Commander-Archive.digest.vol-br
August 19, 2005 - September 15, 2005
      > Folks,
      > This is where it is
      http://www.teletuition.org/documents/Aviation/Aero%20Commanders/Articles%20Manuals%20etc/_8-19-2005/
      > Thanks
      > Nico
      > ----- Original Message -----
      > From: <BertBerry1(at)aol.com>
      > To:
      > Subject: Commander-List: 500B OCTOBER 1983 PILOT REPORT
      > > I just sent Nico the October 1983 Private Pilot Report on the 500B, so
      be
      > > looking for it.
      > > Thanks again Nico.
      > > Bert
Subject: Re: 500B OCTOBER 1983 PILOT REPORT
Date: Aug 19, 2005
I just read Kevin Murphy's article on the 500B and it is a wonder it made it past the editor's desk, in my not-always-humble opinion. Wasn't he supposed to write about the 500B and not his struggles with getting his ME-rating? Or his passion for singles? Or how his Cessna 210 beats a King Air? Is it even wise to do a ME-rating in a complex twin? I don't think so. It sure sounds like a more intelligent course of action to wind up the fans of an Apache or Duchess to get the gist of the thing before strapping something like a 500B onto one's cheeks. Even though his account was meant to be humorous, it doesn't help that he wrote allowing the airspeed to drop below VMC would cause the plane to drop out of the sky. ("... plummeting to earth without so much as a bye-the-bye.") Didn't his instructor demonstrate that, in a single engine configuration, the engine that kills you is the live one and throttling back on the live engine is a distinct (not necessarily desirable) option when having to fly close to VMC? I have a question for you guys who have more experience than I in these matters. Kevin wrote that above a certain altitude the 500B would spin before stalling (in SE config) but at a lower altitude it would stall before spinning. (I never liked referring to loss of control due to loss of VMC as spinning. Spinning an aircraft is caused by a distinct aerodynamic configuration, regardless of the number or type of engines.) Now, if we consider that the altitudes he speaks of here are between about 18,000' and sea level, how would that small layer of atmosphere cause the aerodynamic properties of the airframe to change that much? Surely, if an IAS (pressure) at sea level mandates a certain behavior of the airfoil, it would hardly change if that same IAS (pressure) is achieved at, say, 8,000'. The groundspeed would change, we know that, but the aerodynamic behavior? I don't get it. If he implied that the higher altitude would reduce the power, and therefore the effect, of the live engine causing a lower VMC at higher altitudes, I would agree, but then his language and, so it appears, his understanding of the mechanics of the phenomenon is lacking. On page 5, he said this, "A bit lower in altitude, the Commander will stall before it starts spinning..." That doesn't sound like he's referring to the engine's diminishing horsepower at higher altitudes. Anyway, if you throw a pair of hair-dryers into the nacelles, everything he said about this in his article is out the door. Am I missing something? Oh, one more thing. The takeoff procedure his instructor demonstrated, by pulling back on the stick before the takeoff run, so that the AC can rotate spontaneously, should surely increase the takeoff run because of the induced drag. I always favored my Commander's ability to remain neutral until a deliberate rotation is executed, because, so I believe, it accelerates in a much cleaner configuration. What say you? Thanks Nico ----- Original Message ----- From: <BertBerry1(at)aol.com> Subject: Commander-List: 500B OCTOBER 1983 PILOT REPORT > > I just sent Nico the October 1983 Private Pilot Report on the 500B, so be > looking for it. > > Thanks again Nico. > > Bert > > ________________________________________________________________________________
Subject: 500B OCTOBER 1983 PILOT REPORT
Date: Aug 19, 2005
Nico; As I recall, when we were training or needed a stall speed, we went to the book and plugged in density altitude and gross weight, the chart would then give us a stall/stick shaker speed which was 10 Kts. above stall. As for the take off maneuver, I always thought that is why you called out V1, go/no go speed for a balanced runway and Vr, as I recall was to rotate at one half degree per second until the desired angle on the flight director was achieved to maintain the second segment climb airspeed. I think if holding the yoke back would have been the most desirable way to takeoff, the Boeing test pilots would have described that in the book, especially when performance is so critical. Did I remember that correct Jim & Bilbo.? Sure hope this isn't a rating ride oral! Don > [Original Message] > From: nico css <nico(at)cybersuperstore.com> > To: > Date: 8/19/2005 8:32:00 PM > Subject: Re: Commander-List: 500B OCTOBER 1983 PILOT REPORT > > > I just read Kevin Murphy's article on the 500B and it is a wonder it made it > past the editor's desk, in my not-always-humble opinion. Wasn't he supposed > to write about the 500B and not his struggles with getting his ME-rating? Or > his passion for singles? Or how his Cessna 210 beats a King Air? Is it even > wise to do a ME-rating in a complex twin? I don't think so. It sure sounds > like a more intelligent course of action to wind up the fans of an Apache or > Duchess to get the gist of the thing before strapping something like a 500B > onto one's cheeks. > > Even though his account was meant to be humorous, it doesn't help that he > wrote allowing the airspeed to drop below VMC would cause the plane to drop > out of the sky. ("... plummeting to earth without so much as a > bye-the-bye.") Didn't his instructor demonstrate that, in a single engine > configuration, the engine that kills you is the live one and throttling back > on the live engine is a distinct (not necessarily desirable) option when > having to fly close to VMC? > > I have a question for you guys who have more experience than I in these > matters. Kevin wrote that above a certain altitude the 500B would spin > before stalling (in SE config) but at a lower altitude it would stall before > spinning. (I never liked referring to loss of control due to loss of VMC as > spinning. Spinning an aircraft is caused by a distinct aerodynamic > configuration, regardless of the number or type of engines.) Now, if we > consider that the altitudes he speaks of here are between about 18,000' and > sea level, how would that small layer of atmosphere cause the aerodynamic > properties of the airframe to change that much? Surely, if an IAS (pressure) > at sea level mandates a certain behavior of the airfoil, it would hardly > change if that same IAS (pressure) is achieved at, say, 8,000'. The > groundspeed would change, we know that, but the aerodynamic behavior? I > don't get it. > > If he implied that the higher altitude would reduce the power, and therefore > the effect, of the live engine causing a lower VMC at higher altitudes, I > would agree, but then his language and, so it appears, his understanding of > the mechanics of the phenomenon is lacking. On page 5, he said this, "A bit > lower in altitude, the Commander will stall before it starts spinning..." > That doesn't sound like he's referring to the engine's diminishing > horsepower at higher altitudes. > > Anyway, if you throw a pair of hair-dryers into the nacelles, everything he > said about this in his article is out the door. Am I missing something? > > Oh, one more thing. The takeoff procedure his instructor demonstrated, by > pulling back on the stick before the takeoff run, so that the AC can rotate > spontaneously, should surely increase the takeoff run because of the induced > drag. I always favored my Commander's ability to remain neutral until a > deliberate rotation is executed, because, so I believe, it accelerates in a > much cleaner configuration. What say you? > > Thanks > Nico > > > ----- Original Message ----- > From: <BertBerry1(at)aol.com> > To: > Subject: Commander-List: 500B OCTOBER 1983 PILOT REPORT > > > > > > I just sent Nico the October 1983 Private Pilot Report on the 500B, so be > > looking for it. > > > > Thanks again Nico. > > > > Bert > > > > > > ________________________________________________________________________________
Date: Aug 19, 2005
In a message dated 19-Aug-05 17:32:52 Pacific Daylight Time, nico(at)cybersuperstore.com writes: I always favored my Commander's ability to remain neutral until a deliberate rotation is executed, because, so I believe, it accelerates in a much cleaner configuration. What say you? Nico, Thanks for putting up the article -- and thanks for putting up with such a nit wit article. Mr. Murhpy is confused about Vmc and spinning and stalls and altitudes -- at least that's what impression my quick glance at his article gave me. As to takeoff procedures, I actually taught short field takeoff with the yoke held approximately 1/2 way back to have neutral elevator at the start of the roll. Pre flight, I'd have my client sit in the airplane, pull back (it's heavy with zero airspeed!) while I watched his elevator from outside until it was streamlined and I'd shout to him, "There! Learn that placement!" During acceleration, the elevator would become light and the trick was to keep the same streamlined position -- not to pull back for the same back pressure feel -- until rotation speed. This technique did yield the best acceleration, shortest ground roll and climb out transition. Part of it is stream lining of the elevator and thus reduced drag, but part of it is from keeping the Commander from "pearl diving" due to its natural 1 degree negative angle of attack in its ground stance. Just for fun, a rough field technique on a 680 E or F is: Full up elevator, release brakes and unstick in a few seconds! Weeeeeeeeee! (now get the nose down and accelerate to save your life!) Wing Commander Gordon Life is not simple anywhere. Probably less so elsewhere. ________________________________________________________________________________
Date: Aug 20, 2005
From: W J R HAMILTON <wjrhamilton(at)optusnet.com.au>
Subject: Re: Aviation Converters and Calculators
Tom, Three time table works pretty well, "close enough for Government work", as they say. Three degrees is 320 ft a mile, even if you ignore the 20, it's close, give or take a bit for the threshold elevation (say the African high veldt, or Leadville) and the actual glideslope. If you use Jeppesen, there are some very useful tables in the "Tables and Codes" tab. Another useful rule of thumb, particularly useful on a non precision approach, especially on a "black hole" approach is for Rate of Descent: "Half the groundspeed plus 50" Ergo: Groudspeed say 120 kt. therefor "half" = "60" + 50 = 650 fpm for a 3 degree descent. Works on everything from my 500A through to the B747-438, in my experience. Cheers, Bill Hamilton At 00:22 20/08/2005, you wrote: > > >Nice assortment of conversions, one thing missing was a >slope/distant/altitude calculator. >i.e. how many miles back will I intercept the glide slope at this altitude? >I used to know it but I can't find a reference to this common calculation >and I can't remember my geometry formula. > >Tom F. >C-GISS CONFIDENTIALITY & PRIVILEGE NOTICE W.J.R.Hamilton,Glenalmond Group Companies,Fighter Flights Internet Services and Warbirds.Net. & . This message is intended for and should only be used by the addressee. It is confidential and may contain legally privileged information.If you are not the intended recipient any use distribution,disclosure or copying of this message is strictly prohibited.Confidentiality and legal privilege attached to this communication are not waived or lost by reason of the mistaken delivery to you.If you have received this message in error, please notify us immediately to Australia 61 (0)408 876 526 Dolores capitis non fero. Eos do. ________________________________________________________________________________
From: "Tom Fisher" <tfisher(at)commandergroup.bc.ca>
Date: Aug 20, 2005
Thanks very much Bill, some of that seems familiar I will get current on those. Tom F. C-GISS ----- Original Message ----- From: "W J R HAMILTON" <wjrhamilton(at)optusnet.com.au> Subject: Re: Commander-List: Aviation Converters and Calculators > > Tom, > > Three time table works pretty well, "close enough for Government work", as > they say. > > Three degrees is 320 ft a mile, even if you ignore the 20, it's close, give > or take a bit for the threshold elevation (say the African high veldt, or > Leadville) and the actual glideslope. If you use Jeppesen, there are some > very useful tables in the "Tables and Codes" tab. > > Another useful rule of thumb, particularly useful on a non precision > approach, especially on a "black hole" approach is for Rate of Descent: > > "Half the groundspeed plus 50" > > Ergo: Groudspeed say 120 kt. therefor "half" = "60" + 50 = 650 fpm for a 3 > degree descent. > > Works on everything from my 500A through to the B747-438, in my experience. > > Cheers, > Bill Hamilton > > > At 00:22 20/08/2005, you wrote: > > > > > >Nice assortment of conversions, one thing missing was a > >slope/distant/altitude calculator. > >i.e. how many miles back will I intercept the glide slope at this altitude? > >I used to know it but I can't find a reference to this common calculation > >and I can't remember my geometry formula. > > > >Tom F. > >C-GISS > CONFIDENTIALITY & PRIVILEGE NOTICE > W.J.R.Hamilton,Glenalmond Group Companies,Fighter Flights Internet Services > and Warbirds.Net. & . > This message is intended for and should only be used by the addressee. It > is confidential and may contain legally privileged information.If you are > not the intended recipient any use distribution,disclosure or copying of > this message is strictly prohibited.Confidentiality and legal privilege > attached to this communication are not waived or lost by reason of the > mistaken delivery to you.If you have received this message in error, please > notify us immediately to Australia 61 (0)408 876 526 > Dolores capitis non fero. Eos do. > > ________________________________________________________________________________
Date: Aug 20, 2005
In a message dated 8/19/2005 9:01:31 P.M. Pacific Standard Time, CloudCraft(at)AOL.COM writes: Just for fun, a rough field technique on a 680 E or F is: Full up elevator, release brakes and unstick in a few seconds! Yep, and you had better have the thing already pointed where you want it to go, because in about 4 seconds , it will be there!!! ________________________________________________________________________________
Date: Aug 20, 2005
Subject: exhaust noise
I seem to recall that a Commander owner was going to perform some experiments in an attempt to quite their exhaust noise down. As an owner of an augmentor-tube tube airplane which makes quite a bit of noise (IMO a beautiful sound) I'd be very interested in the results of any experiments. We're beginning to get some complaints at our airport and would like to be proactive in this area. thanks Chris ________________________________________________________________________________
Subject: Re: exhaust noise
Date: Aug 20, 2005
It was a delegate from down under I think. bilbo ----- Original Message ----- From: "Chris Schuermann" <cschuerm(at)cox.net> Subject: Commander-List: exhaust noise > > I seem to recall that a Commander owner was going to perform some > experiments in an attempt to quite their exhaust noise down. As an > owner of an augmentor-tube tube airplane which makes quite a bit of > noise (IMO a beautiful sound) I'd be very interested in the results of > any experiments. We're beginning to get some complaints at our airport > and would like to be proactive in this area. > thanks > Chris > > > > > > > ________________________________________________________________________________
From: "Andrew & Bridget Watson" <andrew.bridget(at)telus.net>
Subject: Tom Fisher: Blue Twin Commander at Abbotsford
Date: Aug 20, 2005
Tom, At the Abbotsford airshow on Sunday, I saw a really nice blue Twin Commander. Didn't get close to it as the kids were dragging me off to see other less important aircraft, like the stealth fighter, for example. :- ) Was the Twin Commander yours? It looked really nice. Wish I'd got a good look at it. Best Regards, Andrew ________________________________________________________________________________
Date: Aug 20, 2005
Yes, I received them thanks. I will be scanning them up asap. Nico ----- Original Message ----- From: "Moe" <moe(at)rosspistons.com> Subject: Re: Commander-List: 500B OCTOBER 1983 PILOT REPORT > > Nico, > > Thanks again for hosting these. > > Did you get the UPS box with two articles in it? > > Moe > N680RR > 680F(p) > ----- Original Message ----- > From: "nico css" <nico(at)cybersuperstore.com> > To: > Subject: Re: Commander-List: 500B OCTOBER 1983 PILOT REPORT > > > > > > > Folks, > > This is where it is > > > http://www.teletuition.org/documents/Aviation/Aero%20Commanders/Articles%20Manuals%20etc/_8-19-2005/ > > Thanks > > Nico > > > > ----- Original Message ----- > > From: <BertBerry1(at)aol.com> > > To: > > Subject: Commander-List: 500B OCTOBER 1983 PILOT REPORT > > > > > > > > > > I just sent Nico the October 1983 Private Pilot Report on the 500B, so > be > > > looking for it. > > > > > > Thanks again Nico. > > > > > > Bert > > > > > > > > > > > > ________________________________________________________________________________
Subject: Re: Tom Fisher: Blue Twin Commander at Abbotsford
Date: Aug 20, 2005
No, unfortunately the week before I blew a seal in a hydraulic pump and pumped $800.00 worth of hydraulic fluid overboard. Sent the pump for overhaul I will have it Monday. I did not see a Commander on the field except for the 690's that belong to the fire fighting company Conair Tom F. C-GISS ----- Original Message ----- From: "Andrew & Bridget Watson" <andrew.bridget(at)telus.net> Subject: Commander-List: Tom Fisher: Blue Twin Commander at Abbotsford > > Tom, > > At the Abbotsford airshow on Sunday, I saw a really nice blue Twin > Commander. Didn't get close to it as the kids were dragging me off to see > other less important aircraft, like the stealth fighter, for example. :- ) > > Was the Twin Commander yours? It looked really nice. Wish I'd got a good > look at it. > > Best Regards, > Andrew > > ________________________________________________________________________________
Date: Aug 21, 2005
Chris, Yes it is me who IF I EVER GET OUT OF TAIWAN will endeavour to bring one to the flyin.It basically consists -----Original Message----- From: Chris Schuermann <cschuerm(at)cox.net> Subject: Commander-List: exhaust noise I seem to recall that a Commander owner was going to perform some experiments in an attempt to quite their exhaust noise down. As an owner of an augmentor-tube tube airplane which makes quite a bit of noise (IMO a beautiful sound) I'd be very interested in the results of any experiments. We're beginning to get some complaints at our airport and would like to be proactive in this area. thanks Chris ________________________________________________________________________________
Date: Aug 21, 2005
Hi Chris, I will try this again as I seem to have sent the last one unfinished. The thing is a tube about 4 in long going ito a taper of about 14 in long with a 1/2 in hole at the end. From the point going forward there are 3/8 holes in three triangular patterns going about 6 in.(the final number of holes is still to be determined) This entier cone has three vanes radiating outwards that are welded to the cone and bolted to the augmentor tube. Each vane is about 8 in long and has a tab on the trailing edge (to cause turbulence in the aug.The front at the parrallel tube extends forward of the firewall and covers the stacks.I have made all the patterns etc and only need to cut the tin. I used .030 304 grade stainless sheet. I will bring a prototype to the flyin. I am also going to adapt it to fit a T Bone. Regards Richard -----Original Message----- From: Chris Schuermann <cschuerm(at)cox.net> Subject: Commander-List: exhaust noise I seem to recall that a Commander owner was going to perform some experiments in an attempt to quite their exhaust noise down. As an owner of an augmentor-tube tube airplane which makes quite a bit of noise (IMO a beautiful sound) I'd be very interested in the results of any experiments. We're beginning to get some complaints at our airport and would like to be proactive in this area. thanks Chris ________________________________________________________________________________
Date: Aug 21, 2005
rnjthompson(at)aol.com wrote: > Hi Chris, > The thing is a tube about 4 in long going ito a taper Hi Richard. I've studied the "Swiss muffler" that seems to be pretty popular in Europe, but I don't think it will work for my needs. They use it on O-200's and smaller and I'm pretty sure my 540's will tear it up quickly. Your description is very interesting, but I can't quite envision the details. How did you come up with that design? Clearly there is a lot of thought put into it. Have you tested it and how is it working so far? Do you have any drawings/pictures/etc you could share? Thanks, Chris ________________________________________________________________________________
Date: Aug 21, 2005
I was having a little problem with the picture in my head too.:>) bilbo ----- Original Message ----- From: "Chris Schuermann" <cschuerm(at)cox.net> Subject: Re: Commander-List: exhaust noise > > > rnjthompson(at)aol.com wrote: >> Hi Chris, >> The thing is a tube about 4 in long going ito a taper > > Hi Richard. > I've studied the "Swiss muffler" that seems to be pretty popular in > Europe, but I don't think it will work for my needs. They use it on > O-200's and smaller and I'm pretty sure my 540's will tear it up quickly. > Your description is very interesting, but I can't quite envision the > details. How did you come up with that design? Clearly there is a lot > of thought put into it. Have you tested it and how is it working so > far? Do you have any drawings/pictures/etc you could share? > > Thanks, > Chris > > > > > > > ________________________________________________________________________________
Date: Aug 21, 2005
Bill Bow wrote: > I was having a little problem with the picture in my head too.:>) yeah, but the voices are loud and clear! :-) ________________________________________________________________________________
Date: Aug 22, 2005
Subject: commander flyin
I would like to attend the next commander flyin if I can get the necessary details. Thanks Ron Hinman rjhinm(at)earthlink.net 352-307-8809 fax 352-427-7272 cell This message was sent through Atlantic.Net Webmail. Sick of pop-up ads and climbing prices? Visit www.atlantic.net to get pure Internet for $19.95/mo. ________________________________________________________________________________
Subject: Hypothetical Vacuum Question, No not Electrolux
Date: Aug 22, 2005
Folks, I don't know how similar the vacuum systems are between the earlier and later airframes, but I've got a question for the group.... I've had two occasions in the past year and a half when I've lost a good vacuum driven HSI on our 500B, with no indication on the gauges that anything was wrong with vacuum. Upon starting up the next time, its fine. The instrument bench checks good (a Century NSD-360). All vacuum lines are new or recent. The problem has occured both before and after some major panel work for new avionics. All lines and hoses behind the instrument panel have been replaced. A needle tap was inserted into the line behind the instrument, and there was normal vacuum during a ground run. The HSI has a heading flag to indicate loss of vacuum or electric power that works fine. At one time, according to the service manual, the Commander's instruments had their own seperate intake and filter. Now pilot and co-pilot instruments are ganged into two individual lines leading to the nose compartment and one common filter. They have been like this for many years.... The new avionics had us remove two vacuum instruments, so the 'load' is less, but I still lost the HSI the other day. I have noticed one of the lines slightly flattened in the nose compartment, just prior to entry into the filter. I'm thinking it is possible to have a flattened line suck closed and the regulators compensate so much so that a gauge indicates normal suction, but with little or no flow through that side. The question to the group would be to what degree can a vacuum system have its flow reduced before the regulators can no longer compensate? Or is it possible with our system to have no flow, yet have a normal vacuum indication? I'd be interested to know what people think. Thanks, Steve ________________________________________________________________________________
Date: Aug 22, 2005
Subject: Re: Hypothetical Vacuum Question, No not Electrolux
steve2 wrote: > The question to the group would be to what degree can a vacuum system have > its flow reduced before the regulators can no longer compensate? Or is it > possible with our system to have no flow, yet have a normal vacuum > indication? I'd say you've probably found the problem. You can certainly pinch off the filter side and have a normal vacuum reading. The regulator just opens up to let outside air be sucked into the pump. If the lines are visibly "flattened" that should be a good sign that they're collapsing in use. May not even be the correct type of hose. If they're collapsing between the gyro and the filter, that is a sign that the filter is plugged up. They can look great but still substantially limit flow. chris ________________________________________________________________________________
"BILL WILSON" , "BROOKE D HARLOW" , "carol haskins" , "CLOUDCRAFT" , "commander-list" , "DAN BRUHL" , "diane yoder" , "fbailey" , "GINGER HIGGINBOTHAM" , "ISSAC MANNING" , "Jay Decker"
Subject: Fw: Cellphones
Date: Aug 22, 2005
0.14 FROM_NO_LOWER From address has no lower-case characters Message ----- Original Message ----- From: Christopher Naso<mailto:chris.naso(at)gmail.com> Subject: FW: Cellphones From: Dan Swarthout [mailto:dswarthout(at)coakleywilliams.com] Subject: Cellphones FYI - > >JUST A REMINDER... 31 days from today, cell phone > >numbers are being released to telemarketing companies > >and you will start to receive sale calls.YOU WILL BE CHARGED FOR > >THESE CALLS... > > > >To prevent this, call the following number from your > >cell phone: 888/382-1222. It is the National DO NOT > >CALL list. It will only take a minute of your time. It blocks your > >number for five (5) years. ________________________________________________________________________________
Subject: Re: Fw: Cellphones
Date: Aug 22, 2005
Not exactly http://www.snopes.com/politics/business/cell411.asp bilbo ----- Original Message ----- From: "MASON CHEVAILLIER" <KAMALA(at)msn.com> ; "BILL WILSON" ; "BROOKE D HARLOW" ; "carol haskins" ; "CLOUDCRAFT" ; "commander-list" ; "DAN BRUHL" ; "diane yoder" ; "fbailey" ; "GINGER HIGGINBOTHAM" ; "ISSAC MANNING" ; "Jay Decker" Subject: Commander-List: Fw: Cellphones > > Message > ----- Original Message ----- > From: Christopher Naso<mailto:chris.naso(at)gmail.com> > To: 'Austin Champion' ; 'George > Chevaillier' ; > billratliffIV(at)hotmail.com ; > chasehagin(at)aol.com ; > willthethrill(at)mail.utexas.edu ; > 'Myles King' ; 'Palmer, > Stephanie' ; 'Jason > Palmer' ; 'Jenniann > Colon' ; 'Caleb > Miller' ; > dpnaso(at)aol.com > Subject: FW: Cellphones > > > From: Dan Swarthout [mailto:dswarthout(at)coakleywilliams.com] > To: 'Brendan Foley (bfoley14(at)hotmail.com)'; > 'Calie Brennan > (calie(at)drinkmorewater.com)'; 'Chris > Heuberger (cheuberg(at)vt.edu)'; 'Chris Naso > (cnaso00(at)mail.utexas.edu)'; 'Cinderblock > (joseph.sufczynski(at)gmail.com)'; > 'Dave Braggins > (DBraggins(at)accredhome.com)'; 'Joey > Winkler (winklerjrw(at)yahoo.com)'; 'Matt > Gravy (Matthew.Garvey(at)puma.com)'; > 'Mickey Rayburn > (mick.rayburn@whiting-turner.com)'; > 'Mike Clark (clarky002647(at)yahoo.com)'; > 'Mike McTavish (mctmct15(at)aol.com)'; 'Mike > Swarthout (mswarthout(at)jinfonet.com)'; > 'Pat Dowd (pdowd2(at)hotmail.com)'; 'Pat > Zimmerman (patzimm! > _15(at)yahoo.com)'; 'Patrick Cosgrove > (Pcosgrove(at)jonesnet.com)'; 'Sam Moore > (cpsfinest(at)msn.com)'; 'Thomas Jackman > (tom.jackman(at)cbre.com)' > Subject: Cellphones > > > FYI - > > >> >JUST A REMINDER... 31 days from today, cell phone >> >numbers are being released to telemarketing companies >> >and you will start to receive sale calls.YOU WILL BE CHARGED FOR >> >THESE CALLS... >> > >> >To prevent this, call the following number from your >> >cell phone: 888/382-1222. It is the National DO NOT >> >CALL list. It will only take a minute of your time. It blocks your >> >number for five (5) years. > > > ________________________________________________________________________________
Date: Aug 22, 2005
bb, oh well we tried. mason ----- Original Message ----- From: Bill Bow<mailto:bowing74(at)earthlink.net> To: commander-list(at)matronics.com Sent: Monday, August 22, 2005 3:28 PM Subject: Re: Commander-List: Fw: Cellphones Not exactly http://www.snopes.com/politics/business/cell411.asp> bilbo ----- Original Message ----- From: "MASON CHEVAILLIER" <KAMALA(at)msn.com<mailto:KAMALA(at)msn.com>> To: "B J YOUNG" >; "BILL MUNRO" >; "BILL WILSON" >; "BROOKE D HARLOW" >; "carol haskins" >; "CLOUDCRAFT" >; "commander-list" >; "DAN BRUHL" >; "diane yoder" >; "fbailey" >; "GINGER HIGGINBOTHAM" >; "ISSAC MANNING" >; "Jay Decker" > Subject: Commander-List: Fw: Cellphones > > Message > ----- Original Message ----- > From: Christopher Naso<mailto:chris.naso(at)gmail.com<mailto:chris.naso(at)gmail.com>> > To: 'Austin Champion'> ; 'George > Chevaillier'> ; > billratliffIV(at)hotmail.com> ; > chasehagin(at)aol.com> ; > willthethrill(at)mail.utexas.edu> ; > 'Myles King'> ; 'Palmer, > Stephanie'> ; 'Jason > Palmer'> ; 'Jenniann > Colon'> ; 'Caleb > Miller'> ; > dpnaso(at)aol.com> > Subject: FW: Cellphones > > > From: Dan Swarthout [mailto:dswarthout(at)coakleywilliams.com] > To: 'Brendan Foley (bfoley14(at)hotmail.com)'>; > 'Calie Brennan > (calie(at)drinkmorewater.com)'>; 'Chris > Heuberger (cheuberg(at)vt.edu)'>; 'Chris Naso > (cnaso00(at)mail.utexas.edu)'>; 'Cinderblock > (joseph.sufczynski(at)gmail.com)'>; > 'Dave Braggins > (DBraggins(at)accredhome.com)'>; 'Joey > Winkler (winklerjrw(at)yahoo.com)'>; 'Matt > Gravy (Matthew.Garvey(at)puma.com)'>; > 'Mickey Rayburn > (mick.rayburn@whiting-turner.com)'>; > 'Mike Clark (clarky002647(at)yahoo.com)'>; > 'Mike McTavish (mctmct15(at)aol.com)'>; 'Mike > Swarthout (mswarthout(at)jinfonet.com)'>; > 'Pat Dowd (pdowd2(at)hotmail.com)'>; 'Pat > Zimmerman (patzimm! > _15(at)yahoo.com)'>; 'Patrick Cosgrove > (Pcosgrove(at)jonesnet.com)'>; 'Sam Moore > (cpsfinest(at)msn.com)'>; 'Thomas Jackman > (tom.jackman(at)cbre.com)'> > Subject: Cellphones > > > FYI - > > >> >JUST A REMINDER... 31 days from today, cell phone >> >numbers are being released to telemarketing companies >> >and you will start to receive sale calls.YOU WILL BE CHARGED FOR >> >THESE CALLS... >> > >> >To prevent this, call the following number from your >> >cell phone: 888/382-1222. It is the National DO NOT >> >CALL list. It will only take a minute of your time. It blocks your >> >number for five (5) years. > > > ________________________________________________________________________________
Date: Aug 22, 2005
Subject: 1965 Flight Magazine
New stuff on the way to Nico. Bert ________________________________________________________________________________
Subject: Re: 1965 Flight Magazine
Date: Aug 23, 2005
Folks, I published Bert's latest and the first episode of the History of Aero Commanders that Moe sent to be scanned. I will redo a few pages such as 01 and 06 and then scan in the second episode tomorrow or so. Why the quality of some came out poorer than the others is unknow. Check the link below and go to History of Aero Commanders or Articles Manuals and click on _8-2-2005 for Bert's latest. Thanks Nico http://www.teletuition.org/documents/Aviation/Aero%20Commanders/ ----- Original Message ----- From: <BertBerry1(at)aol.com> Subject: Commander-List: 1965 Flight Magazine > > New stuff on the way to Nico. > > Bert > > ________________________________________________________________________________
Date: Aug 23, 2005
Subject: Re: commander flyin
Ron, Attached is the information about the Fly-In and a registration form. Let me know if you have any problems receiving and/or opening them. Look forward to seeing you at the Fly-In. Capt Jim Bob ________________________________________________________________________________
Subject: Re: Aero Commander For Sale
Date: Aug 24, 2005
----- Original Message ----- From: "jlyle" <jlyle(at)thomsonaviation.com> Subject: Re: Commander-List: Aero Commander For Sale > > Hi all' > I have dedcided to sell my Aero Commander after much work and restoration. > Please look at the photo's to see results of several years of effort. > I believe it to be the best example of a 520 available. > 5838 TT > 612 SMOH Left with New Top > 196 SMOH Right- > 125 since New Props and Hubs (no AD's) > Great New Panel with Garmin 430, S-tec AutoPilot, Annnunciator lights and much more. > New paint and recent interior > Compete spec sheet and photo's at www.thomsonaviation.com > Will entertain any reasonable offer and consider partial trade for small single engine. > It flies great and will make someone a great aircraft. > Thanks, > James Lyle > N11L > 706-799-2602 cell > > ________________________________________________________________________________
Subject: Re: Continental engine notes
Date: Aug 24, 2005
----- Original Message ----- From: "Chris Schuermann" <cschuerm(at)cox.net> Subject: Commander-List: Continental engine notes > > Okay, several folks have asked me if there's any specific items that > might help make decisions about when and how to overhaul Continental > engines. > > Two BIG items are the case and crank. > Most Continental owners (I hope) already know that the factory changed > the method used to make cranks. They were having a bit of trouble with > cranks breaking. The new process is refered to as VAR (vaccum arc > remelt). If you have a non-VAR crank, it is required to be replaced > with a VAR crank any time the case is split! This is an important note > - if you have to open the case for any reason - even on a low time > engine - the crank must be replaced. Did I mention that they're rather > expensive? Keep that in mind if you're looking at buying an airplane > that doesn't have the new crank - you never know what might happen that > would require an early split. A minor prop strike requires an internal > inspection for example. > > There have been four (I believe) revisions of the 6 cylinder Continental > case assembly. If you have a first generation case, consider it a > throw-away item at overhaul. They had a LOT of problems with those > cases cracking. I've seen airplanes with cylinders laying in the bottom > of the cowling with part of the case still attached. Only the absolute > cheapest shops would consider re-using a phase I case at overhaul. THe > phase III/VI cases can be identified by bumps along the upper spine of > the case where the bolts go through. These are the heavier cases which > are most desirable. They also have a Teledyne logo at the rear of the > case - behind the right rear cylinder if memory serves. > > Here's where the decision making part comes in. IF you happen to have > an engine with an early case and/or a non-VAR crank, you'll almost > certainly want to send it in for a factory re-man. When Continental > receives such an engine for overhaul, they toss the case and crank in > the junk pile and you get a new case and crank at no additional cost > (this will change as some point no doubt). Generally, going for a > factory re-man is very cost effective in this case as a field overhauler > would have to purchase a new or servicable crank and case. (and I > personally hate getting "servicable" parts since I never know what > happend to cause them to end up on the market and NOT in an engine). > > > Hope I havn't make everyone paranoid now with all this engine talk! :-) > > Chris > > ________________________________________________________________________________
Date: Aug 24, 2005
Date: Aug 24, 2005
Date: Aug 24, 2005
Date: Aug 25, 2005
says no aircraft for sale at your website ________________________________________________________________________________
Date: Aug 25, 2005
Ron wrote: > ----- Original Message ----- > From: "Chris Schuermann" <cschuerm(at)cox.net> > To: > Subject: Commander-List: Continental engine notes Okay... quit messing with my mind! I wasn't even awake yet and I see all these emails from ages ago.... Thought I was loosing my marbles.... Chris ________________________________________________________________________________
"barry.collman" <barry.collman@air-britain.co.uk>, "BILL MUNRO" , "BILL WILSON" , "BROOKE D HARLOW" , "candice" , "CLOUDCRAFT" , "commander-list" , "DAN BRUHL"
Subject: Fw: STS-114 Pictures
Date: Aug 25, 2005
FW: STS-114 Pictures ----- Original Message ----- From: Avtec2<mailto:avtec2(at)bellsouth.net> Subject: Fw: STS-114 Pictures ----- Original Message ----- From: FB<mailto:cdr680(at)cfl.rr.com> Subject: Fw: STS-114 Pictures Shuttle photos from STS 114. ________________________________________________________________________________
Subject: GO-480
Date: Aug 25, 2005
Hi Guys, Is it getting difficult to find parts for the GO-480? What about for the 680E GSO-480? Thanks! Ben ________________________________________________________________________________
Subject: Re: GO-480
Date: Aug 25, 2005
No Problem on parts or engines for either engine Harry 321 267-3141 ----- Original Message ----- From: "Ben Baltrusaitis" <ben(at)gmpexpress.net> Subject: Commander-List: GO-480 > > > Hi Guys, > Is it getting difficult to find parts for the GO-480? > What about for the 680E GSO-480? > Thanks! > Ben > > > ________________________________________________________________________________
From: "jmenchetti(at)cantv.net" <jmenchetti(at)cantv.net>
Subject: Re: GO-480
Date: Aug 25, 2005
Hello Sir, i have 2 gso-480 that came of my 1956 aero commander 680, also i have the props and spinners, plus the main langind gear and the nose gear, all the original avionics, yokes and panel, crew seats and sofa, and interior plastics, let me know if i can be of any help best regards ----------- Mensaje Original -------------- De: Ben Baltrusaitis [ben(at)gmpexpress.net] Para: Aero Commander list [commander-list(at)matronics.com] Asunto: Commander-List: GO-480 Fecha: 25/08/2005 10:38:58 Mensaje: Hi Guys, Is it getting difficult to find parts for the GO-480? What about for the 680E GSO-480? Thanks! Ben ________________________________________________________________________________
Subject: Pilot stories
Date: Aug 26, 2005
Folks, There is an interesting story about Bill Weaver and his Blackbird breakup over New Mexico - click on the link below and then Pilotories. There are some navy pics too - click on navypics. Take a look. Thanks Nico http://www.teletuition.org/documents/Aviation/ ________________________________________________________________________________
"Yanknbank2002"
Subject: Re: Commander Article
Date: Aug 26, 2005
We received a nice article on the -10 Commanders from yanknbank2002(at)yahoo.com.au. Hmmm. I wonder who that would be? I see he's a member of the Real Aussie Air Force. Thanks anyway, Yanknbank. It has been published in http://www.teletuition.org/documents/Aviation/Aero%20Commanders/Articles%20Manuals%20etc/_8-26-2005/ Thanks Nico ----- Original Message ----- From: Yanknbank2002 To: nico(at)cybersuperstore.com Sent: Friday, August 26, 2005 9:36 AM Subject: Commander Article See the attachment Messenger 7.0: Make free PC-to-PC calls to your friends overseas. You could win a holiday to see them! ________________________________________________________________________________
Subject: sale reported
Date: Aug 28, 2005
Does anybody know the deal with the 680Es in Okalahoma? There are 7 aircraft listed in the state and 6 have "sale reported" on the FAA site. Ben ________________________________________________________________________________
Date: Aug 28, 2005
Subject: Morris Kendrick
I would like to contact Morris about a twin commander project (rebuild). Any help with finding a phone number would be greatly appreciated. Thanks Ron Hinman (Eastern Airlines retired) rjhinm(at)earthlink.net 352-427-7272 This message was sent through Atlantic.Net Webmail. Sick of pop-up ads and climbing prices? Visit www.atlantic.net to get pure Internet for $19.95/mo. ________________________________________________________________________________
Subject: Re: Morris Kendrick
Date: Aug 28, 2005
Hi Ron, Morris can be reached at 321-403-8813. That's his cell number and the best way to reach him. /John ----- Original Message ----- From: <rjhinm(at)atlantic.net> Subject: Commander-List: Morris Kendrick > > > I would like to contact Morris about a twin commander project (rebuild). Any > help with finding a phone number would be greatly appreciated. > Thanks > Ron Hinman (Eastern Airlines retired) > rjhinm(at)earthlink.net > 352-427-7272 > > This message was sent through Atlantic.Net Webmail. > Sick of pop-up ads and climbing prices? > Visit www.atlantic.net to get pure Internet for $19.95/mo. > > > __________ NOD32 1.1201 (20050825) Information __________ > > This message was checked by NOD32 antivirus system. > http://www.eset.com > > > __________ NOD32 1.1201 (20050825) Information __________ > > This message was checked by NOD32 antivirus system. > http://www.eset.com > > ________________________________________________________________________________
From: "Randy Dettmer, AIA" <rcdettmer(at)charter.net>
"Commander-List Digest List"
Date: Aug 28, 2005
Here is Morris' cell phone number - 321 403 8813. It's the best way to contact him. I'll be dropping off my 680F tomorrow (Monday) at SCK (Stockton, CA) for Morris to do the annual. Good luck with the project. Randy Dettmer 680F / N6253X -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com]On Behalf Of rjhinm(at)atlantic.net Subject: Commander-List: Morris Kendrick I would like to contact Morris about a twin commander project (rebuild). Any help with finding a phone number would be greatly appreciated. Thanks Ron Hinman (Eastern Airlines retired) rjhinm(at)earthlink.net 352-427-7272 This message was sent through Atlantic.Net Webmail. Sick of pop-up ads and climbing prices? Visit www.atlantic.net to get pure Internet for $19.95/mo. ________________________________________________________________________________
Date: Aug 28, 2005
Hey Randy, how you getting back to SBP? I may pop down to visit my brother....need a ride? /J ----- Original Message ----- From: "Randy Dettmer, AIA" <rcdettmer(at)charter.net> Subject: RE: Commander-List: Morris Kendrick > > Here is Morris' cell phone number - 321 403 8813. It's the best way to > contact him. I'll be dropping off my 680F tomorrow (Monday) at SCK > (Stockton, CA) for Morris to do the annual. > > Good luck with the project. > > Randy Dettmer > 680F / N6253X > > > -----Original Message----- > From: owner-commander-list-server(at)matronics.com > [mailto:owner-commander-list-server(at)matronics.com]On Behalf Of > rjhinm(at)atlantic.net > To: Commander-List Digest List > Subject: Commander-List: Morris Kendrick > > > I would like to contact Morris about a twin commander project (rebuild). Any > help with finding a phone number would be greatly appreciated. > Thanks > Ron Hinman (Eastern Airlines retired) > rjhinm(at)earthlink.net > 352-427-7272 > > This message was sent through Atlantic.Net Webmail. > Sick of pop-up ads and climbing prices? > Visit www.atlantic.net to get pure Internet for $19.95/mo. > > > __________ NOD32 1.1201 (20050825) Information __________ > > This message was checked by NOD32 antivirus system. > http://www.eset.com > > > __________ NOD32 1.1201 (20050825) Information __________ > > This message was checked by NOD32 antivirus system. > http://www.eset.com > > ________________________________________________________________________________
Date: Aug 29, 2005
Hi John, Yes, I would love a ride back to SBP..!! I will be arriving at SCK around 10:30AM. I had planned to drive a rental car home, but would happily cancel that in favor of a Commander ride. If I don;t hear from you this morning, I'll give you a call (if I can find your phone number...) Thanks, Randy 805 541 4864 / 805 459 0806 cell -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com]On Behalf Of John Vormbaum Subject: Re: Commander-List: Morris Kendrick Hey Randy, how you getting back to SBP? I may pop down to visit my brother....need a ride? /J ----- Original Message ----- From: "Randy Dettmer, AIA" <rcdettmer(at)charter.net> Subject: RE: Commander-List: Morris Kendrick > > Here is Morris' cell phone number - 321 403 8813. It's the best way to > contact him. I'll be dropping off my 680F tomorrow (Monday) at SCK > (Stockton, CA) for Morris to do the annual. > > Good luck with the project. > > Randy Dettmer > 680F / N6253X > > > -----Original Message----- > From: owner-commander-list-server(at)matronics.com > [mailto:owner-commander-list-server(at)matronics.com]On Behalf Of > rjhinm(at)atlantic.net > To: Commander-List Digest List > Subject: Commander-List: Morris Kendrick > > > I would like to contact Morris about a twin commander project (rebuild). Any > help with finding a phone number would be greatly appreciated. > Thanks > Ron Hinman (Eastern Airlines retired) > rjhinm(at)earthlink.net > 352-427-7272 > > ________________________________________________________________________________
Subject: grass strip length
Date: Aug 29, 2005
Hi Guys, How short of an unobstructed grass strip are you willing to land on, assuming reasonable temperature and a few hundred under gross? Please tell me what you fly. I'm looking to buy a Twin Commander in the spring and have been set on a 680E for a long time. Now I'm wondering if one of the others may be better for me. I have been flying on some really short grass airports and would like to continue that with my Aero Commander. I will be flying with no more than 150 gals fuel, 4-6 people, limited baggage. It looks to me like the 680 may be the best choice, but with fuel prices, a 560 may be smarter. What are your opinions? Thanks!! I hope everyone in the South is safe! Ben-PA ________________________________________________________________________________
Date: Aug 29, 2005
Nico (and others), The new, August 2005 issue of Twin & Turbine Magazine has a good article concerning a soon to be STC environmental control system. Do you have it, can someone email it to you, or shall I mail it to you to post. Thanks Moe ----- Original Message ----- From: "nico css" <nico(at)cybersuperstore.com> Subject: Commander-List: Re: Commander Article > > We received a nice article on the -10 Commanders from yanknbank2002(at)yahoo.com.au. Hmmm. I wonder who that would be? I see he's a member of the Real Aussie Air Force. > Thanks anyway, Yanknbank. > > It has been published in http://www.teletuition.org/documents/Aviation/Aero%20Commanders/Articles%20Manuals%20etc/_8-26-2005/ > > Thanks > Nico > > ----- Original Message ----- > From: Yanknbank2002 > To: nico(at)cybersuperstore.com > Sent: Friday, August 26, 2005 9:36 AM > Subject: Commander Article > > > See the attachment > > > Messenger 7.0: Make free PC-to-PC calls to your friends overseas. You could win a holiday to see them! > > ________________________________________________________________________________
Date: Aug 29, 2005
Fellow Commander drivers, Am considering getting rid of the stock "Frankenstein" voltage regulators on my 680F(p). Any suggestions? Regards, Moe Mills N680RR 680F(p) ----- Original Message ----- From: "nico css" <nico(at)cybersuperstore.com> Subject: Commander-List: Re: Commander Article > > We received a nice article on the -10 Commanders from yanknbank2002(at)yahoo.com.au. Hmmm. I wonder who that would be? I see he's a member of the Real Aussie Air Force. > Thanks anyway, Yanknbank. > > It has been published in http://www.teletuition.org/documents/Aviation/Aero%20Commanders/Articles%20Manuals%20etc/_8-26-2005/ > > Thanks > Nico > > ----- Original Message ----- > From: Yanknbank2002 > To: nico(at)cybersuperstore.com > Sent: Friday, August 26, 2005 9:36 AM > Subject: Commander Article > > > See the attachment > > > Messenger 7.0: Make free PC-to-PC calls to your friends overseas. You could win a holiday to see them! > > ________________________________________________________________________________
Date: Aug 29, 2005
Subject: Voltage Regulators
A bazillion years ago (1997, to be exact) a company called Zeftronics developed and mounted in an Aero Commander, solid state voltage regulators to replace the Frankenstine units. I believe Dennis Polito installed some a few years ago in his AC-500-B. If you can't Google it, let me know and I'll try to find archive issues of the Flight Group News that featured these. Wing Commander Gordon PS: Is it pronounced "Frankenstine" or "Frankensteen?" Life is not simple anywhere. Probably less so elsewhere. ________________________________________________________________________________
Date: Aug 29, 2005
Air conditioner? bilbo ----- Original Message ----- From: "Moe" <moe(at)rosspistons.com> Subject: Re: Commander-List: Re: Commander Article > > Nico (and others), > > The new, August 2005 issue of Twin & Turbine Magazine has a good article > concerning a soon to be STC environmental control system. Do you have it, > can someone email it to you, or shall I mail it to you to post. > > Thanks > > Moe > ----- Original Message ----- > From: "nico css" <nico(at)cybersuperstore.com> > To: ; "Yanknbank2002" > > Subject: Commander-List: Re: Commander Article > > > >> >> We received a nice article on the -10 Commanders from > yanknbank2002(at)yahoo.com.au. Hmmm. I wonder who that would be? I see he's a > member of the Real Aussie Air Force. >> Thanks anyway, Yanknbank. >> >> It has been published in > http://www.teletuition.org/documents/Aviation/Aero%20Commanders/Articles%20Manuals%20etc/_8-26-2005/ >> >> Thanks >> Nico >> >> ----- Original Message ----- >> From: Yanknbank2002 >> To: nico(at)cybersuperstore.com >> Sent: Friday, August 26, 2005 9:36 AM >> Subject: Commander Article >> >> >> See the attachment >> >> >> Messenger 7.0: Make free PC-to-PC calls to your friends overseas. You > could win a holiday to see them! >> >> > > > ________________________________________________________________________________
Date: Aug 29, 2005
If you mail it to me, I will scan it up and post it. Did you see the articles about the history of Commanders that I scanned and posted? If so, please comment on the format and quality. I didn't scan them into a pdf file. Thanks Nico ----- Original Message ----- From: "Moe" <moe(at)rosspistons.com> Subject: Re: Commander-List: Re: Commander Article > > Nico (and others), > > The new, August 2005 issue of Twin & Turbine Magazine has a good article > concerning a soon to be STC environmental control system. Do you have it, > can someone email it to you, or shall I mail it to you to post. > > Thanks > > Moe > ----- Original Message ----- > From: "nico css" <nico(at)cybersuperstore.com> > To: ; "Yanknbank2002" > > Subject: Commander-List: Re: Commander Article > > > > > > > We received a nice article on the -10 Commanders from > yanknbank2002(at)yahoo.com.au. Hmmm. I wonder who that would be? I see he's a > member of the Real Aussie Air Force. > > Thanks anyway, Yanknbank. > > > > It has been published in > http://www.teletuition.org/documents/Aviation/Aero%20Commanders/Articles%20Manuals%20etc/_8-26-2005/ > > > > Thanks > > Nico > > > > ----- Original Message ----- > > From: Yanknbank2002 > > To: nico(at)cybersuperstore.com > > Sent: Friday, August 26, 2005 9:36 AM > > Subject: Commander Article > > > > > > See the attachment > > > > > > Messenger 7.0: Make free PC-to-PC calls to your friends overseas. You > could win a holiday to see them! > > > > > > ________________________________________________________________________________
From: "Barry Collman" <barry.collman@air-britain.co.uk>
Subject: Re: Voltage Regulators
Date: Aug 29, 2005
Don't Lucas do some good ones? BC (UK) ----- Original Message ----- From: <CloudCraft(at)AOL.COM> Subject: Commander-List: Voltage Regulators | | A bazillion years ago (1997, to be exact) a company called Zeftronics | developed and mounted in an Aero Commander, solid state voltage regulators to replace | the Frankenstine units. | | I believe Dennis Polito installed some a few years ago in his AC-500-B. | | If you can't Google it, let me know and I'll try to find archive issues of | the Flight Group News that featured these. | | Wing Commander Gordon | | PS: Is it pronounced "Frankenstine" or "Frankensteen?" | | Life is not simple anywhere. Probably less so elsewhere. | | | | | | | ________________________________________________________________________________
Date: Aug 29, 2005
In a message dated 8/29/2005 4:27:41 P.M. Central Standard Time, CloudCraft(at)aol.com writes: If you can't Google it, let me know and I'll try to find archive issues of the Flight Group News that featured these. Wing Commander Gordon Try: _http://www.zeftronics.com_ (http://www.zeftronics.com) Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator Stearman N3977A Brookeridge Air Park LL22 Downers Grove, IL 60516 630 985-8503 ________________________________________________________________________________
Date: Aug 29, 2005
Subject: Re: grass strip length
Ben, Not one to give advice ... but one to spend other people's money at the drop of a hat, here are some things to consider: The power and long blades of a 680-E can not be beat for short field performance. The long blades of a 680-E do offer less ground clearance, but if it's grass and not gravel, I'd say "no danger!" I've operated 500 series and 680 series in dirt, grass and almost sand and they're just great. Pot holes and rocks with wreck any airplane, regardless. You haven't told us your field elevation and hottest day you'll be flying off it and what your approach and departure path looks like ("obstacle clearance plane," if you want to speak as if it were a major airport) so get back to us with that info and the Group will have lots of free opinions and advice, worth every penny, guaranteed. Wing Commander Gordon Life is not simple anywhere. Probably less so elsewhere. ________________________________________________________________________________
Date: Aug 29, 2005
Lucas, you mean the "Prince of Darkness". bilbo ----- Original Message ----- From: "Barry Collman" <barry.collman@air-britain.co.uk> Subject: Re: Commander-List: Voltage Regulators > <barry.collman@air-britain.co.uk> > > Don't Lucas do some good ones? > > BC (UK) > > ----- Original Message ----- > From: <CloudCraft(at)AOL.COM> > To: > Subject: Commander-List: Voltage Regulators > > > | > | A bazillion years ago (1997, to be exact) a company called Zeftronics > | developed and mounted in an Aero Commander, solid state voltage > regulators to > replace > | the Frankenstine units. > | > | I believe Dennis Polito installed some a few years ago in his AC-500-B. > | > | If you can't Google it, let me know and I'll try to find archive issues > of > | the Flight Group News that featured these. > | > | Wing Commander Gordon > | > | PS: Is it pronounced "Frankenstine" or "Frankensteen?" > | > | Life is not simple anywhere. Probably less so elsewhere. > | > | > | > | > | > | > | > > > ________________________________________________________________________________
Date: Aug 29, 2005
Ben, I have a 500A and fly mostly off field elevations of 700'. I routinely have flown in and out of 2200' strips at gross with out any problems. Commanders are good short field, high altitude, as well as one of the most comfortable planes and one of the best flying airplanes you will ever find. They are all good. I have owned mine since 01APR81 and it has gotten me out of any trouble I could get it into. Jim Addington N444BD jtaddington(at)charter.net -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com]On Behalf Of Ben Baltrusaitis Subject: Commander-List: grass strip length Hi Guys, How short of an unobstructed grass strip are you willing to land on, assuming reasonable temperature and a few hundred under gross? Please tell me what you fly. I'm looking to buy a Twin Commander in the spring and have been set on a 680E for a long time. Now I'm wondering if one of the others may be better for me. I have been flying on some really short grass airports and would like to continue that with my Aero Commander. I will be flying with no more than 150 gals fuel, 4-6 people, limited baggage. It looks to me like the 680 may be the best choice, but with fuel prices, a 560 may be smarter. What are your opinions? Thanks!! I hope everyone in the South is safe! Ben-PA ________________________________________________________________________________
Date: Aug 29, 2005
In a message dated 29-Aug-05 14:33:48 Pacific Daylight Time, barry.collman@air-britain.co.uk writes: <barry.collman@air-britain.co.uk> Don't Lucas do some good ones? BC (UK) > > Lucas, Sir Barry? Where's that British sense of public shame? Wing Commander Gordon Life is not simple anywhere. Probably less so elsewhere. ________________________________________________________________________________
Date: Aug 29, 2005
They're the ones! BC (UK) ----- Original Message ----- From: "Bill Bow" <bowing74(at)earthlink.net> Subject: Re: Commander-List: Voltage Regulators | | Lucas, you mean the "Prince of Darkness". | | bilbo | ----- Original Message ----- | From: "Barry Collman" <barry.collman@air-britain.co.uk> | To: | Subject: Re: Commander-List: Voltage Regulators | | | > <barry.collman@air-britain.co.uk> | > | > Don't Lucas do some good ones? | > | > BC (UK) | > | > ----- Original Message ----- | > From: <CloudCraft(at)AOL.COM> | > To: | > Subject: Commander-List: Voltage Regulators | > | > | > | | > | A bazillion years ago (1997, to be exact) a company called Zeftronics | > | developed and mounted in an Aero Commander, solid state voltage | > regulators to | > replace | > | the Frankenstine units. | > | | > | I believe Dennis Polito installed some a few years ago in his AC-500-B. | > | | > | If you can't Google it, let me know and I'll try to find archive issues | > of | > | the Flight Group News that featured these. | > | | > | Wing Commander Gordon | > | | > | PS: Is it pronounced "Frankenstine" or "Frankensteen?" | > | | > | Life is not simple anywhere. Probably less so elsewhere. | > | | > | | > | | > | | > | | > | | > | | > | > | > | | | | | | | ________________________________________________________________________________
Date: Aug 29, 2005
Thanks, Wing Commander Gordon! The fields I fly from now are grass and in the Northeast, so elevation is less than 2000 ft. and mostly under 1000. Summer temperatures here are usually cool in the morning 60-70 F., however, this summer was an exception. Most of the grass runways have 30 foot or less obstructions-several unobstructed. I do plan to go West and get in some wilderness under-the-wing camping. I've never been to Idaho or Wyoming. I've been looking at the specs that Chris compiled on the Twin Commander Flight Group site and it says there that the 680 will beat the 680E off the ground and the 560 will beat the 680. I appreciate the advice. Ben-PA ----- Original Message ----- From: CloudCraft(at)aol.com To: commander-list(at)matronics.com Sent: Monday, August 29, 2005 5:32 PM Subject: Re: Commander-List: grass strip length Ben, Not one to give advice ... but one to spend other people's money at the drop of a hat, here are some things to consider: The power and long blades of a 680-E can not be beat for short field performance. The long blades of a 680-E do offer less ground clearance, but if it's grass and not gravel, I'd say "no danger!" I've operated 500 series and 680 series in dirt, grass and almost sand and they're just great. Pot holes and rocks with wreck any airplane, regardless. You haven't told us your field elevation and hottest day you'll be flying off it and what your approach and departure path looks like ("obstacle clearance plane," if you want to speak as if it were a major airport) so get back to us with that info and the Group will have lots of free opinions and advice, worth every penny, guaranteed. Wing Commander Gordon Life is not simple anywhere. Probably less so elsewhere. ________________________________________________________________________________
Date: Aug 29, 2005
Sorry guys, I have already had a Jag and a Triumph that had Lucas electronics. However, I must admit that improvements may have been made....my Phillips TV doesn't wonder from station to station like the Phillips radio did in the Jag. Moe ----- Original Message ----- From: "Bill Bow" <bowing74(at)earthlink.net> Subject: Re: Commander-List: Voltage Regulators > > Lucas, you mean the "Prince of Darkness". > > bilbo > ----- Original Message ----- > From: "Barry Collman" <barry.collman@air-britain.co.uk> > To: > Subject: Re: Commander-List: Voltage Regulators > > > > <barry.collman@air-britain.co.uk> > > > > Don't Lucas do some good ones? > > > > BC (UK) > > > > ----- Original Message ----- > > From: <CloudCraft(at)AOL.COM> > > To: > > Subject: Commander-List: Voltage Regulators > > > > > > | > > | A bazillion years ago (1997, to be exact) a company called Zeftronics > > | developed and mounted in an Aero Commander, solid state voltage > > regulators to > > replace > > | the Frankenstine units. > > | > > | I believe Dennis Polito installed some a few years ago in his AC-500-B. > > | > > | If you can't Google it, let me know and I'll try to find archive issues > > of > > | the Flight Group News that featured these. > > | > > | Wing Commander Gordon > > | > > | PS: Is it pronounced "Frankenstine" or "Frankensteen?" > > | > > | Life is not simple anywhere. Probably less so elsewhere. > > | > > | > > | > > | > > | > > | > > | > > > > > > > > ________________________________________________________________________________
Date: Aug 29, 2005
In a message dated 29-Aug-05 15:07:26 Pacific Daylight Time, ben(at)gmpexpress.net writes: it says there that the 680 will beat the 680E off the ground and the 560 will beat the 680. I'd take the extended wing (the "E" in 680E) any day over the short wing ... as long as I'm spending your money ... for the increased lift and handling characteristics at the low speed range. (as in stall characteristics) A 560 beating a 680? Ummmmmmm ... maybe in the world of brochures but I doubt that would be the case in the field. There's little substitute for power. Or, as one of my mentors told me, "the only thing that compensates for lack of brains is lots of thrust and lots of fuel." (He was flying Gulfstreams for a major construction firm in Alaska in the 1970s.) At the risk of public outrage, I'd say if you developed some expertise in the 680-E, you could work off 2000 feet. Less, maybe, but I wouldn't ever say that on a public email net, would I? Your mileage may vary. If you're grass strip is 2500+ feet, you'll be very comfortable, quite soon. Keep in mind, you'd better have a flat clearance plane in the event of going one engine inoperative. I hate to state the obvious, but I am forced to. If you ever had one engine inoperative, or a hydraulic abnormal, go land at a big airport and get a ride home. Obviously, if you're going to go camping under the wing in Idaho or Wyoming, your runway requirement is going up. How much? Can't tell you without the AFM, which I don't have. Wing Commander Gordon ________________________________________________________________________________
Date: Aug 29, 2005
Just as a note, a sea level warm 25 degree day take-off with no wind @ 8500 Lbs. in my Mr.RPM 680FLP takes all of 2500 feet (and you better fly around that 50' obstacle). I don't think the engines/controls are tuned/rigged properly but I have nothing to compare it to. Tom F. C-GISS ----- Original Message ----- From: "Ben Baltrusaitis" <ben(at)gmpexpress.net> Subject: Re: Commander-List: grass strip length > > Thanks, Wing Commander Gordon! > The fields I fly from now are grass and in the Northeast, so elevation is less than 2000 ft. and mostly under 1000. Summer temperatures here are usually cool in the morning 60-70 F., however, this summer was an exception. Most of the grass runways have 30 foot or less obstructions-several unobstructed. > I do plan to go West and get in some wilderness under-the-wing camping. I've never been to Idaho or Wyoming. > I've been looking at the specs that Chris compiled on the Twin Commander Flight Group site and it says there that the 680 will beat the 680E off the ground and the 560 will beat the 680. > I appreciate the advice. > Ben-PA > > ----- Original Message ----- > From: CloudCraft(at)aol.com > To: commander-list(at)matronics.com > Sent: Monday, August 29, 2005 5:32 PM > Subject: Re: Commander-List: grass strip length > > > Ben, > > Not one to give advice ... but one to spend other people's money at the drop > of a hat, here are some things to consider: > > The power and long blades of a 680-E can not be beat for short field > performance. > > The long blades of a 680-E do offer less ground clearance, but if it's grass > and not gravel, I'd say "no danger!" > > I've operated 500 series and 680 series in dirt, grass and almost sand and > they're just great. > > Pot holes and rocks with wreck any airplane, regardless. > > You haven't told us your field elevation and hottest day you'll be flying off > it and what your approach and departure path looks like ("obstacle clearance > plane," if you want to speak as if it were a major airport) so get back to us > with that info and the Group will have lots of free opinions and advice, worth > every penny, guaranteed. > > Wing Commander Gordon > > Life is not simple anywhere. Probably less so elsewhere. > > ________________________________________________________________________________
Date: Aug 29, 2005
I remember my father's MkIV and then the 420G, the heater could be turned on or off (nothing in between), for a high-end car I thought that was pretty miserable and the electric's were always a problem. Tom F. C-GISS ----- Original Message ----- From: "Moe" <moe(at)rosspistons.com> Subject: Re: Commander-List: Voltage Regulators > > Sorry guys, I have already had a Jag and a Triumph that had Lucas > electronics. However, I must admit that improvements may have been > made....my Phillips TV doesn't wonder from station to station like the > Phillips radio did in the Jag. > > Moe > ----- Original Message ----- > From: "Bill Bow" <bowing74(at)earthlink.net> > To: > Subject: Re: Commander-List: Voltage Regulators > > > > > > Lucas, you mean the "Prince of Darkness". > > > > bilbo > > ----- Original Message ----- > > From: "Barry Collman" <barry.collman@air-britain.co.uk> > > To: > > Subject: Re: Commander-List: Voltage Regulators > > > > > > > <barry.collman@air-britain.co.uk> > > > > > > Don't Lucas do some good ones? > > > > > > BC (UK) > > > > > > ----- Original Message ----- > > > From: <CloudCraft(at)AOL.COM> > > > To: > > > Subject: Commander-List: Voltage Regulators > > > > > > > > > | > > > | A bazillion years ago (1997, to be exact) a company called Zeftronics > > > | developed and mounted in an Aero Commander, solid state voltage > > > regulators to > > > replace > > > | the Frankenstine units. > > > | > > > | I believe Dennis Polito installed some a few years ago in his > AC-500-B. > > > | > > > | If you can't Google it, let me know and I'll try to find archive > issues > > > of > > > | the Flight Group News that featured these. > > > | > > > | Wing Commander Gordon > > > | > > > | PS: Is it pronounced "Frankenstine" or "Frankensteen?" > > > | > > > | Life is not simple anywhere. Probably less so elsewhere. > > > | > > > | > > > | > > > | > > > | > > > | > > > | > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Aug 29, 2005
Ben, I can't think of a light twin I'd rather be in than a Commander for short field. Did get my multi in a Robertson equiped Aztruck, though. Not as cute as an Apache and kinda full-figured but gets the short field job done pretty good and hauls a load. Faster than I would have figured too.... If you're not new to twins, don't read any further and I apologize in advance.... The following would not be appropriate, as I'm sure you well know it. Landing short is no problem and you CAN haul these things (any light twin) off 'really short fields', but do you really want to as a steady diet? I'm thinking grass fields means a lot of pleasant summer time flights in high-density altitude conditions. Yuck. If you're 'stepping-up' to twins, there are a couple excellent references I keep around and reread myself fairly often. Cavet Emptor, but if multi-engine flying is new to you, the following links might illustrate some of the operational problems with light twins and short fields. Interested in what the other fellows think. I've been taught from some time back to go for the speed early, and decelerate to Vx when you lose an engine .... Can't do that short field. Got to have the presence of mind to shut the good engine down and crash straight-ahead rather than push it and end up upside-down in heap. Sounds easy, but in practice we don't do so well and a lot of us end up in the heap. http://www.avweb.com/news/columns/182040-1.html http://www.iflypete.com/documents/Always_Leave.html Steve ----- Original Message ----- From: "Ben Baltrusaitis" <ben(at)gmpexpress.net> Subject: Commander-List: grass strip length > > > Hi Guys, > How short of an unobstructed grass strip are you willing to land on, > assuming reasonable temperature and a few hundred under gross? > Please tell me what you fly. > > I'm looking to buy a Twin Commander in the spring and have been set on a > 680E for a long time. Now I'm wondering if one of the others may be better > for me. I have been flying on some really short grass airports and would > like to continue that with my Aero Commander. I will be flying with no > more than 150 gals fuel, 4-6 people, limited baggage. > It looks to me like the 680 may be the best choice, but with fuel prices, > a 560 may be smarter. What are your opinions? > Thanks!! > I hope everyone in the South is safe! > Ben-PA > > > ________________________________________________________________________________
Date: Aug 29, 2005
My 560F has no problems loaded with lobsters from X01 ________________________________________________________________________________
Date: Aug 29, 2005
Thanks for the links, Steve, I'm stepping up to a twin and find the information most valuable. Ben ________________________________________________________________________________
Date: Aug 29, 2005
Ben; I fly a 560E and when I had my annual a few years ago, I flew into a 2800 ft. grass strip. I could land and take off in just over half the length, 2 on board with about 150 gal. of fuel on board, warm spring day, 1000 ft. elevation. (Atlanta). In fact there used to be a video of me taking off from that strip. However I will say that when operating normally I rotate at 90 kts. but when on a short field I rotate and approach at 70 kts. 90 kts is my single engine speed, if I don't need to fly below it, why sit myself up for the extra work. I don't believe it would be a problem at the slower speeds, but would probably not be able to hold a heading while controlling the airplane until I got my speed up to 90 kts. Just my thoughts. Don > > > Hi Guys, > How short of an unobstructed grass strip are you willing to land on, > assuming reasonable temperature and a few hundred under gross? > Please tell me what you fly. > > I'm looking to buy a Twin Commander in the spring and have been set on a > 680E for a long time. Now I'm wondering if one of the others may be better > for me. I have been flying on some really short grass airports and would > like to continue that with my Aero Commander. I will be flying with no > more than 150 gals fuel, 4-6 people, limited baggage. > It looks to me like the 680 may be the best choice, but with fuel prices, > a 560 may be smarter. What are your opinions? > Thanks!! > I hope everyone in the South is safe! > Ben-PA > > > ________________________________________________________________________________
Date: Aug 29, 2005
Look in Trade A Plane for Zefftronics. The regulators you need are manufactured by them and they are GREAT replacements for the old open frame units originally installed. They are all solid state and have been trouble free since installation. Dennis Polito ----- Original Message ----- From: <CloudCraft(at)aol.com> Subject: Commander-List: Voltage Regulators > > A bazillion years ago (1997, to be exact) a company called Zeftronics > developed and mounted in an Aero Commander, solid state voltage regulators > to replace > the Frankenstine units. > > I believe Dennis Polito installed some a few years ago in his AC-500-B. > > If you can't Google it, let me know and I'll try to find archive issues of > the Flight Group News that featured these. > > Wing Commander Gordon > > PS: Is it pronounced "Frankenstine" or "Frankensteen?" > > Life is not simple anywhere. Probably less so elsewhere. > > > ________________________________________________________________________________
Date: Aug 29, 2005
I got a demonstration from Morris in a 500B at sea level. There were the two of us and about half fuel. He had me watch the 1000 foot mark and we were off before it. I have also gone out of a 7600 elevation and 70 degrees with full fuel and at gross and used 5000' to get off the ground. It did climb ok after I got the gear and flaps up. Density Altitude can make a big difference. If you have never flown out of high altitudes, allow lots of extra runway to start with and learn what it will do. At the TCFG meeting in Hillsboro, OR they showed a movie of landing up the side of a mountain like in the movie Air America. It showed what can be done. I would not try it. Happy flying. Tylor Hall Ben; I fly a 560E and when I had my annual a few years ago, I flew into a 2800 ft. grass strip. I could land and take off in just over half the length, 2 on board with about 150 gal. of fuel on board, warm spring day, 1000 ft. elevation. (Atlanta). In fact there used to be a video of me taking off from that strip. However I will say that when operating normally I rotate at 90 kts. but when on a short field I rotate and approach at 70 kts. 90 kts is my single engine speed, if I don't need to fly below it, why sit myself up for the extra work. I don't believe it would be a problem at the slower speeds, but would probably not be able to hold a heading while controlling the airplane until I got my speed up to 90 kts. Just my thoughts. Don > > > Hi Guys, > How short of an unobstructed grass strip are you willing to land on, > assuming reasonable temperature and a few hundred under gross? > Please tell me what you fly. > > I'm looking to buy a Twin Commander in the spring and have been set on a > 680E for a long time. Now I'm wondering if one of the others may be better > for me. I have been flying on some really short grass airports and would > like to continue that with my Aero Commander. I will be flying with no > more than 150 gals fuel, 4-6 people, limited baggage. > It looks to me like the 680 may be the best choice, but with fuel prices, > a 560 may be smarter. What are your opinions? > Thanks!! > I hope everyone in the South is safe! > Ben-PA > > ________________________________________________________________________________
Date: Aug 29, 2005
Admittedly, my straight 500 was a bit lazy when the density altitude rose above 7 or 8,000 feet, which a Commander with a couple of blowers could fix. I used to land on the side of a mountain close to a construction site and got quite a kick out of flying fellow pilots into that strip. It couldn't have been more than 1,000' long at about 3,000 agl, but it sloped up aggressively making the virtual runway length much longer. Gear and flaps down with only a mountain side filling the windscreen couldn't get much reaction from non-flying pax, but folks who had some stick time got two moments of reality: landing and when we took off again. We always had flying pax in awe at the Commander once we were airborne. Less than a 1,000' is not much when you line up to take off. I have video where I took off from Inhaca, an island off the east coast of Mozambique with nine people on board (mercy flight) with diving weight belts, O2 bottles and gear. It was no joke but the Commander performed like a star. I will post the video in the near future. A Baron 55 couldn't take its regular load out of the strip on the island and time/ daylight was running out in an African/communist country. Those folks had to get out with us or they could be lost forever. The 500 did the job so well that all of the excess pax got back into the Commander after we cleared customs and immigration at Maputo with a 10,000' runway. No Baron for them. HAHAHA. We were a jolly bunch, I must say, laughing at the Baron, singing the accolades of the Commander. Most of these guys were fighter jocks in the air force with plenty of French Mirage time. Ben, you cannot go wrong with any Commander. Go fly a couple of them and get the one that makes the most sense for you. Listen to the folks on this list who have flown more variations of the Commander than most and you cannot go wrong. There will come a time when another plane would respond, "you wanna do WHAT?" while a Commander would just say, "Sure, let's go." Having said that, Commanders do command respect, both on the ramp and in the left-seat. See here http://www.teletuition.org/documents/Aviation/Accidents/AeroCommanderStalled.jpg what I mean. Nico ----- Original Message ----- From: "tylor.hall" <tylor.hall(at)sbcglobal.net> Subject: RE: Commander-List: grass strip length > > > I got a demonstration from Morris in a 500B at sea level. There were the > two of us and about half fuel. He had me watch the 1000 foot mark and we > were off before it. > > I have also gone out of a 7600 elevation and 70 degrees with full fuel and > at gross and used 5000' to get off the ground. It did climb ok after I got > the gear and flaps up. > > Density Altitude can make a big difference. If you have never flown out of > high altitudes, allow lots of extra runway to start with and learn what it > will do. > > At the TCFG meeting in Hillsboro, OR they showed a movie of landing up the > side of a mountain like in the movie Air America. It showed what can be > done. I would not try it. > > Happy flying. > Tylor Hall > > > Ben; > > I fly a 560E and when I had my annual a few years ago, I flew into a 2800 > ft. grass strip. I could land and take off in just over half the length, 2 > on board with about 150 gal. of fuel on board, warm spring day, 1000 ft. > elevation. (Atlanta). In fact there used to be a video of me taking off > from that strip. However I will say that when operating normally I rotate > at 90 kts. but when on a short field I rotate and approach at 70 kts. 90 > kts is my single engine speed, if I don't need to fly below it, why sit > myself up for the extra work. I don't believe it would be a problem at the > slower speeds, but would probably not be able to hold a heading while > controlling the airplane until I got my speed up to 90 kts. Just my > thoughts. > > Don > > > > > > > > Hi Guys, > > How short of an unobstructed grass strip are you willing to land on, > > assuming reasonable temperature and a few hundred under gross? > > Please tell me what you fly. > > > > I'm looking to buy a Twin Commander in the spring and have been set on a > > 680E for a long time. Now I'm wondering if one of the others may be better > > for me. I have been flying on some really short grass airports and would > > like to continue that with my Aero Commander. I will be flying with no > > more than 150 gals fuel, 4-6 people, limited baggage. > > It looks to me like the 680 may be the best choice, but with fuel prices, > > a 560 may be smarter. What are your opinions? > > Thanks!! > > I hope everyone in the South is safe! > > Ben-PA > > > > > > ________________________________________________________________________________
Date: Aug 30, 2005
Ben, Joe Shepherd and I have been operating a 560F off of a 2000' grass strip for years. (Elev 925') No Problem! However........when the density altitude starts climbing, we do restrict the gross weight. (You can tell a big difference at a 1000' @ 90 degrees.) We've also operated a 520, and 680E from the same strip. My personal preferences: 520---Not an issue 560---Not an issue 560E---Not an issue 560A HC---Not an issue 560F---Watch density altitude/limit gross weight 680E---See above 680F---See above (Do-able but no room for error) The remaining models---Consider an Aztruck Commander Gordon is spot on concerning 2nd segment climb, as you don't want to be turning around a tree after losing an engine. You are not be operating off of a balanced field, so expect NOT to stop on the field if you lose an engine near Vmc. (It does make every takeoff exciting!) The method Joe and I use is to remain on the ground until attaining Vmc. (Chanting, "Engines Don't Fail Me Now" during the takeoff roll and climb out also seems to help!) Another consideration when operating off of grass is field condition, i.e., dew, rain and depth of grass. We elect NOT to operate our aircraft during periods of dew, rain or high grass. I'm sure it probably can be done, but being an old-fart retired airline pilot with 25,000+ hours I've decided that my heart can't take the excitement. (Definitely OLD, definitely not Bold.) :-) You mentioned flying out west. If this is part of your 'mission' I would strongly suggest something with superchargers for the higher altitude airports, i.e., a 680E. Before making a decision it would be prudent to review the single engine service ceilings of the various aircraft you might have in mind. (It would be a real bitch to find the single engine service ceiling is 8500' when the terrain is 9500' where you find yourself---Bummer!) Hope I've been some help. Jim Crunkleton ________________________________________________________________________________
"BROOKE D HARLOW" , "candice" , "carol haskins" , "commander-list" , "DAN BRUHL" , "Fearn Mastin" , "FEDERICO M VELEZ A"
Subject: Fw: Too Cool a Story Not To Send.......
Date: Aug 30, 2005
0.14 FROM_NO_LOWER From address has no lower-case characters ----- Original Message ----- From: Kay Farman<mailto:kaydickson(at)charter.net> Subject: Fw: Too Cool a Story Not To Send....... ----- Original Message ----- From: Jane Lancaster<mailto:jrlancaster(at)yahoo.com> Subject: Too Cool a Story Not To Send....... Subject: Irish Luck - Remember to send it back! I want this back. It DOES work. His name was Fleming, and he was a poor Scottish farmer. One day, while trying to make a living for his family, he heard a cry for help coming from a nearby bog. He dropped his tools and ran to the bog. There, mired to his waist in black muck, was a terrified boy, screaming and struggling to free himself. Farmer Fleming saved the lad from what could have been a slow and terrifying death. The next day, a fancy carriage pulled up to the Scotsman's sparse surroundings. An elegantly dressed nobleman stepped out and introduced himself as the father of the boy Farmer Fleming had saved. "I want to repay you," said the nobleman. "You saved my son's life." "No, I can't accept payment for what I did," the Scottish farmer replied waving off the offer. At that moment, the farmer's own son came to the door of the family hovel. "Is that your son?" the nobleman asked. "Yes," the farmer replied proudly. "I'll make you a deal. Let me provide him with the level of education my own son will enjoy. If the lad is anything like his father, he'll no doubt grow to be a man we both will be proud of." And that he did. Farmer Fleming's son attended the very best schools and in time, graduated from St. Mary's Hospital Medical School in London, and went on to become known throughout the world as the noted Sir Alexander Fleming, the discoverer of Penicillin. Years afterward, the same nobleman's son who was saved from the bog was stricken with pneumonia. What saved his life this time? Penicillin. The name of the nobleman? Lord Randolph Churchill. His son's name? Sir Winston Churchill. Someone once said: What goes around comes around. Work like you don't need the money. Love like you've never been hurt. Dance like nobody's watching. Sing like nobody's listening. Live like it's Heaven on Earth. It's National Friendship Week. Send this to everyone you consider A FRIEND. Pass this on, and brighten someone's day. AN IRISH FR! IENDSHIP WISH: You had better send this back!! Good Luck! I hope it works... May there always be work for your hands to do; May your purse always hold a coin or two; May the sun always shine on your windowpane; May a rainbow be certain to follow each rain; May the hand of a friend always be near you; May God fill your heart with gladness to cheer you. ________________________________________________________________________________
Date: Aug 30, 2005
Jim Crunkleton wrote: >520---Not an issue >560---Not an issue >560E---Not an issue >560A HC---Not an issue >560F---Watch density altitude/limit gross weight >680E---See above >680F---See above (Do-able but no room for error) >The remaining models---Consider an Aztruck > > > Thanks, Jim. Before seeing this, I was thinking one of two scenarios was happening: a - The Commander list had banded together to play a big joke on me (or scramble the few brain cells I had left), or b - N400CH is missing an engine and/or dragging a plow. I'm pretty sure both engines are attached and as strong as they can get and I (usually) unhook the tug before taking the runway, so I had the BS flag at half mast! While the 680FL(P) has impressed me with its short-field capabilities, they are nothing to write home about with any load past pilot and a half a gallon of gas or so. Darn extra seats. I'd really complain if I couldn't get them up over 200 knots. Brock Lorber N400CH ________________________________________________________________________________
Date: Aug 30, 2005
Gentlemen: Thanks very much for the replies. Perhaps I should have mentioned that I have 100 amp generators on the 680F(p), and Zeftronics only has 50 amp voltage regulators. This came as a surprise to me so I called their tech assistance lady and she confirmed it. Any other suggestions? Regards, Moe N680RR ----- Original Message ----- From: <BobsV35B(at)aol.com> Subject: Re: Commander-List: Voltage Regulators > > > In a message dated 8/29/2005 4:27:41 P.M. Central Standard Time, > CloudCraft(at)aol.com writes: > > If you can't Google it, let me know and I'll try to find archive issues of > the Flight Group News that featured these. > > Wing Commander Gordon > > > Try: _http://www.zeftronics.com_ (http://www.zeftronics.com) > > Happy Skies, > > Old Bob > AKA > Bob Siegfried > Ancient Aviator > Stearman N3977A > Brookeridge Air Park LL22 > Downers Grove, IL 60516 > 630 985-8503 > > ________________________________________________________________________________
Subject: Zefftronics Regulators
Date: Aug 30, 2005
>Am considering getting rid of the stock "Frankenstein" voltage regulators on my 680F(p). Any suggestions? >Look in Trade A Plane for Zefftronics. The regulators you need are manufactured by them and they are GREAT replacements for the old open frame units originally installed. They are all solid state and have been trouble free since installation. I, too, have the Zefftronics solid state system installed on my 500B. I had the Merlyn folks install it during my Merlyn 320 turbo engine conversion. It completely replaces the stock one, and I have never had any trouble with it. Sorry, I don't remember the cost because it was mixed in with the engine conversion where I was spending BIG money. I also had their smaller solid state regulator on my Cardinal RG for many years with the same perfect result. It is over voltage protected and self resets. Larry Wokral ________________________________________________________________________________
Subject: Short Grass Strips
Date: Aug 30, 2005
>How short of an unobstructed grass strip are you willing to land on, assuming reasonable temperature and a few hundred under gross? Please tell me what you fly. I have been practicing high performance, short field takeoffs and landings in my Merlyn 320 converted 500B in preparation for taking it into my new 1,200' sloped sod strip (close to 2,000' flat land equivalency with no departure obstructions). My local paved field is 3,642' in elevation. On density altitude days where it is closer to 5,000' in elevation and with just me and 100 gallons of fuel aboard, I've been getting off in about 900', and always under 1,000'. I start by holding brakes until getting 38" MP, increasing to 42" MP on the roll, and rotating by 70 KIAS. I pick up VYse speed after breaking ground quickly. As Morris suggested to me once, I've even tried holding the brakes until reaching the full 42" and then rotating at 65 KIAS and holding it there for the initial climb. That was exhilarating! The stall horn was sounding during initial rotation, but the plane kept its climb and accelerated with a little lessening of back pressure on the yoke. I really believe that it would easily operate out of short, unobstructed grass strips. Of course I have read the articles on multi engine takeoff speed safety techniques and was trained on making every attempt at reaching blue line before rotation or gaining it ASAP after rotation. None the less, these planes will give great short field performance when needed. Using a short field technique doesn't prevent you from gaining blue line speed immediately after breaking ground and clearing the obstacle. I readily admit that I am new at flying Aerocommanders. I would really love to have one of you really experienced Commander drivers fly this thing at this edge of the envelope just to help verify or determine its full capabilities. Larry Wokral ________________________________________________________________________________
Date: Aug 30, 2005
In a message dated 30-Aug-05 07:35:52 Pacific Daylight Time, blorber(at)vegasfc.com writes: a - The Commander list had banded together to play a big joke on me (or scramble the few brain cells I had left), or b - N400CH is missing an engine and/or dragging a plow. I'm pretty sure both engines are attached and as strong as they can get and I (usually) unhook the tug before taking the runway, so I had the BS flag at half mast! While the 680FL(P) has impressed me with its short-field capabilities, they are nothing to write home about with any load past pilot and a half a gallon of gas or so. > > As much as we enjoy conspiring to blow your mind, Brock, we didn't this time. The (sad) fact of the RPM-FLP is that the 400 hp just doesn't get through the props and turn into thrust like the original model's engine & prop combination. Mr RPM did demonstrate the short field / high DENALT capability to some missionaries by taking off at gross weight from Big Bear, California (L35) on a warm day -- but -- he loaded the aircraft with aft most C.G., which he says is the key to short field work in the long body Commander. Are you sure you unhooked the tug? I heard you on frequency a while ago and I remember ATC asking if you were a flight of two. Back to the original question, Ben -- if you can find a 680-E, you'll have as good a short field Commander as you can get, both for East Coast and Rocky Mountain regions. Barry Hancock who is in the Group is selling his. Get in touch with him. Wing Commander Gordon Life is not simple anywhere. Probably less so elsewhere. ________________________________________________________________________________
Date: Aug 31, 2005
From: W J R HAMILTON <wjrhamilton(at)optusnet.com.au>
Folks, I can testify to the Zeftronics, I have them in the 500A. Neither the previous two owners, nor I have had a problem. Cheers, Bill Hamilton At 07:23 30/08/2005, you wrote: > >A bazillion years ago (1997, to be exact) a company called Zeftronics >developed and mounted in an Aero Commander, solid state voltage regulators >to replace >the Frankenstine units. > >I believe Dennis Polito installed some a few years ago in his AC-500-B. > >If you can't Google it, let me know and I'll try to find archive issues of >the Flight Group News that featured these. > >Wing Commander Gordon > >PS: Is it pronounced "Frankenstine" or "Frankensteen?" > >Life is not simple anywhere. Probably less so elsewhere. > > CONFIDENTIALITY & PRIVILEGE NOTICE W.J.R.Hamilton,Glenalmond Group Companies,Fighter Flights Internet Services and Warbirds.Net. & . This message is intended for and should only be used by the addressee. It is confidential and may contain legally privileged information.If you are not the intended recipient any use distribution,disclosure or copying of this message is strictly prohibited.Confidentiality and legal privilege attached to this communication are not waived or lost by reason of the mistaken delivery to you.If you have received this message in error, please notify us immediately to Australia 61 (0)408 876 526 Dolores capitis non fero. Eos do. ________________________________________________________________________________
Date: Aug 31, 2005
Barry, Lucas ??? The reason poms drink warm bear, they've got Lucas Fridge's. Have you seen the Jaguar Clubs t-shirt, with a caricature of the old Joseph Lucas and Sons logo In the double circle it says "Joseph Lucas --- Prince of Darkness". The deep dark secret, they not Lucas electrical systems in Jaguars, they are all work on smoke, its not a battery, it's a smoke reservoir, and the proof of this theorem, every time the smoke leaks out, the car stops. My two bob's worth on Lucas. Cheers, Bill Hamilton. also a proprietor of a Mk11 3.8 Coombs and an XK-6C, all now with Bosch. At 07:30 30/08/2005, you wrote: ><barry.collman@air-britain.co.uk> > >Don't Lucas do some good ones? > >BC (UK) > >----- Original Message ----- >From: <CloudCraft(at)AOL.COM> >To: >Subject: Commander-List: Voltage Regulators > > >| >| A bazillion years ago (1997, to be exact) a company called Zeftronics >| developed and mounted in an Aero Commander, solid state voltage >regulators to >replace >| the Frankenstine units. >| >| I believe Dennis Polito installed some a few years ago in his AC-500-B. >| >| If you can't Google it, let me know and I'll try to find archive issues of >| the Flight Group News that featured these. >| >| Wing Commander Gordon >| >| PS: Is it pronounced "Frankenstine" or "Frankensteen?" >| >| Life is not simple anywhere. Probably less so elsewhere. >| >| >| >| >| >| >| > > CONFIDENTIALITY & PRIVILEGE NOTICE W.J.R.Hamilton,Glenalmond Group Companies,Fighter Flights Internet Services and Warbirds.Net. & . This message is intended for and should only be used by the addressee. It is confidential and may contain legally privileged information.If you are not the intended recipient any use distribution,disclosure or copying of this message is strictly prohibited.Confidentiality and legal privilege attached to this communication are not waived or lost by reason of the mistaken delivery to you.If you have received this message in error, please notify us immediately to Australia 61 (0)408 876 526 Dolores capitis non fero. Eos do. ________________________________________________________________________________
Date: Aug 31, 2005
In a message dated 8/29/2005 3:07:26 P.M. Pacific Standard Time, ben(at)gmpexpress.net writes: it says there that the 680 will beat the 680E HELO BEN. I own a 680E. I also fly and have flown every short bodied piston type, except the 520, 560 and 680F. I fly my 680E from a 2600 ft strip and can use 1/2. any day, any load. Book figures aside, the 680E will outperform all other short bodied Commanders except the 680F. Part of the difference in performance numbers is the gross weight the airplanes are certified at. For instance, the 680 has a gross weight 500lbs less that the 680E. The 560E is thousand pounds less, same airframe. Since TO performance is basically a "drag race" to see who can accelerate to take off speed first, the 500 pound penalty the 680E carries skews the true numbers. Same weight, same day, the 680E will blow the doors off all of them, except maybe the "F" (and I have empirical knowable) That said, the 680E is probably not the perfect Commander. Almost any of it's flat naccelled brethren will out run it on 20% less fuel. Performance is a ballancing act. If you want the very best short field, the 680E is the one. If you want a great balance of performance, maybe another model will fit your needs better. BTY, I was born and raised flying the Idaho back country. A Commander works great!! I used to love flying into Johnson Creek or Garden Valley with my 560A. All those harry chested Cessna 180 and 206 guys couldn't believe their eyes when the Commander came around the corner. It looked like an airliner!! Good luck, choose wisely. jb. ________________________________________________________________________________
Date: Aug 31, 2005
Bill, How many amps are the generators on your 500A? Problem is, they advise that their voltage regulators will handle a maximum of 50 amps, whereas, my plane has 100 amp generators. Thanx! Moe N680RR ----- Original Message ----- From: "W J R HAMILTON" <wjrhamilton(at)optusnet.com.au> Subject: Re: Commander-List: Voltage Regulators > > Folks, > I can testify to the Zeftronics, I have them in the 500A. > Neither the previous two owners, nor I have had a problem. > Cheers, > Bill Hamilton > > > At 07:23 30/08/2005, you wrote: > > > >A bazillion years ago (1997, to be exact) a company called Zeftronics > >developed and mounted in an Aero Commander, solid state voltage regulators > >to replace > >the Frankenstine units. > > > >I believe Dennis Polito installed some a few years ago in his AC-500-B. > > > >If you can't Google it, let me know and I'll try to find archive issues of > >the Flight Group News that featured these. > > > >Wing Commander Gordon > > > >PS: Is it pronounced "Frankenstine" or "Frankensteen?" > > > >Life is not simple anywhere. Probably less so elsewhere. > > > > > > > CONFIDENTIALITY & PRIVILEGE NOTICE > W.J.R.Hamilton,Glenalmond Group Companies,Fighter Flights Internet Services > and Warbirds.Net. & . > This message is intended for and should only be used by the addressee. It > is confidential and may contain legally privileged information.If you are > not the intended recipient any use distribution,disclosure or copying of > this message is strictly prohibited.Confidentiality and legal privilege > attached to this communication are not waived or lost by reason of the > mistaken delivery to you.If you have received this message in error, please > notify us immediately to Australia 61 (0)408 876 526 > Dolores capitis non fero. Eos do. > > ________________________________________________________________________________
Subject: Fly-in Preview
Date: Aug 31, 2005
Hello Commanderland..!! Just wanted to share a neat "sneak peek" at the venue for the Fly-in coming up next month. I dropped off my 680F at Morris Kernick's hangar in Stockton (SCK) on Monday for it's annual, and John Vormbaum volunteered to give me a lift in his 500B back home to San Luis Obispo (SBP). But first, we stopped in Marina (near Monterey) to pick up JimBob, who was down doing some pre-flyin planning. It was great to see the location for the Fly-in...lots of ramp space, very nice meeting room, and facilities at the old Fort Ord army base. It's going to be a great event. It was really nice to see JB and his wife, and to share a great Commander ride in John's 500B. Looking forward to seeing many of you at the fly-in. JB says that he's only got a handful of sign-ups so far. Let's get with the program, and get your reservations turned in..!! See you all next month. Randy Dettmer 680F / N6253X ________________________________________________________________________________
Date: Sep 01, 2005
Moe, I will double check next time I am out at the hangar, also the P/N of the regulators. Cheers, Bill Hamilton. At 02:46 1/09/2005, you wrote: > >Bill, > >How many amps are the generators on your 500A? Problem is, they advise that >their voltage regulators will handle a maximum of 50 amps, whereas, my plane >has 100 amp generators. > >Thanx! > >Moe >N680RR >----- Original Message ----- >From: "W J R HAMILTON" <wjrhamilton(at)optusnet.com.au> >To: >Subject: Re: Commander-List: Voltage Regulators > > > > > > > Folks, > > I can testify to the Zeftronics, I have them in the 500A. > > Neither the previous two owners, nor I have had a problem. > > Cheers, > > Bill Hamilton > > > > > > At 07:23 30/08/2005, you wrote: > > > > > >A bazillion years ago (1997, to be exact) a company called Zeftronics > > >developed and mounted in an Aero Commander, solid state voltage >regulators > > >to replace > > >the Frankenstine units. > > > > > >I believe Dennis Polito installed some a few years ago in his AC-500-B. > > > > > >If you can't Google it, let me know and I'll try to find archive issues >of > > >the Flight Group News that featured these. > > > > > >Wing Commander Gordon > > > > > >PS: Is it pronounced "Frankenstine" or "Frankensteen?" > > > > > >Life is not simple anywhere. Probably less so elsewhere. > > > > > > > > > > > > CONFIDENTIALITY & PRIVILEGE NOTICE > > W.J.R.Hamilton,Glenalmond Group Companies,Fighter Flights Internet >Services > > and Warbirds.Net. & . > > This message is intended for and should only be used by the addressee. It > > is confidential and may contain legally privileged information.If you are > > not the intended recipient any use distribution,disclosure or copying of > > this message is strictly prohibited.Confidentiality and legal privilege > > attached to this communication are not waived or lost by reason of the > > mistaken delivery to you.If you have received this message in error, >please > > notify us immediately to Australia 61 (0)408 876 526 > > Dolores capitis non fero. Eos do. > > > > > > CONFIDENTIALITY & PRIVILEGE NOTICE W.J.R.Hamilton,Glenalmond Group Companies,Fighter Flights Internet Services and Warbirds.Net. & . This message is intended for and should only be used by the addressee. It is confidential and may contain legally privileged information.If you are not the intended recipient any use distribution,disclosure or copying of this message is strictly prohibited.Confidentiality and legal privilege attached to this communication are not waived or lost by reason of the mistaken delivery to you.If you have received this message in error, please notify us immediately to Australia 61 (0)408 876 526 Dolores capitis non fero. Eos do. ________________________________________________________________________________
Date: Aug 31, 2005
Moe, Gary Gadberry at Air Center owns the STC for the A/C units in Twin Commanders and part of the kit is 90 AMP Alternators to carry the extra load. I do not know if the alternator mod is an STC by its self. You may want to call them to see which regulator they use as part of the STC. Tylor Hall Subject: Re: Commander-List: Voltage Regulators Bill, How many amps are the generators on your 500A? Problem is, they advise that their voltage regulators will handle a maximum of 50 amps, whereas, my plane has 100 amp generators. Thanx! Moe N680RR ----- Original Message ----- From: "W J R HAMILTON" <wjrhamilton(at)optusnet.com.au> Subject: Re: Commander-List: Voltage Regulators > > Folks, > I can testify to the Zeftronics, I have them in the 500A. > Neither the previous two owners, nor I have had a problem. > Cheers, > Bill Hamilton > > > At 07:23 30/08/2005, you wrote: > > > >A bazillion years ago (1997, to be exact) a company called Zeftronics > >developed and mounted in an Aero Commander, solid state voltage regulators > >to replace > >the Frankenstine units. > > > >I believe Dennis Polito installed some a few years ago in his AC-500-B. > > > >If you can't Google it, let me know and I'll try to find archive issues of > >the Flight Group News that featured these. > > > >Wing Commander Gordon > > > >PS: Is it pronounced "Frankenstine" or "Frankensteen?" > > > >Life is not simple anywhere. Probably less so elsewhere. > > > > > > > CONFIDENTIALITY & PRIVILEGE NOTICE > W.J.R.Hamilton,Glenalmond Group Companies,Fighter Flights Internet Services > and Warbirds.Net. & . > This message is intended for and should only be used by the addressee. It > is confidential and may contain legally privileged information.If you are > not the intended recipient any use distribution,disclosure or copying of > this message is strictly prohibited.Confidentiality and legal privilege > attached to this communication are not waived or lost by reason of the > mistaken delivery to you.If you have received this message in error, please > notify us immediately to Australia 61 (0)408 876 526 > Dolores capitis non fero. Eos do. > > ________________________________________________________________________________
Date: Sep 01, 2005
Subject: FLY-IN!!!!!!!!!!
HI KIDS. Well, the time is short!! I about three weeks the TCFG will be meeting in Marina CA. (OAR) Sue and I just returned form there making the last minute arrangements. This year may be the best ever. We have great speakers lined up on great subjects. There will be important news. Like, Andrew Towner is in the final stages of establishing a first class piston Commander training facility, complete with a Commander flight training device. The software for the trainer has already been written and he planes to use a cabin section from a real Commander. They will also be able to provide "real" training in the company Shrike. This is amazing good news, so plan to attend and get all the straight skinny. We will be meeting in a nice room at the Marina airport office. We have a TV, VCR overhead and power point capabilities. It will be a great place to lean about Commanders. The awards dinner and auction is being held at Gilberts Seafood Restraint with a not to be missed view of Monterey Bay!! We have a great fly-out planned. On Friday, John Vormbaum will be leading us to Columbia CA to a small "Gold rush town" for lunch. On Saturday, the ladies will have a day of shopping in Carmel Ca while the "boys" talk Commanders. There will be tons of great food and Commanders, Commanders, Commanders. The sign up is bigger that usual for this time so if you are planning to attend (and you should be planning to attend, lest why would you be on this chat list), get your registration info in NOW!! Enterprise rent-a-car will be delivering cars to the Marina airport and they can be dropped there after the event. Make you reservation through the Seaside Ca office. Be sure to ask for the TCFG rate. We have set up a corporate account to get a discount. If you have never been to a TCFG fly-in, you don't know what you are missing. If you love Commanders, own a Commander, think you might buy a Commander or just want to have a great time around great people and great airplanes, register today and we will see you there!! Jim Metzger (capt jimbob) Director, Twin Commander Flight Group ________________________________________________________________________________
Subject: Re: FLY-IN!!!!!!!!!!
Date: Sep 01, 2005
Commandermen & Ladies, I have to voice my support for the upcoming flyin. Captain Jimbob & Captain Suebob have done an amazing amount of legwork to make sure that this event will be the best yet. Marina is a great facility; tons of ramp space, a quality meeting room, a location near fantastic sightseeing, eating, shopping & relaxing, and a chance for a great "poker run" in our airplanes. I for one can't wait until a formation of Commanders descends on Columbia---that should be a sight to see! We'll have a chance to shop & eat in an authentic CA Gold Rush town that is literally a 10 minute walk from the airfield. It's also a huge benefit to have some of the senior Commander brains attending, including the Towners, Jimbob, Morris, Sir Barry (you WILL be here, right Barry?) and hopefully a surprise guest whose last name is synonymous with Aero Commander. I know there are some great talks planned....it's a chance to learn something new about these wonderful airplanes, which is what happens for me every time these people congregate. Having made the trip to Dayton & Kansas City myself, I'm really hoping some of you easterners & southerners will put in a little effort to come see the Monterey Bay during the best time of year to visit. Also, if anyone has the "jones", I may try to squeeze in a round of golf at one of the famous 17 Mile Drive golf courses on Sunday after (I'm assuming) the early departure of our esteemed visitors. If you want to play, let me know and I will get a group set up. So make SURE you attend this year.....because next year, avgas could be $6 a gallon at the rate we're going! /John ----- Original Message ----- From: <YOURTCFG(at)aol.com> Subject: Commander-List: FLY-IN!!!!!!!!!! > > HI KIDS. > > Well, the time is short!! I about three weeks the TCFG will be > meeting in Marina CA. (OAR) Sue and I just returned form there making the last > minute arrangements. This year may be the best ever. We have great speakers > lined up on great subjects. There will be important news. Like, Andrew > Towner is in the final stages of establishing a first class piston Commander > training facility, complete with a Commander flight training device. The > software for the trainer has already been written and he planes to use a cabin > section from a real Commander. They will also be able to provide "real" training > in the company Shrike. This is amazing good news, so plan to attend and get > all the straight skinny. > We will be meeting in a nice room at the Marina airport office. We have > a TV, VCR overhead and power point capabilities. It will be a great place > to lean about Commanders. > The awards dinner and auction is being held at Gilberts Seafood > Restraint with a not to be missed view of Monterey Bay!! > We have a great fly-out planned. On Friday, John Vormbaum will be > leading us to Columbia CA to a small "Gold rush town" for lunch. On Saturday, the > ladies will have a day of shopping in Carmel Ca while the "boys" talk > Commanders. > There will be tons of great food and Commanders, Commanders, Commanders. > The sign up is bigger that usual for this time so if you are planning to > attend (and you should be planning to attend, lest why would you be on this > chat list), get your registration info in NOW!! > Enterprise rent-a-car will be delivering cars to the Marina airport and > they can be dropped there after the event. Make you reservation through the > Seaside Ca office. Be sure to ask for the TCFG rate. We have set up a > corporate account to get a discount. > If you have never been to a TCFG fly-in, you don't know what you are > missing. If you love Commanders, own a Commander, think you might buy a > Commander or just want to have a great time around great people and great airplanes, > register today and we will see you there!! Jim Metzger (capt jimbob) > Director, Twin Commander Flight Group > > ________________________________________________________________________________
From: "Howard Windham" <buddy(at)cyconenterprises.com>
Date: Sep 01, 2005
Jimbob, registration is in the mail for Kerry and myself. Would never let you down. -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of YOURTCFG(at)aol.com Subject: Commander-List: FLY-IN!!!!!!!!!! HI KIDS. Well, the time is short!! I about three weeks the TCFG will be meeting in Marina CA. (OAR) Sue and I just returned form there making the last minute arrangements. This year may be the best ever. We have great speakers lined up on great subjects. There will be important news. Like, Andrew Towner is in the final stages of establishing a first class piston Commander training facility, complete with a Commander flight training device. The software for the trainer has already been written and he planes to use a cabin section from a real Commander. They will also be able to provide "real" training in the company Shrike. This is amazing good news, so plan to attend and get all the straight skinny. We will be meeting in a nice room at the Marina airport office. We have a TV, VCR overhead and power point capabilities. It will be a great place to lean about Commanders. The awards dinner and auction is being held at Gilberts Seafood Restraint with a not to be missed view of Monterey Bay!! We have a great fly-out planned. On Friday, John Vormbaum will be leading us to Columbia CA to a small "Gold rush town" for lunch. On Saturday, the ladies will have a day of shopping in Carmel Ca while the "boys" talk Commanders. There will be tons of great food and Commanders, Commanders, Commanders. The sign up is bigger that usual for this time so if you are planning to attend (and you should be planning to attend, lest why would you be on this chat list), get your registration info in NOW!! Enterprise rent-a-car will be delivering cars to the Marina airport and they can be dropped there after the event. Make you reservation through the Seaside Ca office. Be sure to ask for the TCFG rate. We have set up a corporate account to get a discount. If you have never been to a TCFG fly-in, you don't know what you are missing. If you love Commanders, own a Commander, think you might buy a Commander or just want to have a great time around great people and great airplanes, register today and we will see you there!! Jim Metzger (capt jimbob) Director, Twin Commander Flight Group ________________________________________________________________________________
"barry.collman" <barry.collman@air-britain.co.uk>, "BILL MUNRO" , "BILL WILSON" , "BROOKE D HARLOW" , "candice" , "carol haskins" , "CLOUDCRAFT" , "commander-list" , "DAN BRUHL"
Subject: Fw: Breath Taking Photos-worth opening to see..
Date: Sep 01, 2005
----- Original Message ----- From: Lindsay Carver<mailto:rockergurl8301(at)hotmail.com> Subject: FW: Breath Taking Photos-worth opening to see.. From: "Kevin Thaxton" <kthaxton(at)lesliegp.com<mailto:kthaxton(at)lesliegp.com>> To: "'Jenny Stallsmith'" ,"'marquita,"'marquita> ricketts'" ,"'Mary,"'Mary> Zelnik'" ,"'Michael,"'Michael> Hale'" ,"'Stephanie,"'Stephanie> Byer'" ,"'Lindsay,"'Lindsay> Carver'" ,,> CC: "'Becky Bender'" > Subject: FW: Breath Taking Photos-worth opening to see.. Date: Wed, 31 Aug 2005 11:10:48 -0400 Kevin Thaxton The Leslie Group 5060 Parkcenter Ave Suite B Dublin, Ohio 43017 Direct: 614-760-8705 Main: 614-760-0701 Fax: 614-760-0705 Cell: 614-309-1597 From: Elaina Leslie [mailto:eleslie(at)lesliegp.com] Sent: Wednesday, August 31, 2005 10:30 AM To: kendall(at)mlarchs.com; Joan Mooney; Kevin Thaxton; Kit Redman; 'Carole Mauro'; 'Susan Hayden' Subject: FW: Breath Taking Photos-worth opening to see.. From: Laura Creske [mailto:lcreske(at)columbuskw.com] Sent: Wednesday, August 31, 2005 9:18 AM To: BDTman(at)aol.com; 'Elaina Leslie'; 'Coleman, Rosemary'; 'Lisa Nichols'; dlemley(at)columbuskw.com; 'Judy Jensen'; tracy_franckhauser(at)bankone.com Subject: FW: Breath Taking Photos-worth opening to see.. These pictures are beautiful!!! Enjoy!! From: Marilyn Kramer [mailto:mkramer(at)columbuskw.com] Sent: Wednesday, August 31, 2005 7:50 AM To: SHARON SULLIVAN; MICHELE KUDLA; LAURA CRESKE; Jackie Ingersoll; BETH MORTON Subject: FW: Breath Taking Photos-worth opening to see.. -----Original Message----- From: Whitcraft, Barbara [mailto:barbara.whitcraft(at)realliving.com] Sent: Wednesday, August 31, 2005 7:29 AM To: mkramer(at)columbuskw.com; Lephart, Margaret; Zborovsky, Linda; Baker, Mary Jo Cc: sonja_whitcraft(at)yahoo.com Subject: FW: Breath Taking Photos-worth opening to see.. From: BLSnyder [mailto:BLSnyde(at)columbus.rr.com] Sent: Tuesday, August 30, 2005 12:04 PM To: Dayna Hale; kathy roudabush; Kim Branch-Harris; Lisa Lyons Subject: FW: Breath Taking Photos-worth opening to see.. ________________________________________________________________________________
Subject: Re: Voltage Regulators
Date: Sep 01, 2005
Bill, Thank you very much! Moe ----- Original Message ----- From: "W J R HAMILTON" <wjrhamilton(at)optusnet.com.au> Subject: Commander-List: Voltage Regulators > > Moe, > I will double check next time I am out at the hangar, also the P/N of the > regulators. > Cheers, > Bill Hamilton. > > > At 02:46 1/09/2005, you wrote: > > > >Bill, > > > >How many amps are the generators on your 500A? Problem is, they advise that > >their voltage regulators will handle a maximum of 50 amps, whereas, my plane > >has 100 amp generators. > > > >Thanx! > > > >Moe > >N680RR > >----- Original Message ----- > >From: "W J R HAMILTON" <wjrhamilton(at)optusnet.com.au> > >To: > >Subject: Re: Commander-List: Voltage Regulators > > > > > > > > > > > > Folks, > > > I can testify to the Zeftronics, I have them in the 500A. > > > Neither the previous two owners, nor I have had a problem. > > > Cheers, > > > Bill Hamilton > > > > > > > > > At 07:23 30/08/2005, you wrote: > > > > > > > >A bazillion years ago (1997, to be exact) a company called Zeftronics > > > >developed and mounted in an Aero Commander, solid state voltage > >regulators > > > >to replace > > > >the Frankenstine units. > > > > > > > >I believe Dennis Polito installed some a few years ago in his AC-500-B. > > > > > > > >If you can't Google it, let me know and I'll try to find archive issues > >of > > > >the Flight Group News that featured these. > > > > > > > >Wing Commander Gordon > > > > > > > >PS: Is it pronounced "Frankenstine" or "Frankensteen?" > > > > > > > >Life is not simple anywhere. Probably less so elsewhere. > > > > > > > > > > > > > > > > > CONFIDENTIALITY & PRIVILEGE NOTICE > > > W.J.R.Hamilton,Glenalmond Group Companies,Fighter Flights Internet > >Services > > > and Warbirds.Net. & . > > > This message is intended for and should only be used by the addressee. It > > > is confidential and may contain legally privileged information.If you are > > > not the intended recipient any use distribution,disclosure or copying of > > > this message is strictly prohibited.Confidentiality and legal privilege > > > attached to this communication are not waived or lost by reason of the > > > mistaken delivery to you.If you have received this message in error, > >please > > > notify us immediately to Australia 61 (0)408 876 526 > > > Dolores capitis non fero. Eos do. > > > > > > > > > > > > > CONFIDENTIALITY & PRIVILEGE NOTICE > W.J.R.Hamilton,Glenalmond Group Companies,Fighter Flights Internet Services > and Warbirds.Net. & . > This message is intended for and should only be used by the addressee. It > is confidential and may contain legally privileged information.If you are > not the intended recipient any use distribution,disclosure or copying of > this message is strictly prohibited.Confidentiality and legal privilege > attached to this communication are not waived or lost by reason of the > mistaken delivery to you.If you have received this message in error, please > notify us immediately to Australia 61 (0)408 876 526 > Dolores capitis non fero. Eos do. > > ________________________________________________________________________________
Date: Sep 01, 2005
In a message dated 9/1/2005 5:37:29 A.M. Pacific Standard Time, buddy(at)cyconenterprises.com writes: Jimbob, registration is in the mail for Kerry and myself. Would never let you down THANKS!! See you soon. jb ________________________________________________________________________________
Date: Sep 01, 2005
Buddy, I was hoping you'd show! Excellent! /John ----- Original Message ----- From: "Howard Windham" <buddy(at)cyconenterprises.com> Subject: RE: Commander-List: FLY-IN!!!!!!!!!! > > Jimbob, registration is in the mail for Kerry and myself. Would never let > you down. > > -----Original Message----- > From: owner-commander-list-server(at)matronics.com > [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of > YOURTCFG(at)aol.com > To: commander-list(at)matronics.com > Subject: Commander-List: FLY-IN!!!!!!!!!! > > > HI KIDS. > > Well, the time is short!! I about three weeks the TCFG will be > meeting in Marina CA. (OAR) Sue and I just returned form there making the > last minute arrangements. This year may be the best ever. We have great > speakers > lined up on great subjects. There will be important news. Like, Andrew > Towner is in the final stages of establishing a first class piston > Commander training facility, complete with a Commander flight training > device. The software for the trainer has already been written and he > planes to use a cabin > section from a real Commander. They will also be able to provide "real" > training > in the company Shrike. This is amazing good news, so plan to attend and > get > all the straight skinny. > We will be meeting in a nice room at the Marina airport office. We > have a TV, VCR overhead and power point capabilities. It will be a great > place to lean about Commanders. > The awards dinner and auction is being held at Gilberts Seafood > Restraint with a not to be missed view of Monterey Bay!! > We have a great fly-out planned. On Friday, John Vormbaum will be > leading us to Columbia CA to a small "Gold rush town" for lunch. On > Saturday, the ladies will have a day of shopping in Carmel Ca while the > "boys" talk Commanders. > There will be tons of great food and Commanders, Commanders, > Commanders. > The sign up is bigger that usual for this time so if you are planning > to attend (and you should be planning to attend, lest why would you be on > this chat list), get your registration info in NOW!! > Enterprise rent-a-car will be delivering cars to the Marina airport and > they can be dropped there after the event. Make you reservation through > the Seaside Ca office. Be sure to ask for the TCFG rate. We have set up a > corporate account to get a discount. > If you have never been to a TCFG fly-in, you don't know what you are > missing. If you love Commanders, own a Commander, think you might buy a > Commander or just want to have a great time around great people and great > airplanes, register today and we will see you there!! Jim Metzger (capt > jimbob) Director, Twin Commander Flight Group > > ________________________________________________________________________________
Subject: Voltage Regulators
Date: Sep 01, 2005
>How many amps are the generators on your 500A? Problem is, they advise that their voltage regulators will handle a maximum of 50 amps, whereas, my plane has 100 amp generators. The Zefftronics system on my 500B handles my 70 amp alternators without a problem. I'm really not sure what they are actually rated for. Perhaps you should call Hugh Evans at Merlyn Products who worked it all out with the manufacturer to see how he did it. Larry Wokral ________________________________________________________________________________
Date: Sep 03, 2005
I deleted a message from aviation(at)aol.com (or something like that) without reading it. Please resent. I don't want to appear non-responsive. Nico ----- Original Message ----- From: "Larry Wokral" <l.wokral(at)ix.netcom.com> Subject: Commander-List: Voltage Regulators > > >How many amps are the generators on your 500A? Problem is, they advise > that > their voltage regulators will handle a maximum of 50 amps, whereas, my plane > has 100 amp generators. > > The Zefftronics system on my 500B handles my 70 amp alternators without a > problem. I'm really not sure what they are actually rated for. Perhaps you > should call Hugh Evans at Merlyn Products who worked it all out with the > manufacturer to see how he did it. > > Larry Wokral > > ________________________________________________________________________________
Date: Sep 04, 2005
Moe, My 500A is really original, 50 amp. generators, so old that brushes are hard to come by, except where truck parts are sold, the actual origin of the generator is an AC-Delco truck unit. Despite the pre historic 618M-2 Collins VHF - 2 off, 51V-4A Collins ADF by 2, one old Collins VOR/ILS 51R-8A/51V-5 , marker etc plus King Transponder,DME and interphone, battery charge etc doesn't seem to have ever been a problem. Cheers, Bill Hamilton At 14:56 1/09/2005, you wrote: > >Moe, >Gary Gadberry at Air Center owns the STC for the A/C units in Twin >Commanders and part of the kit is 90 AMP Alternators to carry the extra >load. I do not know if the alternator mod is an STC by its self. You may >want to call them to see which regulator they use as part of the STC. >Tylor Hall > > >Subject: Re: Commander-List: Voltage Regulators > > >Bill, > >How many amps are the generators on your 500A? Problem is, they advise that >their voltage regulators will handle a maximum of 50 amps, whereas, my plane >has 100 amp generators. > >Thanx! > >Moe >N680RR >----- Original Message ----- >From: "W J R HAMILTON" <wjrhamilton(at)optusnet.com.au> >To: >Subject: Re: Commander-List: Voltage Regulators > > > > > > > Folks, > > I can testify to the Zeftronics, I have them in the 500A. > > Neither the previous two owners, nor I have had a problem. > > Cheers, > > Bill Hamilton > > > > > > At 07:23 30/08/2005, you wrote: > > > > > >A bazillion years ago (1997, to be exact) a company called Zeftronics > > >developed and mounted in an Aero Commander, solid state voltage >regulators > > >to replace > > >the Frankenstine units. > > > > > >I believe Dennis Polito installed some a few years ago in his AC-500-B. > > > > > >If you can't Google it, let me know and I'll try to find archive issues >of > > >the Flight Group News that featured these. > > > > > >Wing Commander Gordon > > > > > >PS: Is it pronounced "Frankenstine" or "Frankensteen?" > > > > > >Life is not simple anywhere. Probably less so elsewhere. > > > > > > > > > > > > CONFIDENTIALITY & PRIVILEGE NOTICE > > W.J.R.Hamilton,Glenalmond Group Companies,Fighter Flights Internet >Services > > and Warbirds.Net. & . > > This message is intended for and should only be used by the addressee. It > > is confidential and may contain legally privileged information.If you are > > not the intended recipient any use distribution,disclosure or copying of > > this message is strictly prohibited.Confidentiality and legal privilege > > attached to this communication are not waived or lost by reason of the > > mistaken delivery to you.If you have received this message in error, >please > > notify us immediately to Australia 61 (0)408 876 526 > > Dolores capitis non fero. Eos do. > > > > > > CONFIDENTIALITY & PRIVILEGE NOTICE W.J.R.Hamilton,Glenalmond Group Companies,Fighter Flights Internet Services and Warbirds.Net. & . This message is intended for and should only be used by the addressee. It is confidential and may contain legally privileged information.If you are not the intended recipient any use distribution,disclosure or copying of this message is strictly prohibited.Confidentiality and legal privilege attached to this communication are not waived or lost by reason of the mistaken delivery to you.If you have received this message in error, please notify us immediately to Australia 61 (0)408 876 526 Dolores capitis non fero. Eos do. ________________________________________________________________________________
Date: Sep 04, 2005
Subject: Old Panels
Mr. Hamilton, Could you do us a favor and photograph your panel? I was thinking the other day about the double edged sword that is being swung in the Commander world. Lots of panels are being upgraded with Buck Rogers avionics, but nobody is dedicated to preserving any specimens of the originals. It would be great to gather up some original panel photos and I'm sure lots of the owners on this list have some "Before and After" series. Maybe Nico, the Patron Saint of On-Line Commander Archival Material, would host them. Wing Commander Gordon Life is not simple anywhere. Probably less so elsewhere. ________________________________________________________________________________
Date: Sep 04, 2005
Subject: Fly-In Registration
For those of you who haven't received a Fly-In registration or misplaced it, attached is the form in a Word document that you can download and print. Looking forward to seeing everyone later this month. Capt. Jim Bob ________________________________________________________________________________
Date: Sep 04, 2005
Subject: CQ Dennis Polito
CQ CQ CQ Dennis Piloto Please call me. 702-496-9112 Over. Wing Commander Gordon Life is not simple anywhere. Probably less so elsewhere. ________________________________________________________________________________
Subject: Re: Old Panels
Date: Sep 04, 2005
Sure. Let me have them and I will host them. Nico ----- Original Message ----- From: <CloudCraft(at)aol.com> Subject: Commander-List: Old Panels > > Mr. Hamilton, > > Could you do us a favor and photograph your panel? > > I was thinking the other day about the double edged sword that is being swung > in the Commander world. > > Lots of panels are being upgraded with Buck Rogers avionics, but nobody is > dedicated to preserving any specimens of the originals. > > It would be great to gather up some original panel photos and I'm sure lots > of the owners on this list have some "Before and After" series. > > Maybe Nico, the Patron Saint of On-Line Commander Archival Material, would > host them. > > Wing Commander Gordon > > Life is not simple anywhere. Probably less so elsewhere. > > ________________________________________________________________________________
From: "jmenchetti(at)cantv.net" <jmenchetti(at)cantv.net>
Subject: Old Panels, my 680F panel
Date: Sep 05, 2005
Dear gentlemen, here are some pics of my 680f panel, before having a facelift ________________________________________________________________________________
Subject: Re: fly-in
Date: Sep 05, 2005
> > For those of you who haven't received a Fly-In registration or > misplaced it, > attached is the form in a Word document that you can download and > print. > > Remember this site strips all attachments.... Cheers, Barry ________________________________________________________________________________
Date: Sep 05, 2005
Subject: Re: Old Panels, my 680F panel
Now THAT is a classic panel! Thank you, Sir. You all do realize that soon there will be a generation of pilots who will not recognize most of the instruments shown here. Wing Commander Gordon Life is not simple anywhere. Probably less so elsewhere. ________________________________________________________________________________
Date: Sep 05, 2005
Keith, I have collected a number of panel photos. Some are before and after photos. I have N2001M before and after photos. I will send them to Nico to post. I just check the www.aerocommander.com web site and the distance calculator and hotel information is for last year. Tylor Hall Subject: Re: Commander-List: Old Panels, my 680F panel Now THAT is a classic panel! Thank you, Sir. You all do realize that soon there will be a generation of pilots who will not recognize most of the instruments shown here. Wing Commander Gordon Life is not simple anywhere. Probably less so elsewhere. ________________________________________________________________________________
Date: Sep 05, 2005
N2001M's panel has been posted to http://www.teletuition.org/documents/Aviation/Aero%20Commanders/ Click on "Panels" and "N2001M". I created a special folder for panels to reduce the clutter in case there are some other folks who would want to have their panels published. Currently there is a folder for each Commander for which I have pictures. If you feel it would be better to merely include the panel photos within the Commander's folder instead of separately under a "Panels" folder, let me know. Your feedback would be appreciated. Then, perhaps, Mason could send us pictures of the rest of his Commander. Thanks Nico ----- Original Message ----- From: "tylor.hall" <tylor.hall(at)sbcglobal.net> Subject: RE: Commander-List: Old Panels, my 680F panel > > Keith, > I have collected a number of panel photos. Some are before and after > photos. > I have N2001M before and after photos. > I will send them to Nico to post. > > I just check the www.aerocommander.com web site and the distance calculator > and hotel information is for last year. > Tylor Hall > > > Subject: Re: Commander-List: Old Panels, my 680F panel > > > Now THAT is a classic panel! Thank you, Sir. > > You all do realize that soon there will be a generation of pilots who will > not recognize most of the instruments shown here. > > Wing Commander Gordon > > Life is not simple anywhere. Probably less so elsewhere. > > ________________________________________________________________________________
Date: Sep 05, 2005
Subject: Re: fly-in
Thanks for the reminder. If anyone needs a registration form, let me know and I'll send to your individual email. jb ________________________________________________________________________________
Date: Sep 05, 2005
I didn't realize there were pictures from the "Unofficial Redneck Commander Flying, Pensacola" there. One of the few times mine was running. bilbo ----- Original Message ----- From: "nico css" <nico(at)cybersuperstore.com> Subject: Re: Commander-List: Old Panels, my 680F panel > > > N2001M's panel has been posted to > http://www.teletuition.org/documents/Aviation/Aero%20Commanders/ > Click on "Panels" and "N2001M". I created a special folder for panels to > reduce the clutter in case there are some other folks who would want to > have > their panels published. Currently there is a folder for each Commander for > which I have pictures. If you feel it would be better to merely include > the > panel photos within the Commander's folder instead of separately under a > "Panels" folder, let me know. Your feedback would be appreciated. Then, > perhaps, Mason could send us pictures of the rest of his Commander. > > Thanks > Nico > > > ----- Original Message ----- > From: "tylor.hall" <tylor.hall(at)sbcglobal.net> > To: ; > Subject: RE: Commander-List: Old Panels, my 680F panel > > > >> >> Keith, >> I have collected a number of panel photos. Some are before and after >> photos. >> I have N2001M before and after photos. >> I will send them to Nico to post. >> >> I just check the www.aerocommander.com web site and the distance > calculator >> and hotel information is for last year. >> Tylor Hall >> >> >> Subject: Re: Commander-List: Old Panels, my 680F panel >> >> >> Now THAT is a classic panel! Thank you, Sir. >> >> You all do realize that soon there will be a generation of pilots who >> will >> not recognize most of the instruments shown here. >> >> Wing Commander Gordon >> >> Life is not simple anywhere. Probably less so elsewhere. >> >> > > > ________________________________________________________________________________
Date: Sep 05, 2005
The collection is slowly growing and, as time passes, it will become quite a memory jerker. It would be nice if I could get some narratives that go with the pictures. Then one can see, read and enjoy the experiences again. Nico ----- Original Message ----- From: "Bill Bow" <bowing74(at)earthlink.net> Subject: Re: Commander-List: Old Panels, my 680F panel > > I didn't realize there were pictures from the "Unofficial Redneck Commander > Flying, Pensacola" there. One of the few times mine was running. > > bilbo > ----- Original Message ----- > From: "nico css" <nico(at)cybersuperstore.com> > To: > Subject: Re: Commander-List: Old Panels, my 680F panel > > > > > > > > N2001M's panel has been posted to > > http://www.teletuition.org/documents/Aviation/Aero%20Commanders/ > > Click on "Panels" and "N2001M". I created a special folder for panels to > > reduce the clutter in case there are some other folks who would want to > > have > > their panels published. Currently there is a folder for each Commander for > > which I have pictures. If you feel it would be better to merely include > > the > > panel photos within the Commander's folder instead of separately under a > > "Panels" folder, let me know. Your feedback would be appreciated. Then, > > perhaps, Mason could send us pictures of the rest of his Commander. > > > > Thanks > > Nico > > > > > > ----- Original Message ----- > > From: "tylor.hall" <tylor.hall(at)sbcglobal.net> > > To: ; > > Subject: RE: Commander-List: Old Panels, my 680F panel > > > > > > > >> > >> Keith, > >> I have collected a number of panel photos. Some are before and after > >> photos. > >> I have N2001M before and after photos. > >> I will send them to Nico to post. > >> > >> I just check the www.aerocommander.com web site and the distance > > calculator > >> and hotel information is for last year. > >> Tylor Hall > >> > >> > >> Subject: Re: Commander-List: Old Panels, my 680F panel > >> > >> > >> Now THAT is a classic panel! Thank you, Sir. > >> > >> You all do realize that soon there will be a generation of pilots who > >> will > >> not recognize most of the instruments shown here. > >> > >> Wing Commander Gordon > >> > >> Life is not simple anywhere. Probably less so elsewhere. > >> > >> > > > > > > > > ________________________________________________________________________________
"Jerry Sprayberry"
Subject: Re: Before and After Panel
Date: Sep 05, 2005
Jerry, It has been published at http://www.teletuition.org/documents/Aviation/Aero%20Commanders/ click on N198JW and then on the .html file. You may ignore the images folder - it just contains the images that are in the .html file. This is an example of images that come with commentaries - it looks a lot nicer, don't you think? So, if you guys would go through the images and send me the commentaries, I will repost them in this format. I reposted N2001M's panel under its registration number; I will remove the "Panels" folder later. Click on N2001M to view. Thanks Nico ----- Original Message ----- From: Jerry Sprayberry To: nico(at)cybersuperstore.com Sent: Monday, September 05, 2005 4:30 PM Subject: Before and After Panel Hi Nico: These are N198JW Panels Before and after. It is a 680F(p) Commander, that ended up with a Garmin 530, 430, Transponder and Audio Panel. Collins FD105 FD, Shaden Fuel Flow & Altitude Alerter. Thanks for posting. Jerry Sprayberry ________________________________________________________________________________
Subject: Re: 680FL-1794
Date: Sep 05, 2005
Tylor, They are in http://www.teletuition.org/documents/Aviation/Aero%20Commanders/ and click on Commanders in Chile. Thanks Nico ----- Original Message ----- From: tylor.hall To: Nico van Niekerk Sent: Monday, September 05, 2005 7:38 PM Subject: 680FL-1794 Nico, 680FL SN 1794 is a Mr RPM conversion that has lived in Chile for many years. It is one of 4 that are down there hauling boxes for a living. What is very different is the STC'ed large baggage door and clamshell opening main door. The STC is owned by Central Air, but they only did one conversion. The last photo shows the sister ships that are down there. Tylor Hall ________________________________________________________________________________
Date: Sep 05, 2005
From: "Randy Dettmer, AIA" <rcdettmer(at)charter.net>
Subject: Fly-in Reservations
Date: Sep 06, 2005
Hello JimBob, Please let us know again what hotels you have coordinated with for the fly-in. I would like to make my reservations for room and rental car. Looking forward to all the fun..!! (I probably will arrive on Friday evening, since I am teaching a class at Cal Poly University this quarter that goes through Friday afternoon...darn) Thanks for all your hard work Jim..!! Randy D. 680F / N6253X ________________________________________________________________________________
Date: Sep 06, 2005
Bill, Thanx for the comments. I am very hesitant to get rid of my 100 amp generators just so I can run different voltage regulators. In the next few days I will call Gary Gadberry and see what he has to offer. Regards, Moe ----- Original Message ----- From: "W J R HAMILTON" <wjrhamilton(at)optusnet.com.au> Subject: RE: Commander-List: Voltage Regulators > > Moe, > My 500A is really original, 50 amp. generators, so old that brushes are > hard to come by, except where truck parts are sold, the actual origin of > the generator is an AC-Delco truck unit. > Despite the pre historic 618M-2 Collins VHF - 2 off, 51V-4A Collins ADF by > 2, one old Collins VOR/ILS 51R-8A/51V-5 , marker etc plus King > Transponder,DME and interphone, battery charge etc doesn't seem to have > ever been a problem. > Cheers, > Bill Hamilton > > > At 14:56 1/09/2005, you wrote: > > > >Moe, > >Gary Gadberry at Air Center owns the STC for the A/C units in Twin > >Commanders and part of the kit is 90 AMP Alternators to carry the extra > >load. I do not know if the alternator mod is an STC by its self. You may > >want to call them to see which regulator they use as part of the STC. > >Tylor Hall > > > > > >Subject: Re: Commander-List: Voltage Regulators > > > > > >Bill, > > > >How many amps are the generators on your 500A? Problem is, they advise that > >their voltage regulators will handle a maximum of 50 amps, whereas, my plane > >has 100 amp generators. > > > >Thanx! > > > >Moe > >N680RR > >----- Original Message ----- > >From: "W J R HAMILTON" <wjrhamilton(at)optusnet.com.au> > >To: > >Subject: Re: Commander-List: Voltage Regulators > > > > > > > > > > > > Folks, > > > I can testify to the Zeftronics, I have them in the 500A. > > > Neither the previous two owners, nor I have had a problem. > > > Cheers, > > > Bill Hamilton > > > > > > > > > At 07:23 30/08/2005, you wrote: > > > > > > > >A bazillion years ago (1997, to be exact) a company called Zeftronics > > > >developed and mounted in an Aero Commander, solid state voltage > >regulators > > > >to replace > > > >the Frankenstine units. > > > > > > > >I believe Dennis Polito installed some a few years ago in his AC-500-B. > > > > > > > >If you can't Google it, let me know and I'll try to find archive issues > >of > > > >the Flight Group News that featured these. > > > > > > > >Wing Commander Gordon > > > > > > > >PS: Is it pronounced "Frankenstine" or "Frankensteen?" > > > > > > > >Life is not simple anywhere. Probably less so elsewhere. > > > > > > > > > > > > > > > > > CONFIDENTIALITY & PRIVILEGE NOTICE > > > W.J.R.Hamilton,Glenalmond Group Companies,Fighter Flights Internet > >Services > > > and Warbirds.Net. & . > > > This message is intended for and should only be used by the addressee. It > > > is confidential and may contain legally privileged information.If you are > > > not the intended recipient any use distribution,disclosure or copying of > > > this message is strictly prohibited.Confidentiality and legal privilege > > > attached to this communication are not waived or lost by reason of the > > > mistaken delivery to you.If you have received this message in error, > >please > > > notify us immediately to Australia 61 (0)408 876 526 > > > Dolores capitis non fero. Eos do. > > > > > > > > > > > > > CONFIDENTIALITY & PRIVILEGE NOTICE > W.J.R.Hamilton,Glenalmond Group Companies,Fighter Flights Internet Services > and Warbirds.Net. & . > This message is intended for and should only be used by the addressee. It > is confidential and may contain legally privileged information.If you are > not the intended recipient any use distribution,disclosure or copying of > this message is strictly prohibited.Confidentiality and legal privilege > attached to this communication are not waived or lost by reason of the > mistaken delivery to you.If you have received this message in error, please > notify us immediately to Australia 61 (0)408 876 526 > Dolores capitis non fero. Eos do. > > ________________________________________________________________________________
Date: Sep 06, 2005
The attachments don't go through on the list. > -------- Original Message -------- > Subject: [SPAM] Commander-List: Old Panels, my 680F panel > From: "jmenchetti(at)cantv.net" <jmenchetti(at)cantv.net> > Date: Mon, September 05, 2005 4:58 am > To: CloudCraft(at)aol.com, commander-list(at)matronics.com > > > Dear gentlemen, here are some pics of my 680f panel, before having a > facelift > > ________________________________________________________________________________
Date: Sep 06, 2005
Subject: Re: Fly-in Reservations
Hi Randy, Unfortunately, after 5 weeks of negotiation we were unable to secure a group rate that would be better than what you could get on your own (via phone call, travel site, travel agency). It was an unbelievable experience -- they wanted more for a group rate ($149+) than the standard "rack" rate (~$114) and would have required us to pay for any unused rooms. Understandably, we finally gave up and are letting members book their own. So would suggest you book through your favorite site (like travelocity), through a travel agent or see a list of hotels on the following link: _http://beachcalifornia.travelhero.com/index.cfm/id/139491/aid/68/city/MARINA/ index.html_ (http://beachcalifornia.travelhero.com/index.cfm/id/139491/aid/68/city/MARINA/index.html) . It will probably bring up Holiday Inn, but click on the Marina tab for a list of other hotels. Marina's rates are high for 2-3 star hotels. So, if you're looking for a better deal and don't mind a little commute (5-15 miles) better rates can be found in Seaside (~5 miles) or Salinas (~10-15 miles). Enterprise Rent-a-Car in Seaside will give our members a corporate rate. Call Laura Haaker or Sara Jacobsen at 831-372-4200 and let them know you are with the Twin Commander Flight Group (TCFG) and what time you will need your car and they will pick you up at the airport and shuttle you to their office to pick one up. Let me know if you need any additional information. We're looking forward to seeing everyone. Best Regards, Mrs. Jim Bob ________________________________________________________________________________
Date: Sep 06, 2005
Subject: TCFG Newsletter
Hi everyone, Hope you all enjoyed the long weekend and sent the summer out in style. The latest issue of the Flight Group News was mailed today and includes the following information: * Fly-In Information * How to get a Pressure Carb Manual * Using a Checklist * Safety Alert * Commanderland News * Great Article on Modernizing a Shrike Also, if you haven't gotten back to us with updates for the TCFG Directory (both personal information and vendor information), please do so ASAP as we will start printing around September 12th and won't be able to make changes after that. The Directory will be given out to TCFG Members at the Fly-In and mailed to the members not in attendance after the Fly-In. Also, at this year's Fly-In we will be offering members who bring their airplanes a free "walk around" tech inspection by a panel of experts (there will be a charge for non members). If you're not a member you can join at _www.aerocommander.com_ (http://www.aerocommander.com) or can contact us directly for a membership form. Capt Jim Bob ________________________________________________________________________________
From: "Barry Collman" <barry.collman@air-britain.co.uk>
Subject: Fly_in
Date: Sep 06, 2005
Hi Guys, Well, I'm booked into the Comfort Inn, on Reservation Road, Marina for the Fly-In. Anyone else booked in there? Really looking forward to seeing some new faces and meeting up with some old ones! Also looking forward to seeing some new paint jobs (one which was long overdue!!). Sincere Best Regards, Barry ________________________________________________________________________________
Date: Sep 06, 2005
Subject: Matronics Web Server Upgrade Today Tuesday 09/06/05 5pm
PDT Dear Listers, I will be taking the Matronics Web Server down for a few hours today, Tuesday September 6 2005 for a chassis upgrade. Archive browsing and searching along with subscription services will be unavailable for be processed normally during the upgrade. Please check the Matronics System Status Page for updates (although this page resides on the web server and won't be available during the upgrade): http://www.matronics.com/SystemStatus/ Matt Dralle Matronics Email List Admin. Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Sep 06, 2005
From: John Towner <johntowner(at)centralairsouthwest.com>
Subject: Re: Fly_in
*Barry,* We will try to book too at the Comfort Inn at Marina. We wish everyone could stay at the same place but hopefully all will workout. PS-Andrew has been working on buildfing a Commander simulator for us, attached is a picture from the prototype we thought you might enjoy. Are you going to bring N4007H? and we hope all is well with her. *YOUR FRIENDS, Andrew & John Towner* Barry Collman wrote: > >Hi Guys, > >Well, I'm booked into the Comfort Inn, on Reservation Road, Marina for the >Fly-In. > >Anyone else booked in there? > >Really looking forward to seeing some new faces and meeting up with some old >ones! > >Also looking forward to seeing some new paint jobs (one which was long >overdue!!). > >Sincere Best Regards, >Barry > > > > ________________________________________________________________________________
Subject: Fly_in
Date: Sep 06, 2005
Kip and I are booked at the Comfort Inn too. Looking forward to seeing you guys Friday afternoon or evening. Randy D. -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com]On Behalf Of John Towner Subject: Re: Commander-List: Fly_in *Barry,* We will try to book too at the Comfort Inn at Marina. We wish everyone could stay at the same place but hopefully all will workout. PS-Andrew has been working on buildfing a Commander simulator for us, attached is a picture from the prototype we thought you might enjoy. Are you going to bring N4007H? and we hope all is well with her. *YOUR FRIENDS, Andrew & John Towner* Barry Collman wrote: <barry.collman@air-britain.co.uk> > >Hi Guys, > >Well, I'm booked into the Comfort Inn, on Reservation Road, Marina for the >Fly-In. > >Anyone else booked in there? > >Really looking forward to seeing some new faces and meeting up with some old >ones! > >Also looking forward to seeing some new paint jobs (one which was long >overdue!!). > >Sincere Best Regards, >Barry > > ________________________________________________________________________________
Subject: Website
Date: Sep 06, 2005
We are now manufacturing this www.nicsysco.com so if you have important data on your computer and fear you might lose it if your equipment fails, let me know. Even though the website is pitched to the business owner, data on one's home computer or laptop is equally important and expensive to replace. Thanks Nico PS. Sorry about this shameless plug. ________________________________________________________________________________
Subject: Info on service bulletin & AD
Date: Sep 06, 2005
7.50 BARRACUDA_HEADER_FP56 RBL: Blacklist bl.spamcop [Blocked - see <http://www.spamcop.net/bl.shtml?64.4.51.220>] I have an AD I need to take care of on a Shrike Commander I own. I just bought the plane a year ago and AD 940419 is due. It is an ultrasound on the wing spar. One is due yearly and another approximately every 36 months. Both are currently due. Can anyone give me any information on the most reasonable place to have this performed and its approximate cost? I would greatly appreciate any assistance you can provide. The airplane is based in North Louisiana. Sincerely, Tommy Mathieu, member ________________________________________________________________________________
Subject: Aircraft Heaters
Date: Sep 06, 2005
I had the heater installed one month ago as they are in "my back yard". It has worked beautifully "as advertised". Thanks for the heads up and recommendation as the existing Janitrol unit had never worked correctly. Don -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Moe Subject: Commander-List: Aircraft Heaters Fellow Commander Drivers: You might want to add to your parts source list for heaters: C & D Associates 302 Post Road Buchanan, MI 49107 (Niles Michigan Airport 3TC) Phone 269.695.7469 FAX 269.695.6004 www.aircraftheater.com For less than the price of a stock overhaul, they will install a brand new C & D unit that has a TBO of 2,000 hours. For the pressurized models it works completely independent of the troublesome B/C environmental control. It also does not use the stock combustion air fan and its assorted paraphernalia. It comes with its own single knob off/ on temp control switch. They also rebuild stock heaters (but why?). I went back last week and had them install one, and although I have used it only a couple of hours I am very favorably impressed. Moe N680RR 680F(p) ________________________________________________________________________________
Subject: used simmonds 580SU
Date: Sep 07, 2005
Dear Gentlemen, im looking for 2 simmonds 580SU units, in to be overhauled condition, many thanks ________________________________________________________________________________
Subject: Re: Aircraft Heaters
Date: Sep 07, 2005
Don, Glad that you have had the same great good results that I have enjoyed. Moe ----- Original Message ----- From: <dfalik(at)sbcglobal.net> Subject: RE: Commander-List: Aircraft Heaters > > I had the heater installed one month ago as they are in "my back yard". > It has worked beautifully "as advertised". Thanks for the heads up and > recommendation as the existing Janitrol unit had never worked correctly. > Don > > -----Original Message----- > From: owner-commander-list-server(at)matronics.com > [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Moe > To: commander-list(at)matronics.com > Subject: Commander-List: Aircraft Heaters > > > Fellow Commander Drivers: > > You might want to add to your parts source list for heaters: > > C & D Associates > 302 Post Road > Buchanan, MI 49107 (Niles Michigan Airport 3TC) > Phone 269.695.7469 > FAX 269.695.6004 > www.aircraftheater.com > > For less than the price of a stock overhaul, they will install a brand > new C & D unit that has a TBO of 2,000 hours. For the pressurized > models it works completely independent of the troublesome B/C > environmental control. It also does not use the stock combustion air > fan and its assorted paraphernalia. It comes with its own single knob > off/ on temp control switch. They also rebuild stock heaters (but > why?). > > I went back last week and had them install one, and although I have used > it only a couple of hours I am very favorably impressed. > > Moe > N680RR > 680F(p) > > > > > > > ________________________________________________________________________________
Date: Sep 07, 2005
Subject: Re: Commander-List Digest: 12 Msgs - 09/06/05
Hi fellow "Commanderers" I hope we are not the only ones staying at the H. Inn on the registration. The gal gave us a AAA rate but we are coming early the 21rst to look around the area. Unfortunately 69U is getting two new cranks and won't be there. dan farmer Commander-List Digest Server wrote: * ================================================== Online Versions of Today's List Digest Archive ================================================== Today's complete Commander-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the Commander-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/commander-list/Digest.Commander-List.2005-09-06.html Text Version: http://www.matronics.com/digest/commander-list/Digest.Commander-List.2005-09-06.txt ================================================ EMail Version of Today's List Digest Archive ================================================ Commander-List Digest Archive --- Total Messages Posted Tue 09/06/05: 12 Today's Message Index: ---------------------- 1. 06:44 AM - Fly-in Reservations (Randy Dettmer, AIA) 2. 07:11 AM - Re: Voltage Regulators (Moe) 3. 09:49 AM - Re: Old Panels, my 680F panel (todd(at)hindmarsh.us) 4. 11:23 AM - Re: Fly-in Reservations (YOURTCFG(at)aol.com) 5. 11:30 AM - TCFG Newsletter (YOURTCFG(at)aol.com) 6. 02:00 PM - Fly_in (Barry Collman) Dralle) 8. 05:21 PM - Re: Fly_in (John Towner) 9. 05:49 PM - Re: Fly_in (Randy Dettmer, AIA) 10. 06:20 PM - Website (nico css) 11. 08:52 PM - Info on service bulletin & AD (Tommy Mathieu) 12. 09:01 PM - Re: Aircraft Heaters () ________________________________ Message 1 _____________________________________ From: "Randy Dettmer, AIA" Subject: Commander-List: Fly-in Reservations Hello JimBob, Please let us know again what hotels you have coordinated with for the fly-in. I would like to make my reservations for room and rental car. Looking forward to all the fun..!! (I probably will arrive on Friday evening, since I am teaching a class at Cal Poly University this quarter that goes through Friday afternoon...darn) Thanks for all your hard work Jim..!! Randy D. 680F / N6253X ________________________________ Message 2 _____________________________________ From: "Moe" Subject: Re: Commander-List: Voltage Regulators Bill, Thanx for the comments. I am very hesitant to get rid of my 100 amp generators just so I can run different voltage regulators. In the next few days I will call Gary Gadberry and see what he has to offer. Regards, Moe ----- Original Message ----- From: "W J R HAMILTON" Subject: RE: Commander-List: Voltage Regulators > > Moe, > My 500A is really original, 50 amp. generators, so old that brushes are > hard to come by, except where truck parts are sold, the actual origin of > the generator is an AC-Delco truck unit. > Despite the pre historic 618M-2 Collins VHF - 2 off, 51V-4A Collins ADF by > 2, one old Collins VOR/ILS 51R-8A/51V-5 , marker etc plus King > Transponder,DME and interphone, battery charge etc doesn't seem to have > ever been a problem. > Cheers, > Bill Hamilton > > > At 14:56 1/09/2005, you wrote: > > > >Moe, > >Gary Gadberry at Air Center owns the STC for the A/C units in Twin > >Commanders and part of the kit is 90 AMP Alternators to carry the extra > >load. I do not know if the alternator mod is an STC by its self. You may > >want to call them to see which regulator they use as part of the STC. > >Tylor Hall > > > > > >Subject: Re: Commander-List: Voltage Regulators > > > > > >Bill, > > > >How many amps are the generators on your 500A? Problem is, they advise that > >their voltage regulators will handle a maximum of 50 amps, whereas, my plane > >has 100 amp generators. > > > >Thanx! > > > >Moe > >N680RR > >----- Original Message ----- > >From: "W J R HAMILTON" > >To: > >Subject: Re: Commander-List: Voltage Regulators > > > > > > > > > > > > Folks, > > > I can testify to the Zeftronics, I have them in the 500A. > > > Neither the previous two owners, nor I have had a problem. > > > Cheers, > > > Bill Hamilton > > > > > > > > > At 07:23 30/08/2005, you wrote: > > > > > > > >A bazillion years ago (1997, to be exact) a company called Zeftronics > > > >developed and mounted in an Aero Commander, solid state voltage > >regulators > > > >to replace > > > >the Frankenstine units. > > > > > > > >I believe Dennis Polito installed some a few years ago in his AC-500-B. > > > > > > > >If you can't Google it, let me know and I'll try to find archive issues > >of > > > >the Flight Group News that featured these. > > > > > > > >Wing Commander Gordon > > > > > > > >PS: Is it pronounced "Frankenstine" or "Frankensteen?" > > > > > > > >Life is not simple anywhere. Probably less so elsewhere. > > > > > > > > > > > > > > > > > CONFIDENTIALITY & PRIVILEGE NOTICE > > > W.J.R.Hamilton,Glenalmond Group Companies,Fighter Flights Internet > >Services > > > and Warbirds.Net. & . > > > This message is intended for and should only be used by the addressee. It > > > is confidential and may contain legally privileged information.If you are > > > not the intended recipient any use distribution,disclosure or copying of > > > this message is strictly prohibited.Confidentiality and legal privilege > > > attached to this communication are not waived or lost by reason of the > > > mistaken delivery to you.If you have received this message in error, > >please > > > notify us immediately to Australia 61 (0)408 876 526 > > > Dolores capitis non fero. Eos do. > > > > > > > > > > > > > CONFIDENTIALITY & PRIVILEGE NOTICE > W.J.R.Hamilton,Glenalmond Group Companies,Fighter Flights Internet Services > and Warbirds.Net. & . > This message is intended for and should only be used by the addressee. It > is confidential and may contain legally privileged information.If you are > not the intended recipient any use distribution,disclosure or copying of > this message is strictly prohibited.Confidentiality and legal privilege > attached to this communication are not waived or lost by reason of the > mistaken delivery to you.If you have received this message in error, please > notify us immediately to Australia 61 (0)408 876 526 > Dolores capitis non fero. Eos do. > > ________________________________ Message 3 _____________________________________ From: todd(at)hindmarsh.us Subject: RE: Commander-List: Old Panels, my 680F panel The attachments don't go through on the list. > -------- Original Message -------- > Subject: [SPAM] Commander-List: Old Panels, my 680F panel > From: "jmenchetti(at)cantv.net" > Date: Mon, September 05, 2005 4:58 am > To: CloudCraft(at)aol.com, commander-list(at)matronics.com > > > Dear gentlemen, here are some pics of my 680f panel, before having a > facelift > > ________________________________ Message 4 _____________________________________ From: YOURTCFG(at)aol.com Subject: Re: Commander-List: Fly-in Reservations Hi Randy, Unfortunately, after 5 weeks of negotiation we were unable to secure a group rate that would be better than what you could get on your own (via phone call, travel site, travel agency). It was an unbelievable experience -- they wanted more for a group rate ($149+) than the standard "rack" rate (~$114) and would have required us to pay for any unused rooms. Understandably, we finally gave up and are letting members book their own. So would suggest you book through your favorite site (like travelocity), through a travel agent or see a list of hotels on the following link: _http://beachcalifornia.travelhero.com/index.cfm/id/139491/aid/68/city/MARINA/ index.html_ (http://beachcalifornia.travelhero.com/index.cfm/id/139491/aid/68/city/MARINA/index.html) . It will probably bring up Holiday Inn, but click on the Marina tab for a list of other hotels. Marina's rates are high for 2-3 star hotels. So, if you're looking for a better deal and don't mind a little commute (5-15 miles) better rates can be found in Seaside (~5 miles) or Salinas (~10-15 miles). Enterprise Rent-a-Car in Seaside will give our members a corporate rate. Call Laura Haaker or Sara Jacobsen at 831-372-4200 and let them know you are with the Twin Commander Flight Group (TCFG) and what time you will need your car and they will pick you up at the airport and shuttle you to their office to pick one up. Let me know if you need any additional information. We're looking forward to seeing everyone. Best Regards, Mrs. Jim Bob ________________________________ Message 5 _____________________________________ From: YOURTCFG(at)aol.com Subject: Commander-List: TCFG Newsletter Hi everyone, Hope you all enjoyed the long weekend and sent the summer out in style. The latest issue of the Flight Group News was mailed today and includes the following information: * Fly-In Information * How to get a Pressure Carb Manual * Using a Checklist * Safety Alert * Commanderland News * Great Article on Modernizing a Shrike Also, if you haven't gotten back to us with updates for the TCFG Directory (both personal information and vendor information), please do so ASAP as we will start printing around September 12th and won't be able to make changes after that. The Directory will be given out to TCFG Members at the Fly-In and mailed to the members not in attendance after the Fly-In. Also, at this year's Fly-In we will be offering members who bring their airplanes a free "walk around" tech inspection by a panel of experts (there will be a charge for non members). If you're not a member you can join at _www.aerocommander.com_ (http://www.aerocommander.com) or can contact us directly for a membership form. Capt Jim Bob ________________________________ Message 6 _____________________________________ From: "Barry Collman" Subject: Commander-List: Fly_in Hi Guys, Well, I'm booked into the Comfort Inn, on Reservation Road, Marina for the Fly-In. Anyone else booked in there? Really looking forward to seeing some new faces and meeting up with some old ones! Also looking forward to seeing some new paint jobs (one which was long overdue!!). Sincere Best Regards, Barry ________________________________ Message 7 _____________________________________ From: Matt Dralle Subject: Commander-List: Matronics Web Server Upgrade Today Tuesday 09/06/05 5pm PDT Dear Listers, I will be taking the Matronics Web Server down for a few hours today, Tuesday September 6 2005 for a chassis upgrade. Archive browsing and searching along with subscription services will be unavailable for be processed normally during the upgrade. Please check the Matronics System Status Page for updates (although this page resides on the web server and won't be available during the upgrade): http://www.matronics.com/SystemStatus/ Matt Dralle Matronics Email List Admin. Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________ Message 8 _____________________________________ From: John Towner Subject: Re: Commander-List: Fly_in *Barry,* We will try to book too at the Comfort Inn at Marina. We wish everyone could stay at the same place but hopefully all will workout. PS-Andrew has been working on buildfing a Commander simulator for us, attached is a picture from the prototype we thought you might enjoy. Are you going to bring N4007H? and we hope all is well with her. *YOUR FRIENDS, Andrew & John Towner* Barry Collman wrote: > >Hi Guys, > >Well, I'm booked into the Comfort Inn, on Reservation Road, Marina for the >Fly-In. > >Anyone else booked in there? > >Really looking forward to seeing some new faces and meeting up with some old >ones! > >Also looking forward to seeing some new paint jobs (one which was long >overdue!!). > >Sincere Best Regards, >Barry > > > > ________________________________ Message 9 _____________________________________ From: "Randy Dettmer, AIA" Subject: RE: Commander-List: Fly_in Kip and I are booked at the Comfort Inn too. Looking forward to seeing you guys Friday afternoon or evening. Randy D. -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com]On Behalf Of John Towner Subject: Re: Commander-List: Fly_in *Barry,* We will try to book too at the Comfort Inn at Marina. We wish everyone could stay at the same place but hopefully all will workout. PS-Andrew has been working on buildfing a Commander simulator for us, attached is a picture from the prototype we thought you might enjoy. Are you going to bring N4007H? and we hope all is well with her. *YOUR FRIENDS, Andrew & John Towner* Barry Collman wrote: > >Hi Guys, > >Well, I'm booked into the Comfort Inn, on Reservation Road, Marina for the >Fly-In. > >Anyone else booked in there? > >Really looking forward to seeing some new faces and meeting up with some old >ones! > >Also looking forward to seeing some new paint jobs (one which was long >overdue!!). > >Sincere Best Regards, >Barry > > ________________________________ Message 10 ____________________________________ From: "nico css" Subject: Commander-List: Website We are now manufacturing this www.nicsysco.com so if you have important data on your computer and fear you might lose it if your equipment fails, let me know. Even though the website is pitched to the business owner, data on one's home computer or laptop is equally important and expensive to replace. Thanks Nico PS. Sorry about this shameless plug. ________________________________ Message 11 ____________________________________ From: "Tommy Mathieu" Subject: Commander-List: Info on service bulletin & AD 7.50 BARRACUDA_HEADER_FP56 RBL: Blacklist bl.spamcop [Blocked - see ] I have an AD I need to take care of on a Shrike Commander I own. I just bought the plane a year ago and AD 940419 is due. It is an ultrasound on the wing spar. One is due yearly and another approximately every 36 months. Both are currently due. Can anyone give me any information on the most reasonable place to have this performed and its approximate cost? I would greatly appreciate any assistance you can provide. The airplane is based in North Louisiana. Sincerely, Tommy Mathieu, member ________________________________ Message 12 ____________________________________ From: Subject: RE: Commander-List: Aircraft Heaters I had the heater installed one month ago as they are in "my back yard". It has worked beautifully "as advertised". Thanks for the heads up and recommendation as the existing Janitrol unit had never worked correctly. Don -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Moe Subject: Commander-List: Aircraft Heaters Fellow Commander Drivers: You might want to add to your parts source list for heaters: C & D Associates 302 Post Road Buchanan, MI 49107 (Niles Michigan Airport 3TC) Phone 269.695.7469 FAX 269.695.6004 www.aircraftheater.com For less than the price of a stock overhaul, they will install a brand new C & D unit that has a TBO of 2,000 hours. For the pressurized models it works completely independent of the troublesome B/C environmental control. It also does not use the stock combustion air fan and its assorted paraphernalia. It comes with its own single knob off/ on temp control switch. They also rebuild stock heaters (but why?). I went back last week and had them install one, and although I have used it only a couple of hours I am very favorably impressed. Moe N680RR 680F(p) ________________________________________________________________________________
Subject: Re: Fly_in
Date: Sep 08, 2005
Hi John, Well, it looks as though there might be a few of us booked into the Comfort Inn, which will be good. I'm still getting things ready to take with me, but N5007H will not be making the trip! Wow! That simulator looks pretty neat. Andrew must have put a long time into that project and must be a very talented young man. Looking forward to seeing you both again, Best Regards, Barry ----- Original Message ----- From: "John Towner" <johntowner(at)centralairsouthwest.com> Subject: Re: Commander-List: Fly_in | | *Barry,* | | We will try to book too at the Comfort Inn at Marina. We wish everyone | could stay at the same place but hopefully all will workout. | | PS-Andrew has been working on building a Commander simulator for us, | attached is a picture from the prototype we thought you might enjoy. | Are you going to bring N4007H? and we hope all is well with her. | | *YOUR FRIENDS, | | Andrew & John Towner* | | Barry Collman wrote: | <barry.collman@air-britain.co.uk> | > | >Hi Guys, | > | >Well, I'm booked into the Comfort Inn, on Reservation Road, Marina for the | >Fly-In. | > | >Anyone else booked in there? | > | >Really looking forward to seeing some new faces and meeting up with some old | >ones! | > | >Also looking forward to seeing some new paint jobs (one which was long | >overdue!!). | > | >Sincere Best Regards, | >Barry | > | > | > | > | | | | | | | ________________________________________________________________________________
Subject: Re: Fly_in
Date: Sep 08, 2005
Yesterday I was in New Orleans helping with rescue efforts when I heard the familiar sound of a twin commander. Just wondering if it was any of you. The sun was in my eyes but it looked like it was red. Man what a mess this place is. Bert -----Original Message----- From: "Barry Collman" <barry.collman@air-britain.co.uk> Date: Thu, 8 Sep 2005 11:16:42 To: Subject: Re: Commander-List: Fly_in Hi John, Well, it looks as though there might be a few of us booked into the Comfort Inn, which will be good. I'm still getting things ready to take with me, but N5007H will not be making the trip! Wow! That simulator looks pretty neat. Andrew must have put a long time into that project and must be a very talented young man. Looking forward to seeing you both again, Best Regards, Barry ----- Original Message ----- From: "John Towner" <johntowner(at)centralairsouthwest.com> Subject: Re: Commander-List: Fly_in | | *Barry,* | | We will try to book too at the Comfort Inn at Marina. We wish everyone | could stay at the same place but hopefully all will workout. | | PS-Andrew has been working on building a Commander simulator for us, | attached is a picture from the prototype we thought you might enjoy. | Are you going to bring N4007H? and we hope all is well with her. | | *YOUR FRIENDS, | | Andrew & John Towner* | | Barry Collman wrote: | <barry.collman@air-britain.co.uk> | > | >Hi Guys, | > | >Well, I'm booked into the Comfort Inn, on Reservation Road, Marina for the | >Fly-In. | > | >Anyone else booked in there? | > | >Really looking forward to seeing some new faces and meeting up with some old | >ones! | > | >Also looking forward to seeing some new paint jobs (one which was long | >overdue!!). | > | >Sincere Best Regards, | >Barry | > | > | > | > | | | | | | | bertberry1(at)aol.com ________________________________________________________________________________
Subject: Hurricane Katrina
Date: Sep 08, 2005
Hi All, Bert's posting just now has prompted me to do something I should have done last week and that is to see whether any of our members were caught up in the hurricane. If so, I trust they are all OK. Is there anyone we 'should' have heard from in that area? Perhaps a 'usual' poster of messages who hasn't been heard from? Best Regards, Barry C (UK) ________________________________________________________________________________
Date: Sep 08, 2005
Subject: Re: Hurricane Katrina
Hi, Barry I'm writing this with genset running...aircraft are safe, area is not....the 560A, 2774B??, I believe, the one with the rumored mismatched engines, was on the ramp at Picayune, Ms, and was blown sideway's and collapsed the left and nose gear. I flew her about 6 weeks ago and she was a good one. I made the lady a fair offer and she turned it down. I believe it has no insurance. A sad waste of a good commander. Don't know detailed damage. Steve and I were in the bonanza on a fly over of our hurricane area. Cheers, Rob, Slidell, La. ________________________________________________________________________________
Date: Sep 08, 2005
Hi Rob, Glad you're OK. Yes, it's always sad to see the demise of a good Commander. N2774B was a 560A (s/n 274), converted to a 560A(HC) in September 1967. This was indeed the Commander with mismatched engines. GO-480-D1A one side and GO-480-G1B6 the other side. I saw it at Arlington, Washington about 3 years ago. Best Regards, Barry ----- Original Message ----- From: <RRamm52(at)cs.com> Subject: Re: Commander-List: Hurricane Katrina | | Hi, Barry | I'm writing this with genset running...aircraft are safe, area is not....the | 560A, 2774B??, I believe, the one with the rumored mismatched engines, was on | the ramp at Picayune, Ms, and was blown sideway's and collapsed the left and | nose gear. I flew her about 6 weeks ago and she was a good one. I made the lady | a fair offer and she turned it down. I believe it has no insurance. A sad | waste of a good commander. | Don't know detailed damage. Steve and I were in the bonanza on a fly over of | our hurricane area. Cheers, | Rob, Slidell, La. | | | | | | | ________________________________________________________________________________
Date: Sep 08, 2005
Subject: Fwd: Status Report from Milt Concannon
For those of you who know Dr. Milt Concannon (most recently of AC-685 N414C), here is his status. Wing Commander Gordon Life is not simple anywhere. Probably less so elsewhere. From: "Milt" <rocket(at)swmrmc.org> Subject: Re: Status Report Date: Thu, 8 Sep 2005 12:25:05 -0500 RPD=4.00.0003; RPDID=303030312E30413039303230352E34333230374236372E303031352D422D4D3936762F49374B305A4157444C546645354F3975413D3D; ENG=IBF; TS=20050908180117; CAT=NONE; CON=NONE; Airplane family and house are OK. Lost my hangar, barns, many trees and condo on the coast (sat photo attached ) is toast. We are lucky compared to most. ----- Original Message ----- From: CloudCraft(at)aol.com To: N395V(at)direcway.com Sent: Thursday, September 08, 2005 11:33 AM Subject: Status Report Dr. Milt, Are you / your airplane OK down there? Wing Commander Gordon Life is not simple anywhere. Probably less so elsewhere. Airplane family and house are OK. Lost my hangar, barns, many trees and condo on the coast (sat photo attached ) is toast. We are lucky compared to most. ----- Original Message ----- From: CloudCraft(at)aol.com To: N395V(at)direcway.com Sent: Thursday, September 08, 2005=2011:33 AM Subject: Status Report Dr. Milt, Are you / your airplane OK down there? Wing Commander Gordon Life is not simple anywhere. Probably less so elsewhere. name=condo.JPG filename=condo.JPG /9j/4AAQSkZJRgABAQEAYABgAAD/2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsLDBkSEw8UHRof Hh0aHBwgJC4nICIsIxwcKDcpLDAxNDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwLDBgNDRgyIRwh MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjL/wAAR CAMABAADASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAA AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkK FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWG h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl 5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREA AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYk NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOE hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk 5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwDIFL69aO2KPStBBx6UdulJ1JI6U4UgVxPa uk0u1HkwMyngEkVl6bYm6nUsP3YOa65IIVtI3Vv33mbfL7BfWpltY0ih6blliVACWPOewqa/ OCiZ5x1ptmv+kSOTlNuAfQ1DcyiebKn5RWbVjQYFHAABpGHy7fenZ5/Cm9Sp96Bj9uMVXkYN LtB5HWrEreWhz1IrIQTfa/M2kqM5x3oSuJmmozxQ/wB7YPTqKgifau5iQT0zUhlCIS+MmlYL oUMVIH9KUk59aoR3kcl2Yhnjq1aC89O1Jqw0xBGTJknr7VKkIJ57Gmsx3D+dO3kGkxllUXOB wuc1oIE+z5PU8DFZsb4Tcan+1eXETjPSjqDNKF/3QAzgDAzVWeGO6JRz1BOfpTpZ1jtty5PA rE1i/lsrMSwlSxGM+maduwisvkNLcNjKRn88Vz13qISRJoECMr5TjpWrpSMdIvGkO53JOT3r n54z5Y44B71S3Ey1PqcmqXccsqoGHB2DFPu1wCAODzVHTog86qT7mrNzcebkAYCnFEkJMy70 j5AKqA/OD3GOanuCJJhzjFVjwT9a6IbGMnqb+m/Ner5hzxkEfStG7bOjTgdcn+dZ2mI/2pGI 5EfT2q7MSdMnGO+aze5a2MPzppbQW7SE26HciE/Lu/xpLiZ0th8nzY5z2qA71iDD7uQPxq8o EqDeeCMVbEjQ8IaZ4cu9PvrzW7oCSJG2wliCB6r6muQkKGeTywREHPl5OTtzxn8K0ZbYRWjx k9W3YHHFZucda1jsZSVmKDzT0wWUMSFFR/pRk1ZKJ2kLttLHYOKkVAUOw/KtVWfjgUu+RoxG Dx+tTyj5i3E6BNq4PvUcm4HgEA9zSxwrHblvPCuThkxSCZ2jkjCh2HFZ21KvZFaaTewHXbxm kqaC0Z5Nh4wM81NKkezG3nsRWnMlsRZsqY55oGQ3tUv2dkXc1NAOQKpNCcWKzEALg89qmtYA Y3dpPLQD72M7j6CnhFjJLkEFfm9vpUUbB3Cvnyl+6o7+9F0NJpiB2IzjHbAqWNd64xzSnB2x ouOeaJUaBty8g+lRzFWVx32fC4J571E8YQEMPl65qRLwEgEUs0gZCMjpUpyvYbsUw6v8uKtC 1lFkbhSPL6Y75qiMhv61c+074hGQQg64rSVyI2C1EjA4YD1NbMEUfkExSbWI+UnrIe49sVRh RUHyjjuKjlxETInBz69KylqaJ2Hi3PnOXPTsKZNOPMA2qAgAAFNe787Lou0gYOD1quI5HcOw IB9RRa4XRYYKuSpyAOOKVHCxA7gfXimqr3OI48BfX1qwwNr5TpGuF7sM5P0p+QeYiLMuwmJh G43K56MPanM7MCFzmomup5Z2mfDZOSqcAfSlklEmFA56YzSdr3HFsnMh+XkZB6U2R/Mww5kJ 5GOMVGqGEEsvze5p6MsuS/ykdxUuN9irhIQIchsH0pivuRfMIA9qY0m3djBXNQhi464HpTsK 6JSzeaN4xGaVZEDlnyW6AGmhWkU4O3HVj39qkUiOMtjJI4GOlADSxKEj5j0wPSoBD0ZuAx/G pFkBVCQNwPWpFVndnfp14qtibXFEMJIckbxUgKKrycZ6LxVSQMBuGeemKY8khCJLHn0ApNXH oi8IQIWkKhy3U56Go2QIGIHJHHvT4ljCcKyyn+LOR9MUyZ8rsyNw/lSuFiFG2Es4A7ClWNhJ lzyeR+NRffkVI9xqUsytsbqvXNVZi0Q4x/MenHeoyPnxuxnrUrSDywem7saImJDHbzjHI7Ui iLZ8hySc1HKDn5BwOtXPMzCoGOOKVoBjcOp60XE4lFmbAOBitbwwCfFmjEt/y/Qf+hiqT2+0 jbkitPw2pPizSOmPt0HH/AxTclYSTR9HUUUVgMKKKKACiiigAooooAKKKKACiiigAooooAKK KKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiig AooooAKKKKACiiigD5qoo6mlArQBAOamihZmCjnNEKFmAxW7Y2IK7mHPaoc0mXGOhY0+DyIR xg1oAlU3DrUKrtXb6VWlF211uaQLarjgdSal6lxNTesNqw5BcZBHcmoIwVhAbqB19aRUmlup Gf7iDAA6UTOEAAHPQUnuFxIZPMViPXGakj+Z8DtSQosYA7dTSB9m4jueKXoMhvJWe4WNOexq aKMpGFOAaQIqneR8xp5K4OTzRcEQTQK4wOPxqBrZ94G75cc1FcJI9zuy2UHGOlFpqPmSus42 le9FmBbitYoRvC4Y96cxZWYZx3+tQy6jG0LeS29+gAqrpsl087+eMq3r2pLzHsaAk3t0IAqV WywNRcggGlAw3WkwLYIPCnvzRPcFEESKWPUkVX8zacA8mljcCRmJP5Uhkq3TvFt2kZ4O6qt9 EJIAv3sc1aeWMHO7PtVWWfBYn7o5xTv2ERW7iO1ki2gF1IHtXN3SFU25robaVLqQMB8pyKxL 1cMwHQHimnqJlbT8i8Cj86hkBieRSc5JPFLay7LnI6nNMuZA8zMo4xitepmZ7EmU/SmYz/n3 qRwQ59aaGCqe5P8AjWvQzW502lg+a59IRTpf+PeZexzRpvDSt/0zA/Sh1IQjruyRWMTaXYwt mbbB6CTNTwgbFwc80yVD9lOP+ehFPtIyuW9+lX0JtZjbuzkuMvECWXhlrFkQo5QjGO1dbA8k ccm3ALggkiudlsZhcOCpOOdx9KqErEyiUSSefSm7qnSAyzCMED1J6USWskZwRn6VtdGTTIKX IXkHmgjtR5ZJAp6E6jGd8nnrV62gYL5m/wC9jpUBhw453DuK0BJFFGvqRwB2qJ7aFJdWMmQx t5iHpx9aiM23dkDHvT5JCGAxk9RUFwSzqdnIPOKzitdSmNaUtHk5x2qKORgeDV+ILMpcoRt+ 6OxpIbSGcsSpWUHkVakhcrexWZmk3Z7UKfk2fjnvVie3EAwh6+tV1HB4zjqapNCaaJYA0s6Z P0omdvMZB90cc02IssoKJgjtUgQs24x8ucDJ703ZMOmhCiknNWFgJOSetOW3LEkkKV6jNNLr vCoc96lu+wJW3IpISM9MVNbskSkFfmPIyKjUmRiGySO1T+WB85G3aOaTk2NR1uWi6tbeawxM eMdsVVciRVDcUgmLPg9O1NllBAk2Yk+7moUWW2mg8lIjgZ5qfLSRpE+QiHdimQ524Zfp7VNt J6kZ602xpIAuxjIhznoOmKkmkF1EAwC+XUREhyzLgdAcVWk4VioYN3qVrsD0E8wlgqAYqVUJ G5RyKpEs0hwM4q48hgiQKmD061bRKI5zLI6kqVH8RoE4HbHvVsgtDknOR0xVCTCkgjHpSi7j Y9Tln8sg55P1pF++Qpw/vUSs2zecYzjAqRYyzBlbDe9U0K6JjJsUo3zH+dOhVpV29H6gUbwv ylQzU15THzjBNQVdDZIZRJjbx7VMjbBjBLenpSrdt5e1lDA9KiMiq2DkA09WFrE6vGcAjJ9u lEiqSXAAYdar9HyOhpFZlJZzx0pNMQ7cqpuyfrVN2dnYquVP51P/AK0gEYjB4NThI1bgbmP5 U1oDVxkShl3KCrJTyyru3jLkd6cw8vBk+QHoq96Ei3EySD5uwpOQJENuBuweSOuasMpK5Xlj xikXBUsQAQcYoZyCcDJ7Cle+wysiSrcAPGwHfI4q0ZUYsobgdhTBds0RR8nk8eh9ahwm3Ckl u59aNXuCZOJhI+3r6Yq/4aYHxbpGP+f6H/0MVik+X838VaXhI/8AFWaQGP8Ay/Q/+hiq5VYT bZ9LUUUViAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRR QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAHzUfXsKUHJFB GabyDWgGhajGDgZJrorbiEVzFrIFkGeldHYybotuc1jJam0XoWx0pCudq7QVJ+angCp7eJ5J xj7o9qAGB5TEYwwUDrx1FQMEeTI6L0q1cr5ty65A2jGBVcrs4WiWoJWFDAkgHpTIslyTjaKF G0kjrR5m1goXk9aQyY4Y+9U7jKz9etTscKSDzUEPz+bJ1wcDNCTQMHyFL+oxVGS0CR5z871q xxqRz0FNeLLhmGdvApXY7FTTbMW6MWAyTkGr/bjH5Uu0Lx/KmthFzQ9Q2EJGelRu2CQOTT8Z HJx7UAd8UgGBcAE8sf0qVRtXnmmfxVKqnHTB7e9AxFCMC2OKqTL+5kCnORirLj5CM855qCZG W3Y7geDQlbcTINERRtG7lGO4VlagMTSDrgmtbQOVkOASc1laiMTy/U0vtA9jKtxzI/daiYfM ffpUlmrNJKc8elNkyryZH3eldVjAqNwSfwNRD/P51ZEe87e5qIphiPQ4/WqT6CtqdPYkJAxP GVFKXDYX+6B/OmAbbcc9VFRFivPrWSRpLcz7k+XCfTzTUdrIxzzUt6pEK8E/vKgtQQSQM96a 1QupoxSlGGeM1KNszhPXO7/aFVAc4PXJ4qzHGxfftKgDr61LLIriwtY3BUZbHQfw+1U1V4Jf MRwuM1oysuADnJ6moruzdYg0ZyTTi+5MkYUytPdO+M5PJHrUjxLBgvyCOtTGN442Rz8+emKS QK21TyOta8xlYggMYmyQQCc7j0qtc3DGfcmMD2qe6KhCFPOegqiAf4+BVxV3dkN6DzM7sDnj vUyuEOTyo9ar8E9eBV8QRzQ9cAVUrISI/t2QFVQFHSpLaQI7M5JZhxVYxJC5I5x61NCBJEZN +xs9KlxRSlYlAeUlnHy0nmIXCBcoo5x/Wo/OK5B+YnuKQbowCp4cc0knYbZMi7HJcYJHFQys zDapI2ng1Klx2YZ7ZNNCkPtboSTTV76gNJ3QjrycE0ip5PzPnHahSrOUT5RnqafgyAoD83r2 qnJE2FtrhFYk9SeKfLOshZQNwHXHeoooBG+584Bzz3q29xDJkxw4OAOBis5b3KiQGM7Ny9B3 FMKqYldXDNnBXHSp5NwhJHGR0NUcFIw4JHtTixtFiISMOPx5qZGZ1ZCcEd6qKxkX5M4FOAkU txg4GeaTSBNl/wC0MYljL/KvTjvUfG8rvBJ61WLbYxllxmlYxhfMRsEClYGydo41bKnBzmmS FpJyyqCevtUcD+eV+bD5q00bwuQwwcUnoCQwSzEldhx7Uzy1lGG65prSMJMA05ZSRnbgetCH uI8ARx8hwelOMQXknk8YHarCt8oAIGe5qF92GDDPOQaV2VZCJF5L7mOVI4prmMqcdfWmjMhG 44A7UgPlEqDnPrVWENiRjImTxmrBQG4dXOABkVEhKknv70yVzu3BuvBo3DYfKQRgcDOeajfe +DsOymARvIo3k461ejeONmDHCgdaewkQxkJJgx5OOBUmepAwwpEUTrJ86oeo45NQtGzDBYgA 8kdzSYDo3BlIkOXxnB6Cp0lyxDdqptyfl6+tOVSE34yFPJoauCdi35ivwDjFIqKzbi3WqrS4 2sBgN1FSRvhMkjr0pOLBMsOFXhcZHWgRqwJ+XpUaHezbjhakYLtwOpPGKnXqMrtHjrgjsa0f CsRXxfpbdhewDH/AxVJk2ck9+/StPw5IreKtIVP+f2DJ/wCBrV30Bn0XRRRWIgooooAKKKKA CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAPm8kMoGMUwxkMaaCelSiQuoU4yO9WwQ1 MrznpW1pUrEj8qyVTf0GBmt7SIAvOPzqJFx0NZRzWjZIVjL/AFrMnEhhZYSFkI4LDIFX7aZ1 tCrrmUDnb0+tSXYoyM32l2z14pW5AApGH6nijoKVxkMhZVO3rSW6s3L/AHqlC7jk07ABAFK4 DHXedufbineSFj8tegpyjkmk5JNAxygKgHOaVuwz+lNLhRj+KmiYFCw5KiiwXJCQRxWZql39 ktiR99uFq4bhPK+X7xrNvbbzmUOw9eaIpoUnczdOu5heK87M+7gnsK6QnniqNtZxcYAI7mrp HPTpRLUFoGfmqRS5+Rfu9zTRjOSOnanbiRkcCkUSRxx5xnJ6mqlywCv2yCOasW64LOAT65qt ODlio5xnH400Sw0a3e2dg45wDx2yayNXieO4m3Y55xXTW07TuZWRVOQDjv71h68B9ofjkrS6 g9jmbWVUklB/i6U+9wkjgHqoNV1IEpz61LcOZXLkcEYrezbuYjEPzKfQ4rVj06NgGx97msmM gAjqc13mkosumwOQucYPHtUzdikrmDP8seBxgAVXfsPpVzU+JSBxlqqzxmOQA9wDTjsNlXUS UjRccF6q28nlZAIBPermqrmKHB5zVIW1wZCojbcFDH6Uo7A1qXo5gCq5B789qtQyKVIYcfWq duWNvlo8jON57VZhRWI3Pwehp2uO+pJ9kWXBU7WJ79KtEKFAJBXoKhkYwfKiEs36VXminaPz EUlfY9qVmNFbVBHDIrqAPr3NYVzcNLMX+6R2FaVzBJM8aKHcHpk9DVC6t/sz+RcRuko5yTw3 0raFjKZBGyBi0nPsOuaich5C3NGCQcDNNyQBWqRi30FEZcgZwDTvOfG0ngcYpgJ7U3PJJ9ap JdSdh6hmJyaeuUI4+XvSRqSTml2MT8p/Ch2BEkhEnKjAHpTopAmN3TtSRhscDPPSpmiSVlwy hjwR6VL0LSvqNzuxx+NOZyrjJ4A4q5Y20MV6qSlZIt4DA/xDp+lLrOlyaRqTW0mCCN0bA8Mj dDUc6vZl2drlKGNTIxJ5HSrKhPuqMP1NKbKWGeNZQQxGSh4I+tWXhVVB2jJ96mUk9hqJnThi 42/ePUUxVaORJM7lXqB3rSlghSIHdvlbpj+CqckbN5ixnkDJoTvoDWoI4uN2/gA9BRKqmDkA gdKbafOWHTHJqScK53IDkHpRfWwbleCPy4wx5Rj0p0hLEIg27jzmn8p95ME84zxVi2ihdZJZ lfGRsI6GnJ63GlYpyJEY+Cd68c96r7VZsA4J6g1YmQvcOqjKDp9KRYlljJGAV707kWEhiCsT yPTHrV1srGWY5OOtVxKUtxC3QHd05oSYyKc8AdvSoeruUtBXIeJACBzk564pk0f7oypIHUHG PSm7jISAPu96bvEcoYrlRzjPeqSE2SJIcg9c1bUKY8N8p/PJqk83nSGRAMknIHSpYWBGS27s B6UmikxSDnjA9aaxRPmxkgU+S1JBdmyw6KKRBGXw3XoaOgiMB5E8xuB6UxkAjyc1a65+YADt TSEwCMnNCYyBEAXco564pzRFlEjcn+VSGMxtlcFTUshZvlwBxRcncqRkzcbsH19asIOfn5A4 AFVjb4fcrYx2qdSB0NDY46Ep2k42j6UwpgNGMgEcjFNbcrl+xHSpUlUsT3xjmp1HoUT8hGRl c1Myx7QyjJPOAaRs7yD0znpTC4RlPbvV6kEZkO47SQAatpKNuQuT61RkGJGYdGHFWLeZViwe tEkCkSyM8vy8AVo+F1EfizSB1zew8/8AAxWaZdynHIq/4akkXxdoylRzfQf+hrSs7FOx9J0U UViAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUU AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAHzT0FOQHPSl2EgYxT1 QhwKtjSLtmhlcAjgV0lvEsUYAGKxNNTEorfXpWT3NUh+fSpLdysh55IwRUO4IpJ6AVFZMd80 rcKTuXPpSGOlJVvoacaRgHiyTyeaSL7u0nn1pAOB6n0FInLZNMO5Xb+7SSSYYAU7CuTE/KcU 1Txmo2kCKCx4pjTgKWxweAKVihtzw29W6dazhcXKTs4X90TjHtWlDASpL5O+pzEojKgDA9qq 4rFeOMzMsmAE6ipZYg4DADr3pwx9lDYOQegqjdavBbyCMklj1A7VOrDYvIu1SowBntSHrxzT YbiOeESxtlcYxThnqeBU6ooAGJyOtSmNggwRk80i8dKeu5s8UwHxx7FyTyecVWn4Z8fexmpp WUOGz0HaoJpVZ9w/u80kDJ7LBtS/qeKzPEcJAEoAzjHWtDTG32CccZbB/GoPECK1izscEcD3 p294W6ODX/WHI5NPclVwaanMo+tPuP8AWn8K6kc41OpruvDz79LALdCa4q2ETTDziVj5yR+l dj4eGywbJ4Oce9ZTNIGXqefPx71VuHMkinpgAVc1Lm5qjL95acNUKWjNiztIrnTJGkA3CT5S e1OtIZGk2PEGH3TITxgU/Tz/AMSlh6yU9WIGOR9KwnKzaOmnS5tS46Wr2JtFVVAPDFe9U7PT vK1CIXWwW7HaJOx9qUvhRimTQm48rDEBH3496UJvYupQW6L3iTT7CFYTp+37Qx5Ct/CelUf7 LltI2+1sU3Lny/5Gtmy8tJElRF3w8AsPz+tWtYuUv9NKNEBICPm/GtIyd7HM0eeXVhqUTtPc Qskbj922eCOxqK4Dm1SyuXVgDu3EfMPxrvNatraXQpFFyW+UERkjI9hXKDToZIY9r/KP9Yp6 j61opX1IatuYs1nHv2REYXn61UuLRoWYttyO1b50yKCWMh0Jkb5T1BXtTLnTWhmkiJSRY/41 Od2a1u0iOXWxgL9kVwslt5gPXaefwq1CNIQTktLHIy4QuN2z2rQeJLeBQgRSjZyRndVA28c8 hZyFdjk4ocu4OKMvyjGCQ/HYe1AbKqF6561qDSbi5Z++BwT6VJa6Ssb7nbdjnGOtUpqxPI72 M97SRIkk3hhIm4H+6R2qyLRVCMxyW9O1azQ/uEd/9XG29QO49KryuZZpPlAjC5Ws3K6LUOUp IsTOUlzg5w4PTmrl+kAgXEjTSjGJi3G3+6RUJhVIBvBMhJOO2KptMqDYCSDStzO5Wy1L8Mxu JN8zN5yjajDoR6GpJbWaSKR4gzRov7wqeFz0rMglImREY4PrWnunjDRKW2lQWGfvUNWZO60K crRxJJEJN78HcOlNGYQxznI60SrskOf4uoxyKheRiXTd8o6GrUeqF6jd6eZ5iD5j1Ap6Sqsj qV6802TCbNi9h2o5aZTtxmi2gkTKI5ZSqDGBzk1J5iqqxenQVGihXd24OMVCpYS8ckilZjuS Twh1LE7SB2PWo4AqQjCk5PWpuertwRUHmKjkRrkf1p2AGdNgBHzdTVVWcOyZ6ntVpkdHPyA7 hyfemLboZZN7YJAIqoksQEKSoGabIjNx0HenShI2GzOfemGdsAA8k8007iLFrbvIrCLGSMj6 UIpRyT9Pxp6EpCdrFWZeCKkbaQgDdOG9ai5a2JN5eFwo5AqvHErKMnr1NSLIqAqj9O570I+5 yCMY6UiiHJSVjjgAD61KDvlRVwoPBqXAkTBABPemAbWUlSMcZzQIklsxEUzOGzknjpVN5BGA 0jYPTb61dmczRbF+Vgc5qituxmJm+bJoQWsOVC3IBAPIFOBWMjf1PSpgcZVcZxionjzEWyM9 1NPcWw2RjjA69ai3HbknFJ8wCkfcHFQSSKfkJwv61SRLZM1x8nbHrTPN3rgLUaKCCCR7CpoI nV+cEAU3oJajZEwq4O71HpSKFVCDkEcipZJFJIC896rvJmQcdBSSYMnjV2cKhGDxk9M10Ph2 xuLbxRpHnRn/AI/IPn7ffFc3DK24qq8k8V1fhTWLqTXNMtpSro15AvI5GHFTK5UUup9AUUUV iMKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAC iiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigD5wUqW3DjipQCcH9aq/d IHephIQAuO9UykzT03ImGeldAK5yycGdSDxmuhU+nSszXoPbhTgVBGGFvON3J6fTNTHoaiRM xTHBAC00K4spKwoByelPixjpzTSwYL0xilDbXx6ipaGDtuJH51DKpEobtUgcPuA702TLcY5p klOaQs454HarNvHvPmSY29hUZt986+gHNWwvQDoKL2Q0h4wDjilbpim4702Q/KNp/OoKILib 7OpVeSc8VgfYZJ5GfaSSeprcWPzrgx7s4GTmrCwgHGBjFO9ibXKGnW0trGQT8h7Gr5I45pSB jGaaoGCcUr3KsOU5GeakUqRz/OoRkg4qeJMgA0DFHdR933FU7nbCrkDPBrSdCEI9uKzpVzlD znrQgZLpjH+z4WJI6/LjpUWrvHPayRs+Ci5xVy1UJZooHeqeuFIdNlO0b3+XPrQ/iF0OGt/m uEz0Jqe+jCXLAdBwKjtRtuQRyVPFWLs73ZyMEnmuroc5XjGfzrtdCQjTQSOma5GKMfaVUdDi u20oFbFsEABqxm9DSJhX7Zuc1Sl++Kt324zfU1BcR7LhVz1GaqDVhS1NfTwP7HLf9NDUlJY4 /sjaB/y0NSxQvICwAC92J4rnqK8mdtCSUNSPvVqyj8y46DA55NReXASVF3Fu9O351ftLcRxF jtPuDxSjEdSouWyL4VcD5Cp9hUEhXcQR17VIrgSEKcmoS/74kgVpFanK9gk02C4YPIufxqhe abBNefZFXyxIC+5T1b0rWWcYxil4LBkA8wdG9KrVEmIYzolg1vA4kmLdCmWQdzn0rEtre5+3 KsEYZichWOVHuTXauoJaRkLs3ByKxbi2KXp+yRsQzAyAnAFNNhfQx9Q02Z4zdTRDzNx4Xpjs azbW0inSRZEzMTlCD0PpXXXMt1ChjS2WXPLxA8fWsSOze+1UtCEiEgGV7D8auMm3qS2jJaW5 sgqSxkFMhie9RJNLtDl+M5OP5Cui1bSLiCURTxqitkxHOd4x1rA1CzS2n2xElsbjg5HNKLUn Yp7ajnvhMMkDJPAB4qOWKWS3kdTkp99B296z94EgB+XFTrcbm2hz6NjuKpwdyL3GQu2UBctu OOe1W5Io1jljAGyTGcjp9KryxEFPLxtHWp7dXLRs4yM4we9GwIrRxQAFolwwPJJq400cVqrq rmQnG7NOuoCkrsmB0JB4xUJhDMyjLAHIz60LXViemxXZzIpbYTJnjPb3p0JjNz/pWW3Dhlp+ DDF5ZTEgPOe1VmEsjLxt2VT8hDLmRI5jjO3tmpYopTCJArHB5p0kBuIsAbm29APSkd38hdhL Y4PamtrIPUGjZojKfufrSKQGJI56CrkMBnWGOOQFj8pSqssEiyBACDnByKQ7AAJYpAWIYHoB 1pqRrGeTljVlIxHIVZguVyaqknzWJ6LU6jcRxjBUsMn0qttPmNuyCB3qwkgMhU546U5Yt7bm 4NUtNxWuZhaTIxyQauho1QSOoWTHQipDbxb3Y5JHINVrlWlclWzx6VVyUrCSXBOQvbpT4S+4 sy8HvTI0PzBxkjrVvy91uAvGT1NOVkNJtkRURruOA39KRWj3Hkn3FWJLQxwLJJgrnHXmomtg swIGR3IqU0waaZYjmVfSnmaM8ggn0qowxJt7U0KFLc4xU2HcsNOiy5I6Co/PEhLHIHYYqNkB 5JLUxiV6DirtcLkmShLk5IGQKikuSG5x71G7vnI9BSmMbVZuS55FFiW+g8zpJgcBabJHFyQD mnNDGGAjBAPJNIIIjLh5evbFNNITK44cDvVpXAXgFqR7VUAbcuzPyn1qURHyx8wJ64ockwSZ VUkuxxg5qY2yyNuPApSygYJGaQNIQFUfLRcEhYowjljgY6DvWr4WGPFWkkjapvocfXeKzsAB Sq5c/erQ8MuH8W6QGG3F9Dgf9tBUNlWPpCiiisgCiiigAooooAKKKKACiiigAooooAKKKKAC iiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooo oAKKKKACiiigAooooA+aQcdetOG7PvSYx0605Qc5J5rQC7YZEqnPGa6eI5QEelcjDIUIzwK6 LT5xLHjOcVk1qbJ6Gh1pQpMUuwc4xn0pueM1PaqG3knGRzQhFQbg2CQcDrTwvzBz6UrY3Gkc jZ8x6Utx3GRnAOQOvBp8a5JJqPqFA+7UkWe3SgEO4QZxye1Kp47VDOHc4zhR3qBpyg2p3796 VrjvYuBhvINNeLcQ5b5QOlZUQuBc+Z5hIJ6Vr/eAz6cilYYkChIztPXqe9IDIwfoMnipflC4 FNBwMcYpXGiJsntiheOKceSSRTc80AKFOang681DnAzTHuAg4IHvQgL1zJiMN3HasaSc/M5I GKivdWWHKEln9KwLvUDO6lwVUdQp61UUJs7qF1FpESRxzWH4inDQW6KfvScj8Kv6RKDpURPz EevcVja64a5tUH94mpSvITdkYtov75j71NdDIf6imWwILfU0+4BwxHfFdDMhbYbr1PbH8q7f SgPsB75Y1xVoQt2rMflPH413Gm5WyYbh6/pWU9ionL3Z/wBI9txqCeTzZkbpniprw4nOTzmq z/fFaRQmb1pLFBpUbTtiMynC+prPvL2W6lGWKRAcIOlV7tmVLdRyp5xmrOn2tnLLMt9eG3RE LRsvJZvSoa1uXFuw2J0Ckleg7GrOmavJHM0WT5RODntWZaw3EttcSpGZD91cHpz6V0+jaHp1 xYz3V2zJIgPBOCCPUUnyoNWywtxDNNOscg3RgHJHUU5WD8rzmqtvAFgWU4LPwCOw7ZqRvTqf aqSS2Ey2uQcEU9WwSc8VRjndByOPT1FX7cG5VzEoZo/vKG5H4UCCN9meSQeeacSuDtGCfaoG dSe4I9aC/HWkArqTbfPgqzfP2Iqv9jTyzKAx4yAOKmZSY8g8elPadY7Ys6Haq8YNFxpK5niE TP58qEsFwmW+7ioDb2l3apIuIbhCQpYZB9c/41Ytr6GV2YjazDG01DeTW8EDSbCxkOAB2pWG 9NGcpfeHmGqiJJ4kR135zkAntmnP4d1HS40uZYfOt2ziROfr+FdF5Eclq0skAcheFz0NaUWo O+l7ZVYt5WFH8NWptIjl1ujhXaKRFWD7o5ZyOTntVxEjNiscWFkXnFdTpug2WtWnmzSBZYy2 QgwSfcViXekT2cFw5YGBGwXX+tTzp6FJMyIS08rxTSBT6Y7+9MvCbV4w4U57qeKajJ9oDBNo A+Yk43GoL0ZYZ5zyOatLWxNy27qr7wMIwBOeearShRIWBxz3pjTFNhB3FhjFDFnIULlz270x C+bJDLviYBwMhuwpEd5F3yAfMSxwO5qPfu2rkZAIxU8kkkgDYCr0J9KHcVhsUnkXKSxtypHP pV8QJPcxSzk7XbDHOPfNUBDtidWG4seGFXsQjTmUFmkVeoPQ0pFR03Kc7MhLbsFiRt68DpVQ uWf5sgEelPyTOw6K44J7UwR53EgnBq0RJstIUZc8Hj0pjTBeo56D3qBZkVdoXPNOUqrFzyx6 A9qLdyuYURO7+Y2cZ5X2p5RSdyjGKT7SywsgXDHkmoIbhdrbxkDvRZvULrYsLGP9a5wrEjHe poGwSoAOTkVSDG4I8vIReTT4v3LEbySTjHrQ1oEXYv6kQoVR/cHH4VWg2sCrttwM88UO0iAx O37pvug8tUKkkkhsMOuelCjoDldkjRkkMCOncURFlcFhkd88CoSV+8dxb+VM84seCTmmSW5v sygiIPtJ4JNVWU5OOgp6qxHzcj0pylOQetIdiER4jKYzmneWQBhc7e9PPDZBGKUZJBB/D1p3 FYaEfbtXHPemEqh8sna2OvrUryHqBgg8ioZHPmD0+lCVwdg+YKoIyAeKesb7SJCR6KOppio7 N+7kxznApxlaNgJBjnj1o9BAIOjZCjpgd6FMaOVAPtk09n3BQOo5oOw24GPn3Hmi4JDA7nIw AorU8NR/8VVo7gZ/06HOf98VnIkSAtJJyf4Vq94bnUeL9GRQcG+hHP8Avikxn0lRRRWQBRRR QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAF FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAfNYBzShsZHX1pPxozgZx7VoA8 sOAvIrW0gnzMDOKxx96tjSDtn/ColsXE3x04qezClZAxIznFQr0qWFfMhnGcOoyuKlbFELgD KqcgcZpjZSJjjNCncq06UFlKipuOxHGpf2zzipgNgxQsRjcZ9KU8tntRcaQyT7h9B1qmiEuZ CMqOBVmdmYiNe55NPVRwBjCjB+tCdgsRCPaRxU3Ochc0/APNIQC3XFK4ytLMUfbjrSiQoW8z hccVHdMsSSyZyyjgVTs9TaaJ1uwAc5U47U9LCNJX3IKQnLZz0pFZWQOv3T0pD8vy96lFC/fP GcelZWpXDK7W/YjOa1HkS3hLucADmuVv9S+03heJcKBjmqir7EsrSTZY7ySQO9UZZgWx7YpZ 5XcknH0rR0+RGKrEI/M/2lzWyVjLdnU6V8ukRMPTFY2stjXI0yCqqOR0rZ0lpbmd1udj7V4V RgVgajh9clZFwoOOtZKLTdzSTRHbLmVFx1JovSBNIB0BwKdCCLhcH7vNNvRlm9Sa1Mug21Cm 8wwzk8V3OnjFgwHI5rhbQD7eATxu6+ldlpz+VYGFjk84PeomtS4PQwb+bzLkAIEC8cc596pO xEg6datTgNcHPXcarzqFuAvYVURElzl2gzx8pNRSkGTaDxin3bGN4HA/gqESIZfnBaM8sFOC aJDWx0Pg/UY7CS7zE0zEcIBnP0qlqc2otevIIZF3kkrtxhfU1d8JiJ7i6WzzHcYLQhhnA96j +2z6trEhuWG+P5DtGBio05xt6GjaL5VsgK4LDJGabNOsA37T9M1OmCNpPP8ASs7WVc+SEUkE gDHrTitbEt2NqK2tp9Fl1NJwBEpZlPb2/OvO01O7juZJ0mdZHYnr2zXXeIAuj+HbW13ETXB+ cA9uvSuHkfzGL4xmrpLdMmcjrLDxNc3C7Li3FwiAZY8MPxq6NWhYFljaMZ5Vuq/WuR069Nix IBYN1X1qxc3O5nkDBHcD5DzTlC7GpLlO3hk3xCQHMf8AeHIpt1Oqwcn5TxXFWer3lq6+W425 Hy9Qa3rTWm1W/lgmijCKmeP71RKDRSki3DY4n+YfKFzu9TU0torKrMBhTxU4f+EjGBiowGdg FOVzyKke4RxZTng/TingqXOcbAvTFWA4EeT9MYqFVBOwDOahspGQ17PHqIKZQR/6vb0b61Hf 3s7WktlI5aO7O9wB0NbKWVt9qBu1ZolBKxpwc/Ws59OiuNUErswVgQiE/d56U1FXuJyexzqa fO7llJCKw3Kf6Gr19ov2uaFbKKQC5x5akdwOa3pbAvKkeFCKQc9PwqOeCW1eKeGdhOjkxr2j B61V23dCeiOQ/s82ruLnCyRsUC55yP5irLxGW0jeOMB15RgOo9vWtS7sYJFne9tbiWdh+6Mb YAz2P881tab4cs30Nrq4nkeXYNyZIKdsAVcpR6k2fQ8/lhSJ0ZHDSbvmG2rU0ccsexVLSMuV weBWlq2jw2108cUzrJGoZARwwPqazbeF5LhgH2qD839aV76jjpoTRhJSpQbAFw4Pr3qtMY4S yq3ylemO9WmCWszCNxh13KSOmaoSRq4Zmfc2eCOhpKw27FeQK8YCD5yOoNV9rxcM27jkVMQs NwwHXGR6Uk20jJYEdQc9a1M9yoZcEgjA6DFTw7QAxOaREG3zAQDnnNBKkgD1q3boStCeKYLu HOTwR1zUccaGTcV2+1SkAOPkySMAU94ZICA67SRnFSpWKUbu5P5KC2yF2bvU9aoNGfNQg5C1 Kr5JO7d6elSFQoHBPfGahNDaIvJa6cKOHJ+U5xj60+WKKIMAx3ZwO9BZC+7BHXjPSq+3Mh2k 8c4PYVQrMbIxSQx9/WmMNu0BOe5qaTY0Y5Bcc59RTEkAQhjyKomw0uVKjJpzOFf1HrUZzuU7 sj+VMKsSTtOOtOwtSct84PbHSpkG5M8/UVCigx+YzYx2NTJKSDgYX0NQMcoXBDH5uo+lL9nS Xgsc9sVD/GWzUqOsadevc0tStGNME0W5doIPcUNCjYznjvUyTArwSaieUHIxTAjI+cnPAGPr TFcgkYyD0qXI2Z7mmjC8MOvSnYSG8FSSMMKv+GQT4v0Y4z/p0HP/AG0WqJKkbc4PvWl4XjKe KtJJb/l+g/8ARgotYT1PpGiiisRhRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQ AUUUUAfNXXilH90U3pThwDxzWgDlI6d61NJB+0DPSspR3rY0fJmFRIuJ0Aqa1bbv47HNQr0q a14aRjyNpqehRCm0uCPu80ZG/PY9qjiB2qwNPJ5BPWoKHAsScnJJpzcU1etOYZxSGN2jknrT VOM+9JK2XKZwB3qMyAcDoBRYCUuM+hFMa4RSQ7Csq81FYXG0F27j0NZEt/dSSbiQPaqsK50y qsnnSFgykYJPYVzuo3QaXZagbVPLetSia6vU2FsRjqF4qxFpWEGcA+lK9mCINNurt5kjLZT0 PaugHHQY9Saq21tHZ87d0jVbCNIcueOwobuOxXuoDdwsmcJ2965S9sXtZOeucD3rtQuHx0Wo ruyiuoxvGCDkHFCdhNHBTxPtyRVzQ1jW43H79dBfaSs9tiMDeKp2Wm/Y2VpceY3b2rVSvEhR szd0XAuXOMEL/SucYiS+kPdpWOfatuF5UikaHAZep9iKw4Y9t5+ZpRkE1rcSMf6VTLsfMPrT oyPPY85zRcEM6g9M1oiHsU0ZlvSw6Bq7jT0DWvmbfvLnNcXdJ5VwxB6nNdnpW7+yY+P4aioV DY5+5x9qOOxNVbgkzZ9asXBP2o8d6qzE+YPrTiAmqXCRPagt8xTkegoKqXVlOVxxiqGtE/bo faJf51Z0ydokinDDfG2RkZ79xVTWgQd9Da0WO+hvi9qvkySjapccEVuy+Go9Jc3LzZu5z88S nj60arcnWfsZQxW90IwXkjHB/AdKaRIGXMxl2gAN1rBPXUtrQkQHGeT2zUqGQyqsYBfooPOK hSQjtwKfc3JtLCbUc7fKUiM4+83pVbE30OY14TahqciRyeYIRtyx7jrWCQVk245PA+talrbr cyFjKQ3VwD1qncwmO4dQMKpyv0raDsZyVyqySRtiQEYo3D6H1Nacdnb3EXmGcqCPunuazvKJ L7MEKSKtSuS4kluwW4VfvAn8q3dF0wWki6i7N8+cp6isW0sZLiaJclQ7YB967of8e6xhV2qM celc9epyuxvQp8yuRS3CoBIoyG6c1MJ7WaxEkJMMyn5pXOVPsBWVqs62tg0gXPTZ7GqFjqGo JKrmAPEvDJjjNTD3lcc1yux08Pmz2Pm7goBwSBww9aSOWD5iZAAlZ63kiJKs8RaMjciA8Lz1 qTI1HUWGFAaNQAg7AdTVKOoubTQvQ3AuQzxtuUHFFxGktxAfu7W5bpipYYI7eMpAMrnkA5wa t3NjdC2jne3LqxyjDg8dyKW2w15leWKSNSAd3161We7itIw8sLMQevXrV62uXvWZBEemck4q jKws3/eMNrHBGM4P1pJeQNlmOZZULlcggEZqlcGYzM6BirgAL71oDYkJdugxkelRRSQzoHjO VB5FSrdRtPoY97pE91F5hnbzyMFD0AHvTNP0uKzaK5ulwiE713fMx9cVvmN/J8wITFnbketZ N6PKwWXfuJH0qk29EKyWpl69cWt1PJHAnygZVcYIPeuaLsAM9e+O1dWdHt5LFtQjuwkoJYqw 7DisS4s/stzE92DJGflBUYB9K1jGxnKV0Zpt5Q5cqVjYDn1qS2gAmCMQ0Z9eoru9A0nT5dOm gkkjZmydjHpWNNbQWrtbxrGNjnarc5pOom+VDjHqY91FFbYEZEikfeI4FZk7CTbhc44yOK3r 3zFRkeBPMPKMBw31HaseWCTHllTlgNpXsaqKt1FJNlUOfOQ5IwetWJZZrq42jMkz4WNe+ahk jeBirn94DyPSpoEQsrmQr/MVctFciNx+97bfDPGI7mNisisOQR1zTTJvlwq5GOta1hpX9r/a ZEuBvgXLb+rf/XrKljZZZFxgrkGo0Ku+pC8gBIxikjVypONrN1zxS28oBYFQ3YZp5WRnAPAx TYkymZdjlTjrinFUIB27SD8x9asTQohRAo35yzHv7VG+1cI0eT2OelUIRYgW3Nyo6iomlAci JDj86l88qNrKMnpT4YQMvnk9qG7BYZG0hhZSoy6457UqRAh8Mdy8j3qYtHu2529eRVZA/mPs fp1z6VO4x6uNn3cmlDpjGMn0qs7Yf5mx9KkAjfB5GOpqrEk/nKQAvFN255PBpwEcakAcHpmo sqvPUD3oXkMmIK+mAKryyDKk/e7ClLGdiQccAULbdNp49TRsF7i4y2T1rV8MkjxZpBPQ30AH /fxayZB5U5EmegxWr4aw/ivRyHAAv4DjH/TRaQH0lRRRWIwooooAKKKKACiiigAooooAKKKK ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAo oooAKKKKACiiigAooooAKKKKAPmvg8k0Kcc0g704AAZPStADdWro7YmxzzWZtFaGkAm7FTLY uJ0y9Klt+kp3cBcYqI5Ct9DipNMyllIz5Lck8dqjoUQxgKqqOgpSMgGheeaWpsUPAyc+1DMF Qk0LSOu8e1IZRly+CCeTz9KaysQxHTFXDEMZPQVHIQEyMYpvQVjnriJjI3HNQCBi3StiSMEs +OaYtvlQ6rj3pXCxFp+IpgrDhq2yileoOKz4IQGDEjIq8XweTx7UmhojXiU/LgDvUxcHjmm5 56daXI6ZoAcMBcd6eCAMZFMG7HA4pu/DbcY+tNITBz82D+BFUZ9pmVeNy/yqa8nFvEWJ2n1r EtLl7i+kZmzTSC+pqMM2z44A64PWqaQ8ljgYHWrTvst3yOCQKjIHl8dMVSJkZ9mVa/25ySck elRXbCOUORwHJpkSMt27g4HYim6lkwgZ78mtEtTNiXc63M4lVdoPau00xtuhJu/u9fwrz+H+ EAk8963EuJ1tVQSHYe1KSuOOgyVv9J69zVeX/WjPrUwyZ0x685pl1j7WR056U0nYL6mZrf8A x/R/9cV/nTNPfBMbPgdQPWpNaGb9P+uSj9aZp4Cz5xyPWrbvEUVqdJYXP2SYPGpcHAwetbse oW88jxqdpXggjvXMxybgWP3gc8VbhuvkXZtJZuTXM43ZsnY6NolI4HGe3esvxRq8T2kGnWgx s+aUEU17me2hJgdZZXQnaB93np9aoalcRy2crND++VRlvWiKd0xSaa0MY3RkdlVhGhHYcmo1 Y8vu3dqqiZHHIKH39anjG3aSQynsK60jC7YFsqfmHXgVJEqbS20kYw3sasq1vDC8ZjUs54Oc 7ahWBtn7rIQ88/xVN0OzRoWdzb2kKGRtioOCe7Gg6qZo5ZIyUCn5cHrWPrTmOOC1GOFDuR3z WSCwI2sVUds1DoqWrLVbl0R6BZudU0x4bl13ZwoAxmsV4r61uCfN2sjZAP8AFWba6zNGYkcf JGe3U1utq8N9AY/lEqfdY9SPSs4xlCW2hcmpq6ZCdYnMks03yN18rHA9cfU9qtWd1ugM1uzK W4YL0rIm1FLaMeVGH558zmtDTNdsQDE8AiLckj1q5t291E010bNW3uLq0AQqCh6OOavpqdwt tLJPdPLtX5E6BfSobeW2mHmW8qSDJzjrRLEpiYvgDGSK51VadmjZ0rrQktrq7vWjmaJv3wIB XjpWY0w1GeRRJtjjcLID2weuasNqE1raQSCGYWzHG4dF/D3qxZXljOf3ITdyWAXGfrW8JWd5 IycW9EX5bm0to5Le3nkeJowFlIySO/FQROnlqEIx2JOKgitTJJMBKqq4wAw6e2auG0e0ZkRF ZAvPPQ1L5egJyW437asbGJi30HTPrViVo7lg6gKCo2bepPrWbBbLIJTKS4Xlh021YhaIxbA5 WIcI/TJz3pxhdXQpTtoTNDBJbqstuxmLcyg8bfTFMvIoJI41WPEgGCx6EU+/1OH7fDHBEsaK gLsP4velSBdTBCyrgj7x4A/Gld3sPRxMGPQroSysJyISThVPJNWYtMQw7GUxsq4LMc5PrVm2 C28jReezJv24Pt6VZVzHOoCM69m9PrSk31GttCtc2NqTDNIrIucMeuR7elZ2s2ltZTwSwMxj JPDDlK6OdGuwTJwOwA4rA11mUBmOXVNqkjAxQknsF9NTAfRrq5lll8tkU/N9c1BDpjSyOFiY Mgyd3BrstG1ItBGt0olhRQcjqvHSr139l1HT5VjdI5WHykrzTc5LQXLc84i81pykRZWfrzjP tT38yB5I7hhGw+8G5J/GiS1lge5YzIHQ4DDuPaqs+Sm2XLZ53Gtk77E3SWoKEjlLgEqfu570 qOMOzEYzk+1V/M2vtbgDoankKNEuz/gXvQ0RcUr5zjZ1FSSxsUA2jI6UxHVcNnDY6Cka4HBP U+9LUYfZWZRIw/eHr6UqOocxnr7083DeXlR8tN+0l7TyxGu3Od/encEhfLUx4IG8E4NMZFIR URhKSQxzwaRckkjo1Sp+7PqT60bAVGtWjk/ejA9aaY9xGM7c84q5KVdcEkmoizxxMiYxJ94Y qkyWiAuM+w6UFlb5VYetP2KRhiA/cU1rPapIJzmhWEJFGxfkgJ6irh2oSMg+hqFF28Z4pzDc uQc4pPUpaBOBMxJJ3Yx09KveF1CeKtHU8j7dCQffeKz1LBs54PX2rX8MqP8AhJ9Jycf6bBj3 +cUgZ9FUUUVkAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAB RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAHzUOnNOPQ D8aRiOKQVoBMgz1rY0eDDF6xVfDCui0j5oCR1rORpE1P4CB1xx9abaTS/wBmyxhA82SG/wBk Zp69BUWm5fUrrYNqjg+5qb6FWHIoUDB61JilCckehqTYD0pXGNUYGaUjHFOIpGpDIpOEP0rO kfeMDPFX5fmBFUxCyt93g96LgRgcEkcdKsmJdgxkelAUKNpBOTVhgo+X0FAFVIhG+cVMDk8j 9KazBupBFMZiSEAJX+VAD3kAbAGfpTuuCBTEhWJeFOT3NPXIGKQAxPHOfaop32KXIwo6+1Oc nqKimt5bmLYThW6/SmgMi+1ESo8EQzn+I1X0xMTNnnA6VtPpdvFE2egHWsuzTbPKR90cA+1O 99ERbUtXP/Hn3HzioPM2x5z0BqeVhsweRkYqpLIIoCzrlWGMGtI9BO/QqW8omVm4Bz0pmon5 AP8AaFS2USbVWNTt689abqgwRx/EKtbkPYoRjBzWrbkmBG6jNZSda2LIb7Rh/dNSxxHSlQwc D5vQVVkJMwJHJq0yYc45qHYXnGOvpRcdtQnjE0rJLHuQBTt6dvWoI7ZFG6M5Unhe4qxIV/tN lblWUD9KrwAKWCk/Kx4NTG9h21LEMscc6GRAxU5IB61cmZLiaWSKIR55VB2rHE6i5KkHJ6Gt FXIUYOCOtTsNFlJiMZBBxUEnzRyhu6mnblIJB5pVcSKy56DkHg01dA10OWlGF3KMjNReZtIK MQAM810w0a0uI2xvRz9zHOTWdfeH72zjjMi4DSbU3D7w7nHpXRGrFmDhJGcLp0+d13ZrQttY hMSCXiOM5IHU+wrMuFEf7rqy9xVeJCW4GQKvlTJ5mmWriRrm8aQjluce1WlsxNB+7TLuar2s cktwvlE7yQABW+Y8atDbrhDGAxI9cVE3Z6FwV1qiunhac6cb1ZI3iThhn5lrFceXckISMdT6 11l5K0dg4lyx69cHr6VUubCKaOMxPiRxvCsMZz1GamNSSeoTglsc5I7MoU/cyfrmljilGSoY kjoOtaI0rzl/d5j2nBftn0q19hFtZE7cvIwTdn7v0rVzSWhmotsxYJZYD8rsvOQc1tQeIrj7 P5VwRJGP4gMEU2XSJSPu70HJK9qoo5tLwTIgMSnaQ/I9KyajLVI3jKUdGzetb+52mayudwVh uikXIUVZm1i9vLiDdbrEI1Id0AAcUtvaTorqFU3kqiQlRwF64p8twRb4hRDI64weMGpcmlZl Kzd0W5WN5YulqfnUbRnjaaZA0sU5/fu2VAG7qT3BpllqTrKsU9uY3HVh0PFVPKCFrkswk3l8 5xwecYrni7Npm0kmrmveGWCVUC+UeDID3q1B5jzwxrAjuwIQE4UZ5JNN1eQamGuIwyNMioWI 7gc1TsLU22EjmYvjgsenrRCrZXE6d9EW4TbPcyRXaKyscELwY2+tTMsUJZWYBVzvA6k1nMwi uVXzNjEbixHT/wDXST3McVqt07BZGJXeT978K1WrujF6aMu26W8kOI+UHKk9c1XHmhOAxG4g t2H1qtY34zInljy8A7um01p7Jio+yyArJ95SM5HtTt7xSbsRW+Wl2u0gUn5ih9PSma3A88Q2 RtLx8q56D1q/BHGgBH4ZprSxoxDNjI4FDqNOyBQdtWYekQXECSLMdit0Xua0fKSRBHOCAeMr /CfWpEgYyMz4AHNK9xEhYKwOeDmlLXUIqysYV5pXnX4Mkv7qMFAOu/HesX7LLcyOp2JuOwB+ hFdBqchkt5IskbcZfuB7VTh05JoIxG/zxnIf1q0/dItrYqpoqmeG2uWS2CoQGzkOeuT6Vmf2 ZM1qZk5jVyCvoAetXtQjnWeVriVQe3v7CtfRtVhhtjBdRK6MBkoOV9qm7SuLl1scfNGquHUk gdTTcFZVBIwDz7Cupks9KvLWRlKrfGQiMMe2ep9KyrzRZrORHcgq68c9fXNWp6A4tFNnAwpH ykmkbHyBD8nekkSSONtvKj161BHjYSgJI5ppXJTLLOJI1UAjHKkd6RP9rO+ktrtbeGdQAZHX AzziiFvkx95f73ehpjuSOmSrZ5A6CmFXdcqOQTmhmOeufapzKhWIBNjKPm96m7Q1ruVdpRQT jcTg5p/JXANOlw6lT09aqmFlAEYZ8mna4noWMbyQvSoyHiBHbrU0RUxnPykDoahd2yQRwaa3 sHQRnITIrU8LSlvFGkhh/wAv0GP++xWOhZgQBmtXwyrr4s0YMMf6dB/6GKpk3PpKiiisCgoo ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAPmvGeaSnICx4FPC5NXcENVC2 PrXU6VC0VmMj5ic1kafaedICRwK6SNQoCjgYqJO5olYrahfpYxnHzSngKO1XdJt3htTcTYDv 8x/GsvUrKJ3Eoz5zcYJ681oTXgt47e3bJZvSpS0KuTgYyajlvVgX516nAc9BTgSV9zUE9sJ4 XiYZBFSrDLYyUB3A8dRUbN2HWkiBSJYx/CAKUDA560DIpCyowQZfHFQWyT7C08u5s4CgdKth stgComKxlscnrQgYNuA5IyKdgBc4yfUVXWeK5fy8HeOcipiCi4Xkd/ahoEMwSvAHWnquBliB TYxJvI3YT0x1qTA6gZoAQtke1Nzgk0hBJIK/LRtBHGQKQCDLAY9alzmmhdqDbzSHcvPrQgEu BvidS3GKwLZQs8ihsoPStmfc8bDAy3AzWKX+xTMCnmdiFPAqooRckQeRu77+aqXUHnW+0HoM 1bLmS0RhGU3P0JqN1KgelXF7ENMraezRYVlAwODVXVTnYfVs1eiVWAyfmziqGrfKYl7gmq+0 S9jOUnjNbFm0n2LCEKgPT1NZC1rWTZsmXpg0mOJKrZYgd+1JF8t2CR2ogwbhOe/NP4F07EjC g96AM+6ZjfsVzng0yCRQ7Bzhj3p80o8wlRtYgZNWLbSrmJItQEazxHLBSOvtSvaOo+pGIlY5 IGVqWNGZjhjwM9KeI3Z+Im64HoPapYYXRyWBUkcUrpjSJrC5+yyCZIw0nO7IyCPpUWoX5u7p S0MSFOAU71NLcyaZYypGVZblcOSMlT7Vmac0sl/blV8wl+FHehXB2vodDJc21v4fhuLeQJdM xEyEfMV7EHtWG9/OYBPtlLjtI2cAngY+lWr4RyXM6XEXlszH5P7pB5FNjEBlQOuUjOR9R0FK CtoErtHR2WiW0tgkEtqoikGS7/3jzkd65bWtCi0+8KWQO0n5I8/mSa7A+IzFbQtJbjzHGFRT iuUv7k32oNOAYlLZIPJFVCTuTKHUzLdfKVbl9okAwq9CffNa1uQLaS6UMGlARfM54HvVWZJ5 LN/Jjyi5LkdM5qSDbDaIIXKyFvmU/dA9cVck9xJrYS4yzpEMFJCN2eRjvV2ezS3mjjEqtGF3 EqcgDtVW2sNRiRrpbZpYWz8yNj6nBpyTRSTxrIxBOc9segqCty5pjRW9wssnELMSwXkYPSor /wAufUgtpKJIwA5AGMfUetT21tbvKftcbqhGUZePpVCexZbiWdmKl2Cop4O3tTHayLF5OlnG gDKdx6gcg+4pBZQXUI3BGnBLGQcEc8jHenm3RryFX/1XB/edRgdM1NdySQWu2RlEkgym5ece xprRaE9dTc0C7s5/9EVlF1F8ojbqVxgc96xfENokVuFNzmZpCpUL9wZ46VFaaVL5SXTu8UoX I5zuHrntUu0/LLGWkdwS7Mcg+g+tKUtSkl0IYzLYaS4uWyCu5D1J+ntVDTbyTUxFE6oMtw2e eOlNv7YiO4QM6eZHjbI2dnPQVTk0xxLbyQMIsY5B6nHWj2d9Rc/K7HQzX8zXRt9rSbF5KHAH sRVddMW5uDK0rQ5wAit0PrUtmyvEJY8bm4Yn2qXd83zVy3UdEdSXNuZ3iOC6sY4JFd34+Yju K506jLLbqskoYE5wf4cV3cZDjllIx/HyKqSaLpTTvKYgJSOoHGfpWtKvGKszGpQlJ3Rjad9t 1UkRL5MCjLOP4vYV02j3V3alJoZI/MhJVC4yD65qhawC2gdEfgMcY4q1a74cxsMoTkDvmnOs +g40VazLd7q0txE6bwZvM85wibfm9B7U7Tb+3gaWbyY5G28hxkJ/9ehrSKZV3rtOTkjrUCQG AyDapgb3pKpGTE6TQyfWRaRJOImKyORjrilS8guLqSSdVSTywVBXk57Cql6kS2/lNbP5gbIJ PAq3bbXsv3xCupJzjJArR35TPVOxDexR3QcoSsqjlfX2ptpbtBp/z4MmCfl4NTwXFtwXBiUn II5yasJHG0hlBIBHSleyBK7uYkUkcl2ySYYH7u7kipLzSIg5uVYrxkqO57VsJaQK4fYN/XNO aNZCUxgAc0nIaizkJLcwyyfdG5c+5qoJJXZFycKCNzc59q6k2Pl3u98FNv3vX2rLv4cR4hgz HvyFHUZrSMyXFmda29vcJcRTM0bHlG6iln0m3SFGhmSSdslivGBWhb2Z80Q5BaRSR7VRurc2 qHJZZ1PHpirT1IkjJjSWKcM0Zweme9SSyorkIBhgMiryXYdlS5/dEceaBlR9ahurBonZoWS4 j/56RfzIo1vZiKgjBIcPgjtR5jhwGxjk0xJowV7Edc1KQJMHIzmh+Y79iGSTIBGcE4qe2lwx fHCrUUikYHHBqZrdkgdl5yOgo0QK4+xuI1Qlo/MQfMVPcelQyN5mcIFU9BmokdI8KD87DkCp /K8pFJUgnnn3pbajILchMxjhs5zWz4cIk8UaOM/dv4Tn1/eCsi6jeBI3GCG7ir/hRiPF2k7+ pvYMD/gYqt1dE9T6TooorEYUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFF AHzYDg5HHY1PCocgCoB6VdsVBfHvVS2LijfsYRDbbiAKtCRN4UMCWGQM9qYIw9vs6AiqX9kI W3vM5I4ABxgVkiy9OnmiMKR9772ainiWTWI9wJCR8fWoVtPIuIPKLFIuoJ61ffa1wGxh8ciq 6BYlBI7CkZiB2pAfwpJPu1LGKrZFDn5QAOTSoPlzS4yaQxAu1CO9ZtywBb5unWtGZ9i8dTWT coZNyjqTyaaJZi3F3MZ8xEoo7itzTL0XUAQndMv3h61SksMdOaZBG9nKJVzjvincSOhVQmee TTXfauQveoop0ufmjboORnpTmYbcOfwqShpkDHCtz9akUHueKYpGflXj1pw9xQMmDhcA49qi Kszb24HYUrYAXjpTXbPy5IpIGR3Mr+U2zG8DiufXcbhxKMr1k9fbFamoRsIMqMnqWB6VSt4V eLz5ZMsOF3Hp+HerRN9S7I6myhZeBvqWVQYVUDtzUc6/8S63ICgZzgVMMMUbsR0pDMkfLgf7 VVNZQrPGpxnbu/Or0q/6QyqCcNniqWqETX8EeeGUAn2rRbmb2M4dBitKx5tH571p+INJt7PS opo1CuMDPrWZpAV3kRjxjOKNwWg8D96e1NnIQSHJ+5inA/vCagvH/cv7gCqAhkdk2qgGSBkm p7bVLy1wI5CVX+E9BUc0allIOOBViENHkp/EMHPSovdWGXl1S4eIEhB1J+XuaIZGKq78k96g mji+zxyBi0rMfMQ8DHYiktpQCVzmoRaL7wrOF3Lnadx/pUMsb3Opw3G5YiNo+QYAApHlbaBy D3waWEwsxErsgxyRQm7g7dCG/tiZWuY2zGJDGwJznjqfxq7bW8NnbC4uz8w+6g7mqcG21lcR MTHnIVuc1osbHUUj2S+TInCqaTutARnzStdT+bIcAdAO1SG3Nw7MihMrkj1HrWhBpCfal+2S gwt0K8EH1p8Fm8Nxdy28qeRHH80jdceoHvVxcbEtNsp28+0R2n8IJJOKsTwJJNuCo6hc4UdT Vq0spriGWSC1MsCjiQpxuPYe9bGm6DcajlVia38oYZpB941aZDsY01xNqdhJaWcJTZ8rBDxW eY4ZJvs1xDJC6gDaBnJrvIfBoskeR9RZFAydoxz7024trCytEvFlzcPhZCMFpPY+lTJ2RcXd nJXtlFBpkUMLuPM/12Tu2Z6cGsm6afSJUiikFyWwEcc5GOmO1dDqNiNVvPPSQI5jxGinoo6Z rJh05tRZWa6RbqElUTuw9c01orslu7sjKtrqR/O3M8bEELGwzg/0rSjkt7mzEXkyJMVCswO5 T6n2FTDT1LLFKCPnwS57DoQapJpd5/aDS2yGe2DhGZTg5HJoT6jfY2DBCthJJHLibGDhiAfw NYtp58CosciNGZSfLboCO9O1C+3bYrhjsU/KrHDAfXuK0Z3trbTJBI3lo0YIzzn6Htmk1JK4 0c1rGpyXMwilgIk3ZXB5P1o0WA3lyzMSYo1+UZ61u+GtHh1i/kuntnDDBgDHgY9feppoIbG9 mhgG5dxJIHU5pVGoxt1CCcpBHbpEmyMYHpSlCFxjr3pVYOTjipACw9cVxa3O3QjVQqbe9AUs cZ59ac4xgn71AVwDgc07isOAAUoVGGPNLEqRF3eZUwOFbqaRGJbDDp3rm9dtrx757iIO8WAN wP3QOoxV04c7s2ROXKrnZLMpRRkdKhlvIrGGR5rZrncuEQe9ZGitEtjhJy4J53c4PfmtpZ1M eFVCMcd6lr2cy786sZk97a3EtvEFktFPDrKNyr6EGr66f9lYxNIrhgCNpyCPXNMuIYr2MxTD j24qS3iSC28pC3tuOTWkq14mUaTUrsguLN05t2QgDOO9VrN543fz8oG5we9aixttJfpgYxTz hsBlVh/KpjW7jdJLYoTXTHYISG55OelWIJt2QfvnrUcthAEkIYRbjnPpUUM0aoWQqxQ42Dgt 71srS2Mn7r1Jt29iCNvB61RsTuurlCAQoPParyXKSSkkbSOCp7VDdTwRB4Y0y8mNrDg59Kpd idb3IZAv2WOaMZkDY6dqxL1pp7poCeW5WtyZimls5Vgw+8BSaPF9oRriSEgEDYxqou2pLV3Y 5ue1ktE2Ng71wysKis7FLi48u28yKQ/xE5A+tdfqdpBLaPJMPuDII/rXNW8vkTo6EjHXntVK V1cXLqV7u1nilkSWFLjj74GMVmJHIp+WNtoOevFdhfGA2H20h1DdqyzbkxllXKOmc/3T6VpG V1qRKNnoYtxFO7GQRlUUDOanG97UYG0Hjmug02e0u7GaK52rKy4Xd0bFZEthH5LHzGjZOdp5 BFJtXsCutzM+yoGBV8mp3uD9nMZwSOhq9DY2txaSTCba6LxHjqaoR2872+/YSRkFR1oF6lWO clCrc4rW8Mox8WaNIBwb6HP/AH2KxYl3SlADit3w0ZE8WaOuw7ftsHOf9tab0QlrqfR9FFFY lBRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAfNQPNXrRsMCPaqYUk49O alif95kdM9Kp7FRep10LbolPtUvWqdkxeEVcFZLQ1sRXC58vHrUm5TOcA7sAfhUc2SyY/vUs cZ80MM9MGqFcnP6UwnNOc8U1BmoGSp/q6d0BpP4QPakPTFAzPvpGDAKp5OKZGmDtI3HqTVi5 jLsiLxzkmojCBKNikt3JNArEqxDy8gdPWmvCjKUYDkdqnXKjaRkmgDkcVIzMTT2t3aWNmP8A s1b8g4WQg5POM9KtZJJ6UhPQe9VcLEW7naRgU70pXUbqAMmkA/OeMZqtcsQFJq0uADUEwBVW YcZoQMjmhiltyBndt9axo7JBKc7iq+/fvW6wDD5OnWqczA/cwOatOwrDXUrBF/d3mpw2FBGD 9KrzSAWqZ7MTSxSfIDjrSWoMif5LxyTjK1i3eW1SHnoFFal1IGucDPQVkznOrx/7wrWOxn1O n8WH/iTQj/aH8q53SD/pLj1Suh8WEDSYB/tD+Vc7pGBeH/dNEEKROi75dvU+lVr5QEI/2hV6 1IF2rN0FUb5su3+9T+1YLkw2bW3DJAAAqdGSPIZgDTlhtfsQuEYm737WU9AvrUBRzMjKvfn3 Has2jRMfOQRjP1qJXijZVk+YEHp1pLts3DKDyev1pgUQzFnU5CYzngZoQXJUR13shIVOTlq2 7fXZFs47RrBZXZSMsvJU9DWJH+7KSxozKv3ie5qxBqtzb3kl0ygs67dpHAX0FNwi372oudoZ f77S98pdv3ecHNTaelu0oE0hDnqqjNVoUlmimKOAoPRhktnsDWlZaU4tvMjdFm3YLt0h9/en KwKV2bSW1tqDJbRXBZwN0wU4CqP4Sffrmsa9KRvOA7+WHwAO4zjpViW7ghumMJJIQBmBxvPr VWVLkiKWZAFmO1fM4wBWCd5XS0NNEtzp9L1LUdL04+bGBaxbQxHTDfxH3rqBeyuY5Pt8TSIm 5lVcBlNec3+szS/Y9Onxtib59nBf0B+lb7Tiw0rnfPFJFvOD82fT6VvdbmdkJfz391O7T3p+ wtMVRUOd3Ht2q9fX0YtoALbbKqBXHYr6/WsPT7t7kxymPylRz8g5yfSpTI975pVHZYPmcIeA T6mle+4tti1BfRvnf5azH720dPwoubqzluUD2Me8gAMgwGHsazJoIzcR3XlMxTGWBx17V0Ft oU91ZyXDFd8i/ul9O4P5VpeNlciz6CGzt76BobaAxIWxlz8y+3/16ZLo8OnQS3NnO1swHy5+ YH14rRsVguYQ8m+Lb+6ZIx95vr61cDWlhaEwQEhQNvmn9eetZuTTLUX1PKvEEKwXAtYPMkj/ AOPgyOuC7HgkewPA9a1dUs7e005nPyHywrg/xH6Gm+KpBqGqQy2bmeQLlyi8LjoOK3E0CKGC 2uprppIhHmQSHIPHBqtLXBXuZ+i3OoWOl29sghMMyFkIGZEwOn0rLlv7RLqSCSYLL1IPvzW3 pOs6dBdzWyrkPlUdumfb0FcP4r057fV5ZVl83ePMJHueP0qXBVJWY1P2aOk8rC5RgR7Ug3py D371xlhd3luvmJKxYcFScgVr23iPzJPKuE5GMsO1Zzw04msMRBnQKxkcHp7+tWTsXnPaqcci TrvgYSqB1U9KQu2Ac5/rWDg1ubKSexM7hIiQOWojAMWDjOOc1WDO2Sfu+npU6SYTHGTU2sO4 +3RQhAUKpzggYp0aCM5ByTxuqJpzlEQcdxTTMT8oPFGo0ki3uWNlGPmPFPcgemaoq7O7Bug+ 6fWrCqMDgn3qbWHcmWdo0B3cZ6GpkkSQbiNueCRVN1LOE6kdqRFIm2ZO2iwXMfxZeXVvGgh/ 1Jx+8HY+9Zmma00l3Gl8QFfjzMfdrrLmGKaF45VBVhgqf51zl54YUgSWbbWP8L8iuuhUgo2Z yVqcm7otahcR20yi2vI5SeSw449/eoBqts0kcs8oYq3AUcj61Xh8K3ZGXuEXd1AGajl0GS0I 87O08Kw6Hmt+anLZmVppXZ1FtexTleVCN2bvWn5yRqq4CrnHA4ribhthCKeEGM+9WbHUQY2h aQsVBY5PSsnHsbLZNnT6tatd2RWLqenofrXHyxmKUxOmHQ4Irb0LxGkk3k3KnLEhH9B9K1tQ 0mG/jLJgSN91x6UleO5L1ehiWBtTpsi3D5xkhD3qPR0s5JEt7i4ESkndvGUI9PY0tmsUN49l cr5rE7VcdqnvfDjRIWt5NxGcg8cValZkuLsJfeHjNbXF9oEAFtAeTI2S7DgsPYdPeuRd9Qsp WtriORGIyVYc/Wrh1K70uYxq7m2J/ewk8Pjt7c1He6tcateTXUww8yhSoHAUdAPTFb9DCzuN tpRE8uCGyvSi2mdJPMjfaegz0AqlIdjqo4Per1nZySGMBwTI+zb7etR0LWrJrmF5ZDcpGNsQ G8Yxk+oq1osSr4r0VopfNDXsDMduMHetHie68m3hskTytgBJ7MKj8JOX8S6WHxxeQ8D/AHxQ 25LmJ0TsfRFFFFZjCiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA+bAem DTk4bI9ajAycVctoDI4A7kVTKjubmlFmhOcitMYHJ7VDbwrDGEHapiu5MHpmsjUi3ErHv/ib j6VMNwkII49aSONHkGMkJ0p27JY02hWEYZPpTkUUwtk1KlSMUjFN6Ak05jUMsmFJ7CgZG5LS Db3qC7ube0AkmY7j0A70pkZ0LpgDp9Kxb8NcT5bJC/dFOxNyafxFlcW8RyD1arum6mL1W3gL KvYdKxI7RmONtXLS1ktrkMOjcGnZAjdwMbgDSZ+bFRq3z7XB9sVMBUMpMDzQATyKNwBIPJNA BJHpQMcMBOoqMqpXL9j0qRl7dqY4+Q0ITEJAA2jqKzHkBd0HVTVuScxQOWH3RmsXTXNzJcSM epzVJXFfUu3QxZ59z/KltXDW6H2pt+NtkMnjmmWx226/SlHYHuQS5+1Zz1NZKNv1QMef3gH6 1sqPOmbb1TNYkCsl+u4YPmAkfjW0TN6M6zxcR/ZUAH94fyrmtM/4/FH+ya6Lxac6Zbe7j+Vc 5pxxdKfY0oPQUi4FAY/41SvOCucglu9XMuC2zAY8c1RvNyzoHOTkdatbiZq2FjNeXEq2kZkk RNzKDghfX3peCoYcmmxNJCN6FkYjG5TipIm3jHHrmspPU0RBPDvIYjGTWlpjafHeJNeh2KAB Aozu46EVWmwEOag0+4jbUF87O1B8q/3jTSuDOwupra/01YLa1ELqQTnHIrNutAt7j5o2Mbnt 6VoWsDLCH2gO/Uegp07+XAzjggUlo/dEkYkNiLPyUmYuqyEjHRT6/WkntpZLaW1ErFGYvnOO T6+tWS6GJnuFIXAzk4BJ6Z9KqlVMRYuVC55z19/pUPmbN0oxVuo2OBVgEeQ7NwXA9PSo7yTM tta2qM0xIGGbcufXnpmprQQXDSm5jllgjQ4dQRtIqOBFW+t5GcrdMMIuOEHr9TVxbjuZTaI5 9MW3umDHMgP3CcY981pac6PDJFvfdKCoD9B+NUIkaa+kmmmDEMRyevNXblIY45HRSqyLtRie AR1quXoQnpct6MrS6VJHDCWlQnd7NmtTT2uYoZkigG0Dc2OoPfNc3pOsnRLHdgSBiRgcMSeh pbjxJd3NvNGkXkJMfvfxN7ClqytLHWaEukX0syrzMAd0LngepB71dNx5F/Dps1zmzIwrjjPo hPYe9eeJp95b29tepII2JLYD/Pj0PqK2hrbXcMxkhJmdArAdBjutNwu2JyR0vifWG0OK3aAq Zt2GQjnYep+vpXnl7qN1q18S91MLZmGM8Yq4zSyTR3FxOzIMY3cnA96ZPNBPIk8bCIlgpQ9y O9OnHTUlzZ0OijTU057GS6jMjDghcMPQVf1CzW5037AZ2SFeC2OX4459KqaHeaPp+mK9xPCL h2+cnk1owapZ6rdC1sp0mlYcccYqG7OxUU2jkdB8NnULO4jvQ8bJJ+5kPBOD6Vp+ItAuJLSz jtYVleIYfbwX47110emGzmjmvLhI4+Fwo4J9DUuq20kJhezg81Vb94gbBq7u6aQnZqzPE59L uLG6dLmIxIy4Ktz+tUILKGBnZpMAnAz29K9cnuYL3fBJZ5kA5ilwCR7ZrgpNDGqeKXttOh8l X+Vkc5Cke9awr3fvIxlT5VdGHDJvdvsk7LKnOfWrEHie6jfZdxCXaeSODWrc+Er/AEPcZYd2 7PzIfugVy8wiurthEeGHB9x1rRxhIlTcTp4tas7g/fCE9n/xq0l2qhRKrKGPB6g/jXDTxuo3 bSFzgkdqlttTurMgwyE+obkH8Kxlh0bxxDPQh5Zwqjkjr6U0x5Y7CAGFYFh4qhZQlxD5bdNy dB+FbMV3DdAGC4jdc9utcc6E0dUasZE0aZxkfdHJPc0scm3PmAgfw052G0Kep7CgIpXA5A9a yd+pqtR6zLgBhgt1b0pkWVkIB/E1DIzCfAHy47+tTozIqMwBz1pNDTHGESM28lyvQ5qULjbk 9O1NVQQcEgZziieUINzHHapt0QIcgbkHGOw9Kz9WkW0smeV9y9R9avRvui4+8Oua5XxjdkJF aqeWO4+1a0Y3kjOq0o3KjXUMkTSLICfSqVhcbLiTIz5mc/SqNtIsUoaRc8cYPSpFVpbuM7sK 5ycdhXo+ysjhlWcrI2YYjJs+zjDKxyc9q6DQNZMbmwuJDg8Ix6g+lZDSW1vbtJZMV4AYGh2t phZyIRCAP3j+/rWN09GaXtsbOr2TWtz9piTD7uueprWsZ5r+xYu+2UfKx9KxNQ1SOa1EUUjM 448zHUU3QdRFs0ySFmDDhBzk1DWhaZm69pstjOwOX/iVyODmsMSLEvCkEEkmuw1S6n1KGRH2 QQRjLF645gCxU8gdc8cVpTba1Mp6PQ19C0ttXk2b1WUkkMR0A9almgurbUZDkEwMPujg47/j Wno2n3VrbC7tIWQTLhXPYd8+lZ2o3FxbmSaCQMSuGzzx6USlroOMPduR6zK+qXYvXjCnaFaL 6UnhqH7P4r0gE4zew8f8DFU5bz7W3m42MABtHSr3h9i/irRye19D/wChihXtZkys9T6Joooq RBRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAfOEcWW56+lbmlW2Muw+l ULGEtIMjiuhiQRoABUylc1iidR0p7/KnGKatQXXneWghcLlvmz3qUUSfaFitHkHLdh706FW8 oBsAmo5F/wBHiXjBbBq0U8sgEgkincCMphgKeOKMUnfmkMQmopBuGPWnswLYXrTCecAZNAhp jWOPZjtmqoty2SR1PHFXDv7nJ+lKq8UBYpLAqSDnmrRjU44pWXJyee2BS9MDGPakMhlZ4l3Z GM09JN0e4daVgHBU01VOMdPSgEhSc5PenrkhcnHFM6detMMnzE9hQBYORjnjNEp2oeKrrIS3 qPSp549pBLAllyKAMq/JOn3BB5xWXo24rNgVoanI0enyqQMse1Z+ikqku2rWxPUu6o22wjU/ eZjx+FJB8sYQ9cU+6j81rcN6k01SN2amOxRBZSqkt0JOMDINZCPv1FWc9ZM8fWtKQAzSj19K zWUJfeWvZhzWqZk9WdP4rIbTbPHHzD+Vc5Zf8fAwegrZ8RMx0mxDHknNYtlgSsewFENgluXk UmRh14zVK9kBuwMAjA/OrsRxIWyRkVl3bZu1HoBVok1GmEUCA8se1OSfJjkAwSApHbiqTht0 UkufLPAq1G6qMIcheT7Vm0aKxaYeYB2punJa2128kwEiAfKTwFY1Z2b4vlHbJqbT7AzsGkA8 rr9aUUNm9oDwSXRt7tnOBuQE/ez6mnar9ni1FIftCRw7gXGNw+h9aqiyVHWZDle49PepDJbC MmQZ2g53Dr702tRJlDaFlu4WCziYFQXP3TnhqoSQOySJ5gZI+HlAxipkSeS8JUMZW5Vf7q+9 NO5rp7d13Q3HzyAfLux0I9BU3sy+l2bt14ms30y00xrUrux5soAwyjqR9am0WbTZb+MzNEY1 y6HHPsK5iCNrm6afzWkRFKoFXpSTJCjNLLA8bkYDq3Aq7tK5n1O0uLbSJtPkD26OXZnVozzy cgVz13pN9qVq6WNmYbaNDkF+Wbv9MUyGdrbw8JmuEDL8xiZck+2e2at2WjalrcUoJms0aPzE RmP732BpSbtzD0Whl/ZVvLaA29lKUtkzNMMYUkfrWbAlzFqDllYSr8uHH3R9P61ctoZ4nu7V LiRXRMbRwQQehFE6XFxceZnLIgySeSe4FOPMLc1InTyEgiIYKckH7x9Tn09qHSJJ4xbOFcD5 go4YH0rnbi5uIpogpO7qT35rQTW5UGwMoeNdoyvOaeqZOjN3T47fTL2M3UbtE+Rt65zRMkRl kW6tBncWgjxhlGep9c1l6Rq4WO4kvcyoG3K/UL9RUkuqtqNxauVDPCCN6cbsdOKqLdxSWhVe e0vmyIBBbBsOuMlj7e9d74Vs9PH/ABN0hjtmkXywu4Y46msPxDcRN4aulWxiaQKNxiIGwE5B +tc9/ajXdtFDMWQwJtVQcZ/ChS5wsluem6jr9jLFLaWs6zXLDaAmCAffPFZi+KPspQ3o2rG2 2RlH5YFc/ZXcel+TKiosmOEYc/U1rC80+SSCGXyWMh3MV5+Y+tONldMLPoT38+mavZwmUzvM pLZgG04PTcf6VnWMNrZwzXdjHsMcfmO27PmEenpU+s6jY2bPaXKO4lTYwgGGQnofzqS20e5t yY5Z8ma32FFHBA9fcVHMDT2WhkR6/qN5dpNPb+XcFtsUY5VB3zT7/QdKa3aaW3SxuWy877hk j+8Pp0xWtaa1BYxyWt1CjXCDazoBllxgE+lcimmf21cu0YknVZD+6STbsT6nr9KuN946ClFf b1OZu9PaOVlsmWeFvmVcYJHrWPdxFX+eMofTFd+bDMskQLQ70xE0i4wR2rJFmDalLnaxLEDj BNaKb6kcqexx21c8nFAaWFwyOwA6EGurPhc380dvZRpHNI2FQnPTqxqrrfgvV9DQPKonhxln jPC/hQqiloQ4yRTs/El5bgK7iRPRutbVp4iguHCyN5P+y3SuOKBeCN3p2o2EDPTFEqUZIuNa UT0YXMcyZyCOoK9Kk4ldSDwOeK87gvrm2YGOVlx0B5BratfFEiLi5jDHB+ZODXLPDPodMMQu p2CvuXORj1pY1DFt/OOgrLsNTt7oAxyoX9CcGr+4NJsQ/Mx+bIxXNKnKL2OmNSL2JnbZG5cg 9eBXnmsXP2vU5JXBManao+ldjrV0tlpUmOJG4xnrXAqWYkEHk8iurCw1cjmxU+hp2+ns9qbi C1LJzlielSaTGLJpLyVMsp2qjDg/WtazVLPT44kl4lG2RT/SoLmNWu0AUqrtgHqK1dRttGKg lqULl0aVnRflbpg8Cpo2V7YRNNtC8qAOpPWo7uzAwsUwd0f7uOCPWrUNtbm5iUzbkf7zAY21 F79SlcuRW8Escpi6RKPmzwTT9N0u7ngnuo2VI0zgNxv9fyqTQ440vWhYlgwKnPequqvPYpPZ wzN5bcnHaoa1sikQyXUMkLq0rHH8H94+9ZsEQub6NGXYpbk+gpbSV8mIAEEema2LGJUjcvCP M7N6VfwoW5Pdzzyh1hkdIwoVUHGB2qiICcROpZ8ctn7v+NaLxujCQ/xDawPcVcidV0tbeO23 NvLNI3XFRqjS3Q52LTEkmMMbbJB2YZAFaOiWL2/ibSclWAvoeV/3xTlKxW8hPEjdPU1N4djn n1zTpfK/dpew5bd0O8U+ZkOOh7pRRRQZhRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUU UUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFA BRRRQAUUUUAeH2ccasCp6dq0gc1Tis0gbIYmragde1ZtG6RIOelRXJkBUo3AHKY61MlNkIVx ke+aEmARuJY4kI2uBlvaps5PP4VVhIM0jqRhwOPQ1ZzTsAuccU1zilpkhxyOvpQAcAZ7mgME HTJojyclutBILYApAJ15zTuQpzxTC+T5ePlBznvmkZx1f5UHU0dRjlOQTRtJ5xTI5Y5MtGcj PUU9mCqTR1AaeKbznOaaJ1OaTdkE0WAc3NDD5AMCmhjgU8DIoARBtOcUPhs7sk9qfgAcmonO BxSQMwtcmIRIR9TTNHX/AEeQ7sHNVNZuPMvGA6AYqxor5tZckcNWqWhnfUvXLEXFqqnuc0TD a3FEmGntzkdSaS7IBHPastjQo7v37VSY5v3+uRViIGRZMn7pyPWopox9rjAHzNya1uZ21NHX JGbS7HcMncRWVBhVlPotXr4ma1hQnhCTVCI/u5/90URdkDWpeQ8bvasqRt87E9c4rUU/uCf9 msoDdIx96tdyOp1NhHDd6QLa5XKE5BA5U565q/exb1WK0to2Cw7A4I59zVDTD/oHsDVxGIJ5 I/GueU2mdapKSHQWF3JtiJ2xpjcfWte2sIovMXJ8twBj0xWVFcSIeGP41eh1E42uOvenGZMq TRddNoGwAKO1U7tN1tI3l5xxgd6n8xmUFQcmpEDEMmAd3BqvMyMd4fJhkmjm2bRkKvVieuD3 qhb3Eot7u7Yeam3a2epA9Pxrck08xRsbfled0Z659apWsSjTpLf7wLkNkc/jTshXZD4bvIbW J47mHzRMSU7bT61du5B/ZN242vGq4Y46H2pbO1Yw/uogWyTsI7eoNUr6Iw212o3L8vPuT7U2 tQT6mhotrFdWVmdjSXRcb0A4Kit3xd4pTTFSys4yl4E3JJ/CnbHvWBp+rXGgRQTJGo2KBKOu 4Y4FVdRuBr1/Pf7fK3qARnOwL2/OjTqJvqZDJOjqY3zKyli453Z/vVs2SeTp/mXjLgfd9JM/ yxVFF2KttCE2lsueuKZeNMASm3A6snQ/h2ptdATV7gsMct8zWwZoQOZMZHvkelGp2sLgRQru 2gHepyDnoBWnotraWlrDJOwO9iWAbBHfHvWdcT/bNaLQMrQliyIPlJHTafx5pxvfyCS00If7 AuILRLiC4zF/zxPJPqfpVFbt5LgyXIZDGMITwVrdubj7EYFbJYnIDcNn0H406KCJ3KTxM8hz I4xg5PJpX0b6CWxkw6lJJMY2zPHKRlScE/Wt3NhA7XPkgzFAqCU/d+nrWQ2nQytIVbypEAKj 1z71XubbULeMebgrn5ATnNJ+RV090dBqdpcazbxzxLEk0fyYY480eoPtUWm295qnnrb2W64t l+cltvT09apWt67KIEQxyFT0PAx1q3pGtvpkUnlFSH5Mi8gn3pqUkiZRXQ6Tw3JdPG8mq22y dPkiZlyWA7H1p9/q8Nw6RQzN9kDlZpIjhh9KwJfEOpXcifZrhQ7EsTjjb6AVzl1dXlvqLxWa EmZQNoB69zUpNuzL6G99uilea0t1LW3mfOZD+8Yeua73QfDmk2MENxbQlndQwd2ycEV5jFbX MTl5oWVwuT74roNCurjVree3mvWtreNSyRdCx+tbWdvdehk97SOk8XyWs1mltFsa5WQEBRyv 41zJ8LSXgW5UkPGC20n/AFlanhrTkvJkkmuMmKTmHqW98+ld0Y0CEbFGBjp2ocuVWCxxXhTR LW2gXUWk33E5Kqzdu3FYPjbV2NxLpyMHC/NKR39hVW41270y6mtLSfZDC0gbeMquSeg9a4xJ pJjJLKXKlsZJ5rJRbd2XdIGtIboO2MMO1N/4R+9mLfY1Mi4yVHWr0cTSfOVCqBzg9vetTS9W FnMq4Z0lwpP93mtedrYhxTOGlglglMUsLI4OCD2pjDjP613V5Akt7JuiXe7ZA6j3IPesW506 OVGMUYxAx82c8ZJ7YqlWuTKlYwU3IAyswOeoNa1l4hvbNPL3h4+4fn9aqyWexGcjcF9O1VV5 ypH51rpJEXcTW1PVBqiR+XGYgvVd2QTTNJ06e+mZ9jYi5OBwarWFn9oulU5VDy7+gFdxpEum pGbbT2a1f+IuNwY+/pWNR+zWhpTXtHqYd3aGKeMHOON/P8qsum4Expj+6K1ZdGvZ3aU7JAWJ Jj5qtLFsGeRIPlIrnck7Gzj0M17OTyXUR9OR7fjTIbhEuEeW33iM8r0yMVtBhHbOsib5GXCH +5Ve5sALbzJR5YHGRyM+9XoxWaZW0mQtebkBAyW2jniorue3ub9zP8qbsMOv0rT0izZGLh1E Z6lai1bRGRTdRJhCcdcbj7Cpb1GrpWOflge21AMo3Rk5AQ8EVuxXCkEQgAkZwecVVtoZYkKE gOxxgjkVdjjiS4hRIMSYJZ93Bq5O6CEeo9bva4LoHSI5bNaemXpRnuEgQuR8sT85HTpWXHbj LPcQiRQCdoOMH1I71PbF4btLmEpJK3zIB93FZPe9jRJ3sF3aSR3xjuVRmI3Ep90Dtirnh+NJ tfto3mFv5FxE6KP4yXHFZt7rJk1FzKqGRhs3IOE9SPXNO0a2mXxHpskb7oTew7iev3ximvMT 2PcaKKKo5wooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAPEIJbiYjdHtF XZZ0tovMcnAODimwsroGTBBHBqfYsqbXUMp7VndXsdBMk+y3Z1KsjgYaokwVDyScKad5CQwk RjgnuelV2EafuZWOHOFx3NNCLAZHbemNhHpT1piR+WgX0GKeOlMAPTNR53NyKeTmkA5pAKeB zTcZGRTmGaVRxSGRBDjPQnPWsLW7lvKEGSGJ+bBrXu5SjbQe1Yk9vJcys5XPPBprTUksaVfK LVYD8rDp9KtXNw+BsXe3pWYsfkSCMjDMcZratrcQQ7Tyx5yab7givbM8mTNCyN7GreAqe9Pw KTaDmpuURMvGc96kT5hnsKbjJ9KdwBgUDHMap30pjtnZeuOKsk44rF1s4UYJz7HpQiZHOTyl 5PVia3dKg2WZBGCTkiuc3bZwxG7Bziui0q43q77WVemGP8q2lsZwtcuT5jnt0HBKntUF6XUq G6L1PrVmcqLi3Z8bdpGfeodRAIxxnbWLNE7lSAeTIMjO/NMkCiQOfvdBUhP7yBvT/CqXml5e fWi13cXUkuGOxVzVZARBPz/DVmcgr0zVdT+5n5/hqoiLaozWjsH4EdZkbMCOOCetXYrkLaPH jJZcVLHGkdoFfG48jjmtJOyISuzQ0tvkdSfl64rSWsK11SCyYgw+Z2znvW9Y3NtqcH7keTKO dp6GsJxduY66dRbDo4jJIEHUmtFbSO3ZcfvHJxz0FU48hsqOauW7OzhyC2PSojqXUbRf2qzA Y6VDdyyW8kLRDKl8OPapww78VEzq7HPI7VrfsctrkglKsdoyKyWj83VJfs5KyABs/wAJ9qss kpu4pFkxEg+ZfU1Z8teeArHqRQmAtrcLcMybDFKBymOv0qvfWE1w5SEgRKmQDzuOakmg84EE kNjhl4Knt9ags724hlNrfyKd53LIwxTk9NAUVIqalsS1nR0IeNRlf71ZdkI5rcMp3Sk7WjPb 6V1d9ZwaxCDB0U4cg8Eisw+XYXDxiECY/u4weQT/AI4pxfmEl0M22tEtriR18wAttU55Q/1q vGhW4ktVJfzHySeoPU1q3U1utuuzAc8Nk/Kc1StwIi0v3Yxwu7nnvVcz3ISJbhVuRbRAnzix XD/Ltx70ywscSyXLR+XCx2qDyT7g1BeyxTSmOJmZ127CeQc/TsKv3U3lW7eQQcJksp4JPbFL mf3ldStq9qJfLDSOrBsoG+bCjp0pLmfdYrszECMAnlW9/UUmlvcXO+Z4Wi5ABHI9uKdqXmS3 RaSRF3kRrsHp147VSkr26Ca7DY45YipmysTDcSpyvtmonJmjWWNwuCWLDkemMVPLNGIQrAJJ nANS6fZpcRFVdBIxZmcnGB9Kh92PVGakLQwshG+QMWLKc8HsKfKPP8uK32xSKowFXjpzmntb 5ueJfNU/MWJ27cdTVidd9wkW/ej8q23aRx0z3o5gM23IjuS7gux+7jsauSamVaFZIwobhWx9 3J61DFG3ngyNj5sIh64+ta3h/TF8Q+MmjeNks7OIFk/vNVLVk7I6G1Wf7OZLxFe0gGFuFGMj 1+lZ2qXtjPZtNazrE5JMiqME/Sun8YL9k8OGKJG8snaQvZeteXLLaXCkwzhG7I/+NK7TuhwS kdp4Iuo5XmQK32wqDDk4G3vVzxP4lfQ9ZMOxZEaIHBbua4SOW6sXDoXQkYBB/rTAlpdzu180 paQAEls4A6Yqm7u72G6bjqZN/c3Gq3stwqFFZvnKjhTmrqWV8ESV1zbofv44PvXUCK2bSjbW 3lLGEyOBkn61XtGuJrqK2yHA+Xb0UcVSlzaIi1tzJurWSEKhIxMCQU6HPqKpX1mYXCeYnABy OlXr53854EwdmWBPUH0rEmeW4GHYgDk5otZhpuX5tTVFjt0JKAfM0dVGilY/IpCNzgngmoYl 8yLcgB5rVsreC4hJuHljmUEgjkY9MVLVmF7lF0ESBWBVwMOSOvtitJrGyuLPiNNygdDzmq8N gL4lonJVeGJp0qJaOsCbjIeWbNWrkjoLAWLCKTaVkxgA8gHnFa0cKRMGiXGRzWBfGd7rMZJM IGSO571ONZkkgKiPbPGPvenr9ayqQlJ6G9KUEi3JqFxBqSi2dlAHzc96s/2r9olT7bCroD8z L8prChaZ2LZ68t3o85pZQB2/hNaKCtYyc3e51Eq2dzbNNa3ADgcI/WsIXl1Dcs28qzHkEcH8 DTWcKgV/lB9DUSzTIzrkNEecPzS5NLFxqK92bNnqoa5jWSBVJJyy+tLrN80tzHbiRdsfzbve uavtSMDQm1BWTODzxirUIkljjuJyT5jbT65rNwtqy3OMnZG5NPYyWdu8RLXLg+dngE9sVBJY SwW5kuW2tnAJPU+v0pTbnylRdnlIckEYOafFbTaldkvIfJgXDn1/Cle2ol2KF3erFHLFtDeZ jnpt+lPt7oLYyKuc7cMw4BqC7tVWQjBaPouOelUylwYVTGecgj+tWoqSuxczTFmn3zqztuZc A7eARW9o1yn/AAkemCHcEe5hBXPGd45rCjtlUgEHzGrqPC+jSS6pp9ww8xY7hHIH8JDDmk42 16Cuz2OiiigyCiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK KKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA8QsN9tbRe crBZD8pz0rSU8+9Y+m37geScFT/eGcfStZR3FZy3OhE7ZaLAqFoFeLdtJdDkfWn+YkeA7AE9 MnrUsEgeF5AchWPFNCY0fcGetKOlJuzyOM9qAaLgGKTPNO70nekMOSaXACmgU2VtsbGhCZl3 bb5G56cCpo4SIRnHTNKiZjyV+Z2yc+lWQqhPlXOaqQooprFFLMC6nzFHFXFHOeSKVEVc4XnH JNKMAYHFQihh9aaDzSvxmoy3PHShagPPINJ2zQaa2MYpgN37iV9s1k38EkoYuQQRxj0rUZJP lEWOnJNNS1LxMsmcnpigTVzjktXkuNuOScV0kdqtvGsZI6A0R2EVrdlmcYAzzUpkFyzOmNgH WnzMlRSKWoZae3QHChc8U3UTlotp4wBT7/LSxFB/BiqN1MSIx3U4psa2JZgFMfPIBqhEczDP qatyMGhLnqoqlC4aUU0rIV9SzJytUnJGcdDVybA281SlOwg9RTgtSZbD7c70H1q0w3QmQnno KpCWNf8AVg5Azn3qaFmkjYswq5xFCRY0+xgv7lI5ZxAp4eRunFaxuLfT7tv7MXNvHwN38XrW NbEgOy9R2q9sxb5U4LAjBFZPdGsWjefUrZAJFXYrKOM8g96s6fqkCLJJeIUhYjYccnP8q5iI KZgZshQMDPc0BpBLLtYugwcdcU1FFObOvuJ7g3LG0jD2rIQDIwBBplozqVglhdAx3byepqjp /il4pE+0wxzIgCjAwQBW9feILW906NLIL9olbhWAyuKiVxLXYHtiBkNknnFM3t/EMY4rNutU uFKNnaiYMqgc1rW87TQRtNHtd/fINAmgVtw2gYI5zUV1HHNbkSKCB0I65qfy/l3L1PTFVZQ7 ZU9jg0/MRQt2vLK5i8mYANkbsdh0Bo1FDf3FsPtEds0RLFiPvuf5VdVAGAPI9abLBHOwjCZP A/GldXH0MLUNNvrGNiEEiD5m2nqajs2aFGJUFxn5O4PfIrr7rS7vSdOW5nIuIox+8jX70Pof esm30u1vLGe9dvNdyTI6HGz8KvmvoQrGbBLC/l+WB91tsuMEuetRsPNWUSIHKjaGB2kH3qha wPHGUikEikn5QMEc+tTFpLTUvLuCo2gOFJyDx61fK9ETfQkN20MoidWb5vlCnGKZBGzXLzuv mRA5xnBzUk1232XzJY+XcsMjjOfWiMnCMv8ABkt/dNNpLYd7lUmK9cQNuQM2F39c+xroLeFf 7P3NOIwPlVJByQOwasSWe3V03MByXxjOD6U66nzCkClljB/hOcmoeuhS1RasUgluJJEkCR7t uxxuUev61Jcyaa0E0Bd0vQ22Nicxkdx7Z9abbzi0ssRxYVx8zg559xVa3na4Vw0SKI+Sx/h9 x6mjYFqIIJcTSS5DRjzF/u4Pb2rsfhvZC1e6klniluZVDEp2Geme+K4HUbozz+TG+6STBCjq ecAYr2DwroS6PoMMMwzO675SexI6fStFpG76mcjkPiL4pMGpDRoVDDyszMDypP8A9YfrXDW1 nDK4Er4ducdCBWprqac/ii8k05jJBHhS7tuLOOuPagWLRwGUEPPt+/6D0rOpJRStoaUlzbkN va3EF0scUshhPLB+RV2a1iIyF2se8fT8qj0+6aSQQ7CAOrGtDaGLbT0rB1JJ6nTGOmhmrFLE SIirsOwPP5Uxby4hnWZWKSoc5x+FaEkfmOAOPcVE6FmaNo1dR3PX86uNVCcCmJlSSS4I3zSE 7iffvVaQCaOZVtm3HpITwBV+SyQqzqzRgdm5FVnhkWNgUJQjkr0q1IylTvsQ2scdrbESowY/ d9/epo5pPO/d4K/3fU9zSRSYuhM/zNt2ID0x6Vf8uHesiROj4wE9MVopdTKUWtCKSWdGYjyw 2eCBgH61SYAvNIRvaP8AiPp6VJdXDG6Viv7vdjFUbiUmNRkgu3AA7VVncm9kDzMg4cOcZJ+v WohGjgPGOectmnBlhzIq7mIGQaC6FHwNu4cVa0JauT2ylLbcTkt0+lDgID8uM9DREQwUj5QP WlkYSSknoBSArEvt3bsrnGDTTLIq8jK+tb3huCN5LrUJlLLaxlwuMg9qxL+6Mkck7hQWJAA4 z70XVwtoYV05mu3bsvauv0mUPowMsaxsnERJ4Y+tceFZiq/eZyB+Zr0C+sYrbQ7S08slsbmI /h461NVpKzCne9xweSw0g6hGw+0RDHlNyNp71laXciUzYk8oN8zAnrUvh+Szmu2g1JmEbZO4 nggVmailumqTRWrhbbfhSKw3N0+pqyvbtBiJyMHcCe5pge1TTzLISb48KR0RfX8azYpEkI35 2pzgelWWvrSZiCjED7n/ANehqzsht31JbCXyJ/MCAledzc4NdJpuvzDXtNgiYEzXESzFRgYL AYrkppoRH5cKu0jnHB4ArT8P208eu6UzYwLyLOeoG8VT10Fc90ooooMQooooAKKKKACiiigA ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK KACiiigAooooAKKKKACiiigAooooAKKKKAPALBd8y46CuhHHFZGlIOtbArN6s6EK0cb7S6Ak dKfLAI4ItjY+boO9PUfIKdOo8uHA75NNOwmRN60qnjpSdSc+tOpAHWkHXFL2pB1oGLjFMlXe oUd6kNJ/SgCFkKkKBwopw9j34pS4B571RnWeaVGjO0IenrQCL5IUYqNnCgZpjS9z1qnJfRu6 whvnzRYLli5nWGMSM2MnFNWUtGGRSQeh9aa9p9omDzH5V/hFT5AwAAFHQCkgALIVJYAUzB6k VbyMYHSoXjLZxxQBXR28917YpGtpWbckxTPWnrEU3sTkk1MFzhiTkUwMnUbf7PbPK8m9+gOa h091e1yowc4J9TR4jmYLFHjjOT70zSsLZdMfMar7NyepZuwEMTlMnYQMVhzRuXkZkI5zXSzL mGFwMkdKzb5gYCJFCs3pST1GzLeT92B/eFQQr8+RSyfdA9qSI4zWvQy6kkgKvnOQar3H3RUy jcCcnrTXxjmiOjHLYhggLRTMQQVXNW7cILdW/i71HCWwRz84watyxrDAqiib1FBBbQSOHlRQ IwdufWrMjuYo1dAFQkEjvVeyb5DGHI5zg9M1flX/AEYiQgN1HPWk7OxS0KkbgfLJkjHX0qa3 85DiEM2R2GcioNpI464yavWE5t9xV9rEYxSbBeRAcySeZtCluvvUixstxugcgg8EcEU+aQry R8p7Y5FKhAjVhnjv71Ny0hLTULmyeQELIznDeYM10elaxLPZtZJF/plw5Ct6/wCAFc2QH5K8 k5zV/TtTfT5DNA0azqCisRng9aTS3sO7tY6jSXilhn028l2zxMfO5xu9AD7VAFiWWeO3m80R Lu+c4JOcYHrXPW9rA10txPI7KzFmKNg896ZHeC2vXVC7s7BYpm7Ac4IpNdQOkkBRgGUrn1GK jb74x19RWhF4jsJFCakqxyqvPGQazbu8tHm+0WeQh+XYfWpUlfUfKWN0pjZTIxz1Gc7vrWcb KOIu6M67uqg8H8KngulmlKDqBzinTOscZk+8FOMe9Uld6CaSKj2kLqu4hGPQDgmqd/pKOjmP mQjAY9q1YYCDuPLHv1AqQrkZAzniq5mmTy3OYuUt3uYVijljCn52Y5XI68dqfNcqbObCiQov Dx8D8RW49qCRz0H51n3mj7mzCu1Sfm549c1fOiHBrYxopIJ3llkiw6oMY4/HFIimZ1licmQf Mynv6VqT2PmhQ6Fh1Lrway2s3aQtbHCluFI5AHv2o0eoO5PfGSzZRddWAJVPfpUXmy4RGwMk 4Ydv8ajmuJobsCciQj15zV5bi3lVYEhZppHAKoeOarlbHfsdd4B0m0mMkstorywyB1nx3HRf yre8e65JonhyRoAfPnPlIw/hJ71d0m2Gh6HHFFECqDcw6YJ5OfpXmniXVZ/E/iAWsMubSA4A IwuR1NDeq7EJNmNouky3VnNfxRl5kfKMG+/65FdKyhYY3lj2SkfMvXBrM0iaTRoJIxE43SYQ sflwTWhqd/DGViBLzsQGwOBXJXlKctdkdtJRjH1KwChyyAADjpUihkjx1JqAEqgT9akjY7ym M1my0Ll1bAwxpdhEe9jhielNd8SBSvOKcjbo9pbOD0pdAQ1gxjzgHPXNQ4QL/dbjj1qUyMzM FHHSq74ijeVzjaDk1UW72FLa5g63dL9vitw4jwwZnXgD610sM0UiwjcGQLkyJx+nevPbmZ7m 8knIJUsefxrorG7WS0gjMbBl/jJ4xXdKm1FHCql5O5sX0UV3B5pb5wSW2DqvY1hNcxyTCWNh 8vCKfStO4vEtLXMR5lOGPYDtXNavGyNFL90sOdvrVxfQmWiua8kyTZVlCHqT0quimT7h4HrW JDfzINrNuX0x1rWh1ldpXYEJwOeRWji0QpXLe10ViHzjjbUCzusgU96mWRLgjbhzjqD2pwhi Qow+bnvU3Gaf9qRxaE1lBE3mysWZs4APbPtXK6lNl44VOQOproi0UULSrzwc56VyEkhmuZpj 0ycD2zRBXYTeljc8NwQy6xBJM6IkJ3kN3re1e5nvVAB+ff5YxwCPWm+HdLhtdCa/mAE9xlcE dF7GmSRLCWYO0iZwK56rTlobUo+6ZNwDGzxyHY6gcCqw+aVVz3FaN+Glk3BRmNfl/wBoVWEU sNqLhduCcc0cySCz2LFxCkSyBXxgDgd6otgpgqF9waC753ls545ph4PXHf8AI0RVxNmhaQOH R9m0gbk3DgDuSa09Gv5L3xdpUCMvlx3URLYxuw4qte+Kp5LI26RoIDGI5F2jLfT0qt4bUjxP o0jAhjew9P8AfFHK29RtpI+iKKKKDMKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiig AooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKK KKACiiigDxDTowq1pgdKpWxESIpHJq4tZnQSRyAzGIA5Azmp5/ldPTFRRnDAgD60TSq1yCM4 Axj3piExkUppuDTh0pABPFHbNIacBkUAJmg/dJpoPzEe9EzbYmNDQX0KjfvJRgnirO3av0qv b8oGK85NMvhLKnkwnBfGTnoKb7AFwhmixEefUVmx2+ydX/iHXNakapaWgTfhEH3jWPeamHbF uvQ8sR1pA2jbaT5AT39KZwcdRism11XP7u4XjsRWpC6yKCjgigEyQOxI54HpTjLkYFQM5D46 +1OTJHIwKYxx+ZAOc5p4BzhTUW7L7RwBTy2EIJ5PekBieJEOYsnmjS8LYgN1zUevOPtCjOcC pNO+ayUn+8areJHU05QfKh+bt0rF1Itt2kgnPWteTIK4GeOKxtTL7m3DAHShPUp7GW5+alRc q3bihwojLckg8URfcNataGKeo9Y3jXJXCkcN61HJ0p0edzZJIHQZpj84FTEpktoSp3Yzzird 1nYM9fSjT4t0ZJx60l3ky4qZPUcdiFCQcr2rbsLX7fHsPD+vtWUsTJEpYff6V0fh2X91KhQb VGdwqW+pdijNoxWdwkhBXv60kelSvINz4J9q1XlEkr8YzVi12+b81JyHYpxacHType3X/aqV NPWGJolHHoa0NsSzcMATznrUqwb2DZz/AFoDU5ue1JukhAKY5NWjpNu+SwIYjCsD3qy0aG7m nc43HavrxU6DIyTnIxUSbKSuYH2K6gZ9x3JGeSDnNV7mVZJw8YPy/pXUQwxIjRtEXDdyeh9a ivrZZLUIgUF+CQMGnGauEo2RinT7yS0a+aJ0gXGZW5Aq1YX729ystvGHUALsHTgdTVR7nUVt v7Lkkf7IH3BPf3Nalhocf+vnZxERgRjgue30q3a3vCi2IkV9czStbL5cszFiEHOM8jPpTnaQ kWRV2m4JQfw+9XdOa40rUreF3XyXfhj1A9Kg1e1jsNaku4ZvMyclw3Bz6U4QT1RM2JHZXQJi MpEMX3nbuT2q5DbiNZS0qhUTcpJ+83tVeHUvN0+WBZkPnfL8wwc+tNsfKgSRLnc8o/1SDp7m ly2QEqysXGDkHnpUxljPA54rOuZovtSva3CyQ8biB90ntVt4reWPAmy+Mlm4AqW1oUk2hxK7 d2Aq9j61VOmtfTgKvlA9ZR0+lWYLl7jTWtoY13I3DkdfpUVvqohHlyH593zEdKtLsQ9SvfeG YUcS20xSULgb+Q4Hasy3vbrRL2HUorZQ0YILEbgP/wBdbmoxXN48dxbALEpxy3J96qvNPbL5 bIEZx82VyCK2g7LUxau/dKs3xMv76aWNgkVu8exowPzOarw21kz+dZzSHft8yZTkID0BBqs2 nR3MzvJCqEE/d70xNHuA7x28pCtgtEDjOO+acmnsNNp6nSzRXWn2UluFjuH6iRR1HoK5cpcw XhlmlEYxkJIOT7A1pxau9rL5N7IVAACN6/j3rVUpfQDLRuh5yBk1yOUqb1R0250nFlGKdbq1 DovT7w7qfenQjjd371Wlt5LLV1mgOEmG0p2471ozfZ0QSO6xhuAfespW6GsfMhAQShjwegzR HFsZtx5NNaJmOYZFk6dDmpSwUDcOO7VNrbl2GPmKPOOprA8Q3hhsSi53SHFbtzIiLuJyqjNc JrF4b28LqD5a8YrfDU+aVzCvNRhYdoOi3OuaklpbOqsQWZj0AFdILGZofsyqX8rKEoPQ4qn4 Ju59NvpryKDziFCbWOAef6Vv5lheUmMpdSFndgflcHnaPpXdUdkckFrqYTadeOksdvA8oRdx 2+n9ap6pE9zaQLFCxkXqD2FWhqt4LwmNikgzxnA61Pc61LO7iSKMyMuAyDFRG6d2OaurI42S MxOVIwfSlIOz7p5PWuh8tJYmWaPdJ3PSo5NLEqIkSsGHIHtWsal9zFwa2Mq1eWBhLFu3KfrW zb+IhtP2q3D46MnGKW10+7tFc+V5jKvmHHOBVaZhHHK4jX5lIII96bs3ZDWiuyzf6lbvpxW1 lVjKeV7rXPqpUqqnGfx5qRQqx7gMD0rS0nRLrUY5b1AFgixlj6UrKCFdyZ0mmT3Oo2Sx3Ewi jgXCMq8HjoaofahEXwNwU7fxrrNtjp3haOW2kUtIuwuRklu9clf/AGBYkNpJI0h+8D0rjVnI 6ldIszboLJPNQOsgyo9PxrIy7Dyg2VHOO1WrjUGnsIbXaQIj9+qhIDowJIxzj1oUX1Jm9dCO QYA9KryF1kAX5vf0qwzeYeP4v0qJvlzx8xrWJBPGITG5lYk7PlwO9aPhuQDxLpCtyTfQ8/8A AxWPzGAzLlfatTwqj3XizSVhGdl3FI2ewDg1XdgfRVFFFZAFFFFABRRRQAUUUUAFFFFABRRR QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAF FFFABRRRQAUUUUAFFFFABRRRQB4zGoZQTVlapWLFoQG61cUc1kdBMrFXUgZwakuFHniUdCMb cd6jRCzCpbslDCo/GmBHQTxSUdqBARkChsjoeKdxSEA0DGDlqivGPk4/lVkAAE+1Z15ITwKt bk7IW1l3W4VQSQasiMsnz89+KgtfL8kbT8/U4qZ5SuMLUy1YzP1RsxLAg5brg1leTtGMVtrC rSiSXO4jgelQyW53/cO3PXNILXMnyD6damtDLDOAoJVuorQWAGbbg8DjNW1gWIcKPrQKxGgy 5z2qTIHFG0E5FGAOtBQLGMk5prY80HPHpTmLFfk4FJGgB6ZJ9aAMHXI/9IPv0qbT12WSZ9/5 0uu7cocfODjGe1OssLaIOvXrVLYlbluZv3vHZRgVj3wcxvlj17itidMSq+PvqKp6igeyJUYI PNJPUpnPSM/3c8ewojyImbsKScgN9RmgHbbMPWt3qkYLQesql8DvTXGXxnjIqCI/vVqx1lA9 SP50lox3ubCRizifPaMH6ZqqW8wb6vaypjGAfvRjNUh8sS4HFZS7mkexLEdyBTzt6Vt6ZOtv ZyrtO5+MjtWEhYsNoxmtiCJljAbgY5qS7FiIqyOd+GHIHrTkLMMZwfWprKya6WcK+xUXIbFU 08xWI8wHHGfWpZVi4m5QNp57k1Y+1tDkZ7cVWiZiRmk1RxZ2PnucMcACpYMZG+7dk5yc1IJn QjHIrOhuflDO3XoBUv2raxDDkdPen5MDUjuMMjHnJ5FTzyhpNyDIB4FZi3Ct747elWI2zINv AqbWZV9C1JB538K8jOcdKkt2Cl8kbl+UCqtxJM1zFbxAlm+924qKUqks3l5CRkd++K0mmzJW 2HXIuNWlNrbgNFAd0srHBAPpWfqOLS9SxaQP5YDdMEVWsNXfS1maJN1xKCFcnhBn071UMj3V x50zF3bgnvWidkT1NKXBgZoQo3HIT37mrmnCOW3aSZuSfnycFuwAPassyEIQy4GcLjtV6Lyp LbJZQEOFJ7n61N7blJXJNd06PSERoGLgt5jRv19jms9b2RoWVwF8wDcQeRTNQ1K5uZN9wT5m NuCOo7CsqSRwNm7bntTi7ohpLQ6KC9a0UxB9qZw7N2z0Iq7dWVu1rNdRLgbMoSf4u5rn4ruU R26uiug4OR1rQvboWnlbyz25Xkg8U9b3DoMhvJERRu3Acg5q0t3LJIzvtLEYOegxVKe8s3nW S324PybT6etSLqlvC6wkDD/6xvX0FNt7oPi3JZ7hJbnfFH5abQCBzk+tNBIU/NtJ6NWTeXgg uZJYI8RnjbnNVP7TkRi2MkDgH170WctgukbeoW8F7YsPl/coXk3DGPTBrj1vbuwuC1vcNweB ng10ejia9eRrkSPARt2r/ET0FY2r6VNZXzoI8qowdvY9xW0XdcsjKTa1iy7b+KTLIjXsW94+ hQ4rQOs2d5NbujbJYWLqknIY+9cY0bM/pip49oIDg9MA9KfsI30D28mrSOxkvFNpdKLcJcyA ssiZAD5/lWfDqerwgeZEsq98qKxku7u0BVZd6dcHnIq7Fr0boEkTY1J0Y9gjVfRmrc6iLjSZ 5ZofKwhHpzXGLtkDbyQcYGK19XvRJbRxRt/rDkgelZMCFLlM8kHOD9a0pw5FoRUk5tXO2tbO GLRYo44287O4nPA9T71ZjnkS3WIqxj9ADnP1pz31q9mwaIqyryy/wkjvXQ6VBDbWSlTukkXc ZCMjFcra6nRutDhdSjWK6bzkdCeWxznPSqjg+Wu0AgdcVpapeQ3GuzM5Qj7o9sVlwxXCzbkj Z1U8N2NaLYhjkfoWyR2q/bzMbgSKxaVvkVV/hApYLVmMvm7fnOdo7VfgiitgvyYA6HuKlu2w JX3Oj8PWAf7TKQSWjVCTznnmsvxJ4WiW1u9Qjk2YT5o8cE+1SW01zbsRE7BD90g1Ff6xftmy vpA0DAM21eo7VHNLmui+RNanAwaff3cscUUBMkhAVf8AA1296y6V4dg0iHcty43T5HT2z3qa KZrLy9SjRP3LgLFtySDVHxFfG51JpHXy5NgwmQRVVJtqxCgo6mJJPMkIgMjGND8q9galsbKS 9ciMYUDJbtVRi4JBXg1Zi1C4jshax4RCckgcmo5dNBppvVhcQpGCRIrODgrVXzdiyJtHzD5v Ye1LIz+WzqpZe/HSoiQxBGc455rVLSxLa6AmQ2V5UdTSS4lbI6eoqN51L7F4yBmlDqjY60LQ QhyFVR+NafhR3g8W6U8Z63cSN9C4BrOJGcL1rT8MKP8AhK9JB/5/YT/4+KHoB9FUUUVABRRR QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAF FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAeCabeOZArDit9MHvzXP2duPOQ g5+ldRKyNbwBVAZQQ2OpqbG1x1qoaTcTwKguJxLfsoYYQU25nOn2LSqm49MetYVjcyfaXZ0y XOTk0JDudBRnimLIr4x97uKeM+lLqAtLkU0O3QoV989aUUDG3Mixw5NZkYM8/tjvV64BcYHO KrwofMDdMcVS2Ie5UaCW2aWWGTBPY1espXkt1ab730p0ie3JpQCkYXHepuikOcDhuvNIy5k5 Hy44xSl1AIY4C8n2qm+rW8eQMuRxxSGW0QZLEc+tObkdKz4tVgmcR4Kk1eBDLnn60gGMpDcU inaP8acScdaaSKYDwQV6U1shl2+tIDxT1woyeKAOc1a0ma63nJVjxirsUSxQIhHIxU2o3cdu m9sMx+6KiibzoUkf7zelUhLcu3IH7tQPuoBTBsjZy6CRMdDSvln59BTZwSuF644qFroPYwNZ lspREbW38tx/rDnqay34QDNaOpx7LSLgAlzk1myZIX1rogvdsYsYhxIPTNXY0Jul/wB4GqXf 8a1rRd15CvdiP5UPTUUS7qz78nPQAVXWFiiDuegq3fxZYKepOKhDbbmPHG3j61lLY1juXbK2 t1uF+0tgYJHuat+YiqodhycDB6msyWTN190kgU2eZRsSMkhfmP1qeW5adjZ86WFnjDFCeGFM wRwB9KoW95PMAxTfg4Lk1tRQO8gcc7eTUNNOzK6XJrO0lyJJUIXGRUGqQxzwr5m5okOXA4J+ ldBbSb4FPp2xUbxRzudyggcYxWkWjJ81zhC6CRvKJEJb5N3UDtmtdtM22wmadDMy7lU9hVvV tCiMfmWyBX3Zcf3v8KrfYrwxYFwjsgwuUFDXM9Cou25k29+8ZZTEcucMBXYCLyNGs32KzXAP HdPY1z1jaLbvIGUSzvwOMbKvAz28oMxKbBxk8ZNRJq9i7OwSPI96ZER8DjA61C+0WUgG7czn JPt1q7JJIuEs8Pclcs7HjBqvcwmKyJd+VjJb6nrTUbohuy1OTLgyEA8ZrU02ykvWbyWXagy7 N/DWTyQOQfwqzb3M8FvcRwttSUAOe/HpVNdjOOppEH7VtVgyJkE464pz3kcSKiRAjOTnvVVL sJC643Pt/WmRkPLtmcKxPyj04p2vuaJ2GXk8YRrtWQIX4Q8mqCvu3EjcxJxijUJFjgYImxic c9D71BaObSMS7sOBxurSMNLmMpe8aNneSwlG2bmVyFVhx+NQXc6vES8g5P3fQ1Da3ERY+exy zbvTNJFaxSXDO7cdVGM4p8utx8wxHwiqoOc53e1DsZW+Zzx0p0w2OUz756ZpoDGIyqBtC0lb oJMWWVgyJJINuMZ9q1PskFw4jjUklchjwDWWh+03eY02YwWBGckdTXVLq9gIA7xorhdjKB6d DTlLlQkr7ljRrS7sNMjvVXdMjHCHp6fpVG4M0kzJdLmY5dsDnn1qWDXPK00J5+JI23iPsR6V NZ65FLdzz3aKjyqACBkCsry3NElaxivY29wAJIsHHB6HFZt1oEmS1s+4Dnb0Nd5Pa2l5aNMj Rk44cdqyPsV3Fpi3UqfxbdxPG3satVGiZQRxMsEsKlJo2VvU1X8jcM12xjWUHeqkH2qhdaNb lC0Z8tvStlWXUydK2xzHkbgBnke9aOl6NcX7mSNsKoznHWll0+aJN5BdAe1b2l7orBUX5EJ3 FR/jVymuUiNNuRKtm4uHy6ybkAZccEVpwXEsamOJ2+UYG08Y9CKrCU44OGPerFqyLndjnniu ZzdjpSsUNR0xIbJr6GBSyfeIqha3Qljj5xwO3WunkAmh8sLu35B54ArEg0SS2vml8wGPsvYU RkmgaaZZRTxJt49xVtWaJWljjVyFI2HkHNMGW3BBkjrTJb6K0gklkGAeFTPJNR6FJE1lOslm I2f54hkk9h2FYiXcjXsivjErFd7dMDvVKGd7i7fD+XGx3P8AN29Ks32oRPbvZWaDyWILMfvf TParhGzuyJS6Gnp2oiQsixqkrsfLuXPyhB2xWJqiLBfyqu4Z5O7k5/wrqfC+hfaDHfXzC3to ySQ/VyBwPYVmR3un3vjNtQvrdzZRtnYvoOhNJtcw+hh3C3Me03KMmQCAwxxULkqgYEYPatvx PrTa7qpmCLHbxfLCowMD1P1rAkXaVXPyn17UReupDRo2WpNZRyoERvOXadw6VkMCZ2Cgll5+ tTlAocZBPY1XhcKX7v61qlYTGxocsXALjqPSkbhsgVNCk11dBAFwq/M3rUVyrLIVU5C8EnjF MTNbTLBLywvbqRSRDHlTnHzUvhgFPFWkbgdxvYeD/viqNjcyCOKEMREGO7Hf61raWsR8aaOY SXX7bASfQ71rP3k9TRuLWh9CUUUVJAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFA BRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUU UUAFFFFAHiNlEkGWHA5JyetI0xM4mdjGv3QM9R60tmoliAJOKsPZRM4cqSR2zxUJmzQ5ZU4C 75iO/aq9y0/2oGKEKpAJOO9XAoWMAAVKMCLntTQiGDc53Hjj86mZ8YApUC44pR8rk4zjpRco UcqM9aG45oI55pTwvWkMj2Fzz0pkjpCMY96mY7VLVQbMxcnqOBQhMzrrWpFutkUe5F61oWmo w3a4zsf+6agXTUwzHkmqX2byboHB2g9qHZiRc1OZnYRDIUfeI7+1Uo7R3AwvU1sqkcg+ZRk1 MkarjAApPQaVzIOlyAZBGc8VdtfNjj2yjGOAauOMAgHBqIg7QCeaLjEY57g0gxnBFDAAdPxz TFZjKVA4UZzQA5j06Upy4yOopMgjOKXIVR2zQBzWqrMbsmXsflx0xWlb4EEQByMDmqutSbpV TA4xz61bhQeXGo44FXfRE2LbsAQ3PpTFbdIV2EbcnJ70u4EnvjikVyQxYfNjtUMrdHPauxL7 f4QeKzm/hrR1c4I/Ws49K3jsYPcj71r2mRdW7JyeP5VkHOa2NMUvNb4z1oktBxNecMIhLIoB DE5rJhZnmU+vOTWzqUbPaygHlFYkVkWxDSIAMEism9DRblt1DMhX5sDB9zUH2chmWT5HHP50 9C6zgEjANWpXjkmB284w3vSuVYLCBlDFSCfSugteIDuJJK8KO9Y1gPuyf3m2j3xXRwKEj3kd DUS1ZSdkWbWUG34A3DgqO1SnnDcDPYVF50YOF4+lKZQFOMk/3V701Zbk7sS53mAj1OPfFVXx FE+F+6vX1qC/uZyoRka2BIxk8/jQ06zWrQocuQRuBzVITXczrfJ1N3dCF25yO9WyReqGIJBH B9KhkjZ1SyQ4fje/t7UvlrBc/ZAXKlNxIPUily3d2ac1kNitJvPCqx8sLuDE9RTr4k2M+SGA Sp5bhGVYLcnsm49/WqeoTCPSpU2tukJUADOTmqfSxn5s5VeD7UrON2wE564qN45ASrRuGz02 nipY4QXXAZwwGSB2q3BmfMie2A3ZPfjHvVqIJJcwtIFCo3zFqfd2xt79fs0P7jaNmepOOc0z fGSQW2o/DbhnFStS07hfxQrKXVVZX7dhWRIqxGRZYlnUr8i/3a3VCRtBlBII5SGVf41Hesy/ EVzfFgTFEXLDH8I7CtIys7GclcwPmD8tzWpASsK7z8x6fSoPIILNu3ZPGR2q1bbC6+awUD19 acnfYUdCJ2YyeYQCOlX7Xy2glBAUbeFPc1TulRiWUn2AquLphsUn5ehqXHsXGSRr2s72dyrv AGXBBHtVG5gaa2BYFFeQlX7nnpVlbxDbgb+N3J71DdTGYoW5WMHaB2JqY6MbtaxWEZySvp0z U0RzLtJ7c81SRZkZc5pyyEzbT0x61djO9jThvjBKrK5GD0J4ro5dbm1eyFoFRI4V3zSkcY9K 4+SVRAEwBgjJ+taYs57W2VHlPky/cIP3s8kGpkral3bRtaJLprec0siMhULGncn1o1Gzkt7m KNCHaZ8BAPujtXOkRRxKiht6HOemPanSajNlZJJWdo+VOeQalp3C5pSQS2UjRTKVz04zmmrP H91Ww/pUdp4hd7kCd1YcDJGcCr2s2djcR/bbCZC4wGhUc/71V1Fcqm4TK8g1ILxFUnI6etVZ NHv4rZLsRGSFhkOpzxVCUSRkLIjRuRnDDqKfLcfMb1rfJIAob5h702XVoItylixBxjNYIka3 YOhw3oahmkMsrSMcOe3ahwQudmhcazM7kQny1PGao5kkJLkysenPSmKfmJyMmlBIYc4wOvrS tbYltsXA25DdRU2nwO93H5abnVgVU9OveqyqTkdh0rqfBWmf2hezyyBtkKArj1p3UVdha50n izUZ4NEFv+7DyKonAXaGyO30rzqFjvKrnL9a3/F2ryahf/Y3BUWvA56/WsRCI4NiKBk/Me7f 4VMFpqW3Zi3MChElQqQeoHaqkhzkEDHarpZDuUHg1Wkh38DjHNCEyEMC+3uRRb2TMpdTuJJ4 p8cJcuMhAo4z3qewjZ9wLbG7c1b0RKTuVo5Y0mwy4I/iBqnO/mXJMh3Kc8Dj6VoXVsYpjLGu +L+Jv7pqs8A87oTu5HHWqTE2Qwo2cgYUcKtbnh6Jo/FOkbmUf6bBx/wNazIFeQMUG4L1Fa/h hS/ifS2DYAvIThuv3xUt3GkfQdFFFQIKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK KKKACiiigDw6wlVYgM81oBs1iWKlnAzxW6i8CoN9xf4aVOUdOfu0/jFKn8ZI4xTQmhFyOKca Yh7080mMD2oxkfjTScr70BgqjPWkA6Q8Y4qFk2r25pzypuAPc0jsC/HQUAAXCj3FRmBGYlh+ NTHpmszUL7aDDDy7dSKAZDc6qls/lIm/B5Nadndx3UG9Dj1HpXOJZOzE7Sc9zU0QmtGyi7Tj p2p2EmdEzYOBz60wsoBJbisiK9lklVHycntWn5JbA3cChqw0wfBA96UFRwPzpSgX3qOkMO9D yJEhdyAAO9AUmnMqsDuAPHINAHM6jci6uQyLxmteFCI4yeuBWZerG13mEfKvU+lacRz5ZD9c VQkOL7A5C7m3HAqMyv5ZZ1wxPQVYmjEdy2OeM/jVWY/6Sidj1pJ3DZGVq6jytzfezx71mHkC tzxAn+i27Ad+1YoXKgdK2WiMepCOtdFoagzxEjhUzWMLXMwizyRkGt7S4pIT93LBcYpN6FJW NS6QP9r9DESPyrnLHLMMcEDvW9PI4F0GTB8vGKw4VMLMvtxWe6LQ/cWnz9PzqeVVVzk8gCoV QB9jgh+DmnSKS7Ec80NFGlaicQ5GAgOeR/KtORy8cbDdvK8kHjNV4VeaO1OB8g4zU7+WEG6X AJ4J9aUddWKT6FqaaS1jBZsuQMLjr65qtJfSWsyyTKVgkG5T3iz7Uzf5yyQNnevzSP8A3R7V LbwQuG/dF4XXA3npQ7bgrle6aFnRwWMb8785zmpoLSKPL20heT+9ng1j6hu0q7MsTKIBjKHk E96s6dqls6KzZgOMYYcU4q6CTLxDxSCHeDM3Jeoi2yYXDyblwUP19qdc3Egj8uMrJI4+UgdB TbZVNkVuABjp7Gh6AldEM979kzcSIpIb5VB9ahs7uXeJ2YG4A+UY+WPn+dVoYJLy6YfwqSA3 UY9R61vyWMdrpVvEuN00oU5HJAp/C0Ja6G/bwRiFQ5iaV8E59fSuntrWwtY0t/LgyFySVHNe fYJ8zAPA4Oay7i8MTrJJOw9fmOTVtsjlR6dNa6aXuppoozGuNxIGB9K898V3umxG1fSTESGc MduQAe3vWFe3U1wzpb3Urq3DZYgfSslnlVfL8wBACD3waPZttB7qZqNbyQR2yiRd7tkYOdox 3rNuivmHaRnJzXS31vp9r4UgMLs928gaSQ/0rni6LhwAW7g0nGwXKBcEjBz9KmSEyQ+ZvGB1 TuRVeaRRcDaRscduxpAyo/Xr2puJCZO7RBsKu0EcZPSqc0e/5V4wc5qRsmQAFePbpStL5bhc Ak9TQrobsMUMijGSM8ileQg5zUxcAYyMUwRNKzbGGQOc0766iuQm6YELmke3uvIFyELRZxnN QCNxMc9ulWkkmjieKP59wyVPQVW2xK1HJnOZI2xjpmp7SWVoZHeXiIYAPOc9qt6RBZ6hbPHd s63Cr+6YHpj1qhYO7yT26oGYuQT7A1LaehootWZZbe7AADnnjpioJJEVio5rSuLQMEe32jaM MfU1nTpk/P8Aw4AAFQtxyi09CKMF3wFwPWr4ur1EKWzrtYANxzgelQPIkaqhPGP1qO2kYSqV 5I547Vb7ojqb9n4jvbJIYZl3wqcvHjqPSr97c6brltI7sYniA8qMfeYnqM+lcfLJJJOXdz16 Vd097dLotP8AKgXIJ4yaiceqNItPc19Q8Oxw20M3n+X5y5CtzisF7YI+xWBI7jvS3N/PJKSZ mIJ+VCegqF5zcBQi4c85oinYTSQpUqSCMH+VRSlvLZ8j5O1X4HSW38idP3gbII6mrV94Yvhp 8d4itJG5+6Oo9qtE6mTFKZ1GBgH+VdvoWpvpGkT2skXkpjeJiOmRXN+H9L+165b2c0bJhsye wFdb8Q9QjhtrOyhADP8AM4UD7o7VFTVpFw0Vzh5XeSZpmbczsevWhX2jBqHcOOeafxgfLx3N VYVx7DJz0FMywHB47VJ5iEcDj3pN4z1pMNxg6HJquJGinypOPrVxypAI61XYAt0HFNdhMt2t /JZCbyyMTLtfcN2R6D0qxqN3p01rbx6fYPDIn+tLPnf/AIVncZ5HFLjsvWiwWHRTvEuFA5Hp V/QCG8VaSc4zewHA9d4rLJYHFafhvnxRpOev22H/ANDFIGz6FooopEhRRRQAUUUUAFFFFABR RRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUU AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAeCaYW8wccVvLWNpuCeK2BU2NxzkKMt0pd2IuAea Y+SpAFErEBFxjvmgB4GABTj0pB2pe9JgIAMd6jlBIwKkzim4DZpAULrzEiXywSScfSqsZmhu hvct6iteTakJz0HrWM94JrzbGnyjgmnfQXUnu7yRW2RKcNxk1PY2KqPMk+Zz681mXsbv91sY NaFpepHaDzXUFfXvUrUaNDYq9APyqNrdJT8yis2HW45bkRFMKTgNWwOnByabVtwepWjs4org uBnHSp2IQZoLcYx3pkxyAKW4JEbtu57VCsqvIY1+8BzUzDAxSRRIhYjq3U0xjF3b85wKkOAP fvTcccU2ZC0RG7bnoaEBl6sf3bCOPaSw59asW3zGJRjtVY2tuXkivJyGKfujn+L3q9aoWeJc hWx+tW1aIkTX5CTtjk7R0rOBzeBj0wauT5R5FflulUwG85z2C8VMRSKeryFrKAk/xVkqcnNa uqJmwjJ/hOayY626GXU6/S9Ktbu1huZF/eAcEGpJF8u7IDAljzU3h8ltIUjsT1qGYH+0OetZ Lc0EvXws5GM7TmsGI+YkrZxtHJrXuH3Q3ueuzArGsmKWzyryyncAemQapbgiMO+/c24NgA7u 1WvMPOevApNS1KfV743lwsfmbAvyLtGB7Uw/zxihoaZrW4uYSpWVCJQAFParcNmzmeCQhge5 /hqxFGslhErKCdo+buOKzpra6EyvblpGf5SScbQKfK7WFzJsdcefpqMgBa2JB3H72aI9Wa4U pakbyeS3FTWlxb29wq6kX85f4jyMVBNJbkXBSFJTL9yXONp9cCov0saqPZle4R1nBuF3NKuF LdPwqy6QxMssRBfupHDCoh5s9oi+fuCcmJl/UGqNzeOjYbO/OFRe+KdlbRi9TThitpWkurfd EemA33fqDUMurM1u1kiLPJu+R04P41BHZ3GqEzv+5h42xrwT9a3LezjgVPKjXPr6VShbVkSm ug6yxJFCI4ipHDAjkVNqLyG5tokAAh+b86mgASTdwCagnOSZ0+cNMEwOoAGc/nSeskKOibI9 Rw1pgtt3OAcHBxWRrFnaQX6vaq0lsqLvV279zVzVmEiJ8rqXcVl3NrI2RDuZj1BOapLUVrol ubWCe63WeWQqH2ju3pVyy8OQaklws7pbGID7xyc+grGmuLmz2q0oQ4BOB2q7pM88k8jrKYkP R3GTz1OO9VFO2gpWNPT9TXU7uzsNXKGzhyu1VwTzgZqp490ODR9QjazTZaXMeYwpz8wpz6Xp 0ehteNfbL1HIVXHEmD1HpWTqWoS37xNdOZIsDbn1AqdmD1Rz9xGqxhieO2KqbneQH8qs3bPL uHUA9qro/lToJFIArZbXMXvYtxNlH+bGOd1NB82ZSzDp2p8gjIOw/lTYIvMJCtgr1qdNyh8k Z8whSQMZwajEjRsVJIz3ouyTOjbyc/LnpgVFIh3Ao2VHc0JAWXUAhs0ttO8dyShG0jByKiWY tEflyBTo3VlHGDik7oEWkfYzhfvHPzdOTSR4TDJkOPTvVcvnHYVNBhZt/ZBlucZFSik77l+1 uJQwyRsAGAKlm+yR3Rluy21l4CnPPvWdLdrIGjtlKozElm5xVR0L5ZpeBxkilyXdy3KyHyXc QMoGSeqkiktwrAys+Npyyg9arMoWNsndnvToF3Fo1cKCo5xWqStoY3uaV9epdLEkMQjWM9fb tmoZJkfAz06AVRLvGjRdTnr60pG9VIP7wnAFLlG2SzzeY21hsPr6U6MZxtyNpoS3mhlPnx/M OuakWMxMxVsk9qTaSsBPBGwcSsd2OAfSulsNVv5ltrWWZRCH3LkZyBXNKwCMcZfAxzxWnprR pKrSMWULzj19qzb0NIvU63Sr61/t+e6nMY3p5XGAAB3Fch4suJJfEc6ynAChUwcgL2+lSqY5 dSeZxut4RllLY3H/AOtWVdoTeSv5vmyE8yHoT7e1KKV+ZjlLSxVaQlvQ1Ikgxtwc9c0+SFJF 81zsf+6OhqDzAqhUHFaXXQzZMr/NjpTieTUWeM9DVu2tPOtJLk3ESGP/AJZt95/pSehVyEtx 3pMDbkU0yDdijcBwPWkAoYjrUilCG+c5ABGKjIyasy3KyWNvbLCqmJizP3bNMZBnJ5PPrWl4 bB/4SnSdx/5fIcf99istRwQAeK1/DWD4l0nH/P5D/wChilYVj6CoooqSQooooAKKKKACiiig AooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKK KKACiiigAooooAKKKKACiiigAooooAKKKKAPnmyuDFMvPGea6eNgwDDoa9N/4R3RM5/sbT8/ 9eqf4VMukaaowunWgHoIV/wpWLUzzAj5lB71JcrjywRXpf8AZOm5z/Z9pn18lf8AClOl6exy bC1J94V/wosPnPLx2p3evTv7K07/AJ8LX/vyv+FH9lad/wA+Fr/35X/Clyhznl/SgYwTXqH9 lacf+XC1/wC/K/4Uf2Vp3/Pha/8Aflf8KOUOdHkF/Izx7EOST0qpa27RSruXknmvaP7H0zOf 7Os/+/C/4Uf2Rpmc/wBnWmf+uC/4Ucoc55bJaxyIRtH1rn7+3Mc2wfdFe6f2Xp3/AD4Wv/fl f8KY2iaSxy2mWRPqbdP8KSiDmeDx2crsCiMSDxiujiaSOFPMGGwBXqy6Rpi/d060H0gX/ClO k6aeun2h/wC2K/4VQlKx5QZsZA61FBdLNcmIAnA5NetnR9LPXTbM/WBf8KRdG0pDldMs1PtA o/pSsPnPLJGAUgck01eEwOfWvVv7H0z/AKB1p/34X/Cl/sjTR/zD7T/vyv8AhS5R855P2FVN RjkkiUopJB4INexf2Rpn/QOtP+/C/wCFL/ZGmn/mHWn/AH5X/CmohznhV1YyR7ZJWy5Ix71q 23FxFkjJI5/CvX20fTG+9p1ocesC/wCFA0bSwQRptmCOhEC/4U3qhc547dKWuJMnnPWoAMJI T9BXtJ0bS2JJ02zJPcwL/hTf7E0kjB0uyx6fZ0/wpJWE53PDtUQrpoz6CsWM4GMV9FvoWkSL tfSrFl9Gt0I/lUf/AAjehf8AQF07/wABU/wrTm0J6nlnhpgdMZQM4JqKZv8ATXcrgButevRa PpkClYtOs4weyQKP6UHRtLbrptmfrAv+FQlqPmPEZHzBcnafmzWdaBTZSAkgdq99/sPSNpX+ y7HB6j7OnP6U1fD+iqu1dIsAPQWyf4VTYKR4AMhv6VKsg7Dvj6Cvef8AhHtE/wCgPp//AIDJ /hR/wj2if9AfT/8AwGT/AAouPmPMYECWke3J+UdfpUsbbdo2nA6+1enjSdNAAGn2oA6AQr/h SjS9PAIFjajPXEK/4U07Et3PIHhEmqSyP80ZUdRUN5ZoW3w5VuAOeK9k/snTc5/s+0/78r/h R/ZGmHrp1p/34X/ChyC54vLFdyhg7hbVeSFGGY+gpun6czS7pVPnKflYnIAr2o6RppGDp9pj 08lf8KUaVpw6WFqP+2K/4Uiud2seZ4ZQcgkdtop0YKYxjHevSv7L0/8A58LX/vyv+FH9l6eP +XG1/wC/K/4UX7iujzFgkjnJIC8gg96mCvBpVoAcPLIWyR616P8A2Vp2c/2fa5/64r/hTm02 xYKGsrYhfugxLx9OKm2tylNWseR6oku23eR9yiTpjFV7iZ5P3UYGxz90dR+NexPpGmyAB9Pt GAOQGhU/0pn9iaTnP9l2WfX7On+FXfUXMeVWmnwljPcxAqAflPb0NWNIhjudWhaUYTeAMD8u K9ROl6eV2mxtSPTyV/wpY9MsInDx2VsjDoyxKCP0o5tbiujyb4gW8sE0ckigNvG0DoB7VyRU tEoL5VBkg9q+hLnSdNvJPMutPtJ3/vSwqx/MioW8P6Kww2j6efrbJ/hRcVz5xkK+XkdWP6Uj lGjXaDleo9a+jf8AhGdB/wCgJpv/AICR/wCFH/CM6D/0BNN/8BI/8KrnEfNa5UjP5UoGZsAk DHPavpI+GPD5OToemE/9ekf+FH/CM6AP+YHpv/gJH/hRzoR82SRnPU7c55pZY8Qhg2Mcj3r6 T/4RrQf+gJpv/gIn+FIfDOgMMHQ9NI97SP8AwoVSwrHzhb7Fti3cnmpUEZdd3brX0WPDOgAY Gh6aB6fZI/8ACj/hGdB/6Amm/wDgJH/hScrjSPnWQAhtinb2qPzApJAJG0A19H/8I5oWMf2L p2P+vVP8Kb/wjOgf9APTf/ASP/ClzAfOm3aodRjPUU/CnnBI9K+if+Eb0IjH9i6bj/r1T/Cg eG9CHTRdN/8AAVP8KHIZ84T7AoBGfpUbRhVJR1XjoetfSf8AwjOgk5Oiabn/AK9I/wDCk/4R nQM5/sPTc+v2SP8AwpxnYSR80xZOVByalaIogx1J5z2r6R/4RnQM5/sPTc/9ekf+FKfDWgnr ommn/t0T/CnzhY+cBckcFi3QEnvU2Co3ZyT0r6H/AOEW8Pf9AHS//AOP/CnDw1oIGBommj/t 1T/Ck5JgfOb3A2HYOelXbS6dImyQuO3rXv3/AAjGgZz/AGHpmf8Ar0j/AMKX/hGtB/6Amm/+ Aqf4Um0NaM+ep58HIOCew70m4KmSPnr6GPhrQTjOiabx0/0SP/Cj/hGtBP8AzBNN/wDAVP8A Ci6sD1PnRppI3BUjbjvT0jV23J35r6I/4RnQf+gJpv8A4CR/4UDw3oS9NF04fS1T/Ci6A+dn j2kuWqEsfvg5XuK+kD4b0IjB0XTiP+vVP8KT/hGdAxj+xNNwf+nSP/ChPuFj5yEiNx09KkUc 4LYr6I/4Rjw//wBAPTP/AAEj/wAKX/hGtBzn+xNN/wDAVP8ACnzAfPowB7gU07uCK+hf+Ec0 P/oC6d/4Cp/hR/wjmhf9AXTv/AVP8KXMO589AOTkEc1qeGlK+J9K7f6ZD/6GK9x/4RzQx/zB tO/8BU/wp8Wg6PDKksWk2MciMGV1tkBUjoQccGlcLmhRRRSEFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQB//9k ________________________________________________________________________________
Date: Sep 09, 2005
Subject: Re: Hurricane Katrina
Hey Barry and all, I wonder how our old mate Milt Concannon faired in the Hurricane? Last time I checked he was living in Gulfport which was pretty heavily hit. Does anyone know how he is? Cheers from Oz Russell --- Original message ---- >Date: Thu, 8 Sep 2005 15:06:10 +0100 >From: "Barry Collman" <
barry.collman@air-britain.co.uk> >Subject: Commander-List: Hurricane Katrina >To: > barry.collman@air-britain.co.uk> > >Hi All, > >Bert's posting just now has prompted me to do something I should have done last >week and that is to see whether any of our members were caught up in the >hurricane. > >If so, I trust they are all OK. > >Is there anyone we 'should' have heard from in that area? Perhaps a 'usual' >poster of messages who hasn't been heard from? > >Best Regards, >Barry C (UK) > > =============== =============== > > ________________________________________________________________________________
Date: Sep 09, 2005
Subject: Re: Fwd: Status Report from
Milt Concannon Many thanks Keith for letting us know that Milt is ok! Cheers Russell ---- Original message ---- >Date: Thu, 8 Sep 2005 14:14:28 EDT >From: CloudCraft(at)aol.com >Subject: Commander-List: Fwd: Status Report from Milt Concannon >To: commander-list(at)matronics.com > > >For those of you who know Dr. Milt Concannon (most recently of AC-685 N414C), >here is his status. > >Wing Commander Gordon > >Life is not simple anywhere. Probably less so elsewhere. > >From: "Milt" <rocket(at)swmrmc.org> >To: CloudCraft(at)aol.com >Subject: Re: Status Report >Date: Thu, 8 Sep 2005 12:25:05 -0500 > RPD=4.00.0003; > RPDID303030312E30413039303230352E34333230374236372E303031352D422D4 D3936762F49374B305A4157444C546645354F3975413D3D; > ENG=IBF; TS=20050908180117; CAT=NONE; CON=NONE; > > >Airplane family and house are OK. Lost my hangar, barns, many trees and condo on the coast (sat photo attached ) is toast. > >We are lucky compared to most. > ----- Original Message ----- > From: CloudCraft(at)aol.com > To: N395V(at)direcway.com > Sent: Thursday, September 08, 2005 11:33 AM > Subject: Status Report > > > Dr. Milt, > > Are you / your airplane OK down there? > > Wing Commander Gordon > > Life is not simple anywhere. Probably less so elsewhere. > > > > > > >Airplane family and house are OK. Lost my hangar, barns, many >trees and condo on the coast (sat photo attached ) is toast. > >We are lucky compared to most. > > ----- Original Message ----- > From: > CloudCraft(at)aol.com > To: N395V(at)direcway.com > Sent: Thursday, September 08, 2005=2011:33 > AM > Subject: Status Report > > > Dr. Milt, > > Are you / your airplane OK down > there? > > Wing Commander Gordon > > Life is not simple anywhere. Probably less so > elsewhere. > > > name=condo.JPG > filename=condo.JPG > >/9j/4AAQSkZJRgABAQEAYABgAAD/ 2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsLDBkSEw8UHRof >Hh0aHBwgJC4nICIsIxwcKDcpLDAxNDQ0Hyc5PTgyPC4zNDL/ 2wBDAQkJCQwLDBgNDRgyIRwh >MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjL/ wAAR >CAMABAADASIAAhEBAxEB/ 8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAA > AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwR VS0fAkM2JyggkK > FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R 1dnd4eXqDhIWG > h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ 2uHi4+Tl >5ufo6erx8vP09fb3+Pn6/ 8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREA > AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCS MzUvAVYnLRChYk > NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN 0dXZ3eHl6goOE > hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tP U1dbX2Nna4uPk >5ebn6Onq8vP09fb3+Pn6/ 9oADAMBAAIRAxEAPwDIFL69aO2KPStBBx6UdulJ1JI6U4UgVxPa > uk0u1HkwMyngEkVl6bYm6nUsP3YOa65IIVtI3Vv33mbfL7BfWpltY0ih6blliVAC WPOewqa/ >OCiZ5x1ptmv+kSOTlNuAfQ1DcyiebKn5RWbVjQYFHAABpGHy7fenZ5/ Cm9Sp96Bj9uMVXkYN >LtB5HWrEreWhz1IrIQTfa/M2kqM5x3oSuJmmozxQ/ wB7YPTqKgifau5iQT0zUhlCIS+MmlYL >oUMVIH9KUk59aoR3kcl2Yhnjq1aC89O1Jqw0xBGTJknr7VKkIJ57Gmsx3D+ dO3kGkxllUXOB >wuc1oIE+z5PU8DFZsb4Tcan+1eXETjPSjqDNKF/ 3QAzgDAzVWeGO6JRz1BOfpTpZ1jtty5PA >rE1i/lsrMSwlSxGM+ maduwisvkNLcNjKRn88Vz13qISRJoECMr5TjpWrpSMdIvGkO53JOT3r > n54z5Y44B71S3Ey1PqcmqXccsqoGHB2DFPu1wCAODzVHTog86qT7mrNzceb kAYCnFEkJMy70 >j5AKqA/OD3GOanuCJJhzjFVjwT9a6IbGMnqb+m/ Ner5hzxkEfStG7bOjTgdcn+dZ2mI/2pGI >5EfT2q7MSdMnGO+aze5a2MPzppbQW7SE26HciE/Lu/ xpLiZ0th8nzY5z2qA71iDD7uQPxq8o > EqDeeCMVbEjQ8IaZ4cu9PvrzW7oCSJG2wliCB6r6muQkKGeTywREHPl5OTtzx n8K0ZbYRWjx >k9W3YHHFZucda1jsZSVmKDzT0wWUMSFFR/pRk1ZKJ2kLttLHYOKkVAUOw/ KtVWfjgUu+RoxG >Dx+ tTyj5i3E6BNq4PvUcm4HgEA9zSxwrHblvPCuThkxSCZ2jkjCh2HFZ21KvZFaaT ewHXbxm > kqaC0Z5Nh4wM81NKkezG3nsRWnMlsRZsqY55oGQ3tUv2dkXc1NAOQKpNCc WKzEALg89qmtYA >Y3dpPLQD72M7j6CnhFjJLkEFfm9vpUUbB3Cvnyl+6o7+ 9F0NJpiB2IzjHbAqWNd64xzSnB2x >ouOeaJUaBty8g+ lRzFWVx32fC4J571E8YQEMPl65qRLwEgEUs0gZCMjpUpyvYbsUw6v8uKtC >1lFkbhSPL6Y75qiMhv61c+ 074hGQQg64rSVyI2C1EjA4YD1NbMEUfkExSbWI+UnrIe49sVRh > RUHyjjuKjlxETInBz69KylqaJ2Hi3PnOXPTsKZNOPMA2qAgAAFNe787Lou0gYO D1quI5HcOw > IB9RRa4XRYYKuSpyAOOKVHCxA7gfXimqr3OI48BfX1qwwNr5TpGuF7sM5P0 p+QeYiLMuwmJh >G43K56MPanM7MCFzmomup5Z2mfDZOSqcAfSlklEmFA56YzSdr3HFsnMh+ XkZB6U2R/Mww5kJ >5GOMVGqGEEsvze5p6MsuS/ ykdxUuN9irhIQIchsH0pivuRfMIA9qY0m3djBXNQhi464HpTsK > 6JSzeaN4xGaVZEDlnyW6AGmhWkU4O3HVj39qkUiOMtjJI4GOlADSxKEj5j0w PSoBD0ZuAx/G > pFkBVCQNwPWpFVndnfp14qtibXFEMJIckbxUgKKrycZ6LxVSQMBuGeemKY8k hCJLHn0ApNXH >oi8IQIWkKhy3U56Go2QIGIHJHHvT4ljCcKyyn+LOR9MUyZ8rsyNw/ lSuFiFG2Es4A7ClWNhJ >lzyeR+NRffkVI9xqUsytsbqvXNVZi0Q4x/ MenHeoyPnxuxnrUrSDywem7saImJDHbzjHI7Ui >iLZ8hySc1HKDn5BwOtXPMzCoGOOKVoBjcOp60XE4lFmbAOBitbwwCfFmjEt/ y/Qf+hiqT2+0 >jbkitPw2pPizSOmPt0HH/ AxTclYSTR9HUUUVgMKKKKACiiigAooooAKKKKACiiigAooooAKK > KKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKK KKACiiig > AooooAKKKKACiiigD5qoo6mlArQBAOamihZmCjnNEKFmAxW7Y2IK7mHPaoc 0mXGOhY0+DyIR > xg1oAlU3DrUKrtXb6VWlF211uaQLarjgdSal6lxNTesNqw5BcZBHcmoIwVhAbq B19aRUmlup >Gf7iDAA6UTOEAAHPQUnuFxIZPMViPXGakj+ Z8DtSQosYA7dTSB9m4jueKXoMhvJWe4WNOexq > aKMpGFOAaQIqneR8xp5K4OTzRcEQTQK4wOPxqBrZ94G75cc1FcJI9zuy2UH GOlFpqPmSus42 >le9FmBbitYoRvC4Y96cxZWYZx3+tQy6jG0LeS29+gAqrpsl087+ eMq3r2pLzHsaAk3t0IAqV > WywNRcggGlAw3WkwLYIPCnvzRPcFEESKWPUkVX8zacA8mljcCRmJP5Uhkq3 TvFt2kZ4O6qt9 > EJIAv3sc1aeWMHO7PtVWWfBYn7o5xTv2ERW7iO1ki2gF1IHtXN3SFU25robaV LqQMB8pyKxL > 1cMwHQHimnqJlbT8i8Cj86hkBieRSc5JPFLay7LnI6nNMuZA8zMo4xitepmZ7E mU/SmYz/n3 >qRwQ59aaGCqe5P8AjWvQzW502lg+a59IRTpf+PeZexzRpvDSt/0zA/ Sh1IQjruyRWMTaXYwt >mbbB6CTNTwgbFwc80yVD9lOP+ehFPtIyuW9+ lX0JtZjbuzkuMvECWXhlrFkQo5QjGO1dbA8k > ccm3ALggkiudlsZhcOCpOOdx9KqErEyiUSSefSm7qnSAyzCMED1J6USWskZw Rn6VtdGTTIKX >IXkHmgjtR5ZJAp6E6jGd8nnrV62gYL5m/ wC9jpUBhw453DuK0BJFFGvqRwB2qJ7aFJdWMmQx > t5iHpx9aiM23dkDHvT5JCGAxk9RUFwSzqdnIPOKzitdSmNaUtHk5x2qKORgeD V+ILMpcoRt+ >6OxpIbSGcsSpWUHkVakhcrexWZmk3Z7UKfk2fjnvVie3EAwh6+ tV1HB4zjqapNCaaJYA0s6Z > P0omdvMZB90cc02IssoKJgjtUgQs24x8ucDJ703ZMOmhCiknNWFgJOSetOW3 LEkkKV6jNNLr >vCoc96lu+wJW3IpISM9MVNbskSkFfmPIyKjUmRiGySO1T+ WB85G3aOaTk2NR1uWi6tbeawxM >eMdsVVciRVDcUgmLPg9O1NllBAk2Yk+7moUWW2mg8lIjgZ5qfLSRpE+ QiHdimQ524Zfp7VNt >J6kZ602xpIAuxjIhznoOmKkmkF1EAwC+ XUREhyzLgdAcVWk4VioYN3qVrsD0E8wlgqAYqVUJ > G5RyKpEs0hwM4q48hgiQKmD061bRKI5zLI6kqVH8RoE4HbHvVsgtDknOR0xV CTCkgjHpSi7j >Y9Tln8sg55P1pF++Qpw/vUSs2zecYzjAqRYyzBlbDe9U0K6JjJsUo3zH+ dOhVpV29H6gUbwv > ylQzU15THzjBNQVdDZIZRJjbx7VMjbBjBLenpSrdt5e1lDA9KiMiq2DkA09WFrE 6vGcAjJ9u >lEiqSXAAYdar9HyOhpFZlJZzx0pNMQ7cqpuyfrVN2dnYquVP51P/ AK0gEYjB4NThI1bgbmP5 >U1oDVxkShl3KCrJTyyru3jLkd6cw8vBk+ QHoq96Ei3EySD5uwpOQJENuBuweSOuasMpK5Xlj >xikXBUsQAQcYoZyCcDJ7Cle+ wysiSrcAPGwHfI4q0ZUYsobgdhTBds0RR8nk8eh9ahwm3Ckl >u59aNXuCZOJhI+3r6Yq/4aYHxbpGP+f6H/0MVik+X838VaXhI/ 8AFWaQGP8Ay/Q/+hiq5VYT > bZ9LUUUViAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQA UUUUAFFFFABRRR > QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFAHzUfXsKUHJFB > GabyDWgGhajGDgZJrorbiEVzFrIFkGeldHYybotuc1jJam0XoWx0pCudq7QVJ+ angCp7eJ5J > xj7o9qAGB5TEYwwUDrx1FQMEeTI6L0q1cr5ty65A2jGBVcrs4WiWoJWFDAkgH pTIslyTjaKF >G0kjrR5m1goXk9aQyY4Y+9U7jKz9etTscKSDzUEPz+bJ1wcDNCTQMHyFL+ oxVGS0CR5z871q >xxqRz0FNeLLhmGdvApXY7FTTbMW6MWAyTkGr/bjH5Uu0Lx/ KmthFzQ9Q2EJGelRu2CQOTT8Z >HJx7UAd8UgGBcAE8sf0qVRtXnmmfxVKqnHTB7e9AxFCMC2OKqTL+ 5kCnORirLj5CM855qCZG >W3Y7geDQlbcTINERRtG7lGO4VlagMTSDrgmtbQOVkOASc1laiMTy/ U0vtA9jKtxzI/daiYfM >ffpUlmrNJKc8elNkyryZH3eldVjAqNwSfwNRD/P51ZEe87e5qIphiPQ4/ WqT6CtqdPYkJAxP >GVFKXDYX+6B/OmAbbcc9VFRFivPrWSRpLcz7k+XCfTzTUdrIxzzUt6pEK8E/ vKgtQQSQM96a >1QupoxSlGGeM1KNszhPXO7/ aFVAc4PXJ4qzHGxfftKgDr61LLIriwtY3BUZbHQfw+1U1V4Jf >MRwuM1oysuADnJ6moruzdYg0ZyTTi+5MkYUytPdO+ M5PJHrUjxLBgvyCOtTGN442Rz8+emKS >QK21TyOta8xlYggMYmyQQCc7j0qtc3DGfcmMD2qe6KhCFPOegqiAf4+ BVxV3dkN6DzM7sDnj >vUyuEOTyo9ar8E9eBV8QRzQ9cAVUrISI/ t2QFVQFHSpLaQI7M5JZhxVYxJC5I5x61NCBJEZN >+xs9KlxRSlYlAeUlnHy0nmIXCBcoo5x/Wo/OK5B+ YnuKQbowCp4cc0knYbZMi7HJcYJHFQys > zDapI2ng1Klx2YZ7ZNNCkPtboSTTV76gNJ3QjrycE0ip5PzPnHahSrOUT5Rnqaf gyAoD83r2 >qnJE2FtrhFYk9SeKfLOshZQNwHXHeoooBG+ 584Bzz3q29xDJkxw4OAOBis5b3KiQGM7Ny9B3 > FMKqYldXDNnBXHSp5NwhJHGR0NUcFIw4JHtTixtFiISMOPx5qZGZ1ZCcEd6qK xkX5M4FOAkU >txg4GeaTSBNl/wC0MYljL/ KvTjvUfG8rvBJ61WLbYxllxmlYxhfMRsEClYGydo41bKnBzmmS >FpJyyqCevtUcD+eV+ bD5q00bwuQwwcUnoCQwSzEldhx7Uzy1lGG65prSMJMA05ZSRnbgetCH > uI8ARx8hwelOMQXknk8YHarCt8oAIGe5qF92GDDPOQaV2VZCJF5L7mOVI4pr mMqcdfWmjMhG > 44A7UgPlEqDnPrVWENiRjImTxmrBQG4dXOABkVEhKknv70yVzu3BuvBo3DYf KQRgcDOeajfe >+ DsOymARvIo3k461ejeONmDHCgdaewkQxkJJgx5OOBUmepAwwpEUTrJ86oe o45NQtGzDBYgA >8kdzSYDo3BlIkOXxnB6Cp0lyxDdqptyfl6+ tOVSE34yFPJoauCdi35ivwDjFIqKzbi3WqrS4 >2sBgN1FSRvhMkjr0pOLBMsOFXhcZHWgRqwJ+ XpUaHezbjhakYLtwOpPGKnXqMrtHjrgjsa0f >CsRXxfpbdhewDH/AxVJk2ck9+/StPw5IreKtIVP+f2DJ/ wCBrV30Bn0XRRRWIgooooAKKKKA > CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAoo > ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAPm8kMoGMUwxkMaaCelSi QuoU4yO9WwQ1 >MrznpW1pUrEj8qyVTf0GBmt7SIAvOPzqJFx0NZRzWjZIVjL/ AFrMnEhhZYSFkI4LDIFX7aZ1 >tCrrmUDnb0+tSXYoyM32l2z14pW5AApGH6nijoKVxkMhZVO3rSW6s3L/ AHqlC7jk07ABAFK4 >DHXedufbineSFj8tegpyjkmk5JNAxygKgHOaVuwz+lNLhRj+ KmiYFCw5KiiwXJCQRxWZql39 >ktiR99uFq4bhPK+X7xrNvbbzmUOw9eaIpoUnczdOu5heK87M+ 7gnsK6QnniqNtZxcYAI7mrp >HPTpRLUFoGfmqRS5+ Rfu9zTRjOSOnanbiRkcCkUSRxx5xnJ6mqlywCv2yCOasW64LOAT65qt > ODlio5xnH400Sw0a3e2dg45wDx2yayNXieO4m3Y55xXTW07TuZWRVOQDjv7 1h68B9ofjkrS6 >g9jmbWVUklB/i6U+ 9wkjgHqoNV1IEpz61LcOZXLkcEYrezbuYjEPzKfQ4rVj06NgGx97msmM >gAjqc13mkosumwOQucYPHtUzdikrmDP8seBxgAVXfsPpVzU+ JSBxlqqzxmOQA9wDTjsNlXUS > UjRccF6q28nlZAIBPermqrmKHB5zVIW1wZCojbcFDH6Uo7A1qXo5gCq5B789 qtQyKVIYcfWq >duWNvlo8jON57VZhRWI3Pwehp2uO+ pJ9kWXBU7WJ79KtEKFAJBXoKhkYwfKiEs36VXminaPz >EUlfY9qVmNFbVBHDIrqAPr3NYVzcNLMX+6R2FaVzBJM8aKHcHpk9DVC6t/ sz+RcRuko5yTw3 > 0raFjKZBGyBi0nPsOuaich5C3NGCQcDNNyQBWqRi30FEZcgZwDTvOfG0ngcY pgJ7U3PJJ9ap >JdSdh6hmJyaeuUI4+XvSRqSTml2MT8p/ Ch2BEkhEnKjAHpTopAmN3TtSRhscDPPSpmiSVlwy >hjwR6VL0LSvqNzuxx+NOZyrjJ4A4q5Y20MV6qSlZIt4DA/xDp+ lLrOlyaRqTW0mCCN0bA8Mj >dDUc6vZl2drlKGNTIxJ5HSrKhPuqMP1NKbKWGeNZQQxGSh4I+ tWXhVVB2jJ96mUk9hqJnThi >42/ePUUxVaORJM7lXqB3rSlghSIHdvlbpj+CqckbN5ixnkDJoTvoDWoI4uN2/ gA9BRKqmDkA > gdKbafOWHTHJqScK53IDkHpRfWwbleCPy4wx5Rj0p0hLEIg27jzmn8p95ME84 zxVi2ihdZJZ >lfGRsI6GnJ63GlYpyJEY+ Cd68c96r7VZsA4J6g1YmQvcOqjKDp9KRYlljJGAV707kWEhiCsT > yPTHrV1srGWY5OOtVxKUtxC3QHd05oSYyKc8AdvSoeruUtBXIeJACBzk564pk 0f7oypIHUHG >PSm7jISAPu96bvEcoYrlRzjPeqSE2SJIcg9c1bUKY8N8p/ PJqk83nSGRAMknIHSpYWBGS27s >B6UmikxSDnjA9aaxRPmxkgU+ S1JBdmyw6KKRBGXw3XoaOgiMB5E8xuB6UxkAjyc1a65+YADt >TSEwCMnNCYyBEAXco564pzRFlEjcn+ VSGMxtlcFTUshZvlwBxRcncqRkzcbsH19asIOfn5A4 >AFVjb4fcrYx2qdSB0NDY46Ep2k42j6UwpgNGMgEcjFNbcrl+ xHSpUlUsT3xjmp1HoUT8hGRl > c1Myx7QyjJPOAaRs7yD0znpTC4RlPbvV6kEZkO47SQAatpKNuQuT61RkGJGY dGHFWLeZViwe >tEkCkSyM8vy8AVo+F1EfizSB1zew8/8AAxWaZdynHIq/4akkXxdoylRzfQf+ hrSs7FOx9J0U > UViAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAUUUU > AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAHzT0 FOQHPSl2EgYxT1 >QhwKtjSLtmhlcAjgV0lvEsUYAGKxNNTEorfXpWT3NUh+ fSpLdysh55IwRUO4IpJ6AVFZMd80 >rcKTuXPpSGOlJVvoacaRgHiyTyeaSL7u0nn1pAOB6n0FInLZNMO5Xb+ 7SSSYYAU7CuTE/KcU > 1Txmo2kCKCx4pjTgKWxweAKVihtzw29W6dazhcXKTs4X90TjHtWlDASpL5O+ pzEojKgDA9qq > 4rFeOMzMsmAE6ipZYg4DADr3pwx9lDYOQegqjdavBbyCMklj1A7VOrDYvIu1S owBntSHrxzT > YbiOeESxtlcYxThnqeBU6ooAGJyOtSmNggwRk80i8dKeu5s8UwHxx7FyTyecV Wn4Z8fexmpp >WUOGz0HaoJpVZ9w/u80kDJ7LBtS/qeKzPEcJAEoAzjHWtDTG32CccZbB/ GoPECK1izscEcD3 >p294W6ODX/WHI5NPclVwaanMo+ tPuP8AWn8K6kc41OpruvDz79LALdCa4q2ETTDziVj5yR+l > dj4eGywbJ4Oce9ZTNIGXqefPx71VuHMkinpgAVc1Lm5qjL95acNUKWjNiztIrnT JGkA3CT5S >e1OtIZGk2PEGH3TITxgU/Tz/ AMSlh6yU9WIGOR9KwnKzaOmnS5tS46Wr2JtFVVAPDFe9U7PT > vK1CIXWwW7HaJOx9qUvhRimTQm48rDEBH3496UJvYupQW6L3iTT7CFYTp+ 37Qx5Ct/CelUf7 >LltI2+1sU3Lny/5Gtmy8tJElRF3w8AsPz+tWtYuUv9NKNEBICPm/ GtIyd7HM0eeXVhqUTtPc >Qskbj922eCOxqK4Dm1SyuXVgDu3EfMPxrvNatraXQpFFyW+ UERkjI9hXKDToZIY9r/KP9Yp6 > j61opX1IatuYs1nHv2REYXn61UuLRoWYttyO1b50yKCWMh0Jkb5T1BXtTLnTW hmkiJSRY/41 > Od2a1u0iOXWxgL9kVwslt5gPXaefwq1CNIQTktLHIy4QuN2z2rQeJLeBQgRSjZ yRndVA28c8 >hZyFdjk4ocu4OKMvyjGCQ/HYe1AbKqF6561qDSbi5Z++ BwT6VJa6Ssb7nbdjnGOtUpqxPI72 >M97SRIkk3hhIm4H+6R2qyLRVCMxyW9O1azQ/uEd/ 9XG29QO49KryuZZpPlAjC5Ws3K6LUOUp >IsTOUlzg5w4PTmrl+kAgXEjTSjGJi3G3+ 6RUJhVIBvBMhJOO2KptMqDYCSDStzO5Wy1L8Mxu > JN8zN5yjajDoR6GpJbWaSKR4gzRov7wqeFz0rMglImREY4PrWnunjDRKW2lQ WGfvUNWZO60K > crRxJJEJN78HcOlNGYQxznI60SrskOf4uoxyKheRiXTd8o6GrUeqF6jd6eZ5iD5j 1Ap6Sqsj > qV6802TCbNi9h2o5aZTtxmi2gkTKI5ZSqDGBzk1J5iqqxenQVGihXd24OMVCp YS8ckilZjuS > Twh1LE7SB2PWo4AqQjCk5PWpuertwRUHmKjkRrkf1p2AGdNgBHzdTVVWcO yZ6ntVpkdHPyA7 > hyfemLboZZN7YJAIqoksQEKSoGabIjNx0HenShI2GzOfemGdsAA8k8007iLFrb vIrCLGSMj6 > UIpRyT9Pxp6EpCdrFWZeCKkbaQgDdOG9ai5a2JN5eFwo5AqvHErKMnr1NSLI qAqj9O570I+5 > yCMY6UiiHJSVjjgAD61KDvlRVwoPBqXAkTBABPemAbWUlSMcZzQIklsxEUzO GzknjpVN5BGA >0jYPTb61dmczRbF+Vgc5qituxmJm+ bJoQWsOVC3IBAPIFOBWMjf1PSpgcZVcZxionjzEWyM9 > 1NPcWw2RjjA69ai3HbknFJ8wCkfcHFQSSKfkJwv61SRLZM1x8nbHrTPN3rgLUa KCCCR7CpoI >nV+ cEAU3oJajZEwq4O71HpSKFVCDkEcipZJFJIC896rvJmQcdBSSYMnjV2cKhGDx k9M10Ph2 >xuLbxRpHnRn/AI/ IPn7ffFc3DK24qq8k8V1fhTWLqTXNMtpSro15AvI5GHFTK5UUup9AUUUV > iMKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooo oAKKKKAC > iiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigD5wUqW3DjipQ CcH9aq/d >IHephIQAuO9UykzT03ImGeldAK5yycGdSDxmuhU+ nSszXoPbhTgVBGGFvON3J6fTNTHoaiRM > xTHBAC00K4spKwoByelPixjpzTSwYL0xilDbXx6ipaGDtuJH51DKpEobtUgcPuA 702TLcY5p >klOaQs454HarNvHvPmSY29hUZt986+ gHNWwvQDoKL2Q0h4wDjilbpim4702Q/KNp/OoKILib > 7OpVeSc8VgfYZJ5GfaSSeprcWPzrgx7s4GTmrCwgHGBjFO9ibXKGnW0trGQT 8h7Gr5I45pSB >jGaaoGCcUr3KsOU5GeakUqRz/ OoRkg4qeJMgA0DFHdR933FU7nbCrkDPBrSdCEI9uKzpVzlD >znrQgZLpjH+z4WJI6/LjpUWrvHPayRs+Ci5xVy1UJZooHeqeuFIdNlO0b3+ XPrQ/iF0OGt/m >uEz0Jqe+ jCXLAdBwKjtRtuQRyVPFWLs73ZyMEnmuroc5XjGfzrtdCQjTQSOma5GKMfaV UdDi >u20oFbFsEABqxm9DSJhX7Zuc1Sl++ Kt324zfU1BcR7LhVz1GaqDVhS1NfTwP7HLf9NDUlJY4 >/sjaB/ y0NSxQvICwAC92J4rnqK8mdtCSUNSPvVqyj8y46DA55NReXASVF3Fu9O351f tLcRxF >jtPuDxSjEdSouWyL4VcD5Cp9hUEhXcQR17VIrgSEKcmoS/ 74kgVpFanK9gk02C4YPIufxqhe >abBNefZFXyxIC+ 5T1b0rWWcYxil4LBkA8wdG9KrVEmIYzolg1vA4kmLdCmWQdzn0rEtre5+3 >KsEYZichWOVHuTXauoJaRkLs3ByKxbi2KXp+ yRsQzAyAnAFNNhfQx9Q02Z4zdTRDzNx4Xpjs >azbW0inSRZEzMTlCD0PpXXXMt1ChjS2WXPLxA8fWsSOze+ 1UtCEiEgGV7D8auMm3qS2jJaW5 >sgqSxkFMhie9RJNLtDl+ M5OP5Cui1bSLiCURTxqitkxHOd4x1rA1CzS2n2xElsbjg5HNKLUn >Yp7ajnvhMMkDJPAB4qOWKWS3kdTkp99B296z94EgB+ XFTrcbm2hz6NjuKpwdyL3GQu2UBctu > OOe1W5Io1jljAGyTGcjp9KryxEFPLxtHWp7dXLRs4yM4we9GwIrRxQAFolwwP JJq400cVqrq > rmQnG7NOuoCkrsmB0JB4xUJhDMyjLAHIz60LXViemxXZzIpbYTJnjPb3p0JjNz /pWW3Dhlp+ > DDF5ZTEgPOe1VmEsjLxt2VT8hDLmRI5jjO3tmpYopTCJArHB5p0kBuIsAbm29 APSkd38hdhL > Y4PamtrIPUGjZojKfufrSKQGJI56CrkMBnWGOOQFj8pSqssEiyBACDnByKQ7A AJYpAWIYHoB > 1pqRrGeTljVlIxHIVZguVyaqknzWJ6LU6jcRxjBUsMn0qttPmNuyCB3qwkgMhU 546U5Yt7bm > 4NUtNxWuZhaTIxyQauho1QSOoWTHQipDbxb3Y5JHINVrlWlclWzx6VVyUrCS XBOQvbpT4S+4 > sy8HvTI0PzBxkjrVvy91uAvGT1NOVkNJtkRURruOA39KRWj3Hkn3FWJLQxwLJ JgrnHXmomtg >swIGR3IqU0waaZYjmVfSnmaM8ggn0qowxJt7U0KFLc4xU2HcsNOiy5I6Co/ PEhLHIHYYqNkB >5JLUxiV6DirtcLkmShLk5IGQKikuSG5x71G7vnI9BSmMbVZuS55FFiW+ g8zpJgcBabJHFyQD > mnNDGGAjBAPJNIIIjLh5evbFNNITK44cDvVpXAXgFqR7VUAbcuzPyn1qURHyx 8wJ64ockwSZ > VUkuxxg5qY2yyNuPApSygYJGaQNIQFUfLRcEhYowjljgY6DvWr4WGPFWkkjap vocfXeKzsAB >Sq5c/ erQ8MuH8W6QGG3F9Dgf9tBUNlWPpCiiisgCiiigAooooAKKKKACiiigAooooAKK KKAC > iiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAC iiigAooo >oAKKKKACiiigAooooA+ aQcdetOG7PvSYx0605Qc5J5rQC7YZEqnPGa6eI5QEelcjDIUIzwK6 > LT5xLHjOcVk1qbJ6Gh1pQpMUuwc4xn0pueM1PaqG3knGRzQhFQbg2CQcDrT wvzBz6UrY3Gkc >jZ8x6Utx3GRnAOQOvBp8a5JJqPqFA+ 7UkWe3SgEO4QZxye1Kp47VDOHc4zhR3qBpyg2p3796 >VrjvYuBhvINNeLcQ5b5QOlZUQuBc+Z5hIJ6Vr/ eAz6cilYYkChIztPXqe9IDIwfoMnipflC4 > FNBwMcYpXGiJsntiheOKceSSRTc80AKFOang681DnAzTHuAg4IHvQgL1zJiMN3 HasaSc/M5I > GKivdWWHKEln9KwLvUDO6lwVUdQp61UUJs7qF1FpESRxzWH4inDQW6KfvScj 8Kv6RKDpURPz >EevcVja64a5tUH94mpSvITdkYtov75j71NdDIf6imWwILfU0+ 4BwxHfFdDMhbYbr1PbH8q7f >SgPsB75Y1xVoQt2rMflPH413Gm5WyYbh6/pWU9ionL3Z/ wBI9txqCeTzZkbpniprw4nOTzmq >z/fFaRQmb1pLFBpUbTtiMynC+ prPvL2W6lGWKRAcIOlV7tmVLdRyp5xmrOn2tnLLMt9eG3RE > LRsvJZvSoa1uXFuw2J0Ckleg7GrOmavJHM0WT5RODntWZaw3EttcSpGZD91c Hpz6V0+jaHp1 > xYz3V2zJIgPBOCCPUUnyoNWywtxDNNOscg3RgHJHUU5WD8rzmqtvAFgWU4L PwCOw7ZqRvTqf >aqSS2Ey2uQcEU9WwSc8VRjndByOPT1FX7cG5VzEoZo/ vKG5H4UCCN9meSQeeacSuDtGCfaoG >dSe4I9aC/ HWkArqTbfPgqzfP2Iqv9jTyzKAx4yAOKmZSY8g8elPadY7Ys6Haq8YNFxpK5ni E >TP58qEsFwmW+7ioDb2l3apIuIbhCQpYZB9c/ 41Ytr6GV2YjazDG01DeTW8EDSbCxkOAB2pWG >9NGcpfeHmGqiJJ4kR135zkAntmnP4d1HS40uZYfOt2ziROfr+ FdF5Eclq0skAcheFz0NaUWo >O+ l7ZVYt5WFH8NWptIjl1ujhXaKRFWD7o5ZyOTntVxEjNiscWFkXnFdTpug2WtWn mzSBZYy2 >QgwSfcViXekT2cFw5YGBGwXX+tTzp6FJMyIS08rxTSBT6Y7+ 9MvCbV4w4U57qeKajJ9oDBNo >A+ Yk43GoL0ZYZ5zyOatLWxNy27qr7wMIwBOeearShRIWBxz3pjTFNhB3FhjFDFn IULlz270x >C+ bJDLviYBwMhuwpEd5F3yAfMSxwO5qPfu2rkZAIxU8kkkgDYCr0J9KHcVhsUnk XKSxtypHP > pV8QJPcxSzk7XbDHOPfNUBDtidWG4seGFXsQjTmUFmkVeoPQ0pFR03Kc7Mh LbsFiRt68DpVQ > uWf5sgEelPyTOw6K44J7UwR53EgnBq0RJstIUZc8Hj0pjTBeo56D3qBZkVdoXP NOUqrFzyx6 >A9qLdyuYURO7+ Y2cZ5X2p5RSdyjGKT7SywsgXDHkmoIbhdrbxkDvRZvULrYsLGP9a5wrEjHe >poGwSoAOTkVSDG4I8vIReTT4v3LEbySTjHrQ1oEXYv6kQoVR/ cHH4VWg2sCrttwM88UO0iAx >O37pvug8tUKkkkhsMOuelCjoDldkjRkkMCOncURFlcFhkd88CoSV+8dxb+ VM84seCTmmSW5v > sygiIPtJ4JNVWU5OOgp6qxHzcj0pylOQetIdiER4jKYzmneWQBhc7e9PPDZBGK UZJBB/D1p3 >FYaEfbtXHPemEqh8sna2OvrUryHqBgg8ioZHPmD0+lCVwdg+ YKoIyAeKesb7SJCR6KOppio7 >N+ 7kxznApxlaNgJBjnj1o9BAIOjZCjpgd6FMaOVAPtk09n3BQOo5oOw24GPn3Hm i4JDA7nIw >AorU8NR/8VVo7gZ/06HOf98VnIkSAtJJyf4Vq94bnUeL9GRQcG+ hHP8Avikxn0lRRRWQBRRR > QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUUUAF > FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAfNYBzShsZH X1pPxozgZx7VoA8 >sOAvIrW0gnzMDOKxx96tjSDtn/ ColsXE3x04qezClZAxIznFQr0qWFfMhnGcOoyuKlbFELgD > KqcgcZpjZSJjjNCncq06UFlKipuOxHGpf2zzipgNgxQsRjcZ9KU8tntRcaQyT7h9 B1qmiEuZ >CMqOBVmdmYiNe55NPVRwBjCjB+tCdgsRCPaRxU3Ochc0/ APNIQC3XFK4ytLMUfbjrSiQoW8z > hccVHdMsSSyZyyjgVTs9TaaJ1uwAc5U47U9LCNJX3IKQnLZz0pFZWQOv3T0p D8vy96lFC/fP >GcelZWpXDK7W/YjOa1HkS3hLucADmuVv9S+ 03heJcKBjmqir7EsrSTZY7ySQO9UZZgWx7YpZ >5XcknH0rR0+RGKrEI/M/ 2lzWyVjLdnU6V8ukRMPTFY2stjXI0yCqqOR0rZ0lpbmd1udj7V4V > RgVgajh9clZFwoOOtZKLTdzSTRHbLmVFx1JovSBNIB0BwKdCCLhcH7vNNvRl m9Sa1Mug21Cm >8wwzk8V3OnjFgwHI5rhbQD7eATxu6+ldlpz+VYGFjk84PeomtS4PQwb+ bzLkAIEC8cc596pO >xEg6datTgNcHPXcarzqFuAvYVURElzl2gzx8pNRSkGTaDxin3bGN4HA/ gqESIZfnBaM8sFOC >aJDWx0Pg/ UY7CS7zE0zEcIBnP0qlqc2otevIIZF3kkrtxhfU1d8JiJ7i6WzzHcYLQhhnA96j >+2z6trEhuWG+ P5DtGBio05xt6GjaL5VsgK4LDJGabNOsA37T9M1OmCNpPP8ASs7WVc+ SEUkE >gDHrTitbEt2NqK2tp9Fl1NJwBEpZlPb2/OvO01O7juZJ0mdZHYnr2zXXeIAuj+ HbW13ETXB+ > cA9uvSuHkfzGL4xmrpLdMmcjrLDxNc3C7Li3FwiAZY8MPxq6NWhYFljaMZ5Vuq /WuR069Nix > IBYN1X1qxc3O5nkDBHcD5DzTlC7GpLlO3hk3xCQHMf8AeHIpt1Oqwcn5TxXF Wer3lq6+W425 >Hy9Qa3rTWm1W/lgmijCKmeP71RKDRSki3DY4n+ YfKFzu9TU0torKrMBhTxU4f+EjGBiowGdg >FOVzyKke4RxZTng/ TingqXOcbAvTFWA4EeT9MYqFVBOwDOahspGQ17PHqIKZQR/6vb0b61Hf >3s7WktlI5aO7O9wB0NbKWVt9qBu1ZolBKxpwc/Ws59OiuNUErswVgQiE/ d56U1FXuJyexzqa > fO7llJCKw3Kf6Gr19ov2uaFbKKQC5x5akdwOa3pbAvKkeFCKQc9PwqOeCW1e KeGdhOjkxr2j >B61V23dCeiOQ/ s82ruLnCyRsUC55yP5irLxGW0jeOMB15RgOo9vWtS7sYJFne9tbiWdh+6Mb >YAz2P881tab4cs30Nrq4nkeXYNyZIKdsAVcpR6k2fQ8/ lhSJ0ZHDSbvmG2rU0ccsexVLSMuV > weBWlq2jw2108cUzrJGoZARwwPqazbeF5LhgH2qD839aV76jjpoTRhJSpQbAF w4Pr3qtMY4S > yq3ylemO9WmCWszCNxh13KSOmaoSRq4Zmfc2eCOhpKw27FeQK8YCD5yO oNV9rxcM27jkVMQs > NwwHXGR6Uk20jJYEdQc9a1M9yoZcEgjA6DFTw7QAxOaREG3zAQDnnNBKkg D1q3boStCeKYLu >HOTwR1zUccaGTcV2+ 1SkAOPkySMAU94ZICA67SRnFSpWKUbu5P5KC2yF2bvU9aoNGfNQg5C1 >Kr5JO7d6elSFQoHBPfGahNDaIvJa6cKOHJ+U5xj60+WKKIMAx3ZwO9BZC+ 7BHXjPSq+3Mh2k >8c4PYVQrMbIxSQx9/ WmMNu0BOe5qaTY0Y5Bcc59RTEkAQhjyKomw0uVKjJpzOFf1HrUZzuU7 >sj+VMKsSTtOOtOwtSct84PbHSpkG5M8/UVCigx+ YzYx2NTJKSDgYX0NQMcoXBDH5uo+lL9nS >Xgsc9sVD/ GWzUqOsadevc0tStGNME0W5doIPcUNCjYznjvUyTArwSaieUHIxTAjI+ cnPAGPr >TFcgkYyD0qXI2Z7mmjC8MOvSnYSG8FSSMMKv+GQT4v0Y4z/p0HP/ AG0WqJKkbc4PvWl4XjKe >KtJJb/l+g/ 8ARgotYT1PpGiiisRhRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUU AFF > FFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQA UUUUAFFFFABRRRQ >AUUUUAfNXXilH90U3pThwDxzWgDlI6d61NJB+ 0DPSspR3rY0fJmFRIuJ0Aqa1bbv47HNQr0q >a14aRjyNpqehRCm0uCPu80ZG/ PY9qjiB2qwNPJ5BPWoKHAsScnJJpzcU1etOYZxSGN2jknrT >VOM+9JK2XKZwB3qMyAcDoBRYCUuM+ hFMa4RSQ7Csq81FYXG0F27j0NZEt/dSSbiQPaqsK50y >qsnnSFgykYJPYVzuo3QaXZagbVPLetSia6vU2FsRjqF4qxFpWEGcA+ lK9mCINNurt5kjLZT0 > PaugHHQY9Saq21tHZ87d0jVbCNIcueOwobuOxXuoDdwsmcJ2965S9sXtZOeu cD3rtQuHx0Wo >ruyiuoxvGCDkHFCdhNHBTxPtyRVzQ1jW43H79dBfaSs9tiMDeKp2Wm/ Y2VpceY3b2rVSvEhR >szd0XAuXOMEL/SucYiS+kPdpWOfatuF5UikaHAZep9iKw4Y9t5+ ZpRkE1rcSMf6VTLsfMPrT > oyPPY85zRcEM6g9M1oiHsU0ZlvSw6Bq7jT0DWvmbfvLnNcXdJ5VwxB6nNdnp W7+yY+P4aioV >DY5+5x9qOOxNVbgkzZ9asXBP2o8d6qzE+ YPrTiAmqXCRPagt8xTkegoKqXVlOVxxiqGtE/bo >faJf51Z0ydokinDDfG2RkZ79xVTWgQd9Da0WO+hvi9qvkySjapccEVuy+ Go9Jc3LzZu5z88S >nj60arcnWfsZQxW90IwXkjHB/ AdKaRIGXMxl2gAN1rBPXUtrQkQHGeT2zUqGQyqsYBfooPOK >hSQjtwKfc3JtLCbUc7fKUiM4+ 83pVbE30OY14TahqciRyeYIRtyx7jrWCQVk245PA+talrbr > cyFjKQ3VwD1qncwmO4dQMKpyv0raDsZyVyqySRtiQEYo3D6H1Nacdnb3EXm GcqCPunuazvKJ >L7MEKSKtSuS4kluwW4VfvAn8q3dF0wWki6i7N8+ cp6isW0sZLiaJclQ7YB967of8e6xhV2qM > celc9epyuxvQp8yuRS3CoBIoyG6c1MJ7WaxEkJMMyn5pXOVPsBWVqs62tg0g XPTZ7GqFjqGo > JKrmAPEvDJjjNTD3lcc1yux08Pmz2Pm7goBwSBww9aSOWD5iZAAlZ63kiJKs8 RaMjciA8Lz1 > qTI1HUWGFAaNQAg7AdTVKOoubTQvQ3AuQzxtuUHFFxGktxAfu7W5bpipYYI7 eMpAMrnkA5wa > t3NjdC2jne3LqxyjDg8dyKW2w15leWKSNSAd3161We7itIw8sLMQevXrV62uX vWZBEemck4q >jKws3/ eMNrHBGM4P1pJeQNlmOZZULlcggEZqlcGYzM6BirgAL71oDYkJdugxkelRRSQz oHjO >VB5FSrdRtPoY97pE91F5hnbzyMFD0AHvTNP0uKzaK5ulwiE713fMx9cVvmN/ J8wITFnbketZ >N6PKwWXfuJH0qk29EKyWpl69cWt1PJHAnygZVcYIPeuaLsAM9e+ O1dWdHt5LFtQjuwkoJYqw >7DisS4s/ stzE92DJGflBUYB9K1jGxnKV0Zpt5Q5cqVjYDn1qS2gAmCMQ0Z9eoru9A0nT5 dOm >gkkjZmydjHpWNNbQWrtbxrGNjnarc5pOom+ VDjHqY91FFbYEZEikfeI4FZk7CTbhc44yOK3r > 3zFRkeBPMPKMBw31HaseWCTHllTlgNpXsaqKt1FJNlUOfOQ5IwetWJZZrq42jM kz4WNe+ahk >jeBirn94DyPSpoEQsrmQr/MVctFciNx+ 97bfDPGI7mNisisOQR1zTTJvlwq5GOta1hpX9r/a >ZEuBvgXLb+rf/XrKljZZZFxgrkGo0Ku+ pC8gBIxikjVypONrN1zxS28oBYFQ3YZp5WRnAPAx >TYkymZdjlTjrinFUIB27SD8x9asTQohRAo35yzHv7VG+ 1cI0eT2OelUIRYgW3Nyo6iomlAci > JDj86l88qNrKMnpT4YQMvnk9qG7BYZG0hhZSoy6457UqRAh8Mdy8j3qYtHu25 29eRVZA/mPs >fp1z6VO4x6uNn3cmlDpjGMn0qs7Yf5mx9KkAjfB5GOpqrEk/ nKQAvFN255PBpwEcakAcHpmo >sqvPUD3oXkMmIK+mAKryyDKk/ e7ClLGdiQccAULbdNp49TRsF7i4y2T1rV8MkjxZpBPQ30AH >/fxayZB5U5EmegxWr4aw/ivRyHAAv4DjH/ TRaQH0lRRRWIwooooAKKKKACiiigAooooAKKKK > ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKK ACiiigAo > oooAKKKKACiiigAooooAKKKKAPmvg8k0Kcc0g704AAZPStADdWro7YmxzzW ZtFaGkAm7FTLY >uJ0y9Klt+ kp3cBcYqI5Ct9DipNMyllIz5Lck8dqjoUQxgKqqOgpSMgGheeaWpsUPAyc+ 1DMF >Qk0LSOu8e1IZRly+ CCeTz9KaysQxHTFXDEMZPQVHIQEyMYpvQVjnriJjI3HNQCBi3StiSMEs >+OaYtvlQ6rj3pXCxFp+IpgrDhq2yileoOKz4IQGDEjIq8XweTx7UmhojXiU/ LgDvUxcHjmm5 >56daXI6ZoAcMBcd6eCAMZFMG7HA4pu/DbcY+tNITBz82D+BFUZ9pmVeNy/ yqa8nFvEWJ2n1r >EtLl7i+kZmzTSC+ pqMM2z44A64PWqaQ8ljgYHWrTvst3yOCQKjIHl8dMVSJkZ9mVa/25ySck > elRXbCOUORwHJpkSMt27g4HYim6lkwgZ78mtEtTNiXc63M4lVdoPau00xtuhJu/ u9fwrz+H+ >EAk8963EuJ1tVQSHYe1KSuOOgyVv9J69zVeX/ WjPrUwyZ0x685pl1j7WR056U0nYL6mZrf8A >x/R/9cV/nTNPfBMbPgdQPWpNaGb9P+ uSj9aZp4Cz5xyPWrbvEUVqdJYXP2SYPGpcHAwetbse > oW88jxqdpXggjvXMxybgWP3gc8VbhuvkXZtJZuTXM43ZsnY6NolI4HGe3esvx Rq8T2kGnWgx >s+aUEU17me2hJgdZZXQnaB93np9aoalcRy2crND++ VRlvWiKd0xSaa0MY3RkdlVhGhHYcmo1 > Y8vu3dqqiZHHIKH39anjG3aSQynsK60jC7YFsqfmHXgVJEqbS20kYw3sasq1v DC8ZjUs54Oc >7ahWBtn7rIQ88/ xVN0OzRoWdzb2kKGRtioOCe7Gg6qZo5ZIyUCn5cHrWPrTmOOC1GOFDuR3z > WSCwI2sVUds1DoqWrLVbl0R6BZudU0x4bl13ZwoAxmsV4r61uCfN2sjZAP8A FWba6zNGYkcf >JGe3U1utq8N9AY/ lEqfdY9SPSs4xlCW2hcmpq6ZCdYnMks03yN18rHA9cfU9qtWd1ugM1uzK > W4YL0rIm1FLaMeVGH558zmtDTNdsQDE8AiLckj1q5t291E010bNW3uLq0AQq Ch6OOavpqdwt > tLJPdPLtX5E6BfSobeW2mHmW8qSDJzjrRLEpiYvgDGSK51VadmjZ0rrQktrq7v WjmaJv3wIB >XjpWY0w1GeRRJtjjcLID2weuasNqE1raQSCGYWzHG4dF/ D3qxZXljOf3ITdyWAXGfrW8JWd5 >IycW9EX5bm0to5Le3nkeJowFlIySO/ FQROnlqEIx2JOKgitTJJMBKqq4wAw6e2auG0e0ZkRF ---- Message was truncated ---- ________________________________________________________________________________
Date: Sep 08, 2005
rlegg(at)austarnet.com.au wrote: > I wonder how our old mate Milt Concannon faired in the Hurricane? Poor Milt (and family) have had a pretty rough time - though not as bad as others have had. They have been without power or water until today and Milt has been on call at the hospital around the clock now since the big blow. Just talked to him a few minutes ago and he's sounding pretty worn out. Multiple trips to the hospital every night would kinda do that to a person and it certainly gives me a renewed appreciation for the professionals of the medical industry. I think he's just really happy that he can finally have a hot shower and a cup of coffee! The good news is that they suffered only minor damage to their house. Did loose several other buildings including the hangar. Fortunately, he'd moved his airplane over to Jim Crunkleton's place in atlanta before the storm hit, so it's safe-n-sound. Chris ________________________________________________________________________________
Date: Sep 08, 2005
Subject: CAR RENTAL
commander-list-digest(at)matronics.com Hi Everyone; I just finished renting a car through www.expedia.com and for the 21rst through the 25th the total taxes and all from sjc airport is $135 for a Dodge neon, unlimited milage. It was about $80 cheaper than next. dan farmer ps. i do not get a commission:-)) ________________________________________________________________________________
Date: Sep 08, 2005
In a message dated 9/8/2005 5:58:17 P.M. Pacific Standard Time, cschuerm(at)cox.net writes: > I wonder how our old mate Milt Concannon faired in the Hurricane? Great to hear Milt is OK. I sure miss him in our group!! jb ________________________________________________________________________________
Subject: Capt. JimBob Please send an invite to the fly-in to
Date: Sep 09, 2005
JB, In San Jose, CA there is a 500B Merlyn 290 Conversion owned by Vladimir Rivkin. I believe N698RR based at the Reid Hillview Airport. I was speaking with Vladimir about 6 weeks ago and he has interest in attending, his airplane is for sale (upgrading apparently). I told him I would try to have the details of the Fly-in sent to him. I do not have his address, only a phone number. Maybe you can get some information to him. Phone Number - 408-568-6886 See you in a few weeks. ________________________________________________________________________________
Date: Sep 09, 2005
Subject: Re: Capt. JimBob Please send an invite to the fly-in to
In a message dated 9/9/2005 3:28:53 A.M. Pacific Standard Time, kevincoons(at)cavucompanies.net writes: I do not have his address, only a phone number. Maybe you can get some information to him I will cal him today, thanks!! jb ________________________________________________________________________________
Subject: Re: used simmonds 580SU
Date: Sep 09, 2005
I Have two complete units Thay may be useable ASIS Price $1,000.00 Each Harry Merritt 321 267-3141 > > From: "jmenchetti(at)cantv.net" <jmenchetti(at)cantv.net> > Date: 2005/09/07 Wed AM 09:02:38 EDT > To: commander-list(at)matronics.com > Subject: Commander-List: used simmonds 580SU > > > > Dear Gentlemen, im looking for 2 simmonds 580SU units, in to be overhauled > condition, many thanks > > > > > > > ________________________________________________________________________________
Subject: showmen
Date: Sep 09, 2005
Sorry this is non Commander. I must have been living under a rock for the last month and a half. I was shocked to find out yesterday that Bobby Yonkin and Jimmy Franklin, two of the all time greats were killed in mid July. What a shame. So few in that sport quit while they can. bilbo ________________________________________________________________________________
Subject: Queen Air Question
Date: Sep 09, 2005
Commander Folks, This is not a Commander question, however, I need a fast answer. It is my understanding that one of the branches of the US Military purchased some Queen Airs that had the IGSO 540-B1A engines in them. Does anyone know the Military designation of the airplane? Much Thanks! Moe N680RR 680F(p) ________________________________________________________________________________
From: "Barry Collman" <barry.collman@air-britain.co.uk>
Subject: Re: Queen Air Question
Date: Sep 09, 2005
Hi Moe, The Beech 65 Queen Air was initially designated the L-23F, later U-8F. However, these had IGSO-480 series engines. The Beech 65-80 and 65-A80 Queen Air had the IGSO-540 series, but I'm not sure if the military had this variant. Best Regards, Barry ----- Original Message ----- From: "Moe" <moe(at)rosspistons.com> Subject: Commander-List: Queen Air Question | | Commander Folks, | | This is not a Commander question, however, I need a fast answer. | | It is my understanding that one of the branches of the US Military purchased some Queen Airs that had the IGSO 540-B1A engines in them. Does anyone know the Military designation of the airplane? | | Much Thanks! | | Moe | N680RR | 680F(p) | | | | | | | ________________________________________________________________________________
Date: Sep 10, 2005
i had one with the excaliber conversion . io 720 s. it was u-8. mason >From: "Barry Collman" <
barry.collman@air-britain.co.uk> >Reply-To: commander-list(at)matronics.com >To: >Subject: Re: Commander-List: Queen Air Question >Date: Fri, 9 Sep 2005 21:42:18 +0100 > ><barry.collman@air-britain.co.uk> > >Hi Moe, > >The Beech 65 Queen Air was initially designated the L-23F, later U-8F. >However, >these had IGSO-480 series engines. > >The Beech 65-80 and 65-A80 Queen Air had the IGSO-540 series, but I'm not >sure >if the military had this variant. > >Best Regards, >Barry > >----- Original Message ----- >From: "Moe" <moe(at)rosspistons.com> >To: >Subject: Commander-List: Queen Air Question > > >| >| Commander Folks, >| >| This is not a Commander question, however, I need a fast answer. >| >| It is my understanding that one of the branches of the US Military >purchased >some Queen Airs that had the IGSO 540-B1A engines in them. Does anyone >know the >Military designation of the airplane? >| >| Much Thanks! >| >| Moe >| N680RR >| 680F(p) >| >| >| >| >| >| >| > > ________________________________________________________________________________
Subject: VH-EXD
Date: Sep 10, 2005
Hi Russell, I don't seem to have recorded this before, but 500U-1639-3, VH-EXD is reported in Air-Britain News (July issue) to be inside the Australian Aviation Heritage Centre at Winnellie, Northern Territory. The marks were cancelled on 22Oct90. I've got a bit behind with my database up-dating, so if you've told me of this before, I offer my sincere apologies. If it's news, then that's great! Can you 'remind' me of the ones left to hunt down? Sincere Best Regards, Barry ________________________________________________________________________________
Date: Sep 10, 2005
From: John Towner <johntowner(at)centralairsouthwest.com>
Subject: [Fwd: [Fwd: Hello]]
Date: Sep 10, 2005
Subject: [Fwd: Hello]
Subject: Re: Fly_in
Date: Sep 10, 2005
bb, angel flight america is flying supplies from largo vista, tx to slidell airport (ads) a hangar there. if they need the stuff i can load my truck and trailer (3000lbs +) and make a run. better than too many trips by air. please check and let me know if needed. mason 817-517-4977 >From: "Bert Berry" <bertberry1(at)aol.com> >Reply-To: commander-list(at)matronics.com >To: commander-list(at)matronics.com >Subject: Re: Commander-List: Fly_in >Date: Thu, 8 Sep 2005 13:24:15 +0000 GMT > > >Yesterday I was in New Orleans helping with rescue efforts when I heard the >familiar sound of a twin commander. Just wondering if it was any of you. >The sun was in my eyes but it looked like it was red. > >Man what a mess this place is. > > >Bert >-----Original Message----- >From: "Barry Collman" <barry.collman@air-britain.co.uk> >Date: Thu, 8 Sep 2005 11:16:42 >To: >Subject: Re: Commander-List: Fly_in > ><barry.collman@air-britain.co.uk> > >Hi John, > >Well, it looks as though there might be a few of us booked into the Comfort >Inn, >which will be good. I'm still getting things ready to take with me, but >N5007H >will not be making the trip! > >Wow! That simulator looks pretty neat. Andrew must have put a long time >into >that project and must be a very talented young man. > >Looking forward to seeing you both again, >Best Regards, >Barry > >----- Original Message ----- >From: "John Towner" <johntowner(at)centralairsouthwest.com> >To: >Subject: Re: Commander-List: Fly_in > > > >| >| *Barry,* >| >| We will try to book too at the Comfort Inn at Marina. We wish everyone >| could stay at the same place but hopefully all will workout. >| >| PS-Andrew has been working on building a Commander simulator for us, >| attached is a picture from the prototype we thought you might enjoy. >| Are you going to bring N4007H? and we hope all is well with her. >| >| *YOUR FRIENDS, >| >| Andrew & John Towner* >| >| Barry Collman wrote: >| ><barry.collman@air-britain.co.uk> >| > >| >Hi Guys, >| > >| >Well, I'm booked into the Comfort Inn, on Reservation Road, Marina for >the >| >Fly-In. >| > >| >Anyone else booked in there? >| > >| >Really looking forward to seeing some new faces and meeting up with some >old >| >ones! >| > >| >Also looking forward to seeing some new paint jobs (one which was long >| >overdue!!). >| > >| >Sincere Best Regards, >| >Barry >| > >| > >| > >| > >| >| >| >| >| >| >| > > >bertberry1(at)aol.com > > ________________________________________________________________________________
Date: Sep 12, 2005
Subject: Re: VH-EXD
Hi Barry, Great to hear from you! Coincidentally, was about to email you re finally getting closure on 680E VH-EXU. The story is sad but my source is impeccable! He has checked his diaries and confirmed that EXU was cut up for scrap and removed from Jandakot Airport (fire dump area) during August 1991. Do you remember the week I spent in Perth trying to track it back in 2001 (I guess I was 10 years late!). Please update your database. Yes we have known about VH-EXD and it is displayed in the heritage centre. After withdrawal from Coastwatch service the c/n plate was removed (to never fly again!), so somewhere in the future this may pose a problem for identification! Sister 500U VH-EXK is the missing aircraft. It was withdrawn from use about the same time and supposedly parked at Townsville Airport. (I did recieve one report that it was noted at Perth, Jandakot but I believe this was incorrect). Both EXK and 680F VH-ELH were parked at Townsville and removed (still no word on when or where they went). Unfortunately it looks like I will be a scratching this year for the flyin...:-( I will really miss catching up with youself and all my great pals. Please say a special hello to John and Andrew T, Buddy and Mr & Mrs Jimbob! I think that Richard will be getting along this year. Have a great time and I would really appreciate a list of participating Commanders when you get time. How are you getting to Marina (via Washougal)? How is the book coming along...remember I would be pleased to proof the Ozzie stuff! Cheers and regards Russell >From: "Barry Collman" <barry.collman@air-britain.co.uk> >Subject: Commander-List: VH-EXD >To: > barry.collman@air-britain.co.uk> > >Hi Russell, > >I don't seem to have recorded this before, but 500U-1639-3, VH-EXD is reported >in Air-Britain News (July issue) to be inside the Australian Aviation Heritage >Centre at Winnellie, Northern Territory. The marks were cancelled on 22Oct90. > >I've got a bit behind with my database up-dating, so if you've told me of this >before, I offer my sincere apologies. > >If it's news, then that's great! > >Can you 'remind' me of the ones left to hunt down? > >Sincere Best Regards, >Barry > > =============== =============== > > ________________________________________________________________________________
Subject: Re: [Fwd: [Fwd: Hello]]
Date: Sep 12, 2005
John, Received two emails from you, however there was no message? Moe ----- Original Message ----- From: "John Towner" <johntowner(at)centralairsouthwest.com> Subject: Commander-List: [Fwd: [Fwd: Hello]] > > ________________________________________________________________________________
Date: Sep 12, 2005
Barry, Thanks for the information. Any ideas on how I might find out if the 65-80 or 65-A80 were ever used by the US Military? Confidentially, (as you may have suspected) I am on a mission to get information on the Simmonds fuel pumps. If the US Military ever used this engine, a repair manual was made and can be traced if the aircraft designation is known. The information on the flow bench used by the military to test the Simmonds unit by the military has been located, so one can only assume that a manual was written explaining how to rebuild the injector and flow it on the above mentioned flow bench. As usual, the companies that had the super cheap prices on the lens did not have it in stock and could not guarantee a delivery date, so I will have the lens with me next week, however the cost including UPS freight will be a grand total of $ 482.14. Hope this is OK. Best regards, Moe ----- Original Message ----- From: "Barry Collman" <barry.collman@air-britain.co.uk> Subject: Re: Commander-List: Queen Air Question <barry.collman@air-britain.co.uk> > > Hi Moe, > > The Beech 65 Queen Air was initially designated the L-23F, later U-8F. However, > these had IGSO-480 series engines. > > The Beech 65-80 and 65-A80 Queen Air had the IGSO-540 series, but I'm not sure > if the military had this variant. > > Best Regards, > Barry > > ----- Original Message ----- > From: "Moe" <moe(at)rosspistons.com> > To: > Subject: Commander-List: Queen Air Question > > > | > | Commander Folks, > | > | This is not a Commander question, however, I need a fast answer. > | > | It is my understanding that one of the branches of the US Military purchased > some Queen Airs that had the IGSO 540-B1A engines in them. Does anyone know the > Military designation of the airplane? > | > | Much Thanks! > | > | Moe > | N680RR > | 680F(p) > | > | > | > | > | > | > | > > ________________________________________________________________________________
Date: Sep 12, 2005
Hi Moe, Give me a day or two and I'll try and find out. I know the US Army had Queen Airs, but I'm not sure of the Model. I'll get back to you as soon as I can. Very Best Regards, Barry ----- Original Message ----- From: "Moe" <moe(at)rosspistons.com> Subject: Re: Commander-List: Queen Air Question | | Barry, | | Thanks for the information. Any ideas on how I might find out if the 65-80 | or 65-A80 were ever used by the US Military? | | Confidentially, (as you may have suspected) I am on a mission to get | information on the Simmonds fuel pumps. If the US Military ever used this | engine, a repair manual was made and can be traced if the aircraft | designation is known. The information on the flow bench used by the | military to test the Simmonds unit by the military has been located, so one | can only assume that a manual was written explaining how to rebuild the | injector and flow it on the above mentioned flow bench. | | As usual, the companies that had the super cheap prices on the lens did not | have it in stock and could not guarantee a delivery date, so I will have the | lens with me next week, however the cost including UPS freight will be a | grand total of $ 482.14. Hope this is OK. | | Best regards, | | Moe | ----- Original Message ----- | From: "Barry Collman" <barry.collman@air-britain.co.uk> | To: | Subject: Re: Commander-List: Queen Air Question | | | <barry.collman@air-britain.co.uk> | > | > Hi Moe, | > | > The Beech 65 Queen Air was initially designated the L-23F, later U-8F. | However, | > these had IGSO-480 series engines. | > | > The Beech 65-80 and 65-A80 Queen Air had the IGSO-540 series, but I'm not | sure | > if the military had this variant. | > | > Best Regards, | > Barry | > | > ----- Original Message ----- | > From: "Moe" <moe(at)rosspistons.com> | > To: | > Subject: Commander-List: Queen Air Question | > | > | > | | > | Commander Folks, | > | | > | This is not a Commander question, however, I need a fast answer. | > | | > | It is my understanding that one of the branches of the US Military | purchased | > some Queen Airs that had the IGSO 540-B1A engines in them. Does anyone | know the | > Military designation of the airplane? | > | | > | Much Thanks! | > | | > | Moe | > | N680RR | > | 680F(p) | > | | > | | > | | > | | > | | > | | > | | > | > | | | | | | | ________________________________________________________________________________
Date: Sep 12, 2005
*Barry & Moe,* I know the Army has and still uses the BE-65 Queen Air and the modded ones have 8 cyl Lycoming direct drive engines on them. Several years ago we looked into using this engine I think it is called IO-720, for the 2 680FL's we use to have because the GSIO-540's that were on them gave us so much trouble. We never did do the mod and ended up selling the aircraft *YOUR FRIEND, John Towner * Barry Collman wrote: > >Hi Moe, > >Give me a day or two and I'll try and find out. I know the US Army had Queen >Airs, but I'm not sure of the Model. > >I'll get back to you as soon as I can. > >Very Best Regards, >Barry > > >----- Original Message ----- >From: "Moe" <moe(at)rosspistons.com> >To: >Subject: Re: Commander-List: Queen Air Question > > >| >| Barry, >| >| Thanks for the information. Any ideas on how I might find out if the 65-80 >| or 65-A80 were ever used by the US Military? >| >| Confidentially, (as you may have suspected) I am on a mission to get >| information on the Simmonds fuel pumps. If the US Military ever used this >| engine, a repair manual was made and can be traced if the aircraft >| designation is known. The information on the flow bench used by the >| military to test the Simmonds unit by the military has been located, so one >| can only assume that a manual was written explaining how to rebuild the >| injector and flow it on the above mentioned flow bench. >| >| As usual, the companies that had the super cheap prices on the lens did not >| have it in stock and could not guarantee a delivery date, so I will have the >| lens with me next week, however the cost including UPS freight will be a >| grand total of $ 482.14. Hope this is OK. >| >| Best regards, >| >| Moe >| ----- Original Message ----- >| From: "Barry Collman" <barry.collman@air-britain.co.uk> >| To: >| Subject: Re: Commander-List: Queen Air Question >| >| >| <barry.collman@air-britain.co.uk> >| > >| > Hi Moe, >| > >| > The Beech 65 Queen Air was initially designated the L-23F, later U-8F. >| However, >| > these had IGSO-480 series engines. >| > >| > The Beech 65-80 and 65-A80 Queen Air had the IGSO-540 series, but I'm not >| sure >| > if the military had this variant. >| > >| > Best Regards, >| > Barry >| > >| > ----- Original Message ----- >| > From: "Moe" <moe(at)rosspistons.com> >| > To: >| > Subject: Commander-List: Queen Air Question >| > >| > >| > | >| > | Commander Folks, >| > | >| > | This is not a Commander question, however, I need a fast answer. >| > | >| > | It is my understanding that one of the branches of the US Military >| purchased >| > some Queen Airs that had the IGSO 540-B1A engines in them. Does anyone >| know the >| > Military designation of the airplane? >| > | >| > | Much Thanks! >| > | >| > | Moe >| > | N680RR >| > | 680F(p) >| > | >| > | >| > | >| > | >| > | >| > | >| > | >| > >| > >| >| >| >| >| >| >| > > > > ________________________________________________________________________________
Date: Sep 13, 2005
Subject: Fly-In
WHERE DID THE SUMMER GO???? The Fly-In is next week so if you're planning on attending you need to make your hotel reservations as rooms are filling up fast and the price is going up. If the price in Marina is too high for your wallet (some hotels are now charging over $150/night) we would recommend nearby Seaside (~ 5 miles and there's a nice Howard Johnson's in the $80 range) or Salinas (~12 miles with many hotels in the $70-90 range). Also if you have not sent in your registration and are planning to attend, PLEASE let us know via email or phone call the number & names in your party so we can have name tags prepared and more importantly an accurate count for food (especially the dinner). We look forward to seeing you all there and having a great time! jb ________________________________________________________________________________
From: "Kristian Meszaros" <krmesza(at)attglobal.net>
"Commander-List Digest List"
Subject: Re: Commander-List Digest: 4 Msgs - 09/12/05
Date: Sep 13, 2005
INNOCENT GLOBAL 0.0000 1.0000 -4.4912 Somehow I remember that the 65-80 series, all of them, had Bendix RSA fuel injectors, not the Simmonds units. They were IGSO540 A1A or A1D Lycs, 380 hp, but not Simmonds equipped. The engines were slightly shorter overall, but higher, as the FCU was mounted in an updraft config. Rehards Kris ----- Original Message ----- From: "Commander-List Digest Server" <commander-list-digest(at)matronics.com> Subject: Commander-List Digest: 4 Msgs - 09/12/05 > * > > ================================================== > Online Versions of Today's List Digest Archive > ================================================== > > Today's complete Commander-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the Commander-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > > http://www.matronics.com/digest/commander-list/Digest.Commander-List.2005-09-12.html > > Text Version: > > > http://www.matronics.com/digest/commander-list/Digest.Commander-List.2005-09-12.txt > > > ================================================ > EMail Version of Today's List Digest Archive > ================================================ > > > Commander-List Digest Archive > --- > Total Messages Posted Mon 09/12/05: 4 > > > Today's Message Index: > ---------------------- > > 1. 07:02 AM - Re: [Fw: [Fw: Hello]] (Moe) > 2. 03:11 PM - Re: Queen Air Question (Moe) > 3. 03:16 PM - Re: Queen Air Question (Barry Collman) > 4. 03:45 PM - Re: Queen Air Question (John Towner) > > > ________________________________ Message 1 > _____________________________________ > > > From: "Moe" <moe(at)rosspistons.com> > Subject: Re: Commander-List: [Fwd: [Fwd: Hello]] > > > John, > > Received two emails from you, however there was no message? > > Moe > ----- Original Message ----- > From: "John Towner" <johntowner(at)centralairsouthwest.com> > Subject: Commander-List: [Fwd: [Fwd: Hello]] > > > >> >> > > > ________________________________ Message 2 > _____________________________________ > > > From: "Moe" <moe(at)rosspistons.com> > Subject: Re: Commander-List: Queen Air Question > > > Barry, > > Thanks for the information. Any ideas on how I might find out if the 65-80 > or 65-A80 were ever used by the US Military? > > Confidentially, (as you may have suspected) I am on a mission to get > information on the Simmonds fuel pumps. If the US Military ever used this > engine, a repair manual was made and can be traced if the aircraft > designation is known. The information on the flow bench used by the > military to test the Simmonds unit by the military has been located, so > one > can only assume that a manual was written explaining how to rebuild the > injector and flow it on the above mentioned flow bench. > > As usual, the companies that had the super cheap prices on the lens did > not > have it in stock and could not guarantee a delivery date, so I will have > the > lens with me next week, however the cost including UPS freight will be a > grand total of $ 482.14. Hope this is OK. > > Best regards, > > Moe > ----- Original Message ----- > From: "Barry Collman" <barry.collman@air-britain.co.uk> > Subject: Re: Commander-List: Queen Air Question > > > <barry.collman@air-britain.co.uk> >> >> Hi Moe, >> >> The Beech 65 Queen Air was initially designated the L-23F, later U-8F. > However, >> these had IGSO-480 series engines. >> >> The Beech 65-80 and 65-A80 Queen Air had the IGSO-540 series, but I'm not > sure >> if the military had this variant. >> >> Best Regards, >> Barry >> >> ----- Original Message ----- >> From: "Moe" <moe(at)rosspistons.com> >> To: >> Subject: Commander-List: Queen Air Question >> >> > purchased >> some Queen Airs that had the IGSO 540-B1A engines in them. Does anyone > know the >> Military designation of the airplane? >> >> > > > ________________________________ Message 3 > _____________________________________ > > > From: "Barry Collman" <barry.collman@air-britain.co.uk> > Subject: Re: Commander-List: Queen Air Question > > <barry.collman@air-britain.co.uk> > > Hi Moe, > > Give me a day or two and I'll try and find out. I know the US Army had > Queen > Airs, but I'm not sure of the Model. > > I'll get back to you as soon as I can. > > Very Best Regards, > Barry > > > ----- Original Message ----- > From: "Moe" <moe(at)rosspistons.com> > Subject: Re: Commander-List: Queen Air Question > > > | > | Barry, > | > | Thanks for the information. Any ideas on how I might find out if the > 65-80 > | or 65-A80 were ever used by the US Military? > | > | Confidentially, (as you may have suspected) I am on a mission to get > | information on the Simmonds fuel pumps. If the US Military ever used > this > | engine, a repair manual was made and can be traced if the aircraft > | designation is known. The information on the flow bench used by the > | military to test the Simmonds unit by the military has been located, so > one > | can only assume that a manual was written explaining how to rebuild the > | injector and flow it on the above mentioned flow bench. > | > | As usual, the companies that had the super cheap prices on the lens did > not > | have it in stock and could not guarantee a delivery date, so I will have > the > | lens with me next week, however the cost including UPS freight will be a > | grand total of $ 482.14. Hope this is OK. > | > | Best regards, > | > | Moe > | ----- Original Message ----- > | From: "Barry Collman" <barry.collman@air-britain.co.uk> > | To: > | Subject: Re: Commander-List: Queen Air Question > | > | > | <barry.collman@air-britain.co.uk> > | > > | > Hi Moe, > | > > | > The Beech 65 Queen Air was initially designated the L-23F, later U-8F. > | However, > | > these had IGSO-480 series engines. > | > > | > The Beech 65-80 and 65-A80 Queen Air had the IGSO-540 series, but I'm > not > | sure > | > if the military had this variant. > | > > | > Best Regards, > | > Barry > | > > | > ----- Original Message ----- > | > From: "Moe" <moe(at)rosspistons.com> > | > To: > | > Subject: Commander-List: Queen Air Question > | > > | > > | > | > | > | Commander Folks, > | > | > | > | This is not a Commander question, however, I need a fast answer. > | > | > | > | It is my understanding that one of the branches of the US Military > | purchased > | > some Queen Airs that had the IGSO 540-B1A engines in them. Does > anyone > | know the > | > Military designation of the airplane? > | > | > | > | Much Thanks! > | > | > | > | Moe > | > | N680RR > | > | 680F(p) > | > | > | > | > | > | > | > | > | > | > | > | > | > | > | > > | > > | > | > | > | > | > | > | > > > ________________________________ Message 4 > _____________________________________ > > > From: John Towner <johntowner(at)centralairsouthwest.com> > Subject: Re: Commander-List: Queen Air Question > > > > *Barry & Moe,* > > I know the Army has and still uses the BE-65 Queen Air and the modded > ones have 8 cyl Lycoming direct drive engines on them. Several years > ago we looked into using this engine I think it is called IO-720, for > the 2 680FL's we use to have because the GSIO-540's that were on them > gave us so much trouble. We never did do the mod and ended up selling > the aircraft > > *YOUR FRIEND, > > John Towner * > > Barry Collman wrote: > >><barry.collman@air-britain.co.uk> >> >>Hi Moe, >> >>Give me a day or two and I'll try and find out. I know the US Army had >>Queen >>Airs, but I'm not sure of the Model. >> >>I'll get back to you as soon as I can. >> >>Very Best Regards, >>Barry >> >> >>----- Original Message ----- >>From: "Moe" <moe(at)rosspistons.com> >>To: >>Subject: Re: Commander-List: Queen Air Question >> >> >>| >>| Barry, >>| >>| Thanks for the information. Any ideas on how I might find out if the >>65-80 >>| or 65-A80 were ever used by the US Military? >>| >>| Confidentially, (as you may have suspected) I am on a mission to get >>| information on the Simmonds fuel pumps. If the US Military ever used >>this >>| engine, a repair manual was made and can be traced if the aircraft >>| designation is known. The information on the flow bench used by the >>| military to test the Simmonds unit by the military has been located, so >>one >>| can only assume that a manual was written explaining how to rebuild the >>| injector and flow it on the above mentioned flow bench. >>| >>| As usual, the companies that had the super cheap prices on the lens did >>not >>| have it in stock and could not guarantee a delivery date, so I will have >>the >>| lens with me next week, however the cost including UPS freight will be a >>| grand total of $ 482.14. Hope this is OK. >>| >>| Best regards, >>| >>| Moe >>| ----- Original Message ----- >>| From: "Barry Collman" <barry.collman@air-britain.co.uk> >>| To: >>| Subject: Re: Commander-List: Queen Air Question >>| >>| >>| <barry.collman@air-britain.co.uk> >>| > >>| > Hi Moe, >>| > >>| > The Beech 65 Queen Air was initially designated the L-23F, later U-8F. >>| However, >>| > these had IGSO-480 series engines. >>| > >>| > The Beech 65-80 and 65-A80 Queen Air had the IGSO-540 series, but I'm >>not >>| sure >>| > if the military had this variant. >>| > >>| > Best Regards, >>| > Barry >>| > >>| > ----- Original Message ----- >>| > From: "Moe" <moe(at)rosspistons.com> >>| > To: >>| > Subject: Commander-List: Queen Air Question >>| > >>| > >>| > | >>| > | Commander Folks, >>| > | >>| > | This is not a Commander question, however, I need a fast answer. >>| > | >>| > | It is my understanding that one of the branches of the US Military >>| purchased >>| > some Queen Airs that had the IGSO 540-B1A engines in them. Does >>anyone >>| know the >>| > Military designation of the airplane? >>| > | >>| > | Much Thanks! >>| > | >>| > | Moe >>| > | N680RR >>| > | 680F(p) >>| > | >>| > | >>| > | >>| > | >>| > | >>| > | >>| > | >>| > >>| > >>| >>| >>| >>| >>| >>| >>| >> >> >> >> > > > ________________________________________________________________________________
Subject: 1961 500B up for auction
Date: Sep 13, 2005
I found this on Trade-a-plane today. Sir Berry, do you have any information on N620DR? Tylor Hall 1961 STRIKE 500B Aero Commander, N620DR, A/C sn 1115-66, TTA unknown, last annual unknown, recorder Semanco International, Ltd., Charlotte, NC 28129. Mr. Dan Seman, President. Title search recorded liens #1 Gem City Aviation BBA, Aztec Executive Flight, Kennesaw, GA, 30144. #2 Rockhill Bank and Trust, Rockhill, SC 29731. Inglewood Aviation, Inc., (IAI), is soliciting bids on aircraft described above. Bids in US dollars will be accepted on an as is, where is, bases until 4:00 pm Eastern Daylight Savings Time, Friday, September 23, 2005 Inglewood Aviation Inc. holds a lien against the airplane for $31,290.17 which will be extinguished via this public sale. The winning bidder will be notified promptly. Satisfactory financial arrangements must be made within (48) hours of notification or bid may be voided. Aircraft may be inspected by appointment. Contact Inglewood Aviation, Inc., NC/(704) 983-1915 or (704) 983-1917. inglewood(at)vnet.net <http://www.trade-a-plane.com/protected/cgi-bin/selleremail.pl?id=729935&ses =696e676c65776f6f6440766e65742e6e6574&srch=%26maxads%3D25%26atcode%3DB%26web class%3D10030%26browse%3Ddetail%26opage%3Dclsfd_boolean_B%26sessionid%3D8147 5831%26start%3D1> Aircraft is located at Albermarle Stanley County Airport, Albermarle, NC. Bids may be mailed to: Inglewood Aviation, Inc., P.O. Box 1720, Albermarle, NC 28002. (VUJ) Minimum bid of $31,290.17. ________________________________________________________________________________
Subject: Re: 1961 500B up for auction
Date: Sep 14, 2005
Hi Tylor, Well, firstly the serial number is wrong. The correct s/n is 1116-66. First Certificated in October 1961, it was placed in the Experimental-R&D category between April and August 1962 for testing of a Federal ITT F-400 Autopilot which set-up received STC SA70CE. Rajay Turbochargers were installed under STCs SE6WE and SA529WE in June 1965 and a 'Miller' nose under STC SA585SW in October 1972. As N789S, it was damaged on February 9th 1988 at Pueblo Memorial Airport, when the right MLG collapsed on rollout. Aircraft veered off the runway and hit a snowbank. Repairs were signed-off as effected on May 17th 1989. It was owned by Aircenter Inc from January 1997 to November 1997, so probably has all the "Shrike" mods. I doubt if a gun/bomb/rocket package was ever installed - it is certainly not a "Strike" Commander! Nothing much else to comment on! Very Best Regards, Barry ----- Original Message ----- From: "tylor.hall" <tylor.hall(at)sbcglobal.net> Subject: Commander-List: 1961 500B up for auction | | I found this on Trade-a-plane today. | Sir Berry, do you have any information on N620DR? | Tylor Hall | | | 1961 STRIKE 500B Aero Commander, N620DR, A/C sn 1115-66, TTA unknown, last | annual unknown, recorder Semanco International, Ltd., Charlotte, NC 28129. | Mr. Dan Seman, President. Title search recorded liens #1 Gem City Aviation | BBA, Aztec Executive Flight, Kennesaw, GA, 30144. #2 Rockhill Bank and | Trust, Rockhill, SC 29731. Inglewood Aviation, Inc., (IAI), is soliciting | bids on aircraft described above. Bids in US dollars will be accepted on an | as is, where is, bases until 4:00 pm Eastern Daylight Savings Time, Friday, | September 23, 2005 Inglewood Aviation Inc. holds a lien against the airplane | for $31,290.17 which will be extinguished via this public sale. The winning | bidder will be notified promptly. Satisfactory financial arrangements must | be made within (48) hours of notification or bid may be voided. Aircraft may | be inspected by appointment. Contact Inglewood Aviation, Inc., NC/(704) | 983-1915 or (704) 983-1917. inglewood(at)vnet.net | <http://www.trade-a-plane.com/protected/cgi-bin/selleremail.pl?id=729935&ses | =696e676c65776f6f6440766e65742e6e6574&srch=%26maxads%3D25%26atcode%3DB%26web | class%3D10030%26browse%3Ddetail%26opage%3Dclsfd_boolean_B%26sessionid%3D8147 | 5831%26start%3D1> Aircraft is located at Albermarle Stanley County Airport, | Albermarle, NC. Bids may be mailed to: Inglewood Aviation, Inc., P.O. Box | 1720, Albermarle, NC 28002. (VUJ) Minimum bid of $31,290.17. | | | | | | | ________________________________________________________________________________
Date: Sep 15, 2005
The IGSO-480A1A6 Had Simmons, Not the same as Simmons on the IGSO540B1A or B1C. The IGSO-480A1E6 has the bendix RS10 fuel injector, Harry ----- Original Message ----- From: "Kristian Meszaros" <krmesza(at)attglobal.net> To: ; "Commander-List Digest List" Sent: Tuesday, September 13, 2005 6:43 PM Subject: Commander-List: Re: Commander-List Digest: 4 Msgs - 09/12/05 > > Somehow I remember that the 65-80 series, all of them, had Bendix RSA fuel > injectors, not the Simmonds units. They were IGSO540 A1A or A1D Lycs, 380 > hp, but not Simmonds equipped. The engines were slightly shorter overall, > but higher, as the FCU was mounted in an updraft config. > > Rehards > > Kris > ----- Original Message ----- > From: "Commander-List Digest Server" > To: "Commander-List Digest List" > Subject: Commander-List Digest: 4 Msgs - 09/12/05 > > > > * > > > > ================================================== > > Online Versions of Today's List Digest Archive > > ================================================== > > > > Today's complete Commander-List Digest can also be found in either of the > > two Web Links listed below. The .html file includes the Digest formatted > > in HTML for viewing with a web browser and features Hyperlinked Indexes > > and Message Navigation. The .txt file includes the plain ASCII version > > of the Commander-List Digest and can be viewed with a generic text editor > > such as Notepad or with a web browser. > > > > HTML Version: > > > > > > http://www.matronics.com/digest/commander-list/Digest.Commander-List.2005-09 -12.html > > > > Text Version: > > > > > > http://www.matronics.com/digest/commander-list/Digest.Commander-List.2005-09 -12.txt > > > > > > ================================================ > > EMail Version of Today's List Digest Archive > > ================================================ > > > > > > Commander-List Digest Archive > > --- > > Total Messages Posted Mon 09/12/05: 4 > > > > > > Today's Message Index: > > ---------------------- > > > > 1. 07:02 AM - Re: [Fw: [Fw: Hello]] (Moe) > > 2. 03:11 PM - Re: Queen Air Question (Moe) > > 3. 03:16 PM - Re: Queen Air Question (Barry Collman) > > 4. 03:45 PM - Re: Queen Air Question (John Towner) > > > > > > ________________________________ Message 1 > > _____________________________________ > > > > > > From: "Moe" <moe(at)rosspistons.com> > > Subject: Re: Commander-List: [Fwd: [Fwd: Hello]] > > > > > > John, > > > > Received two emails from you, however there was no message? > > > > Moe > > ----- Original Message ----- > > From: "John Towner" <johntowner(at)centralairsouthwest.com> > > Subject: Commander-List: [Fwd: [Fwd: Hello]] > > > > > > > >> > >> > > > > > > ________________________________ Message 2 > > _____________________________________ > > > > > > From: "Moe" <moe(at)rosspistons.com> > > Subject: Re: Commander-List: Queen Air Question > > > > > > Barry, > > > > Thanks for the information. Any ideas on how I might find out if the 65-80 > > or 65-A80 were ever used by the US Military? > > > > Confidentially, (as you may have suspected) I am on a mission to get > > information on the Simmonds fuel pumps. If the US Military ever used this > > engine, a repair manual was made and can be traced if the aircraft > > designation is known. The information on the flow bench used by the > > military to test the Simmonds unit by the military has been located, so > > one > > can only assume that a manual was written explaining how to rebuild the > > injector and flow it on the above mentioned flow bench. > > > > As usual, the companies that had the super cheap prices on the lens did > > not > > have it in stock and could not guarantee a delivery date, so I will have > > the > > lens with me next week, however the cost including UPS freight will be a > > grand total of $ 482.14. Hope this is OK. > > > > Best regards, > > > > Moe > > ----- Original Message ----- > > From: "Barry Collman" <barry.collman@air-britain.co.uk> > > Subject: Re: Commander-List: Queen Air Question > > > > > > <barry.collman@air-britain.co.uk> > >> > >> Hi Moe, > >> > >> The Beech 65 Queen Air was initially designated the L-23F, later U-8F. > > However, > >> these had IGSO-480 series engines. > >> > >> The Beech 65-80 and 65-A80 Queen Air had the IGSO-540 series, but I'm not > > sure > >> if the military had this variant. > >> > >> Best Regards, > >> Barry > >> > >> ----- Original Message ----- > >> From: "Moe" <moe(at)rosspistons.com> > >> To: > >> Subject: Commander-List: Queen Air Question > >> > >> > > purchased > >> some Queen Airs that had the IGSO 540-B1A engines in them. Does anyone > > know the > >> Military designation of the airplane? > >> > >> > > > > > > ________________________________ Message 3 > > _____________________________________
August 19, 2005 - September 15, 2005
Commander-Archive.digest.vol-br
