Aerobatic-Archive.digest.vol-ad
June 09, 2005 - November 30, 2009
Who built your prop?
Mike Larkin
-----Original Message-----
From: | owner-aerobatic-list-server(at)matronics.com |
[mailto:owner-aerobatic-list-server(at)matronics.com] On Behalf Of
pullsomegs(at)AOL.COM
airrendezvous(at)mcleodusa.net; carolrob(at)intergate.ca; ELeuter(at)AOL.COM;
GWG1650(at)AOL.COM; jeff(at)parnau.com; michaelhmoore(at)yahoo.com;
SGerow(at)AOL.COM; jim(at)whirlwindpropellers.comacro@aerobatics.ws;
acro(at)gf24.de; aerobatic-list(at)matronics.com; airrendezvous(at)mcleodusa.net;
carolrob(at)intergate.ca; ELeuter(at)AOL.COM; GWG1650(at)AOL.COM;
jeff(at)parnau.com; michaelhmoore(at)yahoo.com; SGerow(at)AOL.COM;
Subject: | [acro] Prop Failure CAUSE DETERMINED |
My propeller has been inspected by the manufacturer. Apparently the
wrong type of thread lock (permatex) was used by the overhaul shop, that
assembled it last winter. All of the pin base bolts had lost torque, and
the failure occuured as a result of loose bolts on the pin base that
failed. The prop is being repaired and the proper thread lock (locktite)
is being used. I had noticed one blade seemed a little looser over the
last few weeks and had planned to have it looked at by the prop shop on
the way to my next show....didn't make it that long :) I would suggest
checking the blades by twisting them in pitch and have any looseness
inspected. The bottom line is that this was an error in reasssembly by a
prop shop and not a problem with the propeller design...
Thanks to all who called and wrote...
Skip
Hi, I operate an EA300s with AEIO-540 standard spec and am having difficulty
with hot starts. Suggestions appreciated.
Currently, priming till no more vapour in injector lines, WOT then rich when
it fires and set throttle with pump on.
Left Mags has been OH'ed and is up to spec.
http://www.yakuk.com/elite.asp is the a/c.
Best regards, fly safe-Mark Jefferies
For YAK UK Ltd www.yakuk.com
Lt Gransden Airfield
Sandy, Beds
SG19 3BP
England.
Tel +44 (0)1767 651156.
Fax +44 (0)1767 651157
Mobile +44 (0)7785 538 317
Conditions and terms of business
Aircraft for sale
From: | "Rick Basiliere" <discrab(at)earthlink.net> |
Hi Mark;
Another method I've used is to run the fuel pump with the mixture in idle
cut off for say 30 seconds to a minute. This will circulate cool fuel in
the lines without putting any in the engine. After this try a normal start.
BTW, the smoke system for my Yak-55 is awesome - thanks.
Rick
[mailto:owner-aerobatic-list-server(at)matronics.com]On Behalf Of Mark
Jefferies
Subject: Aerobatic-List: hot starts
Sandy, Beds
SG19 3BP
England.
Aircraft for sale
From: | "Ron Carter" <ronc(at)metropolisdesign.com> |
On my IO-540 c4b5-
1. I leave throttle closed and mixture lean.
2. Run pump to pressurize gauge
3. Crank engine while simultaneously advancing mixture, as soon as you hear
a couple pops open throttle slowly.
4. When it catches go full rich with mixture, or advance mixture to your
regular ground setting.
Cross your fingers!
Ron Carter
Harmon Rocket II
----- Original Message -----
difficulty
when
> Sandy, Beds
> SG19 3BP
> England.
> Aircraft for sale
From: | "Phil Sisson, Litchfield Aerobatic Club" <sisson(at)consolidated.net> |
Subject: | [Fwd: [acro] Ohio Aerobatic Open UNOFFICIAL results] |
Here are the scores for the Ohio Contest held over the weekend. The
Salem IL contest will be in a month and it is sponsored by chapter 61.
Everyone is welcome.There is always a good time. Motels are close by,
and camping is permitted on the field...
Phil
-------- Original Message --------
Subject: [acro] Ohio Aerobatic Open UNOFFICIAL results
Date: Mon, 27 Jun 2005 19:46:16 -0500
Thanks again to one and all who braved the 90 degree heat and humidity!
(Better that than rain). We had a great time, met a lot of new people
and flew everyone three times except Primary. Only one short lightening
show kept us on the ground for an hour and a half.
It was a new place for the Ohio contest and we had a few things to
learn, but the net result seems to be that they want us to come back!
So, we look forward to seeing you and having our contest in Marysville
Ohio (MRT) once again in June 2006!
Following are the UNOFFICAL contest Results:
Primary
Ch
Known
Free
TOTAL
%pp%
1.Giles Henderson
61
400.60
413.00
813.60
90.40
2.Craig Henry
399.10
789.50
87.72
3.Tyler Will
373.00
386.00
759.00
84.33
4.Rusty Bogue
377.70
369.20
746.90
82.99
5.John Sollinger
34
372.90
372.20
745.10
82.79
6.Eric Backscheider
34
382.80
341.70
724.50
80.50
7.Elliot Abel
34
343.50
342.60
686.10
76.23
Sportsman
Ch
Known
Free
Unknown
TOTAL
%pp%
1.Gordon Penner
34
1222.60
1270.10
1286.30
3779.00
86.87
2.Joe Haycraft
61
1198.50
1293.40
1236.80
3728.70
85.72
3.Matt Miller
1247.10
1207.50
1265.30
3719.90
85.51
4.Douglas Lovell
52
1223.50
1228.40
1224.20
3676.10
84.51
5.Michael Wild
34
1207.30
1226.90
1215.30
3649.50
83.90
6. Stan Moye
1206.80
1219.10
3630.40
83.46
7.Keith Register
1188.00
1192.50
1249.50
3630.00
83.45
8.Randy Wolfe
34
1159.80
1222.00
1246.30
3628.10
83.40
9.Robert Baker
58
889.40
1111.80
1084.60
3085.80
70.94
10.Greg Kuehner
34
1174.70
1091.30
449.60
2715.60
62.43
11.Ed Larkin
34
1026.90
1190.50
0.00
2217.40
50.97
Intermediate
Ch
Known
Free
Unknown
TOTAL
%pp%
1.Bruce Ballew
61
1768.10
1740.40
1264.00
4772.50
85.22
2.Bob Richards
1666.40
1263.90
4658.40
83.19
3.Bill Weber
34
1740.50
1684.30
1216.90
4641.70
82.89
4.Jeff Granger
34
1665.50
1719.80
1246.40
4631.70
82.71
5Ashley Messenger
34
1592.70
1683.00
1227.90
4503.60
80.42
6.Wayne Buescher
88
1705.60
1619.90
1169.10
4494.60
80.26
7. Dick MacDonald
88
1333.70
1552.00
962.90
3848.60
68.72
Advanced
Ch
Known
Free
Unknown
TOTAL
%pp%
1.Walter Plentis
88
2118.20
2728.10
2404.40
7250.70
86.83
2.James Hogg
34
2075.80
2625.10
2373.40
7074.30
84.72
3.Steve Johnson
61
2018.50
2639.90
2168.90
6827.30
81.76
4.Rob Bond
1941.90
2651.60
2179.00
6772.50
81.11
5.Scott Gusakov
88
1812.90
2503.90
2030.60
6347.40
76.02
Unlimited
Ch
Known
Free
Unknown
TOTAL
%pp%
1.Steve Grohsmeyer
11
2387.50
3777.33
3052.00
9216.83
79.46
2.Brett Hunter
34
2435.30
2499.10
2996.70
7931.10
68.37
3.Dennis Thompson
52
2440.70
2890.79
1522.70
6854.19
59.09
4.Hugo Ritzenthaler
88
2275.20
2779.68
1520.80
6575.68
56.69
5.Michael Vaknin
0.00
2663.10
5110.90
44.06
Lorrie Penner, IAC34 Secretary
513-284-5076 (cell) 513-791-7331(hm)
7628 Plainfield Rd.
Cincinnati, OH 45236
Subject: | List Digest Truncation Fixed!! |
Dear Listers,
I finally figured out today what was causing the occasional
truncation of the daily List Digest emails. Seems that every once in
a while a message would contain a single "." (period) on line all by
itself. The mailers would see this and assume that this was the
universal emailer signal for "end of message", and consequently
wouldn't process any of the rest of the Digest message.
I've put in a filter today to remove any of these sequences so we
should be back in business on the Digests.
Best regards,
Matronics Email List Admin.
Subject: | Oshkosh bound from South Mid-west |
If you are going to Oshkosh, you may want to consider a stop at our
little small town airport.
3LF http://www.litchfieldil.com/airport/
take a look at the photography, the young eagle links, the pilot info
and then.......... stop over here for a night.
Gas is guaranteed at $2.85 a gallon (self service, like at the car gas
stations). We have a courtesy car ( old chevy, not pretty. but runs
good) No, the gas price is not very good, but it is the best we can do
and it will be this price on return trip also. We are about 340 or 350
miles straight south of Oshkosh..
On field camping, and motels within 1 mile walk. restarants, bars, Free
overnighting and Admin. bulding will be
Kept open for rest rooms and what ever. Sleep in there if you want......
Broadband Internet.
Pass this information around to the other lists if you dont mind.
Bring your tie downs and ropes that you will need in Oshkosh just in
case we would have more than eight planes here. There is plenty of grass
for tie downs.......
Also Chapter 61, Acro contest will be going on that weekend at Salem
Illinois.(about 45 miles southeast) Feel free to stop in there for some
great competition and partying....
Phil RV6 flown and tore down now for painting............
Sure wish I had a Pitt's to Fly..........
Subject: | Matronics Web Server Upgrade Today Tuesday 09/06/05 5pm |
PDT
Dear Listers,
I will be taking the Matronics Web Server down for a few hours today,
Tuesday September 6 2005 for a chassis upgrade. Archive browsing and
searching along with subscription services will be unavailable for
be processed normally during the upgrade. Please check the Matronics
System Status Page for updates (although this page resides on the web
server and won't be available during the upgrade):
http://www.matronics.com/SystemStatus/
From: | "Brian Fowler" <brianf(at)fowlerssheetmetal.com> |
Subject: | RE: Aerobatic-List Digest: 0 Msgs - 09/25/05 |
Please remove me from the Aerobatic List.
Brian
Aerobatic-List Digest Server
Subject: Aerobatic-List Digest: 0 Msgs - 09/25/05
Today's complete Aerobatic-List Digest can also be found in either of the
of the Aerobatic-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/aerobatic-list/Digest.Aerobatic-List.200
5-09-25.html
Text Version:
5-09-25.txt
Aerobatic-List Digest Archive
Total Messages Posted Sun 09/25/05: 0
Today's Message Index:
Subject: | will work for flight(s) |
To All / Any,
I am just a simple girl from the East Coast who likes to go flying, and
will be in San Mateo at the end of November (Thanksgiving to December)
Does anyone know of a good place to fly from for a visiting enthusiast?
Or a good person to fly with? ((my first time upside-down in an airplane was
last year in a Giles 202 w/a wicked paint scheme)
I'm "mechanically inclined" & will work for flight(s)
The last time I was in CA, I got to fly in a T-34 !!!
Respectfully,
"*Shasta*"
*"We are all islands in a common sea"
--* Anne Morrow Lindbergh
http://www.geocities.com/shasta_fly/
From: | "Richard Basiliere" <BasiliereR(at)ci.boulder.co.us> |
INNOCENT GLOBAL 0.3407 1.0000 -0.4138
I just helped a friend pull a 360 horse M14P off his Sukhoi 26mx. He
upgraded to the M14PF is the reason for pulling it.
It has 750 hours TTSN, Savage ignition harness, fresh annual
conditional inspection, compressions 72-78/80. It has been A+P owned
and operated for the last 5 years. It's in "good condition" according
to Don.
$11,000. contact me off list, please.
Don has also made a couple of 1500 psi compressors that operate on
28vdc. He uses them to charge either his Sukhoi or his scuba bottles.
$500 each They are small enough (almost) to fit in an Igloo cooler.
Also, what is my MTV-3-250 (German) overhauled by MT 2/03 - no ad's
now. 330 TSOH worth to any one???
Ok-OK - I bought Don's MTV-9-260 wide cord...mea culpa
Thanks, Rick b
From: | Mark Jefferies YAK UK Ltd <mark.j(at)yakuk.com> |
Subject: | FW: Aero GP - 2006 World Series |
YAK Club yahoo ,
YAK USA-list , aerobatic-list(at)matronics.com
Jeff Zaltman <jzaltman@aero-gp.com> wrote: From: "Jeff Zaltman" <jzaltman@aero-gp.com>
Subject: FW: Aero GP - 2006 World Series
Date: Tue, 27 Dec 2005 12:58:01 -0000
Dear pilots,
We spoke in early 2005 about our first Aero GP competition (held in Slovenia),
which met with great success! We had worldwide media coverage and our television
programme was broadcast on TV in more than 100 countries! In April 2006
our first full world series is beginning and were looking for more pilots to
join the tour.
Ive attached a brief introduction about it, so if you are interested in competing
in the Aero GP series this year please let me know soon. Please forward
this to anyone else who might be interested.
If not able to join us, we hope that you will still support our new series the
ultimate test of pilots in the world and help us promote it
I wish you all well and happy flying,
Jeff.
MORE INFO AT: www.aero-gp.com
Jeff Zaltman
Managing Director
Flying Aces Limited
4th Floor Hamilton House
Mabledon Place
London UK, WC1H 9BB
+44 (0)207 554 8650 (Office)
+44 (0)207 554 8652 (Direct)
+44 (0)207 554 8651 (Fax)
+44 (0)793 272 6990 (Mob)
Best regards, Mark
www.yakuk.com
+44 (0)1767 651156 office +44 (0)7785 538 317 mobile
From: | "Robert du Plooy" <rduplooy(at)iafrica.com> |
Subject: | Re: Aerobatic-List Digest: 0 Msgs - 01/02/06 |
Please delist me
From: "Aerobatic-List Digest Server" <aerobatic-list-digest(at)matronics.com>
Subject: Aerobatic-List Digest: 0 Msgs - 01/02/06
> HTML Version:
> http://www.matronics.com/digest/aerobatic-list/Digest.Aerobatic-List.2006-01-02.html
> Text Version:
> http://www.matronics.com/digest/aerobatic-list/Digest.Aerobatic-List.2006-01-02.txt
> Total Messages Posted Mon 01/02/06: 0
From: | "George Maxwell" <geomax(at)grapevine.net> |
Subject: | Re: Aerobatic-List Digest: 1 Msgs - 01/03/06 |
Please delist me from the aerobatic-list.
Thank You
George Maxwell
Subject: Aerobatic-List Digest: 1 Msgs - 01/03/06
> HTML Version:
> http://www.matronics.com/digest/aerobatic-list/Digest.Aerobatic-List.2006-01-03.html
> Text Version:
> http://www.matronics.com/digest/aerobatic-list/Digest.Aerobatic-List.2006-01-03.txt
> Total Messages Posted Tue 01/03/06: 1
> 1. 09:22 PM - Re: Aerobatic-List Digest: 0 Msgs - 01/02/06 (Robert du
> Plooy)
> ________________________________ Message 1
> From: "Robert du Plooy" <rduplooy(at)iafrica.com>
> Subject: Aerobatic-List: Re: Aerobatic-List Digest: 0 Msgs - 01/02/06
> Please delist me
> Thanks
>> HTML Version:
>> Text Version:
Why don't you follow the instructions from the list and delete yourself.
Dave
-------------- Original message from "George Maxwell" : --------------
> Thank You
> George Maxwell
> To: "Aerobatic-List Digest List"
> > HTML Version:
> html
> > Text Version:
> txt
> > Plooy)
> > Please delist me
> > Thanks
> >> HTML Version:
> html
> >> Text Version:
> txt
Dave
-------------- Original message from "George Maxwell" geomax(at)grapevine.net: --------------
-- Aerobatic-List message posted by: "George Maxwell"
Thank You
George Maxwell
From: "Aerobatic-List Digest Server" <AEROBATIC-LIST-DIGEST(at)MATRONICS.COM>
HTML Version:
html
Text Version:
txt
Plooy)
-- Aerobatic-List message posted by: "Robert du Plooy"
Please delist me
HTML Version:
html
Text Version:
txt
Web Site -
Subject: | All New BBS Interface For Matronics List Forums! |
Dear Listers,
I'm very proud to announce a completely new BBS interface is now available for
all of the Email Lists at Matronics! This is a full-featured system that allows
for viewing, posting, attachments, polls - the works.
But the best part is that it is *completely* integrated with all of the existing
email tools currently available at Matronics! What this means at the most basic
level is that, if you post a message to List from Email in the traditional
way, it will show up on the BBS system *and* get distributed to everyone currently
subscribed to the Email List. By the same token, if you are on the BBS
and post a message to a given List-Forum, the message will not only show up on
the BBS, but also be distributed to everyone on the Email List!!
It is really a very nice implementation and I am very pleased with its operation.
All of the tools you have come to know and love such as the List Search Engine
and List Browse and Download will still be available and contain all of the
latest posts. Think of the new BBS interface as just another method of accessing
the all of the Lists.
You can use the BBS to view all of the latest posts without having to do anything
except use your browser to surf over to the site. You can view and look at
all of the various List's posts. If you want to post a new message or reply
to an existing message from the BBS, you will have to Register on the BBS. This
is a *very* simple process and will only take a couple of minutes. There is
a small icon in the upper righthand side of the main BBS page labeled "Register"
to get you started.
I strongly recommend that you use the exact *same* email address you are subscribed
to the Email Lists with when registering on the BBS. Also, while not an
absolute requirement, I would really appreciate it if people would use their full
name when choosing their Username on the BBS (for example "Matt Dralle").
This just makes it easier for everyone to know who's posting. Also, I have enabled
the ability to upload a small user picture with your profile called an
"avatar". Please use a *real* picture of yourself *with* your cloths on! Thank
you! Maximum size of the bitmap is 120x120.
You can either be subscribed to the BBS, or any number of Email Lists, or both.
Registering on the BBS will allow you to email directly to all of the various
Lists. However, to receive direct List Email, you will need to be *subscribed*
to the various Lists as you have in the past. No changes here in operation.
I have added numerous links on the BBS pointing to the Email List subscription
page.
I've had the BBS connected to the Lists for about a week now, so its already loaded
up with a fair number of messages. You can post photos and other documents
directly to the BBS and links to them will appear in the List Email distributions.
Also, when any messages posted to the BBS are viewed in the List Email
distribution, there will be a URL link at the bottom of the message pointing
back to the BBS.
And here's what you've been waiting for -- the main URL for the new Matronics Email
List BBS is:
http://forums.matronics.com
Please surf on over, Register, and have a great time! I think this will be the
dawn of a whole new era for the Lists at Matronics!
Best regards,
Subject: | Six New Email Lists / Forums At Matronics! |
Dear Listers,
Its my pleasure to announce the addition of six new Email List / Forums to the
aviation line up at Matronics! These new lists support all the usual features
you've come to know and love from the Matronics Email List including full integration
with the All New Web BBS Forums Site!! The new Lists include:
LycomingEngines-List Textron/Lycoming Engines
RotaxEngines-List Rotax Engine for Aircraft
M14PEngines-List Vendenyev M14P Radial Engine
MurphyMoose-List Murphy Moose Aircraft
Allegro-List Allegro 2000, a Czech-built, Rotax-powered Aircraft
Falco-List Sequoia Aircraft's Falco Experimental
To sign up for any or all of the new Lists, surf over to the Matronics Email List
Subscription Form and follow the instructions:
http://www.matronics.com/subscribe
Don't forget to check out the All New Web BBS Forum now available along with all
of the usual message and archive viewing tools at the Matronics Email Lists
site. Surf over to the following URL for information on the BBS Forum:
Enjoy the new Lists!
Subject: | Matronics Email List Wiki! |
Dear Listers,
I have added a new feature to the Email List Forums at Matronics called a Wiki. What's "Wiki" you ask? A Wiki is a website. You go to it and browse just like you would any other web site. The difference is, you can change it. You can put anything you want on this web site without having to be a web designer or even being the owner. You can write a new page just like writing an email message on the BBS. You don't need to send it off to anyone to install on the site. It is kind of like a Blog (weblog) in which anyone can post. Here is a great page on where the term Wiki came from and what it means in the context of a website: http://en.wikipedia.org/wiki/Wiki
So on to the new Matronics List Wiki... I've created this site for anyone from
any of the Email Lists to use. I envision that there are a great many things
that can be added to this new Wiki since there are always new and interesting
tidbits of useful information traversing the Lists.
Off the main Matronics List Wiki page, you will find a link called "Community Portal".
Here you will find more links to stubs for all the various Lists found
at Matronics (and a few other links). Brian Lloyd others of Yak-List have already
been busy adding content in a number of areas. Bob Nuckolls of AeroElectric
fame has added a great article on "Ageing Aircraft".
I have discussed the new Matronics Email List Wiki with Tedd McHenry and Dwight Frye of the RV Wiki Site and they have decided to merge their site over onto the new Matronics Wiki server giving everyone a single source for information on RV building and flying! This migration will begin today and you should be able to find all of the content currently found at www.rvwiki.org moved over to the Matronics Wiki within a few days.
To make edits to the Matronics Wiki, you will need to have a login account on the
Matronics Wiki and have disabled anonymous edits. This protects the Wiki site
from automated spam engines and other nuisances that could compromise the
data at the site.
Signing up for an account is fast and easy and begins by clicking on the "create
an account or log in" link in the upper right hand corner of any page. Note
that you do not have to have a login or be logged in to view any of the content.
The Matronics Email List Wiki is YOUR Wiki! It is only as useful as the content
found within. The concept of the Wiki is that the people the use it update
it. If you've got an interesting procedure for doing something, MAKE A WIKI PAGE
ON IT! You can even upload pictures. Saw something interesting at a flyin?
MAKE A WIKI PAGE ON IT! Don't be shy, this is YOUR site to share information
with others with similar interests.
Here is a users guide on using the Wiki implemented at Matronics: http://meta.wikimedia.org/wiki/MediaWiki_User's_Guide This gives a lot of great information on how to get started editing pages.
And finally, here is the URL for the Matronics Email List Wiki:
http://wiki.matronics.com
Brian Lloyd has written an excellent introduction to Wikis on the front page.
I encourage you to read it over, then drill into the "Community Portal" and HAVE
FUN!!
Best regards,
Subject: | Fuse availability |
What follows is a message from a Paul Messenger's new Yahoo List concerning in-flight
availablity of fuses, etc. which seems to counter advice given in Bob's
book regarding in-flight availability of these devices.
Any comments on this posting greatly appreciated, as I am confused.
Jack Lucas[/color]
Message: 1
Date: Fri, 7 Apr 2006 13:26:14 -0700
Subject: ILLEGAL EQUIPMENT
Perhaps I need to point out a few very common misconceptions that can get you
grounded at best and void your aircraft insurance at worst.
My only purpose is to inform you.
Fuses for equipment essential for the flight conditions MUST be replaceable in
flight. I question why anything is on a small single engine aircraft that is not
essential to flight.
For example if a radio or light or heated pitot etc is requires for the
flight conditions taken they must be pilot accessible and spares on board.
Strobes must meet the FAR's if they are required for a specific flight
condition.
AeroFlash DO NOT MEET FARS. They are grandfathered for older type
certificated aircraft NOT new TC or experimental aircraft. That they are
sold for experimentals means they are ONLY legal when the flight condition does
not require them. This after personally speaking to the President of Aeroflash
some years ago.
Ever wonder why production aircraft come out with new models of an old
design where ever possible? Its to take advantage of grandfathering and thus allow
lower quality/cost equipment to be used as well as far lower
certification requirements.
Recognition lights must also meet FARs when required. There are several LED recognition
lights being sold as meeting the FARs but they do not. Like the AeroFlash
strobes you are being mislead. But at least the AeroFlash is reasonably close
(1/2) as bright where the LED's are far short of the required coverage. Soon
perhaps but not at present. Whelan has just started with one light and look
at the price of the first attempt!
Lets say you have fuses in your recognition light system and the fuse opens during
a night flight and you land at an airport with no lights and there happens
to be a FAA inspector on the ground and he walks over and inquired and finds
out the fuse must have blown and its not accessible in flight. Your C of A can
be rescinded and you can be sited with a violation. If your insurance Co finds
out your insurance is most likely voided.
Or you have an totally unrelated (to lighting or fuses) accident and it
comes out you have unapproved lights, fuses, etc. your insurance Co can and has
in some cases voided the insurance as there is a clause covering the requirement
to meet all applicable FARS. I have discussed this with both the FAA FSDO
and my insurance company so its not just an opinion.
As far as lights/strobes etc I want the brightest available and the multi
flash is the most attention getter I know of. See and Be seen can be a life
saver. Its a few hundred bucks more to get the best and a drop in the bucket in
a 60,000-150,000 aircraft.
"But the DAR signed off on my installation so it must be legal". That sign
off only means its likely in compliance for day VFR and the Pilot is
responsible (not the builder if different) to assure the aircraft fully
meets all requirements of the intended flight.
One of my pet peeves, sorry for the outburst :-)
Paul
http://forums.matronics.com/viewtopic.php?p=27235#27235
Subject: | Matronics BBS Forums |
Hello Listers,
I just wanted to send out a reminder to all of the Listers regarding the new-ish
BBS (Bulletin Board System) Forums that are available at Matronics for the Email
Lists. The BBS Forums give you Web-based access into the same email content
that is generated by the Email Lists. When an email message is posted to
any of the email lists, a copy of the message is also copied to the respective
List forum section on in the BBS Forums. By the same token, when a message is
posted within the BBS Forum interface context, it will also be posted to the
respective email list.
Basically, the BBS Forums give you yet another method of accessing the Matronics
Email List content. Some people prefer email, some prefer web forums; now you
can have it either way or both with the Matronics Lists!
You'll have to register for a login/password on the BBS Forum to _post_ from the
BBS, but you can view message content without registering for an account. To
Register for an account, look for the link at the top of the main BBS Forum
page entitled "Register". Click on it and follow the instructions. Site Administrator
approval will be required (to keep spammers out), but I will try to
get these approved in less than 24 hours.
If you haven't yet taken a look at the Matronics Email List content over on the
BBS Forum, surf on over and take a peek. Its pretty cool. The URL is:
I want to stress that the BBS Forums are simply an adjunct to the existing Matronics
Email Lists; another way of viewing and interacting with the Matronics List
content. If you like Email, great. If you like Web Forums, great. If you
like both, great. Its up to you how you view and create your content.
You will also find a URL link at the bottom of this email called Matronics List
Features Navigator. You can click on this link at any time to find URL links
to all of the other great features available on the Matronics site like the Archive
Search Engine, List Browse, List Download, FAQs, Wiki, and lots more.
There is a specific Navigator for each Email List and the link for this specific
List is shown below.
Thanks for all the great list participation and support; it is greatly appreciated!
Subject: | Two New Email Lists at Matronics and Wiki Reminder! |
Dear Listers,
I have added two new email Lists to the Matronics Line up today. These include
a Continental engine List and a Lightning aircraft List:
continental-list(at)matronics.com
http://www.matronics.com/Navigator?Continental-List
Everything related to the Continental aircraft engine. Sky's the limit on discussions
here.
lightning-list(at)matronics.com
http://www.matronics.com/Navigator?Lightning-List
This is an exciting new design from Arion Aircraft LLC in Shelbyville Tennessee. Pete Krotje has a very nice web site on the aircraft that can be found here: http://www.arionaircraft.com/
Also, if you haven't checked out the new Matronics Aircraft Wiki, swing by and
have a look. Remember, a Wiki is only as good as the content that the members
put into it. Have a look over some of the sections, and if you've got some interesting
or useful, please add it to the Wiki! Its all about YOU! :-) The
URL for the Matronics Wiki is:
Best regards,
Subject: | List Enclosure Support |
Dear Listers,
Over the years, I have resisted the urge to enable enclosure support on the Matronics
Lists for a number of reasons relating to performance, capacity, capability,
and security. However, its now 2006 and most everyone using email these
days is on an email client that, at some level, supports the viewing and handling
of enclosures. I get a fair amount of email each month from people on the
various Lists asking why their posts of this or that picture didn't go through.
Back quite a while ago by popular request, I enabled enclosure support for a few
Lists such as the RV10-List, Kolb-List, and the Tailwind-List. Contrary to
my fears, there really hasn't been any significant issues on these Lists relating
to the advent of enclosure support and for the most part, members have policed
themselves well with respect to the size of things they have posted.
Having enclosures enabled on some Lists and not others has given me a fair amount
of headaches with respect to filtering messages and content since the formats
are often quite different between a typical MIME encoded message and a generic
plain-text message. The spammers are getting more cleaver all the time and
are constantly trying to thwart my best efforts at keeping them from posting
to the Lists.
So, for these reasons, I've have decided to go ahead and enable limited enclosure
posting on all of the email Lists at Matronics. This will not only increase
the utility of the Lists, but will afford me a better opportunity to filter
out the chaff.
Here are some of the features and limits of enclosures on the Matronics Lists:
1) Enclosures will only be posted to the Real Time version of the
Lists.
2) Enclosures will NOT be included in the Daily Digest version of
the Lists.
3) Enclosures WILL BE forwarded on to the BBS Forum Web site.
4) Enclosures will NOT be appended to the Archives.
5) Enclosures will NOT be available in the List Browse feature.
6) Only the following file types and extensions will be allowed:
jpg, bmp, gif, txt, xls, pdf, and doc
All other enclosures types will be rejected and email returned to
sender. The enclosure types listed above are relatively safe from
a virus standpoint and don't pose a particularly large security risk.
7) !! All incoming enclosures will be scanned for viruses prior to posting
to the List. This is done in real time and will not slow down
the process of posting the message !!
Here are some rules for posting enclosures. Failure to abide by these rules could
result in the removal of a subscriber's email address from the Lists.
1) Pay attention to what you are posting!! Make sure that the files
you are enclosing aren't HUGE (greater that 1MB). Remember that there
are still people checking they're email via dial up modem. If you post
30MB worth of pictures, you are placing an unnecessary burden on these
folks and the rest of us, for that matter.
2) SCALE YOUR PICTURES DOWN!!! I don't want to see huge 3000 x 2000
pictures getting posted that are 3 or 4MB each. This is just
unacceptable. Use a program such as Photoshop to scale the picture
down to something on the order of 800 x 600 and try to keep the
file size to less-than 200KB, preferably much less.
Microsoft has a really awesome utility available for free that allows
you to Right-Click on a picture in Explorer and automatically
scale it down and resave it. This is a great utility - get it, use it!
http://www.microsoft.com/windowsxp/downloads/powertoys/xppowertoys.mspx
Look for the link "Image Resizer"
3) !! This would seem to go without saying, but I'll say it anyway. Do not
post anything that would be considered offensive by your grandmother.
And you know what I'm saying; I don't want to see anything even
questionable. !!
4) REMEMBER THIS: If you post a 1MB enclosure to a List with 1000 members
subscribed, your 1MB enclosure must be resent 1000 times amounting
to 1MB X 1000 = 1 Gigabyte of network traffic!! BE CAREFUL and BE COURTEOUS!
I hope everyone will enjoy the added functionality of enclosures. Please police
yourself and use good judgement when posting messages with enclosures using
the guidelines I've outlined above.
Best regards,
Subject: | Matronics Email List Web Server Upgrade Tonight... |
Dear Listers,
This evening I will be upgrading the Matronics Web Server hardware to a new Quad-processor
2.8Ghz Xeon system (yes, 4-physical CPUs!) with an Ultra 320 SCSI
Raid 5 disk system and 5GB of DDR2 RAM.
As with the older system, the new system will be running the latest version of
Redhat Linux. Most of the software configuration work is already done for the
migration, but I still have to sync all of the archive and forum data from the
old system to the new system. I am anticipating about 2 to 3 hours of downtime
for me to fully make the transition, although it could be considerable less
if everything goes according to plan.
The Matronics Webserver will be *UNavailable* from the Internet during the work,
and you will receive a time-out if you try to connect during the upgrade.
Email List Distribution will be *available* during the upgrade of the Web Server,
and List message distribution will function as normal.
This represents a significant performance upgrade for the Matronics Web Server
and you should notice nicely improved searching and surfing performance following
the upgrade!
Best regards,
Subject: | New Incoming Message Size Limit Implemented... |
Dear Listers,
Due to a number of requests to limit the size of incoming posts to the Lists because
of the recently added enclosure feature, I have add a new filter that will
limit the total size of any given message posted to the List. I have initially
set the limit to 2MB
and we'll see how everyone likes that.
If a member attempts to post a message that is greater than the set limit, they
will receive an email back indicating that their message wasn't posted to the
List and why. Also included in the message will be the current size limit and
how large their message
was.
Some might say that 2MB is still too large, but its a place to start...
Best regards,
Subject: | Please Unsubscribe Me! |
Sent: Monday, September 04, 2006 2:05 AM
Subject: Aerobatic-List Digest: 0 Msgs - 09/03/06
HTML Version:
2006-09-03.html
Text Version:
2006-09-03.txt
Total Messages Posted Sun 09/03/06: 0
From: | "Dennis Jones" <djones(at)northboone.net> |
Does anyone have the install manual to the EZE Instruments G Spot G meter model
number GS95-A. The company no longer carries the manual for this particular meter.
http://forums.matronics.com/viewtopic.php?p=62295#62295
From: | Mark Sorenson <marksorenson(at)sprintpcs.com> |
Our annual chapter BBQ is fast approaching. As mentioned in the newsletter, on
the date of our next scheduled practice -- October 7th, 2006 -- we will meet at
Big T in Senoia,GA for food, fellowship, and flying, though not necessarily
in that order. Mark Sorenson and Butch Walker will host this gathering which promises
to be a great time! Come out and join the fun.
Date/Time: 10/7/2006, 10:00 arrival at the earliest; ending late afternoon.
Invited: All chapter members, family, friends, Big T neighbors, aerobatic enthusiasts
(especially if they might want to join!) Fly in, drive, walk, whatever.
Food: Grilled stuff; probably hamburgers, hot dogs, etc.
Gas: Some gas will be available, but no cheaper than Tara.
Flying: There is space next to the field for practice and critiquing will be available,
but there is NO WAIVERED AIRSPACE at Big T.
Mark has offered to place cones to mark center field and 500 ft. to the end of
the runway (it's 2200ft long). If you decide you don't want to land there, Tara
and Falcon are not far away.
For more information on the field and how to get there, try Skyvector. Search
for 64GA in the Airport/VOR/Fix box. Map will center on Big T and provide current
METAR info for nearby reporting stations.
For field information, Airnav is a good source. It has an aerial picture of the
strip and lots of runway and navaid info.
122.85 is the field freq.
Left hand traffic for Rwy 34 and Right Hand traffic for Rwy 16.
For any field-related questions, call Mark at 678-463-5944.
If you are driving, Google Maps should help.
If you have questions, please contact Tim Walter via e-mail (president(at)iac3.org)
or 678-406-0620.
Looking forward to seeing everyone there!
Best Regards,
Mark-
678-GO-FLY-HI-lander aircraft
Sprint PCS Mail
Subject: | Comcast Was Blocking Matronics Email Lists... |
Dear Listers (Specifically Comcast Listers),
For about the last two days, Comcast was blocking incoming email from the Matronics
Email Lists because their spam filters thought the mail was spam. I was
that people on Comcast are receiving List messages again.
If you are a Comcast user, you might want to email them and express your displeasure
with their Spam blocking policy, particularly as it relates to "matronics.com".
Sorry for the hassle...
Subject: | Matronics Email List Fund Raiser - November! |
Dear Listers,
Each November I hold a PBS-like fund raiser to support the continued operation
and upgrade of the List services at Matronics. It's through these sole Contributions
of List members that these Matronics Lists are possible.
You have probably noticed that there are no banner ads or pop-up windows on any of the Matronics Lists or related web sites such as the Forums site ( http://forums.matronics.com ), Wiki site ( http://wiki.matronics.com ), or other related pages such as the List Search Engine ( http://www.matornics.com/search ), List Browse ( http://www.matornics.com/listbrowse ), etc. This is because I believe in a List experience that is completely about the sport we all enjoy - namely Airplanes and not about annoying advertisments.
During the month of November I will be sending out List messages every few days
reminding everyone that the Fund Raiser is underway. Each message will generally
highlight a particular feature or benefit of the Matronics Lists or detail
a new feature or service that was added this year. I ask for your patience
and understanding during the Fund Raiser and throughout these regular messages.
The Fund Raiser is only financial support mechanism I have to pay all of the
bills associated with running these lists.
Once again, this year I've got a terrific line up of free gifts to go along with
the various Contribution levels. Most all of these gifts have been provided
by some of the vary members and vendors that you'll find on Matronics Lists and
have been either donated or provided at substantially discounted rates.
This year, these generous people include Bob Nuckolls of the AeroElectric Connection (http://www.aeroelectric.com/), Paul Besing of Aeroware Enterprises aka Kitlog Pro (http://www.kitlog.com/), Andy Gold of the Builder's Bookstore (http://www.buildersbooks.com/), and Jon Croke of HomebuiltHELP (http://www.homebuilthelp.com/).
These are extremely generous guys and I encourage you to visit their respective
web sites. Each one offers a unique and very useful aviation-related product
line. I would like publicly to thank Bob, Paul, Andy, and Jon for their generous
support of the Lists again this year!!
You can make your List Contribution using any one of three secure methods this
year including using a credit card, PayPal, or by personal check. All three methods
afford you the opportunity to select one of this year's free gifts with
a qualifying Contribution amount!!
To make your Contribution, please visit the secure site below:
https://www.matronics.com/contribution
I would like to thank everyone in advance for their generous financial AND moral
support over the years. I know it sounds a little cliche, but you guys really
do feel like family.
Thank you for your support!
Subject: | Have You Tried The New Matronics List Forum? |
Hello Listers,
One of the major new additions to the Matronics Email Lists this year was the addition
of a new and full function Forum Web Site at:
The best part of these new Forums is that they are tied directly to the Classic
email distribution Lists! That also means that posts go in both directions.
If you post a message on the Forum web site, it will be cross posted to the respective
Email List. And, if you post a message to a particular Email List,
it will be cross posted to the same respective forum on the Forum site!
So, no matter what your content viewing pleasure is - either direct email distribution
or web-based GUI interface, you can have it at the Matronics Email Lists!
Won't you make a Contribution to support these Lists? It is your SOLE Contributions
that make their continued operation and upgrade possible!
The Contribution site is Fast, Easy, and Secure. Please surf over and make your
Contribution today:
Thank you!!
_-
_-
_-
_-
_-
_-
Subject: | Wow, Cool! New List Feature... [Please Read] |
Dear Listers,
By popular suggestion, I've written a substantial new code module for the Matronics
Email Lists system. Here's how it works...
During each November, I send out quite a few PBS-like "Please make a Contribution
to support your List" emails. Wouldn't it be cool if, once a member made a
Contribution, they didn't have to receive my support pleas anymore for the rest
of that year?
Well, that's exactly what I've written! Following this posting, anyone that makes
a List Contribution in 2006 will no longer receive my Contribution Pleas for
the rest of the year!
The best part is this not only applies to the Realtime distribution, but also the
Digest distribution! For those that have made a Contribution, the Daily Digest
email-version will be invisibly stripped of my requests as well! (Note that
my requests will still be present in the online versions of the Digests, List
Browse, and on the Forum site.)
For those submitting their Contribution by personal Check, please be sure to include
your email address along with your Check as this is what is used to determine
eligibility.
So, in a nutshell, here's how it works:
Make a Contribution = No more "Please Make a Contribution" messages!
How sweet is that? If that's not a great reason to jump on the Matronics Email
List Contribution site and make your donation today, I don't know what is!
Don't forget that there are some totally awesome free gifts to be had along with
your List Contribution this year!! Don't wait a minute longer to support your
Lists!
Thank you for your Support!!
Subject: | If You Got This Email, You Haven't Made A Contribution |
Yet! :-)
If you received this particular Matronics List Email message, its because you haven't
yet made a Contribution to support your Lists! This is the first PBS-like
funds drive message under the new distribution system. The new system selectively
sends out the Contribution messages ONLY to those that forgot to whip
out the 'ol credit card this year to support the continued operation and upgrade
of the Matronics Email Lists! Don't you wish PBS worked that way? :-)
You heard that right. Once you make your Contribution, these support requests
messages during November will suddenly stop coming to your personal email inbox!
Pardon me if I seem kind of excited about the new feature. I've wanted to
implement something like this for a number of years now, but it was always such
a daunting task to modify the back-end List processing code, that I just kept
putting it off. Finally this year, I just decided to bite the bullet and put
the code-pounding time it to make it work. A few days later, bam! A working
system!
Anyway, I'll stop gushing now. I really do appreciate each and every one of your
individual Contributions to support the Lists. It is your support that enables
me to upgrade the hardware and software that are required to run a List Site
like this. It also goes to pay for the Commercial-Grade Internet connection
and to pay the rather huge electric bill to keep the computer gear running
and the air conditioner powered up.
Your personal Contribution matters because when combined with other Listers such
as yourself, it pays the bills to keep this site up and running. I accept exactly
ZERO advertising dollars for the Matronics Lists sites. I can't stand
the pop-up ads and all other commercialism that is so prevalent on the Internet
these days and I particularly don't want to have it on my Email List site.
I'm pretty sure you don't either.
If you appreciate the ad-free, grass-roots, down-home feel of the Matronics Email
Lists, please make a Contribution today to keep it that way!!
Thank you!
Subject: | Clarification On New Contribution Module Operation... |
Dear Listers,
A number of Listers emailed and indicated that, even though they had made a Contribution
this year, they still received the Contribution message yesterday.
I looked into it and I found a slight anomaly (ok, bug) in the new code specifically
as it related to Listers that had made their Contribution through PayPal
AND have a DIFFERENT email address for their PayPal account and for their Matronics
List subscription.
If your PayPal account email address is DIFFERENT than the email address you are
subscribed to the Matronics List(s) as, then my new code module couldn't tell
that you had made a Contribution, since it was using the PayPal email address
instead of the List email.
I've fixed this issue for any new PayPal Contributions, but I don't have any easy
way of resolving this for any of the previous Contribtuions. Again, this is
ONLY an issue if your PayPal and Matronics List email addresses ARE NOT the
same. Otherwise, everything works great.
If you made a PayPal Contribution before 11/09/06 AND your email addresses don't
match, please drop me an email at " info(at)matronics.com " (do not reply to this
message!) and give me your Name, and both Email Addresses and I will manually
update the records so that things will work as advertised.
Sorry for the hassle! New code; new bugs... :-)
To make a Contribution, please see: http://www.matronics.com/contribution
Thank you!
Matronics Email List Administration
Dear Listers,
I added a new Wiki web site to the Matronics Email List features earlier this year. What's a Wiki, you ask? Well, here's the Wikipedia (http://en.wikipedia.org/wiki/Wiki) definition:
A wiki (IPA: [ w .ki ] or [ wi .ki ] ) is a type of Web site
that allows the visitors themselves to easily add, remove, and otherwise edit
and change some available content, sometimes without the need for registration.
This ease of interaction and operation makes a wiki an effective tool for
collaborative authoring. The term wiki also can refer to the collaborative software
itself (wiki engine) that facilitates the operation of such a Web site,
or to certain specific wiki sites, including the computer science site (an original
wiki), WikiWikiWeb, and on-line encyclopedias such as Wikipedia.
Under the Matronics Email List Moniker, there is now a very nice List-specific
Wiki available! It a place for Listers to put articles about any aviation topic
that suits them. The purpose is to provide what the mailing lists do not:
structure and persistence. The mailing lists are a fantastic resource to ask
a question and get good (and bad and funny and annoying) answers. But once the
question is asked and answered it is not in front of the List anymore. If a
new person subscribes the next day, he/she does not see that information unless
he/she goes to the trouble to search the archives, a hit or miss proposition.
The result is that the same thread of conversation gets created and/or revisited.
There are several things that happen as a result:
1. The person gets his or her question answered;
2. The information gets better as more people think about and answer the question;
3. The people who have seen the same question asked and answered get annoyed
at seeing the same things over and over and over and ...
So this is where the Wiki comes in. You know what questions you wanted answered.
You may have asked or answered the question. You know the information is useful.
So you put the information here, in the Matronics Email List Wiki!
It doesn't matter that this information is 100% complete or correct. Just writing
something creates a placeholder and makes useful information available immediately.
It has the same immediacy as the mailing list but it has persistence
and structure.
But what if the information is incomplete or incorrect? No problem! Anyone else
coming along can edit the article! If I write something and you discover something
I have left out or stated incorrectly, you can fix it right then!
So let's begin and make this the place for information about building, flying,
maintaining, and understanding our airplanes.
But what about whether something is "appropriate" or not? Don't worry. Write
it down. Let the reader determine whether or not it is appropriate. If it is,
he/she will read it. If it isn't, he/she won't. It's as simple as that.
And when you do write that article you won't have to worry about whether some editor
is going to decide whether or not to print it in a newsletter or whether
the webmaster will have time to put it up on the web page.
The last question I hear brewing out there is: if anyone can post anything, won't
this just become a mass of garbage? Surprisingly, the answer is a resounding
no. If you want proof, go visit the Wikipedia, a free-to-everyone encyclopedia
written by whoever wants to write articles. The articles there are as good
as anything I have read anywhere and anyone can add anything anytime they want
to.
So don't hesitate. Write it down. Put it here. It will never hurt anyone. The
more information we get here, the more useful it will become to other people
and the more information they will put here for YOU to use.
Here's the URL to start (there are lots more bured under this starting place):
http://www.matronics.com/wiki/index.php/Matronics:Community_Portal
But please don't forget that this Wiki and all of the other Matronics Email List
features are supported solely by YOUR Contributions!! November is List Fund
Raiser month and there are lots of Free Gifts to be had with your qualifying
Contribution. Please make a Contribution to support the continued operation and
upgrade of these great services!!! Thank you!
Subject: | WLAS [Please Read] |
Dear Listers,
I sat down at the 'ol computer tonight to have a look at a few of the nice comments
List Members have been including along with their Contributions this year.
I was amazed at how many I found and even more amazed at some of the very nice
things Listers have been saying about the Lists and how valuable the they
are to them.
I've included quite a few of these nice comments below. Please read over some
of this great Lister feedback. No doubt you will find that you agree with at
least one or two of those comments - maybe all of them! If you find that do,
won't you please make a Contribution to support these Lists today!! Its fast
and easy with the Matronics List Contribution Web Site:
Don't forget that I've now fully implemented the new *List Fund Raiser Squelch*
feature that will automatically intercept any future iterations of my "Please
Contribute" messages -- that is, *once you've made YOUR Contribution*! How cool
is that? (Make sure the email address you enter along with your Contribution
matches exactly your subscribed List email address. An exact match is how
it works.)
Thank you for your generous Contributions this year and for all the wonderful comments!!
================= What Listers Are Saying (WLAS) ================
Absolutely the best deal on the Internet!!
-Owen B
I love The Matronics...
-Robeto B
My wife has her soaps & I've got my lists!
-Hal B
These lists are, indeed, the lifeline of our hobby.
-Bob R
The best source of information for my a/c.
-Tony C
The Zenith list is the first thing I read in the morning.
-Herbert H
You do more good than you can imagine. I wish I'd known
about you while I was building my Kitfox, but you are
still an after-the-fact resource.
-Ben B
..an excellent site.
-Ashley M
The "List" has been the ultimate help for my Zenith
CH 701 project!!
-Brian U
I appreciate the list being here for me.
-Geoff H
..a great service.
-William C
The List continues to be an interesting and useful facility.
-David M
Your list is a constant goad to keep me working on my project.
-Thomas S
..a great service.
-Robert W
The Pietenpol list is a great resource.
-Benjamin W
The Yak-list is Awesome!
-James S
..great service.
-Robert S
The features you have implemented recently have you poised
to knock out yahoo groups...
-Danny D
I like how your forum looks/works and the list service...
-Ken E
..great service.
-David P
Very useful web site.
-Wayne E
..a very valuable service.
-Chris D
Great sites...
-Randall R
I used to look at [that other] site also but it's gotten so
cluttered with advertising that I've stopped looking at it.
-Wayne E
Without your services, the build would be a grope in the dark...
-Fergus K
The information and help I've received greatly outweighs the
donation...
-Lee P
..great service!
-Christopher D
I really don't think I could be building my plane without the
wisdom I find on this list.
-William G
It really makes building a pleasure.
-James P
..great service.
-Doug W
I'm getting near the end of my build (Europa tri XS) don't
think I could have done it with out the help of the forum.
-Stanislaus S
Marvelous service. Couldn't have done it without you.
-Jim G
Love the list, this is a wonderful way to help others...
-Michael S
..good service.
-Derek L
The list is responsible for helping me complete this project
and educating me in the process.
-Jeff D
Definitely worth the donation.
-Ron L
..great service to the aviation community.
-Tony P
I have been flying my plane for 5 years (RV-6) but I still
get valuable information from this service.
-Don N
A very helpful site.
-Roland S
It's a great community to be part of.
-David L
Great sites.
-John C
A great place to find and share not only information but to
meet people across the country and make lasting relationships.
-Uncle Craig
Great facility.
-Peter H
Its a great source of information!
-Michael W
Great improvements to the List...
-Edward A
Great service!!!
-Rich D
..great resource!
-William C
..excellent lists!
-Michael S
Couldn't have built my RV4 without the list.
-Warren M
..a great service...
-James N
I would not have missed [the list] for anything during the
building of my Europa.
-Svein J
..another great year.
-Robert D
..this [is an] essential builder's resource.
-David A
..excellent service.
-Gregory B
I've learned a huge amount of "stuff" over the past year
and look forward to it every day!
-Smith M
..a great communication tool...
-Jon M
Finished building 5 years ago, but still are lurking on
your great list!
-Lothar K
..a valuable service. At 11:00 pm Matronics is the goto
place for my RV questions.
-Mike D
Each year at the end of the List Fund Raiser, I post a message acknowledging everyone
that so generously made a Contribution to support the Lists. Its sort
of my way of publicly thanking everyone that took a minute to show their
appreciation for the Lists.
Won't you take a moment and assure that your name is on that List of Contributors
(LOC)? As a number of members have pointed out over the years, the List seems
at least - if not a whole lot more - valuable as a
building/flying/recreating/entertainment tool as your typical magazine subscription!
Please take minute and assure that your name is on this year's LOC! Show others
that you appreciate the Lists. Making a Contribution to support the Lists is
fast and easy using your Credit card or Paypal on the Secure Web Site:
or by popping a personal check in the mail to:
Matt Dralle / Matronics
PO Box 347
Livermore CA 94551-0347
I would like to thank everyone that has so generously made a Contribution thus
far in this year's List Fund Raiser! Remember that its YOUR support that keeps
these Lists going and improving! Don't forget to include a little comment
about how the Lists have helped you!
Best regards,
If you look forward to checking your List email everyday (and a lot of you have
written to say that you do!), then you're probably getting at least 0 or 0 worth
of Entertainment from the Lists each year. You'd pay twice that for a subscription
to some lame magazine or even a dinner out. Isn't the List worth at
least that much to you? Wouldn't it be great if you could pay that same amount
and get a well-managed media source free of advertising, SPAM, and viruses?
Come to think of it, you do...
Won't you please take a minute to make your Contribution today and support YOUR
Lists?
Contribution Page:
Again, I want to say THANK YOU to everyone that has made a Contribution thus far
during this year's List Fund Raiser!! These Lists are made possible exclusively
through YOUR generosity!!
Email List Admin.
Subject: | Why? [Please Read] |
Dear Listers,
Each year I like to explain why I have a Fund Raiser and also take the opportunity
to express why I think the List Services here provide a superior experience
over the commercial equivalents.
I use the List Fund Raiser each year to offset the costs involved with running
a high performance email list site such as this one. With the annual support
from the List members through the PBS-like Fund Raiser, I have found I can run
the entire site without having to inflect any of the members with those annoying
banner ads flashing up all the time trying to sell little-blue-pills or other
garbage nobody wants or needs. From the comments I've received over the years
regarding the Lists, the great majority of the members really appreciate
the non-commercialism of my List systems and don't mind my 'go-team-go' banter
once a year during November to encourage members to support the Lists.
I believe that the Lists services that I provide here offer many benefits over
the commercial equivalents in a number of ways. The first feature I believe to
be significant is that you cannot receive a computer v*rus from any of these
Lists directly. Each incoming message is filtered and dangerous attachments
stripped off prior to posting. I also provide a Photo and File Share feature
that allows members to share files and bitmaps with other members and everyone
can be assured that these files will be prescanned for any sort of v*rus before
they are posted. Safe and simple.
Another very important feature of this system in my opinion is the extensive List
Archives that are available for download, browsing, and searching. The Archives
go all the way back to the very beginning of each List and with the very
fast Search Engine, the huge size of some of the Archives is a non-issue in quickly
finding the data you're looking for.
And added just this year is the new Email List Forum that allows members who prefer
the Web BBS-style of List interaction. The beauty of the new List Forums
is that they contain the exact same content that is distributed via email. Messages
posted via email are cross-posted to the respective Forum and vice versa.
The Forums also allow for another convenient method of sharing pictures and
other files. Additionally added this year is the new List Wiki that allows
members to build their own "Online List Encyclopedia" of sorts, documenting various
aspects of their project for all to share.
I've been running email Lists and services under the matronics.com domain since
about 1989 starting with RV-List and 30 guys I knew and who where also building
RVs. It has grown into nearly 70 different aviation-related Email Lists and
an associated web site that receives over 23,000,000 hits each year!! Additionally,
the List Email system forwarded well over 87,000 postings last year,
accounting for an unbelievable 39,000,000 (yes, that's 39 MILLION) email messages
delivered to Matronics List subscribers! I think there's a lot of value in
supporting a service that has gone the long haul and is still providing and
improving a high quality service all _without any advertising budget_!
I have to admit running these Lists is a labor of love and I hope it shows in the
quality of the experience that you receive when you get a List Email Message,
Search the Archives, use the List Browser, or surf the Forums and Wiki sites.
The Lists will be here for a long time to come. If you just want to lurk
a while for free, that's great and I encourage you to do so. If you use, appreciate,
and receive value from these Lists, then please support them during the
Annual List Fund Raiser!
Thank you,
Subject: | Please Make a Contribution to Support Your Lists... |
Dear Listers,
Just a reminder that November is the Annual List Fund Raiser. Please make a Contribution
today to support the continued operation and upgrade of these great
List services!! Pick up a really nice free gift with your qualifying Contribution
too!
The Contribution Site is fast and easy:
Thank you!
Subject: | More Great List Comments - Please Make A Contribution! |
Dear Listers,
There's a little less than one week left for this year's List Fund Raiser. I thought
it would a great time to share a few more of the great comments I've been
receiving from Contributors regarding what the Lists mean to them. There are
some particularly poignant ones in this batch and I encourage you to have a
look at some of them.
Don't forget that once you make your Contribution, the Contribution Squelch kicks
in and you won't receive any future messages from me regarding the Fund Raiser
this year! This holds true for the Realtime and Digest distributions and
now also the HTML and TXT links included with the Digest! (Note that for technical
reasons, if someone replies to one of my contribution messages, the Squelch
will _not_ be activated, and you will still receive it. Contribution messages
will also still be found on the Forums site and the List Browse).
Please make your Contribution today to support these List services! Pick up a
great Gift too!
Thank you!
============================= WLAS #2 ============================
Tackling my project without the List would be like
building on a deserted island. The List has made me
part of a learning (and laughing) community. -Larry W
Thank you for providing such a fantastic resource for us
Kolbers. I'm very happy to contribute towards keeping such a
wonderful resource available. -Geoff T
..you do a great service for the flying community by
providing this service. -John L
..solidly administered. -James C
A great source of information. -Ralph S
The Lists have likely saved a numbers of lives... -James F
..exceptional user service. -Larry W
Better than a magazine! -Aaron G
Thanks to your List I will be able to finish and fly
my project. Without the help of the great people on
your List I doubt it would have happened. -Ed G
I learn something on a too regular basis thanks to
these lists! -Ralph C
..valuable service. -John F
..a well administered service. -Stewart C
Great forum! -Ronald C
A great service! -Andy H
Been reading the lists since my first RV in 1999. Good
work and as necessary to me as a rivet. -Albert G
The lists are a great help. -Gary S
This resource has been critical to my building success
so far. -Timothy F
Great system and support! -Richard P
Very helpful in the building my CH 701. -Ralph S
Another year of entertainment and pleasure! -Larry B
A great resource for all of us. -Larry W
Another year of great service! Once again, the
information is worth more than I can ever contribute.
Thank you also for the "community" that the List fosters.
I cannot tell you the number of times that seeing an
friend's name come up has caused so many awesome memories
to come flooding back - along with the eager desire to
gather with these great guys again. I love hearing the
beginner's enthusiasm, the builder's progress, and the
flyer's success... -Robert B
Our list has great info and I love reading the
"Flame Posts! " -Stephen M
Great service! -James B
Excellent source of information. -David P
You provide a very valuable service to the aviation
community. -David H
The RV related lists have been a tremendous help in the
construction of my RV-7... -Norman R
Awesome list!! -John E
Great bunch of guys and very knowledgeable! -Herbert G
Thank you for making it so easy to stay in touch
with my fellow RV-10 builders. -David J
I love the list and have been a reader for a long
time. -James V
Continues to be a great service! -George A
Awesome List server. -Deke M
Many of us would never finish our airplanes without
[the List]. With it, I'm getting close! -Ronald C
An excellent source of both information and
inspiration! -William R
Forums and format are easy to use. -Jack B
Great help with my kit building. -Ralph H
Super service. -Richard N
Still loving it. -Jared S
You have a fantastic web! -Harvey R
..a great service. -James M
Glad you are there... -David A
I get some great information on your list. -John P
Fantastic service. Couldn't have made it as far
as I have without it. -Stephen T
A great learning experience with my RV-6A. -Ron B
Great resources! -Jason H
Well done. Very valuable. -Jeffrey D
Great resource for the experimental aircraft
community. -Chris H
This List has been one of the most helpful tools in
building my RV-10, since I build alone, and do not
have any help readily available. Without the List,
I could not have embarked on building my RV-10. -Jim H
You run a great list there. -James H
Really like the Kolb List. -Don W
Subject: | List of Contributors Coming Soon - Make Sure You're Listed! |
Dear Listers,
The List of Contributors (LOC) is just around the corner! On December 1st I post
a list of everyone that so generously made a Contribution to support the Lists.
Its my way of publicly thanking everyone that took a minute to show their
As a number of people have pointed out in their Contribution comments, the List
seems at least as valuable of a building/flying/recreating tool as a typical
your magazine subscription! And how interactive is a magazine, after all? :-)
Won't you take minute and assure that your name is on the upcoming LOC? Tell others
is fast and easy using your Visa, MasterCard, or Paypal account:
Or, by droping a personal check in the mail to:
Matronics / Matt Dralle
PO Box 347
USA
(Please include your email address on the check!)
far during this year's List Fund Raiser! Remember that its YOUR support that
keeps these Lists running and improving! Don't forget to include a little comment
Thank you!
Subject: | Who is "Matt Dralle" & What Are "The Lists"? [Please Read] |
Dear Listers,
Who is Matt Dralle and what exactly are these Lists? Well, I've been working in
the information technology industry for over 20 years primarily in computer
networking design and implementation. I have also done extensive work in web
development and CGI design during this period.
I started the Matronics Email Lists back in 1990 with about 30 fellow RV builders
from around the world. Since that time, I have added 63 other kinds of aircraft
related Lists to the line up and numerous other List related services such
as the Forums, Wiki, Archives and Search Engine just to name a few.
For flexibility and reliability, I have chosen to run all of my own servers here
locally. Other List-related systems include a 1 Gigabit, fully switched network
infrastructure, a commercial-grade Netscreen firewall, a Barracuda spam filter,
a local T1 Internet router, and a commercial-grade business T1 Internet
connection with full static addressing.
The computer servers found here include a brand new, quad-processor Xeon Linux
server for List web services, a dual-processor Xeon Linux system dedicated to
the email processing List functions, and another P4 Linux system serving as a
remote storage disk farm for the archives, databases, and for an on-line hard
drive-based backup system with 3.2 Terra Bytes of storage, soon to be upgraded
to over 6 Terra Bytes! This entire system is protected by three large, commercial-grade
uninterrupted power supply (UPS) systems that assure the Lists are
available even during a local power outage! Speaking of power, imagine how much
electricity it takes to run all of these systems. One month this Summer,
I had a staggering $1368 bill for electricity alone!
I recently upgraded all of the computer racking infrastructure including new power
feeds and dedicated air conditioning for the room that serves as the Computer
Center for the Matronics Email Lists. This year I added another rack to house
the new MONSTER quad-processor web system that didn't quite fit into the
first rack! Here's a composite photo of the List Computer Center before the addition
of the second rack:
http://www.matronics.com/MattDralle-ListComputerCenter.jpg
As you can see, I take running these Lists very seriously and I am dedicated to
providing an always-on, 24x7x365 experience for each and every Lister.
But building and running this system isn't cheap. As I've stated before, I don't
support any of these systems with commercial advertising on the Lists. It
is supported 100% through List member Contributions! That means you... and you...
and YOU!
To that end, I hold a List Fund Raiser each November and ask that members make
a small Contribution to support the continued operation and upgrade of this ever-expanding
system. Its solely YOUR Contributions that keeps it running!
Please make a Contribution today to support these Lists!
Or, by dropping a personal check in the mail to:
PO Box 347
USA
Thank you!
Subject: | Last "Official" Day Of The List Fund Raiser! |
Dear Listers,
Well, its November 30th and that means three things...
1) Today I am now officially 43 years old... (arg...)
2) It marks that last "official" day of the List Fund Raiser!
3) Its the last day I will be bugging everyone for a whole year! :-)
If you use the Lists and enjoy the content and the no-advertising, no-spam, and
no-censorship way in which they're run, please make a Contribution today to support
their continued operation and upkeep. Your $20 or $30 goes a long way
to further the List operation and keep the bills paid.
I will be posting the List of Contributors next week, so make sure your name is
on it! :-)
Thank you to everyone that has made a Contribution so far this year! It is greatly
appreciated.
List Contributions: http://www.matronics.com/contribution
Best regards,
Subject: | Matronics Fund Raiser - 2006 List of Contributors |
Dear Listers,
I would like to thank everyone that made a Contribution in support of the Lists
this year! It was really nice to hear all great comments people had regarding
the Lists! As I have said many times before, running these Lists is a labor
of love. Your generosity during the List Fund Raiser only underscores the great
sentiments people have made regarding the Lists.
If you haven't yet made a Contribution in support of this year's Fund Raiser please
feel free to do so. The nice List gifts will be available on the site for
just a little while longer, so hurry and make your Contribution and get your
great gift. Once again, the URL for the Contribution web site is:
I would like to thank Andy Gold of the Builder's Bookstore ( http://www.buildersbooks.com ), Paul Besing of Aeroware Enterprises ( http://www.kitlog.com ), Jon Croke of Homebuilt HELP ( http://www.homebuilthelp.com ) and Bob Nuckolls of AeroElectric ( http://www.aeroelectric.com ) for their extremely generous support during this year's Fund Raiser through the contribution of merchandise. These are great guys that support the aviation industry and I encourage each and every Lister to have a look at their products. Thank you Andy, Paul, Jon and Bob!! Your support is very much appreciated!
And finally, below you will find a web link to the 2006 List of Contributors current
as of 12/7/06! Have a look at this list of names as these are the people
that make all of these List services possible! I can't thank each of you enough
for your support and great feedback during this year's Fund Raiser!
THANK YOU!
http://www.matronics.com/loc/2006.html
I will be shipping out all of the gifts in the next few weeks and hope to have
everything out by the end of the month. In most cases, gifts will be shipped
via US Postal Service. Kitlog Pro serial numbers should go out via email this
weekend.
Once again, thank you for making this year's List Fund Raiser successful!
Best regards,
Subject: | ANYBODY DOING IT? |
I see NO activity on this site...considering an RV, and would like to see
some info on current activity....Chute info, maneuver criteria, ....I would hope
to engage in basic aerobatics if I buy such an A/C...what's going on in
2007???? JOHN SHERM, Wilmington, NC
From: | "Grant Piper" <grant.piper(at)bigpond.com> |
Subject: | Re: ANYBODY DOING IT? |
Yes John, it is very quiet, and has been that way for some time. No
one 'chats' about acro, all the secrets are very secret.....
I fly comp aero's in my RV-4 at Sportsman level, but have done one comp
at Intermediate. I believe there is a guy in the US that flies
Intermediate in an RV-8 (I'm in Australia). Most RVs (not a -9) will
walk through Sportsman if flown right. The low drag and relatively
slow roll rate can be a problem though. Be very aware of speed build
up when nose low, and 45=B0 down lines are steep! I try and keep the
speed back below 140KIAS, as above that the roll rate seems to decrease
and the forces go up. I use mid power, about 20"MAP for most normal
acro, only using full power when going vertical, but also go back to
idle when going down hill. This is very different than flying a Pitts,
so beware 'good' advice from traditional acro aircraft pilots. Try and
get some instruction from someone used to clean aircarft, say
ex-military jet trainer or similar.
The RV-4 and -6 feel very similar to me, the -7 I flew felt heavier in
the controls. I haven't flown an -8, but cannot see why it would not
be suitable either. I think it is more about getting good advice and
practice so you are very familiar with your aircraft. You can get
through Sportsman without inverted fuel and oil systems, but it means
you can't draw long inverted lines or do really s-l-o-w rolls.
I'm happy to talk more if you need to.
Grant Piper
RV-4 VH-PIO
2006 Australian Sportsman Champion
----- Original Message -----
To: aerobatic-list(at)matronics.com
Sent: Tuesday, February 13, 2007 3:16 PM
Subject: Aerobatic-List: ANYBODY DOING IT?
see some info on current activity....Chute info, maneuver criteria,
....I would hope to engage in basic aerobatics if I buy such an
A/C...what's going on in 2007???? JOHN SHERM, Wilmington, NC
20MP but what RPM(s) for entry into ? maneuvers?
Yes John, it is very quiet, and has been that way for some time. No one 'chats'
I fly comp aero's in my RV-4 at Sportsman level, but have done one comp at Intermediate.
I believe there is a guy in the US that flies Intermediate in an RV-8
(I'm in Australia). Most RVs (not a -9) will walk through Sportsman if flown
right. The low drag and relatively slow roll rate can be a problem though.
Be very aware of speed build up when nose low, and 45 down lines are steep!
I try and keep the speed back below 140KIAS, as above that the roll rate
seems to decrease and the forces go up. I use mid power, about 20"MAP for most
normal acro, only using full power when going vertical, but also go back to
idle when going down hill. This is very different than flying a Pitts, so
beware 'good' advice from traditional acro aircraft pilots. Try and get some
instruction from someone used to clean aircarft, say ex-military jet trainer
or similar.
The RV-4 and -6 feel very similar to me, the -7 I flew felt heavier in the controls.
I haven't flown an -8, but cannot see why it would not be suitable either.
I think it is more about getting good advice and practice so you are very
familiar with your aircraft. You can get through Sportsman without inverted
fuel and oil systems, but it means you can't draw long inverted lines or do
Grant Piper
RV-4 VH-PIO
I see NO activity on this site...considering an RV, and would like to see some
info on current activity....Chute info, maneuver criteria, ....I would hope to
engage in basic aerobatics if I buy such an A/C...what's going on in 2007????
href="http://www.matronics.com/Navigator?Aerobatic-List">http://www.matronics.com/Navigator?Aerobatic-List
No one 'chats' about acro, all the secrets are very secret.....
one comp at Intermediate. I believe there is a guy in the US that
flies Intermediate in an RV-8 (I'm in Australia). Most RVs (not
a -9) will walk through Sportsman if flown right. The low drag and
relatively slow roll rate can be a problem though. Be very aware
of speed build up when nose low, and 45 down lines are steep! I try
and keep the speed back below 140KIAS, as above that the roll rate seems to
Pitts, so beware 'good' advice from traditional acro aircraft pilots.
Try and get some instruction from someone used to clean aircarft, say ex-military
in the controls. I haven't flown an -8, but cannot see why
it would not be suitable either. I think it is more about getting
good advice and practice so you are very familiar with your aircraft.
You can get through Sportsman without inverted fuel and oil systems, but it
means you can't draw long inverted lines or do really s-l-o-w rolls.
Grant Piper
RV-4 VH-PIO
would like to see some info on current activity....Chute info, maneuver criteria,
....I would hope to engage in basic aerobatics if I buy such an A/C...what's
I have a FP wood prop, so its about 24-2500 for me. You can loop,
barrell roll, slow roll stall turn anywhere from 110-140KIAS. Roilling
manoeuvres above 140 get hard to do nicely due to high forces.
Grant
Sent: Tuesday, February 13, 2007 11:07 PM
Subject: Re: Aerobatic-List: ANYBODY DOING IT?
comp at Intermediate. I believe there is a guy in the US that flies
in the controls. I haven't flown an -8, but cannot see why it would
not be suitable either. I think it is more about getting good advice
and practice so you are very familiar with your aircraft. You can get
Grant Piper
RV-4 VH-PIO
Subject: | For Sale Brand New Unlocked Nokia N95 For Just $200USD |
From: | "stephen" <stephen_markeletro(at)mail2world.com> |
EVERGREEN ELETRONICS INTERNATIONAL LIMITED.
As the leading distributor to the TV, video, plasma tv cam
corder, mobile phones laptops and audio trade in Hong Kong,
we supply over 5000 shops and service departments with:02
Phones, Nokia Phones, Play station games,APPLE IPOD
VIDEO,Laptops,Digital Camcorders etc.
Email :stephen_markeletro@mail2world
N80.......$160USD
Nokia N93.......$160USD
Nokia N93i.......$200USD
Nokia N92.......$170USD
Nokia N95........$200USD
Nokia N91.......$150USD
Nokia N90.......$140USD
Nokia N70.......$130USD
Nokia N73.......$160USD
Nokia N76 ........$ 180USD
Nokia N71.......$130USD
Nokia 8800......$200USD
Nokia 7710.......$130USD
Nokia 7610.......$110usd
Nokia 9300......$120USD
Nokia 9500......$150USD
Juicy SIDEKICK I...........$80USD
SIDEKICK II..........$100
SIDEKICK II MISTER CARTOON...... $130
JUICY COUTURE SIDEKICK II .....$120
SIDEKICK 3..........$170
Motorola A1200............$120usd
Motorola razor v3.........$100usd
Motorola razor v3 pink edition....$120usd
Motorola v3X...................$140usd
Motorola V3i.............$100
Motorola V3c..........$110
Motorola MPX300.,...$120usd
Motorola U6........$120
Nextel i880.........$130usd
Nextel i930.........$130usd
Nextel i870.........$100usd
Nextel i860.........$80usd
Nextel i90c.........$75USD
Nextel i95cl........$90USD
02 Phones o2 xDA Exec ........ $200
02 XDA Atom ........ $160
02 XDA NEO ........ $180
02 XDA mini S ....... $200
02 XDA II mini ...... $150
02 XDA IIi ......... $130
02 XDA IIs ......... $140
O2 X2i ......... $100
02 X4 ......... $110
02 X3 ......... $105
02 x7 ......... $120
Sony Ericsson p990.....$150usd
Sony Ericsson p910i....$130usd
Sony Ericsson w900i....$130usd
Sony Ericsson K750i....$110usd
Sony Ericsson k800i....$120usd
Sony Ericsson k700i....$100usd
Sony Ericsson W800i....$120usd
Sony Ericsson W900 ....$160usd
sony Ericsson w600i....$110usd
Sony Ericsson d750i....$130usd
Sony Ericsson z1010....$150usd
I-MATE PHONES I-MATE Smartflip ....... $120
I-MATE JAMin ......... $200
I-MATE JASJAR ........ $220
I-MATE K-JAM ......... $160
I-MATE SP5 ......... $130
I-MATE SP5m ......... $140
I-MATE SP4m ......... $110
I-MATE JAM Black ........ $130
I-MATE JAM ......... $140
I-MATE PDA2 ......... $160
I-MATE PDA2k ......... $110
I-MATE SP3i ......... $110
I-MATE SP3 ......... $120
I-MATE Pocket PC ......... $120
I-MATE Smartphone2 ........ $100
I-MATE Smartphone ........ $110
Treo 700...............$200usd
Treo 600...............$150usd
Treo 650...............$160usd
PPC-7600.............. $200
Cingular 8125 ............ For $200
Play station games
PSP............................$100usd
GameBoy Advance................$80usd
Nintendo DS....................$50usd
Nintendo Wii...................$150usd
GameCube.......................$60usd
Xbox 360.......................$120usd
Xbox...........................$70usd
Playstation 3..................$200usd
Playstation 2..................$120usd
RIM Blackberry 8800.............................$150
Rim Blackberry 7230g...........................$135
BlackBerry 7290......................................$140
6710 Blackberry RIM.............................$110
Speck Blackberry 7100T.........................$120
Color 7520 RIM Blackberry....................$100
Apple iphones Apple iphone 8gb...........$230
Apple iphone 4gb...........$170
Apple iphone 2gb...........$130
Dopod 838 pro .............$200
APPLE IPOD VIDEO Apple 30 GB iPod Photo
M9829LL/A.......$60USD
Apple 512 MB iPod Shuffle MP3 Player...$40USD
Apple 4 GB iPod Mini Blue M9436LL/A....$50USD
Apple 2 GB iPod Nano..................$60USD
Apple 4 GB iPod Nano...................$70USD
Apple 30 GB iPod Vidoe................$100USD
Apple 60 GB iPod Vidoe................$140USD
Apple 20GB iPod 20GB iPod .............$50USD
Apple 4 GB iPod Mini Pink M9435LL/A ..$50USD
Apple 40 GB iPod photo.................$50USD
Apple 4 GB iPod Mini Silver M9160LL/A .$50USD
Apple 60 GB iPod Photo M9830LL/A.......$70USD
Apple 60 GB iPod photo ...............$50USD
Digital Cameras :
Sony Cybershot DSC-W7 7.2 Megapixel .... $100
Sony Cybershot (DSC-T1) 5.1MP .... $120
Sony DSCT33 Cyber-Shot - 5.1 MegaPixels .... $150
SONY CyberShot 8.1 Megapixel .... $220
ony Cybershot Digital Camera, 8.0 Megapixel .... $130
SONY Cybershot 5.24 MP 2560x1920 5x Opt .... $150
Sony Cybershot Digital Camera 5 Megapixel .... $160
Sony Cybershot Digital Camera + 1GB Kit .... $250
Sony Cybershot Digital Camera 512M Pro Duo .... $200
Sharp 50cmV LCD-4:3 Format-NICAM Stereo:.$290
Sharp XVZ200:............................$190
Sharp LCD TV:............................$200
Sharp Aquos LC32G1DE32?Widescreen LCD TV with Freeview:$305
Digital Camcorders :
DVD Handycam Camcorder,DCR-DVD203 .... $250
DVD Handycam Camcorder,DCR-DVD7E .... $160
MicroMV Digital Camcorder,DCRIP1 .... $280
DCR-DVD7 DVD Camcorder .... $170
CR-DVD602E PAL DVD Camcorder .... $200
Dcr Dvd201e Sony Dvd Camcorder .... $320
Sony DVD HandyCam Camcorder .... $500
Sony DCR-DVD201 DVD Digital Camcorder ....$210
Sony DCRHC42 DVD Handycam Camcorder .... $170
Sony DCR-DVD103DVD Camcorder .... $240
Qtek Qtek 8500 ....... $130
Qtek S200 ....... $150
Qtek 9000 ....... $200
Qtek 8310 ....... $180
Qtek 8300 ....... $160
Qtek 9100 ....... $230
Qtek 8100 ....... $130
Qtek S110 ....... $150
Qtek S100 ....... $170
Qtek 9090 ....... $180
Qtek 8020 ....... $160
Qtek 8010 ....... $130
Qtek 2020i ...... $200
Qtek 2020 ....... $180
Qtek 1010 ....... $120
Laptops (TOSHIBA)
Toshiba Satellite A75-S229 Laptop Computer---$350
Toshiba Satellite M45-S311 LaptopComputer---$450
Toshiba Satellite R15-S822 Laptop Computer---$600
Toshiba Qosmio G15-AV501 Laptop Computer---$900
Toshiba Satellite A65-S126 Laptop Computer---$350
Toshiba Satellite P25-S526 Laptop Computer---$800
Toshiba Satellite A45-S120 Laptop Computer---$350
Toshiba Satellite M35X-S149 Laptop Computer---$400
Toshiba Qosmio E15-AV101 Laptop Computer---$950
Toshiba Satellite P35-S609 Laptop Computer---$850
Toshiba Qosmio F15-AV201 Laptop Computer----$700
Toshiba Portege M200 Laptop Computer------$500
(Sony VAIO)
Sony VAIO A170 Laptop Computer-----$1000
Sony VAIO GRT250 Laptop Computer----$800
Sony VAIO V505DC1 Laptop Computer----$850
Sony VAIO GRT270 Laptop Computer------$1000
Sony VAIO GRT100 Laptop Computer------$1100
Sony VAIO PCG-GRX7001 Laptop Computer---$900
Sony VAIO PCG-R505ESK SuperSlim Pro Notebook---$950
Sony VAIO A130P LaptopComputer -------$900
Sony VAIO VGN-B100B08 Laptop Computer Notebook---$900
Sony PCG-K33 VAIO K33 - Mobile Pentium 4----$600
If you wish for any product not listed here please email me
the product Brand Name and Model and i will source it from
our warehouse Our product are brand new, you can book your
order at
http://forums.matronics.com/viewtopic.php?p=127779#127779
Subject: | New Realtime Spell Checker Added To Matronics Forums! |
Dear Listers,
Today 9/8/2007 I have added a new real-time spell checker function to all of the
BBS Forums at Matronics. When you reply or create a new message on the Forums,
you will notice that misspelled words will be high-lighted in yellow. If
you left-click on the word, you will be prompted with a drop-down list of suggested
spellings.
Enjoy!
Matornics Email List and Forum Administrator
From: | "Brian Fowler" <brianf(at)fowlerssheetmetal.com> |
Subject: | RE: Aerobatic-List Digest: 0 Msgs - 10/03/07 |
Please unsubscribe me from this mailing list
Brian
-----Original Message-----
[mailto:owner-aerobatic-list-server(at)matronics.com] On Behalf Of
Aerobatic-List Digest Server
Sent: Thursday, October 04, 2007 2:56 AM
Subject: Aerobatic-List Digest: 0 Msgs - 10/03/07
Today's complete Aerobatic-List Digest can also be found in either of the
of the Aerobatic-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter
07-10-03&Archive=Aerobatic
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter
2007-10-03&Archive=Aerobatic
Aerobatic-List Digest Archive
Total Messages Posted Wed 10/03/07: 0
Today's Message Index:
8:59 AM
8:59 AM
Subject: | Re: Aerobatic-List Digest: 0 Msgs - 10/23/07 |
In a message dated 10/24/2007 12:56:32 A.M. Mountain Daylight Time,
aerobatic-list(at)matronics.com writes:
please remove me from the list
Subject: | November is Matronics Email List Fund Raiser Month! |
Dear Listers,
You've probably noticed that there are no banner ads or pop-up windows or spam
from any of the List and Forum services at Matronics. These include, for example:
The Email List Postings - http://www.matronics.com/listbrowse
The Email List Forum Site - http://forums.matronics.com
The List Wiki - http://wiki.matronics.com
The List Search Engine - http://www.matronics.com/search
This is because I have always enjoyed a List experience that was completely about
the sport we enjoy - airplanes - and not about advertising!
But running a high performance, highly available service like this isn't free and
a fair amount of money in terms of computer upgrades, business-class Internet
connectivity, and electricity. Consequently, many similar sites turn to advertising
to support these costs. Advertising that you have to look at each and
every time you read an email message or browse the their web site.
Rather than subject my List community to another constant commercial bombardment,
I have chosen to hold a PBS-like fund raiser each year in November to support
the continued operation and upgrade of the List services. It's solely through
the Contributions of List members that the Lists and Forums continue to be
possible!
During the month, I will be sending out a Fund Raiser reminder message every few
days and I ask for your patience and understanding during the month throughout
these regular messages. Think of them as PBS' Pledge Breaks... :-)
To minimize the impact of the Fund Raiser on the List community, I implemented
a new feature late last year specifically related to making Contributions. If
you are an Email List subscriber, once you make a Contribution using the online
web site, you will no longer receive the email from me regarding the Fund Raiser!
There are a couple of exceptions to this, however. If someone replies
to a Contribution message I've sent, you might receive that. Additionally, the
messages will always be posted to the Forums site. To a first order, however,
once you make a Contribution, you won't get my email messages about the Fund
Raiser for the rest of the month. For Contributions by check, the squelch
will take effect once the check is received.
There is a whole new line up of really great Contribution gifts this year! When
you make a qualifying Contribution, you can select one of the many free gifts
that are available during the Fund Raiser. These gifts are provided through
the generous support of a number of our industry's leading supporters including:
Bob Nuckolls - AeroElectric - http://www.aeroelectric.com
Andy Gold - Builder's Bookstore - http://www.buildersbooks.com
Jon Croke - HomebuiltHELP - http://www.homebuilthelp.com
Please visit these guy's respective sites, as they have some great products to
offer and are generously supporting the Matronics List Fund Raiser.
year including using a credit card, PayPal, or by personal check. From the Contribution
site, you can select any one of this year's free gifts with a qualifying
Contribution amount. The Contribution page is pretty loooonnnnng this year
in order to list great selection of great gifts available so be sure to scroll
all the way to the bottom of the web page to see everything that's available!
Please make a List Support Contribution:
I would like to thank everyone in advance for their generous support! Your Contributions
truely keep this operation afloat!
Thank you,
Matronics Email List Forum Administrator
Subject: | List Fund Raiser |
Dear Listers,
Just a reminder that November is the Matronics Email List Fund Raiser month. I've
got a bunch of really nice incentive gifts this year. There's really something
for everyone!
Please make a Contribution today:
Thank you!
Subject: | What Listers Are Saying... |
November is Matronics List Fund Raiser month and a number people been sending some
really nice comments regarding the Lists. I thought I'd share a few below.
The Lists are completely supported by your Contributions. All of the bills for
new hardware, connectivity, and electricity are paid by the generous support
of the List members.
Please make your Contribution today to support the continued operation of the List
and Forums:
Thank you!
================= What Listers Are Saying ================
Flying and building is much safer with this List!!
Robert D.
Thanks for having and maintaining such a great resource to
all of us builders and flyers.
Wayne E.
Love the fact that you haven't caved to advertising!
Peter J.
..a great resource!!
Robert C.
Not building at the moment, but the Lists keeps me right
up to date with what's going on.
Chris D.
The web forum has been running great.
James O.
I enjoy this [List] site very much...
Paul C.
This is a great list!
Albert G.
..a valuable resource!
Roger C.
I am deployed to Pakistan right now, and being able
to go on-line and keep up with the aircraft discussions
helps keep the aircraft building dream alive in my mind!
Gregory C.
..fantastic service!
Roger M.
..clearly a work of passion!
Mike C.
It is a great service to us!
Kevin C.
The list is a wonderful resource...
Ralph O.
[The Lists] have been the single greatest resource in
building my RV-9A and now my RV-10.
Albert G.
..a valuable and always improving service.
Dick S.
STILL THE BEST BARGAIN AROUND!!
Owen B.
..such a valuable tool.
Jon M.
[The Lists] have been an invaluable resource for me
as a Zenith homebuilder.
David G.
The opportunity to meet (on line at least) many other
interesting builders and to make some new friends is
truly appreciated.
Albert G.
Yet! :-)
Dear Listers,
yet made a Contribution to support your Lists! Implemented for the first
time last year, the Matronics system selectively sends out the Contribution
messages to those that forgot to whip out the 'ol credit card this year to support
the continued operation and upgrade of the Matronics Email Lists! Don't
I wanted to implement something like this for a number of years, but it was
always such a daunting task to modify the back-end List processing code, that
I just kept putting it off. Finally last year, I just decided to bite the bullet
and put the code-pounding time it to make it work. A few days later, bam!
A working system!
I really do appreciate each and every one of your individual Contributions to support
the Lists. It is your support that enables me to upgrade the hardware
and software that are required to run a List Site like this. It also goes to
pay for the commercial-grade Internet connection and to pay the rather huge electric
bill to keep the computer gear running and the air conditioner powered
up. I run ALL of the Matronics Email List and Forums sites here locally which
allows me to control and monitor every aspect of the system for the utmost in
reliably and performance.
Lists, please make a Contribution to keep it that way!!
Thank you!
[Please note the following regarding the selective posting system. There are certain
circumstances where you might still see a Contribution related message.
These situations include if someone replies to one of the messages, or when
using the List Browse feature, or when accessing List message via the Forum.
Since most of these are anonymous public access methods, there is no simple way
to filter them.]
Subject: | Post Mortem - Matronics List Pummeled By Spam... |
Dear Listers,
Over a 3-day period, Thursday 11/8 though Saturday 11/10, the Matronics Lists were
pummeled with over 450,000 spam emails causing posting delays and a few duplicate
messages. Yeah, I really said nearly half a million spams! The good
news is that I don't believe a single one of them actually made it to the Lists
thanks to the aggressive List filtering code and the Barracuda spam filter.
The bad news was that it caused quite a back log of email messages starting Friday
and continuing until late Saturday when I noticed that delivery seemed a bit
sluggish. By about 11pm on Saturday night, I had managed to get the backlog
cleared out of the spam filter by temporarily adjusting some of the filtering.
A check of the queues this morning, and everything looks like its working great
and there are no incoming filtering delays and spam levels appear to be back
to "normal".
There were a number of people asking what was going on, so I thought that I'd send
out a follow up post mortem on the event...
November is the annual List Fund Raiser. Your contribution directly enables me
to buy systems like the Barracuda spam filter that keep the List free of that
garbage. Please make a contribution to support your Lists!
Thank you!
Subject: | List of Contributors |
that so generously made a Contribution to support the Lists. Its sort of
my way of publicly thanking everyone that took a minute to show their appreciation
for the Lists.
at least - if not a whole lot more - valuable as a building/flying/recreating/entertainment
PO Box 347
these Lists going and improving! Don't forget to include a little comment about
Best regards,
From: | "Russell Lassetter" <rblassett(at)alltel.net> |
Subject: | Construction/Restoration |
Hello all,
I would like to offer my aircraft construction/restoration services to the
group. I have a 40' X 60' hangar in NE Georgia and have a lifetime of
experience with various aircraft. I can construct large projects for $15.00
per hour with first-class workmanship. Please email me directly or give me
a call.
Russ Lassetter
202 Aviation Blvd.
Cleveland, GA 30528
706-348-7514
Subject: | Value of the List... |
to some lame magazine or even a dinner out. Isn't the List worth at least
that much to you? Wouldn't it be great if you could pay that amount and get
a well-managed media source free of advertising, SPAM, and viruses? Come to
think of it, you do... :-)
Won't you please take a minute to make your Contribution today and support the
Lists?
Contribution Page:
Email List Admin.
List services!! And pick up a really nice free gift with your qualifying Contribution
too!
Thank you!
Subject: | [Please Read] Why I Have A Fund Raiser... |
Dear Listers,
a high performance email list site such as this one. With the annual support from
regarding the Lists, the great majority of the members really appreciate the
non-commercialism of my List systems and don't mind my 'go-team-go' banter once
Lists directly. Each incoming message is filtered and dangerous attachments stripped
off prior to posting. I also provide a Photo and File Share feature that
allows members to share files and bitmaps with other members and everyone can
they are posted. More recently, I have enabled limited posting of a number of
file formats including pictures and PDFs.
And added just a couple of years ago is the new Email List Forum that allows members who prefer the Web BBS-style of List interaction. The beauty of the new List Forums is that they contain the exact same content that is distributed via email. Messages posted via email are cross-posted to the respective Forum and vice versa. The Forums also allow for another convenient method of sharing pictures and other files (http://forums.matronics.com ). Additionally, added recently is the List Wiki that allows members to build their own "Online List Encyclopedia" of sorts, documenting various aspects of their project for all to share ( http://wiki.matronics.com ).
an associated web site that receives over 34,000,000 hits each year!! Additionally,
the List Email system forwarded well over 77,000 postings last year, accounting
for an unbelievable 33,000,000 (yes, that's 33 MILLION) email messages
delivered to Matronics List subscribers! I think there's a lot of value in supporting
a service that has gone the long haul and is still providing and improving
The Lists will be here for a long time to come. If you just want to lurk a
and receive value from these Lists, then please support them during the Annual
List Fund Raiser!
Thank you,
Subject: | What Are You Thankful For...? |
Dear Listers,
Here in the United States, Thursday is our National day of Thanksgiving. Many
of us will be traveling to be with our families and friends to share in generous
feasts of plenty and giving thanks for many blessings that have been bestowed
upon us.
Many Listers have expressed over the last couple of weeks how thankful they are
for the Email Lists and Forums here on the Matronics servers and for all of the
assistance and comradery they have experienced being a part of the Lists.
One of my favorite kind of comments is when write to me and says something like,
"Its the first thing I do in the morning while I'm having my morning coffee!".
That's a wonderful tribute to the purpose and function of these Lists. Its
always great to hear I'm not the only one that jumps out of bed each morning
to check my List email!!
Won't you take a minute today and show your appreciation for these Lists and for
their continued operation and upgrade?
The List Contribution Site is:
Thank you in advance for your kind consideration,
Dear Listers,
Below are a few more of the nice comments Listers have been making along with their
Contributions in support of the Lists this year. Please make your Contribution
today to support the continued operation and upgrade of these services.
Remember, there is _no advertising budget_ to keep these Lists funded. It is
solely through your generosity that they continue.
Please make a Contribution:
Thank you!
Matronics Email List and Forum Administrator
------------------------------What Listers Are Saying------------------------------
The list has been invaluable in the building of my Zenith CH701.
George R
Thanks for keeping the lists a non-commercial venue for us
to gather and share knowledge.
Neal G
What a fantastic resource!
Ralph C
It's a pretty cheep troubleshooting tool with and unlimited
resource of personal knowledge.
Bruce G
A full house of Info & Ideas...
Ellery B
I really enjoy the Piet list.
Steven D
The Lists are an indispensable resource for those of us
building OBAM aircraft.
Bret S
..a great service.
Frank D
..all in all it is a great resource if you ask specific
questions.
Richard S
Your list has really helped me in my first build.
Michael W
Always a pleasure to support this great resource...
Richard W
I enjoy the lists very much, they are very beneficial.
Bob L
Great place to chat with other builders and Flyers.
Ellery B
Your lists are a great service to builders and owners!
Richard D
A real good place for someone that is starting to get
interested into flying without investing any money at
first.
Ellery B
The list has been an great help to my building process.
David B
I'm close to finishing my Zenith 601 thanks to you and
the Zenith List.
Jeff D
Subject: | Make Sure You're Listed! List of Contributors Published |
Dec 1!
Dear Listers,
As a number of people have pointed out in their Contribution comments, these Lists
PO Box 347
USA
far during this year's List Fund Raiser! Remember that its YOUR support that keeps
Thank you!
Subject: | [Please Read] What are "The Lists" and Who's This Matt |
Dralle?
Dear Listers,
the information technology industry for nearly 25 years primarily in computer
development and CGI design during that time, along with some embedded system
development as well.
The computer servers found here include a quad-processor Xeon Linux server for
List web services, a dual-processor Xeon Linux system dedicated to the email processing
List functions, and another P4 Linux system serving as a remote storage
disk farm for the archives, databases, and for an on-line hard drive-based
backup system with 3.2 Terra Bytes of storage! This entire system is protected
by three large, commercial-grade uninterrupted power supply (UPS) systems that
assure the Lists are available even during a local power outage! Speaking
of power, imagine how much electricity it takes to run all of these systems. One
month last Summer, I had a staggering $1368 bill for electricity alone!
Center for the Matronics Email Lists. Last year I added another rack to
house the MONSTER quad-processor web system that didn't quite fit into the first
of the second rack:
support any of these systems with commercial advertising on the Lists. It is
and YOU!
Won't you please take a moment to make a Contribution to support these Lists!
PO Box 347
USA
There are some great gifts available with qualifying Contribution levels too!
Thank you!
Subject: | Wow! A Ton of Comments! |
Dear Listers,
I've been getting a ton of great comments from Listers along with their List Support
Contributions lately! I've shared a bunch more below. Please read over
some of them and see what your fellow Listers think of the Lists and Forums.
There are just a couple more days left before the official end of this year's Fund
Raiser. Please make a Contribution today to support the continued upgrade
and operation of these services.
There are still lots of awesome gifts available, so browse the extensive selection
and pickup a nice item along with your qualifying Contribution.
Thank you in advance for your generous support! It is very much appreciated!
Best regards,
----------- What Listers Are Saying About The Lists -----------
In the big picture, you are most certainly saving lives.
The fact that you do it at a very good level of service,
quality, and simplicity is just icing on the cake. We
all owe you a debt of gratitude.
Bruce M
Can't go a single day without reading my lists. Even
when I am overseas.
Terry W
Best list ever. No comparison.
Johann J
I get the digest for the two lists I subscribe to each
morning -- they go great with my coffee! I can't tell
you how much I've learned from this great service...
Mark S
..great lists, best on the Net!
Robert S
It is very nice to enjoy a SPAM free list.
Ken L
You run a great list. Makes a builder feel like there's
lots of help out there for the asking, and it's
appreciated.
Steve T
The list is a very valuable resource.
Thomas S
You run a good list.
James G
Thanks for a great forum.
Jimmy Y
Thanks for a well-maintained list(s).
Michael M
Great job! Worth every penny!
Stephen T
Helps me learn and think about issues I didn't know I
didn't know.
Martin H
I find the list very useful...
Robert F
What you do provides me with daily contact with a passion
of my life, aviation.
Wendell M
..the list it is very valuable information.
Dwayne H
..a great service to homebuilders.
Andrew H
I have learned quite a lot from reading the Forums. I
have been reading at the forum pages and I like the way
it works.
Ron L
[The List] makes a builder feel like there's lots of
help out there for the asking, and it's appreciated.
Steve T
The list service many purposes, not the least of which is
motivation to join my fellow RVer in completing my project
and getting in the air.
John S
Thanks for running a great site. Its simplicity is its
greatness. Don't know how I would have been successful
without it.
Timothy F
..terrific service to experimental and general aviation.
James F
You have a well run operation. I am happy to support what
you do.
Mark S
A wonderful service to the GA community.
David M
Great list - let's keep it ad-free!
Ben C
They have been of great help, learning and friendship
for all the members Worldwide. Great job of yours, a
little idea that grew really big and wonderful.
Gary G
..a thoroughly enjoyable and informative List.
John W
A GREAT LEARNING TOOL!!
Dwayne Y
This is a very well-run list and it is a valuable resource
for the Pietenpol enthusiast.
Graham H
Thanks for running this great site - helps those of
us on the east of the pond keep in touch.
Malcolm H
Thanks for the major contribution to my continuing
education program.
Oldbob S
I'm just getting started in the building process & find
Matronics to be the most valuable site.
Scott D
Without the information and encouragement from the listers
my project would have been sitting in the corner of my shop
collecting dust long ago. Now it's almost ready for final
assemble and covering.
Edward G
Great List. No Ads, just RV-10 builders. Keep it
going.
Rick E
Wonderful source of info for building & flying...
Graham H
The Yak-list is a superb single source to get answers to
questions on the operation of these aircraft.
Craig W
This list is valuable to everyone and your hard work is
very much appreciated.
Jim S
Subject: | Just Two Days Left... |
Dear Listers,
There are just a couple days left for this year's List Fund Raiser. Over all,
participation has been good, but things have been pretty slow this week for some
reason. If you've been putting off making your Contribution until the last
minute, this is it! The last minute, that is... :-)
Please remember that there isn't any sort of commercial advertising on the Lists
and the *only* means of keeping these Lists running is through your Contributions
during this Fund Raiser.
Please make a Contribution today!
Thank you!
Subject: | Re: Aerobatic-List Digest: 0 Msgs - 11/28/07 |
I am new to this site. Can anyone tell me anything about a CAP10 B?
Aerobatic-List Digest Server wrote: *
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=37461&View=html&Chapter 07-11-28&Archive=Aerobatic
Text Version:
http://www.matronics.com/digest/digestview.php?Style=37461&View=txt&Chapter 07-11-28&Archive=Aerobatic
Total Messages Posted Wed 11/28/07: 0
Never miss a thing. Make Yahoo your homepage.
Subject: | [Please Read] - Last Official Day of List Fund Raiser! |
Dear Listers,
Its November 30th and that means a couple of things. Its my 44th birthday for
one, but I'm trying to forget about that... But, it also means that its that
last official day of the Matronics Email List Fund Raiser!
If you been drooling over one of the really sweet free gifts that are available
this year with a qualifying Contribution, then now is the time to jump on one!!
If you've been meaning to make a Contribution, but just keep putting it off, then
now is the time!
I will be posting the List of Contributors in a few days, so you'll probably want
to be known as a person that supported the Lists! Rather than the guy that,
er, ah, forgot (or whatever)... :-)
I want to thank everyone that has so generously made a Contribution so far this
year in support of our Lists. It is your generosity that keeps this operation
a float and I don't ever forget it. Hopefully everyone will feel the same.
The List Contribution page is fast and easy. Please support our habit by making
your Contribution right now:
Thank you all in advance!
Subject: | Matronics List Fund Raiser - 2007 List of Contributors |
Dear Listers,
of love. Your generosity during the List Fund Raiser underscores the great sentiments
feel free to do so. The great List Fund Raiser gifts will be available on
the Contribution site for just a little while longer, so hurry and make your
Contribution and get your great gift! Once again, the URL for the Contribution
web site is:
I would like to thank Andy Gold of the Builder's Bookstore ( http://www.buildersbooks.com ), Jon Croke of Homebuilt HELP ( http://www.homebuilthelp.com ) and Bob Nuckolls of AeroElectric ( http://www.aeroelectric.com ) for their extremely generous support during this year's Fund Raiser through the contribution of discounted merchandise. These are great guys that support the aviation industry and I encourage each and every Lister to have a look at their products. Thank you Andy, Jon and Bob!! Your support is very much appreciated!
And finally, below you will find a web link to the 2007 List of Contributors current
as of 12/6/07! Have a look at this list of names as these are the people
THANK YOU!
http://www.matronics.com/loc/2007.html
Best regards,
Subject: | Re: Aerobatic-List Digest: 0 Msgs - 12/12/07 |
does anyone use this forum?
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 07-12-12&Archive=Aerobatic
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 07-12-12&Archive=Aerobatic
Total Messages Posted Wed 12/12/07: 0
Looking for last minute shopping deals? Find them fast with Yahoo! Search.
hardly ever
Sent: Thursday, December 13, 2007 2:59 PM
Subject: Aerobatic-List: Re: Aerobatic-List Digest: 0 Msgs - 12/12/07
of the
formatted
Indexes
version
editor
HTML Version:
Text Find them fast with Yahoo! Search.
Is there an aeerobatic list people do use?
Sent: Thursday, December 13, 2007 5:39:08 AM
Subject: Re: Aerobatic-List: Re: Aerobatic-List Digest: 0 Msgs - 12/12/07
hardly ever
HTML Version:
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?Aerobatic-List">http://www.matronics.com/Navigator?Aerobatic-List
From: | "Wesley Warner" <warner.wesley(at)gmail.com> |
Acro mailing list
Acro(at)aerobaticsweb.org
http://aerobaticsweb.org/mailman/listinfo/acro
From: | "Konrad L. Werner" <klwerner(at)comcast.net> |
Not much!!! Very sporadic...
Sent: Thursday, December 13, 2007 5:59 AM
of the
formatted
Indexes
version
editor
HTML Version:
Subject: | Re: Aerobatic-List Digest: 5 Msgs - 12/13/07 |
I have been looking for 1 1/2 yr....pretty much unused! Was hoping to see dialogue...hope
to return to this dimension someday...even if relatively mild stuff.
John Sherm, wilmington, NC
From: Aerobatic-List Digest Server <aerobatic-list(at)matronics.com>
Sent: Fri, 18 Jan 2008 11:55 pm
Subject: Aerobatic-List Digest: 0 Msgs - 01/18/08
the
formatted
editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 08-01-18&Archive=Aerobatic
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 08-01-18&Archive=Aerobatic
Total Messages Posted Fri 01/18/08: 0
http://webmail.aol.com
Subject: | Re: Aerobatic-List Digest: 0 Msgs - 01/21/08 |
remove
Sent: Mon, 21 Jan 2008 11:55 pm
Subject: Aerobatic-List Digest: 0 Msgs - 01/21/08
the
formatted
editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 08-01-21&Archive=Aerobatic
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 08-01-21&Archive=Aerobatic
Total Messages Posted Mon 01/21/08: 0
Just bought an Extra, Most fun I ever had flying but it takes a little getting
use to the landings.
Steve Raddatz
http://forums.matronics.com/viewtopic.php?p=162994#162994
Steve,
Can you elaborate? What is it about the landings that takes getting used
to? What did you fly before? Just curious.
Sent: Friday, February 08, 2008 9:45 AM
Subject: Aerobatic-List: extra
> getting use to the landings.
> Steve Raddatz
I have got over 600 hours in RV's with 500 plus hours in taildraggers. My plane
is a Extra 260 with the mid wing design. so when I'm on final I lose site of
the runway at any speed under 80kts due to the angle of attack so what I have
learned is to slip my landing from downwind right to the numbers and that seems
to work well. But its still work in progress.
http://forums.matronics.com/viewtopic.php?p=163004#163004
Excellent! That's exactly the information I was looking for. Thank you!
Sent: Friday, February 08, 2008 10:49 AM
Subject: Aerobatic-List: Re: extra
> plane is a Extra 260 with the mid wing design. so when I'm on final I lose
> site of the runway at any speed under 80kts due to the angle of attack so
> what I have learned is to slip my landing from downwind right to the
> numbers and that seems to work well. But its still work in progress.
From: | "Peter Pengilly" <peter(at)sportingaero.com> |
Steve,
I had a mid wing 300 for a while. The best technique I found was to fly
a curving approach if at all possible, and convert that to a large slip
as I lined up on final, with plenty of power. I held the slip to the
absolute last minute (probably 20' or below), straightened up, cut the
power and landed. On take off I would leave the ground at 80kt in the 3
point attitude, so I approached at 80kt. Any more and I would float down
the runway completely blind. I want to know that the airplane would land
as soon as I shut the throttle. Kicking off the slip was enough to give
a little 'flare' to stop the rate of descent. Speed control +2kt -0 on
final was key to a good landing, at light weights I could get it down to
75kt without arriving too much tailwheel first. Using this technique I
did land on a 900ft runway one day with plenty to spare (but there was a
25kt wind blowing) - the alternative was 25kt across 1800' or land 25
miles away! Once on the ground I would pick the tail up so I could see
where I was going and could brake quite heavily controlling the attitude
with the elevator down to about 20 kt.
Hope this helps, Peter
[mailto:owner-aerobatic-list-server(at)matronics.com] On Behalf Of raddatz
Sent: 08 February 2008 15:49
My plane is a Extra 260 with the mid wing design. so when I'm on final I
lose site of the runway at any speed under 80kts due to the angle of
attack so what I have learned is to slip my landing from downwind right
to the numbers and that seems to work well. But its still work in
progress.
Peter that is beautiful, I also stand the tail during rollout. Thanks for the info
I'm also landing at my airpark which is narrow for a blind landing, but its
progressing nicely.
http://forums.matronics.com/viewtopic.php?p=163050#163050
From: | "Monty Barrett Sr" <MONTY(at)bpaengines.com> |
You guys all need some Cessna 195 time. Talk about BLIND--------
Monty Barrett
C-195
Pitts 12
Former Skybolt
[mailto:owner-aerobatic-list-server(at)matronics.com] On Behalf Of Peter
Pengilly
Sent: Friday, February 08, 2008 1:25 PM
Subject: RE: Aerobatic-List: Re: extra
Steve,
progress.
Dan Farmer a crit :
What do you want to know about the CAP 10 B ?
Nice airplane with beautifully harmonized controls.
Logged about 500-600 hrs in it, almost 98 % aerobatics.
Best regards,
Gilles
http://contrails.free.fr
Monty you could mount a video camera under the wing and a tv screen in the panel
and still not affect useful load.
Monty, I'm going to put a full Slick ignition system on my extra 260 which has
a 315hp IO-540 that you built, What model slick mag would you use because it has
23* degree bendix on it now and would you install duel impulse mags.
Steve Raddatz
http://forums.matronics.com/viewtopic.php?p=163076#163076
Subject: | Inflight camera's |
Hi,
Wondering if anyone has any experiance with in flight video camera's. Havin
g trouble finding reasonably high quality camera's as well as recorders tha
t can take mutliple camera's without the quality degrading.
Or do people just run individual video camera's for each remote head?
cheers
Chris
Overpaid or Underpaid? Check our comprehensive Salary Centre
2Eau%2Fsalary%2Dcentre%3Fs%5Fcid%3D595810&_t=766724125&_r=Hotmail_Email
_Tagline_MyCareer_Oct07&_m=EXT
From: | =?iso-8859-1?Q?H=E5vard_N=E6r=F8_Iversen?= <haavard-iversen(at)c2i.net> |
Hello!
You may check this out
http://www.sports-camera.com/?gclid=COL849SHuZECFQgsQwodoG7dDQ
Normally you use several cams with a selector. A TIP IS TO USE MEMORY
CAM.
That wont be disturbed by vibration.
_____
Fra: owner-aerobatic-list-server(at)matronics.com
[mailto:owner-aerobatic-list-server(at)matronics.com] P=E5 vegne av Chris
East
Sendt: Sunday, February 10, 2008 7:16 AM
Til: aerobatic-list(at)matronics.com
Emne: Aerobatic-List: Inflight camera's
Hi,
Having
that
cheers
Chris
_____
Check our comprehensive Salary Centre Overpaid or Underpaid?
om%2E
_Taglin
e_MyCareer_Oct07&_m=EXT>
Hello there fellow aviation enthusiasts!
Please allow me to introduce a new website geared towards bringing
pilots and non-pilots, hobbyists and professionals, together.
HTTP://AVIAPORTAL.NET
Our aim is to help aviators socialize, discuss and enjoy everything about wings
and the sky.
My friends and I developed this non-profit site with the goal to give back to and
support the aviation community. We thought this would be best accomplished
by providing a medium for members to share and discuss their passion through
various features. This website is user-friendly and absolutely free of charge.
Get the latest news and reports from the aviation world, as well as the following
features that the website offers.
Forums: these offer members the opportunity to post information, stories, tips
and tricks about numerous aviation topics. We also have a free classified section
to post items for sale or wanting to buy.
Chat: chatting is live one-on-one discussion with other members. The possibilities
here are endless, but lets keep it clean!
Blog: blogging gives members the opportunity to randomly post thoughts, ideas,
stories and commentaries without the structure of forums. Members are free to
post about anything, anytime.
Photo Album: members are allowed to post up to 50 MB of pictures. So lets see
your planes, your projects and whatever else you have captured with your camera.
Groups: this feature offers the option to create groups based on common interests.
The groups can be private or public, goal-oriented or just for fun. Just
a place to get together with aviator friends.
Virtual events: have an upcoming event? This feature allows members to advertise
for their future events, as well as report on past events. Posts can be accompanied
by pictures.
Messages: e-mail other aviation buffs with this feature, as long as mail recipients
are aviaportal.net members.
Whether youre interested in commercial or general aviation, light sport or ultralights, a career or a hobby, an interest or a passion, this website has something for you. Log on to http://aviaportal.net to sign up, and explore new heights.
Have blue skies,
Rudolph
Best regards,
Mr Rudder
mr_rudder(at)aviaportal.net
Subject: | Two New Lists Added to the Matronics Lineup! |
Dear Listers,
I've added two new Email Lists to the Matronics List and Forum lineup today. These
include the Rans-List and RV12-List. Please surf over to the Matronics List
Subscription page and sign up for these new Lists if they are of interest
to you:
http://www.matronics.com/subscribe
Full support on the Forums, List Browse, Archives, etc. is available.
Rans-List:
http://www.matronics.com/Navigator?Rans-List
RV12-List
http://www.matronics.com/Navigator?RV12-List
Best regards,
From: | Blake Lancaster <blakeandsue(at)sbcglobal.net> |
Subject: | Re: Aerobatic-List Digest: 0 Msgs - 04/19/08 |
Please unsubscribe me from the Aerobatic-List.
Sent: Sunday, April 20, 2008 2:55:37 AM
Subject: Aerobatic-List Digest: 0 Msgs - 04/19/08
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 08-04-19&Archive=Aerobatic
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 08-04-19&Archive=Aerobatic
Total Messages Posted Sat 04/19/08: 0
Subject: | Four New Email Lists At Matronics!! |
Dear Listers,
I have added four new Lists to the Matronics line up today. These include the
following categories:
Citabria-List Citabria, Decathlon, Scout, and Champ
Zenith601-List Zenair Zodiac CH 601
Zenith640-List Zenair Zodiac CH 640
Zenith701801-List Zenair STOL CH 701 and CH 801
All services are enabled and now available including Search, Browse, Digest, Archives,
Forums, Chat, etc., etc. etc...:
Citabria:
http://www.matronics.com/navigator?citabria-list
Zenith601:
http://www.matronics.com/navigator?zenith601-list
Zenith640:
http://www.matronics.com/navigator?zenith640-list
Zenith701801:
http://www.matronics.com/navigator?zenith701801-list
To subscribe, go to the Matronics Email List Subscription Form:
To check the new Lists out on the Matronics Forum go here:
Enjoy the new Lists!! Don't forget me during the Fund Raiser! :-)
Best regards,
Subject: | Aviation microphone selfpowered circuit |
Howdy
I have searched the web for a mic preamp it seems like 1 transistor and powered
via 4 diodes in a bridge.
Has anyone a circuit? the purpose is for cupless headset
http://img353.imageshack.us/img353/2310/oldmicap2dd6.jpg
thanks
Tony
Subject: | Wanted to buy 2 Parachutes-Cash |
Hi guys,
Anyone interested in selling a set of parachutes?
I had 2 parachutes lined up to buy from a friend for my Yak-52, but he
decided to keep all 4 of his chutes, so I'm back to trying to find 2 used seat
chutes that someone out there no longer needs or might want to unload for cash.
My wife is pregnant and is putting the squeeze on me to have parachutes when
I fly the Yak.
If anyone knows of someone that would like to sell their used chutes please
have them contact me off the matronics list directly via my email which is
_sd737(at)aol.com_ (mailto:sd737(at)aol.com)
Again, please email me directly.
Thanks guys,
Scott Douglass
Reno, Nv
**************Looking for a car that's sporty, fun and fits in your budget?
Read reviews on AOL Autos.
(http://autos.aol.com/cars-BMW-128-2008/expert-review?ncid=aolaut00050000000017 )
Subject: | Yahoo! Auto Response |
I am away from a computer until Sunday, September 14. I will respond to your email
at that time.
Thank you,
Steve
Subject: | BrightLine Bags Pilot Flight Bag |
From: | "BrightLine" <info(at)brightlinebags.com> |
Hello Everyone,
My name is Bryan Smith and I am with a company called BrightLine Bags. Company is a loose term as there are two of us, but whos counting. I do not want to offend anybody by posting on this list, so I apologize in advance if I have. I am a student pilot as well. I posted on the Commander list with the help of a Commander owner and received wonderful response from quite a few Commander owners. We make a brand new type of Pilot Flight Bag. It is like nothing you have seen or used before. If you use a flight bag, I am quite certain that if you go to our website at www.brightlinebags.com and click on the demo video http://brightlinebags.ipower.com/videopage.html, you will be impressed. Thank you everyone for this forum. If you have any questions, you can contact me directly at bryan@brightlinebags.com.
Bryan
http://forums.matronics.com/viewtopic.php?p=210553#210553
http://forums.matronics.com//files/brightline_pilot_flight_bag_105.jpg
Subject: | Matronics Email List Fund Raiser During November! |
Dear Listers,
Each November I hold a PBS-like fund raiser to support the continued operation
and upgrade of the List services at Matronics. It's through soley through the
Contributions of List members that these Matronics Lists are possible.
You have probably noticed that there are no banner ads or pop-up windows on any of the Matronics Lists or related web sites such as the Forums site ( http://forums.matronics.com ), Wiki site ( http://wiki.matronics.com ), or other related pages such as the List Search Engine ( http://www.matronics.com/search ), List Browse ( http://www.matronics.com/listbrowse ), etc. This is because I believe in a List experience that is completely about the sport we all enjoy - namely Airplanes and not about annoying advertisments.
During the month of November I will be sending out List messages every few days
reminding everyone that the Fund Raiser is underway. I ask for your patience
and understanding during the Fund Raiser and throughout these regular messages.
The Fund Raiser is only financial support mechanism I have to pay all of the
bills associated with running these lists. Your personal Contribution counts.
Once again, this year I've got a terrific line up of free gifts to go along with
the various Contribution levels. Most all of these gifts have been provided
by some of the vary members and vendors that you'll find on Matronics Lists and
have been either donated or provided at substantially discounted rates.
This year, these generous people include Bob Nuckolls of the AeroElectric Connection (http://www.aeroelectric.com/), Andy Gold of the Builder's Bookstore (http://www.buildersbooks.com/), and Jon Croke of HomebuiltHELP (http://www.homebuilthelp.com/).
These are extremely generous guys and I encourage you to visit their respective
web sites. Each one offers a unique and very useful aviation-related product
line. I would like publicly to thank Bob, Andy, and Jon for their generous support
of the Lists again this year!!
You can make your List Contribution using any one of three secure methods this
year including using a credit card, PayPal, or by personal check. All three methods
afford you the opportunity to select one of this year's free gifts with
a qualifying Contribution amount!!
To make your Contribution, please visit the secure site below:
https://www.matronics.com/contribution
I would like to thank everyone in advance for their generous financial AND moral
support over the years. I know it sounds a little cliche, but you guys really
do feel like family.
Thank you for your support!
Subject: | Contribution Site URL Clarification |
Dear Listers,
In my List Fund Raiser kickoff email last night, I mistyped the URL for the *initial*
Contribution web site and couple of people reported receiving SSL certificate
errors. The actual payment entry pages where were correct, however, so
there were no certificate issues that impacted payment data. I'm sorry for the
confusion.
Please use the following URL to start your List Contribution:
Dear Listers,
and upgrade of the List services at Matronics. It's through solely through the
You have probably noticed that there are no banner ads or pop-up windows on any of the Matronics Lists or related web sites such as the Forums site ( http://forums.matronics.com ), Wiki site ( http://wiki.matronics.com ), or other related pages such as the List Search Engine ( http://www.matronics.com/search ), List Browse ( http://www.matronics.com/listbrowse ), etc. This is because I believe in a List experience that is completely about the sport we all enjoy - namely Airplanes and not about annoying advertisements.
Subject: | Please Make a Contribution to Support Your Lists... |
Dear Listers,
Just a reminder that November is the Annual List Fund Raiser. Please make a Contribution
these great List services!! Pick up a really nice free gift with your qualifying
Contribution too!
The Contribution Site is fast and easy:
Thank you!
A couple of years ago I implemented an automatic "squelch button" of sorts for
the Fund Raiser messages. Here's how it works... As soon as a List member makes
a
Contribution through the Matronics Fund Raiser web site, he or she will instantly
cease to receive these Fund Raiser messages for the rest of the month! Its
just that simple. Don't you wish PBS worked that way! :-)
and
software that are required to run a List Site like this. It also goes to pay for
the commercial-grade Internet connection and to pay the huge electric bill
to
keep the computer gear running and the air conditioner powered on. I run all of
the Matronics Email List and Forums sites here locally which allows me to
control and monitor every aspect of the system for the utmost in reliably and performance.
Your personal Contribution matters because, when combined with other Listers such
as yourself, it pays the bills to keep this site up and running. I accept
exactly ZERO advertising dollars for the Matronics Lists sites. I can't stand
the pop-up ads and all other commercials that are so prevalent on the Internet
these days and I particularly don't want to have it on my Email List sites.
If you appreciate the ad-free, grass-roots, down-home feel of the Matronics Email
Thank you!
[Note that there are certain circumstances where you might still see a Contribution
related message. For example, if someone replies to one of the messages,
when using the List Browse feature, or when accessing List message via the Forum.
The system keys on the given email address and since most of these are
anonymous public access methods, there is no simple way to filter them.]
From: | "steve, ashley and corbin" <gobigred(at)sio.midco.net> |
Subject: | Re: Contribution Site URL Clarification |
Please stop e-mailing
Sent: Saturday, November 01, 2008 10:01 AM
Subject: Aerobatic-List: Contribution Site URL Clarification
> Dear Listers,
> the *initial* Contribution web site and couple of people reported
> receiving SSL certificate errors. The actual payment entry pages where
> were correct, however, so there were no certificate issues that impacted
> payment data. I'm sorry for the confusion.
> Matt Dralle
> Matronics Email List Administrator
Dear Listers,
Just a quick reminder that November is the annual List Fund Raiser. The Matronics
Lists are 100% member supported and all of the operational costs are provided
for my your Contributions during this time of the year.
Your personal Contribution makes a difference and keeps all of the Matronics Email
Lists and Forums completely ad-free.
Please make your Contribution today to keep these services up and running!
Thank you in advance!
Subject: | Fund Raiser List of Contributors - Please Make A Contribution |
Today!
Each year at the end of the List Fund Raiser, I post a message acknowledging everyone
for the Lists.
Won't you take a moment and assure that your name is on that List of Contributors
(LOC)? As a number of members have pointed out over the years, the List seems
tool as your typical magazine subscription!
Please take minute and assure that your name is on this year's LOC! Show others
that you appreciate the Lists. Making a Contribution to support the Lists is
fast and easy using your Credit card or Paypal on the Secure Web Site:
or by dropping a personal check in the mail to:
Matt Dralle / Matronics
PO Box 347
Livermore CA 94551-0347
I would like to thank everyone that has so generously made a Contribution thus
far in this year's List Fund Raiser! Remember that its YOUR support that keeps
how the Lists have helped you!
Best regards,
Subject: | Please Make A Contribution To Support Your Lists |
Dear Listers,
There is no advertising income to support the Matronics Email Lists and Forums.
The operation is supported 100% by your personal Contributions during the November
Fund Raiser.
Please make your Contribution today to support the continued operation and upgrade
of these services. You can pick up a really nice gift for making your Contribution
too!
You may use a Credit Card or Paypal at the Matronics Contribution Site here:
or, you can send a personal check to the following address:
Matronics / Matt Dralle
PO Box 347
Livermore, CA 94551-0347
Subject: | Fund Raiser Lagging Last Year By Over 30%... |
As of the 13th, the Fund Raiser is currently about 30% behind last year in terms
of the number of Contributions. Yet, oddly the number of messages posted per
day is up by 10 to 20% on the average. It costs real money to run these Lists
and they are supported 100% though your Contributions during the Fund Raiser.
Won't you please take a minute right now to make your Contribution to keep
these Lists up and running?
Contribution Page:
Email List Admin.
Subject: | What's My Contribution Used For? |
Dear Listers,
Some have asked, "What's my Contribution used for?" and that's a good question.
Here are just a few examples of what your direct List support enables. It provides
for the very expensive, commercial-grade T1 Internet connection used on
the List insuring maximum performance and minimal contention when accessing
List services. It pays for the regular system hardware and software upgrades
enabling the highest performance possible for services such as the Archive Search
Engine, List Browser, and Forums. It pays for 19+ years worth of online archive
data available for instant random search and access. And, it offsets the
many hours spent writing, developing, and maintaining the custom applications
that power this List Service such as the List Browse, Search Engine, Forums,
Wiki and PhotoShare.
But most importantly, your List Contribution enables a forum where you and your
peers can communicate freely in an environment that is free from moderation,
censorship, advertising, commercialism, SPAM, and computer viruses. How many
places on the Internet can you make all those statements these days?
It is YOUR CONTRIBUTION that directly enables these many aspects of these valuable
List services. Please support it today with your List Contribution. Its
one of the best investments you can make in your Sport...
List Contribution Web Site:
Subject: | What Members Are Saying... |
Dear Listers,
November is the Annual Matronics List Fund Raiser. The Lists are supported solely
through your generous Contributions during this time. Please make your Contribution
today and pick up a really nice free gift at this same time:
Listers have been including some really nice comments regarding what the Lists
mean to them along with their Contributions this year. I've included a few of
them below. Please read them over and see if some perhaps echo your feelings
as well.
Thank you for your support this year!
Best bargain in the entire industry!!
-Owen B
Every year your lists are better, sure #1 in e-mail list in the world.
-Gary G
Thank you for an awesome site!
-Ashley M
Your lists are important to me and well worth paying for.
-Calvin A
Thank you for providing such and informative and ad free environment
to learn by.
-Myron H
As always, a valuable and extremely useful resource.
Stephen T
As always, a great service.
-Reade G
Very much appreciate this site and the communications it has
enabled between builders.
-Larry M
This service is worth every penny.
-Robert S
Great site! Thanks a ton for its functionality!
-Peter B
The RV-10 list feels like my community.
-Dave S
The lists are fantastic, a great source!
-Jimmy Y
I've learned a lot from the List.
-Gabriel F
A wonderful resource.
-Gerald G
Well done.
-Richard N
Years of good service.
-William M
Valuable service.
-Keith H
The site is quite helpful.
-Jon M
Very interesting List that I read form the beginning.
-Alain L
A well managed site.
-Carl B
Great service.
-Svein Kare J
Still the most useful program on the computer.
-Fergus K
Great contribution to my project!
-Robert K
Thanks for keeping a great list.
-Dt G
The List continues to provide excellent information.
-Tony C
This is a wonderful resource that has easily saved me a bunch on
my build-time.
-Ralph C
Thank you for providing a great service. The Zenith builder's community
would be in sad shape without the Zenith-List's.
-Terrence P
I really do get pleasure out of reading the List every day.
-Bill V
Great source of information.
-Arthur V
Thanks for a great service. Very enjoyable.
-Louis B
You know we all could not do without your support!!
-James S
Great resource!
-Douglas D
Thanks for the great service.
-John B
Subject: | Behind By 21% - Advertising May Be Needed...? |
Dear Listers,
The percentage of people making a Contribution to support the Lists this year is
currently lagging behind last year by approximately 21%! I'm hoping that everyone
is just waiting until the last minute to show their support... ;-)
Please remember that it is solely your direct Contributions that keep these Lists
up and running and most importantly - AD FREE! If the members don't want to
support the Lists directly, then I will likely have to start adding advertisements
to offset the costs of running the Lists. But I *really* don't want to
have to start doing that. I really like the non-commercial atmosphere here and
I think that a lot of the members appreciate that too.
Please take a moment to make a Contribution today in support of the continued ad-free
operation of all these Lists:
I want to send out a word of appreciation to all of the members that have already
made their generous Contribution to support the Lists! Thank you!
Dear Listers,
of my way of publicly thanking everyone that took a minute to show their appreciation
for the Lists.
or by popping a personal check in the mail to:
c/o Matt Dralle
PO Box 347
Best regards,
If you look forward to checking your List email everyday (and a lot of you have
written to say that you do!), then you're probably getting at least $20 or $30
worth of Entertainment from the Lists each year. You'd pay twice that for a
subscription to some lame magazine or even just a single dinner out. Isn't the
List worth at least that much to you?
Lists?
Contribution Page:
Again, I want to say THANK YOU to everyone that has made a Contribution thus far
during this year's List Fund Raiser!! These Lists are made possible exclusively
through YOUR generosity!!
Email List Admin.
Subject: | Just A Few More Days... |
Dear Listers,
There are just a few more days left in this year's List Fund Raiser. There are
some great gifts available when you make a qualifying Contribution and there's
plenty still available. Don't forget that its *your* Contribution that keeps
the computers running, the electricity turned on, and the computer room AC cooling!
If you look forward to reading your List email each day, won't you please take
a minute right now to make your personal Contribution?
Credit Card or Paypal:
Personal Check:
PO Box 347
Livermore, CA 94550
Subject: | Just 3 Days Left - Please Make Your List Contribution |
Today!
There are only three days left until the end of this year's List Fund Raiser.
Please take a minute to show your support as so many others have this year and
make sure YOUR name is on the forthcoming List of Contributors 2008!
Its quick and easy using the secure web site with a credit card or PayPal:
or by sending your personal check to:
Matronics Lists c/o Matt Dralle
PO Box 347
(Please write your email address on the check!)
Thank you in advance for your support of these List services!
Matronics Email and Forum Administrator
Subject: | What Listers Have Been Saying |
Wow! Many of the members making a List Support Contribution this year have been
using the Comments field to leave a personal message about the Lists. Thank
you! I have included a number of them below. Please read over a few and see
if you perhaps can echo some of the same sentiments regarding the value of the
Lists to you...
There is only a couple more days left for this year's List Fund Raiser and we're
still way behind previous years. If you've been waiting until the last minute
to show your support, Now is the Time! Please make your Contribution and pick
up a great gift at the same time!
By Credit Card or Paypal:
or By Personal Check:
PO Box 347
Livermore, CA 94550-7227
Thank you in advance!!
Email List and Forums Administrator
Here is some of the great feedback members have been including along with their
personal Contributions this year...
Over the years, the info I have received from the RV-List has
saved me thousands of dollars, and dozens of hours of time by
helping me avoid bad purchases, pointing me at vendors with
low prices and excellent support, and providing solutions to
the typical head scratchers that you run into.
Kevin H
Valuable service. Best List(s) on the Internet!
George A
Please accept this token not as an indicator of what
this list has been worth to me this past year.
Lew G
Great information and entertainment.
Tim V
Thanks again for another great year of service. This
project would be beyond me if it were not for the list.
Moreover, the friendships I have found are worth their
weight in GOLD!
Robert B
Great support you provide to all the subscribers!
Freddie H
Read it every day.
PF B
Thanks for your excellent management of the Matronics
Lists! Your services are head and shoulders above the
rest.
James M
Without the "List", there would be no Kolb "community".
Bill T
Thanks, Matt, for a great service! I've been monitoring
and using the lists since 1999.
Richard D
Thanks for such a terrific site and for all the work and
effort you put into it.
John R
A great service year after year.
John D
..another year of fantastic service.
Jerry B
This list is a great resource.
Arden A
Great list.
James M
Lists were a great help while building HRII N561FS.
John S
Great resources for both the beginner and experienced.
George R
Good service.
Gary G
The List is an invaluable resource!
William C
AeroElectric list is a great source of info and learning!
Janice J
Thank you, Matt for being there for us making it all happen
on the List for so many years - Great JOB!
Sam S
Thank you for providing a great venue. You definitely hit
the nail on the head with your solicitation asking if
readers look forward to receiving the email digests. I
certainly do and when I move from a dreamer to a builder, I
expect the anticipation will only increase.
Joe S
Thanks for a Perfect working list.
Hans-Peter R
Great List
Bryan K
Such a great selection of valuable forums!
David G
Nice job!
Walt E
Good resource...
Robert P
Thank you for another great year!
Scott S
I could not do this without you...
Robert D
I believe I've been a list member for over a decade
now. Thanks for the service!
Tim L
Great List
Hendrik W
Subject: | Last "Official" Day Of The List Fund Raiser! |
Dear Listers,
Its November 30th and that means three things:..
1) Today I am now officially 45 years old...
2) It marks that last "official" day of this year's List Fund Raiser!
3) Its the last day I will be bugging everyone for a whole year!
If you use the Lists and enjoy the content and the no-advertising, no-spam, and
no-censorship way in which they're run, please make a Contribution today to support
their continued operation and upkeep. Your $20 or $30 goes a long way
to keep the List bills paid.
I will be posting the List of Contributors next week so make sure your name is
on it!
Thank you to everyone that has made a Contribution so far this year! It is greatly
appreciated.
Best regards,
Subject: | List of Contributors 2008 |
Dear Listers,
This year's Fund Raiser has drawn to a close and I want to thank everyone that
so generously made a contribution this year in support of the Matronics Email
List and Forum operation. Your generosity keeps the wheels on this cart and I
truly appreciate the many kind words of encouragement and financial reimbursement.
If you haven't yet made a Contribution in support of this year's Fund Raiser, please
on the Contribution site for a little while longer, so hurry and make your Contribution
today and still get your great gift! Once again, the URL for the Contribution
web site is:
or by personal check to:
PO Box 347
I would like to thank Andy Gold of the Builder's Bookstore ( http://www.buildersbooks.com ), Jon Croke of HomebuiltHELP ( http://www.homebuilthelp.com ) and Bob Nuckolls of AeroElectric ( http://www.aeroelectric.com ) for their extremely generous support during this year's Fund Raiser through the contribution of discounted merchandise. These are great guys that support the aviation industry and I encourage each and every Lister to have a look at their products. Thank you Andy, Jon and Bob!! Your support is very much appreciated!
And finally, below you will find a web link to the 2008 List of Contributors current
as of 12/7/08! Have a look at this list of names as *these* are the people
that make all of these List services possible! I can't thank each of you
enough for your support and great feedback during this year's Fund Raiser!
THANK YOU!
http://www.matronics.com/loc/2008.html
I will be shipping out all of the gifts around the end of December. In most cases,
gifts will be shipped via US Postal Service.
Once again, thank you for making this year's List Fund Raiser successful!
Best regards,
Subject: | Re: Aerobatic-List Digest: 0 Msgs - 12/17/08 |
Hi there, just announcing a live broadcast from Al Ain Aerobatics Show
and Aero GP
Details below.
Merry Christmas
EXCLUSIVE LIVE BROADCAST OF AERO GP 2009
High-speed formula one style Air Racing series, Aero GP (www.aero-
gp.com) will be broadcast live online in January 2009 to motorsport
fans worldwide at Airsports.tv (www.airsports.tv)
Al Ain, U.A.E. is the location for the first grand prix of the 2009
Aero GP air racing series. The Aero GP will be the main event of the
prestigious Al Ain Aerobatic Show which will be broadcast LIVE from 30
31 January 2009 on the new online TV channel, Airsports.tv.
Airsports.tv broadcasts features of top-level air sports competitions
worldwide and boasts an ever-increasing number of avid enthusiasts
tuning in regularly to watch. Now online viewers have the capacity to
watch exclusive live broadcasts of high profile competitions such as
the Aero GP the only international air racing series with multiple
airplanes competing against each other at the same time (pylon
racing).
Aero GP is already broadcast on television to over 300 million homes
worldwide, now motorsports and air racing fans can get free and
exclusive access to the fastest motorsport series in the world in real
time straight right from their desktops.
Online viewers will be able to see each round of the most exciting and
difficult competition elements, which include:
1. Air Race Six aircraft in the circuit at the same time racing
against each other just metres above the ground at speeds of up to
500mph.
2. Air Combat Two pilots compete head-to-head in a battle for
air supremacy
3. Barnstorming Various stunts ranging from aerobatics to limbo
flying. In Al Ain, pilots will compete in a real target bombing
competition.
Jeff Zaltman, Managing Director of Aero GP, said We are extremely
proud to be bringing the Aero GP to the region and are excited to
showcase our sport to a new audience both in Al Ain and Online.
For more information visit www.airsports.tv.
- ends -
Notes to Editors:
For more information on Airsports.tv please contact:
Zo Adjonyoh zadjonyoh(at)airsports.tv , +44(0)207 554 8650
About Aero GP
Flying Aces Ltd, based in London UK, owns and manages global media
rights connected to top-level aviation sport. Flying Aces is the
organiser of the internationally televised Aero GP air racing series.
For more info visit www.aero-gp.com
Contact: Dylan Lloyd, dylan.lloyd(at)flyingaces.co.uk, +44(0)207 554 8650
Subject: | Re: Aerobatic-List Digest: 0 Msgs - 12/23/08 |
Hi,
is there anyone on this list? Is there anyone flying aerobatics in
gliders?
Dylan
From: | Rick Basiliere <discrab(at)earthlink.net> |
Yes, and yes, but not me in gliders. Kline Gilhousen and all the zoomies from Air
Force Academy in CO Springs, to name a few. Rick b
-----Original Message-----
>From: Dylan Caldwell <macquistan(at)mac.com>
>Sent: Dec 24, 2008 1:02 AM
>To: aerobatic-list(at)matronics.com
>Subject: Aerobatic-List: Re: Aerobatic-List Digest: 0 Msgs - 12/23/08
>Hi,
>gliders?
> Dylan
Hi,
Yes, me for example! ;-)
Markus
> -----Ursprngliche Nachricht-----
> Von: "Dylan Caldwell"
> Gesendet: 24.12.08 09:10:18
> An: aerobatic-list(at)matronics.com
> Betreff: Aerobatic-List: Re: Aerobatic-List Digest: 0 Msgs - 12/23/08
> Hi,
> gliders?
> Dylan
Subject: | Re: Aerobatic-List Digest: 3 Msgs - 12/24/08 |
Yup me in Hawaii cruise in my Libelle and " RIP" in the FOX> Life is good,
Linne'
**************One site keeps you connected to all your email: AOL Mail,
Gmail, and Yahoo Mail. Try it now.
From: | "Rob Stapleton, Jr." <foto(at)alaska.net> |
Yes to the list question, check the www.eglider.org site and post a question
to Thomas Knauff.
Merry Christmas!
Rob Stapleton, Photojournalist
Anchorage, Alaska
907-230-9425
KL2AN
Skype:rob.stapleton.jr
IM Windows Live Messenger: foto(at)alaska.net
[mailto:owner-aerobatic-list-server(at)matronics.com] On Behalf Of Dylan
Caldwell
Sent: Tuesday, December 23, 2008 11:02 PM
Hi,
gliders?
Dylan
Subject: | Re: Aerobatic-List Digest: 2 Msgs - 12/25/08 |
Recently got reply re motor glider experience...great read...and now I can't
locate it! Would sender poss be able to resend....drjsherm(at)aol.com
Dylan, did you have a particular question in mind then? Or why did you ask?
Markus
> Hi,
> gliders?
> Dylan
Subject: | Re: Aerobatic-List Digest: 1 Msgs - 12/30/08 |
Hi, Markus,
I don't have a specific question at this time. I was trying to find
other people who fly aerobatics in gliders. I have a B4 and took some
lessons from Jason Stephens in Oct and plan to go back this spring.
Eventually, I would like to try competing.
Dylan
Hi Dylan,
Ok, I see. Should you have any glider aerobatics related questions in the future,
feel free to ask at any time! Even though the glider aerobatics community might
be small here, the experience is quite high (from sportsman up to international
unlimited level).
Regards and have fun with your B4,
Markus
> Gesendet: 01.01.09 07:57:37
> Betreff: Aerobatic-List: Re: Aerobatic-List Digest: 1 Msgs - 12/30/08
> Hi, Markus,
> Dylan
Subject: | Re: Aerobatic-List Digest: 0 Msgs - 01/28/09 |
Dear Editor,
Please find below a press release titled: 'AERO GP air race goes LIVE
online with Airsports.tv' for possible inclusion in your publication.
January 29 2009
London
AERO GP air race goes LIVE online with Airsports.tv
Nicknamed the Formula One of aviation; the Aero GP air race series (www.aero-gp.com
) will be broadcast live online on 30-31 January 2009 to air racing
The live broadcast comes as part of a celebration of the centenary of
air racing and the Aero GPs debut in the Middle East. The Aero GP
will be the first competitive multiple airplane race of its kind in
the region and the main event of the prestigious Al Ain Aerobatic
Show. Both spectacular events will be broadcast LIVE on 30 31
worldwide and is fast becoming a focal point for the air sports
community.
Jeff Zaltman, Managing Director of Aero GP, said We want to share the
excitement and enthusiasm of this amazing sport with as many people as
possible and get competitive air racing noticed by the wider sporting
community. The online broadcast with Airsports.tv is an essential part
of the process.
Viewers who tune in will see all aspects of the Aero GP events with
live commentary including:
1. Pylon Air Race Five aircraft racing simultaneously around a
tight circuit, 20 feet off the ground at at speeds of up to 500kph.
2. Dog Fighting Two pilots compete head-to-head in a battle for
air supremacy in an air combat round
3. Target Bombing As part of the Barnstorming round pilots
will perform various aerobatic stunts and compete in a real target
bombing competition.
The impressive line up of world-class pilots includes: Richard
Smokey Young, Andy Bickmore, Zoltan Veres, Gerald Cooper and Mark
Jefferies.
Broadcast times:
30 - 31 January 2009
09:00am - 14:00pm GMT London
13:00 - 18:00 Local time
- ends -
Notes to Editors:
Full pilot biographies and images are available, for more information
contact:
Zo Adjonyoh zadjonyoh(at)airsports.tv , (+44 20 31 7 35 34)
About Aero GP
Contact: Dylan Lloyd, dylan.lloyd(at)flyingaces.co.uk, (+44 20 31 78 35
30)
Subject: | JUICY COUTURE SIDEKICK I----- $100,SIDEKICK II MISTER |
CARTOO
We Are Arrow Electronics,we sell brand new mobile phone, unlocked, laptops,Plasma
T.V, with full accessories,and 1year international warranty from the Manufacturer.
*SPECIFICATIONS:
(europeans/usa-specifications) general network gsm 900/gsm 1800/gsm 1900 platform
- tri band (gsm900 + 1800 + 1900 MHz: countries where manufactured: Finland.
Contact Name: Mr : Prince Sacasto
E-Mail: princodestate(at)gmail.com
Do have a look at the rated and other mobile phones we stock below.
Apple iPhone 3G 16Gb Unlocked @190usd
Apple iPhone 3G 8GB Unlocked @155usd
Apple iPhone 8GB Unlocked @110usd
Apple iPhone 16GB Unlocked @120usd
Nokia 6700 classic @290usd
Nokia 6303 classic @280usd
Nokia 6208c @280usd
Nokia 8800 Gold Arte @265USD
Nokia N97 @250usd
Nokia N85 @200usd
Nokia N96 16GB @190usd
Nokia N95 8GB @170usd
Nokia N95 @150usd
Nokia N93i@ 150usd
Nokia n93 @ 140usd
Nokia N92 @ 130usd
Nokia N91 8GB @ 145usd
Nokia N80 @160usd
Nokia N76 @160usd
Nokia N75 @120usd
Nokia N73 @110usd
Nokia N70 @95usd
Nokia E75 @230usd
Nokia E71 @145usd
Nokia E66 @150usd
Nokia E90 Communicator @185usd
Nokia E65 @ 100usd
Nokia E55 @200usd
Nokia 8800 Sirocco @ 195usd
Nokia 770 Internet @160usd
Nokia 5630 XpressMusic @ 300usd
Nokia 5800 xpressMusic. @ 290usd
Nokia 5320 XpressMusic @ 250usd
Nokia 5220 XpressMusic @ 205usd
HTC Magic------------------$330
HTC Touch Pro2-----------$300
HTC Touch Diamond2----$290
HTC Dream---------------$300
HTC Touch Cruise 09----$290
HTC Max 4G---------------$280
HTC Touch HD-------------$250
HTC Touch 3G--------------$250
HTC Touch Viva------------$215
HTC Touch Pro - - - - - - - $200
HTC Touch Diamond - - $190
HTC Shift Pocket PC---$220
HTC Advantage X7510 - - $290
HTC P3470 - - $200
HTC Touch Cruise - - $250
HTC Touch Dual - - $225
HTC P6500 - - $210
HTC S730 - - $200
HTC TyTN II - - $195
HTC S630 - - $150
HTC Touch - - $101
HTC P6300 - - $120
HTC Shift - - $230
HTC Advantage X7500 - - $215
Blackberry Curve 8900 @230usd
Blackberry Storm 9530@210usd
Blackberry Storm 9500 @200usd
Blackberry Pearl Flip 8220 @210usd
Blackberry Bold 9000 @200usd
Blackberry Curve 8320 @190usd
Blackberry Curve 8310 @205usd
Blackberry Curve 8300 @ 200usd
Blackberry 8820 @195usd
Blackberry 8830 World Edition @200usd
Blackberry 8800 "indigo" unlocked @ 200usd
Blackberry 8700g @ 160usd
Blackberry 8100 Pearl Cingular unlocked @140usd
LG Phones
LD GM730 @300
LG KM900 Arena @300
LG GD910 @290
LG KS500 @280
LG KF900 Prada @290
LG KC780 @250
LG KP500 Cookie @255
LG KC910 Renoir @260
LG KB770 @200
LG CB630 Invision @200
LG KS360 @190
ETEN glofiish X610 @210
ETEN glofiish V900 @220
ETEN glofiish X900 @205
ETEN glofiish DX900 @210
ETEN glofiish M750@200
ETEN glofiish M810 @170usd
ETEN 500 Glofiish @ 160usd
ETEN M700 Glofiish 2 @195usd
ETEN M600 @ 135usd
ETEN G500 @ 110usd
ETEN 800 Glofiish @ 200usd
Samsung i8910 Omnia HD $310
Samsung S8300 UltraTOUCH $290
Samsung T929 Memoir $290
Samsung S9402 Ego ......$270
Samsung T919 Behold.....$260
Samsung M3200. $260
Samsung i907 Epix @270
Samsung A767 Propel@260
Samsung A867 EternityN @255
Samsung M8800 Pixon @245
Samsung D980 @230
Samsung i8510 INNOV8 16GB @210
Samsung Instinct @200
Samsung i900 Omnia @ 200usd
Sony Ericsson W902 Volcanic @240
Samsung SGHB600 @ 230usd
Samsung i760 @ 210uad
Samsung F500 @ 180uad
Samsung D900 @ 110uad
Sony Ericsson Idou @350usd
Sony Ericsson W395 @295usd
Sony Ericsson C901 @285usd
Sony Ericsson C903 @290usd
Sony Ericsson C510 @280usd
Sony Ericsson W508 @270usd
Sony Ericsson W705 @300usd
Sony Ericsson W715 @295usd
Sony Ericsson G705 @280usd
Sony Ericsson W705 @260usd
Sony Ericsson C905 @250usd
Sony Ericsson XPERIA X1 @ 195usd
Sony Ericsson W950i @ 205uad
Sony Ericsson W880i Walkman Phone @ 200usd
Sony Ericsson W850i @ 200usd
Sony Ericsson W810i Walkman Phone @ 110usd
Sony Ericsson W660i @ 120usd
Sony Ericsson M600i @ 210usd
APPLE IPODS:
Apple IPod 32GB Newest! ---------$180
Apple iPod 30GB (Video) New! - - $100
Apple iPod 60GB (Video) New! - - $110
Apple iPod Nano 2GB New! - - $70
Apple iPod Nano 4GB New! - - $80
Apple iPod Shuffle 512 MB - - $65
Apple iPod Shuffle 1 GB - - $75
Apple iPod Mini 4 GB - - $70
Apple iPod Mini 6 GB - - $90
Apple iPod Photo 30 GB - - $100
Apple iPod U2 SE 20 GB - - $111
Apple iPod Photo 60 GB - - $121
Apple iPod 20 GB - - $95
Apple ipod 80 GB - - $115
VIDEOGAMES PRICELIST
Sony PlayStation Portable (PSP) Console:$180usd
Sony PlayStation 2 Console:$120usd
Sony PlayStation 2 Slimline Console:$140usd.
Sony PlayStation 3 (60 GB) Console:$375usd.
Sony PlayStation 3 (20 GB) Console:$275usd
Sony PlayStation 3 (80GB) Console:$475usd
Nintendo Wii T Console:$200usd
Nintendo DS Lite Console:$220usd
Nintendo Game Boy Advance SP Console:$110usd
Nintendo GameCube Console:$100usd
Nintendo DS Console:$160usd
Nintendo Super NES Console:$140usd.
Nintendo Game Boy Advance Console:$120usd
Nintendo 64 Console:$85usd.
Microsoft Xbox 360T Premium Console:$230usd
Microsoft Xbox 360T Elite Console:$200usd
Microsoft Xbox Console:$195usd
Microsoft Xbox 360 Core System Console:$220usd
Microsoft Xbox 360 Platinum Console:$150usd
PANASONIC PLASMA TV
Panasonic TH-37PHD8UK Plasma $900
Panasonic TH-42PWD8UK Plasma $950
Panasonic TH-42PHD8UK Plasma $945
Panasonic TH-42PX50U Plasma $850
Panasonic TH-50PX50U Plasma $800
panasonic TH-65PHD8UK Plasma $820
SONY PLASMA TV
SONY FWD-42PV1 Plasma Display $800
Sony PFM-42X1 Plasma Display $780
Sony FWD-50PX2 Plasma Display $950
PHILIPS PLASMA TV
Philips 42PF7320A/37 Plasma TV $590
Philips 42PF9630A/37 Plasma HDTV $650
Philips 50PF7320A/37 Plasma HDTV $600
Philips 50PF9630A/37 Plasma HDTV $495
Philips 50PF9830A/37 Plasma HDTV $750
SAMSUNG PLASMA TV
SAMSUNG HPP3761 Plasma TV $200
Samsung PPM42M5S Plasma Display $800
Samsung SPP4251 Plasma TV $800
Samsung PPM42M5H Plasma Display $950
Samsung HPR4252 Plasma $900
Samsung HPR4262 Plasma TV $800
Samsung HPR4272 Plasma $800
Samsung PPM50M5H Plasma Display $840
Samsung HPR5052 Plasma $700
Samsung HPR5072 Plasma $650
Samsung HPP5581 Plasma TV $550
Samsung PPM63H3Q Plasma Display $500
Samsung HPR6372 Plasma $500
HITACHI PLASMA TV
Hitachi CMP4211u Plasma $850
Hitachi CMP4212u Plasma $350
Hitachi 42HDF52 Plasma HDTV $400
Hitachi 42HDT52 Plasma TV $440
Hitachi 55HDS52 Plasma HDTV $480
Hitachi 55HDT52 Plasma TV $650
Hitachi CMP-55HDM71 Plasma $420
APPLE LAPTOPS
Apple Macbook Air............................$750
Apple MacBook (MA700LL/A) Mac Notebook...$500usd
Apple MacBook Pro (MA611LL/A) Notebook...$500usd
Apple MacBook (MA254LL/A) Mac Notebook...$450usd
Apple iBook G3 (M7698LL/A) Mac Notebook..$600usd
Apple MacBook Pro (MA609LL/A) Notebook...$550usd
Apple MacBook Pro (MA600LLA) Notebook...$500usd
Apple MacBook Pro (MA610LL/A) Notebook...$450usd
Apple Macbook Pro (885909119400) Notebook..$445usd
DELL LAPTOP:
Dell XPS M1710 PC Notebook...$500usd
Dell XPS M2010 PC Notebook....$550usd
Dell Laptop 1100-BX7ZT21...$350
Dell Latitude C640 - 2.0GHz, 512MB, 40GB...$400
Dell Inspiron Model 8500 Laptop..$400
Dell Latitude D810...$500
Dell Inspiron 6000 Notebook Computer..$400
Dell Laptop,Wireless,Intel M,60GB HD,CD/DVD, XP,Pro...$360
ACER FERRARI P4 LAPTOP:
Acer Ferrari 3200 - Mobile Athlon 64 2800+ ...$450
Acer Ferrari 3400LMi Notebook ...$500
Acer Ferrari 3000LMi - Athlon XP-M...$480
Acer Ferrari 3200LMi - Mobile Athlon..$650
Apple Powerbook G4 1.67ghz Drive Bluetooth
SONY LAPTOP
Sony VAIO VGN-T1..$1100
Sony VAIO VGN-FS315...$1000
Sony VAIO VGN-S3...$850
Sony VAIO VGN-TX1...$780
Sony VAIO VGN-FS215...$710
Sony VAIO VGN-S4...$870
Sony VAIO PCG-K35...$750
Sony VAIO A170 Laptop ....$900
Sony VAIO GRT250 Laptop ....$850
Sony VAIO V505DC1 Laptop ....800
RETURN POLICY
You may return the item within twenty {60} days of delivery. Products with Manufacturer
Warranty which exceed 70 days, could be returned directly to the manufacturer
according to their instructions.
OUR TERM
We ship to any destinations less than 2 days after confirming your part payment
for the order or phones demanded for . We supply through FedEx shipping company
for distribution of our goods worldwide.
Your enquiry will be greatly appreciated.
http://forums.matronics.com/viewtopic.php?p=234558#234558
Subject: | Teach your kid to use the internet |
My husband and I are very busy in our respective professions. That leaves us with
very little time for our adolescent twin daughters. Sometimes it so happens
that we are even unable to meet on a certain day due to all our schedules. I
want to install a safe internet connection at home, so that I can at least communicate
with my daughters. At the same time I fear their exposure to vulgar and
adult sites. Is there any such service provider?
http://forums.matronics.com/viewtopic.php?p=241482#241482
Subject: | Re: Teach your kid to use the internet |
A friend of mine recently availed services of www.kidsemail.org for his eleven year old son. Kidsemail.com enables safe internet access for kids, without them stumbling upon forbidden sites with adult content. You can check out the site for details and all the features they are offering.
http://forums.matronics.com/viewtopic.php?p=242055#242055
Enjoy the Internet along with your children. 2. Teach your kids to trust their
... Get tips by age to help guide your children's use of the Internet: ...
http://forums.matronics.com/viewtopic.php?p=245846#245846
Subject: | Hot offer for aircraft parts |
From: | "Nanchang CJ6" <liutiantian1987(at)hotmail.com> |
We supply the aircraft parts as below, if there have anything you need, pls contact
with us. Pls Mail to:lcdzkj(at)live.cn
Aircraft tires:
K8/JL8,F-6,F-7
Su-22/24/25/27/30,IL12/18/62/76, MIG 15/17/21/25/29/31, Yak18, An2,
Mi2
Tu-154,J-5/6/7,H-5/6
B737-200/300/500, MD82, AIRBUS-A310/320 , IL76/86. etc.
Brake plates:
An-24/-26/-30, IL-18/-62/-76/-86, Yak-42, Tu-134/-154
B737, B767, MD82, IL86, MD90 etc
Others:Aircraft parts for China made aircraft: CJ6/PT6,Y-5,Y-7,Y-8,Y-10,Y-12,Z-9,MA60,
K-8,J-7...
Tally:86-13468610692
http://forums.matronics.com/viewtopic.php?p=254258#254258
Subject: | Aircraft Tyres For Sale |
No. Size Des Outer(kg) Inner(kg) Aircraft
1 660160 TT 14 2 F-5MIG15MIG17FT-5
2 600180 TT 9 2 H-5MIG8LA29YAK11
3 480200 TT 7 1 MIG15.MIG17.F-5Y-12IV
4 800260 TT 23 4 Y-5/AN-2.IL10
5 400150 TT 4 1 Z-5,CJ-6,LA29,Y-11B,J-8,IL10
6 300125 TT 2 1 LA-9
7 500150 TT 6 1 CJ-5/YAK18,CJ-6
8 470210 TT 6 1 Y-5
9 700250 TT 15 3 Z-5/M14,Y-7/AN24,IL18,AN26
10 500180G TT 7 1 J-6,J-7,J-7B
11 500180G TL 8 F-7CF-7M
12 595230 TT 10 2 Q-5 original
13 595230 TL 13 Q-5 series main wheel
14 865280 TT 26 4 Du124MIG8
15 830205 TT 20 4 A-5
16 830205 TL 22 A-5
17 6.5010 TL 9 K-8,K-11
18 660200 TT 15 3 F-6,F-7,Du124
19 660200T TL 16 F-6,F-7
20 560210 TL 11 J-8
21 850250G TL 31.8 J-8
22 560210G TL 12.4 J-8
23 1300480 TT 78 13 IL76
24 1030350 TL 62 SU-27
25 680260 TL 22 SU-27
26 840290 TL 32 MIG29
27 570140 TT 10 1 MIG29
28 20.0020 TL 120 C130
29 950300 TL 43.2 SU-24,TU-154,TU153
30 620180 TT 11 KA-27/28
31 480200 TT 5.3 KA-27/28
32 1030350 8A TL 63 SU-30MKK.SU-30MK2
33 620180 4A TL 12 SU-30MKK.SU-30MK2
Sarah:86-13468610692
http://forums.matronics.com/viewtopic.php?p=254259#254259
Subject: | Hot offer for Nanchang CJ-6 aircraft parts |
Part number Description
1 DZ-5 Spark Plugs
2 QS-2 Brake valve differential
3 BG12-1A Instrument altimeter
4 FL-3 Compass amplifier
5 ZH-4 Instrument compass indicator
6 GY-1 Fuel pressure
7 ZWH-1 Instrument cyl. Temp
8 ZZ30-1C Instrument tach single needle
9 DH-2 Boost coil
10 TS-1 Prop governer
11 CP-15 Petrol Pumb(gasoline)
12 CB-32A Engine oil pump
13 BC10 Instrument vsi (rate of climb)
14 BAV-3 Instrument current voltage
15 BYJ-1 Instrument manifold press
16 CSR-1 Air radiator
17 H2-6112-00A/1 2 Oil house R/H
18 Propeller blade
19 BDP-2B Instrument Horizon
20 301 Clock front cockpit
21 2UC2-7 Instrument oil indicator
22 BYQ80-1A Air pressure guage
23 QS-1 Brake valve reducing
24 KY-2C Air Compressor
25 SB-1 Pump manual fuel wobble pump
26 QHQ-14 Carburetor
http://forums.matronics.com/viewtopic.php?p=254261#254261
Subject: | Support the World Aerobatic Championships 2009 |
Hi all,
Hope you are well.
I was wondering whether you would mind adding a link to our live
broadcast of the World Aerobatic Championships 2009
(http://www.airsports.tv/worldaerobaticchampionshiplive.asp
We're really excited to be part of the event and looking for aviation
sites and aerobatic clubs and flying schools to share the news of the
live broadcast so everyone can be a part of it.
We're always looking for contributors to the site, whether providing
video content of important sports competitions or if you would like to
write articles and sports updates, please do not hesitate to get in
touch with me.
Best,
Zoe
Zoe Adjonyoh
Airsports.tv
Email: zadjonyoh(at)airsports.tv
Airsports.tv =88=99 Flying Aces =88=99 Aero GP =88=99
World Aerobatic
Championships
This electronic mail message (e-mail) and any files transmitted with
it are privileged and confidential information and intended solely for
the use of the addressee. Neither the confidentiality nor any
privilege in this e-mail is waived, lost or destroyed by reason that
it has been transmitted other than to the addressee.
Hi Zoe=2C
I have forwarded the email to our AErobatic Club President here in New Zeal
and. I for one am very excited about being able to watch the competition on
line as I follow the worlds closely.
Best Regards=2C
Andrew Love
Andrew Love Contracting
trading as
AWL Air Services
and
Nu Look Window Cleaning Services
P +64 3 451 0396 I F +64 3 451 0395 I M +64 21 81
8 816
Subject: Aerobatic-List: Support the World Aerobatic Championships 2009
Date: Tue=2C 4 Aug 2009 09:08:32 +0100
Hi all=2C
Hope you are well.
I was wondering whether you would mind adding a link to our live broadcast
of the World Aerobatic Championships 2009 (http://www.airsports.tv/worldaer
obaticchampionshiplive.asp)
We're really excited to be part of the event and looking for aviation sites
and aerobatic clubs and flying schools to share the news of the live broad
We're always looking for contributors to the site=2C whether providing vide
o content of important sports competitions or if you would like to write ar
ticles and sports updates=2C please do not hesitate to get in touch with me
Best=2C
Zoe
Zoe Adjonyoh
Airsports.tv
Airsports.tv - Flying Aces - Aero GP - World Aerobatic Cha
mpionships
This electronic mail message (e-mail) and any files transmitted with it are
privileged and confidential information and intended solely for the use of
the addressee. Neither the confidentiality nor any privilege in this e-mai
l is waived=2C lost or destroyed by reason that it has been transmitted oth
Brrr... its getting cold out there Find someone to snuggle up with
Fchannel%2Findex%2Easpx%3Ftrackingid%3D1048628&_t=773568480&_r=nzWINDOW
SliveMAILemailTAGLINES&_m=EXT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Subject: | Re: Teach your kid to use the internet |
Hi Jenx,
Me Lara croft and I read your post, I am giving you solutions. You can get Internet
from any ISP. You just need MS Windows Vista Operating System installed on
your computer system. There is a option given in control penal for Family Security.
When you activate it. It will restrict porn and adult sites. If you have
other windows family operating system, you can use K9 Web protections software
for blocking of unwanted and adult,porn sites. This application software is
freely available on Internet.
R4games
http://forums.matronics.com/viewtopic.php?p=270213#270213
Subject: | PLEASE READ - Matronics Email List Fund Raiser During |
November!
Dear Listers,
Each November I hold a PBS-like fund raiser to support the continued operation and upgrade of the List services at Matronics. It's solely through the Contributions of List members that these Matronics Lists are possible. There is NO advertising to support the Lists. You might have noticed the conspicuous lack of flashing banners and annoying pop-ups on the Matronics Email List email messages and web site pages such as the Matronics List Forums ( http://forums.matronics.com ), the List Wiki ( http://wiki.matronics.com), or other related pages such as the List Search Engine ( http://www.matronics.com/search ), the List Browser ( http://www.matronics.com/listbrowse ), etc. This is because I believe in a List experience that is completely about the sport we all enjoy - namely Airplanes and not about annoying advertisements.
During the month of November I will be sending out List messages every couple of
days reminding everyone that the Fund Raiser is underway. I ask for your patience
and understanding during the Fund Raiser and throughout these regular messages.
The Fund Raiser is only financial support mechanism I have to pay all
of the bills associated with running these lists. Your personal Contribution
counts!
Once again, this year I've got a terrific line up of free gifts to go along with
the various Contribution levels. Most all of these gifts have been provided
by some of the vary members and vendors that you'll find on Matronics Lists and
have been either donated or provided at substantially discounted rates.
This year, these generous people include Bob Nuckolls of the AeroElectric Connection (http://www.aeroelectric.com/), Andy Gold of the Builder's Bookstore (http://www.buildersbooks.com/), and Jon Croke of HomebuiltHELP (http://www.homebuilthelp.com/).
These are extremely generous guys and I encourage you to visit their respective
web sites. Each one offers a unique and very useful aviation-related product
line. I would like publicly to thank Bob, Andy, and Jon for their generous support
of the Lists again this year!!
You can make your List Contribution using any one of three secure methods this
year including using a credit card, PayPal, or by personal check. All three methods
afford you the opportunity to select one of this year's free gifts with
a qualifying Contribution amount!!
To make your Contribution, please visit the secure site below:
I would like to thank everyone in advance for their generous financial AND moral
support over the years!
Subject: | November List Fund Raiser |
A couple of years ago I implemented an automatic "squelch button" of sorts for
the Fund Raiser messages. Here's how it works... As soon as a List member makes
a Contribution through the Matronics Fund Raiser web site, he or she will
instantly cease to receive these Fund Raiser messages for the rest of the month!
Its just that simple. Don't you wish PBS worked that way! :-)
I really do appreciate each and every one of your individual Contributions to support
the Lists. It is your support that enables me to upgrade the hardware
and software that are required to run a List Site such as this one. It also goes
to pay for the commercial-grade Internet connection and to pay the huge electric
bill to keep the computer gear running and the air conditioner powered
on. I run all of the Matronics Email List and Forums sites here locally which
allows me to control and monitor every aspect of the system for the utmost in
reliably and performance.
Your personal Contribution matters because, when combined with other Listers such
as yourself, it pays the bills to keep this site up and running. I accept
exactly ZERO advertising dollars for the Matronics Lists sites. I can't stand
the pop-up ads and all other commercials that are so prevalent on the Internet
these days and I particularly don't want to have it on my Email List sites.
If you appreciate the ad-free, grass-roots, down-home feel of the Matronics Email
Lists, please make a Contribution to keep it that way!!
Thank you!
[Note that there are certain circumstances where you might still see a Contribution
related message. For example, if someone replies to one of the messages,
when using the List Browse feature, or when accessing List message via the Forum.
The system keys on the given email address and since most of these are anonymous
public access methods, there is no simple way to filter them.]
Dear Listers,
Just a quick reminder that November is the annual List Fund Raiser. The Matronics
Lists are 100% member supported and all of the operational costs are provided
for my your Contributions during this time of the year.
Your personal Contribution makes a difference and keeps all of the Matronics Email
Lists and Forums completely ad-free.
Please make your Contribution today to keep these services up and running!
Thank you in advance!
Matronics Email List and Forum Administrator
Subject: | Please Make A Contribution To Support Your Lists |
Dear Listers,
There is no advertising income to support the Matronics Email Lists and Forums.
The operation is supported 100% by your personal Contributions during the November
Fund
Raiser.
Please make your Contribution today to support the continued operation and upgrade
of these services. You can pick up a really nice gift for making your Contribution
too!
You may use a Credit Card or Paypal at the Matronics Contribution Site here:
or, you can send a personal check to the following address:
Matronics / Matt Dralle
PO Box 347
Livermore, CA 94551-0347
Thank you in advance for your generous support!
Subject: | Fund Raiser List of Contributors - Please Make A Contribution |
Today!
Each year at the end of the List Fund Raiser, I post a message acknowledging everyone
that so generously made a Contribution to support the Lists. Its my way
of publicly thanking everyone that took a minute to show their appreciation for
the Lists.
Won't you take a moment and assure that your name is on that List of Contributors
(LOC)? As a number of members have pointed out over the years, the List seems
at least - if not a whole lot more - valuable as a building/flying/recreating/entertainment
tool as your typical magazine subscription!
Please take minute and assure that your name is on this year's LOC! Show others
that you appreciate the Lists. Making a Contribution to support the Lists is
fast and easy using your Credit card or Paypal on the Secure Web Site:
or by dropping a personal check in the mail to:
Matt Dralle / Matronics
PO Box 347
Livermore CA 94551-0347
I would like to thank everyone that has so generously made a Contribution thus
far in this year's List Fund Raiser! Remember that its YOUR support that keeps
these Lists going and improving! Don't forget to include a little comment about
how the Lists have helped you!
Best regards,
Subject: | List Fund Raiser |
Dear Listers,
Just a reminder that November is the Matronics Email List Fund Raiser month. There
are some very nice incentive gifts to choose from as well!
Please make your Contribution today:
Thank you!
Subject: | Some Very Nice Comments... |
Dear Listers,
I've been getting some really nice comments from Listers along with their List
Support Contributions. I've shared some of them below. Please read them over
and see what your fellow Listers think of the Lists and Forums.
Please make a Contribution today to support the continued upgrade and operation
of these services.
There are lots of sweet gifts available, so browse the extensive selection and
pickup a nice item along with your qualifying Contribution.
Thank you in advance for your generous support! It is very much appreciated!
Best regards,
----------- What Listers Are Saying About The Lists -----------
Few things in life bring more usefulness than the List. This
is worth every penny!
Stephen T.
I have enjoyed the list for way too many years, but continue
to get closer to flying my project with the help of listers.
C.L.
Thanks for this List. It's been a great source of encouragement
and information.
Arden A.
Great service!
Gerald T.
It's always interesting reading the lists and I've gotten some
good help from the issues and answers there.
Steve T.
Been a member of the List for 12 years. Keep up the good work.
John H.
Great Site!
Harry M.
Great source of information...
Martin H.
Thanks for providing this great service!
Jeff P.
I continue to get and give information through these lists.
Ralph C.
This is a wonderful resource!
Warren H.
This is what inernet was meant for, sharing information and
experience. Michael W.
Thanks for making such a good list!
Fred D.
Thanks for running a great service!
Michael F.
I really appreciate it.
Dan H.
Thanks for the great service.
Michael L.
Thanks for maintaining this great resource.
John C.
Your sites have been a great resourses and an introduction
to many competent aircraft designers and fabricators.
Jon M.
Thanks for all that you do to maintain the Matronics forums
and for the personal help that you have been to me in
answering my questions regarding the use of the forums.
William B.
[The List] helped me get flying, fly off my test hours and
make my systems better. Ralph C.
The Universe is a better place because of you.
Eric J.
From: | "lucaslendies" <lucaslendies(at)sify.com> |
R4 Game Card
If you have a Nintendo DS or Nintendo DS Lite, you will definitely need the R4
Card. Why? The R4 Game Card enhances the power of your Nintendo device and enables
you to enjoy games even better.
With the R4 Game Card, you have considerable storage space, so much so that you
can use it to browse pictures, watch movies, enjoy listening to your favorite
audio files, read E-Books and much more. The R4 Card has the standard FAT system
and you can use it with a host of micro SD cards. It supports different speed
levels for the many types of micro SD cards that you use with your Nintendo
DS or Nintendo DS Lite device.
http://forums.matronics.com/viewtopic.php?p=272645#272645
Subject: | Contributions Down By 21%... |
Dear Listers,
As of today, contributions to the Matronics List Fund Raiser are lagging behind
last year at this time by 21%. I have a fund raiser each year simply to cover
my operating costs for the Lists. I *do not* accept any advertising income
to support the Lists and rely solely on the contributions of members to keep the
expenses paid.
I run all of my own servers and they are housed here locally, and the Internet
connection is a commercial-grade, T1 connection with public address space. I
also maintain a full backup system that does nightly backups of all List-related
data so that in the event of a server crash or worse, all of the Lists and
the many years of List archive data could be restored onto a new server in a matter
of hours.
All of this costs a fair amount of money, not to mention a significant amount of
my personal time as well. I have a Fund Raiser each year to cover these costs
and I ask that members that feel they receive a benefit from my investments,
make a modest contribution each year to support the continued operation and
upgrade of these services.
If you enjoy the Lists, please make a contribution today. I also offer some incentive
gifts for larger contribution levels. At the Contribution Web Wite, you
can use a credit card, Paypal, or personal check to show your support for the
continuation of these services:
Thank you for your support!
Subject: | What's My Contribution Used For? |
Dear Listers,
Some have asked, "What's my Contribution used for?" and that's a good question.
Here are just a few examples of what your direct List support enables. It provides
for the very expensive, commercial-grade T1 Internet connection used on
the List insuring maximum performance and minimal contention when accessing List
services. It pays for the regular system hardware and software upgrades enabling
the highest performance possible for services such as the Archive Search
Engine, List Browser, and Forums. It pays for narly 20 years (yeah, I really
said *20* years) worth of online archive data available for instant random search
and access. And, it offsets the many hours spent writing, developing, and
maintaining the custom applications that power this List Service such as the List
Browse, Search Engine, Forums, and Wiki.
But most importantly, your List Contribution enables a forum where you and your
peers can communicate freely in an environment that is free from moderation,
censorship, advertising, commercialism, SPAM, and computer viruses. How many places
on the Internet can you make all those statements these days?
It is YOUR CONTRIBUTION that directly enables these many aspects of these valuable
List services. Please support it today with your List Contribution. Its one
of the best investments you can make in your Sport...
List Contribution Web Site:
Email List Administrator
Subject: | Just A Few Days Left; Still Trailing Last Year... |
Dear Listers,
There are just a few more days left of this year's List Fund Raiser! Response
has been very good, but still well behind last year. If you've been waiting until
the last minute to make your contribution and maybe even pick up a great
gift, now might be good time to show your support!
Please remember that there isn't any sort of commercial advertising on the Lists
and the *only* means of keeping these Lists running is through your Contributions
during this Fund Raiser.
Please make a Contribution today!
Thank you!
Subject: | Make Sure You're Listed! List of Contributors Published |
in December!
Dear Listers,
The List of Contributors (LOC) is just around the corner! In December I post a
list of everyone that so generously made a Contribution to support the Lists.
Its my way of publicly thanking everyone that took a minute to show their appreciation
for the Lists.
Won't you take minute and assure that your name is on the upcoming LOC? Tell others
is fast and easy using your Visa, MasterCard, or Paypal account:
Or, by dropping a personal check in the mail to:
PO Box 347
USA
(Please include your email address on the check!)
far during this year's List Fund Raiser! Remember that its YOUR support that keeps
these Lists running and improving! Don't forget to include a little comment
about how the Lists have helped you!
Thank you!
Subject: | Just A Few More Days To Make Your List Contribution... |
There is less than a week left in this year's List Fund Raiser and only a few short
days to grab one of the great Contribution Gifts available this year. Support
is still significantly lagging behind last year at this point but hopefully
it will pick up here towards the end. Please remember that it is solely the
Contributions of List members that keeps the Lists up and running as there
is no commercialism or advertising on the Matronics Lists and Forums.
The List Contribution web site is secure, fast, and easy and you can use a credit
card, Paypal, or a personal check:
I want to thank everyone that has already made a generous contribution to support
the Lists!
Thank you!
Matronics EMail List and Forum Administrator
Subject: | What Are You Thankful For...? |
Dear Listers,
Here in the United States, Thursday is our National day of Thanksgiving. Many
of us will be traveling to be with our families and friends to share in generous
feasts of plenty and giving thanks for many blessings that have been bestowed
upon us.
Many Listers have expressed over the last couple of weeks how thankful they are
for the Email Lists and Forums here on the Matronics servers and for all of the
assistance and comradery they have experienced being a part of the Lists.
One of my favorite comments is when someone writes to me and says something like,
"Its the first thing I do in the morning while I'm having my morning coffee!".
That's a wonderful tribute to the purpose and function of these Lists.
Its always great to hear I'm not the only one that jumps out of bed each morning
to check my List email!!
Won't you take a minute today and show your appreciation for these Lists and for
their continued operation and upgrade?
The List Contribution Site is:
Thank you in advance for your kind consideration,
Subject: | No "Black Friday" For List Fund Raiser... |
Even though the number of List subscriptions and List posts are up significantly
this year compared to last year, support during this year's List Fund Raiser
has been woefully lagging from last year. There are only a couple more days
left in November and the end of the Fund Raiser is quickly approaching.
I have always preferred a non-commercial List experience as many, many members
have also expressed that they do as well. However, if the yearly fund raiser
cannot generate sufficient funds to keep the bills paid on the List service expenses,
I will have to look into some sort of advertising. Please don't let that
happen!
Your personal contribution of $20 or $30 goes a long ways to keeping the operation
a float. The lunch combo at Carl's Jr costs nearly $10 these days. Isn't
the List worth at least as much as a couple of burgers?
Please make sure your name is on this year's List of Contributors published in
December. The Contribution site is secure, quick, and easy:
Thank you in advance for your support!
Subject: | Just Two More Days Left; Fund Raiser Behind By 12%... |
Dear Listers,
This year's List Fund Raiser is still trailing last year by a 12% margin. If you
like the ad-free environment that is the Matronics Email List and Forum experience,
please make a quick Contribution to keep it that way!
I've been getting a ton of really nice comments from Contributors regarding the
Lists. Please read over some of them below and see if they don't resonate with
you as well.
Thank you in advance for your generous contribution to support these Lists!
--------------------------- Member Feedback ----------------------------
ur web site is a real institution of the whole Experimental
Aircraft subculture.
John G
Thanks Matt for the lists. A lot of good info. Great bunch
of list members. Great videos and no SPAM.
Paul C
It has been a valuable tool.
Troy M
..appreciate the site as much as ever.
Larry M
By using various forums I've learned a ton, received great
advice, made friends, and saved money!
Craig W
Since I've finished [my project], I've not had much to do as
far as fabrication of electrical systems. However,
selectively reading various topics is still very valuable
and Bob's insights and new how to's make me a continuous
subscriber.
Larry F
Matronics user groups are the best tool I have for learning
to build my RV-10!
Philip W
There is always useful knowledge to be found on this list,
and I suspect that it has kept quite a few people out of
trouble over the years it has been in operation. Good
entertainment, too.
Graham H
Great web site. I wish I'd known about it while building.
Bob S
I'm happy to provide some support to this list. It is very
helpful.
Vaughn T
Good service to sport aviation!!
Roger B
Awesome Service you provide for us!
Bill R
My [project] is almost finished! However, it wouldn't be
close without the [this] group.
Douwe B
Great list.
Robert S
I'm not a builder yet but learning lots from the list.
Peter M
Some nonsense, some humor, but mostly good information.
Tony C
Thanks for creating and keeping the Lists. They are
entertaining and always informative!
John M
Thanks for this valuable resource to our community.
Barry H
The list is IMHO the greatest resource on the net.
John B
Thanks again for providing another year of your useful
List service.
Jerry B
Great site indeed, every time I get a message I usually
learn something.
Peter B
You are making a huge contribution to the builder fraternity
and in no small way enhancing sport aviation safety.
Richard G
The List is the SINGLE, MOST IMPORTANT resource I have in
building my RV10. I would be lost without out it. And I
have made a bunch of new friends as well!
Les K
The lists are one of the things I really enjoy, so keep
up the good work.
Freddie H
Every year -- the best value for my time and money!
Owen B
This list is a major contribution to safe building!
Donald K
Really enjoy the daily boost it gives me.
Walter S
In the last 18 months I have been privileged to listen &
ask. I have learnt at the feet of the masters...
Stewart G
You set the standard on how Internet forums should be run
and managed.
Larry W
Eric J
make my systems better. I continue to get and give
Ralph C
..another GREAT year of advice, answers, and inspiration
courtesy of the Lists and your hard work!!!!
Rob B
..the best forum on the Internet!
Robert B
I can't tell you how grateful I am for your list and your
subscribers to keep me up to date and holding the dream.
Ashley M
This page makes it easy to contribute.
Jeffrey P
Thank you for your expertise in creating & running the
much useful lists!
Anthony P
Thanks for providing our advertising free on line community.
George R
Thanks for maintaining the equipment and software to
provide this valuable source of information to us
individuals. Your effort is appreciated by many more people
than you realize.
Ross H
Thanks for a great site. Although the project is complete
and flying I still get a wealth of information from all
the messages.
Marcus C
Only learned about you six months ago...my RV-7A is just
finished, but the list has been helpful. Wish I had
discovered you sooner.
Jack B
This is an invaluable communications media for us
June 09, 2005 - November 30, 2009
Aerobatic-Archive.digest.vol-ad
