AeroElectric-Archive.digest.vol-pw
December 24, 2020 - Present
      >>>   Lots of products out there but not difficult to build
      >>>   The 'transfer' device is simply a two-pole, double-throw
      >>>   contactor that connects loads to EITHER ac mains OR
      >>>   inverter.
      >>>   You'll need a control system with some simple logic.
      >>>   (1) Transfer to INVERTER is asserted when (a)
      >>>       battery voltage is higher than some minimum
      >>>       -AND- (b) when AC mains power is not present.
      >>>   (2) Inverter system is in a 'relaxed maintenance'
      >>>       mode any time AC mains power is present.
      >>>   (3) you might need a timer with xx milliseconds
      >>>       delay from time AC mains fails until transfer
      >>>       is asserted. Needed only if inverter doesn't gracefully
      >>>       grunt a load during startup. Not likely but
      >>>       should be confirmed.
      >>>   There are dozens of off-the-shelf product that
      >>>   would accomplish this task. Check out websites
      >>>   that target off-grid, homepower systems.
      >>>   Bob . . .
      >>>   Un impeachable logic: George Carlin asked, "If black boxes
      >>>   survive crashes, why don't they make the whole airplane
      >>>   out of that stuff?"
      >>  Virus-free.
      >> www.avast.com
      >> <#m_-9204594603288255310_m_7286640853633196346_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
Date: Dec 24, 2020
Subject: automatic switch
>That's fine, but if it's 'automatic', that implies that it can switch over >and begin consuming power off the backup(s) whether you're there to 'load >shed' or not. Just something to think about. I have been contemplating some of these issues off and on for a while. One option would be to put all essential loads on one phase of the main panel. Have adequate wiring to a heavy duty 120v receptacle on a dedicated breaker on that phase. When the power fails, trip the main breaker and plug a portable generator into the dedicated receptacle. No load shedding required, just about as simple as can be, and probably not more than $20 in parts. FWIW- ________________________________________________________________________________
Subject: Re: automatic switch
Date: Dec 24, 2020
While these manual schemes work well somebody should mention that they are illegal almost everywhere due to the risk of back feeding power to the utility and electrocuting a lineman by mis handling the main breaker. It happens which is why a double throw main breaker arrangement is mandated. Ken On 24/12/2020 7:01 AM, GLEN MATEJCEK wrote: > >That's fine, but if it's 'automatic', that implies that it can switch > over > >and begin consuming power off the backup(s) whether you're there to 'load > >shed' or not. Just something to think about. > > I have been contemplating some of these issues off and on for a > while. One option would be to put all essential loads on one phase of > the main panel. Have adequate wiring to a heavy duty 120v receptacle > on a dedicated breaker on that phase. When the power fails, trip the > main breaker and plug a portable generator into the dedicated > receptacle. No load shedding required, just about as simple as can > be, and probably not more than $20 in parts. > FWIW- ________________________________________________________________________________
Date: Dec 24, 2020
At 06:27 AM 12/24/2020, you wrote: > >While these manual schemes work well somebody >should mention that they are illegal almost >everywhere due to the risk of back feeding power >to the utility and electrocuting a lineman by >mis handling the main breaker.=C2 It happens >which is why a double throw main breaker arrangement is mandated. Yup, that's why there is a check-list for transitions between mains and generator . . . but failure to disconnect ac mains would result in immediate operation of the generator's breakers. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Dec 24, 2020
The essential loads that I need to run are boiler, unit heater, well pump and refrigerator/freezer and hangar door. Given that this is at least 90% of the total amperage and a good percentage of the circuits, I believe powering the whole building is what makes sense. And I definitely agree that the system must not allow for feedback to the grid through operator error. Ken On Thu, Dec 24, 2020 at 4:41 AM Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 06:27 AM 12/24/2020, you wrote: > > > While these manual schemes work well somebody should mention that they ar e > illegal almost everywhere due to the risk of back feeding power to the > utility and electrocuting a lineman by mis handling the main breaker.=C3 =82 It > happens which is why a double throw main breaker arrangement is mandated. > > > Yup, that's why there is a check-list for > transitions between mains and generator . . . > but failure to disconnect ac mains would > result in immediate operation of the generator's > breakers. > > > Bob . . . > > Un impeachable logic: George Carlin asked, "If black boxes > survive crashes, why don't they make the whole airplane > out of that stuff?" > ________________________________________________________________________________
Date: Dec 25, 2020
Once I made a relatively low cost manual transfer switch using a 100 amp panel. In the two top places I mounted two 2-pole 100A breakers side by side with a small alum bar and two screws connecting the two breaker handles. One of the holes on the alum bar was actually slotted so you could turn off both breakers if wanted. But the bar made it impossible to turn on both breakers at the same time. One of the breakers was connected to the 12 KWh generator, the other to a breaker (strictly speaking not needed if lugs available after main breaker) in the main panel. That 100 amp panel became the sub panel for essential stuff: lights, one A/C and computers. Sure was a lot cheaper than the $500 to $1,000 manual transfer switches available at the time. I think the cost of the two 100A breakers and panel was less than $100. Finn On 12/24/2020 9:01 AM, Ken Ryan wrote: > The essential loads that I need to run are boiler, unit heater, well > pump and refrigerator/freezer and hangar door. Given that this is at > least 90% of the total amperage and a good percentage of the circuits, > I believe powering the whole building is what makes sense. And I > definitely agree that the system must not allow for feedback to the > grid through operator error. > > Ken > > On Thu, Dec 24, 2020 at 4:41 AM Robert L. Nuckolls, III > > > wrote: > > At 06:27 AM 12/24/2020, you wrote: >> > >> >> While these manual schemes work well somebody should mention that >> they are illegal almost everywhere due to the risk of back >> feeding power to the utility and electrocuting a lineman by mis >> handling the main breaker. It happens which is why a double >> throw main breaker arrangement is mandated. > > Yup, that's why there is a check-list for > transitions between mains and generator . . . > but failure to disconnect ac mains would > result in immediate operation of the generator's > breakers. > > > Bob . . . > > Un impeachable logic: George Carlin asked, "If black boxes > survive crashes, why don't they make the whole airplane > out of that stuff?" > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Dec 25, 2020
Yep; some breaker panel mfgrs make optional slides to do exactly that. In our area, about 10 miles out of the biggest town in the state, we tend to lose power if it rains anywhere in the county. I went 'full auto' because the spousal unit wasn't going to learn how to the multi-step switching required to keep our air conditioner functional on the generator; also wanted the switch to happen if we were out of town for a few days. Didn't want to lose freezer/fridge stuff. I also spent a long time waiting for craigslist deals on the generator & automatic transfer switch/subpanel (as mentioned, I'm way too cheap to buy new). Charlie On 12/25/2020 10:58 AM, Finn Lassen wrote: > Once I made a relatively low cost manual transfer switch using a 100 > amp panel. > In the two top places I mounted two 2-pole 100A breakers side by side > with a small alum bar and two screws connecting the two breaker handles. > One of the holes on the alum bar was actually slotted so you could > turn off both breakers if wanted. But the bar made it impossible to > turn on both breakers at the same time. One of the breakers was > connected to the 12 KWh generator, the other to a breaker (strictly > speaking not needed if lugs available after main breaker) in the main > panel. That 100 amp panel became the sub panel for essential stuff: > lights, one A/C and computers. > > Sure was a lot cheaper than the $500 to $1,000 manual transfer > switches available at the time. I think the cost of the two 100A > breakers and panel was less than $100. > > Finn > > On 12/24/2020 9:01 AM, Ken Ryan wrote: >> The essential loads that I need to run are boiler, unit heater, well >> pump and refrigerator/freezer and hangar door. Given that this is at >> least 90% of the total amperage and a good percentage of the >> circuits, I believe powering the whole building is what makes sense. >> And I definitely agree that the system must not allow for feedback to >> the grid through operator error. >> >> Ken >> >> On Thu, Dec 24, 2020 at 4:41 AM Robert L. Nuckolls, III >> > > wrote: >> >> At 06:27 AM 12/24/2020, you wrote: >>> > >>> >>> While these manual schemes work well somebody should mention >>> that they are illegal almost everywhere due to the risk of back >>> feeding power to the utility and electrocuting a lineman by mis >>> handling the main breaker. It happens which is why a double >>> throw main breaker arrangement is mandated. >> >> Yup, that's why there is a check-list for >> transitions between mains and generator . . . >> but failure to disconnect ac mains would >> result in immediate operation of the generator's >> breakers. >> >> >> >> Bob . . . >> >> Un impeachable logic: George Carlin asked, "If black boxes >> survive crashes, why don't they make the whole airplane >> out of that stuff?" >> > > > > Virus-free. www.avast.com > > > > <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> -- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Subject: Manual utility/generator switch
Date: Dec 25, 2020
I bought the ReliAnce panel, 200/100 (or smaller at your choice) with interl ock. About $300. It=99s a repurposed Siemens panel, UL and all. ________________________________________________________________________________
Date: Dec 25, 2020
Our utility in S Indiana =98grounds=99 all wiring before any wor k is done. Although our solar system has the required disconnects etc they r eally are not needed. It does increase the down time since all the grounds n eed to be removed before applying power, it will save lives. This method pr obably is growing and will be used everywhere soon. [I am a retired electri cian] > On Dec 25, 2020, at 2:13 PM, Charlie England wrote: > > =EF=BB > Yep; some breaker panel mfgrs make optional slides to do exactly that. In o ur area, about 10 miles out of the biggest town in the state, we tend to lo se power if it rains anywhere in the county. I went 'full auto' because the s pousal unit wasn't going to learn how to the multi-step switching required t o keep our air conditioner functional on the generator; also wanted the swit ch to happen if we were out of town for a few days. Didn't want to lose free zer/fridge stuff. > > I also spent a long time waiting for craigslist deals on the generator & a utomatic transfer switch/subpanel (as mentioned, I'm way too cheap to buy ne w). > > Charlie > >> On 12/25/2020 10:58 AM, Finn Lassen wrote: >> Once I made a relatively low cost manual transfer switch using a 100 amp p anel. >> In the two top places I mounted two 2-pole 100A breakers side by side wit h a small alum bar and two screws connecting the two breaker handles. >> One of the holes on the alum bar was actually slotted so you could turn o ff both breakers if wanted. But the bar made it impossible to turn on both b reakers at the same time. One of the breakers was connected to the 12 KWh ge nerator, the other to a breaker (strictly speaking not needed if lugs availa ble after main breaker) in the main panel. That 100 amp panel became the sub panel for essential stuff: lights, one A/C and computers. >> >> Sure was a lot cheaper than the $500 to $1,000 manual transfer switches a vailable at the time. I think the cost of the two 100A breakers and panel wa s less than $100. >> >> Finn >> >> On 12/24/2020 9:01 AM, Ken Ryan wrote: >>> The essential loads that I need to run are boiler, unit heater, well pum p and refrigerator/freezer and hangar door. Given that this is at least 90% o f the total amperage and a good percentage of the circuits, I believe poweri ng the whole building is what makes sense. And I definitely agree that the s ystem must not allow for feedback to the grid through operator error. >>> >>> Ken >>> >>> On Thu, Dec 24, 2020 at 4:41 AM Robert L. Nuckolls, III <nuckolls.bob@ae roelectric.com> wrote: >>>> At 06:27 AM 12/24/2020, you wrote: >>>>> >>>>> While these manual schemes work well somebody should mention that they are illegal almost everywhere due to the risk of back feeding power to the u tility and electrocuting a lineman by mis handling the main breaker.=C3=82 I t happens which is why a double throw main breaker arrangement is mandated. >>>> >>>> Yup, that's why there is a check-list for >>>> transitions between mains and generator . . . >>>> but failure to disconnect ac mains would >>>> result in immediate operation of the generator's >>>> breakers. >>>> >>>> >>>> >>>> Bob . . . >>>> >>>> Un impeachable logic: George Carlin asked, "If black boxes >>>> survive crashes, why don't they make the whole airplane >>>> out of that stuff?" >>>> >> >> >> Virus-free. www.avast.com > ________________________________________________________________________________
Date: Dec 26, 2020
Thanks Stu. I've been studying these switches. One thing I have not been able to discover is how much current an automatic utility disconnect transfer switch uses. I would like to know the answer to that question both for the grid connection and for the "generator" connection. I have found some spec sheets, but none of them have this information. I have learned that my application is probably what is referred to as utility-utility (rather than utility-generator) Another question I have not been able to answer is whether an automatic switch that is designed for a generator (which includes provisions for starting and stopping a generator) can be used in a utility-utility application, without a lot of hassle. On Sat, Dec 26, 2020 at 1:12 AM wrote: > Hi Ken; > They're available and called (appropriately) "automatic transfer switch." > They're generally used to transfer from utility current to emergency > generator current, but will work equally well in your application. There > are also "manual transfer switches," if you want to save some money. > Cheers! Stu. > > ------------------------------ > *From: *"Ken Ryan" <keninalaska(at)gmail.com> > *To: *aeroelectric-list(at)matronics.com > *Sent: *Wednesday, December 23, 2020 6:11:44 AM > *Subject: *AeroElectric-List: automatic switch > > This is for a hangar home that is under construction, so it is relevant :) > > I am planning a small solar/generator powered emergency electrical system. > Three solar panels, a 4800 watt-hour lithium battery, charge controller and > an inverter/charger. > > It's function will be to run necessary equipment (boiler, unit heater, > well pump, refrigerator/freezer) in the event of a power outage. > > I have experience with systems like this from having built three campers. > But this is different in that I would like to have a switch that > automatically detects when the power goes off, and switches things over to > the alternate system. > > I know such switches exist, but I know nothing about them -- how they > operate, how to choose one, how to wire one into the system, etc. I would > appreciate any info people might have. > > Ken Ryan > > ________________________________________________________________________________
Subject: Re: Magnetos
Date: Dec 26, 2020
Its me again! I got my earthX battery and it really cranks! I also bought and installed new REM 40 spark plugs but again, no engine start! I will try the test suggested by Charlie England and see nor that goes!removing spark plugs and cranking with them toiuching the engine. I suspect the wire harness because I do hear the sharp clacking sound... Well see... -------- EfraimOtero Fisher Celebrity EX N500BC O200 COntinental Read this topic online here: http://forums.matronics.com/viewtopic.php?p=499825#499825 ________________________________________________________________________________
Date: Dec 27, 2020
Efraim, I hear your frustration. Once upon a time, when an elusive ignition problem was plaguing me, I got pissed and made a spark test fixture out of a section of aluminum angle material with (6) 18mm tapped holes to which (4) old spare spark plugs were installed. Magneto leads were temporarily removed from upper spark plugs and installed on the test fixture spark plugs. The aluminum angle & plugs were grounded to the engine and situated where I could easily observe sparks with the business end of the plugs pointing directly at me. Remember that you are only going to see a spark if it comes from a magneto that has an impulse coupling. As was said, you only need three things for combustion: FUEL / COMPRESSION / IGNITION. On old cars, it was easy to check for as fuel problem with a squirt of starting ether down the carb. I don't recommend that unless extreme frustration sets in. Just prime the heck out of the carburetor and if you can smell fuel, you can assume fuel supply is good. ALSO, since this is an experimental airplane, you may be using a non-standard ignition switch(s). "ON" in a normal switch usually means continuity across the switch, which would ground out the magnetos, disabling them. I suggest, for test purposes, temporarily remove the magneto grounding leads. BE CAREFUL - ASSUME THE ENGINE WILL FIRE UP AT FULL POWER. Make sure the tail is SECURELY tied down and that you can easily shut down the engine by turning off fuel supply. CHOCKS are USELESS here. Hope this helps. Jerry King -------- Jerry King Read this topic online here: http://forums.matronics.com/viewtopic.php?p=499829#499829 ________________________________________________________________________________
Date: Dec 28, 2020
At 10:32 PM 12/26/2020, you wrote: >"EfraimOtero" > >It=99s me again! I got my earthX battery and it >really cranks! I also bought and installed new >REM 40 spark plugs but again, no engine start! I >will try the test suggested by Charlie England >and see nor that goes!removing spark plugs and >cranking with them toiuching the engine. I >suspect the wire harness because I do hear the sharp clacking sound... >We=99ll see... It's unlikely that a whole harness bad . . . and one or two bad wires would still give you some activity on the remaining cylinders. There are other maladies that can befall a magento rendering it completely silent: There are points that require proper continuity and gap. There is a coil. There is a capacitor. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Dec 29, 2020
Subject: Firewall Penetration Redux
BobN, A couple of weeks ago you posted a picture of a Bonanza's firewall under co nstruction.=C2- It shows a firewall pass-thru fitting with a 90 deg bend and some sort of flange attached to firewall.=C2- What is that fitting ma de of? -Jeff ________________________________________________________________________________
Subject: Re: Firewall Penetration Redux
Date: Dec 29, 2020
On 12/29/2020 2:03 PM, Jeff Luckey wrote: > BobN, > > A couple of weeks ago you posted a picture of a Bonanza's firewall > under construction. It shows a firewall pass-thru fitting with a 90 > deg bend and some sort of flange attached to firewall. What is that > fitting made of? > > > -Jeff I'm not Bob, but stainless grab bars work well. Just find versions that have the flange welded onto the bend. I needed a straight shot off the firewall for mine, so I cut it short enough that I just had a short stub left for clamping the fire sleeve. Ebay has had smaller (~1") stainless flanged stubs in the past, but I can't find the link now. Charlie -- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Dec 29, 2020
At 02:03 PM 12/29/2020, you wrote: >BobN, > >A couple of weeks ago you posted a picture of a Bonanza's firewall >under construction. It shows a firewall pass-thru fitting with a 90 >deg bend and some sort of flange attached to firewall. What is that >fitting made of? Beech fabricated their fittings from stainless steel. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Subject: Clearance Delivery Diode Leakage
Date: Dec 29, 2020
The wiring has begun for my RV-7. I've decided to use fuse blocks for circuit protection. The architecture will utilize a clearance delivery (CD) buss. The CD buss has a diode installed per Z101B. When applying DC voltage to the CD bus and measuring the voltage at the main buss, there is a 350 to 390 mv reading. Is that enough to worry about or do I have a bad diode? This is the B&C Essential Bus Diode w/ 8 watt heatsink PN-221-200. Heres a photo of the fuse blocks while being tested for leakage. You may be able to make out the 351.8 mv leakage. http://myplace.frontier.com/~tokosha/avionics/test_diode.jpg -------- Michael Fleming Read this topic online here: http://forums.matronics.com/viewtopic.php?p=499896#499896 ________________________________________________________________________________
Date: Dec 30, 2020
Efraim, In order to simplify things, lets try to isolate the magnetos to see if they are EVER actually producing a spark. First, pull all the top spark plugs to insure there is NO COMPRESSION and no possibility of injury with the engine suddenly coming to life. With all spark plugs removed, reconnect all ignition leads and lay the plugs on top of each cylinder and insure that each plug is electrically grounded to the engine. Try to aim the sparking end of the plugs outward and to each side, so that a relatively weak spark can be easily observed. View one side or one bank of cylinders at a time. That way you don't have to completely remove and reroute the magneto ignition leads for the test. At this point, since there is no compression in any cylinder, you can easily and with complete safety turn the propeller by hand OR by the starter if you wish. If you rotate the propeller TWO turns in the normal direction of rotation, a spark should be observed at each sparkplug sometime during the two-turn rotation at the instant you hear the loud click of the impulse coupling snapping free. In other words, a spark should occur once every other propeller rotation at the click. Jerry King -------- Jerry King Read this topic online here: http://forums.matronics.com/viewtopic.php?p=499903#499903 ________________________________________________________________________________
Subject: Re: Clearance Delivery Diode Leakage
Date: Dec 30, 2020
A voltage drop across a diode is normal. A drop of o.4 volts is low. It will be 2 or even 3 times that much under heavy load. Power (heat) equals volts times current. Suppose that the load is 10 amps. 10 amps times 1 volt equal 10 watts. That is a lot of heat and the reason for the heat sink. If you want to minimize the amount of power lost, a Schottky diode will waste about half as much as a regular diode. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=499904#499904 ________________________________________________________________________________
Date: Dec 30, 2020
Use heat conductive paste between the diode and the heat sink. Otherwise the diode could overheat and fail. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=499905#499905 ________________________________________________________________________________
Date: Dec 30, 2020
As far as I can see on your picture, you have no loads anywhere and have the positive supply lead only connected to the CD bus. Under those conditions any voltages you can measure are pretty much meaningless. A good DVM has a very high input impedance so puts no load on whatever it is measuring. On the other hand, if there is any load on the main bus then you may have a defective diode. To check, just put some sort of load on the main bus (resistor, light bulb, relay coil, etc.). With a load there I doubt you will see anything (unless the diode bridge is actually bad - pretty unlikely). Dick Tasker MFleming wrote: > > The wiring has begun for my RV-7. I've decided to use fuse blocks for circuit protection. > > The architecture will utilize a clearance delivery (CD) buss. The CD buss has a diode installed per Z101B. When applying DC voltage to the CD bus and measuring the voltage at the main buss, there is a 350 to 390 mv reading. > > Is that enough to worry about or do I have a bad diode? This is the B&C Essential Bus Diode w/ 8 watt heatsink PN-221-200. > > Heres a photo of the fuse blocks while being tested for leakage. You may be able to make out the 351.8 mv leakage. > > http://myplace.frontier.com/~tokosha/avionics/test_diode.jpg > > -------- > Michael Fleming > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=499896#499896 > > ________________________________________________________________________________
Date: Dec 30, 2020
user9253 wrote: > A voltage drop across a diode is normal. A drop of o.4 volts is low. It will be > 2 or even 3 times that much under heavy load. Power (heat) equals volts > times current. Suppose that the load is 10 amps. 10 amps times 1 volt equal > 10 watts. That is a lot of heat and the reason for the heat sink. If you want > to minimize the amount of power lost, a Schottky diode will waste about half > as much as a regular diode. So the voltage feedback, leakage is the issue. The voltage drop when the diode is supplying current to the CD buss from the main buss is expected. When the CD buss is being fed from the battery and the diode is supposed to prevent the main buss from seeing current is when I'm seeing the 350+ millivolts. I'm not sure if the feedback through the diode to the main buss is considered OK or not. user9253 wrote: > Use heat conductive paste between the diode and the heat sink. > Otherwise the diode could overheat and fail. > Assuming that the heat sink will be mounted to an aluminum surface, also > use heat conductive paste between the heat sink and mounting surface. B&C provided the diode and heat sink as a unit so I'm hopping they assembled it with the proper paste. Would dielectric grease be suitable as a heat sink paste? -------- Michael Fleming Read this topic online here: http://forums.matronics.com/viewtopic.php?p=499916#499916 ________________________________________________________________________________
Date: Dec 30, 2020
When I installed mine I put the pipe end of the fitting inside the cockpit This is purely cosmetic, the firesleeve and sealer clamp are then out of sig ht =46rom the engine side you only see the wires bundle going into the fitting Mike Sent from my iPhone > On Dec 29, 2020, at 2:28 PM, Robert L. Nuckolls, III <nuckolls.bob@aeroele ctric.com> wrote: > > =EF=BB At 02:03 PM 12/29/2020, you wrote: >> BobN, >> >> A couple of weeks ago you posted a picture of a Bonanza's firewall under c onstruction. It shows a firewall pass-thru fitting with a 90 deg bend and s ome sort of flange attached to firewall. What is that fitting made of? > > Beech fabricated their fittings from stainless > steel. > > > Bob . . . > > Un impeachable logic: George Carlin asked, "If black boxes > survive crashes, why don't they make the whole airplane > out of that stuff?" ________________________________________________________________________________
Date: Dec 30, 2020
It is normal to see voltage like you are with no load. Put a load on the main bus and that voltage will disappear. A 12 volt test light will make a good load. Use a test light that does not have an internal battery. The test light should operate off from the aircraft battery. Grease might melt. Home Depot and Amazon sells part number 98003/202932736 -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=499917#499917 ________________________________________________________________________________
Date: Dec 30, 2020
At 09:48 AM 12/30/2020, you wrote: >Tasker > >As far as I can see on your picture, you have no >loads anywhere and have the positive supply lead >only connected to the CD bus.=C2 =C2 Under those >conditions any voltages you can measure are >pretty much meaningless.=C2 A good DVM has a very >high input impedance so puts no load on whatever it is measuring. > >On the other hand, if there is any load on the >main bus then you may have a defective >diode.=C2 To check, just put some sort of load on >the main bus (resistor, light bulb, relay coil, >etc.).=C2 With a load there I doubt you will see >anything (unless the diode bridge is actually bad - pretty unlikely). Right on! I set up an experiment on the bench with an exemplar bridge rectifier. A multimeter set to read leakage CURRENT indicated less than 0.1 microamps. Changing the meter to read VOLTS gave an indication on the order of 400mV. What you're seeing is normal and expected. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Dec 30, 2020
At 01:57 PM 12/30/2020, you wrote: > > >user9253 wrote: > > A voltage drop across a diode is normal. A drop of o.4 volts is > low. It will be > > 2 or even 3 times that much under heavy load. Power (heat) equals volts > > times current. Suppose that the load is 10 amps. 10 amps times > 1 volt equal > > 10 watts. That is a lot of heat and the reason for the heat > sink. If you want > > to minimize the amount of power lost, a Schottky diode will waste > about half > > as much as a regular diode. > > >So the voltage feedback, leakage is the issue. > >The voltage drop when the diode is supplying current to the CD buss >from the main buss is expected. > >When the CD buss is being fed from the battery and the diode is >supposed to prevent the main buss from seeing current is when I'm >seeing the 350+ millivolts. > >I'm not sure if the feedback through the diode to the main buss is >considered OK or not. Doing the math on your observations: Assuming a nominal 10,000,000 ohm input impedance of your multimeter in the voltage mode . . . E 0.400 I = --- = --------- = 4 NANOAMPS! R 10,000,000 Some multimeters have as much as 20M Ohms input impedance which would give you 2 NANOAMPS . . . quite normal and insignificant. If you put your multimeter into the current measuring mode, the impressed current would be too small to wiggle the display on the most sensitive scale. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Dec 31, 2020
[quote="nuckolls.bob(at)aeroelect"]At 09:48 AM 12/30/2020, you wrote: > > As far as I can see on your picture, you have no loads anywhere and have the positive supply lead only connected to the CD bus. Under those conditions any voltages you can measure are pretty much meaningless. A good DVM has a very high input impedance so puts no load on whatever it is measuring. > > On the other hand, if there is any load on the main bus then you may have a defective diode. To check, just put some sort of load on the main bus (resistor, light bulb, relay coil, etc.). With a load there I doubt you will see anything (unless the diode bridge is actually bad - pretty unlikely). So this is correct, there are no loads during this test. BUT there is not supposed to be a load or current on the main buss in this photo during the test. The test was supposed to verify that the diode is doing its job of preventing flow from the CD bus back to the main buss when the CD buss is energized and the main buss is deenergized. The test simulate the CD buss being energized while the master contactor is open, ergo - main bus should show no voltage. Now if your saying I need a load on the CD buss during this test great...but a load or any current on the main buss would negate the test as far as I can see. On the other hand it sounds like Bob is saying what I'm seeing is normal...so I think I'll move on to more wiring. -------- Michael Fleming Read this topic online here: http://forums.matronics.com/viewtopic.php?p=499930#499930 ________________________________________________________________________________
Date: Dec 31, 2020
In an attempt to clarify: In the situation where the master contactor is off there will be no active avionics on the master buss because there will be no power to the buss. However, all the avionics that reside on the master buss will still be connected and will thereby provide a load on the buss. In that situation, the diode will be doing what it is supposed to be doing and if you measure the voltage on the master buss you will see nothing. A diode is not a "perfect" one-way valve. Darn close, but it you have no load except the 10 Megohm impedance of the DVM you will still measure something as you discovered and as Bob described. This is due to the reverse leakage of the diode - a very small number but not zero. MFleming wrote: > > [quote="nuckolls.bob(at)aeroelect"]At 09:48 AM 12/30/2020, you wrote: > >> >> As far as I can see on your picture, you have no loads anywhere and have the positive supply lead only connected to the CD bus. Under those conditions any voltages you can measure are pretty much meaningless. A good DVM has a very high input impedance so puts no load on whatever it is measuring. >> >> On the other hand, if there is any load on the main bus then you may have a defective diode. To check, just put some sort of load on the main bus (resistor, light bulb, relay coil, etc.). With a load there I doubt you will see anything (unless the diode bridge is actually bad - pretty unlikely). > > So this is correct, there are no loads during this test. BUT there is not supposed to be a load or current on the main buss in this photo during the test. > > The test was supposed to verify that the diode is doing its job of preventing flow from the CD bus back to the main buss when the CD buss is energized and the main buss is deenergized. The test simulate the CD buss being energized while the master contactor is open, ergo - main bus should show no voltage. > > Now if your saying I need a load on the CD buss during this test great...but a load or any current on the main buss would negate the test as far as I can see. > > On the other hand it sounds like Bob is saying what I'm seeing is normal...so I think I'll move on to more wiring. > > -------- > Michael Fleming > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=499930#499930 > > ________________________________________________________________________________
Date: Dec 31, 2020
Check for electricity on the main bus using a test light. The light will not illuminate. That means there is no voltage on the main bus. Leave the test light connected to the main bus, then measure the voltage with the digital meter again. The main bus will have zero volts. The diode is OK. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=499932#499932 ________________________________________________________________________________
Date: Dec 31, 2020
user9253 wrote: > Check for electricity on the main bus using a test light. > The light will not illuminate. That means there is no voltage on the main bus. > Leave the test light connected to the main bus, then measure the voltage with > the digital meter again. The main bus will now have zero volts. The diode is OK. I see....The test light (load) on the main buss drains the residual voltage and kinda make the diode seal better like a check valve with differential pressure would. -------- Michael Fleming Read this topic online here: http://forums.matronics.com/viewtopic.php?p=499933#499933 ________________________________________________________________________________
Date: Jan 01, 2021
Subject: Power-Sonic LiFePO4 (Hypersport)
SGksCgpUTERSOyBUaGUgUEFMNTBOMThMIExpRmVQTzQgKEh5cGVyc3BvcnQpIGlzIHJhdGVkIGF0 IDEyOCBXL0hyLiBJIHRlc3RlZCBhdCBjdXJyZW50cyBiZXR3ZWVuIDEyLjUgYW5kIDIwIGFtcHMg YW5kIGZvdW5kIHRoZSBjYXBhY2l0eSB3YXMgYXQgbGVhc3QgMjYwIFcvSHIuIEF0IHdlbGwgdW5k ZXIgJDIwMCBpcyB0aGlzIGEgZmFudGFzdGljIGJhcmdhaW4gaW4gYmF0dGVyaWVzLCBvciBoYXZl IEkgbWlzc2VkIHNvbWV0aGluZz8KCknigJltIGJ1aWxkaW5nIGEgTWFycXVhcnQgQ2hhcmdlciB3 aXRoIGFuIGVsZWN0cmljYWxseSBkZXBlbmRlbnQgZW5naW5lIHVzaW5nIFNEUyBFRklJLiBJIHNl dHRsZWQgb24gYSBzaW5nbGUgYWx0ZXJuYXRvciAvIDIgYmF0dGVyeSBzeXN0ZW0uIEkgZm9yZ2V0 IEJvYuKAmXMgc2NoZW1hdGljICMgYnV0IGl04oCZcyBvbmUgb2YgdGhlbS4gTXkgb2JqZWN0aXZl IGlzIHRvIGhhdmUgYSBjb21mb3J0YWJsZSBhbW91bnQgb2YgZmx5aW5nIHRpbWUgaW4gdGhlIGV2 ZW50IG9mIGFuIGFsdGVybmF0b3IgZmFpbHVyZS4gVG8gY29tcGVuc2F0ZSBmb3IgYSBmYWlsdXJl IG9mIG9uZSBiYXR0ZXJ5IG9yIHRoZSBvdGhlciwgZWFjaCBvZiB0aGUgYmF0dGVyaWVzIG5lZWRz IHRvIGJlIGFibGUgdG8gcnVuIHRoZSBlbmdpbmUgZm9yIGEgcmVhc29uYWJsZSBhbW91bnQgb2Yg dGltZS4gSSBiZWxpZXZlIHRoYXQgd2l0aCBhIHNpbmdsZSBib29zdCBwdW1wIG9wZXJhdGluZyBJ IHdpbGwgaGF2ZSBhIGN1cnJlbnQgY29uc3VtcHRpb24gb2YgYSBsaXR0bGUgdW5kZXIgMTAgYW1w cy4gVGhlIE1hcnF1YXJ0IENoYXJnZSBpcyBhbiBvcGVuIGNvY2twaXQgYmlwbGFuZS4KCkFueXdh eSwgSSB0b29rIGEgcGx1bmdlIGFuZCBib3VnaHQgYSBQb3dlci1Tb25pYyBQQUw1ME4xOEwgTGlG ZVBPNC4gWWVzdGVyZGF5IEkgc3RhcnRlZCB0ZXN0aW5nIGl0LCBhbmQgSSB3YW50IHRvIHNoYXJl IHRoZSByZXN1bHRzIGZvciAyIHJlYXNvbnMuIDEpIEhlbHAgb3V0IHNvbWVib2R5IGxvb2tpbmcg Zm9yIGEgYmF0dGVyeSBsaWtlIHRoaXMuIDIpIERvdWJsZSBjaGVjayBteSBleHBlcmltZW50YWwg cmVzdWx0cyB0byBtYWtlIHN1cmUgdGhleSBhcmUgY29ycmVjdC4KCkZvciBteSB0ZXN0IEkgYm91 Z2h0IGEgY2hlYXAgYmF0dGVyeSBtb25pdG9yIGZyb20gQW1hem9uIGFuZCB1c2VkIGEgTGVjdHJv biAxMEEgaG9iYnkgY2hhcmdlci4gVGhlIGJhdHRlcnkgbW9uaXRvciB1c2VzIGEgNzVtdiAtIDEw MEEgc2h1bnQuIFRoZSBiYXR0ZXJ5IG1vbml0b3LigJlzIGN1cnJlbnQgcmVhZGluZ3Mgd2VyZSB2 ZXJpZmllZCBieSB0aGUgdm9sdGFnZSBkcm9wIGFjcm9zcyB0aGUgc2h1bnQsIG15IG11bHRpbWV0 ZXIgaG9va2VkIHVwIGluIHNlcmllcyBhdCBsZXNzIHRoYW4gMTBBLCBhbmQgYWxzbyB0aGUgTGVj dHJvbiBjaGFyZ2Vy4oCZcyBBSCBudW1iZXJzLiBJZiB0aGUgYmF0dGVyeSBtb25pdG9yIHNheXMg dGhhdCB5b3UgdG9vayBvdXQgMjAuMyBBaCB0aGUgTGVjdHJvbiB3aWxsIHB1dCB2ZXJ5IGNsb3Nl IHRvIDIwLjMgQWggYmFjayBpbi4gU28gZXZlbiB0aG91Z2ggSeKAmW0gdXNpbmcgY2hlYXAgc3R1 ZmYsIEkgdGhpbmsgaXTigJlzIGZhaXJseSBhY2N1cmF0ZS4KCkkgbG9hZGVkIHRoZSBiYXR0ZXJ5 IHdpdGggYSA0MDBXIGludmVydGVyIHJ1bm5pbmcgYSB3b3JrIGxpZ2h0IGFuZCBhIGJveCBmYW4u IFBpY3R1cmVzIGFyZSBhdHRhY2hlZC4KCkRvZXMgdGhpcyBhbGwgbWFrZSBzZW5zZT8gSSB0aGlu ayBhIExpRmVQTzQgdGhhdCBwdXNoZXMgdHdpY2UgdGhlIHJhdGVkIEFoIGlzIHVudXN1YWwuIEkg d2lsbCBzYXkgdGhhdCBQb3dlci1Tb25pYyBzYXlzIHRoZSBiYXR0ZXJ5IHdlaWdodHMgNCBsYnMu IEl0IHJlYWxseSB3ZWlnaHMgNi4gVGhlIGZvbGtzIGF0IFBMUEJhdHRlcnkgd2VyZSBncmVhdC4g V2hlbiBJIHRvbGQgdGhlbSB0aGUgYmF0dGVyeSB3YXMgb3ZlcndlaWdodCB0aGV5IHdlaWdodCBl dmVyeSBvdGhlciBQb3dlci1Tb25pYyBiYXR0ZXJ5LiBBY2NvcmRpbmcgdG8gdGhlbSwgdGhpcyBp cyB0aGUgb25seSBtb2RlbCB0aGF0IGlzIG92ZXJ3ZWlnaHQuCgpQYXQKCltBIHBpY3R1cmUgY29u dGFpbmluZyBpbmRvb3IKCkRlc2NyaXB0aW9uIGF1dG9tYXRpY2FsbHkgZ2VuZXJhdGVkXQ= ________________________________________________________________________________
Date: Jan 03, 2021
At 07:10 PM 12/31/2020, you wrote: > > >user9253 wrote: > > Check for electricity on the main bus using a test light. > > The light will not illuminate. That means there is no voltage on > the main bus. > > Leave the test light connected to the main bus, then measure the > voltage with > > the digital meter again. The main bus will now have zero > volts. The diode is OK. > > >I see....The test light (load) on the main buss drains the residual >voltage and kinda make the diode seal better like a check valve >with differential pressure would. No, leakage through the reverse biased diode is relatively constant irrespective of the load. Consider the attached drawing. The red boxes represent your ship's battery and the diode under study. I've depicted a reverse leakage resistor RL2 around the diode. To read 0.4v across a 10M resistor in series (your voltmeter) describes a ratio: RL2 + 10M 10M ---------- = ---------- 12V 0.4V Solving for RL2 RL2 + 10M = (10M x 12V)/0.4V RL2 = [(10M x 12V)/0.4V] - 10M RL2 = 290,000,000 ohms which represents a parasitic (leakage) load on the battery of 12/290M ~ 41 NANOAmps For this leakage to take say, an 18AH battery down to 1/2 capacity would require . . . 9,000,000,000 nAHr/41nA = 220 Million hours or roughly 25,000 years. The value for leakage current is generally always cited on data sheets for diodes but it's so tiny that only in very specialized, small signal applications is it significant to the design. We CAN measure it, as you have done, but in the airframe, its more of a curiosity than a concern. Also, reverse leakage varies widely with temperature, applied voltage and batch-to-batch variations. Going back to the drawing I show another 'leakage' resistor (RL1) that is internal to the battery. All batteries have one of these and depending on chemistry and temperature, it too will discharge the battery. Most secondary SLVA and Lithium products are good on the shelf for 1-2 years. I suggest that leakage inside the battery is of far greater concern than diode leakage(s) outside the battery. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Subject: Any ideas where to get electric motor brushes?
Date: Jan 03, 2021
Hi Group I need some brushes for the exciter on my Monarch EE lathe. Was making some aeroplane parts and it quit. Sizes needed: 3/8" x 3/8" and worn out length is 1.060", it has a shunt and terminal (need 4, will buy 8) 1/2" x 1/4" and worn out length is .495", it has a shunt and terminal (need 2, will buy 4) Any ideas where I can purchase from? Thanks Ron P. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=499971#499971 ________________________________________________________________________________
Subject: How electricity works
Date: Jan 04, 2021
Dear Bob et al. I have a question on how electricity works in relation to components in our obam aircraft and hope you can help my understanding. I have a unit that has a power requirement of 15 amps. It is my intention to control this unit utilising a relay. I wish to control the relay with a micro-switch. I'll at first wire up the relay as per Z diagrams where the main power supply wire to the relay, and thence unit, is also the power for the relay operating coil. Starting with the micro-switch contacts open and no current flowing, on closing the micro-switch contacts and power flows through the coil I'd imagine the relay's coil needs and only "takes" little amperage. At this point the relay's contacts close and the same power supply wire now feeds through to the unit at the amperage it needs. My question is; will the micro-switch and its small gauge wires also "see" the 15 amps that the unit will take? I could wire up the micro-switch and relay coil separate to the power to the unit, but I'm generally wondering how components "choose" their amount of current and if I can use one less wire here safely? Hoping you can help increase my knowledge, thanks. Patrick Elliott ________________________________________________________________________________
Subject: Re: How electricity works
Date: Jan 04, 2021
No, the micro switch will not "see" 15 amps. The switch will only conduct relay coil current. Current through the switch is limited by the resistance of the relay coil. A diode should be installed across the relay coil to prevent arcing and sparking across the switch contacts, thus prolonging the life of the switch. The banded end of the diode must be connected to the positive side of the coil. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=499980#499980 ________________________________________________________________________________
Subject: Re: Power-Sonic LiFePO4 (Hypersport)
Date: Jan 04, 2021
On 1/1/2021 9:53 AM, Patrick Brannan wrote: > > Hi, > > TLDR; The PAL50N18L LiFePO4 (Hypersport) is rated at 128 W/Hr. I > tested at currents between 12.5 and 20 amps and found the capacity was > at least 260 W/Hr. At well under $200 is this a fantastic bargain in > batteries, or have I missed something? > > Im building a Marquart Charger with an electrically dependent engine > using SDS EFII. I settled on a single alternator / 2 battery system. I > forget Bobs schematic # but its one of them. My objective is to have > a comfortable amount of flying time in the event of an alternator > failure. To compensate for a failure of one battery or the other, each > of the batteries needs to be able to run the engine for a reasonable > amount of time. I believe that with a single boost pump operating I > will have a current consumption of a little under 10 amps. The > Marquart Charge is an open cockpit biplane. > > Anyway, I took a plunge and bought a Power-Sonic PAL50N18L LiFePO4. > Yesterday I started testing it, and I want to share the results for 2 > reasons. 1) Help out somebody looking for a battery like this. 2) > Double check my experimental results to make sure they are correct. > > For my test I bought a cheap battery monitor from Amazon and used a > Lectron 10A hobby charger. The battery monitor uses a 75mv - 100A > shunt. The battery monitors current readings were verified by the > voltage drop across the shunt, my multimeter hooked up in series at > less than 10A, and also the Lectron chargers AH numbers. If the > battery monitor says that you took out 20.3 Ah the Lectron will put > very close to 20.3 Ah back in. So even though Im using cheap stuff, I > think its fairly accurate. > > I loaded the battery with a 400W inverter running a work light and a > box fan. Pictures are attached. > > Does this all make sense? I think a LiFePO4 that pushes twice the > rated Ah is unusual. I will say that Power-Sonic says the battery > weights 4 lbs. It really weighs 6. The folks at PLPBattery were great. > When I told them the battery was overweight they weight every other > Power-Sonic battery. According to them, this is the only model that is > overweight. > > Pat > Double the rated total energy sounds like a mislabeled battery. ;-) Supporting that would be the 50% greater weight than spec. The PS datasheet for that model says that the 'cutoff' point should be 12.8V, and their discharge graph shows a 7.5A load discharging to ~12.8V at around 50 minutes. That '128WH' number means that even though the model number makes you 'feel' like it's an 18 AH battery (using typical SLA nomenclature), it's really a 10AH battery. If I were electrically dependent, I'd treat that number as the absolute best case, and de-rate by close to 50% to account for variations in quality, load, aging factors, etc. EFI, including the fuel pump, *might* consume as low as 10 amps, but I'd want to verify that in actual operation; not by 'faith'. The fuel pump alone will consume somewhere between 4.5 & 8 amps, depending on model. To the engine electrical consumption, you need to add whatever additional loads needed in the plane. FWIW, Charlie -- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jan 04, 2021
Subject: Re: Any ideas where to get electric motor brushes?
At 10:43 PM 1/3/2021, you wrote: > >Hi Group >I need some brushes for the exciter on my Monarch EE lathe. Was >making some aeroplane parts and it quit. >Sizes needed: >3/8" x 3/8" and worn out length is 1.060", it has a shunt and >terminal (need 4, will buy 8) >1/2" x 1/4" and worn out length is .495", it has a shunt and >terminal (need 2, will buy 4) >Any ideas where I can purchase from? About 40 years ago I had ready access to a stockroom of brushes that would probably have yielded something that would cut-down to suitable profiles. Alas, no more. There are listings on eBay (40,000+) that might produce useful candidates but most come out of China . . . so it depends on your urgency. I've cut down many a brush on a mill. In your case, avoid brushes destined for use in h9gh current, intermittent motors like starter and winch motors. There are hundreds of 'recipes' for brush make-up . . . unless you order spares from the original manufacturer of you motor, finding an exact replacement for size and content is problematic. However, for anything less then high duty cycle applications, optimization of recipe will have little significance on service life of your substitution. You might research DC motor overhaul services on the 'net. They may have spares suitable for modification if not okay as-is. Keep your old springs if they're not obviously compromised. 1" is pretty long for a worn brush . . . 1/2" values are quite common. Is that in a 4-pole motor? What are the nameplate sizes for these motors? Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jan 04, 2021
McMaster-Carr has a nice selection of brushes available. On Mon, Jan 4, 2021 at 11:29 AM Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 10:43 PM 1/3/2021, you wrote: > > rparigor(at)hotmail.com> > > Hi Group > I need some brushes for the exciter on my Monarch EE lathe. Was making > some aeroplane parts and it quit. > Sizes needed: > 3/8" x 3/8" and worn out length is 1.060", it has a shunt and terminal > (need 4, will buy 8) > 1/2" x 1/4" and worn out length is .495", it has a shunt and terminal > (need 2, will buy 4) > Any ideas where I can purchase from? > > > About 40 years ago I had ready access to > a stockroom of brushes that would probably > have yielded something that would cut-down > to suitable profiles. Alas, no more. > > There are listings on eBay (40,000+) that > might produce useful candidates but most > come out of China . . . so it depends on your > urgency. > > I've cut down many a brush on a mill. In > your case, avoid brushes destined for use > in h9gh current, intermittent motors like > starter and winch motors. > > There are hundreds of 'recipes' for brush > make-up . . . unless you order spares from > the original manufacturer of you motor, > finding an exact replacement for size and > content is problematic. > > However, for anything less then high duty > cycle applications, optimization of recipe > will have little significance on service > life of your substitution. > > You might research DC motor overhaul > services on the 'net. They may have > spares suitable for modification if not > okay as-is. Keep your old springs if they're > not obviously compromised. > > 1" is pretty long for a worn brush . . . 1/2" > values are quite common. Is that in a 4-pole > motor? What are the nameplate sizes for these > motors? > > > Bob . . . > > Un impeachable logic: George Carlin asked, "If black boxes > survive crashes, why don't they make the whole airplane > out of that stuff?" > ________________________________________________________________________________
Date: Jan 04, 2021
At 10:43 PM 1/3/2021, you wrote: > >Hi Group >I need some brushes for the exciter on my Monarch EE lathe. Was >making some aeroplane parts and it quit. >Sizes needed: >3/8" x 3/8" and worn out length is 1.060", it has a shunt and >terminal (need 4, will buy 8) >1/2" x 1/4" and worn out length is .495", it has a shunt and >terminal (need 2, will buy 4) >Any ideas where I can purchase from? check out these guys https://tinyurl.com/yczw98h4 and no doubt there are others. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jan 04, 2021
*Dear Bob et al.I have a question on how electricity works in relation to components in our obam aircraft and hope you can help my understanding.I have a unit that has a power requirement of 15 amps.It is my intention to control this unit utilising a relay.I wish to control the relay with a micro-switch.I'll at first wire up the relay as per Z diagrams where the main power supply wire to the relay, and thence unit, is also the power for the relay operating coil.Starting with the micro-switch contacts open and no current flowing, on closing the micro-switch contacts and power flows through the coil I'd imagine the relay's coil needs and only "takes" little amperage.At this point the relay's contacts close and the same power supply wire now feeds through to the unit at the amperage it needs.My question is; will the micro-switch and its small gauge wires also "see" the 15 amps that the unit will take?I could wire up the micro-switch and relay coil separate to the power to the unit, but I'm generally wondering how components "choose" their amount of current and if I can use one less wire here safely?Hoping you can help increase my knowledge, thanks.Patrick Elliott* On Mon, Jan 4, 2021 at 8:44 AM user9253 wrote: > > No, the micro switch will not "see" 15 amps. The switch will only conduct > relay coil current. > Current through the switch is limited by the resistance of the relay coil. > A diode should be installed across the relay coil to prevent arcing and > sparking across the switch contacts, thus prolonging the life of the > switch. > The banded end of the diode must be connected to the positive side of the > coil. > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=499980#499980 The 'one wire' question is electrically ok, but might not make logistical sense, unless the high current load is very close to the microswitch control point. If that's your situation, then it's no big deal to jump from the high current supply terminal of the relay to the supply side of the microswitch, then from the load side of the microswitch to the supply side of the relay coil. (Pay attention to the length and damage-risk of the run from relay 'hot' to microswitch; that will be 'unprotected' due to the high current fusing for your primary load.) Charlie ________________________________________________________________________________
Date: Jan 04, 2021
Have you tried Monarch ? On Mon, Jan 4, 2021 at 11:43 AM John B wrote: > McMaster-Carr has a nice selection of brushes available. > > On Mon, Jan 4, 2021 at 11:29 AM Robert L. Nuckolls, III < > nuckolls.bob(at)aeroelectric.com> wrote: > >> At 10:43 PM 1/3/2021, you wrote: >> >> rparigor(at)hotmail.com> >> >> Hi Group >> I need some brushes for the exciter on my Monarch EE lathe. Was making >> some aeroplane parts and it quit. >> Sizes needed: >> 3/8" x 3/8" and worn out length is 1.060", it has a shunt and terminal >> (need 4, will buy 8) >> 1/2" x 1/4" and worn out length is .495", it has a shunt and terminal >> (need 2, will buy 4) >> Any ideas where I can purchase from? >> >> >> About 40 years ago I had ready access to >> a stockroom of brushes that would probably >> have yielded something that would cut-down >> to suitable profiles. Alas, no more. >> >> There are listings on eBay (40,000+) that >> might produce useful candidates but most >> come out of China . . . so it depends on your >> urgency. >> >> I've cut down many a brush on a mill. In >> your case, avoid brushes destined for use >> in h9gh current, intermittent motors like >> starter and winch motors. >> >> There are hundreds of 'recipes' for brush >> make-up . . . unless you order spares from >> the original manufacturer of you motor, >> finding an exact replacement for size and >> content is problematic. >> >> However, for anything less then high duty >> cycle applications, optimization of recipe >> will have little significance on service >> life of your substitution. >> >> You might research DC motor overhaul >> services on the 'net. They may have >> spares suitable for modification if not >> okay as-is. Keep your old springs if they're >> not obviously compromised. >> >> 1" is pretty long for a worn brush . . . 1/2" >> values are quite common. Is that in a 4-pole >> motor? What are the nameplate sizes for these >> motors? >> >> >> >> >> Bob . . . >> >> Un impeachable logic: George Carlin asked, "If black boxes >> survive crashes, why don't they make the whole airplane >> out of that stuff?" >> > ________________________________________________________________________________
Date: Jan 04, 2021
There is a small one man shop near work who's main business for the last 35 years has been repairing and rebuilding electric motors, generators, and alternators. Whenever I need brushes, I go to him. If it is automotive, he looks it up and sells me what I need. If it is not automotive, I bring him the brushes, and/or the device and he has always been able to come up with a replacement from his stocks. He told me that brushes come in different hardnesses. Hard brushes will last a long time, but wear the slip ring or commutator faster, so you may be in for a ring turning or replacement eventually. Softer brushes don't last as long, and need replacement more often, but you will get more ring life out of your device with them. I usually go softer, since it is much easier to replace several sets of brushes than dismantle a motor and turn or replace the commutator once. My local Home depot also carries a selection of brushes, but you may have to surreptitiously scratch them to get an idea of their hardness. The salesmen have no idea. Some large hardware stores also carry a selection of brushes. If they don't have exactly what you need, they can be filed or milled to fit. --Joel On Sun, Jan 3, 2021 at 11:52 PM rparigoris wrote: > rparigor(at)hotmail.com> > > Hi Group > I need some brushes for the exciter on my Monarch EE lathe. Was making > some aeroplane parts and it quit. > Sizes needed: > 3/8" x 3/8" and worn out length is 1.060", it has a shunt and terminal > (need 4, will buy 8) > 1/2" x 1/4" and worn out length is .495", it has a shunt and terminal > (need 2, will buy 4) > Any ideas where I can purchase from? > Thanks > Ron P. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=499971#499971 > > ________________________________________________________________________________
Date: Jan 04, 2021
Subject: D-Sub High Density 78 female - solfder or crimp contacts
Hi Group. What type contacts would you recommend for a 78 female connector - solder or crimp, and why?It seems that solder type are easier to find and less expensive. The connector will be used for a relays box to select VHF nav signals to an HSI.Rumen.... ________________________________________________________________________________
Date: Jan 04, 2021
Hi Bob It's for a 1941 Monarch EE. It has a 5HP 3 phase AC motor that spins a 4 pole DC generator, the generator is connected to a 2 pole exciter and the DC motor is 4 pole. In 1941 they didn't know how to speed control an AC motor so they did so with a DC motor. I forget exactly the hocus pocus they are doing, it doesn't have a huge tube, but slow speed torque is quite impressive. I need exciter and generator brushes and will probably change the motor brushes as well. All 3 devices have shunt wires. How do I determine what hardness I might want? The exciter brush has 600 on it. The generator brush has 063A on it. I have a call into Monarch, but my generator and exciter may not be stock. Thx. Ron P. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=499998#499998 ________________________________________________________________________________
Date: Jan 04, 2021
At 04:11 PM 1/4/2021, you wrote: > >Hi Bob It's for a 1941 Monarch EE. It has a 5HP 3 phase AC motor >that spins a 4 pole DC generator, the generator is connected to a 2 >pole exciter and the DC motor is 4 pole. In 1941 they didn't know >how to speed control an AC motor so they did so with a DC motor. I >forget exactly the hocus pocus they are doing, it doesn't have a >huge tube, but slow speed torque is quite impressive. I need exciter >and generator brushes and will probably change the motor brushes as >well. All 3 devices have shunt wires. How do I determine what >hardness I might want? The exciter brush has 600 on it. The >generator brush has 063A on it. I have a call into Monarch, but my >generator and exciter may not be stock. Thx. Ron P. Hmmm . . . used to teach those systems at Great Lakes . . . wish I had the books! Those number may well be brush grades . . . I've never worked on motors directly but the gurus were in the next cubicles . . . and I did a lot of test instrumentation. So my useful info is limited. If Monarch can't help, a call to one of the brush specialty houses may yield some up-to-date expertise. Also, check around for users/parts manuals. I'm seeing a lot of offers for used/reproduction on Monarch manuals. Do look over the McMaster Carr offerings. Also, this supplier seems likely to have specialty expertise. https://www.graphitestore.com/Carbon-Brushes/Brushes Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jan 04, 2021
On 1/4/2021 4:11 PM, rparigoris wrote: > > Hi Bob It's for a 1941 Monarch EE. It has a 5HP 3 phase AC motor that spins a 4 pole DC generator, the generator is connected to a 2 pole exciter and the DC motor is 4 pole. In 1941 they didn't know how to speed control an AC motor so they did so with a DC motor. I forget exactly the hocus pocus they are doing, it doesn't have a huge tube, but slow speed torque is quite impressive. I need exciter and generator brushes and will probably change the motor brushes as well. All 3 devices have shunt wires. How do I determine what hardness I might want? The exciter brush has 600 on it. The generator brush has 063A on it. I have a call into Monarch, but my generator and exciter may not be stock. Thx. Ron P. > I'm not Bob, but that sounds like a basic rotary phase converter; still available to get 3 phase power from 'single phase' service. Might be branded/made by Monarch, or sourced from a vendor that makes motors & phase converters. Is the rotary converter built into the lathe, or a separate component? The ones I've seen are typically separate from the tool, and often are used to power more than one 3phase tool in the shop (sometimes one-at-a-time, depending on converter capacity). If it's a separate component, it should have a dataplate on it somewhere. FWIW, solid state converters are relatively cheap these days; ex: https://www.amazon.com/Digital-Phase-Converter-5HP-Range/dp/B07F243HLG/ref=psdc_10967761_t1_B00FF1S5IS And if you shop around a bit, you can find a 'variable frequency drive' that will not only give you 3 phase, but the ability to vary the rpm of the lathe using the converter. Like this: https://www.amazon.com/Single-Phase-Variable-Frequency-Inverter-Controller/dp/B07L8XZFYG And no more brush worries (at least in the converter). Charlie -- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jan 04, 2021
contacts We generally try to avoid solder cup connectors on aircraft because typically the average builder doesn=99t have a good high temp yet sma ll iron able to successfully use the solder cups (wires often end up cold soldered and fall off in with future vibration), or they end up wicking tons of solder up into the wire that inevitably leads to wire breakage. On top of that, in a 78 pin arrangement the solder cups would be incredibly densely packed, and it=99s likely the end result would not be pretty. It also takes longer than simply crimping on a pin and inserting it into a connector. Also, if you need to =9Cmove=9D a wire in the middle of that large 78 pin connector, it=99s pretty easy to do with crimp pins, not so mu ch with solder cups. Lastly, the 78 pin crimp connectors aren=99t that terribly expensive (we stock and sell them for about $17 each), standard crimp tooling works well. Just my 2 cents as usual! Cheers, Stein *From:* owner-aeroelectric-list-server(at)matronics.com < owner-aeroelectric-list-server(at)matronics.com> *On Behalf Of *rd2 *Sent:* Monday, January 4, 2021 3:38 PM *To:* aeroelectric-list(at)matronics.com *Subject:* AeroElectric-List: D-Sub High Density 78 female - solfder or crimp contacts Hi Group. What type contacts would you recommend for a 78 female connector - solder or crimp, and why? It seems that solder type are easier to find and less expensive. The connector will be used for a relays box to select VHF nav signals to an HSI. Rumen.... ________________________________________________________________________________
Date: Jan 04, 2021
Subject: Re: D-Sub High Density 78 female - solfder or crimp
contacts At 03:37 PM 1/4/2021, you wrote: >Hi Group. >What type contacts would you recommend for a 78 female connector - >solder or crimp, and why? >It seems that solder type are easier to find and less expensive. >The connector will be used for a relays box to select VHF nav >signals to an HSI. >Rumen.... Do you already have the connector to which you want add wires? How many wires total in your task? If you're considering a solder style, have you compared your solder skills and tools with the sizing of those pins and space between them? I'm pretty sure that the $savings$ would have a poor return on investment for the increase in $time$ and $risk$ unless you're REALLY good at working with those tiny spaces. I personally wouldn't take on a soldering task for more than a handful of wires. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jan 04, 2021
contacts At 04:45 PM 1/4/2021, you wrote: We generally try to avoid solder cup connectors on aircraft because typically the average builder doesn't have a good high temp yet small iron able to successfully use the solder cups (wires often end up cold soldered and fall off in with future vibration), or they end up wicking tons of solder up into the wire that inevitably leads to wire breakage. Lastly, the 78 pin crimp connectors aren't that terribly expensive (we stock and sell them for about $17 each), standard crimp tooling works well. Just my 2 cents as usual! More like $20 worth . . . thank you. Hope you're well and optimistic for the future my friend. Long time no talk! Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jan 04, 2021
Hi Charlie My Monarch EE helped to win WW2. It was owned by the Singer Corporation until the 1970s. Back in the day, 3 phase AC motors couldn't be speed controlled. Thus Monarch has an integral 3 phase AC motor with DC Generator. At the tip of the spinning mass is an Exicter. Some Monarch also used a Magnetron tube. The idea was you could have a variable speed on the fly with good low speed torque. If you just cut voltage on a DC motor you can speed control it but low speed torque suffers. Monarch does some hocus pocus that increases torque at lower speeds compared to just cutting voltage. DC motor has 4 brushes. Today you have PWM speed controls for DC motors which can do the same thing, but back then this was a terrific desirable feature. There are many Monarchs that modify the unit by removing all this stuff and associated relays and controls and replace it with a brushless 3 phase AC motor with a speed controller. Not a trivial modification. I power my stuff with a 7.5hp rotophase running on 220v single phase including the Monarch. The main DC motor was rebuilt early on but the Exciter and AC/DC Generator is what was with machine when purchased from Singer. I actually have 2 rotophase converters. One 3hp and one 7.5hp. Since the late 1970s all that I did with the Rotophase converters is put in a tiny amount of grease and replaced relays and capacitors perhaps once each. I remember replacing all the brushes in the 1980s when I was using the machine alot. I goth them from the motor rebuilder. Brushes have lasted till now. Ron P. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=500005#500005 ________________________________________________________________________________
Date: Jan 04, 2021
Hi Bob Thx. for info. I actually have an inquiry for quote from McMaster. I printed brush info from graphitestore over the weekend. Minimum of 12 brushes each buy, would require talking to them about hardness and size of pig tail. One size only has a spring over pig tail, but could solder on a terminal. I spoke to a buddy who works for the railroad in the motor rebuilding shop. I'm going to give him a set of old brushes and he will match em up. He said he's pretty good determining the hardness of brushes using his precision calibrated "EyeChrometer". Thx. Ron Read this topic online here: http://forums.matronics.com/viewtopic.php?p=500006#500006 ________________________________________________________________________________
Date: Jan 04, 2021
Subject: Connector advice
Hey group, I'm replacing the legacy engine and fuel gauges in my 1978 Cherokee Six with Mitchell products cluster gauges. The original gauges were fed from a 20AWG wire from a 5A breaker to one of the original gauges and then wired in series with a jumper wire from gauge to gauge. I need to connect the original power wire to the power wires of 7 new gauges.I would like a connector instead of soldering due to the specific requirements I have. Any recommendations? Cannon plug, molex, dsub? I could go to a bus bar and feed from there but room is pretty tight under the dash. ________________________________________________________________________________
Date: Jan 04, 2021
>Double the rated total energy sounds like a mislabeled battery. In my experience, PowerSonic has been pretty solid in specifying their products. I would expect some variation of delivered energy over a spectrum of test loads, but not by much. LiFePO4 discharge plots are exceedingly 'flat' with respect to load. Watt-Hours is a measurement of energy delivered at the test-value load. This is difficult to measure without some pretty light footed data recording techniques. The WestMountain Radio CBA series battery analyzers are a fine example of low cost, battery ENERGY measurement tools. The technique calls for MEASURING load current to some degree of accuracy (unless you're using a precision, bench test load) along with battery voltage. You measure each value at say, 1 second intervals, the multiply volts x amps = watts. You now have a measured packet of energy delivered for a 1-second interval of time. You SUM that increment to previous measurements already in storage. When the test termination voltage is achieved (typically 11.0 volts) then stop the test, add up all the watt-seconds in storage then divide by 3600 to get watt-hours AT THAT PARTICULAR TEST CONDITION. Note that the PC680 is spec'd to deliver 132 WH for 30 minutes under a 23A load. LiFePO4 with similar capacity will be in that ballpark. Note too that as the test current goes DOWN, the delivered energy goes UP. This is because less energy is lost to the battery's INTERNAL RESISTANCE at lighter loads. A similar thing happens with LiFePO4 but with less spread across the spectrum of test loads. This is due to the much lower internal resistance of the LiFePO4 chemistry. LiFePO4 family of discharge curves are almost coincident. Your test results suggest a review of test methodology and instrument capability. I suggest that the PowerSonic spec sheet is pretty much gospel. Your bench tests should produce results pretty close to specs. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jan 04, 2021
At 07:18 PM 1/4/2021, you wrote: > >Hi Charlie >My Monarch EE helped to win WW2. It was owned by the Singer >Corporation until the 1970s. Back in the day, 3 phase AC motors >couldn't be speed controlled. Thus Monarch has an integral 3 phase >AC motor with DC Generator. At the tip of the spinning mass is an >Exicter. Some Monarch also used a Magnetron tube. The idea was you >could have a variable speed on the fly with good low speed torque. >If you just cut voltage on a DC motor you can speed control it but >low speed torque suffers. Monarch does some hocus pocus that >increases torque at lower speeds compared to just cutting voltage. Actually, not all that mysterious. Railroad locomotives use a similar technology. Generate power with lots of volts and current that is hooked to the traction motors full time. Now, just like the regulator in your car adjusts power output by modulating FIELD current, the throttle of a locomotive adjusts field current of a small exciter which in turn drives the field of the traction generators which in turn powers the traction motors. The current being handled by the engineer's throttle is quite small compared to thousands of amps available to produce motive power. In the case of locomotives, they're interested in traction force which is proportional to motor current. The electronic controls that watch traction current to achieve conformity with engineer's throttle commands operate at relatively low power. In the lathe case, the goal is to achieve constant speed as opposed to constant torque. Shuffle the components in the feedback loop a bit and the 'throttle' now produces a command that the electronics interprets as a 'speed' requirement as opposed to 'torque'. The electronics work just like the cruise control on your car. I.e. adjust manifold pressure (motor current) as required to achieve constant MPH (spindle RPM). What ever current it takes to do that is limited only by capabilities of the power supply WATTS (gas pedal flat on the floor). The motor controller in the lathe is oblivious to present voltage/current as long as physical limits are not exceeded. BTW, if anyone has a treadmill, the controller for tread speed is a direct descendant of the system in the Monarch lathe except that AC/DC conversion is done with a rectifier instead of a 3-phase motor generator set. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jan 04, 2021
>I power my stuff with a 7.5hp rotophase running on 220v single phase >including the Monarch. Okay, if I interpret your words correctly you use a single-phase to 3-phase external converter to power the 3-phase to DC motor-generator in the lathe which includes a low power exciter (generator) to manage energy delivered to a work-motor that powers the head-stock? Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jan 04, 2021
Hi Bob Exactly correct. The work motor is a 4 brush DC motor, probably ~5hp. I had an event about 5 years ago, the timing screws loosened up and the thing slid to full retarded and ripped out a wire. Good thing the wire ripped as running a motor retarded will trash the armature. I timed motor so it was pretty close to neutral, perhaps I gave it 1 degree advanced in forward. Has been running great. To find neutral timing on a motor, you run it forward and reverse and mark where the current draw is identical. I used about 500 rpm. If running forward and reverse neutral is best. For best efficiency if only running forward ~ 5 degrees advanced. Depending on motor, how much heat it can tolerate and how long you plan to run it hard best power is 7.5 to 15 degrees advanced. Many electric motors are 5 degrees advanced, don't run them in reverse unless you neutral time. Ron Read this topic online here: http://forums.matronics.com/viewtopic.php?p=500011#500011 ________________________________________________________________________________
Date: Jan 05, 2021
At 08:53 PM 1/4/2021, you wrote: > >Hi Bob >Exactly correct. The work motor is a 4 brush DC motor, probably >~5hp. I had an event about 5 years ago, the timing screws loosened >up and the thing slid to full retarded and ripped out a wire. Good >thing the wire ripped as running a motor retarded will trash the >armature. I timed motor so it was pretty close to neutral, perhaps I >gave it 1 degree advanced in forward. Has been running great. To >find neutral timing on a motor, you run it forward and reverse and >mark where the current draw is identical. I used about 500 rpm. If >running forward and reverse neutral is best. For best efficiency if >only running forward ~ 5 degrees advanced. Depending on motor, how >much heat it can tolerate and how long you plan to run it hard best >power is 7.5 to 15 degrees advanced. Many electric motors are 5 >degrees advanced, don't run them in reverse unless you neutral time. Ron Yep, that brings back memories. I taught several sections in ETC School at Great Lakes Naval Training Base for about 6 months . . . loved the job but had to give it up and come back to Wichita where wages were more commensurate with cost of living! Energy conversion in rotating machines was two sections I taught to Navy recruits. One of my favorite topics was a thing called the Amplidyne. An electro-mechanical amplifier widely used on shipboard radar antenna sweep servos. https://tinyurl.com/y5ex9ek6 A very interesting critter that took awhile to wrap your head around! Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jan 05, 2021
contacts Excellent advice, as usual, thanks Stein. Crimped it'll be. The problem was my soldering skills are much better than my crimping skills (almost none). Thanks for bringing up the questions, Bob: --snip-- Do you already have the connector to which you want add wires? How many wires total in your task? ---snip--- I already have the female connector - it is populated from another applicat ion. I assume that I can reuse it - just need to remove the populated conta ct sockets, crimp the new ones and repopulate. I don't now the exact number of wires yet, I expect most (or more than 1/2) of the positions to be used. I will visit Stein's web site to order sockets and tools, but first I need to find some mp4 on youtube that will guide me through the process instead of asking questions. Thanks again. Rumen ----- Original Message ----- From: SteinB <stein(at)steinair.com> Subject: RE: AeroElectric-List: D-Sub High Density 78 female - solfder or c rimp contacts We generally try to avoid solder cup connectors on aircraft because typi cally the average builder doesn=99t have a good high temp yet small i ron able to successfully use the solder cups (wires often end up cold solde red and fall off in with future vibration), or they end up wicking tons of solder up into the wire that inevitably leads to wire breakage. On top of t hat, in a 78 pin arrangement the solder cups would be incredibly densely pa cked, and it=99s likely the end result would not be pretty. It also t akes longer than simply crimping on a pin and inserting it into a connector . Also, if you need to =9Cmove=9D a wire in the middle of that large 78 pin connector, it=99s pretty easy to do with crimp pins, not so much with solder cups. Lastly, the 78 pin crimp connectors aren =99t that terribly expensive (we stock and sell them for about $17 each), s tandard crimp tooling works well. Just my 2 cents as usual! Cheers,Stein F rom:owner-aeroelectric-list-server(at)matronics.com On Behalf Of rd2 Sent: Monday, January 4, 2021 3:38 PM To:aeroelectric-list(at)matronics.com Subject: AeroElectric-List: D-Sub High Density 78 female - solfder or crimp contacts Hi Group.What type contacts would you recommend for a 78 female c onnector - solder or crimp, and why?It seems that solder type are easier to find and less expensive. The connector will be used for a relays box to se lect VHF nav signals to an HSI.Rumen.... ________________________________________________________________________________
From: "Matthew S. Whiting" <m.whiting(at)frontier.com>
contacts
Date: Jan 05, 2021
Soldering is a perfectly fine approach IF your soldering skills are good. A s a retired EE, my soldering skills are not as good as those of many of the t echnicians who used to work for me, but they aren=99t bad. I would ha ve no hesitation soldering d-sub connectors although my issue is becoming mo re of an eyesight issue than a soldering skills issue. I would need to buy a lighted magnifier to solder high density parts now as the naked eye is no l onger adequate. And, as Stein mentioned, being able to remove and relocate crimped pins is a huge advantage when doing low-volume custom work. Matt Sent from my iPad > On Jan 5, 2021, at 8:28 AM, rd2 wrote: > > =EF=BB > Excellent advice, as usual, thanks Stein. Crimped it'll be. > The problem was my soldering skills are much better than my crimping skill s (almost none). > Thanks for bringing up the questions, Bob: > > --snip-- > Do you already have the connector to which you want > add wires? How many wires total in your task? > ---snip--- > > I already have the female connector - it is populated from another applica tion. I assume that I can reuse it - just need to remove the populated conta ct sockets, crimp the new ones and repopulate. > I don't now the exact number of wires yet, I expect most (or more than 1/2 ) of the positions to be used. > I will visit Stein's web site to order sockets and tools, but first I need to find some mp4 on youtube that will guide me through the process instead o f asking questions. > > Thanks again. > Rumen > > ----- Original Message ----- > From: SteinB <stein(at)steinair.com> > To: aeroelectric-list(at)matronics.com > Subject: RE: AeroElectric-List: D-Sub High Density 78 female - solfder or c rimp contacts > > We generally try to avoid solder cup connectors on aircraft because typica lly the average builder doesn=99t have a good high temp yet small iron able to successfully use the solder cups (wires often end up cold soldered a nd fall off in with future vibration), or they end up wicking tons of solder up into the wire that inevitably leads to wire breakage. > > > > On top of that, in a 78 pin arrangement the solder cups would be incredibl y densely packed, and it=99s likely the end result would not be pretty . It also takes longer than simply crimping on a pin and inserting it into a connector. Also, if you need to =9Cmove=9D a wire in the middle of that large 78 pin connector, it=99s pretty easy to do with crimp p ins, not so much with solder cups. > > > > Lastly, the 78 pin crimp connectors aren=99t that terribly expensive (we stock and sell them for about $17 each), standard crimp tooling works w ell. > > > > Just my 2 cents as usual! > > > > Cheers, > > Stein > > > > > > From:owner-aeroelectric-list-server(at)matronics.com On Behalf Of rd2 > Sent: Monday, January 4, 2021 3:38 PM > To:aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: D-Sub High Density 78 female - solfder or crim p contacts > > > > Hi Group. > > What type contacts would you recommend for a 78 female connector - solder o r crimp, and why? > > It seems that solder type are easier to find and less expensive. > > The connector will be used for a relays box to select VHF nav signals to a n HSI. > > Rumen.... > > > > > ________________________________________________________________________________
Date: Jan 05, 2021
contacts If you're having trouble crimping subD pins, you likely have the wrong tools for the task. I've been soldering for over 50 years (a lot of them professionally), and crimping is still easier/faster (though more expensive) than soldering for me. Harder for me is accurately stripping the wire to prep for the crimp. A decent quality stripping tool with dies sized for each gauge wire (I like this style ) seems essential, and a good eye for strip length helps (to ensure full depth of bare wire into the terminal, without leaving excess bare wire exposed). I've never had good luck with the 'automatic' strippers, but I've never invested in a new, really high quality version. The crimp itself is 'automatic'; as long as the terminal is the proper depth into the crimper, the tool forces you to make a full crimp before releasing. BTW, you really don't need to spend $hundreds on a production crimper for one project. Stein and others sell this tool which many of us have used to wire entire a/c. Since you're using HD pins, you might want the optional HD positioner , though I've had good success manually positioning the pin when I've only needed to do a couple at a time. I'll bet you will have much more trouble depinning the old shell (you need this tool ) than crimping the new pins. Charlie On Tue, Jan 5, 2021 at 7:28 AM rd2 wrote: > Excellent advice, as usual, thanks Stein. Crimped it'll be. > The problem was my soldering skills are much better than my crimping > skills (almost none). > Thanks for bringing up the questions, Bob: > > --snip-- > Do you already have the connector to which you want > add wires? How many wires total in your task? > ---snip--- > > I already have the female connector - it is populated from another > application. I assume that I can reuse it - just need to remove the > populated contact sockets, crimp the new ones and repopulate. > I don't now the exact number of wires yet, I expect most (or more than > 1/2) of the positions to be used. > I will visit Stein's web site to order sockets and tools, but first I nee d > to find some mp4 on youtube that will guide me through the process instea d > of asking questions. > > Thanks again. > Rumen > > ----- Original Message ----- > From: SteinB <stein(at)steinair.com> > To: aeroelectric-list(at)matronics.com > Subject: RE: AeroElectric-List: D-Sub High Density 78 female - solfder or > crimp contacts > > We generally try to avoid solder cup connectors on aircraft because > typically the average builder doesn=99t have a good high temp yet s mall iron > able to successfully use the solder cups (wires often end up cold soldere d > and fall off in with future vibration), or they end up wicking tons of > solder up into the wire that inevitably leads to wire breakage. > > > On top of that, in a 78 pin arrangement the solder cups would be > incredibly densely packed, and it=99s likely the end result would n ot be > pretty. It also takes longer than simply crimping on a pin and inserting it > into a connector. Also, if you need to =9Cmove=9D a wire in t he middle of that > large 78 pin connector, it=99s pretty easy to do with crimp pins, n ot so much > with solder cups. > > > Lastly, the 78 pin crimp connectors aren=99t that terribly expensiv e (we > stock and sell them for about $17 each), standard crimp tooling works wel l. > > > Just my 2 cents as usual! > > > Cheers, > > Stein > > > *From:*owner-aeroelectric-list-server(at)matronics.com < > owner-aeroelectric-list-server(at)matronics.com> *On Behalf Of *rd2 > *Sent:* Monday, January 4, 2021 3:38 PM > *To:*aeroelectric-list(at)matronics.com > *Subject:* AeroElectric-List: D-Sub High Density 78 female - solfder or > crimp contacts > > > Hi Group. > > What type contacts would you recommend for a 78 female connector - solder > or crimp, and why? > > It seems that solder type are easier to find and less expensive. > > The connector will be used for a relays box to select VHF nav signals to > an HSI. > > Rumen.... > > ________________________________________________________________________________
Date: Jan 05, 2021
Subject: Re: Connector advice
At 07:41 PM 1/4/2021, you wrote: >Hey group, > >I'm replacing the legacy engine and fuel gauges >in my 1978 Cherokee Six with Mitchell products >cluster gauges. The original gauges were fed >from a 20AWG wire from a 5A breaker to one of >the original=C2 gauges and then wired in series >with a jumper wire from gauge to gauge. I need >to connect=C2 the original power=C2 wire to the >power wires of 7 new gauges.I would like a >connector instead of soldering due to the >specific requirements I have. Any >recommendations? Cannon plug, molex, dsub? I >could go to a bus bar and feed from there but >room is pretty tight under the dash. For this and similar situations, I start with the question: "Why wouldn't a d-sub work here?" Admittedly, I'm flush with dsub tooling and inventory. A condition deliberately crafted based on the versatility off these connectors. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jan 05, 2021
Subject: Power distribution parts
I have a lot of 5 fuse blocks and 3 ground busses that are surplus to my needs. Want to turn them back to 'the wild' where there's a better chance of being used. I'd like to get $20 for the lot which includes priority mail to any US address. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Subject: Re: Power distribution parts
Date: Jan 05, 2021
On 1/5/2021 12:42 PM, Robert L. Nuckolls, III wrote: > I have a lot of 5 fuse blocks and 3 ground > busses that are surplus to my needs. Want > to turn them back to 'the wild' where > there's a better chance of being used. > > I'd like to get $20 for the lot which > includes priority mail to any US > address. > > Bob . . . > > Un impeachable logic: George Carlin asked, "If black boxes > survive crashes, why don't they make the whole airplane > out of that stuff?" > Hi Bob, I'll certainly take the lot. But happy to stand aside if someone else has an immediate need for it. How would you prefer payment? Thanks, Charlie -- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jan 05, 2021
Hi Bob, I can take those... thanks. John Bright107 King Forest LaneNewport News, VA=C2- 23608c: 757-812-1909 nuckolls.bob(at)aeroelectric.com> wrote: I have a lot of 5 fuse blocks and 3 ground busses that are surplus to my needs. Want to turn them back to 'the wild' where there's a better chance of being used. I'd like to get $20 for the lot which includes priority mail to any US address. =C2- Bob . . . =C2- Un impeachable logic: George Carlin asked, "If blackboxes =C2- survive crashes, why don't they make the whole airplane =C2- out of that stuff?" ________________________________________________________________________________
Date: Jan 05, 2021
I yield to Charlie. -------- John Bright, RV-6A, at FWF, O-360 Z-101 single batt dual alt SDS EM-5-F. john_s_bright(at)yahoo.com, Newport News, Va https://drive.google.com/drive/folders/1u6GeZo6pmBWsKykLNVQMvu4o1VEVyP4K Read this topic online here: http://forums.matronics.com/viewtopic.php?p=500031#500031 ________________________________________________________________________________
Date: Jan 05, 2021
Bob and Charlie That's a lot of fuse blocks. I am in need of a 10 fuse block. Do you want to split the sale. Thanks Paul On Tue, Jan 5, 2021 at 2:15 PM Charlie England wrote: > On 1/5/2021 12:42 PM, Robert L. Nuckolls, III wrote: > > I have a lot of 5 fuse blocks and 3 ground > busses that are surplus to my needs. Want > to turn them back to 'the wild' where > there's a better chance of being used. > > I'd like to get $20 for the lot which > includes priority mail to any US > address. > > Bob . . . > > Un impeachable logic: George Carlin asked, "If black boxes > survive crashes, why don't they make the whole airplane > out of that stuff?" > > Hi Bob, > I'll certainly take the lot. But happy to stand aside if someone else has > an immediate need for it. > > How would you prefer payment? > > Thanks, > > Charlie > > > Virus-free. > www.avast.com > > <#m_6240126768322279902_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> > ________________________________________________________________________________
Date: Jan 05, 2021
Subject: Junk parts, free for science
I have a small box full of unairworthy odds and ends. Does anyone want them for taking apart or other education before I put them in the trash? There is a contactor, overvoltage relay, voltage regulator, switches and breakers. ________________________________________________________________________________
Date: Jan 05, 2021
If no one else speaks up, I'll be glad to pay Bob, and forward a 10-slot one to you so he doesn't have to prep two shipments. Charlie On 1/5/2021 3:36 PM, Paul Eckenroth wrote: > Bob and Charlie > > That's a lot of fuse blocks. I am in need of a 10 fuse block. Do you > want to split the sale. > > Thanks > Paul > > On Tue, Jan 5, 2021 at 2:15 PM Charlie England > wrote: > > On 1/5/2021 12:42 PM, Robert L. Nuckolls, III wrote: >> I have a lot of 5 fuse blocks and 3 ground >> busses that are surplus to my needs. Want >> to turn them back to 'the wild' where >> there's a better chance of being used. >> >> I'd like to get $20 for the lot which >> includes priority mail to any US >> address. >> >> Bob . . . >> >> Un impeachable logic: George Carlin asked, "If black boxes >> survive crashes, why don't they make the whole airplane >> out of that stuff?" >> > Hi Bob, > I'll certainly take the lot. But happy to stand aside if someone > else has an immediate need for it. > > How would you prefer payment? > > Thanks, > > Charlie > > > Virus-free. www.avast.com > > > > <#m_6240126768322279902_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> > -- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jan 05, 2021
I'd love to take the lot but currently I'm only in need of a 2 ground blocks and 32 fuses worth of blocks. I'd pay the $20 just for that. Any way we can make this work out? On Tue, Jan 5, 2021 at 1:49 PM Paul Eckenroth wrote: > Bob and Charlie > > That's a lot of fuse blocks. I am in need of a 10 fuse block. Do you > want to split the sale. > > Thanks > Paul > > On Tue, Jan 5, 2021 at 2:15 PM Charlie England > wrote: > >> On 1/5/2021 12:42 PM, Robert L. Nuckolls, III wrote: >> >> I have a lot of 5 fuse blocks and 3 ground >> busses that are surplus to my needs. Want >> to turn them back to 'the wild' where >> there's a better chance of being used. >> >> I'd like to get $20 for the lot which >> includes priority mail to any US >> address. >> >> Bob . . . >> >> Un impeachable logic: George Carlin asked, "If black boxes >> survive crashes, why don't they make the whole airplane >> out of that stuff?" >> >> Hi Bob, >> I'll certainly take the lot. But happy to stand aside if someone else has >> an immediate need for it. >> >> How would you prefer payment? >> >> Thanks, >> >> Charlie >> >> >> Virus-free. >> www.avast.com >> >> <#m_-4915725974748346567_m_4119643337842739199_m_1162196725734180277_m_6240126768322279902_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> >> > ________________________________________________________________________________
Date: Jan 05, 2021
*2 ground blocks, not a 2 ground blocks On Tue, Jan 5, 2021 at 2:01 PM Sebastien wrote: > I'd love to take the lot but currently I'm only in need of a 2 ground > blocks and 32 fuses worth of blocks. I'd pay the $20 just for that. Any way > we can make this work out? > > On Tue, Jan 5, 2021 at 1:49 PM Paul Eckenroth > wrote: > >> Bob and Charlie >> >> That's a lot of fuse blocks. I am in need of a 10 fuse block. Do you >> want to split the sale. >> >> Thanks >> Paul >> >> On Tue, Jan 5, 2021 at 2:15 PM Charlie England >> wrote: >> >>> On 1/5/2021 12:42 PM, Robert L. Nuckolls, III wrote: >>> >>> I have a lot of 5 fuse blocks and 3 ground >>> busses that are surplus to my needs. Want >>> to turn them back to 'the wild' where >>> there's a better chance of being used. >>> >>> I'd like to get $20 for the lot which >>> includes priority mail to any US >>> address. >>> >>> Bob . . . >>> >>> Un impeachable logic: George Carlin asked, "If black boxes >>> survive crashes, why don't they make the whole airplane >>> out of that stuff?" >>> >>> Hi Bob, >>> I'll certainly take the lot. But happy to stand aside if someone else >>> has an immediate need for it. >>> >>> How would you prefer payment? >>> >>> Thanks, >>> >>> Charlie >>> >>> >>> Virus-free. >>> www.avast.com >>> >>> <#m_-5365706941029605914_m_-4915725974748346567_m_4119643337842739199_m_1162196725734180277_m_6240126768322279902_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> >>> >> ________________________________________________________________________________
Date: Jan 05, 2021
My primary interest was in a ground block or two; the rest would just go into my 'stash'. If you & Paul can work it out & make it easy on Bob, I'll step aside. Y'all need to know that it's a smokin' good deal; just the large fuse block is worth more than Bob's asking for the whole batch with free shipping. Charlie On 1/5/2021 4:01 PM, Sebastien wrote: > I'd love to take the lot but currently I'm only in need of a 2 ground > blocks and 32 fuses worth of blocks. I'd pay the $20 just for that. > Any way we can make this work out? > > On Tue, Jan 5, 2021 at 1:49 PM Paul Eckenroth > wrote: > > Bob and Charlie > > That's a lot of fuse blocks. I am in need of a 10 fuse block. Do > you want to split the sale. > > Thanks > Paul > > On Tue, Jan 5, 2021 at 2:15 PM Charlie England > > wrote: > > On 1/5/2021 12:42 PM, Robert L. Nuckolls, III wrote: >> I have a lot of 5 fuse blocks and 3 ground >> busses that are surplus to my needs. Want >> to turn them back to 'the wild' where >> there's a better chance of being used. >> >> I'd like to get $20 for the lot which >> includes priority mail to any US >> address. >> >> Bob . . . >> >> Un impeachable logic: George Carlin asked, "If black boxes >> survive crashes, why don't they make the whole airplane >> out of that stuff?" >> > Hi Bob, > I'll certainly take the lot. But happy to stand aside if > someone else has an immediate need for it. > > How would you prefer payment? > > Thanks, > > Charlie > > > Virus-free. www.avast.com > > > > <#m_-4915725974748346567_m_4119643337842739199_m_1162196725734180277_m_6240126768322279902_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> > -- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jan 05, 2021
How about this. I'll pay the $20 + shipping to Bob and he ships the whole thing to Charlie. Paul pays Charlie for shipping and Charlie ships him the power block he needs. Charlie takes what he wants and ships the rest to me in Canada at his expense. Does that work? On Tue, Jan 5, 2021 at 3:19 PM Charlie England wrote: > My primary interest was in a ground block or two; the rest would just go > into my 'stash'. If you & Paul can work it out & make it easy on Bob, I'll > step aside. Y'all need to know that it's a smokin' good deal; just the > large fuse block is worth more than Bob's asking for the whole batch with > free shipping. > > Charlie > > On 1/5/2021 4:01 PM, Sebastien wrote: > > I'd love to take the lot but currently I'm only in need of a 2 ground > blocks and 32 fuses worth of blocks. I'd pay the $20 just for that. Any way > we can make this work out? > > On Tue, Jan 5, 2021 at 1:49 PM Paul Eckenroth > wrote: > >> Bob and Charlie >> >> That's a lot of fuse blocks. I am in need of a 10 fuse block. Do you >> want to split the sale. >> >> Thanks >> Paul >> >> On Tue, Jan 5, 2021 at 2:15 PM Charlie England >> wrote: >> >>> On 1/5/2021 12:42 PM, Robert L. Nuckolls, III wrote: >>> >>> I have a lot of 5 fuse blocks and 3 ground >>> busses that are surplus to my needs. Want >>> to turn them back to 'the wild' where >>> there's a better chance of being used. >>> >>> I'd like to get $20 for the lot which >>> includes priority mail to any US >>> address. >>> >>> Bob . . . >>> >>> Un impeachable logic: George Carlin asked, "If black boxes >>> survive crashes, why don't they make the whole airplane >>> out of that stuff?" >>> >>> Hi Bob, >>> I'll certainly take the lot. But happy to stand aside if someone else >>> has an immediate need for it. >>> >>> How would you prefer payment? >>> >>> Thanks, >>> >>> Charlie >>> >>> >>> Virus-free. >>> www.avast.com >>> >>> <#m_4003248747224172824_m_-4915725974748346567_m_4119643337842739199_m_1162196725734180277_m_6240126768322279902_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> >>> >> > ________________________________________________________________________________
Subject: Monarch EE Anti-Plugging Field Accelerating?
Date: Jan 05, 2021
Hi Bob Perhaps you can enlighten me a little more how Monarch controls speed on my EE with their hocus pocus. Here's a link to the only schematic I have: https://1drv.ms/b/s!Ah1S270Nwg9V4St1iHBVNSihPNyL?e=Y3H4UJ The huge Ohmite-A-1925 Rheostat (size of a volley ball) controls the field for the motor and generator at the same time. Why not just control the generator field? At the top of the schematic there is Field Accelerating using a CXG 2105-B and Anti-Plugging using a SD4-2-S-14. What is Field Accelerating? What is Anti-Plugging? Amplidyne is very interesting! Thank you for sharing. Ron P. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=500053#500053 Attachments: http://forums.matronics.com//files/monarch_ee_schematic_491.pdf ________________________________________________________________________________
Date: Jan 06, 2021
Since the two of you have immediate needs, I'd suggest you work it out between you, and one of you do the purchase from Bob. If you both back out Bob can contact me directly for payment/shipping info exchange. Charlie On Tue, Jan 5, 2021 at 5:40 PM Sebastien wrote: > How about this. I'll pay the $20 + shipping to Bob and he ships the whole > thing to Charlie. Paul pays Charlie for shipping and Charlie ships him the > power block he needs. Charlie takes what he wants and ships the rest to me > in Canada at his expense. > > Does that work? > > On Tue, Jan 5, 2021 at 3:19 PM Charlie England > wrote: > >> My primary interest was in a ground block or two; the rest would just go >> into my 'stash'. If you & Paul can work it out & make it easy on Bob, I'll >> step aside. Y'all need to know that it's a smokin' good deal; just the >> large fuse block is worth more than Bob's asking for the whole batch with >> free shipping. >> >> Charlie >> >> On 1/5/2021 4:01 PM, Sebastien wrote: >> >> I'd love to take the lot but currently I'm only in need of a 2 ground >> blocks and 32 fuses worth of blocks. I'd pay the $20 just for that. Any way >> we can make this work out? >> >> On Tue, Jan 5, 2021 at 1:49 PM Paul Eckenroth >> wrote: >> >>> Bob and Charlie >>> >>> That's a lot of fuse blocks. I am in need of a 10 fuse block. Do you >>> want to split the sale. >>> >>> Thanks >>> Paul >>> >>> On Tue, Jan 5, 2021 at 2:15 PM Charlie England >>> wrote: >>> >>>> On 1/5/2021 12:42 PM, Robert L. Nuckolls, III wrote: >>>> >>>> I have a lot of 5 fuse blocks and 3 ground >>>> busses that are surplus to my needs. Want >>>> to turn them back to 'the wild' where >>>> there's a better chance of being used. >>>> >>>> I'd like to get $20 for the lot which >>>> includes priority mail to any US >>>> address. >>>> >>>> Bob . . . >>>> >>>> Un impeachable logic: George Carlin asked, "If black boxes >>>> survive crashes, why don't they make the whole airplane >>>> out of that stuff?" >>>> >>>> Hi Bob, >>>> I'll certainly take the lot. But happy to stand aside if someone else >>>> has an immediate need for it. >>>> >>>> How would you prefer payment? >>>> >>>> Thanks, >>>> >>>> Charlie >>>> >>>> >>>> Virus-free. >>>> www.avast.com >>>> >>>> <#m_7168316372381935183_m_4003248747224172824_m_-4915725974748346567_m_4119643337842739199_m_1162196725734180277_m_6240126768322279902_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> >>>> >>> >> ________________________________________________________________________________
Date: Jan 06, 2021
Ok. Bob could you please charge me $20 + shipping to Canada and send me whatever is leftover after Paul takes what he needs. On Wed, Jan 6, 2021 at 9:07 AM Charlie England wrote: > Since the two of you have immediate needs, I'd suggest you work it out > between you, and one of you do the purchase from Bob. If you both back out > Bob can contact me directly for payment/shipping info exchange. > > Charlie > > On Tue, Jan 5, 2021 at 5:40 PM Sebastien wrote: > >> How about this. I'll pay the $20 + shipping to Bob and he ships the whole >> thing to Charlie. Paul pays Charlie for shipping and Charlie ships him the >> power block he needs. Charlie takes what he wants and ships the rest to me >> in Canada at his expense. >> >> Does that work? >> >> On Tue, Jan 5, 2021 at 3:19 PM Charlie England >> wrote: >> >>> My primary interest was in a ground block or two; the rest would just go >>> into my 'stash'. If you & Paul can work it out & make it easy on Bob, I'll >>> step aside. Y'all need to know that it's a smokin' good deal; just the >>> large fuse block is worth more than Bob's asking for the whole batch with >>> free shipping. >>> >>> Charlie >>> >>> On 1/5/2021 4:01 PM, Sebastien wrote: >>> >>> I'd love to take the lot but currently I'm only in need of a 2 ground >>> blocks and 32 fuses worth of blocks. I'd pay the $20 just for that. Any way >>> we can make this work out? >>> >>> On Tue, Jan 5, 2021 at 1:49 PM Paul Eckenroth >>> wrote: >>> >>>> Bob and Charlie >>>> >>>> That's a lot of fuse blocks. I am in need of a 10 fuse block. Do you >>>> want to split the sale. >>>> >>>> Thanks >>>> Paul >>>> >>>> On Tue, Jan 5, 2021 at 2:15 PM Charlie England >>>> wrote: >>>> >>>>> On 1/5/2021 12:42 PM, Robert L. Nuckolls, III wrote: >>>>> >>>>> I have a lot of 5 fuse blocks and 3 ground >>>>> busses that are surplus to my needs. Want >>>>> to turn them back to 'the wild' where >>>>> there's a better chance of being used. >>>>> >>>>> I'd like to get $20 for the lot which >>>>> includes priority mail to any US >>>>> address. >>>>> >>>>> Bob . . . >>>>> >>>>> Un impeachable logic: George Carlin asked, "If black boxes >>>>> survive crashes, why don't they make the whole airplane >>>>> out of that stuff?" >>>>> >>>>> Hi Bob, >>>>> I'll certainly take the lot. But happy to stand aside if someone else >>>>> has an immediate need for it. >>>>> >>>>> How would you prefer payment? >>>>> >>>>> Thanks, >>>>> >>>>> Charlie >>>>> >>>>> >>>>> Virus-free. >>>>> www.avast.com >>>>> >>>>> <#m_2552288989016189718_m_7168316372381935183_m_4003248747224172824_m_-4915725974748346567_m_4119643337842739199_m_1162196725734180277_m_6240126768322279902_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> >>>>> >>>> >>> ________________________________________________________________________________
Date: Jan 06, 2021
Bob If you want to handle splitting the shipment, I'll take one of the 10 fuse blocks. Please advise what cost you desire. You can send the information privately to Paul(at)eckenroth.com. If it is all too much hassle for you , that's no problem. I'm good either way. Thanks Paul On Wed, Jan 6, 2021 at 12:29 PM Sebastien wrote: > Ok. Bob could you please charge me $20 + shipping to Canada and send me > whatever is leftover after Paul takes what he needs. > > On Wed, Jan 6, 2021 at 9:07 AM Charlie England > wrote: > >> Since the two of you have immediate needs, I'd suggest you work it out >> between you, and one of you do the purchase from Bob. If you both back out >> Bob can contact me directly for payment/shipping info exchange. >> >> Charlie >> >> On Tue, Jan 5, 2021 at 5:40 PM Sebastien wrote: >> >>> How about this. I'll pay the $20 + shipping to Bob and he ships the >>> whole thing to Charlie. Paul pays Charlie for shipping and Charlie ships >>> him the power block he needs. Charlie takes what he wants and ships the >>> rest to me in Canada at his expense. >>> >>> Does that work? >>> >>> On Tue, Jan 5, 2021 at 3:19 PM Charlie England >>> wrote: >>> >>>> My primary interest was in a ground block or two; the rest would just >>>> go into my 'stash'. If you & Paul can work it out & make it easy on Bob, >>>> I'll step aside. Y'all need to know that it's a smokin' good deal; just the >>>> large fuse block is worth more than Bob's asking for the whole batch with >>>> free shipping. >>>> >>>> Charlie >>>> >>>> On 1/5/2021 4:01 PM, Sebastien wrote: >>>> >>>> I'd love to take the lot but currently I'm only in need of a 2 ground >>>> blocks and 32 fuses worth of blocks. I'd pay the $20 just for that. Any way >>>> we can make this work out? >>>> >>>> On Tue, Jan 5, 2021 at 1:49 PM Paul Eckenroth >>>> wrote: >>>> >>>>> Bob and Charlie >>>>> >>>>> That's a lot of fuse blocks. I am in need of a 10 fuse block. Do you >>>>> want to split the sale. >>>>> >>>>> Thanks >>>>> Paul >>>>> >>>>> On Tue, Jan 5, 2021 at 2:15 PM Charlie England >>>>> wrote: >>>>> >>>>>> On 1/5/2021 12:42 PM, Robert L. Nuckolls, III wrote: >>>>>> >>>>>> I have a lot of 5 fuse blocks and 3 ground >>>>>> busses that are surplus to my needs. Want >>>>>> to turn them back to 'the wild' where >>>>>> there's a better chance of being used. >>>>>> >>>>>> I'd like to get $20 for the lot which >>>>>> includes priority mail to any US >>>>>> address. >>>>>> >>>>>> Bob . . . >>>>>> >>>>>> Un impeachable logic: George Carlin asked, "If black boxes >>>>>> survive crashes, why don't they make the whole airplane >>>>>> out of that stuff?" >>>>>> >>>>>> Hi Bob, >>>>>> I'll certainly take the lot. But happy to stand aside if someone else >>>>>> has an immediate need for it. >>>>>> >>>>>> How would you prefer payment? >>>>>> >>>>>> Thanks, >>>>>> >>>>>> Charlie >>>>>> >>>>>> >>>>>> Virus-free. >>>>>> www.avast.com >>>>>> >>>>>> <#m_-4044729938871906126_m_2552288989016189718_m_7168316372381935183_m_4003248747224172824_m_-4915725974748346567_m_4119643337842739199_m_1162196725734180277_m_6240126768322279902_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> >>>>>> >>>>> >>>> ________________________________________________________________________________
Date: Jan 07, 2021
contacts Thanks to all who responded, advice from this list is invaluable. Even if soldering skills are good, crimping seems the better choice in the case of high density, especially for the inner rows and aging eyes R ----- Original Message ----- From: Charlie England <ceengland7(at)gmail.com> Subject: Re: AeroElectric-List: D-Sub High Density 78 female - solfder or c rimp contacts If you're having trouble crimping subD pins, you likely have the wrong tool s for the task. I've been soldering for over 50 years (a lot of them profes sionally), and crimping is still easier/faster (though more expensive) than soldering for me. Harder for me is accurately stripping the wire to prep f or the crimp. A decent quality stripping tool with dies sized for each gaug e wire (I like this style) seems essential, and a good eye for strip length helps (to ensure full depth of bare wire into the terminal, without leavin g excess bare wire exposed). I've never had good luck with the 'automatic' strippers, but I've never invested in a new, really high quality version. T he crimp itself is 'automatic'; as long as the terminal is the proper depth into the crimper, the tool forces you to make a full crimp before releasin g. BTW, you really don't need to spend $hundreds on a production crimper fo r one project. Stein and others sell this tool which many of us have used t o wire entire a/c. Since you're using HD pins, you might want the optional HD positioner, though I've had good success manually positioning the pin wh en I've only needed to do a couple at a time. I'll bet you will have much more trouble depinning the old shell (you need this tool) than crimping the new pins. Charlie On Tue, Jan 5, 2021 at 7:28 AM rd2 wrote: Excellent advice, as usual, thanks Stein. Crimped it'll be. The problem was my soldering skills are much better than my crimping skills (almost none). Thanks for bringing up the questions, Bob: --snip-- Do you already have the connector to which you want add wires? How many wires total in your task? ---snip--- I already have the female connector - it is populated from another applicat ion. I assume that I can reuse it - just need to remove the populated conta ct sockets, crimp the new ones and repopulate. I don't now the exact number of wires yet, I expect most (or more than 1/2) of the positions to be used. I will visit Stein's web site to order sockets and tools, but first I need to find some mp4 on youtube that will guide me through the process instead of asking questions. Thanks again. Rumen ----- Original Message ----- From: SteinB <stein(at)steinair.com> Subject: RE: AeroElectric-List: D-Sub High Density 78 female - solfder or c rimp contacts We generally try to avoid solder cup connectors on aircraft because typical ly the average builder doesn=99t have a good high temp yet small iron able to successfully use the solder cups (wires often end up cold soldered and fall off in with future vibration), or they end up wicking tons of sol der up into the wire that inevitably leads to wire breakage. On top of that , in a 78 pin arrangement the solder cups would be incredibly densely packe d, and it=99s likely the end result would not be pretty. It also take s longer than simply crimping on a pin and inserting it into a connector. A lso, if you need to =9Cmove=9D a wire in the middle of that lar ge 78 pin connector, it=99s pretty easy to do with crimp pins, not so much with solder cups. Lastly, the 78 pin crimp connectors aren=99t that terribly expensive (we stock and sell them for about $17 each), standa rd crimp tooling works well. Just my 2 cents as usual! Cheers,Stein From:o wner-aeroelectric-list-server(at)matronics.com @matronics.com> On Behalf Of rd2 Sent: Monday, January 4, 2021 3:38 PM To:aeroelectric-list(at)matronics.com Subject: AeroElectric-List: D-Sub High Density 78 female - solfder or crimp contacts Hi Group.What type contacts would you recommend for a 78 female c onnector - solder or crimp, and why?It seems that solder type are easier to find and less expensive. The connector will be used for a relays box to se lect VHF nav signals to an HSI.Rumen.... ________________________________________________________________________________
Date: Jan 07, 2021
At 03:04 PM 1/6/2021, you wrote: >Bob > >If you want to handle splitting the shipment, >I'll take one of the 10 fuse blocks.=C2 Please >advise what cost you desire.=C2 You can send the >information privately=C2 to >Paul(at)eckenroth.com.=C2 >If it is all too much hassle=C2 for you , that's >no problem.=C2 I'm good either way.=C2 Thanks I'm sorta in a housecleaning mode and had a choice to pitch 'em or get them into hands that have more time and will to distribute. John is the da man! Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jan 07, 2021
Subject: Re: Monarch EE Anti-Plugging Field Accelerating?
At 09:00 PM 1/5/2021, you wrote: > >Hi Bob Perhaps you can enlighten me a little more how Monarch >controls speed on my EE with their hocus pocus. Here's a link to the >only schematic I have: >https://1drv.ms/b/s!Ah1S270Nwg9V4St1iHBVNSihPNyL?e=Y3H4UJ >The huge Ohmite-A-1925 Rheostat (size of a volley ball) controls the >field for the motor and generator at the same time. Why not just >control the generator field? >At the top of the schematic there is Field Accelerating using a CXG >2105-B and Anti-Plugging using a SD4-2-S-14. What is Field >Accelerating? What is Anti-Plugging? I'm taking a guess based on what I know about motor characteristics. Motor speeds in this machine are adjusted based on field excitation of the parallel wound motors. The stronger the field, the slower the motor. This is kinda cool because the field excitation control has no effect on armature supply current/volage, hence a minimal effect on available torque at the selected speed. "Plugging" is a motor stopping technique that calls for reversing power to the armature for milliseconds after initiating the stop command. It's easy to see that the initial current flow is quite high . . . higher than inrush. Further, timing is very important. If the 'plugging' interval is too long, the motor comes to a stop before REVERSING until the plugging configuration is discontinued. I suspect that in this case, anti-plugging \ features are added so that should the lathe operator quickly switch from FWD to REV rotation (a clasic plugging situation), the opposite polarity of motor drive current is delayed until after normal dynamic breaking has completed. This is just a guess. Wiring diagrams for this machine are not exactly lucid illustrations of functionality. While no doubt accurate, they are not exactly great teaching tools! This is a common condition across a spectrum of suppliers of electrically driven systems from lawn mowers to . . . well . . . really nice old lathes! Are the speed control rheostats on a common shaft? Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jan 07, 2021
Subject: Where to put the Cross-Feed Contactor?
I have A-14 with rear batteries. Finishing the wiring right now. My thought was that the cross-feed contactor would go on the inside of the firewall so that only one fat wire has to go through (I have the brass ground block that bolts through the firewall, and of course, there are a bunch of smaller wires that go through, probes and such and wires from the alternator controllers, which are on the engine side). The person helping me thinks it would be better to locate the cross feed contactor on the engine side because maintenance is easier. But if it is on the engine side, more fat wires go through the firewall. Does anyone have an opinion on this? I understand it is a pain to crawl under the panel and get at the firewall. On the other hand, it seems to me there is a benefit to minimizing the number of fat wires through the firewall. ________________________________________________________________________________
Subject: Re: Where to put the Cross-Feed Contactor?
Date: Jan 07, 2021
Mine sits beside the batteries and batteryr contactor. Maintenance is largely a non issue. It is in a relatively benign area. It conducts significant current during cranking but doesn't actually switch high current like a starter contactor. Ken On 07/01/2021 3:39 PM, Dan wrote: > I have A-14 with rear batteries. Finishing the wiring right now. My > thought was that the cross-feed contactor would go on the inside of > the firewall so that only one fat wire has to go through (I have the > brass ground block that bolts through the firewall, and of course, > there are a bunch of smaller wires that go through, probes and such > and wires from the alternator controllers, which are on the engine > side). The person helping me thinks it would be better to locate the > cross feed contactor on the engine side because maintenance is > easier. But if it is on the engine side, more fat wires go through > the firewall. > > Does anyone have an opinion on this? I understand it is a pain to > crawl under the panel and get at the firewall. On the other hand, it > seems to me there is a benefit to minimizing the number of fat wires > through the firewall. ________________________________________________________________________________
Date: Jan 07, 2021
Hi Bob Yes the speed control rheostats are on a common shaft. I found this link: https://www.practicalmachinist.com/vb/monarch-lathes/field-acceleration-relay-226109/ I believe it's Field Accelerating that is the hocus pocus I never fully understood too much that I believe helps increase torque? I read the post in practical machinist several times, still don't fully understanding it. If the chat and Motor-Generator and Control System Design Schematic help you understand what's going on, an interpretation would be appreciated. What is Base Speed? Thx. Ron P. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=500076#500076 ________________________________________________________________________________
Subject: Revmaster R2300 PMA
Date: Jan 07, 2021
Hello all, This is a revisiting of the dual integrated PMA that Revmaster (VW derivative) implements on their latest engine design. There's a lot here so my apologies in advance. Attached is a scematic of how I've implemented control using a variation of the Z drawings. I've included the current front page with shows the full control scheme with the alternator and a second drawing that I simply redrew to show only the charging circuit. I've done enough checking to convince myself that the regulator / rectifier (R/R) is depicted in a way that at least "losely" shows it's function. Specifically, it is a half wave rectifier with a control circuit controlling an SCR. This SCR opens the path to ground for the alternator to limit charging. The circuit is actually pretty sophisticated in that it will not "turn on" the SCR unless it first senses a battery is present in the circuit. US patent 4,220,909 describes in more detail the safe guards of the circuit that go beyond insuring a battery connection. My goal with this post is to solicit comments on a failure mode that a few of these engines have had, particularly over the last few years. One strong suggestion the engine supplier has made is to avoid running both stators at the same time AND avoid using the AGM style batteries. My initiial goal was to find evidence (for or against) use of the AGM (Odessey PC680). The third drawing is the setup I assembled to test the rectifying circuit, independent of the Revmaster alternator. This uses a small 3 phase motor I had along with a 120, single phase input, 3 phase output VFD to drive the motor - coupled to a John Deere, 20 amp 6 pole alternator (very close in performance and characteristics to 1/2 the Revmaster). I plan on expanding testing to verify open circuit and short circuit performance of the full Remaster alternator and RR (in my engine) once I am comfortable withk the design and have enough data to support the use (or not) of an AGM battery. Sorry for this being so long, almost done setting up the question... The next two plots are of a couple of the many scope traces I have of the alternator /RR test assembly. The slow speed run up at 30 hz / 875 rpm shows the RR not "turning on" and basically an open circuit voltage measurement of the low rpm alternator with a well charged battery. The 42 hz (1200 rpm) shows the charging circuit just beginning to inject current to the battery at a voltage of 13.52 volts (not this is on the negative trace of the sine wave due to my scope orientation in the charging circuit but it was a positive voltage to the battery. A few notes. The trace is using a 10x probe. The blue trace is the current measured across the 100 mv @ 30 amp shunt. The values on the horizontal lines on the scope trace are on the bottom right of the printout. The John Deere alternator runups were done using a large, wet, lead acid battery (donated by my '64 Pontiac that's resting for the winter). The regulator will not activate without a working battery attached. More on that if anyone is interested. Finally, the last photo is of one of the stators on the Revmaster engine AFTER it failed. I'm told by the pilot (Glen Bradley) that his two stator failures occurred in flight under higher rpms and after the battery (the Odessey AGM) was worked over during a hard start. HERE IS MY Thesis: I suspect that the stators are experiencing "turn to turn short circuits." This fault mode was suggested to me by another engineer where I work (experienced in these failures) and in his words, "a short between two adjacent wires in the stator is common and one of the most rapid ways a stator will self destruct." (as opposed to a phase to ground fault on a stator) After a bit of reading I've come up with what I think are justifying equations that would predict the result of shorting a single loop of the stator wire. A single loop of wire on a permanent magnet alternator experiences a circulating current that is at least an order of magentude greater than the complete coil. This rotating conductor (attached to the upstream and down stream stator wiring at a single point) quickly overheats and initiates a cascading failure of adjacent insulation. If you look at the photo of the burned stator, the 12 O'clock and 6 )'clock coils are stand a lone stators for the redundent CDI ignition. The right five from 1 O'clock to 5 O'clock make up the right stator for the PMA. The left five from 7 to 11 O'clock are the other PMA stator, making up the dual alternator. I find it more than interesting that only one of the coils making up the left stator is burned while the other 4 appear perfect. Also, the CDI ignition coil failed as well and of course, it is in no way connected to the AGM battery. I'll stop there and wait for comment -------- Scratch building Sonex #1362 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=500077#500077 Attachments: http://forums.matronics.com//files/cx5_r2300_stator_failure_211.jpg http://forums.matronics.com//files/42_hz_1200_rpm_113.pdf http://forums.matronics.com//files/30_hz_875_rpm_no_charging_394.pdf http://forums.matronics.com//files/revmaster_r2300_electrical_test_163.pdf http://forums.matronics.com//files/revmaster_2300_alternator_ckt_214.pdf http://forums.matronics.com//files/z16m_revmaster_2300_r13_pg1_183.pdf ________________________________________________________________________________
Date: Jan 07, 2021
>The person helping me thinks it would be better to locate the cross >feed contactor on the engine side because maintenance is easier. The cross-feed contactor becomes the forward power distribution point for energy from the two systems. Having it on the cabin side probably simplifies wiring to the busses and reduces volume of wire through the firewall. This contactor has a VERY low operating stress profile. Maintenance should be the lowest of all the contactors. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Subject: Re: Revmaster R2300 PMA
Date: Jan 08, 2021
As I re-read my post from last night I realized it was too long and missing some key information. Not to mention a few errors in the text. There are two issues here. My intent to show the difference in performance of a wet lead acid battery charge vs an AGM. The second is to try and expose the failure mode of the Revmaster alternator. First, some clarity. The scope trace was my first step to compare a lead acid battery to an AGM. I'll repeat the scope trace and post this weekend the "loaded" lead acid battery charge curve with a loaded AGM charge curve, using the JD alternator and RR previously shown. Attached is the summary of the Kv curve and charging with the (pretty much) fully charged wet cell battery. Note tha the currents are "Peak" and not RMS. the half wave rectified amperage curve peak values are dramatically larger than the RMS values. I will include RMS calculations (that my scope can do) with the loaded charge system curves I'll publish this weekend. A few errors and ommissions I need to correct. Only the red scope trace from my previous post (channel B) was a 10x probe. With regard to the image of the burned stator: > I find it more than interesting that only one of the coils making up the left stator is burned while the other 4 appear perfect. This should have read "right stator" not left. Hope this helps a bit. Dan Theis -------- Scratch building Sonex #1362 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=500080#500080 Attachments: http://forums.matronics.com//files/jd_am877577_peak_charge_amps_with_unloaded_wet_cell_542.pdf http://forums.matronics.com//files/jd_am877577_ocv_664.pdf ________________________________________________________________________________
Date: Jan 08, 2021
On 1/8/2021 9:35 AM, dj_theis wrote: > > As I re-read my post from last night I realized it was too long and missing some key information. Not to mention a few errors in the text. > > There are two issues here. My intent to show the difference in performance of a wet lead acid battery charge vs an AGM. The second is to try and expose the failure mode of the Revmaster alternator. > > First, some clarity. The scope trace was my first step to compare a lead acid battery to an AGM. I'll repeat the scope trace and post this weekend the "loaded" lead acid battery charge curve with a loaded AGM charge curve, using the JD alternator and RR previously shown. Attached is the summary of the Kv curve and charging with the (pretty much) fully charged wet cell battery. Note tha the currents are "Peak" and not RMS. the half wave rectified amperage curve peak values are dramatically larger than the RMS values. I will include RMS calculations (that my scope can do) with the loaded charge system curves I'll publish this weekend. > > A few errors and ommissions I need to correct. > > Only the red scope trace from my previous post (channel B) was a 10x probe. > > > With regard to the image of the burned stator: > > >> I find it more than interesting that only one of the coils making up the left stator is burned while the other 4 appear perfect. > > This should have read "right stator" not left. > > Hope this helps a bit. > > Dan Theis Hi Dan, I read through the earlier post & looked at the images, though I didn't download the pdf files. I'm certainly no expert, but my thought is that what your friend said about internal shorting of the coil would be the most likely failure mode. Heat within a coil would eventually cause insulation to fail, and once an internal short occurs, there'd be an avalanche of heat due to the lowered resistance in the shorter path through the coil. It seems to me that all the analysis in the world won't help solve the problem if you can't do anything about the stator itself. Has anyone done data logging on one of the failed stators prior to, and during, a real-world in-use failure? Was it asked to deliver more current than the rated current? Did the associated rectifier/regulator fail at the same time, or did it survive, and continue to work correctly? If the rectifier/regulators aren't failing, then you're left with either an overload (this is what the mfgr is hinting at with the SLA prohibition), or a rating number that isn't realistic for the stator's environment (bolted directly to a hot engine block with near-zero airflow). The brute force cure for stator survival would be to limit output current with a *current* regulator, set to limit current below the stator's *real world* capabilities, in its real world environment. The prohibition on SLA batteries won't solve anything, in and of itself, because a larger 'wet cell' battery (to achieve the same CCA) could easily have the same internal resistance as the previous SLA. All they're really saying is to limit the load current, but they're apparently unwilling or unable to give a real world number on the alternator's current capability, in its environment. FWIW, Charlie -- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jan 08, 2021
That Field Acceleration relay is interesting. Based on its name I assume the relay picks during acceleration. Its contact shunts the motor field resistance, increasing motor torque. The coil has two windings, with the shunt winding across the fixed exciter voltage and the series winding in the loop circuit. Looking at the diagram the windings appear to be connected differentially so the higher starting current picks the relay, once the motor is up to speed the loop current falls and the differentially connected shunt coil neutralizes the series coil, dropping the relay. The speed regulation here is not magic. In a DC shunt motor; armature voltage is proportional to speed. armature current is proportional to load. as you weaken the motor field, armature current will rise and RPM will increase. In a ward Leonard system the motor and generator armatures are in a loop, the generator will output voltage to the motor. The generator voltage is proportional to the generator field current. The field current has two components the shunt field and the series field. The shunt field is set by the operator with the rheostat. The series field has the current of the motor load. As the motor load increases loop current rises, generator field strength increases and the generator output voltage will rise. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=500082#500082 ________________________________________________________________________________
Date: Jan 08, 2021
Thanks Charlie, > It seems to me that all the analysis in the world won't help solve the > problem if you can't do anything about the stator itself. Has anyone > done data logging on one of the failed stators prior to, and during, a > real-world in-use failure? Was it asked to deliver more current than the > rated current? Did the associated rectifier/regulator fail at the same > time, or did it survive, and continue to work correctly? Fully agree. I am working on investigating alternatives (if the failure is primarily due to insufficient vacuum impregnation of the coils). I will be continuing to collect data on my engine before I run it and plan on continued data collection during operation, should if fail. I do not believe the associated RR failed during the event that led to the burned coil. Also, I don't believe the 30 amp fuses failed either. This is one of the reasons I was looking (and found) the explanation for the inter coil short phenomenon. In all failures, heat will contribute to the problem and I think there is a sever lack of cooling of the stator. Something else I want to instrument and test with my engine. Dan Theis -------- Scratch building Sonex #1362 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=500083#500083 ________________________________________________________________________________
Date: Jan 08, 2021
At 08:22 PM 1/7/2021, you wrote: > >Hi Bob >Yes the speed control rheostats are on a common shaft. >I found this link: >https://www.practicalmachinist.com/vb/monarch-lathes/field-acceleration-relay-226109/ > >I believe it's Field Accelerating that is the hocus pocus I never >fully understood too much that I believe helps increase torque? "acceleration" implies that this is a dynamic thing in effect only during changes of velocity . . . either increasing or decreasing. In this case, it's probably only a feature of start-up acceleration is proportional to rotational mass * torque. Torque: T = k*Ia*Bf proportional to armature current * field flux. Torque is proportional to field flux x armature current . . . period. From published schematics, we see no provisions for controlling armature excitation . . . all speed control magic happens with field excitation. So to speed up the acceleration of this machine's rotating mass, I'm suspecting that there's s system in place to apply full field current during the first tens of milliseconds after turn-on. Take a peek at the attached exemplar DC motor curve. Note that for a FIXED applied armature voltage, motor performance is plotted by a straight line running from max rpm at zero load to max torque at zero rpm. This load line has SLOPE that is defined by LOOP RESISTANCE. Add up all the resistance for power supply source impedance, wires, brushes and armature to get total loop resistance. Divide that value into source voltage and you get a value of absolute maximum current which occurs at zero rpm (stall current) which is also your start-up, inrush current. Note that at zero rpm, max torque and stall the available voltage is not changed. There is a FAMILY of lines, parallel to the blue line that represent a range of applied voltage. The slope is constant as long as loop resistance is constant. Note the yellow plot showing an increase in max rpm at zero load; drop in torque (and stall current) at zero rpm. This illustrates a 'hot' motor condition due to increased resistance of the armature windings due to temperature. Let's consider another characteristic: k RPM ~ ------------ Bf Speed is roughly inversely proportional to field flux. So, if you want to get things moving right smartly, you apply both full field and uncontrolled full armature current. This will get you a speedy spin-up to MINIMUM speed but at maximum torque. You can then reduce field flux to bring the motor up to operating speed at reduced torque. This second characteristic offered a clever means for controlling the speed of some pretty beefy motors by fiddling with the relatively minor field current(s). >What is Base Speed? That's a local vernacular probably unique to the industry. We do know that at MAX available voltage you get minimum operating speed at maximum available torque . . . that might well be the 'base speed'. I have a lot of respect for the folks who designed these machines. With no assist from electronics or software, they squeezed an amazing amount of functionality with 1930's technology. Examples of similar intellectual agility include these DC generator regulators http://aeroelectric.com/Pictures/Regulators/Carbon_Pile_1a.jpg http://aeroelectric.com/Pictures/Regulators/12VN7E_Delco-Remy_3.jpg Then there's the second picture attached . . . this piece of equipment is the size of a big loaf of bread. It contains no electronics. Just copper, Bakelite and steel. It contains 1 bit comparators, analog-digital converters, etc. etc. It's one of several controllers used to manage a 1930's steam driven megawatt power plant. The thought processes and talents that brought your lathe into a practical reality are in the same class. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jan 08, 2021
> >The brute force cure for stator survival would be to limit output >current with a *current* regulator, set to limit current below the >stator's *real world* capabilities, in its real world environment. >The prohibition on SLA batteries won't solve anything, in and of >itself, because a larger 'wet cell' battery (to achieve the same >CCA) could easily have the same internal resistance as the previous >SLA. All they're really saying is to limit the load current, but >they're apparently unwilling or unable to give a real world number >on the alternator's current capability, in its environment. Agreed. I've been pondering this thread periodically for months. A possible contributor to 'single coil' failures is the rather large positive temperature coefficient of copper resistance. Some months back we discussed the propensity for a free-air span of copper wire to always burn in two at or near center of the span . . . and considered the effects of tempco on the physics of the melt. Once a single coil temperature rises above that of its brothers, electrical energy dissipation within that coil will climb above the rest with a positive feedback. It would be REALLY interesting/useful to mock up this stator/rotor assembly on a vari-drive to get some data. I'm not at all comfortable with the notion of running ONE HALF of a system with demonstrated vulnerabilities while keeping an equally inadequate half in reserve. I'm thinking elegant solution might be to run BOTH coils in a full-wave center tapped supply configuration to a switchmode power supply fitted with accurate/stable voltage regulation and calibrated current limiting. Instead of walking a tight-rope of high probability failure modes, designing a system that strives for predictable stress limiting seems more in order. Generators did it, alternators do it, why not a PM alternator? Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Subject: RV10 Electrical System Safety
Date: Jan 08, 2021
=EF=BBHey guys I am way in over my head on this forum but a nice man from BandC suggested I try. Attached is the electrical diagram of my recently p urchased RV10. It was completed in 2009 and the avionics was switched to a G armin 900x a year later. My issue is it safe and operationally sound. It is an =9C###=9DX=9D design; if that is familiar. Apparently the builder added a =9Cbus tie=9D in order to bypass a diode (bridge rectifier type) because the draw to recharge the =9CAux Battery=9D (2 wheel chair batteries 7Ah 12v wired in series) reduced t he essential bus voltage to 12.6v. This =9Cbus tie=9D when on bo osts both busses back to 13.6v. Is this how it was meant to be run? Additionally with both alternators on, the displayed =9Calternator amp erage=9D seems to be all over the scale; sometimes 45-50 amps when the airplane has most accessories off. Feeding both alternators into a single =9Cbus bar=9D seems to cause issues and is that safe? Therefore it=99s been recommended that I swap out the Stby Alt for a 6 0A PP alternator and just use it as the primary power source. My preference would be going to a =9CxxxZ=9D plan where each alternator power s its own bus but I=99ve been advised against that. (The good news is m y A&P figured out the shunt had not been changed per Garmin install instruct ional, a 100A 50 milivolts currently on order.) Sorry for the length of this. William Booth ________________________________________________________________________________
Subject: RV10 Electrical System Safety & Operational Issues
Date: Jan 08, 2021
=EF=BB =EF=BB Hey guys I am way in over my head on this forum but a nice man fro m BandC suggested I try. Attached is the electrical diagram of my recently p urchased RV10. It was completed in 2009 and the avionics was switched to a G armin 900x a year later. My issue is it safe and operationally sound. It is an =9C###=9DX=9D design, if that is familiar. Apparently the builder added a =9Cbus tie=9D in order to bypass a diode (bridge rectifier type) because the draw to recharge the =9CAux Battery=9D (2 wheel chair batteries 7Ah 12v wired in series) reduced t he essential bus voltage to 12.6v. This =9Cbus tie=9D when on,bo osts both busses back to 13.6v. Is this how it was meant to be run? Additionally with both alternators on, the displayed =9Calternator amp erage=9D seems to be all over the scale; sometimes 45-50 amps when the airplane has most accessories off. Feeding both alternators into a single =9Cbus bar=9D seems to cause issues and is that safe? Therefore it=99s been recommended that I swap out the Stby Alt for a 6 0A PP alternator and just use it as the primary power source. My preference would be going to a =9CxxxZ=9D plan where each alternator power s its own bus but I=99ve been advised against that. (The good news is m y A&P figured out the shunt had not been changed per Garmin install instruct ional, a 100A 50 milivolts currently on order.) Sorry for the length of this. William Booth Sent from my iPad ________________________________________________________________________________
Date: Jan 08, 2021
Subject: RV10 Electrical Issues
Hey guys I am way in over my head on this forum but a nice man from BandC su ggested I try. Attached is the electrical diagram of my recently purchased R V10. It was completed in 2009 and the avionics was switched to a Garmin 900x a year later. My issue is it safe and operationally sound. It is an =9C###=9DX=9D design, if that is familiar. Apparently the builder added a =9Cbus tie=9D in order to bypass a diode (bridge rectifier type) because the draw to recharge the =9CAux Battery=9D (2 wheel chair batteries 7Ah 12v wired in series) reduced t he essential bus voltage to 12.6v. This =9Cbus tie=9D when on,bo osts both busses back to 13.6v. Is this how it was meant to be run? Additionally with both alternators on, the displayed =9Calternator amp erage=9D seems to be all over the scale; sometimes 45-50 amps when the airplane has most accessories off. Feeding both alternators into a single =9Cbus bar=9D seems to cause issues and is that safe? Therefore it=99s been recommended that I swap out the Stby Alt for a 6 0A PP alternator and just use it as the primary power source. My preference would be going to a =9CxxxZ=9D plan where each alternator power s its own bus but I=99ve been advised against that. (The good news is m y A&P figured out the shunt had not been changed per Garmin install instruct ional, a 100A 50 milivolts currently on order.) Sorry for the length of this. I=99ve sent other versions of this tryin g to get the photo the right size. William Booth Sent from my iPad ________________________________________________________________________________
Date: Jan 09, 2021
Subject: RV10 Electrical Issue (w/ Format Clean Up)
Hey guys I am way in over my head on this forum but a nice man from BandC su ggested I try. Attached is the electrical diagram of my recently purchased R V10. It was completed in 2009 and the avionics was switched to a Garmin 900x a year later. My issue is it safe and operationally sound. It is an X desi gn, if that is familiar. Apparently the builder added a bus tie in order to bypass a diode bridge rec tifier type because the draw to recharge the Aux Battery, 2 wheel chair batt eries 7Ah 12v wired in series reduced the essential bus voltage to 12.6v. Th is bus tie when on,boosts both busses back to 13.6v. Is this how it was mean t to be run? Additionally with both alternators on, the displayed alternator amperage see ms to be all over the scale; sometimes 45-50 amps when the airplane has most accessories off. Feeding both alternators into a single =9Cbus bar =9D seems to cause issues and is that safe? Therefore it=99s been recommended that I swap out the Stby Alt for a 6 0A PP alternator and just use it as the primary power source. My preference would be going to a Z plan where each alternator powers its own bus but I =99ve been advised against that. The good news is my A&P figured out the s hunt had not been changed per Garmin install instructions, a 100A 50 milivol ts currently on order. Sorry for the length of this & the formatting issues. ________________________________________________________________________________
Subject: RP3 Indicator
Date: Jan 09, 2021
Looking to buy leftover RP3 indicators. The new RP4 has a different installation method that I'm not ready for yet as I have a bunch of them in use. If you have any in your leftover bins - let me know what you want for them ________________________________________________________________________________
Subject: Re: RP3 Indicator
Date: Jan 09, 2021
On 1/9/2021 8:46 AM, recapen(at)earthlink.net wrote: > > Looking to buy leftover RP3 indicators. > > The new RP4 has a different installation method that Im not ready for > yet as I have a bunch of them in use. > > If you have any in your leftover bins let me know what you want for them > 'Center of the Universe Principle'?? -- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jan 09, 2021
Subject: Battery Charger
Old battery charger stopped working. What is the current recommendation for a charger and battery minder? Pete Hudes ________________________________________________________________________________
Subject: Re: Battery Charger
Date: Jan 10, 2021
Ive had good luck with Schumacher . A little more expensive than what can be bought at HF but Ive had good performance for planes boats and autos. https://www.amazon.com/Battery-Chargers-Schumacher/s?keywords=Battery+Chargers&rh=n%3A15707061%2Cp_89%3ASchumacher&c=ts&ts_id=15707061 The brand, battery tender comes to mind and I might actually have a small one of those around that seems to behave well. I look for a switch on the charger to allow for selection-between AGM and wet lead acid. I think Bob ran some tests on lessor brands with good results And he has a great explanation in his book on chargers that hes expanded on in this forum, if you do a search. Dan Theis. -------- Scratch building Sonex #1362 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=500104#500104 ________________________________________________________________________________
Date: Jan 10, 2021
At 01:37 AM 1/10/2021, you wrote: > >Old battery charger stopped working. What is the current >recommendation for a charger and battery minder? How big a charger? My local Walmart stocks a range of Schumacher chargers as well as the now legendary Battery Tender Jr. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jan 10, 2021
Subject: Re: RV10 Electrical Issue (w/ Format Clean Up)
At 06:54 AM 1/9/2021, you wrote: >Hey guys I am way in over my head on this forum >but a nice man from BandC suggested I >try. Attached is the electrical diagram of my >recently purchased RV10. It was completed in >2009 and the avionics was switched to a Garmin >900x a year later. My issue is it safe and >operationally sound. It is an X design, if that is familiar. That's a REALLY busy electrical system . . . >Apparently the builder added a bus tie in order >to bypass a diode bridge rectifier type because >the draw to recharge the Aux Battery, 2 wheel >chair batteries 7Ah 12v wired in series reduced >the essential bus voltage to 12.6v. This bus tie >when on,boosts both busses back to 13.6v. Is this how it was meant to be run? The thought processes behind this architecture cannot be know to us unless it's documented somewhere. The system depicted has features that are >Additionally with both alternators on, the >displayed alternator amperage seems to be all >over the scale; sometimes 45-50 amps when the >airplane has most accessories off. Feeding both >alternators into a single =9Cbus bar=9D seems to cause issues and is that safe? Why run both at the same time? >Therefore it's been recommended that I swap out >the Stby Alt for a 60A PP alternator and just >use it as the primary power source. My >preference would be going to a Z plan where each >alternator powers its own bus but I've been >advised against that. The good news is my A&P >figured out the shunt had not been changed per >Garmin install instructions, a >100A 50 milivolts currently on order. Aside from the things you've described here has this system been flying 'successfully' since 2009? Unless the seller offered the equivalent of a pilots operating handbook for the system, you're kinda stuck with second guessing the builder's original design goals. The builder spent a lot of time providing a good drawing of the wiring which is good. But the arrangement makes it difficult to sort out exactly how this system is supposed to function. Wiring for bridge rectifier is curious . . . it shows all four terminals tied together which negates its function as a diode array. Changing this system to conform to a Z-figure would be a BIG task. What are your plans/expectations for getting the airplane flyable? Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jan 10, 2021
On Sun, Jan 10, 2021 at 8:14 AM Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 06:54 AM 1/9/2021, you wrote: > > Hey guys I am way in over my head on this forum but a nice man from BandC > suggested I try. Attached is the electrical diagram of my recently > purchased RV10. It was completed in 2009 and the avionics was switched to a > Garmin 900x a year later. My issue is it safe and operationally sound. I t > is an X design, if that is familiar. > > snipped > > Additionally with both alternators on, the displayed alternator amperage > seems to be all over the scale; sometimes 45-50 amps when the airplane ha s > most accessories off. Feeding both alternators into a single =C3=A2=82 =AC=C5=93bus bar=C3=A2=82=AC > seems to cause issues and is that safe? > > > snipped > > > Bob . . . > > I couldn't see the diagram, but the 'all over the place' alternator amperage suggests issues with the shunt's wiring. My (purchased) RV6 had inline fuse holders for glass fuses to 'protect' the sense lines (protect in quotes because the fuses were somewhere near the middle of the wire runs). The flaky contact between the cheezy fuse holders and the fuses caused amperage readings to be... 'all over the place'. Just one place to look, to isolate your random current readings. Charlie ________________________________________________________________________________
Date: Jan 10, 2021
In the email I received there was no drawing attached.=C2- Could someone re-post the drawing file?=C2- Or send it to me directly. In fact, I only see Bob's & Charlie's replies, not the original post.=C2- That seems weird.... -Jeff d7(at)gmail.com> wrote: On Sun, Jan 10, 2021 at 8:14 AM Robert L. Nuckolls, III <nuckolls.bob@aeroe lectric.com> wrote: At 06:54 AM 1/9/2021, you wrote: Hey guys I am way in over myhead on this forum but a nice man from BandC su ggested I try.=C2-Attached is the electrical diagram of my recently purch ased RV10. It wascompleted in 2009 and the avionics was switched to a Garmi n 900x a yearlater.=C2- My issue is it safe and operationally sound. It i s an Xdesign, if that is familiar. snipped Additionally withboth alternators on, the displayed alternator amperage see ms to be allover the scale; sometimes 45-50 amps when the airplane has most accessories off. Feeding both alternators into a single =C3=A2=82=AC=C5 =93bus bar=C3=A2=82=AC seems to cause issues and is that safe? =C2- =C2-snipped =C2- Bob . . . I couldn't see the diagram, but the 'all over the place' alternator amperag e suggests issues with the shunt's wiring. My (purchased) RV6=C2-had inli ne fuse holders for glass fuses to 'protect' the sense lines (protect in qu otes because the fuses were somewhere near the middle of the wire runs). Th e flaky contact between the cheezy fuse holders and the fuses caused ampera ge readings to be... 'all over the place'. Just one place to look, to isola te your random current readings. Charlie ________________________________________________________________________________
Date: Jan 10, 2021
At 12:27 PM 1/10/2021, you wrote: >In the email I received there was no drawing attached. Could >someone re-post the drawing file? Or send it to me directly. > >In fact, I only see Bob's & Charlie's replies, not the original >post. That seems weird.... The drawing has been contrast adjusted and posted at http://www.aeroelectric.com/Pictures/Misc/Booth_RV10_Wiring.jpg Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jan 10, 2021
Hi Jeff, I never saw the original, either. Since it doesn't show up in the forum format either, I wonder if it went direct to Bob. However.... I get the list via individual emails, and I *frequently* see replies to posts for which I never got the original. Occasionally, I'll find the original in my gmail spam/junk folders, but often the only way I see them is to look at the forum version. I've assumed that the cause is glitches in the multi-format distribution methods required, but I've never pushed the question to Matt (list owner). Charlie On 1/10/2021 12:27 PM, Jeff Luckey wrote: > In the email I received there was no drawing attached. Could someone > re-post the drawing file? Or send it to me directly. > > In fact, I only see Bob's & Charlie's replies, not the original post. > That seems weird.... > > > -Jeff > > wrote: > > > On Sun, Jan 10, 2021 at 8:14 AM Robert L. Nuckolls, III > > > wrote: > > At 06:54 AM 1/9/2021, you wrote: >> Hey guys I am way in over my head on this forum but a nice man >> from BandC suggested I try. Attached is the electrical diagram of >> my recently purchased RV10. It was completed in 2009 and the >> avionics was switched to a Garmin 900x a year later. My issue is >> it safe and operationally sound. It is an X design, if that is >> familiar. > snipped >> Additionally with both alternators on, the displayed alternator >> amperage seems to be all over the scale; sometimes 45-50 amps >> when the airplane has most accessories off. Feeding both >> alternators into a single bus bar seems to cause issues and >> is that safe? > > snipped > > > Bob . . . > > I couldn't see the diagram, but the 'all over the place' alternator > amperage suggests issues with the shunt's wiring. My (purchased) RV6 > had inline fuse holders for glass fuses to 'protect' the sense lines > (protect in quotes because the fuses were somewhere near the middle of > the wire runs). The flaky contact between the cheezy fuse holders and > the fuses caused amperage readings to be... 'all over the place'. Just > one place to look, to isolate your random current readings. > > Charlie -- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jan 10, 2021
-----Original Message----- From: "Robert L. Nuckolls, III" Sent: Jan 10, 2021 5:38 AM Subject: Re: AeroElectric-List: Battery Charger Battery is a PC 680 in a RV9A. Pete At 01:37 AM 1/10/2021, you wrote: --> AeroElectric-List message posted by: Old battery charger stopped working. What is the current recommendation for a charger and battery minder? How big a charger? My local Walmart stocks a range of Schumacher chargers as well as the now legendary Battery Tender Jr. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jan 10, 2021
BobN - Thanks for the drawing. Charlie - I interact with the List in exactly the same way & have the same experiences you detailed.=C2- Good to know it's not just me. Does anyone know in what part of the country the original poster is located ? -Jeff d7(at)gmail.com> wrote: Hi Jeff, I never saw the original, either. Since it doesn't show up in the forum fo rmat either, I wonder if it went direct to Bob. However.... I get the list via individual emails, and I *frequently* see r eplies to posts for which I never got the original. Occasionally, I'll find the original in my gmail spam/junk folders, but often the only way I see t hem is to look at the forum version. I've assumed that the cause is glitche s in the multi-format distribution methods required, but I've never pushed the question to Matt (list owner). Charlie On 1/10/2021 12:27 PM, Jeff Luckey wrote: In the email I received there was no drawing attached.=C2- Could someone re-post the drawing file?=C2- Or send it to me directly. In fact, I only see Bob's & Charlie's replies, not the original post.=C2 - That seems weird.... -Jeff and7(at)gmail.com> wrote: On Sun, Jan 10, 2021 at 8:14 AM Robert L. Nuckolls, III <nuckolls.bob@aer oelectric.com> wrote: At 06:54 AM 1/9/2021, you wrote: Hey guys I am way in over my head on this forum but a nice man from BandC s uggested I try.=C2- Attached is the electrical diagram of my recently pur chased RV10. It was completed in 2009 and the avionics was switched to a Ga rmin 900x a year later.=C2- My issue is it safe and operationally sound. It is an X design, if that is familiar. snipped Additionally with both alternators on, the displayed alternator amperage se ems to be all over the scale; sometimes 45-50 amps when the airplane has mo st accessories off. Feeding both alternators into a single =C3=A2=82=AC =C5=93bus bar=C3=A2=82=AC seems to cause issues and is that safe? =C2- =C2-snipped =C2- Bob . . . I couldn't see the diagram, but the 'all over the place' alternator ampera ge suggests issues with the shunt's wiring. My (purchased) RV6=C2-had inl ine fuse holders for glass fuses to 'protect' the sense lines (protect in q uotes because the fuses were somewhere near the middle of the wire runs). T he flaky contact between the cheezy fuse holders and the fuses caused amper age readings to be... 'all over the place'. Just one place to look, to isol ate your random current readings. Charlie | | Virus-free. www.avast.com | ________________________________________________________________________________
Date: Jan 10, 2021
Had a little more time to review your drawing. >My issue is it safe and operationally sound. It >is an X design, if that is familiar. Not familiar with that designatoin. >Apparently the builder added a bus tie in order to bypass a diode bridge >rectifier type because the draw to recharge the Aux Battery, 2 wheel chair >batteries 7Ah 12v wired in series . . . . In series? Parallel maybe? >reduced the essential bus voltage to 12.6v. This bus tie when on,boosts >both busses back to 13.6v. Is this how it was meant to be run? The diode WILL drop the voltage by about 0.7 volts which is insignificant when only e-bus accessories are being powered. You don't want to charge a battery through this pathway. >Additionally with both alternators on, the displayed alternator >amperage seems to be all over the scale; sometimes 45-50 amps when >the airplane has most accessories off. Feeding both alternators >into a single =9Cbus bar=9D seems to cause issues and is that safe? TWO alternators don't play well running in tandem unless their regulators are specifically chosen for parallel operation. If you want to run two batteries, then consider rerouting some wiring to achieve Z14 configuration. Replace the diode bridge (which is not wired correctly in the drawing) with a cross-feed contactor. Normal Z14 ops call for both alternators to run all the time independently of each other on separate systems but with an ability to share energy between systems should one alternator fail >Therefore it=99s been recommended that I swap >out the Stby Alt for a 60A PP alternator and >just use it as the primary power source. Don't think that's necessary . . . >My preference would be going to a Z plan where each alternator powers its >own bus but I=99ve been advised against that. Can't imagine why . . . Z14 was published about 20 years ago an is flying on a lot of OBAM aircraft. If you want to keep two batteries, Z-14 is the way to go. Conversely, you could take some weight out of the airplane by dropping to one battery and picking the relevant features of Z101 which is the decades younger, recommended replacement for Z14 Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jan 10, 2021
> >Battery is a PC 680 in a RV9A. Sounds like all your needing is a Battery Tender for battery maintenance. It will recharge your PC680, albeit slowly. But how often do you need to recharge badly depleted battery? Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Subject: Two charging devices running in parallel?
Date: Jan 10, 2021
Hi Bob You wrote in a post for RV10: "TWO alternators don't play well running in tandem unless their regulators are specifically chosen for parallel operation." My specific question is about my Rotax 914. I will be using a single Earth-X 680C LiFe battery. It has an internal generator and I am using a B&C AVC1 regulator with set-point at 14.5 volts. In addition on the vacuum pad I have a B&C LR3D with set-point at 14.6 volts. The vacuum pad doesn't spin very fast and at lower RPMs the alternator doesn't put out as much as the internal generator. That said the internal generator best be kept to 12 amps or less continuous amp draw to achieve long life from it. Idea is let the alternator put out it's best and do as much work as it can as it can do so without worry of over taxing it. Then if set-point of 14.6 volts can't be maintained the generator will take over and supplement. I have a shunt to read amp output on both chargers. Would my plan satisfy "regulators specifically chosen for parallel operation." Thx. Ron P. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=500124#500124 ________________________________________________________________________________
Date: Jan 10, 2021
Hi Group Thanks to those who replied about brushes and enlightenment how a 1941 Monarch EE works. I certainly have a much better grasp on how it works. Anyway today I finished up replacing it's 10 brushes and tending to anything that needed to be done. It's working perfectly! Have owned it since mid 1970s. Here's a pic. from 2013 when it was in need of a good going over: https://1drv.ms/u/s!Ah1S270Nwg9VtFmAe2PksSsa9K14 In 2017 gave it the tending to it needed. Took several months. Here's a pic. from today: https://1drv.ms/u/s!Ah1S270Nwg9V4VH1Kt1w_kil96gs Managed to fill it with chips today and retrieve resultant aeroplane parts. Ron P. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=500125#500125 ________________________________________________________________________________
Date: Jan 10, 2021
=EF=BBThanks for your time, interest and help. My formatting is from an i Pad so.... I am located in Fredericksburg VA. The builder is getting up there in age and it was built 12 years ago but he t old me he chose this design so if there was an alternator failure it would t ransfer automatically. He added that he always thought he should remove the one way diode. The diode diagram is attached. I did remove the diode by di sconnecting it but the Stby Alternator regulator and fuse blew. I can add after 6 months of frustration I have learned a lot about my electr ical system. The shunt off of the alternators is incorrect and will be repl aced this week. The battery shunt appears to be off by a factor of 2.5. The Garmin draw with only the battery on and both PFD=99s tested at 7amps draw while the Garmin displayed 17 amps draw. This implies to me that it n eeds a 250a and 50mV shunt. I plan on contacting Garmin this week to determ ine their requirements. Regarding the two batteries; number 1 is an Odyssey 925 and number two are t he wheel chair batteries wired maybe in parallel; picture included. I am no t sure these qualify for an alternator all their own? I=99m not sure w hich way to turn. With regards to the Z101 option or the Z14 for that matter I am for what eve r works best for my current situation. I need to be able to communicate it t o my A and P. William Booth > On Jan 10, 2021, at 4:26 PM, Robert L. Nuckolls, III <nuckolls.bob@aeroele ctric.com> wrote: > =EF=BB Had a little more time to review your drawing. > >> My issue is it safe and operationally sound. It is an X design, if that i s familiar. > > Not familiar with that designatoin. > >> Apparently the builder added a bus tie in order to bypass a diode bridge >> rectifier type because the draw to recharge the Aux Battery, 2 wheel chai r >> batteries 7Ah 12v wired in series . . . . > > In series? Parallel maybe? > >> reduced the essential bus voltage to 12.6v. This bus tie when on,boosts >> both busses back to 13.6v. Is this how it was meant to be run? > > The diode WILL drop the voltage by about 0.7 volts > which is insignificant when only e-bus accessories > are being powered. You don't want to charge a battery > through this pathway. > >> Additionally with both alternators on, the displayed alternator >> amperage seems to be all over the scale; sometimes 45-50 amps when >> the airplane has most accessories off. Feeding both alternators >> into a single =9Cbus bar=9D seems to cause issues and is that safe? > > TWO alternators don't play well running > in tandem unless their regulators are > specifically chosen for parallel operation. > > If you want to run two batteries, then consider > rerouting some wiring to achieve Z14 configuration. > Replace the diode bridge (which is not wired > correctly in the drawing) with a cross-feed > contactor. > > Normal Z14 ops call for both alternators > to run all the time independently of each > other on separate systems but with an > ability to share energy between systems > should one alternator fail > > > >> Therefore it=99s been recommended that I swap out the Stby Alt for a 60A PP alternator and just use it as the primary power source. > > Don't think that's necessary . . . > >> My preference would be going to a Z plan where each alternator powers its >> own bus but I=99ve been advised against that. > > Can't imagine why . . . Z14 was published about 20 years > ago an is flying on a lot of OBAM aircraft. If you > want to keep two batteries, Z-14 is the way to go. > Conversely, you could take some weight out of the > airplane by dropping to one battery and picking > the relevant features of Z101 which is the > decades younger, recommended replacement for Z14 > > Bob . . . > > Un impeachable logic: George Carlin asked, "If black boxes > survive crashes, why don't they make the whole airplane > out of that stuff?" ________________________________________________________________________________
Date: Jan 10, 2021
For what it's worth, I have the individual emails sent to my computer email and I definitely received all four copies of the email with the attached schematic. Obviously something is different between our computers but I have no idea what it might be. I also have a weird issue with emails. Whenever I send an email like this one, the matronics server sends me a bounceback saying I cannot post because I am not a member (which is wrong as I am a member) but the email gets posted anyway. I tried contacting Matt to get it fixed to no avail, but since the email does go through I just ignore it.\ now. Jeff Luckey wrote: > BobN - Thanks for the drawing. > > Charlie - I interact with the List in exactly the same way & have the same experiences you detailed. Good to know it's not just me. > > Does anyone know in what part of the country the original poster is located? > > > -Jeff > > wrote: > > > Hi Jeff, > > I never saw the original, either. Since it doesn't show up in the forum format either, I wonder if it went direct to Bob. > > However.... I get the list via individual emails, and I *frequently* see replies to posts for which I never got the original. Occasionally, I'll find the original in my gmail spam/junk folders, but > often the only way I see them is to look at the forum version. I've assumed that the cause is glitches in the multi-format distribution methods required, but I've never pushed the question to Matt > (list owner). > > Charlie > > On 1/10/2021 12:27 PM, Jeff Luckey wrote: > In the email I received there was no drawing attached. Could someone re-post the drawing file? Or send it to me directly. > > In fact, I only see Bob's & Charlie's replies, not the original post. That seems weird.... > > > -Jeff > > > > On Sun, Jan 10, 2021 at 8:14 AM Robert L. Nuckolls, III > wrote: > > At 06:54 AM 1/9/2021, you wrote: >> Hey guys I am way in over my head on this forum but a nice man from BandC suggested I try. Attached is the electrical diagram of my recently purchased RV10. It was completed in 2009 and the >> avionics was switched to a Garmin 900x a year later. My issue is it safe and operationally sound. It is an X design, if that is familiar. > snipped >> Additionally with both alternators on, the displayed alternator amperage seems to be all over the scale; sometimes 45-50 amps when the airplane has most accessories off. Feeding both >> alternators into a single bus bar seems to cause issues and is that safe? > > snipped > > > Bob . . . > > I couldn't see the diagram, but the 'all over the place' alternator amperage suggests issues with the shunt's wiring. My (purchased) RV6 had inline fuse holders for glass fuses to 'protect' the > sense lines (protect in quotes because the fuses were somewhere near the middle of the wire runs). The flaky contact between the cheezy fuse holders and the fuses caused amperage readings to be... > 'all over the place'. Just one place to look, to isolate your random current readings. > > Charlie > > > Virus-free. www.avast.com > > > <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> ________________________________________________________________________________
Date: Jan 10, 2021
The email problems can be avoided by reading posts here: http://forums.matronics.com/viewforum.php?f=3 The OP is from Virginia. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=500128#500128 ________________________________________________________________________________
Date: Jan 10, 2021
We're aware, but some of us just prefer email delivery=2E =81=A3Sent fr om BlueMail =8B On Jan 10, 2021, 9:31 PM, at 9:31 PM, user9253 wrote: " > >The email problems can be avoided by reading pos ts here: >http://forums=2Ematronics=2Ecom/viewforum=2Ephp?f=3 >The OP is from Virginia=2E > >-------- >Joe Gores > > >Read this topic online her e: > >http://forums=2Ematronics=2Ecom/viewtopic=2Ephp?p=500128#500128 > > > > ============= ic-List Email Forum - rowse rchive Search & Download, 7-Day Browse, Chat, FAQ, uch much more: eroElectric-List ================== - MATRONICS WEB FORUMS - he Web Forums! > WIKI - http://wiki=2Ematronics=2Ecom ==================== - List Contribution Web Site - support! >_ -= --> http://www=2Ematronics=2Ecom/contribution === ________________________________________________________________________________
Date: Jan 10, 2021
Subject: Re: Two charging devices running in parallel?
Hi Bob You wrote in a post for RV10: "TWO alternators don't play well running in tandem unless their regulators are specifically chosen for parallel operation." Okay, the legacy definition of 'paralleled alternators/generators' says the two machines are regulated for the same set-point and ideally, they SHARE the system loads between them. Many GA twins were fitted with paralleling systems on their generators. The Beech 18 had some carbon pile regulators . . . the Cessna 310/320 had some electro-mechanical devices; both had paralleling coils on their voltage sense magnetics. To date, I'm aware of NO dual alternator systems in an OBAM aircraft wherein the two alternators are expected to simultaneously deliver energy into a system. The B&C standby systems are fitted with lowered set-point regulators so that they 'auto-switch' when the bus voltage falls below the setpoint due to main alternator failure. Tandem operation was never anticipated. Yeah, they were sorta connected up all the time but they were designed to operate independently of each other. My specific question is about my Rotax 914. I will be using a single Earth-X 680C LiFe battery. It has an internal generator and I am using a B&C AVC1 regulator with set-point at 14.5 volts. In addition on the vacuum pad I have a B&C LR3D with set-point at 14.6 volts. The vacuum pad doesn't spin very fast and at lower RPMs the alternator doesn't put out as much as the internal generator. Have you discussed this will B&C? I wonder if they have any customers with field experience on this configuration. Let's noodle thru this: The LiFePO4 delivers energy at 13.0 and below. So after start up the regulators on both alternators will sense 'voltage low' and command their respective machines to pick up the bus. If rpm is high enough the PM alternator will pick up system loads at 14.5 . . . at higher rpm the pad driven alternator will pick up loads at 14.6 whereupon the PM alternator will 'relax' until such time as system loads exceed output of the pad-driven alternator. The pad driven alternator becomes 'unregulated' and limited in output only by rpm. Voltage sags until the PM alternator picks up what's left over. Whether or not this is a stable condition is subject to tests. In this case the alternators are not sharing system loads. The pad-driven device is running full-field and the PM alternator becomes 'system master' and ostensibly will hold the bus at 14.5. Looks pretty good on paper . . . do you know any one who is flying this? That said the internal generator best be kept to 12 amps or less continuous amp draw to achieve long life from it. Idea is let the alternator put out it's best and do as much work as it can as it can do so without worry of over taxing it. Then if set-point of 14.6 volts can't be maintained the generator will take over and supplement. I have a shunt to read amp output on both chargers. Would my plan satisfy "regulators specifically chosen for parallel operation." Dunno . . . the condition Mr. Booth was citing is classic behavior for a pair of machines expected to operate REGULATED and regulator dynamics causes them to wrestle with each other. The result is often manifested in wildly fluctuating field voltages and outputs. In your case, you never have both alternators fighting for regulation dominance. One of the regulators is always hard-over wherein regulation dynamics are not a factor. Whether or not the regulators are sufficiently stable to setpoints that close together remains to be seen . . . and the spread can always be opened up a bit. An interesting experiment! Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jan 11, 2021
On 1/10/2021 7:06 PM, WILLIAM BOOTH wrote: > I can add after 6 months of frustration I have learned a lot about my > electrical system. The shunt off of the alternators is incorrect and > will be replaced this week. The battery shunt appears to be off by a > factor of 2.5. The Garmin draw with only the battery on and both PFDs > tested at 7amps draw while the Garmin displayed 17 amps draw. This > implies to me that it needs a 250a and 50mV shunt. I plan on > contacting Garmin this week to determine their requirements. Garmin specs a 100amp 50mV shunt. Certainly if the shunt and efis settings don't match you'll get inaccurate readings. 7 amps sounds about right to me. Also, I saw the previous comment about fuses in the middle of the sense lines. Excess resistance there will also affect the readings. Fuses are a good idea but they should be right at the shunt. I used pico fuses to avoid issues with a fuse holder. --Rick ________________________________________________________________________________
Date: Jan 11, 2021
>Garmin specs a 100amp 50mV shunt. Certainly if the shunt and efis >settings don't match you'll get inaccurate readings. 7 amps sounds >about right to me. Also, I saw the previous comment about fuses in >the middle of the sense lines. Excess resistance there will also >affect the readings. Fuses are a good idea but they should be right >at the shunt. I used pico fuses to avoid issues with a fuse holder. >\ There is virtually zero current flowing in the sense leads off a shunt to the display. Fuses and connectors in these leads do not adversely affect calibration. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jan 11, 2021
On 1/11/2021 7:15 AM, Robert L. Nuckolls, III wrote: >> Garmin specs a 100amp 50mV shunt. Certainly if the shunt and efis >> settings don't match you'll get inaccurate readings. 7 amps sounds >> about right to me. Also, I saw the previous comment about fuses in >> the middle of the sense lines. Excess resistance there will also >> affect the readings. Fuses are a good idea but they should be right >> at the shunt. I used pico fuses to avoid issues with a fuse holder. >> \ > > There is virtually zero current flowing in the sense > leads off a shunt to the display. Fuses and connectors > in these leads do not adversely affect calibration. > > > Bob . . . > But varying resistance does; at least with a Dynon EMS D-10. My plane has really cheesy inline fuse holders for the little glass instrument fuses. I was seeing large but inconsistent discharge indications. When I reached under the panel and pulled on the inline fuse holders, current readings would return to normal. After a few days or weeks, random high current readings would show up again, and the cure would be the same. I didn't attempt to 'instrument' the sense leads to prove the diagnosis, but as you know, this troubleshooting technique has been pretty effective since we started thumping vacuum tubes. Charlie -- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jan 11, 2021
Subject: Re: Monarch EE Anti-Plugging Field Accelerating?
>Here's a pic. from 2013 when it was in need of a good going over: >https://1drv.ms/u/s!Ah1S270Nwg9VtFmAe2PksSsa9K14 Rode hard and put away wet . . . Got a soft spot in my heart for nice, old and still functional tools. One of my prized possessions is a Craftsman table saw of 1950 vintage. Belonged to my wife's grandfather. When we did their estate sale about 20 years ago, nobody would offer what we thought the saw was worth. My father- in-law 'willed' it to me. I put it on a new base with casters. Upgraded the motor. Added extensions to the table top. Next enhancement is to facilitate long rips with rollers added to the down-stream edge of the extensions. There's something really satisfying to exploit the utility of a tool that's nearly as old as I am! Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jan 11, 2021
>With regards to the Z101 option or the Z14 for that matter I am for >what ever works best for my current situation. I need to be able to >communicate it to my A and P. Okay. It sounds like you're amenable to considering an 'upgrade' Z101 is a project we started here on the List last year. It's a kind of "legos" approach to configuring a light aircraft electrical system. As published, it includes everything-AND-the-kitchen-sink. To utilize this drawing, you delete un-needed features. Give me a few days. I'll take the base drawing and 'trim' it to what most closely incorporates what's in your airplane now . . . Let's see if we can gather up some loose ends in the current configuration while minimizing the $time$ and $effort$ to incorporate the changes. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jan 11, 2021
Subject: Ground LC3C controllers
The wiring diagram indicates ground the #7 pin from the alternator controllers to the engine block. The firewall side 24 tab ground block is close by. Is there a reason the controller ground should go to the engine block rather than the 24 tab ground? Does it matter? (It's all tied together in my composite.) Thanks, Dan ________________________________________________________________________________
Date: Jan 11, 2021
Subject: Re: Ground LC3C controllers
At 03:47 PM 1/11/2021, you wrote: >The wiring=C2 diagram indicates ground the #7 pin >from the alternator controllers to the engine >block.=C2 The firewall side 24 tab ground block >is close by.=C2 Is there a reason the controller >ground should go to the engine block rather than >the 24 tab ground?=C2 Does it matter?=C2 (It's all >tied together in my composite.) > >Thanks, >Dan To the FIREWALL GROUND BLOCK . . . NOT ENGINE Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jan 11, 2021
Subject: Shielding for strobes
A tech that wired my strobes (a composite) used three regular shielded wires rather than the gray wheelen strobe wire that has a shield around all three wires. Is there a problem with that? ________________________________________________________________________________
Date: Jan 11, 2021
Was written... Hey guys I am way in over my head on this forum but a nice man from BandC suggested I try. Attached is the electrical diagram of my recently purchased RV10. It was completed in 2009 and the avionics was switched to a Garmin 900x a year later. My issue is it safe and operationally sound. It is an X design, if that is fa I missed your original post, but I feel the same way about being a newbie. Cannot understand why aircraft electronics are hard for me. I can wire 125v circuits with my eyes closed. Apprehensive about wiring my EAB aircraft. On Sun, Jan 10, 2021 at 8:15 AM Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 06:54 AM 1/9/2021, you wrote: > > Hey guys I am way in over my head on this forum but a nice man from BandC > suggested I try. Attached is the electrical diagram of my recently > purchased RV10. It was completed in 2009 and the avionics was switched to a > Garmin 900x a year later. My issue is it safe and operationally sound. I t > is an X design, if that is familiar. > > > That's a REALLY busy electrical system . . . > > > Apparently the builder added a bus tie in order to bypass a diode bridge > rectifier type because the draw to recharge the Aux Battery, 2 wheel chai r > batteries 7Ah 12v wired in series reduced the essential bus voltage to > 12.6v. This bus tie when on,boosts both busses back to 13.6v. Is this how > it was meant to be run? > > > The thought processes behind this architecture cannot > be know to us unless it's documented somewhere. The > system depicted has features that are > > > Additionally with both alternators on, the displayed alternator amperage > seems to be all over the scale; sometimes 45-50 amps when the airplane ha s > most accessories off. Feeding both alternators into a single =C3=A2=82 =AC=C5=93bus bar=C3=A2=82=AC > seems to cause issues and is that safe? > > > Why run both at the same time? > > > Therefore it's been recommended that I swap out the Stby Alt for a 60A PP > alternator and just use it as the primary power source. My preference > would be going to a Z plan where each alternator powers its own bus but > I've been advised against that. The good news is my A&P figured out the > shunt had not been changed per Garmin install instructions, a 100A 50 > milivolts currently on order. > > > Aside from the things you've described here has > this system been flying 'successfully' since 2009? > Unless the seller offered the equivalent of a pilots > operating handbook for the system, you're kinda > stuck with second guessing the builder's original > design goals. > > The builder spent a lot of time providing a good > drawing of the wiring which is good. But the arrangement > makes it difficult to sort out exactly how this > system is supposed to function. Wiring for > bridge rectifier is curious . . . it shows all > four terminals tied together which negates its > function as a diode array. > > Changing this system to conform to a Z-figure > would be a BIG task. What are your plans/expectations > for getting the airplane flyable? > > > Bob . . . > > Un impeachable logic: George Carlin asked, "If black boxes > survive crashes, why don't they make the whole airplane > out of that stuff?" > ________________________________________________________________________________
Date: Jan 11, 2021
Subject: Re: Shielding for strobes
At 04:43 PM 1/11/2021, you wrote: >A tech that wired my strobes (a composite) used three regular >shielded wires rather than the gray wheelen strobe wire thathas a >shield around all three wires.=C2 Is there a problem with that? Don't believe so . . . Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jan 11, 2021
Hi Bob I spoke with TJ today, he doesn't know of anyone that has done what I propose thus far. After he did a bit of noodling, he thought it will probably work OK. His suggestion was to start with a .2volt spread and could open to .3 or .4 if needed. I don't know of anyone who is using a LR3D (or C) and a AVC1 at the same time like I propose. AVC1 has not been around too long. I will add this to the list of Interesting Experiments! Appreciate your opinion as always. Ron P. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=500144#500144 ________________________________________________________________________________
Date: Jan 11, 2021
Hi Bob Slick saw! Ron P. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=500146#500146 ________________________________________________________________________________
Subject: Tibet and Nepal Travels
Date: Jan 11, 2021
Lhasa, the capital and political, economic, and cultural center of the Tibet Autonomous Region. It is located in the middle of the Qinghai-Tibet Plateau and southeast of the Tibet Autonomous Region. With an altitude of 3650 meters above sea level, Lhasa is one of the highest cities in the world and also known as the "Sunlight City". Lhasa is the first impression of a Tibet tour for most travelers. Tibet Lhasa Map (https://www.greattibettour.com/lhasa-travel-tips/map.html) Lhasa stands on the north bank of the Lhasa River which is a tributary of the Yarlung Zangbo River. The city spans 277 kilometers from east to west and 202 kilometers from north to south, with a total area of 29,518 square kilometers. Tibet is composed of one city and six prefectures. Lhasa is encompassed by Nagqu in the north, Lhoka in the south, Shigatse in the west, and Nyingchi in the east. Beyond that, there are Ngari and Chamdo which are not connected to Lhasa. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=500147#500147 ________________________________________________________________________________
Date: Jan 12, 2021
On 1/11/2021 8:26 PM, Gary Wold wrote: > Was written... > >> Hey guys I am way in over my head on this forum but a nice man from >> BandC suggested I try. Attached is the electrical diagram of my >> recently purchased RV10. It was completed in 2009 and the avionics >> was switched to a Garmin 900x a year later. My issue is it safe and >> operationally sound. It is an X design, if that is fa > I missed your original post, but I feel the same way about being a > newbie. Cannot understand why aircraft electronics are hard for me. > I can wire 125v circuits with my eyes closed. Apprehensive > aboutwiring my EAB aircraft. I'm not a complete newbie but an amateur that has installed a Z-14 in an RV10 and flown it for 10+ years and 1,000+ hours. Untangling someone else's pride and joy versus working on your own electrical system from the ground up appears to be 2 different tasks. In this case the system is well documented but the design intent is unknown. That's half good but challenging. If you are DIYing your electrical system one of the best things you can do is read up the stuff presented here and decide to implement one of the 'Z' designs documented here. Then implement it without modifying it here and there to achieve some capability you think you need. Why not? Because that capability has most likely been considered, hashed out, possibly tested, and then either implemented in the appropriate Z design or discarded as not needed or wrong headed. If you select the right Z figure and stick with it, you'll do well. Some very good heads have spent a lot of time and effort honing these designs down into very serviceable solutions - all under the guidance and leadership of Mr Nuckulls. Doing a Z design 'as-is' will simplify things greatly. Me, I think I'm going to write up a 1 pager on my design intent and how it should be operated. Right now that just in my head. Have Fun! -- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jan 12, 2021
What appear to be relays in the lower right corner are actually illuminated switches. I do not see any over voltage protection. While cranking the engine, if the bus tie switch is closed and if bus B switch is closed, then the aux battery will help crank the engine. Are the wires big enough to handle the current? The solution is to eliminate the bus tie switch. So what if bus B is one volt less than Bus A? A Schottky diode will not drop as much voltage and will not get as hot. Alternators A and B have their labels reversed. The strobe circuit needs to be protected by a fuse. Connecting both alternators to one current shunt is not necessarily unsafe unless the shunt fails. Consider using individual hall effect current sensors. If the alternators do not play well with each other, the simple solution is to only have one on at a time. If the original builder practiced good workmanship, I would not rewire the airplane. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=500156#500156 ________________________________________________________________________________
Subject: Re: Magnetos
Date: Jan 12, 2021
Bob, Jerry, Firstly may you have a happy and safe new year! many thanks for your input! I will try Jerry's suggestion to test for sparks. I have to say I am not quite electrically savvy. I changed the spark plugs to brand new REM 40E and I will try the spark test. I have also been looking for the proper P/N to replace the harness if necessary. Anyone know what this would be? Again, thanks! Ef -------- EfraimOtero Fisher Celebrity EX N500BC O200 COntinental Read this topic online here: http://forums.matronics.com/viewtopic.php?p=500160#500160 ________________________________________________________________________________
Date: Jan 12, 2021
I would like to avoid rewiring if possible. - Over voltage protection I can resolve with a PP alternator (and change it o ver to the primary?). - The batteries to help crank not only are not big enough , but the wires ar e not big enough. (Picture included.) - A Schottky diode is a great solution but wiring it like my current one wo uld be incorrect as =9CI=9D understand it. (Picture included.) - Great catch on the mislabeled alternators; I saw that too. - The Hall effect current sensor; is that a directional flow item, like a d iode? - Yes on the one at a time and only keep the other one for STANDBY use. William Booth Sent from my iPad > On Jan 12, 2021, at 11:42 AM, user9253 wrote: > l.com> > > What appear to be relays in the lower right corner are actually illuminate d switches. > > I do not see any over voltage protection. > > While cranking the engine, if the bus tie switch is closed and if bus B sw itch is closed, > then the aux battery will help crank the engine. Are the wires big enough to > handle the current? The solution is to eliminate the bus tie switch. So w hat > if bus B is one volt less than Bus A? A Schottky diode will not drop as m uch > voltage and will not get as hot. > > Alternators A and B have their labels reversed. > > The strobe circuit needs to be protected by a fuse. > > Connecting both alternators to one current shunt is not necessarily unsafe unless the shunt fails. > Consider using individual hall effect current sensors. > If the alternators do not play well with each other, the simple solution i s to only have one on at a time. > > If the original builder practiced good workmanship, I would not rewire the airplane. > > -------- > Joe Gores > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=500156#500156 > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= ========================== ========= > > > ________________________________________________________________________________
Date: Jan 12, 2021
Ef - Assuming your O-200 is fitted with Continental mags, the harness is P/N: 10-821471-17 <http://ipc.cmg.aero/IPC/PartsOfaSection#/>. Neal ================ On Jan 12, 2021, at 1:34 PM, EfraimOtero wrote: Bob, Jerry, Firstly may you have a happy and safe new year! many thanks for your input! I will try Jerry's suggestion to test for sparks. I have to say I am not quite electrically savvy. I changed the spark plugs to brand new REM 40E and I will try the spark test. I have also been looking for the proper P/N to replace the harness if necessary. Anyone know what this would be? Again, thanks! Ef -------- EfraimOtero Fisher Celebrity EX N500BC O200 COntinental ________________________________________________________________________________
Date: Jan 12, 2021
Subject: Sealed Connectors
Is there a weather sealed PIDG blade crimp connector? I seem to remember something with heat shrink and glue. They looked like this but with a heat shrink end for the wire. [image: OIP.jpg] ________________________________________________________________________________
Date: Jan 12, 2021
I would suggest that the battery arrangement in the picture shouldn't have ever been part of the cranking circuit. I say this because it looks like that was a copy of my aux battery config, of which I was the first RV-10 to put them in that location. It looks like the liked my location, liked some of the configuration, but then if they tried in any way to use it for engine cranking, they took a hard turn and went down a different path than those batteries would have ever been planned to be used for. My primary battery is an Odyssey PC925, located in the tail, and it has no problem cranking the engine all by itself. People who use PC680's often install 2, in the same rear location, and tie them together for cranking. You should probably have someone look over that portion of your electrical system in particular, and just plan to remove these by the flap torque tube completely from any engine cranking operation. Tim On 1/12/2021 3:07 PM, WILLIAM BOOTH wrote: > I would like to avoid rewiring if possible. > > - Over voltage protection I can resolve with a PP alternator (and change it over to the primary?). > - The batteries to help crank not only are not big enough , but the wires are not big enough. (Picture included.) > - A Schottky diode is a great solution but wiring it like my current one would be incorrect as I understand it. (Picture included.) > - Great catch on the mislabeled alternators; I saw that too. > - The Hall effect current sensor; is that a directional flow item, like a diode? > - Yes on the one at a time and only keep the other one for STANDBY use. > > William Booth > > > Sent from my iPad > >> On Jan 12, 2021, at 11:42 AM, user9253 wrote: >> >> >> What appear to be relays in the lower right corner are actually illuminated switches. >> >> I do not see any over voltage protection. >> >> While cranking the engine, if the bus tie switch is closed and if bus B switch is closed, >> then the aux battery will help crank the engine. Are the wires big enough to >> handle the current? The solution is to eliminate the bus tie switch. So what >> if bus B is one volt less than Bus A? A Schottky diode will not drop as much >> voltage and will not get as hot. >> >> Alternators A and B have their labels reversed. >> >> The strobe circuit needs to be protected by a fuse. >> >> Connecting both alternators to one current shunt is not necessarily unsafe unless the shunt fails. >> Consider using individual hall effect current sensors. >> If the alternators do not play well with each other, the simple solution is to only have one on at a time. >> >> If the original builder practiced good workmanship, I would not rewire the airplane. >> >> -------- >> Joe Gores >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=500156#500156 >> >> >> >> >> >> > =================================== > =================================== > =================================== > =================================== > =================================== >> >> ________________________________________________________________________________
Date: Jan 12, 2021
BTW what is the purpose of the diode, how is it used and how does the electricity flow thru it? William Booth > On Jan 12, 2021, at 11:42 AM, user9253 wrote: > > > What appear to be relays in the lower right corner are actually illuminated switches. > > I do not see any over voltage protection. > > While cranking the engine, if the bus tie switch is closed and if bus B switch is closed, > then the aux battery will help crank the engine. Are the wires big enough to > handle the current? The solution is to eliminate the bus tie switch. So what > if bus B is one volt less than Bus A? A Schottky diode will not drop as much > voltage and will not get as hot. > > Alternators A and B have their labels reversed. > > The strobe circuit needs to be protected by a fuse. > > Connecting both alternators to one current shunt is not necessarily unsafe unless the shunt fails. > Consider using individual hall effect current sensors. > If the alternators do not play well with each other, the simple solution is to only have one on at a time. > > If the original builder practiced good workmanship, I would not rewire the airplane. > > -------- > Joe Gores > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=500156#500156 > > > > > > > > > ________________________________________________________________________________
From: Stuart Hutchison <stuart(at)stuarthutchison.com.au>
Subject: Re: Sealed Connectors
Date: Jan 12, 2021
I just put dual-wall (glue-lined) heatshrink over the crimped connector its then sealed and provides great strain relief all in one. V/r, Stuart > On 13 Jan 2021, at 8:56 am, Sebastien wrote: > > Is there a weather sealed PIDG blade crimp connector? I seem to remember something with heat shrink and glue. They looked like this but with a heat shrink end for the wire. > > ________________________________________________________________________________
Date: Jan 12, 2021
Neal, thanks for the prompt response. Mine are Bendix S4 LN -21 mags, P/N 10-51360-30. Are these the same as Continental? Gues not...? [Shocked] [Embarassed] -------- EfraimOtero Fisher Celebrity EX N500BC O200 COntinental Read this topic online here: http://forums.matronics.com/viewtopic.php?p=500167#500167 Attachments: http://forums.matronics.com//files/img_1555_146.jpg ________________________________________________________________________________
Date: Jan 12, 2021
Think of the diode as a one way check valve. It allows current to flow from bus A to bus B, but not in the opposite direction. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=500172#500172 ________________________________________________________________________________
Date: Jan 12, 2021
This stuff is *awesome* for sealing connectors, splices etc, and its not badly priced. Comes in 4 diameters, with a great shrink ratio. IF you cant find the connector you want you can use a section of this on the stem: https://www.mouser.ca/datasheet/2/418/5/NG_DS_ES1000_404-735359.pdf On Jan 12, 2021, at 4:56 PM, Sebastien wrote: Is there a weather sealed PIDG blade crimp connector? I seem to remember something with heat shrink and glue. They looked like this but with a heat shrink end for the wire. ________________________________________________________________________________
Date: Jan 12, 2021
Yes, they are the same. Continental bought the Bendix ignition line about 35 years ago Neal ================= On Jan 12, 2021, at 4:25 PM, EfraimOtero wrote: Neal, thanks for the prompt response. Mine are Bendix S4 LN -21 mags, P/N 10-51360-30. Are these the same as Continental? Gues not...? [Shocked] [Embarassed] -------- EfraimOtero Fisher Celebrity EX N500BC O200 COntinental ________________________________________________________________________________
Date: Jan 12, 2021
If the connection is where you are worried about weather connection, and the wire is #18 or smaller, suggest you dump the blade connectors and get Electronics International OLC-1 or better OLC-2 connectors. They create a weather tight seal using Allen screws in a connective sleeve. Intended for EGT, CHT and fuel sending units in engine compartment. They cost $1 each in multiples of 5 from the company direct, free shipping and free Allen wrench. Blade connectors on EGT and CHT weather and get highly variable resistance, causing unpredictable swings in readings. The OLC connectors give rock solid readings and are reusable, unlike crimp connectors. On 1/12/2021 5:07 PM, Alec Myers wrote: > > This stuff is *awesome* for sealing connectors, splices etc, and its not badly priced. Comes in 4 diameters, with a great shrink ratio. > IF you cant find the connector you want you can use a section of this on the stem: > https://www.mouser.ca/datasheet/2/418/5/NG_DS_ES1000_404-735359.pdf > > > > On Jan 12, 2021, at 4:56 PM, Sebastien wrote: > > Is there a weather sealed PIDG blade crimp connector? I seem to remember something with heat shrink and glue. They looked like this but with a heat shrink end for the wire. > > > > > > > ________________________________________________________________________________
Date: Jan 12, 2021
RE the diode: Specifically why is it needed on this design; how else could the power flow? Re: Tims comment on the Aux Batteries; too small and the wires too small too.... I agree it has puzzled me when I first saw it but if buse B is turned on for start I should be ok? That being said how else should it be done? Again safe and sound is the goal. William Booth > On Jan 12, 2021, at 7:05 PM, user9253 wrote: > > > Think of the diode as a one way check valve. It allows current to > flow from bus A to bus B, but not in the opposite direction. > > -------- > Joe Gores > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=500172#500172 > > > > > > > > > ________________________________________________________________________________
Date: Jan 12, 2021
Follow the wires from the aux battery, through the bus B relay, to Bus B, through the bus tie switch, to bus A, to the big dot (junction) below bus A, to the starter relay, to the starter. Lots of current will flow through that path. Prevent it by removing the bus tie switch. And remove that jumper from the bottom of the diodes (labeled 2) because it also will conduct starter current. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=500182#500182 ________________________________________________________________________________
Subject: test messae from gmail to rc dot org dot uk
Date: Jan 13, 2021
| Rowland Carson ... that's Rowland with a 'w' ... | http://www.rowlandcarson.org.uk | Skype, Twitter: rowland_carson Facebook: Rowland Carson ________________________________________________________________________________
Subject: low voltage warning
Date: Jan 13, 2021
a few months i posted about a low voltage warning that would trip at 13.4 volts especially for earthx batteries. i set up a circuit board for a low voltage trip and another voltage regulator board to supply a constant 12 volts to the low voltage board. a lot of wires [reg. voltage, sense voltage, power to led warn light, ground]. i did get it all working as it was supposed to. 10 square inches of circuit board. i went back to the perihelion web site and they supply them now for $50. i called the owner and he said he could build them set to any alarm voltage and would i like steady or flashing light? how could i resist? the store bought device trips at the same voltage every time, no 'stuttering' of the light. when it goes on it's on. raising the voltage .5 volts will shut it off. i see a very popular vender sells a like item for $185. this whole thing slips thru the hole in the panel for the led and is about 2' deep. you connect a pos. and a neg. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=500190#500190 ________________________________________________________________________________
From: David and Elaine Lamphere <dalamphere(at)comcast.net>
Subject: Alternator bench test
Date: Jan 13, 2021
Twice I have sent a PlanePower (internal volt regulator) back to Hartzell as it is not charging. Both times they have told me it checks out OK on the bench. I have checked wiring 3 times without finding a culprit. The last thing I did before sending it to them was set it up on the bench. It did not work (would not charge). Let me describe what I set up - perhaps I am missing something. I tried to make the setup as simple as possible. ________________________________________________________________________________
Subject: Re: low voltage warning
Date: Jan 13, 2021
On 1/13/2021 9:09 AM, bobnoffs wrote: > > a few months i posted about a low voltage warning that would trip at 13.4 volts especially for earthx batteries. i set up a circuit board for a low voltage trip and another voltage regulator board to supply a constant 12 volts to the low voltage board. a lot of wires [reg. voltage, sense voltage, power to led warn light, ground]. i did get it all working as it was supposed to. 10 square inches of circuit board. > i went back to the perihelion web site and they supply them now for $50. i called the owner and he said he could build them set to any alarm voltage and would i like steady or flashing light? how could i resist? > the store bought device trips at the same voltage every time, no 'stuttering' of the light. when it goes on it's on. raising the voltage .5 volts will shut it off. > i see a very popular vender sells a like item for $185. > this whole thing slips thru the hole in the panel for the led and is about 2' deep. you connect a pos. and a neg. Hi Bob, Here you go: https://www.tomtop.com/p-e1021.html Charlie -- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jan 13, 2021
thanks Kelly, > Blade connectors on EGT and CHT weather and get > highly variable resistance, causing unpredictable swings in readings. So, you are suggesting that the PIDG connectors have been an issue for you in the past, with TC wiring. I just yesterday recieved a large order from an avionics vendor (obviously, not EI) that included both EGT and CHT TC wiring, with one end pre-terminated using PIDG connectors and the mating PIDG included. I guess this suggests I should swap these out to avoid an issue. Do you think that corrosion is the mail culprit and that properly sealing the PIDG connectors would address this? Dan Theis -------- Scratch building Sonex #1362 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=500194#500194 ________________________________________________________________________________
Date: Jan 13, 2021
Subject: Re: Alternator bench test
I recently had a problem and replaced the internal VR and in doing so did not tighten the B lead to alt enough. No Charge. Tightened and now works perfectly. May have been the original problem as field cb never tripped. Ed On Wed, Jan 13, 2021 at 11:20 AM David and Elaine Lamphere wrote: > > Twice I have sent a PlanePower (internal volt regulator) back to Hartzell as it is not charging. > Both times they have told me it checks out OK on the bench. > > I have checked wiring 3 times without finding a culprit. The last thing I did before sending it to them was set it up on the bench. It did not work (would not charge). Let me describe what I set up - perhaps I am missing something. I tried to make the setup as simple as possible. > > ________________________________________________________________________________
Date: Jan 13, 2021
The OLC connectors are much better than the blade connectors at reducing erroneous EGT and CHT readings. They are rather fiddly to work with and are not weather sealed. Our engine puts out a great deal of heat, vibration, and movement and after many problems with the PIDG connectors supplied by Dynon we were going to replace them with OLC connectors but decided to try a cheaper solution first: Dsub pins covered with shrink wrap. So far very pleased with the result. Easy to install, good quality signal and no failures. Thank you for the suggestion Kelly but these connectors are going to be installed in a set of floats so the OLCs would quickly fail due to corrosion. I'm actually pushing the owners to go to Deutsch connectors but don't think they'll like the cost. On Wed, Jan 13, 2021 at 8:45 AM dj_theis wrote: > > thanks Kelly, > > > > Blade connectors on EGT and CHT weather and get > > highly variable resistance, causing unpredictable swings in readings. > > > So, you are suggesting that the PIDG connectors have been an issue for you > in the past, with TC wiring. > > I just yesterday recieved a large order from an avionics vendor > (obviously, not EI) that included both EGT and CHT TC wiring, with one end > pre-terminated using PIDG connectors and the mating PIDG included. > > I guess this suggests I should swap these out to avoid an issue. Do you > think that corrosion is the mail culprit and that properly sealing the PIDG > connectors would address this? > > Dan Theis > > -------- > Scratch building Sonex #1362 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=500194#500194 > > ________________________________________________________________________________
Date: Jan 13, 2021
Thats interesting - what would be your opinion of my cruse bench setup? Would it work? On Jan 13, 2021, at 12:03 PM, edward Clegg wrote: I recently had a problem and replaced the internal VR and in doing so did not tighten the B lead to alt enough. No Charge. Tightened and now works perfectly. May have been the original problem as field cb never tripped. Ed On Wed, Jan 13, 2021 at 11:20 AM David and Elaine Lamphere wrote: > > Twice I have sent a PlanePower (internal volt regulator) back to Hartzell as it is not charging. > Both times they have told me it checks out OK on the bench. > > I have checked wiring 3 times without finding a culprit. The last thing I did before sending it to them was set it up on the bench. It did not work (would not charge). Let me describe what I set up - perhaps I am missing something. I tried to make the setup as simple as possible. > > > ________________________________________________________________________________
Date: Jan 13, 2021
Have you measured the field current? If so, what is it? -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=500199#500199 ________________________________________________________________________________
Date: Jan 13, 2021
hey charlie, that is the board i started with. when you get it it doesn't match the picture. has 4 buttons, not 3 for starters. when i asked for some kind of instructions for the board i got they ended up sending a refund.i did get the board figured out. then someone posted their board, similar to the one you posted, was erratic if the board was powered by more than 13 volts. so i added a voltage reg. board. it was all interesting and i don't regret any of it but i ended up with 10 sq inches of circuit board. layered in plexi. it is an inch thick. i had confidence in it but it just couldn't compete spacewise. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=500200#500200 ________________________________________________________________________________
Date: Jan 13, 2021
David, During Covid hibernation I had some time to bench-test a couple of alternat ors and I found that some were sensitive to low RPM.=C2- In other words, some alternators need to spin pretty fast to work properly. I used a test fixture (picture attached) and used a 3/4 horsepower motor fr om my shop sander to drive it.=C2- That motor spins at 3450 RPM and I had a pulley configuration of about 1.2:1.=C2- So I'm guestimating that the alternator was turning somewhere around 2800 RPM. Some alternator/regulator combinations that I tested would not self-start a t that low RPM.=C2- If I momentarily jumped the field, it would generate electricity and regulate normally.=C2- When I changed the pulley arrangem ent to get higher alternator RPM, it would self-start. Some regulators have a self-starting feature where they won't turn-on until they reach some minimum RPM.=C2- It is designed to keep power off the fi eld when the engine is not turning.=C2- I have no idea about how the Plan e Power devices are supposed to work.=C2- (I was testing automotive alter nators & regulators) What I learned: 1. Some alternator/regulator combinations won't work properly until they hi t some minimum RPM2. Manually jumping the field to get it started can be va luable 'cuz it showed the regulator could regulate (was not DOA) However, Jumping the field may be more challenging on an internal regulator unit??? My test fixture is UGLY. But it worked well and was fast & cheap to build. =C2- The 3/4 HP motor mounts to the right on the 2 studs that are stickin g up.=C2- I would have preferred to use a more powerful motor, at least 1 HP, but none was available, so I went with what I had.=C2- The motor wou ld bog-down with about 25 Amps of load on the alternator. Lamphere wrote: here(at)comcast.net> That=99s interesting - what would be your opinion of my cruse bench s etup? Would it work? On Jan 13, 2021, at 12:03 PM, edward Clegg wrote: I recently had a problem and replaced the internal VR and in doing so did not tighten the B lead to alt enough. No Charge. Tightened and now works perfectly. May have been the original problem as field cb never tripped. Ed On Wed, Jan 13, 2021 at 11:20 AM David and Elaine Lamphere wrote: > > Twice I have sent a PlanePower (internal volt regulator) back to Hartzell as it is not charging. > Both times they have told me it checks out OK on the bench. > > I have checked wiring 3 times without finding a culprit. The last thing I did before sending it to them was set it up on the bench. It did not work (would not charge). Let me describe what I set up - perhaps I am missing so mething. I tried to make the setup as simple as possible. > > > - S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. /9j/4QgaRXhpZgAATU0AKgAAAAgADQEPAAIAAAAGAAAAqgEQAAIAAAAWAAAAsAESAAMAAAABAAEA AAEaAAUAAAABAAAAxgEbAAUAAAABAAAAzgEoAAMAAAABAAIAAAExAAIAAAAFAAAA1gEyAAIAAAAU AAAA3AE8AAIAAAAWAAAA8AFCAAQAAAABAAACAAFDAAQAAAABAAACAAITAAMAAAABAAEAAIdpAAQA AAABAAABBgAAAABBcHBsZQBpUGFkICg2dGggZ2VuZXJhdGlvbikAAAAASAAAAAEAAABIAAAAATE0 LjIAADIwMjE6MDE6MTMgMTA6MTA6MjcAaVBhZCAoNnRoIGdlbmVyYXRpb24pAAAjgpoABQAAAAEA AAKwgp0ABQAAAAEAAAK4iCIAAwAAAAEAAgAAiCcAAwAAAAEAMgAAkAAABwAAAAQwMjMxkAMAAgAA ABQAAALAkAQAAgAAABQAAALUkBAAAgAAAAcAAALokBEAAgAAAAcAAALwkBIAAgAAAAcAAAL4kQEA BwAAAAQBAgMAkgEACgAAAAEAAAMAkgIABQAAAAEAAAMIkgMACgAAAAEAAAMQkgQACgAAAAEAAAMY kgcAAwAAAAEABQAAkgkAAwAAAAEAIAAAkgoABQAAAAEAAAMgkhQAAwAAAAQAAAMoknwABwAABIwA AAMwkpEAAgAAAAQ5OTMAkpIAAgAAAAQ5OTMAoAAABwAAAAQwMTAwoAEAAwAAAAEAAQAAoAIABAAA AAEAAAzAoAMABAAAAAEAAAmQohcAAwAAAAEAAgAAowEABwAAAAEBAAAApAIAAwAAAAEAAAAApAMA AwAAAAEAAAAApAUAAwAAAAEAHwAApAYAAwAAAAEAAAAApDIABQAAAAQAAAe8pDMAAgAAAAYAAAfc pDQAAgAAAC4AAAfiAAAAAAAAAAEAAAAeAAAADAAAAAUyMDIxOjAxOjEzIDEwOjEwOjI3ADIwMjE6 MDE6MTMgMTA6MTA6MjcALTA4OjAwAAAtMDg6MDAAAC0wODowMAAAAAKBUQAAgrAAAe4nAADDnwAA /SgAAEN7AAAAAAAAAAEAAAAhAAAACgZfBMcHAwQ1QXBwbGUgaU9TAAABTU0AGQABAAkAAAABAAAA DAACAAcAAAIuAAABQAADAAcAAABoAAADbgAEAAkAAAABAAAAAQAFAAkAAAABAAAAsgAGAAkAAAAB AAAArwAHAAkAAAABAAAAAQAIAAoAAAADAAAD1gAOAAkAAAABAAAADAARAAIAAAAlAAAD7gAUAAkA AAABAAAABAAWAAIAAAAdAAAEFAAXAAkAAAABAAAAAAAZAAkAAAABAAAAAAAaAAIAAAAGAAAEMgAf AAkAAAABAAAAAAAgAAIAAAAlAAAEOAAlAAkAAAABAAAAAAAmAAkAAAABAAAAAAAnAAoAAAABAAAE XgArAAIAAAAlAAAEZgAvAAkAAAABAAAANQA2AAkAAAABAAADTAA7AAkAAAABAAAAAAA8AAkAAAAB AAAAAAAAAABicGxpc3QwME8RAgDOADUB2AHOARkCcQGcAL4A7gAHAQIB8QCLAIQAoACSAHEAsQCd AGsA/QB+AaQAmADjAPQAyQALAZIAmQCyAKAAbQCLAJgAbAF2AnEBuQCbANUA9QBmAboBJQG7AK4A VwB5AKAAwQDEAAgBvwDTAAgBOgEuAWsB1wHVAQ4BtABTAI8AugDPALsAyACTAJkA0wAyATwBGgFb AT8B0gDYABwBnwDoABcB4QDPANcA0QDIALwAtgDEALcAtwCsAKwAGgHPAAwBCgGyAOcAxADIAI8A lwCWALAAtACbAKoArwC6ACoBAAGpAJsAEwEOAVwB3gB9AJwAowCXAJ0AmgCfAJoABwGpAIEAqQDe ANQAKQGYAGkAnwCdAKgAqgCcAJoAkQDlAI8AcABpAIYAagCxAGMAZQCTAL8AqwCnAKMAigB6AO8A xgChAL0AmACAAI8AtACsANEADgGxAJYAmQCXAIkA5AAkAV8BQwFQAYAAewCvABcB9wDaAKYAdQB7 AHkAZQDJAE4BagE6Ac4AewBeAH4AsQCWAGoAXgBbAEkARwAvAKIAzgC4AIsAbQBiAFsAVABTAE4A PgAsAB0AGgAXABcAowCHAH4AawBZAEkARgA2AC0AGwAcABYAGAAYACIAQgCOAGcAZABSAD0AMgAd ABcAFQAWABcAFgAUAB4AMQA1AAAIAAAAAAAAAgEAAAAAAAAAAQAAAAAAAAAAAAAAAAAAAgxicGxp c3QwMNQBAgMEBQYHCFVmbGFnc1V2YWx1ZVl0aW1lc2NhbGVVZXBvY2gQARMAAMn73tmGdhI7msoA EAAIERcdJy0vOD0AAAAAAAABAQAAAAAAAAAJAAAAAAAAAAAAAAAAAAAAP///vL0AAFsy///h1AAD j0H//2XVAADh6TU5RUI0ODIwLUY1QzItNDQ2RC05NDZFLUZEMjI0NkNGRDAwRgAAQVZUSmZuNXB5 VnVjVXQ0WUpjd3hlUEEwNVAvaAAAcTkwMG4ARjU4QjlCQjQtMjM3OC00RUY1LTgzRUQtRUVDN0RC RTU1QTU1AAAAAAAAAAAAAUUzQ0U1MzZELUI2OEYtNEFCNC04Qzc0LUYxQThFRDREQTFEMwAAAAAA IQAAAAoAAAAhAAAACgAAAAwAAAAFAAAADAAAAAVBcHBsZQBpUGFkICg2dGggZ2VuZXJhdGlvbikg YmFjayBjYW1lcmEgMy4zbW0gZi8yLjQAAAD/6gJuQVJPVAAAAAAAmJUhAAD/RQAA7G0AAHWUAABh ugAAxOAAAC4LAQCrNAEAOVsBAL6BAQBBqgEAV9ABAHn1AQDlGwIAWUMCAG1nAgCKiQIAmasCAGfO AgBD8gIAmhMDANA2AwAaWgMAdX0DAPuhAwCBxwMAN/ADADkVBAAENgQAuVQEAKNzBAAzlAQAbbUE AIHXBACh+wQAtSAFAPhHBQBjbAUA6Y4FAACwBQAN0gUAUPcFANQcBgCQRQYAzmsGALCVBgDdvAYA TOMGAKQIBwBKLQcAVlIHAMZ2BwD6nwcAuMkHAJ34BwDkJAgAGFAIADp7CAAWowgAw8sIAIL2CAD7 IAkARUsJAMV2CQCyowkA59AJAEr+CQDQLAoAVl4KALKNCgB7uQoAYOQKAAgTCwDURQsAiHQLAHSk CwAR1QsA1QUMACg2DACSZgwA45QMABTFDABY9AwAmyUNAKxWDQD6hQ0Ac7cNAJvmDQAmFA4AfEEO AC1vDgD4nQ4A2csOAKz6DgANKA8AgVQPANeDDwA5sg8Aid8PAIoOEAAkPxAAxmsQAK2WEADKvhAA i+UQAP4OEQD9NREAdV4RAEuGEQA7rhEAvtcRAK8DEgB2LxIAs10SAJ6KEgCgtBIA3d8SALkKEwA3 NRMA8F0TAOCEEwA/rBMA29MTAGf9EwAuJhQALlEUANB8FAATqBQA49EUABH7FABTJBUA2EsVAD10 FQBInRUAXMYVAMftFQASFRYAMDsWAHFjFgDxjBYAFbYWADzgFgB1ChcAyzIXANlbFwC2hhcADbMX AFvdFwDoBhgAcTIYAOVcGACZhRgAAAD/2wCEAAICAgICAgMCAgMFAwMDBQYFBQUFBggGBgYGBggK CAgICAgICgoKCgoKCgoMDAwMDAwODg4ODg8PDw8PDw8PDw8BAgICBAQEBwQEBxALCQsQEBAQEBAQ EBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEP/dAAQAzP/AABEICZAM wAMBIgACEQEDEQH/xAGiAAABBQEBAQEBAQAAAAAAAAAAAQIDBAUGBwgJCgsQAAIBAwMCBAMFBQQE AAABfQECAwAEEQUSITFBBhNRYQcicRQygZGhCCNCscEVUtHwJDNicoIJChYXGBkaJSYnKCkqNDU2 Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6g4SFhoeIiYqSk5SVlpeYmZqio6Sl pqeoqaqys7S1tre4ubrCw8TFxsfIycrS09TV1tfY2drh4uPk5ebn6Onq8fLz9PX29/j5+gEAAwEB AQEBAQEBAQAAAAAAAAECAwQFBgcICQoLEQACAQIEBAMEBwUEBAABAncAAQIDEQQFITEGEkFRB2Fx EyIygQgUQpGhscEJIzNS8BVictEKFiQ04SXxFxgZGiYnKCkqNTY3ODk6Q0RFRkdISUpTVFVWV1hZ WmNkZWZnaGlqc3R1dnd4eXqCg4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqys7S1tre4ubrCw8TF xsfIycrS09TV1tfY2dri4+Tl5ufo6ery8/T19vf4+fr/2gAMAwEAAhEDEQA/APkfwNPqSal9ntJN vlctk4wD/Ovs74bXqEmOSRZrhVwT+NfCFndahZXi3em7fMH3t3Qf419hfCrUIVnR5XXzWH71sYGS M148D2KlM+lJIPMPPeuZ8VeCNM8XaRJpV7FncDtYDlT613iQAqhHUir8UWw88VoY8p+dPiz9iy5v Lm3n0p47lricBz5IbyYwCS7An5ufTvjtkhng39kmDR/EgvtUvftCRAbQIinTnBBPA78V+mtnHGe2 PXFWU0mxSRSkA2mg09pLueceBfBlv4dgUWBYQhduCTj8Aeg9K9JFvuKyHh+n1rSWFUG1AFX0FTpA 3BK8CgkghtCDkVp28G1uRU0UWFyBVpAo+9WZtzGzp8JOE/vV8f8A7YmjMYdMuo/lRvk9PnwT/IV9 kacf3gHpXzN+1ykf/CN6TNc/d89v/RZrOrtc9TJ52xET8qNTDW9yY3BO3AyKWNQUG44brW1rdqHm R0UhuM+lZzRvtIKgEdCK+dxEl2P3/I1aJasQyoWkP0BrcjZ3j2jv29qwrGKR5Dv6D1roYldflkGA neuGUj6uKMbVUC2zIoww6k+nU161+zbPEfEk3hhl8z7VIl2rL91RFksD9a8qvtwdm4YKDj3r1P8A ZvVW+J6ys4A+yyY9sqMGujBfEfF8aL/Z5S7I+8mjAi5xUGM49qsEgIV64NRhPmAPevcR+DzK0isq MfSmWEDG5Vg33qnnjkztA4NQWM6Q3iI/AB618VxfBuB7OUS949U0xWEapJwe1dFG65ABrlNPvI5J FUH5h/Kt5XT+Hr61+PzTTsfapmo5qq8nGM1EZCR1qHcxPFYE3Embjb0rktSOCQDXUXW9QDXKXu3J LDmtqMPeBnFahLIoKuDgisfQLl/7X+zbSBtz7Vt6qzKh2jcCOM9q5vQ5PJ1VCxJeQY9q+24b/iHh 5t/DPYYiG7VpR529Kx4BIMc1sRlitfrlP4Ufn9T4iTpz61OvUg96jjBBy/apoh8wdq3juQjyLxlA lvdEdCTmuXiChRuOM816l48tYvsjXrLlsAZry7ahTaeelflvFlP3mfbZPU90e5G0gc5ridThkjvN z5Nd00YVFVRzWRqFpI8TPj5hXwbPduc5FNtI54NaBkR2Xpms5YHVdoBJB71aj2F1CjDd6yYXN+3I 4U5J715t4gI07VA9suCp3N716ZbI+MgY7Vwvia2ZrllwC3rXtZIkppsjEq8Gem6Ff/bLSK5U4UqD x612dvdmSIqRyO9ebeETH/ZUcK8Mh5HrXawhlyQc1+2ZarwR+d43SbOhtpGJ68Vu2pAYGuaglAUb a6G1cMy4r10jhR0UeAD3zU6ZU5JyPSoo9oFTqOBkda2REyTJY8cCpx8w4GMVXOAMCpgSRha1MywM ntmng7Dz3qKNux4qQ4J+lBDJ0z1HSrCHgA/LVWPPQGrCKxxk5FBZJs+bI5qeMEEYPFN2g42nFWIo wADigzLQVMAtUoQcHvUar03dKsCNuMUAJk4xTdpqXBAwaYMg1oZjgBSkjpQCKCBWZoO6U8nA4qNT xilArQzJAMcFcVIBjpRtz1bNHsOKzNBy57nircYPpz61XRBkd62ra33D7v4UAQou3r3pypya5nxh 8TPhr8OFjXxvrUGlyzAmNJD8z4IBwPbIritC/aN+CvifUf7I0PXoJLs7flLjJ3nA49M984FAHrRQ j5qrHJO2tvy/MgSZBlWyM9uOOKzpUCknFAFBuMU3AGTUhBpgWlzAOAHWpF6UzHNPGeKOYCUDFKow eabzu5pSOaYGnbVV8Y+NtB+Hnhe88WeJLgW1nZRmQse+PTnmrVnXyb+3YNXb4M3cWmWxmiePbOdu 77x+VV56nGfoPxoA+IPiL/wUt8aR+JJbbwpJFpdhbHK7x53nZPXK4OMdR05rsfgl/wAFLbnUvEmn +HfiGlsLDUJykt7EGjSBXOA20glQueeSMc4BPH46eKJpF1yS3nXY0aqvP0rmfM3I4HyN0+bpzQOx /ZPpmtad4j0W11zSZfPsbtA8UoBUOh6MAQCM8dao3HNfAn/BPn4n694q+FemaB4gka8msnNsJjID iGJQVwnZRkZxznnp0+/LjvQNxsZ+OtIAtGG70gHPNBz1BuSTT9uKUgHpTeRWhiLtpVHNLTlFZkJG hb7ARkV+Sv7bXwVutV8YvrdzC8ml6ooFu0KFyjIcFXOCAT7/AFHQ4/WSJ8dqq61oen+I7RbS/U7O QCDjBPf/AAqJo7aUrH8p3jL4B+JNLnH9irLc2Zd/NSFCz2+OVWRsDoOuO/vwOt+Anwf8T6r8RNB1 aS1nBsruIujRsCFDfxDHQY5PA9+9fvDrX7Lcd7eSfYb4rYu24KW2HH0Xg12Hw3+Amg+BNabVwzzX bja0m9uVAwAc9cfl7cCseeVzXmR7D4eEsGlQwydRVyRcMSRmtBIY412RpwKTyXY/KtamJnbTnOaY 6kjNayWspIBTNTG2hUDzZFT68VfOW4y6I5wp1qmepzWjqOqeH7AZub6GMDqd44/WuFv/AIjeCrKX ymug5P8AdP60SrxXU1o4OtVdlFm1PGfvpVdVx16mvJ9U+OnhW3aSCzWSVkLfMFIXg4HUZ5+leb+I /wBorU1j+z6BbRwOCMyzjdwOyjjn3NZSxcEejR4erz6H0pcwOSCAW4rlfFHhrw5r9uIvE0Suk3Hz EKzYHY+36V8K+K/jP461eOa3TUmtnmxukhJjbA9NpG38Oa8pvvEniG+UjUdUubkEFSXldjtIwR8x PXP8/WuGrjYn0GF4HraSnL5WPq7UvCfwX0++tRNqkDTQsWjR7gMPlOMEcg/j3zXz94y0D4N6y1/d 6I370riEQ74kDrjJKkAHP5GvJbjzpCSZiUHQHmoYkPUZI9q45Y5rWB7X/EP8PNfv22u2i/LUw5NF FujJG+6RTxjjIq/BHsjMXlbCMe+TWm0ZDiU/dFVJE4BjbByetL+0Kr6nRT4Cy2Hw0U/Vt/g3YdHb xRSNIFJ3AcehrLmTy1JwoGT19a1EyZFOcbRzVC+jWZc7uQeBXHUqybvJn0eV8O4bDK1OCj6IoCEI gYkHdVkhsbFwQD1qtlgNrjIA+lI8r8Kh2j+dY3R9EqKLLJwUAyT29KgixGxEmW5xn0pTKQpOTnFR RAyEkHke9Tc6Y0mW/NII2gk9u2KtmcOAw+bHWsYu3mBC20mlMotixKnb+VM35DaX+Pby2Pyp4Zth kjxuHXmrlnputXtoL+20yd7dh/rQvysBxwfY19Q/BH9nTS/iDp1/rniOd4kilESxR7lLHAY5Jxgj PTmt4wb2PPxGNp0o80mfK6mNcKrHd2zVnKsgZ2y+ePwr6R8R/AyXXfFreGfh/aOw0sOJZpWAGARn PQcZIHrjtWH4h+DM/wAPBHc6pZ3eoEg72jhZolOM5yuePU9qHTZjDNKMrWZ4XMYk6yY/GnRSwliD jeOles2Q0mK6jnuvDLzw/wAQkiblfbjitf4gQfCaTQ7ebwlEbXVxkyAK6keqnd8px7VlUgzppYqE 5WieRI+cZ61J8xbJ6e1RxeT5YxksBzmpQ2NpHIrlPWiLuCEhULd8mpN6KpIGSRSbzySCR0FOChh7 irbKIdxVgBxxUbAkqzDKd6lk3yOpPRfTrRgHG7j2FQVEpSDD5j4A7U1NxJ28VYlJVtuORxVcZRC5 rRm6ZaiaNmVVG1gOTVuOT58NknsapQkZDsuMjrV6MfOpJyorMGyU8qCOcGpFJYccZNV1G1m54JyK tKMjrwarlJcmPXLSccYqfLnOMgDrUMSkPg9D3qxuwhGeWOKOUzchykKcdzSqRs5HWmKm84zzUioN uc8VRAfwj5unaoCuZBt4zT92RtAAz0NMBCOE5J7mgzGPjOM85/lUTzNGd8RxjnHvUrRruz1qlKjZ 6cZ6e1XEiqfof8EvilF4709tA1Fli1PTrdNoZvmmVflyCcbjjqByOvTmvY7oZTaw5FfkPY6hf6Jq lvq+lO0V3ZuJI2BPVfp7cfTI71+lvw0+J+kfEfw6l4hVNShVUuoQCuybaCcA87TnINfR5Zirx5Gf iXG3DvsajxNL4Xv5M6+bA+lZ8gz9K0plyB6VSkBUj0r0j87gUZYCyfL8tfL37R2l2clnZ6z5QFxH tRpAOoGcZ/xr6qnO1K8+8f6Hba/4Yv7aaIORE20HuccD86xx9F1KMorse1kmKjRxVOo+jR+f2nXS rKo4CsML36V3STJ5a7RnjmvNLCxksrmSxmUrLbsQVbqK7izfCAIfbHWvxjE05Rk4y3P67yXFRlBW 2Zqbi/QcE0jZA6dDSqQg56mmYBOc1x8p7UmYOvwRX1kbecbhuz+NeN6nbi2lkgh+4OBn0r2/UFZo WRBgk968r1y1HktcfdZDzXr4SZ8tmlE7j4VXy3HhLUvD10zM9q5lT/c7D86z7yALdtDbgqFwc/Xr +tcV4A1SSy8UfZA3F8hQjtx0Fej3oRbiRWA39SK9bMKnNRPmcnp8uKd+pqWjBYdz5LegqxJtA6ck Vn2sxdRgdRWjlo+XUEEda+WjE+zmtTDuMZJAyTxkdqc0e+IRt2FWJIwqkgZz2FR7GMe48H0raMTn qHL6jFhTv6KaxrKcxa7YPg4aVQBXS6mMQngEE9a5ZkljmhmiGWjYMpr1cuj+8Xy/M8DOP4M4901+ B9kXgUrsB3blGffiuPuoWxhPldOV+tdXa4u9MtrlBvVlUE4xyBWdPaRNg4+ZuvPpX61Q2P5exkrO x+TH7Tmg3ejeN/7RntykdygELD7pbPzfhk14hom1Qnzc190/tm6HG+kaXqjBiqrKg446g18I6TBG IImjk7DFdB5tzss7UWLGTyajlJDLuPKggVImVTeeTio5CuQcZzWhkV5BtzKwwTTVIYBTyB82amb5 yVBPHrSEFf4QQo6CtAKrjzPvfcavqr9jbxHcaT471jSPJT7LeWqtLcSOEEXk7mD5PucH2PtXy0n+ 7tXPOe1Z0MExlZkfaHbPJIx9OevvWMncuG5+7Q+LPw8DeS3iPT1kXglbhGw/pweua9RsJ47pInSe OU7BIDGwYEN05HH5V/MrJeanFOySSys0cmQd5B4PqK++P2KPjZrNhr0/gnW9YZtPmCm0t5AzbOSW 8s44GWyR78dKxcDrUj9fpWCtjpu5qaGQsuE5GaoLMtwiyoQwOP1q/CML8nFBJbDMqnjtVdE+YvVz y9yZzUaAl9gFaGh+en7aEbx+JtIf/lh9nKIM/wAeck/y718f2kfmJER1xX6CftkaNbzaTY6nIuWg lZMg9QU6e2DXwVpsOIox7V8xmTtUP2LhH3sLG/RtG7Y24VBuySec1rQFyw2DrxVC2DKzMzHGOlau nx5DO2RxXz+J3P1LLvgNqxvG0y5juT8wXtX0v4f1CTUbK3u2GyRxznuB0r5Wuo5TA5JBbHGO3pXs fwrvbjVLZnef57UbCrdARXm4mn7pebU/c5j3cXJSRVUc+tdZprOy8tXA+cWZQ/510unyyhlG7iuA +YO4jBC1G+B0pkLOV61Kycc9qzY0dJ4VuN7yaYV90+p4Nea+NdIl07U3lV/MVhjAB4JrpdI1H+zt XgnY/LvGecd69X+OXheNNPsfE+mAeXchVdVGQp25zuAwc130PhPPr/EfFS2+ZCkTEAHPXkGvnb46 +HrPTfEuna1p6eSdQh2ygAbS6d/r6k19RywxpKzIMFic1xfxO8Pv4j8D3UcUSs9mrTZPB+QZ4OK6 aUrM4no7nxxpjSpMZIflz2r0KN3VoZAcleoHevPdEiaMrJJwEyOa9ARGZY1B+7g5FaTPvMnXum7H OHP70Mu/t710awGK1SEHezHP4Vy0ZG5Vc7jiuggkZEVgOnauc+gRBfptT0r9FP2HdQe68E6nazNu lt5+PoRmvz6vU3Dcy8EV9e/sMap5Gt6xo/I8/EuMjCj7oyPTtxXpZHpiUvU+M8Q4qWVVG+jX5n6O XXJNUgOD71bus7j71WUHB9q/QoH8xVepLGuMD0qXg5pqggA1IFzkV0HOgQcEClCYIIp8a4BBpyoQ RQZk6E9PSpwcjd6VGFx83rT+goMx4ANOXANCAYp2BnFZgJjBxT9uDmlHBpwGDzQAtSIKTAp60AA9 TTwvfvSBRmplArRaAAGOR1qRfWkUYOalAPWhgPXHWnjOaYoJ4qQIy8ZoAdnHWnhgRTQCeDT1AFQ0 A4NmnpQEApyj0pAOyR0oyT1pRx2pcZrQBo+lSDHTFAXtSgdqAHqB0xSgDP0pAD61IEPTPWrQDcgc U7gc0BQadhTxUALgdacMU7aKbxWgDWHpQopaKzAYeak420EHFKc7aAI+PSkxT9p6etG3n60AJk55 6VG3TkVME565pCDigCHbu49KbtHVu1TBalCHsKAIFwfu0oHPNXlgz1FSLb+goNDL5z7Up21oyWzD k8VVkTHWgzIFUDJzTSB0p6hRmkAPagBpABFIw35qTaaMdeKAK2NjVagO7gU3aeCeauWyKCMigCdU 2jdVtAxT5BXmPxl+L3hD4H+CNQ8YeLX2pbw74UHV2OQPpzjrxX4b+Mf+Cofxj1nxK03hy3g0uwtw VSMEgEE4yeMlscgnHPYZrNaBY/oLlQ/x1mzcV8e/si/tSf8ADQfg57jV4Ft9V0/ZHKVOfMbHLEep P419kTqMZatAKJPU1FjB3VIeOBTMY61MgEbOM04YXAHehlyKTrj2oiBaiHPNbaSW1vbSXl5IsMFs jSSOeiooyxP0FYkVY3xAiu7n4e+IrayieWWWxmUBPvZK8YqZgfhP+2p+3L4r+IPiTUvAvw6vbjQ9 F01jbq0LbWuSD8zy91UjlBnjvz0+TPgf8Yvib4Z8Zw6hZavcXElpNDKAZW8sp0ZdhyDnA7fyGOau /hf4p1jxNcapLaN/Z81zIJnJG4BCQcjOcetfTnwh+BHhrUPFemaN4atpBd6jPGsruXb90rAuAQfl +UdR0rJuxqqMj+iTw3rjeJ/C+l+IJ4/Kk1C2inKjsXUEipp8Z4qroenroOiWWi24xFZxJEmeuFGK kmJzzXSjIhJI6U3fg0760oC96AGs3eolc5zUhOTmmoo3ZqJgXoWIZW9Dz71+Pf8AwUl+Cni7xLr+ mePrHT5brTIYhBdvAAfKEkuI9y/eyxOCQMDjOOtfsArbTmq2r6VY63AIdQjE8R6q3IP1pchUZWP5 pvAX7PNpGbewtHklvpSq7UGY0L8AFscDPUn/AOvX7Xfsy/A9PhVo7X2oRCPVr9UMyAArGqrgKjdw T83Qfyr3XSvhh4H0CcXGkaPb27qSVKrkgtwTz3PrXbsFUBUGMDFHsy51LqxUmBYcmqxxjFWZOnNR FDj5aDIoOMZqLOOgq6VyTmniGgtlEDdwRVlECnpU6qAACKftANBAyqUtskjBmA45H1q8Rioh15oA oyIsfB5zXJ6qGdJAvIWu8a3DDJrAu7NcOR1Par5wPGpYSrMFXBqNbaQLkJxXox8PtcHeBtrRj0GJ AqKPrTA8qW3OemK6Gxs2bG1cGu+Gg2nUplq0INLhixtGKzA5uzsnTBNbkaGPjFaotx0GKaYMckdK AKo47VMrYFPEfPSpBH7UARDb6UHFThD3FHl+xrMCuQcVGc5FX/IJAxTvs2aDQzOSTTgp9K1ksuel KbTAoHYysZPNO2NjithLZD1PapFt05wuaAsYmD3qSt8WizLiKPcw7DGaZcf2Vp8cZ1O7hsnlJCrM 6qW29cZPak2FjHC+1XI13da53xD8Rfhr4YjDaz4isrfKswzKvReprzW+/ai+AmmQSTP4os5/JXcy RyZfHsO/4Vixxjc9xAwfpU46V8Mav/wUK+Btley21hb3l35ZwCseM49mwRXnOt/8FK/Cnnf2f4V8 N3BuGyA9xIgQk8DgZOO5/mOtIr2Z+mSFBVlN8fz7fvV+Kusf8FGPineaPctZ2unabdRj5Q8LyNJ2 2LyADnnJyOx9a8bvP25P2htWDWp15LFJF+YwW6ocH+HLFiPw/Oi5r7E/oFndPLLEqF7sSBtrnb3x b4U0yB21DWLSMxnBXzk3E/TNfzS+KPjH8UPFN3Nf6z4r1CcSqIzGlxJGmByAVQqp57kE19F/AP8A Za+M/wAere312ygbS9FuXIXUtQZmSQKfnZAMu3cZOAW4z3pDdJdz9bNe/ai+Avhyd7LU/FVsskb7 SFbcdwHzKAM5KkEH0NcBq37cv7PWns40/Wn1NlQsEhiYF2GfkBbABPrnHvX5w/td/sk3P7P+meH9 fj1qTVbe/knhllKLGkciruRdoLE7gDg+xz2z8KxwPIAl182zlT3yfXHWmHKj9mfE3/BSnwLZBLfS PCV/5j5+aeaEKMdztJIrzOb/AIKQ6ugnOnaDF5kpzAJWyFHoWGM/Wvy8ktsx8KQy1TjtpF+RgPYZ 5osupifbfij9vb47XogtYry3tbeEvg26BpmMh5DO2cgDgcZHXPavI0/an+M13e28eqeILm5S2mjm CsVUZU+ihc/RiRmvn50C/NICMHAODjNSrYPKrNjJfHPpinKK6Afr1+3/AKn4l1P4IeB/H+nXUkBW SP7RsJVnM8eVyF44btnqa/HBbq7iuxdPKzO/OW5znrX7OfBiCz+Of7JOr/DDUraYz6RatIkrPvaR 4cmIDndnK7e+O3XFflB/wrrxHa6hFp2oRbJ4WIz/AAtj29DjjNZFwZ+ofxksptN/4J/+G1lby5Sl mvHHEgdT+JzX432unm3QRLmN04PfIB4zX7j/ALTvh7UW/Y18J+HLKZGmSKxYt6iJOAB3HPWvzD0r 4NavMxeacTSSxhgvTAJyee+M0DPCtNsfP1mzsZF3PO4DN1wPcV9UeKodG8A+ElsYZf8ATbyLd5YY FsscA7ey8HB4zg1t+C/ha9hrDXUdqZ9sYT5sZz7V6hqXwLuPFJTUNXs4nm2BFaQBXVVJwpYHOM8+ 2aqUrjgj84IoEuLppPLaaWRuSvOPpVx9N1hw0osZnjzgOqcZ9/av0fh+A2oWkkfmfY0iUBVWGIBs f7RrvX+Cnh2KHzGaW5wAcRkqFb3HesZln5R2Hg3XL15IdOsZJJFy7qoyFz6ntW7b/DPxtcFttjsa Pn5wcYr9ifDf7MuuapbJfW+jNFp5CFnkba0ocZBVVwTXu3hT9kJ4bgnV5Bo6qFO4P5zSoeo4JX+R FZgfhja/BXxY8Ah1Q20BYbgq4Urnvzya2If2fpv3aN5lyuQG8tlABb19vxr+iWL9mP4Vi2U6hafb bleGmckyMowFXcfuhccFcHtnFdfovwa+G+gTvPYaXAEmB8yMRDBPY+g/AVMpWA/nksP2cLi+KbWK O/zKGQEbAeu4HmuwtP2aCLWRFt4JZc/xJsGPXiv3b+IXwj0fxRY2zeH4o7CeyTy0RUAXa3JPGOcj p3yT1r53T9nnx1cFldIYHJ7yCoVQ05z8yLD9npLeNYoFt1depSEYH512umfBnTPICLAZ/K+SXESq rHryc1+pfgH9mjT7SM3njC7kluQ3EUTL5eB07HP+frX0ZoXgDwdoFo9rpmnxokj72yoYk+h46DtW yq6GcpXPxOtvhpo2noftA+zh+AE+7+I713Vj4C8N2Fuk7w7FIyXHyqf/AK9fr9N4B8ITROo0yFHk 53hFDA+ucV4Z8XPgJ4b1bwdqdz4cjNnq0EUk0UjSNs3DLMGHocntx2rGrO4on5L6pqeha14murHb FBo+nrueZRgyMvVRt6k9Bz+VdnoXxLm8ZajpHgCzWKy0iCMww6fBx5sgBxJLnqzDk9s5PUk18Na3 4u1OPUrqyRSsayMMA/NkHkn1r2L4K6zb6d4ysdV1NCkU8TRSMf4O4b9K5DtR6r8bvhfNpGtW7311 EiFSUt4T/q9w+YemTjqDz1r5kuPC0Ec3nWuW25Axyce9fVnjvWbXxLqnn6SZJoYv+WzLtVsj+HPJ x05A9s14tPbGwnm6EdRigBnw8sNM8L+JF1u5kNspjaN+OG96+udL8W+GNUeKCy1CORmBYc8ntivk mC2n1BD/AGfG1wNpJA5FbGjaDcpiYfuCcAEHYRWlMzPsgFeABUD9K4Lwt4ss3tl029nDSQDBY9Tj +dd0jpcxJcQtujPfsa64MiaIGYOQFGCDQodZXJ6H1qcqS2UGPrUONzHeelaiIi0ccg65PpT+Ady5 zingAHBXAxmjAwCOd3rTbAjOe1PB5zt7U8L3P5CgqG55A9KloBNuegxTQrAHYacN2MA8CpVyRuOO KZbRXZpQdp5ApQ7gdOTxU4Cs25xTjGOijgUAkQAkAEHBFBVSQzAk1P5ZGAQOaYxKP83fgVm0EhNp 2HPanBiY/wB50NKzPGAVG6mlcjA+9QkERqgKh3N8o6CpkJxvB/CmKCRhhwP1qYYRdxHyiqiMjOTh lHAPNTKGL5HAppVn+XOM80oGzknp+tRIBVdtpT36Upw20HihBuBIGOaduUcEZqARDIEGVbsc1I+3 aNgo3licJmpWGR6UAMVCFJPUU2MOULMMGpMYG1uM96UNGMJk4FADBnoBzUnlgY2n5vent8pBHGaQ ckMTnFWkBXVirEAc96cjMQOMYpzbfMJXjNISgZVGcnrTAfgEgVCdzqV6Yqfcy8Co3GzBB5NNAQZ+ UdytNIZT8vXrV8qNijHPrUMicb+w4pAUGJPO3B9aTaSSc5wKmkwW2p0FQuCBlOB3oAqtMC/SrQiZ kLB/lqGPYsjFhgHpVuMHbuxQjQYyuAqdSe9KC4baDjHc0903bV+73qRgpfYw4IpsCo7yo53fOtWI W2OAoz6CoSFQ4HPYVYgcxkSSDnrisjaB89/FnWL3TL63vUYPl9hXNeYafeTTXsdx5HnPk4x2zXqH jvw5NrV3cSZUKCWTd1BrK8L6QmnIA672GPmxwWoNjqLGOeRlldNh7j0r0GyjDRrKz4GMD3rnJAsV sbmV1ijAJGeCcVF4QvJfEGplBGY7NAQpP8RrzMxzKNKN2fa8NcMV8dVSWi6trY9BNsZA0Kt5cki4 RwMiuJ1q1urARxXb+Y4P3lHX0r1yO2jhiSNeBFxUdwLeSF0eISSehr5qhxDN1Pe2P1DHeHWGhQtT vzLrfc89062FtYoHQj+LpUxVNjLt+lbl4FRACMf0rDuZM/LDjrzxX2FD3lzH4VnGF9jVdKW6KgaW IFePm6UokEaYcEt7VOnlqNrcs1RghXZfvDvXYj59iO2FDj+L1qid6OUkOQemKtPJGDtCkgVWbAbI HB6VUQFIwY1IzTHOHJC1MOcNnlaQ/KxDj71EgI45PnDBTWjFIjKxxjFZ6uYckDOaa8jEBVOKmYE2 yJnOeC1MK7Ay9cDiqW/GMv8AMTVoO4bDfNgVmA0KWTcwIzTdr7gOMHjNSecWAAUkZxirkMcSrjGD nvQZmNfq0EB44PU1nglEAxkGrOuXIMflh8EHpUEEXmwq+7BoNBduQGFGNp7GpDCGIBbirSRqPm4x WhmVEdi2GXd6VOwx91cGpZGgUYU4Y1Ve9jjHzck9KylsKWx//9D4mTfbMzxjcD1H419B+CNUtrC8 VGbKSR/M391scV4Y42IVQckda1PD+qPY3QTO95BgIe4rx4H0WJp2P038FXJ1PwzY6iH80SRgbj13 KSrfyrqthGMmvGfg7qy3+lW8dlKPICkbGOdrDqte4XEJG3g1ocJdtIwoArXTk4rDicoynHTit23c OPcUAWUU5Gela6KNoxWahBPPQVpKeABwKAJMbKQcn5hxTiBgZ5pSCCO9BokbmmoJcqgwTjn6Gvnv 9qy3MvgaxuGTeba4yB7sMV9D6eSQqgY6Y/OvD/2nIxB8OpbnYWEMkZz77gKzrfAz0Mq/3mPyPyb1 e4ciQSD5gcLj0rLtNhUbmJPUZq/rccgkEZ5YMefaqFuu/btPK9+wr5nEH9B5M9DYtnJcxiPGO9bW 18K56nt/WsKxeVpwEkG4nkdq6UbwgQqNxrhaPrUzDvEjYgt8oHB/WvTf2cEe98f6lKylRDbbYj6g kV5hq+2LCEknOPx5r1b9mktD8RtQjYkn7JhF98iunBfEfJ8X0+bDTj3R95xxFo8HoKkManGRVyBM wgY5FREjdivbkfz7LdlWYCKB3cZCiuUR/Nfd0JNdsyRtGwY/KetcY0JiuGXHAPH0r5jiOCdNnpZZ K0zv9LPlpHKwJOMV10MoZfl4FcjYsFjRQegzXRwt5g44r8WxKtJn3cNi6XO6pVbNVaerYrmaBoS5 csAB1rnr1Qc5HNdDORtHY1gXUrBHwMmqpjOG1bKoQfyrhGWWJzNAcSg4B9K7vUWVx8/3jXMQQpLf JuOEQ5I9a+z4bn755Gaw9w9ZtJALWB2bLFVz9cVsxNuAIOOa5q2bdtUcKoFb0DlQO4NfsdP4Efnt T4maJfccZqeNlxtaqoGfmFPVvmrSG5Bh+L4BqGkywBvL2Yb3OK8bs5fMXdjvjn8q951GAXFs5HLK pGPXNeJXFukF3NCE8oJzg+9fHcXYXmpXPdyWv71iQFC2T/DTmIkOR3qOLDIMdO9IWG7ZjIFfkctz 7JIzr+3IyVGA3pVC1sVWYGTmtuZSw2jgA8VCsUgfLDAFYjSNQIgUBRgVyPiK2+0wSMqYOBzXUxbp MBOnQ5pmpwsLZvl3EDtW+EnKM00VNXTPPvCMkltdeWznEb9PXNerq7AMqnk8mvDPtL2Wq+cmQxcD b6D1r2rTme4jEjN/9c1++cOz56CPzfNVaqzoLNCQGzXRWzjcB0xWNaKQo471uW8Pzg19BY4InTW+ do3Va5OO+KYiBYVwOaePUDpTImSg5OBxU68YHeoBg/N3qXOetaGZYPUCpAe1RpwuTTlxnBFBDLCM o6DpU+5f4T1qtgjp3qaMZ+6M4oEW061p2kZYEGsxBk9cV0enwbmXc2xe5PQAdTQBoW9g8mAFzVmW yeLqhr4o+Pv7ZmjfDGa88P8AhJTqeoxN5EjAGJbWYDcpYkZbPA4496+LtC/4KNfEe01G1uNftl1O AS/6THAEVpE4GELABSMZz/TigD9nJLfHaqMkeK8m+C/7SHw++OlhHJo0iafqIVTNZyPmWEnPXpkf KeRx+de03kYUBgQQR2qkxWMoGgkUFaQLxVEC4JyT2qQcgCgAcUAYJoAmWnAYqNegxU69aDQnhHzK K0NWvn0rQr3U0USG0heTaeOFGaoxnac1avrVdU0y609pBGLuJ4sEZzuUjpU8oH8z37RHxH8T+JPH 17caxdyS7/uCWRnEShjjAPTHevntfE3iC3vY3julVQ2DLgjaq8g8e9fXf7UfwZ1rSNbcR2bm4t5p 1SVCdksRfg4PUD36dK+SYvAnjO4vYrcafIvmkJlQZFBbgfKBmiLCzeyP24/YI/ak1f4oW914K8cX rXGoWAUW87YBkjRduCo7YAPA45yea/TaZQU3DvX4Yf8ABPr4YeJdG8dHxJdxb7KHzEclChT5SuDn ocnp3HPtX7kscQovtUgU2A6U3bxUhxTMY5quUAApwxxQQck0nBxRyhcfTQDmnU7bxUgXbV9tU/F/ hy18a+F7vw9es0aXA4dAC6MvIZd3GQRViHA5rSjk2LzQUpWPw3+P/wCyVaRX9/qFzpzW8uYY0eJX ZFXgEjGVyRy3oTxwMDw/w5+yxJc6lYrfXLyeRONypGS5h4J44GQMg/Tp6/0ZXttp2oRCG+tkmToN wBH61kx+G/DsT7oLCFGHcIM0FqSPmj9m/wCHFh8PYXGi2C2VjPjy1+YuHxhmJboW746nmvqyR8im w2sNsgigUKq9BVoWxeixE2Z+CwwKf5XGDWqlmw7VItpIWwoo5DHm8jH8vtSCFs1vPa244MyIy/eB IrNuNT0Kxz9rvYlx6sOabkluXDCTm9EReRgUCLdwK47W/ix4J0V/IkuPMkAyAozuz2HauH1H9oTw zbrstbR3ZOecID7A88/p71i68T06OR1puyVj22K3dmwOlX/J8oZlYIp7npXyRe/tEakZZTarHCH3 EAbXwCOMk85ryfU/jh4zuyVmuyY+2AKxeIR6VLhasz9EHe1RQ8lwioTjJIH864/UPG/gnTBI9zqc e6OQxsoPO4HB6+lfnbe+O9Z1G0aG7vZ2UHcAJWUA9OgNcJc6ldzAIZS4UnG4k4z9a56uKS6Hq4fg ucvjdj9Fr/47+AtPZoraVrp/QAiuEu/2lreOTbZWQ8rOMkgNXw2lxcyOTuIPqKmbMsgZiS3SsHin 0PocJwXRh8TbZ9Pax8ffFN3LIbKdIUYYwq8gHvk968+1T4meJdQtjbS3ryq/Xcc/l6V5VHvXd2p2 XHeud159z0YcPUIbxN671i/usiW4Yt9azJtRnZArE5HfNVCwOSODVed9gGDzUObZ30MDRjtErSTy jdkksehrLyGVxN8xqzNIzKTnp1qnJKhQIBknvUc1ztp0VfRHJagmyZpUxj2rEZkklYO21cdK09Sn EU+WkHpjpWFM4RfMK557c1Ezs5LBMAgyFyvrVffs5Hy0W8GsakQbGzleI8biu0D867Lw78LfiD4v kni0DSmu/s4+ZldQo6ZySRjA5rKz6EtxW7OLad2XH51XZvnyRgHoa6q48CeKtIvrjTdWhFndW2N6 yFSOfcEg/UEivqy1/ZJ8J2vhmPxF4l8Tzzfu0lZ7eNYlG5clQG3E46f0qlBmdXFU6VnJ7nxC80cT 7Zn27uhPArJN9GC0pbcvPavs/wCGXwx8L6l4r8qTSG1fTYRgPd4wP9plwuR9O/SvUPjJ4G+DVrpQ 8LaLYWNhq05AWaHClCSM5OSMHuD61TpNIzWb03NQjF6n5xwR3d6FaG2leN/41XI/Ic16LpnwW+K+ vQibQfD1zdQFFkLgohCP904dgea+lbz4d+EfAfhsXD6va6ldQ4SQwMEIHHJTexPuf8K6TwP8efA3 w/8AD8tmvnX1+/zeWvyx/KOF3H8+B9eaiFPudM8bUj8CPiPVvh3420rXv+EW1awez1JkEixuV5Qn GcgkdjXpPhX4S2dzqFnB4lsrpo7zC7VPlHnjcD1PNes6f+0NpyeKLnxTq+iRXkkwKo3ymRFHIRSQ MD3rl/GHx1XWb2bVdJszBcHBhy33CD7ZHT0rTlitzqhPEVI9j2PWf2Ufg5pGhx6td3d3ZypGDIWn yu/t16ZrD+A/7PvgXVobvxRrzxayyOYYYDKTGAG5aSPjBO3IB/8Arn5s1/4oeM/FEPlatdGUc4AJ AGTk5HQ/jXKwapqlrG3k3c1v5mciKRkB+uDUSqQWyM55diZRcXU3PtP4329npmpi1triCwsGCLDF Ey5CgckKOgBz7frXonhf45/B/wAKeCo/Dmi31zey2cDbYWiZZJnflvnI27s8+lfnddX896ipPNJK cYLOxY4+prMNnGH+XII5HNNVrGL4f5klNt2Ps/4V3vxCkgvvEHhDVUUxXLB4Z23K/G4AjvgN611o +OXxd81ob2zsmKHGSCBkd8gmvhiwu9Q09W+xzPAW67WIz79a2P7b1aWDy2u5Cp9Tnmmqwf6vJPRn 6IaL8bdHjsTN43ltResT8kSeYMH8Ofwr5I+OfiPwl4o1+PUPB9mltCcCUonls7HuR9BXiqPIXMjS MznuTnNPG7nPU1E6tzuweTqlNTvqOijO7kZz3qxs2Lwc01QygEd6kVSAfauY9weuehPHWnABQeCK cpK9FJJFTKGC7j9DQSyFduR3OKjIVcOAcjrVpUHYc4piBjww6dqhsqLMttxyw5JpAr7cdRV5wRMd g+WpREDhgeQOlWzVRKQRkdQTncKtpvXoOCMUkm7HzfwjinRRldpY8kVmNxHRD+919DViMS4IcADt USnk7lzjpWjGFdlUnJPYVXMJRbIVTZhT82OanwrFT0HpVxrMqysFIHerMemncD1X0o5jRUJPoZqM hY87ccdKkZJADHgHPTHaukSwRk2HA96a2kZjMhBOOmKXtTT6hU7HLyRbfuktj05pkMM0pMnXtgV2 WlWAS7W02bfO4yRmvRrfwPpsFykl1e+Un8W/Cp+dXTPOxUPZfEeGG2cAkjnsMU1bOdl3qhck4xj+ dem+JPiT8IvBQWO5u11G5LMmy0j81gy8HdyAMfX6CvcfgOfB3xKs5dQ8rEy/KIFUfJgnDA45zx24 rtpYdydkfIZpn8aUXJK9j5Ph8Ga3qTLFFCVcnjjj6mvqL4K+Fbzw1O81xEWuZPvuo4Cjt0r6mtvC Hh7S0J+zh5Sfvt1x6dKtC2sbUN9nAUn0r28Ll3s7SufmOf8AFksTSdGMbJ+dzNlRCOMjFZ0ig9e1 aEmWByelQMAScdq9Q+EMqQFhgjpTViEq+URw/FWmUnIHelQEc/3eazRofn58Z/Dc/h3xa15GpEdx nnGOK43SZoiu4nJPQe9fXf7QPhi61jwi2qWQDS6efNYY5ZTwRn2618L6VfIFRjkOp5Hoa/OuJcv5 Krmtmf0d4d54quEjSlvHT5HqC7mHTmhOmWGOeKo299HKgI4z1NWJZWCgA9a+S5D9RjXTWpW1AIy5 R8kda8j8V3SWyOJMqsnavUJLiArIBwwFeReLwbuASTfw5wK7sFHU8PN6ycHys53wvOg8W6bJFywl Ax6gkCvYfGjT6VqlsYCAbuXy2PXk+leafCrQ5NU8eWE7QedFZ5kYZIwOx4x3xxXrHxugubS+tGRd ipL5itjG044r6uWCTo80tj8zWbTji40o7kdrIyTAdQ3B9q2RgE/3QPzrmdOuGu7eKfgu4BPpXTwK ChaRfyr4pws2j9V9peHMUpi/mbgcL2FJuHR+Aw5rGvtVWK7EUfKitclZFVyvBFaJHDOZm3dqjxFd 3Hauclt3SJnQ4KZxXS3MqqhGOT1NZc5DWsxi5ABz+VehhfjR5GP+Bng/wt/aa8QeHvHT+DfFgk1O yeYxJIuFEKZwNqADOPz4471+hKXUF3bpfWnMUvIPXr29jX4aeK9Ovbn4i3LRZB88FCOPmB4/Wv2O +EInl+HGh29xk3McISUtncXXhic1+q4P4EfzLmq/eSPPv2jtFh1r4fTRyRO0lorzKFGSVIw5xg5A HWvyU00iO6aHoI+F/Gv3Q8XaeNY8OX2jXBZFnRoy6DL4PYCvxF17TZtE8Walpc4/49pmi+Xp8jED B716MEePI6G1k81SRxs6571I3zKAmOazrQb0QgmMRngf3qs7xJIHKbCD+dBkTPy5J9AKhB8v5f73 p1qY4wX/AIgeaQhD+8H3u1BmRng+3vUBysm8DIPvVtyxBzxt61n3iB4SFHPYjig3gcff2V9Lqey0 tzL5x6+lfYH7PHw0u4fFMGtQwyymEDcYgP3TdcuP7pHp3rc/Z3+Hdj8R9OurlyY5LEIjA4KlWzjj 1ODmv0X+H/w+0LwbFHFZQrHNMuXb+M4/hY9+ahs6Ej1bTlEdjCucsVUk++K2oGGD3xWRHIAMHtWz aFCo96RpBmkgDKD0zTIzslOOcU9c7fWodmJM0FI+Zv2trQTeBrcgZKyFj75Ar85bIAFkPQ4Ix7V+ p/7RNnBefDi68wfvFKYJ7ZNflNpxYb1fqjMv1wa+czVe+j9X4PrXoW8zooU2xtJ1JH61t2CHczNw pA/OsWNiGRSvymtu2dtpAGB/Wvm8Toz9cyr4S9NCWTKnkVu+BriDT9UxLN5IlcZx3NYCytsCNEWz 3FWLO1SOeO5ncfunDAD0rhqyuj0MVR9pCx9RW8w3fP8AMnY1v292uVZSQO1cDoV3Hd20YRs4FdTZ NLHOrMNyZ4rzKh8XUhyy5T0LT55Dk5P41vl2kTPQVzFk4Z92OfSugEo2DHHqKzApTgoVfsrV9xeE bCz+IvwaudMkUedbZC7cFvMjGR19fSviKfDRsvr0r6o/Zo8RCC/uvD9zJ5cM0YZQe8gwD/SvTwD0 cTz8WrO58UeJNFutI1Ceyu8iRH5HcD0punwxz7rK4A8q4Ro2BGRhhivqH9pDwH/YPiRtXijJtr35 y3XHHNfMNsqrOrhs7SOvSt5U2mcyXMj4M8RaX/wjHie90J/maByT6YHcfWtGzw0ke4hRj5cnjNel ftF6HZ2fiPTPEFrEIXvYwk5B4Yr3P1ryyyuA8bRoo+UAKDyM1U/hPuMnn+7RvQZSTe5yQfwreh81 nDDq2Melc6hJKoy8L1rTjaRsKCVC8gVzn0MDv0s0uNOZnbcRxmvXf2O9Visfi9LZpgfbbeSPlsEb GBBHrk5ryLQriO50422dr8nnvWj8C7xdK+NmkTL8qGcocejcH9ea6sC2q0Wu6/M8PiWmpZfXUlf3 X+CP2wuITu5FVPL7gVszbZMMBt4HFZ7pjgjPvX6dGB/IjqXK/piplGTyKEXFS4z0Fachm2GDnjpU oQ4xQgP5VIpNWo2EKAQAKlwKXjHFGKgBwXinKBTlX5acq8VmA3Hen7RmnECkI/CgB46GnJTB0NPX 0oMx3FTLgUwemKUccGtGBKuc5qYA9RUCntU65oQD1yalweuaiUnp0qbGAAatodhR61Iu09aYBngV Iq1AWJKKKB1oCw4+hqRQMUmw54qUIcc1mIYB2p2MHFKEOcYqQpWgERHangHH0oII5py56VaAYASa kVeaUKc1IoGagBoI6UEGpPlHanqoNAEKxsamEeKvRQFv92tR7aCGDzJMIo7setAHPbBSbas2OqaJ qjPDY3UU0kZwVVgWz9M1YmgCHb0PpQBlY/Ojb371OUAOaTHOaAIdvr1pdhqTGfrQMqcGgCPZU8S9 zTcZPPSrEajrQaF63RTktwqjJPoK8F+MP7Tvwb+CTpa+L9VUXrsFWCNgWyw3LnHA3AZGSM9q6r41 /ED/AIVP8K9c8b+T5xtotig/3pSEX9TX8ivxP+Ifij4i+NNS1vxPPLc6pcysymR95Vc5AyAOg44H HQcAVMpWKjG5/U18Ff2u/g38eZZdK8LXzWurIxEdpcnEsqDPzL+RO0/NgZI619F3CeWdpHNfy2fs w+G9c0/xnoPiWxWVZjNEsezPmeYxwSAPXpxyQfz/AKjtNLXWk2VxKf3jxJuz64FKFRS2FUpOO5Ds GOKOQOKssAuRUJUkVZkRANQwODVlVYJmo9hYnNOwECjpWlFGSvNUDhSAauxlmX5TSsB+Iv8AwVg8 YawfEOh+D2vfL09bNp2jHG51cbQcDnIxxk9K/ILw74an8W3ohWOaG33KjzBSUjzzyeOuOBmv6j/2 o/2V/Df7QGn2WqmMRa5py7Unf5sop3CPaeAC3JPJr4q8D/sLeJptSgj1+JtO0m6ba7QOu6Fozw7Z X5h/s9e+BWbfkbJot/8ABOjwGNAvdUaGCWTTlcCOSblWK4yTwOQTwD061+ttye3pXFeAPAehfDfw 9b+H9Ehwqj95K2PMlcdHcgAbsYBwK65mOMGnEie5VPykjrUZXPI7U5zyTQvGPenIgOozQR0pxHGK aT2NEQHr8vvWnHKHt3gyVDjBI4NZI7VIHI68USA+aPiD+yn8O/GWsy63ZwNp95ctvl8jCxs2MZKj jn6Zz3rsfhT8AvBfwuja4sLUSXsnLTyMXkLDPzLn7nB6DrxnOK9qWcjo1RtKTUJGjqMtSlMcVQkI 4xQXJzzTOtamYw4pDjtTynBqJlNADgOQaYc7sCn8gCgDPOc0ANyVFKJGxycUEAjBqM5A9azAcW7g 5qI5wfWlweCBRsYnNAEO0mkIccAVY8tqeEI680GhSWMnOaeVwMVbCH+7TTGTxinYTKYTil2ZNWhC QORSiPPGKLEFEpQV5rS8joKl+yj0pGZkgkHBqFlVmyVrZ+yZbGMUrWgBHOKDWxkLEoHSneQCcYrb W0YDhcirUdopI3pxQFjn/KUdBmjyPatyWK0t3IuZUt/99gKwtQ8R+FNKRnvtYtYsAnDSKDgfj7VM pWCxILY0v2Rm7V5frf7RfwQ0GCWW78V2zGHIYR5bDA4xx78V4Zq37dfw10kMdNtJNVRBu8xHEaN7 DdznHtU+0L9k+h9hixPfirKWiryea/Nm9/4KEafcy77DQpo8H7rTgIB/3z1rgdb/AOCgnxBu5xpP h3TrbTopXwZ5UNzhSO2NmOe+Tj0NZe2NFhpH60myZiqhMZqCSK2gVmuJUiAOMscAn8a/DfxV+198 dNetjZJq6WsbxNE7RoVkIJ6q6kYPoQM149rvxj+K/iuPGu+Iby/jA2iOSUgDb0xtx/nrVqaJdFn9 B+p+IvC2hhX1fV7SzjY4DSyqo/U1xniH47fBPwujf2j4ptJSF3L5EgmZj3AVMnA9cV/Opqd14iu3 ikuNRnlCElY2kYohPXAzjJ+lRQLN5n2u4lZpxj5yTkY6Y+lJzNIxtufuXe/tu/AfTYvNOpNcK3CB A2/PupNef61/wUS+GVqFj0nTJ7k9naI7ce/NfjcbTawPkKzY47D86YbaSIGVQUJPI6flS9oa2ifp vqP/AAUg1ZpZH07w3YQwdEE8zM4bnrwOPavHdU/4KC/F/W9OnhtPsekGTpJawnzIvozE5691r4gm spj++K4/DP8ASrSabcybHRMqeCAMH6kVMpXKtE+g9W/a6+PN5CFsfF935nO9wqI2CMcFQMflXh+u +PvHfiSf7X4l1u+vZnJwTO5IJ69yMHPpVaPRbyN3Ei7VHQ+tPXQtUdiILSWZX6MF4B9zU6j5Uc4+ peIJ0aC4uXnQja29mJwe2aynsIWKFi2RnksSB7da7nTvCfiGfzXlspUUHa2BuAJ962Y/h1rdy0a2 ykRtjflTkfjQRynlT24MbIyBu+ScHj361WEMjH98mFHc5z+FfTMHwM1SVEdRK5J6hchR/M12en/s 72hAjktpGmA+dwWUEnp8p6VmQfJdvpstzARG2FHVTzkComspw7BlChBkFsnI+tffWlfs5xxxmyMc sMgwfmOAfxrqD8DdOsUEE7R+ZGOQ4DA07mh+bFppGs3cpnttOlmgj5JUAZ+hNf0Cf8E9vEkepfCo aLNujvLPJeJjnCBto9h9B2wa+RD8P/D8cMUIt0EigAbRhfyr6Q/ZsvLPwT4xFlaTfLqBEboOFx7/ AI9KcY3HJe6eift++Abnxr8Gbj7Bbefc2DCSPC7m9Dj0Poe34mvxJ0/4GeIDsVgsI8sYeUNtz9AC a/pK+NWn2+reAL+znJ+YBhg44HX8K/PJbaytIk+zQquBjpnpTSsSj86rX9nDXZJBcXV0sikD5YlI x9a63Tf2brgTCeO3WQjpuY4P1r7jEYz5igKSeRinwuQ+7YD6gcAUyD5Rt/gPo6T+VLFPOqjOH5QH vjpx6Zq6nwN0QSC4WzjOwYSOUny1z1JwMkn68V9WyynyTzXOOc8dcUAbnwPttG+GN1bxqn2aKdDD L5RyN0jZDc9dvatH4zfBjQrbxrF4y0TToBZasqPKTgp9oLEOcHkbsg46Z9K5EzHbtHb1r6Z+H+v2 XiTSrfwnqzpczqu6Ad8LwAf9odvWk0FjP/aJ8NWF18N/C0KQj7JE6bNhyn3MMDmvjG+GlaW621uF j+UlBjoOM19uftHC30P4ZaZfXbGK20iUCR2JKonQFj6mvy/l1N9f8QxtY3AlilcqGVsgAntisAPe fDVjbwRm5iI3k5XPauzkvIjtMjnzBxXMabaiyt44omLEAZzWjJCXUkgA5/KtALEl0Z5RH5gX36Y9 8197fDn4fafo2gRXc6B7u7jAdyq+YvsGH8J6/WvgzRNHub3V7G0tGzM0yHnoVBBPr0FfqLaw/Z7G 3to+iIP5VhWnY0LUV15aLACcIMZoaYFQSc/WmpAAQ2OvU1cWNCMYwBXE6jMyqbjjLU0TjO5eKvmO IjAXNQSQJjgYrLnAUTBh0qVJQBVdVCjpQW4rPnNC79ox1qVbgjFZnJGacjZOKamwsbsNyc881X8T KJfDOqbB1tZv/QDUETDNaeoRPPpF1bwjLSQyKPqVIFO40fyKX90z+NdZNydsdrcsoU+xNfQXh/Rt RNvbTsPKhuEEi7uuDXkWoaHd6J8fdV0zVIvLSy1crOkq/KQDkg+oIGPfNfXWqXiaje/aYovs8YAV UXoFHQccYAoidUWa9lp0s9ksdou4KOcdq29C8Az6rdtLettiVeq/e/Oo/CcohkeHfw4H61k/FH4+ 6L8KbYeE/DWzU/E16hPnK2YbBWBAZ1wQ8mcYQ9OrdgbGXfij4i+H/wAGrFYBD5N7dLvCjLnBH8Q5 2g9RkV8Ha3+1B48uJdul2NhHArE5liMhK9snI5+grjfGuv6p4n1mbWtZvJNWvZI9kss2Xyw+706A DiuRtfB+qeIY1tbCCSSeciOGGJSzSSOeFAAJyegrWECWjs9C/aY8cx662oPbQRx2pHmNHHjqQPlB 7cfrX6v/AAw8QN4v8E6d4hMflC8j3hc5C56ivxc8RfCjx94Lukj8W6Vc6O7ZJhuV8t3HYhTzg9j0 PbrX7D/AO11C1+EHh9dS0+TT5BbqF34xKvVZFA5AYEde+e2CemJLR6RNGwk2g8CmBeuegq20WG3G q78HA6NWxmQGRSFxGcepp+c/KON3Sn7FEYTkc03y8qNp5XvSTAUhV69aVW3OCOQKcqcHdyfWmlCD uBqkgEYHOB3NPQEBlFMI+uKfuVV45Y8Ui0KgwxVhxSkZHPelUknkcjinMFzt6e1AMaEBIA4AoAVG ye9JjDDrtNNILsV/hqZIJAz54U5IpUTIZXOCelOjjxlgMY4pyjLDNEUESNUVG2PzStjZhuhNSkEE jPWohkZHUjv2oiMcoIcAHIp7uEOMZakAwd3rT0DE/OM1EgF37iMnHFOwh4x1ppIZmVR+VSFSCvbF QCGrkA44zTvLkABzmnBCeOtKQx4FADWBClc4A5pFYmMFe1TKu47T29aDhflC1aQDGJf5m6U7KoAR ypqSTKKOBUYjAIb9KpICFiC+RxUixBeWPWpAAxJccDpTMYYlTkCnygHlkKzZyBQOfpipM7jtPFMZ vbgUcoDMEjPapQFkIz9KrmTHDdM8Ckd9y8cc1JdhJ1WIlTwxqgpTeUz2qRy5BMh5zxR5e8jA4HWg LDNikqO1WldQuT2oVVVtwFIcl+RxQhkZIZyW9OKjLLt3yKfl7irEix7gw4qB/mkIjGQvWmwI1OcM o4rM1OadYWaJvmA4FbGGYDaOlYOukwxBSPLbPWkaI8inuZLuQ+YSQDytStJHp8QuJ5BHAo6nr+Aq trj22nI8wk8rD59Sa8w1HU7nVrrceYl4AHAGPb3ryMbmcaXmz7jh/hWeKalJ2j/XQ2tQ1ubW70iA s1qg4DHGTXrXgbUFtI41EYCJ37ZNeK2keQNi7FBxz3NdBp17c22YbeTYqnIz2r4DH151LO5/RWUY Glh4ctONlsfXXm+bEu0D5hnNQSMEUyPgqn54rxTTvHuoRRrFKw2KMcDrV7T/ABPc6pcTRs7MBzjH Qd64qKvKy3PcxFaMKbqTdktTrtSvo5S0cHKjnNY8cicgnnrVWRhBEVGSX/rVQuyOqE/jX6vgoWpR XY/jjP8AExxGMqV4vSTb+Xb5Gi8hJ+TtUqrtbjnPWs5N7y+WOc1pHcQVXnArsPEI925mULt+tBBV QQNwqU42BW601V2qMZb1qomZDiNUy4JanBk2gdDS8gYVT+NQu2TyM/SiQDSxZcdKiA4ODk9qft2A sx+gquXZhkDFSBG0LMCxIBB/GnTSnzVX061TeWZpfJiBd2/hUZOPwrrPC/gvxP4mvHhsrRvLA+83 Cn15oAwIrgElUH3eSewqKW7lJ+XIJ4B6D8K+gdG+AbRyxXFwkgZsGRWYlQfau5v/AIIWU5SC5YBO MDocVmB8S3Fjd3DpLMGVA3LHuK1bVBFF5KkEJ3znj8q+qb74PQfZJbSwyiyLsDnkKa5aH4Ba1Ni3 /tKKNE/j8vcW/MigDwhXTcQTgj8M04s5YoqdDwM16O/w31h7OaeCBmkiOCAAW9On9a4nXfBnifSo wJrWXfKCRyBwvJ5/pWgGLcTpbOIrlQkn909axZpmnn4wMdBWU1rfxyxrfQvHI448zOcDvz2rTitT FyOS3esq2wpbH//R+RJQfL81l2knaAfaslAFlF03+tGfwxXQXMDhGMp+VeM+prKdI1GeeBivFoyT Psc5w0oTs1Y+ofgLfCDWYwsojMoDSRg5GFUhcdhk9a+7FPnQJKvOa/J3wpr0+nXENzY7hJHgkj5S yg8gn6V+pXhDULfUtFt5YOYpEVkz1+YA4PuK2PCZoFGzwKuWqMJc54q61qRk02FSG4FXyGZrRphd /rWhHzjFZ6NkBK0IuKOUtE6qSeRUiqFPNNyQR+tSjBIpOJtFmvp6/Op/z1rxf9pdWPw9v4ZGyk4Q RD/bDAn+VezWjFCPSvEf2m5T/wAK5jmVcm2vYX/Aggj9axrr3Gd2Uu+JiflH4gy0pjhHzxoCfr3r EtyHjVN+d+SMVt6yr3Fx5sbbTzu+h7ViRwi0T9yuQnSvmMRE/oLJYe6i3p7NvBI2sCQ3rXZxQFcI W3t2PtXMaAXurorKAqnkf3jmu8m8qJVRVy3cjsK4pRPqUtjitZh+TJxy3f2r1X9mgO/xFa1Rh+8s 5P3j84IYHH5cV5p4iicxL5fdifzr039mSKST4pJbmMqPss7n0G1eP1rfDT94+b4n/wB0qS7I/Qt4 gijBrPYdcjFarqVQY5qk6ZPNeyfz3U+NlKUYjYD0rmnz5pPUmuz8odOvFYd1aLHPu6AV42dU/wBy zsy/+Ii3ZSsFUEdMV1lmz4HvXLWq4xgda620wFGO1fhmO+Nn6BQ+EvYYmpcHb8q05R3IpL2dNPsZ b+UEpEMkDriuWJpIpysGO3nIrMuE/iIxzVbR/EGna+C1s/zA1o3ARsAHOOtXAk4q/j3ux7joK4m5 iNlfKhbHm9Pxr0XVR5cbSYwEGQPWvL7maS6Jkl5bPH4V9XkU7VYnmZh8J6bYzKyqvHTn8K6KFiRt xzXH6TJE8MZXk967G3BO31HP4V+04Z3hE/PcQrTZoRMRwwqULk5WrVuiycEVaFv5ZOBW73MDN8ty CMYFeQ+LI0tL4bv4hnFe2urtxjFeN+OYZBemV+qDFeHxBSvSZ35TO0zmUyqgr37VcihZz71WtY8o kn8R7V0EMZOBivxHFx5ZNH6BQ1RQNq/3WHTvS/Zwx2g5xWmy8EAVEEAbCiuBM3nsFraKikHnJpmo onk4BxWrFEMAqeakubVZ4ioGXFdmHn7yIcdD5u1+3mW+kji4Ygnd+NeveH5Ea0SKNgSgAJ7GuF8W wxpfrFtPmL1x6VbsJXt4EWJGKIpO0dSa/ZOEswg4KB8NnmHalzHpupeK/D3g6xXVvFF7FY2Ukiwr JIwA81uij1JwTU/hj4n/AA78QTNHpuuW88iEZQONwH97H933r8dvjx4/uvEPiu6+2JdQQWx8sQF8 xbl4DBRkZP8AePOD26D5puNaubK6e7SVkdgw++VHzDHavvvZXXMjwD+oe3MM0KvCyyRsAVZSCpB6 EEdRQ0RRa/HL9kL9qy78Oa/ZeAPiBctdW9xbG1sr6eciK0QEyfvFwS5JG1W6jgc9v2EtdQTUbOO6 jBXzFDAex5B/GpcCCXcAuB1p0ZDH1xVcg8cdasx8N7YpmZZIJUYqVATkt2qFRtHB61JGP71WmQyb OOtTx9MioQOfarCntioLJk+/XUL8+mywBciVWX6ZFczEM7vaum0ybbtR+QaiSMz+d/8Aa6h1W1+K mtz3du9s0s2dzgrlFGxSR74z34NfE0qmS4YGQko/8JIyetf0F/tdfs0XXxD07+39Jt5Lm6gIjVI+ SVPOWweemOR/9b8krj9mjxHZ3rwy2lxb3N1LLHCWUlS8WCyZHG4BunXFax2Ab+yd8Q/G/gH4w6G+ nGJTeyra7ZFDHZOdrEk9vUe3bmv6YbeaS7s455v9YRhgPUcfrX4Wfs8/s2alHfRatLpVxeanDPgT MSkaGNsj5jjJJGSOfpjp+2HhQ3sOiWkF8hjnSJRIGwSGHB5BIPNTcDYk4NNwTjHSpXBfjFNCkNmr SMxRgcEU4DJ+UdKcQSeaVRg4FMtMcuOgqZVJGR2qNVKnPepVBGTQFxwGK0reQoQcdqz1Kv8AWp0b FAXPM/iH8JvD/jwRSzwDzUZmOQDuLdc5r57139nr/hG1tRpqRttlzgKoKhs89OoBNfa6TBMMO1LN LFNguuSKhJPcuMmtjyT4deAdP8HaWLa3QPOzM8kgXbuZzknHb8zzXqqggc09VjXoMUprRmU9SHpn FPwcDjNSIu7OaupbgAEDNLkEUQhNOEXPSrx+zREebIEB7n19Kryaho9snm3F7Eq5xywrGdZRdmbU sJUn8KAQ+1WEts8muf1jxx4L8P2cN7quqwRrcMViUOCzsoycAZ6dzXKXXxz8F2qb7YPcHtgcH8aj 6zE6o5VX/lPUxb7e1Wo7V5OF7V88337R+kwxyvp9j5kiD5dzDax6HcODj2Feb63+03rVxFt0+1jg jzl/mwfoM9qzliYo9Cnw5iKiTij7aTT5X42VDNJpdpFvubhIzuK4PXI659B71+bmu/HbxldOGOpP bpGOFjbufpXk+qfErxVfyO1xrM0gx0Zj09OtclXMUtj28DwZXes7H6l6l8Q/h/pBYXuswKYyAwUh yCTjoOa4K7/aK8B2s80NjKLpYuFfIAfHoDgj8a/LtvEv2hyLkb2Pc1BJNCUM6nnsAOlZLMWerT4H 11P0Q179q/TYCLbS7FWb7pyeF6c15prv7T/im4eS1sdscJG2OQYRj3yVGSCOmM9q+JGklmTK8N3J 4NbOnXccY8q4wxIwGNZPHvue1Q4NoxXvI+gNR+K/ivU0HnXzRv8AxOnBYHsT3Ark7rxZq09uTPcs fQVxwXeFweKlTgtld2Kzni2+p6tLIKMNkWxqVzcyq102709qs3UibcsxYntms07cgkcU7G75gOnS s/bM9CGXwjtEnRy2NowKnBIHzciq4wcfNg1Kr7c9/asuc6lhV2HMowRkc1TMJQEg5NWXZMcdabtP rmp5yvYlSN9h3kfhV9ZEJDgcVLYaTDqk3lz3SQqD+Jrorzw14fs4/nunkcDoG4pcwchzL3CE7RSR zpJkoc8cD1NenfDHwLoXivxRZW7xzThWYMobA+70bPbBzXtHxd+HPgDwZ4XSDTLfGpSSDY5b5iP4 s9unTit4wbVzzMRi6cans29T5ISC5mbbFG0jAE7UG48ewq1deHPE0USXFxp0sdvNwjspXJ9Ocf4V 9afs8eErhvO8TXcaR2mWSLeoPncjDZ9FIPf8q5f9oD4hW2oapFoFm2I7CTLleTnGAwx0GO1Eo2OK ON5qrpRWqPL/AAP8DfEXj+0+1Wl9FYQqTu3nc2QcYIFZ3iX4S2/hLUhp2oaw9xIpIcxR/dOO+cDH 0yfavoLwj8aPh/4K8OxaXpltJLMcPKQ335MAHJJ4HHQcfnXjOq/FGC81qa+tdKXzZp2mV5mDYdiT wuMADtRCMTRyr8zTVkew6F+zn8NJfC0eseII52uTEZZGZxGBxnoDjH5muK+Hv7NXgjWLm68SXup/ btJRiLe0EnlfNwRukBUjB9CAQcH1qx4k0/x34k8Pw6n4u1TNpKhKRQleA/PzbMDnHqf8fERpptJG t7WSWEdCC5A/LNb+71OOft3ex658TPC93q3ieDw74ehtrCEFViVRiN93U5Xr83t7V75bWPhv4KeA LiJ7oNM3LSlfnllIwTtXLEfToABivn7wH4i8IeCdRTUtWuHvL6Di3+bIUkEN/PAqDxp8XPDOt6pF d+JlFwkaERwJwig4JGQTnJFL3Ohx1KOIejTOa+GPgzWPiT48fxBqAP8AZiz+bcsxxx1VFBwT0wem K9t+M/xR0m00U+HPDhjvWkkVZAoO2KNOm0jg88cHj6181+Ivj5rd9aR6L4XgXSbBBs2ocyMB0+YY wPpXk7eINcgQ3Ly+YS3zAjIrOc0kehhMpq1ainV6HbH4h+Pra3FpoaS2M27I+zxNuOOxJB/SuITw X8UdZaaVNEaRWYsWllEWMnPWQj8fetCP4jeMIEX7NeeQo+7tUZArG1Px549vCZZdamMQ6qAq/qoB rmlNs+mpZRy6o7u0+BWtQiG51/WLTTUkUMYw291J6g9ASPrj3rYlvvhx4Nsb6xfGvX7jaEljAQcE ZDgD8SrH2xXz5e6jPqM/2q/naad8csSWOPc1Tmm3fu0yzf3ealVDengrP3ircIskrLGCseeBnNCR KvGKtNZ6wYvNj0q5dR3VC2fy5rsrP4ZePNRVfI0iRGK7vnIUAfU8Z9s1lOVz14NRWhxg2xgGnK8c zbScema9dsPgR4uuXjF/dxWaNnLEq2DjgYHqeK09W+CMOmWaXOta0hMeQkcKgZJ6En09v1qDf2ke h4wkcefmOKnaDkOK7vxTpXhSwsbKLSDI92FxOxG1Sy45Uc9eeO3vXJBgUA/ioNIxuRJEzAAdR1qd YRyMHI7UgwGByVNWiHcbuhPegv2ZXCbTlkxUyBcjAzUoDbQGNKqAlRis7j9giIq5zt7fpUwxgA8m rQhAJDHjHT0qicLIIVXJJrQn2D7F5XKkDbyO9TbcHB5BqRLSRflIJB710MejF7XzvNUN/drncjWO Cm+hi+Q20EYHHWozaqBktgt3NbH2SSIBTzn0qVIY1bfIM47VPtTqhlk2YkNipBC5yDzmpH01937t dx9q1YookZyzAK9XRcWkS4HPvTdQ7qeV/wAxyn9lXj7j5TY+tXodFfCGdgB6d63FmuJ8x267s1rQ eHNeu9oskMjMQDtUkKT6mkpnYsqXVHMjQx5m4P8AL6Vq29jDbncuFY9zXoGi/CPx5qUxSe3mj3YC kJhe/fNexWv7NsrpDLrUk0rLHuYRnkfl1rSnSqz+GJw4mtg6GlWokz5o821TiZtx/wBmqRvI1b5U Y/8AAT/hX3TpH7NWmBYzbaXPOHwQ0hO38817PpX7N+l3VvFBrGmWkUUZBVhkOMc87ev4120spxEn ax85i+PMow/vOpe3Rb/cflwg1KY/6PaO+e22uj07wZ401IgfZJbYHnDrgY7YNfrxZ/BbwxbJGrRx kx8DbEBwOnvXc2/gvw9AiK1okhQYBYcce1enS4dn9udvkfJY3xpwUXahQlL52PyN0v4I+K7uW2up JHQbxnKE4APsK0fj5+zX468Y+FrE+DjLLfwnDxbCQ68HnkDtke+K/X6DStNtwBBbRpj+6oFaAAAw BgCu2GRRj9o+HzXxVniFb6ukv8X/AAD+dXw5+wB+0D4iuU+32SWEROGaY4Bx9CMV97fA79iLxz8K r03w8URxfaFVJ40BfIXJBHHXk98c564x+mtFehTwEYpJM+Dx/E9WsrJWX3/meKxfBm1kjCalrN1c Y9Aif0NaVx8JPCkGlzxW8TtcbDtleRiwI+hAr1ikIDAqehrsVOysfOzqtu7PiG4tHtriS3IO5Dg5 qHysdq6fxFC9rrNzBIuJA5Bz7VhlaiUS4yMuRCrZqLHBzxWjKmBzWe45qeUu5R1HT7PVtOm0y+Tz IJ12uOmR9a/MX4h+E9Q8C+L7uyvYhBb3DtJARypQk4x6V+oyDBwelfN37Q3w7k8UeH77VtIjL6xb xp5JGWLpG2WjA/vMCQDXkZtl/tqbXU+u4Wz94Suk9mfFthrtpjyNxlDMclTwPrU+s68lpbcSZQg7 SeK8Vez8RaRetaTadcROx27XRkJ/76FP8U2/iKLS4pZ7G5hgLY3MrbfzxXxH9ktPY/Yf9Z48vuy/ E2bfxo63xEnK/XtVS8v77X9Tg0yzZWmvJFiiXsGc4UH6k15jZ2esXlwltbW8s0jH5BGhYt68Y7dT 7V9f/AL4SXcfk+NNeTM24mNSPu4GOnqM134PKrzVkeRmfEqp0pNu99j2T4R/D6LwRaPvj/0iaOMS l8MS4GWwcD5c9OBx15rjP2jFQ21kzj5ZCensMivo/CLwK8u+NOj2+oeB5rvyw8todw/vfhX1FbDL 2Lgux+X4LM5yxkKkn1PmLwdqPm6bHE4+eEY+tdnc6ki2+yLh2HSvIPD12bOSMFxIithgOort3u45 ZBJFwT0z3r80xGF5Zs/onCZhzUlG5Wksmlk3SdDya7BWQW8arnIGDXO3EuyHzO+Ksw337lN3cVl7 Oxp7a5Z1Ff3W4frXJXlw32R4I8s78AKeSewq/qF/hSshwvrXRfCjwhe+L/ES6k0L/wBk6edwJyBL KpGAGHPHf16V6OX4OU6iSPEzrM6dGhKUznvCP7Pl1FqOm+IL0RyLc5keNodrpu5OXyc8/wD6/X6p trGDTIfs9uoRUGFA6Cu/uYfL527SOK5W9jG/coxmv0zCYdwgo3P52zDE+2qORz1wvmJ5T5ZX4OM5 zX5J/tJaHHofxIl+z4MU5LYAwQecg/lX68LvST5f4ea/PT9sjQrUxWHiAF0ltMRj938kgJLH5+mR zx15rviePUPjm2cCPCk5P6VdjDkAEjJ71g2EreUrsdu7nB7V0MYiAxnJ68UzMkAAO1z14pcMjYQ5 HQUmEK4HLdqkG7GCOT+lABJGQmEOT396p3AMf3l4YVpBUA3LkHvVGSLzgCARtPU9DQCPp79jjXv7 L+I17ojT4hv4PLKZ+8QQwwD3Ffq1aoq5IPy/w1+Gvwe8QReEfitomvygCG3lUtngDcNh/T+Vfufa TxPbpKhV1YBhj0NB1RLaKxy3UVu2mFx6CqMShtuBweta0SLjgVmaRNG3+fpTZkZXBq3bRFU460NA 5OTQUebfF7T49W+G2r2hTdLHGXT6rzX5DQwi3uZ1JzliTjnrX7gappv2/wAOX9iqbzcRPGBjqWFf izrlsumeIr/T1O0QyMhB7FTg14ebQ2Z+j8Ey0nH0JYfmG0HgDvV6It9xThhWfF84U5yW44q1BGyy dckHFfK4tH7Rk7NqyDum0kgZq3Cql23ngd6ghUqg3kDHNJFjcV6bq89bH0kVoeh+E9Uczm337Ezt Gepr3DTQz9eQDXyvZXL6fex3S/MUbpX0JoGqC7EXlNhSMnPc1x1YHx+Z4XkqNnqlkDHJvJxWuH8w DHGK5O3usFQ/XNdVb/MvAyAKxPLuSyMVXmu/+H2tReH/ABHp16GYN5i52+jHmvP+vWnwXMkEyugw VPB9x0rowsrTRz4pe4z7y/aC02LxH4Ej1G2lUSKpZVIzvUj+lfmy6tp8xEgzu6V+l3h6dPGfwwht LzBuIYsNuwNuwHv34H49K/PfxNp6xaldW7N9yVwp9s17FRX1PLw8raHkXxe0aHxD4CupVg827s2V oz0wM/Mc+wzgV8oaW37qJR2Uc+pHU1+gdlbRXljcaVIgdLmNkO7kEsMfpX593FhcaFr95pUgJW3l ZRnjgE9q55bH2OR1b3g+h0Sr3HGOtWY3ByueveqkKtsJ656ipYYyzcCuc+oRvWMvlH7/AMvStDwl cNYfEPRryAlf9JjwR6l1H9awETZu+aqZv5LTUdOuoSRJBdRMD/wIf4UUqjUrozxdJTpyg+qsf0K2 4L2MDk7i0aHP1AqF1IXms3wVfR6n4L0i/i6T28bHuQdoyO1arqxPNfrFKV43P4yq0HCTTKyj16VI qkn2oCknHap8YGB0rQwEX27VKAD16UgTAzUijIyaADaelOGCdp61IEY8jpTwgPUYoAYF7elPC07Y q9KXoKAE47CnEE9sUijIqQKc5rMBoUgDNSKo608LkU8AdaDMaPQipBHxuNSooIq8kG4cUAZyp3NT LkcEVfNowGaY0QBxitAKwUZxipsE8UoTBNOAxQAir7VMATwBSL15qdRzigCPZkipFj+bmn7Tk5qV FORjmgB6QsRnFXUt1wN3HqatWsO4getfAf7Zv7aNp8AF/wCEO8Hotz4omUPLIwytlHnh2U8Nv6Lz zQB96LAkmShyB3HNRSQYPAr+c3w1/wAFJfjyviGPVptSXUreGVnktWhRY2jJ6EgA8DpjHoexr9+v hJ8R9P8Ai34A0zxrp6LCl9ErmMElkyOjZAIOc0DaOxePbj3pFX26Vclj6e1Q4C0CGhR1PSgrzTwv 5UFccdqAAKCTinxgFuecUAKD9akjVQeOc0Aaayw28fnTZ8tBk4r+eb9uT9tLx34g+I+vfDjwTrc9 loOlSCBhAfL3OOWDMuNwB6H8Oor+gvWEMmiXSR7hI0bhdgy2SpHA9a/kF+Jvw78ZQeN9bdrczXLX MqThRlVZGPpwMjt26dqzmzSCOn+Cnx6+IvgX4laZrGn6xcXLwTq0sUhZ4pdxAIY56lcg+o+gx/Vp 4H8SSeMPB2meI7mAwyXsKuwyCNxHOMf4V/NB+zp+zdrXivxbptlLbR6kZyJJIVJjEXIO/ecDK4z1 7e1f0yeEdEg8LeE9O0GBdqWUSx5yeSAOefWrTCZpzAZpqjipZFFQngYpmYmDRg0+jvQAzac1ZiFQ 1NGcEE0AeZftD/D2b4qfBXxJ4KtG23F9bER8kZcEFQMEHOQMY59K/nD1H9mbX/CPiySDXUE04fyU Hkussrn7yrnuG7+lf1KGYEGMqCvcH2rBvvDvh/Vix1Gwin8xgxLICwIPBB6j8DWVWnzG9Gtyu5+W H7JPwB1+98QWni7VLCW10rSJMwx3CeW5lTkEZHzLu4P0r9ZJy4G5iAT1A6UJHBZxCztUEcKncqjg AnrimSHeMVVOHKrCrVnN3KbKTz2pccZp5OwbTUZPHtSMRxI24FRc9aecdqbzWnOBGVPU0LLt4HFP J28VXdecmk5AaEd0AMU5rlAm0AAelZyjApT0pcwEryBmqBhk9aRRhulO/CqArbTSbTVjZSbKDQhx x70beKl28YoxxigzIQKQjtUgTvTtmetZgVgmKSrflU0wVoBWGfSnDd2q2sINWFtQcUAZu1wORRtJ HStsWORTxZMo6VmBglDjbjg0giOMAcCuh+zgYB705rIKu/HAoA58Qt6U7yf84rqoLESoGCg/iM0G KwQkSXEUZHXcwH9aLjscsLY1NHYs54rK1T4i/DvQrl7TVtctreaMgMpdcgnPXn2rz3Xf2nPgjolq bmPxHBcMp2lIgXcn2A60uZFcjPX204jnNJ9kx3/Svma6/bN+ElrbGW1uJrmXn92IjzgZ59M15fqP /BQXwjHbFtL8O3FxIAV8hmWMsex3HpjHTv0qZTSNFSZ90/ZPerkenO44Qn6V+U2qft9+PZgy6FoM du5+4JcPjnpkAdvqck15pf8A7bXx4uopoXu0ti6bR+7TK9ASpXBB4+nPSp9qUqTP2ma0jxsZQGHY nFZd9LpmnQNcXt3BbovHzyBST6Adz7V+Bur/ALQHxW1aeKY67dxGFAiqHySRyWbAA5PoPauQ1/x9 8QPFFvDHrev3VwYS2Cr7MBscYXAPIHX09hU+1ZaoH703fxY+F+mhUu9ftt5cRkKwbae5bB+VR3J6 V5/4i/al+CugAeVrBvizOoMMMjDKY64HAY9D7V+Fdqb+AhUuptp6guT/AFrXjgCeqhqnnZrHDJbs /WvVf26PhdZRMbSxuJpF/h5XP0yO3X8K8ev/APgoDqPyrp+ixzA/3uWHoSRX5+GHjCoMetVXgjUn ZgE9cVEqjQ/Yo+x9Y/bs+Keo2U82lW9vaOz4VkTftGeeuK8V1X9o741Xl296viGcLLz5f3AD7AV4 mbSWzRiOY3b7w6Z9+1WBa3NwU2Ru+4/KUBwePWo9qwVNHS658U/ilrl21zrutzXgflR5jrs9AOeg z0rir+/13U5PtOpX8kkh44Y8DrjkmtIaZfq5Q28pb/dNa9l4X1S+iG6ExDP3pPlxS9oxqKOFlt+B mZ2U/wALNu61D9kRceYvXsPT6V6zb/CzxRId+2Tno3lEjFb1p8EtcuWDTsQx6Hac4+lPUZ4nJZrh RtGwcjFB0uKf5/urX1JB+zlJfpHbzG5VZmB3qoIRj3YZB2+v9eh6eL9n24Pkie0JVPlbcwBIHG7H vRYdz4mn0hpJlgh/i6eij3pYNJv1Yxm1Z2U8YBww9RX6O6F8A9NgTN2qIq9AFyx9y1dSvwc0azjR IyJMNwSvIB96BH5kWvhfW7qVZItPkGT8u7gfrXTR/CTxXcxpPJbiCInPJDZr9JP+FX6G8iNdg/u8 EKhwGHow9K6qz8JeHrNWW2tBGGOWwcj8Ac4p8xPKfl3H8GdZupfLlnMSjkER/wD1q7FfgVqWp20S JcyZTj7pGa/RtPDekRo2VIU846/0rWiFvBCBGAFHAyOaOYz5T89dO/Z9u5IxBcWckzBApk3Dn3xX oOl/s56fZadFDc2a+dkk/vDkA9ORxX2ObmPlUwM9doxmqU046YzijmKPn3TPgjoVralri2jWQ/eU /P8AkTyKtxfCbRsHYAAeChztIHSvbDN2C1VwmTxRzDTOD0j4R+EbTe8sK7pAMomQPeu7j8K+FLWF I4tOQbAFBxzgDHPrTxMysAvU1JJcMME0SlYsbZ6PoOmB3sbFIGfncSWOR9elPjkjV9vBL9yKgkuO xqFZVY5I6VJPKbq3Mana4yB1ryLxPfm61FpFXaqHAIr0oSBgcHBx3rzPXArXrLF0PU+poDlOe+0s Uw3PUZPXFW/Dl8+larBfxttk8wHcfUdKrfZQJF253d89MGpmsyyCIMOuQfQirixtaH6baXqSeO/h +mT891AyEt1DL1zX556hby6XqFzp1wcyQSMDzx16ivrX9nXXo5fD13ZySAmGTAjbue5FeR/GXwXb 6L4wnv7It9m1FRKMj5UYcFQe/r+NMg8d3l/mzgj9amikABY/xDkVA9scqFPAPWljUfxHp+tBmI8j lCo6etUmxjjrVyUgkBCMelQyKhjLqwyO1AFKSRo8YXk1mvr13pAe/sZGjnhIIKnB4OeKs3MpKYXg 1lTRJJGVPG7g+9A0dP8AEr43+CfjF8J7nwbr2oTWuvxowitzE2y4nAwOVBHI5BOME9+a+dvhB4Hn 0K2k1rWbQwNdMywGQcHaBk9v8n8a+k/hB8IfBviXxY+o39r5tzCFlhZ2O1JInDZ2jAJb3zggEV9n fFfwbH4j8HskFvH59kQ0K7R8p/2T/D06+9Z2Lk0j4RRhnCL0/OnCRtpyPWnkJtIBbH68VX3KAOPl 96zIR7D8D2ju/GFtCYhLKgfBPOCP/rV+hLRDovSviH9mJYp/FkzpHgKhIJH1wf0r7ukixXn173KZ QCjaBTxjGKeVxxTeBXK2MQcUOMgU+iqMyuVyKhx2q8FzxVd1wTQBW5p6KDxUioDyeDVmKP2oQBDH uIIOMVuBMQt8xGFNVkiAwV/Gr0qEwSBRyVIFCWpUT8ZvG3w/8I3Gu694hubKHUJru7mWSSRFZgSx Cktk4Axx0xivnnS5IZpri2hIm8tyAwwVKjjIPcV8l/HHxP4ni+MPjfS1v5YVW/miKpIyr5YOMbQc Z98Uz4R/E2XTYpPDt+zPOhJt2f7hQfwls5LZPPtXRVoNbM6Is9y+IPxUsvCOmzroWoeTfIQrSKoJ TPHAYEHFfDd3r2qeIry51Fz9ourmQlmIAdixBzjtknPFfRnij4G+L/iDaw6pok6TTXM7TSjyysan AAycj3yPTFeGx/Drxb4Eu0vPF0S28Zl+zRzp913HzbVx3wO/4UqWhqj7S+CHhzwpo+nF/GjxN9qt cys6gLw24g98jA9KoeN/jJpen6pbL8MNOGmWcIz5i26JKzH72QAVXB6YJ45PXFeDDxV5strpsLkR sdrFuODX0h4R8D+H9a0H7RcwFWVipO7lu9ajPH4Z/EPxW8YWo8XapLePqE8cTyXJLlI93yquM7QO 2B+tfptYLDpmnWWloirDaQrDGqAhQicL1z2r4H1XRW8IairaWGtpt6vEwbJV05BGe1Je/tV+N/Ck 66ffWFrqwVcPIco7P6HHHHsK6KcW9iJn6AkCbheMUrWL8civirT/ANtPw02F1Dw/cpwA7pgDd37m vY9B/ac+FuqJC2oaqLBZU3fvlIEZIztc4xkYx6e9dHs2ZXPZ/JYNhzkCkMXzccCnaJrHh/X55otI vYrqS3RZZFRgQEf7rD1BrcEVnc7WSZCmSDhh1FRYDn2X+7071GykEEnINbbW0e8orDaKpMiD7pzi kaFFtzAADpShcdeoqdhlNo60x8ZCgc0CiB56Dp3pp2t82OR3p2CFIBpoJC4FASCNWPTkUpbZHjvm kyy4FJ93/WevFJkEm5uKd82d3akJHBFKclSg71BoIFdjx0pzA/d4GKYpKjalAjLdcgigBELZ2MMg 9ParSlBhV55xSplE2gY96FUNnI5B60APhiEbsxIwe1THaMEjOKrjqT1xT9jqQzcZoMxQC7FwcAUH LkhOMVJsBU84xScMcrwRWZoABILE8imgs/LcYpJeFyOppyg7fmrQBGwxwTn0p67iQrDApY02ZY85 prB2+lADHYBmA5xQhG4qKBGkSnqSxpcDnPymtAF25z2qDa4PPSrDCPZknDCmgsyYOCKAK+Du+Zfl qpKzbwI+KvDaVPc9qrThi2D1qGaFd13/ACbuTU6oUXaW+tLGgHJ4YUwbiCOlIBSG2g9ATilSOVTl jkUvD7UJ27TmiSRdwweB/Og0IXzwW7GkyVYr0PU1DIqtKNxwDzU0cZbLyHrQZl6FxGhdh8tcB411 m1VFt0BZsZyTjFa3jDXI/D2hrdTSKsbvsySM5xnAHHpXzTb65f6zdXVxdHIJ+QewryMwx7p3ij7n hfh76zNVJaop63NcXlw0iPvQHoe1Z0CbiwXqeta9xHujyByTziq6/wCjyFjjOOBXxlas5yuz9+yr LYUIKMUJIfJ2xxfepqS7JfLBJ3darxTAEyzcHOAaQSxQgSOwAY157ie1TnZHSQMOEzXqXhez8qKT UD1YeWB7V5doNi93qFvHEco7KW+neveL82ehWguL9hZ2oHDNwGIGSBnGTgZx9a+j4dwMHUc5dD8s 8Ts+nRoRwkNpav0RSmjVQWY/KOBWZ9n+0S8sdveuWvPi58N7XUBYalrkEe1A4IJZGDdMOPlJ9s8V wl/8fPCTQStplvPFnHl+YRuk+gya+9jCx/Pvtmz3y3szbsVTnA61P5SxOxLYyP8AOa+b4/2kvD1t 5cdxI9vcjAVJUBB/LvUn/C6vtzbBtGZMlnXJK+gx2p8pn7Q+hXky2zHA71PGuFyO9eUSfFzwWsDw pdnzVHzMVIVD6e59Kq/8Lp8N2rIg1KKKU8BHjLtn6CjkHznszxbU35rOATzSUOQev1rxPWfikmsX K6ha6nHNEo2iJFMe1uMkqfrXKSfGfxVa3Ci3tbeSAHjzQTuHrwRU+zFKpY+jZHUuUBziruh+HdW8 UapFpWnW7SR5BlYHAVPU+nANfI8/xm8TyXsMt3awPvfBiiypAP1J4r9BPgfdhwl/cjyJbuKMuM4C kjJFKUAjI+hvA/wm0rQYkn+zIkrqNzgcnI55OTg/WvYo9I0yzgEEMCpGOcKMcnqfxrnbPXFiiW2Y NIVHpjjtzXRG48yNTjGayZoVmI+6gIAqBrfzDufJxV2OA5yO9X47cHgjrWLQGFHpkM77sGrK2CRc BcV0KRCPFEsaSJ6UgOdn02zuUHnjLAcdqw7/AMKwXcEkU0aOjjGGXd/Ou5SBQPnORVaeQIcCtAPl nxx8HbK9t3udOCiVUxuwQdwJwBnPBGK+QtT0jU9G1CfSr+Fop4MblPbPI/Sv1eEdvOCJ24/u15J4 j+Gfh7XNUnvpoo1WUAAruEgx6tnB59RSlsKWx//S+Q1QOCIdzqp6MckGjZJncRwpPFXOY/tFzERG VwYwerN3BFahEc8Ku6mNmwcLyAe+a+WwVXm2P2DjLLnTakZ+lulrdxyTuI95Az14JyQa/Qb4OarJ fXE0I+a3gVNre5GAK/O+6gZpAydNw7elfSfwY8XzaPqMUm8SQ3MvkvGTjb6GvVPzWrT1P0UlXCDA 61mSb1GEXmtlEeayhlZcF1B/MVTdedpGDWhiRQ5GMg5rWhIVcnNUkTAzVpG4wKqRcS6CG49asRAl gCOlQxAnkdqvIDjOKkZoWqFWwRkda+d/2oLn7J4QhtCcrdyoV/4Ccmvo63EigFOcjmvlr9raaOPS dGs0OW8syj/vrBrDEfCz0cn/AN5ifm14lshZak7xPmJlBH1PWsJsBTwWz0xWzqkzXs5lmG5YyQAP r3rIxGmXUn5T0r5rEI/oLJan7u5b0xnW8jkjHMPyD1bNemNafu/OlQgkZxXL+FrSRpEvXAd5CNid xzivbvElhb22mCUcSgAke3euKUT341tD5+1MOZ2ldjtHQdq9g/ZsiZ/iNdvG3y/Y33n/AHiBXj3i W6CW+IUJIPP0r2b9llXm8W+IJIV3SRRw7P8AdYkPW2Fp+8fP8U1orB1D79jCm3VsVVk3ZyBxW/Na xLGqRDiljsAy8jivXPwKb94w0jDKDisnVIXQLIejECu3CWVqv+kPHDjpvcL9etcxrd7Y3igWcizN A3IQhuCOvFedmkG6MrHTgJfvUUbcFiAo6V0NmxQ4PWse0UgBulbcOTgkYr8HzKHLUZ+g0Ze6bcJB +9SalaQ6np8tlKSqSKVJU84IxTI1OKnya4Ys0R534b8JQ+FHnlhme4NxjIcAbSvpj1remlwGx/FW 7Im4msq5gGT8tOL1Gcxqm+S3bBzgV5pdLtOMbSK9WuUTqR+Fed+I08qSNtm0PX0GTz/eo4MZD3Wd L4biDWCSkcksPyNd3bbI43mc7REpJJ6ADvXnXhid/sYQngMa2fGl/d2PgrVZNNZFuJLd0JdS4CsM Z2gjOBziv3LL5XpxPzvGvlqHzP8AEb9tDw54G1ZLDQLFtWe2L/anVlQBh8qoOpI/iJ4PTA5rzLw/ /wAFCY7nxNDJ4j05V0qSRgY4HJlTfwmWbgherdM4r82vEtyBqmpTxsJ1ll3pJyA+SfmHbH0rzqb7 W8zu+0pJ1Hqf6V3cpycx/T54O8deGfiFpJ1zwndpqFmG8sywsHTzAMsnHQjNUPGOnwXtlKcbJFwS fUDtX4a/sjfEzxH4I+JNrommzTvYazNCklv5pWJGGRude5Gce4r91L5/7R03z2Xy/NjB57cVxZrS 5qLR0YF2qI8lgTyAuzkGtuNiQNowarG12Hb1A6VdhiYDJyDX4JnS5arR+j4LWJOFDE4pUiy2QMGp FAXHrUyEYwBzXkwZ1SEiXacEVb2YHy9aZEoJ5FX4wrNj1ppi5TyHxZpIufNmxucZ56fSuJ0oXbxv bq/lOxK5POK9e8Sxuhf7P9wfezXnNq6/aXfHJ7V+icIV/wB4fOZ5R9w/Lr4/fD7U7bxhqV1bSSpZ z/MjOmFaQDlQR1wa+UWsL/zpILuMu6DI/HtX7r+Lfh9ovjWxW3vowsyklG7An17/AJV82ah+ybBP NJMZSFznAXlhX7NQxGlj4qdM/P34U+G9X1/xppAsIds+lzJcSiTBjKK46Ee3bk+1f0l6BHHaaPZw RnIWJf1FfGXwX/Z38N+EboajqCi4kjj2mPaArFu56nj+dfaVmiwxKkI+RQFH4VrzXMmjVDZTJPNS xtkbarBSRxU0SgsDnGKhMyLoPCgVNFhid1Qxgk+x6VMByFFWQydAeR2qYAnPtUK5xt9KsAHP0oES xBgcetadtI6MD6VnxH9KvJxzQB0Ud3vUxmuduPDGgXVy1zNZRs7Hc3A+961oRsAMipFlGTg5oAyI NF0/Th5Wn26xjOcgc5/+tWuuAAOlOUkk5oCe1AAF49qTbjlRUrDAGKU52gitBNDMA0dG47U7AI6U 0ewoIJMjBxUgJwKjPA4FOB70ASDrwOKfz1HSo1wT1p6ng4NADgSelSCokA71Ix7YrMCToKTOTTeg xTQMmtANCJo413ydBzXCeNfGZ0rSJ/s8iwHacNnnp2ruo4VmTynGQRzXjfxm8L2a6JLqaSmHyo/k ixnzG789uPSlWdos68FGLqqM9tD5N1Xx/wCKr9vK/tSUKGZhtOAc5rkbzXNUvJN97cPKF4AZvXNY N3ceTGsa8sp5x2qg8pdySeDg18vUqs/esLlFFRUUtF5GpcXgaNSoO9Sec1Xlv7wqoWXp2rPDbn56 Cq8s5QnI+UVj7Rnof2RR+yivcXFyJG2TcN1rEnkkddrPk+tXZnR93ljn0xVJivl4xhqh1TuoYGK0 SM+Wa6ZvvZAHSoHYs3PBqTbKGbJ4p7R5HqRWcnc9BYRLoUljJf5OMdatp5mQqH2qQZCFQPrUEZC4 5qecv2CJzk4QmrITzDjgBaijIAbcRzUwkRNuB0qbhPDHS2FwTAIm+8K01LDvxWFbSo2FA+91NbKS bgFx8q1SZzyoWJzlvuipeAQq8EDmo+OGHHNN3hW6ZLVXMHsiYD5uRUu72qDJU4BxUgHviqJ5B/c/ Smck7Se35UZ+fcecDinfeBK9+tBnyFN4SWB/hHcUEOFLsxwPerRLDC4496gkjZiQvFBDgfYXwH13 4ZeEfDra7qupINVvHO+Ikh1AGMqvXn1xivMPi94yj8Uaw93BKXtomxEAcZTPH5jqO1eIQ74+R98d 6skSsuXO/P6V0fWHa1jx45Gvayq3d2fT/h/9oZtG8PWPh/R9HhtorJNjEk7cAAAqAO/f+dfO/ijW ZvEOsy6g+xRJjIQYXj2rJjV1YbepqYxF9xPykVnKpc7sLl9Ok3JLVmb5QHzkVWnhMyZUkVsKCQQw yPWqzADOBx6UuY7JUL7o1E8T+JE02PShqMn2OIFUi6BQev51yeo3c0/yyuwH161qEr0xisy5g3Hr WbqXHTwsexy0iM24MDVM2pVMAcHtXQtDnK56VVmQEY70vaM39hHsZJgG0YXG3vVy2t7m8dbWIhRJ 1zVeSXyTtYkf1psc5aTMR57dqL3NoQsjpLb4d6leTGP7bHGvXjniobvwVo1jJ9m1m+fA5/djPFV4 dY1Kz+SJ2Qng854rCu72a4dmmLF/c1nYux2dnB8NLe6WW2tHkmXgNIDXR6h4h0LTwkllYWjY7hBu rxqQSfZWuxG5SLgkDI/Sk0+6L4wrMo5PGaz5ka8jPVR8S7iwcvbuYw/8CLxWdL8TteuXO2Rwp7fd NcFPFcagwGnWbvt9KJNI1eFQJ4Wi/wB7ijmOmlgXI7MfEPxBDKXhlY44IY1z+q6/q+ryeZdTMVHO 0ZxWPDpGosmEAXd68mt230SbKEzhSvUEVn7U9OOUHNS3LNGN5zj9KY1wFAKLnH613x0mzTIlAk3c 4qL7BpuVbygAOMUuc6qeUs5GC3e8wVG7B4xW+mmzFNqrlhzWykcsIH2S0d8nACqTzWvFpHiK4gS4 ttPmJYY+7t49an2h3U8m+0cp/Y8wTJcAntVy00yGHBnk3N6jivYtL+DPj/XHt7e1tcGcA5Y4x7eu a6m3/Zo8T2l0X1aUlQOUBDYJ7gYyKcoVJfDFmHPgqTtUqxT7Nq/3HgDR20TFmcEdKnWa0jk2wRjc RjpnNfWmm/s3RqEnLSPIAPlxnrXr2ifs2WFrOty+nG54AOeOTWtHL8RPoeXjeK8qw/x1l8j89Rvl YRw2zyu2OAOmf0xW7pXhPxXrczwWduts6dpgV/Imv1L0r4D2luwlj06C1zjrgnj6V3Nr8HdKeLyr 9YkA6+VGMt3yx45+lenRyGo/iZ8rjPFnK6btBN/15XPyps/g34/vz5dyiwgfxK2RW7b/AAB8QNhX uVdz16mv1btfhV4Yto1jAkcL6nFdfY+G9E05BHa2cYx3Kgn9a9KHD0erPmcV41JaUKV/Wy/G7Pys sf2ctX86FZbNpTuXO3LDH4V7jon7NRkZfM0ZMZyWb5OPxr75WNF4RAmPTAqUCuqnkdGPmfMZj4x5 hUhy04xj97f5nyhY/s36RDCE+zxWrd2ViT+g5rvNC+Ang/SoClxuuZHOWYjb/jXulGBXZDL6Udoo +NxPH+bVo8s68reWhxmn+APC2m4+z2YYjuzE9K6mGxs7cAQwom3pgDirWBRgV0qnFbI+axGPrVXz VJtvzbYAYoooq0cfM73YYFGBRRQHMFFFFaENhRRRQIKKKKzA+afiTZeV4lkmA/1mD+lcKR7V6f8A FBSNcjz3TP8AKvNX4NBqmZ04zWY4rYlxisqVcGsyym0gHAqpdMrR7SM1YcEcY4qnKCRjtQXBnE6r 4d0S7uBqE1okt0jbldwGIIGMjPscVRbSNKksjaTWySRsRlWUEHBz0I9a7KeNcZPasOeH7zLWToQb vY6Fiqq0UjhW8K+F7LUF1Ow02GC7CsokRQOGGDwAB0pz7YEFvCgjReQFGBzWvcxMDkdawp1YNyeT QqMVsjOeJqS0bK5Yltp6CrsNrbXyvaXkSTwyjaySLuUg9QR3zVLaQea0bZtmCKdiacmnc/Oz4l/D rWvhjfS6ldIZNKuJnAmB4jZjuCt6DnCk9SD7ZoaVrkFzHbg4wADmv0iv9G0bxBC9nrtsLu3lGGRv uke9fJ/jH9lqKHNx8M5pImRGzb3MhfzGySMOenUDHYDua+YzTJHJudNH6lw/xdDlVOs7PuedXF1a yRFYjuIwcCsaS7CbcZX61zWsaR488D3i6d4m0eWCSRNyPEfOQ4OCCy8A+2az9OsfF/i7ULbRdKtX hnu3Ch51ZY192IB4xnivm4ZfPm5XFn3NTN6cYc/Mrep3GlaDq3jvWrXQ9NRjHIw82RRnagPzH8K/ RDw94dsPC+jW2k2Z3R28YQNgLk+pA71zXwl+G+n/AA70T7PEPNvJVUzzPyWfvj0Geg//AF16LcjJ xX3OV5Z7GN+p+PcScQzxlTlXwLb/ADOd1ExtGFxyK466CnG7gV1t6QQQeorl9RjcxkKK9Y+UOOu3 bzXCn5R3FfPH7S/h1Nf+HE0qXTItiPMeHGUlI4VsYOGXsfc98EfQ93A6wMwyHHUe1cR4n0aDxP4Y v9KwPOmjKoX+6GB71UTOUT8WLONgBBKcmNsE+1dDCVXKgZ96ra1BLp/iW/sbsCN4p3iYDplT0rQh VFUfNyaowaLCICNpIDDmnYl+YDjHP1FG0rmTcPlGfrUke2QqUbOOT7VdhChgzlRxx+dM8s42t0HN S7V3swBBxxSbWXAJwzCiwHP3KCK6iuh0jYEk8YANfuD8F/EA8WfDPw7qq7me5tly7Ls3MhKMQOw3 Kce1fiRcxgo+7ng1+mv7Cfii51XwffaTqUu86RdOix8AIrYIwPfNJo3pyPvCJPK2qT7Vt20OWyO1 VRGrsSo68ite1QkA4xWJqaUUeFFSmPPFLGMYFWdpBzWgFmzi/dY27sZ/lX4s/FfTotL+IGtWrKVI undvXc3J/Cv2404ASKT2r8hv2q9GstF+MF8tgpSO6VJnBJOXcZPX3ryc1p3gmfecD1rV5QfVHi8D KQpRcVdg+9uI5zWXaZC8DJrbgTyQrfeP+NfHYtH7lkz1NU/Mu7GBRGy45/Olt+FIfpg0qFQwVR8p rzFsfUwJlLIjv1HSvWfC2oxGJYVPzgAj8K8rDKsRKL0re8H3sNtqywzcqw59qxqLQ8rO6ScFJH0F YSSXkm5DnHWvSrZDHbqmfmxzXnXhx4N7TRfdJr0FiVPyHORXHM+KZZQLghqA2w7s4xUK/dHNNk3M p2DpQXY+w/gRrsDW1xo9wd4nTINeJfF7w9FputXFzCu1XJzgdTWd8MPEFxYa/aeYxUqxUKBwQa9k +MVi89qk4XKPneR2yK9yErxTPGa5ZWPkKymWKXYPuqa+X/jb4dudJ8TWutwRjyNRXcHU5BZeGyO2 OPzr6Wkje1uXjf8AgrjviXbve+FZlQZmiBZV9u9Qe9lVRqsrHy9blygcnr+tXrbEZ2d2rCs55NpV +i8fStm1Z3XP92uZn3ZpHarEMOWHWsO8ixLCx+Yo4bHsDWyFBJaTsM/lXP30rCJpFHzkEfhWYc5+ 9nwWuIr34Y6JdId+61jXPY4Fd1KhY4HFeOfstXQvfgfoT5B8pCmOONpPpXtsiYOc1+pYKfNTi/JH 8i5zSUMTVgukmvuZRCHNPAwKkAIp4APWu48Viqm7k9KnWLNTQRbsA10KW1ulrJczuscUC7mY44A+ tBmc+EwMUoWsG3+Ivw71C9i06y8QWE0s7FVCXCMSR6DPJ9s12720OA0TB1PII5BHqKAMRl+ajaDV 2WID8KgVDuoARYyo6VIFGMmpgpIpCMfSlYCIKAal25xgUqqMmp0XkUWMy1bQ56rxXm3xk+NPgL4C eFH8XeOLoQxDiKFeZJj1Kovc459AOScV63bDBViMhev0r+a39v8A+KOv+OPjjrvhy7lZLPSHFvbr vymxSfmCjoWxz/kVLQH6SeFv+Cm3wp1/xHDo2r6TJpdlOxAuvOLsgPC5QL+eDX6I+H9e0Lxbo1v4 h8OXsV/YXShkkiYMMHkZx39q/jQtbDUppnlsIWZojj5ckj1Nf0x/8E+r6+ufgXaW11uEdt8g3Lja VCjaPUAVDZbgfbBB3dOKNvzdKndDjOaYFNbEDgBkcZqbC9TUanHFO4xgmgBy/e4qzFxjNVh94bfa p04xmgDdtyyxOVQycY2jqc1/Jt+2rfam/wC0D4yttank3G8YgOMsVDcZ9sDj6cdK/rDgl4+UleMH HWvgT9oz9i7w58S/E48b+G44o9WuGPmRyxqycgb5GkYFiWwAF9vbmZSsa0km7M/nD8FeGdf16QXd paOtqBkuRhWHt6k+lf1LfsZ+G9T8KfAnRNM1SLynMSuBjswyP0r5w+Fn7G0mjarbyeMMC1t5MiJO N567WxgKvU5yT6da/SLS7Cz0TTotLsUEcEKhVVRgADjAA6CiMrm9fljFJFqTHAFV9oJNSP8AN0qP pWxxijgYo6UUVmAoGfpTl+U57UdBTep9qANOJ24ZCMr6186fEX9m/wCG/wAQNbXWr20FvekEM0OF UhuuR0yT1r3sbgeDRkjoeaTQ07Hj3w1+CHgr4Xow8PQ/vnBVnbBbBOf1717VM4ZAoGB6VUwc5p2M 9aYNjTzx6UKO5pQMUHjigQcd6b+FP5704A/jQBDtIo5FSUFc1mA0H1pwYn8KaAO9OC461oApNMPS pNvFOVARQBXAyORmmEc4xV5Ye1N8k88fpQBSpCPSrnkn0/SnC3Ocf0qeUaZnn/aFN8vNbH2XP3qf 9iJqRGSIeOOtKIfzraFiwHPWnfZMfWtLlwMJosnAFMaFga6VLN+rLUz20YXLLWYzlfL/AL4pxt8j it4fYBMLd5oxKcYQkZOfQHrWBqPijwdoySzatrdpaJbkhzJKihSOoOT1rS47DhbZqQWVeVX/AO0r 8BdLuDazeKbaWRfvCMlgv1wK821j9tv4FaYZ449TleWJsR7ImfdjuO34ZqZSsV7K59PLaLn0xUyW QJ/+tX57az/wUb8E2t0yaV4aubmJeA0kixE++09Pof6V5Hqf/BS/xHdTtcaV4aS1tCdihn3tnkZ4 4P8An6VPtBexfQ/W9dPb+7+lPFieQyEAe1fhzqn/AAUC+O1xuk0+4t7UMCNpgDHnuCcdPpXjV/8A tUfHy+M8q+Lr9Zrg8ojIEI44Hy5/Wl7Q0hQfU/oiddOtCJbq7ht1PA3uq5/M1zuueP8A4d+FVjfx B4l0+y84FkEs6AsF64Gcmv5sdS+IHj3XWCa9q1xcN8zKskzuiknJwpOB17duKwGu9QRnae4acMME OS2M/wB0ms5TbH7E/oUvf2tfgBZfupPEsDyjIKLnII45P1rxrxB/wUF+Dmlwyx6BZ32qS88lPLjy CQMMc9cfyr8PnUDLx5BJz1qGJLhC43MVc5wT8o+gpe0sbRpRe6P1guv+CkE0TloNAhWIAhVZju57 kj+leNeJv+CivxS1WWa00SxitLZl2rIBnP8AtbT05/2unpXwslmFjJ6kdav2lh5sH91c9aOccoRX Q+j779sH476mRGdUMSEnBj4wfwNeZ6l8Uvibqty91c6xcL9oOZFWZ1UtxzgGuNW22SrF98uAFC43 MfpWjY6Brl1O8X2FoyvIZpAAR6UrmNijcapqxjnkeeRpT0y5YZ9Tzk0+1lu7tI3uH3yovRRtrrI/ B2tw4kuNPl3dDtAYfnW7H8K/GN4iXmn2zRxHorbRn8zWdzSx5rt8kPN86MfvANyc1FZp8/Kkse/W vZk+C/jG4khubixBgz8yxyqQT7jrXb2nwE1R2X/RGjDj5jGNxUH1BpGh87TeXGglLMpHPPXNRoC4 EjsxLevcexr6xg+A1lLN9mnEjhQOSmCRXp2j/AqzkT7JDbqkUeDh16/jQB8EC0VQcr85/g/i/Cta 18P6hcAOls5U9AMk1+i9l8FvDloyzX1nbtdJ/HszXTR/DfRIT5qbQx9FAH6UAfnNp/w61e/tzdNH JDIp2orDt7mte0+F3iuZsExtGeuDkj8K/RuLwNoe3MzNKo5K8AZq3b+FfDNiSbaxG5h97cciswuf AGn/AAU8U38ZRi1uEPQr976Gu+8MfACa1eR7q3Ms0/H708V9skRW8SiIYA4x3pJJUGFI59cUAfL0 XwHsI5PKa22k/fQN8hrcsfgpp0L/AGf7GsIPRQeK+gVfjBPH40hdQ2WOW7+1AHmy/CjSfNjSQYTo c8it+H4feGbIFGiEqjjGOK6kzjOCflqu8pJ9FFADH0zS2lRhAqKgACqMAAdAKuJBp0R3JCPx7VQM pHQ0NNtXmgDQ8yBCWVahkuI5AQRis77RhTmoPN3ZIoMzVaZWXjtUX2ggEZ6VQErDjHUUdQM1mUkS NI27OeKckjD6GqzsAeOho8zAxWhJYeYgEjkVXaTIO7oBTJWDDavFRN1x2xQaCBl6ionOSDmjocU0 tgGgzI3kIOBUZZRzUBfIPtVXzCQazAtI4z606RuBiqKuqDg5pPNY9eK0NCcnLZJpnzYznGKhWYlT xnFIkwYE+lAFp5ikRA5Jrjr5GMhLjnNdC0jopPUHpWJel2Xn71AGSV2n5h1pVHI9BUoVyuWFVZ2M K7V6mriB9B/AlxHrcgjYL91gPUjqK9y+MOiT6z4WWeFC0lmSSo6kcZr4/wDhn4ibR/FunrOdsLvt YjvnPFfoVdxG50+aPG/7TCB+YrUzmfnBMVUlRVWuj8UaTc6PrFzaTRFEjkKqSMZzz2rHMOCrHowq ZGZQZVCuWPUcYHSuRlvJ0k2RNwDXVX9wsIKtxnp71x6RNdtK0X/LPk47VICreSO5RlpZZFPyd6yL zWvD2hW8t74i1OLTbaLaGklyRljhR8oJyTwPU1454l/aT8AaGudDY6tPzjgogx0zu9aCZSsfYvwm 8UXHhHxELqTH2ZuGO3cw3EZIyRwB1r9KILQXuliRR5kd3GCSpwCrD9Otfzhav+2HqEai10vR44p3 OGJbdhT6dOa0B+3/APtDQWNtoei38dhb26+UqiHcTGAAoJJJzxy2efbu5RaIlK5+lvxO8HHw74wn a2tpIbS+TzowR8oPdFPc9/xryTUTbQ+bE+UljXcUxyB2r8t/H3xz+NvxI1Yan4h8R6hNJGCEVZGW KMMAGCqpAAOPr715udW8atPLd3Gq3k10/wAvzTv86475Jz+NZ+zKVQ/ok/ZPntNR8Qahc2Mq3MCI AJE5Xco5GfUZGR7190TqV61+Tv8AwSss78eE/Empal5haW4EK+Y275YwW46jHzV+s912rysQ7Ssb mU3WkK5qQ4zS7fSuMzIcc1LgYp4jwal8rcOKpMCsqjPNPMYbotWEj2tgjNSxtFPnyWVgpwSDnkHF UVEorB2xVhItvFXPLC80bQeaChyKAMVZ3KqbmOAByarr1qyo4rSnuJs/jY/aZ8SX+nfHrx7JBLs+ 0apOpO0ttVm3ZGB+tfPumeKru11OC+t5i7Q8A7WxkkdjX9Cvjj4P/D6X4heItQ1HQbXUftd/M+bi BHBO7JzuB4zzjpmucPwy+GzK9nN4Y0tIQcqiWkS8+2F4r0LXQORz/wCxNoOkfG/wBqcPiW7msL/Q Z1Z7S3by2ks5YxskLHn5nDDI9OlemfFT4D3fg/ShqHhLSl1nRpsrdQyKLueHHRzkH5SueR0I9wKd 4W8P6R4V33Hhq2XSWMflEW37rcmc/Nt+9kgHnvXrGm/E6+0OyfTr6P7ep45+8AfXNR7I1U7H49/F b4Tp4ansvEvhyJv7KnwrgMX8qU89SSxDcn29eRXu3wn1q0vbaPw+Zl+1wgKI/UdzWv8AtNatqiXk N74F0cRRb3kngZDOsjMc5EeMYA6n15NfGnw38S61p/i3+29OufKe3STzlCDBWTIKgHI6ke4xkdKz asbRldH6EeL/AAtpl9pN1PIo+0Qp8jd1NfA3jfwisF5Lo2pMsc8mXdB95QfusfTPXB5x9a+z7L4m aXdWEX22Rh5qgyAITge+K+U/jL4u8O39/Pe6fciS8SQAIqjeVUY5cHOD6HpW+Dk3KyMasj5p1LTZ NHuTpmoNvwNykdx/jWRd20LRGVAzmU4IJI4+ldDqTN4hVoIw0s4zswcEn0Fcfrvgr4heGoUvdb0a 9t4doeJkRnXBxglhx39fX0r2EktzncTVi1zW7LUrfVxeXLvZFF2rKykog2hdwIIGBivc/C/7RXjb wpFcxWrpdJdbeLgPvQKcj7pAznqccjivk2TxNbxR+asmSzBGQg59/pW+morDLG2AVk9v5VMqSZKl Y/SHw1+2m93bWH/CYWlvJFICLl7ZGhaF04GdxIO7rjoO5GDX0t4c+NPw38V2ENzputWtu7nb5VxK scmf91iD2PPQ1+KPl+cJGYl1fjbjArUstTu43Ns6JKoXkgBXVR/dNc8qJtGofvXBLaXYV7SRZ12h g6HKkEZyCOCPoarMMFnJ69K/Lv4Sa18fvD+kprfg7SNTvvD9zuih2wvLbl8lSFwv3gw/h78YNfp/ 8NvCnjKTwlZ3nxPVrG/lRWe2KbZIVJz8+cfvGzkjovQGueUbG6dwBOOtPA96+jLH4UeGr60gNnLM WlwQwbOQfbkVS1D4E6xunkspSsUQ3fOvzEDsBg5NZylYdj5+56Zo3Iv3vmr3SP4GeJWBWIeYAM4A G7n2rKl+Gkfg66jvvFEpWORiqRnguwwTgDngU1OPcSR5Oo5IZcAU1pAjgbT+Few+ItU+DUOjtpNr bXcmo/fM6jaS/dSSxwDx0X+teJebIG3OrD04J4/CspTiuoy+iPJllXnNW7e3mlBEnGfSnWNjeXzb YoyGHSu/0rwnfOu6RSCOcHvUuYHNW2h3E7rHuGD+lXG8IagzExSDYvevT7Xw2RGkjsQT/CO1bB0s wgCNjxWcZgfPN3o13ZOfNbHfOKpln25J3ba+mo/Dkeow+XcRBk+n9a8a8f6dbaLqI0a1VVChZG2j HDDOPwrdMDjg5ZQqjqeTUqBQCehHeoG+RBjuKUMwGD0xRcCwseTuc5FWSinnHAqEMGhCdCPSkM2T tUdKYCswU7F79aRgiY5zUiksu7aAaaqAA7h1oAjlOADmoizOwqdYt3zMeBSMm1cgdK0AhUMU3Yz7 UgDbSwODUgBQDJ4pFCuTvG0etAEMi/KMcVAyDALE9andlB+Rg2O1V5WYEEDPPSg0E+UNnPSjp8uD 83epF5HzAAVGJsyYJ+UUXATEP3TnjvWcysrnacrnitJ2jyQnzH1qpsZnwT16UGhEB5jAAgtV7BT5 OuO9RwxRo/T5vUVxfjfxbonhe1nl1USx+VGzgL1kbnCL7n3wPeuapNRV2dWEwdStPkgjzv453cia Ppm1i8CXgJAPXKkc15b4evLd7uGwC+WkhwW7A15Xqfj/AFDxTey3F6GSFypSBidsbAd/7x96uWmq T26bbZl3Lg4J7+xr5fMpqo7o/ceFsF9Vpqm99z3jUtNaym8jk5HDHvXLuN/zYyF45qfRvG0GqQvb a+/lSqPlY9qvGyt72E3VjcxvD/dz8xr5+cD9Ew9a5zhj/ebCMrnjPf3py2j3dwlrgqhPUD/PNdHD 4dupEKLj+9wea6TzdM8OWC3d8UMyfMEbq3/1qmlT5jStWjT+IWfX/Cnw100azrk6wh1MUKEZaSQA nHtkjGTx618AfEP45+MfH91cW2pkPpRYrFErbVh2vkHA6nGAck5rn/iT8Vte+Jl3NFd3EktoLqQx Q8KqbTgYAHTHH8683WxRY9xjYOX6ZzxX6Nk+Wexprm3P5o404hhjsTzU17q0T7jQLqcuLqdyhOVA Y7V+g7V0+maldRxRpKzSe+eg7Y96m8OaGl/q1tp88W23Z8tICAUB5yc8Gvpr4o/s4+GvA2j2Ws+H fF0OvT6iqusEaIrKHG4MdsjkL7kDnjtz7ct0j4GcrHzzDqfmXBt3RfLYfeblj7g06TVL3S7gCzLK /HJPb1qjPYrEwjnG+SPps5GfrSmJpOoyUAxnk03TMOc0v+Eg8SFjIblHV+D8vUf40xrueYTrJgtK MFmHzfgaooCgUkYC/LjvTkjXIG7J9+hFUoC5mXNPuLnTnLwOyiUDcclsge9dZp/iTXrGIm2nEgmG cSIHyfTmuSikxACgO9SRyP6VpwaijS+RJ94Ddx04p8gcx7P4S1bw1LLHrU6uJnXaySY4cdQB2HvX 1p8GvFPiLxT4oj0bR52MIHmTL2CqQOvY89a/N9NTMmoRPdgL0AxwCa+2/wBnL4kW/wAL9du4NViS 6trmNHO0/vEbOQAf7pB6VzVIFwkfq7ZajJaFbaQbscBj6V6joU41OIqP+WfH6V8yw+KdM8XaZH4i 8PSS7SWXypFKMCuPwI56jI/KvR/CnxV8P+G9NNtr8n2ed2z0OeO5xzXFKFjeNQ+gYbRUA4q68UUS KxYc15RN8U/D89uJFu40jbkEnO4eoxWHceMU1J1On3OYvVe9KxspXPZri/0+yIa6c4+may5vEuln i2Rnz04rze0nN4cGZpPXvXQ2tsM7cH3rFlGz/aMkozgjPaq7zMx3nrVe5nSwCgnJk6Cs+W+dgVj4 PpVgaLXC9AcGqJbcSA2cVFmVlHqaFjPzH7pNZSWgpbH/0/lqaNXUrKBvJOcelaWlRyXTSog/0ePC lSPu+9Uh5skizTKIwBzn2p1leS2szMMiKbiT3A6V8Jlc2pn9T8ZYGnUwzj1C9tAoaNG78N6V13w9 toodVT7U5/dsGJJ6gc1hXVuxjSVDw3I/Gs+1nuNJuV1GNDcPASWGeoPavroJWP5xxSlGTj2P158H +I18RaWJI8GOKOPaR7jH9K3XTPOK8G/Z216fV9NbTWiSERKrKu7LOCO3TIX2zX0hPbheBzmqujjR jqvYVNFHjrVmO2bdk1qw2sCK0szBEQbmYnAAHWpLjIgtYDtwavC3YcYryWT9oD4WW909jFq8CPGS reYwUZXHrXpfhXxz4O8W21tdaTqlvOtzuCASLvOw4b5c5wDioNDqLWPcvlDgsMV8dfteNatpmjz2 biV0ka1JU5xjLsD7jHSvtiaHyCPLHIxXyN+2Bp90PDNrqtlH5jmBo1RR0l3D5uB125rlxfwnsZFC +IifmHe3ERklWHnuRWOpAU4G4jlqDKwkkiYEMnByOc981CuY2AU5d+/tXzlU/e8B8CR638KIJbvx fpSpGXFu+cHoSRzX0L8S7e10+4SBI/vLkj0DV4T8IL9dF1+z1G+JG4lpB3x0Fe3fEXxFZajIk0QA IBVQf4geRWB6Sgz5D8dJc6fLH5RDQyE7ieDj1r3L9kITXEmvX8K7ZhIqbz0CtnArwnxrerIjx7vN UFiCf4a+qP2L7W8uvBWtamY9ii/VVY4G/CZP5VvhFqfK8V1rUZI+77eAGBS/pXP+O/FNt4K8JX2s y3CWxVCI5ZSAqNjO4k8Yro4pQihW5zXlH7QHha68WfC/U7PToxNc2iG4SM4UNtGGGT32k49+4r03 ufitWXvM/IL4h/HPxP4i1xNfS+WKdN0ZSAEKdpJ3Mc5JOScEkAnisjwT+0F4yPjG0tbnU7kWs0qr JCrlAyggtyMZ4rxfxhYzaVf3UN8CjRNlRx0b3Hp3rzy31LU7LUrK6s5VhktGMinGSe2D6g+ldFah GVNxt0Iozamj+kbw7rcXiHSrLWLYFYrpFK7hgkDv68+9dnGeeOleA/CfVX1DwDoFyE8tfs6KR24A HFe52W9VDM2VNfzrniSxEkuh+l4J3ppnSwnKbj0oB5J7VBE+VAHSpCCelePA6x2cZqjcAmrvWq84 wPrWkAOSvFfzCRwo7V5p4su0CJCx+Ze/pXq14oVi3b0ry/xPpxnikkK5Ldq9nLJfvEcmJ+FlbwXq UU0TQbslDk5r1AW0OpJ5UrYSQFT34IxXg/gJD/bN/Ht+6qdeme9e320uxvl4xX7fkc+akj87zL+I fmF+0N8ANcuNSaSylW4+0S/uhHEEIGD8h29QPX9OlfDWqfDXxJp99cW725kltvvYQgAjjGfX2r+i 3UdI03XIBHfxCRe//wCvqK8z1L4JeEr24aaG1jgVsEqq8EjjODntivYPOPya/Zz+E/iG/wDiXouq XJMAhkS5kmCFlRI8ELtGMs2MDn+Rr9tppbmaB2I2oeg74rI8OeEdO8O2a2On2kVtGg+UIoH8hXQy LtTbiuesuaLiaU58rucc2wOYu45p4J2jHWnXlvLbXPmEfJJxmmRgnO3qK/EOKMBKnXaP0PJ8SpU0 TpjGT1p0WQaYoIX5utSIcDJr5ax6TJ/M2qdvNItw4UEDpTMk8djVaMujsh5oEZWs3BO5CPlfrXlN xKkWoGNOBXtF5axPD849/wAq8i1+3jtp1dPvSNz9K+p4bxSp1Vc4cxo89PQ07SVWcSK25VrrLWQy vuXoe1ec2d41viNQCDXaWspO3yzhq/c8G7xTPz2urSPRLFoIouFw9dTYuCME8VxFhMkgCsfmrqrX c7BYzjFegtjjOnRuuKkQAKarQsdh3dqsIcYA5FBlIsoSFAFWk6jNVeTjHFW04FaB1LI9AOalTcOM VXT72T0q0MZ3VoQTpwORV2PcRxVRBk81fiVsYWswJkHFSooUlqamV4Iqwo65oAFHfmnLxT1HHSjb 83StAECkAluadwBml5zj+Gm9eFFAMCp6igrgYHWlAoBIoMxRzzRt5p4XikBxRyAAGBxUigZ4pi5J wOlSAYHFAEm2lIzTBU4AxQA3FAWpdvrTTxQBftDtNeYfGTSdUufDEl9pUBuJ4+MIMsAeDj8K9Kt6 uaiXbSLvYcYiYn6AVFXWLNKOk1Lsfj/qO+31a5jlXYA549+9V487Dk/Ka1vEY3+IL1iflaVyP++j WOWz+7xkAj8K+Sqbn9O4XZfL8iVgVAYfLVKUhTk85qxI7NGzYwFFZnmGQHC/nXOepCGhXcqpK9Hb pVJyYztJyauMATub7wrPnZiBgYIrM3pwKrlumehpI5GMnPCml2k/Ofm+lNckKOPpQaCRsX3c45x+ FT7FEfynGDxTGPIDDt2pFIOBjdjvQAoUnORg1fiiLLnAxVXOSFIq0m5WyPu+lCQmasKmIAEYBrSV ygG2slGDH5iQQKuRNhBnnFNMg1onaQbW4qfaFIbriqttkjcR2q58vynsOoq0RJIVhlwVGT3qUHIx gYNMwdwPrUgjHAHWq5jNIXZtQmkPyLgd6UI28k9BUxXChj1FUZ+zINpAB/nS43KCOPpU2A6ljwel IF2Axnk1mLkI1AB9cVOhOOOM01FUDJ5z6VImMAKMfWtDT2Y7GDnOD7UozgnOaPlFNG4fNjIpXL9i IwIwAODQyhiFx0pS5I44xTS+35e5qec0hQ7ELICxLc4qjKuDuxn2q6xOSO4qB9x+90rNzNYYOp2M aRHDGTbwetZVwFLj+9XRyhmGB90VjTxwj94eo61j7U6qeV1GVbWx+3u0OMtnjPWukt/hvrVyUni2 InYZwaTSdQtNPcToBuI9s10Fx4gvJV/0QSuGHAUE/wAqz9sdH9kVDNX4Z3ZnjbV79baEZ3lMFq1h 4N8CRKIbi5muSo5OQCc+9WbXwz4+1l4oLTSLgef/ABvwmB710SfBr4gTA7reOPcODuOfyq1zvZGc 6FKl/Eml80c1p8PhPQrOfT7K3eSKc5xIc8jpxWFJeWNtG8cEKRJnI+QflxX0PpP7NWu6naIbmfyZ YwoYA9WA5PNei+Ev2dtD0u4VPEds+pyNuV1Z8qOPl4FdMcBXltE82vxJl1C96l2ui1f+R8MRXVvH dHyPmkbqF/8ArVqzWuqaiipDaSSEjAxGSDX6laR8DPCenQLPpnh+PzcfMSnH6122k/DOGCfbHpUU C9mIGBXRDJKz3dvkedV8UcBD4KUnbu0vu3PyH0vwB431Z/s+k6dL8oDEyLswG9QTkV6NpP7PXjPU IGlv5hHLu5jjUkgfXGM/yr9a7fwDDHMk5MaMv9xcGulg8K6ZEweQGRh68D8cda7ocPr7Uj53FeNL hb2FBL1dz8v9B/ZevLh45J7+SOM5LdC302keua9N0P8AZ48NabCYLnTm1K6Y58115HpwOOPpX6FR abZQ8pCgP+6M1cCIv3VAruo5JSj0ufL47xix9VuyUV2Wn47nx94a+Cs1qS9rpwjBbILbVAz14PWv VtJ+FXkDF20SoBwoUHHtXttFejHA00rcp8lmHHONxDu5W+9/i2cBa/D7TLeVZTIxx2GF/lXRjw5o wJY2qsxABLc9K3KK2jQgtkfM1cwqzd5SbK1vZ2tqoW3iWMD0GKs0UVqkjgnUctwoooq+UnmCiiij lDmQUUUVIucKKKKB84UUUUE3Ciiigm/QKKKKBBRRRQAUUUUAFFFFAHgvxPGdag/3K81dc16Z8S+d ai9kFefbc44oLRjyxnrWZMvNdDNHnOKxpk56VmMx5Byc9BWfJyCw6CteRMMQ3Ss50xlR0NAGTM4P FZcwBU1rzxAVnyIAOlBaZyV0h38dKxZIGclj1FdVehs7sYFY8gGcetA1Iw3iIAHepVRlIWr5iUdR zTdnOR2oLUh0YIxWrbSMrcVnqPQVaiD54oHzloWli8rSyxBmIxzyMfShdO02OXzoraNH4wQoyMUL leR1q1EvdqainuHtZdy4T5ijFVJlCknrirYAxxUEqnkY4qxcxyOoxhJAw5rFuGLpgDpXX3dujHJH NclqYMXyx9KA5jir9d7Myn2xWQttbyMEGFrobqz3ASg5HU1hyZWTYy4PqKCWz8mv2l/D/wDYvxSn ukt/LivNspYfdLNkcD8K8ntWUkluT/hX2L+2D4dvrpP+ErijY29ukcJOMAEfdA9c8818Y6XMksYI 53LVRRhI31BK5zk+lPBbeUC8DqRUSFAwBPPrUuwMDhiGB596aRI7G1D3NPEZcBzxxTBuPzHt1qcB QAM9Ov0qkwMi7j+Q4+avpT9jjxjJ4c+JsmirH5x1iEJEGPSVW3ZI7grkcY657V8+OitjaOtL4A8Q XHhH4o6Hr0EzWslpPHiRRkgswB4+lJoqLsf0OQTSXUqMRsUgEgdzW3GpVQoNYmivFqFnBeW0iyxy IrB0OVbI6gjsa3gCCFAyazOiJoW6MzAE1pCLHBqpaxkOK2hEOKCiSyDpKuBX52fttabDaeJtPvri Mbrq3YkjGcKcCv0htlCke1fJn7avhWTVvBlvrFsqsuncP8uXXeQMg+nUfjXJjYc1No93h7FKni4N vy+8/L60A2ouOQOfetEcFfmx7elcvpF+hkMczksBxXS5Jw5ORXw+Lp7n9DZRO0jdg+ZdpO44p6nP IHAqvCo+/wByBVl1ZUGzoa8rkPsUTbN0W5unbFUIpja36Tqf3agZxV8EBeMlccfWsyby487+EyN3 0rNo5cYuem0fU3hR1k022GcMwz9a9KglOFTP3BgmvIdAb7La216h/dNGNo/Cu+0++FySc5A4rz6m 58LNe8dUPXNP3IgwWqum4jpxTWQtz2oA2NGvo4NRjnXkxuHB78V9faoy+IfAvnR/O7RgsO+RXxLA xt7gFRjBzmvq34eazLd+HHgdcZyM/WvUwcrxsebi42lc+X/EsYt7hyV53YNYZEF/bXNpOgP2iIoK 7r4jWU9pdvIkeAxJIrzOwcCVW5HStCoM+M9QiWy1y+sOggfpWrYHeOBgV33xm0C10/xVbanaIVGp IWlxwAyYGfx71wNsNrBU6CsZqzP0bB11UpxkWnyqkE+tYV+G8iQgZyprfwS5z0rK1CPfHJt6FTis TdI/Xv8AYm1A3HwatrVv+XaTyc+u3PNfWtyAMYr4m/YImWX4X3iNktDeNH6gNjOSPpg89jX3Bdx4 Br9Myx3ow9D+VeLI8mYV4/3n+JnY9aVFONp60Ac81Ig+b616B8obtpCFQSP90V+H/wDwUR/ac8RP 4rl+FnhDVDBo9njzniYqZ3wCeVOSqkFcEYznrwR+5VidxEO3cXG3H1r+an9t74U+KtH+NWsatPb7 rbX55ntioALKrcnHUDJ70AfFth4w8U2+opqNrqVwk9u6yI4kdfmzx0IPXniv6bP2Mfiv4o+Kvwgs 7jxWRNqWmt9mabABkRBhSQO+B16nvX85Phn4U6zPrFnHeuivJKihCGyVzyOMc+lf0h/sb/DHUPhl 8Ko7HVoXgubuVpSrtk7T04/hPtTQH1NJEcYJ6VW27auzuGPFVl60gGcgU4dKCe1IPetAH4pyYAGa TqM0nUZoMzoLGXYQxG4DqPWvxj/bd/Y51rU/HMnxI8I20l7HqoZZYlH+rfqCSvzYOTzgnJx2FfsV BNsHWpjIsgaOZA8bdiM9etZsqKP50Pg3+y34vuNRk0m302V/OwZlkLCCL5gN4JXcffjtiv34+E/w +tPhj4MsvCVui5sowHdfuyOwyzj2J6Dt0rqLXStKs2D20IjbGCVAGfyrU804wTuxxRCOupbdxHGR UQ9DStnNOC8e9a3MhAvOakI6U0ZpQCKQDhnPFSKcnJpAMcUucHpSiBeibHNTvNjG2s5Mjips5GDS kBaBBOTQ7BhioRkUgBzUgLk80E9KcB1o29KtMBOlPAxTygpypnioAjPNKFzxUm3HFSrF3qkwKpXt TdnvV0x57UCE+lSBW8s4xTsHHSrghwKkEPGMdaAMsA07HStJbaphaUBczQmaXaR2rVW1YdRUwtQa OcDCMZ708RY6it8WyAcihkhjRpHwFUZJ9hT5ioxuYsdvv6Cp/sfrT7zWNE0xGlv7yG2jUZLO4UY/ GvNtU+Pfwa0fcuqeLLC32HB3TL19OM+lPnXUv2Z6aLRacLVa+X/E37an7PnhyF2g8Rx6pKAxCWim QkjoMjjnoCePevEde/4KQfDixhf+xNCvbpgCd0xSNcj8SfyzUyqJFewP0SFsKm+zr6V+RWuf8FKb u8aM6B4cZEUEt+95J9Oma8e1v/goL8bNQgK6atvp06s+S8e8NG33VABGGHqSfoKn2xXsj901+zMx VXUleuO1Vby90rT1WW9uooFY7QXYAZ9OTX86WpftX/HnxA06za5LaCUkqts5iEecA7Rk9cc5zzzx XmWp/E74mao0/wDaXiG8u4rhCjRzTPIgB6lFY4BPqOfyFS6wexP6S774nfDjTLg2t/4hs4ZVGSpk GcV4lrn7Zf7Pmizy26eJEvJYeAIUcoz+gcDHHev59pdTv5Ln7SGVmIU5fJOV+6ck9R2rMkTVby4J uZB5ZOcKAp/Oo9oV7I/cnVP+CinwdsDdeVp93cpaLuLIUAb0C56k+gyR6V4p4g/4KawzSp/wiXhW VoipLGchcHsDzn8q/KkaftT7mfx/+tVhNOuJsJsCio52NU0ffGsf8FE/jBfvIdL06zsIXBwSxkZS RjI4H1xzz7V454j/AG1f2i9f2eX4gjsGVm4jgXGD0+9u/wAgV85nRDHG0kvIWqVxZq00dtHkfWnG TNXBHb3nxW+LGtNM+oeLb+5keMbyZSpIByBlcEfhXB6lqetau8bareTzOBhWklkkwD6bya27HR7u W4MEEeQeM56/Qd63/wDhCfEFwrfZrR299uKr2hkkcG9rMyAiRmY9ST1pYILmGH5c7hyO5zXqtr8K /FzwB/JwGHGex966bSPgn4p1NXF/MlsuOMDhvoalzZukeCSSXU26Wcgj9R7Cp0tZxGshO0Hnk19Q WfwCaGRYLhmZW4+4cD6muztvgAkjLby2mEH3TtLZ9+am4z4vjtnnBRA8rtwNg3Dj6Cr1nps0igeR I+DjOw4z6etfd1j+zdDa3C3QQxMvIYHaP54r0ey+Dlmtp5V2xYjozY3fpRcD8zrfQNTul8yGFgWb H3TnFbcfgLxIZIonjRAxBOc8D8q/UHSfhj4esYVhlgEoXueprdPhHw9vA+xqCMDcDnikB+cUfwZ1 S5fa37onqyJvU/nVqP8AZ/1R+Ld3Vx/fBwfyr9H18J6QqoskRmjB4BYjH5V0KWtjalFijVdnTj/G gdj89bD9ne/8rE0T3cmOcDbivT9F/Z/D2CWEESB4lzyMEGvsKSWM5IX5vyOKEnCkyd/pzQFjwmP4 CeHILeD7TbwvNgZO05DD3z2ras/g14eji2SICcY+RcAfmTXrMlz5j0C42cigVjjIfhl4YhjVTGxK Ds2BXS2nh/RrW1WCO2T5D3G41beQSfMCQaYryE7mPFZgTJYWUbq0UKAdeBVpZ9hLbQCeOKpCQH2A pQSCTQBoPcho9jrQtwAvyngVk7zg88VBI3y/KeaANOS43jk5qJZyF2Y61mKXOOelT9gSeapMC4Lg gbeaaJGzn1quATzmhnxUmhOZeTmmM+etQk5HNMJIHtQZzJ2fp2qNiQSxbNNAU/MR0pCec9qAHs25 QV600ttQA1FvIye1N3sWweaAHbsE1WYyyHHQCpSSCTURO7vQQhpUkdcmhhsAxQWB4FPDEDJGRQWM BBGacfmwAaUMGI4xUbdSQaAHDaoJbnFRPIO2KQ57Cq8iZbOcbaAJFfecHqKbK4Ubs5qu0mDkGq1x N5cfrmgCx5ynpVN5+uazvtIdsK2MVC8sg4JzmgC7JOkS5NVxJu9gKzpDI7LnnHarBI38DkDj0oIs KvDHn6VYyzKR6VA2SoAIzTivAAOSe1AWJc4TAPJqLIQBR+NOACDmgYyTQWQSNkcnHYCqt4pMW48d KtEoZQ56Cs15xJvB79KaQFEyKwIyRiqkuWfCqSBT/MGTuHNKoIKk5IpxiZ1HYqx+ZDcRyITG0TBl YHBBzX6a/D3xLZ+KvC1lfRqyvHGI239SyjBPvzX5rbhK7Ike7b2616J4Q/af+HvwQ0y70zx/rMfm IWK2EZ3XSgjdkIOTnPrW9jJzPTf2graLStYW+LAQ3KDJPQOvYe5zXzDr/jHQvCminWvEN9HbxAgR xF18yQkZwikjPHP0r5z/AGl/27774qfY9P8Ahtpo02xtZ97T3C7mmQjhSg5RvoemO5OPhLUJvEPi m8e/1+7MzyHOEznHYYJPTtTULkuZ9seNf2tPDsbf2d4V02W/mK7knl2rCp9SoJJx+FfKXib4tfEj xRM1z/aH2HKumLMeSCr/AHslcE5784PpXDRXPh/S7yVf+WxTnOO341yep+P57Vz9htEYer8n8BnH 501TJ5zrLDQta1EifVNRuZkPLLJOSDjuQTgVbms/D9l/o91eK2OuwB+B2PNeRS+ItTu7eT7TO8u/ +EEgH8B0rmVvWCuJJBFICSoJzxVqBi3c9putb8JJp1x9gjVnxgKR1+h6A1hxePXW3iSxs1ihC7XM g3Mcf3cdDXj9z4gcxiOziBI4k3cA/T3rMh1toVNtG/kLno3JJNXOBZ7VF4515XQYjZdp8lJByo9c jH61y17408SmOc7w8rsWBI6J6DFed6jqOoQkrcXCxgAY2/f5+ma6fSPBnxH8T3EVnp2lTyPcRApI 2AGQ+hbC1iNI/os/4JO/abn4Q63fXJLFtQfBPuqk/wA6/Vi6+7X5qf8ABLnwXrvg/wCBt1FrrKJp r1/kHX92AjHP+8MfhX6XONwOa+cq/HL1OtGYF56U4Kd1WtlN2YOa5zMQITTL6cWGnXF9sMht0Z9o 4ztGamHDVJd2y3dlNaPjEyMpz05GKtIDzO0j1DxrarqN7Obe1ICpFCdrE553nnnH4VU1fSdR8F7N d8PzPJaQEedbs5IZcYJOf8g/Sud03xTeeArS50HVbYzTQOwtygO1yRlRkAnB6+o6V6losj+J/DEU mrQ+VJeK6yR4wVOSMUwN7TdQg1XTbfUYM7LhAwB6jPardVtP0+HS7CKwt/uRDFWaAHCrC1WFWVrW mZn8u3x7+K/xD8K/HTxq+hancCJr24Cq7F1UB+iq2QvAHQZ965fw9+2F470+4trTXLL7XBCuHkOF kcjvwMDPesL9onxgqfH3x3HqFoJIhqt0E28E7JGUY7HgfrXlVvrvg24fctnKrn7/AJi5/LBr2KcO hofePhn9sb4fahe6bF4ihubP7QMXh5kEJA/gCqN/PbjPQc8H3vR/ij8J/FQaXQvFFpIFAYrO32eT DAEfJLtb+IDp1yOoNfkK3h6z1adpdIlSJWOdr8NkdCKqv4I1aBTINssinO8Mc/l7Vt9X8yZSsfsn 4gtdE1vT7uxnMVwxjJQjIwxHG1q+C9N8N+D9F0u71eZvs17I0kKxF/uurn5SOuBg9TXz9bfFT4se FPKjttWcwW+0IXTzAgUYAO4EqOwrE1XxnqvjXXJNUuYo472chpEtgyxyN/EcEnBbqeevTA4HJVw0 j18pxNJT5Zk3izxl4ksbu50ywuzCkoIIyQfoG7V57a3JdVMi7JnG5stuOfXPvXoOpaFr2uJ9jTSy WYZ3NhWBHoe9ZFr8NfF0Uwa+mt4d/RMBiFHv2rowdPlRjmKp+09x6GHY3/8AZ92ly6MSjArg46HP tX6d/s//ABQ0nxnpd54R1eKO2u51V4VlzIlyqjjhhwy4zgkjnivzqfwNcafhtVuEuVQ5QL/Kuz8K +KLn4e+LNJ8RW1yXe2kDCLHBi5V1yPVSRXVJXOFM/R/UPgD8LNYglOr+GdPkMrFmxEE3E98pgg98 +vNeNR/8E7/DvieJ00XXrjT1Dsd7sskQRs4RVCg5Hrnt0541F/a38FB1hTTL67kfAyWWNMnqMHJO K++JPFGkfCz4Sv428WuLRPI+1IjsEZjMm5Ivm/jwRn3r5vNs19guTq9jtw9CMk2z83fFH/BPzwnp umzRfDjxpeHVF2pGNQRWhMi4EmfKIwDyRwccA5xz8w/DP4B+Itb+Nui/DLxzZtb/AGu+W0l+VlZ4 eW3BRztkUZGOcHIxwa+qNT/bM8ISSSXNjZXPmtlw25PL8wnr1zj8K7n4XftxeCtK1C41Dx/p9zNe xBWtrq2iibKknKEMVKbRjBBOeeAK8+jVxr3TsypwppaH6z2Nvovh/TbXSNEtI7K0s4khjSIBFCxj aMBeg44rx/xTrE1zcTQIMjpu65r5kk/b4+D2o7vs1nqj7v8Apiv9HrI/4bG+Dc8jNcWmqI2eV8lP T2evUUZdjmbXQ+krXx94z0qKC1sbiPZbEFN0Yzwc4JGCfT6V2mm/tC/ECOMWmrxW92VGMqjKevHH NfHsH7XvwAZ2N62oWm0/xwb8/wDfLcV1GjftY/szX921vJqs8UpA8sy2zKGPJIBz2xWc6ktrDVRd T66sPjx40a6JtLO3QOCMOpwPT06GuZ8Vw+OPiW0X9rXnmpbuJY4wiqqNjb8pxu5yc5Jrzvw/+0T+ y+82y78VQxvwfnikH889K9n0r9pP9mO2jFpbeOLTgAs8sLqOewY4GPSuf3uxSqR7mBo/wSlaWK5v bk4ByysnLD06/Su6h+DejiUTOrsN2SAwCkehGP61tWf7Q/7Pd0ifZviBpGX6ZkAP861LT40fBjUZ hb2HjrSZnbPAuVU8exNGvYOYgj8EWNs+9EUHoOMUo0GSPO0fdNbq+OfAE4Z4PEumTxr1ZLqIgen8 Va1p4l8HX0z2dnrNnNNGquyJKjFVfOCcE4zjitIyfVDUjj20i4CjAH5dKqjTjuAcZx1969LaKyzg XEbZ6fMOf1rOkt4+sRV8HnkVKkxnPFrfTNPku5SI1iHGe5r4/wDEGq/2pqUt058xmY5bGMe2K9r+ K11eNdQaGglVlUyMgAVArdGz6nH5V4RLZzxuylSCoOcj9a76MbohSM0tGWw2SB6VIUXdubp+dLbq JHCqQW6nHNTyBVYKxzzXTylJkQUjpTACuSBzV+JIpGAp80ZBwvSnYnnM+NpCeRwKleQHCY+tRSkI cDt1ppZGUDvSEP3xlxGDUxCA8nIrMmmWNSARn1qOIsoDMxbNAF64ZEaMZ4A796pSXAmVoy3bt2qK VhI2zvmoPNhj2qTyKDZIdDGAoHcetXgMqFx8wFZAv4JJfIB+bNJJeeXhA2GoFzk13K2Qg4x1rNWd ojsUBw1PDtKCDksaqyIsHBOR2qeUOc0/MXBZzjHpTHucthcEnt0NUYg0gYDJwNx9gK8x+InxU8Pe D9JEVs3napcZVI4vmxjuTWdarGCtJnrZfl1bENRpxv8Aod94t8U2fhbw1datcSASxRs6xk4dwvXb 1P44r8+/FPjDWfG2ojWtXmMAjTCRIcxovOeD6j1zWRrOt6p4pupLzWrmSQgllSRvunpz+FetfCX4 Vz+NJptW12CSHRbSVVTeAFmZQMgjrtOeCO/Q14FWpOrKy2P1DB5bSy6j7Sq9e/6Ig+D3wpm8Q3Y8 X+IATpcLAwQdPtD9i3/TNf8Ax48dM12vxE+G5026bU9LhWO2cbWCjAXHTAr6sghtrSyg03S7VIYI EEcaqdoAXoPoO1ebfEjyY/DF/HqE/wBnKEKi93bP6U6mButj57/W6aruSfunyNDaJOoV3PJHHT8x XQRPfWCqumz+U6AD1X8q4vTdd02TAvZ1D72Hl/xcVs3fxA0TTk8z+yvM2ceYrYIx6iuH+yZy6H1F Lj2Eep032vVb7clxclSR8xHy5Arwb4z+IXsZItCEzXEcqHYEfBG4fxHuKuxeM9bvLxzbhTDLnapH GD6ntXk95/xO9RlfVyGlD7N390D09q9zKslVOXNJf13/AK/4b5LizjqWJpewp3Se7/r8V+m/CaXa EwBigUr8vGcV1Vjpcs8wR38lSuB8uefettLB47l7SFlVQcjjJxVvDQwmTBDoSBg4FfURSPy5VPM7 n4f6Pp8EN4bcu3mKMlz1x/KuxvLtCAnm+azYRmJBwvp7CvHtJnuopRHsaSS54O0kbVrD8V3V7pmr vHYXimB1AKAcg+n1qUtRSlc6/XvC0VmPt9uCzbiWAbPFcWYWMrSyNg4wCPSqUF9fmUxNM7rIoGM/ dPoatKZtrI65GcjHYj1rQgUuSflX5V79zUgkRcMuGJHIHUVEslxuXptB5I/lUEt06FnMOAPTqaAL qhMcNlhzT4SkW2aUD5uGHcj2rIjvofMjcxFNp+YEc496nk1C1R1nlGAh/KgDcuFsSF3LtK4IHfmt 2DWxptoHUEmPknqT7Vyl5qVtLdJBHg70GT/Sp0ctEYvuKep64osB6tofxj13T7yO9tbu5VIhhbcz si/QhTivWfDvxD8Ya/NHfQXKwQFj56TZbK91JJ6V8raTpkLEySHe+SxPQfT8q3LRNTj1eFNKWV2l bBjUnaw9MdM1yVaRrFn3Db/FTWLV0srS5WWMjAXbuwOBwele/wDhrxfr8NnBNZPgsA5DLkE8nOK+ H/BfiKfRLu2uNQ0kyK7iNg3HAPbtX3/4WntL2wfXNREVnaRZEa524GB17VxtG56j8P8A4px3U4h1 54oJlkMZdcBWA5yMnJwOuOlfRbeJ9LS0W4gcTCVFZGUgqwYZBBHUV+V+t+D9fXX77xdpN0j2EjCR GSXYYtox+Rxx/kVgaN8VNU0rxDa2tsJbm6ScLlpd0IByvzJ378Cs2jaJ+n8uvR6jfhmONp4rtrNb ScDDqzd/X9K/P7UvGnj/AE21W8M0bxseSAeB9a7DRPj7p+m2ix3rywybcs/8IPrmkUfcWy1g+aVw v5/41ly6hE52wLyPxzXx7fftMeH90cVzfW8idQSxBotf2ofC0iEMqInQNHnml7KRm5n/1PlWVmwB 9915OKqxNbJIEvJPlJyfX6VbGDskiIBB+b1rh/FCy28xkWT5XPFfB4WKUj+seIIN0T12ImWICLlQ Oh7CqnkYEgAxyTx3xTNAjdNGtbnlpSuCfUVcN0EkZmXGODjrmvrMNFyWh/Nea6VZHvP7O3jHV/Df iPTlVVk82R4QGGSgm+TJ68c//Xr9MJk+bbt5HUe9fkv4XnbQNWt9SjkMRLLuZegGetfqz4SvP7Y0 m2ulkFyHhRvNXo+QOa6KmHnbRHnwnHqaKW2NvGdxr44/bT8fan4R8LjR9IuWs3v7Z2BTowHDgk8Z A/GvuoW0aqu8hW64JANfLf7TXgay8WeGZ72dfLu1hFnAxQSKvnNljtPUhc4/pXLTpz5kmjSbVtD8 B9V8VXPms3yeYMANFnLfXJNUvC3xT8Y+Btd/4SPwveypqVuwKGUmVF6/8sycGug+Kfwo8T+BryUv bZtYZVVWU/OwdA2dvXA6H0PB5rw9EkkxcP8Auzu6Z5P0rvdLuYwZ/Sn+zJ+0Za/GPwVaTTQGO9tj HBNGHV2ViBukIHIRmzt78EHkGvb/AIp+HLjxP4Qlsbe4EXkP5zgruLKgztB7E/jX4+/8E6LLxLp8 +t3kVjKbPUJIo0uG/wBWoRiWIPABz1r9vYZluLdo5xu8xSrYJGQRg9Oa4a9NNWPWwtZ02pH89/i/ 7ToWt6lpV3G0dxDKxdW4OS2OuOR6EcGsuwvEcg/xBc198/tPfAG++2T+K9NgmvX1EJHG8KqCJcBQ j4/hPY4yMdcZr86buO/0jUJtNmXMsG5JOhw6HDLkcHBHUHB7V4dfD2TZ+sZHnaqKMUz07RdRKXSl 2bkde1dndXe8hPNPzdPSvGdN1EjYpiOR1JPFa93rVytvKEUeZ/D6V5rifcU8Sc34tu5JHmDfuSA3 H9/HHFfpp+yx4Z1Lw78JtMnvQgXVS1wFRs4ycKTjjlQO9fmJpdneeKPENhYSW8t1bwTebdGMEiOM soJJ7DkfpX7S+G9Lt/D+i2Wh2YK29kipGMk/Lgetd+DoNas/OuM80SSpx6nXp0A9K05ILS/tXtLu MSQyoY3U9wRg1hoSvFX4p9pCmutxPzOU7s/Oz4+/sgDWJ73U/DdiJbSOMyxpCQr5B3EcZz6YAr4Z uP2a/FEqR/8AEmuLLGMB0Zff7xGM1/QUs0ZHzrXNa1pGn6ltkmiUsnTcKicpJaBHdHyx8C7S+svB tho+rxNbvZrtAYg/dHqOOtfTkBDqMDCrXJ3Oj2NtcRC2XylAwVXAGc+3rXT28qqgUdK/C+LKajWc u5+i5U70zRjcqfatBOcY+7Wao/irRi4XFfJ7HpjghDE9jQ6CQYFOXcrYbpUgKgECtosDnL+Av06i uN1BFMflMOvU13l6jBSR0rkbqAyRupHNenhZ8skyJxumjxjTFEGty3C/KVmI46EDivZIULKrKODm vGIlf+2/Ij+WMPz9TXteksZLfaw+4cZ+lftvDtTmpI/O86p8tQ29PPzFXrXwvbis6IYAxwfWrZcl gi8+9fRHjFoKuM96CkbBTikAIx6U9UO0nvV2A57xEsEGmyXDrwi+nOfpXiHg/wAeRa1qVzpsyGBo 2ITdxuC8Gvom/g8ywnBHzquR9RXz9b+D9IsdUl1G0j8uZ2LOc5yTyfpXwHF9CPI5WPp8iq62PRY2 LfQd6lAXO08iseG6aNgprTjl39sH1r8dn8TPtOQkJGMdxQA+PTNGPXvRuUcHjFSQLdyRiD5uMV5R 4nVNqS7ScHAr0q4dpwARwvSuL8QA/ZJHRM7eTXqZV/FiRX+FnDWuJHVwMBf511NtJIrCQdq85sL5 zOwkbaG6Cut0+7dJNjnKnpX9BZU70Ys/NcerVLHounSyLIrEcNXo+muv3j1NcFpYjMKOTkiuwtJO 69BXqRPP6nVg5OB0xV+IdMdayrZiSM1vRoAAQKozkSRqe/arCjHHemR8dKkA524rQOpMh6Z6VbUE 8jpVVQABkcVajPp0oILUS4BzV+FSBkVSQ8cVox8DmgCZfmFTqp6VEuAeKnU00gHc4xSHOaBnOKUV YDsYUYoIGRmkUnjvUhA5agGR4GMigDPWnEYUEc5oxzgcUGYgyG9qkO3FRMTxipRjitAHKMLmgZNP BAHNKORxWYC7c4IqVRmo1OKlHy80AKxxnFIOaUDOafGvOKALMCdKxviJd2+m+BNUupJPKYRFUPYs RgZ9uep4rpLaPJAryj496ktt4AvdOUrvmjJwSAzYI4AI56Uqq/ds1oxvI/NfW3UXpKdQSc/WqKod pOOT3qJz57ySzfeVsY+lSxytjanfivkK+5/TmU+9Rj3svyRC8UwfcW4x0qtJ+7+boKuS5AJYZK1S kLBsHkY6VxntxWhVPB3YyGrJYfOc8Aetam4q5OMDtVZ23DLDrQbRM/acnng0oVdvrj1q4jqqsNuT 0AqrLFyrqPrQa8pXO6NsN0PUVIiFxtAyOtSyx7x1xmizikRixb5RwKA5SVQ0aEDrUxVnAOcYFWfL Vf3nX0ppXOeOT2pMhwCOZo1Adfxq5CWPJPXtVaJW5UjI9+1X7dAeMcHvU3I5DSixgEfeqwu7d8wo tgMHcOBVkL1BGQa1uU6VwQMwBAq0FOeaQnCYxxUibc8noKjnBYWTH4J5xT8bhnvSLsbkNwKY80YP Bp+0iEcBMcEBUqRzSbScE4HvVGS9AY7RgetQtfquFyT3olX7HbRyuT+I1OKZv4rAk1EgFnO0fX+t TRWWvalOlvpdrJKZMcqpIGecnHTis44hs9COSmu0qbeagN4RwOFrqdE+FXj7UrgxS2hRdoIJyOv1 xXpFn+zX4jZDJqOoLGjgFVVgCPUdDQo1XsjCrDCYd2q1Ixfm0eEPeRAFiwA+tUJtQidGZGLbfQ5x X2ZpX7MWgLJbyS3MlywwSrAYNesaZ8DNJsTI9v4fimSXA+6DXfHK68ulv68jyq3F2WUtp83pp+dj 837Majf4mtrZ545G2rgc5H413OnfDnx1rJ+z2WmupYZy6kDA9zX6j6b8JdPEEX2LSIbJlOfm45Ht XoFt4Jn8lYJmRFxtOwdh+FdkMim/ikfJ5h4rYWH8Cl976/JM/LLRP2aviDq8e7UGis4WBwS3II9Q K7vRv2US0ytr1/GYU4IjLbmP0r9KY/AmkKF3s5YDBIOM1t2fh3SbLHlQKWHduTXXS4dor4rv5/5H ymL8XsZ/y65Y+i/zufCtt+zj4E+yyWSac80jcq5JO3HYg9Qf0r1fw/8AB2xtJhJDpgw0aJkLtAVR j/8AXX1WsaIMIoAHoKfXfDKKMdVE+Qx/iNmFdOLqS+/9FY8rtvAkqKsQVIUA+taS/D+1LB3uCCPR BxXoVFdf1aFrWPl3nla97nL23hDRrZcFGl5z87E1vJZWkZBSFF29MKOKZqF7Fp9q91KMhO3qfSqe j63a6xEXh+R1+8h6itFSSOStjas/iZsAYpaKK25EcXtX3CiiipByCiiignnCiiigOcKKKKA5rhRR RQAUUUVXMZhRRRRzAFFFFSAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAfP3jubzdekXrsGK4 08rj0rpvEbfadZuX6/Mf0rnZE20FxKT5way5wCTWtIMCsyUUDMq4UHFZjpjd7VtSLnrWfMmN1S0B iygMmKyp12rxWzIu0YqhJFzk81QHOXSZXL9KxGjw+TXS3kPftWTNH8wJoIRlPgHmmrFk5WrjxMWO 0ZqSK2Y8mgsrpA5JOOKtwwuBgitGC3PernkbaDQzUgycMelXIoBjFW0teAcdan8vBBA6UAVxEBj2 pXtQw3DnNaEVtI54rTSxZVJI+lAHDXNq/CgZNcvqFmVB3pmvVJ7UqQSuKxb61jb5SBzQB49PbqA2 F49KxHs4pFJH3vWvSdQ01RJgcZrlrqwSEsg4oA+Wf2kfCs+rfDC+25kWBlkO0cDH97Gf88d6/IzS iILya2XO2JjjIxxX7/6podtrGky2NwxEZwWCnGcV+FPjjQJ/CnjjVdHnBR4LmZCpwNuHOBx6Af5N XEhofFIOSR8pH61OpYYyQQR1qhbksUiByCOTVwBZJDlflAwPrVNGRJlgpHr3q0rAKQBjIqD94QBj 5Y+op6eZhgw4HpUtgPWPIB9BXMatBIFZkPPUsOoxXWDDBgOAo6isu9iQxEOdocde5pgftV+zb41h 8a/CDQNVtpcTQRGGVP4l8o7UD9txUAkdq+n7BlkAY8kivzM/YD8T3t9outeDHH7jTrgTxrtA+WQA Od3U8gcH8K/T21h8twgH3utTymqkXoM+ZjGRW1EC4yeMVHDahANo5q6FwMY6ViXAfAdnvWd408Jp 438H6poE20m6gZVJGcMRweeOOtXQMVrQv8hGe1KaurG9KfJJT7H88vi3QNQ8G+NNR0HUreSGW0kM eWQorgdGTPUH1FXrKYeSolbJHav0M/az+Ad54ru4/G3hmBp7iIL50YYk7cEE49BgHj34r84ntrrT ruSwvI2ilt2KsrjDAjqCK+VzLDuPQ/f+F80p4mCmnr1R3li3mDcv3RVwqxXJGFBrE026xHtB69q6 hEX7OSTtOO/Svm6iP0unUj3MwDdlAD0+Ue/vWLqaGVAofZtYE+p//XV2S5VAc8EDIx0rPtbO717U ILCxBZp3AIHb61MKMpOxjiq8KcJSk7JH2TpOiLqHw0s9exj7OqqOesfTn8ag0pxHGrRnrzX0L4e8 HWmm+Crbw6gDqtqVGeQzFcnPA714DpqRpNLZyDa0Lsv5GujOMvVKEWj8pyjNo4mtOz2f4Hd2Uxlg Bx1rQWM5xiqenlhHtrUTIGSK+cR9AzNuUwmV4A/XFe3/AAy1RZreSyA24wQK8ZuEMm0HgZ6V1fgn UrjT9ajJH7s/Lmu/BztKxyV4Xjc7H4sae+Uu4jhCCx/CvmU3CQSNzncePavsDxbYrqul7XO5Rn8j Xx7qGlmwvpIc7lQnGfavROU5n4jWzax4aMkEYae16Z6kGvnmBZI8buor6wW2e/srvT43Eck0TKjM MgNjivmG5tJtNuX027XZLASpz3PrXPWhrc+pyOvLl5RrMECg/eNZd9vCNt5BHFapjBCMo+YHmszU UAk8wnC+lJRPpoyP0x/4J9uv/CIayqHlrk7x2PygD+VfoLckk4Nfmx/wT2uPIi8Q2RO7Dq+PQMOK /SW6f5jX6Bk/8CP9dT+Y+PIcuZ1vVfkiifYU9DjmouM8inCvZPiDVt5yhBz0riviB8L/AAN8T9P/ ALO8W6bHdKW3+YPllDDod45+o6HvXRAkdDU8czLwazA8D8K/spfCTwnqsWsW9it3cRSCRfOBYKVG 1QNxJHrwevNfS3mKkYjQYC9PU1nCYenWmtKx6UAWJHJpobioVbIpwb1rQzLHUe9LjgCowwFO3DFA D/btS7fypinC4NPyRxQAueal3cVEo4zUiiszREgYgYpwYA1GASKcBzQZk4anqD1qIKTUwDdqAFPX Ap+DQIzU6Rk9apMBo9TTthzVlIT/ABVZEPYU4l2KKoelIA+fpWqtvxilSAZ5pSDlKgU4zUoUVf8A JRVLsQqr1J4AqS2+zTD9wyykdwc1m5JByGesf96p1gz2rQ8qHaZGIVVJBJOORwaha+0yFPNe5jWM HG8sMZ/OjnQcpD5HbFWEteM4rhtb+L/wx8OXDWmr+ILWGZQDs3gk59K8u1L9sP4AadNLbDxLDNNC QrIvXPQgZ6lTwfQ5HajmQ1Sb2Pon7Nk9KsJbgda+DvE3/BQn4W6I9zFpem3eoGFwqEFUWUH+JSTk Ac9u30z5Rrf/AAUpjx/xTvhLzGOD/pE+NvqCEB/P/wDVUe1K9hI/U1bcE5qUQrX4p6v/AMFEPjFJ FI9jp2m2nmZCkK77AemAW5I9fXtXjGp/tpftD69I80viAxfKUAtokiAXPGQBgn36/pS9r5F/VpH9 BssllaKWuZUiA5y7Afzrn7vxr4NsUR73WLWASDI3yqOPpnj8a/m11j4u/FPxDGqa54gvb0o25TJM x2sepAHTNcZc6prNw6TTXcjyIMDzCZOwH8R9AKn2hSwzP6MdY/aU+B2hW5uNQ8VWihX8shG3nd7Y ry3xD+3T8A9DtTcWeoT6owyAsELDJHTBbHU/49M1+CE5uLobbyQuHIJAG3kVahiVwyhcgVXMUsPE /XHWP+ClvhNJni0bwxcyoh4aWVF3+gAwa8i8R/8ABR74hXsM8ei6DZ6WJOY2MjSzAenzLt7dh3/G vzuFpt3YyCf0qNoC6lZO38VK5XsY9j6iP7c/x/mupTFqiBH4KCLIA59+vqa8y1n9pH4768s8N74q ugJjy0chjxz0AQgdOK8ghgYOUtkaRm7gcfXNdBZaUJXaKON5HUZxtNFy1BLoV7vxT4z1LfNqWsXM ofgguxUj8c1z19aXF0ir5sjIDkdxn9K76DSL0zIggPlDgk8c1pp4J8TXszR21tuTGeOSKyHZHl0F iscO2YEsp4OetTz2h4BUFMcjAxXsej/CXxNqYkhR41dPvBsk4/Cuq0r4Ma1C0i3cJlgH3e3P40xN HzWLFW4VfcD0/Krf2CcRgJGXdegH3se2a+oLT4B3N3emd7GSOE98/Kfpg5r0PSfgbZxyKotHKjnd u6H8TmkKx8XW+iyG282WGRM/3hya2tE8HanrbeTaqN2Dw3Wvvn/hT2mAM4tyJmXG5jlfwFOsfhWm n3Kuk/l7CCNq8mg05T4OuPhzr9g7C8tGjTs+07M1taH8Ntb1GFmsotzIeue/0NfojF4KsZ5AL4m4 Ddm6D8PWup0jwhpmlK6RoNj+gGRQI/Pq0+Cmo4V7uVopT98bSyn/AHTjiup034B3MlwhPmwW5PMy 4kx/wEmvv+DS9PgO6OMHscj+lSwxw24xEgVSemOKAPjaz+A1pc7Y76E3YToXJhBHr8tV774A2Gi6 rpeoxW+y0hdhOjSeYWL8JjPYH65r7hZ4zH8ygn6dK828X3ax6tp0CHEbHLDtkYxQBzWk/B/RrT95 LGF4Gz5Rwa6keBtIsIN02JnLcH0rt4CWCknnAz1prKr/AC45ycUBY5+08O6REhZ4Q27pntWgNL0n aEe1RgOm4ZrQMaqMHiocUASwJaQHCRgA+gxU5eMsCo4FVUAClu/vSs3yggYNZl6CzMGPWmeZgbSe KUAD7w60FARgitCrCiQEYHNNG08ilELKOKBleAKAsODPjAprMx+9S9MYpp96AsKdxxupSM96X5cD Joxz8tZmdhpGF5FIOV4FSYzwTUZGOhrQLDccYo5xinY+XNGOKBAARwRSNuz14o/ed+RQxA6UAKUb HtTXCk4FEpITB4zSR9RnmgB4AHQUzIPSpX8sd+lMDJtzipuAoODzTGOTTc7jxT1XnJpcoDCzEYPA pRt2YpWQHjoajePouaQDSSwOKTgDB7UrcLhaaAcEmnYAK5+X1pmDyO4qPdnoOlBkA5xV2AacscMK NoztFSCQ7M7eahL9SRg1mQiQj+HpTW3bSCajUFuGNLncMk8igsadwQAHmm9CXPapMbuegqNwoOQc igCJtyqcd6pTTsnbmrjspUjpisO5lw2M5BoAY1wZGAAxio5pT0PSm8KMHvUTqA231oAh2k/ORgdq JCxwMUrSLt2A1HIxUYHWgBVCcEnBFSR5281U5PzGp4j5Y+agBYlUEEHr2qXcFYjNUZpvl2IMc9aY rsCCpzmgDV8zcCDioSzc47U1FZhxVlIiaA5zJkmXO0j5jVWVVyChG09frWxJYncXA+bFLHpwNpJM ykRRAs7dcAew5PSriRJnJzRZzsb7veuL8ReOfDHhWBpvEWsQ6fChALuCeWOAMKCSSeBgda8e+KH7 S/hvwpdvpXgfGpalPAHiuHAa2iBJHKnl2IB9hxyeRXwpqmq+JfHV1NrWt3Ut1I8p8132iMYHAVAA BgHgCuilEwnM99+IP7THibX59R8NeA7mXS7C5OxLm3Oy5kQcNgkAx59VOcfxV87T6Z4gvbz+0dfm eSWQbS0rhmYDplmJP5mprjWtE8K2R/dJc6jkEAgbhj6Hp9a8w8QeL/EXid1SQCBV7HII9x6V0ShY 5kzsZNf0nQ7lkjjS62jLAthfwNcDrPjDVtSlK205srbOQkZ/9mrn/wCx7hZmdmUjHbk0i2Lo7eWh Y7enX8qgGysbi8f5riYySScNkdj706G0W3G1BtGflB9PXmrdnGZJVtyNhUZO8Y6duaje5tzKPKO9 mbYqryWb0FBYyQ+W2Q2Aw5Fcs1hh3kDFnGePr3rp9A0DxX461SXRfBVjJf3NuhkmKjKwoO7N0/D8 q+1vhf8AsWXWrLbar8Rb0xwNy0cYOVHfPbP0/OpckiOU/PSC21LV28jTbV7vyyC5jywUZwMkA4z7 4r6d8BfscfEjx1bwa3rrR+F9Lm4QXQaWZ8eiIBjPuwI9O1frH8P/AIVfDT4Y2lxF4J0WK2a7CieV hvecp037s8DqB0zz1r0hr2VkCORsUAKo6AAYxisqlZ9DZUz5X+GP7Jfwl8ISx6tc6auvalboqj7a BJE2APnePlSSecH5f9ngGuQ+Mugt4W1WKHRo47K1mXKxwKEVVb2HA/CvtWGTy0P8NcP4t0nSvEEH lalAs7IGAJHIzWLnY1SPrD/gnfMW+Ft/G0rS4ui6FjkhX5Iz9RX39J3r4L/Ybii0jQNZ0OIYW1nJ H0bBA+gFfebTxmvCraTZoRk8gUzvQWGeKYTzWXQzJFYDipkfnHtVTJ60oOBmrgB51q9p4r/tCWeK xhvbXPyBmCH05/H3rkrH4peLbjWP+EZ03wvvuLd9smJSqJxnlsEDP1re+JXix9A0+306zlaK8v5V RJMkBBkE5/Ouh8F2ugeH9KBhvYZbm5O64kMwcu4zyTnt0oA7m0e5ltVe7jEUpzlQdwH0PepKyZ/E ujwKSZvM29kUt/IVBpfiSy1a4NvbxSrgElnXaOO3JzmgDeUYAFTg8H2qFD+lSgfK3vXRBkI/nJ+O 37OPhTxv8UPFOqwahdaXe3WpzTyeUUaNkJI2KpHHPOa+R/FH7LvxC0CE3WgXqa3ub5YkQRsB7sx2 /jX6TfEa6S1+IviZZWP7i6k/LJP9a4221Fb1RGvC9Rk16EKtkbuF0fllq3h3x/4O1F213SJbOXTw GkLMHjKN0IMZIIP/AOus6w+I2qWaNtnMqs4/dKPu5+or9bryG2uZTNNZw3DMnlt5qCTK+nzZ4rwL 43+BfA1n8PZdbj0O2h1C1mUwSQoIjuY878feXGflPFdNOpfRmcoHi2hwPcaSNX1gwIzjBTb8hHY8 9TVv7dZ24ZbaC2jGflZYwGzivA9S8U6tM0MFrKrWNv8AvAj9SzDnj0Fc9b/EyW1vL6fURJLOu1Yh EBs2gdfwrr9mc3sz6thjsbyALqlwYnZsKFwmR7msq4nsZJzb2UgdY+OuTx6V8nz+OL28ljuri4Hl I+WPO0Z9a6dvFV7ImdHIC9WKDlh9TWfwjSPWtdu4rNTJKdu3k55rxzVNSM1y8lu5LsMLt/hFc/rP iC6vr3dJqLAqcFX65HY4FaPhHwP4m+JXibTfBng+P7Xq+sS+XDCDtZz1JDNhQAMkkkDAzmsa2No0 4uc5KyN1Tk2kkfbP7EPwe1v4q+L4fG2sWltN4b8PyfvVuRuW4lHzKFTOGwQAwPHrmvTP+Ch3x1sL 27X4L6Dn/iSsJtQmRg0bSzLgQgD7pjU5PXk44xz9m63d+Cv2Hv2crdbSBJbyNRDao3S51B13FXc8 hFIzk9hjuK/n48Wa/c+JtXutcvGd7i/uJbqffyTJK5fgnk4J4zX5dw/KpmuYSx0v4UG+X9P8320P crtUaPJ1ZDFdslqIZVUbcZbAB471fttTuYZcxv5kfUA4xk9q4zzHBMzPtjiX5yeRjsKfb3vlR+dZ xt+9IIYjC/hmv1uEo7I+efMdNb6jexq10ZgJJCykKSNoz0xVk3t6ZhIHYMoySWILe1coNS8ohJNg yckD3PXFW31HzpHBGEUcEjGTU+73FaR2hubmSLzLic8jIXO7H51HI8jNFKrYZBkDA6nvXMw6hLvL NxGv8WOo/CpRdl5ykcgkHXJJXr2o54g1I65J7gwbTcHP3j0zmk+1yXEQXyQ+eMs3BrlVlS3JdpFy 3bPFXhdQFArMEA684Gfas+eJFjo4psIYFWSE/wAQjfjNEouk8tJJX8vdlT5hLA/WsGGaJQxhfKdW CnJxWlbXsc0KSAcDpnH8qz5U+g1csrPqMTSGNpjn7oaU9/oOa6Ow8UeMoATaX0itx86yssgwAMEg 528cDoO3fPJ29yjkiJtyPk8+taMLk9MFj6CrjTj2NIpvqdTefEf4i2UgVdYv5MgY/wBKm4P4NV4f FH4meSyDWtQwADiO7uBz/wB9Vx8cyBi1wjFwecdq1LXJL/MCCcgdOKn2FPsVd9zvF+L/AMVIY02+ JNQYKg4uruSVh7ZLE4HatW0/aT+LmirFcS6ibmKIYVZDuyPTHU15zJDCfnnjH4Gi3GnzDy2hBCf3 qPYo1TPZbb9sL4ibfMFjH5inORHiNx6OgIOPcEV0+mftofEOCNpJtE0w56bIZlZvrmVh+gr57tdO 0OeZlcnjsOBU0/hvRIW3xF9h5OWyAT3Ao9kg5j7A039t8XEpTXfD3kIFTDWzY2vj5vvnnPbpj3rv E/bG8HXkJ26fcWsYHzSO6MP++RzXwO3hXT5LXzEuMRrnluaij+Hj69ciW0uI41C8sc44+nrQ6Qcx +k/hb9p/4W65EXvLxbJHlFuobd5pbu5GMbOeuc+3TPo0vxS8BDNpHq0Cy5OPMbbkD3PtX5Kp8JdY V2Sxu0lbIyCMD9ag1Hwb440MNdRQSGNn8rK5IAPfHOKXsivaH7CaHrGl69CbqxuIpIyTyrZBxxke orWluo4l+VjJjjCivxfsx8TNJeSWyvrmGJVxuy2zB6gKa6rwv8TPHPhxGstQ1i4eBXLKiEkgnrjP QHrS9l5h7Q/WhpjcpvgYLk8561QZJCSScmvzv/4aW8bwiFNMm+zxRjafORDvP4g/0rqvCH7Xdna6 tJF4v0y4l/d8NDKo3yZ5+Qjgdwc0vZFqqj7Wa2YMXzznPHtU8KSXNwFKkj6GvJtE/aU+FN0vm3lv cWGV3ATMrZ+mK9Y0j45/B2+tk1D+24bJQSBBKP3h2jnGM9eg9SKh0wTudLb2F06jyomkcnGAOa5b xdqWleEVhfxHcC3ZgzCMDc5Ax0Arx/xn+0lcavNNp/hkS2FoSQssYCySAZA+YcrnqR9Px+f5NG8Y eJ7ebVL2+MduGdkR3zvzyfz9TXk1sdZ2gj7XKeFVUXPiXZdl/mdf45+MXiHWWFt4Eu5bGzRsyAqo eVc8g9a8fnt7zUr03l2zSSynPJ7nt7U2617RPDqm3nlDS/dYoMsh+grkNS8U3FmLe706bzUnk25c ZIwM9McVxxwNas7yufaPO8uwVJQpW00st7+bPaND+HFtaodX8bXsOk2Ns24QSHLzBMFgcEEKRxkD PpXsE37Uvw/0q1sNN0C1fUbeKJYUWL9zHAkYAUfMOc9sdu9fEVz4k8Q3olGsXP2yEKwXeDlc/WuG +ziyjTy3wFOWA6tznHFfQ4TK404+9ufmXEHEFXF1LXtFdD7A8V/Hfxt4ie5uNDik0W2toy6bFV1w pzli3POK8HsfHmteOLN9Q1vVWe8UDzoMsFIA+UjtnBrzfVNe1e7WSyguTDaTIoZI+OnODWNGfLiF qjFA4wcHB+tdrpR6o+b55d/6+47ODX9PsdRln+yvKY8mNsgDNTz+PUudMMVxbNDM7HcMAgL9a4iE XLx4dd3lnByOo9cVjX2ow2OFupVWMdd3b2ovHsFpd/6+49Fg1+3sLbzLDdJLj/vlqz47mSYGWXlm OT9a4SG5u7qeKx0q1mv7q+fbBDEpLO2CSF45PB/KugtdA8bXM0FpD4f1BLqRioVk2qcDJO44A/Gs 0zNyudHHqf78Sl0UKccf4VS1PV0kjyjMyL/CgxzWafCPj/TlluLvSJjbq3JYgqvryKxray1CW5Wz XCSOdxLHCr6c1uHIzoDrN5aqsttMyjAIBPIJ6g4qkt6k90budwXAzg85NfQHhP8AY9+OniuwtNUD Q6bBqab4ZZRvjC9F3EdNx4HX374h139k7x54a8Q/8I/Pq9jrV0iKzeQrJtlLbXjHByVPp1HPrgDk Z4ZFqSoDI4+VSTx1re0/ULe9uZrSMgPCgcD+8D3/AMfSvX/iF+x98dfAvhCTxvcaUWsIZCspTJEU QXc8jl0TAXgY5bJ6dcfMkdpdfamlvYPKlaMJ8rfw9R09aCWj0uF4d6OY1aMnlewP1q48djJcJM0O +3zlh1ANeexC8t4g8E2EXqjnIq4Nb1JIJPK2PHjbgjAz7UCPVbbw94auD5lsJUB+Yjdw1Ft8N9K1 FpZFK7CfkVhuIrzKDxhqNttmaOP5hsbB4HuKkl8WarIjWcVw0EbfMJFOMH0oA7rWvhRq1oDLpk8F zAB/HlZC3YDHFcmPCnjKNg0WnTsucMzcJgdTnrXUeFvHD2+iPJLdSS3CfIQ5OCB7Hoa63SPiJc6g 3lNGjJH945xkf1oA8VXVtX0/UpIYdwHdAhb8gK9D0H4iX+kThhaNcyMPlBj2nP1PNekw+LvC0hWa W2TerEF0X7v1qeS28M+J90kF+MgHaRjKn+VTJFxIrD436PbhIPEOnOrDlpUG9UPXDKOvPpXQy/tA J4jtk060uZEtX+Q7l2RgDpuPUVwK/B+11CSUjV9sijK71wMn1C81k3HwK12cxf2U5mAO2SRPuj3I OM/jWc6MS+Y7ybxVcaxF/Z+l38c0CEOdjbjvHGVqTwuskWs/2qG/fabIMkjlz1rxbUvAHjDwteT3 5t5FgszsMyELyfalt9e8XQMUtJ2RXwZGYbl4xXHOmjaEj9CD8e7t41ivNFR7aPAKE8tgdzXzX8QP iN4guZ0js9KYRXhLPMeUi5+VAPSvNofiJqgixIiMyHbgD7xHet/Svidp15E8GuW/2WSM5VgNwPtW fIac5xNxquvxaj9vuGD5UKqhflI9cVPD4g1i6uSLi5IjBACHgLXVTeJPC2qystpIGYHJDJjBrQbS NI15FkMYDNwWT5fxxWtgZ//V+N59St7eMTHPzgMBn1rE8SSXM8FjDb2k07sxYKsbFnyOwAr6QtvC 2iwTRTzW4mlibOcDbt7YGOCPrXSHyouLWNUx0A6j8a/TsF4B1FK9bEaeS/zPrM58faNalahQd/Nn gPw+sPEt3Z3FpqVrcafNCv7vz0Kocn5R+VemW3g68W2DahcxBz1CZJrrTukmBlbKY6+9VgTli/3M 8V97lfg9g6Ks5yl9y/Q/Fc18QKteXMkl97/UYliixIm/5UxgHncQete/+DvjtqfhK2OnWdgrAfxM 7YzjGAorwFi/r93p9KhaVkXaoyXPNfT0PC7L7e9Tb9ZM+aq8Z4rZSX3H1Je/GrVdbHnykW8i8qFY 8Vxl98Qtc1YKmo3LSKhwN3PFeKwu9vIMlmrSS5Y5GSxFepDgjBw+GlHTyRxz4gxM95vXzIfG1h4f 8WyTJdxkmUYJPQ461zvw4/Zd8AePNTeVZooJNNAZYvKP71myMMScY/4Ca15ZDGzy7c/1rW+H3jc+ DfGdrqV2D9lupFSZQcAKDwT9DzXyXGfAuElhpVaEFGaWllbbyPb4e4kxEayjUleLf9an6A/DX4Q+ Gvh3oa6PoNotujzG5l29DMygFvyGBXsyMIkC46VU0yR7mPzimzf0Ht2p82QCPSv5XrRak0z9p9op LQuXDwX1q1tcx748YwcYP4Gvzf8A2h/2WftV2fFHw9Vo3myJLFUAhTb8xdCPmDMeo5H4mv0NVyFA Pao7i4rmqU1JWO3A4+dCfNE/nqvNF8TaPdy6df2Mkb28jRyE88qcHFbvhXwh4v8AG2sL4b0mzYzz ZZGfglV5YL746Dv0r9xbvw74Yu7lrq602GSVuCzICTj8Kz49H0PT7g3VhYxQyYwCiKDj6gZri+pW Z9h/rk3BwSPm74FfBTS/hjos2oNI13qt+Rvmkj2FBGT8oQlsHJO4559OK9+CscFuP61pztntgCs5 jkkeldCVlY+IxNaVSbnJ3Y9sdCeaVP7xPSoBkncaePfvUtEJl0SvkDOaimLuNrdKjyqjI60qyYyM 0nTurFXsc5dohl3d14xUkGS2MYq3eorHcAOe9U0baM96/IONcuaqXR9zkOIvGxrRbhwa0Iycc9ax 0kcgNWnC4Zg1fnVj6UtZJ61ImBUbkHpQmRQBFdjfGVFcnqCtHbtsGGrp53ypA61z12GeNwetduGl 7xDPnXUZXstY+cZbcCfbmvddAkElkoY5bqcV4x42tGF+kyDLMMPjsK9c8LlfsMXOWKj8gK/Z+Fq1 4pHwmfUryudXGdy5P8NTxMWccYqKNVHy9M1p20A+91xX2h85EnQ5GMdKkUZBx1FS7SOgwKXHOAKS 3KbIZYw8RLHPHIryLUoJIr54yuc817Oirgq34V5/42thFJZyQDCqCGI9T0r5jijD81Jnq5NV5ahy CZzuIG0VrQlvLB9uKyFUdOp6fjWtGQUAx0xX4LVp2qO5+hqd0kWM5wSOar4LHmpd4VuajY85qREc 25VIHpXP6hlYHRlzuFdSoB5PpWBqEkYRnkPA4rqw05QmpRFUV0eBBBb3hSc/dcjmuthj3YEXfBBr ntWhgk1GXyvmTrW7Yyxi1RUJDKOTX7bwxjZzp2Z+f5xRSnc9H0a7Owxddtd3pkyyRkDg15NpNyyS qAuUcV3+jsxk2qfwr7Om+54jR6PYg7Oa6KFlaMCuW0+VlOxhXTRnCgqK2MGXGO1eKeh4yetRA8ZN PzxkUFlsE8VYj6fKaoo7dBVtCuPQ0AXUPetCIkgZrPjJrQQgjigzLYP6VOB1NVlGMVOrdaqQD+mK MZPFIqljVhI8A1QEe3pin4A47VYWFuMDmh4mDDjighsgAFO25GacUwc00ZzmgQm3jpUirgfNTsE8 0jDJFaAL34pwPOO1GD2p+PUVmA1QM5FTYyOaZ0GBU8Q/vUAWbe33/SrSWvzYUZq3Zx5KheB3JHGK /OT9oT9uweAvEcvhD4fR2811aStHPdzqREcZG1ckAYPfNBUY3P0lhtDDtdx+FfMP7TkrQx6ddRAM 9lE85U/QqT9Aa/Lvwt/wU++KyatEmv2EF7bRyHcsQ2k89AxyAMe3PTjrX2F8Qvj34b+Nvw+uvE3h aKeAxafKsy3C7GibGWjwPlbH94Ejn1yBnWfu2OjDw99Hxt4D1m81mxuJLwATNPI5x0wzdvxzXovC DA6rXgHwcn8y+1EM5AYKRnp1Jr3osGY47V8rimuax/RfC1VzoXYszfLwc5qlNkNgkVaLKUYHmsmU ohIAJrhPro0xknLjB6VESNzZ6CoZJlRS3ftVVrhZAzg8d/ag6FAuO0SEOD1pgKlCGOMniq9raSzy DyzuRulbkWgXG8NI3APSgr2TKsSqy9M7aD+7G4rkCumbTEChVOAOtJ9ktYF2uNwqOY2p4KbOYNyJ O2D/AEq4EZyAi7mxxWj5dmsgKR9OtTXN9Dbor5WJR1PtWXOd9PKJPqZ4tJwOcD61qW6ALs/ujrUX lanccx2sjof4tuP512enfD/xjqFsLi1sCUYZ3MQMD3qkzV5Wo6y2OaU7RjNBu9nFe2aL+z5401W1 W5uLu3tY3HAOWY+3tXbaZ+zA1yD/AGtqDGEEbio/P3H1rrWDqvaJ51TNsuov95Vin23f3I+UZNWj jBVmyx7VLDcXczeXbW8kpYfwqWFfoHpXwE8J2NwJIrV7kKNo3fOMfSvVtO+DSQjzLPTFjR1xnYBg fSiOUVn5Hk4nj7LaV0m3b/t387H5c2mj+Lbv5ItKuJQc4+XaOPfp+ten2XwP8e3UUbTRRRC4Tcp8 zJXPQEYBz6jseK/Tm0+E8kUASIxwceldPafDPSo41W5kO4f3Bj+dd9DIn9pnx+YeLWGiv3MUn9/+ X5n5naB+zRrQR5db1AxeYflEXt67s16Zof7N3huwJm1S8lu5HwChQn5B/DlcD9K/Qm38G6FbgZg8 wjuxroI7G0iAWOFVA9BXfDI6f2j5TEeLmK+w7eiS/O58W+G/gd4b09nGn6FmObgFl3AZ65DfhXq2 l/CC3sQWsLGGyLfL90Dp04FfQwUKMKMClr0KeVUo6qJ8fi+PsdWdnUdvV/5nkVn8Mjs/027G7sEX /Guitvh9ocSBbhTMw75x+ld3RXTHCwR4WIz3E1JXc/u0Mu30bS7UhoLZEIGM45wK0girwoAp1Fbp WPLq4mct5BRRRWph7VhRRRWZPMFFFFAJhRRRQPnOG8bara6Xa25uG6yA7cZyO/5VyGtaumj3lnrW mACOddxUDaCO/FVviZe2TalDbuC0sacEHgE1w9yJtQ0S3upZfNZG2queQp9vauOpUlzH2GX5dTlR UpdT6Y0vU7XV7KO+s23RyDPuD6GtGvnD4f3+qaRq7QssjWsvDJjI5z8wPtX0YuGUNjqM12U53Vz5 zMMKqNZwi7ofRRRQcQUUUUGYgGKWm7hTS+OtBoPyKMiq7SLtLE/d9qrPfFVBVM0EyRf3AHNG4AZ4 FZ/2lpELRsN/93FMKtJCRJGwkoEjQMiggMw9etAlDruXke1UhCG2uBtZeDnmp0QxqVPQntQIc0rA jA4PeoJLiXYxiGWBxxVgKF4HTrS+WmdwUDuatAyPdIjJnJ3dfarearSyrGRv71GLpC2APl9TUAXM qOtICSciqbTuG2nBU9xTJNxmwpLKRQBdLAEYP600zImdx56VnNbzMMBQCvIbNPjtboENJPkHqMUA X4pllG5TkVNVWGJIixGSWq1VRAKKKKoAooooAKKKKACobhxFBJITjapP5Cpq88+KOur4e8IXN6WI aRkiXHBy5xSaA8pvZlluZZF/iY/qapSDNQ6bMbyxhuiMb1FW2WoGjNlTnNZ8yc1sSDNVpIsjNBZh SIQKoyx7lrcli7YqiYsHFAHNyWxU7sVD5GfmxXUi13DkUx7RVHSgDjZYUZtpWs6awhOMCu9ey3Dg YrOe1A+VhQBwxsyh46GpYbbg4XmulmsyDkdBQIVjHA60AZEdrxyMVejswBllyavJCG56VZER/CgD PKJjAFAgGPu5rQ8huuOKekWDkDFGwFeKIjnGK2o43KjIzTIYM8tVnWNUsfDHhzUPEepErb2EDykj GcqpI68fnxRcaZQvYlji/e7Y8jILcAD3NYUttHLF5kRWZf7y8ivwR/aE/a28ffEbxLfRWWsS2mkO FRbW0ygBU/MnmfeK5AOf73I4wK5D4V/tYfFLwDr9ncWWs3U1huCT2E+JIZYiyltmeFc44IoNLH76 ahY7zkDmuG1W0bPAxiul8I+MbHx1oFvrengbJFXJU7kYkZ+U9wPWpNTVDn5aBHCW1vglXGQRg8V+ PP7ZnhCPw18Tzqtnbslvene8naSY8sw/Pp25r9lPMKy4K4Ar4e/ba8NRa14BttUgtRcNpUjN5ozm NWxuwO/T0Pf1ppmTkfmHYSrIgERZXBzk9DWsnJyOorl7C4iYqInIbAz6jFdHA6kMvUn+I1ZBbAYt 8rfWpcZLK3DD+VQLtAyp3EcYqRePmzkmgCdPk4PQiqVwqMQp+8TVuPOSCOnSoiBhmPT3FAHvf7IP i8+EfjNaws5hi1ItasucIwk6bvoRx2FfvFAqGGKXqWANfzU+FvEFx4U8Y6X4itlLta3URKrwWUno M+2a/pI8MX8Wr6JaXqj70ScdgcUFROwt/mjDU4kAk1WilVPlNTB1fkVlYtMjY8VLDIQMVVZxkgdq RXIPNFguW58FQSFYdDu9DX5zftA/s43ipc+IvBbRtciSSR7cqQVgIzu3HdvYHPGMnt7/AKHSSEtl vu1g6gFnO7BUjoa58Rh4zVme1k+c1cJU56bPwBi1SbT5mjui8UynhWUjcPXFdFZ+J9QmRoni8xH+ 4Vzn8RX6/eNfht4P8bW0kGsaXA0xGPPVFWXHs4GRjr1618vn9kjwxbX8U7alcm3WUM8OAoMeeQD1 6dOa8GeR63TP03D+IsHFc8bP1PifSm1LXdWXRdOt2luZ/lHGMe9ffnwZ+D9n4K8vX7mQXN5Im0HH EZIG4D15zyfp7nufDPw18MeDIPJ0aDBLlyZMM2fr6+9ei20ccMHlouM88dM11YXLFTd3ueBxBxfU xUfZQdo/mbEE+xtygDHpwMV81+NVXT/Fss+wqlwd/TA6c19Bo237x615X8YbJX0CHU4QWltZVyVH O1uOv1rPOMH7Wi49jyOHMa6OJTj1KNjNHLGJLdgw7VsIokHQg964Dw5eZs4hKfnIHSu1t3Gct1r8 1lT5XY/aIu8blkx7+f7tSWU7RXMSJ3bFKAX+YcCs+4aRPmjGCDkGiErO4/Z3Vj6V8uNNFEqncGjJ /GvlvxVak3DyhOck4r6C8O6j/aWgm135ZBj3xXnXjWzFuieYOo6gV7kJXPGbszw+zudrBnO3Brx3 4k2Edl4mWXduW7TzAfevWZleGUuw+T1rlPiDpI1bRIdSUfvLNuo/umpkj2MoxHLUseQph4wD8p9a qahEHXeR8wGKtwk7RvGcdqr3b5hJYgY6Vgfawnsfdf8AwT6dk1bxHbjkMsQJP+yDX6aTlQxDd8mv zH/4J/gjxD4jVuSyoRj2Br9OLxQTke4xX3+SfwY/11P5m8Qf+RnW9Y/kjPBJPtTsk8U0AjinhT1F eu2fFMUDjFS4GAKYFOM1KEJwakyEBwamBzSiPoalEeaDQiX5akUEnpU627GpkhIOKDMgAOeRxS7T nIHFXlgY9RxVpbViOBx9KOcDMCMc8U/aCef0rVjtPmIZanW2iUAk45o5wMlYz0AwKtrGAKkuL7Rr IstxfQrtGTl1/wAetcvqnxM+HGiztbalr1vC6rv5OePwqeYdjpxbj0qVYP8AZFfO2tftffs++HIH e/8AEsbyIrN5caszkjjbgDIOeK8m1n/gob8JbaONvD2nXGpqVzM3MRi9MbwA2fajmLVJvY+7UtVO OKnFsgzX5i6h/wAFLLVwYtL8HlEQkb3nVsj+EnCg59v1rx3Uv+ChXxWv5bg6ZZWemq4wq7GlZeuC Tkfyo5ivq8j9pks2Me8LxUhS2t0Bu3EORkbscj2r+fLVf2uvj5rkcC3PiFohbqVXyY1jOD3Y8lvq STXn2ufGr4x+JJFa68WX4KLsHlysmVPYhcD8etTKpYr6uz+jW98S+E9LjafU9Wt7WNecyOqg457k V5Hc/tQfA60u5rO88R2yvbsVbY5c5Xrxiv59b7X/ABjqsAi1vU7jUUiOU+0zPJtJ6lQxPJrENvcy jaZWx2A4FT7XyLVBn7va3+3H8E/D8k1hHqP9sPF8yvajgBjwrZH3l7/415X4i/4KO+ArSKFfDmi3 Vxcs2XErKiBfYgMSe2MDr+Ffj7b6YNuCMH35q3LaKNg2f8CqXUbNY0kj9CvF3/BQzxHrWmXOjaVo 8VmbhvmndizIuM4C4x7Hpx7815A/7X3xV8PXL3uj34ma4UK6svyDBJ+XByOvr0x6V8pPbAcfeZqe mnLszKMe1VyxK5Ee86x+1Z8ePEEEkF/4guBBOmxogURcZz8pUBlPuDn3ryLUfHHj7Voli1fxNfXC IcorStsU98AVkSWsiooiXd9KtWGlandSNiBtq+ox/SplFByozpbnUJPlnup5JAchmYlfyqQwvMwc xiQj7xHBNdY3hXVUQlYmYMPvLzt+tXNM8Fa7I5jmj2I4ypzy1ZlHEPbSE+pUYAOKpraPEHDJjJ5x Xv0Pwh8QSfvZ4mjgGAGwDW6PgXeAo8ryRo3PQgGgLny6YxI/l4Oc8A8GriWsgnIIbgd1P8zX2L4W +A2nvBcNcRqJ/wDlmXJP9K7qy+D1tCqwS7XYd1Of5igD4D+yzO+xYZXcHoqnHsK6O18Ia1fo8cmn zQyIB8pOMZ6EV+gem/CG1hmVVj3qcnlR+ldrbfDnT0IMyZ6DB6jFAH5wxfDbWZEUW8Qyn3i5JP5C ujtvhbqDlYpGU7upVTx+dfo5a+CNDtFEtvAqyL3A5P1rbh02wgQYgjOOpKAmgD88Lb4GaveIkkLl 4uoJUAfn1rrLT4IT3BSKe3Xd0IJOPzr7yEFspD+UgI6YXH6VaYw8MVXPsBQB8sab8AYtMtrgWEcb x4XZvGQ2c5GM5445rsdG+Cekoi3Go7FnH9wYA/CveMjZx0qHepOKAPIpfhXpaH5Qr7exUV1Np4K0 eG28owKNwG4qME46dPSuzJFMc+lAGND4Y0iAo1tCkRHUgcmr9zYWaAJHEBnrx1qcFx15/GlG5jlh gCszQrIhhAQAbR0FWlSI8unHemEhjjA4psjKoxmqTAsyLCyFFTA7VhtaMWO08dqugv6k1Ii5bOcC qArw2pjwzcmr4bIwRzTlAXOetQuzZ4FZmY4vtyo60btuB3NRDoSetABOPWtDQmR3LEdjXnWuRpe6 /Da84GMmvRVCxMXbqorlLPZcanNIcbsnBrMzOuUrtDjtxSKQSRnp0poVxGAOlNXhs00XcfgnHmdB TgIySoHSoixc470d/c96sLhIABgCk2hlHNKcA4JzTd4xwOlAXHheMNzilOcZXtTRkjJ4p+di46UB dkZLY5NAORzSjOMijAIAxQF2Js3dTxQV+bPalCkMRnijPGDQF2MCKWyKk3YBFKilGJPQ1HgruLdD QQHzdFphDAEZ4p6kKuaRWRxigBRwvXJpvQ/McU7aPoKacMcelZgK8gVfrTRllyaTav4UEBuBxVJg IyhyATSbNpwDTtm35m60rEAg9QadwKzq4fcOQae3JVegFOyOmabuznb1ouNC8AjB6UrNnAU4pOQo HrScI3AzRcQZYZJPIpdw6k9adIOmKhfOyi4McMZwKjb5ehzmmIHXlzzTfnZ8npUGYbQDnP4UzjOD UjbS2OhpgAyQePeqbAYZNnGMio3x0PelyQ5HU+tAX5vm+9UjsDHaoI5NVzKckkYqC7vYoZBEMlva oPtG/BoCxYkkcsNpwKhJIPBNR7t7cdqS5JTAU4oKSIriQhtoPJrLyZGweq05y7Sb85ojIBcnr2oG BbJ2nmoXk+bJOcUpcqD6moNik7iaAJFAILEcmgx52nqBT4o930FWTFh0EfKntQBW8pXPB2ipHtmY AL3qxPqGiaTGs2s3KWiOSq7+NxUZOPoOteOTftE/DKMTyR3beXETt3rtLAHGcA5GewPPrVRjcmUr HqU9usWFJy3erNhp4uGYegzivkTxB+1lolrqL/2Zpsk0SNje7qAV7HAzgGvEfFH7XPxCMUkLz2el xbwyy20JY7OyneW5ORk1tGlcz5z9PJFttPQi4G0EDk9z6Aiql/rejaZYyXN5dRWyxpvPmHGFHcnr X4z65+0J451y48seIJpokXerlvLBOMZwK4DWPi1rmqXBXUdTmle5TawMrFQoGMY6c0nQJ5j9p5fi /wDCyGye+vvE1lbwwL87sxAHYe/J44FfFPx8/aA1XxTcR6L4N1IWWjJkCS2dkkugepcFVYKOgXv1 PBxXwPqfjnUpI4reMLOqHowGCB6+tZd94pvbjywm1ATnAAypraNGxnKdz0e2061Mv2y9clcg8k5b nqa2NU1CcRRWdgQY3BIA4IH97614kfE1/wCW377cRn5Scn8qxZdZmmEXnXRYIdxbJB+mfSr5DM9A awjWR2cgyHqXG4n8TVO75cEyLwu3AAyBXFTa/KbpfKcbWU4YnJO32z2qWA65qcrNp1pPevwMW0Tu 4LewHem5ktHc+G/Dd/4m1htBspR80ZeWUj/VJ/ebngCvY9I+G3gq3uba6guJNTmtwEkm34R2XqQm TgcdK7z4NfCm/wBO+E/izVvEVlPp+sahbM8KSqUkAiBKtg4IBPbv+VfP+m61d2kAg3ZRD/DkHd+F RzC5T7MstT8FPaxWWr6RZ3bJH5TebAjiROgBUg54rmbb4d/s0380Fpd6RLFMkrHzDcyQiMuc/II2 A46DPbAya+bL7Xpr23FtHI6MTnPcE+hqjBqd3au8c80k0ZAwHPOf96qKSP1r8PWfhHRtOtbLwbY2 thZoPkS2jWPccDLHHLMe5PJPJzXR+YdzO/H+zX5Mad8UvFmjtbRadfy2a27goFO9kH1YEH6EV9Pe EP2mbHU7w2etPKxlbLSsRtUgf3R2J7DpWcojPsA3wVichFHaoP7d09BlpR19a8Utfid4d8QWz3Vl qUMtushiyG2Nu44w2D39KfqOsWCp+7IDp94da55RNonrF54qsy+LcsQuc+lcjJ4oWef5FPHBB6EV 5udR81d6TAKRlyOgFc1qesTW1uXt7hWDHAJ9KxkgifpP+x541tB4p1fw7v2xXYE4wPmDIMHJ6Y4G K/QOacj585r8bv2Jr9b34yyIeTFZSFx/e5AxX7E3eFPA4rx8QvfZUyxBeMOW6VZ+0qcHJ5rmkm2Z 561Y88KBk1khJHRpJvGM8VPEMsSSNo9a5mC8Uv16Vp/bI9pOQRVlJnm/ijxj8O9Xvzol+w1C7tmD BEUkAjjkj0yfrXKXmv22mxsNG8MTAIyhXliKJgckKMDj3rG8Qwv4I+JUXjnykbSbpVgfaqqATjhs 9eRkt6V7B4v8XaZa6YbKBkuru+BSGNRk4I++Mdh2/wDrGtTI7LQptJ1TT4dRsUjZJQG+T5gpI5AN bB2q25VA/CuN+H2jTeH/AAtbWV0pSUlmK+m5iR+ldgT8u6kA5ffvVlfuGs9bmGPPmuE9NxrI1Lxd oemRMXuVkdASVXnp6ntTsxo/DL4vGSH4peKbctmNr1yAO4+tc5pJbO4rtx0q/wCPtSi1rx/r2rr0 luZTtGDjDkHvWLBq+jafE1zqF/FbR5CguwHJ6dTXdHY6lsdis7ggA8mvNvi7o0uueCNSSOURS2cb TAEEhz6YzgfWuY8VfH/wR4a1pdH02C41SeJT5wQbEyemyTJ3e+BXzn8Q/jZ428Ro+iPeiytSuTa2 yKpRCeBLKAGdj3B+XjgCuuitbnO6h84avDILx4ORIwHA7n2rnf8AhHvEAR7tLPCJ1d5FUAD619ee CPg54p+IEFuNJvNNsY7hsK1zJiUju2cED86+vPhj/wAE79Bhn/tz4xeI4dQ06NS5hglaJNigk5cl dmODuye/TrWOa57RwlNzqb9i6WHlUdon5Q+Cvhv8QPiTr0fh7wDoU+szuyiQwJuSIE43yMflVQe7 ECv1I+Hf/BPuHwnozeKPj7rUENhZjc1paymNAFySZJxjAPHAAOePr7x40/as/Zw/ZfsLrwT8JdJt rzUQFdktOLUyMCFZ5QSWAxyoIHUjk1+ZPxL/AGm/i38ZrpT4j1JJrSJ3aO1tUaOEBjwNobBwOBnk c818MswzLM53jH2dP8/8z0vq9Klpuz1H4geOPgx4WvZtK+FPh621MyD5r64RlBPThWG9gPUkV9uf sDfAy48P2esfG3xnawW9xrES/YBtw8EAyZZgBwgfIUY5Kg84YZ+K/wBlr4H3vxm+IJTV9MMGjaei zzvI/wApUH5Yh/vY/LPevu79u741D4TeBLL4PeDC0Gqa3EovHhwqx6eFO2FcHKu7bcnpjI5zx8nx Hmbq4mGU4V3lPRvov8/wOjDUfddV9D4s/aY8Q+NP2pfj9a+BvDDJZ6BbyLa2rM5eAQwB2lu5cEBy fmIUDpgdeazdN/4J8a5O8s1/8TdO05iWUebYvtC54JzMo59hXx/beKPFum3DXNlqEtq0pJLQkxyg nrtYcjPfmub1DxN4wvf3DapeXnOR580kgQevzmv1nL8t+qYSGGorRL+n8zy69dzk2z9LvhB+wBZ+ GfiloviDVfH2j+LNPsJRdT2dpEGaRYwcB4y0i43MpGev4c/qfY/CrwzpdvcRPpFjLDM5lKyWkTYY 9cBlO3PpXwz/AME0PAOqWen6t8SNSvImF7F9iEaKScwtksc9CQ3Ue1fqReW7PCRF9w96460qi0bC CPBdQ+H/AMOgPNHhrSwx4dfskXzD8qwD8NfhJKpSTwbpZ3d/skWB+lej32n6nNIzFCFXv2rm57HU CcFCe3TisbeYWOQl+CvwIviF1TwZpkr/AMIW3RB+O0CpX/Zo/Zy1G3L3HgOwZWwMjcv8mFb40bUx IfkYd6zvENxqGm6RO4DfIpLD/CmnJbMux5B4t/Za/Zrnt7zw94W8JaXZavcIY47l5Hf7K56tsV+G A+7njOMgjg8LL+xx+xp4as7LR/FmoPe3kuS8k07rvlC7mYpH8kfB4HTnAzmu10L4Z3V/4Jm1K1VV v7xZHhaRyN27PUnOCOue571454ZPi/T7Wa21jQby9eSYL58qvOgVfl2A4ONvpnjpitKdecXuTKCZ 6Np37B37I/iu3k1Hw0l+9vExizZ6jIY9w69QccdhWfdf8E1v2cZkPlahrNuvZWuhIAfxXNfRnwv8 CXXhe5k13zJLUahHzZAnygOzEcjd29hXsu7aMEZzSq4mb2diY0kj83Ln/gmF8IHs3t7LxVqUU+QY pXSNjGAemBtDAjruz61zuof8EwtOtE83Q/iTPGO/2i1DEf8AfL1+owQr82Ks3hK2DFELMQR9OKzj i6ncJRSPxC+LH7ER+EPhy+8T3fxFt7q3tLcyRwSwFZLmYdI1y/GeOcHHfHfxrwh+z74u8c6VHqnh 3X7BY5VYrHLvVwy9jhTx7jNfQP7enjuKTxjaeC7fzHuLaGGWfLZTEvIAXoMda+Q/DfjPXvDGoQ32 i3ZjS3cSpGSdu/vkdwehHpxX0WFcnG8jnnuej3v7KXxztLbzXax1MP2trkBlx3PmBB+tc3N+zl8d bWWFZvDVzMEGSYZIn4PToxFfW/ws/akju9Lt7Px5CqEStm4giABQ4+V0BAwvPI5x1zX2LpPijQPE ekW+qaFfJcw3S5XY3zAAkcgcjkHrXSQfiPH4C+MejXk1ld+DNSPkSMpbyy3TvkAg/Wqd1F4ntJJU 1jR76xRSFYywSIFORjJI75r9v57eJZPN2jcOSfWuf1+DTbuAi/toZYj/AAyIrZx9RT5hWPxZj1m2 Km2mlKSAY28n+lb+n66ljbl47vcxPy7ep9jiv0/utL8KSIyRaDp7gnkm2jLE/wC8VzXzv46+AvhD xVJNeWFj/ZV8uSrW/wAsRJ/vRjj8sUcxSPl2Hx1dn9xtKFhnKHI49SehrptN+Id/GqwXkqtEuCcn Lfh61x/iL4V+N/An2mbXLZrvSLfYz3kSHYu44GfSoNE8Nrqrm4mujFYyHb5qAFlHTgdzTuO56svj vTpjGZEYrOdoLcIPqO2fcVsWPiPSr288q9soF3DIYAHd+P8A9euKj+BfiS4RL3w/rtpf2oG5vO3C TjjBVQR+RqtqfwP+LGjxI66ULq2lYMj2867Pm5xzgjPuKjmjH4ilTlL4Vc9Pjs/DjySMlvGGfkkr uHP1qhd/C3wtqM8dzpzLHdkZkLEMCD6Y6V4TqGpeMNCvNupo1qzLhA+XVtnXBHWrOm+NNUtpFEj+ WG+Znj4O33Bq48r2M2pR+JWPSNT+EeoTbYtMul2DI+ZeD+dY2ofCrxrY6fPOY3maEAoUYHP0FWLX 4kyxkPZXZlbHyycFR+Fd/B8W7iHTwb1i6uAplPy8+2KdjT/CfPtvq/ijwmk+quBiMKpDhiAR64/X PFTax8TfG3iK2s7S/wBVcWcR3xxQp5IbPqQOR6V9GW/jnRGib+24oXW5Xy5NqAiQH+/ngj1zVu68 EeAvG8FtAJ0sYohiP7OqxYX+6cjGKyhho82yOipmmI5eS7t6nxtqM0cd7LdRuWe4jUEZ5yDyc+tU W1zUIHhTTz5Sw8srYJPHXPrX0X4i+A7C2C+GtWguirsHV+u0jgZ9eK8V8R/DrxB4Xtkj1KIz3FwT hI1ztVT/ABH8a6TzafMVpfHemyL9mSCZMDEhcAgN7YrBu/E2kyzrYiXYpOVdlJBP4dKb4Z8LaTrH iO10rXbxrK0nJMrhSQAuM57njPSv1q/Z2+BH7KEdtcal4TX+2NcsdouV1C73oEYfJJ5BwpUnIXcD yOOmSpVLG3XU/JO0vLm7hM1pCWG8oSoOwEepx174ra0jS/EWqa5aW9lFGInlMRkLDDSEDavryTiv sX9pfxNZr4ybwjY2kFjY6WpSBLdURG3cFsKMEYHBz1r0r9if4TWvxA8arruqWpm07SGLnC4Uug+U Z6ZJx16dR0riqYmRvClcyPCX7Hel67odtqfjq9uhqFxlpEtGCKg9MkEMR647V7p4c/Zt+C/h17KW LQnvLrT2DrJduZsupyCysNrD2xj8OK/RkeCdKtbMWsESoP4awv8AhD7K0LOMH+8DzWcpto02Pzs8 RaP4V0zxXbz6bpUEBt1aMgQooKyeuB6nj07d69ll0TwzqlvbXMtirToignp8wHpXL/tCeHD4Y1rT dRgmU295ExZADlZUbOST1DAjAxxiu903SLm60Sx1ZZlUXMCPgjqcV5MJP2mjPcr2dHVHlHi34cxa raTQwRF4pxtaBR8rDuCccV5V4N/Z80zWvGFjDcWS20VswaSIKS5SQiPK9Q21mGQ3Ht3H1W9zNaof NYYX2rUsdRvLMi+0u48mdFIRwQCN3BHNe1Quz5ypPofov4b+HXw9sPB1npVon7qxt44zI8xLqQOj 8gZzxjHtXm3w5/Zy8B6Z4wTxu2n/ALyyXMEcjmUeechpSSSCccY5H5V8BP4p8Sx6tBeahcx3EO/D t5ZDAN1IYHqDz719VXH7afhnwhpVjoOm6HcanfRwhNiMEjR84G9iTtB64+Y13GF2bv8AwUI1HTNC /Zm8Qu10LW5mCw29uCAs7SMFbKdDsUls44IHrX8xnk7biUl8lwmPpivsf9pv41fGD4peKr3xD4lu na2sGltVskO+2htwcFFQYU7xyzbckgHsAPiO2nWQ/aIUYjJ4J6UCNGUDzFUHCgdxwTVtY0FuEADA 88cCoIZ5S+9jk56HoBV6a4iBEQYAnkYNAFdLS1ZFNwo+Y4qFbGRnaEIBsPHoaui4kyy+nQ+lQi4M UMkcrgfNlW74oZCkUPsNyJ/shO9ywUKnGM+tdePCPiGygaaBSHxxj9a3vCOnvDFPqVygDTDALeg6 ECt2TXY7SYSxtuZFOUPesvam/IzyWDUNe0xsOuyRs8Sdz7rVi28Tz6aSFiVpHPzsvqfaprz7VfX8 805zv5GTlgD0xUywRCMxuuzeBuOASMdKfOFjfs/F2ogeVqN4sLYyhT5XJ9DXaaB8Q9U0WHyY7xmS UkkE8g/SvJrrT7a8LBJ13oCDnGTj0rnlhv7ImUzhwflyQc49jSuRyH13bfFu0S1lFzEt5ImNwPAx 754Natp4v8Oa4XfULKONXUDKooJHpha+N4vtMUKwzSGWEHcFY4OPf1q0viq90uL7OluHg6qwOGP1 xWckbR0PrjUtG+HF8y/aNlszDahBPPvj1rJufgrp14j3mhXgJdfli4dSD3Y5r52TxqXtkSK284qe cn7o+vpXXWfjdEsDeJI9o8YywDHBx6c1nyl8x1R+EGraakzi6jbaSu1UO8egJrkp9F8V6PNHBHDP uHIcbjGB3J9K6rSfjAl3bC1mkKkcl343V0UfxEurgofkkzncuRhlHvVuI7n/1vP0eTBYjgVKJTty U2kd6pq247VNWN27G85yK/0I5I9j+XYTl3JNx2BAM7utRSxkKFDdf0p4GDuY4HamGNEypY/N3Paj 2MSuZ9xrKRHw+aBj5VRefejDDCZyBTVUGPew5Bo5DSEiZSFJMn04qxGdoyDkd6rIqGPce3NSgJzs GC3rWXIac/mQXDSEnYQFzzmuW1JgkTNCu6Qjgn2rp7nb5flnh15rnrqFZgvlja3PPbgV83xGl7I9 7JX75+mv7Pnj+Pxx4N06OCZZZNPsoUutwYSLMp2Nnd1yR15z17ivbrmMBTg1+XH7O/jq48J/EKXT tQuIrOx1aBoi0jbF80MCmO2TgjnjBPIr9O7cyS2iTtznjPY4r+OeLMtdHEtrZ/8ADn7rlOJU6S8i FlIU+9YdzIF4HNbsxAXrzWDMhZGBGPevlj2TNmmAA96oyOcZp04IBzmqEnHXPFZTNBszbvl7mqrn aMDqaexyc9x0qLODk9qgzIyGbgUu7DY54qCWbB3DvUayjPz96hoqLLzMOppN6Y5HJqDIOFPQ96eD Gp46ioTs7l8vQiuV3LgdBWYBgkg9KvTtwd3U1nqqDKg9a+E4ttbU+qyLR6GlDlo85q/AGUjIrPhk Cr5fWr8bhhX4tVfvtH2qLgfaKUN37VXzzUv3e9SBHIpYEr0rBuVG45roJ2Cx+9YF5kplq1pgeT+K TsveRlSMV1PhTyxZQmA5Mh59qw/EMaSK27qlXPBEn7qSMdYjxX61wlW2R8nndPc9WiiAAyMkVoxr 68A1nw7+HBxmryMeM81+knxbZbCjscClwSRioow7cYqTDcAnHNJbjiTLGX+U8YrhvF8NyNLmeMcw DeK7+KNixwegrL1aHzrSdXG4upB9xWGPoqdJo0w1S1RM8MhuGlijbuRnIretZGbcp68Vx0aTWk8l s4wEY7fpWkl55eA3Br+fM8oKnXaR+lYKfPBNnSvkY9aqPKwc9gKSKbzlznkVDO2Q2DXlI6SUXmWC g1g6xbiWLrkE1Z3DGAOTWffTmKHAGcGt6EdTNnmfiG3hheEQDYxPzVWsbkmTZxsHBNbPiGzS7gFw nyspyK5eOPZtPR2P4V+t8K1fdSR8hnVHW56VpskdvBk/d7V2Wiysr+YnXr+Fee6bIJY0hQ5x1r1H RbeOJfMbvX6BCXQ+Xeh2ltdDIYDkiuutJdy57muasLZG2yY4OK6aGPYcjoa2JkXx0qUHAxRHH8vP el2EVoQSJleRU6Z71XTIU1OuSu6gDSh3ZArQjBzjNZkB6DNakQB6VoZlxen0p6jOBUa8cVYjHzZq ZAaNtb+Zx3FaN9Jp2jabNquot5draLvlc9FXOMmo7Id/WvzF/wCCgnxY8T6Oun+EtDnmsI0VpLox SFFmQDAVgPvAZ4B4HXk4ppgfe9x8bfg/ZP5d74psLVnBaMSTqpdBgFgD6E4r09EtrmBLm2kSaORQ 4KkH5W6HHuK/kOl8UXFvOkqSNG6uGbY3B5zjvivt/wDY5/bH8WfDnxxaeCvEJn1TQNXuEiL3ErSS QOxwhBPY5w3XAxgUzM/oFmgxyORVMritG0ubbU7Y3Vi++Eng9j9Pb0Peq0iYJoAr4J7UoVT1p3UY FOxgc1oA0qO1KBzimFlzxQGYsAorMCbaQMYqVDtwWqaKzu5iPLQAe/FXV0O4m/1rCMj05rQDM1m4 K6Le+WxQtC6gg46gjr71/ML8W/CfjrXvG99babpdze3dxNMUjWN5HYlyMYAJyOmO3Sv6rLLQbFY9 t0PNz1//AFGmW/hPwrYXUt7p2mQ29xPxJKqLvcDoCxGSB29KzBH8y3wv/YY/aY+IDDboA0CzWPzH ub7fHFsJGFUFS7P1JGOMcnpX6jfDT9jXxxoXw4HhabULdvPSSOWdBkbW4ICNtzn8ODX6hW0gt4/J XJUdieMemKnimhX+BaiavodFKpZ3Pxi8X/sjXfwQtF1X+04b9bpQgG5hIT1IxyDgDOc15mJ9rZXn Axiv2G+Ofhj/AISvwxBDDYrPLFJkMByq9TyOefSvz01P4KNDevc3oltYySVwMrx3xXz+Mwcua8T9 k4O4moxo+zq6NHgLS4Hv2FNW01Cc8w7VPcnn8q9f1Cw8M6Iq2Zt/tU6cs5QVweqfFjw3os3lWegS Ty9yxWJBj3+bP5V5/wBUn2PsnxVQjsmzlJtLvU5aF5V9UGa67TLC1RQr2uXx0K8n8OawZPj3OH8m 38P24l/h2uzfmOK9C+F+p+MvG3ijS7t9Lb7LFIxn2QnGAMAEn3Pvx6U1hX3Lp8VxbtyNL1M24tbh Ci29i8fvt4pdL8OeJvEBf+zbORjGQCSNo5OB1r9HfD3gEau6G58PrOd3O5MAAV61p/wkZEMKQw2U JJO1cYViOOBWtPLZz22NMTx1g8P8T19V+l3+B+Wel/Cfx/qOof2etpskCFxvOEIGM/NyB1r0Wy/Z 01S4iik1bUBE/Vki5A9jkdjX6bWvwvsIo4xLdMzpgnCgDI9PaukTwN4dVQHtt5AwckjPvgGuynkX 8zPnK/jBTi+WlD8L/nb8j809H/Z28OxNI1wZb1n+QqeAfy6V7n4c+B+h2sAjXw2k2z7rkBipznnH 1r7TttE0m0ULBaxrjnO0Zz65rSVEQYUYAr0qGT01ufL5p4s4ytaMLpetv/SbHzZY/CqRGHl6RBEr f3gOK7XTfhmtvHIjmOFJuHVVBBFew0V6FPA049D43GcW4irduW/m3+dzhLf4faLASSXY4xxgdPpX QWvh7SbQYit0OepIBNbdFbeyR4tbN8RPSUmV0tbeL/Vxqv0UVYowKKOVHnSrSl8TCiiitbEXCiii s7FBRRRWgWCiiiswCiiigAooooAKKKKACim7qN1BpYdRVczRg/MwFQTahb267mJIPp0oJ5Tm7/wN oupX7396HlZ+oJ4H0qxZ+CvDVgoENkpI7t8x/M1dfXIW+WBST78fpUst1JNapJCSDkA4qORHRHE1 FHkT0NGG1t7ZPLgjVB6AVLuXJwee9YsskgHlurlz0IpbG3vLeV3l+4/aqSsZXfU0nvLaP78gHOKr tqEKkKMknpiqraSkkhl8wruPTFTiwQAByZMd6YincatNE+xYQQO/Wn2uoyT4LIw59K00iiiHChR7 0yS4giZVkJBPTAoDkKl1FfySq9twuOQTVOPRp1kWQ3BTByVHNakF5HPK8CAgr696Z59w0cjoQNnt QJxLWwKvXdng5qQAgAAAAVAZtiRu3OevFZkZlkmlDo7KeV7UEGlNKkIDMOe2PemG5GfuNx+lAimm t1EmAynPNTPAJABJkkDBx3oAqyXRCq1uMlj3qNZrl3MUj+U3061cS3toyNijIqU+WG+cgN1564oM 2R/MV2nk4/OoPs028yRnZ22npQ9/bK23ncemeKmiufNDArh1HTrVoGOKB9qyDJWpDDEeqjJquzs8 JePhqy7hNSlkTb0x2qANhFt4tyrtX1qKa7gtgu8khzgYHFUBaXU6iGWNUHUtnJqd7CSWFIJZAVQ8 YFaATC+RiRgjHAqzGd2eR+FV4dPjQkuxc+/SrUcKx5CjaD6VmBMOBS0mBS1UQCiiiqAKKKKACiii gAr5e/ae1K6Xwa1jaZ+UrKxAJwQ3y9OlfT0jrGjSPwFGT+FfEvxS1w+JZNfiHMcVvIiAeqqcfyoA 1Ph9eDUvCGmXSkkNAnJGDkDB/UV1TcEj0ry/4Gyu/wAPdNjkYuYgUy3J4PHP0r1V/vGp5QKRB7U0 4xgVYYYPNRH3qTQpupPamCBTyRirRz0qWNQetBmQxWirG08mEjQZYnsBXxH8Tf20/CXhW31IeDLT +1ZNPd1kY/KoKNtOPXJ6V9f/ABNv59F+G2u6pYki4t7dnXgt0BzwOvFfyw63438R6V4l1S3sbnbD OzJNG37yM8nkZ7n160Gh+uvwv/4KM+F9b1qHRfiJYNpwu32i5hIeKIk4AcD5gMnk9B3r9JEay1Cz h1HT5VntrlQ8br0KkZBr+STS7O91bVoNL02PE2d27njvyewNf0pfsnX/AIgk+DHh+y8RytLLFGwj MvLBM/KM9xjpk8dOMVLlYD3maHqD2qpsU8HtWlOfmzVJtpbFUA+ONVHHNSdKhDr+VIZhnbRsBOGI PtRknBAzVbzecYpyuVPqKANSH5sA1wvx1tJdR+Dmv6fawtLIbeR8joNqk4b0B9eldgkuDkcVox3m UaKRQ6OCrKeQQeCDQB/Jv4k8O6vHqbwi3dvKXMgQ5BPfB+tdH4V+FuuanFDqkga0VXDIrAkvg8rg +vrX7m/Ef9kzwnqest4h8LeVp885ctblcxNk547gjp9Ppg4vhT9mT+xtYtrnU7xJbGD5mhVPm3Ag jk5BHYj0pNtdDZSR6L8CdDv/AA58NdKsNQj8qR4I38vAzHlR8pI7+tej6n/qQa1tkFnCtvAgWOMb QB6Diuc1Sf8AckUJmU0cvORlq8t+IXh4eKvB+t6FtH+lWk5jyobEqoSgGehJ4z2613V1csPlB5NU pB5ts8SnG5Sv5jBpk8p/PYbFtD1C5025DLLDKVO/Gfx6c101qf3OCPmA6+tbXxm8PweHfiVqFsY5 wkk8rb5RtUgn5dv689+MVztqwkRTzyK0INSM7UyeCelSKw2gMDu7ZqBQhBJyac7KzL5nLL6dqALO TuBJoYKVYA8d6agIbGfloDZ3bvwrMDkNVuZLe3kmQneCNvsR0Nfv5+yd4pg174QaLsnD3EMflyxl y7qy4BLE9j1A7DAr8ENZgFwoQAICeSenFfqL/wAE+PFdzePr/hpn8y3RUlRcEMTkDO7GMdeM54rQ aP1LKkHP96rS7VAHrVDDAbSMVKhJBBGKzLJXHJxxikzxkUh4QetID26UAK+NoFULgA8YrQIJ5qF4 iecUActcRfNgVkajb/IHHXFdPcxneTis2SIn79Zmh57LEGUknnOKljtiIuvNdBc2G59y4xTmsXEe /HFBqpHKtG4wp5Oc1S1e3Nzot7abdzSIRg1vSWkzEgZ2mpYrQH5GUsDxSlGLVhwxMoPmjufJuhyM Zntj/rEcr19DivQYN4IVuveuf8aaWdI8byGOMQo6K8eO5PBz75FbVvK0irk5Y9T61+T5vS5K8o+Z /QOSV/b4WFTujoocN8qGnGIvkEZAp8GGjAxhqstHgYz2rzD1TofBcvlan5TnasoxjtXXeKLBLiNA 6BvLz1715xpV0bPUYpVGSf0r6BGjRazYmdeT5e7PpxXs4aVzx8XTtI+Mtft4w0m5NqBjiuaFub3T 7nTQflkjZR9a9Z8U6KWWWFhyGOD9K8wtI/s9y24YKnrXU0ZUJ8s0z5qCSWsjRXX+tBII/HiorrZs wRu68V3PjvT0sdXW4I+a5Gc9hXCXEu3cpbJPesGj73DYhSgmfdP7ACmLWtduXOX4VlXPyjoMnpzX 6gXMak9K/Ij9jr4n+CPhzN4hm8a6rHpLX2wwNNlUfbnjPTPoOpr7Tvv2yvgvp8ptzqMly2dimFMm Rzn5FB7nHc19xk87UY/11P5449g5ZnVt/d/JH0wYvapFjAr4D1v/AIKI/Dyw3HSdCurqUOVELApI uDjJJG0j6c/zrzTXP+CjviKRzF4b8JRwgYO+5bJPttA/XP4V6ykfGukz9U47aRvuLuq2luCDkY29 favxX179uT46a4Yn02e00jYxb93Ap3A9A2/IOO3Feba3+058etauzNceKJLcMANtuqxrx3AUD8af MR7Bn7z6hdaXpdu13qFzFbwpjLO6gDPTqawrjxz4B0/ab3X7SIN6yL/jX86+s+LvGGtGU6pq9xOk xyyvI5BPHOCevFc1tvJnM11K8gA4z83FLmK9iz+hfUf2h/gppkdxJceKbT/RAd4jbzG+XqAqZJ/L jqeOa8Lv/wBvD4L2l69rAbm6RP8AlrDHlT7Ddtz+GR71+Kz2H2iTzWkkBPof6CpfsIRAuS+3+9Uy 1F7I/V7X/wDgoXYAzQ6NoDPCuNspm2sy57gDI9+9eXaz/wAFD/iTeqx0LSLW3jcbUDMxbpgk9PWv z/itgAC0efbtVsWcoxNHDhTWZ0U6EV0PpjXP20vj3rUYii1UacpPzeTGpbqOhINeYav8fPjJqM3n XXim/kR+GzMUzj2XAFearEFkVZTgscAVObUSM0JByOwGarmBU0GoeLfFWsXs1/ealPLM45Z5mJP4 1nPJqNxECZpQ56nzCSfzroIvC2qqiOLd3JOOF5rUfwprsqhY7SRSO5H9KOYfIjgTYys2ZmLE8Zbv +NWPsEaR/MOgxxj+dej23gLxPe2xEUe1lPUgdPpXU2Xwmu7q3jilndZyfvBMj8qhMIqx4rHYS+UG ORu9cZNSS28saAqoLHseK+lrf4KXksYUTeYRx8y7TW7afBFZ8R28JdU5djzimUfJkdndvlgjKRjO Af0roLTSrv7MCbdxJyR8pr7it/g1brDCyph1xzxj8a2V+EWnlN1xI4Zsg7TwKzA+Dv7C1mSFmNoz EH0ya1dJ8LarduVkg8lcfKX4r750/wCF3hyLCjezDoSa6W0+H/h60fcYd59W5oA+AF+H2tGPAQvg /wAAySPat1Pg1rU7RyurqgGQrDGB71+gVv4c0yLKtECAcjgAj6VofYLVXCIgx3PU0Gh8Q2nwTEvl yzWrSSL/AAluDXYaV8E7YBpns1Ep/hzwK+q5oEEgRBgjocYAq/bwR2ysT8zv3I4ouB82WnwW0542 32qRzqPlcdBXSaT8KLCzhCEq0wPzEjg17odhZmUAfpUic8sOD9KAOE0n4e6PbDzjEgbuAOta7+Dd DMuTaqQa6xdu4KDSMdnKnOevtQBQs9J0+zIRI8L/ALXNXbu1t5kEMiAr2wKdncdpAwKUoG79OnNA Geum2sPKDB9O1X4o4kXZtAz6dacMbenNGVxzQBKcKNq8ClWTH3TmoG+fgdKZjZ92szMtAk57UvQH PNV1LDr3qUcnFaAKCeM9qc7A49qb3xTwvGazNCMzEfKKAe/eneWKBxWgDuMe9ID+dKEOdxoKgfMK zMxjA8EUFi3yipDkimBSGoAjUP0AzTyoPykc1KGIzjgUYxzWhoMZAg+WlIBQHvTlIxzQB37UAG3i mgc04g0wZzQZiYGaXHOU6ilCgHNKFH8NBoIUkY/PzXBaMRJr9xAW5gPIrv5XKBn6YGa838K2jy63 e6nu3eYxBH0NZmZ6J8wO0dKeFIHPenZG3ikGVbnkYpoCIoUBfv2qUZc46YpB2zzTvkPWrAiIO7mh QoJFPwAAcUFU64oAjIx1pyDf1p2N/TtTsAdKzAiztYoDkUw5TODShTuJ9aeq8HPNOwDT0Vs09FU5 NJ8oAGMUrEKBtosA4kDp0qJlycCkDYye1CMSc9qsBxQBcGkTaOoxRvJBzSspOCKAGSPg4pFXbytK YCTk0xielS0AFiDjFKFC8jrTQpJ3HmlGW68VICHJTLHOaaBnPPSpCQBsxjFNjDDJPegdiIKoJzSs oRwB3pWbnGKTdlgBzQCRHkAnPJqRRxl6YV+fI4pC7NHjpQICzGTrxSgjbg0iqBye1IXw3AzmgBhG 9uDwKGXt0FPUA9aHOVyByKBJEcYAO7rUEpU8daczbeSelRF8/SgLDFDKCMdaZNMqqfWorq8jjXap y1ZImeRsueaBitGTJvx+dPyASe1RSMzyLupCVXcD1oAf5hzuWqMp85i5JwKk6YGeKicMIyVHFBFy IDYFABOaeybQWNSAbguD0601nYttxmgLkP8AdIGQKcVz83rUrDBABwR2pUU5w3egskiiYjgV4d8X fjFp/gXT/wCytHk+0a5cjhQCUhizguzAjDE8KBznn6+8XCFbVwDgtxn0r8g/iP4qvL/4havJPdGZ YppoQW5CpG5VQOuOBVRjcicrGprOtXerXy3uoXdxLcz5ZneRiSScknPc9z3rxzXPFASR7UEOYpCC pGM11tnOl+rrEd8ki/L659qSH4JfEzxhehvD2gT3SD7zkqikEHBDSFR2PQ1qkcrueD3eqXV5Jhl+ zLu/dqOp+tUnS5kDSTl3HqeVr7K0r9hz4u6pI6ape2mkxjBPmyq/XsPK3civbdG/Yq+DfgbSpdf+ KHiCS7itlYsBI1vGzbScAA7m6cAc1tGROp+XawmRsIBg/Kc9Rio5rV1dQY9yjofevVfifqfw+1Hx jdx/DK3kg0C3Iht/NBDPs/iOSWOf9rmvLdT1lLDMCnfPjK4xtGPWrEZ1x8iFy3lCPr9K7P4ffC3x v8VZnTwfp0s6xNtknIxGmRnLMflHHbOfY1rfAv4OeK/jv4st9LWRLLS4CZbq5k6BF6Ko43M3YA+v pX6+eEvDel+A/Cdl4S0FTFp9hvKjdyXc5ZmIxkk9/wAO1BUY3PzWtv2NfjHvElytsqP8rO0gAQep AGa7XR/2IJYL+NvFPiOCOBxiQ2kbPKM9dobiv0MNz5KmUsSG/wBo1zN9fwmUNICQM7QPXv0qPaFc nmfO3hz9lT4OeG8iWOfV5EbcJLpgrn6BcAfln1r6F0uLQvDdlDp/hLTLXQ4YzuK2kQjLsQAWdhyz HA5JJrntc8QJoy+ZIjGUjO0A8D14rnrbxvpTIHnnEbnuchf1rKWoWNX4iapKmkyWzuQ0ylT/AHsN 1FfnTrXh5bfVZ0Qny5DlVAxjHevsvx3400K4s9r3MKRg4WUuMFvTNfL2rTxXN5I8TqxI7MOnrUol o87Nvfxr81nJKE6NGM5/CsZ9USV9q9uzV7VZ65pvg/QpdWuT9r1An91brjJzkde2Op/+vXhHhc6B 4p1+zs/Fd02k2N7Opmu1AxbBj98+qr36VvTd0STSXHmlT92qjRvkyQERn24r0v4yeDfBXw8m0k+B PHNn4ytL5XecQFGmtgoGDIUdx82c7ThhjlcEE+Oi9trjgSb+/H3asDptMv7qyRksZMGQ5bdyCR6V 3+l/FbX9OH2edJb2AD5/mwAB6YryhJUk2pv2gjA7fpU8c8keFB74BY8fiaTQH0lH4rbWbaM2V0VV fulT69QayLy71WJVimuS4JLcjOPpXjlrqFzZMU06XyU2nI2/Ln1rq9K8TSzwRLqsnmIOHbGGGO4r H2Roj9Qv+Ccyvd/FLVb+5bMVtp6bnI4UyPgkn6gD8a/aS6urV/3KSBmWvxf/AGD/ABj8O9O1/V9H utRhtNRv4YTZCYBGlRN7Sqr5x8gwTntX6pxSCZRPZyCSNwCHRs7gehB54NeHiqD5mzW52DP85BYe 1MlnCrjPNclO86Rhy5PPrVKeeVvvE9K47A0dpFOg+dnAzV1b22VCGmUA+9eZKkk/yhzirkdoduD0 HrVktnVavHoetaXcaVqTie3mUghcbhkYyD2Ncb4M8P8Ah7wWxdTNdyZ+WWcBmC4xtUAYH4DNbltZ nn51UD1Iq4LSGT5hKsh/2CDj9a0Eo3NSfx7LGwWzh3hf79c9qHibxBqU4czGCPHCp0ps0en243NI FP61SfU9OgGSep6npRsKxM8Oo6rtiluG+rdKh8T+GoYPCOptNh5TbSAMBj+E+tSHxVoNogke6VWA xg8YP9a5vxP8Q/Dtz4fvdJv753S6hkjaO2ciYllIXaFw3XHTmsa2YUqPvVZJLzN6VCUn7up/Jv4x 8Va7Hruq239pzRtJcSL99iWCuRg89OOnauWsop9W1FBc35gkkXMcspbD+uOvJr9NPBv7BnjTxj4h vpdX0/8AsfT7uSSYXdztkYguSAADnJ+mOOfSv0H+GX7PPwC+AUi30ENvLrVnCN0lwwdtzr85SNic BzyB24rwM14/wVBWoXqSfZafP/gXPVo5ZOTtPT1PyF8A/se+PviYLebwy13qNvdSiB76P91ZwsFB O+Rhn5Qeg7Y78V75qX/BMnxl4f0ubVdZ+IOnafArEN56PhscA+ZvA59xX6L+IP2h47ZX03wlp6Wq Lys23AOO2wAD/wDXXy94q1Kbx9dtc+Jp5rkglgu8qEY+mKxyzHZvi5KpJqEd7Lf8TSvh8NTVlqz8 ovFvgBfDPipPDvhfVT4sjcgpLZrIwL+sajJyP85roNN+Fvxt1CyWPTtF1BbYk7FnuPIY567o5XUg H3GK/SLStG8P6DJ9q0PTYbK42svmpGvmEN1y2MnOBW5buJD5kj5fpz1r7WUbnmRdj83F/ZN+NF0q 6o0dnhjzFLcJvUDgAkZHb1p9p+zB8eW1K0stM062Q3Mip8l3AF688lgR+XPSv0yEpMbQbflavqj9 nv4YWd3Zf8JlrdrlhI6wrJyAigHcV9+cV8rxZxGsvwrmvieiXmdmGw7qT30M3wX4F0T9lL4B3OoR wPea7DbiWSWb5jLdS5KRFQQNsZOCFYZA9TX8/HxQ8c+IfiT4+1LxZ4suJprq5uJAyy7v3QDEiMKc 7VUnAXsOK/d744/EG28V+J00TT3Mml2rcZBCkqMZwfRs4PHGK+avFPw68FeNtLfR/Eulx3Fu0hdH T91LGzYyVkTDDOBnnB6EEV5vh5kEsNB4/GK9Weuu6T/Jvqa43EKXuR2R+Ttvd2io266ixIcAH735 9KrHTZriEo867N3ysuBX0/4//Y9n0dbzV/h9cy3lvAWl+w3BA/dKu44mJHzZyANvzDAznr8l6Xpm rSeK9K0G9jntje3UcLQSIUbEjBRlWGR1/Gv1D26ep5Dp6n7cfsvftUfCb4b/AAp0DwhfeEtQgkji xdXMHlmN5kBBkOWDsWPXj6V9j2X7Y37Pl+sUQOpQSMMMZLfCBu+Pmyfy9PWvJ/BX7GHwyg8F6Da3 ugy3EsVuommM80JL85Zwrjk9s8446AVcm/Y3+CZQ50e9hkyf3iXs+PwDOQa+frzg5XNL2PXz+0V8 CLja/wDwkvls45iktJdyn0OAakb43/A24b/kb7GIcD96rRjJ6dRxXgR/Yz+GLMRZ6xq9t7CeNgPb lCf1rnNS/YY8HzS+Za+ONXh3Nna6QuF5zxhVJrG8SuU+ph8Wvg3JGRF4z0fI45uE/LBNQ3njH4T6 3atZSeK9HkSReQbmNOv1Ir5Fvf2Fo5I2aD4g3ajdgA2q4IPrh6wb/wDYGu1QyxePDIuDt863zz7g NV6FH0fpkb2dr/Y2geNdBuLOEFUCSRu4jJ4BHmHpwOvNeieB9G03wppI0w6tbX5kZpnlaaPaXk5J VSeBmvz1vv2CfFskXm2vjmwjB677SRT9OHNcnqH7B3xL3lbfx5Yu6jjMc6rge5LEfhRoB+tYaF/9 VPDIvba6kfzqRLVm52Bh/snP8q/Go/sZ/H7RmMml+KbW9KcqsV9PCQQRgjcoqpJ8Af2w/D7+fpOr NIM7wyas+Q3oVfAP8qagnuwP2risjKMAdKW/dNP0u5vX2BbVCzbyFGPcnpX4qXmuft+eGPL05ZtX uwF3qbOKK9UdsZVGbPHSud1j9t79pHT9EvfDfiS0tJp44ntpmvLJ4rjJBVvNj3KAwB6bQM9qujhO aVkzKUj5x+Pl+niT45eJtUtUjFnJO5jMD+ZF945IfJBJPJx3NeWo4hciVSu32rl2keWMXJu280vl yOOSfbpWmmu3UcRiS6W4jbAIGG/M19NCFkkcrepoi5ngQvYu0UhOQy9AfU17d4E+OHi3wOlv/ZsC TCN8zpnbvx/dAHyg9xXz6b25k/d4Vk7f7NSpq95aSKEtYZlJGSepx2qrCP1h8B/tK6L45gitLy1e HU5eEBwFDd8tnH51s+IdfjdJPtMxOfuqMFPz6V+Sl14osLiNRc6bc26of+WUvHPU4FbVl8Xrjw/C kWnNexQr9xGbzIsH1Vjn8qwcAR+nulXIezUq2cHr61dhaPz9iggt1PUV8Y+H/wBoK/hs47iJoJhJ 1hYbW/DNei6N8fmu5yb6z+zxKRwMHFZnQqUpbH1lB5ZjMV0onhYEMjAFWB9QeD+NfN3xA+Atnq7S 3/gy8j8POFLNFEm2J9vQBUxt/AV2C/GXwtbxrM+6bjOxDyfwryvxL8dhr8cq6ZbnTViOAQ4Z2A7Y 4x71LlbY6aWBl1PMvAB8f+HdVf8AtD93FZHLwzc+aPb617B4t+JV3HZxT3Ny1tATiO3QgAN6n6V8 3az8Ubq6unkjzMSNhVupx059q8kk1zUtW1Bm1mR5Tuwqg/KgHQCs3QnV+LQ9CjmFHDL3Umz0vxr4 9F9dJaWtukjwgtukGQR7V4pealNezSSgLEjcFEOB+VXNQdYpBcpIC7DAAOcLXPTFN3nxgowOSex/ CuylRjTjyng4vFSr1PayFa4Nt91irovY/Lirn/CX6pbNFFdzKYYk5QoDyehqjaadfaheRWOmQS3V 9cHbFBEhkdz7BeT9AK+5PhJ+wB8RPGUun6h8TPJ8NaJ/r23Okt/MHHyqIk3BOcZ3kcdAc1pF2IPk iz8Z3iSfZbiWJEUht+zIUH1r0Ow8bK8iWSxmaRxwY22j649K/Zz4Y/sl/BH4W6Y1taaDDq+oSxpH Lf6lElzKxGclA4Kxgnqqj86k+JH7K/wj+IOnSxNpkekX6qPs93aAQ+Ww/vImFYHAByD61POTKNz8 lNI8ZXekTokSFTJ15yterWPxMtZHl0e/szNGwG9sZLfTJ9cV6d49/YL8dWYM/wAMr9dciUgmKWRY pRxzsLkKRntwR0AY9fjvxDb+Jvh34jk8N+KrT7Fe2Z2OjkCQEHgkc8HsQSD2NWmLY99fwD4N8T20 k2nAWkjfNtkxhfTNeceJPhj4tRlj0DO5WwJYGKFwP9oHI9q5+w8VW8x+0PNJG7jBCk4IB6GvUdJ8 aXc/kiKT5Y+CrDqvQVAj5Sla9i1wW/iCOeWWOUGcMT5vbO5mzzjHJ7V+037Ivxb+Dfh3whDod5rd romrXBeaWGUNEhkYABmkPybtgGefqM18WvP4e8RxSSXFvGJWGDtQbuP515J40+Fl1Mol8LNvtmGW R26H29PpU+xUjaNWx+2Gq/tWfs/6DP8AZtV8VK9wrNmOKCaX5QcBt6KVw3bnNeI+K/2/fghpcF22 hxX2q3EDBY1RFRZiT0G4gj3yP1xX4kXug67pTKdQgOzkSjczHC9sCjTzYXAUtEE57nj8ar6vHqTK o2fbnxf/AGzpfihFBYzeETZxWzf6+OfzGkBwduwooGMdc8+1MX9vDxZpGl2vhzQPC1h5djDCiXcu 6WV8L8yyRkhA3qVOM9Oua+RrTw/qNxHK1ouIlUkO3AYgZIGaxp7W2hlENx/rWGWGARx+FEMBTXQp 4ybVmz6j1D9tr4i6grwXGiWo84bVKoqqrHoeuce2a5+T9rH4lIgVrJImcbVeKMfu29QGLAn68V85 /u8s3l8D1qw8RxlG+9/D/jWzppbHNJ3PoKT9rD4k3TiC6htmRMZihiC7sd3J/pXL6l8dPEmuaq+o XtjHDGBtSNWIBx3rx/ckLr9ocosncDnP19K19Kn0tr0wyMJJQuVBwQB9aos9Y0/4p6eIpY9at1kZ csSCcY9xXm97baBrMv8AaNtata5ZmAVsBt3qK6K0m8NPcf2Xqm4b0JxsBBWtOHSfCDwvDoayIq/6 ze3Ax6UGZ5sthBE5cnBPGe1RzWEJeKXHzIeMCutvE0oWgkkmG7Py4PBrO8wRxuI2BYcgUAcrdbUd lAKB+M54zVrRrES3W11yQcZI4xWtDeaZcCNLiFW+b72MnNdDa2VrFC0tmxJz9wnJxXPM0gaVzf7Q LUIMHo4+7xXCXciOxlXPBx7mtk/bb/VbbSLGJpLi6baqr/M+wro5vgf8TbgiWGzEZfPClWAHrnNe ZUxCpvU9SlT5loeWvfKZcDlVHX3qzY3L3kssSspZRnbx+de6WH7Os8EsVx4i1dJVi+aWONfve2RX UReBPh3ot0xtYZDIR8ytISG/AiuSpmSeiNI4XufM3nGNA00QTB64yT+VRS6deahEf7Lt5bmX7yp9 1Sfqa+qf+JdaO62VpGnHykopI/OqcV60oZNka55Pyqp/MU1jmL6sj5+X4c+MpjClzAIUzywO7A/G tZfhfqkcxWeZDEPuvjOPwr1fUdcTT7Yuv7yQnGFPI/WuYn8SX8yKkMpA+mT+lP6zPuX7KByB+GcU GGnufPjY/Mo+Q49iO1Zuq+G9NjdrOwkEMJGCMlgPxPet691i685UMh9Mc5/E1gyOjGUkE46gA4B+ tdOHlN/Ec04LocYdMFhIYzceen8I6Hins9zawmUBhGegU8/jW20MLEOepHA61ehsLeUweZnK8lc4 BPvXWyYn/9fzoKBtfGBT96lsbce9LHuAXeffBp+9ZcMOexFf6G2P5V5iNmAjwAXweakxn73TFDBY ywTjPrR8zYQngd6LD5hrAvImw8KKc0bOMnhSaZwGBGcipjhgVLcGpaLjMh2FcqGGKeN/GenrQ6pt 2nt0oQHJAPy4rJo2hIkeVUVwVyFXI96wG2yMYW+VjyMelbyFSMLyc85rEuIgt6wALFehHavDzuje i2e3llW1RHLXyrY3CyMu5icI/Zfc/Sv1H+AfxAtfGHgeIKJTNZLFDIZDkO6jDODzgMQTz+Z5x+Y+ rwz3EJLH5RyRjmvZPgR4zHg/V7Wybfb2N/KqSHzPlUEEAlT6nAz1H0r+cuMcrVaOm6P2PIsRy77H 6aXHX6VlytgGrdrcteWgndgzDIJA9Ko3W0IWFfidb3ZOL6H2cHdXRhXTiNc/pWPJOZOvArQvG3If auXuZwhwODXO3cs0mfGCBWdK4bJziqjX4X5GOapG7QAnOKLAWZJvyFEcm8+uap+cskfPJpY54lHJ xipaKRpm52jbnkdKh893BC9R3NZ808J+YUz7UrbFHI9qzcbI0kzRlckAvyRVWORd5zzUfmINzHJw OlQwzpMwjAAP86+J4ngpU2fR5JK0jZhOWOK1Izt+Y9qx4DtbaK1EPyV+I1Ye/I+6pstrOhb0pXlP YiqoA+tIwFEBksjM2D6Vl3LBjitMgbetc/dPtJPStaZmcDr4Bdo0OMHJ96d4LlkS6nidsjGfp7VB rivIXYDDEED/ABrn/D17Np+tRQnlLohH9vev0ThetZpHhZxC8T6Itn3KM9K0kT5QRWXZpgFT07Vr RgqTmv1uk9D4GotWToX3gjtVmIbtwIqJVztKHr1rZtrYuwAHJpiIY4269DSXFmZUII6A/jmtxU09 GC3VzHCEOG3Ngj8Kpm7sJ/8Aj1uo50JZQyMCCVOCPw70pK6sTzWaZ89eIdP+y3uVGQ3euYmiY7T0 PBzXqfjqzjLI6AoQRxXm0oU4JHC8V+H8X4Llqylc/QMorc1NIdASmFB61fDDOwjNUYgBwBmrSjI4 O018bT0PWGGNM56Y6VDPDG6MCvJqyRlfVhVlFyMY5FbU52A4i7sXaCRFXGR0+leZLwzo/VTx7V7Z qNvK4Cx8A5JrxHV0ax1N4yvBIwK++4Wx1ppHh5vRvA19KuJra8iSJS3mnGK9bvdbsdC0a51G5beb eNpBGG2FiATtzzjOK8c0udlulduNpp3xW0+a/wDAs7RHBucpydvOOAfrmv1+mr2Z8S4XZ4l4j/by n07WLqy8K6NDb29swTFzJ5kzMnDk4G0At0HJxjPOa9K+En7evhzxFeaX4e8fQwaXcanK4iuFPG1j hMgDhcggE9hzX5JeMNBfTrhDey7bl5JQ8WMFQvIJPevJEkFpOZYZCshJ8vGTznPB7ZrolAwlvY/r e024t9Rsor+0lWeF+joQVI+o4qZkbJwOK+Cf2DfHk3iX4dxafMLnzbECJmmcOkhUcle6+gz0Fffz HjNVFktFQrhcZxUoOFC0zGetPXAOKoRMjMHyOlbFu+eCKyIlJOTWzAOnpTRmX1xkYq1GR3qBVz0q cYXrVgbVqcYxX5zft7fAq+8TaRY+NfCQka7iEkNxborytKGAbevOFVApzxnmv0QgfGOa1ZFtb+zk sL2ISwyqVZTgjn61CZCkfyLan8N/G1lcBZtMYqxITjbux3y3H9K634TfDfxpr3j7Q9OFusAW9i83 CmRYkJzud1yAAAa/oy8Z/szfDfxndxzzRva+X/Ch+Xj0B6Z9qseBv2dPAHw+1J9U0SDzbhhgtKAw HXkA9+asR7N4YsJ9J0mGxmcOYoo48gYU7FxkD361flzk1YyI0VV7AD8qrvyeaAI/0pCR60/AHeom K5wK0MyWzVZLkRsM5rtUs4oVGwAcelcRayiK4jd8DB4r0dIzMm9SDxnrWZoVIVKggjp0qYcHNTJA xIUEfnUjW5WqiBXDkZpnmtnOakMZHOKj8lumKGjMTziWqRZuahERDdKNrKelSaE11cj7OwYZAB/W vmzxTa+L9VuJdO0HSxes4JG7JCr36c9/wr6AuvMKEetWfALtaaxPby8eehx+HNQ6dzswuJdN3R8p Q/sj+J/EFukur6jDZi6TLhVyyeg6da2dH/YO8DLcRz+I9VuNRSP/AJZFVVCCMdgG47c/UV97hQKW ksLHqddTOar2Z86+Fv2Vfgf4TfztP8NwyScHdN85yOuDwQD3GcV7VpfhXw3ogZdI0y3tFbkiKJV/ kK6Cito04rZHnV8wrVPik/vEACjAGAKWiitEjj529woooqivaBRRRWhDYUUUUCsFFFFABRRRQAUU UVmFgooorQAooqN5EjGXOBQaElFU/t1t/e/SoZ9SS3QSOhwenvSaA0qKxrHWre/laCNWVlHOaNVu ri1SOWFSw6MB70cpXKapdVOGOKjkmjgUtK4VR3rklg1G8JLxOpByCeK6N7QXdssUvykD61BXsxBq Vs5/cv5nuOgoeecPtQq2RwRUEGjW9uCFZ+Rg81ZWNbdMD5FB71N2Hs2ULa9upSwuflCtgYFXI5JG fKqzKc9eKct/ZjK+aOOvFUpddhiyFhd1HRh0ouw9m+5ektlkyAMFx6dKqLprqPLkl8yPOcEVmjxI 1z+6tYCjjP3zV57uW8sBJbEiVcAjGOaaZpZF1NOs1KsYxuXoTUzJHEpIIRPXtXOy2d+D/pG+XcOC D0NTDT9SMYt3wY2I5zyKiw7GrDfWUqu8Uu8IOcVmy+JLHbsgYs2CMntUun6J9hd2aYuHzkY4qb+w 9KzvaEEnrWhk7lWw1Qsoe5f923t3p8t1dtK5tyZImGBgdDVxbbT7WIosaohPTGaUX9qGSONs5OOB jFAHPQ6XrBlEjysykZG5jkY9avppepTP5lxIoOe/NXb3VDZSeUU8wYzweax4teluFkiOI2U8EdaB 3RvW2nLbSGUuXc/yqwtuilmVeTXMrcTzgnMhIHBHrWnZJeQuu7JVxzmghsvSXkEKsWJBXtiklvVh tftSKXX06HmmTWJnZldsIeeOtWYrfZD5DHeo45FBJinWZXJKbVUevWoXuzPOgjnZS3UDpW0NLsgT iEc/Wp0tLePGyILj86DMpJ5jKpjibzFPc4zikks57p/PY+S+MY61qlckegp2MUByGWmmmQAXcnmg dOMVahtYrfd5eefXmrlFAuUjVMAin4pcUUDEwKMClooAKKKKACiiigAooooAKKilmigG6Zwg9WOP 51zuoeM/CmlA/wBoarbwkdjIM/pVpgdPRXj+p/HP4daaSg1D7Q+MgRqTn6E4ryu9/as8PlJBpOmv Iy/dMrFQT9MA0wPc/iZ4jHhvwrd3cbYndSsYHXJ46elfH2lw/a4Lp7gFzMjBvqwrE8QfFHxF8RNT jGoxpFbxf6uOMcL689Tn3ruPC1sCpjkGfWgDC+DNwsVlqOmqNotJWCqTjAIFeveYWNZKWljYlvsk SxbjlgoAyfU4pRMxPBwKBo1Sy+tMZh1zWcZjnFBlasyy8XUVIsyCsSS4waha7x3oJSOh1BbbVtOl 0q5A8qcFXHfafT61+J/7QX7EVzF4svtd0ZX+w3E+YxGN2yDsHJHVeOcjNfsSb7B45NUprtZQySqC p9eaiSKPxX+Gf7MBttelTRdIuba6kCgPfo0cW3PIDMPmyBzgHiv198H6BaeFNBsdFtV2JaxquAOA R1x7elbzypwcAlenHSqslwzHJpWsBdnuFNUPP681TkkYmq65JrQzNASE5+ammQlutVxznFB4+tBo Ww5Hel81snmq6570qgkmgCYTSZ61MLiTHWqu0ilGaCLFln3gBu1VbjHWpyuQMVDLERQI527X5jzX M6lGDwTXW3cZLcisie2Dt0zWZoebXloJCc8AdKoQ28m8KeBng16JcaUJFJCnOahj0roWXkVaA/If 9uLwPPpuuQeMbdXa3mCI3ykqkq/wg9PuYIHb8a+MtPm8xV2N6EfjX7Qftj+Botc+E97rk80kR0uS OXavC4wyHIxgjB798V+KGjzKGIfgR5H61omQ0dWC+7k7dvb1NCghiCMs3NMiQP8ANID7VInmbNnR s/pTESk7nVDwO9IzBtwRckcfSkO3KnPA6imEKC3XPt6VmBmXJbkNya+pv2MPGmoeFvjTYadaruTW oJrVgTtCt95GHTJ+XGPevl24jJj9wa6HwFeXel+K9M1K1nME9tcRssgOCvOCcn2qojR/S7aXQvYV mB4/r3qwNxOM1z3hd1k0Gxk373eJC5/2sc100a4Iz3olKxdgCYpBGepFacNu0x2qtXRYoAUZlDjt kZ/Ks5SsOxjhD2FPEfY1Ze60m1lFrdXsUL43YZgDj8643XPi98JPC1u11rPiO0hiQkFmbuOMADP/ ANapdVLcLG/LYFyStU30osPmrlJ/2ifgpbITNrAJUZICn/CvPrv9rX4QWkZmE0l42ceVErb8etL2 iNlTkexDSDlgRU39jHbhzw1fLmq/tweB7GNn0nQXugeB5k4UjHqMEg/UV5Brf7dHiB5JLfw9pMEi OAFaVypAI+bJQdjkDGCcA5GeM/ajUGffKaIMsirurWi0FUiUtEQfavyvvf2ufile2TR2tzCMYzH5 KdfqMNx9a4a+/aI+M+oLz4huLNc52RtsXv0wP5mj2po6Nz9FPjz4UWHR7fxXLiCGxZEdmIH3zgD1 5JrxLSXEiRuG3BgCPoa+F9Z+JHxF8WM1rrmtXN/Akgm8uaRigkUYB25xmvrr4fahM+lWyXb75WjU j246V8LxThl7RVl6H6vwJmH7l4eT21R6/GpGGB4q4G4xWfayAxbe4q6o6Yr5I+7kA/dyZHUV9B/D DW7acw6dfnKs2znuCOBmvApFyvyV0HhjVn0y8D52ncuOQD17E9K7sJUtUSOLFw91yPV/i54F/sqe WWCMpEw3Bz/tdh9K+Sb+yS0vpYichcDPXnHWv1S1zTbTx18Oo7uKASTGAFA56YHr3r84/GelrY6i 1t5fluOvHI/CvexFL7R42HqHgvxN0hJ/Dy38R2yQEDPqDXzugMvHevsXVbBLrRL2wnXzA8ZPuGHp Xx1fS/Z5XVBtAcj3GK4kj7LK60XT5epTniE1jG+3OGK7W7VjCwIIZ0DspyvbBru9F0ebxAsZtR8j 5bn1rrYfhtrt1dNbQpvKqHBTivsMr/hR+f5n41xqv9tqS7228kjxOW1dc+YrbfXrj8aLO0R5CQDn vXuh+EWqlcXhmzIeE4rrbH4QWu1DJBP+7HK//Xr0ec+OPnaKENuGNuOB3NSQ26NKMdRxjqa+rbL4 QxOyNBZZZjyC3zAfWu6i+D+mWoLizjdgM4P3gfrRzgfF3/COarcOqNbs2/0449q0ZfCWpbPJWAxg 4xuIGa+2dK+HljYzm5mjADgYVju2iupHhLQOHNpG+TyHUHHuKOcD4Cj+HniGVltlgEYzyxYEfhVx /hzqLSrDcBgvQMo4/Gvvyz8JafHP9oECoEPygLxXSQ6LZbSZ4065A2gUc5mfDNv8I5LuMPbhmKgD gbsfSuq0j4OXV2htHkktxGoYO8ZwfavsaK0hiJW3iSEL02jr9a0UCRwqucn60uc0Pki2+CUsM63M kKzkcAY6f7VdTb/CCNZvL+zLh+WIPBPrX0eDsJBIBPWpAUKgY6elLnYHkmnfDGytYhE+EAGAcAmt P/hXdrGpZX3Z7GvRjjNHmUrgcraeB9Pt0Vm259MVqRaJZwMqwxjd64rZEnAAzkUgkJI3EgirMysL ZIONoJ9xmrEKRRrhABnrgVK65681GI8VPMAu0luKRkZBnrUm0Y5pEK/dNHMAJmM59amBHryaQDJ4 7UpC9OmKOYBC75yaPmY7sc0bS3HUCrAJzwOlHMA0MSBlelOJk3D+7SZJPPAp/UYHQUcwAODnGakb JGBxSswyNtLtIAyetHMAq7gPU0+Pcc05RxT4yFJ7mqNBSpC0oz19KUEjk96eCDj0qOcCLEmCaf1A I6Gm7GLHnipAABt7ikZjQgXp1qwEXHqaiGWbBqRIymcmgBSq4yaRV5470/POBRlV60AGAuc80vyn pTeGPy8UcYPrQAoJ3Z7UpUBcr1pQegoZcYC0AM5Iwe1ByBwKfgnoelJ0zmgBpyRmlGGGOhow3XtT gAfmNADcc4PagA7cCnnCjI603G33oAbjseKQkgbRTjjqaDjGapMpMTcRgEdKX73K0gOQc0KCB6VQ kI/AAFOJwBScZApWXBFAirqAdtPnCnEmw4+mK4v4fDEF0S2QHYFvfNdpq0iwaTdTMeFjY4/CuR8B QFNOnm3ZSZ8iszQ7gjBGBQAxJz0NOfAOOwoOUX60GY0rheO1BXA9xTtrHHpQzfnQAwZbBPalY5wv SlwRzmkAz96gBNvJHpTDnGB1qcL2z1pGKjgckUANK4VaAGAJHOaack8jgU4AigBp5NNPUL2p67SD kUhUAZoGhNv8NPyo+VR0pEJH3+lDgAAigQMikYNMcHA2npTslTg0jMB160AQlnznPFLtJ5HNJuIO /qPSnNJsXzCMUAiAZGc5FOGeqml+/gr0NOyF+tADeScGmMzg4HAqQcnJ6VATl89qAHKMfNmnH7/y 8UhVD0NACjg9aC4oa2C2Ceai2ENnPSggFuaYSV4oHcldvlGcVXeWMEDoaZJgYHY0iiPv1FBDJQ5w arPc4GKSZ024BxWewJOQTiglIbLKz5IJ460nm7U+XuKVYjktng9aY42Alu1BVyix3Md3SmD0DdKl JWQEDio2UcHbyKhIzW46MknnrTpFHAYdKI13S7mwBUckik7d2assApIyeTUEkoC7Mc0pkdQ22q6o zEF8gnpQAq7zgdPWrGBnI7UiIccnDCnfKoPPNQ0AFN2XDDNSBQMMc5pQoVMtxmo3dsqAOKszJtSl YaTcwqCWkTA9emP61+GfiFkg8XazAMkxzyLuJyc7znOea/c9J5IphMj7CvfqBX5E/tMeBrzwf8UN S1+eKKKy1WQyKYM+Xk5IJzyGbqw6A5wcVpTM6mx5XpF6U1Kxhz8wckY7kDpX7CfBLxLp/iD4daXe 6aRuslMFwhwXDocHp29K/E9nlO0qdssZ3Kw7Gvqb9nz4x2XgfxbY280LQac8bRXMSsX3NKctIAT8 zFgD1456CtDlT1P1S1jWtL0XSbnXNVn8m3tEMkh2liqLyWIAJwBX47/tM/tPa98RvET+FvDVwlv4 c0yZhD9nQE3CYH72Rnzlsg7duAPzr0j9sb4/PrLwfD/wvM72e5DcSwttjkbarBNyn5x69uo5Ocfn hJanKyyPgenrVRNiP7YYYJSm7liQzfe3V6d+z98Cdd+PHiaRPNl0/wAO2GJLy9VN24c/u0LAqzk9 iMAcntniPBfgfWPib4mg8OabJ5NpvH2m6kVjFDH3ztGS2Pur3PGQMkfqJ8NpD8I9OtfDumLBJYpx O1vH5IYDjftH8R6nk5PfrWkpWMz07wppWm/D7TIdB0K2S2W1JJkChHkcjBkbbgbm7447Dipb/WJL jcqsYVPLH+8a1dTvIdZszeWGHjYDJ4G0e/pivhT4o/GHWtF1PUNC0GTybiGUxmchXDxsv/LNecHP f2pXND6P8U/F3T/A1uv9ryMpk3KkLLiR9vXYRwcd818q+If2mPEkV08+gRtHaycJuQO4P49K8f0v S77U7d5tZvZp7ZiXFvI5dizdSCeRnviuc1Kwt5J1tmkESJ0A/lnvSILXiD41eN9YvVnlu3FzH1Oc Aj3A61hRal8UtZnWQm5EczZztKgD29q27CXR9GBuLOGJ9r/LvUPJn1zjgVduPiBrvmEwxSB5TsT9 3uU+wIFZgZsfhPxrqNu9ve3TW8cjq5UMcFk6MR+NXD8PvEa2cs7X3mvs4Ct8/HXH5Ve/4SL4iXpT ydLn+Q4/fRsisfVcCqTW3xWmPnCxfJbIwcYPpg0BZnm015dxSvb+bKxiG3cxOCPoak+0yyoEAAQD GAcbh7iut1Xwp4zWwlv9U0prdc8liMk+wFcGtxDAJIp+MenH4VvETNTRvDmq+J9e0zw14d8tdR1i 5htIPOcRxebOwjTe7cKMkZNfQ3jj9iv9p/4ZaDJ4q1/wvDd6daqWkayuoZpFTGTJ5YYMVHsCfw5r 5ugv1tmWSJjtyBtyQ34Ecg+lexXvx3+NOr6Wmg6j4p1iXQdixpDNM8iBVwAoySccdM49qZHOcBbW XiH93MdImVfdD/hWjJ58Mmy4TY/92u01n4XftIaDoNp4puNC1M6Fq0Edxb3SSo8Rhk5Rm2sxjyOQ HAOO1cLd+C/i9qV2tze6Fqkz4BR1jaRMD/aUFcUGqg3sWI54d/3huPX2qR0dxw3H0qLTvAHxJ1GU R23hi9lZ8sSqHhR1OSAP1qpf6dq3hq+Ol+Iba4025X5vKuFKMw9uxFBEbnUaVr15orqYpiIsjIPO CfT0r7P+Ef7aHxF+G91BpuoXh1LS5Nh8m6PRRx8soy4467sjpgCvgOSTzbf+7vbd9KvWaoXEkhzs XbUzppqzRakz+iP4d/tp/Dfx/Nb6Rqrx6RqMn/LMkmPnoFkOAS3YdT7V75deN9KMReJHIK5U8HI/ AkfrX8usV0ltfQ3DMzPblZY5AOUZTkEY9MV9AfDv9pD4j+CWkshqklzp0xOIZ8NBHuOSy5OVJPOB j9a8yvgLv3C1M/d2f4l29qQMlN44PeqF38XDbbUFwSzfdGP8ivyOg/aIvPFEQXUr+WBNxBEQHlr7 7uvPpWt4kj13xL4ZktNG8Qz2/mukjMshAZFz8rEHJUZzjpnHpXHLDyi7MpM/TvUvjONPgN9NdQxx htrPO4ADYOAMHrXjfiT9rPwZpdnNc33iqxeaP7sULMGc5+6D0z9TX4u+LvBXxY0wTS6lHdSWdk3m 7onLBQTjzAckgH3xWV4C+A3xh+LGpQWfgfRLi/guX/18rFYk2nlnkbooPBI71lXdOnHmqTSXmaQi 27JH6wav+3R8O7K/lsBqMmotHGjg2wYqSwzt3NjBB46V55Y/tr+O/GPiRdD+HPheS+eVdgjw1zNv 5+YhMADp3H1qz8Ov+CeXhjQNKW/+Out7brcWkt7KdY444FydxkXnJ+vGOnNfTDfFX4T/AAl0tdF+ FWkIiqDFGlrCIVO3jezYy2epJzuPOec18HmfEc5y9lgYOb79P682erTwMI/EzD8JfCH9ozxtB/a3 xY8UHRrN3EptVUF8D18vakWB0BJA7iut1f4z/AL4I2wl8Pyr4n1A7hJFDdLdSRFQMksxwGY9uBx1 Hf4G/aL+JH7SnxG0W6uE1h4dGso3kay00m3Lxn7wkCkNMQvJUkjuq5xXwZBfeINMutlzJPYyEKWj k3KTkdeeea4MDwTisXL2mYz5U+i1f+X59ToeNhSTjBan6K+Mv26PiJ44muLDwyI/CFlHJlEgffdk DqHkbjr/AHQPTJFfP+rfE/xLZOPELzTakk7s1z5zsVfPLBjnofT8q8o8I+H9E8V3/wBmF6mn3k2Q jTHIdvRVyMn2zzVjXvC3inR4jY3MbzpG7KGTlHA747fQ19/g+G8Fh0lSpo8ytiZyd2z7F8AfGbwZ 4r02G1u9T8jWVBLwzx+WoTqCJANmB05O49SOa9nazkEMc5GBKoccg5B5BGOxr8nLjTLqIr5ETqQB uK8V7b4D+P8Af+CLZNI1qwkuoUJPmb/m56gdsV7MMMlsc3t+590yRlBz3qvvHauU0L4keDvGIX+y r1Y5nICwuRliRk4Oe3f3r0fw1ol74h12LQtLtjcTyjc2wbmCjqcd8Z7c1jiasKMJVKrskrv0RrSi 5uyPS/hL4CvfG2pWZmTdp4mAuVBIYRjk4YYIz2Ir6T+Pnje18IeF4/Buj3Ihu7gbXhQgOIQBwQP7 +evfn1rsrS28JfAj4emfcyXcyHyRLkySS9+PRc5x2Ffn34o8S6h4w8R3Wt6nIZZLjLZPb0Uew7V+ QZfhpZ1mLxM/4MHouj8tb77vysj26lVUYckd3uZlqWIDyc5H41rxsTESAOtZ0ajAXFXQMKVXpiv1 48c0pbtQCDgxsvNc54N+E/hLxn8YfDN+baFb20uo7iWScb18uLnGzuxP3fQ4PapLhwUCLx619Dfs p+G01Dx/e+IZ1DC2gMKg88uRhgP+AkfQ1FSo0tAsfpvp+j6etjGBGVCgKBk9AKqXnhrTJkO5Bg/3 smujKiO3AT7tZkk+0bTXmz3IaOMufBdjLtETeXt64GAaxbvwVGFOME9jXo3nI5xj7tOEjEnGAKgR 4jc+Fb8ITErqF+leTeIdYjXUxpejsdQurZ3ilSD5v3inBHpkHjFfZWbcjE6gj+LgV82ah8L/ABD4 X8QXetfD24gvLfUWLyW15kbJM5LbxknP4Y9emHcD5j8ReH/jZr1w8OkW0Wj28gBZ5nYytz0UqrAc fTr1PQem6FoXiGy0a2tNYfzryNAsjrkqW/4FzXskWnfEqc5vIbK0xjciM0mPpwP61oWGgavFLJLq 00UiOMAKDkH8aLgeB3Wk6lHNuCFvpVaW0vwhV42A/HFfR66NbCTKjr64qC68M2sg+7uJ9Ku4Hzhb LcRSfeKOnIyTxivzo/bdtfib46j0jwr4a0/+1LOM/aLtbdIxMZwWEbszfMQAei9e4r9etf8AB50z Spr63G9iCMEdMg49a/MLx9ei88V6lNFcmV45DGxU/KAvYEelb4OfLNMUoNrRH423nw++KulhXvfD N/EoO0gQu7/Uoozj3rHNrf2DmO6tmQ7dyluh7nIHpX6924t2lDJIZHHYnIFM1Xw7o0+ng/YYJjuy UaNSDu619D9ciYLCTPyGtNTgWdppmAbGDkkD/wAeqxFfF8+Rnp+72fzr9LNQ+Gnwv1TcNd8M2rFx guq7G49CpBGPavLPGHwT+CLrBe6AJ9NvYpAZY43MkUkQBGxdzfu2Jwd3PQjGSTW0MXC2pv8A2dW7 HxjazS/ZgryZds/eHJr0XwFJa/8ACRImptEIPJaPbIB8zdsZqvrXgDTLS9lvLKSQQyt+7VmJGB6V j6j4WQwWxhuCrn81b6mk3fYn2LhufRaeHPDGp2/7ywglRwRvUjC/jVHS/Dvh3RpZUhu1nKdUdsgZ 6V5XpH2zRIwLWV1lnG2TdkqwHXC9qi1C8kt9Pub05km3E/3Qx7YrL2HmdNLGRj0PRdY8SWlo8VvY qhmkYjpnGO9Y89jb/Yp7llJlRGkIYhTk15fda6To8aQQiLUdww/dB6Z71iavqeo6nOkl7KZGULtC kqBjtiqpUTPE45z2Ijc3lyqkZiwckZ5pgjlX97BJ1B3An+dMC58wsep7deacWiiXhA34+nrXUeby CQwKZBvGCR8x9alNrHdYRpMIGwy47Vni/eSaIRklG4AA6VanZmLInytnczjsKBHpeh63H4NeA+HA ovCcrI3LJ7hjkiveND/at+K/h5hLaa3dPOoUeXIwmj+UfeG7PJr5BDmKcLKd2/nGOh9faui0XRtT 1u6+x6ZCWkIygYEBiemPrUyjcaZ9np+3f8VIrlGn1VHmBy0UlsrLk+wroV/4KAfFW3guIo00+5mU fu82mEDHs/z9K+ZNE+Avi+5DS61GLRQP3gdcOvsCTXe+HfgpotnxqN80gZv9Wvr/ALTdakDD+IH7 W37UHjmS32ay2lRwZiZNNQ2yymTgAhTuJ7D3PrivErH4deP9Qvy0thc3V7cSFpZp5WkfeeTvLZPJ PUnqea+x7vSdA8H30Fqkaxt/yxzgszf3lp/ijxLa6PpX+jOEvdRU8KcnHrxQB8QR6ZrGliSx1OGW GQOd6k42H3IrdstUvLDypluZfJQj5QTjJ9K7ibVVnvG+0qJZHUB93O7HX8arX17oE7ol0nl7BgDG MgegoA2tB8W21jLG80kyEZIb+Ak+tes+GfFj3UTC4mWRck4U4NfLl/ewJOGt4ikL/dyfT2qrBcxl Fls5WimVuu4jr7VpED7s0rWPCHiRWsLmNLYxja2UH55/xrzPxN8CLKF5rzStRQRXJ3xoOQAf72K8 O03xjfadfx3m9TLt2SIQSkgPcj1r0S18c4K3QuduOsJOB+HpQBxNwnijwr52jTx+bbxHh0B2EEcn I5rgPOkucTGTIByo9s9K+stG1/S/EWkC5k4juM5BwM7euDXFat8MNHu9lxpErQl3LMpYH5u2McVo B4nFpWpahHL/AGfDLMvG4rzishbDUNNuB9sSWHbkMpOa9JvtG8V+Fb6RbO4aCKVfmAX7wriLq4ku 5ma4cucEMGHRqAMthBJI6qGbaOjd896zULpG0G4jeCSFHOB2HvXY6db4KmbEkbfKCo5rr7TR9BFz HdRwN9pQhoyTwHHr7GswPCri8hNr5j3LosQIBZ2V8Z5BBOSKfpupPud1uHkMi4YbiML/AA9xxX2R eSeEtVXN9p9pPKuArNEu9T3OemK888S+F/BM8pDWS+a64eVHwf8AZHoBWnOB4N510QsNxMqoDkdx jtWhJf31xbiR5cEPtXnGa7K98CWiwn7Pcq4B+WMnJWuSv9Ia2VfsmHSEck8DPepbKaJ0uowkfmja y/eGe9a2m6jDYSRvDLiSTduHWuJlgkZ8PHyRknPSi3lNmTKJc8YIAzj86Spkn0t8NvEWlWetwarq bRxNDIvz56c4/Lmvu7T5ReLvgfKuNwK9DX5ReFLS/vdVX7OjvdXDReTB7A8/ia/W/wAO2/2fRLRS mxtg3g9Q+OQfxr4/N2lUPdwPwD7rTdOurRrd0wCD82BnPc14F4n8Galaan52iBrmGQDOSAQe+K+k vJVAHUbl4zyOnet+30iO8jDfZQ4AyCOoHevPps72rnwXdXFyrywSDDR5BX+IGuck8xNxSTGa9l+K V/8ACyzvdSVdUtnvrVVMjQMGGT/DuU7Sw7qDkV83an420mxthcWskc3I/wBog9sivVo0JPZHn1Kk Y7kl0HIzj7h6E9fes55oUjD+YEQt1x3rzq98ZanfSMCyhAfkKjHHvVCTU95ElxI2R2H3frXoRwr6 nH7dHd32p20LRyblkaQ7R/jWfJrNusDCGYO7HBAHT1rzW91OW4Qw2zKp46HJGPSstL+/tTKZQpyP lXHf1rujRa6mLqI9AluDEuVU7ACR9a5pb26a5N15rAD1Py/lXP8A9t3VijyXDbyQCMjOM1lXOqys haV1XzBt98npiteVGMqp/9Dztfn+9kkU4fKQUHHenRjaDleG60p2g5UV/olyn8pjBnJ3ZYCpdoJA BwBTFClTgcetSfIFDAZPejlAYwHJBye1NYkKA3zMOuKc0Y3BgDtNHlENmP5s1EkUiDDndtbg9KRG cERnlqlI3fuwBu9aMAFWUfMOKxaNoBlk3FeCOKqTxiKYy7u3zelXixZWDLjNU3IOUdcAdSeleVms P3DPTy6f7xFOZd8eOCp5z/SstLdYru0u2+aS3kEir2JXkVssqhGiX7rcD6VRuYfLMbR8kcY9K/Cc 3hzTcT9Xy6paCPvv4M/ES917SWOsqN0v3XDDJbPzAoAAoAwBzk/z9suZxJlVOVFfmb8MvGN34b8b LB8hs7hCsqS5xluhQ5G1gR154JHevsyDxrLIieWNuzORnOR25r8O4iwao1Hoff5bXVSKsehXsyx7 tx4xXCalqVsiYDZkJ6Vial4kvLvEafKrd652R2fLyn8a+VnioR6nrewk+hr3errbgNkZI71iPqVy 7hpSCp9KqT288nzD5lxUSWV0cMgLe1c7zOmafVGao1eaPlT0qxFrcaqzOucc1nw6JdSsHkYpntjp VseGriEFpJRLn9K5pZt0ijaODYDVJGYNgsX6ewpV1OeKXESgj37U9NNkX5UUkj9KU6TcyEuVIxXH UzKdjoWEMyfXNTh3uMFeeKztH1vUrnUIjjBDcD2rpl8PvIFDHGetFp4fW1nLkfMDwfavm8yxTnFp nq4KlyyO5hk+YMT1rZixt+Y4zXNQrjYr10VuoGc/MK/JMfDlqM+woMsrgKRSjGOajfluKcDuwK54 G0yGWQEHBxXOXwLxkKa6GdQ4zjFc7qEhjQhBWsDM4/UmMcRZhwv9a46xfdrkLrgZYDJrubxvMiKg fe4wfXFeKXeqzafqKToQ7JKMj23V9pw1P94jycxjeB9f6ZJJJbxl/vd63o18zqelc7oEedOhk3bt +TmuiwVX0BxX7Th5Xij8+qxtJl+3KllXbisL4geNbT4eeFrrxTqKu0UAwgjXcdxzgn2z1robRVLA 9e1cX8ZfCNz4z+GmqaFbSCKXCOGILfIrAsAACSSBgcda1kZH4afE/wDaA8c+KL681p9XurS5u5D+ 4SUhVTPGMccjqMcdu1cd4N/aW+KHgLxFpup6brjTR2c5kkhuP3kZDjEhwc4ZlON3UfhXGfFbwZqX hW/kSe6ha5juJovJbIkQI2Pm4xxnnHSvHIvtcbo7LudSDnb8v606dnuYtH9Efwt+NujfHLwFFrsc kMWr2jGK9tY2J2PnKsmQCUZSOcdcjtWtczRIQifN/jX5qfsHW+pL4y1NVtnKSW7SAtwAnQ4yR3I7 V+jeowS6dctA/IcbgT71+Yca4JNOSPrsjr/ZZoQuDjtV3JwOM1z1rMcFc8itJJsqHB4FflaVj6w0 eRyKsQsTjJ6VQWUngLgVbRSxABxT5QLFzARG0sfpnmvGfGUO/ZexrhVOGr2t4xLbGEZOODXkXjUF ALdRlEr3MixPJVRyYyF6TON0zcZhJnIHT3r0o2VtrumtZ6iQ0JI4PY+tefaKy+Y8bMBxx/jXoGly ohVJfu54zX7pl2J54I+BxFPlkz43+Kn7P0t2LmaHT3vVut4SVV3Mno2B/XqOM183aV+y/wCLIXhh 021lKTOIyk6jdz3Hpn9K/aLTJbVpFgwCOvIrsI9O0+ZlnaFWcdyK9XmZxuKe55T+zh8IbP4QeGYd EsW3u6LLcMTuPnMPnAYAZGfb86+n1k+XB5rGskiWFQq7cVqbsgbRWkdjKSHhyW4qbr2qBTg9KkRm 6VRJaQqF461sQOCoXoaxkUH61qW5K4HWmjM1o+OlTjnFQp645qyozz3qyZEysBirkbkdTVRVz161 Ntx1oJJiR1FG89qi5HSkye1AFhicUwHjmgdKO2K0ACOKZTz0plAEJUHrSBZuiSsv0Yj+RqeiiwD4 nmi5EjZ9dxqT+0NQVsrO3HvUFHFSmBpDWtUPAn/Sj+3dWXrKD+FZmMUn/ARVAb8Wt3r/AOsKn8K8 48RfFjxB4f16w0ebSUjTUH8uOVnwGJ6YbkDHU57V2Ma15/8AGPQU17wBewlN81p++jOcMpAxuUju ATj3qZ7XKgrySPoeGCSa2S4nChtoLYIKj8f5VA5ttMcanlP3Qzy4Ffi1F8UfiJpi/wBlW/iC7EFv +7EbyEqQvTKngH371lX/AMUvHFy+y41S4O3/AKaEV81HPWnrE/W6PhNiKkVJVl9zP6DLa4juoEni IZHAII5BBqeviX9kP46Dxx4bXwbrilNS0rMaSMwYzBecYA6gEHPTHpX21X0GHxUa0VOB+ZZrldbB YieGxCtKP9Jr1QUUUV1nlhRRRQZhRRRQAUUUVoAUUUUAFFFFABRRRQAUUUVmaFS8nNvGHAzzz7VV VjcEhJmwy54FahVWGGAI96gMSIQEATPoKBpGHPDcBVALPg8nNRiy1AyGWFsAkHBramnS3UGU4Gfz rPOrkKzRxghM5ycUGvKTPYGVSk0mVzngYoj0uBWxIzSKOgboK42+8XXqPm3UbAemOcV1x1BgkU+x nSVATjnBoHyl4RWVsSwCoTx+VPmuILdN0zYXGa4ePTr+cSr5DjcxKsT+Vbcmhz3thFb3k5DrQEYs ml8Q2xUtbKZMd+1V5L/UpP8Aj3dCHHy8d6S28J2FuMh3JIIODwa1oLawsEWFSAV5561macrOLtfE mqqzGdDJs+9hMVsW1zq91KLsQ+ZA38LcEVcn8S6LaxmRmOM4OE702LxRp1wrG2DuVGcYxV3QcvmW ZLMzs2cQhxjGM81Xh0B1ASW4MkeeVximrrLXsbPB+7CjkHrWddXV0Ikl067ad24K46UXQuU6WPSL CEgiPJHQk1LJPZ2SiN2EXoB615repr2qRpbW8Esb/wAe44Aoh8LeJQVZ5QNpB+Zs9KzTRTgj0mG6 gnZhGx3IOQe9Ytz4ia23kxbgpxnmr1vp0oZJZ2BfHOBV9rK2dShjBVuvbmtLmMpHI3HiW7nkjOnx naPvDGc1csdQ1Oe+ZniZrdgByMba6iGCGHPlIF+gxU9Mm5gPBqJLKqLtzwSaRdLnly1w4DZ6AVvb R09KXGOelBmUvsduSrSLvZV25PpSw2NpCNscQA/OrtFADBGqjA4ApdvvTqKAGBacBjilooMwoooo AKKKKACiiigAorO1DV9M0qE3GpXUVtGP4pHCj9a851X43/DDSM/atet2K9kYMaAPV6K+QPEX7Zfw 20eRoLOC4vmHAZBgZ9+uK8R1/wDbi8QTP5fhrQ4YU6CSViSfwoA/S2qd1f2Vipe8njgUDJLsF/nX 5F6t+1F8X9dieE6n9kVjnECKnHpnGa8vv/GnjLWpDLqWpSXL9RvZiAT3wDigD9idV+LXw+0ZSb7W IVIGdoJJ/SvKtd/ao+H2nAjTo59QYf3RsU/ic/yr8wI5Lm+bN5h27tzk46dTWg3yd+lAH3Dq/wC1 zdyxGPQ9Kjgkxw0zFv0FeVar+0x8RNTDILtbXPaJQBXzh50ituJC8Yznmo8Zk+XcWx2FaAen6n8S fGGsMZb7U5nLdg3FcpcahqF8pS6cyg/3jk1lRWOoSIWt7eR/fbXRWPhLxRebBHaMA/cCgDMXzlGz zCF56HOKZH5glUKcjI6f1r0qz+Enii5kG9gi4zgDn8a7nSPgfdLMj3Vw2OCcL1oAyPCWnhHQE4zj 8K+hPD8JRRgDPT61b0b4XJborpGzOOdx4B/CvR7Dwl9mP+qAB9OelZgee60j2wicjAc81z5uWz16 V6D47082mnK3lkENxXloyRz7UAaS3L+tO+1MT1qkoAHWm5HrQUmWXlJOTVZ3z0OKbu9KhYE1mUIW cc5qFnY5NTbeKgYEc1oBFuOKiY84qZeajxzUyAqyD05xTEDkZ281bMJzwDUkcLFuelSBXTNTbMCr IgGeBVlbfgZFaAZwVs1KikkgCtFLQk5xVyOyPYUAZQhJHSkEJz0rdWzYcEVYSy9RWZpY55UwaPK3 jkGunGnOADtq0ums3ASi5mcTJZhhyuapNpoz0ru5La3icxSyxowGcFh/kVwut+OfBWhXAtb/AFiz jlP8LTop/U/pQBWaxINPSzA5FefeJPj38IPDOy41bXovImLpHJCfNQyRY8xMpn5lyMivJNd/bI+D Wl2N3Lpt3Nf3af6iJIXAl/4FtIX8aAse5fEHQLDxD4I1rSLy2F1FdWzxeWf4mYcD86/mv8W6Td+H /GGr6PPam1jt52UI5G4YOMcemK/YbUP22/D8pddM0W4uPNXhZXEa7ifukDJ4PfNfk78aL8638Qr/ AF0QLp8V/IXW3VjJ5XsGOMnv/QVrBkyOXtpzcR4TI21cVzHEVXJcnkmsey4CsmQR2rVJD7ZE5IPJ qySU8gs3egAD95ySeKFbI+UZyaMKr7TkhueO1ADZE5DA9B0NZVvBcx38cqO2xW+cA4IrVky/CHA/ WqBQAM6nDeuazGj9SPhp+11a+FvBWk+HrfS7q6vNItkt3eZx5cgGcNnkj0A5rU1H9t7xlBM503TY YwRgI/IXPvjk18EeC0S5sAYwWlP3j6eg5rrfsahMSJ83qBUSVzpR9TL+278U3Y+SsI2jHyRDvxnk /wBK8t1H46fFHVLyS/k1b9/NzvPDqCTxn2+leU29qzP5MaYX1reg0YEMGRgVGRkYzWRSQt/408ba pcfbNR1u5kuAuzf5rD5D/CPasMSXs8m2SRph/eZiw57DNa50e4aPf5bMGPQAniumtNAuZoQttAcA Z2kYP61mbpHEw2MkfLLvUn7pNTm0YsSB5R7EcV3f/CI6kSgl2ID1UnJFXrfwPdXIKzruQdNuc0DP M/sKkPnv+tOXT4wu2Pktj6V65H8NZ5cxq8gbovHaussvhf8AZYAzI8rJ1OcDNZgeGW+ngKPlB3cD A9KsQ6XM8oTGdvIxX0hpvwwkYvG8Wxjypb3rqIPhVEpDyohZeCwag0sfKTadcbhGkBDgngjg/jXt Hwq1m+hvZtK1AMZkXK7h/COOK9wi8F6SIksmjHYbgPmH41k+K/Dn9g/ZNascGJW8tsjDDvXhZ1R9 pS9D6fh/EeyrJ3PQrGUMoB4z/Wt2NNq+tcJol41zCpf7wFdtbSKY8HqK/PUrOx+wQleKZPIMAYqk VV7jn+GrrM+QF6VHNjO49TVw91jep9s/s4+KF1HTbzw86lkgUNFg7gB/EMdq8j/aE8DS6Xq/9qoA IbluHx/Eeo/XArgPhb4guPD3i1Lu3u/sqlVDru2iT5h+Z56f/rr7y+Ifh6Dx94BeWzRZZkUTRnAz wpyBnivrqDVWjY+Sxf7mvbofkxIM3UkW44HHH65r478f6TeWfim50+FNkU5BQnjOf/r19ta/p502 7dACCGySeMn/APXWPpXhnQNf1iC+1W0FzLakEZ7Yrmw1L3uVnof2l7CHtEaXwq8NW9h4Jso9RskW 6WNQzBcblHTIwPmx1r0mO0srcFreIIW4OKuTSqSI4xsjHAAqD7lfV4aHJE/Jsfi5VpuU3q9Q8pJB ukRTjvipG2gDgY9akQMw2849amSPAAY8V0HmkiAYVxVoMDg55qABFAweKA2DQHIWvLV856mo/szI xJPFSxMobHepm+bmtCWyZH2xgUjSHqeoqDaSwPYVNwSBWZJJGRg+poALZ56U6GE8sx4FBjBJKnrQ AwFmPuKsRll5oRMcVYEefwoAYeTuxTMFX61b2dADULqeflximgAEqelP2hhkVWUuvWniYL1qzQtZ zwe1P2lh2FRqw+/3NOAJPzHArMzGgSAYwDigbVYDbyaeBg8fdpy7ACKAJMEDKjrSmPj3NMUkDPan jmgAXgEZxTlVxyelNKL69KcN2OD0oAeqqfoKfjjgVGCwAJqdCDxmgAwBjAqbcGGGHSmcZ5OalVFY gCgBuMdKcFUc96fs2kmo/LYnOetADmcEbQKfHnABFNSFuS1PKkAc0Gg/GepximqO5ppBYjPFShG2 7qDMBHk46CpSO2elRksTnPAoABHXpQA4tj60bVfG7inYC4IoIXvzmgBTtHHWoieflqZFBzThGBkC gCJVYgE8UoJHXmpSe3pUe2gBS69MUo+bim4J7VIvHFZgKQBw1MKntTieOeaUccmtAGEZXA60KeM0 7GDn1pMcelACYJzUYG/5emKlxgdc0m3bz3oHYbtCjFOwMCjHrzQc4NUmCQ0gAAinhelNJG3FSLyO KoRjeIpB/Yt5GeAYnX8cVg/DtGTw1GsvXn+dbviSMto8ka8u2fyxUXhKBLfSI0i+ZeTWZobZ5bHa jaw4pzKo6dqRiAAaDMeTxz1oCY59aZgbhupxwfbFAEZ27iSelGQTntQVBT3pNhXk9KAIjGXyc4xT o0ycelPBx070vqDxQA085GcUAMDgnpSc5GOlSMeKAGtjHXmo0RjyxqQsmBkUBw2RQNAdoHNQlGzn dx2p5+U9OtMyd3XigQp3DGTTGychhSttJ25qNvlIWgBhLDvT/vACo2PY9aex2j5eTQWkSucAEHpT MKMuTkmoiWYY6GkYFcE9aAsDOxBUcVFjHBNNZ+DnrUathcHqaAsWAVHfGKjG5j83SmEr3604ynG3 HSgY5mO8Be1RHHfOaUHCse1R8gb8gVFzO412LAbugqt0diehp80qcAHrVYy71I6Y70XBFUuXkKU9 nwMg9KaVb74PNIFBOM81YWDzdg5JyaZKGcAMfrUyqpYlu1RsDnPagTZEqKq46Gq0qkPx1qd+Ohz6 VBvIIDDJNBKGMuAC3IqLCnPHTpViT5Y8AcE1Vk8x3BBCgVDZYrbiQMHBp+cMFXnFHKkDdu9aUMOR jBNCYAyfgaUDJBI6d6TDbsdqcudvtVgNc5+U/hTRvA3E9KsJDvU89KgldMhQM4PNBmDOPLZieW4r 52/aI+FmrfE/wTNp2hxLLf2aG4jTyxJJN5XzeWpP3WYAgH1PpmvfZWRgVU+9XIdQktrV5bfiYDAJ FVETR+AzzSIXjmia2aNioViCeOvSj7T92SHg9MjrX2X+1b8FYNIuLT4i+G3WOz1K5l+3W/A8u4kG /wAxP9h8NkYwrYxnIA+GomlYhZk2Kp/WuiKucrR193aWPiCK2N4jTSRH+FsYP1rlG8La54i1mPw3 oFoZJrk/uskKDjry3HFSK5XcnmFF3buOK9H+Hfj6bwprJvLiGO8DoUUyICUz/EhOcH6e46E00hxP r34ffCnTvhnoMGnrEW1OaFDc3TY3yMw3bGCll/dkkAg/WtO/fyw4+g3fjUvhrxxo3jTSvPsbxWeM lWQnaysp5G08++e4xTNSngeIgLn+tMo8s+IfjrUPCHhTVYba8WGSWLMYY5yx4UAd8da+N9Pt76KK 3v8AWww+2kyiSTgvk5JHoM19LfGvw9/afhw3oUiOx2zMegBJ2gH2xXNnTPCHj74PXkk0g/tnQbdn jVH2yJ5QyCR3BoBnkelz3Wu+IE0wz+TbbScgcgD+te7aR8OPCskStqNt9rn4KuzcEHvivFvg3qGi R3g/tq7SKS5I8tX7t2wa+x47dVwsabnxkEcD6igKZwcPgnSbWQmC2SKP0Cjn6Vdj0mCzfEMKBm6H aOK6SbeG2zKQV6CrVnCsylAhOO+P5VmdFjlV0+8ZvL3bsnjPSuksNA+zKrSfNKRkkGuit7JWVCyc KeD612NvYxiz8xh09qzCx59P4Zs9atXsdQjaSNs4JJABNfnv8Wfh9e+B/FL6cZ/tcCoHVwMff5Ct z1Hr0r9UodPEsDfwq1Ra98PdA8a6PFouuwSXNmW+ZUOxj9G5wfeqUrEuNz8eNCsrq8v4ltiDyDtx np6/TtX0z4WXVjYTi5tRInmAJlQShHTFT33hPRvhLf3+m30iXl6lw6JKo+8qnCp9QOtcmvxO0q3k uYp4Jo2bsjAAY6fjVe1N6WDh9o+8Pgp8bW8N2sfgX4g251/wq4IkhPzy2xc5Mi55YLydmcdcda+q NQ+DgsNMtfE/hDUYtY8NTgSQXUbBQiyZIDjOBjGDnoeDg8V+P2l+P1n2zWqn5jn5jh9w9a9BsvjD 40itp9Hsr24srS8OZIIZZPIbByG2btv6VnUxHKexhssjU0g0fWni34oeDfB8rJq2qRRyPkJDGcvk DIJABwPf6V53e/ED4M/FCVNF1xrOf7RhdtwCH3k4GyQgFTz2IJr5yub7S9VmdrxDK+S+6RSWJ9ea 5WbTNA3B41G9j1PH/wCqsFjonVLhVvZnqXjv9l2ezs/tvw11JpLmFyz2V1giYM3ASUYC7R/eByP4 h3+YdYi1TwnrU2i+IIhY31swDxSdeQCOmc5BBFfW+g/GS+0O2jtbqIztbL5YIOTJH/tZ61ta18cf BOuac9h4o8PLqELAlTPGrlHHQqeoP0PI4qXmEV5nkz4dxUW1KOnfQ+QIL6Od/LUfNjrjjPt2q5F5 L5QkMSMEHBrS8S2Xg27vEufBlvc2Ayd0Mjloz/ujGRXH39jq+gwxLqNpLAJgWVyCQR9cV04fHUp/ DJX7HBXwFan9l272O6t0KwiNCVULgegI6VsQeJ/EtmkBN6ZILc52cjcK800/V5ZBHEJCvclsge1d lHqVoWiieYCRhjB6D1rot/McJ9w/A/8Aaa+G/h+4vYPH+nSvFc2wRd6q6MU52SKeSrdgAfcY5H6U /Cr4zfCv4m+IBovgu6tdODxQiYqixS4ZSVBjOOBg884xz7/z/SWSTjzUxII+j4p9jrfiPw1frrej vPDcYKb4yUYocZAIxwfSvls24Rw+LqqrKT06dDto42UFY/qg1f4YeC9YsLnT72zLx3SGJ5c5Yg9T uxkevGPy4r83Pi98D/EfgNbvWLWA3miQS+UCqHegXgO2M/KT0PHFfLXwT/b++Jvw+uIrHxF5muaL 5SQPFcOPNjCkcxuedwGevrznAFfqR8O/2rPgl8YbGWzh1Eabc3K+XJY6gVUSBgAQrg7SSTgd+4yO a9LDZbToQVOEdER9alN3kz85A21FY/cXmuK8U/CTwT428691OGUXFwP9ajtvVh0Ydsj3BHtX6ffE X9m3wn4ks4LnwNLDpV3OwlBc7rZlHG0bM8k9/r14FfI3iD4f+LfBczQ67YtBFE/lmdPmhZsZ+VgO a6HEad3c/L3xd8H/ABl4AM+tLambS7aTEVyki+YuThSyj5gfcDHvVfTfi7rmlA2sub0hTGVm6jPX B9a/S+IxSQyBgsiOMMCMjB+teL+NvgJ8OvFsTXcEf9lXpHLQdCfUr0pITR8exatp95B5kJMZkB+R uq964PUd7SPsYFTwwI6iuy+I3wM+J3w/jl8SxMNV0SMANPanJhB4USRkZHPGRkZI5rxZNZvGspBe YhnRwrBk2nHuDXVSjcho6jQory116zbQlnkupWwsUBPmSA/3B3Nf0Y/stfCOf4ZfDdfHHxfneHVT GLp2lbeLKyjTdGxKjcXKkl+TxgYzkn5O/YH/AGV7mV7P4reOdLCWp3CztpBtnDxjInO7P7twflxg nH9083P25v2ldD8TXcfwq8EanI+naazHULq3cxpPOuUFuCCCUj+bcCNpOMdBX4hxZnM85xiyrL/g XxSvo7b69vzZ9BgsJKlB1JrXsVvil+1r4d+LXidRb3a2OkafNLBDFKADKoYATb+VAbORk8A47Zq1 BbQOfMt3WQOARyB1Ga/KO+8HSuPtVgpeOU5IU/yFRWPjz4j+DTHa2OqSW4WQurT7nZjjGBkkBQB0 A/Wv1XK8no4TDxw9HZHm1JSlJykfrh9kZTyMGk8pRwGzX5/6J+1N4nsvIOrWSXCRqFuJYnIdh3IU jGTXsOjftF+HdXtEn85rB5DgrKuT/wCO8V0OnYy5z6Bupow5jH3s19x/sb6Ol62o6zIOS6rj0Cj/ ABr83fB2vw+LGnubKUSorbd5OBn8fzr9dv2YtP0/wz4EluZJY2lkYM7KeMnPGe+K4a01do2lBqPM z6nuwdoUcY/KsGbaM5rmb7xpZGYweaG9gCKoTeIIvL+Rg2e2ea5JmcTqhMqZB6CqVxqcUfCmudh1 QXAIUjI61WWSNizkgioBo6I6zn7oNMS7Ru2Kw4njLggfLkD865Dwp4+sfEPifxL4eM0K/wDCPzrE PnUNtI5LZPrkD6UEnqBk3H61B5DtVafWNGsYTdTXUZUEDhh1P41yF/8AF/wjY3LWduy3EiffKyr8 vJHIH0oGkdstkrHOKmSzK9OteAav+1V8LtF0ubWHv0vI7c4ZIAWbnjGTgD8SK8Y8T/t7+ArOwmOn WlxLLLhYg2xMHOfvAnsPerjC5rGlfqfYvjQvb+GdUdNpaK0mkwTjlUJFfz0zadrV7qTzPI8FuZpH 2q5Ub3Yk49cmvsL4lfta638S9B1HRtJxpttcwpEjiT963zZk37cDkZx7cdM18b3OqeGtFDz3uppP OBzGGO9tvoDW0KTex9DlWLw9KDVR6vyOka8sNEiWTV9UhsZGG0AtudvwXOaoXfiW1SPzFu5poB0Z crn+XFeY6n8Q/C8t0pXTBfNKpUHgFCO31rzTxJ4m8Sa7plxa28X2K0Xo0ZwQB2z3rqpZdOW5vieJ KEY2gr/Jf5XPetV8V3DWb30yFLaEZ3M+WYD2rwrW/iGt7HJ9nt2XfkLgjGfcVxMcSnybWW5cvMuQ DISD9RWja2+nW3+k3johThQOa9WhgeU8CvnTqR92Nh1t4kj1ea3s7hQoGFLkdCepqXVtPtdPu4pV uN6SjIz2INeWiW6mllubOdVIbeCenXip9R1vUNQdZNUdFWLqFPGa7ErHlOu5bnSXeqQw3cvzZRhj PXOR2PauNOoX89gLe5k87axBUDqueKfa2V9rdw1potvJdjcNzouY0z/ePavQ5/hLqFrZFvEl4tuE OVEbfMV+gp3JPNI7dZ7oQYYhx8qk4JNbw8L3F3E2x1heEcbucn0q/DpNnYybrVmlCH5HY5NayXap ERny3Y/e75pGZ57d6PqFswL7VYAA9fzq9/wj263D3M+7JAwgJ4967iPT7y/ZpogN/Qk5ICivQPDH gueV7JNShliN4+FKjKvGO4rQls8QjsbWGaGztYwGkwFO0ljnrXtFt8OL37Oizwq0cuFJ2chT1r1q Pw7p+leIm0/yozFANyMVGcdvmrXute0uPTb2Ga7RJojnr09OKDGZ5nY/CjwtZ27tqUwvMnIxlXUD sT3Fe16PPo2i6aNTjgVBargbEG7joC3rXzyviDUUu0mtJlmTn5WXPX0FRar4h8Z/Ypri0Mos+RKo UbFHril7SHc61lmIcebldj2DxJ8QEubP7eWe2Q4zErbm/KvN73x3PcqE8O+a8iEEl0OPxHas/wCH 9hpus3y3viPRb/UrW3xIQIpUWQDoN4ABGR0Br768C+H/AArp+5dB0NdLt5o1dlAOSDkgMXyxxngE 8ZpnN7Ox+fesap418UXw1O80+6uZERY1MUEkgUjsNoNYOoaF8T79Y9nhzUZzCSQxtpBjPbBWv1vt NPtII5IbGIQox3cHHJqdYLKykWW4k+ccgliTms7FH4zX3hb4lW2XuvC2pQNIMqXt3XP5qKqHwj4j EkQuIPJnfG5JFYPk9BwDX7I6xrnga0Sdr27g/tCTpC7je3uqk8gdzjA4r571D4neANFvZiNJW7kj bhiAee59KmUrCTufEVz8BfirMn9qWOlzXyFMrBCh3tnpjOCK4a6+Fvxb0S8eLUfBGrpcPiQJHbPM qqTxueMFQfbORX6OXv7RtqtqLy3sZE2dRkDI6Vxl1+0XbG6RLeOSFpuWMn3R+R9MVn7aXcuMbnw1 p3w5+LU8xeDwLrMrId2fskgxn6rWu3gr4laSlxP4n8LalYQqo3STwlAiscBsHBIz6V+hWn/Fq+az afUpxlx8uzPC/nUafE+zvJVYlppFPCSndn8CTVRqNluJ+feja5qmjxw6dcQSxQxfu41kQoSOCMZ9 Qa9G03xPeG4CxME2/wAB619R6t4Y8OeM47ufxFYRJJO24tD8jqT/ABDHQ187eMvgnq/huy+16Bqs uorK2BEsIDAE8ZYMSTyOwrT2tyXA6CDVrfUi7XEYKdBnkZ7kZrgdX8EQX8nnWMgUSMCUbqRnnBFe aSXfiPw5dzaRfK9tcQorEPnjdz3rsdJ8Sy3Li6WXygyjcG6cDnFaEHO3GlX+mSy2sYPyNxu5B+lc 1cXl3el1y6eVxxx81e1pqxu9oGwqpyDjJNY2qaRYX5823Ajn67sYXPvQB46bq7VfJMrsDgE5OeO1 ZD65qxle2aR/LAIIJ+8PXmvTNT8HyLGbi2HnTNwVFcNdeH7rT2e+ntJETo2e35UAVLPUpLdWRGKB hy2ec1dNzNK6QEggjlf61QgtVe54BQDnBrSjsGMmDzjv3HtWlwJUsfM3+YKhi0yCafygqqq8nOSe eOMV0dvAzo6qQiqOh5J/Gu0+HWr6T4Y12bWfEdoJoItskfQneucYB/z/AFyrc3LeG4HufwY+Dktk p8ReJYJbLUItn2ZGPBRu/tX1Zqvinwp4eAg1nWLeGdUz5Bb5zx1OOM18S+Pf2ktUuvJtvD88FpFM hEyspYspHAz/AAmvmLXPiBqWu3SXl0itgFTkcEDpgnnNfO/2NWqT55vc9KGJilaJ9y+Nf2nrGz36 d4fESCPLFydxK9+K+TfEvx18aeLbufT31mZdMkxiNGMat7YHX8a8hu5rO4gEsKAO/Bx1/XrWcJrc WwnJC8nrha9ijlVKnqck8RNnSzSzwxxRyOVhRt4B6EE4ycdaxrjV0ieUl/PVsbSowVHrXNtf3V6T a2AkuHkIVVAOCe/X0r3nwF+zN8WvFWn/ANqS2kmlQyyeWPOj2kIOr49Mgj/62CSpyU9SVzzPIk1B bRGdJAFX1HHNV/7SF84a3t5rjB2uY1O0HsOeK/Rbwd+w14EsLMXnjnWLjXdQc/diP2eBBgcYG5yc 992McY7163e/s++AjaywW9iIY3wWMR2vweME5rilmkNrGywkj8podF1W6mh/0KeITHG/bjaB6101 t4D1ia5QzEfZ953OB82O3FfWfi74fJ4S1aO0gV2sxkoWfdu+tYty0ZQxxgAD7vy4rR4lstUUeJWf w60+Azfb3M6Pgc8ce3vWs3gnwpbDybezMkZOV3tzke9dzJKSwgiOMD5gRxz6VPbeH7rUrmKxssJL K/lgucDmspTm+pp7KPU//9HgEVgCpO7NKAqjCnmo2ZBkqCccUEZx1ya/0UP5TJXICBWO2lZGAyDx ioHjbqSdtMVncbTkc0ATKSQQvJ6UKzx5XGfpTVYR5G2pBnZ8tJoBo5bKjaaQRsc84K01pMrxy1Lu BAZeG6GosXEUjeSDnI561BJgxzbh8wHH0qWMhWMnUHg4qtflI7ORUOwsRh/X2rzsbBODR2YWpyyu Msw08bu4wEHFEqZTgZJqnBdz27NEBxgfN61ckleRA5XaTX4ln2H5KzbP1DLKzlTRz13A3mJNBlJo yCBjrg+tfSHw51O81lpYnfiFBlO5PqPpXztcOJFkCA9T35//AFVueDvE1z4Y8QWeoSMfJLBXOeAC e49K/NuKspVfDycF7yPsclxXs6iUtj7ZsNJaUsJuB0rT/wCEcgVWAO7I/WtXTr211G2S4tcOHXOR 6etXG8wgZHFfzxXvFuMlqfpNLVXWxzUOgOrAMfl9KuxaWkLFcitgySqRg5NRMSwLHg1wzmdCKflo Dg9RR5a45HFO2tnkUnzYAJ4rPnNkh0cUaEqF5YU7ycDDdKam4En0qwFbpjmspz0GkVCihsjpUckP mbm6Yq1Kjrz6VASwHSvOxCvE66O5BHjcFbr2rcg3BcisdfvZ9K14c7MmvznN6fLNs+lwz90nL8Zp EJyWpCy4xTVJyRXjwOwZM4bvisK8j+UnOc1uMgYNkZxWRPKo+TFdEDM4i6cq4UjeQ3GOK8N8Qq/2 y4Upsb19e9e6arbnzjLC3OM814b4mEyXJaUnYpb8eMV9Lw9VaqI4MarxPq74aaqNT8J2SkfvLdNj k9TycH8a9EADDFePfBLYfCbqDl1K5z1yc8fpXssKd+9fumX+9TTPz3GK02TRSCLGBXQW0yygK3I7 j1Fc+VwcVahldGwBXVJHFzHzn8bf2erLxs8usaRJCk7nJgaBCm5V2q4cfMDjOex46V8q2v7EWpRC FboQyW7Kxk4Ak3kjGzjGMZyT0wOtfqQk/ADc5qZZI+hHFYTiHMfMPwv+B+h/C7ShZ6NH/pIUhp3V fMIYhmB2gDkjnAA9qk8c2K2jrLnL4yw9K+kJ0jPKrXmnxCsrb+zHuAmXVDk+vtXzPEGGUqLbR6+X VWqisfPFpOQ2/HB4rTjnKn5elYkBXZ5anlua1YA4YDFfjWIoctz7umbMcshTpWhA8mQcVmxAhuta MWQetcQGvFNtV9o69a4DxVboyuzHBYYH411qzYBUdzisDWLf7WACenrXXgvdqJk1vhZ4eoktrvER IdSeWr0Hw/MbtN052EdvXFcRq5kh1iSFuFXG33rb0aSKK8GH57V+48Pz5qaPhcfDlme2aK8CTLuz kjivT9Plg8pQDXmOkRiRQyYIruLL90cEcV9JA8mR3Vs4J2YrUQk9BwOlZFoSEXpnFbEZ8wcDFbGT Hr1xmrCJk81Cq7eTUqEnrVGROuQcCtG2yrDPOaoqRgYFaFvgYPemjM2o8ECrCdTVaLtVnOM1ZoS0 /OajByKWgholzTsimAYpQM0GQ+iiig0FzxikoorQzE5peKQZo4oAMCl4oAOOaMig0AgHtSY9KMg0 uDUMCeM4rWe1t9Q065sriPfHPE0bfRgRWQlblpOsR55B4NKWqBLsfjP470K58PeLr23nj8qOeaQx oTlhtYjn8BXCzxHeWc53V9M/tW+HZ/D/AI3j1CGFmtbxvMifnazMPmGeRwe2a+Z42kkHzCvhcZDl qNH9jcH45Vsuo1F/Kk/VaM9a+AfxTg+E3xVtdfu4g9leqltccZKgsMMPTGTk1+9Gnaha6rYwajZv vguUWRD7MM/nX8115HznAORgZ7Gv12/Yi+MP/CaeBz4L1e483VNE+VM/eeHJO4nvg8V63D+Ks3Sl 8j8x8XeHeaMcxpLbSX6P79P+GPuiiiivrD8CbCiiiggKKKKACiiigAooooAKQkKMk4FLVLUIJLm0 khiOGYYrQCKfVLWBxGxyT0xzWNP4mMWWW0dkQ4YnjHpTrHTdQiaMTldsfORySK2J9MtbhZElGRJ1 +vrWZqjmbjxY8bIotygkGQ2c4NWFk1SYmRJyVIyuAK0Y7DStOXMjAhRg7zmlbXNEtwIxcooA4A9K zN+QxM30mYnjk85sbWB4IpsOiaylzHcJKAAfmDndxW2uuW0pJtEMqxjJI44rCvvEt25X+zFAKZLK /Uig1VM6+5tVuoDDMOSO3qPSqC6LZlI1fOVGCemfrXmcXjrxA1xseEeUXXBCcBfevS7mS5vtKZ7X icjIHQZHpQK1hskeh2zhGEauvbgniprXWNOuZXt7aTcydVA9PSuG/wCEb12ZxevtWZmyVY+vWtjS fCtxZ339oSS7Hz90cjB61oK50N5qbQ2hurdQ5Bxg8Vktr0geOfgxH7yjqDV0+H4GkZjK5VjkqTwT V2PSLCPgQgj35oIuzi/EWoaxLMsempIEI4I/rVTTrPXph5k8Lw3Kngk/Kwr1LaAOB0pcVLRXtEcp N4YgvonS7bHmYJC9iKhh8GWMC7Y5XA/KuyopJE+0MmLRNOiKssQ3KMZ71pJDFGPkQL9BipKKrlIb YUUUUaEfMKMUUUyQooooAKKKKACiio5ZYoV3zOqL6sQB+tAmySiuG1f4l+AdByNX160tiOzSj+le O+If2tvg1oE0dsdV+1SyKSFiUsRjnBwDjI6ZxQS2fTdFfnV4o/4KAaFZi4i8M+HpbqaEnaZXGxxx z8uCOvv9BXzX4n/4KB/E/VNRSx8OWsFnEynO5SCGPvnPH+cUCP2nZgoyxA+tc7qnjDwvoiGTVtUt 7VQcfPIBz9K/BjxR+0B8cvFsCzzaxcF0G3ybZjGoX1xyf1rxm4vvHfiFriTUGvJfMckrJMzD8QTt 69MAUFRVz96vEX7UvwX8NzSW93r8MskYyVQgnHsOv6V4Nf8A/BQX4bC+ey0XS7q+wcK3Chvzr8lm 8JaremO4nkCvtAYFeeBj+VWNG8C6tb6lHeXV0rpGSQqrt4+tAmj9HNe/ba8ZXjbdB06GxTJOZBvO K8d1j9pf4va8JI7nWHtoTn5YcLXiX2AxqCoz9PWpBaFyE2tk84IoEbOoeKvEmvMZdV1C4nOSQWlb qe+M4H4ViFHnbdIS7jjJPOK2bbw/rFxGGtrZ5BnHyjNdZpHw68VahMgjs2jB7uMUAeeGzQBj0B5P PSrEdrEWVY25xnFe86R8ENfnuMzZHcjHavUtH+ANq9zFNMrHb94YoA+Tre2coWSJn29StX7Wzupp B9mtpJAOvy4r760X4I6fbXJkhtiqtx8w4r0S0+EmmW6qphQY5yoArQzPz203wf4jvyzWdgxAAJPT H512lj8Hda1SHzrh/J9gN2PqQcV+g2m+ANIshvkQFz1wMZx0J9/eumh0bT4UC+Upx7UAfE2j/AO3 NjG9zvnm7gDAFelaJ8DrGNA5t8MO7DmvqSJIY0CIgA7VOr7gRwoHtQB43pnwxtrIbYo1HQn5RzXa WHgjTbQF9ijPYCuwDAZ5o34oNDOg0HTLYEogy3HSrEVpbwkCONRj2qwzjHrUJOTjpigzLHmKBgDF LGwzwKr9KfGfSgDiviEhfTpMjcoGa+dVdpH3dAK+oPGlsbjRsAcnIr5nS2dJWTqFJFZmg5XIU/4U 9QNuQOtWPsjx8vGyj1IqSOKJG+eRV+pFZmiKoT0FOEQ71LJrHh20Utealbwheu5xxXE33xb+GFhK 0cviGzYoSDtkB6e1BUY3O1W2ZulRtZOOozXimuftPfCnQXSJb77Ycbn8roi9iT78/lXzh8Qf24NE kvoF+G6iRF3eZJdKVBIAwFHb69x6d0qhTifeos8Gl+yP2WvzPf8A4KCaw2iRWraAj6iGcSXAfcuP 4SExjPr2rkX/AG3viOdstvFDJ1zlNmz0x2JpSqIap3P1kFqyYL8Cp/s9uE8xpFQe/FfjTN+2D8X5 ZjLNqkkQQkqI4o8BW7fdJI+teY+IPjr4+16B7Z9Yu5InbcRO2Dn6Kf60ozuU4I/dldW0RC0c17Aj L13OvH61m6t448CaJA11quuWsEQHVpV/TnNfz1NrniO8fzLi9IbPXJyfrkkVLJLf3EZjnunkJ689 Ppmr5xcqP3Av/wBp74H6GFa58S28oYZAQsxx+AJrhdc/bk+C+kpu0sz37N0xGyj82xX40izUfJyT 704aepbcYyT644o5w5UfqvqP/BQbwnCUXRdCmmZ8g7nUAfn615drn7fXjbUfMg0zQbW1jWTKSMSz lQeAykbTkYzg59CK+BY9LMrfulAFE9rLarh8/wAxWcncfKfUVx+2v8dGd/JuYrYKcgooIH4N1rh9 S/aS+NurFpLjxLcKbg5Ko5VPwC9K8dhtJpMeR+9DDHGTWpBpDmQJIjJIR3GF/CpDkL+oePviBq9x LPfa1ds8qlWZZ5FGOnTP69a5aR7+8G67uTctn/lrlj+pNdeugylGRBuz15qzbeFZ5QqxoDzz6imh ONjgmsCgUInA+tWBZv8AKzqqgd8Yr0i38E3vzMXbJ6LtrRTwLcyMAQxK9R1pjseZwIiSqwAOT1P5 V5l8U9Okiitb+SPKklI+2SK+uLP4bSkortjJJ+Ydq4v4r/DO/k8KXEgQstmRJE49T979KqDOeUT4 nt5ZG8s4wTxW9GeAqjA747muYgykrRud2x9v1rpogg3beMcEV1IgdkAhRxmnJzlGJIUZph3KCV+t PznBPJxnj0oAGcqMhCB2qqqBn+8NhOGHerKZwSGIXtmo41AfO3OP1oGj3z4PWaa1PPYrxEq4YA4P HvX0BD4CgDARkncCp3cqPrXzZ8BtRFj41XT5BtW5YZOegNfd7qRJ9nA4DYH/ANesKp2Q2OEsvhiJ HMiusUQP3cda6u38GRqqA7fl4GRXf2lxGUSFly2cdK0TbKW2sBkD8RXNMs4K18I7Z0wy7M88V1Ef hOwjJO7J/StyNAEAA2kHr604SEsExjnrWZoRW+gaVAgKQjcOvHWrMOmwRtujTHoKvx9AQeelSqcN wOTxigAjsYVHmuAznoMVcghjVNqryeaq7pFk46e9WkJU5YUGhZVASCx6cD2q3EDs6k4qtEFkwAau AheDxWZrEeE3v0A96lutOt7zTLqKVBLmJwFYZBbHBx7HmljZKt277ZNo5BrGvC8bHRRq8klLseD+ FN0d61pKjx3UTfNk8Y6V63D8mcD2rhfEOny6P4sF0hxFcqCCenHWuysLiOZASevSvzjMKHs6rR+y ZNiHVoxma4AwDVaUsSc9qvKqhOO9MaEkEt2rkPXK1m0kN4lwg4Xqe4r76+CHjyHUNMfQr9t7BcJn oQR0NfCKQlCQCDn/AAr0PwL4km0G8jAby42YEk9q9bLsVyOzPIzHCe0V+pU+Pmgtpnii7lRcK5JR QMLg9AteK+Hpns9QDbciUYPavtn4z2EPijwbF4isQHnjj2urD5uf4hXwrNDNaAxuSsgHHNeq9Kik jyXC9N05HsZGdrCjI34PesnRNTFzbRx3XEuOntXQmOL0xX01LWKZ+U4iNqkkMjcnKqMAVOnKEmow mxhjoakVMtg1uTIFAABNSHjPFPWLaMetKqEEmgghi3NINpxV8KQcE80ipwM4/ClJY8YoJaJOOxqQ xsBuHNU13K5yK0IZQUKGtCiFXkVuc4NWAw6sOlSbht2Hgik25GQKDMsKMqG9alzjiqib+h4xVisw JFYg09vm71UO8HpkVMu9hjtQAogRjuY9KozwENt6elXQzJnIyBQxLqC3OK0AbFCSFYnAFWSoHTmo xIAAOlShtw5rM0E3cYApdoxmn5AHFJhnHy9qDMcu3oalXHTbkVAMA/MMCpVZfug8UuYBzDdwoxSA H7pFP2EcindOW7UcwAq/Lgik8sq1PDbiO1THqAaLmgwqCop6Ha1RnOcU/aTioAn3HpjOaRWK5BHS o1JBNSYwN2c1V2Zk+NwDA8GmsSTtA6VH1HHAqVFPc0XZTZHuccEUqCXdz0qyu0HNMLcmqJEOCcUq RquWJpFC9utSYwvTNACbSxwBxSLnODzimtIyDcvNMEyn7o5qLAWt20gAUfNknoKrrcqWCkYqwG6k iiwC9BwKb1604Ek7ugpp3BuOlWAvbnpQOelLgdc8UAA85xQAijuetPHTBppyvNBxwQaDQdgCmEFm xTmOMEUo67qAA4UYxzSE8UDnJak2kfMelZgB6ig9DSMehp5rRMCMAAc9KfGvOR0qPJH0qRabYGP4 jLDTJeDuPyrSeHgYNHgXbhhnd+dVPEvmLaKcn71amlxBbKNiT8wpAXpGx93pTSqkDFOwB8tIcbiB QAu5V4JGaj35oyf4aQ470E8onz53dBS5c8HoKXe3A7UbyHxjAp85IgJBzikGWoJ3KRQWYDaKjmAk zhSBUTBuKYZSMgmgEtwT0qgEfn5TRgq3y1GSecUZYAnPNAEud59MVGxwc+tMwTjnmnFgOH60AJgB +tNbJbJpG54qMuScelAEjYx71AGIfJPFKRu/CmFQvAag0JBKN+aQ3fzlcDFQfNgntTfJRjuPFACE 7nLDmlJ4pcqmdvWoyM8DqayRmSblPHegttXB5qNhtXPemg8+1aIBd/twKrSyM+4KMKKkkbYuAeKr Ejac/hTNCAjkc5xTt4JxjiktxmcLKPlqSdFSQ+XwvagzBQKQIDz3pFKj73JPSkEg5ycFaVwBzj5Q KgViAVbjFSs6Dn1qFMSMWPWi4Ebpn8ahmwrBQfrU08gjRmJ5FZKzsTvxnNQBaZt4GDwO1MjG9ip7 UFgE3EVGGDAk/LQA4qN+AaVVzyT0qNABuOetSk4xg9aA5xGfBxnNPEgVcHpUAGM8ZqGWcj5QvNAE /wBp5IHCjvVKVyiGRjwxqq1yiHafvE1mXmog/u8gBaANDz8tuWppZx8u5vrXMS3/AJcW8np2FeIf Gz4g3fgzwTca1Y3i2+oTDyrVSu4CR88nsMAZGa1RMj5R/au+K1z4k8Rx+ANNf/QtGnfzXVv9ZIcZ yMDGzBH1Ptz8wtCk8TJON2SGGOKqfadQ1e+fVdYmae5nJ3yPyzEnkse59T3rRt7K91fUINC00Zub yRYkxycsQB9Mk12QWhxyWpyEk/lyuku5Sp6MO316UO0kke4H5v4RX3bcfsmz+J/CUM1jfRWN7tIl aUEh9gGduTyMk8jHIwe9fDnizw74h8AavLpfiO1aIQSmETL80TMBuwGHGSuDitIoVizYanq2jSi9 0xgLiRCpDZK/XA717R4T+OF3p1tLY+Kh5ohjASQLhj7ZPavBINRt5tmw5Q5+ZcNiteTT4L6zPIeU Y5PPFIR9r6X4p8J+MdNmFneR3AmjKS27/K+1hzlSfTpXx98Sfh5rHw58RXF1osMx0G4jylw2Sqb/ ALyHbk4B45/+vWXH4X8QlV1HTWkgHO14iQwYdcEdK2IfHHiTw5bPo2uvJqdogbAuSzklxgkNU8oO djN+Gfwx1j4qWWrR+FbqI61oUSzx2jkI9ygODsJ4GOOvGSBkZr2L4YfGC4sLtPC3xHZoBDItvJMR 80JQ7CG/3T97HSvm7wh4h1/wb4hHijwtdiwv4ZhOrp0ypJCso4ZOcFD8pHB4r7xurbwZ+1n4Ya8u Z7Xwp8S9OiURzsQtrqMYJJ81doxnkcZZDg4ZTtElqR7FDplnfR7rZ1uLdhlHXncD3BqVNNjiT7PG mFFfFXg74r+N/gp4nuPBPiwteafpU7W1xCqh1VN+HkifqdoGQM+2BzX3n4c1rw14rtE1XwrfR6jA 8YkO3h0B/hZTyGByCPUcZFZXNoSuZ9pp2fmmX5RwBXQx2iiAQv0rYjsyQpdRlugqytsgfKgFu9Yt G9jNt44UIwM7RgV0NqHiRpmHKDj0qSx0wSlpGdV9u9bAsFkBibIQ8FqRooH46/EXxFcXniXUIdRY yvb30zoeMortx9a5bx18PNV8M2OneJtLzqlhqqs8r7SBBIP4SeeMc5+o9Ce08Z/DXx9ffFbV/C2g 6LPq99qM7NaxQIXeaMjzMoP4sAHOPQ9+K+1PBnwW+OPiz4G33w+vvAupwXFw7Qp5sSw4QYbaRIVx nGCTgf18rHZxh8Lb200r/f8AcdMqTcVY/LC1v7zTlaSxmInPz56jP+yK9U8DeIde8SaraaHbIblr jl96bXQYyTnAxjHWvsfwz/wSv+OutXqR6/e2XhzTxhhJJItxKoPONsTHJGcYJ5r64+HX/BNzwB8O YH1D4j/ESTMiESPaxpaMvXI3uXyMcnAyPfFeDmXHGXwp+5Jyfkv87G+BhVpS5loflpd6va6XevZz N+9gYo3JOMdRkcfyrW8PR3XiXUItN0XSbjUJpSSBFE7cDqeAf/rV+qtx4R/4J7fBto9U1u8tNavd rxxpLdm6laTPLsobAb0zwO1VJP8AgoN8BfDQNl8M/BTmKEKiyxwxWrPgYbBxk+7Hk18nPibFV9MH Qb87N/l/mfXYbN+Re9Y+W/hz+yb8ZfHEcc9roP8AZdnMpZbi/byUOOgAOWOe2F96+sdC/YJ8GeH7 Eat8T/E6RMkeZra2CrErEjGJH5PHB+Xkn06+G+Of+CiHj/U4EttEmi0xS5KCOFCwiPRHMhbJB7qA Pavlmy+OnjXUfEljrvinUpfEP9nTxzG3upGw8aPvCF+flPI6dD3rXDZVnWJfNVfJH7vy1/EnF8UU eW278l+p+lni27/Z0+C9oul+CvCH9uXtvGridYkcksfmZnbknjnA4yOBXw/8SfH3in4hm9s7Xw5H pun3iFCBb7+W7htowcenfNfX+n/Hr4IfE8Qpr3g+OyszIn7y3nCXMJc85VAu5F75b3AzXri/Anwl qHh4694N8dWbW1vlzFcqiquckqzq33x3+X37c/bZVw79XSfNdnzs+IYu6a0PwnPwv8S3wf8As7TL 6aZDiKOO3fBx6sQeK5v/AIR3xvZswvNAu/MgYqw8sggjr1+lfrB4k1bSvDGs3ej6jrdtdG3x81o+ +IqwyPmH8WOo7H864Gf4leFo5DDvSWHuJE/+tzX1MKjtZnz2KnSk7wVj8ztP8QzQllimZZE+9EeO p969HtfFOmloFuYSqEZJyCCe9e5+PdA8A+NbWWTT7OG0utrHz4E2uzZ7tXzDeeCvE2iRzXiRG5t4 WEadN/PTjvTjM5Gj0saT4c11JW01wJywIVjtCn/69Vk8Oa3oc6X1pJsnjO7dE5UcemOpFeUy3t3p 00UeoWrwSOAdvKsR6j1xXeaH42uLeNraVmmiUZG4c/QH3qiT6B+HX7XPxo+FUZ07RNRbVtLG3Fnq DiSJCvXyyRuT3AOPavp61/4KIJ4ss4tH8ZeDrWB3GGK3jeSW6E/MhPP1r4AgufCviuIWdyy287nI /hbd71aufhLe6vEW8NH7WvCEAZx9aPZ3NKdTldz9DH8UQeJboXmkaCmnW0ig7YZxJn3z0PtXKX2r +ILMTLBpHlhhhGkyRu9SQPzr8654fG/gyeW086VFRdjJKJFAB9Bnn2rrPB/xa8VaDeQvfXzXMABU IGZgmf8AZNeBjaGIp+9Tl/X3H3eV43L6kVGtT/r1TPpTVPEnxFlRo7hLVY4m+95LBW9ioJB/EV6h +zT+xjd/GD4hN8Q/iHAjaFY3Il8tVZPtco+bauP4VYgnrnkH1rqP2YfhlrPx6v8A+17q6Q6Fbys0 6bDmVFIBRWzhTznODivvT48fHDQfgX4TbwV4HjRvELxKipHuUWqHADMyj/WMp4HX+I9s/kfE/F2M xDeWYKV5S0dt/T/Psj6PEZfgKclKlBJ97uyOR/as8feI/D3gK4+G3wrS1jvb+3e3eYyiPyY4sK0c bIw2S46Z+mPT8coPgH8QdRm8261G1W4lIZ2mcvyepYgHmvfNV8brqV4da1fRQ91LzJKkjAyP1LNk nJPc1i6nq+navE0MKyQwyYMmH5+mRyPzr2uFsnqZbQ5F8b3dv60Pco5VgasEqk4yflJf5nNaX8E/ EukRQQ6jrlgFTIJj3nK+5KiugT4TeFzvXWtbsZlkBClypOT2HINZkVzpNsfLgkkeMerHr+NZ923h ucOH5li+ZgWyQPbivopYzEN6yZ3w4fy6O0Iv1af6l5PhN8CNPLm+v0eX+Ixs/B/Miti08PfAmxnT +yLc3MwwF81tyE9zgivMdU8T/D/R0C3t+kSsQBvQkknnGRWZF8X/AIeLeQWMAF0Z2WNHg4ClvXIq n7Zrq/vNHRyul/Iv/AT3yQQ+GZFhsNOWOKdgVOcBifTbX6reAJLrRPh/oVnCCoaBZW9zIN2P1r8t X0q/06/067uIQ0GmyxziN/mVzGwbawJ5DYwa+ph+01cCztTbaGZZFVg6NKAiBT8uDjPI7Y46c1tQ jJX5j854zxVCbjCjZ77H1ZqWr3cmZyxjPYA4z+tc2vj3VLHzEfc+DxwCPxr5muP2lbp282XRHXg4 Ebggn3JFeW+I/jv471ZWl0nTLfTwudykGVnH1OBXQz4iOh9wzfGFrfErWbSEcAqcYORnI9MVw3iL 476vYIj2+2NNw+V8d+eMHk1+bFz44+Imr3Fyn24QpNndtB+TPPB7e1T+EPhn8U/HstxBojb0hyfM uZGVGbv8xB5HUgDOKQWPrHx5+0j8TjdD+xtaGlWO1BHAIkZnfaA5kcgluenYDHGck/NUfj7xPa6p qOtXniOVb/V3zPLCSkkuTkDMYHA4A9gK+jfDX7F92++TXNeW93bOSjJ5efv4BY5OehyOM9zmvcNZ +CPw58EaDPFaabE6XFuItzJ8wZQcOGOWDEkkcgAnp6TGvFOwM/KF/wBrnxbpdzc2ssupXXkSMsbP cMwKg9cN61g6j+1JqV85u59EuXDf614pgWJPU/NivL/if4d0jTvGU1tZNKht1IkDHKg54/SuK0SK K6uZbSeRZMjIyOMjt0PevoqWBic1TEcp6DdfHa7vtLuIIfDZt3ZhteSUuAueTgYrCvfG/jGS18+1 eK0A+ZdkIJ+vzZFZ2mWsDTWc96sQXfhl7BR69q6jxh4n0waJcQWjKbpsJGFQY2/Wu5UYR6HL7efc 5e48UeKJjE1/qLeWoz8o27j36VqaFp8urRT3JLTsTnLZJAPb2rzdDIYlYS5GMkd81oRa7qOkyY0q Vy1yu2QdVx6e1CS6IiTb3PULa4sLa2nK3KRG3XLiRQOPY1C/j3RIPC0toQZbl8rGqYIIbqc15YbG a9ikWWV5N55GSc+xrb8K/DLV/El2baDbaI6kq0rKoAH3sCqRVjKj1RZoc4UyQpkOvUe3NUIZ1kZZ F3TySAgKnzHnsMcA19c+G/2c/BqQ2l/rWrrdTvkSgSpHEoHqOp/On3Gv/DHwFqEll4T04XBhGDPF tZWk9QT3H1raLHfofO2hfDzxP4mtJBsXTLfOQ0qnf7rivQIfh58MvC1mj+J5ReXwILZdlViemB6C ma/8TPEniC9XyzHAqFlUImwsB0B+lcDJDf65dxwzAz3ty+yJc5y56KB6ntVWEeqz/E6x0uNdP8K2 Nvb2yJs3Iv3j0xjgVwN/d6zrV4t9dsJDbnhCcAg/XNdO3gPULG1TUrmAWwiILI+CyNnBBxkV6df+ GvDH9mPDBCIbjyvMZyeMgZPJosVzHjy+FtfmKSNZPDalQ/m7cDBHWtKz0iwtnDSKHYZbDHqcenrX qc3xDgk0eLTEVJ5vs6gL/DlRwc15g3hvxde363NxY3Ee/wCdWUZTpx+FD90V7m3bXtgkrSXUoRWy AoHP5V6TJ8VdMaGC3s4ndokClyMCMAYrxn+zRJIJ/MSUnIIPGwirX2TeGQDAPXFeTXzGMXofTZbw zUqrmlsXvE/iTUNa8SnVreYRnyEhXH8Sr3NcuXVboScyyP8AebPetCeOMoYYcKVGM45NUVSS0Ki3 hM0jnkgZH5159bNG1ufZYLhiKa0uW4LkxzuAwwBkY6g9/pXe+C7y7srzz71Ultoz5xVxu3N/dx2r JsfDU+pWm/DJcORuVVyc91r1nTPh5e2cccF/E6+aBtcnBFeRUzVLdn6Bh+GZOklyn01ZftL+CNC0 a3+1XyW5CbWhSF22+21R/LNZPir9o/RbR7RdMubO4YsTLJDEJQ6Yzt64z9PXvzXh9/8ABRtT/wBd Jt4wjsM1x3iX4bX3hgqtmWuUUBSwGME98V6dLPo1LRi9T8yzvgmWEm5OL5Wb2t/tMeJ7957d7CVY 0lZkaN1VmXPyjaFA6VxeqfHjxbBp82oyvNHE7BUt3+YqCeu4Gsy68LavEqhYjJJIAVwAASfrVxvB uvx26ztDDvOCUfJ4/LFdX12Z89/ZtM8c1T4ieIdevVvRqIEY4RSm519s10nhzN2RPIN/nZ3k5A3f StXVTbaa4MlmoI+8FQceprO0vXLa51QWixNH5g+XIxj3rKpipNFLLqXN7p6/pujaJeWckevwqrRq FQ7tqn0xWta6H4Y2rsto98ZGGUD8M5rMtvCeo6ksMMd0sQkI+8OPavHfH/iLxL4W1yXw7vjlSEZa QLjjtmscPXnJir4OnFXZ7frdv4eQulzK25l52E8j0G2vL9S8Y+EfB2qRWcUcxmnQNvkb5AfT2rwR /H3ihoiUkS1C5JZBngd65+5lmvr0XM0hnWcgtISSfyPSvbo05X94+eqzje0T6a8P/H+zju1tpLRx lyAAdzMB3Br6q8G+JNL8XpbyxOyiQZKtwRjqPrX5iKYbQsAvLEkHpj3Br1b4S/EKDwD4ilTVZ3+x SqoRD82wt1Y+xroIP0n1L4N+G/G+lNYaxD5kIIdHXAdfo3UA18RfGr4Dal8KNU87w1Z3l9o9yPkb aZyh5zkooA/Ht3PU/b3w0+Lfh3WDb2FnfJItwpKBmAztzkAnrivo3TbnT7qYwXIEkcowythlIPqO QRUqbE0fhTb6xPbw7WfyCGUtn0B5HI/A10P9vWTxlZpctklSvQZ9a/aHW/gL8KfFYuX1DRoFluGM gdFChHIxkBccfSvin4mfsMaz9our74dapa2sYG+O2nZmVz3VCRlSP9okfSrVQz9n2PlWwv1uFWUT fL0/GtWdbW5L2t1GHifnFed+IvBHj/4YXNnb+MNJnsVu2fynI3IxQ4PzLlfQ4PODmm23ioC8FvLJ kj+HvWimLlOzu9C0mdNiW6QPgrnPJ9K5f/hG57cPJ5ih4uCmMsfStgeK9MfzGyJGiI2qRgmpBqa3 w8+32+Y/XB+7U8wcpzADCRy0XlBfWsDWvMleJ1BO3j8K7W4ILOSuNo+b3+lURDazRbsbSRkA1qmS ebX9g83zW5G4ckAd6zbrRNeaKNobQyq33tpFepS6VafIyvgnkjNI1hJaAmKXAfn8KftWB5n4a+HH iTxVeTWNpbLZsP8AlpO21QO+3pk47V9S+FP2d/hBodlDe+ONan1K8iGZEUrFBwOBt+Y8epPP04ry CTU76BJPJlxjlec1Zk125u7fbO7nemG4x8lZTnc0jofcHhzxd8F/Bunxab4as7dLaOf7Tm3hEjtM ABli5+7gYx05J6k527j9pXwEkzWkTyLNySpAAH4dPwr85o44PJ+WQjrgMTzmsa60yNcGJ9oAO0D+ 9XNKhGXxFRqtbH3tf/tV6ZY74zBHckghcKVX8SK4bU/2rNS1KzEOj6elhdK4YSM29Co7YNfFs13f QqbfaJGC5OQRgeorn2vJhEYpI2EnXcvIxUf2fR7FfWZH1f4p+L3i3xNMLzV7iKd40CgIoXHrwOK8 stfHepRTzT3ERbBIbPHHqMV5aupyRtsF0oJUEqT6joc1FJqYkjNtGpcE4O3JB/St1hYoh4hroenW nxCjJla/lZGQnkLgY7dK07f4izxWv2iCSOSJmOZJByo7V4ml/tla1wrOTjBB6D8KrMnkmVSf3ZBO wDjP8qt0I9ECqt7H/9Lz1AWBVBg96Vixk+Xnb1pnO0h+DmkBO4+UOCK/0UP5THEso3D5g1G0xMGB zvOMUu8KAmNoNGCoDMMntQA8ht20jJzSN+6Zo260mDuDA896a43AnHPrTaAjVwGKJzipFLHPAUGh wqkOq9qZtcgknFTYtDyx8vygcNnriqd6kmRuXMIH61pREDHHGO/rRIryKVjXGBznoa5cRFNM6KTs YsUPlkLJnb1X3qy0Zk256LxmqqRObmJHztj6/jW4bdQ4jGcnn86/FuLoNVD9KyOacDjdQlg0/UfI mbHmhcD0LVDckRYQY3dR6Z7VzHxQea3ktbpB5crJxnpuB4qj4b8SrqNqYJ0MlwnDkfzr89+s3lyM +nhB9D7w+AXiiDWdJj0b5zd2aE3DNjaC7kgDnJ4x2r6MnhxgD7tfnJ8PfELeG/EsWowzNDE3Eyg4 DKPUeua/R3RNVsPEWmQ6hYyeYHUE8YwfpX4rxzlDpVfaw2Z+jcP4n2lLlluigYwp6UhiyvA61pzW 439OlNWHGeOtfnbkfQqNjGkj3AY4K1CU3IFI5HetmS14LDk1UMXJUjmg1gRQxKeD2FT7c/N1I7Uq oBz6VIqk4rlm9TaxE8asuXHWq7QHlQPlPQ1fOFOOtQuNqEEZx0rnrLQ3pmAw2yGP0rahOEVa82n1 Ga517yi3lxowUAeoFeh27ZUd6+Cz2hZ3PfwT0J2AVsU87QKCAeaaSDxXzUD0JicKD7iueulAIro2 jOBj0rnL1GOfatEQjm76MiKSV+nQY9K8E8YXFxiRiuVUYGfSvoW4JFpISMnAGK8Q16NJrG9VhvaE E/hXvZPU5aiObFLQ7z9nTX5X0jWdFuX8xrSdHQnqVkyNv04yK+m7e8hf5T8p96+FvgDJFb+Mbqze VsXke1DzjzAQQD+AOK+zwpQ8nJFfvGTVOaij86zGNqljp1mUnb1xVgEYyKwIHJ5zWxC+cCvQkcFi 5vwoNSK+eCKjXltvpUv3cHNSZkoG4YHasvW9Lj1CxkjZcqwNayE4x2qWXMiKuOOhrDEUFOLizSlV cXdHwndpJo2s3mnPlzbufUcHoK6bT5Gmj8xhXQfFHw5HpOsm/B+a6+YccEAdv89a5TTJmKBT2r8Y 4kwipVWkfoWWYj2kEzd3AZPerET/ADbWPaqQZWJBHNTpICwPTivllE7i0ZADhBnFV5mQIC/NAcjk 06RTKvTpWinYLHkPiSPdcb9pDHIFV9G2x3UZYjmt3xdbbQkyn7jD9a5vSpFinMrjIPSv13hDFc0L Hyed0bO57To18Y18mP72a9P08sQrOM8V5DoaNIGuEI2nFer6RJuWME5r7qJ8zI7O1BZwynoK3oif xNYUMT7QV6VrW6njPJrYyZf+Y4x0qwnPQ9KgGQQKlXjPHSqMi3GQCN1aFuQWGelZSjOM1pQY3bQO lBDN2PO3ipR0wagVspxVgA55qkxpj16cVIoPamIoI+lSjJ46VRQDrUg4pMYooMx5OODQV9KYxwAT Ti24hV6UGgEZ5FA54pw4oIxWhmJyOaODzRweKOny0AKCcc0m0Uu5vSigBAooAxS0h4qGBOnFaNv8 xrNHNaVrSL5+U+T/ANr3RYp/DNhfKz+cJFCr1VcZzwOuRX56RqBGK/XX446BHrvw51NmYq1jGJTh d24KenHIye9fkgNqvJEoyqscV8lndPlqKS6n9DeD2YKrhauH6xd/vX/AM26hz8x+6a0vhr8QNQ+F /wAQ9M8V6Mu2aKdULZwDG5AcN/skfeHpSSRqV+asC4tY2DE4wfUV4tOq4tSR+u4nBwrU3SqK6eh/ Rh4G8Z6L4/8ADFl4p0GZZrW8QNlTna2BuX8K66vxn/Yy+PcngbxSPAniAtFoWrs2ySRgVglXhSBg YUj7xz2FfsqkiSqHjYMrAEEHIIPQg1+g5fiva01Lqfxvxbw7PLMbKhL4d4vuv60H0UUV3HzVgooo oCwUUUUCCiiigAooorQBCcVzniK9urS1je0VmYtyF9K6SjAosVFnmkUFxqyyGOBlLqeX4wwrOHhL Vr4pHdqIguRuz/SvXKKx5TrjVOB07wlfWIUJfkevy8EVrReFtMVvMmUyv1yeP0FdRRT5Q9q+hUis bSAYijVR0PHXFW6KKXKRKTe4UUUVVibhRRRQZhRRRQAUUUVmaBRRWNqPiHQ9JUtqV9DbYOMO4ByB kjH05oA2aK8G8R/tM/BTwuJV1DxJDJLFjMcIaR8noAAOc+1eF+If2+vhXpm6PSbC+1KQLlSsZVST 25GfzoJ5T7tor8kfEX/BQvx5O+3wv4Tgt4xnLTyFiB2yMdR34FfPviT9rP8AaT8Vs0FnqsdpG7ZH 2aMKV9gTkfp/TFcxUadz95bi/srRGkuriOFF6l3CgfnXmHiP46/CbwmM694ltLbnbjzNxyfZc/ie g7mv599d1f45eLbotrnie5ZWKkiRsruXo3Azkda5Jvhz4mv55Hv9RF227rIWkb5upy3NNMtUE9z9 3B+2f8FZHeO0v5LnbwGjXKE+me35Y5615F4j/bgk8kp4Z0VN43fNO+RjscLzX5m+E/C8mg2a2k37 xgSSenXmu0Wy5+7TBxS2PonX/wBrv4s6sWjtbqOxz3tlxx6At0+uK8h8SfE/x/4qUDU9bu13bvM8 uZx5mfXnHHbAArkmt0Bwy0GEsAI1zigwaOcvtGOqokd4zyqhJBZjkk9ST3/H/Co/7Ee2RYolG0dO K7G2sr+5/wCPS3Mqg4JFdNH4V1m8AgjtiJAu7DHAP09fwoMzyw6A8tuymQxt6rjiudt/BUEV39ql us7TkAgAf419T6b8HfE00phuGRVKqwyWwM/rXc6T+z88gD6rsbBIwikj8TWgHzFbRQ4BhyT04HHF XYNLu7gs9tA77cnhSTX3h4Z+CGnQwO/2MPngKARtOfevWNL+D1rFD5clvEDwQwX+dZgfmzo/gjxL rA2Q2zRsehkQoMflXpGh/BLxLd3AjuiYowOSoBz+dfo/a/DzSbYIqYUqo4A4/lXRw6BYWoVY1UHv 0zQB8A6f+z6XiZby4lJJ5AUKDXpmg/s+2NtHE3ksecgucmvseOys4gQsQH4CrsYhRQu0AdO39aDM 8P074V2tuNqRiMD2rrLLwBp0DhnfJHtXobOc5BOKTfg4AoAx4fDemW2NibvrWilraRDHlgfSpS3P B/SmOaAJRIFAVBtUUoPX3qLtSZx0rQCUtg0zPvTeaMVmBNRR0ooAKXJpKK0Adu9KacmnbabQA4D1 qVR6dqhyO9SxnniswF1e3M2mFU5ypzn1r8R/j7+0d8Tvh18R9Y8J6Rcxx2to4EaiP52B5zuNfuHI jS2csXXI49q/ns/bs8P3en/Gm/1WWJ42uo4zGuDhto27hj6VMpWNqOrseN+IP2ofjL4lKwPrktom csEO3/0GvNtW+KfxG1OQm61+4kljGBl3OfyriUQI3lyqY2bpwetaY0TUZm37eF6EnGR+FYXN3TF/ 4SHxPdlnvL2cs3J+c81VeS6ClmYlm5yxJrr7Xw3fXMSyxxGQYwNoxU6eDtVnZVmi2qTjJPT8KY4o 4WUz3ShZXbAGeDgfU1JBY+eqgA7B3HAJ969atvhjeSAtCjt7ngfhXRWvwr1HKxYCg8nPH4ZpNlHg cGmiKcqqgKDzj1rS8jaRkAgDoRX0JafCJvtCNcxs0JOSuTwa7KH4QaFIj7wUJHyk54NYs0PkuON2 YlELn0xgY+tCaVePuPkk+ZzwMjH1r7N034Q2KspEivtHORwRXUWfw/0woYiiIVOBjjj6VpATR8UW nhLVbglTayCNRksBx9K0LfwNrNxIGSEBcdzya+6LfwBo9qFhWVmU8tk8VYfwho8bkqnmAfd4pE2P iiL4e6i5+aN1kXsemPwrqbH4barcwiNYXZPVV719jWllZ2w+WFRj0H+Na9tDEPnU4HYDgUGlj5S0 r4N3MzlBBJyMEngE10y/A+do901pGVUYbLbmIr6c4QBo1Ge9Qea24lcDPpwKA5TxLTvg1pEMSJHA Ij0L46Vv/wDCrtBtx5cpVxHyrAdTXqpZmUDP4djVCaOMn5Tye2KBHnq+BfDkeWSyjU4+9jBNSSeE tBEaAQKHH8YwCa666SRRnP5VnyIwG5TnA6DrQBzY0HSLYghMsOmac0FtCzeTGuR14q5LG0mSR831 qjIAh5+9VJktEEnzMNuBxzWTrGn21/pk2nzuuJvl5Gevsa12YucAdODSPZxuhkZvu/NnvxVE2Px0 8SadcaXr95ZSDiGZwp27AQpxkA9qfaybiXI4IwRXof7QGn3tj8Q59QuWDw3blx2wp4HFeaWRBDc8 dq6KbOepE02G0bQ3y+lKrZO7OD0wKjDc/McmncKVYL3rQzECgJgk9ehp8bhZSOSfTFRhdhKspZjz TGldcbTtY9T6CgD0H4YXL2fjzTJ5flBnxk/3fSv0zh8uaVZQNrsOM+lflz4GZpfGOnq7hlEqt+tf qJZFZIV3nJIXafbHSuSqdtE0YE2zB84KmtoYdvN3cmsNBtbA4OK0bKVXPlSnFcxuaEe52yx4HSnQ srTbCOM8mkVCuSvQdKltxtYd91AF0qilSg6VICzNhTzUA3Mw29RUqI8fzMeTQBeRd6DzR070BjjH WmCRtvH41PAct0IzQaFuCNUj3kfMamxxu7jsai5XC+lTRgk5P8P61maQHmRQuFHNWoHwM9TVdojn jrU0A5wwpSKRz3xA09rnRoNRGTJaPkAf3T61haLd+asY6DHPsDXq8Sx3VtNZyKHSRShB6nNeH2CP p2r3Om7/AJYZMLnvXxuf4XVVEfofBeO9x0JPbVfqetwKJAAK1BbAqc9qx9H3SRk9dtdcsB2ZHpXz R92c9Im3jpTUlKfMee1at3AoALDmsqUDacjGORWkBM9N0vxHJLobaNOxeP8ApXguv2yHUpYyDlDk D1BrtrK5kVx2zwKz9asopGa6J/eEfmRXfCvI4p0EZXh9lPy/8tAcbfSu6hZgp3jNeU2l6LC/WVvl GcGvZIfLngjmHO8Zr6jLK8pJJn5txFgYwm5IiOAF4zmkVJGbjpVxlI2kDhetRZbeXXkV7p8oxEDA 4apwmQT0ApvzFcmpFc9xgGgkcjYGTR1ORSjHemldpyOlBmP3qQRnmpEXowNQhVyCBzUiNg7QOKAL IILZfipslTleRVfaGUDoalAIAU0AP3YOaMvnB705AACGqUOpAJIoAVNyj2p6SDoKZvDcA8UoVT0N OwBvBOKcpGcYpoBQ4AzUh+Xr1osAmwNz1xS4fORwKaAwJI6U7JYewpATAY96AXVjTEVm5zjFSs3y jjmszQRslcP3ohAThhmkGTyeKcA3rk1fKZlkuMbRShjj1qFQQcmpw6MMGjlAYc5yOtSA5GamVFxn sKjIBORRymhLkBQT1FR7iTkdRUgj3AZp4VQ278KOUzE3MQGxUgIxwOtOABOKeEVaLgNXgcnmnEkD pUbMueRTdx6A0XAeWkYYqREYjLCkj4PNWcgn2pgMAH8VKWCjaBkUhChiRzRgEc8UAP2jaOKiaFi2 cYFSg8BcdKlDHAoArRQru+YZqYgAHHNOyaaMDIzQAwg4pRkDBpwAHem4J780AHy+lOGOuKTtjPNI D2oACdx9qAi5zSqcdRS9RQO40cGlyAeKDvOBimFtp20BccpBOMYoP90ngUCMnvSY42jk1mWNwpA9 qecE4pdoAFMLAUAKeOlApARzUiKTVJmZznih2Wyi4yPMUce9a0KmKJIweAKztWYG5jjPKjk1pgCN Qq8rgVRoTmUZwBSdOag83I5FSLyM0GYuGJzSFTwTSGTBFQGRi5NZlJk3AJxxSck5NReYSemKA7c0 EkwAC81EWBPJqIybvlJozgAYzVcoCbQzdeBT/wCL5eahAJ7YqXcUB5xVALjB54pg+8STxTt4Kgsc 1Vkcj5UGc0ASlsnjml3E8NTYUbbinkHOGoAjOFfPWmsRu46GpHC1GRn5TxQAm4LStgDJGAaYQOm3 AFDKzjHTFBoNAIySetIuV9wKk28hTyKax2DB7UAQyEMc5wKVXUHLHgUw7c7jUTMGQjFZmY5W3uee BSMBnJOKiPy/dNIzbcZp3AjYdWf7oqB5t+FB6dBUMssm4qenpQoKkMRzVmhP5mOCM0FlJHcVGu4k 1JtCgr3o5zMikP8AEvUdKqhWdyx4JqYjBIBzTW+UjceTWYC7lZQp6rU0eOQRjFU2yMJ0BoDbEYbq AINRkR5QsfQdapx7TxVd3/eEE8UuSDkdaB2LZHy4PNSJHjl/u1VSUhhu6d6qXd15ku2M/KvWgLGi +Oi4qJ5IYmBesd7hgQM4xVV74SMCWzigLG3PchYyITuzVCaaQDDHkCsOS8MUjAOAuM59K5q78UGN tpgOScZoEdDf6h9kh8wjcWyQPpXFf2yt0xkHyh+g9PrWdqOrz3bGMnavb8awyz/6uLgIQRWgHQXN 7eJHPLERJsUkAdTjtX5r/G/xxf8AjfxRDai6VrWxX5IoXYRAt1LqeGfI6+nA9/r/AOLHjr/hDdGg nm3CS6LKgQ7fmAyAT71+a8DvNcS3cuCZ5GY56jNb0omVQv77e3QG6kEaoMZPAJ9PqTX1v+zp4J1T TZb3xdq9i0KXsEbWjyx4LRv/ABJn145549M8/NHg/wAPal4016Dw5pFr5++RXmkIyI41Oc+1fprZ 6SmlaXaaXYRlY7RFi2ZJwEG3j06VcpWIjTubNtq15Bay22/d5mB+FYHiHw7pXivTH0nVbeGeJx/y 1jDhfcZ7+9aYhZWCkYNSOYYBvu5RFH61lLEKO500MLKbtFXPlDx7+yLb6rMNU+Hmo29ndbs/ZGVk gx3wcsFP4YHpXx54j8NeMfADvJ4t0mfT4FuHtluGRvKeSM4IUnGc9RxyOa/W2bxXpmm2c5hQXLxL uHzBQwryjxH4x03VIpY75UMc43eQ2JAW552nr27Vy1szUVfc+mwnB9WortqPr/wD4F8MfEDWTbLp kCi/+f5IwrBmHoMCvU9L0qTW79I9U8OzCK4GCZQFAbp1OM/jX0LbaFrLeV/ZWiRjOTu2JET36HGP wqbWvDHxCj0GfVbXSfNljBwsMiGRR/eCj73/AAHmsVmE5bR/M7P9VsJT/i1te2i/O7Pn2/8AgJps DmTTLjyWOSzFd3J6D8KwLf4JX1tIxOuxo56Lhl2/r3qp4t1/43aRqLyXmkXVgEG4BoS2R/eGPWvJ Lz4jeJL2ZhqGo+XKOqhdrD1DCt7Vu5z+zyuP2W/m/wDM9xm+FFlb2hh1PW4icYU7c/gK6PwDdar4 AvJm8Oa6kcbpsKldwNfMv/CYXt4sT35EoRsRklgfqTXR22uxRbZbeJ5PLbcUXcc/jR7Kp3B4rAx/ h07fiz7Tt/ib8Tolb7HcWV+VOdtxGdo9wYyuaW4/aE+IXhwm31rw9Z6mJeRJa7oce2CWJr5EPiK/ uw0sK3FsuP4jwT6AVasfGGqQss0UB2RcASAMC3vnmj2VRdSfb4We6/A+j4v21be0nZb7ws8KJ8px LnB9D8oq+P26NMCsp8JmYAY2i528epyjA18x38ml69I82p2LK843MseI/m/DIrkR4Zsbi63iOS3j xt2g8n8uldB89U+LyPqTQP2uvDel/ErS/ibc+HLm2uNH3FLaMqwk+VlVd7gYX5uePw5yPoPW/wDg q/4xa/abQPCVtDYlQFW4kaSQNjn7uO/tX5zxeDNDlfmORpWIT5pT+gr1zT/CWgaTZqlpaJM8XzuZ BvYMQM4zXkZjw7g8VNVK0btK27X5Ewxc4KyZ63r/AO318Y/H/h+7trPXpdCd5WZI7WHbIAMgKJRl sEc5znI7V8m+J/FHxf8AH09tea9rusakkSsuXupTgMQSMbsYyB2r3fR9PvZovsGkaX5qJlmYKAAC c/e/pXVweAPHNxatLBZLGGGVQsASPU81lhMgwlD+HTXzV397uRLE1Huz45t/BOuXNyn9oJKQOcSn d8vsa7+w8Em2Tct0MMMBVXLCvp3Tfg54juXM2r3UNqrrk7ucH+7gV1Nr8KdGtWV31IrInB8uPn8M 1694mN5Hx4fhzp7+W1xetIF6grgnPfjpXU2Xgl7a2aKycybencge5NfVtp4H8NwXEyFHutwA3Pwc /QVov4bgiA/s+2SJSQrFuc/SsfaIVj5g0rSr7SodltG5ujyxHAPtW+th4huLXzommQ5J2AhcGvcb 3R3gk8uXYw9V55/Cqa6LCzAlSuBztPU1aqaGMoHnmkeDbu7h26lJ5Kj5sO2Tk12Nt4V0CFlV7h5G jXGF6c1tR2axqdyck9CajMMsQccKc8DrT5w9mQ23h7wlCJfOsZJlkwC27nit2y03QrNkWy06MHqr MMkVzF0LnYUhyxxlscY+tWrRrqKJGy/UAe2asku+I/A/h7xRpFxo2rQo8c/Ifb+8ifsyNwRz1Gee R3r5n8Zfs8po8qy+DNUa4iEfmGKfhmYdQpHr719Ri+lXhGIPc1zs+mxCVp8nDHJGeKuMrCaPz11O 21Xw9eyWer2j2NzGQwbBO3I4BYetew+BfiRqenaSsWmOiXTsWkDEYkA9RX0pfx2N4PsVxp8V2kvD b1B7cZJ5rxvWPgj4dunF1o18+lSgszZwwJ7AD0zXQqkftEeykXtL8bp4z1l5PF0EENtaIodly3B4 wM55OOMV9QfBv9j3wd8dNettb0aa+tfDVm4e78+MIrrgfJFIuCWJHPp/Plv2RP2OfGvxF1+41bxW /wBn8MfJHO5TabhMniLjJ6A7sd6/RX4+/tLfDv8AZN8L2nww8B2yXPiCC18u3hQIY7QkERy3IyN2 5hyv3u/1/HeNOM6lat/ZmUpym9HJdPJefd9F57e/gcByL2tXRHUfHP4v+Ff2XvhhceC/hjZRw+IE hjito4FRvsrEYWWccZG0HHfNfgrrHxh+Ii61f+INU1B7u8vZnlf7UTLhpDknBJA9gOK7vTvilrvi v4hHUtau31Fp5XupnmdpI1EhyyqG52rnAB6V2+p6p4P8Q3M9pHYW4lmIR2UZZvTA7Y4r6zgvganl tHnnaVSW77eS/rU5sdmbm7K9jz7w98dtMuRDbeMVktJRhWkChlYdmIxwa9LTxZ4TuIPPs76GVQSd oIVsdjz1rita+BROoCK0vIN7J0cEnb6YHpXhOoeAvEHhq+Yzwicqxz5TEqR24xxivramCgc1LHS6 fkj6uvPGvhdLcAgTbhghRnA9c1xmpeM9BaRJ7W1LRj5WOME186x6pqlojgBtpBBXZ0+lQfbLq6g2 M5Kqe3B/HBrL6tFbIc8wnLt9x6h4tv8AQ9SjX7BZxnc285+bHbFeVS2Npbhbq2iWKWJxIgGOGXn0 rRSITlYwuAOrA8VYWzRZWRFwqge/zVbp6GPt7bf1+B9Jn9o5NS061/4SCwJvtiiZ7fAVmXI+6eme pA4HbilT43+HpxIDFNp64GGlUbfwIOf0r5r+wM6vzzgnjjFVJLd0RTI3m7PujvUvAU5atCniGfaH hr4p+E9UsWt7jUIjeqx3M7bN6nG0KG6n6V7v4X1fwRfKllc6taRXqqjTWjuodFc4Utz0ODg98V+U l7ocs4Z1sXL4zlDjr3GK5+TQfEUG393cRCbgzZYYA6Amsp5bF7MlVz94PDVn4ChzNbRWc8MMgysQ Qt5i4xux717A3xK8P2aI11YSJyQrqigEjryCD2r+cyWx8amYNNd3eU27TFO8aOBwG+UjsOa6JX8f zJGPtV8sUJLRP9okZlbpxk1wPLJdzoWIR/QmPijYHb9ivobdWIG2RlySenevMfjP8Xn/AOEOvr/T wsv2BfnUo33wCec/57fX8Ql1zxxn7PBLffaAys0pZi25Tkc9Rg+9XWuPivczvNqGoarIsmBJ5kjt vC4KhgSQQCBwfSsaWRvn52wddHJ+NvEOp+L/ABHqevAi3e6kI8sdNoNczEbmIRup8tk4Zh1+ldo/ hPxPqNwZpLdo5JCTuKhFyevFOg+HnieSZI7r5BIDgqh7dvxr6SEeU4Zu5xc0ty8yDzVjjzkg/Mee 1OcPFbJEs2QOQTzivRI/hdrl2SARb7QQyyL83HfNZ9x8N9ThKvczCOIkpuPIbHtVSVxcqOENzsRc rkrzu7E1lz6s6KywL+8HUDtXokXgbQo8SapO8rocqIyfLx7gU82Gk6fI8mnWoiDD5nwf5VPsx2OG 0608TauG+xSPEPKy0n3cY9M8k1vWWlzRRo9/cSTOi8gscqa7bQdN1nxLcRaboUIkdiRuY+Wigcks cHge2T6V1fhv4eX2v+KLnw5rU/2NIYi52H95kDI2nuM4quUUpWPO4vMv3/s5M5b7oBO4+xz3rc0r wvq1+6x2VvnyztG4/IXHUH3rYfwvb6Jrs2nNM6NAxIZzkgD+9jvXQaR460bwtpcmmyyFpzKzrJty gz3+tV7Tl+IkztK8Gxxag0mss0d1ZtxGpBBPXk12F49jaQrq7xwpNZ/OhQBZGYemKw9OsvHHj/Vl vNEsXdbhiFukBSAFeCWY8frXt+n/ALI3irXil/rHiKAWykH9xvaTPcBWwP1rzcdxDhaHuymr9lqd NLDVJdDxDWfidpupaeY4LRxJOCHZui5PJHvXlGsfEZAq27Xsl8keVaNDgqB2yTzX2rrf7Kfw98Ja Rca34h1K6+z2yF2Msm3J6E4UZxXitlpvhiylaLw5oIvI4G/1oUM5U99xBJrynxBGfvQ2+46PqLXx Hz1ZeP8A7E8WpWtpsCkgJID9706V3Wk/G3x1IkdxcSNcxlztO3aFT+6dvYV63eLpE8Inl05WuCch JI14P+7jGapXENxLA0NlpaIdudyoqgY/xrCrnEpR5Tuw1CMZcxkyt57SX/kiFJSOOwz7CrGn2F5J kBcA4xjrWAbvVIAUeJRFnOD6jpXdaJqVtdJ5DyotwBucDgKK8mddvc/Ucnx8HFJsji8OG/dIwvDZ zj736V654a8L6fbm3sp4PLDY+Zx+ec1z2nXEljKs8abpCMR7eRz3r2DTdWstShEU0i/aNpUhuCSB 2rxsbXa2Z+l5JhqSkpHUW3hqwssCxZNo74zXSwpEFjjdA7RngkcVyNmJo2QQMSo64PaupEizDIzt /Kvn6k5dz9GpRjtY1F3nO85VanWw0+/Uw3Y8xXXr/EPSsyOXYAp+6eK6GwiRvlQYPrWUcTODumbV 8uo1YOE4pp+R8yaxFeaJf3FrqKFI4mJRwhIwemSOnFYd1qrp8lspkkcZBx0zX2vJpy3No1o6ZWXA LYyR9K+bvifqXh/4eXlsutWslpYzuyi5RBInmbd2GAO75u2B1r73Kc3VeKjLSX5n838a8GSwDdWl rT/Ly/4J4JNbajN5ySQ+aT7dKjs9GE5jhmj2sOS23n6ZxXpFh8QvAV9JsXVLWAMvPmMqZHp1rq9O vdGu1hk0+4t7hHbC+WytkenWvoeQ/MOfzOGtNQlgCNbqCbYHGc/rXinxR8H6740vZNV+0wWN7NtG zBZWUepr7Sk8O6feuI1iWFsZJAAB/KqU3ga0KM022QnoDkfrWlF8r0MqtRtWZ+YF38MPGEO9TMk4 QkMEBAZR2UVyk+g67p7BLzTbi3OcDcG2kfWv0+vdAFqm2OIx7TjDYP5Vce1hjt1tpokuFYfxKCBj p1rvjiHfU8t07O6PyoutZaAJbu+3yXw3yk5HpkDAx9aoajqrzOr2s4DuoyV+bIXotfpmfhh4N1KC aC90qEwzZ3xKiqC7clhgZ57+9cs/wH+F1vHcPDoqqQpC4dxgnjIOcg+h7VbxUUP2Z+ftvrEyXsTX dy8Vvjb5eflB7jjoDX2H8Ev2oNV+HctloGtwNcaHI3kLJCVLxiQjB+bqqnBwMHGcEk4qG/8AgL4W giIs9KMcrD5SZXYPnsdxNeGa74IHhu5kU2rx26FQF5YKSccE9ck8e9WqqZLiftz4H+MGleIPD63t newmKUnDyyBCfb5sHj/CvTbTWNPubYTi8hlwAzFJFdRn/aBIr8S/htZy+MbebQ/tTQXFqmVwzKvT +7XnvjHxL4++E3iz7BZXt3a/ZHWW0kRn8mRupYZ+V1zkEHIPOaOcbgfu14w+H/hvxfaRQ69osF7J BzG03OAf1ArxzXvgZ8PYdL2R+HbG2ERL74oFZx+JG4j2r83fA37bXxX0jxNaaprlxNqNq6tGbeVs ROccfLz09QBX3D4C/a+8FeNIoV8S2Fxo8knylwDNGTnkYA3Ae9HvEHzv4++B3hLzJL/RIpNNkG8y Fd5WbJyGKEkKfQLgYr5ru/BGraXHI8V2t7v6bcoVx2x1r9mo9O8E+LLY3dveW1zaXAIjKSKA3rjJ 6/yrltS+AvhPVIJYmgXbIMDaMnH1FCqtbisfjfKdXsI2e8t5YkU8t95SB781NHrMFziNUYKeNxBH Sv1ef9kfQrhB/Zd3HC0w2tFPG0mFP1xzWBef8E/nvZ2a01FbZJMABYjgZ755rZYhdhcp+YC35kRQ x5jY1cjvndCjAn/a9K/QO9/4JnfEh2B06N0VCVJEnPHc8Y59ia53Uv8Agmr8dNMto5tEhW8JzmOS Xac/3sjgj1H481SkhNHxMkyFMlA7DvViR8xqMoFx/wACr1L4jfsyfHn4SWNxrPifwzK1nb/x2xEq kE4ySOQPwz+HNfO9xrMttIwvUFlJGAWjZWJGfXjg0+ZCOpdVChCA+OR6iqkm2QZjGCPbiuGk8X2x 3iGYSSHttzWrb+JJpooVEJIP3ivy1JmbEtm8nlyIvmHOHzWzEul6bIDd6cJYiOh4NYserWrOu1/L wfnB6VvNJBeAbp1eN/u1djRHq/hjTvgNqt0w8WWwjUIGXaThmI6HAzXeWfwq/Zz1QFtP822U+s7h efr2r5mkFqSuxAEQ/MenHtTUt4i4nBbGeBvbqfauKWFvszvWOa3jc+kbr4Xfs2WG99Nj+1ywqdyx Syklh7ng1xlt4V8FQhvIsRHExyVwSce+a4DTte1LRjG9psyjZ2uOGHviusb4l6U8IbUbF1nc8FG4 PPtzWfsKketxSxUJbqx//9PzxgA2dwK08BONpwRTdkbjb1pSBhQBgr1r/RQ/lMG2lM4yc0pO5ee1 KrHeQBTQNilj1NAEZbHTv1pNzFMKuTmkZMfvC3XtUm07gQeTQXcbu+Ty2yWx+VNQblCsxyDTm8xW OTjdQTzjGAOM0BcQEqxU9BzT1kfeVydrDvUTLtBC8M3OTUjqfKEshxgVlUjoa05Iypkna53I33WH Tpit1JhdSnjDL3rGcjJMZwvUCtKFmUL5Y5HU1+OcXr33ZH3+Qz92yPPPijawzac0nnGS6sinHor1 594EvYI5pFRQAAA2TgEn0r2rxpaQ3OhXN28X71E5b2HT64r5S0G9Fheu0hHluMnJ9elfimY1nSrH 6PgKKnTv1PpC8Q2gZ4Iy5cZwD0NfbvwA8bRalYvpMqGKV41yG5IC8AivgSx1SO9RSz/vVXuev0r0 b4c+N5fBWvQaheM7WjMUfZ1UN6/Spz7LfrmClFbrY6Msx/sa9ntex+n8sJ27hVLpUfh3WrbxBodt qttkw3K7kZgRuGcZAPNWXXqPSv5zqUnTm4SP1GnNSipIgJBXiqjMD8wHNW1ix81Oe1cDOOKwNEjN Ktn2pwAOMcVZwW+QjiphA23bjisZ7mqMuQYYgAk1TkSbIVQeRWtOh3Yx1qB/Kjw7DkCuepqi4Hie uX8NjriLg4Zgc+hr03T7mKcAxn5WrwLx/qCDVBFDJk/xEdgDXtOi7FsLe4HJZAePpXyGfU/due5l 8jrWyq4xURyRnFTBSydaYQSRg9K+QPVE+faKyrpc7gOtboTKnPbpWTeoyjp161mBx8qyYaM8qc1w /iRLGDT57U48yZSDxyBXoczbQTjGDXBeJrYSkzqw8zB49RXrZe7VEclY8V+EedI8YvcM3+rA2D1O ccfhX3UkyyIjJ6A896+ANPmXS/Gujru27rlQ4H93pg1916Zco0B28j3r904dq3pWPg85haVzdhZl 6960Y7g5CjtWFHPn5V7VpRMHHoa948Y2hP3q3HKHUFu1YqYHB5qyJNv3aewmbMcn5VciYEcGsVZG xg9KuRyEdD0pw1MmjzT4taLDqGmR6gzHzLYFc9gD7V882edu4cDp+VfXut2Vhq2ny2uop5sEuAyB iu7HbKkEc+hr4/8AL+x3lzYoSFhldQCckDPFfmHG+WT5lWWx9jkWJSjys31fHJ7CrCYI31Riw+F9 KtBNhJHOa/OD6UtbwQAamidgDuHy4qkf9YD2AqwJQygY4osCOQ8RgSRsrLhBXCRxr5mxOMjj3rv9 bilmidVGPT8K8/G4nheQcfSvrOGcXKnVUb6Hn5pSUoeZ6F4ZNzbK0fJDdM9BXruiS8or/KQM/jXj eh3EtuY4bgHngE+tem29wbcRkDlutftNCfNE+AxEOWTPYrGTA2k5rajxwAcZrgdNnkmRRnGa7G2Z lAUndW5zGwoHTOcU/pzUK5xmn4I4zWhmW4jkZ7VpwYDD1rLiG4hSelakBwDntQBsRnjFWFc5xWdG xzzVyN/mxjNAFsGn0xeeaf8ASrTAf7UKTmkHIxU8SZINQAhUtT1iB4FakFmzHgbvoKxLzxB4W0y7 FpeazZwTMNyo8yKSPxNNAWvKpuz2q1a3On3UXn29zFPFwNyOGHPuM0+eNU5HIPStzMoHC/WmA5pz E00Z70GYuRRkVHRWZoSUHpRRQBLHWlH+6ieTacKMk+mKzk4P0qfUJL9dLm+wKzTbSAFGT900MTjf Q+Ofil+2R4N8P+LR8NbK2/tBJf3F1cLMoVPMG0/w9V53A4A9eK+O/F+mjSvEM8EG4I+XCuBkD044 r49+MmleJ5PGuo6ksTPNPcysGC7iSr85wMd+Rx6V9meLNct/FEWleJoSM6lbJMxxjkqNwx7E189n EU6b8j9X8LMT9XzCCvZTun911+KOTZtwGaybwZjwvarjsSM+lUpAZBgV8oj+njmrmOf93NbMVmgd ZEI6hlOR+or9hf2O/wBoy28baJD8PvE10X1zTkVI3kODLGBgZ4GW9cZx0r8hpFVZSe46im6Rr2pe FNftvE2iSGG6tGBDqcMvPzYPuOD3weK9fLcc6E7vZnxPHHCVLNMI4WtNaxfZ/wCT6n9ONFfM37N3 7QOh/GfwnAkk6R69YRpHdw5OXYceYu4DKnGeM+/NfTNfcU6qkro/kfG4Kph6sqNZWktGFFFFanKF FFFBmFFFFBoFFFFABRRRQZhRRRQaBRRRRzhYKKimmht08yd1jTpliAP1rjNY+JXgLQQf7V120hYH G3zQzZHsuTS5i7ncUV8s6x+2D8HdLLLFeTXTISDsjIAI7ZP868a8Q/t3aalvMfDegtIU5VpZRl1J ABVcD9adxn6F013SNS7kKqjJJOAAK/I3X/22PiZqaSR6RDHZKeVIRdwz279K8R1j46fE3xDvGo6v PscEERysikHsVXilcuMLn7fan4w8L6NH5mqapb2y5xl5F/xry3xH+0Z8LfDtsZ21Vbts4CxdSfxx /KvxXutb1PUlU30klwV6b3LfzrEeC8upmcts9hRcUqVup+qviD9t3wlp7NFpekyzNj5WkdVB/AZr wrxL+3B8Qrgo+g6baW8Z7BizfiSpr4rtrMqCTktjvk/pVtLJBlnPJHAHH50x8h6rrn7SHxi8UKY7 7VLiyjdyzLFLhSMYxgKPbpx+mPI9U1HW9fbdrt9cXz5J3Sysc5PpnH4dOnHFWI7ZB/DirCQAHLcD 3oJehzUejxJ80cYyOnU/zq4tqwGdmGFdGIAxGD+VaFvpEsxBijZz7DNBdjlobNXfLDmr8VqkZ/0d FX1xxXZWfgnxHfSkWlhM2e/lmvStF+BviXVbaOeVhbLIM4I5osTKVjw0vEuUbCgD9frQiIQFtjuJ OTtr660L9nlDLs1GH7SAASDxj8q9m0X9n3QDGpks13RnPpx+FaWInVPz+trO9lj3W1m8oX721TuF dFpngLxFrLyG2tXhEePvDBOfrX6XWnwjtYgWEKLzlvlGSfwrsLHwFY25UyoDgY5HaosjPnZ+dOkf Ae/1C1El1KwIOHwyqVbPTkHIxzmvTdB/Z+trUkHfKp4JyD9egr7rg8N6XAnlpDHtHtV+O3tbNRHD EqIOAABxRYhVD5d0X4OQWcZgtYVWJ/vqR9705r0zTvhlp0EaQyxIAo6Ba9a81ewFIHG7d3pAcnb+ DNLtQqqgO315rei03TrdAi26fl1NWmbmm5oM5agkaRHMaKo9hVsTjGAMVWzkdcUzfg8DFAE7MDUf vTQaC2KAHUuTTA1LkGgB+R2pCc00HNBOKAFz2p+c1EeORTlOKAHj60H6UfhQfrQZjgcUuM8mkUE9 ak5FaAJRRRWZoFOA70gGaf0qkzMKawp1BobNCPGOKUcc07HrS4zUgacDEKGHOOtfkv8AtvfD0a74 u07Voi32hlKnJ+VUUnoOufzr9bLVC67B8u6vzr/a/jjtZdMui4+0OzZQHnbWdQ6cL8R+bunfCmyi uVaWPzPVmroP+FdeH+sqc56qf6V01vf+YdxP1NPa7G9h0HbFZne0NsdH022iWCCEDy+hNaEekaaD ue2VXJ5I71HbyDHHfnmpPM3HG7FZMy5TWAt7fEcUYVMdMVAT8uABhT0HFQpIwwqtnHXNOLqVyec9 KnUOU0YpCYxk8E0siGXCrgZqhDOFcbsBa04dsrF0HAqxj7JpbdipNaBkEvCjGO9VCrHA6mnRF0bB HFAFsSgHa7cnirImKEAc+lVeGOSv3e9ToFdcA4NBSJCvUt1ParEG5R0wO1JC6qCJBnPAqzuB24GB QNFlGbG6l8nexdzgdhQm449KkAfdj0oGPjtxtwG21G9qyqW6mkLyEkHpVzzw0QDLzQBjSQ7l2t1q kU2McL8vrWvMoGSPvGsi6kEfBOTipkRYyXiCys/aqs8av9xR9ashg5LE49qZjcpQnGe9EQscwC4d geue1PdWkj8sthW4qeW3e3c7nyD6VVJKEhT8o55qucLHxJ+1z4SFtDpfiRWCtdMbdk7bYxuDDjr6 5NfH1nIygDP3q/Tn46eGLvxZ8Pr+0tkMrxFZ8ADIWPlsE+1fmDCLi3YRsuNrEEN6CuimznqI31l2 Da/zZ9KmXcMHoM9+1UYnXexK5GOMdqso5OBJyD0HtWhzFhgwYFSM9z04qONB9oYs4Ix0Pemb1yQV Kj86jMsEILz4zkbe2TQB6T8KrWS58d2IRR+4O7OOMHIOa/Se2YRGO26FVAr5Y/Z+8GWKJP4qkAe6 CgE4+65zxg+gr6pg2PcgPmuapU1sd9KNkbqomCepp0EcZYFeoqOVljHyckVNbMhIcCsDpNaNGVSC adCGBAxxSYR1GPxp6Ou4IDigC2u4HcKsx42nce9MRSuGA4qcBnABwuOtAEgZA2B0qymdu0HpVUpy FQ5FSQkFmXnAoBI0OgAx+NWI3BIXODVUb3X5e1OVAGzJxWZcGXmyue+afE2wjf3qHIbgHIFNZN2D u5FBfMasTHzBIh+7Xk3jmyOm6vbanG2Y7s4IHBBXqa9QgDHHt1rH8aaCNe8PTID5U9qpkRj046jj 1FefmOF9pRlE9TJcweHxMJ9CHwlqiwnKneso6HsK9Gt75XlVQPv/AKV82eBdda5kkjdf9SdhJ6Zr 6E0yVA6SMBtHNfnU4OL94/ZoV4zipRNq+iEgLkcLXM3ELbueBXbvPbyx4xkNXKX5G4DtTTIbMsSe Sw9qszqLqAhevUfWqb/KfWvRfA3hw+JJpbG1XdKsbNzwPaurDrmdjGrKyufOmsQzW826YYwfzr1f wnqaX+lIH+VlOMegrhvGNtPp161ncfejYhlPVa0vh/cCWOaPbhYzgZr6LK52lY+O4lp80OY9KJYH A5BpQSBjFNVyPpSh9xzX00T85ZKASvTg04dPemCXnHpSOxUZTmrYEhHG88U7IIwajBMnDVL8gOKm QmIvftTipHI7UFDsznFIoZj1q4kExLMBxg1JtfkdSKYp5wT0qQbWY8kEU7gGG5zxT/3YAxzUZBGc c0FiAKLgT/KB8vWlhJ+bdUKjcMinsCDgc5qALYcA804AHkmqqqScZ4qQKQTzQBKCRkDinY4xmoS2 fl704B92Oi1L3KWw8SbeT0oEoJIzxS+XlcdRTPKAOV7UPYFuWVwcDPNS496rorZzVwLkDAqiRoA5 96csY4GKcFIOM1KpOfpWZSRIqkcGjywOak3AjIFCgsvBoKFUAEZNTFMjPao8BfvUrF8cdKAEwAPe lMchICmnIjEYxgmpPKYMBmtDMiYKTsPUVNFDkFiOKVVXJ3dak80qPl6UANC88UoA5pokJNPz60AN A60hBJqTIHSkBHJ9KAGgFT1qUNk81GrZPNSFVzwaAG5O72pSBnpQSOmOaCDt680AKxTgDrSDrkUw RhRnOTTicYoAXbgnPehSMGjPOTQcY96AEKk89qQnJG3ml6cdaXAHFZgOfPBzQQGHvULFuq00yMOC MUAXcAKCKb8u456CoFlAUhucVH9oRhhetaGg/rIBng0pAJOKQP8ALnFRu6r9TQA9sdzUbz7SUQmn qu5QzU/b8xOBQBymqb4riJ5jhWNbu/oCewxXI+IxJJqlvHuypOQPpXTbxtTIywoAnYjqadvYcL3q IHcelOUkHFAExwqjJyaYWAXcKYvBJzSUANySeKQ8Dk807IyQBg0g4HzDJrMBiqxByKApU8HNBOTw MVICV60GYh35ypoZCV2k9aUuFB4o4bBoAgdedg6CpvLUAHHIpwAA96iOScelAEwwBkcGod4AIf72 eKa5YlQKV9gPPJFXcBGycYFPcoo3MaZx17moGVyRzxRcB7AkdTzUuxVXJNIdyJyelRM5OB261mVy j8kYFQE73Iz0pquTlupFOHyguR0oDlIJSSpOMAGmNjAAGBjmmebvbc3A/lVO5v1EvkQnf6mmSS84 YjnP6VWdjgEnpUahs5LYB7U4EHpQA0Mu87hk04sz/KOopfLDEYqQqAd4U/LQBGARhmOMUr8HcTmo 2lDnaBwKhEhZiR0FAErNt+YDNQkjBZup/SgvuNRSHtQA0sWOc52052VEMh6Co2zjOMAVnXLSSDyg enNZmYmRIxk9aRyQAT2qNmWCIyMegqqbxLgfIeQK0NCV2LLt5+tVdqIAR1xTizKmTVG5nCxMgzuI oAgupucA4JrDuJJIo2PTNWMsdo6motSZEh8scvQBzM11JI3cj+dUriaNIyzKEPrUl2zW0eSNpPr3 rGnnWQqo5B6j0oAZ8j5k65/SrVvZNN8w4zxVXO3helZ3jHxG3hTwVqmuQIss9tFlFbldx4GR6AnN XF3diZSSPgn4/ePrrxX4pn0VpQsWkzFI1jOYz5eV3Eg4Jb/61eIwSIk4G9UXB69KyNQ1CXUdQn1E IzXN1K5MajO5mOSQPr0/SvX/AAR8F/GXi27tLrVbOXStIuTt850O/g9wRwPc4/UV01qkKUbyZeCw lbEVFTowbfkfU37LHw8itvD03xA1GOS3vb8tBBuI8t7dcEOq+pbufTjvX1BeX2k6YpaSQzTN95Ix uI9t3QVzOpeIrPQbSDTrWSK1tLWNYreKNcbUQYCivOL7XdS1mR2tylvBJ1+Xk+9eFLGTqP3T9Gpc LYfAr2mPqLXZL+v67nok+vSS+YqxfZ0PCqPmbHue1YN/4X8Sa3EkswiS2HK73xx9PWubsRc2kZhZ znO4Meufaugg1O9dHZ3MkqjIHp9fWkoN/G7nFiOKqVNezwdJR82dTpHwr0bykm1S5mvjKoBQ4jCH 0G3kj6129tovhPw7E6Q2NtGuMncqkkj0PXNeVz69rM0JFzckY4Xy8rgHtkdao6WLmWXy5Nzs3PzE twK6oqK2R81WzTEVL89R/f8A5HfSXMZmZ9oAl5GP7vpVZ9Qt4NqoCFJxgn7tTQWFvJAJJSQTjpxj FOC6Kl4E2Z8z73fgVfMeU3J9TTimF/GqSIsqEYwyBhivNdQ+Enw3164uZNR0OzZrk4kkaMBsn0bK kH6Gun+JIvPEGkW+keENUOjBW3TTRjEj46YYcjHoOuea8MuPglr2vW4XV/GryoCTkqxKk8ZGTkH8 a1hO5jyPqzjPiv8AAb4MaLo2oapo+mG21C3hK25iuXKGTnkqztkj07Yr5Mgt0srSPzpY4vXnmvuD Tf2bfh7ps0w8Zave69GABDDFcGBEY9WOAWPHvXY23wr+Cmg6clvZ+EI7mRGZhNdSvPISfUscEDsM Vqp2Cz7n50JMNVuIbDTN99OxOEiyTj17V1el+DNcuyzfYZoXB+UyAqrH0Ga+8UtPDWlNHJouj2lh NESA0MKofxIxU32qaViZgrE/7Axz6VLxAc77nyLa/B/x7NJFb3EUUSSnbv3ZEY9eK9J079myzfY/ iDVJLuPqwt28o5+te4b4C2yGLdnhua6c6rGYlgMJhZBwOv6iuWVZl3PGrD4QeDfDzRR2ImmuB3lY MMfSu2g8N2+nOzCyRFwPnIBz+FdLcfZb0Rlw0bRnr61BKw8zah3L781l7eYcpkAJp5McCBBL1AGK Ybsb9iueO3pU97MsnzFMkd/Ssc/K+RzVe1LOhiuQSBsJ9GzTjgOzvyx9O1YEVwyMS3Cn+daEUm1W dW+Y84NQ5MSL7S7HBByzVSkun8wAg5FQi4aWYqBgj/PFOeZnYRgjHcd6cGSh6AmM5+Zgd2TWgtlH GmA+S/J/+tVe3OSOM7eP/wBdaEsgk4Rug4xWgik+nozfJyT1J7VPHaJbRBto3Zxz1NTQQy7lUjJP TFY2s6/pGgtv1KYRv0wen41rFkyIJ4IxM8mOX4JxxTBZzXCj7MmSvc8DP5ivH/EXx70Wyujb+H4P tTdDJjcgPoAa8f1z4j+KPEXltcr9naB9yIDhCfcDFaQRDZ9U6jHJYozXI8lQM7m/XGK8w1j4i6Vp yyQG6WNlGBIwytfP+q6zrurOINQuZXVR8saOSPfAJrG0zQdW8RX6aJo1ncX93efJFAgJkZu2Bg1V WpCnBzm0kldsqEOY9G1n4iazeo8UMontWGFaIeWVJ7/Lyetfen7Kf7IXin4hm08c/Egy6f4fmBMN u3FzcgdGGfuKe5716J+zH+wvovgrTbXx38bEgvLmGJLm1smkKw2Rxkm5xgOcYBU9DSftLftjJE03 w8+D1+BEF8qe+t1KoUA2+VCQAU2nutfjuc8U4nNqv9m5Uvd+1PpY97D4anQj7SsepftOftiaN8F9 NPw8+FPlS65bQRRJPGqPa2qEFGAweZVxznoSDzyB+JfiN9S8RazPqusyS3cl6/mvJJIzszk8ks3N dNObq8vpb27LT3EhLNJIdxJ9TkdTUUaOBtRS4APAHSvueFuE8NlkPc96b3k9/TyR5uLxzqy8kcDd 2GoWcgGnN5Esf3ihwxFVLTWvEFlfW9zdL5kcLZ252kn3NeopDlAWO0Hg7uSatpplpKAJFVsfeGOa +0U9DyW2TW3xkWQuLi3NtMV2iQPuVce5r0L4d+OdItZLm/uruKeecfxgMQPavKrrwNody4uoYQgA /wBWTkE+tcyPAWp2s7S2d0CjfcU8FR6UcwtT6a0yTwp4wi1a51SzVGikxCFXAkiPXAHBNcNrvwc8 IOkU+hySLev8wikb5Bn19celeRWt34y8LSwR2Uha335cMMgH3zzitmPx3rEMl1f3p3SSDCD+FD3w DVElu5+DHjS2TNr5cjOeTb/vcD+fNea6lD4h0KeW11K2aKSI4O9DzX0H4Y+J+rpYLHpNyiyA/vHY 7Sfb8K1n8Y2l/dzar4it1u1t+ShAcOaDQ+dtK8SpamOQoCyjMikc49s13dh448PwW7PPpu5ZGzuI HPtXp/mfDTxZKqRWIgkkGSGTy8D6jNcvrXgTwbf3bppkrRqoCpuxgfpQAum+LvDF1IjylbEKeI2H OPrjpXZReIfCV0y2/wBtt5OeEIBz7V5xJ8H9NlX7VBq6rIAFcMCfy5rnbv4M64oaawuI5YozxJIM ZP5UAfStreeAVd2mNukgXLA4xj2FPl1r4czkPHNED6iP5V/Svl3/AIVX4xZllby/mJxJv+U/iTVq 4+FXi4xzKyma38sZZWPysOvfml7NGdz6bfxB4BZPJlu4iqD5tq8+3Q5p1r40+F+lXQhnnJkbsYy4 Cn3zXyRafCzxDj7TM/lQqM+YckgAdCM5NWtC+EWr61cxv9qiTTw37yfcRJgf3VJxRyILn0Jrvxg+ Fcdo114b09tUvd5HlPH5aL75rzPUPjkwIjsPD0UTN2L7lz34rzSDwzNY6hNZXFwNqNhSv8Y7Vpya Fo9tKWC75WAxljgGnYC7rHxR1rVgZGtIrSRRgBM7ce4Fcba6l4i1+7FrDiZnPCKCOfXn0r6G0L4e +Gda0aOZf9fkBiD8uKoeOIvDngnVrRtHkSN5IhiOPJcFepb61pyBc8ysfCd9dT/Z9YdraCIjzUTG 8+uDXYeL/h/4c8K6rYJYTSSC+jDjzTkj2/KuV8W/EPTJ57JNL3LcTR5YlNpZ8njjr0qxH4e+L/xK vLfUWtJZ4rSPyraWQCFQuSQcH73IxWcqkI/Ex2OigubDSdQ2K6wZ/h6CuO1PxjcnxZNJ4din1G7a HYyW0Rkk245OFBOAO9exaN+zxqNyYLvxfqnkyrKTKtthiyYG0KxXCsD1POemK+nPCOk6H4AsJYfD djFZJNy0hXfIzdyWbJ5zyOntXm4nOKdPWKudEMJJ7nyh4V/Zv+J3xHeDVvEEsHh+yuHCYuWJuGU8 k+Wo3D6Ntr668O/sbfBrw01nqGoNe6tdWuDcJPOPImOc8KqhlUem78a0ft+oSTCWEFt/zcE9KqFt auruQtcS5PT5icj0r47Ms1q13a+h6NCjGC2PeYfC3gGHTo7PTLaKzgzlVhIVCfoK8v8AEvxG8K+G JxpkM6CSI7cDkA/hxXBauNZsrF3geRJNp2ru6H6V8tzeEbzXtQK3lzILydyNpOCWP6V899TjvI7l M7r4sX1p8XobbSrW48tomJXGfm3AVZ8K+A7rwTpsdpAyzbuS7EZHtjNeifCb4K20TPNrOoD7Rg7C MnbtJGOa+obHwd4XtFVLhBdSqMbmAIP513UYqKshN3Pg7UPCttqOotsgYS3ByDg7S/tRH8J/FIVk a3vME5GyI7SPZq/R2L+xbBETT9LhJUZG5VIzWdcatPuMpEcQHOFG4flmukix+cmo/AnxG8CTS6fO vzjIcEfL7Y65OPSuef8AZ18YqLrUpNQtNIimbaqyq0j7T0JC4x9M1+jM+t+fIXMvCjGMcflXL3tr BdSGRomLP0P8J/CrjFPdnXSxMoO8T4Ctfh34p8JqxOqjVIU7xoUHQDgMSe3qPpU2m6hqt3rcOhWF hcX17cHAjgQvMcf3VUEn8BX19rvw0v8AX7yJbVJgYyC0cSncykjPA9s19lfs6/BHwx4HvL/WIdE8 zW5USPzJfnWKI8ko3IUsR82PQUpYenK9z7HK+MatHpex+d1nNqmj4t50aKROJYJQVlQjqGBwQR6V 2WmXsF/HiNsEDkdwfpXrX7VHhbUNN8Y3GuX1tDZS4EsaW+GjdGYjLNwSzHJOa+S0upYtVtWZ/s7l s/KeGzwP1rwMdgLXaP2Dh3jGNdR59LnuULiJ0ib58ng+ld9pEatGJAABXkukaitzJyN2w4I7g16t ptxHDaFXBGOcH0rwHCVz9ThJcvNfQ7S2McUZkk+6oz+VfHv7TvhvXPF1hA2nQN9ks2LuwGfmxtXA 68g19KveXNyqxWasyPXpGg6BZ3ixteQq5UD74yPyPFdODxUqFWNRdD8o8T8ypvCPDxest/RH4jT/ AAm1OG1SRIRG7g7CV5Yj1JJrIuvB/i3SohdQQXcaQbTLLAxRUbOAQQeD9DX7ya98LPhx4js7hdV0 e3lnuFC71DIVx02lSMGvJNV/Zt8KahYtaaDfy6SxI5DM6A5z0bJz+NfdYPipS92oj+apUGtj8krT 4l/F/Qr1be01e5nXAO2QbyF+pBP6131h+0p47MfkapawTxI2x2CsJR7jkCv0Ivf2M/E2CNO1W0vk ZcbpFMbkn65FeWfEH9jzxjoGitq0ujrdWdqv7ySGZGOT/EVHOK+gpZhRkczizxG0/aB8GXyxw6nF PZbuCzqCAfw5/Su007xj4c1udrfSrwXBUAgAYyD9a8cu/gebmby/sFysmMAiF5ST+HH8qx9T/Z7+ Ia36zaPpl+kBUBAYJEJYdeVzXc3DuQ4n1Lbrcz52Kf3fWo5G+faa+K4j8QPBz7rHUZQxlKSqrMxV l4IYHn2+tdLZfG3xfpAC6hbx3EcBORIhDtntnOP0pRgc0pWPrM2Udwpz820cAZzn2rnU8MvLco05 bbuyMqOBXC6V8cdDnubX7VZy2KyrlmI3AH0OK9h0Tx34J1yWKKHWYBcP0RztJb0GaOUtSRgHwpba ZqQuktlSRRxKIwrMD6kVwnjn4a6B8Tbm3XX0lK6WXEXlNtAWTGQ3r04NfT9lHBqTOigOqcE9QKtw 6Hp8KtLAB5j5ByeOKFdMmckj4esv2UPh7LMrQ6neQsh3Z3BlT8DjP511Nx8BbzRlSTw3qMd3JGwZ RyssgHJ4OQD6c/8A1/q46Ta5PyBc9cDFY+o6HGsEkkUuwgcD1NbxnJ7swPhTU1+LfhK4a8k8OX6s rFkeRG2rzwTsJA/KsXw58X/jLbaukl/4ivbOORvnkWTbgc5GM4x+FfX9xd63YyErqMsjf3WO4D04 NejaJ8fvEmn3NrbeI7ax1G0gOHSWHDSAdF3jgH0JH51vfyA0/h98SvGtnoa3Wr3TanITlZ5BluR3 I/DivoLwl8aPHbQreXuJIAfkRU+V/wDZLc8fhU3hH9pf4MSWun2V54WNlJDM0hQBDGsjZy/8Oc57 jivqXwr8QfhN4xhaz0e7tljjYqiSKIye5KggcZ75rNlONjX8LfFZNUto3uoJoCyqcMOORng4Feq2 fiHTb6IPFPgn+E8Gsxn8IS28cUdzCqxgBSCCOO3FczrGufDfw/Al9rGqQW8RLDcpwwKjOSOuPwrZ GUkd3PDY6nC8F2vnRsCMfWvnHWP2T/hNqd9Nq114U0y+uZeWkuYFeTOc46YP5V554n/a/wDA/hm8 s38MSvrTzMVa1jTDBBkby5yoA49z271a8Mftq+GtQvFh1rS5rRJCVIkbAQ54ZiCfl+lNu44xuZ/j 39hD9nHxksZ1f4fC0aI7lbSQbVywBwWMeCQe46E4r8bfj7+yXovww1GS18A3evTNeGQRpfQKkcYQ 8gkLlz6H5cdTkZr+l7wv8Q/DfimES6bcI/ybjsYNznGPX6HHNdVdeH/CWv26S32k29wxJOZIwWy3 U/U81KlYmx/FvqXh/wAU6JeyWM1hIxMQIdFLLnuSBnHWsZNcuNOtPtkm6XDBQR9zcfUfga/rH+In 7FXwr8aXMWo6VYx6ZMpG7y12DAycDZgYJNfnl8U/2MvFvhC1ntdT0aDXPDybsyWsStceSTkLsA3Z UdWGDk5GO1e1sPkT2Pxog8YRymNZE8qEJ87fp1rWTW0kaKeAkQ4PQZLc19JT/s6fDW8gu4NCtprG 4aQqv2yRz5eG5DL3ryi9/Z2+IlhcTzabeW88EZ/cxt8okx0AP8NTGsjf6s11Oet7y2n3uXUgDgdC PfNLLGTt8sYcjb1PQ+wrjLzwt4qs1ni1jSp7J2fYGzlQ4PXI7Vc/tFsMlzK8X2YbSGBXdge9a3M2 vI//1POwvp1owwIdj0605jjGe/pUeQq8Hn3r/Rg/lMe+ciQNj2ozk47UihWXcecUFC5BBxQZiBmI PGAOKF3SfKF5XvTyQQNvahWUA564oAGy5VDke9MMaAtGM4pfN3oVU/8A66BuVBuBLd6AGqWVMEZA 4H0qN08xSVPzDjB6YqXDsNvTP8qhdAwCFuBzms5LojSndlGfbFuc/wDLIdPWrUMkhxK3EZwcdzUF 7Croky/eQ4I9vWno3mADdlh0r834twfVI+1yCty6D9Wjkv7VkwTEscjMp4GAvQ18O62hh1SeDYW8 kKXC8deePwr7vWGSW1dC37x1+YH0xyK+J/G9okfiy/uYgYoiUUD+8VGDX87cV0OWzXc/WcmldXO0 8Ha9DduJpImiWIcL1Zh0r1q9QzwNHAdhcDn0zXy/4e1A2+pieaNkRTt8wnCj0zX0fBMQoEj7xgYx 6darIcdGVPke6MswwrUudH2l8AfG9/PPa+GHcPFCpIDt02jkD+dfV5kBGa/KbwzrGpeGtag1K0md PKIcKpwSM8gkdsV+nXhS+uNb0C11CVcNcqGX12kAjNfl3iDk6o1lWgrKX5n3fC+Ye0pOEt0b5mRU JxnFeeeO/H0nhyyNtZhWkcD5j2616cLB/Kcv0Ck/kK+Gfin4pkvYPLVCZrxhnjhQODX5st7H1k3Z XNaf45Xdgo1C4K3EbttVCdoyPQ81wEP7d0U01xa22hFZrZmjIkkAT5DjJbBPPbjpXzv8R9SWy0lL GLcXkXcSoyAe3FfGGp3UtxeNE8m3rlgMfnXp0cBCSuziqYhrY/XTw7+214d1zV4LHWdIaxikOwvE 3mNv7fLxxn8q95HxW8P63p7tYiRJyMhJF2tt7Ejrg5yK/Fvwzp93eQW0jOoijIP3fmxnrur3ux1/ UtGktItOuZN9xIBI5bcQgPTnp0qa2XQS90Kddtn1R4kvDeXbynh2znHY17T8I9YN9osdresS6Eou 49Qp7V82QXpvdPS7L7i2evt616v8IJoI7lbC5f8AfqWdMnrk9q+Q4hwtqWx7eX1LSPqvJQAAcYpg ORin7S8YbNNcbACK/Mj6ZEZZt22o50d1ZanUhh71M6HHFAHHX1sYPoRXAa1byF0kQZGCPpXqGoxO 6EDkCuF1OMeRKXO1FG4n2FehhNGmclV3PlXVjFZeN7e7lP7tT8x/uk8Cvr/wlqzT2hUtkbuPcetf IfjVIF1eQMhwy7s+oHQ19PeBAg0SxZnBDQoQfcjNfsnCtX3bHx2dw0uesRSKx9K0oZMYrlhMEwM1 s2twsnINfYHy50kDgjmrSkrncOtYizHjHatCKdZMZNO1zQ0lHHNWkxwRVSNsirKHIwKcNBcosibg UIyOelfMPxD0saLrK3sZyLlvmyejV9WwR/LtxyeRXk3xW0Q3mhNd20DTXJdQNq5wO5rxeJaSqYaU T1MqlapY8MtLkzjDfKyntWyHODnoeM1xtrM0MyxscE8Y966aJmYEEEFa/C8RRcGfeU3dWLyAsdrH g1Iq7RtHQVUWcJg96mkusrx1rOCGQ3MAlB7DHWvMNQspbW6aNfuE5Feol8jKd64rxEHVgq9T3r18 DVUJJnJWg5CaRdtdyeRN/rFNel20wljC4O5en1FeH2F+lneYlz5jfdr1/wAPSNOocggN1r9syqpz UFI+Dx0OWbR67ov7y2i/vY5rvrG3ZRk/NnpXn+iSokgjzxjPoAB1NeP/ABd/ax8I/Bq6s9MEB1q9 ussUhlTYqDvnnJz27c5r0onByn1yIiwwR0prQMoz0r87fDn/AAUR8JahqcNrrXh6fTbWSXbLdNKr RxJ3JCgsTxwPzxX374Q8Z+GvHugQeIfDd4l3Z3Cho2B5Kt0yOx9jW5k0bEXDA46VrQYxkiqBG04W rcD8YNAjUjGfxq4gIqpESwAHarYYjk1oBMpOMU8E1GoGKkUCswJBwRWhbjnpxWbkelaNseetaAfL P7YHxi8R/CfwGlz4VnMN/JnaQufvfKpDdtp5ORg9K/nj8U/EjxNrWqteXt7LeXN0C0kshYuzknJz niv6MP2q/hEPil4EunhTE1lESoLEKVA64/vZ6V/Pf40+DHjPw5qcEXlJdCVc7oz0HJII7EEHjNAa 9D1f9nX9qv4ifCPxNbC+vDqujSGOOS2mkO2NQQPMBPJZBwuSAB7V/R54a8RWHi/w/Ya/YurR3kQk wuSB+dfyq6P8LPGk981t9k3I/lxiJcO7GVtoA29OR3r+mf4FeH9Q8H/DzTfDOpo4ktIQFLA5Rf8A nm3qy9iOCOaamZnpsrLyAKgB9KnlyTUFIzCim/xUmRu60AOGe9SA5qEnmkL+lBoXFOK1Leb5dqnF YaMpHvU4l24I60FRPkH47fs7w6/qEuuaDZK0lynz+Wv3SoAwozjJA5J5rwnxP8MZtM8C6RZW1pK1 3pztDFhCGZW5Ksvp6HsR1xnP6fpdlhjOK4bx1aLPpHnIFBhcMCR05HTiuHEYdTTiz6HKM0nhasK0 N4tP7j8mpPBvjNGaM6PcqwOCvkycf+Omrun/AA0+JOp3MdtaeGb1i/Q+Wyjjn+ICv2u8J6na6tp0 bQx8Ii5LIBk9OO9diskaRhUUKw7gAfyFeOsgh1kz9Ql41YiOiw6v6/8AAPxAH7O3xju7gGPwzLBF /E7sBj/GtH/hlL4vXLlLfT4lcjIZ5toH1+U1+1Us8pXCsfzrnroByQ4rSORU11Zy1PGPHzulSgl8 /wDM/LT4bfAT44/DPxOniixnt4Ly1Ix5cwCmM43A5HzZ7jt161+uHgLxqfEmmxQ6mqQapEoE0ang nGSV74rzS+tUZTgVx8kV1YXsd/YOYZ4TlWFe9h6ahHlR+YZ7mVXG1nXq7n1/RXnXgzxxBrsS2F/+ 5v0HIPR/cV6LXYeFYKKKKBBRWJeeJNA08Mb3UIItvUFxkfh1rzPWfj38NdIheQakLpkONsY9Prig D2eivjfxH+2J4V0+Jjolg926jPzttU/kM8V4J4q/bY8ayyM2g6bBaWbY+bO6YYHOARjr056forjs fqHWdeavpOnxtNf3sNvGvVpJFUD8Sa/EPXP2i/jH4hjMeo6tNANxIET4OPTjFeX6l4p8Ua1L5mo3 ck65ztkYkA+uAcVHOaKjLsfuDrnx2+FHh9HbUPEVsWj6pG29vyFeLeIP20fhrp6t/YkM+pleNwxG oPvnPb6V+Sdxbz3x8yQEeyEiqj6PLF90P83XkmlzlrDs/QjX/wBvC7S8ez0fTreFlXIZ98o+YZBy vBwOuDXjXiH9sD4n60DBHeG1hY/N5CBCR04OeOK+Y4dLxjKg+9WjYRphpHRfQFhzS5jrhhJPZHUa x8T/AIha8rW99r15PG5yQ0h6fhXL3F3qN6i/bHErD+JssfzNMefSLYn7VeRRgcnLDP5ZqD/hKPBk CA3GpICTwFyTmrcjf6lP+X8BslvcNn5h8oGcAYpE0+RyMHPPSsfUfiN4H0whJp/PDdkOc1kv8avA kakiGSMj7pIJ/lXK60e500sqry+x+B6CmnuSpHXuB1q8NPVRg8+3SvI5vj7oEaD+zrCW5k9GG0Vj SfH/AFh5ClnpMag935xUPFU+561PhXGT+Gn+R74tgNnC1bj0ycrlYz+VfOUnxc8d6gALVIbb0KoD +eajHjH4kXrqqam53feKqoC/TionmNNHXDgHGS+yvv8A8kz6ZGj3KKDsxn86lj0a+kKssYweMHiv mxdQ8ds+bnVZnUemP8KsWa65cys93eT7X9XI/LFcVXO4R2R7eA8KcXU/izSXldn1la+DoJHQ6jqE FqPRmwf510aeGvBlo+bvXLdtvYuuK+RxpZjVVlkeQn1Y/wCNakGmw7xIowe+c/1rjlxC+kdfU+rw /gmvtYh+nLr99z7Hsr/4GaVCE1O++0yY52AsM+20Gum074r/AAI0Pc9j5sjHovksOfbdXw+LVFPA GRVjygoBIFcc8/rp3Vj38N4M4FW55z+9f5H3WP2mfh7ZhfsGlzzMTyMqpH5k1HP+1tpNoqva6CR/ d86Uf+yg18NFSMYGaeYy33zx6VjLP8S/tfkerS8HsoW8HL1k/wBD7Gu/2xPEwf8A4lOmWcCt7ljX KXX7W/xTu3JsLmK0UDB2xK2Tk9zz0r5eaAZyBUYUopHrXO8dWf23957lHw7yiCssNH5q/wCZ7xqX 7SXxNu4XluNbudgIZthCqdhz0/8ArV+qnwp8Wt408A6LrzyebLcWkLSMAQC5XkjPP/16/C11DoYT 0fiv1n/Yz1eXUvhHb2c8rytYlo13dFTPyhfYc17GR4qTquM3fTqfl/i9wphsLlsK+Foxi1LWyto+ 59THIJqB8nirEgIqHGa+uP5tIMGlBOOlSmM+tKENAEQ3Yp4zjmpRFxyakEfFAEBHaoivODVtk9qb s7igCsAwIxUhTirkUTuMbanFlP2jJoAyTgUhPtV6SAofmGKrEH04rQCMcU771LtFSBcCswIT6elP XmlK809VxQAmB6UuPan4FOwa0AatLmmgYpSMigzFopB0pazNCQdKKB0ooAB0opVpWoAbTTmnU7bW gGrZtypNfln+2dbfZfiAJ4wVDx7gM8dBkgV+pVqORX53/t1aR5F1pGudfMRo2x6cAGsavQ7MF8Vj 4EtG2n5eQ1ailJXwBtNZlnGCxz8vpWpGFEv+71rlOyZIqeWdwbGO1XV3EDeQwqFofOYAcA1YhhQO F5GKDNIkA2spU81bJ2YGMk9KYo3fK4pZVYsu35vcdqBpCvH/ABLgZFSae0sDknoe1PbAUY/GpoyU G0jg96BGrEC7Bj0A4qzGcggjkVkef5T7RyCK10O5AW+8RQA5DKAxAzRGXVye5pUJB2hjg1dWMqy9 896CkKh4BJxVwkggAdKq4IJLZxU3mSgbl6D1oGiwhc9OBV5EY4z2rMSXzB8xwakS4mD7OwoGXmU8 jvTlePH7w9KNwdc96ryA4DEYoAgnkWRiEzgVmTxeZwxwTWjKRnD/AHcday5CFYgNxUyAx3geJjk5 U1GGdMqSCoq7K6OPXt+NVJFHl4xwOpoiBRd0JI67ulUZYTkhW/CgszMf4cdKUsOp/OpApTbfs7xg Z3gqQehB9a/PL44/By98M3s3ibQrY/2ZdHc8cbF/Kc9c55AY8/Xiv0LaTYXU9zWVOtvODDdpvhYF WQ8q6kYIIPBFapmTV1Y/HeG+iciOMkSdCCPzFaEV0oYbgeenfB/CvvrV/wBnnwPqFxNLZRNaCUlv 3Jxt/OvMtW/Zc0+GIz6JebJiDtDNu57FsdK2UjndA+WHut/+tbavqOK7f4SeDpvGfjaITZl07T9s 0uSMAZ+Xg8Nk8Y+tegR/su+NrxFt5NTtrS3UjdIwLkqTgkKMZOOxIr628B/DzRvh/pUmk6KXkRpN +6UgsTgA9ABziiVSxVOjqeiWL20NsI4wEUBVAUYACjAGPpTwdsvm54qh8kS7n+9VqFhMuB2rna1O tG6sjSbWAGD+daFnbfOxJOBWVEUjRc5JNb9q8ZXGORUGhf2AD5T1pvl/Mrfdp0YZmPf0pCr79hFA GrG4wAOcVYYZTn5apwMo4z+FTBWbr0NADlk8s4zU6lgNyjINRrb7jjgYq3ygAYflQWkPikO4DO01 cA3jcTurKI8uUuDke9W4pC5G0isyUaCpt7UpX5Sy8VGqtzmpY5Mx7WoLHQsY8cnk81qrcxSh435S QbSD3FZhwzA9jSZkbKgAdqCNtT5z1a1/4Q3xe0AJSwny0Z7Yc+vtXu/h7XobmARiQFRj64rA8d+D 5vEmiyXkEg+02EZeNeu4eg968F8O+NBY6haW9whWQNsJzhcDqCPWvjs6y+0uaOx+m8OZxGpS5Zbo +1bW+jCMp6dqpXLebgmuJ0vXYbqPKvkt29K6S3vEaMK7Zx3r5y3KfYwfMNlyrYz15FfRnwUksdH0 +91e6ZN0ysPmbH3Oa+crkpICQc8fSm2/iGSy0xtNhcMp3d+metdODn7xjXWhz3xI1CC/1q+vY3JM 0m4fSpfhsk7WV1Ow5Z1I+hry7V9Rmu7tkzmRicAete4eDdPubCxt4yhTdHls+tfQZdCXPc+J4ir0 1S5Jbvb5HZZyAFHFKGwPekRSgyx5JpSMda+pifnjQpZlXOOKkQjuKXaHGD0pRk8HjFWx2HblAqVd rr8gqHZt696cd6fd4FSyWT7jgjFLG69CuMVWV2YdelT7SeauJBOvJ6UcbyDxUQf04xTztPJNSA4B myVqTYyj5qYrBVOOtOEhIO/rQArMAmFp0XyjPXNNIRiAeKRckFV6CgCwgAO4mnj5iSKrgcYHamrI QaALZj3LkcGpD90DuKiVmKnFPjyfvVL3KWwg8wjmrKphOTzUZfaMgZFSI4IPqaHsC3JMDAHtUqEK ADTFcZAq0iK1SUKNr5FOUY+X9aY0bDgdKA+BtrQzJwGHy9qeMjgDFVyTjPf3pwZjwRj6UGhbVcnL DipAqjjNVgW+7mng56jkUATMSMbBTgQMAnmmAjbn0pOpyKDMcQOMjNBAJGDxTEfBIYcCpfvCgBPk z1pN2O2aNq/xCjgfdNADlJPag5xSAHnJxSZIXg/jQBIHVfvUzzAfumo/lkGB260wIQcg9KzNCwpP 8VPXBqEZ6mpdwxxQA5h39KQtnk9KYpJ5FBy/ArQzHn5vpQOetMGRwKC2OvWgCcAYJY9KjPrnFR73 Y+gFGSTiswAkseKTtyacMgYPFNYYHrQBBwOSaZFD+9LZ4psm5jnGAKcH2Y46VoaFxzxhe1RZDL05 qEucnaetPHA96AJDKsfB5NRNLI3K9KXYOpoCg9OKAOXvLR59Xhl7AdK33iVBuY81iveImtJErZYK eK1yzM2T3rMBN+z6mnJuzlqaVO7J5ppZlzjpWgFjcvA6U7gnPpVdB1ZqnXaBnPWgA3Dd0pScdO1R 8F+DUgBqLANHzCmVJTSPSixmG0cZ6VIoXaXHaoW5PtTJHxGQtIBzSn+AUxWIJzUEZLLxxinsPlwT zQBJ5jcgCmA8bn60KMHNOIBHzHkdqC7CDO7CdalAXbknkVWZ9gLdBTHkBAbpQFhsrln4PC9RR5hK 7B36VFtJ56ZqwkWOT0FLUWhCu9flI5psoAQhmqOSbZJ6gVmXl0Gfan40ahoOkmUHaoOKqbFxwMAm o/MZF9S3anhMbTuI9jTJJm2JwpzinoRt3AYzUO0iTL9Kcr7yxIwBQBJH5m4sTgVHLLLyM0ruCAmM VXYkkjOanmAkxtT5u9MOxBjuOtQyTbfkz06UoJK5bqaOYAkkTjFQM/LZ5oZC3NUprjy8gUrmg/7U 5baTxUe/a3y8mszzucKelD6hbwDzC2WH8NIzLNwwlBUjg8VStogsqwpl3l+VVUZJPaqFxfnZ5iHL N2Fd54G8X+EtCuHu9ft2mnRcQsgHyt3OCRnj/wCtVcwFPWvC+t6Hpq6nqcIhgdtq7mG4n6Vwkkgk kB3fhXefE34g/wDCZ3FpaWMBh0+1dim8/NISMZx2xXmgITLnoKOYCy/yEtnAWsCdpJ52YN8vXmq9 9r0O1oo87gcVzz3M8yuGcruHGKaiBNq0/mMyZ+ROhrEUhIi7nKL0PvVG+kv5o8RJlUGD1yT9KpJe 3tzD9jMQUg544P5VfLYOc2I5zNwD9K8z8caWviSAaFrU8gsjIsrrEcFmXpzXoFpC4Yoy7WFWIdDt 9OuX1q/mRkYYCEdPzrjr4pU15nsZHkNXHTajpFbt7L/N+X3nnnhv4O+BPDapqUNhieL5laUAso7Y B6Gu6u9St5ZYdJgl8k7d78dF9uetcz4r8RX97ssdN+WEcsw5BHbHOQa57S/NVjK5LsRgs2cn8TXm +9V9+q/kfZ1szw+Xp4fBLXq/63/IyLjSdcm1uRIz9ujRsxFupFagh1KCePzoGixwwA4FdXbwGBjd xEhkGc9hXSL4rAhIu4UlIGA2Oa6YpR2PksxzGWIlectTlLOxWa4zcSEA9sdveurk0y38kmLCKePU tVm0j0jVSJLY+XKw6FsAmtG2sZXuBaTNjZ/dq0eS6ZiQeHbh0Us/ynpgVr22k/YV4wc1008KQwqk eQPc4rFlnlI28Fvat1UMmiJ5ZQpUYwBjiqMdsykykkY+6R3qXcE3Ox+tQabfi6c2twuCD8p9aZi2 RFYwyl1PvV2K9jjt2hhh3Zq5LFHgxvg4rDOEuWWMfLR7QRau0tbhg0Uflt9Kz72zDRbG+bAzjtV4 Od4GMk+tNkPLBfm4xUe0A4S5RSSAuCKplXjHy10V7bKASo+Y1zUuckZxSuALL5RLDjua37e4W5RZ HHWsK1tRJIEnb5T0reaGNP3MZ4HNABPJIx4IHtUcmFTAPzD0prQsBvT5h9KreYBkSAkhhxQaA/Cr Gy5LcVWm0yUyYGQuOv8AjWriPdhhuGePUVZWY7SX+6eMetOxmc82nTIvJypqeGweSRSxO3pV9mXA RlziryqY1UjgGlctD4baBHXI5HAzSSadG0heRArDvV62tGmnjYn5R1rRmtnkYqp3BT19qcGSjk0j aNyqNyfaqGsahaaHAs+o/LG5IG37xP0p3i3xFoPhjTZ7qXUY4LuNC0SsNx3dsqOv0r428UePPEfj G8Wa9ceRFlQIwVLe5xxz6dq0SY2es+LvjTJEJNN8O3BtypIDFckH3NeG3msa3rp87ULprjceSeMY q9ovhWfU/wDSnBIzkDGMgetehQeFbp0VWhTapyVXvW8Ec7PNLXwvPcqjqiE9gBg10TeErGF2ecqk 6gYbqMV6ponhi81PUI7DTbaSWZ+EVUJIHfgDJ/Cvs/4Yfsj32qWpv/HsiWMBPyQL/rpF/wBojgDg EdCfbFeZnOe4bAU3OtLXt1fp/WnU6aGDnUdonxl8I/gLr/xJ1lY9AsHC7gjXhy0a553EnAAAz/IV +rPw3+Dvw1/Zx8MLq/iK6t7i+tcTy30qjerIOWjXBKjnBA655zV3V/HPgX4U+H7nRfBWnoJWPIgT bCJTwS2CASQO2eea+M/GWueLfH2p/wBq6m7Styu0cBV6AKMdMds1+b4unmeeSs/3dDt1fb1/9JPY i6WH0teRe+OH7Q+s/Ey5k0zTN9l4bMoCxdWlC5XczDkqwOSp49q+Zo/Ctjc3fmJGv+0QucfpXtWl +HorLzA0II+6QwB609tBiSXMSeWntX6ZkuR4fAUVQw6suvn6/wBeh5mJxMqkryPFR4JgV9/VQSSo HX8KsReAtLicz25mZ3GcZwR7Yr3CDSxaEy7QSRwD0+tTKCsnmGII2cdOvvXpnGeHN4GU2uxbZhN/ edcflUQ+D8gtxeWM5Eh+/GwOGP1r355Ek+Ugk+3Smb9jgqc4HTPFbcpF0fPA+GfiMROZ5BHKPuIo yCP96opfh5q8SNOoIdl4jzk59jX0DNcuo6ZJrj7+4lNwxEm1lHGBRyhdHi9x4P1KDYt7E0TNjqob n3Ncxq3wykuZZJ5LMyKSOIzgH8BXviXU+SC+c+1VWjvpZl2sWHsDitImR8qXnwdIEtxp/mp5h4i3 nINZdh8OvHunOV0xzvzgrKQVx9DX2MsUpXZLGflPWtCGFHcboVKr8xYgZNUB8RrpnxIgu2F3ZMrq CAyKdpx7LWRbaj4swzPYyiRGPzFWUHH1FffF7cpbR74gqt6Y6fSuYklgcE+Srqx3HKjg+tAHxZce IdTRxFqNs8ZYbuSwx716BZ/Eya20AWCQu12DtcZyGT1Br2rXPDOl+I7QQtbBeDmRV+Y/X2rkl+CX h+/jhlkaWJbdTwjbC/tjmgDDX4reHv7CisbjUVhn258p0IkU9cE45qx4f+K/h2z0pbS7n8+b5iNh PRunBrnm/Z/luXeZZZU7kbdzgHoM81IP2f3hKvFczQNtwfl7/lVWMyhovxKWKDUhdIxinBWFQRwx 7tmo9P8AifLo+hzWdisaTyNnc3Ix3xXT2HwKkhO17hblB1VlKSfUetXW+Dtk+1NnzR8eWR+tAHh9 n4se8llZsNJu6IOXP4VW1DVLxvmWKUFuPlRgyn1r6z0jwV9jWKC2sIIJIzncYx+ea7CLSLmOUC5t YSDzkIKnnNOQ+TvAXhrWvFV1Fp/9q/2bas3ytKzhtxxk7B/Pge9fUVj+ypo1w32vUNZu9aONvloV Cgk5yCPmHT16dc12v2yC1VVudMt5wP4jGgYD2IGa6nw/q+l6VILvSZpLKXd0LMyhv90187mWJrL4 Gb0qK6nR/D74C3Ggw25sPD626xlmjuZ4QZsnjO7Bbp716Pb/AAQ+IF5K4gitbK35+Z5Du9M4UE9O lddp3xX16xso49Q8QQNIAGH7pDweg4XsKWb4lTav5iG/kkI4IX5R+mB9a+VnKvKXNI9KKguhzL/A PWYI1l1DW4UIPKkFU/Fs5x+FcrL4WUE2yxiQKMcE7SR716Amy5lSXymmkk5BfLcc/X0rXiScFSyB I/8AdwKzlOVrMrQ4qw0KOzkjAtzvx3I/rXUPbQSQ+V5Kqw7nH9K0JoQx87O4+1VJJLO1Rpr+YQx+ pNYc8R2PMfFXhg6qAiXP2UqOCozk151b+D9Flvod4nv79JPlEYJcsPRQK+h4PEfwmFskuu63bRl2 YBZZvLOR7GsG9+P/AMPPA2qC58JW0GpzBjGGiGSgx9/ewwQTgcc/hmsKlVLdlpnS+Ffhr8QvESLa eG/DjAIxTfcsLdRg8534xj9f1r3iy/Za8duyS6zqVoqH5mjjyxUE8JnAGQOpBwT6CuC8NfHbxhq+ +/02FHtLlVVSAFO4k5yB+XWvZbbx/wCKr+BBcTmMr3Xjr61i80prQZzPiH4HahoelXHkot/Lg4ki yHX0AH8WTjjmvJ9B+Hi3F8v/AAlwntoh1iKmMtzjqRz0r6o03xJrMhWK9naVWIPNdyutbxtnKuF9 UzXfRnzq6C54uNN+FYtUsLbRY45I1AEjEucKMc5ySamth4Tt42t7WzXaP9gH8s16/dLo+pc3lrFL t9Vway30Dww//LiP++jXTLAVJbO33lRlY88sLTw9qe8CIgr8o5C/pXrWn3UVtpsdlswEGF2jt9az rfw/4fssvZ6equ3Ukk1c3LGoEfyr2GKdDC1I7jlUMbXfBPgzxZHt1syM2eT8ucenzKeK80vP2afg vqp2pqDQy7geW24698Dk16s1zmTZXnmv6dc29x5n2k7JP4AODRVh3PSwWMnT+FnKy/sgfBy3xdBL ppiuGeC5dA5BJDELgdDj04qx/wAMu+AJUKWOt3URwANzbyoB5Ge+en/16bHq97pk7LdSSW6gbwVY n5foDV9fi7DZTGGzRLh14YzFgf0NeLWxOHi+WSufT4fi7MKaShWkvn+juFh+yromlBpNN8QM5Yg4 nX0ABGV9Tz0rRsfg9f8A26W3W7igt0XInZSdzdNu0HP41g3HxEvbnCpdNDI3YHeK6fS/G2pC3UXr efzgHAH8q5HUozfunh5nmVfES56srtli+/Z61i+MTx+I4UjXJdVRkJB6fMc0yz/ZumScyXGtLsXo SxYHPHI+Xr2rqP7bgnjD52k+jH/Goxqk8jBFchO/NdtDDU7ps8Oc5I2rf4O3C4Q69GQB2XJ/nV+X 4Y+DUiktPEmpvqELbQYm+VDzwGA684I9Ko213bkbCSPxpbmKxulCl8k5HJxzXqxstjm1NuLRPhXo AMWnafboWGOV3fzzVW81vwTaxMgS3TAwPlA/kK43+w9rHy51Y84xzXCeJNNuLOIu6k5Pp/jRUr1P si5TwX4qfAD4a+Mdcm1/R1/s28k+fzYkV1805Bd0I+YgHAGRjAI5HPxf4j/Zk8QaQZNttFK+7MRD bmkBPGVK8V+i0ckg6fJWvYPJAWkdy+79KxpZrWpst0Yn4x6p8FZ7WCY6lo13BtyzSMWRFI+vWvFN V+G2o7GmtLtVfd8oBKyY9ARiv6Dr+20/VUeK8t47pZFKsroCCD7Y615rc/B/wRqZDy2MS7eAxijJ Uf7J28V9Tl+ZqputTCVJI/Ea3h+KvhpbUWusXf2fqY3lYjHPBBJzmvSofjh8RNLs5Dq2knUF/glB 8sDGeBjnmvv3xh8BfAUd+9/De3EZkABQbChAHTAHGfrXzb4h+GdjDc3FnpvntascqrYJwD0HHOfp Xr3OWUTzTTf2nLT7NGmr6c2nXGcMA3mbQO/Yn8q9KtPjB4I1y0t1stRSSaZ9jB1ZMeh59a8S8S/D q0uryBvszQzAbMgdcdMjpx9K5C8+C92FMf72OVuhiywA9wMYq4pEcp9DamyPeSTRP5kTHgjnn8Kx 3tvPkMcnyntn/wCuK+XG8MeNPCCva2+oPcLHICUSVhu/4AxrqYviX4k00+XdWO4xKFy2VYH6mtSz 6PtNJMk0CyfNg8twePevT7HTCmWgdolIyVUkA18oaB8bLBZGj1mL7AFwQT8wcn0r6G8N/FnwDd24 W81SK2JwADknJpNCaO4mbWYIlFjqFzEB2Ez44AHr7Vj6kmo38Si6le42jqxJP41t6f4g8P6lK0CX UcbMAYtzDEoP93FaxtEMJniIZG4BHT3qdSbHmENlLEDLgJEo696z7m0cs02AUYdK9CltFBbPzbuo 7Vk3Nm20+XwR1GKEykiHwx401jwbeQXGm3EkCxEMAjspJAwBkH04+lfd3wk/ap0Se5ttI1d5o5ij vJLI+V+UbiCWOcn8Qe1fn69kX4K5pf7OEfMagP8A0q7g0fvV4V+IXhjxTYQXOn30BEvUJIGx6Z5x nHOO1dRcSWdwhjnRZEwV45yK/CXwr4t8YeD5hJ4fv3SIHd5LHdET67Txkdj1HUc819aeAf2vNctL Y2PjG2FxcKm1XjTCMSewHKgd8k5J4qbE8h6b8a/2UPD3jeCfWfCsK2WsyyrJKyLhGHRiR0yc5I5J PQivzQ+KXwf+I/w1+1tqelz3dlYjzHu7eN3hVD0y2MDp0zkd6/Y7wh8evBXiiOBJ5BbXEy8gk4Jy RjGOD7GvdHvNJ1GzVLh4poXGCrYI5GCCD1461EkjanOS0P5lLfULe+lksp40lk4YiRBn8mrN1nw7 4Y1eKQa5YJscFcABT2yVIHFf0KeO/wBmP4R+Oo5nl0qGyu50x5sS7SfxBH4HqO1fnX8XP+CfHizw 9bya18PtXXUxbRu0lveEpuHG0RuC2TngDaPdulZTuVN2P//V87Riq4YU1x84GOTTCVYhD1HU0HKn duyR0r/Rmx/JrY5gVb5SPl/hpsYZg3PzE/lTW8mY7s7WHU1MxEedoySKLDQmNvyZ571J8rEDb0FP RGMYdl5qEngnJzSGNUxA/IuDTV3CRnLcGkXaGLHJIoCtswwxk8UAAcnI6MaaMocPyR196apIIjbk njdTt4Rgm3g55pTVi4uxWmkZiY0XcjDk1FaFPN2ryUGCKc2E/dx8E9qjsHjRn2fMxJBJ9a+Q4oin SbPo8mfvo6KEAMHHBBGPx9a+Q/izDFY+OtStiNiSskqccHcozj2zX15aO4cPmvnr426TdN4gt9ek 8uC3u7YpGzY/ePEcnj1+YCv5v4vpL2dz9fyKbuongaO4Cyj5ip5Br2fwLrx1T/Q3hMbqcKM547V4 4iK6eW4HyjnHc1f8KTtYa0blJdjt8p5wPbivzvBYh06qktj6mtS5oOJ9OTzOY8bc/Svsb9nv4iTv p1j4Q1AOwSZ4o3JzgYzg/wAhXw7ZXU4tlWfiTvXa+F9dufD+q2uq20zL9mnSZhnjC9vx719ZnuVQ zDBOm990/M8TLsfLCVlJbdT9ZPEdy9poztDII5tjbc89uBX54+ILe51PUjcai4AVm3RqfuHPp719 HeKviPZaz4VW+sJgI7hcox6oecj6180R2s2r3d1qMM4HlKzSHqOB3HrX82+wnTk6c1Zo/VfaqaUk 7pnzn8SbiC41Ge2tZPKFqu1j3OelfHL2013qjxSbVIlJdcZ6GvoHxdrkkGs3LSAZLfOxHX0rwzTf 9M8QRyLmZnd8qn9a+nwtK0Dhq7ntPh7Sv7OX7SzbgwGwjgfSuu8Fo2reNTbEFk+UsD2x3FVFhB0u CBBlYgMDuT/9aul+FFoV8R3upS5LxARnHQe9cNZ2N6SPd3hNtGyoRs9PSuj8I3v/ABMbe5XMctuw w3asGQ+aCB0NaXhxzHqUNocMpbLH0FfNZ7FypNo9LBz98+6NJvTdWsTuPvgEEdzWkUOCpHeuO0Gd Layhj3bgo4NdWbwEhxwB1zX45ZqbufYJ3J1QDAPBqQDBzuziqjzqOepqKW6VVwo5PWmNFa+2lHXO K8/1JlaNsdMc11F9NI4OeBXI3IxE/Gciuyi9TCZ8++P4La6YhRsCgDf9e1ei/D67a/0K2uGOIo8x qB3EfeuP8dwLa2xLp5iTDCbf4TjnNT/Da4CadDBE+5I8hl9Dmv1XhStokfMZzD3GfQPnqNgzx35r as51OCv3a4M3CnCqfmxV7T7qVQR71+hnxp6Ws4UgnnNaELEYwOtcXDfrtB6mtS01Bio3CgDureQf xVvWcHnMQgyMfjXIWcoZQ/Qd6+f/ANpf4/XHwa8Kpb6EqtrmokrG24h7eMDJl2gc+g59eDQB9nwW exc4yR6nBrC1qGX7HPbQDcJeD9O4/Gv52NT/AGoPjCb+bV7jxZez3bnoJCvHUAAYH14r6H/Z9/bz 8U6drqeH/idqKz6TcsixSeU006OcDHykAo3JYnJB6ccVz4mnzxtY6KE3F3PpzxJpbaVr99YxuzRw vnJ/hLHOK17bxbZIqQXh8t1HLZ64r0j4g6dpmtadL4m0Z0uEuBG5khOVdHHDA18465oE2o2wSEcr ySDzxX5dmuW8tRprQ+zwOL5oHrkWs6fe7fKfPPTIzV8ydNzY44r49nstb0Kby4ZpI5Y+VJJxXpPh Lxt4haeKyv5kmjDBQ7Lyc14dTLl0O6Nc98jdlChjnPcVk6yjtbyTAbwueB1rVRldS6Y5/KsXXLuW zsg4IBkyDWVGg1I0VTQ8iiuUj1mCW4f5VPQ19E+GrkTptOFZeMDuO1fINxcKb43UjknnBP5ivojw nqM8tnZzp8ryIC34V+ycOvmpKJ8Jmv8AEZ755TNYu4UnywS69mGOhr8EvjTFfWni65u3VoWcliG7 IrEcD0zxX7u6JfNO5ikUnaOfQg9q+cPjd8EbXxLZpdWdgJoY3Z3bbuZc9ivdeu49hjg19BCNjzIs /EKW+YzFFnVuPm3jIGfxFfor+wF8UvFfh3xwvw5S+N1o+pSq5iY7okbHLIDypPHQ/XPFedz/ALO1 xHdMl5KZLdiSVEe0bc9AcZ4r7F/ZR+A2maRrK+KnSW1W0kCx22zEalMFJPM65YfwjgjrnpVzsyGj 9Q1AIJPFTRbfu1UDBwMfWrUONygikkZmvCM9ODVgcDBqrDy47VcJGcCtAJAdoFTpzyarE5+XvUgy FArMzJu2BVqEhec1RXO3AqQHacgZrQ0NudLO9spbK8TzIplKsD6f/r5r518e/s/+HPFV7Bd20/2N EG1o0RdgAGM8j8+a91EuajaSgzmfPHgf9nzw14R8QDxDclb+VArRLJGu2J1z8y8fePr7CvoyHCJh c89arFl4309WGOKzAkkc01GPemnmjOK0AHIqM49aUmmOfagzEyc5ozzmkAOMmlxxmsxoUEin7m71 HgetGK0OmJLuNR6pH9o0m5Rx5ny9PYUDPQ1ajAfEZGd3FTI2gyt8HtSgnju9MfcrWgwhzkPk9OfS vafs7k18UXnxU0r4LeOXl1nT5ZbC+zEHQFthXknA69f616L/AMNi/C35vsYmlZR3jKj82xXn1sbS i7SlY9vA8N43FQ58NScl5LT7z6RNu4qjcWoP3uCa+YL/APbS8F2w/caTJcuQDjcFHvyCa4q+/bet sSfYtBjK7eEMmWDY4OcevNYPNKK+0e9hvDnOpx0w7+bS/Nn2BNpxweMisGbSy2civhjVf20/F1zE ostJtbSUHmQuXJX02YHP4/nXmPiD9r34r3Nwq6VLa2qAHfvg3lj7c5AFJZ3R6XOyj4VZxL4oKPq1 +lz9G30545xJbNsljOcjg1tf8J/4l02EW8kkUm3+KQYP51+SOp/tM/Fy6lbbrEaqyjISELzjk968 11X4p/EHV38y+1ydm27R5blMD8OOKf8AbtPomddPwlx1/wB5ONvm/wDI/ZTXfin4hEAP263sh/eB Vc/nXjur/EJJbg/2j4njEk3A/fDn8jX5Lan4o8V6lGI9Q1OW5Ve7uTxXD6xczxKnzyHf0wxOKSzr yOj/AIhY4/FW+6P+bP0o8Q/EfwLZXE1vc+IoWeJ9smZGbBJxwBkd+T0HfGK8t1f4qfD+1t3kfVEf JIUJ85fHU5GRXwObe4OZA5JYYySf5VRa2KQiFDwpJ/E+/wCFX/aTew1wDRjpKTf3f5H1frnxd8GR WpnjmJcn5fl7elec3fxm8MsrGOGQoOcY714O8KNGQeQp4zWfLb/eB5U9c9jU/XJdzNcHYePf7/8A gHsN18bEdg9rphwOBubBrBn+M+vibfbW8QB6BhuxXmfkhX/esBgdR6VTkKISy4OO3rS+uS7lLhqh H7J6XJ8YfGDRkKVQA5wqisq5+I/ja7mV4r94xjO0H+lcLsYgS+WQGOAMGrPkXC5dlwBxk1Lxj7m9 Dh2HSB0M/i7xddTmW41FzhcYBx/KsKfUNUklXdds2f8AaqePTbmUfu1yvXOfWta38M4VXyXdRmue WM8z3KPDje0EvkcnfxfvN0wZ3PBySePWnWkM93tht13c8V63YeG1uIVB+Z8c+oroLXwiyx7LdQgH HoQa5p5il1PfwXB86luh4pHoGrkt58WxE6d61LbQ7pnCkgbuuRXvmm+Fo0QG7GD3yc1pSeGNPG51 HzdttcU8zPpsDwLGEve1PGLTwo0cysBu3dsYFbq+DrmWXKw7AO9evW9nbQxLG0e8r3qwhCAgDArl qY+X2T6OnwtTj0OC07wlLGQJZAV9MdK6620yC2GAuQOvqavhl3bsYU96YXVDnkjtXHPFTfU9ehkl KK2HhINwO3GO1TSuJFG1QQO1VTIcFyee1MRt2R7ZFQqre53Ry+K+FF0AFMlRuB71JvBOFIFZsspj j3kgGqD6hEBv3DirsEKbub3mZOGGPelMg6HgVmJejcsUilSenHWlmW/kYfZrSSYAnlVJ4/CjlfRG jj5mmHPY1G7uO9aem+EfHGrIDpvh2+nD9CsLY/PFdhp/wV+L2rTJbaf4auELAsTONgGOo578cdve t4YWrJXUGcWJzLC0ZctSrFPzaR58ZiR8vaoDIP4jXven/srfHS/kKPpMUKngMZcf0P8AnNd5Z/sO /FifE02r2Ftt5wcuTz2Irohl9eW0GeFiuNMno/xMVD5O/wCR8eOWcsFb6V+g/wCwprLQXWveHGkK IGWRc9NpHOB9evFZlj+wTrJjjfU/FSLI5+cRxZBHtknH619GfB/9nOy+EOsS6ra67NeyTJskRkAU j0/Dsa9zKsrrU6qqSVkfmHiLx7k+Myutg6FXnk7W0e6a62sfTkmMcHNSRxoQCx2gttH161VDc9eK 8/8Ai54B1P4i+Ef7F0vW5dEcuC0kRO44OQRjByPrX18Y3P5ZlHqeg3Nxpli5N5ewwBOvmOqAfmap 22taBqFzLaaZqMF1NDjekbglc+2a/A74/wCi6j4Q8UL4b0fxpd+LngDG4WNpsxkFfkba7g9BuIPB 4x0r7f8A2Pbn4Li+W40HUtQtPFUsapc2eoufvKOfLBUBhzgY545FHKTyn6O3N1DZ2lxeTj93bIZH 9lUZJ/CvlDxV+3H8DPCks9hJNdXE8HB2QNgnocZ9K+rxEJfNjmQOrqQynowPBBr8tv2jLnw3401G ++Enws8FW1/rEpRJ9QS0zJDhgdiMRlfmOGYsFAyOSeHyg0e1aL+3f4I8Va7p+h+G9Avrpr+SONWM ZBAfqxAB4Xuc4/CvuGCYTxJNGu0OobB7ZGcV+Vngn4YftI/swW8Oow29h4w8P3BEk9pbRYuIGKjc Q2NxAHGckf7Izkfp/wCGtah8R+HdP1tITbPeRK7RMcsmR0PTn2qWhNHzP8Y/E37UGm67c2fwq0iG 906JNwlJQE8ZGdzL9ABXyn4P8S/tmfFrSL3xTa+KINOtoLh4DbYCPujwDhACQPTJ9+mK/V281LTd LgWXVr2K0ic4XzGCZPXgmvy5+L/gzwXonjTV9d8HfGSy8K2+uXHm3Vn56sHlbghAsinGc5bBwDgc UjNSPsf9mvxjr/jf4X2eqeJpvtd9A7wPMeGcqTksOmT7cele8MDj6V88/sw3/wAOYPBLeE/AWujX Tp0hN1PsMe6WTklA3Vc5xg4Hqa+jZI8ZrQszNTuPsVg91jhKfY3KX1tHPCdyuAc1fu7VLzTbm1YZ 8yNh+ODXl/wo8Qx6rpV7YysGm0+d4m9RzwT6Z7VmB6cRU6RbqcELGp3aK2t5LiXO2JWY4wOB9eKA OWk16zXXh4fjBadV3MegVa6EjAr5A+AnxAX4pfF/xpq6kx2unSeWisd3ynC4Pb+HcPTPrX2HIB0F NAVNvNLtp205zTtppGZGDTqds9KbQaBRRRQAUUUUAHSpKjpQe1aGZoQkggivjn9uDSobvwHY3jcP G4XP1IP9P89/seHqK8B/an0mLU/hTqE7L/qCrt3PHIK+hrGqj0Mvfvn49xx5XAPIHWr0YITcOQOt VLQfL6YFXsBVx/ePSuU76nxMtRzq5Cx5HFXYxlwFzWSmGlGPl29atpLMGLIcAU2zNGwpAyGFTIyq h2j86pxkvhj3qwc9FFS0JbkpRZEy3FSLDIAFbkVNbpvjKSDnpipgSMI46UyRnlA4BHNWNzQEP1oA LHirKgkYcA46UAOjYN85GDWgJXIBA4qlhscqAKmBOMKcUAXN5Y896Z5mzKv1NN44w3XvSkYb5ufe gC4qROilMbqkVju27c4qhEzbiACM+1XIzKp7ZrM0LAZlPSpASxw9ISSgDDlu9GWGFHatDMVoPNzk YArKmgEbjPFbIYj7xqGZFmXb1PrWZoc3NHEBhRgGqhXYuCavXdpKi7utUGSQKN3AoAy7mMMflWs2 WFtgGcYrZdkGA3NUpQrBtvNVIhHOTFiWI5INUph8m4/lWw0aksFGMVkXLsCBjgDtREsxZS43fNjH IqOEtIpyetWZk80HbnNV0YxkJyKVwJo3cxhMnaDT45HLqrHBJqN1O0gdKYoZXViMGiwGxNCssYX0 PJqK0iMMnB47Ugm5AzjPWrXkkqCh6c1Y4GupygZh0rStZIiAU5NZUGTHhjg4q5YZLkAfd71mWb8c rgZxjnirscqyEqfxJqjGoJ3E1diRMnedpP60BcVhGrkKce9aUGZBwelZoiyTt5+vpUqTmIgqOKAt c1AJI1OBnNSbztz1IqvHIJVznrU5K4Kd6AHnDENj5SKZGijlDtA60qKNnX5abtIwAOGoA0Fcn5Se DUqRK3Ct0rPUuOvarCS5bYp4pMqJfEbABScinjG8IxqONsxgA1Z2rgO3WoFIu2RTaEPQ8Eeor5d+ Lnwpk028m8U+G4i9sx3z26liY8cl1zk44y2Tx178fScZI4zitOGTC7SM+ua5a9FVI2Z3YPFyoy5k fHngfxjbwsI5pgfMAwT2x25r2qx8QqD5oUuhxzn+lYPi/wCAvh7WI/7R8Ozf2ZfAk+WB+6Y/T+Gu Jk8F/E3RImjSAXEUS8lJFPT+VfL4rKpOWh9/hc9j7PVnsDeJYWjcI361xl1rDRF442DGX+IHpXmh 0X4xXgljh8N3JRc4cqqj8ya9L+Hnwt8UTF5/F84top0x5CAGSNuoJbHUHgjkYOcntFHK5xew6mdp Jts6H4feHHvdQbVb9QY05UnnNe9DYCoDfd4qKy060sLSO1tFEcMa7Qo659TUohAORX1GFwyjHzPz /MsXKtUcmx+1iAW9anxgjdURVxgg8CplJcfMOldpwDxjn9KXB2kAVGAzZIHAprPLjCcGrTAm6AU4 tjAbpTIx8oDnJqYKo5PNF0NsYuAMU8uD7VGcnIAoU/MVIouRzEwVW5NG09+lKoI7VNt9DzUEiwhD knrTzH81VGjkVwwbirIJOOaAH4B5PVadwMY70w57U8KQckcUASAg1GEy1PyTyOlPOO3BrMByP5eV apCSy56CoggUb3PWhHwTmtDQlQbl604AAjPGKj43jj8qlGGbBGBWZmTIyA9KnSSJeM81V2B8hT0q N45FAKitDQ00nByDSq0bMBiqENu5OSa0I4gvNAEuSOGHFTYBGVHSmMvAyaRWkQ8fdoJuxXIJGB0q TaTz0pWI4qMyFm29BQF2TDAQigsFGB3qvkgFT0pqncenSgkthlUAMKaZD0AqElmxkdKUN19RQBK0 meMZxTC3I45pgOPmNLvJOcVmUkTHcRntSheMVX3knAqXeT8x5xVoocyhAcCkySMUgkJU+1PHPU1A DMspANJkHgHmnHO4dxUgSPOSKCGhNzY2gUEHA5pd4J24xUQYZxTuO7JMkE+1MyWOWpchs4FIMt06 Ci4cwucKQDzTlBxmo2znHSlw20gHpSJJJJFChSarocnioQWY4btVlQByoxQA8qGBB4qN4dy8c4qQ 5VdxOaiaQ7cKetHOAzITGacGy2T0qvuznd2p+SQK0AmLZbFSbgg5qIYGGqK5lwmazNDjPsr3Gtvc xnbsrrYU8zOTnArPtY8u7Z+9WuiSRjJOKAJliJXkUww4yTzThcqiYPJFRNd+YBgbaAGk5XaBxQFV SNxzTXYkjHQVHIdzA44oAeWUGl3v07UwHJ9qfuJGMcUXIsLndjNLnacCmeYqjaBk1E04A/2qLhYk kJ3Y9Kjc8Gm+b8m71phbkD1ouFgGRQeetPwD0qM/LWYhd4HHXtTPM5yelMxuJPQCqxkB5XnB6VXM aF08rgjIqs/HfAFPDmR+uMVSvLuFkaNTkjvRzAaGiR3WuXUtpYwtJJDgkKMnBPoK7eT4feNJVMdv Y/NgHBYZP0rgPB3iifwjqMt5AokWXAOeDhe2f519QWvxZ8Oz2YvROol258pSdxPcAe3vRKVjM+UN TS90jUZ9L1GPZcW5CuvUDIzwe/BrHY5kz610fjTxLF4i8QzXsSYU4XOMdK5ZJeSSOF70lICyzdzU fngsIx19agaYlsDvTVG0lj0Peo5gL5mIGG5IpfPCRM+KzWk/erGvNe7an4F8KW/hJr2e5aK5aNSJ t2cswyF2jjGe/pQmOx4Q98C/ytyalguELn5sgda58RSGU45I4Aq7a215k5iwDS5zSxsvNGZlGAR6 0XU6RLwRk1nCFkbbKCrdqVrSeUfvRx2pCKVzftDG2G5PSslbp5gCx5rXudMUrg5PrVVbNFj2qCNv 61oBUdgqZZgD61lyOkspUYb3rUn0lrlAZG2AHpRHpIiJCfNQS0YrRlT+7BLe1Pj0bUb2UBUwB611 dlp2WDMdu3tXRxKY03YHFRzgonnI8I3+/LOeKur4au2Xy2brXePKGww7VEzgHIHWsqk+UaieV3fh vQ7TKXiqCp+bPBFUvsmhE+XbMC2eBu5PsK7HW/D66jqxRnIR4wWPavOtU8Ai11E3FhcMYzghTyVP qK8+pjJdDoVGJ0UWn2lnMj+Xlu2eaqajFbLvuXRR6nbVG3t/E2WjVhcqn8Z4ZfxNefat4n1LWZls 7Mboy2wbOTK2dvA7jPYdaweOqdz38n4d+tTVtlv6Gw17p1nHLqdycwxgkAcEgc14SnjK48Y391dQ SM1mrbVQfKFC17p4xtdZ+FnhtvEvi6xSS0RvKwDuG9h8qkdcnnj2rwvTvGuh+L5fN0SxSyhdsBI4 hEgx1wB+taUYubvM9/Os1p0YLDYTSK7f1/wfMsIX4QNu74z3pJ3dWXZlsEZwex61furCaJWkhzhA egyaXSLG4vU8wkIqdjwTXXofCSm+ZtnXWQklgMYOBivPvE+vnwtqthDfW2+0vesiclD6bep9a9Hs yAPJPUdxXBeMPD91q13pVwcGKzm3PnnIGMcfhzSMbEl7HPbyebExV1yynOMZrV0PxFq2kqzSN9oD j5FI6evNRT75HB5O8Y5rPdRGwMrgL0IrP2yjuzb2bOom8a6g8Yl2bD+ePzrfsNXW8H+lECYgHJ+6 fpXOaV4Zm1wsmkW0l1MAPlRWYj8OleraJ8DPHWoW0czKmnRnHzXHJP0Vea4cbnWGw8b1aiX5/gEM JOWyOZnVmUkHINZzW8tqPtKckDcK+htH/Z6mggVNR8QOZH+8IoBj8CzV2H/CsvhfpNkZdfumxb4j kkknCfN05AwAeOmK+breIeBj8DcvRf52NY5ZO/vaHx2fFoCbZUG734qRdZsTIE3hGYZOea+rXl/Z 40DZIlzZSknufPbj1AyP5VJB45+B1rI0ttbWZLDBf7KC5x/wHOK56nHzdnh8NOS+79GDyxdZnyz9 rtgDKsodV+v+FUf7VtZmLRyLx1Azj+VfYUnxP+FlpFvWyhWKTj/j1A3f+O1RT4pfCOL5PsFsFbnB iVSP/Ha5v9esZ/0Ay+//AO1L/syH8/8AX3nyJdzOUzL8kajPvWHIInOV5zX2i/xN+CVu6NfQRbHG 0Yj8xhtGOeM9Kpv43/Z01CZvN8mLH95GT/0H/CtafHlVa1sLKK+/9EL+y19mSPjm3tmjkMhb5QOB mrYuYwxBPzdK+3v+EN/Z5nJleS2j3gHDXDY+b23cVTj+EvwEuSDbXscm7oVuM/hjNH/ESsH1hP8A 8B/4JUcob+0j4/ssqCoO7byDnilEU00kqMo+YZ3HoK+w/wDhQPw5uVb7FqcwjXkKsyHH6VTb9mnw 3Iha012VHf7vmFW/Tiuqn4hYGX2mvVf8EqeUVOh8kTWC2oTY+95Bk96w5klVTJIrFAevJr7Sb9mZ owHHiBflGB+5z/JquW/wBlSy+y3WqxPEx52xYJ/HdWv/ABEDLF8db8GZrKa3Y+KYYbohZsfKemRz W5a2l1c5KjNfW8v7PMDsoXUkCDgAg1etv2d54FYQXy49QDWf/EQ8q/5//gy/7LqdvxR8u2lnLbYD d+tYHjLWY/DujzXpDbyMDb2z3r7Sg+AMLITNqiHZ13Kcfzql4j/Z08F+IdNRfEGqlrZiVJVlQ/J1 C/8A1/Wsp+IeBpu8W5LyX+bMv7JqPy+Z+JvifW73xRq3mPxEjbcuMk57nNekeFfDEDPHtjF3ckfK kK5JA/Ov1K0X9nv9mfwmry3ttBfyN1N1O0mMf7I/wrvrHxF8N9EZIdAsLZUgG1FhgQYHbnGa0peI Lr64TDSl8v8AgMHlK/5eSSPg/wAMfA/x3qstv/Zum+XHeEHfMvlqFb+8TxivpDw3+ydYWcb3fiTU dl22MR27bkXHqSOtev6n8Ry7q2k24jA4+fnB9sGuZuPF2vXbEy3G0cDCjA/Suab4hx2l1Rj3W+/3 3+ZUaeFp7as77SvD/gbwDYpBpVggmB5k2h5Cfqa6bxFYajqOiXVtHM1q8qjLAkHH4eteAy67fy7l Z8kdPaoz4g10p82pSOh/hyK9PKfD/D0air4iTqT3u9r97f5tmFbNJ25IqyONvfB93ESk1w8jM3zb iaox6E0YePG1V6Yrs7jUZZlEjSlm75rGN24Z3yCDX3ypHmnPGwMYbK7gPaqHlrbsQcZc9COldYt3 kZIArIvp/NkLOqg+1dMYGTMC5iRT5krDk+nasK5lti5Cnhe9a96pclYiWHcGuXnSXazFeBVpCkM8 yM7u47VTZtxC+tSQ201zGJohkZ4q9FZSlgX42c1qkZWMUWd7KzLg8HiqL6M8rM5+XHXPeu03shOT 1qEAyybDyBzTTCxyB0WQIGgTr1NX10t0RVkJ57iuygtZTkuMg9KiazaV9inAFJMtxOTutA87Z5ec DuKiGmPHAVILBT1716D9lijVUQkue/anlYRGEYe1CmQ4Hn0eg21xGGuEPopPaoZPCNkuDGxJPYdq 9Pi037WBBD8q9dxqW08OYmbz2b5T0HeodUqUDgbLwjb2kTboiqN1z3NW28JWbBQylwvOPWvW3sVu o4okOVTgCoZdBuvNEqOCF6e1Q6pUIHn1roPlqMDy1zxxzW9HZWIQ/a4gVbjNdE1lLEU384PNJJpc 0qfIO/4UvaCcDMtfDHhXU4FvbpiW3bWjOM47YxV5fg2LhPP0u8hS2ly2JELP7LTf7LuLVcsAFGM0 681fV4QsNrMYo4+QMc5pqqJwObm+F/iX7ZOtxb+ZEgKiRO+PavLb3Rr2wdo72J4/mIG7npX07p/j q+W3UXUZkKjGQeproIb7TNVt2e5tUJf7ylQ2PxqHULUT4/tNBudQdlQYK8gt0qtJp09rJ5Mo/IYr 62/4R7Rbi3kSBDE7cjb/AA1wuo/Dq61DItZQzr90kdawZR4ZiQqyOc49avwSz2kGYH2gjn1rauPD ur2E8sd3alDF94npWdLASMgYBPFL6vT7Dues+BfihqWiaemnXDLc2oZjHG4G4O3XDdQOOn9c16dN 4/0HV3H2+B7XOMuBuX9K+YrW1BP91q04o7yNMtMHb+7j+teZiMpjP4WbRrWPrq303w9qFgGg1O3V G5VncIfyNcF4y/Zwh8YSWv2i9aG3iLMzJM+4k4xgHcp+v+R4dBcTBwszEY+6w/hrtLX4heJbGMWk NzJLEudu85Uev0rwMRwnV+KNQ0hjF2PQYP2bvCsGmJpX2Y3CJ/EwLSE+u7Gewq7b/skeAtM1K31m fSr2WS3ZZAgd3jYjkbkxyM9u/epNJ+KVzc6erPPJFfwdWTGPqOor2b4Y/tBT6XKdP8VvJf23mAie TAdYz68AYXqK8PE5BXjG5vDEp6WM2Dw40BU6docwC8BUhI6e2OK77w14U1fVoTcy6dPZxIxQmRCC pHqOOK9evviZoMgf+z7iO4nYZjVTyR9K52X4j62sZW2HlsT1IGMemMV8VUrujUtNWsbLUhXwyLNy 00hkYc8Ljiqcz28Ofn+7wRisXWvE2tagd08+0sOdnAxWEl/MseB8xJ6nrXq0OIbdB/Vmd1HdafFG rzTqhftzWnHLEU3Lz6HNeaLeRyj/AEok7ehrqdP1G2kRNso47Zr67B8R05R1HOhJHVPcMqBlcj6V kyz3D5xP17NUk1/Er7FXPvmo2kRwAxAzXR/bVORl7KRCpKLuPWuW1VWmkLOT8vIrrJiCm1BnPpWD qNtfSpm1hJI4rgxuI9pD3DelpI560ggW4S6uofO29ARkflWtfWnhLVAbbVbWICTjO0I35is+KC5E ohuVKSDqMdKbcWYVmDfMTx7ivga2V4hty11O6NYjfwR4WsRnTEMMQ5G52f8AVjmqsWnhFYp9wUJa To+NzEf7xrUtXmtmJIGP9o1tgsBWjK7Q5TuYcdxNDKyOu0H7rHvWzb6taxL5cjZcegrbg1fw+haT XZIUjjGcvggY6/T6muB17xV4Wl1XzdGCQWgACOM4lPdgD0zX2uX4StNKyOKvJLc6v7W1wMREhW7k 1kzswk8gMW45OTXAaj8VtOg/0fTLXMkRxIzt8rfSuT1D4r6u4D2FtFAVPThifzr31llTscftEe2w TXllPG0e4g89f54qx4i1W2nthLcXUcPlcsHNfJusePfGN+f32o+XF6IoXH5Vxaa1qc5YXdy1xGxw c5yfrmu+jlclqzJ1D6cufF+lx2ga0VHmjYfvequv0rnZviRdi0JsooVkyMl0zhc9q8ZtWbaoBwv0 wPyqwuVZlU4b9K2eWQJ9qdnfeOteLO6ThGk4+Va47UNavpZ0mlu5d69cHikdEUCWQ59earfZlJ8w /hg1vhcvhB3RDqXK0t5eXmXlLMD7nNLDLkKhjH4jNXfJ3KVQcGke3YbCTlRXpcpg2clf+FrO7vZN QLtE5/hAG2oI/D1pGzyMWB24A7Gurmb5T5eSe/FZs7SRAsCSa1SGmeQX/gTTftMl40aNI/HmYxk1 xmteCbaS3mS5iV9/8KgHIr3HUEEsaLt+TOfesltOR5hK4yPTnFMk+O7r4Qedib7E0sRfgnggelch qXwh1KxnkgsLa4WRTjdKNsbA8/Ke49x9OoNfobZ6baHi5j3hxjA4xWkPD1smEdTcL1UNzsoA/MC8 8JeLfCV5aXFnM01xJkgoW2Rbf72fWuv8OfFHx94Vnuzqls987gZ3ggKo/uHpX3J4k+FiarMFjtiL dx1j4wT6968z8R/DC9aWXRLGFTbogJeTIDA9cD2oA858JftBW2omSx8TRRae6tlJXckGMYypIGc8 17/pPiDw5r6/arLULZoJVBQ+YATjrjJ/SvmPxD8J9FktHa4EkV8mANikKCOmT3FeYan8LPEukMLj RnaeSArIqjKsrDpgdD0otGQ7n6MJpcT24nhRTGe/BqsdPhf+AV8O2Xxr+Jeh3EcPiSMzBl2pBCRC 2RgA9Djvx3r27wV+0HpeqbNL8TE6ZcY/jIYHP+0KxnSaKTPbW08Fwy4VV4PA5rTtIILT991cnAJ7 VmjUY7qINBIHVhuyCOhrPnvpZEMUPzAHvWHMzU9Q0bW0tJVD+WGQ5DdD1zXrmifE6SxWWKScOrtn BYgdK+RcSF/NIJweoNOa2DMZGkbn3OKz5maWP0h8N/tFQWLwJqM/nxg4KxqOEx+uPrXrOi/tF/Dj UXa31G+Fq3QPKvyMCcYIyf1r8iQZV2ukjhk/2jVJp9V83P2phk8cniiVSwpI/9bzTIRWZV3Z60+I oVDnIPpSiMgkSd+mKUR4UBepr/Rw/ksbjD7gODSp3BH/ANakCbCRJkin4LcfdwKC0I6uCrIT8tLx jcPmJ6ikG5BheuaRd3mHIHPOBSsMjyN3oaY/+twCTjtVhgGG7b9PakDZ/dkDP60WAZ5aNgyHaewq MoNhBBU54NWe/wAq5xShT/EDWUotoSepCsIUq0g+Yc1lQZM0q7NmWJx/Wt2NPMDEnKkECueV1ZzC rEmM8n1r5nPqLlSZ7eU1rVEb0EixIE5JPpzXkfxzEFzp+ixzNtEJkcfQnn+Qr1KCR0RnByF61578 Xbf7Z4ZgO0HcUw+OUUMNxz6etfzrxVS9ycT9iySolKLZ8wDqT90YOQainTMRZCFZNr+5xSNKwaaM /cjJAz3xSOhIQxq2R1z6Gvx+fU+8geveDtWGq2qtMGDRgDa3U4ruGPmbtuQhHI7Gvn/w9rQsL7yJ OfNbk9lr6Dsrm1uljnhfeu0Bh6NX2PDeaxcPZT3R4GcYH7cTqtG1y9itxp1y+bZDwua6vUZRpvhH UktrgwtOAS4OGYnoteeR2n2vCgZHtway/GviASaf/Y8AHmZCE56EV8pxnkMHV+s0la+/+fzPa4bz GXJ7GXQ+ePGl0bOa7LHzpFAK555Pc1wfhx7q1um1K0Mawl9shPXOMkLXUePrmIGCJYuWyHYd+Oam 8EaZb201jbyw7kV97buc7hxmvkrWifTbs9XtNQgudKjvrBDHDLnCnqD0Jr1P4XW6x6TcCRCsrync /qK841Gz/wBFZ7SJY9xKhRwOf8K998N2sVroVpb4BcoCx/vHFfPVqmp2U0bG1VVo0+961LplzBYX 6zyPyw249zVZn2J06VmyMgeK4K8q4JHsK8vE03ODidlGyZ9i6DdOthbiQ7jgdK7hZQ6AlvlP55rx jw1q8N3p8EaHkgEV6DBcnywp+YDvX5Pj8G4VXc+wozTidN9q2rgdajkvMnpWMbhcAk9KrS3asmF6 1y8gX1LF7dhuPSucupXchE6GrjnJLdazJ5duTjGK3pxMZM8q8fQ3M52q+IlHT19a5nwHcI2pSW1r IOTkoOvFdZ46dpLQeWxB25UDpk15z4PP9mX0kg/17vnI7DvX6NwrPY+ezpaM+kIXO7JT5sVqW84h 6rkmudjvGdFkXuOavQyBipDZFfp6mfGPQ6qGdQTxyRWnaznC7h0Nc5anJyGq6kwA+U81oM9Fs7oN GB0r45/bN8Jtr1nBqVvbST3DQJEjqhKIgYsxbqBwMZ/xr6atLx1xntW9cpbatp8ljfIJoZFI2NyD kVDQ4xP5pfEOharoeqTF1kuIi3ykDcD3/DHvUem2Gry65pyRWrqjPkZG3knpnFfsr4n/AGXzqurS z6Y8NraSZYqseBk9emeSeetW/C/7J2hmSz1LXJrhpLa48wIhVVKr06qT196pCcT234SaBfS/CXw/ oGpHy7+C0RZ9/wAwDAnaCe+Fxx+FeWeM9KuPCutm0m4hflGHIOeuPpX1tbaXbaXZLa6ZAsEUagBR /nmvOvHXhyy8S6fLb3yYdUyjgZKuOQR+NeLmeVqrC63O7CY105a7Hzqq2d7CUlVZB9OcVzGsaSlv C1xp8ZUIMqFGOfcU28i1Lw5dNFeZOxsbgOGHvWtba/p8pIMvOMAda/PMThalOTTR9TQrQlG9yTwp 4llad9NutyEoGTcCSx789q6jXphNprtu3FRgfXvXGHV7CCUudqt6kYrK1PxcHtvstsyuCCCRWP1f mtZamjqpHHXQDsyAAk8Y969m8I3Ukdqikbdgwo9q8KeVz84Ygkls16n4VvvtCW0qHKkkCv0rh3DS pw94+SzHlk2fSOhamTgjG84Fev6YsNxbiOcAgjkH3r550Iym7RRjdnP4V7hpdxIy5bHpivojy4mx N4U0aR/PjgTf7qCB9K6uyjhsbSK1iVVSMYAUAAd+lUbc/KCKuAgHmgnmuakEpU8nIrWiIbkVz8cg Hbmtu2Izk9aIyMzXjJAHtVkDDc1WX7vFWcEgGtAJO/HNTdfvVEoz04qZIyevNBmAOM4p2W4o8sjI pQjcYoNBPeg+1SJE3apvs5ODQTJFX6ijBPStBbZz2qdbItRcVjJAJp+G9K2RYMDUwsyB0ouFjCWN j0GaRoTnniukWzcDlfyqUWIbGRjHrRcLHL+V2qUQcdK2pUsow26aNdvXkfyrmNX8a+BPDoK6vr9l bkDOJJlVsfQn14pXCxoLaGpBaMOoryC5/aW+CFpex6fJ4lgWeXoOcEeucYx15z2rzLWP25/gXpMk iC6nvVjIG6JOCTkcZ569ePfpms5VkjWEWfVv2X2qzDbbWB7ivzi1b/gpH4RthNHpHhqe58t8KzTB N65IyAV/SvK9Y/4KMeP54mg0LQrOw83dtabMzgfw5+6OO/rUOVzdQsfaX7Vfh+O58K2OoW6N51tO 0jlef4OSfQY6/nX5z+U7/vf71ei+BP2l/GPxo1ObwT4rnjuJbqKR4oIYhEAIRvZnYt93aDxzk4GK 5G4gWGaSCPkqTkdMelfJ53C8+c/ozwdxCeHqUb/a5vk1b9DNEMm3apqIW7ruzya0VXYMN1pG8sAg 9a+d5j959kjK+zYG7vUbWyqu4nNaYAxjGQartGwU45FHtg+qrsYU1qCGZeKypLZlTOK6OWIgEg5N U5IgQCT+FbwqHnV8Ek9Ec1KGi+V+44xWbeIksKgY54rqp7B5xuPBHSs7+z9mQ/zCuqFWx5FfAc3Q 4uWBUAVRtzx9apzQAEhMHcPyr0GTSUkKllyFPFRHQMyZWPp1q/rLOCeRc3Q8nuLcoMgZJOOBUMmj TzxNhmRfp1r2X/hHkJ/dx5f0qaXRJ5MRRL8y+1N4szjwzHseNRaIhRUm7jA9auQeGfIKxrF5gbv2 FezR+H44XxIA24dh0Na406AQxhlIZeuOmKyeMZvHheHY8ptvDMkqiOKML68Vq2vhRnjYMmR3Br0s NBGyxphR61PI8aRmQ4VPUVnLFSPUwmQ0Ybo4qz8JQJCY2RQp9q0YdEtLZlCIM1vrdWkxUfaAAOKr zXFs0hiV9zL3FZOsz14ZfRjtEbDZQW7eYsa5HWreQMsqBQeaprc2xXY785xTZdQt4uJG4HArByZ1 RhGPwoteY2cDgHmpAX4JPB96yo9RglISME59qa98Zn2RgDbxVG0bm23mlsLjBqF0YOA36Vg3OpXt tykgGO2M5qzpt/Nfxs868jv0zQaF8uq8Dt2pz4YAA8U37zfLg03a5BViAR6VmbRRG7HaeeBX0H+z h8C9B+NF9qkWvX81odNfCiHGXVhnJz6enevnVthVo6+2/wBhbVpZPiDremTKFeWFZFYH7xI+6F9g uetdmU0ozxMYTWh81x3j8RhcnxFfCy5ZxV0+2uv4H0ha/sR/COCRZL+W6vCg4Vm2oMjBO0dT9f51 2dt+yR8DYH8xtESY4Iw5Zhz9TX0pM/yc1XBOOtfoqy+itoo/i6rxrnFR808VP5Nr8jzDSfgd8LNE Ty7LQLTaOMPEG4HbmussvB3hTS4jb6dpkFvEx+ZEjUKfwxXSZNAXdXRGmlokeTVzjGTbdSrJ+rbI Ley0+1UR2kCQqOygCrYm8rhRjHoKekL9NvJ9qnFpMeSnFVynkyqOT95/iVPPLHLZNM3qRmtL7GMZ bC/XiqzR2iNtkuI489MkAH6c0C5X1KbOvpVF9u4tik/tbQ5rtrC31GCWdM7kV1yMde9LJ12+lbQt ZmNaTWjHRkZye1c/8Q7E6x4D1jTI7prJpYCRMn3kC4Jx9QMcVuKRnFW2trS+t5bW6jEkUqlHU9Cp 6irM0fmp8MfiV+yt8GIZmuNYk1fxCoYT3ZtJWf5mY7VyoUccHHXGe9LYfHn9m3xx8T9Kv/DeiXlr 4huLhY4rwWxiRi3DM4BGcjjJGc4NfQGu6D+x94V1GZdbh0ayu49zSCcpv54bhu3OM4/lXz18cPjJ 8CLfw3ZQfDPU7GTUrW6iJFrGilIVPJ3AY4/Hn6Ggo/TRCi7AQeAB6Z4r4S+KPib46eCPH1/Z/CHw Rb3tvOwkkuniZ2YYOFBVk7nOCTwc19l+FdTh1zw1pmrwuXS5hjcFjlsMoxu968e+Nnx11z4T+RDo 3haXxJJOG4hZlAI9SFbnBoMz5Yn8Uft7apZz3b2NjpVkvV2ijDqh44BZycDrxnnp6fZ/wM1jUdY+ HWlT67fwajqSIVne3xtDg85wAM+vA57V8cah+0x+0h4us5bTwr8J5CJUAMspkAAfA5VwmevTcO/p Xc/sL6xqtz4Z8Q6Frlo9rf2d87yo42FTL1BXAwQwIIpNAfUXxV+EHh34waXa6b4juJ4YLYll+zts OcgjJ+oyK/Mr4tfsyfDH4Y/FvwfZkvceHtanf7XHcyqcmPaMbwFYDLgkE89BxX6qfEHwre+MfCV3 ouk6o+jXLYZbhBlhjr9B61+RvxW+EvwT8O6tLH8XPijrGrapHy0duDKy5I6jbLjOeOnAOOnC5Rcp +nXwt8C/BrwD5tj8ORaW1xcjLxW8m5iw+8Tkn6fhivXpc4r89P2TfDn7Olrq8V98NfEt3caqFKrb Xx8uZgcHJiKqTkAYPoBxkZr9DpUJ4PFJSBInh5GPwr4s8E6qvgn9pXW/BV1Iy2mv/vbYN93zAoba Pc/Nj6V9pwdR9a/MH9sm+1P4d/Gjwf8AEa0BFvFNFJuHqjfMo9flJBzjrinGNxn6kpFXyP8AtqfF m3+GPwav7WC/jtNS1xTbQKSfMfP3lQDqcdfbNfVOh6nbaxolrrayhoLiBZ944BVl3A47cV/Pl+3x 8dIviF8T5dC02fztJ0XKRYBGZF4bB6Hnr3HQ1QH2n/wTSjurzwt4i12YgrJdqhz3woB568cfnX6g smOTX5y/8ExLXd8EJ78Jta7vZZMnBypxiv0rmMMSlpyqIoJLHgADkknsKlgUY4wx+bAUdSeAK8Xu fifY+KfF6eBvB0nm/Ynb7fcDBVSuPkGPrXxT+1z+2lo+mtP8M/hxcJcXLgrc30Tg+VhtpWPHVjgq Tnjp16fQv7JHw1vfCnw6tfEuuxONY14C6n83lkBz5a4PIIU/N+VSKx9WqSiKvXAAJpjYPQ1KYyvU 5qFk54rQYUUUVLQBRRRUgFFFFBmXYmxXF/FvThrHw31u0UgN9nJGeh28n9K7CM1Dr9ol/wCGNQtn Gd8Lj9KmR0YRtVI2PwPBaB2gK/cyCfcGtBCMgqcg/nU3iC0OmeIr+0XkJKxOenJNQgRn514ya5T2 cSveJ/s4cjnGTWk0aRj5eQagRFeMMamjcpGUODj1pJmKJY1YKD3FTKrE7geaZGzKNw61NGwJ3HrV JCW4CaWJvmXg1qwyrKORz71RXa2T29PercYGemCKRI/c+T3Iqbe+VbGKYQWJwfypBIFO3OcUAaSE SjLHihjtGetRKylckYqVUDKMHkUACmIjA4qUSMybSdwFRKMtuAzirCJx2GaALkTM4G3jFWcgkAda qQyRpkNxVqPYBkc0GhOWPQ84oyTzTcDqOpow68DoazMyKVHX5gc1Ckn7s7DyOtWnQhc5xVLAVj71 oaCNJvX5uazLiIOMhquSKFOT1NQSjgnpQBzszImfmywrO+2KxK4254q1fRFGbC5Lc1lvCEHmLwD2 qZEIaxUNgc1k3UTONw+ULWi67VJUcmqjyKQC305oiWYjrtUjPJ9KoNuVgQeldBLD5gO0AEVjPC6y McZU9KLMB6bQMyNmpWwcY70xYCOG7DNOJIIAFCkwEcZzx9K07aQsFU/wiqaISPnOc9q1IkSPAH51 Q4FhZNxzjA6VeilMYOOMVBHFkknrUohbBHQE1mWdNZlZIS7AGrgQFVkIyBWHpsjxo8THKitpSNgx kr6UBaw5FOeuATUixKcjrjpTlQnn07U/BfKg9KAvYmQYXC4UDrTmOMMOtHAUKRmpMjZyuKAER9ww OlSlmyD2FVjxyvQdqkRi/NAF0Ybn1pg9Mc0zJGBmplbHTnNJiQ6MnGwnaa00RwdzHIPSsgu4cFa3 IiVRQRnNQDIyhDdc1eDbe1ViNrLjmrX3sZFAyRJWU84PtVhJAoITKg9qiVFLKoHWrzW67cqMEVlY tTl3JBMThWJNTFxsJBNViCEG05zRgg4J60WQe0l3LtuT1J+tXXUgbj+FUIwBgKfrVxW42nn0q47G L3ECnFSgLxjtTwpIUj8amEfXikmWRBM8jil8r+JTk1OYhwVPXrTQmAcHkVYEJRuNy4NN5+6avFSQ ueopu3C8jJoIuQbQpGDzTgNwORzSn72COTSqnXdQS0CNt+90qUYPPWmPCrL1NJDAYwdzcUDJyDjP WkIOfSnFQy8UoAUetBoOUE1MBuBXvUJcDpTkbGWoIsSFMpg8GoQGQZJyBU/4ZzTiARtxQWQlsgel TBFJGKayYA29qcE+YEHmgixIuAxBpyshPzHpSAZNP+zo43ZoLsTx+UDlKkwG+XpVUKiEbe1OMqk5 c4xQBooEQBcc+tPZAO9Yc1zKp3I2RVuG8MiANQBfVRnk0jyYGB2qDecgnpQzBjQK44yngE8U8FcE 0wBSMmnBRz6UBcCcjg9KdEfm60w+i09E+UdjQQTkk8jtSAAtzT0VRGeeajyVBJ7UAKwx05xSY4DG mr843ZxUhO0c1maCBMHd6008HK9qVpFxwaYWBGeuatEthvZs4GMU4FiMUwI2Mg1IpKgGoEmTo2Bh qTdyRULueKjExDEYoLLfyqpPc1CBsGfWk6rRKfkC5oFyi8k+gpwfaQgOagDBeTTTKuzOKCXAuO4G AajSYbtuaovKT14xTYxzuzQI1N6yPil2jkms9Z0QnPWmS3QYHa1AFyRsjaKrgc4PWmRsWVWz+NPk cFhsPNBoTlVHWowWbjoKrvJIpwfmqLzMe1OwchakkVOM5rmNa1KK0ZCznntW0EmnYrChcgZOKq6x 8Hh8Q44rWfUmsHiO4hOGIxgfN/T+dICvY61pTooa5jRz/CWGRV9dftZpjaxHzGX+LtXn9z+zL4m0 BpJ7fVFvhAS+/YVAUe5Y8/hXSaVo0VrCjyndIBjj+dFwOgabfjaMUIhySTmoxd21v8svWoRqETsd vArPnAvb/LGDzTN4ZsnNVvND855pPOUHJPSjnAtM5HI5qPzTnJbFVZLsIMjuahM6MAWbFHMBbN8i qQVOaqC5DnkGqzSF2yWGKarkEgGjmA1I5Cyn2qcSK54OCPWsyN8AkDNVLuZogWPQ+lAG9JfQWqZc g4rGbVXnfCqAB0rCe4875SSR9KfarLIdyqSOmcUTA6I3zEbdmDjrWe1+YVZsZNWxp0zKMtiq76Fc kZMmQTSuBnrqkk6sHG0mshrxo3A7Z5rt4vDcRX94/wAw9KnGg2UCY27h3zRcDzi5vXwRHu+b0FWb F7s7cjAPGa9Ci061jbMSAdsEVYaFUG3aBj0FQBwRtJZWYIDuqSSwvgqoEJNdbsEZJxgmpjLkAlua AOQg0XURKrXGI09Ca030uKYbCdretahYOxXO7b70yKeEYyQGFAEMGkQQRgEbyOpq8IocKhLOq9FY khfpQ1xH/ezTxjGR3oARLCwhzLFGN59akOwYBA/Kmu3TA5qHfnIbtWdgEltraY7nX5h0NJ5MK9Fz 9aTcO1U7u6ECgkce2T/KtlETZFc2qMDtOC36Vz0kflfK3JFdHDDqV0wS3tJZtwyNiluPwrqrL4W+ LtXjWb7MbZO/mDB59jWkYNi50eWxruYg8inRgKSccV7bp/wL1h5H+3X4t1I+Xamc/U5rtrH4N+FL VYv7T8y6uIxyyyFFY/7o6VXsmQ60T5gg8yWUxwrux19q2rfS9UvD5NjbS3EjYAVV5zX1bbeCPCmn sHt7BFI6Z+b+dbMS29oG8iNUY9wKf1ZkPEI+abX4a+KZpVV7UQgjLbnX/Gtq2+EupSPi+u1twxxw N2K96aVNylzk98DrULTFZDtPX3qlho9SHXPlFIIfDXiA23iO3WcxnDRk8MnZhj9K9bsJvAt1Hvt7 SKH/AGXUkrXpN3Z6ZqKsl/ZxT7xtJZQWx6ZIyK8a8eeHvDfgvw3qniBZPsvkwu6Kx4ZgNwjGe7Yw P6187jsBVoSdSFpLsergpxqSVN7s8f8A2ifiJB4b0+z8G+GIY4rm/wAySTKBhIAMOoAySX3AdsDP fFcD8B/hp5bW/jvUWWSBcmwTkkOGIZyDjBGOOD1yDU3w88Z6d8TrqbTDo58y3iWSVn/eYXP3TnnG Scfyr6NhuWt7eO35VIVCqmMBVHAAHYAV83RzeHtlLERcfyR9tXxs8Ng/qdBWk/ifX/gX2/4c+PP2 5NZgbwRpnhsK5vJLtbpgB8pRFZevc5NfF/wfsphpkykGJ2uThHGODX6k/Er4TeH/AIuzabfa9qb2 S6arqUjUAspOQQ/PPbGP8K+ZNf8ABHh3w745Oj+EllktbWONAZW3yPJjLNn8enb9K+yhmGFqL93U TfqfDThUT1RkQS2VkyxyjOPvd61ov7Eu5hFCgEj91q/d/Dfxnq17FHo+lyy+bhQxwBk9SSegrrvD f7PPi0XCt4guYbWLO5vJc+Zn8sfqK8PMuI8Hh3adRX7LV/ga0MPUqdNDjD4dJckMF7Yxg/jWdcaD q5kWKzsJryZjhViQkHPoTX2JB4V8D+FIftOoFXfpulbgfrUOqfEfwtoluE0u3S4IHyNEo5J9DXyi 4vr1r/VaLl5vZPz/AOHO76pBfGzwPTv2e/F+qW63V/PFpUUjlTGxEkmV5JIXgD055r0jT/hH8LvB kG/xIRf3KP5gmZjGBt6AxhiD/nNcJ4m+L/iW8tXtrCVrEknO3kjPXHpx+NfP805luZriWWWWWTkm SQtuP/1645ZVmWM/3qpyLstf1/VmkcRSgrRVz7AvfjT4J0SzaDQ7NGDsVZI9sRUDowGPm57cVwuv fG/xHPZTtYtHDGyFUynzA+o5614LFAHjEjJtq8IklhaBzuB617WD4NwUN48z83/loZVcxlslYZqv xB8c62Vln1aWLaONhwB9APpXGb7l0K+Y0m0c7u5Pc10s1lHHGY4V/wDrVgy2skKtubrXu4XJaNJ3 pwUfQ4KuKk+pii1jRjJF+7ZuTnpWkt9La4MeCvQj3qB2OACowOtQyMynITcvX6Cu36mjmdY7aHX7 d7fbqKbFXuTmr0U+gahL/ozhuh6Yrye5neYeXEQ2T0rLu7W7iUbJHBxnAOKf1RB7Y9rvND0q5QPv Q+nPX2rGl8JQWq+eCrZ/hxnFeZ2zX9pbC7ilYMp+6Tmu7tPF9xd2qfaFC44YDv70ngYB7YSTTRMr Q7GDdiCaot4WlMyvHLNGV6gMea6K11O0nkAZ9g7Z5zXXaaHMLTrIGB/ICuWeANIVjibax8R2ZaSz nuVB4/1rcitWx8R+J1uBGlzOxA2ndI4K+45rp53khdSCGQjJI9azyxU5wMHvjBrgnktGXxwT+7/I 6HiZdyZPF/jGwdRDrVyA3BDO7fzNWovHvjuCUIddmxnO1skVHY2jSOJWXO3nJ6V1KG3MPlbEdj0J AzWf9gYJb0Y/cv8AI0hi5/zMwG8efEGU4h1+Qjphl4NUz4r+JDyb/wC13YLxhWZR+VdvaeGopVWV RhwOnari+CN6B/tIVyc89Ky/sbB/8+I/+Ao1lXqfzP7zgD4r+IEikvq7qUPIVmGao3+o+J9atxBJ qUpOehcjn867C48GaxFK0q7JYx3HGaWHTI4OXi2so54PWt8Pl2Gpy5o0op+iMHVn1kctoOp3eyPT r+TeYs/Mea9QstW0mKOMXMyRsvVjxXFtYebcGRRgDqcVONL86TyJFBDd6+joVklZI5KqZ6KL21f5 7R1miPO5TnNRnUcZUrnnqK5/w7o19pV6pd1ktUbOOmB6Yr2UavoUkWJbaMAnsuCPxroRznm5uF64 +9145qPzYTlWX7tenQ23gPUZQJ714XPQoMgfpWq/gjwmSCupu6t+B/lXSpGUjxo3MTYAzuz9BWZc NMHduFUfhmvoVfDPw6jTbJe7jjGd3OfyqG68NeAIIEkN48uONpYVaGfOYhmmi8587c8YqiYzPdGM Kc7eK9XfTtPZiI5PlBPA6VhT2METkryDwCOtdCFI4dLGXJXGC1Sx6JtkBlIKMORXXR2qIvzjnsad 9lbJZQWX0rRIwepxzaJbWuVtV+TqBWLLasW252nPau9lQKp3rgHNccEaKZy7554q2BnSwJIw7YpY 4ljmPlLkDqcVbRVkkCYIJOa7LTdHt2jy3Vqm4HP2FvJfS+REmT3Nar+H44ZCZCc9MV29nb29qAkS BWHGe9TS2yOGDjk0myonDw6XApBK+Z2ApToyM2GXHPSujhsFjl3BjkdjV9LJ5ZQVQlT3rOU2aJCa Ro9msQLJ83pXRSaPbNHlVANXYNOMMccinJPatSO1PO7jPauZzY5I5u28Pwt8xbZilOiQBmUknPTF dYsaqNhHJqQxo2AEwR3pcw4HHNpcG0RyKDisyezVWKhQR6V372kDZZutZM1mrZVh9KzTBo46e1WQ KiL0qg2kiTcHH6V6Jb6aqDeRnFNlRIzjYOaoVjzJdEjTKpng56VbitJbZWiQY3c816AEjX5yo5qK 4SKbDFAMcU0QeXyXFxEWVHZH9RxU1pq08USgsS4PWu3m0+GXKyIvI4NcRe6aIWO3oD2qwL8mpib5 7hRuA64zmsXUNE0TVEV3XZ644qpcK6qByF7giohM25Yw2AtaAY2peFYo7d201jmL1PWuXW2uYpAt xnOOMV6JPcgwsFbn+dYbxLyZME1oZnOiE+mad5e4ZBxWg0G7IB21XMEqqG4KVe5mWLSMxD7xGa1v tssURjjOeO9ZSEpgt0PrU4KEHawqPZrqaoq3Go6x5kMlrdvbNA4dXRmDqR6MDkfhXpNj8XfFOnCN I2S72kFzL1YDqO1eZzDcSmR0rNSBkZvnrixmVUK9vaxTt3OyFVx2PrbSPjx4TuGkXX7Q6cqjht+S PqTjP4Cu/wBP8SeGNbeMWF8itOnmIkhCsV65xnPI5r8/p7Xz3ORmqsCT2dyjwsQVPqa+exXBeDqN uEbPyN44qXU/SO50+eKHzxiSP1XkfpXES6o9rOzCNmAPY4r5V0XxT4k0+5M1vePtI+6xJUDjtnrX q3h/4u6/pV19ovdLg1BCMEfdb6jJ/wD1185W4PcJ8sWdyxFz1hdd1WSMyBAit0zyaYNY8Q+kip7D FcNJ8dvE88xa10i0stnIDr5oP15FcxP468Uajl7i6BZiTwoAGfQCtafC1VdR+0R79a3NzlJnuXjY Du3Fdra+O/D+m2LDVr+PKDty36V8cPfahdkfablm/wB0kCsx45vPWSTLBjjOa9fB5A4y97Y5Z1Ox 9Q+IfiXo93fW82jkgxhiXP8AHnHbA6Vxep/FbUEuB9gghmJ4ZpRkEewBHNeWrJtBWo1gB+Y17v8A ZNLsYyr2PQ5fiLrcsZKGOHPUKtcxf+KNSuEd5Lpj7A4FYvl5Pt2qrdsNrLGOnWtoZdTXQh4hmPda rqc6MssjKjdwT0rItgyuxMrsnYZPWrsmX+XPH8qiSNkYbACG4rohRjH4UZybfUcivuIUnDVLsKjn gipQpiHI5qULkh2AIrbnIuUZ7fzYmQnDDk+9ZdhZq0h9B2rZlLFiVGCe1LZRBck/ePNAibyUT5sY A7VC4Ktu6gmrhBPDc5pWt1JGTgYrMCgSWI6Yq6Aq9elOWFevpxTmQegyKuCMxrbRtKce1SMyt8uM e/akABOSOR+VRFsghjxWoFaVAGK54I61kXOxBjOeK1pA5wFHyjvXK61I0QZV5zQBkXc6mQRJkk/l UaSFw3by+oHes0SjzNy5GOuKekrPl+x4oA2be8JnjwMCuthvNrZzjHevP7eJi+8HkdBXRqzqoZx2 6VmB0p1OcIVLbweT7Cqr3pkwAN4buewrHUjnnGe1NyYvunC+grQC5PbabKWa4gV/XNYOt6BHqVkX tIxHjsB2q6XO0nua0Yb4xR4Z+MdAO1AHzf4j8MSNHNYvBBtl++0sW9x6YPavn3xJ8LdRjnW5E6T7 h8wVSAMdPmHIIr9BpPMvoGjGDE5wcjJ/Oub1DwyYkKLCGgkPKkAK1SpGh+ftl4x8XfD/AFC302Qf arXcR5MgO0r3KtX0j8P/AIsaL4onOmyI1pc5HlI5HzH69DXT+K/h5Hq5WWKKNI0BDIFyzj2r5W8V +DLrw5fHUNLchIG4C/fQ1DsyE2ffaIjxqigBV61nSKiuwztUV88fCX4s2mtyjSNadrfUQQm5v9XI B0PsfXNfRcyg8nBArjnFpnTF3REoizhfunvS+UGPIHHenDGNvr2pCqnrnispIpn/1/OGM5IUdKeo IBfdkr2qOMOoO4520oODvU/Ketf6OH8liIskgJf8KZIzCRVPGeKeWYlVGRio97HIcfSgBzsqqduS 1G0rtOfmFEo2RLnnByTTWHmkSdFFADtxCYzyf0pFdSgLcHOM1DvY4VvuHg4qzFtKbdo2LwDQAqgq wPOByfSpo3yxPVe1MkJT5AOO9N3BRhemefas5OxSWpci8tVBH5VzFzB5V/IIeFzyfat8bHj2jqTV C6SLPmDkHgj6V42aL9xI9PLpfvFcSBFKmGInafXnPes7xhAJ9CmSEAuUKcjIVTyxrTttzDAYR5PH HWpdRgjTTJ5JSBG6tHuPbcDX878R4dtySP13Lp2SZ8FzyxzXcjpzuOD2HHFWiGKjysbRy3OMGotS s/sOoSWYTb5H8WfvZPBpqkAtHyS3PHRa/EK8eWbTP0SEvdTQ1omiY3BGCehPb6V6h4H1mSO4/smQ GRJFyH7kntXmxWMusshLqoAx2zV3SNVl07VIZrdBuXOCegPasqNV0qimuhpOKnBxZ9OwttKr0zXM eNtNjurQXEb+WUz9wYyfeti2unuVJlK+YAN3lsGUHvhhwfqDT54XuIdoAkX+6f8AGvt5U1i6HL3P m6VWWHqX7Hx34hEkt0sWS+1u5zke/wBK7jw08k3k2snJhO5nHRx2H4VT8X6QbDxc1rs3QzRjywv8 WeSa2tPjhtYB5QIAU8Z6Yr8xzHDOjJwfQ+8wtdVFzI37rWZUuorWNz+/by41HqTg19QWBFvawxIc iFFUZPPA5xXx/aKw1iwUthopFkHfAPXNfUdneBEToN3Qn1r43FQ5ZHsUX0OpMoIyuS3pWdcrKy4P Dt1FT285YFWIzmpCVchmwWxzWJsj0LwRfOArRkKEHI969ytb8S26vEcq47+tfK+lXUtrdh1cqhIB x3FfS+h3MElmoddnAIB718Dn9K1TQ+lwc/dN9HkYD0o5U4Iwc8UiyRgBm4WkM0bY8vkDvXzvszrU ib527VSuosowwNxqy10Bg44HesG+1JIwxZtxPSuinTMnI4zxBaM8EqzH5McexrxzSQbbVozECQWK kmvYdW1FxYyGRM7lNeM2TE6rbrvwC5OK+u4bnapY8fNVeJ7xZXhSNVYjkc1v25Cx8nr/ACriLXBV S6lgD1roLaUGNQc98Cv1iLuj4qW51cUwRchs1PFKWOQ3Wuejbg54q/auqnbnmqJR2FvLhdjHmuht pWRVycg1xdvKGwR0roIJjs2k1ogOqgmDOuT0rbilXbnNcbA7KRxXQ27NtC4oMzZMisOtYd/aiUE7 cir3zbuBU5gMi/ewaAPCfF/hO31G3fKANjg1873fw31e2nNxptwDsyfLIwD+Nfbt/pjTkqgLFete eappiROSowRXFiMFTm7yR0UsROOlz4p1LRPE5nKvZsufpVZPDupWY866BUn8q+oNQ0zEm5UJx3xW TNZxSpukizjtjisKeU0uxtPFzPmC8jnVmWPJc9D/AEr1XwlEsFtAuDtHLD0ar+peFPtE7PAmA+Dg djXb+GvBl9GFLrt/rXrQgoqyOWU3JnX6M0kskUtpHgjpn0r2fR4LhyCB8vf61zuheGrolGeLG3gY 4r1/TNKMEIQL061sZkUKsoA6VpRqxxnmtOPT84AGa17fS1I+ZcUGMjKt7cP25rore1K7SVrZs9K8 sKNhGe5Fbiaco5fC47k0EnOpCR0FXUg/vUaxq3hfQLV73VtYtbaOP726QZH4ZzXn198evglpVuZ7 zxZZhVGThix/IDNA7Ho8duCTir8NsBXyh4n/AG1fgdoEMlzp2oNqyIBsW3U5bPXBYV5LqX/BRnwL 5BfRdCuHni+6GZQPes+cLH6HG0J6CrEdgB8rLk1+QXiD/gpV4vuG8vRNBSAYOWJBGO2eCc+9eHav +3d8dNRu3ltb0WSSE4WJA20duTWkalwsfvyNPQfwgVFcHTbb5bq7gt+SPndVyQM96/nS1n9rX46a 0VS48S32zJ3KrqnX02gV5RrfxA8c+ILhrzVL64u3c5Bmnkc/qTVpjUbn9JmvfFT4Y+GFlGta/aRe UAR+8B3Z9Nua8g8Q/tj/AAA8PxCQ639pYHaVhjZyP0r+eqTVdfuFAuZ55OccuSOPqTUXkJG+93Jd yM7ic81jcqx+4Ot/8FF/hNZps0PTLm8OBxIBGM59favGPHP/AAUmmk3ReCNEjhk2kB58vk/Qelfl hFChXEalgucgjJz2p6WVy6uJFPmM2AoHT8aLmlj7fk/4KFfGiN5Jke0BZQFVYMAMM5LHdkg+gx9a 8y8Tfti/HXxWI57jXJbOVSRttFEMJX2Xk5+pr56tPCniC6njgsbKWdnbaFCksSfQd66C1+G3irVF BtbYkqcnd8n86LhY0bz4ufFHVJpLu78Q3ju2AT5rdAMHgEVwt1q3iDU1aO9ujOj8MWZjkZ54JNen 2Hwn8SPII7yIqrckJzz9QK7az+BOoaghdDKuMYXZ1+ppXNLHzpHJKIzExwv0zT42ijTyW5b+6B2r 620v9nPUZQYZYpNh6k969J0j9mjRiiJeJskj6v1OKzsEEfn3gMSBA8g/ICrkOj6he4htbd8t0OMD 86/SiD9nHR2ON0bxL224Y12EHwR8Pm3WG6x5cfRVAXH40c5ofBHwW07XfDPxH0bXDblRDN5MjHDf u5gY3z3GVY4PrX1N430gaL4muhFJm2uD5kRP3tp/nXv+mfDXw3YSIbZRFIpHKr1x6iuH+NPhl4Li y11Zd9rbxhdxGMg9cY64OfoMV4ebw56Tt0P1TwrzVYbM4RltNOP+X46fM8RX5l9hTDyOOadnAyOd 3ahMKMnj2r4moz+t4w01FRWDAHvSNGWzzjBoQsxJb8KccgYAzUk2ZWlQK3C1j3EsULgSKcetbj5Y DnpVC6s/tRAzg+lWpEun3M95YXx5bdaqNKySMgXdiphpjKxGdoTuK0FiVcO+CRW6qHHOkjPS6gjB Lg59KsLdAglfvN2o+wJLIZCDk1ILa0ik5c7u4q1MnkK/2sxozEkHNC6s6ABxjjgjrVgWtpKWORhe euBSypZoFlG3C/jT5jVIzPt9zsaQMSSeOKWK9u3JUNu9RitH7fp7LmMbgvpUSahbuCY1CY7kVm2O xBNG7KCi/O3rWXcW+pSBYiGVRyBnitr7ZEj7+GPaoptUIJ+UlW/Si4JFGHSbySLIVUf61Zs9KktT 5jvnJ6VbOoO0OY8eYo6eoqst47jcOHb17UrlJEz6cHmDh9qjn8aluNOidQJAcetZpmuNpjQk88mm lNVmJR8qo6e9Itmj9kgjdTFu46c08W9pGTMzYY9s1RgtdQiyuMovf1prWU0jEr16knvQCNJL2yUF 3CjHGMVIl3AcPGQoPbFUFsG8pkLBS1SJarAoWRstjFVI1ii5Bcwz7ijfMvanAEAjqfWsu20+ZLgT LgIa1nTaQvUVEjaJSZSrnNfQH7JeuHQ/jtp8dzuaC8t5oxtJDB8DGP1rwRhhjW54F8Sx+E/HXh3x JOrJHaXib8E5Ab5QeOoBOcc9K6svqKFaMn3PL4jwDxOXYigusWvnbQ/oOlkV+lY2v61beHtEuNYu YzKluuSq1Y0ucajpNlqIZWW5iVwUOVOR2PcVQ8W6RLrXhXUtJt8eZPA4XPriv1OS926P8/KcbTUZ 6dz5e1H9tfwPp8ktu+kzPJD8vOOSOOWHFefaj+31aqWXStAQOv3S8pA6dwFNfAPjOzl0/XL/AEmb d50cuWZhgksoYg/QmuVSEou018TVzeunbmP61y/woyVU4ydNyvrrJ/pY+5L/APbs+Ik5KWNjbQZB yxy459OmK5LUv2v/AItakxCagtqjjG2NQAMe5Jr5OFuGXgU/ycABucVySzKs/tM+iw/h3k9Npxw8 fnr+Z7nqv7RXxKv7c21zrV04kODh9oXHpgfy/nzXAXfxL8a3abLnV7qVj03zPx+tcaE9P1qFwxyS elcjrT3u/vPoaWS4OOkaMV6RR6d8MfHt74f+Ieg6lf3LvE9wqNnLH5yM/n0r9xlkW8hju0GFkUEd 8jHWv55NPO3XtOZySFnQ8fUfSv6B/CUhuPCOkythWa3QlR0BwOB7V9Xw/UbhJNn87ePeWUoVsNXj Gzakvu2/NlwgK2PSr0LZwD3qKRV+9iljBJ4r6U/nw+bPFX7Ivwb8Xa/d+JdbsZJry8bc2JCq569O /wDhxXJeNP2M/hNfeDbrR/B+gw2uq7P3NwzNu39cMR1DdCPT0rs/j1+0Zc/BK/sNHt9B/tubUYjI uxirKAccjB4Htye3t4Iv7Tv7U2vSGXwz8LjBA8YdTIG3FcZ3fMo9enX88VUQPtL4Z+H9X8L+DdO0 PWwpvLSII7J9w44GOfSvQvs6ztgxI4IBOVGePfrXzR+zv8YvGPxJt9asPHVimn6vpUwjkiCkFVIH Bz3BzxXa/tBXmt2Hwl1q98OXctpqEKK0csOVdAGG7DduM/55qjM9g+zQx/u5JIwknG3INcF4X8Be CvCOv6te+G5k+36xIZ7pFk3MWyTnbk4ySelfA/hP9lT4kfEXQLPxNrnxO1F476MTCON3bYzA/LuB AOM/T2Fb/hb4ZXnwK+Mvh+ws/Ed3rQ1WNtzXBGQoIzkcnBAHfPFAH6B+JZrqDwpqs1lI0c6W8pUr g87T1zXxF+zP8J/hB4o02+8ReIrSz1TXJLmX7Wt2/mlPmOPkfhSe56/hX3ojJKojK71ccr2IYV8Z /Fb9jjw34t16fxR4Y8Qz+FZr7mdIG2Kw9Vxgr9M4pMDifjn4a+F/gLx34VvPh69lo2vSXUcUtpZY QtG2MMVjx3BHPBye9fftoWezgeQ7mKLk+pwK/Ni8+BfhT9nnSn+Jd1q7+Itbs5U+a/kBj2M2GADH O7aepJ6cV+gXgTxHD4t8H6Z4igUKt/EsnB4JI5qAOtiyDgdq+Gv2/vh7d+KfhVD4jsI902iTGWRh ncItp4wOuTx7fTNfcIkINYnjHw3aeM/Cmo+G9QTzILyJlbBIZeOqkdCDyKtAfl98Of2s9C0T9kyT SJ9WV/FdnDc2lvbM4WZyrFYiMknbt7nrzj3/AC68a/DLxPefDlPjNq8vl2Op3r20CyZMkr/NvcE/ wggjJ64qbWvhD4qHxkPwlgtLhLiTUxartwJDE753Dsfk59PWv0e/bv8AAunfDT9n3wd4F0feLbT3 jALHJYop3E/VmJwOBmmB9Tf8E87a38PfsweHb7UJUiSZZpi3YKHK8n6LXyr+2l+3Y1xHdfDz4U3e 2E74rm8TIJ6AhCOc9ec8fqPkD4b/ABc+O3xQ8NaN+zr8N7MRadDEYnMW4O0RbezTyqMKueBgDrgn vXl/x2+FcPgHxVZ+CmvzqOuLApuUjXaiTOSFROST7mk0B6l+xF8IdU+Ofxqg1bUyZtK8PFdQu5HB bzXDfu0J6fMwP5H0r+k2K3SGJYYUEaKMBR2r5R/Yr+BFr8Efg3pelXUSDWtTVby9dV2t5kighTyc 7R+Gc19LeK/Gvg/wHpk2teLtYtdLsrfl3nlVMfnzRYDXeIgUzyGCb5AFX1JxXwZ8Rv8Agol8K/DU l1YeBYG8R3MJ2iYHy7Yn13kZ4OO3P54zPhZqnx+/aLuIfFPjK7PhrwqTvghijaGWdc/dxn7hwDub 1OB0xPMB98Rz2txu+yzLKFODtOcGm1T0vSbHRrVLKxUiOMYGe/vV9qGwGUoGaUD1p1ICOipKKAHJ wa0cK2nzqwzlT+tZyda1YiDGydQwxSaLpS5ZXPxF+LenpY/EDWYgoAe4baB0AGOMe1cCI96hTxiv ff2o4zY/Fe/2gJv254wOR1Arwu22twwzXNJWZ7eI1SZYiDqu0cipcHI3c0FQAAvTvTGOHytSYk0b MjE9R71oRYI5GKxecFiCBVpJXKhV6UAbscQAz2pxWQKWFVLWUtCwbseKuB8D2oMyPzW3r/CKcyjc GFOXbJyo9qkaIK2ADQBKmcZJ4NTIGB2g8mq4BIxjFTK6q+MfN600wJ1lHReMdatgYy26s1WByfer YOOKmQFp1YlTipEcRsMn5T1qtux8xJqwsUU0eGPNKJoX1uIJOQcEU4MG5U8Cs1bdYxweat2rAbo2 PNDAtKdxy35VTuF+fcvSrLuq8HrVOWTIAJ60+YBsg3gcZNQlBghqlztwEFV5gVBZzUNgZt4qH5R1 Fc/cRNs44rekJI3Cs+4wUOaBJGCF+X5qzLmEHAJx3rXuPubhxVGTEmA3WgpMzVUoCD0qOQL/ABcY q+EXkdTTGiUjLDIqrCM9WL5A4ojjLEZ6CtOC2MucEACp/IUMox0pJgU1hXrjJFMYSj93jk+laITY 5JXirVvZpM24cH3pARWjhVAPLVoxlWXIphsyr4j4A61rW9kr4AHvQWmR20aqC2Rlq1YlCjBp1vYA OS44HStMWuRkcYoGVlBLACkyysSBwKvpaL94nmpFhUL5eOvegCgswbOOoFODMw5HB71L9mETE0hV 9pUHANAkUtw8wgnOKniYs2cd8VE5RHAxzVobQAE/GgTJhtPy9MVPHFgDng1XVMjnvU8eQPLbpQST iBM85xWjG2UCg9KpRDcdp4Aq1GFXdnjNAFgqcDNW0fB2EZNVo9pABbijJBBzWY+cu7ip3J2q/DPu wpPP86zFcdD1NPDbTuHagDcCIBTljRhkjms6Ockg+lXlkGQ2cUCECOknTirabiQMU9WJ5NTxjB3U ASqCoB71YBz061Bk5xT1I+73rMpMUbgTSjOOlOOQOtMJxwa0JFD5O0U5VJGQc0gCkY7U7ZnheBQA 0q27J596Dj7pqUHIwe1DAZwRQQyMsMbR2p+cgGlVO+OtPAUjFBY/cvAxxSEE8r0pgDZ61KEcc5yD QBEYxnINIqspwTkVNsA+bvT9yr6A0AIh2jB5qXzFUdOai3gHJFMZixzjrUMdyYkNgg80uDkEdqiD bBu71MrDbluM0XHykoZMAkdaabhQSAOBVGSTaQoNNLu+FB60XKLfnBuv4UpjWYncdtQxq6MBTn3K +CcYqrgSw2yk7SeKRbZhIdrfKKFJY4z0q3GCi7TyKLgCg4+Y8CnoxY8dqAFb7pxipBIAeR0ouAZH Q08Bm6HiondT1qEzbGG080XJaLhVkOTShiDntUfmM+C1KOT70yR+5jnbxShwFw/NMChSc0jZxWZo SM6gDbwBTJJgVGDnNNfLJiq8aAcelZgTqM9aUnB254FJg4yOKjbLcd6AHeeQetPMxI54xVNgAOB0 qPzXK4xwKdwLzHc4IJqTaepOKrLKeNpqOW7bkU+YC15/lnA5pVnEprCa6JcJnBboK9Y0rwDLcaHF qkF4PNkz8hXgkds0+YDhuP4un0prNGfuHpXt+k+AoZo0kvyQ3VgO3tmp/Hnh7wpZaTE0cSW1yoLR hSAzKByWz1pcwHgwGec0pIUYArC/tSRySDtXtQl1IcktkGlcDVkOc1Cke3pzUZdiB6U17hQvqRRc CwLkDCk4x2p3nICTnrXOtMWlL45q6lyZAB0IouBdkuCh3dfSo45g53P0qqXA4bimxkytsh5PejnA 9N0jU9Kt7JonbaW5J6nNbWha9ZWty0kvMY/iHPFecLFKkAG3DAd6dEskafKCpfgkVnKQHc+K/irb Oh0zSkWSGRRvdgQwPcY4wa8kkvWyTF8o7D2rZXw/DM7yMwDN046Va/sK2SMK53N61HMwOCuJ3ZiG HPvUaPLCvmy5C/SvQodAsYxukG81ZGn2fl+WyZHvVAcRaNJcEMhO2rzI6EkruBrrUtLWMqI0A20v kQqx+UHNAHIJaz3GQqmmzeH9Sm2/wqOtdwGiHKqFNNeT+8SB6UAYS6IgtRFvCv60ttoaQ/8AHw/m D2rX83uOab5mOW/KgASztlI2pwajms7NsAxZzS/aMnHpUm8E/N2oMyOKzsEH+pUfhTlit0c7IwPw pjMdxpA5/OgB5RO9JuXoKacDqeaYTt6DmjnAm8wqCKiyxzxUZYn600SkcUAKccY4puMg5PSmNLwc nmljcMDvOAKGaFK5ikC5Q5NUltp5iFZ9ij9a2JJIUGScCi2tb+92tZWks6M2zeqkru9M1Hs29gMG S0kRzsbNEVtsXD8n1r0q3+Hnii+QstuIQvXzOD+VdNZfB25lZU1W/EMTAlvLHJYdB9Perjh5sylV SPE0iQuAGrYWC6OFggMpJCgDuTwK+hNO+FHhWx/14N4xIyXJHAGMcV6VBBaWiJHawrCiDACjgCt1 hJE+38j5ds/AfiS6PmmFYx23VpL8K9YlC7pljBPzEV9JyXAkUqcHHtismf5XwB1966o4ZdTF1zyC 1+FWmRyxm8uHm2/eHQV39r4O8L2ZVoLNSwHBYZrYPGGU85pyu3O4d61UIroZOsy5DbWUB3wxKjHu B3qyZ9q96oK56UE5qnqLmZI1xnJAquzbue5pxz3HWlCA/hSSEU5CxB5qhIpxitV4uvNVngJyKfIB lYxSbec1oG3+Wo7j7LZwNdXs0dtBCu55JGCqq+pJ7VDVhxjd2I41Ct8/ANfn9+1R8QhrniFfAmky 77bTpFN2qnJacAFV2+oBzx696+qPFXxl8NaHoesXunXltdvaQSNEscyNLI6qdoC5zyw4r8vfDWvW UPjqLxh42t59U8y4N9Otu4SV7gHerdgfmwSOAeleTjZqfuI+24XwSp8+MrR0itF5n3l8BPB//CH+ A47mexjt9V1N2lnmZf3xRj8iNnsg6D1Jr0HVdPnN687fOXAJIHA/wr5C1z9rzxLcQuml6Ja6cxOc ylpWOR07DPqeK+d9f+NfxY8SExX/AIgngtiGXbbYgJDn+IxhScdsnj65zNPBxceVxuj53EY+darK tJ2bPr/4t/Giy+FN/aadqGky3iXMYkLoVUKCSB1+hpfDH7Qfw21yyj1C0tZoll+80kS5DYHykgnk V+ZOr6ct+TBqKyPGQMyM7F2IPUsTnNe3/DrTodP8K/2ZCmIUYFd3JzXzWM4IwlRu6cfR/wCdzZZj M+0NY+O+j6Oxk0i0aeJ14YcDNec6h8XvE3iSRWSeK1tHGPLRcHPueteJ65c+WkcWdqn06/ia5GDW 57eR0UBAD69fesqXBuBpaxhd93qaLHzfU9+F7c3EpjuSzB+7HdS380FtgHCbVyOMV5ppniyEwpFL KGlJ4rX1DXYbmAQkZlx1zXp0sNyrkitDP299yld3X22VipxuFRw6W0q7mO0iqlqIwfMJ3DNbCXSd G78Vt7FCuOhR4FMGA6gdTULo0TscFdwz9KmnZdibDzis2a9aCI+cclugrenAzlMDM43b+h/WmXsd s8KlmwRWbPfp5ICnBP6Vlvcs6ku3fpWiTMpSIdoQOVbO39RWfJOZVOPkJH6Vaa4ITdgbRwazbhkk mWQN90cCtORGUyHT4ha7iQCScZPar946yoCow7DFYE93IJSD0HI96tQah5ro8ibccAHvV8qMy40G 2EBhwR0qJAFOwLtxzV2aXcVKjgd6r3AYpuU4xS9mgKrXnkvycEHqOtalvrNwI3iaTI7Vg3KCVdob aeOarhm81UT7ueTR7NFqR6Rp+tfYrEQzuX2dT1IrpLHVtNvApeQ7OBkda8aN8xZlA2gZHuami1Eo jxkEBsexrKVBMqVU+obG1Aj2j7vb8auW9ukb/Kpy1eAWHj/W4YooWuVj2nAZhngetdbpvju2nvjb z3HmS4y7ZwufauSphSo1D3W1kliYsAdo4/CtOG5Cn1rzaz8YWMlxFGhOxxg121lqumyuNjjI4Oaw qUTqjUO1tJI2j3OOT2q1KYZ42iZVAPXiqls9nOv7iZXPr0qSZXtyUfj1FcvsyzHufDllJHmH5G65 Fc6dNewkZ2w4PQiu2GFxt+6azbkRSAq65x0rWAWMaOckbVzkUM7SDaeMd6tCJGU7PlxTDbljwflA rqhVZhKkQqpK7A2D7elIz3CxENIxI4AyelTJAFYlquwR72ztyBXVCqjBwsZClyRHMhO7niqlxHjC bTsHIyTXfW8Kk42gcd8Usmm2cqYmTLHiuyFSJlynI6cX28NgZ6VrtGpRS2AQavnw/brGXRyigdKy lAUbGPA6VtFksuvbI6B1OcU+KMq2cfhUcd4qhYmxt9qsT3cSKGRulaxCxzWvyeSn7tfmIrzqRt7B pMgiuz1i581xzuz6VkrbwBQ33vUVoFjOsrZp5g0eSuea9JtY1SIKB0rJ0uOIQ9h6VtpsAzu59KAs Wht2k4560/eeNwJJqFZFx71MkisNzHkVixxgh4XcRuGDW3p8RkfaegrG3BlLDqa1tHuMTGHGSazb LsdUIxtUDoKlHy9eTTNzKNrDinqG4J61iSPHPJFNDFScGnlTg1HwuOKzLGk45PWq8mCee1WC4KnN ZU85Uj2rMC6ZMLtBrMnfac4zSGfzBUDHPGa0IQbiy5Y4waiDu2TnKimuSvBGRmm7lAPpWkRC3Drs 96wmReWYZq1c3DMSMfKKoEjueTWqAqXEETqdy8VyM0PlsxK8etdjPx0OCaxLmLfkjk1ZMjmpyoXa oINUJNxA4yO9brWzu5aTjFUpLdA+9SfpW6RKM2RWCgoprznUoPEP9rKULNbJltitsJB6gH19M162 Ii65PAFRG3VzuI4PtTAzNSbw3ILWbw5pl3ZSeSouVuJfMLyADJXLEDnPpn0rm9Pk1Fp386MxwnO0 H5jXYNbqhOw1JGiKCpTJ7VDQ0zm/lIJbINLjjcRxWjfwKsecA59O1URG+xHXoOoqzRSI228Dt61C YiJMjle571Zb5gcKPbFRqrFjzWZZr2ke4gBflx1rdhhYDdu4rIsgEG5q6CJYwAT0NQ4GykCWxBLd jWvBANoAHJqJVB+VRVqIgHuMGp9mWpi7GGVx0pY0LYZiAfTNTFG28H71ORQpEbsFb6jNVGJk5XGg MXIIqyF2xEdaVCgJw4+Wmb1DFd4Ofeq5TMYxCoNw4qm6M7HHC1bf52GTgL+tQlhGSz9KOUDnpYds hY8ntVaNiHB7DpV29lVX3rzmqkUisTuGcUWAuSMXUFjwKBygI5xSR8g7hgGpfLIUnsapxDnKTRmZ uW2H2rSESIihDyeOaropBDgZx0rQVD5ZJOfSkAxlIfaAPrTxhCd+DnpUJDKw8zuKsjyxtjYcnpRy ktkOPkJ4HpUe3BK9j60k52Dk/dqhJM27g5PagktyPt47etQnYVIzWdJcOFI6k1A08kZ3g0AaU0yx IST07Vw87SXE0m8EqDxW/czmYADt1rNKHzGIH3uAKAMn7JAvQYZutXIrBHYRocjvUzxtE2WXpV20 WJiVB2nrQBE9gsYDp/D1qMLK7/Me3FbsgHl5P3alg0xZ0LEEEjiswOfWNmbkcip1tGfK9M10tnpi oSH7etSyWCLLuBrQDl4dNcODnIrTWwgLYI6VqmFgBsFSxwjafMGDUNgVItNiVWCcA9qpXGnBE3Kx IHvmt6NVXrnAqGR9rnf936VkBz8VhAH81kJduRXl3iXwhHqdzK0aqWY5ORwa9pmcSOsiDAHArJvI P+W8HLAcgVEzaCPzy8cfD86DrDa/YqYMMDkcDPfivo/4d64useF4ppGbzIvkJbufarnxM0ODU7Z4 wNr4zyep+lYnw30mbSdHa0mQqu84HTntWUp3RqqZ6CXZApxkk1IqkMSzdaIgSdp5AqVk2r5g+bmu YbP/0PNVJVt27NSZQgLjk1XBHmYPHpU+WByBuxX+jh/JYyRpAQAelQKTnI6Z61akBxn7pPamMMDY elAEcTMXcHlT608kt82zgVHtI+QHbUxzt2rwfWgBwaN8EgD2pquq5QDOT0pHU7VbAZgenrTwGA3l dpz0oAAzEsMc1GeQWHQ8Gpdyj506mosIxDrnI6is5M0WxK7RxrhcnH9aoXYjh2SAHHTHqTWtEE2F EG4HkmqeqBUt0Ujljx7V5mPpOdNxOvBvlmmyqkiy7QqjI6U7UYJNRthaq2AGGfftVLTw7CTzxwnQ 9M1qQuWkGMYPQ+4r8RzyjyzcWj9SwFTmppo+J/F0V1Y+Ib62ux9yQop9hyK5y2ZvKKs2188n2ruf ixabfGF3qUjlRNwE7F1rziCfcC8xCE/Nz6V+B5pSUa815n6Vg3elG5sKXZSMAJ6f1plzHlBnkOOR 6iqguTuAd9yMMDHb61E8jTwqwGGHy8+ntXkVYXOtTPePAerW2oaabBCIHthhFJwWTvXdqVXCydR/ XrXzPpOqWemXEUxGSGG8E4PXgV9HwXgv7RbtAPKkAIHp7V9Jw9jFH93I8zMqF/eXU4fx/oqXTwa9 CC7Wkf8ACcYBry+W8jMiJFna3zE+nFfREgF1C9lNDvimQj0wOlfPeuaZForiKJjtLFQp5I5rz+Ls FdqtDY9LJcTZeyZZ8MSRf21aSBS8s7bOTyfw9BX1DHboYkeQ84AGOxFfMnw/spbvxKt2kTbEUgEj gN7V9OSOPJSPGM8AD26mvyXGW57LofZ0FZFq2lCv94kCtLJkBbdtWuWLhFDKSMGuit5hIm1lGyuV nXcmhuo7W7iNySUyQa940nWIrq2SSJ8AAYH0r5s1GaOIqmSw9639N1Zo1RVl2J0Ar5vNsIpq56eE q2PpxdSaQKXbA7gdKWXWIrYff+U14dZ+ILi3fZcMzR9q2n1P7U25uMdK+Zlg7Heqh6tPq6xIBbnz FfrnqK5ya7Bbdn5s8ZrlILklmIzu96nSclwsnzc01QsHMaF5fAQyJIu4kHHpXkkryW98J1XDnp7c 16RetHsdiD0ry++uli1AE8oGHIr3clhaoefj/gPY9MnkeFS+RwM5rpradpFJzwOgrl9Ema9sVeVM HHGK7CKIDYAnYV+q03oj4aejJ43IU55q0gb5ZOhFTRWuWDAY9q2bezDHaR1rcB9puZR2NdVp6Z+Z +WqlZ2YjPSurtLVWwqcNWiAlt4Sxya14xtxUVnHG0jRBwSvX8K1k+wwrI93OkMcalmZiAFA7mgz5 rixx9+9X4rffXneqfFj4V6JdCwv/ABBCk56c/KcdecVhSftF/CCxv20uPWY7u7AUrFGTl9wyNpIw T+Pt1oA9yitCPm2ckYPFYmoeHIrncyjDH0HavlrxB+3P8NLOJv8AhHYZJ5kbBWVlH1rya9/b61h0 LaPodpvVuS7ZOM8UAfa934KUpiIbs+ormx4DYSeTOdob2r4I1X/goB8V7qSWDTtIsLeIgjzQm5ge xGeOK881H9sT436nbNAdT+xl1I3WqLG3PXB5pplXP1bsfh9aWTpNcbWjbIAIAJ/E11Vta+ELB9tz fWsITAYNIoK/meK/CPxF8YPin4kWFNU1/UZyrE5luHwPwVhiuMu/EOrSt55upJJcjc8kjHP5k1YR P6ANT+L3wL8PI/m+NtMJiDbljlDkEf7oINeP6v8Ats/Abw9dm2M93qUYAJltoiyc+mRzX4ppdXMu XuGba5wQvAA981mwq5la3jYyRq5wGJP1x1oJP1l1/wD4KLeHI5ing3wu88fJWS8lWNj77ADj8a8x j/4KMfFZpGZPD2mKgPy4DOMc9eRnFfnyNNuZHXcg8ph75zVyHT7oxMyJ8qcYppiaPqvVP22f2gdX F3FJraW0cwYRpDCkYUHoAR831JO70IrxfUPjf8YdWZpNQ8V3jScknefmJ9cHtXJW3hrWdRujHbQH cB34xnv712ln8I/GMzLCYFkkkwBgHPPtT5hcpwV/rHiDVXeXVNUnldsEkyNz+tVo/PD7w7yyZADb ycV7NafAjxLNK6z5j2e3NdhpP7OGuXKl5UdgOhXIY0rjsfMlxbu21ZpmHOTliBUcdmi72iUufUZI r7l079mec24ivgCHPAPLD8a9Csv2cNCtYliZCpAweeDWdwsfnDZabc3E42RyEN0BH+NaaeFtbluC IrOUbRzkHDV+pdr8GvC1pFCBArtCMFivJrbh+HOgQuTHESAMDdgiruP2R+W9v8N/FEqCUWjbXGdw xx7YzXV2fwU8U3Jt5JTI0cyBgAhBUnsffHPpzX6bWPhDTrTgxqV/uiuut2ggi8mGFEAAA47UpTsH sj84/D/7NOoTDfq3nrDnlfuHHsf/AK1d1afsv6emy6aQFenzA5/rX3C2XH3Q1Tw2kSsHZBkVHtA9 mfMPh39nPTbORLi/ECZILxxqSHUdicjGa7qH4FeELcGKYkwlvMCKMbX9QT06c17Y80ZbG3GPSmEN IaFIrlPPn8F+GLNFjitx/vHrW7pmnaLYJ5cdmkh/vOM1uvaQTAiRc4piQQw42dqnmHYEsbF2yLdI 8/3UAq2ttbwRlY1Bz7Uxp1cnIwBVRpmRDgE0cwcpPIqJgdB3FVCQrbl5HahC85y3AqBsqvHOOhrK 5UUPNxKXIHUUst3JtqlvdQcDk1AxuGwGHy0jcupfyB+uKxvirpk+vfD27e2KiSwKOCeAFdgGHQnn 0yKthQDk1o3q/wBoeGdW0llLG5gwMHHzL8y/qKwxEOaDR62T494fERqrdNP7mfGNuZXQKcZXPP0q yVBPIHpVOOVTc3CYxtkZcemDVlgMHtX59ONm0f3TgMTGrTU4u99V8xu3byp+WhmK4VRjPelclkIx +NNL5xkdOMVFzsb8hvPFNuZJFjLwj94KAcnavBFSgsxJJwRUuRFjmvtE0pYTZDk9KVWkbp0Jxirl zPEkrH+PHWmQ3lnKgABVvcVtFmMoFO7N8rbbYscdhTDbXMoLOh3MOtXv7SkhYgR8etNN7O0ILgDJ 4IrWJk4lBdNldDGDtPfNWbSF0b7LIOP73anT6hJaoskKb/XNVjqck6KyqEY8gUcpXKTDSPKctG4G TVuHToxzI2T37Cq8M9xdoGxtK9hVLyNSkmKHcUJzgVDQ+Q0Dp9p5mQM56HNJJZ2SncT8y8detZk/ neaIkJDDtWh9nmEaqwBY9zWlg5SxF9htsyAgZ4yeahe40+N2ld8MBwMcGkFgzqN7DA7VGNMMhBaV cZ7DmnYaH/2lbop8tcx+gHNJ9vJIIUqCM80q6RGJOZOnapH0+3VVDc89zWYmUv7Xk2bihAU4OKsQ X0smFlUDPT6VY2WCEgIFHQ5pvm2kEyhiCoH8NAIJ4Cp80fMD0x61nSvdIA+dxPpzXWRNE6B0G5TU 0caL91Bg9sVUjoKFqjvEsr8cc09lww+Xj1q3n5iq5KmmsrtLt6qP0qJAUJgQd+OnWseWEhWlfopD D3xXSmPOVHQ1lXcTOoz93P6U4/Eabx5T9rP2XvF8njT4PaLfzlPOtohFIqnJVhxgjsPQelfQiEA5 ZQwPBBr8qf2MPiTHoHiS88EXUgaG6AeDC8tI3y7W6DgdznqPSv1P+bareo7cj86/Tsqxaq0E3utD +FPEbJJZdm9ai1aMnzR9Ja2Xo7r5H5C/tY/DQ+EPH9xrsEDQ2V+RKW5ZcnAyT0GTgYz6Yr5U85M4 BzX7zfFL4a6L8VfCk/h7WYwX25hk7xsvI/M96/Fb4qfCrxf8KdXGnavYO9vIW8qZeU2rjq2Md+PX Br5jN8vlCbqR2Z/QnhVxvQzDDQwNV2qwVkv5kuq9Fv8AecSsgDAvxQHK5J+bNZEcoY4DBmHbNWFl fHzcLntXgH7F7JxNHeCKrSdMCqxkfqGASi0j1HUroW2l2kt6wOMQoW5JwAcVUINuyQVOWEXKWyOj 8G6RP4h8W6RodnEZprm6hO0Zz8rgnkdARX746Favp2hWenyfetowh/Cvh39lP9nTUfDaxfEXxfCk Wp3IY28DDLRxuMEPnoe/FffcncdzX3WS4J0oNy3Z/H/jFxZQzHFww+Gd4U769G3vbyXfr+JRfrgn FOjGQMcAUsxSBBJMdqngVKiggMvIPSvcPxg+df2jvDOryaTpXj7wxCt5qXhiYTi3MYkaVAACAMZw AOnv64I8Qj/b/wDhTbaMYtU0XU4dVjjxLBHEGTzum1XODgt3IB9RX2N8TfEl54M8D6l4osYknnsE Dqj5AbnBGRX5T+N/jX8dJdJHjK3+Guj2Onag6mK8mt2nJkLkKzPvQqQx43DHc8Zq0gPsL9k3+1/E c/ib4k6jpc2lW3iS48y3jm+9tHXOQDkHqSOewr7B1TSbPW9JvtFv0EkN5E0TD03d/qO1fnJ8K/iT +0zonxT8M6H8WZrSPSNbSUqluqNHwoOGZOjEkbcnkH8v0ygK5ViMbgDj0zTIaPzn1T4U/tafCe9n 0r4O6lDe6JLKXRZireXnn7kgIBPOSMD29D4Q+E/Ek/xHk8b/AB28T239vgeVHp8jKrRkcEqAQAuC Sqqpz146V9KePP2qPhB8ObqWx1u6uGvYm2mKKFmJ5wTuxj8Dya+MviT+1l+zh43lmuh4T1DUr75A LhCLdgxJ6ksPTnIJz2oEfqRbJDCyGE7owo2n1Hb9K+Uvi9+zHrPxI1yXVU8Z3Wk6czbjDGxG3PXH OBz/AJ6Y91+G3i3QfGPg3StS8PzF4Wt4zsdgZFBHRvftXhH7T+ueIryXQPhr4YvHsJvEEojlmRth AZgoGT9c8c8DHPNAHz1rf7FXw3fTL0yeL73UNeSMmFnuYijOBkBkO5iOPUe1fW/7NOlax4e+EWla BrsLQ3Onx+SAxz+7jJC49eOp6E9K+fD+wRoEuieY3irUH1dQX81QioZAcqQMFhhv9o/yr1f9mTWf FUFjrXgHxRdHUJvD8phS4fBkKg42n1xjgkk4NAH1CeDVqJxnB6VXaNhzUYbbUJgfMWg/s+6Xa/tA 6n8VbqBdhUNbqwDbHcYLKeqnjP8A9avHv22/hR4z+Nut+G/AXhePNvFmWeQ52qpAyxx3ABAGeTj8 P0BEpq2jq2HKjd0zjmruB8PeFfhb8Of2J/gdqev29utxrBgzd3eAtxe3LcIgbnaM9AOAATzivw60 z4sWNv8AGWH4teLrE661tdyXX2Z3EfmlwxUHcG2qGbcODkccda/oE/aP/Z58V/tBfY/DU2sLpHh2 1AkYRr5jyTngsRlRwB8vpk14z/wyh+yX+zZoP/CXePLd9SktP3hutSk812lTB+SNcLgdduMUAfGX jL9uH9pjx3oU2o+DNIl8O6CsDySXFvbs5WPA5M7KoyB6c9/p+duv+NvHPjvVwdYvL3WLm6kAVXke V3cnjanPf0r60+LXxv8AG/7T/jG0+FXwu0s2OkysUtNMtgIBMY8t5kzZVQoAzg4APua/Tz9k79iH wv8ACSGDxl4zgTWfFk0Y+dgDDbbs5jQcg8Hlu56cUAfPn7H/AOwpdWxs/iV8Y4RK42SWWl7iVUgk 75iDhjnBC9OMmv10gtLazgjtrSIRRxLtVVGAAK24rfy0EapgKMAA9AKZJBJ/DGalolSMck9MU3mr zQTjqtV2jcdRUlEVFFFaAFFFFACqOa0rbrWWoO6r8WR9azBH5nfth6EkvxEs72JGIeFi5PTIwBXy UsEsTcjpX6z/ALQfhvTNR8LXV/dWguLiFC0bnqv9Dj3r8p53MReHqVZvy7Vz1FqerTndIiDHYfSj OOvPvSI2FLOPwpQA464rMsdGT909DTi4Tg8YpqFlBUDP1pZMyAL0IoA1rYo0YdcVaC561i252HYD 1rajjYrljzQZj1ATb6VczuX1PaqMeASr1NE6qSoGDQBcWFynIzmhoyqjjNPiuHU7SMg1JIAcFT06 iqkBCoHlgdPWpGjkZcp6UoKHvVqEKcn16VCYFaNZXUKe1XYYyByelSbM8A4NSbCDlTwaImg0B1JJ 5FN+bO7GKeC3HOcUo3MSR2oYEsSKzc81YltE4IGcVQUyq/XFaHmM2KOUdikysJMAcCopk82MgitB hgFiagzlOBUNBY5uWBo/XHSqMsTFcjk11cgWYBCMYqgLVVcknigGjkHtDJkdAeKh/skKQVbgV09x AqGoSighR0oJbMA2YCkA4/CpTpwWPJHStoRY4xnFWkjNwCCOntWkloM5m2tlXIA6082fmEfPg11D WUTKNvykdareQsfQVmBkJpidGPWtGPTYwPMLZxxgVaEcjH5hgCrkEY7cbauxCZlfZRuOOhrUto1g iH95uKfLEw+ZR71ZhQnIGKdix8SFmx6VbZRtAWnRqc4HFWsDbnrWY7lIoy4bdx6UA5JzUzKrA1Tk R88dqAuWGAZQTVeSMA7m7U5WYgR5xSsxI2NyKAbM903MGb8KlWEKcryR1qQx5H8qegwvuOtArDCC wGBUpV1IbGBSAbm3HoKsKCxOTkelACZZydgq7GGdQfTiq2AvzR8VaibIy3agCdAfSpYxzyafgDAB oKkHgYrMlIeFG7noKdwRk8Goh1I71bjZCADQULGnHFW0jLnjtSoqsMCpFbyyCKALkSyFquIxGKrR zljnpV1MEEgUAScnG2nIhByetKMYz0FSxkNwvNACcnkjBox2xVgW7ZzVlYCRjvQBQUZGwjn1ox2B q/LbLGu/ue1Uj8owe9ACKrEZHIFPBJPPaoTIIyVBqFJ2Y/LQQy2/H3WzQRnBBqMS7vlIp555U8Cg sFIDY61OCc8dKpfaoY+HGTT/AD0IBHCmgC2V755pnlofvjJpUk3cY49ac4wox+dAEYI6FeKlVABu HSqjPg4Jp6yjoTgVDQF3aOvWkIL8HpTFkXp2qnNd7DtAosaOJeaBflB5NQYCueOlVDfd+4qWKZZg W70rENMtFCy8HpUITbu35JPSgTqpCmkmvoUPlry1BZaQEAFuM1OvJG48VVhkaRMt2qRuQADjFAF5 VUH5TSH3rOa7WHgmntco8W4UATsGcnHSkSA4yeMVWN4iqoBqVLpZOVOcUAWhJs46kU4TnPSqRni+ ZmOKqPqcIYRLxn+I0Aa73AbjpULTkgjOMVkLdK5OHyaSecgBl6iswNdZQBkNmmG5VTwa5v7RK2SD kVAZ2U8HmjnA6p9QB+UHgVUF4S24n6Vz32pgdx6d6c8/O7B29qz5wOn+2xqMngmqEtyXO5WzWM7t t3EYBqqrSM5ESE01MDqFu8fePSoZL2E7gTiqEVrfvHu8upv7FvbgYk/d59aakBVkuTK6CDqpzk17 n4R+JI08C21hBNBGgVFXjb6nAHJryC30F4EKO6scdutaNnpqW5JxknqSKnnA+qrjx94WTS5L61vU aVE3CNjh8nsB3r5o8Xale+ItSa/Zz0+Vc/dHYUJaqOw+uKspAo4OKmUrgcHHpt8cnZlRV62tbgk7 4yAK7VdicEcU5tufkXI9KOUDnDZybMdzVd9JuGIbOBXUbVJ3dKVzgZ6UuUDn4NCtQDuzk981pR6V ZW53BCTjqTTyxJA6ipQ5cFOn1pcwDfsttnLRg/hUyxQL92ML9BTM881JuGOOKYDigJwTUWEB280h Zc5BNBKseOtIB5dVPFAkJNRE4GaUSDHNZhyE+9mHNNZzmk8wEcVEWrQCXefSot7A/MKQtg9aYzD+ I0APZwoHNDkEDH51UZmBAPI9KaX/AHnzDpQBc3BVABFQM5qs0ylsN8op4LMf3WX+lAEnHWn+acYa rcGj6xdoskFnIVJwSRjBrbi8DeIrnGLcp7mrgriZy3ndjT+pr0RfhPqBMRnvNnGW46Gultfhzo8O 1ruaS5YHJGdqn2wK2VGRjKolueHeaZHZF6rTlLso2o7/AEU819LWnhnw1aszW9koJ7nmtu2tbWBf LhiRR6bRTVCRHtz5itdF1m/YLBaSBfUgiteD4feLZn+W2UL/ALTYr6WWYgbF4x6ACmGUbvmOfetf ZCVU+f4/hh4kkZHmeK3QEg55bHQ4rqB8KrfZlNQ/ApXp0kgbgGmBiK1WHXUidZrY5vSPAXh3S4cT QfapWABZ+30Arurd0t4Vt7cCOJOij1rLMjdqesh6HitYwS2MlUb3NRpyc5NVmm4qAbmzg01dw61Z HMWVbHNO39u1QAGrCR7qA5g3DvVaRNx6VfERHXpS+X6igkyfKPTFO2Y7VsxwYHC7jVe4ms7RN97N Hbj/AG2C/wA6Vx2Kgi9qlMeO1eX+Ivjv8JPDNt52p62spyQFtwXbcM8ADqeOnWvAPEv7aui2YMHh TQpLwY4nnO1Tn0Tr+dR7VdTSNCTPtiGDf1XNV7lYbaCS6mkWKOJS7FiAAo6nPpX5VeMf2sPir4it 7i2sr6PR7Rz+7FvGBJ+LtknH5e1eD6/4s8c+KZ3Ot6zfajNMuzyhK+xxwceWvGPXisqmJUVc6Fhm frt4l+OHwl8MsLfUdehmnxnZbETMOMjOwnGe1cLD+0RpviHUF0vwHoNxqmd2Zpm8tcA43DAYgf72 PSvm/wCAf7Pn27To/E3xAtWjsmP7i1ZtplGPvP3Cg9MHn6VufEr4n+F/hpp0nhT4X2MNlqCyvG77 dxVlbJyxJ3dT1PA9M18auNKdXFrB0E5Pq1svn5f1qavCNR5pH0p4s+Lvh74faCuqeKLlHncHZbws GlkZRkgDtjpk4Ge9fnF42+NfxW+Kmq3J0mGUafJ5kS2kIBBgJON+7jdtPzYPHavGfEmuX2tXFxda /dma7lfzJHJLZyenXgc8DtVfRPiHqPhbUPsmnO8Ej4JUYAPowz+NfcU8PVlG7RzU6sFNRbNu8TUF gMGtW5tJoTyuRu9s4rkzqDpGJy23qvPXFWfiF4iurDS5NbkuRLdSspBcZPuMV5Hp/iGTWJducscH JUpwfTNcWW4ZVHKo3p/X6H2vEuPlhsPTwVK+qTb/AE+bO4uLyGFGe4bf0wByx9a5691W+u8RaOki EnlzxhfpW/BoVvNNFPIxLd1J65rVuLZYJPLtUA2r8zdMD61388Y7Hw3Ked6ZoWoi4NxqlwzFmzsL Z6V9ReFINukqqjK7sg187ad4i8Na1dyWenXqTzxryVbNfSWgfudJihXPyDLe+RWFSdzSJj+KbaQl Av3Tya8tuGZJMHlOc13fjTVZUkht4PkkYZ59K8tNxJv/AH3zk+nSuCZ00jXsriJmyvBB4rs1nkwr sMkd686t22zeYvHPSu1s/MK/OSR3FcxR01tOwAjA5bvWp9oXbtIw47Vy0EuyXeeEHFWvMCliGyDQ aG2tzuySeRxgVQv7uN12jr0x6VS81FG8EjdxWcch94O7dVpGdxHI3eZngVAwJXep9zVgnkLtxjvU Eh4KEZzVqJDZEMeU27gGqcmzAbHC8VM3OFY/KDVSXb5bBTnca15TIz3QSbi5+YHio/Ld3jXOFj5B
December 24, 2020 - Present
AeroElectric-Archive.digest.vol-pw
