Beech-Archive.digest.vol-ak
October 18, 2006 - November 29, 2010
>> http://www.matronics.com/digest/beech-list/Digest.Beech-List.2006-10-12.txt
>> EMail Version of Today's List Digest Archive
>> Beech-List Digest Archive
>> Total Messages Posted Thu 10/12/06: 3
>> Today's Message Index:
>> 1. 05:16 AM - Re: cleveland brakes and gear doors (Masterson, Fred)
>> 2. 07:42 AM - Re: Main gear doorsMain gear doors (Murray Randall)
>> 3. 08:18 AM - Re: cleveland brakes and gear doors (Rob Breitbarth)
>> ________________________________ Message 1
>> _____________________________________
>> From: "Masterson, Fred" <Fred.Masterson(at)airliquide.com>
>> Subject: RE: Beech-List: cleveland brakes and gear doors
>> If you hold the drain to one side you can use a thin screwdriver to loosen
>> the clamp.
>> The hardest part is holding it to reinstall the drain.
>> I pulled both and put new o rings in last year.
>> Fred Masterson
>> -----Original Message-----
>> From: owner-beech-list-server(at)matronics.com
>> [mailto:owner-beech-list-server(at)matronics.com]On Behalf Of Bruce Bell
>> Sent: Wednesday, October 11, 2006 4:58 PM
>> Subject: Re: Beech-List: cleveland brakes and gear doors
>> Can't be for sure but a small box wrench is what I used to loosen the
>> clamp.
>> It's been about 20 or more years since I replaced mine. It is close but
>> you
>> can work through the opening in the wing. On my A35 anyway.
>> ----- Original Message -----
>> From: "Home" <rob87b(at)earthlink.net>
>> Sent: Wednesday, October 11, 2006 4:37 PM
>> > Great advice, thanks.
>> > How did you reach the hose clamp too loosen up the drain valve? It
>> > doesn't look like there is an easy access panel in sight for the main
>> > tanks.
>> > thanks, Rob.
>> >>From: Bruce Bell <brucebell74(at)sbcglobal.net>
>> >>Sent: Oct 10, 2006 4:12 PM
>> >>To: beech-list(at)matronics.com
>> >>Don't know about the rubbing but the Curtis drain valve can be replaced
>> >>with
>> >>out removing the tank. Two people work best one to stick his finger over
>> >>the
>> >>hole to stop the fuel flow and the other to reinstall the valve. A little
>> >>messy but gets the job done. Take proper precautions with the fuel. Use a
>> >>drip pan and put your cigars out!
>> >>To:
>> >>Sent: Tuesday, October 10, 2006 5:56 PM
>> >>Subject: Beech-List: cleveland brakes and gear doors
>> >>> I recently installed the Cleveland brake kit 199-50 which uses the
>> 6.5x8
>> >>> rims and and Superhawks tires. I find the outside edge of the
>> calipers
>> >>> are just rubbing the main gear doors. I checked and the tires are up
>> >>> tight when retracted. Any ideas?
>> >>> Also, I have a Curtis drain valve that needs changing on the left main
>> >>> tank. This is the hose clamp type. It looks like I have to pull the
>> >>> bladder to change it. Am I right?
>> >>> thanks for the help, rob.
>> ________________________________ Message 2
>> From: "Murray Randall" <aeroads(at)comcast.net>
>> Subject: Re: Beech-List: Main gear doorsMain gear doors
>> It sure is easy to imagine lacquer thinner damage....lacquer thinner
>> will dissolve about everything near it I use it to clean up the
>> comutator segments and the tooth brush I've had several cases of
>> gear inoperability the majority have been motor related so I watch
>> the second hand on my old dial clock on each and every cycle and now
>> I'm rebuilding a damaged 260 HP Maule in an attempt to get some of the
>> Bonanza utility without the gear issues....we'll see Murray Randall
>> ________________________________ Message 3
>> From: Rob Breitbarth <rob87b(at)earthlink.net>
>> Thanks for the help Fred. I'll replace mine this weekend.
>> rob
>> >Sent: Oct 12, 2006 3:07 AM
>> >the clamp.
>> >Fred Masterson
>> clamp.
>> but you
>> >To:
>> >> tanks.
>> >> thanks, Rob.
>> >>>with
>> over
>> >>>the
>> little
>> Use a
>> >>>To:
>> 6.5x8
>> calipers
For those of you that may have missed this great gathering in Tullahoma this past
weekend, here are a few of my memories.
http://www.pbase.com/shelbyrv6a/beech_party_2006
Shelby Smith
BE23 Nashville, TN
From: | "llsbiii3(at)netzero.net" <llsbiii3(at)netzero.net> |
Subject: | G-35 rear engine baffle |
My rear engine (E-225) baffle has cracked, and I am looking for one to i
nstall or use as a pattern. Does anyone have one to sell?
Sherman Butler
Polishing
Idaho falls
one to install or use as a pattern. Does anyone have one to sell?
Sherman Butler
Polishing
Idaho falls
