Avionics-Archive.digest.vol-ar
January 05, 2014 - July 19, 2016
      depends on how you plan to use it.
      Kelly
      On 1/5/2014 3:34 PM, spcialeffects wrote:
      > Hi all, haven't posted in this section before but am after some advice from some
      of you experienced people. I'm building a Europa aircraft and have started
      thinking about my panel. I am going to get a dynon 10" screen instead of the
      old 6 pack and was thinking about getting another 7"dynon screen for the sat nav.
      I am also fitting auto pilot both pitch and roll. What i want to know is 1-
      has anyone used the dynon sat nav system and is it any good and 2- if the dynon
      system is not recommended what other GPS would work with the 10" dynon and
      auto pilot system i am fitting? Thanks to all Frank
      > http://forums.matronics.com/viewtopic.php?p=416610#416610
Subject: Re: GPS Unit
Date: Jan 05, 2014
That is a drawback for the Dynons, they will not interface with other autopilots. Tim > On Jan 5, 2014, at 6:05 PM, Kelly McMullen wrote: > > > I'm not sure what your criteria are for your GPS. I have a dual Dynon instrument panel installed, complete with the Dynon VFR GPS receiver. > It picks up satellites any time my hangar door is open providing a view of some of the sky. I don't know what you mean by "any good". > I also have the Dynon Skyview autopilot installed. You do not need a second screen for the moving map, although more screen space available does allow for a bigger picture. Other EFIS will not work with the Dynon. While the servos are physically interchangeable with some others, like Trutrack, they are different electronically. I'm a ways from first flight, so I can't tell you how well they work in the air. > You don't say if you are planning for VFR use, IFR use. What you need depends on how you plan to use it. > Kelly >> On 1/5/2014 3:34 PM, spcialeffects wrote: >> >> Hi all, haven't posted in this section before but am after some advice from some of you experienced people. I'm building a Europa aircraft and have started thinking about my panel. I am going to get a dynon 10" screen instead of the old 6 pack and was thinking about getting another 7"dynon screen for the sat nav. I am also fitting auto pilot both pitch and roll. What i want to know is 1- has anyone used the dynon sat nav system and is it any good and 2- if the dynon system is not recommended what other GPS would work with the 10" dynon and auto pilot system i am fitting? Thanks to all Frank >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=416610#416610 > > > > > ________________________________________________________________________________
Date: Jan 05, 2014
It is also a positive......substantially less money than other autopilots. On 1/5/2014 9:24 PM, Tim Andres wrote: > > That is a drawback for the Dynons, they will not interface with other autopilots. > Tim > >> On Jan 5, 2014, at 6:05 PM, Kelly McMullen wrote: >> >> >> I'm not sure what your criteria are for your GPS. I have a dual Dynon instrument panel installed, complete with the Dynon VFR GPS receiver. >> It picks up satellites any time my hangar door is open providing a view of some of the sky. I don't know what you mean by "any good". >> I also have the Dynon Skyview autopilot installed. You do not need a second screen for the moving map, although more screen space available does allow for a bigger picture. Other EFIS will not work with the Dynon. While the servos are physically interchangeable with some others, like Trutrack, they are different electronically. I'm a ways from first flight, so I can't tell you how well they work in the air. >> You don't say if you are planning for VFR use, IFR use. What you need depends on how you plan to use it. >> Kelly >>> On 1/5/2014 3:34 PM, spcialeffects wrote: >>> >>> Hi all, haven't posted in this section before but am after some advice from some of you experienced people. I'm building a Europa aircraft and have started thinking about my panel. I am going to get a dynon 10" screen instead of the old 6 pack and was thinking about getting another 7"dynon screen for the sat nav. I am also fitting auto pilot both pitch and roll. What i want to know is 1- has anyone used the dynon sat nav system and is it any good and 2- if the dynon system is not recommended what other GPS would work with the 10" dynon and auto pilot system i am fitting? Thanks to all Frank >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=416610#416610 >> >> >> >> > > ________________________________________________________________________________
Date: Jan 06, 2014
So i will be using the set up for VFR. I have 2x dynon SV32 servo's for the auto pilot. What i want to know really is....what is the dynon GPS moving map like to use/fly with OR is there another GPS unit which is better than the dynon i.e map wise, graphics wise,info wise ect. I like the look of the air box 3 but i cant connect that to my auto pilot system can i?. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=416634#416634 ________________________________________________________________________________
Date: Jan 06, 2014
The Dynon will accept input from any GPS with standard aviation or NEMA output. It can handle something like 5 GPS inputs, in priority that you set. As for the quality of the moving map, I've only seen it in a stationary view, so far. However, it looks as sharp and detailed as any other moving map I've seen. You also can supplement whatever you install with an Ipad or mini-Ipad to have a different moving map or chart reference to what is in your panel. The menu/button selection on the Dynon seems fine to me, but again, I have not flown with it, only operating and making selection with the display powered up on the ground. All EFIS will have a learning curve. Some are more feature rich than others. So far the Dynon appears to be the most cost effective. Garmin has lowered the price of their G3X system to compete. However, you have to consider price of updating the data. Dynon charges a one time fee for moving map and synthetic vision, then the data updates are free. Garmin updates are generally quite expensive. When they get some competition, that may change. On 1/6/2014 3:16 AM, spcialeffects wrote: > > So i will be using the set up for VFR. I have 2x dynon SV32 servo's for the auto pilot. What i want to know really is....what is the dynon GPS moving map like to use/fly with OR is there another GPS unit which is better than the dynon i.e map wise, graphics wise,info wise ect. I like the look of the air box 3 but i cant connect that to my auto pilot system can i?. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=416634#416634 > > ________________________________________________________________________________
Subject: Vertical Power VP-X Sport
Date: Jan 11, 2014
Iv done some reading on this unit and just want to get peoples opinions on it instead of the normal fuses and MCB's OR if anyones using this in their set up whats it like? Many thanks Frank Read this topic online here: http://forums.matronics.com/viewtopic.php?p=416794#416794 ________________________________________________________________________________
Date: Jan 11, 2014
Subject: Re: Vertical Power VP-X Sport
I have the VP-X Pro in my all-electric Glasair SII-RG, and I'm very happy with it. The documentation is clear and complete. The phone support was quick and right on target the few times I had questions. The installation went well, and the unit has worked flawlessly since the first power up. It integrates perfectly with my AFS EFIS and also works with Dynon and Grand Rapids. Maybe others? John Grosse > spcialeffects > January 11, 2014 at 1:11 PM > > > Iv done some reading on this unit and just want to get peoples > opinions on it instead of the normal fuses and MCB's OR if anyones > using this in their set up whats it like? Many thanks Frank > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=416794#416794 > > ________________________________________________________________________________
Date: Jan 11, 2014
At 11:11 AM 1/11/2014 Saturday, you wrote: > >Iv done some reading on this unit and just want to get peoples opinions on it instead of the normal fuses and MCB's OR if anyones using this in their set up whats it like? Many thanks Frank Frank, I have a Vertical Power VP-200 system installed in both my RV-8 and RV-6 and highly recommend it. I have close to 400 flying hours across the two systems and have never had a single problem. Very high quality throughout. - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 172+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... RV-6 #20916 N360EM "The Flyer" http://www.mattsrv6.com - Matt's RV-6 Revitalization Log Status: 180+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode Matt's Livermore Airport Live ATC Stream! Check out the live ATC stream directly from my hangar at the Livermore Airport. Includes both Tower and Ground transmissions. Archives too! For entertainment purposes only. http://klvk.matronics.com ________________________________________________________________________________
Date: Jan 11, 2014
When I hear about VP, I find myself asking questions like:=0A=0A1.- Why =0A would I want a software-controlled circuit breaker when I can just buy a=0A good old circuit breaker < $10 (or a 25 cent fuse).- It seems as tho ugh the complexity =0Afar out weighs any other benefit. =0A=0A=0A2.- Sing le Point of Failure?=0A=0A3.- It seems expensive when compared to alterna tives=0A=0AI realize that VP systems provide additional functionality in ad dition to power distribution, but much of that is easy to get otherwise.=0A =0A=0AIt would be great if some of you VP owners would run us thru your dec ision-making process.=0A=0A=0A=0A________________________________=0A From: spcialeffects =0ATo: avionics-list(at)matronics.com =0A Sent: Saturday, January 11, 2014 11:11 AM=0ASubject: Avionics-List: Vertica ects" =0A=0AIv done some reading on this unit and ju st want to get peoples opinions on it instead of the normal fuses and MCB's OR if anyones using this in their set up whats it like? Many thanks Frank =0A=0A=0A=0A=0ARead this topic online here:=0A=0Ahttp://forums.matronics.co === ________________________________________________________________________________
Date: Jan 11, 2014
Well, it's really the same reason I got rid of the black rotary phone hanging on the kitchen wall in favor of a smart phone in my pocket, and don't still run Windows 3.1 on an IBM 286. The features and advantages of the VP system are all on their website if you're the least bit interested. There's no point in listed that information here since the original poster already has that information, and was asking for feedback from builders using the VP system. From my personal experience the VP-X has delivered on all the advertised promises. I realize that it's more expensive than a bunch of 25 cent fuses or a panel full of 1940's technology CB's but neither "cheap" nor "old and bulky" were among my criteria so I rejected those alternatives. I'm very satisfied with the VP-X and would buy another if I was building another airplane. John Grosse > Jeff Luckey > January 11, 2014 at 3:07 PM > When I hear about VP, I find myself asking questions like: > > 1. Why would I want a software-controlled circuit breaker when I can > just buy a good old circuit breaker < $10 (or a 25 cent fuse). It > seems as though the complexity far out weighs any other benefit. > > 2. Single Point of Failure? > > 3. It seems expensive when compared to alternatives > > I realize that VP systems provide additional functionality in addition > to power distribution, but much of that is easy to get otherwise. > > It would be great if some of you VP owners would run us thru your > decision-making process. > > > ------------------------------------------------------------------------ > *From:* spcialeffects > *To:* avionics-list(at)matronics.com > *Sent:* Saturday, January 11, 2014 11:11 AM > *Subject:* Avionics-List: Vertical Power VP-X Sport > > > > > Iv done some reading on this unit and just want to get peoples > opinions on it instead of the normal fuses and MCB's OR if anyones > using this in their set up whats it like? Many thanks Frank > > > Read this topic online here: > > http://forums.matronics.com/viewthe Builder's Bookstore > www.homebuilthelpnbsp; * Race Consulting > <http://www.mrrace.comnbsp;+%A0+%A0+%A0+%A0+%A0+%A0+%A0+%A0+%A0+%A0+%A0+%A0+%A0+%A0+-Matt+Dralle,%20List%0A======================%3Cbr%3E%3Cbr%3E%3Cbr%3E%3Cbr%3E%3Cbr%3E%3Cbr%3E%3C/div%3E%20%3C/div%3E%20%3C/div%3E%20%20%3C/div%3E%0A%3Cpre%3E%3Cb%3E%3Cfont%20size=2%20color=>http://www.matronics.com/Navigator?Avionics-List > http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jan 11, 2014
I have a VPX Pro in my RV-7 project. I studied it for a long time before committing. I like it and have no regrets so far. On Saturday, January 11, 2014, John Grosse wrote: > > > Well, it's really the same reason I got rid of the black rotary phone > hanging on the kitchen wall in favor of a smart phone in my pocket, and > don't still run Windows 3.1 on an IBM 286. The features and advantages of > the VP system are all on their website if you're the least bit interested. > There's no point in listed that information here since the original poster > already has that information, and was asking for feedback from builders > using the VP system. From my personal experience the VP-X has delivered on > all the advertised promises. I realize that it's more expensive than a > bunch of 25 cent fuses or a panel full of 1940's technology CB's but > neither "cheap" nor "old and bulky" were among my criteria so I rejected > those alternatives. I'm very satisfied with the VP-X and would buy another > if I was building another airplane. > > John Grosse > >> Jeff Luckey >> January 11, 2014 at 3:07 PM >> When I hear about VP, I find myself asking questions like: >> >> 1. Why would I want a software-controlled circuit breaker when I can >> just buy a good old circuit breaker < $10 (or a 25 cent fuse). It seems as >> though the complexity far out weighs any other benefit. >> >> 2. Single Point of Failure? >> >> 3. It seems expensive when compared to alternatives >> >> I realize that VP systems provide additional functionality in addition to >> power distribution, but much of that is easy to get otherwise. >> >> It would be great if some of you VP owners would run us thru your >> decision-making process. >> >> >> ------------------------------------------------------------------------ >> *From:* spcialeffects >> *To:* avionics-list(at)matronics.com >> *Sent:* Saturday, January 11, 2014 11:11 AM >> *Subject:* Avionics-List: Vertical Power VP-X Sport >> >> spcialeffects(at)aol.com > >> >> Iv done some reading on this unit and just want to get peoples opinions >> on it instead of the normal fuses and MCB's OR if anyones using this in >> their set up whats it like? Many thanks Frank >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewthe Builder's Bookstore >> www.homebuilthelpnbsp; * Race Consulting <http://www.mrrace.comnbsp;+% >> A0+%A0+%A0+%A0+%A0+%A0+%A0+%A0+%A0+%A0+%A0+%A0+%A0+%A0+- >> Matt+Dralle,%20List%0A======================%3Cbr%3E%3Cbr% >> 3E%3Cbr%3E%3Cbr%3E%3Cbr%3E%3Cbr%3E%3C/div%3E%20%3C/div% >> 3E%20%3C/div%3E%20%20%3C/div%3E%0A%3Cpre%3E%3Cb%3E%3Cfont% >> 20size=2%20color=>http://www.matronics.com/Navigator?Avionics-List >> http://www.matronics.com/contribution >> > > -- -- Larry Bowen Larry(at)BowenAero.com http://BowenAero.com ________________________________________________________________________________
Date: Jan 11, 2014
With the VPX I don't have to devote any panel space to breakers, fuses, etc. For items that have dedicated switch, there is also a software backup method to turning items on or off. I can custom tailor the actual breaker value for each circuit, not locked to circuit breaker values manufacturer chooses. Not to mention the need to individually wire each circuit breaker and label it for individual breakers. I sold the breakers that came with my RV-10 kit for around $200, so they aren't exactly cheap. On 1/11/2014 5:47 PM, Larry Bowen wrote: > I have a VPX Pro in my RV-7 project. I studied it for a long time > before committing. I like it and have no regrets so far. > > ________________________________________________________________________________
Subject: Tuning dipole aerial
Date: Jan 22, 2014
Hi I'm looking for some help with regards tuning in my dipole aerial as i seem to have a slight problem. I Have everything connected up to my swr meter and got the following readings at the start 118.000 1.2 127.350 2.7 136.975 3.1 I have been trimming the copper tape of the dipole and the lower frequency swr reading has increased and the mid frequency has decreased however there has been no real effect on the hight frequency as this is still at a swr of 3. I now have the copper tape legs cut to the lengths that were specified in my manual 480mm. I dont really want to cut much more off these as its not having any effect on the top frequency swr value therefore i feel there is an underlying issue that i need to sort out first? With the 2 legs cut to 480mm i have the following swr readings 118.000 2.0 127.350 2.1 136.985 3.0 I would appreciated any help and advice that people have to offer to try and recrify this problem for me. Im now not sure how to proceed to sort this problem out. I look forward to your replies. Kind regards Donald -------- Fireflier Read this topic online here: http://forums.matronics.com/viewtopic.php?p=417402#417402 ________________________________________________________________________________
Subject: Re: Tuning dipole aerial
Date: Jan 22, 2014
Plot it with more data points to find its center freq. If you think of it in terms of the "higher the frequency the shorter the element", it was resonant at 118 MHz, and after cutting (how much?) it's moved higher. Is you meter designed for VHF? Also, nearby objects including you can affect it. Try to place it vertical and away from other objects. Both elements should be equal length, and you should measure from the crotch of the separated coax. Tim > On Jan 22, 2014, at 2:55 AM, "fireflier" wrote: > > > Hi > I'm looking for some help with regards tuning in my dipole aerial as i seem to have a slight problem. > > I Have everything connected up to my swr meter and got the following readings at the start > > 118.000 1.2 > 127.350 2.7 > 136.975 3.1 > > I have been trimming the copper tape of the dipole and the lower frequency swr reading has increased and the mid frequency has decreased however there has been no real effect on the hight frequency as this is still at a swr of 3. > > I now have the copper tape legs cut to the lengths that were specified in my manual 480mm. I dont really want to cut much more off these as its not having any effect on the top frequency swr value therefore i feel there is an underlying issue that i need to sort out first? > > With the 2 legs cut to 480mm i have the following swr readings > > 118.000 2.0 > 127.350 2.1 > 136.985 3.0 > > I would appreciated any help and advice that people have to offer to try and recrify this problem for me. Im now not sure how to proceed to sort this problem out. > > I look forward to your replies. > > Kind regards > Donald > > -------- > Fireflier > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=417402#417402 > > > > > > > > > > ________________________________________________________________________________
Date: Jan 22, 2014
Donald, you did not mention if the antenna was installed on Carbon Fibre, Fiberglass or Aluminum skin. Aren't the copper tapes used to establish an effective groundplane? Is it a concealed antenna? is it homemade or manufactured? Tesla's are having problems with quality FM reception due to dipole, concealed. Some owners thought the side mirrors were the concealed antenna, Turns out the location was selected for cosmetics not function along the rear window deck and use a two frequency combiner. Are you assuming the coax connections were both done on the shielding correctly? John On Wed, Jan 22, 2014 at 7:26 AM, Tim Andres wrote: > > Plot it with more data points to find its center freq. > If you think of it in terms of the "higher the frequency the shorter the > element", it was resonant at 118 MHz, and after cutting (how much?) it's > moved higher. > > Is you meter designed for VHF? > Also, nearby objects including you can affect it. Try to place it vertical > and away from other objects. Both elements should be equal length, and you > should measure from the crotch of the separated coax. > > Tim > > > On Jan 22, 2014, at 2:55 AM, "fireflier" > wrote: > > > fireflier(at)btinternet.com> > > > > Hi > > I'm looking for some help with regards tuning in my dipole aerial as i > seem to have a slight problem. > > > > I Have everything connected up to my swr meter and got the following > readings at the start > > > > 118.000 1.2 > > 127.350 2.7 > > 136.975 3.1 > > > > I have been trimming the copper tape of the dipole and the lower > frequency swr reading has increased and the mid frequency has decreased > however there has been no real effect on the hight frequency as this is > still at a swr of 3. > > > > I now have the copper tape legs cut to the lengths that were specified > in my manual 480mm. I dont really want to cut much more off these as its > not having any effect on the top frequency swr value therefore i feel there > is an underlying issue that i need to sort out first? > > > > With the 2 legs cut to 480mm i have the following swr readings > > > > 118.000 2.0 > > 127.350 2.1 > > 136.985 3.0 > > > > I would appreciated any help and advice that people have to offer to try > and recrify this problem for me. Im now not sure how to proceed to sort > this problem out. > > > > I look forward to your replies. > > > > Kind regards > > Donald > > > > -------- > > Fireflier > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=417402#417402 > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jan 22, 2014
Copper foil dipoles are pretty common in glass airplanes. Jim Weir use to se ll a kit and book, I don't think he's shipping them anymore but I'm assuming Donald's working from that recipe. He did mention it is a dipole. Tim > On Jan 22, 2014, at 12:08 PM, John Cox wrote: > > Donald, you did not mention if the antenna was installed on Carbon Fibre, Fiberglass or Aluminum skin. Aren't the copper tapes used to establish an e ffective groundplane? Is it a concealed antenna? is it homemade or manufact ured? Tesla's are having problems with quality FM reception due to dipole, c oncealed. Some owners thought the side mirrors were the concealed antenna, T urns out the location was selected for cosmetics not function along the rear window deck and use a two frequency combiner. Are you assuming the coax co nnections were both done on the shielding correctly? > > John > > >> On Wed, Jan 22, 2014 at 7:26 AM, Tim Andres wrote : >> >> Plot it with more data points to find its center freq. >> If you think of it in terms of the "higher the frequency the shorter the e lement", it was resonant at 118 MHz, and after cutting (how much?) it's move d higher. >> >> Is you meter designed for VHF? >> Also, nearby objects including you can affect it. Try to place it vertica l and away from other objects. Both elements should be equal length, and you should measure from the crotch of the separated coax. >> >> Tim >> >> > On Jan 22, 2014, at 2:55 AM, "fireflier" wro te: >> > com> >> > >> > Hi >> > I'm looking for some help with regards tuning in my dipole aerial as i s eem to have a slight problem. >> > >> > I Have everything connected up to my swr meter and got the following re adings at the start >> > >> > 118.000 1.2 >> > 127.350 2.7 >> > 136.975 3.1 >> > >> > I have been trimming the copper tape of the dipole and the lower freque ncy swr reading has increased and the mid frequency has decreased however th ere has been no real effect on the hight frequency as this is still at a swr of 3. >> > >> > I now have the copper tape legs cut to the lengths that were specified in my manual 480mm. I dont really want to cut much more off these as its no t having any effect on the top frequency swr value therefore i feel there is an underlying issue that i need to sort out first? >> > >> > With the 2 legs cut to 480mm i have the following swr readings >> > >> > 118.000 2.0 >> > 127.350 2.1 >> > 136.985 3.0 >> > >> > I would appreciated any help and advice that people have to offer to tr y and recrify this problem for me. Im now not sure how to proceed to sort th is problem out. >> > >> > I look forward to your replies. >> > >> > Kind regards >> > Donald >> > >> > -------- >> > Fireflier >> > >> > >> > >> > >> > Read this topic online here: >> > >> > http://forums.matronics.com/viewtopic.php?p=417402#417402 >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> >> >> ========== >> t" target="_blank">http://www.matronics.com/Navigator?Avionics-List >> ========== >> http://forums.matronics.com >> ========== >> le, List Admin. >> ="_blank">http://www.matronics.com/contribution >> ========== > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Jan 22, 2014
Dave hasn't answered up, but the math does not look right. Assuming a concealed dipole, the starting measurement for a 1/4 wave in the mid band of the frequencies desired might have been 564.1 mm or 22.2". Trimming it to 488 moves that SWR towards the higher end frequency giving rise to the loss of 118mHz for SWR = 1.2 and then heading south to the more undesirable 2.0. Just a perspective. Maybe he is going 1/8 wave, no ground plane and properly matched BALUN for the coax to the transceiver?? John On Wed, Jan 22, 2014 at 12:58 PM, Tim Andres wrote: > Copper foil dipoles are pretty common in glass airplanes. Jim Weir use to > sell a kit and book, I don't think he's shipping them anymore but I'm > assuming Donald's working from that recipe. He did mention it is a dipole. > Tim > > On Jan 22, 2014, at 12:08 PM, John Cox wrote: > > Donald, you did not mention if the antenna was installed on Carbon Fibre, > Fiberglass or Aluminum skin. Aren't the copper tapes used to establish an > effective groundplane? Is it a concealed antenna? is it homemade or > manufactured? Tesla's are having problems with quality FM reception due to > dipole, concealed. Some owners thought the side mirrors were the concealed > antenna, Turns out the location was selected for cosmetics not function > along the rear window deck and use a two frequency combiner. Are you > assuming the coax connections were both done on the shielding correctly? > > John > > > On Wed, Jan 22, 2014 at 7:26 AM, Tim Andres wrote: > >> >> Plot it with more data points to find its center freq. >> If you think of it in terms of the "higher the frequency the shorter the >> element", it was resonant at 118 MHz, and after cutting (how much?) it's >> moved higher. >> >> Is you meter designed for VHF? >> Also, nearby objects including you can affect it. Try to place it >> vertical and away from other objects. Both elements should be equal length, >> and you should measure from the crotch of the separated coax. >> >> Tim >> >> > On Jan 22, 2014, at 2:55 AM, "fireflier" >> wrote: >> > >> fireflier(at)btinternet.com> >> > >> > Hi >> > I'm looking for some help with regards tuning in my dipole aerial as i >> seem to have a slight problem. >> > >> > I Have everything connected up to my swr meter and got the following >> readings at the start >> > >> > 118.000 1.2 >> > 127.350 2.7 >> > 136.975 3.1 >> > >> > I have been trimming the copper tape of the dipole and the lower >> frequency swr reading has increased and the mid frequency has decreased >> however there has been no real effect on the hight frequency as this is >> still at a swr of 3. >> > >> > I now have the copper tape legs cut to the lengths that were specified >> in my manual 480mm. I dont really want to cut much more off these as its >> not having any effect on the top frequency swr value therefore i feel there >> is an underlying issue that i need to sort out first? >> > >> > With the 2 legs cut to 480mm i have the following swr readings >> > >> > 118.000 2.0 >> > 127.350 2.1 >> > 136.985 3.0 >> > >> > I would appreciated any help and advice that people have to offer to >> try and recrify this problem for me. Im now not sure how to proceed to sort >> this problem out. >> > >> > I look forward to your replies. >> > >> > Kind regards >> > Donald >> > >> > -------- >> > Fireflier >> > >> > >> > >> > >> > Read this topic online here: >> > >> > http://forums.matronics.com/viewtopic.php?p=417402#417402 >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> >> >> ========== >> t" target="_blank">http://www.matronics.com/Navigator?Avionics-List >> ========== >> http://forums.matronics.com >> ========== >> le, List Admin. >> ="_blank">http://www.matronics.com/contribution >> ========== >> >> >> >> > * > > D============================================ > ics-List"">http://www.matronics.com/Navigator?Avionics-List > D============================================ > //forums.matronics.com <http://forums.matronics.com> > D============================================ > ot;">http://www.matronics.com/contribution > D============================================ > > * > > * > > > * > > ________________________________________________________________________________
Subject: Re: Value of the List...
Date: Jan 26, 2014
typically the move are generally a factor might possibly facilitate guests to always be delighted a long time Read this topic online here: http://forums.matronics.com/viewtopic.php?p=417649#417649 ________________________________________________________________________________
Subject: Serial port question
Date: Feb 01, 2014
Originally, I was going to go with a pair of Grand Rapids HX screens with a traditional radio stack. But when the HXr came out that supported remote avionics and the ability to use a tablet as a secondary display, I decided to opt for that But recently I discovered that a single screen wouldn't work because each device (EIS, 2 Coms, 1 Nav, Transponder, Audio Panel, GPS, VPX, 2 AHRS) requires a serial port and there are only 8 ports per screen. I've been told that I need to add a second HXr to get more ports. :( Another builder has told me that I can use a 4-port RS-232 serial-to-USB adapter which would connect to the USB port on the HXr. I've got an email in to GRT on this but I was wondering if anyone knows if this is a workable solution. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=417987#417987 ________________________________________________________________________________
Date: Feb 10, 2014
Subject: Northstar M-3 GPS internal battery
Does anyone have a part number and source for this battery? Thanks, Kelly ________________________________________________________________________________
Date: Feb 11, 2014
atbatt.com xeno XL-210F > Date: Mon=2C 10 Feb 2014 21:13:53 -0700 > From: kellym(at)aviating.com > To: avionics-list(at)matronics.com=3B aeroelectric-list(at)matronics.com > Subject: Avionics-List: Northstar M-3 GPS internal battery > > > Does anyone have a part number and source for this battery? > Thanks=2C > Kelly > =========== =========== =========== =========== > > > ________________________________________________________________________________
Subject: Honeywell KT 70 Install Manual
Date: Mar 01, 2014
Would anyone have a KT 70 Install manual .pdf I could get a copy of? Thanks -------- Hayden Read this topic online here: http://forums.matronics.com/viewtopic.php?p=419613#419613 ________________________________________________________________________________
Subject: Vertical Power move to Everett, WA and Oshkosh, WI
Date: Mar 18, 2014
Hi folks, Just wanted to put a post out there to be sure the news is on Matronics that the Vertical Power product line was purchased by Astronics Ballard Technology in Everett, WA, and I am the new customer support rep, based in Oshkosh, WI. Marc Ausman is working with me during the transition to get me up to speed on support issues and if you need anything, please don't hesitate to contact me at 425-328-1658 or 920-216-3699. Email is support(at)verticalpower.com -------- Chad Jensen Vertical Power Support RV-7, built, flown, sold Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420559#420559 ________________________________________________________________________________
Date: Mar 18, 2014
Subject: Auto Response
Thank you for your email but I will be on vacation with limited email and phone access. Please leave your email and I will return all my emails after March 21st. In case of emergencies, please contact Rodney at 480-217-5555. THANK YOU! ________________________________________________________________________________
Date: Mar 18, 2014
Subject: Re: Vertical Power move to Everett, WA and Oshkosh, WI
At 01:24 PM 3/18/2014 Tuesday, you wrote: > >Hi folks, > >Just wanted to put a post out there to be sure the news is on Matronics that the Vertical Power product line was purchased by Astronics Ballard Technology in Everett, WA, and I am the new customer support rep, based in Oshkosh, WI. Marc Ausman is working with me during the transition to get me up to speed on support issues and if you need anything, please don't hesitate to contact me at 425-328-1658 or 920-216-3699. Email is support(at)verticalpower.com > >-------- >Chad Jensen >Vertical Power Support >RV-7, built, flown, sold Great to see you on the List, Chad. I have a VP-200 in my RV-8 and another one in my RV-6. Absolutely love them. I can't imagine flying without the electrical automation features of the VP-200 specifically. Will Astronics be working on a new version of the VP-200 with those automation features? Marc had said that they were going to add them to the VP-300/400 models, but I understand that Astronics won't be carrying those models. For me, the real utility and strength in the Vertical Power products is/was the automation. If I were in the market for a new experimental electrical system, I'm not sure I'd be all that interesting in the VP-x, but I'd buy another VP-200 in a heartbeat. Please keep us up to date on Astronics' current and future product updates. Big Fan of Vertical Power Products, - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 172+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... RV-6 #20916 N360EM "The Flyer" http://www.mattsrv6.com - Matt's RV-6 Revitalization Log Status: 180+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode Matt's Livermore Airport Live ATC Stream! Check out the live ATC stream directly from my hangar at the Livermore Airport. Includes both Tower and Ground transmissions. Archives too! For entertainment purposes only. http://klvk.matronics.com ________________________________________________________________________________
Date: Mar 20, 2014
Thanks Matt! I will definitely keep Matronics up to date on our products. I don't know of any plans at this time to bring back anything like the VP-200 and the VP-300/400 is no more. The concentration will be on the VP-X and the development of the primary power system, which is in a second engineering review state. Glad you like your 200's though! -------- Chad Jensen Vertical Power Support RV-7, built, flown, sold Read this topic online here: http://forums.matronics.com/viewtopic.php?p=420688#420688 ________________________________________________________________________________
Date: Mar 20, 2014
WI Count me as another VP-200 fan...and I haven't even installed mine yet. I got the last one after the VP-300/400s came out, a refurbished unit that the owner traded in for a VP-400. Why did I want the -200? For the same reasons Matt cited. I just don't see the benefit of merely replacing some circuit breakers that is essentially the role of the VP-X. For a couple of years now I've thought that the logical next step for VP would be to provide an add-on for the -X to achieve all or most of the -200 functionality. With the -X physical switches handle only very low power triggering currents. Those triggers could be provided by an onboard computer, like the -200 offers. Furthermore, you wouldn't have to replace all your physical switches. Just put the onboard computer behind the panel, wire each physical switch in parallel to the computer, and have a small LCD screen on the panel to provide system status info. Ralph Finch Davis, CA On Thu, Mar 20, 2014 at 1:03 PM, c1jensen wrote: > > Thanks Matt! I will definitely keep Matronics up to date on our products. I don't know of any plans at this time to bring back anything like the VP-200 and the VP-300/400 is no more. The concentration will be on the VP-X and the development of the primary power system, which is in a second engineering review state. > > Glad you like your 200's though! > > -------- > Chad Jensen > Vertical Power Support > RV-7, built, flown, sold > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=420688#420688 > > ________________________________________________________________________________
Date: Mar 21, 2014
At 05:24 PM 3/20/2014 Thursday, you wrote: > >Why did I want the -200? For the same reasons Matt cited. I just >don't see the benefit of merely replacing some circuit breakers that >is essentially the role of the VP-X. I think the biggest downfall of the VP-200 was that potential customers didn't really understand just how *awesome* the automation functionality is and how it really works. Many times at fly-ins or other events where I've had an opportunity to show off the VP-200, fellow homebuilders are in awe of the automation after I've take a few minutes to explain just how it works and how it significantly reduces my workload during the various phases of flight. The fact that the VP-200 knows, based on GPS/RPM/AHRS data exactly what mode of flight that I'm in - Start/Taxi/Runup/Takeoff/Cruse/Landing - and switches on or off the electrical circuits that I've pre-programmed for each mode of flight is simply genius. Not only is the concept certainly revolutionary in the market, but the VP-200's implementation of it just works and works great. The only external input that is missing to the logic, IMHO, is the determination of Day vs. Night. I have to manually turn the position lights on. It seems like either the input from the exiting dimmer electric eye or from some sort of real time clock could make this happen. Ralph's idea of adding automation to the VP-x though the use of an external embedded processor and display is a good one. Maybe when I get the RV-8 back in the air, I'll start working on something along those lines... :-) Best regards, - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 172+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... RV-6 #20916 N360EM "The Flyer" http://www.mattsrv6.com - Matt's RV-6 Revitalization Log Status: 200+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode Matt's Livermore Airport Live ATC Stream! Check out the live ATC stream directly from my hangar at the Livermore Airport. Includes both Tower and Ground transmissions. Archives too! For entertainment purposes only. http://klvk.matronics.com ________________________________________________________________________________
Date: Mar 21, 2014
Subject: Re: RV8-List: Re: Vertical Power move to Everett, WA and
Oshkosh, WI Based on GPS information (position and time), you can know whether you are in Day or night, no problem, without having to resort to external devices such as a light sensor (which can break). I would think that sort of thing would be quite easy. Shaun On Fri, Mar 21, 2014 at 8:56 AM, Matt Dralle wrote: > --> RV8-List message posted by: Matt Dralle > > At 05:24 PM 3/20/2014 Thursday, you wrote: > ralphmariafinch(at)gmail.com> > > > >Why did I want the -200? For the same reasons Matt cited. I just > >don't see the benefit of merely replacing some circuit breakers that > >is essentially the role of the VP-X. > > > I think the biggest downfall of the VP-200 was that potential customers > didn't really understand just how *awesome* the automation functionality is > and how it really works. Many times at fly-ins or other events where I've > had an opportunity to show off the VP-200, fellow homebuilders are in awe > of the automation after I've take a few minutes to explain just how it > works and how it significantly reduces my workload during the various > phases of flight. The fact that the VP-200 knows, based on GPS/RPM/AHRS > data exactly what mode of flight that I'm in - > Start/Taxi/Runup/Takeoff/Cruse/Landing - and switches on or off the > electrical circuits that I've pre-programmed for each mode of flight is > simply genius. Not only is the concept certainly revolutionary in the > market, but the VP-200's implementation of it just works and works great. > The only external input that is missing to the logic, IMHO, is the > determination of Day vs. Night. I have to manually turn the position > lights o! > n. It seems like either the input from the exiting dimmer electric eye > or from some sort of real time clock could make this happen. > > Ralph's idea of adding automation to the VP-x though the use of an > external embedded processor and display is a good one. Maybe when I get > the RV-8 back in the air, I'll start working on something along those > lines... :-) > > Best regards, > > > - > Matt Dralle > > RV-8 #82880 N998RV "Ruby Vixen" > http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log > http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log > http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel > Status: 172+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... > > RV-6 #20916 N360EM "The Flyer" > http://www.mattsrv6.com - Matt's RV-6 Revitalization Log > Status: 200+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer > Mode > > Matt's Livermore Airport Live ATC Stream! > Check out the live ATC stream directly from my hangar at the Livermore > Airport. Includes both Tower and Ground transmissions. Archives too! > For entertainment purposes only. http://klvk.matronics.com > > ________________________________________________________________________________
Date: Apr 16, 2014
Subject: Matronics Web Server Down for Repair (PLEASE READ)...
Dear Listers, Late Tuesday night 4/15/2014, the Matronics Web server crashed due to a multi-disk RAID 5 failure. The system has complete data backups, but I will likely have to order some replacement disks to rebuild the system. I'll work as quickly as I can to restore the Matronics Web Server. The Matronics EMAIL server is NOT impacted by this issue. All normal Matronics Email List mail will flow as usual. However, the Matronics Web Forums interface will not be available. Also impacted by the Web Server outage will be the AeroElectric web site. I will try to post daily updates on the Web Server restoration status. I apologize for the inconvenience... :-( Best regards, Matt Dralle Matronics Email List and Forum Admin. Matt G Dralle | Matronics | 581 Jeannie Way | Livermore | CA | 94550 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Apr 17, 2014
Subject: Matronics Web Server Repaired and ONLINE! (PLEASE READ)
Dear Listers, The new hard drives for the Matronics web server arrived today, Thursday 4/17/2014 and the RAID5 disk array rebuild went very smoothly. Web server is back online and fully functional! No data or files were lost. Additionally, those that frequent the AeroElectric web site will find that it has been restored as well. Best regards, Matt Dralle Matronics Email List and Forum Admin. Matt G Dralle | Matronics | 581 Jeannie Way | Livermore | CA | 94550 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
From: "DEAN PSIROPOULOS" <dean.psiropoulos(at)verizon.net>
Subject: Garmin SL-30 poor VOR reception
Date: Apr 25, 2014
Hello listers: I have an RV-6A that I've been flying for a few years. When I first started flying the airplane I did some rough VOR range reception checks with the SL-30 and I had to get within 20 miles of a VOR station to get the receiver to lock on and the OBS indicator to stabilize with no flag displayed. I continued with the flight test regimen and getting familiar with the airplane and enjoying it. Since flights have been in VFR conditions around the busy Tampa (Florida) airspace I used the panel mounted moving map (GPS/Comm) to make sure I stayed out of the Class B, there was no need to have good VOR reception. The Com portion was the only thing I was using on the SL-30 and that worked very well. Then, a couple months ago I turned on the SL-30 and, nothing, no display or Com so I returned the unit to Garmin for repair. In the meantime I'd been talking to a CFII about working on my instrument proficiency to get back up to FAA standards after a long hiatus. When the SL-30 was repaired and back in the instrument panel I took off on a flight to Ocala to check it out. I climbed up to 4500 feet and watched the OBS and listened for the ID code as I entered the 40 mile radius of the Ocala VOR. Nothing so I kept going on a course straight for the station. Around 20-25 miles out I started getting activity on the indicator but the flags were intermittent and the radio could not maintain a lock. Finally about 15 miles out the indicators stabilized and the flags stayed off, obviously something is amiss. I'm using a Comant CI-159 VOR/ILS antenna. This unit consists of a phenolic "puck" with a BNC connector cast into it for the coax connection. There are two fiberglas elements (thin rods about 18 inches long) that screw into the puck to form a "V" shaped antenna. I have it mounted on the bottom of the fuselage in the back of the airplane under the horizontal stabilizer. The BNC sticks through a hole in the belly and appx 25 foot length of RG-58 coax runs inside the aircraft up to the SL-30 receiver. No gasket was supplied with the antenna so I just bolted the puck to the aluminum using the two bolt holes. After the Ocala flight I removed the puck and elements for closer inspection and checked the connector on the coax cable at the antenna end. Nothing wrong that I could tell just by looking at the equipment. There was a bit of engine oil (from the exhaust) on the puck surface facing the skin. I cleaned it off and made a gasket to go between the puck and the skin to minimize the oil build up again. I have not flown the airplane since but I doubt that lack of a gasket was causing the poor reception, maybe someone here can tell me. The other thing I checked was the resistance between the center pin and outside barrel of the BNC connector on the antenna. Resistance was showing basically a dead short (less than 1 ohm, same reading as touching the meter probes together). I'm not an antenna designer so I don't know if this is what the reading should be or not. Aircraft Spruce has the following description for this antenna: " "V" Dipole VOR/Glide Slope Antenna with detachable elements is similar to the CI 158C-3 with the exception of offering 2-hole mount instead of a 4-hole mount. This V Dipole encompasses reduced static capability with the use of P-Stat paint. Integral ferrite balun provides for higher radiation efficiency." . I don't know if the construction of the antenna would cause the meter to show such a low resistance, maybe some here could shed some light on that. Any ideas, experiences with poor VOR reception here on the list? Since the radio has been repaired and tested by the factory I'd say it's not the radio. I checked the connector at the back of the radio tray and it appears secure so I'm not sure what else to do. Since VORs are being decommissioned there is going to be less and less need for VOR reception but if I have to use victor airways during instrument operations I need to have good reception at the expected range or I won't be able to comply with ATC clearances. Thanks for the help Dean Psiropoulos RV-6A N197DM 200+ hours since 2008 ________________________________________________________________________________
Date: Apr 25, 2014
Subject: Re: Garmin SL-30 poor VOR reception
I just went and measured the resistance between the center pin and the outside connector on my CI-158C and it too is basically a short, so that part seems "normal". I would do a similar test on your cable with both ends disconnected. That should be infinate resistance. Are you using "RG-58A" or "RG-58C/U"? "RG-58A" is really lossy. ""RG-58C/U" is better, but still not that great. I would strongly recommend RG-142 or RV-400 for that application. I have RG-142 installed in my RV-8 connected to an SL-30 and to a CI-158C antenna mounted in the top of my vertical stab and I get outstanding reception. Pull the RG-58 out, get some RG-142 and some high-quality BNC connectors (the crimp-on kind NOT the screw-on kind) and then see how things work. You may still have a problem with the NAV receiver on the SL-30, but upgrading your cable will go a long way in improving your reception in any case. Matt At 09:17 PM 4/24/2014 Thursday, you wrote: > >Hello listers: > >I have an RV-6A that I've been flying for a few years. When I first started >flying the airplane I did some rough VOR range reception checks with the >SL-30 and I had to get within 20 miles of a VOR station to get the receiver >to lock on and the OBS indicator to stabilize with no flag displayed. I >continued with the flight test regimen and getting familiar with the >airplane and enjoying it. Since flights have been in VFR conditions around >the busy Tampa (Florida) airspace I used the panel mounted moving map >(GPS/Comm) to make sure I stayed out of the Class B, there was no need to >have good VOR reception. The Com portion was the only thing I was using on >the SL-30 and that worked very well. Then, a couple months ago I turned on >the SL-30 and, nothing, no display or Com so I returned the unit to Garmin >for repair. In the meantime I'd been talking to a CFII about working on >my instrument proficiency to get back up to FAA standards after a long >hiatus. When the SL-30 was repaired and back in the instrument panel I took >off on a flight to Ocala to check it out. I climbed up to 4500 feet and >watched the OBS and listened for the ID code as I entered the 40 mile radius >of the Ocala VOR. Nothing so I kept going on a course straight for the >station. Around 20-25 miles out I started getting activity on the indicator >but the flags were intermittent and the radio could not maintain a lock. >Finally about 15 miles out the indicators stabilized and the flags stayed >off, obviously something is amiss. > >I'm using a Comant CI-159 VOR/ILS antenna. This unit consists of a phenolic >"puck" with a BNC connector cast into it for the coax connection. There are >two fiberglas elements (thin rods about 18 inches long) that screw into the >puck to form a "V" shaped antenna. I have it mounted on the bottom of the >fuselage in the back of the airplane under the horizontal stabilizer. The >BNC sticks through a hole in the belly and appx 25 foot length of RG-58 coax >runs inside the aircraft up to the SL-30 receiver. No gasket was supplied >with the antenna so I just bolted the puck to the aluminum using the two >bolt holes. After the Ocala flight I removed the puck and elements for >closer inspection and checked the connector on the coax cable at the antenna >end. Nothing wrong that I could tell just by looking at the equipment. >There was a bit of engine oil (from the exhaust) on the puck surface facing >the skin. I cleaned it off and made a gasket to go between the puck and the >skin to minimize the oil build up again. I have not flown the airplane >since but I doubt that lack of a gasket was causing the poor reception, >maybe someone here can tell me. The other thing I checked was the >resistance between the center pin and outside barrel of the BNC connector on >the antenna. Resistance was showing basically a dead short (less than 1 >ohm, same reading as touching the meter probes together). I'm not an >antenna designer so I don't know if this is what the reading should be or >not. Aircraft Spruce has the following description for this antenna: " "V" >Dipole VOR/Glide Slope Antenna with detachable elements is similar to the CI >158C-3 with the exception of offering 2-hole mount instead of a 4-hole >mount. This V Dipole encompasses reduced static capability with the use of >P-Stat paint. Integral ferrite balun provides for higher radiation >efficiency." . I don't know if the construction of the antenna would cause >the meter to show such a low resistance, maybe some here could shed some >light on that. > >Any ideas, experiences with poor VOR reception here on the list? Since the >radio has been repaired and tested by the factory I'd say it's not the >radio. I checked the connector at the back of the radio tray and it appears >secure so I'm not sure what else to do. Since VORs are being decommissioned >there is going to be less and less need for VOR reception but if I have to >use victor airways during instrument operations I need to have good >reception at the expected range or I won't be able to comply with ATC >clearances. Thanks for the help > >Dean Psiropoulos >RV-6A N197DM >200+ hours since 2008 > > Matt G Dralle | Matronics | 581 Jeannie Way | Livermore | CA | 94550 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Apr 26, 2014
Matt wrote: > > Are you using "RG-58A" or "RG-58C/U"? "RG-58A" is really lossy. ""RG-58C/U" is > better, but still not that great. I would strongly recommend RG-142 or RV-400 > for that application. I have RG-142 installed in my RV-8 connected to an SL-30 > and to a CI-158C antenna mounted in the top of my vertical stab and I get > outstanding I wonder what the source of that information is. Commercial RG-58A, mil spec RG-58 (MIL-DTL-17 M17/28-RG058) such as Belden 9203, RG-142 and RG400/LMR400 are all rated between 3.3 and 4.9 dB per 100 ft at 100 MHz -- around 1 dB for a practical airplane installation. > > Pull the RG-58 out, get some RG-142 and some high-quality BNC connectors (the crimp-on > kind NOT the screw-on kind) and then see how things work. You may still > have a problem with the NAV receiver on the SL-30, but upgrading your cable > will go a long way in improving your reception in any case. Original RG-58 cable was just fine for decades with receivers far worse than the Garmin. In my experience, connectors are the problem nine times out of ten. Commercial grade crimp connectors from a manufacturer that also supplies military grade connectors (Amp, Amphenol, Kings) crimped with the manufacturer-specified tool checked for the correct crimp dimensions by someone experienced with this process is the key. Original military soldered connectors are also OK but only if the installer is experienced enough to get the dimensions right without melting the dielectric. Quick test, after you've confirmed that the cable has continuity end to end and isn't shorted: grab the cable in one hand and the body of the connector in the other. Using moderate force, can you rotate the connector body with respect to the cable? If so, cut it off and try again, it is not terminated correctly. This isn't the cause of all problems but is usually diagnostic of whether it was crimped right in the first place. ________________________________________________________________________________
Subject: Basic VFR system
Date: May 01, 2014
Hi Guys/Bob I'm thinking now about the wiring for the RV9a, requirements are 'basic' VFR, and looking at Z-11, is not basic enough, so have ventured to B & C for their basic VFR diagram http://www.bandc.biz/pdfs/001510VFRSingleALT.pdf The only thing I see here that I havn't seen on any other (Z-xx) diagram, is the extra ANL from the Battery to Main Bus, between the contacter (items 9 &10) and main bus is a ANL fuse. Can someone expand on the theory for this item where it is, but not generally found. Best regards John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422671#422671 ________________________________________________________________________________
From: "bigdog(at)bentwing.com" <bigdog(at)bentwing.com>
Date: May 01, 2014
I'm used to seeing the big fuse in the B lead to protect against a runaway alternator. But the other one between the battery and main bus seems redundant. The only thing I see it protecting is a direct short of the bus bar. Anything attached to the bus is protected by its own fuse/cb. I'm also interested to know if there's another purpose. BTW, if you want Bob to chime in then post it to the Aeroelectric list. Regards, Greg Young -----Original Message----- From: owner-avionics-list-server(at)matronics.com [mailto:owner-avionics-list-server(at)matronics.com] On Behalf Of JOHN TIPTON Sent: Thursday, May 01, 2014 10:57 AM Subject: Avionics-List: Basic VFR system --> Hi Guys/Bob I'm thinking now about the wiring for the RV9a, requirements are 'basic' VFR, and looking at Z-11, is not basic enough, so have ventured to B & C for their basic VFR diagram http://www.bandc.biz/pdfs/001510VFRSingleALT.pdf The only thing I see here that I havn't seen on any other (Z-xx) diagram, is the extra ANL from the Battery to Main Bus, between the contacter (items 9 &10) and main bus is a ANL fuse. Can someone expand on the theory for this item where it is, but not generally found. Best regards John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422671#422671 ________________________________________________________________________________
Date: May 01, 2014
Subject: Re: Basic VFR system
John,=0A=0AThe purpose of the current limiter is to protect the feeder that goes from the Master relay/solenoid to the main bus.- It does not have a nything to do w/ the alternator in that location.=0A=0AThe drawing does sho w another ANL in the output of the alternator, however it would not be good protection against a runaway alternator. This is because it would require at least 150% overload for several seconds (you would have to look at the c urrent curve in the spec sheet for that ANL for exact numbers of time vs % overload).- =0A=0ABy the time the ANL popped, the buss voltage would have been unacceptably high for too long and very likely cooking electrical com ponents.- The ANL in the B lead is to protect it from ground faults.=0A =0ATo prevent damage from a runaway alternator you should use an Overvoltag e Protection Module which will shut-down an errant alternator in less than a second.=0A=0AIn what part of the country are you located?=0A=0A=0A=0A-Jef f Luckey=0A=0A=0A________________________________=0A From: "bigdog@bentwing .com" =0ATo: "avionics-list(at)matronics.com" =0ASent: Thursday, May 1, 2014 10:48 AM=0ASubject: RE: A vionics-List: Basic VFR system=0A =0A=0A--> Avionics-List message posted by : "bigdog(at)bentwing.com" =0A=0AI'm used to seeing the b ig fuse in the B lead to protect against a runaway alternator. But the othe r one between the battery and main bus seems redundant. The only thing I se e it protecting is a direct short of the bus bar. Anything attached to the bus is protected by its own fuse/cb. I'm also interested to know if there's another purpose. =0A=0ABTW, if you want Bob to chime in then post it to th e Aeroelectric list.=0A=0ARegards,=0AGreg Young=0A=0A=0A-----Original Messa ge-----=0AFrom: owner-avionics-list-server(at)matronics.com [mailto:owner-avio nics-list-server(at)matronics.com] On Behalf Of JOHN TIPTON=0ASent: Thursday, May 01, 2014 10:57 AM=0ATo: avionics-list(at)matronics.com=0ASubject: Avionics TON" =0A--> =0A=0AHi Guys/Bob=0A=0AI'm thinking n ow about the wiring for the RV9a, requirements are 'basic' VFR, and looking at Z-11, is not basic enough, so have ventured to B & C for their basic VF R diagram=0A=0Ahttp://www.bandc.biz/pdfs/001510VFRSingleALT.pdf=0A=0AThe on ly thing I see here that I havn't seen on any other (Z-xx) diagram, is the extra ANL from the Battery to Main Bus, between the contacter (items 9 &10) and main bus is a ANL fuse.=0A=0ACan someone expand on the theory for this item where it is, but not generally found.=0A=0ABest regards=0A=0AJohn=0A =0A=0A=0A=0ARead this topic online here:=0A=0Ahttp://forums.matronics.com/v iewtopic.php?p=422671#422671=0A=0A=0A=0A=0A=0A=0A=0A=0A=0A=0A=0A=0A=0A=0A =============== ________________________________________________________________________________
Subject: Equipping experimental for IFR
Date: May 15, 2014
I"m new to owning a plane and trying to learn. I bought a used experimental plane. The panel includes an MGL Voyager EFIS, Backup airspeed, Backup altimeter, Garmin 430W, Garmin GTX-327, Garmin 240 audio panel, and a Navworx ADS-B. The Voyager has the horizon, slip skid ball, compass, altimeter, airspeed, OAT, clock, timer, oil temp, oil pressure, RPM, CDI, glideslope, autopilot, and more. My question is, what is the required equipment for IFR and what testing has to be done prior to filing and flying? Any insight and guidance is greatly appreciated. Thanks, Curt Read this topic online here: http://forums.matronics.com/viewtopic.php?p=423326#423326 ________________________________________________________________________________
Date: May 15, 2014
Subject: Re: Equipping experimental for IFR
The answer is in your operating limitations. Normally you have to meet the requirements of 91.205(d). You have to have altimeter and static system certified to meet IFR standards. If you have an encoder, it has to meet the correspondence standards to the altimeter. You need two way communication radio and at least 1 navigation method. In most circumstances you will need a Mode A/C or Mode S transponder and it has to be certified. The only nav radio that has to be certified is the GPS. On 5/15/2014 5:26 PM, curts63 wrote: > > I"m new to owning a plane and trying to learn. I bought a used experimental plane. The panel includes an MGL Voyager EFIS, Backup airspeed, Backup altimeter, Garmin 430W, Garmin GTX-327, Garmin 240 audio panel, and a Navworx ADS-B. > > The Voyager has the horizon, slip skid ball, compass, altimeter, airspeed, OAT, clock, timer, oil temp, oil pressure, RPM, CDI, glideslope, autopilot, and more. > > My question is, what is the required equipment for IFR and what testing has to be done prior to filing and flying? > > Any insight and guidance is greatly appreciated. > > Thanks, Curt > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=423326#423326 > > ________________________________________________________________________________
Date: May 16, 2014
Ok, thanks. In the case of the pitot static and transponder, they get tested every 24 months. Is this test different for VFR versus IFR? For the Garmin 430W, I've heard that this requires a ground test and flight test? Is this something that needs to be repeated on a standard interval? Is it required to have a backup instruments to the EFIS ? I know it's the better practice to have those, but are they required in experimental? Curt Read this topic online here: http://forums.matronics.com/viewtopic.php?p=423340#423340 ________________________________________________________________________________
Date: May 16, 2014
5/16/2014 Hello Curt, You wrote: =9C.... trying to learn.=9D I really appreciate it when an EAB (Experimental Amateur Built) aircraft builder or owner comes out with an attitude like that =93 way to go! Some time back I created the attached document to help answer questions like yours. It has been published in Kitplanes magazine. Please let me know if you have any further questions. =98OC=99 Baker 'O C' Baker says "The best investment you can make is the effort to gather and understand information." ================== Subject: Avionics-List: Equipping experimental for IFR From: "curts63" <curt.stein(at)verizon.net> I"m new to owning a plane and trying to learn. I bought a used experimental plane. The panel includes an MGL Voyager EFIS, Backup airspeed, Backup altimeter, Garmin 430W, Garmin GTX-327, Garmin 240 audio panel, and a Navworx ADS-B. The Voyager has the horizon, slip skid ball, compass, altimeter, airspeed, OAT, clock, timer, oil temp, oil pressure, RPM, CDI, glideslope, autopilot, and more. My question is, what is the required equipment for IFR and what testing has to be done prior to filing and flying? Any insight and guidance is greatly appreciated. Thanks, Curt ________________________________________________________________________________
Date: May 16, 2014
Yes, the IFR altimeter/static test involves checking every 1000 ft up to max altitude you want. No on repetition of the 430. See AC 20-138A No backups required for experimental, just Part 23. Good idea to plan what type of backup you want. On 5/16/2014 4:48 AM, curts63 wrote: > > Ok, thanks. In the case of the pitot static and transponder, they get tested every 24 months. Is this test different for VFR versus IFR? > > For the Garmin 430W, I've heard that this requires a ground test and flight test? Is this something that needs to be repeated on a standard interval? > > Is it required to have a backup instruments to the EFIS ? I know it's the better practice to have those, but are they required in experimental? > > Curt > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=423340#423340 > > ________________________________________________________________________________
Date: May 16, 2014
5/16/2014 Hello Curt, You wrote: 1) Does it have to be field tested/certified prior to IFR flight .....? a) Lets take the certified part first. This extract: Fly WAAS Approaches GNS 430W comes with built-in WAAS navigation capabilities. It is approved to fly LPV glideslope approaches without reference to ground-based navaids of any kind. Featuring an advanced 15-channel receiver capable of five position updates per second, GNS 430W meets the FAA's stringent TSO C146a standards for WAAS "sole means" navigation providing vertical and lateral approach guidance into thousands of U.S. airports previously inaccessible in IFR conditions. copied from a Garmin page shows that the 430W is fully compliant with TSO C146a for sole means navigation including precision approaches. No further certification in the field is needed. b) Regarding field testing: There are no provisions in the federal regulatory system for the FAA to field test the avionics installation in your EAB aircraft. One may turn to an FAA approved MRO (Maintenance and Repair Organization) for such field testing, but that organization is obligated to comply with some regulatory provisions established for type certificated aircraft which do not apply to your EAB. In the MRO's misguided attempts to comply with type certificated aircraft criteria in regard to your EAB you can wind up with a real (and expensive) mess on your hands. So my recommendation is that you use an FAA approved MRO for the bench testing and repair of your individual avionics components when required, but do not attempt to have them field test any EAB entire avionics installation. b) .... does it need to be certified on an ongoing interval,... No regulatory recertification for the 430W is required, but there are the issues of navigation data base and software updates: a) Navigation Data Base Updates: This can be an ongoing chore / expense depending upon how you approach it. The ultimate (and most expensive) navigation data base update solution is to have a Jeppesen subscription that provides one an appropriate geographic navigation data base update every 26 days that you must download with your computer onto the navigation data base card for your 430W and then install in the unit. An alternative is to call Jeppesen to order and install a one time navigation data base download when you see the need. b) Software Updates: If you poke around digitally inside your 430W you will discover an amazingly large number of different software programs that control the various aspects of that box. You can write down the identity, including the version, of each of those software programs and carry it off to a nearby qualified Garmin dealer / servicing facility. They can check their Garmin files to see if there are any available updates to those software programs. Those updates will fall into categories such as mandatory (in Garmins opinion) or sort of nice to have. Use your judgment as to whether you want to go to the effort / expense to have any software updates done. Please let me know if you have any further questions. 'OC' ==================================================================================== From: Curt Sent: Friday, May 16, 2014 9:23 AM Subject: RE: Equipping experimental for IFR Owen, Thank you for the equipment list, that helps with whats needed for flight rules. The one outstanding question is with the Garmin 430W. Does it have to be field tested/certified prior to IFR flight and does it need to be certified on an ongoing interval, like the transponder? Sincerely, Curt Stein ==================================================== From: Owen Baker [mailto:bakerocb(at)cox.net] Sent: Friday, May 16, 2014 9:08 AM aeroelectric-list(at)matronics.com Subject: Equipping experimental for IFR 5/16/2014 Hello Curt, You wrote: .... trying to learn. I really appreciate it when an EAB (Experimental Amateur Built) aircraft builder or owner comes out with an attitude like that way to go! Some time back I created the attached document to help answer questions like yours. It has been published in Kitplanes magazine. Please let me know if you have any further questions. OC Baker 'O C' Baker says "The best investment you can make is the effort to gather and understand information." ==================================================================== Subject: Avionics-List: Equipping experimental for IFR From: "curts63" <curt.stein(at)verizon.net> I"m new to owning a plane and trying to learn. I bought a used experimental plane. The panel includes an MGL Voyager EFIS, Backup airspeed, Backup altimeter, Garmin 430W, Garmin GTX-327, Garmin 240 audio panel, and a Navworx ADS-B. The Voyager has the horizon, slip skid ball, compass, altimeter, airspeed, OAT, clock, timer, oil temp, oil pressure, RPM, CDI, glideslope, autopilot, and more. My question is, what is the required equipment for IFR and what testing has to be done prior to filing and flying? Any insight and guidance is greatly appreciated. Thanks, Curt ________________________________________________________________________________
Date: May 16, 2014
5/16/2014 Hello Curt, You wrote: 1) "There are no mandatory tests like you would see in the VOR area where you're required to check the accuracy?" I am aware of no regulatory mandatory requirement to check the GPS accuracy performance of a Garmin 430W prior to filing and flying IFR. You may wish to check into the subject of RAIM (Receiver Autonomous Integrity Monitoring). 2) "So in conclusion, the 430w does not need any kind of test prior to using it in IFR conditions?"** As you imply in 1 above, if you are using the VOR capability of the 430W for IFR navigation then you must comply with 14 CFR 91.171. 3) "You don't need a signed flight manual supplement to go along with the POH?" Here you are treading into the area of trying to super impose regulatory requirements established by the FAA for type certificated aircraft onto the far thinner regulatory arena that EAB aircraft operate in. Where is the regulation that requires a POH for an EAB aircraft? Where is the regulation that says who is authorized to sign the flight manual supplement for an EAB aircraft POH?## 4) "I really appreciate you taking the time to educate me." It is my pleasure, sir. 5) "Thanks again for your assistance." You are welcome any time. 'OC' **PS: I would recommend extensive practice under VFR in VMC conditions with your aircraft's avionics installation before venturing into IFR under IMC conditions. ##PS: I am not saying that a good POH / supplement is not needed for safe flight in EAB aircraft, just that the FAA does not mandate those items by regulations and it is up to the builder / pilot of the EAB aircraft to create what is needed for safe flight for him and his aircraft. ======================================================= From: Curt Sent: Friday, May 16, 2014 3:26 PM Subject: RE: Equipping experimental for IFR Owen, So in conclusion, the 430w does not need any kind of test prior to using it in IFR conditions? There are no mandatory tests like you would see in the VOR area where you're required to check the accuracy? You don't need a signed flight manual supplement to go along with the POH? I do know about the monthly nav data updates from Jeppesen. I did purchase the expensive annual update package for my intended area of flying. Thanks again for your assistance. I really appreciate you taking the time to educate me. Curt ________________________________________________________________________________
Date: May 16, 2014
I strongly recommend following the guidance of AC 20-138A (available for download from FAA) when installing a certified GPS in an OBAM experimental aircraft. Item 22 on pg 37 is Installed performance-ground tests. Ensures there are not interference issues with other installed avionics. Item 23 on pg 39. Installed performance - flight test. Again, suggestions to ensure flight guidance, especially for approaches is as expected. Not regulatory, but highly recommended. The AC also has some guidance on flight manual supplements. Generally not a big deal, unless you plan on having someone other than yourself fly the plane. On 5/16/2014 2:50 PM, Owen Baker wrote: > > 5/16/2014 > > Hello Curt, You wrote: > > 1) "There are no mandatory tests like you would see in the VOR area > where you're required to check the accuracy?" > > I am aware of no regulatory mandatory requirement to check the GPS > accuracy performance of a Garmin 430W prior to filing and flying IFR. > You may wish to check into the subject of RAIM (Receiver Autonomous > Integrity Monitoring). > > 2) "So in conclusion, the 430w does not need any kind of test prior to > using it in IFR conditions?"** > > As you imply in 1 above, if you are using the VOR capability of the > 430W for IFR navigation then you must comply with 14 CFR 91.171. > > 3) "You don't need a signed flight manual supplement to go along with > the POH?" > > Here you are treading into the area of trying to super impose > regulatory requirements established by the FAA for type certificated > aircraft onto the far thinner regulatory arena that EAB aircraft > operate in. Where is the regulation that requires a POH for an EAB > aircraft? Where is the regulation that says who is authorized to sign > the flight manual supplement for an EAB aircraft POH?## > > 4) "I really appreciate you taking the time to educate me." > > It is my pleasure, sir. > > 5) "Thanks again for your assistance." > > You are welcome any time. > > 'OC' > > **PS: I would recommend extensive practice under VFR in VMC conditions > with your aircraft's avionics installation before venturing into IFR > under IMC conditions. > > ##PS: I am not saying that a good POH / supplement is not needed for > safe flight in EAB aircraft, just that the FAA does not mandate those > items by regulations and it is up to the builder / pilot of the EAB > aircraft to create what is needed for safe flight for him and his > aircraft. > > ======================================================= > From: Curt > Sent: Friday, May 16, 2014 3:26 PM > To: 'Owen Baker ' > Subject: RE: Equipping experimental for IFR > > Owen, > So in conclusion, the 430w does not need any kind of test prior to > using it in IFR conditions? There are no mandatory tests like you > would see in the VOR area where you're required to check the accuracy? > You don't need a signed flight manual supplement to go along with the > POH? > > I do know about the monthly nav data updates from Jeppesen. I did > purchase the expensive annual update package for my intended area of > flying. > > Thanks again for your assistance. I really appreciate you taking the > time to educate me. > > Curt > > ________________________________________________________________________________
Date: May 16, 2014
The Garmin 430W install manual has a checkout procedure as well. FWIW, I do know the local avionics shop here has a pilot they use to shoot various approaches in VFR to verify all is well. I don't know that it's required, but it seems only prudent to do so. Tim > On May 16, 2014, at 7:15 PM, Kelly McMullen wrote: > > > I strongly recommend following the guidance of AC 20-138A (available for download from FAA) when installing a certified GPS in an OBAM experimental aircraft. > Item 22 on pg 37 is Installed performance-ground tests. Ensures there are not interference issues with other installed avionics. > Item 23 on pg 39. Installed performance - flight test. Again, suggestions to ensure flight guidance, especially for approaches is as expected. > Not regulatory, but highly recommended. The AC also has some guidance on flight manual supplements. > Generally not a big deal, unless you plan on having someone other than yourself fly the plane. > >> On 5/16/2014 2:50 PM, Owen Baker wrote: >> >> 5/16/2014 >> >> Hello Curt, You wrote: >> >> 1) "There are no mandatory tests like you would see in the VOR area where you're required to check the accuracy?" >> >> I am aware of no regulatory mandatory requirement to check the GPS accuracy performance of a Garmin 430W prior to filing and flying IFR. You may wish to check into the subject of RAIM (Receiver Autonomous Integrity Monitoring). >> >> 2) "So in conclusion, the 430w does not need any kind of test prior to using it in IFR conditions?"** >> >> As you imply in 1 above, if you are using the VOR capability of the 430W for IFR navigation then you must comply with 14 CFR 91.171. >> >> 3) "You don't need a signed flight manual supplement to go along with the POH?" >> >> Here you are treading into the area of trying to super impose regulatory requirements established by the FAA for type certificated aircraft onto the far thinner regulatory arena that EAB aircraft operate in. Where is the regulation that requires a POH for an EAB aircraft? Where is the regulation that says who is authorized to sign the flight manual supplement for an EAB aircraft POH?## >> >> 4) "I really appreciate you taking the time to educate me." >> >> It is my pleasure, sir. >> >> 5) "Thanks again for your assistance." >> >> You are welcome any time. >> >> 'OC' >> >> **PS: I would recommend extensive practice under VFR in VMC conditions with your aircraft's avionics installation before venturing into IFR under IMC conditions. >> >> ##PS: I am not saying that a good POH / supplement is not needed for safe flight in EAB aircraft, just that the FAA does not mandate those items by regulations and it is up to the builder / pilot of the EAB aircraft to create what is needed for safe flight for him and his aircraft. >> >> ======================================================= >> From: Curt >> Sent: Friday, May 16, 2014 3:26 PM >> To: 'Owen Baker ' >> Subject: RE: Equipping experimental for IFR >> >> Owen, >> So in conclusion, the 430w does not need any kind of test prior to using it in IFR conditions? There are no mandatory tests like you would see in the VOR area where you're required to check the accuracy? You don't need a signed flight manual supplement to go along with the POH? >> >> I do know about the monthly nav data updates from Jeppesen. I did purchase the expensive annual update package for my intended area of flying. >> >> Thanks again for your assistance. I really appreciate you taking the time to educate me. >> >> Curt > > > > > ________________________________________________________________________________
Subject: Garmin 430W Software
Date: May 17, 2014
5/17/2014 Hello Bill Bradbury, Start with getting a copy of the 400W Series Pilot Guide & Reference and sitting down in front of an installed 430W. (The trainer version that I have installed on my computer will not allow me to check its installed software.) Using this Guide you can: 1) On page 149 select the AUX Page Group. 2) On page 149 select the Utility Page. 3) On page 158 select the Software Versions Page. 4) On page 164 see a discussion of the Software / Database Versions. I found eight different sets of software and their versions on my 430W: MAIN 2.0, GPS 2.4, COM 4.00, VLOC 2.06, G/S 2.03, IOFPGA 2.2, STAGE 1 2.01, and STAGE 2 2.00. I carried this listing over to our local qualified Garmin dealer / servicer and asked them to tell me if I was up to date. After a fair amount of struggle and searching they told me that: MAIN is required to be updated to 3.30 with an optional update to 5.3. GPS is required to be updated to 3.20 with and optional update to 5.0. Since I am not currently using my 430W for IFR flight purposes I am deferring any software updates until that need arises. I hope that this helps. Any other questions? =98OC=99 Baker 'O C' Baker says "The best investment you can make is the effort to gather and understand information." ============== From: "Bill Bradburry" <bbradburry(at)verizon.net> Subject: RE: AeroElectric-List: Re: Equipping experimental for IFR OC, Where do I find the procedures to "poke around digitally inside your 430W"? I would like to check to see what software is loaded in my unit. Thanks, Bill ________________________________________________________________________________
Date: May 17, 2014
5/17/2014 Hello Curt Stein, You wrote: 1) =9CIn the case of the pitot static and transponder, they get tested every 24 months. Is this test different for VFR versus IFR?=9D The answer to your question is found in 14 CFR Sections 91.411 and 91.413 that require these inspections, and the related Appendices E and F of Part 43. (All available at the FAA web site.) A) 91.411 applies to any operation under IFR in controlled airspace. B) 91.413 is a bit more complicated. Please see that section and its referenced section 91.215 for details. C) It is unfortunate that the term =9Cpitot static and transponder checks=9D has come into common use when describing the tests required by 91.411 and 91.413. A review of those sections and the relevant appendicies of Part 43 shows that no test of the pitot system is required, but that extensive and detailed tests of the static system and transponder are required to include the altimeter viewed by the pilot, and the automatic altitude reporting system which consists of the encoder and the transponder. I guess that we are just stuck with that unfortunate common terminology, but I strongly urge all EAB builders and pilots to become familiar with the actual requirements of the regulations, including the technicians and organizations that are permitted / required to perform the tests involved. 2) =9CIs it required to have a backup instruments to the EFIS ? I know it's the better practice to have those, but are they required in experimental?=9D The regulatory requirements for EAB instruments have been covered in our previous exchange postings and the attached document. =98OC=99 'O C' Baker says "The best investment you can make is the effort to gather and understand information." ================ Subject: Avionics-List: Re: Equipping experimental for IFR From: "curts63" <curt.stein(at)verizon.net> Ok, thanks. In the case of the pitot static and transponder, they get tested every 24 months. Is this test different for VFR versus IFR? For the Garmin 430W, I've heard that this requires a ground test and flight test? Is this something that needs to be repeated on a standard interval? Is it required to have a backup instruments to the EFIS ? I know it's the better practice to have those, but are they required in experimental? Curt ________________________________________________________________________________
Subject: Can Mircoair Transponder be installed in AC with battery
Date: May 19, 2014
I have a Microair Transponder that i'd like to install in a Pietenpol that has a 12 v battery to power a hand held radio, any suggestions or tips would be most useful. Jill Read this topic online here: http://forums.matronics.com/viewtopic.php?p=423461#423461 ________________________________________________________________________________
Subject: Instruments for Sale
Date: May 31, 2014
UMA 1 1/4" Carb Air Temp and probe, used, color range marked for M-14, $75. UMA 1 1/4" Fuel Pressure, used, color range marked for M-14, $75. Electronics International M-1 Manifold Pressure, used, needs plastic hose barb replaced on back of unit. $200. Electronics International FL-2C dual Fuel Level, used, $195. Can Email photos Jeff jdair(at)sbcglobal.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=424124#424124 ________________________________________________________________________________
Date: Jun 04, 2014
Subject: Comm Radio Transmit Problem
The Terra 760D comm radio in my Pazmany is getting harder for ATC to hear o ver time. Last weekend, my home field tower controller couldn't even hear m e when I was only 5 miles away.-=0A=0ASo I formed a plan to find the issu e relating to my comm radio or the antenna. My plan was to remove antenna c oax cable from Terra comm and connect it to my Icom portable radio then go flying. If tower controller could hear me over the Icom without issue, the problem most likely is in the Terra comm.=0A=0AFeeling good about my plan, I went ahead and made the needed connections, including connecting Icom to ship power. I also connected my headset directly to my Icom bypassing inter com. I tested it with ground and got a "loud and clear" reply.-=0A=0AI th en started the engine, listened to ATIS, then called ground to taxi. This t ime the ground controller said he only received a transmit carrier. Thinkin g it maybe noise from ship power, I connected Icom to its battery pack then call ground, but the ground controller still could not hear me. I then tur ned the master switch off, called ground again and received a "loud and cle ar" reply. All of the above were done while the engine was still running. =0A=0AI think the problem maybe in my charging system, most likely my alter nator. But I have no idea what to do next to locate the problem. Any sugges tion?=0A=0AThanks in advance,=0A=0ARobin Hou ________________________________________________________________________________
Subject: Re: Comm Radio Transmit Problem
Date: Jun 04, 2014
Hi Robin, Not sure about your specific system; but, how old is your main battery? My radios had some issues until I replaced the four year old (Concorde) battery. Maybe the alternator could not keep the battery supplied with enough volts and enough amps to run the on board system? Suggestion: swap in a new battery and see if it works. Francis On Jun 4, 2014, at 7:23 PM, Robin Hou wrote: The Terra 760D comm radio in my Pazmany is getting harder for ATC to hear over time. Last weekend, my home field tower controller couldn't even hear me when I was only 5 miles away. So I formed a plan to find the issue relating to my comm radio or the antenna. My plan was to remove antenna coax cable from Terra comm and connect it to my Icom portable radio then go flying. If tower controller could hear me over the Icom without issue, the problem most likely is in the Terra comm. Feeling good about my plan, I went ahead and made the needed connections, including connecting Icom to ship power. I also connected my headset directly to my Icom bypassing intercom. I tested it with ground and got a "loud and clear" reply. I then started the engine, listened to ATIS, then called ground to taxi. This time the ground controller said he only received a transmit carrier. Thinking it maybe noise from ship power, I connected Icom to its battery pack then call ground, but the ground controller still could not hear me. I then turned the master switch off, called ground again and received a "loud and clear" reply. All of the above were done while the engine was still running. I think the problem maybe in my charging system, most likely my alternator. But I have no idea what to do next to locate the problem. Any suggestion? Thanks in advance, Robin Hou ________________________________________________________________________________
Date: Jun 04, 2014
The other side of the coin could be either alternator diode failed or the alternator noise filter (capacitor/condenser) failed. On 6/4/2014 4:49 PM, Francis Herr wrote: > Hi Robin, > > Not sure about your specific system; but, how old is your main battery? > > My radios had some issues until I replaced the four year old > (Concorde) battery. Maybe the alternator could not keep the battery > supplied with enough volts and enough amps to run _the on board _system? > > Suggestion: swap in a new battery and see if it works. > > Francis > > On Jun 4, 2014, at 7:23 PM, Robin Hou wrote: > > The Terra 760D comm radio in my Pazmany is getting harder for ATC to > hear over time. Last weekend, my home field tower controller couldn't > even hear me when I was only 5 miles away. > > So I formed a plan to find the issue relating to my comm radio or the > antenna. My plan was to remove antenna coax cable from Terra comm and > connect it to my Icom portable radio then go flying. If tower > controller could hear me over the Icom without issue, the problem most > likely is in the Terra comm. > > Feeling good about my plan, I went ahead and made the needed > connections, including connecting Icom to ship power. I also connected > my headset directly to my Icom bypassing intercom. I tested it with > ground and got a "loud and clear" reply. > > I then started the engine, listened to ATIS, then called ground to > taxi. This time the ground controller said he only received a transmit > carrier. Thinking it maybe noise from ship power, I connected Icom to > its battery pack then call ground, but the ground controller still > could not hear me. I then turned the master switch off, called ground > again and received a "loud and clear" reply. All of the above were > done while the engine was still running. > > I think the problem maybe in my charging system, most likely my > alternator. But I have no idea what to do next to locate the problem. > Any suggestion? > > Thanks in advance, > > Robin Hou > * > > href="http://www.matronics.com/Navigator?Avionics-List">http://www.matronics.com/Navigator?Avionics-List > href="http://forums.matronics.com/">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/contribution > > * > > * > > > * ________________________________________________________________________________
Subject: Direction Indicator Needs
Date: Jun 10, 2014
6/10/2014 Hello Aeroelectric and Avionics Listers, I know that there are many technically smart people on these lists and I would like to enlist your assistance. Picture this situation: There are hundreds (maybe thousands) of EAB (Experimental Amateur Built) IFR capable aircraft flying around with vacuum driven mechanical spinning mass gyroscopic attitude and directional indicators. A large percentage of these builders and pilots would like to (or need to) replace those indicators with something electronic (other than expensive electrical motor driven mechanical spinning mass gyroscopic) in nature and remove the entire vacuum system from their EAB. Replacing the attitude indicator does not appear to be a big problem in meeting the requirement of 14 CFR 91.205 (d) (8) =9CGyroscopic pitch and bank indicator (artificial horizon)=9D since there are several offerings available. Here are some: http://www.dynonavionics.com/docs/D6_intro.html http://trutrakap.com/product/gemini-pfd/ http://www.grtavionics.com/mini.html http://www.sandia.aero/?q=node/80 But there does not appear to be available an electronic directional indicator that would meet the 14 CFR 91.205 (d) (9) criteria for a =9CGyroscopic directional indicator (directional gyro or equivalent)=9D if one believes that the Regulatory intended direction to be indicated must indeed be the current aircraft magnetic heading and not the current aircraft magnetic course (provided by GPS) over the surface. I feel that somewhere in the electronic magic that MEMS << https://www.memsnet.org/mems/what_is.html >> and AHARS << http://www.microstrain.com/inertial/3DM-GX3-25?gclid=CjgKEAjw2dqcBRC2q- LXjpfxjnQSJAAeYF5LUC4gvWycBVg6DDW_mzzSdTyyF3q0yoQHrT6ij9VbvvD_BwE >> represents there must be a practical, relatively inexpensive means of creating a direction indicator that will meet the intended requirements of 14 CFR 91.205 (d) (9). If so, I (and probably many others) would like to buy one for my EAB airplane. How about it experts (and entrepreneurs) are my desires hopeless and unrealistic? OC 'O C' Baker says "The best investment you can make is the effort to gather and understand information." ________________________________________________________________________________
Date: Jun 10, 2014
6/10/2014 Hello Dj Merrill, Thanks for your quick response. You wrote: ".... an external magnetometer box which gives magnetic heading information to the EFIS." 1) See here for information on what constitutes a magnetometer: http://science.howstuffworks.com/magnetometer-info.htm If the heading that appears on the display, see here: http://www.grtavionics.com/mini.html#Features is simply the indication of a remotely located magnetometer (which is available for the Mini-X and Mini-AP, but not the Mini-B) then I don't think that will meet the intended requirement of 14 CFR 91.205 (d) (9) criteria for a Gyroscopic directional indicator (directional gyro or equivalent). 2) One other big downside of the Mini displays from GRT was GRT's failure to package the units such that they could be readily installed in a standard round nominally 3 inch instrument cut out hole where the old attitude indicator resides. See here: http://www.grtavionics.com/Mini%20Drawing%202.pdf Needing to cut panel metal to install a Mini unit from GRT in an existing panel raises the difficulty of a swap over significantly. Note that Sandia recognized the significance of this issue and packaged the SAI 340 - Quattro accordingly. See here: http://www.sandia.aero/?q=system/files/SAI340BroR2Web.pdf I am still searching. OC =================================================================== From: Dj Merrill Sent: Tuesday, June 10, 2014 3:34 PM Subject: Re: AeroElectric-List: Direction Indicator Needs I am not familiar with the other brands, but the GRT EFIS units come with an external magnetometer box which gives magnetic heading information to the EFIS. Is that what you are asking about? -Dj -- Dj Merrill - N1JOV - VP EAA Chapter 87 Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Glastar Flyer N866RH - http://deej.net/glastar/ ================================================ On 06/10/2014 02:24 PM, Owen Baker wrote: > But there does not appear to be available an electronic directional > indicator that would meet the 14 CFR 91.205 (d) (9) criteria for a > Gyroscopic directional indicator (directional gyro or equivalent) if > one believes that the Regulatory intended direction to be indicated must > indeed be the current aircraft magnetic heading and not the current > aircraft magnetic course (provided by GPS) over the surface. > ________________________________________________________________________________
Date: Jun 10, 2014
Subject: Re: Direction Indicator Needs
...is simply the indication of a remotely located magnetometer (which is =0Aavailable for the Mini-X and Mini-AP, but not the Mini-B) then I don't t hink =0Athat will meet the intended requirement of 14 CFR 91.205 (d) (9) cr iteria =0Afor a =9CGyroscopic directional indicator (directional gyro or equivalent)=9D....=0A=0AI bet the magnetometer-driven heading ind icator does satisfy the requirement.=C2- =0A=0A=0AThe reason the gyroscop ic heading indicator is used is to get rid the lead/lag and dip issues asso ciated with a magnetic compass.=C2- The modern EFIS units & their magneto meter-based displays do not have these issues.=0A=0AThat's probably the rea son for the "..or equivalent.." language in the reg.=0A=0A-Jeff=0A=0A=0A=0A On Tuesday, June 10, 2014 3:26 PM, Owen Baker wrote:=0A et>=0A=0A6/10/2014=0A=0AHello Dj Merrill, Thanks for your quick response. Y ou wrote: "....=C2- an =0Aexternal magnetometer box which gives magnetic heading=0Ainformation to the EFIS."=0A=0A1) See here for information on wha t constitutes a magnetometer:=0A=0Ahttp://science.howstuffworks.com/magneto meter-info.htm=0A=0AIf the heading that appears on the display, see here: =0A=0Ahttp://www.grtavionics.com/mini.html#Features=0A=0Ais simply the indi cation of a remotely located magnetometer (which is =0Aavailable for the Mi ni-X and Mini-AP, but not the Mini-B) then I don't think =0Athat will meet the intended requirement of 14 CFR 91.205 (d) (9) criteria =0Afor a =9CGyroscopic directional indicator (directional gyro or equivalent) =9D.=0A=0A2) One other big downside of the Mini displays from GRT was GRT's failure to =0Apackage the units such that they could be readily installed in a standard =0Around nominally 3 inch instrument cut out hole where the o ld attitude =0Aindicator resides. See here:=0A=0Ahttp://www.grtavionics.com /Mini%20Drawing%202.pdf=0A=0ANeeding to cut panel metal to install a Mini u nit from GRT in an existing =0Apanel raises the difficulty of a swap over s ignificantly. Note that Sandia =0Arecognized the significance of this issue and packaged the SAI 340 - Quattro =0Aaccordingly. See here:=0A=0Ahttp://w ww.sandia.aero/?q=system/files/SAI340BroR2Web.pdf=0A=0AI am still searchi ng.=0A=0AOC=0A=0A=================== =========================0A =0AFrom: Dj Merrill=0ASent: Tuesday, June 10, 2014 3:34 PM=0ATo: aeroelectr ic-list(at)matronics.com ; bakerocb(at)cox.net=0ASubject: Re: AeroElectric-List: Direction Indicator Needs=0A=0AI am not familiar with the other brands, but the GRT EFIS units come=0Awith an external magnetometer box which gives ma gnetic heading=0Ainformation to the EFIS.=0A=0AIs that what you are asking about?=0A=0A-Dj=0A=0A-- =0ADj Merrill - N1JOV - VP EAA Chapter 87=0ASportsm an 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/=0AGlastar Flyer N8 66RH - http://deej.net/glastar/=0A=0A============ =============0A=0AOn 06/10/2014 02:24 PM, Owen Bake r wrote:=0A> But there does not appear to be available an electronic direct ional=0A> indicator that would meet the 14 CFR 91.205 (d) (9) criteria for a=0A> =9CGyroscopic directional indicator (directional gyro or equiva lent)=9D if=0A> one believes that the Regulatory intended direction t o be indicated must=0A> indeed be the current aircraft magnetic heading and not the current=0A> aircraft magnetic course (provided by GPS) over the su - =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- -Matt Dralle, L ======== ________________________________________________________________________________
Subject: Direction Indicator Needs (Summary)
Date: Jun 12, 2014
6/12/2014 Hello Aeroelectric and Avionics Listers, On this subject back on 6/10/2014 I wrote: =9CI know that there are many technically smart people on these lists and I would like to enlist your assistance. Picture this situation: There are hundreds (maybe thousands) of EAB (Experimental Amateur Built) IFR capable aircraft flying around with vacuum driven mechanical spinning mass gyroscopic attitude and directional indicators. A large percentage of these builders and pilots would like to (or need to) replace those indicators with something electronic (other than expensive electrical motor driven mechanical spinning mass gyroscopic) in nature and remove the entire vacuum system from their EAB.=9D and =9CHow about it experts (and entrepreneurs) are my desires hopeless and unrealistic?=9D I want to now post what I have learned / concluded and express my gratitude to the several people who responded: 1) The two best choices for replacing my previous vacuum driven attitude gyro: a) The Sandia SAI 340 Quattro. See here: http://www.sandia.aero/?q=node/80 b) The Dynon EFIS-D6. See here: http://www.dynonavionics.com/docs/D6_intro.html 2) The best choice for replacing my previous vacuum driven directional gyro: The MGL Avionics Velocity Singles Horizon / Compass. See here: http://www.mglavionics.com/html/velocity_singles.html Many thanks again for all that posted help and I would be willing to discuss my choices if desired. OC 'O C' Baker says "The best investment you can make is the effort to gather and understand information." ________________________________________________________________________________
Date: Jun 12, 2014
Subject: Re: Direction Indicator Needs (Summary)
There is also the Trutrak gemini ADI series for a drop in 3" replacement with gps track (not magnetic heading). These are rate sensing gyros so they are a bit different than spinning gyro's. If you hold a pitch attitude and there is an altitude change they function well. However with no corresponding altitude change they gradually return to displaying nose level. Not really a problem but if I decelerate very very slowly I can get the nose quite high while the display still reads a level flight attitude. Accordingly the gemini flashes an airpseed warning when the speed gets low. Similarly if you maintain a turn for a long time, the display will gradually indicate wings level unless it has heading or track information such as from a gps. I would not expect the $500. MGL magnetic sensor and display to be a satisfactory replacement for a directional gyro. I've never flown it but the description says it won't be accurate during any turn unless you upgrade to the substantially more expensive AHRS. I was surprised to learn that in my location at 45*N lattitude, the magnetic vector is tilted about 70 degrees below the horizon which makes attitude info pretty much essential to simulate a gyro compass. While it's as heavy as the removed vacuum pump, I've been running a $25. junk table 28volt T&B for quite some time powered with a $5. dc-dc converter on my 12 volt electrical system. Nothing like the noise from a spinning gyro to remind me that the master is still on. Ken On 12/06/2014 1:21 PM, Owen Baker wrote: > 6/12/2014 > Hello Aeroelectric and Avionics Listers, On this subject back on > 6/10/2014 I wrote: > I know that there are many technically smart people on these lists and > I would like to enlist your assistance. > Picture this situation: There are hundreds (maybe thousands) of EAB > (Experimental Amateur Built) IFR capable aircraft flying around with > vacuum driven mechanical spinning mass gyroscopic attitude and > directional indicators. A large percentage of these builders and pilots > would like to (or need to) replace those indicators with something > electronic (other than expensive electrical motor driven mechanical > spinning mass gyroscopic) in nature and remove the entire vacuum system > from their EAB. > and > How about it experts (and entrepreneurs) are my desires hopeless and > unrealistic? > I want to now post what I have learned / concluded and express my > gratitude to the several people who responded: > 1) The two best choices for replacing my previous vacuum driven attitude > gyro: > a) The Sandia SAI 340 Quattro. See here: > http://www.sandia.aero/?q=node/80 > b) The Dynon EFIS-D6. See here: > http://www.dynonavionics.com/docs/D6_intro.html > 2) The best choice for replacing my previous vacuum driven directional gyro: > The MGL Avionics Velocity Singles Horizon / Compass. See here: > http://www.mglavionics.com/html/velocity_singles.html > Many thanks again for all that posted help and I would be willing to > discuss my choices if desired. > OC > 'O C' Baker says "The best investment you can make is the effort to > gather and understand information." > > * > ________________________________________________________________________________
Date: Jun 13, 2014
6/13/2015 Hello Ken, Thanks for your posting. You wrote: 1) There is also the Trutrak gemini ADI series for a drop in 3" replacement with gps track (not magnetic heading). I do not think that the units that provide only GPS track information, but not stabilized magnetic heading information, meet the intended requirements of 14 CFR 91.205 (d) (9) Gyroscopic direction indicator (directional gyro or equivalent)" for replacing my vacuum driven directional gyro. A case in point: Suppose that ATC tells the pilot to Fly heading XXX. I dont think that flying some very similar track instead will necessarily result in immediate danger or a flight violation (if the ATC controller is not happy with the movement of your aircraft he will most likely just issue you a new heading to fly), but I dont think that flying a track instead of a heading is what a conscientious pilot would want to do. 2) I would not expect the $500. MGL magnetic sensor and display to be a satisfactory replacement for a directional gyro. I've never flown it but the description says it won't be accurate during any turn unless you upgrade to the substantially more expensive AHRS. My comments: a) You write: .... the description says it won't be accurate during any turn unless you upgrade to the substantially more expensive AHRS. I can not find that information on the MGL web site. Can you please help me find it? http://www.mglavionics.com/html/velocity_singles.html b) You write: .... the description says it won't be accurate during any turn unless you upgrade to the substantially more expensive AHRS. I can not find any information on the MGL web site that states or implies that there is any improvement or relationship between a lone SP-6 Sensor, Tilt-compensated magnetic compass and the display of its heading information and the heading information displayed from a lone SP-7 Sensor Attitude indication and turn/bank indication. c) Here is an extract from the MGL web site: "Heading stability issues: You may find short term fluctuations of the heading occurring. These tend to be very small and are typically less than one degree. This could still cause the heading to fluctuate occasionally by a single degree. These fluctuations occur naturally in the earths magnetic field and can also be caused by nearby electrical equipment such as radios, lamps, electronic instrumentation or computers, even the ignition systems of engines. The AV-2 is specifically designed for fast response and thus may show residual fluctuations of the magnetic field that are impossible to filter out without causing delays in the update of the heading information." I can understand that there exists different levels of heading stability and instantaneous accuracy between the magnetic wet compass envisioned by 14 CFR 91.205 (b) (3) for VFR flight and a stabilized magnetic device that would meet 14 CFR 91.205 (d) (9) for IFR flight to perfection so it may come down to which device will meet both the intention of 14 CFR 91.205 (d) (9), but not to perfection, and the individual pilot's needs. d) You write: "I was surprised to learn that in my location at 45*N lattitude, the magnetic vector is tilted about 70 degrees below the horizon which makes attitude info pretty much essential to simulate a gyro compass." Understand. How does one determine whether or not some stabilized magnetic heading indication device indeed has attitude information incorporated at all into providing more accurate and instantaneous magnetic heading indication and to the level of that incorporation between the zero stabilization of a wet compass and perfection? 3) "Nothing like the noise from a spinning gyro to remind me that the master is still on." Any time my master switch is on and the alternator is not putting out the minimum acceptable voltage (such as after alternator failure or engine shut down) the B&C voltage regulator in my system is flashing a light on my instrument panel. See here: http://www.bandc.biz/alternatorcontrollerregulator14vhomebuilt.aspx Different strokes for different folks. Thanks again for your input. OC 'O C' Baker says "The best investment you can make is the effort to gather and understand information." ============================================================= From: Ken <kleh(at)dialupatcost.ca> Subject: Re: Avionics-List: Direction Indicator Needs (Summary) There is also the Trutrak gemini ADI series for a drop in 3" replacement with gps track (not magnetic heading). These are rate sensing gyros so they are a bit different than spinning gyro's. If you hold a pitch attitude and there is an altitude change they function well. However with no corresponding altitude change they gradually return to displaying nose level. Not really a problem but if I decelerate very very slowly I can get the nose quite high while the display still reads a level flight attitude. Accordingly the gemini flashes an airpseed warning when the speed gets low. Similarly if you maintain a turn for a long time, the display will gradually indicate wings level unless it has heading or track information such as from a gps. I would not expect the $500. MGL magnetic sensor and display to be a satisfactory replacement for a directional gyro. I've never flown it but the description says it won't be accurate during any turn unless you upgrade to the substantially more expensive AHRS. I was surprised to learn that in my location at 45*N lattitude, the magnetic vector is tilted about 70 degrees below the horizon which makes attitude info pretty much essential to simulate a gyro compass. While it's as heavy as the removed vacuum pump, I've been running a $25. junk table 28volt T&B for quite some time powered with a $5. dc-dc converter on my 12 volt electrical system. Nothing like the noise from a spinning gyro to remind me that the master is still on. Ken ________________________________________________________________________________
Subject: Re: 91.205 - NOT!
Date: Jun 13, 2014
6/13/2014 Hello Andy, Thanks for your response. You wrote: Why do you think that it (91.205) does? 1) I agree, 91.205 does not normally apply to any aircraft that has a: Special Airworthiness Certificate, Category/Designation: Experimental. 2) Such an aircraft is limited to VFR day only flight. See here: "14 CFR 91.319 Aircraft having experimental certificates: Operating limitations. (d) (2) Operate under VFR, day only, unless otherwise specifically authorized by the Administrator;...." 3) However the entire context of the recent postings regarding the subject Direction Indicator Needs has been for IFR flight by an aircraft that has a: Special Airworthiness Certificate, Category/Designation: Experimental. Purpose: To operate Amateur Built Aircraft. Operating Limitations Dated XX/XX/XXXX Are Part Of This Certificate. Note: The terminology and entries in 1 and 2 above are taken directly from an issued FAA Form 8130-7 (10/82). 4) This below extract copied from the attached document states why 91.205 DOES APPLY for IFR or night flight for an aircraft certificated as in 3 above.(commonly referred to as an EAB (Experimental Amateur Built) aircraft): "The Special Airworthiness Certificate issued for each amateur built experimental aircraft includes specific Operating Limitations. Per FAA Order 8130.2G the Operating Limitations state: After completion of Phase I flight testing, unless appropriately equipped for night and/or instrument flight in accordance with 91.205, this aircraft is to be operated under VFR, day only. The interpretation given this statement is that if the aircraft is appropriately equipped in accordance with 91.205 then the VFR day only limitation no longer applies and the aircraft can be flown at night or under IFR in IMC." 4) If the EAB in question does not contain the above quoted Operating Limitations extract then one must, as you say, look at the Operating Limitations for that specific aircraft to see what does apply. Please let me know if the above information does not clarify this issue. Thanks, OC ====================================================================== From: Dr. Andrew Elliott Sent: Friday, June 13, 2014 8:38 AM Subject: RE: 91.205 - NOT! It does not. In your list, 91.205 is the reference for nearly all requirements. And most clearly, 91.205 does not apply to experimental category aircraft. Why do you think that it does? Andy ================================================================== From: Owen Baker [mailto:bakerocb(at)cox.net] Sent: Friday, June 13, 2014 5:15 AM Subject: 91.205 - NOT! 6/13/2014 Hello Andrew Eliot, Does the attached document help clarify things for you? Thanks, OC 'O C' Baker says "The best investment you can make is the effort to gather and understand information." ======================================================================================== From: "Dr. Andrew Elliott" <a.s.elliott(at)cox.net> Subject: AeroElectric-List: 91.205 - NOT! Just a reminder to note that, as specifically stated in the heading section, 14CFR 91.205 applies to, and only to, "Powered civil aircraft with *standard* category U.S. airworthiness certificates". For the larger number of us who are building/flying experimental category aircraft, the applicable rules appear in your operating limits. The recommendations in 91.205 are good guidelines, but it's your ops limits, and the general requirement to have appropriate equipment to complete the planned flight, that rule here. Andy ------------------------ Andrew S Elliott, CFI ________________________________________________________________________________
Date: Jun 13, 2014
Hi Owen I agree that gps track does not equate to a gyro compass. If you look in the manual http://www.mglavionics.com/AV2.pdf on page 10 you will see the definitions of the 2-D, 3D-A, and 3D-G choices or operating modes. The disadvantages column says "Cannot correctly compensate for tilt during any form of turn due to centrifugal forces acting on the accelerometers" That is for the 3D-A mode which is what you get with the SP6 as far as I can tell. The disadvantage column for the 3D-G (the best mode of operation with a full AHRS) says "Can show very large errors if the horizon information is invalid which could have a number of causes such as exceeding operational limitations of the horizon system." I interpret this to mean that you are back to the 3D-A mode if the attitude info is not available. This is the same results I found in my little experiments with a 3D magnetic sensor. The results were only useable when flying straight and level. I'd expect much better results near the equator of course. Again I have no experience with the MGL products but lacking actual performance reports, I discounted purchasing the stand alone $500. magnetic heading system for these reasons. Ken On 13/06/2014 10:03 AM, Owen Baker wrote: > > 6/13/2015 > > Hello Ken, Thanks for your posting. You wrote: > > 1) There is also the Trutrak gemini ADI series for a drop in 3" > replacement > with gps track (not magnetic heading). > > I do not think that the units that provide only GPS track information, > but not stabilized magnetic heading information, meet the intended > requirements of 14 CFR 91.205 (d) (9) Gyroscopic direction indicator > (directional gyro or equivalent)" for replacing my vacuum driven > directional gyro. > > A case in point: Suppose that ATC tells the pilot to Fly heading XXX. > I dont think that flying some very similar track instead will > necessarily result in immediate danger or a flight violation (if the ATC > controller is not happy with the movement of your aircraft he will most > likely just issue you a new heading to fly), but I dont think that > flying a track instead of a heading is what a conscientious pilot would > want to do. > > 2) I would not expect the $500. MGL magnetic sensor and display to be a > satisfactory replacement for a directional gyro. I've never flown it but > the description says it won't be accurate during any turn unless you > upgrade to the substantially more expensive AHRS. > > My comments: > > a) You write: .... the description says it won't be accurate during any > turn unless you > upgrade to the substantially more expensive AHRS. > > I can not find that information on the MGL web site. Can you please help > me find it? > > http://www.mglavionics.com/html/velocity_singles.html > > b) You write: .... the description says it won't be accurate during any > turn unless you > upgrade to the substantially more expensive AHRS. > > I can not find any information on the MGL web site that states or > implies that there is any improvement or relationship between a lone > SP-6 Sensor, > Tilt-compensated magnetic compass and the display of its heading > information and the heading information displayed from a lone SP-7 Sensor > Attitude indication and turn/bank indication. > > c) Here is an extract from the MGL web site: > > "Heading stability issues: You may find short term fluctuations of the > heading occurring. These tend to be very small and are typically less > than one > degree. This could still cause the heading to fluctuate occasionally by > a single degree. These fluctuations occur naturally > in the earths magnetic field and can also be caused by nearby > electrical equipment such as radios, lamps, electronic > instrumentation or computers, even the ignition systems of engines. The > AV-2 is specifically designed for fast response > and thus may show residual fluctuations of the magnetic field that are > impossible to filter out without causing delays in the > update of the heading information." > > I can understand that there exists different levels of heading stability > and instantaneous accuracy between the magnetic wet compass envisioned > by 14 CFR 91.205 (b) (3) for VFR flight and a stabilized magnetic device > that would meet 14 CFR 91.205 (d) (9) for IFR flight to perfection so it > may come down to which device will meet both the intention of 14 CFR > 91.205 (d) (9), but not to perfection, and the individual pilot's needs. > > d) You write: "I was surprised to learn that in my location at 45*N > lattitude, the magnetic vector is tilted about 70 degrees below the > horizon which makes attitude info pretty much essential to simulate a > gyro compass." > > Understand. How does one determine whether or not some stabilized > magnetic heading indication device indeed has attitude information > incorporated at all into providing more accurate and instantaneous > magnetic heading indication and to the level of that incorporation > between the zero stabilization of a wet compass and perfection? > > 3) "Nothing like the noise from a spinning gyro to remind me that the > master is still on." > > Any time my master switch is on and the alternator is not putting out > the minimum acceptable voltage (such as after alternator failure or > engine shut down) the B&C voltage regulator in my system is flashing a > light on my instrument panel. See here: > > http://www.bandc.biz/alternatorcontrollerregulator14vhomebuilt.aspx > > Different strokes for different folks. Thanks again for your input. > > OC > > ________________________________________________________________________________
Date: Jun 14, 2014
6/14/2014 Hello Ken, Thanks for your response. 1) I had written: =9CI can not find that information on the MGL web site. Can you please help me find it?=9D And that is exactly what you did when you wrote: 2) =9CIf you look in the manual http://www.mglavionics.com/AV2.pdf on page 10 you will see the definitions of the 2-D, 3D-A, and 3D-G choices or operating modes.=9D and =9DI discounted purchasing the stand alone $500. magnetic heading system for these reasons.=9D 3) I agree completely with your analysis and greatly appreciate your input. If I want the degree of stabilization that I interpret that 14 CFR 91.205 (d) (9) =9CGyroscopic direction indicator (directional gyro or equivalent)" intends then I must purchase: a) The AV-2 AHRS Display (VELOCITY Series), b) Both the SP-6 and SP-7 Sensors (Full AHRS), c) And, if I intend to mount the two sensors in the same location, an SP-2 / SP-4 Connector. d) For a total cost of USD $1305 plus shipping. This increased cost over my earlier posted solution of using just the display and the SP-6 sensor causes me to reconsider the potential solutions to my problem, but I can not yet rule out the MGL solution because of the additional expense. (An addict will go to some extreme lengths to feed his addiction.) Thanks again for your inputs and I continue to welcome any inputs that others may have. OC 'O C' Baker says "The best investment you can make is the effort to gather and understand information." == From: Ken <kleh(at)dialupatcost.ca> Subject: Re: Avionics-List: Direction Indicator Needs (Summary) Hi Owen I agree that gps track does not equate to a gyro compass. If you look in the manual http://www.mglavionics.com/AV2.pdf on page 10 you will see the definitions of the 2-D, 3D-A, and 3D-G choices or operating modes. The disadvantages column says "Cannot correctly compensate for tilt during any form of turn due to centrifugal forces acting on the accelerometers" That is for the 3D-A mode which is what you get with the SP6 as far as I can tell. The disadvantage column for the 3D-G (the best mode of operation with a full AHRS) says "Can show very large errors if the horizon information is invalid which could have a number of causes such as exceeding operational limitations of the horizon system." I interpret this to mean that you are back to the 3D-A mode if the attitude info is not available. This is the same results I found in my little experiments with a 3D magnetic sensor. The results were only useable when flying straight and level. I'd expect much better results near the equator of course. Again I have no experience with the MGL products but lacking actual performance reports, I discounted purchasing the stand alone $500. magnetic heading system for these reasons. Ken ________________________________________________________________________________
Date: Jun 15, 2014
6/15/2014 Hello Listers, Andrew Elliott wrote: And most clearly, 91.205 does not apply to experimental category aircraft. Why do you think that it does? Please see the FAA Feb 2, 2009 letter available here: http://www.faa.gov/about/office_org/headquarters_offices/agc/pol_adjudication/agc200/interpretations/data/interps/2009/rourke-1%20-%20(2009)%20legal%20interpretation.pdf This Feb 2, 2009 letter from the FAA explains why I think that 14 CFR 91.205 does apply to all EAB aircraft ever since change 3 to FAA Order 8130.2F** was issued on 4/18/2007. The below copied explicit wording has been required in every EAB Operating Limitations since 4/18/2007: After completion of Phase I flight testing, unless appropriately equipped for night and/or instrument flight in accordance with 91.205, this aircraft is to be operated under VFR, day only. Prior to 4/18/2007, starting at some date that I can not determine, the FAA or DAR airworthiness inspectors were ordered to instruct the EAB aircraft applicant regarding this requirement and to include the requirement in the Operating Limitations, but no explicit wording was provided. OC 'O C' Baker says "The best investment you can make is the effort to gather and understand information." **PS: The current version, FAA Order 8130.2G, dated 4/16/2011, with Change 1, dated 7/02/2012, contains that same wording. ============================================================================= From: Dr. Andrew Elliott Sent: Friday, June 13, 2014 8:38 AMSubject: RE: 91.205 - NOT! It does not. In your list, 91.205 is the reference for nearly all requirements. And most clearly, 91.205 does not apply to experimental category aircraft. Why do you think that it does? Andy ________________________________________________________________________________
Subject: Collision avoidance
Date: Jun 25, 2014
So I'm still thinking about putting my panel together and an avoidance system is on my list. My gps and display are both dynon and so want something which will integrate well with them. I have settled on the TRX-1500, which has been tested with the dynon skyview system. I just wanted to know if anyone on the forum has this set up or use the TRX-1500 or if you had about 1000ish what would you buy? Many thanks Frank Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425432#425432 ________________________________________________________________________________
Date: Jun 25, 2014
Subject: Shielding of audio signal wires, ARINC 129 wires
According to the Garmin GNS430W installation manual, the audio output wires should be shielded, with the shield grounded at one end. In addition, the ARINC 129 should be shielded. I bought a dynon d10a EFIS and pre-wired harness (before I learned how easy it is to wire the connectors). In the pre-wired harness, the ARINC 129 wires are twisted together, but not shielded. Furthermore, I would expect very little crosstalk at audio frequencies, so I wouldn't expect much benefit from shielding the audio wires. Does anyone have experience with these issues? Are shielded wires really necessary? ________________________________________________________________________________
Subject: Re: COZY: Shielding of audio signal wires, ARINC 129 wires
Date: Jun 25, 2014
Yes you should use shielded wire, buy 2 or 3 conductor wire as needed since you never use the shield as audio low AND you never ground the shield at both ends even accidentally as Nick pointed out the need for insulating washers on the headphone jacks if installed on a conductive panel. Typically the shields are grounded at the audio panel. 'Lectric Bob has some great pics on his web site on how to treat the shield grounds, daisy chain them and get them cleanly into D-sub pins. You may also run into different terms for "audio low" among the various mfg's. Also, suggest you convert the shields to wire just out side the D-sub hood since the completed bundle usually grows too big to fit inside the hood on the audio panel end. PSE once had a ppt. on their web site that that gave some good detail on how to do this. I just looked and didn't see it but I believe I have a copy of it if you want. Tim Andres > On Jun 25, 2014, at 6:26 AM, Alan Barnett wrote: > > According to the Garmin GNS430W installation manual, the audio output wires should be shielded, with the shield grounded at one end. In addition, the ARINC 129 should be shielded. > > I bought a dynon d10a EFIS and pre-wired harness (before I learned how easy it is to wire the connectors). In the pre-wired harness, the ARINC 129 wires are twisted together, but not shielded. Furthermore, I would expect very little crosstalk at audio frequencies, so I wouldn't expect much benefit from shielding the audio wires. > > Does anyone have experience with these issues? Are shielded wires really necessary? > > ________________________________________________________________________________
Date: Jun 26, 2014
wires Another perspective... I can't directly address the ARINC issue, but for audio wires in aircraft avionics, the shield is of minimal use, 99.9% of the time. Without diving into physics, the basic idea is this: at the low (600 ohms) load impedance and even lower source impedance in avionics audio circuits, the circuits are almost immune to electrostatic noise, and the typical shield material will do nothing to stop electromagnetic noise. (Some consumer audio circuits have load impedances as high as 50K ohms and are much more susceptible to acting like an antenna to pick up electrostatic noise.) For both the audio and ARINC issues, consider that there are lots of Dynon harnesses flying with Garmin radios. If there were real problems with the lack of shields, I'm pretty sure that Dynon would have revised their harness construction a long time ago. I'd bet that Garmin's bean counters put the 'shield required' phraseology in their manual. If they tell (at no cost to Garmin) all the thousands of installers to run shielded cable, then if there is a single installation where the shield, it has saved them a troubleshooting call. No matter that it cost the consumers thousands (millions?) of dollars in extra installation costs. Kinda like every caller to a company spending 20 minutes wandering through layer after layer of 'automated' call menus, so the company doesn't have to pay one person to answer the phone and route each call correctly in 10 seconds. 'Ground loops' (multiple ground paths) are a different issue; careful attention to grounding techniques will do a LOT to minimize noise pickup in the audio systems. That's the reason that mic/phone jacks should have grounds that are isolated from the airframe, with grounds going only to their parent device. I think that a prowl around Bob's aeroelectric site will reveal confirmation of the info above. Charlie On 6/25/2014 9:18 AM, Tim Andres wrote: > > Yes you should use shielded wire, buy 2 or 3 conductor wire as needed since you never use the shield as audio low AND you never ground the shield at both ends even accidentally as Nick pointed out the need for insulating washers on the headphone jacks if installed on a conductive panel. Typically the shields are grounded at the audio panel. 'Lectric Bob has some great pics on his web site on how to treat the shield grounds, daisy chain them and get them cleanly into D-sub pins. You may also run into different terms for "audio low" among the various mfg's. > Also, suggest you convert the shields to wire just out side the D-sub hood since the completed bundle usually grows too big to fit inside the hood on the audio panel end. > PSE once had a ppt. on their web site that that gave some good detail on how to do this. I just looked and didn't see it but I believe I have a copy of it if you want. > Tim Andres > >> On Jun 25, 2014, at 6:26 AM, Alan Barnett wrote: >> >> According to the Garmin GNS430W installation manual, the audio output wires should be shielded, with the shield grounded at one end. In addition, the ARINC 129 should be shielded. >> >> I bought a dynon d10a EFIS and pre-wired harness (before I learned how easy it is to wire the connectors). In the pre-wired harness, the ARINC 129 wires are twisted together, but not shielded. Furthermore, I would expect very little crosstalk at audio frequencies, so I wouldn't expect much benefit from shielding the audio wires. >> >> Does anyone have experience with these issues? Are shielded wires really necessary? >> >> > ________________________________________________________________________________
Subject: King KX155 weak VOR reception
Date: Jul 13, 2014
Hello all, New member here! I'm having an issue that I wanted to share with some of the more experienced members on here hoping to find a resolution. I have two king KX-155 Nav/Coms one with GS and the other without GS installed in a Glasair III with a single NAV antenna feeding both radios including GS via a multiplexer. The NAV antenna is embedded in the horizontal stabilizer as the Glasair is a composite aircraft. The NAV indicators are KI-209 and a KI-208. Both indicators exhibit erratic needles when turning but only through a portion of the turn (example: sometimes when intercepting a radial the needle will start to move in and nearly be centered but as I roll out expecting to capture the radial the needle suddenly moves three-quarter scale deflection. Also when flying an ILS the GS flag pops in and out of view well down the approach when the GS signal should be strong. All needles are not as stable as I think they should be. I recently had both radios checked out at the local avionics shop and they are performing within specs. The thought now is that I either have an antenna or a feedline issue. The multiplexer currently has one open port that used to service a second glideslope receiver. I've ordered a 50 ohm BNC terminator to cap the open port thinking that I might be getting some reflections/interference that is causing the issue but that has yet to be proven. The aircraft was built in 1990 so all of the coax is original RG58. If the 50 ohm Terminator doesn't solve my problem the next logical step is to replace the RG58 with RG400 but I'm starting to feel like I'm grasping at straws. With no antenna analyzer/distance to fault meter I have no way to verify the condition of the antenna/coax. Questions: 1. Do you think it's likely that the open multiplexer port could be causing my issues? 2. How likely is it that the old RG58 cable could be causing my issues? 3. Should I bite the bullet and buy an antenna analyzer such as the rigexpert AA 600? NOTES: Because the NAV antenna is embedded in the horizontal stabilizer it is physically impossible to access the antenna. The best that I can do will be to replace the RG58 with RG400 but even at that there's will still be approximately 2 feet of the old RG 58 left that is inaccessible the so I will need to install a BNC connector back near the tail to connect the old RG58 (short pigtail that will still be connected to the antenna) with the new RG400. Your ideas, tips & suggestions will be most appreciated! James Phoenix, AZ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426590#426590 ________________________________________________________________________________
Date: Jul 13, 2014
Subject: Manual for Vision microsystems EPI-800 engine monitor
Does anyone have a digital copy of the manual for the Vision microsystems EPI-800 engine monitor? I bought a plane with an EPI-800 installed, but most of the installation manual was lost. I'm particularly interested in the wiring associated with the backlighting system. At present, the backlighting doesn't work at all. It's supposed to sense the voltage on the lighting bus. My plane has no lighting bus, and the builder disconnected the lighting wiring for the VOR head and the transpondes, so I assume he disconnected wiring for the EPI-800 as well. ________________________________________________________________________________
Date: Jul 14, 2014
Subject: Re: King KX155 weak VOR reception
On 7/13/14 11:58 PM, Avionics-List Digest Server wrote: > * > > > 1. Do you think it's likely that the open multiplexer port could be causing my > issues? It's possible, but not too likely to cause the severity of symptoms you describe. You could eliminate the nav splitter by taking it out of the circuit, connecting the antenna lead to one VOR or the GS only, and seeing if the problem remains. > > 2. How likely is it that the old RG58 cable could be causing my issues? Not likely, unless it has gotten mashed somewhere. More likely that a connector or the termination between the antenna and the cable has failed. I have 50 year old RG-58 that's still fine. There's no practical difference between old RG-58 and LMR400 in your application -- there will be more loss in the additional coax connectors than there is difference in attenuation. You could try an old vee dipole bolted on to the underside of the tail as a test. > > 3. Should I bite the bullet and buy an antenna analyzer such as the rigexpert AA > 600? Since you can't get to the antenna, no. An "antenna analyzer" will not tell you whether you have an effective antenna, which may be very different from 50 ohms but still work fine, or an open at the end of the cable. A 50 ohm resistor at the end of tiny coax will look great but won't be a very good antenna. The best comparative test will be with a low power VOR/GS ramp tester. ________________________________________________________________________________
Date: Jul 14, 2014
Re my interest in an antenna analyzer: I've been looking at some of the newer units online (such as the Rigexpert AA-600) and it appears they have the capability of testing the coax for faults (distance to fault) while connected to the antenna. I wasn't thinking of replacing the RG58 with RG400 simply because of the RG400 is a lower loss cable, rather I wanted to use the analyzer to check the RG58 for faults. I would replace the RG58 with RG400 ONLY IF the RG58 is questionable (open, shorted, etc). This BTW may be a real possibility because the existing cable makes some pretty tight bends under the panel. Also using a tester such as the AA-600 would allow me to check the SWR of the antenna. Thoughts? -------- Jim Phoenix, AZ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426666#426666 ________________________________________________________________________________
Date: Jul 15, 2014
On 7/14/14 11:59 PM, Avionics-List Digest Server wrote: > > Re my interest in an antenna analyzer: I've been looking at some of > the newer units online (such as the Rigexpert AA-600) and it appears > they have the capability of testing the coax for faults (distance to > fault) while connected to the antenna. I wasn't thinking of > replacing the RG58 with RG400 simply because of the RG400 is a lower > loss cable, rather I wanted to use the analyzer to check the RG58 > for faults. I would replace the RG58 with RG400 ONLY IF the RG58 > is questionable (open, shorted, etc). This BTW may be a real > possibility because the existing cable makes some pretty tight bends > under the panel. Also using a tester such as the AA-600 would > allow me to check the SWR of the antenna. > > Thoughts? My thoughts are that you really want to buy a new antenna analyzer. Great, but only if you're willing to invest in the time needed to understand what's going on. These things are not magic and can easily produce numbers and graphs that can fool you if you don't know what you're looking at. You do have the ability to make an S-parameter measurement over a range of frequencies, and remote it to the end of a characterized transmission line by the use of time gating so you can actually measure the antenna separately from the coax -- this is a powerful tool. Just prepare for a steep learning curve. I don't know about the AA-600 specifically, I have always done this with traditional lab equipment. I would suggest looking at the VNWA 3E (sdr-kits.net) as an alternative to the AA-600. It's about the same price, uses a PC for display, works up through DME/ATCRBS frequencies, and is supported by lots of hams worldwide who use it for antenna development. Finally, no amount of electrical sleuthing will tell you whether the antenna was an effective receive device as built. It may have a good 50 ohm match which is nearly irrelevant to its performance as a VOR/LOC/GS antenna. ________________________________________________________________________________
Date: Jul 21, 2014
Subject: Re: COZY: Phantom audio return path (Narco 12MKE)
Date: Sep 10, 2014
Subject: WTB - 430W from someone upgrading
Anyone out there planning to upgrade from a GNS430W to a GTN650/750 or IFD440/540? Looking to upgrade to a GNS430W in a less expensive manner. Thanks! ________________________________________________________________________________
Date: Sep 10, 2014
Subject: Re: WTB - 430W from someone upgrading
From: DeWitt Whittington <dee.whittington(at)gmail.com>
Yes, Ralph, My partner and I are considering installing a GNS430W in my Cessna 172M. Checked out the used units at AirVenture this year. Dee DeWitt (Dee) Whittington Richmond, VA 804-677-4849 iPhone 804-358-4333 Home On Wed, Sep 10, 2014 at 9:12 AM, Ralph E. Capen wrote: > recapen(at)earthlink.net> > > > Anyone out there planning to upgrade from a GNS430W to a GTN650/750 or > IFD440/540? > > Looking to upgrade to a GNS430W in a less expensive manner. > > Thanks! > > ________________________________________________________________________________
Date: Sep 10, 2014
Try Tod Ott at Shanandoah Aviation in Va.He did great work for us at remarkable prices. Their email: _toddott(at)att.net_ (mailto:toddott(at)att.net) phone: 540-740-3949 In a message dated 9/10/2014 9:40:42 A.M. Eastern Daylight Time, dee.whittington(at)gmail.com writes: Yes, Ralph, My partner and I are considering installing a GNS430W in my Cessna 172M. Checked out the used units at AirVenture this year. Dee DeWitt (Dee) Whittington Richmond, VA 804-677-4849 iPhone 804-358-4333 Home On Wed, Sep 10, 2014 at 9:12 AM, Ralph E. Capen <_recapen(at)earthlink.net_ (mailto:recapen(at)earthlink.net) > wrote: --> Avionics-List message posted by: "Ralph E. Capen" <_recapen(at)earthlink.net_ (mailto:recapen(at)earthlink.net) > Anyone out there planning to upgrade from a GNS430W to a GTN650/750 or IFD440/540? Looking to upgrade to a GNS430W in a less expensive manner. Thanks! ========== r> nics-List" target="_blank">http://www.matronics.com/Navigator?Avionics-List ========== FORUMS - _blank">http://forums.matronics.com ========== b Site - -Matt Dralle, List Admin. target="_blank">http://www.matronics.com/contribution ========== ________________________________________________________________________________
Subject: Fwd:
Date: Sep 17, 2014
http://micahscustomcycles.com/_sent.photo2.jpeg?typady652488 ________________________________________________________________________________
Subject: Fwd:
Date: Sep 17, 2014
http://alwaysstrikefirst.info/_sent.photo1.jpeg?ofesy681610 ________________________________________________________________________________
Subject: Re:
Date: Sep 17, 2014
http://audicionperu.com/_sent.photo2.jpeg?ebyxuwy423322 ________________________________________________________________________________
Subject: Re:
Date: Sep 18, 2014
Don't know who sent this URL address below, but, it apparently has a nasty virus associated with it. Suggest not opening it. . . . ________________________________________________________ ----- Original Message ----- From: "Roger Galvin" <galvinnspi(at)aol.com> Sent: Wednesday, September 17, 2014 1:21 PM Subject: Avionics-List: Re: > > http://audicionperu.com/_sent.photo2.jpeg?ebyxuwy423322 > > > ________________________________________________________________________________
From: "=?utf-8?B?cmNpdGpoQGFvbC5jb20=?=" <rcitjh(at)aol.com>
Subject: =?utf-8?B?UmU6IEF2aW9uaWNzLUxpc3QgRGlnZXN0OiAwIE1zZ3MgLSAxMC8xOC8xNA==?
Date: Oct 19, 2014
w5I4CgpTZW50IGZyb20gbXkgVmVyaXpvbiA0RyBMVEUgU21hcnRwaG9uZQoKLS0tLS0gUmVwbHkg bWVzc2FnZSAtLS0tLQpGcm9tOiAiQXZpb25pY3MtTGlzdCBEaWdlc3QgU2VydmVyIiA8YXZpb25p Y3MtbGlzdEBtYXRyb25pY3MuY29tPgpUbzogIkF2aW9uaWNzLUxpc3QgRGlnZXN0IExpc3QiIDxh dmlvbmljcy1saXN0LWRpZ2VzdEBtYXRyb25pY3MuY29tPgpTdWJqZWN0OiBBdmlvbmljcy1MaXN0 IERpZ2VzdDogMCBNc2dzIC0gMTAvMTgvMTQKRGF0ZTogU3VuLCBPY3QgMTksIDIwMTQgMjo1OSBB TQoKKgoKPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0K T25saW5lIFZlcnNpb25zIG9mIFRvZGF5J3MgTGlzdCBEaWdlc3QgQXJjaGl2ZQo9PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQoKVG9kYXkncyBjb21wbGV0 ZSBBdmlvbmljcy1MaXN0IERpZ2VzdCBjYW4gYWxzbyBiZSBmb3VuZCBpbiBlaXRoZXIgb2YgdGhl IAp0d28gV2ViIExpbmtzIGxpc3RlZCBiZWxvdy4gIFRoZSAuaHRtbCBmaWxlIGluY2x1ZGVzIHRo ZSBEaWdlc3QgZm9ybWF0dGVkIAppbiBIVE1MIGZvciB2aWV3aW5nIHdpdGggYSB3ZWIgYnJvd3Nl ciBhbmQgZmVhdHVyZXMgSHlwZXJsaW5rZWQgSW5kZXhlcyAKYW5kIE1lc3NhZ2UgTmF2aWdhdGlv bi4gIFRoZSAudHh0IGZpbGUgaW5jbHVkZXMgdGhlIHBsYWluIEFTQ0lJIHZlcnNpb24gCm9mIHRo ZSBBdmlvbmljcy1MaXN0IERpZ2VzdCBhbmQgY2FuIGJlIHZpZXdlZCB3aXRoIGEgZ2VuZXJpYyB0 ZXh0IGVkaXRvciAKc3VjaCBhcyBOb3RlcGFkIG9yIHdpdGggYSB3ZWIgYnJvd3Nlci4gCgpIVE1M IFZlcnNpb246CgpodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vZGlnZXN0L2RpZ2VzdHZpZXcucGhw P1N0eWxlPTgyNzAxJlZpZXc9aHRtbCZDaGFwdGVyPTIwMTQtMTAtMTgmQXJjaGl2ZT1Bdmlvbmlj cwoKVGV4dCBWZXJzaW9uOgoKaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2RpZ2VzdC9kaWdlc3R2 aWV3LnBocD9TdHlsZT04MjcwMSZWaWV3PXR4dCZDaGFwdGVyPTIwMTQtMTAtMTgmQXJjaGl2ZT1B dmlvbmljcwoKCj09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PQpFTWFpbCBWZXJzaW9uIG9mIFRvZGF5J3MgTGlzdCBEaWdlc3QgQXJjaGl2ZQo9PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KCgotLS0tLS0tLS0tLS0tLS0t LS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tCkF2aW9uaWNzLUxpc3Qg RGlnZXN0IEFyY2hpdmUKLS0tClRvdGFsIE1lc3NhZ2VzIFBvc3RlZCBTYXQgMTAvMTgvMTQ6IDAK LS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0t LQoKClRvZGF5J3MgTWVzc2FnZSBJbmRleDoKLS0tLS0tLS0tLS0tLS0tLS0tLS0tLQoKCgoKCgoK Xy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT0KXy09ICAgICAgICAgIC0gVGhlIEF2aW9uaWNzLUxpc3QgRW1haWwgRm9ydW0gLQpfLT0g VXNlIHRoZSBNYXRyb25pY3MgTGlzdCBGZWF0dXJlcyBOYXZpZ2F0b3IgdG8gYnJvd3NlCl8tPSB0 aGUgbWFueSBMaXN0IHV0aWxpdGllcyBzdWNoIGFzIExpc3QgVW4vU3Vic2NyaXB0aW9uLApfLT0g QXJjaGl2ZSBTZWFyY2ggJiBEb3dubG9hZCwgNy1EYXkgQnJvd3NlLCBDaGF0LCBGQVEsCl8tPSBQ aG90b3NoYXJlLCBhbmQgbXVjaCBtdWNoIG1vcmU6Cl8tPQpfLT0gICAtLT4gaHR0cDovL3d3dy5t YXRyb25pY3MuY29tL05hdmlnYXRvcj9Bdmlvbmljcy1MaXN0Cl8tPQpfLT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT0gICAgICAg ICAgICAgICAtIE1BVFJPTklDUyBXRUIgRk9SVU1TIC0KXy09IFNhbWUgZ3JlYXQgY29udGVudCBh bHNvIGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMhCl8tPQpfLT0gICAtLT4gaHR0cDovL2Zv cnVtcy5tYXRyb25pY3MuY29tCl8tPQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT0gICAgICAgICAgICAgLSBMaXN0IENvbnRy aWJ1dGlvbiBXZWIgU2l0ZSAtCl8tPSAgVGhhbmsgeW91IGZvciB5b3VyIGdlbmVyb3VzIHN1cHBv cnQhCl8tPSAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIC1NYXR0IERyYWxsZSwgTGlzdCBB ZG1pbi4KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24KXy09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT0 ________________________________________________________________________________
Date: Nov 01, 2014
Subject: PLEASE READ - Matronics Email List Fund Raiser During November!
Dear Listers, Each November I hold a PBS-like fund raiser to support the continued operation and upgrade of the Email List and Fourm Services at Matronics. It's solely through the Contributions of List members (you) that these Matronics Lists are possible. You have probably noticed that there are no banner ads or pop-up windows on any of the Matronics Lists or related web sites such as the Forums site http://forums.matronics.com , Wiki site http://wiki.matronics.com , or other related pages such as the List Search Engine http://www.matronics.com/search , List Browse http://www.matronics.com/listbrowse , etc. This is because I believe in a List experience that is completely about the sport we all enjoy - namely Airplanes and not about annoying advertisements. During the month of November I will be sending out List messages every couple of days reminding everyone that the Fund Raiser is underway. I ask for your patience and understanding during the Fund Raiser and throughout these regular messages. The Fund Raiser is only financial support mechanism I have to pay all of the bills associated with running these lists. YOUR personal Contribution counts! This year we have a really HUGE and TERRIFIC line up of free gifts to go along with the various Contribution levels. In fact, there are over 30 different gifts to choose from - more than we've ever had before! There's something for everyone, to be sure. Most all of these gifts have been provided by some of the vary members and vendors that you'll find on the Matronics Lists and they have been either donated or provided at substantially discounted rates. This year, these generous members include: Andy Gold of the Builder's Bookstore http://www.buildersbooks.com Bob Nuckolls of the AeroElectric Connection http://www.aeroelectric.com Corbin Glowacki of My Pilot Store http://www.mypilotstore.com George Race of Race Consulting http://www.mrrace.com/ Jon Croke of HomebuiltHELP http://www.homebuilthelp.com These are very generous guys and I encourage you to visit their respective web sites. Each one offers a unique and excellent aviation-related product line. I would like publicly to thank Andy, Bob, Corbin, George, and Jon their generous support of the Lists again this year!! Please make your List Contribution using any one of three secure methods including using a credit card, PayPal, or by personal check. All three methods afford you the opportunity to select one of this year's free gifts with a qualifying Contribution amount!! To make your Contribution, please visit the secure web site: http://www.matronics.com/contribution I would like to thank everyone in advance for their generous financial AND moral support over the years! Thank you! Matt Dralle Matronics Email List Administrator RV-4/RV-6/RV-8 Builder/Rebuilder/Pilot ________________________________________________________________________________
Date: Nov 03, 2014
Subject: Please Make A Contribution To Support Your Lists
Dear Listers, There is no advertising income to support the Matronics Email Lists and Forums. The operation is supported 100% by your personal Contributions during the November Fund Raiser. Please make your Contribution today to support the continued operation and upgrade of these services. You can pick up a really nice gift for making your Contribution too! You may use a Credit Card or Paypal at the Matronics Contribution Site here: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you in advance for your generous support! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 05, 2014
Subject: Coming Soon - The List of Contributors - Please Make A
Contribution Today! Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Please take a moment and assure that your name is on that List of Contributors (LOC)! As a number of members have pointed out over the years, the List seems at least as valuable a building / entertainment tool as your typical magazine subscription! Assure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 07, 2014
Subject: Please Make a Contribution to Support Your Lists...
Dear Listers, Just a reminder that November is the Annual List Fund Raiser. Please make a Contribution today to support the continued operation and upgrade of these great List services!! Pick up a really nice free gift with your qualifying Contribution too! The Contribution Site is fast and easy: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94551-0347 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 10, 2014
Subject: A List Contribution - It's Your Personal Squelch Button...
There is an automatic "squelch button" of sorts for the Fund Raiser messages. Here's how it works... As soon as a List member makes a Contribution through the Matronics Fund Raiser web site, their email address is automatically added to this year's Contributor List and they instantly cease to receive further Fund Raiser messages for the rest of the month! Its just that simple! :-) I really do appreciate each and every one of your individual Contributions to support the Lists. It is your support that enables me to upgrade the hardware and software that are required to run a List Site such as this one. It also goes to pay for the commercial-grade Internet connection and to pay the huge electric bill to keep the computer gear running and the air conditioner powered on. I run all of the Matronics Email List and Forums sites here locally which allows me to control and monitor every aspect of the system for the utmost in reliably and performance. Your personal Contribution matters because, when combined with other Listers such as yourself, it pays the bills to keep this site up and running. I accept exactly ZERO advertising dollars for the Matronics Lists sites. I can't stand the pop-up ads and all other commercials that are so prevalent on the Internet these days and I particularly don't want to have it on my Email List sites. If you appreciate the ad-free, grass-roots, down-home feel of the Matronics Email Lists, please make a Contribution to keep it that way!! http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you! Matt Dralle Matronics Email List Administrator [Note that there are certain circumstances where you might still see a Contribution related message. For example, if someone replies to one of the messages, when using the List Browse feature, or when accessing List message via the Forum. The system keys on the given email address and since most of these are anonymous public access methods, there is no simple way to filter them.] ________________________________________________________________________________
Date: Nov 12, 2014
Subject: Make Sure You're Listed! List of Contributors Published
in December! Dear Listers, The List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 14, 2014
Dear Listers, Just a reminder that November is the Annual List Fund Raiser. Please make a Contribution today to support the continued operation and upgrade of these great List services!! Pick up a really nice free gift with your qualifying Contribution too! The Contribution Site is fast and easy: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: RE: Avionics-List Digest: 0 Msgs - 11/15/14
Date: Nov 16, 2014
SSBkb24ndCB3aGFudCB0aSByZWNpdmUgYW55IG1haWwgZnJvbSB5b3UuIENhbiB5b3UgaGVscCBt ZT8NCg0KLS0tLS1PcmlnaW5hbCBNZXNzYWdlLS0tLS0NCkZyb206ICJBdmlvbmljcy1MaXN0IERp Z2VzdCBTZXJ2ZXIiIDxhdmlvbmljcy1saXN0QG1hdHJvbmljcy5jb20+DQpTZW50OiDigI4xNi7i gI4xMS7igI4yMDE0IDEwOjE3DQpUbzogIkF2aW9uaWNzLUxpc3QgRGlnZXN0IExpc3QiIDxhdmlv bmljcy1saXN0LWRpZ2VzdEBtYXRyb25pY3MuY29tPg0KU3ViamVjdDogQXZpb25pY3MtTGlzdCBE aWdlc3Q6IDAgTXNncyAtIDExLzE1LzE0DQoNCioNCg0KID09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09DQogICBPbmxpbmUgVmVyc2lvbnMgb2YgVG9kYXkn cyBMaXN0IERpZ2VzdCBBcmNoaXZlDQogPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT0NCg0KVG9kYXkncyBjb21wbGV0ZSBBdmlvbmljcy1MaXN0IERpZ2Vz dCBjYW4gYWxzbyBiZSBmb3VuZCBpbiBlaXRoZXIgb2YgdGhlIA0KdHdvIFdlYiBMaW5rcyBsaXN0 ZWQgYmVsb3cuICBUaGUgLmh0bWwgZmlsZSBpbmNsdWRlcyB0aGUgRGlnZXN0IGZvcm1hdHRlZCAN CmluIEhUTUwgZm9yIHZpZXdpbmcgd2l0aCBhIHdlYiBicm93c2VyIGFuZCBmZWF0dXJlcyBIeXBl cmxpbmtlZCBJbmRleGVzIA0KYW5kIE1lc3NhZ2UgTmF2aWdhdGlvbi4gIFRoZSAudHh0IGZpbGUg aW5jbHVkZXMgdGhlIHBsYWluIEFTQ0lJIHZlcnNpb24gDQpvZiB0aGUgQXZpb25pY3MtTGlzdCBE aWdlc3QgYW5kIGNhbiBiZSB2aWV3ZWQgd2l0aCBhIGdlbmVyaWMgdGV4dCBlZGl0b3IgDQpzdWNo IGFzIE5vdGVwYWQgb3Igd2l0aCBhIHdlYiBicm93c2VyLiANCg0KSFRNTCBWZXJzaW9uOg0KDQog ICAgaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2RpZ2VzdC9kaWdlc3R2aWV3LnBocD9TdHlsZT04 MjcwMSZWaWV3PWh0bWwmQ2hhcHRlcj0yMDE0LTExLTE1JkFyY2hpdmU9QXZpb25pY3MNCg0KVGV4 dCBWZXJzaW9uOg0KDQogICAgaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2RpZ2VzdC9kaWdlc3R2 aWV3LnBocD9TdHlsZT04MjcwMSZWaWV3PXR4dCZDaGFwdGVyPTIwMTQtMTEtMTUmQXJjaGl2ZT1B dmlvbmljcw0KDQoNCiA9PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT0NCiAgIEVNYWlsIFZlcnNpb24gb2YgVG9kYXkncyBMaXN0IERpZ2VzdCBBcmNoaXZlDQog PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQoNCiANCiAg ICAgICAgICAgLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0t LS0tLS0tLS0tLQ0KICAgICAgICAgICAgICAgICAgICAgICAgICAgQXZpb25pY3MtTGlzdCBEaWdl c3QgQXJjaGl2ZQ0KICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAtLS0NCiAg ICAgICAgICAgICAgICAgICAgIFRvdGFsIE1lc3NhZ2VzIFBvc3RlZCBTYXQgMTEvMTUvMTQ6IDAN CiAgICAgICAgICAgLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0t LS0tLS0tLS0tLS0tLQ0KIA0KIA0KVG9kYXkncyBNZXNzYWdlIEluZGV4Og0KLS0tLS0tLS0tLS0t LS0tLS0tLS0tLQ0KIA0KIA0KIA0KIA0KIA0KDQoNCl8tPT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQpfLT0NCl8tPSAgICAgICAtLSBQ bGVhc2UgU3VwcG9ydCBZb3VyIExpc3RzIFRoaXMgTW9udGggLS0NCl8tPSAgICAgICAgICAgKEFu ZCBHZXQgU29tZSBBV0VTT01FIEZSRUUgR2lmdHMhKQ0KXy09DQpfLT0gICBOb3ZlbWJlciBpcyB0 aGUgQW5udWFsIExpc3QgRnVuZCBSYWlzZXIuICBDbGljayBvbg0KXy09ICAgdGhlIENvbnRyaWJ1 dGlvbiBsaW5rIGJlbG93IHRvIGZpbmQgb3V0IG1vcmUgYWJvdXQNCl8tPSAgIHRoaXMgeWVhcidz IFRlcnJpZmljIEZyZWUgSW5jZW50aXZlIEdpZnRzIHByb3ZpZGVkDQpfLT0gICBieToNCl8tPSAg IA0KXy09ICAgICAqIEFlcm9FbGVjdHJpYyB3d3cuYWVyb2VsZWN0cmljLmNvbQ0KXy09ICAgICAq IFRoZSBCdWlsZGVyJ3MgQm9va3N0b3JlIHd3dy5idWlsZGVyc2Jvb2tzLmNvbQ0KXy09ICAgICAq IEhvbWVidWlsdEhFTFAgd3d3LmhvbWVidWlsdGhlbHAuY29tDQpfLT0gICAgICogTXkgUGlsb3Qg U3RvcmUgd3d3Lm15cGlsb3RzdG9yZS5jb20NCl8tPSAgICAgKiBSYWNlIENvbnN1bHRpbmcgd3d3 Lm1ycmFjZS5jb20NCl8tPQ0KXy09ICAgTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGU6DQpfLT0N Cl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uDQpfLT0NCl8t PSAgIFRoYW5rIHlvdSBmb3IgeW91ciBnZW5lcm91cyBzdXBwb3J0IQ0KXy09DQpfLT0gICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAtTWF0dCBEcmFsbGUsIExpc3QgQWRtaW4uDQpfLT0NCl8t PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09DQpfLT0gICAgICAgICAgLSBUaGUgQXZpb25pY3MtTGlzdCBFbWFpbCBGb3J1bSAtDQpfLT0g VXNlIHRoZSBNYXRyb25pY3MgTGlzdCBGZWF0dXJlcyBOYXZpZ2F0b3IgdG8gYnJvd3NlDQpfLT0g dGhlIG1hbnkgTGlzdCB1dGlsaXRpZXMgc3VjaCBhcyBMaXN0IFVuL1N1YnNjcmlwdGlvbiwNCl8t PSBBcmNoaXZlIFNlYXJjaCAmIERvd25sb2FkLCA3LURheSBCcm93c2UsIENoYXQsIEZBUSwNCl8t PSBQaG90b3NoYXJlLCBhbmQgbXVjaCBtdWNoIG1vcmU6DQpfLT0NCl8tPSAgIC0tPiBodHRwOi8v d3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP0F2aW9uaWNzLUxpc3QNCl8tPQ0KXy09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCl8t PSAgICAgICAgICAgICAgIC0gTUFUUk9OSUNTIFdFQiBGT1JVTVMgLQ0KXy09IFNhbWUgZ3JlYXQg Y29udGVudCBhbHNvIGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMhDQpfLT0NCl8tPSAgIC0t PiBodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20NCl8tPQ0KXy09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCiANCiANCg0KDQo ________________________________________________________________________________
Date: Nov 17, 2014
Subject: What's Your Contribution Used For?
Dear Listers, You might have wondered at some point, "What's my Contribution used for?" Here are just a few examples of what your direct List support enables... It provides for the expensive, commercial-grade Internet connection used on the List. It pays for the regular system hardware and software upgrades enabling the highest performance possible for List services such as the Archive Search Engine, List Browser, and the Web Forums. It pays for the over 23 years of on-line archive data always available for instant search and access. And, it offsets the many hours spent writing, developing, and maintaining the custom applications that power these List Service such as the List Browse, Search Engine, Forums, and Wiki. But most importantly, your List Contribution enables a forum where you and your peers can communicate freely in an environment that is free from moderation, censorship, advertising, commercialism, SPAM, and computer viruses. It is YOUR CONTRIBUTION that directly enables all these aspects of Matronics List services. Please support it today with your List Contribution. Its one of the best investments you can make in your Sport! List Contribution Web Site: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you for your support! Matt Dralle Email List Administrator ________________________________________________________________________________
Date: Nov 19, 2014
Subject: Value of the List...
If you look forward to checking your List email everyday (and a lot of you have written to say that you do!), then you're probably getting at least $20 or $30 worth of Entertainment from the Lists each year. You'd pay twice that for a subscription to some magazine or even a dinner out. Isn't the List worth at least that much to you? Wouldn't it be great if you could pay that amount and get a well-managed media source free of advertising, SPAM, and viruses? Come to think of it, you do... :-) Won't you please take a minute to make your Contribution today and support these Lists? http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I want to say THANK YOU to everyone that has made a Contribution thus far during this year's List Fund Raiser!! These Lists are made possible exclusively through YOUR generosity!! Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Date: Nov 21, 2014
Subject: [PLEASE READ] Why I Have A Fund Raiser...
Since the beginning, the Matronics List and Forum experience has been free from advertising. I have been approached by fair number of vendors wanting to tap into the large volume of activity across the various lists hosted here, but have always flatly refused. Everywhere you go on the Internet these days, a user is pummeled with flashing banners and videos and ads for crap that they don't want. Yahoo, Google and that elk are not "free". The user must constantly endure their barrage of commercialism thrust into their face at an ever increasing rate. Enough is enough, and the Lists at Matronics choose not to succumb to that. That being said, running a service of this size is not "free". It costs a lot of money to maintain the hardware, pay for the electricity, air conditioning, maintenance contracts, etc, etc. etc. I choose to hold a PBS-like fund raiser each year during the month of November where I simply send out a short email every other day asking the members to make a small contribution to support the operation. That being said, that contribution is completely voluntary and non-compulsory. Many members choose not to contribute and that's fine. However, a very modest percentage of the members do choose to make a contribution and it is that financial support that keeps the Lists running. And that's it. To my way of thinking, it is a much more pleasant way of maintaining the Lists and Forums. The other 11 months of the year, you don't see a single advertisement or request for support. That's refreshing and that is a List and Forum that I want to belong to. I think other people feel the same way. Won't you please take a minute to make your Contribution today and support these Lists? http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Date: Nov 23, 2014
Subject: Just A Few Days Left...
Dear Listers, There are just a few days left for this year's List Fund Raiser. If you've been putting off making a Contribution until the last minute, well, this is it! The last minute, that is... :-) There are some GREAT new gift selections to choose from this year. I personally want at least three of them! There's probably something you can't live without too! And, best of all it supports your Lists! Please remember that there isn't any sort of commercial advertising on the Lists and the *only* means of keeping these Lists running is through your Contributions during this Fund Raiser. Let's make this a "Black Friday" for the Lists! Please make a Contribution today! http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 24, 2014
Subject: Fund Raiser Behind By 20% - Please Contribute Today!
Dear Listers, The percentage of members making a Contribution to support the Lists this year is currently behind last year by at this time by roughly 20%. Please take this opportunity to show your support for the Matronics Lists and Forums! Please remember that it is *solely* your direct Contributions that keep these Lists and Forums up and running and most importantly - AD FREE! If the members don't want to support the Lists directly, then I might have to add advertisements to offset the costs of running the Lists. But I don't want to have to do that. I really like the non-commercial atmosphere here and I think that a lot of the members appreciate that too. Please take a moment to make a Contribution today in support of the continued ad-free operation of all these Lists: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I want to send out a word of appreciation to all of the members that have already made their generous Contribution to support the Lists! Thank you! Matt Dralle Email List and Forums Administrator ________________________________________________________________________________
Date: Nov 25, 2014
Subject: Make Sure You're Listed! List of Contributors Coming Soon!
Dear Listers, There's just a few more days left in this year's List Fund Raiser and that means the List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 26, 2014
Subject: Giving Thanks - Your List Contribution...
Dear Listers, Here in the United States, Thursday is our National day of Thanksgiving. Many of us will be traveling to be with our families and friends to share in generous feasts of plenty and giving thanks for the many blessings that have been bestowed upon us. Many Listers have expressed over the last couple of weeks how thankful they are for the Email Lists and Forums here on the Matronics servers and for all of the assistance and comradery they have experienced being a part of the Lists. One of my favorite comments is when someone writes to me and says something like, "Its the first thing I do in the morning while I'm having my morning coffee!". That's a wonderful tribute to the purpose and function of these Lists. Its always great to hear I'm not the only one that jumps out of bed each morning to check my List email!! Won't you take a minute today and show your appreciation for these Lists and for their continued operation and upgrade? The List Contribution Site is: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you in advance for your kind consideration, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 26, 2014
Date: Nov 28, 2014
Subject: Just Two Days Left! - Still Behind...
Dear Listers, There are just two more days left in this years List Fund Raiser. We are still way behind last year in terms of the number of contributions and total contribution amount. I really want to keep providing these services to the homebuilt community, but it take resources. Since there's no advertising budget or deep pockets to keep the operation a float, its solely your generosity during the Fund Raiser that keeps things going. Please make a Contribution today. If you've been putting off showing your support for the Lists, now is the time to do it! Make a contribution with a Credit Card or though PayPal at that Matronics Contribution web site: http://www.matronics.com/contribution Or, drop a check in the mail: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you in advance for your support! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 29, 2014
Dear Listers, There's just two more days left in this year's List Fund Raiser and that means the List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 30, 2014
Subject: [Please Read] - Last Official Day of List Fund Raiser!
Dear Listers, It's November 30th and that always means a couple of things. Its my birthday again - 51, so don't reminde me! :-) But it also means that it's that last official day of the Matronics Email List Fund Raiser! If you been thinking about picking up one of those really nice incentive gifts now is the time to jump on it!! If you've been meaning to make a Contribution this month but have been putting it off for some reason, NOW is the time! I will be posting the List of Contributors in a few days, so you'll probably want to be known as a person that supported the Lists! I want to thank everyone that has so generously made a Contribution this year in support of our Lists. It is your generosity that keeps this operation running and I don't ever forget it. The List Contribution Web Site is fast and easy. Please support our habit by making your Contribution right now: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you to all in advance! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: Icom a210 display problems
Date: Dec 11, 2014
Less than 30 hours on unit, but out of warranty. Radio works well for a while, then without warning display will dim then disappear. Dial lights are still on and can transmit and receive but nothing showing on display. Have already replaced the ribbon cable.. No problem for 10 hours of flying, then problem started again. Power off and on works sometimes, but most times display does not light up. Even tried turning dimmer function off. Any ideas? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435602#435602 ________________________________________________________________________________
Subject: Re: Icom a210 display problems
Date: Dec 11, 2014
Ship it to Icom with a letter explaining the issue. They are a whole lot better to deal with than Garmin. I had a squelch issue on mine out of warranty they fixed for a reasonable amount. IIRC shipping and repairs including a software update was less than $100 Tim > On Dec 11, 2014, at 12:36 PM, Rebel56 wrote: > > > Less than 30 hours on unit, but out of warranty. Radio works well for a while, then without warning display will dim then disappear. Dial lights are still on and can transmit and receive but nothing showing on display. Have already replaced the ribbon cable.. No problem for 10 hours of flying, then problem started again. Power off and on works sometimes, but most times display does not light up. Even tried turning dimmer function off. > > Any ideas? > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435602#435602 > > > > > > > > > > ________________________________________________________________________________
Date: Dec 11, 2014
The A210 has an EL display and I would start by looking at the voltages supplied to it. The service manual shows IC75, a BD9001F IC supplying 16V and IC2, an NJM2307001 IC supplying 3V. Email me if you'd like me to email you the service manual (a 10MB file). -- Joe RV-8A Independence, OR Rebel56 wrote, On 12/11/2014 12:36: > > Less than 30 hours on unit, but out of warranty. Radio works well for a while, then without warning display will dim then disappear. Dial lights are still on and can transmit and receive but nothing showing on display. Have already replaced the ribbon cable.. No problem for 10 hours of flying, then problem started again. Power off and on works sometimes, but most times display does not light up. Even tried turning dimmer function off. > > Any ideas? ________________________________________________________________________________
Date: Dec 11, 2014
Thanks Joe, but I am not that tech savvy. Best I can do is clean the basic contacts and remove the ribbon cable, but beyond that I would be dangerous. [Shocked] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435618#435618 ________________________________________________________________________________
Date: Dec 11, 2014
Tim Any chance they made the squelch more effective for you? thanks Ken On 11/12/2014 4:36 PM, Tim Andres wrote: > > Ship it to Icom with a letter explaining the issue. They are a whole lot better to deal with than Garmin. I had a squelch issue on mine out of warranty they fixed for a reasonable amount. IIRC shipping and repairs including a software update was less than $100 > Tim > > >> On Dec 11, 2014, at 12:36 PM, Rebel56 wrote: >> >> >> Less than 30 hours on unit, but out of warranty. Radio works well for a while, then without warning display will dim then disappear. Dial lights are still on and can transmit and receive but nothing showing on display. Have already replaced the ribbon cable.. No problem for 10 hours of flying, then problem started again. Power off and on works sometimes, but most times display does not light up. Even tried turning dimmer function off. >> >> Any ideas? >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=435602#435602 >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Dec 11, 2014
Yes, the issue I had was continuous open squelch, they said it was in spec but tightened it up for me. I bought it from a shop in Canada, then when I needed service shipped it to Icom America. That was a mistake evidently, somehow they are two separate entities and could not/would not warrant it. Wasn't too happy about, but still least the charge was reasonable. Seems like it was $35, then shipping both ways. Tim > On Dec 11, 2014, at 6:08 PM, C&K wrote: > > > Tim > Any chance they made the squelch more effective for you? > thanks > Ken > >> On 11/12/2014 4:36 PM, Tim Andres wrote: >> >> Ship it to Icom with a letter explaining the issue. They are a whole lot better to deal with than Garmin. I had a squelch issue on mine out of warranty they fixed for a reasonable amount. IIRC shipping and repairs including a software update was less than $100 >> Tim >> >> >> >>> On Dec 11, 2014, at 12:36 PM, Rebel56 wrote: >>> >>> >>> Less than 30 hours on unit, but out of warranty. Radio works well for a while, then without warning display will dim then disappear. Dial lights are still on and can transmit and receive but nothing showing on display. Have already replaced the ribbon cable.. No problem for 10 hours of flying, then problem started again. Power off and on works sometimes, but most times display does not light up. Even tried turning dimmer function off. >>> >>> Any ideas? >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=435602#435602 > > > > > ________________________________________________________________________________
Date: Dec 24, 2014
Subject: 2014 List of Contributors
Dear Listers, The 2014 Matronics Email List and Forum Fund Raiser officially ended a couple of weeks ago and it's time that I published this year's List of Contributors. It is the people on this list that directly make these Email Lists and Forums possible! Their generous Contributions keep the servers and Internet connection up and running! You can still show your support this year and pick up a great gift at the same time. The Contribution Web Site is fast, easy, and secure: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I also want to thank Andy, Bob, Corbin, George, and Jon for their generous support through the supply of many great gifts this year!! These guys have some excellent products and I encourage you to visit their respective web sites: Andy Gold - The Builder's Bookstore - http://www.buildersbooks.com Bob Nucklolls - AeroElectric - http://www.aeroelectric.com Corbin Glowacki - My Pilot Store - http://www.mypilotstore.com George Race - Race Consulting - http://www.mrrace.com Jon Croke - HomebuiltHELP - http://www.homebuilthelp.com And finally, I'm proud to present The 2014 Fund Raiser List of Contributors: http://www.matronics.com/loc/2014.html Thank you again to everyone that made a Contribution this year!! Matt Dralle Matronics Email List & Forum Administrator ________________________________________________________________________________
Subject: New (Free) Aviation App
Date: Jan 03, 2015
"Airport Courtesy Cars" is a new Google Play/Apple iPhone app that lists over 1100 airports nationwide that have crew/courtesy cars. Make sure you search for it in the phone store, as searching from a tablet won't work. You can load it on an iPad by changing the search function in the app store from iPad apps to iPhone apps.You can dial the listing directly from the app to see if a car is available. If you have a listing that I missed, or a correction, you can email me via the app, or to airportcars101(at)gmail.com. Thanks for looking. Glenn -------- Glenn Brasch RV-9A Flying 1952 Piper Tri-Pacer Medevac Helicopter Driver Tucson, Arizona Owner, www.RVairspace.com and "Airport Courtesy Cars" Smart Phone App www.RVairspace.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=436565#436565 Attachments: http://forums.matronics.com//files/appcoverpage_173.png ________________________________________________________________________________
Date: Jan 03, 2015
Subject: Re: New (Free) Aviation App
Anything for us in the android world? On 1/3/2015 1:48 PM, gbrasch wrote: > > "Airport Courtesy Cars" is a new Google Play/Apple iPhone app that lists over 1100 airports nationwide that have crew/courtesy cars. Make sure you search for it in the phone store, as searching from a tablet won't work. You can load it on an iPad by changing the search function in the app store from iPad apps to iPhone apps.You can dial the listing directly from the app to see if a car is available. If you have a listing that I missed, or a correction, you can email me via the app, or to airportcars101(at)gmail.com. Thanks for looking. Glenn > > -------- > Glenn Brasch > RV-9A Flying > 1952 Piper Tri-Pacer > Medevac Helicopter Driver > Tucson, Arizona > Owner, www.RVairspace.com and "Airport Courtesy Cars" Smart Phone App > www.RVairspace.com > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=436565#436565 > > > Attachments: > > http://forums.matronics.com//files/appcoverpage_173.png > > ________________________________________________________________________________
Date: Jan 03, 2015
Charles, I may be wrong but I believe that Google Play is the same as Android. Sacha -----Original Message----- From: owner-avionics-list-server(at)matronics.com [mailto:owner-avionics-list-server(at)matronics.com] On Behalf Of Charlie England Sent: Saturday, 03 January, 2015 16:43 Subject: Re: Avionics-List: New (Free) Aviation App --> Anything for us in the android world? On 1/3/2015 1:48 PM, gbrasch wrote: > > "Airport Courtesy Cars" is a new Google Play/Apple iPhone app that ________________________________________________________________________________
Date: Jan 03, 2015
uuccio(at)gmail.com wrote: > Charles, > I may be wrong but I believe that Google Play is the same as Android. > Sacha > > -- It is, Google Play is Android devices. -------- Glenn Brasch RV-9A Flying 1952 Piper Tri-Pacer Medevac Helicopter Pilot (Ret) Tucson, Arizona Owner, www.RVairspace.com and "Airport Courtesy Cars" Smart Phone App www.RVairspace.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=436598#436598 ________________________________________________________________________________
Date: Jan 04, 2015
On 1/3/2015 9:49 PM, gbrasch wrote: > > > uuccio(at)gmail.com wrote: >> Charles, >> I may be wrong but I believe that Google Play is the same as Android. >> Sacha >> >> -- > > It is, Google Play is Android devices. > > -------- > Glenn Brasch > RV-9A Flying > 1952 Piper Tri-Pacer > Medevac Helicopter Pilot (Ret) > Tucson, Arizona > Owner, www.RVairspace.com and "Airport Courtesy Cars" Smart Phone App > www.RVairspace.com Duh... All I saw were the references to iphone, ipad, app store. Totally missed the 'Google Play' reference in the 1st line. Thanks, Charlie ________________________________________________________________________________
Date: Jan 04, 2015
>> It is, Google Play is Android devices. >> >> -------- >> Glenn Brasch >> RV-9A Flying >> 1952 Piper Tri-Pacer >> Medevac Helicopter Pilot (Ret) >> Tucson, Arizona >> Owner, www.RVairspace.com and "Airport Courtesy Cars" Smart >> Phone App >> www.RVairspace.com > > Duh... > > All I saw were the references to iphone, ipad, app store. Totally > missed the 'Google Play' reference in the 1st line. > > Thanks, > > Charlie So, next question: Why does an app that simply lists which airports have courtesy cars, need access to everything in my phone? Why do you need my identity, my schedule, my contacts, my phone, my pictures, my location, my camera, and my device ID/call info? Or is it just that you *want* all that info? Not trying to look a gift horse in the mouth, but I would like to have some confidence that it isn't the Trojan version. ________________________________________________________________________________
Date: Jan 04, 2015
Charlie, where are you seeing this? I installed the app and used it, and under the privacy settings on my iPhone, I went into photos, contacts, calendar, and others, and I don't see that it has access to any of that. Tim > On Jan 4, 2015, at 7:02 PM, Charlie England wrote: > > > >>> It is, Google Play is Android devices. >>> >>> -------- >>> Glenn Brasch >>> RV-9A Flying >>> 1952 Piper Tri-Pacer >>> Medevac Helicopter Pilot (Ret) >>> Tucson, Arizona >>> Owner, www.RVairspace.com and "Airport Courtesy Cars" Smart Phone App >>> www.RVairspace.com >> >> Duh... >> >> All I saw were the references to iphone, ipad, app store. Totally missed the 'Google Play' reference in the 1st line. >> >> Thanks, >> >> Charlie > So, next question: > Why does an app that simply lists which airports have courtesy cars, need access to everything in my phone? Why do you need my identity, my schedule, my contacts, my phone, my pictures, my location, my camera, and my device ID/call info? > > Or is it just that you *want* all that info? > > Not trying to look a gift horse in the mouth, but I would like to have some confidence that it isn't the Trojan version. > > > > ________________________________________________________________________________
Date: Jan 04, 2015
In Android, the Google Play Store shows you everything that the app can access before you execute installation. Apparently the little i doesn't protect its users as well as it pretends. Charlie On 1/4/2015 7:21 PM, Tim Olson wrote: > > Charlie, where are you seeing this? I installed the app and used it, and under the privacy settings on my iPhone, I went into photos, contacts, calendar, and others, and I don't see that it has access to any of that. > Tim > > >> On Jan 4, 2015, at 7:02 PM, Charlie England wrote: >> >> >> >>>> It is, Google Play is Android devices. >>>> >>>> -------- >>>> Glenn Brasch >>>> RV-9A Flying >>>> 1952 Piper Tri-Pacer >>>> Medevac Helicopter Pilot (Ret) >>>> Tucson, Arizona >>>> Owner, www.RVairspace.com and "Airport Courtesy Cars" Smart Phone App >>>> www.RVairspace.com >>> Duh... >>> >>> All I saw were the references to iphone, ipad, app store. Totally missed the 'Google Play' reference in the 1st line. >>> >>> Thanks, >>> >>> Charlie >> So, next question: >> Why does an app that simply lists which airports have courtesy cars, need access to everything in my phone? Why do you need my identity, my schedule, my contacts, my phone, my pictures, my location, my camera, and my device ID/call info? >> >> Or is it just that you *want* all that info? >> >> Not trying to look a gift horse in the mouth, but I would like to have some confidence that it isn't the Trojan version. >> >> >> >> > > ________________________________________________________________________________
Date: Jan 05, 2015
Subject: Question about the Z-19 Electrical Schematic
Hi Bob, I have mostly completed wiring up my Titan T-51 Mustang using your schematic Z-19. "Dual Battery, Single Alternator, Electronically Controlled Fuel Injection Engine". I have a question regarding the fuses leading from the Main and the Engine Battery buses to the Diode bridge for the fuel pumps. My pumps require a 20A Circuit Protection. If I place a 20A Circuit Breaker on both of the buses as shown in the drawings, I have 20A protection if I am using only one battery path. In normal operation however, I will have the dual pathway activated and as far as I can tell this means that the fuel pump would need to pull over 40A before the circuit breakers would trip? If I address this situation by using two 10A Circuit breakers and then one of the batteries drops out, I would have a situation where the pump could trip the circuit breaker at 10A which is well before the specified limit. I expect that I am just reading the schematic wrong or my DC theory is off. Can you help me out please? Steve ________________________________________________________________________________
Date: Jan 04, 2015
I think you're wrong. Any app that gets access on iPhone ASKS for access. Then it shows up in the privacy settings. If you want to revoke it, after you opted in, because all privacy breaking features are opt-in only, then it shows up in the list. Sounds to me more like its the Android side that may have the issues with privacy settings and that app. Tim > On Jan 4, 2015, at 8:50 PM, Charlie England wrote: > > > In Android, the Google Play Store shows you everything that the app can access before you execute installation. Apparently the little i doesn't protect its users as well as it pretends. > > Charlie > >> On 1/4/2015 7:21 PM, Tim Olson wrote: >> >> Charlie, where are you seeing this? I installed the app and used it, and under the privacy settings on my iPhone, I went into photos, contacts, calendar, and others, and I don't see that it has access to any of that. >> Tim >> >> >> >>> On Jan 4, 2015, at 7:02 PM, Charlie England wrote: >>> >>> >>> >>>>> It is, Google Play is Android devices. >>>>> >>>>> -------- >>>>> Glenn Brasch >>>>> RV-9A Flying >>>>> 1952 Piper Tri-Pacer >>>>> Medevac Helicopter Pilot (Ret) >>>>> Tucson, Arizona >>>>> Owner, www.RVairspace.com and "Airport Courtesy Cars" Smart Phone App >>>>> www.RVairspace.com >>>> Duh... >>>> >>>> All I saw were the references to iphone, ipad, app store. Totally missed the 'Google Play' reference in the 1st line. >>>> >>>> Thanks, >>>> >>>> Charlie >>> So, next question: >>> Why does an app that simply lists which airports have courtesy cars, need access to everything in my phone? Why do you need my identity, my schedule, my contacts, my phone, my pictures, my location, my camera, and my device ID/call info? >>> >>> Or is it just that you *want* all that info? >>> >>> Not trying to look a gift horse in the mouth, but I would like to have some confidence that it isn't the Trojan version. >>> >>> >>> >>> >> >> >> >> > > > > > ________________________________________________________________________________
Date: Jan 05, 2015
Hmmm... you may be right; I don't have an i device right now to check it on. But I do know that many android apps *don't* require access to areas of the phone that they don't need. Might have been a simple programming oversight when the app was written, but there's no valid reason for this type of app to need access to the entire phone just to display a more or less fixed list that, I assume, exists in the cloud. Speaking of which, does the app actually download the list to the phone so you can see it offline, or do you need a wifi/cell connection to see it? Thanks, Charlie On Sun, Jan 4, 2015 at 9:46 PM, Tim Olson wrote: > > I think you're wrong. Any app that gets access on iPhone ASKS for > access. Then it shows up in the privacy settings. If you want to revoke > it, after you opted in, because all privacy breaking features are opt-in > only, then it shows up in the list. Sounds to me more like its the Android > side that may have the issues with privacy settings and that app. > Tim > > > > On Jan 4, 2015, at 8:50 PM, Charlie England > wrote: > > > ceengland7(at)gmail.com> > > > > In Android, the Google Play Store shows you everything that the app can > access before you execute installation. Apparently the little i doesn't > protect its users as well as it pretends. > > > > Charlie > > > >> On 1/4/2015 7:21 PM, Tim Olson wrote: > >> > >> Charlie, where are you seeing this? I installed the app and used it, > and under the privacy settings on my iPhone, I went into photos, contacts, > calendar, and others, and I don't see that it has access to any of that. > >> Tim > >> > >> > >> > >>> On Jan 4, 2015, at 7:02 PM, Charlie England > wrote: > >>> > ceengland7(at)gmail.com> > >>> > >>> > >>>>> It is, Google Play is Android devices. > >>>>> > >>>>> -------- > >>>>> Glenn Brasch > >>>>> RV-9A Flying > >>>>> 1952 Piper Tri-Pacer > >>>>> Medevac Helicopter Pilot (Ret) > >>>>> Tucson, Arizona > >>>>> Owner, www.RVairspace.com and "Airport Courtesy Cars" > Smart Phone App > >>>>> www.RVairspace.com > >>>> Duh... > >>>> > >>>> All I saw were the references to iphone, ipad, app store. Totally > missed the 'Google Play' reference in the 1st line. > >>>> > >>>> Thanks, > >>>> > >>>> Charlie > >>> So, next question: > >>> Why does an app that simply lists which airports have courtesy cars, > need access to everything in my phone? Why do you need my identity, my > schedule, my contacts, my phone, my pictures, my location, my camera, and > my device ID/call info? > >>> > >>> Or is it just that you *want* all that info? > >>> > >>> Not trying to look a gift horse in the mouth, but I would like to have > some confidence that it isn't the Trojan version. > >>> > >>> > >>> > >>> > >> > >> > >> > >> > > > > > > > > > > > > ________________________________________________________________________________
Date: Jan 05, 2015
I just launched it with no wifi or LTE/Cellular Data and the app does load but the map page doesn't come up, so the map function doesn't appear to cache anything. But, it still lets you go under states and see a list of airports and cars. So it may be much less convenient without a connection, but it appears to still be useable. (This is the iphone version) Tim On 1/5/2015 7:46 AM, Charlie England wrote: > Hmmm... you may be right; I don't have an i device right now to check it > on. But I do know that many android apps *don't* require access to areas > of the phone that they don't need. Might have been a simple programming > oversight when the app was written, but there's no valid reason for this > type of app to need access to the entire phone just to display a more or > less fixed list that, I assume, exists in the cloud. Speaking of which, > does the app actually download the list to the phone so you can see it > offline, or do you need a wifi/cell connection to see it? > > Thanks, > > Charlie ________________________________________________________________________________
Date: Jan 15, 2015
Subject: Re: Avionics-List Digest: 0 Msgs - 01/14/15
From: "contato (at)kraussaero.com.br" <contato(at)kraussaero.com.br>
unsubscribe. Tks. 2015-01-15 5:59 GMT-02:00 Avionics-List Digest Server < avionics-list(at)matronics.com>: > * > > ======================== > Online Versions of Today's List Digest Archive > ======================== > > Today's complete Avionics-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the Avionics-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html& Chapter 15-01-14&Archive=Avionics > > Text Version: > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&C hapter 15-01-14&Archive=Avionics > > > ======================== ======================= > EMail Version of Today's List Digest Archive > ======================== ======================= > > > ---------------------------------------------------------- > Avionics-List Digest Archive > --- > Total Messages Posted Wed 01/14/15: 0 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > =========== =========== =========== =========== > > -- Serrano, Roberto Brand=C3=A3o, M.Sc. Kra=C3=BCss Aeron=C3=A1utica Ind. e Com. de Aeronaves Ltda. www.kraussaero.com.br www.facebook.com/KraussAeronautica contato(at)kraussaero.com.br krauss(at)kraussaero.com.br Tel. Fixo Oficina: +55 (0xx) 35 4104 0434 Tel. Fixo F=C3=A1brica: + 55(0xx) 35 4101 2952 Cel. 1: +55 (0xx) 35 9166 2954 TIM Cel. 2: +55 (0xx) 35 8838 5487 VIVO ________________________________________________________________________________
Date: Jan 20, 2015
Subject: Delta-Pop ADS-B antenna placement
Having purchased the NavWorx ADS600B and Delta-Pop antenna, I'm trying to figure out where to install the antenna.... Since the Delta-Pop is a blade-type antenna, it will need to be mounted along the fuselage direction of flight axis. There are a couple of places where bulkheads mount to the bottom skin and are aligned correctly. I'm thinking of taking advantage of one of these bulkheads instead of mounting a doubler plate to the underside. Thoughts please? Thanks, Ralph RV6A N822AR @ N06 "Patience" 240 hrs.... ________________________________________________________________________________
From: "bigdog(at)bentwing.com" <bigdog(at)bentwing.com>
Date: Jan 20, 2015
That should work fine. The one behind the baggage bulkhead is off-center a bit if that's important. I'm getting ready to mount the NavWorx UAT and GPS antennas on my Navion and both will need to be off the centerline due to skin lap joints. If you don't have an autopilot pitch servo already make sure you leave mount it far enough aft to leave room for one near the bellcrank. You could also put it under the baggage pushrod cover. You'd probably need to offset it for the cable to clear the pushrod. I don't remember if the flanges go inboard or outboard so you might need the doubler unless the other baggage floor panels are removable. That's a shorter cable run and one less bulkhead to penetrate. Regards, Greg Young -----Original Message----- From: owner-avionics-list-server(at)matronics.com [mailto:owner-avionics-list-server(at)matronics.com] On Behalf Of Ralph E. Capen Sent: Tuesday, January 20, 2015 10:44 AM Subject: Avionics-List: Delta-Pop ADS-B antenna placement --> Having purchased the NavWorx ADS600B and Delta-Pop antenna, I'm trying to figure out where to install the antenna.... Since the Delta-Pop is a blade-type antenna, it will need to be mounted along the fuselage direction of flight axis. There are a couple of places where bulkheads mount to the bottom skin and are aligned correctly. I'm thinking of taking advantage of one of these bulkheads instead of mounting a doubler plate to the underside. Thoughts please? Thanks, Ralph RV6A N822AR @ N06 "Patience" 240 hrs.... ________________________________________________________________________________
Date: Jan 20, 2015
Subject: Re: Delta-Pop ADS-B antenna placement
On 01/20/2015 12:37 PM, bigdog(at)bentwing.com wrote: > > That should work fine. The one behind the baggage bulkhead is off-center a bit if that's important. I'm getting ready to mount the NavWorx UAT and GPS antennas on my Navion and both will need to be off the centerline due to skin lap joints. If you don't have an autopilot pitch servo already make sure you leave mount it far enough aft to leave room for one near the bellcrank. > > You could also put it under the baggage pushrod cover. You'd probably need to offset it for the cable to clear the pushrod. I don't remember if the flanges go inboard or outboard so you might need the doubler unless the other baggage floor panels are removable. That's a shorter cable run and one less bulkhead to penetrate. > > Regards, > Greg Young > > -----Original Message----- > Sent: Tuesday, January 20, 2015 10:44 AM > To: rv-list; avionics-list(at)matronics.com > Subject: Avionics-List: Delta-Pop ADS-B antenna placement > > --> > > Having purchased the NavWorx ADS600B and Delta-Pop antenna, I'm trying to figure out where to install the antenna.... > > Since the Delta-Pop is a blade-type antenna, it will need to be mounted along the fuselage direction of flight axis. There are a couple of places where bulkheads mount to the bottom skin and are aligned correctly. I'm thinking of taking advantage of one of these bulkheads instead of mounting a doubler plate to the underside. > > Thoughts please? > > Thanks, > Ralph > RV6A N822AR @ N06 "Patience" 240 hrs.... Hmmm... ADS-B is telling others where you are. ADS-B OUT and ADS-B IN are supposed to be transmitted and read by aircraft for collision avoidance.. I once had the job of converting electronics in a couple of army Cessna 337's - the front and rear engined beast. There were being returned from Vietnam and turned over to the FBI for use at home. The equipment in them was military including things like TACAN and, of course they used transponders in mode B, the secret identification friend or foe. All of the interesting stuff had been removed. But installing the new transponder was a problem. I couldn't find the L-band antenna that I knew was there. A friend found a funny antenna on top of the cabin which turned out to be what I was looking for. Why on top ?? Well, thinking about it the 337's were low flying beasts that were spotting for the F4's and B52's above and that's what the transponders were for. Now we have ADS-B and not only the ground based radar sets will be looking. It will likely become common for ADS-B IN, in larger, faster, and higher flying airplanes, to depend on reading your ADS-OUT information in a way that can be independent of ground facilities. How long will it be before the instructions get changed about antenna locations? Will we need two of them? ________________________________________________________________________________
Date: Feb 04, 2015
Subject: Navworx ADS600b and SL70
Anyone out there using this configuration? I am getting ready for installation in my RV6A - already have the gear The navworx manual indicates it is a valid combination - but they reference an "extended mode" or "remote mode" that needs to be programmed in the SL70. I have the SL70 manuals (install and user) and can find no reference to programming either of these functions. What say ye oh "been there, done that" t-shirt wearers? Thanks, Ralph ________________________________________________________________________________
Subject: RE: RV-List: Navworx ADS600b and SL70
Date: Feb 04, 2015
I'm in the process of installing that config in my Navion. I'm tying into my SL-70, 430W and MX-20. I hope to pull the harness this weekend and complete the physical part of the installation. Then comes the panel diving to hook it up. I don't recall a reference to those modes but the SL-70 came in both panel mount and remote mount versions. I'll have to check the manual to see if that's what it means. I also plan to put the NavWorx in my RV which also has an SL-70 and 430w but I want to get it flying first. I'm seeing light at the end of the tunnel and have decreed "no more changes". Regards, Greg Young -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ralph E. Capen Sent: Wednesday, February 04, 2015 3:54 PM Subject: RV-List: Navworx ADS600b and SL70 --> RV-List message posted by: "Ralph E. Capen" Anyone out there using this configuration? I am getting ready for installation in my RV6A - already have the gear The navworx manual indicates it is a valid combination - but they reference an "extended mode" or "remote mode" that needs to be programmed in the SL70. I have the SL70 manuals (install and user) and can find no reference to programming either of these functions. What say ye oh "been there, done that" t-shirt wearers? Thanks, Ralph ________________________________________________________________________________
Date: Feb 05, 2015
Cross-posted to make sure everyone can see responses..... I was initially asking them about the differences between connecting pins 3 and 5 of the SL70 to pins 32 and 33 of the ADS600B for control versus connecting pins 3 and 5 of the SL70 to pins 6 and 7 of the ADS600B for altitude data. Their initial response indicated that I only need 3 and 5 to 32 and 33 as that connection will pass control and data messages. They followed up with indicating extended mode or remote mode were also required - I haven't been able to get a direct response to that question. I sent them pdf's of the SL70 install and user guides - my Navworx manual is rev 33 (guessing from the part number) - it doesn't have any references to remote mode for the SL70...but it does reference a remote mode for the GNS480 and GTX330 units. There is a remote ident supress feature common to the ADS600B (pin 35) and the SL70 (pin 19), which NavWorx recommended to connect also. >From reading everyone's manuals, my gut tells me that connecting pins 3, 5, and 19 of the SL70 to pins 32, 33, and 35 (respectively) of the ADS600B is all that is required....no 'programming' in the SL70 - but there are settings in the ADS600B.... This is how I'm planning my installation - unless I get additional/contrary guidance from NavWorx. Ralph -----Original Message----- >From: "bigdog(at)bentwing.com" >Sent: Feb 4, 2015 6:54 PM >To: "rv-list(at)matronics.com" >Subject: RE: RV-List: Navworx ADS600b and SL70 > >--> RV-List message posted by: "bigdog(at)bentwing.com" > >I've got Rev. 33 of the NavWorx install manual and can't find any reference to extended and remote modes. Where did you find the reference to programming the SL-70? > >Greg > >-----Original Message----- >From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of bigdog(at)bentwing.com >Sent: Wednesday, February 04, 2015 5:16 PM >To: rv-list(at)matronics.com; avionics-list(at)matronics.com >Subject: RE: RV-List: Navworx ADS600b and SL70 > >--> RV-List message posted by: "bigdog(at)bentwing.com" >--> > >I'm in the process of installing that config in my Navion. I'm tying into my SL-70, 430W and MX-20. I hope to pull the harness this weekend and complete the physical part of the installation. Then comes the panel diving to hook it up. I don't recall a reference to those modes but the SL-70 came in both panel mount and remote mount versions. I'll have to check the manual to see if that's what it means. I also plan to put the NavWorx in my RV which also has an SL-70 and 430w but I want to get it flying first. I'm seeing light at the end of the tunnel and have decreed "no more changes". > >Regards, >Greg Young > >-----Original Message----- >From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ralph E. Capen >Sent: Wednesday, February 04, 2015 3:54 PM >To: avionics-list(at)matronics.com; rv-list >Subject: RV-List: Navworx ADS600b and SL70 > >--> RV-List message posted by: "Ralph E. Capen" > > >Anyone out there using this configuration? I am getting ready for installation in my RV6A - already have the gear > >The navworx manual indicates it is a valid combination - but they reference an "extended mode" or "remote mode" that needs to be programmed in the SL70. I have the SL70 manuals (install and user) and can find no reference to programming either of these functions. > >What say ye oh "been there, done that" t-shirt wearers? > >Thanks, >Ralph > > ________________________________________________________________________________
Date: Feb 05, 2015
Subject: Re: RE: RV-List: Navworx ADS600b and SL70
Greg, I have similar equipment (420W instead of 430W) in my 6A. >From what I have read in everyone's manuals, the position out from the 400W/500W series does not carry the same formatting (message number) that the NavWorx box is expecting (even though it is a standard ARINC message) - so plan on the additional GPS antenna for the NavWorx box and don't waste your time trying to get position data out of the 400W/500W series units. Since the MX20 will take in both traffic and weather data streams from the ADS600B and the 400W/500W series will only take traffic, I am seriously considering NOT burdening the 400W/500W box's processor with the data stream. Ralph -----Original Message----- >From: "bigdog(at)bentwing.com" <bigdog(at)bentwing.com> >Sent: Feb 4, 2015 6:15 PM >To: "rv-list(at)matronics.com" , "avionics-list(at)matronics.com" >Subject: Avionics-List: RE: RV-List: Navworx ADS600b and SL70 > > >I'm in the process of installing that config in my Navion. I'm tying into my SL-70, 430W and MX-20. I hope to pull the harness this weekend and complete the physical part of the installation. Then comes the panel diving to hook it up. I don't recall a reference to those modes but the SL-70 came in both panel mount and remote mount versions. I'll have to check the manual to see if that's what it means. I also plan to put the NavWorx in my RV which also has an SL-70 and 430w but I want to get it flying first. I'm seeing light at the end of the tunnel and have decreed "no more changes". > >Regards, >Greg Young > >-----Original Message----- >From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ralph E. Capen >Sent: Wednesday, February 04, 2015 3:54 PM >To: avionics-list(at)matronics.com; rv-list >Subject: RV-List: Navworx ADS600b and SL70 > >--> RV-List message posted by: "Ralph E. Capen" > > >Anyone out there using this configuration? I am getting ready for installation in my RV6A - already have the gear > >The navworx manual indicates it is a valid combination - but they reference an "extended mode" or "remote mode" that needs to be programmed in the SL70. I have the SL70 manuals (install and user) and can find no reference to programming either of these functions. > >What say ye oh "been there, done that" t-shirt wearers? > >Thanks, >Ralph > > ________________________________________________________________________________
Date: Feb 05, 2015
I installed my NavWorx last summer,and have no idea what you are talking about. Mine is using the Wi Fi dongle to transmit to my Ipad. Suggest calling the factory and talking with Bethany Bunin, she is very sharp and was always helpful with all my questions. When she say's "I'll find out" - she WILL. Richard -----Original Message----- From: Ralph E. Capen Sent: Thursday, February 05, 2015 6:27 AM Subject: Avionics-List: RE: RV-List: Navworx ADS600b and SL70 Cross-posted to make sure everyone can see responses..... I was initially asking them about the differences between connecting pins 3 and 5 of the SL70 to pins 32 and 33 of the ADS600B for control versus connecting pins 3 and 5 of the SL70 to pins 6 and 7 of the ADS600B for altitude data. Their initial response indicated that I only need 3 and 5 to 32 and 33 as that connection will pass control and data messages. They followed up with indicating extended mode or remote mode were also required - I haven't been able to get a direct response to that question. I sent them pdf's of the SL70 install and user guides - my Navworx manual is rev 33 (guessing from the part number) - it doesn't have any references to remote mode for the SL70...but it does reference a remote mode for the GNS480 and GTX330 units. There is a remote ident supress feature common to the ADS600B (pin 35) and the SL70 (pin 19), which NavWorx recommended to connect also. >From reading everyone's manuals, my gut tells me that connecting pins 3, 5, >and 19 of the SL70 to pins 32, 33, and 35 (respectively) of the ADS600B is >all that is required....no 'programming' in the SL70 - but there are >settings in the ADS600B.... This is how I'm planning my installation - >unless I get additional/contrary guidance from NavWorx. Ralph -----Original Message----- >From: "bigdog(at)bentwing.com" >Sent: Feb 4, 2015 6:54 PM >To: "rv-list(at)matronics.com" >Subject: RE: RV-List: Navworx ADS600b and SL70 > >--> RV-List message posted by: "bigdog(at)bentwing.com" > >I've got Rev. 33 of the NavWorx install manual and can't find any reference >to extended and remote modes. Where did you find the reference to >programming the SL-70? > >Greg > >-----Original Message----- >From: owner-rv-list-server(at)matronics.com >[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of >bigdog(at)bentwing.com >Sent: Wednesday, February 04, 2015 5:16 PM >To: rv-list(at)matronics.com; avionics-list(at)matronics.com >Subject: RE: RV-List: Navworx ADS600b and SL70 > >--> RV-List message posted by: "bigdog(at)bentwing.com" >--> > >I'm in the process of installing that config in my Navion. I'm tying into >my SL-70, 430W and MX-20. I hope to pull the harness this weekend and >complete the physical part of the installation. Then comes the panel diving >to hook it up. I don't recall a reference to those modes but the SL-70 came >in both panel mount and remote mount versions. I'll have to check the >manual to see if that's what it means. I also plan to put the NavWorx in my >RV which also has an SL-70 and 430w but I want to get it flying first. I'm >seeing light at the end of the tunnel and have decreed "no more changes". > >Regards, >Greg Young > >-----Original Message----- >From: owner-rv-list-server(at)matronics.com >[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ralph E. Capen >Sent: Wednesday, February 04, 2015 3:54 PM >To: avionics-list(at)matronics.com; rv-list >Subject: RV-List: Navworx ADS600b and SL70 > >--> RV-List message posted by: "Ralph E. Capen" > > >Anyone out there using this configuration? I am getting ready for >installation in my RV6A - already have the gear > >The navworx manual indicates it is a valid combination - but they reference >an "extended mode" or "remote mode" that needs to be programmed in the >SL70. I have the SL70 manuals (install and user) and can find no reference >to programming either of these functions. > >What say ye oh "been there, done that" t-shirt wearers? > >Thanks, >Ralph > > --- This email has been checked for viruses by Avast antivirus software. http://www.avast.com ________________________________________________________________________________
Date: Feb 05, 2015
Thanks - a phone call may be in order..... -----Original Message----- >From: Richard DeWitt <radrv6(at)cox.net> >Sent: Feb 5, 2015 9:46 AM >To: avionics-list(at)matronics.com >Subject: Re: Avionics-List: RE: RV-List: Navworx ADS600b and SL70 > > >I installed my NavWorx last summer,and have no idea what you are talking >about. Mine is using the Wi Fi dongle to transmit to my Ipad. Suggest >calling the factory and talking with Bethany Bunin, she is very sharp and >was always helpful with all my questions. When she say's "I'll find out" - >she WILL. >Richard > >-----Original Message----- >From: Ralph E. Capen >Sent: Thursday, February 05, 2015 6:27 AM >To: rv-list(at)matronics.com ; avionics-list(at)matronics.com >Subject: Avionics-List: RE: RV-List: Navworx ADS600b and SL70 > > > >Cross-posted to make sure everyone can see responses..... > >I was initially asking them about the differences between connecting pins 3 >and 5 of the SL70 to pins 32 and 33 of the ADS600B for control versus >connecting pins 3 and 5 of the SL70 to pins 6 and 7 of the ADS600B for >altitude data. > >Their initial response indicated that I only need 3 and 5 to 32 and 33 as >that connection will pass control and data messages. They followed up with >indicating extended mode or remote mode were also required - I haven't been >able to get a direct response to that question. I sent them pdf's of the >SL70 install and user guides - my Navworx manual is rev 33 (guessing from >the part number) - it doesn't have any references to remote mode for the >SL70...but it does reference a remote mode for the GNS480 and GTX330 units. >There is a remote ident supress feature common to the ADS600B (pin 35) and >the SL70 (pin 19), which NavWorx recommended to connect also. > >>From reading everyone's manuals, my gut tells me that connecting pins 3, 5, >>and 19 of the SL70 to pins 32, 33, and 35 (respectively) of the ADS600B is >>all that is required....no 'programming' in the SL70 - but there are >>settings in the ADS600B.... This is how I'm planning my installation - >>unless I get additional/contrary guidance from NavWorx. > >Ralph > > >-----Original Message----- >>From: "bigdog(at)bentwing.com" >>Sent: Feb 4, 2015 6:54 PM >>To: "rv-list(at)matronics.com" >>Subject: RE: RV-List: Navworx ADS600b and SL70 >> >>--> RV-List message posted by: "bigdog(at)bentwing.com" >> >>I've got Rev. 33 of the NavWorx install manual and can't find any reference >>to extended and remote modes. Where did you find the reference to >>programming the SL-70? >> >>Greg >> >>-----Original Message----- >>From: owner-rv-list-server(at)matronics.com >>[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of >>bigdog(at)bentwing.com >>Sent: Wednesday, February 04, 2015 5:16 PM >>To: rv-list(at)matronics.com; avionics-list(at)matronics.com >>Subject: RE: RV-List: Navworx ADS600b and SL70 >> >>--> RV-List message posted by: "bigdog(at)bentwing.com" >>--> >> >>I'm in the process of installing that config in my Navion. I'm tying into >>my SL-70, 430W and MX-20. I hope to pull the harness this weekend and >>complete the physical part of the installation. Then comes the panel diving >>to hook it up. I don't recall a reference to those modes but the SL-70 came >>in both panel mount and remote mount versions. I'll have to check the >>manual to see if that's what it means. I also plan to put the NavWorx in my >>RV which also has an SL-70 and 430w but I want to get it flying first. I'm >>seeing light at the end of the tunnel and have decreed "no more changes". >> >>Regards, >>Greg Young >> >>-----Original Message----- >>From: owner-rv-list-server(at)matronics.com >>[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ralph E. Capen >>Sent: Wednesday, February 04, 2015 3:54 PM >>To: avionics-list(at)matronics.com; rv-list >>Subject: RV-List: Navworx ADS600b and SL70 >> >>--> RV-List message posted by: "Ralph E. Capen" >> >> >>Anyone out there using this configuration? I am getting ready for >>installation in my RV6A - already have the gear >> >>The navworx manual indicates it is a valid combination - but they reference >>an "extended mode" or "remote mode" that needs to be programmed in the >>SL70. I have the SL70 manuals (install and user) and can find no reference >>to programming either of these functions. >> >>What say ye oh "been there, done that" t-shirt wearers? >> >>Thanks, >>Ralph >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> > > >--- >This email has been checked for viruses by Avast antivirus software. >http://www.avast.com > > ________________________________________________________________________________
Date: Feb 05, 2015
They are great people to work with ! RAD -----Original Message----- From: Ralph E. Capen Sent: Thursday, February 05, 2015 8:14 AM Subject: Re: Avionics-List: RE: RV-List: Navworx ADS600b and SL70 Thanks - a phone call may be in order..... -----Original Message----- >From: Richard DeWitt <radrv6(at)cox.net> >Sent: Feb 5, 2015 9:46 AM >To: avionics-list(at)matronics.com >Subject: Re: Avionics-List: RE: RV-List: Navworx ADS600b and SL70 > > >I installed my NavWorx last summer,and have no idea what you are talking >about. Mine is using the Wi Fi dongle to transmit to my Ipad. Suggest >calling the factory and talking with Bethany Bunin, she is very sharp and >was always helpful with all my questions. When she say's "I'll find out" - >she WILL. >Richard > >-----Original Message----- >From: Ralph E. Capen >Sent: Thursday, February 05, 2015 6:27 AM >To: rv-list(at)matronics.com ; avionics-list(at)matronics.com >Subject: Avionics-List: RE: RV-List: Navworx ADS600b and SL70 > > > >Cross-posted to make sure everyone can see responses..... > >I was initially asking them about the differences between connecting pins 3 >and 5 of the SL70 to pins 32 and 33 of the ADS600B for control versus >connecting pins 3 and 5 of the SL70 to pins 6 and 7 of the ADS600B for >altitude data. > >Their initial response indicated that I only need 3 and 5 to 32 and 33 as >that connection will pass control and data messages. They followed up with >indicating extended mode or remote mode were also required - I haven't been >able to get a direct response to that question. I sent them pdf's of the >SL70 install and user guides - my Navworx manual is rev 33 (guessing from >the part number) - it doesn't have any references to remote mode for the >SL70...but it does reference a remote mode for the GNS480 and GTX330 units. >There is a remote ident supress feature common to the ADS600B (pin 35) and >the SL70 (pin 19), which NavWorx recommended to connect also. > >>From reading everyone's manuals, my gut tells me that connecting pins 3, >>5, >>and 19 of the SL70 to pins 32, 33, and 35 (respectively) of the ADS600B is >>all that is required....no 'programming' in the SL70 - but there are >>settings in the ADS600B.... This is how I'm planning my installation - >>unless I get additional/contrary guidance from NavWorx. > >Ralph > > >-----Original Message----- >>From: "bigdog(at)bentwing.com" >>Sent: Feb 4, 2015 6:54 PM >>To: "rv-list(at)matronics.com" >>Subject: RE: RV-List: Navworx ADS600b and SL70 >> >>--> RV-List message posted by: "bigdog(at)bentwing.com" >> >>I've got Rev. 33 of the NavWorx install manual and can't find any >>reference >>to extended and remote modes. Where did you find the reference to >>programming the SL-70? >> >>Greg >> >>-----Original Message----- >>From: owner-rv-list-server(at)matronics.com >>[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of >>bigdog(at)bentwing.com >>Sent: Wednesday, February 04, 2015 5:16 PM >>To: rv-list(at)matronics.com; avionics-list(at)matronics.com >>Subject: RE: RV-List: Navworx ADS600b and SL70 >> >>--> RV-List message posted by: "bigdog(at)bentwing.com" >>--> >> >>I'm in the process of installing that config in my Navion. I'm tying into >>my SL-70, 430W and MX-20. I hope to pull the harness this weekend and >>complete the physical part of the installation. Then comes the panel >>diving >>to hook it up. I don't recall a reference to those modes but the SL-70 >>came >>in both panel mount and remote mount versions. I'll have to check the >>manual to see if that's what it means. I also plan to put the NavWorx in >>my >>RV which also has an SL-70 and 430w but I want to get it flying first. I'm >>seeing light at the end of the tunnel and have decreed "no more changes". >> >>Regards, >>Greg Young >> >>-----Original Message----- >>From: owner-rv-list-server(at)matronics.com >>[mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ralph E. Capen >>Sent: Wednesday, February 04, 2015 3:54 PM >>To: avionics-list(at)matronics.com; rv-list >>Subject: RV-List: Navworx ADS600b and SL70 >> >>--> RV-List message posted by: "Ralph E. Capen" >> >> >>Anyone out there using this configuration? I am getting ready for >>installation in my RV6A - already have the gear >> >>The navworx manual indicates it is a valid combination - but they >>reference >>an "extended mode" or "remote mode" that needs to be programmed in the >>SL70. I have the SL70 manuals (install and user) and can find no >>reference >>to programming either of these functions. >> >>What say ye oh "been there, done that" t-shirt wearers? >> >>Thanks, >>Ralph >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> > > >--- >This email has been checked for viruses by Avast antivirus software. >http://www.avast.com > > --- This email has been checked for viruses by Avast antivirus software. http://www.avast.com ________________________________________________________________________________
Date: Feb 05, 2015
Subject: NavWorx / SL 70 -> Extended mode
>From the folks at NavWorx - kudos to them for documenting this...I expect to find it in a NavWorx manual update soon. The SL70 IM is missing the instructions on how to configure it for extended mode. On page 31 of the 2003 Garmin SL70 installation manual, Appendix E Serial Interface Specification, there is reference/clue in the paragraph Message Definitions. Messages are divided into two groups, the Standard Message which is simply the pressure altitude and system status and the Extended Message group which includes the squawk code and all the other good stuff listed in Appendix E. The last sentence references that this is accomplished in the setup mode and saved in the EEPROM. What is missing is exactly how to do this. The procedure is as follows: Reference page 12 of the 2003 Apollo SL70 Installation Manual Post Installation Checkout 1. Put the unit in setup mode: A. To operate the SL70 in the setup mode hold down the IDENT and ALT buttons while turning the power on 2. Turn the large knob to the SL70 config page a. This should be one click clockwise and change from set up to SL70 config 3. Using the small knob: a. Turn to ASRC This is the altitude source page b. The two choices for altitude INPUT are gray or serial i. Unless Navworx can update its software to run at 1200 baud, an encoder capable of gray code and or a serial to gray code convertor such as Dynon Manufactures will need to be used to interface with the SL70. The SL70 will only accept altitude data from an encoder at 1200 baud. ii. So at this point assuming you use the serial to gray converter, set the input to GRAY by: 1. Press the ident button the serial or gray field will start to flash 2. Set to gray if not already indicating gray 3. Press ident again to set into the memory if the setting was changed, if not proceed 4. Turn the small knob one click to set the baud rate a. To select and change the baud rate, press the ident button once, the baud rate field will start to flash b. To interface with the Navworx unit, at present, the baud rate will need to be set to 9,600 c. Turn the small knob until 9600 in displayed and press the ident button again to set into memory 5. Here is what is missing from the manual Turn the small knob clockwise one click to the next input screen a. The next screen is the TX screen The TX is for the message transmit format used on the serial port b. There are two options Standard STD and Extended EXT c. Press the ident button to highlight the field. It will start to flash d. Turn the small knob to set the EXT into the field e. Press the ident button again to set the field 6. Cycle the SL70 power off and turn back on. The SL70 is good to go and should now be set up to control the Navworx unit a. Using the maintenance port on the Navworx, set the Input screen to SL70 and DB37 pin 33. I have not verified this from a functionality standpoint yet. In my installation, the SL70 port referenced above is currently being used to provide altitude data to my MX20 - so I have a couple of if scenarios.....: If the baud rate on the SL70 port is currently at 9600 and if my MX20 ignores the extended stuff and parses out just the altitude, I'm OK by simply forking the serial output to both the MX20 and the ADS600B. Otherwise, if the MX20 is version 5.6 or later, it should take altitude data along with the Lat/Long it is already receiving from the 420W and freeing up the port for dedicated communication with the ADS600B. I prefer the latter - but I'll take whatever I can get! Hope this helps - and thanks again to the NavWorx crew! Ralph ________________________________________________________________________________
Date: Feb 05, 2015
Thanks Ralph! The extended message makes sense. Luckily I'm using gray code in the Navion but using the GRT as my encoder in the RV. I'll deal with that downstream sometime. Thanks for the write-up. Greg -----Original Message----- From: owner-avionics-list-server(at)matronics.com [mailto:owner-avionics-list-server(at)matronics.com] On Behalf Of Ralph E. Capen Sent: Thursday, February 05, 2015 3:32 PM Subject: Avionics-List: NavWorx / SL 70 -> Extended mode --> >From the folks at NavWorx - kudos to them for documenting this...I expect to find it in a NavWorx manual update soon. The SL70 IM is missing the instructions on how to configure it for extended mode. On page 31 of the 2003 Garmin SL70 installation manual, Appendix E Serial Interface Specification, there is reference/clue in the paragraph Message Definitions. Messages are divided into two groups, the Standard Message which is simply the pressure altitude and system status and the Extended Message group which includes the squawk code and all the other good stuff listed in Appendix E. The last sentence references that this is accomplished in the setup mode and saved in the EEPROM. What is missing is exactly how to do this. The procedure is as follows: Reference page 12 of the 2003 Apollo SL70 Installation Manual Post Installation Checkout 1. Put the unit in setup mode: A. To operate the SL70 in the setup mode hold down the IDENT and ALT buttons while turning the power on 2. Turn the large knob to the SL70 config page a. This should be one click clockwise and change from set up to SL70 config 3. Using the small knob: a. Turn to ASRC This is the altitude source page b. The two choices for altitude INPUT are gray or serial i. Unless Navworx can update its software to run at 1200 baud, an encoder capable of gray code and or a serial to gray code convertor such as Dynon Manufactures will need to be used to interface with the SL70. The SL70 will only accept altitude data from an encoder at 1200 baud. ii. So at this point assuming you use the serial to gray converter, set the input to GRAY by: 1. Press the ident button the serial or gray field will start to flash 2. Set to gray if not already indicating gray 3. Press ident again to set into the memory if the setting was changed, if not proceed 4. Turn the small knob one click to set the baud rate a. To select and change the baud rate, press the ident button once, the baud rate field will start to flash b. To interface with the Navworx unit, at present, the baud rate will need to be set to 9,600 c. Turn the small knob until 9600 in displayed and press the ident button again to set into memory 5. Here is what is missing from the manual Turn the small knob clockwise one click to the next input screen a. The next screen is the TX screen The TX is for the message transmit format used on the serial port b. There are two options Standard STD and Extended EXT c. Press the ident button to highlight the field. It will start to flash d. Turn the small knob to set the EXT into the field e. Press the ident button again to set the field 6. Cycle the SL70 power off and turn back on. The SL70 is good to go and should now be set up to control the Navworx unit a. Using the maintenance port on the Navworx, set the Input screen to SL70 and DB37 pin 33. I have not verified this from a functionality standpoint yet. In my installation, the SL70 port referenced above is currently being used to provide altitude data to my MX20 - so I have a couple of if scenarios.....: If the baud rate on the SL70 port is currently at 9600 and if my MX20 ignores the extended stuff and parses out just the altitude, I'm OK by simply forking the serial output to both the MX20 and the ADS600B. Otherwise, if the MX20 is version 5.6 or later, it should take altitude data along with the Lat/Long it is already receiving from the 420W and freeing up the port for dedicated communication with the ADS600B. I prefer the latter - but I'll take whatever I can get! Hope this helps - and thanks again to the NavWorx crew! Ralph ________________________________________________________________________________
Date: Feb 09, 2015
Subject: NavWorx ADS600B integration to Garmin based panel -> the
saga continues Folks, Here's another update since getting the details on implementing the "Extended" mode from the NavWorx folks: I was able to get the SL70 configured for the "Extended" mode per their instructions. The extended mode data did not interfere with passing altitude data to the MX20 as currently connected. Their additional requirements are causing some interoperability issues.... The ADS600B requires the "Extended" mode output from the SL70 at 9600 baud - which the SL70 is capable of delivering. The 9600 baud setting is not compatible with the MX20 - which only allows 1200 baud communications. I have a note in to NavWorx to see if they are going to allow 1200 baud in the future...I'm not the only one with this issue! As a potential workaround, I looked at the documentation for my GNC420W. It indicates that it is capable of transmitting the altitude data to the MX20 along with the existing connection that provides lat/long. I tried that too - it doesn't work. I have a note in to Garmin to see if there is a configuration setting that I missed or if there was a printing error. If all else fails - throw money at it.....I can replace the installed altitude encoder with one that has a 1200 baud serial port as well as the Gray code. I'm starting to see why everyone is screaming about the cost vs benefit of ADS-B in the first place..... Ralph ________________________________________________________________________________
Date: Feb 09, 2015
Subject: Re: NavWorx ADS600B integration to Garmin based panel ->
the saga continues An update from NavWorx - they support 1200 baud communications. Should solve all of the issues I am experiencing! -----Original Message----- >From: "'Ralph E. Capen' recapen(at)earthlink.net [RV7A]" <RV7A(at)yahoogroups.com> >Sent: Feb 9, 2015 12:52 PM >To: rv-list , "avionics-list(at)matronics.com" >Cc: RV7 Yahoo list , EXP-AVIONICS >Subject: [RV Builders] NavWorx ADS600B integration to Garmin based panel -> the saga continues > >Folks, > >Here's another update since getting the details on implementing the "Extended" mode from the NavWorx folks: > >I was able to get the SL70 configured for the "Extended" mode per their instructions. The extended mode data did not interfere with passing altitude data to the MX20 as currently connected. > >Their additional requirements are causing some interoperability issues.... The ADS600B requires the "Extended" mode output from the SL70 at 9600 baud - which the SL70 is capable of delivering. The 9600 baud setting is not compatible with the MX20 - which only allows 1200 baud communications. I have a note in to NavWorx to see if they are going to allow 1200 baud in the future...I'm not the only one with this issue! > >As a potential workaround, I looked at the documentation for my GNC420W. It indicates that it is capable of transmitting the altitude data to the MX20 along with the existing connection that provides lat/long. I tried that too - it doesn't work. I have a note in to Garmin to see if there is a configuration setting that I missed or if there was a printing error. > >If all else fails - throw money at it.....I can replace the installed altitude encoder with one that has a 1200 baud serial port as well as the Gray code. > >I'm starting to see why everyone is screaming about the cost vs benefit of ADS-B in the first place..... > >Ralph ________________________________________________________________________________
Date: Feb 23, 2015
Subject: Eaton lighted switches - group buy...long ago
A long time ago, there was a group buy on a batch of Eaton Lighted rocker switches. SPDT with 12 VDC lighting. They are marked Eaton and "USA 9931". We had them engraved by the folks at Aircraft Engravers if I recall correctly. Anyone have a couple of spares - or know where I can get some of them? Thanks, Ralph Capen ________________________________________________________________________________
Date: Mar 01, 2015
Now approaching 6000 pilots using the app with over 1350 listings, and a recent review on the EAA website. And in a feeble attempt to recoup my costs, I am now offering very reasonably priced ad's for aviation related businesses as I keep my word to keep this app free for pilots. If you or someone you know may be interested, please email me at airportcars101(at)gmail.com for rates. And please tell your FBO where you found them. Thank you. Glenn -------- Glenn Brasch RV-9A Flying 1952 Piper Tri-Pacer Medevac Helicopter Pilot (Ret) Tucson, Arizona Owner, www.RVairspace.com and "Airport Courtesy Cars" Smart Phone App www.RVairspace.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438850#438850 ________________________________________________________________________________
Date: Mar 18, 2015
I still get a lot of questions on how to download the Airport Courtesy Cars app on an iPad. So here are some simple instructions on how to do so. The app is approaching 1400 car listings with over 6,400 pilots that have downloaded the app. Glenn Go to the app store on your iPad, Click the search box and search for Airport Courtesy Cars, The search will not show any results, however when the search is complete a bar of menus will appear along the top of the page, The very first one on the left says "Ipad only", Click it to show a drop down menu, Choose "iPhone only" and Airport Courtesy Cars" will be displayed, and you can download the app. -------- Glenn Brasch RV-9A Flying 1952 Piper Tri-Pacer Medevac Helicopter Pilot (Ret) Tucson, Arizona Owner, www.RVairspace.com and "Airport Courtesy Cars" Smart Phone App www.RVairspace.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439531#439531 ________________________________________________________________________________
Date: Mar 26, 2015
I can now insert photos of your courtesy cars into the app listings. Feel free to email me your photos, and please be sure to indicate in the title of the email the airport ID and/or city location, and if there is more than one FBO, which one the car is located at. The app has broken 1400 locations nationwide. Thanks, Glenn Email to airportcars101(at)gmail.com -------- Glenn Brasch RV-9A Flying 1952 Piper Tri-Pacer Medevac Helicopter Pilot (Ret) Tucson, Arizona Owner, www.RVairspace.com and "Airport Courtesy Cars" Smart Phone App. Over 1400 cars nationwide. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439937#439937 ________________________________________________________________________________
Subject: Minimal IFR: What to do with your old Nav-122?
Date: Apr 02, 2015
Minimal IFR: What to do with your old Nav-122? Lots of Pipers from the 60 and 70s have Narco radios they were the least expensive at the time, have since gone out of business and support for these radios is fading away. We send a steady flow of Narco products to Bevan-Rabell in Wichita for repair. They usually take about 4 weeks and $450 and your Mark12D is back in operation. This has not been the case for the all-in-one navigation radios. Last week we sent a Nav-122 for repair to find it needed plastic gears that are no longer available. This instrument candidate is working to get his plane ready for an instrument training, checkride and regular flights to Houston and New Mexico. What are the best solutions? He has a mixture of other radios such as an old Apollo GX-55 GPS, and couple communication radios (TKM-810, and KY196). Of course we recommended buying a Garmin setup with new or used GNS or GTN with an indicator and an audio panel, and keeping one of his Com radios as a second Com. - used Garmin GNS430W = $6500 - 340 audio panel used = $1000 - GI106A indicator used = $1500 - Wiring harness = $1200 - Installation $1000 At a minimum $11,200 and this does not get ADS-B. What about if all you want to do is instrument training, checkride and basic IFR for less money? (Assuming you do not need/want an IFR GPS and the $425 plus year subscription). Is there a replacement for a NAV-122? You can use Foreflight/wingx/etc or for VFR GPS and you just want to fly VOR/LOC/GS approaches if needed. We installed a VAL INS-422 in our blue Cessna 150 about 11 years ago. It is designed after a Nav-122 and has been trouble free. I used it for a CFI-I instrument check ride and did some IFR training in our blue Cessna 150. This radio has not seen a lot of use. Our C150 has not done a lot of instrument training due to its limited climb rate, slow speeds with faster traffic and limited range. Val redesigned the new INS-429 a few years ago. It has much better features including operation as a course deviation indicator for a Garmin installation. With a street price of $1585, it is about the same price as a used Garmin Indicator (GI-106A) and could be integrated with a Garmin in the future. We pulled the trigger on this last week and will report how well it works. The installation is straight forward as we will reuse most of the existing wiring: 3 antenna cables (VOR, Glideslope from splitter, and existing marker beacon antenna), power, ground and existing audio cables to audio panel. Installation will be a minor alteration as defined in Advisory Circular AC 20-138D, and a logbook entry. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440190#440190 ________________________________________________________________________________
Subject: Re: Minimal IFR: What to do with your old Nav-122?
Date: Apr 02, 2015
On 2 Apr 2015, at 15:25, n1345p wrote: > Last week we sent a Nav-122 for repair to find it needed plastic gears that are no longer available Sounds like a job for a 3-D printer! in friendship Rowland | Rowland Carson ... that's Rowland with a 'w' ... | http://www.rowlandcarson.org.uk | Skype, Twitter: rowland_carson Facebook: Rowland Carson | pictures: http://picasaweb.google.com/rowlandcarson ________________________________________________________________________________
Date: Apr 02, 2015
Makes a good door stop. I have an ARC-300 Nav/Comm that I use for one. Regards, Dennis W. Wilt N616DW (Arion Lightning S/N 132) -----Original Message----- From: n1345p <n1345p(at)suddenlink.net> Sent: Thu, Apr 2, 2015 10:27 am Subject: Avionics-List: Minimal IFR: What to do with your old Nav-122? Minimal IFR: What to do with your old Nav-122? Lots of Pipers from the 60 and 70=C3=A2=C2=C2=99s have Narco radios =C3=A2=C2=C2=93 they were the least expensive at the t ime, have since gone out of business and support for these radios is fading away. We send a ste ady flow of Narco products to Bevan-Rabell in Wichita for repair. They usually take about 4 weeks and $450 and your Mark12D is back in operation. This has not been the case for the all-in-one navigation radios. Last week we sent a Nav-122 for repair to find it needed plastic gears that are no longer available. This instrument candidate is working to get his plane ready for an instrument training, checkride and regular flights to Houston and New Mexico. What ar e the best solutions? He has a mixture of other radios such as an old Apollo GX- 55 GPS, and couple communication radios (TKM-810, and KY196). Of course we recommended buying a Garmin setup with new or used GNS or GTN with an indic ator and an audio panel, and keeping one of his Com radios as a second Com. - used Garmin GNS430W = $6500 - 340 audio panel used = $1000 - GI106A indicator used = $1500 - Wiring harness = $1200 - Installation $1000 At a minimum $11,200 and this does not get ADS-B. What about if all you want to do is instrument training, checkride and basic IFR for less money? (Assuming you do not need /want an IFR GPS and the $425 plus year subscription). Is there a replacement fo r a NAV-122? You can use Foreflight/wingx/etc or for VFR GPS and you just want to fly VOR/LOC/GS approaches if needed. We installed a VAL INS-422 in our blue Cessna 150 about 11 years ago. It is designed after a Nav-122 and has been trouble free. I used it for a CFI-I instrument check ride and did some IFR training in our blue Cessna 150. This radio has not seen a lot of use. Ou r C150 has not done a lot of instrument training due to its limited climb rat e, slow speeds with faster traffic and limited range. Val redesigned the new INS-429 a few years ago. It has much better features including operation a s a course deviation indicator for a Garmin installation. With a street price of $1585, it is about the same price as a used Garmin Indicator (GI-106A) and could be integrated with a Garmin in the future. We pulled the trigger on this l ast week and will report how well it works. The installation is straight forwa rd as we will reuse most of the existing wiring: 3 antenna cables (VOR, Glideslo pe from splitter, and existing marker beacon antenna), power, ground and exist ing audio cables to audio panel. Installation will be a minor alteration as de fined in Advisory Circular AC 20-138D, and a logbook entry. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440190#440190 - The Avionics-List Email Forum - to browse Archive Search & Download, 7-Day Browse, Chat, FAQ, much more: http://www.matronics.com/Navigator?Avionics-List - MATRONICS WEB FORUMS - Forums! http://forums.matronics.com - List Contribution Web Site - -Matt Dralle, List Admin. http://www.matronics.com/contribution ________________________________________________________________________________
Subject: Advisory Circulars =?ISO-8859-1?Q?=93?= Aircraft - Federal
Aviation Administr
From: "terrystrickl" <terrystrickland100(at)gmail.com>
Date: Apr 04, 2015
This advisory circular (AC) provides guidance on airworthiness ... However, if you use the means described in this AC, you must .... and requirements to obtain approved model list (AML)supplemental typecertificate(STC). -------- ASD Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440275#440275 ________________________________________________________________________________
Subject: Matronics
Date: May 13, 2015
Dear Listers, Its November 30th and that means a couple of things. Its my birthday again, 48 of them, in fact! But it also means that its that last official day of the Matronics Email List Fund Raiser! If you been jones'n over one of those really nice incentive gifts now is the time to jump on one!! If you've been meaning to make a Contribution this month but have been putting it off for some reason, NOW is the time! I will be posting the List of Contributors in a few days, so you'll probably want to be known as a person that supported the Lists! I want to thank everyone that has so generously made a Contribution this year in support of our Lists. It is your generosity that keeps this operation running and I don't ever forget it. Hopefully everyone feels the same. Below are a few more of the nice comments from Listers I've received this year. Please read them over and see if you don't agree. -------- NOOR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442095#442095 ________________________________________________________________________________
Subject: Need Knob for Garmin GTX320A - squawk selectors
Date: May 26, 2015
2nd digit knob broke on a Garmin GTX320A transponder. Garmin wants to sell the whole front panel. I will probably find some knobs from digi-key unless someone has a better solution. Any onehave a cross reference for the know or some used ones they want to sell. mitch >From Garmin service: Dear MItchell Williams, Thank you for contacting Garmin International. Mitchell, the only way that knob can be replaced is by replacing the front panel. That is as far as we break down the parts list. That work can be done at any Garmin Aviation Dealer near you. Best Regards, Terry Garmin Aviation Support -------- Mitchell Williams OKPE, ATP/CFI/A&P/IA www.chickashawings.com of shadow and ash http://www.amazon.com/dp/B009KZGVQS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442578#442578 ________________________________________________________________________________
Subject: Re: New (Free) Aviation App
Date: Jun 14, 2015
Quick update, 18,000 launches, more discounts being added for users, more positive national press coverage and keeping it free to pilots. Thanks, Glenn -------- Glenn Brasch RV-9A Flying 1952 Piper Tri-Pacer Medevac Helicopter Pilot (Ret) Tucson, Arizona Owner, "Airport Courtesy Cars" Smart Phone App. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=443505#443505 ________________________________________________________________________________
Date: Jun 17, 2015
Subject: Reconsider Garmin Purchases
In the rebuild of my RV-8 recently, I managed to get a scratch in the lens of both the Garmin SL-30 and the Garmin GTX-327. No biggie, I thought, I'll just order up a replacement and stick them in, much like I did on the King KX-125 on the RV-6. I called up Pacific Coast Avionics today to order the parts and was told the following: Garmin will not sell the lens. Yup, you hear that right. My only option is to return both units to Garmin for a "factory repair" and the MINIMUM charge will be $535 for EACH unit! That is $1070 to replace two $4 pieces of plastic! That is simply outrageous! Frankly, criminal behavior. I will NOT be buying ANY future Garmin products. I refuse to do business with a company that treats their customers this way. Unacceptable. - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 182+ Hours TTSN - Version 2.0 Now Flying! RV-6 #20916 N360EM "The Flyer" http://www.mattsrv6.com - Matt's RV-6 Revitalization Log Status: 300+ Hours - Full Flyer Mode! Matt's Livermore Airport Live ATC Stream! Check out the live ATC stream directly from my hangar at the Livermore Airport. Includes both Tower and Ground transmissions. Archives too! For entertainment purposes only. http://klvk.matronics.com ________________________________________________________________________________
Date: Jun 17, 2015
Subject: Re: Reconsider Garmin Purchases
I am not surprised. Regards, Dennis W. Wilt N616DW (Arion Lightning S/N 132) -----Original Message----- From: Matt Dralle <dralle(at)matronics.com> Sent: Wed, Jun 17, 2015 2:17 pm Subject: Avionics-List: Reconsider Garmin Purchases In the rebuild of my RV-8 recently, I managed to get a scratch in the lens of both the Garmin SL-30 and the Garmin GTX-327. No biggie, I thought, I'll just order up a replacement and stick them in, much like I did on the King KX-125 on the RV-6. I called up Pacific Coast Avionics today to order the parts and was told the following: Garmin will not sell the lens. Yup, you hear that right. My only option is to return both units to Garmin for a "factory repair" and the MINIMUM charge will be $535 for EACH unit! That is $1070 to replace two $4 pieces of plastic! That is simply outrageous! Frankly, criminal behavior. I will NOT be buying ANY future Garmin products. I refuse to do business with a company that treats their customers this way. Unacceptable. - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 182+ Hours TTSN - Version 2.0 Now Flying! RV-6 #20916 N360EM "The Flyer" http://www.mattsrv6.com - Matt's RV-6 Revitalization Log Status: 300+ Hours - Full Flyer Mode! Matt's Livermore Airport Live ATC Stream! Check out the live ATC stream directly from my hangar at the Livermore Airport. Includes both Tower and Ground transmissions. Archives too! For entertainment purposes only. http://klvk.matronics.com - The Avionics-List Email Forum - to browse Archive Search & Download, 7-Day Browse, Chat, FAQ, much more: http://www.matronics.com/Navigator?Avionics-List - MATRONICS WEB FORUMS - Forums! http://forums.matronics.com - List Contribution Web Site - -Matt Dralle, List Admin. http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jun 17, 2015
Before making my original post, I had contacted two different Avionics shops and received the exact same story, so I didn't base my findings on a single vendor. I have subsequently contacted Garmin directly and was told that the parts are in fact orderable by dealers. But, when those same avionics dealers call the Garmin parts department they are told they are not allowed to order those parts. So, something is definitely not quite lining up here. I guess I apologize to the community for venting my frustration with this process, but this really shouldn't be this difficult. I will follow up with more information on this debacle as it hopefully progresses. Btw, the lens part number for the SL-30 is 308-3201-42 and the lens for the GTX-327 is 470-00034-00. Matt At 11:13 AM 6/17/2015 Wednesday, Matt Dralle wrote: >In the rebuild of my RV-8 recently, I managed to get a scratch in the lens of both the Garmin SL-30 and the Garmin GTX-327. No biggie, I thought, I'll just order up a replacement and stick them in, much like I did on the King KX-125 on the RV-6. > >I called up Pacific Coast Avionics today to order the parts and was told the following: Garmin will not sell the lens. Yup, you hear that right. My only option is to return both units to Garmin for a "factory repair" and the MINIMUM charge will be $535 for EACH unit! That is $1070 to replace two $4 pieces of plastic! That is simply outrageous! Frankly, criminal behavior. > >I will NOT be buying ANY future Garmin products. I refuse to do business with a company that treats their customers this way. Unacceptable. > >- >Matt Dralle - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 182+ Hours TTSN - Version 2.0 Now Flying! RV-6 #20916 N360EM "The Flyer" http://www.mattsrv6.com - Matt's RV-6 Revitalization Log Status: 300+ Hours - Full Flyer Mode! Matt's Livermore Airport Live ATC Stream! Check out the live ATC stream directly from my hangar at the Livermore Airport. Includes both Tower and Ground transmissions. Archives too! For entertainment purposes only. http://klvk.matronics.com ________________________________________________________________________________
Date: Jun 17, 2015
A few years ago I was able to get lenses for an SL-30 and SL-70. I went through Avionics Unlimited in Conroe, TX. (936) 788-7333. Talk to Johnny Blain. IIRC they were about $60 each. Yeah, that seems high but I hear Bendix charges $120 for theirs. The new ones were actually nicer than my originals circa 2001. They have the adhesive built in and install nicely once the old lens is pried off and the old adhesive cleaned off. Regards, Greg Young -----Original Message----- From: owner-avionics-list-server(at)matronics.com [mailto:owner-avionics-list-server(at)matronics.com] On Behalf Of Matt Dralle Sent: Wednesday, June 17, 2015 4:39 PM Subject: Avionics-List: Re: Reconsider Garmin Purchases Before making my original post, I had contacted two different Avionics shops and received the exact same story, so I didn't base my findings on a single vendor. I have subsequently contacted Garmin directly and was told that the parts are in fact orderable by dealers. But, when those same avionics dealers call the Garmin parts department they are told they are not allowed to order those parts. So, something is definitely not quite lining up here. I guess I apologize to the community for venting my frustration with this process, but this really shouldn't be this difficult. I will follow up with more information on this debacle as it hopefully progresses. Btw, the lens part number for the SL-30 is 308-3201-42 and the lens for the GTX-327 is 470-00034-00. Matt At 11:13 AM 6/17/2015 Wednesday, Matt Dralle wrote: >In the rebuild of my RV-8 recently, I managed to get a scratch in the lens of both the Garmin SL-30 and the Garmin GTX-327. No biggie, I thought, I'll just order up a replacement and stick them in, much like I did on the King KX-125 on the RV-6. > >I called up Pacific Coast Avionics today to order the parts and was told the following: Garmin will not sell the lens. Yup, you hear that right. My only option is to return both units to Garmin for a "factory repair" and the MINIMUM charge will be $535 for EACH unit! That is $1070 to replace two $4 pieces of plastic! That is simply outrageous! Frankly, criminal behavior. > >I will NOT be buying ANY future Garmin products. I refuse to do business with a company that treats their customers this way. Unacceptable. > >- >Matt Dralle - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 182+ Hours TTSN - Version 2.0 Now Flying! RV-6 #20916 N360EM "The Flyer" http://www.mattsrv6.com - Matt's RV-6 Revitalization Log Status: 300+ Hours - Full Flyer Mode! Matt's Livermore Airport Live ATC Stream! Check out the live ATC stream directly from my hangar at the Livermore Airport. Includes both Tower and Ground transmissions. Archives too! For entertainment purposes only. http://klvk.matronics.com ________________________________________________________________________________
Date: Aug 23, 2015
Subject: S-Tec System 50 assistance
Folks, I am helping out a fellow owner-flier with some autopilot function issues. I have an S-Tec System 30 in my RV6A and I know the systems have similar functionality - albeit different installations. I have tried downloading the installation manual - but all of the places that have it seem very hokey. Anyone out there in 'list-land' have a PDF for the System 50 installation? I already have the GPSS installation documentation for the 50 as it came with my GPSS when I put it in my 6A. Thanks, Ralph Capen ________________________________________________________________________________
Subject: Headphone Jack Wiring Mono to Stereo Icom A-210
Date: Sep 09, 2015
I bought a Icom A-210. Unfortunately it has only a Mono output. Can I wire the Mono output to the Left and Right tab of a Stereo Headphone Jack? Thanks Detlef ________________________________________________________________________________
Subject: Re: Headphone Jack Wiring Mono to Stereo Icom A-210
Date: Sep 09, 2015
On 9/9/2015 6:57 PM, Detlef Heun wrote: > > I bought a Icom A-210. Unfortunately it has only a Mono output. > Can I wire the Mono output to the Left and Right tab of a Stereo > Headphone Jack? > Thanks > Detlef > > _- If the rest of the audio system is mono, then no problem. But most stereo headsets have a stereo/mono switch built in. If you have a stereo intercom, it should have a mono input for the com. ________________________________________________________________________________
Subject: Re: Headphone jack wiring
Date: Sep 10, 2015
On 9/9/15 11:59 PM, Avionics-List Digest Server wrote: > From: Detlef Heun <detlili(at)email.de> > Subject: Avionics-List: Headphone Jack Wiring Mono to Stereo Icom A-210 > > > I bought a Icom A-210. Unfortunately it has only a Mono output. > Can I wire the Mono output to the Left and Right tab of a Stereo > Headphone Jack? > Thanks You can, the problem is that if you then plug a mono headphone into the stereo jack, the sleeve (ground terminal) will connect to the right channel (ring contact of the tip-ring-sleeve jack) and short the output to ground. A solution commonly used in broadcast stations where this problem also occurs is to connect the mono output of the radio through ~300 ohm resistors to the left and right tabs of the jack. If you use a stereo headphone, the level is reduced somewhat because each channel has a resistor in series with it. If you use a mono headphone, the output sees another 300 ohms to ground rather than a dead short. It's a good compromise if the radio has enough volume to drive the headphones you're using even with the additional loss of the resistors. David Josephson ________________________________________________________________________________
Date: Sep 10, 2015
Date: Sep 22, 2015
Subject: Alternative sources for MX20 and 400W databases
Anyone out there know of any alternative sources? Are we stuck with the expensive monopoly Jeppesen? ________________________________________________________________________________
Date: Sep 24, 2015
Subject: Aviation headset shielding
I am curious if headsets need to be shielded or unshielded. I have seen both but on the ones with shielding it is not terminated at either side doesn't this make it ineffective? ________________________________________________________________________________
Subject: Garmin Brain Teaser... 320A Transponder issue....
Date: Sep 25, 2015
Avionics experts can't seem to help.... Maybe someone here can. Mounted in a Zodiac 601 XL-B is the above Transponder and encoder. Avionics experts tested it on the ground, no engine running. Antenna is shielded. Turned on, and ran tests. PERFECT signal and perfect parameters. HOWEVER.... In flight, ATC CANNOT get ANY read on me for about 15-20mins. But they do get a read eventually for the most part. Sometimes they get me as soon as I hit 2000'asl. (460' elevation). Now.... This is secondary radar out of Toronto, approx 45sm away. Two days ago, I took off, no read, not even Mode A. Nada. Made a 9 min flight north, then east further away from the radar station and after about 15mins, she got a perfect signal on me. Transponder matched my altitude and Ground speed no problem. Again.... Avionics specialist ran the system through extensive testing and the second we fire it up, and run it through its paces, comes back ultra strong. No issues. Any idea?! Cheers! Chad -------- C-GYXQ. 912ULS. 601XL-B Read this topic online here: http://forums.matronics.com/viewtopic.php?p=447428#447428 ________________________________________________________________________________
Subject: Re: Garmin Brain Teaser... 320A Transponder issue....
Date: Sep 25, 2015
How does it work in a different a/c? Typos courtesy of Siri > On Sep 25, 2015, at 06:40, SIDESLIP wrote: > > > Avionics experts can't seem to help.... Maybe someone here can. Mounted in a Zodiac 601 XL-B is the above Transponder and encoder. Avionics experts tested it on the ground, no engine running. Antenna is shielded. Turned on, and ran tests. PERFECT signal and perfect parameters. > > HOWEVER.... > > In flight, ATC CANNOT get ANY read on me for about 15-20mins. But they do get a read eventually for the most part. Sometimes they get me as soon as I hit 2000'asl. (460' elevation). Now.... This is secondary radar out of Toronto, approx 45sm away. Two days ago, I took off, no read, not even Mode A. Nada. Made a 9 min flight north, then east further away from the radar station and after about 15mins, she got a perfect signal on me. Transponder matched my altitude and Ground speed no problem. Again.... Avionics specialist ran the system through extensive testing and the second we fire it up, and run it through its paces, comes back ultra strong. No issues. > > Any idea?! > > Cheers! > > Chad > > -------- > C-GYXQ. 912ULS. 601XL-B > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=447428#447428 > > > > > > > > > > > ________________________________________________________________________________
Date: Sep 25, 2015
I have no way of trying it. No one I know has the same TX. Cheers! Chad -------- C-GYXQ. 912ULS. 601XL-B Read this topic online here: http://forums.matronics.com/viewtopic.php?p=447430#447430 ________________________________________________________________________________
Date: Sep 25, 2015
> >Avionics experts can't seem to help.... Maybe someone here can. Mounted >in a Zodiac 601 XL-B is the above Transponder and encoder. Avionics >experts tested it on the ground, no engine running. Antenna is >shielded. Turned on, and ran tests. PERFECT signal and perfect >parameters. > >HOWEVER.... > >In flight, ATC CANNOT get ANY read on me for about 15-20mins. But they >do get a read eventually for the most part. Sometimes they get me as >soon as I hit 2000'asl. (460' elevation). Now.... This is secondary >radar out of Toronto, approx 45sm away. Two days ago, I took off, no >read, not even Mode A. Nada. Made a 9 min flight north, then east >further away from the radar station and after about 15mins, she got a >perfect signal on me. Transponder matched my altitude and Ground speed >no problem. Again.... Avionics specialist ran the system through >extensive testing and the second we fire it up, and run it through its >paces, comes back ultra strong. No issues. > >Any idea?! > >Cheers! > >Chad > >-------- >C-GYXQ. 912ULS. 601XL-B > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=447428#447428 > > Pull the transponder and check the front edge of the tray. Make sure it's flush with the front side of the panel. If not, then fix it. Then make sure that the transponder seats completely when you reinstall it. Check operation on the ground with the engine running. -- Sent from my Android device with K-9 Mail. Please excuse my brevity. ________________________________________________________________________________
Date: Sep 25, 2015
Keep in mind that parts of this system have a stabilization heater associa ted in the transponder system. Sometimes I have seen those take more than 10 mins. to get the altitude encoder to stabilize at a fixed temp. The new er transponder units stay quiet until stabilized. If you are operating in cold weather, it may take even longer to get a solid reading. Let us know what you find out. . . --------------------------------------------------------------------------- ----- ----- Original Message ----- From: Charlie England To: avionics-list(at)matronics.com Sent: Friday, September 25, 2015 5:44 AM Subject: Re: Avionics-List: Garmin Brain Teaser... 320A Transponder issue =2E... e: cs experts can't seem to help.... Maybe someone here can. Mounted in a Zodi ac 601 XL-B is the above Transponder and encoder. Avionics experts tested i t on the ground, no engine running. Antenna is shielded. Turned on, and ran tests. PERFECT signal and perfect parameters. HOWEVER....In flight, ATC CA NNOT get ANY read on me for about 15-20mins. But they do get a read eventua lly for the most part. Sometimes they get me as soon as I hit 2000'asl. (46 0' elevation). Now.... This is secondary radar out of Toronto, approx 45sm away. Two days ago, I took off, no read, not even Mode A. Nada. Made a 9 m in flight north, then east further away from the radar station and after ab out 15mins, she got a perfect signal on me. Transponder matched my altitude and Ground speed no problem. Again.... Avionics specialist ran the system through extensive testing and he Web -- Sent from my Android device with K-9 Mail. Please excuse my brevity. --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Oct 04, 2015
Thank you iPhone users for waiting out the IOS 9 upgrade while the Airport Courtesy Car app was down. The app is back up for all users and the layout and look of the app has been upgraded also. The listings continue to grow, currently at over 1,520, and approaches 25,000 launches. Please continue to send in listings I have missed or corrections that need to be made and I will get right on them. And if you use and like the app, please consider a small donation to help with expenses, even the tip that you leave on the lunch counter is appreciated. There are PayPal links on the app, and my mailing address is also listed within the app. Glenn -------- Glenn Brasch RV-9A Flying 1952 Piper Tri-Pacer Medevac Helicopter Pilot (Ret) Tucson, Arizona Owner, "Airport Courtesy Cars" Smart Phone App. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=447660#447660 ________________________________________________________________________________
Date: Oct 29, 2015
Subject: Re:
http://goo.gl/tbXKfk ________________________________________________________________________________
Date: Nov 01, 2015
Subject: PLEASE READ - Matronics Email List Fund Raiser During November!
Dear Listers, Each November I hold a PBS-like fund raiser to support the continued operation and upgrade of the Email List and Fourm Services at Matronics. It's solely through the Contributions of List members (you) that these Matronics Lists are possible. You have probably noticed that there are no banner ads or pop-up windows on any of the Matronics Lists or related web sites such as the Forums site http://forums.matronics.com , Wiki site http://wiki.matronics.com , or other related pages such as the List Search Engine http://www.matronics.com/search , List Browse http://www.matronics.com/listbrowse , etc. This is because I believe in a List experience that is completely about the sport we all enjoy - namely Airplanes and not about annoying advertisements. During the month of November I will be sending out List messages every couple of days reminding everyone that the Fund Raiser is underway. I ask for your patience and understanding during the Fund Raiser and throughout these regular messages. The Fund Raiser is only financial support mechanism I have to pay all of the bills associated with running these lists. YOUR personal Contribution counts! This year we have a really HUGE and TERRIFIC line up of free gifts to go along with the various Contribution levels. In fact, there are over 30 different gifts to choose from - more than we've ever had before! There's something for everyone, to be sure. Most all of these gifts have been provided by some of the vary members and vendors that you'll find on the Matronics Lists and they have been either donated or provided at substantially discounted rates. This year, these generous members include: Andy Gold of the Builder's Bookstore http://www.buildersbooks.com These are very generous guys and I encourage you to visit their respective web sites. Each one offers a unique and excellent aviation-related product line. I would like publicly to thank Andy, Bob, Corbin, George, and Jon their generous support of the Lists again this year!! Please make your List Contribution using any one of three secure methods including using a credit card, PayPal, or by personal check. All three methods afford you the opportunity to select one of this year's free gifts with a qualifying Contribution amount!! To make your Contribution, please visit the secure web site: http://www.matronics.com/contribution I would like to thank everyone in advance for their generous financial AND moral support over the years! Thank you! Matt Dralle Matronics Email List Administrator RV-4/RV-6/RV-8 Builder/Rebuilder/Pilot ________________________________________________________________________________
Date: Nov 04, 2015
Subject: Please Make A Contribution To Support Your Lists
Dear Listers, There is no advertising income to support the Matronics Email Lists and Forums. The operation is supported 100% by your personal Contributions during the November Fund Raiser. Please make your Contribution today to support the continued operation and upgrade of these services. You can pick up a really nice gift for making your Contribution too! You may use a Credit Card or Paypal at the Matronics Contribution Site here: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you in advance for your generous support! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 05, 2015
Subject: Coming Soon - The List of Contributors - Please Make A
Contribution Today! Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Please take a moment and assure that your name is on that List of Contributors (LOC)! As a number of members have pointed out over the years, the List seems at least as valuable a building / entertainment tool as your typical magazine subscription! Assure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 07, 2015
Subject: Please Make a Contribution to Support Your Lists...
Dear Listers, Just a reminder that November is the Annual List Fund Raiser. Please make a Contribution today to support the continued operation and upgrade of these great List services!! Pick up a really nice free gift with your qualifying Contribution too! The Contribution Site is fast and easy: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94551-0347 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 09, 2015
Subject: A List Contribution - It's Your Personal Squelch Button...
There is an automatic "squelch button" of sorts for the Fund Raiser messages. Here's how it works... As soon as a List member makes a Contribution through the Matronics Fund Raiser web site, their email address is automatically added to this year's Contributor List and they instantly cease to receive further Fund Raiser messages for the rest of the month! Its just that simple! :-) I really do appreciate each and every one of your individual Contributions to support the Lists. It is your support that enables me to upgrade the hardware and software that are required to run a List Site such as this one. It also goes to pay for the commercial-grade Internet connection and to pay the huge electric bill to keep the computer gear running and the air conditioner powered on. I run all of the Matronics Email List and Forums sites here locally which allows me to control and monitor every aspect of the system for the utmost in reliably and performance. Your personal Contribution matters because, when combined with other Listers such as yourself, it pays the bills to keep this site up and running. I accept exactly ZERO advertising dollars for the Matronics Lists sites. I can't stand the pop-up ads and all other commercials that are so prevalent on the Internet these days and I particularly don't want to have it on my Email List sites. If you appreciate the ad-free, grass-roots, down-home feel of the Matronics Email Lists, please make a Contribution to keep it that way!! http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you! Matt Dralle Matronics Email List Administrator [Note that there are certain circumstances where you might still see a Contribution related message. For example, if someone replies to one of the messages, when using the List Browse feature, or when accessing List message via the Forum. The system keys on the given email address and since most of these are anonymous public access methods, there is no simple way to filter them.] ________________________________________________________________________________
Date: Nov 11, 2015
Subject: [PLEASE READ] Why I Have A Fund Raiser...
Since the beginning, the Matronics List and Forum experience has been free from advertising. I have been approached by fair number of vendors wanting to tap into the large volume of activity across the various lists hosted here, but have always flatly refused. Everywhere you go on the Internet these days, a user is pummeled with flashing banners and videos and ads for crap that they don't want. Yahoo, Google and that ilk are not "free". The user must constantly endure their barrage of commercialism thrust into their face at an ever increasing rate. Enough is enough, and the Lists at Matronics choose not to succumb to that. That being said, running a service of this size is not "free". It costs a lot of money to maintain the hardware, pay for the electricity, air conditioning, maintenance contracts, etc, etc. etc. I choose to hold a PBS-like fund raiser each year during the month of November where I simply send out a short email every other day asking the members to make a small contribution to support the operation. That being said, that contribution is completely voluntary and non-compulsory. Many members choose not to contribute and that's fine. However, a very modest percentage of the members do choose to make a contribution and it is that financial support that keeps the Lists running. And that's it. To my way of thinking, it is a much more pleasant way of maintaining the Lists and Forums. The other 11 months of the year, you don't see a single advertisement or request for support. That's refreshing and that is a List and Forum that I want to belong to. I think other people feel the same way. Won't you please take a minute to make your Contribution today and support these Lists? http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Date: Nov 12, 2015
Subject: doRNE C-70 aNTENNA pROBLEMS
ood morning, I wanted to ask about a problem we are having a c-70 dorne a cessan 150. We had an escort radio- vor 110 radio, and now a narco Radio 120. The problem is that the antenna is not working. We have disarmed the antenna and do not see anything wrong, like check the antenna, and found on the antenna plate containing two terminal cabels soldiers, I do not have to work that way. Someone knows how to make an antenna for the 118-137 MHz frequency. to replace given that their cost is very high. thanks you ________________________________________________________________________________
Date: Nov 13, 2015
Subject: Make Sure You're Listed! List of Contributors Published
in December! Dear Listers, The List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 15, 2015
Subject: Reminder
Dear Listers, A quick reminder that November is the annual Matronics List Fund Raiser. The Lists are 100% member supported and all of the operational costs are covered solely through your Contributions during this time of the year. *Your* personal Contribution makes a difference and keeps all of the Matronics Email Lists and Forums completely ad-free. Please make your Contribution today to keep these services up and running for another great year! Use a credit card or your PayPal account here: http://www.matronics.com/contribution Or, by sending a personal check to: Matronics / Matt Dralle 581 Jeannie Way Livermore CA 94550 Thank you in advance! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 16, 2015
Subject: List Contribution - Value of the List...
If you look forward to checking your List email everyday (and a lot of you have written to say that you do!), then you're probably getting at least $20 or $30 worth of Entertainment from the Lists each year. You'd pay twice that for a subscription to some magazine or even a dinner out. Isn't the List worth at least that much to you? Wouldn't it be great if you could pay that amount and get a well-managed media source free of advertising, SPAM, and viruses? Come to think of it, you do... :-) Won't you please take a minute to make your Contribution today and support these Lists? http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I want to say THANK YOU to everyone that has made a Contribution thus far during this year's List Fund Raiser!! These Lists are made possible exclusively through YOUR generosity!! Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Date: Nov 18, 2015
Subject: What's Your Contribution Used For?
Dear Listers, You might have wondered at some point, "What's my Contribution used for?" Here are just a few examples of what your direct List support enables... It provides for the expensive, commercial-grade Internet connection used on the List. It pays for the regular system hardware and software upgrades enabling the highest performance possible for List services such as the Archive Search Engine, List Browser, and the Web Forums. It pays for the over 23 years of on-line archive data always available for instant search and access. And, it offsets the many hours spent writing, developing, and maintaining the custom applications that power these List Service such as the List Browse, Search Engine, Forums, and Wiki. But most importantly, your List Contribution enables a forum where you and your peers can communicate freely in an environment that is free from moderation, censorship, advertising, commercialism, SPAM, and computer viruses. It is YOUR CONTRIBUTION that directly enables all these aspects of Matronics List services. Please support it today with your List Contribution. Its one of the best investments you can make in your Sport! List Contribution Web Site: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you for your support! Matt Dralle Email List Administrator ________________________________________________________________________________
Date: Nov 20, 2015
Dear Listers, Just a reminder that November is the Annual List Fund Raiser. Please make a Contribution today to support the continued operation and upgrade of these great List services!! Pick up a really nice free gift with your qualifying Contribution too! The Contribution Site is fast and easy: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: Re: doRNE C-70 aNTENNA pROBLEMS
Date: Nov 21, 2015
I had the same D&M type on my C150 but it didnt look like your connection plate photo They are a good antenna and are better for the full aircraft band 118-137 than a simple rod antenna Usually it is best to replace - maybe a used one - to fit the same mounting holes on your aircraft. Actually for my 150 I bought a second one and mounted it on the other side. They were not expensive when you consider the mounting requirements and the wide bandwidth. The rod antennas sold for cropdusters etc. are very stiff and heavy so would damage the C150 they are cheaper I got one from ACS but cut it off and welded a tapered stainless steel rod from a radiotelephone antenna supplier instead. Its OK for my microlight where i also have a couple of minature R/T antenna bases on but for a C150 you would need something that looks like it has TSO approval..... Ralph -------- Ralph - CH701 / 2200a Read this topic online here: http://forums.matronics.com/viewtopic.php?p=449865#449865 ________________________________________________________________________________
Date: Nov 22, 2015
Date: Nov 23, 2015
Subject: Fund Raiser Behind By 22% - Please Contribute Today!
Dear Listers, The percentage of members making a Contribution to support the Lists this year is currently behind last year by at this time by roughly 22%. Please take this opportunity to show your support for the Matronics Lists and Forums! Please remember that it is *solely* your direct Contributions that keep these Lists and Forums up and running and most importantly - AD FREE! If the members don't want to support the Lists directly, then I might have to add advertisements to offset the costs of running the Lists. But I don't want to have to do that. I really like the non-commercial atmosphere here and I think that a lot of the members appreciate that too. Please take a moment to make a Contribution today in support of the continued ad-free operation of all these Lists: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I want to send out a word of appreciation to all of the members that have already made their generous Contribution to support the Lists! Thank you! Matt Dralle Email List and Forums Administrator ________________________________________________________________________________
Date: Nov 24, 2015
Subject: Just A Few Days Left...
Dear Listers, There are just a few days left for this year's List Fund Raiser. If you've been putting off making a Contribution until the last minute, well, this is it! The last minute, that is... :-) There are some GREAT new gift selections to choose from this year. I personally want at least three of them! There's probably something you can't live without too! And, best of all it supports your Lists! Please remember that there isn't any sort of commercial advertising on the Lists and the *only* means of keeping these Lists running is through your Contributions during this Fund Raiser. Let's make this a "Black Friday" for the Lists! Please make a Contribution today! http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 25, 2015
Subject: What Are You Thankful For...?
Dear Listers, Here in the United States, Thursday is our National day of Thanksgiving. Many of us will be traveling to be with our families and friends to share in generous feasts of plenty and giving thanks for the many blessings that have been bestowed upon us. Many Listers have expressed over the last couple of weeks how thankful they are for the Email Lists and Forums here on the Matronics servers and for all of the assistance and comradery they have experienced being a part of the Lists. One of my favorite comments is when someone writes to me and says something like, "Its the first thing I do in the morning while I'm having my morning coffee!". That's a wonderful tribute to the purpose and function of these Lists. Its always great to hear I'm not the only one that jumps out of bed each morning to check my List email!! Won't you take a minute today and show your appreciation for these Lists and for their continued operation and upgrade? The List Contribution Site is: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you in advance for your kind consideration, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 27, 2015
Subject: Make Sure You're Listed! List of Contributors Coming Soon!
Dear Listers, There's just three more days left in this year's List Fund Raiser and that means the List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 28, 2015
Subject: Fund Raiser - Just Two Days Left! - Still Well Behind...
Dear Listers, There are just two more full days left in this year's List Fund Raiser. Over the last couple of weeks I have received some really nice comments from members on what the Lists have meant to them and I really appreciate the feedback! At this point, unfortunately, we are still well behind last year in total Contributions to support the continued operation of these services. I really want to keep providing these Lists and Forums to the home built community, but it takes resources. Since there's no advertising budget or deep pockets to keep the operation a float, it's *solely your generosity* during the yearly Fund Raiser that keeps things going. Please make a Contribution today so that I can keep the bills paid and the services and systems turned on. If you've been putting off showing your support for the Lists, now is the time to do it! To make a contribution with a Credit Card or though PayPal at that Matronics Contribution web site: http://www.matronics.com/contribution Or, drop a check in the mail: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 USA Thank you in advance for your support! It is very much appreciated... Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 29, 2015
Since the beginning, the Matronics List and Forum experience has been free from advertising. I have been approached by fair number of vendors wanting to tap into the large volume of activity across the various lists hosted here, but have always flatly refused. Everywhere you go on the Internet these days, a user is pummeled with flashing banners and videos and ads for crap that they don't want. Yahoo, Google and that elk are not "free". The user must constantly endure their barrage of commercialism thrust into their face at an ever increasing rate. Enough is enough, and the Lists at Matronics choose not to succumb to that. That being said, running a service of this size is not "free". It costs a lot of money to maintain the hardware, pay for the electricity, air conditioning, maintenance contracts, etc, etc. etc. I choose to hold a PBS-like fund raiser each year during the month of November where I simply send out a short email every other day asking the members to make a small contribution to support the operation. That being said, that contribution is completely voluntary and non-compulsory. Many members choose not to contribute and that's fine. However, a very modest percentage of the members do choose to make a contribution and it is that financial support that keeps the Lists running. And that's it. To my way of thinking, it is a much more pleasant way of maintaining the Lists and Forums. The other 11 months of the year, you don't see a single advertisement or request for support. That's refreshing and that is a List and Forum that I want to belong to. I think other people feel the same way. Won't you please take a minute to make your Contribution today and support these Lists? http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Date: Nov 30, 2015
Subject: [Please Read] - Last Official Day of List Fund Raiser!
Dear Listers, It's November 30th and that always means a couple of things. Its my birthday again - 52, so don't remind me! :-) But it also means that it's that last official day of the Matronics Email List Fund Raiser! If you been thinking about picking up one of those really nice incentive gifts now is the time to jump on it!! If you've been meaning to make a Contribution this month but have been putting it off for some reason, NOW is the time! I will be posting the List of Contributors in a few days, so you'll probably want to be known as a person that supported the Lists! I want to thank everyone that has so generously made a Contribution this year in support of our Lists. It is your generosity that keeps this operation running and I don't ever forget it. The List Contribution Web Site is fast and easy. Please support our habit by making your Contribution right now: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you in advance! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Dec 19, 2015
Subject: Auction For P113 eMag To Support Matronics List Fund Raiser
Dear Listers, Bob Nuckolls of the AeroElectric fame has generously put a new eMag P113 electronic 4-cylinder mag up for sale on EBay. Bob has pledged to donate all of the proceeds from this auction in support of this year's Matronics Fund Raiser. If you are in the market for one of these great electronic ignitions (I have two eMags on my RV-8 and love them), please bid on this one! http://www.ebay.com/itm/151920582478 Thank you in advance! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Dec 19, 2015
Subject: 2015 List of Contributors
Dear Listers, The 2015 Matronics Email List and Forum Fund Raiser officially ended a couple of weeks ago and it's time that I published this year's List of Contributors. It is the people on this list that directly make these Email Lists and Forums possible! Their generous Contributions keep the servers and Internet connection up and running! You can still show your support this year and pick up a great gift at the same time. The Contribution Web Site is fast, easy, and secure: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I also want to thank Andy, Bob, and George for their generous support through the supply of many great gifts this year!! These guys have some excellent products and I encourage you to visit their respective web sites: Andy Gold - The Builder's Bookstore - http://www.buildersbooks.com Bob Nucklolls - AeroElectric - http://www.aeroelectric.com George Race - Race Consulting - http://www.mrrace.com And finally, I'm proud to present The 2015 Fund Raiser List of Contributors: http://www.matronics.com/loc/2015.html Thanks again to everyone that made a Contribution this year!! Matt Dralle Matronics Email List & Forum Administrator ________________________________________________________________________________
Date: Mar 16, 2016
We just completed a major upgrade to Airport Courtesy Cars App, which now makes the app available on ALL devices, including the web. Please upgrade your app to the latest version. If your phone does not support the app, then go to our new website, www.airportcourtesycars.com The site is mobile friendly and you can place its icon to your phone or tablet screen. Both versions show Google maps for each state, the app version still shows the entire US map which some people prefer. The site currently lists over 1560 cars. Thanks for your input and contact us with any questions, new listings, or corrections to airportcars101(at)gmail.com And please check out our advertisers and FBOs who offer you fuel discounts. The app remains free. -------- Glenn Brasch RV-9A Flying Medevac Helicopter Pilot (Ret) Owner, "Airport Courtesy Cars" Smart Phone App and www.airportcourtesycars.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=453849#453849 ________________________________________________________________________________
Date: Apr 19, 2016
Subject: Matronics Web Server Back Online
Dear Listers, The Matronics Web server lost a critical system hard drive yesterday 4/18/2016. I have been working feverishly for the last 24 hours to repair the system and get the Matronics Forums and other web-based resources back online. Email services were not impacted in anyway. back online and all resources were successfully restored from a backup. My apologies for the down time. Matt Dralle Matronics Email and Forum Admin ________________________________________________________________________________
Date: May 10, 2016
Subject: Narco NAV122D/GPS driving STEC-30 Autopilot
Anyone out there using a NARCO to drive their AP? I'm trying to determine if there are any gotchas with the interface / installation. I have both running nicely - but not touching each other...yet. I'm looking to drive the AP TRK feature from the NARCO by pulling off the needle signal - just like the SL-30 (which works nicely). Looking for diversity and backup. Thanks, Ralph Capen ________________________________________________________________________________
Date: May 16, 2016
Subject: Tru-Trak roll servo in 6/6A wing
Anyone have a TruTrak servo installed in the wing? >From memory, there previously was a wing bracket - but not currently. Looking for drawings to make the wing install bracket - the place under the seats has too much other difficult to relocate stuff... Thanks, Ralph Capen ________________________________________________________________________________
Date: May 16, 2016
Subject: Re: [RV Builders] Re: Tru-Trak roll servo in 6/6A wing
Thanks Dan - I already had those drawings... The 6/6A wing is different internally - they built the bellcrank with a different method. I now have the three drawings for the 6/6A left wing- but are still looking for the details for the "Servo Mount Bracket" referenced in those drawings. I suppose I could cobble something together but was trying to go with what already worked. Anyone with details on the "Servo Mount Bracket" - help would be greatly appreciated. Ralph -----Original Message----- From: "dbygroups(at)gmail.com [RV7A]" Sent: May 16, 2016 11:34 AM Subject: [RV Builders] Re: Tru-Trak roll servo in 6/6A wing Ralph... The drawings I think you want (for a 7 in the right wing) are at http://www.trutrakap.com/wp-content/uploads/2014/03/RV-710RightWing.pdf Dan __._,_.___ Posted by: dbygroups(at)gmail.com Want more RV news? Sign up for the RV Builder's Hotline. It's free! http://rvbuildershotline.com Visit Your Group Privacy Unsubscribe Terms of Use __,_._,___ ________________________________________________________________________________
From: "bigdog(at)bentwing.com" <bigdog(at)bentwing.com>
wing
Date: May 16, 2016
I'm guessing you've checked with Tru-Trak? They seemed to try hard to accommodate all installs back then. When I was planning to add the roll servo to my -6 I thought I'd mount it in the wing and use the -7 mount. I don't remember any one talking about problems with it but did not investigate it that deeply as I decided to go with the under seat mount. If it helps I don't see any reason why you couldn't mount it under either seat. You could also consider the Navaid approach and mount the servo in the wingtip with a long pushrod to the bellcrank. I've got the mount and pushrod from my 1st RV-6 if you want to see how that worked. Greg Young -----Original Message----- From: owner-avionics-list-server(at)matronics.com [mailto:owner-avionics-list-server(at)matronics.com] On Behalf Of Ralph E. Capen Sent: Monday, May 16, 2016 12:53 PM Subject: Avionics-List: Re: [RV Builders] Re: Tru-Trak roll servo in 6/6A wing --> Thanks Dan - I already had those drawings... The 6/6A wing is different internally - they built the bellcrank with a different method. I now have the three drawings for the 6/6A left wing- but are still looking for the details for the "Servo Mount Bracket" referenced in those drawings. I suppose I could cobble something together but was trying to go with what already worked. Anyone with details on the "Servo Mount Bracket" - help would be greatly appreciated. Ralph -----Original Message----- From: "dbygroups(at)gmail.com [RV7A]" Sent: May 16, 2016 11:34 AM Subject: [RV Builders] Re: Tru-Trak roll servo in 6/6A wing Ralph... The drawings I think you want (for a 7 in the right wing) are at http://www.trutrakap.com/wp-content/uploads/2014/03/RV-710RightWing.pdf Dan __._,_.___ Posted by: dbygroups(at)gmail.com Want more RV news? Sign up for the RV Builder's Hotline. It's free! http://rvbuildershotline.com Visit Your Group Privacy Unsubscribe Terms of Use __,_._,___ ________________________________________________________________________________
Date: May 16, 2016
wing Thanks Greg - I'll zap you directly! -----Original Message----- >From: "bigdog(at)bentwing.com" <bigdog(at)bentwing.com> >Sent: May 16, 2016 2:39 PM >To: "avionics-list(at)matronics.com" , rv-list >Subject: RE: Avionics-List: Re: [RV Builders] Re: Tru-Trak roll servo in 6/6A wing > > >I'm guessing you've checked with Tru-Trak? They seemed to try hard to accommodate all installs back then. When I was planning to add the roll servo to my -6 I thought I'd mount it in the wing and use the -7 mount. I don't remember any one talking about problems with it but did not investigate it that deeply as I decided to go with the under seat mount. If it helps I don't see any reason why you couldn't mount it under either seat. You could also consider the Navaid approach and mount the servo in the wingtip with a long pushrod to the bellcrank. I've got the mount and pushrod from my 1st RV-6 if you want to see how that worked. > >Greg Young > >-----Original Message----- >From: owner-avionics-list-server(at)matronics.com [mailto:owner-avionics-list-server(at)matronics.com] On Behalf Of Ralph E. Capen >Sent: Monday, May 16, 2016 12:53 PM >To: rv-list ; avionics-list(at)matronics.com >Subject: Avionics-List: Re: [RV Builders] Re: Tru-Trak roll servo in 6/6A wing > >--> > >Thanks Dan - I already had those drawings... > >The 6/6A wing is different internally - they built the bellcrank with a different method. > >I now have the three drawings for the 6/6A left wing- but are still looking for the details for the "Servo Mount Bracket" referenced in those drawings. I suppose I could cobble something together but was trying to go with what already worked. > >Anyone with details on the "Servo Mount Bracket" - help would be greatly appreciated. > >Ralph > >-----Original Message----- > >From: "dbygroups(at)gmail.com [RV7A]" > >Sent: May 16, 2016 11:34 AM > >To: RV7A(at)yahoogroups.com > >Subject: [RV Builders] Re: Tru-Trak roll servo in 6/6A wing > > > > > > >Ralph... > >The drawings I think you want (for a 7 in the right wing) are at http://www.trutrakap.com/wp-content/uploads/2014/03/RV-710RightWing.pdf > >Dan > > >__._,_.___ > > > > > > > > Posted by: dbygroups(at)gmail.com > > > >Want more RV news? Sign up for the RV Builder's Hotline. It's free! > >http://rvbuildershotline.com > > > > > > > > > > > > > > > Visit Your Group > > > > > > > > Privacy Unsubscribe Terms of Use > > > > > > > > > > >__,_._,___ > > ________________________________________________________________________________
Date: May 29, 2016
Subject: Re: Avionics-List Digest: 0 Msgs - 05/27/16
please unsubscribe _yanisk(at)aol.com_ (mailto:yanisk(at)aol.com) In a message dated 5/28/2016 12:07:09 A.M. US Mountain Standard Time, avionics-list(at)matronics.com writes: * ================================================= Online Versions of Today's List Digest Archive ================================================= Today's complete Avionics-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the Avionics-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 16-05-27&Archive=Avionics Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 2016-05-27&Archive=Avionics =============================================== EMail Version of Today's List Digest Archive =============================================== ---------------------------------------------------------- Avionics-List Digest Archive --- Total Messages Posted Fri 05/27/16: 0 ---------------------------------------------------------- Today's Message Index: ---------------------- ________________________________________________________________________________
Subject: Impedance matching
Date: Jun 01, 2016
Hi all, I am trying to hook up audio outputs from a Garrecht TRX-1500 (3Vpp, 8 Ohm) and Dynon Skyview (10V, 50 Ohm, output volume controllable by software setting) into a PMA5000EX (510 Ohm, max 3Vpp input or "damage will occur"). Partial feedback from suppliers is confusing - according to PSE / ACS the Skyview should be OK if I hook it up directly (despite potentially much higher output voltage than the audio panel accepts), but the TRX-1500 is allegedly problematic despite the relatively low output voltage. I am tending towards fitting a 470 Ohm trim pot across each output as a voltage divider using the wiper as input for the audio panel, more or less as proposed by Garrecht for a line level input. Can anyone tell me if I am on the right or wrong track? Gordon Anderson Switzerland, Van's RV-10 - 41015 ________________________________________________________________________________
Date: Jun 08, 2016
Subject: Interfacing MX-20 (or GMX-200) with NavWorx ADS600-B
Folks, Anyone out there using either a MX-20 or GMX-200 as the display for their NavWorx ADS600-B UAT? I'm trying to figure out the settings to be applied to the MX-20 - there isn't anything I can find in the manual. I've sent a note to NavWorx - no response so far. There's a setting hint for the 400W/500W in the NavWorx manual, so that one was easy. It tells you to set it up as getting a GTX330 feed. Thanks, Ralph Capen ________________________________________________________________________________
Date: Jun 08, 2016
UmFscGgsDQoNCg0KDQpJIGluc3RhbGxlZCBpdCB3aXRoIG15IE1YLTIwLiBJJ3ZlIHNpbmNlIHJl d29ya2VkIG15IHBhbmVsIGFuZCByZXBsYWNlZCBpdCB3aXRoIGEgNzk2IGluIGFuIEFpckdpem1v IGRvY2suIEJ1dCBJJ3ZlIHN0aWxsIGdvdCBzb21lIHBpY3R1cmVzIG9mIHRoZSBzZXR0aW5ncy4g VGhlIHJlbGV2YW50IG9uZXMgYXJlOg0KDQoNCg0KTWlzYyBTZXR1cDogR0RMIDkwIFVBVCBSYWRp byA9IERpc3AgT25seSwgR0RMIDkwIENvZGUgRWRpdCA9IEVuYWJsZWQNCg0KRXh0ZXJuYWwgRGF0 YSBTb3VyY2VzOiBVQVQgVHJhZmZpYy9EYXRhIExpbmsgU291cmNlID0gUG9ydCA0IChmb3IgbWUp DQoNCkVuYWJsZS9EaXNhYmxlIEZ1bmN0aW9uOiBUcmFmZmljID0gRW5hYmxlZCwgRklTIERhdGEg TGluayA9IEVuYWJsZWQNCg0KDQoNCkFsc28gbWFrZSBzdXJlIHlvdSBzZXQgdGhlIEJyb2FkY2Fz dCBJQ0FPIEFkZHJlc3MuIEkgZG9u4oCZdCBrbm93IHdoaWNoIHNjcmVlbiBpbiBzZXR1cC4gSXTi gJlzIHRoZSA4IGRpZ2l0IGhleC1sb29raW5nIE1vZGUtUyBjb2RlIHRoYXQgdHJhbnNsYXRlcyB0 byB5b3VyIE4tbnVtYmVyLiBGb3Igd2hhdGV2ZXIgcmVhc29uIEkgcHV0IG15IE4tbnVtYmVyIGlu IGl0IGFuZCBmb3VnaHQgYW4gZXJyb3IgbWVzc2FnZSBmb3IgYSB3aGlsZS4NCg0KDQoNCkkgZ290 IHRyYWZmaWMgYW5kIE1ldGFycyBvbiB0aGUgTVgtMjAgYnV0IG9ubHkgdHJhZmZpYyBvbiB0aGUg NDMwVy4gSeKAmW0gdmVyeSBkaXNhcHBvaW50ZWQgd2l0aCB0aGUgZGlzcGxheSBvbiB0aGUgNDMw Vy4gU2luY2UgR2FybWluIGRvZXNu4oCZdCBwbGF5IG5pY2Ugd2l0aCBvdGhlcnMgTmF2d29yeCBj YW4gb25seSBmZWVkIGl0IHRyYWZmaWMgYW5kIHlvdSBkb27igJl0IGdldCBhbGwgdGhlIGNhcGFi aWxpdHkgb2YgdGhlIDQzMFcgdGhhdCBpdCBoYXMgd2l0aCBzYXkgYSBHREwtODguIEkgbG92ZSB0 aGUgZGlzcGxheSBvbiB0aGUgNzk2IGJ1dCB1bmZvcnR1bmF0ZWx5IE5hdndvcnggZG9lc27igJl0 IHN1cHBvcnQgaXQgZWl0aGVyLCBhZ2FpbiBiZWNhdXNlIEdhcm1pbiBkb2VzbuKAmXQgcGxheSBu aWNlIGFuZCB0aGV5IGhhdmVu4oCZdCByZXZlcnNlIGVuZ2luZWVyZWQgaXQuIFNvIEnigJltIGZl ZWRpbmcgaXQgZnJvbSBhIEdETC0zOSB3b3JrcyB3ZWxsIGRlc3BpdGUgYmVpbmcgdG90YWxseSBz ZXBhcmF0ZS4NCg0KDQoNCkdvb2QgbHVjay4gSWYgbmVlZGVkIEkgY2FuIHNlbmQgdGhlIHBpY3Mg b2YgdGhlIHNldHVwIHNjcmVlbnMuDQoNCg0KDQpHcmVnIFlvdW5nDQoNCg0KDQotLS0tLU9yaWdp bmFsIE1lc3NhZ2UtLS0tLQ0KRnJvbTogb3duZXItYXZpb25pY3MtbGlzdC1zZXJ2ZXJAbWF0cm9u aWNzLmNvbSBbbWFpbHRvOm93bmVyLWF2aW9uaWNzLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb21d IE9uIEJlaGFsZiBPZiBSYWxwaCBFLiBDYXBlbg0KU2VudDogV2VkbmVzZGF5LCBKdW5lIDA4LCAy MDE2IDc6NTMgQU0NClRvOiBhdmlvbmljcy1saXN0QG1hdHJvbmljcy5jb207IHJ2LWxpc3QgPHJ2 LWxpc3RAbWF0cm9uaWNzLmNvbT4NClN1YmplY3Q6IEF2aW9uaWNzLUxpc3Q6IEludGVyZmFjaW5n IE1YLTIwIChvciBHTVgtMjAwKSB3aXRoIE5hdldvcnggQURTNjAwLUINCg0KDQoNCi0tPiBBdmlv bmljcy1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiAiUmFscGggRS4gQ2FwZW4iDQoNCi0tPiA8cmVj YXBlbkBlYXJ0aGxpbmsubmV0PG1haWx0bzpyZWNhcGVuQGVhcnRobGluay5uZXQ+Pg0KDQoNCg0K Rm9sa3MsDQoNCg0KDQpBbnlvbmUgb3V0IHRoZXJlIHVzaW5nIGVpdGhlciBhIE1YLTIwIG9yIEdN WC0yMDAgYXMgdGhlIGRpc3BsYXkgZm9yIHRoZWlyIE5hdldvcnggQURTNjAwLUIgVUFUPw0KDQoN Cg0KSSdtIHRyeWluZyB0byBmaWd1cmUgb3V0IHRoZSBzZXR0aW5ncyB0byBiZSBhcHBsaWVkIHRv IHRoZSBNWC0yMCAtIHRoZXJlIGlzbid0IGFueXRoaW5nIEkgY2FuIGZpbmQgaW4gdGhlIG1hbnVh bC4gIEkndmUgc2VudCBhIG5vdGUgdG8gTmF2V29yeCAtIG5vIHJlc3BvbnNlIHNvIGZhci4NCg0K DQoNClRoZXJlJ3MgYSBzZXR0aW5nIGhpbnQgZm9yIHRoZSA0MDBXLzUwMFcgaW4gdGhlIE5hdldv cnggbWFudWFsLCBzbyB0aGF0IG9uZSB3YXMgZWFzeS4gIEl0IHRlbGxzIHlvdSB0byBzZXQgaXQg dXAgYXMgZ2V0dGluZyBhIEdUWDMzMCBmZWVkLg0KDQoNCg0KVGhhbmtzLA0KDQpSYWxwaCBDYXBl bg0KDQoNCg0KDQoNCg0KDQoNCg0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT0NCg0KXy09ICAgICAgICAgIC0gVGhlIEF2aW9uaWNz LUxpc3QgRW1haWwgRm9ydW0gLQ0KDQpfLT0gVXNlIHRoZSBNYXRyb25pY3MgTGlzdCBGZWF0dXJl cyBOYXZpZ2F0b3IgdG8gYnJvd3NlIF8tPSB0aGUgbWFueSBMaXN0IHV0aWxpdGllcyBzdWNoIGFz IExpc3QgVW4vU3Vic2NyaXB0aW9uLCBfLT0gQXJjaGl2ZSBTZWFyY2ggJiBEb3dubG9hZCwgNy1E YXkgQnJvd3NlLCBDaGF0LCBGQVEsIF8tPSBQaG90b3NoYXJlLCBhbmQgbXVjaCBtdWNoIG1vcmU6 DQoNCl8tPQ0KDQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9B dmlvbmljcy1MaXN0DQoNCl8tPQ0KDQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KDQpfLT0gICAgICAgICAgICAgICAtIE1BVFJP TklDUyBXRUIgRk9SVU1TIC0NCg0KXy09IFNhbWUgZ3JlYXQgY29udGVudCBhbHNvIGF2YWlsYWJs ZSB2aWEgdGhlIFdlYiBGb3J1bXMhDQoNCl8tPQ0KDQpfLT0gICAtLT4gaHR0cDovL2ZvcnVtcy5t YXRyb25pY3MuY29tDQoNCl8tPQ0KDQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KDQpfLT0gICAgICAgICAgICAgIC0gTkVXIE1B VFJPTklDUyBMSVNUIFdJS0kgLQ0KDQpfLT0gQWRkIHNvbWUgaW5mbyB0byB0aGUgTWF0cm9uaWNz IEVtYWlsIExpc3QgV2lraSENCg0KXy09ICAgLS0+IGh0dHA6Ly93aWtpLm1hdHJvbmljcy5jb20N Cg0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT0NCg0KXy09ICAgICAgICAgICAgIC0gTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGUg LQ0KDQpfLT0gIFRoYW5rIHlvdSBmb3IgeW91ciBnZW5lcm91cyBzdXBwb3J0IQ0KDQpfLT0gICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAtTWF0dCBEcmFsbGUsIExpc3QgQWRtaW4uDQoNCl8t PSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uDQoNCl8tPT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQoN Cg0KDQoNCg0KDQoNCg0KDQoNCg= ________________________________________________________________________________
Date: Jun 08, 2016
SGVyZeKAmXMgYSBsaW5rIHRvIHNvbWUgcGljdHVyZXMgb2YgbXkgTVgtMjAgc2V0LXVwIHNjcmVl bnMuIFRoZXJlIGFyZSBhbHNvIHNvbWUgaW4gdXNlIHNob3RzIG9mIHRoZSB0cmFmZmljIGRpc3Bs YXlzIG9uIG15IDQzMFcsIE1YLTIwIGFuZCA3OTYuDQpodHRwczovL29uZWRyaXZlLmxpdmUuY29t L3JlZGlyP3Jlc2lkPTE0MjEwNjRCRkM4OTJEQTEhMTQzODEmYXV0aGtleT0hQU9DMmI4bTU5VnQ1 Rk84Jml0aGludD1mb2xkZXIlMmNqcGcNCg0KDQpHcmVnDQoNCkZyb206IG93bmVyLWF2aW9uaWNz LWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb20gW21haWx0bzpvd25lci1hdmlvbmljcy1saXN0LXNl cnZlckBtYXRyb25pY3MuY29tXSBPbiBCZWhhbGYgT2YgYmlnZG9nQGJlbnR3aW5nLmNvbQ0KU2Vu dDogV2VkbmVzZGF5LCBKdW5lIDA4LCAyMDE2IDEwOjAzIEFNDQpUbzogYXZpb25pY3MtbGlzdEBt YXRyb25pY3MuY29tOyBydi1saXN0IDxydi1saXN0QG1hdHJvbmljcy5jb20+DQpTdWJqZWN0OiBS RTogQXZpb25pY3MtTGlzdDogSW50ZXJmYWNpbmcgTVgtMjAgKG9yIEdNWC0yMDApIHdpdGggTmF2 V29yeCBBRFM2MDAtQg0KDQoNClJhbHBoLA0KDQoNCg0KSSBpbnN0YWxsZWQgaXQgd2l0aCBteSBN WC0yMC4gSSd2ZSBzaW5jZSByZXdvcmtlZCBteSBwYW5lbCBhbmQgcmVwbGFjZWQgaXQgd2l0aCBh IDc5NiBpbiBhbiBBaXJHaXptbyBkb2NrLiBCdXQgSSd2ZSBzdGlsbCBnb3Qgc29tZSBwaWN0dXJl cyBvZiB0aGUgc2V0dGluZ3MuIFRoZSByZWxldmFudCBvbmVzIGFyZToNCg0KDQoNCk1pc2MgU2V0 dXA6IEdETCA5MCBVQVQgUmFkaW8gPSBEaXNwIE9ubHksIEdETCA5MCBDb2RlIEVkaXQgPSBFbmFi bGVkDQoNCkV4dGVybmFsIERhdGEgU291cmNlczogVUFUIFRyYWZmaWMvRGF0YSBMaW5rIFNvdXJj ZSA9IFBvcnQgNCAoZm9yIG1lKQ0KDQpFbmFibGUvRGlzYWJsZSBGdW5jdGlvbjogVHJhZmZpYyA9 IEVuYWJsZWQsIEZJUyBEYXRhIExpbmsgPSBFbmFibGVkDQoNCg0KDQpBbHNvIG1ha2Ugc3VyZSB5 b3Ugc2V0IHRoZSBCcm9hZGNhc3QgSUNBTyBBZGRyZXNzLiBJIGRvbuKAmXQga25vdyB3aGljaCBz Y3JlZW4gaW4gc2V0dXAuIEl04oCZcyB0aGUgOCBkaWdpdCBoZXgtbG9va2luZyBNb2RlLVMgY29k ZSB0aGF0IHRyYW5zbGF0ZXMgdG8geW91ciBOLW51bWJlci4gRm9yIHdoYXRldmVyIHJlYXNvbiBJ IHB1dCBteSBOLW51bWJlciBpbiBpdCBhbmQgZm91Z2h0IGFuIGVycm9yIG1lc3NhZ2UgZm9yIGEg d2hpbGUuDQoNCg0KDQpJIGdvdCB0cmFmZmljIGFuZCBNZXRhcnMgb24gdGhlIE1YLTIwIGJ1dCBv bmx5IHRyYWZmaWMgb24gdGhlIDQzMFcuIEnigJltIHZlcnkgZGlzYXBwb2ludGVkIHdpdGggdGhl IGRpc3BsYXkgb24gdGhlIDQzMFcuIFNpbmNlIEdhcm1pbiBkb2VzbuKAmXQgcGxheSBuaWNlIHdp dGggb3RoZXJzIE5hdndvcnggY2FuIG9ubHkgZmVlZCBpdCB0cmFmZmljIGFuZCB5b3UgZG9u4oCZ dCBnZXQgYWxsIHRoZSBjYXBhYmlsaXR5IG9mIHRoZSA0MzBXIHRoYXQgaXQgaGFzIHdpdGggc2F5 IGEgR0RMLTg4LiBJIGxvdmUgdGhlIGRpc3BsYXkgb24gdGhlIDc5NiBidXQgdW5mb3J0dW5hdGVs eSBOYXZ3b3J4IGRvZXNu4oCZdCBzdXBwb3J0IGl0IGVpdGhlciwgYWdhaW4gYmVjYXVzZSBHYXJt aW4gZG9lc27igJl0IHBsYXkgbmljZSBhbmQgdGhleSBoYXZlbuKAmXQgcmV2ZXJzZSBlbmdpbmVl cmVkIGl0LiBTbyBJ4oCZbSBmZWVkaW5nIGl0IGZyb20gYSBHREwtMzkgd29ya3Mgd2VsbCBkZXNw aXRlIGJlaW5nIHRvdGFsbHkgc2VwYXJhdGUuDQoNCg0KDQpHb29kIGx1Y2suIElmIG5lZWRlZCBJ IGNhbiBzZW5kIHRoZSBwaWNzIG9mIHRoZSBzZXR1cCBzY3JlZW5zLg0KDQoNCg0KR3JlZyBZb3Vu Zw0KDQoNCg0KDQoNCi0tLS0tT3JpZ2luYWwgTWVzc2FnZS0tLS0tDQpGcm9tOiBvd25lci1hdmlv bmljcy1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tPG1haWx0bzpvd25lci1hdmlvbmljcy1saXN0 LXNlcnZlckBtYXRyb25pY3MuY29tPiBbbWFpbHRvOm93bmVyLWF2aW9uaWNzLWxpc3Qtc2VydmVy QG1hdHJvbmljcy5jb21dIE9uIEJlaGFsZiBPZiBSYWxwaCBFLiBDYXBlbg0KU2VudDogV2VkbmVz ZGF5LCBKdW5lIDA4LCAyMDE2IDc6NTMgQU0NClRvOiBhdmlvbmljcy1saXN0QG1hdHJvbmljcy5j b208bWFpbHRvOmF2aW9uaWNzLWxpc3RAbWF0cm9uaWNzLmNvbT47IHJ2LWxpc3QgPHJ2LWxpc3RA bWF0cm9uaWNzLmNvbTxtYWlsdG86cnYtbGlzdEBtYXRyb25pY3MuY29tPj4NClN1YmplY3Q6IEF2 aW9uaWNzLUxpc3Q6IEludGVyZmFjaW5nIE1YLTIwIChvciBHTVgtMjAwKSB3aXRoIE5hdldvcngg QURTNjAwLUINCg0KDQoNCi0tPiBBdmlvbmljcy1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiAiUmFs cGggRS4gQ2FwZW4iDQoNCi0tPiA8cmVjYXBlbkBlYXJ0aGxpbmsubmV0PG1haWx0bzpyZWNhcGVu QGVhcnRobGluay5uZXQ+Pg0KDQoNCg0KRm9sa3MsDQoNCg0KDQpBbnlvbmUgb3V0IHRoZXJlIHVz aW5nIGVpdGhlciBhIE1YLTIwIG9yIEdNWC0yMDAgYXMgdGhlIGRpc3BsYXkgZm9yIHRoZWlyIE5h dldvcnggQURTNjAwLUIgVUFUPw0KDQoNCg0KSSdtIHRyeWluZyB0byBmaWd1cmUgb3V0IHRoZSBz ZXR0aW5ncyB0byBiZSBhcHBsaWVkIHRvIHRoZSBNWC0yMCAtIHRoZXJlIGlzbid0IGFueXRoaW5n IEkgY2FuIGZpbmQgaW4gdGhlIG1hbnVhbC4gIEkndmUgc2VudCBhIG5vdGUgdG8gTmF2V29yeCAt IG5vIHJlc3BvbnNlIHNvIGZhci4NCg0KDQoNClRoZXJlJ3MgYSBzZXR0aW5nIGhpbnQgZm9yIHRo ZSA0MDBXLzUwMFcgaW4gdGhlIE5hdldvcnggbWFudWFsLCBzbyB0aGF0IG9uZSB3YXMgZWFzeS4g IEl0IHRlbGxzIHlvdSB0byBzZXQgaXQgdXAgYXMgZ2V0dGluZyBhIEdUWDMzMCBmZWVkLg0KDQoN Cg0KVGhhbmtzLA0KDQpSYWxwaCBDYXBlbg0KDQoNCg0KDQoNCg0KDQoNCg0KXy09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCg0KXy09 ICAgICAgICAgIC0gVGhlIEF2aW9uaWNzLUxpc3QgRW1haWwgRm9ydW0gLQ0KDQpfLT0gVXNlIHRo ZSBNYXRyb25pY3MgTGlzdCBGZWF0dXJlcyBOYXZpZ2F0b3IgdG8gYnJvd3NlIF8tPSB0aGUgbWFu eSBMaXN0IHV0aWxpdGllcyBzdWNoIGFzIExpc3QgVW4vU3Vic2NyaXB0aW9uLCBfLT0gQXJjaGl2 ZSBTZWFyY2ggJiBEb3dubG9hZCwgNy1EYXkgQnJvd3NlLCBDaGF0LCBGQVEsIF8tPSBQaG90b3No YXJlLCBhbmQgbXVjaCBtdWNoIG1vcmU6DQoNCl8tPQ0KDQpfLT0gICAtLT4gaHR0cDovL3d3dy5t YXRyb25pY3MuY29tL05hdmlnYXRvcj9Bdmlvbmljcy1MaXN0DQoNCl8tPQ0KDQpfLT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KDQpf LT0gICAgICAgICAgICAgICAtIE1BVFJPTklDUyBXRUIgRk9SVU1TIC0NCg0KXy09IFNhbWUgZ3Jl YXQgY29udGVudCBhbHNvIGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMhDQoNCl8tPQ0KDQpf LT0gICAtLT4gaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tDQoNCl8tPQ0KDQpfLT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KDQpf LT0gICAgICAgICAgICAgIC0gTkVXIE1BVFJPTklDUyBMSVNUIFdJS0kgLQ0KDQpfLT0gQWRkIHNv bWUgaW5mbyB0byB0aGUgTWF0cm9uaWNzIEVtYWlsIExpc3QgV2lraSENCg0KXy09ICAgLS0+IGh0 dHA6Ly93aWtpLm1hdHJvbmljcy5jb20NCg0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCg0KXy09ICAgICAgICAgICAgIC0gTGlz dCBDb250cmlidXRpb24gV2ViIFNpdGUgLQ0KDQpfLT0gIFRoYW5rIHlvdSBmb3IgeW91ciBnZW5l cm91cyBzdXBwb3J0IQ0KDQpfLT0gICAgICAgICAgICAgICAgICAgICAgICAgICAgICAtTWF0dCBE cmFsbGUsIExpc3QgQWRtaW4uDQoNCl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20v Y29udHJpYnV0aW9uDQoNCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09DQoNCg0KDQoNCg0KDQoNCg0KDQoNCg= ________________________________________________________________________________
ADS600-B
Date: Jun 08, 2016
SGVsbG8gUmFscGgsDQoNCkkgYW0gYXR0YWNoaW5nIGEgUERGIHRoYXQgc2hvd3Mgd2hhdCB0aGUg TVgyMCBzZXR0aW5ncyBzaG91bGQgYmUuDQoNCg0KQmVzdCBSZWdhcmRzLA0KDQpCaWxsIE1vZmZp dHQNCk5hdldvcnggSW5jb3Jwb3JhdGVkDQo4ODgtNjI4LTk2NzkNCig5NzIpIDM3Mi0wNzY4IChk aXJlY3QpDQo0NjktNjQ0LTI0NTkgKGNlbGwpDQo0NjktMzI3LTI2ODMgKGZheCkNCg0KRnJvbTog b3duZXItcnYtbGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbSBbbWFpbHRvOm93bmVyLXJ2LWxpc3Qt c2VydmVyQG1hdHJvbmljcy5jb21dIE9uIEJlaGFsZiBPZiBiaWdkb2dAYmVudHdpbmcuY29tDQpT ZW50OiBXZWRuZXNkYXksIEp1bmUgMDgsIDIwMTYgMTE6MjIgQU0NClRvOiBhdmlvbmljcy1saXN0 QG1hdHJvbmljcy5jb207IHJ2LWxpc3QNClN1YmplY3Q6IFJWLUxpc3Q6IFJFOiBBdmlvbmljcy1M aXN0OiBJbnRlcmZhY2luZyBNWC0yMCAob3IgR01YLTIwMCkgd2l0aCBOYXZXb3J4IEFEUzYwMC1C DQoNCkhlcmXigJlzIGEgbGluayB0byBzb21lIHBpY3R1cmVzIG9mIG15IE1YLTIwIHNldC11cCBz Y3JlZW5zLiBUaGVyZSBhcmUgYWxzbyBzb21lIGluIHVzZSBzaG90cyBvZiB0aGUgdHJhZmZpYyBk aXNwbGF5cyBvbiBteSA0MzBXLCBNWC0yMCBhbmQgNzk2Lg0KaHR0cHM6Ly9vbmVkcml2ZS5saXZl LmNvbS9yZWRpcj9yZXNpZD0xNDIxMDY0QkZDODkyREExITE0MzgxJmF1dGhrZXk9IUFPQzJiOG01 OVZ0NUZPOCZpdGhpbnQ9Zm9sZGVyJTJjanBnDQoNCg0KR3JlZw0KDQpGcm9tOiBvd25lci1hdmlv bmljcy1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tPG1haWx0bzpvd25lci1hdmlvbmljcy1saXN0 LXNlcnZlckBtYXRyb25pY3MuY29tPiBbbWFpbHRvOm93bmVyLWF2aW9uaWNzLWxpc3Qtc2VydmVy QG1hdHJvbmljcy5jb21dIE9uIEJlaGFsZiBPZiBiaWdkb2dAYmVudHdpbmcuY29tPG1haWx0bzpi aWdkb2dAYmVudHdpbmcuY29tPg0KU2VudDogV2VkbmVzZGF5LCBKdW5lIDA4LCAyMDE2IDEwOjAz IEFNDQpUbzogYXZpb25pY3MtbGlzdEBtYXRyb25pY3MuY29tPG1haWx0bzphdmlvbmljcy1saXN0 QG1hdHJvbmljcy5jb20+OyBydi1saXN0IDxydi1saXN0QG1hdHJvbmljcy5jb208bWFpbHRvOnJ2 LWxpc3RAbWF0cm9uaWNzLmNvbT4+DQpTdWJqZWN0OiBSRTogQXZpb25pY3MtTGlzdDogSW50ZXJm YWNpbmcgTVgtMjAgKG9yIEdNWC0yMDApIHdpdGggTmF2V29yeCBBRFM2MDAtQg0KDQoNClJhbHBo LA0KDQoNCg0KSSBpbnN0YWxsZWQgaXQgd2l0aCBteSBNWC0yMC4gSSd2ZSBzaW5jZSByZXdvcmtl ZCBteSBwYW5lbCBhbmQgcmVwbGFjZWQgaXQgd2l0aCBhIDc5NiBpbiBhbiBBaXJHaXptbyBkb2Nr LiBCdXQgSSd2ZSBzdGlsbCBnb3Qgc29tZSBwaWN0dXJlcyBvZiB0aGUgc2V0dGluZ3MuIFRoZSBy ZWxldmFudCBvbmVzIGFyZToNCg0KDQoNCk1pc2MgU2V0dXA6IEdETCA5MCBVQVQgUmFkaW8gPSBE aXNwIE9ubHksIEdETCA5MCBDb2RlIEVkaXQgPSBFbmFibGVkDQoNCkV4dGVybmFsIERhdGEgU291 cmNlczogVUFUIFRyYWZmaWMvRGF0YSBMaW5rIFNvdXJjZSA9IFBvcnQgNCAoZm9yIG1lKQ0KDQpF bmFibGUvRGlzYWJsZSBGdW5jdGlvbjogVHJhZmZpYyA9IEVuYWJsZWQsIEZJUyBEYXRhIExpbmsg PSBFbmFibGVkDQoNCg0KDQpBbHNvIG1ha2Ugc3VyZSB5b3Ugc2V0IHRoZSBCcm9hZGNhc3QgSUNB TyBBZGRyZXNzLiBJIGRvbuKAmXQga25vdyB3aGljaCBzY3JlZW4gaW4gc2V0dXAuIEl04oCZcyB0 aGUgOCBkaWdpdCBoZXgtbG9va2luZyBNb2RlLVMgY29kZSB0aGF0IHRyYW5zbGF0ZXMgdG8geW91 ciBOLW51bWJlci4gRm9yIHdoYXRldmVyIHJlYXNvbiBJIHB1dCBteSBOLW51bWJlciBpbiBpdCBh bmQgZm91Z2h0IGFuIGVycm9yIG1lc3NhZ2UgZm9yIGEgd2hpbGUuDQoNCg0KDQpJIGdvdCB0cmFm ZmljIGFuZCBNZXRhcnMgb24gdGhlIE1YLTIwIGJ1dCBvbmx5IHRyYWZmaWMgb24gdGhlIDQzMFcu IEnigJltIHZlcnkgZGlzYXBwb2ludGVkIHdpdGggdGhlIGRpc3BsYXkgb24gdGhlIDQzMFcuIFNp bmNlIEdhcm1pbiBkb2VzbuKAmXQgcGxheSBuaWNlIHdpdGggb3RoZXJzIE5hdndvcnggY2FuIG9u bHkgZmVlZCBpdCB0cmFmZmljIGFuZCB5b3UgZG9u4oCZdCBnZXQgYWxsIHRoZSBjYXBhYmlsaXR5 IG9mIHRoZSA0MzBXIHRoYXQgaXQgaGFzIHdpdGggc2F5IGEgR0RMLTg4LiBJIGxvdmUgdGhlIGRp c3BsYXkgb24gdGhlIDc5NiBidXQgdW5mb3J0dW5hdGVseSBOYXZ3b3J4IGRvZXNu4oCZdCBzdXBw b3J0IGl0IGVpdGhlciwgYWdhaW4gYmVjYXVzZSBHYXJtaW4gZG9lc27igJl0IHBsYXkgbmljZSBh bmQgdGhleSBoYXZlbuKAmXQgcmV2ZXJzZSBlbmdpbmVlcmVkIGl0LiBTbyBJ4oCZbSBmZWVkaW5n IGl0IGZyb20gYSBHREwtMzkgd29ya3Mgd2VsbCBkZXNwaXRlIGJlaW5nIHRvdGFsbHkgc2VwYXJh dGUuDQoNCg0KDQpHb29kIGx1Y2suIElmIG5lZWRlZCBJIGNhbiBzZW5kIHRoZSBwaWNzIG9mIHRo ZSBzZXR1cCBzY3JlZW5zLg0KDQoNCg0KR3JlZyBZb3VuZw0KDQoNCg0KDQoNCi0tLS0tT3JpZ2lu YWwgTWVzc2FnZS0tLS0tDQpGcm9tOiBvd25lci1hdmlvbmljcy1saXN0LXNlcnZlckBtYXRyb25p Y3MuY29tPG1haWx0bzpvd25lci1hdmlvbmljcy1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tPiBb bWFpbHRvOm93bmVyLWF2aW9uaWNzLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb21dIE9uIEJlaGFs ZiBPZiBSYWxwaCBFLiBDYXBlbg0KU2VudDogV2VkbmVzZGF5LCBKdW5lIDA4LCAyMDE2IDc6NTMg QU0NClRvOiBhdmlvbmljcy1saXN0QG1hdHJvbmljcy5jb208bWFpbHRvOmF2aW9uaWNzLWxpc3RA bWF0cm9uaWNzLmNvbT47IHJ2LWxpc3QgPHJ2LWxpc3RAbWF0cm9uaWNzLmNvbTxtYWlsdG86cnYt bGlzdEBtYXRyb25pY3MuY29tPj4NClN1YmplY3Q6IEF2aW9uaWNzLUxpc3Q6IEludGVyZmFjaW5n IE1YLTIwIChvciBHTVgtMjAwKSB3aXRoIE5hdldvcnggQURTNjAwLUINCg0KDQoNCi0tPiBBdmlv bmljcy1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiAiUmFscGggRS4gQ2FwZW4iDQoNCi0tPiA8cmVj YXBlbkBlYXJ0aGxpbmsubmV0PG1haWx0bzpyZWNhcGVuQGVhcnRobGluay5uZXQ+Pg0KDQoNCg0K Rm9sa3MsDQoNCg0KDQpBbnlvbmUgb3V0IHRoZXJlIHVzaW5nIGVpdGhlciBhIE1YLTIwIG9yIEdN WC0yMDAgYXMgdGhlIGRpc3BsYXkgZm9yIHRoZWlyIE5hdldvcnggQURTNjAwLUIgVUFUPw0KDQoN Cg0KSSdtIHRyeWluZyB0byBmaWd1cmUgb3V0IHRoZSBzZXR0aW5ncyB0byBiZSBhcHBsaWVkIHRv IHRoZSBNWC0yMCAtIHRoZXJlIGlzbid0IGFueXRoaW5nIEkgY2FuIGZpbmQgaW4gdGhlIG1hbnVh bC4gIEkndmUgc2VudCBhIG5vdGUgdG8gTmF2V29yeCAtIG5vIHJlc3BvbnNlIHNvIGZhci4NCg0K DQoNClRoZXJlJ3MgYSBzZXR0aW5nIGhpbnQgZm9yIHRoZSA0MDBXLzUwMFcgaW4gdGhlIE5hdldv cnggbWFudWFsLCBzbyB0aGF0IG9uZSB3YXMgZWFzeS4gIEl0IHRlbGxzIHlvdSB0byBzZXQgaXQg dXAgYXMgZ2V0dGluZyBhIEdUWDMzMCBmZWVkLg0KDQoNCg0KVGhhbmtzLA0KDQpSYWxwaCBDYXBl bg0KDQoNCg0KDQoNCg0KDQoNCg0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT0NCg0KXy09ICAgICAgICAgIC0gVGhlIEF2aW9uaWNz LUxpc3QgRW1haWwgRm9ydW0gLQ0KDQpfLT0gVXNlIHRoZSBNYXRyb25pY3MgTGlzdCBGZWF0dXJl cyBOYXZpZ2F0b3IgdG8gYnJvd3NlIF8tPSB0aGUgbWFueSBMaXN0IHV0aWxpdGllcyBzdWNoIGFz IExpc3QgVW4vU3Vic2NyaXB0aW9uLCBfLT0gQXJjaGl2ZSBTZWFyY2ggJiBEb3dubG9hZCwgNy1E YXkgQnJvd3NlLCBDaGF0LCBGQVEsIF8tPSBQaG90b3NoYXJlLCBhbmQgbXVjaCBtdWNoIG1vcmU6 DQoNCl8tPQ0KDQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9B dmlvbmljcy1MaXN0DQoNCl8tPQ0KDQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KDQpfLT0gICAgICAgICAgICAgICAtIE1BVFJP TklDUyBXRUIgRk9SVU1TIC0NCg0KXy09IFNhbWUgZ3JlYXQgY29udGVudCBhbHNvIGF2YWlsYWJs ZSB2aWEgdGhlIFdlYiBGb3J1bXMhDQoNCl8tPQ0KDQpfLT0gICAtLT4gaHR0cDovL2ZvcnVtcy5t YXRyb25pY3MuY29tDQoNCl8tPQ0KDQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KDQpfLT0gICAgICAgICAgICAgIC0gTkVXIE1B VFJPTklDUyBMSVNUIFdJS0kgLQ0KDQpfLT0gQWRkIHNvbWUgaW5mbyB0byB0aGUgTWF0cm9uaWNz IEVtYWlsIExpc3QgV2lraSENCg0KXy09ICAgLS0+IGh0dHA6Ly93aWtpLm1hdHJvbmljcy5jb20N Cg0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT0NCg0KXy09ICAgICAgICAgICAgIC0gTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGUg LQ0KDQpfLT0gIFRoYW5rIHlvdSBmb3IgeW91ciBnZW5lcm91cyBzdXBwb3J0IQ0KDQpfLT0gICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAtTWF0dCBEcmFsbGUsIExpc3QgQWRtaW4uDQoNCl8t PSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uDQoNCl8tPT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQoN Cg0KDQoNCg0KDQoNCg0KDQoNCg= ________________________________________________________________________________
Date: Jun 21, 2016
Subject: MX-20 software
Anyone out there running a MX-20 with a 400W/500W series GPS? I recently upgraded the software on my GNC420W in preparation for ADS-B upgrade interface to a NAVWORX ADS600B. Now the MX-20 will only display current position when a flight plan is active in the GNC420W. Previously, it would display current position as long as the GNC420W was getting a good GPS signal. I think the software is actually on the data card and not in the machine - so it should be easy to get the software upgraded. I need to check my software revision - I think I am at version 5.5...knowing that there is at least a version 5.7 floating around. Anyone have a spare card I can borrow to test in order to see if the new software will help? Thanks, Ralph Capen ________________________________________________________________________________
Date: Jun 25, 2016
Subject: MX-20 interfacing GNC420W (400W/500W)
My MX20 running 5.6 software is connected to an SL30 and a GNC420W. I have a set of 5.7 software coming on loan. The 420W recently received a software upgrade (to 5.3 / 5.0) in preparation for adding an ADS600B to my RV6A. Before the 420W upgrade, my MX20 would display my current position while flying. Now, I only get that information if a flight plan is active. I also previously saw my SL30 VOR radial tracked when it was dialed in and active - I don't get that anymore - unless I happen to have an active flight plan leg running in the 430W. Black screen with my plane and a red X in the middle of the screen until I hit Direct to.... Anyone else out there with this combo experiencing the same issues? More importantly, anyone out there with this same combo where you see your position without an active leg? I don't recall changing any settings - it worked before and it only works now after I activate a leg in the 420W. I contacted Garmin - they said to contact the dealer that installed it to verify the installation? Since I installed it, I have already rung out the wiring and only want to verify settings. They were kinda useless in that they didn't make an effort to understand the installation at all - but then they do have a monopoly on the market. I wrote down all of the info from the MX-20 screens so I have it for reference. I may need to do the same for the 420W for comparison. Any assistance in config settings on a working system would be greatly appreciate...even from 430W and 500W series users. Thanks, Ralph Capen ________________________________________________________________________________
Subject: Another new Avionics-oriented (sort of) smartphone App
Date: Jul 01, 2016
Greetings All, While being grounded for the past many months with a cracked engine block, I have been amusing myself by writing software. Allow me to introduce avAltimeter Not many many people are aware that in the iPhone 6 and later, Apple has incorporated a Bosch barometer chip. I recently released to the App Store a unique app which emulates an analog flight altimeter with a number of "smart" features including a Kollsman window for setting the current pressure, calculation of Density Altitude, true airspeed and takeoff performance. The App also provides a warning for supplemental oxygen consistent with US FARs. The latest version of the app, now allows entry of the Altimeter Setting (QNH) in millibars or in inches of mercury, and allows display of altitude and density altitude in Feet or Meters. Obviously avAltimeter is not FAA TSO approved and so I provide it for entertainment only. At present it can only be run on iPhone 6 and later, and not iPads or iPods. I understand the new Samsung Galaxy S7 now has a barometer chip as well and I plan to transfer the code to Android soon. My software web site is http://www.aviametrix.com or search for "avAltimeter" on the Apple App Store! Thanks for your attention! Cheers, -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=457598#457598 ________________________________________________________________________________
Subject: RE: RV-List: MX-20 interfacing GNC420W (400W/500W)
Date: Jul 04, 2016
The 5.7 software didn't fix it - anyone have a set of 5.8 software that I can borrow to test - before I rip Garmin via the FSDO!? -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ralph E. Capen Sent: Saturday, June 25, 2016 4:53 PM Subject: RV-List: MX-20 interfacing GNC420W (400W/500W) --> RV-List message posted by: "Ralph E. Capen" My MX20 running 5.6 software is connected to an SL30 and a GNC420W. I have a set of 5.7 software coming on loan. The 420W recently received a software upgrade (to 5.3 / 5.0) in preparation for adding an ADS600B to my RV6A. Before the 420W upgrade, my MX20 would display my current position while flying. Now, I only get that information if a flight plan is active. I also previously saw my SL30 VOR radial tracked when it was dialed in and active - I don't get that anymore - unless I happen to have an active flight plan leg running in the 430W. Black screen with my plane and a red X in the middle of the screen until I hit Direct to.... Anyone else out there with this combo experiencing the same issues? More importantly, anyone out there with this same combo where you see your position without an active leg? I don't recall changing any settings - it worked before and it only works now after I activate a leg in the 420W. I contacted Garmin - they said to contact the dealer that installed it to verify the installation? Since I installed it, I have already rung out the wiring and only want to verify settings. They were kinda useless in that they didn't make an effort to understand the installation at all - but then they do have a monopoly on the market. I wrote down all of the info from the MX-20 screens so I have it for reference. I may need to do the same for the 420W for comparison. Any assistance in config settings on a working system would be greatly appreciate...even from 430W and 500W series users. Thanks, Ralph Capen ________________________________________________________________________________
Subject: Re: Minimal IFR: What to do with your old Nav-122?
Date: Jul 05, 2016
We have a Narco Nav122 in a Cherokee 140. We had it repaired by BevanRabell about 2 years ago and it quit again. We are considering replacing it with a Val INS-429. We have an older INS-422 in a Cessna 150 which works good. Anyone have opinions about Val INS429? Mitch -------- Mitchell Williams OKPE, ATP/CFI/A&P/IA www.chickashawings.com of shadow and ash http://www.amazon.com/dp/B009KZGVQS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=457746#457746 ________________________________________________________________________________
Date: Jul 05, 2016
Subject: MX-20 connected to 400W/500W
Any of you out there using the MX-20 connected to either a 400W or 500W series GPS? I have a 420W connected to a MX-20. Recently upgraded the software in the 420W and now the MX-20 screen map area is blank with the red X in the middle unless I have a flight plan active. I have verified my wiring and settings - along with the system showing my position with the flight plan active so i am confident in the wiring / settings. The 420W is running 5.3/5.0 software and the MX-20 has been tested up to version 5.7. My understanding is that a newer version of software is available for the MX-20 and I am making inquiries as to upgrading. My question to other users is - Does it work with the later software - or did Garmin abandon this device already!? Thanks, Ralph Capen ________________________________________________________________________________
Date: Jul 06, 2016
Subject: Re: MX-20 connected to 400W/500W - UPDATE
Just to keep everyone in the loop.... There are multiple valid output protocols from the 400W/500W series that work with the MX-20...some have more features than others - the differences are not spelled out in the installation manuals. Got with the folks at Stark Aviation (I bought most of my gear through his shop), he was able to get an understanding of the differences and pass them to me. I was using "Aviation" as the output protocol from my 420W as it is acceptable to both the MX20 and my AFS3400s EFIS. Come to find out, the software upgrades changed some of the bits making this one a less viable option. I need to use "MXMap" for the MX20 and wire up two more outputs from the 420W...one for the EFIS and another for the ADS-600B -----Original Message----- >From: "Ralph E. Capen" <recapen(at)earthlink.net> >Sent: Jul 5, 2016 1:19 PM >To: rv-list , "avionics-list(at)matronics.com" >Subject: RV-List: MX-20 connected to 400W/500W > >--> RV-List message posted by: "Ralph E. Capen" > >Any of you out there using the MX-20 connected to either a 400W or 500W series GPS? > >I have a 420W connected to a MX-20. Recently upgraded the software in the 420W and now the MX-20 screen map area is blank with the red X in the middle unless I have a flight plan active. I have verified my wiring and settings - along with the system showing my position with the flight plan active so i am confident in the wiring / settings. > >The 420W is running 5.3/5.0 software and the MX-20 has been tested up to version 5.7. My understanding is that a newer version of software is available for the MX-20 and I am making inquiries as to upgrading. My question to other users is - Does it work with the later software - or did Garmin abandon this device already!? > >Thanks, >Ralph Capen ________________________________________________________________________________
Date: Jul 07, 2016
Subject: MX-20 Ver 5.8 software
Anyone out there with an MX-20 off the top of their heads know what size card the latest 5.8 software (non-chartview) comes on? I have a set of 5.8 software on the way and I want to put it in a card rotation like I am currently doing. The version 5.6 software (non-chartview) is on a 32MB card - which appears to be almost full. I have a few of these already - just want to know if I need to buy a set of 64MB or larger cards. Thanks, Ralph Capen ________________________________________________________________________________
Date: Jul 19, 2016
Subject: HSI repair vs new EFIS
My electric HSI has been in and out of the shop a bunch of times for failing drive bands - now they're saying "Gyro Capsule has Precession and needs to be replaced" - to the tune of about $3500. The plane has less than 300 hours on it so my BS alarm is going off thinking that they are trying to recover some warranty costs with a major component swapout. Not mentioning names here yet until I figure out what is going on and what I want to do. I can get a brand new - new technology AFS AF5500 with ADAHRS and moving map software for less than $6000 and be done with all the old stuff. I was planning to migrate to this newer technology after I get my IFR ticket anyway as my electric AI gyro is of the same technology - as well as the turn coordinator. Who all out there is flying with just the new glass screen/EFIS stuff? How long did it take you to re-learn the instrumentation? I'm already running one of their 3400EE units and I have been very happy with the performance so far! Thoughts?!
January 05, 2014 - July 19, 2016
Avionics-Archive.digest.vol-ar
