AeroElectric-Archive.digest.vol-rp
December 23, 2023 - March 26, 2024
      On Thu, Dec 21, 2023 at 6:10=AFPM Dave Saylor
       wrote:
      > Thanks Joe. The door switches are good, still looking.
      > On Thu, Dec 21, 2023 at 13:21 user9253  wrote:
      >> I had the same problem with my microwave.  The problem was the door
      >> switch.  Evidently the microwave was designed so that if it operates wit
      h
      >> the
      >> door not fully latched, then it will short out the power supply.  How
      >> dare them
      >> design something that blows the house circuit breaker which could cause
      >> the
      >> refrigerator to quit and spoil food.  I bypassed that switch.  The
      >> microwave
      >> has been working fine for years since.
      >> Joe Gores
      >> http://forums.matronics.com/viewtopic.php?p=512829#512829
Date: Dec 23, 2023
Subject: Re: Fusible links
Only thought is that the normal 'spread' is 4; not 6. 22 for 18, 20 for 16, etc. OTOH, testing might show that if using a really short link, using a wider spread might be helpful, because the shorter length is going to reduce system heating. Virus-free.www.avast.com <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> On Sat, Dec 23, 2023 at 10:30=AFAM Christopher Cee Stone wrote: > The Delphi spec does not indicate length. Really is' material properties > not performance characteristics. > > I will do a couple of tests with varying "link" lengths using a fully > charged 12v, group 24, new lead acid battery. (I happen to have a new one > in the shop) > > Unfortunately I don't have a recording scope at the moment... so this wil l > have to be an empirical test. That is, what is the failure mode, not tim e > to 'link' open. > > Test specimens: 24 awg tefzel wire 'links', connected to 18 awg feeder > using PIDG butt splices, fibreglass sleeve. > > 'link' lengths in inches: 2,3,6,12 > > Comments/suggestions are welcomed! > > I will post results in the coming days. > > ...chris > > > On Sat, Dec 23, 2023 at 8:02=AFAM Robert L. Nuckolls, III < > nuckolls.bob(at)aeroelectric.com> wrote: > >> At 09:31 AM 12/23/2023, you wrote: >> >> Back to the original question of the length of a fusible link. That is >> the length of smaller gauge wire comprising=C3=82 the 'link'. >> >> >> >> Had to do some 'digging' to see if I could >> find where that 3-6 inch citation came from. >> No joy. >> >> Actually, 6" is the minimum. 9" is more typical, >> 10" not unheard of. 3" is too short . . . >> >> . . . and INSULATED with material resistant to >> energy released by clearing the fault. >> >> See: http://tinyurl.com/4vnzdjpc >> >> >> >> >> Bob . . . >> >> //// >> (o o) >> ===========o00o=(_)=o00o====== == >> < Go ahead, make my day . . . > >> < show me where I'm wrong. > >> ======================= ========= >> >> In the interest of creative evolution >> of the-best-we-know-how-to-do based >> on physics and good practice. >> > ________________________________________________________________________________
Date: Dec 23, 2023
At 10:27 AM 12/23/2023, you wrote: >The Delphi spec does not indicate >length.=C2 Really=C2 is' material properties not performance characteristics. There were TWO data points in that link . . . One was a listing of manufactured links specific to certain automotive applications: https://tinyurl.com/yrgvc2er Here we see lengths quoted from 8" to 10.5" I've read other sources citing similar lengths. Too short compromises the fusing dynamic of which material properties a part of the formula. >I will do a couple of tests with varying "link" >lengths using a fully charged 12v, group 24, new >lead acid battery. (I happen to have a new one in the shop) >Unfortunately I don't have a recording scope at >the moment... so this will have to be an >empirical=C2 test.=C2 That is, what is the failure mode, not time to 'link' open. > >Test specimens: 24 awg tefzel wire 'links', >connected to 18 awg feeder using PIDG butt splices,=C2 fibreglass sleeve. > >'link' lengths=C2 in inches: 2,3,6,12 24AWG links are atypical of the devices in common use. That combination of fiberglas over 24AWG was crafted in our shops about 30 years ago as an alternative to cartridge fuses in the leads between an b-lead shunt and a panel-ammeter. I have no doubt that you will successfully 'fuse' 2" lengths of 24AWG . . . 100+ amps of battery current pretty well predicts the outcome. When I'm considering a 'bus extension' in crafting an architecture, the decision considers mechanical robustness and ease of reliable assembly. For example, extending the bus out to a 5A crowbar breaker might call for 20AWG fusible link driving a 16AWG extension. These are system segments NOT part of the post crash fire safety considerations that call for relatively small, FAST protection on always hot circuits. 7A fuses work good in crash post crash fire concerns. Hence my design decision would lean toward easily acquired, manufactured link material that behaves well in PIDG crimps . . . there is no practical motivation to consider 'amperage' values for the links. But having offered that, I'm interested in results of your experiments. You can roughly control the magnitude of fault current by how much 20AWG wire is in series with your link. I'd shoot for something on the order of 100A. 20AWG is 10mOHMs/foot. Your battery will present a series impedance on the order of 10 mOhm. So 5 feet of wire in the remainders of the test loop would be about right. Bob . . . //// (o o) ===========o00o=(_)=o00o======= = < Go ahead, make my day . . . > < show me where I'm wrong. > ======================== ======== In the interest of creative evolution of the-best-we-know-how-to-do based on physics and good practice. ________________________________________________________________________________
From: Christopher Cee Stone <rv8iator(at)gmail.com>
Date: Dec 23, 2023
...appreciate your discussion and input! This discussion is the result of the addition of two E-mags to the current RV project and reviewing the Emag installation instruction. They call for a circuit breaker in series with the power feeder for the E-mag(s). I am using Z-13/8 as a reference guide for this build. I am considering a fusible link instead of a circuit breaker as I am running out of panel space. Thus my concern for both reliability and safety. ...chris On Sat, Dec 23, 2023 at 9:26=AFAM Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 10:27 AM 12/23/2023, you wrote: > > The Delphi spec does not indicate length.=C3=82 Really=C3=82 is' materia l > properties not performance characteristics. > > > There were TWO data points in that link . . . > > One was a listing of manufactured links specific to > certain automotive applications: > > * https://tinyurl.com/yrgvc2er * > > Here we see lengths quoted from 8" to 10.5" > I've read other sources citing similar > lengths. Too short compromises the fusing > dynamic of which material properties a > part of the formula. > > > I will do a couple of tests with varying "link" lengths using a fully > charged 12v, group 24, new lead acid battery. (I happen to have a new one > in the shop) > Unfortunately I don't have a recording scope at the moment... so this wil l > have to be an empirical=C3=82 test.=C3=82 That is, what is the failure m ode, not > time to 'link' open. > > Test specimens: 24 awg tefzel wire 'links', connected to 18 awg feeder > using PIDG butt splices,=C3=82 fibreglass sleeve. > > 'link' lengths=C3=82 in inches: 2,3,6,12 > > > 24AWG links are atypical of the devices in > common use. That combination of fiberglas over > 24AWG was crafted in our shops about 30 years > ago as an alternative to cartridge fuses in the > leads between an b-lead shunt and a panel-ammeter. > > I have no doubt that you will successfully 'fuse' > 2" lengths of 24AWG . . . 100+ amps of battery > current pretty well predicts the outcome. > > When I'm considering a 'bus extension' in > crafting an architecture, the decision considers > mechanical robustness and ease of reliable assembly. > For example, extending the bus out to a 5A crowbar > breaker might call for 20AWG fusible link driving > a 16AWG extension. > > These are system segments NOT part of the > post crash fire safety considerations that call > for relatively small, FAST protection on always > hot circuits. 7A fuses work good in crash post > crash fire concerns. > > Hence my design decision would lean toward easily > acquired, manufactured link material that behaves > well in PIDG crimps . . . there is no practical > motivation to consider 'amperage' values for > the links. > > But having offered that, I'm interested in results > of your experiments. You can roughly control > the magnitude of fault current by how much 20AWG > wire is in series with your link. I'd shoot for > something on the order of 100A. 20AWG is 10mOHMs/foot. > Your battery will present a series impedance on the order > of 10 mOhm. So 5 feet of wire in the remainders of > the test loop would be about right. > > > Bob . . . > > //// > (o o) > ===========o00o=(_)=o00o====== == > < Go ahead, make my day . . . > > < show me where I'm wrong. > > ======================= ========= > > In the interest of creative evolution > of the-best-we-know-how-to-do based > on physics and good practice. > ________________________________________________________________________________
Subject: Re: Plane Power alternator $$$$
Date: Dec 24, 2023
Thanks Bob, Well, I did note several .1 volt fluctuations as displayed on the Dynon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=512943#512943 ________________________________________________________________________________
From: "Gerry van Dyk" <gerry.vandyk(at)eastlink.ca>
Subject: Beginnings of my Tailwind Electrical System
Date: Dec 26, 2023
Hello all I'm deep in thought working on the power distribution for my Tailwind Project. I'm working towards a Z13/8 implementation, the Z101 extras don't hold much appeal or utility for me. I hope some of you learned gents could give my proposed system a quick look. It's pretty basic so far. I'm not ready to offer my basic bus power distribution drawing or load analysis just yet. But I'd like to ask a question or two as I'm wrapping my head around all the issues. I note on all the Z drawings the wire from the battery contactor to the main bus is not fused. Is this similar to the starter cables, in that it's a fat wire that is unlikely to be compromised? On the Z13/8 drawing I see a double pole single throw switch is used to bring up the main alternator (Plane Power AS 12-E160 in my case) and the battery contactor / main bus. I'm considering using another DPST switch to bring up the SD-8 and the alt E-bus feed. Is there any condition where I would want one or the other of those to be switched off? My current thought is to run the ignition start power for the pair of P-Mags from the endurance bus. To start the engine I'd turn on the endurance bus, the low voltage warning should come up as the battery will be at rest. After starting the engine, the EFIS ammeter should show the SD-8 supplying power. Bringing up the main bus I'd then switch off the alt E-bus feed / SD-8 to run on the main alternator. That should satisfy preflight testing of the backup systems would it not? I'd appreciate any insights that I'm sure I'm missing so far. I've attached a basic sketch of my proposed bus power distrubution drawing, and load analysis. If any of you have thoughts or questions please offer them. With any changes we find we need, I'll then get stuck in with a more complete power distrubution drawing. Thanks for any help you all can provide. Gerry van Dyk Tailwind W10 C-GVDZ ________________________________________________________________________________
Date: Dec 27, 2023
Subject: Re: Beginnings of my Tailwind Electrical System
Hi Gerry, I just finished my Tailwind this year.=C2- =C2-I went with a simple Z-1 1 approach. The main feed from the battery contactor should be routed carefully to prev ent compromise.=C2- If you smell smoke the first thing to do is turn of t he master.=C2- That is what ultimately protects that line.I put my single P-mag on the main bus.=C2- I don't know how you are wiring your starter but it is typically powered off of the main which is where you want your P- mag power to come from.=C2- To start I turn on the master with the e-bus off. After the engine starts I turn on the avionics master and e-bus ( which is actually avionics alternate feed).=C2- The engine gauges (EIS) are powere d off of the main bus so that I can check them before engine start.Just som e thoughts.=C2-=C2- -Mike vandyk(at)eastlink.ca> wrote: Hello allI'm deep in thought working on the power distribution for my Tail wind Project.=C2- I'm working towards a Z13/8 implementation, the Z101 ex tras don't hold much appeal or utility for me.=C2- I hope some of you lea rned gents could give my proposed system a quick look.=C2- It's pretty ba sic so far. I'm not ready to offer my basic bus power distribution drawing or load anal ysis just yet.=C2- But I'd like to ask a question or two as I'm wrapping my head around all the issues. I note on all the Z drawings the wire from the battery contactor to the mai n bus is not fused.=C2- Is this similar to the starter cables, in that it 's a fat wire that is unlikely to be compromised? On the Z13/8 drawing I see a double pole single throw switch is used to bri ng up the main alternator (Plane Power AS 12-E160 in my case) and the batte ry contactor / main bus.=C2- I'm considering using another DPST switch to bring up the SD-8 and the alt E-bus feed.=C2- Is there any condition whe re I would want one or the other of those to be switched off? My current thought is to run the ignition start power for the pair of P-Mag s from the endurance bus.=C2- To start the engine I'd turn on the enduran ce bus, the low voltage warning should come up as the battery will be at re st.=C2- After starting the engine, the EFIS ammeter should show the SD-8 supplying power.=C2- Bringing up the main bus I'd then switch off the alt E-bus feed / SD-8 to run on the main alternator.=C2- That should satisfy preflight testing of the backup systems would it not? I'd appreciate any insights that I'm sure I'm missing so far.=C2- I've at tached a basic sketch of my proposed bus power distrubution drawing, and lo ad analysis.=C2- If any of you have thoughts or questions please offer th em.=C2- With any changes we find we need, I'll then get stuck in with a m ore complete power distrubution drawing. Thanks for any help you all can provide. Gerry van DykTailwind W10 C-GVDZ ________________________________________________________________________________
Date: Dec 26, 2023
'Current thought'. I like it. ;-) The master contactor provides circuit protection for the 'fat' wires (manual trip mode). Charlie Virus-free.www.avast.com <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> On Tue, Dec 26, 2023 at 4:08=AFPM Gerry van Dyk <gerry.vandyk@eastlin k.ca> wrote: > Hello all > I'm deep in thought working on the power distribution for my Tailwind > Project. I'm working towards a Z13/8 implementation, the Z101 extras don 't > hold much appeal or utility for me. I hope some of you learned gents cou ld > give my proposed system a quick look. It's pretty basic so far. > > I'm not ready to offer my basic bus power distribution drawing or load > analysis just yet. But I'd like to ask a question or two as I'm wrapping > my head around all the issues. > > I note on all the Z drawings the wire from the battery contactor to the > main bus is not fused. Is this similar to the starter cables, in that it 's > a fat wire that is unlikely to be compromised? > > On the Z13/8 drawing I see a double pole single throw switch is used to > bring up the main alternator (Plane Power AS 12-E160 in my case) and the > battery contactor / main bus. I'm considering using another DPST switch to > bring up the SD-8 and the alt E-bus feed. Is there any condition where I > would want one or the other of those to be switched off? > > My current thought is to run the ignition start power for the pair of > P-Mags from the endurance bus. To start the engine I'd turn on the > endurance bus, the low voltage warning should come up as the battery will > be at rest. After starting the engine, the EFIS ammeter should show the > SD-8 supplying power. Bringing up the main bus I'd then switch off the a lt > E-bus feed / SD-8 to run on the main alternator. That should satisfy > preflight testing of the backup systems would it not? > > I'd appreciate any insights that I'm sure I'm missing so far. I've > attached a basic sketch of my proposed bus power distrubution drawing, an d > load analysis. If any of you have thoughts or questions please offer > them. With any changes we find we need, I'll then get stuck in with a mo re > complete power distrubution drawing. > > Thanks for any help you all can provide. > > Gerry van Dyk > Tailwind W10 C-GVDZ > ________________________________________________________________________________
From: "Gerry Van Dyk" <gerry.vandyk(at)eastlink.ca>
Date: Dec 27, 2023
Thanks Charlie=2E Working on the full distribution drawing now=2E Gerry On 12/26/23 08=3A18 PM=2C Charlie England =3Cceengland7=40gmail=2Ecom=3E wrote=3A =3E =3E =3E =3E =27Current thought=27=2E I like it=2E =3B-) =3E =3E The master contactor provides circuit protection for the =27fat=27 w ires (manual trip mode)=2E =3E =3E =3E =3E Charlie =3E =3E =3E =3E =3E (https=3A//www=2Eavast=2Ecom/sig-email=3Futm=5Fmedium=email=26utm=5F source=link=26utm=5Fcampaign=sig-email=26utm=5Fcontent=webmail=22 iwc-bad-attr==22=22 target==221=22=3EVirus-free=2Ewww=2Eavast=2Ecom( https=3A//www=2Eavast=2Ecom/sig-email=3Futm=5Fmedium=email=26utm=5Fsou rce=link=26utm=5Fcampaign=sig-email=26utm=5Fcontent=webmail ) =3E =3E (=23DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2 ) =3E =3E =3E =3E On Tue=2C Dec 26=2C 2023 at 4=3A08=AFPM Gerry van Dyk =3Cgerry =2Evandyk=40eastlink=2Eca(javascript=3Amain=2Ecompose( )=3E wrote=3A =3E =3E =3E =3E =3E =3E =3E Hello all =3E =3E =3E =3E I=27m deep in thought working on the power distribution for my T ailwind Project=2E I=27m working towards a Z13/8 implementation=2C the Z 101 extras don=27t hold much appeal or utility for me=2E I hope some of you learned gents could give my proposed system a quick look=2E It=27s p retty basic so far=2E =3E =3E =3E =3E I=27m not ready to offer my basic bus power distribution drawing or load analysis just yet=2E But I=27d like to ask a question or two as I=27m wrapping my head around all the issues=2E =3E =3E =3E =3E I note on all the Z drawings the wire from the battery contactor to the main bus is not fused=2E Is this similar to the starter cables=2C in that it=27s a fat wire that is unlikely to be compromised=3F =3E =3E =3E =3E On the Z13/8 drawing I see a double pole single throw switch is used to bring up the main alternator (Plane Power AS 12-E160 in my case) and the battery contactor / main bus=2E I=27m considering using another DPST switch to bring up the SD-8 and the alt E-bus feed=2E Is there any condition where I would want one or the other of those to be switched o ff=3F =3E =3E =3E =3E My current thought is to run the ignition start power for the pa ir of P-Mags from the endurance bus=2E To start the engine I=27d turn on the endurance bus=2C the low voltage warning should come up as the batt ery will be at rest=2E After starting the engine=2C the EFIS ammeter sho uld show the SD-8 supplying power=2E Bringing up the main bus I=27d then switch off the alt E-bus feed / SD-8 to run on the main alternator=2E T hat should satisfy preflight testing of the backup systems would it not=3F =3E =3E =3E =3E I=27d appreciate any insights that I=27m sure I=27m missing so f ar=2E I=27ve attached a basic sketch of my proposed bus power distrubuti on drawing=2C and load analysis=2E If any of you have thoughts or questi ons please offer them=2E With any changes we find we need=2C I=27ll then get stuck in with a more complete power distrubution drawing=2E =3E =3E =3E =3E Thanks for any help you all can provide=2E =3E =3E =3E =3E Gerry van Dyk =3E =3E Tailwind W10 C-GVDZ =3E =3E =3E =3E =3E =3E =3E ________________________________________________________________________________
Date: Dec 27, 2023
At 09:59 AM 12/24/2023, you wrote: > >Thanks Bob, >Well, I did note several .1 volt fluctuations as displayed on the Dynon the significance of this observation is not a 'given'. Digital displays may exhibit some 'jumpiness' in the least significant digits in spite of a rock solid stimulus. This characteristic is the result of response times, a/d converter performance and environment for which the instrument is intended. Laboratory grade instruments are not expected to be fast while stability is valued. Field instruments tend to be faster . . . but more jitter. A 0.1V fluctuation COULD be a driver for the current fluctuations you observed . . . depends on a number of system variables most important of which is battery internal resistance. But if none of the illumination in the cabin fluctuates in sympathy with the current readings, I tend to think that the readings are an artifact of measurement technology. I've got a constellation of tools suited for ferreting out root cause of your concerns. Yeah, the 'numbers' are intellectually irritating but you've not described any indication that something needs fixing. I've oft suggested that ammeters are a tiny step above useless in the operation of your airplane. All loads are known and critical components your management of energy in the design phase. After that, airborne operation of the electrical system should require no analysis/diagnosis/decisions based on any condition other than LO VOLTS. From there, it's implementation of a proven change of configuration . . . Plan-A, Plan-B, perhaps a Plan-C. Bob . . . //// (o o) ===========o00o=(_)=o00o======= = < Go ahead, make my day . . . > < show me where I'm wrong. > ======================== ======== In the interest of creative evolution of the-best-we-know-how-to-do based on physics and good practice. ________________________________________________________________________________
Date: Dec 26, 2023
At 12:05 PM 12/23/2023, you wrote: >...appreciate your discussion and input!=C2 =C2 > >This discussion is the result of the addition of >two E-mags to the current RV project and >reviewing the Emag installation instruction. >They call for a circuit breaker in series with >the power feeder for the E-mag(s).=C2 I am using >Z-13/8 as a reference guide for this build.=C2 I >am considering a fusible link instead of a >circuit breaker as I am running out of panel >space.=C2 Thus my concern for both reliability and safety. Aha! That's a whole different problem. If I'm reading ElectroAir literature correctly, that input of bus voltage to the EMag is a CONTROL signal for the purpose of disabling the mag during engine run-up and/or engine shut down. Input current to that port is TINY . . . about 0.04 Amps. That feeder is an excellent candidate "source impedance fault limiting". Limiting a fault current to feeder friendly levels: just splice a 22 ohm, 1-watt resistor into the same spot you might use a fusible-link. Cover with heat shrink. A short on that feeder would be limited to 600 mA or less. Voltage drop would be 0.9 volts or less . . . no effect on functionality. It's been a common technique in my toolbox in a constellation of designs for decades. Bob . . . //// (o o) ===========o00o=(_)=o00o======= = < Go ahead, make my day . . . > < show me where I'm wrong. > ======================== ======== In the interest of creative evolution of the-best-we-know-how-to-do based on physics and good practice. ________________________________________________________________________________
Date: Dec 27, 2023
I think we're talking about not a control signal but power for the electron ic ignition. This is for engine start and in case of failure of the alterna tor internal to the emagair unit. The way I read the emagair install manuals: Four cylinder: Manual-114-L_C4-V33.pdf Six cylinder: Manual-P200-6XLycoming-V41-1.pdf Bus power ' terminal #5 for four cylinder, pin A for six cylinder, 12, 24 , or 48-volt systems a) Minimum - 10 volts b) Maximum - 58 volts c) Current draw from bus: i) less than 0.5 amp (normal operating conditions) ii) less than 1.0 amp (maximum draw with no-op internal alternator) ________________________________ From: owner-aeroelectric-list-server(at)matronics.com <owner-aeroelectric-list -server(at)matronics.com> on behalf of Robert L. Nuckolls, III Sent: Tuesday, December 26, 2023 14:19 Subject: Re: AeroElectric-List: Re: Fusible links At 12:05 PM 12/23/2023, you wrote: ...appreciate your discussion and input!=C2 =C2 This discussion is the result of the addition of two E-mags to the current RV project and reviewing the Emag installation instruction. They call for a circuit breaker in series with the power feeder for the E-mag(s).=C2 I am using Z-13/8 as a reference guide for this build.=C2 I am considering a f usible link instead of a circuit breaker as I am running out of panel space .=C2 Thus my concern for both reliability and safety. Aha! That's a whole different problem. If I'm reading ElectroAir literature correctly, that input of bus voltage to the EMag is a CONTROL signal for the purpose of disabling the mag during engine run-up and/or engine shut down. Input current to that port is TINY . . . about 0.04 Amps. That feeder is an excellent candidate "source impedance fault limiting". Limiting a fault current to feeder friendly levels: just splice a 22 ohm, 1-watt resistor into the same spot you might use a fusible-link. Cover with heat shrink. A short on that feeder would be limited to 600 mA or less. Voltage drop would be 0.9 volts or less . . . no effect on functionality. It's been a common technique in my toolbox in a constellation of designs for decades. Bob . . . //// (o o) ===========o00o=(_)=o00o======= = < Go ahead, make my day . . . > < show me where I'm wrong. > ======================== ======== In the interest of creative evolution of the-best-we-know-how-to-do based on physics and good practice. ________________________________________________________________________________
Date: Dec 27, 2023
Bob, et al... Aha! That's a whole different problem. If I'm reading ElectroAir literature correctly, that input of bus (SNIP) A short on that feeder would be limited to 600 mA or less. Voltage drop would be 0.9 volts or less . . . no effect on functionality. It's been a common technique in my toolbox in a constellation of designs for decades. I too have been going through the Emagair document. I have very limited panel space left for ignition management as the ACS key switch is already installed, Per Emagair, there is a 5A CB for each EI. I am contemplating powering from the main bus (through a 22 ohm resistor). For simplicity, a common feeder for both EI's then to a SPDT switch (Disable power to both EI's) then two NC push button switches for independent preflight check. No 5A CB's. As I had assigned one fuse slot to the original plan of one EI/one mag, I will use it with a 10A fuse. Running the EI's from the main buss assures they are disabled with the Master Switch. What am I missing? I did some fusible link testing that I will publish soon, that was to be the circuit protection for the EI's. I like the 22 ohm solution better. ...chris On Wed, Dec 27, 2023 at 10:07=AFAM Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 12:05 PM 12/23/2023, you wrote: > > ...appreciate your discussion and input!=C3=82 =C3=82 > > This discussion is the result of the addition of two E-mags to the curren t > RV project and reviewing the Emag installation instruction. They call for a > circuit breaker in series with the power feeder for the E-mag(s).=C3=82 I am > using Z-13/8 as a reference guide for this build.=C3=82 I am considering a > fusible link instead of a circuit breaker as I am running out of panel > space.=C3=82 Thus my concern for both reliability and safety. > > > Aha! That's a whole different problem. If I'm reading > ElectroAir literature correctly, that input of bus > voltage to the EMag is a CONTROL signal for the > purpose of disabling the mag during engine run-up > and/or engine shut down. Input current to that > port is TINY . . . about 0.04 Amps. That feeder > is an excellent candidate "source impedance > fault limiting". > > Limiting a fault current to feeder friendly > levels: just splice a 22 ohm, 1-watt resistor > into the same spot you might use a fusible-link. > Cover with heat shrink. > > A short on that feeder would be limited to > 600 mA or less. Voltage drop would be 0.9 volts > or less . . . no effect on functionality. > > It's been a common technique in my toolbox > in a constellation of designs for decades. > > > Bob . . . > > //// > (o o) > ===========o00o=(_)=o00o====== == > < Go ahead, make my day . . . > > < show me where I'm wrong. > > ======================= ========= > > In the interest of creative evolution > of the-best-we-know-how-to-do based > on physics and good practice. > ________________________________________________________________________________
Date: Dec 27, 2023
On Wed, Dec 27, 2023 at 12:44=AFPM Christopher Cee Stone wrote: > Bob, et al... > > Aha! That's a whole different problem. If I'm reading > ElectroAir literature correctly, that input of bus > (SNIP) > > A short on that feeder would be limited to > 600 mA or less. Voltage drop would be 0.9 volts > or less . . . no effect on functionality. > > It's been a common technique in my toolbox > in a constellation of designs for decades. > > > I too have been going through the Emagair document. > I have very limited panel space left for ignition management as the ACS > key switch is already installed, Per Emagair, there is a 5A CB for each E I. > I am contemplating powering from the main bus (through a 22 ohm > resistor). For simplicity, a common feeder for both EI's then to a SPDT > switch (Disable power to both EI's) then two NC push button switches for > independent preflight check. No 5A CB's. > As I had assigned one fuse slot to the original plan of one EI/one mag, I > will use it with a 10A fuse. Running the EI's from the main buss assures > they are disabled with the Master Switch. > What am I missing? > > I did some fusible link testing that I will publish soon, that was to be > the circuit protection for the EI's. I like the 22 ohm solution better. > > ...chris > There might be some confusion about Emag power vs control lines. A resistor in the power feeder probably isn't a great idea. The fact that Emags 'self power' when the engine is running above a certain rpm kinda 'muddies the water', but... In general, the reason you (and they) want engine electrons to come directly from the battery is so the system operates like a traditional a/c, where shutting off the master has no effect on the engine. Also in general, it's a bad idea to create 'single points of failure' in a system. A single fuse for both ignitions means that any fault in either system *or* a fault in the supply circuit takes out both ignitions. As I said, the 'self power' feature does muddy the water a bit on that, but still a bad habit to get into. (Have I mentioned lately how much I despise the moron that came up with the idea of 'top posting' back in the last century, resulting in random order reading? Makes watching 'Memento' seem like a simple, transparent process.) Charlie > > On Wed, Dec 27, 2023 at 10:07=AFAM Robert L. Nuckolls, III < > nuckolls.bob(at)aeroelectric.com> wrote: > >> At 12:05 PM 12/23/2023, you wrote: >> >> ...appreciate your discussion and input!=C3=82 =C3=82 >> >> This discussion is the result of the addition of two E-mags to the >> current RV project and reviewing the Emag installation instruction. They >> call for a circuit breaker in series with the power feeder for the >> E-mag(s).=C3=82 I am using Z-13/8 as a reference guide for this build. =C3=82 I am >> considering a fusible link instead of a circuit breaker as I am running out >> of panel space.=C3=82 Thus my concern for both reliability and safety. >> >> >> Aha! That's a whole different problem. If I'm reading >> ElectroAir literature correctly, that input of bus >> voltage to the EMag is a CONTROL signal for the >> purpose of disabling the mag during engine run-up >> and/or engine shut down. Input current to that >> port is TINY . . . about 0.04 Amps. That feeder >> is an excellent candidate "source impedance >> fault limiting". >> >> Limiting a fault current to feeder friendly >> levels: just splice a 22 ohm, 1-watt resistor >> into the same spot you might use a fusible-link. >> Cover with heat shrink. >> >> A short on that feeder would be limited to >> 600 mA or less. Voltage drop would be 0.9 volts >> or less . . . no effect on functionality. >> >> It's been a common technique in my toolbox >> in a constellation of designs for decades. >> >> >> >> >> Bob . . . >> >> //// >> (o o) >> ===========o00o=(_)=o00o====== == >> < Go ahead, make my day . . . > >> < show me where I'm wrong. > >> ======================= ========= >> >> In the interest of creative evolution >> of the-best-we-know-how-to-do based >> on physics and good practice. >> > ________________________________________________________________________________
Date: Dec 27, 2023
Subject: Fusible link test results
My very basic test rig with somewhat empirical results- no measured data. Objective: observe failure of fusible links of various lengths when subjected to a high current short circuit event. 12V wet cell, new, fully charged battery Knife switch 18 ga tefzel feeder, 20" length x2 PIDG style butt splices (red) Camera DUT: 2", 6", 13" lengths 24 ga tefzel FL (M22759/16) Procedure: Fabricate fusible links of 2, 6 an 13 inch lengths Crimp w/ AMP PIDG crimper to Feeder 20" 18 ga tefzel Clamp feeders to B+ Knife switch and B- battery terminal Start camera video Rabidly close switch Two inch FL setup [image: 2InchSetup.jpg] Crimp tool and butt splice [image: AmpCrimpTool.jpg] results: http://tinyurl.com/mryadbfx No fiberglas sleeve was used so that failure could be observed. Comments, questions, critique! ...chris ________________________________________________________________________________
Date: Dec 28, 2023
I ordered a new battery. I figured its time to replace it anyway and maybe if battery internal resistance is the cause of the fluctuations Im seeing, that will clear it up. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=512965#512965 ________________________________________________________________________________
Date: Dec 28, 2023
Subject: Re: Filling All the Holes in a DB Connector
Closing the loop... I spoke w/ Garmin Tech Support and the guy who teaches the Experimental Wir ing class at the Aircraft Electronics Assn and I stand corrected.=C2- Som ehow, I got it in my head that you should populate all the pins in a DB con nector, even if there is no wire attached to it.=C2- Don't know where I g ot this but it is INCORRECT. - I was mistaken (not the first time;) I don't think that there is anything wrong with doing this, but it is not a recommended procedure (as I had originally thought). It is interesting to note however, that pre-wired harnesses from Spruce com e with all the pins populated (even the ones without a wire attached).=C2 - This is probably so that you can customize the pre-fabbed harness and a dd wires specific to your installation.=C2- But it would seem better if S pruce just populated the ones required for their harness and sent you a bag of spare pins.=C2- I wonder how many people bother to remove the un-used pins? Happy New Year! -Jeff .whiting(at)frontier.com> wrote: Where does Garmin recommend that? =C2-I don=99t recall seeing that in the G3X installation manual. =C2-I=99ve been an EE for nearly 4 0 years and don=99t recall this being a common practice. =C2-Most w eather resistant connectors have plugs available specifically for the holes in the connectors that aren=99t loaded. Matt Sent from my iPad On Nov 21, 2023, at 4:46=AFPM, Jeff Luckey wrot e: =EF=BBListers, Question about DB/D-Sub connectors eg: DB9, DB25, DB37, etc. Garmin recommends, and it seems to be common practice, that all holes in a given DB connector have a pin/socket installed, even when there is no wire connected to that pin.=C2-=C2- Why is that? -Jeff =C2- ________________________________________________________________________________
Date: Dec 28, 2023
Alternator fluctuations.... By any chance do you have flashing strobes or something like that type of load..? That will make your amp meter flicker.... On Thu, Dec 28, 2023 at 5:43=AFAM Coastflyer wrote: > jessejenks72(at)gmail.com> > > I ordered a new battery. I figured it=99s time to replace it anyway and > maybe if battery internal resistance is the cause of the fluctuations I =99m > seeing, that will clear it up. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=512965#512965 > > =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Subject: Tailwind Electrical System Drawing and Power Analysis
Date: Dec 28, 2023
Hello again all Well, I think I'm ready for a good critique on my proposed electrical system for my Tailwind project. For the most part it's based on Z13/8, we're using a Plane Power AL12-E160 primary alternator, and of course the B&C SD-8 backup alternator. The E160 is internally regulated, and also has an internal crowbar system and alt-out panel light output, which I intend to use. The SD-8 has their older PMR1 regulator, so we've got the external crowbar module and no voltage sensing. I've drawn these items as shown on their respective install instructions call for. As I mentioned earlier, I intended to start the engine on the endurance bus, and check the SD-8 operation during the startup procedure. I had neglected to think about where the starter was going to get power from, so the idea has forced an additional switch and relay (a rather robust one at that) to run the main bus. The battery contactor would be closed for startup, then the SD-8 operation checked and finally the main bus would be brought up to begin normal operation. I'm a little uneasy about this extra switching, as I know this group is inclined toward fewer failure points, and with good reason. As I look at the 'textbook' Z13/8 drawing, with my dual EFIS, IFR capable panel in mind, it seems to me that a startup would bring the entire panel up with the main bus, then with the engine running I'd have to close the E-bus switch, open the battery contactor, dropping out half the instrument panel. Then check the backup alternator operation, and finally reboot the rest of the panel again. It just really feels rather clunky to me. Bob, have I missed something with the original architecture concept? Is there a way to check the backup alternator function while the main bus is up and running? It would certainly help me simplify my system. I'd appreciate if you good folks would give my drawing a good review. Questions, comments and critiques are all welcome. Thanks again Gerry van Dyk Tailwind C-GVDZ ________________________________________________________________________________
Date: Dec 28, 2023
At 07:40 AM 12/28/2023, you wrote: > >I ordered a new battery. I figured it=99s time >to replace it anyway and maybe if battery >internal resistance is the cause of the >fluctuations I=99m seeing, that will clear it up. I'm sorry . . . the battery condition that promotes hyper-active ammeter indications is LOW internal resistance characteristic of a battery in excellent condition. If this is indeed root cause of your observed condition, a new battery will only make it worse. That's only one of the possible causes. As I mentioned in the former post, I your airplane were in my shop, I have the equipment necessary to deduce the root cause but it's a pretty detailed investigation. I was pretty wordy in that missive. Short answer: I don't think there are any operational concerns that arise from your observations. Bob . . . //// (o o) ===========o00o=(_)=o00o======= = < Go ahead, make my day . . . > < show me where I'm wrong. > ======================== ======== In the interest of creative evolution of the-best-we-know-how-to-do based on physics and good practice. ________________________________________________________________________________
Date: Dec 29, 2023
Why do you want to switch the SD-8 alternator? Why switch battery power to the bus twice? Use an externally regulated main alternator to avoid having to switch the alternator output. Provide a method to connect the battery directly to the bus. Do not use a diode in the feed to the essential bus. There are a number of services connected directly to the battery just waiting to flatten it If the voltage of the SD8 is set (say) 0.2v lower than the main alternator it will not produce power if the main is on line. If the main fails it takes up the load. For my liking you have too many relays between the battery and the bus bar. If you use an externally regulated main alternator then initially only switch on the SD8 on start up. Then power up the main alternator regulator and bring that on line. Install a switch that powers up the essential (or main) bus directly from the battery, if the switch is a double pole use the second pole to disable the starter. The large diode in the feed line to the essential bus will always drop the voltage by an amount. The benefit is auto load shedding but do you need that with 2 alternators? If you really want to shed the main bus use a large switch and ensure there is a path to the essential bus directly from the battery. I used to have a feed diode and would not use one again. A diode is very beneficial on the starter contactor. Having a low voltage waring that is independent of the EFIS is useful. It is possible you will get immune to EFIS warnings Peter From: owner-aeroelectric-list-server(at)matronics.com On Behalf Of Gerry van Dyk Sent: Thursday, December 28, 2023 11:32 PM Subject: AeroElectric-List: Tailwind Electrical System Drawing and Power Analysis Hello again all Well, I think I'm ready for a good critique on my proposed electrical system for my Tailwind project. For the most part it's based on Z13/8, we're using a Plane Power AL12-E160 primary alternator, and of course the B&C SD-8 backup alternator. The E160 is internally regulated, and also has an internal crowbar system and alt-out panel light output, which I intend to use. The SD-8 has their older PMR1 regulator, so we've got the external crowbar module and no voltage sensing. I've drawn these items as shown on their respective install instructions call for. As I mentioned earlier, I intended to start the engine on the endurance bus, and check the SD-8 operation during the startup procedure. I had neglected to think about where the starter was going to get power from, so the idea has forced an additional switch and relay (a rather robust one at that) to run the main bus. The battery contactor would be closed for startup, then the SD-8 operation checked and finally the main bus would be brought up to begin normal operation. I'm a little uneasy about this extra switching, as I know this group is inclined toward fewer failure points, and with good reason. As I look at the 'textbook' Z13/8 drawing, with my dual EFIS, IFR capable panel in mind, it seems to me that a startup would bring the entire panel up with the main bus, then with the engine running I'd have to close the E-bus switch, open the battery contactor, dropping out half the instrument panel. Then check the backup alternator operation, and finally reboot the rest of the panel again. It just really feels rather clunky to me. Bob, have I missed something with the original architecture concept? Is there a way to check the backup alternator function while the main bus is up and running? It would certainly help me simplify my system. I'd appreciate if you good folks would give my drawing a good review. Questions, comments and critiques are all welcome. Thanks again Gerry van Dyk Tailwind C-GVDZ ________________________________________________________________________________
Date: Dec 29, 2023
Subject: PMag power requirements
At 09:19 PM 12/28/2023, you wrote: >Hi Bob, > >I would answer on Aeroelectric List if I could. I get the postings >by email but I can't answer due to longstanding technical issues >with the forum. My next try at a resolution will be a postal letter >to Matt Dralle. > >Re your post 19 at ><http://forums.matronics.com/viewtopic.php?t=16781981>http://forums.matronics.com/viewtopic.php?t=16781981 > >I'm writing because I believe it is incorrect that the Pmag bus >power feeder is "about 0.04A". I have no idea where you got that >number. This feeder is EI power for starting and in case of Pmag internal You are correct. Emag specs and installation sheets are not satisfyingly clear on their electrical requirements. Had to dig around in some older EMag literature to come up with the attached illustration: That 0.04A number was for bus supply loads under normal operation above 1800 rpm or so on a PMag. Obviously, should the internal alternator fail (exceedingly unlikely) demands from ship's bus will be on the order of 0.3 to 0.7A depending on rpm. NOTE: the attached figure is exemplar data captured from EMagair literature from some years back. This thread illustrates an oft ignored hazard for not having manufacturer's published data. I've not spoken with the guys for some years. I'll call them tomorrow to renew acquaintance. I'm planning on a trip to Ft. Worth in March . . . will plan on visiting them. I'll suggest some updating of their electrical performance data would be helpful. In the mean time, I'll update my suggestion to utilize a "Polyswitch" . . . a solid state, self-resetting fault limiter. https://tinyurl.com/yu2tjncu I've used these in numerous applications over the years. These are NOT a universal replacement for fuses/breakers/limiters BUT in this case I think it will fill the bill. I've added some to an order from Digikey. I want to do a bit of bench testing. I'll have some to 'donate to the cause'. Bob . . . //// (o o) ===========o00o=(_)=o00o======== < Go ahead, make my day . . . > < show me where I'm wrong. > ================================ In the interest of creative evolution of the-best-we-know-how-to-do based on physics and good practice. ________________________________________________________________________________
Analysis
Date: Dec 29, 2023
Hi Peter, thanks for your thoughts. Why do you want to switch the SD-8 alternator? because it is shown on the original Z-13/8 drawing. I'm working from rev T 1/07/14. Is there a later revision with this switch removed? Why switch battery power to the bus twice? As I mentioned, I want to start the engine on the E-bus. I need to supply power to the starter, but leave the main bus un-powered, in order to check the function of SD-8. Supplying starting power through the E-bus seems impractical. Use an externally regulated main alternator to avoid having to switch the alternator output. Yeah, I'm hamstringing myself a little bit here. I bought the AL 12-E160 alt several years ago, I don't have a spare couple thousand dollars to buy another. I'll have to think about it better, but on the face of it, having a separate regulator doesn't seem to change how the alternator is controlled. Mr. Nuckolls has mentioned on many occasions that we want to have definite control of the alternator output with a switch in the cockpit. Z12/8 shows this switch in the center of the drawing. Provide a method to connect the battery directly to the bus. (I presume your're talking about the main bus here.) Perhaps I'm being foolish here. I'm placing an absolute requirement to check the operation of the backup alternator at the beginning of every flight. My life will depend on it should the main alternator fail. With the main bus and main alternator connected directly to the battery contactor they will be running at startup. As yet I don't see a way to check the backup alternator operation with the main's running. I'd like to do so without turning half the panel on-off-on during startup. Do not use a diode in the feed to the essential bus. This diode is called for by B&C on their installation drawing 504-500, and they provide it in the kit. What would be the reason to remove it? There are a number of services connected directly to the battery just waiting to flatten it Quite right, and this duplicates what's shown on Z13-8. They are a couple of conveniences, loading the baggage compartment, charging a phone etc, without having to turn on the battery master and it's relatively large current draw. In building my panel, all switches will be down=off, and they're all in two rows so visually obvious when left on. I'll have to have a quick scan of the panel when leaving the airplane, and if I flatten the battery by mistake, my fault. If the voltage of the SD8 is set (say) 0.2v lower than the main alternator it will not produce power if the main is on line. If the main fails it takes up the load. I presume you are making another case for removing the backup alt switch. Again, it is called for on Z13/8, but your point is well taken. For my liking you have too many relays between the battery and the bus bar. I absolutely agree, I haven't yet come up with an elegant solution to check the backup alternator without cycling the avionics. If you use an externally regulated main alternator then initially only switch on the SD8 on start up. Then power up the main alternator regulator and bring that on line. I think we've covered this already. In order to start the engine I need to switch on the battery contactor, which would also bring the main bus and main alt online. I could move the starter wire to the always-hot side of the battery contactor, so the mains are still inop, but with that wire permanently hot, and 2 gauge wire at that, it violates the idea of making the electrical system as inert as possible in a forced landing. Again, I don't see the difference between an externally or internally regulated alternator. The red wire to lead 1 on the alt connector is the equivalent of the A wire on an external regulator, the jumper is the same as one to the S wire, and the F wire is internal. Peter, writing this is making me think about separating the main alt control to a separate switch. Let me think that through a bit and I'll report back later. Install a switch that powers up the essential (or main) bus directly from the battery, if the switch is a double pole use the second pole to disable the starter. Interesting, I'll think that out as well. The large diode in the feed line to the essential bus will always drop the voltage by an amount. The benefit is auto load shedding but do you need that with 2 alternators? If you really want to shed the main bus use a large switch and ensure there is a path to the essential bus directly from the battery. I used to have a feed diode and would not use one again. Yes, I believe it is necessary. 8 amps will not power the entire panel, so the load shedding is still valid. Incidentally, I discovered on the SD-8 literature that a Lycoming will need to run at 2500 rpm to get the full 8 amps out of the SD-8. it's looking like about 6.8 amps at 2300 rpm. Your suggestion will mean both main and E-bus need to be switched on for normal operations. Bob has made note on many of his drawings that "all buses are on when the main is on". I've had that in mind when drawing this up. Having the E-bus switched on for normal ops means the backup alternator is always running, though as you've suggested it can be set lower than the main, and loaf along in the background. I need to get my head around this idea. A diode is very beneficial on the starter contactor. That's a whoops, should have added it to the drawing, I'll get it on there. Having a low voltage waring that is independent of the EFIS is useful. It is possible you will get immune to EFIS warnings Yes, I do agree here. I was hoping the 'alt out light' function of the main alternator would be a 'low voltage monitor' as B&C does on their newer AVC regulator. After exchanging a couple of emails with Tim at Plane Power, it indeed only sees the output within the alternator, nothing outside. I've already got the Dynon EMS with all the engine sensors, so it makes some sense to use what I've got. My thinking is if it becomes annoying I can add the separate voltage monitoring system after the fact. Tim at PP did mention that he regularly sees OBAM guys using the EFIS for voltage monitoring, and all too often they've got parameters set way too stringent, and get many nuisance warnings. As yet I haven't investigated what parameters and settings I can work with, so the external LV warning is always on the table. Thanks very much for the thoughts Peter. It's very useful to think through the questions and comments. Cheers Gerry ------ Original Message ------ >From "Peter Pengilly" <peter(at)sportingaero.com> To aeroelectric-list(at)matronics.com Date 2023-12-29 2:11:12 AM Subject RE: AeroElectric-List: Tailwind Electrical System Drawing and Power Analysis >Why do you want to switch the SD-8 alternator? > >Why switch battery power to the bus twice? > >Use an externally regulated main alternator to avoid having to switch >the alternator output. > >Provide a method to connect the battery directly to the bus. > >Do not use a diode in the feed to the essential bus. > >There are a number of services connected directly to the battery just >waiting to flatten it > > >If the voltage of the SD8 is set (say) 0.2v lower than the main >alternator it will not produce power if the main is on line. If the >main fails it takes up the load. > >For my liking you have too many relays between the battery and the bus >bar. > >If you use an externally regulated main alternator then initially only >switch on the SD8 on start up. Then power up the main alternator >regulator and bring that on line. > >Install a switch that powers up the essential (or main) bus directly >from the battery, if the switch is a double pole use the second pole to >disable the starter. > >The large diode in the feed line to the essential bus will always drop >the voltage by an amount. The benefit is auto load shedding but do you >need that with 2 alternators? If you really want to shed the main bus >use a large switch and ensure there is a path to the essential bus >directly from the battery. I used to have a feed diode and would not >use one again. > >A diode is very beneficial on the starter contactor. > >Having a low voltage waring that is independent of the EFIS is useful. >It is possible you will get immune to EFIS warnings > > >Peter > > >From:owner-aeroelectric-list-server(at)matronics.com > On Behalf Of Gerry van >Dyk >Sent: Thursday, December 28, 2023 11:32 PM >To:aeroelectric-list(at)matronics.com >Subject: AeroElectric-List: Tailwind Electrical System Drawing and >Power Analysis > > >Hello again all > >Well, I think I'm ready for a good critique on my proposed electrical >system for my Tailwind project. For the most part it's based on Z13/8, >we're using a Plane Power AL12-E160 primary alternator, and of course >the B&C SD-8 backup alternator. The E160 is internally regulated, and >also has an internal crowbar system and alt-out panel light output, >which I intend to use. The SD-8 has their older PMR1 regulator, so >we've got the external crowbar module and no voltage sensing. I've >drawn these items as shown on their respective install instructions >call for. > > >As I mentioned earlier, I intended to start the engine on the endurance >bus, and check the SD-8 operation during the startup procedure. I had >neglected to think about where the starter was going to get power from, >so the idea has forced an additional switch and relay (a rather robust >one at that) to run the main bus. The battery contactor would be >closed for startup, then the SD-8 operation checked and finally the >main bus would be brought up to begin normal operation. > > >I'm a little uneasy about this extra switching, as I know this group is >inclined toward fewer failure points, and with good reason. As I look >at the 'textbook' Z13/8 drawing, with my dual EFIS, IFR capable panel >in mind, it seems to me that a startup would bring the entire panel up >with the main bus, then with the engine running I'd have to close the >E-bus switch, open the battery contactor, dropping out half the >instrument panel. Then check the backup alternator operation, and >finally reboot the rest of the panel again. It just really feels >rather clunky to me. > > >Bob, have I missed something with the original architecture concept? >Is there a way to check the backup alternator function while the main >bus is up and running? It would certainly help me simplify my system. > > >I'd appreciate if you good folks would give my drawing a good review. >Questions, comments and critiques are all welcome. > > >Thanks again > >Gerry van Dyk > >Tailwind C-GVDZ > ________________________________________________________________________________
Date: Dec 29, 2023
My very basic test rig with somewhat empirical results- no measured data. Objective: observe failure of fusible links of various lengths when subjected to a high current short circuit event. 12V wet cell, new, fully charged battery Knife switch 18 ga tefzel feeder, 20" length x2 PIDG style butt splices (red) Camera DUT: 2", 6", 13" lengths 24 ga tefzel FL (M22759/16) Procedure: Fabricate fusible links of 2, 6 an 13 inch lengths Crimp w/ AMP PIDG crimper to Feeder 20" 18 ga tefzel Clamp feeders to B+ Knife switch and B- battery terminal Start camera video Rabidly close switch Two inch FL setup [image: 2InchSetup.jpg] Crimp tool and butt splice [image: AmpCrimpTool.jpg] results: http://tinyurl.com/mryadbfx No fiberglas sleeve was used so that failure could be observed. Comments, questions, critique! ...chris On Sat, Dec 23, 2023 at 8:02=AFAM Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 09:31 AM 12/23/2023, you wrote: > > Back to the original question of the length of a fusible link. That is th e > length of smaller gauge wire comprising=C3=82 the 'link'. > > > Had to do some 'digging' to see if I could > find where that 3-6 inch citation came from. > No joy. > > Actually, 6" is the minimum. 9" is more typical, > 10" not unheard of. 3" is too short . . . > > . . . and INSULATED with material resistant to > energy released by clearing the fault. > > See: http://tinyurl.com/4vnzdjpc > > > Bob . . . > > //// > (o o) > ===========o00o=(_)=o00o====== == > < Go ahead, make my day . . . > > < show me where I'm wrong. > > ======================= ========= > > In the interest of creative evolution > of the-best-we-know-how-to-do based > on physics and good practice. > ________________________________________________________________________________
Date: Dec 29, 2023
Hi Chris; Hi All; That's a great demonstration Chris. And it evidences exactly why I would not use fusible links in an aircraft, or automobile for that matter. There's smoke, there's fire, and there's molten metal! With most fuses the burned wire, smoke, and fire are contained. Cheers! Stu. From: "Christopher Cee Stone" <rv8iator(at)gmail.com> Sent: Friday, December 29, 2023 7:30:01 AM Subject: Re: AeroElectric-List: Re: Fusible links My very basic test rig with somewhat empirical results- no measured data. Objective: observe failure of fusible links of various lengths when subject ed to a high current short circuit event. 12V wet cell, new, fully charged battery Knife switch 18 ga tefzel feeder, 20" length x2 PIDG style butt splices (red) Camera DUT: 2", 6", 13" lengths 24 ga tefzel FL (M22759/16) Procedure: Fabricate fusible links of 2, 6 an 13 inch lengths Crimp w/ AMP PIDG crimper to Feeder 20" 18 ga tefzel Clamp feeders to B+ Knife switch and B- battery terminal Start camera video Rabidly close switch Two inch FL setup Crimp tool and butt splice results: [ http://tinyurl.com/mryadbfx | http://tinyurl.com/mryadbfx ] No fiberglas sleeve was used so that failure could be observed. Comments, questions, critique! ...chris On Sat, Dec 23, 2023 at 8:02 AM Robert L. Nuckolls, III < [ mailto:nuckolls .bob(at)aeroelectric.com | nuckolls.bob(at)aeroelectric.com ] > wrote: At 09:31 AM 12/23/2023, you wrote: BQ_BEGIN Back to the original question of the length of a fusible link. That is the length of smaller gauge wire comprising=C3=82 the 'link'. Had to do some 'digging' to see if I could find where that 3-6 inch citation came from. No joy. Actually, 6" is the minimum. 9" is more typical, 10" not unheard of. 3" is too short . . . . . . and INSULATED with material resistant to energy released by clearing the fault. See: [ http://tinyurl.com/4vnzdjpc | http://tinyurl.com/4vnzdjpc ] Bob . . . //// (o o) ===========o00o=(_)=o00o======== = < Go ahead, make my day . . . > < show me where I'm wrong. > ======== In the interest of creative evolution of the-best-we-know-how-to-do based on physics and good practice. BQ_END ________________________________________________________________________________
Date: Dec 29, 2023
Thats ok Bob, I wanted to replace the battery anyway. I do appreciate your analysis. I took some video yesterday, still with the old battery. https://youtu.be/1TluvrVBLJo?si=IkUwgLP910Cht7Kt Read this topic online here: http://forums.matronics.com/viewtopic.php?p=512976#512976 ________________________________________________________________________________
Date: Dec 29, 2023
At 11:44 AM 12/29/2023, you wrote: > >That=99s ok Bob, I wanted to replace the battery >anyway. I do appreciate your analysis. >I took some video yesterday, still with the old battery. > >https://youtu.be/1TluvrVBLJo?si=IkUwgLP910Cht7Kt That's interesting. The period of oscillation is too long to be a regulation issue especially since the voltage is not similarly afflicted. It will be interesting to see if it persists with the new battery. How old is the present battery? Have you recently cap-checked it? It's a strong suggestion of some accessory load . . . but what? This began after installation of the new alternator? Bob . . . //// (o o) ===========o00o=(_)=o00o======= = < Go ahead, make my day . . . > < show me where I'm wrong. > ======================== ======== In the interest of creative evolution of the-best-we-know-how-to-do based on physics and good practice. ________________________________________________________________________________
Analysis
Date: Dec 29, 2023
Hello again all Peter I'll follow-up here on those couple of points... I've attached the latest revision to my architecture. Thinking about what you've suggested, separating the main alternator to it's own switch, I've done so, and it cleans up both the drawing and the electrical system quite a bit. Effectively what we've done is separate the "battery / alt / DC power" switch shown on the Z13/8 drawing into two. I've got a keyed switch which I want for some basic theft deterrence, and then the main alt switch. In operation we'll turn on the main bus, which will mean the entire panel will be up. The big consumers will of course be off, pitot heat, exterior lighting, AP servos, boost fuel pump, and the radios will be in passive receive mode. At this point we'd close the ebus / aux alt switch and start the engine. Dynon says this will not bring down the EFIS's so with the EMS operating we should see the aux alternator bump the voltage, I'd flip the switch on and off if need be to see this change. Satisfied that the aux alternator is operating we'll then bring the main alternator online and turn the e-bus / aux alt switch off. Or I may come around on leaving it on for normal operations. For alternator-out condition: turn the e-bus / aux alt switch on, open the main battery switch, dropping out the battery contactor and therefor the main bus. If the main alt has failed or thrown the belt, it won't matter much if we turn off the main alt switch or not. What are your thoughts on this layout? I known I haven't used all your suggestions, I hope you take no offense to it, I think some were moving away from the original Z13/8 philosophy which I do rather agree with. Best regards Gerry ------ Original Message ------ >From "Gerry van Dyk" <gerry.vandyk(at)eastlink.ca> To aeroelectric-list(at)matronics.com Date 2023-12-29 8:12:00 AM Subject Re[2]: AeroElectric-List: Tailwind Electrical System Drawing and Power Analysis >Hi Peter, thanks for your thoughts. >Why do you want to switch the SD-8 alternator? >because it is shown on the original Z-13/8 drawing. I'm working from >rev T 1/07/14. Is there a later revision with this switch removed? >Why switch battery power to the bus twice? >As I mentioned, I want to start the engine on the E-bus. I need to >supply power to the starter, but leave the main bus un-powered, in >order to check the function of SD-8. Supplying starting power through >the E-bus seems impractical. >Use an externally regulated main alternator to avoid having to switch >the alternator output. >Yeah, I'm hamstringing myself a little bit here. I bought the AL >12-E160 alt several years ago, I don't have a spare couple thousand >dollars to buy another. I'll have to think about it better, but on the >face of it, having a separate regulator doesn't seem to change how the >alternator is controlled. Mr. Nuckolls has mentioned on many occasions >that we want to have definite control of the alternator output with a >switch in the cockpit. Z12/8 shows this switch in the center of the >drawing. >Provide a method to connect the battery directly to the bus. (I >presume your're talking about the main bus here.) >Perhaps I'm being foolish here. I'm placing an absolute requirement to >check the operation of the backup alternator at the beginning of every >flight. My life will depend on it should the main alternator fail. >With the main bus and main alternator connected directly to the battery >contactor they will be running at startup. As yet I don't see a way to >check the backup alternator operation with the main's running. I'd >like to do so without turning half the panel on-off-on during startup. >Do not use a diode in the feed to the essential bus. >This diode is called for by B&C on their installation drawing 504-500, >and they provide it in the kit. What would be the reason to remove it? >There are a number of services connected directly to the battery just >waiting to flatten it >Quite right, and this duplicates what's shown on Z13-8. They are a >couple of conveniences, loading the baggage compartment, charging a >phone etc, without having to turn on the battery master and it's >relatively large current draw. In building my panel, all switches will >be down=off, and they're all in two rows so visually obvious when left >on. I'll have to have a quick scan of the panel when leaving the >airplane, and if I flatten the battery by mistake, my fault. >If the voltage of the SD8 is set (say) 0.2v lower than the main >alternator it will not produce power if the main is on line. If the >main fails it takes up the load. >I presume you are making another case for removing the backup alt >switch. Again, it is called for on Z13/8, but your point is well >taken. >For my liking you have too many relays between the battery and the bus >bar. >I absolutely agree, I haven't yet come up with an elegant solution to >check the backup alternator without cycling the avionics. >If you use an externally regulated main alternator then initially only >switch on the SD8 on start up. Then power up the main alternator >regulator and bring that on line. >I think we've covered this already. In order to start the engine I >need to switch on the battery contactor, which would also bring the >main bus and main alt online. I could move the starter wire to the >always-hot side of the battery contactor, so the mains are still inop, >but with that wire permanently hot, and 2 gauge wire at that, it >violates the idea of making the electrical system as inert as possible >in a forced landing. Again, I don't see the difference between an >externally or internally regulated alternator. The red wire to lead 1 >on the alt connector is the equivalent of the A wire on an external >regulator, the jumper is the same as one to the S wire, and the F wire >is internal. >Peter, writing this is making me think about separating the main alt >control to a separate switch. Let me think that through a bit and I'll >report back later. >Install a switch that powers up the essential (or main) bus directly >from the battery, if the switch is a double pole use the second pole to >disable the starter. >Interesting, I'll think that out as well. >The large diode in the feed line to the essential bus will always drop >the voltage by an amount. The benefit is auto load shedding but do you >need that with 2 alternators? If you really want to shed the main bus >use a large switch and ensure there is a path to the essential bus >directly from the battery. I used to have a feed diode and would not >use one again. >Yes, I believe it is necessary. 8 amps will not power the entire >panel, so the load shedding is still valid. Incidentally, I discovered >on the SD-8 literature that a Lycoming will need to run at 2500 rpm to >get the full 8 amps out of the SD-8. it's looking like about 6.8 amps >at 2300 rpm. Your suggestion will mean both main and E-bus need to be >switched on for normal operations. Bob has made note on many of his >drawings that "all buses are on when the main is on". I've had that in >mind when drawing this up. Having the E-bus switched on for normal ops >means the backup alternator is always running, though as you've >suggested it can be set lower than the main, and loaf along in the >background. I need to get my head around this idea. >A diode is very beneficial on the starter contactor. >That's a whoops, should have added it to the drawing, I'll get it on >there. >Having a low voltage waring that is independent of the EFIS is useful. >It is possible you will get immune to EFIS warnings >Yes, I do agree here. I was hoping the 'alt out light' function of the >main alternator would be a 'low voltage monitor' as B&C does on their >newer AVC regulator. After exchanging a couple of emails with Tim at >Plane Power, it indeed only sees the output within the alternator, >nothing outside. I've already got the Dynon EMS with all the engine >sensors, so it makes some sense to use what I've got. My thinking is >if it becomes annoying I can add the separate voltage monitoring system >after the fact. Tim at PP did mention that he regularly sees OBAM guys >using the EFIS for voltage monitoring, and all too often they've got >parameters set way too stringent, and get many nuisance warnings. As >yet I haven't investigated what parameters and settings I can work >with, so the external LV warning is always on the table. > >Thanks very much for the thoughts Peter. It's very useful to think >through the questions and comments. > >Cheers >Gerry > > >------ Original Message ------ >From "Peter Pengilly" <peter(at)sportingaero.com> >To aeroelectric-list(at)matronics.com >Date 2023-12-29 2:11:12 AM >Subject RE: AeroElectric-List: Tailwind Electrical System Drawing and >Power Analysis > >>Why do you want to switch the SD-8 alternator? >> >>Why switch battery power to the bus twice? >> >>Use an externally regulated main alternator to avoid having to switch >>the alternator output. >> >>Provide a method to connect the battery directly to the bus. >> >>Do not use a diode in the feed to the essential bus. >> >>There are a number of services connected directly to the battery just >>waiting to flatten it >> >> >> >>If the voltage of the SD8 is set (say) 0.2v lower than the main >>alternator it will not produce power if the main is on line. If the >>main fails it takes up the load. >> >>For my liking you have too many relays between the battery and the bus >>bar. >> >>If you use an externally regulated main alternator then initially only >>switch on the SD8 on start up. Then power up the main alternator >>regulator and bring that on line. >> >>Install a switch that powers up the essential (or main) bus directly >>from the battery, if the switch is a double pole use the second pole >>to disable the starter. >> >>The large diode in the feed line to the essential bus will always drop >>the voltage by an amount. The benefit is auto load shedding but do you >>need that with 2 alternators? If you really want to shed the main bus >>use a large switch and ensure there is a path to the essential bus >>directly from the battery. I used to have a feed diode and would not >>use one again. >> >>A diode is very beneficial on the starter contactor. >> >>Having a low voltage waring that is independent of the EFIS is useful. >>It is possible you will get immune to EFIS warnings >> >> >> >>Peter >> >> >> >>From:owner-aeroelectric-list-server(at)matronics.com >> On Behalf Of Gerry van >>Dyk >>Sent: Thursday, December 28, 2023 11:32 PM >>To:aeroelectric-list(at)matronics.com >>Subject: AeroElectric-List: Tailwind Electrical System Drawing and >>Power Analysis >> >> >> >>Hello again all >> >>Well, I think I'm ready for a good critique on my proposed electrical >>system for my Tailwind project. For the most part it's based on >>Z13/8, we're using a Plane Power AL12-E160 primary alternator, and of >>course the B&C SD-8 backup alternator. The E160 is internally >>regulated, and also has an internal crowbar system and alt-out panel >>light output, which I intend to use. The SD-8 has their older PMR1 >>regulator, so we've got the external crowbar module and no voltage >>sensing. I've drawn these items as shown on their respective install >>instructions call for. >> >> >> >>As I mentioned earlier, I intended to start the engine on the >>endurance bus, and check the SD-8 operation during the startup >>procedure. I had neglected to think about where the starter was going >>to get power from, so the idea has forced an additional switch and >>relay (a rather robust one at that) to run the main bus. The battery >>contactor would be closed for startup, then the SD-8 operation checked >>and finally the main bus would be brought up to begin normal >>operation. >> >> >> >>I'm a little uneasy about this extra switching, as I know this group >>is inclined toward fewer failure points, and with good reason. As I >>look at the 'textbook' Z13/8 drawing, with my dual EFIS, IFR capable >>panel in mind, it seems to me that a startup would bring the entire >>panel up with the main bus, then with the engine running I'd have to >>close the E-bus switch, open the battery contactor, dropping out half >>the instrument panel. Then check the backup alternator operation, and >>finally reboot the rest of the panel again. It just really feels >>rather clunky to me. >> >> >> >>Bob, have I missed something with the original architecture concept? >>Is there a way to check the backup alternator function while the main >>bus is up and running? It would certainly help me simplify my system. >> >> >> >>I'd appreciate if you good folks would give my drawing a good review. >>Questions, comments and critiques are all welcome. >> >> >> >>Thanks again >> >>Gerry van Dyk >> >>Tailwind C-GVDZ >> ________________________________________________________________________________
Date: Dec 29, 2023
Subject: Re: Plane Power alternator $$$$
On Fri, Dec 29, 2023 at 11:47=AFAM Coastflyer wrote: > jessejenks72(at)gmail.com> > > That=99s ok Bob, I wanted to replace the battery anyway. I do appre ciate > your analysis. > I took some video yesterday, still with the old battery. > > https://youtu.be/1TluvrVBLJo?si=IkUwgLP910Cht7Kt > > I'd suggest taking a long hard look at the circuit between your current shunt and the engine monitor. If it's a resistance type shunt and you have the recommended protective fuses in the sense lines (or a flaky connection anywhere in either line), then you will see wildly varying current displayed with no actual changes in current. My Dynon monitor was installed with glass fuses in those lines, and it does exactly what yours is doing. Reaching under the panel and wiggling inline fuse holders will (temporarily) make the symptom go away. Charlie Virus-free.www.avast.com <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> ________________________________________________________________________________
Date: Dec 29, 2023
Subject: Re: Tailwind Electrical System Drawing and
Power Analysis Gerry, before looking at the details what are you planning to use the airplane for? What do you want the system to do? Long range IFR touring, medium range VFR/occasional IFR touring and VFR hamburger runs, something else? Peter On Fri, 29 Dec 2023, 19:27 Gerry van Dyk, wrote: > Hello again all > Peter I'll follow-up here on those couple of points... > > I've attached the latest revision to my architecture. Thinking about wha t > you've suggested, separating the main alternator to it's own switch, I've > done so, and it cleans up both the drawing and the electrical system quit e > a bit. Effectively what we've done is separate the "battery / alt / DC > power" switch shown on the Z13/8 drawing into two. I've got a keyed swit ch > which I want for some basic theft deterrence, and then the main alt switc h. > > In operation we'll turn on the main bus, which will mean the entire panel > will be up. The big consumers will of course be off, pitot heat, exterio r > lighting, AP servos, boost fuel pump, and the radios will be in passive > receive mode. At this point we'd close the ebus / aux alt switch and sta rt > the engine. Dynon says this will not bring down the EFIS's so with the EM S > operating we should see the aux alternator bump the voltage, I'd flip the > switch on and off if need be to see this change. Satisfied that the aux > alternator is operating we'll then bring the main alternator online and > turn the e-bus / aux alt switch off. Or I may come around on leaving it on > for normal operations. > > For alternator-out condition: turn the e-bus / aux alt switch on, open th e > main battery switch, dropping out the battery contactor and therefor the > main bus. If the main alt has failed or thrown the belt, it won't matter > much if we turn off the main alt switch or not. > > What are your thoughts on this layout? I known I haven't used all your > suggestions, I hope you take no offense to it, I think some were moving > away from the original Z13/8 philosophy which I do rather agree with. > > Best regards > Gerry > > > ------ Original Message ------ > From "Gerry van Dyk" <gerry.vandyk(at)eastlink.ca> > To aeroelectric-list(at)matronics.com > Date 2023-12-29 8:12:00 AM > Subject Re[2]: AeroElectric-List: Tailwind Electrical System Drawing and > Power Analysis > > Hi Peter, thanks for your thoughts. > Why do you want to switch the SD-8 alternator? > because it is shown on the original Z-13/8 drawing. I'm working from rev > T 1/07/14. Is there a later revision with this switch removed? > Why switch battery power to the bus twice? > As I mentioned, I want to start the engine on the E-bus. I need to suppl y > power to the starter, but leave the main bus un-powered, in order to chec k > the function of SD-8. Supplying starting power through the E-bus seems > impractical. > Use an externally regulated main alternator to avoid having to switch the > alternator output. > Yeah, I'm hamstringing myself a little bit here. I bought the AL 12-E160 > alt several years ago, I don't have a spare couple thousand dollars to bu y > another. I'll have to think about it better, but on the face of it, havi ng > a separate regulator doesn't seem to change how the alternator is > controlled. Mr. Nuckolls has mentioned on many occasions that we want to > have definite control of the alternator output with a switch in the > cockpit. Z12/8 shows this switch in the center of the drawing. > Provide a method to connect the battery directly to the bus. (I presume > your're talking about the main bus here.) > Perhaps I'm being foolish here. I'm placing an absolute requirement to > check the operation of the backup alternator at the beginning of every > flight. My life will depend on it should the main alternator fail. With > the main bus and main alternator connected directly to the battery > contactor they will be running at startup. As yet I don't see a way to > check the backup alternator operation with the main's running. I'd like to > do so without turning half the panel on-off-on during startup. > Do not use a diode in the feed to the essential bus. > This diode is called for by B&C on their installation drawing 504-500, an d > they provide it in the kit. What would be the reason to remove it? > There are a number of services connected directly to the battery just > waiting to flatten it > Quite right, and this duplicates what's shown on Z13-8. They are a coupl e > of conveniences, loading the baggage compartment, charging a phone etc, > without having to turn on the battery master and it's relatively large > current draw. In building my panel, all switches will be down=off, and > they're all in two rows so visually obvious when left on. I'll have to > have a quick scan of the panel when leaving the airplane, and if I flatte n > the battery by mistake, my fault. > If the voltage of the SD8 is set (say) 0.2v lower than the main alternato r > it will not produce power if the main is on line. If the main fails it > takes up the load. > I presume you are making another case for removing the backup alt switch. > Again, it is called for on Z13/8, but your point is well taken. > For my liking you have too many relays between the battery and the bus ba r. > I absolutely agree, I haven't yet come up with an elegant solution to > check the backup alternator without cycling the avionics. > If you use an externally regulated main alternator then initially only > switch on the SD8 on start up. Then power up the main alternator regulato r > and bring that on line. > I think we've covered this already. In order to start the engine I need > to switch on the battery contactor, which would also bring the main bus a nd > main alt online. I could move the starter wire to the always-hot side of > the battery contactor, so the mains are still inop, but with that wire > permanently hot, and 2 gauge wire at that, it violates the idea of making > the electrical system as inert as possible in a forced landing. Again, I > don't see the difference between an externally or internally regulated > alternator. The red wire to lead 1 on the alt connector is the equivalen t > of the A wire on an external regulator, the jumper is the same as one to > the S wire, and the F wire is internal. > Peter, writing this is making me think about separating the main alt > control to a separate switch. Let me think that through a bit and I'll > report back later. > Install a switch that powers up the essential (or main) bus directly from > the battery, if the switch is a double pole use the second pole to disabl e > the starter. > Interesting, I'll think that out as well. > The large diode in the feed line to the essential bus will always drop th e > voltage by an amount. The benefit is auto load shedding but do you need > that with 2 alternators? If you really want to shed the main bus use a > large switch and ensure there is a path to the essential bus directly fro m > the battery. I used to have a feed diode and would not use one again. > Yes, I believe it is necessary. 8 amps will not power the entire panel, > so the load shedding is still valid. Incidentally, I discovered on the > SD-8 literature that a Lycoming will need to run at 2500 rpm to get the > full 8 amps out of the SD-8. it's looking like about 6.8 amps at 2300 > rpm. Your suggestion will mean both main and E-bus need to be switched o n > for normal operations. Bob has made note on many of his drawings that "a ll > buses are on when the main is on". I've had that in mind when drawing th is > up. Having the E-bus switched on for normal ops means the backup > alternator is always running, though as you've suggested it can be set > lower than the main, and loaf along in the background. I need to get my > head around this idea. > A diode is very beneficial on the starter contactor. > That's a whoops, should have added it to the drawing, I'll get it on ther e. > Having a low voltage waring that is independent of the EFIS is useful. It > is possible you will get immune to EFIS warnings > Yes, I do agree here. I was hoping the 'alt out light' function of the > main alternator would be a 'low voltage monitor' as B&C does on their new er > AVC regulator. After exchanging a couple of emails with Tim at Plane > Power, it indeed only sees the output within the alternator, nothing > outside. I've already got the Dynon EMS with all the engine sensors, so it > makes some sense to use what I've got. My thinking is if it becomes > annoying I can add the separate voltage monitoring system after the fact. > Tim at PP did mention that he regularly sees OBAM guys using the EFIS for > voltage monitoring, and all too often they've got parameters set way too > stringent, and get many nuisance warnings. As yet I haven't investigated > what parameters and settings I can work with, so the external LV warning is > always on the table. > > Thanks very much for the thoughts Peter. It's very useful to think > through the questions and comments. > > Cheers > Gerry > > > ------ Original Message ------ > From "Peter Pengilly" <peter(at)sportingaero.com> > To aeroelectric-list(at)matronics.com > Date 2023-12-29 2:11:12 AM > Subject RE: AeroElectric-List: Tailwind Electrical System Drawing and > Power Analysis > > Why do you want to switch the SD-8 alternator? > > Why switch battery power to the bus twice? > > Use an externally regulated main alternator to avoid having to switch the > alternator output. > > Provide a method to connect the battery directly to the bus. > > Do not use a diode in the feed to the essential bus. > > There are a number of services connected directly to the battery just > waiting to flatten it > > > If the voltage of the SD8 is set (say) 0.2v lower than the main alternato r > it will not produce power if the main is on line. If the main fails it > takes up the load. > > For my liking you have too many relays between the battery and the bus ba r. > > If you use an externally regulated main alternator then initially only > switch on the SD8 on start up. Then power up the main alternator regulato r > and bring that on line. > > Install a switch that powers up the essential (or main) bus directly from > the battery, if the switch is a double pole use the second pole to disabl e > the starter. > > The large diode in the feed line to the essential bus will always drop th e > voltage by an amount. The benefit is auto load shedding but do you need > that with 2 alternators? If you really want to shed the main bus use a > large switch and ensure there is a path to the essential bus directly fro m > the battery. I used to have a feed diode and would not use one again. > > A diode is very beneficial on the starter contactor. > > Having a low voltage waring that is independent of the EFIS is useful. It > is possible you will get immune to EFIS warnings > > > Peter > > > *From:* owner-aeroelectric-list-server(at)matronics.com < > owner-aeroelectric-list-server(at)matronics.com> *On Behalf Of *Gerry van Dy k > *Sent:* Thursday, December 28, 2023 11:32 PM > *To:* aeroelectric-list(at)matronics.com > *Subject:* AeroElectric-List: Tailwind Electrical System Drawing and > Power Analysis > > > Hello again all > > Well, I think I'm ready for a good critique on my proposed electrical > system for my Tailwind project. For the most part it's based on Z13/8, > we're using a Plane Power AL12-E160 primary alternator, and of course the > B&C SD-8 backup alternator. The E160 is internally regulated, and also h as > an internal crowbar system and alt-out panel light output, which I intend > to use. The SD-8 has their older PMR1 regulator, so we've got the extern al > crowbar module and no voltage sensing. I've drawn these items as shown o n > their respective install instructions call for. > > > As I mentioned earlier, I intended to start the engine on the endurance > bus, and check the SD-8 operation during the startup procedure. I had > neglected to think about where the starter was going to get power from, s o > the idea has forced an additional switch and relay (a rather robust one a t > that) to run the main bus. The battery contactor would be closed for > startup, then the SD-8 operation checked and finally the main bus would b e > brought up to begin normal operation. > > > I'm a little uneasy about this extra switching, as I know this group is > inclined toward fewer failure points, and with good reason. As I look at > the 'textbook' Z13/8 drawing, with my dual EFIS, IFR capable panel in min d, > it seems to me that a startup would bring the entire panel up with the ma in > bus, then with the engine running I'd have to close the E-bus switch, ope n > the battery contactor, dropping out half the instrument panel. Then chec k > the backup alternator operation, and finally reboot the rest of the panel > again. It just really feels rather clunky to me. > > > Bob, have I missed something with the original architecture concept? Is > there a way to check the backup alternator function while the main bus is > up and running? It would certainly help me simplify my system. > > > I'd appreciate if you good folks would give my drawing a good review. > Questions, comments and critiques are all welcome. > > > Thanks again > > Gerry van Dyk > > Tailwind C-GVDZ > > ________________________________________________________________________________
From: "Gerry van Dyk" <gerry.vandyk(at)eastlink.ca>
Analysis
Date: Dec 29, 2023
It will be for mainly VFR touring and vacation, IFR Training and eventually IFR travel though VFR will be preferred over IFR. The VFR weekend breakfast flyins and hambergers will likely be the bulk of service. I want the personal rating and currency and the airplane's IFR capability to be there the 2 or 3 time per year when it's likely to be required. Like an annual pilgrimage to Osh. I don't want to be stranded for weather that's overcast but otherwise fairly benign. Does that answer the question? Gerry ------ Original Message ------ >From "Peter Pengilly" <peter(at)sportingaero.com> To "Aeroelectric List (aeroelectric-list(at)matronics.com)" Date 2023-12-29 12:44:19 PM Subject Re: Re[3]: AeroElectric-List: Tailwind Electrical System Drawing and Power Analysis >Gerry, before looking at the details what are you planning to use the >airplane for? What do you want the system to do? >Long range IFR touring, medium range VFR/occasional IFR touring and VFR >hamburger runs, something else? Peter > >On Fri, 29 Dec 2023, 19:27 Gerry van Dyk, >wrote: >>Hello again all >>Peter I'll follow-up here on those couple of points... >> >>I've attached the latest revision to my architecture. Thinking about >>what you've suggested, separating the main alternator to it's own >>switch, I've done so, and it cleans up both the drawing and the >>electrical system quite a bit. Effectively what we've done is >>separate the "battery / alt / DC power" switch shown on the Z13/8 >>drawing into two. I've got a keyed switch which I want for some basic >>theft deterrence, and then the main alt switch. >> >>In operation we'll turn on the main bus, which will mean the entire >>panel will be up. The big consumers will of course be off, pitot >>heat, exterior lighting, AP servos, boost fuel pump, and the radios >>will be in passive receive mode. At this point we'd close the ebus / >>aux alt switch and start the engine. Dynon says this will not bring >>down the EFIS's so with the EMS operating we should see the aux >>alternator bump the voltage, I'd flip the switch on and off if need be >>to see this change. Satisfied that the aux alternator is operating >>we'll then bring the main alternator online and turn the e-bus / aux >>alt switch off. Or I may come around on leaving it on for normal >>operations. >> >>For alternator-out condition: turn the e-bus / aux alt switch on, open >>the main battery switch, dropping out the battery contactor and >>therefor the main bus. If the main alt has failed or thrown the belt, >>it won't matter much if we turn off the main alt switch or not. >> >>What are your thoughts on this layout? I known I haven't used all >>your suggestions, I hope you take no offense to it, I think some were >>moving away from the original Z13/8 philosophy which I do rather agree >>with. >> >>Best regards >>Gerry >> >> >>------ Original Message ------ >>From "Gerry van Dyk" <gerry.vandyk(at)eastlink.ca> >>To aeroelectric-list(at)matronics.com >>Date 2023-12-29 8:12:00 AM >>Subject Re[2]: AeroElectric-List: Tailwind Electrical System Drawing >>and Power Analysis >> >>>Hi Peter, thanks for your thoughts. >>>Why do you want to switch the SD-8 alternator? >>>because it is shown on the original Z-13/8 drawing. I'm working from >>>rev T 1/07/14. Is there a later revision with this switch removed? >>>Why switch battery power to the bus twice? >>>As I mentioned, I want to start the engine on the E-bus. I need to >>>supply power to the starter, but leave the main bus un-powered, in >>>order to check the function of SD-8. Supplying starting power >>>through the E-bus seems impractical. >>>Use an externally regulated main alternator to avoid having to switch >>>the alternator output. >>>Yeah, I'm hamstringing myself a little bit here. I bought the AL >>>12-E160 alt several years ago, I don't have a spare couple thousand >>>dollars to buy another. I'll have to think about it better, but on >>>the face of it, having a separate regulator doesn't seem to change >>>how the alternator is controlled. Mr. Nuckolls has mentioned on many >>>occasions that we want to have definite control of the alternator >>>output with a switch in the cockpit. Z12/8 shows this switch in the >>>center of the drawing. >>>Provide a method to connect the battery directly to the bus. (I >>>presume your're talking about the main bus here.) >>>Perhaps I'm being foolish here. I'm placing an absolute requirement >>>to check the operation of the backup alternator at the beginning of >>>every flight. My life will depend on it should the main alternator >>>fail. With the main bus and main alternator connected directly to >>>the battery contactor they will be running at startup. As yet I >>>don't see a way to check the backup alternator operation with the >>>main's running. I'd like to do so without turning half the panel >>>on-off-on during startup. >>>Do not use a diode in the feed to the essential bus. >>>This diode is called for by B&C on their installation drawing >>>504-500, and they provide it in the kit. What would be the reason to >>>remove it? >>>There are a number of services connected directly to the battery just >>>waiting to flatten it >>>Quite right, and this duplicates what's shown on Z13-8. They are a >>>couple of conveniences, loading the baggage compartment, charging a >>>phone etc, without having to turn on the battery master and it's >>>relatively large current draw. In building my panel, all switches >>>will be down=off, and they're all in two rows so visually obvious >>>when left on. I'll have to have a quick scan of the panel when >>>leaving the airplane, and if I flatten the battery by mistake, my >>>fault. >>>If the voltage of the SD8 is set (say) 0.2v lower than the main >>>alternator it will not produce power if the main is on line. If the >>>main fails it takes up the load. >>>I presume you are making another case for removing the backup alt >>>switch. Again, it is called for on Z13/8, but your point is well >>>taken. >>>For my liking you have too many relays between the battery and the >>>bus bar. >>>I absolutely agree, I haven't yet come up with an elegant solution to >>>check the backup alternator without cycling the avionics. >>>If you use an externally regulated main alternator then initially >>>only switch on the SD8 on start up. Then power up the main alternator >>>regulator and bring that on line. >>>I think we've covered this already. In order to start the engine I >>>need to switch on the battery contactor, which would also bring the >>>main bus and main alt online. I could move the starter wire to the >>>always-hot side of the battery contactor, so the mains are still >>>inop, but with that wire permanently hot, and 2 gauge wire at that, >>>it violates the idea of making the electrical system as inert as >>>possible in a forced landing. Again, I don't see the difference >>>between an externally or internally regulated alternator. The red >>>wire to lead 1 on the alt connector is the equivalent of the A wire >>>on an external regulator, the jumper is the same as one to the S >>>wire, and the F wire is internal. >>>Peter, writing this is making me think about separating the main alt >>>control to a separate switch. Let me think that through a bit and >>>I'll report back later. >>>Install a switch that powers up the essential (or main) bus directly >>>from the battery, if the switch is a double pole use the second pole >>>to disable the starter. >>>Interesting, I'll think that out as well. >>>The large diode in the feed line to the essential bus will always >>>drop the voltage by an amount. The benefit is auto load shedding but >>>do you need that with 2 alternators? If you really want to shed the >>>main bus use a large switch and ensure there is a path to the >>>essential bus directly from the battery. I used to have a feed diode >>>and would not use one again. >>>Yes, I believe it is necessary. 8 amps will not power the entire >>>panel, so the load shedding is still valid. Incidentally, I >>>discovered on the SD-8 literature that a Lycoming will need to run at >>>2500 rpm to get the full 8 amps out of the SD-8. it's looking like >>>about 6.8 amps at 2300 rpm. Your suggestion will mean both main and >>>E-bus need to be switched on for normal operations. Bob has made >>>note on many of his drawings that "all buses are on when the main is >>>on". I've had that in mind when drawing this up. Having the E-bus >>>switched on for normal ops means the backup alternator is always >>>running, though as you've suggested it can be set lower than the >>>main, and loaf along in the background. I need to get my head around >>>this idea. >>>A diode is very beneficial on the starter contactor. >>>That's a whoops, should have added it to the drawing, I'll get it on >>>there. >>>Having a low voltage waring that is independent of the EFIS is >>>useful. It is possible you will get immune to EFIS warnings >>>Yes, I do agree here. I was hoping the 'alt out light' function of >>>the main alternator would be a 'low voltage monitor' as B&C does on >>>their newer AVC regulator. After exchanging a couple of emails with >>>Tim at Plane Power, it indeed only sees the output within the >>>alternator, nothing outside. I've already got the Dynon EMS with all >>>the engine sensors, so it makes some sense to use what I've got. My >>>thinking is if it becomes annoying I can add the separate voltage >>>monitoring system after the fact. Tim at PP did mention that he >>>regularly sees OBAM guys using the EFIS for voltage monitoring, and >>>all too often they've got parameters set way too stringent, and get >>>many nuisance warnings. As yet I haven't investigated what >>>parameters and settings I can work with, so the external LV warning >>>is always on the table. >>> >>>Thanks very much for the thoughts Peter. It's very useful to think >>>through the questions and comments. >>> >>>Cheers >>>Gerry >>> >>> >>>------ Original Message ------ >>>From "Peter Pengilly" <peter(at)sportingaero.com> >>>To aeroelectric-list(at)matronics.com >>>Date 2023-12-29 2:11:12 AM >>>Subject RE: AeroElectric-List: Tailwind Electrical System Drawing and >>>Power Analysis >>> >>>>Why do you want to switch the SD-8 alternator? >>>> >>>>Why switch battery power to the bus twice? >>>> >>>>Use an externally regulated main alternator to avoid having to >>>>switch the alternator output. >>>> >>>>Provide a method to connect the battery directly to the bus. >>>> >>>>Do not use a diode in the feed to the essential bus. >>>> >>>>There are a number of services connected directly to the battery >>>>just waiting to flatten it >>>> >>>> >>>> >>>>If the voltage of the SD8 is set (say) 0.2v lower than the main >>>>alternator it will not produce power if the main is on line. If the >>>>main fails it takes up the load. >>>> >>>>For my liking you have too many relays between the battery and the >>>>bus bar. >>>> >>>>If you use an externally regulated main alternator then initially >>>>only switch on the SD8 on start up. Then power up the main >>>>alternator regulator and bring that on line. >>>> >>>>Install a switch that powers up the essential (or main) bus directly >>>>from the battery, if the switch is a double pole use the second pole >>>>to disable the starter. >>>> >>>>The large diode in the feed line to the essential bus will always >>>>drop the voltage by an amount. The benefit is auto load shedding but >>>>do you need that with 2 alternators? If you really want to shed the >>>>main bus use a large switch and ensure there is a path to the >>>>essential bus directly from the battery. I used to have a feed diode >>>>and would not use one again. >>>> >>>>A diode is very beneficial on the starter contactor. >>>> >>>>Having a low voltage waring that is independent of the EFIS is >>>>useful. It is possible you will get immune to EFIS warnings >>>> >>>> >>>> >>>>Peter >>>> >>>> >>>> >>>>From:owner-aeroelectric-list-server(at)matronics.com >>>> On Behalf Of Gerry >>>>van Dyk >>>>Sent: Thursday, December 28, 2023 11:32 PM >>>>To:aeroelectric-list(at)matronics.com >>>>Subject: AeroElectric-List: Tailwind Electrical System Drawing and >>>>Power Analysis >>>> >>>> >>>> >>>>Hello again all >>>> >>>>Well, I think I'm ready for a good critique on my proposed >>>>electrical system for my Tailwind project. For the most part it's >>>>based on Z13/8, we're using a Plane Power AL12-E160 primary >>>>alternator, and of course the B&C SD-8 backup alternator. The E160 >>>>is internally regulated, and also has an internal crowbar system and >>>>alt-out panel light output, which I intend to use. The SD-8 has >>>>their older PMR1 regulator, so we've got the external crowbar module >>>>and no voltage sensing. I've drawn these items as shown on their >>>>respective install instructions call for. >>>> >>>> >>>> >>>>As I mentioned earlier, I intended to start the engine on the >>>>endurance bus, and check the SD-8 operation during the startup >>>>procedure. I had neglected to think about where the starter was >>>>going to get power from, so the idea has forced an additional switch >>>>and relay (a rather robust one at that) to run the main bus. The >>>>battery contactor would be closed for startup, then the SD-8 >>>>operation checked and finally the main bus would be brought up to >>>>begin normal operation. >>>> >>>> >>>> >>>>I'm a little uneasy about this extra switching, as I know this group >>>>is inclined toward fewer failure points, and with good reason. As I >>>>look at the 'textbook' Z13/8 drawing, with my dual EFIS, IFR capable >>>>panel in mind, it seems to me that a startup would bring the entire >>>>panel up with the main bus, then with the engine running I'd have to >>>>close the E-bus switch, open the battery contactor, dropping out >>>>half the instrument panel. Then check the backup alternator >>>>operation, and finally reboot the rest of the panel again. It just >>>>really feels rather clunky to me. >>>> >>>> >>>> >>>>Bob, have I missed something with the original architecture concept? >>>> Is there a way to check the backup alternator function while the >>>>main bus is up and running? It would certainly help me simplify my >>>>system. >>>> >>>> >>>> >>>>I'd appreciate if you good folks would give my drawing a good >>>>review. Questions, comments and critiques are all welcome. >>>> >>>> >>>> >>>>Thanks again >>>> >>>>Gerry van Dyk >>>> >>>>Tailwind C-GVDZ >>>> ________________________________________________________________________________
Date: Dec 29, 2023
Thanks Charlie, I will check out those wires. I dont think I have fuses in them but will check all the connections. Its possible I could have damaged one of the connections at the shunt when I was hurriedly removing the cover on the current limiter (which is right above the shunt) after the original alternator failure. Bob, I will try isolating all the loads. I think I already tried turning the avionics master off, and I have turned off all the exterior lighting, but I will try everything again. It could be the Dynon I could pull the fuse and run it on its backup battery. Otherwise, there is only the alternator field, battery solenoid, and elevator trim, and a USB charge outlet. I did unplug my phone, but will try pulling the fuse. Yes, the oscillation started when I installed the new alternator. The battery is 5 years old and I havent done a capacity test, and it did get deeply discharged during the alternator failure flight. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=512982#512982 ________________________________________________________________________________
Date: Dec 29, 2023
Power Analysis I don't like the key switch.=C2- If you turn it off with the engine runn ing it could cause a load dump by disconnecting the alternator from the bat tery.=C2- Use a DPDT key switch to turn off the alternator as well, or I used a momentary key switch in place of a pushbutton for the starter.=C2- Not so much for theft protection, but to protect from having some kid (or adult) accidentally engage the starter at Oshkosh. andyk(at)eastlink.ca> wrote: Hello again allPeter I'll follow-up here on those couple of points... I've attached the latest revision to my architecture.=C2- Thinking about what you've suggested, separating the main alternator to it's own switch, I 've done so, and it cleans up both the drawing and the electrical system qu ite a bit.=C2- Effectively what we've done is separate the "battery / alt / DC power" switch shown on the Z13/8 drawing into two.=C2- I've got a k eyed switch which I want for some basic theft deterrence, and then the main alt switch. In operation we'll turn on the main bus, which will mean the entire panel w ill be up.=C2- The big consumers will of course be off, pitot heat, exter ior lighting, AP servos, boost fuel pump, and the radios will be in passive receive mode.=C2- At this point we'd close the ebus / aux alt switch and start the engine. Dynon says this will not bring down the EFIS's so with t he EMS operating we should see the aux alternator bump the voltage, I'd fli p the switch on and off if need be to see this change.=C2- Satisfied that the aux alternator is operating we'll then bring the main alternator onlin e and turn the e-bus / aux alt switch off.=C2- Or I may come around on le aving it on for normal operations. For alternator-out condition: turn the e-bus / aux alt switch on, open the main battery switch, dropping out the battery contactor and therefor the ma in bus.=C2- If the main alt has failed or thrown the belt, it won't matte r much if we turn off the main alt switch or not. What are your thoughts on this layout?=C2- I known I haven't used all you r suggestions, I hope you take no offense to it, I think some were moving a way from the original Z13/8 philosophy which I do rather agree with. Best regardsGerry ------ Original Message ------From "Gerry van Dyk" <gerry.vandyk(at)eastlink.c a>To aeroelectric-list(at)matronics.comDate 2023-12-29 8:12:00 AMSubject Re[2] : AeroElectric-List: Tailwind Electrical System Drawing and Power Analysis Hi Peter, thanks for your thoughts.Why do you want to switch the SD-8 alter nator?because it is shown on the original Z-13/8 drawing.=C2- I'm working from rev T 1/07/14.=C2- Is there a later revision with this switch remov ed?Why switch battery power to the bus twice?As I mentioned, I want to star t the engine on the E-bus.=C2- I need to supply power to the starter, but leave the main bus un-powered, in order to check the function of SD-8.=C2 - Supplying starting power through the E-bus seems impractical.Use an ext ernally regulated main alternator to avoid having to switch the alternator output.Yeah, I'm hamstringing myself a little bit here.=C2- I bought the AL 12-E160 alt several years ago, I don't have a spare couple thousand doll ars to buy another.=C2- I'll have to think about it better, but on the fa ce of it, having a separate regulator doesn't seem to change how the altern ator is controlled.=C2- Mr. Nuckolls has mentioned on many occasions that we want to have definite control of the alternator output with a switch in the cockpit.=C2- Z12/8 shows this switch in the center of the drawing.Pr ovide a method to connect the battery directly to the bus.=C2- (I presume your're talking about the main bus here.)Perhaps I'm being foolish here. =C2- I'm placing an absolute requirement to check the operation of the ba ckup alternator at the beginning of every flight.=C2- My life will depend on it should the main alternator fail.=C2- With the main bus and main al ternator connected directly to the battery contactor they will be running a t startup.=C2- As yet I don't see a way to check the backup alternator op eration with the main's running.=C2- I'd like to do so without turning ha lf the panel on-off-on during startup.Do not use a diode in the feed to the essential bus.This diode is called for by B&C on their installation drawin g 504-500, and they provide it in the kit.=C2- What would be the reason t o remove it?There are a number of services connected directly to the batter y just waiting to flatten itQuite right, and this duplicates what' s shown on Z13-8.=C2- They are a couple of conveniences, loading the bagg age compartment, charging a phone etc, without having to turn on the batter y master and it's relatively large current draw.=C2- In building my panel , all switches will be down=off, and they're all in two rows so visually obvious when left on.=C2- I'll have to have a quick scan of the panel whe n leaving the airplane, and if I flatten the battery by mistake, my fault.I f the voltage of the SD8 is set (say) 0.2v lower than the main alternator i t will not produce power if the main is on line. If the main fails it takes up the load.I presume you are making another case for removing the backup alt switch.=C2- Again, it is called for on Z13/8, but your point is well taken.For my liking you have too many relays between the battery and the bu s bar.I absolutely agree, I haven't yet come up with an elegant solution to check the backup alternator without cycling the avionics.If you use an ext ernally regulated main alternator then initially only switch on the SD8 on start up. Then power up the main alternator regulator and bring that on lin e.I think we've covered this already.=C2- In order to start the engine I need to switch on the battery contactor, which would also bring the main bu s and main alt online.=C2- I could move the starter wire to the always-ho t side of the battery contactor, so the mains are still inop, but with that wire permanently hot, and 2 gauge wire at that, it violates the idea of ma king the electrical system as inert as possible in a forced landing.=C2- Again, I don't see the difference between an externally or internally regul ated alternator.=C2- The red wire to lead 1 on the alt connector is the e quivalent of the A wire on an external regulator, the jumper is the same as one to the S wire, and the F wire is internal.Peter, writing this is makin g me think about separating the main alt control to a separate switch.=C2 - Let me think that through a bit and I'll report back later.Install a sw itch that powers up the essential (or main) bus directly from the battery, if the switch is a double pole use the second pole to disable the starter.I nteresting, I'll think that out as well.The large diode in the feed line to the essential bus will always drop the voltage by an amount. The benefit i s auto load shedding but do you need that with 2 alternators?=C2-=C2-If you really want to shed the main bus use a large switch and ensure there i s a path to the essential bus directly from the battery. I used to have a f eed diode and would not use one again.Yes, I believe it is necessary.=C2- 8 amps will not power the entire panel, so the load shedding is still vali d.=C2- Incidentally, I discovered on the SD-8 literature that a Lycoming will need to run at 2500 rpm to get the full 8 amps out of the SD-8.=C2- it's looking like about 6.8 amps at 2300 rpm.=C2- Your suggestion will me an both main and E-bus need to be switched on for normal operations.=C2- Bob has made note on many of his drawings that "all buses are on when the m ain is on".=C2- I've had that in mind when drawing this up.=C2- Having the E-bus switched on for normal ops means the backup alternator is always running, though as you've suggested it can be set lower than the main, and loaf along in the background.=C2- I need to get my head around this idea. A diode is very beneficial on the starter contactor.That's a whoops, should have added it to the drawing, I'll get it on there.Having a low voltage wa ring that is independent of the EFIS is useful. It is possible you will get immune to EFIS warningsYes, I do agree here.=C2- I was hoping t he 'alt out light' function of the main alternator would be a 'low voltage monitor' as B&C does on their newer AVC regulator.=C2- After exchanging a couple of emails with Tim at Plane Power, it indeed only sees the output w ithin the alternator, nothing outside.=C2- I've already got the Dynon EMS with all the engine sensors, so it makes some sense to use what I've got. =C2- My thinking is if it becomes annoying I can add the separate voltage monitoring system after the fact.=C2- Tim at PP did mention that he regu larly sees OBAM guys using the EFIS for voltage monitoring, and all too oft en they've got parameters set way too stringent, and get many nuisance warn ings.=C2- As yet I haven't investigated what parameters and settings I ca n work with, so the external LV warning is always on the table. Thanks very much for the thoughts Peter.=C2- It's very useful to think th rough the questions and comments. CheersGerry ------ Original Message ------From "Peter Pengilly" <peter(at)sportingaero.com >To aeroelectric-list(at)matronics.comDate 2023-12-29 2:11:12 AMSubject RE: Ae roElectric-List: Tailwind Electrical System Drawing and Power Analysis Why do you want to switch the SD-8 alternator? Why switch battery power to the bus twice? Use an externally regulated main alternator to avoid having to switch the a lternator output. Provide a method to connect the battery directly to the bus. Do not use a diode in the feed to the essential bus. There are a number of services connected directly to the battery just waiti ng to flatten it =C2- If the voltage of the SD8 is set (say) 0.2v lower than the main alternator it will not produce power if the main is on line. If the main fails it take s up the load. For my liking you have too many relays between the battery and the bus bar. If you use an externally regulated main alternator then initially only swit ch on the SD8 on start up. Then power up the main alternator regulator and bring that on line. Install a switch that powers up the essential (or main) bus directly from t he battery, if the switch is a double pole use the second pole to disable t he starter. The large diode in the feed line to the essential bus will always drop the voltage by an amount. The benefit is auto load shedding but do you need tha t with 2 alternators? If you really want to shed the main bus use a large s witch and ensure there is a path to the essential bus directly from the bat tery. I used to have a feed diode and would not use one again. A diode is very beneficial on the starter contactor. Having a low voltage waring that is independent of the EFIS is useful. It i s possible you will get immune to EFIS warnings =C2- Peter =C2- From: owner-aeroelectric-list-server(at)matronics.com <owner-aeroelectric-list -server(at)matronics.com> On Behalf Of Gerry van Dyk Sent: Thursday, December 28, 2023 11:32 PM Subject: AeroElectric-List: Tailwind Electrical System Drawing and Power An alysis =C2- Hello again all Well, I think I'm ready for a good critique on my proposed electrical syste m for my Tailwind project.=C2- For the most part it's based on Z13/8, we' re using a Plane Power AL12-E160 primary alternator, and of course the B&C SD-8 backup alternator.=C2- The E160 is internally regulated, and also ha s an internal crowbar system and alt-out panel light output, which I intend to use.=C2- The SD-8 has their older PMR1 regulator, so we've got the ex ternal crowbar module and no voltage sensing.=C2- I've drawn these items as shown on their respective install instructions call for. =C2- As I mentioned earlier, I intended to start the engine on the endurance bus , and check the SD-8 operation during the startup procedure.=C2- I had ne glected to think about where the starter was going to get power from, so th e idea has forced an additional switch and relay (a rather robust one at th at) to run the main bus.=C2- The battery contactor would be closed for st artup, then the SD-8 operation checked and finally the main bus would be br ought up to begin normal operation. =C2- I'm a little uneasy about this extra switching, as I know this group is inc lined toward fewer failure points, and with good reason.=C2- As I look at the 'textbook' Z13/8 drawing, with my dual EFIS, IFR capable panel in mind , it seems to me that a startup would bring the entire panel up with the ma in bus, then with the engine running I'd have to close the E-bus switch, op en the battery contactor, dropping out half the instrument panel.=C2- The n check the backup alternator operation, and finally reboot the rest of the panel again.=C2- It just really feels rather clunky to me. =C2- Bob, have I missed something with the original architecture concept?=C2- Is there a way to check the backup alternator function while the main bus i s up and running?=C2- It would certainly help me simplify my system. =C2- I'd appreciate if you good folks would give my drawing a good review.=C2- Questions, comments and critiques are all welcome. =C2- Thanks again Gerry van Dyk Tailwind C-GVDZ ________________________________________________________________________________
Date: Dec 29, 2023
Subject: Re: Fusible links
At 10:12 AM 12/29/2023, you wrote: >Hi Chris; >Hi All; >That's a great demonstration Chris. >And it evidences exactly why I would not use fusible links in an >aircraft, or automobile for that matter. >There's smoke, there's fire, and there's molten metal! >With most fuses the burned wire, smoke, and fire are contained. >Cheers! Stu. Chris' demonstrations are essentially the same as those I conducted 23 years ago when this article was published on the website. https://tinyurl.com/msx5ofe The original impetus for the article was to craft a robust, minimum labor, alternative to the signal leads from a firewall mounted shunt extending to the instrument on the panel. In this special case, the links were out on the firewall . . . having the links 'fuse' under fiberglas sleeving presented no special hazard. AeroElectric -and- B&C sold a goodly number of kits that included the somewhat hard-to- find silicon impregnated fiberglas sleeve. This was before I became aware of sources for bulk, cut-n-terminate fuse link wire which is now readily available from a constellation of sources. This stuff is ordinary, stranded copper wire insulated in 'magic plastic'. One of the first materials to be qualified was 'Hypalon' by DuPont. It was favored for use in all manner of industrial grade electric vehicles including over the rails engines, mining engines, cranes, etc. Any situation where people shared close spaces with really fat wires. The smoke emitted by a faulted cable was very low toxicity and irritation. Hence it became a go-to choice for fusible links as well. The stuff is TOUGH! It's used to fabricate all manner of inflatable rubber flotation. This toughness goes to it's ability to contain byproducts of the melted wire within. Hypalon is no longer made, newer competitive products have forced it out of the market place. Due to the general ruggedness of fusible link insulation, smaller wire down to 22AWG is available for nasty environment applications as well as fusible links. By the way, there's a rather extensive SAE specification describing requirements for fusible link fabrication and peformance. Fusible links should qualify to SAE J-1128 Type HTS. Fusible links should not be used in systems that exceed 50V. At 60+ years, this is almost vintage technology with well proven track records. Bob . . . //// (o o) ===========o00o=(_)=o00o======== < Go ahead, make my day . . . > < show me where I'm wrong. > ================================ In the interest of creative evolution of the-best-we-know-how-to-do based on physics and good practice. ________________________________________________________________________________
Subject: Re: Re[3]: Tailwind Electrical System Drawing and Power
Analysi
Date: Dec 29, 2023
Suggestions: Replace the 15A E-Bus fuse with a fusible link. It is not good practice to have fuses in series. Locate the E-Bus relay near the battery bus. In the event of over voltage, the crowbar module will smoke. Protect it with a 3 amp fuse or circuit breaker. The 2A fuse in the battery contactor coil circuit is a good idea. It will protect against reversed battery polarity. (It happens) Consider using a Hall Effect sensor instead of a shunt, if compatible with your Dynon. The starter contactor diode is wired wrong. Connect the banded end to the "S" terminal. Connect the other end of the diode to the other end of the contactor coil (ground). -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=512985#512985 ________________________________________________________________________________
Date: Dec 29, 2023
What I found very interesting is how often the melt/disconnect occurred near the butt splices. Seems to negate the theory of the splices and bigger wire leading away the heat needing to melt the wire. Any chance that you "nicked" one or more of the strands when stripping the insulation? Would be interesting to see the same experiment with soldered connections. Finn On 12/29/2023 10:30 AM, Christopher Cee Stone wrote: > My very basic test rig with somewhat empirical results- no measured data. > > Objective: observe failure of fusible links of various lengths when > subjected to a high current short circuit event. > > 12V wet cell, new, fully charged battery > Knife switch > 18 ga tefzel feeder, 20" length x2 > PIDG style butt splices (red) > Camera > > DUT: 2", 6", 13" lengths 24 ga tefzel FL (M22759/16) > > Procedure: > Fabricate fusiblelinks of 2, 6 an 13 inch lengths > Crimp w/ AMP PIDG crimper to > Feeder 20" 18 ga tefzel > Clamp feeders to B+ Knife switch and B- battery terminal > Start camera video > Rabidly close switch > > Two inch FL setup > 2InchSetup.jpg > Crimp tool and butt splice > AmpCrimpTool.jpg > results: > > http://tinyurl.com/mryadbfx > > No fiberglas sleeve was used so that failure could be observed. > > Comments, questions, critique! > > ...chris > > On Sat, Dec 23, 2023 at 8:02AM Robert L. Nuckolls, III > wrote: > > At 09:31 AM 12/23/2023, you wrote: >> Back to the original question of the length of a fusible link. >> That is the length of smaller gauge wire comprising the 'link'. > > > Had to do some 'digging' to see if I could > find where that 3-6 inch citation came from. > No joy. > > Actually, 6" is the minimum. 9" is more typical, > 10" not unheard of. 3" is too short . . . > > . . . and INSULATED with material resistant to > energy released by clearing the fault. > > See: http://tinyurl.com/4vnzdjpc > > > <http://tinyurl.com/4vnzdjpc> > > Bob . . . > > //// > (o o) > ===========o00o=(_)=o00o======== > < Go ahead, make my day . . . > > < show me where I'm wrong. > > ================================ > > In the interest of creative evolution > of the-best-we-know-how-to-do based > on physics and good practice. > ________________________________________________________________________________
and Power Analysi
Date: Dec 30, 2023
Thanks for the notes Joe Replace the 15A E-Bus fuse with a fusible link. It is not good practice to have fuses in series. Yep, makes good sense. Locate the E-Bus relay near the battery bus. I plan to locate the SD-8 regulator between the panel and firewall. The battery and it's bus are behind the passenger seat. My plan is to replace the relay that came in the alternator kit with a double pole relay, and place it beside the regulator. I suppose I could have the switch operate two separate relays, but that seems pretty clunky. Could you please tell me what problem you see with the relay beside the endurance bus rather than the battery bus? In the event of over voltage, the crowbar module will smoke. Protect it wi th a 3 amp fuse or circuit breaker. This confused me for a while till I realized I've got the breaker in the wr ong position. I need to have the breaker in the switch wire, not the alte rnator feed line back to the battery bus. I'll correct this. B&C's wiring drawing is calling for a 2 amp breaker. The 2A fuse in the battery contactor coil circuit is a good idea. It will protect against reversed battery polarity. (It happens) It'll be a long wire making its way from the contactor, up between the seat s, through the tunnel with the flap linkages, then up to the panel, so fusi ng it is a no-brainer. ;^) Consider using a Hall Effect sensor instead of a shunt, if compatible with your Dynon. Yes, the EMS-220 from Dynon is compatible with hall effect sensors. The engine sensor kit came with the shunt so I'll use it till I find a need to change it. Don't get me wrong, I like hall effect sensors, but I'm too cheap to set aside something that works and buy something different. ;^) The starter contactor diode is wired wrong. Connect the banded end to the "S" terminal. Connect the other end of the diode to the other end of the contactor coil (ground). I'm a little red-faced on this one. When I added it, I first had it wired as you say, then a quick glance at the battery contactor made me think it goes on those two contacts on the side. So I changed it. Doh!!! I'll put it back right. Of course it needs to be across the coil. Thanks again Joe, I'll get these corrections made. Gerry ------ Original Message ------ >From "user9253" <fransew(at)gmail.com> To aeroelectric-list(at)matronics.com Date 2023-12-29 5:53:34 PM Subject AeroElectric-List: Re: Re[3]: Tailwind Electrical System Drawing and Power Analysi > >Suggestions: >Replace the 15A E-Bus fuse with a fusible link. It is not good practice t o have fuses in series. >Locate the E-Bus relay near the battery bus. >In the event of over voltage, the crowbar module will smoke. >Protect it with a 3 amp fuse or circuit breaker. >The 2A fuse in the battery contactor coil circuit is a good idea. >It will protect against reversed battery polarity. (It happens) >Consider using a Hall Effect sensor instead of a shunt, if compatible with your Dynon. >The starter contactor diode is wired wrong. Connect the banded end to the "S" terminal. >Connect the other end of the diode to the other end of the contactor coil (ground). > >-------- >Joe Gores > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=512985#512985 > > ________________________________________________________________________________
Date: Dec 30, 2023
Subject: Data logger for DC volts and amps
Does anyone know of a device that will keep a log of current draw in the .05-5A range, for 12-24 hours or so? I'm trying to troubleshoot an intermittent battery drain but the usual multimeter requires me being there and looking at it. The best alternative I have come up with so far is to point a video camera at the multimeter but there must be a gadget for this. ________________________________________________________________________________
Analysi
Date: Dec 30, 2023
> Could you please tell me what problem you see with the relay beside the endurance bus rather than the battery bus? The pilot should have the ability to shut off all electrical power as close to the source(s) as possible. This is especially important in the event of smoke in the cockpit or an imminent forced landing. Avoid installing always-hot wires any distance from the battery, especially near the engine. A NTSB accident inspector once commented that fires are unlikely if the battery is thrown clear of the wreckage. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=512989#512989 ________________________________________________________________________________
Subject: Re: Data logger for DC volts and amps
Date: Dec 30, 2023
Here are a couple of other ideas: Put a very small fuse in series with the battery cable. If the fuse blows, you will know that current was flowing. Digikey 486-7110-1-ND . Put an analog wrist watch in series with the battery cable. Put a forward biased diode in parallel with the watch to limit the voltage across the watch. If the time on the watch changes, current was flowing. . Just don't turn the master switch on while testing. :-) -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=512990#512990 ________________________________________________________________________________
Date: Dec 30, 2023
On 12/30/2023 10:26 AM, Jared Yates wrote: > Does anyone know of a device that will keep a log of current draw in > the .05-5A range, for 12-24 hours or so? I'm trying to troubleshoot an > intermittent battery drain but the usual multimeter requires me being > there and looking at it. The best alternative I have come up with so > far is to point a video camera at the multimeter but there must be a > gadget for this. Maybe omething like this: https://www.amazon.com/Triplett-VDL48-Voltage-USB-Datalogger/dp/B0CFCBXKRH/ref=sr_1_3?adgrpid=1225955794707457&hvadid=76622403291054&hvbmt=bp&hvdev=c&hvlocphy=94237&hvnetw=s&hvqmt=p&hvtargid=kwd-76622497037322%3Aloc-190&hydadcr=13412_13504749&keywords=data+logger+voltage&qid=1703961567&sr=8-3 But too expensive for my taste. I would use an Arduino Nano connected to a laptop or computer. Yes, you'd need a resistor (shunt) to convert current into voltage. Program would just be a loop to monitor one of the Nano's A/D channels. If the A/D value read exceeds the limit you set, output the value to the Arduino Serial Monitor with the Nano to Laptop USB cable. I think the Nano can do close to 4,000 samples per second (0.00025 seconds/sample) which I think would be sufficient to catch any event. If you don't want it connected to a laptop, you'd need an SDCard shield for the Nano so you can log the events to that. I now see that US-sold Nano's apparently have gotten ridiculously expensive ($25) at some sellers. But you can get them on eBay for $2 shipped if you're willing to wait for it to arrive from China. I also see that some come with screw terminals if you don't like soldering. Finn ________________________________________________________________________________
Date: Dec 30, 2023
I know this is an English site, but similar devices must be available in the US. https://www.geminidataloggers.com/data-loggers Look under =9CTinytag Instrumentation=9D We use their temperature loggers at work, they are very reliable. From: owner-aeroelectric-list-server(at)matronics.com On Behalf Of Jared Yates Sent: Saturday, December 30, 2023 3:26 PM Subject: AeroElectric-List: Data logger for DC volts and amps Does anyone know of a device that will keep a log of current draw in the .05-5A range, for 12-24 hours or so? I'm trying to troubleshoot an intermittent battery drain but the usual multimeter requires me being there and looking at it. The best alternative I have come up with so far is to point a video camera at the multimeter but there must be a gadget for this. ________________________________________________________________________________
Subject: Tailwind Electrical System Drawing and Power
Analysis
Date: Dec 30, 2023
Gerry, In your initial post you asked for =9Ca good critique=9D of your system, please take these comments in the supportive way they are intended You are building a lot of redundancy (along with complexity and cost) into your system that may not be required by the purpose for which you intend to use the airplane. If you just want the redundancy, and will tolerate the complexity and cost, then ignore what I have written below. Certified installations are required to operate for no less than 30 minutes following loss of the alternator. There are various rules concerning how to calculate that endurance, but if your system can run for 45 minutes on around 50% of the name plate battery capacity then you are in about the right place. Your planned usage doesn=99t really need two alternators and may not need 2 busbars. The things that will cause you the most problems are engine reliability, maintaining control of the airplane and then electrical reliability. We=99re not really concerned with conventional engine reliability here. Fitting an attitude indicator like a Garmin G5 (or similar with on-board sensors and back-up battery) will provide *a lot* of redundancy. It may be you could tolerate one bus bar and a POH list of stuff to turn off if the alternator quits. The assumption is if the electrical supply is lost you will always be within no less than 30 minutes flying time of an acceptable alternate. Actually, with aggressive load shedding, you will almost certainly be able to burn all the fuel you have on board before the battery runs out of juice, IMC, IFR or VMC. In a Tailwind you should be able to fly 50+ miles, and make an approach, in 30 minutes. In actuality you should be able to fly for an hour or two. Take a step back and look at the design of the whole electrical system. Considering your intended usage do you really need all the complexity you have designed into it? Will a single main battery, single alternator, single busbar, battery backed-up AI system satisfy you needs? What hazard is the 2 alternator, 3 busbar system you have drawn intended to mitigate? Peter Battery capacity =93 many battery manufacturers are not entirely helpful with their nameplate battery capacities with the makers of the Odyssey series top of the list. The stated capacity is sometimes at the 10 or 20 hour rate, so the power provided if discharged over that time. For our purposes the one hour, or even the 30 minute rate is what is important. That number is usually less than the number quoted in the sales literature. For a PC680 (nominally a 17AH battery) the one hour rate is around 12Ah. Battery endurance calculations assume a battery with 80% capacity (so shortly before replacement) with 10% charge used on the ground, so take 72% of the one hour rate (8.6 Ah for a PC680). =9CAircraft=9D battery makers are usually a little more helpful. There are also guidelines on how quickly to assume the pilot can carry out any loadshedding. From: owner-aeroelectric-list-server(at)matronics.com On Behalf Of Gerry van Dyk Sent: Friday, December 29, 2023 7:57 PM Subject: Re[5]: AeroElectric-List: Tailwind Electrical System Drawing and Power Analysis It will be for mainly VFR touring and vacation, IFR Training and eventually IFR travel though VFR will be preferred over IFR. The VFR weekend breakfast flyins and hambergers will likely be the bulk of service. I want the personal rating and currency and the airplane's IFR capability to be there the 2 or 3 time per year when it's likely to be required. Like an annual pilgrimage to Osh. I don't want to be stranded for weather that's overcast but otherwise fairly benign. Does that answer the question? Gerry ------ Original Message ------ >From "Peter Pengilly" <peter(at)sportingaero.com > To "Aeroelectric List (aeroelectric-list(at)matronics.com )" > Date 2023-12-29 12:44:19 PM Subject Re: Re[3]: AeroElectric-List: Tailwind Electrical System Drawing and Power Analysis Gerry, before looking at the details what are you planning to use the airplane for? What do you want the system to do? Long range IFR touring, medium range VFR/occasional IFR touring and VFR hamburger runs, something else? Peter On Fri, 29 Dec 2023, 19:27 Gerry van Dyk, > wrote: Hello again all Peter I'll follow-up here on those couple of points... I've attached the latest revision to my architecture. Thinking about what you've suggested, separating the main alternator to it's own switch, I've done so, and it cleans up both the drawing and the electrical system quite a bit. Effectively what we've done is separate the "battery / alt / DC power" switch shown on the Z13/8 drawing into two. I've got a keyed switch which I want for some basic theft deterrence, and then the main alt switch. In operation we'll turn on the main bus, which will mean the entire panel will be up. The big consumers will of course be off, pitot heat, exterior lighting, AP servos, boost fuel pump, and the radios will be in passive receive mode. At this point we'd close the ebus / aux alt switch and start the engine. Dynon says this will not bring down the EFIS's so with the EMS operating we should see the aux alternator bump the voltage, I'd flip the switch on and off if need be to see this change. Satisfied that the aux alternator is operating we'll then bring the main alternator online and turn the e-bus / aux alt switch off. Or I may come around on leaving it on for normal operations. For alternator-out condition: turn the e-bus / aux alt switch on, open the main battery switch, dropping out the battery contactor and therefor the main bus. If the main alt has failed or thrown the belt, it won't matter much if we turn off the main alt switch or not. What are your thoughts on this layout? I known I haven't used all your suggestions, I hope you take no offense to it, I think some were moving away from the original Z13/8 philosophy which I do rather agree with. Best regards Gerry ------ Original Message ------ >From "Gerry van Dyk" <gerry.vandyk(at)eastlink.ca > To aeroelectric-list(at)matronics.com Date 2023-12-29 8:12:00 AM Subject Re[2]: AeroElectric-List: Tailwind Electrical System Drawing and Power Analysis Hi Peter, thanks for your thoughts. Why do you want to switch the SD-8 alternator? because it is shown on the original Z-13/8 drawing. I'm working from rev T 1/07/14. Is there a later revision with this switch removed? Why switch battery power to the bus twice? As I mentioned, I want to start the engine on the E-bus. I need to supply power to the starter, but leave the main bus un-powered, in order to check the function of SD-8. Supplying starting power through the E-bus seems impractical. Use an externally regulated main alternator to avoid having to switch the alternator output. Yeah, I'm hamstringing myself a little bit here. I bought the AL 12-E160 alt several years ago, I don't have a spare couple thousand dollars to buy another. I'll have to think about it better, but on the face of it, having a separate regulator doesn't seem to change how the alternator is controlled. Mr. Nuckolls has mentioned on many occasions that we want to have definite control of the alternator output with a switch in the cockpit. Z12/8 shows this switch in the center of the drawing. Provide a method to connect the battery directly to the bus. (I presume your're talking about the main bus here.) Perhaps I'm being foolish here. I'm placing an absolute requirement to check the operation of the backup alternator at the beginning of every flight. My life will depend on it should the main alternator fail. With the main bus and main alternator connected directly to the battery contactor they will be running at startup. As yet I don't see a way to check the backup alternator operation with the main's running. I'd like to do so without turning half the panel on-off-on during startup. Do not use a diode in the feed to the essential bus. This diode is called for by B&C on their installation drawing 504-500, and they provide it in the kit. What would be the reason to remove it? There are a number of services connected directly to the battery just waiting to flatten it Quite right, and this duplicates what's shown on Z13-8. They are a couple of conveniences, loading the baggage compartment, charging a phone etc, without having to turn on the battery master and it's relatively large current draw. In building my panel, all switches will be down=off, and they're all in two rows so visually obvious when left on. I'll have to have a quick scan of the panel when leaving the airplane, and if I flatten the battery by mistake, my fault. If the voltage of the SD8 is set (say) 0.2v lower than the main alternator it will not produce power if the main is on line. If the main fails it takes up the load. I presume you are making another case for removing the backup alt switch. Again, it is called for on Z13/8, but your point is well taken. For my liking you have too many relays between the battery and the bus bar. I absolutely agree, I haven't yet come up with an elegant solution to check the backup alternator without cycling the avionics. If you use an externally regulated main alternator then initially only switch on the SD8 on start up. Then power up the main alternator regulator and bring that on line. I think we've covered this already. In order to start the engine I need to switch on the battery contactor, which would also bring the main bus and main alt online. I could move the starter wire to the always-hot side of the battery contactor, so the mains are still inop, but with that wire permanently hot, and 2 gauge wire at that, it violates the idea of making the electrical system as inert as possible in a forced landing. Again, I don't see the difference between an externally or internally regulated alternator. The red wire to lead 1 on the alt connector is the equivalent of the A wire on an external regulator, the jumper is the same as one to the S wire, and the F wire is internal. Peter, writing this is making me think about separating the main alt control to a separate switch. Let me think that through a bit and I'll report back later. Install a switch that powers up the essential (or main) bus directly from the battery, if the switch is a double pole use the second pole to disable the starter. Interesting, I'll think that out as well. The large diode in the feed line to the essential bus will always drop the voltage by an amount. The benefit is auto load shedding but do you need that with 2 alternators? If you really want to shed the main bus use a large switch and ensure there is a path to the essential bus directly from the battery. I used to have a feed diode and would not use one again. Yes, I believe it is necessary. 8 amps will not power the entire panel, so the load shedding is still valid. Incidentally, I discovered on the SD-8 literature that a Lycoming will need to run at 2500 rpm to get the full 8 amps out of the SD-8. it's looking like about 6.8 amps at 2300 rpm. Your suggestion will mean both main and E-bus need to be switched on for normal operations. Bob has made note on many of his drawings that "all buses are on when the main is on". I've had that in mind when drawing this up. Having the E-bus switched on for normal ops means the backup alternator is always running, though as you've suggested it can be set lower than the main, and loaf along in the background. I need to get my head around this idea. A diode is very beneficial on the starter contactor. That's a whoops, should have added it to the drawing, I'll get it on there. Having a low voltage waring that is independent of the EFIS is useful. It is possible you will get immune to EFIS warnings Yes, I do agree here. I was hoping the 'alt out light' function of the main alternator would be a 'low voltage monitor' as B&C does on their newer AVC regulator. After exchanging a couple of emails with Tim at Plane Power, it indeed only sees the output within the alternator, nothing outside. I've already got the Dynon EMS with all the engine sensors, so it makes some sense to use what I've got. My thinking is if it becomes annoying I can add the separate voltage monitoring system after the fact. Tim at PP did mention that he regularly sees OBAM guys using the EFIS for voltage monitoring, and all too often they've got parameters set way too stringent, and get many nuisance warnings. As yet I haven't investigated what parameters and settings I can work with, so the ex4899258752836872026xb32b8cd5421647c9b8b804b1366feb00"> Thanks very much for the thoughts Peter. It's very useful to think through the questions and comments. Cheers Gerry ------ Original Message ------ >From "Peter Pengilly" <peter(at)sportingaero.com > To aeroelectric-list(at)matronics.com Date 2023-12-29 2:11:12 AM Subject RE: AeroElectric-List: Tailwind Electrical System Drawing and Power Analysis Why do you want to switch the SD-8 alternator? Why switch battery power to the bus twice? Use an externally regulated main alternator to avoid having to switch the alternator output. Provide a method to connect the battery directly to the bus. Do not use a diode in the feed to the essential bus. There are a number of services connected directly to the battery just waiting to flatten it If the voltage of the SD8 is set (say) 0.2v lower than the main alternator it will not produce power if the main is on line. If the main fails it takes up the load. For my liking you have too many relays between the battery and the bus bar. If you use an externally regulated main alternator then initially only switch on the SD8 on start up. Then power up the main alternator regulator and bring that on line. Install a switch that powers up the essential (or main) bus directly from the battery, if the switch is a double pole use the second pole to disable the starter. The large diode in the feed line to the essential bus will always drop the voltage by an amount. The benefit is auto load shedding but do you need that with 2 alternators? If you really want to shed the main bus use a large switch and ensure there is a path to the essential bus directly from the battery. I used to have a feed diode and would not use one again. A diode is very beneficial on the starter contactor. Having a low voltage waring that is independent of the EFIS is useful. It is possible you will get immune to EFIS warnings Peter From: owner-aeroelectric-list-server(at)matronics.com > On Behalf Of Gerry van Dyk Sent: Thursday, December 28, 2023 11:32 PM Subject: AeroElectric-List: Tailwind Electrical System Drawing and Power Analysis Hello again all Well, I think I'm ready for a good critique on my proposed electrical system for my Tailwind project. For the most part it's based on Z13/8, we're using a Plane Power AL12-E160 primary alternator, and of course the B&C SD-8 backup alternator. The E160 is internally regulated, and also has an internal crowbar system and alt-out panel light output, which I intend to use. The SD-8 has their older PMR1 regulator, so we've got the external crowbar module and no voltage sensing. I've drawn these items as shown on their respective install instructions call for. As I mentioned earlier, I intended to start the engine on the endurance bus, and check the SD-8 operation during the startup procedure. I had neglected to think about where the starter was going to get power from, so the idea has forced an additional switch and relay (a rather robust one at that) to run the main bus. The battery contactor would be closed for startup, then the SD-8 operation checked and finally the main bus would be brought up to begin normal operation. I'm a little uneasy about this extra switching, as I know this group is inclined toward fewer failure points, and with good reason. As I look at the 'textbook' Z13/8 drawing, with my dual EFIS, IFR capable panel in mind, it seems to me that a startup would bring the entire panel up with the main bus, then with the engine running I'd have to close the E-bus switch, open the battery contactor, dropping out half the instrument panel. Then check the backup alternator operation, and finally reboot the rest of the panel again. It just really feels rather clunky to me. Bob, have I missed something with the original architecture concept? Is there a way to check the backup alternator function while the main bus is up and running? It would certainly help me simplify my system. I'd appreciate if you good folks would give my drawing a good review. Questions, comments and critiques are all welcome. Thanks again Gerry van Dyk Tailwind C-GVDZ ________________________________________________________________________________
Analysis
Date: Dec 30, 2023
Gerry, I don=99t mind if you ignore all or anything I write! It is your airplane after all. I think you are overstating the situation by saying your life may depend on the SD8 operating correctly. With aggressive load shedding, and particularly in VMC, you will be able to fly for an hour or two on the battery. Being able to turn off the battery contactor will remove (around) 1A of draw from the system, so being able to connect the battery to the bus bar (for low draw services, say up to 20A) can be beneficial. Peter From: owner-aeroelectric-list-server(at)matronics.com On Behalf Of Gerry van Dyk Sent: Friday, December 29, 2023 7:18 PM Subject: Re[3]: AeroElectric-List: Tailwind Electrical System Drawing and Power Analysis Hello again all Peter I'll follow-up here on those couple of points... I've attached the latest revision to my architecture. Thinking about what you've suggested, separating the main alternator to it's own switch, I've done so, and it cleans up both the drawing and the electrical system quite a bit. Effectively what we've done is separate the "battery / alt / DC power" switch shown on the Z13/8 drawing into two. I've got a keyed switch which I want for some basic theft deterrence, and then the main alt switch. In operation we'll turn on the main bus, which will mean the entire panel will be up. The big consumers will of course be off, pitot heat, exterior lighting, AP servos, boost fuel pump, and the radios will be in passive receive mode. At this point we'd close the ebus / aux alt switch and start the engine. Dynon says this will not bring down the EFIS's so with the EMS operating we should see the aux alternator bump the voltage, I'd flip the switch on and off if need be to see this change. Satisfied that the aux alternator is operating we'll then bring the main alternator online and turn the e-bus / aux alt switch off. Or I may come around on leaving it on for normal operations. For alternator-out condition: turn the e-bus / aux alt switch on, open the main battery switch, dropping out the battery contactor and therefor the main bus. If the main alt has failed or thrown the belt, it won't matter much if we turn off the main alt switch or not. What are your thoughts on this layout? I known I haven't used all your suggestions, I hope you take no offense to it, I think some were moving away from the original Z13/8 philosophy which I do rather agree with. Best regards Gerry ------ Original Message ------ >From "Gerry van Dyk" <gerry.vandyk(at)eastlink.ca > To aeroelectric-list(at)matronics.com Date 2023-12-29 8:12:00 AM Subject Re[2]: AeroElectric-List: Tailwind Electrical System Drawing and Power Analysis Hi Peter, thanks for your thoughts. Why do you want to switch the SD-8 alternator? because it is shown on the original Z-13/8 drawing. I'm working from rev T 1/07/14. Is there a later revision with this switch removed? Why switch battery power to the bus twice? As I mentioned, I want to start the engine on the E-bus. I need to supply power to the starter, but leave the main bus un-powered, in order to check the function of SD-8. Supplying starting power through the E-bus seems impractical. Use an externally regulated main alternator to avoid having to switch the alternator output. Yeah, I'm hamstringing myself a little bit here. I bought the AL 12-E160 alt several years ago, I don't have a spare couple thousand dollars to buy another. I'll have to think about it better, but on the face of it, having a separate regulator doesn't seem to change how the alternator is controlled. Mr. Nuckolls has mentioned on many occasions that we want to have definite control of the alternator output with a switch in the cockpit. Z12/8 shows this switch in the center of the drawing. Provide a method to connect the battery directly to the bus. (I presume your're talking about the main bus here.) Perhaps I'm being foolish here. I'm placing an absolute requirement to check the operation of the backup alternator at the beginning of every flight. My life will depend on it should the main alternator fail. With the main bus and main alternator connected directly to the battery contactor they will be running at startup. As yet I don't see a way to check the backup alternator operation with the main's running. I'd like to do so without turning half the panel on-off-on during startup. Do not use a diode in the feed to the essential bus. This diode is called for by B&C on their installation drawing 504-500, and they provide it in the kit. What would be the reason to remove it? There are a number of services connected directly to the battery just waiting to flatten it Quite right, and this duplicates what's shown on Z13-8. They are a couple of conveniences, loading the baggage compartment, charging a phone etc, without having to turn on the battery master and it's relatively large current draw. In building my panel, all switches will be down=off, and they're all in two rows so visually obvious when left on. I'll have to have a quick scan of the panel when leaving the airplane, and if I flatten the battery by mistake, my fault. If the voltage of the SD8 is set (say) 0.2v lower than the main alternator it will not produce power if the main is on line. If the main fails it takes up the load. I presume you are making another case for removing the backup alt switch. Again, it is called for on Z13/8, but your point is well taken. For my liking you have too many relays between the battery and the bus bar. I absolutely agree, I haven't yet come up with an elegant solution to check the backup alternator without cycling the avionics. If you use an externally regulated main alternator then initially only switch on the SD8 on start up. Then power up the main alternator regulator and bring that on line. I think we've covered this already. In order to start the engine I need to switch on the battery contactor, which would also bring the main bus and main alt online. I could move the starter wire to the always-hot side of the battery contactor, so the mains are still inop, but with that wire permanently hot, and 2 gauge wire at that, it violates the idea of making the electrical system as inert as possible in a forced landing. Again, I don't see the difference between an externally or internally regulated alternator. The red wire to lead 1 on the alt connector is the equivalent of the A wire on an external regulator, the jumper is the same as one to the S wire, and the F wire is internal. Peter, writing this is making me think about separating the main alt control to a separate switch. Let me think that through a bit and I'll report back later. Install a switch that powers up the essential (or main) bus directly from the battery, if the switch is a double pole use the second pole to disable the starter. Interesting, I'll think that out as well. The large diode in the feed line to the essential bus will always drop the voltage by an amount. The benefit is auto load shedding but do you need that with 2 alternators? If you really want to shed the main bus use a large switch and ensure there is a path to the essential bus directly from the battery. I used to have a feed diode and would not use one again. Yes, I believe it is necessary. 8 amps will not power the entire panel, so the load shedding is still valid. Incidentally, I discovered on the SD-8 literature that a Lycoming will need to run at 2500 rpm to get the full 8 amps out of the SD-8. it's looking like about 6.8 amps at 2300 rpm. Your suggestion will mean both main and E-bus need to be switched on for normal operations. Bob has made note on many of his drawings that "all buses are on when the main is on". I've had that in mind when drawing this up. Having the E-bus switched on for normal ops means the backup alternator is always running, though as you've suggested it can be set lower than the main, and loaf along in the background. I need to get my head around this idea. A diode is very beneficial on the starter contactor. That's a whoops, should have added it to the drawing, I'll get it on there. Having a low voltage waring that is independent of the EFIS is useful. It is possible you will get immune to EFIS warnings Yes, I do agree here. I was hoping the 'alt out light' function of the main alternator would be a 'low voltage monitor' as B&C does on their newer AVC regulator. After exchanging a couple of emails with Tim at Plane Power, it indeed only sees the output within the alternator, nothing outside. I've already got the Dynon EMS with all the engine sensors, so it makes some sense to use what I've got. My thinking is if it becomes annoying I can add the separate voltage monitoring system after the fact. Tim at PP did mention that he regularly sees OBAM guys using the EFIS for voltage monitoring, and all too often they've got parameters set way too stringent, and get many nuisance warnings. As yet I haven't investigated what parameters and settings I can work with, so the external LV warning is always on the table. Thanks very much for the thoughts Peter. It's very useful to think through the questions and comments. Cheers Gerry ------ Original Message ------ >From "Peter Pengilly" <peter(at)sportingaero.com > To aeroelectric-list(at)matronics.com Date 2023-12-29 2:11:12 AM Subject RE: AeroElectric-List: Tailwind Electrical System Drawing and Power Analysis Why do you want to switch the SD-8 alternator? Why switch battery power to the bus twice? Use an externally regulated main alternator to avoid having to switch the alternator output. Provide a method to connect the battery directly to the bus. Do not use a diode in the feed to the essential bus. There are a number of services connected directly to the battery just waiting to flatten it If the voltage of the SD8 is set (say) 0.2v lower than the main alternator it will not produce power if the main is on line. If the main fails it takes up the load. For my liking you have too many relays between the battery and the bus bar. If you use an externally regulated main alternator then initially only switch on the SD8 on start up. Then power up the main alternator regulator and bring that on line. Install a switch that powers up the essential (or main) bus directly from the battery, if the switch is a double pole use the second pole to disable the starter. The large diode in the feed line to the essential bus will always drop the voltage by an amount. The benefit is auto load shedding but do you need that with 2 alternators? If you really want to shed the main bus use a large switch and ensure there is a path to the essential bus directly from the battery. I used to have a feed diode and would not use one again. A diode is very beneficial on the starter contactor. Having a low voltage waring that is independent of the EFIS is useful. It is possible you will get immune to EFIS warnings Peter From: owner-aeroelectric-list-server(at)matronics.com > On Behalf Of Gerry van Dyk Sent: Thursday, December 28, 2023 11:32 PM Subject: AeroElectric-List: Tailwind Electrical System Drawing and Power Analysis Hello again all Well, I think I'm ready for a good critique on my proposed electrical system for my Tailwind project. For the most part it's based on Z13/8, we're using a Plane Power AL12-E160 primary alternator, and of course the B&C SD-8 backup alternator. The E160 is internally regulated, and also has an internal crowbar system and alt-out panel light output, which I intend to use. The SD-8 has their older PMR1 regulator, so we've got the external crowbar module and no voltage sensing. I've drawn these items as shown on their respective install instructions call for. As I mentioned earlier, I intended to start the engine on the endurance bus, and check the SD-8 operation during the startup procedure. I had neglected to think about where the starter was going to get power from, so the idea has forced an additional switch and relay (a rather robust one at that) to run the main bus. The battery contactor would be closed for startup, then the SD-8 operation checked and finally the main bus would be brought up to begin normal operation. I'm a little uneasy about this extra switching, as I know this group is inclined toward fewer failure points, and with good reason. As I look at the 'textbook' Z13/8 drawing, with my dual EFIS, IFR capable panel in mind, it seems to me that a startup would bring the entire panel up with the main bus, then with the engine running I'd have to close the E-bus switch, open the battery contactor, dropping out half the instrument panel. Then check the backup alternator operation, and finally reboot the rest of the panel again. It just really feels rather clunky to me. Bob, have I missed something with the original architecture concept? Is there a way to check the backup alternator function while the main bus is up and running? It would certainly help me simplify my system. I'd appreciate if you good folks would give my drawing a good review. Questions, comments and critiques are all welcome. Thanks again Gerry van Dyk Tailwind C-GVDZ ________________________________________________________________________________
From: "Gerry van Dyk" <gerry.vandyk(at)eastlink.ca>
Analysis
Date: Dec 30, 2023
No worries Peter, all fair points. A little background on myself for you. I am an engineer and draftsman by trade. That along with a Dutch heritage, it is absolutely fair to say I AM STUBBORN! ;^) For the last 10 years or so while I've been building I've been following along the AE list and reading the AEC. Mr Nuckolls has been recommending Z13/8 as the most bang for the buck, and I certainly agree with the idea. Along the way I've been collecting all the parts to build the system. The two alternators have been bolted to the engine for a couple of years. Quick segue for a moment. I've always owned vehicles with 4 seats. For most of my life I've owned pickup trucks. It is shocking how rarely I carry even 1 passenger, and 4 people is more rare than a blue moon. Even carrying something in the back of the truck isn't that common, yet I, like many other people, think nothing of selecting such a vehicle, just for the utility when it comes up. Back on point... I've had some friends have issues with Transport Canada getting the 'no IFR' clause removed from the limitations on their flight permits. Though the rules are murky, transport usually cites redundancy of systems. I've heard of one occasion where a guy needed to put an altitude encoder into his airplane, so the altitude signal went to the encoder, was converted to grey code and then passed on to the efis which had to decode it back to the signal it was expecting in the first place. The inspected remembered some 30 year old guidance document from Transport that this was required, and weather or not the thing was still in force, (it was most certainly obsolete) when the inspector writes it up, we must comply or be denied. Actually that fellow installed the encoder, showed the inspector for the signoff, then promptly removed it before going flying. These are the things we must do to satisfy bureaucrats all over the world. In my mind, being able to show a system with two approach certified VORs, one approach certified GPS, plus a triple redundant power supply should make the IFR signoff relatively easy. And because I've been studying the drawings for so long, it does indeed give me comfort in the system. As for acutally using the airplane for IFR, I indeed class it the same as owning a four seat pickup truck. Rarely ever used, but there when I need it. And to be sure, I still need to earn the rating, and keep current, so I suspect I'll fly under the hood more often than I've carried lumber in the truck. ;^) As for the extra bus, the battery bus is really only there for the convenience of charging a phone now and then, and lighting the baggabe bay when loading up in the wee hours of the morning before a trip. I could easily function without it, but I suspect I'll use it about as often as I fly in actual IMC. Yeah, it's a bit of overkill, but it's what I've been working towards for years, so changing the system, pulling parts off the engine, and ignoring the parts already on the shelf would really be against my nature. ;^) Thanks for the thoughts Peter. It is wise to give some sober thought to what the hell we're doing once in a while. For what it's worth, I've got a rebuild project on a Mong Sport biplane in the wings. It'll have a simple 8 amp alternator, battery and starter circuit, and a small efis with a couple of analog instruments, because I have no delusions of flying that airplane for anything more than an afternoon of giggles. ;^) Best regards Gerry ------ Original Message ------ >From "Peter Pengilly" <Peter(at)sportingaero.com> To aeroelectric-list(at)matronics.com Date 2023-12-30 3:35:32 PM Subject RE: Re[5]: AeroElectric-List: Tailwind Electrical System Drawing and Power Analysis >Gerry, > > >In your initial post you asked for =9Ca good critique=9D of yo ur system, >please take these comments in the supportive way they are intended You >are building a lot of redundancy (along with complexity and cost) into >your system that may not be required by the purpose for which you >intend to use the airplane. If you just want the redundancy, and will >tolerate the complexity and cost, then ignore what I have written >below. > > >Certified installations are required to operate for no less than 30 >minutes following loss of the alternator. There are various rules >concerning how to calculate that endurance, but if your system can run >for 45 minutes on around 50% of the name plate battery capacity then >you are in about the right place. Your planned usage doesn=99t reall y >need two alternators and may not need 2 busbars. The things that will >cause you the most problems are engine reliability, maintaining control >of the airplane and then electrical reliability. We=99re not really >concerned with conventional engine reliability here. Fitting an >attitude indicator like a Garmin G5 (or similar with on-board sensors >and back-up battery) will provide *a lot* of redundancy. It may be you >could tolerate one bus bar and a POH list of stuff to turn off if the >alternator quits. > > >The assumption is if the electrical supply is lost you will always be >within no less than 30 minutes flying time of an acceptable alternate. >Actually, with aggressive load shedding, you will almost certainly be >able to burn all the fuel you have on board before the battery runs out >of juice, IMC, IFR or VMC. In a Tailwind you should be able to fly 50+ >miles, and make an approach, in 30 minutes. In actuality you should be >able to fly for an hour or two. > > >Take a step back and look at the design of the whole electrical system. >Considering your intended usage do you really need all the complexity >you have designed into it? Will a single main battery, single >alternator, single busbar, battery backed-up AI system satisfy you >needs? What hazard is the 2 alternator, 3 busbar system you have drawn >intended to mitigate? > > >Peter > > >Battery capacity =93 many battery manufacturers are not entirely hel pful >with their nameplate battery capacities with the makers of the Odyssey >series top of the list. The stated capacity is sometimes at the 10 or >20 hour rate, so the power provided if discharged over that time. For >our purposes the one hour, or even the 30 minute rate is what is >important. That number is usually less than the number quoted in the >sales literature. For a PC680 (nominally a 17AH battery) the one hour >rate is around 12Ah. Battery endurance calculations assume a battery >with 80% capacity (so shortly before replacement) with 10% charge used >on the ground, so take 72% of the one hour rate (8.6 Ah for a PC680). >=9CAircraft=9D battery makers are usually a little more helpfu l. There are >also guidelines on how quickly to assume the pilot can carry out any >loadshedding. > > >From:owner-aeroelectric-list-server(at)matronics.com > On Behalf Of Gerry van >Dyk >Sent: Friday, December 29, 2023 7:57 PM >To:aeroelectric-list(at)matronics.com >Subject: Re[5]: AeroElectric-List: Tailwind Electrical System Drawing >and Power Analysis > > >It will be for mainly VFR touring and vacation, IFR Training and >eventually IFR travel though VFR will be preferred over IFR. The VFR >weekend breakfast flyins and hambergers will likely be the bulk of >service. I want the personal rating and currency and the airplane's >IFR capability to be there the 2 or 3 time per year when it's likely to >be required. Like an annual pilgrimage to Osh. I don't want to be >stranded for weather that's overcast but otherwise fairly benign. > > >Does that answer the question? > >Gerry > > >------ Original Message ------ > >From "Peter Pengilly" <peter(at)sportingaero.com> > >To "Aeroelectric List (aeroelectric-list(at)matronics.com)" > > >Date 2023-12-29 12:44:19 PM > >Subject Re: Re[3]: AeroElectric-List: Tailwind Electrical System >Drawing and Power Analysis > > >>Gerry, before looking at the details what are you planning to use the >>airplane for? What do you want the system to do? >> >>Long range IFR touring, medium range VFR/occasional IFR touring and >>VFR hamburger runs, something else? Peter >> >> >> >>On Fri, 29 Dec 2023, 19:27 Gerry van Dyk, >>wrote: >> >>>Hello again all >>> >>>Peter I'll follow-up here on those couple of points... >>> >>> >>> >>>I've attached the latest revision to my architecture. Thinking about >>>what you've suggested, separating the main alternator to it's own >>>switch, I've done so, and it cleans up both the drawing and the >>>electrical system quite a bit. Effectively what we've done is >>>separate the "battery / alt / DC power" switch shown on the Z13/8 >>>drawing into two. I've got a keyed switch which I want for some >>>basic theft deterrence, and then the main alt switch. >>> >>> >>> >>>In operation we'll turn on the main bus, which will mean the entire >>>panel will be up. The big consumers will of course be off, pitot >>>heat, exterior lighting, AP servos, boost fuel pump, and the radios >>>will be in passive receive mode. At this point we'd close the ebus / >>>aux alt switch and start the engine. Dynon says this will not bring >>>down the EFIS's so with the EMS operating we should see the aux >>>alternator bump the voltage, I'd flip the switch on and off if need >>>be to see this change. Satisfied that the aux alternator is >>>operating we'll then bring the main alternator online and turn the >>>e-bus / aux alt switch off. Or I may come around on leaving it on >>>for normal operations. >>> >>> >>> >>>For alternator-out condition: turn the e-bus / aux alt switch on, >>>open the main battery switch, dropping out the battery contactor and >>>therefor the main bus. If the main alt has failed or thrown the >>>belt, it won't matter much if we turn off the main alt switch or not. >>> >>> >>> >>>What are your thoughts on this layout? I known I haven't used all >>>your suggestions, I hope you take no offense to it, I think some were >>>moving away from the original Z13/8 philosophy which I do rather >>>agree with. >>> >>> >>> >>>Best regards >>> >>>Gerry >>> >>> >>> >>> >>> >>>------ Original Message ------ >>> >>>From "Gerry van Dyk" <gerry.vandyk(at)eastlink.ca> >>> >>>To aeroelectric-list(at)matronics.com >>> >>>Date 2023-12-29 8:12:00 AM >>> >>>Subject Re[2]: AeroElectric-List: Tailwind Electrical System Drawing >>>and Power Analysis >>> >>> >>> >>>>Hi Peter, thanks for your thoughts. >>>> >>>>Why do you want to switch the SD-8 alternator? >>>> >>>>because it is shown on the original Z-13/8 drawing. I'm working >>>>from rev T 1/07/14. Is there a later revision with this switch >>>>removed? >>>> >>>>Why switch battery power to the bus twice? >>>> >>>>As I mentioned, I want to start the engine on the E-bus. I need to >>>>supply power to the starter, but leave the main bus un-powered, in >>>>order to check the function of SD-8. Supplying starting power >>>>through the E-bus seems impractical. >>>> >>>>Use an externally regulated main alternator to avoid having to >>>>switch the alternator output. >>>> >>>>Yeah, I'm hamstringing myself a little bit here. I bought the AL >>>>12-E160 alt several years ago, I don't have a spare couple thousand >>>>dollars to buy another. I'll have to think about it better, but on >>>>the face of it, having a separate regulator doesn't seem to change >>>>how the alternator is controlled. Mr. Nuckolls has mentioned on >>>>many occasions that we want to have definite control of the >>>>alternator output with a switch in the cockpit. Z12/8 shows this >>>>switch in the center of the drawing. >>>> >>>>Provide a method to connect the battery directly to the bus. (I >>>>presume your're talking about the main bus here.) >>>> >>>>Perhaps I'm being foolish here. I'm placing an absolute requirement >>>>to check the operation of the backup alternator at the beginning of >>>>every flight. My life will depend on it should the main alternator >>>>fail. With the main bus and main alternator connected directly to >>>>the battery contactor they will be running at startup. As yet I >>>>don't see a way to check the backup alternator operation with the >>>>main's running. I'd like to do so without turning half the panel >>>>on-off-on during startup. >>>> >>>>Do not use a diode in the feed to the essential bus. >>>> >>>>This diode is called for by B&C on their installation drawing >>>>504-500, and they provide it in the kit. What would be the reason >>>>to remove it? >>>> >>>>There are a number of services connected directly to the battery >>>>just waiting to flatten it >>>> >>>>Quite right, and this duplicates what's shown on Z13-8. They are a >>>>couple of conveniences, loading the baggage compartment, charging a >>>>phone etc, without having to turn on the battery master and it's >>>>relatively large current draw. In building my panel, all switches >>>>will be down=off, and they're all in two rows so visually obvious >>>>when left on. I'll have to have a quick scan of the panel when >>>>leaving the airplane, and if I flatten the battery by mistake, my >>>>fault. >>>> >>>>If the voltage of the SD8 is set (say) 0.2v lower than the main >>>>alternator it will not produce power if the main is on line. If the >>>>main fails it takes up the load. >>>> >>>>I presume you are making another case for removing the backup alt >>>>switch. Again, it is called for on Z13/8, but your point is well >>>>taken. >>>> >>>>For my liking you have too many relays between the battery and the >>>>bus bar. >>>> >>>>I absolutely agree, I haven't yet come up with an elegant solution >>>>to check the backup alternator without cycling the avionics. >>>> >>>>If you use an externally regulated main alternator then initially >>>>only switch on the SD8 on start up. Then power up the main >>>>alternator regulator and bring that on line. >>>> >>>>I think we've covered this already. In order to start the engine I >>>>need to switch on the battery contactor, which would also bring the >>>>main bus and main alt online. I could move the starter wire to the >>>>always-hot side of the battery contactor, so the mains are still >>>>inop, but with that wire permanently hot, and 2 gauge wire at that, >>>>it violates the idea of making the electrical system as inert as >>>>possible in a forced landing. Again, I don't see the difference >>>>between an externally or internally regulated alternator. The red >>>>wire to lead 1 on the alt connector is the equivalent of the A wire >>>>on an external regulator, the jumper is the same as one to the S >>>>wire, and the F wire is internal. >>>> >>>>Peter, writing this is making me think about separating the main alt >>>>control to a separate switch. Let me think that through a bit and >>>>I'll report back later. >>>> >>>>Install a switch that powers up the essential (or main) bus directly >>>>from the battery, if the switch is a double pole use the second pole >>>>to disable the starter. >>>> >>>>Interesting, I'll think that out as well. >>>> >>>>The large diode in the feed line to the essential bus will always >>>>drop the voltage by an amount. The benefit is auto load shedding but >>>>do you need that with 2 alternators? If you really want to shed the >>>>main bus use a large switch and ensure there is a path to the >>>>essential bus directly from the battery. I used to have a feed diode >>>>and would not use one again. >>>> >>>>Yes, I believe it is necessary. 8 amps will not power the entire >>>>panel, so the load shedding is still valid. Incidentally, I >>>>discovered on the SD-8 literature that a Lycoming will need to run >>>>at 2500 rpm to get the full 8 amps out of the SD-8. it's looking >>>>like about 6.8 amps at 2300 rpm. Your suggestion will mean both >>>>main and E-bus need to be switched on for normal operations. Bob >>>>has made note on many of his drawings that "all buses are on when >>>>the main is on". I've had that in mind when drawing this up. >>>>Having the E-bus switched on for normal ops means the backup >>>>alternator is always running, though as you've suggested it can be >>>>set lower than the main, and loaf along in the background. I need >>>>to get my head around this idea. >>>> >>>>A diode is very beneficial on the starter contactor. >>>> >>>>That's a whoops, should have added it to the drawing, I'll get it on >>>>there. >>>> >>>>Having a low voltage waring that is independent of the EFIS is >>>>useful. It is possible you will get immune to EFIS warnings >>>> >>>>Yes, I do agree here. I was hoping the 'alt out light' function of >>>>the main alternator would be a 'low voltage monitor' as B&C does on >>>>their newer AVC regulator. After exchanging a couple of emails with >>>>Tim at Plane Power, it indeed only sees the output within the >>>>alternator, nothing outside. I've already got the Dynon EMS with >>>>all the engine sensors, so it makes some sense to use what I've got. >>>> My thinking is if it becomes annoying I can add the separate >>>>voltage monitoring system after the fact. Tim at PP did mention >>>>that he regularly sees OBAM guys using the EFIS for voltage >>>>monitoring, and all too often they've got parameters set way too >>>>stringent, and get many nuisance warnings. As yet I haven't >>>>investigated what parameters and settings I can work with, so the >>>>ex4899258752836872026xb32b8cd5421647c9b8b804b1366feb00"> >>>> >>>>Thanks very much for the thoughts Peter. It's very useful to think >>>>through the questions and comments. >>>> >>>> >>>> >>>>Cheers >>>> >>>>Gerry >>>> >>>> >>>> >>>> >>>> >>>>------ Original Message ------ >>>> >>>>From "Peter Pengilly" <peter(at)sportingaero.com> >>>> >>>>To aeroelectric-list(at)matronics.com >>>> >>>>Date 2023-12-29 2:11:12 AM >>>> >>>>Subject RE: AeroElectric-List: Tailwind Electrical System Drawing >>>>and Power Analysis >>>> >>>> >>>> >>>>>Why do you want to switch the SD-8 alternator? >>>>> >>>>>Why switch battery power to the bus twice? >>>>> >>>>>Use an externally regulated main alternator to avoid having to >>>>>switch the alternator output. >>>>> >>>>>Provide a method to connect the battery directly to the bus. >>>>> >>>>>Do not use a diode in the feed to the essential bus. >>>>> >>>>>There are a number of services connected directly to the battery >>>>>just waiting to flatten it >>>>> >>>>> >>>>> >>>>>If the voltage of the SD8 is set (say) 0.2v lower than the main >>>>>alternator it will not produce power if the main is on line. If the >>>>>main fails it takes up the load. >>>>> >>>>>For my liking you have too many relays between the battery and the >>>>>bus bar. >>>>> >>>>>If you use an externally regulated main alternator then initially >>>>>only switch on the SD8 on start up. Then power up the main >>>>>alternator regulator and bring that on line. >>>>> >>>>>Install a switch that powers up the essential (or main) bus >>>>>directly from the battery, if the switch is a double pole use the >>>>>second pole to disable the starter. >>>>> >>>>>The large diode in the feed line to the essential bus will always >>>>>drop the voltage by an amount. The benefit is auto load shedding >>>>>but do you need that with 2 alternators? If you really want to shed >>>>>the main bus use a large switch and ensure there is a path to the >>>>>essential bus directly from the battery. I used to have a feed >>>>>diode and would not use one again. >>>>> >>>>>A diode is very beneficial on the starter contactor. >>>>> >>>>>Having a low voltage waring that is independent of the EFIS is >>>>>useful. It is possible you will get immune to EFIS warnings >>>>> >>>>> >>>>> >>>>>Peter >>>>> >>>>> >>>>> >>>>>From:owner-aeroelectric-list-server(at)matronics.com >>>>> On Behalf Of Gerry >>>>>van Dyk >>>>>Sent: Thursday, December 28, 2023 11:32 PM >>>>>To:aeroelectric-list(at)matronics.com >>>>>Subject: AeroElectric-List: Tailwind Electrical System Drawing and >>>>>Power Analysis >>>>> >>>>> >>>>> >>>>>Hello again all >>>>> >>>>>Well, I think I'm ready for a good critique on my proposed >>>>>electrical system for my Tailwind project. For the most part it's >>>>>based on Z13/8, we're using a Plane Power AL12-E160 primary >>>>>alternator, and of course the B&C SD-8 backup alternator. The E160 >>>>>is internally regulated, and also has an internal crowbar system >>>>>and alt-out panel light output, which I intend to use. The SD-8 >>>>>has their older PMR1 regulator, so we've got the external crowbar >>>>>module and no voltage sensing. I've drawn these items as shown on >>>>>their respective install instructions call for. >>>>> >>>>> >>>>> >>>>>As I mentioned earlier, I intended to start the engine on the >>>>>endurance bus, and check the SD-8 operation during the startup >>>>>procedure. I had neglected to think about where the starter was >>>>>going to get power from, so the idea has forced an additional >>>>>switch and relay (a rather robust one at that) to run the main bus. >>>>> The battery contactor would be closed for startup, then the SD-8 >>>>>operation checked and finally the main bus would be brought up to >>>>>begin normal operation. >>>>> >>>>> >>>>> >>>>>I'm a little uneasy about this extra switching, as I know this >>>>>group is inclined toward fewer failure points, and with good >>>>>reason. As I look at the 'textbook' Z13/8 drawing, with my dual >>>>>EFIS, IFR capable panel in mind, it seems to me that a startup >>>>>would bring the entire panel up with the main bus, then with the >>>>>engine running I'd have to close the E-bus switch, open the battery >>>>>contactor, dropping out half the instrument panel. Then check the >>>>>backup alternator operation, and finally reboot the rest of the >>>>>panel again. It just really feels rather clunky to me. >>>>> >>>>> >>>>> >>>>>Bob, have I missed something with the original architecture >>>>>concept? Is there a way to check the backup alternator function >>>>>while the main bus is up and running? It would certainly help me >>>>>simplify my system. >>>>> >>>>> >>>>> >>>>>I'd appreciate if you good folks would give my drawing a good >>>>>review. Questions, comments and critiques are all welcome. >>>>> >>>>> >>>>> >>>>>Thanks again >>>>> >>>>>Gerry van Dyk >>>>> >>>>>Tailwind C-GVDZ >>>>> ________________________________________________________________________________
Analysis
Date: Dec 30, 2023
Yeah, I'm obviously not above a little healthy hyperbole now and then. ;^) Gerry ------ Original Message ------ >From "Peter Pengilly" <Peter(at)sportingaero.com> To aeroelectric-list(at)matronics.com Date 2023-12-30 3:47:38 PM Subject RE: Re[3]: AeroElectric-List: Tailwind Electrical System Drawing and Power Analysis >Gerry, > > >I don=99t mind if you ignore all or anything I write! It is your air plane >after all. > > >I think you are overstating the situation by saying your life may >depend on the SD8 operating correctly. With aggressive load shedding, >and particularly in VMC, you will be able to fly for an hour or two on >the battery. Being able to turn off the battery contactor will remove >(around) 1A of draw from the system, so being able to connect the >battery to the bus bar (for low draw services, say up to 20A) can be >beneficial. > > >Peter > > >From:owner-aeroelectric-list-server(at)matronics.com > On Behalf Of Gerry van >Dyk >Sent: Friday, December 29, 2023 7:18 PM >To:aeroelectric-list(at)matronics.com >Subject: Re[3]: AeroElectric-List: Tailwind Electrical System Drawing >and Power Analysis > > >Hello again all > >Peter I'll follow-up here on those couple of points... > > >I've attached the latest revision to my architecture. Thinking about >what you've suggested, separating the main alternator to it's own >switch, I've done so, and it cleans up both the drawing and the >electrical system quite a bit. Effectively what we've done is separate >the "battery / alt / DC power" switch shown on the Z13/8 drawing into >two. I've got a keyed switch which I want for some basic theft >deterrence, and then the main alt switch. > > >In operation we'll turn on the main bus, which will mean the entire >panel will be up. The big consumers will of course be off, pitot heat, >exterior lighting, AP servos, boost fuel pump, and the radios will be >in passive receive mode. At this point we'd close the ebus / aux alt >switch and start the engine. Dynon says this will not bring down the >EFIS's so with the EMS operating we should see the aux alternator bump >the voltage, I'd flip the switch on and off if need be to see this >change. Satisfied that the aux alternator is operating we'll then >bring the main alternator online and turn the e-bus / aux alt switch >off. Or I may come around on leaving it on for normal operations. > > >For alternator-out condition: turn the e-bus / aux alt switch on, open >the main battery switch, dropping out the battery contactor and >therefor the main bus. If the main alt has failed or thrown the belt, >it won't matter much if we turn off the main alt switch or not. > > >What are your thoughts on this layout? I known I haven't used all your >suggestions, I hope you take no offense to it, I think some were moving >away from the original Z13/8 philosophy which I do rather agree with. > > >Best regards > >Gerry > > >------ Original Message ------ > >From "Gerry van Dyk" <gerry.vandyk(at)eastlink.ca> > >To aeroelectric-list(at)matronics.com > >Date 2023-12-29 8:12:00 AM > >Subject Re[2]: AeroElectric-List: Tailwind Electrical System Drawing >and Power Analysis > > >>Hi Peter, thanks for your thoughts. >> >>Why do you want to switch the SD-8 alternator? >> >>because it is shown on the original Z-13/8 drawing. I'm working from >>rev T 1/07/14. Is there a later revision with this switch removed? >> >>Why switch battery power to the bus twice? >> >>As I mentioned, I want to start the engine on the E-bus. I need to >>supply power to the starter, but leave the main bus un-powered, in >>order to check the function of SD-8. Supplying starting power through >>the E-bus seems impractical. >> >>Use an externally regulated main alternator to avoid having to switch >>the alternator output. >> >>Yeah, I'm hamstringing myself a little bit here. I bought the AL >>12-E160 alt several years ago, I don't have a spare couple thousand >>dollars to buy another. I'll have to think about it better, but on >>the face of it, having a separate regulator doesn't seem to change how >>the alternator is controlled. Mr. Nuckolls has mentioned on many >>occasions that we want to have definite control of the alternator >>output with a switch in the cockpit. Z12/8 shows this switch in the >>center of the drawing. >> >>Provide a method to connect the battery directly to the bus. (I >>presume your're talking about the main bus here.) >> >>Perhaps I'm being foolish here. I'm placing an absolute requirement >>to check the operation of the backup alternator at the beginning of >>every flight. My life will depend on it should the main alternator >>fail. With the main bus and main alternator connected directly to the >>battery contactor they will be running at startup. As yet I don't see >>a way to check the backup alternator operation with the main's >>running. I'd like to do so without turning half the panel on-off-on >>during startup. >> >>Do not use a diode in the feed to the essential bus. >> >>This diode is called for by B&C on their installation drawing 504-500, >>and they provide it in the kit. What would be the reason to remove >>it? >> >>There are a number of services connected directly to the battery just >>waiting to flatten it >> >>Quite right, and this duplicates what's shown on Z13-8. They are a >>couple of conveniences, loading the baggage compartment, charging a >>phone etc, without having to turn on the battery master and it's >>relatively large current draw. In building my panel, all switches >>will be down=off, and they're all in two rows so visually obvious when >>left on. I'll have to have a quick scan of the panel when leaving the >>airplane, and if I flatten the battery by mistake, my fault. >> >>If the voltage of the SD8 is set (say) 0.2v lower than the main >>alternator it will not produce power if the main is on line. If the >>main fails it takes up the load. >> >>I presume you are making another case for removing the backup alt >>switch. Again, it is called for on Z13/8, but your point is well >>taken. >> >>For my liking you have too many relays between the battery and the bus >>bar. >> >>I absolutely agree, I haven't yet come up with an elegant solution to >>check the backup alternator without cycling the avionics. >> >>If you use an externally regulated main alternator then initially only >>switch on the SD8 on start up. Then power up the main alternator >>regulator and bring that on line. >> >>I think we've covered this already. In order to start the engine I >>need to switch on the battery contactor, which would also bring the >>main bus and main alt online. I could move the starter wire to the >>always-hot side of the battery contactor, so the mains are still inop, >>but with that wire permanently hot, and 2 gauge wire at that, it >>violates the idea of making the electrical system as inert as possible >>in a forced landing. Again, I don't see the difference between an >>externally or internally regulated alternator. The red wire to lead 1 >>on the alt connector is the equivalent of the A wire on an external >>regulator, the jumper is the same as one to the S wire, and the F wire >>is internal. >> >>Peter, writing this is making me think about separating the main alt >>control to a separate switch. Let me think that through a bit and >>I'll report back later. >> >>Install a switch that powers up the essential (or main) bus directly >>from the battery, if the switch is a double pole use the second pole >>to disable the starter. >> >>Interesting, I'll think that out as well. >> >>The large diode in the feed line to the essential bus will always drop >>the voltage by an amount. The benefit is auto load shedding but do you >>need that with 2 alternators? If you really want to shed the main bus >>use a large switch and ensure there is a path to the essential bus >>directly from the battery. I used to have a feed diode and would not >>use one again. >> >>Yes, I believe it is necessary. 8 amps will not power the entire >>panel, so the load shedding is still valid. Incidentally, I >>discovered on the SD-8 literature that a Lycoming will need to run at >>2500 rpm to get the full 8 amps out of the SD-8. it's looking like >>about 6.8 amps at 2300 rpm. Your suggestion will mean both main and >>E-bus need to be switched on for normal operations. Bob has made note >>on many of his drawings that "all buses are on when the main is on". >>I've had that in mind when drawing this up. Having the E-bus switched >>on for normal ops means the backup alternator is always running, >>though as you've suggested it can be set lower than the main, and loaf >>along in the background. I need to get my head around this idea. >> >>A diode is very beneficial on the starter contactor. >> >>That's a whoops, should have added it to the drawing, I'll get it on >>there. >> >>Having a low voltage waring that is independent of the EFIS is useful. >>It is possible you will get immune to EFIS warnings >> >>Yes, I do agree here. I was hoping the 'alt out light' function of >>the main alternator would be a 'low voltage monitor' as B&C does on >>their newer AVC regulator. After exchanging a couple of emails with >>Tim at Plane Power, it indeed only sees the output within the >>alternator, nothing outside. I've already got the Dynon EMS with all >>the engine sensors, so it makes some sense to use what I've got. My >>thinking is if it becomes annoying I can add the separate voltage >>monitoring system after the fact. Tim at PP did mention that he >>regularly sees OBAM guys using the EFIS for voltage monitoring, and >>all too often they've got parameters set way too stringent, and get >>many nuisance warnings. As yet I haven't investigated what parameters >>and settings I can work with, so the external LV warning is always on >>the table. >> >> >> >>Thanks very much for the thoughts Peter. It's very useful to think >>through the questions and comments. >> >> >> >>Cheers >> >>Gerry >> >> >> >> >> >>------ Original Message ------ >> >>From "Peter Pengilly" <peter(at)sportingaero.com> >> >>To aeroelectric-list(at)matronics.com >> >>Date 2023-12-29 2:11:12 AM >> >>Subject RE: AeroElectric-List: Tailwind Electrical System Drawing and >>Power Analysis >> >> >> >>>Why do you want to switch the SD-8 alternator? >>> >>>Why switch battery power to the bus twice? >>> >>>Use an externally regulated main alternator to avoid having to switch >>>the alternator output. >>> >>>Provide a method to connect the battery directly to the bus. >>> >>>Do not use a diode in the feed to the essential bus. >>> >>>There are a number of services connected directly to the battery just >>>waiting to flatten it >>> >>> >>> >>>If the voltage of the SD8 is set (say) 0.2v lower than the main >>>alternator it will not produce power if the main is on line. If the >>>main fails it takes up the load. >>> >>>For my liking you have too many relays between the battery and the >>>bus bar. >>> >>>If you use an externally regulated main alternator then initially >>>only switch on the SD8 on start up. Then power up the main alternator >>>regulator and bring that on line. >>> >>>Install a switch that powers up the essential (or main) bus directly >>>from the battery, if the switch is a double pole use the second pole >>>to disable the starter. >>> >>>The large diode in the feed line to the essential bus will always >>>drop the voltage by an amount. The benefit is auto load shedding but >>>do you need that with 2 alternators? If you really want to shed the >>>main bus use a large switch and ensure there is a path to the >>>essential bus directly from the battery. I used to have a feed diode >>>and would not use one again. >>> >>>A diode is very beneficial on the starter contactor. >>> >>>Having a low voltage waring that is independent of the EFIS is >>>useful. It is possible you will get immune to EFIS warnings >>> >>> >>> >>>Peter >>> >>> >>> >>>From:owner-aeroelectric-list-server(at)matronics.com >>> On Behalf Of Gerry van >>>Dyk >>>Sent: Thursday, December 28, 2023 11:32 PM >>>To:aeroelectric-list(at)matronics.com >>>Subject: AeroElectric-List: Tailwind Electrical System Drawing and >>>Power Analysis >>> >>> >>> >>>Hello again all >>> >>>Well, I think I'm ready for a good critique on my proposed electrical >>>system for my Tailwind project. For the most part it's based on >>>Z13/8, we're using a Plane Power AL12-E160 primary alternator, and of >>>course the B&C SD-8 backup alternator. The E160 is internally >>>regulated, and also has an internal crowbar system and alt-out panel >>>light output, which I intend to use. The SD-8 has their older PMR1 >>>regulator, so we've got the external crowbar module and no voltage >>>sensing. I've drawn these items as shown on their respective install >>>instructions call for. >>> >>> >>> >>>As I mentioned earlier, I intended to start the engine on the >>>endurance bus, and check the SD-8 operation during the startup >>>procedure. I had neglected to think about where the starter was >>>going to get power from, so the idea has forced an additional switch >>>and relay (a rather robust one at that) to run the main bus. The >>>battery contactor would be closed for startup, then the SD-8 >>>operation checked and finally the main bus would be brought up to >>>begin normal operation. >>> >>> >>> >>>I'm a little uneasy about this extra switching, as I know this group >>>is inclined toward fewer failure points, and with good reason. As I >>>look at the 'textbook' Z13/8 drawing, with my dual EFIS, IFR capable >>>panel in mind, it seems to me that a startup would bring the entire >>>panel up with the main bus, then with the engine running I'd have to >>>close the E-bus switch, open the battery contactor, dropping out half >>>the instrument panel. Then check the backup alternator operation, >>>and finally reboot the rest of the panel again. It just really feels >>>rather clunky to me. >>> >>> >>> >>>Bob, have I missed something with the original architecture concept? >>>Is there a way to check the backup alternator function while the main >>>bus is up and running? It would certainly help me simplify my >>>system. >>> >>> >>> >>>I'd appreciate if you good folks would give my drawing a good review. >>> Questions, comments and critiques are all welcome. >>> >>> >>> >>>Thanks again >>> >>>Gerry van Dyk >>> >>>Tailwind C-GVDZ >>> ________________________________________________________________________________
Subject: Re: Tailwind Electrical System Drawing and Power
Analysis
Date: Dec 31, 2023
Hello again all Well, with the most recent comments from Joe and Peter, here's what I believe may become the final configuration. I will stipulate, I recognize this is a whole lot more system than the airplane needs to fly, however I believe it will be required to have the 'VFR Only" limitation removed from my flight limitations. And as pointed out by a fellow Canadian in a DM, the panel has been built with the "visual field" requirements in the Canadian regs. Specifically backup nav instruments have to be within 12" of pilots centerline, and there must be an independent direction instrument. I'll have a basic whiskey compass up on the dashboard, though I might have gotten away with the dual ADAHRS units. As I was revising the drawing this morning I had one of those forehead slap moments. I thought I was being clever using a dpdt relay to run both the aux alt and the e-bus. In fact, if the OV relay tripped, it would have taken both items down leaving me with a dark panel. Joe's suggestion of locating the e-bus relay near the battery forced a separate relay, which now means when the OV crowbar takes down the aux alt relay, the e-bus will now remain powered by the battery. I'll still welcome any additional comments pointing out deficiencies, however I think we might just have this dialed in now. I hope I can pay the help forward that I've received here. Thanks to everyone. Cheers Gerry ________________________________________________________________________________
Subject: Re: Tailwind Electrical System Drawing and Power Analysis
Date: Dec 31, 2023
> however I think we might just have this dialed in now. Not quite. :-) The 15A circuit breaker below the overvoltage module is WAY to big. The crowbar over-Voltage module might smoke before that circuit breaker pops. The relay coil will draw much less than one amp. So the circuit breaker could be rated at 1A, 3 amps maximum. Or maybe even use a 5 amp fuse. . The E-Bus relay will not work with positive connected to both ends of the relay coil. Connect terminal 5 of the E-Bus on-off switch to ground instead of to that 2A fuse. . Assuming that the E-Bus relay is located within 6 inches of the battery bus, then connect them together with a fusible link. Eliminate the fusible link on the right side of the relay. Doing that will eliminate one splice. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=512999#512999 ________________________________________________________________________________
Analysis
Date: Dec 31, 2023
Thanks again Joe. I had already marked up the backup OV breaker to 5 amps, but you're quite right, on the much smaller alternator 1 or 2 amps would be about right. It's a 5A breaker on the 60 amp alt. On the E-bus relay, another of those 'facepalm' moments. I'm showing my mechanical engineering side, and not thinking through electrical flow properly. Gotta get better at that. ;^) I had the thought of connecting the E-bus relay with the fuseable link, but hadn't drawn it that way. the battery, b-bus and contactor are all screwed down to one plate behind the seats, I'll bolt the relay there as well. I'll set up a loop of fuselink to connect the relay, and we should be good. Thanks again, you're help is absolutely invaluable. Gerry ------ Original Message ------ >From "user9253" <fransew(at)gmail.com> To aeroelectric-list(at)matronics.com Date 2023-12-31 10:18:45 AM Subject AeroElectric-List: Re: Tailwind Electrical System Drawing and Power Analysis > > >> however I think we might just have this dialed in now. > >Not quite. :-) >The 15A circuit breaker below the overvoltage module is WAY to big. The >crowbar over-Voltage module might smoke before that circuit breaker pops. >The relay coil will draw much less than one amp. So the circuit breaker could >be rated at 1A, 3 amps maximum. Or maybe even use a 5 amp fuse. >. >The E-Bus relay will not work with positive connected to both ends of the relay coil. >Connect terminal 5 of the E-Bus on-off switch to ground instead of to that 2A fuse. >. >Assuming that the E-Bus relay is located within 6 inches of the battery >bus, then connect them together with a fusible link. Eliminate the fusible >link on the right side of the relay. Doing that will eliminate one splice. > >-------- >Joe Gores > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=512999#512999 > > ________________________________________________________________________________
Analysis
Date: Dec 31, 2023
Date: Jan 11, 2024
Subject: Z101B and battery in the rear wiring question
Hi folks, I have an additional question here concerning Z101 which I use in my RV-10 . On the RV-10 the battery is behind the baggage compartment so that brings some question concerning wiring here the part of Z101 which shows that: The wire marked with 1 (feed line aux alternator) would be about 14 feet long, I plan to protect that wire with an ANL 40A fuse on the FW close to the alternator, but it would be always (unfused) hot on the other side as the battery is directly hooked to that wire. The wire marked with 2 could be very short if the relay 704-1 is placed close to the battery The wire marked with 3 would be again about 12 feet long, but would only be hot when either relay is on. In this situation I would have 3 wire runs along these 12 feet #1, #3 and the starter wiring (I use 2 AWG there because of length) and #1 and the short #2 would always be hot. Now I could reduce the wire runs, if I would move the Alt Bus feed relay (704-1) to the front and hook #1 wire directly on point #4 to the relay,=C2- I would still have the long #2 and the short #1 wire hot. But in summary its still one hot wire run along the fuselage. I could mitigate that by moving the ANL fuse to the rear, but introducing a risk, if the Aux alternator is on, that the protection of the wire is on the other end of the source (Aux alternator). Many thanks for the consideration and tips on that question what is best or common practice. Cheers from Switzerland Werner ________________________________________________________________________________
Date: Jan 11, 2024
Subject: Re: Z101B and battery in the rear wiring question
Hi Werner; Hi All; I won't attempt to answer Werner's questions, but have one of my own. I had a 30 Amp shunt break in the middle, which may have led to my engine-out off-airport landing in my Zodiac 601-XLB. A Hall effect current sensor, like the one shown in his schematic, seems a much more secure way to go, since the conductor whose amperage is being measured remains continuous. My question is what specific Hall effect device should be used? A less important question: Is my present gauge compatible, or do I need a new one? The present gauge reads "amperage" directly from the shunt. Not a "deal killer," if I need a new gauge. Cheers! Stu. From: "Werner Schneider" <glastar(at)gmx.net> Sent: Thursday, January 11, 2024 5:57:39 AM Subject: AeroElectric-List: Z101B and battery in the rear wiring question Hi folks, I have an additional question here concerning Z101 which I use in my RV-10. On the RV-10 the battery is behind the baggage compartment so that brings some question concerning wiring here the part of Z101 which shows that: The wire marked with 1 (feed line aux alternator) would be about 14 feet long, I plan to protect that wire with an ANL 40A fuse on the FW close to the alternator, but it would be always (unfused) hot on the other side as the battery is directly hooked to that wire. The wire marked with 2 could be very short if the relay 704-1 is placed close to the battery The wire marked with 3 would be again about 12 feet long, but would only be hot when either relay is on. In this situation I would have 3 wire runs along these 12 feet #1, #3 and the starter wiring (I use 2 AWG there because of length) and #1 and the short #2 would always be hot. Now I could reduce the wire runs, if I would move the Alt Bus feed relay (704-1) to the front and hook #1 wire directly on point #4 to the relay, I would still have the long #2 and the short #1 wire hot. But in summary its still one hot wire run along the fuselage. I could mitigate that by moving the ANL fuse to the rear, but introducing a risk, if the Aux alternator is on, that the protection of the wire is on the other end of the source (Aux alternator). Many thanks for the consideration and tips on that question what is best or common practice. Cheers from Switzerland Werner ________________________________________________________________________________
Date: Jan 19, 2024
Good morning, there is not a lot of echo on my question, I would appreciate if the "usual suspects" ;) could give me a short feedback if I'm on the right way to reduce wire runs. Many thanks for your help, plan is to crimp the wires next week :) Cheers Werner On 11.01.2024 14:57, Werner Schneider wrote: > Hi folks, > > I have an additional question here concerning Z101 which I use in my > RV-10. > > On the RV-10 the battery is behind the baggage compartment so that > brings some question concerning wiring here the part of Z101 which > shows that: > > > The wire marked with 1 (feed line aux alternator) would be about 14 > feet long, I plan to protect that wire with an ANL 40A fuse on the FW > close to the alternator, but it would be always (unfused) hot on the > other side as the battery is directly hooked to that wire. > The wire marked with 2 could be very short if the relay 704-1 is > placed close to the battery > The wire marked with 3 would be again about 12 feet long, but would > only be hot when either relay is on. > > In this situation I would have 3 wire runs along these 12 feet #1, #3 > and the starter wiring (I use 2 AWG there because of length) and #1 > and the short #2 would always be hot. > > Now I could reduce the wire runs, if I would move the Alt Bus feed > relay (704-1) to the front and hook #1 wire directly on point #4 to > the relay,=C2- I would still have the long #2 and the short #1 wire ho t. > But in summary its still one hot wire run along the fuselage. > > I could mitigate that by moving the ANL fuse to the rear, but > introducing a risk, if the Aux alternator is on, that the protection > of the wire is on the other end of the source (Aux alternator). > > Many thanks for the consideration and tips on that question what is > best or common practice. > > Cheers from Switzerland > > Werner > > ________________________________________________________________________________
Subject: RE: 24 Jan 2023: Status of Aerolectric List?
Date: Jan 22, 2024
The database is having a bit of trouble. And causing the Matronics Forums site some errors. I=99m working on restoring it asap. Thank you for the heads up! Matt Dralle From: stuart anderson <stuart.td.anderson(at)gmail.com> Sent: Monday, January 22, 2024 12:33 PM Subject: 24 Jan 2023: Status of Aerolectric List? Mr. Dralle: is the Aerolectric List offline for good? I was searching (again) for some architecture information and could not get to the html display. My digest view has only (1) message from 19 Jan... thanks, Ron Willis ________________________________________________________________________________
Date: Jan 23, 2024
Subject: Matronics Web Forums Back Online...
There was a database issue impacting the Matronics Web Forums for a few day. I have resolved the issue and am happy to report the Forums are fully back online and operational. Matt Dralle Matronics Email List & Forum Administrator ________________________________________________________________________________
Date: Jan 23, 2024
In case of an immanent forced landing or smoke in the cockpit, the pilot should have the ability to shut off all electrical power as close to the source as possible. To comply with that rule, the battery contactor and other relays should be located near the battery. The starter contactor may be located at the firewall. Z-101 was not intended for a rear mounted battery. And so I recommend connecting the 10AWG aux alternator wire that you have labeled "1" to the starter contactor just like the main alternator is with a fuselink. If you do that, then there will not be always-hot wires running from the back to the front. Alternators do NOT need to be protected against producing too much current. Alternators can not produce much more than they are rated for. Protection for alternator feeders should be located closer to the battery end, not at the alternator end. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513130#513130 ________________________________________________________________________________
Date: Jan 24, 2024
Thanks a lot Joe for your thoughts, if I connect the wire 1 at the starter contactor I would defy the idea of Z101, that the aux alternator can feed the essential bus without switching on the main contactor, so I rather would like to keep that as in the original architecture. The main alternator feed can be protected close to the starter contactor here, as it would need a huge fuse when being close to the main contactor (starter current). Unfortunately due to CG reasons I need to have the battery at the rear end I agree would be easier/more logical on the FW..... Cheers Werner On 24.01.2024 03:43, user9253 wrote: > > In case of an immanent forced landing or smoke in the cockpit, the pilot should > have the ability to shut off all electrical power as close to the source as possible. > To comply with that rule, the battery contactor and other relays should be located > near the battery. The starter contactor may be located at the firewall. > Z-101 was not intended for a rear mounted battery. And so I recommend connecting > the 10AWG aux alternator wire that you have labeled "1" to the starter contactor > just like the main alternator is with a fuselink. If you do that, then > there will not be always-hot wires running from the back to the front. > Alternators do NOT need to be protected against producing too much current. > Alternators can not produce much more than they are rated for. Protection for > alternator feeders should be located closer to the battery end, not at the alternator end. > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=513130#513130 > > ________________________________________________________________________________
Date: Jan 24, 2024
> if I connect the wire 1 at the starter contactor I would defy the idea > of Z101, that the aux alternator can feed the essential bus without > switching on the main contactor That is not correct. If your wire #1 is connected to the starter contactor, then the path is from Aux Alt to starter contactor to downstream side of battery contactor to pink bridge rectifier diode to normal feed to brownout/AUX Bus. You might have to reduce the main bus electrical load depending on the capability of the aux alternator. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513132#513132 ________________________________________________________________________________
Date: Jan 24, 2024
Hi Joe, how could I doubt your advice :( (I just overlooked that path via the diode) That is very elegant, as the Aux would source the whole system the wire run would be short (and common to both alternators) (you would not use the blade fuses instead a fusible link in front of the starter contactor point?) So there would be a bit a different logic: - standard feed by main alternator to both buses - in case main fails Aux takes over all buses (independent if battery contactor is on or off (but should remain on to have stabilizing battery in system), reducing load on main bus could keep load in limits of Aux alternator - in case both fail the alt feed switch would connect the essential/engine bus directly to the bat. Simple and elegant, I bow my head to you for that solution, thank you!! Werner On 24.01.2024 11:23, user9253 wrote: > > >> if I connect the wire 1 at the starter contactor I would defy the idea >> of Z101, that the aux alternator can feed the essential bus without >> switching on the main contactor > That is not correct. If your wire #1 is connected to the starter contactor, then > the path is from Aux Alt to starter contactor to downstream side of battery > contactor to pink bridge rectifier diode to normal feed to brownout/AUX Bus. > You might have to reduce the main bus electrical load depending > on the capability of the aux alternator. > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=513132#513132 > > ________________________________________________________________________________
Date: Jan 24, 2024
So it would look something like this, only long wire would be #3 but could be disconnected via the relay high concentration on starter contactor now of # of connection On 24.01.2024 11:23, user9253 wrote: > > >> if I connect the wire 1 at the starter contactor I would defy the idea >> of Z101, that the aux alternator can feed the essential bus without >> switching on the main contactor > That is not correct. If your wire #1 is connected to the starter contac tor, then > the path is from Aux Alt to starter contactor to downstream side of batt ery > contactor to pink bridge rectifier diode to normal feed to brownout/AUX Bus. > You might have to reduce the main bus electrical load depending > on the capability of the aux alternator. > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=513132#513132 > > ======================== ============ ======================== ============ ======================== ============ ======================== ============ ======================== ============ > > ________________________________________________________________________________
Date: Jan 24, 2024
Werner, some well respected people like Bob N. and Charlie E. prefer to use fusible links instead of ANL fuses. Fusible links have advantages: light weight and no exposed terminals that could short out and less money. It is a matter of personal choice. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513137#513137 ________________________________________________________________________________
Date: Jan 24, 2024
Subject: Re: OVM-14 MkIII development (update)
Haven't been ignoring you guys . . . fun projects got kinda diluted with holiday festivities and frivolities along with a few home maintenance items that could not wait . . . But in the mean time: I've been fiddling with the etched circuit for the prototype OVM-14 upgrade . . . due to the very compact ecb layout I was interested in exploring solder reflow assembly processes using joint-by-joint application of solder paste. The experiments were frustrating. The consistency and makeup of the solder 'paste' is critical. Samples I had on hand proved problematic in that they were reluctant to 'stick' to the pad until the component was placed. Seems this stuff has a shelf life too. Finally did conquer the process but while working with these cute little boards, it occurred to me that it was a bit late in my career life cycle to be spooling up in new manufacturing processes and inventorying new products! To my way of thinking, the optimized assembly configuration would lend itself to offering bare boards or even kits in addition to limited sales of completed assemblies while striving for compact assembly. Thought I give this a try: The attached figure is a snapshot of the present configuration OVM-14 ECB. It's not terribly larger than the legacy CBOVMs. I've not used this assembly technique in more years than I can recall . . . first observed it in the fabrication of my first solid state pocket radio. A Regency TR1 that cost me a pretty penny in newspaper route earnings about 1958! Note the resistors stand on end soldered into pads with very close spacing. This offers a tighter layout opportunity with another benefit: The upper end of each resistor can be oriented such that it attaches to an interesting 'test node' on the board. An oscilloscope or voltmeter probe can be clipped to the lead wire for performance evaluation and/or troubleshooting. What, you may ask, is that 'thing' hanging off the end of the board? My short path to low cost prototype boards is predicated on a fixed 3.8 x 2.5 inch coupon. Hmmm . . . what to do with that opportunity for a 'free' ecb? How about exploring a recently noticed LED product that caters to night time drone pilots? Red or green LEDs with built in flashers. A bit slower than I'd like but certainly bright enough. I've added a little 'parasite' board to the layout to proof an idea for a precision low volts warning annunciator with a very low parts count. I'll publish drawings for the ECB shortly with the notion of exploiting any willing talents for proofing the layout. I've got an order into Digikey for thru-hole parts to assemble the prototypes which should go VERY quickly. This may not be the optimal route but I think it's better than the rabbit hole I dove into the first time. Let's see what shakes out. Bob . . . //// (o o) ===========o00o=(_)=o00o======== < Go ahead, make my day . . . > < show me where I'm wrong. > ================================ In the interest of creative evolution of the-best-we-know-how-to-do based on physics and good practice. ________________________________________________________________________________
Date: Jan 24, 2024
Subject: 'Funky' fuses and other interesting adventures
Shortly before the holidays we had a brief thread concerning the relative merits of utilizing automotive fuses of unknown source and equally unknown qualifications. We harkened to the admonitions from representatives of Busssman, Littlefuse, etc. etc: "NO . . . you can't have that . . . you'll shoot your eye out!" Oops . . . wrong movie . . . "Those fuses do not come with the assurances of performance control and reliability offered by our products . . . you're gonna set your wires on fire!" Okay, as we've discussed many times on this forum over the years, the science of good design requires a working knowledge in properties of materials, management of energy and refinement of process. Doesn't matter if you're baking cheese souffle, building a house . . . or wiring an airplane. There's another bit of wisdom handed down to us from history: "I often say that when you can measure what you are speaking about, and express it in numbers, you know something about it; but when you cannot measure it, when you cannot express it in numbers, your knowledge is of a meagre and unsatisfactory kind." ---- Lord Kelvin ---- To be sure, a great deal of what is pushed down on us these days is considerably lacking in numbers! Okay, let's consider how we can 'go get the numbers'. I've acquired a new tool for the mess-making shop. Toward the goal of being able to test and quantify performance on various components, an accurately calibrated electronic load-bank is of considerable value. This critter will sink up to 250 watts with max voltage of 100; max current of 50A. It features a pulse generator that allows the load to be modulated with excursions in both magnitude, frequency and duration. I've not enjoyed this capability since the last regulator I did for Beech about a bazillion years ago. It also has a scaled current sample port that will drive my oscilloscope. This instrument will be invaluable for evaluating a box of 'funky' fuses. I will suggest there are two experiments to be designed and conducted. (1) compare interruption characteristics of the funky fuses with some name brand devices -and- their data sheets. (2) craft an experiment that attempts to set a wire on fire . . . or at least cause a level of destruction that generates expensive repairs if not risks to comfortable completions of flight. Things are moving ahead with the test stand. How would we set up the experiment for demise of an 'inadequately' protected wire? Keep in mind that my prodigal environmental chamber has returned from a 20-year 'sabbatical' so our experiment can include elevated environmental temperature effects. Bob . . . //// (o o) ===========o00o=(_)=o00o======== < Go ahead, make my day . . . > < show me where I'm wrong. > ================================ In the interest of creative evolution of the-best-we-know-how-to-do based on physics and good practice. ________________________________________________________________________________
Date: Jan 25, 2024
Bob, If you send me the schematic I can then make up a board with SMD and have it made by PCBway. They are very cost effective. As an example the photo is an RF/audio probe I just finished using SMD. I used 1206 sized SMD for this. -------- KC1DNJ General Radiotelephone Commercial SEL A & P Building scale P51, rebuilding Tailwind W10 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513144#513144 Attachments: http://forums.matronics.com//files/20231218_171455_213.jpg ________________________________________________________________________________
Date: Jan 26, 2024
Subject: Z-12N based architecture review request
Team: I=99d appreciate a review of my first draft architecture, base d on Z-12N. Any credit goes to Mr. Nuckolls and many contributors; any errors are mine. Aircraft: Vans RV-14A Mission: IFR cross-country Engine: electrically dependent (SDS EFI/I) IO-390. Electric Power: -main: B&C 60a externally regulated alternator -backup: Monkworkz MZ30L 30a externally regulated generator -battery: EarthX ETX900, approx 50 min power for engine bus only (18.6ah @ 1c rate.) Electric Load Analysis: -Engine bus: <14a for SDS dual ECU, coils, injectors, fuel pumps... -Main bus estimates: <35a max draw (avionics, flap motor, fans, lights...); <8a steady state; still working the "minimum essential avionics" estimate I have considered Z-13, Z-14, and Z-101; 12N seems the best fit for my mission, skills, and planned equipment. thank you ________________________________________________________________________________
Subject: Shorts & Blown Fuse
Date: Jan 26, 2024
Hello Joe, hello Bob. Apologies for e-mailing you both off forum but I have difficulties when trying to post to the AeroElectric forum. I'd like to ask a couple of questions and if it is possible, could I ask you to also post this request to the forum please. General question; what are the events that will actually cause a fuse to blow? Also, the word "short" is mentioned together with blown fuses, but what exactly is meant by a short in our amateur-built aircraft? I have yet to find a really good source for advice on fault-finding. If you know of one, I'd appreciate hearing of it please. Specifically I have a nav/com unit that has blown the fuse of its nav board. The unit has separate power supplies for nav and com and also for light dimming capability. This nav/com is connected to a cdi that has its own separate power supply and again a supply for light dimming. In the past the cdi vertical needle fluctuated, after having been steady, and if I remember correctly shortly afterwards the nav/com display showed nav receiver and gs receiver failure. It was on checking that I found the nav board power supply 5amp fuse had blown. I have replaced it and the fault messages have disappeared and the cdi needle is currently steady. But I am concerned that the fuse may blow again. If it doesn't, the issue that caused it to blow in the first place may damage the nav side of the unit with ensuing expensive repair charges! So you can see that I am trying to fault-find and hence my initial general questions. Any direction/guidance/information you and the forum can provide will be extremely helpful, thanking you both in advance. With kind regards Patrick Elliott, Surrey, England Long-EZ, G-LGEZ -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513146#513146 ________________________________________________________________________________
Subject: Re: Shorts & Blown Fuse
Date: Jan 26, 2024
This is the link that I use for the AeroElectric List: http://forums.matronics.com/viewforum.php?f=3 - Fuses can blow from old age or vibration, excessive ambient temperature, excessive current, or a loose fuse holder which makes heat. Glass fuses such as AGC are prone to fail due to the long element and due to poor fuse holder spring tension. Make sure that fuses are held firmly with lots of spring tension. - A short circuit is an unintended current path which is usually shorter than the intended current path. A wire that vibrates against a sharp metal can result in a short circuit when the insulation is worn away and the copper wire contacts the aluminum airframe. - It is not clear from Patrick's description where the problem fuse is located. Is the fuse part of the aircraft electrical system or is the fuse located within the navigation power supply? If the blown fuse is contained within avionics, there is not much that the average person can do except replace it, making sure it is held in place with lots of spring tension. A fuse holder with weak springs will result in a poor electrical connection that has resistance. Current flowing through resistance makes heat which can cause the fuse to blow. A poor electrical connection can also cause intermittent failures. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513147#513147 ________________________________________________________________________________
From: "Matthew S. Whiting" <m.whiting(at)frontier.com>
Date: Jan 26, 2024
Fuses failing from old age is a thing of the past, unless you uses fuses fro m the past. Modern auto blade fuses will likely outlast your airplane if use s within their specifications. https://www.eaton.com/us/en-us/support/eaton -answers/what-is-fuse-fatigue.html Matt Sent from my iPad > On Jan 26, 2024, at 4:29=AFPM, user9253 wrote: > l.com> > > This is the link that I use for the AeroElectric List: > http://forums.matronics.com/viewforum.php?f=3 > - > Fuses can blow from old age or vibration, excessive ambient temperature, > excessive current, or a loose fuse holder which makes heat. Glass fuses s uch > as AGC are prone to fail due to the long element and due to poor fuse hold er > spring tension. Make sure that fuses are held firmly with lots of spring t ension. > - > A short circuit is an unintended current path which is usually shorter tha n the > intended current path. A wire that vibrates against a sharp metal can res ult > in a short circuit when the insulation is worn away and the copper wire > contacts the aluminum airframe. > - > It is not clear from Patrick's description where the problem fuse is locat ed. > Is the fuse part of the aircraft electrical system or is the fuse located w ithin > the navigation power supply? If the blown fuse is contained within avioni cs, > there is not much that the average person can do except replace it, making > sure it is held in place with lots of spring tension. A fuse holder with w eak > springs will result in a poor electrical connection that has resistance. C urrent > flowing through resistance makes heat which can cause the fuse to blow. A > poor electrical connection can also cause intermittent failures. > > -------- > Joe Gores > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=513147#513147 > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= ========================== ========= > > > ________________________________________________________________________________
Subject: Re: Z-12N based architecture review request
Date: Jan 26, 2024
The Monkworkz MZ30L is NOT wired like most alternators. Read the installation manual. https://docs.google.com/document/d/1BckaSN06Lv4BYY07AfHk3YRvx8b60yybpX0qHB-Mymc/edit Below is my interpretation of the owner's manual. ALL of the wires from the MZ30L go to its regulator and no place else. Not counting the wires between the generator and regulator, a minimum of 4 wires are required to be connected to the regulator. Regulator pins 1 & 6 go to an enable switch. Regulator pins 17 & 18 go to the main power bus and ground respectively. 10AWG wire could be used for pins 17 & 18. The fuselink would then be 14AWG. The other pins on the regulator are optional and are for an external indicator light and signal outputs to a customer supplied ammeter. The Monkworkz MZ30L is self current limiting. If overloaded, the output voltage will automatically decrease to limit the current. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513149#513149 ________________________________________________________________________________
Date: Jan 26, 2024
Joe: thank you very much for the review. I've read the Monkworkz installation manual a few times, and I'm working out the integration required. Bill Judge is very clear about the need to connect to the switched side of battery contactor- that is one of the reasons I chose the Z12 as a model. As I learn and refine this, I'll add more details. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513151#513151 ________________________________________________________________________________
Date: Jan 27, 2024
Subject: Re: Fuses and shorts
At 03:35 AM 1/26/2024, you wrote: >Hello Joe, hello Bob. > >Apologies for e-mailing you both off forum but I have difficulties >when trying to post to the AeroElectric forum. No problem. >I'd like to ask a couple of questions and if it is possible, could I >ask you to also post this request to the forum please. > > >General question; what are the events that will actually cause a fuse to blow? Fuses are, in general, fabricated from materials with low melting temperatures compared to preferred conductors like copper. Fusible elements are not zero ohms conductors. Current passing through them creates a voltage drop. Volts x Amps equals Watts. Watts manifest in HEAT. The thermal dynamics for a fuse are 'tuned' to allow melting of the fusible element when subjected to a particular current over time event. Fuses come with an 'Amps' rating that only generally defines its dynamic behavior. Fuses have a 'fusing constant' mathematically depicted as Amps(squared) times Seconds. Consider the plots that describe characteristics of the plug-in, plastic ATC style fuses: https://tinyurl.com/yw8kttde These curves tell us that at ATC fuse subjected to 3X overload can be expected to open on the order of 100 milliseconds. The 3A fuse can be expected to carry 4A indefinitely. >Also, the word "short" is mentioned together with blown fuses, but >what exactly is meant by a short in our amateur-built aircraft? Shorts are 'hard faults'; severe overload which will cause a fuse to operate in a few milliseconds. Shorts are generally caused by mechanical compromise of the conductors that bring them in contact with 'ground'. >I have yet to find a really good source for advice on fault-finding. >If you know of one, I'd appreciate hearing of it please. You study the schematic . . . where does the power go after the fuse? What components are most likely to develop faults that overload the circuit protection. >Specifically I have a nav/com unit that has blown the fuse of its nav board. > >The unit has separate power supplies for nav and com and also for >light dimming capability. > >This nav/com is connected to a cdi that has its own separate power >supply and again a supply for light dimming. > >In the past the cdi vertical needle fluctuated, after having been >steady, and if I >remember correctly shortly afterwards the nav/com display showed nav receiver >and gs receiver failure. > >It was on checking that I found the nav board power supply 5amp fuse >had blown. > >I have replaced it and the fault messages have disappeared and the >cdi needle is currently steady. > >But I am concerned that the fuse may blow again. > >If it doesn't, the issue that caused it to blow in the first place >may damage the nav side of the unit with ensuing expensive repair charges! It seems unlikely . . . internal fuses are installed to prevent faults from 'spreading'. >So you can see that I am trying to fault-find and hence my initial >general questions. > >Any direction/guidance/information you and the forum can provide >will be extremely helpful, thanking you both in advance. If a replaced fuse does not blow immediately, then you're looking for a soft fault . . . an overload as opposed to a short . . . or an intermittent short (unlikely inside a radio . . . but not impossible. How old is this radio? Do you have service documents on it . . . i.e. schematics? Electrolytic filter capacitors are early suspects for developing leakage currents with age. If you have schematics, you could consider replacing any such candidate capacitors there won't be very many. Can you scan or photograph the circuitry downstream of the fuse and share it with us? I'm sorry there's no short, turn-key answer to your problem. Some grey haired technician with years of experience with your radio might well say, "Oh yeah . . . seen that before . . . no problem." Bob . . . //// (o o) ===========o00o=(_)=o00o======== < Go ahead, make my day . . . > < show me where I'm wrong. > ================================ In the interest of creative evolution of the-best-we-know-how-to-do based on physics and good practice. ________________________________________________________________________________
Date: Jan 28, 2024
At 04:10 PM 1/26/2024, you wrote: >Fuses failing from old age is a thing of the past, unless you uses fuses from >the past. Modern auto blade fuses will likely outlast your airplane >if uses within their specifications. >https://www.eaton.com/us/en-us/support/eaton-answers/what-is-fuse-fatigue.html The key phrase here is "within their specifications". The document cited doesn't describe 'fuses' but 'current limiters' These are exceedingly robust devices like the ANL/ANN/MIDI series devices along with fusible links. They are intended for protection within a distribution system . . . often upstream of multiple feeders unique to individual systems or appliances. There is no mention of the low level, fast operating devices like the ATC fuses and their cousins. True, fuses operated within their specifications can be expected to go to the scrap yard with the rest of your airplane, hopefully decades hence. The same is true of circuit breakers. This fact underscores what I would describe as poor return on investment for the $, time and panel space to fit your airplane with 'acres of breakers'. We've long suggested that your time, talent and resources would be better spent. An anecdotal aside on this topic: Missed my one and only chance to participate in the development of Jim Bede's BD-10J way back when. Had a phone call from his project manager asking if I had any recommendations for hardware and architecture. After a month of conversations and exchange of data, I submitted a 'z-figure' starting point for future discussions. The next call informed me that "Jim wanted breaker panels" . . . seems he want his future customers to feel like they were flying some form of military hardware. For the sake of simplified installation and lower weight, I had a number of fuse blocks located remotely from the cockpit. Hmmm . . . thought about it for awhile then emailed them to respectfully bow out of the program. Included an invoice for time-to-date . . . never heard back! That specifications thingy represents the greatest risk to the application of fuses in our projects. The fusible element is a thermally responsive device that can be 'hammered' . . . a phenomenon that happens only with the modern plastic fuses and their legacy counterparts - glass cartridge fuses. A fuse should not be continuously loaded to more than 75-80 percent of rating with careful attention to knowing if it's subject to short duration excursions to 'peanut-butter- metal' territory. Recall the discussions about characteristics of solder . . . review those pages in the 'Connection if you don't remember the details. As you depart either side of the eutectic melting point for the alloy, the melding temperature goes up and the 'plastic' range gets wider. The operating element in a fuse does exactly the same thing . . . for some range of heating due to flow of current, the element will become soft and may well change shape while not actually opening up. However, these events will reduce the element's cross section/ density and cause its operating current to GO DOWN. Repeated events will eventually cause the fuse to fail. This is what happened in the crash of N811HB in California in 2008. Readers new to the List are invited to review details of this even at: https://tinyurl.com/2j7yytto So yeah, fuses in our airplanes are as likely to go to the scrap yard as fuses in our cars. Treat 'em nice and they'll treat you nice too. Bob . . . //// (o o) ===========o00o=(_)=o00o======== < Go ahead, make my day . . . > < show me where I'm wrong. > ================================ In the interest of creative evolution of the-best-we-know-how-to-do based on physics and good practice. ________________________________________________________________________________
Date: Jan 28, 2024
Overview architecture updated to include MonkWorkz-specified installation. Engine bus (approved by SDS) also attached. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513156#513156 Attachments: http://forums.matronics.com//files/20230118_eng_bus_schematic_v11__165.pdf http://forums.matronics.com//files/20240128_z12_140455_v2_196.pdf ________________________________________________________________________________
Date: Jan 29, 2024
Esco, your schematic shows 4 wires going from the MZ-30L generator to the aircraft electrical system. The MZ-30L installation manual shows ZERO wires going from the MZ-30L generator to the aircraft electrical system. All of the wires from the MZ-30L generator must ONLY go to the regulator. None go to the aircraft. Only the regulator has wires going to the aircraft electrical system. The generator puts out 3 phase AC. Therefore it can NOT be connected directly to the aircraft DC electrical system. The generator can only be connected to the rectifier / regulator. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513157#513157 Attachments: http://forums.matronics.com//files/monkworkz_mz_30l_189.png ________________________________________________________________________________
Date: Jan 29, 2024
Joe: thank you very much! You're absolutely correct. I read the installation manual, specifically "2.2. Minimum Installation / Required Connections" several times... and still misunderstood. I'll make the updates tonight! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513158#513158 ________________________________________________________________________________
Date: Jan 29, 2024
At 05:57 AM 1/25/2024, you wrote: > > >Bob, > >If you send me the schematic I can then make up a board with SMD and >have it made by PCBway. They are very cost effective. >As an example the photo is an RF/audio probe I just finished using >SMD. I used 1206 sized SMD for this. Thank you so much for the offer sir. BTW, nice looking assembly. SMA connectors? What does it do? I did a surface mount ECB and already have the boards. However, while resolving some issues with solder paste dispensing I had an epiphany . . . I'm not at the stage of my 'career' to be launching a project to be manufactured in my shops. Decided to convert it to thru-hole so that I might offer kits . . . and perhaps get some local kids interested in learning how to put such things together. I've published the 'plan-b' details in another posting. I'll comb it for errors one more time and get boards on order. Should be here Friday. I'll also get an order in to Digikey for parts compliment. If you'd care to proof the layout yourself, your input would be truly appreciated. It's a bit risky to proof one's personal work product . . . but then I'm probably not telling you anything you don't already know! Yeah, about that 1206 footprint . . . that's been my favorite choice for hand assembly for the past 20 years or so! Bob . . . //// (o o) ===========o00o=(_)=o00o======== < Go ahead, make my day . . . > < show me where I'm wrong. > ================================ In the interest of creative evolution of the-best-we-know-how-to-do based on physics and good practice. ________________________________________________________________________________
Date: Jan 29, 2024
I've published the ECB layout and assy data at https://tinyurl.com/ytdg9ehf Any any assistance in proofing the layout to the schematic would be appreciated. Will order boards late tonight. Got an order about ready to ship to Digikey for parts. We might get this project into smoke-test yet! Bob . . . //// (o o) ===========o00o=(_)=o00o======== < Go ahead, make my day . . . > < show me where I'm wrong. > ================================ In the interest of creative evolution of the-best-we-know-how-to-do based on physics and good practice. ________________________________________________________________________________
Date: Jan 29, 2024
Bob, Still interested in being a beta-tester. With the through-hole redesign I c an probably competently assemble it myself! Even better for my use case if t he low voltage warning light/LED option is included. Peter > On Jan 29, 2024, at 10:12=AFAM, Robert L. Nuckolls, III wrote: > > =EF=BB I've published the ECB layout and assy data at > > https://tinyurl.com/ytdg9ehf > > Any any assistance in proofing the layout to the > schematic would be appreciated. Will order boards > late tonight. > > Got an order about ready to ship to Digikey for > parts. > > We might get this project into smoke-test yet! > > Bob . . . > > //// > (o o) > ===========o00o=(_)=o00o======= = > < Go ahead, make my day . . . > > < show me where I'm wrong. > > ======================== ======== > > In the interest of creative evolution > of the-best-we-know-how-to-do based > on physics and good practice. ________________________________________________________________________________
Date: Jan 29, 2024
At 01:03 PM 1/29/2024, you wrote: >Bob, >Still interested in being a beta-tester. With the through-hole >redesign I can probably competently assemble it myself! Even better >for my use case if the low voltage warning light/LED option is included. > >Peter You're at the top of the list. We'll assemble the first 'batch' here for testing. The lv warning board gets trimmed off . . . that's a separate project that's still under cultivation. But you can have one of those too once they're ready for prime time. Bob . . . //// (o o) ===========o00o=(_)=o00o======== < Go ahead, make my day . . . > < show me where I'm wrong. > ================================ In the interest of creative evolution of the-best-we-know-how-to-do based on physics and good practice. ________________________________________________________________________________
Date: Jan 29, 2024
[quote="nuckolls.bob(at)aeroelect"]At 05:57 AM 1/25/2024, you wrote: Thank you so much for the offer sir. BTW, nice looking assembly. SMA connectors? What does it do? /quote] Bob, The unit displayed is an RF/audio probe for signal tracing. this feeds an amplifier. Yes, SMA connectors. It makes a nice compact unit using RG 174 as a lead. The probe is powered from the amp. I am not sure how this is going to get displayed as I rarely use quotes or even reply. Merle -------- KC1DNJ General Radiotelephone Commercial SEL A & P Building scale P51, rebuilding Tailwind W10 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513168#513168 ________________________________________________________________________________
Date: Jan 29, 2024
Revised to show MZ30L: all aircraft connections at regulator only. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513169#513169 Attachments: http://forums.matronics.com//files/20240129_z12_140455_v3_941.pdf ________________________________________________________________________________
Date: Jan 30, 2024
nuckolls.bob(at)aeroelect wrote: > I've published the ECB layout and assy data at > > https://tinyurl.com/ytdg9ehf (https://tinyurl.com/ytdg9ehf) > > Any any assistance in proofing the layout to the > schematic would be appreciated. Will order boards > late tonight. > > Got an order about ready to ship to Digikey for > parts. > > > We might get this project into smoke-test yet! > > > Bob . . . > > I looked at your layout and after finally figuring out the semantics it looks OK initially. It was confusing until I understood the numbering scheme for components. For me it usually takes about 3 iterations to figure out what I forgot. At 82 I am finally recognizing a memory failure. Merle -------- KC1DNJ General Radiotelephone Commercial SEL A & P Building scale P51, rebuilding Tailwind W10 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513174#513174 ________________________________________________________________________________
Subject: One for the battery gurus: recovery from deep discharge
Date: Jan 30, 2024
I have an SBS-J16 battery in an aircraft in which the battery master was left on for two weeks (I know). When found, the open circuit terminal voltage had dropped to 2.2 volts. A Dewalt sophisticated battery charger didnt want to have anything to do with it, so Ive now put it on charge with my bench power supply at 14.4V limited to 4 amps. Initially the battery resistance was very high, and increasing - the voltage was limited at 14.4V and the current dropped from 1.3 amps, to about 1.1 amps, within a couple of minutes, and then started to ramp up, about 1mA per second. After being on charge for an hour or so, the current it is accepting has risen so the current limiting has kicked in, presently at 4 amps and the terminal voltage has dropped to 14.3 V. Im curious why the resistance was so high to start with, why it has now dropped (to what seems normal charging behaviour to me) and also to know if this battery has a chance of resurrection,. Its only a couple of years old, so if it will soldier on after its mistreatment, I would be happy. What are my chances, do you think? ________________________________________________________________________________
Date: Jan 30, 2024
The MZ-30L regulator output terminal 2 provides ground for an indicator light. The light needs to get positive from a fuse connected to the aircraft main power bus. Notice that there is a "Pilot Enable Switch". Every aircraft should have one of those, even aircraft without an electrical system. :-) -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513176#513176 ________________________________________________________________________________
Date: Jan 31, 2024
esco wrote: > ... Bill Judge is very clear about the need to connect to the switched side of battery contactor... It is not necessary to connect the Monkworkz regulator current output to the switched side of the master contactor/main bus, only that it be disconnected from the battery somehow while parked to prevent its parasitic load from depleting the battery. I show it connected to the engine/essential bus which is on the forward side of the firewall. This way the engine will run with the main bus offline, for instance in the smoke in the cockpit scenario. Snip attached. More complete PDF schematic in folder 1) / A) here The OP has seen this but maybe others have thoughts. -------- John Bright, RV-6A N1921R, working on FWF. Single battery, alternator on main bus, Monkworkz generator on engine/essential bus. My links here Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513177#513177 Attachments: http://forums.matronics.com//files/n1921r_electrical_power_schematic_snip_141.jpg ________________________________________________________________________________
Date: Jan 31, 2024
Subject: Re: One for the battery gurus: recovery from deep
discharge At 04:09 PM 1/30/2024, you wrote: > >I have an SBS-J16 battery in an aircraft in >which the battery master was left on for two weeks (I know). > > When found, the open circuit terminal voltage > had dropped to 2.2 volts. A Dewalt > sophisticated battery charger didn=99t want to have anything to do with it, Yeah . . . many smart chargers do a pre-assessment of the target battery and will not take on the task unless the terminal voltage is above some minimum level . . . I have a couple chargers that do this. A temporary parallel connection of the smart-charger and some other voltage source, like another battery will often convince the charger that it's time to go to work. Now, recall the days long before RG/GlasMat batteries. The 'wet' stuff inside was (and still is) a dilute mixture of water and sulfuric acid. Pure water is a very poor conductor of electrons . . . but adding some combination of free ions like salt, sodium bicarbonate, or sulfuric acid to the water and it becomes a ready conductor of current. Recall that we could test the relative state of charge for a lead-acid battery by measuring the electrolyte's DENSITY with a hydrometer. The legacy float/in/glass hydrometer is generally calibrated in density vs. state of charge where electrolyte 12% greater than 1.000 (pure water) is zero-percent; 26% is full charge. Note in attached figure (shamelessly stollen off BatteryUniversity.com), 0% state of charge on a 12 volt produces an open circuit reading on the order of 11.9 volts. You cited an open circuit voltage of 2.2 volts . . . Hmmmm . . . less than 0% state of charge? Actually, yes. Active material in the plates had sucked still more acid from the electrolyte than what would produce any useful energy from the chemistry. The closer to pure water . . . the more depressed conductivity. Hence, first attempts to push energy back into the battery will be met with lots of resistance . . . no pun intended. I recall reading a qualification test on a Concorde battery document where a fully discharged battery is dead-shorted for a period of time after which a recharge protocol calls for applying a higher than normal voltage until significant recharge current is observed. The test proceeds with a normal constant voltage/constant current charge. After top-off, the battery is cap-checked and must demonstrate some minimum. I dug around in the library but could not come up with that document so I cannot quote exact times and values. But note that this is a quality test for a new battery. While a certain level of degradation is expected, the battery is EXPECTED to recover by some minimum amount required for return to service. > so I=99ve now put it on charge with my bench > power supply at 14.4V limited to 4 amps. >Initially the battery resistance was very high, >and increasing - the voltage was limited at >14.4V and the current dropped from 1.3 amps, to >about 1.1 amps, within a couple of minutes, and >then started to ramp up, about 1mA per second. >After being on charge for an hour or so, the >current it is accepting has risen so the current >limiting has kicked in, presently at 4 amps and >the terminal voltage has dropped to 14.3 V. Yup, this is expected and you may well recover this battery to some level for continued service. After a 24-hour float at 14.4, let it see idle for 24-hours then do a cap check followed by recharge and a load test. >I=9Dm curious why the resistance was so high to >start with, why it has now dropped (to what >seems =99normal=99 charging behaviour to me) and >also to know if this battery has a chance of >resurrection,. It=99s only a couple of years >old, so if it will soldier on after its >mistreatment, I would be happy. What are my chances, do you think? As Lord Kelvin oft admonished, if you don't know the numbers, what you DO know is of limited value. Bob . . . //// (o o) ===========o00o=(_)=o00o======= = < Go ahead, make my day . . . > < show me where I'm wrong. > ======================== ======== In the interest of creative evolution of the-best-we-know-how-to-do based on physics and good practice. ________________________________________________________________________________
Subject: 2nd LSE Standby Power.
Date: Feb 01, 2024
Have a pretty solid electric system derived from the Z diagrams on my EZ. Going to dual electronic ignition and have high confidence in 2 alternators and a battery, but want a standby "get me down" battery since my 2nd alternator is an SD8 and it doesn't make power when the RPM is pulled back. Switch shown here is a progressive switch. Off (down) is off. Up is normal main bus providing power to the ignition and charge current to the standby small battery. Middle position is isolating the ignition to a ~5ah 12V battery (EarthX or similar). Diode keeping electrons flowing to the ignition and not the rest of the world. Have I missed anything? Thought was if the world is going to hell, One switch and I've got that ignition isolated and powered. Probably never use it, but... Thoughts? Andy Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513182#513182 Attachments: http://forums.matronics.com//files/lsestandbypower_756.png ________________________________________________________________________________
Date: Feb 01, 2024
Subject: Re: 2nd LSE Standby Power.
On Thu, Feb 1, 2024 at 1:48=AFPM andymeyer wro te: m > > > > Have a pretty solid electric system derived from the Z diagrams on my EZ. > Going to dual electronic ignition and have high confidence in 2 > alternators and a battery, but want a standby "get me down" battery since > my 2nd alternator is an SD8 and it doesn't make power when the RPM is > pulled back. > > Switch shown here is a progressive switch. Off (down) is off. Up is norma l > main bus providing power to the ignition and charge current to the standb y > small battery. Middle position is isolating the ignition to a ~5ah 12V > battery (EarthX or similar). Diode keeping electrons flowing to the > ignition and not the rest of the world. > > Have I missed anything? Thought was if the world is going to hell, One > switch and I've got that ignition isolated and powered. Probably never us e > it, but... > > Thoughts? > > Andy > My personal thought process is to have engine 'stuff' isolated from airframe stuff as much as possible, so 'off nominal' operation comes closer to our training. I don't see what EI is being used, but most systems advise tying their power source directly to the airframe battery bus. That gets it away from the airframe circuitry, and keeps power available even with the Master off. FWIW, if you have a main (big) alternator, plus the SD8, plus the main battery, adding another battery is a belt on suspenders on a belt on a..... ;-) *If* I felt a real need to add battery redundancy, I'd consider a pair of diode isolated switches feeding the ignition; one from each battery. Using a single switch to select battery source creates a single point of failure if the switch fails mechanically. It also raises potential operational issues during off-nominal, because we tend to see switches as two-state devices. Might not be a big issue for the builder, but could bite anyone else flying the plane. Hope that's of some use, Charlie Virus-free.www.avast.com <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> ________________________________________________________________________________
Date: Feb 01, 2024
I agree with Charlie about using 2 separate switches. Put dots on your schematic at wire junctions. The diode is backwards. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513185#513185 ________________________________________________________________________________
Date: Feb 03, 2024
On Thu, Feb 1, 2024 at 9:11=AFPM user9253 wrote: > > I agree with Charlie about using 2 separate switches. > Put dots on your schematic at wire junctions. > The diode is backwards. > > -------- > Joe Gores > > I thought the same thing about the diode, but after studying the action o f the switch, I think he has the diode oriented correctly for that desired function. I still think separate switches make more sense, though. Virus-free.www.avast.com <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> ________________________________________________________________________________
discharge
Date: Feb 03, 2024
Here=99s how it turned out: 12 hours on a bench PSU at 14.4v, then 12 hours rest, then I attached a different =9Csmart=9D charger that showed the battery as discharged, but did proceed to engage the charging cycle. 24 hours after that, the charger was showing the battery at 100% charge and it had enough juice to start the engine, and I flew for about an hour. Hopefully it will maintain enough energy to power a start cycle again, some time next week. Thanks for the comments, Bob! On Jan 31, 2024, at 22:31, Robert L. Nuckolls, III wrote: At 04:09 PM 1/30/2024, you wrote: > > I have an SBS-J16 battery in an aircraft in which the battery master was left on for two weeks (I know). > > When found, the open circuit terminal voltage had dropped to 2.2 volts. A Dewalt sophisticated battery charger didn=C3=A2=C2=C2=99t want to have anything to do with it, Yeah . . . many smart chargers do a pre-assessment of the target battery and will not take on the task unless the terminal voltage is above some minimum level . . . I have a couple chargers that do this. A temporary parallel connection of the smart-charger and some other voltage source, like another battery will often convince the charger that it's time to go to work. Now, recall the days long before RG/GlasMat batteries. The 'wet' stuff inside was (and still is) a dilute mixture of water and sulfuric acid. Pure water is a very poor conductor of electrons . . . but adding some combination of free ions like salt, sodium bicarbonate, or sulfuric acid to the water and it becomes a ready conductor of current. Recall that we could test the relative state of charge for a lead-acid battery by measuring the electrolyte's DENSITY with a hydrometer. The legacy float/in/glass hydrometer is generally calibrated in density vs. state of charge where electrolyte 12% greater than 1.000 (pure water) is zero-percent; 26% is full charge. Note in attached figure (shamelessly stollen off BatteryUniversity.com), 0% state of charge on a 12 volt produces an open circuit reading on the order of 11.9 volts. You cited an open circuit voltage of 2.2 volts . . . Hmmmm . . . less than 0% state of charge? Actually, yes. Active material in the plates had sucked still more acid from the electrolyte than what would produce any useful energy from the chemistry. The closer to pure water . . . the more depressed conductivity. Hence, first attempts to push energy back into the battery will be met with lots of resistance . . . no pun intended. I recall reading a qualification test on a Concorde battery document where a fully discharged battery is dead-shorted for a period of time after which a recharge protocol calls for applying a higher than normal voltage until significant recharge current is observed. The test proceeds with a normal constant voltage/constant current charge. After top-off, the battery is cap-checked and must demonstrate some minimum. I dug around in the library but could not come up with that document so I cannot quote exact times and values. But note that this is a quality test for a new battery. While a certain level of degradation is expected, the battery is EXPECTED to recover by some minimum amount required for return to service. > so I=C3=A2=C2=C2=99ve now put it on charge with my bench power supply at 14.4V limited to 4 amps. > Initially the battery resistance was very high, and increasing - the voltage was limited at 14.4V and the current dropped from 1.3 amps, to about 1.1 amps, within a couple of minutes, and then started to ramp up, about 1mA per second. After being on charge for an hour or so, the current it is accepting has risen so the current limiting has kicked in, presently at 4 amps and the terminal voltage has dropped to 14.3 V. Yup, this is expected and you may well recover this battery to some level for continued service. After a 24-hour float at 14.4, let it see idle for 24-hours then do a cap check followed by recharge and a load test. > I=C3=A2=C2=C2=9Dm curious why the resistance was so high to start with, why it has now dropped (to what seems =C3=A2=C2=C2=99normal=C3=A2 =C2=C2=99 charging behaviour to me) and also to know if this battery has a chance of resurrection,. It=C3=A2=C2=C2=99s only a couple of years old, so if it will soldier on after its mistreatment, I would be happy. What are my chances, do you think? As Lord Kelvin oft admonished, if you don't know the numbers, what you DO know is of limited value. Bob . . . //// (o o) ===========o00o=(_)=o00o======= == < Go ahead, make my day . . . > < show me where I'm wrong. > ======================== ======== In the interest of creative evolution of the-best-we-know-how-to-do based on physics and good practice. ________________________________________________________________________________
Date: Feb 03, 2024
Subject: Re: One for the battery gurus: recovery from deep discharge
In my case I had a newish deep cycle 12v100a/h battery in an inverter drop to 3.6v...dont ask... Anyway...the Victron charger didnt see the battery...put a 24v CTEK intelligent charger on it got it to 15v in about 30min. Changed over to the 7amp Victron 12v smart charger... I had just about given up after about 5 days when suddenly the charge light went green! Its been about a month and the battery seems fine. Maybe a bit of luck? On Sat, 03 Feb 2024, 18:03 Alec Myers, wrote: > Here=99s how it turned out: 12 hours on a bench PSU at 14.4v, then 12 hours > rest, then I attached a different =9Csmart=9D charger that sh owed the battery > as discharged, but did proceed to engage the charging cycle. 24 hours aft er > that, the charger was showing the battery at 100% charge and it had enoug h > juice to start the engine, and I flew for about an hour. > > Hopefully it will maintain enough energy to power a start cycle again, > some time next week. > > Thanks for the comments, Bob! > > > On Jan 31, 2024, at 22:31, Robert L. Nuckolls, III < > nuckolls.bob(at)aeroelectric.com> wrote: > > At 04:09 PM 1/30/2024, you wrote: > > > I have an SBS-J16 battery in an aircraft in which the battery master was > left on for two weeks (I know). > > When found, the open circuit terminal voltage had dropped to 2.2 volts. A > Dewalt sophisticated battery charger didn=C3=A2=82=AC=84=A2t want t o have anything to do > with it, > > > Yeah . . . many smart chargers do a pre-assessment of the target > battery and will not take on the task unless the terminal voltage > is above some minimum level . . . I have a couple chargers that > do this. > > A temporary parallel connection of the smart-charger and some > other voltage source, like another battery will often convince > the charger that it's time to go to work. > > Now, recall the days long before RG/GlasMat batteries. > The 'wet' stuff inside was (and still is) a dilute mixture > of water and sulfuric acid. Pure water is a very poor > conductor of electrons . . . but adding some > combination of free ions like salt, sodium bicarbonate, > or sulfuric acid to the water and it becomes a ready > conductor of current. > > Recall that we could test the relative state of > charge for a lead-acid battery by measuring the > electrolyte's DENSITY with a hydrometer. The > legacy float/in/glass hydrometer is generally > calibrated in density vs. state of charge > where electrolyte 12% greater than 1.000 > (pure water) is zero-percent; 26% is full > charge. > > Note in attached figure (shamelessly stollen > off BatteryUniversity.com), 0% state of charge > on a 12 volt produces an open circuit reading > on the order of 11.9 volts. > > You cited an open circuit voltage of 2.2 volts . . . > Hmmmm . . . less than 0% state of charge? > Actually, yes. Active material in the plates > had sucked still more acid from the electrolyte > than what would produce any useful energy > from the chemistry. > > The closer to pure water . . . the more depressed > conductivity. Hence, first attempts to push energy > back into the battery will be met with lots of > resistance . . . no pun intended. > > I recall reading a qualification test on > a Concorde battery document where a fully > discharged battery is dead-shorted for a > period of time after which a recharge > protocol calls for applying a higher than > normal voltage until significant recharge > current is observed. The test proceeds with > a normal constant voltage/constant current > charge. After top-off, the battery is cap-checked > and must demonstrate some minimum. > > I dug around in the library but could not > come up with that document so I cannot quote > exact times and values. But note that this > is a quality test for a new battery. While > a certain level of degradation is expected, > the battery is EXPECTED to recover by some > minimum amount required for return to > service. > > > so I=C3=A2=82=AC=84=A2ve now put it on charge with my bench power supply at 14.4V > limited to 4 amps. > > > Initially the battery resistance was very high, and increasing - the > voltage was limited at 14.4V and the current dropped from 1.3 amps, to > about 1.1 amps, within a couple of minutes, and then started to ramp up, > about 1mA per second. After being on charge for an hour or so, the curren t > it is accepting has risen so the current limiting has kicked in, presentl y > at 4 amps and the terminal voltage has dropped to 14.3 V. > > > Yup, this is expected and you may well > recover this battery to some level for > continued service. After a 24-hour float > at 14.4, let it see idle for 24-hours > then do a cap check followed by recharge > and a load test. > > > I=C3=A2=82=AC m curious why the resistance was so high to start with, why it has now > dropped (to what seems =C3=A2=82=AC=84=A2normal=C3=A2=82=AC =84=A2 charging behaviour to me) and also to > know if this battery has a chance of resurrection,. It=C3=A2=82=AC =84=A2s only a couple of > years old, so if it will soldier on after its mistreatment, I would be > happy. What are my chances, do you think? > > > As Lord Kelvin oft admonished, if you > don't know the numbers, what you DO know > is of limited value. > > > Bob . . . > > //// > (o o) > ===========o00o=(_)=o00o====== == > < Go ahead, make my day . . . > > < show me where I'm wrong. > > ======================= ========= > > In the interest of creative evolution > of the-best-we-know-how-to-do based > on physics and good practice. > > > ________________________________________________________________________________
Date: Feb 03, 2024
You are right Charlie. I was wrong. I mistakenly thought the battery was supposed to supply power to the main bus. Below are two schematics. The top one functions the same as the OP's. The bottom schematic is simpler but accomplishes the same goal. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513192#513192 Attachments: http://forums.matronics.com//files/aux_bat_for_lightspeed_ign_130.png ________________________________________________________________________________
Date: Feb 03, 2024
Lightspeed Ignition. Klaus recommends that #1 be tied to the battery - it is. #2 can be tied to the main or essential bus. This circuit is only for #2. Thought here is that it's a single switch (less failure points - arguable... More complex switch.) Master switch is progressive - alternator issue - click down to the center position. This switch would have the same mentality. It'd also never be a "Boldface switch flip" unless all power went away on the aircraft (Battery dead short, took out alternator and backup alternator - too many failures in that chain for this to be boldface.) Any circuit issues with this design, along with a diode recommendation? Diode reversed. Whoops - sorry about that. Fixed... Thanks! Andy Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513194#513194 ________________________________________________________________________________
Subject: toggle switches better than Carling?
Date: Feb 03, 2024
After reading on VAF about failures of Carling toggle switches with faston tabs attached with hollow rivets I was planning to use Honeywell TS but they have been discontinued. One VAF thread: https://vansairforce.net/threads/failing-intermittent-toggle-switch.172765/ I'd like to find good quality toggle switches that use faston tabs and come in configurations like 2-10... any thoughts here on AEL? I find APEM on Newark, part number 644H/2 for instance seems to be 2-10 configuration. It has tabs called solder lug/quick-connect which have a larger thru hole compared to what APEM calls normalized quick-connect tabs which have the smaller through hole I am used to seeing. APEMs with normalized quick-connect tabs are not stocked that I can find. The switch description says "terminal and contact support is manufactured from a single piece of metal. The contacts are resistance-welded to the terminal for increased mechanical strength". Bushing dia is 12 mm which is practically the same, 0.004" larger, compared to the 15/32" I am used to. Newark page for APEM 644H/2: https://www.newark.com/apem/644h-2/switch-dp3t-10a-250vac/dp/96C7308 APEM 600H data sheet: https://www.farnell.com/datasheets/1697794.pdf -------- John Bright, RV-6A N1921R, working on FWF. Single battery, alternator on main bus, Monkworkz generator on engine/essential bus. My links here Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513195#513195 ________________________________________________________________________________
Date: Feb 03, 2024
Joe, You mangled my schematic and made it better. I had the diode in the wrong spot. In you configuration, in the top switch position, the engine keeps running if the battery bus dies, runs off of the standby battery. In my drawing it didn't. Thank you! I think that's my implementation. I want to be able to get the 2nd igntiion as far away from anything else as possible, and that configuration does exactly that. Thank you for the diode recommendation as well - perfect. Thanks! Andy Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513196#513196 ________________________________________________________________________________
Date: Feb 03, 2024
While the main alternator is running, the 5AH standby battery should be connected to the main bus to keep the standby battery charged. My last schematic accomplishes that with only a diode. There is no concern of parasitic aux battery drain because the diode has infinitesimal reverse leakage current. If the switch is closed, Ignition 2 will draw current from the source with the highest voltage, which is normally the main bus, not the aux battery. The definition of infinitesimal is the distance that an aircraft carrier sinks into the water when a house fly lands on its deck. :-) -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513197#513197 ________________________________________________________________________________
Date: Feb 04, 2024
Subject: Re: toggle switches better than Carling?
Nikkai (NKK) switches seem good to me and they are available in fast on configuration. On Sat, Feb 3, 2024 at 3:58=AFPM N1921R wrot e: > > > After reading on VAF about failures of Carling toggle switches with fasto n > tabs attached with hollow rivets I was planning to use Honeywell TS but > they have been discontinued. > > One VAF thread: > https://vansairforce.net/threads/failing-intermittent-toggle-switch.17276 5/ > > I'd like to find good quality toggle switches that use faston tabs and > come in configurations like 2-10... any thoughts here on AEL? > > I find APEM on Newark, part number 644H/2 for instance seems to be 2-10 > configuration. It has tabs called solder lug/quick-connect which have a > larger thru hole compared to what APEM calls normalized quick-connect tab s > which have the smaller through hole I am used to seeing. APEMs with > normalized quick-connect tabs are not stocked that I can find. The switch > description says "terminal and contact support is manufactured from a > single piece of metal. The contacts are resistance-welded to the terminal > for increased mechanical strength". Bushing dia is 12 mm which is > practically the same, 0.004" larger, compared to the 15/32" I am used to. > > Newark page for APEM 644H/2: > https://www.newark.com/apem/644h-2/switch-dp3t-10a-250vac/dp/96C7308 > > APEM 600H data sheet: https://www.farnell.com/datasheets/1697794.pdf > > -------- > John Bright, RV-6A N1921R, working on FWF. > Single battery, alternator on main bus, Monkworkz generator on > engine/essential bus. > My links here > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=513195#513195 > > =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Feb 04, 2024
On Sat, Feb 3, 2024 at 6:58=AFPM N1921R wrot e: > > > After reading on VAF about failures of Carling toggle switches with fasto n > tabs attached with hollow rivets I was planning to use Honeywell TS but > they have been discontinued. > > One VAF thread: > https://vansairforce.net/threads/failing-intermittent-toggle-switch.17276 5/ > > I'd like to find good quality toggle switches that use faston tabs and > come in configurations like 2-10... any thoughts here on AEL? > > I find APEM on Newark, part number 644H/2 for instance seems to be 2-10 > configuration. It has tabs called solder lug/quick-connect which have a > larger thru hole compared to what APEM calls normalized quick-connect tab s > which have the smaller through hole I am used to seeing. APEMs with > normalized quick-connect tabs are not stocked that I can find. The switch > description says "terminal and contact support is manufactured from a > single piece of metal. The contacts are resistance-welded to the terminal > for increased mechanical strength". Bushing dia is 12 mm which is > practically the same, 0.004" larger, compared to the 15/32" I am used to. > > Newark page for APEM 644H/2: > https://www.newark.com/apem/644h-2/switch-dp3t-10a-250vac/dp/96C7308 > > APEM 600H data sheet: https://www.farnell.com/datasheets/1697794.pdf > > -------- > John Bright, RV-6A N1921R, working on FWF. > Single battery, alternator on main bus, Monkworkz generator on > engine/essential bus. > My links here > > > Hi John, Did you read the entirety of that VAF thread? Might be worth your time to go back and re-read it, assigning weight to what's significant. Your takeaway about hollow rivets might be the most insignificant thing in the thread. ;-) There are also some criticisms of supposed failure points where the responder got the failure point wrong. Only one responder mentioned multiple failures; that could have been a bad batch of switches, or 'pilot error'. Consider that quite a few of us have seen failures of milspec circuit breakers; does that mean *everyone* should find a different circuit breaker? (I was the 1st responder to that VAF thread.) Virus-free.www.avast.com <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> ________________________________________________________________________________
Date: Feb 04, 2024
--- MIME Errors - No Plain-Text Section Found --- A message with no text/plain MIME section was received. The entire body of the message was removed. Please resend the email using Plain Text formatting. HOTMAIL is notorious for only including an HTML section in their client's default configuration. If you're using HOTMAIL, please see your email application's settings and switch to a default mail option that uses "Plain Text". --- MIME Errors No Plain-Text Section Found --- ________________________________________________________________________________
Date: Feb 04, 2024
At 11:15 AM 2/4/2024, you wrote: >On Sat, Feb 3, 2024 at 6:58=AFPM N1921R ><RV.6A.N1921R(at)gmail.com> wrote: >"N1921R" <RV.6A.N1921R(at)gmail.com> > >After reading on VAF about failures of Carling >toggle switches with faston tabs attached with >hollow rivets I was planning to use Honeywell TS >but they have been=C2 discontinued. > >One VAF thread: >https://vansairforce.net/threads/failing-intermittent-toggle-switch.172765 / > >I'd like to find good quality toggle switches >that use faston tabs and come in configurations >like 2-10... any thoughts here on AEL? Failed after 660 hrs??? How many years of service and under what manner of environmental/service stress? Was root cause for the failure skillfully diagnosed? I've studied and resolved dozens of 'contact failures' in a constellation of relays and switches that ranged from hardware-store to mil-spec devices. There were very few instances wherein studies were the basis for 'upgrading' a failed device. The Carling switch configuration under discussion has been used in very high volumes in aircraft for decades. We're just making the change-over to those switches (with rocker actuators) at Cessna when I worked there in 1965. Yes, there were field failures but relatively rare in the grand scheme of things with majority of failures attributable to conditions external to the switch . . . moisture, bad terminal crimp, poor fast-on-grip, etc. So what's the benchmark for satisfactory service life? Is the failure of any switch a potential for uncomfortable termination of flight? If so, what about the myriad of peripheral components of that system? Had a reader many moons ago who was worried about the quality of his landing light switch . . . I had to remind him, "You do know those bulbs burn out sometime." Do your FMEA and strive to have no single failure become a hazard to comfortable completion of flight. Did a study on roll trim relays on Beechjets way back when where contacts were sticking shut causing the occasional hard-over runaway in roll trim. After much study and bench tests I discovered a design consideration that didn't manifest until a redesign of the trim system replaced legacy 10A relays (mil-spec no less) with a 5A relay (also mil-spec). I discovered that arcing during contact bounce was exacerbated by reflections of energy from the far end of a shielded wire bypassed with a fat capacitor. Clip the shield ground or eliminate the capacitor (neither one of which was needed) and the problem resolved. During the investigation of some 2+ years, I did discover that one brand of relay was a bit more tolerant of the abuse. Management in their infinite wisdom purged stock of the 'bad' relay and banned them from future purchase. The 'good' relay was substituted and life went on . . . that way nobody had to change any drawings. Yeah, that's a short story made long but I hope it illustrates the value in having good data as to cause/effect and cost/benefit before changing course from a well worn pathway. Bob . . . //// (o o) ===========o00o=(_)=o00o======= = < Go ahead, make my day . . . > < show me where I'm wrong. > ======================== ======== In the interest of creative evolution of the-best-we-know-how-to-do based on physics and good practice. ________________________________________________________________________________
Date: Feb 04, 2024
discharge At 11:25 AM 2/3/2024, you wrote: >In my case I had a newish deep cycle=C2 12v100a/h >battery in an inverter drop to 3.6v...dont ask... > >Anyway...the Victron charger didnt see the >battery...put a 24v CTEK intelligent charger on >it got it to 15v in about 30min. Changed over to >the 7amp Victron 12v smart charger... > >I had just about given up after about 5 days >when suddenly the charge light went green! > >Its been about a month and the battery seems fine. Maybe a bit of luck? It may have been quite predictable. When the battery is discharge to LESS than zero, i.e. open terminal volts less than 12.0 V and SG below 1.12, then what's left of the acid is free do mischief on the battery's innards . . . like sulfation at an accelerated rate. In the fully charged state, the negative plate consists of lead; the positive plate is lead dioxide. The electrolyte has a higher concentration acid which is where chemical energy is stored. When discharged, both the positive and negative plates become lead sulfate; the electrolyte becomes less acid and more water. The lead sulfate is initially fine grains and convertible back into hydrogen sulfide thus increasing strength of the acid. Depending on depth and duration of discharge, SOME of the lead sulfate forms hard, insoluble crystals thus diminishing battery CAPACITY. Without a doubt, your battery has experienced and extra-ordinary, deep-discharge which will have consumed more of its service life than if it had been subjected to a normal discharge-recharge cycle. Bob . . . //// (o o) ===========o00o=(_)=o00o======= = < Go ahead, make my day . . . > < show me where I'm wrong. > ======================== ======== In the interest of creative evolution of the-best-we-know-how-to-do based on physics and good practice. ________________________________________________________________________________
Date: Feb 04, 2024
Thanks guys for bringing me back to reality. -------- John Bright, RV-6A N1921R, working on FWF. Single battery, alternator on main bus, Monkworkz generator on engine/essential bus. My links here Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513206#513206 ________________________________________________________________________________
Date: Feb 07, 2024
Joe, Looking at this again, the reason for the 3 position switch is so that I can preflight the system. With the two position switch, I only know that one of the two batteries is providing power. The three position switch allows me to power the ignition solely from the aux battery and verify its voltage under operating load. Again, thank you for the tweak to my original intent - I like yours better! I have a display that shows the RPM, MP, Timing and voltage of the 2nd ignition system - powered directly from the power feeding that second ignition. If the second ignition has power, the display has power. I do understand the mentality of "any other pilot" flying the airplane. I counter this a bit with "Know your equipment." I know of no 152's with dual alternators, dual electronic ignitions, endurance buses or... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513214#513214 ________________________________________________________________________________
Date: Feb 07, 2024
Andy, Do you intend to fly with the 2nd ignition normally on, or normally off for emergency use only? -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513217#513217 ________________________________________________________________________________
Date: Feb 07, 2024
Joe, Normally on in the full up position. This position, with your diagram would provide charge power to the standby battery and diode selected power in the case of either battery failing. EMER position is the middle position, clearly marked. Useful for preflight or if there was any other reason to get the main electrical system out of the mix. (With that diode, not very likely, but...) Panel is already cut, labeled and the progressive switch installed. Just wanted a sanity check of the circuit and you helped me refine it - thanks! Andy Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513218#513218 ________________________________________________________________________________
Date: Feb 09, 2024
Subject: OVM-14 MkIII development (update)
Boards are on order . . . stared at that last iteration of the layout and finally succumbed to an instance of 'creative destruction'. I've re-laid the board to more conventional fabrication philosophies. Yeah, it got a bit bigger but will go together in minutes and 'look good'. The assembly is now 2.2 x 0.7 inches and will still 'house' nicely under a piece of heat shrink. Those interested in taking a peek can download the proof prints at: http://aeroelectric.com/DIY/OVM14%20mkII%20proof%20prints.pdf The boards will be solder masked and silk screened to facilitate kit-builders. Parts and boards will be on hand for 15 prototypes next Thursday. Bob . . . //// (o o) ===========o00o=(_)=o00o======== < Go ahead, make my day . . . > < show me where I'm wrong. > ================================ In the interest of creative evolution of the-best-we-know-how-to-do based on physics and good practice. ________________________________________________________________________________
Date: Feb 09, 2024
Subject: Re: OVM-14 MkIII development (update)
Hi Bob Very interested in a kit or a completed and tested one. Thanks Chris On Fri., Feb. 9, 2024, 9:10 a.m. Robert L. Nuckolls, III, < nuckolls.bob(at)aeroelectric.com> wrote: > Boards are on order . . . stared at that last > iteration of the layout and finally succumbed > to an instance of 'creative destruction'. I've > re-laid the board to more conventional fabrication > philosophies. Yeah, it got a bit bigger but will > go together in minutes and 'look good'. > > The assembly is now 2.2 x 0.7 inches and will > still 'house' nicely under a piece of heat > shrink. > > Those interested in taking a peek can download > the proof prints at: > > http://aeroelectric.com/DIY/OVM14%20mkII%20proof%20prints.pdf > > > The boards will be solder masked and silk screened > to facilitate kit-builders. Parts and boards will be > on hand for 15 prototypes next Thursday. > > Bob . . . > > //// > (o o) > ===========o00o=(_)=o00o======== > < Go ahead, make my day . . . > > < show me where I'm wrong. > > ================================ > > In the interest of creative evolution > of the-best-we-know-how-to-do based > on physics and good practice. > ________________________________________________________________________________
Date: Feb 10, 2024
At 12:23 AM 2/10/2024, you wrote: >Hello Bob, > >Are you looking for testers for the prototypes? I've had numerous volunteers to be 'beta testers' of the new ovm. Performance testing will be carried out in my shop with respect to confirming 'the numbers' and stability of those numbers under temperature extremes. Field tests will explore possible vulnerability to un-anticipated conditions in functional dc power systems. They won't even need to be actively guarding against failure of a regulator/ alternator installation. I'll install 'em on two of my own vehicles to simply 'watch the bus thru a 5A breaker'. With the ovm in the cabin and by means of the functional verification feature, I can exercise the critters every time the engine is started . . . while watching for vulnerabilities to noise in the 'normal' mode. So yeah, I'd be interested in having a few of these little guys similarly exercised in more vehicles. Once we're reasonably satisfied with this field qualification experiment, 'test articles' will remain property of the tester to be installed in their project as needed. By using cars for the field test platforms, we'll be able to secure a lot more information than if first articles went directly to airplanes. Bob . . . //// (o o) ===========o00o=(_)=o00o======== < Go ahead, make my day . . . > < show me where I'm wrong. > ================================ In the interest of creative evolution of the-best-we-know-how-to-do based on physics and good practice. ________________________________________________________________________________
Date: Feb 10, 2024
> snipped > > > By using cars for the field test platforms, > we'll be able to secure a lot more > information than if first articles > went directly to airplanes. > > > Bob . . . > Hmm. Just about every car built in the last decade or two has OV & load dump protection hard wired into either their regulator or their computer, if the computer regulates the alternator (getting more common these days). Does that affect the ability to gather data on the device? Charlie Virus-free.www.avast.com <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> ________________________________________________________________________________
Date: Feb 10, 2024
Date: Feb 10, 2024
At 10:15 AM 2/10/2024, you wrote: >snipped > > >=C2 By using cars for the field test platforms, >=C2 we'll be able to secure a lot more >=C2 information than if first articles >=C2 went directly to airplanes. > > >=C2 Bob . . . > >Hmm. Just about every car built in the last >decade or two has OV & load dump protection hard >wired into either their regulator or their >computer, if the computer regulates the >alternator (getting more common these days). >Does that affect the ability=C2 to gather data on the device? Excellent question! Throughout the 30 or so year history of the OVM project, difficulties in the field NEVER involved a failure to respond to an OV event . . . at least if one did, I was not made privy to it. All of our products have a lifetime warranty: https://matronics.com/aeroelectric/Catalog/warranty.html Difficulties I was aware of involved nuisance tripping in both my production units and similarly configured OV management features in B&C products. Some DIY'ers had difficulties too which became the rotten tomato ammunition for some of the more vociferous antagonists here on the List. Root cause for those event were discovered and resolved. So what we're looking for with this new version is unwarranted sensitivity to normal perturbations in DC power system bus voltage . . . generated by the operation of vehicle accessories of all stripe. Based on what we've learned over the years, I think the current design will not suffer the same shortcomings. But if there ARE 'rats' in the current logic, I'd be delighted if we could chase 'em out early! Yeah, modern automotive designs do manage the 'dragons' quite well but put a 'scope on your car's bus some time . . . it's as trashy as the one in your airplane. Bob . . . //// (o o) ===========o00o=(_)=o00o======= = < Go ahead, make my day . . . > < show me where I'm wrong. > ======================== ======== In the interest of creative evolution of the-best-we-know-how-to-do based on physics and good practice. ________________________________________________________________________________
Date: Feb 12, 2024
I'll test one. I can put it in a mid-60s car that has been converted to negative ground. ________________ Best Regards, Al Fuller On Sat, Feb 10, 2024, 6:10 AM Robert L. Nuckolls, III < nuckolls.bob(at)aeroelectric.com> wrote: > At 12:23 AM 2/10/2024, you wrote: > > Hello Bob, > > Are you looking for testers for the prototypes? > > > I've had numerous volunteers to be > 'beta testers' of the new ovm. > > Performance testing will be carried > out in my shop with respect to confirming > 'the numbers' and stability of those > numbers under temperature extremes. > > Field tests will explore possible > vulnerability to un-anticipated > conditions in functional dc power > systems. > > They won't even need to be actively > guarding against failure of a regulator/ > alternator installation. > > I'll install 'em on two of my own > vehicles to simply 'watch the bus > thru a 5A breaker'. With the > ovm in the cabin and by means of > the functional verification feature, > I can exercise the critters every > time the engine is started . . . > while watching for vulnerabilities > to noise in the 'normal' mode. > > So yeah, I'd be interested in having > a few of these little guys similarly > exercised in more vehicles. > > Once we're reasonably satisfied > with this field qualification experiment, > 'test articles' will remain property > of the tester to be installed in > their project as needed. > > By using cars for the field test platforms, > we'll be able to secure a lot more > information than if first articles > went directly to airplanes. > > > Bob . . . > > //// > (o o) > ===========o00o=(_)=o00o======== > < Go ahead, make my day . . . > > < show me where I'm wrong. > > ================================ > > In the interest of creative evolution > of the-best-we-know-how-to-do based > on physics and good practice. > ________________________________________________________________________________
Date: Feb 17, 2024
Subject: OVM-14 MkIII boards here
Was out of pocket most of last week. I'll see if I can get one of these puppies populated this weekend! Bob . . . //// (o o) ===========o00o=(_)=o00o======== < Go ahead, make my day . . . > < show me where I'm wrong. > ================================ In the interest of creative evolution of the-best-we-know-how-to-do based on physics and good practice. ________________________________________________________________________________
Date: Feb 21, 2024
Subject: Matronics Web Repaired - Now Back Online...
The main Matronics Web Server had a pretty major disk corruption. After a LOT of work I was able to rebuild it and fully restore it from a recent backup. I am a believer in regular backups, especially now! Sorry it took so long, but I was really pulling my hair out on this one... Matt Dralle Matronics Email List & Forum Administrator ________________________________________________________________________________
Date: Feb 21, 2024
Subject: Re: Matronics Web Repaired - Now Back Online...
Thank you Matt, I appreciate what you do for us! On Wed, Feb 21, 2024 at 2:33=AFPM Matt Dralle wrote: m > > > > The main Matronics Web Server had a pretty major disk corruption. After a > LOT of work I was able to rebuild it and fully restore it from a > recent backup. I am a believer in regular backups, especially now! > > Sorry it took so long, but I was really pulling my hair out on this one.. . > > Matt Dralle > Matronics Email List & Forum Administrator > > =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Subject: help for tap off starter cable
Date: Feb 22, 2024
Good morning I'm in Australia, building an RV-8, with rear-mounted batteries. For the main feed from battery to starter and alternators, I'm using Tycab 35mm^2 flexible power and welding wire, part # ZDU1112102. =C2-On its ends I'm using Cabac =C2-CAL 35-6 tinned coper crimp lugs. However, I'd like to tap off this cable about half way along it to feed to my electrical/avionics bus. =C2-One way to do it would be to just brea k the cable, using lugs and a 6mm stud. =C2-I'm thinking about an alternative, stripping off about 20mm of insulation and wrapping with a copper tag, similar to Aero-Electric Connection book Figure 9-5 flag terminal. =C2-The wrap around the wire could be either soldered or crimped. Has anyone tried anything like this? =C2-Is there any reason why this might be a bad or good idea? Thank you for your help and advice. Dan Newman ________________________________________________________________________________
Date: Feb 21, 2024
Subject: Re: help for tap off starter cable
On Wed, Feb 21, 2024 at 7:20=AFPM Dan Newman <daniel.m.newman.au@gmai l.com> wrote: > Good morning > > I'm in Australia, building an RV-8, with rear-mounted batteries. > > For the main feed from battery to starter and alternators, I'm using Tyca b > 35mm^2 flexible power and welding wire, part # ZDU1112102. On its ends I 'm > using Cabac CAL 35-6 tinned coper crimp lugs. > > However, I'd like to tap off this cable about half way along it to feed t o > my electrical/avionics bus. One way to do it would be to just break the > cable, using lugs and a 6mm stud. I'm thinking about an alternative, > stripping off about 20mm of insulation and wrapping with a copper tag, > similar to Aero-Electric Connection book Figure 9-5 flag terminal. The > wrap around the wire could be either soldered or crimped. > > Has anyone tried anything like this? Is there any reason why this might > be a bad or good idea? > > Thank you for your help and advice. > > Dan Newman > Hi Dan, I wouldn't do it. Unless you're doing something very unusual in where you're mounting your primary bus, it will logically be between the instrument panel and the firewall; barely 18" of length difference, and actually closer to the electrical bus than a mid-point cut/splice. If you're trying to minimize firewall penetrations, I'd consider mounting the starter contactor on the cold side of the firewall. Then the 'hot' side of the starter contactor is still your distribution point, and only the starter cable penetrates the firewall (other than control/monitoring stuff, of course). FWIW, Charlie Virus-free.www.avast.com <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> ________________________________________________________________________________
Date: Feb 21, 2024
Hi Dan; Where are you going to tie in your ammeter? You want to measure all the current going to and from the battery. Cheers! Stu. From: "Dan Newman" <daniel.m.newman.au(at)gmail.com> Sent: Wednesday, February 21, 2024 5:15:18 PM Subject: AeroElectric-List: help for tap off starter cable Good morning I'm in Australia, building an RV-8, with rear-mounted batteries. For the main feed from battery to starter and alternators, I'm using Tycab 35mm^2 flexible power and welding wire, part # ZDU1112102. On its ends I'm using Cabac CAL 35-6 tinned coper crimp lugs. However, I'd like to tap off this cable about half way along it to feed to my electrical/avionics bus. One way to do it would be to just break the cable, using lugs and a 6mm stud. I'm thinking about an alternative, stripping off about 20mm of insulation and wrapping with a copper tag, similar to Aero-Electric Connection book Figure 9-5 flag terminal. The wrap around the wire could be either soldered or crimped. Has anyone tried anything like this? Is there any reason why this might be a bad or good idea? Thank you for your help and advice. Dan Newman ________________________________________________________________________________
Date: Feb 22, 2024
If Charlie's good advice does not fit your situation and you think it better to make a splice, then I would NOT make a flag terminal as described in fig 9-5 because it is designed for connecting to a battery. The screw and nut are unnecessary failure points and so is the ring terminal that is clamped to the flag. Perhaps a variation of this method would work for you: http://www.aeroelectric.com/articles/Tech_Tips/Solder_Lap_Splicing/Solder_Lap_Splices.html Make the splice as you intended without cutting the large cable, except, instead of a flag, wrap the small wire to the large cable with a fine strand and solder. Protect the splice against vibration. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513315#513315 ________________________________________________________________________________
Date: Mar 01, 2024
Subject: Video camera connection
I am trying to install a forward looking video camera in my Bearhawk cowlin g to help with taxiing, its pretty blind over the cowling. I purchased a ba ckup camera that installs in a 9/16" hole. I have the Garmin G3X, the video connection on the screens is a BNC connector. Supported formats are NTSC, PAL, and SECAM.=C2- Garmin says to connect the video with RG179 coax. The camera video connector has a single composite video plug with a red 20 ga pigtail coming out the back of the plug. I cut the connector off one end an d found that the cable contains 3 24ga wires, white, black and red. I would like to install a BNC connector at the camera so it can be disconnected fo r cowl removal. Then use a coax cable to connect to the G3X. I have no idea how to wire this. I have $17 invested in the camera, if someone knows of a small camera that comes wired with a BNC connector, I am all over it. ________________________________________________________________________________
Date: Mar 01, 2024
Subject: Re: Video camera connection
I used this adapter on the back of the G3X Touch display to connect the backup camera's RCA plug to the G3X's BNC connector. https://www.amazon.com/gp/product/B082D2RGCB/ref=ppx_yo_dt_b_search_asin_ title It sounds like the camera you are using is similar to the one I used: https://www.amazon.com/gp/product/B07QBMNVVB/ref=ppx_yo_dt_b_search_asin_ title --- David Carter david(at)carter.net On Fri, Mar 1, 2024 at 11:02=AFAM Rod Smith wr ote: > I am trying to install a forward looking video camera in my Bearhawk > cowling to help with taxiing, its pretty blind over the cowling. I > purchased a backup camera that installs in a 9/16" hole. I have the Garmi n > G3X, the video connection on the screens is a BNC connector. Supported > formats are NTSC, PAL, and SECAM. Garmin says to connect the video with > RG179 coax. The camera video connector has a single composite video plug > with a red 20 ga pigtail coming out the back of the plug. I cut the > connector off one end and found that the cable contains 3 24ga wires, > white, black and red. I would like to install a BNC connector at the came ra > so it can be disconnected for cowl removal. Then use a coax cable to > connect to the G3X. I have no idea how to wire this. I have $17 invested in > the camera, if someone knows of a small camera that comes wired with a BN C > connector, I am all over it. > ________________________________________________________________________________
Subject: Radio Interference
Date: Mar 01, 2024
I have a LOM M332 aircraft engine with 2 factory magnetos and an MGL V16 radio. Antenna is copper foil with balun epoxied into the VS There are no filters installed. While listening to ATIS (118.1) there is a ticking sound that is linked to the right magneto, it goes away when right mag is switched off. No noise when running only on left mag While listening to ATIS I can also hear static that is not there on the other frequencies I cannot be 100% certain but I think the noise is new. This noise is not present when listening to Tower (121.9) Any ideas on what could cause this Thanks Mike ________________________________________________________________________________
Date: Mar 02, 2024
Subject: Re: Radio Interference
Not knowing that particular engine's characteristics makes it even more difficult to remotely troubleshoot. But here are some generic things to think about. One thought (but not easiest to check) would be the condenser in the mag. (If it *is* the condenser, you'll be putting points in the mag soon. ;-) ) If the mags are the same or similar to each other, you might be able to swap the condensers between the mags to see if the noise moves to the other mag. Depending on the plug wire and plug specs, you could have damaged shielding on a plug wire, and/or if the engine uses resistor plugs like a Lyc, you might have a plug going bad. Then there's the possibility of grounding issues with that mag. Have you done a recent mag check before shutting down to be sure that killing both mags actually kills the engine? Depending on how the plane is wired, even that might not tell you if a P-lead shield is ungrounded. Has anything else changed in the wiring of the plane in general? If so, the work could have either removed a needed ground path or added one that wasn't there before, resulting in a 'ground loop' that is affecting the comm. Just shots in the dark; about the best that can happen 'long distance'. Virus-free.www.avast.com <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> On Fri, Mar 1, 2024 at 6:39=AFPM wrote: > I have a LOM M332 aircraft engine with 2 factory magnetos and an MGL V16 > radio. > > Antenna is copper foil with balun epoxied into the VS > > There are no filters installed. > > While listening to ATIS (118.1) there is a ticking sound that is linked t o > the right magneto, it goes away when right mag is switched off. > > No noise when running only on left mag > > While listening to ATIS I can also hear static that is not there on the > other frequencies > > I cannot be 100% certain but I think the noise is new. > > This noise is not present when listening to Tower (121.9) > > Any ideas on what could cause this > > > Thanks > > > Mike > ________________________________________________________________________________
Date: Mar 02, 2024
Try listening using a hand-held radio running on its own internal battery power. If there is no ignition noise on the hand-held radio, then it can be assumed that the noise in the aircraft radio is coming through the aircraft electrical system. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513332#513332 ________________________________________________________________________________
Date: Mar 03, 2024
Thanks Charlie this is bankable info On Sat, 02 Mar 2024, 23:59 Charlie England, wrote: > Not knowing that particular engine's characteristics makes it even more > difficult to remotely troubleshoot. But here are some generic things to > think about. > One thought (but not easiest to check) would be the condenser in the mag. > (If it *is* the condenser, you'll be putting points in the mag soon. ;-) ) > If the mags are the same or similar to each other, you might be able to > swap the condensers between the mags to see if the noise moves to the oth er > mag. > Depending on the plug wire and plug specs, you could have damaged > shielding on a plug wire, and/or if the engine uses resistor plugs like a > Lyc, you might have a plug going bad. > Then there's the possibility of grounding issues with that mag. Have you > done a recent mag check before shutting down to be sure that killing both > mags actually kills the engine? Depending on how the plane is wired, eve n > that might not tell you if a P-lead shield is ungrounded. > Has anything else changed in the wiring of the plane in general? If so, > the work could have either removed a needed ground path or added one that > wasn't there before, resulting in a 'ground loop' that is affecting the > comm. > > Just shots in the dark; about the best that can happen 'long distance'. > > > > Virus-free.www.avast.com > > <#m_-8209997907517583625_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> > > On Fri, Mar 1, 2024 at 6:39=AFPM wrote: > >> I have a LOM M332 aircraft engine with 2 factory magnetos and an MGL V16 >> radio. >> >> Antenna is copper foil with balun epoxied into the VS >> >> There are no filters installed. >> >> While listening to ATIS (118.1) there is a ticking sound that is linked >> to the right magneto, it goes away when right mag is switched off. >> >> No noise when running only on left mag >> >> While listening to ATIS I can also hear static that is not there on the >> other frequencies >> >> I cannot be 100% certain but I think the noise is new. >> >> This noise is not present when listening to Tower (121.9) >> >> Any ideas on what could cause this >> >> >> >> Thanks >> >> >> >> Mike >> > ________________________________________________________________________________
Date: Mar 04, 2024
Matt, I've been seeing a lot of "phpBB : Critical Error" messages lately when viewing the AeroElectric-List web interface. Repeated forced-reloads will sometimes cause it to load, but it's making the forum virtually unusable. Here's a screenshot, taken after clicking the "Preview" button on this post. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513343#513343 Attachments: http://forums.matronics.com//files/capture_126.jpg ________________________________________________________________________________
Date: Mar 04, 2024
I also have been having trouble opening the AeroElectric List. After trying several times, I might eventually succeed. Below is a copy of the error message that I get: phpBB : Critical Error Error creating new session DEBUG MODE SQL Error : 1062 Duplicate entry '1960' for key 2 INSERT INTO phpbb_sessions (session_id, session_user_id, session_start, session_time, session_ip, session_page, session_logged_in, session_admin) VALUES ('9803384edc1f80f8952e3ed4a46db8bf', 1960, 1709597076, 1709597076, '619ce26f', 3, 1, 0) Line : 187 File : sessions.php -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513344#513344 ________________________________________________________________________________
Date: Mar 04, 2024
I rarely use the web version, but I did today and I got the same errors several times. And if Matt sees this, I'm apparently not getting the email versions if someone posts to to the web version. Virus-free.www.avast.com <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> On Mon, Mar 4, 2024 at 6:19=AFPM user9253 wrote: > > I also have been having trouble opening the AeroElectric List. > After trying several times, I might eventually succeed. > Below is a copy of the error message that I get: > > phpBB : Critical Error > Error creating new session > DEBUG MODE > SQL Error : 1062 Duplicate entry '1960' for key 2 > > INSERT INTO phpbb_sessions (session_id, session_user_id, session_start, > session_time, session_ip, session_page, session_logged_in, session_admin) > VALUES ('9803384edc1f80f8952e3ed4a46db8bf', 1960, 1709597076, 1709597076, > '619ce26f', 3, 1, 0) > > Line : 187 > File : sessions.php > > -------- > Joe Gores > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=513344#513344 > > =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Mar 04, 2024
Internet Spammers fill up the Sessions table causing this error. I've clean the table, should work better now. Thank you for reporting. Matt Dralle -------- Matt Dralle Matronics Email List Administrator Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513346#513346 ________________________________________________________________________________
Date: Mar 06, 2024
The AeroElectric-List landing page loaded OK, but when I tried to click through to this thread, I got the error again. One reload attempt brought it up this time. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513358#513358 ________________________________________________________________________________
Date: Mar 18, 2024
Subject: Re: AeroElectric-List Digest: 1 Msgs - 03/06/24
I have not been getting the list since the below date. Is something wring with my e-mail? wrote: > ________________________________________________________________________________
Date: Mar 18, 2024
Matt repaired AeroElectric on Fri, 08 Mar 2024. It has been working fine since. But nobody has posted anything since then. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513390#513390 ________________________________________________________________________________
Date: Mar 19, 2024
Subject: Re: AeroElectric-List Digest: 2 Msgs - 03/18/24
Thanks Joe ________________________________________________________________________________
Subject: LM386 Output Capacitor
Date: Mar 20, 2024
Radio Shack's Engineer's Notebook by Forrest Mims is my favorite book. One page is devoted to the LM386. I made the "Audible Alarm". I question the value of the 22 microfarad output capacitor because all of the other LM386 circuits on that page use 220F output capacitors. Could that be a typo in the book and the value should be 220F? I used three 10F capacitors in parallel and the alarm works. Would it work better with a 220F capacitor? I increased the value of C1 to 1F to get a lower pitched tone. Are there any other suggestion for getting a lower pitched tone? I have trouble hearing high frequency tones in my old age. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513398#513398 Attachments: http://forums.matronics.com//files/audible_alarm_841.png ________________________________________________________________________________
Date: Mar 20, 2024
Subject: Re: LM386 Output Capacitor
On Wed, Mar 20, 2024 at 8:40=AFAM user9253 wrote: > > Radio Shack's Engineer's Notebook by Forrest Mims is my favorite book. > One page is devoted to the LM386. I made the "Audible Alarm". > I question the value of the 22 microfarad output capacitor because > all of the other LM386 circuits on that page use 220=C2=B5F output capaci tors. > Could that be a typo in the book and the value should be 220=C2=B5F? > I used three 10=C2=B5F capacitors in parallel and the alarm works. > Would it work better with a 220=C2=B5F capacitor? > I increased the value of C1 to 1=C2=B5F to get a lower pitched tone. > Are there any other suggestion for getting a lower pitched tone? > I have trouble hearing high frequency tones in my old age. > > -------- > Joe Gores It's been a really long time since I played with R-C filter formulas, but I'd bet that they went with 22 instead of 220 because they didn't need low frequency audio performance from the circuit. IIRC, the out capacitor sets the low frequency cutoff for the output. It's a 'point design' for a single, high frequency tone. IIRC, the LM386 is basically a high current opamp. I'd suggest downloading a copy of either the TI or National analog IC 'cookbook' to see circuits. Here's a 1kHz square wave oscillator from the TI LM386 datasheet : [image: image.png] The square wave will give a 'nastier' more irritating tone, which is what you'd want for an alarm. Virus-free.www.avast.com <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> ________________________________________________________________________________
Date: Mar 20, 2024
Thanks for that circuit Charlie. I will give it a try. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513400#513400 ________________________________________________________________________________
Date: Mar 20, 2024
I made the Texas Instruments square wave oscillator, substituting a speaker for the load resister. It works but with a high pitched tone. So then I went back to Forrest Mims' alarm circuit and put a 10F capacitor in parallel with C1. Now I am satisfied with the deeper tone. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513401#513401 ________________________________________________________________________________
Date: Mar 21, 2024
Subject: Instrumentation amplifiers
Trying to measure pressure in front of my radiators to somehow get uniform airflow through entire rad surface. A few years ago I bought 5 MPX10DP 10kPa (1.45psi) pressure sensors because they were relatively inexpensive. Been measuring 1" from each corner and center. But have now added steering vanes in # pattern -- in other words rad surface now divided into 9 squares. Throwing good money after bad I just ordered additional 4 MPX10DPs. Problem with the MPX10 sensors is they are not amplified (nor temperature compensated). Only outputs 35mV/10kPa. However outputs are offset at about 2.5V when fed 5V. Basically wheatstone bridge. The smarter move would have been using MPX5010DP sensors. They are internally amplified and temperature compensated. Output between 0.5 and 4.5V. However they are considerably more expensive. I've been using two of LM324 opamps for each sensor to handle offset and get the amplification I'd like. Had not looked at temperature compensation because mainly interested in relative pressures over the 5 channels. Not expecting to see more than 20 inH2O or 5 kPa so 250x amplification would be ideal but at least 140x to get full range from the MPX10DPs. Now I've seen mention of INA122 (about $5+ each) and similar instrumentation amplifiers which are designed for the MPX10DP type of sensors. Came across the INA350CDS instrument amplifier reasonably priced at less than $1 at Mouser. However only 50x amplification. Thinking of making a PCB for the 9 MPX10DPs and amps. Before I do I'm wondering if any of you have experience in this area (differential input instrument amplifiers with output going to 0-5V input A/D converters) and may have other suggestions. Inexpensive differential input instrument amplifiers with digital outputs? Or some other modern ICs I'm not aware of. Finn P.S. I did consider 3D printing a 9 to 1 valve to be driven by a stepper motor and just one MPX5010DP pressure sensor but worried about how long it would take for pressure to settle out after changing from one input to the next. Currently logging the 5 channels 2 times per second but able to log much faster. ________________________________________________________________________________
Subject: PZL 104 Wilga 80 Tachometer
Date: Mar 24, 2024
Good day, My tachometer stopped working. I tried to test with a multimeter with the engine on if there is a signal coming from the engine but I could not notice anything unless there is a proper way to connect the meter or check if the gauge is faulty. Could anyone be kind enough to advise on how I can test this? Many thanks Manel Cape Town[/b] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513405#513405 ________________________________________________________________________________
Subject: Re: PZL 104 Wilga 80 Tachometer
Date: Mar 24, 2024
Is your meter capable of measuring frequency? If not, try AC. The vast majority of electrical problems are due to bad electrical connections. Check for a loose or corroded connection or a broken wire. What is the make and model of the tachometer? -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513406#513406 ________________________________________________________________________________
Subject: Re: Which Oil Pressure Switch?
Date: Mar 26, 2024
I've been away from electrical work on my project while I installed engine and related accessories. I'm reviving this thread on ways to activate a hobbs meter without using an oil pressure switch. I have an LED hobbs meter that I would like to wire so that it will display the hours when the batt switch is on , but not count time. I would like the timer to begin when engine is started. As a review from the previous threads above, I have a 3-terminal hobbs (+, -, and Enable). The positive terminal is fed from the Main Power Bus when batt is switched, and negative to firewall ground bus. The LED digits illuminate with Batt switch on. I now need a way to power the Enable terminal to begin the timer. I have an idea but not sure of the part I need or if it even exists. Here the plan. The positive terminal will have the 12v input from the main power bus. Also, I will have a feed wire from the positive terminal to the "Unknown Device". The wire will continue from the unknown device to the Enable pin on the hobbs meter. The "Unknown Device" will need to block power until volts are above batt voltage.. say 13V??. When the engine is started and alternator is switched on, power will pass the unknown device and power the enable terminal of the hobbs meter. Does this "Unknown Device" exist, and does the plan seem feasible? Links to PDF drawings of a simple wire diagram and also tech sheet of the Honeywell LCD Hour meter. Thanks for the help. Shawn Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513410#513410 Attachments: http://forums.matronics.com//files/honeywell_lcd_hour_meter_173.pdf http://forums.matronics.com//files/hobbs_meter_117.pdf ________________________________________________________________________________
Date: Mar 26, 2024
I have a battery charger that senses vibration caused when the engine is started, and uses that as a trigger. I wouldn't have any idea how to procure or implement a vibration sensor as a trigger for your Hobbs, but I'll bet some of the guys on this list do. On Tue, Mar 26, 2024 at 5:28=AFAM Mudfly wrote: > shawntedwards(at)hotmail.com> > > I've been away from electrical work on my project while I installed > engine and related accessories. > I'm reviving this thread on ways to activate a hobbs meter without > using an oil pressure switch. I have an LED hobbs meter that I would > like to wire so that it will display the hours when the batt switch is on > , > but not count time. I would like the timer to begin when engine is > started. > As a review from the previous threads above, I have a 3-terminal > hobbs (+, -, and Enable). The positive terminal is fed from the Main > Power Bus when batt is switched, and negative to firewall ground bus. The > LED > digits illuminate with Batt switch on. I now need a way to power the > Enable terminal to begin the timer. > I have an idea but not sure of the part I need or if it even exists. > Here the plan. The positive terminal will have the 12v input from the > main power bus. Also, I will have a feed wire from the positive terminal > to > the "Unknown Device". The wire will continue from the unknown > device to the Enable pin on the hobbs meter. The "Unknown Device" > will need to block power until volts are above batt voltage.. > say 13V??. When the engine is started and alternator is switched on, > power will pass the unknown device and power the enable terminal of the > hobbs meter. > Does this "Unknown Device" exist, and does the plan seem feasible? > Links to PDF drawings of a simple wire diagram and also tech sheet of the > Honeywell LCD Hour meter. > Thanks for the help. > Shawn > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=513410#513410 > > > Attachments: > > http://forums.matronics.com//files/honeywell_lcd_hour_meter_173.pdf > http://forums.matronics.com//files/hobbs_meter_117.pdf > > =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Mar 26, 2024
On Tue, Mar 26, 2024 at 8:28=AFAM Mudfly wrote: > shawntedwards(at)hotmail.com> > > I've been away from electrical work on my project while I installed > engine and related accessories. > I'm reviving this thread on ways to activate a hobbs meter without > using an oil pressure switch. I have an LED hobbs meter that I would > like to wire so that it will display the hours when the batt switch is on > , > but not count time. I would like the timer to begin when engine is > started. > As a review from the previous threads above, I have a 3-terminal > hobbs (+, -, and Enable). The positive terminal is fed from the Main > Power Bus when batt is switched, and negative to firewall ground bus. The > LED > digits illuminate with Batt switch on. I now need a way to power the > Enable terminal to begin the timer. > I have an idea but not sure of the part I need or if it even exists. > Here the plan. The positive terminal will have the 12v input from the > main power bus. Also, I will have a feed wire from the positive terminal > to > the "Unknown Device". The wire will continue from the unknown > device to the Enable pin on the hobbs meter. The "Unknown Device" > will need to block power until volts are above batt voltage.. > say 13V??. When the engine is started and alternator is switched on, > power will pass the unknown device and power the enable terminal of the > hobbs meter. > Does this "Unknown Device" exist, and does the plan seem feasible? > Links to PDF drawings of a simple wire diagram and also tech sheet of the > Honeywell LCD Hour meter. > Thanks for the help. > Shawn > > 1st thing that comes to mind is a comparator circuit . It looks at two inputs, and outputs when the trigger input exceeds the reference input. If you set the reference input to 13V using a voltage regulator, then the trigger input would go above that when the alternator comes on line. Potential downside is that the Hobbs will stop counting if the alternator fails. If you don't know about it, a 'Tiny Tach' works in a similar manner but has an internal battery. The sense lead is normally wrapped around a spark plug lead; won't work with shielded leads. But you can make it work with a slight mod to the distributor cap on a mag. Charlie Virus-free.www.avast.com <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> ________________________________________________________________________________
Date: Mar 26, 2024
You could modify Bob's latest overvoltage module to do what you need.=C2 - Change the trip point to 13.5 volts, and remove the SCR. >From schematic 9003-630-IP6:Change R7 from 13.7K to 11KRemove Q15Add a wire from U11B pin 7 to the enable input=C2- of the hour meter. What we don't know is how much current the enable input to the hour meter d raws.=C2- To test, place a 2.49K resistor between the enable input of the hourmeter and 12Volts.=C2- If it starts counting, no additional changes to the OVM need to be made.=C2-=C2- tmail.com> wrote: om> I've been away from electrical work on my project while I installed engine and related accessories.=C2- I'm reviving this thread on ways to activate a hobbs meter without using an oil pressure switch.=C2- I have an LED hobbs meter that I would like to wire so that it will display the hours when the batt switch is on , but not count time.=C2- I would like the timer to begin when engine is st arted. As a review from the previous threads above, I have a 3-terminal hobbs (+, -, and Enable).=C2- =C2- The positive terminal is fed from th e Main Power Bus when batt is switched, and negative to firewall ground bus . The LED digits illuminate with Batt switch on.=C2- I now need a way to power the Enable terminal to begin the timer.=C2- I have an idea but not sure of the part I need or if it even exists. Here the plan.=C2- The positive terminal will have the 12v input from the main power bus.=C2- Also, I will have a feed wire from the positive term inal to the "Unknown Device".=C2- The wire will continue from the unknown device to the Enable pin on the hobbs meter.=C2- =C2- The "Unknown Devi ce" will need to block power until volts are above batt voltage.. say 13V??.=C2- When the engine is started and alternator is switched on, power will pass the unknown device and power the enable terminal of the hobbs meter.=C2- =C2- Does this "Unknown Device" exist, and does the plan seem feasible? Links to PDF drawings of a simple wire diagram and also tech sheet of the Honeywell LCD Hour meter. Thanks for the help. Shawn Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513410#513410 Attachments: http://forums.matronics.com//files/honeywell_lcd_hour_meter_173.pdf http://forums.matronics.com//files/hobbs_meter_117.pdf - S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Mar 26, 2024
Thanks for the Ideas. Kenryan, I have seen the vibration activated hour meters. Definitely the most simple solution. Unfortunately, I already have the Honeywell installed in my panel and will try and make that work if I can. Charlie, I will do some studying of the comparator circuit. Looks like it could work. Mike, Thanks for the details on how to modify Bob's overvoltage module. I haven't been able to locate schematic 9003-630-IP6 you mentioned. I will keep searching. Shawn Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513416#513416 ________________________________________________________________________________
Date: Mar 26, 2024
eBay item number:364742288098 might be the device that you are looking for. Or maybe this one from Amazon: https://www.amazon.com/XH-M609-Digital-Disconnect-Discharge-Protection/dp/B07WRZSJ5M Instructions written in Chinlish: https://www.robotics.org.za/XH-M609 -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513417#513417 ________________________________________________________________________________
Date: Mar 26, 2024
I used the XH-M609 for a low voltage shutoff and posted about it here with directions: http://forums.matronics.com/viewtopic.php?t=16776629&postdays=0&postorder=asc&start I believe that the XH-M609 can also detect high voltage, but am not sure. -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=513418#513418 ________________________________________________________________________________
Date: Mar 26, 2024
[quote="user9253"]eBay item number:364742288098 might be the device that you are looking for. Or maybe this one from Amazon: https://www.amazon.com/XH-M609-Digital-Disconnect-Discharge-Protection/dp/B07WRZSJ5M Instructions written in Chinlish: https://www.robotics.org.za/XH-M609[/quote]
December 23, 2023 - March 26, 2024
AeroElectric-Archive.digest.vol-rp
