Avionics-Archive.digest.vol-aq
December 27, 2010 - January 05, 2014
      >>     I need to look out for or should I get a PC based laptop to take
      >>     to the airport for the upgrades?
      >>     John
      >>     (fiberglas finishing)
      >     3D============================================
      >     href="x-msg://5/3D%22http://www.aeroelectric.com%22">www.aeroelectric.com
      >     href="x-msg://5/3D%22http://www.buildersbooks.com%22">www.buildersbooks.com
      >     href="x-msg://5/3D%22http://www.homebuilthelp.com%22">www.homebuilthelp.com
      >     href="x-msg://5/3D%22http://www.matronics.com/contribution%22">http://www.matronics.com/contribution
      >     href="x-msg://5/3D%22http://www.matronics.com/Navigator?Avionics-List%22">http://www.matronics.com/Navigator?Avionics-List
      >     href="x-msg://5/3D%22http://forums.matronics.com%22">http://forums.matronics.com
      >     _blank">www.aeroelectric.com
      >     .com" target="_blank">www.buildersbooks.com
      >     ="_blank">www.homebuilthelp.com
      >     _blank">http://www.matronics.com/contribution
      >       target="_blank">http://www.matronics.com/Navigator?Avionics-List
Subject: Re: updating avionics
Date: Dec 27, 2010
I bought "vmWare fusion 3" . It was an easy download. Then I loaded windows 95 and now I can drag and drop files between the two os systems. Really kind of cool. Larry On Dec 27, 2010, at 9:36 AM, Georg Isenbuerger wrote: > John, > > Do not use Bootcamp. You would have to reboot the MAC whenever switchi ng Operating Systems. Better use virtualisation: Parallels for about 80 Dollars or Virtualbox for free. You install Win 7 in a so called virtual container. It allows you to run both at the same time without the hassl e to partition the hard disk and rebooting all the time. > > Regards > > George > > > > Am 27.12.2010 um 15:07 schrieb John Long : > >> I am finishing my RV-8. I have DYNON 180 plus HS-34 and SL-30, GTX- 327. with a 696. >> >> All have capability to be up dated in the aircraft. >> >> My old PC based lap top died a couple of years ago and I now have a M acBook. >> >> Dynon says if I am running bootcamp with Windows 7 installed the upda tes should work fine. I have bootcamp and am debating purchasing Window s 7. >> >> Does anyone have experience using this set-up? Are there things I ne ed to look out for or should I get a PC based laptop to take to the airp ort for the upgrades? >> >> John >> (fiberglas finishing) >> >> > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D ____________________________________________________________ Mortgage Rates Hit 2.99% If you owe under $729k you probably qualify for Gov't Refi Programs http://thirdpartyoffers.juno.com/TGL3141/4d18b9e2171e3868c4bst05duc ________________________________________________________________________________
Date: Dec 27, 2010
I could not agree more about Mac vs. PC. Every time I use my Fusion to use a PC program, I am reminded how crumby the Microsoft world is ... and how simple the Mac is. I switched when Microsoft went to that Never Never land of charging for a "downgrade" from Vista to XP. Bill ********************************* William L. Paulin, Ph.D. PaulinNeal Associates 1575 South Forest Drive Prescott, AZ 86303 Cell +1 858 722 2905 Office +1 760 720 2905 Europe +358 40 720 4047 wpaulin(at)paulinneal.com On Dec 27, 2010, at 7:42 AM, John Grosse wrote: I have a similar situation, and I used Bootcamp to set it up. You do have to reboot to load Windows, but I only do it once or twice a month so it's really no big deal. I bought a cheap copy of Windows on eBay and it works fine. I wouldn't waste my money on Win 7 unless I had to. The Mac is so much better that I really only use Windows for one program. Check with Dynon and see what version they require to do the upgrades. Good luck. John Grosse >> >> My old PC based lap top died a couple of years ago and I now have >> a MacBook. >> >> Dynon says if I am running bootcamp with Windows 7 installed the >> updates should work fine. I have bootcamp and am debating >> purchasing Windows 7. >> >> Does anyone have experience using this set-up? Are there things >> I need to look out for or should I get a PC based laptop to take >> to the airport for the upgrades? >> >> John >> (fiberglas finishing) >> ________________________________________________________________________________
Date: Dec 27, 2010
Yes, that is what I do ... when I am forced to use a PC program. Bill *********************************** William & Sandra Paulin 1575 South Forest Drive Prescott, AZ 86303 Bill Cell +1 858 722 2905 Office +1 760 720 2905 Europe +358 40 720 4047 wpaulin(at)usa.net Sandy Cell +1 858 349 1729 Office +1 928 443 7739 On Dec 27, 2010, at 8:08 AM, Larry Mac Donald wrote: I bought "vmWare fusion 3" . It was an easy download. Then I loaded windows 95 and now I can drag and drop files between the two os systems. Really kind of cool. Larry On Dec 27, 2010, at 9:36 AM, Georg Isenbuerger wrote: > John, > > Do not use Bootcamp. You would have to reboot the MAC whenever switching Operating Systems. Better use virtualisation: Parallels for about 80 Dollars or Virtualbox for free. You install Win 7 in a so called virtual container. It allows you to run both at the same time without the hassle to partition the hard disk and rebooting all the time. > > Regards > > George > > > > Am 27.12.2010 um 15:07 schrieb John Long : > >> I am finishing my RV-8. I have DYNON 180 plus HS-34 and SL-30, GTX-327. with a 696. >> >> All have capability to be up dated in the aircraft. >> >> My old PC based lap top died a couple of years ago and I now have a MacBook. >> >> Dynon says if I am running bootcamp with Windows 7 installed the updates should work fine. I have bootcamp and am debating purchasing Windows 7. >> >> Does anyone have experience using this set-up? Are there things I need to look out for or should I get a PC based laptop to take to the airport for the upgrades? >> >> John >> (fiberglas finishing) >> >> > > > =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D > > tric.com%22">www.aeroelectric.com > ww.buildersbooks.com%22">www.buildersbooks.com > lthelp.com%22">www.homebuilthelp.com > ribution%22">http://www.matronics.com/contribution > =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D > gator?Avionics-List%22">http://www.matronics.com/Navigator?Avionics-List > =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D > 2">http://forums.matronics.com > =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D ____________________________________________________________ Mortgage Rates Hit 2.99% If you owe under $729k you probably qualify for Gov't Refi Programs SeeRefinanceRates.com ________________________________________________________________________________
From: William J Hamilton <wjrhamilton(at)optusnet.com.au>
Date: Dec 28, 2010
John, Given how cheap Windows laptops (with Windows 7) have become, why leave yourself open to any hassles, particularly ones that may not be obvious, until you fire them up in the aircraft. I have observed some less than satisfactory results running the Windows emulation on a Macbook. Cheers, Bill Hamilton ----------------------------------------------------------------------------------------------------------------- > John Long wrote: > > I am finishing my RV-8. I have DYNON 180 plus HS-34 and SL-30, > GTX-327. > with a 696. > > All have capability to be up dated in the aircraft. > > My old PC based lap top died a couple of years ago and I now have a > MacBook. > > Dynon says if I am running bootcamp with Windows 7 installed the updates > should work fine. I have bootcamp and am debating purchasing Windows 7. > > Does anyone have experience using this set-up? Are there things I need > to > look out for or should I get a PC based laptop to take to the airport > for > the upgrades? > > John > (fiberglas finishing) ________________________________________________________________________________
Date: Dec 30, 2010
Subject: Re: Avionics-List Digest: 12 Msgs - 12/27/10
For all the replies on my question about avionics upgrades, Thank you. Now I have more to think about while I sand the fiberglas smooth. John On Tue, Dec 28, 2010 at 2:56 AM, Avionics-List Digest Server < avionics-list(at)matronics.com> wrote: > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete Avionics-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the Avionics-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 10-12-27&Archive=Avionics > > Text Version: > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 10-12-27&Archive=Avionics > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > Avionics-List Digest Archive > --- > Total Messages Posted Mon 12/27/10: 12 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 06:11 AM - updating avionics (John Long) > 2. 06:36 AM - Re: updating avionics (Francis Herr) > 3. 06:36 AM - Re: updating avionics (Georg Isenbuerger) > 4. 06:41 AM - Re: updating avionics (Steve Thomas) > 5. 07:01 AM - Re: updating avionics (William L. Paulin) > 6. 07:24 AM - Re: updating avionics (Larry Bowen) > 7. 07:46 AM - Re: updating avionics (John Grosse) > 8. 07:46 AM - Re: updating avionics (John Grosse) > 9. 08:12 AM - Re: updating avionics (Larry Mac Donald) > 10. 02:35 PM - Re: updating avionics (William L. Paulin) > 11. 02:35 PM - Re: updating avionics (William L. Paulin) > 12. 10:02 PM - Re: updating avionics (William J Hamilton) > > > ________________________________ Message 1 > _____________________________________ > > > Subject: Avionics-List: updating avionics > From: John Long <johnlong63(at)gmail.com> > > I am finishing my RV-8. I have DYNON 180 plus HS-34 and SL-30, GTX-327. > with a 696. > > All have capability to be up dated in the aircraft. > > My old PC based lap top died a couple of years ago and I now have a > MacBook. > > Dynon says if I am running bootcamp with Windows 7 installed the updates > should work fine. I have bootcamp and am debating purchasing Windows 7. > > Does anyone have experience using this set-up? Are there things I need to > look out for or should I get a PC based laptop to take to the airport for > the upgrades? > > John > (fiberglas finishing) > > ________________________________ Message 2 > _____________________________________ > > > From: Francis Herr <fherr(at)cfl.rr.com> > Subject: Re: Avionics-List: updating avionics > > John, > > I too own Mac computers and have the same upgrade issues. To solve them, > I bought a $70 desktop from Craig's list for the airport. I can download > files to a Mac and take them to the PC via thumb drive. > > I am not familiar with the Dynon upgrade process; however, my system > uses an SD card for updates, which means the PC can be anywhere. > > Francis > > > On Dec 27, 2010, at 9:07 AM, John Long wrote: > > I am finishing my RV-8. I have DYNON 180 plus HS-34 and SL-30, > GTX-327. with a 696. > > All have capability to be up dated in the aircraft. > > My old PC based lap top died a couple of years ago and I now have a > MacBook. > > Dynon says if I am running bootcamp with Windows 7 installed the updates > should work fine. I have bootcamp and am debating purchasing Windows 7. > > Does anyone have experience using this set-up? Are there things I need > to look out for or should I get a PC based laptop to take to the airport > for the upgrades? > > John > (fiberglas finishing) > > > ________________________________ Message 3 > _____________________________________ > > > Subject: Re: Avionics-List: updating avionics > From: Georg Isenbuerger <gi(at)av8r.de> > > John, > > Do not use Bootcamp. You would have to reboot the MAC whenever switching > Ope > rating Systems. Better use virtualisation: Parallels for about 80 Dollars > or > Virtualbox for free. You install Win 7 in a so called virtual container. > It > allows you to run both at the same time without the hassle to partition > the > hard disk and rebooting all the time. > > Regards > > George > > > Am 27.12.2010 um 15:07 schrieb John Long : > > > I am finishing my RV-8. I have DYNON 180 plus HS-34 and SL-30, GTX-327. > w > ith a 696. > > > > All have capability to be up dated in the aircraft. > > > > My old PC based lap top died a couple of years ago and I now have a > MacBoo > k. > > > > Dynon says if I am running bootcamp with Windows 7 installed the updates > s > hould work fine. I have bootcamp and am debating purchasing Windows 7. > > > > Does anyone have experience using this set-up? Are there things I need > to > look out for or should I get a PC based laptop to take to the airport for > t > he upgrades? > > > > John > > (fiberglas finishing) > > > > > ========================= > ======== > ========================= > ======== > ========================= > ======== > ========================= > ======== > > ________________________________ Message 4 > _____________________________________ > > > Subject: Re: Avionics-List: updating avionics > From: Steve Thomas <lists(at)stevet.net> > > > What is the method for updating the device? Is it a simple matter of > transferring > files or does Dynon require a proprietary software program to do it? I > have > Blue Mountain equipment and it uses a simple FTP procedure to update files. > So, any computer with a good FTP client can do it. If Dynon uses > proprietary > software, all I can say is, "Shame on them." > > Having said that, running bootcamp on a Mac is the same thing as having a > Windows > based machine. In some early testing, Windows ran faster under bootcamp > than > it did on some Windows machines. I use Parallels on my Mac and that allows > me to run Windows in a window on top of OS X. Much more convenient. > > I see no reason to buy a specialized machine. > > > Steve Thomas > ________________________________________________________________________ > > > On Dec 27, 2010, at 6:07 AM, John Long wrote: > > > I am finishing my RV-8. I have DYNON 180 plus HS-34 and SL-30, GTX-327. > with > a 696. > > > > All have capability to be up dated in the aircraft. > > > > My old PC based lap top died a couple of years ago and I now have a > MacBook. > > > > Dynon says if I am running bootcamp with Windows 7 installed the updates > should > work fine. I have bootcamp and am debating purchasing Windows 7. > > > > Does anyone have experience using this set-up? Are there things I need > to look > out for or should I get a PC based laptop to take to the airport for the > upgrades? > > > > John > > (fiberglas finishing) > > > ________________________________ Message 5 > _____________________________________ > > > From: "William L. Paulin" <wpaulin(at)usa.net> > Subject: Re: Avionics-List: updating avionics > > Agreed on the don't use Bootcamp. > > I use VMWare Fusion, instead of Parallels and it works fine too ... but > I have not used it with avionics ... just several other PC based > software. > > Bill > ********************************* > William L. Paulin, Ph.D. > PaulinNeal Associates > 1575 South Forest Drive > Prescott, AZ 86303 > > Cell +1 858 722 2905 > Office +1 760 720 2905 > Europe +358 40 720 4047 > > wpaulin(at)paulinneal.com > > On Dec 27, 2010, at 6:36 AM, Georg Isenbuerger wrote: > > John, > > Do not use Bootcamp. You would have to reboot the MAC whenever switching > Operating Systems. Better use virtualisation: Parallels for about 80 > Dollars or Virtualbox for free. You install Win 7 in a so called virtual > container. It allows you to run both at the same time without the hassle > to partition the hard disk and rebooting all the time. > > Regards > > George > > > Am 27.12.2010 um 15:07 schrieb John Long : > > > I am finishing my RV-8. I have DYNON 180 plus HS-34 and SL-30, > GTX-327. with a 696. > > > > All have capability to be up dated in the aircraft. > > > > My old PC based lap top died a couple of years ago and I now have a > MacBook. > > > > Dynon says if I am running bootcamp with Windows 7 installed the > updates should work fine. I have bootcamp and am debating purchasing > Windows 7. > > > > Does anyone have experience using this set-up? Are there things I > need to look out for or should I get a PC based laptop to take to the > airport for the upgrades? > > > > John > > (fiberglas finishing) > > > > > > > 3D============== > 3D============== > 3D============== > 3D > > 3D============== > 3D============== > 3D============== > 3D > > 3D============== > 3D============== > 3D============== > 3D > > 3D============== > 3D============== > 3D============== > 3D > > > ________________________________ Message 6 > _____________________________________ > > > Subject: Re: Avionics-List: updating avionics > From: Larry Bowen <larry(at)bowenaero.com> > > Virtualbox might work. > > http://virtualbox.org > > -- > Larry Bowen > Larry(at)BowenAero.com > http://BowenAero.com > > > On Mon, Dec 27, 2010 at 9:57 AM, William L. Paulin > wrote: > > > Agreed on the don't use Bootcamp. > > > > I use VMWare Fusion, instead of Parallels and it works fine too ... but I > > have not used it with avionics ... just several other PC based software. > > > > Bill > > ********************************* > > William L. Paulin, Ph.D. > > PaulinNeal Associates > > 1575 South Forest Drive > > Prescott, AZ 86303 > > > > Cell +1 858 722 2905 > > Office +1 760 720 2905 > > Europe +358 40 720 4047 > > > > wpaulin(at)paulinneal.com > > > > On Dec 27, 2010, at 6:36 AM, Georg Isenbuerger wrote: > > > > John, > > > > Do not use Bootcamp. You would have to reboot the MAC whenever switching > > Operating Systems. Better use virtualisation: Parallels for about 80 > Dollars > > or Virtualbox for free. You install Win 7 in a so called virtual > container. > > It allows you to run both at the same time without the hassle to > partition > > the hard disk and rebooting all the time. > > > > Regards > > > > George > > > > > > Am 27.12.2010 um 15:07 schrieb John Long : > > > > I am finishing my RV-8. I have DYNON 180 plus HS-34 and SL-30, GTX-327. > > with a 696. > > > > All have capability to be up dated in the aircraft. > > > > My old PC based lap top died a couple of years ago and I now have a > > MacBook. > > > > Dynon says if I am running bootcamp with Windows 7 installed the updates > > should work fine. I have bootcamp and am debating purchasing Windows 7. > > > > Does anyone have experience using this set-up? Are there things I need > to > > look out for or should I get a PC based laptop to take to the airport for > > the upgrades? > > > > John > > (fiberglas finishing) > > > > * > > * > > > > * > > > > 3D=========================================== > > href="x-msg://5/3D%22http://www.aeroelectric.com%22"> > www.aeroelectric.com > > href="x-msg://5/3D%22http://www.buildersbooks.com%22"> > www.buildersbooks.com > > href="x-msg://5/3D%22http://www.homebuilthelp.com%22"> > www.homebuilthelp.com > > href="x-msg://5/3D%22http://www.matronics.com/contribution%22"> > http://www.matronics.com/contribution > > 3D=========================================== > > href="x-msg://5/3D%22http://www.matronics.com/Navigator?Avionics-List%22 > ">http://www.matronics.com/Navigator?Avionics-List > > 3D=========================================== > > href="x-msg://5/3D%22http://forums.matronics.com%22"> > http://forums.matronics.com > > 3D=============================================* > > > > > > * > > > > > > ________________________________ Message 7 > _____________________________________ > > > From: John Grosse <grosseair(at)comcast.net> > Subject: Re: Avionics-List: updating avionics > > > I have a similar situation, and I used Bootcamp to set it up. You do > have to reboot to load Windows, but I only do it once or twice a month > so it's really no big deal. I bought a cheap copy of Windows on eBay and > it works fine. I wouldn't waste my money on Win 7 unless I had to. The > Mac is so much better that I really only use Windows for one program. > Check with Dynon and see what version they require to do the upgrades. > > Good luck. > > John Grosse > > >> > >> My old PC based lap top died a couple of years ago and I now have > >> a MacBook. > >> > >> Dynon says if I am running bootcamp with Windows 7 installed the > >> updates should work fine. I have bootcamp and am debating > >> purchasing Windows 7. > >> > >> Does anyone have experience using this set-up? Are there things > >> I need to look out for or should I get a PC based laptop to take > >> to the airport for the upgrades? > >> > >> John > >> (fiberglas finishing) > >> > > > ________________________________ Message 8 > _____________________________________ > > > From: John Grosse <grosseair(at)comcast.net> > Subject: Re: Avionics-List: updating avionics > > > I have a similar situation, and I used Bootcamp to set it up. You do > have to reboot to load Windows, but I only do it once or twice a month > so it's really no big deal. I bought a cheap copy of Windows on eBay and > it works fine. I wouldn't waste my money on Win 7 unless I had to. The > Mac is so much better that I really only use Windows for one program. > Check with Dynon and see what version they require to do the upgrades. > > Good luck. > > John Grosse > > Larry Bowen wrote: > > Virtualbox might work. > > > > http://virtualbox.org > > > > -- > > Larry Bowen > > Larry(at)BowenAero.com > > http://BowenAero.com > > > > > > On Mon, Dec 27, 2010 at 9:57 AM, William L. Paulin > > wrote: > > > > Agreed on the don't use Bootcamp. > > > > I use VMWare Fusion, instead of Parallels and it works fine too > > ... but I have not used it with avionics ... just several other PC > > based software. > > > > Bill > > ********************************* > > William L. Paulin, Ph.D. > > PaulinNeal Associates > > 1575 South Forest Drive > > Prescott, AZ 86303 > > > > Cell +1 858 722 2905 > > Office +1 760 720 2905 > > Europe +358 40 720 4047 > > > > wpaulin(at)paulinneal.com > > > > On Dec 27, 2010, at 6:36 AM, Georg Isenbuerger wrote: > > > > John, > > > > Do not use Bootcamp. You would have to reboot the MAC whenever > > switching Operating Systems. Better use virtualisation: Parallels > > for about 80 Dollars or Virtualbox for free. You install Win 7 in > > a so called virtual container. It allows you to run both at the > > same time without the hassle to partition the hard disk and > > rebooting all the time. > > > > Regards > > > > George > > > > > > Am 27.12.2010 um 15:07 schrieb John Long > >: > > > >> I am finishing my RV-8. I have DYNON 180 plus HS-34 and SL-30, > >> GTX-327. with a 696. > >> > >> All have capability to be up dated in the aircraft. > >> > >> My old PC based lap top died a couple of years ago and I now have > >> a MacBook. > >> > >> Dynon says if I am running bootcamp with Windows 7 installed the > >> updates should work fine. I have bootcamp and am debating > >> purchasing Windows 7. > >> > >> Does anyone have experience using this set-up? Are there things > >> I need to look out for or should I get a PC based laptop to take > >> to the airport for the upgrades? > >> > >> John > >> (fiberglas finishing) > >> * > >> > >> * > > * > > > > 3D=========================================== > > href="x-msg://5/3D%22http://www.aeroelectric.com%22"> > www.aeroelectric.com <http://www.aeroelectric.com> > > href="x-msg://5/3D%22http://www.buildersbooks.com%22"> > www.buildersbooks.com <http://www.buildersbooks.com> > > href="x-msg://5/3D%22http://www.homebuilthelp.com%22"> > www.homebuilthelp.com <http://www.homebuilthelp.com> > > href="x-msg://5/3D%22http://www.matronics.com/contribution%22"> > http://www.matronics.com/contribution > > 3D=========================================== > > href="x-msg://5/3D%22 > http://www.matronics.com/Navigator?Avionics-List%22"> > http://www.matronics.com/Navigator?Avionics-List > > 3D=========================================== > > href="x-msg://5/3D%22http://forums.matronics.com%22"> > http://forums.matronics.com > > 3D=========================================== > > * > > > > > > * > > > > _blank">www.aeroelectric.com > > .com" target="_blank">www.buildersbooks.com > > ="_blank">www.homebuilthelp.com > > _blank">http://www.matronics.com/contribution > > target="_blank">http://www.matronics.com/Navigator?Avionics-List > > tp://forums.matronics.com > > * > > > > > > * > > > > * > > > ________________________________ Message 9 > _____________________________________ > > > From: Larry Mac Donald <lm4(at)juno.com> > Subject: Re: Avionics-List: updating avionics > > I bought "vmWare fusion 3" . It was an easy download. > > Then I loaded windows 95 and now I can drag and drop > files between the two os systems. Really kind of cool. > Larry > > On Dec 27, 2010, at 9:36 AM, Georg Isenbuerger wrote: > > > John, > > > > > Do not use Bootcamp. You would have to reboot the MAC whenever switchi > ng Operating Systems. Better use virtualisation: Parallels for about 80 > Dollars or Virtualbox for free. You install Win 7 in a so called virtual > container. It allows you to run both at the same time without the hassl > e to partition the hard disk and rebooting all the time. > > > > > Regards > > > > > George > > > > > > > > > > > Am 27.12.2010 um 15:07 schrieb John Long : > > > > >> I am finishing my RV-8. I have DYNON 180 plus HS-34 and SL-30, GTX- > 327. with a 696. > >> > > >> All have capability to be up dated in the aircraft. > >> > > >> My old PC based lap top died a couple of years ago and I now have a M > acBook. > >> > > >> Dynon says if I am running bootcamp with Windows 7 installed the upda > tes should work fine. I have bootcamp and am debating purchasing Window > s 7. > >> > > >> Does anyone have experience using this set-up? Are there things I ne > ed to look out for or should I get a PC based laptop to take to the airp > ort for the upgrades? > >> > > >> John > >> (fiberglas finishing) > >> > > >> > > > > > > > > 3D============= > ============== > 3D============= > == > > 3D============= > ============== > 3D============= > == > 3D============= > ============== > 3D============= > == > 3D============= > ============== > 3D============= > == > > ____________________________________________________________ > Mortgage Rates Hit 2.99% > If you owe under $729k you probably qualify for Gov't Refi Programs > http://thirdpartyoffers.juno.com/TGL3141/4d18b9e2171e3868c4bst05duc > > ________________________________ Message 10 > ____________________________________ > > > Subject: Re: Avionics-List: updating avionics > From: "William L. Paulin" <wpaulin(at)usa.net> > > > I could not agree more about Mac vs. PC. Every time I use my Fusion to use > a PC > program, I am reminded how crumby the Microsoft world is ... and how simple > the Mac is. I switched when Microsoft went to that Never Never land of > charging > for a "downgrade" from Vista to XP. > > Bill > ********************************* > William L. Paulin, Ph.D. > PaulinNeal Associates > 1575 South Forest Drive > Prescott, AZ 86303 > > Cell +1 858 722 2905 > Office +1 760 720 2905 > Europe +358 40 720 4047 > > wpaulin(at)paulinneal.com > > On Dec 27, 2010, at 7:42 AM, John Grosse wrote: > > > I have a similar situation, and I used Bootcamp to set it up. You do have > to reboot > to load Windows, but I only do it once or twice a month so it's really no > big deal. I bought a cheap copy of Windows on eBay and it works fine. I > wouldn't > waste my money on Win 7 unless I had to. The Mac is so much better that I > really only use Windows for one program. Check with Dynon and see what > version > they require to do the upgrades. > > Good luck. > > John Grosse > > >> > >> My old PC based lap top died a couple of years ago and I now have > >> a MacBook. > >> > >> Dynon says if I am running bootcamp with Windows 7 installed the > >> updates should work fine. I have bootcamp and am debating > >> purchasing Windows 7. > >> > >> Does anyone have experience using this set-up? Are there things > >> I need to look out for or should I get a PC based laptop to take > >> to the airport for the upgrades? > >> > >> John > >> (fiberglas finishing) > >> > > > ________________________________ Message 11 > ____________________________________ > > > From: "William L. Paulin" <wpaulin(at)usa.net> > Subject: Re: Avionics-List: updating avionics > > Yes, that is what I do ... when I am forced to use a PC program. > > Bill > *********************************** > William & Sandra Paulin > 1575 South Forest Drive > Prescott, AZ 86303 > > Bill > Cell +1 858 722 2905 > Office +1 760 720 2905 > Europe +358 40 720 4047 > > wpaulin(at)usa.net > > Sandy > Cell +1 858 349 1729 > Office +1 928 443 7739 > > On Dec 27, 2010, at 8:08 AM, Larry Mac Donald wrote: > > I bought "vmWare fusion 3" . It was an easy download. > Then I loaded windows 95 and now I can drag and drop > files between the two os systems. Really kind of cool. > Larry > > On Dec 27, 2010, at 9:36 AM, Georg Isenbuerger wrote: > > > John, > > > > Do not use Bootcamp. You would have to reboot the MAC whenever > switching Operating Systems. Better use virtualisation: Parallels for > about 80 Dollars or Virtualbox for free. You install Win 7 in a so > called virtual container. It allows you to run both at the same time > without the hassle to partition the hard disk and rebooting all the > time. > > > > Regards > > > > George > > > > > > > > Am 27.12.2010 um 15:07 schrieb John Long : > > > >> I am finishing my RV-8. I have DYNON 180 plus HS-34 and SL-30, > GTX-327. with a 696. > >> > >> All have capability to be up dated in the aircraft. > >> > >> My old PC based lap top died a couple of years ago and I now have a > MacBook. > >> > >> Dynon says if I am running bootcamp with Windows 7 installed the > updates should work fine. I have bootcamp and am debating purchasing > Windows 7. > >> > >> Does anyone have experience using this set-up? Are there things I > need to look out for or should I get a PC based laptop to take to the > airport for the upgrades? > >> > >> John > >> (fiberglas finishing) > >> > >> > > > > > > > ===============3 > D============== > 3D============== > 3D > > > > tric.com%22">www.aeroelectric.com > > ww.buildersbooks.com%22">www.buildersbooks.com > > lthelp.com%22">www.homebuilthelp.com > > ribution%22">http://www.matronics.com/contribution > > > ===============3 > D============== > 3D============== > 3D > > > gator?Avionics-List%22">http://www.matronics.com/Navigator?Avionics-List > > > ===============3 > D============== > 3D============== > 3D > > 2">http://forums.matronics.com > > > ===============3 > D============== > 3D============== > 3D > > > ____________________________________________________________ > Mortgage Rates Hit 2.99% > If you owe under $729k you probably qualify for Gov't Refi Programs > SeeRefinanceRates.com > > > ________________________________ Message 12 > ____________________________________ > > > From: William J Hamilton <wjrhamilton(at)optusnet.com.au> > Subject: Re: Avionics-List: updating avionics > > > John, > Given how cheap Windows laptops (with Windows 7) have become, why leave > yourself > open to any hassles, particularly ones that may not be obvious, until you > fire > them up in the aircraft. > I have observed some less than satisfactory results running the Windows > emulation > on a Macbook. > Cheers, > Bill Hamilton > > > ----------------------------------------------------------------------------------------------------------------- > > > John Long wrote: > > > > I am finishing my RV-8. I have DYNON 180 plus HS-34 and SL-30, > > GTX-327. > > with a 696. > > > > All have capability to be up dated in the aircraft. > > > > My old PC based lap top died a couple of years ago and I now have a > > MacBook. > > > > Dynon says if I am running bootcamp with Windows 7 installed the updates > > should work fine. I have bootcamp and am debating purchasing Windows 7. > > > > Does anyone have experience using this set-up? Are there things I need > > to > > look out for or should I get a PC based laptop to take to the airport > > for > > the upgrades? > > > > John > > (fiberglas finishing) > > ________________________________________________________________________________
Subject: GNS 430 Calibration sequence
Date: Jan 02, 2011
Does anyone on the list have documentation on the initial setup for a 430, calibration with other instruments, that they can share? ________________________________________________________________________________
Subject: Re: GNS 430 Calibration sequence
Date: Jan 02, 2011
What are you connecting it to? The install manual has a lot of info in it for connecting and configuring various peripheral equipment. Tim Andres Sent from my iPhone On Jan 2, 2011, at 8:19 AM, "Dave" wrote: > Does anyone on the list have documentation on the initial setup for a 430, calibration with other instruments, that they can share? > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Jan 04, 2011
Subject: DelMarVa Avionics shops
Looking for a place to get my pitot/static/encoder/transponder certified. Getting ready to start my instrument training in my 6A. I heard Summitt in DE and Easton in MD but didn't catch any of the details...anyone know the details for these two airports. Looking for Shop Name and phone number. I can fly to either but want to arrange to hopefully get it done while I wait. Thanks, Ralph RV6A N822AR @ N06 85 hrs - doing second annual..... ________________________________________________________________________________
Date: Jan 04, 2011
Subject: Re: Avionics-List Digest: 0 Msgs - 01/03/11
I heard a rumor that Lowrance was working to get an updated data base for its aviation GPS family. Has anyone heard anything about it. My 2000C is way out of date and wonder if there is a way to copy the very latest database. Jack in AZ --- On Tue, 1/4/11, Avionics-List Digest Server wrote: > From: Avionics-List Digest Server <avionics-list(at)matronics.com> > Subject: Avionics-List Digest: 0 Msgs - 01/03/11 > To: "Avionics-List Digest List" > Date: Tuesday, January 4, 2011, 12:56 AM > * > > ================================================= > Online Versions of Today's List Digest > Archive > ================================================= > > Today's complete Avionics-List Digest can also be found in > either of the > two Web Links listed below. The .html file includes > the Digest formatted > in HTML for viewing with a web browser and features > Hyperlinked Indexes > and Message Navigation. The .txt file includes the > plain ASCII version > of the Avionics-List Digest and can be viewed with a > generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 11-01-03&Archive=Avionics > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 11-01-03&Archive=Avionics > > > =============================================== > EMail Version of Today's List Digest > Archive > =============================================== > > > > ---------------------------------------------------------- > > Avionics-List > Digest Archive > > > --- > > Total Messages Posted Mon 01/03/11: > 0 > > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > > > > > > > Email Forum - > FAQ, > - MATRONICS WEB FORUMS - > List Contribution Web Site - > -Matt > Dralle, List Admin. > > > > > ________________________________________________________________________________
Date: Jan 05, 2011
That'd be great! I have a 1000 that I'd really prefer to keep! Do you remember where you read the rumor? Bob Taylor TigerCub N657RT -------------------------------------------------- From: "frequent flyer" <jdhcv(at)yahoo.com> Sent: Tuesday, January 04, 2011 3:53 PM Subject: Avionics-List: Re: Avionics-List Digest: 0 Msgs - 01/03/11 > > I heard a rumor that Lowrance was working to get an updated data base for > its aviation GPS family. Has anyone heard anything about it. My 2000C is > way out of date and wonder if there is a way to copy the very latest > database. Jack in AZ > --- On Tue, 1/4/11, Avionics-List Digest Server > wrote: > >> From: Avionics-List Digest Server <avionics-list(at)matronics.com> >> Subject: Avionics-List Digest: 0 Msgs - 01/03/11 >> To: "Avionics-List Digest List" >> Date: Tuesday, January 4, 2011, 12:56 AM >> * >> >> ================================================= >> Online Versions of Today's List Digest >> Archive >> ================================================= >> >> Today's complete Avionics-List Digest can also be found in >> either of the >> two Web Links listed below. The .html file includes >> the Digest formatted >> in HTML for viewing with a web browser and features >> Hyperlinked Indexes >> and Message Navigation. The .txt file includes the >> plain ASCII version >> of the Avionics-List Digest and can be viewed with a >> generic text editor >> such as Notepad or with a web browser. >> >> HTML Version: >> >> >> http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 11-01-03&Archive=Avionics >> >> Text Version: >> >> >> http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 11-01-03&Archive=Avionics >> >> >> =============================================== >> EMail Version of Today's List Digest >> Archive >> =============================================== >> >> >> >> ---------------------------------------------------------- >> >> Avionics-List >> Digest Archive >> >> >> --- >> >> Total Messages Posted Mon 01/03/11: >> 0 >> >> ---------------------------------------------------------- >> >> >> Today's Message Index: >> ---------------------- >> >> >> >> >> >> >> >> Email Forum - >> FAQ, >> - MATRONICS WEB FORUMS - >> List Contribution Web Site - >> -Matt >> Dralle, List Admin. >> >> >> >> >> > > > ________________________________________________________________________________
Subject: KX 155A with Glideslope
Date: Jan 05, 2011
KX 155A Nav Com with glideslope, 720 channel comm 10W transmitter. New in box comes with tray and connectors. 28 Volt Will work with KI 204, 209, or 209A indicators. (not included) $1800 plus shipping. -------- Milt Read this topic online here: http://forums.matronics.com/viewtopic.php?p=325650#325650 ________________________________________________________________________________
Date: Jan 07, 2011
Tim, Ever since I had my 430 converted to a 430w the GI-106 has been out of calibration. On startup the half up and half left don't quite make it to half. When flying a course on the 106 it would not match the CDI built in the 430 by about half a needle tick on the 106. I have entered the setup mode and done the 225 (I believe) adjustment and that is spot on. I don't fly hard IFR so it's not a life or death issue, but it was spot on before the upgrade so I know it can be adjusted somehow. I have the install manuals but I'm missing one that deals with calibration. I have pinouts and rack mounting antenna mounting etc but nothing on calibration. I learned about the set up mode from another user. Dave -----Original Message----- From: owner-avionics-list-server(at)matronics.com [mailto:owner-avionics-list-server(at)matronics.com] On Behalf Of tim2542(at)sbcglobal.net Sent: Sunday, January 02, 2011 11:59 AM Subject: Re: Avionics-List: GNS 430 Calibration sequence What are you connecting it to? The install manual has a lot of info in it for connecting and configuring various peripheral equipment. Tim Andres Sent from my iPhone On Jan 2, 2011, at 8:19 AM, "Dave" wrote: Does anyone on the list have documentation on the initial setup for a 430, calibration with other instruments, that they can share? 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D ________________________________________________________________________________
Date: Jan 07, 2011
On 1/7/2011 8:36 PM, Dave wrote: > Tim, > Ever since I had my 430 converted to a 430w the GI-106 has been out of > calibration. On startup the half up and half left don't quite make it > to half. When flying a course on the 106 it would not match the CDI > built in the 430 by about half a needle tick on the 106. I have > entered the setup mode and done the 225 (I believe) adjustment and > that is spot on. I don't fly hard IFR so it's not a life or death > issue, but it was spot on before the upgrade so I know it can be > adjusted somehow. I have the install manuals but I'm missing one that > deals with calibration. I have pinouts and rack mounting antenna > mounting etc but nothing on calibration. I learned about the set up > mode from another user. > Dave > > -----Original Message----- > *From:* owner-avionics-list-server(at)matronics.com > [mailto:owner-avionics-list-server(at)matronics.com] *On Behalf Of > *tim2542(at)sbcglobal.net > *Sent:* Sunday, January 02, 2011 11:59 AM > *To:* avionics-list(at)matronics.com > *Subject:* Re: Avionics-List: GNS 430 Calibration sequence > > What are you connecting it to? The install > manual has a lot of info in it for connecting and > configuring various peripheral equipment. > Tim Andres > > Sent from my iPhone > > On Jan 2, 2011, at 8:19 AM, "Dave" > wrote: > >> Does anyone on the list have documentation on the initial setup >> for a 430, calibration with other instruments, that they can share? >> * >> >> >> * > * > > 3D============================================ > href='3D"http://www.matronics.com/Navigator?Avionics-List"'>http://www.matronics.com/Navigator?Avionics-List > 3D============================================ > href='3D"http://forums.matronics.com"'>http://forums.matronics.com > 3D============================================ > href='3D"http://www.matronics.com/contribution"'>http://www.matronics.com/contribution > 3D============================================ > > * > > * > > > * Sorry then Icant help except to email you a copy of my install manual. MAybe call a Garmin Tech or Stein. Good luck, Tim ________________________________________________________________________________
Date: Jan 10, 2011
Subject: Icom A 210
Has anyone had success getting serial data (Frequency load ) into the Icom A 210 from the GRT HS or a 430W? I've struck out on everything I can think of. I have it connected to serial 1 "out" (P4001 pin 56) on the 430W, 9600 baud rate and aviation format. This is required by (and shared with) the EFIS so I cant change it. Any ideas? Thanks, Tim ________________________________________________________________________________
Date: Jan 31, 2011
Subject: AFS fuel flow system display changes
First, I'll preface by saying that I really like the equipment that these folks have for our planes and their customer service is top-notch - and I am an outsider not related to the company other than as a customer. Not bashing anyone here - just trying to get an understanding of who this change impacts and how it impacts them. My configuration started as a 3400EM - I have since upgraded to 3400sSP configuration (new processor and screen in addition to six-pack display) to have a set of backup instruments. The upgrade also included a Beta software release to fix a couple of last minute bugs in my system. Here's the scoop: I have 19 gallons per side for main tanks and 9 gallons per side for tip tanks for a total capacity of 56 gallons, with them all filled, the system reports 56 gallons available. Previously, the "Fuel Used" display only showed that fuel that has flowed through the flow-meter. If I only fill the mains, the system shows 38 gallons available and zero used. As I ran the engine for my flight, the "Fuel Used" display would increase from Zero by showing only fuel flowed through the flow meter. Now, the "Fuel Used" display shows the fuel that has flowed through the flow-meter plus the unfilled tanks. If I only fill the mains, the system shows 38 gallons available and 18 gallons used. As I ran the engine for my flight, the "Fuel Used" display would increase from 18 while adding the fuel that has subsequently flowed through the flow-meter. Somewhere during the flight, if I look at the "Fuel Used" display, I note that what is reported is getting close to what I just put in.....18 gallons early. Good safety margin - but not what I was expecting. I have queried the folks at AFS about this - they respond that the change was made in the interest of safety and to reduce confusion. Yes, I could simply not look at the "Fuel Used" display and only look at the "Fuel Available" display and cross check that with my fuel guages and time calculations for flight endurance planning purposes. I also asked for an optional flowed-only mode or to allow the user the choice of calculation methods (they still have the old code and it simply would be a system setting). I know that I am not the only one having trouble with this change - AFS indicated that they have received multiple indications of concern. Anyone else out there think this is an "odd change"? How are you (planning to) accomodating this? I am planning to try ignoring the "Fuel Used" display and see how that works....with a plan B of having multiple configurations (with and without tip-tanks) that I can upluad when Iplan to fuel the tiptanks. I don't expect them to change it back - but they may provide options if enough folks ask for it. Or, am I being overly picky about something that shouldn't matter - in the big picture? Your opinions please, Ralph Capen ________________________________________________________________________________
Subject: Foster RNAV 612 Installation Manual
Date: Feb 09, 2011
I need to remove a Foster RNAV 612 and having an installation diagram would be pretty handy. Any of you old-timers have one sitting around you can take a picture of, or scan, or I'd buy? Tom Johnson Phoenix, Az Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330379#330379 ________________________________________________________________________________
Subject: Re: Thermocouple compatible bulkhead connector?
Date: Feb 16, 2011
I just need to find a cheap source for mil spec circular connectors (MIL-C-5015). Anybody have a favorite source? I need a bulkhead and plug connector with 24 pins for the thermocouples. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331317#331317 ________________________________________________________________________________
Subject: RDR1200 / Avidyne
Date: Feb 21, 2011
RDR1200 in an Mu2 linked to an Avidyne, works great. But with Stabilization on, it paints more to the left than the right. I leveled the airplane and made sure the R/T was also level to the airplane and the gyro has also been leveled to the airplane. But the Avidyne still paints more left than right. I tried the Roll Trim inside the Avidyne maintenance pages but it didn't help. There is a Roll and Pitch potentiometer on the R/T antenna itself, not sure what that does. The Radar book says to shim the gyro so maybe that is all thats left. Any insight is appreciated. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331785#331785 ________________________________________________________________________________
Subject: Re: RDR1200 / Avidyne
Date: Feb 22, 2011
I'm not familiar with the specifics of the RDR 1200, but before I adjusted anything on the antenna I'd be certain that the gyro was putting out the proper signal. There's a good chance that the roll pick off in the gyro is out of alignment, given that the antenna tracks normally without the stabilization signal. I'd have the gyro bench checked, especially if it hasn't been done in a few years. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331805#331805 ________________________________________________________________________________
Date: Feb 23, 2011
Subject: Great ebay deal on Kroy K4100 shrink wrap label printer
I hope this is allowed on this list - great tool for wiring. Check out this new Kroy shrink wrap label printer - purchased new for aircraft wiring pro ject - never used - 7 boxes of shrink wrap and 1 box of wire marker include d. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=160550371023&ssPageNam e=STRK:MESELX:IT If this link doesn't work just go to ebay and search Kroy K4100. Contact me through ebay or gjs55(at)yahoo.com Thanks. Jim -=0A=0A=0A ________________________________________________________________________________
Date: Feb 23, 2011
Good idea. Might just continue to live with it. I think sending a Gyro for bench test that is otherwise working just fine is begging to get a $5000 invoice and no improvement. Down the road a G600 will fix all of that I am sure.. Thanks. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331956#331956 ________________________________________________________________________________
Date: Feb 23, 2011
Actually, just a bench check without doing any repair or adjustment is pretty inexpensive. In fact, any avionics shop that does radar installations can test the gyro on a tilt table with it hooked up to your RDR 1200 and you'll find out quickly where the problem really is. I had my setup tested just this way and it took only about an hour, with most of the time spent for R&R of the radome and gyro. I found it very educational. -----Original Message----- >From: tjyak50 <tomjohnson(at)cox.net> >Sent: Feb 23, 2011 12:13 PM >To: avionics-list(at)matronics.com >Subject: Avionics-List: Re: RDR1200 / Avidyne > > >Good idea. Might just continue to live with it. > >I think sending a Gyro for bench test that is otherwise working just fine is begging to get a $5000 invoice and no improvement. > >Down the road a G600 will fix all of that I am sure.. > >Thanks. > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=331956#331956 > > ________________________________________________________________________________
Subject: RE:hi!5c
Date: Feb 26, 2011
YD Dear sir/madam: ???????????????????? Please forgive us to disturb your valued time. ??????????????????????????????????????? This is a big wholesale company in china, sell electronic products to all the world,such as laptop, camera, phone and so on. We can offer the low price and high quality to you. If you have free??? ????????????????????????? time, please take a few to visit our official we bsite: www.edazzone.com ???? Then any questions, please contact us freely. ???? Email: edazzone(at)gmail.com??? ????????????????????? Temporary use your e-mail, I am sorry eJ ________________________________________________________________________________
Subject: Looking for a Bendix/King KMH 820 or 920
Date: Mar 02, 2011
Hello, I know this is probably a long shot, but I am looking for a good, used, serviceable KMH 820 or 920 TAS/TAWS unit. It doesn't have to be yellow-tagged, just serviceable. Thanks, Stan ________________________________________________________________________________
Date: Mar 10, 2011
Subject: Avionics Installation Tools & Supplies
I hope this is allowed here - My project is over and someone on this list m ay need some of the things I have left over, now-for sale. Check out this -auction on eBay --Avionics installation tools and supplies. Have many other aviation related items as well so check my other items on eBay. More things will be available soon. - http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=16055680361 0&viewitem=&sspagename=STRK%3AMESELX%3AIT - Thanks, I hope someone will need something for their project. - Jim=0A=0A=0A ________________________________________________________________________________
Subject: BMA Engine Pod
Date: Apr 02, 2011
I=99m looking to purchase a BMA engine pod (sensors optional). If you have one or know someone who does, please get in touch with me off-list. Thanks James Redmon www.berkut13.com ________________________________________________________________________________
Subject: Nav com
Date: Apr 07, 2011
Looking for an economical instrument hole nav com for my panel. Escort II be the best bet if I can find one? Bob, Wichita ====== Email scanned by PC Tools - No viruses or spyware found. (Email Guard: 7.0.0.21, Virus/Spyware Database: 6.17260) http://www.pctools.com/ ====== ________________________________________________________________________________
Subject: =?utf-8?Q?u/5good_deals=EF=BC=81?
Date: Apr 12, 2011
18 Hi friend! How are you doing now? I have a friend working in a Korean comp any, they have adopted a variety of good deals, all their things are at ve ry nice prices, their web is zabty.com,and you can go to their web to have a look, thanks!? Best Regards 40/18 ________________________________________________________________________________
Subject: Your E-mail; please phone if you need an immediate response.
Date: Apr 19, 2011
Your e-mail generated this automated response. This auto response does not mean your e-mail arrived in whole or in part. It does mean that your e-mail or anything related, if received, is awaiting reading. We attempt to respond to all e-mails as quickly as possible. Please phone (866) 747-1747, (918) 747-1747 or (918) 629-3685 should you need immediate verification of a status, have immediate action taken or need any other type of immediate response. ________________________________________________________________________________
Subject: Re: Your E-mail; please phone if you need an immediate
response.
Date: Apr 19, 2011
I sent no message? ********************************* William L. Paulin, Ph.D. PaulinNeal Associates 1575 South Forest Drive Prescott, AZ 86303 Cell +1 858 722 2905 Office +1 760 720 2905 Europe +358 40 720 4047 wpaulin(at)paulinneal.com On Apr 19, 2011, at 7:21 AM, Cliff Magee wrote: Your e-mail generated this automated response. This auto response does not mean your e-mail arrived in whole or in part. It does mean that your e-mail or anything related, if received, is awaiting reading. We attempt to respond to all e-mails as quickly as possible. Please phone (866) 747-1747, (918) 747-1747 or (918) 629-3685 should you need immediate verification of a status, have immediate action taken or need any other type of immediate response. ________________________________________________________________________________
Date: May 01, 2011
Subject: Narco AT-50A
Is there any way to bench test for failure of the expensive cavity tube in a Narco AT-50A transponder? Two units here show overheating in the area of the 2N6109 transistors (the two green TO-220 transistors). It would be nice to know if the tubes are gone before investing in the maintenance manual or professional testing. Another way of asking this might be - has anyone brought their unit back to life by replacing those burned/failed components around the 2N6109 transistors? thank you Ken ________________________________________________________________________________
Subject: SL-70 WTB
Date: May 07, 2011
Looking for a nice Apollo SL-70 with rack and connectors. Prefer 8130'd but can do it locally if necessary. Thanks, Tom M ________________________________________________________________________________
Subject: KT76A manual
Date: May 22, 2011
Anyone have a manual for a KT76A transponder in electronic format? I don't trust any of the download sites - especially when they want you to sign up for their membership services. Thanks, Ralph Capen ________________________________________________________________________________
Subject: RE: RV-List: KT76A manual
Date: May 22, 2011
Thanks Stein! From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ralph E. Capen Sent: Sunday, May 22, 2011 2:19 PM Subject: RV-List: KT76A manual Anyone have a manual for a KT76A transponder in electronic format? I don't trust any of the download sites - especially when they want you to sign up for their membership services. Thanks, Ralph Capen ________________________________________________________________________________
Date: May 22, 2011
Subject: Re: KT76A manual
Ralph... The Bendix King KT76A transponder manual is here in a pdf format: No "sign up" ...just download it... http://tinyurl.com/3pdq9zo The URL was a bit long, so I tiny URL'd it for you... Harley ----------------------------------------------------------------- On 5/22/2011 2:19 PM, Ralph E. Capen wrote: > > Anyone have a manual for a KT76A transponder in electronic format? > > I don't trust any of the download sites -- especially when they > want you to sign up for their membership services. > > Thanks, > > Ralph Capen > > * > * ________________________________________________________________________________
Date: May 22, 2011
Thanks - that one is for a KT76C - but other documentation says they're pin-compatible - so I'll keep it for reference.. From: owner-avionics-list-server(at)matronics.com [mailto:owner-avionics-list-server(at)matronics.com] On Behalf Of Harley Sent: Sunday, May 22, 2011 3:23 PM Subject: Re: Avionics-List: KT76A manual Ralph... The Bendix King KT76A transponder manual is here in a pdf format: No "sign up" ...just download it... http://tinyurl.com/3pdq9zo The URL was a bit long, so I tiny URL'd it for you... Harley _____ On 5/22/2011 2:19 PM, Ralph E. Capen wrote: Anyone have a manual for a KT76A transponder in electronic format? I don't trust any of the download sites - especially when they want you to sign up for their membership services. Thanks, Ralph Capen ________________________________________________________________________________
Date: May 26, 2011
Date: Jul 04, 2011
Subject: Help with Gns 480 Century HSI
I have a CNX-80 - GNS480 witht he following other units. Century 1000 HSI, MX20, SL15. I had the GNS 480 software upgrade, since then I am not getting any CDI function on the HSI. the VDI etc, still works, but not CDI. I have checked my setup and all seems OK to me - but I may be missing something. Also, Altitude does not display on MX 20 - have an SL70 remote transponder - output from GNS 480 is showing correct altitude. Any GNS 480 experts, help would be appreciated. Avionics shop where I had the upgrade done is not homebuilder friendly. Dave Burnham RV6A - N64FN - flying since 2006 ________________________________________________________________________________
Date: Jul 04, 2011
Subject: Help with GNS 480 - Century HSI
Date: Jul 10, 2011
Subject: Audio Panel Connections
My SL40 com has separate "mic lo" and "head phone lo" outputs, but my PS 8000 audio panel only has a single "com lo" input. Can I just ignore one of the "lo" outputs from the com assuming that they're all connected internally anyway, or do I need to pigtail both "lo" output wires together and connect to the single "lo" input on the audio panel? Thanks. John Grosse ________________________________________________________________________________
Date: Jul 11, 2011
Subject: Re: Help with Gns 480 Century HSI
Many comments on the Yahoo 480 group regarding poor seating/mating in the mounting tube. Make sure it is secure, fully engaged. Even 1/32" makes a difference. Ron Q. At 15:17 7/4/2011, you wrote: >I have a CNX-80 - GNS480 witht he following other units. Century >1000 HSI, MX20, SL15. >I had the GNS 480 software upgrade, since then I am not getting any >CDI function on the HSI. the VDI etc, still works, but not CDI. >I have checked my setup and all seems OK to me - but I may be >missing something. >Also, Altitude does not display on MX 20 - have an SL70 remote >transponder - output from GNS 480 is showing correct altitude. > >Any GNS 480 experts, help would be appreciated. Avionics shop where >I had the upgrade done is not homebuilder friendly. > >Dave Burnham >RV6A - N64FN - flying since 2006 > ________________________________________________________________________________
Date: Jul 11, 2011
Dave: I've been flying my RV-7A for nearly two years, I have a Garmin 480 as my primary radio - probably one of the last ones to come off the production line - took me a long time to get comfortable with it - not terribly user friendly - have finally done it - it's a great radio - amazing capability. A couple of months ago I kept losing GPS function - I'd be in the middle of an approach or in cruise - suddenly - nothing - my long time mentor suggested sliding the radio partially out of the rack and reseating it - push firmly on the four corners of the case - then snug it down real good with the allen wrench - haven't had a problem since - I carry the allen wrench in the side pocket by my left elbow - every couple of weeks I snug the set screw down. Just a suggestion - Dan Bergeron RV-7A - N307TB 247 hours since first flight on 8/4/09 On Mon, Jul 11, 2011 at 10:16 PM, Ron Quillin wrote: > Many comments on the Yahoo 480 group regarding poor seating/mating in the > mounting tube. > Make sure it is secure, fully engaged. Even 1/32" makes a difference. > > Ron Q. > At 15:17 7/4/2011, you wrote: > > I have a CNX-80 - GNS480 witht he following other units. Century 1000 HSI, > MX20, SL15. > I had the GNS 480 software upgrade, since then I am not getting any CDI > function on the HSI. the VDI etc, still works, but not CDI. > I have checked my setup and all seems OK to me - but I may be missing > something. > Also, Altitude does not display on MX 20 - have an SL70 remote transponder > - output from GNS 480 is showing correct altitude. > > Any GNS 480 experts, help would be appreciated. Avionics shop where I had > the upgrade done is not homebuilder friendly. > > Dave Burnham > RV6A - N64FN - flying since 2006 > > * > > * > > ________________________________________________________________________________
Date: Jul 12, 2011
Thanks Dan, I heard the same concerns from other users - I removed the unit, my tray was set back about 1/32 from the panel. Moved it forward and reseated the unit and tightenned it well, I heard that they had designed a new tray and some have replaced the tray? All is working well again. I know what you mean about user friendly, but once you get it sorted out it is great. Regards, Dave On Mon, Jul 11, 2011 at 9:49 PM, Dan Bergeron wrote: > Dave: > I've been flying my RV-7A for nearly two years, I have a Garmin 480 as my > primary radio - probably one of the last ones to come off the production > line - took me a long time to get comfortable with it - not terribly user > friendly - have finally done it - it's a great radio - amazing capability. > A couple of months ago I kept losing GPS function - I'd be in the middle of > an approach or in cruise - suddenly - nothing - my long time mentor > suggested sliding the radio partially out of the rack and reseating it - > push firmly on the four corners of the case - then snug it down real good > with the allen wrench - haven't had a problem since - I carry the allen > wrench in the side pocket by my left elbow - every couple of weeks I snug > the set screw down. > Just a suggestion - > Dan Bergeron > RV-7A - N307TB > 247 hours since first flight on 8/4/09 > > On Mon, Jul 11, 2011 at 10:16 PM, Ron Quillin wrote: > >> Many comments on the Yahoo 480 group regarding poor seating/mating in >> the mounting tube. >> Make sure it is secure, fully engaged. Even 1/32" makes a difference. >> >> Ron Q. >> At 15:17 7/4/2011, you wrote: >> >> I have a CNX-80 - GNS480 witht he following other units. Century 1000 HSI, >> MX20, SL15. >> I had the GNS 480 software upgrade, since then I am not getting any CDI >> function on the HSI. the VDI etc, still works, but not CDI. >> I have checked my setup and all seems OK to me - but I may be missing >> something. >> Also, Altitude does not display on MX 20 - have an SL70 remote transponder >> - output from GNS 480 is showing correct altitude. >> >> Any GNS 480 experts, help would be appreciated. Avionics shop where I had >> the upgrade done is not homebuilder friendly. >> >> Dave Burnham >> RV6A - N64FN - flying since 2006 >> >> * >> >> target="_blank">http://www.matronics.com/Navigator?Avionics-List >> tp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> * >> >> > * > > * > > ________________________________________________________________________________
Date: Jul 21, 2011
You may be able to request samples. These pins are not usually stocked Digikey or Newark, etc., but that does not mean they are not likely to provide... -------- ,, Read this topic online here: http://forums.matronics.com/viewtopic.php?p=347348#347348 ________________________________________________________________________________
Subject: Re: Encoder Certification
Date: Jul 21, 2011
I agree, provided the word "under" words "in the" to "Medium" is a more inclusive word... -------- ,, Read this topic online here: http://forums.matronics.com/viewtopic.php?p=347352#347352 ________________________________________________________________________________
Subject: Re: GTX330 TIS with DAC GDC34A/Chelton
Date: Jul 21, 2011
I thought, GTX330 need EFIS GPS location information, requiring ARINC 429 input. Do you think? I have a call to Garmin, and hope to hear from them Monday.... -------- ,, Read this topic online here: http://forums.matronics.com/viewtopic.php?p=347353#347353 ________________________________________________________________________________
Subject: Anywhere Map
Date: Aug 07, 2011
I have a single station Ipaq based system that runs the anywhere map system, and I'll sell it all for $500. It has the IPAQ 4700, charger, bluetooth GPS, Bluetooth WxWOrks weather receiver, mount, power connector, and SD card. New, they are going for $1500 w. the Ipaq. This system has a lifetime system and map update. It also has approach plates - but that part is only paid for a year or so. Please contact me off list if you are interested. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=348856#348856 ________________________________________________________________________________
Subject: King KS-505 Help
Date: Aug 28, 2011
Does anyone have any service/installation information for a King KS-505 Power Supply Modulation Unit? Thanks, Phil ________________________________________________________________________________
Subject: Hum in Radio?
Date: Sep 03, 2011
I have an Icom IC-A24 Aviation Transceiver mounted in my aircraft with an external antenna. The radio sends and receives while in the air very well. However, when I am on the ground at airports with a control tower or Unicom I get a hum in the radio. This also occurs when I am on the ground near another aircraft that has its radio on the same frequency. Where is this hum coming from? I assume that it is some type of feedback but I do not know what to do. Suggestions? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=351323#351323 ________________________________________________________________________________
Date: Sep 03, 2011
Subject: Re: Hum in Radio?
> >I have an Icom IC-A24 Aviation Transceiver mounted in my aircraft with an external antenna. The radio sends and receives while in the air very well. However, when I am on the ground at airports with a control tower or Unicom I get a hum in the radio. This also occurs when I am on the ground near another aircraft that has its radio on the same frequency. Where is this hum coming from? I assume that it is some type of feedback but I do not know what to do. Suggestions? Some things to check: Most non-engineers describe "hum" as a low frequency audio noise that is an octave of so lower than middle C. It is usually 60 Hz or 120 Hz noise that comes from a commercial power source. That would be very unusual in a light airplane. But at an airport with big mercury lights, perhaps. If what you hear is a higher frequency it could be originating in your generator or alternator. The test is to move the throttle and report that the tone of the noise changes. Alternators run about 400 Hz which would sound like an A. It's possible for a nearby aircraft to be transmitting because of leakage in the local oscillator of it's receiver. That kind of thing is pretty rare unless the radio has been subjected to unprofessional servicing. You would notice it and remember the aircraft involved. Or do you mean that that other aircraft is deliberately transmitting? I have seen cases in which the aircraft antenna is broken and works only when forward airspeed makes it bend and effectively connect the fine copper tape inside of the fiberglass tube that is the antenna. I don't see how that would generate "hum" though. Perhaps noise because of some automatic gain control though, In short, you need to be more explicit about your problem. -- --> From the U S of A, the only socialist country that refuses to admit it. <-- ________________________________________________________________________________
Date: Sep 03, 2011
I would say that the "hum" that I am hearing is about one octave below middle C. It sounds a lot like the noise that you hear when folks are having trouble with feedback with a microphone in a nightclub. I doubt very much that it is from some noise source on the ground. Maybe it is being generated from something in my aircraft that I do not hear while in the air. I also don't think that it is from a bad connection in my antenna since I do not hear it at all on the ground when I am on the grass strip that I operate from. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=351346#351346 ________________________________________________________________________________
Date: Sep 04, 2011
>I would say that the "hum" that I am hearing is about one octave below middle C. It sounds a lot like the noise that you hear when folks are having trouble with feedback with a microphone in a nightclub. I doubt very much that it is from some noise source on the ground. Maybe it is being generated from something in my aircraft that I do not hear while in the air. I also don't think that it is from a bad connection in my antenna since I do not hear it at all on the ground when I am on the grass strip that I operate from. I have never played with an Icom IC-A24 but I suspect that it has an automatic squelch scheme that is supposed to turn off received audio until there is a sufficiently large signal coming in on the selected frequency. If the squelch is set too low it's conceivable that it works properly at your home base where there may be only a tiny bit of RF activity in the neighborhood. On a large airport there may be a lot of transmitters such as ILS equipment or radar that are "breaking squelch". That kind of noise would not usually get described as hum. But ILS and VOR use low audio frequency modulation tones that might come thru. If your receiver has a squelch control you might need to adjust it differently. If it doesn't there is probably an internal adjustment that could be mucked with but somewhere it will say that needs to be done by a man with a radio license. It isn't true though so long as you don't tune the transmitter. Someone on this list probably knows about that particular radio. OK on grass strip plus NG on a big taxiway seems to rule out something in your aircraft power system. -- -->A flashlight: is a metal tube used to store dead dry cells. <-- ________________________________________________________________________________
Date: Sep 06, 2011
Thanks for your suggestion. I have not tried to adjust the squelch and that certainly is worth a try. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=351552#351552 ________________________________________________________________________________
Date: Sep 10, 2011
Subject: Transponder troubles
Had strange occurrence with Salt Lake Approach yesterday. Initially, when they said they couldn't see my transponder, I had a reply light. Then they said they could see a 1200 code from it, not the 0363 assigned that I had dialed in. A bit later they saw the correct code, and it continued to be okay until out of their airspace. Now I departed the Phoenix area the day before, communicating with 2 radar equipped towers that had no complaints on my transponder and were giving me radar traffic callouts, so I know it was working. Not sure how a transponder could possibly put out a 1200 code when set to something else, and then revert to sending the selected code. I could see one or two digits being wrong, but the whole code? I could only think they had a weak signal, but checked after I landed and antenna was clean. I guess I can check the coax connection, and reseat the unit in its tray, but would rather not have to spend for an unnecessary bench check. It is an old model with cavity tube, but has been rock solid since it was aligned 8 yrs ago, passing every biennial check. Any other thoughts? ________________________________________________________________________________
Date: Sep 10, 2011
Subject: Re: AeroElectric-List: Transponder troubles
I had something similar happen to me only a few weeks ago arriving at Lancaster, PA. I was on a discrete code from prior flight following services and the tower said I was squawking 1200. A quick right turn followed by a look down revealed a VERY close VFR aircraft underneath me on my exact original course which was the runway heading for a straight in to the active. Was he blanketing my signal in some manner? unknown. Once I had diverged a bit the tower began seeing my signal and correct discrete code. I wonder how long we had been flying in "un-intentional formation"? On Sat, Sep 10, 2011 at 9:52 AM, Kelly McMullen wrote: > --> AeroElectric-List message posted by: Kelly McMullen < > kellym(at)aviating.com> > > Had strange occurrence with Salt Lake Approach yesterday. Initially, > when they said they couldn't see my transponder, I had a reply light. > Then they said they could see a 1200 code from it, not the 0363 > assigned that I had dialed in. A bit later they saw the correct code, > and it continued to be okay until out of their airspace. Now I > departed the Phoenix area the day before, communicating with 2 radar > equipped towers that had no complaints on my transponder and were > giving me radar traffic callouts, so I know it was working. Not sure > how a transponder could possibly put out a 1200 code when set to > something else, and then revert to sending the selected code. I could > see one or two digits being wrong, but the whole code? I could only > think they had a weak signal, but checked after I landed and antenna > was clean. I guess I can check the coax connection, and reseat the > unit in its tray, but would rather not have to spend for an > unnecessary bench check. It is an old model with cavity tube, but has > been rock solid since it was aligned 8 yrs ago, passing every biennial > check. Any other thoughts? > > ________________________________________________________________________________
Subject: Re: Transponder troubles
Date: Sep 10, 2011
Maybe there was another plane close by you (confusion by approach) or morse likely the controller simply messed up? I would wait and see or run it over a few towered airports before I would do anything drastic. My 2 cents Francis On Sep 10, 2011, at 9:52 AM, Kelly McMullen wrote: Had strange occurrence with Salt Lake Approach yesterday. Initially, when they said they couldn't see my transponder, I had a reply light. Then they said they could see a 1200 code from it, not the 0363 assigned that I had dialed in. A bit later they saw the correct code, and it continued to be okay until out of their airspace. Now I departed the Phoenix area the day before, communicating with 2 radar equipped towers that had no complaints on my transponder and were giving me radar traffic callouts, so I know it was working. Not sure how a transponder could possibly put out a 1200 code when set to something else, and then revert to sending the selected code. I could see one or two digits being wrong, but the whole code? I could only think they had a weak signal, but checked after I landed and antenna was clean. I guess I can check the coax connection, and reseat the unit in its tray, but would rather not have to spend for an unnecessary bench check. It is an old model with cavity tube, but has been rock solid since it was aligned 8 yrs ago, passing every biennial check. Any other thoughts? ________________________________________________________________________________
Date: Sep 10, 2011
It's ATC problem. I have had the same issue with ATC on a number of occasions, if one radar site has a problem and nobody else does I wouldn't be in a hurry to get to the repair shop. George -----Original Message----- From: owner-avionics-list-server(at)matronics.com [mailto:owner-avionics-list-server(at)matronics.com]On Behalf Of Kelly McMullen Sent: Saturday, September 10, 2011 8:52 AM Subject: Avionics-List: Transponder troubles Had strange occurrence with Salt Lake Approach yesterday. Initially, when they said they couldn't see my transponder, I had a reply light. Then they said they could see a 1200 code from it, not the 0363 assigned that I had dialed in. A bit later they saw the correct code, and it continued to be okay until out of their airspace. Now I departed the Phoenix area the day before, communicating with 2 radar equipped towers that had no complaints on my transponder and were giving me radar traffic callouts, so I know it was working. Not sure how a transponder could possibly put out a 1200 code when set to something else, and then revert to sending the selected code. I could see one or two digits being wrong, but the whole code? I could only think they had a weak signal, but checked after I landed and antenna was clean. I guess I can check the coax connection, and reseat the unit in its tray, but would rather not have to spend for an unnecessary bench check. It is an old model with cavity tube, but has been rock solid since it was aligned 8 yrs ago, passing every biennial check. Any other thoughts? ________________________________________________________________________________
Date: Sep 10, 2011
On 09/10/2011 08:52 AM, Kelly McMullen wrote: > --> Avionics-List message posted by: Kelly McMullen > > Had strange occurrence with Salt Lake Approach yesterday. Initially, > when they said they couldn't see my transponder, I had a reply light. > Then they said they could see a 1200 code from it, not the 0363 > assigned that I had dialed in. A bit later they saw the correct code, > and it continued to be okay until out of their airspace. Now I > departed the Phoenix area the day before, communicating with 2 radar > equipped towers that had no complaints on my transponder and were > giving me radar traffic callouts, so I know it was working. Not sure > how a transponder could possibly put out a 1200 code when set to > something else, and then revert to sending the selected code. I could > see one or two digits being wrong, but the whole code? I could only > think they had a weak signal, but checked after I landed and antenna > was clean. I guess I can check the coax connection, and reseat the > unit in its tray, but would rather not have to spend for an > unnecessary bench check. It is an old model with cavity tube, but has > been rock solid since it was aligned 8 yrs ago, passing every biennial > check. Any other thoughts? Another + for it being an ATC problem. One of my neighbors used to fly all over the central & southeast USA, & whenever he (and others) would fly through Memphis airspace ATC would tell them that their transponder wasn't working properly (no altitude, incorrect altitude, etc etc). The various transponders seemed to work fine around other class B/C airspace, & all had problems whenever they entered Memphis airspace. Charlie ________________________________________________________________________________
Date: Sep 10, 2011
From: Pete Christensen <pchristensen10(at)austin.rr.com>
Not saying this happened to you but my transponder transmitted the wrong code once. A tech told me to turn the knobs once in awhile because they can develop a dirty contact since I fly around on 1200 all the time. Pete On 9/10/2011 8:52 AM, Kelly McMullen wrote: > --> Avionics-List message posted by: Kelly McMullen > > Had strange occurrence with Salt Lake Approach yesterday. Initially, > when they said they couldn't see my transponder, I had a reply light. > Then they said they could see a 1200 code from it, not the 0363 > assigned that I had dialed in. A bit later they saw the correct code, > and it continued to be okay until out of their airspace. Now I > departed the Phoenix area the day before, communicating with 2 radar > equipped towers that had no complaints on my transponder and were > giving me radar traffic callouts, so I know it was working. Not sure > how a transponder could possibly put out a 1200 code when set to > something else, and then revert to sending the selected code. I could > see one or two digits being wrong, but the whole code? I could only > think they had a weak signal, but checked after I landed and antenna > was clean. I guess I can check the coax connection, and reseat the > unit in its tray, but would rather not have to spend for an > unnecessary bench check. It is an old model with cavity tube, but has > been rock solid since it was aligned 8 yrs ago, passing every biennial > check. Any other thoughts? > > ________________________________________________________________________________
Date: Sep 12, 2011
Kelly, What kind of transponder? Cheers, Bill Hamilton --------------------------------------------------------------------------------------------------------------- > Pete Christensen wrote: > > > > Not saying this happened to you but my transponder transmitted the wrong > > code once. A tech told me to turn the knobs once in awhile because they > > can develop a dirty contact since I fly around on 1200 all the time. > > > Pete > > > On 9/10/2011 8:52 AM, Kelly McMullen wrote: > > --> Avionics-List message posted by: Kelly > McMullen > > > > Had strange occurrence with Salt Lake Approach yesterday. Initially, > > when they said they couldn't see my transponder, I had a reply light. > > Then they said they could see a 1200 code from it, not the 0363 > > assigned that I had dialed in. A bit later they saw the correct code, > > and it continued to be okay until out of their airspace. Now I > > departed the Phoenix area the day before, communicating with 2 radar > > equipped towers that had no complaints on my transponder and were > > giving me radar traffic callouts, so I know it was working. Not sure > > how a transponder could possibly put out a 1200 code when set to > > something else, and then revert to sending the selected code. I could > > see one or two digits being wrong, but the whole code? I could only > > think they had a weak signal, but checked after I landed and antenna > > was clean. I guess I can check the coax connection, and reseat the > > unit in its tray, but would rather not have to spend for an > > unnecessary bench check. It is an old model with cavity tube, but has > > been rock solid since it was aligned 8 yrs ago, passing every biennial > > check. Any other thoughts? > > > > > > > > > > > ________________________________________________________________________________
Date: Sep 11, 2011
Subject: re:Transponder troubles
A Narco AT-50. On 9/11/2011 6:29 PM, William J Hamilton wrote: > > Kelly, > What kind of transponder? > Cheers, > Bill Hamilton ________________________________________________________________________________
Date: Sep 12, 2011
Subject: Re: re:Transponder troubles
Kelly, The reason I asked is that, down here in AU, we have seen some interesting problems with early King transponders, including transmitting codes other than that selected, and incorrect Mode C replies. Some are now subject to to an AD, which effectively means replacement, but I have not heard of any similar problems with Narco. Cheers, Bill Hamilton ----------------------------------------------------------------------------------------------------------------- > Kelly McMullen wrote: > A Narco AT-50. On 9/11/2011 6:29 PM, William J Hamilton wrote: > > Kelly, > What kind of transponder? > Cheers, > Bill Hamilton ________________________________________________________________________________
Date: Sep 30, 2011
> >A Narco AT-50. Mode A and mode C are distinguished by a time spacing between pulses received in the interrogation from the ground. Mode A inserts twelve bits as entered into you code selector. Mode C sends twelve bits of altitude information. There is also a mode B for which the details are "protected" by the US military. Those settings, in an AT50 are set with analog adjustments inside your transponder and might well have drifted out of spec. If you're sending mode C information in response to a mode A request the ground will get a code they don't expect. It might also look intermittent because it could depend on the received signal amplitude of the interrogation pulses. (How far away is the transmitter?) Ant at one time there was an AD that required transponders to reply to mode C requests even if they had altitude responding turned off. Reason: collision warning detectors is other aircraft. I believe the AT50 was one of those that was considered not worth making the modification to. That is from long term memory though and may not be quite right. Watch out, though, if you ask for a bench test. You might discover you have an illegal transponder. I'm pretty sure there was an AT-50A that came out. -- --> From the U S of A, the only socialist country that refuses to admit it. <-- ________________________________________________________________________________
Date: Sep 30, 2011
Yes, your suspicion was correct, re the alignment. It was a bit out of spec. Once adjusted back in spec, it tested perfectly both on the bench and in the aircraft. Yes, there is an AT50A, which I think has more output power, but otherwise is pretty much the same box, and they are interchangeable, like all Narco units...same tray, same pins, etc. On 9/30/2011 9:28 AM, Doug McNutt wrote: > --> Avionics-List message posted by: Doug McNutt > >> --> Avionics-List message posted by: Kelly McMullen >> >> A Narco AT-50. > Mode A and mode C are distinguished by a time spacing between pulses received in the interrogation from the ground. Mode A inserts twelve bits as entered into you code selector. Mode C sends twelve bits of altitude information. There is also a mode B for which the details are "protected" by the US military. > > Those settings, in an AT50 are set with analog adjustments inside your transponder and might well have drifted out of spec. If you're sending mode C information in response to a mode A request the ground will get a code they don't expect. It might also look intermittent because it could depend on the received signal amplitude of the interrogation pulses. (How far away is the transmitter?) > > Ant at one time there was an AD that required transponders to reply to mode C requests even if they had altitude responding turned off. Reason: collision warning detectors is other aircraft. I believe the AT50 was one of those that was considered not worth making the modification to. That is from long term memory though and may not be quite right. Watch out, though, if you ask for a bench test. You might discover you have an illegal transponder. I'm pretty sure there was an AT-50A that came out. > > ________________________________________________________________________________
Subject: Transponder Whip Antenna in a Composite A/C
Date: Sep 30, 2011
I am going to be installing a ACK Technologies ELT into my Lightning. The install manual explains that for a composite aircraft you should install a ground plane for the antenna. I want to install the antenna inside the fuselage and I am wondering if anyone has done this with an ELT. The antenna is a whip antenna and I have some ideas, that I think would work, but thought I would ask the community first. Thanks, Dennis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=353656#353656 ________________________________________________________________________________
Date: Oct 01, 2011
Subject: Removal of Garmin GNS-430 from Instrument Panel
Could someone please tell me the step-by-step procedure on how to remove a Garmin GNS-430 from an instrument panel. Does one need any special tools? Thanks. George Nielsen RV-6 PH-XGN ________________________________________________________________________________
Date: Sep 30, 2011
Only an allen wrench to crank the unit out of the tray. A 430 has a locking leg on the bottom of the unit that pulls it in and pushes it out of the tray. Depending on the clearance in your stack you can see it just left of center on the bottom and there is a small diameter hole in the unit where the allen fits. It's about 3" below the face to the release mechanism. -----Original Message----- From: owner-avionics-list-server(at)matronics.com [mailto:owner-avionics-list-server(at)matronics.com] On Behalf Of George Nielsen Sent: Friday, September 30, 2011 5:06 PM Subject: Avionics-List: Removal of Garmin GNS-430 from Instrument Panel --> Could someone please tell me the step-by-step procedure on how to remove a Garmin GNS-430 from an instrument panel. Does one need any special tools? Thanks. George Nielsen RV-6 PH-XGN ________________________________________________________________________________
Subject: Avionics package
Date: Oct 01, 2011
Need to add avionics to my KR which has very limited panel space. Was thinking of a Becker transponder, (3 1/4) and a hand held, panel mounted nav/com. Any other suggestions? Thanks, Bob ________________________________________________________________________________
Date: Oct 01, 2011
Date: Oct 05, 2011
Subject: Re: Avionics-List Digest: 0 Msgs - 10/04/11
Please remove my name from the avionics list. Thanks John Long On Wed, Oct 5, 2011 at 2:55 AM, Avionics-List Digest Server < avionics-list(at)matronics.com> wrote: > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete Avionics-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the Avionics-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 11-10-04&Archive=Avionics > > Text Version: > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 11-10-04&Archive=Avionics > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > Avionics-List Digest Archive > --- > Total Messages Posted Tue 10/04/11: 0 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > ________________________________________________________________________________
Date: Oct 07, 2011
Subject: RE: Avionics-List Digest: 0 Msgs - 10/06/11
Date: Oct 09, 2011
Subject: RE: Avionics-List Digest: 0 Msgs - 10/08/11
Date: Oct 11, 2011
Subject: RE: Avionics-List Digest: 0 Msgs - 10/10/11
Date: Oct 13, 2011
Subject: RE: Avionics-List Digest: 0 Msgs - 10/12/11
Date: Oct 14, 2011
Subject: RE: Avionics-List Digest: 1 Msgs - 10/13/11
Date: Oct 16, 2011
Subject: RE: Avionics-List Digest: 0 Msgs - 10/15/11
Date: Oct 16, 2011
Subject: Slobovia Outernational Pumpkin Drop 2011
Hi guys, I hope you can make it to Slobovia on Nov 5 for our annual Pumpkin Drop. Cajun gumbo (& chili for those who can't handle the gumbo) at noon, & bombing commences at 1:30. Location info on the attached poster, or email/call me for detailed info. Charlie ________________________________________________________________________________
Subject: Garmin GNC 430
Date: Oct 16, 2011
Can you tell me if there is a way to program the Garmin GNC 430 so that the Ground Speed will read out in miles per hour instead of knots? Cliff Hoyle ________________________________________________________________________________
Subject: Re: Garmin GNC 430
Date: Oct 17, 2011
Cliff, I would call Garmin support. They will get you a quick answer if it is not in the manual. D ----- Original Message ----- From: Cliff Hoyle To: avionics-list(at)matronics.com Sent: Sunday, October 16, 2011 8:10 PM Subject: Avionics-List: Garmin GNC 430 Can you tell me if there is a way to program the Garmin GNC 430 so that the Ground Speed will read out in miles per hour instead of knots? Cliff Hoyle ________________________________________________________________________________
Date: Oct 18, 2011
Subject: RE: Avionics-List Digest: 1 Msgs - 10/17/11
Date: Oct 20, 2011
Subject: RE: Avionics-List Digest: 0 Msgs - 10/19/11
Date: Oct 24, 2011
Subject: Two VOR/GS/LOC one antenna
Folks, I have two VOR/GS/LOC radios 1. Apollo (now Garmin) SL-30 2. Narco NAV122D/GPS Attached to a Comant CI-182 dual whisker antenna mounted on top ov my VS in my RV6A. The Narco requires a diplexer which is installed and there is aCoax T-Connectorbefore the diplexer as the SL-30 doesn't need to be seperated. Recently, I was doing some practice work for my IFR training - holds at an intercept - requiring two VOR's. Consistently, the SL-30 can pick up either station while the NAV122D is flaky with both stations - but eventually will bring me to the intercept point. I'm gonna guess it's not the antenna - as the SL-30 brings it in fine. My thoughts go to three possible culprits.....the T-Connector, the diplexer, or the radio...question is, how to tell which one? Getting the Narco repaired will bring the "Mission Impossible" theme song in the background - with Narco recently going under. The diplexer is probably easily replaceable for just a few bucks as well as replacing the T-Connector with a Comant splitter (CI-5120). Any opinions out there? I would really rather not replace the radio if the other items may really be the culprit......and I will probably need both VOR's to finish my IFR training and take my checkride. Thanks in advance! Ralph Capen ________________________________________________________________________________
Date: Oct 24, 2011
You might try hooking the SL-30 to the LOC output of the diplexer. You won't have GS but re-flying your practice holds should let you evaluate if the signal getting to the Narco is degraded. You can use the SL-30 standby freq and obs for the 2nd Nav. The SL-30 is a great radio and routinely locks on stations 10-20nm (at ~100nm) before my 430W. The split for my 430W is done the same way as yours, a diplexer and T-connector. Greg Young -----Original Message----- From: owner-avionics-list-server(at)matronics.com [mailto:owner-avionics-list-server(at)matronics.com] On Behalf Of Ralph E. Capen Sent: Monday, October 24, 2011 5:02 PM Subject: Avionics-List: Two VOR/GS/LOC one antenna --> Folks, I have two VOR/GS/LOC radios 1. Apollo (now Garmin) SL-30 2. Narco NAV122D/GPS Attached to a Comant CI-182 dual whisker antenna mounted on top ov my VS in my RV6A. The Narco requires a diplexer which is installed and there is a Coax T-Connector before the diplexer as the SL-30 doesn't need to be seperated. Recently, I was doing some practice work for my IFR training - holds at an intercept - requiring two VOR's. Consistently, the SL-30 can pick up either station while the NAV122D is flaky with both stations - but eventually will bring me to the intercept point. I'm gonna guess it's not the antenna - as the SL-30 brings it in fine. My thoughts go to three possible culprits.....the T-Connector, the diplexer, or the radio...question is, how to tell which one? Getting the Narco repaired will bring the "Mission Impossible" theme song in the background - with Narco recently going under. The diplexer is probably easily replaceable for just a few bucks as well as replacing the T-Connector with a Comant splitter (CI-5120). Any opinions out there? I would really rather not replace the radio if the other items may really be the culprit......and I will probably need both VOR's to finish my IFR training and take my checkride. Thanks in advance! Ralph Capen ________________________________________________________________________________
Date: Oct 25, 2011
10/25/2011 Hello Ralph, You wrote: "and I will probably need both VOR's to finish my IFR training and take my checkride." I am puzzled by your problem. Since the SL-30 has simultaneous dual VOR capability (providing radial information from one VOR to an external CDI to track along and cross track radial information from a different VOR on the face of the SL-30) why would you need to use the Narco NAV122D/GPS to get information from a third VOR? Do you lack a separate CDI for the SL-30 to feed or are you unable to feed the CDI of the Narco unit with the SL-30 as described here? "The NAV 122D/GPS is the same as the NAV 122D except it will include a resolver, thus having the additional capability of being utilized as the required "Left/Right Indicator", in IFR approved GPS or multi-sensor systems installations." 'OC' Baker Says: "The best investment we can make is the time and effort to gather and understand knowledge." PS: I think that it was grossly misleading for Narco to attach the GPS designation to their unit because it has absolutely no GPS capability, but only provides a CDI to be fed in case a separate GPS or other sensor is installed in the aircraft. See here: http://www.aircraftspruce.com/catalog/avpages/narco122Dgps.php ========================================================== From: "Ralph E. Capen" <recapen(at)earthlink.net> Subject: Avionics-List: Two VOR/GS/LOC one antenna Folks, I have two VOR/GS/LOC radios 1. Apollo (now Garmin) SL-30 2. Narco NAV122D/GPS Attached to a Comant CI-182 dual whisker antenna mounted on top ov my VS in my RV6A. The Narco requires a diplexer which is installed and there is aCoax T-Connectorbefore the diplexer as the SL-30 doesn't need to be seperated. Recently, I was doing some practice work for my IFR training - holds at an intercept - requiring two VOR's. Consistently, the SL-30 can pick up either station while the NAV122D is flaky with both stations - but eventually will bring me to the intercept point. I'm gonna guess it's not the antenna - as the SL-30 brings it in fine. My thoughts go to three possible culprits.....the T-Connector, the diplexer, or the radio...question is, how to tell which one? Getting the Narco repaired will bring the "Mission Impossible" theme song in the background - with Narco recently going under. The diplexer is probably easily replaceable for just a few bucks as well as replacing the T-Connector with a Comant splitter (CI-5120). Any opinions out there? I would really rather not replace the radio if the other items may really be the culprit......and I will probably need both VOR's to finish my IFR training and take my checkride. Thanks in advance! Ralph Capen ________________________________________________________________________________
Date: Oct 25, 2011
Subject: Re: [ExperimentalAvionics] Two VOR/GS/LOC one antenna
Jake, Good info on the Narco antenna impedance issues - and it could be an inexpensive solution putting in a real splitter instead of the T-connector. Thanks, Ralph -----Original Message----- >From: James Hookham <godsbman(at)yahoo.com> >Sent: Oct 24, 2011 11:56 PM >To: ExperimentalAvionics(at)yahoogroups.com >Subject: Re: [ExperimentalAvionics] Two VOR/GS/LOC one antenna > > >There is actually a splitter that will do all that you need done. the Narco is very suseptible to impedance issues on the antenna... where as the Garmin is not. But there is a CI splitter that has a dual VOR/GS/LOC output where the VOR has all the information on it the SL30 would need. The T is more than likely causing some issues in your reception... and there are still a few shops that will still work on a 122D (even if self destruct sequence is activated). > >I've actually seen this on quite a few birds out there... the main thing is to avoid too many splitters/T's in a line. > >Jake >xpaviation.com > >--- On Mon, 10/24/11, Ralph E. Capen wrote: > > >From: Ralph E. Capen <recapen(at)earthlink.net> >Subject: [ExperimentalAvionics] Two VOR/GS/LOC one antenna >To: avionics-list(at)matronics.com >Cc: "EXP-AVIONICS" >Date: Monday, October 24, 2011, 4:54 PM > > > > > >Folks, > >I have two VOR/GS/LOC radios >1. Apollo (now Garmin) SL-30 >2. Narco NAV122D/GPS > >Attached to a Comant CI-182 dual whisker antenna mounted on top ov my VS in my RV6A. > >The Narco requires a diplexer which is installed and there is aCoax T-Connectorbefore the diplexer as the SL-30 doesn't need to be seperated. > >Recently, I was doing some practice work for my IFR training - holds at an intercept - requiring two VOR's. Consistently, the SL-30 can pick up either station while the NAV122D is flaky with both stations - but eventually will bring me to the intercept point. > >I'm gonna guess it's not the antenna - as the SL-30 brings it in fine. >My thoughts go to three possible culprits.....the T-Connector, the diplexer, or the radio...question is, how to tell which one? > >Getting the Narco repaired will bring the "Mission Impossible" theme song in the background - with Narco recently going under. > >The diplexer is probably easily replaceable for just a few bucks as well as replacing the T-Connector with a Comant splitter (CI-5120). > >Any opinions out there? I would really rather not replace the radio if the other items may really be the culprit......and I will probably need both VOR's to finish my IFR training and take my checkride. > >Thanks in advance! > >Ralph Capen > > ________________________________________________________________________________
Date: Oct 25, 2011
Greg, Thanks - something ultra-cheap to try from a troubleshooting perspective. Ralph -----Original Message----- >From: Greg Young <bigdog(at)bentwing.com> >Sent: Oct 24, 2011 9:49 PM >To: avionics-list(at)matronics.com >Subject: RE: Avionics-List: Two VOR/GS/LOC one antenna > > >You might try hooking the SL-30 to the LOC output of the diplexer. You won't have GS but re-flying your practice holds should let you evaluate if the signal getting to the Narco is degraded. You can use the SL-30 standby freq and obs for the 2nd Nav. The SL-30 is a great radio and routinely locks on stations 10-20nm (at ~100nm) before my 430W. The split for my 430W is done the same way as yours, a diplexer and T-connector. > >Greg Young > >-----Original Message----- >From: owner-avionics-list-server(at)matronics.com [mailto:owner-avionics-list-server(at)matronics.com] On Behalf Of Ralph E. Capen >Sent: Monday, October 24, 2011 5:02 PM >To: avionics-list(at)matronics.com >Subject: Avionics-List: Two VOR/GS/LOC one antenna > >--> > >Folks, > >I have two VOR/GS/LOC radios >1. Apollo (now Garmin) SL-30 > >2. Narco NAV122D/GPS > >Attached to a Comant CI-182 dual whisker antenna mounted on top ov my VS in my RV6A. > >The Narco requires a diplexer which is installed and there is a Coax T-Connector before the diplexer as the SL-30 doesn't need to be seperated. > >Recently, I was doing some practice work for my IFR training - holds at an intercept - requiring two VOR's. Consistently, the SL-30 can pick up either station while the NAV122D is flaky with both stations - but eventually will bring me to the intercept point. > >I'm gonna guess it's not the antenna - as the SL-30 brings it in fine. > >My thoughts go to three possible culprits.....the T-Connector, the diplexer, or the radio...question is, how to tell which one? > >Getting the Narco repaired will bring the "Mission Impossible" theme song in the background - with Narco recently going under. > >The diplexer is probably easily replaceable for just a few bucks as well as replacing the T-Connector with a Comant splitter (CI-5120). > >Any opinions out there? I would really rather not replace the radio if the other items may really be the culprit......and I will probably need both VOR's to finish my IFR training and take my checkride. > >Thanks in advance! > >Ralph Capen > > ________________________________________________________________________________
Date: Oct 25, 2011
Subject: Re: Two VOR/GS/LOC one antenna
Thanks OC! Yes, the SL-30 can do that - I just need to read the manual - good reminder! I do have it set up to act as a backup CDI - not as a primary head to a second NAV radio though...makes me rethink my panel strategy.... I'll start with re-reading the SL-30 manual for the dual capability. Ralph -----Original Message----- >From: bakerocb(at)cox.net >Sent: Oct 25, 2011 8:24 AM >To: avionics-list(at)matronics.com, recapen(at)earthlink.net >Subject: Avionics-List: Two VOR/GS/LOC one antenna > > >10/25/2011 > >Hello Ralph, You wrote: "and I will probably need both VOR's to finish my >IFR training and take my checkride." > >I am puzzled by your problem. Since the SL-30 has simultaneous dual VOR >capability (providing radial information from one VOR to an external CDI to >track along and cross track radial information from a different VOR on the >face of the SL-30) why would you need to use the Narco NAV122D/GPS to get >information from a third VOR? > >Do you lack a separate CDI for the SL-30 to feed or are you unable to feed >the CDI of the Narco unit with the SL-30 as described here? > >"The NAV 122D/GPS is the same as the NAV 122D except it will include a >resolver, thus having the additional capability of being utilized as the >required "Left/Right Indicator", in IFR approved GPS or multi-sensor systems >installations." > >'OC' Baker Says: "The best investment we can make is the time and effort to >gather and understand knowledge." > >PS: I think that it was grossly misleading for Narco to attach the GPS >designation to their unit because it has absolutely no GPS capability, but >only provides a CDI to be fed in case a separate GPS or other sensor is >installed in the aircraft. See here: > >http://www.aircraftspruce.com/catalog/avpages/narco122Dgps.php > > >========================================================== > > >From: "Ralph E. Capen" <recapen(at)earthlink.net> >Subject: Avionics-List: Two VOR/GS/LOC one antenna > > >Folks, > >I have two VOR/GS/LOC radios >1. Apollo (now Garmin) SL-30 > >2. Narco NAV122D/GPS > >Attached to a Comant CI-182 dual whisker antenna mounted on top ov my VS in >my >RV6A. > >The Narco requires a diplexer which is installed and there is aCoax >T-Connectorbefore >the diplexer as the SL-30 doesn't need to be seperated. > >Recently, I was doing some practice work for my IFR training - holds at an >intercept >- requiring two VOR's. Consistently, the SL-30 can pick up either station >while the NAV122D is flaky with both stations - but eventually will bring me >to the intercept point. > >I'm gonna guess it's not the antenna - as the SL-30 brings it in fine. > >My thoughts go to three possible culprits.....the T-Connector, the diplexer, >or >the radio...question is, how to tell which one? > >Getting the Narco repaired will bring the "Mission Impossible" theme song in >the >background - with Narco recently going under. > >The diplexer is probably easily replaceable for just a few bucks as well as >replacing >the T-Connector with a Comant splitter (CI-5120). > >Any opinions out there? I would really rather not replace the radio if the >other >items may really be the culprit......and I will probably need both VOR's to >finish my IFR training and take my checkride. > >Thanks in advance! > >Ralph Capen > > ________________________________________________________________________________
Date: Oct 25, 2011
Remember that some of us are old enough to have taken our instrument check rides with a single nav-com and ADF(no, I'm not old enough to have used a 4 course AN range). Need a crossing radial? Better be fast on dialing between frequencies and identifying. The SL-30 feature of showing you the radial from the standby VOR is really all you need..just get familiar with activating that feature. On 10/25/2011 6:32 AM, Ralph E. Capen wrote: > --> Avionics-List message posted by: "Ralph E. Capen" > > Thanks OC! > > Yes, the SL-30 can do that - I just need to read the manual - good reminder! > I do have it set up to act as a backup CDI - not as a primary head to a second NAV radio though...makes me rethink my panel strategy.... > > I'll start with re-reading the SL-30 manual for the dual capability. > > Ralph > > ________________________________________________________________________________
Date: Oct 25, 2011
Thanks Kelly, Another vote for learning the features THat I have -----Original Message----- >From: Kelly McMullen <kellym(at)aviating.com> >Sent: Oct 25, 2011 10:10 AM >To: avionics-list(at)matronics.com >Subject: Re: Avionics-List: Two VOR/GS/LOC one antenna > > >Remember that some of us are old enough to have taken our instrument >check rides with a single nav-com and ADF(no, I'm not old enough to have >used a 4 course AN range). Need a crossing radial? Better be fast on >dialing between frequencies and identifying. The SL-30 feature of >showing you the radial from the standby VOR is really all you >need..just get familiar with activating that feature. > >On 10/25/2011 6:32 AM, Ralph E. Capen wrote: >> --> Avionics-List message posted by: "Ralph E. Capen" >> >> Thanks OC! >> >> Yes, the SL-30 can do that - I just need to read the manual - good reminder! >> I do have it set up to act as a backup CDI - not as a primary head to a second NAV radio though...makes me rethink my panel strategy.... >> >> I'll start with re-reading the SL-30 manual for the dual capability. >> >> Ralph >> >> >> > > ________________________________________________________________________________
Date: Nov 01, 2011
Subject: PLEASE READ - 2011 List Fund Raiser Kickoff - 21 Years
Strong!! Dear Listers, This year marks 21 years of the Email Lists and Forums at Matronics! I've been running these forums for nearly half my life! I've made some great friends over the years and had countless email and personal conversations with builders about aircraft building and flying. What a great community of people! The advice, support, and friendship has be invaluable over the years. To support the continued operation and upgrade of the List servers, each November I hold a PBS-like fund raiser. It is solely through the Contributions of List members that these Matronics Lists are possible. There is NO advertising to support the Lists. You might have noticed the conspicuous lack of flashing banners and annoying pop-ups on the Matronics Email List email messages and web site pages including: * Matronics List Forums http://forums.matronics.com * Matronics List Search Engine http://www.matronics.com/search * Matronics List Browser http://www.matronics.com/listbrowse * Matronics List List Wiki http://wiki.matronics.com You don't find advertising on any of these pages because I believe in a List experience that is completely about the sport we all enjoy - airplanes! During the month of November, I will be sending out List messages every couple of days reminding everyone that the Fund Raiser is underway. I ask for your patience and understanding during the Fund Raiser and throughout these regular messages. The Fund Raiser is only financial support mechanism I have to pay all of the bills associated with running these Lists. Your personal Contribution counts! Once again, this year we've got another terrific line up of free gifts to go along with the various Contribution levels. Many of these gifts have been provided by some of the vary members and vendors that you'll find on Matronics Lists and they have been either donated or provided at substantially discounted rates. This year, these generous people include: * Bob Nuckolls of the AeroElectric Connection http://www.aeroelectric.com * Andy Gold of the Builder's Bookstore http://www.buildersbooks.com These are extremely generous guys and I encourage you to visit their respective web sites. Each one offers a unique and very useful aviation-related product line. I would like publicly to thank Bob, and Andy for their generous support of the Lists again this year!! You can make your List Contribution using any one of three secure methods including using a credit card, PayPal, or by personal check. All three methods afford you the opportunity to select one of this year's free gifts with a qualifying Contribution amount!! To make your Contribution, please visit the secure site below: http://www.matronics.com/contribution I would like to thank everyone in advance for their generous financial AND moral support over the years! Matt Dralle Matronics Email List Administrator RV-8 Builder (and Rebuilder) and Flyer RV-6 Rebuilder and Flyer RV-4 Builder ________________________________________________________________________________
Date: Nov 02, 2011
Subject: Electric Connectors
When removing the wings of my RV-6 The wires have to be disconnected. That is done by removing the seats. (The seats have to be removed to remove the wings anyway.) I would like to mount electric connectors in the wing roots so that the dismantling and reassembly of the wings can be facilitated. Does anyone know where I can get suitable electrical connectors? Thanks. George Nielsen RV-6 PH-XGN The Hague, the Netherlands ________________________________________________________________________________
Date: Nov 03, 2011
Subject: Please Support The Lists...
Dear Listers, Just a reminder that November is the Matronics Email List Fund Raiser month. There are some very nice incentive gifts to choose from as well! Please make your Contribution today at: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 05, 2011
Subject: Fund Raiser List of Contributors - Please Make A Contribution
Today! Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its sort of my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take a moment and assure that your name is on that List of Contributors (LOC)? As a number of members have pointed out over the years, the List seems at least - if not a whole lot more - valuable as a building/flying/recreating/entertainment tool as your typical magazine subscription! Please take minute and assure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 07, 2011
Subject: Make A List Contribution - It's Your Personal Squelch Button...
There is an automatic "squelch button" of sorts for the Fund Raiser messages. Here's how it works... As soon as a List member makes a Contribution through the Matronics Fund Raiser web site, their email address is automatically added to this year's Contributor List and they instantly cease to receive further Fund Raiser messages for the rest of the month! Its just that simple! :-) I really do appreciate each and every one of your individual Contributions to support the Lists. It is your support that enables me to upgrade the hardware and software that are required to run a List Site such as this one. It also goes to pay for the commercial-grade Internet connection and to pay the huge electric bill to keep the computer gear running and the air conditioner powered on. I run all of the Matronics Email List and Forums sites here locally which allows me to control and monitor every aspect of the system for the utmost in reliably and performance. Your personal Contribution matters because, when combined with other Listers such as yourself, it pays the bills to keep this site up and running. I accept exactly ZERO advertising dollars for the Matronics Lists sites. I can't stand the pop-up ads and all other commercials that are so prevalent on the Internet these days and I particularly don't want to have it on my Email List sites. If you appreciate the ad-free, grass-roots, down-home feel of the Matronics Email Lists, please make a Contribution to keep it that way!! http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List Administrator [Note that there are certain circumstances where you might still see a Contribution related message. For example, if someone replies to one of the messages, when using the List Browse feature, or when accessing List message via the Forum. The system keys on the given email address and since most of these are anonymous public access methods, there is no simple way to filter them.] ________________________________________________________________________________
Date: Nov 09, 2011
Subject: Reminder
Dear Listers, Just a quick reminder that November is the annual List Fund Raiser. The Matronics Lists are 100% member supported and all of the operational costs are provided for my your Contributions during this time of the year. Your personal Contribution makes a difference and keeps all of the Matronics Email Lists and Forums completely ad-free. Please make your Contribution today to keep these services up and running! http://www.matronics.com/contribution Thank you in advance! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 11, 2011
Subject: Please Make A Contribution To Support Your Lists
Dear Listers, There is no advertising income to support the Matronics Email Lists and Forums. The operation is supported 100% by your personal Contributions during the November Fund Raiser. Please make your Contribution today to support the continued operation and upgrade of these services. You can pick up a really nice gift for making your Contribution too! You may use a Credit Card or Paypal at the Matronics Contribution Site here: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you in advance for your generous support! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 13, 2011
From: "p.segino(at)libero.it" <p.segino(at)libero.it>
Subject: Gps Connection.
Hello,my name is Peter, I have a problem with my Dynon Skyview D1000 in stalled on my ultralight aircraft (Skyleader 150); I would like to in stall a second gps an AvMap II, on the plane there is already installed the genuine one the SV-GPS-250, and on the DB37 connector for electrical connections there no more free pins. I need a free RX pin for my work. Is there someone who can help me? I need to know where I can connect my second gps. Thank you for your help. Bye Peter. ________________________________________________________________________________
Date: Nov 13, 2011
Subject: Make Sure You're Listed! List of Contributors Published
in December! Dear Listers, The List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 15, 2011
Subject: What's Your Contribution Used For?
Dear Listers, You might have wondered at some pointd, "What's my Contribution used for?" Here are just a few examples of what your direct List support enables... It provides for the expensive, commercial-grade Internet connection used on the List. It pays for the regular system hardware and software upgrades enabling the highest performance possible for List services such as the Archive Search Engine, List Browser, and the Web Forums. It pays for over 21 years (yeah, I really said *21* years) worth of on line archive data available for instant search and access. And, it offsets the many hours spent writing, developing, and maintaining the custom applications that power this List Service such as the List Browse, Search Engine, Forums, and Wiki. But most importantly, your List Contribution enables a forum where you and your peers can communicate freely in an environment that is free from moderation, censorship, advertising, commercialism, SPAM, and computer viruses. It is YOUR CONTRIBUTION that directly enables these aspects of Matronics List services. Please support it today with your List Contribution. Its one of the best investments you can make in your Sport! List Contribution Web Site: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you for your support! Matt Dralle Email List Administrator ________________________________________________________________________________
Date: Nov 17, 2011
Dear Listers, Just a reminder that November is the Matronics Email List Fund Raiser month. There are some very nice incentive gifts to choose from as well! Your Contributions alone keep these services up and running. Please make your Contribution today at: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 17, 2011
You can use the SL-30 standby freq and obs for the 2nd Nav. The SL-30 is a great radio and routinely locks on stations 10-20nm (at ~100nm) before my 430W. .......... -------- || Read this topic online here: http://forums.matronics.com/viewtopic.php?p=358332#358332 ________________________________________________________________________________
Subject: Re: Removal of Garmin GNS-430 from Instrument Panel
Date: Nov 17, 2011
A 430 has a locking leg on the bottom of the unit that pulls it in and pushes it out of the tray....... -------- || Read this topic online here: http://forums.matronics.com/viewtopic.php?p=358334#358334 ________________________________________________________________________________
Date: Nov 18, 2011
On 11/17/2011 08:56 PM, royalina wrote: > --> Avionics-List message posted by: "royalina"<25royalina(at)gmail.com> > > A 430 has a locking leg on the bottom of the unit that pulls it in and pushes it out of the tray....... > > -------- And you move the tang by inserting a small allen wrench (sorry; don't recall the exact size) in that small hole you see at the bottom-center of the front panel. Turn counter-clockwise until it stops; you might notice the 430 backing out of the panel slightly as you turn the allen head screw. ________________________________________________________________________________
Date: Nov 18, 2011
From: "George, Neal Capt 505 TRS/DOJ" <Neal.George(at)hurlburt.af.mil>
Use a 3/32" Allen wrench with care - it's a retainer, not a jack screw. Too much enthusiasm will bend the tray and jam things up. When you release the initial clamp-up tension, you'll get 2 or 3 relatively free turns, then meet more resistance. That's your clue to use fingers in addition to the Allen wrench to coax the radio out of the tray. Same exercise when putting it back in. Position the locking lug by turning the Allen wrench counter-clockwise, then slide the radio into the tray - gently - make sure things are lined up in the back as it begins to seat. When the radio stops, begin to tighten the Allen wrench while continuing to push the radio home. When things stop moving easily, it's time to stop tightening the retainer. Resist the urge to cinch it down. neal -----Original Message----- And you move the tang by inserting a small allen wrench (sorry; don't recall the exact size) in that small hole you see at the bottom-center of the front panel. Turn counter-clockwise until it stops; you might notice the 430 backing out of the panel slightly as you turn the allen head screw. ============ On 11/17/2011 08:56 PM, royalina wrote: > A 430 has a locking leg on the bottom of the unit that pulls it in and pushes it out of the tray....... ________________________________________________________________________________
Date: Nov 19, 2011
Subject: The Value of a Forum...
If you look forward to checking your List email everyday (and a lot of you have written to say that you do!), then you're probably getting at least $20 or $30 worth of Entertainment from the Lists each year. You'd pay twice that for a subscription to some magazine or even a dinner out. Arn't the Lists worth at least that much to you? Wouldn't it be great if you could pay that same amount and get a well-managed media source free of advertising, SPAM, and viruses? Come to think of it, you do... Won't you take a minute to make your Contribution today and support YOUR Lists? Please make a Contribution today at: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Again, I want to say THANK YOU to everyone that has made a Contribution thus far during this year's List Fund Raiser!! These Lists are made possible exclusively through YOUR generosity!! Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Date: Nov 21, 2011
Subject: Make Sure You're Listed -- List of Contributors Published
Dec 1! Dear Listers, The List of Contributors (LOC) is just around the corner! On December 1st I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. As a number of people have pointed out in their Contribution comments, the Lists are a whole lot more valuable than your typical magazine subscription! Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matronics / Matt Dralle 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 23, 2011
Subject: Contributions Down By 20%...
Dear Listers, As of today, Contributions to the Matronics List Fund Raiser are lagging behind last year at this time by roughly 20%. I have a Fund Raiser each year simply to cover my operating costs for the Lists. I *do not* accept any advertising income to support the Lists and rely solely on the Contributions of members to keep the expenses paid. I run all of my own servers and they are housed here locally, and the Internet connection is a commercial-grade, T1 connection with public address space. I also maintain a full backup system that does nightly backups of all List-related data so that in the event of a server crash, all of the Lists and the many years of List archive data could be restored onto a new server in a matter of hours. All of this costs a fair amount of money, not to mention a significant amount of my personal time. I have a Fund Raiser each year to cover these costs and I ask that members that feel they receive a benefit from my investments make a modest Contribution each year to support the continued operation and upgrade of these services. If you enjoy the Lists, please make a Contribution today. I also offer some incentive gifts for larger Contribution levels. At the Contribution Web Site, you can use a credit card, Paypal, or personal check to show your support for the continuation of these services: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you for your support! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 25, 2011
Subject: Just A Few More Days To Make Your List Contribution...
There is less than a week left in this year's List Fund Raiser and only a few short days to grab one of the great Contribution Gifts available this year. Support is still significantly lagging behind last year at this point but hopefully it will pick up here towards the end. Please remember that it is solely the Contributions of List members that keeps the Lists up and running as there is no commercialism or advertising on the Matronics Lists and Forums. The List Contribution web site is secure, fast, and easy and you can use a credit card, Paypal: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I want to thank everyone that has already made a generous contribution to support the Lists! Thank you! Matt Dralle Matronics EMail List and Forum Administrator ________________________________________________________________________________
Date: Nov 27, 2011
Subject: Please Make A Contribution Today...
Dear Listers, A quick reminder that November is the annual List Fund Raiser and the List of Contributors is quickly approching. The Matronics Lists are 100% member supported and all of the operational costs are provided for by your Contributions during this time of the year. Your personal Contribution makes a big difference and keeps all of the Matronics Email Lists and Forums completely ad-free. Please make your Contribution today to keep these services up and running! http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you in advance! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Subject: Maintenance manual for King KT76A?
Date: Nov 27, 2011
Anyone got the Maintenance manual for King KT76A in PDF? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=359457#359457 ________________________________________________________________________________
Date: Nov 27, 2011
Subject: Re: Maintenance manual for King KT76A?
*greetz from the netherlands * 2011/11/27 Brantel > > Anyone got the Maintenance manual for King KT76A in PDF? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=359457#359457 > > -- Met vriendelijke groet, Eric Tiethoff mail: eric(at)tiethoff.nl web: http://tiethoff.nl ________________________________________________________________________________
Date: Nov 29, 2011
Subject: Just Two Days Left - Still Way Behind...
Dear Listers, There are just two more days left in this years List Fund Raiser. Over the last few weeks I have received some really nice comments from members on what the Lists have meant to them. I have included some of them below. Please read over the comments and ponder on your own feelings about the Lists and the support and camaraderie you have found here. We are still way behind last year in terms of the number of contributions. I really want to keep providing these services to the homebuilt community, but it take resources. Since there's no advertising budget or deep pockets to keep the operation a float, its solely your generosity during the Fund Raiser that keeps things going. Please make a Contribution today. If you've been putting off showing your support for the Lists, now is the time to do it! Make a contribution with a Credit Card or though PayPal at that Matronics Contribution web site: http://www.matronics.com/contribution Or, drop a check in the mail: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you in advance for your support! Matt Dralle Matronics Email List Administrator ==================== A Few List Member Comments ===================== I get a lot of useful information and satisfaction from belonging to your groups. Somehow you foster a great sense of community without the baggage that accompanies other lists. Dave S. We do appreciate you running the lists spam and advertising free. Jeff P. I am celebrating my first flight day and you and the lists deserve a thanks since without it my build would have taken twice as long. Chris L. I enjoy the list. Have my morning coffee with it! Buddy M. Your lists are the best investment of my time and money, bar none, when it comes to interfacing with my fellow amateur builders. Owen B. Keep it going!! Thanks for taking over. Wallace J. I enjoy the Pietenpol List a lot. Malcolm Z. Thanks for your great site! As a new CJ-6 owner, your web site is an invaluable resource. Ken B. Great informational source. Fred S. Thanks for doing this! Lance G. Thank you for the service i do enjoy the many hours I use on line with the banter/ serious technical items. Noel G. Thanks for the years of builder support. Roy H. Great forum! Roger C. Thank you VERY MUCH, Matt, for carrying on with this great service. The "Europa" community really appreciates it. All the best, Svein - now celebrating 10 years as a subscriber, I think! Svein J. Matt, I'm building a much nicer and safer airplane because of your efforts. Robert D. 21 years for you 9 years for me on the Zenith lists. Could not imagine building and flying without Matronics. Brian U. Thanks for ALL the hard work and time you put into maintaining these forums. As an EAA Tech counselor I recommend them often. Paul M. This Pietenpol list is a huge part of the motivation that keeps me working on my project. This has been a great place for meeting like minded folks and getting help for the difficult parts. Thomas S. Thanks for the excellent service Matt. Frank S. Matt, I'm a Sonex building, but I have to say that the Piet group is without a doubt the most interesting. Ken M. I can't tell you how much I appreciate the Piet List. This is one of my sanity lifelines! Daniel H. Your site has provided us over the years with excellent connections to others for advice. Good job! Bob M. Kolb List is my #1 source! Henry V. Matt, you do a great job with this site. I've been with it since the beginning! John M. I am very grateful for all of your excellent work on the List. Arthur L. Thank you for the service you provide us all! Nicholas C. ________________________________________________________________________________
Date: Nov 30, 2011
Subject: [Please Read] - Last Official Day of List Fund Raiser!
Dear Listers, Its November 30th and that means a couple of things. Its my birthday again, 48 of them, in fact! But it also means that its that last official day of the Matronics Email List Fund Raiser! If you been jones'n over one of those really nice incentive gifts now is the time to jump on one!! If you've been meaning to make a Contribution this month but have been putting it off for some reason, NOW is the time! I will be posting the List of Contributors in a few days, so you'll probably want to be known as a person that supported the Lists! I want to thank everyone that has so generously made a Contribution this year in support of our Lists. It is your generosity that keeps this operation running and I don't ever forget it. Hopefully everyone feels the same. Below are a few more of the nice comments from Listers I've received this year. Please read them over and see if you don't agree. The List Contribution Web Site is fast and easy. Please support our habit by making your Contribution right now: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you to all in advance! Matt Dralle Matronics Email List Administrator ==================== A Few More List Member Comments ===================== I never would have ended up with the great flying airplane I have without the help of people on the Pietenpol list. Thanks for giving us the medium to communicate our questions, tips and suggestions. Matt P. Thanks for the hard work and maintaining the site commercial free. Good luck for the future and this site has been a source of great friendship. Peter B. It is a great resource. Jim G. Thanks so much for your continuing support of the homebuilt community. Gerald A. You are doing an outstanding job running the list's. Keep it going. Bill V. Thanks for keeping this valuable information source going. Best of all the forums. George A. Another Great year on the RV-List! Thomas E. Still the best source of information (& opinion) for builders on a wide range of issues. Martin H. Matt, thanks for hosting and maintaining the lists! Rumen D. It is a great resource. Bryan R. Thanks for your continuing interest in Van's RV8 kitplanes. Peter C. I'm no longer building or flying but like to keep in touch with the current generation of builders. Best wishes to a great list system. Gerry C. A great list that is most useful for builders. Graham H. Thanks for this wonderful tool! Ralph C. Thanks for a great service to the experimental aviation community. Douglas D. Great topics and loads of useful info keep the subject matter relevant. George H. Thanks for keeping this going. Richard R. Great facility and well managed. Victor F. Thanks for a great service. John D. Thank you for you time and efforts they have made Aviation a better place for everyone. Jim W. I still enjoy getting the list in the morning. Don M. You provide a great resource. David M. You have probably saved a few necks over the years. Robert F. Thank you for being there. Benjamin B. You perform a great service. Bruce M. Thank you for providing this invaluable resource. William D. ________________________________________________________________________________
Subject: Re: Avionics-List Digest: 1 Msgs - 11/30/11
Date: Dec 01, 2011
Matt, I know it's Dec 1st, but hope that won't preclude you from cashing my donation check when it arrives. Jim Kinninger Smith Valley, Nevada On Nov 30, 2011, at 11:56 PM, Avionics-List Digest Server wrote: > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete Avionics-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the Avionics-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 11-11-30&Archive=Avionics > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 11-11-30&Archive=Avionics > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > Avionics-List Digest Archive > --- > Total Messages Posted Wed 11/30/11: 1 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 0. 12:20 AM - [Please Read] - Last Official Day of List Fund Raiser! (Matt Dralle) > > > > ________________________________ Message 0 _____________________________________ > > > From: Matt Dralle <dralle(at)matronics.com> > Subject: Avionics-List: [Please Read] - Last Official Day of List Fund Raiser! > > > Dear Listers, > > Its November 30th and that means a couple of things. Its my birthday again, 48 > of them, in fact! But it also means that its that last official day of the > Matronics Email List Fund Raiser! If you been jones'n over one of those really > nice incentive gifts now is the time to jump on one!! > > If you've been meaning to make a Contribution this month but have been putting > it off for some reason, NOW is the time! > > I will be posting the List of Contributors in a few days, so you'll probably want > to be known as a person that supported the Lists! > > I want to thank everyone that has so generously made a Contribution this year in > support of our Lists. It is your generosity that keeps this operation running > and I don't ever forget it. Hopefully everyone feels the same. > > Below are a few more of the nice comments from Listers I've received this year. > Please read them over and see if you don't agree. > > The List Contribution Web Site is fast and easy. Please support our habit by making > your Contribution right now: > > http://www.matronics.com/contribution > > Or, by dropping a personal check in the mail to: > > Matt Dralle / Matronics > 581 Jeannie Way > Livermore CA 94550 > > Thank you to all in advance! > > Matt Dralle > Matronics Email List Administrator > > > ==================== A Few More List Member Comments ==================== > > I never would have ended up with the great flying airplane I have without > the help of people on the Pietenpol list. Thanks for giving us the medium > to communicate our questions, tips and suggestions. > > Matt P. > > Thanks for the hard work and maintaining the site commercial free. Good > luck for the future and this site has been a source of great friendship. > > Peter B. > It is a great resource. > > Jim G. > > Thanks so much for your continuing support of the homebuilt community. > > Gerald A. > > You are doing an outstanding job running the list's. Keep it going. > > Bill V. > > Thanks for keeping this valuable information source going. Best of all > the forums. > > George A. > > Another Great year on the RV-List! > > Thomas E. > > Still the best source of information (& opinion) for builders on a wide > range of issues. > > Martin H. > > Matt, thanks for hosting and maintaining the lists! > > Rumen D. > > It is a great resource. > > Bryan R. > > Thanks for your continuing interest in Van's RV8 kitplanes. > > Peter C. > > I'm no longer building or flying but like to keep in touch with the current > generation of builders. Best wishes to a great list system. > > Gerry C. > > A great list that is most useful for builders. > > Graham H. > > Thanks for this wonderful tool! > > Ralph C. > > Thanks for a great service to the experimental aviation community. > > Douglas D. > > Great topics and loads of useful info keep the subject matter relevant. > > George H. > > Thanks for keeping this going. > > Richard R. > > Great facility and well managed. > > Victor F. > > Thanks for a great service. > > John D. > > Thank you for you time and efforts they have made Aviation a better > place for everyone. > > Jim W. > > I still enjoy getting the list in the morning. > > Don M. > > You provide a great resource. > > David M. > > You have probably saved a few necks over the years. > > Robert F. > > Thank you for being there. > > Benjamin B. > > You perform a great service. > > Bruce M. > > Thank you for providing this invaluable resource. > > William D. > > > > > > > > > ________________________________________________________________________________
Date: Dec 04, 2011
Subject: Hardware Failure - Matronics Web Servers Currently Offline
failure and is currently not available. Replacement hardware has been ordered and should arrive on Tuesday 12/6/2011. All services should be restored shortly there after. During the outage, the Matronics Forums, Wiki, and other web-based List services will NOT be available. However, during the outage, all normal EMAIL based sevices WILL be available so you may continue to post messages to the various lists without an issue. I am so sorry for any inconvenience this web server outage has caused... Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Dec 07, 2011
Subject: Matronics Web Services Restored!
Dear Listers, web services have been fully restored including the Web Forums, List Browse, Archive Search, Wiki, and AeroElectric web sites. It was quite an ordeal getting the replacement boards for the server, but things went back together tonight and are up and running nicely. The first company I ordered the boards from originally called me a day later to say that, whoops, they really didn't have them in stock after all... Fortunately, I was able to locate some through a different source and had then over-nighted and they arrived today. Thank you for your patience and consideration though the whole thing! The List Contribution web site is also back on line for those wishing to make a donation to the effort: http://www.matronics.com/contribution Best regards, Matt Dralle Matronics List Administrator ________________________________________________________________________________
Subject: Re: Avionics-List Digest: 0 Msgs - 12/08/11
Date: Dec 09, 2011
Matt, I went to the Matronics website to Register. I have never been asked for the following info and don't know what the answers are or where to find them: ICQ Number AIM Number MSN Messenger Yahoo Messenger I don't have a website. I have never used a Signature and not sure how to enable that feature. Thanks for your help. Jim Kinninger On Dec 8, 2011, at 11:56 PM, Avionics-List Digest Server wrote: > * > > ======================== > Online Versions of Today's List Digest Archive > ======================== > > Today's complete Avionics-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the Avionics-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&C hapter 11-12-08&Archive=Avionics > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Ch apter 11-12-08&Archive=Avionics > > > ======================== ======================= > EMail Version of Today's List Digest Archive > ======================== ======================= > > > ---------------------------------------------------------- > Avionics-List Digest Archive > --- > Total Messages Posted Thu 12/08/11: 0 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > > > > > > > > > > James Kinninger jimk(at)hdiss.net ________________________________________________________________________________
Date: Dec 09, 2011
Jim...those are instant messengers (IM)...if you don't belong to any of them, then you don't have...or need.. to enter your IM identification numbers there. Personally, I'm was only an ICQ user, but have since dropped that. As far as a signature, that is just something that is automatically added at the end of your email or messages. You can add that if you want to include stuff like your company, plane type, etc...personally, I don't do that either, as I may want to use a different sign out for different groups, so I always enter it manually...like this: Harley ----------------------------------------------------------------- On 12/9/2011 1:19 PM, James Kinninger wrote: > Matt, > I went to the Matronics website to Register. I have never been > asked for the following info and don't know what the answers > are or where to find them: > ICQ Number > AIM Number > MSN Messenger > Yahoo Messenger > I don't have a website. > I have never used a Signature and not sure how to enable that > feature. > Thanks for your help. > Jim Kinninger > > * > * ________________________________________________________________________________
Date: Dec 09, 2011
Jim, You only need to enter that information if you want to and if you have it. I, for instance have an ICQ number, but did not enter it. You don't have to use a signature either. Have a wonderful day, Dennis N616DW (Arion Lightning S/N 132) -----Original Message----- From: James Kinninger <jimk(at)hdiss.net> Sent: Fri, Dec 9, 2011 1:25 pm Subject: Avionics-List: Re: Avionics-List Digest: 0 Msgs - 12/08/11 Matt, I went to the Matronics website to Register. I have never been asked for th e following info and don't know what the answers are or where to find them: ICQ Number AIM Number MSN Messenger Yahoo Messenger I don't have a website. I have never used a Signature and not sure how to enable that feature. Thanks for your help. Jim Kinninger On Dec 8, 2011, at 11:56 PM, Avionics-List Digest Server wrote: * Online Versions of Today's List Digest Archive Today's complete Avionics-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the Avionics-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html &Chapter 11-12-08&Archive=Avionics Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt& Chapter 11-12-08&Archive=Avionics ====================== EMail Version of Today's List Digest Archive ====================== ---------------------------------------------------------- Avionics-List Digest Archive --- Total Messages Posted Thu 12/08/11: 0 ---------------------------------------------------------- Today's Message -- Please Support Your Lists This (And Get AeroElectric http://www.matronics.com/co -Matt Dralle, List - The --> http://www.matro &n - &nbs --> http://www.matronics.com/co=== ============= James Kinninger jimk(at)hdiss.net James Kinninger jimk(at)hdiss.net - -= -- Please Support Your Lists This Month -- -= (And Get Some AWESOME FREE Gifts!) - -= November is the Annual List Fund Raiser. Click on -= the Contribution link below to find out more about -= this year's Terrific Free Incentive Gifts provided -= by: - -= * AeroElectric www.aeroelectric.com -= * The Builder's Bookstore www.buildersbooks.com -= * HomebuiltHELP www.homebuilthelp.com - -= List Contribution Web Site: - -= --> http://www.matronics.com/contribution - -= Thank you for your generous support! - -= -Matt Dralle, List Admin. - -======================== -= - The Avionics-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Avionics-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Subject: NARCO NAV825 - Pin 'N' - NAV Video
Date: Dec 14, 2011
Is this connection ('ARINC NAV VIDEO') a 'composite out', for indicators that use a single input a/o the C/D/E/F/G/H resolver inputs? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=360949#360949 ________________________________________________________________________________
Date: Dec 15, 2011
Subject: Yahoo! Auto Response
I am turning this email off due to being HACKED and can't stop it. Please forward any future email to mark.schrick(at)gmail.com Thank you Mark ________________________________________________________________________________
Date: Dec 19, 2011
Subject: 2011 List of Contributors
Dear Listers, The 2011 Matronics Email List and Forum Fund Raiser officially ended a couple of weeks ago and its time that I publish this year's List of Contributors. Its the people on this list that directly make the Email Lists and Forums possible. Their generous contributions keep the servers and Internet connection up and running! You can still show your support this year and pick up a great gift at the same time. The Contribution Web Site is fast, easy, and secure: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I also want to thank Bob, Jon, and Andy for their generous support through the supply of great gifts this year!! These guys have some great products and I encourage you to visit their respective web sites: Bob Nucklolls - AeroElectric - http://www.aeroelectric.com Jon Croke - HomebuiltHELP - http://www.homebuilthelp.com Andy Gold - The Builder's Bookstore - http://www.buildersbooks.com And finally, I'm proud to present The 2011 Fund Raiser List of Contributors: http://www.matronics.com/loc/2011.html Thanks again to everyone that made a Contribution this year!! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Subject: Transmit Noise
Date: Dec 31, 2011
Hello All. Today flying my KF Vixen 912UL I developed a radio transmit noise. As soon as I pressed the PTT (on either stick) there is a solid sharp buzzing sound in the headsets. almost like something is shorting out. Other a/c and the tower could understand the transmission OK but the tower said it sounded "hollow, like I was talking from inside a can". This is a very recent development. The radio is a 18 month old ICOM A210. I will start checking things on my own but just wondering if I could tap into this wealth of knowledge before I start buggering things up. I was using the built in intercom. Forgot to try with it disabled. Have a great News Years everyone. Drive a FLY safe! Cheers Don Read this topic online here: http://forums.matronics.com/viewtopic.php?p=362154#362154 ________________________________________________________________________________
Date: Jan 01, 2012
Subject: Re: Transmit Noise
On 12/31/2011 06:15 PM, VIXEN wrote: > --> Avionics-List message posted by: "VIXEN" > > Hello All. > Today flying my KF Vixen 912UL I developed a radio transmit noise. As soon as I pressed the PTT (on either stick) there is a solid sharp buzzing sound in the headsets. almost like something is shorting out. Other a/c and the tower could understand the transmission OK but the tower said it sounded "hollow, like I was talking from inside a can". This is a very recent development. The radio is a 18 month old ICOM A210. > I will start checking things on my own but just wondering if I could tap into this wealth of knowledge before I start buggering things up. > I was using the built in intercom. Forgot to try with it disabled. > Have a great News Years everyone. Drive a FLY safe! > Cheers > Don > Easy stuff is to make sure the other headset isn't plugged in (if there's no head in the headset), and as you mentioned, go direct into the radio, bypassing the intercom. Most intercoms can be taken out of the circuit by just turning them off. Make sure that your volume & gain settings haven't changed, also. Charlie ________________________________________________________________________________
Subject: Composite NAV signal from Collins VIR-351 Nav radio...
Date: Jan 02, 2012
Essentially, it's supposed to support this feature (bypassing the vor/loc converter) but I can't find a pinout that lists how to get this signal... I'm trying to figure out how to hook up a CDI that takes composite input, as the only ones that don't are the really expensive Collins and King models. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=362228#362228 ________________________________________________________________________________
Date: Jan 02, 2012
Subject: Narco AT-165 Transponder wiring question
I recently purchased a nice used Narco AT-165 transponder from a third party. Luckily, it came with a harness. Unfortunately, it did not come with installation instructions. The harness has a 23 pin connector on the transponder side and a 15 pin connector on the altitude reporter side. Three heavier wires (I believe 16 ga.) are cut to about 4 inches in length, coming out of the 23 pin connector. I am assuming these are the power leads, red (+14V), black (Grnd), and yellow (?). That's my question; what should this yellow wire attach to? It comes out of pin #12 on the connector. I can't seem to find any wiring instructions on the internet for this 23 pin transponder. ________________________________________________________________________________
Date: Jan 02, 2012
Traditional avionics color coding makes the red wire power, the black wire ground, and the yellow wire the dimmer. Here=99s a link to the AT-165 installation manual. It says that pin 5 is +13.75 V input, pin 11 is the 14 V dimmer, and pin 12 is ground. Perhaps the yellow wire is going to pin 11 instead of pin 12? And I think it may be a 24-pin edge connector, with 12 pins on each side. Hope this helps you get everything sorted out! http://www.aeroelectric.com/Installation_Data/Narco/narco-at-165-install. pdf From: owner-avionics-list-server(at)matronics.com [mailto:owner-avionics-list-server(at)matronics.com] On Behalf Of N262TH(at)comcast.net Sent: Monday, January 02, 2012 3:24 PM Subject: Avionics-List: Narco AT-165 Transponder wiring question I recently purchased a nice used Narco AT-165 transponder from a third party. Luckily, it came with a harness. Unfortunately, it did not come with installation instructions. The harness has a 23 pin connector on the transponder side and a 15 pin connector on the altitude reporter side. Three heavier wires (I believe 16 ga.) are cut to about 4 inches in length, coming out of the 23 pin connector. I am assuming these are the power leads, red (+14V), black (Grnd), and yellow (?). That's my question; what should this yellow wire attach to? It comes out of pin #12 on the connector. I can't seem to find any wiring instructions on the internet for this 23 pin transponder. ________________________________________________________________________________
Date: Jan 02, 2012
Subject: Re: Narco AT-165 Transponder wiring question
Narco did one thing right. All of their transponders use the same tray and pin connections. So pinout for AT50 or 150 will work. On 1/2/2012 4:23 PM, N262TH(at)comcast.net wrote: > I recently purchased a nice used Narco AT-165 transponder from a third > party. Luckily, it came with a harness. Unfortunately, it did not > come with installation instructions. The harness has a 23 pin > connector on the transponder side and a 15 pin connector on the > altitude reporter side. Three heavier wires (I believe 16 ga.) are > cut to about 4 inches in length, coming out of the 23 pin connector. > I am assuming these are the power leads, red (+14V), black (Grnd), > and yellow (?). That's my question; what should this yellow wire > attach to? It comes out of pin #12 on the connector. I can't seem to > find any wiring instructions on the internet for this 23 pin transponder. > * > > > * ________________________________________________________________________________
Subject: Re: Narco AT-165 Transponder wiring questionNarco AT-165
Date: Jan 03, 2012
After further investigation, I found out that Narco made several models of the AT-165 Transponder as either a new installation (AT-165) or as a King KT-76 slide-in replacement (AT-165K) or as a Cessna RT-359/459 slide in replacement (AT-165C). Turns out the unit I have is the AT-165C model. It does, for sure, have a 23 pin connector just like the old Cessna Transponder. After finding this out, I was able to determine that the 16ga. yellow wire from pin #12 was, indeed, for lighting. Thanks fella's! ________________________________________________________________________________
Subject: WTB dead Narco CP 135/136 or similar
Date: Feb 02, 2012
I have a 1" (actually 1.1") slot on my radio stack that I want to fill with some homebrew electronics and need a tray and whatever was in the tray. A depth between 6 and 10 inches (the longer the better). Anybody have anything clogging up the shop? Send offers to johnl(at)loram.org thanks, -john- ________________________________________________________________________________
Subject: RST 447K assembly manual wanted
Date: Feb 24, 2012
I am trying to help a friend with an RST-447K panel mount intercom that has died. He has lost the Assembly Manual, which is section D and separate to the general manual. Does anyone have a copy of the manual that they could email to me, or at least a circuit of the unit. My email address is ballalae(at)yahoo.com Thanks, Brian. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367115#367115 ________________________________________________________________________________
Date: Feb 24, 2012
Subject: Re: RST 447K assembly manual wanted
Why not just contact RST? On 2/24/2012 3:25 AM, oldngrey wrote: > --> Avionics-List message posted by: "oldngrey" > > I am trying to help a friend with an RST-447K panel mount intercom that has died. He has lost the Assembly Manual, which is section D and separate to the general manual. Does anyone have a copy of the manual that they could email to me, or at least a circuit of the unit. My email address is ballalae(at)yahoo.com > Thanks, > > Brian. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=367115#367115 > > ________________________________________________________________________________
Date: Feb 24, 2012
I have been trying to contact RST for weeks, NO LUCK. Anyone know what has happened to them? Thanks Rob Henderson -----Original Message----- From: owner-avionics-list-server(at)matronics.com [mailto:owner-avionics-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Friday, February 24, 2012 6:12 AM Subject: Re: Avionics-List: RST 447K assembly manual wanted --> Why not just contact RST? On 2/24/2012 3:25 AM, oldngrey wrote: > --> Avionics-List message posted by: "oldngrey" > > I am trying to help a friend with an RST-447K panel mount intercom > that has died. He has lost the Assembly Manual, which is section D and > separate to the general manual. Does anyone have a copy of the manual > that they could email to me, or at least a circuit of the unit. My > email address is ballalae(at)yahoo.com Thanks, > > Brian. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=367115#367115 > > ________________________________________________________________________________
Date: Feb 24, 2012
That has been tried Kellym, with the same result that Rob Henderson had. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367171#367171 ________________________________________________________________________________
Subject: Swap: I have a KMA-20 and need a KA-134
Date: Feb 27, 2012
I have a King KMA-20 audio panel with tray which I wish to swap for a KA-134 with tray. -john- JOHNL(at)LORAM.ORG ________________________________________________________________________________
Subject: Re Re-juvinate a NiCad Battery?
Date: Mar 07, 2012
I had this experience with my Dynon EFIS. I had a major delay in my building project (like 4 years) and when I got back to it my EFIS (Electronic Flight Instrument System) battery pack was beyond resuscitation. The replacement battery pack was listed at $125. So I took the shrink wrap off the pack which revealed 4 batteries soldered together with some mini electronic parts (possible diodes?) included in the wiring. Very carefully, I took the pack apart, examined the batteries and looked them up on the web. I bought a pack of 6 just incase of a screw up, used silver solder to put it back together and it works and charges just fine, Cost w/ shipping about $36. Jim Kinninger Tundra Builder ________________________________________________________________________________
Date: Mar 07, 2012
Subject: Re: Re Re-juvinate a NiCad Battery?
Good job. I know a guy that did the same for his ELT battery. Easy, effective, and cheap. My three favorite things. Cheers, -- Larry Bowen Larry(at)BowenAero.com http://BowenAero.com On Wed, Mar 7, 2012 at 10:18 AM, James Kinninger wrote: > > I had this experience with my Dynon EFIS. I had a major delay in my > building project (like 4 years) and when I got back to it my EFIS > (Electronic Flight Instrument System) battery pack was beyond > resuscitation. The replacement battery pack was listed at $125. So I took > the shrink wrap off the pack which revealed 4 batteries soldered together > with some mini electronic parts (possible diodes?) included in the wiring. > Very carefully, I took the pack apart, examined the batteries and looked > them up on the web. I bought a pack of 6 just incase of a screw up, used > silver solder to put it back together and it works and charges just fine, > Cost w/ shipping about $36. > Jim Kinninger > Tundra Builder > > ________________________________________________________________________________
Date: Mar 12, 2012
Subject: discontinued Garmin repair facilities?
Who fixes the discontinued Garmin GNC 300 non-moving map (flourescent tube display?)? Are these junk when the display goes out? Thanks, Skip Simpson In a message dated 03/11/12 23:58:00 Pacific Daylight Time, avionics-list(at)matronics.com writes: * ================================================== Online Versions of Today's List Digest Archive ================================================== Today's complete Avionics-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the Avionics-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 12-03-11&Archive=Avionics Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 12-03-11&Archive=Avionics ================================================ EMail Version of Today's List Digest Archive ================================================ ---------------------------------------------------------- Avionics-List Digest Archive --- Total Messages Posted Sun 03/11/12: 0 ---------------------------------------------------------- Today's Message Index: ---------------------- ________________________________________________________________________________
From: "John Cammarano" <jcappraiser(at)sbcglobal.net>
Subject: Transponder
Date: Mar 20, 2012
Can anyone tell me if there is such a thing as a "Portable transponder". I have a small antique airplane with no electrical system & would often like to have a transponder but I don't really want to add a small battery. I don't mind adding the small transponder type antenna. I am trying to find out if there is a transponder out there powered by it's own rechargeable batteries - like a handheld comm radio or a portable GPS. Any info here would be very appreciated. Thanks. Johnny ________________________________________________________________________________
Date: Mar 21, 2012
3/21/2012 Hello John, See this web site: http://www.kinetic.co.uk/last.php Note that a true portable transponder for use in the U. S may be a real tough problem to solve because of the TSO requirements. Also note the requirements of 14 CFR 91.413. The sailplane people work in this arena -- just google transponder for sailplanes. Here is one source: http://www.soaringsafety.org/prevention/Guide-to-transponders-in-sailplanes-2010B.pdf 'OC' Baker Says: "The best investment we can make is the time and effort to gather and understand knowledge." ============================================================== From: "John Cammarano" <jcappraiser(at)sbcglobal.net> Subject: AeroElectric-List: Transponder Can anyone tell me if there is such a thing as a "Portable transponder". I have a small antique airplane with no electrical system & would often like to have a transponder but I don't really want to add a small battery. I don't mind adding the small transponder type antenna. I am trying to find out if there is a transponder out there powered by it's own rechargeable batteries - like a handheld comm radio or a portable GPS. Any info here would be very much appreciated. Thanks. Johnny ________________________________________________________________________________
Subject: Fw: Portable Transponder
Date: Mar 22, 2012
3/2/2012 Hello John Cammarano, I hope that this helps solve your problem. 'OC' Baker ================================================================= From: "John Delafield" <john.delafield(at)lxavionics.co.uk> Sent: Thursday, March 22, 2012 4:15 PM Subject: RE: Portable Transponder > Dear Sir, > > We assemble the transponder box using a certified TT 21 or 22 which has > FAA > approval so no worries there. The entire box is not approved by anyone > but > as it is portable I do not think it necessary anyway. > > The altitude encoder is built in to the transponder and it meets the new > 25ft spacing requirement. > > I am pretty sure for your application that you would not need the very > expensive hand made leather case that we normally provide and not having > this would reduce the price to you by about $200. > > Lead time for delivery would be a few weeks. > > I very much hope that we can help you, > > All the best, > > John Delafield > LX avionics Ltd > 07850 950349/01865 374125 > www.lxavionics.co.uk > Company Number 4417407 Registered in England and Wales > VAT GB 793 1777 86 > Registered address (NOT FOR BUSINESS): 30 St Giles, Oxford > ====================================================== From: bakerocb(at)cox.net [mailto:bakerocb(at)cox.net] > Sent: 22 March 2012 15:42 > To: johnd(at)lxavionics.co.uk > Subject: Portable Transponder > > 3/22/2012 > > Hello John, We are seeking a portable airtraffic radar transponder for use > in a small homebuilt (no electrical power) fixed wing airplane in the US. > Your products seen here: > > http://www.lxavionics.co.uk/portables.htm > > appear to offer a solution. > > I have two questions: > > 1) How is the information normally provided to a transponder by an > altitude > encoder for automatic altitude information transmission by the transponder > provided for in your products? > > 2) Are you aware of any regulatory reason (TSO or inspection requirements) > that would make your products not be acceptable for use in the United > States? > > Thanks for your help, > > 'OC' Baker Says: "The best investment we can make is the time and effort > to > gather and understand knowledge." > ________________________________________________________________________________
Date: Mar 23, 2012
From: "Jesse Kluijfhout, PE1RUI" <jessevli(at)zeelandnet.nl>
Subject: Re: Fw: Portable Transponder
I would suggest to use an external antenna with a good groundplane. It doubt the VSWR is very good the way when it is directly connected (however Trig products will give an error when the VSWR is very high). Another point to think of is the high peak power that a transponder is transmitting (about 125 or 250 Watt depending on class) The pulse duration is only short, lowering the average power. My transponder test equipement suggest to take a distance of at least to meter to reduce field strength your exposed to during transponder field testing. When the antenna is directly on the unit you will be likely close to the antenna. Some scientist say that exposure to high level RF fields is not dangerous, while other doubt this, I think it is better to take some distance from the antenna to reduce the field strength at your seating position. Jesse ________________________________________________________________________________
Subject: ELT Antenna
Date: Mar 23, 2012
3/23/2012 Hello Noel Loveys, Thank you for your inputs on this subject, but in the interest of stamping out hearsay, gossip, and rumors regarding experimental amateur built aircraft I'd like to point out that some of your comments are just not applicable in the USA. The following statements that you wrote are not correct in the USA: 1) "In that case if even on an OBAM aircraft the ELT and transponder must be installed or signed off by a certified AME (Canada) or A&P (U.S.)" 2) "One of the things I do not like about the new ELT is that aircraft cannot borrow another ELT while one is out having scheduled service done." 3) "...so they wouldn't have to fly without one... Which is legal for up to 90 days." Note that the regulatory requirements for having an ELT in a US registered civil aircraft operating in the US, and the circumstances permitted for flying without an ELT installed, are contained in 14 CFR 91.207. That section is too long and complicated to be copied, or even extracted in this posting. It may be accessed here: http://ecfr.gpoaccess.gov/cgi/t/text/text-idx?c=ecfr&sid=e13e8f64d66f124a79dbd562cbe93f0b&rgn=div8&view=text&node=14:2.0.1.3.10.3.7.4&idno=14 4) "In fact even a licensed AME is not allowed to change the batteries on an ELT it has to be done by an approved Avionics tech or an approved avionics shop." 5) "Amateur built aircraft are another quintal of fish... They don't even have to carry an ELT." They do in the USA in accordance with 14 CFR 91.207. Thanks for your help in posting accuracy. 'OC' Baker Says: "The best investment we can make is the time and effort to gather and understand knowledge." ============================================================= From: "Noel Loveys" <noelloveys(at)yahoo.ca> Subject: RE: AeroElectric-List: ELT Antenna In that case if even on an OBAM aircraft the ELT and transponder must be installed or signed off by a certified AME (Canada) or A&P (U.S.) Noel From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: March 21, 2012 8:26 PM Subject: RE: AeroElectric-List: ELT Antenna The minimum for use of ELTs is to demonstrate that the complete system meets the TSO. Good luck with doing that with a roll your own antenna of unknown impedance and SWR. ELTs and transponders are two items on OBAM aircraft that must comply with the TSO. Noel wrote: It sure would be... but for amateur aircraft you might be able to use your own antenna. Noel From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ed Holyoke Sent: March 20, 2012 10:18 PM Subject: Re: AeroElectric-List: ELT Antenna Have to look at your ELT installation instructions. The ELT is TSOed and might require that you use their antenna. ========================================================= From: "Noel Loveys" <noelloveys(at)yahoo.ca> Subject: RE: AeroElectric-List: ELT Antenna In this country any appliance on a certified aircraft with certain exceptions has to be installed by or checked by a certified AME ( aircraft maintenance engineer ) and the installation has to be documented in the airframe log book and noted if there is a separate log book for the appliance. One of the things I do not like about the new ELT is that aircraft cannot borrow another ELT while one is out having scheduled service done. In the past the AMO I worked for had a "loaner" ELT that we would put in aircraft so they wouldn't have to fly without one... Which is legal for up to 90 days. In fact even a licensed AME is not allowed to change the batteries on an ELT it has to be done by an approved Avionics tech or an approved avionics shop. Amateur built aircraft are another quintal of fish... They don't even have to carry an ELT. Mind I don't know anyone who is stupid enough to fly this land without one. Noel ________________________________________________________________________________
Subject: Re: ELT Antenna
Date: Mar 23, 2012
3/23/2012 Hello Noel, Thank you for your most courteous reply. You wrote: "New 406 mHz. ELTs are identified to specific aircraft in specific configuration." This is a very important point that you make. Each of those ELT's is also identified to a specific Owner/Operator of that specific aircraft and to a specific Primary and Alternate 24-Hour Emergency Contact associated with that specific ELT and aircraft along with communication information for all of those individuals. See here: http://www.nmea.org/Assets/elt%20406%20registration%20and%20renewal.pdf The purpose of that contact information is to permit rapid communication with one of those individuals should an emergency signal be received by a satellite to confirm that the signal is not a false alarm. Also note that it is possible on that form to submit a Change of ELT Information or Ownership and to do it fairly quickly online at: www.beaconregistration.noaa.gov This would permit a fairly flexible and timely means of swapping a 406 Mhz ELT from one aircraft to another if that became a need and one complied with all provisions of the registration requirements. 'OC' Baker Says: "The best investment we can make is the time and effort to gather and understand knowledge." =================================================== From: "Noel Loveys" <noelloveys(at)yahoo.ca> Sent: Friday, March 23, 2012 2:35 PM Subject: RE: ELT Antenna > My apologies sometimes I forget that most people on the lists are not > Canadian and there are several differences in our aviation procedures. > > In Canada an aircraft flown commercially must have an ELT on board. > However > I'm not sure it has to be turned on. An ELT may be removed for servicing > for up to 90 days. > > New 406 mHz. ELTs are identified to specific aircraft in specific > configuration. One of the new ELT cannot be taken out of one aircraft and > put in another. The identifier code on the ELT is "Married "to a specific > airplane. My understanding is if a large plane is converted from > passenger > to cargo it must be refitted with a new ELT as there is no vehicle to do > this. > > I do like to keep up with what is going on south of the 49th so I will > have > a look through your link and at the same time I'll have another look > through > CARs, Canada's equivalent to FARs. > > Thank you. > > Noel ________________________________________________________________________________
Date: May 09, 2012
Subject: Garmin GMA 240 Fail-Safe Question
I posted this on the AeroElectric List but the silence was deafening (except for the continuous off-topic political arguing). Can someone with actual hands-on experience with the Garmin GMA 240 Audio Panel answer this question, please? Is the volume of the "Failsafe Warning Audio" (P2402 pin 29) controllable or is it fixed? The installation manual implies it's useful for an audio input that will be audible in the pilot headset even if power is removed. It seems like an obvious choice for my Dynon Skyview EFIS warning audio but not if the audio level is not acceptable and cannot be set. In that case, one of the ALERT, AUX, or even NAV audio inputs would work better -- except in the case of power failure. Or maybe it's wired in parallel with one of the other inputs to provide an adjustable level under normal conditions and some arbitrary level after a power failure. Has anyone used this feature? Thanks, Joe Independence, OR http://www.mail2600.com/cgi-bin/webcam.cgi ________________________________________________________________________________
Date: May 12, 2012
Subject: KI 209A and Century I Problems
I have a Grumman in my shop with a Century 1 autopilot that derives its left/right input from a KI204 or a KI209A via a 4P3T switch. The KI209A can be switched to act as a GPS CDI from a KLN94 or as a VOR CDI. The owner says that when the autopilot is connected to Nav 1 (KX170/KI204) it captures the radial just fine with a minimum number of overshoots. When it's connected to Nav 2 (KX170 or GPS/KI208A), it continually S-turns across the radial (or course line supplied by the GPS). The owner had the 209A/KLN 94 installed about 2 years ago and he says it never worked right from the time was installed (I'll not go into why he didn't just take it back to them ...). Both VOR systems indicate the appropriate course deflection when checked with a flightline tester. When the 209A is set for GPS mode, it displays the appropriate deflection during GPS self test (1/2 right). I checked the wiring and switch - there is continuity between the autopilot output of each CDI to the autopilot Left/Right input when switched in and are open when switched out. Each of the wires are appropriately open to ground, and there is no continuity between them. Both CDIs put out 150mV at full scale, 75 mV at half scale, etc. The 209A also puts out the right deflection voltage when switched to GPS mode. The only difference I noticed: The Left/Right reference voltage out of the 209A is about 4.15 V (appropriate per the 209A maint manual), but the reference out of the 204 is around 350mV. I could find no mention of the reference voltage in the 204 maint manual. The 209A manual says that the output is designed for a 1Kohm load. The Century install manual says the input to the autopilot presents no load. SO ... do I have a problem with one of the indicators? Do I need to load the output of the 209A in some way? Or is there some other problem? Thanks, Chuck ________________________________________________________________________________
Subject: Re: KI 209A and Century I Problems
Date: May 13, 2012
you better check your Century a/p behavior instead of wasting your time on the NAV parts! Gabe ----- Original Message ----- From: "Chuck Birdsall" <cbirdsall6(at)cox.net> Sent: Sunday, May 13, 2012 1:25 AM Subject: Avionics-List: KI 209A and Century I Problems > > I have a Grumman in my shop with a Century 1 autopilot that derives its > left/right input from a KI204 or a KI209A via a 4P3T switch. The KI209A > can be switched to act as a GPS CDI from a KLN94 or as a VOR CDI. > > The owner says that when the autopilot is connected to Nav 1 (KX170/KI204) > it captures the radial just fine with a minimum number of overshoots. > When it's connected to Nav 2 (KX170 or GPS/KI208A), it continually S-turns > across the radial (or course line supplied by the GPS). The owner had the > 209A/KLN 94 installed about 2 years ago and he says it never worked right > from the time was installed (I'll not go into why he didn't just take it > back to them ...). > > Both VOR systems indicate the appropriate course deflection when checked > with a flightline tester. When the 209A is set for GPS mode, it displays > the appropriate deflection during GPS self test (1/2 right). > > I checked the wiring and switch - there is continuity between the > autopilot output of each CDI to the autopilot Left/Right input when > switched in and are open when switched out. Each of the wires are > appropriately open to ground, and there is no continuity between them. > > Both CDIs put out 150mV at full scale, 75 mV at half scale, etc. The 209A > also puts out the right deflection voltage when switched to GPS mode. > > The only difference I noticed: The Left/Right reference voltage out of > the 209A is about 4.15 V (appropriate per the 209A maint manual), but the > reference out of the 204 is around 350mV. I could find no mention of the > reference voltage in the 204 maint manual. > > The 209A manual says that the output is designed for a 1Kohm load. The > Century install manual says the input to the autopilot presents no load. > > SO ... do I have a problem with one of the indicators? Do I need to load > the output of the 209A in some way? Or is there some other problem? > > > Thanks, > > Chuck > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > ________________________________________________________________________________
Date: Jun 08, 2012
Subject: Bi-ennial transponder/encoder/static certifications
In reading 91.411 and 91.413, it says the manufacturer of the airplane can perform the tests. Since I built my 6A, I'm thinking that I cando the tests myself and make the logbook entry. Testing the transponder codes might be the difficult part - but I have already built the test equipment and tested the Pitot-static system and verified the altitude goung to the transponder is correct. Thoughts please, Ralph ________________________________________________________________________________
Date: Jun 08, 2012
Subject: Re: Bi-ennial transponder/encoder/static certifications
A common misconception. Yes you built your aircraft. That does not make you a "manufacturer" in the terms of these regulations. You need the transponder certified by someone with a repair station license. There is no certification of the pitot system, only the static system. The only reason the pitot is connected to the test is to protect your airspeed indicator from an excessive pressure difference with the static port. You can leak test your static system if you ever need to open it between the required certifications, and that is legal, but the certification must be done by an appropriately rated repair station. Kelly McMullen A&P/IA, EAA Tech Counselor On 6/8/2012 6:46 AM, Ralph E. Capen wrote: > > In reading 91.411 and 91.413, it says the manufacturer of the airplane can perform the tests. > > Since I built my 6A, I'm thinking that I cando the tests myself and make the logbook entry. > > Testing the transponder codes might be the difficult part - but I have already built the test equipment and tested the Pitot-static system and verified the altitude goung to the transponder is correct. > > Thoughts please, > Ralph > > ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Jun 08, 2012
Thanks - I figured there would be some weasel-wording in there. Since I have already done most of the tests, I have a high confidence level in taking it to a 'certified' shop. Good scoop! -----Original Message----- >From: Kelly McMullen <kellym(at)aviating.com> >Sent: Jun 8, 2012 10:22 AM >To: avionics-list(at)matronics.com >Subject: Re: Avionics-List: Bi-ennial transponder/encoder/static certifications > > >A common misconception. Yes you built your aircraft. That does not make >you a "manufacturer" in the terms of these regulations. >You need the transponder certified by someone with a repair station >license. There is no certification of the pitot system, only the static >system. The only reason the pitot is connected to the test is to protect >your airspeed indicator from an excessive pressure difference with the >static port. >You can leak test your static system if you ever need to open it between >the required certifications, and that is legal, but the certification >must be done by an appropriately rated repair station. >Kelly McMullen >A&P/IA, EAA Tech Counselor > >On 6/8/2012 6:46 AM, Ralph E. Capen wrote: >> >> In reading 91.411 and 91.413, it says the manufacturer of the airplane can perform the tests. >> >> Since I built my 6A, I'm thinking that I cando the tests myself and make the logbook entry. >> >> Testing the transponder codes might be the difficult part - but I have already built the test equipment and tested the Pitot-static system and verified the altitude goung to the transponder is correct. >> >> Thoughts please, >> Ralph >> >> >> >> >> >> > > >----- >No virus found in this message. >Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: Jun 09, 2012
6/9/2012 Hello Ralph Capen, Kelly McMullen has given you some good words on this subject, but I would like to clarify one point. Kelly wrote: "You can leak test your static system if you ever need to open it between the required certifications, and that is legal, ......" This is true only if you meet one of the qualification requirements listed in paragraph 91.411 (b). See a copy of that paragraph below: "91.411 Altimeter system and altitude reporting equipment tests and inspections. (a) No person may operate an airplane, or helicopter, in controlled airspace under IFR unless- (1) Within the preceding 24 calendar months, each static pressure system, each altimeter instrument, and each automatic pressure altitude reporting system has been tested and inspected and found to comply with appendices E and F of part 43 of this chapter; (2) Except for the use of system drain and alternate static pressure valves, following any opening and closing of the static pressure system, that system has been tested and inspected and found to comply with paragraph (a), appendix E, of part 43 of this chapter; and (3) Following installation or maintenance on the automatic pressure altitude reporting system of the ATC transponder where data correspondence error could be introduced, the integrated system has been tested, inspected, and found to comply with paragraph (c), appendix E, of part 43 of this chapter. (b) The tests required by paragraph (a) of this section must be conducted by- (1) The manufacturer of the airplane, or helicopter, on which the tests and inspections are to be performed; (2) A certificated repair station properly equipped to perform those functions and holding- (i) An instrument rating, Class I; (ii) A limited instrument rating appropriate to the make and model of appliance to be tested; (iii) A limited rating appropriate to the test to be performed; (iv) An airframe rating appropriate to the airplane, or helicopter, to be tested; or (3) A certificated mechanic with an airframe rating (static pressure system tests and inspections only)." Note that holding only a Repairman's Certificate for a specific experimental amateur built aircraft is not listed as one of the persons qualified to perform static pressure system tests and inspections (in order to detect a leak) on the aircraft that he is rated for. Please let me know if you have any questions on this subject. 'OC' Baker Says: "The best investment we can make is the time and effort to gather and understand knowledge." PS: It is possible that some FAA employee has given the OK for some Repairman to perform a static pressure system leak test on his experimental amateur built aircraft, but that does not constitute a universal change the regulation. Besides what equipment and test performance criteria would the Repairman use to determine whether or not he had an acceptable leak? Hint: The answer to this question can be found in the Matronics aeroelectric list archives. (Search for "static check" dated Sep 11) ========================================================== >From: Kelly McMullen <kellym(at)aviating.com> >Sent: Jun 8, 2012 10:22 AM >To: avionics-list(at)matronics.com >Subject: Re: Avionics-List: Bi-ennial transponder/encoder/static >certifications > > >A common misconception. Yes you built your aircraft. That does not make >you a "manufacturer" in the terms of these regulations. >You need the transponder certified by someone with a repair station >license. There is no certification of the pitot system, only the static >system. The only reason the pitot is connected to the test is to protect >your airspeed indicator from an excessive pressure difference with the >static port. >You can leak test your static system if you ever need to open it between >the required certifications, and that is legal, but the certification >must be done by an appropriately rated repair station. >Kelly McMullen >A&P/IA, EAA Tech Counselor =========================================== > >On 6/8/2012 6:46 AM, Ralph E. Capen wrote: >> >> >> In reading 91.411 and 91.413, it says the manufacturer of the airplane >> can perform the tests. >> >> Since I built my 6A, I'm thinking that I cando the tests myself and make >> the logbook entry. >> >> Testing the transponder codes might be the difficult part - but I have >> already built the test equipment and tested the Pitot-static system and verified the altitude goung to the transponder is correct. >> >> Thoughts please, >> Ralph ________________________________________________________________________________
Subject: Withdrawal from the group
Date: Jun 13, 2012
About two weeks ago I had a major fire here. Caused by, so they say, a faulty extension cord. For the time of being I am going to withdraw from all my aviation lists within the next few days. I hope you all continue to post and fly safely. Clear skies Noel -------- Noel Loveys Kitfox III-A Aerocet 1100 Floats Read this topic online here: http://forums.matronics.com/viewtopic.php?p=375537#375537 ________________________________________________________________________________
Subject: Blue Mountain Avionics User's Group
Date: Jul 26, 2012
Hey Guys, I know a few of you are still flying behind Blue Mountain Avionics EFIS systems. I too have one of the orphaned systems in my aircraft. Up until recently, Greg has been keeping the User Discussion group going on his website. We'll it finally went away and now there's no dedicated site for us to discuss issues and/or solutions with other users of the equipment. I decided to create a Yahoo! Group dedicated to the BMA equipment. If you would like to join, it can be found at... http://groups.yahoo.com/group/BMA_Users/ Again, this has no connection to Greg or the ex- BMA company, just a site for Users to talk to Users. = Michael Crowder Sonex N293SX Flying with an EFIS/Lite Plus and it's working really nicely. -------- Michael Crowder Jabiru 3300A w/ Hyd Lifters AeroCarb w/ #3 needle Sonex N293SX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=379261#379261 ________________________________________________________________________________
Subject: BMA Display
Date: Jul 30, 2012
I have installed dual screen BMA EFIS/One, Gen 3 displays (LC640.480.33-AC) in my aircraft. In the hangar, the displays are great, but when I take it out, the ambient light results in not being able to read the screens. Any suggestions would be appreciated. Giff Marr ________________________________________________________________________________
Date: Jul 30, 2012
Subject: Re: BMA Display
On 07/30/2012 05:24 PM, Giffen Marr wrote: > I have installed dual screen BMA EFIS/One, Gen 3 displays > (LC640.480.33-AC) in my aircraft. In the hangar, the displays are > great, but when I take it out, the ambient light results in not being > able to read the screens. > Any suggestions would be appreciated. > Giff Marr > *Easy 1st check: you're not wearing polarized sunglasses, are you?* ________________________________________________________________________________
Date: Aug 16, 2012
Subject: Mooney Alternator woes
My hangar neighbor is trying to figure out why his alternator occasionally drops off line - requiring a weird reset sequence. He has to shut off the battery and field, then go to a low power setting and bring it back up again. Something about resetting an overvoltage protection device. It is an M20S with Cont 550 and gear driven alternator. The first regulator lasted only a couple of years before giving up the ghost and the replacement was a special from Mooney. My first line of thinking is to locate the regulator and test it. Nobody knows where it is hiding. (I'm in DC - the plane is in DE...I'll be home next weekend to help more.) Meanwhile, does anyone have an electronic copy of the Light Plane Maintenance article on troubleshooting alternators...and the Mooney M20S maintenance manual? If we can find it, I'm hoping that we can determine if the regulator is the culprit. Thanks in advance, Ralph RV6A N822AR in N06 - waiting for my engine/prop to come back from overhaul after being hit by a flying hangar door! ________________________________________________________________________________
Subject: handheld problems
Date: Aug 17, 2012
Let me start by saying I'm the village idiot when it comes to radios so hopefully someone can point out the obvious problem to me. I'm trying to use my handheld (Vertex VXA 150) along with a set of Peltor 7004 headsets to communicate from my Kitfox. On the ground with the engine off everyone around the airport hears me fine. Once the engine is started everyone complains about background noise or static when I transmit. A FOB unicom can just barely hear me from 5 miles out. I receive fine in flight. The radio is not wired into the aircraft power, I'm using the radio's battery. It is the same for both the rubber ducky antenna and the external aircraft mounted antenna. The headset works fine in other aircraft. I'm wondering if the headset is picking up too much background noise ? thanks, EG Read this topic online here: http://forums.matronics.com/viewtopic.php?p=381090#381090 ________________________________________________________________________________
Date: Aug 17, 2012
Subject: Re: handheld problems
egp8111 wrote: I'm wondering if the headset is picking up too much background noise ? Most likely - The microphone should be touching your lips, and there are mic shrouds available with a hole pointing to the speaker, and a covered back to reject other sound sources. (Wind, engine noise.) ________________________________________________________________________________
Date: Aug 17, 2012
Eg On my older icom if I press the transmit switch on the radio it also transmits all the noise from the radio mic as well as from my headset mic. That is same symptoms as you seem to have. The only way to use it in flight without all the noise is to plug in an optional remote transmit switch which then only transmits from my headset mic. Think the icom switch was around $20. from Spruce. Ken On 17/08/2012 1:47 PM, egp8111 wrote: > --> Avionics-List message posted by: "egp8111" > > Let me start by saying I'm the village idiot when it comes to radios > so hopefully someone can point out the obvious problem to me. I'm > trying to use my handheld (Vertex VXA 150) along with a set of Peltor > 7004 headsets to communicate from my Kitfox. On the ground with the > engine off everyone around the airport hears me fine. Once the > engine is started everyone complains about background noise or static > when I transmit. A FOB unicom can just barely hear me from 5 miles > out. I receive fine in flight. The radio is not wired into the > aircraft power, I'm using the radio's battery. It is the same for > both the rubber ducky antenna and the external aircraft mounted > antenna. The headset works fine in other aircraft. I'm wondering if > the headset is picking up too much background noise ? > > thanks, EG > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=381090#381090 > > ________________________________________________________________________________
Date: Oct 18, 2012
Subject: Garmin 400W/500W series flight plan migrator kit
Does anyone use this to enter their flight plans? Obviously it is overpriced! - Is there any added value in entering flight plans? If you have one - do you want to get rid of it? Back to the overpriced thing..... ________________________________________________________________________________
Subject: Re: Garmin 400W/500W series flight plan migrator kit
Date: Oct 18, 2012
I didn't know about it, but why bother? In the time it takes to sit at the pc, punch it in and then dump it at both ends you could have entered it in manually. Tim Sent from my iPad On Oct 18, 2012, at 8:50 AM, "Ralph E. Capen" wrote: > > Does anyone use this to enter their flight plans? > > Obviously it is overpriced! - Is there any added value in entering flight plans? > > If you have one - do you want to get rid of it? Back to the overpriced thing..... > > > > > > ________________________________________________________________________________
Subject: High Quality Jade Necklaces Onsale
Date: Oct 25, 2012
Jade Necklace (http://www.jadejewelrymall.com/jadeite-necklace.html) has launched its ecstatic collection of Diamond Bangle Bracelets, Ladies Diamond Bracelets, and Diamond Tennis Bracelets at factory direct prices. It has offered the finest selection of ladies jewelry including ladies diamond bracelets with most popular designs such as Diamond Bangle Bracelets and Diamond Tennis Bracelets Jade Bracelet (http://www.jadejewelrymall.com/jadeite-bracelet.html) as well as other delicate diamond ladies bracelets with high quality natural white diamonds and fancy color diamonds. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=386023#386023 ________________________________________________________________________________
Date: Nov 01, 2012
Subject: PLEASE READ - Matronics Email List Fund Raiser During November!
Dear Listers, Each November I hold a PBS-like fund raiser to support the continued operation and upgrade of the Email List and Fourm Services at Matronics. It's through solely through the Contributions of List members that these Matronics Lists are possible. You have probably noticed that there are no banner ads or pop-up windows on any of the Matronics Lists or related web sites such as the Forums site http://forums.matronics.com , Wiki site http://wiki.matronics.com , or other related pages such as the List Search Engine http://www.matronics.com/search , List Browse http://www.matronics.com/listbrowse , etc. This is because I believe in a List experience that is completely about the sport we all enjoy - namely Airplanes and not about annoying advertisements. During the month of November I will be sending out List messages every couple of days reminding everyone that the Fund Raiser is underway. I ask for your patience and understanding during the Fund Raiser and throughout these regular messages. The Fund Raiser is only financial support mechanism I have to pay all of the bills associated with running these lists. Your personal Contribution counts! Once again, this year I've got a terrific line up of free gifts to go along with the various Contribution levels. Most all of these gifts have been provided by some of the vary members and vendors that you'll find on Matronics Lists and have been either donated or provided at substantially discounted rates. This year, these generous people include: Bob Nuckolls of the AeroElectric Connection http://www.aeroelectric.com Andy Gold of the Builder's Bookstore http://www.buildersbooks.com Jon Croke of HomebuiltHELP http://www.homebuilthelp.com These are very generous guys and I encourage you to visit their respective web sites. Each one offers a unique and very useful aviation-related product line. I would like publicly to thank Bob, Andy, and Jon for their generous support of the Lists again this year!! Please make your List Contribution using any one of three secure methods including using a credit card, PayPal, or by personal check. All three methods afford you the opportunity to select one of this year's free gifts with a qualifying Contribution amount!! To make your Contribution, please visit the secure site: http://www.matronics.com/contribution I would like to thank everyone in advance for their generous financial AND moral support over the years! Thank you for your support! Matt Dralle Matronics Email List Administrator RV-4/RV-6/RV-8 Builder/Rebuilder/Pilot ________________________________________________________________________________
Date: Nov 01, 2012
Subject: Auto Response
My father, William Dean (Bill) has passed away. We are monitoring this email and will reply to you if appropriate. If you were a friend of his or family that keeps up with him on email, and we have not reached out to you and given you the news, please forgive us. It was sudden and we are dealing with a lot at this time. The Dean Family ________________________________________________________________________________
Date: Nov 03, 2012
Subject: Please Make A Contribution To Support Your Lists
Dear Listers, There is no advertising income to support the Matronics Email Lists and Forums. The operation is supported 100% by your personal Contributions during the November Fund Raiser. Please make your Contribution today to support the continued operation and upgrade of these services. You can pick up a really nice gift for making your Contribution too! You may use a Credit Card or Paypal at the Matronics Contribution Site here: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you in advance for your generous support! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 05, 2012
Subject: Coming Soon - The List of Contributors - Please Make A
Contribution Today! Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Please take a moment and assure that your name is on that List of Contributors (LOC)! As a number of members have pointed out over the years, the List seems at least as valuable a building / entertainment tool as your typical magazine subscription! Make sure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 06, 2012
Subject: A Message From AeroElectric's Bob Nuckolls...
Dear Listers, The well known Bob Nuckolls of the AeroElectric posted a great message Monday on the AeroElectric-List regarding the Matronics Lists and the importance of supporting the operation during the Fund Raiser. Please take a minute to read Bob's commentary below, reposted to the other Matronics Lists with his permission... Date: Mon, 05 Nov 2012 08:58:41 -0600 From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Subject: AeroElectric-List: Re: Please Make A Contribution Today! At 02:14 AM 11/5/2012, Matt Dralle wrote: > > Each year at the end of the List Fund Raiser, I post a message > acknowledging everyone that so generously made a Contribution to > support the Lists. Its my way of publicly thanking everyone that > took a minute to show their appreciation for the Lists. > I will add my voice to this suggestion. It's easy to enjoy the benefits of what's available to us off-the-shelves at the corner mega-marts. It's seldom that we give pause to learn and understand the processes and tools that made it possible to reach out and select from dozens of options. This, and all civil societies, runs on talent, energy and mobility. Mobility exploited by thousands of hands, machines and transportation that figure into the 'infrastructure' that puts the boxes of Wheaties and Pop Tarts on the shelves. See "I pencil" http://tinyurl.com/36xkhq Any break in that chain of time, talent and resources at least interrupts if not totally halts flow of that benefit. Matt's room full of byte-thrashers is like the natural gas pumping station a few miles from my house. If those pumps stop, who ever is expecting the furnace to come on at the other end of the pipe is at risk for reduced service and/or higher costs for that service. Matt's yearly endeavor to keep his pumps running is a trivial burden on the members of the Lists but of incalculable value to those who participate on them. No donation is too small. We go to a fly-in a willingly chuck a few bucks into the coffee can at the drinks and donuts table, let's chuck a few bucks into Matt's coffee can too. 50,000 pounds of value doesn't get to the shelves on time if one 18-wheeler runs out of gas. The T-bytes of data flow we all enjoy don't get from your keyboard to the screens of others unless Matt pays the light bill and strokes the machines to keep them happy. No, $5 won't get you a free copy of the 'Connection or a fuel sampler but it will go toward the assurance that logging onto your favorite List will open doors that you would be sorely missed should you find that hitting the return key doesn't produce the expected response. $5 from every List customer on Matt's system will go a very long way to keeping the byte-pumps running. $More$ will go a long way to upgrading the size and quality of the machines as the old ones get long in the tooth. No matter what size of donation you choose . . . please do it now . . . Bob . . . Please make your Contribution today to support the continued operation and upgrade of these services. You can pick up a really nice gift for making your Contribution too! You may use a Credit Card or Paypal at the Matronics Contribution Site here: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 08, 2012
Subject: Make A List Contribution - It's Your Personal Squelch Button...
There is an automatic "squelch button" of sorts for the Fund Raiser messages. Here's how it works... As soon as a List member makes a Contribution through the Matronics Fund Raiser web site, their email address is automatically added to this year's Contributor List and they instantly cease to receive further Fund Raiser messages for the rest of the month! Its just that simple! :-) I really do appreciate each and every one of your individual Contributions to support the Lists. It is your support that enables me to upgrade the hardware and software that are required to run a List Site such as this one. It also goes to pay for the commercial-grade Internet connection and to pay the huge electric bill to keep the computer gear running and the air conditioner powered on. I run all of the Matronics Email List and Forums sites here locally which allows me to control and monitor every aspect of the system for the utmost in reliably and performance. Your personal Contribution matters because, when combined with other Listers such as yourself, it pays the bills to keep this site up and running. I accept exactly ZERO advertising dollars for the Matronics Lists sites. I can't stand the pop-up ads and all other commercials that are so prevalent on the Internet these days and I particularly don't want to have it on my Email List sites. If you appreciate the ad-free, grass-roots, down-home feel of the Matronics Email Lists, please make a Contribution to keep it that way!! http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you! Matt Dralle Matronics Email List Administrator [Note that there are certain circumstances where you might still see a Contribution related message. For example, if someone replies to one of the messages, when using the List Browse feature, or when accessing List message via the Forum. The system keys on the given email address and since most of these are anonymous public access methods, there is no simple way to filter them.] ________________________________________________________________________________
Date: Nov 10, 2012
Subject: Please Support The Lists...
Dear Listers, Just a reminder that November is the Matronics Email List Fund Raiser month. There are some very nice incentive gifts to choose from as well! Please make your Contribution today at: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 12, 2012
Subject: What's Your Contribution Used For?
Dear Listers, You might have wondered at some pointd, "What's my Contribution used for?" Here are just a few examples of what your direct List support enables... It provides for the expensive, commercial-grade Internet connection used on the List. It pays for the regular system hardware and software upgrades enabling the highest performance possible for List services such as the Archive Search Engine, List Browser, and the Web Forums. It pays for the over 22 years of on-line archive data always available for instant search and access. And, it offsets the many hours spent writing, developing, and maintaining the custom applications that power these List Service such as the List Browse, Search Engine, Forums, and Wiki. But most importantly, your List Contribution enables a forum where you and your peers can communicate freely in an environment that is free from moderation, censorship, advertising, commercialism, SPAM, and computer viruses. It is YOUR CONTRIBUTION that directly enables all these aspects of Matronics List services. Please support it today with your List Contribution. Its one of the best investments you can make in your Sport! List Contribution Web Site: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you for your support! Matt Dralle Email List Administrator ________________________________________________________________________________
Date: Nov 14, 2012
Subject: Make Sure You're Listed! List of Contributors Published
in December! Dear Listers, The List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matronics / Matt Dralle 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 16, 2012
Subject: Who is Matt Dralle & What Are The Lists?
Dear Listers, Who is Matt Dralle and what exactly are these Lists anyway? I've been working in the Information Technology industry for over 28 years, primarily in computer networking design and implementation and more recently as an embedded software engineer. I have also done a fair amount of work in web design and development. I started the Matronics Email Lists way back in 1990 shortly after I started building my RV-4 with about 30 fellow RV builders from around the world. Since that time, I have added many other types of aircraft related Lists to the line up and numerous other List related services such as the Forums, Wiki, Archives and Search Engine just to name a few. For flexibility and reliability, I have chosen to run all of my own servers locally. Other List-related systems include a 1 Gigabit, fully switched network infrastructure, a commercial-grade Netscreen firewall, a Barracuda spam filter, a local T1 Internet router, and a bonded dual T1 commercial-grade business Internet connection with full static addressing. The computer servers include a dual quad-core Linux server for List web services with 24GB of memory, a quad -core Linux system dedicated to the email processing List functions, and another standalone Linux system serving as a remote storage disk farm for the archives, databases, and for an on-line hard drive-based backup system with multi-terra byts of online storage. This entire system is protected by three large, commercial-grade uninterrupted power supply systems (UPS) that assure the Lists are available even during a local power outage! Speaking of power, imagine how much electricity it takes to run all of these systems. On the average, the elctric bill is in the neighborhood of $7000-$8000/yr and the newly upgraded dual-T1 Internet connection runs roughly $6000/yr. A while back, I upgraded all of the computer racking infrastructure including new power feeds and dedicated air conditioning for the room that serves as the Computer Center for the Matronics Email Lists and followed that upgrade up with a second rack upgrade to house the MONSTER web system that didn't quite fit into the first rack! Here's a composite photo of the List Computer Center prior to the addition of the second rack: http://www.matronics.com/MattDralle-ListComputerCenter.jpg As you can see, I take running these Lists very seriously and I am dedicated to providing an always-on, 24x7x365 experience for each and every Lister. But building and running this system isn't cheap. As I've mentioned many times before, I don't use commercial advertisments to support any of these systems. It is supported 100% through List member Contributions! That means you... and you... and YOU! To that end, I hold a List Fund Raiser each November and ask that members make a Contribution to support the continued operation and upgrade of this ever-expanding system. Its solely YOUR Contributions that keeps it running! Please make a Contribution today to support these Lists! http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matronics / Matt Dralle 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 19, 2012
Subject: Reminder
Dear Listers, A quick reminder that November is the annual Matronics List Fund Raiser. The Lists are 100% member supported and all of the operational costs are covered solely through your Contributions during this time of the year. *Your* personal Contribution makes a difference and keeps all of the Matronics Email Lists and Forums completely ad-free. Please make your Contribution today to keep these services up and running for another great year! Use a credit card or your PayPal account here: http://www.matronics.com/contribution Or, by sending a personal check to: Matronics / Matt Dralle 581 Jeannie Way Livermore CA 94550 Thank you in advance! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 21, 2012
Subject: Some Nice Comments...
Dear Listers, I've been getting some very nice comments from Listers along with their List Support Contributions. I've shared a number of them below. Please read them over and see what your fellow Listers think of the Lists and Forums. Please make a Contribution today to support the continued upgrade and operation of these services. There are lots of sweet gifts available this year, so please browse the nice selection and pickup something fun with your qualifying Contribution! You may use a credit card or your PayPal account here: http://www.matronics.com/contribution Or feel free to send a personal check to: Matronics / Matt Dralle 581 Jeannie Way Livermore CA 94550 Thank you in advance for your generous support! It is very much appreciated! Best regards, Matt Dralle Matronics Email List Administrator -------------------- What Listers Are Saying About The Lists -------------------- I have been flying my Pietenpol for a month now and am enjoying the fruits of ten hard years of work. I seriously doubt it would ever have been finished but for the help, encouragement and friendships I've received and made through the Pietenpol list. Douwe B Outstanding service to the flying community. George A Matt, I look forward to support each others projects, Glenn B Great list!!! Thanks for all your efforts! Roger C Thank you for keeping up the lists. Without it i would never have completed my aircraft. Stan S Keep up the good work my friend. I don't think I could ever finish my Pietenpol Air Camper without the help I get from this List. Tom S Thank you for keeping these list alive. Lee V The List is invaluable!! Svein J Thanks for continuing to provide the list service! Earl S You have a really GREAT service. Thankyou so much I've been on for nearly 30 years and I still check-in every morning. John B I rely fully on the lists which govern my every decision. The flexibility provides the security I seek. Fergus K My RV 7 Finally flies... 7 years of Matronics.com certainly helped. Martin H Great service here, thanks! I am just getting back to a project I dropped for a few years, great to see your site and all the folks again! James C Thanks for the great site. Robert U The Rotax list is good and the AeroElectric list outstanding! Jay H Thank you for a great resource! Jack T Thanks for your great record of outstanding service to the homebuilding community! Larry W This service is invaluable. Michael W You're doing a great job Matt. Robert D Thanks for all your work, its a great asset to all. John F Thank you for your time & effort Matt! Ted W Matt, been a follower since 2005 on the -10 list, now starting an -8. Keep up the great work! John M Still my favorite place to hang out. William W I'm not a Piet builder, but this is the most informative and congenial list I've ever run across. Please forgive my lurking-I learn a LOT here! Ken M Many thanks for keeping this alive, keep pushing! Adrian C Thanks! Please keep r going! Rich Z Many thanks for your hard work. Robert C Thanks for the Lists! I probably need to subscribe to a few more... John M Been a quick 14 years. Think I subscribed to the Kolb List in 1998, when I got my first computer. Thanks for keeping everything running smoothly for all these years. John H Great resource - thank you. David M I don't post very much, but get the postings, a lot of really practical info. John N Great job Matt, thanks for all you do. Roger M Thanks for ANOTHER great year, Matt! True grassroots experimental aviation has been pushed aside in many ways. But the List represents the evolution of this great tradition of home-building. One man, the plans, the tools, and the List - that's all you need to build the dream! Robert B This message board is a real help to my project and creating friendships. John S Many thanks for your continuing excellent work. Mike G Thank you for your work Matt. Your lists have helped me a great deal during the construction of my plane. Hal B Nice List Van E These lists are priceless for builders. Ronald C Thanks for keeping me in touch with the Pulsar community. Otto S Thanks for keeping up this great warbird sight!! Yak Ron Thanks for providing all the lists for so many years. H H Thanks for all that you do. Your dedication is much appreciated! Warren H Best service on the internet! Owen B I have learned so much from the "list". Nick C Great Service You Are Providing! Giffen M Thanks so much for maintaining these great resources. Dave S I no longer fly due to age and health problems, but I still enjoy the reading from other pilots. Dallas S This is a wonderful site. Robert B Useful service over the last year - thanks. Om T -------------------- What Listers Are Saying About The Lists -------------------- ________________________________________________________________________________
Date: Nov 23, 2012
Subject: "Black Friday" For List Fund Raiser...?
Dear Listers, The number of List subscriptions are up by a fair amount this year, but support during this year's Fund Raiser is substantially behind last year, and there's only about a week left until the end of the Fund Raiser. I have always preferred a non-commercial List experience as many, many members have also expressed that they do as well. However, if the yearly fund raiser cannot generate sufficient funds to keep the bills paid, other sources of income might be required including some sort of advertising. Please don't let that happen! Your personal Contribution of $20 or $30 goes a long ways to keeping this operation a float. Please make sure your name is on this year's List of Contributors! The List Contribution site is secure, quick, and easy: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you in advance for your support! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 25, 2012
Subject: Just A Few More Days To Make Your List Contribution...
There is less than a week left in this year's List Fund Raiser and only a few short days to grab one of the great Contribution Gifts available this year. Support is still significantly lagging behind last year at this point but hopefully it will pick up here towards the end. Please remember that it is solely the Contributions of List members that keeps the Lists up and running as there is no commercialism or advertising on the Matronics Lists and Forums. The List Contribution web site is secure, fast, and easy and you can use a credit card, Paypal, or a personal check: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I want to thank everyone that has already made a generous contribution to support the Lists! Thank you! Matt Dralle Matronics EMail List and Forum Administrator ________________________________________________________________________________
Date: Nov 26, 2012
Subject: Contributions Down By 23%...
Dear Listers, As of today, Contributions to the Matronics List Fund Raiser are lagging behind last year at this time by roughly 23%. I have a Fund Raiser each year simply to cover my operating costs for the Lists. I *do not* accept any advertising income to support the Lists and rely solely on the Contributions of members to keep the expenses paid. I run all of my own servers and they are housed here locally, and the Internet connection is a commercial-grade, dual T1 connection with public address space. I also maintain a full backup system that does nightly backups of all List-related data so that in the event of a server crash, all of the Lists and the many years of List archive data could be restored onto a new server in a matter of hours. All of this costs a fair amount of money, not to mention a significant amount of my personal time. I have a Fund Raiser each year to cover these costs and I ask that members that feel they receive a benefit from my investments make a modest Contribution each year to support the continued operation and upgrade of these services. If you enjoy the Lists, please make a Contribution today. I also offer some incentive gifts for larger Contribution levels. At the Contribution Web Site, you can use a credit card, Paypal, or personal check to show your support for the continuation of these services: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you for your support! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 27, 2012
Subject: Make Sure You're Listed! List of Contributors Coming in
December! Dear Listers, There's just a couple more days left in this year's List Fund Raiser and that means the List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 28, 2012
Subject: Just 3 Days Left - Please Make Your List Contribution Today!
There are only three days left until the end of this year's List Fund Raiser. Please take a minute to show your support as so many others have this year and make sure YOUR name is on the forthcoming List of Contributors! Its quick and easy using the secure web site with a credit card or PayPal: http://www.matronics.com/contribution or by sending your personal check to: Matronics Lists c/o Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you in advance for your support of these List services! Matt Dralle Matronics Email and Forum Administrator ________________________________________________________________________________
Date: Nov 29, 2012
Subject: Just Two Days Left! - Still Behind...
Dear Listers, There are just two more days left in this years List Fund Raiser. Over the last couple of weeks I have received some more really nice comments from members on what the Lists have meant to them. I have included a few more of them below. Please read over the comments and ponder on your own feelings about the Lists and the support and camaraderie you have found here. We are still behind last year in terms of the number of contributions. I really want to keep providing these services to the homebuilt community, but it take resources. Since there's no advertising budget or deep pockets to keep the operation a float, its solely your generosity during the Fund Raiser that keeps things going. Please make a Contribution today. If you've been putting off showing your support for the Lists, now is the time to do it! Make a contribution with a Credit Card or though PayPal at that Matronics Contribution web site: http://www.matronics.com/contribution Or, drop a check in the mail: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you in advance for your support! Matt Dralle Matronics Email List Administrator ==================== A Few List Member Comments ===================== I have been flying my Pietenpol for a month now and am enjoying the fruits of ten hard years of work. I seriously doubt it would ever have been finished but for the help, encouragement and friendships I've received and made through the Pietenpol list. Douwe B Hey-Long time subscriber, zero-time contributor. Just a note of thanks. This is first time I have the resources to contribute. Thanks for carrying a lightweight for years and a special thanks for your time and effort. Billy R My 601 hd is flying with the help with the listers. Noel G A very useful facility. Graeme B ..great site! Robert C Great Pietenpol site! Don Y Not active but always interested in keeping up. Enjoy when I can. Richard R Dave and Tim from Aircrafters just want to reiterate our thanks for hosting the lists. Tim F. I don't have a lot to give at this time of year, but I hope my contribution helps none the less. I really enjoy the message board. Mark C Thanks to your continued work on maintaining these lists. Ralph C The lists and the various contributors have been a great help while I was building and also now that I'm flying. Albert G Very helpful tools for the homebuilder. Vaughn T We appreciate your great help! Richard H Many of our customers have expressed to us that you provide them with an invaluable service - and we agree! Bill B I Fly a Quicksilver GT400 but love to read what the Kolb boys have to say and it was on your list that I found out about the Yamaha product Ring Free,, now called engine med, that shit works.. no carbon in my rings or any to speak of with the use of the Yamaha product with a premix 503 with over 300 hrs of use.. thanks to your Kolb bulletin board. Robert B You are providing a valuable service that helps a lot of people through information sharing. When I built my Pietenpol over 40 years ago we were largely on our own, working without a resource like this list. Graham H Thanks for the opportunity to link us all, keep the good work! Peter B ________________________________________________________________________________
Subject: ANR headset feedback
Date: Nov 29, 2012
Have a new RV-7 and upgraded to ANR headsets. (Running through a Garmin 240 and SL40 radio.) Trying to broadcast gets a side tone (which broadcasts) as soon as I hit the PTT. Hadn't noticed the problem until started taking passengers in the airplane. At first, it only seemed to be on the pax side, but realized it was on the pilot side as well (which might show up depending if I have something plugged to the pax jacks). Happens with different brands of headsets. New Sennheiser gets the feedback when I turn on the ANR. Lightspeed G3 gets the feedback whether the ANR is on or not. Regular headsets work fine for both the intercom and transmission. would like to use the new ANR headsets; any ideas where to look for a problem? Marty RV-7 50 hours. -------- Marty RV-7 (Flying) Southport, NC (KSUT) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=389487#389487 ________________________________________________________________________________
Date: Nov 30, 2012
Subject: [Please Read] - Last Official Day of List Fund Raiser!
Dear Listers, Its November 30th and that always means a couple of things. Its my birthday again; number 49 actually! But it also means that its that last official day of the Matronics Email List Fund Raiser! If you been thinking about picking up one of those really nice incentive gifts now is the time to jump on it!! If you've been meaning to make a Contribution this month but have been putting it off for some reason, NOW is the time! I will be posting the List of Contributors in a few days, so you'll probably want to be known as a person that supported the Lists! I want to thank everyone that has so generously made a Contribution this year in support of our Lists. It is your generosity that keeps this operation running and I don't ever forget it. The List Contribution Web Site is fast and easy. Please support our habit by making your Contribution right now: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you to all in advance! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Dec 03, 2012
Subject: Re: ANR headset feedback
Hi Marty, it seems some kind of resonance. Did you experience the same with open canopy ? Ricardo Urio 2012/11/29 Airmarty2 > > Have a new RV-7 and upgraded to ANR headsets. (Running through a Garmin > 240 and SL40 radio.) Trying to broadcast gets a side tone (which > broadcasts) as soon as I hit the PTT. Hadn't noticed the problem until > started taking passengers in the airplane. > > At first, it only seemed to be on the pax side, but realized it was on the > pilot side as well (which might show up depending if I have something > plugged to the pax jacks). Happens with different brands of headsets. New > Sennheiser gets the feedback when I turn on the ANR. Lightspeed G3 gets > the feedback whether the ANR is on or not. > > Regular headsets work fine for both the intercom and transmission. > > would like to use the new ANR headsets; any ideas where to look for a > problem? > > Marty > RV-7 > 50 hours. > > -------- > Marty > RV-7 (Flying) > Southport, NC (KSUT) > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=389487#389487 > > ________________________________________________________________________________
Date: Dec 03, 2012
Try reducing the mic level. You can find how to here http://www.rv7-a.com/manuals/SL40Comm_InstallationManual.pdf . Take a look at page 13. Ricardo Urio 2012/11/29 Airmarty2 > > Have a new RV-7 and upgraded to ANR headsets. (Running through a Garmin > 240 and SL40 radio.) Trying to broadcast gets a side tone (which > broadcasts) as soon as I hit the PTT. Hadn't noticed the problem until > started taking passengers in the airplane. > > At first, it only seemed to be on the pax side, but realized it was on the > pilot side as well (which might show up depending if I have something > plugged to the pax jacks). Happens with different brands of headsets. New > Sennheiser gets the feedback when I turn on the ANR. Lightspeed G3 gets > the feedback whether the ANR is on or not. > > Regular headsets work fine for both the intercom and transmission. > > would like to use the new ANR headsets; any ideas where to look for a > problem? > > Marty > RV-7 > 50 hours. > > -------- > Marty > RV-7 (Flying) > Southport, NC (KSUT) > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=389487#389487 > > ________________________________________________________________________________
Date: Dec 03, 2012
The problem occurs with engine off and canopy open. Haven't tried with engine running yet? -------- Marty RV-7 (Flying) Southport, NC (KSUT) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=389735#389735 ________________________________________________________________________________
Subject: Garmin 250XL
Date: Dec 09, 2012
I've just experienced the third screen failure (illuminates but no characters or digits) of this GPS/com in 10 years and 830 hours flight time. The last repair was $653 which had to be shipped through an avionics shop as Garmin no longer deals direct with OBAM users. I am disinclined to invest any more dollars in what is an unreliable design. Any other users have a similar experience? Larry Ford Glasair I RG N149LF Read this topic online here: http://forums.matronics.com/viewtopic.php?p=390114#390114 ________________________________________________________________________________
Date: Dec 10, 2012
Subject: 2012 List of Contributors
Dear Listers, The 2012 Matronics Email List and Forum Fund Raiser officially ended about a week ago and its time that I publish this year's List of Contributors. It is the people on this list that directly make the Email Lists and Forums possible! Their generous Contributions keep the servers and Internet connection up and running! You can still show your support this year and pick up a great gift at the same time. The Contribution Web Site is fast, easy, and secure: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I also want to thank Bob, Jon, and Andy for their generous support through the supply of great gifts this year!! These guys have some excellent products and I encourage you to visit their respective web sites: Bob Nucklolls - AeroElectric - http://www.aeroelectric.com Jon Croke - HomebuiltHELP - http://www.homebuilthelp.com Andy Gold - The Builder's Bookstore - http://www.buildersbooks.com And finally, I'm proud to present The 2012 Fund Raiser List of Contributors: http://www.matronics.com/loc/2012.html Thanks again to everyone that made a Contribution this year!! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Jan 01, 2013
Subject: Auto-response
Away on holiday from the 22 December 2012 till 29 January 2013 Wishing you a happy festive season . Merry Christmas and a Happy New Year from Viorel ... ________________________________________________________________________________
Subject: PS Engineering PMA4000/King KX170B Interface/Garmin 250
XL
Date: Jan 25, 2013
Can anyone confirm for me what pins on the KX170B and 250XL are picked up by pins 19, 7, 22, 21, 9, 18, 6, 24, 23, and 10 from the PMA4000? The 20th and 21st Centuries don't mesh quite as seamlessly as I'd hoped. :-) Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=393042#393042 ________________________________________________________________________________
Date: Feb 11, 2013
Subject: SD-20 Alternator / SB1B-14 regulator failure modes
As a follow up to my recent failure. The issue ended up being the gear coupling in the alternator. The gear coupling is a field replaceable item and I have one on the way. More when it happens.... ________________________________________________________________________________
Date: Mar 13, 2013
Hello guys..Head set during the flying is that type which have warranty or branded another or local headset is not affordable for the flyer.I do not have experience of the ANR head set but i hope these head set is very comfortable. -------- do good have good Read this topic online here: http://forums.matronics.com/viewtopic.php?p=396191#396191 ________________________________________________________________________________
Date: Mar 14, 2013
3/14/2013 Hello havi333, Buy Lightspeed brand. 'O C' Baker says "The best investment you can make is the effort to gather and understand information." ===================== Subject: Avionics-List: Re: ANR headset feedback From: "havi333" <nannesbrook(at)yahoo.com> Hello guys..Head set during the flying is that type which have warranty or branded another or local headset is not affordable for the flyer.I do not have experience of the ANR head set but i hope these head set is very comfortable. ________________________________________________________________________________
From: John MacCallum <john.maccallum(at)bigpond.com>
Date: Mar 15, 2013
I have a Lightspeed Zulu and I'm quite happy with it. People that have Bose Noise cancelling headsets seem to be happy with them as well So I think you can safely go with either. Cheers John MacCallum VH-DUU RV10 #41016 From: owner-avionics-list-server(at)matronics.com [mailto:owner-avionics-list-server(at)matronics.com] On Behalf Of Owen Baker Sent: Thursday, 14 March 2013 10:47 PM Subject: Avionics-List: ANR headset feedback 3/14/2013 Hello havi333, Buy Lightspeed brand. 'O C' Baker says "The best investment you can make is the effort to gather and understand information." ===================== Subject: Avionics-List: Re: ANR headset feedback From: "havi333" < <mailto:nannesbrook(at)yahoo.com> nannesbrook(at)yahoo.com> Hello guys..Head set during the flying is that type which have warranty or branded another or local headset is not affordable for the flyer.I do not have experience of the ANR head set but i hope these head set is very comfortable. ________________________________________________________________________________
Subject: Re: RST 447K assembly manual wanted
Date: Mar 18, 2013
oldngrey wrote: > I am trying to help a friend with an RST-447K panel mount intercom that has died. He has lost the Assembly Manual, which is section D and separate to the general manual. Does anyone have a copy of the manual that they could email to me, or at least a circuit of the unit. My email address is ballalae(at)yahoo.com > Thanks, > > Brian. I have this intercom, and all applicable manuals. I tried emailing to the above email. No response. I know this is a old thread, but I can see the need may remain. If anyone needs a copy of the manual, reply to this thread. Henry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=396571#396571 ________________________________________________________________________________
Date: Apr 20, 2013
Subject: microair transponder/encoder hookup question
Has anyone successfully installed a Microair T2000SFL-01rev8 transponder combined with their EC2002-01rev3 encoder, using serial connection? The manual for the xp rev8 at > http://www.microair.com.au/admin/uploads/documents/T2000SFLInstallationManual01R80.pdf shows *2* data lines between the components: encoder pin6data receive to xp pin 5data transmit, and encoder pin 7data transmit to xp pin 4data receive. *But*... note 7 on the hookup page (pg 13) says that the diagram is applicable to revs 5,6, & 7. I can't find an install manual for the 01rev3 encoder on their web site, but the manual for the 01rev12 shows pin 6 of the encoder (labeled rs232in) as unconnected. However.... Looking at the page on their pre-wired harnesses at http://www.microair.com.au/index.aspx?page=186&productID=36 The diagram for wiring their xp to their encoder shows encoder pin 6 (data receive) to be *grounded*. So, various docs on the Microair website show the encoder pin 6 to be: open, tied to transponder pin 5, and grounded (through the harness) to the case of the transponder. Anyone have any words of wisdom on the *right* way to do it? Thanks, Charlie <http://www.microair.com.au/index.aspx?page=186&productID=26> ________________________________________________________________________________
Date: Apr 22, 2013
Subject: Garmin GNS 430 Simulator and Windows 7
A year and a half ago I downloaded from the Garmin Website the simulator of the GNS 400 series on my Windows XP computer. Recently I tried to do the same with my Windows 7 computer. This did not work. Admittedly I had been forewarned as the Garmin Website stated that this simulator is not compatible with Windows 7 and 8 but it is with Windows XP. Does anyone know where I can find a Garmin GNS 430 simulator which is compatible with Windows 7? Thanks. George Nielsen RV-6 PH-XGN The Hague, the Netherlands ________________________________________________________________________________
Subject: Narco Transponder Tray Coax Connector
Date: Jul 04, 2013
Can someone point me to the part number/source for a replacement 90-degree, bulkhead, slide-on, coax connector used on the Narco AT-150 transponder tray? Any of the usual suspects (Mouser, Digi-Key, Allied, etc) carry them? Thanks, James ________________________________________________________________________________
Date: Jul 04, 2013
Subject: Re: Narco Transponder Tray Coax Connector
> >Can someone point me to the part number/source for a replacement 90-degree, bulkhead, slide-on, coax connector used on the Narco AT-150 transponder tray? Any of the usual suspects (Mouser, Digi-Key, Allied, etc) carry them? <http://www.brackemfg.com> Bracke Manufacturing, LLC CC. sales(at)brackemfg.com <http://www.pasternack.com> Pasternaclk Enterprises, Inc CA techsupport(at)pasternack.com Both of those keep sending me catalogs but I have never bought anything. Prices are way up in the sky and they seem to want to know how many thousands you want. The Digi-key web site tells all. Mouser is catching up rapidly. I may have a used Narco tray here. Offline to dmcnutt AT same domain with Narco in the subject. Is that transponder still legal? There were some problems with it two decades ago. -- --> The best programming tool is a soldering iron <-- ________________________________________________________________________________
Date: Jul 04, 2013
Single AD to comply with a Narco service bulletin back in 2004 with regard to responses to mode S interrogation. Only applies to a certain serial number range. Any Narco transponder from AT-50 up through AT165 use same tray and pinout. So even if one specific unit is bad, there are plenty of good ones in service to get a replacement. On 7/4/2013 11:42 AM, Doug McNutt wrote: > >> Can someone point me to the part number/source for a replacement 90-degree, bulkhead, slide-on, coax connector used on the Narco AT-150 transponder tray? Any of the usual suspects (Mouser, Digi-Key, Allied, etc) carry them? > <http://www.brackemfg.com> Bracke Manufacturing, LLC CC. > sales(at)brackemfg.com > > <http://www.pasternack.com> Pasternaclk Enterprises, Inc CA > techsupport(at)pasternack.com > > Both of those keep sending me catalogs but I have never bought anything. Prices are way up in the sky and they seem to want to know how many thousands you want. > > The Digi-key web site tells all. Mouser is catching up rapidly. > > I may have a used Narco tray here. Offline to dmcnutt AT same domain with Narco in the subject. > > Is that transponder still legal? There were some problems with it two decades ago. > ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
From: "John denDekker" <john(at)carpenteravionics.com>
Date: Jul 04, 2013
If you are referring to the tray mounted coax connector which is typically a TED brand connector like is used on most tray mount avionics of that generation, you can probably use the Deklin DBA-600. It mounts to the tray the same way (cir-clip) but has a BNC on the other end so you don't have to try to solder the coax on which is a challenge. Best regards, John DenDekker www.carpenteravionics.com 800.300.0352 Toll Free 615.355.9970 office NOTICE: This electronic transmission (including any referenced or attached materials) is covered by the Electronic Communications Privacy Act, 18 U.S.C. Sec. 2510-2521, and is PRIVILEGED, WORK PRODUCT, PROPRIETARY and/or CONFIDENTIAL. It is not intended for transmission to, or receipt by, any unauthorized person. If you have received this transmission in error you are PROHIBITED from disclosing, disseminating, reproducing, using or relying upon it. Please immediately delete it from your system without copying and notify the sender by return e-mail of the erroneous receipt. Thank you. -----Original Message----- From: owner-avionics-list-server(at)matronics.com [mailto:owner-avionics-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Thursday, July 04, 2013 4:07 PM Subject: Re: Avionics-List: Narco Transponder Tray Coax Connector Single AD to comply with a Narco service bulletin back in 2004 with regard to responses to mode S interrogation. Only applies to a certain serial number range. Any Narco transponder from AT-50 up through AT165 use same tray and pinout. So even if one specific unit is bad, there are plenty of good ones in service to get a replacement. On 7/4/2013 11:42 AM, Doug McNutt wrote: > >> Can someone point me to the part number/source for a replacement 90-degree, bulkhead, slide-on, coax connector used on the Narco AT-150 transponder tray? Any of the usual suspects (Mouser, Digi-Key, Allied, etc) carry them? > <http://www.brackemfg.com> Bracke Manufacturing, LLC CC. > sales(at)brackemfg.com > > <http://www.pasternack.com> Pasternaclk Enterprises, Inc CA > techsupport(at)pasternack.com > > Both of those keep sending me catalogs but I have never bought anything. Prices are way up in the sky and they seem to want to know how many thousands you want. > > The Digi-key web site tells all. Mouser is catching up rapidly. > > I may have a used Narco tray here. Offline to dmcnutt AT same domain with Narco in the subject. > > Is that transponder still legal? There were some problems with it two decades ago. > ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Jul 15, 2013
Subject: Vision Microsystems VMS 1000C
In my RV-6 which is powered by a 160 HP Lycoming O-320 I have a Vision Microsystems VMS 1000C. On Sunday the 7th July it worked flawlessly but on Saturday the 13th of July it unfortunately did not work. I have not used it between these dates. The problem with my VMS 1000C is that it displays *Err* on the readings for *MAN*, *OIL PSI*, *FUEL SYS PSI*, *FUEL QTY* *L* and *FUEL QTY **R*. Furthermore the readings for *OIL TEMP* and *CHT *seem suspect. *OIL TEMP* showed some 370 even though I have not run the engine for a week. I switched on the fuel pump but that did not give any fuel pressure reading. As for the fuel level, the tanks are approximately one third full. Their capacity is 19 US gal. Do you know whether the fault lies within my VMS 1000C or with a fault in the electrical connections? In the latter case which circuits may need to be reconnected? It seems to me that Vision Microsystems is defunct and has been so for many years. George Nielsen RV-6 PH-XGN The Hague, the Netherlands ________________________________________________________________________________
Date: Jul 15, 2013
Subject: Re: Vision Microsystems VMS 1000C
VMS was purchased by JPI a number of years ago. Shortly after that the 'C' came out and support for the earlier versions became more difficult to acquire. I pulled mine and replaced it with an AFS 3400 EM which I have since upgraded to EE. I sold my VM1000 parts one at a time to help other users keep their systems running. -----Original Message----- From: George Nielsen Sent: Jul 15, 2013 2:33 PM Subject: Avionics-List: Vision Microsystems VMS 1000C In my RV-6 which is powered by a 160 HP Lycoming O-320 I have a Vision Microsystems VMS 1000C. On Sunday the 7th July it worked flawlessly but on Saturday the 13th of July it unfortunately did not work. I have not used it between these dates. The problem with my VMS 1000C is that it displays Err on the readings for MAN, OIL PSI, FUEL SYS PSI, FUEL QTY L and FUEL QTY R. Furthermore the readings for OIL TEMP and CHT seem suspect. OIL TEMP showed some 370 even though I have not run the engine for a week. I switched on the fuel pump but that did not give any fuel pressure reading. As for the fuel level, the tanks are approximately one third full. Their capacity is 19 US gal. Do you know whether the fault lies within my VMS 1000C or with a fault in the electrical connections? In the latter case which circuits may need to be reconnected? It seems to me that Vision Microsystems is defunct and has been so for many years. George Nielsen RV-6 PH-XGN The Hague, the Netherlands ________________________________________________________________________________
Date: Jul 28, 2013
A software fault tolerant computer system includes a primary virtual machine and a secondary virtual machine. The secondary virtual machine is operable to replicate the primary virtual machine by replicating operations performed on the primary virtual machine. The primary and the secondary virtual machines are further operable to test for equivalent operation of the primary and secondary virtual machines at predetermined stages of operation. This provides software fault tolerance wherein both a unit of replication and a component that implements the fault tolerance mechanisms is a virtual machine (VM). Since a VM as used by the invention has full knowledge of the semantics of application-level code, fault tolerance mechanisms can be provided by the VMs without requiring any increase in application complexity. Co-ordination of replicated states and computations is achieved with characteristics of both active and passive replication. -------- http://www.rctophobby.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405544#405544 ________________________________________________________________________________
Subject: Cleaning out the Hangar, Looking for more toys
Date: Aug 07, 2013
Hi all, I am upgrading my avionics therefore have several items for sale (just removed from the panel): - AvMap EKP IV GPS NAV/Map/HSI - Dynon EFIS-D10A Electronic Flight Information System - TX 760D Aviation Comm Radio See the details at http://tinyurl.com/n8hnbmx I am also looking for the following items: - Garmin/Apollo SL 30 NAV/COMM Radio - Garmin/Apollo SL 50 Enroute GPS Receiver - Mid Continent MD222-406 VOR/NAV Course Indicator Thx, M Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406140#406140 ________________________________________________________________________________
Subject: Re: Cleaning out the Hangar, Looking for more toys
Date: Aug 21, 2013
Mike: I'm receiving your emails... apparently you're not getting mine. I need your mailing address and an agreed upon exchange rate. Dennis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407168#407168 ________________________________________________________________________________
Date: Aug 22, 2013
Mike: Checks are in the mail...money orders for parts + insurance via registered mail. Dennis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407276#407276 ________________________________________________________________________________
Date: Oct 29, 2013
i iike this topic -------- erum Read this topic online here: http://forums.matronics.com/viewtopic.php?p=411662#411662 ________________________________________________________________________________
Date: Oct 29, 2013
Personally speaking I have never been a fan of the RST products. I have tried to find some information on this particular one and have been unsuccessful. Is it just an intercom or an audio panel with intercom? My recommendation is to change it with a better product (typically speaking of RST products) with a PS Engineering intercom or audio panel. www.ps-engineering.com John DenDekker www.carpenteravionics.com 800.300.0352 Toll Free 615.355.9970 office -----Original Message----- From: owner-avionics-list-server(at)matronics.com [mailto:owner-avionics-list-server(at)matronics.com] On Behalf Of erum Sent: Tuesday, October 29, 2013 6:55 AM Subject: Avionics-List: Re: RST 447K assembly manual wanted i iike this topic -------- erum Read this topic online here: http://forums.matronics.com/viewtopic.php?p=411662#411662 ________________________________________________________________________________
Date: Oct 31, 2013
I found this web-site which I believe is the manufacturer of your intercom. http://www.rst-engr.com/ Best regards, John DenDekker www.carpenteravionics.com 800.300.0352 Toll Free 615.355.9970 office -----Original Message----- From: owner-avionics-list-server(at)matronics.com [mailto:owner-avionics-list-server(at)matronics.com] On Behalf Of erum Sent: Tuesday, October 29, 2013 6:55 AM Subject: Avionics-List: Re: RST 447K assembly manual wanted i iike this topic -------- erum Read this topic online here: http://forums.matronics.com/viewtopic.php?p=411662#411662 ________________________________________________________________________________
Date: Nov 01, 2013
Dear Listers, Each November I hold a PBS-like fund raiser to support the continued operation and upgrade of the Email List and Fourm Services at Matronics. It's solely through the Contributions of List members (you) that these Matronics Lists are possible. You have probably noticed that there are no banner ads or pop-up windows on any of the Matronics Lists or related web sites such as the Forums site http://forums.matronics.com , Wiki site http://wiki.matronics.com , or other related pages such as the List Search Engine http://www.matronics.com/search , List Browse http://www.matronics.com/listbrowse , etc. This is because I believe in a List experience that is completely about the sport we all enjoy - namely Airplanes and not about annoying advertisements. During the month of November I will be sending out List messages every couple of days reminding everyone that the Fund Raiser is underway. I ask for your patience and understanding during the Fund Raiser and throughout these regular messages. The Fund Raiser is only financial support mechanism I have to pay all of the bills associated with running these lists. YOUR personal Contribution counts! This year we have a really HUGE and TERRIFIC line up of free gifts to go along with the various Contribution levels. In fact, there are over 30 different gifts to choose from - more than we've ever had before! There's something for everyone, to be sure. Most all of these gifts have been provided by some of the vary members and vendors that you'll find on the Matronics Lists and they have been either donated or provided at substantially discounted rates. This year, these generous members include: Andy Gold of the Builder's Bookstore http://www.buildersbooks.com Bob Nuckolls of the AeroElectric Connection http://www.aeroelectric.com Corbin Glowacki of My Pilot Store http://www.mypilotstore.com George Race of Race Consulting http://www.mrrace.com/ Jon Croke of HomebuiltHELP http://www.homebuilthelp.com These are very generous guys and I encourage you to visit their respective web sites. Each one offers a unique and excellent aviation-related product line. I would like publicly to thank Andy, Bob, Corbin, George, and Jon their generous support of the Lists again this year!! Please make your List Contribution using any one of three secure methods including using a credit card, PayPal, or by personal check. All three methods afford you the opportunity to select one of this year's free gifts with a qualifying Contribution amount!! To make your Contribution, please visit the secure web site: http://www.matronics.com/contribution I would like to thank everyone in advance for their generous financial AND moral support over the years! Thank you! Matt Dralle Matronics Email List Administrator RV-4/RV-6/RV-8 Builder/Rebuilder/Pilot ________________________________________________________________________________
Date: Nov 04, 2013
Date: Nov 06, 2013
Subject: Network Issues At Matronics Last Few Days...
Dear Listers, Starting sometime on Friday November 1st, my Internet Service Provider (ISP) began "upgrading" their Domain Name Servers (DNS). DNS servers allow the resolution of computer names such as "www.matronics.com" to real addresses such as 64.81.74.3. This also impacts email delivery as well, since there is another layer of resolution that applies to email names. Because of this upgrade on the part of my ISP, DNS service started getting unreliable around Friday sometime, but I didn't notice it until sometime on Saturday. When I used a tool called "nslookup" to test the resolution of name-to-address, about 50-75% of the time my ISP's servers would response with an "SERVFAIL" indicating that they didn't know the answer. I opened a ticket with the ISP on Saturday, and by Sunday afternoon I had no feedback on the ticket so I called in to support. "We upgrading the DNS servers, and it should back by Sunday at 5pm." 5pm came and went with no resolution. Well, long story short by Tuesday morning things were still not fixed and in fact much worse. So, I opted to move all my DNS service to a different service provider. I have a lot of DNS entries, so it took a while to get everything moved over. It generally takes about 24 hours for a change like that to fully propagate across the Internet which would be Wednesday morning sometime. I've noticed that the Matronics web server traffic is picking up again, so many sites have already propagated the new information. I really should have just moved the DNS on Saturday when I first noticed the troubles, but with stuff like this, you just keep believing that it gonna be fixed any minute now.... And, in fact, that's what my ISP kept telling me... Its always a giant bummer when stuff like this happens and particularly during the Fund Raiser. I apologize to anyone that has tried to make a Contribution in the last few days and had issues or was simply unable to connect. By the time you read this email, the DNS should be fully propagated, and I ask that you please try again. The Contribution web site URL is: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you for your kind consideration and patience, Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 07, 2013
Contribution Today! Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Please take a moment and assure that your name is on that List of Contributors (LOC)! As a number of members have pointed out over the years, the List seems at least as valuable a building / entertainment tool as your typical magazine subscription! Assure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 09, 2013
Subject: Please Make a Contribution to Support Your Lists...
Dear Listers, Just a reminder that November is the Annual List Fund Raiser. Please make a Contribution today to support the continued operation and upgrade of these great List services!! Pick up a really nice free gift with your qualifying Contribution too! The Contribution Site is fast and easy: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94551-0347 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 11, 2013
Subject: A List Contribution - It's Your Personal Squelch Button...
Date: Nov 11, 2013
Subject: Matronics Email Disruption Fixed...
Dear Listers, Starting around midnight this morning 11/11/13, the Matronics Barracuda spam filter that receives all incoming email from the Internet, developed a problem and started rejecting all incoming email. I just got off the phone with the Barracuda technical support and we have If you have posted to any of the Lists during this time, you will need to resend your email to the respective List. My apologies for the disruption! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 13, 2013
Subject: Please Make A List Contribution Today; Some Nice Comments...
Dear Listers, I've been getting some very nice comments from Listers along with their List Support Contributions. I've shared a number of them below. Please read them over and see what your fellow Listers think of the Lists and Forums. Please make a Contribution today to support the continued upgrade and operation of these services. There are lots of really nice gifts available this year, so please browse the selections and pickup something fun with your qualifying Contribution! You may use a credit card or your PayPal account here: http://www.matronics.com/contribution Or feel free to send a personal check to: Matronics / Matt Dralle 581 Jeannie Way Livermore CA 94550 Thank you in advance for your generous support! It is very much appreciated! Best regards, Matt Dralle Matronics Email List Administrator -------------------- What Listers Are Saying About The Lists -------------------- I wondered off for a few years & am coming back. I firmly believe you provide greater value to us than some magazine subscriptions. William F Thanks for helping me connect to people have truly blazed the trail. Terry M Thank you for the time and effort you put into keeping these lists going. I am on the verge of flying my RV 8 and would not be here without the help of Matronics. Michael W Thank you for providing a valuable service. Vaughn T Matt I like your forums. Jerry D Thank you for another year of service. Oscar Z Been a "member" for years - this has been a fantastic resource and a great gift to the aviation community. Reade G Thanks for the many years of support to RV builders. Roy H Best run list on the net. Roger C Thanks for your excellent forum! Fred D Truly respect your work and service to many readers!! Fergus K Thanks for an ad-free list! William A Thank you for your GREAT service. I read it every day. John B ..great service! Ralph C Thanks so much for being there. Your contribution to aviation knowledge is invaluable. Benjamin B Thank you for providing the list service. It's great! William V I'd never have finished my Glasair without them. Ronald C Thank you Matt for the valuable forum, am pleased to contribute! Jeffrey J Fine service. Byron G Thanks for your support of our community! Kenneth B -------------------- What Listers Are Saying About The Lists -------------------- ________________________________________________________________________________
Date: Nov 15, 2013
in December! Dear Listers, The List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 18, 2013
Subject: Fund Raiser Behind By 25% - Please Contribute Today!
Dear Listers, The percentage of members making a Contribution to support the Lists this year is currently behind last year by at this time by roughly 25%. We got off to a slow start this year with the network DNS issues on the kickoff weekend, so please take this opportunity to show your support for the Matronics Lists and Forums! Please remember that it is *solely* your direct Contributions that keep these Lists and Forums up and running and most importantly - AD FREE! If the members don't want to support the Lists directly, then I might have to add advertisements to offset the costs of running the Lists. But I don't want to have to do that. I really like the non-commercial atmosphere here and I think that a lot of the members appreciate that too. Please take a moment to make a Contribution today in support of the continued ad-free operation of all these Lists: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I want to send out a word of appreciation to all of the members that have already made their generous Contribution to support the Lists! Thank you! Matt Dralle Email List and Forums Administrator ________________________________________________________________________________
Date: Nov 20, 2013
Subject: Value of the List...
If you look forward to checking your List email everyday (and a lot of you have written to say that you do!), then you're probably getting at least $20 or $30 worth of Entertainment from the Lists each year. You'd pay twice that for a subscription to some magazine or even a dinner out. Isn't the List worth at least that much to you? Wouldn't it be great if you could pay that amount and get a well-managed media source free of advertising, SPAM, and viruses? Come to think of it, you do... :-) Won't you please take a minute to make your Contribution today and support these Lists? http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I want to say THANK YOU to everyone that has made a Contribution thus far during this year's List Fund Raiser!! These Lists are made possible exclusively through YOUR generosity!! Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Date: Nov 22, 2013
Subject: Please Make A Contribution Today...
Dear Listers, A quick reminder that November is the annual List Fund Raiser and the List of Contributors is quickly approching. The Matronics Lists are 100% member supported and all of the operational costs are provided for by your Contributions during this time of the year. Your personal Contribution makes a big difference and keeps all of the Matronics Email Lists and Forums completely ad-free. Please make your Contribution today to keep these services up and running! http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you in advance! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 25, 2013
Subject: [PLEASE READ] Why I Have A Fund Raiser...
>From the beginning, the Matronics List and Forum experience has been free from advertising. I have been approached by fair number of vendors wanting to tap into the large volume of activity across the various lists hosted here, but have always flatly refused. Everywhere you go on the Internet these days, a user is pummeled with flashing banners and videos and ads for crap that they don't want. Yahoo, Google and that elk are not "free". The user must constantly endure their barrage of commercialism thrust into their face at an ever increasing rate. Enough is enough, and the Lists at Matronics choose not to succumb to that. That being said, running a service of this size is not "free". It costs a lot of money to maintain the hardware, pay for the electricity, air conditioning, maintenance contracts, etc, etc. etc. I choose to hold a PBS-like fund raiser each year during the month of November where I simply send out a short email every other day asking the members to make a small contribution to support the operation. That being said, that contribution is completely voluntary and non-compulsory. Many members choose not to contribute and that's fine. However, a very modest percentage of the members do choose to make a contribution and it is that financial support that keeps the Lists running. And that's it. To my way of thinking, it is a much more pleasant way of maintaining the Lists and Forums. The other 11 months of the year, you don't see a single advertisement or request for support. That's refreshing and that is a List and Forum that I want to belong to. I think other people feel the same way. Won't you please take a minute to make your Contribution today and support these Lists? http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Date: Nov 26, 2013
Subject: Of Pencils & Airplanes [Repost From AeroElectric-List]...
[Dear Listers, last week, Bob Nuckolls of the AeroElectric fame, posted a very nice message discussing the Lists and Forums at Matronics. It is a very insightful piece and I asked Bob if I could forward it to the rest of the Lists for the other members to enjoy and contemplate as well. He gladly agreed, and so below I have included the text from that message. Enjoy. -Matt Dralle, Matronics Email List and Forum Administrator] "As most of you know, Matt's ISP was fiddling with some crucial details for the exchange of data on the 'net a few weeks ago. The Lists, Matt's business site, and AeroElectric.com got really flakey. . . I was 'unhooked' from the List and all of three of my e-mail services for several days. Out of business and out of touch. After two days, I was beginning to worry. I had no idea as to root cause nor was there a time table for resolution . . . I began to mull over plan-B options. Of course, plan-B would have entailed seeking a new home for aeroelectric.com and ancillary services. NOT a quick, inexpensive or happy thing to contemplate. The time talents and resources that go into fabrication and maintenance of some of the 'simplest' features of our lives often go unnoticed . . . not because they're unappreciated . . . but simply because we're unaware of their significance. I will invite you all to read an essay by one Leonard Read written in 1958 titled "I pencil". See: http://tinyurl.com/me3q3hj It's a fascinating and well crafted peek into a society of unacquainted, self-interested individuals who exploited uncountable windows of opportunity for what has been called "spontaneous order" in the manufacture and sales of the simple wood pencil. The point of citing Mr. Read's essay is to examine two features of the human experience that contribute to the success of this List and our various interests in airplanes. The first point I'd like to make is that we cannot know the millions of individuals who contributed to the materials and infrastructure that make this List possible. We sit at the top of a pyramid of work-product derived from the time, talents and resources of millions of people who we'll never know. Another feature I'd like to emphasis is our ignorance of the criticality for any single component for a host of materials and components for the manufacture and sales of a simple pencil or an affordable airplane. Suppose any one of the materials or processes described in Read's essay were simply unavailable. How would that impact the price of a pencil? Would the pencil even continue to exist at it's new price? The really big question is, "How might some seemingly small loss ripple throughout the economy of our existence?" The time, talent and resources that support infrastructure for this List, my website, Matt's website, and our e-mails cannot be accurately known. That infrastructure stands on an exceedingly complex array of activities that arose from the ingenuity and spontaneous organization of free- market enterprises. But from our perch at the top of this pyramid we need only look down a few layers and see that this resource upon which we depend is vulnerable. There are risks we all assume . . . Matt could get t-boned in an intersection tomorrow. Lightning could strike the pole behind his facility and do catastrophic damage to the hardware. Yours truly could take a deer through the windshield on his way to Wichita some morning. Other risks are less catastrophic. They include things like amateurish behaviors by maintainers of the Internet highway's potholes. Perhaps some material critical to the manufacture of terabyte hard drives dries up. Or maybe the cost of keeping the lights on and the bytes herded become more than Matt can justify given his personal needs for existence. Several times a year I get an opportunity to plant new seeds of thought in the minds of fellow citizens. One of my favorites is to be standing in a long line at Panera's waiting to purchase a bagel and coffee and hear somebody in line complaining about the wait. I suggest to them that to wait in line for a much desired product is a GOOD thing. Not having to wait is a BAD thing if there is not enough business to encourage them to be open tomorrow. It goes without saying that few, if any of us, possess the talents, resources or motivation to step up and do what Matt does. At last count, there were about 1600 individuals who subscribe to this List [Aeroelectric-List]. . . certainly many more make up the population of subscribers to all of the Lists on Matronics. A few years back, Matt was besieged by legal trials and tribulations over the naming of his products . . . seems somebody claimed ownership of the words 'scan' and/or 'scanner' . . . We here on the AeroElectric-List perceived a risk to Matt's operations and came up with several thousands of dollars to contribute to his defense fund. We need make no greater 'investment' in Matt's operations now than it takes to stand in a line for a Quarter-Pounder Combo . . . or a fist full of pencils. You and I can have no more positive influence over the manufacture of pencils and hard drives than to continue to purchase such things and encourage those with the time, talent and resources to continue doing what they do best. Let's contribute to the comfortable maintenance of this service which is probably more valuable than we know. Just a little bit from thousands of us on the Matronics Lists can make a big difference. Bob . . ." Please take a minute to make your Contribution today: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you for your support! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 27, 2013
Subject: Make Sure You're Listed! List of Contributors Coming Soon!
Dear Listers, There's just a few more days left in this year's List Fund Raiser and that means the List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 29, 2013
Subject: Just Two Days Left...
Dear Listers, There are just a couple days left for this year's List Fund Raiser. If you've been putting off making a Contribution until the last minute, well, this is it! The last minute, that is... :-) There are some GREAT new gift selections to choose from this year. I personally want at least four of them! There's probably something you can't live without too! And, best of all it supports your Lists! Please remember that there isn't any sort of commercial advertising on the Lists and the *only* means of keeping these Lists running is through your Contributions during this Fund Raiser. Let's make this a "Black Friday" for the Lists! Please make a Contribution today! http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 30, 2013
Dear Listers, It's November 30th and that always means a couple of things. Its my birthday again; the big 50, in fact! But it also means that it's that last official day of the Matronics Email List Fund Raiser! If you been thinking about picking up one of those really nice incentive gifts now is the time to jump on it!! If you've been meaning to make a Contribution this month but have been putting it off for some reason, NOW is the time! I will be posting the List of Contributors in a few days, so you'll probably want to be known as a person that supported the Lists! I want to thank everyone that has so generously made a Contribution this year in support of our Lists. It is your generosity that keeps this operation running and I don't ever forget it. The List Contribution Web Site is fast and easy. Please support our habit by making your Contribution right now: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you to all in advance! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Dec 16, 2013
Subject: 2013 List of Contributors
Dear Listers, The 2013 Matronics Email List and Forum Fund Raiser officially ended a couple of weeks ago and it's time that I published this year's List of Contributors. It is the people on this list that directly make these Email Lists and Forums possible! Their generous Contributions keep the servers and Internet connection up and running! You can still show your support this year and pick up a great gift at the same time. The Contribution Web Site is fast, easy, and secure: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I also want to thank Andy, Bob, Corbin, George, and Jon for their generous support through the supply of many great gifts this year!! These guys have some excellent products and I encourage you to visit their respective web sites: Andy Gold - The Builder's Bookstore - http://www.buildersbooks.com Bob Nucklolls - AeroElectric - http://www.aeroelectric.com Corbin Glowacki - My Pilot Store - http://www.mypilotstore.com George Race - Race Consulting - http://www.mrrace.com Jon Croke - HomebuiltHELP - http://www.homebuilthelp.com And finally, I'm proud to present The 2013 Fund Raiser List of Contributors: http://www.matronics.com/loc/2013.html Thank you again to everyone that made a Contribution this year!! Matt Dralle Matronics Email List & Forum Administrator ________________________________________________________________________________
Subject: GPS Unit
Date: Jan 05, 2014
Hi all, haven't posted in this section before but am after some advice from some of you experienced people. I'm building a Europa aircraft and have started thinking about my panel. I am going to get a dynon 10" screen instead of the old 6 pack and was thinking about getting another 7"dynon screen for the sat nav. I am also fitting auto pilot both pitch and roll. What i want to know is 1- has anyone used the dynon sat nav system and is it any good and 2- if the dynon system is not recommended what other GPS would work with the 10" dynon and auto pilot system i am fitting? Thanks to all Frank Read this topic online here: http://forums.matronics.com/viewtopic.php?p=416610#416610 ________________________________________________________________________________
Date: Jan 05, 2014
Subject: Re: GPS Unit
I'm not sure what your criteria are for your GPS. I have a dual Dynon instrument panel installed, complete with the Dynon VFR GPS receiver. It picks up satellites any time my hangar door is open providing a view of some of the sky. I don't know what you mean by "any good". I also have the Dynon Skyview autopilot installed. You do not need a second screen for the moving map, although more screen space available does allow for a bigger picture. Other EFIS will not work with the Dynon. While the servos are physically interchangeable with some others, like Trutrack, they are different electronically. I'm a ways from first flight, so I can't tell you how well they work in the air. You don't say if you are planning for VFR use, IFR use. What you need
December 27, 2010 - January 05, 2014
Avionics-Archive.digest.vol-aq
