Commander-Archive.digest.vol-aa
April 29, 2001 - May 25, 2001
Date: Apr 29, 2001
Subject: Re: Oil? Well ...
The best thing I have ever done for any airplane engine is install a pre-oiler. No more bare metal rubbing on same at start up. You will be amazed at the pristine condition of your powerplants at TBO and regret that you tore them down. Pre heated oil still sits in the bottom of the pan. A pre-oiled engine will start far eaisier, run better and burn less oil. It's a beautiful thing as they say. Take a look and judge for yourselves. WWW.OILAMATIC.COM. If Lycoming and Continental made these standard equipment they would sell alot less engines ----- Original Message ----- From: Paul Odum To: CloudCraft(at)aol.com Cc: tcfg(at)listbot.com Sent: Sunday, April 29, 2001 1:11 PM Subject: Re: Oil? Well ... Keith, Actually it is due to the additives that the particular oil manufacturer uses in the oil(s). And, with the advance of time the additives get better and better. Take a read on John's book. It's gets a little over my head occasionally - actually most of the time - and I have an aeronautical engineering degree and a minor in chemistry ! Paul CloudCraft(at)aol.com wrote: In a message dated 04/28/01 23:52:11 Pacific Daylight Time, calnet01(at)gte.net writes: Lycoming recommends that we all run Phillips X/C II 20W-50 oil in our engines. PERIOD - end of conversation. Why do you want to do something different than the factory recommends ? Thanks for putting that out there. Much of the conversation was about the aerodynamics of the breather tube in the flat-nacelle models. As far as choice of oil, I'm not surprized what Lycoming calls for, but I wonder if they are reaching back to the 50 year old designs. In the past, they've distanced themselves from those engines and at one TCFG round table the tech rep was apparantly unaware of some of the operating tips Lycoming published back in the good old days. Just food for thought. Wing Commander Gordon ________________________________________________________________________________
Date: Apr 30, 2001
From: Chris Schuermann <chris(at)skymaster.c2-tech.com>
Subject: Re: Aviation Oil 101 Homework
Paul Odum wrote: > By the way - didn't mean to ruffle any feathers. Doin' fine Paul. One of the reasons I set up this list is to facilitate dialog, discussion, and questions. I don't mind "heated debate" at all as long as folks continue to provide useful information and don't get too personal. Everyone's entitled to opinions and hopefully will share them - backed with constructive information. Chris ________________________________________________________________________________
Date: Apr 30, 2001
From: CloudCraft(at)aol.com <CloudCraft(at)aol.com>
Subject: Yokes on 666DF
In a message dated 04/30/01 06:03:57 Pacific Daylight Time, Aircntr writes: > Keith; > They appear to be rubber grips, kind of like the old bicycle handle bar > grips we used as a kid. They look home made. > The above is forwarded from Gary Gadberry to the Group re: the grips on N666DF. ________________________________________________________________________________
Date: Apr 30, 2001
Now there's a great idea ! I always pre-oil my boat with a drill motor before we go out. It's a hassle but worth the effort ! Paul garyloff wrote: > > The best thing I have ever done for any airplane engine is install a > pre-oiler. No more bare metal rubbing on same at start up.You will be > amazed at the pristine condition of your powerplants at TBO and regret > that you tore them down. Pre heated oil still sits in the bottom of > the pan. A pre-oiled engine will start far eaisier, run better and > burn less oil. It's a beautiful thing as they say. Take a look and > judge for yourselves. WWW.OILAMATIC.COM. If Lycoming and Continental > made these standard equipment they would sell alot less engines > > ----- Original Message ----- > From: Paul Odum > To: CloudCraft(at)aol.com > Cc: tcfg(at)listbot.com > Sent: Sunday, April 29, 2001 1:11 PM > Subject: Re: Oil? Well ... > > Transfer balances to an APR as low as 2.99% Intro or 9.99% > Ongoing. > 24-hour online account management and Rewards Points for > every > > > Keith, > > Actually it is due to the additives that the particular oil > manufacturer uses in the oil(s). And, with the advance of > time the additives get better and better. > > Take a read on John's book. It's gets a little over my head > occasionally - actually most of the time - and I have an > aeronautical engineering degree and a minor in chemistry ! > > Paul > > CloudCraft(at)aol.com wrote: > > > > > Transfer balances to an APR as low as 2.99% Intro or 9.99% > > Ongoing. > > 24-hour online account management and Rewards Points for > > every > > > > > > In a message dated 04/28/01 23:52:11 Pacific Daylight > > Time, calnet01(at)gte.net > > writes: > > > > > > > > > Lycoming recommends that we all run Phillips X/C II > > > 20W-50 oil in our > > > engines. PERIOD - end of conversation. Why do you want to > > > do something > > > different than the factory recommends ? > > > > > > > > > > Thanks for putting that out there. > > > > Much of the conversation was about the aerodynamics of the > > breather tube in > > the flat-nacelle models. > > > > As far as choice of oil, I'm not surprized what Lycoming > > calls for, but I > > wonder if they are reaching back to the 50 year old > > designs. > > > > In the past, they've distanced themselves from those > > engines and at one TCFG > > round table the tech rep was apparantly unaware of some of > > the operating tips > > Lycoming published back in the good old days. > > > > Just food for thought. > > > > Wing Commander Gordon > > ________________________________________________________________________________
Date: Apr 30, 2001
Subject: AirLifeLine
Folks, In case your are interested. I just signed up to volunteer the 680E for AirLifeLine missions. It's tax deductible and, I think, a good cause. So write off some of those sightseeing flights ! Paul ________________________________________________________________________________
Date: Apr 30, 2001
Subject: Re: AirLifeLine
I have been interested in volunteering my 680F for Angel Flight, or similar flights. Is AirLifeLine the same?? If so, can you pass along info..?? Thanks, Randy Dettmer ----- Original Message ----- From: Paul Odum <calnet01(at)gte.net> To: ; Sent: Monday, April 30, 2001 8:25 AM Subject: AirLifeLine > > > Folks, > > In case your are interested. I just signed up to volunteer the 680E for > AirLifeLine missions. It's tax deductible and, I think, a good cause. So > write off some of those sightseeing flights ! > > Paul > > ________________________________________________________________________________
Date: Apr 30, 2001
In a message dated 4/30/2001 8:23:52 AM Pacific Daylight Time, calnet01(at)gte.net writes: I just got my application Jim Furlong > Folks, > > In case your are interested. I just signed up to volunteer the 680E for > AirLifeLine missions. It's tax deductible and, I think, a good cause. So > write off some of those sightseeing flights ! > > Paul > > ________________________________________________________________________________
Date: Apr 30, 2001
If you are interested in Air Lifeline or any of the other organizations look at the AOPA web site. They should have the listings. I threw away the article - sorry folks ! Paul Randy Dettmer wrote: > I have been interested in volunteering my 680F for Angel Flight, or similar > flights. Is AirLifeLine the same?? If so, can you pass along info..?? > > Thanks, > Randy Dettmer > ----- Original Message ----- > From: Paul Odum <calnet01(at)gte.net> > To: ; > Sent: Monday, April 30, 2001 8:25 AM > Subject: AirLifeLine > > > > > > > Folks, > > > > In case your are interested. I just signed up to volunteer the 680E for > > AirLifeLine missions. It's tax deductible and, I think, a good cause. So > > write off some of those sightseeing flights ! > > > > Paul > > > > ________________________________________________________________________________
Date: Apr 30, 2001
Subject: Ya'll
Hey Gang, just a little note to let you know that now I am accountable for my own actions,yes,I passed my check{forgot to carry cash}ride!I as a lowly highschool gradeate,have tried to include my actual experience as a non pilot non holier than thou first time airplane owner of a very special airplane,Lucille,into this chat group.Today I experienced a feeling that you fellows seem to have forgoten.I have enjoyed picking at you guyes because you knew and I did'nt,now all of a sudden everybody has to have an enginering degree to have a thought about something that used to be common sense.HEY,lighten up DAMN IT and get back to being what I liked about ALL OF YOU! BIG AL ________________________________________________________________________________
Date: Apr 30, 2001
From: RnJThompson(at)aol.com <RnJThompson(at)aol.com>
Subject: RE Newsletter
Hi JIM, Recieved the news letter today.Unfortunately the mailman left part of the envelope sticking out of the letter box. It rained and hence one very wet news letter full of wonderful colours. The power chart survived.Please could you forward me another copy if possible. Regards, Richard. P.S. Ithink I will change my name to Dick seeing as there seem to be a number of Richards. ________________________________________________________________________________
Date: Apr 30, 2001
Subject: Re: Ya'll
In a message dated 04/30/01 22:39:13 Pacific Daylight Time, allen_reed2(at)hotmail.com writes: > now I am accountable for > my own actions,yes,I passed my check{forgot to carry cash}ride!I as a lowly > highschool gradeate Ahhhh, the burden of command. Well, congratulations, Big Al! Thanks for the reminder ... these are the good old days of aviation. Oh - and you're completely over-educated. Bill Lear was a high school drop out. Wing Commander Gordon ________________________________________________________________________________
Date: May 01, 2001
Subject: stc
Hey Guys, Is there an STC for a Shadin fuel flow indicating system on a 560E and does anyone have a copy I could peruse? rodd ________________________________________________________________________________
Date: May 01, 2001
Subject: Re: Ya'll
Allen Reed wrote: > Hey Gang, just a little note to let you know that now I am accountable for > my own actions,yes,I passed my check{forgot to carry cash}ride! CONGRATS Allen! I DO remember! Chris ________________________________________________________________________________
Date: May 01, 2001
Subject: Re: stc
> Rodd Browne wrote: > Is there an STC for a Shadin fuel flow indicating system on a 560E and > does anyone have a copy I could peruse? Rodd, the last time I spoke to Shadin about this (granted, some years ago) they told me that they'd never been able to get their system to provide accurate numbers on a pressure carb installation and would therefor not pursue an STC. There are several new totalizers on the market which might be worth looking into. Chris ________________________________________________________________________________
Date: May 01, 2001
Subject: Re: Ya'll
Congrats Big Al!!!! (ANY CHECK PASSED IS WORTH MORE THAN CASH!!) And Oh, by the way..........WELL SAID!!!!!!! Paul Reason ________________________________________________________________________________
Date: May 01, 2001
Subject: Re: stc
I have a Shadin in my 690 and it's terribly innaccurate, although it is stc'd. Their support has been poor and the unit is truly unservicable and unadjustable. You need to pull it out and set some switches on the side to do anything and no one has been able to get it calibrated properly. I used a JPI in my 500 and it was a wonderful instrument, with great support and with the manual you can set up readily. It's programming and setup is straighforward, available and logical. You'll have your fuel flow reading adjusted perfectly within a few flights. one guys opinion, JPI is a terrific instrument and in the new 700 twin model they also do a reverse indication for lean of peak setting. I highly recommend the whole enchilada, w/ egt/cht, fuel flow, electrical and oil. Over the life of your engine and flying availability, it will more than pay for itself. It allowed me to immediately identify when I had a clogged injector, a little oil leak collecting on a cylinder that made it run hot, mag ground-wire problems, alternator/battery problems etc. Each event was minor and caught before it actually grounded me. As well as complete information to run your engine for maximum reliability and tbo. It also has 2 full fuel levels, I set the second one 10 gals less than the full, so in the event, I didn't personally confirm that that last 10 gallons was squeezed in it was easy to have a reliable verification to your main fuel gauge. I know it sounds like I'm a JPI sales man, which I'm not, I wouldn't operate a piston engine w/o it! andrew Rodd Browne wrote: Hey Guys, Is there an STC for a Shadin fuel flow indicating system on a 560E and does anyone have a copy I could peruse? rodd ________________________________________________________________________________
Date: May 01, 2001
>definition of ZnDTP and what it's used for. Here yea go Paul, It's used as an anti-wear additive. In medium-high loading conditions (anti wear), or very high (EP), the additive reacts with metal surfaces forming layers with a low friction coefficient. Types: Zinc diackyl dithio phosphates, Sulfur-Phosphorous Compounds, Clorurated Paraffins, Organic sulphur compounds Zinc Dialkyl Dithio Phosphates (ZnDTP) They also have very good antioxidant performances. Question on ZnDTP has been raised after the introduction of catalytic converters. In fact phosphorous contained in ZnDTP seems to be a poison towards the catalytic systems. Contamination to the converter is possible as a consequence of the oil consumption which burns and goes in the exhausted gases. If it's used in Aviation, I'm sure glad we don't have catalytic converters. No existing efficient alternatives to ZDDPs, a limit in phosphorous content in engine oil has been introduced in new specifications. Randy Sharp calnet01(at)gte.net said: >Ok guys, > >Seemed I caused quite a ruckus over the oil thing. Looking through notes >from my days as a chemist for a rather major Oil Company's Aviation >division I found some interesting stuff. > >Here's a little homework for you. > >There is a particular oil additive that you "should" be running in your >piston engined Lycomings (I am). This particular additive is found in >Phillips X/C II and Shell 15W/50. Although Lycoming does not recommend >against using the Shell brand it has been found to leave greater varnish >deposits, lead deposit accumulation, etc., etc., etc. This is one >problem associated with synthetic oils. > >I will give you one hint. The additive helps to prevent friction induced >hot spots. > >Anybody care to take a crack at what additive we should be looking for >in the oil we pour into the tank ? Try to give everyone the name of the >additive and the additive designation. > >I'll provide the answer next Saturday night unless I'm motoring around >in N680E. > >Oh, by the way - according to my notes some additives are required per >Lycoming AD/Service Bulletin. Someone in the group should do some >research and discover whether or not we are all impacted by one of these >Lycoming SB's in our GO, GSO, IGSO Lyc's. > >Have to teach for Cisco Systems all week. Also - may have N680E sold - >partner maybe ? Anyway, maybe we'll get a new member and I'll get a >t-shirt. > >By the way - didn't mean to ruffle any feathers. After having worked for >years as a chemist for this rather large Aviation Oil Company I get a >little self righteous. My Oncologist thinks being a chemist caused me to >get cancer - twice. All those thousands of hours of combat flying and I >get cancer because I worked in the aviation oil/fuels business. What's >up with that ? Be careful around this stuff. > >There's another freak of the aviation oil business. Aircraft oil doesn't >use ZnDTP. Go figure ! That would be great. > >I think Schwaner talks about some of this stuff in his book. I'll take a >look this week if I get time. By then I'm sure all you dedicated engine >guys will have the answer. Bonus points will be awarded for the >definition of ZnDTP and what it's used for. > >Catch ya later dudes. > >Paul > > ________________________________________________________________________________
Date: May 01, 2001
From: Barry.Collman(at)airclaims.co.uk <Barry.Collman(at)airclaims.co.uk>
Blow it! Randy just beat me to it - just what I was going to say!! (Tongue firmly in cheek here). Oh well, I'll just have to try and be a bit quicker with the next brain-teaser. How Y'All doin'? Best Regards, Barry Collman Randy Sharp e.com> cc: Subject: Re: Aviation Oil 101 Homework 01/05/2001 16:29 >definition of ZnDTP and what it's used for. Here yea go Paul, It's used as an anti-wear additive. In medium-high loading conditions (anti wear), or very high (EP), the additive reacts with metal surfaces forming layers with a low friction coefficient. Types: Zinc diackyl dithio phosphates, Sulfur-Phosphorous Compounds, Clorurated Paraffins, Organic sulphur compounds Zinc Dialkyl Dithio Phosphates (ZnDTP) They also have very good antioxidant performances. Question on ZnDTP has been raised after the introduction of catalytic converters. In fact phosphorous contained in ZnDTP seems to be a poison towards the catalytic systems. Contamination to the converter is possible as a consequence of the oil consumption which burns and goes in the exhausted gases. If it's used in Aviation, I'm sure glad we don't have catalytic converters. No existing efficient alternatives to ZDDPs, a limit in phosphorous content in engine oil has been introduced in new specifications. Randy Sharp calnet01(at)gte.net said: >Ok guys, > >Seemed I caused quite a ruckus over the oil thing. Looking through notes >from my days as a chemist for a rather major Oil Company's Aviation >division I found some interesting stuff. > >Here's a little homework for you. > >There is a particular oil additive that you "should" be running in your >piston engined Lycomings (I am). This particular additive is found in >Phillips X/C II and Shell 15W/50. Although Lycoming does not recommend >against using the Shell brand it has been found to leave greater varnish >deposits, lead deposit accumulation, etc., etc., etc. This is one >problem associated with synthetic oils. > >I will give you one hint. The additive helps to prevent friction induced >hot spots. > >Anybody care to take a crack at what additive we should be looking for >in the oil we pour into the tank ? Try to give everyone the name of the >additive and the additive designation. > >I'll provide the answer next Saturday night unless I'm motoring around >in N680E. > >Oh, by the way - according to my notes some additives are required per >Lycoming AD/Service Bulletin. Someone in the group should do some >research and discover whether or not we are all impacted by one of these >Lycoming SB's in our GO, GSO, IGSO Lyc's. > >Have to teach for Cisco Systems all week. Also - may have N680E sold - >partner maybe ? Anyway, maybe we'll get a new member and I'll get a >t-shirt. > >By the way - didn't mean to ruffle any feathers. After having worked for >years as a chemist for this rather large Aviation Oil Company I get a >little self righteous. My Oncologist thinks being a chemist caused me to >get cancer - twice. All those thousands of hours of combat flying and I >get cancer because I worked in the aviation oil/fuels business. What's >up with that ? Be careful around this stuff. > >There's another freak of the aviation oil business. Aircraft oil doesn't >use ZnDTP. Go figure ! That would be great. > >I think Schwaner talks about some of this stuff in his book. I'll take a >look this week if I get time. By then I'm sure all you dedicated engine >guys will have the answer. Bonus points will be awarded for the >definition of ZnDTP and what it's used for. > >Catch ya later dudes. > >Paul ________________________________________________________________________________
Date: May 01, 2001
Subject: Re: Engine Analyzers
afoss(at)caw.com said: >I have a Shadin in my 690 and it's terribly innaccurate, although it is >stc'd. Their support has been poor and the unit is truly unservicable and >unadjustable. You need to pull it out and set some switches on the side >to do anything and no one has been able to get it >calibrated properly. I too have the Shadin unit and it appears to be inaccurate some of the time. It reads on the high side for fuel flows for the RE. (LE appears ok) But it has been reliable, never had a problem with it for the past 9 years other than the indications on the right. >I used a JPI in my 500 and it was a wonderful instrument, with great >support and with the manual you can set up readily. It's programming and >setup is straighforward, available and logical. You'll >have your fuel flow reading adjusted perfectly within a few flights. >one guys opinion, JPI is a terrific instrument and in the new 700 twin >model they also do a reverse indication for lean of peak setting. I highly >recommend the whole enchilada, w/ egt/cht, fuel flow, >electrical and oil. Over the life of your engine and flying availability, >it will more than pay for itself. It allowed me to immediately identify >when I had a clogged injector, a little oil leak collecting on a >cylinder that made it run hot, mag ground-wire problems, >alternator/battery problems etc. Each event was minor and caught before it >actually grounded me. As well as complete information to run >your engine for maximum reliability and tbo. I installed the Insight engine monitor, great support and very small package. I really liked the IR support for downloading the EGT/CHT values into a handheld from the front panel for charting and printing of saved data records. (This feature is included and is not an extra option) The unit can be used as a warranty indicator for newly overhauled engines. I saved all of my data points as an excel spreadsheet and charted them in case the manufacturer had questions on the operation of the remanufactured engines. This unit also has an auto lean setting, press two buttons simultaneously, start the lean process by reducing the mixtures and it accurately determines which cylinder is leaned FIRST. >I know it sounds like I'm a JPI sales man, which I'm not, I wouldn't >operate a piston engine w/o it! >andrew Same here, in fact ANY engine analyzer is recommended. I quickly determined I had a failed plug (ONLY leaked above 10K PA), the EGT/CHT for #3 cylinder was almost shut-down (<300 deg EGT, <50 CHT). On the ground the mag check and temps revealed no problems because the ambient atmosphere was higher. The problem didn't reveal itself until I climbed to altitude. This would have been impossible to troubleshoot without the engine analyzer. The engine wasn't running rough so I would have never known a problem existed. (In cruise, 5.5 out of 6 cylinders appears to be enough, I did notice sluggish performance for climbs above 6K) and I'm sure in the long run the cylinder would have been damaged. I replaced the plug on that cylinder and it fixed the problem. I had some mechanics telling me that I had a bad valve in the cylinder or leaking rings etc. (It was just a bad plug) The Documentation does a very good job in troubleshooting using example photos of EGT/CHT readings for various flight conditions. Randy ________________________________________________________________________________
Date: May 01, 2001
Barry.Collman(at)airclaims.co.uk said: >Blow it! >Randy just beat me to it - just what I was going to say!! (Tongue firmly in >cheek here). Oh well, I'll just have to try and be a bit quicker with the next >brain-teaser. That's OK Barry, Next time I'll let you give the answer. >How Y'All doin'? Great and you? How is the wx over there in the fatherland? Enjoy the week, Randy >Best Regards, >Barry Collman >>definition of ZnDTP and what it's used for. > >Here yea go Paul, > >It's used as an anti-wear additive. > >In medium-high loading conditions (anti wear), or very high (EP), the >additive >reacts with metal surfaces forming layers with a low friction >coefficient. > >Types: >Zinc diackyl dithio phosphates, Sulfur-Phosphorous Compounds, Clorurated >Paraffins, >Organic sulphur compounds Zinc Dialkyl Dithio Phosphates (ZnDTP) > >They also have very good antioxidant performances. > >Question on ZnDTP has been raised after the introduction of catalytic >converters. >In fact phosphorous contained in ZnDTP seems to be a poison towards the >catalytic systems. Contamination to the converter is possible as a >consequence of the oil >consumption which burns and goes in the exhausted gases. > >If it's used in Aviation, I'm sure glad we don't have catalytic >converters. > >No existing efficient alternatives to ZDDPs, a limit in phosphorous >content in >engine oil has been introduced in new specifications. > >Randy Sharp > > >calnet01(at)gte.net said: >>Ok guys, >> >>Seemed I caused quite a ruckus over the oil thing. Looking through notes >>from my days as a chemist for a rather major Oil Company's Aviation >>division I found some interesting stuff. >> >>Here's a little homework for you. >> >>There is a particular oil additive that you "should" be running in your >>piston engined Lycomings (I am). This particular additive is found in >>Phillips X/C II and Shell 15W/50. Although Lycoming does not recommend >>against using the Shell brand it has been found to leave greater varnish >>deposits, lead deposit accumulation, etc., etc., etc. This is one >>problem associated with synthetic oils. >> >>I will give you one hint. The additive helps to prevent friction induced >>hot spots. >> >>Anybody care to take a crack at what additive we should be looking for >>in the oil we pour into the tank ? Try to give everyone the name of the >>additive and the additive designation. >> >>I'll provide the answer next Saturday night unless I'm motoring around >>in N680E. >> >>Oh, by the way - according to my notes some additives are required per >>Lycoming AD/Service Bulletin. Someone in the group should do some >>research and discover whether or not we are all impacted by one of these >>Lycoming SB's in our GO, GSO, IGSO Lyc's. >> >>Have to teach for Cisco Systems all week. Also - may have N680E sold - >>partner maybe ? Anyway, maybe we'll get a new member and I'll get a >>t-shirt. >> >>By the way - didn't mean to ruffle any feathers. After having worked for >>years as a chemist for this rather large Aviation Oil Company I get a >>little self righteous. My Oncologist thinks being a chemist caused me to >>get cancer - twice. All those thousands of hours of combat flying and I >>get cancer because I worked in the aviation oil/fuels business. What's >>up with that ? Be careful around this stuff. >> >>There's another freak of the aviation oil business. Aircraft oil doesn't >>use ZnDTP. Go figure ! That would be great. >> >>I think Schwaner talks about some of this stuff in his book. I'll take a >>look this week if I get time. By then I'm sure all you dedicated engine >>guys will have the answer. Bonus points will be awarded for the >>definition of ZnDTP and what it's used for. >> >>Catch ya later dudes. >> >>Paul > > ________________________________________________________________________________
Date: May 01, 2001
Subject: FOOL BURN
Hey Chris, NOOOOO! ________________________________________________________________________________
Date: May 01, 2001
Subject: Re: TOWBARS
Hello JB!!! I got a first hand look at one of your new towbars when I first laid eyes on N444WA. What a great job!!! It is well worth the money, and a first class piece of work. No baggage compartment is complete without one!!! (along with the 2 step folding ladder and a set of jumper cables!!) Paul Reason ________________________________________________________________________________
Date: May 01, 2001
Subject: Blown 500
Hey Team,Many of you thought that Lucille was an appropriate name,so what would Chris call his blown 500,hows about SLICK WILLIE TWO!!!! BIG AL ________________________________________________________________________________
Date: May 01, 2001
In a message dated 5/1/01 10:23:25 PM Eastern Daylight Time, JETPAUL(at)aol.com writes: << Hello JB!!! I got a first hand look at one of your new towbars when I first laid eyes on N444WA. What a great job!!! It is well worth the money, and a first class piece of work. No baggage compartment is complete without one!!! (along with the 2 step folding ladder and a set of jumper cables!!) >> Oh Yeah I almost left out the most important stuff in the baggage compartment...... A FEW QUARTS OF YOUR FAVORITE OIL.......JUST DONT TELL ANYONE WHAT KIND IT IS, BECUASE I THINK WE PUT THAT BABY TO BED ALREADY!!!!!! PAUL REASON ________________________________________________________________________________
Date: May 01, 2001
Subject: Re: Am I here?
In a message dated 05/01/01 18:28:58 Pacific Daylight Time, w.bow(at)att.net writes: > Sorry but I have been having a bit of a time. Have I returned to the group? Affirmative. You are at your present position at this time. Wing Commander Gordon ________________________________________________________________________________
Date: May 01, 2001
Subject: Welcome Home
Finally the fun is back on this site! Please gang lets not get out of sorts again,Okaaaa! By the way,someone asked what I took my check ride in,wellll,it was a YES,,,Cessna 172 and it was for my private but have faith,my pilot,friend,and my tutor{same man}is in town and I will be starting my For Real training tommorow.Tighten your corsett Lucille cause Daddy's a coming to get you.Best to all. BIG AL ________________________________________________________________________________
Date: May 01, 2001
In a message dated 5/1/01 7:23:30 PM Pacific Daylight Time, JETPAUL(at)aol.com writes: > Hello JB!!! I got a first hand look at one of your new towbars when I first > laid eyes on N444WA. What a great job!!! It is well worth the money, and > a > first class piece of work. No baggage compartment is complete without > one!!! > (along with the 2 step folding ladder and a set of jumper cables!!) > > THANKS PAUL....... Wait tell you see my next offering. I am having a baggage door organizer made. It will replace the baggage door upholstery and contain a pouch for a quart of Hyd. fluid, a quart of oil for each engine as well as window cleaner, preflight tool etc, etc. It will end all of that fun we used to have hunting in the dark cave for a quart of oil. They will be available soon (at a discount to TCFG members, of cource). I should have the prototype done right away. Thanks for the kind words!! jb ________________________________________________________________________________
Date: May 01, 2001
In a message dated 5/1/01 8:01:31 PM Pacific Daylight Time, john(at)vormbaum.com writes: > Oh, lots of rags/shop towels seem to make their way into my baggage > compartment (what, me leak oil? No way!). > > There will be room for plenty of rages John!! jb ________________________________________________________________________________
Date: May 02, 2001
Subject: Re: FUEL BURN
HI RANDY........ You should contact Dick Maccoon at Mr. RPM 360-387-2272. He is in Washington State and will have a new twin turbo kit for your airplane soon. I have visited his shop recently an it is a well thought out system Good luck!! jb ________________________________________________________________________________
Date: May 02, 2001
Subject: Re: FLYIN, TOWBARS AND STUFF
In a message dated 5/1/01 3:35:38 PM Pacific Daylight Time, Furlong5(at)aol.com writes: > I'm wondering how many - if any --- Commander owners would be interested in > beginning a formation flying group in the Northwest. The greater Portland > and Seattle areas. HI JIM..... Count me in. I really enjoyed flying with you last week. I know there will be some other Commanders coming on line this summer, a 520 in Troutdale and there is a 500 in Bremerton. We see who else makes contact. jb ________________________________________________________________________________
Date: May 02, 2001
Randy Sharp wrote: > So what do you think about the cost, installation, maintenance etc. with > the Rayjays? Honestly, I did not go looking for a turbo'd bird - just happened across a truely outstanding Viking which happened to have them. From my experience and other research, I've found the Rayjay's to be a darn good choice. If they're really taken care of, they might come close to making a 2000hr TBO, but I think a 1000hr life is a more reasonable expectation. The failure mode generally isn't anything exciting - they just begin to loose boost and may begin to use a little oil. My setup has the auto wastegate controller which basicly makes operation invisible. Just fly it like any other injected engine except that MAP doesn't drop off as you climb. At overhaul, I installed two brand new turbos even though the old ones didn't seem to be showing any trauma. (I think they were about $2600) They had both been overhauled at around 1200hrs so I figured it was a good time. The wastegates I have are very simple devices (no castings) and I had them overhauled for a couple hundred dollars (the valve was getting a bit warped - it's just a piece of flat metal welded to a shaft). The installation certainly adds some cost at overhaul, but I've not found that it added any significant operational cost. Havn't had a bit of trouble in the 3 1/2 years that I've owned this airplane. I do make sure to keep fresh oil in her and am carefull to cool the turbos for the recomended 4 minutes before shutdown. The folks I've know that have had problems with turbo'd birds have all been "abusive" from what I've seen. I know one fellow who had to replace his turbos almost every year, but he was the type who is still at cruise power entering downwind, chops the power, brakes hard to make the first turnoff, then shuts down as soon as he's on the ramp.... with stuff still glowing red hot. He seems to go through a LOT of cylinders also :-) Anyway, hope this was of some interest. I'd be happy to discuss further if you like.... Chris ________________________________________________________________________________
Date: May 02, 2001
Subject: Re:Turbo Rayjay's
Thanks Chris! As usual your wealth of knowledge and very informative format is greatly appreciated! The installation of the Rayjay's looks more like an advantage than a disadvantage at this point. Yes I would like to discuss this further! (not sure if you want to take it off-line or not?) Your experience with the turbos will be very helpful in the decision process! Thanks, Randy chris(at)skymaster.c2-tech.com said: >Randy Sharp wrote: >> So what do you think about the cost, installation, maintenance etc. with >> the Rayjays? > >Honestly, I did not go looking for a turbo'd bird - just happened across >a truely outstanding Viking which happened to have them. >From my experience and other research, I've found the Rayjay's to be >a darn good choice. If they're really taken care of, they might come >close to making a 2000hr TBO, but I think a 1000hr life is a more >reasonable expectation. The failure mode generally isn't anything >exciting - they just begin to loose boost and may begin to use a >little oil. My setup has the auto wastegate controller which basicly >makes operation invisible. Just fly it like any other injected engine >except that MAP doesn't drop off as you climb. >At overhaul, I installed two brand new turbos even though the old ones >didn't seem to be showing any trauma. (I think they were about $2600) >They had both been overhauled at around 1200hrs so I figured it was a >good >time. The wastegates I have are very simple devices (no castings) >and I had them overhauled for a couple hundred dollars >(the valve was getting a bit warped - it's >just a piece of flat metal welded to a shaft). >The installation certainly adds some cost at overhaul, but I've not >found >that it added any significant operational cost. Havn't had a bit of >trouble in the 3 1/2 years that I've owned this airplane. I do make >sure to keep fresh oil in her and am carefull to cool the turbos for >the recomended 4 minutes before shutdown. The folks I've know that >have had problems with turbo'd birds have all been "abusive" from what >I've seen. I know one fellow who had to replace his turbos almost >every year, but he was the type who is still at cruise power entering >downwind, chops the power, brakes hard to make the first turnoff, >then shuts down as soon as he's on the ramp.... with stuff still >glowing red hot. He seems to go through a LOT of cylinders also :-) > >Anyway, hope this was of some interest. I'd be happy to discuss >further if you like.... > >Chris > > ________________________________________________________________________________
Date: May 02, 2001
I rather think that everyone on who wants to be a millionaire should be asked the questions on Win Ben Stein's Money. No one would get past $1000 !!! Randy Sharp wrote: > > > JETPAUL(at)aol.com said: > >Boy this Randy guy seems to be a pretty "SHARP" Cookie. > >Wow, I can't believe that you guys let me beat you to that one!!!! > >Paul Reason > > >- and I have an aeronautical engineering > >degree and a minor in chemistry ! > >Paul Odum > > Like Paul I too have an Aeronautical Engineering Degree but instead of a > chemistry minor, I have a computer science degree. > > The Internet has a wealth of information at your finger tips! > > (Too bad I can't bring the computer with me on the show > "Who wants to be a Millionaire?") > > ha ha > Randy > ________________________________________________________________________________
Date: May 02, 2001
Randy, I got the stuff from Dick McCoon on his new turbo kit. The new system will include an intercooler and oil cooler. His system also removes the cowl flaps, which are replaced by SS exhaust ports. The first system is about to go on a customer's aircraft in the Seattle area. In the west, having 25-29" MP available is very good for going over mountains. Regards, Tylor Hall tylorh(at)sound.net 913-422-8869 -----Original Message----- From: Randy Sharp [mailto:sharp.r(at)apple.com] Sent: Wednesday, May 02, 2001 11:03 AM To: TCFG(at)listbot.com Subject: Re: FUEL BURN YOURTCFG(at)aol.com said: >HI RANDY........ > You should contact Dick Maccoon at Mr. RPM 360-387-2272. He is >in Washington State and will have a new twin turbo kit for your airplane >soon. I have visited his shop recently an it is a well thought out system >Good luck!! jb THANK YOU VERY MUCH! JB I will give him a call. Randy ________________________________________________________________________________
Date: May 02, 2001
Subject: Re: To turbo or not to turbo
Thanks Keith! Your input is greatly appreciated as well! And yes D.P. is a great guy. It's always good to hear the other side and subsequent related issues in order to make a sound decision. Randy CloudCraft(at)aol.com said: >> When I first bought the 500B I didn't want the extra headaches associated >> with turbos but now most of my flights take me to Tahoe and the extra HP >> would >> help. > >Randy, >Recently had this discussion with a 500B owner who is also an A&P (not to >mention one of my favorite people in the world). >Once you install a pair of "hair dryers" you'll have a totally crammed >engine compartment, making many other maintenence actions difficult. >Maintaining the turbos is another epic all together. > >However. Now that you're flying to Tahoe, Truckee, (Santa Fe, Telluride?) >etc. fairly regularly, I'd be happy to spend your money and suggest you tubo >normalize. > >If I was the King of Siam, I'd have a 500-B with manual waste gates. That >way, I could use the turbos when needed and spare them and the rest of the >engine components the extra heat on most flights. > >It's always been my opinion that if you operate from some of the Western >U.S. > airports, you really need the boost. It's not just the MEAs. It's the >O.E.I. climb gradients. > >Wing Commander Gordon ________________________________________________________________________________
Date: May 02, 2001
Subject: Turbos
You guys picked a bad time to talk about this! I have a blown 500-B. Since I bought it in Oct. of '99, the turbos have never worked. Last fall Morris fixed the right engine turbos, and that engine is incredible. I can overboost the engine at 15k feet if I'm not careful with the wastegate controllers! Of course, that was only the beginning of the saga. When we tried to get new turbos for the left engine, we discovered that Rayjay recalled 500 housings & bearings because of incorrect manufacture. Suddenly there were none available......3 mos. later, when I finally found a pair of brand new ones, they were $2,600/ea. Youch. Oh well, bought 'em anyway, and Morris again redid all the ductwork on the left engine (we estimated that both sides had about 1500 hrs. on the turbo hardware). I now have new wastegates, new turbos, and all new ductwork on both engines. However, my left engine isn't making an ounce of boost. I'm assuming the air door isn't closing when the system begins to develop positive pressure. We'll find out tomorrow when Morris tries to diagnose & fix the problem. The engine compartment does indeed become cramped, and I have the scars to prove it. When everything works as advertised, I'll be a happy camper. I'm a speed freak, so a non-geared commander that can do 200ktas up high is very attractive to me. As far as the extra expense, I figure that just comes with the territory when you buy (complex) airplanes. It's still worth it to me out west here, as Keith said, because of the OEI safety cushion it will give me. /John ----- Original Message ----- From: "Randy Sharp" <sharp.r(at)apple.com> To: Sent: Wednesday, May 02, 2001 8:22 AM Subject: Re: FUEL BURN > > > chris(at)skymaster.c2-tech.com said: > >Randy Sharp wrote: > >> Flying a 1964 500B. > >> 10K PA, Std Temp; 2350 RPM, 20" MAP, (13.5x2) or 27 GPH > >> (172-177 KTAS) > >> 10K PA, Std Temp; 2200 RPM, 19-20" MAP, (11.5 x2) or 23 GPH > >> (160-165 KTAS) > > > >Thanks for that data Randy! I'm with you on the power settings. > >I've found that by decreasing from 75% to about 60% on my Viking > >that I don't loose much time on my shorter trips but cut the > >fuel burn a LOT. I've got the side advantage that I can drop my > >RPM way down and crank the MAP up with my "hairdryers" and it > >sure makes a big difference in cabin noise. > >At 10K I like to run 2200 and 25" which gives me about 155kt and > >12.5 GPH. (this actually equates to an equiv 23" effective due > >to turbo heating). Gotta admit that I do like my Rayjays for those > >long trips. At 24k running 2400 X 27" I can squeeze almost 200kts > >out of the wood-winged-wonder. > > > > >Chris (I wanna "blown" 500B!) Schuermann > > I have been considering that. > I want to install de-ice but if I can't climb above it I don't want > to be in it. > > So what do you think about the cost, installation, maintenance etc. with > the Rayjays? > > When I first bought the 500B I didn't want the extra headaches associated > with > turbos but now most of my flights take me to Tahoe and the extra HP would > help. > > Randy > > ________________________________________________________________________________
Date: May 02, 2001
Subject: Re: Turbos
I'm flying a 500B - w/rayjay turbos - as a loaner from Gary Gadberry while he is refurbishing my new 500A. the wastes gates don't want to close. I've put Mouse Milk on the connections but they still don't seem to want to work. I've always had a fear of Rayjays because of all of the war stories I've heard over the years. Unless I can get these to work I won't have the advantage of seeing how they perform at altitude and since it is not my airplane I am not going to put any money into fixing them. Jim Furlong ________________________________________________________________________________
Date: May 02, 2001
Subject: Re: Turbos
One thing I've discovered is that the wastegates are the first to go; they warp, and no matter how smooth the mechanism, they won't close due to the misshape. /John ----- Original Message ----- From: Furlong5(at)aol.com To: john(at)vormbaum.com ; TCFG(at)listbot.com Sent: Wednesday, May 02, 2001 10:36 AM Subject: Re: Turbos I'm flying a 500B - w/rayjay turbos - as a loaner from Gary Gadberry while he is refurbishing my new 500A. the wastes gates don't want to close. I've put Mouse Milk on the connections but they still don't seem to want to work. I've always had a fear of Rayjays because of all of the war stories I've heard over the years. Unless I can get these to work I won't have the advantage of seeing how they perform at altitude and since it is not my airplane I am not going to put any money into fixing them. Jim Furlong ________________________________________________________________________________
Date: May 02, 2001
Subject: Re: Turbo
Randy, www.mrrpm.com only talks about the Orinda engine program. Does not have any thing on the web site about the 500B Turbo. That is coming. He is offering it two ways. All new and upgrade to the old Rajay system reusing the existing turbos. Give me a call and I can sent it to you. Regards, Tylor Hall tylorh(at)sound.net 913-422-8869 -----Original Message----- From: Randy Sharp [mailto:sharp.r(at)apple.com] Sent: Wednesday, May 02, 2001 12:28 PM To: Tylor Hall Subject: RE: Turbo tylorh(at)sound.net said: >Randy, >I got the stuff from Dick McCoon on his new turbo kit. The new system will >include an intercooler and oil cooler. His system also removes the cowl >flaps, which are replaced by SS exhaust ports. The first system is about to >go on a customer's aircraft in the Seattle area. >In the west, having 25-29" MP available is very good for going over >mountains. >Regards, Tylor Hall Thanks Tylor for this information! Did he mail the information to you or does he have a web site yet? Do you remember what the cost and installation downtime was? Randy ________________________________________________________________________________
Date: May 02, 2001
Several good points everyone. Yes, the additional plumbing definitly makes it more difficult to work on. Here are a few pics of the installation in my Viking Left side http://www.c2-tech.com/~chris/Eng/r0100241.jpg Right side http://www.c2-tech.com/~chris/Eng/r0100236.jpg Here is a picture of one of my wastegates http://www.c2-tech.com/~chris/7ML/mvc-053x.jpg (the pics in the first directory are pre-overhaul - the second dir is during the "firewall forward" if anyone wants to see more) One of the reasons I have so many pictures of the engine installation is that I've had to help _four_ shops re-install engines on turbo- Vikings as they couldn't figure out how to hook everything back up! I never had any problems with my wastegates, but I don't lean at all agressivly and try to keep the temps way down. There are basicly two different Rayjay installations - manyual and auto. In the manual config, you get another knob to play with to control the wastegates by hand. Simple and effective, but it's up to the operator to remember to decrease boost as you decend and to manage boost during climb. The automatic version just maintains selected MAP. Mine also has a little toggle switch on the panel to turn the turbos off (ie: fully open the wastegates). I just always leave 'em turned on. Figure if I'm paying to have the hairdryers that I'll use them... Chris ________________________________________________________________________________
Date: May 02, 2001
HI KIDS......... Good points all. I have no empirical experience with turbo normalized Commanders but I flew a Duke for many years. It to had automatic controllers and they worked great (one would 0ccationaly hang up on TO, so you had to monitor that) It was a joy to fly as you simply set the MP and forgot about it until approach. The engines and turbo system had 1800 hr since overhaul (1600 TBO) when I sold the airplane. I flew it about 400hr. I had ZERO trouble with the turbo system. It used one large turbo one each engine. I chose my current Commander, a 680E, because I need to climb to at least 10K and be able to stay there on one engine. No normally aspirated twin will do that, so one needs turbo or supercharging. I can tell you that it is worth the hassle for me. My airplane climbs well even above 10K and the cruse speeds at altitude are much higher. As a rule of thumb, I figure that climbing from sea level to 12K turns MPH into KPH at the same power setting and fuel burn. It climbs smartly so I climb higher that I otherwise would, giving better performance and a cooler, smother ride in the summer months. I had a normally aspirated 560A before the Duke and made a terrifying trip from SEA to BOI one night. With the family sleeping after a fun weekend, I was looking at a solid undercast only 500 feed below the belly at 11.5K. It was absolutely clear, above and a spectacular ride. My destination was also clear but below me I listened to the shrill voices of the commuter airline guys whining abut "moderate to sever ice" and they were "missing" all the approaches in snow and fog. There I sat knowing that even the failure of one mag would be a "dial 911" emergency! It was one of the longest flights in my log book. The old gal never missed a beat but I promised myself never to expose my family to that again and I never did, hence the Duke and now the 680E. Sorry to be so long winded but living out west has some disadvantages (it is worth it)! I would opt for the hair dryers if I could. Just my opinion. jb ________________________________________________________________________________
Date: May 02, 2001
Subject: Blown Language
In a message dated 05/02/01 12:52:09 Pacific Daylight Time, YOURTCFG(at)aol.com writes: > No normally aspirated twin will do that, so one needs turbo or > supercharging. Everyone here has chosen an airframe / powerplant combination to fit their needs and I am NOT suggesting one is better than another. Let me perfectly clear about that. Just an observation that I was discussing with Michael Macoscko (a list member) who I had the pleasure of meeting in real life on Sunday: The superchargers on the G-series Lycomings are bullet proof. I've only flown one pair that needed to be overhauled and I think it was because the engines had had an overhaul or two, but never the blowers. I know there are several potential owners watching our conversations and they may not know the difference between superchargers and turbochargers. The superchargers on the Geared-Lycoming engines found on Commanders are spun by the engine crankshaft (via reduction gears) and thus are not subject to the 1600 degree exhaust temperatures that turbochargers are. There are no waste gates on the superchargers and they also spin at a much lower RPM than a turbocharger. Many of the turbocharger operating techniques are not required for superchargers, such as the 3-4 minute idle for spin-down, etc. (You may still want to do this for general thermal evening of the entire engine, however, but the roll-out and taxi if not super short will take care of that.) Continental kind of blows the language by calling their big engines "Turbo-Supercharged" bla bla bla when, in fact, they're turbocharged. (As in GTSIO-520-K) Lycoming has upheld the King's English and calls one method "Supercharged" (GSO-480, IGSO-540) and the other "Turbocharged." (TIO-540) OK, class. That's today's lesson in airplane semantics. Your homework assignment is to write a sentence using Supercharger and Turbocharger, and say which one you have or wish you have or wish you didn't have. Wing Commander Gordon ________________________________________________________________________________
Date: May 02, 2001
Subject: WOW!
What an amazing last 24 hours worth of information on this list! I'd like to take a moment to thank everyone who's contributed to the incredible discussions going on. I'm just proud of the content quality here. The "signal-to-noise" ration is higher than any other aviation chatlist I've ever been subscribed to! I hope none of the "lurkers" are becoming overwhelmed with email :-) Howdy to all the new folks - I see quite a few have joined the list in the last few weeks. I (your humble list and web site manager) hope you are finding the list content and discussions informative. The fearless Capt Jimbob (chief of the Twin Commander Flight Group) is a regular contributer the list. There are also some of our friends at Twin Commander Aircraft Corp hanging around who will hopefully hop in and address various topics from time to time as well as let us in on the latest news from the factory. (like when the Shrike will be put back into production :-) If you're an owner or wannabe owner, please consider joining the TCFG. Jim is doing an outstanding job of providing support, information, answers, discounts, etc as well as producing a truely useful newsletter. (besides, he's actually a pretty nice guy, but don't tell him I said so). Chris Schuermann ________________________________________________________________________________
Date: May 02, 2001
Subject: Re: WOW!
Guys, I want to put together a Calendar for the rest of this year and for next year. How about you guys go out and take some pictures of your Commanders on the ground and in flight. Maybe we could get up a formation flight for the calendar next year when we meet in August. I'd like to get the story on your airplanes - maybe Barry can help fill in the blanks. Run out and get a roll of 24 exposure 35 MM film - take some pics - and send the roll of film to me. I will send it up to Photoworks in Seattle. They will put all the pictures online and we can sort through the photos we want on the 2001 remaining calendar. Later in the year we can haggle over the 2002 calendar. We can design the calendar on line on the photoworks site. Also - they will put off high res pictures on CD for 5.00. What do you think ? Paul Chris Schuermann wrote: > > > What an amazing last 24 hours worth of information on this list! > I'd like to take a moment to thank everyone who's contributed to > the incredible discussions going on. I'm just proud of the content > quality here. The "signal-to-noise" ration is higher than any other > aviation chatlist I've ever been subscribed to! > I hope none of the "lurkers" are becoming overwhelmed with email :-) > > Howdy to all the new folks - I see quite a few have joined the > list in the last few weeks. I (your humble list and web site manager) > hope you are finding the list content and discussions informative. > > The fearless Capt Jimbob (chief of the Twin Commander Flight Group) is > a regular contributer the list. There are also some of our friends at > Twin > Commander Aircraft Corp hanging around who will hopefully hop in and > address various topics from time to time as well as let us in on the > latest news from the factory. (like when the Shrike will be put back > into production :-) > > If you're an owner or wannabe owner, please consider joining the TCFG. > Jim is doing an outstanding job of providing support, information, > answers, > discounts, etc as well as producing a truely useful newsletter. > (besides, he's actually a pretty nice guy, but don't tell him I said > so). > > Chris Schuermann > ________________________________________________________________________________
Date: May 02, 2001
Hey guys, Did you all read that article on the space station today ? Apparently it is so loud in the thing that NASA, and everyone else participating in the program, is afraid that the astronuts will go deaf in a short period of time ! And I thought my Aero Commander was loud ! The astronuts have to wear earplugs all the time. Paul YOURTCFG(at)aol.com wrote: > > > In a message dated 5/1/01 6:28:52 PM Pacific Daylight Time, > chris(at)skymaster.c2-tech.com writes: > > >> There's no vibration coupled through and no >> metalic noise or oil-canning. > > CHRIS, That is because there is no metal in there my friend!! love > jb ________________________________________________________________________________
Date: May 02, 2001
Subject: 2001 Calendar
Hey Commanderheads, Please mail the photos to me at: Paul C. Odum 3168 Jacinto Drive Simi Valley, CA 93063 ________________________________________________________________________________
Date: May 02, 2001
Subject: Re: WOW!
How about some digital pix emailed directly to you, Paul? I hear there's going to be a great opportunity to get some formation shots of some Northern California Commanders late in August (heh)... BTW, I finally had a chance to meet another list member today; I had the opportunity to see Randy Sharp land his 500-B in some of the most challenging crosswind conditions I've experienced in my (brief) piloting career, on his way to Morris' hangar today. I know, because I landed my 500-B 10 minutes prior to his arrival. The ATIS called for 20kt. winds, gusting to 35kts., from 360 deg....and we got all of that. And we were landing on Rwy 28....almost a perfect 90 deg. crosswind. All I can say is that Randy's an artist. I'm sure his landing looked a whole lot better than mine! Actually, today was a good day in Commanderland. Randy S. gave Andrew Foss a ride over to pick up his dash 10 690-B. Randy D.'s 680-F was also present, as was Mean Mary....so we had 5 fine examples of Commanders, pretty much covering all phases of Commander development present. I'm getting psyched up for the fly-in! Every time I fly I seem to learn a lesson about Commanders & their versatility. Today's lesson? I have discovered that I own a twin that is perfectly comfortable being slipped! On short final I thought I'd (risk it?) give it a try....and she slipped in as docile as a lamb! Morris confirmed that it's OK....he told me to go ahead and throw full pedal & opposite aileron from 5,500 ft. with the gear out & full flaps, and watch 'er come down at 4,000fpm, not a bit more. I don't know that I'm brave enough to try that yet.... /John PS: How come it always seems to be a headwind on BOTH legs of a round trip? ----- Original Message ----- From: "Paul Odum" <calnet01(at)gte.net> To: Cc: Sent: Wednesday, May 02, 2001 10:04 PM Subject: Re: WOW! > > > Guys, > > I want to put together a Calendar for the rest of this year and for next > year. > > How about you guys go out and take some pictures of your Commanders on the > ground and in flight. Maybe we could get up a formation flight for the > calendar next year when we meet in August. > > I'd like to get the story on your airplanes - maybe Barry can help fill in > the blanks. > > Run out and get a roll of 24 exposure 35 MM film - take some pics - and > send the roll of film to me. > > I will send it up to Photoworks in Seattle. They will put all the pictures > online and we can sort through the photos we want on the 2001 remaining > calendar. Later in the year we can haggle over the 2002 calendar. > > We can design the calendar on line on the photoworks site. Also - they > will put off high res pictures on CD for 5.00. > > What do you think ? > > Paul > > Chris Schuermann wrote: > > > > > > > > > What an amazing last 24 hours worth of information on this list! > > I'd like to take a moment to thank everyone who's contributed to > > the incredible discussions going on. I'm just proud of the content > > quality here. The "signal-to-noise" ration is higher than any other > > aviation chatlist I've ever been subscribed to! > > I hope none of the "lurkers" are becoming overwhelmed with email :-) > > > > Howdy to all the new folks - I see quite a few have joined the > > list in the last few weeks. I (your humble list and web site manager) > > hope you are finding the list content and discussions informative. > > > > The fearless Capt Jimbob (chief of the Twin Commander Flight Group) is > > a regular contributer the list. There are also some of our friends at > > Twin > > Commander Aircraft Corp hanging around who will hopefully hop in and > > address various topics from time to time as well as let us in on the > > latest news from the factory. (like when the Shrike will be put back > > into production :-) > > > > If you're an owner or wannabe owner, please consider joining the TCFG. > > Jim is doing an outstanding job of providing support, information, > > answers, > > discounts, etc as well as producing a truely useful newsletter. > > (besides, he's actually a pretty nice guy, but don't tell him I said > > so). > > > > Chris Schuermann > > > > ________________________________________________________________________________
Date: May 03, 2001
Subject: Re: WOW!
"John Vormbaum" To: Subject: Re: WOW! 03/05/2001 08:24 How about some digital pix emailed directly to you, Paul? I hear there's going to be a great opportunity to get some formation shots of some Northern California Commanders late in August (heh)... Hey - YEH!! What about a formation of fifty Commanders, flying in the shape of '50' at Hillsboro - now that would be a blast! Decibel readings off the scale, or what! I seem to recall the South African Air Force doing a similar formation of T-6s when they were retired from duty some years back. The noise must have been something else. PS: How come it always seems to be a headwind on BOTH legs of a round trip? Yeh! One of life's mysterious anomolies. Could it be the effect of the Gulfstream? Another anomoly is why is it, that when you dial a wrong number, it's never engaged?? Have a Nice Day! Barry ________________________________________________________________________________
Date: May 03, 2001
Subject: Re: WOW!
What a day, flying w/ Randy Sharp. We first left RHV in a Hiller helo, 15 minutes after departure, we hadn't even left RHV's airspace getting spanked and buffeted by a 60+ kt headwind. Bumper to bumber stop and go gridlock traffic on Hwy 680 was about 2x our forward speed. In the spirit of Monty Python's flying circus, we "Ran away...", and took the 500 up to HWD. Arriving in HWD, Randy chirped it in on the right wheel, the left followed eventually, and he was fully cross controlled all the way in. On the roll out w/ full input already in, he had to pat the right brake a bit to stay on the centerline. 3 times that flight he asked "wanna fly?", I assured him I was pretty happy as a pax, thanks anyway. Going in to Steamboat last weekend ATC vectored me right through the approach and into some really nasty looking Wx over the Rockies, since a Pilatus ahead of me hadn't closed their plan. I had a VFR hole, so I cancelled and did John Meredith's knife edge descent. Gear down, 200kts, on the right wing tip, my VSI stops moving at 6000'/min, absolutely smooth, no G's, it's great. The commander come's out of the sky in a hurry, when you need it. As far as sideslipping, I thought the issue with twins had something to do w/ recovery in the event of an engine failure? andrew John Vormbaum wrote: > > > How about some digital pix emailed directly to you, Paul? I hear there's > going to be a great opportunity to get some formation shots of some Northern > California Commanders late in August (heh)... > > BTW, I finally had a chance to meet another list member today; I had the > opportunity to see Randy Sharp land his 500-B in some of the most > challenging crosswind conditions I've experienced in my (brief) piloting > career, on his way to Morris' hangar today. I know, because I landed my > 500-B 10 minutes prior to his arrival. The ATIS called for 20kt. winds, > gusting to 35kts., from 360 deg....and we got all of that. And we were > landing on Rwy 28....almost a perfect 90 deg. crosswind. All I can say is > that Randy's an artist. I'm sure his landing looked a whole lot better than > mine! > > Actually, today was a good day in Commanderland. Randy S. gave Andrew Foss a > ride over to pick up his dash 10 690-B. Randy D.'s 680-F was also present, > as was Mean Mary....so we had 5 fine examples of Commanders, pretty much > covering all phases of Commander development present. I'm getting psyched up > for the fly-in! > > Every time I fly I seem to learn a lesson about Commanders & their > versatility. Today's lesson? I have discovered that I own a twin that is > perfectly comfortable being slipped! On short final I thought I'd (risk it?) > give it a try....and she slipped in as docile as a lamb! Morris confirmed > that it's OK....he told me to go ahead and throw full pedal & opposite > aileron from 5,500 ft. with the gear out & full flaps, and watch 'er come > down at 4,000fpm, not a bit more. I don't know that I'm brave enough to try > that yet.... > > /John > > PS: How come it always seems to be a headwind on BOTH legs of a round trip? > > ----- Original Message ----- > From: "Paul Odum" <calnet01(at)gte.net> > To: > Cc: > Sent: Wednesday, May 02, 2001 10:04 PM > Subject: Re: WOW! > > > > > > > > > Guys, > > > > I want to put together a Calendar for the rest of this year and for next > > year. > > > > How about you guys go out and take some pictures of your Commanders on the > > ground and in flight. Maybe we could get up a formation flight for the > > calendar next year when we meet in August. > > > > I'd like to get the story on your airplanes - maybe Barry can help fill in > > the blanks. > > > > Run out and get a roll of 24 exposure 35 MM film - take some pics - and > > send the roll of film to me. > > > > I will send it up to Photoworks in Seattle. They will put all the pictures > > online and we can sort through the photos we want on the 2001 remaining > > calendar. Later in the year we can haggle over the 2002 calendar. > > > > We can design the calendar on line on the photoworks site. Also - they > > will put off high res pictures on CD for 5.00. > > > > What do you think ? > > > > Paul > > > > Chris Schuermann wrote: > > > > > > > > > > > > > > What an amazing last 24 hours worth of information on this list! > > > I'd like to take a moment to thank everyone who's contributed to > > > the incredible discussions going on. I'm just proud of the content > > > quality here. The "signal-to-noise" ration is higher than any other > > > aviation chatlist I've ever been subscribed to! > > > I hope none of the "lurkers" are becoming overwhelmed with email :-) > > > > > > Howdy to all the new folks - I see quite a few have joined the > > > list in the last few weeks. I (your humble list and web site manager) > > > hope you are finding the list content and discussions informative. > > > > > > The fearless Capt Jimbob (chief of the Twin Commander Flight Group) is > > > a regular contributer the list. There are also some of our friends at > > > Twin > > > Commander Aircraft Corp hanging around who will hopefully hop in and > > > address various topics from time to time as well as let us in on the > > > latest news from the factory. (like when the Shrike will be put back > > > into production :-) > > > > > > If you're an owner or wannabe owner, please consider joining the TCFG. > > > Jim is doing an outstanding job of providing support, information, > > > answers, > > > discounts, etc as well as producing a truely useful newsletter. > > > (besides, he's actually a pretty nice guy, but don't tell him I said > > > so). > > > > > > Chris Schuermann > > > > > > > > > > ________________________________________________________________________________
Date: May 03, 2001
Subject: Re: WOW!
I at least had one of life's major anomoly mathematically explained and put to rest the other day. socks + heat = socks -1 which explains why socks get lost in the dryer. andrew Barry.Collman(at)airclaims.co.uk wrote: > > > "John > Vormbaum" To: > m.com> Subject: Re: WOW! > > 03/05/2001 > 08:24 > > > How about some digital pix emailed directly to you, Paul? I hear there's > going to be a great opportunity to get some formation shots of some > Northern > California Commanders late in August (heh)... > > Hey - YEH!! What about a formation of fifty Commanders, flying in the shape > of '50' at Hillsboro - now that would be a blast! Decibel readings off the > scale, or what! I seem to recall the South African Air Force doing a > similar formation of T-6s when they were retired from duty some years back. > The noise must have been something else. > > PS: How come it always seems to be a headwind on BOTH legs of a round trip? > > Yeh! One of life's mysterious anomolies. Could it be the effect of the > Gulfstream? Another anomoly is why is it, that when you dial a wrong > number, it's never engaged?? > > Have a Nice Day! > > Barry > ________________________________________________________________________________
Date: May 03, 2001
Subject: Re: Propellers
Hi Capt! Thanks for this. It's just that certain 'official' documents show one presentation of this data, whilst others show another. '9333C' it is then, which is good, because that's what I input on the database and with over 250 model 680s, that would have mean a lot of alterations!! Thanks too for letting me know what the various digits mean, that's going to be useful information when looking at other models. Thanks! Kindest Regards, Barry HI BARRY........ Reading from the HARTZELL APPLICATION HANDBOOK, there is NO dash. It should read 9333C. Some of the shorter blades have a dash AFTER the C i.e., 9333C-3. The 3 is some factory modification and not always defined, could be a little more (or less) twist in the blade? Hope this helps.Sorry about the sun, I'll pray for rain!! capt jimbob HI BARRY...... Not that it probably really matters, but I gave you a bit of misinformation. I used to know all this by heart after getting the STC for the "T Bone" props. Here is the correct breakdown. 9333C blades are: 93 = original, uncut diameter. 33 = original templet design. "C" is the twist modification. If it has a -3, that indicates that 3 inches have been removed from the original diameter (now 90 inches). I know, I know, you asked what time it was and I told you how to make a watch, sorry. jb ________________________________________________________________________________
Date: May 03, 2001
Subject: Re: 2001 Calendar
HI KIDS....... I have arranged to have a noted air-to-air photographer at or flyin. His work has been on the cover of many magazines. He took the Feathered engine photo of triple two some of you have seen. He will take a photo of you flying your airplane over the beautiful Oregon scenery for $250, 36 exposures, you keep the negatives. We will have a Maule photo plane 150MPH so everybody should be able to stay close without wearing any flaps. It will be a great opportunity to have a great pix of your bird. He loves doing this so I am sure I can talk him int some "freebie" formation shots if we can get some guys to fly CLOSE formation. The Commander is so big that a lose formation wont work. If you want to have a photo done let me know so we can plan a schedule, it will be a busy few days. Sounds fun, cant wait!! jb ________________________________________________________________________________
Date: May 03, 2001
In a message dated 5/3/2001 9:03:31 AM Pacific Daylight Time, YOURTCFG(at)aol.com writes: > If you want to have a photo done let me know so we can plan a > schedule, it will be a busy few days. > Count me in. Jim Furlong ________________________________________________________________________________
Date: May 03, 2001
From: WilliamPeper(at)cs.com <WilliamPeper(at)cs.com>
Subject: Flying formation sounds great
Hi, y'all It's really great to contemplate a "tight" formation flight up to Washington. . . . I'm even trying to envision getting there myself. However, the talk about formation flight in the last couple of days has caused me to stand up and say a couple of things that I believe are of utmost importance: I have flown quite a bit of "tight" formation in a North American T-28 Trojan with 1400 HP, and the successful execution of it takes knowledge of formation flight, exquisitely precise verbal and hand signal communication, better-than-meticulous technique, and LOTS of practice, practice. Anything less than a thoroughly familiar formation team will, by the power of statisitcs, most likely end up with a tragically disastrous outcome. Straight-ahead formation flight, especially when close-in, is demanding enough when there are several aircraft involved. The complexity immediately increases when you mix airframes of different horsepower and speed capabilities. Start adding turns to the left and right, and you downright INVITE disaster if every person in the flight is not "in sync". I care too much for the people in the TCFG, their heirs, and the image of the venerable aircraft itself to stand by and idly follow the very well-intentioned and inspired threads about flying in a huge formation to the Fly-in. For those who have experience in formation flight, civil or military, careful planning, briefing, and execution could turn out a really nice formation. Again, it takes practice, practice with multiple aircraft, even with "loose" formations. I would suggest getting a copy of the T-34 Association's training films on formation flight. Alternatively, Sporty's carries a good (albeit dry) tape series on T-28 formation flight (at least I think it's still available). Takes a strong cup of coffee to get through those tapes, but there's wisdom in them there cassettes. May everything we do "build up" the image of the Twin Commander . . . if you fly one, you're an ambassador for the design whether you know it or not! Best to all of you Bill Peper Crawford, Texas . . . home of Geo. W. Bush ________________________________________________________________________________
Date: May 03, 2001
Subject: Re: Advice Please!
There is one more consideration. The 685 is built under the same TC as the 690 airplanes and as such is subject to the same, very expensive wing spar AD. This requires that several fuel bladders be removed and the wing be subjected to an ultrasound inspection every 36 months. The 680 airframe does not have thei AD. My .002 jb ________________________________________________________________________________
Date: May 03, 2001
Subject: Re: Flying formation sounds great
Well said Bill. Formation flying is extremely hard under the best of circumstances. You know - no bumps and clear skies. I personally liked to tuck within 2 or 3 feet of the aircraft I flew forms with in the Navy. If you can't do it close you can't do it far away. It's one thing to talk the talk. A completely different proposition to walk the walk - or fly the Aero Commander as it were. We can probably do a very "loose" form workup. I don't think we have enough time to practice for a good group shot. Maybe some two or three ship loose form photos. Paul Callsign - P51PAUL (used to fly my uncle's P-51D down to PCola - hence the callsign) WilliamPeper(at)cs.com wrote: > > > Hi, y'all > It's really great to contemplate a "tight" formation flight up to > Washington. > . . . I'm even trying to envision getting there myself. However, the > talk > about formation flight in the last couple of days has caused me to > stand up > and say a couple of things that I believe are of utmost importance: > I have flown quite a bit of "tight" formation in a North American T-28 > Trojan > with 1400 HP, and the successful execution of it takes knowledge of > formation > flight, exquisitely precise verbal and hand signal communication, > better-than-meticulous technique, and LOTS of practice, practice. > Anything > less than a thoroughly familiar formation team will, by the power of > statisitcs, most likely end up with a tragically disastrous outcome. > Straight-ahead formation flight, especially when close-in, is > demanding > enough when there are several aircraft involved. The complexity > immediately > increases when you mix airframes of different horsepower and speed > capabilities. Start adding turns to the left and right, and you > downright > INVITE disaster if every person in the flight is not "in sync". > I care too much for the people in the TCFG, their heirs, and the image > of the > venerable aircraft itself to stand by and idly follow the very > well-intentioned and inspired threads about flying in a huge formation > to the > Fly-in. > For those who have experience in formation flight, civil or military, > careful > planning, briefing, and execution could turn out a really nice > formation. > Again, it takes practice, practice with multiple aircraft, even with > "loose" > formations. > I would suggest getting a copy of the T-34 Association's training > films on > formation flight. Alternatively, Sporty's carries a good (albeit dry) > tape > series on T-28 formation flight (at least I think it's still > available). > Takes a strong cup of coffee to get through those tapes, but there's > wisdom > in them there cassettes. > May everything we do "build up" the image of the Twin Commander . . . > if you > fly one, you're an ambassador for the design whether you know it or > not! > Best to all of you > Bill Peper > Crawford, Texas . . . home of Geo. W. Bush ________________________________________________________________________________
Date: May 03, 2001
From: CloudCraft(at)aol.com <CloudCraft(at)aol.com>
In a message dated 05/03/01 19:30:56 Pacific Daylight Time, MRPOULIN27(at)aol.com writes: > I am in the process of purchasing a "Twin Commander". Yes I'm excited, but > a little confused. I'm looking at pressurized versions. Other the the > body length, what are the differences between the "685" and the "Shrike > Conversion 680F(P)"? Even though its 10 years older, why is the "680F(P)" > up to $80,000 more. Capt jimbob sent me some great info, but I would like > your opinions. Oh yeah, the "680F(P)" has 400HP R.P.M. engines. Look > forward to hearing from y'all. > Mark, Here's a quick rundown on the differences -- and with little clues to go on, I'll make a few assumptions (eeegads, not that!) about pricing. The AC-685 is the Turbo Commander (AC-690) airframe with Continental GTSIO-540-K engines, rated at 435 hp. for take off. It's a "long body" model with many of the Turbo Commander systems and refinements that came in the early 1970s. The AC-680F(P) is actually an earlier design, but from what you've hinted at, is a "Mr. RPM" conversion, using turbocharged (dual RayJay) Lycoming I0-720 engines rated at 400 hp. This is a "short body" model. The Mr. RPM conversion removed the geared Lycoming engines, skydrol hydraulic system (most conversions did, but not all) and cabin supercharger and went with bleed air pressurization from the RayJay turbos. Being a "Shrike Coversion" 680F(P) marks it as one of Gary Gadberry's products and most likely sports many refinements which may include a Shrike nose, rudder cap, wingletts, and many other nifty things; perhaps a new panel is part of the package. Also, price difference could be due to difference in engine times, mod status and market on one model vs. another. The 680F(P) will have the lesser runway requirement of the two but if you need seating capacity, the 685 is the obvious choice. Ask some more specific quesitions and we'll do our best to answer. Wing Commander Gordon ________________________________________________________________________________
Date: May 04, 2001
AMEN!!!! Bill Bow ----- Original Message ----- From: WilliamPeper(at)cs.com To: TCFG(at)listbot.com Sent: Friday, May 04, 2001 12:28 AM Subject: Flying formation sounds great Hi, y'all It's really great to contemplate a "tight" formation flight up to Washington. . . . I'm even trying to envision getting there myself. However, the talk about formation flight in the last couple of days has caused me to stand up and say a couple of things that I believe are of utmost importance: I have flown quite a bit of "tight" formation in a North American T-28 Trojan with 1400 HP, and the successful execution of it takes knowledge of formation flight, exquisitely precise verbal and hand signal communication, better-than-meticulous technique, and LOTS of practice, practice. Anything less than a thoroughly familiar formation team will, by the power of statisitcs, most likely end up with a tragically disastrous outcome. Straight-ahead formation flight, especially when close-in, is demanding enough when there are several aircraft involved. The complexity immediately increases when you mix airframes of different horsepower and speed capabilities. Start adding turns to the left and right, and you downright INVITE disaster if every person in the flight is not "in sync". I care too much for the people in the TCFG, their heirs, and the image of the venerable aircraft itself to stand by and idly follow the very well-intentioned and inspired threads about flying in a huge formation to the Fly-in. For those who have experience in formation flight, civil or military, careful planning, briefing, and execution could turn out a really nice formation. Again, it takes practice, practice with multiple aircraft, even with "loose" formations. I would suggest getting a copy of the T-34 Association's training films on formation flight. Alternatively, Sporty's carries a good (albeit dry) tape series on T-28 formation flight (at least I think it's still available). Takes a strong cup of coffee to get through those tapes, but there's wisdom in them there cassettes. May everything we do "build up" the image of the Twin Commander . . . if you fly one, you're an ambassador for the design whether you know it or not! Best to all of you Bill Peper Crawford, Texas . . . home of Geo. W. Bush ________________________________________________________________________________
Date: May 04, 2001
From: Mark Woodley Earthlink <woodlema(at)earthlink.net>
I am going to make an assumption that everyone who flies has access to some spare change. If you want to fly formation I would suggest purchasing Elit Flight control systems, and Microsoft Combat Flight sim, and Micsrosoft Flight sim 2001. You can choose a realistc Cessna 182, and perform flights to and from over 3000 airports around the country. Combine the 2, access the Online Microsoft site, and form a squadron. Schedule a Dibs line, and set up a conferance call so everyone in the flight group can talk with each other. Then play Formation flight on the simulator on your home comuter systems. Since he have, what appears to be quite a few military pilots they can teach using the simlator the principals of flight fomationat a cheaper cost than the fuel it would take to perform the training. Once the principals are learned, and there is some semblace of proficiency, you might wanna try it in a Real Life formation. Just a suggestion. You could also buy a nice flight control system from COMP-USA for a few hundred dollars, less than the cost of a tank of fuel. ----- Original Message ----- From: w.bow To: WilliamPeper(at)cs.com ; TCFG(at)listbot.com Sent: Friday, May 04, 2001 10:10 AM Subject: Re: Flying formation sounds great AMEN!!!! Bill Bow ----- Original Message ----- From: WilliamPeper(at)cs.com To: TCFG(at)listbot.com Sent: Friday, May 04, 2001 12:28 AM Subject: Flying formation sounds great Hi, y'all It's really great to contemplate a "tight" formation flight up to Washington. . . . I'm even trying to envision getting there myself. However, the talk about formation flight in the last couple of days has caused me to stand up and say a couple of things that I believe are of utmost importance: I have flown quite a bit of "tight" formation in a North American T-28 Trojan with 1400 HP, and the successful execution of it takes knowledge of formation flight, exquisitely precise verbal and hand signal communication, better-than-meticulous technique, and LOTS of practice, practice. Anything less than a thoroughly familiar formation team will, by the power of statisitcs, most likely end up with a tragically disastrous outcome. Straight-ahead formation flight, especially when close-in, is demanding enough when there are several aircraft involved. The complexity immediately increases when you mix airframes of different horsepower and speed capabilities. Start adding turns to the left and right, and you downright INVITE disaster if every person in the flight is not "in sync". I care too much for the people in the TCFG, their heirs, and the image of the venerable aircraft itself to stand by and idly follow the very well-intentioned and inspired threads about flying in a huge formation to the Fly-in. For those who have experience in formation flight, civil or military, careful planning, briefing, and execution could turn out a really nice formation. Again, it takes practice, practice with multiple aircraft, even with "loose" formations. I would suggest getting a copy of the T-34 Association's training films on formation flight. Alternatively, Sporty's carries a good (albeit dry) tape series on T-28 formation flight (at least I think it's still available). Takes a strong cup of coffee to get through those tapes, but there's wisdom in them there cassettes. May everything we do "build up" the image of the Twin Commander . . . if you fly one, you're an ambassador for the design whether you know it or not! Best to all of you Bill Peper Crawford, Texas . . . home of Geo. W. Bush ________________________________________________________________________________
Date: May 04, 2001
Guys, Us military people spent hours and hours and dollars and dollars of your tax money learning how to do this. Flight sims, while a good (read safe) method are no substitution for burning up a lot of fuel practicing. Paul Mark Woodley Earthlink wrote: > > I am going to make an assumption that everyone who flies has access > to some spare change. If you want to fly formation I would suggest > purchasing Elit Flight control systems, and Microsoft Combat Flight > sim, and Micsrosoft Flight sim 2001. You can choose a realistc Cessna > 182, and perform flights to and from over 3000 airports around the > country. Combine the 2, access the Online Microsoft site, and form a > squadron. Schedule a Dibs line, and set up a conferance call so > everyone in the flight group can talk with each other. Then play > Formation flight on the simulator on your home comuter systems. Since > he have, what appears to be quite a few military pilots they can teach > using the simlator the principals of flight fomationat a cheaper cost > than the fuel it would take to perform the training. Once the > principals are learned, and there is some semblace of proficiency, you > might wanna try it in a Real Life formation. Just a suggestion. You > could also buy a nice flight control system from COMP-USA for a few > hundred dollars, less than the cost of a tank of fuel. > > ----- Original Message ----- > From: w.bow > To: WilliamPeper(at)cs.com ; TCFG(at)listbot.com > Sent: Friday, May 04, 2001 10:10 AM > Subject: Re: Flying formation sounds great > > Transfer balances to an APR as low as 2.99% Intro or 9.99% > Ongoing. > 24-hour online account management and Rewards Points for > every > > AMEN!!!! Bill Bow > > ----- Original Message ----- > From: WilliamPeper(at)cs.com > To: TCFG(at)listbot.com > Sent: Friday, May 04, 2001 12:28 AM > Subject: Flying formation sounds great > Twin Commander Flight Group - > http://www.aerocommander.com > > > Hi, y'all > It's really great to contemplate a "tight" > formation flight up to Washington. > . . . I'm even trying to envision getting there > myself. However, the talk > about formation flight in the last couple of days > has caused me to stand up > and say a couple of things that I believe are of > utmost importance: > I have flown quite a bit of "tight" formation in a > North American T-28 Trojan > with 1400 HP, and the successful execution of it > takes knowledge of formation > flight, exquisitely precise verbal and hand signal > communication, > better-than-meticulous technique, and LOTS of > practice, practice. Anything > less than a thoroughly familiar formation team > will, by the power of > statisitcs, most likely end up with a tragically > disastrous outcome. > Straight-ahead formation flight, especially when > close-in, is demanding > enough when there are several aircraft involved. > The complexity immediately > increases when you mix airframes of different > horsepower and speed > capabilities. Start adding turns to the left and > right, and you downright > INVITE disaster if every person in the flight is > not "in sync". > I care too much for the people in the TCFG, their > heirs, and the image of the > venerable aircraft itself to stand by and idly > follow the very > well-intentioned and inspired threads about flying > in a huge formation to the > Fly-in. > For those who have experience in formation flight, > civil or military, careful > planning, briefing, and execution could turn out a > really nice formation. > Again, it takes practice, practice with multiple > aircraft, even with "loose" > formations. > I would suggest getting a copy of the T-34 > Association's training films on > formation flight. Alternatively, Sporty's carries > a good (albeit dry) tape > series on T-28 formation flight (at least I think > it's still available). > Takes a strong cup of coffee to get through those > tapes, but there's wisdom > in them there cassettes. > May everything we do "build up" the image of the > Twin Commander . . . if you > fly one, you're an ambassador for the design > whether you know it or not! > Best to all of you > Bill Peper > Crawford, Texas . . . home of Geo. W. Bush > To unsubscribe, write to > TCFG-unsubscribe(at)listbot.com > > ________________________________________________________________________________
Date: May 04, 2001
In a message dated 5/4/2001 7:52:48 AM Pacific Daylight Time, calnet01(at)gte.net writes: > I am going to make an assumption that everyone who flies has access to some > spare change On the contrary --- if I didn't fly I might have some "spare change". ________________________________________________________________________________
Date: May 04, 2001
Subject: Flying formation sounds great but safety is paramount
I agree with the concerned members about formation safety. There is no substitution for actual flight experience and thorough training using approved instructors. Think about putting a cocky 23 year old kid in a T38 and group them all together in one large flight... The only way they survived was from a dedicated, regimented, disciplined, flight program. Yes the USAF and other military organizations do have simulators but from my experience the feedback from the visuals and performance characteristics are not the same. (And these are MULTI-MILLION dollar full motion full visual Sims) Not a $2K PC. If the program is done correctly it can be safe, but when done incorrectly it can be disastrous, and this of course strongly depends on the experience of the pilots in the formation and flight LEAD. I really don't think anyone was suggesting taking zero time formation pilots and flying them at 5-10 ft echelon intervals. Hopefully that was not inferred from the conversations. As someone mentioned, we probably don't have the time to coordinate for a large formation nor tight spacing in the given time frame even WITH the experienced formation pilots we have. Maybe a brief introduction to the basics at a very loose interval while enroute to OR would be more appropriate. No more than two to a wing formation etc. (practice is key but coordination is critical!) If anyone is interested, I have enclosed a Formation inflight briefing guide for example. You will see there are LOTS of details that need to be discussed before every formation flight. (word document) Randy calnet01(at)gte.net said: >Guys, >Us military people spent hours and hours and dollars and dollars of your >tax money learning how to do this. Flight sims, while a good (read safe) >method are no substitution for burning up a lot of fuel practicing. >Paul > >Mark Woodley Earthlink wrote: >> I am going to make an assumption that everyone who flies has access >> to some spare change. If you want to fly formation I would suggest >> purchasing Elit Flight control systems, and Microsoft Combat Flight >> sim, and Micsrosoft Flight sim 2001. You can choose a realistc Cessna >> 182, and perform flights to and from over 3000 airports around the >> country. Combine the 2, access the Online Microsoft site, and form a >> squadron. Schedule a Dibs line, and set up a conferance call so >> everyone in the flight group can talk with each other. Then play >> Formation flight on the simulator on your home comuter systems. Since >> he have, what appears to be quite a few military pilots they can teach >> using the simlator the principals of flight fomationat a cheaper cost >> than the fuel it would take to perform the training. Once the >> principals are learned, and there is some semblace of proficiency, you >> might wanna try it in a Real Life formation. Just a suggestion. You >> could also buy a nice flight control system from COMP-USA for a few >> hundred dollars, less than the cost of a tank of fuel. >> >> ----- Original Message ----- >> From: w.bow >> To: WilliamPeper(at)cs.com ; TCFG(at)listbot.com >> Sent: Friday, May 04, 2001 10:10 AM >> Subject: Re: Flying formation sounds great >> >> AMEN!!!! Bill Bow >> >> Hi, y'all >> It's really great to contemplate a "tight" >> formation flight up to Washington. >> . . . I'm even trying to envision getting there >> myself. However, the talk >> about formation flight in the last couple of days >> has caused me to stand up >> and say a couple of things that I believe are of >> utmost importance: >> I have flown quite a bit of "tight" formation in a >> North American T-28 Trojan >> with 1400 HP, and the successful execution of it >> takes knowledge of formation >> flight, exquisitely precise verbal and hand signal >> communication, >> better-than-meticulous technique, and LOTS of >> practice, practice. Anything >> less than a thoroughly familiar formation team >> will, by the power of >> statisitcs, most likely end up with a tragically >> disastrous outcome. >> Straight-ahead formation flight, especially when >> close-in, is demanding >> enough when there are several aircraft involved. >> The complexity immediately >> increases when you mix airframes of different >> horsepower and speed >> capabilities. Start adding turns to the left and >> right, and you downright >> INVITE disaster if every person in the flight is >> not "in sync". >> I care too much for the people in the TCFG, their >> heirs, and the image of the >> venerable aircraft itself to stand by and idly >> follow the very >> well-intentioned and inspired threads about flying >> in a huge formation to the >> Fly-in. >> For those who have experience in formation flight, >> civil or military, careful >> planning, briefing, and execution could turn out a >> really nice formation. >> Again, it takes practice, practice with multiple >> aircraft, even with "loose" >> formations. >> I would suggest getting a copy of the T-34 >> Association's training films on >> formation flight. Alternatively, Sporty's carries >> a good (albeit dry) tape >> series on T-28 formation flight (at least I think >> it's still available). >> Takes a strong cup of coffee to get through those >> tapes, but there's wisdom >> in them there cassettes. >> May everything we do "build up" the image of the >> Twin Commander . . . if you >> fly one, you're an ambassador for the design >> whether you know it or not! >> Best to all of you >> Bill Peper >> Crawford, Texas . . . home of Geo. W. Bush ________________________________________________________________________________
Date: May 04, 2001
Subject: Re: Flying formation sounds great but safety is paramount
I never suggested PC sim training as a substitute. Only as a basis for getting the basic principals involved in it. As with anything there are principals (theories that need understood) involved. We all study things before we actually practice them, or at least I hope we would. I simply suggested a method by which you could easily learn the principals prior to kicking the starter. I apologize for my pitiful suggestion. **Mark goes into corner and shuts his mouth now** Mark ----- Original Message ----- From: "Randy Sharp" <sharp.r(at)apple.com> To: Sent: Friday, May 04, 2001 12:40 PM Subject: Flying formation sounds great but safety is paramount > > > I agree with the concerned members about formation safety. > There is no substitution for actual flight experience and thorough > training using approved > instructors. > > Think about putting a cocky 23 year old kid in a T38 and group them > all together in one large flight... > The only way they survived was from a dedicated, regimented, disciplined, > flight program. Yes the USAF and other military organizations do have > simulators > but from my experience the feedback from the visuals and performance > characteristics > are not the same. (And these are MULTI-MILLION dollar full motion full > visual Sims) > Not a $2K PC. > > If the program is done correctly it can be safe, but when done > incorrectly it can > be disastrous, and this of course strongly depends on the experience of > the pilots > in the formation and flight LEAD. > > I really don't think anyone was suggesting taking zero time formation > pilots and flying > them at 5-10 ft echelon intervals. Hopefully that was not inferred from > the conversations. > > As someone mentioned, we probably don't have the time to coordinate for a > large formation > nor tight spacing in the given time frame even WITH the experienced > formation pilots we have. > > Maybe a brief introduction to the basics at a very loose interval while > enroute to OR would > be more appropriate. No more than two to a wing formation etc. > > (practice is key but coordination is critical!) > > If anyone is interested, I have enclosed a Formation inflight briefing > guide for example. > You will see there are LOTS of details that need to be discussed before > every formation flight. > (word document) > > Randy > > calnet01(at)gte.net said: > >Guys, > >Us military people spent hours and hours and dollars and dollars of your > >tax money learning how to do this. Flight sims, while a good (read safe) > >method are no substitution for burning up a lot of fuel practicing. > >Paul > > > >Mark Woodley Earthlink wrote: > >> I am going to make an assumption that everyone who flies has access > >> to some spare change. If you want to fly formation I would suggest > >> purchasing Elit Flight control systems, and Microsoft Combat Flight > >> sim, and Micsrosoft Flight sim 2001. You can choose a realistc Cessna > >> 182, and perform flights to and from over 3000 airports around the > >> country. Combine the 2, access the Online Microsoft site, and form a > >> squadron. Schedule a Dibs line, and set up a conferance call so > >> everyone in the flight group can talk with each other. Then play > >> Formation flight on the simulator on your home comuter systems. Since > >> he have, what appears to be quite a few military pilots they can teach > >> using the simlator the principals of flight fomationat a cheaper cost > >> than the fuel it would take to perform the training. Once the > >> principals are learned, and there is some semblace of proficiency, you > >> might wanna try it in a Real Life formation. Just a suggestion. You > >> could also buy a nice flight control system from COMP-USA for a few > >> hundred dollars, less than the cost of a tank of fuel. > >> > >> ----- Original Message ----- > >> From: w.bow > >> To: WilliamPeper(at)cs.com ; TCFG(at)listbot.com > >> Sent: Friday, May 04, 2001 10:10 AM > >> Subject: Re: Flying formation sounds great > >> > >> AMEN!!!! Bill Bow > >> > >> Hi, y'all > >> It's really great to contemplate a "tight" > >> formation flight up to Washington. > >> . . . I'm even trying to envision getting there > >> myself. However, the talk > >> about formation flight in the last couple of days > >> has caused me to stand up > >> and say a couple of things that I believe are of > >> utmost importance: > >> I have flown quite a bit of "tight" formation in a > >> North American T-28 Trojan > >> with 1400 HP, and the successful execution of it > >> takes knowledge of formation > >> flight, exquisitely precise verbal and hand signal > >> communication, > >> better-than-meticulous technique, and LOTS of > >> practice, practice. Anything > >> less than a thoroughly familiar formation team > >> will, by the power of > >> statisitcs, most likely end up with a tragically > >> disastrous outcome. > >> Straight-ahead formation flight, especially when > >> close-in, is demanding > >> enough when there are several aircraft involved. > >> The complexity immediately > >> increases when you mix airframes of different > >> horsepower and speed > >> capabilities. Start adding turns to the left and > >> right, and you downright > >> INVITE disaster if every person in the flight is > >> not "in sync". > >> I care too much for the people in the TCFG, their > >> heirs, and the image of the > >> venerable aircraft itself to stand by and idly > >> follow the very > >> well-intentioned and inspired threads about flying > >> in a huge formation to the > >> Fly-in. > >> For those who have experience in formation flight, > >> civil or military, careful > >> planning, briefing, and execution could turn out a > >> really nice formation. > >> Again, it takes practice, practice with multiple > >> aircraft, even with "loose" > >> formations. > >> I would suggest getting a copy of the T-34 > >> Association's training films on > >> formation flight. Alternatively, Sporty's carries > >> a good (albeit dry) tape > >> series on T-28 formation flight (at least I think > >> it's still available). > >> Takes a strong cup of coffee to get through those > >> tapes, but there's wisdom > >> in them there cassettes. > >> May everything we do "build up" the image of the > >> Twin Commander . . . if you > >> fly one, you're an ambassador for the design > >> whether you know it or not! > >> Best to all of you > >> Bill Peper > >> Crawford, Texas . . . home of Geo. W. Bush > > ________________________________________________________________________________
Date: May 04, 2001
woodlema(at)earthlink.net said: >I never suggested PC sim training as a substitute. Only as a basis for >getting the basic principals involved in it. As with anything there are >principals (theories that need understood) involved. We all study things >before we actually practice them, or at least I hope we would. That's why I mentioned the simulator WAS used in the military. Believe me they DO use them a lot. I just wanted to say that it confused me more in some cases than helped. (some guys got really sick from the desync situation, must be from the lowest bidder on the software program) But it's always a good staring point. (Saves JP4 too in the long run) >I simply suggested a method by which you could easily learn the principals >prior to kicking the starter. I apologize for my pitiful suggestion. It's Not a bad suggestion, a sim is still a good idea to be used as a supplement teaching aid. Especially If you have enough monitor screens! I actually taught my son how to fly an F18 from a dual CPU 3 monitor sim setup. Albeit it wasn't like the real thing but it sure was fun. (Except he kept shooting me down while in formation) I consistently told him NOT to fire on his wingmen. (Kids) >**Mark goes into corner and shuts his mouth now** >Mark Nah Keep those ideas and suggestions coming! A suggestion not given is an Idea not learned? (where did I hear that?) RS ________________________________________________________________________________
Date: May 04, 2001
From: Chris Schuermann <chris(at)skymaster.c2-tech.com>
Subject: web site update
First, my appologies for not keeping the web site updated very well. I've been working almost around the clock for what seems like forever and also trying to work in building a new house in my spare moments. Anyway, I've added several backed up pages on the Rennaisance 690 from Byerly. I've also decided to provide individually clickable pics since for several weeks the pictures were very large. In the latest update, she's back on her feet and ready for a test flight and then on to the paint shop. (sure wish _I_ was the customer!) Chris ________________________________________________________________________________
Date: May 04, 2001
Guys, I think that we could get away with several loose finger 4 formations. The Bonanza guys do it for Oshkosh. it will take extreme concentration, gasoline and " No RT Chatter !!!!" We can set up the aircraft in finger 4 formations on the ground and then pick out that rivet you will keep sighted on the entire flight ! Follow the leader. Paul Randy Sharp wrote: > > > I agree with the concerned members about formation safety. > There is no substitution for actual flight experience and thorough > training using approved > instructors. > > Think about putting a cocky 23 year old kid in a T38 and group them > all together in one large flight... > The only way they survived was from a dedicated, regimented, disciplined, > flight program. Yes the USAF and other military organizations do have > simulators > but from my experience the feedback from the visuals and performance > characteristics > are not the same. (And these are MULTI-MILLION dollar full motion full > visual Sims) > Not a $2K PC. > > If the program is done correctly it can be safe, but when done > incorrectly it can > be disastrous, and this of course strongly depends on the experience of > the pilots > in the formation and flight LEAD. > > I really don't think anyone was suggesting taking zero time formation > pilots and flying > them at 5-10 ft echelon intervals. Hopefully that was not inferred from > the conversations. > > As someone mentioned, we probably don't have the time to coordinate for a > large formation > nor tight spacing in the given time frame even WITH the experienced > formation pilots we have. > > Maybe a brief introduction to the basics at a very loose interval while > enroute to OR would > be more appropriate. No more than two to a wing formation etc. > > (practice is key but coordination is critical!) > > If anyone is interested, I have enclosed a Formation inflight briefing > guide for example. > You will see there are LOTS of details that need to be discussed before > every formation flight. > (word document) > > Randy > > calnet01(at)gte.net said: > >Guys, > >Us military people spent hours and hours and dollars and dollars of your > >tax money learning how to do this. Flight sims, while a good (read safe) > >method are no substitution for burning up a lot of fuel practicing. > >Paul > > > >Mark Woodley Earthlink wrote: > >> I am going to make an assumption that everyone who flies has access > >> to some spare change. If you want to fly formation I would suggest > >> purchasing Elit Flight control systems, and Microsoft Combat Flight > >> sim, and Micsrosoft Flight sim 2001. You can choose a realistc Cessna > >> 182, and perform flights to and from over 3000 airports around the > >> country. Combine the 2, access the Online Microsoft site, and form a > >> squadron. Schedule a Dibs line, and set up a conferance call so > >> everyone in the flight group can talk with each other. Then play > >> Formation flight on the simulator on your home comuter systems. Since > >> he have, what appears to be quite a few military pilots they can teach > >> using the simlator the principals of flight fomationat a cheaper cost > >> than the fuel it would take to perform the training. Once the > >> principals are learned, and there is some semblace of proficiency, you > >> might wanna try it in a Real Life formation. Just a suggestion. You > >> could also buy a nice flight control system from COMP-USA for a few > >> hundred dollars, less than the cost of a tank of fuel. > >> > >> ----- Original Message ----- > >> From: w.bow > >> To: WilliamPeper(at)cs.com ; TCFG(at)listbot.com > >> Sent: Friday, May 04, 2001 10:10 AM > >> Subject: Re: Flying formation sounds great > >> > >> AMEN!!!! Bill Bow > >> > >> Hi, y'all > >> It's really great to contemplate a "tight" > >> formation flight up to Washington. > >> . . . I'm even trying to envision getting there > >> myself. However, the talk > >> about formation flight in the last couple of days > >> has caused me to stand up > >> and say a couple of things that I believe are of > >> utmost importance: > >> I have flown quite a bit of "tight" formation in a > >> North American T-28 Trojan > >> with 1400 HP, and the successful execution of it > >> takes knowledge of formation > >> flight, exquisitely precise verbal and hand signal > >> communication, > >> better-than-meticulous technique, and LOTS of > >> practice, practice. Anything > >> less than a thoroughly familiar formation team > >> will, by the power of > >> statisitcs, most likely end up with a tragically > >> disastrous outcome. > >> Straight-ahead formation flight, especially when > >> close-in, is demanding > >> enough when there are several aircraft involved. > >> The complexity immediately > >> increases when you mix airframes of different > >> horsepower and speed > >> capabilities. Start adding turns to the left and > >> right, and you downright > >> INVITE disaster if every person in the flight is > >> not "in sync". > >> I care too much for the people in the TCFG, their > >> heirs, and the image of the > >> venerable aircraft itself to stand by and idly > >> follow the very > >> well-intentioned and inspired threads about flying > >> in a huge formation to the > >> Fly-in. > >> For those who have experience in formation flight, > >> civil or military, careful > >> planning, briefing, and execution could turn out a > >> really nice formation. > >> Again, it takes practice, practice with multiple > >> aircraft, even with "loose" > >> formations. > >> I would suggest getting a copy of the T-34 > >> Association's training films on > >> formation flight. Alternatively, Sporty's carries > >> a good (albeit dry) tape > >> series on T-28 formation flight (at least I think > >> it's still available). > >> Takes a strong cup of coffee to get through those > >> tapes, but there's wisdom > >> in them there cassettes. > >> May everything we do "build up" the image of the > >> Twin Commander . . . if you > >> fly one, you're an ambassador for the design > >> whether you know it or not! > >> Best to all of you > >> Bill Peper > >> Crawford, Texas . . . home of Geo. W. Bush > > > Name: Formation Brief.doc > Formation Brief.doc Type: Winword File (application/msword) > Encoding: base64 ________________________________________________________________________________
Date: May 04, 2001
Subject: Oil 101 Answer
I'm pretty bushed tonight so I thought I would give the answer early and take the weekend off. The answer to Homework question was Lycoming Additive LW-16702. This additive is found in Aeroshell W100 Plus and 15W-50 oils. Also found in Exxon Aviation Oil Elite 20W-50. I'm checking on the Phillips. I was under the impression that it contained LW-16702 according to some old documentation I had from Lycoming that recommended as the company's choice for the GSO-480. If it does not I may switch to the Exxon Elite. New's at 11:00. Here' some information for your edification. http://www.lycoming.textron.com/support/publications/index.html http://www.tdatacorp.com/saib/ANE9922.htm http://www.prime-mover.com/Engines/GArticles/Copper.html http://www.carneyaviation.com/doc/breakin.htm I happened to read the May AOPA pilot tonight and they stated that about 1/3 of the engines that come through Lycoming for rebuild will need new camshafts if LW-16702 is not run (assuming from article). LW-16702 is an antiscuffing additive. It helps to lubricate the camshaft and hydraulic lifter bodies after engine startup. You guys don't need any additional homework reading do you ? NAH ! P51PAUL ________________________________________________________________________________
Date: May 04, 2001
From: MRPOULIN27(at)aol.com <MRPOULIN27(at)aol.com>
Subject: Two more cents
Dear Commander Owners, Thank you all for your previous input. Excuse the errors(if any). I've just finished reading the last 50 pages of y'alls postings . . . "You guys are great!" I'm going to make it to the Fly-In. Even if I have to bring my instructor along w/me! Some more background; Most of my flying will be 700-900 miles. Roughly 30 times a year, w/ smaller trips of 200-300 miles, 10 times a year. Passengers will be freinds, family, and biz associates(4-6max). O.K Question 1: Performance of the 685? 2: Is the SPAR a problem(685)? 3: Why do I like the 680F(P) so much? Gary Gadberry has a couple of the planes I'm looking at.(AIRCNTR.com) 89PK and 414C. Let me know what you think. Again, Thanks for ALL the help! Mark ________________________________________________________________________________
Date: May 04, 2001
Subject: Re: Two more cents
In a message dated 05/04/01 21:05:17 Pacific Daylight Time, MRPOULIN27(at)aol.com writes: > Gary Gadberry has a couple of the planes I'm looking at.(AIRCNTR.com) 89PK > and 414C. > Let me know what you think. Again, Thanks for ALL the help! Mark, I've given several check-outs in 680F(P)s and FLPs and set my clients up with trend monitoring sheets, but don't know if they ever used them. Off the top of my head, I can't recall accurate performance figures, only distorted memories. On the other hand, I used to fly N414C and if you'll give me a few days, I'll go to my storage locker and look up my trend monitoring data from that aircraft, circa 1997-98. Q: Is the spar a problem on the 685? A: No, not if its ultra sound inspection allows it to be a 36 month interval. Even a 24 month interval is not that bad. It is an additional inspection and although there is lots of experience doing it now, you still have to budget that in, plus the inevitable fuel cell replacement here and there that goes along with disturbing them for the inspection. Q: Why do I like the 680F(P) so much? A: Because you have good taste in airplanes. Of course, this shows with both of your choices. You haven't told us about your runways. If they're long enough and you are really going to carry 6 pax for business, I'd consider the 685. As a biz airplane, bigger is always better. It's also way quieter. You'll find the pressurization on the 685 more reliable and easier to operate. (You have to deal with vairiable RayJay output on the Mr. RPM 680F(P) and maintaining cabin pressure during descent is an art.) If your biz pax are really more of the "friends going along for a ride" variety and if 6 of them is rare and they're genuine aviation enthusiasts, the 680F(P) will be great. As you can see, I'm starting to make a distinction between a personal airplane and a biz airplane. The 685 was definitely a biz airplane from its inception. Few of my clients would stand up and admit that their Commander was for pure fun. All but one or two claimed them as biz aircraft, so just between us girls, let us know to what degree you're looking for a corporate airplane, or are just going to write off your dream come true. Uhhhh .... I don't think we have any IRS agents on this list, do we? Keith S. Gordon aka Wing Commander Gordon ________________________________________________________________________________
Date: May 04, 2001
Subject: Re: Oil 101 Answer and another Mystery Question
In a message dated 05/04/01 20:59:55 Pacific Daylight Time, calnet01(at)gte.net writes: > You guys don't need any additional homework reading do you ? Sure, P51Paul! Why quit now? OK, class. What is it in automotive fuel (MoGas) that Lycoming really doesn't like and is really why they won't allow it in the GO-435 or GO-480? (In earlier days of the Twin Commander Flight Group I tried to push MoGas through as an advocate to those owners and found out this factoid.) Don't worry -- I won't keep you in suspense like Paul-O did. I'll only leave you sleepless for a day or two. Wing Commander Gordon ________________________________________________________________________________
Date: May 05, 2001
MRPOULIN27(at)aol.com wrote: Again, Thanks for ALL the help! > > Mark Mark, I'm glad you're getting valuable info here! Thought I'd a my two cents worth... As one point of reference - the freight guys LOVE the 680FL(P)'s. That says a lot for the overall abilities, reliability, and functionality of the model. I know you're looking at a 720-powered bird. The Lycomng 720s are outstanding engines. I've seen many run to TBO with no problems on crop dusters (which certainly is "severe" duty). You WILL need to study up on operation of the turbo systems if they are of the manual type. Properly operated, they won't affect the reliability or life of the engine at all. I ran my turbo'd IO-540 2000 hrs and never had a jug off. It is possible to destroy the engines due to boost mismanagment though. There was an accident a few years ago in a 680FLP where the new owner just shoved ALL the knobs in on his very first flight and blew both engines catastrophicaly due to MASSIVE overboost. Keith's previous info is, of course, dead on.... Let us know how your search work out! Chris ________________________________________________________________________________
Date: May 05, 2001
Subject: N414C, AC-685 cruise data
I'm ashamed to say I now have to apologize to all past girlfriends, wife, or worse. Three weeks ago I came across the flight logs for N414C and was going to throw them way. Then I heard the collective voices off all those women scolding me, "You may need that someday"; and so, kept it. And here it is. A sample of flights I did in N414C, an AC-685. Low altitude sprints and higher altitude cruise. A few notes: The power setting I used is about 62-65% and fuel flows were set to obtain a TIT (Turbine Inlet Temperature) that was 100 degrees rich of peak. This TIT averaged 1550 / 1525 degrees. The fuel flows are Left /Right engine, respectively. Altitude 10,000' IOAT -10c KIAS: 163 DENALT: 8356 KTAS: 185 33" MAP 2600 RPM FUEL FLOW: 120/130 pph Altitude: 11,000 IOAT -08c KIAS 153 DENALT: 10317 KTAS: 179 33" MAP 2600 RPM FUEL FLOW: 125/120 pph Altitude: 17,000 IOAT: -14c KIAS 154 DENALT: 16049 KTAS: 197 33" MAP 2600 RPM FUEL FLOW: 125/120 pph **75% power to break in newcylinder** Altitude: 6000 IOAT: +01c KIAS 175 DENALT: 5147 KTAS: 189 35" MAP 2800 RPM FUEL FLOW: 165/160 pph set for cylinder head temp. I never took this airplane into the flight levels because I never had trips long enough to climb that high. This model is NOT a climber so I used the mid to high teens for my trips. It does its best in the high teens, as you can see. Let me know if you have anymore questions about this particular AC-685, or anything else. Do we have any MR. RPM operators on the list for fuel flows and TAS? I'm tempted to say the performance is close to the same as the AC-685, but really wish I had hard data right now. Wing Commander Gordon ________________________________________________________________________________
Date: May 05, 2001
Subject: Chlorine
Chlorine. That's what's in automotive fuel (MoGas) that Lycoming is really squeamish about. The Lycoming tech reps never got around to discussing why there was chlorine in MoGas, but it was verbally put to me that this is why Lycoming Just Says No to MoGas, aside from the usual talk of vaporization, detonation, bla bla bla, and why AC-520 and AC-560 operators couldn't get approval. Wing Commander Gordon ________________________________________________________________________________
Date: May 05, 2001
Subject: Another Day In Commanderland With Yoda
Well Damn ! I finally got to get airborne in N680E around Noon today. took a couple of friends along to meet Yoda. Pointed her at Hayward and visited with Morris for 1.5 hours. He was painting on some 500B nacelles out behind the hangar. Typical ! Tuned up the carbs. Fuel burns were 33.6 GPH up, at 12,500 feet, and 32.7 GPH at 13,500 homeward bound. I started with empty tanks. Towed the airplane down to the fuel pits at Camarillo and calibrated the tanks. That's great information to have. I know what I've got now starting from zero (0). That's the way to go. Loaded 222.1 gallons into the airplane. Beautiful day ! Paul ________________________________________________________________________________
Date: May 05, 2001
Hey Keith and group, I did some trend monitoring today in the 680E. Here are the numbers. Do you they look OK to you guy ?. I'm worried about fuel pressures. Time 1330 Local Location between Santa Maria and Paso Robles ( Outbound to Morris's) Altitude 12,500 feet OAT 32 F / 0 C TAS - I think around 183 Knots MP 30 / 30 RPM 2700 / 2700 CHT 190 / 185 Oil Temp 78 C / 75 C Oil Pres 85 / 83 Fuel Pres 8.2 / 9.8 Carb Temp 10 C / 10 C Return From Morris's Time 1705 Local Location King City Alt 13,500 OAT 32 F / 0 C TAS - 183 Knots MP 31.5 / 31.5 RPM 2750 / 2750 CHT 199 / 189 Oil Temp 80 C / 79 C Oil Pres 87.5 / 85 Fuel Pres 8.0 / 9.8 Carb Temp 12 C / 11 C CloudCraft(at)aol.com wrote: > > > In a message dated 05/04/01 21:05:17 Pacific Daylight Time, > MRPOULIN27(at)aol.com writes: > > >> Gary Gadberry has a couple of the planes I'm looking >> at.(AIRCNTR.com) 89PK >> and 414C. >> Let me know what you think. Again, Thanks for ALL the help! > > Mark, > > I've given several check-outs in 680F(P)s and FLPs and set my clients > up with > trend monitoring sheets, but don't know if they ever used them. Off > the top > of my head, I can't recall accurate performance figures, only > distorted > memories. > > On the other hand, I used to fly N414C and if you'll give me a few > days, I'll > go to my storage locker and look up my trend monitoring data from that > > aircraft, circa 1997-98. > > Q: Is the spar a problem on the 685? > A: No, not if its ultra sound inspection allows it to be a 36 month > interval. > Even a 24 month interval is not that bad. It is an additional > inspection > and although there is lots of experience doing it now, you still have > to > budget that in, plus the inevitable fuel cell replacement here and > there that > goes along with disturbing them for the inspection. > > Q: Why do I like the 680F(P) so much? > A: Because you have good taste in airplanes. Of course, this shows > with > both of your choices. > > You haven't told us about your runways. If they're long enough and > you are > really going to carry 6 pax for business, I'd consider the 685. As a > biz > airplane, bigger is always better. It's also way quieter. You'll > find the > pressurization on the 685 more reliable and easier to operate. (You > have to > deal with vairiable RayJay output on the Mr. RPM 680F(P) and > maintaining > cabin pressure during descent is an art.) > > If your biz pax are really more of the "friends going along for a > ride" > variety and if 6 of them is rare and they're genuine aviation > enthusiasts, > the 680F(P) will be great. > > As you can see, I'm starting to make a distinction between a personal > airplane and a biz airplane. The 685 was definitely a biz airplane > from its > inception. > > Few of my clients would stand up and admit that their Commander was > for pure > fun. All but one or two claimed them as biz aircraft, so just between > us > girls, let us know to what degree you're looking for a corporate > airplane, or > are just going to write off your dream come true. > > Uhhhh .... I don't think we have any IRS agents on this list, do we? > > Keith S. Gordon > aka Wing Commander Gordon ________________________________________________________________________________
Date: May 05, 2001
Subject: Baja California
Hey, Have any of you guys done some flying in Baja. I want to take a trip in the airplane and just lay around in a swimming pool, get some sun and sip margarita's for a few days with some friends. This will be a husband and wives trip. Paul ________________________________________________________________________________
Date: May 05, 2001
In a message dated 05/05/01 19:47:48 Pacific Daylight Time, calnet01(at)gte.net writes: > Here are the numbers. Do you they look OK to you guy ?. I'm worried about > fuel pressures. Those looked like good 680-E numbers to me! As far as fuel pressures, I am suspect of all fuel pressure guages unless I know they've been calibrated within one year. I only worry about fuel pressure on the GSO-480 when I see the needles dancing around -- time for boost pumps on during cruise. If it is chronic, time to check fuel filters. Sounds like a perfect Commander day, complete with a trip to see Yoda. (Yes, the Master painting something out behind the hangar is part of the charm!) Wing Commander Gordon ________________________________________________________________________________
Date: May 05, 2001
Subject: Fuel Drain O'Rings
Guys, Does anyone know the size of the O'Ring for the fuel drains located in the engine nacelles ? You know - the ones by the landing gear. If not I'll get a drawing from Geoffrey Pence on Monday. Paul ________________________________________________________________________________
Date: May 06, 2001
Subject: Re: N414C, AC-685 cruise data
Hey Commander Gordan!! How did you get TIT measurements on a non Turbine airplane?? Isn't the GTSIO-520 on the 685?? I have not flown the commander, but the C-421 with the same engine has only EGT gauges??? Don't get me wrong, I am with you all the way, and understood what you said: <> To paraphrase, (When you run a boosted engine you have to "COOL WITH FUEL!!") Paul Reason ________________________________________________________________________________
Date: May 06, 2001
Subject: Temperature Terminology
In a message dated 05/06/01 07:04:37 Pacific Daylight Time, JET PAUL writes: > Hey Commander Gordan!! How did you get TIT measurements on a non Turbine > airplane?? Outstanding point, Paul! When I first got in the AC-685 I was amused by the terminology "TIT" and I wrote it off to Rockwell's marketing department who were the ones who concieved that model as a stepping stone to the AC-690. Then, some other airframer -- Piper or Mooney or someone, did the same thing. Here's where the term comes from: You can measure the exhaust gas temperature coming out of the cylinder, or, you can measure the temperature where it enters the turbine housing of a turbocharger. Semantics. It's where the probe goes. (What's the difference between an oral and rectal thermometer? The taste.) Wing Commander Gordon ________________________________________________________________________________
Date: May 06, 2001
Subject: Re: Temperature Terminology
Keith, I confer you with an honorary Doctor of Medicine. Most medical students never grasp the true difference between rectal and oral as you have. ----- Original Message ----- From: CloudCraft(at)aol.com To: JETPAUL(at)aol.com Cc: tcfg(at)listbot.com Sent: Sunday, May 06, 2001 10:49 AM Subject: Temperature Terminology In a message dated 05/06/01 07:04:37 Pacific Daylight Time, JET PAUL writes: Hey Commander Gordan!! How did you get TIT measurements on a non Turbine airplane?? Outstanding point, Paul! When I first got in the AC-685 I was amused by the terminology "TIT" and I wrote it off to Rockwell's marketing department who were the ones who concieved that model as a stepping stone to the AC-690. Then, some other airframer -- Piper or Mooney or someone, did the same thing. Here's where the term comes from: You can measure the exhaust gas temperature coming out of the cylinder, or, you can measure the temperature where it enters the turbine housing of a turbocharger. Semantics. It's where the probe goes. (What's the difference between an oral and rectal thermometer? The taste.) Wing Commander Gordon ________________________________________________________________________________
Date: May 06, 2001
Subject: TITs and stuff
Wow, an all time first - I'm going to take some exception to a post from master Keith (okay, only a _little_ exception) RE: EGTs and TITs. Although closely related, some aircraft have instruments for both. The new digital, multi-channel EGT/CHT gauges are also available with seperate TIT inputs. The reason is that you may have max operating temperatures for the hairdryers. During some operations, it may be necessary to run a richer mixture (or leaner if you of the LOP crowd) than you would normaly select just by EGT to keep the TIT parameters acceptable. On my turbo Viking, for example, the TITs actually run hotter than the EGTs due to the continuation of burn in the exhaust stacks. (I run ROP). The TIT probes are over 12 inches further down the pipe than the EGT probes. Chris ________________________________________________________________________________
Date: May 06, 2001
Subject: Re: TITs and stuff
In a message dated 05/06/01 13:17:25 Pacific Daylight Time, chris(at)skymaster.c2-tech.com writes: > Wow, an all time first - I'm going to take some exception to a post from > master Keith (okay, only a _little_ exception) I notice you won't debate the thermometer issue .... You bring up a good point, Chirs and we don't disagree at all. I was only attempting to answer why a Commander has a TIT guage and not an EGT, as the Cessna 421 does. By the way, JetPaul was wondering why TITs on were there when it's a "turbine engine guage." Actually, the turbine engines have ITT guages -- Interstage Turbine Temperature. But then the Garrett dash 10 engine runs EGT as a limit instead of ITT, so nothing is sacred. Again, it's where the thermometer goes. Something in the engine area is going to melt at a certain temperature and 'ya got to measure it somewhere. Knowing that TIT runs higher than EGT was a revelation. I've never had both points guaged. Thanks! Wing Commander Gordon ________________________________________________________________________________
Date: May 06, 2001
>I notice you won't debate the thermometer issue .... I bow to your vastly greater experience :-) >Again, it's where the thermometer goes. Something in the engine area is >going to melt at a certain temperature and 'ya got to measure it somewhere. That pretty much summs it up - yep. I'm guessing that it has a lot to do with the exhaust plumbing and variations in engines. Probably many setups can't overtemp the turbos without exceeding max EGT or CHTs thus they don't need a TIT probe. Interesting topic anyway. BTW, I've been studying lean-of-peak operation for some time now and have come to my own conclusions based upon all available information. If anyone really wants to know what I think on the topic, speak up... otherwise I'll stay silent on the subject. Chris ________________________________________________________________________________
Date: May 06, 2001
Subject: Re: Baja California
Baja is terrific! I'd recommend hotel Solidad, but there are plenty of great places depending on your 'druthers, from Cabo if you want the resort city to Mulege or San Fransicito if you want a sand beach strip and a quiet bungalo on a deserted beach. I'd highly recommend joing the Baja Bush Pilots association.
http://www.bajabush.com/ They have the most current information on airport conditions etc. In fact, Jack McCormick the president flies a Shrike! later, andrew Paul Odum wrote: > > > Hey, > > Have any of you guys done some flying in Baja. > > I want to take a trip in the airplane and just lay around in a swimming > pool, get some sun and sip margarita's for a few days with some friends. > This will be a husband and wives trip. > > Paul > ________________________________________________________________________________
Date: May 06, 2001
In a message dated 05/06/01 13:51:56 Pacific Daylight Time, chris(at)skymaster.c2-tech.com writes: > If anyone really wants to know what I think on the topic, speak up... > otherwise I'll stay silent on the subject. > Speak! ________________________________________________________________________________
Date: May 06, 2001
Subject: Lean of Peak
The best discussion I have seen is from GAMI. www.gami.com <http://www.gami.com/> I have been to ADA, OK and seen their engine test cell and it is amazing to see what they can see going on inside of an engine while it is running. It will make a believer of you. You will want to run out and install JPI instruments and GAMI injectors to save 3 gallons per hour/ side in cruse. Regards, Tylor Hall tylorh(at)sound.net 913-422-8869 ________________________________________________________________________________
Date: May 06, 2001
Subject: LOP Operation
>Speak! WOOF! Okay, you asked... Some preliminaries... LOP (lean of peak) engine operation came back into the light 3-ish years ago when a company called GAMI (General Aviation Modifications Inc) began marketing special fuel injectors which supposedly "balanced" or allowed all cylinders to run at exactly the same temps. Their claim to fame is that you can successfully operate aircraft engines on the lean side of peak EGT, thus substantially reducing fuel flow, running the engine cooler, and making much cleaner exhaust. I have been studying this topic since I first read articles and reports on the GAMI system and I have now formed some opinions. First, the folks at GAMI have worked hard to prove their theories scientificly. I'm impressed with their attitude and engineering and havn't heard a single negative comment about the company or the people. Their web site is very convincing: http://www.gami.com/ Lycoming, on the other hand, strongly advises against LOP operation: http://www.lycoming.textron.com/support/engine_operation_tips/SSP700A.pdf Frankly, I find the years of history of reliable ROP operation MUCH more convincing than Lycoming's technical refute. One can poke many holes in their "official" documentation. There are also some knowledgable folks who rave about GAMI and LOP operation: http://www.avweb.com/articles/pelperch/pelp0042.html My point of view: I do believe almost everything GAMI has to say on the subject. It is clearly true that LOP will provide cooler temperatures, slower burn, cleaner exhaust, and obviously lower fuel flow. Without re-hashing many things which have already been written in many places, I'll jump to the summary of why _I_ don't run LOP. 1) My last engine gave 2000 trouble-free hours running 75-100 ROP. 2) Although I agree that there is no chance of detonation below 75% power and 50 LOP, GAMI suggests dialing up 75% power, then leaning to LOP, then increasing MAP to make up for the lost power. I am not convinced that my MAP and mixture controls are stable enough to maintain exactly the correct setting over a long flight. If the mixture happens to creep just a little rich, I could find myself at 85%+ and right around peak EGT which _could_ definitly induct detonation (at least). 3) When running ROP, there is obviously NO oxygen remaining after the combustion cycle. LOP, there is no fuel left, but there IS excess oxygen. My fear is that this oxygen-rich, high-temp gas could be damaging to the valves and exhaust system. (isn't that why we weld with a "neutral" flame?). There is some scientific evidence to back up this ascertation including metalurgical analysis of damaged valves coming out of LOP-operated engines which suffered surface fractures. Anyway, that's my short summary and is MY opinion only. I think there is a lot to be said for LOP operations - most new cars run that way right? I'd say there is a good likelyhood that some engines can be run LOP more successfully than others - depending on many variables in the induction system as well as differing material issues (valve and guide materials, exhaust components, etc). Let me see a fleet of aircraft which all had uneventful TBO runs while operating LOP and I might change my tune. Until then (and as long as I'm paying the bills), I'll stick with what has worked for years-n-years. Comments? Chris Schuermann ________________________________________________________________________________
Date: May 06, 2001
Subject: ALPHIBET SOUP
HI KIDS........ All this talk about TITs, ROP, LOP and EGT sure is confusing!! I am sure glad I just push the mixtures up to "Normal" and go-a-flyn! Had a great weekend in Commanderland. Had some good old car buddies from Idaho come up for the weekend and attended the big PDX swap meet. Found a Hyd press gauge for the Commander for $5 (those car guys didn't have a clue what it was) Also found three old ads for commanders to add to my collection. Friday eve we grabed some fried rice and Col. Sanders and flew triple 2 out to the coast for dinner, sitting on the airport fence, what fun! Then flew an air to air photo shoot late Sat eve. I don't know how best to share these with you but the are spectacular. Jim Raeder, the guy who will be at the flyin, shot them and, well, I will have to figure a way to post some of them. Today we flew up the coast to Tillomook to the air museum for lunch. On the way home the Hobbs turned 100hr since the completion of the restoration! Pretty cool. All in all a great weekend in Commanderland!! Hope yours was great as well. capt jimbob ________________________________________________________________________________
Date: May 06, 2001
Subject: Re: ALPHIBET SOUP
YOURTCFG(at)aol.com wrote: > Had a great weekend in Commanderland. Sounds like it! I ended up fighting a 30+kt X-wind and getting bounced all over this weekend :( Some of my termites are pretty bruised up! > I don't know how best to share these with you but the are spectacular. If you have a scanner, just email me the jpegs and I'll get 'em online for ya. If not, I can scan and return. My new computer should be arriving sometime this week (a 1.7Ghz P-4 with ALL the doo-dads). Most likely it'll take me a full week to get everything working again and all my stuff transfered over. (won't affect the web site thought . that's running on another server). Chris ________________________________________________________________________________
Date: May 06, 2001
Do you guys have the number for Sun West ? Also - still need that o'ring number for the fuel drain in the nacelle. Do you guys work on your airplanes or just drive them ? Paul YOURTCFG(at)aol.com wrote: > > bsp;   Get all the corrosion taken > care of. >
Barry Hancock wrote: >
Paul, >
Got your address off of the ad you posted at aerocommander.com... >
Sorry I missed you today.  Morris was gracious and the trip was > > HI KIDS........ > > All this talk about TITs, ROP, LOP and EGT sure is confusing!! > I am sure glad I just push the mixtures up to "Normal" and go-a-flyn! > Had a great weekend in Commanderland. Had some good old car buddies > from Idaho come up for the weekend and attended the big PDX swap meet. Found > a Hyd press gauge for the Commander for $5 (those car guys didn't have a clue > what it was) Also found three old ads for commanders to add to my collection. > Friday eve we grabed some fried rice and Col. Sanders and flew triple > 2 out to the coast for dinner, sitting on the airport fence, what fun! > Then flew an air to air photo shoot late Sat eve. I don't know how > best to share these with you but the are spectacular. Jim Raeder, the guy > who will be at the flyin, shot them and, well, I will have to figure a way to > post some of them. > Today we flew up the coast to Tillomook to the air museum for lunch. > On the way home the Hobbs turned 100hr since the completion of the > restoration! Pretty cool. > All in all a great weekend in Commanderland!! Hope yours was great as > well. capt jimbob ________________________________________________________________________________
Date: May 06, 2001
http://www.sunwestaviation.com/ Phone: 520.889.8191 or 800.557.0149 Fax: 520.889.8192 Does this help?? Regards, Tylor Hall tylorh(at)sound.net 913-422-8869 -----Original Message----- From: Paul Odum [mailto:calnet01(at)gte.net] Sent: Sunday, May 06, 2001 9:01 PM To: YOURTCFG(at)aol.com Cc: TCFG(at)listbot.com Subject: Re: ALPHIBET SOUP Do you guys have the number for Sun West ? Also - still need that o'ring number for the fuel drain in the nacelle. Do you guys work on your airplanes or just drive them ? Paul YOURTCFG(at)aol.com wrote: > > bsp;   Get all the corrosion taken > care of. >
Paul, >
Date: May 06, 2001
Subject: Air Cornditioning
Do you guys know where I can line up a good used air conditioner for 80E ? My partner is interested in installing one but I can't afford to fork over 1/2 of $14K for one. Thanks. Paul ________________________________________________________________________________
Date: May 06, 2001
HI PAUL..... Cant help with the "O" rings but suggest you just take them out and match them up, or replace the whole drain, they are only about $20 from Spruce. Sun west can be reached at 800-557-0149 520-889-8191 fax 520-889-8192 jb ________________________________________________________________________________
Date: May 06, 2001
From: CloudCraft(at)aol.com <CloudCraft(at)aol.com>
Subject: Sun West
In a message dated 05/06/01 18:58:11 Pacific Daylight Time, calnet01(at)gte.net writes: > Do you guys have the number for Sun West ? Here's what I have, hope it's still current tel 800-557-0149 tel 320-889-8191 fax 320-889-8192 Sunwest Aviation Wing Commander Gordon ________________________________________________________________________________
Date: May 06, 2001
From: James Crunkleton <crunk1(at)worldnet.att.net>
Subject: Rop/Lop
Chris, I too have read the articles about LOP. My trouble is that my engines won't run LOP! Using a GEM1200, the engines get rough long before reaching LOP, so the considerations are moot. I'm rather curious as to the performance of the GAMI injectors, but not curious enough to spring for a set. The 'Distinguished Gentleman' from Georgia ________________________________________________________________________________
Date: May 06, 2001
Subject: Alphibet Soup
Jim Bob, I've got to agree with you. All those letters sure are confusing. That's why my mixtures in the 520 are labeled "Loud" and "Quiet". ( Hint: Don't use "Quiet" while airborne!) Jim Crunkleton aka T.D.G.F.G. ________________________________________________________________________________
Date: May 06, 2001
----- Original Message ----- From: Milt Concannon To: CloudCraft(at)aol.com ; JETPAUL(at)aol.com Cc: tcfg(at)listbot.com Sent: Sunday, May 06, 2001 3:32 PM Subject: Re: Temperature Terminology Keith, I confer you with an honorary Doctor of Medicine. Most medical students never grasp the true difference between rectal and oral as you have. THAT'S SCARY, BUT BELIEVABLE! ----- Original Message ----- From: CloudCraft(at)aol.com To: JETPAUL(at)aol.com Cc: tcfg(at)listbot.com Sent: Sunday, May 06, 2001 10:49 AM Subject: Temperature Terminology In a message dated 05/06/01 07:04:37 Pacific Daylight Time, JET PAUL writes: Hey Commander Gordan!! How did you get TIT measurements on a non Turbine airplane?? Outstanding point, Paul! When I first got in the AC-685 I was amused by the terminology "TIT" and I wrote it off to Rockwell's marketing department who were the ones who concieved that model as a stepping stone to the AC-690. Then, some other airframer -- Piper or Mooney or someone, did the same thing. Here's where the term comes from: You can measure the exhaust gas temperature coming out of the cylinder, or, you can measure the temperature where it enters the turbine housing of a turbocharger. Semantics. It's where the probe goes. (What's the difference between an oral and rectal thermometer? The taste.) Wing Commander Gordon ________________________________________________________________________________
Date: May 07, 2001
Subject: Re: Lean of Peak
I did it, and put a few hundred hours on my 500B and the plugs and oil were beautiful every change! andrew Tylor Hall wrote: The best discussion I have seen is from GAMI. www.gami.com I have been to ADA, OK and seen their engine test cell and it is amazing to see what they can see going on inside of an engine while it is running. It will make a believer of you.You will want to run out and install JPI instruments and GAMI injectors to save 3 gallons per hour/ side in cruse. Regards, Tylor Hall tylorh(at)sound.net 913-422-8869 ________________________________________________________________________________
Date: May 07, 2001
Subject: Re: LOP Operation
One comment/correction, even ROP, there's still lot's of O2 left, maybe less, but you we're not nearly efficient enough to burn it all, or even most of it. andrew Chris Schuermann wrote: > > > >Speak! > > WOOF! > > Okay, you asked... > > Some preliminaries... > LOP (lean of peak) engine operation came back into the light 3-ish > years ago when a company called GAMI (General Aviation Modifications > Inc) > began marketing special fuel injectors which supposedly "balanced" or > allowed all cylinders to run at exactly the same temps. Their claim to > fame is that you can successfully operate aircraft engines on the lean > side of peak EGT, thus substantially reducing fuel flow, running the > engine cooler, and making much cleaner exhaust. > > I have been studying this topic since I first read articles and reports > on the GAMI system and I have now formed some opinions. > First, the folks at GAMI have worked hard to prove their theories > scientificly. > I'm impressed with their attitude and engineering and havn't heard a > single > negative comment about the company or the people. Their web site is > very convincing: http://www.gami.com/ > > Lycoming, on the other hand, strongly advises against LOP operation: > http://www.lycoming.textron.com/support/engine_operation_tips/SSP700A.pdf > Frankly, I find the years of history of reliable ROP operation MUCH more > convincing than Lycoming's technical refute. One can poke many holes in > their "official" documentation. > > There are also some knowledgable folks who rave about GAMI and LOP > operation: > http://www.avweb.com/articles/pelperch/pelp0042.html > > My point of view: > I do believe almost everything GAMI has to say on the subject. It is > clearly true that LOP will provide cooler temperatures, slower burn, > cleaner exhaust, and obviously lower fuel flow. Without re-hashing > many things which have already been written in many places, I'll jump > to the summary of why _I_ don't run LOP. > > 1) My last engine gave 2000 trouble-free hours running 75-100 ROP. > > 2) Although I agree that there is no chance of detonation below 75% > power and 50 LOP, GAMI suggests dialing up 75% power, then leaning > to LOP, then increasing MAP to make up for the lost power. I am not > convinced that my MAP and mixture controls are stable enough to maintain > exactly the correct setting over a long flight. If the mixture happens > to creep just a little rich, I could find myself at 85%+ and right > around peak EGT which _could_ definitly induct detonation (at least). > > 3) When running ROP, there is obviously NO oxygen remaining after > the combustion cycle. LOP, there is no fuel left, but there IS > excess oxygen. My fear is that this oxygen-rich, high-temp gas > could be damaging to the valves and exhaust system. (isn't that why > we weld with a "neutral" flame?). There is some scientific evidence > to back up this ascertation including metalurgical analysis of > damaged valves coming out of LOP-operated engines which suffered > surface fractures. > > Anyway, that's my short summary and is MY opinion only. I think there > is a lot to be said for LOP operations - most new cars run that way > right? I'd say there is a good likelyhood that some engines can be > run LOP more successfully than others - depending on many variables in > the induction system as well as differing material issues (valve and > guide materials, exhaust components, etc). Let me see a fleet of > aircraft which all had uneventful TBO runs while operating LOP and I > might change my tune. Until then (and as long as I'm paying the bills), > I'll stick with what has worked for years-n-years. > > Comments? > Chris Schuermann > ________________________________________________________________________________
Date: May 07, 2001
CloudCraft(at)aol.com said: >Actually, the turbine engines have ITT guages -- Interstage Turbine Temperature. >But then the Garrett dash 10 engine runs EGT as a limit >instead of ITT, so nothing is sacred. Good point Keith, As mentioned, in some turbines you can't install a probe in areas where you would like to monitor the temperature limits. (You'd fry the probe) So they install them in a cooler area downstream and refer to them as a derivative of that location ie hence T3, T4, T4a etc. Some USAF inventory engines are also labeled in generic terms such as EGTs, TGTs, etc. It appears every manufacturer has their own terminology and method for thermal measurements. TGT seems to be the most common, at least in the AF. (Turbine Gas Temperature) GE likes to use this term I believe. RS ________________________________________________________________________________
Date: May 07, 2001
Subject: New pics
Just added a couple of STUNNING pictures of Capt Jimbobs bird to the web site. They're under the "Bathtub" section: http://www.aerocommander.com/Pbathtub/3/index.html They're a little large, but the quality was so good I didn't want to shrink them any. Chris ________________________________________________________________________________
Date: May 08, 2001
Subject: Re: New pics
In a message dated 05/08/01 00:05:47 Pacific Daylight Time, chris(at)skymaster.c2-tech.com writes: > Just added a couple of STUNNING pictures of Capt Jimbobs bird to > the web site. That's an appropriate description! Quality photos of a quality Commander. Wing Commander Gordon ________________________________________________________________________________
Date: May 08, 2001
From: Barry.Collman(at)airclaims.co.uk <Barry.Collman(at)airclaims.co.uk>
Hi All! That's my boy! STUNNING pictures? An understatement old chap!! Really sharp images, great stuff!! Barry Collman Chris Schuermann cc: Sent by: Subject: New pics cschuerm(at)skymaster.c 2-tech.com 08/05/2001 01:23 Please respond to chris Just added a couple of STUNNING pictures of Capt Jimbobs bird to the web site. They're under the "Bathtub" section: http://www.aerocommander.com/Pbathtub/3/index.html They're a little large, but the quality was so good I didn't want to shrink them any. Chris ________________________________________________________________________________
Date: May 08, 2001
Subject: Web site update
Thanks to Mr Bert Berry, we now have a bunch of new Commander ADs up on the web site! Thanks Bert! I'd never seen some of these before. Chris Schuermann ________________________________________________________________________________
Date: May 08, 2001
Subject: jimbo
WOW Capt jimbobs plane is impressive. Is that the captain himself at the helm? Nice to know there is someone else in this world as portly as me ________________________________________________________________________________
Date: May 08, 2001
Subject: Mixture controls and flaps
Recently there were two items of discussion on tcfg that I have found service letters on. 1 leaning pressure carbs 2 Flaps drifting down in flight I have sent them to Chris for his download section on the website. #1 says dont like chris and jimbob so emphatically stated and gives aerodesigns reason why. #2 is a bit surprising (at least to me) It says leave the flap lever in the full up position all the time. I'sn't that a little tough on the actuators? ________________________________________________________________________________
Date: May 08, 2001
Subject: Re: jimbo
WOW!!! That's pretty. bilbo ----- Original Message ----- From: Milt Concannon To: Twin Commander Flightgroup Sent: Tuesday, May 08, 2001 1:12 PM Subject: jimbo WOW Capt jimbobs plane is impressive. Is that the captain himself at the helm? Nice to know there is someone else in this world as portly as me ________________________________________________________________________________
Date: May 08, 2001
Subject: Re: jimbo
In a message dated 5/8/01 10:25:12 AM Pacific Daylight Time, mdcmd@ms-online.com writes: > Nice to know there is someone else in this world as portly as me Be careful Milt, it's not nice to insult "The King" jb ________________________________________________________________________________
Date: May 08, 2001
Subject: Reagan in His Own Hand
Dear Nico: I hope you have heard about a new book the Ronald Reagan Presidential Foundation co-published with the Hoover Institution called, Reagan, In His Own Hand: The Writings of Ronald Reagan That Reveal His Revolutionary Vision for America. I have attached for you an editorial I authored about this book that ran in Sunday's Los Angeles Daily News. Attached is the link to read the editorial. If you would like to buy this book, please visit our web site at http://www.reaganfoundation.org and receive 10% off as a supporter of the Reagan Foundation. I welcome your thoughts about the editorial, please e-mail me at: info(at)reaganfoundation.org Best regards, Mark Burson Executive Director Mark Burson Editorial --------------------- http://www.dailynews.com/opinions/articles/0501/06/vew03.asp Editorial ________________________________________________________________________________
Date: May 08, 2001
Subject: The Rod
Hey Gang,Since getting my ticket,I have been my butt ready to take my multi check ride,Today while my instructor and i were taxing Lucille to the run-up area she gave me one Hell of a shock.If you guyes will think back,we all had a little chat about the emergency pump handle in the floor.Me being a non-forreal pilot of a commander{Howl a loogy} I added my 1.5 cents worth and said live it were it was put!Well,today proved me right.AS soon as I passed the last turnout I gave Lucille a little nudge to the left,but what does sheeee do you ask,Sheeee turns abbruptly to the right.Holding both feet to the floor,my breath,and my roid with a death grip on the seat cushion helped nothing!Things happened so quickly that I grabbed the throttles,and the real pilot{clark} grabbed the mixtures,closing both seamed to piss Lucille Off and shegave a few gutterly growls and pulled a little harder.At the same instance this was happening we were both assesing the loss of hydrolic pressure and he reached for the pump lever{right were I left it}and gathered enough pressure to hit the breaks and stop,with no dammage to lucille.So please take my previous advice and leave the pump handles were they were meant to be. Best To All, BIG AL ________________________________________________________________________________
Date: May 09, 2001
Subject: June 7th
Hey Guys, Keep an eye open for June 7th. President Blair (anagram of B-liar!) has called a General Election. We'll show you all how it's done - COUNT ON IT !!! Best Regards, Barr (I'll-get-lynched-at-Hillsboro) Collman ________________________________________________________________________________
Date: May 09, 2001
Subject: applications
HI KIDS.......... For many years I was a decon on a small nondenominational Christian church in Idaho. We always seemed to be out of money. We always managed to pay the bills, but never had anything left over for other important things (like fixing a leaky roof) We had enough people attending each Sunday and the adult bible classes were full, but no money, they weren't members. I remember telling our pastor that he should preach a sermon explaining the importance of joining our little group and tithing regularly. He said that he was afraid to, because it might drive people away from church, and they needed to be there. I didn't understand until now. So, I am reluctantly sending a reminder to those who have requested an application to join the TCFG, but have not retuned it. There are about (over) twenty applications that have been sent (some have been requested and sent twice) that have not been returned. I know that it is eassy to get busy and forget, I let my AOPA dues lap recently, but it is important to get them in. As I plan the flyin, the upfront expences will be high and it will help. It is also important to continue the growth that we have recently enjoyed. Since I took the reins of the group, we have seen more that 20% growth in the membership and I think this is fantactic. But I have lofty plans for this group and understand that a growing membrship is what will make it happen. Sorry to have to remind eveyone, and for those who have paid their dues or become new members THANKS!!!! This group is healthy and growing and I am proud to represent you. jb ________________________________________________________________________________
Date: May 09, 2001
Subject: AD's
Hello Guys(Gals), Thanks again for all your help! I read the AD's in Chris's message #1161. Does anyone know why every 600 series model is listed except 680F(P)? The AD is 00-00-30(http://av-info.faa.gov/ad/CE00/00-02-30.html). See ya! Mark Poulin ________________________________________________________________________________
Date: May 10, 2001
Subject: flyin update
HI KIDS...... I just got back from a little flying in triple 2. Spent some time with Lori and Allen at Aero Air working out some details. Here is a little new news. Morris Kernick will be handling the SB223, 90D and 208A. He also plans to take us through the Brakes/steering system from the first press on the pedal to the last movement of the brakes, or steering. He will bring the components that make it happen so we can really see how this works. I thought I knew a lot about it but still keep finding new little tricks. Yesterday I moved the adjustment on the pedals from the center hole to the lower one and it made an amazing difference (for the better). Kevin Mculugh will be handling flight ops for both the piston and turbine models. He is the Pres of Aero Air and the company check airman. I plan to have Ken Mollson do the turbine engine seminar (Yoda calls him for help!) Sweed Ralston will join us for lunch on Saturday. Sweed started Aero Air and has spent his life with Aero Commanders and many other airplanes. He is an amazing guy and fun to talk to. In his mid eighties, he still gets into the office every day. We have the back hangar reserved and it will really work great. There will be room for one or two Commanders inside and 7-8 just outside the door. Allen said he will arrange a nice discount on fuel for all of us. So, things are coming together but man is there a lot to do!! Had a great flight. Plan to fly to Idaho tomorrow eve or Saturday, AM, Moms day. Talked to a really nice guy this week who is considering buying a 720 (they only made 13 of them). He found the airplane in the Midwest and it flys! (Sweed Ralston told me he bought the FIRST 720, that would be the FIRST pressurized private airplane) Well i think that is all, hope all is well in Commanderland. jb jb ________________________________________________________________________________
Date: May 10, 2001
Subject: Re: flyin update
Kids, An Paul Odum will "hopefully" be bringing a video, courtesy of John Schwaner at Sacramento Sky Ranch on the care and feeding of the GSO-480 ! YOURTCFG(at)aol.com wrote: > > > HI KIDS...... > > I just got back from a little flying in triple 2. Spent > some > time with Lori and Allen at Aero Air working out some details. Here > is a > little new news. Morris Kernick will be handling the SB223, 90D and > 208A. > He also plans to take us through the Brakes/steering system from the > first > press on the pedal to the last movement of the brakes, or steering. > He will > bring the components that make it happen so we can really see how this > works. > I thought I knew a lot about it but still keep finding new little > tricks. > Yesterday I moved the adjustment on the pedals from the center hole to > the > lower one and it made an amazing difference (for the better). > Kevin Mculugh will be handling flight ops for both the piston > and > turbine models. He is the Pres of Aero Air and the company check > airman. I > plan to have Ken Mollson do the turbine engine seminar (Yoda calls him > for > help!) > Sweed Ralston will join us for lunch on Saturday. Sweed started > Aero > Air and has spent his life with Aero Commanders and many other > airplanes. He > is an amazing guy and fun to talk to. In his mid eighties, he still > gets > into the office every day. > We have the back hangar reserved and it will really work great. > There > will be room for one or two Commanders inside and 7-8 just outside the > door. > Allen said he will arrange a nice discount on fuel for all of > us. So, > things are coming together but man is there a lot to do!! > Had a great flight. Plan to fly to Idaho tomorrow eve or > Saturday, > AM, Moms day. > Talked to a really nice guy this week who is considering buying > a 720 > (they only made 13 of them). He found the airplane in the Midwest and > it > flys! (Sweed Ralston told me he bought the FIRST 720, that would be > the > FIRST pressurized private airplane) > Well i think that is all, hope all is well in Commanderland. jb > > jb > ________________________________________________________________________________
Date: May 10, 2001
Subject: TED SMITH
HI KIDS........ I just had a couple of interesting conversations today. First was with Sweed Ralston. He talked a bit abut the old days. He asked what model Commander I flew and said that Ted Smith chose a 680E as his last airplane and owned one at his passing. I was wondering if Barry might be able to confirm that. What a great airplane that would be to find! I then returned a call to a soon to be new member who lives in the SEA area. He just took delivery of a 685 (he has also owned a 680FP and a 500 A & B) from Eagle creek, (New Engines!) and said he had the privilege of flying Ted's widow to an Aerostar event a few years ago. He said that she was very nice and complemented him on his fine airplane but said "you know, Ted really liked the Aero Commanders much better that these airplanes" Pretty cool! jb ________________________________________________________________________________
Date: May 11, 2001
Subject: Re: TED SMITH
Everytime govt irritates me and I think it should stay out of our business I'm reminded of the first Lears and certain pharmaceuticals. G ----- Original Message ----- From: CloudCraft(at)aol.com To: YOURTCFG(at)aol.com Cc: tcfg(at)listbot.com Sent: Friday, May 11, 2001 9:18 AM Subject: Re: TED SMITH In a message dated 05/10/01 22:19:07 Pacific Daylight Time, YOURTCFG(at)aol.com writes: He said that she was very nice and complemented him on his fine airplane but said "you know, Ted really liked the Aero Commanders much better that these airplanes" I always wondered about that. I came to the Commanders via the Aero Star and I still love the 'Star dearly. Ted Smith was a most remarkable man. The Aviation world was blessed with 5 genius/innovators who were lucky enough to exist at a time when they could build what they wanted and were given latitude to experiment. That just doesn't happen any more; if you're not Raytheon, Cessna, etc., it's just too difficult to bring a new idea into production. Those 5? Bill Lear, Kelly Johnston, Ed Swearingen, Dee Howard and Ted Smith. (Not that I like all their products. Lear's 20 series jets are lawn darts and Ed Swearingen concocted fast but squirrely airplanes.) As all of you have figured out by now, I'm very opinionated about aircraft and I've always told people shopping propeller twins to stay with Ted Smith designs if they want safe and delightful aircraft to fly. I have to admit that it really pleases me to know that Ted Smith owned a 680E to the end! Wing Commander Gordon ________________________________________________________________________________
Date: May 11, 2001
From: Barry Collman <barry.collman@air-britain.co.uk>
Subject: Re: Ted Smith
Hi again! Apologies Jim, should have indeed added its current location. Last I knew, it was in Colombia, registered as HK-2440 with Occidental de Aviacion Ltda., in Cali, Valle de Cauca. They were, I believe, formerly known as Aerovias Bueno Ltda (AEROBUENO). The Commander was sold to them on March 4th 1980. They've also had a 690A, serial 11100, HK-2415 which was destroyed in an accident September 7th 1991 and a 695A, serial 96009, HK-3271 which was possibly seized in Haiti. Sold back to the USA in 1988, it was believed sold back in Colombia under 'Operation Starwatch', through Eagle Air in Memphis, TN. So, I wonder if the 680E really is still around? Anyone fancy a trip to Cali? Barry. ----- Original Message ----- From: YOURTCFG(at)aol.com To: barry.collman(at)air-britain.co.uk ; TCFG(at)listbot.com Sent: Saturday, May 12, 2001 12:09 AM Subject: Re: Ted Smith THANKS BARRY!! Where is it now?? jb ________________________________________________________________________________
Date: May 11, 2001
From: Chris Schuermann <chris(at)skymaster.c2-tech.com>
Subject: Teds Commander
Barry just sent me the picture of Ted's bird. Its in the "Temporary" directory on the Commander web site. Large file, but VERY high quality. Thanks Barry! Chris Schuermann http://www.aerocommander.com ________________________________________________________________________________
Date: May 12, 2001
From: H. James McConnell <skipper10(at)peoplepc.com>
Subject: Twin Commander
I am International President of Pilots for Christ, Int'l. We have members in 40 states and 10 countries. We refer to ourselves as "The Lord's Airforce" and fly evangilistic support missions, Mercy Missions and Disaster Relief, amoung some of our activities. Our flights cover the US proper and extend down into the Islands off Florida, and Central and South American. Up to now, most of our missions have been handled will with four place singles and light twins. The missions are getting longer and involve more weight than something like a Seneca can handle. We are looking for a 6+ place aircraft that can handle flights of up to 1000 miles. Our headquarters is in Northern Virginia and we are not in a position to travel long distances in our search unless the candidate is really exceptional. Contact me on email at skipper10(at)peoplepc.com or by phone at 540 439 0940. Jim McConnell ________________________________________________________________________________
Date: May 12, 2001
Subject: Re: Twin Commander
It seem to be a slow Saturday Night and no one has answered you. TCFG is an owners group to support Twin Commanders. If you are looking for a recommendation, you should consider a 680FL. It is the only light twin that will carry full fuel and 6 people. They are popular with the freight haulers. There are 8 680FLs for sale in Omaha just north of me. I live in Kansas City. You must have seen the web site. www.aerocommander.com <http://www.aerocommander.com/> Lots of photos and information there. Are you looking to buy an aircraft or looking for a donation of one??? How can we help Gods work? Regards, Tylor Hall tylorh(at)sound.net 913-422-8869 -----Original Message----- From: H. James McConnell [mailto:skipper10(at)peoplepc.com] Sent: Saturday, May 12, 2001 6:35 PM To: TCFG(at)listbot.com Subject: Twin Commander _____ _____ I am International President of Pilots for Christ, Int'l. We have members in 40 states and 10 countries. We refer to ourselves as "The Lord's Airforce" and fly evangilistic support missions, Mercy Missions and Disaster Relief, amoung some of our activities. Our flights cover the US proper and extend down into the Islands off Florida, and Central and South American. Up to now, most of our missions have been handled will with four place singles and light twins. The missions are getting longer and involve more weight than something like a Seneca can handle. We are looking for a 6+ place aircraft that can handle flights of up to 1000 miles. Our headquarters is in Northern Virginia and we are not in a position to travel long distances in our search unless the candidate is really exceptional. Contact me on email at skipper10(at)peoplepc.com or by phone at 540 439 0940. Jim McConnell _____ ________________________________________________________________________________
Date: May 13, 2001
In a message dated 05/12/01 16:33:05 Pacific Daylight Time, skipper10(at)peoplepc.com writes: > We are looking for a 6+ place aircraft that can handle flights of up to 1000 > miles. Mr. McConnell, Both at the same time, meaning 6 pax for 1000 miles? You may be getting into turbine equipment, if so. Keith S. Gordon ________________________________________________________________________________
Date: May 13, 2001
Cessna 402C $300,000 190knots We have two great Airplane fopr the Money. or get a 690 for 600,000. crusie at 260knots f[Paul Gravel] or -----Original Message----- From: CloudCraft(at)aol.com [mailto:CloudCraft(at)aol.com] Sent: Sunday, May 13, 2001 6:27 AM To: skipper10(at)peoplepc.com; TCFG(at)listbot.com Subject: Re: Twin Commander -- -- In a message dated 05/12/01 16:33:05 Pacific Daylight Time, skipper10(at)peoplepc.com writes: We are looking for a 6+ place aircraft that can handle flights of up to 1000 miles. Mr. McConnell, Both at the same time, meaning 6 pax for 1000 miles? You may be getting into turbine equipment, if so. Keith S. Gordon -- ________________________________________________________________________________
Date: May 13, 2001
Date: May 13, 2001
In a message dated 05/13/01 04:46:01 Pacific Daylight Time, skipper10(at)peoplepc.com writes: > No. Not at the same time but we need something better than 4 passengers and > 500 miles as in the Sececa. W do some overwater flights of 500 miles and > the Seneca without full fuel is a no-go. OK, guys, let's help this fellow out. About 2 weeks ago lots of you weighed in with your cruise speeds and fuel burns. Can you give your actual usefull load for the model you're flying and list any "extraordinary" equipment or appliances that may make your Commander heavier than the average? As a bonus, if you could post your cruise airspeeds in knots and fuel burns in pounds per hour, it would be a terrific service for this gentleman and others lurking on the list who are evaluatin Commanders. Not to have tunnell Commander vision, Paul Gravel's comment about the Cessna 402 is quite right. A STOL kit and/or VGs may be required to get it to behave like a Commander on shorter runways, but SVG Air are short field / island hopping experts and wouldn't use equipment that didn't work. Wing Commander Gordon ________________________________________________________________________________
Date: May 13, 2001
Date: May 14, 2001
Subject: Re: sump
In a message dated 5/14/01 2:21:40 PM Pacific Daylight Time, CloudCraft(at)aol.com writes: > They have a repair for the magnesium fuel sumps. > > HI KIDS......... REAL breaking news! TCAC has just released SB 230 and it WILL become an AD note (see Flight Group News, DEC issue). I have a copy and it REQUIRES the REPLACEMENT of ALL magnesium sumps (repaired or not). Right now, as a SB,only 135 operators are required to make the upgrade, (Paul Gravell just ordered 9K worth for his three Commanders in St. Vincent) but all effected Commanders will soon be included when the AD is issued. I am planing to meet with TCAC and the FAA soon. SL 379 required that the sumps be removed and inspected. If they were OK, (or could be repaired) they could remain in service. SB 230 is a continuation of this letter up the food chain, but with an important change,ie the requirement for a replacement sump, regardless of the condition of your old one. I will keep my personal feelings to myself for the time being, except to say that I feel this requirement, and the elimination of any alternative repair, is unfair to owners. I hope to persuade TCAC and the FAA to allow for a reasonable approach to this problem. For sure, not all sumps will be a candidate for repair and need to be replaced, and equally certain is the fact that a new aluminum sump will be a more perminate fix, and therefore appeal to many owners. On the other hand, the old sumps have served for about 40 years, so a "no corrosion" or repaired sump should not pose any safety concern. I will keep you posted. jb ________________________________________________________________________________
Date: May 14, 2001
Subject: THIS WEEKS ADVENTURE!
HI KIDS..... I just got back in town from a trip to Idaho for MOMs day. Great trip up, 205 MPH, "sever clear" all the way at 11.5. Took my son and grand daughter for a nice scenic flight and ice-cream. Sunday eve Sue and I flew a dear friend and his new honey to a late dinner Mcall Id, 30 minutes ea. way. Home after dark, super black, gorgeous night!! Got a "sqeeeeker" Everybody had a great time. Flew home this afternoon. Got away late, deteriorating weather, etc, etc. Had a lousy ride home. Ice above 10K and the "low show" was awful. Did the "scud run" thing, (its been awhile). Tried direct and wasted 30 minutes, had to backtrack. Finally slipped over the Blue Mts. following the interstate. Into the Columbia Gorge it got even worse, (usually home free when you get here) At the "Bridge of the Gods" (a town) went from bad to worse, but we got through. 17 miles from the home drome, almost had to turn back again! (it was forcast to be 4500 overcast, 7, in light rain) Then, got to the airport in pouring rain and barley min vis and I missed the VFR approach!! I haven't "gone around" in about 15 years, but I did today! Oh well, some days are diamonds and some days are stone!! Finally, made a terrible landing (with all my airport buddies watching) and even missed my usual precision parking spot. Man, was I glad to turn off the master switch today! Or did I?? Oh no! Love capt jimbob ________________________________________________________________________________
Date: May 14, 2001
Subject: Re: sump
In a message dated 5/14/01 7:14:10 PM Pacific Daylight Time, YOURTCFG writes: > REAL breaking news! TCAC has just released SB 230 and it WILL become an AD > note (see Flight Group News, DEC issue). I have a copy and it REQUIRES the > REPLACEMENT of ALL magnesium sumps (repaired or not). A CORRECTION, By ALL sumps I meant to sat ALL EFFECTED sumps. All of the bathtub airplanes are exempt. Read the SB closely to make certain your airplane is included. Sorry for the error. jb ________________________________________________________________________________
Date: May 14, 2001
Subject: Re: sump
It is reasonable to me. If we can rap Twinkies in a product that will last 500 years in our landfills, we should be able to "rap" our magnesium fuel sumps in something that will last another 40 years. Which by the way, would probably outlast the aluminum sump. bilbo ----- Original Message ----- From: YOURTCFG(at)aol.com To: YOURTCFG(at)aol.com ; CloudCraft(at)aol.com ; w.bow(at)att.net Cc: tcfg(at)listbot.com Sent: Monday, May 14, 2001 11:40 PM Subject: Re: sump In a message dated 5/14/01 7:14:10 PM Pacific Daylight Time, YOURTCFG writes: REAL breaking news! TCAC has just released SB 230 and it WILL become an AD note (see Flight Group News, DEC issue). I have a copy and it REQUIRES the REPLACEMENT of ALL magnesium sumps (repaired or not). A CORRECTION, By ALL sumps I meant to sat ALL EFFECTED sumps. All of the bathtub airplanes are exempt. Read the SB closely to make certain your airplane is included. Sorry for the error. jb ________________________________________________________________________________
Date: May 14, 2001
Subject: Required replacement of the sump
In a message dated 05/14/01 19:14:10 Pacific Daylight Time, YOURTCFG writes: > > I will keep my personal feelings to myself for the time being, except > to say that I feel this requirement, and the elimination of any alternative > repair, is unfair to owners. You are more of a diplomat that I am, Capt. Jimbob. TCAC pulled the same stunt with SB-223 and that got swatted down after the TCFG went to the FAA directorate and reminded them of the provisions of SBs and ADs. Alternative methods can be used to comply. (Note the Saunders Spar kit, and Central Airlines' SB-223 inspection / fix program as two examples) TCAC's error in the original SB-223 was saying that ONLY named Commander Service Centers could perform the work. How totally untrue. Not only is that not legal, but gives the appearance of "make work" bulletins and thus fosters a bad image of the OEM. I have not seen this service letter and I'm not up on the state of the art of AD legal language, but I am glad you're meeting with the FAA. You may come away with a different or modified interpretation. I allow myself to be wrong on this topic today; I am using a historical perspective, so excuse me if necessary. ... With my hand on the lid of Pandorra's Box ... Wing Commander Gordon ________________________________________________________________________________
Date: May 15, 2001
Subject: Re: Required replacement of the sump
NOW WE WILL SEE IF THE LEOPARD HAD BEEN ABLE TO CHANGE IT'S SPOTS. ----- Original Message ----- From: CloudCraft(at)aol.com To: YOURTCFG(at)aol.com Cc: tcfg(at)listbot.com Sent: Tuesday, May 15, 2001 1:43 AM Subject: Required replacement of the sump In a message dated 05/14/01 19:14:10 Pacific Daylight Time, YOURTCFG writes: I will keep my personal feelings to myself for the time being, except to say that I feel this requirement, and the elimination of any alternative repair, is unfair to owners. You are more of a diplomat that I am, Capt. Jimbob. TCAC pulled the same stunt with SB-223 and that got swatted down after the TCFG went to the FAA directorate and reminded them of the provisions of SBs and ADs. Alternative methods can be used to comply. (Note the Saunders Spar kit, and Central Airlines' SB-223 inspection / fix program as two examples) TCAC's error in the original SB-223 was saying that ONLY named Commander Service Centers could perform the work. How totally untrue. Not only is that not legal, but gives the appearance of "make work" bulletins and thus fosters a bad image of the OEM. I have not seen this service letter and I'm not up on the state of the art of AD legal language, but I am glad you're meeting with the FAA. You may come away with a different or modified interpretation. I allow myself to be wrong on this topic today; I am using a historical perspective, so excuse me if necessary. ... With my hand on the lid of Pandorra's Box ... Wing Commander Gordon ________________________________________________________________________________
Date: May 15, 2001
Subject: Re: sump
In the past when given the opportunity TCAC has gone for the juglar and had done everything in their preceived power to stick it to the owner. We will now see if JBs good works have gone for naught. Here's an opportunity for TCAC to stand up and say "Hey we don't really think you piston guys are "bottom feeders" and if we had our way your airplanes would be red tagged. Inviting us to what is little more than a showcase for their products was nice (yes I know about all the seminars) but now is the time for something substantive and not a repeat of the attempted wingstrap piracy. Your move TCAC. GL ----- Original Message ----- From: Bow To: YOURTCFG(at)aol.com ; CloudCraft(at)aol. com Cc: tcfg(at)listbot.com Sent: Tuesday, May 15, 2001 12:58 AM Subject: Re: sump It is reasonable to me. If we can rap Twinkies in a product that will last 500 years in our landfills, we should be able to "rap" our magnesium fuel sumps in something that will last another 40 years. Which by the way, would probably outlast the aluminum sump. bilbo ----- Original Message ----- From: YOURTCFG(at)aol.com To: YOURTCFG(at)aol.com ; CloudCraft(at)aol.com ; w.bow(at)att.net Cc: tcfg(at)listbot.com Sent: Monday, May 14, 2001 11:40 PM Subject: Re: sump In a message dated 5/14/01 7:14:10 PM Pacific Daylight Time, YOURTCFG writes: REAL breaking news! TCAC has just released SB 230 and it WILL become an AD note (see Flight Group News, DEC issue). I have a copy and it REQUIRES the REPLACEMENT of ALL magnesium sumps (repaired or not). A CORRECTION, By ALL sumps I meant to sat ALL EFFECTED sumps. All of the bathtub airplanes are exempt. Read the SB closely to make certain your airplane is included. Sorry for the error. jb ________________________________________________________________________________
Date: May 15, 2001
Subject: Pointed noses
Hi Gang, If Lucilles' little stubby nose,DD engine nacells,and geared engines are soooo outdated,then why is it that she,unlike all of your pointed nosed,flat chested,under torquing,so quiet,super rides is she never threatened by all of yall's little problems.Could it be that they had it right the first time and could not leave well enough alone? BIG AL ________________________________________________________________________________
Date: May 15, 2001
Subject: NEW MEMBER
HI KIDS..... Welcome another new member to the TCFG. David White is the President of Continental Labs, in California. He is looking to buy his second Commander. He has previously owned a 500 A colemill with all the toys, including a Shrike nose, F door and gap seals. Welcome David! capt jimbob ________________________________________________________________________________
Date: May 15, 2001
Subject: Re: NEW MEMBER
In a message dated 5/15/01 9:27:38 AM Pacific Daylight Time, YOURTCFG(at)aol.com writes: << HI KIDS..... Welcome another new member to the TCFG. David White is the President of Continental Labs, in California. He is looking to buy his second Commander. He has previously owned a 500 A colemill with all the toys, including a Shrike nose, F door and gap seals. Welcome David! capt jimbob >> That's what I'm buying. If I ever get it from Gadberry. I'd like to know how David liked it. What to look for - specific problems etc. Jim Furlong ________________________________________________________________________________
Date: May 15, 2001
Subject: Re: sump
Is there any information on the time line for this "soon to be" sump AD? What is the time period for compliance? I'm looking at spending money NOW to get this thing flying with a serviceable magnesium sump. I am wondering if I am buying more "Lucent stock". bilbo ----- Original Message ----- From: YOURTCFG(at)aol.com To: YOURTCFG(at)aol.com ; CloudCraft(at)aol.com ; w.bow(at)att.net Cc: tcfg(at)listbot.com Sent: Monday, May 14, 2001 11:40 PM Subject: Re: sump In a message dated 5/14/01 7:14:10 PM Pacific Daylight Time, YOURTCFG writes: REAL breaking news! TCAC has just released SB 230 and it WILL become an AD note (see Flight Group News, DEC issue). I have a copy and it REQUIRES the REPLACEMENT of ALL magnesium sumps (repaired or not). A CORRECTION, By ALL sumps I meant to sat ALL EFFECTED sumps. All of the bathtub airplanes are exempt. Read the SB closely to make certain your airplane is included. Sorry for the error. jb ________________________________________________________________________________
Date: May 15, 2001
Subject: question
Thought I'd bounce this off y'all and see if I can get some substantial information to base a decision on. I'm looking at a 500S. Without getting into a discussion over attributes of various models, can anyone provide some further insight into the spar issue? This is a very clean, low time airframe with a "clean spar". What has the service history on this spar design been? ie: if it's clean now will I absolutely eventually have problems, or not? If I purchase this aircraft, I'll likely have it for a long time and I have not heard any real FACTS regarding how many aircraft have had problems or about aircraft that have developed problems after having been given a clean bill of health previously. If the spar suddenly fails an inspection, what's the true repair cost? I know we've got a few TCAC folks here. I would sincerely appreciate some feedback on this topic. I'm sure you guys have the info that would tell me what to expect over the next 10 years if I purchase this a/c Thanks, Chris Schuermann ________________________________________________________________________________
Date: May 15, 2001
Subject: Re: sump
HI BILL........ First, there is no absolute guarantee that it will ever become an AD. Not all SBs make all the way up the food chain. However, I feel very strongly that this one will make for a couple of reasons including the fact that the FAA is pretty touchy about fuel related problems (flight 800). To answer your question regarding compliance, the SB requires that an inspection be performed on the sump and filter bodies for seepage prior to each flight. If seepage is found, they must (and I really mean MUST) be replaced before further flight. They are to be replaced within 100 hrs or at the next annual inspection. Guys, this is the real deal. These sumps really do fail and need to be taken seriously. The sumps should never have been produced from Magnesium but they were. The good news is that TCAC has tooled up and has the parts in stock to keep you flying. Jeff C. at Commander is checking now to see if only the sump can be changed or if the complete "kit" will be required. The way I read the SB is that all the parts will need to be changed. The sump only, is about $1400, the "kit" is About $2200, (- 10% from Aero Air) depending on the model. There are some "O" rings and gaskets, etc., that will need changed as well and I don't know how much labor will cost, but they probably wont jump out of the box and onto your airplane, so $3000 is probably not that far off. If you already have the sump off, It might pay to bolt a new one on, just to be sure?? I will contact John Bosch at Commander Aero today for his thoughts and let you know later. jb ________________________________________________________________________________
Date: May 15, 2001
Subject: Re: sump
JB Thank you, however these dollar amounts do not resemble the numbers I got from Down Town Airpark. Their figures are $3469.03 less 10% for the sump only. bilbo ----- Original Message ----- From: YOURTCFG(at)aol.com To: w.bow(at)att.net ; YOURTCFG(at)aol.com ; CloudCraft(at)aol.com Cc: tcfg(at)listbot.com Sent: Tuesday, May 15, 2001 3:22 PM Subject: Re: sump HI BILL........ First, there is no absolute guarantee that it will ever become an AD. Not all SBs make all the way up the food chain. However, I feel very strongly that this one will make for a couple of reasons including the fact that the FAA is pretty touchy about fuel related problems (flight 800). To answer your question regarding compliance, the SB requires that an inspection be performed on the sump and filter bodies for seepage prior to each flight. If seepage is found, they must (and I really mean MUST) be replaced before further flight. They are to be replaced within 100 hrs or at the next annual inspection. Guys, this is the real deal. These sumps really do fail and need to be taken seriously. The sumps should never have been produced from Magnesium but they were. The good news is that TCAC has tooled up and has the parts in stock to keep you flying. Jeff C. at Commander is checking now to see if only the sump can be changed or if the complete "kit" will be required. The way I read the SB is that all the parts will need to be changed. The sump only, is about $1400, the "kit" is About $2200, (- 10% from Aero Air) depending on the model. There are some "O" rings and gaskets, etc., that will need changed as well and I don't know how much labor will cost, but they probably wont jump out of the box and onto your airplane, so $3000 is probably not that far off. If you already have the sump off, It might pay to bolt a new one on, just to be sure?? I will contact John Bosch at Commander Aero today for his thoughts and let you know later. jb ________________________________________________________________________________
Date: May 15, 2001
Subject: SUMPS
HI KIDS....... Let me start by saying that while I and this group my not always agree with TCAC, it is refreshing to have a seat at the table. As I have said in the past, they are listening. This interaction with the factory simply would not have been possible a few short months ago and it is a good thing. I have had a couple of calls from Jeff Cousins today and need to clarify a couple of things. Bill's quote of $3480 appears to be correct. The SB calls for the replacement of not just the sump but the fuel filter bodies as well, hence the $3480 total. This price my vary a bit depending on the type of fuel pumps you have. This would not include installation but should include all necessary "O"rings, gaskets etc. It seems that the best guess on labor time is 10-15 hr., just an estimate, you can do the math with your shop rate. Looks a lot like $5000 to me. Second, I was mistaken when I posted that 135 operators would be required to comply. According to Jeff, they are required to comply with SBs on accessories, propellers and engines but not on the airframe?? I don't write the rules, I just pass the info along. I want to thank all of you who have sent personal emails and phone calls. I understand the importance of the issue. I want to thank Jeff for his quick reply as well. jb ________________________________________________________________________________
Date: May 15, 2001
Subject: Re: SUMPS
JB I was hoping YOU were going to be correct. Now that the price has escalated somewhat isn't it reasonable that if a serviceable magnesium sump can be coated with a finish to prevent corrosion that it would be safe and economically feasible? bilbo ----- Original Message ----- From: YOURTCFG(at)aol.com To: TCFG(at)listbot.com Sent: Tuesday, May 15, 2001 7:17 PM Subject: SUMPS 1. Fill in the brief application 2. Receive approval decision within 30 seconds HI KIDS....... Let me start by saying that while I and this group my not always agree with TCAC, it is refreshing to have a seat at the table. As I have said in the past, they are listening. This interaction with the factory simply would not have been possible a few short months ago and it is a good thing. I have had a couple of calls from Jeff Cousins today and need to clarify a couple of things. Bill's quote of $3480 appears to be correct. The SB calls for the replacement of not just the sump but the fuel filter bodies as well, hence the $3480 total. This price my vary a bit depending on the type of fuel pumps you have. This would not include installation but should include all necessary "O"rings, gaskets etc. It seems that the best guess on labor time is 10-15 hr., just an estimate, you can do the math with your shop rate. Looks a lot like $5000 to me. Second, I was mistaken when I posted that 135 operators would be required to comply. According to Jeff, they are required to comply with SBs on accessories, propellers and engines but not on the airframe?? I don't write the rules, I just pass the info along. I want to thank all of you who have sent personal emails and phone calls. I understand the importance of the issue. I want to thank Jeff for his quick reply as well. jb ________________________________________________________________________________
Date: May 15, 2001
Subject: That spar thing
Chris, Your question about the 500-S spar future is best answered by Miss Cleo or any of the other 900-Psychic Hotlines. Here is some stuff to ponder. As always, I promise you some fact, some of it anecdotal, some of it urban legend. I think Sir Barry may be able to come up with specific serial numbers that were taken out of service due to failed spars. When I tried to interview TCAC a few years ago on this very subject, I was given the phrase over and over again, "We've elected not to answer that question at this time." Getting the spar inspection done is not hard science. It's an ultrasound NDT process and things like adhesive or other ... gick ... can appear as corrosion. The opinion of the NDT specialist plays big into this inspection. There are many stories of failed spars, and brokers who bought the doomed Commander, only to have it re-emerge as a "36 month spar." Bad NDT or bad spar-karma? These airplanes have gone through subsequent inspections and no stories of them dropping off the registry. If a spar is clean now, chances are it will remain so. In the early days of this AD, there was no valid trend in which spars were failing. One of the first ones was in Phoenix or some other desert area where corrosion would not be expected. As Matt Hagan of Eagle Creek and I discussed back then, it seems to be as random as how the guy spraying the zinc chromate on that day was swinging his arm. As with a cancer diagnosis, if you get a failed spar, get a second opinion. Next, (and TCAC will really hate me this week) as far as the thinking deep within the FAA goes, TCAC kit does not eliminate the problem. There is still dissimilar metal contact. Yes, yes, they know there's epoxy and mylar and other high tech stuff, but they still consider it dissimilar metal contact. Will that force the NDT inspection of all Commanders, even those with factory spar kits, in the future? Miss Cleo thinks so. Crystal balling: Boeing's efforts in developing NDT processes for the Aging Aircraft Program may trickle down to us. It's not impossible to imagine a non-invasive scan of the spar in the future. If you had a clean spar, over 10 years, you'd look at it 3 times. I'd gamble on that. If you want the sure-fire fix, go with the Saunders spar mod. It's aluminum, so no dissimilar metal contact, strengthens the spar and reduces fatigue as well. But you'll be flying your old Citation Jet by the time you have to deal with that. Wing Commander Gordon ________________________________________________________________________________
Date: May 15, 2001
Subject: OLD ADS
HI KIDS.......... If you haven't taken time to visit our web site lately, I encourage you to do so. Chris has found and posted some GREAT old Commander ads. I have a small collection of ads that will begin to appear in the newsletter, but Chris has put together a fun collection of "how it was". I hope you will take a few minutes and check it out. THANKS CHRIS!! jb ________________________________________________________________________________
Date: May 15, 2001
From: Dennis Polito W6DEN <cloudhopper(at)home.com>
Subject: Sumps and my .02 worth.
Here we go again, yet another big bucks AD in the works. Sure, safety is everyone's main concern, especially me, the person sitting next to 156 gallons of fuel, but I kinda get the feeling that the folks at TCFG would just as soon see the piston operators disappear. Not enough money to be made on those measly 100LL machines for their liking. Let's see now, how many of the fleet can we retire with this latest assault? Is that the real goal? Hey TCFG folks, how about showing some support here? Or is it your goal to profit from the failure of your product? I for one would like to know what the failure rate (in numbers) has been on the sump. Can the good folks at TCFG supply us with the data? Surely there must be an alternative method of insuring the integrity of the sumps that pass visual and NDT inspection, perhaps a coating of some sort. Too easy a concept though, it will never work. I inspected my sump during a recent fuel cell replacement and I did not see even a hint of corrosion. Who wants to scrap a perfectly serviceable component? My preflight sniff o meter is ever vigilant and I am happy to report the absence of errant misplaced 100LL in the baggage compartment. Ditto with the filter housings. Now is TCFG's opportunity to show support. Hartzell did, they showed tremendous support. Remember the 50% off list regarding the prop replacement program? Bet that a deeply discounted sump and filter kit would get a higher and quicker compliance percentage throughout the fleet! You bet! JB: Thanks ever so much for all of the effort and time that you have given to the group, I for one appreciate it! I am looking forward to meeting you on 24 August, that is if my aircraft is still airworthy at that time. Dennis Polito ________________________________________________________________________________
Date: May 16, 2001
Subject: Re: SUMPS
Capt JB It took 3 Hrs to Defuel, Then removed the sump, with the pumps mounted in the bottom. 1 HRS to remove the necel drain sumps, @- orings and 4 Gaskets I will give you the information on the best epoxy paint to use, Crazy Harry Bow wrote: > > 1. Fill in the brief application > 2. Receive approval decision within 30 seconds > 3. Get rates as low as 2.99% Intro or 9.99% Ongoing APR and no annual > fee! > JBI was hoping YOU were going to be correct. Now that the price has > escalated somewhat isn't it reasonable that if a serviceable magnesium > sump can be coated with a finish to prevent corrosion that it would be > safe and economically feasible? bilbo > > ----- Original Message ----- > From: YOURTCFG(at)aol.com > To: TCFG(at)listbot.com > Sent: Tuesday, May 15, 2001 7:17 PM > Subject: SUMPS > > 1. Fill in the brief application > 2. Receive approval decision within 30 seconds > 3. Get rates as low as 2.99% Intro or 9.99% Ongoing APR and > > HI KIDS....... > > Let me start by saying that while I and this > group my not always > agree with TCAC, it is refreshing to have a seat at the > table. As I have > said in the past, they are listening. This interaction with > the factory > simply would not have been possible a few short months ago > and it is a good > thing. I have had a couple of calls from Jeff Cousins today > and need to > clarify a couple of things. > Bill's quote of $3480 appears to be correct. The SB > calls for the > replacement of not just the sump but the fuel filter bodies > as well, hence > the $3480 total. This price my vary a bit depending on the > type of fuel > pumps you have. This would not include installation but > should include all > necessary "O"rings, gaskets etc. It seems that the best > guess on labor time > is 10-15 hr., just an estimate, you can do the math with > your shop rate. > Looks a lot like $5000 to me. > Second, I was mistaken when I posted that 135 > operators would be > required to comply. According to Jeff, they are required to > comply with SBs > on accessories, propellers and engines but not on the > airframe?? I don't > write the rules, I just pass the info along. > I want to thank all of you who have sent personal > emails and phone > calls. I understand the importance of the issue. I want to > thank Jeff for > his quick reply as well. jb > > ________________________________________________________________________________
Date: May 16, 2001
Subject: Re: OLD ADS
YOURTCFG(at)aol.com wrote: > If you haven't taken time to visit our web site lately, I > encourage you to do so. Chris has found and posted some GREAT old > Commander > ads. Thanks for the kind words JB. I also have to make sure to credit Bert (one of our members) for contributing a bunch of new ads. Many of the pictures on the site have come from other Commander enthusiasts. Please feel free to submit anything you think will be of interest to others on the site! Chris ________________________________________________________________________________
Date: May 16, 2001
Subject: Re: Sumps and my .02 worth.
Hey Dennis, I think you meant to aim your frustration at TCAC, not TCFG, the piston Twin Commander association. Jimbo (not Jimbob) You wrote: Here we go again, yet another big bucks AD in the works. Sure, safety is everyone's main concern, especially me, the person sitting next to 156 gallons of fuel, but I kinda get the feeling that the folks at TCFG would just as soon see the piston operators disappear. Not enough money to be made on those measly 100LL machines for their liking. Let's see now, how many of the fleet can we retire with this latest assault? Is that the real goal? Hey TCFG folks, how about showing some support here? Or is it your goal to profit from the failure of your product? ________________________________________________________________________________
Date: May 16, 2001
Subject: Odd Specimen
Sir Barry, I have an odd specimen for you. At least, it's nothing I've ever come across. Today I was treated to a tour of the North Las Vegas Airport by Mike Macosko who is on this list and learning about Commanders with us. He brought me to one N29DE, a 680-T with it's engines yanked off, struts and tires flat and in general tragic condition. Here's what I need your help with; the data plate gives the following: s/n 1699-76 Type certificate 2-A-4 Production Certificate 203 engine type TPE 331-43 Mfgrs. Ass'n data plate #315623 All standard stuff, eh what? Now, below this is a small data plate that says: Type cert 2-A-4 Production Cert. 203 engine: IGSO-540 B1A Do I take this to mean this was built as a 680FLP and run back through the production line to emerge as a 680T? Never seen this. Next, and not so odd, is N1187D, with the s/n 680-626-252. I stood looking thinkng I was looking at a long wing, but Mike paced it off and it's about 44'. "Pre E" style gear and flap handles, hand hydraulic pump, so it's not an E, but wouldn't the data plate say 680-S in this case, or is the "S" not standard nomenclature? Thanks for your help, old boy. Wing Commander Gordon ________________________________________________________________________________
Date: May 17, 2001
Subject: Re: What is this plane worth?
> Nico van Niekerk wrote: > He wants about $100K. > Do you think this could be a good buy? Something doesn't sound quite right to me Nico. If the airplane is truely as nice as it sounds, I'd expect it to bring considerably more. If you don't want it, I'd sure like to take a look! :-) Chris ________________________________________________________________________________
Date: May 17, 2001
If you believe the Bluebook (Spring 2001 edition) which sometimes tends to overestimate these values for Commanders.... The 680FL earliest models - 1963 S/N 1244 to 1375 show a retail of $121 k and wholesale of $100-106 k. The last ones built in 1969, S/N 1765-1852, show a retail of 140 k and a wholesale of 116-123. This is based on the usual: mid-times engines (with 1200 TBO - so you have a plus there which the Bluebook says to add $30.20 per hour for low engine times), no damage history, good compression, excellent P&I, 6 month annual, etc. There is one important footnote which says "prices do not reflect spar cap mod, costing $70,000 to 105,000." I am not an expert on the mechanical side of things, but it looks like you better research the spar status on this bird. BTW I am a Commander fan with a lot of hours on old 500 series birds, but I am treading carefully before I buy one because of these spar problems which can make a potential investment worth its weight in beer cans.... To me it sounds like the current or previous owner spent big bucks on a major avionics upgrade, so if I were you I would be a little curious as to why he wants out the airplane now. You may have a true bargain there, but as they say, "buyer beware". Invest in a thorough pre-buy inspection. Good luck. Juan Leon PS please drop me a line and let me know what happens. It is always helpful to have actual sales prices. Thanks. > > > Chief, > > I can get a 680FL with IGSO-540-B1A (380 HP) WITH L 208 / R 588, props 27 Snew L > & R. Total time 2,800! Interior and exterior 10/10 > > Panel kit: > New century 2000 auto pilot with altitude hold and pre select. Coupled to GPS. > New Sandals digital RMI. > New Garmin GNS430 GPS, NAV, COM. > New Garmin 340 audio panal. > New JPIntenational engine monitoring system. > Shadin Digiflo fuel computer > 1 x King KDX 150 color radar. > 1 x King KY 97 com > 1 x King KT76A Transponder with mode c encoding altimeter. > 1 x King KN 52 Nav with glide slop. > 2 x King K___ digital A.D.F > > The owner says that there is no need for spar inspections or mods. Is this right > on the 680FL? > > He wants about $100K. > Do you think this could be a good buy? An educated guess would be appreciated. > Thanks > Nico > > > > > > ________________________________________________________________________________
Date: May 17, 2001
From: CloudCraft(at)aol.com <CloudCraft(at)aol.com>
Subject: Re: Odd Specimen
In a message dated 05/17/01 01:30:39 Pacific Daylight Time, Barry.Collman(at)airclaims.co.uk writes: > The aircraft is > registered to a Gene Forsthofel, of Palm Coast, Florida and has been so > since February 1989, but the new FAA database on the web indicates mail is > undeliverable. > Exellent, Sir Barry. I have the current name and local phone number of who pays the tie-down fee, so will call and realy what I find out. I didn't see the Experimental legend -- either it's far too faded to see now, or, I just wasn't observant enough. Of course, I was terribly distracted by two rods that were stuck through the nose area, seeming to go to or through the nose wheel strut. One entered via an inspection panel on the left side, the other through a drilled hold. Mike and I just couln't figure it out and I left well enough alone in accordance with Aviation Prime Directive #1: "If you don't know what it does, don't touch it." N29DE does indeed have turbine engine nacelles and it looks like the engines were removed with some degree of care - - lines capped off -- as if it was to have engines put back on. Will follow up and let you know. Thanks for the info! I hope at least one of those steady streams of lunches will be on me next time. Wing Commander Gordon ________________________________________________________________________________
Date: May 17, 2001
From: Mark Woodley Earthlink <woodlema(at)earthlink.net>
I know I personally took advantage of the 50% Hartzell deal. After evaluating the cost of overhaul, vs. new, I had a $3,000.00 difference in cost. I opted for the new, since overhauled is always overhauled. But New, has a much better ring to it, and a higher resale value in the long haul. I have not seen the "NEW" AD yet on the sump, but I imaging it is not gonna be cheap. Mark ----- Original Message ----- From: garyloff To: Dennis Polito W6DEN ; TCFG(at)listbot.com Sent: Thursday, May 17, 2001 5:48 AM Subject: Re: Sumps and my .02 worth. LATER WHEN I GET INTO THE OFFICE I WILL PUBLISH WHAT THE FAA HAS SAID ABOUT SBs AND ADs. TO PARAPHRASE THEY ARE THE ONLY ONES WITH THE AUTHORITY TO ISSUE THESE. LIGHT AC MANUFACTURERS DONNOT HAVE THE AUTHORITY PERIOD. LIKE I SAID I'LL SUPPLY THE DIRECT QUOTE AND REFERENCE. JUST BECAUSE SOME MANUFACTURER DECIDES THEY HAVE FOUND A NEW PROFIT CENTER IT IS NOT SO AND THE FAA IS PUTTING A STOP TO IT. CHANCES ARE IF YOU SHIP HAS FLOWN ON A REGULAR BASIS AND WATER DIDN'T GET A CHANCE TO SIT FOR MONTHS YOU'RE PROPABLY IN GOOD SHAPE. THE LAST TIME TCAC MADE SUCH A NAKED GRAB FOR YOU MONEY WAS OVER THE WING STRAP AD. THEY CLAIMED TO BE THE ONLY ONES QUALIFIED AND PETITIONED THE FAA TO HAVE ONLY THEIR SHOPS APPROVED TO DO THE WORK. HAD THIS BEEN THE CASE MY LESS THAN 3K EVENT WOULD HAVE BEEN OVER 12. ----- Original Message ----- From: Dennis Polito W6DEN To: TCFG(at)listbot.com Sent: Wednesday, May 16, 2001 2:47 AM Subject: Sumps and my .02 worth. 1. Fill in the brief application 2. Receive approval decision within 30 seconds Here we go again, yet another big bucks AD in the works. Sure, safety is everyone's main concern, especially me, the person sitting next to 156 gallons of fuel, but I kinda get the feeling that the folks at TCFG would just as soon see the piston operators disappear. Not enough money to be made on those measly 100LL machines for their liking. Let's see now, how many of the fleet can we retire with this latest assault? Is that the real goal? Hey TCFG folks, how about showing some support here? Or is it your goal to profit from the failure of your product? I for one would like to know what the failure rate (in numbers) has been on the sump. Can the good folks at TCFG supply us with the data? Surely there must be an alternative method of insuring the integrity of the sumps that pass visual and NDT inspection, perhaps a coating of some sort. Too easy a concept though, it will never work. I inspected my sump during a recent fuel cell replacement and I did not see even a hint of corrosion. Who wants to scrap a perfectly serviceable component? My preflight sniff o meter is ever vigilant and I am happy to report the absence of errant misplaced 100LL in the baggage compartment. Ditto with the filter housings. Now is TCFG's opportunity to show support. Hartzell did, they showed tremendous support. Remember the 50% off list regarding the prop replacement program? Bet that a deeply discounted sump and filter kit would get a higher and quicker compliance percentage throughout the fleet! You bet! JB: Thanks ever so much for all of the effort and time that you have given to the group, I for one appreciate it! I am looking forward to meeting you on 24 August, that is if my aircraft is still airworthy at that time. Dennis Polito ________________________________________________________________________________
Date: May 17, 2001
In a message dated 5/17/01 8:03:57 AM Pacific Daylight Time, woodlema(at)earthlink.net writes: << I have not seen the "NEW" AD yet on the sump, but I imaging it is not gonna be cheap. Mark >> My understanding from Gary Gadberry is that the sump issue is a service letter and he does not believe it will become an AD but just an inspection. Is he right or wrong. Jim Furlong ________________________________________________________________________________
Date: May 17, 2001
At this point it is a Service Letter ONLY. JB says it is to be a Service Bulletin soon. Running the progression on out COULD have it as an AD in the future. bilbo ----- Original Message ----- From: <Furlong5(at)aol.com> To: ; Sent: Thursday, May 17, 2001 11:20 AM Subject: Re: Sumps and my .02 worth. > > > In a message dated 5/17/01 8:03:57 AM Pacific Daylight Time, > woodlema(at)earthlink.net writes: > > << > I have not seen the "NEW" AD yet on the sump, but I imaging it is not gonna > be cheap. > > Mark >> > > > My understanding from Gary Gadberry is that the sump issue is a service > letter and he does not believe it will become an AD but just an inspection. > > Is he right or wrong. > > Jim Furlong > > ________________________________________________________________________________
Date: May 17, 2001
Subject: Cool Hand Luke flies a Commander
============================== The following is an open letter to TCAC from myself as an individual and NOT the expressed opinion of the TCFG, its members or affiliates. "What we have here is a failure to communicate." The recent volley about the sump replacement bulletin demonstrates yet another link in a chain of "sneak attacks" that cause the piston owner/operators in particular, to believe that they are not receiving support from you as the OEM. The reason this kind of sentiment exists is because you lob these grenades from your bunker and then don't emerge again until it's Twin Commander University time and you can troop about the Grand Renaissance program. Other OEMs do a better job of keeping their fleets informed of continuing airworthiness concerns and may, from time to time, solicit input, suggestions and solutions from outside vendors and service providers. Of course, the topic of outside vendors and service providers has always been a contentious one, hasn't it? You have the means to improve your public relations. This forum is open to you as it is to me (much to your dismay, I'm sure) and everyone else. You have a web site. You publish a magazine. Have Mark Twombly write a breezy-yet0-compelling article to explain what you're doing and why. Have Maintenance and Operators' meetings in different regions around the country and inform your customers of what's on your mind. Work with the TCFG! When the TCFG was originally formed in 1994 by an outside public relations firm at your behest, it was to do exactly the above. There was a rift in philosophy between you and that P.R. firm and you retreated from the scene. The current TCFG is a grass roots owners' club; you have no investment in it, except for the fact that it's attracted a growing percentage of your customers. Your concerns about this fleet are legitimate -- obviously right now you have a concern about fuel sumps on certain models of Commanders. You also have a resentful customer base, which you could have minimized. Even politicians take the time to communicate with their constituents. I realize you're not running for reelction, but it wouldn't hurt to keep your owner/operators in the loop. Remember that this letter is from me, not the TCFG, and take it as my priceless offer of free advice. Regards, Keith S. Gordon former TCFG coordinator former Flight Group News editor former Twin Commander training provider current and long-standing TCAC black-list member ________________________________________________________________________________
Date: May 17, 2001
Nico van Niekerk wrote: > > Chris, > Thanks for the response. I would like to buy this plane but am a little > worried about hidden costs Nico, The engines are IGSO-540 Lycomings. They're generally a pretty durable motor, but definitly can be torn up quickly due to improper operation. They are supercharged and work pretty hard. I understand that it's not unusual to "top" a few jugs before getting to TBO. Definitly a great airplane, it it will cost some money to keep her in top shape. Chris ________________________________________________________________________________
Date: May 17, 2001
HI JIM..... This action started as a service letter (379) I reported this in the DEC FGN (remember, you heard it here first) It has now become a (mandatory) service bulletin, SB230A. This is the usual progression of an action unless the FAA feels there is immediate danger. From here, who knows?? It is my personal belief that it almost certainly will become an AD. I plan to meet with the TCAC and the FAA soon regarding this action. I have had a couple of contacts with Jeff Cousins at TCAC, and he also believes it will become an AD and Commander has already invested in an inventory of new parts in anticipation of this. There are several options open now. First, I will meet with the Feds and discuss the possibility of an optional means of compliance. As a group, we own or care for a large number of piston commanders and we may be able to use our "field experience" to defer the SB from becoming an AD. Next, we can lobby that the factory authorized inspection procedure should be adequate to comply. While I would agree that Magnesium is the wrong material to have made the sumps from, Most have lasted a long time and may still be serviceable. An inspection would determine this. Lastly, it has been mentioned that Hartzell offered a substantial discount to owners. This seems like a reasonable approach assuming the sumps really require replacement. I will propose this to TCAC when we meet. I want to say that I have checked with a few Commander Gurus and it is widely agreed that sump corrosion is a problem but no one has any hard data. I don't know how many replacement sumps TCAC has sold over the last 5 years, and there seems to be no information on the results of SL379. For sure, some airplanes have been found with unsafe sumps, others have been checked and no corrosion was found. If you have any sump history, please email me personally with that information. Thanks jb ________________________________________________________________________________
Date: May 17, 2001
HI NICO...... If that airplane is "as represented" it is a steal!!! Call Morris Kernick for a pre buy inspection, it will be the best Commander $$ you will spend. GOOD LUCK!! jb Morris Kernick Commander Services, 510-783-3041 ________________________________________________________________________________
Date: May 17, 2001
Subject: Re: (Re: wings)
I've had my nose against the grindstone all this week and havn't even had a chance to catch up on the list email, but I wanted to thank everyone who took the time to answer some of my questions regarding the 500S wing spar. Jeff Cousins (TCAC) wrote me an extensive letter which does somewhat put my mind at ease. The summary was that if the airplane has passed several inspections with no problems, that the likelyhood of finding a problem in the near future is probably quite low. Evidently there were about 10 percent of the Shrikes that required immediate spar replacement when first insepcted, and once those were weeded out that things are pretty stable now. Thanks again, Chris Schuermann ________________________________________________________________________________
Date: May 17, 2001
Subject: Re: Cool Hand Luke flies a Commander
Bravo, Keith. /John ----- Original Message ----- From: CloudCraft(at)aol.com To: tcfg(at)listbot.com Sent: Thursday, May 17, 2001 8:58 AM Subject: Cool Hand Luke flies a Commander 1. Fill in the brief application 2. Receive approval decision within 30 seconds ============================== The following is an open letter to TCAC from myself as an individual and NOT the expressed opinion of the TCFG, its members or affiliates. "What we have here is a failure to communicate." The recent volley about the sump replacement bulletin demonstrates yet another link in a chain of "sneak attacks" that cause the piston owner/operators in particular, to believe that they are not receiving support from you as the OEM. The reason this kind of sentiment exists is because you lob these grenades from your bunker and then don't emerge again until it's Twin Commander University time and you can troop about the Grand Renaissance program. Other OEMs do a better job of keeping their fleets informed of continuing airworthiness concerns and may, from time to time, solicit input, suggestions and solutions from outside vendors and service providers. Of course, the topic of outside vendors and service providers has always been a contentious one, hasn't it? You have the means to improve your public relations. This forum is open to you as it is to me (much to your dismay, I'm sure) and everyone else. You have a web site. You publish a magazine. Have Mark Twombly write a breezy-yet0-compelling article to explain what you're doing and why. Have Maintenance and Operators' meetings in different regions around the country and inform your customers of what's on your mind. Work with the TCFG! When the TCFG was originally formed in 1994 by an outside public relations firm at your behest, it was to do exactly the above. There was a rift in philosophy between you and that P.R. firm and you retreated from the scene. The current TCFG is a grass roots owners' club; you have no investment in it, except for the fact that it's attracted a growing percentage of your customers. Your concerns about this fleet are legitimate -- obviously right now you have a concern about fuel sumps on certain models of Commanders. You also have a resentful customer base, which you could have minimized. Even politicians take the time to communicate with their constituents. I realize you're not running for reelction, but it wouldn't hurt to keep your owner/operators in the loop. Remember that this letter is from me, not the TCFG, and take it as my priceless offer of free advice. Regards, Keith S. Gordon former TCFG coordinator former Flight Group News editor former Twin Commander training provider current and long-standing TCAC black-list member ________________________________________________________________________________
Date: May 17, 2001
Well I had no idea this(Sump Monster) was going to raise anybody's blood pressure but mine. As of today we,really Harry Merritt & Co., are going to continue with a sump from Yoda that will be coated to preserve it for use in the twenty second century. My only hope, in addition to safely fixing the problem, is the investment will cover any future AD plans buy any group. After that quote, Luke you should duck. I think that's when the gunfire broke out and Luke was dropped. Luke,I mean Keith, I'd be glade to join you on the Black List. They can't get my Birthday. bilbo ----- Original Message ----- From: John Vormbaum To: TCFG(at)listbot.com Sent: Thursday, May 17, 2001 2:37 PM Subject: Re: Cool Hand Luke flies a Commander 1. Fill in the brief application 2. Receive approval decision within 30 seconds Bravo, Keith. /John ----- Original Message ----- From: CloudCraft(at)aol.com To: tcfg(at)listbot.com Sent: Thursday, May 17, 2001 8:58 AM Subject: Cool Hand Luke flies a Commander 1. Fill in the brief application 2. Receive approval decision within 30 seconds ============================== The following is an open letter to TCAC from myself as an individual and NOT the expressed opinion of the TCFG, its members or affiliates. "What we have here is a failure to communicate." The recent volley about the sump replacement bulletin demonstrates yet another link in a chain of "sneak attacks" that cause the piston owner/operators in particular, to believe that they are not receiving support from you as the OEM. The reason this kind of sentiment exists is because you lob these grenades from your bunker and then don't emerge again until it's Twin Commander University time and you can troop about the Grand Renaissance program. Other OEMs do a better job of keeping their fleets informed of continuing airworthiness concerns and may, from time to time, solicit input, suggestions and solutions from outside vendors and service providers. Of course, the topic of outside vendors and service providers has always been a contentious one, hasn't it? You have the means to improve your public relations. This forum is open to you as it is to me (much to your dismay, I'm sure) and everyone else. You have a web site. You publish a magazine. Have Mark Twombly write a breezy-yet0-compelling article to explain what you're doing and why. Have Maintenance and Operators' meetings in different regions around the country and inform your customers of what's on your mind. Work with the TCFG! When the TCFG was originally formed in 1994 by an outside public relations firm at your behest, it was to do exactly the above. There was a rift in philosophy between you and that P.R. firm and you retreated from the scene. The current TCFG is a grass roots owners' club; you have no investment in it, except for the fact that it's attracted a growing percentage of your customers. Your concerns about this fleet are legitimate -- obviously right now you have a concern about fuel sumps on certain models of Commanders. You also have a resentful customer base, which you could have minimized. Even politicians take the time to communicate with their constituents. I realize you're not running for reelction, but it wouldn't hurt to keep your owner/operators in the loop. Remember that this letter is from me, not the TCFG, and take it as my priceless offer of free advice. Regards, Keith S. Gordon former TCFG coordinator former Flight Group News editor former Twin Commander training provider current and long-standing TCAC black-list member ________________________________________________________________________________
Date: May 17, 2001
Subject: Lycoming Exhaust Studs
Owners, I just came into 250 brand new Lycoming exhaust studs. Please let me know if you need any. I know Yoda and the engine shops sell them for around $6.00 apiece. I'll let them go for $2.50 each. You guys can pay the shipping. I know there are alot of lousy studs out there. I just did all of mine. They are GREAT now. Also put on the good exhaust gaskets. Keep the shiny side down ! Signing the paperwork today (hopefully) with my new partner, and TCFG member (hopefully), Barry Hancock. If Barry shows up on the list wish a a great TCFG welcome ! I'll be expecting your orders. Thanks guys ! Paul P51PAUL ________________________________________________________________________________
Date: May 17, 2001
Subject: Re: Lycoming Exhaust Studs
Gee Paul, thought I was the only exhausted stud out there. ----- Original Message ----- From: "Paul Odum" <calnet01(at)gte.net> To: ; Sent: Thursday, May 17, 2001 3:47 PM Subject: Lycoming Exhaust Studs > > > Owners, > > I just came into 250 brand new Lycoming exhaust studs. Please let me > know if you need any. I know Yoda and the engine shops sell them for > around $6.00 apiece. I'll let them go for $2.50 each. You guys can pay > the shipping. > > I know there are alot of lousy studs out there. I just did all of mine. > They are GREAT now. Also put on the good exhaust gaskets. > > Keep the shiny side down ! > > Signing the paperwork today (hopefully) with my new partner, and TCFG > member (hopefully), Barry Hancock. > > If Barry shows up on the list wish a a great TCFG welcome ! > > I'll be expecting your orders. > > Thanks guys ! > > Paul > P51PAUL > > ________________________________________________________________________________
Date: May 17, 2001
Nico, I had a conversation with Jay Armstrong at Suburban Air in Omaha, NB. They run 8- 680FLs. They get 1500 hours out of their engines. They do not exceed 40 MP on take off and climb. They cruse at 30 MP and 2400 RPM (engine RPM, props are much slower turning). Doing this they can haul 2000 lbs for 500 miles at 165KTS. They can get an engine overhauled for under $30,000 with new cylinders from Central Cylinder in Omaha. Central Cylinder owns the rights to the Simmons Fuel Controller used on that airframe and are the only place in the world to get one fixed. They are selling all 8 aircraft. Asking price is $116,000 and up with only cargo interior. http://www.subair.com/ The seller should be able to show you what they paid to have the new avionics installed. The autopilot is $11,000+, the 430 are $9,000+, and the JPI is super at about $7,500. I am just guessing they put $25,000+ into it. You would be buying the basic airplane at $75,000, which is a lot of airplane for the dollar. Major item to watch out for is the fuel cells and any thing rubber. If one fuel cells needs replacement, you need to replace all of them and all the fuel lines. Look into the logs to see when they were replaced. Any thing out of rubber that is 40 years old needs to be replaced. It is age not time on the airframe. Also check out the hoses in the engine and landing gear for age. Most hoses only last 10 years. Again it is age not time on airframe. The MR RPM engine swap is available to the IO-720s with 400 HP. If the 680FL fits your mission, it is a good buy. This is only one opinion and it is your money. Get good type specific training in it. And Have Fun. Regards, Tylor Hall tylorh(at)sound.net 913-422-8869 -----Original Message----- From: Nico van Niekerk [mailto:nico(at)cybersuperstore.com] Sent: Thursday, May 17, 2001 12:47 AM To: tcfg(at)listbot.com Subject: What is this plane worth? _____ 1. Fill in the brief application 2. Receive approval decision within 30 seconds _____ Chief, I can get a 680FL with IGSO-540-B1A (380 HP) WITH L 208 / R 588, props 27 Snew L & R. Total time 2,800! Interior and exterior 10/10 Panel kit: New century 2000 auto pilot with altitude hold and pre select. Coupled to GPS. New Sandals digital RMI. New Garmin GNS430 GPS, NAV, COM. New Garmin 340 audio panal. New JPIntenational engine monitoring system. Shadin Digiflo fuel computer 1 x King KDX 150 color radar. 1 x King KY 97 com 1 x King KT76A Transponder with mode c encoding altimeter. 1 x King KN 52 Nav with glide slop. 2 x King K___ digital A.D.F The owner says that there is no need for spar inspections or mods. Is this right on the 680FL? He wants about $100K. Do you think this could be a good buy? An educated guess would be appreciated. Thanks Nico _____ ________________________________________________________________________________
Date: May 17, 2001
Subject: Twin Commander Support of Your Airplane
As the new (6 month) General Manager of Twin Commander it has been educational (and certainly interesting) interacting with you, our customer, the Twin Commander Owner. Ithas been my goal since before moving to Arlington to see more dialog between TCFG and TCAC. I can refer you to Jim Metzger and the discussions we held last summer while I was visiting Seattle and getting the opportunity to see Puget Sound in his floatplane.The goal then and I believe in every meeting we've had since then has been to support your association as the type certificate holder for the Twin Commander models. We have made no attempt to drag out old issues, have not in any way entered into the discussions you have had concerning your organization or expressed opinions on you individually. Twin has responded when one of you has made a request for information that we could provide and are happy to continue doing so. I personally have referred two new owners to Jim for membership in TCFG which I believe falls under being judged by your actions. Twin wants very much to support TCFG and will continue to do so as long as it remains a productive relationship. I couldn't agree more with the observation that we should communicate with our customers. Four separate letters from me have been mailed either to specific groups of owners or to all owners of record since I arrived six months ago. The letters encouraged owners to contact me if you had concerns, (which several of you have) and have strived to inform you of Twin's programs. That included our plans for our website to provide you, the owner, with updated information on your aircraft. Some of those changes are in place and the rest are scheduled for completion in the next few weeks. If you are an owner and are not receiving these letters and Twin's SBs and other mailings please go to our website and register your current info including model and serial number to insure you are receiving all our communiqus. Twin Commander is the holder ofthe Type Certificates for the twin engined Commander aircraft. Assuch we are required to report any information we receive that has the possibility of affecting safety of flight to the FAA's Seattle Aircraft Certification Office within 24 hours. The reports we make invariably result in a request from the ACO to keep them appraised of our follow up investigation. The system of Service Letters, Service Bulletins, and Mandatory AD's (Which are issued by the FAA) works in the following way. Twin Commander can independently issue a Service Letter for issues we do not believe create an immediate threat to safety of flight. That was donewith SL379after the first reports of sump problems aroseover two years ago. SL 379 required only a visualinspection for leaks and then a structural inspection to verify the integrity of the sumpif leaks were found. As a result of reports from those inspections including one where the inspector was able to punch his finger through the side of the sump and another where the wall was corroded away and had been repaired with JB Weld it was determined that the non safety of flight status of a SL was not appropriate for this problem. Because Twin does not issue Service Bulletins without FAA review and because of the location of the sump in the fuselage, the extent of corrosion discovered, the past history of Aero Commander replacing the magnesium sumps in the earlier models, and the very significant consequences of having a 100 octane and associated vaporleak in a confined area with electrical contactors present it was decidedto recommend replacing the sumps. The communication with the FAA culminated with a meeting with Mr. Mike Paison and Mrs. Della Reese in March of this year. At that time the status as an AD had not been made and was to be referred to the Small Aircraft Directorate in Kansas City for a final decision. It is Twin Commanders belief that these sumps should be replaced for your benefit, but the FAA, who is the only authority to require replacement via an AD has not yet reached that decision.Certainly the process was open to discussion thought SL 379, and SB 230A. The personnel involved in reaching the consensus are dedicated, professional engineers with years of Commander experience. Theyare under a great deal of pressurefrom owners, service centers, and the FAA todetermine a solution for these situations.Another consequence of the recommendation to replace the sumps is that TCAC (Without an AD requiring replacement) has spent a year and a half, countless engineering and purchasing hoursand significant dollars insuring that the components required will be available for this SB. The alternative to this process would be that no action was taken, the FAA would make a determination that the sumps should be replaced, issue an AD, and owners would find their aircraft grounded without replacement parts. We went through that scenario with lower spar caps in the early 90's and do not intend for it to happen again. The last issue I will try to address is the requirement for specifying by whom the work can be accomplished. Both SL 379 and SB 230Aspecify that any A&P mechanic may accomplish these items. Several years ago Twin Commander issuedSB 218 on thelater turbine models that called for significant modifications to the vertical and horizontal stabilizers. That SB required only an A&P for the work as had all our bulletins to that point.Over the next couple of years aircraft returned to Service Centers for other workwere discoveredto havespars in the horizontal stabilizerswithholes drilled through them because of ignorance on the part of the people accomplishing the work. Twin (as well as other manufactures) have struggled with how to insure that complicated bulletins are accomplished by properly trained personnel. The current requirements for completing this type work is not that it be done by a service center but by someone who has attended the appropriate training at the Flight Safety/Twin Commander training center in Bethany, OK. I have listened with interest and pride as Commander owners have described their $100,000 plus piston Commanders that werepurchased for prices as low as $10,000-$15,000. The appreciation of your investments would not have occurred if the only parts and engineering support available were used partsand field repairs. Jim Metzger has already addressed the value Twin Commander adds to your aircraft and though you may not agree with the decision we reached concerning the fuels sumps I hope you can acceptour commitment to supporting your aircraft. Twin Commander depends heavily on our Service Center network for the technical information they provide, the countless days spent in support of the airframe, and the hundreds of years of collective experience their personnel represent. The Twin Commander Service Center Network is one of the greatest resources available to the Commander Owner and I heartily encourage you to utilize them. The team effort between Twin Commander and its Service Centers benefits you the Commander owner. Jeff Cousins Vice President/General Manager Twin Commander Aircraft Corporation Tel: 360-435-9797 Fax:360-435-1112 Cell:425-210-2907 Email: jcousins(at)twincommander.com ________________________________________________________________________________
Date: May 17, 2001
Subject: Re: Twin Commander Support of Your Airplane
Very nice letter, Mr. Cousins; very nice look inside TCAC. Keep it up. Keith S. Gordon ________________________________________________________________________________
Date: May 17, 2001
I forgot to say Thank You. Keith S. Gordon ________________________________________________________________________________
Date: May 17, 2001
Untitled StationeryJeff, Thanks for the very educational reply, and thanks for reaching out to the TCFG. I appreciate the personal attention! Regards, /John ----- Original Message ----- From: Jeff Cousins To: 'tcfg(at)listbot.com' Sent: Thursday, May 17, 2001 4:52 PM Subject: Twin Commander Support of Your Airplane 1. Fill in the brief application 2. Receive approval decision within 30 seconds As the new (6 month) General Manager of Twin Commander it has been educational (and certainly interesting) interacting with you, our customer, the Twin Commander Owner. It has been my goal since before moving to Arlington to see more dialog between TCFG and TCAC. I can refer you to Jim Metzger and the discussions we held last summer while I was visiting Seattle and getting the opportunity to see Puget Sound in his floatplane. The goal then and I believe in every meeting we've had since then has been to support your association as the type certificate holder for the Twin Commander models. We have made no attempt to drag out old issues, have not in any way entered into the discussions you have had concerning your organization or expressed opinions on you individually. Twin has responded when one of you has made a request for information that we could provide and are happy to continue doing so. I personally have referred two new owners to Jim for membership in TCFG which I believe falls under being judged by your actions. Twin wants very much to support TCFG and will continue to do so as long as it remains a productive relationship. I couldn't agree more with the observation that we should communicate with our customers. Four separate letters from me have been mailed either to specific groups of owners or to all owners of record since I arrived six months ago. The letters encouraged owners to contact me if you had concerns, (which several of you have) and have strived to inform you of Twin's programs. That included our plans for our website to provide you, the owner, with updated information on your aircraft. Some of those changes are in place and the rest are scheduled for completion in the next few weeks. If you are an owner and are not receiving these letters and Twin's SBs and other mailings please go to our website and register your current info including model and serial number to insure you are receiving all our communiqus. Twin Commander is the holder of the Type Certificates for the twin engined Commander aircraft. As such we are required to report any information we receive that has the possibility of affecting safety of flight to the FAA's Seattle Aircraft Certification Office within 24 hours. The reports we make invariably result in a request from the ACO to keep them appraised of our follow up investigation. The system of Service Letters, Service Bulletins, and Mandatory AD's (Which are issued by the FAA) works in the following way. Twin Commander can independently issue a Service Letter for issues we do not believe create an immediate threat to safety of flight. That was done with SL379 after the first reports of sump problems arose over two years ago. SL 379 required only a visual inspection for leaks and then a structural inspection to verify the integrity of the sump if leaks were found. As a result of reports from those inspections including one where the inspector was able to punch his finger through the side of the sump and another where the wall was corroded away and had been repaired with JB Weld it was determined that the non safety of flight status of a SL was not appropriate for this problem. Because Twin does not issue Service Bulletins without FAA review and because of the location of the sump in the fuselage, the extent of corrosion discovered, the past history of Aero Commander replacing the magnesium sumps in the earlier models, and the very significant consequences of having a 100 octane and associated vapor leak in a confined area with electrical contactors present it was decided to recommend replacing the sumps. The communication with the FAA culminated with a meeting with Mr. Mike Paison and Mrs. Della Reese in March of this year. At that time the status as an AD had not been made and was to be referred to the Small Aircraft Directorate in Kansas City for a final decision. It is Twin Commanders belief that these sumps should be replaced for your benefit, but the FAA, who is the only authority to require replacement via an AD has not yet reached that decision.Certainly the process was open to discussion thought SL 379, and SB 230A. The personnel involved in reaching the consensus are dedicated, professional engineers with years of Commander experience. They are under a great deal of pressure from owners, service centers, and the FAA to determine a solution for these situations. Another consequence of the recommendation to replace the sumps is that TCAC (Without an AD requiring replacement) has spent a year and a half, countless engineering and purchasing hours and significant dollars insuring that the components required will be available for this SB. The alternative to this process would be that no action was taken, the FAA would make a determination that the sumps should be replaced, issue an AD, and owners would find their aircraft grounded without replacement parts. We went through that scenario with lower spar caps in the early 90's and do not intend for it to happen again. The last issue I will try to address is the requirement for specifying by whom the work can be accomplished. Both SL 379 and SB 230A specify that any A&P mechanic may accomplish these items. Several years ago Twin Commander issued SB 218 on the later turbine models that called for significant modifications to the vertical and horizontal stabilizers. That SB required only an A&P for the work as had all our bulletins to that point. Over the next couple of years aircraft returned to Service Centers for other work were discovered to have spars in the horizontal stabilizers with holes drilled through them because of ignorance on the part of the people accomplishing the work. Twin (as well as other manufactures) have struggled with how to insure that complicated bulletins are accomplished by properly trained personnel. The current requirements for completing this type work is not that it be done by a service center but by someone who has attended the appropriate training at the Flight Safety/Twin Commander training center in Bethany, OK. I have listened with interest and pride as Commander owners have described their $100,000 plus piston Commanders that were purchased for prices as low as $10,000-$15,000. The appreciation of your investments would not have occurred if the only parts and engineering support available were used parts and field repairs. Jim Metzger has already addressed the value Twin Commander adds to your aircraft and though you may not agree with the decision we reached concerning the fuels sumps I hope you can accept our commitment to supporting your aircraft. Twin Commander depends heavily on our Service Center network for the technical information they provide, the countless days spent in support of the airframe, and the hundreds of years of collective experience their personnel represent. The Twin Commander Service Center Network is one of the greatest resources available to the Commander Owner and I heartily encourage you to utilize them. The team effort between Twin Commander and its Service Centers benefits you the Commander owner. Jeff Cousins Vice President/General Manager Twin Commander Aircraft Corporation Tel: 360-435-9797 Fax:360-435-1112 Cell:425-210-2907 Email: jcousins(at)twincommander.com ________________________________________________________________________________
Date: May 17, 2001
From: Chris Schuermann <chris(at)skymaster.c2-tech.com>
> Jeff Cousins wrote: > though you may not agree with the decision we reached concerning the > fuels sumps I hope you can accept our commitment to supporting your > aircraft. Jeff, First I would like to express my sincere appreciation at you taking the time to explain TCAC's point of view on this topic as well as thank you personally for jumping in to what has become a public forum filled with great discussions on a broad range of topics. When I first created this list, I did indeed have concerns about how it would be taken by TCAC managment. It has been my strongest hope since inception that the very open dialog as well as expression of concerns would be of value to all Commander enthusiasts as well as TCAC if accepted with an open mind and an ability to listen to both positive and negative feedback as of potential value. As a business owner myself, I can definitly empathize with how difficult it can be to receive negative comments regarding an action that you honestly believe was made in the customers best interests. I have found (via the school of hard knocks) that keeping my customers abreast of any issue which may negativly (or positivly) affect them often results in a much greater acceptance of any problems. This sump issue is a great case and point - most of the frustration that I've heard so far is primarily rooted in a lack of understanding. Given the somewhat fragmented user base, most owners will only understand that they've been presented with a solution to a problem they don't think they have unless dialog such as you just presented occurs. TCAC is to be applauded for taking the initiative to not only proactivly address the problem, but also actually produce parts so that owners will not be "stuck" when the paperwork hits. Your letter pointed out several issues which I, for one, was not clear on such as the fact that without TCACs intervention that this issue could have jumped straight to AD status without much warning. I hope that this is not the last time you decide to participate in such a valuable way to this list Jeff. Please consider the door open. I believe I speak for the majority of the members of this list when I say that direct information is very much appreciated. As you noted, there WILL be disagreement with various actions and decisions from time to time, but I think that most owners will be vastly more supportive if they truely understand the facts that drive these actions. Chris Schuermann ________________________________________________________________________________
Date: May 17, 2001
Subject: SL 379 / SB230
Hay gang, I hate to ask the dumb question, but. Where do I read the full text of SL 379 and SB 230 ???? Can someone give us the link to it on the web?? Jeff C TCAC. Hurray, someone as least has the volume turned up a little. I must give you one good Atta Boy for your response. This may be a new day. I like to sum up things into small words. It is how my daughter teaches me computers. 1.The subject sump has a documented corrosion problem. Hence SL 379. JB weld is not the answer. It is more than just the can, but all related connections. Only on a certain model and SN Twin Commanders and not the entire fleet. 2. TCAC (after many hours of eng.) Concludes that all affected sumps must be replaced. Hence SB 230. Est. cost is the better part of $4,000. 3. The FAA may take it to a required AD level. 4. TCFG is working with TCAC and FAA to find the next best solution? (Go Capt JB.) What about a sump that has no corrosion after inspection?? There is no data on number of inspections, number of failed sumps, and number of replacements made?? Is there a FIX short of replacement? Coating, replace only the sump? Am I close??? Regards, Tylor Hall tylorh(at)sound.net 913-422-8869 JB-My check is in the mail. TH ________________________________________________________________________________
Date: May 17, 2001
Subject: Twin Commander support
Dear Jeff, Thank you for your reply to our concerns. I too think it is very important to communicate with piston owners. A lot of your Turbine Customers, (many more than you may imagine) first heard of or became interested in your Turbine aircraft as a result of seeing our 5 and 600 series piston aircraft on the local ramps accross the country. My first experience with Twin Commanders was October 15, 1963 when we purchased a 500B s/n 1302-117 from Brown Aero Corp. (My Uncle was a Commander Dealer) We flew this aircraft for several years in business and pleasure activities. I have always loved Twin Commanders. Recently, I decided that it was time to unload the 414 and buy a Twin Commander, as my mission had changed since retirement. After searching for SN 1302-117, our old plane, I was frustrated at being unable to locate it. Then things turned great. I discovered 500B s/n 893-1, the first 500B made, and I had to have it. Now I am in Commander heaven again. The purpose of relating this story to you is to demonstrate the love and loyalty that Twin Commander owners have for their aircraft. I belive Twin commander owners are more loyal and radical in their love of their babies than Piper Comanche owenrs. (I owned a PA 24-260 and know of what I speak, still love Comanches). This is why owners get worried when they think TCAC is gouging or not communicating. You mentioned the process for SL, SB and ADs in your e-mail. We all understand the process, but thank you for reminding us. The type of info your company gleaned from field reports that generate potential serious SL, SB, or ADs could have been communicated to TCFG at earlier stages. I feel this would eliminate this type of uproar in the future. Jeff, I do appreciate your intrest and concern for piston Commander owners. We love our aircraft. (what other 6500lb+ twin can you operate from 1000ft?) I also very much appreciate TCAC's attempt to place parts on hand to prevent our birds form being grounded for lengthy periods in case of an AD issuance. This does a lot to show TCAC's care and support of Piston Twins. Thank you. One final question, in case of the dreaded AD, is TCAC, as Hartzel did for Comanche 250 owners and Twin Commander owners, going to offer the sump at a one-time reduced price for compliance? Thank you, Richard Brown N108RG pawpaw(at)dallas.net ________________________________________________________________________________
Date: May 17, 2001
I sencond that!!! ----- Original Message ----- From: Chris Schuermann <chris(at)skymaster.c2-tech.com> To: Jeff Cousins ; Sent: Thursday, May 17, 2001 8:44 PM Subject: Re: Twin Commander Support of Your Airplane > > > > Jeff Cousins wrote: > > though you may not agree with the decision we reached concerning the > > fuels sumps I hope you can accept our commitment to supporting your > > aircraft. > > > Jeff, > First I would like to express my sincere appreciation at you taking > the time to explain TCAC's point of view on this topic as well as thank > you personally for jumping in to what has become a public forum filled > with great discussions on a broad range of topics. When I first > created this list, I did indeed have concerns about how it would be > taken by TCAC managment. It has been my strongest hope since inception > that > the very open dialog as well as expression of concerns would be of value > to all Commander enthusiasts as well as TCAC if accepted with an open > mind > and an ability to listen to both positive and negative feedback as of > potential value. > As a business owner myself, I can definitly empathize with how difficult > it can be to receive negative comments regarding an action that you > honestly believe was made in the customers best interests. I have > found (via the school of hard knocks) that keeping my customers > abreast of any issue which may negativly (or positivly) affect them > often > results in a much greater acceptance of any problems. > This sump issue is a great case and point - most of the frustration that > I've heard so far is primarily rooted in a lack of understanding. Given > the somewhat fragmented user base, most owners will only understand that > they've been presented with a solution to a problem they don't think > they > have unless dialog such as you just presented occurs. > > TCAC is to be applauded for taking the initiative to not only proactivly > address the problem, but also actually produce parts so that owners will > not be "stuck" when the paperwork hits. Your letter pointed out several > issues which I, for one, was not clear on such as the fact that without > TCACs intervention that this issue could have jumped straight to AD > status > without much warning. > > I hope that this is not the last time you decide to participate in such > a > valuable way to this list Jeff. Please consider the door open. I > believe > I speak for the majority of the members of this list when I say that > direct information is very much appreciated. As you noted, there WILL > be > disagreement with various actions and decisions from time to time, but I > think that most owners will be vastly more supportive if they truely > understand the facts that drive these actions. > > Chris Schuermann > > > ________________________________________________________________________________
Date: May 17, 2001
Subject: THANKS JEFF.
HI KIDS....... I wanted to ad my thanks to Jeff for his response. I know that his days are full and I appreciate him taking this time. It also reminds me of what I have said before, "They are listening" Many good ideas have already come from this forum and feel confident that a livable solution can be found. I look forward to meeting with Jeff and the Commander crew this coming week (I am moving back to my summer home in SEA on Monday, 15 min drive to the FAA office and a 15 min flight to TCAC). We all want the same thing here, to see Twin Commanders live on for many years, and to have enough $$ left over for gas. Thanks to all for your many great ideas. Next week will be a busy time. I will keep you posted. jb ________________________________________________________________________________
Date: May 17, 2001
The SB in questions has it been issued by the FED's or TCAC? ----- Original Message ----- From: YOURTCFG(at)aol.com To: Furlong5(at)aol.com ; woodlema(at)earthlink.net ; TCFG(at)listbot.com Sent: Thursday, May 17, 2001 12:09 PM Subject: Re: Sumps and my .02 worth. 1. Fill in the brief application 2. Receive approval decision within 30 seconds HI JIM..... This action started as a service letter (379) I reported this in the DEC FGN (remember, you heard it here first) It has now become a (mandatory) service bulletin, SB230A. This is the usual progression of an action unless the FAA feels there is immediate danger. From here, who knows?? It is my personal belief that it almost certainly will become an AD. I plan to meet with the TCAC and the FAA soon regarding this action. I have had a couple of contacts with Jeff Cousins at TCAC, and he also believes it will become an AD and Commander has already invested in an inventory of new parts in anticipation of this. There are several options open now. First, I will meet with the Feds and discuss the possibility of an optional means of compliance. As a group, we own or care for a large number of piston commanders and we may be able to use our "field experience" to defer the SB from becoming an AD. Next, we can lobby that the factory authorized inspection procedure should be adequate to comply. While I would agree that Magnesium is the wrong material to have made the sumps from, Most have lasted a long time and may still be serviceable. An inspection would determine this. Lastly, it has been mentioned that Hartzell offered a substantial discount to owners. This seems like a reasonable approach assuming the sumps really require replacement. I will propose this to TCAC when we meet. I want to say that I have checked with a few Commander Gurus and it is widely agreed that sump corrosion is a problem but no one has any hard data. I don't know how many replacement sumps TCAC has sold over the last 5 years, and there seems to be no information on the results of SL379. For sure, some airplanes have been found with unsafe sumps, others have been checked and no corrosion was found. If you have any sump history, please email me personally with that information. Thanks jb ________________________________________________________________________________
Date: May 17, 2001
From: AOPA ePilot Newsletter <aopa_news(at)aopa.org>
Subject: AOPA ePilot -- Vol. 3, Issue 20
AOPA ePilot--Vol. 3, Issue 20 Departments Inside AOPA On Capitol Hill Airport Support Network ASF News Quiz Me! 2001 Bonanza Sweepstakes ePilot Calendar Weekend Weather You can receive a 5-percent discount at Sportys Pilot Shop with the AOPA credit card and your valid AOPA member number. Click here to apply for the AOPA credit card. CAF grounds unit following fatal crash Murphy heavy-hauler makes maiden flight AOPA underscores need for real-time SUA data Shoot-down law must be repealed, says AOPA Volume 3, Issue 20 May 18, 2001 GA News AOPA LAUNCHES TV SPOTS TO SAVE MEIGS FIELD AOPA is launching an unusual airwaves campaign to save Chicago's Meigs Field airport. An AOPA-produced television commercial designed to convince Illinois state legislators and the public to keep Merrill C. Meigs Field open will begin airing this Sunday evening on TV stations in Springfield, the Illinois capitol. The timing is critical as the Illinois legislature adjourns next Friday. "At a time when the nation's attention has turned to airport capacity problems, particularly in Chicago, should a reliever airport like Meigs be closed?" asked AOPA President Phil Boyer. "Our 370,000 members want to draw attention to this issue that is so important to Illinois and the nation's air transportation system." Chicago Mayor Richard Daley intends to close Meigs Field in February 2002. AOPA is working for a solution that will keep the airport open and meet Daley's desire for more parks. In a recent independent survey, a majority of Chicago residents were in favor CAF GROUNDS UNIT FOLLOWING FATAL CRASH The Confederate Air Force has grounded one of its units following a fatal crash on Monday. CAF members Dan Secker, 61, and Neal Clifton, 54, died when their Vultee BT-13A military trainer crashed at Bates Field near Odessa, Texas. The NTSB and the FAA are investigating. The CAF board of directors voted to ground the High Sky Wing pending a review of the wing's operations and maintenance procedures. Exactly one month earlier on April 14, another aircraft assigned to the High Sky Wing, a Fairchild PT-19, crashed, killing CAF member Roy Green. The High Sky Wing has one remaining airplane in service, an AT-6/SNJ-4 Texan. The grounding does not affect other CAF units. For more, see the Web site. RACE CAR LEGEND TAKES ROBINSON R44 TO THE TRACK Legendary auto racer Bob Bondurant has found yet another use for the Robinson R44 helicopter. Bondurant will use the Raven to observe and photograph racing lines around corners for student drivers at the Bob Bondurant School of High Performance Driving in Phoenix. He bought the aircraft in partnership with professional helicopter pilot Barry Sprague. Bondurant became interested in helicopters and auto racing at about the same time in the early 1960s. For more on Robinson, see the Web site. MURPHY HEAVY-HAULER MAKES MAIDEN FLIGHT The Murphy SR3500 Super Rebel kitplane made its first flight recently. Based on the SR2500, it features a 1,759-pound useful load with a nine-cylinder M-14P radial engine. Switching to a lighter Lycoming IO-540 increases the useful load even more. At gross weight, the four- to six-place taildragger climbs at 1,400 feet per minute and cruises at 143 knots. Murphy Aircraft said fast-build kits are available for the all-metal airplane. For more, see the Web site. AIRSHOW PERFORMER GOES SOLO Former Northern Lights pilot Michael Mancuso will be performing alone this season in his Extra 300L. He is being sponsored by Klein Tools, a manufacturer of professional-grade hand tools and protective equipment. Mancuso left the competitive aerobatic arena in 1998 to join the Northern Lights aerobatic team. He was with the team until last year. The Northern Lights team will be flying L-39C Albatross jets instead of the Extra 300s for the 2001 season. Mancuso's next performance is at Air Expo 2001 at the Patuxent River Naval Air Station, Maryland, May 25 through 27. For a complete performance schedule, see the Web site. For daily news updates, see AOPA Online. Inside AOPA AOPA UNDERSCORES NEED FOR REAL-TIME SUA DATA Pilots need improved "real-time" information on special use airspace, AOPA told the FAA recently. In the agency's Operational Evolution Plan (a 10-year blueprint for improving safety, increasing capacity, and managing delays), the FAA calls for better coordination and more efficient utilization of special use airspace when not in use by the military. AOPA said the agency has to go further. AOPA wants the FAA to add controlling agency radio frequencies and telephone numbers to charts so that pilots can ask if the airspace is actually in use. AOPA also said that flight service stations and general aviation pilots should have access to special airspace management system (SAMS) scheduling data. As part of a test program with the FAA, AOPA members can currently access the SAMS database on AOPA Online. COURT OVERTURNS WINGS FIELD RESTRICTION A Pennsylvania court has overturned a 1998 state law that restricted which airports could receive federal and state funds. The law was targeted at just four airports and it singled out AOPA's birthplace, Wings Field, outside of Philadelphia. "This is a significant decision not only for Wings Field, but for other airports as well," said Phil Boyer, AOPA president. "Had this law remained on the books, it could have set a precedent in other states and given local agencies the power to interfere with the national air transportation system." For more, see AOPA Online. NEW SKYDIVING RULE NEEDS REPACKING, AOPA SAYS Last week the FAA issued final changes to FAR Part 105the regulations governing skydiving operations. The agency refused to address two issues raised by AOPA: the need for flight service notification (the FAA said that the requirement is implicit in the existing regulation) and the issue of a pilot's being held responsible for the actions of individuals not on board the pilot's aircraft. But the FAA did agree to eliminate the proposed accident-reporting requirements for pilots, stating that it did not have the resources to administer the program. See AOPA Online. FAA ISSUES NOTAM FOR AOPA FLY-IN The FAA has issued a notam for the eleventh annual AOPA Fly-In and Open House at Frederick Municipal Airport (FDK), Maryland, on Saturday, June 2. The notam includes special VFR arrival procedures and information on the temporary control tower that will be operating from 7 a.m. to 6 p.m. Reduced runway separation and simultaneous arrivals to intersecting runways will be in effect. Arrival/departure information and a map are available on AOPA Online. For a copy of the notam, see the Web site. Changing your mailing or e-mail addresses? Click here to update. On Capitol Hill SHOOT-DOWN LAW MUST BE REPEALED, SAYS AOPA AOPA is urging Congress to repeal the law brought to light in the shoot-down of an American missionary aircraft in Peru. In a letter to all members of the House, AOPA President Phil Boyer asked for support of House Bill 1818, which was introduced by Rep. Collin Peterson (D-Minn.), a pilot and AOPA member. That bill would prohibit employees and agents of the U.S. government from assisting foreign countries in interdiction of aircraft suspected of drug-related operations. For more, see AOPA Online. Airport Support Network ASN LOOKS FOR PILOTS TO SAVE NATION'S AIRPORTS What would you do if your airport closed tomorrow? Every day 915 AOPA Airport Support Network volunteers are working with AOPA headquarters on a local level to help save their airports. That's a lot, but not enough. Ask yourself these questions: Has my flying been affected by development, new restrictions, or negative public relations about my local airport? Have local issues or political pressures affected my use and the efficiency of my local airport? If the answer is "yes" to either question, you may be just the kind of person we're looking for to help ensure the health and availability of your airport. See your regional section under the calendar below for a list of airports that are particularly in need. To learn more about ASN, see AOPA Online. AOPA Air Safety Foundation News MINNESOTA LIFE DONATES $100,000 TO ASF Minnesota Life Insurance Company has marked the fiftieth anniversary of its relationship with AOPA by creating a $100,000 special endowment fund for the AOPA Air Safety Foundation. "The excellent partnership between AOPA and Minnesota Life is now enhanced with the addition of ASF programs," said Bruce Landsberg, ASF executive director. "It is in our collective best interest to continue to improve general aviation safety." For more, see AOPA Online. ASF RELEASES NEW COLLISION AVOIDANCE BOOKLET The AOPA Air Safety Foundation has released a new Safety Advisor to supplement its acclaimed collision avoidance seminar. The booklet can also serve as a self-study course. The new 16-page publication, Collision Avoidance: Strategies and Tactics, is illustrated with dramatic photographs and graphics. It includes concise information on the physiology of vision, points out when and where most midair collisions occur, and suggests techniques and resources for avoiding such accidents. Click to download it from AOPA Online. Quiz Me! Heres a question asked by an AOPA member last week of our AOPA technical specialists. Test your knowledge. Question: I'm a military pilot. Can I receive a civilian rating for my military experience? Answer: Under FAR 61.73, current and former military pilots may, depending on experience, receive: (1) a commercial pilot certificate; (2) an aircraft rating in the category and class of aircraft for which that military pilot is qualified; (3) an instrument rating with appropriate aircraft rating for which that pilot is qualified; or (4) a type rating, if appropriate. The pilot must present documentation showing compliance to an FAA flight standards district office in the pilot's area. The military pilot must pass a military competency knowledge test for the certificate or rating sought, and if not on active flight status within the past 12 months, pass a practical examination. See AOPA Online for a copy of the regulation. Got a technical question for AOPA specialists? Call 800/872-2672 or e-mail to inforequest(at)aopa.org. Send comments on our Quiz Me! questions to epilot(at)aopa.org. AOPA Sweepstakes Bonanza Update If you're not convinced yet that the AOPA 2001 Sweepstakes Bonanza is on the cutting edge of technology, try an oxygen system with computerized delivery. Thanks to Mountain High Equipment and Supply Company of Redmond, Oregon, the airplane will have a much safer and more efficient oxygen system for those high-speed, high-altitude cross-country sorties. For the latest project update, see AOPA Online. On The Road To Expo MACHADO TO OFFER FOUR SEMINARS AT AOPA EXPO Rod Machado, aviation humorist and columnist for AOPA Pilot, will conduct four seminars at AOPA Expo 2001 in Fort Lauderdale, Florida. The programs are titled Defensive Flying, Handling In-Flight Emergencies, Pilots, Poets, and PsychologistsHow Literature Can Help Us Make Better Cockpit Decisions, and Aviation HumorReducing Cockpit Stress by Developing Your Aviation Sense of Humor. For complete Expo information, see AOPA Online. What's New At AOPA Online If you know someone who hasn't yet experienced the wealth of information available in AOPA's Airport Directory Online, have them take a tour. It requires a Macromedia Flash browser plug-in. ePilot Calendar WEEKEND FLYING DESTINATIONS Pine Bluff, Arkansas. "Operation Skyhook," the Black Pilots of America Memorial Day Fly-In, takes place May 24 through 28 at Grider Field (PBF). Call 870/879-6612 for event information. Watsonville, California. Annual Fly-In and Airshow takes place at Watsonville Municipal Airport (WVI) May 25 through 27. Call 831/763-5600 for event information. Patuxent River Naval Air Station, Maryland. Air Expo 2001 takes place May 26 and 27. Call 301/757-3976 for event information. Brunswick, Georgia. The World Beechcraft Society Fly-In takes place May 31 through June 3 at Glynco Jetport (BQK). Call 800/345-9066 for event information. REGIONAL INFORMATION AND EVENTS ASN SEEKS VOLUNTEERS The AOPA Airport Support Network is looking for volunteers at several airports in California, including L45, BNG, BIH, CRQ, 2O6, O22, COM, and CEC. To sign up, see ( http://www.aopa.org/asn/ ). FLYING DESTINATIONS IN YOUR AREA CHICO, CALIFORNIA. "Wings to Victory," a tribute to the pilots and personnel of Chico Army Airfield, takes place May 23 at Chico Municipal Airport (CIC). Call 530/342-0651 for event information. LLANO, CALIFORNIA. The "World's Smallest Airshow" takes place May 26 and 17 at Brian Ranch Airport. Call 661/261-3216 for event information. SANTA MONICA, CALIFORNIA. The Museum of Flying at Santa Monica Municipal Airport (SMO) commemorates the sixtieth anniversary of the sinking of the German battleship Bismarck with a display of one of the few remaining Fairey Swordfish aircraft on May 27. Call 310/392-8822 for event information. AOPA PILOT TOWN MEETINGS Featuring AOPA President Phil Boyer (7:30 p.m.; admission is free). The next Pilot Town Meetings in California are in Sacramento June 5, Santa Rosa June 6, and Fresno June 7. For more information, see ( http://www.aopa.org/prez/ptmsked.html ). For more airport details, see AOPA's Airport Directory Online. For more events, see Aviation Calendar of Events ASF SAFETY SEMINARS The next AOPA ASF Safety Seminars are scheduled in Spruce Pine, North Carolina, May 19 and 20; Charlotte, North Carolina, and Baltimore May 21; Jamestown, North Carolina, May 22; and Raleigh, North Carolina, May 23. See AOPA Online for more information. ASF FLIGHT INSTRUCTOR REFRESHER CLINICS (All clinics start at 7:30 a.m.) The next AOPA Air Safety Foundation Flight Instructor Refresher Clinic is scheduled in Austin, Texas, June 2 and 3. For the Flight Instructor Refresher Clinic schedule, see AOPA Online. ASF PINCH-HITTER GROUND-SCHOOL COURSES (Pinch-Hitter courses start at 9:30 a.m.) The next Pinch-Hitter Ground School will take place June 10 in San Jose, California. For more Pinch-Hitter courses, see AOPA Online. For comments on calendar items or to make submissions, contact Julie S. Walker at julie.walker(at)aopa.org. Contacting ePilot Got news tips? Contact ePilot editor Nathan A. Ferguson at nate.ferguson(at)aopa.org. Having difficulty using this service? Visit the ePilot Frequently Asked Questions now at AOPA Online or write to epilot(at)aopa.org. You are currently subscribed as NAME-NICO VAN NIEKERK eMail Address-NICO(at)CYBERSUPERSTORE.COM. Changing your mailing or e-mail addresses? Click here to update. To UNSUBSCRIBE: Click here Unsubscribe, then hit the "Send" button. Do not include a message. To SUBSCRIBE: visit http://www.aopa.org/members/epilot.html. AOPA, 421 Aviation Way, Frederick, MD 21701 Tel: 800/USA-AOPA or 301/695-2000 Copyright 2001. Aircraft Owners and Pilots Association. Sponsors ________________________________________________________________________________
Date: May 17, 2001
Untitled StationeryAn open letter to Jeff Cousins. I am only a provisional member of TCAC waiting to see if it is worth renewal and do not represent TCFG or anyone else. I would like to propose the following approach to the sump problem. I hope both you and the other owners will consider it fair and equitable foer both sides. Mr. Cousins, As a successful businessman I can trace the origin of much of my sucess to customer service and product support. When my company makes a mistake regardless of the age we assume the responsibility for it as a corporation and replace the item or make the circumstances right. This is my (our) policy regardless of wheather it was our mistake or former management/owner. In the case of the sumps that obviously happened long before this current ieteration of TCAC you have inherited a responsibility to make it right and stand behind a product defect. Is this to say you should give every agrieved owner a new sump, in my opinion no. But neither should you profit from it. I would suggest the following approach. I woould say this was not "our" design and happened long before we came along but as the company now is ours and our personal honor and integrety is a stake we will do everything in our power to mitigate the costs. Whatever the cost of manufacturer will be your purchase cost.This of course should reflect real costs admin, s&h etc. TCAC will not take this opportunity to profit from a design flaw or mistake but nor should we to pay every cent of something that was done long before we owned the company or we would soon be out of business. This is what I as a owner and customer would consider fair. It's not the traditional "bend over and smile approach" of many GA manufacturers where SBs and ADs are considered profit centers. Charge what you want for innovations, improvements etc. If you take this opportunity to show us it's not "your daddies TCAC" then a new day will have dawned at TCAC and it will be safe to do business with you again. My sumps by the way are fine. I eagerly await your response. Best regards, Gary Pudaloff ----- Original Message ----- From: Jeff Cousins To: 'tcfg(at)listbot.com' Sent: Thursday, May 17, 2001 7:52 PM Subject: Twin Commander Support of Your Airplane 1. Fill in the brief application 2. Receive approval decision within 30 seconds As the new (6 month) General Manager of Twin Commander it has been educational (and certainly interesting) interacting with you, our customer, the Twin Commander Owner. It has been my goal since before moving to Arlington to see more dialog between TCFG and TCAC. I can refer you to Jim Metzger and the discussions we held last summer while I was visiting Seattle and getting the opportunity to see Puget Sound in his floatplane. The goal then and I believe in every meeting we've had since then has been to support your association as the type certificate holder for the Twin Commander models. We have made no attempt to drag out old issues, have not in any way entered into the discussions you have had concerning your organization or expressed opinions on you individually. Twin has responded when one of you has made a request for information that we could provide and are happy to continue doing so. I personally have referred two new owners to Jim for membership in TCFG which I believe falls under being judged by your actions. Twin wants very much to support TCFG and will continue to do so as long as it remains a productive relationship. I couldn't agree more with the observation that we should communicate with our customers. Four separate letters from me have been mailed either to specific groups of owners or to all owners of record since I arrived six months ago. The letters encouraged owners to contact me if you had concerns, (which several of you have) and have strived to inform you of Twin's programs. That included our plans for our website to provide you, the owner, with updated information on your aircraft. Some of those changes are in place and the rest are scheduled for completion in the next few weeks. If you are an owner and are not receiving these letters and Twin's SBs and other mailings please go to our website and register your current info including model and serial number to insure you are receiving all our communiqus. Twin Commander is the holder of the Type Certificates for the twin engined Commander aircraft. As such we are required to report any information we receive that has the possibility of affecting safety of flight to the FAA's Seattle Aircraft Certification Office within 24 hours. The reports we make invariably result in a request from the ACO to keep them appraised of our follow up investigation. The system of Service Letters, Service Bulletins, and Mandatory AD's (Which are issued by the FAA) works in the following way. Twin Commander can independently issue a Service Letter for issues we do not believe create an immediate threat to safety of flight. That was done with SL379 after the first reports of sump problems arose over two years ago. SL 379 required only a visual inspection for leaks and then a structural inspection to verify the integrity of the sump if leaks were found. As a result of reports from those inspections including one where the inspector was able to punch his finger through the side of the sump and another where the wall was corroded away and had been repaired with JB Weld it was determined that the non safety of flight status of a SL was not appropriate for this problem. Because Twin does not issue Service Bulletins without FAA review and because of the location of the sump in the fuselage, the extent of corrosion discovered, the past history of Aero Commander replacing the magnesium sumps in the earlier models, and the very significant consequences of having a 100 octane and associated vapor leak in a confined area with electrical contactors present it was decided to recommend replacing the sumps. The communication with the FAA culminated with a meeting with Mr. Mike Paison and Mrs. Della Reese in March of this year. At that time the status as an AD had not been made and was to be referred to the Small Aircraft Directorate in Kansas City for a final decision. It is Twin Commanders belief that these sumps should be replaced for your benefit, but the FAA, who is the only authority to require replacement via an AD has not yet reached that decision.Certainly the process was open to discussion thought SL 379, and SB 230A. The personnel involved in reaching the consensus are dedicated, professional engineers with years of Commander experience. They are under a great deal of pressure from owners, service centers, and the FAA to determine a solution for these situations. Another consequence of the recommendation to replace the sumps is that TCAC (Without an AD requiring replacement) has spent a year and a half, countless engineering and purchasing hours and significant dollars insuring that the components required will be available for this SB. The alternative to this process would be that no action was taken, the FAA would make a determination that the sumps should be replaced, issue an AD, and owners would find their aircraft grounded without replacement parts. We went through that scenario with lower spar caps in the early 90's and do not intend for it to happen again. The last issue I will try to address is the requirement for specifying by whom the work can be accomplished. Both SL 379 and SB 230A specify that any A&P mechanic may accomplish these items. Several years ago Twin Commander issued SB 218 on the later turbine models that called for significant modifications to the vertical and horizontal stabilizers. That SB required only an A&P for the work as had all our bulletins to that point. Over the next couple of years aircraft returned to Service Centers for other work were discovered to have spars in the horizontal stabilizers with holes drilled through them because of ignorance on the part of the people accomplishing the work. Twin (as well as other manufactures) have struggled with how to insure that complicated bulletins are accomplished by properly trained personnel. The current requirements for completing this type work is not that it be done by a service center but by someone who has attended the appropriate training at the Flight Safety/Twin Commander training center in Bethany, OK. I have listened with interest and pride as Commander owners have described their $100,000 plus piston Commanders that were purchased for prices as low as $10,000-$15,000. The appreciation of your investments would not have occurred if the only parts and engineering support available were used parts and field repairs. Jim Metzger has already addressed the value Twin Commander adds to your aircraft and though you may not agree with the decision we reached concerning the fuels sumps I hope you can accept our commitment to supporting your aircraft. Twin Commander depends heavily on our Service Center network for the technical information they provide, the countless days spent in support of the airframe, and the hundreds of years of collective experience their personnel represent. The Twin Commander Service Center Network is one of the greatest resources available to the Commander Owner and I heartily encourage you to utilize them. The team effort between Twin Commander and its Service Centers benefits you the Commander owner. Jeff Cousins Vice President/General Manager Twin Commander Aircraft Corporation Tel: 360-435-9797 Fax:360-435-1112 Cell:425-210-2907 Email: jcousins(at)twincommander.com ________________________________________________________________________________
Date: May 18, 2001
From: postmaster(at)mail3.9netway.com <postmaster(at)mail3.9netway.com>
Subject: MasterCD2001 Disc - E-BIZ Marketing Sources
Due to the many internet copyright pirates, and those who have copied and released our products without our permission or consent, we have a very, very special offer for you. The Ultimate Internet Marketing Tool, MasterCD2001, now updated with contacts representing 12 Million domains Worldwide! ***$99.95*** until May 23rd! OK, you held out at $999.00, at $799.00 and at $499.00, so here's a one time offer you can't refuse to get: MasterCD2001 for only $99.95. We've slashed the price to get you hooked on our data products. Unlimited usage is yours permanently for just $99.95! You can now access, import and export information about contacts for nearly 12 Million domain names worldwide. All of the domain owners have registered at least one .com, .net or .org domain name, which makes them serious prospects for Internet related business. Our newest database on CD-ROM contains the Names, Contact Information, Physical Address, SIC, Phone #, Fax #, URL (Domain Name), and Contact E-Mail Address which allows you to efficiently target companies Worldwide. Physical Addresses let you target businesses by, Country, State, City, Province, Zip Code, Telephone Area Code, numerous SIC codes and even Local Exchange Prefixes. The data is supplied in a delimited ASCII text format which makes it easy to link or import records into contact management, spreadsheet and all other database related applications. MasterCD2001 NOW ONLY $99.95(US) plus $20 shipping & handling for 2-Day UPS Air within the 48 contiguous United States, $40 shipping & handling otherwise, which includes non-contiguous US and Canada. We are currently shipping our April 2001 release. Complete the buyer and shipping info, print and fax this form with the completed credit card information. Updates are available quarterly for $99.95 each. This powerful marketing tool is a 100% tax-deductible business expense! Time is running out quickly, so don't delay. ORDER NOW! EVISION, USA Must Be Received by: May 23rd ORDER FORM IMPORTANT: To reduce potential order delays, please type your information if possible. If you cannot type your order, then please be sure your writing is legible. Orders are accepted by fax only, for maximum security. Orders will NOT be taken by e-mail or phone. Due to this incredibly discounted promotional price, we are accepting only credit card orders faxed to: *** 305-513-5094 *** Promotional Code: 518Q2C Please Send Me: MasterCD2001 for $99.95(US) plus $20 shipping & handling for 2-Day UPS Air within the contiguous US, $40 shipping & handling for International orders (includes Canada and non-contiguous US.) MasterCD2001 _______________$99.95 (plus shipping & handling) S&H Contiguous US __________$20.00_______ S&H Non-Contiguous US_______$40.00_______ Total________ No orders will be accepted without the above shipping and handling fee. I am entering the number of updates I wish to have automatically sent to me, following this one time offer and the "locked in price" of $99.95, plus the above shipping and handling charges, billed each quarter to my credit card only after it is shipped to me. YES_____ Automatically Ship [ ] updates at $99.95 plus the above S&H and bill my credit card at the time of shipping. NO THANK YOU ______ Do not ship any updates and bill my credit card one time only. Please note the required fields below: * = required Buyer/Shipping info: *Name: __________________________________________________________________ Company Name (if applicable): ___________________________________________ *Shipping Address: ______________________________________________________ *City: ______________________________________ *State/Province: ____________________________ *Postal Code: _______________________________ *Country: ___________________________________ *Telephone: _______________________________________________ *Fax: _____________________________________________________ *E-mail Address: __________________________________________ This e-mail address will not be used for ANY purpose other than communication from our company regarding your order. Without providing an e-mail address, you will not be able to track your order. Promotional Code: 518Q2C *Card Type-circle one: (MasterCard) (Visa) (Amex) (Discover) *Credit Card Number: ______________________________________ *Expiration Date: _________________________________________ *Signature: _______________________________________________ *Name as appears on Card: _________________________________ *Billing Address of Credit Card if different than shipping: ___________________________________________________________ City & Province/State & Postal Code: ___________________________________________________________ Fax & Email are the only forms of correspondence available due to the incredible pricing of this offer, so please be sure your email address is legible & accurate. EVISION Customer Service will be provided by E-mail or Fax only. Please fax the completed form to >> 305-513-5094 << Promotional Code: 518Q2C Evision, USA END ORDER FORM ###################################################################### This message is not intended for residents in the States of WA, NV, CA, TN, RI, NC & VA. Screening of addresses has been done to the best of our technical ability. If you wish to remove yourself from future communication, please reply with the word remove in the subject line. One time limited offer only. We reserve the right to revert to standard pricing after May 23rd. ................................................ ________________________________________________________________________________
Date: May 18, 2001
Subject: [Twin Bonanza addition to Flight Simulator 2000]
We need some flight simulators for our different model commanders guys ! ________________________________________________________________________________
Date: May 18, 2001
Subject: new E-mail address
Hi Gang, My new e-mail address is pawpaw1(at)starband.com Thanks Richard Brown N108RG ________________________________________________________________________________
Date: May 19, 2001
Subject: NO LUCK!
Keith, I haven't had any luck on making contact with either owner, yes, joint owners, of N1187D. The phone # that we received the other day was disconnected. I'm going to get creative and see what I can come up with. Any ideas from Commanderland? Live from Las Vegas, ( lost wages) Mike ________________________________________________________________________________
Date: May 20, 2001
Subject: Re: sump
I'D LIKE TO POINT SOMETHING OUT REGARDLESS OF THE FUTURE OF THIS SB. THE MANUFACTURER IS NOT ALLOWED TO ISSUE "MANDATORY" SBs.WITHOUT THE APPROVAL OF THE FAA. THEY KNOW THIS AND TO CONTINUE TO MISLEAD US. THIS IS DISHONEST AND THEY KNOW IT. I HAVE FORWARDED MY "MANDATORY" SB FROM TCAC TO THE FAA AND HAVE ASKED FOR CLARIFICATION. I'VE ALSO CONTACTED A AVIATION ATTORNEY TO SEE IF THIS CONSTITUTES FRAUD AND WHAT MY (OUR) RECOURSE IS. IT'S TIME FOR THIS PRACTICE TO STOP. I HAVE NOT CHECKED MY MAIL FOR SAT. I'M HOPING THEIR IS A NOTIFICATION FROM ED McMHON ABOUT MY WINNING 10 MILLION DOLLARS. I'LL LET YOU KNOW WHAT HAPPENS ON BOTH COUNTS. ----- Original Message ----- From: YOURTCFG(at)aol.com To: w.bow(at)att.net ; YOURTCFG(at)aol.com ; CloudCraft(at)aol.com Cc: tcfg(at)listbot.com Sent: Tuesday, May 15, 2001 3:22 PM Subject: Re: sump HI BILL........ First, there is no absolute guarantee that it will ever become an AD. Not all SBs make all the way up the food chain. However, I feel very strongly that this one will make for a couple of reasons including the fact that the FAA is pretty touchy about fuel related problems (flight 800). To answer your question regarding compliance, the SB requires that an inspection be performed on the sump and filter bodies for seepage prior to each flight. If seepage is found, they must (and I really mean MUST) be replaced before further flight. They are to be replaced within 100 hrs or at the next annual inspection. Guys, this is the real deal. These sumps really do fail and need to be taken seriously. The sumps should never have been produced from Magnesium but they were. The good news is that TCAC has tooled up and has the parts in stock to keep you flying. Jeff C. at Commander is checking now to see if only the sump can be changed or if the complete "kit" will be required. The way I read the SB is that all the parts will need to be changed. The sump only, is about $1400, the "kit" is About $2200, (- 10% from Aero Air) depending on the model. There are some "O" rings and gaskets, etc., that will need changed as well and I don't know how much labor will cost, but they probably wont jump out of the box and onto your airplane, so $3000 is probably not that far off. If you already have the sump off, It might pay to bolt a new one on, just to be sure?? I will contact John Bosch at Commander Aero today for his thoughts and let you know later. jb ________________________________________________________________________________
Date: May 20, 2001
Subject: sump
----- Original Message ----- From: garyloff To: YOURTCFG(at)aol.com ; w.bow(at)att.net ; CloudCraft(at)aol.com Cc: tcfg(at)listbot.com Sent: Sunday, May 20, 2001 6:49 AM Subject: Re: sump 1. Fill in the brief application 2. Receive approval decision within 30 seconds I'D LIKE TO POINT SOMETHING OUT REGARDLESS OF THE FUTURE OF THIS SB. THE MANUFACTURER IS NOT ALLOWED TO ISSUE "MANDATORY" SBs.WITHOUT THE APPROVAL OF THE FAA. THEY KNOW THIS AND TO CONTINUE TO MISLEAD US. THIS IS DISHONEST AND THEY KNOW IT. I HAVE FORWARDED MY "MANDATORY" SB FROM TCAC TO THE FAA AND HAVE ASKED FOR CLARIFICATION. I'VE ALSO CONTACTED A AVIATION ATTORNEY TO SEE IF THIS CONSTITUTES FRAUD AND WHAT MY (OUR) RECOURSE IS. IT'S TIME FOR THIS PRACTICE TO STOP. I HAVE NOT CHECKED MY MAIL FOR SAT. I'M HOPING THEIR IS A NOTIFICATION FROM ED McMHON ABOUT MY WINNING 10 MILLION DOLLARS. IT'S ALMOST AS VALID AS THE MANDATORY SBs. I'LL LET YOU KNOW WHAT HAPPENS ON BOTH COUNTS. ----- Original Message ----- From: YOURTCFG(at)aol.com To: w.bow(at)att.net ; YOURTCFG(at)aol.com ; CloudCraft(at)aol.com Cc: tcfg(at)listbot.com Sent: Tuesday, May 15, 2001 3:22 PM Subject: Re: sump HI BILL........ First, there is no absolute guarantee that it will ever become an AD. Not all SBs make all the way up the food chain. However, I feel very strongly that this one will make for a couple of reasons including the fact that the FAA is pretty touchy about fuel related problems (flight 800). To answer your question regarding compliance, the SB requires that an inspection be performed on the sump and filter bodies for seepage prior to each flight. If seepage is found, they must (and I really mean MUST) be replaced before further flight. They are to be replaced within 100 hrs or at the next annual inspection. Guys, this is the real deal. These sumps really do fail and need to be taken seriously. The sumps should never have been produced from Magnesium but they were. The good news is that TCAC has tooled up and has the parts in stock to keep you flying. Jeff C. at Commander is checking now to see if only the sump can be changed or if the complete "kit" will be required. The way I read the SB is that all the parts will need to be changed. The sump only, is about $1400, the "kit" is About $2200, (- 10% from Aero Air) depending on the model. There are some "O" rings and gaskets, etc., that will need changed as well and I don't know how much labor will cost, but they probably wont jump out of the box and onto your airplane, so $3000 is probably not that far off. If you already have the sump off, It might pay to bolt a new one on, just to be sure?? I will contact John Bosch at Commander Aero today for his thoughts and let you know later. jb ________________________________________________________________________________
Date: May 20, 2001
Subject: Re: sump
In a message dated 5/20/01 7:54:58 AM Pacific Daylight Time, n27kb(at)erols.com writes: > I'D LIKE TO POINT SOMETHING OUT REGARDLESS OF THE FUTURE OF THIS SB. THE > MANUFACTURER IS NOT ALLOWED TO ISSUE "MANDATORY" SBs.WITHOUT THE APPROVAL > OF THE FAA. THEY KNOW THIS AND TO CONTINUE TO MISLEAD US. THIS IS DISHONEST > AND THEY KNOW IT. HI GARY...... You are correct, the FAA must approve all SBs. This was done in this case. In an open letter to our group from Jeff Cousins, TCAC GM, he states "Twin does not issue Service Bulletins without FAA review" (5-17-01). Hope this helps to clarify jb ________________________________________________________________________________
Date: May 20, 2001
Subject: Re: sump
I called TCAC. After speaking with several individuals and a very long time on hold the answer I was given is the "FAA has reviewed the technical aspects of the SB". They said that approval was not sought only a review of the "technical aspects". I asked for some documentation from the FAA that granted them the authority to issue this "Mandatory SB" and at least the individuals I spoke with yesterday had no documentation to offer and none would state categorically that they had been directed to issue this SB. I only got the very strong indication that they are playing with words and semantics. If anyone can offer any documentation from the FAA granting this authority to TCAC regarding SB 230A before todays date I'd like to see it as it would go a long way in putting my mind at ease. Not that they shown it to them or that they are aware of it, have discussed and all the other phrases that TCAC threw at me about it but that the FAA has authorized, granted, directed TCAC to issue this MANDATORY SERVICE BULLETIN. I will offer my apologies in advance if the FAA has directed this SB. However I am sick to death of manufaturers issuing these Mandatory SBs on their own and then lobbying the authorities for the most extreme and thus most expensive fix. Profits down issue a Service Bulletin. G From: YOURTCFG(at)aol.com To: n27kb(at)erols.com ; TCFG(at)listbot.com Sent: Sunday, May 20, 2001 12:48 PM Subject: Re: Fw: sump 1. Fill in the brief application 2. Receive approval decision within 30 seconds In a message dated 5/20/01 7:54:58 AM Pacific Daylight Time, n27kb(at)erols.com writes: I'D LIKE TO POINT SOMETHING OUT REGARDLESS OF THE FUTURE OF THIS SB. THE MANUFACTURER IS NOT ALLOWED TO ISSUE "MANDATORY" SBs.WITHOUT THE APPROVAL OF THE FAA. THEY KNOW THIS AND TO CONTINUE TO MISLEAD US. THIS IS DISHONEST AND THEY KNOW IT. HI GARY...... You are correct, the FAA must approve all SBs. This was done in this case. In an open letter to our group from Jeff Cousins, TCAC GM, he states "Twin does not issue Service Bulletins without FAA review" (5-17-01). Hope this helps to clarify jb ________________________________________________________________________________
Date: May 20, 2001
From: CloudCraft(at)aol.com <CloudCraft(at)aol.com>
Subject: Motivation for SBs, ADs
In a message dated 5/20/01 10:51:58 AM Pacific Daylight Time, n27kb(at)erols.com writes: > I will offer my apologies in advance if the FAA has directed this SB. > However I am sick to death of manufaturers issuing these Mandatory SBs on > their own and then lobbying the authorities for the most extreme and thus > most expensive fix. Profits down issue a Service Bulletin. Gary, Group, Whether or not there is a profit motive, one thing is sure: There is the liability issue. This is not TCAC specific. In today's legal climate, you'll see OEMs of any airframe, avionic, gadget or gizmo issue a SB, and often go to the FAA for backing by convincing them there needs to be an AD, to limit their liability exposure. In the end, you're right. It's to protect the bottom line, but I don't think it's always about selling parts and drawing business to factory maintenance centers. Wing Commander Gordon ________________________________________________________________________________
Date: May 20, 2001
Subject: Odd Specimen again
Hi Guys, A little more on the mysterious N29DE. Originally 680T-76 serial no.1699 registered as N4638E. Later to Canada as C-FIIG, Flying Fireman Ltd. I have a reference to it as a 680V but this may have been after it left the factory. D E Monk ________________________________________________________________________________
Date: May 20, 2001
Subject: Oshkosh 2001
Anyone going in their Commander ? If so what date(s), etc. ? Maybe we can all park together ? I am planning on being there on July 22nd around noon. Staying until Thursday or Friday. Bought my RV-7 Empennage kit so I want to take the buildling classes and all. Paul ________________________________________________________________________________
Date: May 21, 2001
Subject: sump
----- Original Message ----- From: Richard Brown To: tcfg(at)listbot.com Sent: Sunday, May 20, 2001 5:04 PM Subject: sump If you have a problem with the fuel sump SB, quit gripping here. If you dont believe what TCAC says, file a suit and have your Lawyer grab the records. I, for one, am tired of hearing it. If you really feel this way, then fish or cut bait. Richard N108RG ________________________________________________________________________________
Date: May 21, 2001
From: Mark Woodley Earthlink <woodlema(at)earthlink.net>
Subject: Re: sump
Here is my 2 pennies. I called TCAC, and was told that my AC560, straight 560, was exempt from this SB. I spoke at lenght with one of their folks, not sure which one, but I think it was the one who initially recommended the SB in the first place. He told me when he had checked a couple commanders, he was able to puch his finger throught the bottom of one of the sumps, with no effort. The other was close to the same condition. Personally I am going to check my pumps, anyhow since I really don't want to swim in 150 gal of 100LL at 10,000 feet. Perhaps there is a business issue. Perhaps it is motivated to sell parts, perhaps it is motivated by the Lawsuit happy moron jurers in this country, and the ASSES that award mega-bucks to anyone who can convince them that someone else is to blame for their problem. I believe the latter. I would also like to point out 1 thing. How much support would you have for ANYcommander if some aviator filed suit against TCAC and won $100,000,000.00 putting them out of business. I can tell you in one word. NONE. As far as legal terms. TCAC will NOT be guilty of cuplable negilgence if they put out a mandatory SB, if the owner/operator fails to comply. This puts all liablilty on the owner operator for the safety of the aircraft concerning this particular part, and TCAC has fulfilled its fiduciary responsibility to the safety of the pilot, pilots family, others who may be injured by a falling plane and the business interests of not only TCAC, but any and all stock holders. Sorry if some don;t agree with me, but that is how I see it. I was not happy with the AD against the Hartzell props. It cost me a shade over $20,000.00 to fix it. It was necessary, and needed, after seeing the potential for blade seperation, and seeing the results of the inspetion of my old props. Even though they were within tolerances, they were just close enough I did not want to deal with it, hence NEW props. Mark Woodley AC560 Driver. ----- Original Message ----- From: Richard Brown To: tcfg(at)listbot.com Sent: Sunday, May 20, 2001 7:13 PM Subject: Fw: sump 1. Fill in the brief application 2. Receive approval decision within 30 seconds ----- Original Message ----- From: Richard Brown To: tcfg(at)listbot.com Sent: Sunday, May 20, 2001 5:04 PM Subject: sump If you have a problem with the fuel sump SB, quit gripping here. If you dont believe what TCAC says, file a suit and have your Lawyer grab the records. I, for one, am tired of hearing it. If you really feel this way, then fish or cut bait. Richard N108RG ________________________________________________________________________________
Date: May 21, 2001
Subject: sump
If you want a pointy nose You gotta pay the price. BIG AL ________________________________________________________________________________
Date: May 21, 2001
Subject: Re: sump
Amen, Brother Brown enough, already! Jimbo (not Jimbob) -----Original Message----- From: Richard Brown [mailto:pawpaw1(at)starband.net] Sent: Sunday, May 20, 2001 4:13 PM To: tcfg(at)listbot.com Subject: Fw: sump _____ 1. Fill in the brief application 2. Receive approval decision within 30 seconds _____ ----- Original Message ----- From: Richard Brown <mailto:pawpaw1(at)starband.net> To: tcfg(at)listbot.com Sent: Sunday, May 20, 2001 5:04 PM Subject: sump If you have a problem with the fuel sump SB, quit gripping here. If you dont believe what TCAC says, file a suit and have your Lawyer grab the records. I, for one, am tired of hearing it. If you really feel this way, then fish or cut bait. Richard N108RG _____ ________________________________________________________________________________
Date: May 21, 2001
From: nico(at)cybersuperstore.com <nico(at)cybersuperstore.com>
Subject: Re: TAKE A DEEP BREATH
Wise action, Cappie, go for it. We should negotiate before we litigate. I know people are PO'ed, but this is the time to demonstrate that we are different from insects. Nico -----Original Message----- From: YOURTCFG(at)aol.com <YOURTCFG(at)aol.com> To: TCFG(at)listbot.com Date: Monday, May 21, 2001 9:25 AM Subject: TAKE A DEEP BREATH 1. Fill in the brief application 2. Receive approval decision within 30 seconds HI KIDS....... I just wanted to ask everybody to "count to 10" and take a deep breath. As I have said, I will be meeting with the powers to be this week. Lets hear what they have to say. This is an important issue to those owners effected. Assuming a 1000 airplanes will need to be fixed, at a cost of about 5K each, this is a $5 million action against the fleet. Now, let me state that as your director I HAVE NO INTENTION OF ENTERING INTO A LAW SUIT OVER THIS, NONE. NOR WILL I ASSIST ANYONE IN DOING SO, PERIOD. As important as the issue is, it would accomplish nothing and almost certainly damage TCAC. They would have little choice but to raise the price of parts to recover their cost. Lets all see what the week brings. Anybody have any weekend "was stories" to share?? capt jimbob ________________________________________________________________________________
Date: May 21, 2001
thanks Nico..........jb ________________________________________________________________________________
Date: May 22, 2001
Hello all, I have been a little quiet of late, but feel that it is highly important to add my little bit from down here in Oz particularly surrounding the current sump stuff etc. As an inaugural member of this list I have been highly impressed by the levels of professionalism with which we have done our business and the potent exchange of information that has occurred since our inception last year. I salute all those regular contributors... Please keep the dream alive! Those of us here in Oz are incredibly strong supporters of the TCFG and all of its initiatives and see as it as performing an invaluable interface with TCAC. It is a high imperative for the future of our beloved Twin Commanders, that all of our lines of communication stay open. As remote as we are, there are a number of projects currently under way in Oz to preserve many piston and turbine Twin Commanders. Since the first 560E models arrived here in 1960 we have relied heavily on support from the greater ground swell of momentum that owners in the US have been able to exercise. As a group we must ensure that our core business; that is refining and implementing a productive interface with TCAC and the Service Centres is our highest priority. Over the past little while we here in Oz have found the ongoing support of the fleet a highly problematic issue. We continue to heavily rely on the vibrant network of Service Centres and support networks which only the US can provide. Believe me, with the right support there are potentially at least another 3, 4 or 5 long term restorations of bath tub and older piston models that are possible here. Every other week I fly into an airfield in the NT and gaze at 3 Turbine airframes which continue to rot away. As a group we must find better ways to get these airframes and their international equivalents back in the air! We must preserve and support the ongoing initiatives of the TCAC...there are ways to go about it. Lets continue to pull together and support Captain Jimbob in his efforts! Regards to all Russell ________________________________________________________________________________
Date: May 22, 2001
Subject: Lost my mind
HELP! Took good ole 108RG down to Alice TX today to visit a friend and conduct a little revenue producing deal (HOPE HOPE). While there, spied a C-47/DC-3 for sale. A real nice bird. Great appearance and Great interior. Then, I asked the owner what a plane like that was worth. (REAL BIG MISTAKE!!!) He said Oh! this ones for sale for X dollars. I said would you sell it for X dollars. Well, looks like I'm off to type rating school. (Big mistake #3, I bought it. The bright side? If the 500B breaks down, I can stick it in the back and haul it to the shop. If yall see me comming, DUCK! Richard Brown, 108RG ________________________________________________________________________________
Date: May 22, 2001
Subject: ON THE BOAT
HI KIDS.......... I just wanted to let everybody know that I have once again found gainful employment for the summer (giving tourist flights in a biplane on floats, hard work)! This means that I have moved onto our boat in downtown SEA. If you need to reach me by phone, the number is 206-675-1039. I will be on the boat Thursday through Sunday, Home the rest of the week. I check my messages from Washougal each day, so I will return calls from there as well, albeit a day late. I have made arrngments to swap newsletters and information with Dick Ward, the director of the "T" bone society. We share many of the same challenges and vendors so I think we can "gang up" on some issues. It has been a week since I last flew triple 2 and I miss her. I will be using the Commander to commute throughout the summer (a three hour drive becomes a 39 minute flight, past Mt St. Hellens, Mt. Rainier and Mt Hood) It will sure feel good to slide back into the left seat next week. I will be meeting with Jeff and the FAA this week and will let you know any news. have a great eve. jb ________________________________________________________________________________
Date: May 23, 2001
Subject: Re: Lost my mind
> Richard Brown wrote: > Well, looks like I'm off to type rating school. (Big mistake #3, I > bought it. WOW! That's just amazing! So, you gonna fly the thing to the TCFG flyin? Chris ________________________________________________________________________________
Date: May 23, 2001
Subject: mind
Yooo cann do it Rickeee; Congrat's on your purchase. BIG AL ________________________________________________________________________________
Date: May 23, 2001
Subject: Re: mind
Congratulations. I love to be nosey, how much was X, and a DC3 is one of the only planes I like as much as the Twin Commanders. There is a DC3 with the Turbine conversion not to far from where I work. I love to watch it come and go. Mark ----- Original Message ----- From: "Allen Reed" <allen_reed2(at)hotmail.com> To: Sent: Wednesday, May 23, 2001 10:17 AM Subject: mind > > > Yooo cann do it Rickeee; Congrat's on your purchase. BIG AL > > ________________________________________________________________________________
Date: May 23, 2001
Subject: When men were men
When men were men (and yes, the sheep were satisfied) we U.S. Forest Service Air Attack pilots flew AC-500s and AC-680Es. These kids nowadays fly Turbo Commanders! For Sir Barry's files, I spotted one N24GT, s/n 11254 in a hangar at Fresno, California. It was getting a complete avionics, or, rather Forest Service radio package, so watch for that Form 337. This is the second Turbo Commander configured as such. For my purposes, the thrill of flying a piston Commander over a blazing conflagration for 10 hours a day can't be replaced by the relative quiet and air-conditioned comfort of an AC-690A. On the other hand, we must salute the U.S. Forest Service's fine taste in aircraft; their contracts are written to nearly exclude any other make. (Sure, the occasional Skymaster sneaks in, but it's not by choice.) Wing Commander Gordon yearning for the good old days of smoke and oil streaked nacells ________________________________________________________________________________
Date: May 23, 2001
Subject: Thank you, Misc, and Sumps.
TCFG, Thank you for such a warm welcome. WingCommander Gordon, Yes I just recently left Aero-News.net to rejoin Garsite, LLC here in Kansas City. They are the largest builder of Aircraft refueler trucks in the country. www.garsite.com <http://www.garsite.com/> Pardon the commercial plug. I am now building a 30,000 BL fuel farm at the Flamingo Airport in Bonaire, N. A. (that is about 60 miles off the coast of Venezuela). The company has at Ted Smith Aerostar 602P 700 that I get to fly right seat on. We spend a lot of airline time, but that may change after this last trip. We can get there faster in the Aerostar. Yes, I still build the AVGAS self service pumps and tanks. I am also doing some consulting in Unleaded AVGAS replacement for 100LL. Sumps. I wandered into my local friendly airfreight company last Friday. Central Air at MCI Downtown Kansas City Airport. They are now running 38-500Bs. I asked about the sump situation there. The parts guy showed me two sumps that they have replaced. One was full of JB weld and goop with lots of cracks in it. The other looked ok from the outside until you looked inside of it. It was over 50% gone due to corrosion pitting on the inside. Paper thin in spots. We may scream about the cost, but there is a problem here. They can only be inspected from looking inside and that means draining the fuel system just to inspect it. Once you see it, you would not want to put it back in your airplane. Central Air is working on their own solution. I am not sure what. Do you want me to go take some photos of these sumps and send them to Chris to put in the web site??? Can you get a photo of the new style sump and post in on TCAC web site?? Or a drawing?? Any one going from the Mid West to the fly-in in Oregon that has an open seat?? Regards, Tylor Hall tylorh(at)sound.net 913-422-8869 ________________________________________________________________________________
Date: May 23, 2001
Subject: Re: Thank you, Misc, and Sumps.
In a message dated 5/23/01 9:39:56 AM Pacific Daylight Time, thall5(at)kc.rr.com writes: > Yes I just recently left Aero-News.net to rejoin Garsite, LLC here in Kansas > City. They are the largest builder of Aircraft refueler trucks in the > country. I know this guy who now owns a DC-3 that may need one of those trucks ... ;-) Wing Commander Gordon ________________________________________________________________________________
Date: May 23, 2001
Nico, I'll be working on my airplane tomorrow morning and Friday morning. Come on over. I have to get into the office. I work is Westlake Village at Verizon if you want to have lunch out there. Are you interested in going to Oshkosh with us ? Paul work 805.230.3502 nico wrote: > HI Paul,Yes, I live in Westlake Village and often have lunch at the > Waypoint. Didn't know that there was an AC on the 'port. I will > contact you maybe we could have lunch some time.ThanksNico(818) > 225-1913 (office)(818) 421-4089 (Mobile) > > -----Original Message----- > From: Paul Odum <calnet01(at)gte.net> > To: Nico van Niekerk > Date: Wednesday, May 23, 2001 8:03 AM > Subject: Re: Lost my mind > Nico, > > Are you locally based. I am at CMA also ! Come by sometime > or give me a call. I am looking to sell half my Aero > Commander 680E by the way. > > Paul Odum > 805.582.1848 Home > 805.230.3502 Work > > Nico van Niekerk wrote: > > > > > 1. Fill in the brief application > > 2. Receive approval decision within 30 seconds > > 3. Get rates as low as 2.99% Intro or 9.99% Ongoing APR > > Well good for you. You may even use it in a local chapter > > of the Confederate Air Force. Here in Camarillo there is > > one which seems to be in beautiful condition.Nico > > > > ----- Original Message ----- > > From: Richard Brown > > To: tcfg(at)listbot.com > > Sent: Tuesday, May 22, 2001 8:12 PM > > Subject: Lost my mind > > Twin Commander Flight Group - > > http://www.aerocommander.com > > > > ------------------------------------------------- > > 1. Fill in the brief application > > 2. Receive approval decision within 30 seconds > > 3. Get rates as low as 2.99% Intro or 9.99% > > ------------------------------------------------- > > HELP! Took good ole 108RG down to Alice TX today > > to visit a friend and conduct a little revenue > > producing deal (HOPE HOPE). While there, spied a > > C-47/DC-3 for sale. A real nice bird. Great > > appearance and Great interior. Then, I asked > > the owner what a plane like that was worth. > > (REAL BIG MISTAKE!!!) He said Oh! this ones > > for sale for X dollars. I said would you sell > > it for X dollars. Well, looks like I'm off to > > type rating school. (Big mistake #3, I bought > > it. The bright side? If the 500B breaks down, I > > can stick it in the back and haul it to the > > shop. If yall see me comming, DUCK! Richard > > Brown,108RG > > ------------------------------------------------- > > To unsubscribe, write to > > TCFG-unsubscribe(at)listbot.com > > > ________________________________________________________________________________
Date: May 23, 2001
I will stop by tomorrow morning. Where abouts are you, say relative to the Waypoint Cafe and what time? Nico ----- Original Message ----- From: Paul Odum To: nico Sent: Wednesday, May 23, 2001 6:12 PM Subject: Re: Lost my mind Nico, I'll be working on my airplane tomorrow morning and Friday morning. Come on over. I have to get into the office. I work is Westlake Village at Verizon if you want to have lunch out there. Are you interested in going to Oshkosh with us ? Paul work 805.230.3502 nico wrote: HI Paul,Yes, I live in Westlake Village and often have lunch at the Waypoint. Didn't know that there was an AC on the 'port. I will contact you maybe we could have lunch some time.ThanksNico(818) 225-1913 (office)(818) 421-4089 (Mobile) -----Original Message----- From: Paul Odum <calnet01(at)gte.net> To: Nico van Niekerk Date: Wednesday, May 23, 2001 8:03 AM Subject: Re: Lost my mind Nico, Are you locally based. I am at CMA also ! Come by sometime or give me a call. I am looking to sell half my Aero Commander 680E by the way. Paul Odum 805.582.1848 Home 805.230.3502 Work Nico van Niekerk wrote: 1. Fill in the brief application 2. Receive approval decision within 30 seconds Well good for you. You may even use it in a local chapter of the Confederate Air Force. Here in Camarillo there is one which seems to be in beautiful condition.Nico ----- Original Message ----- From: Richard Brown To: tcfg(at)listbot.com Sent: Tuesday, May 22, 2001 8:12 PM Subject: Lost my mind 1. Fill in the brief application 2. Receive approval decision within 30 seconds 3. Get rates as low as 2.99% Intro or 9.99% Ongoing APR and no annual fee! HELP! Took good ole 108RG down to Alice TX today to visit a friend and conduct a little revenue producing deal (HOPE HOPE). While there, spied a C-47/DC-3 for sale. A real nice bird. Great appearance and Great interior. Then, I asked the owner what a plane like that was worth. (REAL BIG MISTAKE!!!) He said Oh! this ones for sale for X dollars. I said would you sell it for X dollars. Well, looks like I'm off to type rating school. (Big mistake #3, I bought it. The bright side? If the 500B breaks down, I can stick it in the back and haul it to the shop. If yall see me comming, DUCK! Richard Brown,108RG ________________________________________________________________________________
Date: May 23, 2001
Nico, If you walk left out of the Waypoint and go down toward the wash rack you will see the Commander to the right of the wash rack. I'll be down there around 10:30 or 11:00. the wash rack is beside the Sheriff's helicopter area behind Camarillo Aircraft Service. I normally go to the gym in the morning and then go out to the airport. I have to do some cleaning on my engine nacelles tomorrow. Paul Nico van Niekerk wrote: > Paul,I will stop by tomorrow morning. Where about are you say from > the Waypoint Cafe and what time would be good?ThanksNico > > ----- Original Message ----- > From: Paul Odum > To: nico > Sent: Wednesday, May 23, 2001 6:12 PM > Subject: Re: Lost my mind > Nico, > > I'll be working on my airplane tomorrow morning and Friday > morning. Come on over. I have to get into the office. > > I work is Westlake Village at Verizon if you want to have > lunch out there. > > Are you interested in going to Oshkosh with us ? > > Paul > work 805.230.3502 > > nico wrote: > > > HI Paul,Yes, I live in Westlake Village and often have > > lunch at the Waypoint. Didn't know that there was an AC on > > the 'port. I will contact you maybe we could have lunch > > some time.ThanksNico(818) 225-1913 (office)(818) 421-4089 > > (Mobile) > > > > -----Original Message----- > > From: Paul Odum <calnet01(at)gte.net> > > To: Nico van Niekerk > > Date: Wednesday, May 23, 2001 8:03 AM > > Subject: Re: Lost my mind > > Nico, > > > > Are you locally based. I am at CMA also ! Come > > by sometime or give me a call. I am looking to > > sell half my Aero Commander 680E by the way. > > > > Paul Odum > > 805.582.1848 Home > > 805.230.3502 Work > > > > Nico van Niekerk wrote: > > > > > Twin Commander Flight Group - > > > http://www.aerocommander.com > > > > > > ------------------------------------------------ > > > 1. Fill in the brief application > > > 2. Receive approval decision within 30 seconds > > > 3. Get rates as low as 2.99% Intro or 9.99% > > > ------------------------------------------------ > > > Well good for you. You may even use it in a > > > local chapter of the Confederate Air Force. > > > Here in Camarillo there is one which seems to > > > be in beautiful condition.Nico > > > > > > ----- Original Message ----- > > > From: Richard Brown > > > To: tcfg(at)listbot.com > > > Sent: Tuesday, May 22, 2001 8:12 PM > > > Subject: Lost my mind > > > Twin Commander Flight Group - > > > http://www.aerocommander.com > > > > > > -------------------------------------- > > > Get a low APR NextCard Visa in 30 > > > seconds! > > > 1. Fill in the brief application > > > 2. Receive approval decision within > > > 30 seconds > > > 3. Get rates as low as 2.99% Intro or > > > http://www > > > bcentral.com/listbot/NextCard > > > -------------------------------------- > > > HELP! Took good ole 108RG down to > > > Alice TX today to visit a friend and > > > conduct a little revenue producing > > > deal (HOPE HOPE). While there, spied > > > a C-47/DC-3 for sale. A real nice > > > bird. Great appearance and Great > > > interior. Then, I asked the owner > > > what a plane like that was worth. > > > (REAL BIG MISTAKE!!!) He said Oh! > > > this ones for sale for X dollars. I > > > said would you sell it for X dollars. > > > Well, looks like I'm off to type > > > rating school. (Big mistake #3, I > > > bought it. The bright side? If the > > > 500B breaks down, I can stick it in > > > the back and haul it to the shop. If > > > yall see me comming, DUCK! Richard > > > Brown,108RG > > > -------------------------------------- > > > To unsubscribe, write to > > > TCFG-unsubscribe(at)listbot.com > > > > > > ------------------------------------------------ > > > To unsubscribe, write to > > > TCFG-unsubscribe(at)listbot.com > > ________________________________________________________________________________
Date: May 23, 2001
Subject: MEMBER IN THE NEWS
HI KIDS...... TCFG member Jack Lewis is in the news. "Lewis, who owns an Aero Commander (685), said he believes the museum ultimately aims to take over the parking on the South west corner of Boeing field..........." He is quoted in the MAY 11, 2001, ISSUE OF FLYER MAGAZINE. GO GET UM JACK!! JB ________________________________________________________________________________
Date: May 23, 2001
Subject: Re: lost my mind
Was wifes idea, said OOOOh! that looks nice. What is that? Look at all the room. I can take all the kids and my MOM on vacation together. (i had to make that sacrifice, darn). It really was here idea. I begged and pleaded with her not to make me buy it. She twisted my arm so hard. MOTHER IN LAW!! Oh well, life aint all gravey. Rich ----- Original Message ----- From: Milt Concannon To: Twin Commander Flightgroup Sent: Wednesday, May 23, 2001 1:19 PM Subject: lost my mind 1. Fill in the brief application 2. Receive approval decision within 30 seconds Man you have some thing that cahoneeeees! Has your wife divorced you yet? I wondered what would get us off the issue of sumps but you really didnt have to do anything that spectacular. With all that space you can just pickup everyone and take us to th flyin. ________________________________________________________________________________
Date: May 23, 2001
Subject: Big Bird
Some pics ________________________________________________________________________________
Date: May 23, 2001
Subject: Re: Big Bird
AWESOME!!!!!!! ----- Original Message ----- From: Richard Brown To: tcfg(at)listbot.com Sent: Wednesday, May 23, 2001 9:53 PM Subject: Big Bird Some pics ________________________________________________________________________________
Date: May 23, 2001
Subject: Big Bird
Richard, That's a fine looking wheel house! Congrats! You'll have a blast flying that. You can strap your Commander to the roof rack and have a run-about -- kind of like those people that tow a car behing their Winnebago. Have fun, Wing Commander Gordon ________________________________________________________________________________
Date: May 24, 2001
Subject: Re: What is this plane worth?
Yes If You dont buy please send me his Phone number Harry 321-267-3141 Nico van Niekerk wrote: > > 1. Fill in the brief application > 2. Receive approval decision within 30 seconds > 3. Get rates as low as 2.99% Intro or 9.99% Ongoing APR and no annual > fee! > Chief, I can get a 680FL with IGSO-540-B1A (380 HP) WITH L 208 / R > 588, props 27 Snew L & R. Total time 2,800! Interior and exterior > 10/10 Panel kit:New century 2000 auto pilot with altitude hold and pre > select. Coupled to GPS. > New Sandals digital RMI. > New Garmin GNS430 GPS, NAV, COM. > New Garmin 340 audio panal. > New JPIntenational engine monitoring system. > Shadin Digiflo fuel computer > 1 x King KDX 150 color radar. > 1 x King KY 97 com > 1 x King KT76A Transponder with mode c encoding altimeter. > 1 x King KN 52 Nav with glide slop. > 2 x King K___ digital A.D.FThe owner says that there is no need for > spar inspections or mods. Is this right on the 680FL? He wants about > $100K.Do you think this could be a good buy? An educated guess would > be appreciated.ThanksNico > > ________________________________________________________________________________
Date: May 24, 2001
Subject: Big Bird
Richard, What does it say across the top of the fuselage?? Is that a USMC paint job? What a great airplane. The photos show that someone has been hard at work. It looks great. Enjoy. Regards, Tylor Hall tylorh(at)sound.net 913-422-8869 ________________________________________________________________________________
Date: May 24, 2001
Subject: big bird
where is the picture of this thing? ________________________________________________________________________________
Date: May 24, 2001
From: AOPA ePilot Newsletter <aopa_news(at)aopa.org>
Subject: AOPA ePilot -- Vol. 3, Issue 21
AOPA ePilot--Vol. 3, Issue 21 Departments Inside AOPA On Capitol Hill Airport Support Network ASF News Quiz Me! 2001 Bonanza Sweepstakes ePilot Calendar Weekend Weather Polen Special to attempt world speed record Golden Knight to jump from 130,000 feet Italian company offers airplane to U.S. market AOPA fights for threatened airports Volume 3, Issue 21 May 25, 2001 GA News CESSNA LAYS OFF WORKERS AT PISTON-ENGINE PLANT Citing sluggish sales in a withering economy, Cessna Aircraft Company laid off nearly 30 percent of its workforce this week at the Independence, Kansas, facility where it makes piston-engine airplanes. Cessna cut 280 of the 1,000 jobs at the factory. "It's something we certainly didn't want to do," said Cessna spokeswoman Marilyn Richwine. Cessna was planning to build 1,100 airplanes this year but is now shooting for 900. Cessna noted a drop in sales after the first of the year as potential buyers became more sensitive about discretionary spending, she said. But the turbine market remains strong for both the Citation and Caravan lines. GOLDEN KNIGHT TO JUMP FROM 130,000 FEET The first female member of the U.S. Army's famed Golden Knights parachute team told The Washington Post that she will attempt next spring to jump from a balloon flying at 130,000 feet. If Army reservist Cheryl Stearns is successful, she will exceed the highest known jump to date of 102,000 feet by Air Force Capt. Joe Kittinger Jr. in 1960. Stearns, a member of the current Golden Knights team, is also a pilot for U.S. Airways. After jumping from a balloon that she will pilot, Stearns will accelerate to 695 knots, exceeding the sound barrier. Stearns told the newspaper that she hopes her efforts will help scientists design escape mechanisms for astronauts. POLEN SPECIAL TO ATTEMPT WORLD SPEED RECORD Dick Keyt, owner of the Polen Special aircraft designed and built by Dennis Polen, will attempt a world speed record in the single-seat tailwheel aircraft this summer at Oshkosh. Keyt said he is making the record attempt to honor Polen, who suffered a stroke following completion of the aircraft. Keyt will attempt the 500-kilometer (270-nautical-mile) closed course record for aircraft in the C-1.b category. He must exceed 285 mph (248 kt) to achieve the record. A Questair Venture aircraft set the current record. The sporty red Polen Special, powered by a 180-hp Lycoming O-360 engine, is expected to reach 260 kt in level flight. It is currently being modified and will use a Mattituck engine and a Hartzell propeller. ITALIAN COMPANY OFFERS AIRPLANE TO U.S. MARKET Tecnam Costruzioni Aeronautiche, located in Naples, Italy, is offering its two-passenger, 124-knot, all-metal high-wing P92-2000RG to the U.S. kitplane market. The fast-build kit will cost $32,100. Completed with a 100-hp Rotax 912ULS engine and cockpit instrumentation, the average aircraft will cost $45,000 to $55,000. The factory claims a build time of 350 hours for experienced builders. The aircraft features side-by-side seating and uses pneumatically retractable tricycle landing gear. There are thousands of older fixed-gear models of the aircraft flying worldwide. The aircraft can operate in the United States under the Experimental category. The aircraft is marketed in America by Pacific Aerosystem; telephone 800/844-1441 or 858/571-1441; e-mail. COMPANY BUYS ORBCOMM SATELLITE SYSTEM International Licensees LLC announced that it has bought all the business assets of Orbcomm Global LP, the world's first commercial low-Earth-orbit (LEO) satellite-based data and communications system. Orbcomm had been under Chapter 11 bankruptcy protection since last September. International Licensees is a consortium of Orbcomm licensees and other investors. Orbcomm contracts services to Echo Flight, which provides weather data and other services to light aircraft. Although it now appears that Echo Flight can look toward a more certain future, there was no interruption in service because of the bankruptcy. For daily news updates, see AOPA Online. Inside AOPA AOPA FIGHTS FOR THREATENED AIRPORTS AOPA and AOPA Airport Support Network volunteers are fighting developments and restrictions that threaten airports. AOPA is supporting local pilot groups and others who are resisting development proposals around airports that would violate laws, regulations, or agreements that prohibit incompatible land use with airport operations. Most recently, AOPA has lodged formal protests with local authorities considering housing and other development proposals close to airports at Kenosha, Wisconsin; Chico, California; and McCall, Idaho. See AOPA Online. AOPA JOINS CHICAGO TO CURB AIR TRAFFIC DELAYS The City of Chicago and FAA officials have asked AOPA to help them find solutions for regional airline delays. AOPA will join the 2001 Chicago Delay Task Force, a group of technical experts that will recommend solutions for reducing aircraft delays at O'Hare International Airport and its surrounding airspace. "We want to make sure that the solutions take general aviation into account," said AOPA President Phil Boyer. Over the weekend, U.S. Sen. Tom Harkin (D-Iowa) warned that Congress would intervene if Chicago didn't take action to reduce airline delays by July 1. Meanwhile, an AOPA-produced TV commercial is airing on Illinois TV stations, reminding politicians and the public that Meigs Field is part of the solution. TEXAS AIRPORT BILL IS CLOSE TO BECOMING LAW The Texas legislature is supporting the construction of a new general aviation airport in central Texas. The Senate this week approved House Bill 2522 and sent it back to the House for concurrence. The governor has said that he will sign the bill. The bill requires the state to build a new general aviation airport to replace facilities lost after the City of Austin closed downtown Austin-Mueller Airport. AOPA and the Texas Aviation Association lobbied extensively for the bill, and AOPA Airport Support Network volunteers helped rally Texas pilots to contact state legislators to push for the bill's passage. FULL RAMP SLATED FOR AOPA FLY-IN More than 50 aircraft are planned for the static display at the eleventh annual AOPA Fly-In and Open House on June 2 at AOPA headquarters in Frederick, Maryland. Fresh out of the avionics shop with a cutting-edge all-glass panel, the 2001 AOPA Sweepstakes Bonanza is scheduled for its first public display. See AOPA Online. Changing your mailing or e-mail addresses? Click here to update. On Capitol Hill DEMOCRATS REGAIN SENATE CONTROL Vermont Sen. Jim Jeffords announced Thursday that he is leaving the Republican Party to become an Independent. This decision gave Democrats control of the Senate for the first time since 1994. Pilot Tom Daschle of South Dakota is now the majority leader of the Senate. Sen. John McCain of Arizona must relinquish the chairmanship of the Senate Commerce Committee to user fee opponent Ernest Hollings of South Carolina. And AOPA member Ted Stevens of Alaska will no longer chair the powerful Senate Appropriations Committee. AOPA will continue to monitor the ramifications for general aviation. See AOPA Online. Airport Support Network VOLUNTEER OF THE WEEKDAVID FAILE JR. David Faile Jr. of Igor Sikorsky Memorial Airport (BDR) in Connecticut advised AOPA that he has been working to improve runway safety. He has created a multimedia presentation tailored to the unique characteristics of BDR. Faile and the local FAA FSDO manager will make a regional presentation at the New England Runway Safety Seminar this month. ASN SEEKS VOLUNTEERS What would you do if your airport closed tomorrow? The AOPA Airport Support Network is looking for volunteers at several airports in California, including DAG, 2Q3, L18, FAT, HAF, HMT, and 1O2. To learn more about the Airport Support Network, visit AOPA Online. AOPA Air Safety Foundation News STILL TIME TO APPLY FOR ASF SCHOLARSHIPS ExxonMobil Lubricants and Petroleum Specialties and the Koch Corporation are offering scholarships to mechanics and people in other aviation fields. The application deadline is July 31. For complete information and applications on scholarships administered by ASF, see AOPA Online. Quiz Me! Heres a question asked by an AOPA member last week of our AOPA technical specialists. Test your knowledge. Question: Are multifocal contact lenses approved by the FAA for pilot medical certification? Answer: No, according to the Guide for Aviation Medical Examiners. The guide states, "Contact lenses that correct near vision acuity only or that are bifocal or monofocal, are not considered acceptable for aviation duties. Similarly, the use of a contact lens in one eye for distant visual acuity and a lens in the other eye for near visual acuity (monovision) is not acceptable." For more, see AOPA Online. Got a technical question for AOPA specialists? Call 800/872-2672 or e-mail to inforequest(at)aopa.org. Send comments on our Quiz Me! questions to epilot(at)aopa.org. AOPA Sweepstakes Bonanza Update It's amazing what a sloped windshield can do for an old Bonanza's appearance. See what this mod has done for the 2001 AOPA Sweepstakes Bonanza in our latest project update. See AOPA Online. What's New At AOPA Online A new medical report is available on AOPA Online about FAA certification for pilots with the human immunodeficiency virus (HIV) and related conditions. See AOPA Online. On The Road To Expo Richard Jarvis of Haverhill, Massachusetts, flew 2,248.5 miles to Long Beach, California, to attend an event last year. What would make him do that? AOPA Expo. Jarvis picked up the award for the pilot who flew the farthest in a general aviation aircraft. See why AOPA Expo 2001 will be even better in Fort Lauderdale, Florida, on AOPA Online. ePilot Calendar
April 29, 2001 - May 25, 2001
Commander-Archive.digest.vol-aa
