Avionics-Archive.digest.vol-ab
November 24, 1999 - December 28, 1999
On 24 Nov, To: avionics-list(at)matronics.com wrote:
> I know there are chips available, looks like some pretty nice stuff
> actually; I was just wondering if there were SBC's around that used
> those chips or if we'd have to make our own hardware right from the
> start.
To answer my own question:
http://www.emicros.com/cantec11.htm
http://www.lawicel.com/e_c505cbbf.htm
http://www.phytec.com/USAmerica/Mm515.html spend some time looking
around this site, they got
some cute little cards
http://www.arcom.co.uk/products/icp/pc104/modules/AIMcan1.htm
-Dave
From: | Livingston John W Civ ASC/ENFD <John.Livingston(at)wpafb.af.mil> |
Subject: | AGATE Databus update |
All,
I have talked to Walter Green (NASA/AGATE) about their AGATE DATAbus. It
is based on Echelon's Lon Bus. (oh great, another bus). Walter said it is
much faster ( 10 vs 1mps?) than CAN and cheaper. Here is what I have so
far...
Walter S. Green, Leader, Flight Systems Work Package
Advanced General Aviation Transport Experiment
Crew Vehicle Integration Branch. Tel. 1+757+864-3355
Mail Stop 152 Fax. 1+757+864-7793
Building 1268A, Room 1170,
NASA Langley Research Center, Hampton, VA 23681
-----Original Message-----
Date: Wednesday, November 24, 1999 8:53 AM
Subject: Re: Avionics Databus Architecture
Walt Green has asked me to provide you with some information on the AGATE
Databus. AGATE is an industry government consortium that was initially
chartered with the goals of reviving general aviation and then as is now to
create a Small Aircraft Transportation System. The AGATE portion was
heavily technology based. As a part of the development of required
technologies, the Databus was identified as an essential element. Over the
last few years, many databuses have been evaluated, including CAN. As a
result of these reviews, Echelon's Lon Bus was selected.
The Lon bus is a multidrop, CSMA CD bus or translated has an open topology
with Carrier Sense Multiple Access bus and Collision Detection. There are
many features of the bus which are desirable including a very low cost --
approximately $1-2 per node and approx $6-8 with a microprocessor. The
protocol is a fully defined 7 layer OSI compliant protocol. This provides
for greater interoperability and commonly defined data packets. Further
AGATE has developed software which will maintain the databus database
packets and generate the required C code when the element is selected as
well as provide other programming and architectural aids. The bus may be
used for most sensors and controls including FADEC and control surfaces with
a deterministic version.
If you would like more information, I would suggest that you attend the
session in Hampton on December 8th, 1999 at the Raddison Hotel.
Regards, JKM
James K. Meer,
Principal
Microflight
----- Original Message -----
Sent: Tuesday, November 23, 1999 11:07 AM
Subject: Fw: Avionics Databus Architecture
From: John W. Livingston <john.livingston@ascxp/wpafb.af.mil>
Date: Tuesday, November 23, 1999 10:15 AM
Subject: Avionics Databus Architecture
>I am part of a sport aviation group trying to develop standards for
>advanced avionics. Our aim is to reduce cost, improve performance and
>allow for easy expansion of avionics systems . Our efforts have led us
>to focus on the various databus architectures, particularly CAN, DoD's
>CDA 101 and NMEA2000. I noticed your upcoming meeting to discuss the
>same. Can I get your thoughts on where AGATE currently stands on this?
>What are the current existing standards that you are looking at.
>John W Livingston
>Senior Design Engineer
>USAF ASC/ENFD
Subject: | Re: The CAN Bus Architiecture, Software and Softwa |
re
Dave
>> In another vain, I found a Web sight that has JAVA on a
>> microcontroller chip.
>With a CAN interface? Either way could you send me the URL? Thanks.
http://members.xoom.com/_XMCM/simpleRTJ/home.html
From: | Marlin Mixon <myshkin(at)worldnet.att.net> |
Subject: | Getting back to the bus |
Any further thoughts, anyone, on bus architecture?
I started to muck around in the bowels of "The kvaser CDA101 specs" to
see if
there were any details about CAN that were deal killers as far as
avionics are concerned. One thing I'm sure of--military documentation
sucks! (Though the CDA101 documents aren't too loaded with jargon and
"see obscure reference XYZ"
I also wanted to grease the wheels by pre-interpreting the documentation
a little bit so that it might help those of you who know more than I
about embedded systems and interfaces.
Here's a table of documents available at CANKing
( http://www.kvaser.com/archive/cda_specs/ )
Each of the following lines preceded by a number is a zipped PDF
document
that can be downloaded from the above site.
Lower Level Specification
101/01 High-Level Specification
101/11 System Messages
101/12 D Parameter Definitions
101/21 P Controller Area Network
* 101/22 P MIL-STD-1553 Bridge
* 101/23 P UDP/IP Bridge
* 101/24 P RS-232/422 Bridge
101/25 P Radio Frequency Transponder Bridge
101/26 P Routers
101/31 D Seaborne Target Systems
101/32 D Ground Vehicle Target Systems
101/33 D Sub-scale Aerial Target Systems
101/34 D Full-scale Aerial Target Systems
101/35 Rotary Wing Target Systems
101/41 D Common Controllers, Sensors, and Actuators
101/42 D Target System Augmentation
P = Physical Layer Specifications
D = Data Specifications
* = Apparently not available
Marlin Mixon
Subject: | What about the Echelon Bus? |
Refresher from John Livingston:
is much faster ( 10 vs 1mps?) than CAN and cheaper.
I went to the http://www.echelon.com/ page and found what appears to be
a wealth of information--I didn't dig too deeply into it. What makes
the Lon (ANSI/EIA 709.1) protocol cheap is it's consumer electronics
approach--Echelon has a "vision of pervasive networking" and wants to
put all your home appliances on a network including light switches, home
entertainment systems, ovens, telephones, doorlocks etc. The
high-volume mass-production of their chips would thus make them cheap.
One question I'd want to look into is "What premium will we pay for the
chips that can handle -50F"
In any case, there is a document called: The LonTalk Protocol, An Open
Standard for Controls. LonTalk is heavily patented by Echelon, but I'm
ASSUMING that the patents and associated royalties apply only to the
purchase of the chips that manage the protocol.
Here's a relevent quote from a press release:
The ANSI/EIA 709.1 protocol can be embedded into any processor, from
8-bit microcontrollers to 32-bit microprocessors. For cost-sensitive
applications, developers can use Neuron Chips, a family of
microcontrollers optimized for intelligent distributed control
applications that include a built-in, interoperable implementation of
ANSI/EIA 709.1. Neuron Chips are manufactured and distributed worldwide
by Cypress Semiconductor ( http://www.cypress.com ) and Toshiba
Corporation ( http://www.toshiba.com ).
One drawback that I DO see is that the ANSI document describing the
709.1 protocol is not free online. A guess on the cost is $60 to
download?
Marlin Mixon
Subject: | 1999 List of Contributors #1 and a Special Thank You Message!! |
Dear Listers,
I would like to personally thank each and everyone that has contributed
this year to 1999 List Fund Raiser! As you can see from the list of
names below, there were many, many generous people from the Lists this
time around and I want everyone to know just how much your support has
meant to me. The list of members below includes those that have
contributed during this year's List Fund Raiser as well as those that
have contributed throughout the year and also those that made a donation
to my Legal Defense Fund earlier in the year that was sponsored my our
own Bob Nuckolls of Aero Electric.
I want everyone to know just how much it means to me to receive the type
of financial support for these Lists that I have this year. As the Lists
have grown so much over the last few years, so have the equipment costs
as well as the monthly costs such as the Internet connectivity. Your
generosity during the Fund Raiser and throughout the year, truly makes
the continued operation, and more importantly, the continued upgrade and
improvement of these aviation-related services directly possible. That
is the bottom line. Please accept my most sincere appreciation of the
amazing and, at times, overwhelming generosity of so many of you
wonderful people! Thank you!!
For those of you that didn't quite get your contribution in on time for
this first List of Contributors - be it by check or by credit card - I
will be posting a followup List of Contributors #2 for 1999 in a few
weeks to make sure that I properly acknowledge each and everyone of the
generous List members. One last time, the addresses to make a contribution
are:
or
c/o Matronics
PO Box 347
Livermore, CA 94551
Finally, thank you all so much for your support this year both in terms
of the financial contribution but also in the form of the letters and
moral support during what can only be categorized as a very stressful and
unsettling time. And I think you know what I'm referring to... Your
support and encouragement meant more to me than you'll ever know. I felt
as if I had 2500 friends all behind me, and that's a *powerful* force!
Well done one and all! Thank you!
Best regards for the upcoming year.
Your Email List Administrator,
RV-4 Builder #1763
=================== 1999 List of Contributors #1 ====================
Abell, John
Acker, Rob
Adams, Bob
Adamson, Larry
Ahamer, Karl
Albachten, Rudy III
Alcazar, Jesus
Allen, Brent
Allison, Steven
Ammeter, John
Amundsen, Blair
Anderson, Edward
Armstrong, Robert
Arnold, James
Aronson, David
Ashford, James
Ashton, Kent
Atkinson, Harold
Baggett, Robert
Baker, Gary
Baker, Ray
Baldwin, James
Barlow, Melvin
Barnes, Thomas
Barnes, Tom
Barnhart, Dave
Barrenechea, Godo
Battles, Brenton
BB Diversified Services, LTD
Bechtel, Amos
Bell, Bruce
Belted Air Power LTD.
Benhan, Dallas
Bennett, Peter
Besing, Paul
Bieber, Mike
Bilodeau, Paul
Bird, Carroll
Blanton, Stan
Bleier, Roger
Blomgren, Jack
Blum, Ronald
Boadright, Kyle
Boardman, Don III
Boatright, Kyle
Boatright, Robert
Bodie, Pete
Bonesteel, Wayne
Booze, Gregory
Borne, Charles
Bourgeois, Rion
Bourne, Larry
Bovan Pe, Vaso
Bowen, Larry
Bowen, Miles
Bower, Bob
Bowhay, Eustace
Bowman, Brian R
Boyd, Rodney
Branscomb, Warren
Bray, Garrett
Brian Lloyd
Brick, John
Bridgham, David
Brogley, Mike
Brooks, Chris
Brooks, John
Brott, Marvin
Brown, Kent
Brown, Scott
Buckwalter, David - Avionics Systems
Burlingame, Ralph
Burnham, Dave
Calhoun, Ronald
Calvert, Jerry
Cantrell, Ken
Capen, Ralph
Cardinal, Gregory
Carey, Christopher
Carr, David
Carter, Jerry
Carter, Ron
Casey, Jeremy
Chapple, Glen
Chesnut, Bruce
Chesnut, William
Christensen, Peter
Christie, William
Churchill, Frank
Ciolino, John
Clabots, Gerald
Clark, Howard
Clark, James
Clary, Buck
Clay, Dennis
Cloughley, Bill
Cole, Ed
Colontonio, Moe
Colucci, Anthoney
Conaway, James
Cook, David Sr.
Cooley, John
Copeland, Forrest
Corder, Michael
Corriveau, Grant
Cotter, Timothy
Cox, Carson
Croby, Harry
Crosley, Richard
Cullen, Chuck
Czinkota, Garnet
Dall, Richard
Daudt, Larry
Davidson, Jeff
Davis, Christopher
Davis, Jared
Davis, Steve - The Panel Pilot
Davis, William
Day, Robert
Deffner, David
Del Peso, Jose
Derrik, Chuck
Desmond, Richard
Devine, Steven
Devlin, John
Dewees, Ron
Dial, J.R.
Dominey, Clifford
Dorsey, Bob
Downing, Jeff
Dubroc, Tommy
Dudley, Richard
Duffy, Russell
Duncan, John
Dunlap, E.T.
Dziewiontkoski, Bob
Eagleston, Ron
Eagleston, Ronald
Eastburn, James
Elder, William
Elhai, Irv
Emrath, Marty
Ensing, Dale
Ervin, Thomas
Erwin, Chip - Czech Aircraft Works
Evans, Monte
Exstrom, Daniel
Faile, David
Farrar, Jeffrey
Farris, Paul
Fetzer, George
Fiedler, Mike
Filucci, Michael - Red Dragon Aviaion
Finch, K
Flaherty, Edward
Floyd, Joseph
Ford, David
Forrest, Gerald
Forsting, Robert
Fortner, Earl
Four Star Products
Frank, Dan
Franz, Carl
Frazier, Vince
Frederick, Mark
French, Edwin
Friedman, Frank
Froehlich, Carl
Fromm, John
Fry, John
Funk, Edwin Jr.
Funnell, Augustus
George, William
Gilbert, Mark
Giusti, Roberto
Glaser, Arthur
Glass, Roy
Glover, Ken
Gold, Andy - Builder's Book Store
Goldberg, Mark
Good, Chris
Gooding, Lawrence
Goolsby, Jim
Gott, Shelby
Goudreault, Jacques
Graham, James Jr.
Grant, Jordan
Griffin, Bill
Griffin, Randy
Groom, Larry
Guillosso, Alain
Hale, Michael
Hales, Sherman
Hall, Bob
Hall, Thomas
Hamer, Steven
Hamilton, Thom
Hamilton, William
Hand, Chris
Hansen, Ronald
Hargis, Merle
Harmon, John
Harper, Malcom
Harrill, Roy
Harris, John
Hart, Daniel
Harvey, Doug
Hassall, J.C.
Hastedt, Margaret
Hatch, Fletcher III
Hatcher, Clive
Hatfield, Cecil
Hays, Wes
Henderson, George
Henderson, Randall
Heritch, Ian
Herndon, Richard
Herren, Bill
Hevern, Jerry
Hiatt, Mark
Hiers, Craig
Hinch, Christopher
Hine, Joe
Hinkley, Curtis
Hinrichsen, James
Hodge, Jack
Hodgson, Bob
Hodson, Frank
Hoffman, Carl
Holcombe, Richard
Horton, Kevin
Hoshowski, Ken
Hrycauk, Dave
Hughes, Robert
Hulen, Fred
Hundley, Richard
Hurd, James
Hurlbut, Steve
Hutcheson, Ken
Ihlenburg, Fred
Ingram, Jim
Irace, Bill
Irwin, Eric
Isler, Jerry
Ivers, James
James, Larry
Janes, Bob
Janicki, Steven
Japundza, Bob
Jeens, Ken
Johannsson, Johann
Johnson, Jackie
Johnson, Stephen
Jones, Bryan
Jones, Rob
Jones, Russ
Jonker, Bill
Jordan, Thomas
Jory, Rick
Kampthorne, Hal
Kayner, Dennis
Keithley, Rick
King, Da Ve
Kirby, Dennis
Kirby, Graham
Kirtland, Charles
Kitz, John
Knezacek, Dan
Knievel, Gerald
Knoll, Bruce
Kosta, Michael
Kowalski, Ed
Krueger, Dan
Krueger, Scott
Kuss, Charlie
Laczko, Frank Sr.
Lamb, Richard
Lane, Kevin
Lassen, Finn
Laurence, Peter
Laverty, Mike
Lawson, John
Leaf, Dave
Lee, John
Lee, Ric
LeGare, Garry
Leggette, Len
Leonard, William
Lerohl, Gaylen
Lervold, Randy
Lewis, Terry
Lewis, Tim
Ligon, Howard
Lind, Laird
Linebaugh, Jeffrey
Loeber, Wayne
Ludeman, Bruce
Lutes, Rick
Mac Donald, Lawrence
MacKay, Alex
Malczynski, Francis
Mandell, Tom
Marino, Anthony
Marion, Chris
Markert, Michael
Marshall, Robert
Martin, Tom
Maxson, Phil
Mazatuad, Mme Hyun Sook
McElhoe, Bruce
McFarlane, Lloyd
McGee, Michael
McHarry, Joe
McHenry, Tedd
McKibben, Gerald
McNamara, Don
Melder, Frank
Melia, Tom
Metzger, Stephen
Meyers, John
Miller, Jim & Dondi - Aircraft Technical Support
Mitchell, Duane
Moen, Craig
Mojzisik, Allan
Molzen, Jason
Mondy, Malia
Moore, Thomas
Moore, Warren
Morelli, Bill
Morelli, William
Morris, Daniel III
Morrison, Mark
Morrow, Dan
Moulin, Roger
Munn, Mike
Murphy, Ray Jr.
Neal, Danny
Nellis, Michael
Nelson, James
Nelson, Jim
Newell, Alan
Nguyen, Thomas
Nice, James
Nicely, Vincent
Norris, Rob
Nowakowski, Donald
Noyer, Robert
Nuckolls, Robert
Olendorf, Scott
Olson, Larry
Olson, Tom
Orear, Jeffrey
Owens, Laird
Palinkas, Gary
Pardue, Larry
Paulson, Craig
Peck, Bill & Kathy
Peer, Michael - Jem Aviation
Peryk, Dennis
Peternel, Stanley
Petersen, Eric
Petersen, Paul
Peterson, Alex
Pflanzer, Randy
Phillips, Mark
Pickrell, Jim
Pike, Richard
Pinneo, George
Pittenger, Dick
Plathey, Claude
Point, Jeff
Polstra, Philip
Porter, Richard
Porter, Robert
Potter, Mark
Pretzsch, Robert
Ragsdale, Bill
Randolph, George
Ransom, Ben
Rathbun, Richard
Reeck, Jay
Reed, Derek
Reed, Frank
Reisdorfer, Mark
Reynolds, Richard
Richardson, Ray - Powersport Aviation Inc.
Riedlinger, Paul
Riley, Stuart
Roach, Brian
Rodgers, Brian
Rosales, Paul
Rowbotham, Charles
Rowles, Les
Rozendaal, Doug
Rutherford, Ted
Sa, Carlos
Sager, Jim
Sailer, Martin
SanClemente, Andrew
Sapp, Doug
Sargent, Tom
Sax, Samuel
Schemmel, Grant
Schippers, John
Schmitt, Clayton
Schneeflock, Robert
Schrimmer, Mark
Schwarz, Guillermo
Selby, Jim - JKL Aviation Sales
Seward, Douglas
Shackleford, Howard
Shafer, Jim
Shank, Bill
Sheets, Douglas
Shenk, Doug
Shepherd, Dallas
Shettel, Maurice
Shipley, Walter
Sigmon, Harvey
Silverstein, Chuck
Sipp, Dick
Slaughter, Mike
Small, Thomas
Smith, Clayton
Smith, Edmund
Smith, Philip
Smith, Shelby
Smithey, Lloyd
Snyder, David
Solecki, John
Sparks, Timothy
Stafford, David
Staub, Skip
Steer, Bill
Stobbe, Bruce
Stoffers, Larry
Stone, James
Strandjord, Eric
Swaney, Mark
Tauch, Eric
Tauchen, Bryan
Taylor, Tod
Team Rocket
Thayer, George
Therrien, Michel
Thistelthwaite, Geoffrey
Thoman, Daniel
Thomas, Lee
Thomas, Tim
Thompson, Michael
Todd, John
Tompkins, Jeff
Tower, John
True, George
Tucker, Harold
Tuton, Beauford
Tyrrel, Charles
Upshur, Bill
Uribe, Guillermo
Uribe, Gullermo
Utterback, Thomas
Van Der Sanden, Gert
Vandervort, Ronald
VanGrunsven, Stanley
Varnes, William
Volum, Peter
Von Ruden, Dennis
VonLindern, Paul
Vosberg, Roy
Waligroski, Gregg
Walker, Tommy
Walrath, Howard
Ward, Ed
Warren, John
Washburn, Oliver
Watson, Dennis
Watson, Terrence
Watson, William
Webb, Randol
Weber, Ed
Weber, Edward
Weller, Michael
Wendel, Jim
Wentzell, David
Werner, Russ
Werner, Russell
Westridge, David
Whelan, Thomas
Whiler, Douglas
Whitehead, Arthur
Wiesel, Dan
Wigney, John
Williams, Jimmy
Williams, Keith
Williams, Lawrence
Willig, Louis
Wills, Mike
Wilson, Billy
Wittman, James
Wood, Denton
Wood, John
Wood, Mark
Worstell, Glen
Worthington, Victor
Wotring, Dale
Wymer, Gerald
Young, Charles
Young, Rollin
Youngblood, Barry
Zeidman, Richard
Zigaitis, Kestutis
Zinkham, Ralph
Zwart, Frank
Marlin, All,
I've been a little frustrated by my research into Echelon's LonTalk
databus and the fiber-optic media by Raytheon. It sounds good in many ways,
but I can't seem to find anything related to the availability and cost of
hardware or software. Echelon's site has got lots of PR and overview papers
etc, but when you try to find standards or other technical documents or
prices it comes up short. I get the feeling that Echelon has held this very
close(just there circle of developers) and is just now in the process of
opening it up. Also, details and availability of the redundant fiber-optic
technology from Raytheon is not on the net, just PR. I have not found
anything on frequencies greater than 1.25mbs for LonTalk.( the fiber-optic
media should be able to go much faster, but may be limited by the Neuron
chips. Has anyone found a site that sells these and gives a price? At this
stage of my research I have more questions than answers. I sure would like
to attend that Dec 9 AGATE databus meeting, but I can't swing it. How can
you have a low cost open architecture and standard when no one knows
anything about it. No one talks about it (except Echelon and one or two
others). No one has prices listed. The draft standards aren't available.
etc. Go figure. Maybe I've missed something. Can anyone give me a lead on
this?????
From: Marlin Mixon [mailto:myshkin(at)worldnet.att.net]
Sent: Thursday, December 02, 1999 1:13 AM
Subject: Avionics-List: What about the Echelon Bus?
download?
Marlin Mixon
Subject: | Re: Glass Cocokpit: Environmental concerns (was Echelon |
Bus)
>for the chips that can handle -50F"
I hadn't really thought about environmental concerns until I read that
line... My subconsious was thinking that "the system" would be in the
panel, so its environment would be the same as mine... in operation, the
environment would be reasonably moderate in temperature, humidity, etc.
But now the conscious kicks in... These devices will be located various
parts of the aircraft, and some will be subjected to pretty harsh
environments... high altitude winter flight will make most areas or the
plane pretty damn cold. And the engine sensor package will be in an area
which can get quite warm, particularly in the summer...
Hmmm... yet another thing to think about when designing/building this
thing.
Steve
steve@tzogon.com HAM Tech lic: N1YZJ http://www.tzogon.com
http://www.tzogon.com/~steve/glass_cockpit
http://www.tzogon.com/~steve/stolch801
It appears that controllers for and information about the CAN bus are readily
available, while the Lon bus is proprietary and currently does not have wide
support from multiple manufacturers.
With a bit of net surfing I found that I can order a CAN controller (or micro
with a
CAN controller built in) from multiple manufacturers, and transceivers for CAN;
and I suspect that in a very short time I could have a CAN bus working.
The situation for Lon looks much more hazy. My non-expert opinion, if I had to
vote today, would be to go with CAN.
cheers,
Glen.
> if I had to vote today, would be to go with CAN.
If we want to build something now, Lon doesn't look like an option.
However, if we design for CAN it really should be a pretty small
effort to move it over to any other bus that comes along later that
provides equal or greater functionality.
I'd say there's no reason not to move forward with what's available
now and build and experiment to our heart's content.
-Dave
Subject: | Re: Lon vs CAN (485?) |
I concur. Does anyone have any argument AGAINST deciding on the CAN bus
and moving on to the messaging component?
I have to admit, working with an open standard, and using your choice of
components availaible from multiple vendors in a competetive market does
sound like a good thing... :)
Incidentally, has the RS-485 been completely ruled out? Why/why not? It
seems like we just stopped talking about it...
Steve
I don't think it is completely ruled out but I think it is suboptimal
because RS-485 uses a standard character-at-a-time serial interface to the
computer. It is lowest common denominator but doing block-mode or packet
type data transfers is nontrivial.
If the CAN buss automates this process it is going to be easier to program
and less prone to bugs and failures.
Brian Lloyd
brian(at)lloyd.com
+1.530.676.6513
Subject: | Re: Glass Cocokpit: Environmental concerns (was |
Echelon Bus)
No reason not to put your engine sensor interface module behind the
firewall. That is where I located mine in my RV-4 (AFA AV-10) and then
just ran the sensor wires through the firewall. Even so, it is a good
idea not to exceed the environmental range on the components.
Brian Lloyd
brian(at)lloyd.com
+1.530.676.6513
>> not? It seems like we just stopped talking about it...
>to the computer. It is lowest common denominator but doing
>block-mode or packet type data transfers is nontrivial.
>program and less prone to bugs and failures.
I was thinking along these same lines... if the hardware of the CAN
controller "framed" the packets like an ethernet chip does, it would make
the system less error prone...
Steve
From: | Frank and Dorothy <frankvdh(at)ihug.co.nz> |
I don't think that data comms is going to be a bottleneck, so the fact
that RS-485 is suboptimal really isn't important.
There's no reason (apart from more work) why a packet-based RS-485 board
couldn't be built. I envisage something like an 8051 which would do all
the comms work and only interrupt the main CPU when it had a good
packet. This is more or less how Ethernet cards work.
Having said that, I think there would be a lot of work involved, for
very little gain over CAN.
And I agree with the earlier comments about LON -- it has been around
for several years without gaining major backing. I assume that's because
the system designers at major companies are leary of proprietary
standards.
People might also be interested in looking at Steve Eberhart's
Aerocomputer page at http://www.evansville.net/~newtech/ -- this stuff
is a summary of the rec.aviation.homebuilt glass cockpit discussions
some years ago.
Frank.
(Incidentally, feel free to put the mini-bio I posted up on your Web
page Steve)
Glen, All
I agree, but will continue to monitor and pass along anything I find about
the AGATE/LonTalk/Raytheon databus.
Subject: | Re: Glass Cocokpit: Environmental concerns (wa |
s Echelon Bus)
Steve, All,
I think I read where the auto industry stuff is good to -50.
From: Steven J. Devine [mailto:steve(at)tzogon.com]
Sent: Thursday, December 02, 1999 9:32 AM
Subject: Avionics-List: Re: Glass Cocokpit: Environmental concerns (was
Echelon Bus)
In addition to Brian's comments, I'd add that the access method CAN
has blows the doors off anything I've seen written for RS-485. CAN
isn't quite as ubiquitous as RS-485, but it appears to be available
enough.
-Dave
Subject: | What's our name? |
I guess most efforts like the one we are undertaking usually don't have
a name they call themselves, but I'd find it useful when grabbing
documents off the net if I could use a specific organization identifier.
I have been using: "Affiliation of Avionics Hombuilders on the
Internet", but it's kind of long and I can't consistently reproduce it.
What do you think? Should we name ourselves? Do we already have a
name?
If we DO come up with a name, I think it should not be a name that
anyone has commonly heard before--this is so if people are doing
searches on our organization on the internet, they can find us by
keyword without getting a bunch of false hits.
Marlin
Subject: | CAN employs an unusual "kingdom" metaphor |
Since it sounds like we're going to go with CAN, I started to study it.
I downloaded two documents from the archive:
101/11 (System messages) and 101/21 (Controller Area Network). In
101/11 I noticed CAN's unusual and pervasive kingdom metaphor.
I don't understand these terms yet, but here they are:
capital city
kings document *
kings pages *
city, cities
mayors document *
mayors pages *
* Clearly these are posessives, but the documentation doesn't
use the apostrophe "S"
CAN has has a sophisticated feature that enables it to load software
over the network. This and other complexities appear to me to be the
reason why the kingdom metaphor was chosen.
I think the reason why they use this kingdom metaphor is to objectize
the task of multiple designers working on the same project, but at the
same time each designer or team may work in their own compartmentalized
area. (Sounds potentially helpful to us.)
Although the metaphor is used in CAN documents dealing with the software
layer, I don't see it being used in the physical layer.
101/21 describes everything you need to know to cable up CAN, though it
does refer you to the NMEA 2000 spec.
Marlin Mixon
Subject: | Re: What's our name? |
Gee, I always call it "The Glass Cockpit Project" in my thinking!
For what it's worth, the Internet domain name "glasscockpitproject.com" is
available. "glasscockpit.com" is taken. www.glasscockpit.com takes me to a
web site that seems to be vacant.
-Matt
Date: Saturday, December 04, 1999 10:32 AM
Subject: Avionics-List: What's our name?
name?
Marlin
Me too.
However, I kind of like Steve Eberhart's "Aerocomputer".
Do we need a domain name? I personally don't think so.
Frank.
Me too... though we may want to add another word to distinguish ours, such
as Homebuilt Glass Cockpit Project, or some such. (or something more
imaginative if anyone can come up with something better)...
Or, come up with a name that also describes the architecture, bus, or some
such. That way people have some way of identifying compatible components...
>is available. "glasscockpit.com" is taken. www.glasscockpit.com takes
>me to a web site that seems to be vacant.
Hmmm... I *COULD* just add another virtual domain to my linux box... is it
worth it???
Steve
Steven J. Devine, President, Consultant, TZOGON Enterprises Incorporated
Subject: | CAN Implementations |
Hi all,
According to http://www.omegas.co.uk/CAN/implement.htm
there are several different modes of operations that you can use to
implement CAN.
One question that came up earlier was: do we want to use CAN 2.0A (11
bit identifier) or CAN 2.0B (29 bit identifier)? One respondent wanted
to defer that question to a CAN expert. Until we can chat with a CAN
expert, I have some ideas on the subject. 11 bits would give us, at the
most, 2048 different identifiers, whereas 29 bits would give us 529
billion.
Identifiers allow us to identify which module is sending or is to
receive a message. You can certainly develop a glass cockpit for a GA
airplane without exceeding the 2048, even if you placed Angle of Attack
pressure sensors (Motorolla MPX100s) with 1" spacing along the whole
leading edge of your wing top and bottom, you'd still only be using up
600-700 identifiers, but even then, you'd probably put all those sensors
on their own dedicated buss.
This, of course, assumes that we would be serially numbering/identifying
each module. When we DO that, it means that we need to keep track,
somehow, of all the modules that we've installed so far. It also means
that the main CPU needs to know what every ID does. What we have is a
configuration issue.
There is another approach: Develop a numbering scheme using 29 bit
identifiers that does two things: 1) uniquely identifies each module (so
you don't get any id conflicts) by a serial number and 2) Encodes the
function of the module, i.e. code 210 might mean upper AOA pressure
sensor, left wing and code 221 might mean lower AOA pressure sensor,
right wing. By identifying the module correctly, it can be integrated
into the net work sort of like "plug and play."
The drawbacks of the "Plug and Fly" approach are:
1. The longer identifiers reduce network capacity by a certain
percentage. CAN is limited to 1 Mbit/S for data PLUS network overhead.
We will probably want all the bandwidth we can get.
2. The Mice and Men problem: as much as we plan, we still can't
anticipate all possible configurations that people would want to
experiment with in an aircraft.
So my recommendation is to go with CAN 2.0A, and develop configuration
techniques that make it easy to set up the network.
Marlin Mixon
From: | "Chris Atkinson" <chris-atkinson(at)home.com> |
HI guys, you'll all probably start flamin' me for this, but who cares. I'm
going back to my original concepts...i.e. use pre-built hardware & software
components with minimal re-inventing-the-wheel. This thread has become way
too academic for me....the chances of making a real system any time soon
seems to be losing ground with every post. Anyways, I'm sure you're all
wonderful guys & great pilots...I apologize for the negativism. ...sincere
best wishes for your scheme. Over & out. Chris
Subject: | Re: CAN Implementations |
It might be that we'll have to go with CAN 2.0B anyway because I was
looking at MCU chips at Motorolla and all they seemed to offer were for
CAN 2.0B.
Marlin Mixon
Subject: | CAN Module board |
I'm interested in what you think about this board: 1) will it accept a
Motorola CAN chip? and 2) Can it be interfaced to the CAN bus? 3) Any
other solutions out there that are cheaper or less required
modifications out there?
This kit board is a simple board that the Seattle Robotics Society sells
for $60. It uses the 68HC12 chip. The reason why I'm interested in a
board that has as much power as this one does because one of my personal
goals for the GCP is to build an engine monitor. The 68HC12 has eight
A/D input channels that get you most of the way there (I will probably
have to put two of these on the bus in order to monitor all the analog
inputs that I want to monitor).
There's a circuit diagram and building instructions at:
http://www.nwlink.com/~kevinro/b32brd.pdf
Does anyone know if I could swap in a 68HC912BC32 Microcontroller (that
runs CAN 2.0B) in place of the 68HC912B32 (the MCU that comes with the
kit)?
The only interface that this board comes with is a TTL serial interface,
however, as you can see from the PC board diagram in the documentation,
theres a handy little breadboard off to the right allowing you to expand
it somewhat. Anyone know how hard it would be to interface CAN
properly? I know that some people are using Intel 82527 chips to
interface CAN to 68HC11 MCUs. Would that be feasible in this instance?
Marlin Mixon
>billion.
One of the things we have discovered in designing the Internet is that you
should give yourself a lot more room than you think you need. 29 bits
makes a lot more sense.
Dave and I have been tossing this back and forth for the last week in
private email. My take on this "problem" is that configuration is a
one-time issue, i.e. performed when a module or modules are installed on
the buss, and therefore is not a big problem.
Actually, it isn't quite that easy since you might want a module to source
more than one of a particular attribute from the same module. Engine
parameters like CHT and EGT come to mind here. As much as one might hate
it, this is where something like SNMP (simple network management protocol)
experience comes in handy. (FYI, Dave Bridgham is one of the world-wide
industry experts in network monitoring and managment, a skill that impinges
directly on our project.) Dave and I have been using a shorthand that
looks something like this:
engine1.CHT.1
engine1.CHT.2
engine2.EGT.1
engine2.oilp
Clearly we need to get a list of interesting attributes sooner rather than
later so that we can decide if they are repeated (indexed). From this we
can take a stab at how we want to partition up the 29 bits in attribute
identifier. Box ID is certainly one of the fields we want but how many
bits to allocate is not so clear.
If giving up 18 bits per message causes us heartburn, we have a serious
problem and need to be really rethinking the buss. The MIL-STD-1553
avionics buss is 1Mbps and the military is only just now starting to think
about upgrading it to 10Mbps. IMHO their buss traffic is likely to be a
lot greater than anything we are likely to find in any GA aircraft. Given
that I suspect rather strongly that 1Mbps is sufficient for our current and
future needs.
Right, so build in overkill. 29 bits is probably sufficient in that
respect. 11 bits is, IMHO, woefully inadequate.
Then we are in opposition. IMHO we cannot do things in a clean fashion
with only 11 bits and still have room for expansion.
Brian Lloyd Lucent Technologies
brian(at)lloyd.com 3461 Robin Lane, Suite 1
http://www.livingston.com Cameron Park, CA 95682
+1.530.676.6513 - voice +1.530.676.3442 - fax
Subject: | Re: CAN Implementations (A vs B, attributes) |
Concerning CAN 2.0A vs 2.0B... I agree with Brian on all points, and also
feel that the 29 bit resolution is the way to go.
However, I think that it would be best to simply decide that the group as
a whole approved of the use of the CAN bus (those who have an opinion),
regardless of which version for the time being. As we start to work on
our message and numbering scheme, our requirements will start to become
evident.
Again, we want to design something that can not only be used by this group
developing the standard, but also anyone down the road who may want to
benefit from our work. Things like multi-engine and such need to be
considered and incorporated...
So lets move on to the attribute list for the time being.
Steve
Subject: | aircraft attributes/parameters |
Dave and I went through this exercise a couple of years ago. I didn't hang
on to my original message so I will try to recreate it here where it can
live in the archives indefinitely.
In my shorthand below I will indicate with a period and a number after the
attribute name my guess as to how many instantiations we might have for a
given attribute. For example, my big radial engine has four rows of nine
cylinders leading me to want at least 36 instantiations of CHT and EGT per
engine. You know, if we determine that the largest index on a parameter is
something like 64, we can encode the 6-bit index right into the attribute
value. We need discussion on whether dedicating 6 of our 29 attribute ID
bits to an index is sensible.
Attributes:
Airframe:
pitch position
roll position
pitch rate
roll rate
yaw rate
magnetic heading (this is yaw position)
true heading
pressure altitude
absolute altitude
true altitude
IAS
dynamic pressure (this is pitot absolute pressure)
OAT
Angle of attack
cabin pressure
cabin rate-of-climb
elevator position.2
rudder position.2 (the "Connie" has three rudders so is 2 enough?)
aileron position.4 (accommodate biplanes?)
flap position.4 (L&R, inner and outer flaps)
spoiler position.8
slat position.4
landing gear position.8 (multiple trucks?)
door status.8
brake system pressure.4
brake temperature.8
fuel tank float position.16
fuel quantity.16
hydraulic system pressure.4
hydraulic fluid quantity.4
hydraulic fluid temperature.4
pneumatic system pressure.4
DC electrical buss voltage.4
DC electrical buss current.4
AC electrical buss voltage.4
AC electrical buss current.4
alternator/generator load.4
buss cross-connect state.8 (this is a placeholder -- need discussion)
Universal engine attributes:
prop/PTO RPM
torque
oil pressure
oil inlet temperature
oil outlet temperature
fuel flow
fuel pressure
"chip" status
fuel source (which tank is feeding the engine)
Recip engine attributes:
crankshaft RPM
crankshaft position (I am reaching here)
mag/ignition timing.8
CHT.64
EGT.64
TIT.2 (is there anything with more than 2 turbochargers?)
MAP
upper deck absolute pressure
induction air temp
turbocharger RPM.2
Turbine engine attributes: (I need help here)
gas generator RPM
N.4 (interstage pressures as I recall)
Avionics and navigation attributes:
comm frequency.4
comm xmit state.4
comm audio level.4
nav freq.4
nav obs.4
nav valid.4
nav mode.4 (localizer vs VOR)
nav radial.4
nav CDI.4
nav to/from.4
nav ID.4
nav audio level.4
GS freq.2
GS CDI.2
GS valid.2
DME freq.4
DME distance.4
DME speed.4
DME ID.4
DME audio level.4
ADF freq.2
ADF bearing.2
ADF valid.2
ADF ID.2
ADF audio level.2
(should nav, ADF, and DME be combined for TACAN?)
TACAN frequency.2
TACAN bearing.2
TACAN distance.2
TACAN speed.2
TACAN valid.2
TACAN audio level.2
XPDR mode.2 (off, stby, mode-A, mode-C, ???)
XPDR squawk.2
XPDR reply.2 (do we want to dump this on the buss?)
LORANC GRI.2 (would you ever have more than two LORANC receivers?)
LORANC lat/lon.2
LORANC course/track.2
LORANC groundspeed.2
LORANC station valid/blink.64 (how many LORANC stations are there?)
GPS lat/lon.2
GPS altitude.2
GPS course/track.2
GPS groundspeed.2
GPS pitch.2
GPS roll.2
GPS yaw.2
GPS pitch rate.2
GPS roll rate.2
GPS yaw rate.2
(the following are generated by the appropriate devices in a repetitive
manner)
lightning strike (bearing, dist, and intensity)
WX radar return (bearing, dist, tilt, intensity)
traffic (bearing, dist, alt, velocity)
FMS stuff: (FMS stuff will require lots of editing)
desired heading
desired altitude
desired airspeed
desired rate-of-climb/descent
barometric setting
waypoint (can we encode lat/lon, alt, and type into one CAN msg?)
Lever, button, knob movement:
lever (ID, position)
button (ID, press/release)
knob (ID, direction of rotation, number of clicks)
At this point my brain is starting to fade. I suspect that what I have
above will generate sufficient discussion to keeps us busy for several
hours at least. ;
From: | "Joe Hovel" <joe.hovel(at)med.monash.edu.au> |
Subject: | Source for cheap displays |
I just came across this page with lots of references and cheap sources for
displays - I imagine we require some cheap sources for early test and
demonstration units....
Joe Hovel
Subject: | Re: Source for cheap displays |
Sounds good.
Are any of them color?
Do you know if any of the color displays are brighter than 110
Candellas/m2?
Marlin Mixon
Subject: | tiny mobile computer & display |
Came across this site while looking at the Sharp display site:
http://www.eio.com/sage2.htm impressive!
Might be just what we are looking for to run all sorts of avionics software
(including moving map etc)
Joe Hovel
Marlin,
they are color, but I did not see any brightness data - yes I have: I just
downloaded the spec sheets: it's 100 - 120 nt ('nits' I think - that's not
very bright as far as I know, given that there are 500 and 1200 nt
displays).
I also just realized that I omitted to put the URL in my original message
.... duh.... sorry....
it is: http://www.eio.com/colorlcd.htm
Joe
Response to message:
Subject: Re: Avionics-List: Source for cheap displays
Sounds good.
Candellas/m2?
Marlin Mixon
Brian, All,
Most if not all of these are included in "CDA101/12, Parameter
Definitions" including format and units. We should start with CDA101/12.
Most of our concerns have already been addressed by CDA101 which is a CAN
Kingdom (HLP,real-time) architecture tailored for aircraft and marine use. I
have written to David Purdy asking for latest updates and info. This group
also hinted that software was available. This may be helpful.
See http://www.kvaser.se/canking/cda101/index.htm and download the file.
Sent: Monday, December 06, 1999 3:21 PM
Subject: Avionics-List: aircraft attributes/parameters
live in the archives indefinitely..........
Subject: | Re: aircraft attributes/parameters CDA101 |
>CDA101/12...
sounds liek a reasonable course of action... I have downloaded some of
this documentation and given it a cursory review... it seems to be what
we're looking for. It also provides another feature that we're looking
for... interoperability and standardization.
>This group also hinted that software was available.
Downloadable from the specified web site.
Some of it may be more helpful than others, particularly the Windows based
CAN bus monitoring tools and such... sorta like a packet "sniffer" fo rthe
CAN bus... lets us put a Windows machine on the bus to monitor and analyze
our data and performance while testing the system.
Steve
Subject: | CAN Kingdom to the rescue |
Brian, All,
I'll start my comments with ///
Subject: Re: Avionics-List: CAN Implementations
>... do we want to use CAN 2.0A (11 bit identifier) or CAN 2.0B (29 bit
identifier)?
/// I agree we should use CAN2.0B
/// All of the above issues are what the CAN Kingdom and CDA101 are for.
CDA101 is an implementation of CAN Kingdom oriented to the monitoring and
control of aerial and naval Unmanned Vehicles (UV's). CDA101 is a great
starting point for us. CAN Kingdom is a High Level Protacal (HLP) for
designing real-time networked systems. The CAN Kingdom HLP has a setup
phase where it communicates with its nodes and organizes the operation of
the network. We should be investigating how CAN Kingdom and CDA101 does
this and not reinvent this stuff. CAN Kingdom3.01 and CDA101 specifications
are all free from http://www.kvaser.com/canking/index.htm
engine1.CHT.1
engine1.CHT.2
engine2.EGT.1
engine2.oilp
/// CAN Kingdom and CDA101 deals with all of these issues, See CDA101/12
Parameter Definitions.
/// Use CAN2.0B (29 bits) and use CAN Kingdom/CDA101 for flexible system
reconfiguration. CAN Kingdom is designed to be modular, in that each
module/node(ie: engine instruments module etc) can be designed without
having to know how the system designer is going to use it.
I am having trouble reading between the lines. Are you perhaps suggesting
that we maybe ought to look at CAN Kingdom and CDA101 for
guidance? Perhaps you could be more forceful and forward with your
suggestions. ;
Brian Lloyd
brian(at)lloyd.com
+1.530.676.6513
....I am having trouble reading between the lines. Are you perhaps
suggesting
suggestions. ;
Brian Lloyd
subtlety was always one of my strong traits. :-)
Subject: | Re: CAN Module board |
>kit)?
You can download all of the technical data on any Mot device
from their website at http://mot-sps.com/products/
Some of the tech docs are HUGE and time consuming/risky downloads.
I have cable modem and can cut big downloads to CD Rom. If
anyone needs that service, e-mail me.
>billion.
You might want to take a peek at how ARINC 429 bus structures
orchestrate party line communications with literally hundreds
of potential sources and users of data. I've got contacts with
folk who work in that arena at Raytheon Acft here in Wichita.
They might be able to point me to some websites or reference some
basic turorial documents that describe the architecture.
http://www.aeroelectric.com
Nice to here from you. If anyone can help us on the pitfalls of
instrumentation (analog and digital) and the vagueries of electricity in
general, your the one.
You said:
...You might want to take a peek at how ARINC 429 bus structures
basic turorial documents that describe the architecture....
It so happens that Raytheon seems to be heavily involved with this new
AGATE/NASA databus standard. I've been trying to find technical info on it,
but have not been to successful. Perhaps one of your contacts could help.
They claim it is low cost, failsafe, etc. It appears that the physical bus
will be fiber-optic and the protocal will be some form of LonTalk. The
problem is I can't find out anything about it. I have a hunch it won't be
cheap or open.
>Bob,
You're very kind . . . I'll try.
weeelllllll . . . . sort of. The last word I had on
AGATE bus structures was that it's dead . . . that could
change in 30 seconds.
> . . . I've been trying to find technical info on it,
Haven't been made privy to anything proposed in the
past or being considered by any of the so-called
"partners" except that bus structures being offered
were to be held close to the chest by the offerors.
I would have expected this of Allied Signal, et. als.
but I was surprised that a little start-up operation
was taking the same posture.
>cheap or open.
I cannot disagree. Fiber is the latest buzz but does AGATE
really, Really, REALLY justify it? What's the longest
data run? 15 feet? What's the fastest necessary data rate?
I'm betting 1 MBs is plenty. Why spend $millions$ to invent
a new wheel when there's wheels avaialble off the shelf
that meet the requirements? Aviation has a long history
of shooting itself in the foot and AGATE is no exception.
Revitalize GA? Gimme a break. The real leading edge of
GA technology is in people's basements and garages. I'd
use GA's history for guidance but not as an example of
something to strive for or exceed in terms of sophistication.
There's a sign over my desk with with a saying by
a anomynous sage that says, "Sometimes, the best way
to drive a nail is with a hammer."
If you guys are interested in truly low cost technologies
with adequate performance, you're more likely to find it
on an 18-wheeler or a big piece of agricultural equipment.
>John
It appears they are doing something but it also appears that they are
basically ignoring the most obvious source of datacomm experience: people
doing commercial datacomm for process control.
> ... except that bus structures being offered
How does the saying go, "those who ignore history are doomed to repeat
it." If there is anything we have learned from the history of the
Internet, open standards and free software promote growth. Companies in
the past that have tried to hang onto their lead by keeping systems and
protocols proprietary have invariably lost in the long run.
> >cheap or open.
No.
> What's the longest
Until you get to really high data rates or long runs the real advantage
of fiber is electrical isolation. When designing a cabling plant for a
campus I always use fiber between buildings because fiber survives in
buried conduit better than copper and it provides isolation since the
grounds between buildings tend to be a different potential. Neither of
these reasons impact GA.
Oh, and one other thing, it is a heck of a job to make a multidrop fiber
buss.
That is what this group is all about. The big question is how to come up
with something that is both simple and elegant that will foster
experimentation and still be accepted by the establishment. Some of us
here recall the IP vs. OSI war that went on the in '80s. The whole world
was going to adopt the OSI networking standard and IP was going to fall by
the wayside. I personally have been thrown out of a building by a client
for suggesting that the Internet Protocol suite might meet their need for
open data communications between their disparate systems. I suspect that
same type of attitude is likely to exist in the aviation community.
So the big question then is NOT how to build an elegant, simple cockpit
avionics system; we know how to do that. The question is how to get the
Powers That Be to even consider our work as useful. None of us are part
of the aviation establishment and therefore our work is likely to be
dismissed as being too amateur to have any merit in spite of the fact
that we have some really top-notch data communications experts
participating.
> I'd
The corolary to this is, "When all you have is a hammer, everything looks
like a nail." ;
That is why we are looking at the CAN buss. CAN was developed to network
sensors and control systems in automobiles. It seems to be pretty darned
simple.
Brian Lloyd
brian(at)lloyd.com
+1.530.676.6513
Subject: | AGATE databus vs CAN |
Bob, All,
... If you guys are interested in truly low cost technologies
Well, most if not all of the auto and marine industry world wide is going
with CAN. I can see no reason why we shouldn't either. So far we've
identified:
- CAN 2.0B serial comm protocal, basic comm services
- CAN Kingdom High Level Protocal (HPL), Real Time Control (RTC)
- NMEA 2000 marine use, HLP, RTC J1939 implementable in CK
- CDA101 aerospace and marine use, HPL, RTC (CAN
Kingdom)
and a new player I found...
- CAN Aerospace HPL for aerospace very simple, we may want to look
at this more. see
http://www.can-cia.de/NN3.htm and
http://www.mstock.com/
Subject: | Re: CAN Aerospace |
>look at this more. see http://www.can-cia.de/NN3.htm and
Started reading their documentation. Thgis looks interesting, definitely
a contender.
Steve
Steve, All,
Yeh, It might not be as flexible as CDA101/CAN Kingdom but it seems
simpler.
We could cut our teeth on it until we run into a wall. If that happens we
should be smart enough by then to try something more complicated, if we need
to. There may be some performance issues, but for what we need it may not
matter at all. The pdf files hinted that C++ software may be available.
The software availability and cost issues are what we have to sort out
now.
I definately don't want to spend a fortune on software development tools. I
also don't want to attempt something this complex without a good Object
oriented tool set.
Lets see...
- CAN microcontroller with multiple analog, frequency and digital IO
- Many different analog sensor interfaces.
- one or more SBCs with displays
- C++ Software development environment for a PC
- bus diagonstic hardware & software
Lots of work to do, but we've got a start and we're getting the lay of the
land.
....Started reading their documentation. This looks interesting, definitely
a contender....
Steve
From: | "Marlin Mixon" <marlin_mixon(at)hotmail.com> |
I found the following document encouraging. I think we're on the right track
using CAN. Here's an excerpt from
ftp://ftp://www.mstock.com/pub/ (filename=CAN_FlightSim.pdf)
CAN is used as cockpit interface network in three EUROCOPTER development
simulators and the BO 105 Procedure Trainer. It has proven to be an
excellent solution for complex true-to-life flight simulators
due to a.) its object orientation, b.) the efficient error handling and c.)
the flexibility which simply outperforms any other fieldbus for this
application.
In the meantime, the Grob STRATO 2C research aircraft has shown the way that
CAN might go in aero-space: This high-altitude aircraft is equipped with a
CAN-based engine control system which has been designed by the
Industrieanlagen-Betriebsgesellschaft (IABG) in Germany. The STRATO 2C has
already been tested in flight levels close to the stratosphere (60.000ft/
18.000m) and demonstrated that CAN
works without any problems in a harsh environment.
CAN offers all the advantages of dedicated aerospace bus systems like
MIL-STD 1553B or ARINC629 at a much lower cost and complexity level.
Therefore, there is a good chance that we will see this network in flight
critical applications like primary flight control sooner or later.
Marlin
Marlin,
...there is a good chance that we will see this network in flight
critical applications like primary flight control sooner or later....
Marlin
Later for me, thank you. I still prefer steel cable and tubing control
systems. :-)
On Thu, 9 Dec 1999, Livingston John W Civ ASC/ENFD wrote:
> Marlin,
> Marlin
> systems. :-)
I think that autopilot communications is a very real possibility for
this. In that case we are talking about flight control systems.
Brian Lloyd
brian(at)lloyd.com
+1.530.676.6513
From: | "Matthew Mucker" <mmucker(at)airmail.net> |
At first glance, this seems to be a well-thought-out standard that we can
easily adopt. I think this definitely deserves closer scrutiny.
One thing that concerns me is that the specification calls for metric units.
I wonder if we could find a bit flag somewhere in the datastream to indicate
English units of measurement? (With the blessing of the specifications
author, of course.)
I'll look at this over the weekend some more. It certainly looks promising!
-Matt
>author, of course.)
Why bother? One of the tricks we use in internet protocols is to adopt an
intermediate standard on the wire that may differ from what is presented to
the user. In this case it is just fine to use metric units on the wire.
The operator just selects English units in his/her display and the display
does the conversion.
Frankly, I like the idea of sticking with a single system of units on the
wire and Metric units appeals to me from the point of view of doing
calculations. If you want my opinion, stick with MKS and let's move on.
Looking at the necsl_um.pdf document at
My only question is "Jeez, are we allowed to see this?" Even if we can't
duplicate it for proprietary reasons, it answers a lot of hardware
questions.
Marlin Mixon
>Marlin,
>Marlin
>systems. :-)
We're about to demonstrate GPS guided auto-land in the
'agate' Bonanza. This is a fly-by-wire airplane with
really fat servos capable of doing anything a pilot would
need to do to fly the airplane with hand/foot controls.
I keep hearing "data bus" and "fly by wire" spoken in
the same sentence . . . but if one did EVERYTHING by
serial data bus except flight controls, I doubt that it
would add 1 pound of wire to a small airplane. Data
bussing critical, high repetition rate data in with
more mundane things like latitude and oil pressure doesn't
make much sense to me. Flight control systems would also
have to add complexity in terms of serial bus transceivers
just to accomodate doing your fly-by-wire on the same
bus. Might make sense in a B767 but don't see any
benefits in a light plane. There are other relatively
simple tasks like closing a switch to turn on nav lights,
vent blowers, etc . . . don't see any economies in doing
these things via the bus either.
>identified:
(RTC)
>Kingdom)
>at this more. see
>John
Neat stuff. Got a peek at it a few minutes ago. I've
be forwarding parts of these conversations to some of
my fellow perpetrators out at Raytheon. Hope you guys
don't mind being spied on . . . nothing would tickle
me more than to see the "amateurs" get it done before
government does. Come to think of it, EVERYTHING done
for the first time is done by an amateur so perhaps
we should call ourselves somthing more distictive to
keep from being confused with those "other" guys . . .
>participating.
Get it working, let's sell 'em to the homebuilders (and perhaps
into the Owner Maintained aircraft in Canada - if that program
ever gets off the ground) . . . there were about 10,000 Lorans
flying before the FAA got around to admitting that they were a
pretty good thing.
>> I'd
>like a nail." ;
Very good!
>simple.
Go for it! I think it's a winner . . .
Brian Lloyd wrote:
> > What's the longest
What about my digital intercom? And my digital camera?
But seriously, you're right.
I was involved on the perphery of a security/access control project
which required digital camera images and intercom messages to go over
the same wires as the door unit access control comms (and the same wires
to be used for power supply... i.e. just two wires to any unit). Those
gimmicky requirements pushed up the complexity and cost of the project
*enormously*. Can you say 'didn't meet deadline'? How about 'budget
overrun'? Knew you could!
Frank.
To paraphrase the TV ad, "bits is bits." It doesn't matter whether the bits
are oil pressure data or elevator position commands. We have been pushing
critical management and control data over the internet for a long time now.
People have recently started to segregate the traffic for two reasons:
1. traffic levels have reached a point that the latency for time-critical
data/commands has started to increase;
2. there are nasty people out there who would like to break the net if
they could get into the control systems.
Neither of these are a problem in an aircraft. We know the data rates for
all the components so we can bound the latency problem. We also know that
there are no hostile components so that is a non-issue.
Well, so long as the buss is fail-safe, i.e. no failure mode of a single
component can cause the buss to fail to carry the information for all the
other devices, there is no reason not to put all your data on the buss. I
would rather have two redundant busses each capable of carrying all the
information than to have a sensor buss separate from the flight control
buss. The complexity is the same in both cases but you have more
redundancy with the former.
At a couple of bucks, transceivers don't cost very much. Microprocessors
aren't much more. You know, it is very likely that the connectors and
enclosure will cost more than all the electronics they carry. I can put a
whole bunch of microprocessors in an airplane for what most people pay for
circuit breakers. You know, it may actually be as cheap to build on/off
modules as it would to install a switch, a breaker (I know, fuses are
cheaper and better), and some #18 tefzel wire. The economies are shifting
in favor of silicon.
Maybe. You might have a solid-state relay box that talks to your buss and
performs the function of the switch panel.
This whole thing is like the internet in miniture. Once you have
ubiquitous, high-speed, reliable data communications you start thinking
about doing things that you never considered before. If we can come up
with low-cost fly-by-wire systems that are as reliable as torque tubes and
steel cables, why not switch to FBW. (Have you ever asked yourself, just
how reliable are the traditional mechanical systems, anyway?)
Hey, we have the technology. We start with sensor boxes and move to
avionics and FMS. FADEC will be not-so-far behind. FBW is not long after
that. But it all starts with reliable, universal communications. With
that in place, anyone can dream up a new feature and build a box that plugs
into the buss to take advantage of all the information that is already
there. Yeah, we gotta build this.
>Brian Lloyd wrote:
>> > What's the longest
Dave and I planned to put all the audio on the buss. The current crop of
codecs used in PCS phones operate at bit rates under 10 kbps. One very
nice codec in use is variable rate and switches between 1 Kbps and 10 Kbps
depending on the complexity of the audio. With a 1Mbps buss you can put an
awful lot of communications quality audio on there without impacting your
critical stuff. MPEG-3 (MP3) audio delivers two channels of almost CD
quality sound at 128Kbps. No, audio isn't going to break the bank.
And your camera? No problem there either unless you are trying to do full
motion video. A still camera image is on the order of 100KB. One image
per second would stress your 1Mbps buss but do you take pictures that
rapidly? Remember, we are going to have a way to guarantee bandwidth and
latency for critical functions.
That is because they didn't think the problem out ahead of time or because
the requirements changed after the fact, usually after the initial design
is done and noone had the cojones to say, "well, we should throw it out and
start over with a clean sheet."
The data transmission problem looks like it is already solved. The
messaging looks like it might be solved too. With CAN we have close to
1Mbps of capacity. That is a LOT of capacity considering that most of what
is happening in the cockpit today is done at data rates measured in
hundreds of bits per second, not millions. For example, the new S-Tec GPS
steering system is giving heavy-iron quality autopilot performance and the
data rate is 4800 bps (I think that is right -- 4800 bps is the default
data rate for the NMEA interface used by most GPS receivers). Maybe it is
9600 bps. You can do 100 x 9600 bps on a single 1Mbps buss with some room
left over. (I know, we have overhead and dead times, etc., but the order
of magnitude is correct.)
Now let's get something built.
Subject: | Glass Cockpit documentation |
I have reworked the definitions and reference data. I have moved all of
the definitions, links, etc., over to a separate page, and added
hyperlinks within the body of the text to the definitions...
This primarily affects the architecture page, as that is what we have been
working on the most lately...
There are quite a few shortcomings with my definitions, perhaps some
important links I missed. Please email me direct (off list) with any
definitions, links, etc., that should be added or corrected (in addition
to any other comments you may have). If there are any places where terms
should be linked to their definitions, let me know about those as well. I
will get on the changes as soon as possible.
Steve
Subject: | Re: CAN Aerospace (units of measure) |
>adopt an intermediate standard on the wire that may differ from
>what is presented to the user. In this case it is just fine to use
>metric units on the wire. The operator just selects English units
>in his/her display and the display does the conversion.
Yeah, we sorta jumped ahead of ourselves here, but that's exactly right...
heck, we don't know that all of our "users" will want/need English
units... let the rendering software decide on that and convert as needed.
>on the wire and Metric units appeals to me from the point of view
>of doing calculations. If you want my opinion, stick with MKS
>and let's move on.
That's what I used for my first year Physics, and it worked well...
changed schools, and the second year the other school used English units
(in science!!!!)... it was like the dark ages... I felt like we were
measuring mass with stones and distance with our "feet" (on the ends of
our legs).
So internally using the MKS (meters, kilograms, seconds) sounds *FINE* to
me.
Next...
Steve
Existing protocols like ARINC429 assign fixed lables
and data formating so that anyone can generate or
decode that data item. Unless there are strong
technical reasons for changing formats, you might
want to adopt the ARINC429 suite of messages and
add your own unique packets as needs be.
This would save you a lot of time setting up a new
system. It MIGHT encourage some existing vendor
of high-dollar ARINC compatable stuff to service
your market if all they need to do is change their
bus interface. Clumsy as it may be, there's a
LOT of 429 stuff out there. A new system might
enjoy faster acceptance if it had familar features.
Subject: | Java CAN simulator |
Java idea summary: Integrate a software CAN simulator
to Dave B's Java Flightsim allowing us to verify that CAN
and JAVA are suitably fast enough when linked together.
I was initially sending this to Dave B. (who is in offline
in California for a couple more days), but I thought I'd
also mention it to the group.
Dave wrote a Java Flightsim package and some members of the
group have taken a look at it:
http://www.froghouse.org/~dab/inst.tar.gz -or-
http://www.froghouse.org/~dab/inst.zip
To run say "java Simulator".
I ran it and flew it around a little and was impressed with
it. It demonstrates that a Java display can run fast
enough to be suitable as a display system.
So here's the idea: we could modify the Java Classes by
writing a new class that interposes itself between the
Dave's on-screen joystick, and Dave's instrument panel.
This new class would read the flight simulator model data
as it changes in real time and encodes it into CAN messages
just as if a bunch of sensors were encoding real-life data.
Once the basic functionality of this is working, we can
then impose a speed limit of (1 Mbit/s) on the data
encoding process.
Although the CAN simulator would not be used in the
aircraft, it would serve as a stepping stone used during
development. This computer modeling exercise will let us
verify that CAN is fast enough, and that the Java display
is sufficiently powerful enough. Also, it will let us
start to develop the software that will be used for display
because we'll have a source of CAN data (albeit an
artificial one). Finally, it will help us in fine tuning
module transmission cycle rates.
As far as Java goes, I especially like the fact that we can
all work with it because Java Virtual Machines (JVMs) exist
for most Hardware/OS platforms.) Also, some of you
probably aren't aware that Java can run as a stand-alone
application meaning that you wouldn't have to run a browser
on your display unit, just the JVM and the display
application. We're not talking about scrolling text
Applets here!
Marlin Mixon
All right, I admit it. I haven't been able to keep up.
As I understand things, most of us are in agreement that the CAN bus looks
like a good choice for data communications at the lower levels, but we're
debating two or three standards at the higher levels.
Is this about where we are?
If so, I'd move that we plan on CAN if there are no objections and move on
to deciding on a high level protocol.
Geez, folks, if we keep up this pace, sooner or later we're going to have to
BUILD something!
-Matt
Ummm.... embarassing question here....
How do I run it?
I've downloaded the files to my drive (Windows NT running IE5). Do I need
to create a skeleton web page that instantiates the simulator?
-Matt
-----Original Message-----
[mailto:owner-avionics-list-server(at)matronics.com]On Behalf Of Marlin
Mixon
Sent: Friday, December 10, 1999 1:29 PM
Subject: Avionics-List: Java CAN simulator
**YOU** can't keep up? Try documenting the thing (around your full-time
job!)
>bus looks like a good choice for data communications at the lower
>levels, but we're debating two or three standards at the higher levels.
Yes.
>on to deciding on a high level protocol.
I second the motion... Actually, I think that you're seconding MY motion
that was made last week some time... :-) but who's counting...
Steve
>From: "Matthew Mucker" <mmucker(at)airmail.net>
>How do I run it?
No, first of all, forget everything you know about Java!
It's not an applet, so IE5, even though it has Java capabilities,
won't do a bit of good. Instead, go to java.sun.com and download their JDK
1.1.x. JDK 1.2.x will work too, but I had some display problems with it
where the flightsim is concerned. (JDK 1.1.7 for win32 is 8.4 MB). Install
it, then from a command line prompt (DOS window in win32) type "java
Simulator"
which IS CASE SENSITIVE.
Marlin
I have a question for the group that would have big impact on the data bus
standards chosen.
Looking at the Can Aerospace specifications, all data on the bus is
transmitted in real-world units of measurement. (Pascals, meters, etc.)
This is great for listening devices, since no conversion is needed to get a
usable piece of data.
However, such an implementaion requires the individual data collection units
on the bus to convert from their sensors' native units (volts, for instance,
in a pressure-to-voltage transducer) into real-world units. This kinda
scares me. This would require floating point math to be done at the
sensors. Since our sensors would probably use small microcontrollers, we're
talking quite a bit of debugging and coding time. My original thought when
I started this whole thread was that the sensors would send the raw data
back to the listeners (probably a Pentium-class machine), and that that
machine would do the conversion.
Call me crazy, but I'd rather do floating point math in a full-blown
development environment on a PC than in assembly on a micro. (And my
personal prejudice is that if you're programming on a micro, assembly is the
only way to go!)
So, the decision on whether the bus will contain real-world data or raw
sensor data boils down to where we do the conversion from raw data to
real-world data: do we do it at the data collection unit, or at the
listening (display) unit?
As I indicated above, there are advantages in each case. I've never done
any floating-point work on a micro, so just that in itself scares me. I
might find out that it's not as bad as I fear. On the other hand, it might
be worse than I fear!
So, where do we want to do this data conversion? Do we want raw data on the
bus, or real-world data on the bus?
-Matt
From: | Livingston John W Civ ASC/ENFD <John.Livingston(at)wpafb.af.mil> |
Subject: | CDA101/CAN Kingdom update |
Gentlemen, (its just a figure of speech)
I wrote to David Purdy who is deep into CDA101 activities. This is his
responce:
> From: Livingston John W Civ ASC/ENFD [SMTP:John.Livingston(at)wpafb.af.mil]
> Sent: Tuesday, December 07, 1999 8:08 AM
> To: 'David Purdy'
> Subject: CDA101 Status
> David Purdy,
> I'm part of an informal group working on Glass Cockpit architecture for
> Sport aviation. We've been studying the CAN bus and CAN Kingdom as a
> candidate architecture for this effort. Your offices work with CDA101 has
> been helpful, and I was wondering what the current status is? Is there a
> web sight (other than kvaser) where I can find the latest updates.
> Also, do you have any thoughts on the AGATE/NASA databus
> (Echelon/Raytheon) effort. How will this effect CDA101?
> John W Livingston
>David Purdy's responce:
>We are still working on getting our web site approved. We (DoD) got real
>touchy about firewalls during this last year. We do offer a CD with a lot
>of stuff (the latest greatest) and will be offering a another class early
>next year with space available free attendance to interested parties.
>While I am not intimately familiar with the AGATE/NASA initiative our look
>at echelon said that it was not geared toward real time control loops. It
>does appear to work very well at moving switch data and non-time critical
>sensor data. I think it would make an excellent home network standard.
>CAN is very good at closing control loops but is limited to 1 MBit. If you
>are moving large amounts of plot data (i.e. video, radar) I would consider
a
>higher throughput system. Also, CAN has limited small packets. Again,
>excellent for control data, not so great for streaming files.
>That said, we like CAN and the CAN Kingdom approach to plug and play
>architectures and it is in my opinion, the best there is for CAN. We have
>been looking at extending the approach to other media, for example
ethernet.
>Our present work is centered around implementation inside to aerial
>vehicles, the BQM-74 from Northrop-Grumman and the MQM-107 built by Tracor
>with a design package owned by the Army. These vehicles are stepping
>stones, that is, the entire avionics is not distributed on a bus. We do
>have a remote control boat which is completed distributed and it is
entering
>production.
>If you have any more question please free feel to contact me again...
>David Purdy
CDA101/CAN Kingdom still looks very good to me. A system based on CAN
Aerospace will not have the same level of modularity and flexibility. The
best I can tell, with my limited knowledge to date, is that CAN Aerospace
modules predetermine the priorities for various messages based on
preconceived notions of their importance to the system. CAN Kingdom modules
would make no such decisions but allows the system designer(engineer) to do
this based on his system's requirements. CAN Kingdom message priorities are
set(following the designer's instructions) during the system setup mode(when
the system is turned on). This makes the modules and thier messages alittle
more complex but way more flexible. It also puts the fewest constraints on
the system designer; Something we will really need.
Also I read on the web where a concept car was using 2 different buses.
One for systems data another optimized for audio and video.
Anyone know where to find information how to remove magnetism in steel cage fuselage,
by running high current through the frame with battery and jumper cables?
Sten S
Sweden
Matt,
My responces begin with ///
From: Matthew Mucker [mailto:mmucker(at)airmail.net]
Sent: Friday, December 10, 1999 4:04 PM
Subject: RE: Avionics-List: Data Bus
standards chosen.
only way to go!)
///We are talking about simple floating point equations. I personally
prefer code I can easily read, so I would much rather program in C/C++,
Pascal, FORTRAN, JAVA etc. I have seen software some very low price)
for microcontollers in Pascal and JAVA and I know it is available in C.
Very small ram requirements.
///The data module must communicate messages of various types to the CAN
bus. In a CAN Kingdom, for instance some of these identify it and its
services to the Main computer(King) at start up. My point is we will be
doing small but none trivial programming for the microcontollers in each of
our different data modules to support CAN and our HLP. We want to be doing
this in a readable, documentable way using a good language. Lets say C and
C++. Not my first choice but its OK.
///Take what I say with a grain of salt. I haven't done any programing
with a microcontroller, but I've done some assembler coding and I know I
don't like that. I never could easily read what I wrote 2 weeks after I
wrote it. It's hard enough to write supportable,documented,easy to read
code in a high level language.
///At the risk of being vague and misunderstood, I say we bite the
bullet, and make these little modules as smart as we need them to be.
Real-world data on the bus. High level language coding. Take that you bit
head! :-)
Sten,
This is just hear-say, since I haven't done it, but plan to.
I think you need AC current. I was told to insulate your airframe and
just hook it up in series with a light bulb on an AC house line. Beeeee
verrrry careful.
Sent: Friday, December 10, 1999 4:35 PM
Subject: Avionics-List: Degauss
fuselage, by running high current through the frame with battery and jumper
cables?
Sten S
Sweden
There are several ways to do the math without having to do floating
point. Remember, the data as it comes in is integer data in the form of
an 8- to 12-bit signed/unsigned raw value. Yes you have to change the
slope and intercept points to match the transducers you are using but you
can do the floating point multiply as a fraction. For instance, if I want
to use a scaling factor of 1.353, I can instead multiply by 23 and then
divide by 17 (23/17 = 1.3529). Now I am doing integer arithmetic
again. Not a big problem.
> only way to go!)
Maybe. You can do a lot with C and it is pretty darned efficient. Memory
is not the problem it used to be.
If you are trying to do a standard, you want to standardize on the
messages on the wire. If you send raw data you have to have a way to
describe that data so that all devices will understand it. Do you plan to
broadcast the conversion factors (slope/intercept for most transducers) or
do you plan to hand enter them in every box that decides it wants to use
that data? If you use standard units on the wire, all devices will be able
to immediately use the information when they receive it.
Fractions are your friend. Use them.
No ifs, ands, or buts about it, I want real world data on the buss.
Brian Lloyd
brian(at)lloyd.com
+1.530.676.6513
> cage fuselage, by running high current through the frame with battery
> and jumper cables?
No, that will actually magnetize the fuse even more. I have seen people
demagnetize a steel tubing fuse by wrapping it with wire forming a
solenoid (metal fuse inside a coil of wire) and then connect the wire to a
variable autotransformer (a Variac). You turn up the voltage until the
coil of wire is pulling as much current as the Variac can handle and let
it sit for awhile. Then you slowly turn down the voltage so that the
alternating magnetic field goes away slowly. When you are done your fuse
should be demagnetized. If not, repeat the process until the permanent
field is gone.
Brian Lloyd
brian(at)lloyd.com
+1.530.676.6513
> How do I run it?
You need a Java run-time environment (JRE). You don't need to use your
browser at all. Go get the JRE from Javasoft.com.
Brian Lloyd
brian(at)lloyd.com
530.676.6513
Actually that is java.sun.com. Sorry.
Brian Lloyd
brian(at)lloyd.com
+1.530.676.6513
the
> only way to go!)
Yeah, but that would require me to learn C! :-P
I don't disagree with you, and have to admit that real-world data on the bus
makes a heckuva lot of sense. I just wanted to throw the idea out there.
-Matt
Subject: | I'm back.......... |
Hi again,
I've been out of the loop here for a few weeks. I didn't intend to abandon
you guys. Been busy with other stuff. I expect that will continue for a
while. I don't think I've actually lost any messages, though, and I've just
been catching up with reading them. I will now attempt to redeem myself with
another of my long winded missives.
One of the other things I've been doing has been looking at the CAN bus for
an unrelated application. The more I look the better I like it. Apparently
there is a consensus forming here that it fits this application also. I'll
add my vote to that. I would stay far away from the LON bus, BTW.
What I'm referring to is just the CAN spec itself, which covers only the
physical and link layers (roughly). I'm less sure about the upper protocol
layers, but the CAN Kingdom looks about as good as any.
There is a CAN mail list, BTW. To subscribe send mail to
<majordomo@vector-informatik.de> with the following in the body of your
message:
subscribe canlist
Here are a few misc. links I've collected:
Bosch CAN Homepage (THE CAN spec.) http://www.bosch.de/k8/can/
Chips:
CAN - AVAILABLE DEVICES http://www.omegas.co.uk/CAN/devices.htm
Philips http://www-eu2.semiconductors.philips.com/can/
Infineon http://www.infineon.com/us/micro/can/content.html
Fujitsu http://www.fujitsu-fme.com/products/micro/can/04.html
Some board level stuff:
http://www.hmcomp.demon.co.uk/canbus.htm
http://www.hitex-automation.com/ehican.htm
http://www.dipinc.com/products/pd.html
A few random thoughts re bus data semantics and the design of the "sensor
boxes" (we need a better name):
I think airspeed works well as an example. Do we want to display indicated
airspeed in knots or true airspeed in mph, or...? I don't know, and I sure
don't want our "sensor boxes" to have to care.
At the other end of the chain, what's really in the "sensor box" is a pair
(at least) of pressure sensors, a few opamps, an analog mux, an A/D
converter, and a processor. The pitot and static ports are plumbed to the
pressure sensors, which, in turn, output a voltage that is, while
proportional to pressure, otherwise quite arbitrary. The A/D converter then
converts that voltage to a binary number that is even more arbitrary. (It's
not even in volts, it's just a ratio). The processor then does a little
digital filtering on these numbers to get rid of noise. The result is these
two numbers that are proportional to pitot and static pressure but otherwise
meaningless. As if that wasn't bad enough, they may not even be linearly
proportional to pressure. We may need to do a little curve fitting.
So, do we just ship these raw numbers out onto the bus and let the
receiver(s) do the math? How would they know what conversion equation to
use? I think you get my point, no raw data on the bus.
A somewhat fuzzier issue, I think, is do we send two pressures (in psi, kPa,
or whatever) or one indicated airspeed? Sending the two pressures seems
cleaner to me, but I'm open.
Considering the way the bus design is going, I don't think we're going to
get very far with a real low end (i.e. PIC, 8051, etc.) "sensor box"
processor. It could be done, I'm think, but I fear the effort would be a
little too painful.
There are C compilers available for these things, but the chip architecture
forces them to generate very inefficient code. That, combined with the
limited memory available, limits what can be done in C to fairly trivial
projects. (Don't even think about C++, Java, etc.).
I have used these chips (and Z80's, 8085's, and even older things) to do
some fairly tricky stuff, but that has always been with very tight assembly
code. I personally don't aspire to do any more of that "hand polishing each
bit" sort of coding. (And I'm actually pretty good at it, if I say so
myself). Trying to do that sort of thing in the context of a geographically
diffuse group project would be a recipe for frustration. It will do us no
good to have a real cheap box if the firmware is never done.
At the other end of the scale, I doubt these "sensor boxes" can be built
with off the shelf, board level products and remain cost effective. I don't
think anyone sells a board that you can hook up to a bunch of thermocouples,
pressure sensors, etc. and to the CAN bus, and program in C. It wouldn't be
that hard a thing to design but there isn't much of a market for it. I fear
we would end up having to buy a stack of boards, each of which contained
stuff we don't need, and interface them to each other. This would still be a
fairly large engineering job, and we would end up with an overly expensive
box.
Yeah, I know, you're waiting for the third option. There are some relatively
new 16 bit microcontroller chips that seem to be a pretty good fit. I've
been looking at the Infineon C167 and the Fujitsu 905xx series. Their
architectures were designed with compilers in mind and they have larger
address spaces and pointers and more on chip memory. They seem to be
intended for the automotive market so they have on chip A/D, CAN, etc. So
far though, all I know is what I read in the data sheets, and I'm not sure
when I'll have time to go further. I'll keep you posted.
Later,
Jeff
Thanks! I need to get in touch with theese people (either method). The fuselage
on my Pete Jones 450 Stearman is really badly magnetized, making it practically
impossible to compensate the compass deviation. It has the battery in the rear,
with the fuselage acting as minus conductor = high current running through
the steel frame when the starter engages. Ones I get the frame degaussed I figure
I need to run a separate heavy gauge ground cable from the battery to the
engine?
Sten
> field is gone.
> Brian Lloyd
> Sten,
> verrrry careful.
> John
> cables?
> Sten S
> Sweden
Subject: | Re: Data Module formatting... |
Date: Friday, December 10, 1999 11:36 PM
Subject: Avionics-List: I'm back..........
>...A few random thoughts re bus data semantics and the design of the
"sensor
otherwise
we process the data in the data module into a standardized aggreed upon
variables, units, and formats. These are placed in messages and this data
is made known to the system using a HLP such as CDA101/CAN Kingdom. See
CDA101/12 for a list of aircraft related parameters that they have already
defined.
kPa,
Using CAN Kingdom its easy to do both. The data module lists all the
possible data that it can send out The system setup master program picks
and chooses what it is going to use from the various data modules and their
data lists. Each module is free to offer what ever it wants to, and in
various forms. Very modular approach. It makes it easy to provide general
purpose modules that don't have to know how they will ultimately be used.
This is just what we are looking for.
>....There are some relatively
I agree with your observations. Chips of this ilk is probably what we need.
I'd like us to come up with at least one small generic 8 channel analog to
CAN microcontroller board with a little space for analog signal processing
parts. We should also provide some sort of software development
environment for our PCs(probably C/C++). If you haven't yet read the pdf
document on the ST2000 boat project. It contains alot of useful
information. It bridges the gap between the theory of CDA101/CAN Kingdom and
its application.
Subject: | Data Module formatting... |
Hi John,
Do you have a URL handy for "the pdf document on the ST2000 boat project"?
BTW, re the Fujitsu chips I mentioned: Fujitsu is rumored to have a C
compiler, linker, debugger, etc. package available for free! I'm currently
trying to track this down.
Am I still the only hardware designer (EE) type in our little group? I sure
would like to see someone with more analog circuit design experience turn
up. I've been studying up on things like interfacing to thermocouples, but
it would be nice to have someone on board who has actually done this stuff
for a living.
Later,
Jeff
[mailto:owner-avionics-list-server(at)matronics.com]On Behalf Of J
Livingston
Sent: Saturday, December 11, 1999 8:39 AM
Subject: Re: Avionics-List: Data Module formatting...
its application.
Never mind, I found it.
[mailto:owner-avionics-list-server(at)matronics.com]On Behalf Of Jeff
Barlow
Sent: Saturday, December 11, 1999 11:19 AM
Subject: RE: Avionics-List: Data Module formatting...
Hi John,
Subject: | ST2000 boat project |
Hi again,
Just looked at the CDA101 Seaborne Target 2000 documents. It seems to be a
small world. This work was done by the "toy boat and airplane" guys up at
Point Mugu NAS. They make expensive R/C model planes and boats to give the
navy something to practice shooting at. My ex-brother-in-law used to work
there.
Anyway, their design just the sort of thing I was thinking about for our
"sensor box" design. To go along with the small world theme, the processor
chip they used is one of the two I just mentioned.
Later,
Jeff
>for a living.
>Later,
>Jeff
I can probably help a little there . . .
>otherwise meaningless. As if that wasn't bad enough, they may not even
>>be linearly proportional to pressure. We may need to do a little curve
fitting.
The very best value in solid state air data as of this
writing was done for us on AQM-37D supersonic target a
couple of years ago . . . jelly-bean, silicon strain gage
presssure transducers are biased up with precision constant
current sources. A 16 bit a/d looks at BOTH excitation voltage
(temperature dependent) and output signal (ratiometric product
of excitation and pressure). During screening, all units are
tested on automatic pressure and temperature cycling equipment
such that the integrity of system is proven while at the same
time, you gather data on non-linearities and offsets due to
temperature.
After screening, a set of 3 lookup tables provided the ability
do deduce pressure altitude to plus/minus 20 feet at 50,000
feet and pitot pressure to .1% for all effects combined. These
units sold to us fully screend for about $2500 . . . the bill
of materials for the electronics was under $200.
if you borrow from any of the contemporary data bus structures,
the data packets are real numbers, ready to be used by other
clients listening in. Whether BCD, Binary, Hex matters not as
long as they're plug-n-play numbers.
>its application.
The system I described above does 20 Hz updates to a D/A ouput
and uses an 8085 microprocessor. I think it runs at 8 or 10 Mhz.
From: | Frank and Dorothy <frankvdh(at)ihug.co.nz> |
Let's hope it's reasonable quality -- one of the free development
systems I used (Z8 micro) wasn't worth the asking price.
> for a living.
I have done this stuff for a living, but I'm not an EE. However I do
know a bit about interfacing thermocouples, etc, picked up by osmosis
whilst working with EEs. I couldn't design an analog circuit if my life
depended on it though.
Frank.
Hi Bob,
I sort of overlooked you, I guess. Steve hasn't added you to his "players"
list yet. I hope you can find time to help out a bit with the design chores,
it would make me feel less "out on a limb".
When you say "jelly-bean, silicon strain gage pressure transducers" are you
talking about the $15 ones that Lucas and others make for the automotive
market? I was hoping these would be good enough if we temperature compensate
and linearize them in firmware. The old table lookup and interpolate trick.
Lots of prototype R&D work though.
Later,
Jeff
[mailto:owner-avionics-list-server(at)matronics.com]On Behalf Of Robert L.
Nuckolls, III
temperature.
fuselage on my Pete Jones 450 Stearman is really badly magnetized, making
it practically impossible to compensate the compass deviation. It has the
battery in the rear, with the fuselage acting as minus conductor = high
current running through the steel frame when the starter engages. Ones I
get the frame degaussed I figure I need to run a separate heavy gauge
ground cable from the battery to the engine?
I ask my homebuiders to do just that. Engine mounts, fuselage
structures, etc, are always mediocre to poor electrical system
conductors. Idealized ground systems are described in appendix
Z to our book which may be downloaded:
http://www.aeroelectric.com/errata/z8_0299.pdf
>Sten
>> field is gone.
>> Brian Lloyd
>> Sten,
>> verrrry careful.
>> John
One of those Sears buzz boxes (ac arc welders) makes a good, relatively
constant current source to demagnitize large hunks of steel. Clip both
leads to opposite ends of structure . . . or over the ground path presently
used by the battery to get electrons to the crankcase. Start out at
mimimum amps and turn the critter on. Step up rather quickly to max amps
and back to minimum . . . about as quickly as you can move the controls.
In my experience this technique has about a 75/25 chance of doing
a useful thing . . If you have access to a fat Variac (mentioned>
above, then put it in the AC line feed to the welder, set the welder
for max current, then sweep the Variac from min to max to min as fast
as you can go.
>Hi Bob,
Be glad to help when and where I can squeeze it in . . . working about
2-1/2 full time jobs now.
That's the ones. I think the first interation used devices
from ICS . . . the last ones were another vendor but I don't
think they were over $25.
I can probably get a schematic of how it was done and perhaps
some good words from the guy who did the software as well.
From: | "Ian Molesworth" <ian(at)imolesworth.demon.co.uk> |
sure
but
stuff
> >for a living.
> >Later,
> >Jeff
I'm just sitting quietly in the wings here.Does designing and manufacturing
GPS data logging equipment, digital altimetry and a host of sensor equipment
for military helicopters and surveilance aircraft, HUD's , Tank
rangefinding, sighting and gun stabilisation equipment help at all?
I put a long post together about the benefits of formatting bus data as XML
but it got bounced by the list engine since it looked vaugely like HTML. I
have attached the returned interpretation so it might get past the engine
this time.....
> Hi All
> Forgive my late intrusion to the fray but has anyone considered
> formatting data on the bus as XML?
> At first thought the idea may seem a little silly but if you think about
> it all the reasons that XML is getting so popular in the current IT
> arena tend to apply to an open source, open architecture, such as is
> being proposed here.
> XML makes messages human readable so debugging a misbehaving device
> becomes easier.
> XML is VERY java friendly, classes are available for free to do all the
> data manipulation. C has libraries available too.
> XML data is self describing so .............
> A device attached to the bus 'publishes' data to the bus. Devices
> that already understand the data can act upon it. Devices that don't
> comprehend the data dont go into a flat spin, they simply ignore it. The
> advantage is that different versions of firmware can exist on bus
> devices with far less chance of problems with data format.
> Take for example the old NMEA standard stuff that comes out of most
> GPS's
> $GPRMC,212949,A,4915.61,N,12310.55,W,000.0,360.0,11119Mag8,020.3,E*6B
> Now unless you have the NMEA 1.5 and NMEA 2.0 standards next to you
> whilst writing your firmware you are in a bit of a bind!>
> If you were to see
> [GPAviationMessage]
> [Source]Garmin GPS-12xl[/Source]
> [ReceiverHealth] OK [/ReceiverHealth]
> [Timestamp]
> [time]21:29:49[/time]
> [zone]UTC[/zone][/zone]
> [/Timestamp]
> [Position]
> [Latitude] 49=B015.61[/Latitude]
> [LatHemisphere]N[/LatHemisphere]
> [Longitude] 123=B010.25 [/Longitude]
> [LngHemisphere]W[/LngHemisphere]
> [GPSAltitude]
> [Height] 111198[
> [Units Feet
> [/GPSAltitude]
> [/Position]
> [TrueHeading]360[/TrueHeading]
> [MagDeviation]20.3[/MagDeviation]
> [DevHemisphere] E[/DevHemisphere]
> [MessageHash] EF445010[/MessageHash]
> [/GPSMessage]
> It may be about 4 times more verbose but if we're talking megabit comms
> rates does it matter all that much?
> Has anyone looked, or is anyone looking at what will 'reasonably' be
expected to travel on a common bus in terms of messages?
> GPS position. Barometric pressure, Compass (Magnetic) Heading(Gyro) 3 axis
of horizon info, Temperatures ( about a dozen Airspeed, Rate of climb
perhaps ), A handfull of 'digital' signals.
> Remember that inventing a new bus means having to invent the sensors
> that go at BOTH ends of the wire. Can you buy a GPS that interfaces to
> anything but the standard aviation busses?? I would love to play with a
> ring laser gyro to match it to an open system but they are pricey, even
> to very dedicated home enthusiasts!!!
> On another front..... someone else posted ( Matt ) that developing in
> assembler for micro based systems was the only way to go or would
> require him to learn C - I thought I was a dinosaur!!!!! A copy of K&R's
> C book and a couple of hours with something like Kiels C for the 8051
> and your away Matt.>
The following email was received from a friend of mine located in
France. I invided him to join the list. His reply speaks for itself.
Steve Eberhart
mailto:newtech(at)newtech.com
---------- Forwarded message ----------
Date: Sun, 12 Dec 1999 21:23:29 +0100
Subject: Re: Translation
I will be glad to subscribe to the new Glass Cockpit list. As I work with
National Instruments' LabVIEW (visualization software, may-be you know it) and
with CAN (Controlled Area Network), I had already decided to develop a small
Glass Cockpit for my bird, of course after completing the construction of my
"Centaure". It will be great to participate in the discussions of this mailing
list.
I am working as an EE in a small company (we are 12 in France and 5 in
Germany) specialized in the liquid leak detection and location systems. As I
am the only "electrical" person here, I develop our systems from A to Z. I
begun with the detection/location method (some physics of materials), then I
worked on the mechanical and corrosion properties of the detection cable (some
chemistry and ME), after it was the real development in electronics
(microcontrollers, displays, power supplies, EMC, etc.) and now I am working
on the supervision software based on LabVIEW... Oh, I also develop the testing
equipment for our products. As you say, the world is small...
As a student in Bulgaria, I had specialized in the Medical Electronics. In
France I obtained my MSc in the Microwave Electronics and now as you see, it
is another field of electronics. C'est la vie! I like it.
Stefan Balatchev.
> I didn't know that you were an EE. THere is a relatively new mail list
> that is developing a Glass Cockpit system for Experimental aircraft. They
> are using a dedicated network bus for all of the sensors and computers to
> talk over. One person has developed the software for the cockpit display
> in Java. It is very impressive. If you are interrested I can send you
> the information to subscribe to the mail list.
> Before getting a second major in Computer Science I was an Electronic
> Engineer for Potter & Brumfield and worked on microcomputer systems for
> testing Relays made by Potter & Brumfield. Before that I worked for
> Motorola building the test equipment for the worlds first solid state
> memory modules, circa 1968. It truly is a small world.
> Steve Eberhart
> THE WING FLIES! - http://www.newtech.com/nlf for info on the new, flight
> tested, KRnet/UIUC airfoils. Good job KRnet, you can be proud of your
> contribution to Sport Aviation. Special thanks to Dr. Ashok Gopalarathnam
> and Dr. Michael Selig for some great Sport Aviation airfoils.
> One test is worth a thousand expert opinions but a thousand opinions are
> easier to get. --plagiarized from an unknown author
> All information, in any of my aircraft related correspondence, is strictly
> food for thought requiring additional, qualified, engineering analysis.
Welcome Ian.
I too am a student of XML. I think XML is going to take everyone by suprise
in a few months! The only problem with using it in this context is the CAN
specification is limited in the amount of data we may transmit. Each "data
frame" in CAN is limited to between zero and eight bytes in the data field.
This is extremely small when you consider IP packets are typically limited
to 512 bytes of user data.
For our purposes, we can look at CAN from two layers: Chip layer and CAN
Kingdom layer. On the chip layer: we can buy microcontroller chips that
have built-in CAN communications from most any chip manufacturer. To see
details of this, check out http://www.mot-sps.com/ and search for "Bosch
Controller Area Network v2.0 Protocol Standard" which is 1.4 MB. (Also see
MCAN8 & MCAN12 document). On top of this is the CAN Kingdom (CDA101) layer.
For a good intro to this, check out these HTML pages:
http://www.kvaser.com/canking/std/index.htm .
Marlin
Subject: | Java flight simulator - now what? |
I've downloaded the java simulator (zip file), unzipped it into a directory
(c:\Program Files\JavaRE\FS) and then the JRE (installed in (c:\Program
Files\JavaRE), opened a DOS prompt in the simulator directory and this is
the result:
C:\Program Files\JavaRE\FS>..\bin\java.exe simulator
Exception in thread "main" java.lang.NoClassDefFoundError: simulator (wrong
name
: Simulator)
at java.lang.ClassLoader.defineClass0(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at java.security.SecureClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.access$1(Unknown Source)
at java.net.URLClassLoader$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
What am I doing wrong?
I have no idea what I'm doing with java....
(BTW: running Win98)
Joe Hovel
Subject: | Re: Java flight simulator - now what? |
I haven't run the simulator in JRE--I've only gotten it to work in JDK, but
I DID notice that you referred to the simulator with a lowercase 's'. Try
'java Simulator' instead. Let me know if this works.
Marlin
Subject: | Re: Introduction, Bob? |
>Hi Bob,
>"players" list yet. I hope you can find time to help out a bit with
>the design chores, it would make me feel less "out on a limb".
Hey, Bob, care to write up a small bio for the players page?
Steve
Steven J. Devine, President, Consultant, TZOGON Enterprises Incorporated
steve@tzogon.com HAM Tech lic: N1YZJ http://www.tzogon.com
http://www.tzogon.com/~steve/glass_cockpit
http://www.tzogon.com/~steve/stolch801
>Steve
I guess I could do that. My resume (only a couple of years
out of date) is available on our website at:
http://www.aeroelectric.com/resume.pdf
Subject: | CAN Bus Solid State Attitude Device |
Came across this AHRS. It advertises CAN bus compatibility. Here's the link:
http://www.imar-navigation.de/ahz_eng2.htm
From: | "Stefan B." <stefan.balatchev(at)wanadoo.fr> |
Hello to all from France,
I am a new member to this mail list and I saw from the recent archives of the list
that Steve Eberhart has already presented me. My name is Stefan Balatchev and I
am
building a KR-style very large prototype. I am an EE and I am more hardware than
software and work well with the low-level languages as assembler and quite bad
with C++, Pascal, Java, etc.
I have already worked with National Semiconductor's CAN microcontrollers and I
had
also decided to develop a small glass cockpit including the tacho, oil pressure
and temp., speed, altitude, and so on.
Prior to enter the discussions I will read all the archive to not discuss
something dj vu.
Stefan Balatchev,
Paris, France
mailto:Stefan.Balatchev(at)wanadoo.fr
The ARINC messages are kinda kludgy. ARINC is still talking about OSI
protocols which are otherwise pretty much dead and buried. They could use
some datacomm help over there.
We actually considered that (see the archives). The CAN stuff looks like
it will be more useful.
Brian Lloyd Lucent Technologies
brian(at)lloyd.com 3461 Robin Lane, Suite 1
http://www.livingston.com Cameron Park, CA 95682
+1.530.676.6513 - voice +1.530.676.3442 - fax
>for a living.
I have access to a resource to do this. Let me see if I can make it work out.
Let's not go there. I spent time this summer fighting off XML as the
"solution" for AAA.
Well, it isn't THAT poplular. The XML camp strikes me as suffering from
the, "when all you have is a hammer, everything looks like a nail," syndrome.
>> becomes easier.
Well, I don't expect to have too many people attached to the CAN buss.
Everything else will be a uP doing the interpretation.
We have that with CAN and CAN Kingdom too.
>> GPS's
>> If you were to see
>> [GPAviationMessage]
>> [Timestamp]
>> [/Timestamp]
>> [Position]
>> [GPSAltitude]
>> [Height] 111198[
>> [Units Feet
>> [/GPSAltitude]
>> [/Position]
>> [/GPSMessage]
... you would have run into the mountain 5 miles down the road by the time
you transferred that across your buss.
Maybe. I don't see that verbosity for the sake of verbosity is a win.
Yes. Read the archives.
Read the archives.
At 11:11 PM 12/12/99 GMT, you wrote:
>Welcome Ian.
>in a few months!
So will AIDS or Hepatitus-B too.
The limit on the size of IP datagrams is 65535 bytes/octets. Most
networking components transmit datagrams up to 1500 bytes/octets without
fragmenting.
>suprise
> >in a few months!
Of course. And not to mention hemoragic fevers such as hantavirus and
ebola; hep-C, cryptospiridium and Vancomycin Resistant Enterococcus.
But I digress.
All,
I have here some correspondence with Jim Meer about AGATE(Lon)databus.
I thought I'd pass it on for what it is worth. I will continue to monitor
this activity, and try and get some technical details.
From: James K. Meer [mailto:microflight(at)att.net]
Sent: Sunday, December 12, 1999 1:05 PM
Subject: Re: Avionics-List Digest: 12/09/99
Craig, This looks like a very good forum to follow. They are talking about
the right issues and may be excused for their indiscretions about AGATE. We
have looked at CAN 2.0 many times and don't think we can get to Level A --
Flight Critical. Without Level A, there is no market. The Kit and Home
market might be able to support a lower technology bus. There are right
about 1553B and ARINC 629 -- overly expensive and complicated. I saw
mention of ARINC 429 which is a point to point bus which is a pain to
implement.
All databuses have warts. Its a matter of picking your bus and trying to
solve the problems. We are not there yet but the need and potential is
there. It will be only a matter of time. Echelon Lon is the best of the
bunch. There are numerous issues to overcome on Lon as well. Lon is a full
7 OSI compliant stack and may be used as a multidrop bus. It has better
collision handling algorythms than ethernet. It has been developed for the
home and commercial automation martkets which are mega huge in comparison to
aviation -- translate to cheap and reliable. Lon has been used in railroad
break safety and human monitering systems successfully.
One of the guys (John Livingston) on the discussion is at WPAFB and has
asked us for more information. I hope he will stay with us and I would like
to hear from this forum from time to time.
I doubt that really answers your question. Your planning/dreaming should
allow for the possibility of sending digital packets through a virtual
wiring system. This will allow changes to be made by dropping nodes onto
the network at a later time and being able to rewire the airplane with
software.
Regards, JKM
James K. Meer,
Principal
Microflight
My responce:
James Meer,
Don't get me wrong, all of what I did find sounded very good. What
bothered me was what I didn't find. Maybe I'm not looking in the right
place. I could not find (draft) specifications on the net. I could not find
a source for the controllers or fiber-optic bus dirvers. There seemed to be
few Neuron chip manufacturers. What little I did find was from Eschelon and
Raytheon but this was more in the form of PR.
Our goup is interested in getting hardware, software and development tools
at reasonable rates so that we can develope avionics modules and systems.
If we can't get this our little project will be still born. My feeling is
that we need to be able to procure something like the following in order to
get folks started:
- specificatons that can be freely circulated
- basic 8 channel sensor module (includes bus drivers) parts < $100 (or
complete < $200) exclude sensors
- software development environment (for PC, most likely C/C++) for <$500
- example (C/C++) starter software that can be freely circulated.
You get the idea. Costs to get into the game must be minimized even for
serious hobbyists. I hope I'm wrong, but it so far the AGATE databus has
all the hallmarks of being tailored for companies that can drop multiple
thousands of dollars before they build their first board or write their
first line of code. We can't afford that, and I personally don't think it
is in aviations best interests. The more people we can get working in this
area the better.
If you could direct us to this sort of info, it would be much appreciated.
I'm very sorry none of us could get to the AGATE databus meeting. Is there a
way to get info on what transpired?
Would you mind if I share your responces with the group? If theire are
things you don't want shared I'll understand, but I'd rather this be done
with the group as much as possible.
There also appears to be some major discrepencies between what is said
about deterministic timing with reguard to CAN Kingdom and LonTalk. CAN
Kingdom supports this. Some say LonTalk doesn't support it at all and so
can't be seriously considered for a critical control system. Others
obviously say otherwise. Do you know of any papers that compare these
protocals WRT deterministic timing?
John,
I was not being negative and the reason I copied you was to let you know
there is some activity in AGATE in this area. Whether we will be successful
is an open question. Your and other's statments about databuses are all
true. I would like to stay informed of your discussions and I will try to
keep you apprised as well.
Regards, JKM
James K. Meer,
Principal
Microflight
James,
I know and I appreciate your input. We are trying to establish links
where ever possible, and we definately want to keep informed with AGATE's
work. I personally think that optical cabling is the way to go for safety
and bandwidth, but I have just scratched the surface and have no supplier,
technical or cost data yet. I hope you don't mind if I bother you from time
to time.
From: | "Joe Hovel" <joe.hovel(at)med.monash.edu.au> |
Thanks, Jerry et al!
It now loads OK (it crashes my computer, but that's another issue....)- at
least I can see what it looks like.
Joe
Subject: Re: Zenith-List: Java simulator - now what?
--> Zenith-List message posted by: "Jerry Coston"
Joe,
I'm a software developer (mainly C++ but in the process of learning java)
and unfamiliar with the particular program you're running, but it looks to
me like you need to set a class path for your simulator execution. This
is
done simply with a "-cp" parameter prior to the executable class name -
ie:
c:\program files\JavaRE\FS> java -cp "c:\program files\JavaRE\FS"
simulator
Also, if the simulator is in a ".jar" or ".zip" format, there is another
parameter "-jarfile" which may need to be used. You can type in "java"
with
no parameters to see these options.
Hope this helps,
--Jerry
Joe Hovel
Senior Lecturer
Centre for Rural Health &
Centre of Medical Informatics
Monash University
www.med.monash.edu.au/crh
www.monash.edu.au/informatics
Subject: | AGATE databus from James Meer |
All,
An update from James Meer. I guess I was wrong about the fiber-optics.
John, I prefer that you bother me. We need as much participation as
possible in whatever form if we are to succeed with a inexpensive databus
for GA.
By the way, the Echelon implementation that uses fibre has been developed by
Raytheon Electronic Systems. I believe they now have a launch customer for
it but have not been in contact for a few months. The Raytheon
implementation uses an asych on top of the protocol to attain determinism.
The asych, among other things, provides a round robin scheduler. Agate's
problem with the Raytheon implementation is that it is very expensive --
possibly as high as $100 per node. The Agate Lon bus will use shielded
twisted pair.
Our goal was to be under $20 per node based upon the avionics being about
35% of the airplane cost on an airplane with $150,000 list price. Echelon
was initially 6$ per node for just a neuron (3120) without microprocessor
which would be ok for simple sensors and controls. It was $12$ for a neuron
and microprocessor (3150) which could be used with avionics and more complex
avionics even an autopilot. Since then the neurons have decreased in cost
to approximately 1-2$ with a corresponding decrease in the neuron with
microprocessor. These numbers and the full protocol make Echelon very
attractive. Having said that there are many issues to be worked involving
the technology, standards and business issues.
If our February meeting is successful, we will be launching an open
standardization effort for the bus. The standards organization will most
likely be EIA since they have the 709.1 standard for the Echelelon LON
technology. After 5 years as an EIA standard, the standard can become an
SAE standard by application. Another important element of the standard
process is to have a repository for standard data packets such as altitude,
longitude, etc. This databus database is being developed and will reside on
a server at the Agate Alliance Association, Inc. (AAAI) which has been
established by Agate as an administrative facility for Agate programs.
If you and/or your other forum members are interested, I will insure that
you receive notices of the meetings. This should help establish a better
understanding of the technology and its potential use.
Regards, JKM
James K. Meer,
Principal
Microflight
On 14 Dec, Livingston John W Civ ASC/ENFD wrote:
> The Agate Lon bus will use shielded twisted pair.
This reminded me of something I ran across in researching various link
layers. It said that shielded twisted pair had a shorter range than
unshielded twisted pair for the same drivers and data rate. The range
for RS-485 or CAN ove UTP even at 1Mb/s was ample so using sheilded
wire might be something we ought to consider as well.
-Dave
Hi,
Well designed balanced systems (i.e. CAN, RS-485, 10baseT, etc.) inherently
have a low sensitivity to common mode noise without shielding. Adding a
shield to them adds cost, typically doesn't help, and tends to create ground
loops. It is generally better to attenuate the noise at it's source. I view
shielding as a last resort.
Jeff
dab(at)froghouse.org
Sent: Tuesday, December 14, 1999 11:05 AM
Subject: RE: Avionics-List: AGATE databus from James Meer
-Dave
Subject: | Re: XML and other data formats |
Almost ignoring the rather scathing comments about XML.........
Can anyone point me in the direction of free tools for developing with
things like LONworks? Last time I looked LON tools cost a small mint.
Its OK for those that are going to steal a copy of the tools from their
employers but the rest of us are left out in the cold by having to aquire
decent tools.
Ian
>... It has been developed for the
CAN was developed for the auto market, also "mega huge".
I don't yet know enough to campaign for any particular solution, but I am about
ready to order some CAN stuff for experimentation. I have not yet ordered
because
there are so many different suppliers to choose from, and I want to make a
good choice. The Motorola MC68HC912BC32 looks really nice, but it isn't the
cheapest.
In my net surfing, I found nothing, zero, zilch available for Lon. Not saying
that there isn't anything, just that it is my impression that the hype about
the "mega huge" home automation market is mostly just the marketing hopes of
the Lon vendor wannabees. Please correct me (and point me to vendors who are
delivering) if I am wrong.
g.
Subject: | shielded vs. unshielded twisted pair |
>Hi,
A twisted pair is a form of balanced transmission line. Anything that
causes an imbalance, e.g. something in proximity to one conductor and not
the other will imbalance the line and cause radiation. A shield will
reduce the capacitive effect of nearby conductors and it will act as a
faraday shield. Yes, a shield will help to keep things quieters, EMI-wise.
You avoid ground loops by grounding only one end of the shield.
The cost of shielded vs. unshielded wire is usually pretty minimal.
Subject: | Re: shielded vs. unshielded twisted pair |
In a message dated 12/15/99 1:45:19 AM Central Standard Time, brian(at)lloyd.com
writes:
> >Hi,
inherently
> ground
view
Brian, I agree completely with your statements and would add that given a
situation where we can be in control of ALL possible noise generating sources
the use of shielded wire might be unnecessary. We do not however have that
option and control with our panels and should anticipate that any noise
sensitive cable will need to be shielded. The cost of shielded wire will be
one of the least of our costs.
Bob Reed,
KIS Cruiser in progress...http://RobertR237.virtualave.net/ (KIS Project)
From NEAMA 2000 draft:
2.7.2 Light Cable
This cable is the type used with industrial bus systems (e.g., DeviceNet,
Profibus, and SDS, and Seriplex). Light cable used in NMEA 2000
applications willshall have the following characteristics:
a) Light cable may be five-wire constructed with two individually shielded
pairs enclosed by an overall shield with a shield drain wire connecting all
three shields. The [optional] shields may be foil or braid.
b) The five wires shall be stranded-copper with each strand individually
tinned to improve corrosion resistance.
c) The light pair used for network power shall be No. 22 AWG (0.38 sq. mm)
or better.
d) The light pair used for signals shall have the following electrical
characteristics:
Size: No. 24 AWG (0.24 sq. mm) or better,
Characteristic impedance: 120 95 - 140 Ohms,
Propagation delay: 5 nanoseconds per meter, maximum,
Capacitance, wire-to-wire: 40 *F/meter.
e) The light cable drain wire shall be No. 22 AWG (0.38 sq. mm) or better.
f) Insulating materials shall be oil and fuel resistant and capable of
withstanding 80C or higher.
g) When the recommended wire colors shown in Table 2-6 are not used the
cable shall be permanently labeled to indicate the color code in use:
Table 2-6 Light Wire Color Codes
Name Pair Color
Shield drain bare
PS+ power Red
PS- power Black
CAN+ signal White
CAN- signal Blue
From: RobertR237(at)aol.com <RobertR237(at)aol.com>
Date: Wednesday, December 15, 1999 8:30 AM
Subject: Re: Avionics-List: shielded vs. unshielded twisted pair
brian(at)lloyd.com
>writes:
>> >Hi,
>inherently
>> ground
>view
not
EMI-wise.
sources
be
>Bob Reed,
I am more worried about our wiring radiating and interfering with the
avionics than I am with other devices interfering with the buss. ADF,
stormscope/strikefinder, and LORAN are all very susceptable to LF/MF/HF
EMI. Anything we can do to reduce crud getting in OR out is a good thing.
Brian Lloyd
brian(at)lloyd.com
+1.530.676.6513
> 2.7.2 Light Cable
Wow, someone got it right! The more I see of the CAN buss, the more
impressed I am.
Brian Lloyd
brian(at)lloyd.com
+1.530.676.6513
Well, we can table the shielded/unshielded issue for the time being.
This would come much, much later. And, because the same conductors are
used, we can even leave this particular detail up to builder's discretion
(though I probably would install shielded cable myself, all grounded at
one common junction...)
Which reminds me... what is the physical installation of CAN? Does it
require some sort of hub/controller (like 10BT UTP Ethernet, which would
also be the ideal location of that ground connection), or does one device
connect to the next (like 10B2 Coax Ethernet)... or is there another
method? Please elaborate (those of you who know) so that I may update the
documentation...
Steve
Gee, I didn't intend to stir up such a hornets nest over a minor point. One
idea I was trying (and, evidently, failing) to get across was that I have
seen shielding used as a crutch to get otherwise poorly designed systems to
work. I want us to get this to work without it, and then we can add it as
insurance.
We do need to be very careful about ground loops, though. The CAN bus
includes a ground reference wire that is separate from the shield. That plus
a shield plus a metal airframe can make the ground loop problem rather
trickier than it might seem. We just need to be sure that everyone who
installs this is suitably educated. (I guess you can tell I've had some
frustrating experience with this sort of thing.)
Regarding CAN topology: It is a true bus, not a star, there is no hub. There
are bus termination requirements to avoid signal reflections, and therefore,
limits on stub length, depending on the termination strategy used. Again,
this is primarily an installation issue. I think this is pretty well
documented in the various specs. It's just that every installer must RTFM
and comprehend it.
Jeff
documentation...
Steve
>insurance.
That is the case with balanced twisted pair. It will work just fine and
will be very robust. And we will do shielding over it to make it even more
robust and resistant to generating EMI.
Been there, done that too. One of the tricks to do with a shield is to
ground it through a 10 ohm resistor. That will limit any current in the
shield while still allowing it to function as an electrostatic shield.
>and comprehend it.
Well, we can hope that people working on airplanes have a greater
propensity to RTFM than your everyday bozo but there will be some
[hopefully small] minority that will screw it up.
Dave and I discussed this in private email. He talked about finding a jack
that would automatically terminate the data buss when nothing was plugged
in. The connectors he found were not what you would call aviation grade.
OTOH, I am of the, "read the manual and do it right," school of thought. I
feel it is better to make the system simpler but require the installer to
read the manual and do it right.
Hey, Electric Bob! You have eons of experience with avionics installers.
Are they generally bozos or brainiacs (or something in the middle)?
From: | "Matthew Mucker" <mmucker(at)airmail.net> |
All,
Well, the debate about the protocol has died down some, it seems. I read the
spec for CAN Aerospace this weekend. While the basic design seems very well
suited to what we want to do, I have to admit that the spec is just too
immature and ill-defined to be put to use. There are quite a few gaping
holes in the spec, and a LOT of ambiguity.
I haven't looked over CAN Kingdom yet, but others have had good things to
say about it. I'll have to crack that one open this weekend. In any case,
I'd advise against us using CAN Aerospace, much as I hate to lose such a
simple interface. It's just not ready for prime time, IMHO.
-Matt
"I don't care what anybody says, there ARE user serviceable parts inside. "
>>and comprehend it.
At 1 Mhz bit rates, and given the limited physical size of airplanes,
it seems doubtful that one would get into trouble with stubs.
From CEOs to floorsweeps, they come in all flavors.
> because
> cheapest.
You could try these URL's for pricing and samples:
http://www.national.com/pf/CO/COP888EB.html
http://www.national.com/pf/CO/COP884BC.html
http://www.national.com/pf/CO/COP87L88EB.html
http://www.national.com/pf/CO/COP87L84BC.html
(sorry, no HTML support by the mail list)
You could also find a cheep (relatively to Motorola's) programmer/debugger from
NS
(or NS' subcontractor as ICE Technology or MetaLink) but I haven't got an URL
for
it.
Stefan Balatchev.
Subject: | Re: CAN Aerospace |
In your opinion, what gaping holes and ambiguity exist in the spec? This
is a common problems with specifications since often what seems obvious to
the author is nonobvious to the uninitiated reader. It may be that a
discussion with the author of the CAN Aerospace spec would fill in the
blanks an eliminate the ambiguity.
Since we were already starting from scratch it seems to me that it would
be easier to remove the holes and ambiguity than to go back to square
one. Is there something you would prefer to CAN Aerospace? Are you
saying that we should reject CAN with 29 bit tags as a base protocol?
Even if we rolled our own HL protocol, why would you reject CAN for the
physical and base messaging protocol? It seems rather simple and straight
forward for general interfacing.
Brian Lloyd
brian(at)lloyd.com
+1.530.676.6513
You would be surprised. I have actually run into problems with stubs at
audio rates. Granted I was dealing with mile long stubs (phone company
not removing unterminated pairs) but I would never had expected it would
be a problem.
I kinda expected that. What I was really getting at is, can they handle
putting terminators on the connectors at the ends of the buss or are they
more likely to ignore that requirement?
Brian Lloyd
brian(at)lloyd.com
+1.530.676.6513
Belden has a special DeviceBus (DeviceNet or Honeywell SDS - so CAN-oriented)
cables - 3082A, 3083A, 3084A, 3085A, 3086A and 3087A. This information is from
their 1995 catalog. These cables have two shielded individually pairs - power
supply pair and a data pair. The DeviceNet cable has also an additional general
shield.
Stefan Balatchev
From: | Marlin Mixon <myshkin(at)worldnet.att.net> |
Subject: | Java CAN simulator update |
I've begun modifying the Flight Simulator code that Dave kindly
contributed. The design is starting to get really interesting because
of the extensive use of threads. Threads, for the uninitiated are also
known as "lightweight processes" which are autonomous bits of code, sort
of like small programs which run independently of each other, but at the
same time are all controlled by their mother Java program. In the
simulator, we can launch a thread for each sensor on the CAN network
that we want to simulate. This way, we can start to see how various
sensor module behaviors can affect the overall system good or bad.
These sensor threads won't have to "invent" their data, rather, they can
take a peek at the flight simulator information that Dave's original
program generates when it "flies." Dave made a nice java class called
flightEnvironment that makes this simple to do.
Yet another thread monitors all of the messages that each sensor pumps
out and ensures that the network adheres to the simulated bus's speed
limit.
The last thread will be one that we can actually use with few
modifications in the final product. It monitors the CAN dataframes as
they appear on the simulated network and communicates that information
back to Dave's flight instruments, completing the loop.
Marlin
Subject: | CAN Kingdom "King" software |
Anybody know if there is source code available for a "King?"
It makes sense to have the "main display" also run the king. My
reasoning is that the main display in the cockpit is going to have the
most sophisticated processing power and the king will need a lot of
processing power--at least it will tax the typical MCU.
Note: Dissenting opinions and reasonings are welcome here.
I'm starting to develop some Java software to simulate the CAN network
and I will want to start integrating the king code soon.
Although I'm doing this work in Java, I realize that any existing king
software is going to be in C or C++. That's OK, I'll be ahead of the
game if all I have to do is convert it.
Careful. These only support CAN 2.0B passive. The word "passive" is
the gotcha. That means they won't crash when they get 29-bit tags but
they won't receive or transmit them either. I'm pretty sure we're
going to end up wanting 29-bit tags.
-Dave
Subject: | Re: CAN Kingdom "King" software |
I agree with you 100%. Processing power is cheap. I was originally
thinking of a pretty powerful processor in each MFD, at least the
equivalent of a Pentium II but probably a Motorola PowerPC chip. We want
it to be able to do display updating at at least a 15 updates/second rate
for the display. People like things that look analog.
Frankly I like Java and Dave's work makes it attractive but we are going to
want to make this fly at some point in time and the FAA is NOT going to buy
off on Java. We just don't have enough control over the libraries unless
we want to go back and review/rewrite them to ensure they are suitable for
life-critical processes.
OTOH, Java and C++ are sufficiently close that there *might* be some
possibility to do some code reuse down the road.
Subject: | fixed vs. floating point calculations |
I was browsing for something else and found a web site that talks about
using fixed-point (integer and BCD) calculations instead of floating point
calculations in uPs used for process control applications. See:
http://www.noga.de/legOS/
if you are interested in this subject.
While we're on the subject, Jack Crenshaw has written at least one book on
this. Must reading if you're doing embedded process control stuff.
-----Original Message-----
Marlin, All,
-----Original Message------------------------------------------------
Date: Friday, December 17, 1999 1:51 AM
Subject: Avionics-List: CAN Kingdom "King" software
David Purdy eluded to the fact that CDA101 C/C++ code written for the
ST2000 remote control boat, etc. would be available. They are also
currently working on aircraft target drones. CAD101 is a CAN Kingdom
implementation right down our alley. See my post awhile back on CDA101
update. David said they were currently in the process of setting up a web
sight for CDA101, etc.
I'll try and get a hold of him and see what we have to do. to get it.
Makes sense to me. By the way, did you know that once the net(Kingdom) is
setup the King doesn't even have to be part of it's normal operation.
I plan to work in Pascal and C++ as much as possible. I've found embedded
Pascal software systems which are compatible with Borland/Inprise products.
If you like well documented, easy to read code, Pascal is hard to beat.
Having done systems programming in Pascal, I found that it requires enough
extensions that it really isn't standard Pascal anymore. It is more like
C with Pascal syntax and the extensions bypass the strong type and
boundary checking inherent in Pascal. For that reason I finally punted
Pascal and switched to C. I think that we will also find that more people
know C than know Pascal.
But I still prefer Java if we can make it work.
Brian Lloyd
brian(at)lloyd.com
+1.530.676.6513
Date: Saturday, December 18, 1999 12:57 PM
Subject: Re: Avionics-List: CAN Kingdom "King" software
C will probably work fine for low level programing, but I really would
like an object oriented language for the more complex stuff that we are
going to get into for the King (and other higher level modules) and its
multi-function graphics display, etc.
What do you think of Delphi/Pascal or C++Builder IDEs?
Are there Java compilers that are efficient enough for the King? I would
think C++ or Object Pascalwould be preferred? Would you really want to use
Java for the little data modules?
It probably would be a very good idea to try and do everything in one
language with one IDE if at all possible; at least initially, in order to
simplify our lives. I guess this will solve its self as we get down to
specific hardware and software.
I want to get started!!!!
What data module chip/s?
What software IDE C++ Builder, MS C ?
What main computer OS: Windows CE?
How do we want to download software to our microcontrollers?
We need to reclarify our short term objectives. I think they should be to
get starter kits out to our members. So why don't we try and identify some
basic development kits and sources if they exist.
Kits we need:
Data module Kit for gathering analog and digital signals.
Data module Kit for controlling actuators such as trim & autopilot etc.
Main Graphics Multi-Funciton display.
Secondary alphanumerics Multi-Function display.
I'm sure y'all have seen this by now. I'm wondering how the Glass
Cockpit ideas of this forum are related (or completely divorced) from
this AGATE work? It would sure be nice if these new "AGATE compliant"
instruments and sensors could also "plug in" to our homebuilt bus. :-)
Greg Reid (I'll introduce myself in a follow-on append)
NASA Hosts Conference On Avionics Standard Databus
New Standard Could Lead To Lower-Cost "Plug-and-Play" Avionics
In recent years we've seen computer manufacturers adopt "plug-and-play"
data transfer standards to simplify and reduce costs for peripherals.
Could a similar standard for GA avionics put a few more pennies in
pilots' pockets some day? Earlier this month NASA Langley hosted a
one-day meeting in Hampton, Va., to establish a databus standards
working group under the Advanced General Aviation Transport Experiments
(AGATE)
program. Their primary goal will be to develop an open architecture,
open standard databus that could reduce the manufacturing and
installation costs for GA avionics in the future. Some of the potential
players attending the meeting were Allied Signal/Honeywell, Rockwell
Collins, Garmin, B.F. Goodrich Avionics, Avidyne, Archangel, Raytheon
Aircraft, Cessna Aircraft, Textron Lycoming, and Advanced Creations. The
meeting also addressed the work required for FAA certification of the
new databus, and proprietary issues related to converting to an open
standard format.
According to NASA, the AGATE industry/government team has already spent
$2.8 million conducting research into a low cost, high speed,
bi-directional databus, producing a significant amount of technical data
that will be shared with new members. Funding for future work will be
provided by the AGATE alliance, with minimal NASA funds also available.
Both NASA and the FAA are supporting deployment of the new databus
technology and the certification effort, and are encouraging more
companies to participate. The first working meeting of the new group is
scheduled for Feb 3 & 4, 2000, in Kansas City, Mo. The AGATE alliance is
open for membership to all U.S. companies, universities and non-profits
in either Principal, Associate or Supporting member categories. Go to
NASA's AGATE Web site http://agate.larc.nasa.gov to learn more about
this interesting, and we hope, worthwhile effort to reduce the costs of
GA avionics.
Subject: | New interested participant: Greg Reid |
Hi all,
I've been following this forum (in its daily Digest form) for a few
weeks now -- ever since someone from this group made an append in
rec.aviation.homebuilt to invite others. (Thanks.)
I'm just starting work on a Vision homebuilt
(http://www.visionaircraft.com) and hope very much to put a "glass
cockpit" into it. Hence my interest in this group ... although it will
likely be 2+ years before I'll actually do any wiring. By then, my hope
is that this technology will be fairly commonplace -- and even more
powerful and yet less expensive.
I'll likely be mostly an interested bystander (i.e. reading much more
than participating), although if I had the TIME to actively participate
in another hobby, this is where I'd do it. This is very interesting
stuff. :-)
A bit of background (and how I might "fit in" here):
I have my PPL, with about 250 hours, although I haven't flown much since
selling my Arrow in '90. I live in Toronto and work for IBM on the
C/C++ compiler back-end (which is also used for the High-performance
Java compiler back-end). While my responsibilities are for the OS/390
(mainframe) compilers, the same optimizing back-end technology is also
used for the PowerPC, Intel, Sparc, and several other platforms.
Naturally, I'd be most comfortable if C/C++ was chosen for this glass
cockpit work -- although I have to admit that my own C/C++ skills are
not all that strong.
(I must caution now that my opinions stated here are entirely my own and
do not necessarily reflect those of IBM ... blah blah blah ... but
seriously, I may need to watch what I say.)
My thought is that I may be able to help with the actual compilation
process of your C/C++ or Java code (on the platform(s) of your choice),
and help shoot any bugs ... on my own personal time and equipment of
course. Unfortunately I don't have much of the former!
Oh, and I also like to dabble in electronics. I have 3 years of a
4-year EE degree ... a "personal matter" forced my withdrawl from the
course, and since joining IBM, I've never felt the urge to go back and
complete it. :-| Anyway, I can speak electronic-speak (tho' am very
rusty) as well as bit'n'bytes.
I'm also pretty good with a wrench, having rebuilt numerous engines of
various types over the years (I'm 43).
Greg Reid
From: | "Marlin Mixon" <marlin_mixon(at)hotmail.com> |
Subject: | Re: New interested participant: Greg Reid |
Welcome Greg. We have discussed Agate plus we have been communicating with
a couple of the Agate folks. I think we should keep an eye on Agate's
progress, but the consensus here is that the bus they are choosing (LON bus
right?) is not as open, nor accessible as CAN seems to be. Hopefully that
will change later and GA will benefit.
Marlin Mixon
>From: Greg Reid <gregreid(at)sympatico.ca>
I am thinking along similar lines... We could create some C++ classes
which can run on either side of the bus... if we could virtualize the CAN
interface, create well defined message objects, etc...
As far as IDE's go, I would plan on writing code to the standard as much
as possible... If we chose, for example, MS developer studio to write code
for our King, using the MFC classes for the GUI, in addition to requiring
windows on our King (which many of us DON'T want to do), we couldn't port
this code over to our little microcontrollers...
However, some common low level classes could be written where commonality
is required (bus and messages), and integrated into whatever development
environment is appropriate for the module being developed.
Steve
Subject: | Introduction: Seth Fuller |
Hello All,
> I should introduce myself such as Greg Reid. I am a student pilot, less
than 10 hrs, but
> have been increasingly intrigued by the topics that I am receiving news
on,
> namely Avionics, Aerobatics, and Homebuilding. I come as a third
generation
> aviator, but have just now been able to afford to fly. I appreciate all
of
> your inputs and am learning quite allot, mostly I will be just a listener
> but as an Electrical Engineer I hope to be able to supply input if at all
> possible.
> Thanks,
> Seth
Subject: | Reply to Instrumentation discussion |
Has anybody considered connecting these instruments over IEEE-488. This is
a very well defined architecture. I'm not sure about the interface between
this and the microcontroller but this type of instrumentation bussing has
been going on for years. Now there is the question of speed? You guys
would have to decide how much data you need and what clock speeds you
require to make good decisions from. Then we could investigate the correct
electrical architecture.
Seth
Steve
<<...>> Seth A. Fuller
Project Leader
Custom Product Branch
Mixed Signal Wireless
8505 Forest Lane, MS 8727
Dallas, TX 75243
(214)480-2933
(972)598-8991 Beeper
s-fuller1(at)ti.com (wk)
sethfuller(at)worldnet.att.net (hm)
Steve,
I don't know of any C++ compilers for the kind of chips we have been talking
about for the "little" boxes. C++ is much more RAM hungry than C and these
things only have a few kb of RAM. I don't see any way around that without
significantly driving up the cost.
Jeff
[mailto:owner-avionics-list-server(at)matronics.com]On Behalf Of Steven J.
Devine
Sent: Monday, December 20, 1999 1:16 PM
Subject: Re: Avionics-List: Software
Steve
>> . . . . . . The AGATE alliance is
>GA avionics.
Thus far, I've personally seen little evidence that
the grand consortium is doing much to revitalize general
aviation. I'm working in the AGATE program at Raytheon
(Beech) and if there's great progress being made anywhere,
I'm unaware of it.
Never used any of them. I'm stuck in the past with emacs as my "ide".
I've been called a curmudgeon before. Can those IDEs even build for
processors other than *86's? Can their debuggers work against an
embedded platform?
> I would think C++ or Object Pascalwould be preferred? Would you
> really want to use Java for the little data modules?
Sure, I'd love to use Java for the little data modules. Even though
there's a JVM for the 68HC11, I don't think I will though because C
would just be so much easier.
> one language with one IDE if at all possible; at least initially, in
> order to simplify our lives. I guess this will solve its self as we
> get down to specific hardware and software.
One thing to always remember. If we spec the bus and protocol,
there's nothing at all requiring the different devices to be running
code that has any commonality. Whoever builds each device can do it
whatever way they're most comfortable with.
On the other hand, one person or a group of people working together
and building multiple devices would very likely find it easier to have
some common code just to reduce the amount of work.
Well, here are my suggestions then.
I decided one day that I'd look around and just pick one. It turned
out not to be quite that simple but I finally decided that I'd go with
one of the PIC's. I actually didn't pick which one but none of them
have built in CAN controllers anyway. PIC (whatever's the name of the
company that makes them) makes a CAN controller that communicates via
an SPI interface. They also have A/D converters that talk over SPI so
I was thinking that a little board with one of the microcontrollers, a
CAN controller, and room for one or two (or maybe more) A/D converters
would make a fine little data module.
The PIC stuff seems to still be available in DIP packages so this
makes this approach accessible to experimenter level people.
As I said, I just use emacs and gcc.
By "main computer" do you mean the MFD? By the time it gets to
something installed in the panel, I wouldn't have any OS in it at all;
just an event scheduler. I could see experimenting with whatever
you've got though.
Back to the PIC. Since they're in DIP packages you can put a zero
insertion force socket on a test board and use inexpensive programmers
connected to a serial port on your development machine. That would
work with either the flash or EPROM versions (or OTP versions too I
suppose but that's not useful for experimenting). For flash versions,
it might be possible to arrange for the chip to be programmable in
place with a special cable.
> Main Graphics Multi-Function display.
Probably the easiest way to get started on this one is to just use a
laptop. If the data module also has a serial port, a different
software load makes it a bridge between the laptop and the CAN bus. A
step up from that is to use a single board computer that's basically a
PC clone, again with the data module playing bridge. Finding a
suitable LCD might take some effort. One possible source here is the
Panel PCs from Advantech. The displays are disappointingly dim but
they are available as touch panels which might be interesting.
http://www.advantech.com/products/panel_pc/ppc-60.htm
If you wanted to get away from Intel based stuff Motorola has a
fascinating new microcontroller called the MPC555. It's got a PowerPC
core with 448KB flash, 26KB SRAM, 32 analog inputs, and two CAN
interfaces on chip. It would be more hardware and software work than
a PC clone of course. Here are a couple boards based around the chip:
http://www.axman.com/cme555.htm
http://www.wuerz-elektronik.com/MPC555.htm
Do you mean like one of those 4 line 20 character, serial
alpha-numeric displays? An interesting idea. Those can be driven a
lot more easily than a full up color LCD.
-Dave
I dunno, it may be that C++ is the way to go. It's certainly faster, but
when we start talking MFC, we start to narrow down the operating system,
don't we? (hint: that 'M' in MFC doesn't stand for multi-platform) What
about X Windows? Is there anything there that would allow us to write in X
and cross compile for different OS's?
Marlin
>From: "Steven J. Devine" <steve(at)tzogon.com>
>Steve
>talking about for the "little" boxes. C++ is much more RAM hungry
>than C and these things only have a few kb of RAM. I don't see any
>way around that without significantly driving up the cost.
Jeff, OK... screwed up the details, but the concept sill remains... we
should build one library of standard C functions and structures for CAN
interfacing and messaging... for the king, we can write a C++ wrapper aroud
those functions if people want that sort of interface... the point was to
write one common library, particularly for the messaging component...
>but when we start talking MFC, we start to narrow down the operating
>system, don't we? (hint: that 'M' in MFC doesn't stand for multi-
>platform) What about X Windows? Is there anything there that
>would allow us to write in X and cross compile for different OS's?
>Marlin
>to something installed in the panel, I wouldn't have any OS in it
>at all; just an event scheduler. I could see experimenting with
>whatever you've got though.
>Dave
(I just used Micro$oft's MFC to illustrate the point (and certainly don't
want to use it in the system))...
Marlin, I'm thinking more along the lines of what Dave is saying... we will
have *SOME* sort of OS, but very minimal... we write the code for the
display ourselves, and not depend on MS Windows, or X services... we're
most likely talking about standard VGA controllers... they are easy to
program, and graphics libraries are a dime a dozen... plenty of free
libraries to assist in this...
Steve
Subject: | Hungry Programmers |
I seem to be hearing noises that sound to me like a bunch of hungry
application programmers wanting to tare into some code. Woe, steady
boys!
I'm hearing things like:
What main computer OS?
What software IDE?
What data module chip?
What language?
Etc.
Let me make a few rash statements:
OS? Who said we were going to use an OS? There sure as hell isn't going to
be room for much of an OS in the little sensor boxes. It's not clear to me
that there's much need for one in the display module either. It's not as
though it's going to have a disk and a file system and all that.
And let's get rid of this "main computer" talk. The whole point of the bus
design is that there is no "main computer". After the system is configured,
and the "King" code is dormant, we should be able to smash any one box with
a hammer and have the rest of the system keep right on going. (visualize
pink bunny)
I think someone said something like "How do we boot up the sensor modules?".
Huh... The code's all in EPROM, there's nothing to boot. If you mean how
does the code get into the EPROM's, well, it depends on what chip we use.
But what difference does that make to the design?
There is no rotating memory in the system.
This system will look nothing like a PC. (though we may use PCs to prototype
some parts)
It may well be that no two boxes use the same CPU.
Some boxes may use more than one CPU.
I don't even want to hear the words "garbage collector".
An IDE is something that runs on each persons development system. It's not
part of our system. I see no need to pick ONE. As long as we can each load
each other's source files and generate hex files from which to burn EPROM's
that's all the commonality we really need. (More might be handy, though)
A Microchip PIC would be the worst choice for a sensor box CPU. (that'll
light some flames).
Ok, I've got my flame proof suit on, have at me.
Steve,
I understand what you're getting at, I think. It would nice to at least have
common header files (".h") for the various processors. That would give us a
way to get some semblance of configuration control. Common code is ifyer.
For instance, what if some boxes are little endian and some are big endian?
It can get ugly.
Jeff
Subject: | Re: Hungry Programmers (hee hee hee) |
Jeff...
Have to admit, I got quite the chuckle reading this... (but I'm weird like
that).
>hungry application programmers wanting to tare into some
>code. Woe, steady boys!
Yah dude.
>What software IDE?
>What language?
>Etc.
I already covered this last message... agreed.
It's *A* display module people! Not the "main" computer, (especially
considering the fact that I intend to have three (or more?))...
(you can tell the true geeks because they nest their parenthesis(like me)).
(I *HAVE* to get around to looking at this CAN Kingdonm stuff... can we
have multiple kings? Or is one *THE* king? grr... not enough time...)
>modules?". Huh... The code's all in EPROM, there's nothing to boot.
>If you mean how does the code get into the EPROM's, well, it depends
>on what chip we use. sBut what difference does that make to the design?
Yup yup! I was wondering if anyone else was thinking along this line...
Well, perhaps not in yours... that is up to the user... if I want to build
in a CVR or FDR, I'll need permanent storage...
>prototype some parts)
Uhhh... I'm thinking that my display module will look like a PC... a lame
laptop with a standard VGA screen and no real keyboard and certainly no
mouse...
*snicker* hee hee hee
Hmmm... might prove difficult? If we were to all be producing code for the
modules (to burn eproms), then we would all need to have compilers which
build to the target CPU...
This is where the different experience and capabilities of the players comes
in handy. I might be inclined to get a EPROM burner, and exchange coded
EPROM's for ready to solder etched boards...
No flames from me... I may burst into hysterics, but not burst into
flames...
Steve
Subject: | Re: Software... Cowboys and Endians... |
>Steve,
have
>It can get ugly.
One little, two little, three little endians...
OK... just kidding... (in rare form tonight!)
One thing we know for sure... the messages *on the bus* will all be
consistent... so one data structure can be built to represent this... if
there is code required to parse the message, and convert it to a native data
type (such as byte ordering), that can be an included helper function in the
library.
...isn't that what #defines are for? That's how we write "portable" code
across different flavors of UNIX... you set certain #define's based on your
local configuration... whatever, you get the idea...
Steve
There was some talk not long ago of true Java compilers. I heard that
someone was going to do a Java front-end for GCC thus allowing you to
compile Java to object code. This eliminates dynamic extensions to code
which is something we have discovered is very nice. Even so, our tests
about 3 years ago put Java with JIT in the 70% performace realm relative to
GCC. If you don't have 30% slack in your processor, you have probably
underdesigned your system in the first place.
This is where protocols and interfaces are more important than specific
software and hardware. You should be free to create any hardware running
any software you want and still have it play on the network. Look at the
Internet. It works in spite of the rather eclectic mix of Unix, Mac,
Windoze, mainframes, and various smarter-than-the-average-bear process
control whoopties. The model works.
We need our best guess at protocols and messages first.
Which one do you like?
You forgot Java. Even so, which one do YOU want to work with?
Pardon me but someone just shoved a spoon down my throat. This has
triggered my gag reflex.
Well, it might be nice if we could do it over the net. That should be part
of our protocol suite, i.e. a firmware download protocol.
It may make sense to do a pseudo system first. Dave's simulator is a
perfect example of something that people can use now as a base without
having to run custom hardware. All you need is a CAN interface and some
driver software. We can play with code on our PCs.
Here is a wacko idea: let's come up with a CAN-over-IP encapsulation so we
can test across the Internet. That way if one developer comes up with a
data source and another with a data sink, they can test each other's
implementations over the net.
>Kits we need:
I know where this is being developed.
We probably need a sim for this first.
Use your PC for now.
Subject: | Hungry Programmers (hee hee hee) |
Steve,
Glad to hear I'm at least entertaining.
Know what you mean about the CAN Kingdom stuff. I've only skimmed it myself.
I think there is only one King allowed, but he only has to be there during
system configuration. Someone please correct me if I have this wrong.
For data logging those flash modules that they sell for digital cameras are
pretty cheap and drop proof.
By "This system will look nothing like a PC" I meant in terms of software
and look and feel. You're correct that we could steal some parts of laptop
hardware designs.
You said: "then we would all need to have compilers which build to the
target CPU"
...Ur, um, well yeah. We will have to standardize on one compiler per target
CPU. But the development environment in which we run that compiler is
optional.
Then you said: "This is where the different experience and capabilities of
the players comes in handy. I might be inclined to get a EPROM burner, and
exchange coded EPROM's for ready to solder etched boards..."
You know, it's kinda hard to email those EPROM's. But seriously folks,
depending on our chip choices, those may be EEPROM's embedded in flat pack
CPU chips that are soldered to boards before they are programmed. This "in
circuit programming" seems to be the trend these days in the embedded
processor world. This is a detail we can cope with when we get there. I've
been doing that kind of stuff most of my life, it's not a big deal.
Jeff
Jeff...
that).
Yah dude.
>What software IDE?
>What language?
>Etc.
mouse...
flames...
Steve
Subject: | Software... Cowboys and Endians... |
Yup and yup.
library.
Steve
Brian,
Tell me you're not seriously suggesting we use Java on the little boxes!
Read my lips: no garbage collectors! I want code that I can prove works.
Besides which you're doing well get a C compiler for those chips.
I know there is a GNU Java front-end for GCC project. Last I heard it wasn't
working yet.
Lend me that spoon when you're done with it.
This "download code over the net" talk is making me nervous. In an
operational system, I don't want there to be any way to reprogram a module
that doesn't involve unplugging it and unscrewing the lid. Even in a
prototype environment this seems like doing it the hard way to me.
That CAN-over-IP idea is not all that wacko.
You said: "Data module Kit for gathering analog and digital signals. I know
where this is being developed." Really? Is it a secret? What chip have "we"
picked?
Jeff
[mailto:owner-avionics-list-server(at)matronics.com]On Behalf Of Brian
Lloyd
Sent: Monday, December 20, 1999 6:37 PM
would
Here is a wacko idea: let's come up with a encapsulation so we
>Kits we need:
I am not suggesting one way or another. That is why I am focusing on the
wire protocols.
That said, I happen to like Java. If you have a Java compiler you can
change how memory is managed. Even so, we have done a lot of event-driven
server programming with java. Frankly, once we allocate an object, we
reuse it rather that throw it away. That pretty much eliminates the
garbage collector ever running. We got tired of garbage collection
putting spikes in the response time.
Another way of putting it: "Java! It's not just a programming
language; it's an adventure!"
> working yet.
I'm not surprised. Nothing ever happens as fast as you want it to.
Just as soon as we define the virtual spoon passing protocol (VSPP).
Most newer avionics boxes permit database downloads and some support
software upgrades over a serial link. It is much nicer to be able to fix
a problem by plugging new code into the box than by having to pull the box
out of the aircraft. Once you have your avionics buss installed it is the
logical channel for such upgrades. Sure you want some sort of sanity
check the prevents an upgrade in-flight, of course. (Hey Ralph! Just
hold that left turn until the FMS reboots after the upgrade.)
I don't think so either. Actually I think it would be a REALLY useful
tool.
> picked?
It doesn't matter since you probably won't get to fiddle with the
guts. It will be a black box to you. If it happens sooner rather than
later (sometimes we win) I will get the info here sooner rather than
later.
Brian Lloyd
brian(at)lloyd.com
+1.530.676.6513
> optional.
That might be nice but it shouldn't be mandatory.
I used to ship EPROMs in padded envelopes all the time. Use conductive
styrofoam. It provides sufficient rigidity to protect the pins. PLCCs
are even better; no pins to bend.
You need some sort of low-level executive that will handle starting
processes, interprocess communications, and a way to generalize device
interfacing. This sounds like an OS to me. Some people call this a
real-time executive. Trying to build any sort of semi-complex software
without one is like beating your head against a brick wall; it feels
really good when you stop.
It should be sufficiently general that you can move processing functions
from one box to another. One of my failure modes has critical processing
moving from one display to another automatically. This implies some sort
of intermodule health monitoring.
The modules should be autonomous if possible.
If a box has flash and the equivalent to a boot ROM, you can force working
code into it and reboot it to start the new code. This strikes me as
being *really* useful. Imagine you discover you have a code problem but
you are in the middle of nowhere. You land, whip out your cellphone, grab
the fixed code from the author/vendor, upgrade the errant box, and take
off again 30 minutes later. If you want to get really crazy and you have
an in-flight telephone ...
Consider multiple flash modules. 96MB seems relatively common now. You
can also get 1GB type-III PCMCIA disks. Tiny and capable of handling more
G than you or your airplane.
> mouse...
Hey, it is just another algorithm and data structure. It may prove very
useful in some aspects of the design. Let's not get too religious here.
(Except XML which is just evil. :
Brian Lloyd
brian(at)lloyd.com
+1.530.676.6513
Brian,
Java is just not the sort of adventure I want to take flying.
What do you mean by: "you probably won't get to fiddle with the guts". I'm
an EE, fiddling with the guts is what I do. I don't believe in black boxes.
What in hell are you talking about, anyway? Dave's PIC project?
Jeff
know
"we"
> picked?
later.
Brian Lloyd
brian(at)lloyd.com
+1.530.676.6513
Brian,
For clarity I've prefixed my comments (below) with "==="
Jeff
target
> optional.
=== Ok, let me try again, all I was trying to say was that all the code in
any one ROM image has to come out of one compiler. That is unless you can
find two that have the same rules for stack layout, calling conventions,
etc.
=== email, I say Email, It's a joke, son.
=== Well, to be sure, I at least WANT some sort of RTOS. I'm just worried
that some are thinking of something like WinCE. <--pun alert. Also, you'll
have a very hard time trying to wedge an RTOS into a low end PIC, for
instance.
=== Please tell me you're just kidding! I at least want a jumper on the
board to disable this "feature".
=== Repeat after me: "Non-deterministic code doesn't belong in airplanes".
I'll vote against XML if you vote against garbage collection.
Display modules will require a powerful processor, that much is agreed.
For them third generation languages like C, C++ or Java makes sense.
Now, the Sensor modules, OTOH, will be running on MCUs. Unless I'm
really naive here, I can't imagine a sensor having more than, say, three
pages of assembly code because all the program needs to do is poll the
A/D ports and convert them to real-world units and encode them into CAN
( [sensor id] [data value] ) and put the dataframes onto the bus. It
would also poll the counter ports and encode them as well. Then it
might enter a timing loop and finally start at the top again.
Any hidden complexities there?
Also, I agree with Jeff about storing the code for each MCU on a local
EPROM. I assume that this means if power is interrupted for whatever
reason, the MCUs can be back to work in less than a second, right?
Note the above disregards the complexities of interracting with the
king.
Marlin
"Jeff Barlow" wrote:
> we should be able to smash any one box with a hammer and have the
> rest of the system keep right on going. (visualize pink bunny)
Does that mean we're going to call this project "pink bunny" with
a logo consisting of a pair of dark glasses perhaps?
Marlin
Marlin,
Well, I think the code will end up a bit bigger than three pages of
assembly, but I think you've got the general idea right. The timing will end
up being driven by interrupts from the CAN controller and the A/D, etc. The
CPU may spend most of the time halted, waiting for an interrupt.
They should be alive within milliseconds after power on.
For an example of the sort of chip I would like to use see:
http://www.fujitsu-fme.com/products/micro/can/03.html
Jeff
[mailto:owner-avionics-list-server(at)matronics.com]On Behalf Of Marlin
Mixon
Sent: Monday, December 20, 1999 10:36 PM
Subject: Avionics-List: MCU programming
king.
Marlin
From: | Frank and Dorothy <frankvdh(at)ihug.co.nz> |
Subject: | Re: MCU programming |
I think a couple of pages of C might be nearer the mark... there's the
business of handling incoming commands and so on. Also things like a
watchdog timer, initialisation code, etc.
But this does depend on how smart a particular module is going to be and
this leads to a philosophical design point; are we going to have one
module reading all 4 CHTs (for example), or one module for each? A
4-into-1 CHT measuring module is going to be more complex than a 1-to-1
module obviously.
> EPROM.
Do we want to add a layer of complexity by storing code in Flash
memory... i.e. reprogrammable in situ? Just playing Devil's Advocate
here; I tend to think not. In fact, I'd go for a single-chip controller
with on-board ROM and RAM.
Do we want to download calibration constants and suchlike to the unit?
If so, store it in EEPROM or Flash? Or just download at start-up?
You tell us! :-) How long can you live without an altimeter? A VSI? An
ASI? A CHT? My actual feeling is that almost always I'd be OK if it came
back within 10 seconds. OTOH, I see no particular difficulty with
meeting your 'back in one second' spec.
Frank.
I like it... the Pink Bunny Glass Cockpit project...
I'll have the wife draw up the logos... we can paint it on the side of the
cowl (though I'll have to cover up some of the hot rod style flames).
Steve
Subject: | Re: Hungry Programmers |
It's not that bad. I only half disagree with one thing you said and
want clarification of another.
This is the one I half disagree with. The reason I like garbage
collection is it eliminates something like half the bugs in a complex
program (where complex is defined in this case as actually allocating
and discarding memory regularly). In fact, some studies have shown
garbage collection to be faster than the same algorithms coded using
the malloc and free library functions (which may really be more of an
indictment of the general poor quality of malloc and free).
It's only a half disagrement because it's just so damned easy to do GC
wrong and have it be a pig.
> CPU. (that'll light some flames).
No reason to flame but I do want to know why you think this. To me it
was just another microcontroller. So what's wrong with the little
buggers?
-Dave
>Brian,
Have you written and debugged software with it? Our experience is that
using java tends to result in programs that have fewer bugs. Its
performance is good too. If you constrain the library, it can be
relatively compact.
Yes you do. You already treat a microprocessor as a black box. Do you
treat a PC motherboard as a bunch of chips or do you treat the motherboard
as a component? I bet you use potted modules and monolithic power supplies
as "black boxes." What we accept as a "component" varies with our current
point of view.
I should have kept my mouth shut. There is a possibility that a module
will become available that does analog data collection that provides that
data on a CAN buss.
Brian Lloyd Lucent Technologies
brian(at)lloyd.com 3461 Robin Lane, Suite 1
http://www.livingston.com Cameron Park, CA 95682
+1.530.676.6513 - voice +1.530.676.3442 - fax
>Brian,
>Jeff
>target
>> optional.
>etc.
That is obvious but I was thinking on a macro scale where we are working
with multiple modules. We may choose different tools to build the
different modules. I think that people are diving too deeply into this
right now. We need an overall interconnection architecture before we can
dive in and start to build anything. If nothing else we need to at least
agree that we are going to use CAN and CAN Kingdom with the protocols and
messages that entails.
Duh. I read that as "mail" not "email." Never mind. :
>instance.
A nonpreemptive scheduler using shared memory and semaphores for IPC can be
very, very small. This assumes that the processes are burned into the
final system image so you don't need loader functions.
I was half-kidding about the upgrades in-flight but the rest is very real.
The system should be upgradable in the field without a forklift or even a
screwdriver. A technician should be able to plug into the buss in order to
troubleshoot and upgrade the system on the ground. Sure we should have
interlocks to prevent someone from yanking the system out from under you
while you are using it but it shouldn't be a jumper. I might give you a
keylock switch somewhere but that is just an input to the software.
As I pointed out, the tendency should be toward preallocation and reuse of
resources without needing to rely on recovery of released resources, i.e.
roughly translated, "avoid using garbage collection." But I can see times
when I have two mutually exclusive functions on the same component that get
used at different times. When I am done with function 1 and invoke
function 2, I probably want to deallocate the memory and device resources
allocated to function 1 so that function 2 may use them. This is a form of
"garbage collection." It is very real and has a place in this system. It
doesn't necessarily violate non-determinism in the code.
Brian,
Actually, I do tend to think of a PC motherboard as a bunch of chips. I've
never bought one yet without looking to see what chips it's using for what.
I started out working with tube circuits; my mind tends to operate at a very
low level of detail. That's not to say I recommend that point of view,
drives me nuts sometimes.
Ooh... very hush, hush.
point of view.
data on a CAN buss.
Yes. You want some sort of watchdog that will reinitialize the module if
it becomes comatose. You might also want to overlap the data collection,
processing, and data transmission (I am reaching a bit here but I would
rather be conservative). You might want a listener to allow you to modify
the sampling rates under user control from a remote device.
I don't think that anyone was ever implying that the box would want to
remote boot although that would be a really nice option for getting the box
on its feet the first time. I do want a way to download new code to a box
remotely. Every box should have sufficient flash that you can have two
complete copies of code residing in flash concurrently. The box is running
one image out of flash while downloading a new image to the other half of
the flash (this implies that the flash may be erased a piece at a time).
The last thing you change is the pointer that identifies the active image.
This mechanism will allow one to interrupt a download and reboot the system
and guarantee that it will reboot with a valid image.
>king.
Right. This is just plain old good design practice. I deal with this sort
of thing all the time. In big networks, I need to be able to upgrade the
network piecemeal while the network is still running. I may never be able
to "reboot" the whole network all at once. As avionics systems get more
complex and begin to look more like large datacomm networks, they are going
to need the same sorts of features.
I plan to use Pascal for my initial CAN experiments on the Atmel micros. I am a
big fan of Modula-II,
but don't know of any implementations on micros.
g.
Subject: | uP for CAN experiments |
I previously posted:
about
> because
> cheapest.
Someone responded with the url's for some National Semiconductor parts, that are
all ROM or OTP.
A requirement for me is Flash or EPROM.
After some hours of surfing, I have selected the Atmel AVS series, and ordered
a
development kit.
Cheap, available, flash, nice instruction set, nice range of part sizes and
costs.
Also-rans: PIC - very available but the instruction set is not as nice. Wanted
to use because the company
is so hobbyist friendly.
Motorola 68HC12 - not available in cheap packages, and somewhat difficult to
get.
TI MSP - my first choice for architecture, but very difficult to get.
Indications are that the flash parts
really don't exist.
For the CAN controller, I plan to try the one from the PIC folks. Have not yet
tried to order one.
Curious what others are using...
g.
Subject: | Re: Reply to Instrumentation discussion |
We have been beating on this for some time now. I suggest you go back and
read the archives. We have more or less converged on the CAN buss and the
vehicle for moving bits around.
Glen,
I can't believe it! There are two of us? I love Modula II.
From: Glen_Worstell(at)notes.seagate.com <Glen_Worstell(at)notes.seagate.com>
Date: Tuesday, December 21, 1999 1:59 PM
Subject: Avionics-List: language
embedded
am a
>g.
Dave,
Gee, it sure is hard to stir up trouble, here.
My main problem with garbage collectors is that they tend to be a crutch to
make sloppy code with memory leaks sort of work anyway. (You said
"eliminates ", I say "hides") I don't much care for malloc and free either,
for that matter.
Let me back up a little and make sure we're all on the same page here.
First of all I assume we are only talking about the display boxes here. The
little sensor boxes aren't likely to have enough RAM in them to handle that
kind of overhead, anyway.
Second, I assume we'll be running the displays under some sort of
lightweight prioritized preemptive RTOS.
In that environment any sort of global (across processes) dynamic memory
allocation tends to stir up a lot of priority inversion and deadlock
problems. Adding GC to that typically makes matters worse since it runs in a
low priority process. There are ways around that, but they add even more
complexity.
Maybe I'm just old fashioned, but I like dedicated, per process (or per
priority level) memory allocation. That way, when you don't have enough RAM
to run well, you can tell right away. Obviously, things like intertask
message buffers must come from a global pool. (Well, not necessarily...)
Here is what I see happening: We will have a lot of folks, with various
levels of experience on real time systems, writing code. They will each do
some kind of module level testing with appropriate stubs. At that point some
of this code that appears to work will still have reentrancy bugs, memory
leaks, and such like.
The "real" debugging will happen when we start to do system integration.
Things will sort of work, till we crank up the load on the system. Then we
will start to see: stack blowouts, deadlocks, tasks that seem to hit
performance walls, etc. Much of this seems inevitable, it goes with the
territory. (BTDT)
My experience has been that if you keep the memory allocation as
straightforward and deterministic as possible it makes this system level
debugging much less painful. I attribute at least half of my gray hair to
this sort of debugging.
On the PIC issue I will first quote myself from a prior message:
> Considering the way the bus design is going, I don't think we're going
> to get very far with a real low end (i.e. PIC) "sensor box"
> processor. It could be done, I'm think, but I fear the effort would
> be a little too painful.
> There are C compilers available for these things, but the chip
> architecture forces them to generate very inefficient code. That,
> combined with the limited memory available, limits what can be done
> in C to fairly trivial projects. (Don't even think about C++, Java,
etc.).
> I have used these chips (and Z80's, 8085's, and even older things)
> to do some fairly tricky stuff, but that has always been with very tight
> assembly code. I personally don't aspire to do any more of that "hand
> polishing each bit" sort of coding.
> Trying to do that sort of thing in the context of a geographically
> diffuse group project would be a recipe for frustration. It will do
> us no good to have a real cheap box if the firmware is never done.
To get an idea of a reasonable alternative take a look at:
I have the CDROM with the C compiler, etc. on it and I'm currently trying to
chase down some sample chips. I keep you posted.
Jeff
buggers?
Brian,
I think you must have more faith in hardware than I do. I don't even trust
an EEPROM not to erase itself spontaneously. I have seen it happen! I really
do want that jumper. You can leave it off yours if you want.
Re the memory allocation issue, see my reply to Dave.
Jeff
Glen,
Take a look at:
Jeff
about
> because
the
> cheapest.
are
all ROM or OTP.
ordered a
development kit.
costs.
Wanted
get.
really don't exist.
yet
tried to order one.
Good thing it's so much fun.
> crutch to make sloppy code with memory leaks sort of work
> anyway. (You said "eliminates ", I say "hides") I don't much care
> for malloc and free either, for that matter.
Actually, I look at it as letting the computer handle garbage
collection rather than the programmer.
I'm willing to accept that. Even with a JVM available for the 68HC11,
I was mainly thinking about the larger systems like a display.
I make no such assumption. Though if the display code was written in
Java, the language itself sort of comes with a lightweight,
prioritized, preemptive threads package. We're not required to use it
though.
> memory allocation tends to stir up a lot of priority inversion and
> deadlock problems. Adding GC to that typically makes matters worse
> since it runs in a low priority process. There are ways around that,
> but they add even more complexity.
Those are good reasons not to run a prioritized, preemptive RTOS. I
like non-prioritized, non-preemptive event schedulers myself. Very
simple, very small, very easy to understand. They do have the problem
that the whole program needs to be designed to work together.
Piecemeal work is likely to have bad interactions.
> [Examples of the many problems of manual memory management.]
> level debugging much less painful. I attribute at least half of my
> gray hair to this sort of debugging.
It's interesting that the problems you bring up are exactly why I'm
intrigued by garbage collected languages and systems. Write the
garbage collector right once, and then you don't have to worry about
those class of problems anymore. It's pretty nice. Of course the
real world is never so simple, that's why garbage collectors are still
somewhat unusual.
Sorry, I guess I missed it the first time. You're right that they are
very limited little processors.
Looks like nice stuff. The only concern I'd have is we either have to
find someone making a single board computer with these processors on
them or we've got to build our own. These are surface mount only
chips and for now that's beyond my hardware ability. Any volunteers?
> trying to chase down some sample chips. I keep you posted.
I'm very interested in what you find out.
-Dave
Subject: | uP for CAN experiments / modules |
Since a good portion of the group seems to be focusing on the
microprocessors, perhaps we should build a table listing the attributes of
the various processors mentioned, and add it to the hardware pages.
Some items to consider... cost, clock speed, instruction set, built in
interfaces, RAM, ROM, ability to obtain pre-made SBC's, compiler options,
etc... as well as some freeform text noting any other pros/cons or other
special considerations.
Once the data starts flowing, I will compile this into a table on the
hardware page...
Once we have a firmer grasp on thew requirements for each module, we will
have an easier time selecting the appropriate part for the job...
Steve
(again with the 130 message inbox... got to find some way of making sense
of this and updating the web site)
Steven J. Devine, President, Consultant, TZOGON Enterprises Incorporated
steve@tzogon.com HAM Tech lic: N1YZJ http://www.tzogon.com
http://www.tzogon.com/~steve/glass_cockpit
http://www.tzogon.com/~steve/stolch801
Dave,
See === lines
Jeff
=== Last time I looked your average programmer was still smarter that your
average computer.
The
that
though.
=== It's a group project, not a one man show. "Piecemeal work" is going to
be the name of the game. Also non-preemptive event schedulers have terrible
performance in terms of interrupt latency. (I've done both)
somewhat unusual.
=== Gee, I guess that's another assumption that I should have stated. I'm
thinking of this as a real world project, not just hanger flying.
=== You software guys, you always want that predigested, ready to use
hardware. Where's the fun in that? Actually surface mount is no harder
to work with than thru hole, once you get used to it. You just use a smaller
soldering iron and a big magnifying glass. You might as well get used to it,
DIP's are on the way out. See
http://www.twinhunter.com/Products/T_SMT_Prod.htm for SMT proto boards. I
can solder a chip to one of these for you if need be.
>>Has anybody considered connecting these instruments over IEEE-488...
>and read the archives. We have more or less converged on the CAN buss
>and the vehicle for moving bits around.
I really ought to keep the complete list of considered busses and such
online... that way we can simple refer people to the web site for a
summary of the prroject and current status...
Steve (*still* behind in web site maintenance, but working on it)
Steve,
I have just finished lurking through your site. I found my name up there
and wanted to extend to you a thanks for having me on the team. I hope that
I will be able to contribute a bit. At my former position, recently
transferred to Texas Instruments, we use a UNIX based software called QNX.
It was a real time operating system used to track satellites. Of course
this was our application. Not being a Software Engineer, I am not going to
stick my neck out too far but just submitting ideas. Most of our Software
Engineers wrote code in a Visual C++ environment. Secondly, I am very
familiar with the Trimble versions of GPS. I have particular experience
with the Lassen SK-8. This is what we used to get our site local and
altitude for the antennas. Do not use this receiver for altitude reporting
as it is not differential and the accuracy is only about 50 ft. As far as
location, it was excellent! It utilizes the standard 'egg' style of antenna
and the total package is less than $1500.00 Well there is my two cents!
Seth
>Brian,
I started out with empty-state devices too. I have this variable view of
what is the component level. Sometimes the motherboard is a bunch of chips
and sometimes it is an opaque module.
I should hope so. I tend to fly single-engine aircraft a lot.
>I don't even trust
If the hardware isn't reliable then this is all window dressing and we
should quit now. I think we are talking more about software reliability
than hardware reliability.
Subject: | three random comments |
1) I intend to try to allow for the nodes on my experimental CAN network
to be programmable over the network. I see no reason why this is not reasonable
in an aircraft, as the programming (the way I will do it) would require
connecting a
PC to the network, something I'd do only on the ground. There is zero
probabality
that a node could accidently program another node, given that there will
be some sort of protocol. My experimental network, btw, will not be in an a/c.
2) Steven J. Devine wrote:
> ...Since a good portion of the group seems to be focusing on the
> ...Once the data starts flowing, I will compile this into a table on the
hardware page...
Great idea. To minimize the noise on this forum I'll send my comments to
Steven (except that I'll post a little one now:)
3) My selection of silicon for my experimental CAN network has been
frustrating. I want something with flash or eprom, low cost but powerful
enough, easy to get in small quantities, etc etc. So far I have not found
anything exciting, except promises. A new contender on my list is the
TMS320-F241. Anyone had experience with it? Meanwhile, continuing with
Atmel and trying to find a stand-alone CAN controller that I can actually
get.
g.
PS - my take on Java, garbage collection, RTOS, and all that is very
pragmatic: I am comfortable with any or all of it, as long as it works
and tests/analysis show it to be reliable.
That's an assumption we agree on and is also a middlin-fair criticism
of garbage collection.
-Dave
Subject: | Re: three random comments |
This makes sense to me. A feature such as this will prove very useful
during development and will be useful for upgrading a system in the field.
If it scares you, don't use it but don't try to hamstring everyone else by
eliminating the capability.
>hardware page...
I don't see why this shouldn't be open discussion on the list.
Ahh, I like this attitude. Sounds like you want to base you decisions on
fact and test results rather than hearsay and innuendo.
Subject: | Some Interesting Aviation Sized Computers |
I found these four sites which have some very interesting products which fit
our size and weight requirements for processors and drivers. Check them out
and give your opinions.
http://www.cellcomputing.com/
http://www.emjembedded.com/
http://wearables.stanford.edu/
http://www.jumptec.com/
They don't have any prices listed but look most interesting from a size,
weight, and portability standpoint. The Embedded Systems site has some
interesting A/D boards worth taking a look at.
Bob Reed
From: | "Joe Hovel" <joe.hovel(at)med.monash.edu.au> |
This is a bit off-topic (it's avionics but not glass cockpit related)...
I've got hold of an Attitude Indicator (AH) which runs on 115V 400Hz and
wondered if any of you clever people either have a circuit design or can
come up with one for a 12V DC to 115V 400Hz inverter?
There is apparently a commercial aviation version of these things, called a
"peanut inverter", but I've not found one thus far. I'm obviously capable of
building a small electronics project like this safely and to an appropriate
standard for aviation (or I wouldn't ask or consider it), but have no skills
to design one.
I've also got an electric turn co-ordinator which needs 28V DC 200mA and
want to do something about getting it going on 12V - I have a 12 V DC to
18.5V DC inverter (NEC Laptop computer car power adapter) which I could
modify to produce 28V... I could draw the circuit of by following it's
internals and get one of you EEs to look at that?). Maybe someone has a
circuit to build one of these from scratch too?
Joe Hovel
From: | "Matthew Mucker" <mmucker(at)airmail.net> |
Date: Wednesday, December 22, 1999 8:48 PM
Subject: Re: DMU-AHRS
Dear Matthew,
Thank you for your message. The specifications for the DMU-AHRS can be
downloaded from our website at www.xbow.com in the Products section. The
price of the AHRS is $6,500.
Stephan Gallegos
Crossbow Tech.
Date: Wednesday, November 10, 1999 10:35 AM
Subject: DMU-AHRS
>I'm a hobbyist interested in designing a 'glass cockpit' for my
experimental
>aircraft. I'm looking for a sensor that would give me pitch angle, roll
>angle, and heading. It looks like the DMU-AHRS is what I'm after.
>I was wondering if I could get further technical information and the price
>of this unit.
>Thanks,
>-Matthew Mucker
All,
I apologize for sending the last email before it was ready to hit the 'net.
Anyway, you can see that Crossbow responded to my question about a month and
a half after it'd been asked. Other than that, not much information that we
don't already have!
-Matt
"I don't care what anybody says, there ARE user serviceable parts inside. "
Matt,
You've got to learn to stop using that "hobbyist" word. In sales rep
language that translates to "I just want to waste your time; I'm not going
to give you any money". They already know that 99 leads out of 100 are dead
ends. That doesn't mean you are obligated to tell them up front that you are
one of the 99.
Jeff
All,
don't already have!
-Matt
Subject: | Re: Inverter needed |
Do you need single phase or three phase?
> to design one.
Check with a gyro/instrument overhaul shop like The Gyro House in Auburn,
CA. They might have what you need.
I used an eval kit from Maxim (http://www.maxim-ic.com). They make all
kinds of analog and power supply chips. They have an eval kit on a little
postage stamp sized circuit board. You need to change the output caps and
the voltage sense divider but it will work. I used this to power my 28V
attitude gyro in my RV-4.
Brian Lloyd
brian(at)lloyd.com
+1.530.676.6513
>>>I'm a hobbyist interested in designing a 'glass cockpit'...
>>>and the price of this unit.
>>'net.
>>about a month and a half after it'd been asked. Other than that,
>>not much information that we don't already have!
>rep language that translates to "I just want to waste your time;
>I'm not going to give you any money". They already know that
>99 leads out of 100 are dead ends. That doesn't mean you
>are obligated to tell them up front that you are one of the 99.
Perhaps when dealing with suppliers/vendors, we should use language such
as...
...I am representing a group of 20 software and electrical engineers...
...our design tem is working on the development of a glass cockpit project
targeting the experimental/homebuilt aircraft market...
etc...
Never imply that you are acting alone... always represent a group or TEAM
of folks with a common goal.
Implication of larger sales when the project is completed successfully
does not hurt either.
Steve
to design one.
Joe Hovel
First thing I would check would be Burr-Brown. They make DC-DC converters
and have a very wide selection. If you just want to do it your self then
remember you are performing a 'transformer' task and power in is equal to
power out divided by the efficiency of your circuit. Example: 115V @ 20ma
with a converter that is 87% efficient. You would need 2.64 watts in and at
12VDC you would have approximately 220mA in. Radio Shack has a good starter
book on Buck-Boost Switching Converters. They usually use a 555 Timer and
are simple, no more than one or two transistors. If you would like, I would
be glad to take a look at your design once you are done. As well, I will
look around for a design or two in my library. I'm a book nut! As far as
using the Car Power Adapter, it should be fine, unmodified. Try to get the
max and min voltage requirements of the instruments that you want to power
and this will give you the design window that we will work in. As well, the
max and min current requirements are a must. The voltage should be easy to
create, we just don't want to overload any circuit protection devices
upstream. I just moved to my present position from a power intensive design
position so I should be able to help you with whatever you come up with.
Seth
Subject: | Re: Fw: DMU-AHRS |
>From: Stephan Gallegos <sgallegos(at)xbow.com>
>To: mmucker(at)cyberramp.net
>Dear Matthew,
FWIW, we're using a derivation of this product in the
next production upgrade to the AQM-37 rocket powered
target . . . hope to fly it late next year.
http://www.aeroelectric.com
Subject: | Re: Inverter needed (list note) |
In a message dated 12/23/99 6:45:27 AM Central Standard Time,
steve(at)tzogon.com writes:
> That's sad... that we're hogging this list so much that people think
> avionics questions are off topic...
> Perhaps we want to set up an alternate list for the Glass Cockpit project?
> I do not want to flood this list to the point where people who are not
> involved in the Pink Bunny Glass Cockpit project are afraid to ask other
> questions and/or do not ask (or join) because the answer to their question
> will be lost in all the noise...
Not to be argumentative but I would suggest that we leave it alone and just
make sure and include some general interest topics from time to time. The
best thing you can do for any list is to KEEP IT ACTIVE! The Glass Cockpit
discussion at least keeps an ongoing interest level that many lists lack.
Now back to mostly lurking and learning......
Bob Reed
KIS Cruiser in progress at: http://robertr237.virtualave.net/
In a message dated 12/23/99 6:54:44 AM Central Standard Time,
> as...
> etc...
> Steve
And, there is not a single word of deception in any of the above statements.
You may in fact be understating the size of the team and the total interest.
Subject: | Re: DC-DC Converter |
In a message dated 12/23/99 7:57:53 AM Central Standard Time,
s-fuller1(at)ti.com writes:
of
skills
> to design one.
> Joe Hovel
at
starter
would
the
design
> Thanks,
> Seth
OK, I fear that I may be about to show my total ignorance regarding this but
that's never stopped me before. You indicate that the attitude indicator
uses 115 volts. I suspect that the 115 volts is subsequently transformed to
something more in line with typical electronics using 5-6 volts DC. Instead
of converting 12 v to 115 v to then be converted back, why not determine the
required voltage for the circuitry and replace the current transformer with
an appropriate one?
NOW fire away all you electronic experts. I intend to learn from your flames.
Bob Reed
Careful gents. I've flight tested most of the Crossbow products, including
the DMU-AHRS. They perform VERY POORLY in aircraft.
Most sensors are plug and chug directly into aircraft. Attitude sensors are
a different matter. If you want to try out an inexpensive attitude sensor,
go for it. However, make sure that you put the purchase on a credit card and
that you are in a position to fly the sensor very rapidly thereafter so that
you have the power to return a sensor that works great on the ground but not
at all in the air. I, for one, got stuck with a DMU-6VG a few years back. I
have continued to flight test for Crossbow, hoping that they'll get it right,
but I've always taken the sensors on loan since that time.
Here's a link to a page that lists a lot of AHRS type sensors and
manufacturers:
http://www.cee.hw.ac.uk/~tena/ins/
Now, back to lurking.
I have re-read the correspondence and it appears that his instrument takes
an AC Voltage that requires a 115V 400Hz signal. I lumped this in with the
DC-DC converters and was mistaken. Thanks for pointing that out. But in
the same arena, he will need some type of switching converter that will look
at the DC Signal coming in, Chop it at the appropriate frequency, filter out
all of the unwanted harmonics and then boost the AC Signal to the required
voltage. The major problem with this is that to boost 15 to 115 he will
need some type of transformer either an Auto Transformer, or an Isolation
Transformer. I would suggest, for size and efficiency considerations that
he use a Toroidal, Auto Transformer. These types of transformers have a
round core with less flux leakage. The Auto Transformer part shares a
common ground/neutral with the incoming signal and can be sized smaller as
there are not two separate windings. This type of transformer is always
sized for the High Current side.
What he is sounding like he is doing is operating some type of resolver
winding inside that needs a reference voltage. Although I am not familiar
with the internal workings of this instrument, by the description this
sounds like the case. A resolver is basically a small, highly sensitive
motor operating in the reverse, like a generator. Small movements in the
armature/rotor will be translated to the field/stator windings as a voltage
level difference. As I am writing you I am becoming more aware of his need.
My former position was with RSI Precision Controls. We designed antenna
servo systems used to track satellites. The antennas position reporting
system was very critical as tracking 0.0016 degree movements was our goal.
We used resolvers to do this. We had several that used 115V, 400Hz
reference signals to excite the windings. Analog Devices has a complete
book on Resolvers and Synchros. I don't think that before I understood the
nature of his problem. We often had problems in that we would have drift in
the reference signal phasing and this would throw off our readings, as the
out going signal was compared to the generated reference. Hopefully Joe
will not have to deal with any of these problems and he will only have to
provide the voltage, but I would suggest that when he is creating this
reference voltage that he takes into account frequency drift with
temperature as well as efficiency drift over temperature. Both of which
could affect the way that the device behaves and its ability to correctly
report the attitude of the aircraft. All though a quick check with the
manufacturer would tell him the min and max specifications of the voltage
and Joe can determine from there how accurate he needs to be in creating the
power source. If the specifications are too tight, such as a need for
precision references in the switching circuit or Non-Linear Circuits devices
then he may want to farm this out to a design house or just continue to look
on the Web for a supplier. This could be easy or it could be extremely
difficult. I will need to know the specs from the manufacturer on the power
requirements to make a better decision. Joe, if you get this let me know
what you know and I will try to help you.
Seth
a
of
appropriate
skills
> to design one.
> Joe Hovel
converters
20ma
at
starter
and
would
as
the
power
the
to
design
> Thanks,
> Seth
an appropriate one?
flames.
Bob Reed
Subject: | AC powered gyros (Was: DC-DC Converter) |
There seems to be some misunderstanding as to why the gyros might need
115VAC at 400 Hz. AC tends to be used in the cockpit for two things: AC
motors in gyros and angular resolvers. AC motors tend to be smaller and
lighter. Also, you can transfer power by inductive coupling that requires
no contacts with the concomitant friction that they cause.
Even the 14VDC and 28VDC electric gyros that are popular today are really
AC powered. They just have the inverter built into the case of the
gyro. Solid state inverters have made this possible.
The problem comes when you run across a gyro that needs three-phase power
(not unusual). Building an inverter that accepts 14VDC and produces
115VAC, 400Hz, three-phase power is nontrivial. It will probably be a lot
cheaper and easier to get a different gyro. I know because I ran into
this problem myself a few years back.
I finally gave up trying to build or find a three-phase inverter at a
reasonable price and cut a deal with the local gyro shop to use my AC gyro
as a trade-in and got a freshly-overhauled 28VDC powered attitude gyro for
$700. I then made a 14V-to-28V upconverter using an upconverter eval kit
from Maxim (http://www.maxim-ic.com). It worked pretty well but was a bit
noisy electrically. If you go this route be sure to put the inverter in a
small metal box with feed-through capacitors to keep the RF noise in
check.
Brian Lloyd
brian(at)lloyd.com
+1.530.676.6513
Hi there, I've been receiving this list for about a month now and watching this
project develop. I to am planing to put a "glass cockpit in the airplane I'm
building but I am using a different philosophy. My plan included the small
modules that have been discussed here each with enough smarts to do its job. I'm
not sure yet if I'll use a bus structure, because honestly considering how small
my plane will be I'm not sure if the savings in wire are worth the complexity.
The major point where I differ is that I intend to run the whole thing with a
laptop running Labview under Linus. The point is that with mass marketing it is
impossible to custom build a computer that can compete at the price. I am trying
to use parts for my aircraft project that have high volume production and
competition, a suburu for the engine etc. The only part that of the computer I
am
planning to custom design is a LCD panel with push button switches. These will
be
connected directly to the laptop mounted out of sight. This way as new more
powerful (and cheaper) computers become available swapping out will be a simple
matter. I can tell by the tenor of this thread that some of you are itching to
start building and programing. I have been designing electronic test equipment
for the telecommunications industry for the part 25 years and still write many
routines in C, but I have found that it is not worth my time to try and design
a
PC , they're just too cheap to buy. By the way with Labview I can put together
some of the screens with all the dials gauges and buttons I see in ads for glass
cockpits in minutes.
Just my view of things
Tim Shankland
Lucent Technologies
> Bob Reed
Subject: | Re: AC powered gyros (Was: DC-DC Converter) |
Years ago, I used to build and supply single phase, square
wave, 400 Hz inverters to a local instrument shop for spinning
up military surplus 3-phase gyros.
One phase was tied directly to one side of the output. A capacitor
was used in series with a second leg to the second phase. A resistor
was tied from capacitor/inverter junction to the third motor
phase. The quasi-three phase thus generated did not exhibit
the most desired 120 degress phase shift between legs but it was
enough to have the motor's rotor perceived rotation of the field
in which it resides. The gyros took longer to spin up but ran
only about 5% below the fully configured 3-phase speed.
The resistor and capacitor had to be choosen for each type
of motor . . . not sure if he used some means for measuring
derived phase shift or just used a stopwatch on it to measure
spin up time. This technique must have been successful . . .
we built hundreds of these inverters for him.
Thank you all for your helpful comments and suggestions and leads to solve
my power conversion problems for my odd and old instruments (12 to 28V DC &
12V DC to 115V AC 400Hz).
I'm sorry that I didn't put the question to the list in the first place! I
just thought everyone was pre-occupied with the "pink bunny" project.... but
overlooked the learning opportunities for everyone else.
I'll follow up your leads and will report on my progress.
Seasons greetings to you all!
Joe Hovel
Australia
Subject: | Please don't make another list! |
All,
As a lurker (ignorant but interested!!) to this list I'd like to see it
continue as it has... it's always possible to learn even when it seems over
one's head. Sometime in the future it's possible something that's been
written here will come back to me when I'm facing a problem. I don't
think I'd feel intimidated and wouldn't ask a question of you all if I had a
problem... re the one just asked about the horizion, etc.
Larry Bishop
llbish(at)worldnet.att.net
>including the DMU-AHRS. They perform VERY POORLY in aircraft.
>I have continued to flight test for Crossbow, hoping that they'll get it
>right, but I've always taken the sensors on loan since that time.
OK.. have you flight tested any others? Anything that performs well in
this application? Any other items to avoid?
Also, what was the problem with the xbow units? Anything that can be
solved? Was it vibration related? Something that a decent mounting
system might fix?
Thanks for the heads-up.
Steve
> Well, it's not related to the Pink Bunny project...
Hmmmm... it appears as though this name seems to have stuck... going to
have to have someone draw up a logo...
>...but nevertheless, this seems an appropriate forum in which to
>announce that I made my first solo on Christmas day this year.
Congrats! I just had mine earlier in December!
Wow, your instructor worked on X-mas Day?
> I had four of the sweetest touch-and-go landings you could ask for.
Mine were nice and smooth as well... even got a go around due to prior
landing traffic not clearing the runway... bonus!
Steve
Okay, here's a non-pink-bunny question for everyone:
I'd like to take the headphone audio output from an aircraft's
intercom/radio system and use that to feed the microphone input to a
camcorder. Since the microphone, I'm sure, uses much lower voltage and
current than the headphone output, I'm wondering if anyone knows of or could
whip up a circuit to do the proper level matching.
Any help is appreciated.
-Matt
Subject: | Re: Audio question |
Headphone levels are usually somewhere near 0 dbm (zero decibels relative
to on milliwatt). At 600 ohm impedance, that means a voltage level of
about 0.7 V. You need to check your camcorder's input voltage level which
will probably on the order of 1 mV to 10 mV. That means that you are
stepping down from about on the order of 1V to on the order of 1mV which
implies something like a 100-fold to 1000-fold reduction in voltage. A
simple voltage
divider will suffice. Here is the schematic:
headphone output >------[ R1 ] ---+----------> camcorder input
R
headphone ground >----------------+----------> camcorder ground
The ratio of R1 to R2 sets your attenuation level. The sum matches the
output impedence of the headphone jack. Since in this case the impedence
match isn't all that critical we can be flexible about the values of R1
and R2. For instance, a value of 1000 ohm for R1 and 10 ohm for R2 would
reduce the signal level by 100, i.e. 1V at the input becomes 10 mV at the
output. If you need more signal decrease the value of R1. If you need
less signal increase the value of R1.
So what are you working on? Sounds like you are going to be doing some
video taping in the cockpit. Will you be making a training video for
something?
Brian Lloyd
brian(at)lloyd.com
+1.530.676.6513
The one that Collins adopted for their new AHRS come from Systron
Donner. That implies that their sensors may be adapted to AHRS use.
Brian Lloyd
brian(at)lloyd.com
+1.530.676.6513
> Well, it's not related to the Pink Bunny project, but nevertheless, this
> seems an appropriate forum in which to announce that I made my first solo
> on
Contratulations! Good Christmas present!
Brian Lloyd
brian(at)lloyd.com
+1.530.676.6513
How many people here are hams? I am (WB6RQN), Steve Devine is (N1YZJ),
and Dave Bridgham is (I forgot his callsign). Anyone else?
Brian Lloyd
brian(at)lloyd.com
+1.530.676.6513
> about 0.7 V.
Oh, another thought; if your camcorder has a line-level input, you can
probably plug the headphone output directly into that with no attenuation.
Brian Lloyd
brian(at)lloyd.com
+1.530.676.6513
Brian,
Well... Many, many years ago I was (WB6CSV).
November 24, 1999 - December 28, 1999
Avionics-Archive.digest.vol-ab
