AeroElectric-Archive.digest.vol-qd
May 13, 2021 - July 13, 2021
      The file
       engine.pdf
       is the one that has the bus architecture and the alternators.
          -- Art Z.
      On Thu, May 13, 2021 at 7:40 AM Bud K  wrote:
      > Art,
      > Yes I could upgrade to a larger, pad mounted alternator but would rather
      > use what I have.  I recognize the added expense and complexity of going the
      > e-bus route.  And yes, that pitot heat power is over half of my e-bus
      > load.  I don't see myself continuing to fly in IMC with a primary system
      > failure and would head to VMC ASAP.
      > Since your B/U alternator has the capacity, did you implement the e-bus
      > architecture or put everything on a main bus?
      https://CheerfulCurmudgeon.com/
      *Friendship is like a stone. A stone has no value, but when you rub two
      stones together properly, sparks of fire emerge. *
      Rabbi Mordechai of Lechovitz
Subject: Re: Contactor Questions
Date: May 13, 2021
Z-31A does not require a diode because the over-voltage module provides arc suppression. No, do not remove the B&C installed diode. It does not hurt anything. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501909#501909 ________________________________________________________________________________
Date: May 13, 2021
Subject: Re: Primary and B/U Alt Fields on Master Bus
At 04:43 PM 5/13/2021, you wrote: >Bud, > >I put everything on one bus except a couple of >tiny loads which are attached to a small >always-on bus. Here are >all >of my wiring diagrams. The file=C2 > > >[] >=C2 >engine.pdf >=C2 is the one that has the bus architecture and the alternators. Figure Z-13 shows the optimal application of the diminutive SD-8 into a two alternator system. On of the design goals was to eliminate the battery contactor load of approx 0.6 to 0.8 amps when flying on battery only. Eliminating that load was also useful for maximizing available energy from the SD-8. If you're not going to have an e-bus, the tie both alternators to the main bus as depicted in Z-12. Have you done a load analysis of the easily anticipated failure conditions for formulate your plan-b flight configuration? Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: May 13, 2021
At 02:10 PM 5/13/2021, you wrote: > > >Good afternoon, > >I'm working on a schematic for my RV-10 based on the Z-101 >architecture and have come up with a couple questions about contactors... > >First, about the starter contactor. The Z-101 shows a single >conductor connecting the contactor to the starter with a jumper at >the starter. I found another discussion from 2015 with an >alternative arrangement (attached) for permanent magnet starters. >I'm planning to use a B&C starter. Should I be using the extra wire & diode? By 'extra wire' are you talking about the jumper from contactor "I" terminal to the starter's "S" terminal? Yes, wire as shown and including the diode is a good thing. The starter contactor from B*C will include a built in diode on its coil. >Second, I'm adding an external power outlet per Z-31A. I've made >sense of most of this drawing but I'm unsure why there is no diode >shown across the coil in the Z-31A diagram? The B&C continuous >contactor includes an external diode already. Should it be removed? Wouldn't hurt but not necessary assuming you can get a B*C crowbar ov module. Are those available? I though those were out of production. >Thanks for taking the time to read my perhaps basic questions! That's what this organization is here for my friend . . . folks that already know everything don't need us! Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: May 13, 2021
At 09:19 PM 5/12/2021, you wrote: > >I am planning an avionics upgrade on an RV-4. The airplane >currently has and SD-8 back up dynamo as well as an internally >regulated alternator. I plan on installing a Garmin GPS175 and >heated pitot and a Dynon Skyview to allow me to fly IFR. I am >planning to rearchitect the electrical system as part of the >upgrade. I plan on implementing an Essential Bus architecture >similar to figure Z-12, dual alternator, single battery. > >Question #1. Why are both the primary and B/U alternator fields >powered by the master bus? Wouldn't it be prudent to power at least >the B/U alternator field from the E-bus in case you have to shut >down the Master bus, thereby disabling both alternators? I know that >the SD-8 can be 'self exciting', however, if it is not, the B/U >alternator would be shut down. > >Question #2. Shouldn't the B/U alternator B lead go the battery side >of the Battery Contactor as opposed to master bus side? Wouldn't >that charge the battery partially offsetting the power draw from E-bus devices. My apologies, I got some replies mistaken for queries. Scratch my recent post to the thread. If you're running an SD-8 aux alternator, you need to be looking at Z-13. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: May 13, 2021
Thanks to you both for the quick feedback. I'll include the jumper from the contactor "I" terminal to the starter with the extra diode. You are correct that B&C no longer sells the crowbar module so I was going to build my own from your crowbar schematics. Thanks again, I'm sure I'll have lots more questions... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501914#501914 ________________________________________________________________________________
Subject: Ensure Exceptional Growth In Business With Cash App
Support
Date: May 14, 2021
To do the same without any kind of hassle, you can also have a word with the geeks who will teach you some optimal ways regarding the same. Moreover, you can also avail of Cash App Support service through which you will be able to ensure magnificent growth within the least time frame. cash app support (https://www.contact-customer-support.net/cash-app-customer-service-phone-number) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501921#501921 ________________________________________________________________________________
Subject: Do you know what happens if you want to unlock cash
app acco
Date: May 14, 2021
If you want to know a solution for accounting for the use of unlock cash app account. You cannot withdraw money from a closed cash account, you must first open an account. Your money is safe; You have nothing to worry about because you can access it directly by logging into your account. If you still have problems, you should visit the website. unlock cash app account (https://www.supporttechhelp.com/blog/unlock-cash-app-account/) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501922#501922 ________________________________________________________________________________
Subject: Magnetized Dynon D100 Display
Date: May 14, 2021
Here's a really weird one that occurred recently. Flying on a North-Easterly heading the PAI-700 panel mount compass informed me I was heading West. This is a new problem and the photo taken some years ago shows the relative positions of the instruments with reasonable agreement between the panel mount compass and the Dynon EFIS. Taxiing around a circle without the Dynon EFIS D100 in the panel gives good compass readings. With the EFIS in place the compass reading remains between South and West. I took the compass and EFIS to the compass manufacturer, Precision Aviation, where they confirmed that the compass is OK and the EFIS magnetization too strong for a mu-metal shield to help. The next photo below shows a compass correctly pointing North and the second shows it after rotating to point to the EFIS display, folded out from the box of electronics and sensors. The magnetization appears to be concentrated halfway up the left side of the display. Dynon Technical Support deny there is anything wrong and my eventual request to buy a replacement display went unanswered. This led to a google search for a demagnetizer that found many plausible devices for up to a few hundred dollars that's no doubt less than a new display. Can anyone advise if it's feasible to demagnetize a display screen and offer any tips, or ideas as to how the display became magnetized? I understand that a standalone magnetic compass isn't required if you have an remote electronic magnetometer but I appreciate the redundancy and the units did after all coexist harmoniously for some years. Thanks in advance!! Chris Skelt LNC2 N1990L at KIWS. -------- Chris Skelt Lancair 320 N1990L at KIWS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501927#501927 Attachments: http://forums.matronics.com//files/d100_magnetized_798.jpg ________________________________________________________________________________
Date: May 14, 2021
Hi Art; Great electrical drawing and parts list. I haven't analyzed it, but very professionally done. Cheers! Stu. ----- Original Message ----- From: "Art Zemon" <art(at)zemon.name> Sent: Thursday, May 13, 2021 2:43:52 PM Subject: Re: AeroElectric-List: Re: Primary and B/U Alt Fields on Master Bus Bud, I put everything on one bus except a couple of tiny loads which are attached to a small always-on bus. Here are all of my wiring diagrams . The file engine.pdf is the one that has the bus architecture and the alternators. Cheers, -- Art Z. On Thu, May 13, 2021 at 7:40 AM Bud K < budkeil(at)gmail.com > wrote: Art, Yes I could upgrade to a larger, pad mounted alternator but would rather use what I have. I recognize the added expense and complexity of going the e-bus route. And yes, that pitot heat power is over half of my e-bus load. I don't see myself continuing to fly in IMC with a primary system failure and would head to VMC ASAP. Since your B/U alternator has the capacity, did you implement the e-bus architecture or put everything on a main bus? -- https://CheerfulCurmudgeon.com/ Friendship is like a stone. A stone has no value, but when you rub two stones together properly, sparks of fire emerge. Rabbi Mordechai of Lechovitz ________________________________________________________________________________
Date: May 14, 2021
Subject: Re: opinions needed: Apollo/Garmin GNS480 vs Garmin
430 Unimpeachable logic; which reduces me to doing nothing (if I'm honest, the most sensible thing), or to investing much less money in a much older/cheaper nav/ILS radio, & possibly something like a KLN94, which I'm sure is also unsupported but the pain of entry (and exit) is much lower. Spending 10 to 20 AMUs for what could end up being, for all practical purposes in my flying world, 'art', just isn't going to happen. On Fri, May 14, 2021 at 10:42 AM Kelly McMullen wrote: > kellym(at)aviating.com> > > Given the install costs, whether in time/effort, or in paying someone to > install, seems to me a bad idea to consider the 480 that is no longer > supported, the 430 if not upgraded to WAAS, which is barely supported, > and even the WAAS unit that is likely to go unsupported within the next > 5 years. I made the choice to go to a 650 about 7-8 years ago for that > reason, and they are ever closer to becoming boat anchors. > So, to me the discussion about ease of use between the Apollo designed > units and the Garmin is greatly overshadowed by their expected useful > life. Both original units are over 20 yrs old, using computer chips not > made for 20 yrs, and even the upgraded WAAS units are already 13 yrs > old. It seems like very few avionics with chips and displays that wear > out are supported much past 20 yrs and some much less. > > On 5/13/2021 6:54 AM, Charlie England wrote: > > Have any of you IFR flyers flown both the 430 & 480, and can give a > > comparison of the two? I'm toying with the idea of adding an approach > > certified GPS to the RV, but I'm 'not yet rated', so I truly don't know > > what I don't know. I do know that the 430 is far more common, and the > > 480 seems to sell for less money in the used market. I've heard only two > > opinions comparing the two; diametrically opposed. Each said their > > choice was far easier to use in an IFR environment. Not an adequate > > sample size, so I'd like to get a bit more of a consensus. > > > > Thanks, > > > > Charlie ________________________________________________________________________________
Date: May 14, 2021
430 Have you considered an SL-30? On Fri, May 14, 2021 at 12:25 PM Charlie England wrote: > Unimpeachable logic; which reduces me to doing nothing (if I'm honest, the > most sensible thing), or to investing much less money in a much > older/cheaper nav/ILS radio, & possibly something like a KLN94, which I'm > sure is also unsupported but the pain of entry (and exit) is much lower. > > Spending 10 to 20 AMUs for what could end up being, for all practical > purposes in my flying world, 'art', just isn't going to happen. > > On Fri, May 14, 2021 at 10:42 AM Kelly McMullen > wrote: > >> kellym(at)aviating.com> >> >> Given the install costs, whether in time/effort, or in paying someone to >> install, seems to me a bad idea to consider the 480 that is no longer >> supported, the 430 if not upgraded to WAAS, which is barely supported, >> and even the WAAS unit that is likely to go unsupported within the next >> 5 years. I made the choice to go to a 650 about 7-8 years ago for that >> reason, and they are ever closer to becoming boat anchors. >> So, to me the discussion about ease of use between the Apollo designed >> units and the Garmin is greatly overshadowed by their expected useful >> life. Both original units are over 20 yrs old, using computer chips not >> made for 20 yrs, and even the upgraded WAAS units are already 13 yrs >> old. It seems like very few avionics with chips and displays that wear >> out are supported much past 20 yrs and some much less. >> >> On 5/13/2021 6:54 AM, Charlie England wrote: >> > Have any of you IFR flyers flown both the 430 & 480, and can give a >> > comparison of the two? I'm toying with the idea of adding an approach >> > certified GPS to the RV, but I'm 'not yet rated', so I truly don't know >> > what I don't know. I do know that the 430 is far more common, and the >> > 480 seems to sell for less money in the used market. I've heard only >> two >> > opinions comparing the two; diametrically opposed. Each said their >> > choice was far easier to use in an IFR environment. Not an adequate >> > sample size, so I'd like to get a bit more of a consensus. >> > >> > Thanks, >> > >> > Charlie > > -- --- David Carter david(at)carter.net ________________________________________________________________________________
Subject: Re: Magnetized Dynon D100 Display
Date: May 14, 2021
This is indeed very odd. The D-100 case is made of alum, I think. Anything inside could possibly be a power-supply coil, but that should not be a permanent magnet. Long shot -- try to remove the battery pack. How old is the D-100? Still under warranty? I would be tempted to carefully use a simple demagnetizer. Radio Shack used to sell them for something like $20. Tapehead demagnetizer. Finn On 5/14/2021 11:32 AM, cskelt wrote: > > Here's a really weird one that occurred recently. Flying on a North-Easterly heading the PAI-700 panel mount compass informed me I was heading West. This is a new problem and the photo taken some years ago shows the relative positions of the instruments with reasonable agreement between the panel mount compass and the Dynon EFIS. > > Taxiing around a circle without the Dynon EFIS D100 in the panel gives good compass readings. With the EFIS in place the compass reading remains between South and West. I took the compass and EFIS to the compass manufacturer, Precision Aviation, where they confirmed that the compass is OK and the EFIS magnetization too strong for a mu-metal shield to help. > > The next photo below shows a compass correctly pointing North and the second shows it after rotating to point to the EFIS display, folded out from the box of electronics and sensors. The magnetization appears to be concentrated halfway up the left side of the display. > > Dynon Technical Support deny there is anything wrong and my eventual request to buy a replacement display went unanswered. This led to a google search for a demagnetizer that found many plausible devices for up to a few hundred dollars that's no doubt less than a new display. Can anyone advise if it's feasible to demagnetize a display screen and offer any tips, or ideas as to how the display became magnetized? > > I understand that a standalone magnetic compass isn't required if you have an remote electronic magnetometer but I appreciate the redundancy and the units did after all coexist harmoniously for some years. > > Thanks in advance!! > Chris Skelt > > LNC2 N1990L at KIWS. > > -------- > Chris Skelt > Lancair 320 N1990L at KIWS > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=501927#501927 > > > Attachments: > > http://forums.matronics.com//files/d100_magnetized_798.jpg > > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: May 14, 2021
Best thing would be to email Dynon support. They are very good. On 5/14/2021 10:09 AM, Finn Lassen wrote: > > This is indeed very odd. The D-100 case is made of alum, I think. > Anything inside could possibly be a power-supply coil, but that should > not be a permanent magnet. Long shot -- try to remove the battery pack. > > How old is the D-100? Still under warranty? > > I would be tempted to carefully use a simple demagnetizer. Radio Shack > used to sell them for something like $20. Tapehead demagnetizer. > > Finn > > On 5/14/2021 11:32 AM, cskelt wrote: >> >> Here's a really weird one that occurred recently. Flying on a >> North-Easterly heading the PAI-700 panel mount compass informed me I >> was heading West. This is a new problem and the photo taken some years >> ago shows the relative positions of the instruments with reasonable >> agreement between the panel mount compass and the Dynon EFIS. >> >> Taxiing around a circle without the Dynon EFIS D100 in the panel gives >> good compass readings. With the EFIS in place the compass reading >> remains between South and West. I took the compass and EFIS to the >> compass manufacturer, Precision Aviation, where they confirmed that >> the compass is OK and the EFIS magnetization too strong for a mu-metal >> shield to help. >> >> The next photo below shows a compass correctly pointing North and the >> second shows it after rotating to point to the EFIS display, folded >> out from the box of electronics and sensors. The magnetization appears >> to be concentrated halfway up the left side of the display. >> >> Dynon Technical Support deny there is anything wrong and my eventual >> request to buy a replacement display went unanswered. This led to a >> google search for a demagnetizer that found many plausible devices for >> up to a few hundred dollars that's no doubt less than a new display. >> Can anyone advise if it's feasible to demagnetize a display screen and >> offer any tips, or ideas as to how the display became magnetized? >> >> I understand that a standalone magnetic compass isn't required if you >> have an remote electronic magnetometer but I appreciate the redundancy >> and the units did after all coexist harmoniously for some years. >> >> Thanks in advance!! >> Chris Skelt >> >> LNC2 N1990L at KIWS. >> >> -------- >> Chris Skelt >> Lancair 320 N1990L at KIWS >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=501927#501927 >> >> >> >> >> Attachments: >> >> http://forums.matronics.com//files/d100_magnetized_798.jpg >> >> >> >> >> >> > > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus > > > > ________________________________________________________________________________
Date: May 14, 2021
> >Dynon Technical Support deny there is anything wrong and my eventual >request to buy a replacement display went unanswered. This led to a >google search for a demagnetizer that found many plausible devices >for up to a few hundred dollars that's no doubt less than a new >display. Can anyone advise if it's feasible to demagnetize a display >screen and offer any tips, or ideas as to how the display became magnetized? > >I understand that a standalone magnetic compass isn't required if >you have an remote electronic magnetometer but I appreciate the >redundancy and the units did after all coexist harmoniously for some years. > >Thanks in advance!! >Chris Skelt Chris, this is a real puzzler! I'm sorry that Dynon hasn't shown more interest in resolving the issue. I've dropped a note to John Torode at Dynon (the head cheese). Let's see if he is willing to be of assistance. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Subject: Re: Canopy antenna?
Date: May 14, 2021
Le 12/05/2021 22:21, Peter Pengilly a crit: > > Everything is a compromise. Copper tape can be used to create an antenna, the more of the antenna that is vertical the better the performance. A BNC connector can be soldered on to the foot, not sure how the ground plane would work, perhaps it needs to be a dipole? I haven't been very close to anyone who has used a tape antenna, but my impression was always that they required more maintenance, and often have worse performance, than installed antennas. How important is a reliable radio against saving weight? Peter, Thank you for your advice. Indeed the main point is having a reliable radio, so the antenna (Bob Archer) will be in the glass fiber fin, as originally intended. I'll may be able to locate some quality smaller diameter coaxial with acceptable performance as compared to our good old RG58. Thanks for your help, -- Best regards, Gilles http://contrails.free.fr http://lapierre.skunkworks.free.fr ________________________________________________________________________________
Date: May 14, 2021
Thanks to all for the quick replies. It's not the battery -- I removed it and checked. Nor is it the aluminum carcass that I also removed before partially disconnecting the display and folding it down so the face rests on the bench. The photo shows the compass pointing at the display with the back side up. I'm as certain as I can be that the magnetism is "something" at the edge of the screen. The Dynon unit is over ten years old and had 300 hours of faultless performance behind it before this happened. I've had excellent service up until now from Dynon--several issues with the EMS were dealt with promptly and effectively. And the 360 degree taxi test with and without the EFIS in place was suggested by one of the Dynon guys on the stand at Sun-n-Fun. -------- Chris Skelt Lancair 320 N1990L at KIWS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501940#501940 ________________________________________________________________________________
Date: May 14, 2021
>Thank you for your advice. Indeed the main point is having a >reliable radio, so the antenna (Bob Archer) will be in the glass >fiber fin, as originally intended. good show >I'll may be able to locate some quality smaller diameter coaxial >with acceptable performance as compared to our good old RG58. RG174 See if you can get a supplier that offers prefab cables. Putting connectors on this coax is NOT for the novice wire slinger. here is one supplier . . . there are no doubt others https://tinyurl.com/yfgmx3z2 Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: May 14, 2021
> >I've had excellent service up until now from Dynon--several issues >with the EMS were dealt with promptly and effectively. And the 360 >degree taxi test with and without the EFIS in place was suggested by >one of the Dynon guys on the stand at Sun-n-Fun. You've hit them with a ringer . . . I'm not surprised at the reaction of the troops in the trenches . . . but it's all just physics and the answer will be simple. Let's see if John T can help out . . . Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: May 14, 2021
Chris, Just a thought here - have you tried to place the D100 near other compass indicators to verify that the D100 is indeed magnetized? (The compass on your iPhone (if that is what you have) is apparently not affected by a nearby magnet!). Did you move it around and rotate it to see if the apparent magnetism is localized at some point in the D100? Is it possible that you had a steel screw or nut to secure the unit in place? What would happen if you removed both units from the panel and positioned them in various arrangements in magnetically benign area? Just thinking out loud! Doug Windhorn -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com On Behalf Of cskelt Sent: Friday, May 14, 2021 2:47 PM Subject: AeroElectric-List: Re: Magnetized Dynon D100 Display Thanks to all for the quick replies. It's not the battery -- I removed it and checked. Nor is it the aluminum carcass that I also removed before partially disconnecting the display and folding it down so the face rests on the bench. The photo shows the compass pointing at the display with the back side up. I'm as certain as I can be that the magnetism is "something" at the edge of the screen. The Dynon unit is over ten years old and had 300 hours of faultless performance behind it before this happened. I've had excellent service up until now from Dynon--several issues with the EMS were dealt with promptly and effectively. And the 360 degree taxi test with and without the EFIS in place was suggested by one of the Dynon guys on the stand at Sun-n-Fun. -------- Chris Skelt Lancair 320 N1990L at KIWS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501940#501940 ________________________________________________________________________________
430
Date: May 14, 2021
I am on your side Charlie England! > On May 14, 2021, at 11:27 AM, Charlie England wrote : > > =EF=BB > Unimpeachable logic; which reduces me to doing nothing (if I'm honest, the most sensible thing), or to investing much less money in a much older/cheap er nav/ILS radio, & possibly something like a KLN94, which I'm sure is also u nsupported but the pain of entry (and exit) is much lower. > > Spending 10 to 20 AMUs for what could end up being, for all practical purp oses in my flying world, 'art', just isn't going to happen. > >> On Fri, May 14, 2021 at 10:42 AM Kelly McMullen wro te: com> >> >> Given the install costs, whether in time/effort, or in paying someone to >> install, seems to me a bad idea to consider the 480 that is no longer >> supported, the 430 if not upgraded to WAAS, which is barely supported, >> and even the WAAS unit that is likely to go unsupported within the next >> 5 years. I made the choice to go to a 650 about 7-8 years ago for that >> reason, and they are ever closer to becoming boat anchors. >> So, to me the discussion about ease of use between the Apollo designed >> units and the Garmin is greatly overshadowed by their expected useful >> life. Both original units are over 20 yrs old, using computer chips not >> made for 20 yrs, and even the upgraded WAAS units are already 13 yrs >> old. It seems like very few avionics with chips and displays that wear >> out are supported much past 20 yrs and some much less. >> >> On 5/13/2021 6:54 AM, Charlie England wrote: >> > Have any of you IFR flyers flown both the 430 & 480, and can give a >> > comparison of the two? I'm toying with the idea of adding an approach >> > certified GPS to the RV, but I'm 'not yet rated', so I truly don't know >> > what I don't know. I do know that the 430 is far more common, and the >> > 480 seems to sell for less money in the used market. I've heard only tw o >> > opinions comparing the two; diametrically opposed. Each said their >> > choice was far easier to use in an IFR environment. Not an adequate >> > sample size, so I'd like to get a bit more of a consensus. >> > >> > Thanks, >> > >> > Charlie > ________________________________________________________________________________
430
Date: May 14, 2021
Certainly. Used, the market prices I've monitored over the past few years are within a few hundred dollars of non-WAAS 430s. I've got an SL40 in the panel now; I've considered purchasing used a VAL 2000 (uses the SL30 protocol), and a cheap non-WAAS gps to go with it. I really can't make any purchase make financial sense, but I need to at least be able to deceive myself on the value. On 5/14/2021 11:42 AM, David Carter wrote: > Have you considered an SL-30? > > On Fri, May 14, 2021 at 12:25 PM Charlie England > wrote: > > Unimpeachablelogic; which reduces me to doing nothing (if I'm > honest, the most sensible thing), or to investing much less money > in a much older/cheaper nav/ILS radio, & possibly something like a > KLN94, which I'm sure is also unsupported but the pain of entry > (and exit) is much lower. > > Spending 10 to 20 AMUs for what could end up being, for all > practical purposes in my flying world, 'art', just isn't going to > happen. > > On Fri, May 14, 2021 at 10:42 AM Kelly McMullen > > wrote: > > > > > Given the install costs, whether in time/effort, or in paying > someone to > install, seems to me a bad idea to consider the 480 that is no > longer > supported, the 430 if not upgraded to WAAS, which is barely > supported, > and even the WAAS unit that is likely to go unsupported within > the next > 5 years. I made the choice to go to a 650 about 7-8 years ago > for that > reason, and they are ever closer to becoming boat anchors. > So, to me the discussion about ease of use between the Apollo > designed > units and the Garmin is greatly overshadowed by their expected > useful > life. Both original units are over 20 yrs old, using computer > chips not > made for 20 yrs, and even the upgraded WAAS units are already > 13 yrs > old. It seems like very few avionics with chips and displays > that wear > out are supported much past 20 yrs and some much less. > > On 5/13/2021 6:54 AM, Charlie England wrote: > > Have any of you IFR flyers flown both the 430 & 480, and can > give a > > comparison of the two? I'm toying with the idea of adding an > approach > > certified GPS to the RV, but I'm 'not yet rated', so I truly > don't know > > what I don't know. I do know that the 430 is far more > common,and the > > 480 seems to sell for less money in the used market. I've > heard only two > > opinions comparing the two; diametrically opposed. Each said > their > > choice was far easier to use in an IFR environment. Not an > adequate > > sample size, so I'd like to get a bit more of a consensus. > > > > Thanks, > > > > Charlie > > -- > --- > David Carter > david(at)carter.net -- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: May 15, 2021
430 Charlie, I have hundreds of hours flying behind a KLN94; I had one in my Arrow (which I sold when I bought my BD-4C kit). I would not willingly fly with a KLN94 again. Compared to the current generation of Garmins, the user interface is horrible. The screen is tiny. And the database update process is atrocious. To update the KLN94 database, you have a couple of choices. a) You can connect a computer running Windows 95 (that is the last version supported by Bendix King's software, IIRC) to the KLN94 via a serial cable (yes! serial, not USB) and run the magic software for about 20 minutes. b) You can use a specially modified CompactFlash card which has to be written with a no-longer-produced CF card writer by the magic software. Yes, the Garmins are expensive. But having used them, they are worth every penny. Garmin got the UI right. I have VAL nav and comm radios. They are OK. Would I buy them again? Probably. Are they as good as Garmins? No. Like you, I bought them for the size and because the SL30 and SL40 are pretty darned expensive. I don't remember what you have for primary instrumentation. I installed an MGL glass panel. It's built-in GPS is excellent. I happily used it for primary navigation before installing the GPS175. If you don't need your GPS to be IFR-certified, have you considered something like this? It looks like you can get a whole MGL MX1 system for under $2000. See https://www.michiganavionics.com/product-category/efis/ One last thought, the MGL GPS antenna is a little puck which you install *inside* the airplane. I thought that was bogus but did as instructed. I have it under the windshield, and it works beautifully, regardless of my direction of flight. My airplane has an aluminum fuselage. The MGL GPS actually tracks better than the Garmin. Cheers, -- Art Z. On Fri, May 14, 2021 at 11:35 AM Charlie England wrote: > Unimpeachable logic; which reduces me to doing nothing (if I'm honest, the > most sensible thing), or to investing much less money in a much > older/cheaper nav/ILS radio, & possibly something like a KLN94, which I'm > sure is also unsupported but the pain of entry (and exit) is much lower. > -- https://CheerfulCurmudgeon.com/ *Friendship is like a stone. A stone has no value, but when you rub two stones together properly, sparks of fire emerge. * Rabbi Mordechai of Lechovitz ________________________________________________________________________________
Date: May 16, 2021
Didn't see the pictures before. Is that a steel rod holding the display in place? Anything steel or iron, if removable do so. Then simply demagnetize it. Actually, the D-100 has a remote compass, right? If so I don't see any reason you couldn't demagnetize the D-100. Others here may give good reasons why not. Finn On 5/14/2021 5:46 PM, cskelt wrote: > > Thanks to all for the quick replies. It's not the battery -- I removed it and checked. Nor is it the aluminum carcass that I also removed before partially disconnecting the display and folding it down so the face rests on the bench. The photo shows the compass pointing at the display with the back side up. > > I'm as certain as I can be that the magnetism is "something" at the edge of the screen. The Dynon unit is over ten years old and had 300 hours of faultless performance behind it before this happened. > > I've had excellent service up until now from Dynon--several issues with the EMS were dealt with promptly and effectively. And the 360 degree taxi test with and without the EFIS in place was suggested by one of the Dynon guys on the stand at Sun-n-Fun. > > -------- > Chris Skelt > Lancair 320 N1990L at KIWS > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=501940#501940 > > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: May 16, 2021
Today I positioned a hand-held compass near my 10 year old D-180 screen. The compass swung 130 degrees as it neared the left side of the screen, just like cskelt's. Luckily my plane has a remote magnetometer, no panel mounted compass. The master switch was off during the test. My instrument panel does not have steel parts, just aluminum. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501967#501967 ________________________________________________________________________________
Subject: any concerns vibration fatigue mounting tab 40 A relay?
Date: May 16, 2021
Any concerns about vibration fatigue of a 40 A automotive relay's single mounting tab? For instance B&C S8009-1. Firewall mounted Lycoming tractor aircraft. Question from an RV 14 builder. Thanks -------- John Bright, RV-6A, at FWF, O-360 Z-101 single batt dual alt SDS EM-5-F. john_s_bright(at)yahoo.com, Newport News, Va https://docs.google.com/document/d/1YOtPiA3AdUsQEYR4nodBESNAo21rxdnx4pFs7VxXfuI/edit?usp=sharing Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501968#501968 ________________________________________________________________________________
Date: May 16, 2021
Subject: Re: any concerns vibration fatigue mounting tab 40
A relay? At 04:43 PM 5/16/2021, you wrote: > > >Any concerns about vibration fatigue of a 40 A automotive relay's >single mounting tab? No Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: May 16, 2021
Subject: $lower$ lacing material
I told the list I'd look into some of lower cost options for Dacron/polyester lacing material. I brought this spool in off Amazon for about 10.50 postage paid. https://tinyurl.com/yhwfjvfb It's indeed the same stuff as the mil-spec flat lace. Impervious to 400F exposure. Quite adequate in strength for bundle ties. It's thinner so easier to put 'pressure' on the constrained materials . . . but it works real well with the noose-knot but you don't need to put a strangle hold on the wrap. It will live happily under the cowl too. I'm keeping this spool in my bin of tying materials. It will be handy for sewing up rips in flat materials too. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: May 16, 2021
At 04:28 PM 5/16/2021, you wrote: > >Today I positioned a hand-held compass near my 10 year old D-180 screen. >The compass swung 130 degrees as it neared the left side of the screen, just >like cskelt's. Luckily my plane has a remote magnetometer, no panel mounted >compass. The master switch was off during the test. My instrument panel >does not have steel parts, just aluminum. Interesting! Thank you for that. Perhaps John T can enlighten us as to the cause. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: May 16, 2021
Subject: AeroVoltz 270 battery for sale
I have an essentially new AeroVoltz 270 battery I purchased new a couple months ago to evaluate for a client. https://tinyurl.com/yz6d4jpn Found that it does indeed do what it claims; also determined that it was not suited to his task. Will put it up on eBay if nobody here on the list isn't interested in it first. Comes with factory instructions and the 'reset' cable. Will include the plots of laboratory data gleaned from this sample. Would like to get $100 for it postage paid to US addresses. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: May 16, 2021
Subject: M43435/II/B Lacing tape
Here's a attractive option for the 'good' stuff: https://tinyurl.com/yjtp85vn Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Subject: Re: $lower$ lacing material
Date: May 16, 2021
On 5/16/2021 8:10 PM, Robert L. Nuckolls, III wrote: > > > I told the list I'd look into some of lower > cost options for Dacron/polyester lacing > material. > > I brought this spool in off Amazon for about 10.50 > postage paid. > > https://tinyurl.com/yhwfjvfb > > It's indeed the same stuff as the mil-spec > flat lace. Impervious to 400F exposure. Quite > adequate in strength for bundle ties. It's > thinner so easier to put 'pressure' on the > constrained materials . . . but it works real > well with the noose-knot but you don't need > to put a strangle hold on the wrap. > It will live happily under the cowl too. > > I'm keeping this spool in my bin of tying > materials. It will be handy for sewing up > rips in flat materials too. > > Bob . . . > My a&p neighbor just rewired his RV6 using rib lacing tape made for fabric covered a/c. Doesn't seem to be any cheaper than wire lacing tape, but what about this? https://www.sailrite.com/Twine-5-ply-Waxed-Flat-500-Feet?gclid=CjwKCAjwhYOFBhBkEiwASF3KGUDkcsPQ7--vbb4r8mxFYHAoP4a0ug-DwHkdmqhsDxorRHMFarFLZhoCBiUQAvD_BwE Charlie -- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: May 16, 2021
>My a&p neighbor just rewired his RV6 using rib lacing tape made for >fabric covered a/c. Doesn't seem to be any cheaper than wire lacing >tape, but what about this? >https://www.sailrite.com/Twine-5-ply-Waxed-Flat-500-Feet?gclid=CjwKCAjwhYOFBhBkEiwASF3KGUDkcsPQ7--vbb4r8mxFYHAoP4a0ug-DwHkdmqhsDxorRHMFarFLZhoCBiUQAvD_BwE > It's polyester . . . should be fine. Good find. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: May 17, 2021
Thank you Joe Gores as a 10 year old D180 and D100 of similar vintage presumably share a screen type, so this isn't a unique phenomenon. What Joe's data point can't tell us is whether his magnetism was always present or occurred recently, like mine, after years of non-magnetic functioning. In reply to Doug Windhorn's post, I removed the compass and D100 from the panel, opened up the D100, and folded out the display to persuade myself that the magnetism was in the display, not the electronics in the carcass, and to establish that it's permanent magnetism, not RF interference from live avionics. I used the panel mount compass and a hiking compass. The (admittedly rather cryptic) photos in the original post were intended to illustrate this. The threaded steel rod that locks the EFIS into the mounting tray does not appear to be magnetized. If these devices do indeed spontaneously magnetize, the need is for a demagnetizer, not a replacement screen, as the latter would be a relatively expensive and potentially only temporary fix. Chris Skelt -------- Chris Skelt Lancair 320 N1990L at KIWS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501983#501983 ________________________________________________________________________________
Date: May 17, 2021
Thank you Joe Gores as a 10 year old D180 and D100 of similar vintage presumably share a screen type, so this isn't a unique phenomenon. What Joe's data point can't tell us is whether his magnetism was always present or occurred recently, like mine, after years of non-magnetic functioning. In reply to Doug Windhorn's post, I removed the compass and D100 from the panel, opened up the D100, and folded out the display to persuade myself that the magnetism was in the display, not the electronics in the carcass, and to establish that it's permanent magnetism, not RF interference from live avionics. I used the panel mount compass and a hiking compass. The (admittedly rather cryptic) photos in the original post were intended to illustrate this. The threaded steel rod that locks the EFIS into the mounting tray does not appear to be magnetized. If these devices do indeed spontaneously magnetize, the need is for a demagnetizer, not a replacement screen, as the latter would be a relatively expensive and potentially only temporary fix. Chris Skelt -------- Chris Skelt Lancair 320 N1990L at KIWS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501985#501985 ________________________________________________________________________________
Date: May 17, 2021
Upon further investigation, I don't think my D-180 display is magnetized after all. I pulled the D-180 part way out of the instrument panel without disconnecting any cables. Then I moved the compass around. The magnetic interference seemed to be stronger under the instrument panel. Eventually I determined that the control stick is magnetized and attracts the south end of the compass needle. As I moved the compass around the control stick, the needle always pointed at the stick. Sorry about posting an incorrect data point yesterday. It is worth a try for Chris to try demagnetizing the steel locking rod with a soldering gun. https://www.youtube.com/watch?v=g2sFp5Blg_g -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501991#501991 ________________________________________________________________________________
Subject: Re: M43435/II/B Lacing tape
Date: May 17, 2021
What about these? https://www.amazon.com/dp/B00B4GCJV2/ref=sspa_dk_detail_5?psc=1&pd_rd_i= B00B4GCJV2p13NParams&smidAY1HFZHO49U&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUE yWThRSlY3WU9YR1BRJmVuY3J5cHRlZElkPUEwMDkyMjA3Uk9CQkY3UlFINjVMJmVuY3J5cHRlZEFk SWQ9QTA5Njg4NDMxUDdMUVEyNDdSOUxVJndpZGdldE5hbWU9c3BfZGV0YWlsMiZhY3Rpb249Y2xp Y2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU Ty-rap (tm) says they were invented to be used in airliners. And at a nickel each, they=99re pretty reasonable. Their literature cites applications on Mars rovers & Space Shuttle. Is there something inherently better about lacing than Ty-raps? -Jeff > On May 16, 2021, at 18:58, Robert L. Nuckolls, III <nuckolls.bob@aeroelect ric.com> wrote: > > =EF=BB > > Here's a attractive option for the 'good' > stuff: > > https://tinyurl.com/yjtp85vn > > Bob . . . > > Un impeachable logic: George Carlin asked, "If black boxes > survive crashes, why don't they make the whole airplane > out of that stuff?" ________________________________________________________________________________
Date: May 17, 2021
Chris, Thanks for the feedback on your experiment. Out of curiosity, I have a D10A out of the panel - I was going to place it near my glareshield mount magnetic compass today to see if it produced similar results, but got sidetracked by other gremlins, so will have to wait until Thursday to do that check. Will let you know what I find. Doug Windhorn -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com On Behalf Of cskelt Sent: Monday, May 17, 2021 6:52 AM Subject: AeroElectric-List: Re: Magnetized Dynon D100 Display Thank you Joe Gores as a 10 year old D180 and D100 of similar vintage presumably share a screen type, so this isn't a unique phenomenon. What Joe's data point can't tell us is whether his magnetism was always present or occurred recently, like mine, after years of non-magnetic functioning. In reply to Doug Windhorn's post, I removed the compass and D100 from the panel, opened up the D100, and folded out the display to persuade myself that the magnetism was in the display, not the electronics in the carcass, and to establish that it's permanent magnetism, not RF interference from live avionics. I used the panel mount compass and a hiking compass. The (admittedly rather cryptic) photos in the original post were intended to illustrate this. The threaded steel rod that locks the EFIS into the mounting tray does not appear to be magnetized. If these devices do indeed spontaneously magnetize, the need is for a demagnetizer, not a replacement screen, as the latter would be a relatively expensive and potentially only temporary fix. Chris Skelt -------- Chris Skelt Lancair 320 N1990L at KIWS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501985#501985 ________________________________________________________________________________
Date: May 17, 2021
At 04:33 PM 5/17/2021, you wrote: >What about these? > >https://www.amazon.com/dp/B0 0B4GCJV2/ref=sspa_dk_detail_5?psc=1&pd_rd_i=B00B4GCJV2p13NParams&smid AY1HFZHO49U&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEyWThRSlY3WU9YR1BRJmVuY3J5 cHRlZElkPUEwMDkyMjA3Uk9CQkY3UlFINjVMJmVuY3J5cHRlZEFkSWQ9QTA5Njg4NDMxUDdMUVEy NDdSOUxVJndpZGdldE5hbWU9c3BfZGV0YWlsMiZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExv Z0NsaWNrPXRydWU > >Ty-rap (tm) says they were invented to be used >in airliners. And at a nickel each, they=99re pretty reasonable. > >Their literature cites applications on Mars rovers & Space Shuttle. Sincerely doubt that! Tye-wraps on the rovers would be at least tefzel if not nomex. Used work with a guy who was a big-time tech with an air transport maintenance firm. I'll see if I can track him down and ask about tye-wraps. According to the data sheet: http://www.aeroelectric.com/Mfgr_Data/Misc/Thomas&Betts/TY24MX_M3367.pdf intended for indoor applications. Rated to only 165F. These are made from 6.6 Nylon . . . not nearly the capability of Dacron. Virtually everything you can buy from the catalogs in tye-wraps will be nylon. Problematic under the cowl but okay every place else. >Is there something inherently better about lacing than Ty-raps? Tye-wraps ARE more convenient . . . but largely a personal preference. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Subject: Try These Ideas to Help with Accounting Homework
Date: May 18, 2021
Try These Ideas to Help with Accounting Homework Accounting is often challenging for students across the board. It is not only because of the numerous academic assignments that they are expected to provide, but also because of the vast amounts of work that goes into writing such documents.For instance, it would be effortless to assume that just any student could do their math assignment (just check out your url (https://essayhelper.biz/) here). When it comes to paying attention to all the aspects of education, most scholars will make a mistake of assuming that teachers do not intimidate them with complicated tasks. As the situation stands right now, it is elementary for someone to take charge of an entire class. Regardless, every teacher has something special about themselves that makes it difficult for either of the learners to avoid the mistakes or get a poor grade. That does not mean that other people in the same course are better when it Comes to handling various kinds of assignment. At times, the professor might have a lot of workload to deal with. In which case, it is crucial to find a method that will allow you to beat the deadline. But to attain accounting homework's standards, there is no harm in doing so. Write Your Assignment Professionally Once you are familiar with the particular instructions that go with each paper, it is even easier to craft an award-winning essay. Academic papers that are well-written tend to have a high scoring factor. This is why those who do not possess excellent researching skills should turn to a professional to manage their books. Writing audit types are easy to grasp, and planstrategies that assist clients in achieving things like passing tests and performing calculations. Besides, with an accountant coming up with a brilliant strategy, you are assured of submitting a budget that will propel yourself to the top of the pay list. That means you stand a chance of improving overall performance in the discipline. Have a Plan Some students forget to start with a plan until it is too late. Obviously, when planning, it is not always that simple. A planner will come in handy for virtually everyone, including the lecturers and the professors. You will not have to spend much time figuring out what activities to attend to apart from basic accounting. A proper schedule will ensure that you have enough time to handle the actual accounts for the different areas of study. An outline will also enable one to stay focused. Remember, keeping track of the numerical score will be very important. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502000#502000 ________________________________________________________________________________
Date: May 18, 2021
At 02:28 PM 5/17/2021, you wrote: > >Upon further investigation, I don't think my D-180 display is >magnetized after >all. I pulled the D-180 part way out of the instrument panel without >disconnecting any cables. Then I moved the compass around. The magnetic >interference seemed to be stronger under the instrument panel. Eventually I >determined that the control stick is magnetized and attracts the south end of >the compass needle. As I moved the compass around the control stick, the >needle always pointed at the stick. Sorry about posting an >incorrect data point yesterday. > It is worth a try for Chris to try demagnetizing the steel locking > rod with a soldering gun. > https://www.youtube.com/watch?v=g2sFp5Blg_g I received this note from John this morning: ================== received from John Torode 5/18/20 ============== bob, we have repeated the experiment with one of our d100s with the same result: the magnetic fields emanating from the d100 cause significant compass errors. we believe this is from currents inside the device, not from any material becoming magnetized. in fact we would try not to include much ferrous material (d-subs i guess). my electronic compass has a definite signature from the pulsating current in the power leads to the strobe, which are some distance away. what is puzzling is his claim that it used to work fine. one idea is that the power wire to the d100 has moved. we have spoken with him before (i am disappointed that any query from a customer goes unanswered), and have concluded that the panel is a bad place for a compass because of the many currents around. we do not think there is a reliable solution besides moving the compass to a magnetically quiet place. sorry, john ========================================================================== Compass interference issues can be difficult to track down. When Beech began offering the B&C SD-20 variants on the A36, we encountered a situation where turning the aux alternator on/off caused an unacceptable swing in the cowl mounted wet compass. We had to move it up onto the windshield. The distance moved was but a few inches but more toward the fringes of the magnetic field emanating from the rear of an energized alternator which was on the OTHER side of the firewall! Strength of magnetic forces vary with both distance and position. The forces do not radiate in uniformly dispersed spherical pattern. To make matters more complex, they can be strongly influenced by passive features located within the field. Steel tube airplanes were subject to magnetization of structure . . . sometimes difficult to neutralize. It was a rare instance that some interference was mitigated by demagnetizing some rogue source of magnetic force. The 'fix' nearly always called for a design change. We also know that the distance over which a given field has influence has a profound effect on strength. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
From: "Willsmith000" <hansfordresortnarkanda(at)gmail.com>
Date: May 18, 2021
This is very helpful, i was looking for it Biofit Probiotic (https://clickbankproductreviews.org/biofit-probiotic-2021/) Okinawa Flat Belly Tonic (https://clickbankproductreviews.org/okinawa-flat-belly-tonic/) CarboFix (https://clickbankproductreviews.org/carbofix-review/) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502003#502003 ________________________________________________________________________________
Date: May 18, 2021
The TYZ525M is the 330degF, flame resistant, low smoke Ty-rap that is Flouropolymer from ABB/Thomas&Betts but very pricey at $250 for a pack of 100. Regards, iFlyLSA On Sun, May 16, 2021 at 8:55 PM Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > > > Here's a attractive option for the 'good' > stuff: > > https://tinyurl.com/yjtp85vn > > Bob . . . > > Un impeachable logic: George Carlin asked, "If black boxes > survive crashes, why don't they make the whole airplane > out of that stuff?" > ________________________________________________________________________________
Subject: Re: Try These Ideas to Help with Accounting Homework
Date: May 18, 2021
Thanks for your post. Biofit Probiotic (https://clickbankproductreviews.org/biofit-probiotic-2021/) Okinawa Flat Belly Tonic (https://clickbankproductreviews.org/okinawa-flat-belly-tonic/) CarboFix (https://clickbankproductreviews.org/carbofix-review/) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502004#502004 ________________________________________________________________________________
Date: May 18, 2021
At 02:11 PM 5/18/2021, you wrote: >The TYZ525M is the 330degF, flame resistant, low smoke Ty-rap that >is Flouropolymer from ABB/Thomas&Betts but very pricey at $250 for a >pack of 100. Yup. That would be Tefzel ties. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: May 19, 2021
Subject: Re: Magnetism
When we were building two airplanes in a large hangar my rudder cables got relocated to a DC welding machine where they laid for several days while the welder was used several times. I located my remote compass to the rear bottom of the fuselage ( right between the galvanized rudder cables ). When trying to calibrate the compass it would swing wildly when moving the rudder even slightly. We tried degauzing with a solder gun and even found an old TV degauzing ring to no avail. Finally moved the compass up high above the baggage compartment and it worked fine. ________________________________________________________________________________
Date: May 20, 2021
Subject: was "Contactor Questions" now battery in the trunk
This is kinda related to contactors... On the BD4 that I am rebuilding, the battery is behind the baggage compartment, with a really fat wire running up to the firewall. IO 470 engine so lots of amps required for start. Is there a recommended contactor placement/battery disconnect protocol out there? I'm thinking safety in the event of an incident which might short out the fat wire to the fuselage. My setup is very rudimentary (steam 8 pack), conventional engine gauges, perhaps a mini EFIS. I did try the Forum search but struggled a little.... Best Regards, Bob Verwey 082 331 2727 On Fri, 14 May 2021 at 05:46, A Lumley wrote: > andrew.lumley(at)sympatico.ca> > > Thanks to you both for the quick feedback. I'll include the jumper from > the contactor "I" terminal to the starter with the extra diode. > > You are correct that B&C no longer sells the crowbar module so I was going > to build my own from your crowbar schematics. > > Thanks again, I'm sure I'll have lots more questions... > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=501914#501914 > > ________________________________________________________________________________
Date: May 20, 2021
Subject: Re: was "Contactor Questions" now battery in the trunk
Hey Bob, It sounds like you're asking the right questions... The master contactor should be close enough to the battery so that the fat positive cable from the batt to the solenoid can be 18 inches or less.=C2 - Then run the fat wire from the other side of the solenoid forward. Then, just before the crash, when you're running the just-before-I-hit-the- ground checklist, you shut off the master --- just like we were all taught as student pilots.=C2- That makes the length of cable running forward ine rt (obviously) and therefore, if it gets damaged in the crash, it won't cau se a fire. (This scenario requires a bit more engineering in modern aircraft where all the flight instruments are electric (EFIS) and you might want to be watchi ng airspeed as you try to reduce your kinetic energy before impact without stall/spinning.=C2- But, with your instrumentation it is moot.) BTW - this is exactly how my 1965 Cherokee is wired. -Jeff il.com> wrote: This is kinda related to contactors... On the BD4 that I am rebuilding, the battery is behind the baggage compartm ent, with a really fat wire running up to the firewall.=C2- IO 470 engine so lots of amps required for start. Is there a recommended contactor placement/battery disconnect=C2-protocol out there?I'm thinking safety in the event of an incident which might shor t out the fat wire to the fuselage. My setup is very rudimentary (steam 8 pack), conventional engine gauges, pe rhaps a mini EFIS.=C2-=C2-I did try the Forum search but struggled a li ttle.... Best Regards,Bob Verwey082 331 2727 =C2- =C2- =C2-=C2- On Fri, 14 May 2021 at 05:46, A Lumley wrote: o.ca> Thanks to you both for the quick feedback. I'll include the jumper from the contactor "I" terminal to the starter with the extra diode. You are correct that B&C no longer sells the crowbar module so I was going to build my own from your crowbar schematics. Thanks again, I'm sure I'll have lots more questions... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=501914#501914 - Electric-List" rel="noreferrer" target="_blank">http://www.matronics.co m/Navigator?AeroElectric-List FORUMS - eferrer" target="_blank">http://forums.matronics.com WIKI - errer" target="_blank">http://wiki.matronics.com b Site - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: May 20, 2021
Rest of the story is that the starter contactor can be on the firewall. That way, only one long fat wire from the back is needed. The source-side terminal of the starter contactor becomes the distribution point for all your master contactor-controlled 'stuff' in the forward cockpit, etc. Any required 'E-bus' feed can be much smaller, & protected with either a fusible link or appropriate sized slow acting fuse. You should be able to find the concepts detailed in the Z drawings. Charlie On 5/20/2021 10:39 AM, Jeff Luckey wrote: > Hey Bob, > > It sounds like you're asking the right questions... > > The master contactor should be close enough to the battery so that the > fat positive cable from the batt to the solenoid can be 18 inches or > less. Then run the fat wire from the other side of the solenoid forward. > > Then, just before the crash, when you're running the > just-before-I-hit-the-ground checklist, you shut off the master --- > just like we were all taught as student pilots. That makes the length > of cable running forward inert (obviously) and therefore, if it gets > damaged in the crash, it won't cause a fire. > > (This scenario requires a bit more engineering in modern aircraft > where all the flight instruments are electric (EFIS) and you might > want to be watching airspeed as you try to reduce your kinetic energy > before impact without stall/spinning. But, with your instrumentation > it is moot.) > > BTW - this is exactly how my 1965 Cherokee is wired. > > -Jeff > > > wrote: > > > This is kinda related to contactors... > > On the BD4 that I am rebuilding, the battery is behind the baggage > compartment, with a really fat wire running up to the firewall. > > IO 470 engine so lots of amps required for start. > > Is there a recommended contactor placement/battery disconnectprotocol > out there? > I'm thinking safety in the event of an incident which might short out > the fat wire to the fuselage. > > My setup is very rudimentary (steam 8 pack), conventional engine > gauges, perhaps a mini EFIS. > I did try the Forum search but struggled a little.... > > Best Regards, > Bob Verwey > 082 331 2727 > > > On Fri, 14 May 2021 at 05:46, A Lumley > wrote: > > > > > Thanks to you both for the quick feedback. I'll include the jumper > from the contactor "I" terminal to the starter with the extra diode. > > You are correct that B&C no longer sells the crowbar module so I > was going to build my own from your crowbar schematics. > > Thanks again, I'm sure I'll have lots more questions... > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=501914#501914 > <http://forums.matronics.com/viewtopic.php?p=501914#501914> > > > ========== > - > Electric-List" rel="noreferrer" > target="_blank">http://www.matronics.com/Navigator?AeroElectric-List > ========== > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > ========== > WIKI - > errer" target="_blank">http://wiki.matronics.com > ========== > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" target="_blank">http://www.matronics.com/contribution > ========== > > -- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: May 23, 2021
trunk At 11:57 PM 5/19/2021, you wrote: >This is kinda related to contactors... > >On the BD4 that I am rebuilding, the battery is >behind the baggage compartment, with a really >fat wire running up to the firewall.=C2 > >IO 470 engine so lots of amps required for start. > >Is there a recommended contactor >placement/battery disconnect=C2 protocol out there? >I'm thinking safety in the event of an incident >which might short out the fat wire to the fuselage. Battery contactor located as close as practical to battery; starter contactor as close as practical to starter. FAT wire connects battery contactor to starter contactor and main bus feeder. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Subject: Thermocouples
Date: May 23, 2021
Hi Bob, I re-read your chapter on thermocouples. The question I have is: what voltages are introduced at copper/thermocouple wire junctions? You show them in an ice bath. Does that mean that no voltages are generated at 0 degC at copper/chromel and copper/alumel junctions? I made a probe using K-type wire in a 5/32" brass tube, squeezed shut over the twisted wires and then silver-soldered to make it water tight. When I connected it to my engine monitor it read as much as 220 deg F in boiling water. In other words 8F too high. Now I'm wondering if it's contamination of the joint by brass or silver solder, or something in the engine monitor. The Data Acquisition Module for the engine monitor have 16 (x2) inputs going into MAX4558 8-to-1 multiplexers and from there to a MAX6675 (Type-K to 12 bit digital with cold-junction compensation). They are on the same PCB, so in theory the temperature should be the same at the screw connectors and the MAX6675 pins. Terminal block (ED555/DS) is CuZn with wireguard (the metal under the screw pressing down on wire) is CuSn. An issue is that the Data Acquisition Module is mounted where it gets hot (seen as much as 160F). The MAX6675's compensation should be good to 185F, but wondering about the other junctions on the PCB. Since each thermocouple wire has same path (terminal, PCB cu traces, solder, multiplexers) any junction voltages should balance out, or? I have been using LM35 (or similar) temp sensors but they appear to be failing. Finn --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: May 23, 2021
Guys, we're always looking for an honest and reliable service and nobody likes wasting free time that could be spent on travel, friends and self-development. Isn't that right? If I'm right, there is a solution to all your problems! There is a very cool service, , which has been helping pupils and students with their homework for a very long time. They are professionals and know what they are doing, you can count on them! -------- In order to write a correct essay quickly, it is enough to use the free tools . You can also use them to check your finished essay for plagiarism. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502036#502036 ________________________________________________________________________________
Date: May 23, 2021
Subject: Re: Thermocouples
At 12:45 PM 5/23/2021, you wrote: > >Hi Bob, > >I re-read your chapter on thermocouples. > >The question I have is: what voltages are >introduced at copper/thermocouple wire junctions? I don't have specific numbers but they are known. ANY two DISSIMILAR metals will demonstrate the Seebeck effect. >You show them in an ice bath. Does that mean >that no voltages are generated at 0 degC >at=C2 copper/chromel and copper/alumel junctions? No, it only means that the voltages generated are known and STABLE due to the inherent stability of an ice bath. >I made a probe using K-type wire in a 5/32" >brass tube, squeezed shut over the twisted wires >and then silver-soldered to make it water tight. The ideal way to bring two thermocouple wires together is by welding. We used to have a t/c welder that was nothing more than a 50vdc power supply fitted with a high resistance inductor to help stabilize the arc. I.e. a miniature, low power arc welder. Before we got the welder the techs would silver solder the junctions . . . I don't know if they had done any validation of the technique. >When I connected it to my engine monitor it read >as much as 220 deg F in boiling water. In other words 8F too high. Do you have other probes that are closer to 212? >Now I'm wondering if it's contamination of the >joint by brass or silver solder, or something in the engine monitor. You've got several variables there. Try building up some 'test' junctions with your stock wire. Make 2 or 3 junctions simply twisted and compare with your cited results. Then silver solder; repeat. Finally, add your housing and check for consistency. >The Data Acquisition Module for the engine >monitor have 16 (x2) inputs going into MAX4558 >8-to-1 multiplexers and from there to a MAX6675 >(Type-K to 12 bit digital with cold-junction >compensation). They are on the same PCB, so in >theory the temperature should be the same at the >screw connectors and the MAX6675 pins. Terminal >block (ED555/DS) is CuZn with wireguard (the >metal under the screw pressing down on wire) is CuSn. The nature of the various junctions in each t/c loop is not critical as long as they occur in thermally matched pairs. >An issue is that the Data Acquisition Module is >mounted where it gets hot (seen as much as >160F). The MAX6675's compensation should be good >to 185F, but wondering about the other junctions >on the PCB. Since each thermocouple wire has >same path (terminal, PCB cu traces, solder, >multiplexers) any junction voltages should balance out, or? If the DAS designer built the signal conditioning with T/C requirements in mind, you should be okay . . . but it's worth confirming. Sort out the probe issues first then perhaps test the same probes with the DAS multiplexer in an elevated temperature environment. (cardboard box with 100W bulb makes good po' boy's environmental oven). >I have been using LM35 (or similar) temp sensors >but they appear to be failing. What's the highest temperatures of interest to be explored? If this is a 'scratch built' DAS system, have you considered RTDs? Much larger delta-volts/degree and no parasitic junction issues. A 100 ohm RTD changes about 0.38ohms/C. Bias the critter up at 1mA gives you about 380uV per C. That's about 10x bigger signal than a K thermocouple. You can run 2 wires for short runs . . . but if you're really picky, a 3-wire connection will let you do a direct copper drop read on the lead wires or a 4-wire for separate excitation/sense paths. A down side of little RTDs is that they're a bit tricky to mount. I usually tack them onto the end of a shielded trio for a 4-wire connection then dip the assembly in JB Kwik for a rugged encapsulation. Perhaps the simplest thing to do first is to identify root cause for errors in your thermocouples. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: May 24, 2021
Subject: "Contactor Questions" , battery in the trunk, now Ground
power plug Thanks for the responses to my query....I now have the right solution. Any recommendations as to how to tie this receptacle into the schematic? [image: image.png] More specifically the polarity relay that is indicated. Best Regards, Bob Verwey 082 331 2727 On Sun, 23 May 2021 at 19:20, Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 11:57 PM 5/19/2021, you wrote: > > This is kinda related to contactors... > > On the BD4 that I am rebuilding, the battery is behind the baggage > compartment, with a really fat wire running up to the firewall.=C3=82 > > IO 470 engine so lots of amps required for start. > > Is there a recommended contactor placement/battery disconnect=C3=82 proto col > out there? > I'm thinking safety in the event of an incident which might short out the > fat wire to the fuselage. > > > Battery contactor located as close as practical > to battery; starter contactor as close as practical > to starter. FAT wire connects battery contactor > to starter contactor and main bus feeder. > > > Bob . . . > > Un impeachable logic: George Carlin asked, "If black boxes > survive crashes, why don't they make the whole airplane > out of that stuff?" > ________________________________________________________________________________
Date: May 24, 2021
Subject: Re: "Contactor Questions" , battery in the trunk,
now Ground power plug At 12:02 PM 5/24/2021, you wrote: >Thanks for the responses to my query....I now have the right solution. >Any recommendations as to how to tie this receptacle into the schematic? http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z31K.pdf Your schematic didn't come thru to me. The link above is to a recommended methodology for installing this style ground power connector. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: May 24, 2021
now Ground power plug Is this external power receptacle on a Western airplane? Or a Yak/CJ? On Mon, May 24, 2021 at 12:27 PM Bob Verwey wrote: > Thanks for the responses to my query....I now have the right solution. > Any recommendations as to how to tie this receptacle into the schematic? > > [image: image.png] > > More specifically the polarity relay that is indicated. > > Best Regards, > Bob Verwey > 082 331 2727 > > > On Sun, 23 May 2021 at 19:20, Robert L. Nuckolls, III < > nuckolls.bob(at)aeroelectric.com> wrote: > >> At 11:57 PM 5/19/2021, you wrote: >> >> This is kinda related to contactors... >> >> On the BD4 that I am rebuilding, the battery is behind the baggage >> compartment, with a really fat wire running up to the firewall.=C3=82 >> >> IO 470 engine so lots of amps required for start. >> >> Is there a recommended contactor placement/battery disconnect=C3=82 prot ocol >> out there? >> I'm thinking safety in the event of an incident which might short out th e >> fat wire to the fuselage. >> >> >> Battery contactor located as close as practical >> to battery; starter contactor as close as practical >> to starter. FAT wire connects battery contactor >> to starter contactor and main bus feeder. >> >> >> >> Bob . . . >> >> Un impeachable logic: George Carlin asked, "If black boxes >> survive crashes, why don't they make the whole airplane >> out of that stuff?" >> > ________________________________________________________________________________
Date: May 25, 2021
standard Cessna power receptacle https://www.aircraftspruce.com/catalog/elpages/extpowerrect.php On 24.05.2021 23:59, John B wrote: > Is this external power receptacle on a Western airplane? Or a Yak/CJ? > ________________________________________________________________________________
Subject: How many connections are too many
From: "AdventureD" <dobrien(at)microfoundations.com>
Date: May 24, 2021
I am reconfiguring some wiring to make it more user friendly next time I have to dig into it, and a question arises about the trade off between ease of use and connection quality. The main question is where to draw the line in the number of connections allowed to make things easy. For example, my bus (with breakers) on the back of the panel has all wires running to wires to a canon plug to allow disconnecting the canon plug and pulling out the breaker panel. The radio harness connects multiple avionics together but also has power, ground, headset, and lighting wires going to other places. Can I have additional connectors (e.g., Deutsch or canon connectors) making those connections to the harness so that it is easy to pull the harness if I have to? That would mean that each radio power wire has two connections beyond the bus, one just away from the bus, and one nearer the radio (not to mentions the connection to the bus and the dsub connected to the radio. Too many? How many is too many? Same question for grounding. My ground bus on the back of the firewall is in a location that is hard to reach when the panel is installed. Could I have grounds on the cockpit side of the firewall going through a canon plug to allow easy removal of the panel without unplugging each and every ground faston? Too many connections? I realize there is a technical way to see how much you lose from each connection. Are the rules of thumb on the number of connections for different types of circuits that are consistent with accepted practice? What is the best thing to read on this. Thanks in advance. Happy and safe flying, Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502047#502047 ________________________________________________________________________________
Subject: Re: How many connections are too many
Date: May 24, 2021
You can have as many connections as you want. But keep in mind that the vast majority of electrical problems are due to bad connections. Base your decision on how often wires must be taken apart. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502048#502048 ________________________________________________________________________________
Date: May 24, 2021
On 5/24/2021 5:38 PM, AdventureD wrote: > > I am reconfiguring some wiring to make it more user friendly next time I have to dig into it, and a question arises about the trade off between ease of use and connection quality. The main question is where to draw the line in the number of connections allowed to make things easy. > > For example, my bus (with breakers) on the back of the panel has all wires running to wires to a canon plug to allow disconnecting the canon plug and pulling out the breaker panel. The radio harness connects multiple avionics together but also has power, ground, headset, and lighting wires going to other places. Can I have additional connectors (e.g., Deutsch or canon connectors) making those connections to the harness so that it is easy to pull the harness if I have to? That would mean that each radio power wire has two connections beyond the bus, one just away from the bus, and one nearer the radio (not to mentions the connection to the bus and the dsub connected to the radio. Too many? How many is too many? > > Same question for grounding. My ground bus on the back of the firewall is in a location that is hard to reach when the panel is installed. Could I have grounds on the cockpit side of the firewall going through a canon plug to allow easy removal of the panel without unplugging each and every ground faston? Too many connections? > > I realize there is a technical way to see how much you lose from each connection. Are the rules of thumb on the number of connections for different types of circuits that are consistent with accepted practice? > > What is the best thing to read on this. > > Thanks in advance. > > Happy and safe flying, > Dan One option (easiest if you plan for it before executing the build) is to put all the power handling switches/CBs on a panel that can stay with the airframe when the panel comes out. Basically bundle all the wires going to/from the switch or CB panel, and either bottom mount the panel to the main panel or rear mount it in the main panel. To remove the main panel, just remove the screws holding the power panel(s) and let them 'dangle' when you remove the main panel. If you need a pic, I'll try to take one for you tomorrow. Charlie -- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: May 25, 2021
Subject: speaking of solenoids
My neighbor sourced a starter solenoid online (I forget if it was ebay or Amazon) and it worked for about 2 flights before going intermittent. When he disassembled it, he saw this method of grounding the coil wire. I'm not immune to using 'generic' parts, but this does show that it makes sense to verify quality on parts with unknown pedigree. ________________________________________________________________________________
From: "prestonkavanagh" <preston.kavanagh(at)gmail.com>
Date: May 25, 2021
I stumbled into doing what Charlie recommends. The instrument panel is a single piece with a 90 degree bend, the bend forming a shelf on top of the leg holes. (What's the technical term for "leg holes"?) 4 AWG comes to the back of the passenger side of the instrument panel. The ground, main distribution and a brown out buss are all there, mounted on the back of the panel or top of the leg hole shelf. I also have a 12-conductor expansion bus, currently empty but available for future use. To get the panel out I detach the several busses and remove a dozen screws holding panel to airplane structure. It takes about 10 minutes, but it's not complex. (The passenger side of the busses is an ipad frame. If I had avionics spilling over to the passenger side I would need a larger leg hole shelf.) -------- PBK3 PA-12, BD-4, RV6a, gliders Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502051#502051 Attachments: http://forums.matronics.com//files/ip_busses_142.jpg ________________________________________________________________________________
Date: May 25, 2021
now Ground power plug At 04:59 PM 5/24/2021, you wrote: >Is this external power receptacle on a Western airplane?=C2 Or a Yak/CJ? There have been a number of connector styles adapted to ground power service on aircraft. The military was fond of the 3-pin configuration with wiring as illustrated in View-A of: http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z31K.pdf The small pin is shorter than the other two power conducting pins. This pin was used to control a ground power contactor such that the contactor would NOT close until the main power pins were engaged. Conversely, upon disengagement the contactor WOULD open before the main power pins broke contact. This prevented arcing/burning of the power pins should connect/disconnect operations be conducted with a potential for high current flows. View-B illustrates a more pedestrian approach to ground power. This single pin connector was common to terrestrial vehicles manufactured by Cole-Hersee and perhaps others. I think Piper was the first to offer this connector on their product line. Virtually every FBO ground power cart I've encountered has two cart-to-aircraft cables: One with the mil-spec 3-terminal plug, a second with the Mack-truck style plug. I'm aware of a short-lived, single pin ground power connector that Beech used for a time waaayyy back when. http://www.aeroelectric.com/Pictures/Connectors/AeroStart/ I think this ground power combo was offered on some Beech models. A 'jumper cable' was supplied with each airplane 'cause few if any FBOs had mating plugs on their ground power carts. The clips are kinda flimsy for engine cranking currents. I suspect this cable's primary utility was to charge the ship's battery from a nearby vehicle whereupon the engine could be started using internal battery power. There may be others out there but the two styles illustrated in Z31 are the most prevalent in the wild. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: May 25, 2021
The thread started with Bob N. identifying the lacing we should be using. Coincidentally I had already purchased that EBay offering. This morning the seller wrote "Hi Preston, Thank you for contacting us. Yes we have about 65 spools more, how many do you want to purchase? please let us know" I don't want to be the go-between but if someone volunteers I'm guessing you can save a few dollars per spool. You can see the item in his EBay store by clicking through on https://www.ebay.com/str/mycyberoffice?_bkw=MilSpec+AA52081 Regards, PK -------- PBK3 PA-12, BD-4, RV6a, gliders Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502053#502053 ________________________________________________________________________________
Date: May 25, 2021
Subject: Re: speaking of solenoids
That kind of thing makes me wonder if and how, cheap low-quality look-alik es might infiltrate legitimate supply chains.=C2-=C2- Makes me kinda nervous but also makes me feel a little better about spendin g 2x or 3x as much for a "genuine Ford (or whatever manufacturer)" part. Caveat Emptor and you get what you pay for (how do you say that in Latin?;) -Jeff gmail.com> wrote: My neighbor sourced a starter solenoid online (I forget if it was ebay or Amazon) and it worked for about 2 flights before going intermittent. When h e disassembled it, he saw this method of grounding the coil wire. I'm not i mmune to using 'generic' parts, but this does show that it makes sense to v erify quality on parts with unknown pedigree. ________________________________________________________________________________
Date: May 25, 2021
At 08:21 AM 5/25/2021, you wrote: >My neighbor sourced a starter solenoid online (I forget if it was >ebay or Amazon) and it worked for about 2 flights before going >intermittent. When he disassembled it, he saw this method of >grounding the coil wire. I'm not immune to using 'generic' parts, >but this does show that it makes sense to verify quality on parts >with unknown pedigree. Yup . . . There are many sources for form-fit-function contactors that would appear to fill the need. Fortunately, most are probably of good value and will perform well. It is not DIFFICULT to avoid pot-holes in design such as you've discovered. But design isn't always the problem. Check out the illustrations at: http://www.aeroelectric.com/Pictures/Contactors/70%20Series%20Contactors/ In particular, this image at http://www.aeroelectric.com/Pictures/Contactors/70%20Series%20Contactors/70%20Series%20Failure%20(circa%202000)/TearDown_10.jpg This contactor failed for lack of due diligence in assembly . . . which can happen to anybody. All of the products illustrated in this series of pictures were nominally well suited to task by manufacturers with good track records. For those interested in such things, here's the after market electrical/ignition parts catalog from Standard (caution . . . it's a big one ~190MB). http://www.aeroelectric.com/Mfgr_Data/Standard/Ignition%20and%20Electrical%20Illustrated%20Parts%20Guide.pdf On page 1513 we find the SS-598 Starter 'Solenoid". This device probably has the largest applications list of all Standard contactors. I've been citing this part (and it's close cousins) for decades. As you can see from the catalog, Standard is one of the 'big dogs' in the after market parts business. If anyone has had both time and incentive to get it right, Standard is a good place to start. One thing I did notice while browsing the catalog is no mention of diode suppression on the coil. I used to sell a contactor with the necessary diode and if memory serves, it was a Standard part but 20+ years have stretched the gray matter thin. I'll check with B&C to see if they're selling the diode suppressed product and identify its pedigree. If the device is not specifically marked as 'diode suppressed', you can test it (I'll need to do a video on how) or simply add a diode for the heck of it. Two diodes is not 'better' than one . . . but no diode is not a good thing. Coil energy release in starter contactors is particularly wicked. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: May 25, 2021
> > I'll check with B&C to see if they're selling > the diode suppressed product and identify > its pedigree. Dave at B&C assures me that their S702-1 DOES include the coil suppression diode although it's no longer cited on either the box -or- the part itself. My goof - their website DOES call out this feature. https://bandc.com/product/intermittent-duty-starter-contactor/ Electrical testing for existence of the diode is not difficult . . . but it's something that it would be nice not to worry about. At the same time, lacking specific knowledge of it's presence kinda encourages one to add it to the outside . . . just-in-case. Also a PITA. I'll pray over this a bit. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Subject: Re: Magnetized Dynon D100 Display
Date: May 25, 2021
A little late getting this info (had said last Thursday but didn't go to the airport until today), but here goes: I have a SIRS floating magnetic compass mounted on top of my glareshield in a Glastar. I also have a Dynon D10A which was removed from the panel a couple years ago (and has been sitting in a cabinet at home since) and which had no electrical connections to it for the following experiment. Aircraft power was off. Both left and right sides of the D10A screen were placed in proximity to the compass with the following results: D10A right side: No effect at 4". Abt 1 deg at 2" and abt 2-3 deg in contact with the compass. D10A left side: No effect at 6", abt 1 deg at 4", abt 2 deg at 2" and 11 deg in contact with the compass. So the left side has more impact than the right side. The location of the D10A when installed in the aircraft was over 6" from the compass, so I never noticed any impact from the installation arrangement. Not sure what the meaning of the above is, but there is some magnetic affect not associated with current passing through the D10A (and probably other similar display devices). It is apparent also that separating a magnetic compass from display screens of any sort, and steel aircraft frames, is probably a prudent move. Doug Windhorn From: owner-aeroelectric-list-server(at)matronics.com On Behalf Of Robert L. Nuckolls, III Sent: Tuesday, May 18, 2021 11:07 AM Subject: Re: AeroElectric-List: Re: Magnetized Dynon D100 Display At 02:28 PM 5/17/2021, you wrote: > Upon further investigation, I don't think my D-180 display is magnetized after all. I pulled the D-180 part way out of the instrument panel without disconnecting any cables. Then I moved the compass around. The magnetic interference seemed to be stronger under the instrument panel. Eventually I determined that the control stick is magnetized and attracts the south end of the compass needle. As I moved the compass around the control stick, the needle always pointed at the stick. Sorry about posting an incorrect data point yesterday. It is worth a try for Chris to try demagnetizing the steel locking rod with a soldering gun. https://www.youtube.com/watch?v=g2sFp5Blg_g I received this note from John this morning: ================== received from John Torode 5/18/20 =============== bob, we have repeated the experiment with one of our d100s with the same result: the magnetic fields emanating from the d100 cause significant compass errors. we believe this is from currents inside the device, not from any material becoming magnetized. in fact we would try not to include much ferrous material (d-subs i guess). my electronic compass has a definite signature from the pulsating current in the power leads to the strobe, which are some distance away. what is puzzling is his claim that it used to work fine. one idea is that the power wire to the d100 has moved. we have spoken with him before (i am disappointed that any query from a customer goes unanswered), and have concluded that the panel is a bad place for a compass because of the many currents around. we do not think there is a reliable solution besides moving the compass to a magnetically quiet place. sorry, john ========================================================================== Compass interference issues can be difficult to track down. When Beech began offering the B&C SD-20 variants on the A36, we encountered a situation where turning the aux alternator on/off caused an unacceptable swing in the cowl mounted wet compass. We had to move it up onto the windshield. The distance moved was but a few inches but more toward the fringes of the magnetic field emanating from the rear of an energized alternator which was on the OTHER side of the firewall! Strength of magnetic forces vary with both distance and position. The forces do not radiate in uniformly dispersed spherical pattern. To make matters more complex, they can be strongly influenced by passive features located within the field. Steel tube airplanes were subject to magnetization of structure . . . sometimes difficult to neutralize. It was a rare instance that some interference was mitigated by demagnetizing some rogue source of magnetic force. The 'fix' nearly always called for a design change. We also know that the distance over which a given field has influence has a profound effect on strength. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: May 25, 2021
> If the device is not specifically marked > as 'diode suppressed', you can test it > (I'll need to do a video on how) or simply > add a diode for the heck of it. Two diodes > is not 'better' than one . . . but no diode > is not a good thing. Coil energy release > in starter contactors is particularly wicked. I've got a idea for a stone-simple, 'catch diode sniffer' for contactors. I need to proof it on the bench but I'm pretty sure I can post a bill-of-materials and schematic presently. Need to replace shocks on the truck first. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: May 25, 2021
And now we have to worry about pilots being magnetized by Moderna and Johnson & Johnson. It never ends. On Tue, May 25, 2021 at 8:05 PM n1dw wrote: > A little late getting this info (had said last Thursday but didn=99 t go to > the airport until today), but here goes: > > > I have a SIRS floating magnetic compass mounted on top of my glareshield > in a Glastar. I also have a Dynon D10A which was removed from the panel a > couple years ago (and has been sitting in a cabinet at home since) and > which had no electrical connections to it for the following experiment. > Aircraft power was off. Both left and right sides of the D10A screen wer e > placed in proximity to the compass with the following results: > > > D10A right side: No effect at 4=9D. Abt 1 deg at 2=9D and a bt 2-3 deg in > contact with the compass. > > D10A left side: No effect at 6=9D, abt 1 deg at 4=9D, abt 2 deg at 2=9D and 11 > deg in contact with the compass. So the left side has more impact than t he > right side. > > > The location of the D10A when installed in the aircraft was over 6 =9D from > the compass, so I never noticed any impact from the installation > arrangement. > > > Not sure what the meaning of the above is, but there is some magnetic > affect not associated with current passing through the D10A (and probably > other similar display devices). It is apparent also that separating a > magnetic compass from display screens of any sort, and steel aircraft > frames, is probably a prudent move. > > > Doug Windhorn > > > *From:* owner-aeroelectric-list-server(at)matronics.com < > owner-aeroelectric-list-server(at)matronics.com> *On Behalf Of *Robert L. > Nuckolls, III > *Sent:* Tuesday, May 18, 2021 11:07 AM > *To:* aeroelectric-list(at)matronics.com > *Subject:* Re: AeroElectric-List: Re: Magnetized Dynon D100 Display > > > At 02:28 PM 5/17/2021, you wrote: > > > Upon further investigation, I don't think my D-180 display is magnetized > after > all. I pulled the D-180 part way out of the instrument panel without > disconnecting any cables. Then I moved the compass around. The magnetic > interference seemed to be stronger under the instrument panel. Eventuall y > I > determined that the control stick is magnetized and attracts the south en d > of > the compass needle. As I moved the compass around the control stick, the > needle always pointed at the stick. Sorry about posting an incorrect dat a > point yesterday. > It is worth a try for Chris to try demagnetizing the steel locking rod > with a soldering gun. > https://www.youtube.com/watch?v=g2sFp5Blg_g > > > I received this note from John this morning: > > ================== received from John Torode 5/18/20 ============== > bob, > > we have repeated the experiment with one of our d100s with the same > result: the magnetic fields emanating from the d100 > cause significant compass errors. we believe this is from currents insid e > the device, not from any material becoming magnetized. > in fact we would try not to include much ferrous material (d-subs i guess ). > > my electronic compass has a definite signature from the pulsating current > in the power leads to the strobe, which are some distance > away. > > what is puzzling is his claim that it used to work fine. one idea is that > the power wire to the d100 has moved. > > we have spoken with him before (i am disappointed that any query from a > customer goes unanswered), and have concluded that > the panel is a bad place for a compass because of the many currents aroun d. > > we do not think there is a reliable solution besides moving the compass t o > a magnetically quiet place. > > sorry, > > john > > ======================== > > Compass interference issues can be difficult to track down. > When Beech began offering the B&C SD-20 variants on the > A36, we encountered a situation where turning the aux > alternator on/off caused an unacceptable swing in the > cowl mounted wet compass. We had to move it up onto the > windshield. > > The distance moved was but a few inches but more toward > the fringes of the magnetic field emanating from the > rear of an energized alternator which was on the OTHER > side of the firewall! > > Strength of magnetic forces vary with both > distance and position. The forces do not radiate > in uniformly dispersed spherical pattern. To make > matters more complex, they can be strongly > influenced by passive features located within > the field. > > Steel tube airplanes were subject to magnetization > of structure . . . sometimes difficult to neutralize. > > It was a rare instance that some interference > was mitigated by demagnetizing some rogue source > of magnetic force. The 'fix' nearly always called > for a design change. > > We also know that the distance over which > a given field has influence has a profound > effect on strength. > > > Bob . . . > > Un impeachable logic: George Carlin asked, "If black boxes > survive crashes, why don't they make the whole airplane > out of that stuff?" > ________________________________________________________________________________
Subject: Re: Video editing software
Date: May 26, 2021
I know it's been a while and you have recommended/shared here some really cool and uptodate softwares for editing videos, but I need some help. I had a nice pc with great graphic card, very powerful one, and unfortunately I needed to sell it. I bought a little laptop that is like a "toy", you cn do absolutely nothing with it. And I still need to edit videos that I film for my youtube channel. I can't use something like premiere pro or resolve on it, so I was thinking about an online video editor. Maybe fastreel.com (https://www.fastreel.com) will suit me. Has anyone tried it? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502062#502062 ________________________________________________________________________________
Subject: Order essay online cheap
Date: May 27, 2021
Order essay online cheap Students and other people requiring academic writing help might hesitate to request such services because they lack confidence in the helpers skills. Such businesses are prevalent in the social media world. A famous startup was once a focal point for scammers who specialized in offering affordable essays. Today, many students have fallen victim to fake companies, and their private data is being used for fraudulent actions. Although the quality of your work is guaranteed, sometimes the real deal is out there. Take precautions not to fall into the trap. Why Student Navigators Should Consider Buying Essay Online Cheap It is easy to identify a scammer by the look of the profile posted on the site. Furthermore, anyone reading reviews for that particular company will be impressed by the results. You just cant afford to waste money and time dealing with a fraudster. It is possible to use various means to tell that a legitimate write for you. For instance, check through the clients testimonials. If clients are satisfied with the standard of the job done, it shows that the business is trustworthy. Other guarantees that attracts reputable writing agencies include: * Timely delivery of orders * Excellent grades * Proper communication channels * Confidentiality A credible platform will hire expert writers depending on its reputation. Therefore, if you are looking for a genuine writing agency, go ahead and select one that has a record of conducting extensive research on numerous topic areas. The comments section is a crucial area to evaluate a service b before committing yourself. If you are confident that the basis of the task is solid, try to communicate with the agents. Let them give as much information on how your task is coming up. Having the discussions in progress will allow the professional to begin working on the paper. Besides, you will be getting timely deliver dates for your tasks. Whichever option you pick, make sure it is exclusive for you. Some sites have set specific rules for the number of words an order entails, which often contributes to the final price. Avoid paying more than the required deadline or losing something entirely. Instead, instead, opt for a specialist that delivers on time and assures you of a great piece. How Professional Writers Manage Your Paper You could have a lot of material to hand in but fail to do a proper study to submit a flawless article. That is why its vital to seek assistance where necessary. One of the easiest ways to discover a reliable establishment is by visiting the previously served customers feedback. Through the conversations, you will know whether the company is legit. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502063#502063 ________________________________________________________________________________
Date: May 27, 2021
Have you tried Cyberlink Power Director for video editing? It uses less resources than most that are decent editors. Biggest issue for substandard processing computer will be rendering the final video. Just no substitute for lots of processing power........unfortunately...... On-line processors are good for SHORT videos but not much else.. Good luck in your quest. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com On Behalf Of ArnoldWilder Sent: Wednesday, May 26, 2021 6:48 PM Subject: AeroElectric-List: Re: Video editing software --> I know it's been a while and you have recommended/shared here some really cool and uptodate softwares for editing videos, but I need some help. I had a nice pc with great graphic card, very powerful one, and unfortunately I needed to sell it. I bought a little laptop that is like a "toy", you cn do absolutely nothing with it. And I still need to edit videos that I film for my youtube channel. I can't use something like premiere pro or resolve on it, so I was thinking about an online video editor. Maybe fastreel.com (https://www.fastreel.com) will suit me. Has anyone tried it? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502062#502062 ________________________________________________________________________________
Subject: Re: "Contactor Questions" , battery in the trunk, now
Ground
Date: May 29, 2021
Bob's write up made this a fun little project, now easily accessed while hidden away under a rear seat. -------- PBK3 PA-12, BD-4, RV6a, gliders Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502101#502101 Attachments: http://forums.matronics.com//files/shore_power_926.png ________________________________________________________________________________
From: "Matthew S. Whiting" <m.whiting(at)frontier.com>
Date: May 29, 2021
Subject: Z-14 question
Bob, a question about Z-14. I am considering this architecture for my S-21. The starter/cross-feed switch is listed as S700-2-7, but the figure looks more like a 2-5 and the function seems to make that switch the correct choice. I cant see a reason why the non-starter cross-feed position would also be momentary. Is this just a typo on the switch designation? Regards, Matt Whiting Sent from my iPad ________________________________________________________________________________
Date: May 29, 2021
Subject: Re: Z-14 question
At 05:06 PM 5/29/2021, you wrote: >"Matthew S. Whiting" > >Bob, a question about Z-14. I am considering this architecture for my S-21. > >The starter/cross-feed switch is listed as >S700-2-7, but the figure looks more like a 2-5 >and the function seems to make that switch the >correct choice. I can=99t see a reason why the >non-starter cross-feed position would also be >momentary. Is this just a typo on the switch designation? Yes, be sure you're getting the latest revision level of any Z-figure from the website. The current revision for Z-14 dated 2013 is "P" where the switch callout as indeed corrected to S702-2-5. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: May 30, 2021
Hmmmm. I got it from the web site so I thought it was the latest. I got it here: http://www.aeroelectric.com/Books/Connection/AppZ_12A3.pdf I just checked and this version is still incorrect. I am assuming there mus t be another location or maybe you only update the CAD files and I don =99t have a CAD program to read those so I usually look at the PDFs. I will find a .DWG viewer and check the CAD version. Thanks, Matt Sent from my iPad > On May 29, 2021, at 11:13 PM, Robert L. Nuckolls, III <nuckolls.bob@aeroel ectric.com> wrote: > > =EF=BB At 05:06 PM 5/29/2021, you wrote: frontier.com> >> >> Bob, a question about Z-14. I am considering this architecture for my S- 21. >> >> The starter/cross-feed switch is listed as S700-2-7, but the figure looks more like a 2-5 and the function seems to make that switch the correct choi ce. I can=99t see a reason why the non-starter cross-feed position wo uld also be momentary. Is this just a typo on the switch designation? > > Yes, be sure you're getting the latest revision > level of any Z-figure from the website. The > current revision for Z-14 dated 2013 is "P" > where the switch callout as indeed corrected to > S702-2-5. > > Bob . . . > > Un impeachable logic: George Carlin asked, "If black boxes > survive crashes, why don't they make the whole airplane > out of that stuff?" ========================== ========================== ========================== -========================= ========================== -========================= ========================== ========================== ==================== ________________________________________________________________________________
Date: May 30, 2021
http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/ On Sun, May 30, 2021 at 6:33 AM Matthew S. Whiting wrote: > Hmmmm. I got it from the web site so I thought it was the latest. I got > it here: http://www.aeroelectric.com/Books/Connection/AppZ_12A3.pdf > > I just checked and this version is still incorrect. I am assuming there > must be another location or maybe you only update the CAD files and I don =99t > have a CAD program to read those so I usually look at the PDFs. I will > find a .DWG viewer and check the CAD version. > > Thanks, > Matt > > Sent from my iPad > > On May 29, 2021, at 11:13 PM, Robert L. Nuckolls, III < > nuckolls.bob(at)aeroelectric.com> wrote: > > At 05:06 PM 5/29/2021, you wrote: > > m.whiting(at)frontier.com> > > Bob, a question about Z-14. I am considering this architecture for my > S-21. > > The starter/cross-feed switch is listed as S700-2-7, but the figure looks > more like a 2-5 and the function seems to make that switch the correct > choice. I can=99t see a reason why the non-starter cross-feed posi tion would > also be momentary. Is this just a typo on the switch designation? > > > Yes, be sure you're getting the latest revision > level of any Z-figure from the website. The > current revision for Z-14 dated 2013 is "P" > where the switch callout as indeed corrected to > S702-2-5. > > Bob . . . > > Un impeachable logic: George Carlin asked, "If black boxes > survive crashes, why don't they make the whole airplane > out of that stuff?" > ======================== =========== ============= ===================== > ======================== =========== ============= ===================== > ======================== > > -- --- David Carter david(at)carter.net ________________________________________________________________________________
Date: May 30, 2021
Voyager wrote: > Hmmmm. I got it from the web site so I thought it was the latest... I made a cheat sheet. https://docs.google.com/document/d/1iR03DwNeHZy8hO7xBtALPb4_Tl0EY3OdZnAEIxpfMVY/edit?usp=sharing -------- John Bright, RV-6A, at FWF, O-360 Z-101 single batt dual alt SDS EM-5-F. john_s_bright(at)yahoo.com, Newport News, Va https://docs.google.com/document/d/1YOtPiA3AdUsQEYR4nodBESNAo21rxdnx4pFs7VxXfuI/edit?usp=sharing Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502114#502114 ________________________________________________________________________________
Date: May 30, 2021
Thanks. I=99d been in this directory once before, but somehow found m y way to the older one this last time. Sent from my iPad > On May 30, 2021, at 8:58 AM, David Carter wrote: > > =EF=BB > http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/ > > >> On Sun, May 30, 2021 at 6:33 AM Matthew S. Whiting wrote: >> Hmmmm. I got it from the web site so I thought it was the latest. I got it here: http://www.aeroelectric.com/Books/Connection/AppZ_12A3.pdf >> >> I just checked and this version is still incorrect. I am assuming there m ust be another location or maybe you only update the CAD files and I don =99t have a CAD program to read those so I usually look at the PDFs. I will find a .DWG viewer and check the CAD version. >> >> Thanks, >> Matt >> >> Sent from my iPad >> >>>> On May 29, 2021, at 11:13 PM, Robert L. Nuckolls, III <nuckolls.bob@aer oelectric.com> wrote: >>>> >>> At 05:06 PM 5/29/2021, you wrote: g(at)frontier.com> >>>> >>>> Bob, a question about Z-14. I am considering this architecture for my S -21. >>>> >>>> The starter/cross-feed switch is listed as S700-2-7, but the figure loo ks more like a 2-5 and the function seems to make that switch the correct ch oice. I can=99t see a reason why the non-starter cross-feed position w ould also be momentary. Is this just a typo on the switch designation? >>> >>> Yes, be sure you're getting the latest revision >>> level of any Z-figure from the website. The >>> current revision for Z-14 dated 2013 is "P" >>> where the switch callout as indeed corrected to >>> S702-2-5. >>> >>> Bob . . . >>> >>> Un impeachable logic: George Carlin asked, "If black boxes >>> survive crashes, why don't they make the whole airplane >>> out of that stuff?" >>> ========== ========== ==== ====== ========== ========= >>> > -- > --- > David Carter > david(at)carter.net ________________________________________________________________________________
Date: May 30, 2021
At 07:30 AM 5/30/2021, you wrote: >Hmmmm. I got it from the web site so I thought it was the >latest. I got it here: ><http://www.aeroelectric.com/Books/Connection/AppZ_12A3.pdf>http://www.aeroelectric.com/Books/Connection/AppZ_12A3.pdf This link is Rev 12 BOOK, not the page-per-system archives . . . Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: May 30, 2021
At 08:25 AM 5/30/2021, you wrote: >Thanks. I=99d been in this directory once >before, but somehow found my way to the older one this last time. > >Sent from my iPad > >>On May 30, 2021, at 8:58 AM, David Carter wrote: >> >>=EF=BB >><http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/>http://www.aeroe lectric.com/PPS/Adobe_Architecture_Pdfs/ These are the PPS archives where BOTH autocad dwg and Acrobat pdf files are updated and stored. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: May 31, 2021
Thanks, Bob! Matt Sent from my iPad > On May 31, 2021, at 12:50 AM, Robert L. Nuckolls, III <nuckolls.bob@aeroel ectric.com> wrote: > > =EF=BB At 08:25 AM 5/30/2021, you wrote: >> Thanks. I=99d been in this directory once before, but somehow foun d my way to the older one this last time. >> >> Sent from my iPad >> >>> On May 30, 2021, at 8:58 AM, David Carter wrote: >>> >>> =EF=BB >>> http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/ > > These are the PPS archives where BOTH autocad > dwg and Acrobat pdf files are updated and > stored. > > > Bob . . . > > Un impeachable logic: George Carlin asked, "If black boxes > survive crashes, why don't they make the whole airplane > out of that stuff?" ________________________________________________________________________________
Date: Jun 01, 2021
Subject: Diode Failure Current vs Time Graph
Hey BobN, In your vast array of data & test results, do you have a current vs time gr aph of a solenoid spike-suppression diode (1N5004?) short circuit? I'm wondering what the peak current is before it is destroyed. Somewhere I have an old PC based O-scope but I don't remember what its freq uency range is (or even where it is), but how many samples per second would be adequate to catch a failure like that. I would use something like a 150A shunt (I think I have one lying around). =C2- Do you think that would be adequate?=C2- Would a shunt like that r emain linear at say 100% overload?=C2- Or, would we get even close to 300 amps? Purely an academic exercise (electrical nerd inquiring mind(s) want to know ;) -Jeff ________________________________________________________________________________
From: "PippaSutherland" <PippaSutherland7FpxL(at)yahoo.com>
Date: Jun 02, 2021
Good words indeed. If it were possible to make an airplane out of such material, they would work on it.... I think so! Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502201#502201 ________________________________________________________________________________
Date: Jun 03, 2021
Subject: Re: Diode Failure Current vs Time Graph
At 11:35 AM 6/1/2021, you wrote: >Hey BobN, > >In your vast array of data & test results, do you have a current >vs time graph of a solenoid spike-suppression diode (1N5004?) short circuit? > >I'm wondering what the peak current is before it is destroyed. Interesting question and one that can probably be deduced by experiment. Setting up the experiment would be tricky. It's not so much a "peak current" as it is a "watt-seconds" issue . . . very much time dependent. To destroy a diode you need to either (1) MELT the barrier-hill layer between the p/n elements. This requires a watts/second injection of energy at some rate that exceeds the devices ability to reject the resulting generated heat. For our 1N400X series friends, this could be something on the order of 5A for Seconds . . . or 100A for milliseconds. (2) you can punch out the barrier-hill layer with reverse voltage that exceeds that layer's ability to stand it off. Again, it's an energy rate function, how much reverse current flows at the junction's breakdown voltage (watts) for sufficient time and rate to produce melting. Most people don't know it but ordinary junction diodes can be pressed into service as high voltage zeners. I used to use them as 700VDC regulators to bias up Geiger Muller tubes in radiation detectors. I had to hand select diodes from a lot to find the ones that offered 700V operation at about 50 microamps . . . or about 35 milliwatts dissipation. Well below the thermal threshold for damage. Getting back to your question: Download this data sheet . . . http://www.aeroelectric.com/Mfgr_Data/Semiconductors/1N4001.pdf Here we see a forward surge current rating of 50A with an interval of 1/2 of the 60H sine wave of 8.3 milliseconds. The data sheet says you can do this one time (generally interpreted to mean very low duty cycle). You could probably hit the device with this pulse once every second for a duty cycle of less than 1%. On this same data sheet we see thermal ratings citing 3W maximum dissipation. 175C maximum junction temperature and 50C/W thermal resistance to ambient. 50C/W X 3W is a 150C rise which is added to 25C ambient to get to the 175C max operating temperature. My hypothetical 5A 'overload' cited above would probably produce a voltage drop of over 1V. That's 5 Watts dissipation for a potential 275C junction temperature. Somewhere above 175C the junction will fail after sufficient time to produce the rise. The 30A rated surge pulse would obviously heat it up much faster but the 8.3Ms limit would be conservative. These numbers suggest some parameters for setting up your experiment. They also validate our selection of the 1N400x series devices as contactor coil spike catchers. A charged capacitor will deliver discharge voltage at no higher value than the capacitor was charged to. Similarly, an inductor delivers discharge current at the same value to which it was chaged. A 3A starter contactor coil would 'hammer' its catch diode at 3A peak for no more than 5-10 Milliseconds. Well inside the surge current limits suggested by the data sheet. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Subject: Cessna 180 electrical issues
Date: Jun 07, 2021
Dear Bob et al. I'm forwarding a call for help I received from a very good friend. Seems his electrics are playing up possibly as a result of and after the installation of an ADS-B transponder and 8.33Mhz radio. Main question I guess is why are these strange events happening at low engine rpm? Appreciate that in this scenario the alternator output is less but why would that "pop" circuit breakers and turn a transponder "ON"? Could it be grounding/earth issue? Any ideas would be very much appreciated. Many thanks. Patrick Elliott, UK "The electric gremlins in the Cessna are bizarre. Twice now I=99ve had to land at night with no lights at all. Not eve n landing lights. (They have started popping their own circuit breakers!). And, I like flying at night. So, here=99s what I=99m going to have the mechanic try. Take out the mode S transponder and run over it with the tractor. Wire the 12v lighter plug, which is important to keep the iPad going, to the old mode S transponder breaker. Wire the navigation lights breaker directly to the main DC bus. I have no idea what to do with the landing lights. Why would the breaker pop on (engine) power reduction? Why in the world would the xponder turn ON? Your thoughts." ________________________________________________________________________________
Subject: A Beginner Is Simple to Manage
Date: Jun 07, 2021
A Beginner Is Simple to Manage When Falling For The Wrong Math Homework Solver Are you looking for a straightforward way of doing your Mathematics assignments without any difficulties? Our company will try to assist you in getting the best assistant to manage your assignment. So, what are the things that will motivate you to select a faulty math homework solver? Read on to know more! What Makes Us Outstanding? The kind of training that students get in schools determines their performances. Often, scholars face various academic challenges that prevent them from submitting recommended reports. Because of that, most of them end up requesting assistance from professionals. We are a firm that offers students guidance in managing their studies. By securing professional help, we can confidently handle every academic task that you request. We are always available at whatever time you request. Many students would want to benefit from our services. The good thing is that they can quickly access any available source to handle your writing, research, or any other instruction. Not only that, we can also handle requests as per the clients instructions. Furthermore, our clients know how to brand themselves easily. As such, youll never fear to ask for a Physics homework solver from us. You can even relate someone in your social circle to be sure that you are in the right state of mind. * Originality Our writers understand the essence of presenting original math assignments. Any assignment that we handle must adhere to the rules in education. Always check with our centers to confirm if the guidelines are genuine. From there, youll be confident that you will submit a paper that adheres to the instructions. * Plagiarism free documents Students often fail to present plagiarized copies because they didnt have the appropriate citation style. Our company will provide you with a plagiarism report to prove that your calculations are correct. Preferably, we will deliver safe and well-formatted copies for your physics homework assignments. * 24/7 Services Being a science student, you might not be able to handle some tasks on time. Luckily enough, many online sources offer 24-hour papers writing service (https://papernow.org/) to individuals who require Ph. D. assistance. Hiring a Ph.D. helper is one of the easiest ways of ensuring that you get quick deliveries. Also, since we all face different deadlines, you can rely on our help whenever you get stuck in your studies. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502272#502272 ________________________________________________________________________________
Subject: A Beginner Is Simple to Manage When Falling For The
Wrong Ma
Date: Jun 07, 2021
A Beginner Is Simple to Manage When Falling For The Wrong Math Homework Solver Are you looking for a straightforward way of doing your Mathematics assignments without any difficulties? Our company will try to assist you in getting the best assistant to manage your assignment. So, what are the things that will motivate you to select a faulty math homework solver? Read on to know more! What Makes Us Outstanding? The kind of training that students get in schools determines their performances. Often, scholars face various academic challenges that prevent them from submitting recommended reports. Because of that, most of them end up requesting assistance from professionals. We are a firm that offers students guidance in managing their studies. By securing professional help, we can confidently handle every academic task that you request. We are always available at whatever time you request. Many students would want to benefit from our services. The good thing is that they can quickly access any available source to handle your writing, research, or any other instruction. Not only that, we can also handle requests as per the clients instructions. Furthermore, our clients know how to brand themselves easily. As such, youll never fear to ask for a Physics homework solver from us. You can even relate someone in your social circle to be sure that you are in the right state of mind. * Originality Our writers understand the essence of presenting original math assignments. Any assignment that we handle must adhere to the rules in education. Always check with our centers to confirm if the guidelines are genuine. From there, youll be confident that you will submit a paper that adheres to the instructions. * Plagiarism free documents Students often fail to present plagiarized copies because they didnt have the appropriate citation style. Our company will provide you with a plagiarism report to prove that your calculations are correct. Preferably, we will deliver safe and well-formatted copies for your physics homework assignments. * 24/7 Services Being a science student, you might not be able to handle some tasks on time. Luckily enough, many online sources offer 24-hour papers writing service (https://papernow.org/) to individuals who require Ph. D. assistance. Hiring a Ph.D. helper is one of the easiest ways of ensuring that you get quick deliveries. Also, since we all face different deadlines, you can rely on our help whenever you get stuck in your studies. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502271#502271 ________________________________________________________________________________
Subject: Re: Cessna 180 electrical issues
Date: Jun 07, 2021
Post a schematic diagram of the aircraft electrical system, especially loads that draw 1 amp or more. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502275#502275 ________________________________________________________________________________
Subject: EGT issues hwo to troubleshoot best
Date: Jun 07, 2021
Hi there, I changed a few years ago from a Rocky Mountain engine monitor with selector switch to a Dynon EMS 10 engine monitor. The probes from the RM monitor have long leads back into the cockpit and a braided steel cover around the wires. The wires are crimped to D-sub pins and end in a DB25 plug. due the braided steel covers all is a bit tight at the d-sub plug. I had an erratic CHT at the begin but a reseat in the plug solved that mystery. But I had from the begin EGT4 acting up below 200 deg F it has very little differences from the 3 others (see pictures) but above the curve flatens significantly. After all the years living with that error and trying with icebath, boiling water etc to no avail I would like to dig a bit deeper. Does anybody have a good plan how to tackle this as the error shows up only on a running engine. At 2 mins you see the runup, the departure is at about 9 minutes. Many thanks for your ideas, due to the difficult access to the d-sup pins it is pretty difficult to swap 2 probes in the plug. Cheers Werner Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502277#502277 Attachments: http://forums.matronics.com//files/egt_153.jpg http://forums.matronics.com//files/cht_737.jpg ________________________________________________________________________________
Subject: Re: EGT issues hwo to troubleshoot best
Date: Jun 08, 2021
Werner, It's not clear if you're using Dynon sensors although other brands should be compatible if they're the same standard. I has a similar problem with my EMS-D10 five years ago when I first started the engine. This was already a few years since installation. The EGTs read accurate ambient temperature but settled about 530 F during the runup. Unlike your case I saw low temperature on all cylinders. After discussing with Dynon I sent it back and it turned out to be an internal hardware problem that they fixed. No problems during the subsequent 300 hours of operation. It's not troubleshooting, but calling Dynon worked for me. Regards, Chris. -------- Chris Skelt Lancair 320 N1990L at KIWS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502288#502288 ________________________________________________________________________________
Date: Jun 08, 2021
Thanks Chris. No this are the sensors from my Rocky Mountain engine monitor, all the rest is working fine just EGT4 is to low and the temperature is also all the time fluctuating up and down where all the others are stable. Cheers Werner On 08.06.2021 14:16, cskelt wrote: > > Werner, > It's not clear if you're using Dynon sensors although other brands should be compatible if they're the same standard. > > I has a similar problem with my EMS-D10 five years ago when I first started the engine. This was already a few years since installation. The EGTs read accurate ambient temperature but settled about 530 F during the runup. Unlike your case I saw low temperature on all cylinders. After discussing with Dynon I sent it back and it turned out to be an internal hardware problem that they fixed. No problems during the subsequent 300 hours of operation. It's not troubleshooting, but calling Dynon worked for me. > > Regards, > Chris. > > -------- > Chris Skelt > Lancair 320 N1990L at KIWS > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=502288#502288 > > ________________________________________________________________________________
Subject: writers help
Date: Jun 10, 2021
How to Select the Right University Urgent Assignment Help The wait for a quality emergency paper is not an affair. It all starts with selecting a fast delivery date for your task. You may have a lot of work to complete, but it becomes imperative to have a writers help (https://expert-writers.net/) timely assignment as it significantly impacts the final grade. Every student needs to present an error-free essay to succeed in their coursework. Here are some strategies for choosing the best organization for a great US allocation. Verify the Quality of the Submissions You must be accustomed to handling lots of papers from various subjects. Each subject should have value to the reader, and contingent on the kind of workload, it might not be worth a good idea to have a bit of homework on. Look for a legitimate service that has vast experience in the industry and wishes to create awareness through the following: Rating scores Editing and proofreading Formatting Test for plagiarism If the majority of the articles delivered are substandard, it means that yours will end up in the hands of an unqualified writer. Therefore, if there are many instances where a professor deems these pieces unworthy, it is better to disregard them and hand in the article with minimal effort. Find a Company that Priorits to Excellence Regardless of whether the tutor gave you the assignments, the fact that they went global does not mean that the rest of the class didn't meet the demands. After checking every aspect of the catalog, the only thing standing between the two is dependability. Whenever aservice comes knocking at the door, it is because the firm is willing to go the extra mile and delivering impressive items, while additionally offering criticism on the underperforming students. This alone is enough incentive to secure a reliable agency to assign the term academic works. It ensures that even if the slot is in doubt, it will be handled by a qualified professional who is also an expert in that topic. It Is a Chance to Get What Your Instructor Wants One of the safest and fastest ways to attain uniqueness in the scholarly field is by requesting a piece crafted from scratch. A highly experienced author will format the document in a way that gets the message from the beginning to the finish. This gives the scholar an edge over the others and prevents them from deviating away from the expected direction. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502312#502312 ________________________________________________________________________________
Date: Jun 10, 2021
Werner, Here's an example of an EGT probe failure. The duration of the flight is about 28 minutes. The tip was badly eroded and the problem fixed by replacing the offending article. Shortly afterwards two more failed so I replaced the remaining three and it's all been good since. They lasted about 280 hours. Other than the failure, all the EGT and CHT behavior correlates with manifold pressure, mixture etc. and EGTs are more stable than yours. Note that after the failure EGT 2 went back in line with the other probes when the power setting was reduced for descent to destination. Your EGT 4 has some of the characteristics of the others, although the response is attenuated. I would argue that none of your EGTs are as stable as they should be, and EGT 4 is uniquely pathological. Can you make a plot showing correspondence between EGT and CHT, and add some engine parameters like manifold pressure, fuel flow etc. as these should all tie together. Regards, Chris. -------- Chris Skelt Lancair 320 N1990L at KIWS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502314#502314 Attachments: http://forums.matronics.com//files/egt_probe_failure_727.png ________________________________________________________________________________
Subject: Re: Radio or Television Tower Buzz
Date: Jun 11, 2021
Yep, interesting thread. I usually have the same issue while flying in the vicinity of radio towers. At first, I was a little bit scared because of the noises, but then I understood that it gives some kind of adrenaline. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502331#502331 ________________________________________________________________________________
Date: Jun 11, 2021
Subject: Locking 3P switch?
Please see attached diagram. I'm looking for a better solution than what I'm showing now for the "test/kill" connection on the SDS CPI-2 ECU. I believe it would be better if this was on the same switch as the power to the ECU & coil, so that the "test/kill" connection would be grounded any time the ECU & coil power supplies are switched off. Grounding this connection causes the ECU to stop firing the coils/plugs. When power is removed from the ECU & coil primary supply connections, the ECU remains on & automatically switches to the backup power supply. The manufacturer's intent is that this is supplied by a dedicated battery with an unswitched supply rather than the Z101 engine bus, but that's not relevant to the question at hand. Can anyone suggest a locking 3 pole switch similar to the Honeywell NT series, or another creative way to achieve this with more common switches? Thanks, David --- David Carter david(at)carter.net ________________________________________________________________________________
From: "Tom Barter" <kesleyelectric(at)iowatelecom.net>
Subject: MAC/Ray Allen trim actuator connections
Date: Jun 11, 2021
Greetings, I'm in the process of installing an MAC/Ray Allen trim actuator, and am wondering what the best way is to connect the five 26 gauge leads coming out of the actuator to the corresponding 26 gauge five wire control cable that will be routed up to the cockpit. The company used to offer a small, round pin connector for that purpose, but not any more. Would like to be able to disconnect the actuator rather than cut solder joints, if possible. Any suggestions for a connector for fine wires like that appreciated. Tom Barter -- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
From: William Daniell <wdaniell.longport(at)GMAIL.COM>
Date: Jun 11, 2021
Subject: Re: MAC/Ray Allen trim actuator connections
I used a molex but i suspect a dsub would have been better Will William Daniell +1 786 878 0246 On Fri, Jun 11, 2021, 18:25 Tom Barter wrote: > Greetings, > > > I=99m in the process of installing an MAC/Ray Allen trim actuator, and am > wondering what the best way is to connect the five 26 gauge leads coming > out of the actuator to the corresponding 26 gauge five wire control cable > that will be routed up to the cockpit. The company used to offer a small , > round pin connector for that purpose, but not any more. Would like to be > able to disconnect the actuator rather than cut solder joints, if > possible. Any suggestions for a connector for fine wires like that > appreciated. > > > Tom Barter > > > Virus-free . > www.avast.com > > <#m_-6897774303887738996_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> > ________________________________________________________________________________
Date: Jun 11, 2021
At 05:21 PM 6/11/2021, you wrote: >Greetings, > > >I'm in the process of installing an MAC/Ray Allen trim actuator, and >am wondering what the best way is to connect the five 26 gauge leads >coming out of the actuator to the corresponding 26 gauge five wire >control cable that will be routed up to the cockpit. The company >used to offer a small, round pin connector for that purpose, but not >any more. Would like to be able to disconnect the actuator rather >than cut solder joints, if possible. Any suggestions for a >connector for fine wires like that appreciated. > > Ditch the 26AWG 5wire extension and mate your MAC actuator to a 22AWG 5-wire bundle of your own making. Here's a suggested method that is much easier to fabricate and decidedly more robust as a finished installation: https://tinyurl.com/cmq7epd Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jun 11, 2021
Machined subD pins should work fine; if needed strip twice as much and double the wire before inserting in the pin. If you want them 'orderly', use a 9 pin housing; otherwise just use heat shrink over each mated pair. Wish I could claim the idea.. ;-) Charlie Virus-free. www.avast.com <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> On Fri, Jun 11, 2021 at 5:25 PM Tom Barter wrote: > Greetings, > > > I=99m in the process of installing an MAC/Ray Allen trim actuator, and am > wondering what the best way is to connect the five 26 gauge leads coming > out of the actuator to the corresponding 26 gauge five wire control cable > that will be routed up to the cockpit. The company used to offer a small , > round pin connector for that purpose, but not any more. Would like to be > able to disconnect the actuator rather than cut solder joints, if > possible. Any suggestions for a connector for fine wires like that > appreciated. > > > Tom Barter > > > Virus-free . > www.avast.com > > <#m_1956570227212391193_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> > ________________________________________________________________________________
Subject: Garmin GTR 200 Help Needed
Date: Jun 11, 2021
I have a GTR 200 installed in a certificated airplane so Garmin tech support won't help. I'm having an issue with the received volume on the initial response to my transmission in that the volume is about 1/2 of normal, and it only is in the left headset speaker. Either this has recently started or I haven't noticed it before. The radio is stand alone, no audio panel is installed. Garmin says take it to a dealer but there aren't any conveniently located. Any ideas? John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502339#502339 ________________________________________________________________________________
Date: Jun 11, 2021
I remember seeing this approach somewhere also, I want to say from Stein Bru ch at Steinair. He simply used good quality pins and sockets and then mated them and individually heat shrunk them as you describe. I think he may hav e put a larger heat shrink sleeve over the entire bundle for an extra payer o f protection and neatness. It looked like a neat and tidy solution. Certai nly not as quick to disconnect as an actual connector, but then how often do you remove the elevator or tail of your airplane? I am considering this approach, but may also just use a 0.062 pitch mini mol ex as they are fairly robust and small, but not weatherproof. A 5 pin Weath erpack or Metripack is weatherproof, but much bulkier. Matt Sent from my iPad > On Jun 11, 2021, at 6:41 PM, Charlie England wrote: > > =EF=BB > Machined subD pins should work fine; if needed strip twice as much and dou ble the wire before inserting in the pin. If you want them 'orderly', use a 9 pin housing; otherwise just use heat shrink over each mated pair. > > Wish I could claim the idea.. ;-) > > Charlie > > Virus-free. www.avast.com > >> On Fri, Jun 11, 2021 at 5:25 PM Tom Barter wrote: >> Greetings, >> >> >> >> I=99m in the process of installing an MAC/Ray Allen trim actuator, a nd am wondering what the best way is to connect the five 26 gauge leads comi ng out of the actuator to the corresponding 26 gauge five wire control cable that will be routed up to the cockpit. The company used to offer a small, r ound pin connector for that purpose, but not any more. Would like to be abl e to disconnect the actuator rather than cut solder joints, if possible. An y suggestions for a connector for fine wires like that appreciated. >> >> >> >> Tom Barter >> >> >> Virus-free. www.avast.com ________________________________________________________________________________
Date: Jun 11, 2021
The technique is detailed on the Aeroelectric Connection site; I think Bob has a 'comic book' detailing it. But the technique is pretty much everywhere in the wild now. Charlie On 6/11/2021 7:28 PM, Matthew S. Whiting wrote: > I remember seeing this approach somewhere also, I want to say from > Stein Bruch at Steinair. He simply used good quality pins and sockets > and then mated them and individually heat shrunk them as you describe. > I think he may have put a larger heat shrink sleeve over the entire > bundle for an extra payer of protection and neatness. It looked like > a neat and tidy solution. Certainly not as quick to disconnect as an > actual connector, but then how often do you remove the elevator or > tail of your airplane? > > I am considering this approach, but may also just use a 0.062 pitch > mini molex as they are fairly robust and small, but not weatherproof. > A 5 pin Weatherpack or Metripack is weatherproof, but much bulkier. > Matt > > Sent from my iPad > >> On Jun 11, 2021, at 6:41 PM, Charlie England >> wrote: >> >> >> Machined subD pins should work fine; if needed strip twice as much >> and double the wire before inserting in the pin. If you want them >> 'orderly', use a 9 pin housing; otherwise just use heat shrink over >> each mated pair. >> >> Wish I could claim the idea.. ;-) >> >> Charlie >> >> >> Virus-free. www.avast.com >> >> >> >> >> On Fri, Jun 11, 2021 at 5:25 PM Tom Barter >> > > wrote: >> >> Greetings, >> >> Im in the process of installing an MAC/Ray Allen trim actuator, >> and am wondering what the best way is to connect the five 26 >> gauge leads coming out of the actuator to the corresponding 26 >> gauge five wire control cable that will be routed up to the >> cockpit. The company used to offer a small, round pin connector >> for that purpose, but not any more. Would like to be able to >> disconnect the actuator rather than cut solder joints, if >> possible. Any suggestions for a connector for fine wires like >> that appreciated. >> >> Tom Barter >> >> >> >> Virus-free. www.avast.com >> >> >> >> <#m_1956570227212391193_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> >> -- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jun 11, 2021
For those tiny wires I like to use crimp-type D-sub pins and sockets. Stagger the joints and heat-shrink each one, then heat-shrink all five. They don't need to be in a housing. It makes a fairly small and manageable bulge. I think Bob has a write-up on this technique. --Dave On Fri, Jun 11, 2021 at 3:25 PM Tom Barter wrote: > Greetings, > > > I=99m in the process of installing an MAC/Ray Allen trim actuator, and am > wondering what the best way is to connect the five 26 gauge leads coming > out of the actuator to the corresponding 26 gauge five wire control cable > that will be routed up to the cockpit. The company used to offer a small , > round pin connector for that purpose, but not any more. Would like to be > able to disconnect the actuator rather than cut solder joints, if > possible. Any suggestions for a connector for fine wires like that > appreciated. > > > Tom Barter > > > Virus-free . > www.avast.com > > <#m_-5396615780775197602_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> > ________________________________________________________________________________
Date: Jun 12, 2021
Transition away from 26 gauge as soon as possible and use a 9 pin D-sub as a connector Solder the 26g wires from the servo and then crimp 22g for the rest of the run. Peter From: owner-aeroelectric-list-server(at)matronics.com On Behalf Of Tom Barter Sent: 11 June 2021 23:22 Subject: AeroElectric-List: MAC/Ray Allen trim actuator connections Greetings, I'm in the process of installing an MAC/Ray Allen trim actuator, and am wondering what the best way is to connect the five 26 gauge leads coming out of the actuator to the corresponding 26 gauge five wire control cable that will be routed up to the cockpit. The company used to offer a small, round pin connector for that purpose, but not any more. Would like to be able to disconnect the actuator rather than cut solder joints, if possible. Any suggestions for a connector for fine wires like that appreciated. Tom Barter Virus-free. www.avast.com ________________________________________________________________________________
Date: Jun 12, 2021
At 11:04 PM 6/11/2021, you wrote: >For those tiny wires I like to use crimp-type >D-sub pins and sockets.=C2 Stagger the joints and >heat-shrink each one, then heat-shrink all >five.=C2 They don't need to be in a housing. It >makes a fairly=C2 small and >manageable=C2 bulge.=C2 I think Bob has a write-up on this technique. The last frame of this comic-book describes this technique: https://tinyurl.com/c5v2xvm . . . and yes, those 26AWG leads are of questionable design integrity. I've spoken with Ray-Allen folks at OSH about this numerous times 20+ years ago only to be rebuffed. So be it. It's their product. But anything less than 22AWG wire in the airframe bundles only increases fabrication labor and risk, it's not good practice in the GA industry. Raytheon-Beech DID use quite a bit of 24AWG wire in Model 390 airframe bundles. Assembly line folks hated the stuff but it DID save some weight in a very complex airplane (Premier). For our purposes any benefits secured by the use of tiny wires are washed out by degradation of robustness. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jun 12, 2021
Subject: "Contactor Questions" now CONTACTOR AUTOPSY
So there I am rummaging thru 30 years worth of things I kept in case I need them...hhhhmmmm So a contactor ends up in my grubby paws, and I decide to strip it, 'cause that's what BN would do! lol It does not look great at first glance ( easily opened BTW by drilling out the tiniest of rivets; something I suspect you will not be able to do with a recently manufactured device). [image: 1.PNG] The upper part of the housing is surprisingly clean, and the pic makes the contacts look worse than they are. [image: 3.PNG] Wear patterns on the contacts are clearly visible, but what I noticed is that with the factory assembly process, the contacts are slightly off the horizontal, so the plane of contact is not parallel with the contact disc....accidental? I think not..when you tighten the outer nut the contact turns until it hits the coil housing, unless you wedge something in there to prevent turning. [image: 4.PNG] The contact disc is remarkably evenly worn on the other side (contact side), as if the whole thing rotates in service..whoda thunk!! It appears to be a starter contactor based on the 3 ohm coil. This is the cleaned up contact disc, cleaned with a nylon brush and solvent . [image: image.png] and I rotated the contacts [image: image.png] Being the miserly type, I might just be forced to press it into service if it tests OK. Best Regards, Bob Verwey 082 331 2727 On Mon, 24 May 2021 at 19:02, Bob Verwey wrote: > Thanks for the responses to my query....I now have the right solution. > Any recommendations as to how to tie this receptacle into the schematic? > > [image: image.png] > > More specifically the polarity relay that is indicated. > > Best Regards, > Bob Verwey > 082 331 2727 > > > On Sun, 23 May 2021 at 19:20, Robert L. Nuckolls, III < > nuckolls.bob(at)aeroelectric.com> wrote: > >> At 11:57 PM 5/19/2021, you wrote: >> >> This is kinda related to contactors... >> >> On the BD4 that I am rebuilding, the battery is behind the baggage >> compartment, with a really fat wire running up to the firewall.=C3=82 >> >> IO 470 engine so lots of amps required for start. >> >> Is there a recommended contactor placement/battery disconnect=C3=82 prot ocol >> out there? >> I'm thinking safety in the event of an incident which might short out th e >> fat wire to the fuselage. >> >> >> Battery contactor located as close as practical >> to battery; starter contactor as close as practical >> to starter. FAT wire connects battery contactor >> to starter contactor and main bus feeder. >> >> >> >> Bob . . . >> >> Un impeachable logic: George Carlin asked, "If black boxes >> survive crashes, why don't they make the whole airplane >> out of that stuff?" >> > ________________________________________________________________________________
Subject: Re: Garmin GTR 200 Help Needed
Date: Jun 12, 2021
Update-I used the headset and mike switch from the passenger side and all was normal. However, I didn't not swap headsets and will try that next. Both headsets are the same make and model, non-noise reducing style. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502352#502352 ________________________________________________________________________________
Date: Jun 13, 2021
We=99ve been using that method for a long time, and in fact made a qu ick video of it (full credit to Bob Nuckolls)! https://www.youtube.com/watch?v=f8DCvBV2V4M *From:* owner-aeroelectric-list-server(at)matronics.com < owner-aeroelectric-list-server(at)matronics.com> *On Behalf Of *David Saylor *Sent:* Friday, June 11, 2021 11:05 PM *To:* aeroelectric-list *Subject:* Re: AeroElectric-List: MAC/Ray Allen trim actuator connections For those tiny wires I like to use crimp-type D-sub pins and sockets. Stagger the joints and heat-shrink each one, then heat-shrink all five. They don't need to be in a housing. It makes a fairly small and manageable bulge. I think Bob has a write-up on this technique. --Dave On Fri, Jun 11, 2021 at 3:25 PM Tom Barter wrote: Greetings, I=99m in the process of installing an MAC/Ray Allen trim actuator, an d am wondering what the best way is to connect the five 26 gauge leads coming out of the actuator to the corresponding 26 gauge five wire control cable that will be routed up to the cockpit. The company used to offer a small, round pin connector for that purpose, but not any more. Would like to be able to disconnect the actuator rather than cut solder joints, if possible. Any suggestions for a connector for fine wires like that appreciated. Tom Barter Virus-free. www.avast.com ________________________________________________________________________________
Subject: Re: Locking 3P switch?
Date: Jun 13, 2021
Hi David, here is a 3 way, lockable, double pole switch from APEM. I'm selling these, feel free to send me a PM.. https://www.ebay.com/itm/164244841780 -------- Igor RV10 in progress Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502360#502360 ________________________________________________________________________________
Date: Jun 14, 2021
Subject: Re: "Contactor Questions" now CONTACTOR AUTOPSY
At 11:19 AM 6/12/2021, you wrote: >So there I am rummaging=C2 thru 30 years worth of >things I kept in case I need them...hhhhmmmm >So a contactor ends up in my grubby paws, and I >decide to strip it, 'cause that's what BN would do! lol Good work sir! Thank you for sharing. >Wear patterns on the contacts are clearly >visible, but what I noticed is that with the >factory assembly process, the contacts are >slightly off the horizontal, so the plane of >contact is not parallel=C2 with the contact >disc....accidental? I think not..when you >tighten the outer nut the contact turns until it >hits the coil housing, unless you wedge something in there to prevent turning. This is a fundamental weakness in contactors with 'double-nut' fat terminals as opposed to those captive to molded, non-metalic housings. It's a really good idea to put a wrench on the inside nut and apply opposing torque while tightening the outside nut. I've encountered several contactor failures where the fat terminals were twisted out of alignment during installation. This is not necessarily an automatic precursor to failure . . . but it sure elevates risk. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jun 14, 2021
Re "N87BP_Engine_Bus_Detail.pdf" of 11 June 2021 I'm not seeing a failure mode that keeps the engine running if the SDS CPI-2 backup power wires are connected to the engine bus. There IS an SPOF in the form of the single connection to the engine bus. The Bussmann 15600 fuse block can be modified to add a 2nd stud... ref attached three photos. The diode feed from the main bus goes to one stud and the relay feed from the battery goes to the other stud. -------- John Bright, RV-6A, at FWF, O-360 Z-101 single batt dual alt SDS EM-5-F. john_s_bright(at)yahoo.com, Newport News, Va https://docs.google.com/document/d/1YOtPiA3AdUsQEYR4nodBESNAo21rxdnx4pFs7VxXfuI/edit?usp=sharing Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502366#502366 Attachments: http://forums.matronics.com//files/bussmann_15600_fuse_block_add_a_2nd_stud_photo_1_of_3_956.jpg http://forums.matronics.com//files/bussmann_15600_fuse_block_add_a_2nd_stud_photo_2_of_3_949.jpg http://forums.matronics.com//files/bussmann_15600_fuse_block_add_a_2nd_stud_photo_3_of_3_148.jpg ________________________________________________________________________________
Date: Jun 14, 2021
I use the method that Stein's video suggests. I do change one thing. I use clear heat shrink tubing so it is possible to see where to cut the tube to separate the pin/sockett connection. On Sun, Jun 13, 2021 at 9:35 AM SteinB wrote: > We=99ve been using that method for a long time, and in fact made a quick > video of it (full credit to Bob Nuckolls)! > > > https://www.youtube.com/watch?v=f8DCvBV2V4M > > > *From:* owner-aeroelectric-list-server(at)matronics.com < > owner-aeroelectric-list-server(at)matronics.com> *On Behalf Of *David Saylor > *Sent:* Friday, June 11, 2021 11:05 PM > *To:* aeroelectric-list > *Subject:* Re: AeroElectric-List: MAC/Ray Allen trim actuator connections > > > For those tiny wires I like to use crimp-type D-sub pins and sockets. > Stagger the joints and heat-shrink each one, then heat-shrink all five. > They don't need to be in a housing. It makes a fairly small and manageabl e > bulge. I think Bob has a write-up on this technique. > > > --Dave > > > On Fri, Jun 11, 2021 at 3:25 PM Tom Barter > wrote: > > Greetings, > > > I=99m in the process of installing an MAC/Ray Allen trim actuator, and am > wondering what the best way is to connect the five 26 gauge leads coming > out of the actuator to the corresponding 26 gauge five wire control cable > that will be routed up to the cockpit. The company used to offer a small , > round pin connector for that purpose, but not any more. Would like to be > able to disconnect the actuator rather than cut solder joints, if > possible. Any suggestions for a connector for fine wires like that > appreciated. > > > Tom Barter > > > > > Virus-free. www.avast.com > > > ________________________________________________________________________________
Date: Jun 15, 2021
I use clear heat shrink to alliw easy cutting at the joint between the pin and socket On Sat, Jun 12, 2021, 20:00 Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 11:04 PM 6/11/2021, you wrote: > > For those tiny wires I like to use crimp-type D-sub pins and sockets.=C3 =82 > Stagger the joints and heat-shrink each one, then heat-shrink all five. =C3=82 > They don't need to be in a housing. It makes a fairly=C3=82 small and > manageable=C3=82 bulge.=C3=82 I think Bob has a write-up on this techni que. > > > The last frame of this comic-book describes > this technique: > > https://tinyurl.com/c5v2xvm > > . . . and yes, those 26AWG leads are of questionable > design integrity. I've spoken with Ray-Allen folks > at OSH about this numerous times 20+ years ago > only to be rebuffed. So be it. It's their product. > But anything less than 22AWG wire in the airframe > bundles only increases fabrication labor and risk, > it's not good practice in the GA industry. > > Raytheon-Beech DID use quite a bit of 24AWG wire > in Model 390 airframe bundles. Assembly line folks > hated the stuff but it DID save some weight in a very > complex airplane (Premier). For our purposes > any benefits secured by the use of tiny wires > are washed out by degradation of robustness. > > Bob . . . > > Un impeachable logic: George Carlin asked, "If black boxes > survive crashes, why don't they make the whole airplane > out of that stuff?" > ________________________________________________________________________________
Subject: Dual alternators
Date: Jun 17, 2021
I have a somewhat academic question regarding design and operation of a dual alternator system. Ive imagined, but never tested, that running two alternators that are feeding a single battery bus would be dominated by current from one of the alternators. My reasoning is that regardless of how closely the charge systems are matched, small variations would result in a slightly higher output voltage on one of them. This would then result in an even lower output from the lower voltage output charge system, which would reduce its current contribution. If the above assumptions are accurate, how would it change if the two alternators shared a single regulator? (Im not advocating this arrangement) Would the result change If the two alternators were PMA units, mechanically tied together and producing a sin wave in phase. WRT the dual PMA arrangement, Bob had advocated a center tap to ground with a tie point between the two PMA stators. This arrangement (I believe) separates the current load exactly in half between the two sides. One final question Ive wondered about. How do twin engine planes with two alternators manage (my assumed) tendency for two alternators in parallel quickly relying on the larger voltage out unit for most of the current? Dan Theis. -------- Scratch building Sonex #1362 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502409#502409 ________________________________________________________________________________
Date: Jun 17, 2021
Subject: Is there a switch configuration that will do this?
I'd like to have a single switch control both my taxi lights & landing lights. Sounds simple enough, right? Here's the catch. I want to control the taxi lights directly from this switch by making a connection to +12v. The landing lights, however, will be controlled through the Garmin GAD 27 electrical controller "magic box" so that it can provide airspeed-based wig-wag. The GAD 27 light control switch input is active-low. How I'd like it to work: 1. Switch down - both lights off 2. Middle position - +12v supplied to the taxi lights. 3. Top position - taxi lights no longer connected to +12v, GAD 27 light switch input connected to ground. I know I can do this with a relay, but I'd rather avoid adding an additional failure point. It's not the end of the world if I use separate switches for these functions, but I'd prefer they are combined on one switch. Thanks, David --- David Carter david(at)carter.net ________________________________________________________________________________
Date: Jun 17, 2021
Subject: Re: Dual alternators
I've imagined, but never tested, that running two alternators that are feeding a single battery bus would be dominated by current from one of the alternators. My reasoning is that regardless of how closely the charge systems are matched, small variations would result in a slightly higher output voltage on one of them. This would then result in an even lower output from the lower voltage output charge system, which would reduce its current contribution. Yes, until system loads exceeded the capacity of the alternator with the higher set-point. The bus voltage sags allowing the lower set-point alternator to wake up and begin to support the load. This is what happens with a B&C standby alternator system. #2 alternator is set to some lower-than-nominal regulation voltage. Should the #1 alternator quit, voltage sags and #2 wakes up. Similarly, should the #1 alternator suffer an open winding with subsequent loss of capacity, the voltage might sag and again, #2 steps in to take up the slack. In both cases, #1 alternator is running maxed out whether by reason of total system loads =or= loss of capacity. If the above assumptions are accurate, how would it change if the two alternators shared a single regulator? (I=99m not advocating this arrangement) Cessna 336/337 Models do just that. Beech Barons too. There is a switch for bringing a second regulator into service should the first one fail. This philosophy does produce a system whereby the two alternator ammeters track each other fairly closely . . . in my not so humble opinion, a totally misguided practice to keep pilot's 'happy'. There is no practical NEED for balancing the loads on two alternators assuming (1) either alternator can carry 100% of ships loads with (2) demonstrated adequacy of cooling. This shade-tree 'paralleling' scheme creates single points of failure for both alternators. How this got past in-house DERs is a mystery to me . . . how the FAA bought it is a . . . well . . . I won't go there. Would the result change If the two alternators were PMA units, mechanically tied together and producing a sin wave 'in-phase.' The engines cannot be synchronized that tightly. One final question I've wondered about. How do twin engine planes with two alternators manage (my assumed) tendency for two alternators in parallel quickly relying on the larger voltage out unit for most of the current? They parallel fields on a single regulator. I designed a true paralleling regulator proposal for Cessna on the 303 Crusader program thinking that there was a HUGH after market opportunity to put the system on new and fielded Barons and Skymasters. I don't know how the Cessna West was wiring their airplanes. In any case, Cessna East didn't bite on the idea so I was never funded to pursue the design. Twin Generators on earlier Cessna and Beech models WERE fitted with paralleling regulators which DID NOT compromise independence of the two system. Turbine twins have always enjoyed that design philosophy. Here is a sketch on a generator paralleling system on a Beech Model 18 I think . . . but typical of all dual generator twins of the era. http://aeroelectric.com/Pictures/Schematics/Parallel_Aircraft_Generators.jpg This design uses voltage drop in the generator's compensation windings as a current shunt. Any difference in those two voltages biases the voltage sense windings to depress excitation to the generator with the higher load while elevating excitation on the lighter loaded machine . . . pretty slick. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jun 17, 2021
Subject: Re: Is there a switch configuration that will do
this? At 11:28 AM 6/17/2021, you wrote: >I'd like to have a single switch control both my >taxi lights & landing lights. Sounds simple >enough, right? Here's the catch. I want to >control the taxi lights directly from this >switch by making a connection to=C2 +12v. The >landing lights, however, will be controlled >through the Garmin GAD 27 electrical=C2 controller >"magic box" so that it can provide >airspeed-based wig-wag. The GAD 27 light control switch input is active-low.=C2 > >How I'd like it to work: >1. Switch down - both lights off >2. Middle position -=C2 +12v supplied to the taxi lights.=C2 >3. Top position - taxi lights no longer >connected to=C2 +12v, GAD 27 light switch input connected to ground.=C2 > >I know=C2 I can do this with a relay, but I'd >rather=C2 avoid adding=C2 an additional=C2 failure >point. It's not the end of the world if I use >separate=C2 switches for these functions, but I'd >prefer they are combined on one switch.=C2 There MIGHT be a simple way to do this but it depends on the 'pull down' current of the electrical controller. Is there a spec for that device that speaks to parameters of this input? Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jun 17, 2021
Subject: Re: Is there a switch configuration that will do this?
>> There MIGHT be a simple way to do this but it >> depends on the 'pull down' current of the electrical >> controller. Is there a spec for that device that speaks >> to parameters of this input? Here's what I was able to find in the installation manual: (top of page 26-8, or page 342 in Acrobat Reader) https://static.garmin.com/pumac/190-01115-01_an.pdf These active-low discrete inputs conform to the following specification: Low: Vin < 3.5 VDC, or Rin < 375 =CE=A9 (input active) High: Vin > 8 VDC, or Rin> 100k =CE=A9 (input inactive) --- David Carter david(at)carter.net On Thu, Jun 17, 2021 at 5:37 PM Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 11:28 AM 6/17/2021, you wrote: > > I'd like to have a single switch control both my taxi lights & landing > lights. Sounds simple enough, right? Here's the catch. I want to control > the taxi lights directly from this switch by making a connection to=C3=82 +12v. > The landing lights, however, will be controlled through the Garmin GAD 27 > electrical=C3=82 controller "magic box" so that it can provide airspeed-b ased > wig-wag. The GAD 27 light control switch input is active-low.=C3=82 > > How I'd like it to work: > 1. Switch down - both lights off > 2. Middle position -=C3=82 +12v supplied to the taxi lights.=C3=82 > 3. Top position - taxi lights no longer connected to=C3=82 +12v, GAD 27 l ight > switch input connected to ground.=C3=82 > > I know=C3=82 I can do this with a relay, but I'd rather=C3=82 avoid addin g=C3=82 an > additional=C3=82 failure point. It's not the end of the world if I use se parate=C3=82 > switches for these functions, but I'd prefer they are combined on one > switch.=C3=82 > > > There MIGHT be a simple way to do this but it > depends on the 'pull down' current of the electrical > controller. Is there a spec for that device that speaks > to parameters of this input? > > > Bob . . . > > Un impeachable logic: George Carlin asked, "If black boxes > survive crashes, why don't they make the whole airplane > out of that stuff?" > ________________________________________________________________________________
Date: Jun 18, 2021
Bob, in the Beech paralleling schematic below, what is the symbol in the reg comprising the 6 parallel lines with the arrow through it, in series with the shunt field? Brian Phillips On 18/06/2021 3:21 am, Robert L. Nuckolls, III wrote: > I've imagined, but never tested, that running two alternators that > are feeding a single battery bus would be dominated by current from > one of the alternators. > > My reasoning is that regardless of how closely the charge systems > are matched, small variations would result in a slightly higher > output voltage on one of them. This would then result in an even > lower output from the lower voltage output charge system, > which would reduce its current contribution. > > Yes, until system loads exceeded the capacity > of the alternator with the higher set-point. The > bus voltage sags allowing the lower set-point > alternator to wake up and begin to support the > load. > > This is what happens with a B&C standby alternator > system. #2 alternator is set to some lower-than-nominal > regulation voltage. Should the #1 alternator quit, > voltage sags and #2 wakes up. Similarly, should the > #1 alternator suffer an open winding with subsequent > loss of capacity, the voltage might sag and again, > #2 steps in to take up the slack. > > In both cases, #1 alternator is running maxed out > whether by reason of total system loads =or= loss > of capacity. > > If the above assumptions are accurate, how would it change if > the two alternators shared a single regulator? (Im not advocating > this arrangement) > > Cessna 336/337 Models do just that. Beech Barons too. > There is a switch for bringing a second regulator into > service should the first one fail. This philosophy > does produce a system whereby the two alternator > ammeters track each other fairly closely . . . in > my not so humble opinion, a totally misguided practice > to keep pilot's 'happy'. > > There is no practical NEED for balancing the > loads on two alternators assuming (1) either > alternator can carry 100% of ships loads > with (2) demonstrated adequacy of cooling. > > This shade-tree 'paralleling' scheme creates > single points of failure for both alternators. > How this got past in-house DERs is a mystery > to me . . . how the FAA bought it is a . . . > well . . . I won't go there. > > Would the result change If the two alternators were PMA units, > mechanically tied together and producing a sin wave 'in-phase.' > > The engines cannot be synchronized that tightly. > > One final question I've wondered about. How do twin engine planes > with two alternators manage (my assumed) tendency for two alternators > in parallel quickly relying on the larger voltage out unit for most > of the current? > > They parallel fields on a single regulator. > > I designed a true paralleling regulator proposal for Cessna on > the 303 Crusader program thinking that there was a HUGH after market > opportunity to put the system on new and fielded Barons and > Skymasters. > I don't know how the Cessna West was wiring their airplanes. > > In any case, Cessna East didn't bite on the idea so I > was never funded to pursue the design. Twin Generators on > earlier Cessna and Beech models WERE fitted with paralleling > regulators which DID NOT compromise independence of the > two system. Turbine twins have always enjoyed that design > philosophy. > > Here is a sketch on a generator paralleling system > on a Beech Model 18 I think . . . but typical of > all dual generator twins of the era. > > http://aeroelectric.com/Pictures/Schematics/Parallel_Aircraft_Generators.jpg > <http://aeroelectric.com/Pictures/Schematics/Parallel_Aircraft_Generators.jpg> > > > This design uses voltage drop in the generator's > compensation windings as a current shunt. Any difference > in those two voltages biases the voltage sense windings > to depress excitation to the generator with the higher > load while elevating excitation on the lighter loaded > machine . . . pretty slick. > > Bob . . . > > Un impeachable logic: George Carlin asked, "If black boxes > survive crashes, why don't they make the whole airplane > out of that stuff?" > ________________________________________________________________________________
Date: Jun 17, 2021
At 05:00 PM 6/17/2021, you wrote: >Bob, in the Beech paralleling schematic below, what is the symbol in >the reg comprising the 6 parallel lines with the arrow through it, >in series with the shunt field? > >Brian Phillips That is a carbon pile, variable resistor. Simply a stack of carbon disks whose series resistance is a function of compression force. A very common, high current analog for a rheostat. Here's a carbon pile regulator in the flesh . . . http://aeroelectric.com/Pictures/Regulators/Carbon_Pile_1a.jpg No transistors, no modern plastics, no software. One of many fine examples of engineering dexterity on the part of those who did not have our box of tinker-toys to work with. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jun 18, 2021
Also helped a generation of pilots learn the habit of checking voltmeters i n their pre-liftoff gauges check. You only need to smell batteries boiling as you climb into a 200=99 overcast over one time to learn. On Th ob(at)aeroelectric.com> wrote: At 05:00 PM 6/17/2021, you wrote: Bob, in the Beech parallelingschematic below, what is the symbol in the reg comprising the 6 parallellines with the arrow through it, in series with t he shunt field? Brian Phillips =C2- That is a carbon pile, variable resistor. Simply a stack =C2- of carbon disks whose series resistance is a function =C2- of compression force. A very common, high current analog =C2- for a rheostat. Here's a carbon pile regulator in the =C2- flesh . . . http://aeroelectric.com/Pictures/Regulators/Carbon_Pile_1a.jpg =C2- No transistors, no modern plastics, no software. =C2- One of many fine examples of engineering dexterity =C2- on the part of those who did not have our box =C2- of tinker-toys to work with. =C2- Bob . . . =C2- Un impeachable logic: George Carlin asked, "If blackboxes =C2- survive crashes, why don't they make the whole airplane =C2- out of that stuff?" ________________________________________________________________________________
Date: Jun 18, 2021
On 18/06/2021 11:33 am, Robert L. Nuckolls, III wrote: > At 05:00 PM 6/17/2021, you wrote: >> Bob, in the Beech paralleling schematic below, what is the symbol in >> the reg comprising the 6 parallel lines with the arrow through it, in >> series with the shunt field? >> >> Brian Phillips > > That is a carbon pile, variable resistor. Simply a stack > of carbon disks whose series resistance is a function > of compression force. A very common, high current analog > for a rheostat. Here's a carbon pile regulator in the > flesh . . . > > http://aeroelectric.com/Pictures/Regulators/Carbon_Pile_1a.jpg > <http://aeroelectric.com/Pictures/Regulators/Carbon_Pile_1a.jpg> > > No transistors, no modern plastics, no software. > One of many fine examples of engineering dexterity > on the part of those who did not have our box > of tinker-toys to work with. > > > Bob . . . > > Un impeachable logic: George Carlin asked, "If black boxes > survive crashes, why don't they make the whole airplane > out of that stuff?" > Thanks Bob, now that is amazing engineering, zero PN junctions, must be near bulletproof. Cheers, Brian. ________________________________________________________________________________
Date: Jun 18, 2021
You need a DP3T ON-ON-ON switch. Mouser and Digikey and others sell them. https://www.mouser.com/Electromechanical/Switches/Toggle-Switches/_/N-5g2jZ1yzvvqx?P=1z0z2o3Z1z0z28f https://www.digikey.com/en/products/filter/toggle-switches/201?s=N4IgjCBcpgzADFUBjKAzAhgGwM4FMAaEAeygG0RYAWeWAdgE4QBdIgBwBcoQBlDgJwCWAOwDmIAL5EATLACsSEKkiZchEuUoAOafABseluy6ReAkeKkgAtNMXKBAV3WlIFBcwlW7bkABEABVgAFRYJIA -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502430#502430 ________________________________________________________________________________
Date: Jun 18, 2021
do this? >> You need a DP3T ON-ON-ON switch. Joe - thank you, it appears that would work electrically. It took me a few minutes to decipher the actions of this switch, but I got there. However, I have not yet found one in a form factor that would match the rest of the standard toggles in my panel. I may have to just live with two switches. It's not the end of the world, but it's not as elegant. Thanks! --- David Carter david(at)carter.net ________________________________________________________________________________
Date: Jun 18, 2021
In Diamond twins one regulator is the master and has the job of balancing the alternators. I=99m not actually sure how it achieves that, but works well most of the time. The regulators are provided by the engine mfrs (Continental or Austro). The G1000 instrumentation systems use hall effect sensors to detect the output of each alternator. The regulators use a different sensor to do their job. Can result in the G1000 saying the loads are unbalanced, which makes pilots unhappy =93 although voltage is always good. I have spent a lot of time troubleshooting, reloading G1000 software and other stuff to cure what seems to be an imaginary problem. Peter From: owner-aeroelectric-list-server(at)matronics.com On Behalf Of Robert L. Nuckolls, III Sent: 17 June 2021 18:21 Subject: Re: AeroElectric-List: Dual alternators I've imagined, but never tested, that running two alternators that are feeding a single battery bus would be dominated by current from one of the alternators. My reasoning is that regardless of how closely the charge systems are matched, small variations would result in a slightly higher output voltage on one of them. This would then result in an even lower output from the lower voltage output charge system, which would reduce its current contribution. Yes, until system loads exceeded the capacity of the alternator with the higher set-point. The bus voltage sags allowing the lower set-point alternator to wake up and begin to support the load. This is what happens with a B&C standby alternator system. #2 alternator is set to some lower-than-nominal regulation voltage. Should the #1 alternator quit, voltage sags and #2 wakes up. Similarly, should the #1 alternator suffer an open winding with subsequent loss of capacity, the voltage might sag and again, #2 steps in to take up the slack. In both cases, #1 alternator is running maxed out whether by reason of total system loads =or= loss of capacity. If the above assumptions are accurate, how would it change if the two alternators shared a single regulator? (I=C3=A2=82=AC=84=A2m not advocating this arrangement) Cessna 336/337 Models do just that. Beech Barons too. There is a switch for bringing a second regulator into service should the first one fail. This philosophy does produce a system whereby the two alternator ammeters track each other fairly closely . . . in my not so humble opinion, a totally misguided practice to keep pilot's 'happy'. There is no practical NEED for balancing the loads on two alternators assuming (1) either alternator can carry 100% of ships loads with (2) demonstrated adequacy of cooling. This shade-tree 'paralleling' scheme creates single points of failure for both alternators. How this got past in-house DERs is a mystery to me . . . how the FAA bought it is a . . . well . . . I won't go there. Would the result change If the two alternators were PMA units, mechanically tied together and producing a sin wave 'in-phase.' The engines cannot be synchronized that tightly. One final question I've wondered about. How do twin engine planes with two alternators manage (my assumed) tendency for two alternators in parallel quickly relying on the larger voltage out unit for most of the current? They parallel fields on a single regulator. I designed a true paralleling regulator proposal for Cessna on the 303 Crusader program thinking that there was a HUGH after market opportunity to put the system on new and fielded Barons and Skymasters. I don't know how the Cessna West was wiring their airplanes. In any case, Cessna East didn't bite on the idea so I was never funded to pursue the design. Twin Generators on earlier Cessna and Beech models WERE fitted with paralleling regulators which DID NOT compromise independence of the two system. Turbine twins have always enjoyed that design philosophy. Here is a sketch on a generator paralleling system on a Beech Model 18 I think . . . but typical of all dual generator twins of the era. http://aeroelectric.com/Pictures/Schematics/Parallel_Aircraft_Generators. jpg This design uses voltage drop in the generator's compensation windings as a current shunt. Any difference in those two voltages biases the voltage sense windings to depress excitation to the generator with the higher load while elevating excitation on the lighter loaded machine . . . pretty slick. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jun 18, 2021
do this? >However, I have not yet found one in a form factor that would match >the rest of the standard toggles in my panel. What switches are you using? Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jun 18, 2021
> >Thanks Bob, now that is amazing engineering, zero PN junctions, must >be near bulletproof. >Cheers, >Brian. Pretty close. If memory serves, some versions of these regulators came with field remover/refurbish/ replace manuals. They're stone simple in their physics of operation and very repairable as long as they were not abused. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jun 18, 2021
do this? >> What switches are you using? It appears that Stein's crew is putting these in by default unless I ask for something else. https://www.steinair.com/product/toggle-switch-spst-onoff-fast-on-terminals/ --- David Carter david(at)carter.net > ________________________________________________________________________________
Date: Jun 18, 2021
I was under the impression that the Diamond twins either had Austro (originally Thielert) diesel engines or Lycoming avgas engines. Where did Continental come in? On 6/18/2021 12:48 PM, Peter Pengilly wrote: > In Diamond twins one regulator is the master and has the job of > balancing the alternators. > > Im not actually sure how it achieves that, but works well most of the time. > > The regulators are provided by the engine mfrs (Continental or Austro). ________________________________________________________________________________
Date: Jun 18, 2021
At 02:48 PM 6/18/2021, you wrote: >In Diamond twins one regulator is the master and >has the job of balancing the alternators. > >I=99m not actually sure how it achieves that, but works well most of the time. Is there a .pdf of the alternator wiring you could share? Sounds like an interesting system I'd like to understand. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jun 18, 2021
Extremely inspired! Everything is extremely open Chandigarh Escorts Service (http://www.rashmibhargav.in/) clear illumination of issues. It contains really certainties. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502444#502444 ________________________________________________________________________________
Date: Jun 18, 2021
Incredible articles and awesome design. Your forum post entry merits the greater part of the positive input Chandigarh Escorts (http://www.chandigarhescortsgirl.com/) it"s been getting. I want to steer about this, for the explanation that it's useful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502445#502445 ________________________________________________________________________________
Date: Jun 19, 2021
The whole AMM is downloadable and is in ATA100 format. DA42 with Continental engines http://support.diamond-air.at/fileadmin/uploads/files/after_sales_support /DA42_Twin_Star/Airplane_Maintenance_Manual/Basic_Manual/70201-DA42-AMM-r 4.pdf See page 24-30-00 (pdf p 567) and on. Wiring diagrams Ch 92, p2077 & on DA42 with Austro engines http://support.diamond-air.at/fileadmin/uploads/files/after_sales_support /DA42_New_Generation/Airplane_Maintenance_Manual/Basic_Manual/70215-DA42- NG-AMM-r4.pdf See page 613 DA62 (Austro) http://support.diamond-air.at/fileadmin/uploads/files/after_sales_support /DA62/Airplane_Maintenance_Manual/Basic_Manual/70225-r1-complete.pdf pdf p 525 None of these is very specific. I will look in the engine manuals next week. From: owner-aeroelectric-list-server(at)matronics.com On Behalf Of Robert L. Nuckolls, III Sent: 18 June 2021 21:28 Subject: RE: AeroElectric-List: Dual alternators At 02:48 PM 6/18/2021, you wrote: In Diamond twins one regulator is the master and has the job of balancing the alternators. I=C3=A2=82=AC=84=A2m not actually sure how it achieves that, but works well most of the time. Is there a .pdf of the alternator wiring you could share? Sounds like an interesting system I'd like to understand. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jun 19, 2021
this? At 04:58 PM 6/17/2021, you wrote: > >> There MIGHT be a simple way to do this but it > >> =C2 depends on the 'pull down' current of the electrical > >> =C2 controller. Is there a spec for that device that speaks > >> =C2 to parameters of this input? > >Here's what I was able to find in the >installation=C2 manual: (top of page 26-8, or page 342 in Acrobat Reader) > >https://static.garmin. com/pumac/190-01115-01_an.pdf > >These active-low discrete inputs conform to the following specification: >Low: Vin < 3.5 VDC, or Rin < 375 =CE=A9 (input active) >High: Vin > 8 VDC, or Rin> 100k =CE=A9 (input inactive) Aha! Exactly what was needed. The 3.5v or 375 Ohms suggests that pull-down current at the switch point is on the order of 0.01 amps (10 milliAmps). The 375 Ohms number is handy, let's consider a 270 ohm, 2W resistor as an always-connected, pull-down value on this input. To deactivate that input we need to apply bus voltage from the landing/taxi lights management switch. The switches you cited are the Carling line of devices. A manufacturer favored by Cessna since the 60s. The full range of functions is offered by B&C at https://bandc.com The one you want is the S700-2-10 which is a progressive transfer, on-on-on function illustrated by this schematic from the switches chapter of the 'Connection. This switch with addition of two diodes and the resistor cited above can be configured to accomplish the switching functions you requested. See attached: Lower position applies disable signal to landing/wig-wag controller. Mid position applies power to taxi lights while maintaining the landing/wig-wag disable. Upper position removes power from taxi lights -AND- landing/ wig-wag disable. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jun 19, 2021
At 07:05 AM 6/19/2021, you wrote: >The whole AMM is downloadable and is in ATA100 format. > > snip >None of these is very specific. I will look in the engine manuals next week. You got that right! It's been a long time since I did an ATA100 manual. I was still at Electro-Mech so this would have been about 1980. I got 'dinged' for 'too complex', Symptom/Cause/Fix trouble shooting charts. I can see that the authors of these manuals were not at risk for similar debasement! Found a schematic for the left alternator where the regulator appears to be a paralleling regulator; data from sensors on both alternators is supplied to the regulator. Didn't find anything on how the right alternator differed. Man! That's a really 'busy' electrical system. It would be interesting to see the wiring diagrams. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jun 19, 2021
I think the right side regulator is the same box but the current sensor is driven from the LH box, will confirm on Monday. Wiring diagrams are in Ch92 at the end of the book. Peter From: owner-aeroelectric-list-server(at)matronics.com On Behalf Of Robert L. Nuckolls, III Sent: 19 June 2021 18:02 Subject: RE: AeroElectric-List: Dual alternators At 07:05 AM 6/19/2021, you wrote: The whole AMM is downloadable and is in ATA100 format. snip None of these is very specific. I will look in the engine manuals next week. You got that right! It's been a long time since I did an ATA100 manual. I was still at Electro-Mech so this would have been about 1980. I got 'dinged' for 'too complex', Symptom/Cause/Fix trouble shooting charts. I can see that the authors of these manuals were not at risk for similar debasement! Found a schematic for the left alternator where the regulator appears to be a paralleling regulator; data from sensors on both alternators is supplied to the regulator. Didn't find anything on how the right alternator differed. Man! That's a really 'busy' electrical system. It would be interesting to see the wiring diagrams. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jun 19, 2021
> > Man! That's a really 'busy' electrical system. > It would be interesting to see the wiring diagrams. Found them. It will take a bit to sift out the features of interest . . . Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jun 19, 2021
At 03:38 PM 6/19/2021, you wrote: >I think the right side regulator is the same box but the current >sensor is driven from the LH box, will confirm on Monday. > >Wiring diagrams are in Ch92 at the end of the book. Yup . . . found 'em. I think this paralleling system is of the same genre' as that I proposed to Cessna for the C303. Only one regulator is fitted with paralleling smarts. The other is a plain vanilla stand-alone device. Stand alone regulator is set for 'nominal' bus voltage, say 28.5V. Second regulator watches current from each alternator and adjusts its own output to match it's partner with the stand-alone system. The paralleling circuit steering authority is limited to about plus/minus 0.5V. Setup says adjust each system independently for nominal set-point. Then operate normally as a dual system. Both systems retain their redundancy independence with limited but adequate ability to run in lockstep with each other. I thought it would work pretty good . . . never had a chance to explore it in working hardware. Today we would enjoy the benefits of hall-effect sensors for current monitoring . . . back then I had to look at shunts with a rather energetic hat-dance to resolve alternator current signals from the bus common mode noise. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jun 20, 2021
Continental bought Thielert several yers ago Neal George On Jun 18, 2021, at 4:11 PM, Kelly McMullen wrote: I was under the impression that the Diamond twins either had Austro (originally Thielert) diesel engines or Lycoming avgas engines. Where did Continental come in? ________________________________________________________________________________
Date: Jun 20, 2021
OK, so it is just the original diesel engine, not a TCM gas engine. On 6/20/2021 4:08 AM, Neal George wrote: > > Continental bought Thielert several yers ago > > Neal George > > > On Jun 18, 2021, at 4:11 PM, Kelly McMullen wrote: > > > I was under the impression that the Diamond twins either had Austro (originally Thielert) diesel engines or Lycoming avgas engines. Where did Continental come in? > > > > > ________________________________________________________________________________
Date: Jun 20, 2021
Continental (Thielert/Technify) and Austro are different companies and make different engines, although their main engines are both based on a Mercedes 2.0 litre. Diamonds are now only available with Austro engines (except the DA50 which has 300hp Continental diesel), in the past they have been available with Continentals and with Lycomings - may still be sold in US/Canada with Lycs. Peter -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com <owner-aeroelectric-list-server(at)matronics.com> On Behalf Of Kelly McMullen Sent: 20 June 2021 16:17 Subject: Re: AeroElectric-List: Dual alternators --> OK, so it is just the original diesel engine, not a TCM gas engine. On 6/20/2021 4:08 AM, Neal George wrote: > --> > > Continental bought Thielert several yers ago > > Neal George > > > On Jun 18, 2021, at 4:11 PM, Kelly McMullen wrote: > > --> > > I was under the impression that the Diamond twins either had Austro (originally Thielert) diesel engines or Lycoming avgas engines. Where did Continental come in? > > > > > ________________________________________________________________________________
Date: Jun 21, 2021
this? > This switch with addition of two > diodes and the resistor cited above can be configured > to accomplish the switching functions you requested. > See attached: P.S. those 'loose' components present a small packaging problem. I think I'd fabricate an assembly-under-heat-shrink of the three compoents with wires coming out each end. Use 1/2" dual wall heat shrink . . . that's how I packaged a few hundred crowbar ov management modules. Your finished assembly will be about 1-1/2 inches long and 3/8" in diameter. It would tie nicely into an adjacent wire bundle. I've got all the materials in stock. I could build one up for you. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jun 21, 2021
P.S. those 'loose' components present a small packaging problem. I think I'd fabricate an assembly-under-heat-shrink of the three compoents with wires coming out each end. Use 1/2" dual wall heat shrink . . . that's how I packaged a few hundred crowbar ov management modules. Your finished assembly will be about 1-1/2 inches long and 3/8" in diameter. It would tie nicely into an adjacent wire bundle. I've got all the materials in stock. I could build one up for you. Bob - thanks for the solution design & for the packaging tip. I was also wondering how much heat the resistor would need to dissipate in this application? I'm guessing not much? --- David Carter david(at)carter.net On Mon, Jun 21, 2021 at 12:26 PM Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > This switch with addition of two > diodes and the resistor cited above can be configured > to accomplish the switching functions you requested. > See attached: > > > P.S. those 'loose' components present a small > packaging problem. I think I'd fabricate an > assembly-under-heat-shrink of the three compoents > with wires coming out each end. > > Use 1/2" dual wall heat shrink . . . that's > how I packaged a few hundred crowbar ov management > modules. > > Your finished assembly will be about 1-1/2 inches > long and 3/8" in diameter. It would tie nicely > into an adjacent wire bundle. I've got all the > materials in stock. I could build one up for you. > > Bob . . . > > Un impeachable logic: George Carlin asked, "If black boxes > survive crashes, why don't they make the whole airplane > out of that stuff?" > ________________________________________________________________________________
Date: Jun 21, 2021
Will this work? -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502520#502520 Attachments: http://forums.matronics.com//files/taxi_lndg_lt_sw_107.jpg ________________________________________________________________________________
Date: Jun 21, 2021
this? >Bob - thanks for the solution design & for the >packaging tip. I was also wondering how much >heat the resistor would need to dissipate in >this application? I'm guessing not much?=C2 W = E^2/R = 14^2/270 = 0.725 Watts For the 'shrink potted' assembly I would probably use two 130 Ohm resistors in series to spread out the heat generation at 0.360 Watts each. It will warm up noticeably but only slightly so. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jun 21, 2021
do this? At 06:59 PM 6/21/2021, you wrote: > >Will this work? > >-------- >Joe Gores > >http://forums.matronics.com//files/taxi_lndg_lt_sw_107.jpg > Yes . . . that's the single pole switch version of that which I illustrated on 6/19 using a 2-pole, 3-position, on-on-on switch. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jun 22, 2021
Subject: Archer style wingtip antenna fabrication questions
I have an Archer wingtip comm antenna I intend to install in one wingtip (can always add a 1/4 wave whip if needed), and I'm thinking about building the nav version detailed in Bob's 'Antennas & Feedlines chapter for the other wingtip (figure 13-12 in my document). How critical is the material for the .032" x .8" x 3.25" bakelite insulator that forms what I'm guessing is a matching capacitor? Does the bakelite participate in any way in operation, or is it simply a way to get a fixed air gap? Bakelite in that 'thinness' doesn't seem to be available without paying more for shipping than the 3-postage-stamp size needed would cost. What about substituting something like the thin HDPE cutting board stock, available at discount stores? Two layers would be about .034" thick. Thanks, Charlie ________________________________________________________________________________
Subject: Re: Archer style wingtip antenna fabrication questions
Date: Jun 22, 2021
Charlie, It looks like the critical dimension is the 0.31 air gap. My concern is that a softer plastic will flow over time resulting in the screws loosening up. It looks like the angle part of the antenna is fastened to an aluminum wing rib. The directions are not specific. A Bakelite sheet on eBay costs $5 including shipping. Item #: 281793575532 from China. You might have to wait up to a month for shipping. It is 1mm thick which converts to 0.039". I would not sand it down. The Bakelite could possibly contain asbestos. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502533#502533 ________________________________________________________________________________
Date: Jun 22, 2021
On 6/22/2021 3:14 PM, user9253 wrote: > > Charlie, It looks like the critical dimension is the 0.31 air gap. My concern is that a softer plastic will flow over time resulting in the screws loosening up. > It looks like the angle part of the antenna is fastened to an aluminum wing rib. The directions are not specific. A Bakelite sheet on eBay costs $5 including shipping. Item #: 281793575532 from China. You might have to wait up to a month for shipping. It is 1mm thick which converts to 0.039". I would not sand it down. The Bakelite could possibly contain asbestos. > > -------- > Joe Gores Your ebay-Foo is obviously better than mine; all the hits I got were for much thicker stuff. Thanks for the link! -- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jun 22, 2021
At 12:03 PM 6/22/2021, you wrote: >I have an Archer wingtip comm=C2 antenna I intend >to install in one wingtip (can always add a 1/4 >wave whip if needed), and I'm thinking about >building the nav version detailed in Bob's >'Antennas & Feedlines chapter for the other >wingtip (figure 13-12 in my document). > >How critical is the material for the .032" x .8" >x 3.25" bakelite insulator that forms what I'm >guessing is a matching capacitor? Does the >bakelite participate in any way in operation, or >is it simply a way to get a fixed air gap? > >Bakelite in that 'thinness' doesn't seem to be >available without paying more for shipping than >the 3-postage-stamp size needed would cost. What >about=C2 substituting something like the thin HDPE >cutting board stock, available at discount >stores? Two layers would be about .034" thick.=C2 It IS critical . . . yes it forms the dielectric for a capacitor used to series resonate the feeder strut. Bob must have conducted experiments to optimize the characteristics of that capacitor with respect to the matching strut for optimal mid-band impedance match. If it were my project, I'd use ANY available dielectric material and conduct experiments over a ground plane on the table to achieve (1) antenna resonance and (2) best match to the feed line. When I was a kid, a 'gamma match' was commonly used to bring a feed line and antenna radiator into functional harmony. The attached figure illustrates an adjustable feeder strut paired with a variable capacitor to feed a grounded quarter-wave antenna. My 10M, 2-element beam had such a feature that was tuned with the aid of an SWR bridge. Today, a vector network analyzer is the instrument of choice and can cost less than a good SWR meter. After getting close on the bench, you can confirm on the airplane to see if 'tweeking' is called for. I've had readers assemble the Archer wing tip antennas per drawings but found it useful to trim dimensions per measured results. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jun 22, 2021
questions At 04:01 PM 6/22/2021, you wrote: > > >Your ebay-Foo is obviously better than mine; all the hits I got were >for much thicker stuff. > >Thanks for the link! I've got some fiber reinforced pvc sheet that would be suitable for your needs. Drop me a mailing address and I'll send you some scraps to play with. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Subject: EarthX on Firewall
From: "Neal George" <neal(at)appaero.com.matronics.com>
Date: Jun 23, 2021
Bob - For a Rotax-powered KitFox: Any heat-related concerns for putting an EarthX ETX680C on the firewall? Neal Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502544#502544 ________________________________________________________________________________
Date: Jun 23, 2021
On Tue, Jun 22, 2021 at 10:52 PM Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 12:03 PM 6/22/2021, you wrote: > > I have an Archer wingtip comm=C3=82 antenna I intend to install in one w ingtip > (can always add a 1/4 wave whip if needed), and I'm thinking about buildi ng > the nav version detailed in Bob's 'Antennas & Feedlines chapter for the > other wingtip (figure 13-12 in my document). > > How critical is the material for the .032" x .8" x 3.25" bakelite > insulator that forms what I'm guessing is a matching capacitor? Does the > bakelite participate in any way in operation, or is it simply a way to ge t > a fixed air gap? > > Bakelite in that 'thinness' doesn't seem to be available without paying > more for shipping than the 3-postage-stamp size needed would cost. What > about=C3=82 substituting something like the thin HDPE cutting board stock , > available at discount stores? Two layers would be about .034" thick.=C3 =82 > > > It IS critical . . . yes it forms the dielectric > for a capacitor used to series resonate the feeder > strut. > > Bob must have conducted experiments to optimize > the characteristics of that capacitor with respect > to the matching strut for optimal mid-band impedance > match. > > If it were my project, I'd use ANY available dielectric > material and conduct experiments over a ground plane > on the table to achieve (1) antenna resonance and > (2) best match to the feed line. > > When I was a kid, a 'gamma match' was commonly > used to bring a feed line and antenna radiator > into functional harmony. The attached figure > illustrates an adjustable feeder strut paired > with a variable capacitor to feed a grounded > quarter-wave antenna. > > My 10M, 2-element beam had such a feature that > was tuned with the aid of an SWR bridge. Today, > a vector network analyzer is the instrument > of choice and can cost less than a good SWR > meter. > > After getting close on the bench, you can > confirm on the airplane to see if 'tweeking' > is called for. I've had readers assemble the > Archer wing tip antennas per drawings but found > it useful to trim dimensions per measured results. > > > Bob . . . > If any dielectric is worth a shot, I think I'll try my flexible cutting board idea for a start. I've got a pack of them on the shelf, left over from another project (bearing surface for the round top tube of an aluminum hangar door). Package says 43% HDPE/57% EVA, and it's ~0.017" thick, so 2 layers will be pretty close in thickness, at least. How critical is tuning, for a receive-only Nav antenna? I do have a NanoVNA; I just need to learn how to use it. ;-) Thanks for the offer on the dielectric, but let me give the cutting board a shot first. BTW, since this is a Nav antenna and can lie flat on the bottom of the wingtip, I'm thinking I may try aluminum flashing (~0.008"), and slightly 'break' the edges to stiffen it. Any issues with that, if width/length dimensions are maintained? Charlie ________________________________________________________________________________
Subject: Re: EarthX on Firewall
Date: Jun 23, 2021
Neal, Might be best to follow the manufacturer's recommendations: https://earthxbatteries.com/engine-compartment-battery-installations Rob On 6/23/2021 2:32 PM, Neal George wrote: > > Bob - > For a Rotax-powered KitFox: > Any heat-related concerns for putting an EarthX ETX680C on the firewall? > > Neal > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=502544#502544 > > ________________________________________________________________________________
Date: Jun 23, 2021
Huh?=C2- Those recommendations don't make sense to me. The first chart seems to indicate that the box will hold the heat off for 3 0 min in a static situation.=C2- That makes sense, because the engine is cooling down during that 30 min and the delay will keep the battery from hi tting that red line. If taken at face value, the second seems to say that you're limited to 90 m inutes of flight time.=C2- After that, you're killing your battery. Are they seriously saying this?=C2- And what happens when you park after a 2hr flight, and the battery is already heat soaked? .nl> wrote: Neal, Might be best to follow the manufacturer's recommendations: https://earthxbatteries.com/engine-compartment-battery-installations Rob On 6/23/2021 2:32 PM, Neal George wrote: matronics.com> > > Bob - > For a Rotax-powered KitFox: > Any heat-related concerns for putting an EarthX ETX680C on the firewall? > > Neal > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=502544#502544 > > - S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Jun 23, 2021
If it's any indication, I'm running an AeroAkku LFP450D (450A CCA, 7Ah) next to my Jabiru 3300 shoe-horned in a small cowl. The battery is mounted low on the firewall, so heat trapped under the cowl when parked doesn't affect it as much as one mounted high up. But still, everything hot is nearby. I do not have a heat shield or box I've ran my first battery from 2013 to last year. Then replaced it for peace of mind. Measured endurance and CCA of the 7+ battery, and it was as good as new (440CCA, 7Ah). On my second battery, keeping the first one around for experiments and helping out others with flat batteries On 6/23/2021 6:00 PM, Ernest Christley wrote: > Huh? Those recommendations don't make sense to me. > > The first chart seems to indicate that the box will hold the heat off > for 30 min in a static situation. That makes sense, because the > engine is cooling down during that 30 min and the delay will keep the > battery from hitting that red line. > > If taken at face value, the second seems to say that you're limited to > 90 minutes of flight time. After that, you're killing your battery. > > Are they seriously saying this? And what happens when you park after > a 2hr flight, and the battery is already heat soaked? > > ________________________________________________________________________________
Date: Jun 23, 2021
> >If any dielectric is worth a shot, I think I'll try my flexible >cutting board idea for a start. I've got a pack of them on the >shelf, left over from another project (bearing surface for the round >top tube of an aluminum hangar door). Package says 43% HDPE/57% EVA, >and it's ~0.017" thick, so 2 layers will be pretty close in >thickness, at least. How critical is tuning, for a receive-only Nav >antenna? I do have a NanoVNA; I just need to learn how to use it. ;-) The reason that any dielectric can be considered is based on the physics of capacitors. The value of a capacitor is proportional to area of the 'plates', space between the plates, and dielectric constant of the material. Here's a comprehensive tutorial on the topic: http://www.phys.uri.edu/gerhard/PHY204/slides8-phy204.pdf In cases like this, one can estimate the value of any particular capacitor fabrication with the goal of duplicating Bob Archer's design goals. It would be REALLY nice if we had an Archer Original to measure the value of his productions. >Thanks for the offer on the dielectric, but let me give the cutting >board a shot first. No problem. I thought about the cutting sheets too but wondered if their flexibility might compromise the mechanical integrity of Bob's original design goal. But we're in experimental waters here. >BTW, since this is a Nav antenna and can lie flat on the bottom of >the wingtip, >I'm thinking I may try aluminum flashing (~0.008"), and slightly 'break' the >edges to stiffen it. Any issues with that, if width/length >dimensions are maintained? Skin effects for current flow due to operating frequency tell us that thickness of a conductor has no practical influence on performance. It's surface area and then only to a depth of .001" or so. The primary concern for materials selection are conductivity (aluminum and copper are good) and mechanical robustness suited to the environment. Bob's antennas were no more 'robust' than needed to avoid falling apart or breaking. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jun 23, 2021
Ernest - That=99s the way I read it. Doesn=99t address airflow under the cowl during flight, nor does it speak to natural convective cooling after shutdown. KitFox, on the other hand, recommends firewall-forward mounting in a simple tray, no box Neal On Jun 23, 2021, at 11:00 AM, Ernest Christley wrote: Huh? Those recommendations don't make sense to me. The first chart seems to indicate that the box will hold the heat off for 30 min in a static situation. That makes sense, because the engine is cooling down during that 30 min and the delay will keep the battery from hitting that red line. If taken at face value, the second seems to say that you're limited to 90 minutes of flight time. After that, you're killing your battery. Are they seriously saying this? And what happens when you park after a 2hr flight, and the battery is already heat soaked? wrote: > Neal, Might be best to follow the manufacturer's recommendations: https://earthxbatteries.com/engine-compartment-battery-installations Rob On 6/23/2021 2:32 PM, Neal George wrote: > > > Bob - > For a Rotax-powered KitFox: > Any heat-related concerns for putting an EarthX ETX680C on the firewall? > > Neal ________________________________________________________________________________
Date: Jun 23, 2021
I had my first LiFePo strapped to the firewall with no protection. Heat from the exhaust pipe destroyed it.=C2- You could see where it swell ed up on the bottom just above the pipe.=C2- Built a heat shield shelf to sit it on with some intervening insulation tape, and it is doing fine so f ar. Heat in the engine compartment is a lot like magnets in the cockpit.=C2- Inches make a HUGE difference. gmail.com> wrote: Ernest -=C2-That=99s the way I read it.Doesn=99t address air flow under the cowl during flight, nor does it speak to natural convective cooling after shutdown. KitFox, on the other hand, recommends firewall-forward mounting in a simple tray, no box=C2- Neal=C2- On Jun 23, 2021, at 11:00 AM, Ernest Christley wrote: Huh?=C2- Those recommendations don't make sense to me. The first chart seems to indicate that the box will hold the heat off for 3 0 min in a static situation.=C2- That makes sense, because the engine is cooling down during that 30 min and the delay will keep the battery from hi tting that red line. If taken at face value, the second seems to say that you're limited to 90 m inutes of flight time.=C2- After that, you're killing your battery. Are they seriously saying this?=C2- And what happens when you park after a 2hr flight, and the battery is already heat soaked? .nl> wrote: Neal, Might be best to follow the manufacturer's recommendations: https://earthxbatteries.com/engine-compartment-battery-installations Rob On 6/23/2021 2:32 PM, Neal George wrote: matronics.com> > > Bob - > For a Rotax-powered KitFox: > Any heat-related concerns for putting an EarthX ETX680C on the firewall? > > Neal ________________________________________________________________________________
Date: Jun 23, 2021
Ceengland wrote: > ... I do have a NanoVNA; I just need to learn how to use it. ;-) > > Charlie MegawattKS is a retired electrical engineering professor from Kansas State University in Manhattan, KS. He has YouTube videos about the NanaVNA. https://www.youtube.com/user/MegawattKS -------- John Bright, RV-6A, at FWF, O-360 Z-101 single batt dual alt SDS EM-5-F. john_s_bright(at)yahoo.com, Newport News, Va https://docs.google.com/document/d/1YOtPiA3AdUsQEYR4nodBESNAo21rxdnx4pFs7VxXfuI/edit?usp=sharing Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502559#502559 ________________________________________________________________________________
Date: Jun 23, 2021
At 11:00 AM 6/23/2021, you wrote: >Huh? Those recommendations don't make sense to me. > >The first chart seems to indicate that the box will hold the heat >off for 30 min in a static situation. That makes sense, because the >engine is cooling down during that 30 min and the delay will keep >the battery from hitting that red line. > >If taken at face value, the second seems to say that you're limited >to 90 minutes of flight time. After that, you're killing your battery. > >Are they seriously saying this? And what happens when you park >after a 2hr flight, and the battery is already heat soaked? I think the experimental data explores a hypothetical heat transfer from an exhaust pipe to the battery. The environmental chamber is a constant source of heating which does not exist under the cowl. Exhaust plumbing is a source of RADIANT heat that's easy to avoid. I don't recall any GA battery installation on a firewall that was at-risk for radiant heating. Tests we conducted on firewall mounting locations at Cessna waaayyy back when demonstrated that the highest temperatures experienced on the firewall were AFTER engine shutdown with the aircraft sitting in a zero-wind condition. Even then, transient temperatures were not real exciting . . . about 160F as I recall for minutes. Turbo engines were hotter after shutdown due to larger mass of really warm metal positioned in the lower regions of the cowl where convection flow would take the BTUs upward. It was not uncommon for pilot's to open the oil filler access door to allow heat to escape while waiting for the fuel truck to do it's thing. For the vast majority of our projects, any battery should live well sitting out in the open on a firewall mounted battery tray. It doesn't get all that hot there in flight and only for short periods of time in various non-flight conditions. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jun 23, 2021
At 11:49 AM 6/23/2021, you wrote: >I had my first LiFePo strapped to the firewall with no protection. > >Heat from the exhaust pipe destroyed it. You could see where it >swelled up on the bottom just above the pipe. Built a heat shield >shelf to sit it on with some intervening insulation tape, and it is >doing fine so far. > >Heat in the engine compartment is a lot like magnets in the >cockpit. Inches make a HUGE difference. Yes . . . if you put a hotdog on a spit over a fire, it's reasonable to expect it to get toasted. This builder might have avoided the experience by taking advantage of the various forums available. General aviation is over a century old . . . designers have learned a great deal about what works . . . and what doesn't . . . and why. Heat shield? Yup . . . who wuda thunk it? When in doubt, research the history. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jun 23, 2021
Subject: Vector Network Analyzer
>MegawattKS is a retired electrical engineering professor from Kansas >State University in Manhattan, KS. He has YouTube videos about the NanaVNA. > >https://www.youtube.com/user/MegawattKS haven't watched all of these but what I've seen are well done! A builder's first tool needs to be a multi-meter . . . it may well be that the second needs to be a VNA. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jun 23, 2021
=C2-=C2- Heat shield? Yup . . . who wuda thunk it? When =C2-=C2- in doubt, research the history. =C2- Bob . . . =C2- =C2- When in doubt?=C2- The true enemy is lack of doubt.=C2- :-) ________________________________________________________________________________
Date: Jun 23, 2021
>When in doubt? The true enemy is lack of doubt. :-) Yeeaaahh . . . sort of . . . all successful inventions have foundations in knowledge: Properties of materials, management of energy and refinement of process. Any recipe for success features a useful mix of those qualities that can be shared with confidence of achieving the same results. Hence I suggest that the greatest risk to success arises out of ignorance. The thinking craftsman should have doubts when the task at hand is not paired with a recipe for success. This is why networking . . . whether through formalized venues such as forums, special interest groups, etc have become the go-to sources for the evolution, proofing and sharing of recipes. The more knowledge is given away, the greater its worth. The worth of an idea never shared cannot be measured. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jun 24, 2021
Sent from: YOGA TABLET 10 HD+ On Jun 23, 2021 12:00 PM, Ernest Christley wrote: > > Huh? Those recommendations don't make sense to me. > > The first chart seems to indicate that the box will hold the heat off for 30 min in a static situation. That makes sense, because the engine is cooling down during that 30 min and the delay will keep the battery from hitting that red line. > > If taken at face value, the second seems to say that you're limited to 90 minutes of flight time. After that, you're killing your battery. > > Are they seriously saying this? And what happens when you park after a 2hr flight, and the battery is already heat soaked? > > > > Neal, > > Might be best to follow the manufacturer's recommendations: > https://earthxbatteries.com/engine-compartment-battery-installations > > Rob > > On 6/23/2021 2:32 PM, Neal George wrote: > > > > Bob - > > For a Rotax-powered KitFox: > > Any heat-related concerns for putting an EarthX ETX680C on the firewall? > > > > Neal > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=502544#502544 > > > > > > > > > > > > > > > > > > > http://www.matronics.================ > http://wiki.matronics.com<=================== > http://w===== > > ________________________________________________________________________________
Subject: Ameri-King AK-451 AF ELT?
Date: Jun 24, 2021
Hi Group I have a new, purchased long ago Ameri-King AK-451 AF ELT. I'm ready to install it in my Experimental Europa. Is it still a valid ELT? I believe there may be some ADs if installed on Certified Aircraft. Will it affect me? What do I need to know? Should I replace it? Thx. Ron P. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502593#502593 ________________________________________________________________________________
Date: Jun 24, 2021
Subject: Re: Ameri-King AK-451 AF ELT?
I'm not sure about US rules but in Canada these ELTs can still be used in amateur-built aircraft if you can find fresh batteries for them and they pass the yearly ELT check: Electronic Code of Federal Regulations (eCFR) If it passes the test, it's good for another year. The two I looked at in the last few years did not pass the test. On Thu, Jun 24, 2021 at 9:56 PM rparigoris wrote: > rparigor(at)hotmail.com> > > Hi Group > > I have a new, purchased long ago Ameri-King AK-451 AF ELT. > > I'm ready to install it in my Experimental Europa. > > Is it still a valid ELT? > > I believe there may be some ADs if installed on Certified Aircraft. Will > it affect me? What do I need to know? Should I replace it? > > Thx. > Ron P. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=502593#502593 > > ________________________________________________________________________________
Date: Jun 24, 2021
Its really a nice and useful piece of information. I am glad that you shared this useful information with us. I really enjoyed reading this post. Nice thought in your blog is very useful for us. Chandigarh Escorts (http://www.chandigarhescortsgirls.com/) Escorts in Chandigarh (http://www.escortschandigarh.com/) Call Girls in Chandigarh (http://www.callgirlschandigarh.co.in/) Chandigarh Call Girls (http://www.fanni.in/) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502595#502595 ________________________________________________________________________________
Date: Jun 24, 2021
Your blog entry merits the greater part of the positive input it"s been getting. It is rather very good, nevertheless, glance at the data with this handle. Chandigarh Escorts (http://www.kajrai.in/) Escorts in Chandigarh (http://www.riyabhat.in/) Call Girls in Chandigarh (http://www.chandigarhescortsgirls.com/) Chandigarh Call Girls (http://www.fanni.in/) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502596#502596 ________________________________________________________________________________
Date: Jun 27, 2021
Subject: Interav OV relay: how to do an integrity test.
So I'm sitting with this interav OV regulator of unknown condition that I want to test. It has all white leads, but it's fairly easy to pick up what appears to be the coil at 3 ohms and the contacts on the other two wires. [image: image.png] Now since I don't really know how these devices work, I'm looking for advice on how to test effectively. Do these devices work/not work, or is there more to it? Best Regards, Bob Verwey 082 331 2727 > >>> ________________________________________________________________________________
Subject: Re: Interav OV relay: how to do an integrity test.
Date: Jun 27, 2021
Are the wires shorted together that you suspect are the contacts? If not, maybe the 3 ohms are the contact wires. 3 ohms could be from corroded contacts. 3 ohms is too low for a coil. It would draw almost 5 amps and get very hot, 70 watts of heat. Assuming the contacts are normally closed, then: If one pair of wires is open, it means that either the contacts are not making contact or the coil is open. In either case, the relay is defective. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502620#502620 ________________________________________________________________________________
Date: Jun 27, 2021
The FAA pulled Ameri-King's production authorisation a few years ago because of quality concerns so no more batteries. Is your battery still in date? The AD in question is AD 2017-16-01. https://rgl.faa.gov/Regulatory_and_Guidance_Library/rgad.nsf/AOCADSearch/5BA F0370C7871DEB862581A0004AFD68?OpenDocument. I guess the question is are you required by operational regulations to carry an ELT? Peter -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com On Behalf Of rparigoris Sent: 25 June 2021 05:52 Subject: ****SPAM**** AeroElectric-List: Ameri-King AK-451 AF ELT? --> Hi Group I have a new, purchased long ago Ameri-King AK-451 AF ELT. I'm ready to install it in my Experimental Europa. Is it still a valid ELT? I believe there may be some ADs if installed on Certified Aircraft. Will it affect me? What do I need to know? Should I replace it? Thx. Ron P. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502593#502593 ________________________________________________________________________________
Date: Jun 28, 2021
test. At 02:50 PM 6/27/2021, you wrote: > >Are the wires shorted together that you suspect are the contacts? >If not, maybe the 3 ohms are the contact wires. 3 ohms could be >from corroded contacts. >3 ohms is too low for a coil. It would draw almost 5 amps and get >very hot, 70 watts of heat. >Assuming the contacts are normally closed, then: >If one pair of wires is open, it means that either the contacts are >not making contact or the coil is open. >In either case, the relay is defective. > >-------- >Joe Gores Joe's observations are spot on. The OV management product you're evaluating has a history that dates back 50 or so years. I'm aware of at least two OV management devices based on relays. One such product launched my aviation engineering career in 1972. My first task at Electro-Mech was to design a replacement for this device: http://aeroelectric.com/Pictures/Relays/RBM138-1_A.jpg http://aeroelectric.com/Pictures/Relays/RBM138-1_B.jpg In the second image, we see two relays. A normally closed device with rather hefty contacts incorporated to disconnect field excitation on the runaway alternator. The second relay is interesting. It's a reed relay wrapped in mu-metal to ward off effects of external magnetic fields. There is a capacitor across the reed relay coil for what I assume is intended to offer some time delay for energizing the relay. There's a resistor/thermistor network in series with the relay's coil which is also in series with a voltage calibration potentiometer. With set-point calibration voltage applied, the potentiometer is adjusted until the sensing relay just trips thereby energizing the field disconnect relay. The resistor/thermistor network provides temperature compensation for the rather strong, positive resistance vs. temperature coefficient of the sense relay's copper coil. Using relays offers a latching feature in that the drop-out voltage of the sense relay is a small fraction of the pull-in voltage. Hence, if the sense relay closes at 16.0 volts, it probably won't release until the voltage drops below 4-6 volts. This means that the ship's battery voltage will keep the relay closed until the alternator field supply switch is opened. I've not had occasion to inspect an InterAv-Alcor OV relay. Here's what I have in the library with respect to this OV management device and it's ancillary system components: http://www.aeroelectric.com/Installation_Data/Interav/ Two versions of the OV relay are illustrated: one with all white wire and a second with colored wires. As Joe has noted, you should measure a very low resistance between two of the four wires connected to the normally closed contacts of an excitation disconnect relay. The other wires should have a rather high resistance . . . probably on the order of several hundred ohms. This would represent connections to the sense coil. We don't know if this product has two relays. In theory, the whole thing can be implemented with one relay. The design we ultimately offered Cessna had a field disconnect relay driven by an SCR which latches in an on-state after trip. The SCR was triggered through a resistor, capacitor, and zener diode network tailored to optimize temperature stability of the setpoint. Check the resistances between wire again. If you don't see obvious 'coil' and 'contact' values then Joe's hypothesis of relay failure is correct. If you DO see appropriate resistances between the wire pairs, then attach a variable power supply to the HIGHER resistance pair and bring voltage up slowly until you hear a 'click'. This should occur between 15.5 and 16.5 volts according to the OV Relay's placarded performance numbers. You could also wire a tail-light bulb in series with the other pair to the test power supply. The bulb should be illuminated until the 'click' is heard. Is this a 'potted' assembly? If you look at the under side, do you see a metal close-out or is it filled with pour-in plastic? If it is failed and not potted, I'd like to have the carcass. It would be interesting to see how the 'other' competition in 1972 was doing things. I will publish a Shop Notes on the teardown inspection. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jun 28, 2021
Subject: An interesting anecdote on the RBM OV relay
Hadn't thought about this for quite a few years but the RMB Controls 138-1 relay in the picture was acquired at OSH 1990 or thereabouts. A young man showed up at the B&C booth to talk about regulators. Seems he was having trouble with the rear regulator on his recently 'finished' Rutan design Defiant. I remember being amazed that someone so young had the resources, time and talent to have completed such a project! His complaint was that the rear engine's alternator would not stay on line. When the field switch was closed, it would come on for a brief time and then shut down. I wasn't able to leave the booth but suggested that he bring the offending regulator in and we could hook it up to a power supply and evaluated it. An hour or so later he was back and plunked down an RBM Controls 138-1 OV Management relay! Yes, it had all the markings of a regulator (BUS, FLD, GND). He had purchased it from an aviation salvage yard and assumed it was a regulator based on the terminal labels. Fortunately the thing was still functional. As soon as the alternator came up, it would go into over voltage causing the 138-1 to trip. I explained his mistake whereupon he whipped out his credit card and bought at least one and perhaps two LR2 regulators. I asked him if I could have his 'non-regulator' and he gifted it to me. I think I've still got it laying around here somewhere. I also learned that his airplane was flown NY to OSH with only one functioning alternator and too few hours on it to qualify for anything but test-area-flight! At least he went home with two alternators and a fist-full of flight hours in the log. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Subject: Wig wag switching
Date: Jun 29, 2021
I am replacing the 12v incandescent wing recognition lights (2) and nose landing light with a Flyleds array in the nose rated at 10 amps and the two wing lights at 2 amps. I would like to maintain the two panel mounted SPST switches from the previous installation but to operate the wigwag circuit and switch all three to constant "on", one of the switches has to be a DPDT. Theoretically, I could power a DPDT relay from the SPST switch but searching Mouser and Digikey I am finding a dearth of possible candidates. Another option would be to use two SPST relays of which there are plenty and operate them both simultaneously via the panel switch. I would appreciate advice on the variables for the contact materials, coil resistance, etc. for this application. Larry Glasair I RG ________________________________________________________________________________
Date: Jun 29, 2021
Hi Bob, Indeed, a potted version of the device so no salvageable knowledge there! Appreciate the feedback; this is one for the bin! Best Regards, Bob Verwey 082 331 2727 > ________________________________________________________________________________
Subject: Re: Wig wag switching
Date: Jun 29, 2021
If two SPST relays will work, then why not one DPST relay? Mouser #:769-ACTL3CR3V Silver Alloy contacts are good for power applications. Gold contacts are for small signals, not power. Coil resistance should be greater than 100 ohms. Otherwise the relay will get too hot. Here is a DPDT from Digikey. Part number: A102CS12VDC Looks like both relays above have pins that require soldering. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502658#502658 ________________________________________________________________________________
Subject: Re: AeroElectric-List Digest: 1 Msgs - 06/15/21
Date: Jun 30, 2021
Check out my presentation https://1drv.ms/u/s!AhYZCTh8gqcnatdQEjkoOQwE164?e=pQGcQq Password for archive: 666777 * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > >Today's complete AeroElectric-List Digest can also be found in either of the >two Web Links listed below. The .html file includes the Digest formatted >in HTML for viewing with a web browser and features Hyperlinked Indexes >and Message Navigation. The .txt file includes the plain ASCII version >of the AeroElectric-List Digest and can be viewed with a generic text editor >such as Notepad or with a web browser. > >HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 21-06-15&Archive=AeroElectric > >Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 21-06-15&Archive=AeroElectric > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > AeroElectric-List Digest Archive > --- > Total Messages Posted Tue 06/15/21: 1 > ---------------------------------------------------------- > > >Today's Message Index: >---------------------- > > 1. 08:42 AM - Re: MAC/Ray Allen trim actuator connections (don van santen) > > > >________________________________ Message 1 _____________________________________ > > >From: don van santen <donvansanten(at)gmail.com> >Subject: Re: AeroElectric-List: MAC/Ray Allen trim actuator connections > >I use clear heat shrink to alliw easy cutting at the joint between the pin >and socket > >On Sat, Jun 12, 2021, 20:00 Robert L. Nuckolls, III < >nuckolls.bob(at)aeroelectric.com> wrote: > >> At 11:04 PM 6/11/2021, you wrote: >> >> For those tiny wires I like to use crimp-type D-sub pins and sockets.=C3 >=82 >> Stagger the joints and heat-shrink each one, then heat-shrink all five. >=C3=82 >> They don't need to be in a housing. It makes a fairly=C3=82 small and >> manageable=C3=82 bulge.=C3=82 I think Bob has a write-up on this techni >que. >> >> >> The last frame of this comic-book describes >> this technique: >> >> https://tinyurl.com/c5v2xvm >> >> . . . and yes, those 26AWG leads are of questionable >> design integrity. I've spoken with Ray-Allen folks >> at OSH about this numerous times 20+ years ago >> only to be rebuffed. So be it. It's their product. >> But anything less than 22AWG wire in the airframe >> bundles only increases fabrication labor and risk, >> it's not good practice in the GA industry. >> >> Raytheon-Beech DID use quite a bit of 24AWG wire >> in Model 390 airframe bundles. Assembly line folks >> hated the stuff but it DID save some weight in a very >> complex airplane (Premier). For our purposes >> any benefits secured by the use of tiny wires >> are washed out by degradation of robustness. >> >> Bob . . . >> >> Un impeachable logic: George Carlin asked, "If black boxes >> survive crashes, why don't they make the whole airplane >> out of that stuff?" >> > > > > > > > ________________________________________________________________________________
Date: Jun 30, 2021
At 07:23 AM 6/30/2021, you wrote: > >Check out my presentation >https://1drv.ms/u/s!AhYZCTh8gqcnatdQEjkoOQwE164?e=pQGcQq >Password for archive: 666777 > >* ****** CAUTION ****** bill(at)howerton.com IS NOT a subscriber to any Matronics forums. This link is HIGHLY SUSPECT. DO NOT exercise it! Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jun 30, 2021
At 12:12 PM 6/29/2021, you wrote: >I am replacing the 12v incandescent wing recognition lights (2) and >nose landing light with a Flyleds array in the nose rated at 10 amps >and the two wing lights at 2 amps. I would like to maintain the two >panel mounted SPST switches from the previous installation but to >operate the wigwag circuit and switch all three to constant "on", >one of the switches has to be a DPDT. Theoretically, I could power a >DPDT relay from the SPST switch but searching Mouser and Digikey I >am finding a dearth of possible candidates. Another option would be >to use two SPST relays of which there are plenty and operate them >both simultaneously via the panel switch. I would appreciate advice >on the variables for the contact materials, coil resistance, etc. >for this application. >Larry >Glasair I RG > It would be helpful if you could post a schematic of your proposed wiring. Verbal descriptions of schematics are often mis-interpreted leading to the wrong advice. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jun 30, 2021
BillHowerton was a valid Matronics user back in 2006. Evidently someone cracked his password for Matronics and is posting spam. The file, that the spammer provided a link to, is a vbs file which is an ideal format for hiding viruses or other malware. Do NOT download it. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502666#502666 ________________________________________________________________________________
Date: Jun 30, 2021
BillHowerton was a valid Matronics user back in 2006. Evidently someone cracked his password for Matronics and is posting spam. The file, that the spammer provided a link to, is a vbs file which is an ideal format for hiding viruses or other malware. Do NOT download it. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502667#502667 ________________________________________________________________________________
Subject: For Sale New Apple iPhone 12 5G 64/128/256GB $629
Date: Jun 30, 2021
Prices Are Canadian dollars. Visit Our Website www.esellibuy.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502672#502672 ________________________________________________________________________________
Subject: For Sale New Apple iPhone 12 5G 128GB Original Unlocked
$729
Date: Jul 01, 2021
The Price is Canadian dollar. Visit Our Website www.esellibuy.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502676#502676 ________________________________________________________________________________
Subject: For Sale New Apple iPhone 12 5G 256GB Original Unlocked
$829
Date: Jul 02, 2021
The Price is Canadian dollar. Visit Our Website www.esellibuy.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502679#502679 ________________________________________________________________________________
Subject: Re: AeroElectric-List Digest: 10 Msgs - 06/18/21
Date: Jul 02, 2021
Check out my presentation https://1drv.ms/u/s!AreStIOQRXvbbS5ZMN0VLbD3CYY?e=dQdIAf Password for archive: 8888 * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > >Today's complete AeroElectric-List Digest can also be found in either of the >two Web Links listed below. The .html file includes the Digest formatted >in HTML for viewing with a web browser and features Hyperlinked Indexes >and Message Navigation. The .txt file includes the plain ASCII version >of the AeroElectric-List Digest and can be viewed with a generic text editor >such as Notepad or with a web browser. > >HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 21-06-18&Archive=AeroElectric > >Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 21-06-18&Archive=AeroElectric > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > AeroElectric-List Digest Archive > --- > Total Messages Posted Fri 06/18/21: 10 > ---------------------------------------------------------- > > >Today's Message Index: >---------------------- > > 1. 09:54 AM - Re: Is there a switch configuration that will do this? (user9253) > 2. 11:54 AM - Re: Re: Is there a switch configuration that will do this? (David Carter) > 3. 12:49 PM - Re: Dual alternators (Peter Pengilly) > 4. 01:15 PM - Re: Re: Is there a switch configuration that will do this? (Robert L. Nuckolls, III) > 5. 01:27 PM - Re: Dual alternators (Robert L. Nuckolls, III) > 6. 02:10 PM - Re: Re: Is there a switch configuration that will do this? (David Carter) > 7. 02:12 PM - Re: Dual alternators (Kelly McMullen) > 8. 09:34 PM - Re: Dual alternators (Robert L. Nuckolls, III) > 9. 11:07 PM - Re: Dual alternators (tiyaverma) > 10. 11:10 PM - Re: Dual alternators (tiyaverma) > > > >________________________________ Message 1 _____________________________________ > > >Subject: AeroElectric-List: Re: Is there a switch configuration that will do this? >From: "user9253" <fransew(at)gmail.com> > > >You need a DP3T ON-ON-ON switch. >Mouser and Digikey and others sell them. >https://www.mouser.com/Electromechanical/Switches/Toggle-Switches/_/N-5g2jZ1yzvvqx?P=1z0z2o3Z1z0z28f >https://www.digikey.com/en/products/filter/toggle-switches/201?s=N4IgjCBcpgzADFUBjKAzAhgGwM4FMAaEAeygG0RYAWeWAdgE4QBdIgBwBcoQBlDgJwCWAOwDmIAL5EATLACsSEKkiZchEuUoAOafABseluy6ReAkeKkgAtNMXKBAV3WlIFBcwlW7bkABEABVgAFRYJIA > >-------- >Joe Gores > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=502430#502430 > > >________________________________ Message 2 _____________________________________ > > >From: David Carter <david(at)carter.net> >Subject: Re: AeroElectric-List: Re: Is there a switch configuration that will >do this? > >>> You need a DP3T ON-ON-ON switch. > >Joe - thank you, it appears that would work electrically. It took me a few >minutes to decipher the actions of this switch, but I got there. > >However, I have not yet found one in a form factor that would match the >rest of the standard toggles in my panel. I may have to just live with two >switches. It's not the end of the world, but it's not as elegant. > >Thanks! > >--- >David Carter >david(at)carter.net > >________________________________ Message 3 _____________________________________ > > >From: "Peter Pengilly" <Peter(at)sportingaero.com> >Subject: RE: AeroElectric-List: Dual alternators > >In Diamond twins one regulator is the master and has the job of >balancing the alternators. > >I=99m not actually sure how it achieves that, but works well most >of the time. > >The regulators are provided by the engine mfrs (Continental or Austro). > >The G1000 instrumentation systems use hall effect sensors to detect the >output of each alternator. > >The regulators use a different sensor to do their job. > >Can result in the G1000 saying the loads are unbalanced, which makes >pilots unhappy =93 although voltage is always good. > >I have spent a lot of time troubleshooting, reloading G1000 software and >other stuff to cure what seems to be an imaginary problem. > >Peter > > >From: owner-aeroelectric-list-server(at)matronics.com > On Behalf Of Robert L. >Nuckolls, III >Sent: 17 June 2021 18:21 >Subject: Re: AeroElectric-List: Dual alternators > > > I've imagined, but never tested, that running two alternators that > are feeding a single battery bus would be dominated by current from > one of the alternators. > > My reasoning is that regardless of how closely the charge systems > are matched, small variations would result in a slightly higher > output voltage on one of them. This would then result in an even > lower output from the lower voltage output charge system, > which would reduce its current contribution. > > Yes, until system loads exceeded the capacity > of the alternator with the higher set-point. The > bus voltage sags allowing the lower set-point > alternator to wake up and begin to support the > load. > > This is what happens with a B&C standby alternator > system. #2 alternator is set to some lower-than-nominal > regulation voltage. Should the #1 alternator quit, > voltage sags and #2 wakes up. Similarly, should the > #1 alternator suffer an open winding with subsequent > loss of capacity, the voltage might sag and again, > #2 steps in to take up the slack. > > In both cases, #1 alternator is running maxed out > whether by reason of total system loads =or= loss > of capacity. > >If the above assumptions are accurate, how would it change if >the two alternators shared a single regulator? >(I=C3=A2=82=AC=84=A2m not advocating >this arrangement) > > Cessna 336/337 Models do just that. Beech Barons too. > There is a switch for bringing a second regulator into > service should the first one fail. This philosophy > does produce a system whereby the two alternator > ammeters track each other fairly closely . . . in > my not so humble opinion, a totally misguided practice > to keep pilot's 'happy'. > > There is no practical NEED for balancing the > loads on two alternators assuming (1) either > alternator can carry 100% of ships loads > with (2) demonstrated adequacy of cooling. > > This shade-tree 'paralleling' scheme creates > single points of failure for both alternators. > How this got past in-house DERs is a mystery > to me . . . how the FAA bought it is a . . . > well . . . I won't go there. > >Would the result change If the two alternators were PMA units, >mechanically tied together and producing a sin wave 'in-phase.' > > The engines cannot be synchronized that tightly. > >One final question I've wondered about. How do twin engine planes >with two alternators manage (my assumed) tendency for two alternators >in parallel quickly relying on the larger voltage out unit for most >of the current? > > They parallel fields on a single regulator. > > I designed a true paralleling regulator proposal for Cessna on > the 303 Crusader program thinking that there was a HUGH after market > opportunity to put the system on new and fielded Barons and >Skymasters. > I don't know how the Cessna West was wiring their airplanes. > > In any case, Cessna East didn't bite on the idea so I > was never funded to pursue the design. Twin Generators on > earlier Cessna and Beech models WERE fitted with paralleling > regulators which DID NOT compromise independence of the > two system. Turbine twins have always enjoyed that design > philosophy. > > Here is a sketch on a generator paralleling system > on a Beech Model 18 I think . . . but typical of > all dual generator twins of the era. > >http://aeroelectric.com/Pictures/Schematics/Parallel_Aircraft_Generators. >jpg > > This design uses voltage drop in the generator's > compensation windings as a current shunt. Any difference > in those two voltages biases the voltage sense windings > to depress excitation to the generator with the higher > load while elevating excitation on the lighter loaded > machine . . . pretty slick. > > > Bob . . . > > Un impeachable logic: George Carlin asked, "If black boxes > survive crashes, why don't they make the whole airplane > out of that stuff?" > > >________________________________ Message 4 _____________________________________ > > >From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> >Subject: Re: AeroElectric-List: Re: Is there a switch configuration that will >do this? > > >>However, I have not yet found one in a form factor that would match >>the rest of the standard toggles in my panel. > > What switches are you using? > > > Bob . . . > > Un impeachable logic: George Carlin asked, "If black boxes > survive crashes, why don't they make the whole airplane > out of that stuff?" > >________________________________ Message 5 _____________________________________ > > >From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> >Subject: Re: AeroElectric-List: Dual alternators > > >> >>Thanks Bob, now that is amazing engineering, zero PN junctions, must >>be near bulletproof. >>Cheers, >>Brian. > > Pretty close. If memory serves, some versions of > these regulators came with field remover/refurbish/ > replace manuals. They're stone simple in their > physics of operation and very repairable as long > as they were not abused. > > > Bob . . . > > Un impeachable logic: George Carlin asked, "If black boxes > survive crashes, why don't they make the whole airplane > out of that stuff?" > >________________________________ Message 6 _____________________________________ > > >From: David Carter <david(at)carter.net> >Subject: Re: AeroElectric-List: Re: Is there a switch configuration that will >do this? > >>> What switches are you using? > >It appears that Stein's crew is putting these in by default unless I ask >for something else. > >https://www.steinair.com/product/toggle-switch-spst-onoff-fast-on-terminals/ > > >--- >David Carter >david(at)carter.net > >> > >________________________________ Message 7 _____________________________________ > > >Subject: Re: AeroElectric-List: Dual alternators >From: Kelly McMullen <kellym(at)aviating.com> > > >I was under the impression that the Diamond twins either had Austro >(originally Thielert) diesel engines or Lycoming avgas engines. Where >did Continental come in? > >On 6/18/2021 12:48 PM, Peter Pengilly wrote: >> In Diamond twins one regulator is the master and has the job of >> balancing the alternators. >> >> Im not actually sure how it achieves that, but works well most of the time. >> >> The regulators are provided by the engine mfrs (Continental or Austro). > > >________________________________ Message 8 _____________________________________ > > >From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> >Subject: RE: AeroElectric-List: Dual alternators > >At 02:48 PM 6/18/2021, you wrote: > >>In Diamond twins one regulator is the master and >>has the job of balancing the alternators. >> >>I=99m not actually sure how it achieves that, but works well most of > the time. > > Is there a .pdf of the alternator wiring you could > share? Sounds like an interesting system I'd like > to understand. > > > Bob . . . > > Un impeachable logic: George Carlin asked, "If black boxes > survive crashes, why don't they make the whole airplane > out of that stuff?" > >________________________________ Message 9 _____________________________________ > > >Subject: AeroElectric-List: Re: Dual alternators >From: "tiyaverma" <ms.tiyaverma(at)gmail.com> > > >Extremely inspired! Everything is extremely open Chandigarh Escorts Service (http://www.rashmibhargav.in/) clear illumination of issues. It contains really certainties. > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=502444#502444 > > >________________________________ Message 10 ____________________________________ > > >Subject: AeroElectric-List: Re: Dual alternators >From: "tiyaverma" <ms.tiyaverma(at)gmail.com> > > >Incredible articles and awesome design. Your forum post entry merits the greater part of the positive input Chandigarh Escorts (http://www.chandigarhescortsgirl.com/) it"s been getting. I want to steer about this, for the explanation that it's useful. > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=502445#502445 > > > > > > > > ________________________________________________________________________________
Date: Jul 02, 2021
Beware, Link contains virus. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502685#502685 ________________________________________________________________________________
Subject: Re: EGT issues hwo to troubleshoot best
Date: Jul 03, 2021
Hi all, wanted to update on that case, we did dismantle the plug and remove the d-sub pins, could see, that part of the braid around the wires was touching , did use shrinktube to cover the end and now the EGT4 looks stable. Thanks for the advices and help. Cheers Werner ________________________________________________________________________________
Subject: For Sale New Apple iPhone 12 Pro 5G 128GB Unlocked
$849
Date: Jul 02, 2021
The Price is Canadian dollar. Visit Our Website www.esellibuy.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502695#502695 ________________________________________________________________________________
Subject: For Sale New Apple iPhone 12 Pro 5G 256GB Unlocked
$949
Date: Jul 03, 2021
The Price is Canadian dollar. Visit Our Website www.esellibuy.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502697#502697 ________________________________________________________________________________
Subject: For Sale New Apple iPhone 12 Pro 5G 512GB Unlocked
$1,149
Date: Jul 03, 2021
The Price is Canadian dollar. Visit Our Website www.esellibuy.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502700#502700 ________________________________________________________________________________
Subject: Buy New Apple iPhone 12 Pro Max 5G 128GB Unlocked $949
Date: Jul 04, 2021
The Price is Canadian dollar. Visit Our Website www.esellibuy.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502701#502701 ________________________________________________________________________________
Date: Jul 04, 2021
At 05:32 PM 7/2/2021, you wrote: > >Hi all, > >wanted to update on that case, we did dismantle the plug and remove the >d-sub pins, could see, that part of the braid around the wires was >touching , did use shrinktube to cover the end and now the EGT4 looks >stable. > >Thanks for the advices and help. > >Cheers Werner Good detective work! Ain't physics wunderful? Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jul 05, 2021
Indeed, easier to detect then electronic gremlins with a logic approach to each and every component in the line. Found on the annual as well the nicked field wire which in one flight probably caused an elevated voltage and hunted down a crimp on a fast-on which, after 18 years, was degraded to become a high resistance point (heating element). All fine now and plane back in the air with a good feeling for finding these points. Cheers Werner On 04.07.2021 16:57, Robert L. Nuckolls, III wrote: > > -- Good detective work! Ain't physics wunderful? > > > - Bob . . . > ________________________________________________________________________________
Subject: Melted battery contractor ground wire
Date: Jul 05, 2021
I flipped the battery switch that activates the contractor this AM and melted the ground wire. I'm deep in the process of wiring my RV7 (most of the wiring completed), using a legacy schematic with EBUS architecture. Wiring to the battery contractor is standard--wire from contactor to switch (2-10) with ground to field of tabs at firewall. I have used a lawn tractor battery numerous times to energize the system when testing components as they're installed. All has worked well until this AM. I'd appreciate input to help me resolve what the issue might be. Thanks much in advance. -------- Frank McDonald Kitfox S7 912S, Sensenich Composite 3 Blade Acworth, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502714#502714 ________________________________________________________________________________
Subject: Re: Melted battery contractor ground wire
Date: Jul 05, 2021
It might be pertinent to mention I did not hear the typical "clank" from the battery contractor when I flipped the switch. -------- Frank McDonald Kitfox S7 - sold RV7 in progress Acworth, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502715#502715 ________________________________________________________________________________
Date: Jul 05, 2021
Have you made any wiring changes to the battery contactor recently? It seems that the melted wire is connected to positive someplace. One possibility is a shorted contactor coil, but unlikely. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502716#502716 ________________________________________________________________________________
Subject: Buy New Apple iPhone 12 5G 64GB Original Unlocked $679
Date: Jul 05, 2021
The Price is Canadian dollar. Visit Our Website http://www.esellibuy.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502717#502717 ________________________________________________________________________________
Subject: Buy New Apple iPhone 12 5G 128GB Original Unlocked
$729
Date: Jul 06, 2021
The Price is Canadian dollar. Visit Our Website www.esellibuy.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502718#502718 ________________________________________________________________________________
Date: Jul 06, 2021
I haven't made any changes to the battery contactor recently. -------- Frank McDonald Kitfox S7 - sold RV7 in progress Acworth, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502719#502719 ________________________________________________________________________________
Date: Jul 06, 2021
Remove the wire from the small terminal of the battery contactor. Measure the resistance between that small contactor terminal and the large contactor terminal that connects to battery positive. I expect it to be about 20 ohms. If less than 5 ohms, the contactor coil is shorted. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502720#502720 ________________________________________________________________________________
Date: Jul 06, 2021
Thanks Joe. Did that this AM. No resistance at all. Shorted contactor as you suggest. The burnt ground wire was in a loose bundle--run together but haven't tied them together. I assume there's possible damage to other wires in the bundle? If there's no damage to the insulation of the other wires then they're good to go? -------- Frank McDonald Kitfox S7 - sold RV7 in progress Acworth, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502722#502722 ________________________________________________________________________________
Date: Jul 06, 2021
This experience makes me wonder why no circuit protection for the contactor activator switch circuit in any of the architectures. Maybe it's because a short in the contactor is unlikely, as Joe says, but isn't that the assumption behind all circuits that do have circuit protection built in? -------- Frank McDonald Kitfox S7 - sold RV7 in progress Acworth, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502723#502723 ________________________________________________________________________________
Date: Jul 06, 2021
Hello Frank, You are asking good questions. What typically happens is the coil burns up and causes an open circuit, but in your case it appears to have failed closed. It will be interesting to conduct a post-mortem on it to determine how it c reated such a hard fault. Questions: 1. Can you post a picture of the master solenoid/contactor?2. What size wir e runs from the solenoid to the master switch? -Jeff et> wrote: This experience makes me wonder why no circuit protection for the contactor activator switch circuit in any of the architectures. Maybe it's because a short in the contactor is unlikely, as Joe says, but i sn't that the assumption behind all circuits that do have circuit protectio n built in? -------- Frank McDonald Kitfox S7 - sold RV7 in progress Acworth, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502723#502723 - S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Jul 06, 2021
At 03:15 PM 7/6/2021, you wrote: >Hello Frank, > > >You are asking good questions. > >What typically happens is the coil burns up and causes an open >circuit, but in your case it appears to have failed closed. > >It will be interesting to conduct a post-mortem on it to determine >how it created such a hard fault. We've inspected a few failures here over the years but a hard fault across the coil is a new one. Here's an exemplar 'open' coil https://tinyurl.com/yzcx4q2u If you have no other plans for the failed part, I'd like to have it. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jul 06, 2021
At 01:20 PM 7/6/2021, you wrote: > >This experience makes me wonder why no circuit protection for the >contactor activator switch circuit in any of the architectures. > >Maybe it's because a short in the contactor is unlikely, as Joe >says, but isn't that the assumption behind all circuits that do have >circuit protection built in? The vast majority of failures in wires is a lost of continuity. Broken wire, loose terminal, etc. The battery contactor control wire is generally never at-risk for fault to ground on the run between contactor and master switch . . . the master contactor simply becomes 'stuck on'. The fault you've experienced is exceedingly rare . . . the first one I've heard of. It would be interesting to identify and document the failure mode. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jul 06, 2021
Jeff What pic would be most revealing for you? Installed on the firewall? Removed on the bench? Other? -------- Frank McDonald Kitfox S7 - sold RV7 in progress Acworth, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502729#502729 ________________________________________________________________________________
Date: Jul 07, 2021
I'd like to see it as installed, for starters. -Jeff t> wrote: Jeff What pic would be most revealing for you?=C2- Installed on the firewall? =C2- Removed on the bench?=C2- Other? -------- Frank McDonald Kitfox S7 - sold RV7 in progress Acworth, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502729#502729 - S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Jul 06, 2021
Frank, The only way you are going to melt that wire is likely with a direct short between positive and negative battery voltages. Most likely candidates for that occurrence is a mis-wired switch or contactor. I would disconnect the wire from the switch where it attaches to the 'field of tabs' and rewire from the switch to the contactor. Do a continuity test from the contactor terminal to the now disconnected connector at the field of tabs. In the switch 'ON' position, you should have very little resistance, and high resistance in the 'OFF' position. If both of those are TRUE, then that wiring should be OK. If they are not both TRUE, then you need to examine the wiring to the switch more closely. Another possibility is that you have the positive and negative terminals of the contactor switched with your wiring arrangement. That is the area I would examine next after all the foregoing. If neither of these is the problem, could it be a bad contactor? Doug Windhorn -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com On Behalf Of frank3 Sent: Monday, July 5, 2021 1:49 PM Subject: AeroElectric-List: Melted battery contractor ground wire --> I flipped the battery switch that activates the contractor this AM and melted the ground wire. I'm deep in the process of wiring my RV7 (most of the wiring completed), using a legacy schematic with EBUS architecture. Wiring to the battery contractor is standard--wire from contactor to switch (2-10) with ground to field of tabs at firewall. I have used a lawn tractor battery numerous times to energize the system when testing components as they're installed. All has worked well until this AM. I'd appreciate input to help me resolve what the issue might be. Thanks much in advance. -------- Frank McDonald Kitfox S7 912S, Sensenich Composite 3 Blade Acworth, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502714#502714 ________________________________________________________________________________
Subject: Buy New Apple iPhone 12 5G 256GB Original Unlocked
$829
Date: Jul 06, 2021
The Price is Canadian dollar. Visit Our Website http://www.esellibuy.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502732#502732 ________________________________________________________________________________
Subject: Buy New Apple iPhone 12 Pro 5G 128GB Original Unlocked
$849
Date: Jul 07, 2021
The Price is Canadian dollar. Visit Our Website www.esellibuy.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502735#502735 ________________________________________________________________________________
From: "nuckollsr" <bob.nuckolls(at)aeroelectric.com>
Date: Jul 07, 2021
At 09:08 PM 7/6/2021, you wrote: Frank, The only way you are going to melt that wire is likely with a direct short between positive and negative battery voltages. Most likely candidates forthat occurrence is a mis-wired switch or contactor. Question: did this contactor installation EVER work? Q: What is the measured resistance of the contactor's coil? . . . WITH ANY SPIKE SUPPRESSION DIODE REMOVED. Q: Is there ANY continuity between the any terminal of contactor and it's case? Q: What kind of contactor is this? 3-terminal, 4-terminal? Q: Is there a spike suppression diode installed across the contactor's coil terminals. Has this been checked for proper polarity? (Banded end needs to fact the battery, other end faces master switch). If this diode is BACKWARDS or SHORTED it will cause failure of the contactor-to-master switch wire. If a backwards diode is found to be root cause of the burned wire, then replace BOTH diode and wire. The current impressed on the diode during wire-burning will have exceeded its ratings and it's probably toast too. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502737#502737 ________________________________________________________________________________
Date: Jul 07, 2021
Folks, I posted some erroneous info. When I measured the resistance between the small contactor terminal and the larger terminal connecting to the battery (+) I did so with the diode in place. Hence, the "no resistance". (I'm still learning or at least trying to) Today I removed the contactor, removed the diode from the contactor, and checked for resistance, again. This time I got 0.016 ohms. So, according to Joe's criteria, it's still a bad contactor. Guess we ended up at the same place using a different path? Just for kicks, I did a bench test. I connected a 22 awg wire to the small terminal, terminating at the the master switch (2-10). Using a similar wire I connected to the switch terminating at neg side of contactor. I applied jumper cables to the large contactor terminals. I activated the switch and then connected the jumper cables to the battery. Same result--wires melted. Tried to attach pic of the contactor on the firewall but unable to reduce the pic file size. Joe asked what size wire I used. 18 awg contactor to master switch; 22 awg to field of tabs. I can not recall whay I used the 18 awg instead of 22 awg. The 18 awg survived the event. The 22 awg melted, as a fussible link for the 18 awg? Bob, if you still want the contactor I'll gladly send it to you. Just let me know where to send. Thanks everyone for you interest and advice. I have ordered a new contactor from our friends at B&C. -------- Frank McDonald Kitfox S7 - sold RV7 in progress Acworth, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502739#502739 ________________________________________________________________________________
Date: Jul 07, 2021
On 7/7/2021 6:09 PM, frank3 wrote: > > Folks, I posted some erroneous info. When I measured the resistance between the small contactor terminal and the larger terminal connecting to the battery (+) I did so with the diode in place. Hence, the "no resistance". (I'm still learning or at least trying to) > > Today I removed the contactor, removed the diode from the contactor, and checked for resistance, again. This time I got 0.016 ohms. So, according to Joe's criteria, it's still a bad contactor. Guess we ended up at the same place using a different path? > > Just for kicks, I did a bench test. I connected a 22 awg wire to the small terminal, terminating at the the master switch (2-10). Using a similar wire I connected to the switch terminating at neg side of contactor. I applied jumper cables to the large contactor terminals. I activated the switch and then connected the jumper cables to the battery. Same result--wires melted. > > Tried to attach pic of the contactor on the firewall but unable to reduce the pic file size. > > Joe asked what size wire I used. 18 awg contactor to master switch; 22 awg to field of tabs. I can not recall whay I used the 18 awg instead of 22 awg. The 18 awg survived the event. The 22 awg melted, as a fussible link for the 18 awg? > > Bob, if you still want the contactor I'll gladly send it to you. Just let me know where to send. > > Thanks everyone for you interest and advice. I have ordered a new contactor from our friends at B&C. > > -------- > Frank McDonald > Kitfox S7 - sold > RV7 in progress > Acworth, GA That doesn't 'sound' right. There should be 2 'fat' terminals and one small terminal on a typical master contactor. With no voltage applied, you should measure open circuit (infinite resistance) between the small terminal and one of the fat terminals, some relatively low (but not close to zero; see Joe's resistance number) resistance between the small terminal and the other fat terminal, and infinite resistance between the 2 fat terminals. Measuring .016 ohms with a typical ohm meter sounds a little suspicious; there's often more resistance than that in the leads and terminal contact points. Did you have it hooked up as shown in this video? https://www.youtube.com/watch?v=7FSK1JblQaE Near the end, he shows how to hook up a 4 terminal version (less common). Charlie -- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jul 07, 2021
Frank, I interpreted your post to mean that you connected one jumper cable from battery positive to a fat terminal on the contactor, and you connected another jumper cable from the negative battery terminal to the other contactor fat terminal. If that is true, then you are lucky that the contactor is defective. There could have been flying molten metal. The negative battery terminal should NOT be connected to a fat contactor terminal because something bad will happen. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502741#502741 ________________________________________________________________________________
Date: Jul 07, 2021
> >Bob, if you still want the contactor I'll gladly send it to >you. Just let me know where to send. Bob Nuckolls PO Box 130 Medicine Lodge, Kansas 67104-0130 >Thanks everyone for you interest and advice. I have ordered a new >contactor from our friends at B&C. Was this contactor from B&C originally? Which part? Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Subject: Buy New Apple iPhone 12 Pro 5G 256GB Original Unlocked
$949
Date: Jul 07, 2021
The Price is Canadian dollar. Visit Our Website www.esellibuy.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502743#502743 ________________________________________________________________________________
Subject: Buy New Apple iPhone 12 Pro 5G 512GB Unlocked $1,149
Date: Jul 08, 2021
The Price is Canadian dollar. Visit Our Website www.esellibuy.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502744#502744 ________________________________________________________________________________
Date: Jul 08, 2021
Bob's questions answered: 1. Yes, the contactor has been functioning for a couple of months. I've been using jumper cables to connect a lawn tractor battery so I can test components as they are installed. 2. The measured resistance is 16.5 ohms, small terminal to battery side fat terminal with diode removed. (The 0.016 value reported and questioned by Charlie was using the wrong range). 3. There is no continuity between any of the terminals and the case. 4. This is a three terminal Cole Hersee provided by Vans Aircraft. 5. There was a spike supression diode installed, provided by Vans with terminals and shrink tube insulation already installed. I peeled back the insulation to ensure the diode was installed properly, with the band towards the fat terminal. As you suggested, the diode is now nonfunctional. Bob, the contactor is in the mail. As Doug suggested (6 Jul #11) I went through the suggested process to test the wiring and switch. Both were TRUE--both wiring and switch were proper. BTW, I don't understand how a miss-wired switch could cause a direct short. My understand is the switch simply enables the circuit to conduct current or not. I can see the possibility of a short between the switch and the airframe but don't understand miss-wiring. Something I need educating about? Jeff, I submitted the pic with contactor installed. We'll see if it gets published. Joe (7 Jul #5), you interpreted my post correctly. After reviewing schematics I see I WAS lucky! (Might just as well connected the two jumper cables!!! Just talking to myself) Charlie (7 Jul #4), thanks for suggesting the video on battery contractors. It was wired per the video. What you describe re: open circuits & resistance between the terminals is what I was getting. I must not have described clearly. And, as stated above, you were right to be suspicious of my #, I used the wrong range. Again, thanks to all for their interest, questions, and suggestions. -------- Frank McDonald Kitfox S7 - sold RV7 in progress Acworth, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502751#502751 ________________________________________________________________________________
Subject:
Date: Jul 08, 2021
V2h5IGRvZXMgdGhpcyBnYXJiYWdlIGtlZXAgYXBwZWFyaW5nIG9uIHRoZSBBZXJvRWxlY3RyaWMg TGlzdD8NCg0KDQoNCg0KRnJvbTogamVpYWVyeQ0KU2VudDogV2VkbmVzZGF5LCBKdWx5IDcsIDIw MjEgMTA6MzMgUE0NClRvOiBhZXJvZWxlY3RyaWMtbGlzdEBtYXRyb25pY3MuY29tDQpTdWJqZWN0 OiBBZXJvRWxlY3RyaWMtTGlzdDogQnV5IE5ldyBBcHBsZSBpUGhvbmUgMTIgUHJvIDVHIDI1NkdC IE9yaWdpbmFsIFVubG9ja2VkICQ5NDkNCg0KLS0+IEFlcm9FbGVjdHJpYy1MaXN0IG1lc3NhZ2Ug cG9zdGVkIGJ5OiAiamVpYWVyeSIgPGplaWFlcnlAODJ1bHRyYS5jb20+DQoNClRoZSBQcmljZSBp cyBDYW5hZGlhbiBkb2xsYXIuIFZpc2l0IE91ciBXZWJzaXRlIHd3dy5lc2VsbGlidXkuY29tDQoN Cg0KDQoNClJlYWQgdGhpcyB0b3BpYyBvbmxpbmUgaGVyZToNCg0KaHR0cDovL2ZvcnVtcy5tYXRy b25pY3MuY29tL3ZpZXd0b3BpYy5waHA/cD01MDI3NDMjNTAyNzQzDQoNCg0KDQoNCg0KDQpfLT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PQ0KXy09ICAgICAgICAgIC0gVGhlIEFlcm9FbGVjdHJpYy1MaXN0IEVtYWlsIEZvcnVtIC0NCl8t PSBVc2UgdGhlIE1hdHJvbmljcyBMaXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0byBicm93c2UNCl8t PSB0aGUgbWFueSBMaXN0IHV0aWxpdGllcyBzdWNoIGFzIExpc3QgVW4vU3Vic2NyaXB0aW9uLA0K Xy09IEFyY2hpdmUgU2VhcmNoICYgRG93bmxvYWQsIDctRGF5IEJyb3dzZSwgQ2hhdCwgRkFRLA0K Xy09IFBob3Rvc2hhcmUsIGFuZCBtdWNoIG11Y2ggbW9yZToNCl8tPQ0KXy09ICAgLS0+IGh0dHA6 Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/QWVyb0VsZWN0cmljLUxpc3QNCl8tPQ0KXy09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT0NCl8tPSAgICAgICAgICAgICAgIC0gTUFUUk9OSUNTIFdFQiBGT1JVTVMgLQ0KXy09IFNhbWUg Z3JlYXQgY29udGVudCBhbHNvIGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMhDQpfLT0NCl8t PSAgIC0tPiBodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20NCl8tPQ0KXy09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCl8tPSAgICAg ICAgICAgICAgLSBORVcgTUFUUk9OSUNTIExJU1QgV0lLSSAtDQpfLT0gQWRkIHNvbWUgaW5mbyB0 byB0aGUgTWF0cm9uaWNzIEVtYWlsIExpc3QgV2lraSENCl8tPSAgIC0tPiBodHRwOi8vd2lraS5t YXRyb25pY3MuY29tDQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PQ0KXy09ICAgICAgICAgICAgIC0gTGlzdCBDb250cmlidXRpb24g V2ViIFNpdGUgLQ0KXy09ICBUaGFuayB5b3UgZm9yIHlvdXIgZ2VuZXJvdXMgc3VwcG9ydCENCl8t PSAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIC1NYXR0IERyYWxsZSwgTGlzdCBBZG1pbi4N Cl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uDQpfLT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0K DQoNCg0KDQo ________________________________________________________________________________
Date: Jul 08, 2021
Don't know if this is relevant but checked the fuses to all the circuits and found the 5amp fuse to the Dynon EFIS was blown. EFIS was only open circuit at the time of the incident. Evidence there must have been some kind of over voltage event, I guess. New fuse and using EBUS circuit I found the EFIS is good to go. -------- Frank McDonald Kitfox S7 - sold RV7 in progress Acworth, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502753#502753 ________________________________________________________________________________
Date: Jul 08, 2021
Is it possible that you inadvertently hooked-up the battery backwards that day? net> wrote: Don't know if this is relevant but checked the fuses to all the circuits an d found the 5amp fuse to the Dynon EFIS was blown.=C2- EFIS was only open circuit at the time of the incident.=C2- Evidence there must have been s ome kind of over voltage event, I guess. New fuse and using EBUS circuit I found the EFIS is good to go. -------- Frank McDonald Kitfox S7 - sold RV7 in progress Acworth, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502753#502753 - S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Jul 08, 2021
Subject: Re: ectric-List:
I'm surprised you are surprised. Spam is a small problem right now compared to what is coming. Currently, large sections of the internet are constantly under attack by advertisers and criminals. I was a moderator on one of the world's biggest aviation forums and for every legitimate new member who joined and posted, there were 10 ads or scams. In order to prevent the board from being completely flooded, we had to block all new user's posts from being visible until a moderator had checked it and decided whether or not it was legitimate. This means that the spammers and scammers found it worthwhile to create new accounts (as laborious a process as we could reasonably make it) and then post dozens of messages from that account despite 99.999% of those messages never being visible to anyone. Every once in a while there was a real human involved in trying to get spam through and sometimes they succeeded, usually by copying an existing post. Right now the flood is being kept at bay fairly easily by a few minor inconveniences for new users and a lot of effort by unpaid volunteers. Keep in mind though that there is an almost unlimited amount of money being spent on programming AI systems that will get much, much better at pretending to be humans on the internet. Right now, over half of all emails in the world are spam. In the next 50 years I think we will see 99% of internet traffic turn into AI systems trying to figure out ways to advertise and scam the humans still trying to enjoy this technology. It's going to get to the point where the only way you will be allowed to communicate with anyone over the internet (and phone system for that matter) will be to have someone already in the system vouch for you. Unless you know someone who can physically confirm that you exist and can pass that introduction on to others, it will be assumed that you're an AI and you will be blocked. On Thu, Jul 8, 2021 at 9:52 AM Roger & Jean wrote: > Why does this garbage keep appearing on the AeroElectric List? > > > *From: *jeiaery <jeiaery(at)82ultra.com> > *Sent: *Wednesday, July 7, 2021 10:33 PM > *To: *aeroelectric-list(at)matronics.com > *Subject: *AeroElectric-List: Buy New Apple iPhone 12 Pro 5G 256GB > Original Unlocked $949 > > > The Price is Canadian dollar. Visit Our Website www.esellibuy.com > > > Read this topic online here: > > > http://forums.matronics.com/viewtopic.php?p=502743#502743 > > ________________________________________________________________________________
Date: Jul 08, 2021
My 1st thought, as well. That would explain smoking the spike suppression diode on the contactor. Must have been God's Own suppression diode, though, to take the wire with it. Charlie On 7/8/2021 12:06 PM, Jeff Luckey wrote: > Is it possible that you inadvertently hooked-up the battery backwards > that day? > > wrote: > > > > > > Don't know if this is relevant but checked the fuses to all the > circuits and found the 5amp fuse to the Dynon EFIS was blown. EFIS > was only open circuit at the time of the incident. Evidence there > must have been some kind of over voltage event, I guess. > > New fuse and using EBUS circuit I found the EFIS is good to go. > > -------- > Frank McDonald > Kitfox S7 - sold > RV7 in progress > Acworth, GA > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=502753#502753 > <http://forums.matronics.com/viewtopic.php?p=502753#502753> > > > http://www.matronics.com/Navigator?AeroElectric-; - MATRONICS > WEB FORUMS - > http://forums.matronbsp; - NEW MATRONICS LIST WIKI - > http://wiki.matronics.com > http://www.matronics.com/contributi===================== > > -- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jul 08, 2021
I think that jluckey has solved the problem. Reverse battery polarity explains the melted wire and the blown fuse. Luckily the EFIS was not damaged. I predict that Bob N will not find anything wrong with the contactor. An over voltage event is extremely unlikely without an alternator running. It is pretty easy to reverse battery voltage when using jumper cables. One has a 50-50 chance of getting it wrong. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502757#502757 ________________________________________________________________________________
Subject: Re: Magnetized Dynon D100 Display
Date: Jul 08, 2021
The mystery of the magnetized EFIS has been solved. Don Jones of Dynon Technical Support offered to send me a remanufactured D100 EFIS to swap out and to test mine at their shop. I determined that the replacement had barely measurable permanent magnetism in the same location as the original, but it was not enough to affect the panel mount compass nearby. I installed it in the panel, did an approximate compass swing using our local taxiway centerlines as a reference for the cardinal pointsclose enough for our purposes as magnetic deviation is minimal here. The figure shows good agreement in cruise between EFIS and panel mount compass. No doubt a more rigorous compass swing would improve things further. Don sent me his findings. I have looked into the magnetized D100. As you noted, it is the LCD that is the source. More specifically the thin stainless frame around the LCD. Early version LCD's (like yours) apparently have a stainless alloy frame that can be magnetized, later versions (bright screen models) have a better stainless alloy and won't stick to a magnet. The replacement we sent has the later version. The panel mounted compass reads the same whether the master switch and avionics switches are on or off, and whether or not the engine is running. Carefully following Bob's guidelines in the Aero-Electric Connection while building no doubt helped! It should go without saying that I couldnt be happier with Dynons support, the performance of the replacement unit, and that Im confident the problem wont return. Many thanks to Don for his follow up that led to a successful conclusion. Chris Skelt LNC2 at IWS. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502758#502758 Attachments: http://forums.matronics.com//files/reman_efis_works_260.png ________________________________________________________________________________
Date: Jul 08, 2021
That's always a possibility, I suppose. Maybe Bob postmortem will shed some light on your supposition. Thanks for supposing a new idea thread. -------- Frank McDonald Kitfox S7 - sold RV7 in progress Acworth, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=502760#502760 ________________________________________________________________________________
Date: Jul 08, 2021
At 12:59 PM 7/8/2021, you wrote: > >I think that jluckey has solved the problem. Reverse battery >polarity explains the melted wire and the blown fuse. Luckily the >EFIS was not damaged. >I predict that Bob N will not find anything wrong with the >contactor. An over voltage event is extremely unlikely without an >alternator running. >It is pretty easy to reverse battery voltage when using jumper >cables. One has a 50-50 chance of getting it wrong. agreed. in fact, the spike suppression diode served to PROTECT against reversed polarity. It would have prevented contactor closing by shunting the applied voltage to near zero and thus causing the wire to melt. This suggests a reason for including a fuse in the battery contactor control line . . . it would prevent wire and fuse damage in the reverse polarity event. Perhaps a fusible link? 24AWG against a 20AWG control line? Perhaps a bit more robust mechanically. But this should be an exceedingly rare event. If you've not yet mailed the contactor, I suggest you re-install it and see what happens. Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jul 09, 2021
In addition to being embarrassed for crossing the terminals, I am VERY relieved to have the answer. I know my build is good (If only I could do something more robust to guard against human error). The cloud of uncertainty is a dark one. I have learned a lot about electronics problem solving and how contactors and diodes work in the system. Thanks for that. I also know I have an answer for the question, Grandad, what happens if you cross the battery terminals in your airplane. I offer to you all, as a sort of recompense for your support, a Robert Fulghum essay about jumper cables, page 128, in his book, All I Really Need To Know I Learned In Kindergarten. It will surely bring out a chuckle as you read it! Cheers ________________________________________________________________________________
Date: Jul 09, 2021
> This suggests a reason for including a fuse > in the battery contactor control line . . . > it would prevent wire and fuse damage in > the reverse polarity event. See new Z-figure http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z38.pdf Bob . . . Un impeachable logic: George Carlin asked, "If black boxes survive crashes, why don't they make the whole airplane out of that stuff?" ________________________________________________________________________________
Date: Jul 04, 2021
Subject: Re: Buy New Apple iPhone 12 Pro Max 5G 128GB Unlocked
$949
We don't need this advertising crap on the list! Roger On Jul 4, 2021 4:20 AM, jeiaery wrote: > > > The Price is Canadian dollar. Visit Our Website www.esellibuy.com > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=502701#502701 > > ________________________________________________________________________________
Date: Jul 12, 2021
Subject: Bob Archer Antenna Voodoo
BobN, CharlieE, & RF Gurus et al, I'm considering Bob Archer's wingtip VOR antenna for my RV-7 but I am too i gnorant to understand how the thing works. I have read posts all over the intrawebs and have some questions:=C2- (Pl ease use small words and talk slowly): 1. It looks to me like the 'front/leading edge' 60 deg leg is bolted direct ly to the base leg which is grounded.=C2- How can the "active" (is that t he correct word?) be directly connected to ground? 2. I have read articles where the author is talking about "tuning" the ante nna after it is installed in a specific airframe.=C2-=C2-=C2- a. They talk about trimming/cutting pieces - what pieces and how much trimming?=C2 - b. They also talk about fooling with the dielectric section but I don't understand what physical dimensions/properties they are altering.=C2- Ar e they cutting aluminum or bakelite; or moving feed line screw holes; or ju st moving the bakelite piece around in small increments?? 3. SWR meter vs Antenna Analyzer=C2- a. I think that SWR applies to trans mitting, so is it relevant with respect to VOR antenna?=C2- b. What is an Antenna Analyzer and how does it work?=C2- (in 5 words or less) TIA for VOR Antenna 101 -Jeff ________________________________________________________________________________
Date: Jul 13, 2021
Subject: Re: Bob Archer Antenna Voodoo
On Mon, Jul 12, 2021 at 6:28 PM Jeff Luckey wrote: > BobN, CharlieE, & RF Gurus et al, > > > I'm considering Bob Archer's wingtip VOR antenna for my RV-7 but I am too > ignorant to understand how the thing works. > > I have read posts all over the intrawebs and have some questions: (Please > use small words and talk slowly): > > 1. It looks to me like the 'front/leading edge' 60 deg leg is bolted > directly to the base leg which is grounded. How can the "active" (is that > the correct word?) be directly connected to ground? > > 2. I have read articles where the author is talking about "tuning" the > antenna after it is installed in a specific airframe. > a. They talk about trimming/cutting pieces - what pieces and how much > trimming? > b. They also talk about fooling with the dielectric section but I don't > understand what physical dimensions/properties they are altering. Are they > cutting aluminum or bakelite; or moving feed line screw holes; or just > moving the bakelite piece around in small increments?? > > 3. SWR meter vs Antenna Analyzer > a. I think that SWR applies to transmitting, so is it relevant with > respect to VOR antenna? > b. What is an Antenna Analyzer and how does it work? (in 5 words or > less) > > > TIA for VOR Antenna 101 > > > -Jeff > Hi Jeff, Anything beyond a plain 1/4 wave or a dipole is beyond me, too. Only thing I can answer is #1; the center conductor of the coax is only connected 'one end' of the capacitor formed by the little 2.5" long metal strip, the bakelite strip, and rest of the '3rd leg' of the triangle. The entire body of the antenna is *electrically* (at least to a DC ohm meter) tied to the base strip. So the only thing that the center conductor physically touches is that 2.5" metal strip, that's DC-isolated from the rest of the antenna. In the pic, only the two screws with ring terminals are metal. The other two that tie the 2.5" strip, bakelite, and 3rd leg together are both nylon. When it comes to tuning, it seems to me that the only practical thing that mere mortals could reasonably do is trim the length of the outside leg. The pic shows a purchased Archer Comm antenna; you can see my homebrew nav behind my hand, complete with green cutting board dielectric. Will it float? Only Dave knows... Someone on the interwebs once said that the Archer antenna automagically turns the entire plane into the antenna. But that's something I read on the interwebs, so... ________________________________________________________________________________
Date: Jul 13, 2021
Search "gamma match" for more than you want to know on how Bob designed this antenna. It is DC-grounded, like many antennas. This is counter-intuitive when you are just immersing your mind into the world of radiators. "How can it work if it's short-circuited to ground!" At RF, it does a fine job of coupling energy from the feedline to free space (the "ether") which is all that matters. SWR is a concern for Rx as well as Tx because it's all about proper matching and resulting maximum power transfer from antenna to feedline or vice-versa. I can tune my "screwdriver" mobile HF antenna by listening for the sudden increase in received noise as it passes through resonance. That antenna won't radiate much at all if out of tune, but it's also deaf on the receive side if not properly tuned. SWR matters for optimum receive performance. While an out of tune antenna won't blow any finals while receiving as it can on transmit, it also won't put much signal into the receiver when you need it to, like using a VOR/ILS. An antenna analyzer is going to provide much more info than a basic VSWR meter will, but most of it will be unusable if you don't know what the values mean. An analyzer is far easier to find resonance with than an SWR meter (and you'll have to apply transmit power to the antenna to make the SWR meter read anything) - but an SWR meter and transmit power source are all the test equip you need for what you're trying to accomplish. Borrow a nano-vector network analyzer if you can, or drop $60 on one. -Bill On Tue, Jul 13, 2021 at 9:55 AM Charlie England wrote: > > > On Mon, Jul 12, 2021 at 6:28 PM Jeff Luckey wrote: > >> BobN, CharlieE, & RF Gurus et al, >> >> >> I'm considering Bob Archer's wingtip VOR antenna for my RV-7 but I am too >> ignorant to understand how the thing works. >> >> I have read posts all over the intrawebs and have some questions: >> (Please use small words and talk slowly): >> >> 1. It looks to me like the 'front/leading edge' 60 deg leg is bolted
May 13, 2021 - July 13, 2021
AeroElectric-Archive.digest.vol-qd
