Commander-Archive.digest.vol-bg
May 10, 2004 - July 28, 2004
      last replaced in 1993.  If the center bladder was to start a leak where
      would it first become visible?  in the headliner, baggage compt., wing
      roots?  Although there are no visible signs of a leak it seems that there is
      a faint gasoline smell in the baggage compartment when I first open the
      door.
      > Any suggestions from an experienced person will be greatly appreciated.
      > Moe
      > N680RR
      > 680F(p)
Subject: FUEL BLADDERS
Date: May 10, 2004
Hi Moe, In our 500B, gasoline smell in the baggage compartment is the rule rather than the exception. Jimmy N107VC -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com]On Behalf Of Moe Subject: Commander-List: FUEL BLADDERS Fellow Commander Drivers, On my 680f(p) we have replaced all four fuel bladders in the right wing and all four bladders in the left wing, however the large center bladder was last replaced in 1993. If the center bladder was to start a leak where would it first become visible? in the headliner, baggage compt., wing roots? Although there are no visible signs of a leak it seems that there is a faint gasoline smell in the baggage compartment when I first open the door. Any suggestions from an experienced person will be greatly appreciated. Moe N680RR 680F(p) ________________________________________________________________________________
From: "Tom Fisher" <tfisher(at)commandergroup.bc.ca>
Subject: Re: FUEL BLADDERS
Date: May 10, 2004
Me too. Tom F. ----- Original Message ----- From: "Jimmy Rodriguez" <jimmyr(at)popsecs.com> Subject: RE: Commander-List: FUEL BLADDERS > > Hi Moe, > > In our 500B, gasoline smell in the baggage compartment is the rule rather > than the exception. > > Jimmy > N107VC > > -----Original Message----- > From: owner-commander-list-server(at)matronics.com > [mailto:owner-commander-list-server(at)matronics.com]On Behalf Of Moe > To: COMMANDER-LIST(at)matronics.com > Subject: Commander-List: FUEL BLADDERS > > > Fellow Commander Drivers, > > On my 680f(p) we have replaced all four fuel bladders in the right wing and > all four bladders in the left wing, however the large center bladder was > last replaced in 1993. If the center bladder was to start a leak where > would it first become visible? in the headliner, baggage compt., wing > roots? Although there are no visible signs of a leak it seems that there is > a faint gasoline smell in the baggage compartment when I first open the > door. > > Any suggestions from an experienced person will be greatly appreciated. > > Moe > N680RR > 680F(p) > > ________________________________________________________________________________
Date: May 10, 2004
You should be able to spot the stain from the fuel. You might look back behind the curtain, by the radio rack. Mine was the sump but we won't go there AGAIN :>( bilbo ----- Original Message ----- From: "Moe" <moe(at)rosspistons.com> Subject: Commander-List: FUEL BLADDERS > > Fellow Commander Drivers, > > On my 680f(p) we have replaced all four fuel bladders in the right wing and all four bladders in the left wing, however the large center bladder was last replaced in 1993. If the center bladder was to start a leak where would it first become visible? in the headliner, baggage compt., wing roots? Although there are no visible signs of a leak it seems that there is a faint gasoline smell in the baggage compartment when I first open the door. > > Any suggestions from an experienced person will be greatly appreciated. > > Moe > N680RR > 680F(p) > > ________________________________________________________________________________
Date: May 10, 2004
In a message dated 10-May-04 10:11:12 Pacific Daylight Time, moe(at)rosspistons.com writes: > Although there are no visible signs of a leak it seems that there is a > faint gasoline smell in the baggage compartment when I first open the door. > Moe, The center tank, as you know, sits above the baggage compartment ceiling. Depending on your baggage area interior and trim, the fuel sump drain assembly may be "boxed" as a small protrusion below the ceiling of the baggage area. The faint smell of gas is part of the charm of a Commander. I swear you could blind fold any Commander pilot and place him in a variety of aircraft and he'll know when he's in a Commander. It's the combined scent of Avgas and 5606. A wet baggage area is probably going to be your first tip-off. Wing root leaks have always been from wing tanks, in my experience, but I admit to only one center tank leak vs. many wing tank leaks. Wing Commander Gordon ________________________________________________________________________________
Date: May 10, 2004
I forgot about the "box" I have never put mine back on since the great sump battle. I can see mine easily. I think you are right Commander Gordon. It is the Commander smell. bilbo ----- Original Message ----- From: <CloudCraft(at)aol.com> Subject: Re: Commander-List: FUEL BLADDERS > > In a message dated 10-May-04 10:11:12 Pacific Daylight Time, > moe(at)rosspistons.com writes: > > > Although there are no visible signs of a leak it seems that there is a > > faint gasoline smell in the baggage compartment when I first open the door. > > > > Moe, > > The center tank, as you know, sits above the baggage compartment ceiling. > Depending on your baggage area interior and trim, the fuel sump drain assembly > may be "boxed" as a small protrusion below the ceiling of the baggage area. > > The faint smell of gas is part of the charm of a Commander. I swear you > could blind fold any Commander pilot and place him in a variety of aircraft and > he'll know when he's in a Commander. It's the combined scent of Avgas and 5606. > > A wet baggage area is probably going to be your first tip-off. Wing root > leaks have always been from wing tanks, in my experience, but I admit to only one > center tank leak vs. many wing tank leaks. > > Wing Commander Gordon > > ________________________________________________________________________________
Date: May 11, 2004
Dear Commander Drivers, Thanks for the good advice on the center bladder. After replacing the other eight bladders, which were of varying age, I have decided not to replace the center bladder at this time as it has no apparent leaks and was replaced new (according to the log books and receipts that came from the previous owner) in 1993. The requested information about where leaks would appear if the center bladder started a leak was for future reference. As a point of reference, about how long should a new bladder last? Best regards. Moe N680RR 680F(p) ----- Original Message ----- From: <CloudCraft(at)aol.com> Subject: Re: Commander-List: FUEL BLADDERS > > In a message dated 10-May-04 10:11:12 Pacific Daylight Time, > moe(at)rosspistons.com writes: > > > Although there are no visible signs of a leak it seems that there is a > > faint gasoline smell in the baggage compartment when I first open the door. > > > > Moe, > > The center tank, as you know, sits above the baggage compartment ceiling. > Depending on your baggage area interior and trim, the fuel sump drain assembly > may be "boxed" as a small protrusion below the ceiling of the baggage area. > > The faint smell of gas is part of the charm of a Commander. I swear you > could blind fold any Commander pilot and place him in a variety of aircraft and > he'll know when he's in a Commander. It's the combined scent of Avgas and 5606. > > A wet baggage area is probably going to be your first tip-off. Wing root > leaks have always been from wing tanks, in my experience, but I admit to only one > center tank leak vs. many wing tank leaks. > > Wing Commander Gordon > > ________________________________________________________________________________
Date: May 11, 2004
Moe, We recently replaced the cells on the right wing. They were 1978 vintage. The left wing (same vintage) is still holding up. Jimmy N107VC -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com]On Behalf Of Moe Subject: Re: Commander-List: FUEL BLADDERS Dear Commander Drivers, Thanks for the good advice on the center bladder. After replacing the other eight bladders, which were of varying age, I have decided not to replace the center bladder at this time as it has no apparent leaks and was replaced new (according to the log books and receipts that came from the previous owner) in 1993. The requested information about where leaks would appear if the center bladder started a leak was for future reference. As a point of reference, about how long should a new bladder last? Best regards. Moe N680RR 680F(p) ----- Original Message ----- From: <CloudCraft(at)aol.com> Subject: Re: Commander-List: FUEL BLADDERS > > In a message dated 10-May-04 10:11:12 Pacific Daylight Time, > moe(at)rosspistons.com writes: > > > Although there are no visible signs of a leak it seems that there is a > > faint gasoline smell in the baggage compartment when I first open the door. > > > > Moe, > > The center tank, as you know, sits above the baggage compartment ceiling. > Depending on your baggage area interior and trim, the fuel sump drain assembly > may be "boxed" as a small protrusion below the ceiling of the baggage area. > > The faint smell of gas is part of the charm of a Commander. I swear you > could blind fold any Commander pilot and place him in a variety of aircraft and > he'll know when he's in a Commander. It's the combined scent of Avgas and 5606. > > A wet baggage area is probably going to be your first tip-off. Wing root > leaks have always been from wing tanks, in my experience, but I admit to only one > center tank leak vs. many wing tank leaks. > > Wing Commander Gordon > > ________________________________________________________________________________
Subject: RE: baggage compartment
Date: May 11, 2004
My 500B has a faint smell of gasoline, especially in the baggage compartment also. Even though I've had the sump apart and no apparent leakage, it is still there. However, I did notice the smell increased slightly when one of my wing tanks started leaking. That and the big blue stain on the fuselage under the wing tipped me off. Scott N222LE ________________________________________________________________________________
Date: May 11, 2004
I took my center tank out last year and had it checked and rejuvenated. It is I believe 44 years old. The main thing you want to do is keep the tanks full so they do not dry out. Jim A N444BD ________________________________________________________________________________
From: "Jody and Susan Pillatzki" <jpillatzki(at)702com.net>
Date: May 11, 2004
Just replaced my bladders in 411VV. 1951 , 1952 were the dates of manufacture stamped on the bladders. Only one of five had been redone and that one was rebuilt in the 70's. Jody ----- Original Message ----- From: "Jimmy Rodriguez" <jimmyr(at)popsecs.com> Subject: RE: Commander-List: FUEL BLADDERS > > Moe, > > We recently replaced the cells on the right wing. They were 1978 vintage. > The left wing (same vintage) is still holding up. > > Jimmy > N107VC > > -----Original Message----- > From: owner-commander-list-server(at)matronics.com > [mailto:owner-commander-list-server(at)matronics.com]On Behalf Of Moe > To: commander-list(at)matronics.com > Subject: Re: Commander-List: FUEL BLADDERS > > > Dear Commander Drivers, > > Thanks for the good advice on the center bladder. After replacing the other > eight bladders, which were of varying age, I have decided not to replace the > center bladder at this time as it has no apparent leaks and was replaced new > (according to the log books and receipts that came from the previous owner) > in 1993. > > The requested information about where leaks would appear if the center > bladder started a leak was for future reference. > > As a point of reference, about how long should a new bladder last? > > Best regards. > > Moe > N680RR > 680F(p) > ----- Original Message ----- > From: <CloudCraft(at)aol.com> > To: > Subject: Re: Commander-List: FUEL BLADDERS > > > > > > In a message dated 10-May-04 10:11:12 Pacific Daylight Time, > > moe(at)rosspistons.com writes: > > > > > Although there are no visible signs of a leak it seems that there is a > > > faint gasoline smell in the baggage compartment when I first open the > door. > > > > > > > Moe, > > > > The center tank, as you know, sits above the baggage compartment ceiling. > > Depending on your baggage area interior and trim, the fuel sump drain > assembly > > may be "boxed" as a small protrusion below the ceiling of the baggage > area. > > > > The faint smell of gas is part of the charm of a Commander. I swear you > > could blind fold any Commander pilot and place him in a variety of > aircraft and > > he'll know when he's in a Commander. It's the combined scent of Avgas and > 5606. > > > > A wet baggage area is probably going to be your first tip-off. Wing root > > leaks have always been from wing tanks, in my experience, but I admit to > only one > > center tank leak vs. many wing tank leaks. > > > > Wing Commander Gordon > > > > > > ________________________________________________________________________________
Date: May 11, 2004
Subject: Quotes page?
From: "Deneal Schilmeister (iMac)" <deneals(at)sbcglobal.net>
On 5/10/04 17:57, "CloudCraft(at)aol.com" wrote: > The faint smell of gas is part of the charm of a Commander. I swear you > could blind fold any Commander pilot and place him in a variety of aircraft > and > he'll know when he's in a Commander. It's the combined scent of Avgas and > 5606. If there were a "quotes page" for the Commander list, the above statement should be on it! -- Deneal Schilmeister ATP Learjet St. Louis, Missouri USA http://homepage.mac.com/deneals ________________________________________________________________________________
From: "Barry Collman" <barry.collman@air-britain.co.uk>
Subject: Re: Quotes page?
Date: May 11, 2004
All of Wing Commander Gordon's postings should be on a "quotes page"!! BC (UK) ----- Original Message ----- From: "Deneal Schilmeister (iMac)" <deneals(at)sbcglobal.net> Subject: Commander-List: Quotes page? | | On 5/10/04 17:57, "CloudCraft(at)aol.com" wrote: | | > The faint smell of gas is part of the charm of a Commander. I swear you | > could blind fold any Commander pilot and place him in a variety of aircraft | > and | > he'll know when he's in a Commander. It's the combined scent of Avgas and | > 5606. | | If there were a "quotes page" for the Commander list, the above statement | should be on it! | | | -- | Deneal Schilmeister ATP Learjet | St. Louis, Missouri USA | | http://homepage.mac.com/deneals | | | | | | | ________________________________________________________________________________
Date: May 11, 2004
I couldn't resist, now that you guys are talking about the perceptiveness of a Commander pilot. When the first VW bug came out, there were many quotables for that (what we called an excuse for an automobile) car. This one was particularly popular: This guy was a car fanatic and he could tell you blindfolded everything abou a car just by hearing it being started. Playing a trick on him, his buddies took him to a toilet, the kind with the overhead cistern and chain, and flushed it. He thought for a while and said it was a '57 VW Bug with a bad misfire. Nico ----- Original Message ----- From: "Deneal Schilmeister (iMac)" <deneals(at)sbcglobal.net> Subject: Commander-List: Quotes page? > > On 5/10/04 17:57, "CloudCraft(at)aol.com" wrote: > > > The faint smell of gas is part of the charm of a Commander. I swear you > > could blind fold any Commander pilot and place him in a variety of aircraft > > and > > he'll know when he's in a Commander. It's the combined scent of Avgas and > > 5606. > > If there were a "quotes page" for the Commander list, the above statement > should be on it! > > > -- > Deneal Schilmeister ATP Learjet > St. Louis, Missouri USA > > http://homepage.mac.com/deneals > > ________________________________________________________________________________
Date: May 11, 2004
Subject: NUTHER NICE TRIP
HI KIDS. I just got back from my Mothersday trip in triple 2. It was a great ride. Went over at 15.5 (29 X 2550) and 205kts, returned at 9.5 (31.5 X 2550) 171kts (must have had a tailwind both ways??) that is 188kts two way average!! Pretty good for an airplane almost as old as me. The weather was interesting, but the outcome was never in doubt. We were on top most of the way both directions. The new engine is spectacular. Nether engine used any oil on the trip and the new engine didn't even leak any, Yippee!! jb ________________________________________________________________________________
Date: May 11, 2004
> When the first VW bug came out, there were many quotables for that (what we > called an excuse for an automobile) car. My favorite was in Mad Magazine. It had a picture of a Bug floating in water and the caption read. "Had Ted Kennedy had one of these, he would be president today" From the right bilbo > ----- Original Message ----- > From: "Deneal Schilmeister (iMac)" <deneals(at)sbcglobal.net> > To: > Subject: Commander-List: Quotes page? > > > > > > > On 5/10/04 17:57, "CloudCraft(at)aol.com" wrote: > > > > > The faint smell of gas is part of the charm of a Commander. I swear you > > > could blind fold any Commander pilot and place him in a variety of > aircraft > > > and > > > he'll know when he's in a Commander. It's the combined scent of Avgas > and > > > 5606. > > > > If there were a "quotes page" for the Commander list, the above statement > > should be on it! > > > > > > -- > > Deneal Schilmeister ATP Learjet > > St. Louis, Missouri USA > > > > http://homepage.mac.com/deneals > > > > > > ________________________________________________________________________________
Date: May 11, 2004
I have one question about the "keep them full" philosophy. I can understand the inside of the bladder being effected by the fuel, but how does the outside of the bladder know not to crack? bilbo ----- Original Message ----- From: "Jim Addington" <jtaddington(at)charter.net> Subject: RE: Commander-List: FUEL BLADDERS > > I took my center tank out last year and had it checked and rejuvenated. It > is I believe 44 years old. The main thing you want to do is keep the tanks > full so they do not dry out. > > Jim A > N444BD > > ________________________________________________________________________________
Date: May 11, 2004
Great question, must be the baby powder. Also where can you get hold of a inexpensive high volume fuel pump and six empty drums so that I can unload ----- Original Message ----- From: "Bill Bow" <bowing74(at)earthlink.net> Subject: Re: Commander-List: FUEL BLADDERS > > I have one question about the "keep them full" philosophy. I can understand > the inside of the bladder being effected by the fuel, but how does the > outside of the bladder know not to crack? > > bilbo > ----- Original Message ----- > From: "Jim Addington" <jtaddington(at)charter.net> > To: > Subject: RE: Commander-List: FUEL BLADDERS > > > > > > > I took my center tank out last year and had it checked and rejuvenated. It > > is I believe 44 years old. The main thing you want to do is keep the tanks > > full so they do not dry out. > > > > Jim A > > N444BD > > > > > > ________________________________________________________________________________
Date: May 11, 2004
In a message dated 5/11/2004 2:34:48 PM Pacific Standard Time, bowing74(at)earthlink.net writes: I have one question about the "keep them full" philosophy. I can understand the inside of the bladder being effected by the fuel, but how does the outside of the bladder know not to crack? The outside of the cell is coated with a lacquer like material that protects it from Ozone and the elements (remember the article in the last FGN about fuel cells??) The inside cannot be coated, so, we must keep them wet. jb ________________________________________________________________________________
Date: May 11, 2004
Bill Bow wrote: > > I have one question about the "keep them full" philosophy. I can understand > the inside of the bladder being effected by the fuel, but how does the > outside of the bladder know not to crack? bilbo, My understanding of the chemistry is that it's the same thing that happens with most rubbers and plastics - hydrocarbons tend to react with the plasticizers which are used to keep the rubber compounds flexible and sealed. As long as the tanks stay "wet", the plasticizers stay rubbery, but if allowed to dry out after this reaction has taken place, they harden, shrink, and begin leaching from the rubber and cloth. chris ________________________________________________________________________________
Subject: New Commander Pilot with Questions
Date: May 11, 2004
I've just recently started flying an Aero Commander 680 FLP for a company in Ft. Walton Beach, FL. I suspect many of the people on your web site have years of experience with this machine. Sooo...I have a few questions. 1. When the plane is in the hangar, any fuel in the right aux tank will drain into the center tank in a short time. This occurs even if the fuel selector is set to "OFF". It even occurs in flight in that the right aux tank is used up faster than the left with the engines at approximately the same gph fuel burn. Any thoughts on why this is happening. 2. The pressurization system only gets about 2,000' differential at 10,000 ft altitude. The cabin has been checked for leaks and none of any consequence were found. The door seal is new and the seal pump seems to be working. If I just climb, say, to 15,000' will just the fact that the turbos will be putting out more pressure cause the differential altitude to increase beyond more than 2,000'. Right now there's no real benefit to having the pressurization as it doesn't work good enough. This airplane has the Mr. RPM engine conversion to the IO-720 Lycoming. Thanks, Ray Mansfield hcourier(at)cox.net ________________________________________________________________________________
Date: May 11, 2004
Subject: Re: New Commander Pilot with Questions
In a message dated 11-May-04 19:13:08 Pacific Daylight Time, hcourier(at)cox.net writes: > 2. The pressurization system only gets about 2,000' differential at > 10,000 ft altitude. The cabin has been checked for leaks and none > of any consequence were found. Hello Ray, What is your tail number and serial number? Sir Barry Collman, Aero Commander Historian, needs to keep the chain of ownership updated. As to your pressurization troubles, if you've checked the door seal, emergency exit seal, window seals, control column seal and rudder peddal seals, you need to check the ducts and clamps coming off the pressurization manifolds. Don't overlook any of the ducting along the way from turbos to cabin. Also, check to make sure that the inspection / access plates under the carpet in the cabin are sealed. The next most troublesome leak area would be the wing roots, which will require dropping the headliner. You need to run fairly high RPMs on the Mr. RPM conversions because you're sharing the turbo output with the engines. More mass flow = more air for the engine and cabin. If you've checked for leaks -- and I mean really checked for leaks as described above and you're still not keeping a cabin, it may be due to the cabin pressure controller, which isn't young by any standard. The fuel "transfer" is due to a leaking fuel shut-off valve most likely. There are several of these electric gate valves in the airplane and are used for hydraulic, fuel and oil (on the original 680FLP) shut offs. R & R the corresponding valve. Wing Commander Gordon ________________________________________________________________________________
Date: May 11, 2004
Bilbo: It was actually the National Lampoon, 1973. I remember standing in City Lights Books in San Francisco [quiet like a library], flipping through that issue and just bursting out with laughter. I pretty much had to leave after that. Wish I bought the mag. http://www.marksverylarge.com/booksetc/encyclopedia.html ak -----Original Message----- From: Bill Bow [mailto:bowing74(at)earthlink.net] Subject: Re: Commander-List: Quotes page? > When the first VW bug came out, there were many quotables for that (what we > called an excuse for an automobile) car. My favorite was in Mad Magazine. It had a picture of a Bug floating in water and the caption read. "Had Ted Kennedy had one of these, he would be president today" From the right bilbo > ----- Original Message ----- > From: "Deneal Schilmeister (iMac)" <deneals(at)sbcglobal.net> > To: > Subject: Commander-List: Quotes page? > > > > > > > On 5/10/04 17:57, "CloudCraft(at)aol.com" wrote: > > > > > The faint smell of gas is part of the charm of a Commander. I swear you > > > could blind fold any Commander pilot and place him in a variety of > aircraft > > > and > > > he'll know when he's in a Commander. It's the combined scent of Avgas > and > > > 5606. > > > > If there were a "quotes page" for the Commander list, the above statement > > should be on it! > > > > > > -- > > Deneal Schilmeister ATP Learjet > > St. Louis, Missouri USA > > > > http://homepage.mac.com/deneals > > > > > > == == == == ________________________________________________________________________________
Date: May 12, 2004
In a message dated 5/11/2004 7:13:08 PM Pacific Standard Time, hcourier(at)cox.net writes: 1. When the plane is in the hangar, any fuel in the right aux tank will drain into the center tank in a short time. This occurs even if the fuel selector is set to "OFF". It even occurs in flight in that the right aux tank is used up faster than the left with the engines at approximately the same gph fuel burn. Any thoughts on why this is happening. The fuel valve is leaking internally. I allows fuel to transfer. They need new seals. jb ________________________________________________________________________________
Date: May 12, 2004
Subject: Outboard Tank Etiquette
\ > 1. When the plane is in the hangar, any fuel in the right aux tank will > drain into the center tank in a short time. This occurs even if the > fuel selector is set to "OFF". It even occurs in flight in that the > right aux tank is used up faster than the left with the engines at > approximately the same gph fuel burn. Any thoughts on why this > is happening. > Just a thought on this topic for all Commander operators with more than 156 gallon fuel systems. That would be Commanders with geared Lycomings and the MR. RPM converted airframes. OK... And the few Gary Gadberry 223 gallon 500 A/B/U/S series. When using the outboard tanks, keep in mind that more fuel than is required is sent to the fuel metering system (either pressure carburetor or Simmonds fuel injection) and that by-passed fuel returns to the center tank. If one were to switch to outboard tanks too soon (or as in the case with our new friend with the leaking fuel shut-off valve), there is no room in the center tank for this return fuel to go and it dumps overboard. So when is an OK time to switch to outboard tanks? As soon as you see the main or center fuel system come off the full peg and begin to indicate anything less than full, you have room for by-pass fuel. That would be in the 135 gallon indicating range. There are two schools of thought on using the outboard tanks. Either one-at-a-time, or, switching to double outboard but with 15 minutes of staggered time so if you need to run the tanks dry, you don't have two closely occurring adrenaline rushes to recover from. The devotees to single outboard tank feeding run that way because in the event of a total electrical failure, the tank selector valves fail in their present position and that scenario would leave you with only outboard fuel that is NOT useable in all flight attitudes and not all that much fuel to get over the mountains or ocean with. Just something to think about, along with meteor strikes and whether you forgot to run the dishwasher before you left on this trip. Wing Commander Gordon ________________________________________________________________________________
From: "Randy Dettmer, AIA" <rcdettmer(at)charter.net>
Subject: Re: Outboard Tank Etiquette
Date: May 12, 2004
Thanks Keith for the "as usual" great words of wisdom. Now, I ve got a whole new thought process going on about tank switching...thinking about running the tanks dry (I'd rather not), the possibility of an electrical failure ( I had one once...turned out that I left the generator switches off, and ran the battery out of juice), ...oh ya, and turning on the dishwasher. Randy Dettmer 680F/N6253X ----- Original Message ----- From: <CloudCraft(at)aol.com> Subject: Commander-List: Outboard Tank Etiquette > > \ > > > 1. When the plane is in the hangar, any fuel in the right aux tank will > > drain into the center tank in a short time. This occurs even if the > > fuel selector is set to "OFF". It even occurs in flight in that the > > right aux tank is used up faster than the left with the engines at > > approximately the same gph fuel burn. Any thoughts on why this > > is happening. > > > > Just a thought on this topic for all Commander operators with more than 156 > gallon fuel systems. That would be Commanders with geared Lycomings and the > MR. RPM converted airframes. OK... And the few Gary Gadberry 223 gallon 500 > A/B/U/S series. > > When using the outboard tanks, keep in mind that more fuel than is required > is sent to the fuel metering system (either pressure carburetor or Simmonds > fuel injection) and that by-passed fuel returns to the center tank. > > If one were to switch to outboard tanks too soon (or as in the case with our > new friend with the leaking fuel shut-off valve), there is no room in the > center tank for this return fuel to go and it dumps overboard. > > So when is an OK time to switch to outboard tanks? As soon as you see the > main or center fuel system come off the full peg and begin to indicate anything > less than full, you have room for by-pass fuel. That would be in the 135 > gallon indicating range. > > There are two schools of thought on using the outboard tanks. Either > one-at-a-time, or, switching to double outboard but with 15 minutes of staggered > time so if you need to run the tanks dry, you don't have two closely occurring > adrenaline rushes to recover from. > > The devotees to single outboard tank feeding run that way because in the > event of a total electrical failure, the tank selector valves fail in their > present position and that scenario would leave you with only outboard fuel that is > NOT useable in all flight attitudes and not all that much fuel to get over the > mountains or ocean with. > > Just something to think about, along with meteor strikes and whether you > forgot to run the dishwasher before you left on this trip. > > Wing Commander Gordon > > ________________________________________________________________________________
Date: May 12, 2004
Ray, Another place that is a leaker in the commanders is the floor and the boot around the controls to the floor. The floor in a commander is the pressure bulkhead and not the outter skin. These seals are getting old since the aircraft is 35-40 years old. You may also want to talk to Dick MacCoon, Mr RPM. www.mrrpm.com. Tylor Hall Ray Mansfield wrote: I've just recently started flying an Aero Commander 680 FLP for a company in Ft. Walton Beach, FL. I suspect many of the people on your web site have years of experience with this machine. Sooo...I have a few questions. 1. When the plane is in the hangar, any fuel in the right aux tank will drain into the center tank in a short time. This occurs even if the fuel selector is set to "OFF". It even occurs in flight in that the right aux tank is used up faster than the left with the engines at approximately the same gph fuel burn. Any thoughts on why this is happening. 2. The pressurization system only gets about 2,000' differential at 10,000 ft altitude. The cabin has been checked for leaks and none of any consequence were found. The door seal is new and the seal pump seems to be working. If I just climb, say, to 15,000' will just the fact that the turbos will be putting out more pressure cause the differential altitude to increase beyond more than 2,000'. Right now there's no real benefit to having the pressurization as it doesn't work good enough. This airplane has the Mr. RPM engine conversion to the IO-720 Lycoming. Thanks, Ray Mansfield hcourier(at)cox.net ________________________________________________________________________________
Date: May 12, 2004
Ray, If you find leaks around the top of the leather boots where they surround the rudder pedals (as we did on N680RR) you may try just placing a hose clamp around them. Worked for us! Another place for leaks is below the floor around the hoses that connect the heater/pres. air outlets down close to the floor. Moe ----- Original Message ----- From: "Tylor Hall" <tylor.hall(at)sbcglobal.net> Subject: Re: Commander-List: New Commander Pilot with Questions > > Ray, > Another place that is a leaker in the commanders is the floor and the boot around the controls to the floor. The floor in a commander is the pressure bulkhead and not the outter skin. These seals are getting old since the aircraft is 35-40 years old. > You may also want to talk to Dick MacCoon, Mr RPM. www.mrrpm.com. > Tylor Hall > > > Ray Mansfield wrote: > > I've just recently started flying an Aero Commander 680 FLP for a company in Ft. Walton Beach, FL. I suspect many of the people on your web site have years of experience with this machine. Sooo...I have a few questions. > > 1. When the plane is in the hangar, any fuel in the right aux tank will > drain into the center tank in a short time. This occurs even if the > fuel selector is set to "OFF". It even occurs in flight in that the > right aux tank is used up faster than the left with the engines at > approximately the same gph fuel burn. Any thoughts on why this > is happening. > > 2. The pressurization system only gets about 2,000' differential at > 10,000 ft altitude. The cabin has been checked for leaks and none > of any consequence were found. The door seal is new and the > seal pump seems to be working. If I just climb, say, to 15,000' > will just the fact that the turbos will be putting out more pressure > cause the differential altitude to increase beyond more than 2,000'. Right now there's no real benefit to having the > pressurization as it doesn't work good enough. This airplane has the Mr. RPM engine conversion to the IO-720 Lycoming. > > > Thanks, > > Ray Mansfield > hcourier(at)cox.net > > ________________________________________________________________________________
Date: May 12, 2004
Randy -- I thought I had the market cornered on the trip without generators. On a Forest Service flight to pick up another AirBoss during a fire, my radios went dead. Was in the pattern NORDO wondering what I'd do next to save the world when I noticed those gen switches. I started the diswasher this morning and now I'm worried about it flooding the house while I'm away for the next 4 days. You just can't win. KG ________________________________________________________________________________
Subject: CONCORDE'S LAST FLIGHT
Date: May 13, 2004
CONCORDE'S LAST FLIGHT - The red planes are Britain's version of the Blue Angels. They are called the Red Arrows. ________________________________________________________________________________
Date: May 15, 2004
Subject: suggestions on fuel computers
Chicas, Looking to install a fuel computer to interface with the KLN94. I'm considering the Shadin Digidata and Insight's TAS 1000. Would like to hear your experiences and suggestions. Best Regards, Jimmy N107VC ________________________________________________________________________________
Subject: RE: suggestion on fuel computers
Date: May 17, 2004
Hi Jimmy, I have a Shadin Digiflow-L installed in my 500B and I love it. Although I don't have it connected to my Garmin 430 yet, it works great. It is always accurate to within 1 gallon and didn't require any calibration or anything. It worked like that right out of the box. Also, I was able to get it approved as a replacement for the old mechanical flow gague as part of the Merlyn engine conversion. If you are really ambitious, you could try to do that because otherwise you'll have to keep the original gauge in addition to the Shadin. Since the Shadin is TSO'd and always displays the flow to each engine, the FAA allows it to be a direct replacement if you do a field approval (Shadin has no STC for the Commander). I don't know if the Insight is STC'd but if it doesn't show flow to each engine continuously, I don't think you can get it approved as a replacement. In other words, it must always show the flow to each engine separately and you cannot have the ability to change that display to some other value. I'll send you a picture separately. Scott N222LE From: "jimmyr" <jimmyr(at)popsecs.com> Subject: Commander-List: suggestions on fuel computers Chicas, Looking to install a fuel computer to interface with the KLN94. I'm considering the Shadin Digidata and Insight's TAS 1000. Would like to hear your experiences and suggestions. Best Regards, Jimmy N107VC ________________________________________________________________________________
Subject: Re:Commander-List Digest: 4 Msgs - 05/12/04
Date: May 17, 2004
Thanks for your email. I'm away from ARS headquarters and will respond as soon as able. If it is urgent, please contact me on my cell phone (949) 300-5510. Barry Hancock Event Director All Red Star 2004 www.allredstar.com On May 12, 2004, at 11:55 PM, Commander-List Digest Server wrote: > * > > ================================================== > Online Versions of Today's List Digest Archive > ================================================== > > Today's complete Commander-List Digest can be also be found in either > of the two Web Links listed below. The .html file includes the Digest > formatted in HTML for viewing with a web browser and features > Hyperlinked > Indexes and Message Navigation. The .txt file includes the plain ASCII > version of the Commander-List Digest and can be viewed with a generic > text editor such as Notepad or with a web browser. > > HTML Version: > > > List.2004-05-12.html > > Text Version: > > > List.2004-05-12.txt > > > ================================================ > EMail Version of Today's List Digest Archive > ================================================ > > > Commander-List Digest Archive > --- > Total Messages Posted Wed 05/12/04: 4 > > > Today's Message Index: > ---------------------- > > 1. 06:51 AM - Re: Outboard Tank Etiquette (Randy Dettmer, AIA) > 2. 08:04 AM - Re: New Commander Pilot with Questions (Tylor Hall) > 3. 10:15 AM - Re: New Commander Pilot with Questions (Moe) > 4. 11:34 AM - Re: Outboard Tank Etiquette (CloudCraft(at)aol.com) > > > ________________________________ Message 1 > _____________________________________ > > > From: "Randy Dettmer, AIA" <rcdettmer(at)charter.net> > Subject: Re: Commander-List: Outboard Tank Etiquette > > > > Thanks Keith for the "as usual" great words of wisdom. Now, I ve got a > whole new thought process going on about tank switching...thinking > about > running the tanks dry (I'd rather not), the possibility of an > electrical > failure ( I had one once...turned out that I left the generator > switches > off, and ran the battery out of juice), ...oh ya, and turning on the > dishwasher. > > Randy Dettmer > 680F/N6253X > > > ----- Original Message ----- > From: <CloudCraft(at)aol.com> > Subject: Commander-List: Outboard Tank Etiquette > > >> >> \ >> >>> 1. When the plane is in the hangar, any fuel in the right aux tank >>> will >>> drain into the center tank in a short time. This occurs even if > the >>> fuel selector is set to "OFF". It even occurs in flight in that > the >>> right aux tank is used up faster than the left with the engines >>> at >>> approximately the same gph fuel burn. Any thoughts on why this >>> is happening. >>> >> >> Just a thought on this topic for all Commander operators with more >> than > 156 >> gallon fuel systems. That would be Commanders with geared Lycomings >> and > the >> MR. RPM converted airframes. OK... And the few Gary Gadberry 223 >> gallon > 500 >> A/B/U/S series. >> >> When using the outboard tanks, keep in mind that more fuel than is > required >> is sent to the fuel metering system (either pressure carburetor or > Simmonds >> fuel injection) and that by-passed fuel returns to the center tank. >> >> If one were to switch to outboard tanks too soon (or as in the case >> with > our >> new friend with the leaking fuel shut-off valve), there is no room in >> the >> center tank for this return fuel to go and it dumps overboard. >> >> So when is an OK time to switch to outboard tanks? As soon as you >> see > the >> main or center fuel system come off the full peg and begin to indicate > anything >> less than full, you have room for by-pass fuel. That would be in the >> 135 >> gallon indicating range. >> >> There are two schools of thought on using the outboard tanks. >> Either >> one-at-a-time, or, switching to double outboard but with 15 minutes of > staggered >> time so if you need to run the tanks dry, you don't have two closely > occurring >> adrenaline rushes to recover from. >> >> The devotees to single outboard tank feeding run that way because in >> the >> event of a total electrical failure, the tank selector valves fail in > their >> present position and that scenario would leave you with only outboard >> fuel > that is >> NOT useable in all flight attitudes and not all that much fuel to get >> over > the >> mountains or ocean with. >> >> Just something to think about, along with meteor strikes and whether >> you >> forgot to run the dishwasher before you left on this trip. >> >> Wing Commander Gordon >> >> > > > ________________________________ Message 2 > _____________________________________ > > > From: Tylor Hall <tylor.hall(at)sbcglobal.net> > Subject: Re: Commander-List: New Commander Pilot with Questions > > > > Ray, > Another place that is a leaker in the commanders is the floor and the > boot around > the controls to the floor. The floor in a commander is the pressure > bulkhead > and not the outter skin. These seals are getting old since the > aircraft is > 35-40 years old. > You may also want to talk to Dick MacCoon, Mr RPM. www.mrrpm.com. > Tylor Hall > > > Ray Mansfield wrote: > > I've just recently started flying an Aero Commander 680 FLP for a > company in Ft. > Walton Beach, FL. I suspect many of the people on your web site have > years of > experience with this machine. Sooo...I have a few questions. > > 1. When the plane is in the hangar, any fuel in the right aux tank will > drain into the center tank in a short time. This occurs even if the > fuel selector is set to "OFF". It even occurs in flight in that the > right aux tank is used up faster than the left with the engines at > approximately the same gph fuel burn. Any thoughts on why this > is happening. > > 2. The pressurization system only gets about 2,000' differential at > 10,000 ft altitude. The cabin has been checked for leaks and none > of any consequence were found. The door seal is new and the > seal pump seems to be working. If I just climb, say, to 15,000' > will just the fact that the turbos will be putting out more pressure > cause the differential altitude to increase beyond more than 2,000'. > Right now > there's no real benefit to having the > pressurization as it doesn't work good enough. This airplane has the > Mr. RPM engine > conversion to the IO-720 Lycoming. > > > Thanks, > > Ray Mansfield > hcourier(at)cox.net > > > ________________________________ Message 3 > _____________________________________ > > > From: "Moe" <moe(at)rosspistons.com> > Subject: Re: Commander-List: New Commander Pilot with Questions > > > Ray, > > If you find leaks around the top of the leather boots where they > surround > the rudder pedals (as we did on N680RR) you may try just placing a hose > clamp around them. Worked for us! Another place for leaks is below > the > floor around the hoses that connect the heater/pres. air outlets down > close > to the floor. > > Moe > ----- Original Message ----- > From: "Tylor Hall" <tylor.hall(at)sbcglobal.net> > Subject: Re: Commander-List: New Commander Pilot with Questions > > > >> >> Ray, >> Another place that is a leaker in the commanders is the floor and the >> boot > around the controls to the floor. The floor in a commander is the > pressure > bulkhead and not the outter skin. These seals are getting old since > the > aircraft is 35-40 years old. >> You may also want to talk to Dick MacCoon, Mr RPM. www.mrrpm.com. >> Tylor Hall >> >> >> Ray Mansfield wrote: >> >> I've just recently started flying an Aero Commander 680 FLP for a >> company > in Ft. Walton Beach, FL. I suspect many of the people on your web site > have > years of experience with this machine. Sooo...I have a few questions. >> >> 1. When the plane is in the hangar, any fuel in the right aux tank >> will >> drain into the center tank in a short time. This occurs even if the >> fuel selector is set to "OFF". It even occurs in flight in that the >> right aux tank is used up faster than the left with the engines at >> approximately the same gph fuel burn. Any thoughts on why this >> is happening. >> >> 2. The pressurization system only gets about 2,000' differential at >> 10,000 ft altitude. The cabin has been checked for leaks and none >> of any consequence were found. The door seal is new and the >> seal pump seems to be working. If I just climb, say, to 15,000' >> will just the fact that the turbos will be putting out more pressure >> cause the differential altitude to increase beyond more than 2,000'. >> Right > now there's no real benefit to having the >> pressurization as it doesn't work good enough. This airplane has the >> Mr. > RPM engine conversion to the IO-720 Lycoming. >> >> >> Thanks, >> >> Ray Mansfield >> hcourier(at)cox.net >> >> > > > ________________________________ Message 4 > _____________________________________ > > > From: CloudCraft(at)aol.com > Subject: Re: Commander-List: Outboard Tank Etiquette > > > Randy -- > > I thought I had the market cornered on the trip without generators. > On a Forest > Service flight to pick up another AirBoss during a fire, my radios > went dead. > > Was in the pattern NORDO wondering what I'd do next to save the world > when I noticed > those gen switches. > > I started the diswasher this morning and now I'm worried about it > flooding the > house while I'm away for the next 4 days. You just can't win. > > KG > > > _- > ======================================================================= > _- > ======================================================================= > _- > ======================================================================= > _- > ======================================================================= > > > > ________________________________________________________________________________
Subject: Re:Commander-List Digest: 1 Msgs - 05/13/04
Date: May 17, 2004
Thanks for your email. I'm away from ARS headquarters and will respond as soon as able. If it is urgent, please contact me on my cell phone (949) 300-5510. Barry Hancock Event Director All Red Star 2004 www.allredstar.com On May 13, 2004, at 11:55 PM, Commander-List Digest Server wrote: > * > > ================================================== > Online Versions of Today's List Digest Archive > ================================================== > > Today's complete Commander-List Digest can be also be found in either > of the two Web Links listed below. The .html file includes the Digest > formatted in HTML for viewing with a web browser and features > Hyperlinked > Indexes and Message Navigation. The .txt file includes the plain ASCII > version of the Commander-List Digest and can be viewed with a generic > text editor such as Notepad or with a web browser. > > HTML Version: > > > List.2004-05-13.html > > Text Version: > > > List.2004-05-13.txt > > > ================================================ > EMail Version of Today's List Digest Archive > ================================================ > > > Commander-List Digest Archive > --- > Total Messages Posted Thu 05/13/04: 1 > > > Today's Message Index: > ---------------------- > > 1. 07:10 AM - CONCORDE'S LAST FLIGHT (Robert Steele) > > > ________________________________ Message 1 > _____________________________________ > > > From: "Robert Steele" <bob.steele(at)kzf.com> > Subject: Commander-List: CONCORDE'S LAST FLIGHT > > > > > CONCORDE'S LAST FLIGHT - > The red planes are Britain's version of the Blue Angels. They > are called the Red Arrows. > > > _- > ======================================================================= > _- > ======================================================================= > _- > ======================================================================= > _- > ======================================================================= > > > > ________________________________________________________________________________
Subject: Re:Commander-List Digest: 0 Msgs - 05/14/04
Date: May 17, 2004
Thanks for your email. I'm away from ARS headquarters and will respond as soon as able. If it is urgent, please contact me on my cell phone (949) 300-5510. Barry Hancock Event Director All Red Star 2004 www.allredstar.com On May 14, 2004, at 11:55 PM, Commander-List Digest Server wrote: > * > > ================================================== > Online Versions of Today's List Digest Archive > ================================================== > > Today's complete Commander-List Digest can be also be found in either > of the two Web Links listed below. The .html file includes the Digest > formatted in HTML for viewing with a web browser and features > Hyperlinked > Indexes and Message Navigation. The .txt file includes the plain ASCII > version of the Commander-List Digest and can be viewed with a generic > text editor such as Notepad or with a web browser. > > HTML Version: > > > List.2004-05-14.html > > Text Version: > > > List.2004-05-14.txt > > > ================================================ > EMail Version of Today's List Digest Archive > ================================================ > > > Commander-List Digest Archive > --- > Total Messages Posted Fri 05/14/04: 0 > > > Today's Message Index: > ---------------------- > > > _- > ======================================================================= > _- > ======================================================================= > _- > ======================================================================= > _- > ======================================================================= > > > > ________________________________________________________________________________
Subject: Re:Commander-List Digest: 1 Msgs - 05/15/04
Date: May 17, 2004
Thanks for your email. I'm away from ARS headquarters and will respond as soon as able. If it is urgent, please contact me on my cell phone (949) 300-5510. Barry Hancock Event Director All Red Star 2004 www.allredstar.com On May 15, 2004, at 11:55 PM, Commander-List Digest Server wrote: > * > > ================================================== > Online Versions of Today's List Digest Archive > ================================================== > > Today's complete Commander-List Digest can be also be found in either > of the two Web Links listed below. The .html file includes the Digest > formatted in HTML for viewing with a web browser and features > Hyperlinked > Indexes and Message Navigation. The .txt file includes the plain ASCII > version of the Commander-List Digest and can be viewed with a generic > text editor such as Notepad or with a web browser. > > HTML Version: > > > List.2004-05-15.html > > Text Version: > > > List.2004-05-15.txt > > > ================================================ > EMail Version of Today's List Digest Archive > ================================================ > > > Commander-List Digest Archive > --- > Total Messages Posted Sat 05/15/04: 1 > > > Today's Message Index: > ---------------------- > > 1. 06:10 PM - suggestions on fuel computers (jimmyr) > > > ________________________________ Message 1 > _____________________________________ > > > From: "jimmyr" <jimmyr(at)popsecs.com> > Subject: Commander-List: suggestions on fuel computers > > > Chicas, > > Looking to install a fuel computer to interface with the KLN94. I'm > considering > the Shadin Digidata and Insight's TAS 1000. Would like to hear your > experiences > and suggestions. > > Best Regards, > > Jimmy > N107VC > > > _- > ======================================================================= > _- > ======================================================================= > _- > ======================================================================= > _- > ======================================================================= > > > > ________________________________________________________________________________
Subject: Re:Commander-List Digest: 0 Msgs - 05/16/04
Date: May 17, 2004
Thanks for your email. I'm away from ARS headquarters and will respond as soon as able. If it is urgent, please contact me on my cell phone (949) 300-5510. Barry Hancock Event Director All Red Star 2004 www.allredstar.com On May 16, 2004, at 11:55 PM, Commander-List Digest Server wrote: > * > > ================================================== > Online Versions of Today's List Digest Archive > ================================================== > > Today's complete Commander-List Digest can be also be found in either > of the two Web Links listed below. The .html file includes the Digest > formatted in HTML for viewing with a web browser and features > Hyperlinked > Indexes and Message Navigation. The .txt file includes the plain ASCII > version of the Commander-List Digest and can be viewed with a generic > text editor such as Notepad or with a web browser. > > HTML Version: > > > List.2004-05-16.html > > Text Version: > > > List.2004-05-16.txt > > > ================================================ > EMail Version of Today's List Digest Archive > ================================================ > > > Commander-List Digest Archive > --- > Total Messages Posted Sun 05/16/04: 0 > > > Today's Message Index: > ---------------------- > > > _- > ======================================================================= > _- > ======================================================================= > _- > ======================================================================= > _- > ======================================================================= > > > > ________________________________________________________________________________
Date: May 17, 2004
Subject: Re: RE: suggestion on fuel computers
Hi Scott, Thanks. That is great information. The TAS 1000 has only one window to show all functions, so I think I'll go ahead with the Shadin Digidata. BTW, nice looking panel! Best Regards, Jimmy ---------- Original Message ---------------------------------- From: "Scott Dickey" <jdickey(at)radictech.com> Date: Mon, 17 May 2004 07:20:00 -0700 > >Hi Jimmy, > >I have a Shadin Digiflow-L installed in my 500B and I love it. Although I >don't have it connected to my Garmin 430 yet, it works great. It is always >accurate to within 1 gallon and didn't require any calibration or anything. >It worked like that right out of the box. Also, I was able to get it >approved as a replacement for the old mechanical flow gague as part of the >Merlyn engine conversion. If you are really ambitious, you could try to do >that because otherwise you'll have to keep the original gauge in addition to >the Shadin. Since the Shadin is TSO'd and always displays the flow to each >engine, the FAA allows it to be a direct replacement if you do a field >approval (Shadin has no STC for the Commander). I don't know if the Insight >is STC'd but if it doesn't show flow to each engine continuously, I don't >think you can get it approved as a replacement. In other words, it must >always show the flow to each engine separately and you cannot have the >ability to change that display to some other value. I'll send you a picture >separately. > >Scott > >N222LE > >From: "jimmyr" <jimmyr(at)popsecs.com> >Subject: Commander-List: suggestions on fuel computers > > >Chicas, > >Looking to install a fuel computer to interface with the KLN94. I'm >considering >the Shadin Digidata and Insight's TAS 1000. Would like to hear your >experiences >and suggestions. > >Best Regards, > >Jimmy >N107VC > > > ________________________________________________________________________________
Subject: hydraulic accumulator question
Date: May 17, 2004
Hey Everyone, I just topped off my hydraulic accumulator on my 500B according to the service manual and I have a question. The service manual says to connect a nitrogen supply of 600 psi to the accumulator and then raise and lower the flaps to make sure the piston in the accumulator is at the end of its stroke and the hydraulic pressure is at zero. I did all this expecting the the flaps to go down and maybe part way up until the piston bottomed out. However, I was able to lower and raise the flaps twice using just the pressure from the nitrogen bottle (master, aux hyd pump off). I don't see how the flaps could cycle twice with just the little volume of hyd fluid inside the hydraulic accumulator. I was afraid maybe the seals were blown and I was forcing nitrogen into the system and that was providing the pressure to raise the flaps. Does anyone have any advice on this? When I closed the valve on the accumulator my hydraulic pressure was nice and steady with the engines running so it seems like the accumulator is doing its thing now but I am still confused. Scott N222LE ________________________________________________________________________________
Date: May 17, 2004
Subject: NOSE CONE
There is an aero commander nose cone on ebay, starting bid is $10.00. dan farmer 6369U --------------------------------- ________________________________________________________________________________
Date: May 20, 2004
Subject: Need to chrome the pitot tubes. Any suggestions?
Date: May 20, 2004
Subject: Bob Hoover at AS3
Bob Hoover is at the AS3 show in LasVegas. I had the privilage to talk with him at the Shell Oil booth. He is coming to TCFG meeting. He spoke highly of John Towner. Tylor Hall ________________________________________________________________________________
Subject: Re: Bob Hoover at AS3
Date: May 20, 2004
That's GREAT news!!! I can't wait! /John ----- Original Message ----- From: "Tylor Hall" <tylor.hall(at)sbcglobal.net> Subject: Commander-List: Bob Hoover at AS3 > > Bob Hoover is at the AS3 show in LasVegas. I had the privilage to talk with him at the Shell Oil booth. He is coming to TCFG meeting. He spoke highly of John Towner. > > Tylor Hall > > ________________________________________________________________________________
Date: May 20, 2004
Truly great news. There is no tellling how long we still would have the privilege. It makes attendance very important. Nico ----- Original Message ----- From: "John Vormbaum" <john(at)vormbaum.com> Subject: Re: Commander-List: Bob Hoover at AS3 > > That's GREAT news!!! I can't wait! > > /John > > ----- Original Message ----- > From: "Tylor Hall" <tylor.hall(at)sbcglobal.net> > To: > Subject: Commander-List: Bob Hoover at AS3 > > > > > > > Bob Hoover is at the AS3 show in LasVegas. I had the privilage to talk > with him at the Shell Oil booth. He is coming to TCFG meeting. He spoke > highly of John Towner. > > > > Tylor Hall > > > > > > ________________________________________________________________________________
From: "KevinCoons(at)CAVUCompanies.net" <kevincoons(at)cavucompanies.net>
Subject: Need Yoda's phone number
Date: May 21, 2004
Anyone have Yoda's current phone number? Kevin Coons ________________________________________________________________________________
Date: May 21, 2004
Subject: Re: Need Yoda's phone number
Hi Kevin, Try 321-403-8813 Regards, Jimmy N107VC ---------- Original Message ---------------------------------- From: "KevinCoons(at)CAVUCompanies.net" <kevincoons(at)cavucompanies.net> Date: Fri, 21 May 2004 12:22:07 -0400 > >Anyone have Yoda's current phone number? > >Kevin Coons > > ________________________________________________________________________________
Date: May 21, 2004
Subject: New to the Group
Hello, I'm new to the group, I recently stopped in Hammond, Louisiana to get some fuel, and when I was leaving, I noticed two abandoned Commanders parked in the grass there. I looked like a Vintage 560 and a 680. Does anyone have any info on these two planes. I check around and all I could find out was that they were purchased by a gentlemen who apparently died, and no one claimed them. Thanks, Bert Berry ________________________________________________________________________________
Subject: Re: New to the Group
Date: May 21, 2004
I Purchase both the Aircraft they are (2) 680S in are for sale, AS IS WERE IS, No Log's Harry 321 267-3141 ----- Original Message ----- From: <BertBerry1(at)aol.com> Subject: Commander-List: New to the Group > > Hello, > I'm new to the group, I recently stopped in Hammond, Louisiana to get some > fuel, and when I was leaving, I noticed two abandoned Commanders parked in the > grass there. I looked like a Vintage 560 and a 680. Does anyone have any > info on these two planes. > I check around and all I could find out was that they were purchased by a > gentlemen who apparently died, and no one claimed them. > Thanks, > Bert Berry > > ________________________________________________________________________________
Date: May 21, 2004
321 403 88134 Cell 510 783-3028 209 982-9203 Harry ----- Original Message ----- From: "KevinCoons(at)CAVUCompanies.net" <kevincoons(at)cavucompanies.net> Subject: Commander-List: Need Yoda's phone number > > Anyone have Yoda's current phone number? > > Kevin Coons > > ________________________________________________________________________________
Date: May 21, 2004
Can you tell me what the serial numbers and N-numbers are, please sir? ________________________________________________________________________________
Date: May 21, 2004
Harry, What model 680 are they. Any parts on them that I could fly down and rip off (for a price of course) for my 680F(p)? Moe N680RR ----- Original Message ----- From: <avtec2(at)bellsouth.net> Subject: Re: Commander-List: New to the Group > > I Purchase both the Aircraft they are (2) 680S in are for sale, AS IS WERE > IS, No Log's > Harry > 321 267-3141 > ----- Original Message ----- > From: <BertBerry1(at)aol.com> > To: > Subject: Commander-List: New to the Group > > > > > > Hello, > > I'm new to the group, I recently stopped in Hammond, Louisiana to get some > > fuel, and when I was leaving, I noticed two abandoned Commanders parked in > the > > grass there. I looked like a Vintage 560 and a 680. Does anyone have > any > > info on these two planes. > > I check around and all I could find out was that they were purchased by a > > gentlemen who apparently died, and no one claimed them. > > Thanks, > > Bert Berry > > > > > > ________________________________________________________________________________
Date: May 21, 2004
Hi Harry, I too, would like to know both of the aircraft's serial numbers. Any chance of them ever flying in again, or are they beyond help? Thanks! Barry Collman ----- Original Message ----- From: <avtec2(at)bellsouth.net> Subject: Re: Commander-List: New to the Group | | I Purchase both the Aircraft they are (2) 680S in are for sale, AS IS WERE | IS, No Log's | Harry | 321 267-3141 | ----- Original Message ----- | From: <BertBerry1(at)aol.com> | To: | Subject: Commander-List: New to the Group | | | > | > Hello, | > I'm new to the group, I recently stopped in Hammond, Louisiana to get some | > fuel, and when I was leaving, I noticed two abandoned Commanders parked in | the | > grass there. I looked like a Vintage 560 and a 680. Does anyone have | any | > info on these two planes. | > I check around and all I could find out was that they were purchased by a | > gentlemen who apparently died, and no one claimed them. | > Thanks, | > Bert Berry | > | > | | | | | | | ________________________________________________________________________________
Date: May 21, 2004
Hey Barry, Any idea about this one, saw it here in Lafayette, LA 03-03-04. Couldn't get over there to check out the serial number before it let. ________________________________________________________________________________
Date: May 21, 2004
Just as a matter of interst, no plane is beyond help provided enough money is thrown at it, right? Nico ----- Original Message ----- From: "Barry Collman" <barry.collman@air-britain.co.uk> Subject: Re: Commander-List: New to the Group <barry.collman@air-britain.co.uk> > > Hi Harry, > > I too, would like to know both of the aircraft's serial numbers. > > Any chance of them ever flying in again, or are they beyond help? > > Thanks! > > Barry Collman > > > ----- Original Message ----- > From: <avtec2(at)bellsouth.net> > To: > Subject: Re: Commander-List: New to the Group > > > | > | I Purchase both the Aircraft they are (2) 680S in are for sale, AS IS WERE > | IS, No Log's > | Harry > | 321 267-3141 > | ----- Original Message ----- > | From: <BertBerry1(at)aol.com> > | To: > | Subject: Commander-List: New to the Group > | > | > | > > | > Hello, > | > I'm new to the group, I recently stopped in Hammond, Louisiana to get some > | > fuel, and when I was leaving, I noticed two abandoned Commanders parked in > | the > | > grass there. I looked like a Vintage 560 and a 680. Does anyone have > | any > | > info on these two planes. > | > I check around and all I could find out was that they were purchased by a > | > gentlemen who apparently died, and no one claimed them. > | > Thanks, > | > Bert Berry > | > > | > > | > | > | > | > | > | > | > > ________________________________________________________________________________
Date: Apr 23, 2004
Yes they will fly again! N6217B, Serial Number: 680-617-246 and N816B, Serial Number: 680-541-210 Harry 321 267-3141 ----- Original Message ----- From: "Barry Collman" <barry.collman@air-britain.co.uk> Subject: Re: Commander-List: New to the Group <barry.collman@air-britain.co.uk> > > Hi Harry, > > I too, would like to know both of the aircraft's serial numbers. > > Any chance of them ever flying in again, or are they beyond help? > > Thanks! > > Barry Collman > > > ----- Original Message ----- > From: <avtec2(at)bellsouth.net> > To: > Subject: Re: Commander-List: New to the Group > > > | > | I Purchase both the Aircraft they are (2) 680S in are for sale, AS IS WERE > | IS, No Log's > | Harry > | 321 267-3141 > | ----- Original Message ----- > | From: <BertBerry1(at)aol.com> > | To: > | Subject: Commander-List: New to the Group > | > | > | > > | > Hello, > | > I'm new to the group, I recently stopped in Hammond, Louisiana to get some > | > fuel, and when I was leaving, I noticed two abandoned Commanders parked in > | the > | > grass there. I looked like a Vintage 560 and a 680. Does anyone have > | any > | > info on these two planes. > | > I check around and all I could find out was that they were purchased by a > | > gentlemen who apparently died, and no one claimed them. > | > Thanks, > | > Bert Berry > | > > | > > | > | > | > | > | > | > | > > ________________________________________________________________________________
Date: May 22, 2004
Subject: NEWSLETTER
HI KIDS. Well, after what must have seemed an eternity, I have just mailed the latest Flight Group News. I offer my deepest apologies for being so tardy in it's publication, I am already working on the next issue and plan to have it in the mail in a month or so. That will get me back on schedule. It will have a great article written by Wing Commander Gordon on Landing Gears for the flat nacelled airplanes. I will be adding a side bar to cover the older airplanes. I have inclosed the registration forms for this years flyin in KC. I CANNOT TELL YOU HOW IMPORTANT IT IS FOR YOU TO REGISTER EARLY!!!! Can you imagine trying to plan an event of this size and not knowing how many will attend?? All indications are that our host, John Towner and Central Air have arranged to have ROBERT A. (BOB) HOOVER attend!! Can you imagine having the opportunity to have dinner with BOB HOOVER!!! Anyway, I am so jazzed I cant stand it. I hope you are to. jb ________________________________________________________________________________
Subject: Re: Lafayette
Date: May 22, 2004
Hi Bert, I think you probably attached a file to your email. Attachments are not 'allowed' through the chatlist. This is to help preserve the integrity of the list and helps to protect it against virus attacks. If there was an attachment, email me direct and I'll try to help. Kindest Regards, Barry ----- Original Message ----- From: <BertBerry1(at)aol.com> Subject: Re: Commander-List: New to the Group | | Hey Barry, | | Any idea about this one, saw it here in Lafayette, LA 03-03-04. Couldn't get over there to check out the serial number before it let. | | | | | | | ________________________________________________________________________________
Subject:
Date: May 22, 2004
moe, if you are looking for parts, I am going to bring everything off of and out of 2001m to the meeting in sept. if anyone needs anything there we do not plan on bringing any of it back to fort worth. mason 817-877-4977 ________________________________________________________________________________
Subject: Commander for trade
Date: May 23, 2004
If anyone knows of a Commander Owner that may want to trade their Commander into a Commercial Income Property, Please have them contact: Robert Lee 435-862-9534 Thank You Robert Lee ________________________________________________________________________________
Date: May 23, 2004
Subject: Re: Commander for trade
Where is the property??, what Commander are you looking for, piston, turbine?? Thanks jb ________________________________________________________________________________
Date: May 23, 2004
JB, Thank You for responding. Property is in Northern Utah. Want a piston. Preferably a 500S. But am open for anything. Can send pics and information if you would like. Would need the fax number and email address you would like me to use. Thank You Robert ----- Original Message ----- From: <YOURTCFG(at)aol.com> Subject: Re: Commander-List: Commander for trade > > Where is the property??, what Commander are you looking for, piston, > turbine?? Thanks jb > > ________________________________________________________________________________
Date: May 24, 2004
In a message dated 5/23/2004 10:24:22 PM Pacific Standard Time, sather(at)charter.net writes: JB, Thank You for responding. Property is in Northern Utah. Want a piston. Preferably a 500S. But am open for anything. Can send pics and information I have a guy with a really nice 560F for sale. Maybe trade?? I will be delivering an airplane the early part of this week but will see what might be there when I return. Thanks jb ________________________________________________________________________________
Date: May 24, 2004
Hi Everyone, This is just a follow up on my efforts to get my accumulator charged and working properly. Now you are all probably thinking, What a loser. This guy doesnt even know how to service his hydraulic accumulator. So for the one other Commander owner out there who doesnt know how to do this, here are the tricks I learned over the last week. 1. Connect 600 psi nitrogen to the accumulator fitting and make sure the fitting is open by turning the locknut counterclockwise at least 2 turns. Leave the nitrogen source ON and the regulator set for 600 psi +25 / -0 psi. 2. With all power OFF (engine driven and aux pumps), move the flap handle from the neutral position up or down VERY slowly until you hear the pressure bleed down to zero (you can see this happen on the gauge and you can hear it through the flap valve). It turns out the flap valve has a bleed port which bleeds pressure just before going to the flap UP or flap DOWN position. If you move the handle slowly, you will hear pressure relieve and see the gauge go to zero 1/4" or so before getting to the flap UP or DOWN position. Now the piston in the accumulator is at the end of its stroke with 600 psi nitrogen on one side and 0 psi hydraulic fluid on the other. 3. Check your accumulator for internal leaks. Now that you have 600 psi on the accumulator, you can see and hear if the piston o ring is leaking. If you hear anything then open the hydraulic fluid reservoir to see if there is any foam or bubbles. If there is nothing, proceed to step 4. If you see bubbles and the thing is hissing away, take a deep breath and cancel any upcoming trips. The good news is that you can get the whole accumulator overhauled by Higher Planes for just $1800. And since those accumulators just jump in and out practically by themselves, its a real bargain! But if you need it done, they have a FAA approved overhaul for that component (along with other commander stuff like power brake valves). http://www.higherplanes.com/ 4. With the nitrogen still ON, tighten the lock nut on the fitting and remove the nitrogen fill hose (don't forget to turn off the Nitrogen before removing the fitting - 600 psi is A LOT of pressure). I believe this is the first time I've flown the airplane with the accumulator serviced properly. The hydraulic pressure gauge now barely moves, even when actuating the flaps, brakes, etc. It used to snap back and forth during flight and especially when using the system. When serviced properly, the accumulator does and excellent job of dampening the pressure in the system, to the point where there is almost no pressure fluctuation at all. If your gauge moves much at all or if you see any rapid movements, chances are you have flat or low accumulator pressure. The other trick to doing this properly is finding a nitrogen source that can go up to 600 psi. Almost everyone has a N2 bottle with the welder style regulator but most of those cannot regulate to 600 psi downstream pressure. I decided to look for the components to buy and I really had to search for a regulator that could regulate to 600 psi. Most regulators that I saw have maximum of 350 - 450 psi regulating ranges. They maybe go a little higher but you're lucky if your mechanic has the proper rig. If you are planning to build your own rig, plan on spending about $500. Here are sources for everything you will need: 1) 110 cu foot or larger N2 bottle - any local welding shop. About $200 buys the bottle and refills are cheap. 2) 0 - 1500 psi high pressure regulator. Available from www.weldingsupply.com. Item # 3200300, about $230. 3) High pressure hose and N2 ground service fitting. Available from Hoses Unlimited (510-483-8520). They will make up a hose of any length and sell you the fill fitting as well. The regulator terminates in 1/4 NPT female so you want a hose with 1/4 NPT male on one end. So that's it. Anyone who is ever in the LVK area stop by for a free N2 fill. * Credit goes to the service manager at DownTown Airpark for telling me about that bleed port. ________________________________________________________________________________
From: "Tom Fisher" <tfisher(at)commandergroup.bc.ca>
Subject: Re: hydraulic accumulator
Date: May 24, 2004
This article is a keeper, thanks Scott. Tom F. ----- Original Message ----- From: "Scott Dickey" <jdickey(at)radictech.com> Subject: Commander-List: hydraulic accumulator > > Hi Everyone, > > This is just a follow up on my efforts to get my accumulator charged and > working properly. Now you are all probably thinking, What a loser. This guy > doesnt even know how to service his hydraulic accumulator. So for the one > other Commander owner out there who doesnt know how to do this, here are > the tricks I learned over the last week. > > 1. Connect 600 psi nitrogen to the accumulator fitting and make sure the > fitting is open by turning the locknut counterclockwise at least 2 turns. > Leave the nitrogen source ON and the regulator set for 600 psi +25 / -0 psi. > > 2. With all power OFF (engine driven and aux pumps), move the flap handle > from the neutral position up or down VERY slowly until you hear the pressure > bleed down to zero (you can see this happen on the gauge and you can hear it > through the flap valve). It turns out the flap valve has a bleed port which > bleeds pressure just before going to the flap UP or flap DOWN position. If > you move the handle slowly, you will hear pressure relieve and see the gauge > go to zero 1/4" or so before getting to the flap UP or DOWN position. Now > the piston in the accumulator is at the end of its stroke with 600 psi > nitrogen on one side and 0 psi hydraulic fluid on the other. > > 3. Check your accumulator for internal leaks. Now that you have 600 psi on > the accumulator, you can see and hear if the piston o ring is leaking. If > you hear anything then open the hydraulic fluid reservoir to see if there is > any foam or bubbles. If there is nothing, proceed to step 4. If you see > bubbles and the thing is hissing away, take a deep breath and cancel any > upcoming trips. The good news is that you can get the whole accumulator > overhauled by Higher Planes for just $1800. And since those accumulators > just jump in and out practically by themselves, its a real bargain! But if > you need it done, they have a FAA approved overhaul for that component > (along with other commander stuff like power brake valves). > http://www.higherplanes.com/ > > 4. With the nitrogen still ON, tighten the lock nut on the fitting and > remove the nitrogen fill hose (don't forget to turn off the Nitrogen before > removing the fitting - 600 psi is A LOT of pressure). > > I believe this is the first time I've flown the airplane with the > accumulator serviced properly. The hydraulic pressure gauge now barely > moves, even when actuating the flaps, brakes, etc. It used to snap back and > forth during flight and especially when using the system. When serviced > properly, the accumulator does and excellent job of dampening the pressure > in the system, to the point where there is almost no pressure fluctuation at > all. If your gauge moves much at all or if you see any rapid movements, > chances are you have flat or low accumulator pressure. > > The other trick to doing this properly is finding a nitrogen source that can > go up to 600 psi. Almost everyone has a N2 bottle with the welder style > regulator but most of those cannot regulate to 600 psi downstream pressure. > I decided to look for the components to buy and I really had to search for a > regulator that could regulate to 600 psi. Most regulators that I saw have > maximum of 350 - 450 psi regulating ranges. They maybe go a little higher > but you're lucky if your mechanic has the proper rig. If you are planning to > build your own rig, plan on spending about $500. Here are sources for > everything you will need: > > 1) 110 cu foot or larger N2 bottle - any local welding shop. About $200 > buys the bottle and refills are cheap. > 2) 0 - 1500 psi high pressure regulator. Available from > www.weldingsupply.com. Item # 3200300, about $230. > 3) High pressure hose and N2 ground service fitting. Available from Hoses > Unlimited (510-483-8520). They will make up a hose of any length and sell > you the fill fitting as well. The regulator terminates in 1/4 NPT female so > you want a hose with 1/4 NPT male on one end. > > So that's it. Anyone who is ever in the LVK area stop by for a free N2 fill. > > > * Credit goes to the service manager at DownTown Airpark for telling me > about that bleed port. > > ________________________________________________________________________________
Date: May 24, 2004
Thanks for the excellent article. You included some important details I was not aware of. Phil > [Original Message] > From: Scott Dickey <jdickey(at)radictech.com> > To: > Date: 5/24/2004 1:09:29 PM > Subject: Commander-List: hydraulic accumulator > > > Hi Everyone, > > This is just a follow up on my efforts to get my accumulator charged and > working properly. Now you are all probably thinking, What a loser. This guy > doesnt even know how to service his hydraulic accumulator. So for the one > other Commander owner out there who doesnt know how to do this, here are > the tricks I learned over the last week. > > 1. Connect 600 psi nitrogen to the accumulator fitting and make sure the > fitting is open by turning the locknut counterclockwise at least 2 turns. > Leave the nitrogen source ON and the regulator set for 600 psi +25 / -0 psi. > > 2. With all power OFF (engine driven and aux pumps), move the flap handle > from the neutral position up or down VERY slowly until you hear the pressure > bleed down to zero (you can see this happen on the gauge and you can hear it > through the flap valve). It turns out the flap valve has a bleed port which > bleeds pressure just before going to the flap UP or flap DOWN position. If > you move the handle slowly, you will hear pressure relieve and see the gauge > go to zero 1/4" or so before getting to the flap UP or DOWN position. Now > the piston in the accumulator is at the end of its stroke with 600 psi > nitrogen on one side and 0 psi hydraulic fluid on the other. > > 3. Check your accumulator for internal leaks. Now that you have 600 psi on > the accumulator, you can see and hear if the piston o ring is leaking. If > you hear anything then open the hydraulic fluid reservoir to see if there is > any foam or bubbles. If there is nothing, proceed to step 4. If you see > bubbles and the thing is hissing away, take a deep breath and cancel any > upcoming trips. The good news is that you can get the whole accumulator > overhauled by Higher Planes for just $1800. And since those accumulators > just jump in and out practically by themselves, its a real bargain! But if > you need it done, they have a FAA approved overhaul for that component > (along with other commander stuff like power brake valves). > http://www.higherplanes.com/ > > 4. With the nitrogen still ON, tighten the lock nut on the fitting and > remove the nitrogen fill hose (don't forget to turn off the Nitrogen before > removing the fitting - 600 psi is A LOT of pressure). > > I believe this is the first time I've flown the airplane with the > accumulator serviced properly. The hydraulic pressure gauge now barely > moves, even when actuating the flaps, brakes, etc. It used to snap back and > forth during flight and especially when using the system. When serviced > properly, the accumulator does and excellent job of dampening the pressure > in the system, to the point where there is almost no pressure fluctuation at > all. If your gauge moves much at all or if you see any rapid movements, > chances are you have flat or low accumulator pressure. > > The other trick to doing this properly is finding a nitrogen source that can > go up to 600 psi. Almost everyone has a N2 bottle with the welder style > regulator but most of those cannot regulate to 600 psi downstream pressure. > I decided to look for the components to buy and I really had to search for a > regulator that could regulate to 600 psi. Most regulators that I saw have > maximum of 350 - 450 psi regulating ranges. They maybe go a little higher > but you're lucky if your mechanic has the proper rig. If you are planning to > build your own rig, plan on spending about $500. Here are sources for > everything you will need: > > 1) 110 cu foot or larger N2 bottle - any local welding shop. About $200 > buys the bottle and refills are cheap. > 2) 0 - 1500 psi high pressure regulator. Available from > www.weldingsupply.com. Item # 3200300, about $230. > 3) High pressure hose and N2 ground service fitting. Available from Hoses > Unlimited (510-483-8520). They will make up a hose of any length and sell > you the fill fitting as well. The regulator terminates in 1/4 NPT female so > you want a hose with 1/4 NPT male on one end. > > So that's it. Anyone who is ever in the LVK area stop by for a free N2 fill. > > > * Credit goes to the service manager at DownTown Airpark for telling me > about that bleed port. > > ________________________________________________________________________________
From: "Southern Right Air Charter" <flights(at)sr.co.za>
Subject: Commander for sale
Date: May 25, 2004
1.3 X_PRIORITY_HIGH Sent with 'X-Priority' set to high 0.5 X_MSMAIL_PRIORITY_HIGH Sent with 'X-Msmail-Priority' set to high I have a 500S for sale in South Africa. Anyone interested? I will be able to ferry it across to wherever, should a sale be possible. Regards Brad Watson Southern Right Air Charter Cape Town International Airport P.O. Box 43862 FISH HOEK 7974 flights(at)sr.co.za Tel +27 21 786-1962 Fax +27 21 786-1457 Cell +27 82 384-0044 www.sr.co.za ________________________________________________________________________________
Subject: Re: Commander for sale
Date: May 25, 2004
Nice site, Brad. I have flown in Pretoria / Rand / Lanseria for many years and had a couple of trips to your neck of the woods visiting my office in Cape Town. I had a Twin Comanche and an Aero Commander 500 with which I drilled holes in the African sky. Pity the Shrike is not shown on your website. How much do you want for it, just as a matter of interest and what's the registration? Nico van Niekerk Agoura Hills California ----- Original Message ----- From: "Southern Right Air Charter" <flights(at)sr.co.za> Subject: Commander-List: Commander for sale > > I have a 500S for sale in South Africa. Anyone interested? I will be able to > ferry it across to wherever, should a sale be possible. > > Regards > > Brad Watson > > Southern Right Air Charter > Cape Town International Airport > P.O. Box 43862 > FISH HOEK > 7974 > flights(at)sr.co.za > Tel +27 21 786-1962 > Fax +27 21 786-1457 > Cell +27 82 384-0044 > www.sr.co.za > > ________________________________________________________________________________
Date: May 25, 2004
Brad, If you are interested in the trade I proposed in the email you saw, I would be interested. If so I can send information on the shopping center. Thank You Bobby Sather 435-862-9534 ----- Original Message ----- From: "Southern Right Air Charter" <flights(at)sr.co.za> Subject: Commander-List: Commander for sale > > I have a 500S for sale in South Africa. Anyone interested? I will be able to > ferry it across to wherever, should a sale be possible. > > Regards > > Brad Watson > > Southern Right Air Charter > Cape Town International Airport > P.O. Box 43862 > FISH HOEK > 7974 > flights(at)sr.co.za > Tel +27 21 786-1962 > Fax +27 21 786-1457 > Cell +27 82 384-0044 > www.sr.co.za > > ________________________________________________________________________________
Date: May 26, 2004
Thanks Bobby, but I would need a straight sale, as I am in South Africa, and not needing property across there at moment! Regards Brad Southern Right Air Charter Cape Town International Airport P.O. Box 43862 FISH HOEK 7974 flights(at)sr.co.za Tel +27 21 786-1962 Fax +27 21 786-1457 Cell +27 82 384-0044 www.sr.co.za ________________________________________________________________________________
Date: May 26, 2004
From: W J R HAMILTON <wjrhamilton(at)optusnet.com.au>
Brad, Could you please let me have a full specification and pictures, plus indicative price, please. I am in Australia. Regards, Bill Hamilton. At 22:11 25/05/2004, you wrote: > > >I have a 500S for sale in South Africa. Anyone interested? I will be able to >ferry it across to wherever, should a sale be possible. > >Regards > >Brad Watson > >Southern Right Air Charter >Cape Town International Airport >P.O. Box 43862 >FISH HOEK >7974 >flights(at)sr.co.za >Tel +27 21 786-1962 >Fax +27 21 786-1457 >Cell +27 82 384-0044 >www.sr.co.za > > CONFIDENTIALITY & PRIVILEGE NOTICE W.J.R.Hamilton,Glenalmond Group Companies,Fighter Flights Internet Services and Warbirds.Net. & . This message is intended for and should only be used by the addressee. It is confidential and may contain legally privileged information.If you are not the intended recipient any use distribution,disclosure or copying of this message is strictly prohibited.Confidentiality and legal privilege attached to this communication are not waived or lost by reason of the mistaken delivery to you.If you have received this message in error, please notify us immediately to Australia 61 (0)408 876 526 ________________________________________________________________________________
Subject: Re:
Date: May 26, 2004
Mason, This might be a good idea for several of us. I have some decent parts (old radar dome and so forth) that someone might want. I would give them to a good home. Moe ----- Original Message ----- From: "MASON CHEVAILLIER" <KAMALA(at)msn.com> Subject: Commander-List: > > moe, if you are looking for parts, I am going to bring everything off of and out of 2001m to the meeting in sept. if anyone needs anything there we do not plan on bringing any of it back to fort worth. mason 817-877-4977 > > ________________________________________________________________________________
Subject: Re: mander-List:
Date: May 26, 2004
moe, we should sell them for a low price, get some gas money to pay for tri[p ----- Original Message ----- From: Moe<mailto:moe(at)rosspistons.com> To: commander-list(at)matronics.com Sent: Wednesday, May 26, 2004 3:02 PM Subject: Re: Commander-List: Mason, This might be a good idea for several of us. I have some decent parts (old radar dome and so forth) that someone might want. I would give them to a good home. Moe ----- Original Message ----- From: "MASON CHEVAILLIER" <KAMALA(at)msn.com<mailto:KAMALA(at)msn.com>> To: "commander-list" > Subject: Commander-List: > > moe, if you are looking for parts, I am going to bring everything off of and out of 2001m to the meeting in sept. if anyone needs anything there we do not plan on bringing any of it back to fort worth. mason 817-877-4977 > > ________________________________________________________________________________
Subject: for sale, or trade for commercial property :)
Date: May 24, 2004
Gang, Just a reminder that my 680E is still for sale. Morris Kernick is in the middle of replacing the landing gear trusses, engine mounts, and all FWF hoses, lines, etc. When this thing is finished it will be the most mechanically sound 680E out there, much to the chagrin of my wallet. Airplane should be good for another 50 years when it's done.... If anyone is interested, please contact me directly. Price when finished will be around $125K (or $30K less than I have in it!), but it's negotiable right now as work is ongoing.... Cheers, Barry (949) 300-5510 ________________________________________________________________________________
Date: May 29, 2004
Subject: THANKS!
HI KIDS. Just a quick thanks to all those who have sent their 2004 flyin registration. It looks like it will be a great event. For those who haven't, please send yours today. Earl registration is crucial to a successful event. Thanks!! jb PS Thanks to all who have renewed your TCFG membership as well!! jb ________________________________________________________________________________
Date: May 29, 2004
Subject: Re: THANKS!
I have reported you for spamming me! ________________________________________________________________________________
Date: May 29, 2004
Jim I didn't get a Packet !!!! Harry ----- Original Message ----- From: <YOURTCFG(at)aol.com> Subject: Commander-List: THANKS! > > HI KIDS. > Just a quick thanks to all those who have sent their 2004 flyin > registration. It looks like it will be a great event. For those who haven't, > please send yours today. Earl registration is crucial to a successful event. > Thanks!! jb > > PS Thanks to all who have renewed your TCFG membership as well!! jb > > ________________________________________________________________________________
Subject: Re: Looking to buy
Date: May 29, 2004
Any word for me Harry? Tom Fisher ________________________________________________________________________________
Date: May 29, 2004
In a message dated 5/29/2004 1:55:08 PM Pacific Standard Time, Ladyrat01(at)aol.com writes: I have reported you for spamming me! What?? ________________________________________________________________________________
Date: May 29, 2004
In a message dated 5/29/2004 1:56:20 PM Pacific Standard Time, avtec2(at)bellsouth.net writes: Jim I didn't get a Packet !!!! Harry Sorry, I will mail it next week. jb ________________________________________________________________________________
Subject: De-ice boots
Date: May 30, 2004
Hi Guys, I was recently asked if I could help with the following and I thought that through the chatlist was probably the best way. Ice Shield are a division of BAE Aerospace and make de-ice boots for wings and props. They are looking for a Commander 560, 560A, 680 with the series 23 de-ice boots to complete an STC. They will provide the boots free of charge but installation will cost 3-5K and I think will be done in Tipton, Ohio USA. If anyone is interested in supporting their STC and in need of new boots, the contact info is: Willis_Green(at)baeaerospace.com 800-767-6899 www.iceshield.com ________________________________________________________________________________
Date: May 30, 2004
jim, I DID NOT RECEIVE A PACKET FOR THE FLY IN . PLEASE COUNT ME IN, ESPECIALLY IF I CAN GET MY PLANE BACK. MASON ----- Original Message ----- From: avtec2(at)bellsouth.net To: commander-list(at)matronics.com Sent: Saturday, May 29, 2004 3:53 PM Subject: Re: Commander-List: THANKS! Jim I didn't get a Packet !!!! Harry ----- Original Message ----- From: <YOURTCFG(at)aol.com> To: Subject: Commander-List: THANKS! > > HI KIDS. > Just a quick thanks to all those who have sent their 2004 flyin > registration. It looks like it will be a great event. For those who haven't, > please send yours today. Earl registration is crucial to a successful event. > Thanks!! jb > > PS Thanks to all who have renewed your TCFG membership as well!! jb > > ________________________________________________________________________________
Date: May 30, 2004
JIM, I WILL BE THERE. MASON ----- Original Message ----- From: YOURTCFG(at)aol.com To: commander-list(at)matronics.com Sent: Saturday, May 29, 2004 3:32 PM Subject: Commander-List: THANKS! HI KIDS. Just a quick thanks to all those who have sent their 2004 flyin registration. It looks like it will be a great event. For those who haven't, please send yours today. Earl registration is crucial to a successful event. Thanks!! jb PS Thanks to all who have renewed your TCFG membership as well!! jb ________________________________________________________________________________
Date: May 30, 2004
In a message dated 5/30/2004 6:12:08 AM Pacific Standard Time, KAMALA(at)msn.com writes: JIM, I WILL BE THERE. MASON Great!! Are you a TCFG member??. I sent the registration forms with the last newsletter. jb ________________________________________________________________________________
Date: May 31, 2004
have not rcd news letter. thought I joined tcfg at last meeting in ohio. MASON CHEVAILLIER, 910 COLLIER ST., FORT WORTH, TX 76102 817-877-4977 TC680FP 2001M ----- Original Message ----- From: YOURTCFG(at)aol.com To: commander-list(at)matronics.com Sent: Sunday, May 30, 2004 11:16 AM Subject: Re: Commander-List: THANKS! In a message dated 5/30/2004 6:12:08 AM Pacific Standard Time, KAMALA(at)msn.com writes: JIM, I WILL BE THERE. MASON Great!! Are you a TCFG member??. I sent the registration forms with the last newsletter. jb ________________________________________________________________________________
From: "Jerry Sprayberry" <capnspray(at)hotmail.com>
Date: May 31, 2004
have not rcd news letter. thought I joined tcfg at last meeting in ohio. Mason, Your not the only one in this boat. "Me Too". Cap'n Spray ----- Original Message ----- From: "MASON CHEVAILLIER" <KAMALA(at)msn.com> Subject: Re: Commander-List: THANKS! > > have not rcd news letter. thought I joined tcfg at last meeting in ohio. MASON CHEVAILLIER, 910 COLLIER ST., FORT WORTH, TX 76102 817-877-4977 TC680FP 2001M > ----- Original Message ----- > From: YOURTCFG(at)aol.com > To: commander-list(at)matronics.com > Sent: Sunday, May 30, 2004 11:16 AM > Subject: Re: Commander-List: THANKS! > > > In a message dated 5/30/2004 6:12:08 AM Pacific Standard Time, KAMALA(at)msn.com > writes: > JIM, I WILL BE THERE. MASON > Great!! Are you a TCFG member??. I sent the registration forms with the last > newsletter. jb > > ________________________________________________________________________________
Date: May 31, 2004
Subject: [ Matt Dralle ] : New Email List Photo Share Available!
From: Email List Photo Shares <pictures(at)matronics.com>
A new Email List Photo Share is available: Poster: Matt Dralle Subject: WWII Bombers at Livermore California - May 31 2004 http://www.matronics.com/photoshare/dralle@matronics.com.05.31.2004/index.html o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ________________________________________________________________________________
Date: Jun 01, 2004
In a message dated 5/31/2004 12:52:31 PM Pacific Standard Time, KAMALA(at)msn.com writes: have not rcd news letter. thought I joined tcfg at last meeting in ohio. MASON CHEVAILLIER, 910 COLLIER ST., FORT WORTH, TX 76102 817-877-4977 TC680FP 2001M Sorry. I will have it in the mail tomorrow. jb ________________________________________________________________________________
Date: Jun 01, 2004
In a message dated 5/31/2004 3:27:00 PM Pacific Standard Time, capnspray(at)hotmail.com writes: Mason, Your not the only one in this boat. "Me Too". Cap'n Spray What is your address?? jb ________________________________________________________________________________
Date: Jun 01, 2004
(Release 5.0.8 |June 18, 2001) at 06/01/2004 08:44:33 AM Jim, I have not rec'd mine either, however, I am not an official member but my son and I love Commanders (my dad flew in the prototype and flew 520's & 560's for 10 years). I may have spoken to you (via email) a while back about getting a registration form. Please send to: Tom Kinnaird 2900 Englewood Ave. Louisville, KY 40220 Thanks. Tom Kinnaird Commercial Real Estate - Louisville 502-566-5879 This transmission may contain information that is privileged, confidential and/or exempt from disclosure under applicable law. If you are not the intended recipient, you are hereby notified that any disclosure, copying, distribution, or use of the information contained herein (including any reliance thereon) is STRICTLY PROHIBITED. If you received this transmission in error, please immediately contact the sender and destroy the material in its entirety, whether in electronic or hard copy format. Thank you. ________________________________________________________________________________
Date: Jun 01, 2004
Same as ever. 8 Maddox Lake Road Summerville, Ga 30747 ----- Original Message ----- From: <YOURTCFG(at)aol.com> Subject: Re: Commander-List: THANKS! > > In a message dated 5/31/2004 3:27:00 PM Pacific Standard Time, > capnspray(at)hotmail.com writes: > Mason, Your not the only one in this boat. "Me Too". > > Cap'n Spray > What is your address?? jb > > ________________________________________________________________________________
Date: Jun 01, 2004
In a message dated 6/1/2004 5:46:05 AM Pacific Standard Time, tom_kinnaird(at)bankone.com writes: Tom Kinnaird 2900 Englewood Ave. Louisville, KY 40220 Thanks Tom. Your registration form is already on the way. Great to have you on the list. jb ________________________________________________________________________________
Subject: Fly-In and Convention
Date: Jun 03, 2004
JB Just called the K.C. Marriott Downtown at 816.421.6800 and they could not find a discount listing for us. Please advise as to how we get on the deal. Moe N680RR ________________________________________________________________________________
Subject:
Date: Jun 03, 2004
does anyone have a foldaway/storeaway side table worktable game table for a commander available for sale? thanks mason kamala(at)msn.com ________________________________________________________________________________
Date: Jun 04, 2004
Subject: Twin Commander at Mid America Air Museum
L26, AC 520, N711YY, Serial Number 520-76 On a recent driving trip through Kansas, I stopped at the Mid America Air Museum in Liberal, KS. www.liberalairmuseum.com. They have over 100 aircraft on display in a former Beech factory building. One of them is a AC 520 in army paint. It is open for visitors to get into unlike most of the aircraft. It is popular with the children since they can get into to it and sit in the pilot seat. The door is off to allow easy access. It is in good condition being stored inside. It looks ready to fly except for some dust. There is a photo on their web site. Tylor Hall ________________________________________________________________________________
From: "Randy Dettmer, AIA" <rcdettmer(at)charter.net>
Subject: Re: Twin Commander at Mid America Air Museum
Date: Jun 04, 2004
Hi Tyler, On my first trip to Oshkosh as co-pilot of a Martin 404, we stopped at Liberal for the night. The folks at the museum treated us like kings (of course, they were pretty interested in our 1952 M404). We had blown a tire on the way out of Grand Junction, CO (after a single engine approach and landing...that's another story). Took us until 11PM working madly to change the tire and install the spare while a Kansas thunderstorm threatened to blown the Martin off the jack...what an experience. If you all get a chance, stop in Liberal and enjoy their fine museum. Thanks Tyler for sharing your experience. Randy Dettmer 680F/N6253X ----- Original Message ----- From: "Tylor Hall" <tylor.hall(at)sbcglobal.net> Subject: Commander-List: Twin Commander at Mid America Air Museum > > L26, AC 520, N711YY, Serial Number 520-76 > On a recent driving trip through Kansas, I stopped at the Mid America Air Museum in Liberal, KS. www.liberalairmuseum.com. > They have over 100 aircraft on display in a former Beech factory building. One of them is a AC 520 in army paint. It is open for visitors to get into unlike most of the aircraft. It is popular with the children since they can get into to it and sit in the pilot seat. The door is off to allow easy access. It is in good condition being stored inside. It looks ready to fly except for some dust. > > There is a photo on their web site. > > Tylor Hall > > ________________________________________________________________________________
Date: Jun 04, 2004
Randy, This won't in any way inhibit our ability to think straight? Especially so close to the elections. :-) Nico ----- Original Message ----- From: "Randy Dettmer, AIA" <rcdettmer(at)charter.net> Subject: Re: Commander-List: Twin Commander at Mid America Air Museum > > Hi Tyler, > On my first trip to Oshkosh as co-pilot of a Martin 404, we stopped at > Liberal for the night. The folks at the museum treated us like kings (of > course, they were pretty interested in our 1952 M404). We had blown a tire > on the way out of Grand Junction, CO (after a single engine approach and > landing...that's another story). Took us until 11PM working madly to change > the tire and install the spare while a Kansas thunderstorm threatened to > blown the Martin off the jack...what an experience. > > If you all get a chance, stop in Liberal and enjoy their fine museum. > Thanks Tyler for sharing your experience. > > Randy Dettmer > 680F/N6253X > > > ----- Original Message ----- > From: "Tylor Hall" <tylor.hall(at)sbcglobal.net> > To: "TCFG" > Subject: Commander-List: Twin Commander at Mid America Air Museum > > > > > > > L26, AC 520, N711YY, Serial Number 520-76 > > On a recent driving trip through Kansas, I stopped at the Mid America Air > Museum in Liberal, KS. www.liberalairmuseum.com. > > They have over 100 aircraft on display in a former Beech factory building. > One of them is a AC 520 in army paint. It is open for visitors to get into > unlike most of the aircraft. It is popular with the children since they can > get into to it and sit in the pilot seat. The door is off to allow easy > access. It is in good condition being stored inside. It looks ready to fly > except for some dust. > > > > There is a photo on their web site. > > > > Tylor Hall > > > > > > ________________________________________________________________________________
Date: Jun 04, 2004
It's dangerous to be thinking close to an election. RD ----- Original Message ----- From: "nico css 2" <nico(at)cybersuperstore.com> Subject: Re: Commander-List: Twin Commander at Mid America Air Museum > > Randy, > > This won't in any way inhibit our ability to think straight? Especially so > close to the elections. :-) > > Nico > > > ----- Original Message ----- > From: "Randy Dettmer, AIA" <rcdettmer(at)charter.net> > To: > Subject: Re: Commander-List: Twin Commander at Mid America Air Museum > > > > > > > Hi Tyler, > > On my first trip to Oshkosh as co-pilot of a Martin 404, we stopped at > > Liberal for the night. The folks at the museum treated us like kings (of > > course, they were pretty interested in our 1952 M404). We had blown a > tire > > on the way out of Grand Junction, CO (after a single engine approach and > > landing...that's another story). Took us until 11PM working madly to > change > > the tire and install the spare while a Kansas thunderstorm threatened to > > blown the Martin off the jack...what an experience. > > > > If you all get a chance, stop in Liberal and enjoy their fine museum. > > Thanks Tyler for sharing your experience. > > > > Randy Dettmer > > 680F/N6253X > > > > > > ----- Original Message ----- > > From: "Tylor Hall" <tylor.hall(at)sbcglobal.net> > > To: "TCFG" > > Subject: Commander-List: Twin Commander at Mid America Air Museum > > > > > > > > > > > > L26, AC 520, N711YY, Serial Number 520-76 > > > On a recent driving trip through Kansas, I stopped at the Mid America > Air > > Museum in Liberal, KS. www.liberalairmuseum.com. > > > They have over 100 aircraft on display in a former Beech factory > building. > > One of them is a AC 520 in army paint. It is open for visitors to get > into > > unlike most of the aircraft. It is popular with the children since they > can > > get into to it and sit in the pilot seat. The door is off to allow easy > > access. It is in good condition being stored inside. It looks ready to > fly > > except for some dust. > > > > > > There is a photo on their web site. > > > > > > Tylor Hall > > > > > > > > > > > > ________________________________________________________________________________
Date: Jun 05, 2004
Subject: Re: Fly-In and Convention
In a message dated 6/3/2004 9:36:48 AM Pacific Standard Time, moe(at)rosspistons.com writes: ust called the K.C. Marriott Downtown at 816.421.6800 and they could not find a discount listing for us. Please advise as to how we get on the deal. I will call them, Thanks jb ________________________________________________________________________________
Date: Jun 06, 2004
Subject: [ L. Don Girod ] : New Email List Photo Share Available!
A new Email List Photo Share is available: Poster: L. Don Girod Subject: 560E Aero Commander http://www.matronics.com/photoshare/dongirod@earthlink.net.06.06.2004/index.html o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ________________________________________________________________________________
Date: Jun 07, 2004
JB Thanks! Please advise when we are set up there and I will make my reservations. Best regards, Moe ----- Original Message ----- From: <YOURTCFG(at)aol.com> Subject: Re: Commander-List: Fly-In and Convention > > In a message dated 6/3/2004 9:36:48 AM Pacific Standard Time, > moe(at)rosspistons.com writes: > > ust called the K.C. Marriott Downtown at 816.421.6800 and they could not > find a discount listing for us. Please advise as to how we get on the deal. > I will call them, Thanks jb > > ________________________________________________________________________________
Date: Jun 07, 2004
In a message dated 6/7/2004 2:37:41 PM Pacific Standard Time, moe(at)rosspistons.com writes: Please advise when we are set up there and I will make my reservations. Should be Wendsday?? I'll let you know. jb ________________________________________________________________________________
Date: Jun 15, 2004
Subject: aaccumulator o/h 500A
anyone have a good source to overhaul a 500a accumulator? what is a fair price? thanks al hoffman ________________________________________________________________________________
Subject: You`ve got 1 VoiceMessage!
Date: - - - , 20-
Dear Customer! You`ve got 1 VoiceMessage from voicemessage.com website! You can listen your Virtual VoiceMessage at the following link: http://virt.voicemessage.com/index.listen.php2=35affv or by clicking the attached link. Send VoiceMessage! Try our new virtual VoiceMessage Empire! Best regards: SNAF.Team (R). ________________________________________________________________________________
Subject: Re: You`ve got 1 VoiceMessage!
Date: Jun 15, 2004
IS THIS A VALID EMAIL? Tom Fisher ----- Original Message ----- From: "Russell Johnson" <entec1(at)pld.com> Subject: Commander-List: You`ve got 1 VoiceMessage! > > Dear Customer! > > You`ve got 1 VoiceMessage from voicemessage.com website! > You can listen your Virtual VoiceMessage at the following link: > http://virt.voicemessage.com/index.listen.php235affv > or by clicking the attached link. > > Send VoiceMessage! Try our new virtual VoiceMessage Empire! > Best regards: SNAF.Team (R). > > > ________________________________________________________________________________
Date: Jun 15, 2004
Tom, I don't think so. If so it was from the commander group, I think the return address would reflect. CAREFULL how you open. Bobby Sather ----- Original Message ----- From: "Tom Fisher" <tfisher(at)commandergroup.bc.ca> Subject: Re: Commander-List: You`ve got 1 VoiceMessage! > > IS THIS A VALID EMAIL? > > Tom Fisher > > ----- Original Message ----- > From: "Russell Johnson" <entec1(at)pld.com> > To: > Subject: Commander-List: You`ve got 1 VoiceMessage! > > > > > > Dear Customer! > > > > You`ve got 1 VoiceMessage from voicemessage.com website! > > You can listen your Virtual VoiceMessage at the following link: > > http://virt.voicemessage.com/index.listen.php235affv > > or by clicking the attached link. > > > > Send VoiceMessage! Try our new virtual VoiceMessage Empire! > > Best regards: SNAF.Team (R). > > > > > > > > ________________________________________________________________________________
Date: Jun 15, 2004
Subject: accumulator for 500A
i need an o/h of my accumulator. any suggestions? al hoffman ________________________________________________________________________________
Subject: Re: accumulator for 500A
Date: Jun 15, 2004
I notice you did not get a public response earlier so I had one item from this past May and I have posted it here in it's entirety. Don't know if it is going to help you at all but there you go anyway. Tom F. (Still looking for a 680FLP) ******************************************* Hi Everyone, This is just a follow up on my efforts to get my accumulator charged and working properly. Now you are all probably thinking, What a loser. This guy doesnt even know how to service his hydraulic accumulator. So for the one other Commander owner out there who doesnt know how to do this, here are the tricks I learned over the last week. 1. Connect 600 psi nitrogen to the accumulator fitting and make sure the fitting is open by turning the locknut counterclockwise at least 2 turns. Leave the nitrogen source ON and the regulator set for 600 psi +25 / -0 psi. 2. With all power OFF (engine driven and aux pumps), move the flap handle from the neutral position up or down VERY slowly until you hear the pressure bleed down to zero (you can see this happen on the gauge and you can hear it through the flap valve). It turns out the flap valve has a bleed port which bleeds pressure just before going to the flap UP or flap DOWN position. If you move the handle slowly, you will hear pressure relieve and see the gauge go to zero 1/4" or so before getting to the flap UP or DOWN position. Now the piston in the accumulator is at the end of its stroke with 600 psi nitrogen on one side and 0 psi hydraulic fluid on the other. 3. Check your accumulator for internal leaks. Now that you have 600 psi on the accumulator, you can see and hear if the piston o ring is leaking. If you hear anything then open the hydraulic fluid reservoir to see if there is any foam or bubbles. If there is nothing, proceed to step 4. If you see bubbles and the thing is hissing away, take a deep breath and cancel any upcoming trips. The good news is that you can get the whole accumulator overhauled by Higher Planes for just $1800. And since those accumulators just jump in and out practically by themselves, its a real bargain! But if you need it done, they have a FAA approved overhaul for that component (along with other commander stuff like power brake valves). http://www.higherplanes.com/ 4. With the nitrogen still ON, tighten the lock nut on the fitting and remove the nitrogen fill hose (don't forget to turn off the Nitrogen before removing the fitting - 600 psi is A LOT of pressure). I believe this is the first time I've flown the airplane with the accumulator serviced properly. The hydraulic pressure gauge now barely moves, even when actuating the flaps, brakes, etc. It used to snap back and forth during flight and especially when using the system. When serviced properly, the accumulator does and excellent job of dampening the pressure in the system, to the point where there is almost no pressure fluctuation at all. If your gauge moves much at all or if you see any rapid movements, chances are you have flat or low accumulator pressure. The other trick to doing this properly is finding a nitrogen source that can go up to 600 psi. Almost everyone has a N2 bottle with the welder style regulator but most of those cannot regulate to 600 psi downstream pressure. I decided to look for the components to buy and I really had to search for a regulator that could regulate to 600 psi. Most regulators that I saw have maximum of 350 - 450 psi regulating ranges. They maybe go a little higher but you're lucky if your mechanic has the proper rig. If you are planning to build your own rig, plan on spending about $500. Here are sources for everything you will need: 1) 110 cu foot or larger N2 bottle - any local welding shop. About $200 buys the bottle and refills are cheap. 2) 0 - 1500 psi high pressure regulator. Available from www.weldingsupply.com. Item # 3200300, about $230. 3) High pressure hose and N2 ground service fitting. Available from Hoses Unlimited (510-483-8520). They will make up a hose of any length and sell you the fill fitting as well. The regulator terminates in 1/4 NPT female so you want a hose with 1/4 NPT male on one end. So that's it. Anyone who is ever in the LVK area stop by for a free N2 fill. * Credit goes to the service manager at DownTown Airpark for telling me about that bleed port. ******************************************* ----- Original Message ----- From: <alh1(at)juno.com> Subject: Commander-List: accumulator for 500A > > > i need an o/h of my accumulator. any suggestions? al hoffman > > ________________________________________________________________________________
Date: Jun 15, 2004
What about these guys? http://www.aircraftaccessoriesofok.com/ bilbo ----- Original Message ----- From: <alh1(at)juno.com> Subject: Commander-List: accumulator for 500A > > > i need an o/h of my accumulator. any suggestions? al hoffman > > ________________________________________________________________________________
Date: Jun 15, 2004
just fyi, I've been using a place called "Quality Aircraft Accessories Inc" in Tulsa OK recently. I've been impressed with the quality of their work and they seem to have reasonable prices. They do hydraulic pumps, alternators, fuel pumps, prop governors, turbos, mags, , and most other accessories. They'll even do a one-day turnaround on many items if needed. I recently took a prop gov in for overhaul and they had it back in my hands in 48 hours even though I didn't request a quick turn. They have a very well equipped and clean shop and appear to have lots of people with substantial knowledge there. Their number is: 918-835-6948 chris ________________________________________________________________________________
Date: Jun 15, 2004
Subject: Re: Noise
Hi All I am having a great deal of fun trying to get a noise certificate from our local aviation department. Apart from the fact that all the rules apply to transport cat aircraft. Its like talking to a brick wall. It looks like I am going to have all the noise testing done. ANYBODY KNOW HOW TO SHUT A PAIR GSOs UP? I am open to all sugestions. I feel that this might help us in the future as almost all countries are starting to hassel us poor unfortunate folk who happen to drive these geared wonders. My thoughts so far involve 1) Perforated stacks inside a slim shroud. 2) Combining three stacks into one muffler 3) Lining the inside of the augmenter tube with a layer of fibre or mesh. Regards Richard ________________________________________________________________________________
Date: Jun 15, 2004
Subject: Re: Noise
In a message dated 6/15/2004 8:30:25 PM Pacific Standard Time, RnJThompson(at)aol.com writes: am open to all sugestions. I feel that this might help us in the future as almost all countries are starting to hassel us poor unfortunate folk who happen to drive these geared wonders. Contact Dick Ward at he Twin Bonanza Ass (_www.twinbonanza.com_ (http://www.twinbonanza.com) ). There was an article a few issues back about a Twinbo with mufflers in a Scandinavian County. It wasn't cheap, but I guess it worked. Or, how about a revolution. I think we need one here as well!! jb ________________________________________________________________________________
Date: Jun 15, 2004
Try Commander Aero, ask for Gary Kromer 937-885-5580. They are pretty simple. Unlike the old Commanders with a diaphragm type accumulator, these have only a couple of "O" rings. jb ________________________________________________________________________________
Date: Jun 16, 2004
Subject: Re: Noise
RnJThompson(at)aol.com wrote: > ANYBODY KNOW HOW TO SHUT A PAIR GSOs UP? Howdy Richard. Good to hear from ya! I think this is a really good question. The early piper aztecs had augmenter tubes, but they have a perforated liner with some sort of fiber material between the inner and outter liners. That difference eliminates an amazing amount of noise. I wouldn't be surprised if you couldn't just slide a pair of aztec tubes right into place on a commander for an easy test. Beyond that, you're going to have to add a muffler. That's going to be a little tricky to do without screwing up the cooling of the engine. I'd imagine that you'll need to combine three into one, then put the muffler across and exit into the opposite augmenter tube. Havn't tried that though :) Good luck! Chris ________________________________________________________________________________
Subject: RE: accumulator
Date: Jun 16, 2004
Hi Al, If you are referring to your hydraulic accumulator, then you have a couple options. I know all this because I just pulled mine and am waiting for an exchange unit as we speak. First, you have to make sure you really need a true overhaul because that will run about $2500. Most accumulator failures are due to the main o ring seal on the piston wearing out or the bore of the cylinder itself wearing or both. In my case, the accumulator leaked nitrogen in to the hydraulic system so I knew the seal was gone. When I pulled it and removed the cylinder part (the round part where the nitrogen goes) the o ring was shot but the bore itself was scored and worn through the anodizing. That means overhaul. There is only one place that has an FAA approved process to recoat the cylinder and bring it back to new dimensions. They also reseal the rest of it and test it. Call Bob Thormer at Higher Planes - (936) 494-1717. There is a Higher Planes overhauled unit on the shelf at Byerly Aviation. Call Ken in parts. If the cylinder bore looks good and there is no scoring, you can just replace the o ring and give that a shot. Chances are it will work OK for a while. The only problem is that it takes about 8 hours to R&R the accumulator so if you do it twice you just paid for some of the overhaul. Give me a call at 408 425 4393 and I can give you more details. Good luck. Regards, Scott ________________________________________________________________________________
Date: Jun 17, 2004
Subject: N50
HI KIDS... I just had a nice conversation with Ken from the FAA. No, really, it was a nice talk. It seems that the FAA is still operating a 680E in their fleet! Yep, N50 was purchased new by the feds and is still in their stable. It has about 7000 TT and is flown about 150 hr. each year. It is currently assigned to a project and flies daily. The FAA called because they want to install Cleveland brakes on the airplane and don't want the dual caliper style. Cleveland and TCAC sent them to the TCFG and I will be forwarding the paperwork. Pretty cool stuff. Also, I apologize for the lateness of the last newsletter. The next one, July, will be in the mail in a week or so and I think everyone will really enjoy it. That will put me back on track. There is a great story by Buddy Plaster about the restoration of his drop dead 560E, new everything!! Also, Wing Commander Gordon has a piece on the operation of the hydtahaulic system and emergency procedures for the flat nacelled airplanes. I wrote a companion piece for the bath tub models. "Sir" Barry Colman has a gerat historc article. Lots of other stuff. Next issue (Sept) will have a great article on the better than new restoration of a 500A form Commander Aero. Hope all of you are planning to attend the flyin, it is already the best response for this early, should be an absolute ball!! Hope all is well in your Commanderland. jb ________________________________________________________________________________
Subject: Re: N50
Date: Jun 17, 2004
Well, it seems that people "in the know" use a 680E! Even noisy ones down-under!! Barry (UK) ----- Original Message ----- From: <YOURTCFG(at)aol.com> Subject: Commander-List: N50 | | HI KIDS... | | I just had a nice conversation with Ken from the FAA. No, really, it was a | nice talk. It seems that the FAA is still operating a 680E in their fleet! | Yep, N50 was purchased new by the feds and is still in their stable. It has | about 7000 TT and is flown about 150 hr. each year. It is currently assigned | to a project and flies daily. | The FAA called because they want to install Cleveland brakes on the | airplane and don't want the dual caliper style. Cleveland and TCAC sent them to | the TCFG and I will be forwarding the paperwork. Pretty cool stuff. | Also, I apologize for the lateness of the last newsletter. The next | one, July, will be in the mail in a week or so and I think everyone will really | enjoy it. That will put me back on track. There is a great story by Buddy | Plaster about the restoration of his drop dead 560E, new everything!! Also, | Wing Commander Gordon has a piece on the operation of the hydtahaulic system | and emergency procedures for the flat nacelled airplanes. I wrote a companion | piece for the bath tub models. "Sir" Barry Colman has a gerat historc | article. Lots of other stuff. | Next issue (Sept) will have a great article on the better than new | restoration of a 500A form Commander Aero. Hope all of you are planning to attend | the flyin, it is already the best response for this early, should be an | absolute ball!! Hope all is well in your Commanderland. jb | | | | | | | ________________________________________________________________________________
Date: Jun 17, 2004
Subject: Re: N50
Hey Barry, Can you tell me what the serial number was for the 680fl that NASA used I think it was N801NA or just NASA 801? ________________________________________________________________________________
Subject: Re: N50
Date: Jun 17, 2004
Hi Bert, The 680F(P) NASA had was s/n 1288-131. Originally N6297X, it became NASA801, then N801NA. Transferred to the US Customs as N10710. It was withdrawn from use in June 1997 and I think is with US Air Salvage Inc., in Johnson City, TN. Kindest Regards, Barry P.S. I'll be responding to your other list shortly! ----- Original Message ----- From: <BertBerry1(at)aol.com> Subject: Re: Commander-List: N50 | | Hey Barry, | | Can you tell me what the serial number was for the 680fl that NASA used I | think it was N801NA or just NASA 801? | | | | | | | ________________________________________________________________________________
Date: Jun 17, 2004
Subject: Re: N50
Thanks Much, as always, your the Man. Bert ________________________________________________________________________________
Date: Jun 18, 2004
Subject: Re: Noise
Richard, Please give me a ring, 0408 876 526 or 02 9499 8283. There should not be a problem for you in issuing a noise certificate under the Air Navigation Act, yours is not the only aircraft flying with these engines and props, effectively you have grandfather right, and there are some other considerations. However, in Australia, all aircraft have to have a noise certificate, not just transport cat. aircraft. I have ongoing discussions under way with DOTARS, some of the low level minions have been causing trouble. Bill Hamilton. At 13:29 16/06/2004, you wrote: > >Hi All > >I am having a great deal of fun trying to get a noise certificate from our >local aviation department. Apart from the fact that all the rules apply to >transport cat aircraft. Its like talking to a brick wall. It looks like I >am going >to have all the noise testing done. > >ANYBODY KNOW HOW TO SHUT A PAIR GSOs UP? > >I am open to all sugestions. >I feel that this might help us in the future as almost all countries are >starting to hassel us poor unfortunate folk who happen to drive these geared >wonders. > >My thoughts so far involve > >1) Perforated stacks inside a slim shroud. >2) Combining three stacks into one muffler >3) Lining the inside of the augmenter tube with a layer of fibre or mesh. > >Regards >Richard > > CONFIDENTIALITY & PRIVILEGE NOTICE W.J.R.Hamilton,Glenalmond Group Companies,Fighter Flights Internet Services and Warbirds.Net. & . This message is intended for and should only be used by the addressee. It is confidential and may contain legally privileged information.If you are not the intended recipient any use distribution,disclosure or copying of this message is strictly prohibited.Confidentiality and legal privilege attached to this communication are not waived or lost by reason of the mistaken delivery to you.If you have received this message in error, please notify us immediately to Australia 61 (0)408 876 526 ________________________________________________________________________________
Date: Jun 23, 2004
Subject: flyin
Anyone have any details on what the seminars are going to be for this years fly-in and who will be speaking? Any of my old friends going to be there? chris ________________________________________________________________________________
Date: Jun 23, 2004
Subject: Re: flyin
Hey Chris, Mark Poulin from Carolina. I haven't seen you since "Hillsboro". I tried to make it the last to years and was not able to. Hopefully this year!?! Have you ever found anything to replace your Bellanca? Best Regards, Mark ________________________________________________________________________________
Date: Jun 23, 2004
Subject: Re: flyin
MRP wrote: > Hey Chris, > Have you ever found anything to replace your Bellanca? Hey Mark! Good to hear from you. I didn't know you were still around and on the list. I made the S.C. flyin, but missed last year. Just a bit too much trauma and too few $$$ available. Yes, I did acquire a new project/airplane - take a look at: http://members.cox.net/cschuerm/ and tell me what you think. cheers chris ________________________________________________________________________________
From: "Martini Luc J.R." <martini(at)foxinternet.net>
Subject: Re: flyin
Date: Jun 23, 2004
Hi I sure would like to know what you used to get the old paint off your projects. While your at it, you might tell me about how you neutralized the Paint Stripper caustic compounds (I've heard flusing with a lot of water just doesn't hack it, because residue caught in lap joints etc, will only cause the New Paint in those areas to deteriorate and probably result in corrosion. And, since I haven't asked anything hard so far ..... tell me all about how NOT to remove paint. I have heard of horror stories resulting from using wirebrushes (however soft, i.e. fine steel or brass wire brush, particular rotary types) on ALCLAD Aluminum, which even after subsequently being Allodined and receiving a good paint job, resulted in severe granular corrosion setting in over a matter of only a couple of years. I know the preferred thing to use is ScotchbritePads... Is there anything available to help get into tight places like an ALUMINUM WIRE BRUSH that could be used instead of a STEEL wire brush? EAA had an article on Corrosion a few months back, but I gave my copy away, and now can't find it anywhere so I can REREAD the advise..... although I don't think they said much about what using a Steel Brush will do to ALCLAD. ----- Original Message ----- From: "Chris Schuermann" <cschuerm(at)cox.net> Subject: Re: Commander-List: flyin > > > MRP wrote: > > Hey Chris, > > Have you ever found anything to replace your Bellanca? > > Hey Mark! > Good to hear from you. I didn't know you were still around and on the > list. I made the S.C. flyin, but missed last year. Just a bit too much > trauma and too few $$$ available. > Yes, I did acquire a new project/airplane - take a look at: > http://members.cox.net/cschuerm/ > and tell me what you think. > > cheers > chris > > ________________________________________________________________________________
Date: Jun 24, 2004
Subject: Re: Paint work
Martini Luc J.R. wrote: > While your at it, you might tell me about how you neutralized the Paint > Stripper caustic compounds You are quite correct that the pre-paint prep work is VERY important. We used traditional chemical stripper for the majority of the airframe. (with wooden scrapers and scotchbrite pads) The post strip cleanup was very thourough. Every part was carefully washed with water and a neutralizer, then washed again with a steam cleaner with special attention to all the edges, gaps, and rivets. Every seam was "scrubbed" with nylon bristle toothbrushes. After that, the airframe was scrubbed with scotchbrite pads to give a good surface for the paint to adhere to. A final cleaning with MEK was done next. After that was completed, the airframe was treated with alodine, then re-washed prior to the epoxy zinc chromate primer. Now that the paint has fully cured, I'll be going back and "fogging" the interior with ACF50 which will kill any possibility of corrosion from any chemicals which may still have residual traces around. ACF50 is the most amazing stuff - it will even penetrate around rivets and the tightest seams. I have heard of horror stories resulting from using > wirebrushes Correct - use of any metalic brush will embed tiny pieces of the brush material into the aluminum and absolutely WILL result in damaging corrosion. Never ever use a metal brush of any type! A nylon bristle brush is the best choice, but must be used with care as chemical cleaners such as MEK will disolve the bristles and leave goo on the airplane. The whole process isn't perfect, but with sufficient care, the amount of residual stripper can minimized. You'll note that we had the airplane substantially disassembled during the process - this was to assure that we could maximize the cleaning process. Short of drilling apart the skins and prepping each part at the component level, I think that's the best that can be done. As an alternative, there are some shops which are using plastic media blasting to strip old paint. In my opinion, that is a good technology, but without great care can damage thin alumiinum skins. The Piper has a lot of pretty thin sheet metal since it's mostly a non-stressed skin design, so I wasn't comfortable using that method. hope this helped Chris ________________________________________________________________________________
Date: Jun 24, 2004
Subject: 1954 520 Aero Commander at Ebay
Hello group, May be You hav not yet recognized this fine gal at Ebay. She looks like to be worth to be kept airworthy. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=26428&item=2482527873&rd=1 <http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=26428&item=2482527873&rd=1> best regards from germany Volkmar Volkmar Salm Phone +49 7802 980 500 Fax +49 7802 980 954 salm(at)aerocommander.de ________________________________________________________________________________
Date: Jun 24, 2004
Subject: Re: flyin
G'day Chris, We sure missed you last year at the Commander Aero show. It is highly likely that your "Down-under" pals from Oz will be at Kansas City Downtown this year; talking a lot about flying Commanders the "right way up"! Cheers from Oz Russell (still looking for a 560E or maybe a Straight 500) On 24/6/04 10:15 AM, "Chris Schuermann" wrote: > > Anyone have any details on what the seminars are going to be for this > years fly-in and who will be speaking? > > Any of my old friends going to be there? > > chris > > > > > > ________________________________________________________________________________
Date: Jun 24, 2004
there is also a process used by texas aerocolor in brady, tx that uses hydrogenperoxide to strip plane w/o residue to corode. mason >From: Chris Schuermann <cschuerm(at)cox.net> >Reply-To: commander-list(at)matronics.com >To: commander-list(at)matronics.com >Subject: Re: Commander-List: Paint work >Date: Thu, 24 Jun 2004 07:37:43 -0500 > > >Martini Luc J.R. wrote: > > While your at it, you might tell me about how you neutralized the Paint > > Stripper caustic compounds > >You are quite correct that the pre-paint prep work is VERY important. >We used traditional chemical stripper for the majority of the airframe. > (with wooden scrapers and scotchbrite pads) The post strip cleanup was >very thourough. Every part was carefully washed with water and a >neutralizer, then washed again with a steam cleaner with special >attention to all the edges, gaps, and rivets. Every seam was "scrubbed" >with nylon bristle toothbrushes. After that, the airframe was scrubbed >with scotchbrite pads to give a good surface for the paint to adhere to. > A final cleaning with MEK was done next. >After that was completed, the airframe was treated with alodine, then >re-washed prior to the epoxy zinc chromate primer. Now that the paint >has fully cured, I'll be going back and "fogging" the interior with >ACF50 which will kill any possibility of corrosion from any chemicals >which may still have residual traces around. ACF50 is the most amazing >stuff - it will even penetrate around rivets and the tightest seams. > > I have heard of horror stories resulting from using > > wirebrushes > >Correct - use of any metalic brush will embed tiny pieces of the brush >material into the aluminum and absolutely WILL result in damaging >corrosion. Never ever use a metal brush of any type! A nylon bristle >brush is the best choice, but must be used with care as chemical >cleaners such as MEK will disolve the bristles and leave goo on the >airplane. > >The whole process isn't perfect, but with sufficient care, the amount of >residual stripper can minimized. You'll note that we had the airplane >substantially disassembled during the process - this was to assure that >we could maximize the cleaning process. Short of drilling apart the >skins and prepping each part at the component level, I think that's the >best that can be done. As an alternative, there are some shops which >are using plastic media blasting to strip old paint. In my opinion, >that is a good technology, but without great care can damage thin >alumiinum skins. The Piper has a lot of pretty thin sheet metal since >it's mostly a non-stressed skin design, so I wasn't comfortable using >that method. > >hope this helped >Chris > > ________________________________________________________________________________
Subject: Re: flyin
Date: Jun 24, 2004
What a nice project, Chris. It didn't help the other folks that it was located next to a grave yard either, huh? Nico ----- Original Message ----- From: "Chris Schuermann" <cschuerm(at)cox.net> Subject: Re: Commander-List: flyin > > > MRP wrote: > > Hey Chris, > > Have you ever found anything to replace your Bellanca? > > Hey Mark! > Good to hear from you. I didn't know you were still around and on the > list. I made the S.C. flyin, but missed last year. Just a bit too much > trauma and too few $$$ available. > Yes, I did acquire a new project/airplane - take a look at: > http://members.cox.net/cschuerm/ > and tell me what you think. > > cheers > chris > > ________________________________________________________________________________
Date: Jun 24, 2004
Subject: Re: flyin
Chris, All I can say is WOW!, but that doesn't quite cut it. AWESOME job! The Fly-in forms are on my desk, and will go out today. Jim, what's the count so far? Mark ________________________________________________________________________________
Date: Jun 24, 2004
Subject: Re: flyin
Chris, Piper build fine aircraft. Can not say the same for Cessna I WOULD RATHER PUSH MY AERO COMMANDER THAN FLY A CESSNA! Oops ( I own a Cessna) Enough of that. Back on the issue of noise. I have teamed up with one of the formost experts in this field. we have discovered that there are some glaring deficiencies in the test regimes of your beloved FAA and others. I am being forced to test my airplane to ICAO Annex 16 Chapter 6 regulations. The main problem that has arisen is exactly what configuration the aircaft has to be in . The interesting thing is that our noise regulator Airservices have put forward a set of parameters that they will accept. Our aircraft regulator CASA has decreed that the flight profile that the noise boys require is ILLEGAL interms of Australian legislation. So I am beginning to enjoy all of this. It is unusual to have the regulator on my side for once. I will keep you all posted on events. One thing that will happen is that the aircraft will be tested and certified to be compliant in accordance with the ICAO rules. I am going to make this information and all test results availiable to all of you and to TCAC. So if anyone has this problem in the future you will have up to date data to fight with. Regards Richard ________________________________________________________________________________
Date: Jun 25, 2004
Subject: Re: flyin
Folks, Just adding a little bit to Richard's noise story, in fact what the noise nazi's want is the aircraft to be operated outside the FAA AFM Operating Limitations, given that such tests were completed in this fashion, the test results would be evidence for a charge of reckless and negligent operation of the aircraft. "Hi, I'm from the Government and I'm here to help you" Cheers, Bill Hamilton. ZK-DCF At 08:49 25/06/2004, you wrote: > >Chris, > >Piper build fine aircraft. >Can not say the same for Cessna > >I WOULD RATHER PUSH MY AERO COMMANDER THAN FLY A CESSNA! > >Oops >( I own a Cessna) > >Enough of that. >Back on the issue of noise. >I have teamed up with one of the formost experts in this field. we have >discovered that there are some glaring deficiencies in the test regimes of >your >beloved FAA and others. >I am being forced to test my airplane to ICAO Annex 16 Chapter 6 regulations. >The main problem that has arisen is exactly what configuration the aircaft >has to be in . >The interesting thing is that our noise regulator Airservices have put >forward a set of parameters that they will accept. Our aircraft regulator >CASA has >decreed that the flight profile that the noise boys require is ILLEGAL >interms >of Australian legislation. So I am beginning to enjoy all of this. It is >unusual to have the regulator on my side for once. > >I will keep you all posted on events. >One thing that will happen is that the aircraft will be tested and certified >to be compliant in accordance with the ICAO rules. > >I am going to make this information and all test results availiable to all of >you and to TCAC. So if anyone has this problem in the future you will have up >to date data to fight with. > >Regards >Richard > > CONFIDENTIALITY & PRIVILEGE NOTICE W.J.R.Hamilton,Glenalmond Group Companies,Fighter Flights Internet Services and Warbirds.Net. & . This message is intended for and should only be used by the addressee. It is confidential and may contain legally privileged information.If you are not the intended recipient any use distribution,disclosure or copying of this message is strictly prohibited.Confidentiality and legal privilege attached to this communication are not waived or lost by reason of the mistaken delivery to you.If you have received this message in error, please notify us immediately to Australia 61 (0)408 876 526 ________________________________________________________________________________
Date: Jun 24, 2004
Subject: Re: flyin
In a message dated 6/24/2004 4:36:45 PM Pacific Standard Time, wjrhamilton(at)optusnet.com.au writes: "Hi, I'm from the Government and I'm here to help you" AMEN!! jb ________________________________________________________________________________
Date: Jun 24, 2004
Subject: Re: flyin
In a message dated 6/24/2004 9:07:12 AM Pacific Standard Time, mrp37(at)mindspring.com writes: The Fly-in forms are on my desk, and will go out today. Jim, what's the count so far? We are approaching 30!! This is by far the most I have had registered at this early time. This should be a GREAT flyin. Hope you can make it!! Is a Commander in your future?? I know of a guy who might be interested in you T-210. jb ________________________________________________________________________________
Date: Jun 25, 2004
does anyone have a rear bench seat to fit a 680f that alows more entrance way at door? i think it has a 30 or 45 degree angle on front left corner of seat by the door. pls adv. tnx mason 2001m >From: aerocommander <salm(at)aerocommander.de> >Reply-To: commander-list(at)matronics.com >To: commander-list(at)matronics.com >Subject: Commander-List: 1954 520 Aero Commander at Ebay >Date: Thu, 24 Jun 2004 15:11:18 +0200 > > >Hello group, > >May be You hav not yet recognized this fine gal at Ebay. >She looks like to be worth to be kept airworthy. >http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=26428&item=2482527873&rd=1 ><http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=26428&item=2482527873&rd=1> > >best regards from germany > >Volkmar > > >Volkmar Salm >Phone +49 7802 980 500 >Fax +49 7802 980 954 >salm(at)aerocommander.de > > ________________________________________________________________________________
Subject: Re: 1954 520 Aero Commander at Ebay
Date: Jun 25, 2004
I think those were "hand made" from a stock seat. Moe ----- Original Message ----- From: "MASON Chevaillier" <kamala(at)msn.com> Subject: RE: Commander-List: 1954 520 Aero Commander at Ebay > > does anyone have a rear bench seat to fit a 680f that alows more entrance > way at door? i think it has a 30 or 45 degree angle on front left corner of > seat by the door. pls adv. tnx mason 2001m > > > >From: aerocommander <salm(at)aerocommander.de> > >Reply-To: commander-list(at)matronics.com > >To: commander-list(at)matronics.com > >Subject: Commander-List: 1954 520 Aero Commander at Ebay > >Date: Thu, 24 Jun 2004 15:11:18 +0200 > > > > > >Hello group, > > > >May be You hav not yet recognized this fine gal at Ebay. > >She looks like to be worth to be kept airworthy. > >http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=26428&ite m=2482527873&rd=1 > ><http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=26428&it em=2482527873&rd=1> > > > >best regards from germany > > > >Volkmar > > > > > >Volkmar Salm > >Phone +49 7802 980 500 > >Fax +49 7802 980 954 > >salm(at)aerocommander.de > > > > > > ________________________________________________________________________________
Date: Jun 25, 2004
In a message dated 6/25/2004 11:15:28 AM Pacific Standard Time, moe(at)rosspistons.com writes: I think those were "hand made" from a stock seat. Yep. jb ________________________________________________________________________________
Date: Jun 25, 2004
Subject: Commander for sale
A member who is not on the chatlist asked me if I would make a posting to let everyone know he is selling his 520 Commander. I know a little about this airplane and would have to say that it is probably one of the finest bathtub models still in existance. It is one of the few rare early models that has had all the nacelle trusses replaced, has MV series props (NO AD), and seems to have had every single inch of the airplane restored into like-new condition. It's loaded with expensive upgrades and modifications like Cleveland brakes ,radar, Garmin radio, and a modern autopilot. Having gone through a Commander restoration myself, I can attest that you wouldn't be able to replicate this airplane for a LOT more than you could purchase his for. For more info, contact: James Lyle TCFG member N11L 706-799-2602 Cell Someone give this beautiful bird a new home! Chris ________________________________________________________________________________
Date: Jun 25, 2004
Subject: Re: Commander for sale
In a message dated 6/25/2004 3:16:56 PM Pacific Standard Time, cschuerm(at)cox.net writes: Cleveland brakes WOW, man do I need to see that paperwork!! jb ________________________________________________________________________________
From: "Bruce Campbell" <baruch(at)intelligentflight.com>
Date: Jun 25, 2004
What I ant to know is how did he get the field approval for the cleveland brakes, and can I get a copy of it so I can.... Bruce Campbell AC52 N4186B ----- Original Message ----- From: "Chris Schuermann" <cschuerm(at)cox.net> Subject: Commander-List: Commander for sale > > A member who is not on the chatlist asked me if I would make a posting > to let everyone know he is selling his 520 Commander. > > I know a little about this airplane and would have to say that it is > probably one of the finest bathtub models still in existance. It is one > of the few rare early models that has had all the nacelle trusses > replaced, has MV series props (NO AD), and seems to have had every > single inch of the airplane restored into like-new condition. It's > loaded with expensive upgrades and modifications like Cleveland brakes > ,radar, Garmin radio, and a modern autopilot. Having gone through a > Commander restoration myself, I can attest that you wouldn't be able to > replicate this airplane for a LOT more than you could purchase his for. > > For more info, contact: > James Lyle > TCFG member > N11L > 706-799-2602 Cell > > > Someone give this beautiful bird a new home! > Chris > > ________________________________________________________________________________
Date: Jun 26, 2004
I Got The Field approval on the set of Cleveland's on N295V a straight 560 with double Calibers Harry ----- Original Message ----- From: <YOURTCFG(at)aol.com> Subject: Re: Commander-List: Commander for sale > > > In a message dated 6/25/2004 3:16:56 PM Pacific Standard Time, > cschuerm(at)cox.net writes: > > Cleveland brakes > > > WOW, man do I need to see that paperwork!! jb > > ________________________________________________________________________________
Date: Jun 26, 2004
How about the fuel valve Harry? Phil > [Original Message] > From: <avtec2(at)bellsouth.net> > To: > Date: 6/26/2004 8:00:23 AM > Subject: Re: Commander-List: Commander for sale > > > I Got The Field approval on the set of Cleveland's on N295V a straight 560 > with double Calibers > Harry > ----- Original Message ----- > From: <YOURTCFG(at)aol.com> > To: > Subject: Re: Commander-List: Commander for sale > > > > > > > > In a message dated 6/25/2004 3:16:56 PM Pacific Standard Time, > > cschuerm(at)cox.net writes: > > > > Cleveland brakes > > > > > > WOW, man do I need to see that paperwork!! jb > > > > > > ________________________________________________________________________________
Subject: Fw: Pilots seat
Date: Jun 26, 2004
----- Original Message ----- From: Dennis Polito Subject: Fw: Pilots seat ----- Original Message ----- From: Dennis Polito Subject: Pilots seat Greetings to the list. For sale: One vertically adjustable pilot/co pilot seat. In need of paint and recovering. Fully functional and complete. I thought that I would offer this spare pilot's seat to the list before going to e-pay. I bought it to use in my 500B but never got around to refurbishing it. I am sure that it will fit in any Commander that has the same seat rail spacing. This one came from a turbine aircraft. If there is any interest, please contact me off list directly or call me at home. Dennis Polito 28bravo(at)comcast.net 650-595-3949 ________________________________________________________________________________
Date: Jun 27, 2004
Valve or money will pay with C/C or money order. SORRY Monday Harry ----- Original Message ----- From: "Phil Stubbs" <br549phil(at)mindspring.com> Subject: Re: Commander-List: Commander for sale > > How about the fuel valve Harry? > Phil > > > > [Original Message] > > From: <avtec2(at)bellsouth.net> > > To: > > Date: 6/26/2004 8:00:23 AM > > Subject: Re: Commander-List: Commander for sale > > > > > > I Got The Field approval on the set of Cleveland's on N295V a straight 560 > > with double Calibers > > Harry > > ----- Original Message ----- > > From: <YOURTCFG(at)aol.com> > > To: > > Subject: Re: Commander-List: Commander for sale > > > > > > > > > > > > > In a message dated 6/25/2004 3:16:56 PM Pacific Standard Time, > > > cschuerm(at)cox.net writes: > > > > > > Cleveland brakes > > > > > > > > > WOW, man do I need to see that paperwork!! jb > > > > > > > > > > > > ________________________________________________________________________________
Date: Jun 27, 2004
Money, any form OK. let me know address to return valve. Phil > [Original Message] > From: <avtec2(at)bellsouth.net> > To: > Date: 6/27/2004 7:56:48 AM > Subject: Re: Commander-List: Commander for sale > > > Valve or money > will pay with C/C or money order. SORRY Monday > Harry > ----- Original Message ----- > From: "Phil Stubbs" <br549phil(at)mindspring.com> > To: ; > Subject: Re: Commander-List: Commander for sale > > > > > > > How about the fuel valve Harry? > > Phil > > > > > > > [Original Message] > > > From: <avtec2(at)bellsouth.net> > > > To: > > > Date: 6/26/2004 8:00:23 AM > > > Subject: Re: Commander-List: Commander for sale > > > > > > > > > I Got The Field approval on the set of Cleveland's on N295V a straight > 560 > > > with double Calibers > > > Harry > > > ----- Original Message ----- > > > From: <YOURTCFG(at)aol.com> > > > To: > > > Subject: Re: Commander-List: Commander for sale > > > > > > > > > > > > > > > > > > In a message dated 6/25/2004 3:16:56 PM Pacific Standard Time, > > > > cschuerm(at)cox.net writes: > > > > > > > > Cleveland brakes > > > > > > > > > > > > WOW, man do I need to see that paperwork!! jb > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jun 27, 2004
480 N Williams Ave. Titusville, FL 32796 Harry ----- Original Message ----- From: "Phil Stubbs" <br549phil(at)mindspring.com> Subject: Re: Commander-List: Commander for sale > > Money, any form OK. let me know address to return valve. > Phil > > > > [Original Message] > > From: <avtec2(at)bellsouth.net> > > To: > > Date: 6/27/2004 7:56:48 AM > > Subject: Re: Commander-List: Commander for sale > > > > > > Valve or money > > will pay with C/C or money order. SORRY Monday > > Harry > > ----- Original Message ----- > > From: "Phil Stubbs" <br549phil(at)mindspring.com> > > To: ; > > Subject: Re: Commander-List: Commander for sale > > > > > > > > > > > > How about the fuel valve Harry? > > > Phil > > > > > > > > > > [Original Message] > > > > From: <avtec2(at)bellsouth.net> > > > > To: > > > > Date: 6/26/2004 8:00:23 AM > > > > Subject: Re: Commander-List: Commander for sale > > > > > > > > > > > > I Got The Field approval on the set of Cleveland's on N295V a straight > > 560 > > > > with double Calibers > > > > Harry > > > > ----- Original Message ----- > > > > From: <YOURTCFG(at)aol.com> > > > > To: > > > > Subject: Re: Commander-List: Commander for sale > > > > > > > > > > > > > > > > > > > > > > > In a message dated 6/25/2004 3:16:56 PM Pacific Standard Time, > > > > > cschuerm(at)cox.net writes: > > > > > > > > > > Cleveland brakes > > > > > > > > > > > > > > > WOW, man do I need to see that paperwork!! jb > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Subject:
Date: Jun 27, 2004
This is long but so funny and I thought the guys down under would really get a chuckle out of this. Jim Addington N444BD An "Aussie" Bush Pilot's First Check Ride, Upon Returning From Vietnam Hi Mate, I am writing to you, because I need your help to get me bloody pilots licence back (you keep telling me you got all the right contacts, well now's your chance to make something happen for me because, mate, I'm bloody desperate). But first, I'd better tell you what happened during my last flight review with the CAA Examiner. On the phone, Ron (that's the CAA dorkhead) seemed a reasonable sort of bloke. He politely reminded me of the need to do a flight review every two years, since I had been flying Caribou in Vietnam for a year. He even offered to drive out, have look over my property and let me operate from my own strip. Naturally I agreed to that. Anyway, Ron turned up last Wednesday. First up, he said he was a bit surprised to see the plane on a small strip outside my homestead because the ALA (Authorized Landing Area) is about a mile away. I explained that because this strip was so close to the homestead, it was more convenient than that strip, despite the power lines crossing about midway down the strip (it's really not a problem to land and takeoff because at the halfway point down the strip you're usually still on the ground). For some reason Ron seemed nervous. So, although I had done the preflight inspection only four days earlier, I decided to do it all over again. Because he was watching me carefully, I walked around the plane three times instead of my usual two. My effort was rewarded because the colour finally returned to Ron's cheeks - in fact they went a bright red. In view of Ron's obviously better mood, I told him I was going to combine the test flight with farm work as I had to deliver three poddy calves from the home paddock to the main herd. After a bit of a chase I finally caught the calves and threw them into the back of the ol' Cessna 172. We climbed aboard but Ron started getting' into me about weight and balance calculations and all that crap. Of course I knew that sort of thing was a waste of time because, calves like to move around a bit, particularly when they see themselves 500 feet off the ground! So, its bloody pointless trying to secure them as you know. However, I did tell Ron that he shouldn't worry as I always keep the trim wheel set on neutral to ensure we remain pretty stable at all stages throughout the flight. Anyway, I started the engine and cleverly minimised the warm-up time by tramping hard on the brakes and gunning her to 2,500rpm. I then discovered that Ron has very acute hearing, even though he was wearing a bloody headset. Through all that noise he detected a metallic rattle and demanded I account for it. Actually it began about a month ago and was caused by a screwdriver that fell down a hole in the floor and lodged in the fuel selector mechanism. The selector can't be moved now, but it doesn't matter because it's jammed on 'All tanks', so I suppose that's OK. However, as Ron was obviously a real nit-picker, I blamed the noise on vibration from a stainless steel thermos flask, which I keep in a beaut little possie between the windshield and the magnetic compass. My explanation seemed to relax Ron because he slumped back in the seat and kept looking up at the cockpit roof. I released the brakes to taxi out but unfortunately the plane gave a leap and spun to the right, "Hell" I thought, "not the starboard wheel chock again." The bump jolted Ron back to full alertness. He looked wildly around just in time to see a rock thrown by the propwash disappear completely through the windscreen of his brand new Commodore. "Now I'm really in trouble," I thought. While Ron was busy ranting about his car, I ignored his requirement that we taxi to the ALA and instead took off under the power lines. Ron didn't say a word, at least not until the engine started coughing right at the lift off point, then he bloody screamed his head off, "Oh God! Oh God! Oh God!" "Now take it easy, Ron" I told him firmly, "that often happens on takeoff and there is a good reason for it." I explained patiently that I usually run the plane on standard MOGAS, but one day I accidentally put in a gallon or two of kerosene. To compensate for the low octane of the kerosene, I siphoned in a few gallons off super MOGAS and shook the wings up and down a few times to mix it up. Since then, the engine has been coughing a bit but in general it works just fine, if you know how to coax it properly. Anyway, at this stage Ron seemed to lose all interest in my flight test. He pulled out some rosary beads, closed his eyes and became lost in prayer (I didn't think anyone was a Catholic these days). I selected some nice music on the HF radio to help him relax. Meanwhile I climbed to my normal cruising altitude of 10,500 feet (I don't normally put in a flight plan or get the weather because as you know getting Fax access out here is just a joke and the bloody weather is always 8/8 blue anyway. But since I had that near miss with a Saab 340, I might have to change me thinking). Anyhow, on leveling out I noticed some wild camels heading into my improved pasture. I hate camels and always carry a loaded .303 clipped inside the door of the Cessna just in case I see any of the blokes. We were too high to hit them, but as a matter of principle, I decided to have a go through the open window. Mate, when I pulled the bloody rifle out, the effect on Ron was totally electric. As I fired the first shot his neck lengthened by about six inches and his eyes bulged like a rabbit with myxo. He really looked as if he had been jabbed with an electric cattle prod on full power. In fact, Ron's reaction was so distracting that I lost concentration for a second and the next shot went straight through the port tyre. Ron was a bit upset about the shooting (probably one of those pinko animal lovers I guess) so I decided not to tell him about our little problem with the tyre. Shortly afterwards I located the main herd and decided to do my fighter pilot trick. Ron had gone back to praying when, in one smooth sequence, I pulled on full flap, cut the power and started a sideslip from 10,500 feet down to 500 feet at 130 knots indicated (the last time I looked anyway) and the little needle rushing up to the red area on me ASI. What a buzz, mate! About half way through the descent I looked back in the cabin to see the calves gracefully suspended in mid air and mooing like crazy. I was going to comment on this unusual sight but Ron looked a bit green and had rolled himself into the fetal position and was screamin' his head off. Mate, talk about being in a bloody zoo. You should've been there, it was so bloody funny! At about 500 feet I leveled out, but for some reason we continued sinking. When we reached 50 feet I applied full power but nothin' happened; no noise no nothin.' Then, luckily, I heard me instructor's voice in me head saying "carby heat, carby heat," so I pulled carby heat on and that helped quite a lot, with the engine finally regaining full power. Whew, that was really close, let me tell you! Then mate, you'll never guess what happened next! As luck would have it, at that height we flew into a massive dust cloud caused by the cattle and suddenly went I.F. bloody R, mate. You would've been bloody proud of me as I didn't panic once, not once, but I did make a mental note to consider getting a civil instrument rating as soon as me gyro is repaired (something I've been meaning to do for a while now). Suddenly Ron's elongated neck and bulging eyes reappeared. His mouth opened wide, very wide, but no sound emerged. "Take it easy," I told him. "we'll be out of this in a minute." Sure enough, about a minute later we emerge; still straight and level and still at 50 feet. Admittedly I was surprised to notice that we were upside down, and I kept thinking to myself, "I hope Ron didn't notice that I had forgotten to set the QNH when we were taxying." This minor tribulation forced me to fly to a nearby valley in which I had to do a half roll to get upright again. By now the main herd had divided into two groups leaving a narrow strip between them. "Ah!" I thought, "there's an omen. We'll land right there." Knowing that the tyre problem demanded a slow approach, I flew a couple of steep turns with full flap. Soon the stall warning horn was blaring so loud in me ear that I cut its circuit breaker to shut it up, but by then I knew we were slow enough anyway. I turned steeply onto a 75 foot final and put her down with a real thud. Strangely enough, I had always thought you could only ground loop in a tail dragger but, as usual, I was proved wrong again! Halfway through our third loop Ron at last recovered his sense of humour. Talk about laugh. I've never seen the likes of it; he couldn't stop. We finally rolled to a halt and I released the calves, who bolted out of the aircraft like there was no tomorrow. I then began picking clumps of dry grass. Between gut wrenching fits of laughter Ron asked what I was doing. I explained that we had to stuff the port tyre with grass so we could fly back to the homestead. It was then that Ron really lost the plot and started running away from the aircraft. Can you believe it? The last time I saw him he was off into the distance, arms flailing in the air and still shrieking with laughter. I later heard that he had been confined to a psychiatric institution - poor bugger! Anyhow, mate, that's enough about Ron. The problem is I just got a letter from CASA withdrawing, as they put it, my privileges to fly; until I have undergone a complete pilot training course again and undertaken another flight proficiency test. Now I admit that I made a mistake in taxiing over the wheel chock and not setting the QNH using strip elevation, but I can't see what else I did that was so bloody bad that they have to withdraw me flamin' licence. Can you? ________________________________________________________________________________
Date: Jun 27, 2004
Subject: N222JS
HI KIDS..... I flew triple 2 to Idaho and back a couple of days ago to take my granddaughter home. It was a great trip, made for a Commander. Over at 11.5 home at 10.5 Averaged about 171kts over the ground round trip. Fuel burn was really high. I have a bum Carburetor and it is not leaning correctly. I plan to have it O/H next month. On the trip Tripe 2 turned over 400hrs since the "grand renegade" overhaul!! Yippee!! It has been a great old airplane and I hope to have many more hours from her, especially since I now have low time engines. Hope all is well in your Commanderland. jb ________________________________________________________________________________
Date: Jun 27, 2004
In a message dated 6/27/2004 4:57:35 AM Pacific Standard Time, avtec2(at)bellsouth.net writes: Valve or money will pay with C/C or money order. SORRY Monday Harry ----- Original Message ----- From: "Phil Stubbs" <br549phil(at)mindspring.com> Subject: Re: Commander-List: Commander for sale > > How about the fuel valve Harry? > Phil HEY GUYS.. How about sending personal emails just to the recipient rather than sharing it with all of us. Thanks ;-) jb ________________________________________________________________________________
Date: Jun 27, 2004
Subject: Re:
Mr Addington Wonderful story. Richard ________________________________________________________________________________
Date: Jun 27, 2004
I was shopping for a CC number so I could go on a nice shopping spree ----- Original Message ----- From: <YOURTCFG(at)aol.com> Subject: Re: Commander-List: Commander for sale > > > In a message dated 6/27/2004 4:57:35 AM Pacific Standard Time, > avtec2(at)bellsouth.net writes: > > Valve or money > will pay with C/C or money order. SORRY Monday > Harry > ----- Original Message ----- > From: "Phil Stubbs" <br549phil(at)mindspring.com> > To: ; > Subject: Re: Commander-List: Commander for sale > > > > > > > How about the fuel valve Harry? > > Phil > > > HEY GUYS.. > > How about sending personal emails just to the recipient rather than > sharing it with all of us. Thanks ;-) jb > > ________________________________________________________________________________
Subject:
Date: Jun 27, 2004
Though you folks would like that. I am still laughing. -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com]On Behalf Of RnJThompson(at)aol.com Subject: Re: Commander-List: Mr Addington Wonderful story. Richard ________________________________________________________________________________
Date: Jun 28, 2004
Subject: Twin Commander in the news today
In the local paper and on www.aero-news.net is a story about the State of New Mexico wanting to sell their 1966 Aero Commander, a 680FLP with Mr RPM engines to buy a used turbo prop for $4,000,000. The local paper said something about moving money from the road department to the general fund to buy the new airplane. Something about the legislature not being in session and want to do the purchase very soon with out their approval. Some creative accounting? Politics as usual I am told here in NM. I am new to the state. The story said that they would have to spend over $225,000 per year on maintenance on it. I think they are using numbers to include all costs like fuel and pilot? I wounder how much a $4,000,000 turbo prop is going to cost them to run? Aero-News got the photo wrong. Tom, there may be a FLP available soon. NM has owned this aircraft since new and had the Mr RPM conversion done to it. It has over 7000 hours. Tylor Hall ________________________________________________________________________________
From: "Barry Collman" <barry.collman@air-britain.co.uk>
Subject: Re: Twin Commander in the news today
Date: Jun 28, 2004
Thanks for the 'heads-up' Tylor! It seems to me that the only candidate is not a 680FLP, but a 680FL. Serial number is probably 1642-122, N1414S. This is a 1966-build, with the Mr. RPM conversion. As Tylor points out, the photo is totally wrong and is probably N808NC a Model 695B (converted from a 695A) with the Aerosensing terrain mapping radar system. This is very evident in the photo! Best Regards, Barry Collman ----- Original Message ----- From: "Tylor Hall" <tylor.hall(at)sbcglobal.net> Subject: Commander-List: Twin Commander in the news today | | In the local paper and on www.aero-news.net is a story about the State of New Mexico wanting to sell their 1966 Aero Commander, a 680FLP with Mr RPM engines to buy a used turbo prop for $4,000,000. | The local paper said something about moving money from the road department to the general fund to buy the new airplane. Something about the legislature not being in session and want to do the purchase very soon with out their approval. Some creative accounting? Politics as usual I am told here in NM. I am new to the state. | | The story said that they would have to spend over $225,000 per year on maintenance on it. I think they are using numbers to include all costs like fuel and pilot? I wounder how much a $4,000,000 turbo prop is going to cost them to run? | | Aero-News got the photo wrong. | | Tom, there may be a FLP available soon. NM has owned this aircraft since new and had the Mr RPM conversion done to it. It has over 7000 hours. | | Tylor Hall | | | | | | | ________________________________________________________________________________
Date: Jun 28, 2004
Found it, thanks. I hear it may not be a "P". given the number of FLP's that I have seen on the market I may have to settle for a non-pressurized machine. Let me know. Tom F. ----- Original Message ----- From: "Tylor Hall" <tylor.hall(at)sbcglobal.net> Subject: Commander-List: Twin Commander in the news today > > In the local paper and on www.aero-news.net is a story about the State of New Mexico wanting to sell their 1966 Aero Commander, a 680FLP with Mr RPM engines to buy a used turbo prop for $4,000,000. > The local paper said something about moving money from the road department to the general fund to buy the new airplane. Something about the legislature not being in session and want to do the purchase very soon with out their approval. Some creative accounting? Politics as usual I am told here in NM. I am new to the state. > > The story said that they would have to spend over $225,000 per year on maintenance on it. I think they are using numbers to include all costs like fuel and pilot? I wounder how much a $4,000,000 turbo prop is going to cost them to run? > > Aero-News got the photo wrong. > > Tom, there may be a FLP available soon. NM has owned this aircraft since new and had the Mr RPM conversion done to it. It has over 7000 hours. > > Tylor Hall > > ________________________________________________________________________________
Date: Jun 28, 2004
Barry, I spoke to the pilot that flew it for 20 years before retiring. It has two camera holes in it with a quick change seats that have to come out to use the camera. The Highway dept seems to use it. I know it is a Mr. RPM from Dick MacCoon's records. It Sate of New Mexico has a hangar up at Santa Fe. I will have to go look for it. Tylor Hall <barry.collman@air-britain.co.uk> Thanks for the 'heads-up' Tylor! It seems to me that the only candidate is not a 680FLP, but a 680FL. Serial number is probably 1642-122, N1414S. This is a 1966-build, with the Mr. RPM conversion. As Tylor points out, the photo is totally wrong and is probably N808NC a Model 695B (converted from a 695A) with the Aerosensing terrain mapping radar system. This is very evident in the photo! Best Regards, Barry Collman ----- Original Message ----- From: "Tylor Hall" <tylor.hall(at)sbcglobal.net> Subject: Commander-List: Twin Commander in the news today | | In the local paper and on www.aero-news.net is a story about the State of New Mexico wanting to sell their 1966 Aero Commander, a 680FLP with Mr RPM engines to buy a used turbo prop for $4,000,000. | The local paper said something about moving money from the road department to the general fund to buy the new airplane. Something about the legislature not being in session and want to do the purchase very soon with out their approval. Some creative accounting? Politics as usual I am told here in NM. I am new to the state. | | The story said that they would have to spend over $225,000 per year on maintenance on it. I think they are using numbers to include all costs like fuel and pilot? I wounder how much a $4,000,000 turbo prop is going to cost them to run? | | Aero-News got the photo wrong. | | Tom, there may be a FLP available soon. NM has owned this aircraft since new and had the Mr RPM conversion done to it. It has over 7000 hours. | | Tylor Hall | | | | | | | ________________________________________________________________________________
Subject:
Date: Jun 29, 2004
I haven't laughed that hard in years. Thanks Jim > [Original Message] > From: Jim Addington <jtaddington(at)charter.net> > To: COMMANDER-LIST > Date: 6/27/2004 12:36:44 PM > Subject: Commander-List: > > > This is long but so funny and I thought the guys down under would really get > a chuckle out of this. > > Jim Addington > N444BD > > > An "Aussie" Bush Pilot's First Check Ride, Upon Returning From Vietnam > > Hi Mate, I am writing to you, because I need your help to get me bloody > pilots licence back (you keep telling me you got all the right contacts, > well now's your chance to make something happen for me because, mate, I'm > bloody desperate). But first, I'd better tell you what happened during my > last flight review with the CAA Examiner. On the phone, Ron (that's the CAA > dorkhead) seemed a reasonable sort of bloke. He politely reminded me of the > need to do a flight review every two years, since I had been flying Caribou > in Vietnam for a year. He even offered to drive out, have look over my > property and let me operate from my own strip. Naturally I agreed to that. > > Anyway, Ron turned up last Wednesday. First up, he said he was a bit > surprised to see the plane on a small strip outside my homestead because the > ALA (Authorized Landing Area) is about a mile away. I explained that because > this strip was so close to the homestead, it was more convenient than that > strip, despite the power lines crossing about midway down the strip (it's > really not a problem to land and takeoff because at the halfway point down > the strip you're usually still on the ground). > > For some reason Ron seemed nervous. So, although I had done the preflight > inspection only four days earlier, I decided to do it all over again. > Because he was watching me carefully, I walked around the plane three times > instead of my usual two. > > My effort was rewarded because the colour finally returned to Ron's cheeks - > in fact they went a bright red. In view of Ron's obviously better mood, I > told him I was going to combine the test flight with farm work as I had to > deliver three poddy calves from the home paddock to the main herd. After a > bit of a chase I finally caught the calves and threw them into the back of > the ol' Cessna 172. We climbed aboard but Ron started getting' into me about > weight and balance calculations and all that crap. Of course I knew that > sort of thing was a waste of time because, calves like to move around a bit, > particularly when they see themselves 500 feet off the ground! So, its > bloody pointless trying to secure them as you know. However, I did tell Ron > that he shouldn't worry as I always keep the trim wheel set on neutral to > ensure we remain pretty stable at all stages throughout the flight. > > Anyway, I started the engine and cleverly minimised the warm-up time by > tramping hard on the brakes and gunning her to 2,500rpm. I then discovered > that Ron has very acute hearing, even though he was wearing a bloody > headset. Through all that noise he detected a metallic rattle and demanded I > account for it. Actually it began about a month ago and was caused by a > screwdriver that fell down a hole in the floor and lodged in the fuel > selector mechanism. The selector can't be moved now, but it doesn't matter > because it's jammed on 'All tanks', so I suppose that's OK. > > However, as Ron was obviously a real nit-picker, I blamed the noise on > vibration from a stainless steel thermos flask, which I keep in a beaut > little possie between the windshield and the magnetic compass. My > explanation seemed to relax Ron because he slumped back in the seat and kept > looking up at the cockpit roof. I released the brakes to taxi out but > unfortunately the plane gave a leap and spun to the right, "Hell" I thought, > "not the starboard wheel chock again." The bump jolted Ron back to full > alertness. He looked wildly around just in time to see a rock thrown by the > propwash disappear completely through the windscreen of his brand new > Commodore. "Now I'm really in trouble," I thought. > > While Ron was busy ranting about his car, I ignored his requirement that we > taxi to the ALA and instead took off under the power lines. Ron didn't say a > word, at least not until the engine started coughing right at the lift off > point, then he bloody screamed his head off, "Oh God! Oh God! Oh God!" > > "Now take it easy, Ron" I told him firmly, "that often happens on takeoff > and there is a good reason for it." I explained patiently that I usually run > the plane on standard MOGAS, but one day I accidentally put in a gallon or > two of kerosene. To compensate for the low octane of the kerosene, I > siphoned in a few gallons off super MOGAS and shook the wings up and down a > few times to mix it up. Since then, the engine has been coughing a bit but > in general it works just fine, if you know how to coax it properly. Anyway, > at this stage Ron seemed to lose all interest in my flight test. He pulled > out some rosary beads, closed his eyes and became lost in prayer (I didn't > think anyone was a Catholic these days). I selected some nice music on the > HF radio to help him relax. > > Meanwhile I climbed to my normal cruising altitude of 10,500 feet (I don't > normally put in a flight plan or get the weather because as you know getting > Fax access out here is just a joke and the bloody weather is always 8/8 blue > anyway. But since I had that near miss with a Saab 340, I might have to > change me thinking). Anyhow, on leveling out I noticed some wild camels > heading into my improved pasture. I hate camels and always carry a loaded > .303 clipped inside the door of the Cessna just in case I see any of the > blokes. > > We were too high to hit them, but as a matter of principle, I decided to > have a go through the open window. Mate, when I pulled the bloody rifle out, > the effect on Ron was totally electric. As I fired the first shot his neck > lengthened by about six inches and his eyes bulged like a rabbit with myxo. > He really looked as if he had been jabbed with an electric cattle prod on > full power. In fact, Ron's reaction was so distracting that I lost > concentration for a second and the next shot went straight through the port > tyre. Ron was a bit upset about the shooting (probably one of those pinko > animal lovers I guess) so I decided not to tell him about our little problem > with the tyre. Shortly afterwards I located the main herd and decided to do > my fighter pilot trick. > > Ron had gone back to praying when, in one smooth sequence, I pulled on full > flap, cut the power and started a sideslip from 10,500 feet down to 500 feet > at 130 knots indicated (the last time I looked anyway) and the little needle > rushing up to the red area on me ASI. What a buzz, mate! About half way > through the descent I looked back in the cabin to see the calves gracefully > suspended in mid air and mooing like crazy. I was going to comment on this > unusual sight but Ron looked a bit green and had rolled himself into the > fetal position and was screamin' his head off. Mate, talk about being in a > bloody zoo. You should've been there, it was so bloody funny! > > At about 500 feet I leveled out, but for some reason we continued sinking. > When we reached 50 feet I applied full power but nothin' happened; no noise > no nothin.' Then, luckily, I heard me instructor's voice in me head saying > "carby heat, carby heat," so I pulled carby heat on and that helped quite a > lot, with the engine finally regaining full power. Whew, that was really > close, let me tell you! > > Then mate, you'll never guess what happened next! As luck would have it, at > that height we flew into a massive dust cloud caused by the cattle and > suddenly went I.F. bloody R, mate. You would've been bloody proud of me as I > didn't panic once, not once, but I did make a mental note to consider > getting a civil instrument rating as soon as me gyro is repaired (something > I've been meaning to do for a while now). > > Suddenly Ron's elongated neck and bulging eyes reappeared. His mouth opened > wide, very wide, but no sound emerged. "Take it easy," I told him. "we'll be > out of this in a minute." Sure enough, about a minute later we emerge; still > straight and level and still at 50 feet. Admittedly I was surprised to > notice that we were upside down, and I kept thinking to myself, "I hope Ron > didn't notice that I had forgotten to set the QNH when we were taxying." > This minor tribulation forced me to fly to a nearby valley in which I had to > do a half roll to get upright again. > > By now the main herd had divided into two groups leaving a narrow strip > between them. "Ah!" I thought, "there's an omen. We'll land right there." > Knowing that the tyre problem demanded a slow approach, I flew a couple of > steep turns with full flap. Soon the stall warning horn was blaring so loud > in me ear that I cut its circuit breaker to shut it up, but by then I knew > we were slow enough anyway. I turned steeply onto a 75 foot final and put > her down with a real thud. Strangely enough, I had always thought you could > only ground loop in a tail dragger but, as usual, I was proved wrong again! > > Halfway through our third loop Ron at last recovered his sense of humour. > Talk about laugh. I've never seen the likes of it; he couldn't stop. We > finally rolled to a halt and I released the calves, who bolted out of the > aircraft like there was no tomorrow. I then began picking clumps of dry > grass. Between gut wrenching fits of laughter Ron asked what I was doing. I > explained that we had to stuff the port tyre with grass so we could fly back > to the homestead. It was then that Ron really lost the plot and started > running away from the aircraft. Can you believe it? > > The last time I saw him he was off into the distance, arms flailing in the > air and still shrieking with laughter. I later heard that he had been > confined to a psychiatric institution - poor bugger! > > Anyhow, mate, that's enough about Ron. The problem is I just got a letter > from CASA withdrawing, as they put it, my privileges to fly; until I have > undergone a complete pilot training course again and undertaken another > flight proficiency test. > > Now I admit that I made a mistake in taxiing over the wheel chock and not > setting the QNH using strip elevation, but I can't see what else I did that > was so bloody bad that they have to withdraw me flamin' licence. Can you? > > ________________________________________________________________________________
Date: Jun 29, 2004
Subject: "in the mail"
HI KIDS. Just thought I would let everybody know that the summer newsletter is in the mail (YEA!!). This put me back on schedule and I thank all of you for you patience. This edition has a great story from Buddy Plaster about the overhaul of his 560E as well as an important article from Wing Commander Keith Gordon on the operation of our hydraulic system. I asked Keith the contribute this after the discussion some weeks back here on the list. I think it will be very insightful. There is also a piece from our amazing historian, Barry Collman that you will find interesting. Next issue will be on time in Sept and will have an article by John Bosch at Commander Aero on the restoration of a "better than new" 500A Commander. The reservations for this years flyin have been great!! Well ahead of any other flyin. Now is the time to sign up if you can make it. We are putting a great speaker list together and there is always a great feeling of camaraderie in the air. We will have an award dinner on Sat eve. So far Mr. Hoover is still planning to attend. Where else could you have the opportunity to "break bread" with such an aviation legend!! If you are a TCFG member you have received you registration form, if not contact me and I will send one. Hope all is well in your world. jb ________________________________________________________________________________
Date: Jul 04, 2004
Subject: Re: 4 th JULY
To all our American friends. HAPPY 4th of JULY. Regards Richard & Russell The Boys From OZ ________________________________________________________________________________
Date: Jul 04, 2004
Thanks, Mates! Quite kind of you. But don't forget to wish Sir Barry Collman a Happy 4th as well. Wing Commander Gordon Life is not simple anywhere.=A0 Probably less so elsewhere. ________________________________________________________________________________
Date: Jul 04, 2004
Lets not forget that the congress declared independence on 4 July 1776, and we actually got it on 20 Aug 1781 (at the end of the battle of yorktown). From declaration to actual fact was 5 hard years. Sometimes things that are important take a while. Nothing worthwhile comes easily. Bruce Campbell AC52 N4186B ----- Original Message ----- From: <CloudCraft(at)aol.com> Subject: Re: Commander-List: Re: 4 th JULY > > Thanks, Mates! > > Quite kind of you. But don't forget to wish Sir Barry Collman a Happy 4th > as well. > > Wing Commander Gordon > > Life is not simple anywhere.=A0 Probably less so elsewhere. > > ________________________________________________________________________________
Date: Jul 05, 2004
There is a good chance that without the help of our friends from "down under" there would be no celebration. Cheers bilbo ----- Original Message ----- From: <RnJThompson(at)aol.com> Subject: Commander-List: Re: 4 th JULY > > To all our American friends. > > HAPPY 4th of JULY. > > Regards > Richard & Russell > The Boys From OZ > > ________________________________________________________________________________
Date: Jul 05, 2004
This is true. We couldn't have had it with out Sir Barry's ancestors. :>)bilbo ----- Original Message ----- From: <CloudCraft(at)aol.com> Subject: Re: Commander-List: Re: 4 th JULY > > Thanks, Mates! > > Quite kind of you. But don't forget to wish Sir Barry Collman a Happy 4th > as well. > > Wing Commander Gordon > > Life is not simple anywhere.=A0 Probably less so elsewhere. > > ________________________________________________________________________________
Date: Jul 05, 2004
Amen! Especially things like freedom and freedom of speech. Nico ----- Original Message ----- From: "Bruce Campbell" <baruch(at)intelligentflight.com> Subject: Re: Commander-List: Re: 4 th JULY > > Lets not forget that the congress declared independence on 4 July 1776, and > we actually got it on 20 Aug 1781 (at the end of the battle of yorktown). > From declaration to actual fact was 5 hard years. > > Sometimes things that are important take a while. Nothing worthwhile comes > easily. > > Bruce Campbell > AC52 N4186B > > ----- Original Message ----- > From: <CloudCraft(at)aol.com> > To: > Subject: Re: Commander-List: Re: 4 th JULY > > > > > > Thanks, Mates! > > > > Quite kind of you. But don't forget to wish Sir Barry Collman a Happy > 4th > > as well. > > > > Wing Commander Gordon > > > > Life is not simple anywhere.=A0 Probably less so elsewhere. > > > > > > ________________________________________________________________________________
Date: Jul 05, 2004
Subject: COMMANDERING ON THE 4TH
HI KIDS. Did anybody "Commander" anywhere over the 4th?? Sue and I took 222 to Corde alane Idaho where we rented a 24' motorhome and spent the 4th in Clark Fork Id. It was a good time. Sues Brother is the mayor (no worry about parking tickets) and they have no ordnance against fireworks, anything goes!! The before and after show was as good as the main event. There must have been 10K in personal fireworks shot off. Every kind of firecracker, M80 (1/2 sticks of dynamite) and every Arial display imaginable. We flew over at 11.5 with ripping tailwinds. 55%, 30" X 2550rpm, 197kts over the ground. Came home a 10.5, 32" X 2600 = 172kts ground speed. The new engine is spectacular!! I fixed the carb problem with a simple adjustment (more about that later) so the fuel burn is once again normal (33- 35gph) Also, got the biplane annuled (almost) and will have it back in the water this week. I am then planning to leave on the 11th for San Juan, PR to do an annual on Jimmy Rodreguiz 500B, S/N 1. Sue will join me there and be spending her days shopping while I slave away on the airplane (in an air-conditioned hangar) Oh well, somebody gots to does it! Hope all is well in your Commanderland. jb ________________________________________________________________________________
Date: Jul 05, 2004
Subject: Running past TBO
I've recently had several calls and emails asking my opinion about running an aircraft engine past TBO. Since I'm not updating the web site these days, I thought I'd share an important trinket of information that doesn't seem to be widely known - even to A&Ps. Okay Keith (WCG) - I bow to your superior knowledge of Commander systems, but here may be something you don't know (naw, unlikely :-) Your trusty Lycoming 540 in your Commander is getting a bit long in the teeth. It's right at TBO, but the gold standards for "continued operation" say everything is healthy. Hot, idle oil pressure is still pretty good, oil analysis doesn't find anything that you can read part numbers off of, compressions are all still in the high 60's to 70's, and the plugs are not telling any frightening stories. Before making the decision to just keep flying until the jugs fall off, what one important item might you want to check??? Lycoming had the brilliant idea to put little tubes in the rod throws of the crankshaft. They are called "sludge tubes". The idea was that the centrifugal (or is that centripedal, I never can remember) force would cause particulate matter to be forced out of suspension of the oil. Turns out they were right. The sludge tubes work really well. In fact, they work SO well that over time, they can become packed with solidified sludge to the point they cut off oil flow to the rod bearings. When the oil flow to a rod journal becomes limited, the bearing runs hotter and hotter. Amazingly, they become so hot that the bolts become brittle and fracture. There is a pile of Lycoming cases in the junkyard at the local shop with pretty inspection openings in locations not intended by the designers where the big end of a connecting rod ventured out into the sunlight. The common theme was that they were all sludge tube crank engines right around TBO. Lycoming noted this trend some time back and quit making that model of crank. Any new engine or factory overhaul since sometime in the early/mid 70's would no longer have a "sludge tube" crank. The moral of the story is that if you have an older Lycoming engine (like most Commanders do), you might well want to verify which type of crank you have before venturing far past TBO. On most 540's you can remove one of the lower accessories or plates and see the back end of the crank. If you can see through the rod journal, you're set to keep running as long as the engine is healthy. Remember, they're a heck of a lot cheaper to overhaul while all the parts are still inside of the engine... Question: can anyone confirm which crank style was used in the GO-series engines for me? Hope this was somewhat interesting. Maybe I'll note a few interesting tidbits about high time Continentals if I get a chance. Chris ________________________________________________________________________________
Date: Jul 05, 2004
Subject: Re: Running past TBO
In a message dated 05-Jul-04 17:21:55 Pacific Daylight Time, cschuerm(at)cox.net writes: > Okay Keith (WCG) - I bow to your superior knowledge of Commander > systems, but here may be something you don't know (naw, unlikely :-) Sure. I knew all about the sludge tube cranks, but I forgot all that before now, but now I know it. Truthfully, Chris, I'd never heard that and I thank you for such excellent insight to things that are out of sight. Thank you! Wing Commander Gordon Life is not simple anywhere. Probably less so elsewhere. ________________________________________________________________________________
Date: Jul 05, 2004
CloudCraft(at)aol.com wrote: > Truthfully, Chris, I'd never heard that and I thank you for such excellent > insight to things that are out of sight. Thank you! Thanks for the kind words Keith. Just wish I could trade some of my "grease" experience for some of your "actual" experience! :-) Ya know, one of the coolest "out of sight" things I can think of on Commanders is the torque sensing system of the TPE331. I'm trying to build a similar configuration for my gas powered ice cream maker to gauge the set on the ice cream. If I can get the basic mechanical aspects working, I'll make a big, 1880's looking brass gauge head with an artsy pointer for the thickness. So, what exactly IS the unit of measure for the thickness of ice cream anyway??? chris PS: for those who don't know what the heck I'm talking about: http://members.cox.net/vasoll/sei/oddities/gpicm.htm ________________________________________________________________________________
From: "Tom Fisher" <tfisher(at)commandergroup.bc.ca>
Date: Jul 05, 2004
Re. the "set" of the ice cream, an amp meter will tell you how the motor is struggling to give you the "set". How about a fuel flow meter for the gas engine? Not as fancy as a torque reading device. Tom F. ----- Original Message ----- From: "Chris Schuermann" <cschuerm(at)cox.net> Subject: Re: Commander-List: Running past TBO > > > CloudCraft(at)aol.com wrote: > > Truthfully, Chris, I'd never heard that and I thank you for such excellent > > insight to things that are out of sight. Thank you! > > Thanks for the kind words Keith. Just wish I could trade some of my > "grease" experience for some of your "actual" experience! :-) > > > Ya know, one of the coolest "out of sight" things I can think of on > Commanders is the torque sensing system of the TPE331. I'm trying to > build a similar configuration for my gas powered ice cream maker to > gauge the set on the ice cream. If I can get the basic mechanical > aspects working, I'll make a big, 1880's looking brass gauge head with > an artsy pointer for the thickness. So, what exactly IS the unit of > measure for the thickness of ice cream anyway??? > > chris > > PS: for those who don't know what the heck I'm talking about: > http://members.cox.net/vasoll/sei/oddities/gpicm.htm > > ________________________________________________________________________________
Date: Jul 05, 2004
Great article Chris, I will be looking forward to the one on the Continentals. Jim Addington N444BD ________________________________________________________________________________
Date: Jul 05, 2004
Subject: Ice Cream Commander
In a message dated 05-Jul-04 18:16:45 Pacific Daylight Time, cschuerm(at)cox.net writes: > So, what exactly IS the unit of measure for the thickness of ice cream > anyway??? > "Scoop-pounds" if you're using English units of measurment. "Scoop-hectopascalhertzbars" if you're using Metric units of measurment. It's the averaged force placed upon a SAE ice cream scoop to plunge it into=20a standing body of ice cream, make a "J" type stroke and then extract it. You can measure this with either a strain gauge or a hydraulic feed-back system. I'd go with a piezoelectric strain gauge because the hydraulic system can leak and then you have 5606 Swirl when you were trying to make French vanilla. In a pecan nutshell, the TPE-331 torque sensing system is done via a torsion shaft; two concentric shafts geared together at the aft. 1 degree of twist=20 100 shaft horsepower. A helical spline converts the twist into a linear motion that positions a pilot valve which varies oil pressure that is sensed by a torque compensator and converted to voltage sent to the horsepower gage. Whew! Now you see why I wouldn't use that system ... unless you use a TPE-331 to drive your ice cream maker. In that case, you'd have the system=20in place and you could turn out ice cream at a staggering pace. Think of the flavors! Garrett crunch. Oil chip lite (hmmmmm?). Turbine nut. Cinnamon Jet-A. Beta berry ... Wing Commander Gordon Life is not simple anywhere. Probably less so elsewhere. ________________________________________________________________________________
Date: Jul 05, 2004
What I really want to know is, Chris, how much ice cream do you have to make to justify building a TPE-powered 1,017 HP ice cream maker? Because then, the torque sensor would be included and it would be one less step for you.... I bet the Guinness Book folks would be interested were you to do that. /J ----- Original Message ----- From: "Chris Schuermann" <cschuerm(at)cox.net> Subject: Re: Commander-List: Running past TBO > > > CloudCraft(at)aol.com wrote: > > Truthfully, Chris, I'd never heard that and I thank you for such excellent > > insight to things that are out of sight. Thank you! > > Thanks for the kind words Keith. Just wish I could trade some of my > "grease" experience for some of your "actual" experience! :-) > > > Ya know, one of the coolest "out of sight" things I can think of on > Commanders is the torque sensing system of the TPE331. I'm trying to > build a similar configuration for my gas powered ice cream maker to > gauge the set on the ice cream. If I can get the basic mechanical > aspects working, I'll make a big, 1880's looking brass gauge head with > an artsy pointer for the thickness. So, what exactly IS the unit of > measure for the thickness of ice cream anyway??? > > chris > > PS: for those who don't know what the heck I'm talking about: > http://members.cox.net/vasoll/sei/oddities/gpicm.htm > > ________________________________________________________________________________
Date: Jul 06, 2004
Not if it's that grim. bilbo ----- Original Message ----- From: "Jim Addington" <jtaddington(at)charter.net> Subject: RE: Commander-List: Running past TBO > > Great article Chris, I will be looking forward to the one on the > Continentals. > > Jim Addington > N444BD > > ________________________________________________________________________________
Date: Jul 06, 2004
you guys are way way to bored for a long 4th weekend. mason >From: CloudCraft(at)aol.com >Reply-To: commander-list(at)matronics.com >To: commander-list(at)matronics.com >Subject: Commander-List: Ice Cream Commander >Date: Mon, 5 Jul 2004 22:33:15 EDT > > >In a message dated 05-Jul-04 18:16:45 Pacific Daylight Time, >cschuerm(at)cox.net >writes: > > > So, what exactly IS the unit of measure for the thickness of ice cream > > anyway??? > > > >"Scoop-pounds" if you're using English units of measurment. >"Scoop-hectopascalhertzbars" if you're using Metric units of measurment. > >It's the averaged force placed upon a SAE ice cream scoop to plunge it >into=20a >standing body of ice cream, make a "J" type stroke and then extract it. > >You can measure this with either a strain gauge or a hydraulic feed-back >system. I'd go with a piezoelectric strain gauge because the hydraulic >system >can leak and then you have 5606 Swirl when you were trying to make French >vanilla. > >In a pecan nutshell, the TPE-331 torque sensing system is done via a >torsion >shaft; two concentric shafts geared together at the aft. 1 degree of >twist >100 shaft horsepower. A helical spline converts the twist into a linear >motion that positions a pilot valve which varies oil pressure that is >sensed by a >torque compensator and converted to voltage sent to the horsepower gage. > >Whew! Now you see why I wouldn't use that system ... unless you use a >TPE-331 to drive your ice cream maker. In that case, you'd have the >system=20in >place and you could turn out ice cream at a staggering pace. > >Think of the flavors! Garrett crunch. Oil chip lite (hmmmmm?). Turbine >nut. Cinnamon Jet-A. Beta berry ... > >Wing Commander Gordon > >Life is not simple anywhere. Probably less so elsewhere. > > ________________________________________________________________________________
Date: Jul 06, 2004
Subject: Re: Ice Cream Commander
In a message dated 7/6/2004 6:27:36 AM Pacific Standard Time, kamala(at)msn.com writes: you guys are way way to bored for a long 4th weekend. mason AMEN!! jb ________________________________________________________________________________
Date: Jul 06, 2004
Subject: Spinner chrome
Anyone have any good suggestions about refinishing a chrome spinner that is suffering from pitting and peeling? Both of my spinners are a bit on the "crusty" side and I'd sure like to spiff them back up....just not enough to pay Hartzel$$$$$ for new ones. I'm afraid to bead blast them as it might harden the aluminum and cause future cracking. All of the local chrome shops mainly do motorcycle parts and won't touch it. thanks, Chris ________________________________________________________________________________
Date: Jul 06, 2004
YOURTCFG(at)aol.com wrote: > you guys are way way to bored for a long 4th weekend. mason > > > AMEN!! jb just trying to work a little amusing side-line topic into some good Commander discussion..... Y'all say something if it's an annoying distraction. chris ________________________________________________________________________________
Date: Jul 06, 2004
Not annoying. Just took a little while to figure out the ice cream connection. But good fun. Thanks Nico ----- Original Message ----- From: "Chris Schuermann" <cschuerm(at)cox.net> Subject: Re: Commander-List: Ice Cream Commander > > > YOURTCFG(at)aol.com wrote: > > you guys are way way to bored for a long 4th weekend. mason > > > > > > AMEN!! jb > > > just trying to work a little amusing side-line topic into some good > Commander discussion..... > Y'all say something if it's an annoying distraction. > > chris > > ________________________________________________________________________________
Subject: Re: Spinner chrome
Date: Jul 06, 2004
Take Battery Acid AND REMOVE THE CHROME. ----- Original Message ----- From: "Chris Schuermann" <cschuerm(at)cox.net> Subject: Commander-List: Spinner chrome > > > Anyone have any good suggestions about refinishing a chrome spinner that > is suffering from pitting and peeling? Both of my spinners are a bit on > the "crusty" side and I'd sure like to spiff them back up....just not > enough to pay Hartzel$$$$$ for new ones. I'm afraid to bead blast them > as it might harden the aluminum and cause future cracking. All of the > local chrome shops mainly do motorcycle parts and won't touch it. > > thanks, > Chris > > ________________________________________________________________________________
Date: Jul 06, 2004
Hadn't thought about that. I should have several hundred hours to go. Jim N444BD -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com]On Behalf Of Bill Bow Subject: Commander-List: Running past TBO Not if it's that grim. bilbo ----- Original Message ----- From: "Jim Addington" <jtaddington(at)charter.net> Subject: RE: Commander-List: Running past TBO > > Great article Chris, I will be looking forward to the one on the > Continentals. > > Jim Addington > N444BD > > ________________________________________________________________________________
Date: Jul 06, 2004
What do you mean, bored. This is cool stuff they are talking about, I can tell ya'll are not true ice cream eaters. Jim N444BD -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com]On Behalf Of YOURTCFG(at)aol.com Subject: Re: Commander-List: Ice Cream Commander In a message dated 7/6/2004 6:27:36 AM Pacific Standard Time, kamala(at)msn.com writes: you guys are way way to bored for a long 4th weekend. mason AMEN!! jb ________________________________________________________________________________
Date: Jul 06, 2004
avtec2(at)bellsouth.net wrote: > Take Battery Acid AND REMOVE THE CHROME. Really?!?! You've done that and it stripped the chrome without damaging the thin aluminum? Okay, Thanks! chris ________________________________________________________________________________
Date: Jul 06, 2004
blue bell rules, you know that jim. mason >From: "Jim Addington" <jtaddington(at)charter.net> >Reply-To: commander-list(at)matronics.com >To: >Subject: RE: Commander-List: Ice Cream Commander >Date: Tue, 6 Jul 2004 15:51:11 -0500 > > > >What do you mean, bored. This is cool stuff they are talking about, I can >tell ya'll are not true ice cream eaters. > >Jim >N444BD > >-----Original Message----- >From: owner-commander-list-server(at)matronics.com >[mailto:owner-commander-list-server(at)matronics.com]On Behalf Of >YOURTCFG(at)aol.com >To: commander-list(at)matronics.com >Subject: Re: Commander-List: Ice Cream Commander > > >In a message dated 7/6/2004 6:27:36 AM Pacific Standard Time, >kamala(at)msn.com >writes: > > >you guys are way way to bored for a long 4th weekend. mason > > >AMEN!! jb > > ________________________________________________________________________________
Date: Jul 06, 2004
I am afraid I do, and my belt size proves it. I weighed 160 until they put ice cream and yogurt in the terminals. Jim -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com]On Behalf Of MASON Chevaillier Subject: RE: Commander-List: Ice Cream Commander blue bell rules, you know that jim. mason >From: "Jim Addington" <jtaddington(at)charter.net> >Reply-To: commander-list(at)matronics.com >To: >Subject: RE: Commander-List: Ice Cream Commander >Date: Tue, 6 Jul 2004 15:51:11 -0500 > > > >What do you mean, bored. This is cool stuff they are talking about, I can >tell ya'll are not true ice cream eaters. > >Jim >N444BD > >-----Original Message----- >From: owner-commander-list-server(at)matronics.com >[mailto:owner-commander-list-server(at)matronics.com]On Behalf Of >YOURTCFG(at)aol.com >To: commander-list(at)matronics.com >Subject: Re: Commander-List: Ice Cream Commander > > >In a message dated 7/6/2004 6:27:36 AM Pacific Standard Time, >kamala(at)msn.com >writes: > > >you guys are way way to bored for a long 4th weekend. mason > > >AMEN!! jb > > ________________________________________________________________________________
Date: Jul 06, 2004
I weighed 160 until I hit the 10th grade. bilbo ----- Original Message ----- From: "Jim Addington" <jtaddington(at)charter.net> Subject: RE: Commander-List: Ice Cream Commander > > I am afraid I do, and my belt size proves it. I weighed 160 until they put > ice cream and yogurt in the terminals. > > Jim > > -----Original Message----- > From: owner-commander-list-server(at)matronics.com > [mailto:owner-commander-list-server(at)matronics.com]On Behalf Of MASON > Chevaillier > To: commander-list(at)matronics.com > Subject: RE: Commander-List: Ice Cream Commander > > > blue bell rules, you know that jim. mason > > > >From: "Jim Addington" <jtaddington(at)charter.net> > >Reply-To: commander-list(at)matronics.com > >To: > >Subject: RE: Commander-List: Ice Cream Commander > >Date: Tue, 6 Jul 2004 15:51:11 -0500 > > > > > > > >What do you mean, bored. This is cool stuff they are talking about, I can > >tell ya'll are not true ice cream eaters. > > > >Jim > >N444BD > > > >-----Original Message----- > >From: owner-commander-list-server(at)matronics.com > >[mailto:owner-commander-list-server(at)matronics.com]On Behalf Of > >YOURTCFG(at)aol.com > >To: commander-list(at)matronics.com > >Subject: Re: Commander-List: Ice Cream Commander > > > > > > > > > >In a message dated 7/6/2004 6:27:36 AM Pacific Standard Time, > >kamala(at)msn.com > >writes: > > > > > >you guys are way way to bored for a long 4th weekend. mason > > > > > >AMEN!! jb > > > > > > ________________________________________________________________________________
Date: Jul 06, 2004
MASON Chevaillier wrote: > blue bell rules, you know that jim. mason The blue bell plant is just across town from here. They're mere amatures... REAL ice cream costs $40/gal to make :-) (that's including the 100LL to power the machine - a bit more if you figure in hangar costs) chris ________________________________________________________________________________
Date: Jul 06, 2004
Hear, Hear, I agree. That is real ice cream. MMMMMM Good. I talked to George Dalton here in Denton and he has a 700 Commander and a 690 that he just bought. We are planning to have a Commander fly in here for hamburgers some afternoon. Mason if you are reading this you are going to have to get that old plane of yours put together and come up too. Chris you will have to bring your ice cream maker too. Jim N444BD -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com]On Behalf Of Chris Schuermann Subject: Re: Commander-List: Ice Cream Commander MASON Chevaillier wrote: > blue bell rules, you know that jim. mason The blue bell plant is just across town from here. They're mere amatures... REAL ice cream costs $40/gal to make :-) (that's including the 100LL to power the machine - a bit more if you figure in hangar costs) chris ________________________________________________________________________________
Date: Jul 06, 2004
You were taller though, I am only 5'9.5" tall. I weighed 135 all the way through USAF pilot school and survival school but they did something to me there because I gained 15 pounds quickly and then gained another 10 pounds. I stayed at 160 for about 20 years. I just wish I could get back to 180 now. Jim N444BD -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com]On Behalf Of Bill Bow Subject: Re: Commander-List: Ice Cream Commander I weighed 160 until I hit the 10th grade. bilbo ----- Original Message ----- From: "Jim Addington" <jtaddington(at)charter.net> Subject: RE: Commander-List: Ice Cream Commander > > I am afraid I do, and my belt size proves it. I weighed 160 until they put > ice cream and yogurt in the terminals. > > Jim > > -----Original Message----- > From: owner-commander-list-server(at)matronics.com > [mailto:owner-commander-list-server(at)matronics.com]On Behalf Of MASON > Chevaillier > To: commander-list(at)matronics.com > Subject: RE: Commander-List: Ice Cream Commander > > > blue bell rules, you know that jim. mason > > > >From: "Jim Addington" <jtaddington(at)charter.net> > >Reply-To: commander-list(at)matronics.com > >To: > >Subject: RE: Commander-List: Ice Cream Commander > >Date: Tue, 6 Jul 2004 15:51:11 -0500 > > > > > > > >What do you mean, bored. This is cool stuff they are talking about, I can > >tell ya'll are not true ice cream eaters. > > > >Jim > >N444BD > > > >-----Original Message----- > >From: owner-commander-list-server(at)matronics.com > >[mailto:owner-commander-list-server(at)matronics.com]On Behalf Of > >YOURTCFG(at)aol.com > >To: commander-list(at)matronics.com > >Subject: Re: Commander-List: Ice Cream Commander > > > > > > > > > >In a message dated 7/6/2004 6:27:36 AM Pacific Standard Time, > >kamala(at)msn.com > >writes: > > > > > >you guys are way way to bored for a long 4th weekend. mason > > > > > >AMEN!! jb > > > > > > ________________________________________________________________________________
Date: Jul 07, 2004
I'd settle for 220 the weight I was when I quit smoking. bilbo ----- Original Message ----- From: "Jim Addington" <jtaddington(at)charter.net> Subject: RE: Commander-List: Ice Cream Commander > > You were taller though, I am only 5'9.5" tall. I weighed 135 all the way > through USAF pilot school and survival school but they did something to me > there because I gained 15 pounds quickly and then gained another 10 pounds. > I stayed at 160 for about 20 years. I just wish I could get back to 180 now. > Jim > N444BD > > -----Original Message----- > From: owner-commander-list-server(at)matronics.com > [mailto:owner-commander-list-server(at)matronics.com]On Behalf Of Bill Bow > To: commander-list(at)matronics.com > Subject: Re: Commander-List: Ice Cream Commander > > > I weighed 160 until I hit the 10th grade. > > bilbo > ----- Original Message ----- > From: "Jim Addington" <jtaddington(at)charter.net> > To: > Subject: RE: Commander-List: Ice Cream Commander > > > > > > > I am afraid I do, and my belt size proves it. I weighed 160 until they put > > ice cream and yogurt in the terminals. > > > > Jim > > > > -----Original Message----- > > From: owner-commander-list-server(at)matronics.com > > [mailto:owner-commander-list-server(at)matronics.com]On Behalf Of MASON > > Chevaillier > > To: commander-list(at)matronics.com > > Subject: RE: Commander-List: Ice Cream Commander > > > > > > > > blue bell rules, you know that jim. mason > > > > > > >From: "Jim Addington" <jtaddington(at)charter.net> > > >Reply-To: commander-list(at)matronics.com > > >To: > > >Subject: RE: Commander-List: Ice Cream Commander > > >Date: Tue, 6 Jul 2004 15:51:11 -0500 > > > > > > > > > > > >What do you mean, bored. This is cool stuff they are talking about, I can > > >tell ya'll are not true ice cream eaters. > > > > > >Jim > > >N444BD > > > > > >-----Original Message----- > > >From: owner-commander-list-server(at)matronics.com > > >[mailto:owner-commander-list-server(at)matronics.com]On Behalf Of > > >YOURTCFG(at)aol.com > > >To: commander-list(at)matronics.com > > >Subject: Re: Commander-List: Ice Cream Commander > > > > > > > > > > > > > > >In a message dated 7/6/2004 6:27:36 AM Pacific Standard Time, > > >kamala(at)msn.com > > >writes: > > > > > > > > >you guys are way way to bored for a long 4th weekend. mason > > > > > > > > >AMEN!! jb > > > > > > > > > > > > ________________________________________________________________________________
Date: Jul 07, 2004
gaining weight in England means more money too. It's like gaining dollars in the US. :-) ----- Original Message ----- From: "Jim Addington" <jtaddington(at)charter.net> Subject: RE: Commander-List: Ice Cream Commander > > You were taller though, I am only 5'9.5" tall. I weighed 135 all the way > through USAF pilot school and survival school but they did something to me > there because I gained 15 pounds quickly and then gained another 10 pounds. > I stayed at 160 for about 20 years. I just wish I could get back to 180 now. > Jim > N444BD > > -----Original Message----- > From: owner-commander-list-server(at)matronics.com > [mailto:owner-commander-list-server(at)matronics.com]On Behalf Of Bill Bow > To: commander-list(at)matronics.com > Subject: Re: Commander-List: Ice Cream Commander > > > I weighed 160 until I hit the 10th grade. > > bilbo > ----- Original Message ----- > From: "Jim Addington" <jtaddington(at)charter.net> > To: > Subject: RE: Commander-List: Ice Cream Commander > > > > > > > I am afraid I do, and my belt size proves it. I weighed 160 until they put > > ice cream and yogurt in the terminals. > > > > Jim > > > > -----Original Message----- > > From: owner-commander-list-server(at)matronics.com > > [mailto:owner-commander-list-server(at)matronics.com]On Behalf Of MASON > > Chevaillier > > To: commander-list(at)matronics.com > > Subject: RE: Commander-List: Ice Cream Commander > > > > > > > > blue bell rules, you know that jim. mason > > > > > > >From: "Jim Addington" <jtaddington(at)charter.net> > > >Reply-To: commander-list(at)matronics.com > > >To: > > >Subject: RE: Commander-List: Ice Cream Commander > > >Date: Tue, 6 Jul 2004 15:51:11 -0500 > > > > > > > > > > > >What do you mean, bored. This is cool stuff they are talking about, I can > > >tell ya'll are not true ice cream eaters. > > > > > >Jim > > >N444BD > > > > > >-----Original Message----- > > >From: owner-commander-list-server(at)matronics.com > > >[mailto:owner-commander-list-server(at)matronics.com]On Behalf Of > > >YOURTCFG(at)aol.com > > >To: commander-list(at)matronics.com > > >Subject: Re: Commander-List: Ice Cream Commander > > > > > > > > > > > > > > >In a message dated 7/6/2004 6:27:36 AM Pacific Standard Time, > > >kamala(at)msn.com > > >writes: > > > > > > > > >you guys are way way to bored for a long 4th weekend. mason > > > > > > > > >AMEN!! jb > > > > > > > > > > > > ________________________________________________________________________________
Date: Jul 07, 2004
I knew I liked England, now I know why. All this time I thought it was the people. Jim -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com]On Behalf Of nico css Subject: Re: Commander-List: Ice Cream Commander > ________________________________________________________________________________
Subject: GO-435 C2B2 help
Date: Jul 10, 2004
I have for the last long time had a problem wth my right engine, in that the oil pressure is just at the bottom of the green. Have tried everything to fix it, and nothing simple seems to work. So, I think it is at least time for a new oil pump. Anyone familiar with the engine? (Chris....) In particular, is it necessary to dismantle every accessory in order to get to it? I have gotten a new pump body (no small feat, as they dont make them anymore.) and the gears are in production, so I can "just order" them. Should I also replace the driver shaft? (Again, scrounging involved, so I need to anticipate the need...) Also, where do you find cylinders/cam/crankshaft for a GO 435? (had a set when I got the plane, but they were stolen... So I need to find new ones). Etc. Any help is appreciated. Bruce Campbell AC52 N4186B ________________________________________________________________________________
From: "Martini Luc J.R." <martini(at)foxinternet.net>
Subject: Re: GO-435 C2B2 help
Date: Jul 11, 2004
I tried sending Bruce Campbell a section of the Lycoming Manual on Oil Sump/Pump replacement, but the message got bounced back. Must be a dead e-mail address. Luc ----- Original Message ----- From: "Bruce Campbell" <baruch(at)intelligentflight.com> Subject: Commander-List: GO-435 C2B2 help > > I have for the last long time had a problem wth my right engine, in that the oil pressure is just at the bottom of the green. Have tried everything to fix it, and nothing simple seems to work. > > So, I think it is at least time for a new oil pump. Anyone familiar with the engine? (Chris....) In particular, is it necessary to dismantle every accessory in order to get to it? I have gotten a new pump body (no small feat, as they dont make them anymore.) and the gears are in production, so I can "just order" them. Should I also replace the driver shaft? (Again, scrounging involved, so I need to anticipate the need...) > > Also, where do you find cylinders/cam/crankshaft for a GO 435? (had a set when I got the plane, but they were stolen... So I need to find new ones). > > Etc. Any help is appreciated. > > Bruce Campbell > AC52 N4186B > > ________________________________________________________________________________
Date: Jul 11, 2004
In re. Bruce Cambell. I reread bounce message. "Access Denied", he must have some sort of spam filter that keeps EVERYBODY out, not the way to get answers from a forum. Luc ----- Original Message ----- From: "Bruce Campbell" <baruch(at)intelligentflight.com> Subject: Commander-List: GO-435 C2B2 help > > I have for the last long time had a problem wth my right engine, in that the oil pressure is just at the bottom of the green. Have tried everything to fix it, and nothing simple seems to work. > > So, I think it is at least time for a new oil pump. Anyone familiar with the engine? (Chris....) In particular, is it necessary to dismantle every accessory in order to get to it? I have gotten a new pump body (no small feat, as they dont make them anymore.) and the gears are in production, so I can "just order" them. Should I also replace the driver shaft? (Again, scrounging involved, so I need to anticipate the need...) > > Also, where do you find cylinders/cam/crankshaft for a GO 435? (had a set when I got the plane, but they were stolen... So I need to find new ones). > > Etc. Any help is appreciated. > > Bruce Campbell > AC52 N4186B > > ________________________________________________________________________________
Date: Jul 11, 2004
Bruce Campbell wrote: > I have for the last long time had a problem wth my right engine Howdy Bruce. Wow, I can't believe you're still running that right engine. She had more life in her than I expected! It's been too many years since I last had one of those apart, but I seem to recall that you can pull the accessory case off the back of the engine without splitting the case. That should give you access to the pump and housing. I'd recomend calling Central Cylinder in NB. They probably have more geared Lyc parts than anyone else. You might also check Custom Airmotive in Tulsa. They used to do a lot of GO-435s and 480s and had tons of cores. http://centralcylinder.com/ http://customairmotive.com/ > Also, where do you find cylinders/cam/crankshaft for a GO 435? (had > a set when I got the plane, but they were stolen... So I need to find > new ones). Wow, sorry to hear that. With the exception of the nose gear case, that was almost an entire engine of factory new parts. I got the cylinders from El Reno Aviation. Their number is: 405-262-2387 I have 5 cylinders which you are welcome to. They came off the engine that swallowed the exhaust valve. You could probably run them as-is for a while, but I'd STRONGLY suggest that they be overhauled. They still have 7/16" valves and there's a good chance that another would break if put back into service. They're yours if you come get 'em! Chris ________________________________________________________________________________
Date: Jul 11, 2004
In re. Bruce: A quick read of the Lycoming Manual indicates all you do is drop the pan on a -C2 engine. I tried to send Bruce 8 pages from the manual, but they did not make it. Luc ----- Original Message ----- From: "Chris Schuermann" <cschuerm(at)cox.net> Subject: Re: Commander-List: GO-435 C2B2 help > > > Bruce Campbell wrote: > > I have for the last long time had a problem wth my right engine > > Howdy Bruce. Wow, I can't believe you're still running that right > engine. She had more life in her than I expected! > It's been too many years since I last had one of those apart, but I seem > to recall that you can pull the accessory case off the back of the > engine without splitting the case. That should give you access to the > pump and housing. I'd recomend calling Central Cylinder in NB. They > probably have more geared Lyc parts than anyone else. You might also > check Custom Airmotive in Tulsa. They used to do a lot of GO-435s and > 480s and had tons of cores. > http://centralcylinder.com/ > http://customairmotive.com/ > > > Also, where do you find cylinders/cam/crankshaft for a GO 435? (had > > a set when I got the plane, but they were stolen... So I need to find > > new ones). > > Wow, sorry to hear that. With the exception of the nose gear case, that > was almost an entire engine of factory new parts. I got the cylinders > from El Reno Aviation. Their number is: 405-262-2387 > > I have 5 cylinders which you are welcome to. They came off the engine > that swallowed the exhaust valve. You could probably run them as-is for > a while, but I'd STRONGLY suggest that they be overhauled. They still > have 7/16" valves and there's a good chance that another would break if > put back into service. They're yours if you come get 'em! > > Chris > > ________________________________________________________________________________
Date: Jul 11, 2004
I checked the book again, and it looks like in the GO435-C2 you have a dry sump, with a scavenge pump in the pan, and the Pressure pump in the Gear case. The book is hard to follow since it talks to three engine types: GO435, GO480, and GO-540 each of which can come with gear cases on the back or on the side. Luc ----- Original Message ----- From: "Martini Luc J.R." <martini(at)foxinternet.net> Subject: Re: Commander-List: GO-435 C2B2 help > > In re. Bruce: > A quick read of the Lycoming Manual indicates all you do is drop the pan on > a -C2 engine. > > I tried to send Bruce 8 pages from the manual, but they did not make it. > Luc > ----- Original Message ----- > From: "Chris Schuermann" <cschuerm(at)cox.net> > To: > Subject: Re: Commander-List: GO-435 C2B2 help > > > > > > > > Bruce Campbell wrote: > > > I have for the last long time had a problem wth my right engine > > > > Howdy Bruce. Wow, I can't believe you're still running that right > > engine. She had more life in her than I expected! > > It's been too many years since I last had one of those apart, but I seem > > to recall that you can pull the accessory case off the back of the > > engine without splitting the case. That should give you access to the > > pump and housing. I'd recomend calling Central Cylinder in NB. They > > probably have more geared Lyc parts than anyone else. You might also > > check Custom Airmotive in Tulsa. They used to do a lot of GO-435s and > > 480s and had tons of cores. > > http://centralcylinder.com/ > > http://customairmotive.com/ > > > > > Also, where do you find cylinders/cam/crankshaft for a GO 435? (had > > > a set when I got the plane, but they were stolen... So I need to find > > > new ones). > > > > Wow, sorry to hear that. With the exception of the nose gear case, that > > was almost an entire engine of factory new parts. I got the cylinders > > from El Reno Aviation. Their number is: 405-262-2387 > > > > I have 5 cylinders which you are welcome to. They came off the engine > > that swallowed the exhaust valve. You could probably run them as-is for > > a while, but I'd STRONGLY suggest that they be overhauled. They still > > have 7/16" valves and there's a good chance that another would break if > > put back into service. They're yours if you come get 'em! > > > > Chris > > > > > > ________________________________________________________________________________
Date: Jul 11, 2004
Martini Luc J.R. wrote: > I checked the book again, and it looks like in the GO435-C2 you have a dry > sump, with a scavenge pump in the pan, and the Pressure pump in the Gear > case. The book is hard to follow since it talks to three engine types: > GO435, GO480, and GO-540 each of which can come with gear cases on the back > or on the side. Nope, the 435's are wet sump. There are some dry sump versions of the 480 though. chris ________________________________________________________________________________
From: "Randy Dettmer, AIA" <rcdettmer(at)charter.net>
Subject: Hitching a ride..??
Date: Jul 12, 2004
Hi Everyone, I'll be flying 53X from SBP (San Luis Obispo, CA) up to Stockton, CA for it's annual inspection by Morris K. the last week of this month. Anybody passing by Stockton headed south that week..?? Sure would like to hitch a ride home to SBP. I will, of course, cover costs for fuel...and shower you with appreciation. Sure would rather be at Oshkosh that week...but, oh well. Thanks, Randy Dettmer 680F/N6253X ________________________________________________________________________________
Subject: Re: Hitching a ride..??
Date: Jul 12, 2004
Randy, I'll be doing some work at Morris' that week prior to sending my airplane to MO for paint. I was figuring on visiting my brother in SBP, so let's talk about it and see if we coincide. /John ----- Original Message ----- From: "Randy Dettmer, AIA" <rcdettmer(at)charter.net> Subject: Commander-List: Hitching a ride..?? > > Hi Everyone, > I'll be flying 53X from SBP (San Luis Obispo, CA) up to Stockton, CA for it's annual inspection by Morris K. the last week of this month. Anybody passing by Stockton headed south that week..?? Sure would like to hitch a ride home to SBP. I will, of course, cover costs for fuel...and shower you with appreciation. > > Sure would rather be at Oshkosh that week...but, oh well. > > Thanks, > Randy Dettmer > 680F/N6253X > > ________________________________________________________________________________
Date: Jul 12, 2004
Hey John...sounds great. I can drop off my plane anytime that week. Let me know what works for you. Thanks, Randy ----- Original Message ----- From: "John Vormbaum" <john(at)vormbaum.com> Subject: Re: Commander-List: Hitching a ride..?? > > Randy, I'll be doing some work at Morris' that week prior to sending my > airplane to MO for paint. I was figuring on visiting my brother in SBP, so > let's talk about it and see if we coincide. > > /John > > ----- Original Message ----- > From: "Randy Dettmer, AIA" <rcdettmer(at)charter.net> > To: "Commander Chat" > Subject: Commander-List: Hitching a ride..?? > > > > > > > Hi Everyone, > > I'll be flying 53X from SBP (San Luis Obispo, CA) up to Stockton, CA for > it's annual inspection by Morris K. the last week of this month. Anybody > passing by Stockton headed south that week..?? Sure would like to hitch a > ride home to SBP. I will, of course, cover costs for fuel...and shower you > with appreciation. > > > > Sure would rather be at Oshkosh that week...but, oh well. > > > > Thanks, > > Randy Dettmer > > 680F/N6253X > > > > > > ________________________________________________________________________________
Date: Jul 12, 2004
Subject: Continental engine notes
Okay, several folks have asked me if there's any specific items that might help make decisions about when and how to overhaul Continental engines. Two BIG items are the case and crank. Most Continental owners (I hope) already know that the factory changed the method used to make cranks. They were having a bit of trouble with cranks breaking. The new process is refered to as VAR (vaccum arc remelt). If you have a non-VAR crank, it is required to be replaced with a VAR crank any time the case is split! This is an important note - if you have to open the case for any reason - even on a low time engine - the crank must be replaced. Did I mention that they're rather expensive? Keep that in mind if you're looking at buying an airplane that doesn't have the new crank - you never know what might happen that would require an early split. A minor prop strike requires an internal inspection for example. There have been four (I believe) revisions of the 6 cylinder Continental case assembly. If you have a first generation case, consider it a throw-away item at overhaul. They had a LOT of problems with those cases cracking. I've seen airplanes with cylinders laying in the bottom of the cowling with part of the case still attached. Only the absolute cheapest shops would consider re-using a phase I case at overhaul. THe phase III/VI cases can be identified by bumps along the upper spine of the case where the bolts go through. These are the heavier cases which are most desirable. They also have a Teledyne logo at the rear of the case - behind the right rear cylinder if memory serves. Here's where the decision making part comes in. IF you happen to have an engine with an early case and/or a non-VAR crank, you'll almost certainly want to send it in for a factory re-man. When Continental receives such an engine for overhaul, they toss the case and crank in the junk pile and you get a new case and crank at no additional cost (this will change as some point no doubt). Generally, going for a factory re-man is very cost effective in this case as a field overhauler would have to purchase a new or servicable crank and case. (and I personally hate getting "servicable" parts since I never know what happend to cause them to end up on the market and NOT in an engine). Hope I havn't make everyone paranoid now with all this engine talk! :-) Chris ________________________________________________________________________________
Date: Jul 12, 2004
John Vormbaum wrote: > Randy, I'll be doing some work at Morris' that week prior to sending my > airplane to MO for paint. Howdy John! I can't believe you're going to paint your airplane! :-) Where are you having it done at? Maybe I can meet up somewhere for a visit. cheers, Chris ________________________________________________________________________________
Date: Jul 12, 2004
Hey Chris :-). Yeah, there's more metal visible now than paint, so I figure that means it's time. I'm going to a place called Hangar One in Malden, MO. The airplane will be arriving there the first week of August, but because of my work schedule, I'm not positive yet that I'll be accompanying it. I get to pick it up the weekend of the fly-in. Can you believe it? I'll be showing up to the fly-in with a brand spankin' new paint job! Woohoo! I'll ping you when the date gets closer, maybe we can connect! /J ----- Original Message ----- From: "Chris Schuermann" <cschuerm(at)cox.net> Subject: Re: Commander-List: Hitching a ride..?? > > > John Vormbaum wrote: > > Randy, I'll be doing some work at Morris' that week prior to sending my > > airplane to MO for paint. > > Howdy John! > I can't believe you're going to paint your airplane! :-) > Where are you having it done at? Maybe I can meet up somewhere for a visit. > > cheers, > Chris > > ________________________________________________________________________________
Date: Jul 12, 2004
I'll give you a shout when the date gets a little closer & we'll figure it out. /J ----- Original Message ----- From: "Randy Dettmer, AIA" <rcdettmer(at)charter.net> Subject: Re: Commander-List: Hitching a ride..?? > > Hey John...sounds great. I can drop off my plane anytime that week. Let me > know what works for you. > > Thanks, > Randy > > > ----- Original Message ----- > From: "John Vormbaum" <john(at)vormbaum.com> > To: > Subject: Re: Commander-List: Hitching a ride..?? > > > > > > Randy, I'll be doing some work at Morris' that week prior to sending my > > airplane to MO for paint. I was figuring on visiting my brother in SBP, so > > let's talk about it and see if we coincide. > > > > /John > > > > ----- Original Message ----- > > From: "Randy Dettmer, AIA" <rcdettmer(at)charter.net> > > To: "Commander Chat" > > Subject: Commander-List: Hitching a ride..?? > > > > > > > > > > > > Hi Everyone, > > > I'll be flying 53X from SBP (San Luis Obispo, CA) up to Stockton, CA > for > > it's annual inspection by Morris K. the last week of this month. Anybody > > passing by Stockton headed south that week..?? Sure would like to hitch a > > ride home to SBP. I will, of course, cover costs for fuel...and shower > you > > with appreciation. > > > > > > Sure would rather be at Oshkosh that week...but, oh well. > > > > > > Thanks, > > > Randy Dettmer > > > 680F/N6253X > > > > > > > > > > > > ________________________________________________________________________________
Subject: Wet Vacuum pumps
Date: Jul 13, 2004
3.6 ALT_MED Misspelled medication name Gents, What is the life expectancy of the wet vacuum pumps, such as the ones on my 680F(p)? Can't seem to find anything on this. Thanks! Moe N680RR ________________________________________________________________________________
Date: Jul 13, 2004
Subject: Re: Wet Vacuum pumps
Moe wrote: > What is the life expectancy of the wet vacuum pumps It's kinda like how many licks does it take to the center of a tootsie pop.... the world may never know.... The pumps on my 520 were orig 1953 with about 4000 hours on them. I've never seen an overhaul recomendation, but I'd think it would be prudent to overhaul them (and the rest of the accessories) when the engines are overhauled. chris ________________________________________________________________________________
Date: Jul 13, 2004
Moe The wet vac pumps will outlive the engines easily. Depending on what make you have, the common ones being Pesco and Aro. Aro parts are expensive and reasonably rare, Pesco on the other hand are a lot cheaper to do. I have numerous spare ones that I have collected. Regards Richard ________________________________________________________________________________
Date: Jul 14, 2004
From: W J R HAMILTON <wjrhamilton(at)optusnet.com.au>
Folks, That's the great beauty of wet vac. pumps, --- on condition. If they are working fine, leave sleeping dogs lay, and unlike dry pumps, sudden failures seem to be rare, somewhat in contrast to the vanes in dry pumps. Cheers, Bill Hamilton. At 09:16 14/07/2004, you wrote: > >Moe > >The wet vac pumps will outlive the engines easily. Depending on what make you >have, the common ones being Pesco and Aro. Aro parts are expensive and >reasonably rare, Pesco on the other hand are a lot cheaper to do. I have >numerous >spare ones that I have collected. > >Regards >Richard > > CONFIDENTIALITY & PRIVILEGE NOTICE W.J.R.Hamilton,Glenalmond Group Companies,Fighter Flights Internet Services and Warbirds.Net. & . This message is intended for and should only be used by the addressee. It is confidential and may contain legally privileged information.If you are not the intended recipient any use distribution,disclosure or copying of this message is strictly prohibited.Confidentiality and legal privilege attached to this communication are not waived or lost by reason of the mistaken delivery to you.If you have received this message in error, please notify us immediately to Australia 61 (0)408 876 526 ________________________________________________________________________________
Date: Jul 14, 2004
Subject: Re: Aero Commander For Sale
Hi all' I have dedcided to sell my Aero Commander after much work and restoration. Please look at the photo's to see results of several years of effort. I believe it to be the best example of a 520 available. 5838 TT 612 SMOH Left with New Top 196 SMOH Right- 125 since New Props and Hubs (no AD's) Great New Panel with Garmin 430, S-tec AutoPilot, Annnunciator lights and much more. New paint and recent interior Compete spec sheet and photo's at www.thomsonaviation.com Will entertain any reasonable offer and consider partial trade for small single engine. It flies great and will make someone a great aircraft. Thanks, James Lyle N11L 706-799-2602 cell ________________________________________________________________________________
Date: Jul 14, 2004
till they go south. maon >From: "Moe" <moe(at)rosspistons.com> >Reply-To: commander-list(at)matronics.com >To: >Subject: Commander-List: Wet Vacuum pumps >Date: Tue, 13 Jul 2004 12:12:40 -0700 3.6 ALT_MED >Misspelled medication name > > > Gents, > >What is the life expectancy of the wet vacuum pumps, such as the ones on my >680F(p)? Can't seem to find anything on this. > >Thanks! > >Moe >N680RR > > ________________________________________________________________________________
Subject: KEYS
Date: Nov 05, 2003
Does anybody have a suggestion for getting a key for the door to a 500B? dan farmer ________________________________________________________________________________
Subject: KEYS
Date: Jul 19, 2004
Dan, Try the keys from another Commander or maybe even an other plane. My door key to the airline airplanes would fit my Commander but the Commander key would not fit the airline airplane doors. The other thing would be to re-key or replace the lock. These are just my suggestions. Jim Addington N444BD -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com]On Behalf Of Daniel Farmer Subject: Commander-List: KEYS Does anybody have a suggestion for getting a key for the door to a 500B? dan farmer ________________________________________________________________________________
Date: Jul 20, 2004
Subject: KEYS
Folks, I have just put a new barrel in the main door lock of -DCF, once I figured how to remove the pin to dismantle it all, it was easy. A standard barrel was found amongst the great variety at the local locksmith. Internally, the slot the tongue dropped into was really chewed out, but it was relatively easy to turn up a new insert and just file the tongue slot. Needless to say, this time I used a bit of annealed stainless for the tongue slot piece, no more corrosion. Cheers, Bill Hamilton At 01:12 20/07/2004, you wrote: > > >Dan, >Try the keys from another Commander or maybe even an other plane. My door >key to the airline airplanes would fit my Commander but the Commander key >would not fit the airline airplane doors. The other thing would be to re-key >or replace the lock. These are just my suggestions. > >Jim Addington >N444BD > > >-----Original Message----- >From: owner-commander-list-server(at)matronics.com >[mailto:owner-commander-list-server(at)matronics.com]On Behalf Of Daniel >Farmer >To: commander-list(at)matronics.com >Subject: Commander-List: KEYS > > > > >Does anybody have a suggestion for getting a key for the door to a 500B? >dan farmer > > CONFIDENTIALITY & PRIVILEGE NOTICE W.J.R.Hamilton,Glenalmond Group Companies,Fighter Flights Internet Services and Warbirds.Net. & . This message is intended for and should only be used by the addressee. It is confidential and may contain legally privileged information.If you are not the intended recipient any use distribution,disclosure or copying of this message is strictly prohibited.Confidentiality and legal privilege attached to this communication are not waived or lost by reason of the mistaken delivery to you.If you have received this message in error, please notify us immediately to Australia 61 (0)408 876 526 ________________________________________________________________________________
Subject: Door Key
Date: Jul 20, 2004
>Does anybody have a suggestion for getting a key for the door to a 500B? dan farmer I had one cut for my 500B at a locksmith who told me that it is the same as an older Ford tractor. Larry Wokral ________________________________________________________________________________
Subject: RE: Commander-List Digest: 3 Msgs - 07/19/04
Date: Jul 20, 2004
I recall vividly Dick Wartinger saying that all Commander keys are actually Studebaker keys. He pronounced it "Stoo-Dee-Baker!" I might suggest a call to Commander Aero for replacements; and they are apparently all the same cut. Regards, John McNulty -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Commander-List Digest Server Subject: Commander-List Digest: 3 Msgs - 07/19/04 * ================================================== Online Versions of Today's List Digest Archive ================================================== Today's complete Commander-List Digest can be also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the Commander-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/commander-list/Digest.Commander-List.200 4-07-19.html Text Version: http://www.matronics.com/digest/commander-list/Digest.Commander-List.200 4-07-19.txt ================================================ EMail Version of Today's List Digest Archive ================================================ Commander-List Digest Archive --- Total Messages Posted Mon 07/19/04: 3 Today's Message Index: ---------------------- 1. 06:20 AM - KEYS (Daniel Farmer) 2. 08:12 AM - Re: KEYS (Jim Addington) 3. 05:44 PM - Re: KEYS (W J R HAMILTON) ________________________________ Message 1 _____________________________________ From: "Daniel Farmer" <daniellfarmer(at)yahoo.com> Subject: Commander-List: KEYS --> Does anybody have a suggestion for getting a key for the door to a 500B? dan farmer ________________________________ Message 2 _____________________________________ From: "Jim Addington" <jtaddington(at)charter.net> Subject: RE: Commander-List: KEYS --> Dan, Try the keys from another Commander or maybe even an other plane. My door key to the airline airplanes would fit my Commander but the Commander key would not fit the airline airplane doors. The other thing would be to re-key or replace the lock. These are just my suggestions. Jim Addington N444BD -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com]On Behalf Of Daniel Farmer Subject: Commander-List: KEYS Does anybody have a suggestion for getting a key for the door to a 500B? dan farmer ________________________________ Message 3 _____________________________________ From: W J R HAMILTON <wjrhamilton(at)optusnet.com.au> Subject: RE: Commander-List: KEYS --> Folks, I have just put a new barrel in the main door lock of -DCF, once I figured how to remove the pin to dismantle it all, it was easy. A standard barrel was found amongst the great variety at the local locksmith. Internally, the slot the tongue dropped into was really chewed out, but it was relatively easy to turn up a new insert and just file the tongue slot. Needless to say, this time I used a bit of annealed stainless for the tongue slot piece, no more corrosion. Cheers, Bill Hamilton At 01:12 20/07/2004, you wrote: > > >Dan, >Try the keys from another Commander or maybe even an other plane. My >door key to the airline airplanes would fit my Commander but the >Commander key would not fit the airline airplane doors. The other thing >would be to re-key or replace the lock. These are just my suggestions. > >Jim Addington >N444BD > > >-----Original Message----- >From: owner-commander-list-server(at)matronics.com >[mailto:owner-commander-list-server(at)matronics.com]On Behalf Of Daniel >Farmer >To: commander-list(at)matronics.com >Subject: Commander-List: KEYS > > > > >Does anybody have a suggestion for getting a key for the door to a 500B? >dan farmer > > CONFIDENTIALITY & PRIVILEGE NOTICE W.J.R.Hamilton,Glenalmond Group Companies,Fighter Flights Internet Services and Warbirds.Net. & . This message is intended for and should only be used by the addressee. It is confidential and may contain legally privileged information.If you are not the intended recipient any use distribution,disclosure or copying of this message is strictly prohibited.Confidentiality and legal privilege attached to this communication are not waived or lost by reason of the mistaken delivery to you.If you have received this message in error, please notify us immediately to Australia 61 (0)408 876 526 == direct advertising on the Matronics Forums. == == == ________________________________________________________________________________
Date: Jul 20, 2004
Subject: Re: RE: Commander-List Digest: 3 Msgs - 07/19/04
In a message dated 20-Jul-04 12:00:31 Pacific Daylight Time, JMcNulty(at)socalpizza.com writes: > I recall vividly Dick Wartinger saying that all Commander keys > are actually Studebaker keys. He pronounced it "Stoo-Dee-Baker!" > The Stoo Dee Baker connection with Commanders keeps popping up. I wish I could find some answers. There was talk about 2 years ago about the original Commander logo (the word, not the graphic of the airplane) came from Studebaker. One thing I do know about Commander keys is that Ted Smith used the same locks and keys for the AeroStars. Thus, the AeroStar and original Commander keys are all the same. If you can come across an owner of either aircraft (with original locks) a duplicate can be made. Wing Commander Gordon Life is not simple anywhere. Probably less so elsewhere. ________________________________________________________________________________
Subject: Chat virus on list
Date: Jul 22, 2004
I keep getting email from "Chat" with virus files attached. The body of the email shows it comes from chat(at)skymaster.c2-tech.com. Isn't this Chris's old list address? Nico ________________________________________________________________________________
Date: Jul 22, 2004
Subject: Re: Chat virus on list
nico css wrote: > I keep getting email from "Chat" with virus files attached. The body of the > email shows it comes from chat(at)skymaster.c2-tech.com. Isn't this Chris's old > list address? Someone subscribed to the list has a virus. Many of the current nasty ones send out email to everyone in their address book and the "From" address is forged from another entry in the address book. This is a huge, known hole in microsoft's email client. Should be easy enough to find as I can't imagine there are that many chat list members running Outlook with your address in their book. Take a look everyone and see if you are the guilty one.... Chris ________________________________________________________________________________
Date: Jul 22, 2004
Got an email message from John Vornbaum this morning that looked VERY suspicious. It contained an attachment which most likely was a virus. I deleted it. Some nasty virus probably pulled John's name from an address book and sent the message to me. It's importent to be vigilant and alert to supicious looking emails. Good luck everyone..!! Randy Dettmer ----- Original Message ----- From: "Chris Schuermann" <cschuerm(at)cox.net> Subject: Re: Commander-List: Chat virus on list > > > nico css wrote: > > I keep getting email from "Chat" with virus files attached. The body of the > > email shows it comes from chat(at)skymaster.c2-tech.com. Isn't this Chris's old > > list address? > > Someone subscribed to the list has a virus. Many of the current nasty > ones send out email to everyone in their address book and the "From" > address is forged from another entry in the address book. This is a > huge, known hole in microsoft's email client. Should be easy enough to > find as I can't imagine there are that many chat list members running > Outlook with your address in their book. Take a look everyone and see > if you are the guilty one.... > > Chris > > ________________________________________________________________________________
Date: Jul 22, 2004
I definitely didn't send anything to you, Randy. I'll check my system, although it came up clean last night... /John ----- Original Message ----- From: "Randy Dettmer, AIA" <rcdettmer(at)charter.net> Subject: Re: Commander-List: Chat virus on list > > Got an email message from John Vornbaum this morning that looked VERY > suspicious. It contained an attachment which most likely was a virus. I > deleted it. Some nasty virus probably pulled John's name from an address > book and sent the message to me. It's importent to be vigilant and alert to > supicious looking emails. > > Good luck everyone..!! > > Randy Dettmer > > > ----- Original Message ----- > From: "Chris Schuermann" <cschuerm(at)cox.net> > To: > Subject: Re: Commander-List: Chat virus on list > > > > > > > > nico css wrote: > > > I keep getting email from "Chat" with virus files attached. The body of > the > > > email shows it comes from chat(at)skymaster.c2-tech.com. Isn't this Chris's > old > > > list address? > > > > Someone subscribed to the list has a virus. Many of the current nasty > > ones send out email to everyone in their address book and the "From" > > address is forged from another entry in the address book. This is a > > huge, known hole in microsoft's email client. Should be easy enough to > > find as I can't imagine there are that many chat list members running > > Outlook with your address in their book. Take a look everyone and see > > if you are the guilty one.... > > > > Chris > > > > > > ________________________________________________________________________________
Date: Jul 22, 2004
Hi John, That's what I figured. I'm sure that it was a rogue virus-infected program out there somewhere. Got to keep alert. Randy ----- Original Message ----- From: "John Vormbaum" <john(at)vormbaum.com> Subject: Re: Commander-List: Chat virus on list > > I definitely didn't send anything to you, Randy. > > I'll check my system, although it came up clean last night... > > /John > ----- Original Message ----- > From: "Randy Dettmer, AIA" <rcdettmer(at)charter.net> > To: > Subject: Re: Commander-List: Chat virus on list > > > > > > > Got an email message from John Vornbaum this morning that looked VERY > > suspicious. It contained an attachment which most likely was a virus. I > > deleted it. Some nasty virus probably pulled John's name from an address > > book and sent the message to me. It's importent to be vigilant and alert > to > > supicious looking emails. > > > > Good luck everyone..!! > > > > Randy Dettmer > > > > > > ----- Original Message ----- > > From: "Chris Schuermann" <cschuerm(at)cox.net> > > To: > > Subject: Re: Commander-List: Chat virus on list > > > > > > > > > > > > > > nico css wrote: > > > > I keep getting email from "Chat" with virus files attached. The body > of > > the > > > > email shows it comes from chat(at)skymaster.c2-tech.com. Isn't this > Chris's > > old > > > > list address? > > > > > > Someone subscribed to the list has a virus. Many of the current nasty > > > ones send out email to everyone in their address book and the "From" > > > address is forged from another entry in the address book. This is a > > > huge, known hole in microsoft's email client. Should be easy enough to > > > find as I can't imagine there are that many chat list members running > > > Outlook with your address in their book. Take a look everyone and see > > > if you are the guilty one.... > > > > > > Chris > > > > > > > > > > > > ________________________________________________________________________________
Date: Jul 22, 2004
Randy Dettmer, AIA wrote: > That's what I figured. I'm sure that it was a rogue virus-infected program > out there somewhere. Got to keep alert. So true Randy! The one that appeared to be from the skymaster.c2-tech.com address was a good example. Neither that computer or even the domain exists any more. Whoever had the virus had that old address in their address book still. I see nobody has "fessed up" yet :-) Chris ________________________________________________________________________________
Date: Jul 22, 2004
the virus is in matronics !!! ...several "lists" are being duplicated and spread all over...i blocked yak-list(at)matronics.com and stopped most of my unwanted email, but it has started again (2 days later)--- On Thu 07/22, John Vormbaum john(at)vormbaum.com wrote: From: John Vormbaum [mailto: john(at)vormbaum.com]To: commander-list(at)matronics.comDate: Thu, 22 Jul 2004 10:02:54 -0700Subject: Re: Commander-List: Chat virus on list-- Commander-List message posted by: "John Vormbaum" I definitely didn't send anything to you, Randy.I'll check my system, although it came up clean last night.../John----- Original Message ----- From: "Randy Dettmer, AIA" To: Subject: Re: Commander-List: Chat virus on list -- Commander-List message posted by: "Randy Dettmer, AIA" Got an email message from John Vornbaum this morning that looked VERY suspicious. It contained an attachment which most likely was a virus. I deleted it. Some nasty virus probably pulled John's name from an address book and sent the message to me. It's importent to be vigilant and alertto supicious looking emails. Good luck everyone..!! Randy Dettmer ----- Original Message ----- From: "Chris Schuermann" To: Subj Join Excite! - http://www.excite.com The most personalized portal on the Web! ________________________________________________________________________________
Date: Jul 22, 2004
A possible source could be the chat list text pages, which are visible on the internet. I typed my name in google.com and many chats that I was involved in, when our email address was still c2-tech, came up in the search results. If an Internet crawler goes over these pages, it will harvest all those email addresses and who knows what these suckers do with them. The fact that the c2-tech domain has been out of circulation for quite a while already, gives credence to my theory. Go into google.com and type in "Randy Dettmer" (not the quotes) and the very first item shown is our chatlist with all sorts of email addresses in the text. Some of you might remember that when Matt took over the list, I supplied all the old chat lists from my server (I am a nut for collecting all sorts of useless things) and they also come up in that context, but with the old email addresses intact. In google type in "barry hancock commander list" (not the quotes) and you can see the old list in the archives coming up right away. That is the thread in which Milt wanted to know if I really exist. :-) Nico ----- Original Message ----- From: "Chris Schuermann" <cschuerm(at)cox.net> Subject: Re: Commander-List: Chat virus on list > > > Randy Dettmer, AIA wrote: > > That's what I figured. I'm sure that it was a rogue virus-infected program > > out there somewhere. Got to keep alert. > > So true Randy! > The one that appeared to be from the skymaster.c2-tech.com address was a > good example. Neither that computer or even the domain exists any more. > Whoever had the virus had that old address in their address book still. > I see nobody has "fessed up" yet :-) > > Chris > > ________________________________________________________________________________
Date: Jul 22, 2004
They spoof our names. How they get hold of them is a mystery, or an art in deception. I noticed that names of people that I communicate with appear as "From" people in spam mails. They are not even in my address book. So, now we are aware of them. Nico ----- Original Message ----- From: "John Vormbaum" <john(at)vormbaum.com> Subject: Re: Commander-List: Chat virus on list > > I definitely didn't send anything to you, Randy. > > I'll check my system, although it came up clean last night... > > /John > ----- Original Message ----- > From: "Randy Dettmer, AIA" <rcdettmer(at)charter.net> > To: > Subject: Re: Commander-List: Chat virus on list > > > > > > > Got an email message from John Vornbaum this morning that looked VERY > > suspicious. It contained an attachment which most likely was a virus. I > > deleted it. Some nasty virus probably pulled John's name from an address > > book and sent the message to me. It's importent to be vigilant and alert > to > > supicious looking emails. > > > > Good luck everyone..!! > > > > Randy Dettmer > > > > > > ----- Original Message ----- > > From: "Chris Schuermann" <cschuerm(at)cox.net> > > To: > > Subject: Re: Commander-List: Chat virus on list > > > > > > > > > > > > > > nico css wrote: > > > > I keep getting email from "Chat" with virus files attached. The body > of > > the > > > > email shows it comes from chat(at)skymaster.c2-tech.com. Isn't this > Chris's > > old > > > > list address? > > > > > > Someone subscribed to the list has a virus. Many of the current nasty > > > ones send out email to everyone in their address book and the "From" > > > address is forged from another entry in the address book. This is a > > > huge, known hole in microsoft's email client. Should be easy enough to > > > find as I can't imagine there are that many chat list members running > > > Outlook with your address in their book. Take a look everyone and see > > > if you are the guilty one.... > > > > > > Chris > > > > > > > > > > > > ________________________________________________________________________________
Subject: DON'T PISS OFF THE SWIFTIES
Date: Jul 28, 2004
Would it qualify as an aviation related article if we tell the senator to fly to hell? Or that he should fly himself? So, he wants us to know about Vietnam.... ohn [Unable to display image] "During the Vietnam War I was Task Force Commander at An Thoi, and my tour of duty was 13 months, from the end of Tet to the beginning of the Vietnamization of the Navy units. Now when I went there right after Tet, I was restricted in my movements. I couldn't go much of anyplace because the Vietcong controlled most of the area. When I left, I could go anywhere I wanted, just about. Commerce was booming, the buses were running, trucks were going, the waterways were filled with sampans with goods going to market, but yet in Kerry's biography he says that our operations were a complete failure. He also mentions a formal conference with me, to try to get more air cover and so on. That conference never happened..." -- Captain Adrian Lonsdale, USCG (retired) "While in Cam Rahn Bay, he trained on several 24-hour indoctrination missions, and one special skimmer operation with my most senior and trusted Lieutenant. The briefing from some members of that crew the morning after revealed that they had not received any enemy fire, and yet Lt.(jg) Kerry informed me of a wound -- he showed me a scratch on his arm and a piece of shrapnel in his hand that appeared to be from one of our own M-79s. It was later reported to me that Lt.(jg) Kerry had fired an M-79, and it had exploded off the adjacent shoreline. I do not recall being advised of any medical treatment, and probably said something like 'Forget it.' He later received a Purple Heart for that scratch, and I have no information as to how or whom. Lt.(jg) Kerry was allowed to return to the good old USA after 4 months and a few days in-country, and then he proceeded to betray his former shipmates, calling them criminals who were committing atrocities. Today we are here to tell you that just the opposite is true. Our rules of engagement were quite strict, and the officers and men of Swift often did not even return fire when they were under fire if there was a possibility that innocent people -- fishermen, in a lot of cases -- might be hurt or injured. The rules and the good intentions of the men increased the possibility that we might take friendly casualties." -- Commander Grant Hibbard, USN (retired) "I served with these guys. I went on missions with them, and these men served honorably. Up and down the chain of command there was no acquiescence to atrocities. It was not condoned, it did not happen, and it was not reported to me verbally or in writing by any of these men including Lt.(jg) Kerry. In 1971, '72, for almost 18 months, he stood before the television audiences and claimed that the 500,000 men and women in Vietnam, and in combat, were all villains -- there were no heroes. In 2004, one hero from the Vietnam War has appeared, running for President of the United States and Commander-in-Chief. It just galls one to think about it." -- Captain George Elliott, USN (retired) "My name is Steve Gardner. I served in 1966 and 1967 on my first tour of duty in Vietnam on Swift boats, and I did my second tour in '68 and '69, involved with John Kerry in the last 2 1/2 months of my tour. The John Kerry that I know is not the John Kerry that everybody else is portraying. I served alongside him and behind him, five feet away from him in a gun tub, and watched as he made indecisive moves with our boat, put our boats in jeopardy, put our crews in jeopardy... if a man like that can't handle that 6-man crew boat, how can you expect him to be our Commander-in-Chief?" -- Steven Gardner "I do not believe John Kerry is fit to be Commander-in-Chief of the armed forces of the United States. This is not a political issue. It is a matter of his judgment, truthfulness, reliability, loyalty and trust -- all absolute tenets of command. His biography, 'Tour of Duty,' by Douglas Brinkley, is replete with gross exaggerations, distortions of fact, contradictions and slanderous lies. His contempt for the military and authority is evident by even a most casual review of this biography. He arrived in-country with a strong anti-Vietnam War bias and a self-serving determination to build a foundation for his political future. He was aggressive, but vain and prone to impulsive judgment, often with disregard for specific tactical assignments. He was a 'loose cannon.' In an abbreviated tour of four months and 12 days, and with his specious medals secure, Lt.(jg) Kerry bugged out and began his infamous betrayal of all United States forces in the Vietnam War. That included o! ur soldiers, our marines, our sailors, our coast guardsmen, our airmen, and our POWs. His leadership within the so-called Vietnam Veterans Against the War and testimony before Congress in 1971 charging us with unspeakable atrocities remain an undocumented but nevertheless meticulous stain on the men and women who honorably stayed the course. Senator Kerry is not fit for command." -- Rear Admiral Roy Hoffman, USN (retired), chairman, Swift Boat Veterans for Truth "We resent very deeply the false war crimes charges he made coming back from Vietnam in 1971 and repeated in the book "Tour of Duty." We think those cast an aspersion on all those living and dead, from our unit and other units in Vietnam. We think that he knew he was lying when he made the charges, and we think that they're unsupportable. We intend to bring the truth about that to the American people. We believe, based on our experience with him, that he is totally unfit to be the Commander-in-Chief." -- John O'Neill, spokesman, Swift Boat Veterans for Truth [Unable to display image] "During Lt.(jg) Kerry's tour, he was under my command for two or three specific operations, before his rapid exit. Trust, loyalty and judgment are the key, operative words. His turncoat performance in 1971 in his grubby shirt and his medal-tossing escapade, coupled with his slanderous lines in the recent book portraying us that served, including all POWs and MIAs, as murderous war criminals, I believe, will have a lasting effect on all military veterans and their families. Kerry would be described as devious, self-absorbing, manipulative, disdain for authority, disruptive, but the most common phrase that you'd hear is 'requires constant supervision.'" -- Captain Charles Plumly, USN (retired) "Thirty-five years ago, many of us fell silent when we came back to the stain of sewage that Mr. Kerry had thrown on us, and all of our colleagues who served over there. I don't intend to be silent today or ever again. Our young men and women who are serving deserve no less." -- Andrew Horne [Unable to display image] "In my specific, personal experience in both coastal and river patrols over a 12-month period, I never once saw or heard anything remotely resembling the atrocities described by Senator Kerry. If I had, it would have been my obligation to report them in writing to a higher authority, and I would certainly have done that. If Senator Kerry actually witnessed or participated in these atrocities or, as he described them, 'war crimes,' he was obligated to report them. That he did not until later when it suited his political purposes strikes me as opportunism of the worst kind. That he would malign my service and that of his fellow sailors with no regard for the truth makes him totally unqualified to serve as Commander-in-Chief." -- Jeffrey Wainscott "I signed that letter because I, too felt a deep sense of betrayal that someone who took the same oath of loyalty as I did as an officer in the United States Navy would abandon his group here (points to group photo) to join this group here (points to VVAW protest photo), and come home and attempt to rally the American public against the effort that this group was so valiantly pursuing. It is a fact that in the entire Vietnam War we did not lose one major battle. We lost the war at home... and at home, John Kerry was the Field General." -- Robert Elder [Unable to display image] "My daughters and my wife have read portions of the book 'Tour of Duty.' They wanted to know if I took part in the atrocities described. I do not believe the things that are described happened. Let me give you an example. In Brinkley's book, on pages 170 to 171, about something called the 'Bo De massacre' on November 24th of 1968... In Kerry's description of the engagement, first he claimed there were 17 servicemen that were wounded. Three of us were wounded. I was the first..." -- Joseph Ponder [Unable to display image] "Lt. Kerry returned home from the war to make some outrageous statements and allegations... of numerous criminal acts in violation of the law of war were cited by Kerry, disparaging those who had fought with honor in that conflict. Had war crimes been committed by US forces in Vietnam? Yes, but such acts were few and far between. Yet Lt. Kerry have numerous speeches and testimony before Congress inappropriately leading his audiences to believe that what was only an anomaly in the conduct of America's fighting men was an epidemic. Furthermore, he suggested that they were being encouraged to violated the law of war by those within the chain of command. Very specific orders, on file at the Vietnam archives at Texas Tech University, were issued by my father [Admiral Elmo Zumwalt] and others in his chain of command instructing subordinates to act responsibly in preserving the life and property of Vietnamese civilians." -- Lt. Col. James Zumwalt, USMC (retired) [Unable to display image] "We look at Vietnam... after all these years it is still languishing in isolated poverty and helplessness and tyranny. This is John Kerry's legacy. I deeply resent John Kerry's using his Swift boat experience, and his betrayal of those who fought there as a stepping-stone to his political ambitions." -- Barnard Wolff "In a whole year that I spent patrolling, I didn't see anything like a war crime, an atrocity, anything like that. Time and again I saw American fighting men put themselves in graver danger trying to avoid... collateral damage. When John Kerry returned to the country, he was sworn in front of Congress. And then he told my family -- my parents, my sister, my brother, my neighbors -- he told everyone I knew and everyone I'd ever know that I and my comrades had committed unspeakable atrocities." -- David Wallace "I was in An Thoi from June of '68 to June of '69, covering the whole period that John Kerry was there. I operated in every river, in every canal, and every off-shore patrol area in the 4th Corps area, from Cambodia all the way around to the Bo De River. I never saw, even heard of all of these so-called atrocities and things that we were supposed to have done. This is not true. We're not standing for it. We want to set the record straight." -- William Shumadine "In 1971, when John Kerry spoke out to America, labeling all Vietnam veterans as thugs and murderers, I was shocked and almost brought to my knees, because even though I had served at the same time and same unit, I had never witnessed or participated in any of the events that the Senator had accused us of. I strongly believe that the statements made by the Senator were not only false and inaccurate, but extremely harmful to the United States' efforts in Southeast Asia and the rest of the world. Tragically, some veterans, scorned by the antiwar movement and their allies, retreated to a life of despair and suicide. Two of my crewmates were among them. For that there is no forgiveness. " -- Richard O'Meara "I served in Vietnam as a boat officer from June of 1968 to July of 1969. My service was three months in Coastal Division 13 out of Cat Lo, and nine months with Coastal Division 11 based in An Thoi. John Kerry was in An Thoi the same time I was. I'm here today to express the anger I have harbored for over 33 years, about being accused with my fellow shipmates of war atrocities. All I can say is when I leave here today, I'm going down to the Wall to tell my two crew members it's not true, and that they and the other 49 Swiftees who are on the Wall were then and are still now the best." -- Robert Brant "I never saw, heard of, or participated in any Swift boat crews killing cattle, poisoning crops, or raping and killing civilians as charged by John Kerry, both in his book and in public statements. Since we both operated at the same time, in the same general area, and on the same missions under the same commanders, it is hard to believe his claims of atrocities and poor planning of Sea Lord missions. I signed this letter because I feel that he used Swift boat sailors to proclaim his antiwar statements after the war, and now he uses the same Swift boat sailors to support his claims of being a war hero. He cannot have it both ways, and we are here to ask for full disclosure of the proof of his claims." -- James Steffes /9j//gAIV0FORzIC/+AAEEpGSUYAAQEBAGAAYAAA/9sAQwAQCwwODAoQDg0OEhEQExgoGhgWFhgx IyUdKDozPTw5Mzg3QEhcTkBEV0U3OFBtUVdfYmdoZz5NcXlwZHhcZWdj/9sAQwEREhIYFRgvGhov Y0I4QmNjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2Nj/8AA EQgAhwBsAwEhAAIRAQMRAf/EAB8AAAEFAQEBAQEBAAAAAAAAAAABAgMEBQYHCAkKC//EALUQAAIB AwMCBAMFBQQEAAABfQECAwAEEQUSITFBBhNRYQcicRQygZGhCCNCscEVUtHwJDNicoIJChYXGBka JSYnKCkqNDU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6g4SFhoeIiYqSk5SV lpeYmZqio6Slpqeoqaqys7S1tre4ubrCw8TFxsfIycrS09TV1tfY2drh4uPk5ebn6Onq8fLz9PX2 9/j5+v/EAB8BAAMBAQEBAQEBAQEAAAAAAAABAgMEBQYHCAkKC//EALURAAIBAgQEAwQHBQQEAAEC dwABAgMRBAUhMQYSQVEHYXETIjKBCBRCkaGxwQkjM1LwFWJy0QoWJDThJfEXGBkaJicoKSo1Njc4 OTpDREVGR0hJSlNUVVZXWFlaY2RlZmdoaWpzdHV2d3h5eoKDhIWGh4iJipKTlJWWl5iZmqKjpKWm p6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uLj5OXm5+jp6vLz9PX29/j5+v/aAAwDAQAC EQMRAD8AzCDn60AYPStzMQkFTirFlJkPEeoO5foetJoa3LL5AytNU4zmixY8EUcdqAGseauzFQh3 DK9xXPW0asVHYr+fHGCEQ5qbS55P7UhAYhZHww9flOKqMXdyYF7Vrr7JqVm5G9Ajkr6ngfpmsDVp f7QvTO3yfKFUdeBTS0uIrZwePxpc7s+hrYxEYdTmkjfybiOTsOG+lA1uaxA65H+NIIFznJPf0rKV RRNVG5KIUA5XP1pDCrZK/L7Vh7d3L5NCvtUuUkfZ6VakeKRSpcYNOc+ZpoErFKQKrkK2R2NWtLkt YbnzrmQoYiDGAM54IOa6W7oz6lnVbmxvIxIkjmaNSEG0gHJGf5VjkK3J5ogtLMZXx70ZxwasyDBN WbewM65dgo9KznPlQ4xuyOYSW1xguGwOPQD0qdJpC3DZ+lcM3zM64qxYEoX/AFjD8WqOSWMHIUY9 c1kMY/kyryenemK43bc57A1vSlZ2ImtCyLYBS0jbQOwpoihdxsk59D3ro9rroZpElvDatdtFcu6o QoQr1ySK2E0C0IOWkyD/AHqv2lkhHJDhunFBwenWtTIFYA5PTrVpblgVVTz1rjrvWxvTWg24lM0U iovHdqpETrwE9u9YWNiNkcMGMTE/7xoS8lj4lUkH0NNxFctRXAZNwk3DPQ9RTnkXPXI/KpWjGWFu Wmtgrn5kYAn1GOKRW2srdwc12Uo3gYy0Y8y+ZdxvjGZIz+TCuzzhmHuaGuVJEtnnTS/NwKaSx5Oa 2uZCNJsIBPtSpLtYjuTj8K5Z6s3jsWrZvNlYfwJwB6mrwIYVi9DoihrKD15qJoEznYKEwaGNbw/3 FB9cVSuIXj5Q5X07igTQ7TZDI7RH7zDjPqK0Y4HaQblwB1yK6qckoswktR6RNc3m2BM7WVsD0BGT XVtMm489TRLVIk89zwCetISTk1qZlefPmZ7Ux3JlOKwktTWL0NOwyEP+0c1eXpXPLc6Y7DucdaTB 9aRQbAeKjkgpXBmXN/o94rLwQwIIrUlmZlO6b5fpXTTjzanNJ2ZlzXjiYtHcFMcZXIqA3kxOTeS/ r/jXTypkE+Rx7UvXOMZpGZWvMhC3vioIn2gk+lZSNI7G1YgiFSepq4WVBknArke51LYYbqJRznNO SZXXK5xTC5DNdMsmxF3GmieZTl0yO4zUtaBcr30W+7tynIc4/rT7xilsxFduH+E56m5i5orqINAj Pej7owD2rEgkNss9u29wM/dFZ7QOtwIiO/51zzlds3jFpJm6hwnH5U3axOSu89hWBuyNkuDNl2XY Om0VKhw5HODTYojTFtuicZV+adDYyKzM0pIJyBRfQfUbexlI0YZDK4Kn05qG8ffaOe5HIrbDPUzq rQxd3akyD616Bzmkpz2+tLnI6VzkluFg1uyjGVb9Cajlj3Sk4+5j9a4paSZ2R1gi1FUqyL+VZpl2 uOZlIyB07mq6jc5bnGePemxpE5UOgwwDg9+4p4I2gpkgdRUjaILuYyoMgcGsp/mDAdDzXVhu5zV3 axSMQwaBFkV2czMOYujOPpSn2rMkfGxR8g8dDVl23hnBHOMiuWtGzudNF3jYVG5qQHL9KwOhD5GB O3t3qq5cNhX4HSqQMQCWUgljtPpViB2jQr/EOvvSaBMiuD8hH941Uxjg114Ze7c5MQ/fsVH4Yijd 61uYlvsecUh6cmpGO9OQKUMwGAeDWc48yLhLlZJG9WlIODXG9zsQyUkMdwyT0FQGR+nlnHvVJCbB biROFiYgVLG5mkLYxxyKTWgIZIdxPtTSoLD3rsofActf4yvLEpc84NRGEfWtbmRNzQD8wHNSMCR6 0pYgZ9KQEs0LQylepQlT74qWN8gVxS3O1bEgY7iTzSFiOBmkmUNO49sDvSBwhbtxQ2DI0OefWlx3 xzXbSVoI4qmsmRSLzz0xTAMCrIDPrQcUhiAjGMUxm3TwxL/HIo4+tJgjevrcvI8yDKuckDsazsFT kdD6VxSVmdsXeICRlPzDj1p/mAE9M0kUmNebHQ5NRxo9xNtX7zcD296LBJi6mPsepskY/dNGjAH/ AHQD+oNEcysMg/UV3Qeljikru4pGQRVfGapmYhPTNAIC4pFDWcDpUVs+NUtWPQSr/OobLSOwj/u1 XuLFJDuU7XPp3/z+tZyjdFxlysz5AYm8uVR9arlF5AAwDgsegrn2OjdXJYrNpG2xLuPdjwBWvZ2c drHnG5sct61pGN9TOpLoY/iRl860x94RsD/31x/M1lo2OlbIxLCSkDg8UFwTnFWpEuNxjyDpURck mk2Owwmoo2/0uM+jDH50kM7WNsgNU+Nw45/ClYDM1y4itrYbhulc/ux6ep+lYK34d08+PMYOCFPN Q4XdzSM7Kx1Vm8M1qkluQYyMfT2P+f51NISx2KDzT8iG7u5keK7dYo7NxySXUn8jXPrVIQ5Wx3qT IoGQlqTdTJGlveo0O2dG9GBoGdxGgwRxjqD6e38qehIO0/TBpCOX1hria+N2ufLGFQ/3f8/1qgvB wigy7+Gz19qY0dFo0b2bnc+Y5jhh/df1Ht2rbiID89jSaBGV4tPmWsL9o5Qox3JDZP8A46BXL5pL YBc08EEUwJr2wnsWAnC4b7rKcg1UJxQtQsNzzSHgg+lUB2ts4MMLEnlQD+G0f+yGpiM2zynAdF/M 4pWEZ88AWykjA/5Zt19cN/8AEiuZRghX5vkViQQKYzqiga3K9iWwfxfH8hV9QDEJg2WJOB6nmpls Iz/EyY0kD+7Kp/HL1ytJANzzS+aFGOaodj//2Q== /9j//gAIV0FORzIC/+AAEEpGSUYAAQEBAGAAYAAA/9sAQwAQCwwODAoQDg0OEhEQExgoGhgWFhgx IyUdKDozPTw5Mzg3QEhcTkBEV0U3OFBtUVdfYmdoZz5NcXlwZHhcZWdj/9sAQwEREhIYFRgvGhov Y0I4QmNjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2Nj/8AA EQgAhwBsAwEhAAIRAQMRAf/EAB8AAAEFAQEBAQEBAAAAAAAAAAABAgMEBQYHCAkKC//EALUQAAIB AwMCBAMFBQQEAAABfQECAwAEEQUSITFBBhNRYQcicRQygZGhCCNCscEVUtHwJDNicoIJChYXGBka JSYnKCkqNDU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6g4SFhoeIiYqSk5SV lpeYmZqio6Slpqeoqaqys7S1tre4ubrCw8TFxsfIycrS09TV1tfY2drh4uPk5ebn6Onq8fLz9PX2 9/j5+v/EAB8BAAMBAQEBAQEBAQEAAAAAAAABAgMEBQYHCAkKC//EALURAAIBAgQEAwQHBQQEAAEC dwABAgMRBAUhMQYSQVEHYXETIjKBCBRCkaGxwQkjM1LwFWJy0QoWJDThJfEXGBkaJicoKSo1Njc4 OTpDREVGR0hJSlNUVVZXWFlaY2RlZmdoaWpzdHV2d3h5eoKDhIWGh4iJipKTlJWWl5iZmqKjpKWm p6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uLj5OXm5+jp6vLz9PX29/j5+v/aAAwDAQAC EQMRAD8AzwSeoo4Bwa6DMVQMCmuRSA1LA/6DEvcAj9TUrtUGgif6xDngEE09mxOXHIzWUtXYtbE5 GQSB1FGiQxTXT+Yu7auVBPHXmpp7MJGlbCZL+USrGkRG2JF/i561l6rbfZ5jO/Dvcbhz/AAD/OtF uSaV/b/bJLOZXTy45fMbceNuKx4bU3clxLFJGkfnMFDHtQrgYwHrSMM8VuZCgep4FBI9+aQizaTr DbupyW3YUDqc1bitZ5BukB+npXNWqcux00431LCWB2lvSpRpkrruVtoNcvM9zblRXuILm1xuJK+o qCMO7BomIK+hwa6KU1bUynHUkaOdm3tISw7luainWbIZyXHqTmtlKLZm0RbmxgMQPTNMAPY8VpZC Kx6c0Ad8n6UzMT6Yp2MDnp60AaWk2YyJpOrdB6VtKu0YFeZUd5HfSVoibcHGDUyyFQBzgVBpYSQr KhVgCp6g1zl6sllN5kf3QeKqD1IqLQmkY3UccsX3WH60+UmO1ZSfn2kD3Nb6aWOcv2+nWN3aNNF5 ijDLlj0I74qSx0/T7qyinMHDrkZfnHv71085Fjkye4o83AxjmtDIYZN3tTS5yOTgnFTJ2TGlqdNZ ODGm3pirYuVTrXmPc9COwNdxnuacLuLGM0NFXBpgRkdKz7uVChDKDwcZoW5M9iggXa6wAhAxfbnp n/64NMJx8x7c1304q1zkk9TodMR7fSnWVSpcsyj1BHFcXc3dzZy/Z5IxE8YAK5zjjNXBXbEyWXA4 yKixVMyDPqMUE4IJ6DvUT+EuO5tWU7+XFjaiOBj1xnqasoGknZHlRQM8k1xKJ181iFW3LIR0j64p 0TNJFI6FcrjGevXtRYLjhNMib3YY6bSOv5enFZ1xeowdJDtlQ9OzfT8KVtQbuiK1kPnEKTl0PA78 5qzLG8cZcgY9M9a66bUY6nO1qZNzPqDI8rzyKqdtx6e1WD4f1Gb94TG5YAkl8mtoyjuhWIm5J5pM EUMyDjB5q2tvbOqxt5mcrvJPBB61jUlyo2pRuWlhcww7WxiIIT6EVCLaQOSZWI7CuZM3saFnDGLG dnB3v938KoLEzLhcjPIpJlNDoobkKFaUv9R1oNpEI5XmQM7MFB+igfzovZiSvoQ2SxWYErIzynIw DwBUOvT5EQQkIeQPwral787MiceWNygtyDZSROSWPSun8I4l0qRnyW85h19hWyhypmTdzBwTR2q2 YiAkirStmJXzyePyrCvtc6KD1aNK1kVlAYZB6jNOupVjQlOM/pXKmdLWokNxbx24DSZUDqKitZY/ M8vfvQ8qRTQPUtPsVThmrPupSWVV+6vQVLBIibllweQATVXWYJAYMKSMcYFdGHaU7mdb4bFPyPLs 3eVcMfu5rp/C0c0GmOJI2XfKXXPcEDBrp5+a5ztWMI9PSkB7UzIXoMCrNuy/Z5EJG7ORx2xWVb4T aj8RZgPCn1FLcPlgvbHNccTrZWWJCg+UEmnw/uwxUDIq2SmW3k3ICOhFUpfvVn1LJhsEIO4A8fl3 NZl5qLyOoSUDbxkjNdNKnzK5hUlZlGVzKcyTZP0qwupXaqqrfShVAAHPAFdaikrGT1LGeOlNGeuK kyFDUvIOQaUldWHF2Zdt3G0flTrhd7EdvrXAtGdt7kYGMLlgBzjg0iod5ZCw+vSquFiymBCoqpK+ ZMdzUpajvoSiNQhUDAIIrnpEKSMjdVOK9SmklY5JNt3EpM+wq2hGryeCaT7vr+dYGYgxnNKCetAy eBioz781ZSRTyTXDNe8zshsPwKdlenekyiu8y4IBqKJdxLtmhbgQR3DjkNlfQ1Uv8ySeYqYyOa9O DOO5T5FLj3/StAuapPJpNxz3rnZIZwRSMwANJuw7Eln+8ikYnIDAGneXJG3ynIPT3rlktTpi7xJE M75AUZHXLU2UzLgEAE+9KxVxI4G+8x/E1bUeUplfhUUtg+wqow5mKUuVGJA48sc1Y4YEZrrjLSxy yRVZBuIIpPLWquTcvMp3+uaCABzwPSs5OxSVyNpBn0qKViUO2s27l2JtFkw00Td8EVqPEcZUe+K1 lDmiClZkTPt/eAdOGFIp8x9xGT2ArkUW3Y3ui0kZJ3N1HQelV9TfbZS+rDaPxrtjDkhY55S5mYsS Fc88VLWBRIAkg+Yc0ht+flkIH0qlOxLiStJ6VCzk/SpuUNprntSAk04YuyR0xW20ixxM7nCqMk11 x0SMnuZUs7zuTAAV7u3SrWnMctFIVL43DGQSPyrKFuc2mrRL5zWbqp/dhT2INbS2MUZobApd3tXG ajlbHNShiRSAjJJFRbwzHHbimAEnPWkpgXtMhLLLIP4eP5/4VZvWMgEAGRjdJ9PSutaoyZQ2zIix QFVDZYYbBx9aWyhZJFnZ2Minjnj6VjTjeRpN6I3AwZQ4+6Rn6VT1aMJYhz96R1/AAE1rPYzRjUZF chqHmYO0cmpdxAp2ATIxzioGwWyOtAhymmk+hNMDb0VC2nTkdS4x+Gf8agkBaJwGPm5bJz19v0ro vaFyUryKLDfFEnPmRttUY6CtG3QKfLkYZxuBHes6UtTSpHQ0YYm+5nKZzVfxCcW0K+smfyFaVNjF GDTSa5kaCqRnpzTySOpoGMZsEU0daBC0Uxm/oA/0B/8ArpWbd7oL53A3RsT16H2rSo2ohTV2OeEX KiSJvn7H+97H3/nUltJ9oIikJEyfdPf6GsHLld0bJc0X3N22+aEOB1rJ8QtzbL7O38q6pfCcqMbN IeenFc5dhFznmnFiTxTAY/IoU5FIBaM0DN7Q5NlnKccbs/zqhBKLgmKQZZu397/69XU6DgtG0MIa zmBB3RsMjP8AEPerUsQuEE8JO/GR2Jx6+49e9ZNX0NlZPm7mlp10ZLOJ2OSWKn35rL15994i54SP +ZrpfwHM1aTRmUViUITikzgUCP/Z /9j//gAIV0FORzIC/+AAEEpGSUYAAQEBAGAAYAAA/9sAQwAQCwwODAoQDg0OEhEQExgoGhgWFhgx IyUdKDozPTw5Mzg3QEhcTkBEV0U3OFBtUVdfYmdoZz5NcXlwZHhcZWdj/9sAQwEREhIYFRgvGhov Y0I4QmNjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2Nj/8AA EQgAhwBsAwEhAAIRAQMRAf/EAB8AAAEFAQEBAQEBAAAAAAAAAAABAgMEBQYHCAkKC//EALUQAAIB AwMCBAMFBQQEAAABfQECAwAEEQUSITFBBhNRYQcicRQygZGhCCNCscEVUtHwJDNicoIJChYXGBka JSYnKCkqNDU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6g4SFhoeIiYqSk5SV lpeYmZqio6Slpqeoqaqys7S1tre4ubrCw8TFxsfIycrS09TV1tfY2drh4uPk5ebn6Onq8fLz9PX2 9/j5+v/EAB8BAAMBAQEBAQEBAQEAAAAAAAABAgMEBQYHCAkKC//EALURAAIBAgQEAwQHBQQEAAEC dwABAgMRBAUhMQYSQVEHYXETIjKBCBRCkaGxwQkjM1LwFWJy0QoWJDThJfEXGBkaJicoKSo1Njc4 OTpDREVGR0hJSlNUVVZXWFlaY2RlZmdoaWpzdHV2d3h5eoKDhIWGh4iJipKTlJWWl5iZmqKjpKWm p6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uLj5OXm5+jp6vLz9PX29/j5+v/aAAwDAQAC EQMRAD8AonpjNBXI5HP1rcyLunyf6O6H+Bs/n/8AXzUw6mpNEBGe9O6CgYzcvXcPzqe3cEhcAjk5 rOp8N0NBcTNHJhQMYz0pJ1DwbsDfxj6kgVkm1Z9yh8mkXaIWIQgdg3XmobywltYEmLpJG5wGTPXt XSpIglXR3EaNc3EduX4VW6moZ9JvIZNoi8wdQydKXMgMzaR0oJy2PfrWhkLaSeXcKO0g2fj1H9a0 WBI44NSy47DoYC6k5I75x2qV4o9u0sQCB7k1zVKttEbRgLJap5LFECk9yKp29mwZWUOCD1zWCmzS xqCAy8oV3Y4DjvVC5Myv5cgAwe3StKVpPUiSsasDE+GX5OfKlGe/Vqz4r2S4msoZtohjlQ8DHTgZ roS3MzQ1trRDC15bvKMMAQcY6ZzViK8uJokkj09yjDIJcA4qegM48c9/1pcjFbmJE4+XjgjBrTS4 BiSYrjcOAfWs6suWNzSmrshudTYFgnyqO/qas2SS7DNM+Xfkn0HYVwPudaHSTucoHO7GaWOZojvL FgakqxK0rg7geGOarXEryKVJGFOee1VCVncUo3RdXW/3WyO1iEeCNobj3rNmk82Z3C7dxztXoK74 LqcrLq63OIwkkUUuP4mFV59UvJpNwmZBjAVOAKagIzSMDNMLjP41ZkM5kfHOMEn6AZNWrm4V3jjQ cJ37f5/xrmru7SN6SsQRQmaUb/uhuRW55iqgVeg4Fck+x1Q2uQFvmJHU0mSRjGamxaJFcqNrdOoz SOBIc7eO/vSHYpwI1sZ7VzuQkSRN3xkZFdJHObrRJ53VFYpIOBjoDXdBvlTOKa945qCC5u4PMs41 dQdpZmxyMf4is26F5FcyRSY3xkA7SMcgH+tdMWtmQStIW6cD0pAO/wClIzEywPBxnj8OKmMRQgqO hrnq7m0NiS3Y5Y4/i61djYD5c1yT3OqGwrtGON3NKsqBQAc4pFIkjnAJJUGnllc5ULj61LRRSv5R Eu9uMH09qvaVObnw87Hus4wP+BV20v4aOSp8RkeEXJvZF3Er9nJxnjO5f8aq+Iiq63c7iBnYR/3w K6LfvLGW4cAe5pCfSgzJbZfMnAPOOSD0q0is7Hd/Fzke9c1V+8dFNe7cdsVWwAAKSVtgyOa5nqzo WxVe4kyoEbcn7340qSvvIIGFOCQeDVW0EmWrvdDZJODhSwB9hVNbuPf1f5ec+3rSSuim7C3j+fYy FSSFP8+KtxeILW3g8mDT5EiweAeOetdVKLcLHPU+Iz7XUBZ6s91bWhSBl2eTzwuB/UVcuNYtLiXf LpIkbGNznn+VdDi27oz6FMfrSNyeBzSMyS2cpOD6gj/D9cVdUbpFw3AGMfh1rlrfEdNL4GKQc570 /wCQr0wa5upt0ImjyCOQD6VEYkTAHBNW3oCRfnhDac0YYMCvPtVCO1cxjgOCMA+1TF2Q5K4t1bbN OmCHkANx/vD/ABrBaRx/E35134VJxOaruIXb1P50m411ciMrmmMgZPQUu4E81gQAJ3cYHp7VftZU uIoXj27ickf3T3Fc9da3Oii9Gi1cARuB6jmmdsiuW2p0LYRmCr65qodxbKkEkd6qwwMlyQoRCSKl t3ZYTnuTx6UmrDTuIxLQ3K5/5YN/T/CucJzXdhPhZzVviA9aSuy5kamecc5pew71zmYYGM4yaXTV 8m9ZsZVhkfWsaq901pOzNacl1BP3hUaN2rke51RegSuFXJ6VTFyFZiEdmPBGMYqkD1Y59SkgVW4A bHY5qTeZCH24380S2EtGLkCG4PYxFfxPFYHlmurCuyZjXfvCCNietL5Xqf0rq5jHmNA5pOtZEi8j IyMU6Jwk8YJ5P9KifwlQ+I0/NB47HpSKuOR6VxyR1xYxzkAY4ByfejaCOR+dIpajWDEY2gr7ilAM dvnHVyB+QpDaK90/l2LD+OQ/kBWYGxXbRVonHWd5CA804YFamRbz15/KgcKeelIYjEBSxPHrVe1z JqBc9ETIH14rOo7RZpTV5Iv+YyMCeQKkkuCpcA4GOa546o3loyaJ/MKjsOPqO1SyFVJwOgzScdQU gjIkYL6EA066kRYRHxndnFJR1G5aGbdL52G7DjFVTCvOK7YqyOSTuxPIx19KXyh71QibBY4UEmn+ SwHzEDNRKVilG5VuumwEnFQ2kgScZ/i+U/0qZ6wZpDSSNQrkcioZ0YAsOckGuODsbzVwhufLHOce 9WBOsijp0rcxIzfLCcJ8x9aq3F4/nRbjnPX6U4/ED2LEjbRkd+lRd88iukwFz0OaBxSA0MBRgAY9 qhbn5jXLdtnRaxlSszNuDYzzVaXcOTXTbSxBsWlyLmBX/iHDD3p7jI6V57VnY690MeHI+6Dmmi0w py/PoKtSIcbkXkxx5LN8o5NZ7zedc7+g6AegrWlq7mc1ZWL0Mm4bSTgdM1IykZ4yK3UtbMxceogO aB7YqrkGhIcCq1y+yBz3IwPxrkjudBnNkjoKhkBKnNdZmMs7prSfcMlTwy+orfV0kQSIQVPINcda Nnc6KTurD1OaRxkVhc2sYuoXQZjDGeB94j+VVFyMV3Uo2ictR3Zfibowq8hBAIpT7iRIFRxhhz60 n2QH7rnHuKUZ23JlC4k/mo5kQ71/iT09xVa8YtASMjBBqUUylGtxKQF4HqRTru38uEkuzMO/atXI mxRYAAYP1q5pt35L+U5/dseD6GlUjeJVN8sjaBAwM5qpqN35MXlof3j/AKCuSEeaSR1zdo3MUDmp Y4iy5DY9q7nojiLAEsSDfGWX1XmrVnKsgIU8D26VnJ3Q0WweOO1PEvFZFkcjE9OnrURAbhgD35pr QkcCPTFVrzmIj2qluIzWi6mou9bkmrYXqGBkmOGQZU+o9Kz5pGkkZ3PLfpWNOHLNs2nO8UhgyenF XbGPcBWk9jJGiuBS7VXLYAPc9Kw1LESQOCwB29AT3pV6daQGx/ZFvtADy4xxyKT+x7f+/J+lXYi4 v9j2/wDz0l/MUyTRLWRSGeXB9CKdguUtQ8PxxWkk1tK5Ma7mR+4HXBrmWXBNap3EIDg0+OEvkk8D rRcBXUAcdK0NOXEG7vUSd0Ui2ooeMSLhs4zmsiwPyr04qPdj1oQH/9k /9j//gAIV0FORzIC/+AAEEpGSUYAAQEBAGAAYAAA/9sAQwAQCwwODAoQDg0OEhEQExgoGhgWFhgx IyUdKDozPTw5Mzg3QEhcTkBEV0U3OFBtUVdfYmdoZz5NcXlwZHhcZWdj/9sAQwEREhIYFRgvGhov Y0I4QmNjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2Nj/8AA EQgAhwBsAwEhAAIRAQMRAf/EAB8AAAEFAQEBAQEBAAAAAAAAAAABAgMEBQYHCAkKC//EALUQAAIB AwMCBAMFBQQEAAABfQECAwAEEQUSITFBBhNRYQcicRQygZGhCCNCscEVUtHwJDNicoIJChYXGBka JSYnKCkqNDU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6g4SFhoeIiYqSk5SV lpeYmZqio6Slpqeoqaqys7S1tre4ubrCw8TFxsfIycrS09TV1tfY2drh4uPk5ebn6Onq8fLz9PX2 9/j5+v/EAB8BAAMBAQEBAQEBAQEAAAAAAAABAgMEBQYHCAkKC//EALURAAIBAgQEAwQHBQQEAAEC dwABAgMRBAUhMQYSQVEHYXETIjKBCBRCkaGxwQkjM1LwFWJy0QoWJDThJfEXGBkaJicoKSo1Njc4 OTpDREVGR0hJSlNUVVZXWFlaY2RlZmdoaWpzdHV2d3h5eoKDhIWGh4iJipKTlJWWl5iZmqKjpKWm p6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uLj5OXm5+jp6vLz9PX29/j5+v/aAAwDAQAC EQMRAD8AyCD1zgU1gTz0rcyIxuRwVOCOlXoJ1mGDgOO3rQXFkvagRs7YRSx9hmkUSiyuuohYe9Ix niGHcr9QaykozZeqIGO4/NJk+4NKs8iKFW5cKOgBIxVpK1iRruXxvmdseuTihZWVdqzSBfQHA/nT toIjyv8Aef8ACmkx9936UwGkdjkU3jnNMyBlyO2KhIOeM59qBm/p9hI0Qa8PPUKOuPetmCJFG1AF HsK4K1Vt2R3UqdldlkwKAMnk1HLbjbzgg9jzWCbWqNdHoZl3pcLgmMeU/t0NYssLxOVdSCPyrvo1 edWZy1IcrI26UyukyAnHNHWgBOOnegr6d/WpMhADu9z6VpWFoEbzpB838Oe3vWVafLE1pR5pGojj qalWY4wv515h6Av2hh1JNSR3JPBPSmMVmRupNVZkjZvmGRTi3GVyZrmVjI1KFYnAUAZ5qlivVhK8 bnC1Z2EpCasQ0soPNJ5oHIA/GpuZlrTmElwu8DPp6VsSMoVffjFcWId3Y6aKsRrKB36U/wC0D+Gu ax03AzkigTYbPFOw7kyzggcimu2ee9JoGZurMRBHKvLBtp/GsrzX7YA+lejQfuI4ajtIYXkz97A9 hSM7sclmP41sZuQZz1Jo9fzqBFmwbZcBs9j+NXzO2Bx0rkrbnRSYK+eDUmcDisEbksaE854pzJgY p3KJUVAOTz6UFflPGKljM/UAWsJG/uOhPt2rJHSu+h8Bw1vjAjHPaoS7E8DitjImGPSjjH61Ix8T bJl3HjpV1uHrmrbnRSHpjhqscKu4n5RgE+lcxuSJgldrD5hkZOMjn/ChpAON2fTFVYLiGTGfLZXZ U3lQTnqOOR15/SmrcMpDSBsY55HFDQXEWVF3mSMOMA7WI5P071kMnzOBgDceK6MO3qjCulZMhlUd Mmo9g7k10nOSE8jIozxwaQFywkMakhVbe2CCO2KklVc7oxtJriqO8mdkElFMQGXYQcHJAHbFPVg3 zS4HrmpKIprtGISFCwHG4jAH0qW1kbLpnGMYGKbBETLN5jYfYwJHSp4EumAE0qODwBtoewdSS/jK 3UQODiNjn8v8Kzu3PB71vQ2Oet2IWGW6UoHHQVuYiAZ60DAPPegZZtD+9C8A5yKmcnDN3Jriqq0m ddN3ih8f7zj+IYI+oOasLagR7y6j271mmW0NMcWeSDjsDmo7ZdkuOMk5NUwS1LE6CK4DD5hIckds /X1qdSqt8qNj2FS2VYr3zAozDshx61lH7uM9K68P8Jy19yEdetHHf+dbGAgGR1xQOmB6UDHLI0cg I/h5FXeGhV1Bwx5Fc1ZdToovoKudx29ulTmUMuWGfrXMbjMlmIT5RimxuyPnZx7VYySaWSaMqFwn fI5oWVsBGJJ9fWlYBkwxauTnLY/nVI44rqw/wnJX+IhwS3B6UvB5P8q2MRuQcHOeKXP86BgeO9Sx XRSMxsMjOQfSs6keaJdOVmWI2yykdKslMjK8ZrjZ13GMwU4AJHtQGLHITHuTTGhxZsH51z6YzT40 PG4AMOaGNkV62YgvqapHiuugvcOOt8RFICG470gPHStTMTPXnkelJnB5pAKSPQ9KQkA/SgCaKQqB 35rRilBQEGuGaszsi7oQgEkiozndjOBUlokRVJxk5+tSn5SMN2/OkNlK5YmTJ6Dioh2xXfSXuI4a nxMjkGMEGmE+gqyUJjj8KUgZ470hIOmB+tJhieFJHrSuMmt4ywlOMqhXcfTOQP5VNG2zKt0rjn8T OqHwkiSrkkHg084PIIqTRMAVXlj9Ks6datf3gU7liX7xB9e1FhSehmyzLLdTuoHltI2wdsZ4/TFI yMBuxxXVTlbQ5Zq+o3r1qFgVOBnFbMzFQKzYZ1U+tXEtI1XJ+YfzrGVS2xpGA/ZFEOEGe3FV5X+U 5rLmbLskXPD8SXC3sMn3XRAcdRy3P5gVT1GYWdw8BCvJG2GIPFS1dlRdkRQXsUzhHGxj09DVwKqL k1LVjRO5NaWcl24Cj8T0Fa9wU0rSpvL4faVUnqWPGacURNnMW6DGB24q6o44NXexKE2RyEZG0+op GtOeGBHvWkavchw7ECX9jLAbdZLhJCNqsz5U/MTyOmKjs7gh5oHxuQ5GOnoazsVcez5OSaSMLPL5 R8zkfwAE/qeKAZO0506ZDZCQNEN7pIByOM9Oo/8Ar1hTO0lxIzNuYsST6nNUu4iMr711Oj/Y59La +vZiPIO2Rf5H3zRKNyoysVp/FEqnZYQx28Q6bl3MfrVO51u6vUVLllYKcghcUrWJvcngceWGHOea mD9xSZSFzg1MjfKKhjRjG1tF0tZfLfzy3DBuMfSo7I/NLJggE4Ga13RBZOcYzWhpUW2J7hsf7PvU PYoqKfturxRuT5atufH90dR+PSsmVPLupk6bHYfrVx7EiE0xpG2FAxCkgkZ4JHT+tUDGA+lLuNMR o6dLuR07ryKu7sCs3uWhwfIBqQScVDQ7lCMBtPiU+pP6GoY2IADDgkkEVoSTld7LH/ExxitO/mW0 sxGP4R+tQ+wzM0J998+erDj9ap6hIkmoXEkY+RnyKtL3iehXJyKYetWJhS7TjpQIs6cSJz7rWkcY yah7lrYYJlZ9ic46mpCwzUMaKsgxpsZHHNEJJiXIqyS9pUIkunmb7sQqlqdwZ7gJjgtzUrWQ3sQW BK3bKh2lgUB9M9f0qK8j8ucqMYHANX1EQ5wMU3rVCYVd02ETzBX6Hik3oCJobbyS/OWzjPpT5ITK u0sV+neovqUgWPyRsAx/WnlsUtxo/9k /9j//gAIV0FORzIC/+AAEEpGSUYAAQEBAGAAYAAA/9sAQwAQCwwODAoQDg0OEhEQExgoGhgWFhgx IyUdKDozPTw5Mzg3QEhcTkBEV0U3OFBtUVdfYmdoZz5NcXlwZHhcZWdj/9sAQwEREhIYFRgvGhov Y0I4QmNjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2Nj/8AA EQgAhwBsAwEhAAIRAQMRAf/EAB8AAAEFAQEBAQEBAAAAAAAAAAABAgMEBQYHCAkKC//EALUQAAIB
May 10, 2004 - July 28, 2004
Commander-Archive.digest.vol-bg
