9Sc U7gVcewGeOKTZt68nr1q59nXy8jO4H8hTRFheQRx+dAFTA5OSc8daDxnORz0zVk25PB7U6S1GOT0 H50XEVAh3HGcY544o27eBxxywq35JCkkZ5pht03BhyQeM07jsVsjB78YPvTVAAwAVA44q41twMA4 560eRhQOduMdKVwKpODxjA7UnTsfpVtoOOM8+3WkFuCBnnuTmgCrkZ7hsY4PNDDrnJWrhtNrAqfl Iyc0SWwIwCwzxkigCjgAdOnTFKRyR61qR6da7T51ywOPuqo/rUMlpHk7HJQnAz1ouFigQff+dIcZ HfjnHSr5sxtGXGM9BUy2MZUf6QoA4+7mi4rGXgg4HekwOoHX1rSeyh2syTbvTK9aiFoGK5bC+uKA sU84X/Cm/L6+5rWh0qOd0T7YkeeGJHSp5NDto9xXVImK5GNvJpgYaAKOpGRTgAOR196vtpyJGDHc o5x029KiFicZ3qMH060BYr4G78aCvGccdanW2bcMOMdxSm3fjnNAG/8AD8BdcznrE3TvXbzEeexP HfNcV4Fg26zufkBTxk9a7K6H7w4zjpXpYX4Dwsf/ABRySgHj8eKcZlYZ6c1U6j8aGOB3HNdJyJk7 YBPv0yetRK2ORg0wtjHK4HSkyCcn070Bcmzlv/r0mNvvz1zUSZBwR1PWn5x3NIdxecqcdvwp2do7 ZNR5zntjmkP8OOM8ZzQFx244OG49M0m5hxkUnA7fj6U3GeD0x+NAmyRZWHUkjpRnd1JOajPtQTzg 8UIVyQcDGaTcWHDZP1qJjznOPWk6UxEhbI9cfpSZ9fXNMzkZ60g9f0p3EP4/z3pjE9wc/Sl6kZ5+ lNzn8sUCYZzj1oBx/TNIN24cCkzjP4kZpkjhn65pgyyj/Gl746cdRRkntg9KBCjIXryOelL+nOcU hGOSBg8Uh74/OgB2eemaTk/0ozhuRxxR0HNAwH3v6elDHHtxRnOPr0zRxyefUd6BDDyfpS7eQe38 qU/e4ycenFBzz0yPemAe/GPUUZ+o9TTVJGPT3p1ACc4OckUufY0isCfUfzo6nn+dANdgHORmlC9C Tk9M0ucCkJ7KcH/PFMQnU8HJApSMHjPPrRnuB9Pakz19P50CA9OeaCD3/wD1Urfe4/HFJ169DzQM b+ZIHFO+bv6Ud/p+tGfTkjPagQg6njt+NO9MdMY5pF559OOlKcehJ+tMBMGgnp6ml4A555780fw8 9e1AxOhIHHrSbfkx1p+c4yenSkY/LkkCkIdgBF9h0pm3oOD3+lOXlRjjPv0pp5H17etMLahtwOKb txyR+dOwvTH4UdM4HHXjtRcLDQMZ5oxQRlsqfelXt9OtArDcdeaTB5z3HalPQ/40g5Ix+dMNBcHt mkYHnHHpShPpwaf07fX6UhIixz3xwKPXjjt70uAT6/yNGDkErx65pgByOMY4pORjuKk/L3OelN4H 1NAhMeuDx3NKFJHYDtzSdeT+GacQcjtQOwmMcn6E4ox/KjGPXp3pDjv1+tAgYe2MdOaaR8vQZ7nN KP8AvkHnA6UoGD0570xC44Hpn8qAPyox6cU0AbeOO4xSAU8Y4+nNKR82OfpmkBz1/nTh37/jQMQD knp6ik565yD3x1px/XrxScbefWgQmM9R+IpcY7DGaNwY9cnHXFIM4yc49KAGkHbyef50AEZ5x7U4 jp/SkIzyePqaYWDHzDAyeh9qGoxSEDORgdutIBpwSc5GOOBTvTP/AOuhB6/z604+44HApgJjsuOu cGlB6ZU+v40mM9MfWlx09OtACcAdDkdRRn5v0z0pw9MGjnHTJHTJ60AIFz1H1zTvX8qTGewOe1HJ U4B9aBD19yfcUZH5e9ICTjPpx7UvHHUCkIQ9/UdeaTn1J9j2pcc46j1xQeevr1oKDB6cr600DP8A X2pT69c+1Lx+nBFA0JjoAO1A6cUufU4HelA9uaBsVPvDp6VFdD99nB6c1KmNw6E9OlMuAolwOakE hg+6TnIPtxQ3TaPTOfSkYErx0x2pSCuccHHNNAGBn1xSEccEnmlx9CMdu9L0xwPamIYvPX5vTikx xnNOxkADg0Z6cUCG4/zikOev8u9PAznBHX1ox8pyBnHFA7DMHt160bMnPPNO2/KMZx2xTGwGwxx6 0XHcQj0J6dqdjHIz+NGOB9cY9KcCDxycUgGsAP8APSgt2zgGlYf5NLj1GAOcfWmJDFHPQ9cUoGOD +eacqjr/AFoAzkDAoAaOWPPTjpS/3T1x09KkUZPXn3piggjPakFxQPmI6Z9TQOuRg/WkxwR1zSj5 e2frQIbgHaOw/Sgj5ickj2FOXtyRSMM+g64ouMRFBHQYzmmCAoc5H481Ki4GDgfjTlU7Rnmgdhvp uz9cU3nAPfpn0qQjnHPrzSgfNx6c8UgIzwSD9cUYBb6n8qcQdvYt0xR3PtTEIM4HalXkHr06evNB Axxk+3pQq85wR+FIfUd7Y6570+AfOD3PtxSYB4PX2qW3GXG3gk01uTJaFbxquzQoS3XdggHgV5t3 zx1+lekePTjRbfaepPGPSvN8NgZJPb3FeRi/jPpsu/goXkKc/wAqQqByR9eaNrcflTfmGeeOmAK5 jvFwD90e5NHPGf8A9dNwSeSfSkweTkUDHdO35UfUc+lIckgEj/61AJ6g47/WkIXAHTnJ6YowWByM Z9qRdzfyFLliMnH5UAJjPQHNOAIbPOM89hSAnHv60Z+npzTGO6jjnNNxgdBgdx0oLE4BwOwGDRk9 tvp1oAcRtU9ML+lBXHT6Y9aTLEYP14PSjcw9OR61ICkEY6+maCucjHXoRSKSMKMetIGPoDmgBxX2 H1oHfjoewpAx4+QcjpnFGSey469aoQ/byeAR9elIQPf1AJ600MSo5/M0FyBwKVhjsZ6knt9KXbhc 4I7/AEpmc/KQORnrQpOB8ox6E0gH7ckdvwo2g5Kjtg89KBuOeB+FNDH+6PrmiwhzLkHOce5pdpDE 8euRxTQxIPAz2yaA+BwARnHWgY/GCCT+ZpoGABz7e9IXJP3c+najd83zAjIA60AKwPQ7lP0pSB78 89cU1iR0U8nFKpII+U8HpxQIOmeQOOg70YKjIz0FJuPBweKN2eiMe2Ae1AxxXJBU9O1BUhSPyINN 3ZP3CPbNO3DspznigA2kdzzmjlWGc+nHUU0nBxgijfgfdyAcHmgBzA8MC3XGc9KawPOScA8UuTxx wP1pGOM/IRk+uf0pMBWOTwTnvzTTnBbkjpRnndtPpxilDsfvLnH0pgHTpk96NpC5IbA647UgIIwY 8evFG75R8jZ+maBG2So4BB4/AUKVJC8rk96Q/JhxtJz/ABCrM1z52NyqBx36elIsruFP8LEc9egp qoDjaoHOMDgVIQgAwTzweaY2BkjGaEAhHJpABgZJGemaRgPcH68ilfgHn3piAgZ+Vjn1zmjPcMcD n3FNIzj65xSsBzjA6DPr9KAFUEkbiQvXnvScY69PypQABjqe2OgpCpJIzkH3oAUncT6etJ0zk49s 5oVQW5BHFJgZ/iPGBxmgAx2GcducUme/JA5x60Fc4yTkH8qULnA3HgfnQIczHdyRx2pByOvtj0pC mDwSBnrSgDnLAAigYZIJzhsdRRgYx17H3pM47kA+9KoBHB/I0BYFP/6vWlbkYAJ9QRQV9+gxg0pX nO7B7UCEzxtBwpHApMA/WpETABIBNIB1JxjFADDw3XnHFHzNnPBzUhT5crjpgcdKQwkck8e3OKYx uN3ODz04pCT1wPoakZck8+nWmYxnkGgQgG3PXOcUchcZwPpxTgmM4YH6UAZ4yOTz7UwNfwe23XIu Rhsrn8K7G6yJOMH/ABrjPCYB12L5hxk5H0rtL3gntznAr0cJ8B4eY/xEVTz15wPSlJ4OfXkHtSEn PGc/Wj1z6/nXUcCEOOSQPpim856f4U76nNIMBRjHFAxvPPoemakxxwPfPWmAZ4Of8Kco/d5PTp1o ATuCaOnrj1NKwAUA/hmkx/e/TvQA7AHUjFJjA9fxpB97dSgAjmgVxCueg7Z60Kp3d/xNPBxx1HX1 qSM4OOuTxQMgYHbjaOfXvTT0XOBVsx/Nzj8e1RFSNpIz2oArjkkCnYxmp+cZI6UwrkcDr70EkDdO Dn8KTOW68A1M3t6cGowMN3x60yWN4OMdj3pMYX6dBT128ZA9T70cKuM//WpiGZJ65NAGTTtqj7ue KXZjkUCGYI78A0H1/E8VJgbc9/emsAPm9fegYmfbOOab1/HnrUm0egOOtG3C9zxQBEOoyOtP4HUC gIAOT74zQ6/NjPNACMMjjvT1i3x7vypo56YH4UKMjAJx7dKAExg/55owR6H6U5h15puOmenUcUCE GB+vIo9/bp6UuMHp83egg4pgBzwMZo6/Lk4Hf3o9xyaDnPPX0oJDHvz27U1R6U4ke/8ALFAHTOce 9ACEdMZNAH+1xRjHvR7d6YATxgj3HaheB16jrilzk5GPpSZ4xnigAApc4GP5U3JBPcU7PJ7d6YAc 5GOPalzjJyOO9Nznlsn14o5BO0e+KAHAcY7etJIMJ+HSjBxigghf/r5pDD+EA0pGWHalwP1FKOOR x7UCIyMgEDtnBpTkjI6e9PUe4PpzTcY96AGnA/8ArUfpSke+PwpFGMbske9MliHtjr7DvQMjpTiP TqaQLn14oAaeOv8AKhss2TnindfXPSkPHX+dABkZxz0pvXBxjIpxxt5wfrScnpk/ypiYq/n7GjHO Op6YpSDxxx/OlXk546Yz1oAYwxkkA0uB/hQfbH50uOOeMdaBoQnNKFGeefpQMYwf/r0jZx1/HNAB wM45pvfGDg8Urc9yR3oAPHNAhrDnj0oUD6ge9A9u5NKP6YoEHfGffNCqQM5z+FKeOo7UgG0DIGAM /jQMOfbNC46jtzSr2IAFIODjtQgAn5vmPWjOB0/+tSY9+nt0oIHfp/KmIMgHn1oP3TjvwKTqfl5q RIZG6DjrSHYZ1Pr6A01skDI5qyYHCZ3D1NVnBxQDQoIIHWl9mAB/OgZ7ml9jigQnU54I70qnJORj HX3pTyAMcY45xQBnOaAD8Rk8Cge2M4/KniMMvXnGeaQjaR096AGt1yCTx0pOx7/0pcnuenUigdeR njPWgLAB2zS/rk4AxSDjg9RjvQSPx9TQSLgAmjAPfj0oH47qPZen5UFBjaB3JH5Uo44A5NJnABOP pQDnjOTQULngk+valxzgg5xTcc885NKo4APJpCHqMNioZx+99/r1qZfvDjpTLpRv5J/KkUiNsc+m MHnFGQfyzQAPTOaRRkUxMACP58U4j36etI3pxzxigHJyQeOBTJAjPHr3puNv4dRTyM8Z75pg4bt2 60DF78CjPTpn1pecHjB7GkJ+f8KAE5I/QD1pNvXjin+g4b0zxTeoOceh4pAG0HJ/L2oGQe59sUuM 8Hp60c9cY+tMBM8HOM9Kb0IOCOMUHnOQSP5UZ4XHTuKQhQTnjJ+tKAcUifNw2QDz1/CphwMnt29a ZSIehGecc048r17dPSnMP19KMdscAfhSENH4Hj1oyfQgdvSgjnoPwNC47DH0NAIXcRk9cUDHYHrx QenJHHNJz24OOmelIY7HzA4xkUnqNvbt1oJPHJJzSM2Rxx260wFC8UHIXnt+lGPy68Clxg+/ueKQ CA5GdvPT1pBz25HPFO5YZz+VHbJXr6UtQAcHn/8AXS9TxyPamZ+XnjnFOycE4NMB5z6c471Jb4Mw HPA4xUI55Jwexqa1B3ZHA96NhPYz/iIwFjZoxOcEgV5/5aj7pI+teleNow9nAGAO4Y5/nXDSQZGQ vQ4HvXjYmXvn1GBVqKM4DGM7vXrQFP696ttGpYcAmlaJdv3a57nZYofxcfhntQoIHJOcdfStIxAK GaMYbgGmeUCOlAyjjC8njPBo2cBi2OeTjNX1RUTk/pTFGU4BHv6UAVCpHv68U0Kdo2sc+taKwjOc /TNIYo8beB/u8UXCxQZWOSOzc0mxueRyMdK0hDzgkHsKasatyqZGcUXAogNuO3jtjrilweMN+JFa dqxijfaABINrZ54FV5IRvPzAA/jRcdikAw6EHPtR/FzyOhyKtiLOVUZ70qwAfUeooCxTIOBk57nF Koxjocd8Va8sk4pywZUHeDk88YoQWKe0jp06Dim/N2A+mK0YIkXbyp9RUgjXaP3aFiOeO1AWMpQd ucDOMdOtObcoIKr6c1oFE3Z2gY9BVi2+zxtukt0cdwe9FxWMTknt7kUuW9uOo71vT/ZS5K28aD/Z 4FRSRQOv+qVD2wTzRzAjJA5AOOc8ikBPQ7TnrxWnDHbqR5kIlX3Y8U2a1gkkJgzEpHI3ZxSuFigp 9QPpR1ABxj69auLagLwy4PINItnKxx8uPTFFwsU8nnIBHoRTQSB8oA46GtJ7aPOMbccEdKlSzjMh LqqjbzycE0XCxkEnPQHnpSj7vAAOc9etarWke3hQvOfvVIbKFWUGJWx1O7t9KNAsYqtuPABpcHjI B5rXawQklAFGfuDrTl06FQDINozxg5zRcLGOCVYZHA5OaTGDngHA6npWpJYo5AG7JOBk4FTXeiXF rKqSbMsNylXz+FFwMTpnKge3rSMSeQoxnI9614bKJMKwYnPHJH6VIbG2LEvCSCckBttFx2MbJ/uq cdTmjPcKAc5Ga3jYad5zfLOE+9jzBUY02xMj7zcFT90BwMfpzSuFjF3c8AZ5/Kk3EZ3KD75610c2 l6Y8Kvbi5STkEO4OT6jA6UyLTLDygJjcNIepRhzRcLHPhidvCj6nNJ8x42g56Amup/svQduCNRZ+ x3LihdI0YqCZL/A5xuX/AAo5h2KPAGRg+goblhhefbrU88D22PMRscDpUKyLgbeTmmAgwBnBxjAO M809BlSWXdgAAUdxkZUnJIPWnK5XnaCaAZHxjGMHoDQyjaGxx/On7g2MqV/HpTeAMDjPr1oATG5R hMHHXvShVLYxjn0yacrgcdc84xz/AJ6012ZjlM9MHnrTAUpsB3A5BJ4pyx/J0HrgVlXsl3GxwCqn 0qkby6j4ds4PcUgN9lVQwI5xzzUTZ+6CcfzrGhvppZMfKpJxkd69C0bwq15arcGddrAEjrQBzSRq VAJ5/OnspVSePoBXWP4Zgh3B5OM8becCkfw5GYxtmLD8uKLhY5OGBrhsALx+FK1vt69R0rp4PDxj 3bJDkjIzSf8ACPyvnEmGHTuBSuBzJhJbp2PbipGt3UcqOOTXRN4fnUY3fN6ipF0GWQgBu3Tqc0XA 5R43HVCScEHqDTWyjcg+p4ya6KXw/fLuCgKmeGINImiXWckoR0znNFwZgrkjjOM4PFHl/KMHP0Fb x0O9IByCuccnmoRo19HKB8pHTBFK4GZHBnDEkHHIxyKV4V25GfqRWhPYagmcRZYf3ec0psb9VRjG p47mncDOFvuwQCSMAYo+xtjJVgMnrVzyNTDZ8r5ccYHH0pznUPL+aBhxk5XmncCh9jzwM8dRR9ly 2OSM4ziplnvCAI4GLZyBgcVILjUVGBbk5P8Adzii5JN4dsimsW7qx+U8jHBrrb4lZMDkHvmua0Ge 7i1e38+AhX+XO31rqrhA0hHv1r0sG/dZ4mZfEiiMDHWlX73OfTPpStHg4OPqKUrkk498ZrtPNQwD a3GRzRt5IGPxpdhC9ck8UAHdQVcVT06HA/OkXAY5B60uPlxj8jTgmc8jkZ+lIY1mDdOvqe9O3LsO e3ehk9OO1IV64we5oExmM9st1oXsfSlC54PU80pGP4qQICOMg4Oc05CM5YnGKYevXvSheCO+M88U xkgk696eHA7A9z7VXAbGRin4x2xSFcc8is3yg0odSOBk9KiYHHbNMbOBg/lTEPk29hioc84IoJyc DI7dKQgDr/OmSIcBTyfp1oOAaXGeM9M0hFAgXnAJ/Eil53D0poAGM4HH50qjLAcg98mgBSOeOvY0 0gk9BSgdsn8qTnI6UAKPx47UuT1FIvJxwKAfl4PXpgUwDdyDx6de1IDnGQcdqU846n2o69+2DigA YnoMZ9PSkHv164FK4P1PvQF47D+tAgJApP8AHpmlx6Yz9aFXofxzTARe+eOaAfQYoxgAZ9jRgjj8 qCRrZ/DFAxnoM47inYIAzzgUmOMH60wG+5HHSnfWjGR0/ChR2xx3xQAdCM4xS44pDnp0NI3Lc5oA ViAeePWk/H6UNz/9ahs+vFMVxV59qTGO/wCAoHPWlxgjg80DF69OnpR9R+tJ3xnpSrzjgjPagBRx jP40jA7eg4980f496UnA5zSHYMkD8eabuOD1xRztzmg45zikkIVeD26UE9O/HpQQQvHTNC/XHfFU Ag/HJ/Gk4U54PORQeOnalXOBnnPGKRIZPOP50mPwx+FAA3A9DijIwAf5UwsBBHTp14pMHOOPx70c k5GQM+tNOR/9ehCFUYXnscc0dM88dDS4+Xr160Z7/wA6BtCA8cc0o4HFJjnA6+lLgH2/GmFhG9hT sgeuPcUE/LyOn60Dnr+PNAIOe3/66T+L2NAX15z60fWgYdR6e5poGTzz6U/7owOnb2pOpyeefSgk ByexpOgHH9acF78+1DDPK59qAGgZ4B6/nRz16ijqoLA/Q07GfrQAntznqBSHPcYNO7NxzxSZB7j1 IoAT+H9cUY447U7GD79RmhuvpnpQFxFITt7ipPtD4+UADv7VFjkZ5I5JoAx9cUMNhSzEcZP41Efw 9zUirkHpzTcf7vHSkJsPQCl6quM4z6UYzySfX1pzdhn86Yuoh46cfXvRu+b5efw4oG4jjFGDxQG4 K2Bj24p2ckjP/wBamjhucDn1pQRx2P14oEGOc8Yp7HPt7UwD1PelBHOfwNBVxSQOeh6cUgzjjp9K B0zx+fNHBbn0zQIAADyPwNJ+vHHFL3waTAHH4/SgLi9uMdfXFHVqXkHIOKOCenTrQWhPTjnvxTum OufQUh/DH60EZ69j16UhDl4b1/GoJgWkHOQP1qePhhjrUMvzSk44zzSKQxOFx14zmnKBj9PrSEc4 wc9qd/skgkdMjrTEwxlueMUKMnAOPUGl2gj2B70ck84+lAhvOSOBgdqXBzxn86CvBHt0o79O/SmA mCRjGMmjnHGOmaPxwD2FLjPPcUhXG8dD1xQvB+9Sk8c/zpVHr+lMLjRggfMRSscYORjPJ9qVckDH 0oI4Ax3oAZ0XkGkVfTp061Io6frzS4IOORjikAwgAc4xTh07/nQ3QZxgHNCnvjt3NBQdxg5A7UYH Y/hmnfQ57UnTtgfXrQJiHjOTn04pNuDnGPahRknbkevFKBnrn05oGIE6cduxpcZ6+tGOdp9Oc9qd 79fT6UgGYwMsdvvScDkYY+vqKUfj26UuSO2eOOOlAgIG3JJoHI+lLjd05waQdV9fpQMBkgMD1/Oj BA54PrTgDg9z7nFJzj+mKAGlTn6ehoTuTjHqe1Oxk8AZHfvSqowPbkUdQGAEjg4HpmrdoRv5zg84 quMFuM9D0q3Zj/SAB1z3pCMvx2zbLVUbOByPw61yaKxHTaMd67TxaVEsYbn5ccda5qSNCuVwM9sZ BrxcR8bPqsEv3MSh5YPUDj1pGgcANjJHQVZhgZiAvNWCPKPK7jwPWuc6zMKso5DY7e1OGNgwOvtV 9sMSTjHTGOlI1uvHB6dqLjRTigaRgvyr3yTTVgAYAZznGK0fJ2YAwev4VE6MuF6MeAKLgU9jLn16 /Wk29uBx+dXNp74OBjp0pnlM5+bAJJ60hlUZC8kUwnHILKMZxitBbMnqQRnGBU0sUbx7AuDwD70A ZDP1yBjjmhWA5HII79q00s0EeW6DpnvUMluDJjCkZxincCpEWVmKjbnjIFOwxXc/NaTaeGAYEBuv TqajFucgHBx2ouBSeLcp2kkAccdKYEbBGF6cc960VQqpyMkYAoGJFYhFHFAFBELOQOeO9WrcIjob hCUBwdtSCEqFOMHHWja4c8dec0gsRYVpSyKpHbNSMilgcjPQkjGKlhgd23fMm0d+9OkXbu6ccdKA ITEu4F0DR5AI9a1fE39iTeTLo0LxjGHVugPFV0EYhySSxHSk4bgqPQUmxmbKxYfMEyw4HTil8sqg YKhrQS3Tjfzx3xzTvs6hSM5XHA9KLhYy1XzB/qx17dqcjShghUA5xgdzWg0KQkFCSh65NSRwJuBV Tn2ouFig0JcglcNnkDr/AJ4qF0KLkjK5yMVsmGNhtYEHPJ5zin29mpfAUkEZ5FFwsYWVIAC7cDpm p0jYKshwfX2rSubXySMquM8dyKjAD/eYMaLhYoyOG4C/p1p6EuB8i4PUZzgjvVs4RmYKWwB04zVj MUTDZHxn060XEZuQJPlC5BzzUyCUoZNoC9ATzmrqJE8mGhypOcVY82NQFEexRwB1p3GU4GMkbIyR tznJ4al83YpHkoxHqO1SMYRISg+Ujp6e9Eypyxzjv81AyMv5xAEEXHG3HX3qNoSrs6oj8dMcD2qx E6BhtB3gjJBzU32gNnCjr0NGoGcqFk37ITz0C5NPMbMwJiVMj7oU1OxTnsBU807RbR3AGFz0FAGe zrCdrQ49Oe1TrIOhiAHBHHWrUl15kZMgxuxjA6YqM3KOh+QZPPTigdjobgWdyu07XXtntWPf+Gor lS1kQsmOAelVrec5BBwRyQWrWt7vcMscdzimI4260q+tGGUyg4yKqJMF4l+XvzXpMc8T/K20g84Y isjVNItJy+0ADO6mJnI5DMdpPJ6dcUrrjJ9T0q1f6HNbLvt3ZlHOD3rLWaSMnII5wc0xFkjC9DuA 45p6thuowvUVDHcIcbhyx5apwEbIBzn8BigBJHV/vKABxzUU0MDqfkO/HXrUrw9wcD0PNMZdvCgE 9yKQGVLpnO6A42ndtJ6VuaJr+o6VIFLb4wMBTzgVDG2M5wfbpmn/ACHhwfYUAdpa+I4NRjUOGifP QjANBvcyAk7U7VyARP4MA57/ANKv2srjAZs/WkB0gutxAB5+tSpMUx0PPPasO0k2NhiR3znNXUnB Zs8eufelYDYExk+8SARSB2Vt2fyNZ6nzeQSFHHFPbKdTkj9aVgL813LNGFXjA5561X81kJyQOxGK ijuNindn0BqMybyw6Y45oGW/NYjYDkZ7il8zn26YqCORFXcCfbIqPzs/cwOSQQaYi75pBHJUD0pJ JVLKXY+3tVFZOhz0pXfew4Ofb0oAsRz5bcwx6dqWeZX4YA1AWVY8ZIGMU2RgoyPXrSAfGVGdqjNP hPPIG7+dQ5G3OS2OMd6eGHUZwKYmWovmuFIB4PXFPvWxOdoycVFby7ZU55JFPv8A/XLyTng98V6W C2PHzNapldmyORz7dqQYzySeeucUu0YwODnp60m4Bj0Fd55ImSTj8RTh0yP1prcjknH8qRTzzSGP HTpyeKXnnI6cUzcPvehzil3bsbce5PemNMcQNvIJGfXpSAZyeQKar56/jimyYLck0gH8DkH6UoXO eajVsfe6dOtJuZm/DuKAJW+6vOTTlAKnp+FRZ6dx+VJnnI6ZoET8Dg8HHWmnHv6U1W7E0FiMYx+V MB/lg5J4Prmo9uOccVJ1BAJzimcHj6UCuMbpknofSmNyvTNOJIXPJpW2gcnmgkhGN2DwfSlHI6/n QQAc8nt9KQ43YxgevrQAoJxggAduelIVAGPyp3GORnuabj6HPSmAZGeDS544PvTcZPBGR6ijotAC 8bv6UoyBxjH1pGf+IUmQCM85GaAH9PYelJ06Y5pB83rnoKUcY7AcUCD360oHpTc9AcZFOUAL64/S gBSMnjrSEAYz09KPY0qnPQGgBhyvbHp70o9eKAvfI+tKB/LtTE0JzgnFNI5POTTscZzz60089eM9 TTEH8WTwR7UA5A5HpSDJ68+uKbkE59KAHZz9PXFGeT6elN6DvyO1L9T060AB6g9KUH06UmckexoI wwHIPSgB/BGOKCfw+lMzjjPT1o4/z0oFYcOOCPx9aUknpnIPpSdSMc4HrQDnAzg45oHYdnsQcimH AGOT9adkkYJ6CmkY6jp0xU3KsDdBjoTwKVRk5B596CBs4x060g4I6dOOKaYmiT9abgZA5GB0pcgD v17d6QHI64NMQnHQfXOaMf40EDuOnakwDmgQmM9aUA7emT9abzxyfw704kgDp+NMYHIHJIGaZ1/p innpxz25pjHg9Me/ahEh0Y9h70gHbml/I0Y7GmMcP1oxxTgfzpeOP5UhDcYPUmlUZx1496MnuD+N LkHqMcUxjW/lQPvHj3Gad/8Aqo2/Xn1pXENx8pFGMYOOadx2akPXvQIYCD1znNL346jpSN1wcZoI I6celMdhcY+g9+lL0HHf3oHGcfjmg9D7+/SgVg6jr70E4x6Z6+go6cntSck88elIBenA9KTOaCeO ccHrQWJXPTvimAbfp+NJ1IOQD0Ipe/Xr0pcce/Qc0AJgAdfam7cdMce9ObgcDmkUHrgc0EsNuWyP Tj2pAAck/rS8dOg96XGOnPWmxDem7P3c56dKOnXPPSnc8ew/Kkxk9aQC9O360u3Kn6etNYYGOMd/ agnHXFA/UQ9eh6etKF5HTH1po+8eMY/WhmHU/wA6BIeP09qQE89OeMUnp09iKBk9gD160FDjz6/W gDPuOhpvGO/XpTgDtP6ZFIkXHbHPSj1GP0pM45bp796dnB4BoKEHI6ce1BzgcYzQeTzmgk56HFA0 PjXnjqKglGJM96njbB7461WL5kbNIsX3zmlwPccetIud3PY+nWlyR1z/AIUxMcAM5FB/nSDg984z R/DgfWgkVhzjJFJj1OaT19/xpT0O7B5ximJoTAJ6d6XOMk5A9KF6c5J+tBJzxn8qAEbhc4NBx2Pb tQevHrQCSR2PWgGhcZ/x7UY4GD1GPxo3Yzjr0H1pW5AOT9aAE6D0/HFBH+c0MDjnnApyjkEZ4pDD B4H60YAYc9+OO9Lzty2cdqOBnHHGaBCEBccH1PvTepGRTyckYBHGOaQjqePwoAaAdxOBnnmjnnPX HHNLx1696Q8jA/LHWkMBjPJ5xjNIp+Y+nTpSjBUDgY70FiCCf8igYm3gdhSDnqD+NKcbsZIOeRQv 3RjkY696BXFTnJFKAAOhH0prcfe/HFG4Z46j1oBDiNuOO34UZycA8dyKB1xgn1pCPmzwOKBpCjAP POO+aRlO7p19KcQB1wfSg9Me+c9cCgGhEO3BHr0PertmAbgZOR7GqXfGQe+Bzmr+nKvy4zkHjmgS 3Mnxfdpb3cQ8sk7Riuaa9gA+dSD1OMcc13mr2sM8hMyhux47VlLZWceMQx8cbtteFXfvs+twn8JH L/2pbqoKKxOeef4amfV7MoCqSls5wcV0q2tiBn7PHuIIyB/Oqv2KyMmUgTJ9RWB1HMtqcJIzGw5y RnmrP9o2644Ynuc108Gm6c43vCmeRt6VHLpens2FiUD0FAHM/wBrW8QfAZm/nUg1W2mQY3Z43Y5x XT2+k6aowIQST3OaV9G0tnLGIbx15xSuByR1O1yD82Aepp7ahamT5lYAHAOOldMuk6W2VaFcnPSq 9xo2nl9qqAB0x60AYTajZ7wNzuAegXrTWv7UkY8wHPTHAraXRLON1coW28Yz+tW00fTpEHmQLwOA CRmi40c6Ly3kJ+c89MirT3EEcKhSrE8jaOffNbEug2LHKRqp7YOKSHRLePCuSV9AKLjMCG7tiyma RgOSe3NMF3bCUbHO3PU10TaFpySAmEFByN3NS/2Lp7NuFup4/D8qLoDmPtcAkCmQD0I6VaE1rxiZ Djk8d63n0LTJVP7hV9McYqrHoNmP+WZHOOtK4jJaaNmIV1IHcCkM9uGGDnHQEd63F0O1znygMZAJ 6Un9h2rNmSIt7+9K4zKN1EUwpGFqATRZy7gYIOPWt1NCtRuHlH5uvfAp8mgWO0nBDdQQeRTuKxky T26wgowx6Ec0wTwFAQ2Ae4FbEejWRUgoXVeuDipf7KsjD5awKpx19KYzENxA42eYR9TSSNGvG4HP vitMaBZ79z4x6Y4qV9IszJhUztPqfSgLmU0tvsUuwwfQZ4qVLmARCTz1AHbua1ItOtkZgUypGAPQ UyfSLF9vlLtx2BpCuVY9SRkCqPQg9BU0d4JdqqR6fWpotNsxgiLL568mpxBaDhVC/TimIoskbvlp AeOeaYbWz8ptsoSTsBV6S1t2VlYcN6dajh061RjgHGcfe60ijKMaAkBhwcZB609I9o81irDOODWo mnWxJPOP7o5FStaReWVyFzyuO1AtDMVY92XwOwOaR5YtgLBWB44PStFbO3UfNuO4YzmmrY2y7SEP ORnPShAZJaNmcoQDnuadC0WxjK4xjp0zWmNMsVfMkZb0Uk4qWXT7JlCpEsZxyRQBi7rdceW5JI9a bmNiod1IPXHBrWFlaRtlUGfXrTo7K1GQ8IYE8ZouMzkjgKErkkfypd0Ib5uVIxnPatuOOBf3Sooq wNFhmO54gQxzwTSuM5V5oVUqoPzfdy3AqBZrJZj5lxGp69a1PFWiwLbmK0hKyMclh/KsDT/BUkye ZczFHzkgHIxVJgWlGw9+eOnNWxI0a8NkHjnt+FZf2nBOD15zQbl2iYAj8a0sRc01lyBn19M5pYrj Y4DyHp0C9DWXGQRluSQD1pclhlfpRYLm950ca7jyPU1UuktZ1b92oDZ6Cs2Xdt+8c/WnCcKo54z6 UAVb3Rl8vMTtnHAPSseZJoG3MCvvnP6V0jTKVwGzkZ5HeogkcvD7m/DAoYGLBqTxuvnIWGe3arq3 sM5wCATzyeKS70uORg0Q2kngnpWRc2kts7DG7nrmiwG6FGNyknPTJzQUIJ6Y9PasOHUJ4AAcMvcE 9K07PV4nBE+Vx+JoEWH3c4yc9vU0/wAyRcdM5wxPap1aOSP92w6cLjmo2i55GPw60hiQ3Dqw3MeO BmtOG5Voxuzx1BNZqphThenem42k7Tg9c560AdLbzIFBFW0cOvylT6kda5u3unAOGHtxWjb3JLL7 j0pNAXHHzcngHjNK2do/XvRk7clRjtmolkYs3Zc4wRSsBMpLk8gdsilQ8tgAn1qKIhSM8A8kg1O8 iIueN3tQAzLAkMMcZpRIvmccnHbtUW4M2cKO9NJBfA6ew4oAnMo5HU96bJJnHPt1qOTj06VEWcNz zjoAKBFiPcx9fQmrwjIhPBBrNQP14BJ65p0k0gbBJ9fanYGWFbbcIB8w3demK0b0bsnpj9axjK24 EE89/Sty4TCqOvygc16GC6nkZmtEUmOB2OOaZjHTjjnijIJx69PU0fkQDXeeSKOVz79aVz2z3zSD r0IH1oLD0we/FAxrH9OvvThxmkUEkNuHPQUoIHSmAmcAYx0yPakY5IyD/hS5z2xikGeoI9qQmHXG DjHf1oA5z2oA6/y96Cc5HHPemIcQOvOcU1vlGDnHrSqxCgHBPf3oyR09e1IYEdOvSnDrxgAU3v8A Wjdg8dB0piY8eo4GMUpBK4GPWmK47dPSnBlz1x70AN6Y7nvSbC2AcGn5GME80Bs9KAIWJP3tw46E UwnJ5HGeKmkPPykmmEYb+93oENJx1wf6Uoz3P40oBBODn9aRiV6j2/CmIbk+oPNDEnOT1P5UevB6 96XJ4x6daAG9M4zzR9aUYH9TSg5A6BulADVIFAZh1wM+1G35c4H9aUnkY49qAG7fyp4H403+Lrx9 aXnG08+lAh/6dsmgn9KT3xSAZOemKBjiOlIx9PwpFz37jOfekz+HsDQIU/7XpzTWJyMDt19aF9hl unNHp3AqiQ3de49O9NOduc4z7dKU59TgccUnOcHFAhSQWwf0PWhSTkjnmmHGeOx5NKOR1z9BQMVv 6YFHegDn/Gm45+lIBcn659qXJJxyCeenFNJ49M8cU7cVH86B2F6/hyO2acSDj9aj3Z655pQc/Tp9 KkoXJ9eaDz+Wc0gOWwPTFKe3rQA4AnjPtSA4PPHtTlPy9R+dNJ/ecelNAHPFL1PPAxyaOOOMYpGI 5z1p3JsL0PBFNzzx0FNyBnnPqKXqe3rimJi9BgfgDSjBJ4/OmHPQfhzSkepzzTJ3DJ6GgEheefcU d+cenNJn8PTvQDuLnDD364pA3AOPrQo45H+FGcdefpQA/OMGgtwN3FN+vp3pVJz25oAeD1/pS8n1 Jz6Uz05wM07rjANACkY/z1o64x075oPT175pM+o/pQA0n5Rjp7UhPze2McUFe4FJnDZPP40AIGyC M9qXcW6gCkbB68e1MwCc4GaYx46c0mT6Gmg9Oh5zkU7OD+PNIQu7Ayc/UU3PPr35PWgcD6etOA/z igLDQemOnUU4Hr/nFIOnqc5pRz9P5UxCnnv/APWpcjrj+tNXHOKM4FIBef4Tk/ypVJzg4x14pvbB +madnnABIxQJocufekzw245NNB9frxQD1zzn0oEkO5I6j2ppwQT+FIWI9vem7vXt60DsL+n15pD1 7HPGCKRjntn1zSg9M5+tAWF70nTIx1obJP3T6dKT65xn6U0AAY5bt2pQT6+9JkAjB5+tGeBnkZ/S gB/oR9aUcYxUefmHGKduG7jH0pASfTH4Uh49eeKaDwc5Pr70DA6d6QxXPzcHjHanZ/TkU0DqAOvW nAEtyRyO9AIOx9KgBxn/ABqwB/F79KhwN5x69RQWISBz1xxSnAGfw44pCdvP9aUHjn/9VMli5/H9 aNxwPak5I4PXjrQGI649s0CANz/Ol3fLyME88UmQQCePSmqCGAA/AUAKDlice5p2SFyM/Smf7R47 DijJwefWmApbkkcDp65oz/jSKeeO9LwDjHHSgBMntk4NP3HDDg1GDnoD0/KlXG36nHIoESZBXHT1 9qQk9iaQHjgUq5KkZGP5UAPyCowpp3Vhz07VHkg4HXGBinKc5PUenSkAozu5B5zgUuevr/OhgCpw Bx120xiCT0I+tACMTgcdDRn1zRjnqBjjGKTBwD0PtQAE5Iy2MU0jHGSMHPFOU45J7d+1NIJ9PU0F CjJyTtpe/pig4x6ZwOvNJ0zkZPSkAv059Rmk3YGcEevFLnJz0Pek57DjPSgSQo5X/Oadzt7AU0bh 6jv16Uo5AznPWixSF46g444BoA64/lxTevToB+dOzwQD29KAsKpIb9eKu6eQZO3+FUs9gKv6Z8sg brk4FJ7CW4zVGC3RBznGeDxWVJMGGBjkcDFWNckzqEgQk4O3FU44ZH3Ki4Kc/NXg1n77PrsMrUkJ uYJ3I64PamFiTlR0x3oUADaxPXNK79uDg88VkdAeYQMg9Bzk8ULI+/eG56/hSSKypnp3zSJwGB7D 15NAiRpnZieVHbb6U1SxIIbnuc0zf2OAetSfJsBDE596QD4ptjEZzxgHFKGY5OR61BgqxG72GBUo wwXaozyOaGMa0kgX5eeO9Ped9uGJHGM01k2cbgOemM01hjvk47UASJdzAfKW24Aww6VIs7nknJPP NQL33ZxnvxSsXU9Aec8c0AXDOFwfQYzmp4pwcg9D0Pb8azg30GeMfSpIyE4H3s54OKQzSkCxheR1 6Zpkb/NgVQZiXyT9fWiN9jjkkL0oEXXaRJFBzg+tWGkxGDngfnVN7ks2CemM5FRmRiRk8HsBSsMv pdDqeeOnSq9xPkHbkD9ar7sAA84/SmKC/bbgdDRYZNFPgEZGD3pxnbd8uPoT1qsB8p39vwpyjBCs AwA4oJLMdwX/ANYOhI3etOin/fchSMdD2qmp+bJO3B4x3p6vgnIBPsKYFmacNwrEHGTgdajVycn9 DUBwx4BO3j0qaFQSpPApAKJSWbkkdeOKVm3DcMZIxxxSMpXkLx0/yak3IMAcYGcUwIVkw2D69Kdv U7hkkn/PFIQvJHDA5oIKjJYcc8UASr827HHy5A6URkgsGUnB47UkR3EAMEPQe9DLtk+fBGc56igB S25s559D2pN78KSPXjvTy4L5CDrx70yVgMqOOM8dqRQLJubgn+VKzAr9egqILjaQxYDnAGO1SBv4 eMr7c0AK2NuMZPfilXb04HfFRlzxkZPcDjPFW7WDkSEk+xpMCSyAb5iMAdeK17u9h8kJDkNwfT8K q45AxwPSoZrVsFuMZPGakCdJ0P8ArOT055qreOsbKUx+BxgVWnkWEqCx6YHOcVlX2o7VbLbu6hTk 00By+CFHU9un9KOAcFfahTjHQUqMD0OMDgmuggk/TjpmnA8NuYDb6jOKZGx5IK9+opFA2gKMAjua B2Hu7N1wT1zig7mAyAPY+lRlwd2fXn3NKjEA9cZz70wH7sMOe+QKUuTkDtnr396jYbdo9OetIDuz jJz685/GkBKrnjnqfpTmRWGSvY5zUe76+2e1DSA5xnr/AJxTEVrmxjlbIGOwwKyrrT2jLbQTk9Oh rbZwD9e4PelAVu2fpSYWObimntZP4x65rUtdYJAEhHB+bPNS39uGUhFxx0rAkspfmK4wG+9QB2Ed xBIB/CD0yevtTii9ec54FcnAl1CytyD6k10GnSSsvzc0gLasAwBwD1xU8U5ibAC4HYVHxj1x2Bwc 0wbsdSMdcGgZsRXG9QzcH0B4qQToOC2D0z6VhtvVSA2BgdKqB5fOLFiTnpupAdS1xECMMpwM9aY9 zGyAh/bNYDSMR3GDyKaGP3S3J4zimhG+syHgN83TilE8aZH3u2e5rndzbQBkEDPWpRKTjJ47kUWA 2/tkeDg/r1qP7Ypb+eaxd2cj5sYwOOtOY+xx2BoA2/7RjUZXPBzx3ph1FHO47lIHftWGAfp708bj jqRnGDxmiwjZjvULAnJLH7ueK6y4YNbxsqggoOPSvOiwVtwAGD1NehxP5un2z54KdT3rvwm7PLzJ e6mUWHzHP5ZoHBx6+lPkHPXmmHJUFQfQV3nkC85PPGaQ/MrdT9TSbcKfXGMnrSDrxn3OOlAwB2jP Bx+lAxt+YdfakII6fjR83BpiBT6DnqM0EdcHmjae/PPXNGPlyRnv0zQAhz1/TNKvHpn+VKBnrwPe gnBU8A+9AhG6jgZPfNID7+/1oIA6dO5pCAfbvQIM/TPbmj15GPQ0hJI49PSk/h9u9AEgfB7Y9OtL xzgj+dMXpycHPFKD0z1/lQIl3enpyKYWx3I+lNzu5B69qQ9cYAz3zQArt0w3JPbimZO7jp0waD6H p60mM9TzTAcCc559cZoDYPXOaT+EEUdMYwPWgQm4Fge9Ln3+nvSbTtz1Oe9LjKnJH4UAGcDGc0hJ OT04yaFDc9xRjDetAB1ORk++MUp9weelAxx/Sjkfnx7UAIOBj8KMemeOBzQuTjr68Uo5J+tABj0+ tJnC8+vTNHTnpzSKeOeeeDQAufSjjPGSOhppOBz9eKM9OuKAAHI4z/8AWo/l05o5PHJxxR1I5zTJ Fz/dz9PWk5yefYgGkbPfHtikOe3YetMQHuR6UpHqe3Y8UnAYdcdODQB3AGPc9aAuKenOTx2NN7cj oMZ9acPTGD34pMnBJznp0oAReAvB/CjscDGT3pSOD165po/I9vakUhQSB35PSn9BkZPtTBnP+NP6 fj3pAAx9TQwOOOmM8Uu3cvB9hQwAJJzyKQwXPljI7dTTW/8ArU8LhRkfrSOBgf0NMBuR1UHp0FKO Bzz3yaTooLY9Milx/KglsaeePX2oIIXI4H6047j/APWNGB+PaqQmNzhvbHWndQOo4/yabz6DFHQH 0pkig8jA460nRePXvSMcDj8KcCeRgHPPsKAEGTnbSjp7UY7jp/Oj2/rQDQd+DgH26Ud+AcUmefQ0 D3HtxxQA7OMg59qdux93PHQmm7vlyTjj0pcDPB7Uh2H/AIdeSM0n+NNzjk/nSkqcen1pjEPBWkYY zg556etNJ5469KCcDnI/CgTELdcnHqaAuOMnNH8WQeOv1o7DPBzxmgQ4c4POO9J+GQPahenPApc/ qeKAFaT/APXmmlvmAOfwNH8Rx696Ofoc0AKMntgUnU8HNKOvWk56H9KBB7Hn2pAcdc0d+eBRz17f pQIXOPvcd+tKPfHPamjOOQPxpevOOe1Aw6Y547e1LzkdaQg9uaTd8vHekCQ7dg5wef0ppyACfToK CenHB4o79jzjmgBozznP/wBalGSOVx25pXxu6dvWm7unU0wBjt+6Bz1zSdOBgHNA56+uKXr93r1F MBBk45A57ilGNpDE8mmqTnIB659qcORz1GKLiF44P4UvfnsfzpMZwDSjPPXgUhiltvJ9ecUZzxzx SdieMdaTGO+R9aQx38XqTTuO45PWmrkjvnFPGRg9qAsPTjnjpnOaq92PIANWunG3/Cqmxg3PIyef WpKJFGM9T7DuaTnHTkHnijjgEcjoRSMOc+/r0qiWOH3c44FN6AH5vTig+hJH0pSRgjB4piBjtB7c UncH3xS57AdOMUc9TwO3egAGP68Uh4/nR09Bn1pc+n4UANHvjNOVefw/OkJxjn8aXPp360CDH1Pp SdFAUEjk9cUZxjLYxwaUdBjpjpQAhI+XgnHv1oGPm4J57mhiR07CmqcjGM96QyQcgZ4PfmlHOOmf rTRgsSQOuOtO4JHp3NAClwy9+ffmkOCTjk/ypGYHGR3pq+5FAWJDx1JwfxpqnKgr+ANN9h074pVG 3r0x0piDkMPQ07GARjPGabg8kjI6YA607oOBg4456ikMTJPOO3SjIx7DtSEHtwDxQpxnnqeQB0oG OJwecAdORSYweQenTrRjII4zjOKDxxntnFAICOCSBn+VJnP0xRyRx6duacAD26+9FygXpySaDjHb 8+lKRjH60AAjAIA96LgJw2CRj/GtDTBmUe3vWfluMdcZrU0dcygkfKeBUy0TFFe8jD1qVlvpGHXd z61DDezRlvu5Py0a0Q1/McEEuTjpiqPOQDknGR614NT4j6+j8CRdeQHnv1wKj8xtrbT1PHtUGcMD wSRxS7jnk9eoB7VmaFsnzCNzZA45ozsbJGB1/CqRbHpkdDT/ALQM4OT60DNGQRBgSvGOoqMj5htz zyR3quk24HJHIz+FPNwsBIPr29aAJsAnJwO3FQ7yHxjjrUqyRyKpRiwPXB71C0eARz6gk0DJskrk Z6c0h+XrwMcnNVon28Nx2POalWZXwVwSM9+lAEmSeQOOO1NUnb2644NIswO75sn/AHqI2HXgHuC1 ACrIQAjfjjikd8E8CmF8ZKnHXioZJg3DYzx070AX45EfZg55xweKtjDjA6ZrKWRAoCkfTvU8UreW WDnA9KLAWGTY7ZHPGPajJLMAc56c02OdWUMzd8Yz1qBrmND82Djn6UrAS8jGXBOexpwYhuD8vTJq JXQruHOfeiO4QZ3noRxmgCyR83BxjmhtwG0gfhnmq32uM7mB6NgkfyoF8GIw+CD9aLATquH+bPvi pIWRHywG3moTcb3zu+tRtKAwTPB4JFFgLTAbjgEcce9TW7RbMdWJ4B5xUayI4GSCemPX0pfLRVGH xg9c0gLcifL1yPpVVg24gLu28HFPWbA3Fs4GeTURm3YKgHvwaAJht4OO2KiY7cbuuMY71HcSIOMA E4/OhJAzDPH4/rQMnZGVAenPOKUnpnnHNMeQuo6+3OaTY+PvY54oAcQHztyPfPenxoNmMYz2xyai 8xlI24PbAp7SEnjj0IFIQjPjg5A7+2KZzLIRD8vPXNJbwPKxD/d2+vXmtKKJYkwBtJGfWkUJBaCP a55PU9qPtGJMcdwKnnkRImLMpZQcYPesKS8zkqNvPG40gN5LlVcK7YJHB6frTLzUoYUIMiEdsnrj tXMzzyEF42Hy8ZHas+4uDIhyxBOO+c/SqUQbNK9vkmaTCkjHbIrGL/OOOOnSpQyKpwcHpycHNV53 +fOMnrwapIVyMkEDJDcZO0UY5HU57Dj9aaG4wvPPPOaC2CO9WIdkjk5HHGO9SbhwR19xUC5PbPNK OAA449qYyZvvH7vqO3NN2uSBg885OBn2poLHnHbvTx1BHG09fWgQ05K9wc9QaQBSRk8Zxj61MFyA RnrjI6VGq4bdg4xyMcUwEzngbuOny80nJHOBnpml5P3fyzUkMRfjHA6mkwCNNxB4x6DkGpvJwTyA QM+tWIoVUgADPce1TrDxuwBnHI4pMCibbdu3DdnsTTDbIMYTjuBWk0GVJ2jrxxyaiaF8kjBA560g KjW8fGEyV9qEUITtGD3zVtbcjORz39KVrcZJVOfX0p3HYrKDnr1HHFCIQxO0MKsrbnHfHX0NP8vA BOBxx3FK4FbyjtbA5PIzVcwBnIDdfQVoNEWJAGSTjpTlhIHJBJ4yO1FwsZ7W4zxkZFQyQug4HH51 trAxH0pWi4zIAMnFFxWOf7jj2z3py8dvatWXT0YnAPPJqrLYNGSYiCORTTBoqNyDz8uOmacBk/Nn gc+9JIpjbPI9MjOKTcMcA4HOeOaYhRwc5OPenoDuwSOOlMXgcj2GRzTl+6Pr60AMxj7qlsV39sQ2 lWz46pj1xXCouSfp616DocRm0W3DEelduF+I83Ml7iKUgYq2O3c1Dj6e+RWleWRWbaCMcc1nyQyI SGHTivQPDuBPrkZFLz3/AP1UiqV7H8aTr34PXigLi46jkLimrzn0xjjtQQ2AvXPc0uef6igdxQMq M5/lS544wO9IOhJ4xTd2Bkjtj6UxNi455GaTovOeuOaUfxZIHHelHKqQ3ynnNAXGY5GPzpMEU91+ X1Ht2pjcZJ57imJsaep65HHSkUZ5P8uKcMYPfihcnpn6U7C5kAOB64pQcdelICaeDgjjOOtKwXGE 9cfhxSjaTyM+mKVuecZoKkLzgEe3SkMavHTG7PcUgyD+HelOeMY3Uv0xz6UxXI2A65PTOe1LztJ6 85p+PU54oYD9c0C0GdTjbwTn8aFPYjtT2Hfv7U3dxzgdvagLhkd89elAJ/xpM54GM9s0duDQALkZ xzRnKn+lLjHQcflQfU80DBexP/6qOgJ6/j1pcEjtmhcjOQQAaYroRiO36DpSNyR696eMZIz060Nj 0OaQ79iPGV4xjrzSY+bHUg9KkAyPlGOe9Mbg8Z9RQhMOc/d/Ok5GOnTFPOQO5HWm9ccZpkje5zxx 2pcA4BOaVhjB7dOlGd3T6CmAzbz/AJGaXHPOM46U7GOv0oHvj64phYaQcZwcY5GaOvQ8H3pSO5/S gj6/SkAnOen60YycHGOoOKTAA70p4AxjryKkAwfy4pcc/lxQODz/AC6UDgDpQ0Aoz6nI/GlbBBxn 34pMHgDHWncj1H49aRaBSSvXt3FLz9DTFI9cdulOPJH6UIGNAJyB/hQfrSMecHuAQSKUcg9cZ5qk QJwG4xkUdsg/jilxkYHXGKTrn1x65qgG9uv9KMeuPXil6YB6jnNKM88gn3oJEGRgmkbA7cdad+XA 49KMEjIJB6UCEPX14penGecUqp39PfrQq46849KQ0xu0kdDz7YNJxzjinYOBnrRjkZ70D0Gj3Gad jHqe1IQBn0HpTkO40wAgHHrTSM+n5U8fiT0prdehPvQMYOc8dfXtS9xmnEAHnPtQRtzmgTsIR0x/ kUfSgAgdOtH3RxmgkMHAz6Uu3j3+nNH0/HFCkcg8evpSGOXI9xQeMDg+tIMY46UnIIPYHNAIRz8p 4P5daRl9cjgVMz5+9tK+3aoyPw/CgGMA+Xtz60Mo4+tLzx0x3pCfx9femSOUe9J0H/16Uc9R9RS4 P/66Q0IPujHHPPtSkhYypQZ9aOv3sgUHB4zxQVYbjOBjPsKAB1wT3AoznBXt70uewPbsaCRrDceB +Xam4z1A9KfjOMEHPX6UjYzwf1pgM7jJGM8cZpcnHuelLj5sAZNKBhsdRQINvvk0g569uaXrxwc0 h5bqRQAu0DA56ZzjpS559jQPwz3NLgZGRQwGngcg59KMevWnEMR6UmeB3Gc0hgo/vZ9eaeoz6Hig DnnjsM08HHegaFQEjjkYqAsMnHTOOaspkdDiqwA3Edu3tUlAAc9D17UjZ9O+c04jHvzxRgAe3tVI htEfX3yKcB/EAPrSEHjI4xzSrglfWmAL15PvTiOOaTA754PSjdwMA0CAcZ6cUZ4xxxxSZ5xuyRSM fUjn1oAXOSdxx3xSf8BH86XgrgkevFLnnjHAoAYuMkjtQPlzk/WpFwF+vPtTMDnPXPagBGO4EE54 zTBgck+9Px83A/PikOME+h5zSKGqeOuO/Sn546EDHpTMZPJAz2p2MdMbQMDvQAb+Bxx1oRjggDGe lK3XIOcdaaeO2fp60rAOBG4YznoaXgsffn6035h1/Q05e+cZPAqhB947sFcc+wpT93HakPJ+nQet Lg7eRz/KkArHB7HHYd6YeuBjGO9L65JHHXPTmjYOe/v2oBCgfMvagnHoOxpD2znANJk84xx0zxmi 4yTowwMUnY4OO/vSehyRx9aXOByOvepC4Mc8j73T60vQjdnFIv3Tuz+FNzggNjjIJoC44L83PpnH atjRcCT15H4VjoBwR0rW0rIdiOeOKUthxfvI5HW5SdSlUHnfnk9azvMctnBJ3cVe1Nd99Iz/AMRy c9qrLH83Qc9TXgz+Jn2FNWikN89mPJKn1p7OWxu6AUjKykHHA5zS4ZSdwGO461BoIwIHHUUwhgeu OeM9qmUcjgHnHpTSCApGffmgADOORwCMc9KjPmP1Jwcck8U5W+bLFimMHmnMNp6DJ4GKBjELR5Kk j8elO81iBzyM0rHkgDkHim55HPA5xQAjMzMCGPajDEk89afjI79vrSMeRznnsMZoAXBTpnnk80jP L26E44pqjK49BTtp6cdM/SmAnzH5txPv6e1LyzFjwAOnpSqdw3HA7n607HGc4/8A10DGqGAGeRSj PlkL3IzzStjdnJLHjp1qLK5G3ksQBikJjlHznnG3J609syDnjAx0zUbW9zkbIJ2Un5jtPHPrTHZo nZZAd46qQQc0XAsBjxjgD+VMyW4Ofr/WmRyFuUySo5xycUjEofnVgvupGaAHsp3DIwevNP2sQcc4 7ZqIvh2O0rgZ4GRVmCZGUBuh7GgCNZHGAc4xTcknnO78s05sbj5eAckYqPzMDB+UnqD3oAmjZh/E V78dqUSv03n2x2qv54BYHBycYJp3RQOy8Af0pAWhO6kKXOAeeaFuJI1Jz7gVGgDEdAD1qTgrjqM8 +tFgENzI+c5J75HSnreSKDhQT+dQdzgE84ApIVbOCMtjt2oAsm9nLA8AHtjrTxqUg3ZAOTjBNRR2 FxJnCMueh9K0bDS4/MHnAE56mkMfDePclVSPHpjmrUMJDjcpAzziry2kULful2579wKcmNwAPPGf SpHYkZOgHHHpUcpQEE4JHpUtwwTG0gnGeuaz5nJ5A6DpmgZS1KZtih8kdcgVgyF2YlWH4e9aWoyl 3xyvHI61kuxBKk8+oqkhDy4HBbnGCehNNeJRl23/AJ1V8zavynB7cdKbNKxY8gkHkjrmrJDgNycc 8DvTWQ9AWXvn1/Cm7j2yfQ0A5OP6dKALSxZbkIeeoOKXyOm7PTbxzipzzx79T0FOxngkHAGaYFXy wuAfXt1HvT1jAHI4IqVT8q/KCDnDehoUF052qCCF45oAjCHd83Qc9akWIDHy4bHJz1owSQOSCM1I vyk9Rk4zmhgVmDDGUOMY4qJiyEEgjuCTnmr6sWwMD+tPWIffChvxxTuBUgjaRxzkDtmrgQDgBcZ9 e9OAwq/KFGcnBpNwXqhA3Z5OakB+7Gew9SOKkRsfe5OOg4AqD5gOBx0PPGaCyhhk5PT2oAseYA4w PqTSCT5TznPIFVwqnOAeR2NPBwR6j0oAsK+cHIIHY+tOVueQA3Sqy5HYjB5p4clT3BOT/hSGifg+ 9IccH5uOD7Uzecng/wBKUPkdT09aTGTblBXr6DHal4Ix7jr1pm47crj1oDsOikseM5osBPGB/Dkn 3NSSL8uO+ODVXdjGODnjnrVjO9QeGzz6UgDCjqATjAGKRQD14559qawAbpjnkg8mlj+b05OevFCA Li3WUcKOeeBWVLZIWO1SDjgmttQeAemfyoWNW4wM9TntVXEc1NbuowoyQP8A9dRZAGePxFdTLZAD K7TnOaqHTAcgAHjnAppisYGRu+UjAHY16V4Mge40OP7OQzIxVgTyK5E6YOmFGORVjTp7zTJN9pLt B+8Rx+lb0aihK7OTFUfbQ5T0NdCu5Rv+TrwCahuvDd8+CUUbefvCuQfxFqqjBun7kilXxTq7H/j5 Yceldf1uJ5v9mPudI3hu8Kk7VAHbNQHw7fMcKgLHtmsoeJdVxxcMBTl8RaorAm4PXpVfW4i/s2Xc 34/BmrSKHjjX6E0o8DawVLrbA46jIrLj8ZavC3yXR9uKuJ8QNZEZVZlzjB96PraD+zZdwm8MajDJ tktWUkZ7AVGvh28wT5O7nA6U2TxbrEyhnlQn2FV18U6suf3qfivFNYuPUh5ZPoy03hu/AyYDg980 xvDl7jaYjjtzVf8A4SzWNuPMXjjGKb/wlmqN/wAtFI6fd6U/rcRf2ZU7lseHLw5zGcU5fDt0o+aH J9yKpr4o1Uk5mQemFpH8Uap/z2Q46fLR9biDyyp3Jv8AhHL1mxHB9MnAp3/CNX2SPKXcB0zzUA8U 6oOkiHB/u1HJ4s1UtnzEHP3gvWn9biT/AGZPuWx4dvcEsijB/vU4eH7xV3Mq49jWc3ivUj/y1BU8 dOlMfxZqYX5pQQD0Ap/XIj/syp0ZpHw9elsmM46jkUNoF6pH7k5HvWavi/VFGCyn22ipP+Ex1A4y 69+MULGQB5bV6MtNod4pOIj6ZNMOiXeVxH9c1X/4TDUSeTGR/u4NIPF2oAbmVCM+mKf1uBDyyr3J W0i5zzG2aRtKuAvEMnPtUR8YXjciNBx3XNKfF94SQ0UR4zTWMpkPK6/ce2lXG7BjcDHXHFNOl3B+ 7FIR0zjikHjG6OCIo8/TrSN4xuVUfuojnrxT+t0w/s2sH9k3CnHltwOSBSNplw2AsUmfpil/4TS6 H/LGIj2FJ/wmdydw8iL16YprFQE8sr9CSPS7oZBjP1xQdLuOMRNzUT+NbjAK26Zx0xSx+NJww/0e NuPU0fWqYv7MxBL/AGTcbeYz1xgdaeNHnyBsbPuKqP41uQflt48Z7jGKmj8Y3LdY4xgc4FJ4qmCy 2t1JP7JnHOw568ChtKuO0ZA7mmt4umPSNPU0weLpv4oUH40LFUx/2bXJv7KnCk7GOBjimvplxgny 2PbpQvi2QLjy1x7dqVfFrkjMSYPHXmn9api/s6uR/wBmzhcmJuaRtPnxzG3PtUv/AAljBf8AUKfT Bp3/AAlueGtxQsXTD+zq5U/s6YhSY3PPJApwspN2Cjeo4q4PFwPHlKCKd/wlqAZ+zD0xu601iqYn l9cofYpifmiIpBZsONh46jFWm8aQjj7IM9uaYPGlvzutNp64BprE0yXl+I7FU2T7iPLPrR9ilGTt YfhVv/hNbcdbT5fXNKPGtlj5rWQevTFP6zS7h9QxH8pQW1kYk4bGcdMVItjJz8hIAznpVv8A4TO0 PS2JqW18XafKzh4nTj0o+sUu4vqOI7Gf9klZQQp/A0iWknG9CDWjJ4w09H/dQsy+4xTW8Z2QI3Wx 29+maTxFLuNYGv2KZtJByVOPammylYE4bketXG8ZWAwTbSADnpTG8Y2W4ZgPTjIqHiKfRlLBV+xB b6dcNwEYH3HWpV02UdY2HOOlMn8axpkRW25QfXkU2Pxu2Cfsi7e3zUfWqa3H9QrvoSSadMVJ8pt3 QEiovsEvQqd3fC0v/CakNk2i47gN0pF8b9f9EU88e1NYqkJ5diBTZyjCrE34L0pjWkiMcxYyM5xU 6+OEzzZYOOm/j+VC+NYy2PseOM8mq+tUif7OxPQgktJuCVYew5o+xzMBhCePSp08aRgZNmR+NKPG cJbi1IHbmj61S7k/2diu34kMdnL0ZDk+1KtnL82Y/lHpU6+M4AMG2Jz6Gj/hMbUYJtTj2o+tUh/2 diexX+xS7vuEAUfYJA33G49qtL42tj/y5kA/7VKfG1tjK2QOPfrR9apC/s3E9isbOQ4BRvy6U02U ozleM+lX/wDhN7IdbFvwYUf8Jvabvlsjz0yaPrVIf9m4nsZ/2KXdja3JpVspMkbCea0v+E2tP+fE 478ik/4TazOP9AJ+hANH1qkH9nYnsUDZyheEJyfxxSGyk3DCHOcYrSHjfTgfmsXHvuBpy+NNOIJ+ wuw78ij61S7j+oYjt+RlNZP3jI4x0qP7FKELFSeeg61sy+NNMMZWOxlz9QKqf8Jhajj7IwH+8OKf 1ml3E8BiOxR+ySDqpHsaQ2zA9DxzjFbEXi3SHT9/FKpHPzKOahPivSskmCQD1201iKXcj6jiOxmp AyjtnuKa0Tbh8p9sitI+JtKPPkSc+gFXYdZ011DNEyemRmn9Yo9xfUsT/KYXkMo5RuDnJFI0RPP5 DFdGuqaYx+73xkjrTxeaZIvBH0C0e3pdw+qYn+U5j7O/AIPzevFK1q3P3WB9Oa6rz9MP3yp9sU3z 9MBJJUY6DFCr0trh9Vr/AMpyjQk4FILfGOp966htQ0deM9M8helNF/pJZdpBXt8vIo9tS7k/VMR0 ic4InC47ntTSj9snseOldJ9u0rcSQBn1HWmrqOkAEA856lf60KvS7h9UxX8pzvlZ/hJ+lN8psjNd J/aOlEkdeORiom1LSEHzArn0XrT9tS7ieFxP8rOfZGx8o/ACl8pu+c1uLquhgZ8wL7EVJ/aGgbdr 3CYPPPFV7Sn3F9XxK+yznvLO4naSOp9qTyz/AAjINdF9r0Qj5bmL069aXOkMQRdwj23U1On3M3Sx K+w/uOd2nuCV74pCp+Y8YP611S2ulyfduI/wanfYNOb/AFcsecf3qOaHcXJW6xOSEZLD096GRucn PtXWDTrBmws0ZPf5qcujWrNtWQdOgNO8H1Bxq9YnIbScjnPan+WVbHHr1rrxocIHDdDmo20WB2IZ 8EH1xQ+XuC51ujlF3BeffNAA3LwK6ldGtBl/NXHf5waSPR7diNsobnipvHuNup2OZ2HmlwT2IzXV TaJBDy8hHpzUJ0eA5Cyjk/3uTR7vcd59EYKR53dMDpUUkRBwoHPtXXW2l28cbl5VwBk5NUZ5dKQ7 Gnj68gEZ+tZucU9zSMKslpE5wxkcYJC9TTSjnI2/0reU6Wx2+ehzxktV1LOz8rcssRXP3g2a1UoP ZmPs63WLOVWJslgKTYQueo7V2f8AYKMocPhcZ4PFEegRuu6I8+ucii8e4KNTscYFIJxyOuKaVIXp muzn0aOA77hwoPAqm1nZYZfPjwByNwp+73Hy1ekWc0qFTgAjPrSmHLcfez19q6MaZbHbiQNk8fMB TxpMLMQCPzppR7i/efys5jymOOD703BHtz2rqP7IgUnEoHqM1CNLt3bAmXPTrSaj3H7/AEic+iFh t4I70hRlYcV0Z0u2UEC4UkcHnNO/s23YjMyDj1FF49xWqdjmdp5xjJ96bsLbuO3Ga6c6Tajl50G7 jANIunWqDAkjz3yRS919SkqnY5toiD0x60hUgAY79a6htKtmBxKn4mj+ybfGPMU9wM0ly9waqdjl XRsc/jgUFcsMLweK6n+xoixCyAN2GaadEUHCOACPyp2Xcm8lujmwCBjbnsOetLtPIwPzroTop6o6 89OOtP8A+Efm2hzkr64wKfKu4c77HM8+nGfxpTwcc/zrof7EkU/Lg8dOlI+iv6Dce/pSsPmZgEen /wCumr6YIzW6dDnGMqBmg6JMWHyH1z0ApWDnMIZ9cjpStkD1xz9a2V0OcHhOAf8AJpTo020cAHuM UWD2hijhgTwM4pduMZ4rVbSJgowjYNKdIuMZWMk4xg8UcoKr5GTtPXJ5HPvS7PmBx7EZ6Vqf2NOB yMEjJpkGkz+YSynFLlDnuUMELyCD9a1tM+6xYMcDrjHFIulykAxoT2NaWn6bMkbF0YDkdKzm7RZp S96aRwF/EDcMxwCW6A1Ase0gjjjpnNaF8hF1KD2Y8VCq5PfJHrXhT3PtYfCikVz6kY4OaXy8NhgR xnGKnZT7E9eeOKPu/dweh4qRkQUdccZ/zmmMgPHH97ipwMD5eg/SmlCTkDPHU0AMWHI29jzx1pvk bmySfyqb5gvHU8dKGPX7wA4wKQyKSJVA7cY44pm0gYGcEY6ZqR2DE+w4HpSoc8DPrgdqBsr42jC+ h/zihgeqg4NXo12srHJIPBIp8yq6qAcHHYfnSuIzlQnB6n1z0p+zccj8xUqoO3Hr2qRlx94Edx70 XAqMp56jt9aUkKvOSMEcmptmfuNlRwAeKRo8YyOvHXNFwIrNRc3SQkYLcD2r0Pw78PYWliubi5BA 5wF5rgfIIYSR/K2eo7VvWfinU7O2ESzk+hZe1Jgew3Q0vSbIqqqpA+XPU1wl34UXxBfNKZBHEeGO efbGK4+41q8ugGmkZhnuelXrDxHe2MZRSCvbmlZlXPRNN0LQvDtuG8qJ5QMGSQDNcN461CxuLhvs 4DE46AYFZuo6xfX+8yvhTWK0QZRjoc9qqwj2D4UaLpt7pYaaONnP3t2DnmrvjH4f6fcziSCFE9Sp 2/yryvw74ivdEnb7O2YzjCtXQXXxCvLmPb5ag9BzzSBGtF8NdOKfPcOg7bD/APWpzeBdDs/mbzZG HI3SYxXJTeKNQfhZimOcCsy61O9uQRPO7gjH3sYoGdzcW/huyjZY7e0U+gG41wes2sT3DtblR83A UcYqqF2sPvDvkng1Zgt5rmQLGCnOSW4FArmcsTA7pBntuWpVidyMKWOME4zg10kOkRKpVm+bsQO9 XYreKHqgZvXvRcNDBtNJkkPzBtp/AitaHR4Y5MgNn+takZymDj8qeilieT14GKm4DDaR7dyDDHGa reSEIAXbg9avA7X25JpJYRJ2569aGUU2wRtOcY64qvLnooO/HHPFTyERoS5wADgms+WdRuJYAA9c 0gHbjtx26c1WmlSNW55PcGpVmBTk4579KxtRnBON3Of0qkhC3zLtYrjJHc1h3TksvGTjmppro7ux z19KpSvlsgqD6Y5xVpCbGMXDfj19ae2d24fLz+lNzjqOvfPFNMnzeoGMdqoQvJ3E7iPelUE4wPxH rSgNksw4FTbO2eg5we9IRIk21Arfd6DHaj7R82cHp2qhht239TS5I6DnOPWgo0RN8uegPXHc0RyA qD0J4GOaohztO7IB/L60eZn5gf060xGqGQnqRjjk9akACkHv0yB1NZHmuMD7u4YHtThcOyj5j6f/ AK6QGqD0I5OexzUqbeOSPpwaxhcMuMnaQeP61It1tIA+ox1oA2NyrjDZxntR14GR25OayVud2Dyd vc9al+1YYt3x37+9AM0AmFbBJPvSbMdBjB/hqp9vUqu3OAMY60sd4CM9x70AWsEK315A6n60uAce tRR3Cc7h8/THXFK06swVaAH7fUYOfSnBQeN2e+RUSzgKfmwMZxT/AD127mHHcDikBMoG3JzjpxQo OOTyT2qsk/zYz8vB61Ilyp5BHUgZ7UAWduWLZ/KjOBnjjkHNNMgXCjqBgelKZN2Mjt27UrACjOM9 M56dKsK3A29e2Ohqo0iZXHzDPXNL5gwR6HPXFIdy1uwM9PlGAB3NMV8MR8uAOagabI4JOBim7uoz zQBpCTs2cdM1JFKo4/LsayjKyrhSPqeSaVboliec44yOlOwXNlpVCnBzk9BUTNzwfpVBJySoJ7Zp 4m+XGAACOgzTsBf3fLkkj2x3pjDOTwOaq+ft53df0p/2obMtjjvQIfJEp659QapynyyT82Owqysq suV//VVa4YEnj8KLisIJwOmcAdKk87cpyOapMvueOuDTDLsHfnnAqkKxfN0OxIPX2psd1uJOAOfW s8nd14B7Hmk+YMc4A65phY1lvSRjGBjv3povoz3PPtWZuYgEEjHp0pPLP8P3Rk8UBY0JL0MV5OOv FEc+G9e2KzlTB57HIwOtBLF85OaLhY1PteATjDetRrd4yOmeneqBZgTgk9qjbnkMeO/rQFjUN+u3 DjnHOO4qOS+JC4Ax296zN2Dhic/nTmJPAGcdsdKdxWLZuuuPu0R3C/xEdMZ6YqmR85x6YprDrigC 5JOu5eR+FKtyNuSeMdKoMvUZwRTSM4+XANAWNIXEbdT0OcYpPtQOQSB6VnFc4AHH1xim4J28jGe1 AWLzXA5OAT3NNS6zkkkcVSKk5GetJtx90DPbNIC+JwUznDfyoafI4yQBmqHIHJ59PSkZj1yfXbTC xoxyqp54+vSnG4j3Yz61lkE9O45pCxBGMe2aLjsaDzo7BjwaEuFDYPc/lVFsk9Tx0HrTenAJ6dKL isX/ADVLE569RmkEuAeRtPGc1R5C+59KTHJyT+FFwsaH2kL0wO3FJ9pHseKzyOhz3zijPOPxxii4 WL7XHYYC+vrSC5w2V4HrVLrxyKRc5H9aLhY0WusDgg+9C3O4dSV+tZ/50ucfdOMUXCxea5A4/wAi mJc43Dr+NUmHoetIvt27elFx2Rf8wMGORg1CZMsMdupBqAluhP5UmcZyB160XCxayo6n3oVl6Y9q qk9BntQOnUg59aLisWgyjgDt+VHnYY8np0qpvx/FQT159qAsXldcDdSM455HqBmqece2eKTccjnn tRcLFpWBzk044UZBHNVAeh/yaUsx5yaLhYsbhnn6DilWQDB7dx0qseP85pN2fU+9FwsW2cN1z6YH SmAqM9+2MYquJMHBpfM3YxjGeKLhYtq64weO9IJBgZ7jseKrMc55+tKoZjxk8c0rhYs70wc4/HtS Agjrn3zVdt6n5o2z6kU3zAc889SKLhYt8KVzkegpJHAPP1HNUTIT/eI7YGRSs2fu5z2FFwsXFkHb H+FO8xcDBqmqynkRPjuSOlG4lsDOT0AouFi6W/vYOeetIpIOc4I/WqnmMudysv1p6yb32qRk8Gi4 WRZWUN7E+1JnHC7vwNVnSZFy0bAdj/hTA5YgKCWJ7U7hYujg4LfKPekBUAe3eoBHcDpE/wCVL5F0 RzE2fpRcLFjeAD09u1Ir8jsccVB5NwuA8UmPcdKhLnO1gR9aVwsXZHAPqfTrTFbcw54qvk84PNG8 q3P/AOqi4cqNEMkYAJGal+0sF+U5IqnDZ3c0assLlT0IHWnrZ3QODEQRxRcLF6O9C4LZ29fpVj+0 1KjBwT29KyjaXQ5EbH2HU1FLBcQnMkMgBPXbRcOU3V1EtjJIA645pkl7kjnDZ7HtWGJSAc9/SgSk kE4z05phyo1ZbndwSDzjio/tPPByeRycc1m7i3QZPTNI7EnceD70rhY1FveqkD161JHMZOtYhfpj 8qs2c7A/7VFwsb25VQg/qKEj80Z64HNQWYeduuB1q3MvlwkqcDHNFxtHM+JJltlPl4zjqe1ctbX0 rS4O488c1q67FLK3QkeuayLSxl81c4wD1zVXJsdBbySbDySc9TTvMc98gnvT7a3fy+RxTHGGIxii 4cqHebIMbmbHbBqeG4fP32GeMVTP0wO+DSLkdSRT5mHKjZhnZcMHYMevNWobyeB98Ujqf97msKOU hucAZq9FJlQAOTS5hezRqy61enB86QY7Buv1qt/aEzPzI3zH1qs5GcdOfxqBgSfuj2o5mHIjTi1A tkO7Hce5zU8F2Yn3RSsrr0IPQ1jCPDAgH64pxyd3HT8KOZi5I9jVvNQaT5mlLsTyc1WF7KeRLJwf 7xqn354+gpM8jBwaLsfIi8L+cEjzHIIwBk4P1qq0h3ZJPBqMsD1Bbt1pM8DPp+VPmYKCJwNwxkkk 5qRHcDaHf3xVUHqDnr61MjDjPTGM0czHyovNqN4I1RriUxj5QN3SrNr4gv7eExRTyEHjJOcVjs+c gZ+tQMwz+PajnfcXs4voa15qV1cLie5kcZzyelUQ7A8SMO4IOKrlwV44yME+tJuwo5P4Ck5MFBLY uxTyJJuSVx68mnNdTlyyzSZ9jWf5hB9+mKRbjc6pHndRzsORF2a4unUq8kmDn+I1AZ5wy5lct/vV Y+wX5TcYJTxzhOBVORXjf5+KOdvqJ049iXzJmGQ78f7VHm3KrhZn29MEnioc+mM57f1p4l+YFuB9 afOw9nHsSJNcBeZXYe5NHnXJYZmkHY800OCv6dakLBFJOM9BS5mHs49hJpplUEysMnpmq/8AaF0x wksmOnLVDe3W98Z4XjitLRdPW4I3H5scZGaXPLuP2cexWN9fs3NzKQOevFOju7sOC08gA5+9zmui fRtmSnOeOnFZL2DRswIXg8UvasPZR7Ef9tXygATyD6t0rpNJ8YX0dskUhVwOFJHauTkiKZ49gcUK doA7CqVWXch0Kct0dmPFlyJzIQjA8BfSuj8PeIbW9AS4KRy9h615ikvGDjPr0zSqSoJX5T67q1ji JrW5jUwVOatY9jutV0+3Yq8y/hzVO48S6ekZKEyNjIAFeSfaXLYkcnjqe9WVn3xDYSoPOKt4uZis spo7ZPFkf2ouyDZjsetVH8U5vN+R5W7JUdxXETzMOn696qiZ8EHkf57VP1ifc0WCproepw+JbO6n ITCJjPI606TxLaJC7RgNIvA3HtXl6zEL8pO7t7CpEuMFcrzjjv8ASmsVPuT/AGdS7HZXXi6fzTsi QDGAnp+NRt4suF6ImPTbXJNck8nbknuOKaZc98cYPPX3pPET7mn1Kj/KdkvjCVVPlQpt/WrsPjp/ s0g8lDIylVIHQ1595p7AnHFSrJgYPrzUuvO25SwdJO6RbuLgys7v1PTvUfmnbhB+nvUDOWbHU0B9 uTnnrjNYM60TZJPzHPbNKW47g4zwetR71I4x05ANNyd+ABjjvSGTBcsu7kY5z2pVwcZHfGAM80yM 5U5wG6Yz2p27jg9cCkBOVDRgjJzx1waai4JH6k1Eswxgk4xnJNSM5QjJGOuO9ACm3U4xyPbv7VPH Y7uedx45qITEY2gbuvPap47wqQ2M46ikxksem5+8+0Z7dqa1k4/iA55FSLfq2F4bjOM5pTdeY+OR n0oAgazO7IzknHHpTnsAF4yeeef0qfzdjDtg7iad52eWIXPJPegRSe3ZMEqMEEDnJzTRbDuGBPQg 5q3IwVcsMg9eeKq3F4IV/d8nJHFCAJ4liizlj6cVmyT7uhPXHXNOuLt36MOOeeOaobgG5z1pgaSS q8ZJyT6U55EReg3Yw3PNZxmwAOOKXcc9D07niiwXNBrhcYbBPSk8zK8rlR71nRtjktz9etTRuehP APFAFvbuwep6dacgABC4P05NVFcge+SQOxqyJ1JxngdMDrSYyT72OPm6YJ5qVLYycd+v5dqptMFO VcZzn2q3Dcqcbc4OAcHkUCLsEKxkfKvTjJq7A4UnkD2zWSsoZuCAeatxybNvAXI5J/nSA1/tGdpY EA985pd4GMZ5rI88Bvr6VZW4VFBL5z/OiwFzeVQbTmpotQCjgHPTANZrXkagYK570ilR97Gep5pc ozUS78yQFce+RxV6M7kBBPI7HpXOtchGUkgnHOOoFSf2kqL8rEcdqGhmnfQeehUEfSuS1KV7SRVm Ygc5UdcVvW+rR+cqyMPLx3pmv/Zr624dWbHynABx6UJAcg2oSFGA+oPrVOe5MrEscndjI71N9hYE BGDIenqKc2ntt5JUjGeasRVVgOWAx7jJ4pjfMcAH1GBg4rWTTSAfm7Z3dM1ItjsODhgOG9qYjFZC eowSfypQvOcE5x361svpwDblxtxjBHT2/wA+lP8A7M3Jk7QevTrRcDHWFi2DhQeME9amjUgcccDP GQK1VsyuWBBHfHSoTaOeTkBSMY4qbjsYZRlY7l4Ycc1GeFGdxrSaRWUYGCf4QOlN2KSMKRjvnFUI oHLKR1HU8cfjQwYfe4HatPbGFxt5IxnPWnxrAQdy559e3+FAzJByeAQeuMdT0pNpDcYyfwrQKRLt K5HORxUSxxBRnHBJGBQIp7flzjn0pwXaMcnvVkCM5APfkA5pcIMnPPbnrTArsvPfPc4pGOCO4659 qm+UxhWzn0NNYKDhT3xQBBlieVz3A6U5WJBzkY4GaeqoRx+VIVUYyQBnnHegBvmMvIPQYxjinmUk 55Pbg9aYSq8ggAnjIpyBegxntjj86LCJFlZRgfmDxSee5UAHI5xxTAAAM4HqM4pB2BIIx0BosBIJ nwSBz25p3myHrzn5jmoB/tc8+nSnIVJBzk+9AFlZyD/tU/7TJ7qenXtVfPIx16+lA2Ac8ZPTNAFq O4zGB29fSlFxg9iPXFVsAdDz6Urf6zrkjAOKSQFk3JwRgGl+0/MAcY7g9aqEYzyf8TS8cfNyfUU7 AW2nxjqMDoaI5xkZABA59qqKQeTtJp33m65/GgC55+V7cjnHpT1uDyMHJGAc9KpcDOMEnrg8UsbB doznrjnrQ0Fy88rHox6YpvmNgKemcZzUClW6EZIz9KGOMAkmiwFhbgrz/dHPala6IODzx0IqEYaP IOc8fSjHzHAOKQiRpeuSOuTxUZk9/wABTSnJ5xn1ppXk/d470wJVfGBz+BqYMCvBOOvNVDwOvGPX rTQ+FA9Rjr0pjNGEZYY7U8plunNU7eboCc+h6c1cjnU8E8jnBFDAVoc4OCO49KRoP7uTzzVmN4yM twcZ5NPbb7N354qbgZ3lZ43YPUGo5I9uepBPetB4xuBAxj0pvlhiASc9aAM4L8oBPA/OhgCMc5+t abQr5ZOMnPTPWkFqqdcFfTHWncLGWwwSM4z096TBYYPJHTFarWiHAOFOM9Kj+yqFPHvwcUXCxmt1 9uhyKYcccZ44x1HvV2S1AbC5/wAaiFsx4OPTNFwsQMR1yKauCTgHGPXFTvAxPHTufSnLbnbwDjr6 0XAq8AHjHPFNyOvX0xVhrdguf1qMRk459s4ouBH1P4Z4NIwwff8Ah5xmpfLxxk5I496Qo3QnkjIH pTuBEMHrwcd6Ruv9Kk8pjkMPTnOaa8bAHA49fagQmPXjPTmkOOAfl+lOwc8A5AzTSvPoP5UAMJxj OMnrQ2R1/WnBflyTml2kY78elK4EfO4nOfY0A9M5pVGPTGKcFOOcjPFA7Dc55JPTNKDj+Wc80oXD e+MjNBX8uvNMBvfjNLg84pQnOe/5U4IcjjvzQBHgn86aR+tTY3EDgEDFHlk/d6dKAIRw3+eaB79D Vjyd3Tufzpnljknp0zmkBDnnvnpil7/jxUhTr+tCx8cAD2piIxznj3pO/T2qXYTx0/CjHJyRmgBg GOc89cUE8ccdhTwnfp7CgLkcZ+maAIi3px2pcnI7U/y+R69DxQyYPGevWgBmfp9KaOp2n9KmCH1/ DrSbMsMUMZF7/jQG/nTthz684zSYJ46n60gAtyM1oaON90i8be59Oaz8VLbyvAwdM5HAxxRYD1S0 02ze0Xz13cck1xGraLCdTxAzKm7B71La+Jpo4RGwJHfJrOn1NpZd567sjmpSGei6PoFlFYR5HmAL XF65pdrFqo8rKRk5wTmrMHi14YDEg3Aj34rAv9SluZ/M6HH50xHe21pbx6eFljUpt7jNclb2MMWr HZgoxOB2GagTWbgWnksxIHAzWV9olWUyqxU5PFMDvNUgt5LP99AjgDqOCKx9B0u2lv8ABjO0YwCc 1k/2xcmERk5+tRWupXFtOGT15IOOKLAek6vp1munSIYhtx9MVwmjQRrqTYYADoTS3PiK6nt2jYsc +p4FY8M8sMwYHPNFgZ6ulnby26lwD33dKhOn2hZsIK4aPXp0jG5mBPGKUeIp9+Wycds9aVgR3smn 2i25+Q9D3615v4hiiguD5TcA455NaM3iK7ePb90Z/KudvJZJ5tz/AF4FAyexQOwzgn0NdbpOmW0r p5tvGQwyeOtcXEzL8w44xWja63cQemc5pgj1n7FaJbAKqqAuMDpXLX1pbi6YRyECsFfEV02A7HaR 0pp1bu4yewqQOr0extfN+Z9xHI9q27qwtXhKuiuPevOI9cMMm5Bg+mOKmbxTcbCOnHKkZNMLl7VL C2to3dIIxzXL3GBN8mB9KmvdUmuW+Y8H1qiXLMNxz+lMQuckk49xmg9Ox9qQduTn+dIzAnPIp2Ab IcjHUj0q7pyA9eOapYBOCBn86vQShBxjIpCOht5RHjtkYNOmlRlwSCTxg1g/ajv4OOc0/wC0nrnk ZPFFh3HXNsjuQePWq5s4l6Y/GnPMTnB46UglJBBxjFMRYAURgDt1AqjdRAtkDHpipDNg96a0mV5A z1oAonhiMYxxnFN546ip5AOp49agYdRjvQAmOeMDmrsMfydTz3xVWIYYHkkGraMFxgjpxigCfOTk fyp8eO+c+tQeYMZ6nvzSb889O31pAWHI6decims42hj7ZzVVnJz78Cmxse5PocUwJzJkjv361G74 +6RnPpSc9/u9KjduOOnbtQIk35Hf/CmiUnBHHOaZ35z0zik/h6+9DGPMpIHvSLI5THQdeKaq9Dg4 pdgODzQMViR944NAf06eooC5UA84q7p+nteSFUYD0z3pCKoYdWPsKmtYhNcBT36jNbg8IzhVYTKR 14FaFp4dS0UHazyYzk+vpSbHYn0zw7p8kYaWNpGHPJroLWysLIZiggjOecAZzXLX13d2ecRnbjkA 9aw7jV7t5GJfaTxgH9KWoHoGsajAkRwylvTpXnepFZJnEfTJOaikvHckuQ2eoqDzc44B49e1NKwg 2AKSD39KZJxwcf1pTKSpGBnGM9KavJ549aYWJIE3MrH14q+sCleevfNV7eXYOgHPFTiY4AGOvNFw I301Wk34BGe4zW3paiH5c7ccYrMW52AHKk9CM1J9s/HPApDOlFwgX7w561mXzxsSykZz0rIe63dG BHbP9Kj+1kjrjHGaVgJZ03E8Y7+tU5IwoJHbrQ1yVYjqT/Ee1RvPlTnBB4oAjlfa3PbvQszHG4c1 BI+7OOcnGMU5Rk8CmBJnccjBqWMnaTlgOuDUSnIOeefpTlcBTx255poQSIeOc+/rTAMDnpjOKVmH t0yDURfnnrigLDiTjgN+NJuXPT8M1Hvz1xmmt34HBwOetAWLKsOOlDuNoGeOlVmchf14phPPPHfr TGWQ2OcAH60eZjJAxj3NVgccAe2TTlHHA7UgJhN8p6jmk8072wSe2cdKgxnOcdfXpQpy3HT69KAL iSY+7kHOSakWY9H647VSMhHYkDnpmnq3zYG4c8jvSGaCy5xnk9s96czbyM+n0qkhZlOQeDwfanqx PGD+ApAWd3y8/h3pxYtt2gg9AeuP881CDtG7AHGKdE4SZSeF/OgC39jvSQUt5GT1Vc5qK4WSJsTK Q2MEEEYrttH1e1+zY83Y2OpPWsPX7iKSZ8SbgO+c9aQjHjGOV4z1PrQrsGXGOOef1p6HjHU4qaO2 Mh56du9MZHJcEv0x9KYLhicgYGMYJx3rcs9Pj8sllUk8Zxj8KivNOURkIgOe9SBiSXTKrKh4Hrxz Wc7ksx5PQkCrFzE8bFeTj8eKrEdCw+X2q0AhPHJ56cnpSHnkE4470Y6Dv6YzmkJOGLHHbFAg6Hjk 85GalXKjklc9s9KiwOOBkkc04KvAPTFADyfTOO/vTQ315PPpQpZumfwqVYSV79eKBiRuev8APpTi 2Vx3HPXp+FTLbsi5ODxg981KsII5OfT1FIDPXcTlflGecipFVyOjdOeOtXGXYRgAEcD3NRb8MPb5 jigCS3LKuN3QZq15jHkcg8VUVwcgEE9B70hlyOODnGfSlYZK0rEn58emRjFNEz9dxx/h3qAyFs49 emaTf/ez7ntTEWC7ZJHzEcULcyqCAxyPXpVeR+hyS3amNLt6jOeeegoAs/aZDk4LcfL/AFpnnSBc Fhu6jnNVGuegDZxnbg9KVZlPv6e1AFtbhySWPPHJHSrC3DSAKrnC8YAqiHypI/AnpinccEnk424O OaQy27EEHbgjoB2pEjup2VIoXmPQBRyKhkLBBgnGM89q7TwfrVlZRx+bKElVfnJXHfigGc7BpWrO PmsZlXr8y4A/OmXPnW6kTqYyDjqDzXo+seKtPe3IjmWXI6ZxmvPdVuYribzIkwp5Pf8ACi4FfzCe vUDnn2p32zJGQxIOcFuhqBmRVAJNN5lbKrk4xkDrQMuR3q5w3ynoeOBUrXiRsvO71xWbcRuHKsjE nuvNVldS2MfUE4NAmXzprM3Mh69CMfjRLZFGACkhv1rejQDkk/N078VLkA4YL07Ci4zmltWByUwM 5AI60slmw3e+FGBXQqA33cEehFG3AwDwRjg80rgcw9o6lvMQADqopr2e3K+XtzweOa6dsEkHByPT /OaaEC/N1HTg8VQM5r+z3YlcHC9cjGfxqJ7F2QERgLnHSupMQBJUkAcfSjy1b5QMjpgjii5Jyr2b jIKkD72cc1G9njHfHPpiuq8oFsnAycZIzULqrfeRcle9MDmfsw5LbtgFVZUIOVHU4rpJ0U7umPpx WfMoZzuUY7H0pgYOSA2MeozVi3iMhwQWJOasyW43HcpIHfHWpoEVTwMgcHjFAhI7UlF3AnPTPUGh rNlxtB5OORWnbOpQdsZ56d6vxqpXHHA5PagDnjafu+NynPp3p8dmpjHBOAMH1rotm4ZKqDgc+lIY 49mGVQO+Oc0gOfezG8gDJzjp1pTp5HJHDE8H1rcjgjDDPJA4z2p/lKThzu9vWi4HOizbGPLO7PHt THtDtPykYPQDODXSMnbpgenSgRIFCnHuCKVwOWFmwY4U+1SfZGHPI9MiujWKI8rinFIzGVOPXNO4 WOY+zYkIOBjinG2YDpnoeldAbWPJ2lSxyckdqUW24kqTk/pRcDm/KJxjnnr0xQYmIBK4B5x1roms 0ZsMc/1+tO+xx7B0x9aLgc6IiHzg7R04pypkcZB9632tEKEDHTrUCWirzuyM5A9BRcDHVSJCAMDF O2Fm74zgVrG2QFuOvPIFC24DMxJz6Z60CMoqx7HPcnikKksQOvpitU2wPQZ9qDZkg5wB2Ap3GjGY EYwCD7jFRtwp7elaU0IHU8Hgc1nSADPJwOeaaAhaUjkHcc4PegXbrjcSR1zio8Ec/jzTWTPXntxT A04dRDYBOOasx3J4w27tj1rnmUqcnr2OaFkdG64boO9KwHUw3LBcZ796f9rUN8+Cetc4l8+fn4PU 8VOtyH4yM9+KVgOhW5THPGBn2zUvnKy456dawozjOGycHIq1HLgYJI457UgNIy8becd+aaZVO1SM H1xVfJLDngjjFN6EDH4igCVpAwOcgUwuCB1APOaibtzx6VGzE4I/OkMt7ifl685pqsuM5HXLVBlg DwSO+aZv9jzwMUAXUdSvPIxjnrUTbSDgfr1qAvjqPxNRtON/JPtzQBYb72O57UrqDj1UYzVbzum0 jDdAO1L9p6gHrwc9qBE+AR8o7+lNcAdV7VXa6+Xr1ppnJbJOPXHNMCQqDggHJNJtVl5B579MUgmy MNjHr0pxk78k0AIUHt60eWu0bcgZpplXgcZ7GlFwApHT37miwDSgHufTFJgqOmD24zQ0wYDJJzS+ YDyCT2zTAa6Zz/L0prDt17E09pOOMHPQVGZsf3uenFO4Dio4H6kU3GVPr160nmDcB0P0o3qVHr70 gF9ie3SnLjG3GO/Wosg5xz3psjcZOTn0oAn3FuACOOvpSfiPxqDzOe/tQJAMbcgA5oAf05OOvelH B+nNMVuPTjuetIz9AMjPvigRKzcdeO+adjI9j096reYP4jwOKkDHqoJ9wKAJ2Hy8ggk46UxvUZ44 xTPOLEcH1pvm9OcY7UkMmwOQMfWgjGMEegAOc0zzMZPPftSCT0xnHWmImzjPOKQADOPX8RUPmfK3 BB79qeH6bt2KBjyh6/pSFAOnHPHGaYZRjA5+nBpVb2Oe1AD2iHTuMZpPLHfkiguQO/8AWgvk9vyo BibAOR97GeTSMg5zn2wKGfDdD70biMd+1Ahdg9MCnbVKcDI/wpocj7+Qc0u84JHTvQMGjz0x070e UQexOKN2ScH8qNxC8EnHegA8kZw3PpQ0YJ4+lOBOSOpJ6im7/lPHOcGmBGEy/PPqaeqAD39c0ofd 6cH0pGbjmkAxsZ45+valgTdJxioWfnt/9anwsSRtJ69qGBdkiDKdv0Iz1NSxWe9lIHPQYqWyieXp j5fxres7dUUf4VLY7GBeWBjt8qgPvnFZKwOXG7gdAa7y4gjePBx1xxVOKwQPv/u84ouFjFjs9sY4 PpyKimg2/l1zXTzQAR8Y6GsK+G08Dr74oQGPInP+FNyCO3XmnSnHLeuKjBPt+NUIftx1z6YJpvO6 ndsjOPSkHH096ADqB1xSZyPpTmXjH6ilVcnPP40xEYHJzz+FSKSOnbilKDv1xmnLH83XjHrigY0c kdelO3/dyOvp3pCMY6c8/Sk+mTQIlZsrwO9RZI6ZxSN157ds0z26+9AEgJ3Z9eKTdlj1qMdMn+dL 1x/WgBSeODnjH0qNlyQcf0zTv4gRnNLhmbaAT34pANUYPbFSbjjGP6U/7HcKodoyqepqsXIbB9KY 7EvJJyQKdnCg8geuareYQ2fypjS9CDwKAJ2kPrwab5mD0/CoQxbt2xU8EDSYHr1OKBFea72nj+dS W0hkHBzT59Oy3X8hV2xsvLI5479qGBCY225zj3qPoOv1rWljGzoMeg4FZFxw3v0pAwWQDrk4PY0o cMeuc8dar5I6fXOaVeOW+uDTAuBA2QAa1NGvBZyrvUlR1rMtZFOQeO9WZCME8f41LGdpHrtqI1Bc DPTFKNciKlSx71540m3OCAelItyysNrtxRZAdTql6J1Ocj05rm5mJYkY/KoWnJ4ZieMmmmTjhs07 AS59QevPNKNzDjPvUAkAXv1/Ok80jnnA9KYFgZI9ccVKo+QdPU1SWTDHnnrUnn/Tpkj1pAXcHB6n HrTQSGGRjI9elV/P7E/rTvOz7mhgWOMZ9utKD9B0PNV/Mx6e9L9oXIBPFAE+4jsD6ZpvHX3PTvUa y8cdByaQSpu4OMcAjtQIbMDz0/GoiSGPA+mKtZ3Lj8aQgHOCOvTFAyvg4HGPepQSoAI4zkcdaUgD pj0oyOgPfFABhsDgZ/lTWBxznB7VIFGTtJOOxNRPlk9fbOKQiB2+bpk5zxzRuOCD9TmmmNgcdfUe tGCGHHTjNMBx6H396XaM8HIPSm54yOO9DHjpnHb0pgO4zycYHajGAQQMUxWwcH1zTkfAGRjb0wev NAxyxDrkgDmnFcHP65pyOCfbHpS8g9Oe9IBuwE1oaPFC1xukwMcAHpVDA2nPHcn1qSMbdoBwexHS hgehWcFoYcGKF+O6inPpdo2SItnHUH1ri4r64jRQrkdqtwa5cIeTkDnr2qLMZ0Fxp0MH+ob32lRx WJdkYJUADHOF6mo59Sedecr65PWsy5kkZs7uCeopgObg/KM0wgbscc9s9c0n1b2pwxyBkZ5z60A9 gj6ey9s1Y28c8kHB75qLnoMjHPPepEfDdRQBdhQrgv8AjmrMcioFx9eO1Z6ygqB3IxnJpnmgnrgk 5oEb0N4oAyM8nrUr3qmMggYPfPSufSYkgZ6+o60olYblPT1NIC1coki/L6ZBNZF3bbGIToPf+lX0 c4APXGSQKJPnYluGxgYpgzCOFY5PIOM0pHHuCc+1X3tleTn5uOTikjtAOo/CmBREWSBg+oqzDbYH zD9KttAEA2nnPT8KN6qSAeBzz2oARIY1OFPOOO1SbFGDgHHv1qvJKFx2HXjn8KYt1n+JumRSGXmT OAR+tCxseV4571R+1k5AAHPJpTeupJ+8voRQBcaEMR6Zqs0JAGzdgdu9I16NuB0z0NMW5DD0yOma GALEflP8hSuuM4+X2NKJfmHA564OaM56AMc9jjFICLG44GeOc5prAhQAOccCtKztg4O4e5I6VNLB HgqQOOfXNAylZ6c1ym52CKematp4bBJLzjBzwoOPrV2zCopVUXnsauyXGI8kduuc0hFvSNCt/s4V /JbPB+TNWZ/COmSgsyMjnvESuPwrnvt8qt+7zgcE5IqwuuX0eAjkLnBJ54o1KItX8MwW0JktppT0 G0qK5wwOu7AzweprpLrVJ7wYcqox1A5rLkg8znqMY+WqEUmB3HPf/azio9i9AN2Rj8qtG2wQN5JX 8zV2G1G3Hce9AiisR2qQvsPYVYhtnkPGT6461fWIBQCM9vpUwbbjaoHTGB+ZpDIo9LjJwyFuc9el W4reOPHT1+tJHKN+F5A7Z6UjSEMMEYxjmkMka1jZchVDEY9Kx77TjubAwAcZIzkVsKfnZdwZevXp Uc0iKCvqM8HJouBKHz1QrgZ5Oc01nIXOemMD8asrbA7yFJz03GmyWwUAKByentSGV/N3MAMEdelO yMHPHf6VLHAMk9cZOCaaykLjkgegzQBAGBbAP5npRuUt95T7ZqdbfepI4GM4zUh06RlVhtJ6D2pi KoAPJAx6ZokB6jP0FWvsEq9UGfUU17WQLjaOfelcVik2DyM++RUMjdPveoq6bOTLEFlH8K9cVTmt ZgpUbmYccDrTQFKaTkgY5Hasy4kJJwwz0zV+6t7hNw8tiBwO9ZU3nhW3IfmOM4qkAAbj1PXPFSBO c85GOe1V1IyvVTyOPpUmSA2MZ28YpklqBypPQjPPNW4blVb5ivsR6Vk78qMZ4OD2pqyEHdvwe5xQ B1EcmQecn27VIqBjuGM+neudiu2ycsTx9MVftrzJBycEd6ANJslR0HOcUZPI6885qqZmZQSAV6cf ypDMQBweeuTikMstgH5s4J5zSBht2nGAcYNUnm+Ynpg45P6VG8/JOeOO9AjRQ5AwAv070/5cqDgD HU1kee6+w9aa9wR949OOaBmuo+bqDk8VKF9sc4GTWF9tYBckkDueKel/LnIxhjyDSA2TEcHkDPOQ c4prZG0flWX/AGgxzkdARx2qGTUDnLg56e9AGx1YFu46HtShCB0yB0HTIrFS+b+It14yKBqLsecD jjPNMRqyYOSpPtk5pAm45POSTWd9u65OR24p0epFMnAPt7UAaYUAn7oPbtio5pCF4OO1Zcups5JB 6cY9KoS3rF92Sc8ZpgXbqXCsclu9ZUzdcEe3NPafdncMkdMnrUGc8juPSqQgx82B06fSkK7vb8aC uW/A0nI6gEdaBityvX3yKYUyOcY+uaeueSeM8+1KD7n0JpgVmX5sAY/rQuU6k5znHpVkj1GPSmFP UEZpAOjunTGTggcVPDdhnAYg/pWe4ORt9PTNQruDevFAXOrt5lcgI3vz2qc52gjk4rlI5XXBViMV ft9RYH94CexPtU2C5t7TnGBgHjineUQcjkjsKo2+oJJ/Fx6GrqTq4yuDxxg0hj9nHJBPftUTxsDn HJ9D+lSrKpXGcEdSOlN3jI5G0nrQBWaAlvbHFV3Rx0BPtWgvPPbHakkxjleh4xQIygrlj8vfsKVY nbkZAHXFXuAx3fe9ulSxsowOg6Y6YpgZZt5fLJwcUio+eg+tajsp7Y4xgHpTGK5yAM/TNAGcY5eM qetKwIYBuDWkuFBzxg+tRSY5578+1AFXa27b274pjwOFyRxVxcfMQvPtTnP3uVPP6UAZpU5wcDv1 6UoPHervGCduRnpjFGFzuCgUAU1RmZOoz2FdFYxRpHygJHr0FZC/J04749avRXrRrkgH2FAFq+t4 /lkWNVKjGAKoPt2qMDHfI60T35bAXg96haTPOBn1NAxwQDjC+nSlCqFHA/KoxJnPI5PpTfM47Ee4 oAnZA3ocdeBURh2/3fYYpgkz0ABz2pxkI6Y5680ATxxqQDtU/hSeWvIKAhh0xUYlIVflwfp1phmO TwuOwFICe3tlL4Kr+IrprOKMxgeWjfUVy0cxTG0bTmrkWqSx+pHagVjevIoxkCGMc44Wud1SAbNw VR6HbUz6rK+M7eeozVCaYyEk/lQhme0YVsY+tJg8DPA6etWGBLZ4/PpQo5z+AqmIsaZbKXJZc49q 1poo2UqUQqwx06VnWrlHyD+OattOWTbjoc8daQyO3tRFIdi7mPAJGa2Fto2Qbo1PoMVWsondsgf/ AF61PLKr9wk9qVwKVxbIImHloE68is2GyiM2cZwc8dKs6hNNjoagsVlDBiOnr3ouFi8YYjEVeJGU 9eOlZ6W0cbkoo69av3L/ALptq4bqax/tYjwccetAi5cQRTJ8yjPqODU0NvDHDhYgT3OM1Qe+yAFB H15p66huHHGPegBt5axh8qgUt1wa0NNtogq7lBGOPasmW5ZmLdR6mrNrqQi+UjI7GmM24bC2Emdg GatNY2yx7RCuCOprEXWkVyRzgccU+bXA0WDgk+g4oAytZt1glPkjCj8eKzwN3pjFT3ly1xIWzx2F QFcj3HYUxWImXB5/Cn26YI3Z/CpOq45P4UqcHIGMjn1oA2rJgg4AHOelaRuFXGGA9CK5yGd1UgYA xT47huN2AB3x1qWM6E3XzDoec+lC3ie3XFc+ZiMkMQOopvnnZzwR3JpWHc35rtdvDAnpWRfShg3U MemearvcEDJOKqPKzjr749KaQivLgHr0pinPGe/p1qwkJbkg81pWOked94Y46+lVdIVjMRcrzgVI qYOMde3rW7Lo3kR4GWPasa5R0Y/IxA68daVwsyHGGGOvSlzk46ZPSrlraeaPmVsn9Kkn04xKWKnB 4HtRzBYz88cdf50Egfe69qkkixyOO1QYI4/HgUx2CSTBOSfWoy2SM9hnmlZT9KYAe2c4zTEKzDGf 4evA6UhPGByKVh6jHtTcE88+4oEBY8469KkhilmbbGhbPGewqPAxyOMeta2m7RDheDRcDNlgmgce cgXFW9Nhd5A2DjODxV6ZUB+YKccetWIG2xjDH1xmpGPmIWHbIxOR3rmbtMSZ4z6VpalcszkdMHjm sqXceuSeozQDK0nTk1G33v8A69Tspye3ahY/m5zz3FUIIFJyT0A7Vr2hCemQMfWqCDA68YxU8blG +U8imBckw3THHf1pnmbeAR0zx3qoXYHn1prP79+ooYFuacuoGenTFZ8uMnkmnFjVd2xknI5xUjAD HPB9aY5AHTFJ5gPTrn1oKMygjOO1MAWR1OVz04qX7Qx7npVU5zj+lKobd8oJGM8UAPZyzcnrQWOD nGO9Iyt1wfy6U7b8vI7dAaAGrnNKpJHOP6UjAc8Z9s0FT2xzxSAduYc44HpQDu5H86TDZ5GPpSEH HK96AHMcfTsKUN/dpmDu6cep6U4KTktz7Y6UAKWzkZwCeacWye/0BpMY68DOeDSclen0oANxHXAB GBz1pwbLLjnIqaxs2nfGcL1zitgadBbqNyebtHGD39aQC+H9HN1LunYbeuK19TsbW3hO2AA+o71n 2+oLakmL5R144zUN/q3nxsqqSeoyc0IZkyNtYjPyjjnio2fPvTHJfJI49MdaaOTimJEyuT14yeea niTefm47ioYk54z+VXYwE4xQA7bjPAz3A6UvlxluQPfHSnA4JOKazfL+fWkIY8eOgPXPXrVWWLBJ BPHerTyE8fMv1AqtISevOOKEMrEH68YpCMnn609sKPp6HOaZzyOR+FMQnJPqPTHWlx6jHt6UmcdO PSm/d6igZZik2Ej8z6/SpS/pjOao5O4nj/GnqeO3oTmkBYLY4GMd+eBUnm9h1P6VS3ZOc4yOPpTt 2BwM9DimMtLJyd+eO5o80DvjGOtVGJ4z3pzZJOSBnmlYC0ZsnPHUn3pBKeC3fn6mqpbIP6AUZ9On UYNAFwzAqc/XNCyZYnHJxVRiD3FOVh8vHegC6tx8vseaQXHOWXJFOhtBIuWJAHQg1LHo/mybY5JW yeMLk1NwsRmYMqnvnk+lHn9QCB1FbFt4LvLpd0byRqepkXioNW8M3GmoSblJNvJAUimBQ89V7fd6 U4TBuRndVNCw+8CG68jinDjnkHPPPSgRfjm27WLZGcYB4qV5kbjcvbOaz1PPv659akXJ6EE+9AFt 5D1HI+vNIZAvIUE4pkYLdecD6U/YQjMeR35oAbJc9sDPIyB3FU2lJbKDOaW5RgepBz3qDJGMgjvm gY4uWI6/WmJwwPb+hpwP94k545pMDbxxz160CG5w3P8A9am4zn7pPoafkKrdCAcZ60YyO35UDGKP QLTk46YyeeO1BQHOCfTpTwvzdD6kUAS8dz27dKdG2OF9PoabsIj5z+FSIMNz07A80gLVvctGxHQE ZODir/2lf4TgYyR1+lZYXHqWyODxQA3bkN1oYGgl1tJbIGe4p0l6ZCAuOmT7VmlSB94ZPOKY33ic 5JGODQNF37Rhs7v4gTQ0qkhuT9TwKpNI+APmyx9O1XNP0yW/kAQmMkgDKZoGSC4yA3Oe+RTTMpGQ 3PPQ8VfvvCWpWqtJG8cgALcE/lXPxwXrfKYJVJ6YQ9adxWNNJ1YFlPPenfaenIHHOBVe20nV55CY 7OUcZJcbf50t1pd5Yttn8sEjPyPnFAFgXgdTjHpg037WWZeqjB4FZpJVhnOcdc+nFP8ANU9ePx/S lYDVjn2AMd20DHFTi6WTnj5TnBrELFst0znC9QKIIpHYBO4POeposM3WuUAyoOM9R/WozJvcE8Do BVDy5RtHc/KT+NRXCyRg/wAIJwD/ADJpMDpo9WjxklcY6nj9acdSjOckLzj61wYuSdoOOOAG9akN 1KVG0hjtAK4o5QO2N9Fk45yOoHNNN6hYgkAY4NcebxyPmDKcnn04p0V46NhcgjGfenygdxDPH5YU EHuMVdSUdM8e3auIhvXbaG6rjp61ow3OY8b256E84pWA6V2z1cZ+tRPgMdxGO5z1rEN3vULuG7OA OtDu5YnJ9gDSsBrn0GMd6YxwwIYY9qy1mcsdrYPT3+lPWV8YJJPXHagC+xbygMAEnjjqKoXkG+P1 9ad5rlcDsckmmzl2HqT1+lAMyJbON8blYYycjrVGe0C9NzZ756Vuxxsx3Z5bsTTntQE5+XvjHSqU hNHMm2dc9eBngdRUDK47EcdDzXRy2uDncPn4z/SoHtyN3y5A707isYiltxypBznBq1axYAY+nQVd NlvyWU/UelTQ2rKmSCMc8HtRcBip/dJbjnH86ZMcL8zAnOcelWG/dnIBHHGOtZ90xCkheDyTjvQA bsuQSeehxUiDdyMNg/SqCvgDA4HB561NDOR3HHAz3oEaKQJu5yOce1aUVum5dqqR1Oe9ZC3HzDJz kdDVtNRWPAByfXPSkUaDQQ44jX6Y61GLRPm+XvkjtVc6wG/hRT60LqoDNu2twOBQBbNugOQoHrgU 6SGLAJjAOODtzVFdS8w5YLgcdamF+NpKqh2jB7UCHT2SSbi2Afp0qL7Em0HCjJxwOtK2ogEnbxgD k06G9jJP+yPWmAxrOMKdqqT649qqSWCH+HtxkVce8jIGAKY8y5GcnPTNAFF9OR1YbRuHQiqr6bGW zg+ta3nAcBsAjByeDTX285K4z19BQIwLiyKfNGxHPTrmqgjKH0x1weDXQSbGHA46iqc0SggEHI56 VSYGVtY9jjoSeKQgNkjr0rS8rk/Ln1qKSDcMgL7UwKPbpnjvTh1O04HfipRB8wB54zT1ix1X0+lA EaoW/iP508L8w+XHIp4UL2+U+tNYBeRge4NAEEi9ep7+mKreXyR29BzVl2xxwT2xUbdeen160ARb OBnApGypP+NS9W/xprL1+vagCuAUJbGOeatwzyKOHOB6VEw+Yk4Pr60KmM5XrRYRprd8DOAeuc1O s4KjGcZ55rMAGeCPpjpViHYp6/8A16kZbacg9flzkc9aQTMzfMec5ph2k+/SkwMj1/WiwFlXyTkn +eaY0pHfnn8KYcjPbPJxTWOF+lACvMSecUedjp0z0phyegyaCCf/ANdAEhmbOct2/CneYSuSSai2 8d8jFO29flHHqaAJPMK8A9+maQSfNzkc5xmm4YhT19aVcgZKj/CgB+SV5I69jSjkZHB6/Wmjk8dM dqM5znOP50ADY446e9L06Htjjml3ZJPfjOKQdAeAaAEX5SO39adt4+vSjYdpwOaVck46UANJ/FR0 9qbjHWn59MnH60n3uh/AmgY3G0gc9aMDbzz68UuGB6EA4zQFzzj/AOtSATvwMt1yD1pA2MYPbmlK sGAAO73oUEDGcc5oAVcEjJ4rSt02qCRxn86oKvHy59aswTbQOcH+VAjTa3gmT95EFI4+U1nXlgiA +Sx47Gr9rMC20889qvNwp+VW554zmkUccxw2Ae/50itjpz7VsarZxkB4k2Fjkj1rH8th2OOpp3EW oZflxxyeRV+12u3asiMEsPUcc1etyy8evPtQ2B1djtQdRxxVuZk8s84wM1zsN3tUY6jrSyXhdep5 4+lIZcuismcDI7UW4AUKe3XPNZ32nHuT39KX7Yc49eMjvQI0J9oU89e1YV9EADt65zz0q01zuPIJ /Hiqk7ZU459MChAU8eoPX6c04JtAJxijGCu4A8596XHJz/jTExFGOCc+9NwWA5JxTyeCCeOtM4YY JyM8YNMBQnGOvHA6Ujpjp6UuDu56deT0oDBW5BBxg0ANKg8A9TSD+QwPan/w8celO2FiQCBTuMh2 85xgUuf8OtSSKBt+bgDntTAQD1wc46UmInsoPPuUQggZyeK6uxsIggVk3HucVy9iwimV+Qe9droV 3GxbJGQPypMaMjVNG8liyD5W6cVg3MLRSYYYIPpxivSbyVSnzAN9TXGa4I1kbb93HHNA2c8wJyO2 ewzUe07uSeuDxmrDEnr1P8qZzntx6c0ybF/TEDyAMRya7TTbeNYjjknqTXFae/lMCc8frXR2+pLG uSSc/rWcr3KNq6iUx/SufubPdPkjPOSank1IyHqcdgT1pqzBpM8CjYdy1ZWioBkDp+VSXMAZfm+Y dKri78voeKf9tQjplqAOe1a0MZYr0z+VYbDnB+tdPqU6upAIJ71zsoIfnHoKuImQgZPcHpSEZBzu FShSc4HA6Cl25wcCqJINmF6dPakxn1B71YIJ29PSk2gfh+tFwItvpyPYVYheSI5jPboOabtAGVHb rT44mb7o4xkmkAjyvICc49eO9Sx3JX5c54xTWQqOnPTrUTfkPagBGO8kkcUmxSvOPTilBxwx+ozT t2Pu8jI4FAFd4R1BHvmnx2srLwCB1rR0+3+0SqpODnvzXa6fosCqC7MTjgCi9h2OEt9GubjJQjA4 JAqteWs1qdso+mK9OvbRYYwVcKoHIwBXF+INsi/KOM53UJhY5vfgHoPqaRmxgd/amOfmO0jrjOOt NxyDj3+tUSOxvPIHHT1pk0bMi7RwO1W4EznPH49DVjYAvTn1pXGY0UJdsDj0rasbYAN06Y571F5O G3ccc1ZSYIACw9jQwIrq0QHIxjH61TCEZwCa0JpRnHGfU1mzD5t3B/GgBpxjnHrRsBOPfApmTnj8 RilB9+aAJQqk/d6HrSBRjgd6buxjPakZsDnGc55oGSDBDH34pu0Ed+e/8qj3kfn+FDSZwRigCQAA DAo79uvrUQck4xxn14pVP+HSgB5AHOKdtzz096i3Y5xxmhXZjhAXY9qQjV06VIWG0cdxnrV+a7R4 znH1FYSW919/yHANWIopg3zRMOOlIYsik5xxkdOuaidckk5/lVjZJgYVj+Ganj0+7mIKxFQBn5uK LiM0RhuDxzzTliA/AYz61aNs8QO7kljTRH65yfyp3AYAFViOPU1KN33cqR296McnHpyPWmHuMAcc 0CFyxAyMEUhYYGO3IFIzZAwMcZzTGGOoz7CmAH5sAdaa+ehBBzzTs/NwpznFMbcRkjPpSAiZevUn rio2GeeeeKcxyNwz6etN/i6jNMY3p25zimkcYAJqVU49OcdelNKhD2AJ5xQAqoMjIPTinFM4IOfQ Y/SlU4PyfTmpV6gD6ZFJjIVjII9x3FKqc5A/XGKlGD1GOvvTwwHbHvmgGQeSRnknijyWJB9OSfar SsAMflQGG4jHHQe9FwK6wZwGweeMmlMBLc47cYq0q/KDj2p+dqkIvGT0HegCl5RHXilEZU59/StG OMMBlMnGcYqykIBIZcZ6AipbGVLWbayKwBHcAcfWu48OzpFGrEJnvkc1y/kIM4QH6VftmeLG3d6i pbA9EbUoHXCvuIGMZyAa5PxFOkjuOCSD3xiszz5ixKtgHqfeoWj3ZaRyW6dc8UkwMK6ty0rBfu56 0xLbrgkE8ZxnNbbW+/jgj26VH9lAZjngHjBqrgZiQEYC8n2pyx8c4B9zx/8AWq5IhCgqORzzxVd2 ABJGccDPWmIWPI6cHueoqdBwMcf7PpVPdhRjPzdQamWRVbDtgdKAJJowwOAuMc/Ws6aMswOdvbj0 rQaT5gCRyKhkIO4Fcc55FNAZig4IzjB6dadhsgjg1YaLactj0FQuh+XIG0jP0pXHYa68t09KckeW z949+Mik3Dj8QR/WpVkYrkYPbAoYCpAH5GfTpVqG0IH8ROMYqNZMdSOmOtXbeZAOCvrQIjazDK2/ j6HpSR26qOGHAx7mppJ0dCVwce9ME65BIA560DsIYOvuf1pPs3IwT/LmpRMhwynLY61G00ZVFBPX P/66QWGLbFj8xwen4Vcgt0XaQfm+lVfPj/HuoNKl3sY7TxnAGaBmjs+VQO55JHSug0O/jiwrnaAM BgK5U3JZSWxnGTigTvlscjgn24oA9Ha7t7hsRXCt6rmpSUiTcvlqSMdBXlrMwfknOc5HFXheTkKD K2DxQB213cBfvSrwOpNctrTRy5KyIe5xzxWc5eT/AFj545JNRqN3zOAM4yKYiubQliB0Ge3apU00 OeRjjnHQipfOUYO4DJzwOTViS4QNzyMdDQBXjsliBxx689asQRKmMdAeOKgmvFG/vx8vNRxXTHGe dwBweKGM1lRQN2xcE+tVbyJJI8soZmP8Jxio2uCflOdx/wBqofOzjIGOuR3yKkCNoYFX5olOOckd D0qtcWkbAssag442/wAh6VqrGoAGwjB4wMYqWKyExXLbMd8VbHY5aSAxngZ9Bmo0jyCQcEcY6HFd adEYglm6nsnakPh0DgkYAx06mgVjls7Q2GLH19KlglkDADDY561vTeHW7kD0pD4faN1kiDA9CPWg LFSMtnk4J6Z9asrMdy7SCeoPrUsOlXB2tsAXPIJpJNNnjI8oFgxwB3HtQAqsCw35HHapc5yBkA85 JpkdhLGczAliP4RTpAY17lQOM96lgSKM9Rz61ZtoMj+Env6VBbMGHOSM881pWrDyxxzz07UgFWLu Il46GmPAWJBAwOuau8H72MDrxQThenuO1IZT+ygdgQe2M03yQoxhVzycDg1dbkjntioZgN2ckc9q BDCmRgck9gKgmhUMDgEnkmhrhAeQR61FJMMZHXGBzQBE0SD7wGCOQKozWMZPCkZPPNWmk+b15xzU fmKSQHOeuM9Kokx7jTduBg9zkHNUGgaNQcZA6etdHIu5cICTjBFVWspnGEGT22incdjF+YY578Ux eF7jaODWs2mzEfNG3qeDUUmnTAf6t8YzyvFFwsZ25RnBz6mpEGDgED071J9lkYYCknJzxRHaz7R8 rHuM0xEiKcqeD3Ip54+7wcAkUkcL8gryvJ46VK1u4OWBx780gIh8vzDjn0prnHIqWRTGMktjPfti oN4Izx6ZPemAvmZOARn1p0bbmGenr2ojtzLg8Bc9u9WF00tgkkHsR3oGCDdGPnOM9/8ACneWBkmT /wDVVqPSm4JYn1qd9OAXhsdsUAZZRNpIY578U/7PEfvSMMgZ4qybZl+8dpPOM0zBG4dx3oAh+zJn O/rnoKDbxkcMVxzyKnRBjqvHvQ0RA78n680xGdJbLub94voMDpTfsp2ZMgIzyPSrckZ3YA69x2pf L+U55Oey80CKD2/y8kHA7dqqXEMqbsr9CDnNbPlbUIL5ye/aqs1vuVmCgnoR6e9MLGHICp5wO2M1 Fn0/nzWk1k7lskdfSopLNlY8DNFwsVA3r+VJ1Gc9umana0kRhuUD3HU0LbMMbgc+mKaAZGg5PvU3 ldBgDmrUNscfMPf3qwse3A2kexouBnLb7eTwSetSBFU498VaePJ4JPan29qW5IGM/wCc0mMqrGdp 24HbkUskEicryCOorobewYJ8wBz64p01rt4x+OKm47HPRylRhs46VaUxSKNwGc8n2q6umGVv4sE5 DelTQ6JsfGGIJz9KXMOxlyWyclfmHXFR7dr8Yx1rq4dIQKrZYZNSNpUW0fu1PsRmlzBY5AAAgDAO eOaf5ZOS+Oec10Vxp8cnbaRwOKy5LRom65/CncmxS2Nnpg+5qQQMy4AwfpzVxVG3JBPbn1qaAcqT jHqO1O4WM/7DLkDHAOCKetlMVIEbDPpW/CoHI5z3NSMM46Dip5mVY5pLOVuqHBHT0qx9ikOQFxnG BW7tYgZ7dKbuAyBjOaXMx2MNrAgnPr3phsW6gZrfAyx7nFIoGefT1o5mKxhLavn7h68cUv2Nxz5e OTzW+wztP9ajkXAOcc98UczCxiNaSHA24P8AOg2bj5irA/XrWwGzkc47U0jHOT6UXCxkLb7ugyfX NKtnKx5UYrV2qGGBzU3QDPOBnii7CxhyW2w/dCnpwKVIGyAEx34FbDqH4Zck8+tPhVWyAMdvShsV jKjhdMnZkYx9auxkhe/41cNszZKD9etMNjIDnGePWlcZm3gYsPlJU+hzWebYt91W9M4rfeJwwz69 KZ5YAAAA5zTQGGLKQEb42X1xT/JZAAy4/mK2+in1x+VVmXdIScHtk07isUFjZh90+lK0Tq2Nj7j2 9a0FUKeMDvkVb46lRkY7UAY3kvtyVYDPem+X83TuPbmtaRySSTwewFZ91tDDGMn8qLiIChxn04pp i3Adckd+lTL69j2xzUpB557daYFF7baMlRn0qNom2EhW/DvWquA2e/QZqXOBxk/QUAYiodvzDg9i KayAZHbH92tSQKG5Gc1XkCN6CmBntwpOMe9RMeeOR79ausnB3YwOg61XkHPPA6ZzTAYh4AJwPU08 M2MevBAqPkDAwB71Yjt2d+AxPYetK4IpzkjoDgcdahQFSM9frXVw6GTBnb85655p66Ad+SABntS5 kOxh2ke71JUdquW15Jav3A/Lv0rWtdHkilHOPw61FqWlllDqpDDt60XHYbJreU+bj2YdKw7u6aZ9 xAHHA9KSVHBwcA9D61EYyPUEHvR5iYB/rihTz6HoCO1OVSDz9PrUsahRyPc0xDQWypyRx3qbzn4w xGfQ0EDIz0PvQABwc5oAFmfoCSO+RT0uJBnqB7GoyFDepx0qReSCuFOc8UAAml3ct045qwryMuM/ UE9KiKKWHPuferlvEhxwOT+dIaK0iSEODxu7ZqpLbTbeEPXNdOsEPTavI9arTxIBkZP1NK4zmWDL kMpXvyM0mc88H2q9erzxnb0qjgZznntVksaXxyfT1ojb0/lSxxMW4UAeta9npUjx5KkLmk3YEjK5 37cEZPXFXIIJGXcM8dfetaz0WRps4GK3rXRmC9Bk96nmKscXNA6Nk8H3qrICBnv3Ndxf6UACCOcc GuWvLXYxD9+lCkKxj7hkfXOaXfgdzjpRMjI3OOPw4pEUkcjHNWI09KmWOTnPqD612UepxrCGyM44 xXBIhGNuAeepqz58wHyn5PpSsM3dU1jcpQZ5Hr0rmLy5aXIbPXIPSntuZhuJOOBS+UWz0FAig0Rz kjOaEhJYYGfoeavxQEJtJBz0qRbT5wc444707gVFjIUDafTBNOYjGc9zWmLRSoXOTj609dPXaMEZ A4NK4WMj5iCNh9+etNkPbAPpW2umgj7w6/nT108LjGwn3pcw7HP/ADlRlWHfpUEgJ6DoORXUNYDa MYOOue9VpNPBwSoOAeafMKxzhQbc5ycZFIc4/XjtWxLYouDhsHqBUElk20kA7e/FHMFjO2jB569O elLHC0uFXj681fewfd8oJHftV2ztdhAKjrRcdiK30gFeV3k9fQUk+j/L/d759K6qzjRVCsAD3qS5 jQrgDt17UuYdjz2SFoWKOM/4UwHpj0zXQahankhRwcZrEljKfeAXnn2pksiYY4Hp61o6ainnIGOO lUOcDPaprcOh3KQM8CgR0kJwvU/SpOM/wjPH1rKWaQKMnv8ApUiyEuASMdhigo37EKoy2088Grtz Kvl4YBsDgA4rm4XdOME5HNWPOkxjkjH1qRlPUHX5sZ+9VHK7nHoM9f61cuLeWU56g/pUIs33dc98 4600xMqswDE5A44z39qjYk/Nkemc1ebTzx8wwKQWXbaTx+lO5NijknPXPUUFu/bsT1q1NZMqH5cj qMc0630eW5UHIVOuaLhYos3q/T3pGwV4/IVotos68cMc8Ypj6TLGvz9SCeKLhYyyD2A9eKCp7YGR zxU0kDBjx3703advv15pgCpzn0FM8v0OKsbc9B8wOKcsZL7MYoArLAQp4JHNP8o+4HfB9a1YI1XA I5x0NSvbZBKYXrzxk0FWMhYx1zkf3qkVMNwcjufSlkXYDnAPekWcZJAOMmgB2wHkccjg8VJDACe+ M46VGJF4zg8ZIFPjmIKkEgg5GKBHS6TY20aBpIkZu1WprO3GCkSqPQCsq01JgmSvQcjNWGvWYHbj HGBms2xk3lorDcccY6UeWhYj73NVjK56Y57f407zXVxjGP1pDL0VvCp5Ay3Wo5kQM2CR+PFRRzMV +f8AHnNQyMzck8e9ICwfu5JwM8E8UgkXPHrVaQOGwcjP6VE4J64yaAsXGkGeTxgdKryyja2eQTg1 GkMzn93zyAQDSvpd3kny156c0xFV33ZA4OPSq0iggk/l0rSk0i9ClmQHHbdyKqyQSJhXU59D3qri KR3DkdD3ph3KTtPXGM9uKtvCdpOD1zyar+XtOcZweOapAPU8Zwc+pOc04uzDpn6timjnr1BwKmRN 3065IoAgZm4JUjJye9QyKwHANaZiVtxBxnBGahkQKD2OOvJpFGeUJznOO/fNPRGIPXPIFSsATz/D 0waAOmcHI5oAZ5L4GM46Z7VOls4OXA6jbz29aVGB9emeO1WOHVcD5eCaAIGifYP1yaa0bHLAYA56 96sqpBBXB9OKeISOmR60gKHlsTlc4IzyetPW2kZOBkAcY/z71fSHgZwc9TViNBsC8bRxikBmQaXd zkBAq54ySDiti18HSbVa6vAAeWCjmp9PkjWba/rgCt8XkYjDNhRjnnqKGwRhv4dtYFJXznJ6EtgD 2rLms9kh2qVH510txqMcqkYbGMg5/Ks1maVgUXJ5yCaQ7GetsvBbPQHkZzUm0IDluegxWlHpcsyh m2g+m6lOi3III2YHXmi4GUybeRgYwDTdvy8Ak9TxzWhcWLoCfMXgnt1FU95BB3ewqhFK6jfd8oyc evNUZmaNepznqPpWxJg53DkDIbHNVZoiw+7kEYPHWmBjCVhnLEZxirdurspZQcZ+uKkFgNwZlyfu 4JxgCr8a7VVQflzk465pMdiCNXPPl5A55NSrFNkDoDnj1qWNgQcMD3Y96f5iKy7+mOo7UmBVjvg2 FBI55rYtZ8Op3o2Dxz1rglupUOTuzjJGPSrMd84X92dvbg1oB6PBeo45POeQe1WPtIHIYYYZyDXm sepmFhhjjBIJPPvT4dbmDMRtBPTvSsB6E1yq4y2N3A5pvnF8t5g4yDg/0rz5NXkxywIzkhR0pr6r KVO1T/tEN1p2A73zQ3R1HPQnqKcsxK4ZgefTmuBGqucBmJHXJPTHapDrMzRnaRx0BPSlYVjt1lJf jYDkkVTu7lECgIHJGcHtXMR+IZUJ3BCCuOveopNRMz/MSG6sR3osB0yTRDDELk9s1M19GPm6c8c1 ybXhjfcG+Xrk0x70mTdkkjilyhodpHqSHq4G726086ki8Oyn0wc1wq6gQvQsuM5JOaYt+zbWJA7A etHKB3kmpoFGz5iQBVFtScr8wGCeg6D8a5UaiMgjhRxj0pst67tw2VHbPFHKBuyX+SxLhe3tUP2x t3yucE9fwrFa4Jzz8vXjnNN+0YXGR70WA347nLbRkHpnPX3q+rqy9QVHB+tclHeHGDgc9K0LK8UA Ak7ePlA60WEdXbQxEjGMHnnrWrYxIrABABjArlba+VCNze3pV+31sKoB5YHoDRYZ1YhjKkMg5Peh 4YDwYxj68Vz666jHlwF6kU068u0lSvX17VFncZsNa2qsT5ft9KrvbQDICKM+tZr65DnIYc9eeai/ teJ/bHcntTsxGp9lt8Y8vAHUiq1xY2zKTgq2ecVQ/tWMDJYZB45p76pHJ8oK89KaBkF5ZQBW+bg9 e36VjtagHcH4z61durgvnfnjoMdKotOqycsfXGOtUhM0NPiUAZK46mtaBYxwMA9Oa5gXg45A2+h7 5qUX/wAv3iRjjB/OmM6c7VHznI64FRnbtyD0GeTXPf2ntUhfvEbSSelA1PGFaMcjB5xSsBqXDJt5 +pI4rNmOcqWIJyOepqpcarvY7SQAemOKrPd5OAwB4zQJl9WwSwIq1BMWXqeuM4rBExVvvAZ9KsQX ShOCc49fSnYRvKdy4B6HHTrRErE4IUZ6n1rG/tEFsKxGPTvTo9Q+fDMW57nrTsOx1EUaeWvyqfqK l8mLbhwMDjgYrDh1NEUBiSeyjpVqPU0EXy/dpAXVs7diCwHTOcdTTHsINvybQOuCtQLqMbc5yCeg GKb9vTLYcHB9aB2El0qB2LHbyOO+KjXS7fO3H1IPX6U59QUoOctjGO9NF0oHLfWgBsumJuBjJHBH WqFzauhBIB9cGtGS6VunYcms26ugWJ5wTihElTa3QjGe9X7EAHOevOKznlBbjAGCeetWILgRkAEE d6ZR0sOMcnqPyqQkHrjg85rAbUVGFQHJ469KU3+1cZYnB75rNoEdApBbI24+lWITkkg5965qPUsE YAbP6UDWdikb2A9AOtLlY7nXcbfmIFRvJGowWUE8e9ckddHOWwPzqu2rMcfOSeKXIwudLcuu4jjH es66IK5Ug4OD71kHUW+YM3Xnr0oa/wArkEZ9MVSQi7kHHYHpTRIOgPbg9PwrMkujubGDnqR2pPtO Rz09u1OwG1He+Uhwyt6nNMOqB5MjHt9a59rjOQOfXio/OPoWzzRyiudGdRIY7mBABxSf2grMR909 ciuc84nALD+dJ5p425wD+tHKgudL9ty/3gB6Dsau286Bf3pI79K5JJj1PPvWhDc/Jhm4x60nEdzf aVFxtJOfeq4mw2C2PSsqS4IwSeBULzlsHkg84zmjlHc3d6+Xww9eTUTXAHT68nFZAuDs5/n0pomb dyCcUcorm/Cc5O8H0GadM5RflIIrJSciPAPFNluiuQCO3fpRYC0bo7shiOwrQsbjtwfrXMyTtv5q 1a3XOTxj1o5QudzbtGydV3enpRIwA4IPvXPw6mo6H6iiTVgUIyACOPapcWFy/cOgb5jyPSqbSqcn IwvXB6ViXWpM8hCnAJ7GokuSSSG2nv71XKwN3zgepA4znPWoGZd2B3/Ksr7T8uMjH6Uxbg7mBPy5 7U7AbayAZ5GcdO9PaTknIrMWcFgDnnnrUonAUAMCPcUWAtF8KTnHrzVRyXYccdcmo3k3KcY3dcCo lfIxx+BosDLcal37Dnt0qwyLzhs9h6CqauMZAB9qk8/KjrmiwE2wjvn3p23Cnn9cZqEzAfKOecn/ AApryZx0570WAdLvLsDk+me1QFJCMBCfcCneYCTyQcdqkjbCqAT057U7BYryQyKh+U1TZTu5BGTz mtSWQbeT27mqU74cHHPfNCFYggRpXx8wHeuv0exSONeSfbpXN2zZfOD1rftbzEa7mxtpSBHVRhfL CqBg1Xm2o2eOOOvWsdtYCoxVlC9OTVCXWFds7jkngEis7Ms6WMhjkHjHrVa8AZW6e9YSasVJ3EBf btUjamJU459+1NICrfW6O/ygHFZ32Zi3GdtXpJlZ8kgd+KjVxuAU5q0SUzYuPoD9aeLYgdOvP0q7 vPOecHrnGKRSNo5B5wM0CsVfIJ6MPxqRbJpCQSoGO5qUMAwB65xxVyHBAOeT70DsUDpcqsTu6d6a 1hINpU9MjFbihT15oVM7snOB6VNwsYX2WYc47Yp8JkRhkdB0raMIK8gdagaDngD160AQrI4XOBVe echMkEZ74rSS2xyx6VDPFhiuMj+VIZz00jM3AwM0yLDNyDn2q/eW4ViQOT3qtGm0E7SPbHWruI0N NswzAkDGeQa6mzjRUAC8YrmrOUbfmOSPUVpQ3wiX7w4FS2NHRIUjxjaAOtX7d0Zc/LmuOk1cLnnA Hr3qa21o4Cpt9fSoaGdRdIkgO7H+FcnrliB0IrU/tIOuflz1xng1l6heo6nOD6U0JnKXEWHwQPao Avy89B6Crt7IpkyMe/NVyRjg56jFaokTA69RjrjtSsTtOScAelIXwMAbiOKazhRxx260CFz849um KUEdBx3/ABpokHQAY7UF8ccZ70ATKO4/+vViJX3H7wA9utQQPtG09Bxmr8UgC4GRx1pMoYrn04J5 9qcJvwNEjA8tyfbjNRg5OAMjt2pAWVmQHcQSfXHXNSRTq2Oo9qq7lAOEBAPUck1WnJDFkBAx69KL AaazKzbSep4Jp7EbsdcdawftWwctmpFvc9CR9KLAazKmcHGc0qpwSAOew6Vifatu75j+NO/tA8fM F46+tKwGz5e4AnB29DSxKFJOFbI6471lpf8AAJfp2Jp4v0fGByOvFMDdj68kDnOc1KZY+hIPtXON f7lwHOB1xxSNfcZ3dOee9Kw7mteKrKRxjv7VkSW8bdU69feka9Vs7Rx154phulz82B6kGqRI0Wih uE9wDVyOFOQQrA8daqG4jJIz7Ak5zxTvtSp8q4PAB96BGgIEJ5HPqRUixRIOFBIrNS+Bbv8AjT5L 4FDtx14OeKBmh5YDccDOeKcFCqQFGM8nOKyhqGSSWC/3R2qz9tLBsndgd6BlpwM8c45pmdw9yeRi qJu2DdgenFP80lRtY4z+VKwMtSEL1GBimkkMuDz/ACFQmUYz7U1p4+BkfzosSXbb73Jzg9K1omXy sbFAx16c1z8Ey7yS2ceg61ZS62rhWBwOcmixRrlgW98elUNQXjGRx2Iqo90ZFJBHHvUe5m5YkHHH vSEVbiEHOSOe/SqZi+bpnArYa3V15bAz6VDJahfuPkdcnirTEZqpjr+NKuRg4Gau/Z2I7YxjIFI1 lImM7PzoASBgzBWwvfkdKlZysZxyM9c4Bquy7XyQR9TR5jbgSOfQUAVLiPe2QenOaZFZvJ6nt3zm ti3WMAZGT156CrURznnii4zMt9HaTHzqccdK0I9BbarZHoQfStOzdd3GBitBpU4ycjtUNjsYf2AR 5GMHGKVbY4yeR+Xer9zMA/yDI9TVMXScDOSf1pWAX7OABgYGO/P503YxPGCOnFL9pXJGOD0qOSdc e2MDj9aAuPwAByRxjFI3fnGOKi84nHQqR1oV8gZ6+tAFgYbuPvZ6UscCbwW6DrxUIfZyRwakSXkD B9uKQGvbpCicKPU1YUjdwBWNHO0gHPzY4xT/AD5pFIRh6UAaNyV2nqSKwLxfmBwenTFW2klEYUtk gY65qsRIxwcbe/rTQWM9gCRtGTz07VC8fClhx0zitMWzFSCvt1qs6MuO/Pb+VXcRVVQCSPl/vcda mHKjG3j86AoP3huY9gaVFzuGGJ/rQxCNkZC/e9D0FM+zzTKw49sHkVoIE2kBM9OM9auoUJGFA9cV JRgHTZmHTPQYx0qT+y2jbkElec+tdCcI2WGalQDccgDJz0ouxmBHpvzZOemBmpXsWRAMdO4PSt07 duAeM8HFVZT8wxzwTn60rgZiQEY3KMegqQxEOOcDqe3FW2BxwCSRxgdKY8MhG5RnqPwouBWGDkdC vQletPdQw2tuAb0qwtrIyADBJxip/wCymfGZCNvJxzRcRVtovn5TnHXPANbEcScAxq2DUNtZsgB3 Z7Z9avGNs/dJ/GkMqyRxBeEUdeBxVZVRGO0AZNa7WskkfyxknHrx0qi+m3OThRgDgbaQx0UqoPm7 dSx4qVrhcFQ65PvVCawuPLwFbGMYJzg+tQSW0xkIKsq9ACtAh94S/Bx64zWS6kSc/KGGBjr+NXmt JDGA8bED36VA9rIhBZTjtzVJisVTwuNpPbIqdQTtbBOB+B96X7K+T90DPXPerduiA4bg+/ancCky jbx3P1zVGfzg2GV+DkfSuhEf7zp8vepTDExyAp6EZoYzk4kllPKt17cVL5Mrd/u9QTXXQ2UZb5wD 9BxS/wBnxouI/l7DbUOQ7HlJ++OV5ODgdqD1xkjnv1pTxxgjtgd6MY6Z561uTcANoHXg8Aij7oyo z36cCgDLYPP49KTglTt6jBx0/wDr0DDGOQRjPJ/pSjnDN35PFGAq9MkHGen44pfTkAY6mmDA9ME8 9BkUAqGGMcHHTGfeg4Y8nPJNHGDtOSOKQhMj1yM9TThjnac4Pc0gyeueeOmOKOrDHc5BNAWAt3zn HvQRycnnqKTbkY5x65pcZz/D04FMNBM/Nnn39PrS8nk9+c56UZPoMkYxTc5XvjjB9KYhSc88HJ/K jnbhc8DpQwU8EgnoOMCjjsDhhSAMk7SQeT1zSluoHUds0jE4yM8dqUYLdQB0NAByeQR0xk0A4ywB 6gUnBHUnB4z1FKPu8cDNFgHGR1Xgn35pGd84B69ATSZBBOe3UikA+XgZyKBih33Eu5OeevekLSEH 5/lPBGc0A9DnIJx69KQ87iDjHXjkU7APV2baM4PQd8YoaaUDILDPHXNM/hIHTrmnHjHalYB2+TJA JJx/Xmjzn4+YgFs0wMdvf655NGe+D7UASrdygDLsfXntSefI6ncxYY4BNRqAvp6mgnCnuM55osA/ zto3ZzzxzS7zkZ5z2zUZzz/Kg8L7E/lRYBS2cgk4POKCx6ZJFHcj5f8AGkxgbc9sCnYTHKx7An2p mcEY69etHOcckZ/Oj1x9MUIQ5ief8jFJ34JA603p0AHrS4woPPpnNADvMcjjjHO4dqBIRjJxz165 puOQRS8nJ79KGBJ5zYGeT9elPF5IMDceMjp0qvzzxwP0pq989e3FFiix5zj5gf1/KlF24x345war 4PIPJHtmjv7Z5+tICybqVjuLc4wPpSG6k25RiB2NVyenPH0pc5weT/s0AW1u2OAxLEeppslyS3J6 8cGq3oASe/PTFHc5Az6etBJN5p3Z47DI7UolcLx+hqEDrjoaPrz9KAJknffy3Ud6Rbh9pHpyaix9 3JHrR6HPAHYdKBkhcr907cnOKPMz3PvTBgHgZ4oPAxgDmiwWFL8ZJ+X6dacGPIBJFR4wwJ645o9s /ke9AEisRznvRv469+KjPHOfwo98EEc9KLDJA57k0qv6k9cnFRemOO5560uAD/nigSHbvTPr1pOd vUZ9abj0/AUHpx1J607CH59OOeBSDdnJ69KQkEHHrgHPFK2B179BSKHcAfKeKcku3qR0qPgjr+NH AP6imIk8xtoUkng+9Cue3HpUYPHB5zS4z+fekBK0pGdxyP60iy7WznHbOetRtyOMDnpQABn5f1zT CxY+0tzz+FNMxx2z3JqHkDqTnjFAGDwOvHNSImMgzx1zmkD9+meKj544/rSe9A7FgXJOV6jtTHmZ 8hj14xUOMAEYx05pe4zjB96YD0bBGG9jmlWXHuOvvUY55xwaOvQfX2oGSmQbsjjjJzSeZ374qMAH 7ufyoPI5I9elAFmO5YBe9K87nqw49KrA45559BR1xQBajuDuBz14z0pvnsOQx3DgmoOSMkgH255p Me31osIs/aW4IJ4465pzXbYwM7vrVXJORjj60mBgZoC5aF2/B5p32pjjBzj2qn+nHf1pc5Azxzwa ALouSCcABc81Kt5jHzZx1ArMB9j+I6UZJxjPvigZqG5Dq2evXk1C0wPQnIHUmqW4juf5ClJzwelF gLcc7L1b5sdake7IHXJ+tZ5I9vak4yDzn2oEWZLl2UjPX070xZnDDPH1qL+H+tHscAY9KAJvtLbg f61Kt4yggFuc8VUHB4P6UEfN8o7dBSsBbW6cvyeBUiXXI7GqPr+dKDgZGQPaiwGr9tA498mm/bCf XPp2rOB6HnJ/KnoB365xQM1EucnnHTk1bimGMk5x3rJjU+3HoOlXIQc8En8KQGylxwAB/wDXqwko OScCsqMHgAkdxzV2FSB09jUMovBxtxn2p6EZ57VCoO0+w5p5zj8OuaBE28DOBzjrUUpU5ycfWm9c Yz0xj1qOQ+oIyvSkBTu1UsMcjtiqGzacfrWhIMnrjmqknygDg80wK7PjlTgjioJp3xw2B1p02VU9 x3yaqORj1z7U0hCSXEh5P5017mUAEenp1prZ+h9c1Eevv3FUkFy7BfOi7SSMDqDTzqAx0b1HPGay yB0OQtN6N1zRZAy3NciXJGOTnr1pBNsGD/8AqqkMjof1p27K9vzpgWfP54x6AUzzTg89/wAar9u/ vR36/TmiwE4m3H5mGT+FAk/vAgYOOag579/XvR977woFYvQ3W1hu+gqyl5gctwKx+3BHHoaN3GME EDNAzZN6q9MNjse9It6AwJPA71kAt2/nSbicYzRYDde9XdwCR0z0zVa4uQx67sH8hWZuPrkjpz1p GYkZP1osBK8oduuFHA5pPNPYnd9aiU88sOO1N3Z459uOKAJHlI59P1pDJnvz0qPknt1o57/ShiZL 5h4AxjPftSea/BU4PemdeePzo9eo96Qx/mEYydv1oEzgEc9Oeaiz0/rRnnn60AStM46Ng4x65o8w smDj/GoznPQ8CmtkHjkcc+lAEyzH7qk9OfrR556DFQ5+Y/4dKVc56e1AEvnEN7deaUTsMVBuwOe/ ekOM/wD16YFwT5XrnnuKfHOd3LZz3rPxnGQfenDPQ/nSA0kuSOmOuaelwo+6Ryeec1lK5zzz9adv x2GBxxRYDVWfanXnsOtMNwf4Rx0xWX5jDgHjrjvQ0hZunT3osBq+dkYLEY/WmyXGWyc9KzRJ2XOK bvJIPPTqTjFFgNb7ZjByT7+lWLe73qpbnuccVhCQEjnPXjNBlZRxuBPI4zRYDrUuEPuwGab9oy27 K9MY6YrmPtUoHDGgXch4JI9TnvRYR1McobJLd8YpXnUHPHAzmuX+2PjlzUgvTnHOBSsBry3AbJyC zDgVUN2AwLnB6etZ8lzuGcDBH6VF5hOewB6YpgbaX2zqxPc46Uv9odN2Rk8H0rAMhyQPrxQHLLyS eOtAWOgj1PYeNxwcmrK6u3ILkLn06Vy/mHoDk4zSea2PmJpNIZ0c+rEk4PHTIPeoBe7GyMHjGfes VJc55zzgD0p4lzySemMZoA3Ib0bgQT6HHWpReKeT19xWAJsDG7I6cdqVZeSQTjFAG6t2R95hyeMi ni8AUYb7nb1rAadtx56HceaSOduA7HgdqLAdE1xv4zgN6npQt1sYFW4Bz1rnvPbHBwc/lSLM2fU9 fWlYDpor5i3GB9e1WYr30ZQe+BXKpckckEd8elStdNt+Yjv35osB07XQcYBB5zgUv2hcDDDGOD0r mPtbsQOOvT1pyXLrgE5GPTtRYZ1S3OFJyGx3z0qpPOrcg8Z4AFYq3co4yMH29qBMzKN2B83pQhGg ZQTkYGADj0pBcYYkfkKz1HBGDk9c1LHzg46c5p3A0EuQcKPyqb7QwKkHjB4B4rLXBOOox16Zqwh6 5z9MVAGgt8Rjd94cNnnFSrcEHapIPX1qgqrtGe+e+Klxkg7ck8YPtSYzSS5J+9kDnBz1oRmwACRz jIqkozwgzx1PTNWFOMZ7dR2oGW4x82TngY65q3GwydyggDHSqas3Oc8HNTI+CcDAxzx1pXAvJ0IA IA6Cp04X+gqkrgnCk88VMH+ZeSOM+tFwL6AADp0zxU9uVwd3bnHrWWJWLdwOvpUyyspz26Ck2M3E yCcY6daVuSc4NZsdzIzYzwPwqQzsfvZPagRf3AYOF4HGRUU43ddoquszbugHfmgyblyP5UAQ3MO4 be3YGqz2hbKsSe/0q8fU59qdkseODTuBkSWaqMsDnoeOtULgCM5AGBXRNHuXj14Nc3r6bY8BmBB4 A/lTWoGHeauLdmCYHzYG0Ej6UWuuiSfCkggcg8Vx2t3ciudzYJOOO1UdJuibpAxLBjzjt/8AWq7E pnsmn3RlVWIyc4z2rUiVmXOOPbrXOeGnYwBduADnOexrrYR8ozzx0zispRLPDicDb2zxS/dzkYIH FIenOM96XnJJPC9h0roIFxnHOeePYU3IIyF6+h/pS/dB+UDjoKUYCnG716UxhjPpgc5PahuuMqf6 0mB2BBz+dKNw+6uOe1ACkksQCfQA9qTJyOMYPeggk9vWhRjJOeOuO1ADTgKxOeBxz1pzde7EYxjH WkUcHPGemDRzk7uMnoaABeQcdM4OaUjaOo5OaM9OVx9aG6jB96AA5GB2pPqOoyM807PLD09PSk44 OcAcYHFACZxzj5sDrxQScnPJzQcgYcHJOAfakLblBYgrntxTFYdkq3DdPbnFIcYAPPGMUK2W69Tj 2IoAHfOOmCaLAGDjHU49Ov40vYMQOmcZpgwMYHXt1xSjHIXgUAL2wTwOppSWBIPHGeO9NO7acE5x xSnhuFx+OaQBgbfQ+h9abyV56fzpW65HQdOKPrz6DNMA4zzjGOv9KVcZxjP6HFA/iwOOx7UnsvA9 cUhAP/1DPOKU/LyeRkk+9Jt6k4GOnHajBwMHnHFNgHUAcAEdhR0646fNQV+bByfoKB1GD3496QwG OvX1oIweOAO3SheoIP1OKMHbuJU+1MQFiM8cHp3/AEpTg9QMjpzRnGOg47UnQEPjg9R2oBh3OOD9 aPTOPTJoH+1gD2ozn+q5oEJxuycn05oJxjB9vrS/NxgDOMHPvSYwegC4xmmAu7ae3tScjrkduOKM Z9AKXBJJPFIBM4xnpS/dFGO5A9TR0xxn+lBQvTqOgJNIuR3Xr+VGOx+tBz3/ABoAOScgAZPJ9aOV 4A5Ge9Hc5BPbPTNA65z7YPSgBAPlHcY/vUvIAGT044o57/QCkIwRngegpEjgpP3iQDzz7UZ4wSAO 1Jj1HHXNLj1wD15HFA0GMn39KG9ySf5Ufh25penOQRQMRcYAOQff0oAz0PGO9Lzjjpjim9iccj2p gKeOTnnrzS49B27Gg985I70h5wepzkcdqBCg8cZ6Z9abkjIH0Ixmlz0OMfWk/A56nIoAXqcdKM+/ A5NNyMc4FKT/AI896AFHT0PQA0mOwPY9qVuoyDknil/3uOMdaBB0I9PWjpyePrRyGOTSDnOST7Gg oUn14P15oB5O3p14o9Djn1zQBtxuAxQAd8Bhk0AAjn0pOcHJHsBSnHI60gFHOcdOucUE88flmkGQ eQfx70AHAJAz2oAdxg8deOvSk+9znH0HWjHoB370h4HHPFAh5z1+XGPWkzxnHJpBg9TjHFGc4wff igYAkkDrz2pe5K/TmkHPQAgGj0xQIXkrwOPrR1HbJHWkPWl6DoD6UwD35zij8BQ3fqaPQc0AA7A8 Ht7U7BPP6U3p6Y9+tGP1NAx31+vTrSA5BI+maBk4yMZpOoPtQAA8nGaGOO2AORS9cHjOfpRx9OxA oEBOO+Oec0MPfPPX1pMduoxzS4J5oACctk46c0E+o4x6UnHf9aXHPr6mgYcce3vmjpwB2pFHIByB S9c9sigkXp0z1xzRnPQAY68ULyMn60mPfk0FBjn+VL3+vJxRnnIx0o9iAfr2oAUHpn60i/dJ7+pN IeOTnOcYpR6HPWgBV4OBg/0NGcdfwo59s0dAOaAH+meTU0eN2Oo/lUCnBUenSposEnjn1ApAWYh2 XJB5zVqMHI6n3z0qvFgkHk/SrSdevvuqWMuR5wMKT2FXk5XdgZ+tUoRnpnngVcjPYdM1AFhByQOh 96cOh29+opE5IxjmnNnaeaQxMnrnk/pUTkdMEkVM3I+bIPSoWUAke3YUAVpD8ozyccDNUnwD36em c1fdf9k5qlKOq/lTQijIeDzVWbjOM+p9quTfexjnHNVJcnOR+narEV5TzgetQt35561LJgtxg5Hf rUZOR9femAw46cD3phPrzxTjknv/AI0wZP8A9agAPuKTr1HsKQdep6/lS/5FAC+/FB69eMUmSQAR Rk9QuPagAxjABJAPPNBIo7989jQOOCMe9FwE9frx60vV+O465pDjjdxzmkByeMk59MUALnPv2B6U n9OuT1o64H4nPajqCoJApgGPcEjv2pMAngYx1wcUMeRQc49ffrSAQ5HXp696Uk/j0FGCff6jH+RR k9T+lAByeVH50d/x9elIME5Bz6UHnqRjNABnPXrQenoT/KkHGM49cZ60fp+FIBSew/OkH655peef ypuP1/SmAvHtyenemgk9eD34pVI6nnijIGFHT6ZpAGc/d9elB79/X2oPfqQKCOue54xQAmeR+dBz jj06ihiQRx0o570xgeV5GP6UN1+X07d6GzjOB1x6UhGfr6UCD3Ax2o6Dn6UYzk8/lnFIR0IOTjnm gBcjb8oHXvSfln1ApeScY6HI5pFP09qAA++OenvSAc57YxS4wp6+3FBwOn0z6UAHbIwB9KM444GR zSEfLwcnsKGOG+g7UAKAMgDnjApOuTnHtQflB6getGMEdOn50AIcc/p7Uv65656UdMdMZJoGeCM5 7cfrSAUk/h1x0puMZKjr3pc4U/nwOtB6Y6jtQAhyF6/nS4x+Hb1o6cDPHPFHHGeRigYZyNxGOeea Ujg/epvrkDAPX0pwGFwcntSARwdwA60MQc/zpTwD1680HtyPTmgAU+mQM5+lLxzwDQD164+lGPlP BpiHDGcjnFHOMEY5zQvPIApTgsST+lABtB6gYJA+lO578MP4R2ppPHQZ7DFPPP8AeOfUcUAOUHdy M9smjq/Vs9qbjPUk9sinDO3nJDHp0pAKOQAcemAcVIoA5J4xjGetMBBP4ZznpT8kc4ADelAxyHg5 4IAzzUqnPb5c5waYOFGcknk/WnRkkknGR6daQEicjnucVP0zzk+uOnpUXP8ADnHYmpV9DwRz1oBD 1/hH5Z69KmXPzE4AHTFNThhnpjOalUAD046mkBLGN2SM8fjUsYIOPn5ySSOKjj6KD3XJqUDGQCBU sCVRhuw/Dmp0bAyeQP51Cny9Djjk4qdEwvXk8496QyVCDzgZxk8deKnQDIzz9O1Rxg/J7DuOlTZO 3JKjoaQEq849AMjFTKpKjoSRjFQpggheuOualUYyFH60ASouGxjJ7+tSqMYGOM+tRrwQMEDoTjmp o0AbnkHg5oGSRKw9uRjHapwpx146dMVEnLcEZx2FSLkjnoOOe9IQq4PHQ+9PUnaBnp70w8KQMN35 pwPXPX07UDHknb0/xpV6A9O+aTBHI4PegD5vUdsUwFJ2q2O3SuW8SNut2Jba0XzbhXU9V5xtIwTj pXIeJBi1ZSoPy7QSauJLPMNcdWnVupJ7VDoK5ueMZU55PWl1hssnzDGckjjFS+H41a6iBz98Z9K2 toR1PVvDcYMaAB4/bHeuutxhFA6jrkdK5rw6gGduAB2zXTRDMQznOOKxluaI8IYblwQGIpBwuWwR 3yelOC5I5B/2en40g7txx6c4rUkMc5PHTv8AjSc+XzjnoehpSTjPTvnPWlAxxk8Zxx19KBiDHmHI +uOKPvYzn5T93pS4xjAB7DNAx1YdeOOelMBpXjAAIBxkmnYI3Dgg9B60uADxwAKQE8Nx6570AAAP PqeePSk/hB57HFOyV6kn1z1pFAz8wJ6ZJOKAF/D5QaQc5HI9MGhdvUdOtDbvvMTtAz9aBC4JXI+u Sab8pyvPY0uAScZxnqOlBO1eT14oGGFA4wOcZo6kYw2fejnnORjj/wCvS5O3jGc/lQIavyjpxSYz gde+STzTiN2SOB0p3+0p6npnFMBhHI9R27Udcnv3zSjnCjk9TQASB0PagQLww4yc9N1JyBnrk8H1 oOc/LwfWlH3hgjpg8UAIDg8DgDrSY7EHjvTguT0OP0pAenA6UDDryAee2elKBjPcYyMmmsMIcjj3 NL6FcYGOp60iQbv29uvNHB6AdhzSn19Dg89KTPzD5c802UNAIGe+eTmlwABnt2NLuwcDgYzkjpRx kY5weRnrSAQ9AScfrQB1xk880ucd8ccUvpjkY7CmA3GGwMZ9DRgDA5A7il5GM/Xjmg8+o9PWgBMY 4PGBQOc4B5H50HG47Rkn9ad15ORxnrQJjOMdKU84H3QO+OBQ2OBkZxg8UqjJByPypDG8nqBkj8KU 8DrnI4xRgkEfh1pQN2PpximAmOmTnHUCgHuD1oxjAB4FK2Mgf3unpQAikHp39aDwp4HA6Cl6EgnJ HXFB56EYPTB96AG49MHuT/SlwQeTgU45Ppz39KT+Ln6cUgEYkZxxgdM80gIHoee/elwMc+vAFLkd enr70CEHYdB0o6dck+9L+R78c0cdhjp360AgyF7gY6UEYIy3BNGf5c4NGMqc98cA+lAwPHoKB+ma XJ5I4PtSDhiCO2aAAH88etHO7twcYpc/oe3em9+fwpiFx6nikAxnHXtTs/N/P6UmBznHTFADeoBz jPoaVQBnHHpxQMk8jP40YIXac4x6UAHOMNS8AdMfSlyfwpOmOf8A9VAg54I6d80cD8O9HTOMde1G OwFBQo6ge2aF7jGe1L/F68dc0mMg9/rQAYyvUZHNJgYGeg44p2AfpngUmfQY+tIBBx07flS57LnO M4pe3t1xRg84FACHjk//AKqUcY6YHagHHY5PFIfQYPPANADunbBoB47ZNIPU+n50vOMYIzQhCYzj I754FL09j0pG5H3uvGKUnkUDD+IdeBSfhS/hnt60Hn6/XpTJAdvXNHoePrQf9oik57cdulAxcHdz k+/rRz6gnNGOfb9aOfegYhA247ZoPPfp1pcHLdsfkaPYcg0gFGepzge/rQcnvSf7ueOM4pT3z+Yo APXjnOPrSHqOOvJpc/hzR2P6DFADeefp0pRgjv8AU0HoM5PP5UHtzkY5piF7Ufhj0oXoTzSDv796 QxSOTk0E5GTg+nNL29M4xxSdPWgA7/17UmOnp6UvtzihsnIyPr2oEHTJP8+lKvbB/Og0cfUZ70DF VeucA+oNIOgJHsc0H0xjFKuBn+VMB6D07d81LFwcfd4qJV49OanjGMeufSkBZRc4I+vrV2MAgA4x 9aqRemee9W7Xd0OPfmoY0X4lwoI/nVuMZGeKrQ888kVZjOcZ6dc1IyVR15zTsHnOc/pQMEDp6U7v 6dutIBpUnI/TrUUg7nJ78VM3C+h781FIOMZwcUAU5XyxAB2+9UZBtHXvwQKuuMZ+b6DFVZGz0PPf immIpStscbgcHvnpVWTlSSufoas3H3umfSqkoznp7VSArv2+nFMK49Pz605hg8jke9NbOR09KoTI z6c/n0pGHPcmjGCe+OwpMDg4x70AA/Pt1pPrxQ38uRQw6dAc8cUgExj0JpNuP89aUcnGMUD0GMZp jDAJ6jrzSEZ47dqXPftS9Og69PakA0emaAc9aQkEY6enbNLn2BFMQnJ6Z6UE45HXGRigHvyB69KQ nA5J6+lAAe54496M9/boDSnHfJzzSeuRQAc4yaG4+meM0YGcFeKM+2AB0NAXFbnPvwaQ8/04o/iz /Wj+LB9aADHPbj2pB16DOOlHU8dz+dGCSDjHegAxwQOOKQdx60rckcZAPPPSm/w0gDGOo56Ucjp6 0cL1/DFLjHGe3FMBAeeuOp5o47fhSsMdO2DQSMtnkY60hiHBGc5x39TTRz0xnpzTh04+lKT6/QUw ECq3IOe/0pOwHTtS4xnA/wAaToTx2xj0oEGNq8AgijHXIII6UZ7bqCOT39aQCdM/XpQByAeh7+lH 8RAxnr70f/XGKADjOevf2owBx+dA4GGxxz04oXOfx9aEAnGQeQPX1oBz3z2P1pc8c/gKQ8/eIIxj 1FACKc9u3Oe9LjrnHB55perEDI9KP8nNACYwevtk0DOfUY6nvS8nHp6UHk9PYigBvv68YHag9vXN KV4I7GlwNpz+npQAYz6A96TkqM469aUcDjOM96XtjPXt6UWAQ8tnj0oAyMevUUYAzgnr9cUcdTk9 yB2oAQAcDn1ApVycE8ZGTS7sg9/SlYepx6UgE6k5xyP1FKGA64yRzQF45z1pw5xn6cUAJnGSoJz6 Hil4yc9O3NJj2xz096djkZx07UIAUkDHH4etOzwOPqT2pBnng+gyOacxOOcnPb3pgABJY4wMDB9D T8DryOw4pg+9945z1AqRcf4kikAoyeg69RSoMg54x3FInOM46dc8CpF7MOo6ZGaAHLgDPHvTlG7n nk/nQ2eQT1OBx0pVUswz0+vIoGTKTnI+8RinjJxuYfd5piYJDEHPUdqkHy4wfXGO/P8AKkBKgVvc Y4xxViPcp9hnkDrVYklXPtz7VYUN/skKOcHt61IE8a5IAyvGee9PXleQfXimqpK4OS2M5qXHIIye 5HvSGSRgBlOT9atY56dTxzgVBH3xyOPpUwOCuecjjikBNHwwO4cnp6VKgHG4Yz2xUUfLZKnnB61O pCtyPlPTNIB64zwCfl4arEaktnIJzUMeMgYIxzUqAcH5gORxSAniwVxk5AqVcdOflqHPdemM8mng nBPIU4OfWgZLHyfcdQOxqZeWOB+RqNfXp+NP6qV/WgB6gnrkZ7inKDuPbik5bnt2FKq5A6dfyoAc oAGOSaAN3JwB7U5c8ZAPbGadtwflHb1oARlyvynjOMZri/Fa7Q7Lg44IDV20uTGSODjiuC8WvtUi MEt6k1pATPM9W4mZSxY9zjirXhmLfjBJYN/hiqmqnNx1ySc5NanhtGSYPnIByc+lbdDNHrPh6Mrb RlwBxgH1rpUT92Pmzxj61haGh+zgMuTxgVvrkoN2M9AOtZPc0PAsdMYJY8EjpR0wM/UUo+7xyQOa Mr5nGfbHbitSROT97GSeo9KPc5HOeuKOvbnPOaAM5HQEdcc4oGLjbgADPqaFIHXnbzx2/wAaTqcd KX6HcvQc9aAEBIwOpyB0oBU4LYAyaOi9OAex9aVioJ6kelIBCPmJ5H6/jSt06dOTkZpAApx09yOT S45znIByaYmI3HoP92lzhyQOCOQOQKQYK5wT6DoMUp7ZxjpwaADbhuB16ZFNySGGSF9fSlXgAH5h 7e1HtjB7HsaEArZH3hznJOKTPJ3nGPU+tB5Vh7Y60pz2xg8HAoABgv8AKOB1+tIvvyMUvfgY6/gK Tjj1A96AFXBwSMYPY9aQdDjJI4o7YxnjpTh1ySOBQJiAHaM8npgijP489etNAxnPPagZORgEZzTG KMFsDn8KMY6AHt060e/oMH6+1Ko5J3fXtQA3+IcD60pGcZxkH60KM9TgDpmjJ57+4HSgAX77Z78n BxmlHXkEUmBu5wccClAzyOP1FACAcDOSfrSkDdk884+lGAdoOcds0i5HU5B6EUAB4XrnHAwMd6TG ep4Hy5x1pxHyDkgd+aU8r0xxQA08c8jPXnpTckSY4x375pyqMD6dfWgAjHUZ4PakAdhg85BBoOCS eemfrS9AM5yDgEDNIvAKnjHrTAF6j7wpGySORkcYp3puzjFIeV5x04oAQgZzyfUUfXd09cUu0/xn t0o6nnBGPp9BQAdD8gIz0J7U3byDz1xkmnAbRxnPpjpScDoMkkgUAB45Pfr60u3Ixtxx+NA4bk/p Snrz1yevSkA0dOOR0z6UuCevA5J5peemOg4x0o6YGDwOvrTAbjAI68dR2zTsHjA5NGevUmgKc/L1 I7GgSG+4xnHbvSr8xP17UYJxgYPQZNHXrz6e9IYYOd2MemOKT046jHNL2GPwAOaXoeBQAmMdM9cd KU43cAdeTmg/d9cHGTQQeoGc8UwBuO3txSdemffFHAJyCO1Kff8AL0oAQ9OeeOPel5OOO3ShcHHX 1puCfc+3SgB2OoyPTFIccnGB3FLgY4A5OfwpOM8DjuaQCkc8denJpOuSM9M0oJwCcY6/SjnHGB74 60AGAeu3A4PrmkUDbu9Pelx83ygZ4GaUH0OOcnFACDGO/HPpxR2656Y5pcfKB0B560nUd80wBic8 9KM5HTHPpQRjuPx5pWOOnb1NJgIf7xPGfyo5AwemPzpeeR0+tDD1P1xQAvPPc9RTemO2aXHQkZz6 UAEH0yc80ACj8jgE4oA5yOnbmg8feB64FIOF9D0pgL9e1H4d+go6Y7e1LjBPp3pCG5/D+lLjHSl4 oIyee9AB35/L0pOuM/nilYHHI/H0pCOBuJ9AaYxM44PBNLjODxjIIpc55Iz7HtRxnnG3pSAMZPQ/ 40dOc9KMfMB/Ok5/Hvx0oAd3IIzSDt7cEUdRkc8DBoIyDycEcUALzz7+lJkAHqPr3obPYAd89aU+ 2P6UAJ34+tN9PTkGlx9acThuMYz+NACKOO5+tBIGccD27Uo756d6TPPQYAoAU4HU8ZpCPmIJ4o42 k57ZoyPQfnQAp6/Qc4pp6/T2pcYbGefSj27Z/KgA6gkDP6YpQeQaQgnrwPel/HnHX0oAXOPy705Q MdzTe5/LGaXGOo/GgB6gnGKsIB0zmoo+cYx6VNGhbbg9QRwMUmBaiXvu7Z6Zq5HkgEZqvCBgDnHH SrkKj9cVDKLcI6cVbUYwBk+marwjOMDAz0FWUGMd/p2qWBL04zz2wKP4iB3pVGOvPvQfl+negBrD PQ9uarycg+tWW78fnUMgDAZwePxpAUmJ54yMdT3qnKQBk4+uetXJzj6KO9UmOOw9uapCZUfAY9Ce tVJTk4PQ/pVuQ49PxNU2GTwv6VSAgPGfy4PWosZ+lStweuT6YqIjpn1x1poBCB159OtR9CcjB9cU 4gkYB4zj60meDj5uc/SmAh+6cdx1FBxnHUHtR3HHUUgHX3FAg7HtQeScHrR3wAO1Bxk5BP0NAwzy OAPb0FIe2M5x6Up6k9j+FDAnB5x9aAEB5xxnFHA6nNHbOOnoKCfp6etAAcdc59s8UmARg46460vY UfQY9aADr7e1NPpznrjvTsAgbsf4UvUev40gG89+D1o6nPPSg/Nnj2o9zjGOlAhB1H8qDk53AEYo z8vy5x0JpRkD1wcUxjfT0zxxSD3P0pWGDkZFBztxkelACY/EgY+v1o/i6jPalwP544xR0IHPTv3p AJjPGOn6UY9fTJ9aMZOMj60o4HY8560wExj+Emj8vwpVHTJ+lNGT0NIBSc9TnvSfXjjHSgA54H0p c4yDgjtx1oYhM9fvGjAHHAAGOaOvTr/Ol647cn8KAEXPGBj0oP8Anilz8wwWz0pBnjP8+lAxO+eP yoOAe3qMUvQAc9PvdqOuAenXigBqgg4bGQOo6mlJ4JPOKF47dOOaCOOf1NACDAIxz60EDseRS854 A9QB1xRjjB7j060CG8444x69qVl+bOfwzQOvalAGOOmaBjf73ONv40o5HK+3rSggL6AHqKUcN0Bo Aacj8uMCgjnoB60AAR45HHY5zSjvjv7UAN44JIPfpS4y38PPr2pc5HIHXvz0pMHI6knp2oAX/ClP cc59CaTHByB7E04jBxkCgQ3GeoP/ANelYZ5BHqPWlAIIx6nHFGzHHQY6dcUAJzyvccAA05R/9bFC g9R0pQMA9Dj1OaQwUDvgcZzmhVAAXoe/tRt5PTA9qVeB1FACju2cZ/HFL0XnOKF4z0Az9KVRnaAO P5U7iHJ83qOccdKXABx0Pc5zSKMjJPQc04AYHB+9mgBynLdeM/lTuAvOcdaYpHOcYxj6+tPJ24IH 59qQDjg/eyTT0PzDjnvTQOQM8YxkGpVGcYPU+nSpAevI6tz09PrUsYA9QenTpUeegIIwcZJ4qSMD b0xkYwO1IZMg9jge2c1NGc5HLc8cYxUK7ScrySBnmpogoYD+IdPYZoAlVBxjHTgZqwigMuRyCMj2 qJeM49cmpdwK84zjsOoqRkn3vvF8E56VMrYYtjpzUK42Luyc+/Sp4yGZsjgDBoGWowowQMdjzUqk hhg8H1HSoY25A24JHSpBzjr659c0gJwVPAP4etPjY9Rz9OoqJBg5HGG79asKu0ntSEKnLc5/lip4 +g9e4zUSqDgZ5z3qZQD2GaBknG44GR+tPAwSATgnIzTQO46+npT1zgYIx1/CgB6cnpn6U8ZU4PJF CLk5Y4xUo4yfXmgBFwFPpn8qerAHnilxg4OBnkik6svOVz6UAJcEiEnHbA7V594pfAk6nHBJOOa9 CvMLGvUjnPGa828XMg85VXa/JGeQa1gTI851Nj5/zZP17V0nhOEMQW5XGVz2PvXL35JlGerDnmut 8IM22DcgKscZ9K1ZCPVtJUbVOcjaO1beTt7e3esvR8CFeo3DPHNaoA/IZrFmh8/MBwcYBOPxpzDd tyMdsAd6Tv8AeQgc4AzS/wAWBzg9z1rYQg5HO0k9e9HDKMjjHrnNKAcbsD5Rzx0oxg5wB6flQIU/ Ttg/X2pCDzk4AOePypT14y3p7U3gnGB/jSCwY98denelwTxwRnP9aOD65z680Z+b6HPXqaAAZH3h mj0wMc4B60bHG3bycdMfn/SlBPQc84yKYCMvLZznoPSkJyzcHPquOKcuNwPI7c8ZxSYGCSG49Dz7 UIAJw2R97PPrik29OCSD3PvTuCwAOORnAyBSFsjIP3uRxzQAK3QDr0Bz70hUkMcE5z+FOf5TyM4x SkE44IPb2oARuSOPQ8dvegD5l3ZUDjn+dJ94ElSOx7UrdAcAc4yT1oATjpnB68ClIyWY+2O5FAIP HIB7A9KTG4YOOe1ACgkZHJ/DFNwfUk9u1PyCGGDnrSdgQfl9u1MBMHoTn15oGC3y9DnkGlI6AjGO femtk4UYxgnAHOKAF4wTt+uTQT8q7ehHU0qjIXg88g9KRcA5JBJPrxQwEJxlgB6DFKcbeT170vBA xzjtR/FyMADoaAF6Drj9c03vjtnvQ3TsR1weTilGcjbyPTFAAo5G4/4UAAYHrx+VIPlUtgdegoYc kZzt6ZNABg4Gfr+FIpHbIB9+lKOBnAHfFDD5iThf8KAAYK5FGcc5HHU9KB15A+g5pcnaOp+ooAMA HbgE9iTmkJ55zkjPpil4PYHPXv8AjRx0Cg0AIowMnj0waQ4HUnBH507A6HHPYGhTyc5BxnrQAmSe Qc8ZyKO5zwfrQQDn9M0uMng5zx06UAN/h+nWlwQCep747mjGeDj86XPOeD+HekAnXtz0zQcbRuGO 3Xilx3z+lAGPowA+lAARgnoGoK5GPlx1AzSfiT64NKevr3oAO49MU3ccYPWndBgqenpRkjrz1PSg BO/XgdDmkXAxyAcYNLgc45GPwoHI4+h5oAMAt9PQUdwfyGaAD9O1AIHOe/pTAXqv4dRSdc+tHXjt 1ANLyOMYGPxFFwEB/vDNAxxnHr06U7cR0FId2COvHHFDACDjjr70mMYGMbuhpcDoSBzkHNAHuefT tSAM7j3B+uaO3HY45oI6DAHel25IBwfXNMAyD16GmjABKjnvS8A56d6OnbnrQAhwOMdOee1L/Dzn 8qFPTjpS8kccd8HmgY3B9Mn3pNoyAAOlOGOe2eeaXGfXkHBz1oAQg7eRkepox1A5GPSl6DjoKXGM jsx9aQhABj06nrSHjHvS4yvSjgE4/A+lABz16d/rSew+pp2OgpAD+YpgIR/d9PxpRz2wPXvQ2Ooy T9aMEUAKTkHHH1FGPc8e1J2J9/SlAGOfY+tACYyCfbmkOAO/+FLwTxgfXvR055J5HSgBO/B+bvRj Ix36+1KO386TOQBk4HvzSGOxngdM9c9aTdjnGT6ilH4e/NA64yeB2PFAhNp64PsKVhxgn8TR1PHT +VCnJ4oAPw68ZzRjOMfhigH+8GHPajgj/wCvSATq3f6UD2UevNLjOO/GKToRz16UwAj6570mRjnr 6U4DC/8A16TJwMc564oAXnHPpSZ5/HmjAPUHPX6UvOevXpQAYA9MeuaDznuO9HQ54x9aXPrxz3HN ACYHr74FHAHHWl/hH6jpSH2xxx60AHA4GKcncfiPekHPYYzUgGW46Y6k0DJEHzdOMd6njyKhXBzz 065qeEe+ecCkwRdh4xnA565q5Ep3DtxyBVWHrxnPuKtw8gE4PcVBRdi6jB+gFTxjjjg1AhIxnNWV BIH6GpAkHQE9fpTiOc0DBAyMClAwqjn8aBEbDGQDjuTVd/4uMZPTNWWA74wOKrSAk4HP4UhlOcde SO/WqlxkDAGTn8atzn5sZz64qrMR1OBzg5piM+bjIAOMdPSq8hGCADVqZ+W/nVN/vHGOlWhEROPu 8/XtUTjP8I9alIK56f41G2DkbhjoKoCPovbimt6jp39qX/d5PekPGfrTAO/brxmk5xncMdMCjGeQ M49KXGT0HNIBMgr1745pPToB9aD8pHGRil+v40ANz27jmlPPQk+uaOSBnntQenp2oATvzg96CTnt j2FOwD2P4dqbjp1/xpAGPofw60MAMZ6kZxQR6/TpQCOen5UAH589s0nGM9zxS8Y6Uf44xQAh545o AOfalb16+nejGccAAnoKAG46k8Z7ijr37UoB5z16jmkZQMEd6YgxweB09Kb/AAnIGOnvTuAM4780 AdMd/SgY3n060vp0Ppk07PzdD9c03A7Z4oEJjvjseaUc55AoP3jxRnI7DoaBiHo3uf1oPv8Alml5 3cYxjrRzntyKQCYx1wPejJOBgEfWjjaR14596O2SMDHBx0oEJ17gY647Up47il292I6fnSZ9vzoG GMf7tJj0AJA9etKcg9jg0nvz7ZoAUZ689MACjt0zxijjOcUmR0x245oEJjnueefbijGOq45707kY zjPpSYxwOnuaBgeXPp/KkB6YHHfmlyAAR+Ge1K2TnOKQhvXrjGMZ6UuO+O2DzQO4OefQUv1/QUDG 4K4HYnvzijGMdeOBxSj27ZzijqTnk8Y4oAAp5yQPSgdPbr16ClxnGOmfWkAyMdvrTEGP93GcDNGB uOOTS4A5HB7+1Kq8jpjvQMQgEjJ4z2NIp+8RjH0pw5UZx159qTgkZAwfWgQvQ7TgnHXNA4PPbp3o GQvpnrilxnAAPA7GgBVB7fqaaMDBwD3607BPr680oHQgHJ9OlIA/hPH+FHUdCM+tA77ug54p33x1 57k0AIAM9egxjOaf0x1IA9aRQD3/APre9KTzz056mgB3qMZGMninEYxgHgYApoX0wfen9wwKkigA BJ4OfTFOUEZBL9RnFNxjnswzknIzUifKvTGMZwc4oYCqAeMD0qVeOWbbnn1pF3bcDJ7GnpkbuAAf 4v5VLAVAo6Ek89u9TIOxPHTNNXPfOM5Ix1qZTtb73yUhix52ggEFfug96myd/fjjI7VEo3gHlQCD 15qVOAM4weRikBOi7lzwMHqD1qZMkqAR1z1/Ookc/KobnsO1SA5Zgcdcc0DJlUFskE/jViNQATwe M4NQ5x07+1TxDjIGOfzoGPzz8vzH+VTqQZOMLg/nUaZPYAKcg9zUqg/eJY8kelJgSKpJC7upySPW rChiwBJHXPPSo0YAEMOhxk1KnBAwoUdfUmkxD41wQAcnr0qYDGTjPPBPamoTjA7DNThhj0B7mkMA nrxinquGBIJ9j6UgC9OcZ4B5p+DkducdaAHrnuB6fWpF+7/9emRgHGT9STT14Hf8KAFHT14zT4+B zxj1OaZwOV+8RinrkdCeOuDTAhv8CPgdOCe1eceLJR5rZ4IPAxmvRtUdhbttA+leY+LJFbgElk3M fcVpAmR59fcztkEcmuy8GxqkUXmZIYZAz3rjZf3k4YNxvzzXeeFInlZHwdq9e+Sf6VqyUeoaR81u meCVyRWqBleTjHt0rN0oExqG5G2tTA3dzn+lYvcs+fsZB9gOAOlBXGMjaegOKTaGPIU4PoaPu5/T PfitiQUHaQnAAwCadgjkMeRzTRjBwMHocn9aXbgDIBHQ+9ACAck8dMEfjxRnnoD6ZHenchW3YP49 acv8QIAI5GT2x60AM/i524z0IpDjhSc9cHPSnY6DI6djmkwDxkY9T3oARsbevA4wOvtilbPfAxxx R646cDGcmlbHzEYA680AG3A6H0NNbAXHYY7ZpSBkrweOetGMsfYdcdKAEyODtGeTS4+7knHbFAyc YwT/AEobjB69qADJYcDIPXHak2ggfKxHTk/zoOVB3Yx+tKRlhnPPXIFAByOgyRxzSgAtyc7cmkHG cE5z60bM43DoRjPBFABztGcZHXFC/dHYA9QKDkE5/wAKM4Yk4x060wEIzjPPcUdc4zkUuRkBR+Of WkbGMYJoAUA/h05pMfLxzkdqXpySBnnpikXr0AHfAoAMdRt4+tKTxx06jFByWOPTHHajlj8vIxzz igBccjAznnnjBprcZGe/elb73BAP8WRxTV7lVyAfpQAo5YYHB9aFB7gcA/QUHOVIHHWj3GTz1zQA uOB2+naj7uSSBxz7UADdkj3OacpK4x27/wBKAG429O3JP9KOOevXkZoxyfbqaDj+HA9aADr3H0Ip cbVHHXr6fhSAc5P1oAyCRx7YoAT7pXkK3b0p3THBI6daM/LyT7cdvrSqefUUAJjJBAHA6e9Jg4Gc nNKCSM4yRz6Zo5+gAwaAEPOOefp0oxzjIye1A9M9+M9zQTjnIXjGO9FwDG4gDgE/jmlwSBkZ9c9K Dz7jPbjFHAxwQPpn86LgNUfKcAfXtSsuOnI9aO2QM8Yxigg54Bx60gBh6YAx1pAMc9COgHrTuoOK Mn9Oc9KYCAcZY578GnZ4OPwNJwSc8j2FHGB6d80gEYY9Tz0zSnHBOelJwMcjA96X7oGQMZ/rRYBo ywyduc+vanHjPfPpS/THrikzycemB2piG/w5BPI7+1L6559eaU/cyefXmk46nOenXrSGGMDGSMnP vS4A7Z+vagdBn+ecUHr6nHSgBOnYZ9KUfT6gdjR0xjj8OTSquMEHIpoY3GOo/HNO4HOCPrQQPoSc 0mPTp15oEKT3OKOvIwfTNH3c8D35pDyMEd6ADp7d/ajPT+WaOM9vbFB42+tAxM4HTPrSjnGRQCOe pFJjA78dvWkIXpjk/nScDnI+vrTsH7x7fjRxwfyFAMTAzwOfegDHQ5PQ5p3fkZ4pD0/CgBDxnv2o 4Pf6D3p2Mgt1xSexxxzntQAgAIwBzgnp3oJXB544I4pcHdzzg8UmOnT8qAFPDd6Tpk4yM0g68cjO c07Axgd+fQ0AJzxkg9x9KXjHUZHoOlGBjOP8aUkng5H1oATpwMeuD6UdPTI4wOKMc8nAPoetAPA5 IJHp1oGBOfwOeKAMY6Zx9aX29+9CgYBPGenFACYG0nt3PpS4wTx/jSDt06dBS/1/GgBAAOmB34oB 57+1OHuAMcc9qToPmHSgQnTOccccdc0u3OSc9eSBSKPm+vrQRnkgc9MUAJj6ZHTil6K2Bgehozhu ucdsUqgY7kjgH2oADn86QdsHv09KdzgdMn8xSHnscUAJ0OMceg7UvUevvQe+M8ccUEZ47dCM8UDE Prg49uaXOTjrz6YpOB/+ul4Az1Hb3oECgjp1qRctwQT79KYuOcZx3qXqM9+mRSAevYcZ6nmrUAz1 /wDr1XjHPA9ue1W4gw5UYbHGT1oGWoVAPzcnj8Kt265bC5wOeKrR8ckHAq9EAQP1NQxliNBjr+FW lX8D2xUMajpgfXNTw8tyuegzUjJORnIJBHTNIwJB6fnTlH+SKcy+vGKAIXAHIOeKrOTxyfpVpsA4 GTVdwobnjI60CKUnHTnr9c1SmUjkH2yKtzKNxzjHSqkqjnr1oApzLknPJ9qqSAKDz29KtzcZDD24 qtKP4fxwe9WgZWOCxJHXj6VEeVAHvUzg59M84HeolB6Zz6E9DVCI+AOP50d+3XjPU0ueO5Ht2pp4 5xwO2cdaYA2d3GOnTNJgY9f0pcc884/SjHXpn+7SANpJwOKb3/DGCOtOxjkenekGM4oATPzd+KGG AcnHPGaUDGPTnvR9eMnvSAQ9/bpR/Cc8DtTudvJ+tNIznp7UALjnmkH8OcgehoxgHPej0xyO9ACc Ddk+4OKDyOmM076Htmk4PTntQAmM+3pSHB4pSM9uaXDHIXHPegQnrgAUHoMj8qD1+lHXoRz1FFxg RkDAI7kHrTfU8HBz9af0JyOOopoxxnA4z60XEIvTqoxQx/DI5pWGGxnr1pOvYnHamAhxkjkUDtkU o6cgn3FA5Iz+FAxPvdvxxRjjk49KAOp6fWjHIzmkAdB7UYxuC8j+VL/wHHrSkZ47kZpANxjqfc0m 36Y9u9OPQ4/UYpMcAHI/A0wE6ryAp7mlYc4xjNL1PrR/vYJ9BQAnpzmkJwMZHT86U5yOvtSj2UDH WgBOM4x07jvTR7+nSnD/APVQevP6GgAYDd3AxRgLQMhRkUnT7pPA7/WkIQclR3560qj5hg4z1Pal /iJ/pSYwOnbPBoGNznG3rnGc0vQ9yKdyRkY9DxTemBjJpgOwACfTqQaXOWwQDjikGQMA89jSgE9M HjrmgBq7c807HzdO3PNKME9KQdQcd+KAExgfdxgf5zSn5eaUAYIORjtmk52nPpkn2oAMAAdsHkGg rlgSMj2NP4X5lOPr3FN2jkdD270CHAdcDB4/CjJwOAPcd6UjnKnqe1Jjnp19KBikcdD9DTh26Cm8 e+76U7b06nikAnIX0HfI4p6jdg9jQUwcficmlxtzjg/0oAVQSp4GSeoHFKAQo459M/pTfQEdO9Sg ZcDqOnPGfpSARc5JxjI5zg1KB82CNvNCAFckEjPBI9qcpyvU+nbmhgOXIXJyD608cHIwSOv170xc gY3bQB+XtUnO5cr0H50AOBzgjqM5xxUqk8nGPaogpHJXrnjsamUAEHt1NSA+MEhW/lwKkUgKSRtx 26nmmBMt0bGO4z+VTRgAqQT16jikMcvGCAFHTOKtIgK8bcZ4PeoADtOQQo5655qePhR8ozyM4/Wg Cwn8OemeamiyAu1VUeveoUKFlJ5HapEC4IxkA54PSkMsDKkk8Y6fSpsE4zgeuTmoEwCcH/CplOBw MkngnmiwEvbP8PYVOq9wPlPUVCucYOMelToCuM4zj15pAWIwMZOMetSLnt+tRJkL3HsakUZA9etI CRTnjPPJB9KdnKjtn0PWmLktyMAA57U9eeSOaAHr6degqRc7emO31oQdgePrTuWbJ56dqAFxtQ5F SQjnB5/DmmqMDA9e9TJnJO36e9MDN1g+X82CBjAx615R4rP791IIJGQRxxXqmtPmNlkK7ewI6V5P 4qeMyFgd6qPlwegrSBDOMZd8yoMrlhnPpXo/hWISfIn8XB7DFecwoGuFUt8qnv2xXrXhK3RdMUIr GRjuPoa0Yo7ne6WqpEixggKoUDtitHofTH61WsIlCKBzxjNXNmM8cDmsHuWfPC/KCTn6A5oC5GFz wM07OOpOeoHrSAheGBwOcevtXQSJg4yMtngn0peCzYJwcdelA2+g6ZPtQv3jkA9MKBQAnVTtwSeB mnDlSTuzg/hSc/dbjnrnFHD/AO0MflSAD04IJHUY60DOASMH+lGSNuV3ep7fWmqoAOBjnBI7/jTG O4AOCRx94ilHON2OBzSLz0yR654+lKAWO1DtyRyegFAhCRk4ONo6Z6ikI657c9elOXlzhQOMcj3p FyVGwYIHrxmgAwS4IXb3yaAcHPBOe/WkwCvCZyOSeMUo+QbuR/sjmgBvRTzwe/egD5hn65zSsowc 5wOh6Uf7JGOnfNACsCW/pjrS4/iPb9KMfNzjJ6Gmg/Lzkk9OOtMAU5AA4Gc4zzRtww43cng0uOOm 04/OkB2rxkjuM0hhk/570dB8h49e+aANo7jBNLjjjnGB+NMQijjjkYzz70nfI4JHHHFOG7jO4DP3 fSjp94Z9TmgBBwQe/rmgjjscDpjGKVgQm4c8fnQAdwIx7c8ChgJ/COWx6Uu3IAGCSTQOuQe+SDSY 744zjNABycA9j19KOuBn3HvTmGPlOOvXNJnbyc4HXBoATOPQEDihup+X0ySaXP3scEdqPlLZJ78U hhjnjGM+nakxjgDr0pcAKWJIOeRSnleefWmIMeuMY646UA55GMg+vt1pvA9hjpTz3yMcc0ANGOnG evNGfl+boeQaTIIxkf408D+8BjHr1FADWHHPueKMHoemPWjBBXtz60vzZPIJzQMb25AznuaU4DAd Dn8KOowPUDr+tLj5jjPcdOtACEjjqOaMDgE845FLgqBgYoHTHXjIBpCHducD1pu0BDwBzkCjG7OO ST09aU9eenbBpgBOf8abgdRjGOuaXOeRx9O1B5zwPpQMTOGyOd3Xijp0GD7UEYOCAM9eaVRj249c 0CEz8vyk8ClI+b5hnHbNJ+YzyKceu4e1AhAPf8c0de64pcZIyCMdaCMnJB65oGN64FHOSTyM+uaX gYHHXOaCcnqSM85FAIMcjr16Uirxz2p3BByDx1oOOp7dOc0ANwT6Z9+xpTyR8w9MUox6sT3+lGBz ySe3FAxCMLzyPQfrRjGCRjGcZ9KO3y8HryelL7e/c8mkIaCevUDjIHNLyCMn2BpoIJGBzjv0p2O2 cAd8UAIBgHHpRj5R+VB59KUjDe2ccGkMTthvypcZzkcf1o5J5yO3FL0wcY+gpgHXqOnSkPQ5wKXH PbAowM8Y29eO1ACY9c9aXHT86MYzyT+NAGcgYPoM4oExDt759KUAbeCpxxyO9KcDgD396RuF/oaY BjHT6j3pQBxg9qB6f/qozznrjke1ACY9Oc96P4ee/pzRyMkDtn8aceMfTPWkDGjqMDp+lIvQjPc8 etOx3HTvRtPQc+1ACY9OfWlAzxzmkI256+1B4zg8j2oGHbB+vTvRn5hzkdqXr2J9/SgDGR36dKAD Pr9c+lHp6npR15H4UAZOAD1570AAWkxznkf1o/Dn27UvAOO3XGaBCcE9TznJzSenT+dP79/YmmHH 49eaAF7D9fejGQM8496TscZx1py5/unkcUAHOemPxoYZ747nBpASR36YFLk8+ntQAfxdOppF5Ax1 6DNKTkcDpQe3qOlACcr6Z+lKAM549zQD6Z5557U7I5IxQAq5PFAySMAemaUAHPPzetPUfMuce+Ot AIlhQlj6fXvVuH16GqkRz1AA7ir0JwP6Y70iixEcL3PP51cTAYHPXkVVVCe2OPTpV6Dle2Tz0qGB bhGeR355qyoJUZ69TUEHT8KsqPx9cVIMfjsefpR1xgfjS5PrSdeuOaAI2Pp9Biqkw4PGD3A5q1Iw 7jvjiq03bP8A+ugChIm0nsOetUpPRhjnpmr8nLEDGPpVGZcjhf8AGgCnLwpJ69cAmqzcjpk9TU7+ 5PJ6+1V39sepyatCZA/AGGz9OKZgngdc8U+TlOh/rUR/XFUAn8XOSPX0pp47c96X2GcfypvHbp0o AGP4H160dPp6Clxx3x700AdDQAYYZHbsKGBGMc56cUew7HGRS+56elIBAAW5BNJjIAOSe1OAOOAc 5pD0x7fWgAPHOOxBNN3fQ4BPFLwMY49vWlz6gUANx0OM9xij6gkn1NLgn+7gCk68jJoAOPXHHAzS YO0kE+h+lO9enamjkHqR34oAXOOVGc4o6njGMjrS/h09KTPH480CE/hz19c0bfm4xTuDj0zxgUnc Z+vFIY0A8FuP1pSPlyRnAzS98nGelJkcfXmmAEd8flRge+elBHr9Oe1A/P3xQAdFA69snik9h6du 1KcfNkZ7460o+6QB+ZoEM2jAGRknnJoAxnGc9euadgHbjFHrnp7dRQO4mPmGAT3xSLkEenr3p1Id 2eRx7UAJ145z69AKD8v1xxz3peoPUDsBQP4eg7YPpSACd3qfcikx82RkNR2x0H8qU8cEj+VMBBzy eo7dqRe5Bz3PFOPDEH0zgUdQMDj06UhDMZx3FKOD1PPWnEbRhsmjGSMjPYgdKLgJgnuDQpx2GPWj IyOP0oyCRjB7E+tAwP3TjOe2TS8FTycdsUYztJ5waCPmGCeTj60xAQCRjGMYxmk7fTgnPWlxnIHY 9+9Lj3zznrQA3AGM8HsBSYGV/hx0Ip64XsBx0pO3Q9cgYoGG0DtntzQFGcnp14/woxyM4HelwBg8 ds0AKoAxjrjNJyB+v0p3UnPIX0NIQCPlzjoBQA3AyeOeuaeevr6HHFKnOcggg9fWjIC/UUCBQeec YPbvSqMnoD2FIMdhj/GnAggDGG9MZqRgox1JAPpSr90An8jRtJ4X+eKODwcZoAcc4wePx5pR3Cg+ 3OcUYGc4yQKdxycZHT6UACc9TlTwTTkH94YI98kUKcKuQBxyo4pewYKMDI4oAXuTubgYFPwOpB+b nmkXAABAB45PpT1yeSOnIA4wKAHYBGOTzuHFOyCD/APTOBSYA680qDaOV69BjoKQEiouRnOc4XNS fKMdQMZOO3NMUNu+UZ+vFTKu1duMf3sGkMlABAx1Poakj27uR+nWo8/NwMAcnmlz/wDXx3pAWYxk Yz3yRjrU3IPG4gHHXpUK7fl25HerEbH/AGuM5oAkU/dbkZ7DtUo4+8Rg/kKjT5TxtLfTNTx429OM daQDlGMD7vHJ9aljUkA8AA/nTQAVB98cd6mAAZcgnn/IoGPT7vdj0zVkDPReRxzUUYI/hC/WpUBx kknuaAJFXd1xyOfepVHVupOFI9KjUHHHIx0NSRhfbPakBL+oz6VJGc7ty8fXrUWMD5iQe+aljwee CfTpQBMuNoyDzzUgbngZ54PpUaY9PqQakTrgj8jSAUHOCORU8adOB7VEPfn1qcNiM44x60xGH4h2 rGzNkEDB968e8SOYo2yPmJ4P9a9U8VSAqwJO4HPNeR+JzuuCcsRtxj0raGxDMKxTN1jjrgk/4e9e 0+DYyttCqjooH0rx3R1/04BeSehIzivavCe4RIqocBQN2ecU5BHc7S1AVFxn61YqG2wIwMdKmB44 P59qwZofOuRjPPHcGlxnjauevJziggeXgDC49OlDAEjA4xgV0EAOV4HFALhOOSec0pPzZbAyaT5u 55xwe9AAFIycY5HJ60cH5to2570YABycYPI+velCk47r19DQAnQZXPGc4HrRuDA8cdQKB94MQQvX 0FHJxuGRg/8A1v1oGIOMMc7hzz0OaXAH8hjjikGPTHTHFDYBDbSNw5OPemIcMZGQBjGRn1poI25+ 8PX8adu+Yn5t2fWk6EjJGOM5oAO+RnuCaCfmbODxikx6Dk+2adk5ZuCRyccUAhuPlywIHoKXPzYY deOaOADnHfkindOTkD0zQA0ZyD+NAySV/i7Z6Uc4xgevXpzR2BAP9BQMbnI3AYJxzj8KdtDdeMnP FHTAXHTt2pWLYPagBMHJ4x6fj05oIPPXrz35oGWPcZAH5Uq8HqMbsZI9KAGuvyr82QOQDTtuG/i6 8be9GB2ySM4+nenMBu4Hfg0CGAEjjNIwwWycjGKcBuI9PU8A0KDwGwAT3xzQA37pIHzHpildduBt OAcfSgcBcZZu4xSMADggg+h70AKpBXsV+vApcEKSQTnuOlIvDAkj2A9aVe+M5x1PagB33vvA7evT mk6tyWx3xjrSHPtyMdaACQB1zx6YoAQj5QPfPNHHfGcZyDmnDryc8YyTmkUAgFgQeO3rTAQ8jnk5 znpinZy3OOvApueM4XOMgHoKX0PB9iKQC42nnP1xRnp3/DrSNkfjwCDSnhsjHXpmmAi9eB78nrS5 zzgdcHmjkdAOeaTseh6YpDDK45IH09qO+Cec59aU5OMEMfejqRgjYRn0xQIbkAck53UpPXgnH4Up 4P06YoH1znrTGDrnIByKOeDxjFAHC4wc+tN5BbPJGDwKBDj16YGfypM8Dvk0NjaeR7e9K27J6+lA xqgBcjtTjnp1HU+9G30zkDjnNGASc8Y4GO1Ag/hI/XrQPwz6dqBu5ORQB97uaAExwO/40d+nsKcV 5yRj0Bo6KBgfhzQA3B4C4PpQfvY6DHXNOzg+g9hSA7uMcdR7UAJ1GQM45o+8W6HFO6rk9/ejPzc4 z/KiwDQOTz2xSEjbkLnt0607AyDnJ6HI60LkEFeccZoGJ9cZxSDpxhs8k45pyknpgYPUdqP4RnOK QhD933o+nOD0zS4+YAlQuaTDHvwTnPSgBcjOe2elG3Lc4HFHH8Lc46egpRg7cevNIBOq8np6UuPl +lJ35z9B60rA5yQeT/8AqpjEJOegH+etLz7YoPGd2D/WjqOg+npQAHpjp60euckd6TscnPfOKXBK jAHPbrQIOScHHsaB07DPfuaUHDA4z2pMZB7+xpgAA6YIwc8Ug+97U72IHTpSdT15459qAADA44Hq D1pQvT+WaOn1z+VJgDk8HNIGHBznGcetI3bP1wfalIzn2oHocZ6nigAXoOc4/Cjtk5HbnrR/F7+n rRg/3uSM49KYB0BwOfrS5xgEEduKQEY4PtTmBz268D0pDE4BOcgZ/Sj3OP8AEUoznGBjHXPQ0mD6 c+w60ANBGcDn09qU8Z4z7ilwSMDk44oI+YDBxjigA9M5+lJ0x3PvQQMHP5f/AF6XB7YIz3oEJj8B /Kk6N16d6cPcfj3pcADpnPXNADTkdRzng9cUv4YHuKULgr1I54oHbkjFADeNvrn9KUjHt9DmmY45 z1qQAg4wOM/hQAmOD3/Gk788elOweO3Y5owSM9PTikADpx3qZMEDnJ9KjHXGD6gniplGepB54x6U DJY1zyeO3XH+elWbYsNwPWoEODz0+narUOFBINIC/Bwv3RwMdatw9gfwxVSAnA9+emce9X0HGD6+ lSxoswptxzk9+asKD3B/A1FFwCeMgip2Pr+lQwDGCR2680jcY4Ge4zTsdDn9etNP4A55oAhl+8cY znt6VVk5zkduKuyYPXke3eqMobd8uRwcGmMrTdBt/SqM+FyOvr7VfnyvoOKzpl69MdvamkIqT524 Axxiqsy5UD8x3FWJMccjI61BID0wT36dKpAVvukYGM89aYwAbnGPapSAD0468moh94Acc+nNUIb0 IIB+lN5P+19aXHPPGDzxSNj3z9KQC4xj0796YRjHp3wKcPvY2jHvRjGfTOKAFx7e5/8A1UzjnBJ9 zTtueOQAcj24pPYg/T3oATjn0J5pfr0xwc0g7Zxg/rSqefQUANBBUcjHQUdVOQQO9ObOcHjH603P scdKAAeu3Hbml659qDzgjmg85PIx1xQA31+tB+71JGKdzzg/QUik4+g6Y5oATAGefY96VumOaTgH j+eMU7BL9OpoAaPvcHp6UZPULS5/x4oP6/WgAzyfr27UmPTkgY4o6nr780dcdc5oACAOfyHrRj8v T0o9jz9KAc/Nu+lACAevYnJzSNk+hPSnccYNJg85xnvxQAmQc49KM9SDk8c0oz6n0BNA4HJPHpQA Ae2fxo/hznG39aQAbcZwetC9OmTSAUYJ469+aQ89B9aBjOfxxihRg8ADn60AGM4yc8Z47UD7xABH HTFLg5547elIeQc/jQAKPlwePXFCrzjtjnnFL0PGMHpRgD73GeOaAEwcAHt0zzS4+bnOPrSA8Enj FL91TgDjmgBrA9h3H4etLg4P9O/4UvoOCeppFxz06Z+tAC+hxn14pCABzzt96VfqeuD70n3eD09f SmApPcDIPoaMYIHXvxRycDpn2p3zH5SPoPT60AN9W6gHvS4PU/N6UYHOc9PSgqMY6d/XNACAMGH8 T9z6ilB6lcc4BFKQM4OB2oUY6EenApCEI67udvII60rAEDpnr/hQV5Az16YNLk7eQfXg9aBi9uc9 ex60AdFTP50Hg5IwO2ac3HTA9s96BCcZyvODjJHb+lLn5Sc57dM0i4LbenY9qcDlSQOvUg1IxARw NoHfOetKU2g46YxxSKO/TtxThzyO+SDTuIfg5zjA6mnKOn1xz2poXJOcknjPrTs4x90Z9OaVwFAZ sbiME8Uq8hcr7gdc/WngZ/u8ZwelGPu8FRnr7UXGIuBheSenJqQZZgcDd9etNyc+pHpzTujEEE7R npQBIoKk4HTg+1PQHcTzgGmKAc7cfKeMGpT0OMAkbvWkA5QD7ZPNSbd5OQTwOc4596apU+ucZGe5 pRtz8xJBOcdKAHqSMkDAOQamCn5s4HHTPf1pkfB69Bg81OuDjI74IpMZKoY84PI4Gc5qVAXXlAOv BODTIwA3IzyAB6VLGCWIOM49c/lQBIqKpGeD2OelSqfbpzjPSokGOg46EEdakjUmNT14yexoYFhM dCMdQBnNWFHQNxnjGe9QxgLgY4x/Op42xjnIUYHtSAkRWOCePYVIiEYycDp7io0AByvv0qZUwo5P A5zQMeBngMf5VKOoI6jt2qNWG75fzPep1Xpk9OeKQC4DKOpX1qZQVJ/PB7Uikf8A1x2p2QGyVJPq fSgBSM5zktipVGW5Ge5pqjg8Y70/H16c0AOXGeec1LnbEeQOOe9R9MDv64pzDEZwOOuTzQSct4kl CrJwB2HqeK8h8Q/fb5gOcY6EV6X4omwHbJ68Dpz9a8o1gs1zgt83fd61tAhkvh9CbrKY6YI/GvZ/ CokMKYwGzgcdq8j8KBvOQhdx3/NnoPevb9CjCW6gYBzwKU9iom5EMg4BAz0qwoG0Y6+9MThSMYp+ Px44FYlHzsBhehy3Ayeh+tB4xx19+BQAAQAOhwcdKQ/dPO7I6YGK6CRSMZ457Ufe74yfXPNC5I25 IBP6f0pQMkcE4PAApgJyQdoJB+7nse9LgcHj0OT/AEoODk5JPJHHel7njHY89M0ANCYUjg+g9qXD MBwSQcCjqV45xj6ClBJ3HG0HkA0AhByPugtngZ4pQCRgKQR75FM6L6DNPPU/eI9uMUDEHHLDqOgp WHUqcd+O9ID1JPAOPp7UnAQMpK89MdaAHD5my2Bxmm4wfvEgLnpS98ZO76Uu3ruPTqDxTuA3jI9f fHSnYxu7ZOQc9T70g46DvxntRtyD659ORQAdVw3LcAgHFNPBI5zjnH+NP+83qevA6Cmk5xk8ZJ9M UAKo5wxPJ/CgKD90LjPSl28nGM9aQZ9B04zx+VACMOMnJJ9DgU5gAB0xjjqc0nG7B57AnpQeOSBx z06igAx1OD6Ak/rSgex29DzyKTG3jBycng0pHHXn1IzQA0crlgenFKTkjI7daCvzc+nXpikU9ANx OccnrQIFHcdO/NBHysCV3HsP50fxDIyO5pf4vp1HagY7ndyS2epFNYnoDjnNG3Pt/Wl59Pbr+VAA uDwOmeaThu+Bn1oUcdCO3XilUgDHUnnPrTEIBjtj0PtSnGRgYyOp78UYO3BJ9vWgjAPUj09aQA3H HTPTPehh8oJPIJPJ60nI56kUdc5AweRTGBOM+/Xmg9+2Oc9MUbcdVPqDS4I29z7UCDjcRnHH50DO AeMdRRzk/Lntz3pOSc5IwRgUALjC9hj0NJ15PPpz0pzc529uaAPb64oATI6dyKFAOMbh/WlXJJIx u60KOAR17e1IBCu4DGSDyMUZwucc9qMD+HIPTOKXoSc456imMVTgDPUUmM9/rQoBHcA9DQCNoAzj PXoaBCAAMDx0yKU8DB69RxQfmAHpkZNAOTk5yfegAxluce3ahsox4PHHJpT1Gc4/rSL0wDyen+NA CdF4H60uemPqaOpzznPJ6Ckzkc9B3oGKDnnjnrmjlWw3Xr06UDBU88UZwRkUABG3krkdzmjB4wPl 6Dmlxx05Pr3pcnv8tIQ1c9fSkA3dAWyOtGBjPQe55pWPIwMDqOaYCdhzg9MgUvI68DuPWgdD0Pzc c8UdTnHbigBcEcDBx6fpSdMdemB70o59OeDgUbcDj1pAJgEDjH0pNo3UADuMcdqOCTnB5wfegY4Z zn7vHekXAzzjPNLnHbpzRj+7lvSgQYxnHQD8s0Y6cH05o6jI6Hg5o/iPX8aAA5AxnI7CkP0xml2/ KQfqKG7kEg9RQAZ9RyefbNL/AA+ufWjHA44H8qQj1OB9KAAY2579c96BnGB1/nS9OTz3GR0pD2PO cdqYApIzkk98dKBj8KXbnOc8+tJn6e+e1IBcAZxz7ZoGR68UmML0pen8OOfXpQAgHHC/r+dHC568 DvS4PBbrn06UuQFwxz3NADQCRgc+tLxuzz6HJ60nTHBY9e44pfoMZ5xQMOmAccjmk24yOeKdt47c 9803GecZ9M8UAGemTngHNHAY46dBzxSsCFPX8RSNxzg0CDjJxz3J9aOeByOOBSnjp+Q7UZ68dD3O KAEx8pPOO+aOvXOT+VAGSOvHcUZz1XaQfWgAzjkAk9Pwo4GOGFDc7gOlC8+gb65pABJ64JGeT1oP Dc5BBp209weeB703bjkZ6/5FACoAemR7A0J145J/SjGMZyuD60qjJI5xmgBeeD14qVBlugqNQexI H1p8P3sY474oAsxn8R256VejXIG7J4zVRFXcGI56AdcVbiBweQR1XPFIZdiygGBzWjCcqDx0xn3r PQdM88cE1oW+BjHTFSMsRx44OT+PSrEYx6+gqJG9OOKnxt4qBiY/MnpnrSHnqevA9qcRzn8qa+Au AATQBE4PA4xVKZQWyMZPWrkgGBt6ZqlMGDHH3emO4pgU51xjcefUngVSnJ+YAkj+dXJMkYyMk85q nOCPRT+dUK5Tn4ORyScH6VX3A5x34ODzVib7368mqznGM8ccVSAjxksMjjrnrUJ+4ckEd/SpCc56 Fe4NRnpntnNMQ3JwASenBFIx64Y+lGcjuc+1DHC8AcnjPWkA3g57/Wjt8vOODjijvnK49vWj+HPt kUALgqcn6DIpq/w4P09qXv8ALxnB9KXr1znGPWgBvXqOnPvQMnqMd6XkLggdOnWk6Y5PX60AIvPI oB+mfve9H3R/OnfQ54GaAGgn29/WjkKSenTnmlPO0kdTwe4pCOOvtnrQAvTk4HHU+lNB5PQdO/al 69uKM8jH5UwEIyvf69KU7iT2wM8GgbuPpxxRyeDzznmkAnTheecYxR16jIxmlx2Yj3IpB90gGgBO +Sc0u3HYfXmh+DwQQR0zQeH9/wCVACepA59qXscduMk0uAwHBzn8KbwQMD8z0oAM+po9OM9sYoXo CB34zxRnAbgYx60hAD0BI45JoBYg8c/yoxkYUH8O1BOTx0NACAYz04HcdaOD1OcHoe9KRk4znoBS EevXNAw56nPXrShegIAPU0ADsMcnI9OaCPrjODTAbjr6AdjS9Oo59hSkYHt+VJtwTjn39qAEIJKj I9KUZBB5I9QaXGf4eTxn0pDjJJwTj9KADOH56/XpS/Lt698UhHUUvPPOM85zSAb0wBkn19aMEE9c YwMGnN90+wo49T1xx9KTARRt5Yn65o5KAnp3yaOcjHUdOaceo6AHsBmmA0Ag8+vPelXbtON3Tknv Tu/AAJHNJ2Py5xQAEYznO4UmNowcgHpzS59fXoTRtJx6+3Y0ALnOMZAz17mjgsO5J7jjNHVTnOfr S8hWI3HtQADI6A4+lL0A6fnQoz1zj0B60uOFHY++fxpAJt654zz+NOUcZAI/GkXueDk9vWlQAkDO Ox96LgIRn5sZGc0u0ck9/Q84pQBjn6U4D8iew5FACDkfLjG71p42kHjnt3weaAo/i/D0oXOQM4H8 qkBduPr3ANOHynpnuO1JgZAJ4xTwAF4HBH4UAKqcLzuUcdO9OC8HGV9RQgznGGzzmlA4BH8R5Ht6 0AKCexLYOOvFPA+Y5P3eBg01QT069KeD36c9APagY9VJ7dT9KcuMjk8cEgUwANgjMh6gZx0p+PUM B1/GgQJggYz7ZPSplGSCQSc4HPWmqu4cdPpUyAr90c8k8Zx9KBjo1+Yk/XntU6D5lyM5HTNRwgsw zy3UCpYwADyODjFAEq8YCg7vYVJGWLchVGO3aol4OAR7Y61MobAwOMdCelICVQ3Xdgg8mrAUkZx2 GCKhjAx933yPepVC/eGd3QYFAEig7jgg/Nzk4xUyjC/NgjODUavkDjk1IvvtOT168UhkydzkjpjF Tj1x39aiVstwOfTFPXofTGBn1pCJEHbAJ69asIQF6nmoF+6OmalRgzfKPl9fWgZLnjtgD1qRVIxt 4Hfmo0+Y9e+BUqKdo496AJFHOKkwT36daTHQ4z3qQAHJxQAqqTnJ69qddLtjwPTp60sIGcZyevPU 03UGKwbzgAD8aCWec+M3VVk78ZIzXlepOzyYPCivSPGTgMzKDgtwfpXmdyN80gU7SxwRniuiJD3O p8FWxeZDtyA2SB0Ne36OimGIg9R0ryfwHb+W4zwAQc+pPSvWNJ+VAMnnJJrObKiawXHTn60o+lAy RyKdjPXrWQz5yUbju6EZI59qVQhde4x9D70MA27AGOwHakwdoBzuByCOSM10AKd3GOMg4J6CkY8c nIx0xTipPBXbt9x1o78YIxjOMU0IGx0ycAdhgik6KeSfQjvR827nB5yM/wCFKTgc9+3cUxjSBtzn nPXdilH3hgYxySKco6jC9OmeSfyppUcEDOR2NIAwSO3PYn3pV+Y5BGCcgCkydwPTnNBwHGcdM4Jx TsAA4Ykk8ddtLyDjdj/axTQVXaWyMckDnml4z1560gFUEEfxHqOcUirjnOB24pBndlSDt+8M9KUZ zkDGc4A/SmAZ3MBnKjjp3pBwo35HOR+NO+nXpnPWkCjg8Yx+BoAF6gHPocfT1pcYBAXIxkd/pQqZ +9gHPQcZpASBg4zjH5UALjB+bjjqOfwoyNmMYBHNKDhV9Oh5600D356etACknjGcDt60jcEA54GR g+vrSbSFAJwQOo70uGyCeQBwaBB0AzjA9sc0uME8HIwKb04yw460oBOSQcY7UIA25+VQSB054xSY J3ccDHfpTwMtk8Dpn+lIBnGMHPGetMBM5+9gepzmlXDL6g/7XBox0HSkHBz0HQ5BHNIY45Pp15pu MnP05z1NL/CD6Hgd/egHI5O0+46UAJkcHsD1JwDSjgjJyPyx9KMemCP50hGeOc8n6e1AhV7kcHrj HQUAEkZFBB5zux060i+owQegoBgG+XrnJ45pRy4zxkUvfA6deKMYb9KYByoHIOOMnvSdR1OSPvHt SjjqADjdn+VGPYDPv2pAIvD52gtjPWl65x+BpB93jPPFLwMYJx1HtQArAkc880mcA9uM0dWb3/P8 6Bk/1pgAGQBnJ+tO/i5HGOPpTRyeQMAZx3xS4yOBnjtQAhz7njPSj7vOTuPIAFOyQp6jjuaO4bPT OMCgBoxn6DOMUfxAdcj1pSBuOc5oA5ztzzg+9IBpOQcEdeeOlLj36cjNKc7uPWgDpkj0PvQDEHHQ 8/lQuOQMdaPRjkdsUY4Pbt1oABznPHOD3pM8ZIwMdv0p2OuFHtSYO48Dk5oAXOCOoPcUYPRcUKcK ckdaAOOOOMdaADrnsM8Y70vpnJ54yM0ds9uvSkx+noO1AwGQxyB070hGeOMfzpQML8pPX15o5ByA c4yccHrTAQnIyeMj0oxz13djilxg4GfqTR/Ft+Y/SgAxu5z9CDRkDr36YHWjHzHaMelJnjB9MA9K AHYOMcE45ppwGXn34pexyOMdxzSkE8cnsOMd+tIQikkYz0oYZ549c+9LjHb9KFXBACnH8qADByOP ce9JgdxjtwMZoGBjJGeg96XJDcfKOpBFAxvp0PbJOKd2HU+lLj5c4PB9aQnqO/X/ABoAQ5H5YzTs +3XFIB82eoHYUo4PAOOvNACAdOfr270oPT0Hv/OgdBk8dz1/WlY4X3I5zQxDcbSeO/OaTAPXOAcg jtTuuMc5GOaDuwM5A/SgA4BGOvQ0hUkc46flQSMAnoDg0BfmI559RQMDgt9RyPWlUYxwcj1HNIeg 5xk5570MPx9yaADnPzZ6dc9qOR+I9OtGSDzQD9QQc5zxQADGPTvg0cHsffFKOMcc0dVA46c0CDbl uc9h60hGeMnH0pcZxn05xxijqcdO340DGsCeMEE96PQkD8aVT3GPzo24XJ6e1ACfTJ57UYG04ORn t3oHXnd7AZ4ox8pJyR1zQAMT6fTilGMngCk4PTkGnLlW+bFITDn15xmk5zzzn06UZyqspJPTp068 UvRuh6fWgYDG7jGfcZpMZzz1pVx3HX5ufpSjoSxA+lAhyjHJwcjBqQJ6YPGOKaoyo4I9+tToAcoS w/rSC5ZRQqgnPBGMdqtwHIAwfTk5qjGTuGD19uav26EDcQDzgUDLkZViw/SrcC/LnJI4qrbj5un/ ANatCMYHHXPcVDGiwh+XgYxUgBA5xjHpTYxjJPPFT9xj6YxUDG4+cE/lTT1+lPP+0RnrSHv045zQ BXk7nHv9KpTfPycfMeuKuvxnnr29apyp8o7iqAoyLsPzAEZxz0qlcZGONwq9Njc2TznPX2qlc53c ZOeTVCKU2enB9hVaQ/Meh9ParMg56H35qu446kfQd6dxEDHj5h9cCom6c9O1SHByeOhzgVGxO3k0 wEYc9Rz1JNN756A9c04Z3dj06UnPvx696AEB45H4YpByAD9cdaXqOSBk9R3pCDkdfw6UAGSQc4Ps eaOFHXHY0ep4pFAxkY68mgBeVGR6Y6Ug6DGeeoPal9huHqOtGTtIHysRQAmNo5Hfr60mMnIAyP1F OAGfTjqabnIOOR79KAF4HPJHXpik+nTPbjNLz9eOcmkwOScqOoNAC5PtnpQRnjOORjiggr3Jbrwa FzngHjoSe1ACFQSM45HrS9V57/pR04IB560f7xFAAe3HftTfoDTuOMHJHWm5JX8unegBR2HHTtR1 56YoYDnJxj9aTHHy9R39aAE3buAPfnvmncE88464o6Hr168UAdB+YpCGk4ycgenNJkd2BAHrTucb h3NBHzAkYBPQ0DDGDnJBI5waCOh/i9qDy2fX0o9epH50xCdOQcdsGkIJB6dsetL168r2OaP4cdel Aw+hAOaDnH3Rjjr2pVHzDHT0HNLgHrn6daBDRgnIyfej+EUp6nGMClIx33Drj0oGNUcrwCcZ69aP Q8DPIzSrkche3ek6McfNjk0CFHfOcdQM9KTqqjgHp0oXO7PUgYwe9HUgKAeeM/rQMVcFhk9BzScA 88Z6HHNKx54604hsrjGc8kUgGhuQcjgClAyBjjB5z3+lLjOc/MT6jrSOQ38OOcA+lIBPXPGB3HSl HvjGexxmjBP3uh9O1LgY46UwEGWHI9+tLy2Dg/hxmjnd6D2HFOXkdz60gE47/r3NB+9x065B6UKC Dx2+7kU7AGDkkH2oYDeO/wCFOBA/hUY4pzce655ApFU7iOwGetACIP8AgOBxnvSjIAAzg8gbelAy P4iM/pT+gzuHI6jmmABSc8AjtShQfVR3xQRljg4/lSghcdcdu4NSwFzjPf0JpVGflwcn1oxuHTGe QaUjpwAPQUgAHnBx/hTs/KMKQB2PekC/KTg4x2GSKkVThSe/oaAEXHRi2AM9eoqRcndwckf5FAHy ADIPHbNKMZ28++KYC7Rk7mzgdqVActtzkDqaF9NvOOop6KFJz19PakMXbjk4GKcq9MAn/Gl2qM5w AemOOKcqjgFAvOOefxoAd0BwAOByRzmpETaR16Z6H+dCrgDCkYX/ACKl2ZKkkksMAUAKgCjj6k96 mGCOnOeTjrxUffIGQMZ5xT1P3cj8SOtAE65fAx3GOMU9VHGQee471EpIbCk57VOp+UknH0OKQEsY Xuc44wetTRrnZkdqhXnH8R7HPBqRDjHLZ7Y60ASrksD0H161NEOgI9zxUScc7QcdOe1TbR82OMcY BpASAkghRnBxjPWnqPrUSnkBuO5xUqHCkcjHQf57Uhkg6AEdOeKsKpB9O1QRgcE8g9cVYU/MCQSe lICRVyBjOBViMAEEc1BGRuGc/l1qdBjkD8KAJV+8eoI5yKVfoSKbGp64B5/KnKCevPPOKAJY/vAY 6+hqnrM+22fJP3etXFJB56jkDFYHiKVoowRnJbJx0FVETPN/FsolmYKSAVzntXBvm4mAwcMwGB1r p/FVxMs7pvYdidvb0rnbPcbpCueGGa6FsZdT0zwXF5bKCSWyBzzg4r1TToWSEbj2zXn3g+1V41kB 7jHv716PaD93x83GKwkaIsAHHzdPrQGOOlHrgcUA1Az50JA35+7xx0xS/db7ucDsPekc8H68DFG4 Ath1I6cd66BDjjHQZznrzQxHOcA4zjPFI3O37oyMHHFOPB4zzwABTEJndn1Hv1o25xnPPBwc80YA /hyexzScADdxx3x+tMYYIOOcgYHOM0vzPymBgZ96CN3XGFPcdcU373JYn6dKAFI7EYz2znFNOWXO Bt559KXaCeeh554p2fvOwHTIGKQhN3BYIFJI98ZpwX7xB7Y9KjTCrnIJwCc8fhQuPLJ6KR0x0oAX BIHUd8il2kFd/buOtKMHlSMDHSgjoM546k8CiwCcuuGHbGQelL12nAx3owc5UMwUc0ZxkjkDsaYx Gw+Rj6d8GlHX37jpQDzj+ZNCgBugJIPvii4Bg7ScbgOcjqKTHXavIA/pR0AwMe/r70KADxj3460A L0YKB3oPGMr8p756e1IejKeM45FKeVIC7ST09aADgjIGPU45JpDwRzzngA0rbhkevXHUUMRnJwO/ vRYQErkfMOvXPNKF56ZXHUdqTHHIB7AAYoUEtyMnPGO1MAByD19iaTJ+b+/xjPalz0JAPHGKCRwS cEcY29aAEb07jJJHegE45BOD60uPUc469jQwP3jz6UAJwcjHfgelC88g8kEnv+lKc7ePTPpmmr90 E4Jx/D2pAOx1Ix+VGc5GMfU0nAX047DOaX5MgfNgccUwA4PXOKMbs9Djg07Bz3601jtOWP8AtZ/G gBc9BjA6c0mB1A49aMkZ4AyPvUMPUA/0pXAUg5zyFx9M0YJJPB9c9qOB1znOTQTwDyc85zzQAHPX 1OMdMGj0xxxnFAPrnAOM9etAGOOcj9aAF42j5T6A+1J2HcdgKMDjjHPFADAe2aBgeueOSQcGgjr0 6cYPFBXPVh1ySD29qcpxjrwMjimAxuuQGz0z60gXI+Yce9OPHGHzjoKG7gA9PWkAdc9cCgemcg85 60N8zDquAAPejnfxnBOaBBnpuIHY0vU5x0ORntSDKk5+v50N0x074oAOmW+UZ6HP58UvTPT69DSc d+lBGW5A6dDQAp7/ACgc5H0pOcALnHvRxkFSM5604DGc5Hfr1oAD0AYKHPGc4ozyR3PY0hHUBT/+ ujqDjAOO9AIOqnGM0nPPTgYApeP4x360vbGc89c0xiH8D2HNJ0Hy8Ad8Zo+nGPb+tL07HrxQITqD uxjpke9GeTux0zilwO/HGOaTdhuCB9e+aQBu4yB0596UfeyOnUA0YIOOnPegjjufcDFABjIOeece xpWGAvOeex5pRz059hTc4HYcAcDigA4HbJ7ehpecngc56mg9R1AHpQB83yr159aAE9cYHajOcc8j px0p2AewOeAc0jcLzyeuBSAQAHhTnFKv3jx9M0EAZ4OScmlx/wDWzTGJwF4PA9ecUEE+nrS/xY/l xQwxjjIxznkigQnO3tjpSZYNznI5HNKBnngj1BpOvTg4wBQMXnB5OPyoYZHcD2NKW7kY/pTQM9PX k0wFwOP15o46jv0zzQeuABzx70nAIxx+FAhQOx57ZpW6cdR270dSDuGDzjHNBHHGeOuaQwPXgUDj IyPbFGV8wEDHekOMYPAoEHUc8ew6UpB64X0Hej3NDHOcEHvQAjDnnH4HpRnnj9BQfXGOOwo5HBPS gYY6HP5Gm7RtwOD25605eQB3BxyKM9MHoOKBCD6Hk854wKcvI6e2Kb1OD6dM9KcM44ApAxMBjyMY 7elIo75wfQU485/rScgHoT0NACNw2R0+vNPA6KRjJ6EUjYOANoC9sUqnnkn06UDJVPzdR74qVDgj rnp9aiUe/samAIK46kHBpCLUCdSe3T/CrsCkbQMAZ7mqduysM4yQMD3q/EOnoMD1pDLdunzAkYq7 Hx/EcfSqkJx/Wr0ZGOCeKhjJk/2vwqYGiMAjtj8qMDjGfzqRir/+qkJPNLnOemKax9TxQIrzknpj 3qnM57Z/CrsqElunI4NUpRhSOnp9aaGUbgYIxg8YPvVFyRndxxj6Vcm4UbiSfU9qquMKTt59farQ iq447BfaqzEM3QY9Kmm7Y4/rVdzkeg9fWhIRDIOfmwCOTjvUTHGeMDP5VK3Tjv3A6UxuW9fx6fWq AjBPYrjIAwcUNz0AHal5J+7uOfSmnjuSM4oAQ85xxjijBGRjnGSO9L6gH73XApo/XPc0wHKAcd19 utMBA6+vbvS/w8c980p9Odx60AIcjjj1NHQY5+po/h54+tHTpwOmR3pABHTb2OOaTHbIJH5GnE9S SR6mk/h+n5UABxnnvS89cZByOuaTOOpHWhfvYHOeeO1AhDjkn0xSsNzcnA689KCCV64/pQ3cnJ49 KBic46DNHG3joaBnPTGecA0dhgBsdsUAGDkHmgkdOOvNIoAUgAe2PSlHucZ5AoACeTjHrmkJzjPf +dKMbcZP1xigA87gQuMUCEzjv04P1oA+bjHXB59qMEbhwTx34oI69gx78E0gEz0Cn2AJpcYxnuc7 vehcAAbQOcjHel55z1HoeDQwEXPHqP50Zwefx5zR19CfT60cjAOck5+lAAwyScZ7YHajPoB+dKxx kfr600jOQBjFMBTg9xgHrnGKQYB4GTS9xwPfikz0zjnigAGOR1APXPJpCMgZ7ml3Ar/Kl9wc9uDm gYED9OlJyeuPb1pT64wc496Ow7d+tAAMg4656ACj5s9eQM0mM5BNLj3445A7UCDhc5P05oXhfrnk Uu3pngeuM0hxjK9zkZpDDrgdfx6fWl/i46+hNIeWO7B4xSkZwhIAxgYH60BYQEAdMfX9RTlBweAA OaCTtyPpzTiMf7I6CgBMZA5YZ7Z6+lOAztPBAPUdaYCNzKcAjpjmlA+8Rx9KTABnofTOKcFwAAM7 ecjilzuPB5xkUcBtpHGO3eiwBghu2euDRkYOcDBx9aVVGTn0+tLj5euMf5xTANn3gTx0+lAwuCeW GR06UYAHI569KkUbV/ix1pANHGQMZzwM4xTlPcEZHTnrQQe4XIJ57UqjOAQMd+cYpAA3AfNtz2Oe tKvy7j8vHX2NO4QYYMDjkHkGlUBucBgcjGKQDQMyHK9ycE4qTAHXnPboKZxtwpDMcnFTD7oJYfUH oaYxFHCnjk8809F3HhRhTg44xTQA3PJ4wccZqXaCQCDgDI56/wD16AGkYznJx0B7U8AdD64Bx1P9 acCDnncMHjNPCjavQ4pCDKlcD5yeODU6ruPJOc5qPAEeB6g5FSL3BAIBwTQMcAAmRyPensR5mQpI JxkdaRTmMDcflOORTmJ9Bt4x6/WgQ7j5hjjGRUirkcMOmetNUMcjIxjIGKkGGb5sBRzjHAoGSINy FiSG96lQMrcbcg5JPNMQ91zn0HQCpEUfU98UgJdynJO3kcYFSIAUYk88c/8A1qbhtxbG3PBwaem7 HLbc9xSYEuCMY529RUgA25Hr1qP7uGHPpnripgTl888DGBikwFUjbuycdSM1MoC45OM9+c00c+2e KeAAOOe2MYxSGTQDOB+Y9KnThcEflxUUfBHoecdTUq/dGM9aAJM/d6Zz3NSryBwM+xqGMFmBB9/e rEeAAc5I55pAPwOOeKXHXABH1o6jtweaUnd6/hQgHIpGc8n65rmPFUn7vYhIcA9+tdUr+WhODnGf pXCeKp/3LMOeepHetIiZ5l4knaS4wzBlLY9apaIoe4+bPBznsKdqjZlHdjyeelWfDChrxFwM7yW5 ro6GZ654MX9ygXoOpAru4/ljHHvXLeG4isMe0+ldSoIUBvxrnkWh3TbjOT707uQec9xTRzS44x2N QM+cRgqzKGDbeGU5IqRySMkL9AeaQAlQeOPTsaRvnYqowxGcnjFdIgY491XPPWnA4wDzg8g803A8 zaTwcfd+tKGBUZb5T0560wEPC8DoTx60pJPp15Gc5FKAFP8AIdaM/LjBxx055NAAp6kj6c0Zwuep IzgmjBEm3cQMEdO9Iu0j5cgnoSO3tQA7rnuemc9KFyT3IxxzTQc8dR1FIvBA3Dk5ApCFX5n+Tb6+ mPxpwLHOQCcdjyKadv3c+uR6Uc/LkE564phYVeCMswAHApPTnLYxgDINI/CHOQMcH196eWwSQTgd PbNAxMZC/wBaAMIAOmOaMDcOec8Z9KQ8SAg89sUAH3hwvH3cg0vYHuo9KVevHHPQetNwMc4wTzye DSEJgAZ6HpTjzwDxj0zj2peeuR8vHTrSZyO4J5xTAC2cAc5o/iwwAB6nGc0hbKkNkgfnzS5we/tk dPwoAE5zgjbnrSA4VSVBPfGeKCM9BtXvgcml3DHv9eKBgfqOvGO1GcnPO0cHjBApBwyncOfQ54oP 3/lBOOnpQAYHOfwFK3cnOeMYpRtyDwcjuKTHPB5+vemAhHXgZx160rjMnPJPbrk0DJGQcnOaFIIB IxzQAAZ6+vXNBPPOfmHI6Up4xyOvJ703qAOfx6UALzuGMfd+tOJHGOmME0wdT246jpTvlLEjHT6U WEJ13d+RjnrTzzk57/lTfTOOTzTTxngEgdqQxV6jOOeeTzSDjPI9h/OlZeWDHHGRjtQCSchuuBxx QIG4HA59CKd/tBcgevSjHzEc00HA7cdcjFACk8HPfjpS/e65JyTyKRcMR79Tj3ozkd8nigAwCuOo xuGOaMDaD2+lKCA3OQAOMDFIOOpAPHXpTAXuDz07UMcJ82RntTSAM5xnqOacOeSSe2MdaBhn5ecn 07UgPIxgjj8KUDrjH4/0pP7u4YyOhoAD8o5GTR35/ImgAdeAM4+aj7y5znBpAHHAx1HTPNA4FAOD 0HTtSseeDnP86BCdsYB4+gFL3XqcD/8AXTR1wTzjjmnDGMZ6dMUAAOeTgUNnHrxmk6+nTn86XoAS MDp9R7UAIR1B6/zo/L86dghQoyeKRhjOCVBHGe9AACdxHGB0ox344oHQ/KAM9emaQYC9Btx0zTQD jjnPbGc0fKZOeSfypd3JAwOKQfpjpikAuQB04HB9/wAab8x7jnrxS8jA4FAI65Gc9KAEGMd8dcAZ o9OOf0oB+Xjg9KXPBzyO3vQAEZ9h37Un97kdeOM4oIPG3qTyKX1B28/zoAT+HOOTyKAB1H86Vsg4 yOvTOBilVTtXBGOaYB2zjcPpSgdhjH8qQA+pPODijGeTjuetIAOT60Y/dtgD196T/lnnkD27UA5P cDpQMXpkE7eM0Ywc5P3cYoxn7wJ/GjqOuccUCYMM5HqOOKT+Ify/xpf4j2GKa3DHk8cdcUwQvsO3 r6UZ+Un/ACaXoOcH+lAypHY9Qe1IBQT2wOcc9qb1A6AHj6UufXp0oHtjPX1waAAk4J9uAMDNA6nG eDnBNGeuOuOccUjDOM9uMfjTAXP8I/I84oz128kdQfWkBx6E+tKpwAvT3pAAXJPB6880MCP6+9Cg
September 26, 2020 - October 12, 2020
AeroElectric-Archive.digest.vol-pt
