Commander-Archive.digest.vol-bv
December 14, 2005 - January 13, 2006
      > Commander. We fly a 500B for aerial survey work, using a Zeiss LMK2000 in
      a
      > gyro mount. Our work is for precision photogrammetric mapping. I've been
      > doing this stuff since a kid when my Dad got his start with Long Island
      > Airways back in the late sixties doing magnetometer work with mostly
      680e's.
      > The sister company was Canadian.....
      > My company put the hole
      > I'm familiar with SAR, but haven't heard of it being used as low as what
      it
      > sounds like you will be using it. Our stuff now is mostly between 1000'
      and
      > 12,000'.
      > Wonder how many other Commanders on the list are survey aircraft....
      > Steve
Date: Dec 14, 2005
Subject: Re: Documentation & Aerial Survey Aircraft
Don't forget the fuel lines from the fuel valves in the wing to the fuel sump. Maybe those are what you were referring to. Bill Leff ________________________________________________________________________________
Date: Dec 14, 2005
Subject: Re: Documentation +
Check your tach and make sure it is OK, then check the prop blade angles. If properly set you will not get the full 2650 static but 2350 is way low. If the prop blade angels were not set properly the engine will not turn up. I assume the following: Both engines turn up the same Timing is correct Compression is good cam lift is good on all cylinders. ( these engines are notorious for bad cams) Trying to set the automatic turbo controllers is generally not worth the effort as long as you get what you need. Do you still have the extra fuel tank in the nose? Bill Leff ________________________________________________________________________________
Date: Dec 14, 2005
Hey Gang! Even tho I no longer own her,,Lucille--my old Super 680- was used by the state of Kentucky for mappin the state.Of course,,this was many years ago.Just wanted to add her to the list. Big Al ________________________________________________________________________________
From: "Tom Fisher" <tfisher(at)commandergroup.bc.ca>
Date: Dec 14, 2005
Thanks for all of the info and ideas, yes the nose tank is still there but generally empty as is the baggage compartment. I try to cycle fuel through them now and again. Tom F. ----- Original Message ----- From: <BillLeff1(at)aol.com> Subject: Re: Commander-List: Documentation + > > Check your tach and make sure it is OK, then check the prop blade angles. If > properly set you will not get the full 2650 static but 2350 is way low. If > the prop blade angels were not set properly the engine will not turn up. I > assume the following: > > Both engines turn up the same > Timing is correct > Compression is good > cam lift is good on all cylinders. ( these engines are notorious for bad > cams) > > Trying to set the automatic turbo controllers is generally not worth the > effort as long as you get what you need. > > Do you still have the extra fuel tank in the nose? > > Bill Leff > > ________________________________________________________________________________
Subject: Shut-Off Valves
Date: Dec 14, 2005
I ca live with cores, I just have to send them off for overhaul. What pricing?? -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of BillLeff1(at)aol.com Subject: Re: Commander-List: Shut-Off Valves I have several fuel valve cores that are operable but need resealing. Let me know if that is what you are looking for. Bill Leff 937-369-3334 ________________________________________________________________________________
Date: Dec 15, 2005
Subject: Re: (no subject)
Did it still have the camera hole in the tai of the aircraft? Do you know where that aircraft is? If the camera hole has been deactivated, are the control cables still rerouted? I have been looking for that airplane but do not know the serial number. Thanks Bill Leff ________________________________________________________________________________
Date: Dec 16, 2005
Morris usually stocks properly overhauled exchange valves. In my experience it is not worth scrimping on these due to the labor involved. Phil > [Original Message] > From: Ricardo Otaola <otayca(at)telcel.net.ve> > To: > Date: 12/14/2005 6:05:26 PM > Subject: RE: Commander-List: Shut-Off Valves > > > I ca live with cores, I just have to send them off for overhaul. What > pricing?? > > -----Original Message----- > From: owner-commander-list-server(at)matronics.com > [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of > BillLeff1(at)aol.com > To: commander-list(at)matronics.com > Subject: Re: Commander-List: Shut-Off Valves > > > I have several fuel valve cores that are operable but need resealing. Let > me > know if that is what you are looking for. > > Bill Leff > > 937-369-3334 > > ________________________________________________________________________________
Date: Dec 16, 2005
Morris phone number anyone?? -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of br549phil(at)mindspring.com Subject: RE: Commander-List: Shut-Off Valves Morris usually stocks properly overhauled exchange valves. In my experience it is not worth scrimping on these due to the labor involved. Phil > [Original Message] > From: Ricardo Otaola <otayca(at)telcel.net.ve> > To: > Date: 12/14/2005 6:05:26 PM > Subject: RE: Commander-List: Shut-Off Valves > > > I ca live with cores, I just have to send them off for overhaul. What > pricing?? > > -----Original Message----- > From: owner-commander-list-server(at)matronics.com > [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of > BillLeff1(at)aol.com > To: commander-list(at)matronics.com > Subject: Re: Commander-List: Shut-Off Valves > > > I have several fuel valve cores that are operable but need resealing. Let > me > know if that is what you are looking for. > > Bill Leff > > 937-369-3334 > > ________________________________________________________________________________
From: "Randy Dettmer, AIA" <rcdettmer(at)charter.net>
Date: Dec 16, 2005
Here's Morris's phone number - 321 403 8813 cell. Good luck. Randy Dettmer 680F/N6253X -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com]On Behalf Of Ricardo Otaola Subject: RE: Commander-List: Shut-Off Valves Morris phone number anyone?? -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of br549phil(at)mindspring.com Subject: RE: Commander-List: Shut-Off Valves Morris usually stocks properly overhauled exchange valves. In my experience it is not worth scrimping on these due to the labor involved. Phil > [Original Message] > From: Ricardo Otaola <otayca(at)telcel.net.ve> > To: > Date: 12/14/2005 6:05:26 PM > Subject: RE: Commander-List: Shut-Off Valves > > > I ca live with cores, I just have to send them off for overhaul. What > pricing?? > > -----Original Message----- > From: owner-commander-list-server(at)matronics.com > [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of > BillLeff1(at)aol.com > To: commander-list(at)matronics.com > Subject: Re: Commander-List: Shut-Off Valves > > > I have several fuel valve cores that are operable but need resealing. Let > me > know if that is what you are looking for. > > Bill Leff > > 937-369-3334 > > ________________________________________________________________________________
Subject: OneSixRight, the DVD
Date: Dec 17, 2005
While not strictly Aero Commander-related, I hope most will appreciate this post=85 I recently bought this DVD, which is both a clarion call for the preservation of GA airports and a =93biography=94 of a particular airport, Van Nuys, CA. As most of you know VNY is the busiest GA airport in the country. It is actually one of the busiest airports of *any* kind in the world. This DVD traces the history of the airport from inception in 1928 to the present. The cinematography, particularly the air-to-air stuff, is terrific. Among many, there is a brief interview with none other than Bob Hoover! I think many in the group will enjoy this as much as I did. I have no affiliation with makers in any way=85 HYPERLINK "http://www.onesixright.com/"http://www.onesixright.com/ a -- ________________________________________________________________________________
Subject: Thanks for 2005!
Date: Dec 19, 2005
Hey folks, I just wanted to put on the public record my thanks for the great way in which the TCFG and its members have operated during 2005 and festive greetings to everyone. Specifically I want to thank Jimbob for his great goodwill in 'herding Commander frogs' and in sharing his great passion for Commanders. Moe, Nico and Bert have been outstanding contributors with their purchase and display of Commander info and memorabilia that is mostly out of reach for those of us not located in the US. A special thankyou to Sir Barry and Wing Commander Keith for their timely and 'sure hands' approach to sharing such valuable historical and operational data. I am looking forward to the Dayton Flyin next September and urge all members to finds new ways to contribute to the list. A big festive cheer to all from Oz! Russell ________________________________________________________________________________
Date: Dec 19, 2005
Subject: Re: Thanks for 2005!
To all our commander friends. Have a great christmas and new year. Regards from Oz Richard & Jacqui ________________________________________________________________________________
Date: Dec 19, 2005
Thank you for your kind words, Russell. It is truly a labor of love for these wonderful machines. Pity the year sped past with such blinding speed. But then again, the new year will bring with it new opportunities. I wish everyone a Merry Christmas, Happy Hanukkah, and a very prosperous 2006 ! Thank you all who made many a day a delight by sharing an experience, a bit of knowledge and just general 'tire kicking' around Commanderland. Nico ----- Original Message ----- From: <rlegg(at)austarnet.com.au> Subject: Commander-List: Thanks for 2005! > > Hey folks, > > I just wanted to put on the public record my thanks for the great way in > which the TCFG and its members have operated during 2005 and festive > greetings to everyone. > > Specifically I want to thank Jimbob for his great goodwill in 'herding > Commander frogs' and in sharing his great passion for Commanders. > Moe, Nico and Bert have been outstanding contributors with their purchase > and display of Commander info and memorabilia that is mostly out of reach > for those of us not located in the US. > > A special thankyou to Sir Barry and Wing Commander Keith for their timely > and 'sure hands' approach to sharing such valuable historical and > operational data. > > I am looking forward to the Dayton Flyin next September and urge all > members to finds new ways to contribute to the list. > > A big festive cheer to all from Oz! > > Russell > > ________________________________________________________________________________
Date: Dec 19, 2005
To all in Commanderland, I want to add my wish for Merry Christmas and Happy New Year to all. Peace on Earth. I can not say it better than Russell, Richard, and Nico has said. Thank you all for being friends. Tylor Hall On Dec 19, 2005, at 5:36 AM, css nico wrote: > > > Thank you for your kind words, Russell. It is truly a labor of love > for > these wonderful machines. Pity the year sped past with such > blinding speed. > But then again, the new year will bring with it new opportunities. > > I wish everyone a Merry Christmas, Happy Hanukkah, and a very > prosperous > 2006 ! > > Thank you all who made many a day a delight by sharing an > experience, a bit > of knowledge and just general 'tire kicking' around Commanderland. > > Nico > > > ----- Original Message ----- > From: <rlegg(at)austarnet.com.au> > To: > Subject: Commander-List: Thanks for 2005! > > >> >> Hey folks, >> >> I just wanted to put on the public record my thanks for the great >> way in >> which the TCFG and its members have operated during 2005 and festive >> greetings to everyone. >> >> Specifically I want to thank Jimbob for his great goodwill in >> 'herding >> Commander frogs' and in sharing his great passion for Commanders. >> Moe, Nico and Bert have been outstanding contributors with their >> purchase >> and display of Commander info and memorabilia that is mostly out >> of reach >> for those of us not located in the US. >> >> A special thankyou to Sir Barry and Wing Commander Keith for their >> timely >> and 'sure hands' approach to sharing such valuable historical and >> operational data. >> >> I am looking forward to the Dayton Flyin next September and urge all >> members to finds new ways to contribute to the list. >> >> A big festive cheer to all from Oz! >> >> Russell >> >> > > ________________________________________________________________________________
Subject: Christmas
Date: Dec 19, 2005
Commanderland; I too would like to wish everyone a Merry Christmas and a Happy New Year. May we celebrate the Reason for the Season. Don ________________________________________________________________________________
Subject: Cessna 195 crash
Date: Dec 19, 2005
Gentlemen; I just saw on the news of a Cessna 195 crash off St. Augustine and it said the pilot was Gary Tillman of Rome, GA, age 43 and his 16 year old daughter, who are missing. Is this the Gary Tillman who was on the Commander chat list? Either way they need our prayers. Don ________________________________________________________________________________
Subject: Re: Cessna 195 crash
Date: Dec 19, 2005
I found this link: http://www.firstcoastnews.com/news/topstories/news-article.aspx?storyid=49052 with some attached video on the search, from last night's 6 & 11pm news reports from the local channel. I've spoken to Gary on the phone, and he wrote my insurance policy the first year I owned my airplane. I'm holding out hope that the search teams made progress last night and we'll hear something good today.... /John ----- Original Message ----- From: "Don Girod" <dongirod(at)bellsouth.net> Subject: Commander-List: Cessna 195 crash > > Gentlemen; > > I just saw on the news of a Cessna 195 crash off St. Augustine and it said > the pilot was Gary Tillman of Rome, GA, age 43 and his 16 year old daughter, > who are missing. Is this the Gary Tillman who was on the Commander chat > list? Either way they need our prayers. > > Don > > ________________________________________________________________________________
From: "Barry Collman" <barry.collman@air-britain.co.uk>
Date: Dec 19, 2005
Hi All, This is very sad, because I think it is the Gary Tillman some of us have met at Fly-Ins. On the link given by John below, there is a photo of Gary and sadly, it is a face I recognise. Gary was the first auctioneer, at the Hillsboro Fly-In and those present will certainly not forgot it. My heartfelt sympathy goes out to Gary's family and friends. Barry C. (UK) ----- Original Message ----- From: "John Vormbaum" <john(at)vormbaum.com> Subject: Re: Commander-List: Cessna 195 crash | | I found this link: | http://www.firstcoastnews.com/news/topstories/news-article.aspx?storyid=49052 | with some attached video on the search, from last night's 6 & 11pm news | reports from the local channel. | | I've spoken to Gary on the phone, and he wrote my insurance policy the first | year I owned my airplane. I'm holding out hope that the search teams made | progress last night and we'll hear something good today.... | | /John | ----- Original Message ----- | From: "Don Girod" <dongirod(at)bellsouth.net> | To: | Subject: Commander-List: Cessna 195 crash | | | > | > Gentlemen; | > | > I just saw on the news of a Cessna 195 crash off St. Augustine and it said | > the pilot was Gary Tillman of Rome, GA, age 43 and his 16 year old | daughter, | > who are missing. Is this the Gary Tillman who was on the Commander chat | > list? Either way they need our prayers. | > | > Don | > | > | | | | | | | ________________________________________________________________________________
Date: Dec 19, 2005
In a message dated 12/19/2005 10:13:15 A.M. Pacific Standard Time, john(at)vormbaum.com writes: I'm holding out hope Gary was a great guy and his loss will be felt throughout all of aviation. He had been a Commander owner. He attended our first couple of flyins and did the auctions. He was an honest, professional gentleman in the tradition of the "southern gentleman" I will miss him. jb ________________________________________________________________________________
Subject:
Date: Dec 19, 2005
Sad to report that a Mallard went in off the coast Miami Beach FL. Six reported dead for sure, it holds seventeen plus crew of two. On a better note every one have a Merry Christmas and a Happy New Year. Jim Addington N444BD ________________________________________________________________________________
Subject: more on Tillman
Date: Dec 20, 2005
http://www.ajc.com/metro/content/metro/1205/20metplanecrash.html http://www.11alive.com/news/news_article.aspx?storyid=73463 Really sad. bilbo ________________________________________________________________________________
Date: Dec 20, 2005
Our prayers and thoughts go out to Gary's family, and the family of Anna Kipp, as the search continues for him & his daughter Hannah. Randy Dettmer -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com]On Behalf Of Bill Bow Subject: Commander-List: more on Tillman http://www.ajc.com/metro/content/metro/1205/20metplanecrash.html http://www.11alive.com/news/news_article.aspx?storyid=73463 Really sad. bilbo ________________________________________________________________________________
Subject: Re: more on Tillman
Date: Dec 20, 2005
Amen. Nico ----- Original Message ----- From: "Randy Dettmer, AIA" <rcdettmer(at)charter.net> Subject: RE: Commander-List: more on Tillman > > Our prayers and thoughts go out to Gary's family, and the family of Anna > Kipp, as the search continues for him & his daughter Hannah. > > Randy Dettmer > > > -----Original Message----- > From: owner-commander-list-server(at)matronics.com > [mailto:owner-commander-list-server(at)matronics.com]On Behalf Of Bill Bow > To: commander-list(at)matronics.com > Subject: Commander-List: more on Tillman > > > http://www.ajc.com/metro/content/metro/1205/20metplanecrash.html > > > http://www.11alive.com/news/news_article.aspx?storyid=73463 > > > Really sad. > > > bilbo > > ________________________________________________________________________________
Subject:
Date: Dec 20, 2005
0.20 FROM_NO_LOWER From address has no lower-case characters TO ALL A VERY MERRY CHRISTMAS AND A VERY HAPPY AND PROSPEROUS NEW YEAR ( A SAFE ONE). I AM LOOKING FOR A BENCH SEAT FOR A COMMANDER, MORE IMPORTANTLY THE FOUR PINS THAT HOLD A SEAT IN THE FLOOR RAILS. ALSO WOULD LIKE TO BUY/BORROW A STOW A WAY TRAY TABLE TO HAVE A CABINET MAKER BUILD ONE. PLEASE ADVISE. THANK YOU. MASON 2001M ________________________________________________________________________________
Date: Dec 20, 2005
Subject: NICO. PLEASE CALL ME
HI NICO PLEASE CALL ME AT 360-903-6901 THANKS AND METTY CHRISTMAS!! jb ________________________________________________________________________________
Subject: Short ownership
Date: Dec 21, 2005
41KV was purchased in Sept. according to the FAA registry certificate issue date: Serial Number 1422-69 Type Registration Corporation Manufacturer Name AERO COMMANDER Certificate Issue Date 09/08/2005 Model 560-F Status Valid Type Aircraft Fixed Wing Multi-Engine Type Engine Reciprocating Pending Number Change None Dealer No Date Change Authorized None Mode S Code 51151274 MFR Year 1964 Fractional Owner NO Registered Owner Name RUSTY BONES LLC Street 1641 TICE VALLEY BLVD City WALNUT CREEK State CALIFORNIA Zip Code 94595-1625 I see she's for sale again. http://www.controller.com/listings/forsale/detail.asp?OHID1098597&guidDB47B26846124F5294B8149EF97729F6 Waaaaaaaaaaaaaaay out of my price range. . . . The other ad had her for sale in TN (I saved the ad): Contact: Aircenter, Inc. Gary L. Gadberry Send Aircenter, Inc. A Message Aircraft is Located in: Chattanooga, Tennessee, USA Phone: (423)893-5444 Fax: (423)893-5004 I'm only posting for anyone who is interested--nothing more. Ben . ________________________________________________________________________________
Date: Dec 21, 2005
TF, WILL GET COPIES IN NEXT COUPLE OF WEEKS. I LOOKED @ 2001M AND THERE IS A DATA PLATE MOUNTED UNDER ORIGINAL. I WILL TRY TO GET YOU A RUBBING. IT IS VERY FAINT. YOU COULD PROBABLY CUT SHEET METAL AND STAMP ENGINES ON IT AGE IT MOUNT IT AND PUT DIRT AND WAX BUILD UP AROUND IT AND BE OK? MASON HAVE A MERRY CHRISTMAS AND A LESSER EXPENSIVE NEW YEAR ON YOUR BIRD. P S I AM GOING TO BUILD MOUNT FOR BENCH SEAT FROM CARRIAGE BOLTS. IF YOU WILL CONFIRM HOW MANY YOU NEED I WILL BUILD YOUR SETS ALSO. ----- Original Message ----- From: Tom Fisher<mailto:tfisher(at)commandergroup.bc.ca> To: commander-list(at)matronics.com Sent: Saturday, December 10, 2005 7:57 PM Subject: Re: Commander-List: Documentation + Sorry about the blank send a second ago, cell: 604-649-9320 Tom F. ----- Original Message ----- From: "MASON Chevaillier" <kamala(at)msn.com<mailto:kamala(at)msn.com>> To: > Subject: RE: Commander-List: Documentation + > > tf, please forward your phone number i will call you on these. mason > > > >From: "Tom Fisher" <tfisher(at)commandergroup.bc.ca<mailto:tfisher(at)commandergroup.bc.ca>> > >Reply-To: commander-list(at)matronics.com > >To: > > >Subject: Commander-List: Documentation + > >Date: Sat, 10 Dec 2005 15:28:56 -0800 > > > >> > > > >Gents, > > > >I am looking for documentation in the for of drawings or lists of parts on > >the Mr. RPM conversion, one question that came up is that the data plate on > >the aircraft still has the wrong engines on it and we need to see the STC > >to > >determine if the data plate is required to be changed or not. > >Another item is that I have on each engine a plastic air line going from > >the > >fuel pump to the fuel pressure gauge that appears to be an automotive part. > >This too may be mentioned in the STC documentation. > > > >I last heard that Dick sold the MR.RPM rights to a couple of people who > >have > >not been able to supply me with information this summer as they were saying > >"everything is in boxes", and "not set up", any update on them? > > > >My local engineers are about to tackle the job of setting up the engines to > >spec. As I really dislike paying for their learning curve I would like to > >supply them with some form of documentation for this engine setup. > >Short of that I'll pay someone like Morris Kernik to come to Vancouver to > >teach my locals how to service this machine. > > > >I'll take all the responses I can get, I would like to get my plane back > >before the Christmas holidays. > > > >Tom F. > >C-GISS 680FLP (Mr.RPM) > > ________________________________________________________________________________
Date: Dec 21, 2005
Thanks for the thought Mason. I would love to pour over the paperwork. Data plate, well after one of the engineers told me about a possible required data plate I went to look and there was an additional plate there! The Engine model number was and the date (74) was there, so what is the problem? The engineer said that yes it is there but there is no title (label) for the stamped numbers and that is what is was complaining about. A picture of yours to see if it is the same would be great, I don't specifically need the rubbing as I am looking for any other printing that might be on the plate to identify what the numbers stamped on the plate refer to. Seat bolts, thank you for the offer to make eight more attachment seat bolts but I would be very worried if the seat ripped out of it's track during a rapid deceleration, your modified bolts might be stronger than the original but as I fly for the Government I have to keep on the legal side of things as much as possible. I will continue to keep my ear to the ground for these seats track bolts and advise when/if I find some. Tom F. ----- Original Message ----- From: "MASON CHEVAILLIER" <KAMALA(at)msn.com> Subject: Re: Commander-List: Documentation + > > TF, WILL GET COPIES IN NEXT COUPLE OF WEEKS. I LOOKED @ 2001M AND THERE IS A DATA PLATE MOUNTED UNDER ORIGINAL. I WILL TRY TO GET YOU A RUBBING. IT IS VERY FAINT. YOU COULD PROBABLY CUT SHEET METAL AND STAMP ENGINES ON IT AGE IT MOUNT IT AND PUT DIRT AND WAX BUILD UP AROUND IT AND BE OK? MASON HAVE A MERRY CHRISTMAS AND A LESSER EXPENSIVE NEW YEAR ON YOUR BIRD. P S I AM GOING TO BUILD MOUNT FOR BENCH SEAT FROM CARRIAGE BOLTS. IF YOU WILL CONFIRM HOW MANY YOU NEED I WILL BUILD YOUR SETS ALSO. > ----- Original Message ----- > From: Tom Fisher<mailto:tfisher(at)commandergroup.bc.ca> > To: commander-list(at)matronics.com > Sent: Saturday, December 10, 2005 7:57 PM > Subject: Re: Commander-List: Documentation + > > > > > Sorry about the blank send a second ago, cell: 604-649-9320 > Tom F. > > ----- Original Message ----- > From: "MASON Chevaillier" <kamala(at)msn.com<mailto:kamala(at)msn.com>> > To: > > Subject: RE: Commander-List: Documentation + > > > > > > > tf, please forward your phone number i will call you on these. mason > > > > > > >From: "Tom Fisher" > > > >Reply-To: commander-list(at)matronics.com > > >To: > > > >Subject: Commander-List: Documentation + > > >Date: Sat, 10 Dec 2005 15:28:56 -0800 > > > > > >> > > > > > >Gents, > > > > > >I am looking for documentation in the for of drawings or lists of parts > on > > >the Mr. RPM conversion, one question that came up is that the data plate > on > > >the aircraft still has the wrong engines on it and we need to see the STC > > >to > > >determine if the data plate is required to be changed or not. > > >Another item is that I have on each engine a plastic air line going from > > >the > > >fuel pump to the fuel pressure gauge that appears to be an automotive > part. > > >This too may be mentioned in the STC documentation. > > > > > >I last heard that Dick sold the MR.RPM rights to a couple of people who > > >have > > >not been able to supply me with information this summer as they were > saying > > >"everything is in boxes", and "not set up", any update on them? > > > > > >My local engineers are about to tackle the job of setting up the engines > to > > >spec. As I really dislike paying for their learning curve I would like > to > > >supply them with some form of documentation for this engine setup. > > >Short of that I'll pay someone like Morris Kernik to come to Vancouver to > > >teach my locals how to service this machine. > > > > > >I'll take all the responses I can get, I would like to get my plane back > > >before the Christmas holidays. > > > > > >Tom F. > > >C-GISS 680FLP (Mr.RPM) > > > > > ________________________________________________________________________________
Date: Dec 21, 2005
Subject: 520 Aero Commander Pilot Report June 1968
I just sent the June 1968 Pilot Report on the 520, hope you all enjoy. And Merry Christmas and Happy New Years to you all. Bert ________________________________________________________________________________
Subject: Re: 520 Aero Commander Pilot Report June 1968
Date: Dec 21, 2005
Thanks Bert, not only for this item, but also for all the others that you have taken the time and trouble to scan and make available to the Commander Community. A Very Merry Christmas and New Year to you and to All my other Friends in wonderful CommanderLand! Barry C. (UK) ----- Original Message ----- From: <BertBerry1(at)aol.com> Subject: Commander-List: 520 Aero Commander Pilot Report June 1968 | | I just sent the June 1968 Pilot Report on the 520, hope you all enjoy. And | Merry Christmas and Happy New Years to you all. | | Bert | | | | | | | ________________________________________________________________________________
Subject: Seat bolts
Date: Dec 21, 2005
For the seat mounting bolts "studs" talk to Nick Freeman at Aero Air in Oregon he knows the part number and source for them. Mike Floyd Commander NW LTD ________________________________________________________________________________
Subject: Re: Seat bolts
Date: Dec 21, 2005
Thanks for that information, anyone have the number for Aero Air? Tom F. ----- Original Message ----- From: "mike floyd" <floydgm(at)hotmail.com> Subject: Commander-List: Seat bolts > > For the seat mounting bolts "studs" talk to Nick Freeman at Aero Air in > Oregon he knows the part number and source for them. > > Mike Floyd > Commander NW LTD > > > > > > > > ________________________________________________________________________________
Subject: Seat Bolts
Date: Dec 21, 2005
Aero Air Phone number is: 1-800-448-2376 ________________________________________________________________________________
Date: Dec 21, 2005
It is true is Gary Tillman from Georgia they have not found them or the aircraft, went down Sunday off the St. Augustine coast, Gary had a 500A commander that he sold a couple of years ago. A very nice gentleman. AB ________________________________________________________________________________
Date: Dec 21, 2005
I bought Gary's Aero Commander a little over two years ago. My wife and I were very sorry to hear this news this week and have his family, and the families of the other passengers in our hearts and thoughts. Alan On 12/21/05, N560WM(at)aol.com wrote: > > > It is true is Gary Tillman from Georgia they have not found them or the > aircraft, went down Sunday off the St. Augustine coast, Gary had a > 500A commander > that he sold a couple of years ago. > A very nice gentleman. > > AB > > ________________________________________________________________________________
Date: Dec 21, 2005
Would this renew the single vs. multi engine debate? I see a lot of single engine light planes cross the LA metropolitan area at about 1,000' AGL every night, with no place to land within 50 miles. Multi engine planes are more expensive in many ways. In my opinion, it is always a wise investment. Nico ----- Original Message ----- From: "Alan Kucheck" <akucheck(at)gmail.com> Subject: Re: Commander-List: Cessna 195 crash > > I bought Gary's Aero Commander a little over two years ago. My wife and I > were very sorry to hear this news this week and have his family, and the > families of the other passengers in our hearts and thoughts. > > Alan > > > On 12/21/05, N560WM(at)aol.com wrote: > > > > > > It is true is Gary Tillman from Georgia they have not found them or the > > aircraft, went down Sunday off the St. Augustine coast, Gary had a > > 500A commander > > that he sold a couple of years ago. > > A very nice gentleman. > > > > AB > > > > > > ________________________________________________________________________________
Subject: Re: Short ownership N41KV
Date: Dec 21, 2005
N41KV was the last MR RPM conversion done in the late 1999 or 2000. You know about the "How to make a small fortune in Aviation?" Start with a large one. This is an example. these are very good photos of the new paint job that I have not seen before. Tylor Hall On Dec 21, 2005, at 6:44 AM, Ben Baltrusaitis wrote: > > > 41KV was purchased in Sept. according to the FAA registry > certificate issue date: > > Serial Number > > 1422-69 > > Type Registration > > Corporation > > Manufacturer Name > > AERO COMMANDER > > Certificate Issue Date > > 09/08/2005 > > Model > > 560-F > > Status > > Valid > > Type Aircraft > > Fixed Wing Multi-Engine > > Type Engine > > Reciprocating > > Pending Number Change > > None > > Dealer > > No > > Date Change Authorized > > None > > Mode S Code > > 51151274 > > MFR Year > > 1964 > > Fractional Owner > > NO > > > Registered Owner > > Name > > RUSTY BONES LLC > > Street > > 1641 TICE VALLEY BLVD > > City > > WALNUT CREEK > State > CALIFORNIA > > Zip Code > 94595-1625 > > > I see she's for sale again. > http://www.controller.com/listings/forsale/detail.asp? > OHID1098597&guidDB47B26846124F5294B8149EF97729F6 > > Waaaaaaaaaaaaaaay out of my price range. . . . > > The other ad had her for sale in TN (I saved the ad): > Contact: > Aircenter, Inc. > Gary L. Gadberry > Send Aircenter, Inc. A Message > > Aircraft is Located in: > Chattanooga, Tennessee, USA > Phone: (423)893-5444 > Fax: (423)893-5004 > > I'm only posting for anyone who is interested--nothing more. > Ben . > > ________________________________________________________________________________
Date: Dec 21, 2005
Has anyone heard anything new on Gary Tillman? He will be missed. Yes Nico, flying over tall mountains, oceans, and LA, Two seems like a good investment. Tylor Hall On Dec 21, 2005, at 3:54 PM, css nico wrote: > > > Would this renew the single vs. multi engine debate? > > I see a lot of single engine light planes cross the LA metropolitan > area at > about 1,000' AGL every night, with no place to land within 50 > miles. Multi > engine planes are more expensive in many ways. In my opinion, it is > always a > wise investment. > > Nico > > > ----- Original Message ----- > From: "Alan Kucheck" <akucheck(at)gmail.com> > To: > Subject: Re: Commander-List: Cessna 195 crash > > >> >> >> I bought Gary's Aero Commander a little over two years ago. My >> wife and I >> were very sorry to hear this news this week and have his family, >> and the >> families of the other passengers in our hearts and thoughts. >> >> Alan >> >> >> On 12/21/05, N560WM(at)aol.com wrote: >>> >>> >>> It is true is Gary Tillman from Georgia they have not found them >>> or the >>> aircraft, went down Sunday off the St. Augustine coast, Gary had a >>> 500A commander >>> that he sold a couple of years ago. >>> A very nice gentleman. >>> >>> AB >>> >>> >> >> > > ________________________________________________________________________________
Date: Dec 21, 2005
In a message dated 12/21/2005 11:48:09 A.M. Pacific Standard Time, tfisher(at)commandergroup.bc.ca writes: Thanks for that information HI TOM. It sure sounds like you are having a ton of trouble with this Commander. Who did your pre-buy inspection?? Merry Christmas jb ________________________________________________________________________________
Date: Dec 21, 2005
A firm in Toronto did the annual (they have been doing this aircraft for a number of years) I purchased it sight unseen (photos only). When it is the only one in the world for sale and you have waited for over two years to get one and the owner keeps putting it on year long contracts instead of selling it, I expected to sink another $50,000 into it but not for basic things like installing a non-existent hydraulic filter. Someone has suggested that this aircraft may not be airworthy due to the 18" square hole cut out of the aft cabin bulkhead to accommodate previously installed equipment, that will be fun. I did not have the cash up front to buy one (if available) that was in better shape but I have the cash flow to slowly support the aircraft and bring it up to snuff. Look at the prices some are asking for the two 680's (Mr.RPM) currently for sale $395,000. & $425,000. , not in my ballpark. Happy humbugs! Tom F. ----- Original Message ----- From: <YOURTCFG(at)aol.com> Subject: Re: Commander-List: Seat bolts > > In a message dated 12/21/2005 11:48:09 A.M. Pacific Standard Time, > tfisher(at)commandergroup.bc.ca writes: > > Thanks for that information > HI TOM. > > It sure sounds like you are having a ton of trouble with this Commander. > Who did your pre-buy inspection?? Merry Christmas jb > > ________________________________________________________________________________
Subject: Hoover technique question
Date: Dec 22, 2005
Commander-Land A while back I forwarded some of the commander-list's e-mails to Bill Leff. Bill, as some of you know, has a lot of experience with Commanders. He was a good friend and protege of Dick Wartinger's. (Bill knew Dick since he was 12 or 13.) Bill is a pilot's pilot, a former TWA MD-80 instructor, and he has a couple of aerobatic acts, one of which is doing aerobatics at night with fireworks shooting from the wings of his plane (a T-6). Anyway I sent the "Hoover Technique Question" to Bill and this was his answer. I thought Bill's responses/insights were very informative (less rudder input to reduce drag and structural stress???). I also thought the question at the end of Bill's e-mail was interesting. Hope you all have a great Christmas and a prosperous New Year! Bob Steele, Proud (Unsuspecting) Recipient of the TCFG 2005 Golden Rudder Award (and looking forward to passing it on at the 2006 DaytonFly-In) Alan Kucheck - you should come to this one too! -----Original Message----- From: BillLeff(at)aol.com [mailto:BillLeff(at)aol.com] Subject: Re: FW: Commander-List: Hoover technique question Bob Hoover probably shut his engines down using that procedure to reduce the drag incurred during that procedure. Remember his routine was an energy management program. everything he did was done to reduce drag. Watch how much control input he used during rolls. He did not use as much rudder as you would think would be necessary. That reduced drag by not displacing the rudder as much as would be needed to make a perfectly coordinated roll. It was a compromise to reduce structural loads and reduce drag. Bob never had cylinder problems because the head temps on a Shrike normally don't get hot enough to cause thermal shock. So, shutting them down from full power and restarting them to full power just was not a problem as far as the cylinders go. The shut down and start up was so fast it probably never bothered the counterweights. Geared engine airplanes would not stand up well to this treatment. In defense of geared engines, most of the older great aerobatic pilots like Art Sholl and Ed Maler. used geared Lycomings in their aerobatic aircraft. They are very strong when operated properly. His plane was absolutely stock except for the following: It had an additional accumulator to prevent the nose wheel from extending when both engines were shut down. Remember, the aux hydraulic pump does nothing for the gear> The unfeathering pumps normally had a single switch that could operate either the left or right pumps individually. On Bobs Plane he had micro switches that, when armed, would turn on the pump on its respective engine when the prop control is moved to the full forward position. There was nothing done to the mag system. The rest was just a great pilot and a great airplane. By the way, I did work on both of his airplanes. The Shrike and the "Hoover Hornet". Anybody know why a Shrike is called a Shrike? Bill Leff ________________________________________________________________________________
Date: Dec 22, 2005
Subject: Re: Hoover technique question
Nice post, Bob, we appreciate it. Thanks, Rob Munro In a message dated 12/22/2005 7:09:00 AM Central Standard Time, bob.steele(at)kzf.com writes: > > > > Commander-Land > > A while back I forwarded some of the commander-list's e-mails to Bill Leff. > Bill, as some of you know, has a lot of experience with Commanders. He was > a good friend and protege of Dick Wartinger's. (Bill knew Dick since he was > 12 or 13.) Bill is a pilot's pilot, a former TWA MD-80 instructor, and he > has a couple of aerobatic acts, one of which is doing aerobatics at night > with fireworks shooting from the wings of his plane (a T-6). > > Anyway I sent the "Hoover Technique Question" to Bill and this was his > answer. > > I thought Bill's responses/insights were very informative (less rudder input > to reduce drag and structural stress???). I also thought the question at > the end of Bill's e-mail was interesting. > > Hope you all have a great Christmas and a prosperous New Year! > > Bob Steele, > Proud (Unsuspecting) Recipient of the TCFG 2005 Golden Rudder Award > (and looking forward to passing it on at the 2006 DaytonFly-In) > Alan Kucheck - you should come to this one too! > > > -----Original Message----- > From: BillLeff(at)aol.com [mailto:BillLeff(at)aol.com] > To: bob.steele(at)kzf.com > Subject: Re: FW: Commander-List: Hoover technique question > > > Bob Hoover probably shut his engines down using that procedure to reduce the > drag incurred during that procedure. Remember his routine was an energy > management program. everything he did was done to reduce drag. Watch how > much control input he used during rolls. He did not use as much rudder as > you would think would be necessary. That reduced drag by not displacing the > rudder as much as would be needed to make a perfectly coordinated roll. It > was a compromise to reduce structural loads and reduce drag. > > Bob never had cylinder problems because the head temps on a Shrike normally > don't get hot enough to cause thermal shock. So, shutting them down from > full power and restarting them to full power just was not a problem as far > as the cylinders go. The shut down and start up was so fast it probably > never bothered the counterweights. Geared engine airplanes would not stand > up well to this treatment. In defense of geared engines, most of the older > great aerobatic pilots like Art Sholl and Ed Maler. used geared Lycomings in > their aerobatic aircraft. They are very strong when operated properly. > > His plane was absolutely stock except for the following: > > It had an additional accumulator to prevent the nose wheel from extending > when both engines were shut down. Remember, the aux hydraulic pump does > nothing for the gear> > > The unfeathering pumps normally had a single switch that could operate > either the left or right pumps individually. On Bobs Plane he had micro > switches that, when armed, would turn on the pump on its respective engine > when the prop control is moved to the full forward position. > > There was nothing done to the mag system. > > The rest was just a great pilot and a great airplane. > > By the way, I did work on both of his airplanes. The Shrike and the "Hoover > Hornet". > > Anybody know why a Shrike is called a Shrike? > > Bill Leff ________________________________________________________________________________
Date: Dec 22, 2005
I have no idea why they called it a Shrike, but I'm very interested to know. ________________________________________________________________________________
Subject: Fw: This is amazing
Date: Dec 22, 2005
Now, that's what I call progress in the right direction. Flying one day in a projected, virtual cockpit? Look closely n' guess what they could be... PENS WITH HIDDEN CAMS????? Any other wild guesses now? No clue? You have just now looked into the future. You have seen something that would replace your PC in the near future. LOOK AT THIS... In the revolution of miniature of computers, the scientists are ahead with Bluetooth technology... See the forthcoming computers within our pockets .. This pen "sort of instrument" produces both the monitor as well as the keyboard on flat surfaces from where you can just carry out the normal operations you do on your desktop. ________________________________________________________________________________
Subject: Re: Fw: This is amazing
Date: Dec 22, 2005
I must be missing something, were there meant to be links in this post? Tom F. ----- Original Message ----- From: "css nico" <nico(at)cybersuperstore.com> Subject: Commander-List: Fw: This is amazing > > Now, that's what I call progress in the right direction. Flying one day in a projected, virtual cockpit? > > > Look closely n' guess what they could be... > > > PENS WITH HIDDEN CAMS????? > > > Any other wild guesses now? > > No clue? > > You have just now > > looked into the future. > > You have seen something that would replace your PC in > > the near future. > > > LOOK AT THIS... > > > In the revolution of miniature of computers, the scientists > > are ahead with Bluetooth technology... See the forthcoming > > computers within our pockets .. > > > This pen "sort of instrument" > > produces both the monitor as well > > as the keyboard on flat surfaces from where you can just > > carry out the normal operations you do on your desktop. > > ________________________________________________________________________________
Date: Dec 22, 2005
In a message dated 22-Dec-05 05:06:46 Pacific Standard Time, bob.steele(at)kzf.com writes: Anybody know why a Shrike is called a Shrike? A Shrike is a bird of prey -- but it begs the question why this one model got a product name (other than the "Grand Commander") when the rest of the product line did not. OK, Bill, what's the scoop? Wing Commander Gordon Life is not simple anywhere. Probably less so elsewhere. ________________________________________________________________________________
Date: Dec 22, 2005
The shrike (bird) is somewhat unusual in that it preys on other birds. If I remember correctly, Rockwell wanted their Shrike to prey on the competition (other "birds"). And since at least some Commanders were named after real birds (e.g. Hawk, Courser), this also fit with their naming convention. Stan N681SP ________________________________________________________________________________
Date: Dec 22, 2005
In a message dated 22-Dec-05 09:35:24 Pacific Standard Time, swperk(at)earthlink.net writes: And since at least some Commanders were named after real birds (e.g. Hawk, Courser), this also fit with their naming convention. I forgot about those! Good call, Stan. When compared to other product lines the Commanders were fairly devoid of spiffy marketing names drawn from birds, aboriginal tools and tribes, royalty, etc. Wing Commander Gordon Life is not simple anywhere. Probably less so elsewhere. ________________________________________________________________________________
Date: Dec 22, 2005
Along with the 'Shrike', 'Courser' and 'Hawk' on the Twin Commanders, some of the single-engined Commanders also got bird names. (Remember the 'Tough Bird' advertising?). These included Sparrow, Quail, Thrush & Snipe for the 'Ag' types and Darter and Lark for the Cessna 150 look-a-like. Those were the days! Barry C (UK) ----- Original Message ----- From: <CloudCraft(at)aol.com> Subject: Re: Commander-List: Hoover technique question | | In a message dated 22-Dec-05 09:35:24 Pacific Standard Time, | swperk(at)earthlink.net writes: | And since at least some Commanders were named after real birds (e.g. Hawk, | Courser), this also fit with their naming convention. | I forgot about those! Good call, Stan. | | When compared to other product lines the Commanders were fairly devoid of | spiffy marketing names drawn from birds, aboriginal tools and tribes, royalty, | etc. | | Wing Commander Gordon | | Life is not simple anywhere. Probably less so elsewhere. | | | | | | | ________________________________________________________________________________
Date: Dec 22, 2005
Subject: Fwd: 500A
Date: Thu, 22 Dec 2005 09:36:13 -0800 (PST) From: Craig Lundborg <dltafolk(at)sbcglobal.net> Subject: 500A --0-1852664860-1135272973=:59838 Hi Folks, Well several years and a lot of having to fly single engine planes has finally brought me to putting a down payment on a 500A. Does anyone have any info besides registration on this bird...1260B, 500A 1121-57 I sincerely hope it is positive! Craig Lundborg dltafolk(at)sbcglobal.net --0-1852664860-1135272973=:59838 Hi Folks, Well several years and a lot of having to fly single engine planes has finally brought me to putting a down payment on a 500A. Does anyone have any info besides registration on this bird...1260B, 500A 1121-57 I sincerely hope it is positive! Craig Lundborg dltafolk(at)sbcglobal.net --0-1852664860-1135272973=:59838-- ________________________________________________________________________________
Date: Dec 22, 2005
Bert, I am holding off on posting this to my webserver since I should receive the logon privileges for the Commander website imminently. I will then transfer all the postings to their proper location. In future, you may still send the stuff to me from where I will take care of it. Thanks Nico ----- Original Message ----- From: <BertBerry1(at)aol.com> Subject: Commander-List: 520 Aero Commander Pilot Report June 1968 > > I just sent the June 1968 Pilot Report on the 520, hope you all enjoy. And > Merry Christmas and Happy New Years to you all. > > Bert > > ________________________________________________________________________________
Date: Dec 22, 2005
Sorry, folks. I forgot that the Commander list strips off all images. You may look at this thing at http://www.teletuition.org/documents/space/RE_%20Fw_%20This%20is%20amazing.h tm Thanks Nico ----- Original Message ----- From: "Tom Fisher" <tfisher(at)commandergroup.bc.ca> Subject: Re: Commander-List: Fw: This is amazing > > I must be missing something, were there meant to be links in this post? > Tom F. > > ----- Original Message ----- > From: "css nico" <nico(at)cybersuperstore.com> > To: "art la combe" <10sne1(at)sbcglobal.net> > Subject: Commander-List: Fw: This is amazing > > > > > > > Now, that's what I call progress in the right direction. Flying one day in > a projected, virtual cockpit? > > > > > > Look closely n' guess what they could be... > > > > > > PENS WITH HIDDEN CAMS????? > > > > > > Any other wild guesses now? > > > > No clue? > > > > You have just now > > > > looked into the future. > > > > You have seen something that would replace your PC in > > > > the near future. > > > > > > LOOK AT THIS... > > > > > > In the revolution of miniature of computers, the > scientists > > > > are ahead with Bluetooth technology... See the > forthcoming > > > > computers within our pockets .. > > > > > > This pen "sort of instrument" > > > > produces both the monitor as well > > > > as the keyboard on flat surfaces from where you can just > > > > carry out the normal operations you do on your desktop. > > > > > > ________________________________________________________________________________
Subject: T'was the Night Before Christmas - Sports Planes Style
Date: Dec 22, 2005
'Twas the night before Christmas, when all through the forum not an EMAIL was posted, not even a note. The stockings were hung by the laptop with care, in hopes that Tom P. soon would be there. The pilots were nestled all snug in their beds, while visions of SLSA's danced in their heads. The aircraft in their hangars, and I in my cap, had just settled our brains for a long winter's nap. When out on the tarmac there arose such a clatter, I sprang from my desk to see what was the matter. Away to the window I flew like a flash, tore open the shutter, and threw up the sash. The moon on the breast of the new-fallen snow gave the lustre of midday to the tie-downs below, when, what to my wondering eyes should appear, but a Light Sport Aircraft and eight big EAA 'rs. With a little old pilot, so lively and quick, I knew in a moment it must be Tom P. More rapid than eagles, his coursers they came, and he whistled and shouted and called them by name: "Now Rutan! Now Melville! Now, Fossett and Boyer! On, Lawrence! On, Heintz! On, Van G and Sawyer! To the end of the runway! To the tie-down area Now Shut Down ! Shut Down! Shut Down All Engines" As dry leaves that before the wild hurricane fly, when they meet with an obstacle, mount to the sky so up to the top of the FBO they flew, with the sleigh full of flight toys, and Tom P. too. And then, in a twinkling, I heard on the roof the prancing and pawing of each little hoof. As I drew in my head and was turning around, down the chimney Tom P. came with a bound. He was dressed all in fur, from his head to his foot, and his clothes were all tarnished with ashes and soot. A bundle of new FAA rules he had flung on his back, and he looked like a peddler just opening his pack. He spoke not a word, but went straight to his work, and filled all the stockings, with SP and LSA Rulings. And laying his finger aside of his nose, and giving a nod, up the chimney he rose. He sprang to his SLSA, completed his preflight, And away he flew like the down of a thistle. But I heard him exclaim, 'ere he flew out of sight, "Happy Christmas to all, and to all a good night!" (An Adaptation of the Classic Poem, "T'was the Night Before Christmas") Merry Christmas and Happy New Year to All Jim Pellien Mid-Atlantic Sports Planes The Mid-Atlantic Region of SportsPlanes.com www.MASPL.com 703-313-4818 ________________________________________________________________________________
Subject: Fw: This is amazing (3rd try)
Date: Dec 22, 2005
Let's try one more time. http://www.teletuition.org/documents/space/RE_%20Fw_%20This%20is%20amazing.h tm ----- Original Message ----- From: "css nico" <nico(at)cybersuperstore.com> Subject: Commander-List: Fw: This is amazing > > Sorry, folks. I forgot that the Commander list strips off all images. You > may look at this thing at > Thanks > Nico > > > ----- Original Message ----- > From: "Tom Fisher" <tfisher(at)commandergroup.bc.ca> > To: > Subject: Re: Commander-List: Fw: This is amazing > > > > > > > I must be missing something, were there meant to be links in this post? > > Tom F. > > > > ----- Original Message ----- > > From: "css nico" <nico(at)cybersuperstore.com> > > To: "art la combe" <10sne1(at)sbcglobal.net> > > Subject: Commander-List: Fw: This is amazing > > > > > > > > > > > > Now, that's what I call progress in the right direction. Flying one day > in > > a projected, virtual cockpit? > > > > > > > > > Look closely n' guess what they could be... > > > > > > > > > PENS WITH HIDDEN CAMS????? > > > > > > > > > Any other wild guesses now? > > > > > > No clue? > > > > > > You have just now > > > > > > looked into the future. > > > > > > You have seen something that would replace your PC in > > > > > > the near future. > > > > > > > > > LOOK AT THIS... > > > > > > > > > In the revolution of miniature of computers, the > > scientists > > > > > > are ahead with Bluetooth technology... See the > > forthcoming > > > > > > computers within our pockets .. > > > > > > > > > This pen "sort of instrument" > > > > > > produces both the monitor as well > > > > > > as the keyboard on flat surfaces from where you can > just > > > > > > carry out the normal operations you do on your > desktop. > > > > > > > > > > > > ________________________________________________________________________________
Date: Dec 23, 2005
They all had names 681 was the Hawk 680FL was the Courser 500S was the Shrike The singles were the Lark and Darter The Ag Plane was the Thrush Though Birds!!! I'll let you know that a Shrike is after Christmas Keep guessing Bill Leff ________________________________________________________________________________
Date: Dec 23, 2005
I forgot the Quail, Sparrow and Snipe AG Planes Bill Leff ________________________________________________________________________________
Date: Dec 23, 2005
Subject: Recurrent training
This is typical CRM training. From: "Greg Vail" <greg(at)bloomingtonavionics.com> Subject: FW: I've been flying Date: Fri, 23 Dec 2005 11:01:04 -0600 Just want you to know I've been flying a lot http://worteldrie.com/flash/emergency.swf Just want you to know I've been flying a lot http://worteldrie.com/flash/emergency.swf ________________________________________________________________________________
Subject: Re: Commander-List Digest: 1 Msgs - 12/23/05
Date: Dec 24, 2005
FYI...new Commander vids "freightdog" at: twincommanderflyer.com enjoy! -------------- Original message -------------- From: Commander-List Digest Server <commander-list-digest(at)matronics.com> > * > > ================================================== > Online Versions of Today's List Digest Archive > ================================================== > > Today's complete Commander-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the Commander-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > > http://www.matronics.com/digest/commander-list/Digest.Commander-List.2005-12-23. > html > > Text Version: > > > http://www.matronics.com/digest/commander-list/Digest.Commander-List.2005-12-23. > txt > > > ================================================ > EMail Version of Today's List Digest Archive > ================================================ > > > Commander-List Digest Archive > --- > Total Messages Posted Fri 12/23/05: 1 > > > Today's Message Index: > ---------------------- > > 1. 10:56 AM - Recurrent training (BillLeff1(at)aol.com) > > > > ________________________________ Message 1 > _____________________________________ > > > From: BillLeff1(at)aol.com > Subject: Commander-List: Recurrent training > > > This is typical CRM training. > > From: "Greg Vail" > Subject: FW: I've been flying > > > Just want you to know I've been flying a lot > > http://worteldrie.com/flash/emergency.swf > > > > > > > Just want you to know > I've been flying a lot > > http://worteldrie.com/flash/emergency.swf > > > > > > > > > > > > > > > > > > > > > FYI...new Commander vids "freightdog"at: twincommanderflyer.com enjoy! -------------- Original message -------------- From: Commander-List Digest Server commander-list-digest(at)matronics.com * ================================================== Online Versions of Today's List Digest Archive ================================================== Today's complete Commander-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the Commander-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/commander-list/ Digest.Commander-List.2005-12-23. html Text Version: http://www.matronics.com/digest/commander-list/Digest.Commander-List.2005-12-23. txt ================================================ EMail Version of Today's List Digest Archive ================================================ Commander-List Digest Archive --- Total Messages Posted Fri 12/23/05: 1 Today's Message Index: ---------------------- 1. 10:56 AM - Recurrent training (BillLeff1(at)aol.com) ________________________________ Message 1 _____________________________________ From: B illLeff1(at)aol.com Subject: Commander-List: Recurrent training -- Commander-List message posted by: BillLeff1(at)aol.com This is typical CRM training. From: "Greg Vail" <GREG(at)BLOOMINGTONAVIONICS.COM> Subject: FW: I've been flying Just want you to know I've been flying a lot http://worteldrie.com/flash/emergency.swf Just want you to know I've been flying a lot http://worteldrie.com/flash/emergency.swf =================================== ________________________________________________________________________________
Date: Dec 26, 2005
bill bow asked a question about aopa - good or bad? on either this or the twin commander site. since i think more of us are on this page, i am posting my reply here. as a member for about thirty five years, i think it is well worth the money. you get a subscription to the aopa pilot and a representative in washington for issues that concern aircraft owners and operators. as an airline captain, bill already gets the discount at motels, hotels, and rental car agencies, but some of us may not get them. aopa gets those discounts. the kicker is the aopa mbna credit card. with that you get rebates on fuel of 5% and rebates at shorty's pilot shop up to $250.00. i am sure there are other ways to get those rebates, but for me, it was like found money. i did not mention, title searches, medical assistance, legal panel, web site access, but you get the picture. if you are not already a member, now is the time to join. www.aopa.org. allan hoffman ________________________________________________________________________________
Date: Dec 26, 2005
Ha Ha Ha. That's funny, Bill. Happens to me all the time. I have the video where you flew the Orenda Aero Commander. I assume that's you. What happened to the Orenda project? http://www.teletuition.org/documents/Aviation/Aero%20Commanders/Aero%20Comma nder%20Orenda%20Engine/ Have you ever had a look at the Zoche's? http://www.zoche.de/ Sounds exciting and it appears as if they are well funded and eager to complete this project. Thanks Nico ----- Original Message ----- From: <BillLeff1(at)aol.com> Subject: Commander-List: Recurrent training > > This is typical CRM training. > > From: "Greg Vail" <greg(at)bloomingtonavionics.com> > To: > Subject: FW: I've been flying > Date: Fri, 23 Dec 2005 11:01:04 -0600 > > > Just want you to know I've been flying a lot > > http://worteldrie.com/flash/emergency.swf > > > > > > > Just want you to know > I've been flying a lot > > http://worteldrie.com/flash/emergency.swf > > ________________________________________________________________________________
Date: Dec 27, 2005
Subject: Shrike
As promised: Why is a 500S called a Shrike? Some time ago I was in a long layover at Chicago Miegs Field (yes before if was dug up by the mayor !) While I was killing time I went to The Field Museum (for the 4000th time, I have been going to that airport since 1972 on a regular basis). Since I had run out of things I was interested in to look at the museum, I decided to Aviary and look at birds ( I was really board!) As I was looking at the thousands of birds on display a SHRIKE jumped out at me. So, I read about Shrikes. In the description if the shrike it said "A Shrike is a little Hawk" Mostly because it hunts like one. Since the 681 Turbo Commander was a "Hawk" then a 500S is a "Little Hawk"! That is the official Ornithological description of a Shrike. Happy new year! Bill Leff ________________________________________________________________________________
Date: Dec 27, 2005
Very interesting. Both of them. bilbo -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of css nico Subject: Commander-List: Recurrent training Ha Ha Ha. That's funny, Bill. Happens to me all the time. I have the video where you flew the Orenda Aero Commander. I assume that's you. What happened to the Orenda project? http://www.teletuition.org/documents/Aviation/Aero%20Commanders/Aero%20Comma nder%20Orenda%20Engine/ Have you ever had a look at the Zoche's? http://www.zoche.de/ Sounds exciting and it appears as if they are well funded and eager to complete this project. Thanks Nico ----- Original Message ----- From: <BillLeff1(at)aol.com> Subject: Commander-List: Recurrent training > > This is typical CRM training. > > From: "Greg Vail" <greg(at)bloomingtonavionics.com> > To: > Subject: FW: I've been flying > Date: Fri, 23 Dec 2005 11:01:04 -0600 > > > Just want you to know I've been flying a lot > > http://worteldrie.com/flash/emergency.swf > > > > > > > Just want you to know > I've been flying a lot > > http://worteldrie.com/flash/emergency.swf > > ________________________________________________________________________________
Date: Dec 27, 2005
Subject: ZOCHE diesel
Not to burst any bubbles but my first awareness of the zoche diesel goes back to 1993. There web site is as vague on production now as it was 12 years ago. Great theory--wheres the beef? dan ________________________________________________________________________________
Subject: Weight & balance - tail flasher
Date: Dec 27, 2005
Gentlemen, I am about to do a weight and balance on my bird, any comments? I also have determined that the "Aero Signal" flashing unit for my rudder/tail red light is unserviceable. Rather than replace it I should take this opportunity to put in a strobe, any comments or STC's for this application? Tom F. C-GISS 680 FLP (Mr.RPM) ----- Original Message ----- From: <BillLeff1(at)aol.com> Subject: Commander-List: Recurrent training > > This is typical CRM training. > > From: "Greg Vail" <greg(at)bloomingtonavionics.com> > To: > Subject: FW: I've been flying > Date: Fri, 23 Dec 2005 11:01:04 -0600 > > > Just want you to know I've been flying a lot > > http://worteldrie.com/flash/emergency.swf > > > > > > > Just want you to know > I've been flying a lot > > http://worteldrie.com/flash/emergency.swf > > ________________________________________________________________________________
Date: Dec 28, 2005
Subject: Re: Weight & balance - tail flasher
Add weight, as necessaryto the tail bulkhead, the to move the CG to the rear limit with one pilot on board and minimum fuel. Also, check with various fuel loads to verify that you do not ever go out of the aft limit. This will significantly improve the handling, and improve performance by reducing trim drag. Bill Leff ________________________________________________________________________________
Date: Dec 28, 2005
Subject: Re: Recurrent training
Yes, that is me flying it. The Orenda program is dead. That is too bad because it was a great engine. The aircraft and engine performed well. It was fast! Working with Dick MacCoon developing the installation was a real learning experience. What a learning opportunity! Bill Leff ________________________________________________________________________________
Date: Dec 28, 2005
Hi Tom, I'm pretty hot to get one of the new Whelen LED beacons; they're a bit pricey (about $600 US I think) but they'll last the lifetime of the airplane, and their visibility and flash pattern is awesome.... As far as a W&B, I can't help you with that one. I'm just a lowly B-model pilot ;-). Cheers, /John ----- Original Message ----- From: "Tom Fisher" <tfisher(at)commandergroup.bc.ca> Subject: Commander-List: Weight & balance - tail flasher > > Gentlemen, > > I am about to do a weight and balance on my bird, any comments? > I also have determined that the "Aero Signal" flashing unit for my > rudder/tail red light is unserviceable. Rather than replace it I should > take this opportunity to put in a strobe, any comments or STC's for this > application? > > Tom F. > C-GISS 680 FLP (Mr.RPM) > > ----- Original Message ----- > From: <BillLeff1(at)aol.com> > To: > Subject: Commander-List: Recurrent training > > > > > > This is typical CRM training. > > > > From: "Greg Vail" <greg(at)bloomingtonavionics.com> > > To: > > Subject: FW: I've been flying > > Date: Fri, 23 Dec 2005 11:01:04 -0600 > > > > > > Just want you to know I've been flying a lot > > > > http://worteldrie.com/flash/emergency.swf > > > > > > > > > > > > > > Just want you to know > > I've been flying a lot > > > > http://worteldrie.com/flash/emergency.swf > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Dec 28, 2005
Are there different parameters in the Fwd & Aft limits on the Mr.RPM conversion or did they remain the same as factory? Tom F. ----- Original Message ----- From: <BillLeff1(at)aol.com> Subject: Re: Commander-List: Weight & balance - tail flasher > > Add weight, as necessaryto the tail bulkhead, the to move the CG to the rear > limit with one pilot on board and minimum fuel. Also, check with various > fuel loads to verify that you do not ever go out of the aft limit. > > This will significantly improve the handling, and improve performance by > reducing trim drag. > > Bill Leff > > ________________________________________________________________________________
Date: Dec 28, 2005
Limits are the same. However the Mr RPM airplanes typically have a CG that is further forward because the engines sit further forward. The factory autorizes weight on the tail cone bulkhead and installed it on many aircraft right at the factory. Attached is a typical factory installation. File 291 is a 690B and file 297 is a 500A with a shrike nose. Bill Leff ________________________________________________________________________________
Date: Dec 28, 2005
Thanks Bill, a great help. Tom F. ----- Original Message ----- From: <BillLeff1(at)aol.com> Subject: Re: Commander-List: Weight & balance - tail flasher > > Limits are the same. However the Mr RPM airplanes typically have a CG that > is further forward because the engines sit further forward. The factory > autorizes weight on the tail cone bulkhead and installed it on many aircraft right > at the factory. Attached is a typical factory installation. File 291 is a > 690B and file 297 is a 500A with a shrike nose. > > Bill Leff > > ________________________________________________________________________________
Date: Dec 29, 2005
Subject: [Fwd: URLS for commander chat list]
-------- Original Message -------- Subject: URLS for commander chat list Date: Thu, 29 Dec 2005 09:22:45 -0600 From: N395V <N395V(at)direcway.com> Chris would you mind posting these URLs to the commander chat list. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1,1&item=4600376179&sspagename=STRK%3AMESE%3AIT <http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1,1&item=4600376179&sspagename=STRK%3AMESE%3AIT> http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1,1&item=4600372701&sspagename=STRK%3AMESE%3AIT <http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1,1&item=4600372701&sspagename=STRK%3AMESE%3AIT> They are for 685 manuals and fuel caps. Thanks, Milt ________________________________________________________________________________
Subject: FLAPS
Date: Dec 29, 2005
Hi Folks: As I understand it, the beginning of the white arc on the air speed indicator is the point where maximum flaps can be deployed. Does anyone have reliable information (or a chart) as to what speed partial flaps can be let down on a 680F(p)? It seems that ATC keeps holding me higher and higher until later, and getting down with geared engines can be most challenging. Regards, Moe Mills N680RR 680F(p) ________________________________________________________________________________
Subject: Re: FLAPS
Date: Dec 29, 2005
Hi Moe, From figures I've 'picked up' along the way, the maximum flaps extended speeds on a 680F(P) are as follows: Half extended, 130 knots; 150mph; 241 km/hr Fully extended, 118 knots; 136mph; 219 km/hr For reference, the Landing Gear extended speeds (Vle) are 156 knots; 180mph; 290 km/hr All these are True Indicated speeds. Very Best Regards, Barry ----- Original Message ----- From: "Moe" <moe(at)rosspistons.com> Subject: Commander-List: FLAPS | | Hi Folks: | | As I understand it, the beginning of the white arc on the air speed indicator is the point where maximum flaps can be deployed. Does anyone have reliable information (or a chart) as to what speed partial flaps can be let down on a 680F(p)? | | It seems that ATC keeps holding me higher and higher until later, and getting down with geared engines can be most challenging. | | Regards, | | Moe Mills | N680RR | 680F(p) | | | | | | | | | | | | | | ________________________________________________________________________________
Subject: Re: FLAPS
Date: Dec 29, 2005
hi Moe, I was taught both by John Meredith & Morris that 1/2 flaps can be let down at 130kias. IIRC, the beginning of the white arc is at 120kias. When things are congested here in the bay area and they try to jam me into a full pattern, I often use 1/2 flaps at 130kias. /John ----- Original Message ----- From: "Moe" <moe(at)rosspistons.com> Subject: Commander-List: FLAPS > > Hi Folks: > > As I understand it, the beginning of the white arc on the air speed indicator is the point where maximum flaps can be deployed. Does anyone have reliable information (or a chart) as to what speed partial flaps can be let down on a 680F(p)? > > It seems that ATC keeps holding me higher and higher until later, and getting down with geared engines can be most challenging. > > Regards, > > Moe Mills > N680RR > 680F(p) > > ________________________________________________________________________________
Subject: Re: FLAPS
Date: Dec 29, 2005
The operating manual confirms 130K for half flaps. Phil > [Original Message] > From: John Vormbaum <john(at)vormbaum.com> > To: > Date: 12/29/2005 12:41:18 PM > Subject: Re: Commander-List: FLAPS > > > hi Moe, > > I was taught both by John Meredith & Morris that 1/2 flaps can be let down > at 130kias. IIRC, the beginning of the white arc is at 120kias. When things > are congested here in the bay area and they try to jam me into a full > pattern, I often use 1/2 flaps at 130kias. > > /John > ----- Original Message ----- > From: "Moe" <moe(at)rosspistons.com> > To: > Subject: Commander-List: FLAPS > > > > > > Hi Folks: > > > > As I understand it, the beginning of the white arc on the air speed > indicator is the point where maximum flaps can be deployed. Does anyone > have reliable information (or a chart) as to what speed partial flaps can be > let down on a 680F(p)? > > > > It seems that ATC keeps holding me higher and higher until later, and > getting down with geared engines can be most challenging. > > > > Regards, > > > > Moe Mills > > N680RR > > 680F(p) > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Subject: Re: FLAPS
Date: Dec 29, 2005
MM, ACCORDING TO MY CLOUD CRAFT MANUAL, MAX SPEED FOR 1/2 FLAPS IS 150 MPH/130 KTS. AND FULL FLAPS 146 MPH/129 KTS. MASON ----- Original Message ----- From: Moe<mailto:moe(at)rosspistons.com> To: commander-list(at)matronics.com Sent: Thursday, December 29, 2005 10:52 AM Subject: Commander-List: FLAPS Hi Folks: As I understand it, the beginning of the white arc on the air speed indicator is the point where maximum flaps can be deployed. Does anyone have reliable information (or a chart) as to what speed partial flaps can be let down on a 680F(p)? It seems that ATC keeps holding me higher and higher until later, and getting down with geared engines can be most challenging. Regards, Moe Mills N680RR 680F(p) ________________________________________________________________________________
Subject: Re: FLAPS
Date: Dec 29, 2005
Mason, What is a Cloud Craft Manual? MM ----- Original Message ----- From: "MASON CHEVAILLIER" <KAMALA(at)msn.com> Subject: Re: Commander-List: FLAPS > > MM, ACCORDING TO MY CLOUD CRAFT MANUAL, MAX SPEED FOR 1/2 FLAPS IS 150 MPH/130 KTS. AND FULL FLAPS 146 MPH/129 KTS. MASON > ----- Original Message ----- > From: Moe<mailto:moe(at)rosspistons.com> > To: commander-list(at)matronics.com > Sent: Thursday, December 29, 2005 10:52 AM > Subject: Commander-List: FLAPS > > > > > Hi Folks: > > As I understand it, the beginning of the white arc on the air speed indicator is the point where maximum flaps can be deployed. Does anyone have reliable information (or a chart) as to what speed partial flaps can be let down on a 680F(p)? > > It seems that ATC keeps holding me higher and higher until later, and getting down with geared engines can be most challenging. > > Regards, > > Moe Mills > N680RR > 680F(p) > > ________________________________________________________________________________
Subject: Re: FLAPS
Date: Dec 29, 2005
The Cloud Craft Manual is an excellent document! Tom F. ----- Original Message ----- From: "Moe" <moe(at)rosspistons.com> Subject: Re: Commander-List: FLAPS > > Mason, > > What is a Cloud Craft Manual? > > MM > ----- Original Message ----- > From: "MASON CHEVAILLIER" <KAMALA(at)msn.com> > To: > Subject: Re: Commander-List: FLAPS > > > > > > MM, ACCORDING TO MY CLOUD CRAFT MANUAL, MAX SPEED FOR 1/2 FLAPS IS 150 > MPH/130 KTS. AND FULL FLAPS 146 MPH/129 KTS. MASON > > ----- Original Message ----- > > From: Moe<mailto:moe(at)rosspistons.com> > > To: commander-list(at)matronics.com > > Sent: Thursday, December 29, 2005 10:52 AM > > Subject: Commander-List: FLAPS > > > > > > > > > > Hi Folks: > > > > As I understand it, the beginning of the white arc on the air speed > indicator is the point where maximum flaps can be deployed. Does anyone > have reliable information (or a chart) as to what speed partial flaps can be > let down on a 680F(p)? > > > > It seems that ATC keeps holding me higher and higher until later, and > getting down with geared engines can be most challenging. > > > > Regards, > > > > Moe Mills > > N680RR > > 680F(p) > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Dec 30, 2005
Subject: Re: FLAPS
The following is from the Type certification Data Sheet for the 680F Maneuvering 157 m.p.h. (137 K) True Ind. Max. Struc. cruising 230 m.p.h. (200 K) True Ind. Never exceed 288 m.p.h. (250 K) True Ind. Flaps extended - half 150 m.p.h. (130 K) True Ind. Flaps extended - full 136 m.p.h. (118 K) True Ind. Landing gear extended 180 m.p.h. (156 K) True Ind. These are the only limitations that apply to your model. Before you ask what True Indicated Airspeed is; it is the same as Calibrated Airspeed. The full flap 129 kt limitation is for the early Turbo Commanders (680T thru 681) Wait, you have a 680FP. There is no such model. How could that be? Well, it goes like this: Unlike Cessna, Piper and Beechcraft who had to build a special models to pressurize their poorly built aircraft. Ted Smith built the Aero Commander so strong that pressurization was an option!!. See note 5 from the Type Certification Data Sheet. It is installed per an engineering drawing and a Service Information Letter! NOTE 5: An optional pressurized version of the Model 680-F designated "680-F (Pressurized)" was approved June 29, 1962. This model is a standard 680-F incorporating a factory modification per Aero Commander Dwg. 610021. Note the special required equipment list and the special equipment column for this modified 680-F in Revision No. 24 or Service Information SI-118. Cool isn't it. Next time you want to brag about your Aero Commander to the unwashed masses who own Cessnas, Pipers, and Beechcraft tell them about this. Let them top that! By the way the 500A, 500B, 560F and the 680F are all the same airframe. So, any of them could have been pressurized: structurally, that is. I believe if you look at your Data Plate on the tail , it says 680F not 680FP. Happy New Year! Bill Leff ________________________________________________________________________________
Subject: Re: FLAPS
Date: Dec 30, 2005
Bravo!!! That's the kind of info I think we all want to hear. Keep it coming Bill. -----Original Message----- From: BillLeff1(at)aol.com Date: Fri, 30 Dec 2005 00:17:41 To:commander-list(at)matronics.com Subject: Re: Commander-List: FLAPS The following is from the Type certification Data Sheet for the 680F Maneuvering 157 m.p.h. (137 K) True Ind. Max. Struc. cruising 230 m.p.h. (200 K) True Ind. Never exceed 288 m.p.h. (250 K) True Ind. Flaps extended - half 150 m.p.h. (130 K) True Ind. Flaps extended - full 136 m.p.h. (118 K) True Ind. Landing gear extended 180 m.p.h. (156 K) True Ind. These are the only limitations that apply to your model. Before you ask what True Indicated Airspeed is; it is the same as Calibrated Airspeed. The full flap 129 kt limitation is for the early Turbo Commanders (680T thru 681) Wait, you have a 680FP. There is no such model. How could that be? Well, it goes like this: Unlike Cessna, Piper and Beechcraft who had to build a special models to pressurize their poorly built aircraft. Ted Smith built the Aero Commander so strong that pressurization was an option!!. See note 5 from the Type Certification Data Sheet. It is installed per an engineering drawing and a Service Information Letter! NOTE 5: An optional pressurized version of the Model 680-F designated "680-F (Pressurized)" was approved June 29, 1962. This model is a standard 680-F incorporating a factory modification per Aero Commander Dwg. 610021. Note the special required equipment list and the special equipment column for this modified 680-F in Revision No. 24 or Service Information SI-118. Cool isn't it. Next time you want to brag about your Aero Commander to the unwashed masses who own Cessnas, Pipers, and Beechcraft tell them about this. Let them top that! By the way the 500A, 500B, 560F and the 680F are all the same airframe. So, any of them could have been pressurized: structurally, that is. I believe if you look at your Data Plate on the tail , it says 680F not 680FP. Happy New Year! Bill Leff bertberry1(at)aol.com ________________________________________________________________________________
Subject: Re: FLAPS
Date: Dec 30, 2005
Bill, Can you tell me the difference between a 690B and the 690B II? -----Original Message----- From: BillLeff1(at)aol.com Date: Fri, 30 Dec 2005 00:17:41 To:commander-list(at)matronics.com Subject: Re: Commander-List: FLAPS The following is from the Type certification Data Sheet for the 680F Maneuvering 157 m.p.h. (137 K) True Ind. Max. Struc. cruising 230 m.p.h. (200 K) True Ind. Never exceed 288 m.p.h. (250 K) True Ind. Flaps extended - half 150 m.p.h. (130 K) True Ind. Flaps extended - full 136 m.p.h. (118 K) True Ind. Landing gear extended 180 m.p.h. (156 K) True Ind. These are the only limitations that apply to your model. Before you ask what True Indicated Airspeed is; it is the same as Calibrated Airspeed. The full flap 129 kt limitation is for the early Turbo Commanders (680T thru 681) Wait, you have a 680FP. There is no such model. How could that be? Well, it goes like this: Unlike Cessna, Piper and Beechcraft who had to build a special models to pressurize their poorly built aircraft. Ted Smith built the Aero Commander so strong that pressurization was an option!!. See note 5 from the Type Certification Data Sheet. It is installed per an engineering drawing and a Service Information Letter! NOTE 5: An optional pressurized version of the Model 680-F designated "680-F (Pressurized)" was approved June 29, 1962. This model is a standard 680-F incorporating a factory modification per Aero Commander Dwg. 610021. Note the special required equipment list and the special equipment column for this modified 680-F in Revision No. 24 or Service Information SI-118. Cool isn't it. Next time you want to brag about your Aero Commander to the unwashed masses who own Cessnas, Pipers, and Beechcraft tell them about this. Let them top that! By the way the 500A, 500B, 560F and the 680F are all the same airframe. So, any of them could have been pressurized: structurally, that is. I believe if you look at your Data Plate on the tail , it says 680F not 680FP. Happy New Year! Bill Leff bertberry1(at)aol.com ________________________________________________________________________________
Subject: Commander decent
Date: Dec 30, 2005
Gents, Thanks for all of the comments on flap extension. Does anyone have comments on slipping the plane, on final approach, with gear extended and full flaps below 150 mph? When making a straight in approach to HHR, in VFR conditions, we must remain at 1,400 (above threshold height) until 2.8 knots from the threshold. In the past, I have been using rather severe "S" turns, or slipping, or asking the tower for a left 360 turn in order to get down at a manageable speed. The "S" turns seem to scare people on the Lowe's parking lot, and the left 360 disrupts the orderly flow of traffic in the pattern. Further comment will be greatly appreciated. Happy New Year Everyone! Moe Mills N680RR 680F(p) ________________________________________________________________________________
Date: Dec 30, 2005
Subject: Re: Commander decent
In a message dated 12/30/2005 9:33:50 A.M. Central Standard Time, moe(at)rosspistons.com writes: When making a straight in approach to HHR, in VFR conditions, we must remain at 1,400 (above threshold height) until 2.8 knots from the threshold. In the past, I have been using rather severe "S" turns, or slipping, or asking the tower for a left 360 turn in order to get down at a manageable speed. The "S" turns seem to scare people on the Lowe's parking lot, and the left 360 disrupts the orderly flow of traffic in the pattern Good Morning Moe, First question, if I may, where is HHR? As I see your problem, you need to descend at around 500 feet per nautical mile or 434 ft per statute mile. While it has been a very long time since I last flew any Twin Commander, I would think that a power off descent rate with full flap and gear down would result in well over 500 feet per nautical mile. Most competitive twins will descend around 600 to 650 feet per nautical mile traveled in landing configuration. Any head wind at all would help. While I would imagine a simple slip would work very well, wouldn't a low power slow speed descent also work? What is your desired minimum approach speed? Do you use knots or statute? Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator Stearman N3977A Brookeridge Air Park LL22 Downers Grove, IL 60516 630 985-8503 ________________________________________________________________________________
Subject: Re: FLAPS
Date: Dec 30, 2005
Bill, The initial problem is convincing the unwashed masses that the airplane is pressurized. Trying to keep these unwashed types out of the inside of the plane, I tried showing them the blower and equipment in the rear fuselage, only to be told that it was merely a fan to blow through the air conditioner. After allowing them to come inside and view the pressurization control, some seem to still be a unconvinced. The FAA registry in some instances does not mention the (p) in the model information as it was optional equipment, and in some instances it does. ???? Personally, I wish that the designation was 680FP instead of 680F(p), due to the fact that when typing I can't use the top key board keys without looking at my hands. This problem is further exacerbated because one must hold down the shift key with the left pinky while hitting the '(' AND the ')' keys. Wing Commander Gordon in right....life is not simple anywhere. Regards, Moe N680RR 680F(p) ----- Original Message ----- From: <BillLeff1(at)aol.com> Subject: Re: Commander-List: FLAPS > > The following is from the Type certification Data Sheet for the 680F > > Maneuvering 157 m.p.h. (137 K) True Ind. > Max. Struc. cruising 230 m.p.h. (200 K) True Ind. > Never exceed 288 m.p.h. (250 K) True Ind. > Flaps extended - half 150 m.p.h. (130 K) True Ind. > Flaps extended - full 136 m.p.h. (118 K) True Ind. > Landing gear extended 180 m.p.h. (156 K) True Ind. > > These are the only limitations that apply to your model. > > Before you ask what True Indicated Airspeed is; it is the same as Calibrated > Airspeed. > > The full flap 129 kt limitation is for the early Turbo Commanders (680T thru > 681) > > Wait, you have a 680FP. There is no such model. How could that be? > > Well, it goes like this: Unlike Cessna, Piper and Beechcraft who had to > build a special models to pressurize their poorly built aircraft. Ted Smith built > the Aero Commander so strong that pressurization was an option!!. See note 5 > from the Type Certification Data Sheet. It is installed per an engineering > drawing and a Service Information Letter! > > NOTE 5: > > An optional pressurized version of the Model 680-F > designated "680-F (Pressurized)" was approved June 29, 1962. > This model is a standard 680-F incorporating a factory > modification per Aero Commander Dwg. 610021. Note the > special required equipment list and the special equipment > column for this modified 680-F in Revision No. 24 or Service > Information SI-118. > > Cool isn't it. Next time you want to brag about your Aero Commander to the > unwashed masses who own Cessnas, Pipers, and Beechcraft tell them about this. > Let them top that! > > By the way the 500A, 500B, 560F and the 680F are all the same airframe. So, > any of them could have been pressurized: structurally, that is. > > I believe if you look at your Data Plate on the tail , it says 680F not > 680FP. > > Happy New Year! > > Bill Leff > > ________________________________________________________________________________
Date: Dec 30, 2005
When I am doing nap of the Earth flying and have to descend rapidly (non-geared engine) into the next valley I drop my gear and flaps to obtain a descent rate of 3,000 ft/min @ 120MPH. The aircraft appears to be quite unstable in the yaw axis, given that, I would not side slip with full flaps. When I approach the airport I intend to land at I TELL the controllers what speed and maximum descent rate I am able to maintain and that I will need a back track once landed to clear the runway. That way they have time to space other traffic ahead and behind me to accommodate me. Too many times I have had an aircraft launched right in front of me supposedly on an immediate take-off requiring me to over shoot. My local field is now trained to give me room, they advise other traffic about the "fast moving Commander" (110 MPH) on approach. Your geared machine deserves respect from the controllers and perhaps they can handle you more appropriately if they had a heads up of your requirements. Tom F. C-GISS 680FLP (Mr.RPM) ----- Original Message ----- From: "Moe" <moe(at)rosspistons.com> Subject: Commander-List: Commander decent > > Gents, > > Thanks for all of the comments on flap extension. > > Does anyone have comments on slipping the plane, on final approach, with gear extended and full flaps below 150 mph? > > When making a straight in approach to HHR, in VFR conditions, we must remain at 1,400 (above threshold height) until 2.8 knots from the threshold. In the past, I have been using rather severe "S" turns, or slipping, or asking the tower for a left 360 turn in order to get down at a manageable speed. The "S" turns seem to scare people on the Lowe's parking lot, and the left 360 disrupts the orderly flow of traffic in the pattern. > > Further comment will be greatly appreciated. > > Happy New Year Everyone! > > Moe Mills > N680RR > 680F(p) > > ________________________________________________________________________________
Date: Dec 30, 2005
In a message dated 30-Dec-05 07:55:45 Pacific Standard Time, BobsV35B(at)aol.com writes: I would think that a power off descent rate with full flap and gear down would result in well over 500 feet per nautical mile. Most competitive twins will descend around 600 to 650 feet per nautical mile traveled in landing configuration. >> >> You're correct, Old Bob, but Moe has a Commander powered by Lycoming IGSO-540 and power off descents are too expensive to do. He has the classic problem that pilots based in complex airspace (or steep valleys) face. Tom Fisher said no to slips. I've slipped the short body Commanders with half flaps and gear down and do not remember any bad handling characteristics. Sounds like a good excuse to go fly. Set a "hard deck" altitude, set up in approach configuration (or just half flaps) and try it out. Be sure to report back. I'm looking at the LOC RWY 25 approach and see that you can cross DEMON at 660', 2.7 nm from the threshold. I take it your 1400' restriction is some other limitation? Do the local controllers make you adhere to that if you're on the IFR approach in VFR conditions? If not, I'd execute the LOC approach all the time. I can see that LAX controllers may not like the parallels with their airport; the GPS RWY 25 looks like a more ATC happy solution, plus your GPS may give you pseudo glideslope. Any of that a possibility? Wing Commander Gordon PS: Bill Leff! Great to see you active on the email net! Life is not simple anywhere. Probably less so elsewhere. ________________________________________________________________________________
Date: Dec 30, 2005
From: Brock Lorber <blorber(at)southwestcirrus.com>
Moe wrote: > >Gents, > >Thanks for all of the comments on flap extension. > >Does anyone have comments on slipping the plane, on final approach, with gear extended and full flaps below 150 mph? > >When making a straight in approach to HHR, in VFR conditions, we must remain at 1,400 (above threshold height) until 2.8 knots from the threshold. In the past, I have been using rather severe "S" turns, or slipping, or asking the tower for a left 360 turn in order to get down at a manageable speed. The "S" turns seem to scare people on the Lowe's parking lot, and the left 360 disrupts the orderly flow of traffic in the pattern. > >Further comment will be greatly appreciated. > >Happy New Year Everyone! > >Moe Mills >N680RR >680F(p) > > > Moe: I treat every engine the same (geared, direct-drive, normally-aspirated, turbo'd, ad nauseum). I have two inviolate rules: no more that 2" MAP change at a time, and the engines produce power any time I'm not using the brakes. These rules force me to be at least 60 nm ahead of the airplane or I'd be doing a lot of go-arounds. Therefore, I usually surprise Towers who aren't familiar with the N-number by approaching the field at an airspeed they associate with a single-engine commander, anticipating the slam-dunk on to the runway. On speed at the perch (100-120 KIAS) and with approach power setting, I've found the 680FL(P) sticks the touchdown markers from 1,500' and 3 nm every time with full flaps. I use HHR to practice landings with students in the Cirrus SR-22. The turn to final from the freeway requires them to be on-speed (119 KIAS in that airplane) and still may require a slip. But, more than anything, the parking garage and the raised surface of the 105 messes with their heads. So, even if they make a perfect approach from the freeway, or even slightly high of a 3 degree glide slope, they feel like they are too low and pull way above the glide slope. They play catch-up the rest of the way to the runway, and more often than not, end up going around and trying it from a standard pattern. I've never had the commander in to HHR, but if I did I'd approach it the same way as in the Cirrus. Straight-in: stay slow over the freeway, drop the flaps, and lower the nose to Vfe to burn the altitude. Parallel to the freeway: drop the flaps and burn as much energy as I comfortably (for the passengers) can in the turn to final. Individual results may vary! Brock http://www.southwestcirrus.com/n400ch ________________________________________________________________________________
Date: Dec 30, 2005
HI MOE. I keep my commander on a 2400 strip with real 50 foot obstructions on both ends. I routinely slip the airplane. It slips fairly well. I have only slipped it with full flaps. No adverse handling characteristics, it recovers naturally, all by itself. There is no tendency to drop the nose, nor does it pitch up (like some floatplanes). I have slipped to an airspeed as low as 60KIAS, although I think the pitot tube gets blocked a bit in the slip so the speed may have been a little higher. The only caution is that once slowed, the Commander takes a bit of encouragement to re accelerate so plan for that. Have fun jb ________________________________________________________________________________
Date: Dec 30, 2005
JB, Thanks for the tip. I have been slipping pretty heavy at 100 MPH with full flaps. N680RR has dual air speed indicators, with a pitot tube on each side. Will try to check them against each other on next slipping approach to see if there is any difference in the upstream and downstream sides. Moe ----- Original Message ----- From: <YOURTCFG(at)aol.com> Subject: Re: Commander-List: Commander decent > > HI MOE. > > I keep my commander on a 2400 strip with real 50 foot obstructions on > both ends. I routinely slip the airplane. It slips fairly well. I have only > slipped it with full flaps. No adverse handling characteristics, it recovers > naturally, all by itself. There is no tendency to drop the nose, nor does > it pitch up (like some floatplanes). > I have slipped to an airspeed as low as 60KIAS, although I think the > pitot tube gets blocked a bit in the slip so the speed may have been a little > higher. The only caution is that once slowed, the Commander takes a bit of > encouragement to re accelerate so plan for that. Have fun jb > > ________________________________________________________________________________
Date: Dec 30, 2005
What's the vertical speed requirement that would cause one to slip, or is it to avoid throttling back on the engines? Nico ----- Original Message ----- From: "Moe" <moe(at)rosspistons.com> Subject: Re: Commander-List: Commander decent > > JB, > > Thanks for the tip. I have been slipping pretty heavy at 100 MPH with full > flaps. N680RR has dual air speed indicators, with a pitot tube on each > side. Will try to check them against each other on next slipping approach > to see if there is any difference in the upstream and downstream sides. > > Moe > ----- Original Message ----- > From: <YOURTCFG(at)aol.com> > To: > Subject: Re: Commander-List: Commander decent > > > > > > HI MOE. > > > > I keep my commander on a 2400 strip with real 50 foot obstructions on > > both ends. I routinely slip the airplane. It slips fairly well. I have > only > > slipped it with full flaps. No adverse handling characteristics, it > recovers > > naturally, all by itself. There is no tendency to drop the nose, nor > does > > it pitch up (like some floatplanes). > > I have slipped to an airspeed as low as 60KIAS, although I think the > > pitot tube gets blocked a bit in the slip so the speed may have been a > little > > higher. The only caution is that once slowed, the Commander takes a bit > of > > encouragement to re accelerate so plan for that. Have fun jb > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Dec 30, 2005
Wing Commander Gordon: Thank you very much for the reply. As always, your good advice and wise council is muchly appreciated. As mentioned in my reply to JB I have been slipping the plane at about 100 mph with gear down and full flaps. Although aggressive rudder action is required, the aircraft handles well, and the sink rate increases quite rapidly by slipping. Running north and south almost directly over DEMON along the 110 Freeway is a Los Angeles helicopter routing, thus, when flying into HHR VFR there is the altitude restriction of 1,500 (approx 1,440 above the runway). When the LOC RWY 25 approach is used, the choppers are held until the aircraft shooting the approach is clear. On clear days it is much easier to go into HHR VFR than to go in IFR. To get a "pop up" approach you need to go down to SLI (Seal Beach VOR). Also, in many instances the LA APPROACH controllers frequency is so busy that it can take several minutes just to get him to answer you back. Other than when coming from the south east (San Diego) on an IFR flight, going into HHR by shooting an IFR approach is most definitely NOT a time saver. The guys in the HHR tower and LA APPROACH are really a great group, who have been very nice to me over the years, so I try to accommodate them as much as is practical. Regards, Moe ----- Original Message ----- From: <CloudCraft(at)aol.com> Subject: Re: Commander-List: Commander decent > > In a message dated 30-Dec-05 07:55:45 Pacific Standard Time, BobsV35B(at)aol.com > writes: > I would think that a power off descent rate with > full flap and gear down would result in well over 500 feet per nautical mile. > Most competitive twins will descend around 600 to 650 feet per nautical mile > traveled in landing configuration. > >> > >> > > You're correct, Old Bob, but Moe has a Commander powered by Lycoming > IGSO-540 and power off descents are too expensive to do. > > He has the classic problem that pilots based in complex airspace (or steep > valleys) face. > > Tom Fisher said no to slips. I've slipped the short body Commanders with > half flaps and gear down and do not remember any bad handling characteristics. > > Sounds like a good excuse to go fly. Set a "hard deck" altitude, set up in > approach configuration (or just half flaps) and try it out. Be sure to report > back. > > I'm looking at the LOC RWY 25 approach and see that you can cross DEMON at > 660', 2.7 nm from the threshold. I take it your 1400' restriction is some > other limitation? Do the local controllers make you adhere to that if you're on > the IFR approach in VFR conditions? > > If not, I'd execute the LOC approach all the time. I can see that LAX > controllers may not like the parallels with their airport; the GPS RWY 25 looks like > a more ATC happy solution, plus your GPS may give you pseudo glideslope. > > Any of that a possibility? > > Wing Commander Gordon > > PS: Bill Leff! Great to see you active on the email net! > > Life is not simple anywhere. Probably less so elsewhere. > > ________________________________________________________________________________
Date: Dec 30, 2005
With a light load on a cool day I find slipping the easiest way to get the thing down without unloading the box. There seem to be fewer ATC guys who know anything about piston and non-pressurized capabilities. (Worked great in the cub so I figured why not.) Phil > [Original Message] > From: Moe <moe(at)rosspistons.com> > To: > Date: 12/30/2005 10:32:20 AM > Subject: Commander-List: Commander decent > > > Gents, > > Thanks for all of the comments on flap extension. > > Does anyone have comments on slipping the plane, on final approach, with gear extended and full flaps below 150 mph? > > When making a straight in approach to HHR, in VFR conditions, we must remain at 1,400 (above threshold height) until 2.8 knots from the threshold. In the past, I have been using rather severe "S" turns, or slipping, or asking the tower for a left 360 turn in order to get down at a manageable speed. The "S" turns seem to scare people on the Lowe's parking lot, and the left 360 disrupts the orderly flow of traffic in the pattern. > > Further comment will be greatly appreciated. > > Happy New Year Everyone! > > Moe Mills > N680RR > 680F(p) > > > > > > ________________________________________________________________________________
Date: Dec 30, 2005
Nico, The situation with geared engines is that the engines can never be used to slow the airplane down. The prop should always be driven by the crankshaft. Also, on the ground the engines should never be run below about 1,200 RPM (1,500 is better) with the Simmonds fuel pumps. At lower RPM the engines will surge which loads and unloads the sun gear against the planetary gears. I won't go into the part about the 5/16" bolts that hold the gear drive to the drive plate. Regards, Moe ----- Original Message ----- From: "css nico" <nico(at)cybersuperstore.com> Subject: Re: Commander-List: Commander decent > > What's the vertical speed requirement that would cause one to slip, or is it > to avoid throttling back on the engines? > Nico > > ----- Original Message ----- > From: "Moe" <moe(at)rosspistons.com> > To: > Subject: Re: Commander-List: Commander decent > > > > > > JB, > > > > Thanks for the tip. I have been slipping pretty heavy at 100 MPH with > full > > flaps. N680RR has dual air speed indicators, with a pitot tube on each > > side. Will try to check them against each other on next slipping approach > > to see if there is any difference in the upstream and downstream sides. > > > > Moe > > ----- Original Message ----- > > From: <YOURTCFG(at)aol.com> > > To: > > Subject: Re: Commander-List: Commander decent > > > > > > > > > > HI MOE. > > > > > > I keep my commander on a 2400 strip with real 50 foot obstructions > on > > > both ends. I routinely slip the airplane. It slips fairly well. I > have > > only > > > slipped it with full flaps. No adverse handling characteristics, it > > recovers > > > naturally, all by itself. There is no tendency to drop the nose, nor > > does > > > it pitch up (like some floatplanes). > > > I have slipped to an airspeed as low as 60KIAS, although I think > the > > > pitot tube gets blocked a bit in the slip so the speed may have been a > > little > > > higher. The only caution is that once slowed, the Commander takes a > bit > > of > > > encouragement to re accelerate so plan for that. Have fun jb > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Subject: Slips
Date: Dec 30, 2005
My two cents on slips. Be sure to keep the nose below the horizon when doing slips, if you get the nose up with the airspeed indicators being unreliable as they are and it does stall the shiny side will not be up for long. The Commander having a high wing should not give the problems that could come up with the low wing aircraft, such as the fuselage blocking the upper wing. Yes, I have slipped low wing planes too, probable as much as any one, but, there can be trouble. Jim A N444BD ________________________________________________________________________________
Date: Dec 30, 2005
Subject: Re: FLAPS
Thanks Bill for emailing me direct on the 500 and 500 A differences. Could the 500 airframe also be pressurized structurally? Just a question, in case someone asked. Roland BillLeff1(at)aol.com wrote: > >The following is from the Type certification Data Sheet for the 680F > > Maneuvering 157 m.p.h. (137 K) True Ind. >Max. Struc. cruising 230 m.p.h. (200 K) True Ind. >Never exceed 288 m.p.h. (250 K) True Ind. >Flaps extended - half 150 m.p.h. (130 K) True Ind. >Flaps extended - full 136 m.p.h. (118 K) True Ind. >Landing gear extended 180 m.p.h. (156 K) True Ind. > >These are the only limitations that apply to your model. > >Before you ask what True Indicated Airspeed is; it is the same as Calibrated >Airspeed. > >The full flap 129 kt limitation is for the early Turbo Commanders (680T thru >681) > >Wait, you have a 680FP. There is no such model. How could that be? > >Well, it goes like this: Unlike Cessna, Piper and Beechcraft who had to >build a special models to pressurize their poorly built aircraft. Ted Smith built >the Aero Commander so strong that pressurization was an option!!. See note 5 >from the Type Certification Data Sheet. It is installed per an engineering >drawing and a Service Information Letter! > >NOTE 5: > > An optional pressurized version of the Model 680-F >designated "680-F (Pressurized)" was approved June 29, 1962. >This model is a standard 680-F incorporating a factory >modification per Aero Commander Dwg. 610021. Note the >special required equipment list and the special equipment >column for this modified 680-F in Revision No. 24 or Service >Information SI-118. > >Cool isn't it. Next time you want to brag about your Aero Commander to the >unwashed masses who own Cessnas, Pipers, and Beechcraft tell them about this. >Let them top that! > >By the way the 500A, 500B, 560F and the 680F are all the same airframe. So, >any of them could have been pressurized: structurally, that is. > >I believe if you look at your Data Plate on the tail , it says 680F not >680FP. > >Happy New Year! > >Bill Leff > > > > > > > > > ________________________________________________________________________________
Subject: Re: Slips
Date: Dec 30, 2005
I cannot remember ever having had a need to slip my straight 500 (which I flew for about 1,000 hours - measly compared to what some of you guys have spent in the front office), but then again, one could hang full flaps and gear out, nose her over and fall out of the sky like a brick. The few hours I spent flying a 680 - now let me get this right - (P), I had ample time to keep positive thrust in regular descents, so no need there. It never dawned on me that a slip should or should not be attempted, which is why I value this group because there is always something new to learn somewhere. From a gut-feel stance, I would have been hesitant to attempt a slip for fear of the large wing putting the tail in turbulence or exposing the large tail to undue side-ways forces. Sudden high rudder inputs apparently caused structural failure in a large jet reported not too long ago. Do I recall that correctly? Apparently I would have been unduly cautious. What a machine! Nico ----- Original Message ----- From: "Jim Addington" <jtaddington(at)charter.net> Subject: Commander-List: Slips > > > My two cents on slips. > Be sure to keep the nose below the horizon when doing slips, if you get the > nose up with the airspeed indicators being unreliable as they are and it > does stall the shiny side will not be up for long. The Commander having a > high wing should not give the problems that could come up with the low wing > aircraft, such as the fuselage blocking the upper wing. Yes, I have slipped > low wing planes too, probable as much as any one, but, there can be trouble. > > Jim A > N444BD > > ________________________________________________________________________________
Subject: Slips
Date: Dec 30, 2005
". Sudden high rudder inputs apparently caused structural failure in a large jet reported not too long ago. Do I recall that correctly? Apparently I would have been unduly cautious. What a machine!" Nico, the rudders only break off on "Hugo" Jets(AirBus). I know pilots who slipped Stretch DC-8s. The tail didn't break off and the fuselage did not break or bend (not permanently). bilbo -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of css nico Subject: Re: Commander-List: Slips I cannot remember ever having had a need to slip my straight 500 (which I flew for about 1,000 hours - measly compared to what some of you guys have spent in the front office), but then again, one could hang full flaps and gear out, nose her over and fall out of the sky like a brick. The few hours I spent flying a 680 - now let me get this right - (P), I had ample time to keep positive thrust in regular descents, so no need there. It never dawned on me that a slip should or should not be attempted, which is why I value this group because there is always something new to learn somewhere. From a gut-feel stance, I would have been hesitant to attempt a slip for fear of the large wing putting the tail in turbulence or exposing the large tail to undue side-ways forces. Sudden high rudder inputs apparently caused structural failure in a large jet reported not too long ago. Do I recall that correctly? Apparently I would have been unduly cautious. What a machine! Nico ----- Original Message ----- From: "Jim Addington" <jtaddington(at)charter.net> Subject: Commander-List: Slips > > > My two cents on slips. > Be sure to keep the nose below the horizon when doing slips, if you get the > nose up with the airspeed indicators being unreliable as they are and it > does stall the shiny side will not be up for long. The Commander having a > high wing should not give the problems that could come up with the low wing > aircraft, such as the fuselage blocking the upper wing. Yes, I have slipped > low wing planes too, probable as much as any one, but, there can be trouble. > > Jim A > N444BD > > ________________________________________________________________________________
From: "Deneal Schilmeister (Portege)" <deneals(at)sbcglobal.net>
Subject: Slips
Date: Dec 30, 2005
Of course the Commanders' tails are not made of plasti...err "composites" ___________________________ Deneal Schilmeister St. Louis - Cincinnati 1997 SL500 http://homepage.mac.com/deneals/SL500.htm http://homepage.mac.com/deneals/Sites/My_Commanders.htm -----Original Message----- From: On Behalf Of Bill Bow Subject: RE: Commander-List: Slips ". Sudden high rudder inputs apparently caused structural failure in a large jet reported not too long ago. Do I recall that correctly? Apparently I would have been unduly cautious. What a machine!" Nico, the rudders only break off on "Hugo" Jets(AirBus). I know pilots who slipped Stretch DC-8s. The tail didn't break off and the fuselage did not break or bend (not permanently). bilbo ________________________________________________________________________________
Date: Dec 31, 2005
From: W J R HAMILTON <wjrhamilton(at)optusnet.com.au>
Subject: Slips
Folks, I doubt there is any problem structurally or aerodynamically slipping a Commander, after all models such as the 500A were originally in the Utility cat. - limited aerobatics. All the later Boeings I have flown had no prohibition on sideslips, in fact it came in very useful from time to time. Indeed, the 757/767/ 400(in part) all slip across the wind during an auto-coupled approach. Cheers, Bill Hamilton At 15:11 31/12/2005, you wrote: > >". Sudden high rudder inputs apparently caused structural failure in a large >jet reported not too long ago. Do I recall that correctly? Apparently I >would have been unduly cautious. What a machine!" > >Nico, the rudders only break off on "Hugo" Jets(AirBus). I know pilots who >slipped Stretch DC-8s. The tail didn't break off and the fuselage did not >break or bend (not permanently). > >bilbo > > >-----Original Message----- >From: owner-commander-list-server(at)matronics.com >[mailto:owner-commander-list-server(at)matronics.com] On Behalf Of css nico >To: commander-list(at)matronics.com >Subject: Re: Commander-List: Slips > > >I cannot remember ever having had a need to slip my straight 500 (which I >flew for about 1,000 hours - measly compared to what some of you guys have >spent in the front office), but then again, one could hang full flaps and >gear out, nose her over and fall out of the sky like a brick. The few hours >I spent flying a 680 - now let me get this right - (P), I had ample time to >keep positive thrust in regular descents, so no need there. > >It never dawned on me that a slip should or should not be attempted, which >is why I value this group because there is always something new to learn >somewhere. From a gut-feel stance, I would have been hesitant to attempt a >slip for fear of the large wing putting the tail in turbulence or exposing >the large tail to undue side-ways forces. Sudden high rudder inputs >apparently caused structural failure in a large jet reported not too long >ago. Do I recall that correctly? Apparently I would have been unduly >cautious. What a machine! > >Nico > > >----- Original Message ----- >From: "Jim Addington" <jtaddington(at)charter.net> >To: >Subject: Commander-List: Slips > > > > > > > > > My two cents on slips. > > Be sure to keep the nose below the horizon when doing slips, if you get >the > > nose up with the airspeed indicators being unreliable as they are and it > > does stall the shiny side will not be up for long. The Commander having a > > high wing should not give the problems that could come up with the low >wing > > aircraft, such as the fuselage blocking the upper wing. Yes, I have >slipped > > low wing planes too, probable as much as any one, but, there can be >trouble. > > > > Jim A > > N444BD > > > > > > > > > > > > > > > > > > > > > > > > CONFIDENTIALITY & PRIVILEGE NOTICE W.J.R.Hamilton,Glenalmond Group Companies,Fighter Flights Internet Services and Warbirds.Net. & . This message is intended for and should only be used by the addressee. It is confidential and may contain legally privileged information.If you are not the intended recipient any use distribution,disclosure or copying of this message is strictly prohibited.Confidentiality and legal privilege attached to this communication are not waived or lost by reason of the mistaken delivery to you.If you have received this message in error, please notify us immediately to Australia 61 (0)408 876 526 Dolores capitis non fero. Eos do. ________________________________________________________________________________
Date: Dec 31, 2005
Subject: SLIP/NO SLIP
You guys are making this approach far too difficult!! Just turn your transponder off for a couple of minutes as you approach the field at any altitude you like:-))) I would be willing to bet the field was there first. For those of you with no sense of humor IT'S A JOKE. ________________________________________________________________________________
Date: Dec 31, 2005
Subject: Re: SLIP/NO SLIP
In a message dated 12/31/2005 6:33:34 A.M. Pacific Standard Time, daniellfarmer(at)yahoo.com writes: I would be willing to bet the field was there first What about the trees at the end of my runway. Will turning off the TXP take them away?? That would really be handy at night!! Happy New Year Dan!! jb ________________________________________________________________________________
Date: Dec 31, 2005
In a message dated 30-Dec-05 13:48:12 Pacific Standard Time, moe(at)rosspistons.com writes: Running north and south almost directly over DEMON along the 110 Freeway is a Los Angeles helicopter routing, thus, when flying into HHR VFR there is the altitude restriction of 1,500 (approx 1,440 above the runway). When the LOC RWY 25 approach is used, the choppers are held until the aircraft shooting the approach is clear. On clear days it is much easier to go into HHR VFR than to go in IFR. To get a "pop up" approach you need to go down to SLI (Seal Beach VOR). Also, in many instances the LA APPROACH controllers frequency is so busy that it can take several minutes just to get him to answer you back. >> >> Gadzooks! Life isn't simple anywhere! I figured it had to be something along the lines of what you described above, otherwise you'd have found a better way, Moe. Wing Commander Gordon Life is not simple anywhere. Probably less so elsewhere. ________________________________________________________________________________
Date: Dec 31, 2005
Subject: Commercial Use?
Hi. I am new to this group but have been researching Commanders for quite a while. I am attempting a 135 start up and the 500 series provides the best balance of required field performance and passenger comfort. The problem is that prices are quite high, for obvious reasons. Occasionally, some geared models pop onto the market at attractive prices - now, I realize that the increase in OH expense will more than eat up that price difference. But the reduction in up-front costs might make it worthwhile. And so the question is: is it possible to safely demonstrate competency, say, in recurrent training or on a checkride for the Fed in a geared aircraft without trashing the gear box? And if so, how? Thanks in advance, and fire away. ________________________________________________________________________________
Date: Dec 31, 2005
Subject: Re: FLAPS
It could be pressurized if all the drawings and equipment were installed. Actually yours would be a 720. Bill Leff ________________________________________________________________________________
From: "Barry Collman" <barry.collman@air-britain.co.uk>
Subject: HAPPY NEW YEAR
Date: Jan 01, 2006
Hi All, Well, the magic moment has arrived and over here, we're now in 2006! So far, the year has gone very well. No nagging from "her indoors" and it's not snowing. HAPPY NEW YEAR everyone! Barry C (UK) ________________________________________________________________________________
Subject: Re: FLAPS
Date: Jan 01, 2006
If the pressurized 680F was a 680F(P), why wasn't the 720 a 680E(P) and the 680FLP a 680FL(P)? And, of course, the spelling should be pressurised ;-) Good fun, history, isn't it! Barry C. (UK) (Two posts already this year) ----- Original Message ----- From: <BillLeff1(at)aol.com> Subject: Re: Commander-List: FLAPS | | It could be pressurized if all the drawings and equipment were installed. | Actually yours would be a 720. | | Bill Leff | | | | | | | | | | | | | ________________________________________________________________________________
Date: Dec 31, 2005
Subject: Re: Commercial Use?
In a message dated 31-Dec-05 14:42:45 Pacific Standard Time, capt_seth(at)yahoo.com writes: And so the question is: is it possible to safely demonstrate competency, say, in recurrent training or on a checkride for the Fed in a geared aircraft without trashing the gear box? And if so, how? >> >> Seth, The economic debate of geared engine vs. direct drive in a commercial operation is something I'll leave between you and your profit/loss statement. As far as 135 check rides go in a geared engine driven aircraft, I've taken many (AC-680E, AC-680FL, BE-80, CE-411) and can tell you with 99% certainty that the FAA examiner is scared to death of engine cuts and even more scared of geared engines, in general. The POI will probably tell you to simulate feather thrust -- which you'll set up very slowly -- and fly what ever task you're supposed to demonstrate. It's totally unrealistic, as far as a training and check-ride scenario, but it's the best both of you can do. If/when you acquire a geared-Lycoming powered Commander, the collective wisdom on this email net can give you lots of suggestions on power settings to simulate feather thrust, depending on what model you end up with. Wing Commander Gordon Life is not simple anywhere. Probably less so elsewhere. ________________________________________________________________________________
Date: Dec 31, 2005
Subject: Slips
The most recent rudder failure I'm aware of was an AA A300 which experienced rapid and repeated (pilot induced)full rudder reversals after encountering the wake vortex of a B747 departing JFK. (Cleared for takeoff one minute and thirty seconds after the 747 rather than the normal two minute separation) It was a composite rudder which had been found to have a defect during manufacture and had been repaired on the line by Airbus.(a fact which they tried to conceal). -----Original Message----- >From: "Deneal Schilmeister (Portege)" <deneals(at)sbcglobal.net> >Sent: Dec 30, 2005 11:43 PM >To: commander-list(at)matronics.com >Subject: RE: Commander-List: Slips > > >Of course the Commanders' tails are not made of plasti...err "composites" > >___________________________ >Deneal Schilmeister >St. Louis - Cincinnati >1997 SL500 >http://homepage.mac.com/deneals/SL500.htm >http://homepage.mac.com/deneals/Sites/My_Commanders.htm > >-----Original Message----- >From: On Behalf Of Bill Bow >To: commander-list(at)matronics.com >Subject: RE: Commander-List: Slips > > >". Sudden high rudder inputs apparently caused structural failure in a large >jet reported not too long ago. Do I recall that correctly? Apparently I >would have been unduly cautious. What a machine!" > >Nico, the rudders only break off on "Hugo" Jets(AirBus). I know pilots who >slipped Stretch DC-8s. The tail didn't break off and the fuselage did not >break or bend (not permanently). > >bilbo > > > > > > > ________________________________________________________________________________
Subject: Re: Slips
Date: Dec 31, 2005
That explains it. It worried me that, even with sudden full rudder deflections, that the tail would come off. If they messed with the damn thing, it stands to reason that it would fail at some point. Many years ago as a small tyke, I once went up to the fence at an air force base, not more than perhaps 100 or so yards from the threshold of the runway on which C130's landed. After passing only a couple of hundred feet overhead, the air would make noises like the cracking of a whip, just much louder. It was the eeriest thing that I have ever experienced, messing with one's senses, not able to see anything but hearing these "snaps" - very loud - almost like gunfire as the disturbed air regroups. I have always been very aware of wake vortices because of that, watching crosswinds before takeoff to head upwind from possible vortices. Then I watch airliners take off one after the other straight ahead and I wonder. Especially at airports like John Wayne in Orange County, CA, where jets climb out very steeply before leveling off. Noise restrictions, perhaps? Surely steep take-offs like that would create larger than normal vortices? Even if there is a two-minute separation, if there isn't a cross-wind, the turbulent air would hang around, but every jet climbs into the same box time after time. Just some observations. Nico ----- Original Message ----- From: <br549phil(at)mindspring.com> Subject: RE: Commander-List: Slips > > The most recent rudder failure I'm aware of was an AA A300 which experienced rapid and repeated (pilot induced)full rudder reversals after encountering the wake vortex of a B747 departing JFK. (Cleared for takeoff one minute and thirty seconds after the 747 rather than the normal two minute separation) It was a composite rudder which had been found to have a defect during manufacture and had been repaired on the line by Airbus.(a fact which they tried to conceal). > > > -----Original Message----- > >From: "Deneal Schilmeister (Portege)" <deneals(at)sbcglobal.net> > >Sent: Dec 30, 2005 11:43 PM > >To: commander-list(at)matronics.com > >Subject: RE: Commander-List: Slips > > > > > >Of course the Commanders' tails are not made of plasti...err "composites" > > > >___________________________ > >Deneal Schilmeister > >St. Louis - Cincinnati > >1997 SL500 > >http://homepage.mac.com/deneals/SL500.htm > >http://homepage.mac.com/deneals/Sites/My_Commanders.htm > > > >-----Original Message----- > >From: On Behalf Of Bill Bow > >To: commander-list(at)matronics.com > >Subject: RE: Commander-List: Slips > > > > > >". Sudden high rudder inputs apparently caused structural failure in a large > >jet reported not too long ago. Do I recall that correctly? Apparently I > >would have been unduly cautious. What a machine!" > > > >Nico, the rudders only break off on "Hugo" Jets(AirBus). I know pilots who > >slipped Stretch DC-8s. The tail didn't break off and the fuselage did not > >break or bend (not permanently). > > > >bilbo > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jan 01, 2006
No but a little Avgas around the roots will. bb -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of YOURTCFG(at)aol.com Subject: Re: Commander-List: SLIP/NO SLIP In a message dated 12/31/2005 6:33:34 A.M. Pacific Standard Time, daniellfarmer(at)yahoo.com writes: I would be willing to bet the field was there first What about the trees at the end of my runway. Will turning off the TXP take them away?? That would really be handy at night!! Happy New Year Dan!! jb ________________________________________________________________________________
Subject: Re: Slips / Rudder Pulley Brackets
Date: Jan 01, 2006
Good, I'm not the only one to give the rudder a little boot on final sometimes. Doesn't slip like a Cub, but gets the job done and I don't have to mess with power. We need a steeper approach than standard at home base. Speaking of rudders, we noticed something last annual that was really tough to see. On the bulkhead ahead of the pilot's feet (forgot the number) are two rudder pulleys on either side of the airframe. They are a bitch to get at. After pulling the side nose inspection panel off, we noticed a 1/4 inch long crack at the top of the rudder pulley bracket. It takes some work, but we also saw the same crack on the 'back' side of the bracket. Since we saw it on the one bracket, we took a real hard look at the other side and found the same two cracks on the opposite side pulley brackets. The airframe's got about 8000 hours on it, and it is used for survey work where rudder is used often to correct yaw while on flightlines. Aircraft has been indoors for at least 20 years, maybe longer. These brackets are a bear to get at. It's one of the few places on the Commander where I thought it could have been made of a heavier gauge. Talk about rudders and slipping got me to remembering this. I'd be interested in hearing if anyone else has seen the same. Steve ________________________________________________________________________________
Date: Jan 01, 2006
Subject: Re: FLAPS
Around 1979 Commander decided to reduce the price of the 690B by removing some of the standard equipment such as the co-pilot's HSI. They then lowered the price about $100K. The B-II was the completely equipped, higher priced, version. Systems and mechanically they are the same. Rockwell did the same thin when they introduced the 681B. It was just a striped down 681 to lower the cost. Bill Leff ________________________________________________________________________________
From: "Tom Fisher" <tfisher(at)commandergroup.bc.ca>
Date: Jan 01, 2006
What would a simulated feather thrust setting be on a 680FL(P) Mr.RPM? Tom F. ----- Original Message ----- From: <CloudCraft(at)aol.com> Subject: Re: Commander-List: Commercial Use? > > In a message dated 31-Dec-05 14:42:45 Pacific Standard Time, > capt_seth(at)yahoo.com writes: > And so the question is: is it possible to safely > demonstrate competency, say, in recurrent training or > on a checkride for the Fed in a geared aircraft > without trashing the gear box? And if so, how? > >> > >> > > Seth, > > The economic debate of geared engine vs. direct drive in a commercial > operation is something I'll leave between you and your profit/loss statement. > > As far as 135 check rides go in a geared engine driven aircraft, I've taken > many (AC-680E, AC-680FL, BE-80, CE-411) and can tell you with 99% certainty > that the FAA examiner is scared to death of engine cuts and even more scared of > geared engines, in general. > > The POI will probably tell you to simulate feather thrust -- which you'll set > up very slowly -- and fly what ever task you're supposed to demonstrate. > > It's totally unrealistic, as far as a training and check-ride scenario, but > it's the best both of you can do. > > If/when you acquire a geared-Lycoming powered Commander, the collective > wisdom on this email net can give you lots of suggestions on power settings to > simulate feather thrust, depending on what model you end up with. > > Wing Commander Gordon > > Life is not simple anywhere. Probably less so elsewhere. > > ________________________________________________________________________________
Date: Jan 01, 2006
My machine has been flying survey for 19 years so I think I will go take a look, thanks for that. Tom F. ----- Original Message ----- From: "Steven" <steve2(at)sover.net> Subject: Re: Commander-List: Slips / Rudder Pulley Brackets > > Good, I'm not the only one to give the rudder a little boot on final > sometimes. Doesn't slip like a Cub, but gets the job done and I don't have > to mess with power. We need a steeper approach than standard at home base. > > Speaking of rudders, we noticed something last annual that was really tough > to see. On the bulkhead ahead of the pilot's feet (forgot the number) are > two rudder pulleys on either side of the airframe. They are a bitch to get > at. After pulling the side nose inspection panel off, we noticed a 1/4 inch > long crack at the top of the rudder pulley bracket. It takes some work, but > we also saw the same crack on the 'back' side of the bracket. > > Since we saw it on the one bracket, we took a real hard look at the other > side and found the same two cracks on the opposite side pulley brackets. The > airframe's got about 8000 hours on it, and it is used for survey work where > rudder is used often to correct yaw while on flightlines. Aircraft has been > indoors for at least 20 years, maybe longer. These brackets are a bear to > get at. It's one of the few places on the Commander where I thought it could > have been made of a heavier gauge. > > Talk about rudders and slipping got me to remembering this. I'd be > interested in hearing if anyone else has seen the same. > > Steve > > ________________________________________________________________________________
Date: Jan 01, 2006
Subject: Re: Slips
I was an instructor at TWA (then owned by American) when American Flight 587. To keep this short, it was determined that after encountering turbulence from a 747 in front of it, the flying pilot over controlled the A300 aircraft in the yaw axis. This over controlling of the rudder by rapid direction reversal is called a Rudder Doublet. Contrary to popular belief, transport aircraft are only required to demonstrate full travel of the rudder (at or below maneuvering speed) from neutral to full deflection then back to neutral. Demonstration of full deflection from stop to stop is not required! Boeing put out a great paper on the subject and proudly pointed out that their aircraft have never had structural problems with their tails because of the extra design margins in the Boeing Aircraft vs. their French competitors aircraft. Proper use of the rudder became a priority in training after that. Bill Leff ________________________________________________________________________________
Date: Jan 01, 2006
In a message dated 01-Jan-06 09:22:03 Pacific Standard Time, tfisher(at)commandergroup.bc.ca writes: What would a simulated feather thrust setting be on a 680FL(P) Mr.RPM? Tom, With the IO-720, I'd use 14" and 2000 rpm. This is what I've found gave equal performance (or lack of) to having one feathered on the long body MR RPMs. If 14" MAP won't keep yours on the governor, you may have to up the MAP a bit. This are approximate settings, of course. Each airplane seems to have a different set-up. Wing Commander Gordon Life is not simple anywhere. Probably less so elsewhere. ________________________________________________________________________________
Subject: Slips
Date: Jan 01, 2006
Rudder deflection on the B747 is relative to speed. At higher speed you can't get full deflection. bilbo -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of BillLeff1(at)aol.com Subject: Re: Commander-List: Slips I was an instructor at TWA (then owned by American) when American Flight 587. To keep this short, it was determined that after encountering turbulence from a 747 in front of it, the flying pilot over controlled the A300 aircraft in the yaw axis. This over controlling of the rudder by rapid direction reversal is called a Rudder Doublet. Contrary to popular belief, transport aircraft are only required to demonstrate full travel of the rudder (at or below maneuvering speed) from neutral to full deflection then back to neutral. Demonstration of full deflection from stop to stop is not required! Boeing put out a great paper on the subject and proudly pointed out that their aircraft have never had structural problems with their tails because of the extra design margins in the Boeing Aircraft vs. their French competitors aircraft. Proper use of the rudder became a priority in training after that. Bill Leff ________________________________________________________________________________
From: "Randy Dettmer, AIA" <rcdettmer(at)charter.net>
Subject: Happy New Year in Commanderland...!!
Date: Jan 01, 2006
New Years Greetings..!! Just wanted to share some great Commander flying this holiday week. Loaded up the 680F day after Christmas with 3 pairs of skies, 2 snow boards, about 8 big bags of clothing and gear, Christmas presents, and 5 persons (my wife, son & girlfriend, daughter...and me) for our non-stop flight from SBP (San Luis Obispo, CA) to SLC (Salt Lake City) for a week of fun at my sister's house in Park City, UT. Total flight time - less than 3 hours. Not bad considering we had to go south through Palmdale & Las Vegas because bad weather over the Sierras didn't let us go direct at less than the MEA of 14,300 feet (not pressurized). After a week of spectacular skiing and family fun, we piled it all back into the Commander this morning (New Year's Day) for the flight home. The terrible weather in California once again prevented a direct route home, so it was SLC to VGT (North Las Vegas for a fuel & burger stop), then on to SBP, where we entered the nasty weather around Palmdale (30-40 knot headwinds). The commander performed flawlessly with a smooth ride at 11,000 feet (while the airliners all complained about turbulence in the flight levels), with an ILS approach to SBP in heavy rain. After parking, I backed my Ford Explorer up to the plane with the hatch back open and overlapping the engine nacelle & flaps. We unloaded all the gear into the car without even getting wet...can't do that in a low wing airplane. Anyway, I once again find myself so appreciative of the great qualities of our cherished Twin Commander, after transporting our family in comfort and safetly through the winter skies...thought I'd share it with you folks, who can appreciate it too. Best wishes to all of you for a Great New Year in Commanderland..!!! Randy Dettmer 680F/N6253X ________________________________________________________________________________
Date: Jan 01, 2006
Subject: Re: Slips
You are right, That is true of most Transport aircraft. I was an MD-80 instructor and it also had a rudder limiter. However at lower speeds the rudder limiter allows full travel. On the A300 the problem is that it has very light rudder pressures for full defection (33 lbs) due to the fly by wire flight control system. It is very easy to over control. In the case of flight 587 the flying pilot created so much yaw from side to side that the rudder, vertical fin and both engines separated from the aircraft. It was below maneuvering speed by a good margin. Good rudder handling habits are important in any airplane! Bill Leff ________________________________________________________________________________
Date: Jan 01, 2006
Subject: Re: New Year
To all in Commanderland, Have a great New Year. We had a fine day running at about 47 deg C. A little warm. Had a wonderful visit from Moe and Linn. It was great to see them. Flew my Super Cub for the first time on Wednesday. After a complete rebuild and changing from US reg to Oz reg. Havent flown one of these things for about 15 years. Funny how quickly it all comes back to you. You discover things like what a rudders is used for and what torque does in a grossly overpowered aircraft. Its all come back and a blast to fly although I am beginning to become a little afraid of birdstrikes from the rear. Comming over the fence at 40 kts, feels like you could walk faster. But you also land and take off in a very very short space. Now thats finished I will be back on the 680E. Hopefully that can be done by mid year. Best wishes from OZ Richard & Jacqui ________________________________________________________________________________
Subject: Slips
Date: Jan 01, 2006
Yes, I agree. Keep your feet on the floor. bilbo -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of BillLeff1(at)aol.com Subject: Re: Commander-List: Slips You are right, That is true of most Transport aircraft. I was an MD-80 instructor and it also had a rudder limiter. However at lower speeds the rudder limiter allows full travel. On the A300 the problem is that it has very light rudder pressures for full defection (33 lbs) due to the fly by wire flight control system. It is very easy to over control. In the case of flight 587 the flying pilot created so much yaw from side to side that the rudder, vertical fin and both engines separated from the aircraft. It was below maneuvering speed by a good margin. Good rudder handling habits are important in any airplane! Bill Leff ________________________________________________________________________________
Date: Jan 01, 2006
Subject: Re: Happy New Year in Commanderland...!!
GREAT STORY!! Thanks for sharing it. Happy New Year!! jb ________________________________________________________________________________
Date: Jan 01, 2006
CONGRATS RICHARD That ws a long road back. Happy Ne Year!! jb ________________________________________________________________________________
Date: Jan 01, 2006
Great vacation, Randy. Welcome home and a very prosperous 2006! ----- Original Message ----- From: "Randy Dettmer, AIA" <rcdettmer(at)charter.net> Subject: Commander-List: Happy New Year in Commanderland...!! > > New Years Greetings..!! > Just wanted to share some great Commander flying this holiday week. Loaded > up the 680F day after Christmas with 3 pairs of skies, 2 snow boards, about > 8 big bags of clothing and gear, Christmas presents, and 5 persons (my wife, > son & girlfriend, daughter...and me) for our non-stop flight from SBP (San > Luis Obispo, CA) to SLC (Salt Lake City) for a week of fun at my sister's > house in Park City, UT. Total flight time - less than 3 hours. Not bad > considering we had to go south through Palmdale & Las Vegas because bad > weather over the Sierras didn't let us go direct at less than the MEA of > 14,300 feet (not pressurized). After a week of spectacular skiing and > family fun, we piled it all back into the Commander this morning (New Year's > Day) for the flight home. The terrible weather in California once again > prevented a direct route home, so it was SLC to VGT (North Las Vegas for a > fuel & burger stop), then on to SBP, where we entered the nasty weather > around Palmdale (30-40 knot headwinds). The commander performed flawlessly > with a smooth ride at 11,000 feet (while the airliners all complained about > turbulence in the flight levels), with an ILS approach to SBP in heavy rain. > After parking, I backed my Ford Explorer up to the plane with the hatch back > open and overlapping the engine nacelle & flaps. We unloaded all the gear > into the car without even getting wet...can't do that in a low wing > airplane. > > Anyway, I once again find myself so appreciative of the great qualities of > our cherished Twin Commander, after transporting our family in comfort and > safetly through the winter skies...thought I'd share it with you folks, who > can appreciate it too. > > Best wishes to all of you for a Great New Year in Commanderland..!!! > > Randy Dettmer > 680F/N6253X > > ________________________________________________________________________________
Subject: Re: Slips
Date: Jan 01, 2006
I guess there is just so much you can throw overboard before you change a plane into a soon to be pile of crumpled aluminum. ----- Original Message ----- From: <BillLeff1(at)aol.com> Subject: Re: Commander-List: Slips > > You are right, That is true of most Transport aircraft. I was an MD-80 > instructor and it also had a rudder limiter. However at lower speeds the rudder > limiter allows full travel. On the A300 the problem is that it has very light > rudder pressures for full defection (33 lbs) due to the fly by wire flight > control system. It is very easy to over control. > > In the case of flight 587 the flying pilot created so much yaw from side to > side that the rudder, vertical fin and both engines separated from the > aircraft. It was below maneuvering speed by a good margin. > > Good rudder handling habits are important in any airplane! > > Bill Leff > > ________________________________________________________________________________
Date: Jan 02, 2006
Steve, My 500A (#1274) is the same, and it sure is hard to get at, So far I am just monitoring, while a work out a doable repair scheme. I also have the "standard"crack in the nose wheel support structure, where the shaft #5750039-11 and bearings #SF1301-1 reside, but at least this will be a tad easier to repair. Regards, Bill Hamilton At 01:14 2/01/2006, you wrote: > >Good, I'm not the only one to give the rudder a little boot on final >sometimes. Doesn't slip like a Cub, but gets the job done and I don't have >to mess with power. We need a steeper approach than standard at home base. > >Speaking of rudders, we noticed something last annual that was really tough >to see. On the bulkhead ahead of the pilot's feet (forgot the number) are >two rudder pulleys on either side of the airframe. They are a bitch to get >at. After pulling the side nose inspection panel off, we noticed a 1/4 inch >long crack at the top of the rudder pulley bracket. It takes some work, but >we also saw the same crack on the 'back' side of the bracket. > >Since we saw it on the one bracket, we took a real hard look at the other >side and found the same two cracks on the opposite side pulley brackets. The >airframe's got about 8000 hours on it, and it is used for survey work where >rudder is used often to correct yaw while on flightlines. Aircraft has been >indoors for at least 20 years, maybe longer. These brackets are a bear to >get at. It's one of the few places on the Commander where I thought it could >have been made of a heavier gauge. > >Talk about rudders and slipping got me to remembering this. I'd be >interested in hearing if anyone else has seen the same. > >Steve > > CONFIDENTIALITY & PRIVILEGE NOTICE W.J.R.Hamilton,Glenalmond Group Companies,Fighter Flights Internet Services and Warbirds.Net. & . This message is intended for and should only be used by the addressee. It is confidential and may contain legally privileged information.If you are not the intended recipient any use distribution,disclosure or copying of this message is strictly prohibited.Confidentiality and legal privilege attached to this communication are not waived or lost by reason of the mistaken delivery to you.If you have received this message in error, please notify us immediately to Australia 61 (0)408 876 526 Dolores capitis non fero. Eos do. ________________________________________________________________________________
Date: Jan 02, 2006
Good morning Bill, The four cracks were nearly identical in length on ours, and we're monitoring also. We did put a tiny stop-drill on each, but seeing as they cracked to a certain point and no further, we're wondering if they perhaps become somewhat stable over time once that intital crack forms? Steve ----- Original Message ----- From: "W J R HAMILTON" <wjrhamilton(at)optusnet.com.au> Subject: Re: Commander-List: Slips / Rudder Pulley Brackets > > > Steve, > My 500A (#1274) is the same, and it sure is hard to get at, So far I > am just monitoring, while a work out a doable repair scheme. > I also have the "standard"crack in the nose wheel support structure, > where the shaft #5750039-11 and bearings #SF1301-1 reside, but at > least this will be a tad easier to repair. > Regards, > Bill Hamilton > > > At 01:14 2/01/2006, you wrote: >> >>Good, I'm not the only one to give the rudder a little boot on final >>sometimes. Doesn't slip like a Cub, but gets the job done and I don't have >>to mess with power. We need a steeper approach than standard at home base. >> >>Speaking of rudders, we noticed something last annual that was really >>tough >>to see. On the bulkhead ahead of the pilot's feet (forgot the number) are >>two rudder pulleys on either side of the airframe. They are a bitch to get >>at. After pulling the side nose inspection panel off, we noticed a 1/4 >>inch >>long crack at the top of the rudder pulley bracket. It takes some work, >>but >>we also saw the same crack on the 'back' side of the bracket. >> >>Since we saw it on the one bracket, we took a real hard look at the other >>side and found the same two cracks on the opposite side pulley brackets. >>The >>airframe's got about 8000 hours on it, and it is used for survey work >>where >>rudder is used often to correct yaw while on flightlines. Aircraft has >>been >>indoors for at least 20 years, maybe longer. These brackets are a bear to >>get at. It's one of the few places on the Commander where I thought it >>could >>have been made of a heavier gauge. >> >>Talk about rudders and slipping got me to remembering this. I'd be >>interested in hearing if anyone else has seen the same. >> >>Steve >> >> >> >> >> >> >> >> >> >> >> > > > CONFIDENTIALITY & PRIVILEGE NOTICE > W.J.R.Hamilton,Glenalmond Group Companies,Fighter Flights Internet > Services and Warbirds.Net. & . > This message is intended for and should only be used by the > addressee. It is confidential and may contain legally privileged > information.If you are not the intended recipient any use > distribution,disclosure or copying of this message is strictly > prohibited.Confidentiality and legal privilege attached to this > communication are not waived or lost by reason of the mistaken > delivery to you.If you have received this message in error, please > notify us immediately to Australia 61 (0)408 876 526 > Dolores capitis non fero. Eos do. > > > ________________________________________________________________________________
Subject: Re: Slips
Date: Jan 02, 2006
In fact, my first trip back to MD80 training after the airbus we had quite an argument over rudder use. Prior to the entrail restrictions behind 757s, at DFW and elsewhere, before the guy ahead of you had completed his rotaion they would clear you for takeoff which put you right into the rather nasty vortecies generated by the 757. The width of the vortex was such that it completely blanked out the MD80 ailerons. So right after T.O. (happened twice to me) you are in an uncommanded ninety degree bank with full opposite aileron and still rolling. Your only effective controll is the rudder. My feeling was that Boeing and the attorneys were going to cause more trouble by discouraging it's use than by teaching it's proper use. Phil > [Original Message] > From: <BillLeff1(at)aol.com> > To: > Date: 1/1/2006 12:54:55 PM > Subject: Re: Commander-List: Slips > > > I was an instructor at TWA (then owned by American) when American Flight > 587. To keep this short, it was determined that after encountering turbulence > from a 747 in front of it, the flying pilot over controlled the A300 aircraft > in the yaw axis. > > This over controlling of the rudder by rapid direction reversal is called a > Rudder Doublet. Contrary to popular belief, transport aircraft are only > required to demonstrate full travel of the rudder (at or below maneuvering speed) > from neutral to full deflection then back to neutral. Demonstration of full > deflection from stop to stop is not required! > > Boeing put out a great paper on the subject and proudly pointed out that > their aircraft have never had structural problems with their tails because of > the extra design margins in the Boeing Aircraft vs. their French competitors > aircraft. > > Proper use of the rudder became a priority in training after that. > > Bill Leff > > > > > > ________________________________________________________________________________
Subject: Re: FLAPS
Date: Jan 02, 2006
Thanks Bill I wondered what that was all about. We had the first 681 built SN 6001 it was a good machine but noisy. Thanks Bert -----Original Message----- From: BillLeff1(at)aol.com Date: Sun, 1 Jan 2006 12:19:13 To:commander-list(at)matronics.com Subject: Re: Commander-List: FLAPS Around 1979 Commander decided to reduce the price of the 690B by removing some of the standard equipment such as the co-pilot's HSI. They then lowered the price about $100K. The B-II was the completely equipped, higher priced, version. Systems and mechanically they are the same. Rockwell did the same thin when they introduced the 681B. It was just a striped down 681 to lower the cost. Bill Leff bertberry1(at)aol.com ________________________________________________________________________________
Subject: Re: Commander decent
Date: Jan 03, 2006
Which Commanders came standard with geared engines? Bert -----Original Message----- From: "Moe" <moe(at)rosspistons.com> Date: Fri, 30 Dec 2005 14:12:55 To: Subject: Re: Commander-List: Commander decent Nico, The situation with geared engines is that the engines can never be used to slow the airplane down. The prop should always be driven by the crankshaft. Also, on the ground the engines should never be run below about 1,200 RPM (1,500 is better) with the Simmonds fuel pumps. At lower RPM the engines will surge which loads and unloads the sun gear against the planetary gears. I won't go into the part about the 5/16" bolts that hold the gear drive to the drive plate. Regards, Moe ----- Original Message ----- From: "css nico" <nico(at)cybersuperstore.com> Subject: Re: Commander-List: Commander decent > > What's the vertical speed requirement that would cause one to slip, or is it > to avoid throttling back on the engines? > Nico > > ----- Original Message ----- > From: "Moe" <moe(at)rosspistons.com> > To: > Subject: Re: Commander-List: Commander decent > > > > > > JB, > > > > Thanks for the tip. I have been slipping pretty heavy at 100 MPH with > full > > flaps. N680RR has dual air speed indicators, with a pitot tube on each > > side. Will try to check them against each other on next slipping approach > > to see if there is any difference in the upstream and downstream sides. > > > > Moe > > ----- Original Message ----- > > From: <YOURTCFG(at)aol.com> > > To: > > Subject: Re: Commander-List: Commander decent > > > > > > > > > > HI MOE. > > > > > > I keep my commander on a 2400 strip with real 50 foot obstructions > on > > > both ends. I routinely slip the airplane. It slips fairly well. I > have > > only > > > slipped it with full flaps. No adverse handling characteristics, it > > recovers > > > naturally, all by itself. There is no tendency to drop the nose, nor > > does > > > it pitch up (like some floatplanes). > > > I have slipped to an airspeed as low as 60KIAS, although I think > the > > > pitot tube gets blocked a bit in the slip so the speed may have been a > > little > > > higher. The only caution is that once slowed, the Commander takes a > bit > > of > > > encouragement to re accelerate so plan for that. Have fun jb > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > bertberry1(at)aol.com ________________________________________________________________________________
Date: Jan 02, 2006
Bert, Here is a page I use to compare models: http://www.aerocommander.com/aircraft.asp Ben ----- Original Message ----- From: Bert Berry To: commander-list(at)matronics.com Sent: Monday, January 02, 2006 7:05 PM Subject: Re: Commander-List: Commander decent Which Commanders came standard with geared engines? Bert ________________________________________________________________________________
Subject: Geared engined Commanders
Date: Jan 03, 2006
Hi Bert, I'm hoping this list of geared-engined Commanders (standard, ex-factory) is complete.......... Geared: 520; 560; 560A; 560A(HC); 560E. Geared & Supercharged: 680; 680E; 720. Geared & Fuel Injected: 560F. Geared, Supercharged & Fuel Injected: 680F; 680F(P); 680FL; 680FLP; 685. ........but if it isn't, I'm absolutely certain that somebody will shout - LOUDLY! Very Best Regards, Barry ----- Original Message ----- From: "Bert Berry" <bertberry1(at)aol.com> Subject: Re: Commander-List: Commander decent | | Which Commanders came standard with geared engines? | | Bert | -----Original Message----- | From: "Moe" <moe(at)rosspistons.com> | Date: Fri, 30 Dec 2005 14:12:55 | To: | Subject: Re: Commander-List: Commander decent | | | Nico, | | The situation with geared engines is that the engines can never be used to | slow the airplane down. The prop should always be driven by the crankshaft. | Also, on the ground the engines should never be run below about 1,200 RPM | (1,500 is better) with the Simmonds fuel pumps. At lower RPM the engines | will surge which loads and unloads the sun gear against the planetary gears. | I won't go into the part about the 5/16" bolts that hold the gear drive to | the drive plate. | | Regards, | | Moe | ----- Original Message ----- | From: "css nico" <nico(at)cybersuperstore.com> | To: | Subject: Re: Commander-List: Commander decent | | | | > | > What's the vertical speed requirement that would cause one to slip, or is | it | > to avoid throttling back on the engines? | > Nico | > | > ----- Original Message ----- | > From: "Moe" <moe(at)rosspistons.com> | > To: | > Subject: Re: Commander-List: Commander decent | > | > | > > | > > JB, | > > | > > Thanks for the tip. I have been slipping pretty heavy at 100 MPH with | > full | > > flaps. N680RR has dual air speed indicators, with a pitot tube on each | > > side. Will try to check them against each other on next slipping | approach | > > to see if there is any difference in the upstream and downstream sides. | > > | > > Moe | > > ----- Original Message ----- | > > From: <YOURTCFG(at)aol.com> | > > To: | > > Subject: Re: Commander-List: Commander decent | > > | > > | > > > | > > > HI MOE. | > > > | > > > I keep my commander on a 2400 strip with real 50 foot | obstructions | > on | > > > both ends. I routinely slip the airplane. It slips fairly well. I | > have | > > only | > > > slipped it with full flaps. No adverse handling characteristics, it | > > recovers | > > > naturally, all by itself. There is no tendency to drop the nose, nor | > > does | > > > it pitch up (like some floatplanes). | > > > I have slipped to an airspeed as low as 60KIAS, although I think | > the | > > > pitot tube gets blocked a bit in the slip so the speed may have been | a | > > little | > > > higher. The only caution is that once slowed, the Commander takes a | > bit | > > of | > > > encouragement to re accelerate so plan for that. Have fun jb | > > > | > > > | > > > | > > > | > > > | > > > | > > > | > > > | > > > | > > > | > > > | > > > | > > > | > > | > > | > > | > > | > > | > > | > > | > > | > > | > > | > > | > > | > | > | > | > | > | > | > | > | > | > | > | > | > | | | | | | | | | | | | | | bertberry1(at)aol.com | | | | | | | | | | | | ________________________________________________________________________________
Date: Jan 03, 2006
Thanks Ben -----Original Message----- From: "Ben Baltrusaitis" <ben(at)gmpexpress.net> Date: Mon, 2 Jan 2006 19:28:00 To: Subject: Re: Commander-List: Commander decent Bert, Here is a page I use to compare models: http://www.aerocommander.com/aircraft.asp Ben ----- Original Message ----- From: Bert Berry To: commander-list(at)matronics.com Sent: Monday, January 02, 2006 7:05 PM Subject: Re: Commander-List: Commander decent Which Commanders came standard with geared engines? Bert bertberry1(at)aol.com ________________________________________________________________________________
Subject: Re: Geared engined Commanders
Date: Jan 03, 2006
Thanks Barry, I wonder how the K seriers Cont. That were put on the later 685's would have worked on the 680FLP? Bert -----Original Message----- From: "Barry Collman" <barry.collman@air-britain.co.uk> Date: Tue, 3 Jan 2006 00:27:13 To: Subject: Commander-List: Geared engined Commanders Hi Bert, I'm hoping this list of geared-engined Commanders (standard, ex-factory) is complete.......... Geared: 520; 560; 560A; 560A(HC); 560E. Geared & Supercharged: 680; 680E; 720. Geared & Fuel Injected: 560F. Geared, Supercharged & Fuel Injected: 680F; 680F(P); 680FL; 680FLP; 685. ........but if it isn't, I'm absolutely certain that somebody will shout - LOUDLY! Very Best Regards, Barry ----- Original Message ----- From: "Bert Berry" <bertberry1(at)aol.com> Subject: Re: Commander-List: Commander decent | | Which Commanders came standard with geared engines? | | Bert | -----Original Message----- | From: "Moe" <moe(at)rosspistons.com> | Date: Fri, 30 Dec 2005 14:12:55 | To: | Subject: Re: Commander-List: Commander decent | | | Nico, | | The situation with geared engines is that the engines can never be used to | slow the airplane down. The prop should always be driven by the crankshaft. | Also, on the ground the engines should never be run below about 1,200 RPM | (1,500 is better) with the Simmonds fuel pumps. At lower RPM the engines | will surge which loads and unloads the sun gear against the planetary gears. | I won't go into the part about the 5/16" bolts that hold the gear drive to | the drive plate. | | Regards, | | Moe | ----- Original Message ----- | From: "css nico" <nico(at)cybersuperstore.com> | To: | Subject: Re: Commander-List: Commander decent | | | | > | > What's the vertical speed requirement that would cause one to slip, or is | it | > to avoid throttling back on the engines? | > Nico | > | > ----- Original Message ----- | > From: "Moe" <moe(at)rosspistons.com> | > To: | > Subject: Re: Commander-List: Commander decent | > | > | > > | > > JB, | > > | > > Thanks for the tip. I have been slipping pretty heavy at 100 MPH with | > full | > > flaps. N680RR has dual air speed indicators, with a pitot tube on each | > > side. Will try to check them against each other on next slipping | approach | > > to see if there is any difference in the upstream and downstream sides. | > > | > > Moe | > > ----- Original Message ----- | > > From: <YOURTCFG(at)aol.com> | > > To: | > > Subject: Re: Commander-List: Commander decent | > > | > > | > > > | > > > HI MOE. | > > > | > > > I keep my commander on a 2400 strip with real 50 foot | obstructions | > on | > > > both ends. I routinely slip the airplane. It slips fairly well. I | > have | > > only | > > > slipped it with full flaps. No adverse handling characteristics, it | > > recovers | > > > naturally, all by itself. There is no tendency to drop the nose, nor | > > does | > > > it pitch up (like some floatplanes). | > > > I have slipped to an airspeed as low as 60KIAS, although I think | > the | > > > pitot tube gets blocked a bit in the slip so the speed may have been | a | > > little | > > > higher. The only caution is that once slowed, the Commander takes a | > bit | > > of | > > > encouragement to re accelerate so plan for that. Have fun jb | > > > | > > > | > > > | > > > | > > > | > > > | > > > | > > > | > > > | > > > | > > > | > > > | > > > | > > | > > | > > | > > | > > | > > | > > | > > | > > | > > | > > | > > | > | > | > | > | > | > | > | > | > | > | > | > | > | | | | | | | | | | | | | | bertberry1(at)aol.com | | | | | | | | | | | | bertberry1(at)aol.com ________________________________________________________________________________
Date: Jan 02, 2006
In a message dated 02-Jan-06 16:47:12 Pacific Standard Time, bertberry1(at)aol.com writes: I wonder how the K seriers Cont. That were put on the later 685's would have worked on the 680FLP? >>> >>> They would have consumed the same 3 cylinders per year just like they do on the AC-685 ... Wing Commander Gordon Life is not simple anywhere. Probably less so elsewhere. ________________________________________________________________________________
Date: Jan 02, 2006
In a message dated 1/2/2006 4:30:16 P.M. Pacific Standard Time, barry.collman@air-britain.co.uk writes: ........but if it isn't, I'm absolutely certain that somebody will shout - LOUDLY! Well done "Sir" Barry!! ________________________________________________________________________________
Date: Jan 02, 2006
In a message dated 1/2/2006 4:47:12 P.M. Pacific Standard Time, bertberry1(at)aol.com writes: I wonder how the K seriers Cont. That were put on the later 685's would have worked on the 680FLP? Just a poorly as they did on the 685. The problem was the propeller. They never created a proper propeller for the 425HP Cont. jb ________________________________________________________________________________
Date: Jan 02, 2006
Subject: MOLLY
It is with great sadness that I report Sue and I lost our wonderful Wire Fox Terrier, Molly, on Christmas day. She was only 8 years old. She died in our arms of cancer. Molly (short for "Chromoly") was a wonderful, smart, saucy, sassy dear friend who had spent more time in Commanders than many who own them, and we miss her deeply. Those of you who knew her know what I mean. God Bless all of our pets this night. jb ________________________________________________________________________________
Date: Jan 02, 2006
Subject: Re: MOLLY
JB, sorry about your loss, we have many family members other than humans, seven dogs, one cat, feel sorry for your loss. Joe Shepherd ________________________________________________________________________________
Subject: Re: MOLLY
Date: Jan 02, 2006
Jim, Sue, Our thoughts go out to you. The loss of a member of your family at such a young age is a tragedy. All us Dog People understand....most especially those of us with dogs who are Commander People as well. I'm sure that Molly knew just how much she was loved. /John & Sarah ----- Original Message ----- From: <YOURTCFG(at)aol.com> Subject: Commander-List: MOLLY > > It is with great sadness that I report Sue and I lost our wonderful Wire Fox > Terrier, Molly, on Christmas day. She was only 8 years old. She died in > our arms of cancer. Molly (short for "Chromoly") was a wonderful, smart, > saucy, sassy dear friend who had spent more time in Commanders than many who own > them, and we miss her deeply. Those of you who knew her know what I mean. > God Bless all of our pets this night. jb > > ________________________________________________________________________________
Date: Jan 03, 2006
Subject: Re: MOLLY
Jim & Sue, My sincerest sympathies on your loss of Molly. As always she shared some great Commander stories with many of us! Russell On 3/1/06 1:46 PM, "YOURTCFG(at)aol.com" wrote: > > It is with great sadness that I report Sue and I lost our wonderful Wire Fox > Terrier, Molly, on Christmas day. She was only 8 years old. She died in > our arms of cancer. Molly (short for "Chromoly") was a wonderful, smart, > saucy, sassy dear friend who had spent more time in Commanders than many who > own > them, and we miss her deeply. Those of you who knew her know what I mean. > God Bless all of our pets this night. jb > > > > > > > > > > > > ________________________________________________________________________________
Subject: Re: MOLLY
Date: Jan 03, 2006
Jim & Sue, Special thoughts go out to you both from me & Elaine. Molly was indeed a special character and I know you will both be more than deeply saddened at her passing. Barry & Elaine. ----- Original Message ----- From: <YOURTCFG(at)aol.com> Subject: Commander-List: MOLLY | | It is with great sadness that I report Sue and I lost our wonderful Wire Fox | Terrier, Molly, on Christmas day. She was only 8 years old. She died in | our arms of cancer. Molly (short for "Chromoly") was a wonderful, smart, | saucy, sassy dear friend who had spent more time in Commanders than many who own | them, and we miss her deeply. Those of you who knew her know what I mean. | God Bless all of our pets this night. jb | | | | | | | | | | | | | ________________________________________________________________________________
Date: Jan 03, 2006
Steve, What model Commander was this on? Moe ----- Original Message ----- From: "Steven" <steve2(at)sover.net> Subject: Re: Commander-List: Slips / Rudder Pulley Brackets > > Good, I'm not the only one to give the rudder a little boot on final > sometimes. Doesn't slip like a Cub, but gets the job done and I don't have > to mess with power. We need a steeper approach than standard at home base. > > Speaking of rudders, we noticed something last annual that was really tough > to see. On the bulkhead ahead of the pilot's feet (forgot the number) are > two rudder pulleys on either side of the airframe. They are a bitch to get > at. After pulling the side nose inspection panel off, we noticed a 1/4 inch > long crack at the top of the rudder pulley bracket. It takes some work, but > we also saw the same crack on the 'back' side of the bracket. > > Since we saw it on the one bracket, we took a real hard look at the other > side and found the same two cracks on the opposite side pulley brackets. The > airframe's got about 8000 hours on it, and it is used for survey work where > rudder is used often to correct yaw while on flightlines. Aircraft has been > indoors for at least 20 years, maybe longer. These brackets are a bear to > get at. It's one of the few places on the Commander where I thought it could > have been made of a heavier gauge. > > Talk about rudders and slipping got me to remembering this. I'd be > interested in hearing if anyone else has seen the same. > > Steve > > ________________________________________________________________________________
Date: Jan 03, 2006
Richard & Jacqui, Linn and I had a really great time, as we always do in your country. Thank you so very much for showing me what the local gentry are flying. Moe Happy to hear that the paper work came through on the Cub. ----- Original Message ----- From: <RnJThompson(at)aol.com> Subject: Commander-List: Re: New Year > > To all in Commanderland, > > Have a great New Year. We had a fine day running at about 47 deg C. A little > warm. > Had a wonderful visit from Moe and Linn. It was great to see them. > > Flew my Super Cub for the first time on Wednesday. After a complete rebuild > and changing from US reg to Oz reg. Havent flown one of these things for about > 15 years. Funny how quickly it all comes back to you. You discover things > like what a rudders is used for and what torque does in a grossly overpowered > aircraft. Its all come back and a blast to fly although I am beginning to become > a little afraid of birdstrikes from the rear. Comming over the fence at 40 > kts, feels like you could walk faster. But you also land and take off in a very > very short space. > > Now thats finished I will be back on the 680E. Hopefully that can be done by > mid year. > > Best wishes from OZ > > Richard & Jacqui > > ________________________________________________________________________________
Date: Jan 03, 2006
1961 500B (Converted from an A in 1966 I think.) ----- Original Message ----- From: "Moe" <moe(at)rosspistons.com> Subject: Re: Commander-List: Slips / Rudder Pulley Brackets > > Steve, > > What model Commander was this on? > > Moe > ----- Original Message ----- > From: "Steven" <steve2(at)sover.net> > To: > Subject: Re: Commander-List: Slips / Rudder Pulley Brackets > > >> >> Good, I'm not the only one to give the rudder a little boot on final >> sometimes. Doesn't slip like a Cub, but gets the job done and I don't >> have >> to mess with power. We need a steeper approach than standard at home >> base. >> >> Speaking of rudders, we noticed something last annual that was really > tough >> to see. On the bulkhead ahead of the pilot's feet (forgot the number) are >> two rudder pulleys on either side of the airframe. They are a bitch to >> get >> at. After pulling the side nose inspection panel off, we noticed a 1/4 > inch >> long crack at the top of the rudder pulley bracket. It takes some work, > but >> we also saw the same crack on the 'back' side of the bracket. >> >> Since we saw it on the one bracket, we took a real hard look at the other >> side and found the same two cracks on the opposite side pulley brackets. > The >> airframe's got about 8000 hours on it, and it is used for survey work > where >> rudder is used often to correct yaw while on flightlines. Aircraft has > been >> indoors for at least 20 years, maybe longer. These brackets are a bear to >> get at. It's one of the few places on the Commander where I thought it > could >> have been made of a heavier gauge. >> >> Talk about rudders and slipping got me to remembering this. I'd be >> interested in hearing if anyone else has seen the same. >> >> Steve >> >> >> >> >> >> >> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Subject: Re: MOLLY
Date: Jan 03, 2006
So sorry about Molly. We lost our Mollie a couple years back, a black lab, also eight years old. We had expected her to be with us as long as her 'grandmother', a lovely, creaky old dog of 14. Damn cancer. She's buried under a crab apple tree we planted at our new house. LuLu is eight and going strong, Maggie we got a couple months after we lost Mollie. It's never easy, especially when they leave sooner than we expected.. Steve ----- Original Message ----- From: <YOURTCFG(at)aol.com> Subject: Commander-List: MOLLY > > It is with great sadness that I report Sue and I lost our wonderful Wire > Fox > Terrier, Molly, on Christmas day. She was only 8 years old. She died in > our arms of cancer. Molly (short for "Chromoly") was a wonderful, smart, > saucy, sassy dear friend who had spent more time in Commanders than many > who own > them, and we miss her deeply. Those of you who knew her know what I > mean. > God Bless all of our pets this night. jb > > > ________________________________________________________________________________
Subject: Re: MOLLY
Date: Jan 03, 2006
My Bridget was lost with my 500B in an ocean ditching in '99. No doubt she and Molly are keeping each other company exchanging Commander tales. I was also once married to a Molly for three years. Tom F. ----- Original Message ----- From: "steve2" <steve2(at)sover.net> Subject: Re: Commander-List: MOLLY > > So sorry about Molly. > > We lost our Mollie a couple years back, a black lab, also eight years old. > We had expected her to be with us as long as her 'grandmother', a lovely, > creaky old dog of 14. Damn cancer. > > She's buried under a crab apple tree we planted at our new house. LuLu is > eight and going strong, Maggie we got a couple months after we lost Mollie. > > It's never easy, especially when they leave sooner than we expected.. > > Steve > > ----- Original Message ----- > From: <YOURTCFG(at)aol.com> > To: > Subject: Commander-List: MOLLY > > > > > > It is with great sadness that I report Sue and I lost our wonderful Wire > > Fox > > Terrier, Molly, on Christmas day. She was only 8 years old. She died in > > our arms of cancer. Molly (short for "Chromoly") was a wonderful, smart, > > saucy, sassy dear friend who had spent more time in Commanders than many > > who own > > them, and we miss her deeply. Those of you who knew her know what I > > mean. > > God Bless all of our pets this night. jb > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jan 04, 2006
From: W J R HAMILTON <wjrhamilton(at)optusnet.com.au>
Steve, That seems possible, as close as I can get to the brackets to see, the original crack looks quite old, and the engineers who had been looking after the aircraft for some years, before I bought it indicated that they had not observed any change, but in those few years the aircraft did only low annual hours. My total airframe time is about 11,000, some of it on quite rough strips. Cheers, Bill Hamilton At 00:57 3/01/2006, you wrote: > >Good morning Bill, > >The four cracks were nearly identical in length on ours, and we're >monitoring also. We did put a tiny stop-drill on each, but seeing as they >cracked to a certain point and no further, we're wondering if they perhaps >become somewhat stable over time once that intital crack forms? > >Steve CONFIDENTIALITY & PRIVILEGE NOTICE W.J.R.Hamilton,Glenalmond Group Companies,Fighter Flights Internet Services and Warbirds.Net. & . This message is intended for and should only be used by the addressee. It is confidential and may contain legally privileged information.If you are not the intended recipient any use distribution,disclosure or copying of this message is strictly prohibited.Confidentiality and legal privilege attached to this communication are not waived or lost by reason of the mistaken delivery to you.If you have received this message in error, please notify us immediately to Australia 61 (0)408 876 526 Dolores capitis non fero. Eos do. ________________________________________________________________________________
Date: Jan 03, 2006
My 500B has 18,000 hours on it. My rudder pulley brackets are cracked. Morris includes an inspection of them on his 100hr. inspection sheet. He informed me that when they manufactured the brackets, they folded them but didn't stress relieve the corners. He's seen multitudes of cracked ones, and he says even the ones that haven't been stop drilled only crack to a certain point. He says it's a problem he's been aware of only for the last 20 years or so. He is of the opinion that they probably cracked about 10 minutes after the airframe was built (ok, maybe a little longer than that). He's also mentioned that he's never *ever* seen or heard of one failing. I guess I'll just continue to keep an eye on my pulleys, and see if anything changes.... /John ----- Original Message ----- From: "W J R HAMILTON" <wjrhamilton(at)optusnet.com.au> Subject: Re: Commander-List: Slips / Rudder Pulley Brackets > > Steve, > That seems possible, as close as I can get to the brackets to see, > the original crack looks quite old, and the engineers who had been > looking after the aircraft for some years, before I bought it > indicated that they had not observed any change, but in those few > years the aircraft did only low annual hours. My total airframe time > is about 11,000, some of it on quite rough strips. > Cheers, > Bill Hamilton > > > At 00:57 3/01/2006, you wrote: > > > >Good morning Bill, > > > >The four cracks were nearly identical in length on ours, and we're > >monitoring also. We did put a tiny stop-drill on each, but seeing as they > >cracked to a certain point and no further, we're wondering if they perhaps > >become somewhat stable over time once that intital crack forms? > > > >Steve > CONFIDENTIALITY & PRIVILEGE NOTICE > W.J.R.Hamilton,Glenalmond Group Companies,Fighter Flights Internet > Services and Warbirds.Net. & . > This message is intended for and should only be used by the > addressee. It is confidential and may contain legally privileged > information.If you are not the intended recipient any use > distribution,disclosure or copying of this message is strictly > prohibited.Confidentiality and legal privilege attached to this > communication are not waived or lost by reason of the mistaken > delivery to you.If you have received this message in error, please > notify us immediately to Australia 61 (0)408 876 526 > Dolores capitis non fero. Eos do. > > ________________________________________________________________________________
Subject: Commander 680 FLP Fuel Cap
Date: Jan 04, 2006
Hello, I am trying to find a fuel cap for a Commander 680 FLP. I have a part number, "416-67" however I'm not sure if it's the right cap for my plane. The cap on the plane I fly is about 21/2" diameter with a zeus-fastener type screw head in the center. There is no latch to flip up. This "zeus fastner" connects with the flap mechanism in the top of the tank. The cap fits very flush with the top of the wing. The cap spring mechanism which holds pressure on the zeus connection is damaged. I had the parts guy at the local airport look through his parts computer but have not seen a cap like mine pictured. Even so, the price for those that had no picture and might have been the correct cap were asking $400,...a very high price for such a simple device. Does anyone out there know where I can get one. Thanks, Ray Mansfield N91ES Note: This plane may be up for sale soon. Not sure of asking price yet, there's a picture of this plane on this web site. ________________________________________________________________________________
Subject: Re: Commander 680 FLP Fuel Cap
Date: Jan 04, 2006
Hi Ray, If you're going to pay *that* much for an original fuel cap, you might as well pay a couple bucks more and get this cap that I just had installed on my airplane: http://www.commander-aero.com/caps.htm The folks at Commander Aero are great, too! If you want to scrounge an original cap and maybe save some $$, try Morris Kernick here in CA, Mason Chevailler (who posts on this list) or Jack Chappell or Harry Merritt, both in FL I think. I have Morris' contact info, 321-403-8813 but you'll have to depend on someone else here on the list for numbers etc. of the others. Good luck, /John ----- Original Message ----- From: "Ray Mansfield" <hcourier(at)cox.net> Subject: Commander-List: Commander 680 FLP Fuel Cap > > Hello, > > I am trying to find a fuel cap for a Commander 680 FLP. I have a part number, "416-67" however I'm not sure if it's the right cap for my plane. The cap on the plane I fly is about 21/2" diameter with a zeus-fastener type screw head in the center. There is no latch to flip up. This "zeus fastner" connects with the flap mechanism in the top of the tank. The cap fits very flush with the top of the wing. The cap spring mechanism which holds pressure on the zeus connection is damaged. > > I had the parts guy at the local airport look through his parts computer but have not seen a cap like mine pictured. Even so, the price for those that had no picture and might have been the correct cap were asking $400,...a very high price for such a simple device. > > Does anyone out there know where I can get one. > > Thanks, > > Ray Mansfield > N91ES > > Note: This plane may be up for sale soon. Not sure of asking price yet, there's a picture of this plane on this web site. > > ________________________________________________________________________________
Date: Jan 04, 2006
Subject: Fwd: 500A Cover and rudder brace
Date: Wed, 4 Jan 2006 20:06:15 -0800 (PST) From: Craig Lundborg <dltafolk(at)sbcglobal.net> Subject: 500A Cover and rudder brace --0-1153313962-1136433975=:61579 Hi gang, Can anyone direct me to a rudder stop and a canvas cover ....I am now the guy that is spotted at airports steering erradically and looking a little goofy trying to taxi in a straight line...how do you guys do it? Love my new bird and can't wait for the training time to pass so its pilot will look as good as the Commander. Craig Lundborg --0-1153313962-1136433975=:61579 Hi gang, Can anyone direct me to a rudder stop and a canvas cover ....I am now the guy that is spotted at airports steering erradically and looking a little goofy trying to taxi in a straight line...how do you guys do it? Love my new bird and can't wait for the training time to pass so its pilot will look as good as the Commander. Craig Lundborg --0-1153313962-1136433975=:61579-- ________________________________________________________________________________
Date: Jan 04, 2006
Craig: Congrats on your new acquisition! Commander Aero has rudder gust locks, although a number of owners have fashioned their own. Bruce's Custom Covers does canvas covers for your bird: http://www.aircraftcovers.com/ I looked at doing this but opted instead for heat shields from Cunningham: http://www.cunninghamcovers.com/ They make all the difference in Southern California heat. If you have any 500A specific questions, I may be able to help. Feel free to contact me any time. Mine is a Colemill Conversion, 1962 #1256-80. You can see more about mine at: http://akucheck.squarespace.com/ or contact me at: akucheck at gmail dot com Alan -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of YOURTCFG(at)aol.com Subject: Commander-List: Fwd: 500A Cover and rudder brace Date: Wed, 4 Jan 2006 20:06:15 -0800 (PST) From: Craig Lundborg <dltafolk(at)sbcglobal.net> Subject: 500A Cover and rudder brace --0-1153313962-1136433975=:61579 Hi gang, Can anyone direct me to a rudder stop and a canvas cover ....I am now the guy that is spotted at airports steering erradically and looking a little goofy trying to taxi in a straight line...how do you guys do it? Love my new bird and can't wait for the training time to pass so its pilot will look as good as the Commander. Craig Lundborg --0-1153313962-1136433975=:61579 Hi gang, Can anyone direct me to a rudder stop and a canvas cover ....I am now the guy that is spotted at airports steering erradically and looking a little goofy trying to taxi in a straight line...how do you guys do it? Love my new bird and can't wait for the training time to pass so its pilot will look as good as the Commander. Craig Lundborg --0-1153313962-1136433975=:61579-- -- -- ________________________________________________________________________________
Subject: Re: Fwd: 500A Cover and rudder brace
Date: Jan 04, 2006
Craig, The answer for control locks is again Commander Aero. http://www.commander-aero.com/locks.htm They have both internal and external. Some have made their own with some wood, a stick and a rubber chicken. Welcome to Flying and driving a Twin Commander. Anyone can fly a twin commander, but it takes about 100 hours to learn how to drive one. When I checked out in a Twin Commander, they forgot to tell me how to really drive it. The nose wheel on the short body commander has very little weight on it. It takes locking you knees and using your toes to lightly push on the upper part of the rudder peddles. It is a light touch to steer the nose wheel with out getting into the breaks. In a strong cross wind, she will want to weather vane into the wind. It take lots of differential power to make it go the direction you want it to go. Heavy on the up wind engine. I almost lost it into the weeds on a strong cross wind. I was turning left and it went right as it weather vaned on me. I did take it out on a windy day on a large ramp to just play with it, until I got the hang of steering and differential power. I was in Garden City, KS and had to taxi out to the only runway in winds that were steady at 25kts with gusts to 35 at 70 degrees to the runway. Once I got the differential power going and the speed up, it was easy to handle. Upwind power to get the speed up and once you get 40mph, it is all rudder and forget the steering. Have fun with your new bird. Tylor Hall > > > Date: Wed, 4 Jan 2006 20:06:15 -0800 (PST) > From: Craig Lundborg <dltafolk(at)sbcglobal.net> > Subject: 500A Cover and rudder brace > To: YourTCFG(at)aol.com > > > --0-1153313962-1136433975=:61579 > > Hi gang, > Can anyone direct me to a rudder stop and a canvas > cover ....I am now the guy that is spotted at airports steering > erradically and looking a little goofy trying to taxi in a straight > line...how do you guys do it? > Love my new bird and can't wait for the training time to > pass so its pilot will look as good as the Commander. > > Craig Lundborg > > --0-1153313962-1136433975=:61579 > > Hi gang, Can anyone direct me to a rudder stop and a canvas > cover ....I am now the guy that is spotted at airports steering > erradically and looking a little goofy trying to taxi in a straight > line...how do you guys do it? Love my new bird and can't wait for > the training time to pass so its pilot will look as good as the > Commander. Craig Lundborg > > --0-1153313962-1136433975=:61579-- > > ________________________________________________________________________________
Date: Jan 05, 2006
Subject: tax
what i do for taxes is to total the amount spent and divide that by the hours flown to get a cost per hour. that is around $400 per hour. i then keep records to show where i have flown and deduct on schedule c that amount that was for business. i suggest we put this on the commander web site to see what the others have to say. al hoffman n628ah this gets very complicated because i keep the aircraft in a corporation since i do not want the liability of the two other perople who operate the aircraft. in florida, the owner and the operator are both liable for any damage. i have a lien on the plane for all the money i advance for purchase and capital repairs. this is overly simple as there are other things i do to protect me from liability, but make taxes tough. under this system, i am liable for anything that happens when i am flying, but not when someone else is flying. any discussion or suggestions? what i do for taxes is to total the amount spent and divide that by the hours flown to get a cost per hour. that is around $400 per hour. i then keep records to show where i have flown and deduct on schedule c that amount that was for business. i suggest we put this on the commander web site to see what the others have to say. al hoffman n628ah this gets very complicated because i keep the aircraft in a corporation since i do not want the liability of the two other perople who operate the aircraft. in florida, the owner and the operator are both liable for any damage. i have a lien on the plane for all the money i advance for purchase and capital repairs. this is overly simple as there are other things i do to protect me from liability, but make taxes tough. under this system, i am liable for anything that happens when i am flying, but not when someone else is flying. any discussion or suggestions? ________________________________________________________________________________
Date: Jan 05, 2006
Craig, Congratulations, you will love your airplane. I will have had mine 25 years this coming April first. I have tried to trade it several times but have always after looking at it decided for my needs my 500A (Cont-IO-470's) was all I needed. If I can be of any help let me know. Jim Addington jtaddington(at)charter.net 940-566-2651 -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com]On Behalf Of YOURTCFG(at)aol.com Subject: Commander-List: Fwd: 500A Cover and rudder brace Date: Wed, 4 Jan 2006 20:06:15 -0800 (PST) From: Craig Lundborg <dltafolk(at)sbcglobal.net> Subject: 500A Cover and rudder brace --0-1153313962-1136433975=:61579 Hi gang, Can anyone direct me to a rudder stop and a canvas cover ....I am now the guy that is spotted at airports steering erradically and looking a little goofy trying to taxi in a straight line...how do you guys do it? Love my new bird and can't wait for the training time to pass so its pilot will look as good as the Commander. Craig Lundborg --0-1153313962-1136433975=:61579 Hi gang, Can anyone direct me to a rudder stop and a canvas cover ....I am now the guy that is spotted at airports steering erradically and looking a little goofy trying to taxi in a straight line...how do you guys do it? Love my new bird and can't wait for the training time to pass so its pilot will look as good as the Commander. Craig Lundborg --0-1153313962-1136433975=:61579-- ________________________________________________________________________________
Date: Jan 05, 2006
Jim, I owned a stock straight 500 and it appeared to outperform the A model. I once took a 500A up for a short flight and felt it should've done better compared to the 500 in terms of climb and cruise performance. The other thing was, of course, the reliability and TBO of the Lycomings. With the necessary soft-hand handling and care, we could take them well beyond the 2,000 hr TBO without top overhauls. I doubt whether Continentals would let you fly past 1,000 hours or so before requiring some sun light on the pistons. My recollection of the A's performance is admittedly wholly suspect, so your perception would be appreciated. Thanks Nico ----- Original Message ----- From: "Jim Addington" <jtaddington(at)charter.net> Subject: RE: Commander-List: Fwd: 500A Cover and rudder brace > > Craig, > Congratulations, you will love your airplane. I will have had mine 25 years > this coming April first. I have tried to trade it several times but have > always after looking at it decided for my needs my 500A (Cont-IO-470's) was > all I needed. If I can be of any help let me know. > Jim Addington > jtaddington(at)charter.net > 940-566-2651 > > -----Original Message----- > From: owner-commander-list-server(at)matronics.com > [mailto:owner-commander-list-server(at)matronics.com]On Behalf Of > YOURTCFG(at)aol.com > To: commander-list(at)matronics.com > Subject: Commander-List: Fwd: 500A Cover and rudder brace > > > Date: Wed, 4 Jan 2006 20:06:15 -0800 (PST) > From: Craig Lundborg <dltafolk(at)sbcglobal.net> > Subject: 500A Cover and rudder brace > To: YourTCFG(at)aol.com > > > --0-1153313962-1136433975=:61579 > > Hi gang, > Can anyone direct me to a rudder stop and a canvas cover ....I am > now the guy that is spotted at airports steering erradically and looking a > little goofy trying to taxi in a straight line...how do you guys do it? > Love my new bird and can't wait for the training time to pass so > its pilot will look as good as the Commander. > > Craig Lundborg > > --0-1153313962-1136433975=:61579 > > Hi gang, Can anyone direct me to a rudder stop and a canvas cover ....I > am now the guy that is spotted at airports steering erradically and looking > a little goofy trying to taxi in a straight line...how do you guys do it? > Love my new bird and can't wait for the training time to pass so its pilot > will look as good as the Commander. Craig Lundborg > > --0-1153313962-1136433975=:61579-- > > ________________________________________________________________________________
Date: Jan 06, 2006
Subject: Rudder Pulley Brackets
John, Thanks for that, your reply is reassuring, I will just keep the inspections going. Cheers, Bill Hamilton. At 13:47 4/01/2006, you wrote: > >My 500B has 18,000 hours on it. My rudder pulley brackets are cracked. >Morris includes an inspection of them on his 100hr. inspection sheet. He >informed me that when they manufactured the brackets, they folded them but >didn't stress relieve the corners. He's seen multitudes of cracked ones, and >he says even the ones that haven't been stop drilled only crack to a certain >point. He says it's a problem he's been aware of only for the last 20 years >or so. > >He is of the opinion that they probably cracked about 10 minutes after the >airframe was built (ok, maybe a little longer than that). He's also >mentioned that he's never *ever* seen or heard of one failing. > >I guess I'll just continue to keep an eye on my pulleys, and see if anything >changes.... > >/John CONFIDENTIALITY & PRIVILEGE NOTICE W.J.R.Hamilton,Glenalmond Group Companies,Fighter Flights Internet Services and Warbirds.Net. & . This message is intended for and should only be used by the addressee. It is confidential and may contain legally privileged information.If you are not the intended recipient any use distribution,disclosure or copying of this message is strictly prohibited.Confidentiality and legal privilege attached to this communication are not waived or lost by reason of the mistaken delivery to you.If you have received this message in error, please notify us immediately to Australia 61 (0)408 876 526 Dolores capitis non fero. Eos do. ________________________________________________________________________________
Date: Jan 06, 2006
Ray, Have a talk to a DER about replacing the cap with the more readily available types., and fit under a 337. The size of the fitting, PCD ( bolt circle diameter ) and number of fasteners coincides with a standard AN/Mil size, and they are available for around $50 or so, as a complete unit, receptacle and cap. Shaw Aero Devices is what I have used, it will look something like: http://cgi.ebay.com/ebaymotors/AIRCRAFT-FUEL-CAP-ASSEMBLY_W0QQitemZ4590621178QQcategoryZ26439QQssPageNameZWD1VQQrdZ1QQcmdZViewItem If the link doesn't work, the eBay item number is: 4590621178 [] And comes in various sizes, one of which fits my 500A like it's the original, for an un-vented cap. Cheers, Bill Hamilton At 12:41 5/01/2006, you wrote: > >Hello, > > I am trying to find a fuel cap for a Commander 680 FLP. I have > a part number, "416-67" however I'm not sure if it's the right cap > for my plane. The cap on the plane I fly is about 21/2" diameter > with a zeus-fastener type screw head in the center. There is no > latch to flip up. This "zeus fastner" connects with the flap > mechanism in the top of the tank. The cap fits very flush with the > top of the wing. The cap spring mechanism which holds pressure on > the zeus connection is damaged. > > I had the parts guy at the local airport look through his parts > computer but have not seen a cap like mine pictured. Even so, the > price for those that had no picture and might have been the correct > cap were asking $400,...a very high price for such a simple device. > > Does anyone out there know where I can get one. > > Thanks, > >Ray Mansfield >N91ES > >Note: This plane may be up for sale soon. Not sure of asking price >yet, there's a picture of this plane on this web site. > > CONFIDENTIALITY & PRIVILEGE NOTICE W.J.R.Hamilton,Glenalmond Group Companies,Fighter Flights Internet Services and Warbirds.Net. & . This message is intended for and should only be used by the addressee. It is confidential and may contain legally privileged information.If you are not the intended recipient any use distribution,disclosure or copying of this message is strictly prohibited.Confidentiality and legal privilege attached to this communication are not waived or lost by reason of the mistaken delivery to you.If you have received this message in error, please notify us immediately to Australia 61 (0)408 876 526 Dolores capitis non fero. Eos do. ________________________________________________________________________________
Date: Jan 06, 2006
Nico, I have only gotten to fly the 500A and 500B. I have heard that the 500 with the Lyc's does have a little more oomph, no substitute for Cubic inches. When you have not flown something with more power you don't miss it. I usually get 175 to 185 mph cruse but I have added so many extras on my plane that it is a little heavy and does not climb like it use to. I need to add some weight to the tail and get the CG back some which would help some on the cruse. I usually burn about 23 gals per hour total fuel. Jim -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com]On Behalf Of css nico Subject: Re: Commander-List: Fwd: 500A Cover and rudder brace Jim, I owned a stock straight 500 and it appeared to outperform the A model. I once took a 500A up for a short flight and felt it should've done better compared to the 500 in terms of climb and cruise performance. The other thing was, of course, the reliability and TBO of the Lycomings. With the necessary soft-hand handling and care, we could take them well beyond the 2,000 hr TBO without top overhauls. I doubt whether Continentals would let you fly past 1,000 hours or so before requiring some sun light on the pistons. My recollection of the A's performance is admittedly wholly suspect, so your perception would be appreciated. Thanks Nico ----- Original Message ----- From: "Jim Addington" <jtaddington(at)charter.net> Subject: RE: Commander-List: Fwd: 500A Cover and rudder brace > > Craig, > Congratulations, you will love your airplane. I will have had mine 25 years > this coming April first. I have tried to trade it several times but have > always after looking at it decided for my needs my 500A (Cont-IO-470's) was > all I needed. If I can be of any help let me know. > Jim Addington > jtaddington(at)charter.net > 940-566-2651 > > -----Original Message----- > From: owner-commander-list-server(at)matronics.com > [mailto:owner-commander-list-server(at)matronics.com]On Behalf Of > YOURTCFG(at)aol.com > To: commander-list(at)matronics.com > Subject: Commander-List: Fwd: 500A Cover and rudder brace > > > Date: Wed, 4 Jan 2006 20:06:15 -0800 (PST) > From: Craig Lundborg <dltafolk(at)sbcglobal.net> > Subject: 500A Cover and rudder brace > To: YourTCFG(at)aol.com > > > --0-1153313962-1136433975=:61579 > > Hi gang, > Can anyone direct me to a rudder stop and a canvas cover ....I am > now the guy that is spotted at airports steering erradically and looking a > little goofy trying to taxi in a straight line...how do you guys do it? > Love my new bird and can't wait for the training time to pass so > its pilot will look as good as the Commander. > > Craig Lundborg > > --0-1153313962-1136433975=:61579 > > Hi gang, Can anyone direct me to a rudder stop and a canvas cover ....I > am now the guy that is spotted at airports steering erradically and looking > a little goofy trying to taxi in a straight line...how do you guys do it? > Love my new bird and can't wait for the training time to pass so its pilot > will look as good as the Commander. Craig Lundborg > > --0-1153313962-1136433975=:61579-- > > ________________________________________________________________________________
Subject: Re: FLAPS
Date: Jan 06, 2006
There is a AD 73-06-02 that requires the aircraft to have the type you lost! You aircraft will not be airworthy if you change the fuel cap and receptacle. I have a use cap. jack has some new ones. also check AD 87-21-07 Thanks Harry 321 267-3141 ----- Original Message ----- From: "Tom Fisher" <tfisher(at)commandergroup.bc.ca> Subject: Re: Commander-List: FLAPS > > > The Cloud Craft Manual is an excellent document! > Tom F. > > ----- Original Message ----- > From: "Moe" <moe(at)rosspistons.com> > To: > Subject: Re: Commander-List: FLAPS > > >> >> Mason, >> >> What is a Cloud Craft Manual? >> >> MM >> ----- Original Message ----- >> From: "MASON CHEVAILLIER" <KAMALA(at)msn.com> >> To: >> Subject: Re: Commander-List: FLAPS >> >> > >> > >> > MM, ACCORDING TO MY CLOUD CRAFT MANUAL, MAX SPEED FOR 1/2 FLAPS IS 150 >> MPH/130 KTS. AND FULL FLAPS 146 MPH/129 KTS. MASON >> > ----- Original Message ----- >> > From: Moe<mailto:moe(at)rosspistons.com> >> > To: commander-list(at)matronics.com >> > Sent: Thursday, December 29, 2005 10:52 AM >> > Subject: Commander-List: FLAPS >> > >> > >> > >> > >> > Hi Folks: >> > >> > As I understand it, the beginning of the white arc on the air speed >> indicator is the point where maximum flaps can be deployed. Does anyone >> have reliable information (or a chart) as to what speed partial flaps can > be >> let down on a 680F(p)? >> > >> > It seems that ATC keeps holding me higher and higher until later, and >> getting down with geared engines can be most challenging. >> > >> > Regards, >> > >> > Moe Mills >> > N680RR >> > 680F(p) >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> >> >> >> >> >> >> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Jan 07, 2006
I have had IO-470's in other aircraft and always found the engines sound but you don't overheat or overwork them and the cylinders will stay the course. Of course i always give a little more fuel on cruise as they really need their body fluids for cooling...and that starts the "Lean of Peak" argument. P-Punk has a STC for installing the 520 cylinders on the block and is quite successful....but it only applies to the 0-470...I wonder why it won't work on injected? Craig css nico wrote: Jim, I owned a stock straight 500 and it appeared to outperform the A model. I once took a 500A up for a short flight and felt it should've done better compared to the 500 in terms of climb and cruise performance. The other thing was, of course, the reliability and TBO of the Lycomings. With the necessary soft-hand handling and care, we could take them well beyond the 2,000 hr TBO without top overhauls. I doubt whether Continentals would let you fly past 1,000 hours or so before requiring some sun light on the pistons. My recollection of the A's performance is admittedly wholly suspect, so your perception would be appreciated. Thanks Nico ----- Original Message ----- From: "Jim Addington" Subject: RE: Commander-List: Fwd: 500A Cover and rudder brace > > Craig, > Congratulations, you will love your airplane. I will have had mine 25 years > this coming April first. I have tried to trade it several times but have > always after looking at it decided for my needs my 500A (Cont-IO-470's) was > all I needed. If I can be of any help let me know. > Jim Addington > jtaddington(at)charter.net > 940-566-2651 > > -----Original Message----- > From: owner-commander-list-server(at)matronics.com > [mailto:owner-commander-list-server(at)matronics.com]On Behalf Of > YOURTCFG(at)aol.com > To: commander-list(at)matronics.com > Subject: Commander-List: Fwd: 500A Cover and rudder brace > > > Date: Wed, 4 Jan 2006 20:06:15 -0800 (PST) > From: Craig Lundborg > Subject: 500A Cover and rudder brace > To: YourTCFG(at)aol.com > > > --0-1153313962-1136433975=:61579 > > Hi gang, > Can anyone direct me to a rudder stop and a canvas cover ....I am > now the guy that is spotted at airports steering erradically and looking a > little goofy trying to taxi in a straight line...how do you guys do it? > Love my new bird and can't wait for the training time to pass so > its pilot will look as good as the Commander. > > Craig Lundborg > > --0-1153313962-1136433975=:61579 > > Hi gang, Can anyone direct me to a rudder stop and a canvas cover ....I > am now the guy that is spotted at airports steering erradically and looking > a little goofy trying to taxi in a straight line...how do you guys do it? > Love my new bird and can't wait for the training time to pass so its pilot > will look as good as the Commander. Craig Lundborg > > --0-1153313962-1136433975=:61579-- > > ________________________________________________________________________________
Date: Jan 07, 2006
Jim, After ticking off the traffic at the airport by taxing for a couple of hours ...The first take-off re-enforced all my desires to own a Commander. She may not be all powerfull but after I get a couple of bugs out of her because of non use, I am very pleased with the bird. Craig Jim Addington wrote: Craig, Congratulations, you will love your airplane. I will have had mine 25 years this coming April first. I have tried to trade it several times but have always after looking at it decided for my needs my 500A (Cont-IO-470's) was all I needed. If I can be of any help let me know. Jim Addington jtaddington(at)charter.net 940-566-2651 -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com]On Behalf Of YOURTCFG(at)aol.com Subject: Commander-List: Fwd: 500A Cover and rudder brace Date: Wed, 4 Jan 2006 20:06:15 -0800 (PST) From: Craig Lundborg Subject: 500A Cover and rudder brace --0-1153313962-1136433975=:61579 Hi gang, Can anyone direct me to a rudder stop and a canvas cover ....I am now the guy that is spotted at airports steering erradically and looking a little goofy trying to taxi in a straight line...how do you guys do it? Love my new bird and can't wait for the training time to pass so its pilot will look as good as the Commander. Craig Lundborg --0-1153313962-1136433975=:61579 Hi gang, Can anyone direct me to a rudder stop and a canvas cover ....I am now the guy that is spotted at airports steering erradically and looking a little goofy trying to taxi in a straight line...how do you guys do it? Love my new bird and can't wait for the training time to pass so its pilot will look as good as the Commander. Craig Lundborg --0-1153313962-1136433975=:61579-- ________________________________________________________________________________
Date: Jan 07, 2006
In a message dated 1/7/2006 9:29:57 A.M. Central Standard Time, dltafolk(at)sbcglobal.net writes: Congratulations, you will love your airplane. I will have had mine 25 years this coming April first. I have tried to trade it several times but have always after looking at it decided for my needs my 500A (Cont-IO-470's) was all I needed. If I can be of any help let me know. Jim Addington Good Morning Jim, Just out of curiosity, has anyone replaced the O-470s with IO-550 engines? I have heard some rumors that Colemill has offered a conversion that uses the sand cast case of the 470 and has Continental build up a 550 version thereof. That would be nice, but I think the full factory Permold case 550 would be fabulous on your airplane. The engine should fit right in the same spot, weigh less and develop a lot more power. We have made that change in our J35 Bonanza and it is the best money I ever spent on an airplane. From my memory of flying the early 520 Commanders, I believe the combination of the early light weight airframe and the IO-550 would be a beautiful machine. Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator Stearman N3977A Brookeridge Air Park LL22 Downers Grove, IL 60516 630 985-8503 ________________________________________________________________________________
Date: Jan 07, 2006
For a while I had both an Aero Commander and a Piper Twin Comanche, another bird I loved to fly. The logic was that when I travel alone or with only one pax, I would jump into the Comanche. If the trip is to be an extended one with two or more pax, I would use the Commander. It only held true for a little while. For some reason the Commander got the additional avionics and hence, the additional rides. So, the Comanche, eventually, left the stable. :-) It's just the way it is. Nico ----- Original Message ----- From: "Craig Lundborg" <dltafolk(at)sbcglobal.net> Subject: RE: Commander-List: Fwd: 500A Cover and rudder brace > > Jim, > After ticking off the traffic at the airport by taxing for a couple of hours ...The first take-off re-enforced all my desires to own a Commander. > She may not be all powerfull but after I get a couple of bugs out of her because of non use, I am very pleased with the bird. > > Craig > > Jim Addington wrote: > > Craig, > Congratulations, you will love your airplane. I will have had mine 25 years > this coming April first. I have tried to trade it several times but have > always after looking at it decided for my needs my 500A (Cont-IO-470's) was > all I needed. If I can be of any help let me know. > Jim Addington > jtaddington(at)charter.net > 940-566-2651 > > -----Original Message----- > From: owner-commander-list-server(at)matronics.com > [mailto:owner-commander-list-server(at)matronics.com]On Behalf Of > YOURTCFG(at)aol.com > To: commander-list(at)matronics.com > Subject: Commander-List: Fwd: 500A Cover and rudder brace > > > Date: Wed, 4 Jan 2006 20:06:15 -0800 (PST) > From: Craig Lundborg > Subject: 500A Cover and rudder brace > To: YourTCFG(at)aol.com > > > --0-1153313962-1136433975=:61579 > > Hi gang, > Can anyone direct me to a rudder stop and a canvas cover ....I am > now the guy that is spotted at airports steering erradically and looking a > little goofy trying to taxi in a straight line...how do you guys do it? > Love my new bird and can't wait for the training time to pass so > its pilot will look as good as the Commander. > > Craig Lundborg > > --0-1153313962-1136433975=:61579 > > Hi gang, Can anyone direct me to a rudder stop and a canvas cover ....I > am now the guy that is spotted at airports steering erradically and looking > a little goofy trying to taxi in a straight line...how do you guys do it? > Love my new bird and can't wait for the training time to pass so its pilot > will look as good as the Commander. Craig Lundborg > > --0-1153313962-1136433975=:61579-- > > ________________________________________________________________________________
Date: Jan 07, 2006
Subject: ebay item
Hello folks, Enviro systems flow valve part no. 1300490 ser 301 new. Info says it is a pressurization valve for a twinn commander. At this time it is $67.00 including shipping. Roland Gilliam TC 500 (North Carolina) ________________________________________________________________________________
Subject: Taxiing
Date: Jan 07, 2006
Craig, Where do you live? Jim Addington N444BD ________________________________________________________________________________
Subject: Re: Taxiing
Date: Jan 07, 2006
Craig, You should be on the Aero Commander Frappr Map so Jim can find you: http://www.frappr.com/aerocommander Post some pictures, too. Ben ----- Original Message ----- From: Jim Addington To: jtaddington(at)charter.net Sent: Saturday, January 07, 2006 10:46 PM Subject: Commander-List: Taxiing Craig, Where do you live? Jim Addington N444BD ________________________________________________________________________________
Date: Jan 07, 2006
Hello Old Bob, I am not as up to date as some of the other people on the group but I don't know of the conversion however Colemill would sure be a good place to start looking. Jim N444BD -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com]On Behalf Of BobsV35B(at)aol.com Subject: Re: Commander-List: Fwd: 500A Cover and rudder brace In a message dated 1/7/2006 9:29:57 A.M. Central Standard Time, dltafolk(at)sbcglobal.net writes: Congratulations, you will love your airplane. I will have had mine 25 years this coming April first. I have tried to trade it several times but have always after looking at it decided for my needs my 500A (Cont-IO-470's) was all I needed. If I can be of any help let me know. Jim Addington Good Morning Jim, Just out of curiosity, has anyone replaced the O-470s with IO-550 engines? I have heard some rumors that Colemill has offered a conversion that uses the sand cast case of the 470 and has Continental build up a 550 version thereof. That would be nice, but I think the full factory Permold case 550 would be fabulous on your airplane. The engine should fit right in the same spot, weigh less and develop a lot more power. We have made that change in our J35 Bonanza and it is the best money I ever spent on an airplane. From my memory of flying the early 520 Commanders, I believe the combination of the early light weight airframe and the IO-550 would be a beautiful machine. Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator Stearman N3977A Brookeridge Air Park LL22 Downers Grove, IL 60516 630 985-8503 ________________________________________________________________________________
Date: Jan 08, 2006
We are in the heart of the California Delta...The bird rests at C-83 (Byron) www.LundborgLanding.com is where we work and live...This "fishing hole" is considered one of the top three in America! Craig Jim Addington wrote: Craig, Where do you live? Jim Addington N444BD ________________________________________________________________________________
Date: Jan 08, 2006
Wow, hi Craig, I didn't know you were in the Delta. I'm based at PAO but spend a lot of time in Discovery Bay, and land at Byron often. I'll have to look you up the next time I'm out there...or at least take a peek at your airplane! Cheers, /John ----- Original Message ----- From: "Craig Lundborg" <dltafolk(at)sbcglobal.net> Subject: Re: Commander-List: Taxiing > > We are in the heart of the California Delta...The bird rests at C-83 (Byron) > > www.LundborgLanding.com is where we work and live...This "fishing hole" is considered one of the top three in America! > > Craig > > Jim Addington wrote: > > > Craig, > Where do you live? > > Jim Addington > N444BD > > ________________________________________________________________________________
Subject: Taxiing
Date: Jan 08, 2006
I was afraid of that, if you weren't so far away I would have been glad to have given you some free instruction. Jim Addington N444BD -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com]On Behalf Of Craig Lundborg Subject: Re: Commander-List: Taxiing We are in the heart of the California Delta...The bird rests at C-83 (Byron) www.LundborgLanding.com is where we work and live...This "fishing hole" is considered one of the top three in America! Craig Jim Addington wrote: Craig, Where do you live? Jim Addington N444BD ________________________________________________________________________________
Date: Jan 08, 2006
Good Evening John, As long as we are locating folks, is your Commander the one parked right at the end of the row which we taxi past after every landing? Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator Stearman N3977A Brookeridge Air Park LL22 Downers Grove, IL 60516 630 985-8503 In a message dated 1/8/2006 6:22:00 P.M. Central Standard Time, john(at)vormbaum.com writes: I didn't know you were in the Delta. I'm based at PAO but spend a lot of time in Discovery Bay, and land at Byron often. I'll have to look you up the next time I'm out there...or at least take a peek at your airplane! Cheers, /John ________________________________________________________________________________
Date: Jan 08, 2006
Well, Bob, I'm a long way from Brookeridge ;-) but if you've been to PAO there's Paul Seipp (who, although a friend, grumpily ignores us TCFG folks), he owns the white/burgundy 500U at the very end of Charlie row (which you would taxi past), and I own the white/blue/gray 500B in the 2nd-from-the-end spot on Foxtrot row, which you would only taxi past if you were taxiing back for takeoff or going through the runup area. Of course, you wouldn't have seen my airplane since early October as it's had a Grand Annual inculding the installation of much new equipment. She's ready to fly & all signed off, but I'm in no hurry to get her out of that nice warm hangar of Morris' and subject her to the weather we've been having.... Are you now on the west coast, or do you get here regularly? Cheers, /John ----- Original Message ----- From: <BobsV35B(at)aol.com> Subject: Re: Commander-List: Taxiing > > > Good Evening John, > > As long as we are locating folks, is your Commander the one parked right at > the end of the row which we taxi past after every landing? > > Happy Skies, > > Old Bob > AKA > Bob Siegfried > Ancient Aviator > Stearman N3977A > Brookeridge Air Park LL22 > Downers Grove, IL 60516 > 630 985-8503 > > > In a message dated 1/8/2006 6:22:00 P.M. Central Standard Time, > john(at)vormbaum.com writes: > > I didn't know you were in the Delta. I'm based at PAO but spend a lot of > time in Discovery Bay, and land at Byron often. I'll have to look you up the > next time I'm out there...or at least take a peek at your airplane! > > Cheers, > > /John > > ________________________________________________________________________________
Date: Jan 08, 2006
Subject: Taxiing
Jim, I have found the answer to the taxi...practice and more practice...I told my wife I must go out and fly each day for her comfort and safety...so far it has worked, I was in Morris' back yard in SCK to get my props balanced the 10,000 foot runway makes it look like I am doing short field landings and it gave me almost two miles each way to taxi...it does get better! Craig Jim Addington wrote: I was afraid of that, if you weren't so far away I would have been glad to have given you some free instruction. Jim Addington N444BD -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com]On Behalf Of Craig Lundborg Subject: Re: Commander-List: Taxiing We are in the heart of the California Delta...The bird rests at C-83 (Byron) www.LundborgLanding.com is where we work and live...This "fishing hole" is considered one of the top three in America! Craig Jim Addington wrote: Craig, Where do you live? Jim Addington N444BD ________________________________________________________________________________
Date: Jan 09, 2006
Subject: All New BBS Interface For Matronics List Forums!
Dear Listers, I'm very proud to announce a completely new BBS interface is now available for all of the Email Lists at Matronics! This is a full-featured system that allows for viewing, posting, attachments, polls - the works. But the best part is that it is *completely* integrated with all of the existing email tools currently available at Matronics! What this means at the most basic level is that, if you post a message to List from Email in the traditional way, it will show up on the BBS system *and* get distributed to everyone currently subscribed to the Email List. By the same token, if you are on the BBS and post a message to a given List-Forum, the message will not only show up on the BBS, but also be distributed to everyone on the Email List!! It is really a very nice implementation and I am very pleased with its operation. All of the tools you have come to know and love such as the List Search Engine and List Browse and Download will still be available and contain all of the latest posts. Think of the new BBS interface as just another method of accessing the all of the Lists. You can use the BBS to view all of the latest posts without having to do anything except use your browser to surf over to the site. You can view and look at all of the various List's posts. If you want to post a new message or reply to an existing message from the BBS, you will have to Register on the BBS. This is a *very* simple process and will only take a couple of minutes. There is a small icon in the upper righthand side of the main BBS page labeled "Register" to get you started. I strongly recommend that you use the exact *same* email address you are subscribed to the Email Lists with when registering on the BBS. Also, while not an absolute requirement, I would really appreciate it if people would use their full name when choosing their Username on the BBS (for example "Matt Dralle"). This just makes it easier for everyone to know who's posting. Also, I have enabled the ability to upload a small user picture with your profile called an "avatar". Please use a *real* picture of yourself *with* your cloths on! Thank you! Maximum size of the bitmap is 120x120. You can either be subscribed to the BBS, or any number of Email Lists, or both. Registering on the BBS will allow you to email directly to all of the various Lists. However, to receive direct List Email, you will need to be *subscribed* to the various Lists as you have in the past. No changes here in operation. I have added numerous links on the BBS pointing to the Email List subscription page. I've had the BBS connected to the Lists for about a week now, so its already loaded up with a fair number of messages. You can post photos and other documents directly to the BBS and links to them will appear in the List Email distributions. Also, when any messages posted to the BBS are viewed in the List Email distribution, there will be a URL link at the bottom of the message pointing back to the BBS. And here's what you've been waiting for -- the main URL for the new Matronics Email List BBS is: http://forums.matronics.com Please surf on over, Register, and have a great time! I think this will be the dawn of a whole new era for the Lists at Matronics! Best regards, Matt Dralle Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Jan 10, 2006
Subject: Re: All New BBS Interface For Matronics List Forums!
My name is Donnie Rose and am the proud new owner of 69PT. Greetings everyone! --- Matt Dralle wrote: > > > > > Dear Listers, > > I'm very proud to announce a completely new BBS > interface is now available for all of the Email > Lists at Matronics! This is a full-featured system > that allows for viewing, posting, attachments, polls > - the works. > > But the best part is that it is *completely* > integrated with all of the existing email tools > currently available at Matronics! What this means > at the most basic level is that, if you post a > message to List from Email in the traditional way, > it will show up on the BBS system *and* get > distributed to everyone currently subscribed to the > Email List. By the same token, if you are on the > BBS and post a message to a given List-Forum, the > message will not only show up on the BBS, but also > be distributed to everyone on the Email List!! > > It is really a very nice implementation and I am > very pleased with its operation. All of the tools > you have come to know and love such as the List > Search Engine and List Browse and Download will > still be available and contain all of the latest > posts. Think of the new BBS interface as just > another method of accessing the all of the Lists. > > You can use the BBS to view all of the latest posts > without having to do anything except use your > browser to surf over to the site. You can view and > look at all of the various List's posts. If you > want to post a new message or reply to an existing > message from the BBS, you will have to Register on > the BBS. This is a *very* simple process and will > only take a couple of minutes. There is a small > icon in the upper righthand side of the main BBS > page labeled "Register" to get you started. > > I strongly recommend that you use the exact *same* > email address you are subscribed to the Email Lists > with when registering on the BBS. Also, while not > an absolute requirement, I would really appreciate > it if people would use their full name when choosing > their Username on the BBS (for example "Matt > Dralle"). This just makes it easier for everyone to > know who's posting. Also, I have enabled the > ability to upload a small user picture with your > profile called an "avatar". Please use a *real* > picture of yourself *with* your cloths on! Thank > you! Maximum size of the bitmap is 120x120. > > You can either be subscribed to the BBS, or any > number of Email Lists, or both. Registering on the > BBS will allow you to email directly to all of the > various Lists. However, to receive direct List > Email, you will need to be *subscribed* to the > various Lists as you have in the past. No changes > here in operation. I have added numerous links on > the BBS pointing to the Email List subscription > page. > > I've had the BBS connected to the Lists for about a > week now, so its already loaded up with a fair > number of messages. You can post photos and other > documents directly to the BBS and links to them will > appear in the List Email distributions. Also, when > any messages posted to the BBS are viewed in the > List Email distribution, there will be a URL link at > the bottom of the message pointing back to the BBS. > > And here's what you've been waiting for -- the main > URL for the new Matronics Email List BBS is: > > http://forums.matronics.com > > Please surf on over, Register, and have a great > time! I think this will be the dawn of a whole new > era for the Lists at Matronics! > > Best regards, > > Matt Dralle > > > > > > > > > Matt G Dralle | Matronics | PO Box 347 | Livermore | > CA | 94551 > 925-606-1001 V | 925-606-6281 F | > dralle(at)matronics.com Email > http://www.matronics.com/ WWW | Featuring Products > For Aircraft > > > > > > > > browse > Subscriptions page, > FAQ, > http://www.matronics.com/Navigator?Commander-List > > Admin. > > > > > > > > > > Donnie Rose 205/492-8444 ________________________________________________________________________________
Date: Jan 10, 2006
Try Byerly Aviation I just sold 2 of them to Byerly on E bay. They got a great deal maybe they will pass it on to you. [Idea] -------- Milt N395V F1 Rocket Read this topic online here: http://forums.matronics.com/viewtopic.php?p=2553#2553 ________________________________________________________________________________
Subject: Re: Geared engined Commanders
Date: Jan 10, 2006
> Geared, Supercharged & Fuel Injected: > 680F; 680F(P); 680FL; 680FLP; 685. Barry not to be a nitpicker but the 520Ks are turbocharged not supercharged and they are also intercooled. :) To expand upon Wing Commander Gordon's comment about the 520Ks consuming 3 jugs a year I think a more accurate measure would be 3 cylinders per engine for every 700-900 hrs flown. These beasts are putting out 435HP each on only 520CID (.84HP/CI) Thats a lot to ask from an aircooled engine running overboost especially when 870HP total is really inadequate for that particular airframe. With graphic engine analyzers and judicious lean of peak ops you can extend the life a little and only consume 2 jugs each 900 hrs+-. This costs a bit at the top end in performance and saves about 3GPH per side. -------- Milt N395V F1 Rocket Read this topic online here: http://forums.matronics.com/viewtopic.php?p=2562#2562 Attachments: http://forums.matronics.com//files/airborne4_842.jpg ________________________________________________________________________________
Subject: Re: Commander decent
Date: Jan 10, 2006
I would frequently slip the 685 in any flap configuration. ATC always treated me like a turbine and gave rapid descents from the Flight levels leaving me to scurry to get down to initial approach altitudes and speeds. At all flap and gear configurations I had good control and good rudder authority. Even went high once and pulled back into a flaps down stall while slipping. The plane recovered itself. Nothing squirrly. Both airspeed indicators (pitots R & L) always registered the same no matter the direction of slip. I tried to avoid slips on final approach as I have absolutely no idea how it would behave if you lost an engine so close to VMC and dirty. Never had the balls to pull an engine while slow and doing a slip. Did this once in a 310 and ended up on my back with a helluva sink rate. The thought of 9000 pounds on it's back and slow was just more than I could stomach. During rapid descents I would also pull the props back to 1500-1600 RPM and keep MP up to whatever was needed to keep the engine loading the prop. Many "geared engine gurus" advised against this but questioning them usually revealed that their experience in geared engines was obtained flying coffee mugs in hangars with other coffee mug experts. I am also not a believer in shock cooling and never experienced it on the engine monitors when pulling power at altitude. Especially when running LOP. I saw much more rapid cooling in cruise when plowing through heavy rain than with rapid or prolonged power reductions. -------- Milt N395V F1 Rocket Driver Read this topic online here: http://forums.matronics.com/viewtopic.php?p=2578#2578 ________________________________________________________________________________
Date: Jan 10, 2006
Boy I love this format. Now I can easily be an expert on all the lists for all the planes I fly/have flown. One stop shopping. -------- Milt N395V F1 Rocket Driver Read this topic online here: http://forums.matronics.com/viewtopic.php?p=2584#2584 ________________________________________________________________________________
Date: Jan 10, 2006
"Top Secret" at twincommanderflyer.com This is Classified information and must not be mentioned in any way shape or form to anyone. -------------- Original message -------------- From: "Milt" <N395V(at)direcway.com> > > I would frequently slip the 685 in any flap configuration. ATC always treated me > like a turbine and gave rapid descents from the Flight levels leaving me to > scurry to get down to initial approach altitudes and speeds. > > At all flap and gear configurations I had good control and good rudder > authority. > > Even went high once and pulled back into a flaps down stall while slipping. The > plane recovered itself. Nothing squirrly. > > Both airspeed indicators (pitots R & L) always registered the same no matter the > direction of slip. I tried to avoid slips on final approach as I have > absolutely no idea how it would behave if you lost an engine so close to VMC and > dirty. Never had the balls to pull an engine while slow and doing a slip. Did > this once in a 310 and ended up on my back with a helluva sink rate. The thought > of 9000 pounds on it's back and slow was just more than I could stomach. > > During rapid descents I would also pull the props back to 1500-1600 RPM and keep > MP up to whatever was needed to keep the engine loading the prop. > > Many "geared engine gurus" advised against this but questioning them usually > revealed that their experience in geared engines was obtained flying coffee mugs > in hangars with other coffee mug experts. > > I am also not a believer in shock cooling and never experienced it on the engine > monitors when pulling power at altitude. Especially when running LOP. I saw much > more rapid cooling in cruise when plowing through heavy rain than with rapid or > prolonged power reductions. > > -------- > Milt > N395V > F1 Rocket Driver > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=2578#2578 > > > > > > > > > > > > > > > > > "Top Secret" at twincommanderflyer.com This isClassified information and must not be mentioned in any way shape or form to anyone. -------------- Original message -------------- From: "Milt" N395V(at)direcway.com -- Commander-List message posted by: "Milt" I would frequently slip the 685 in any flap configuration. ATC always treated me like a turbine and gave rapid descents from the Flight levels leaving me to scurry to get down to initial approach altitudes and speeds. At all flap and gear configurations I had good control and good rudder authority. Even went high once and pulled back into a flaps down stall while slipping. The plane recovered itself. Nothing squirrly. Both airspeed indicators (pitots R L) always registered the same no matter the direction of slip. I tried to avoid slips on final approach as I have absolutely no idea how it w ould behave if you lost an engine so close to VMC and dirty. Never had the balls to pull an engine while slow and doing a slip. Did this once in a 310 and ended up on my back with a helluva sink rate. The thought of 9000 pounds on it's back and slow was just more than I could stomach. During rapid descents I would also pull the props back to 1500-1600 RPM and keep MP up to whatever was needed to keep the engine loading the prop. Many "geared engine gurus" advised against this but questioning them usually revealed that their experience in geared engines was obtained flying coffee mugs in hangars with other coffee mug experts. I am also not a believer in shock cooling and never experienced it on the engine monitors when pulling power at altitude. Especially when running LOP. I saw much more rapid cooling in cruise when plowing through heavy rain than wi th rapid or prolonged power reductions. -------- Milt N395V F1 Rocket Driver Read this topic online here: http://forums.matronics.com/viewtopic.php?p=2578#2578 Matt Dralle, List Admin. ________________________________________________________________________________
Subject: What is this???
Date: Jan 10, 2006
-------- Milt N395V F1 Rocket Driver Read this topic online here: http://forums.matronics.com/viewtopic.php?p=2641#2641 ________________________________________________________________________________
Date: Jan 10, 2006
In a message dated 1/10/2006 10:54:54 A.M. Pacific Standard Time, N395V(at)direcway.com writes: Milt Milt, great to hear from you!! How is life?? jb ________________________________________________________________________________
Date: Jan 11, 2006
Life is good. Like you I am approaching retirement and trying to figure out what to do and how to survive financially and still fly. I now fly a homebuilt and live on the rocket and RV forums. This new format really provides easy access to all the forums so I thought I would drop in and provide some comic relief/greif for awhile. -------- Milt N395V F1 Rocket Driver Read this topic online here: http://forums.matronics.com/viewtopic.php?p=2838#2838 Attachments: http://forums.matronics.com//files/dcp_1184_127.jpg ________________________________________________________________________________
Date: Jan 11, 2006
In a message dated 1/11/2006 7:36:27 AM Central Standard Time, N395V(at)direcway.com writes: so I thought I would drop in and provide some comic relief/greif for awhile Great to hear. I look forward to you sharing your pearls of wisdom with the group!! Fly safe. jb ________________________________________________________________________________
Subject: GSO-480 Overhaul
Date: Jan 11, 2006
Anyone know what factory rebuilts are running these days? Any problems getting parts? Thanks... S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=2966#2966 ________________________________________________________________________________
Date: Jan 11, 2006
Subject: Re: GSO-480 Overhaul
captseth wrote: > Anyone know what factory (GSO-480) rebuilts are running these days? Sure hope you're joking or you're going to be in for a terrible disapointment.... Hit the junk yards and try to find parts that are less worn out than what you've got..... cs ________________________________________________________________________________
Date: Jan 11, 2006
So you're saying that if you pop a jug or trash a gearbox lycoming doesn't stock parts? Not entirely unexpected, but I am trying to determine the viability of this powerplant. Of course, if you have to overhaul the thing and you can't get a piston pin that you need, all is for naught. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=2998#2998 ________________________________________________________________________________
Date: Jan 11, 2006
captseth wrote: > > So you're saying that if you pop a jug or trash a gearbox lycoming doesn't stock parts? Unfortunatly, that's the case. Lycoming no longer supports many of the oldest engines including the radials and GO series. There are a few shops left that will overhaul them, but there are fewer every day. We used to have several very good shops in the tulsa area that specialized in geared lycs, but they've all dropped those over the last 10 years or so due to lack of parts. Once in a while you can find some NOS parts, but mostly you're just looking at "is it better than what I've got" these days. Central Cylinder still does quite a bit of work on those engines and probably has more parts than anyone. You might give George Czarneki a call and see what they can do. Bottom line is that you're not going to get a "new limits" quality overhaul or many new parts. bummer - I think that if Lyc had kept progressing on the GSO-480 that it could have been the engine of choice for many modern designs too.... Chris ________________________________________________________________________________
Date: Jan 11, 2006
$22,000.00 in ft lauderdale.includes mags harnesses Air Mark Harry ----- Original Message ----- From: "Chris Schuermann" <cschuerm(at)cox.net> Sent: Wednesday, January 11, 2006 2:53 PM Subject: Re: Commander-List: GSO-480 Overhaul > > > > captseth wrote: >> Anyone know what factory (GSO-480) rebuilts are running these days? > > Sure hope you're joking or you're going to be in for a terrible > disapointment.... > Hit the junk yards and try to find parts that are less worn out than > what you've got..... > > cs > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jan 11, 2006
Se habla Espaniol??? Guermo -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of avtec2(at)bellsouth.net Sent: Wednesday, January 11, 2006 3:33 PM Subject: Re: Commander-List: GSO-480 Overhaul $22,000.00 in ft lauderdale.includes mags harnesses Air Mark Harry ----- Original Message ----- From: "Chris Schuermann" <cschuerm(at)cox.net> Sent: Wednesday, January 11, 2006 2:53 PM Subject: Re: Commander-List: GSO-480 Overhaul > > > > captseth wrote: >> Anyone know what factory (GSO-480) rebuilts are running these days? > > Sure hope you're joking or you're going to be in for a terrible > disapointment.... > Hit the junk yards and try to find parts that are less worn out than > what you've got..... > > cs > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jan 12, 2006
Subject: Re: Commander 680 FLP Fuel Cap
Capt Milt! Great to catch you on the email string again! When are you visiting the Topend of Oz? Best regards from Oz Russell On 11/1/06 11:05 PM, "N395V" wrote: > > Life is good. Like you I am approaching retirement and trying to figure out > what to do and how to survive financially and still fly. > > I now fly a homebuilt and live on the rocket and RV forums. This new format > really provides easy access to all the forums so I thought I would drop in and > provide some comic relief/greif for awhile. > > -------- > Milt > N395V > F1 Rocket Driver > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=2838#2838 > > > > > Attachments: > > http://forums.matronics.com//files/dcp_1184_127.jpg > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jan 11, 2006
anyone have knowledge of: where is this Twin Commander? "1/2 of a tough bird" @ twincommanderflyer.com -------------- Original message -------------- From: Russell Legg <rlegg(at)austarnet.com.au> > > Capt Milt! > > Great to catch you on the email string again! > > When are you visiting the Topend of Oz? > > Best regards from Oz > > Russell > > > > On 11/1/06 11:05 PM, "N395V" wrote: > > > > > Life is good. Like you I am approaching retirement and trying to figure out > > what to do and how to survive financially and still fly. > > > > I now fly a homebuilt and live on the rocket and RV forums. This new format > > really provides easy access to all the forums so I thought I would drop in and > > provide some comic relief/greif for awhile. > > > > -------- > > Milt > > N395V > > F1 Rocket Driver > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=2838#2838 > > > > > > > > > > Attachments: > > > > http://forums.matronics.com//files/dcp_1184_127.jpg > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > anyone have knowledge of: Questionhttp://www.twincommanderflyer.com/forums/images/icons/icon5.gif" border=0> where is this Twin Commander? "1/2 of a tough bird" @ twincommanderflyer.com -------------- Original message -------------- From: Russell Legg rlegg(at)austarnet.com.au -- Commander-List message posted by: Russell Legg Capt Milt! Great to catch you on the email string again! When are you visiting the Topend of Oz? Best regards from Oz Russell On 11/1/06 11:05 PM, "N395V" wrote: -- Commander-List message posted by: "N395V" Life is good. Like you I am approaching retirement and trying to figure out what to do and how to survive financially and still fly. I now fly a homebuilt and live on the rocket and RV forums. This new format really provides e asy access to all the forums so I thought I would drop in and provide some comic relief/greif for awhile. -------- Milt N395V F1 Rocket Driver Read this topic online here: http://forums.matronics.com/viewtopic.php?p=2838#2838 Attachments: http://forums.matronics.com//files/dcp_1184_127.jpg or to browse ________________________________________________________________________________
Date: Jan 11, 2006
bowing74(at)earthlink.net wrote: > Se habla Espaniol??? > > Guermo Un Pocito. Anyway, thanks guys, that was helpful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=3089#3089 ________________________________________________________________________________
Date: Jan 11, 2006
You may need more that pocito. bilbo -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of captseth Sent: Wednesday, January 11, 2006 8:03 PM Subject: Commander-List: Re: GSO-480 Overhaul bowing74(at)earthlink.net wrote: > Se habla Espaniol??? > > Guermo Un Pocito. Anyway, thanks guys, that was helpful. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=3089#3089 ________________________________________________________________________________
Date: Jan 11, 2006
hey gang,,I saw a pair of gso 480'S,i think I can find the add,will be right back with ya!! Big AL >From: Chris Schuermann <cschuerm(at)cox.net> >Reply-To: commander-list(at)matronics.com >To: commander-list(at)matronics.com >Subject: Re: Commander-List: Re: GSO-480 Overhaul >Date: Wed, 11 Jan 2006 14:18:56 -0600 > > >captseth wrote: > > > > So you're saying that if you pop a jug or trash a gearbox lycoming >doesn't stock parts? > > >Unfortunatly, that's the case. Lycoming no longer supports many of the >oldest engines including the radials and GO series. There are a few >shops left that will overhaul them, but there are fewer every day. We >used to have several very good shops in the tulsa area that specialized >in geared lycs, but they've all dropped those over the last 10 years or >so due to lack of parts. Once in a while you can find some NOS parts, >but mostly you're just looking at "is it better than what I've got" >these days. Central Cylinder still does quite a bit of work on those >engines and probably has more parts than anyone. You might give George >Czarneki a call and see what they can do. Bottom line is that you're >not going to get a "new limits" quality overhaul or many new parts. > >bummer - I think that if Lyc had kept progressing on the GSO-480 that it >could have been the engine of choice for many modern designs too.... > >Chris > > ________________________________________________________________________________
Date: Jan 11, 2006
In a message dated 1/11/2006 2:19:27 PM Central Standard Time, cschuerm(at)cox.net writes: There are a few shops left that will overhaul them, but there are fewer every day Actually, there are several good shops that still do Geared engiens (see FGN last year). Parts are not yet a problem (except for the oldiest GO 435). I have also found that OH prices are reasonable. Several shops still do OH of geared engiens even though they dont advertize. Moe Mills ah had his engiens done by a shop in CA a couple years ago. I had not heard of them, but they did a great job. I have an engine shop here in the portland aera (Priemer engiens) who will wlso do them. The owner cut his teath on geared engiens and still has a catche of NOS parts. There is, at this time, no problem getting a GO or GSO engine overhauled at a reasnoble cost. Also, the 480 searies engiens will almost always make or exceed the TBO if properly flown. In the next FGN, (being printed now) I hav an areticle on the proper operation of the lyc geared engine. jb ________________________________________________________________________________
Date: Jan 12, 2006
Commander drivers, Starman Bros. is having an auction in Hastings, FL soon. Earl Aircraft Salvage is throwing in the towel, and I think that they had a lot of 480 stuff and Commander parts. Starman Bros. has a web sight www.starmanauctions.com. If anyone goes, please let me know, as there is one small item that I would like to get. Regards, Moe N680RR 680F(p) ----- Original Message ----- From: "Allen Reed" <allen_reed2(at)hotmail.com> Sent: Wednesday, January 11, 2006 5:59 PM Subject: Re: Commander-List: Re: GSO-480 Overhaul > > hey gang,,I saw a pair of gso 480'S,i think I can find the add,will be right > back with ya!! Big AL > > > >From: Chris Schuermann <cschuerm(at)cox.net> > >Reply-To: commander-list(at)matronics.com > >To: commander-list(at)matronics.com > >Subject: Re: Commander-List: Re: GSO-480 Overhaul > >Date: Wed, 11 Jan 2006 14:18:56 -0600 > > > > > > > > > >captseth wrote: > > > > > > So you're saying that if you pop a jug or trash a gearbox lycoming > >doesn't stock parts? > > > > > >Unfortunatly, that's the case. Lycoming no longer supports many of the > >oldest engines including the radials and GO series. There are a few > >shops left that will overhaul them, but there are fewer every day. We > >used to have several very good shops in the tulsa area that specialized > >in geared lycs, but they've all dropped those over the last 10 years or > >so due to lack of parts. Once in a while you can find some NOS parts, > >but mostly you're just looking at "is it better than what I've got" > >these days. Central Cylinder still does quite a bit of work on those > >engines and probably has more parts than anyone. You might give George > >Czarneki a call and see what they can do. Bottom line is that you're > >not going to get a "new limits" quality overhaul or many new parts. > > > >bummer - I think that if Lyc had kept progressing on the GSO-480 that it > >could have been the engine of choice for many modern designs too.... > > > >Chris > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jan 12, 2006
I asked the guys in the shop this morning if they do GO-480 overhauls and they laughed. Apparently I was standing on what used to be the assembly line where they did 8 each week during the war. The shop is Columbia Aircraft Services in Bloomsburg, Pa. 17815. 570-784-3070. Airport N13. They said Scott Smith (the boss) still buys the scarcer parts wherever he can find them. Tell him Ben the Kitfox guy told you to call. HTH Good luck! Ben Read this topic online here: http://forums.matronics.com/viewtopic.php?p=3292#3292 ________________________________________________________________________________
Subject:
Date: Jan 12, 2006
I got this off AVFLASH, does any one know any thing about this. PilotShareTheRide.com. Jim Addington N444BD ________________________________________________________________________________
Date: Jan 12, 2006
Wow, great - all good stuff. I'll keep the info handy. I want to use the airplane in LIMITED commercial service and want to be able to support it. My employer has a similar problem with a discontinued aircraft/engine, and they resorted to cannabilization - which is not going to last more than another couple of months on that airplane. So, I don't want to make the same mistake they did: not having a plan "b." It sounds like there are enough parts out there to keep them going, especially if one's original equipment remains servicable through the overhaul. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=3317#3317 ________________________________________________________________________________
Date: Jan 12, 2006
Hi. I am part of the staff for Gary Tillman, who was killed in the Cessna 195 crash the week of Christmas. We want to keep his email address active for business reasons because a lot of clients have the address...however Gary seems to get a lot of emails from the commander chat list. How do we get his email address removed from the list? Thanks, Melissa Av. Ins. Brokers of NA http://www.flysafeinsurance.com/ 800-228-4283 706-291-4077 office 706-238-1143 cell 706-232-3081 fax ________________________________________________________________________________
Subject: Re: Gary Tillman
Date: Jan 12, 2006
Melissa, Gary was a friend and a lot of us knew him. Gary is missed in the Twin Commander world. I hope his body and his daughter were recovered? As a group, our condolences to to his family. When it happened, many of our members put posts to this site and we prayed for him. To remove his email, you will need to contact the webmaster at www.matronics.com Many regards to the Tillman family. Tylor Hall On Jan 12, 2006, at 11:37 AM, TILLMAN333(at)aol.com wrote: > > Hi. I am part of the staff for Gary Tillman, who was killed in the > Cessna > 195 crash the week of Christmas. We want to keep his email address > active for > business reasons because a lot of clients have the > address...however Gary seems > to get a lot of emails from the commander chat list. How do we get > his email > address removed from the list? > > Thanks, > Melissa > > Av. Ins. Brokers of NA > http://www.flysafeinsurance.com/ > 800-228-4283 > 706-291-4077 office > 706-238-1143 cell > 706-232-3081 fax > > ________________________________________________________________________________
Date: Jan 13, 2006
G'day Tylor, Many thanks on saying so eloquently what we all feel at this very sad time around the whole Gary thing. As you said; he had so many great friends in the Twin Commander community! I still remember the look on 'lil Crunk's face when Gary auctioned off those items to him at the Hillsboro flyin! Mewlissa, please pass on our very heartfelt regards to Gary's family. Cheers Russell ---- Original message ---- >Date: Thu, 12 Jan 2006 20:15:10 -0700 >From: Tylor Hall <tylor.hall(at)sbcglobal.net> >Subject: Re: Commander-List: Gary Tillman >To: commander-list(at)matronics.com > > >Melissa, >Gary was a friend and a lot of us knew him. >Gary is missed in the Twin Commander world. >I hope his body and his daughter were recovered? > >As a group, our condolences to to his family. > >When it happened, many of our members put posts to this site and we >prayed for him. > >To remove his email, you will need to contact the webmaster at >www.matronics.com > >Many regards to the Tillman family. > >Tylor Hall > > >On Jan 12, 2006, at 11:37 AM, TILLMAN333(at)aol.com wrote: > TILLMAN333(at)aol.com >> >> Hi. I am part of the staff for Gary Tillman, who was killed in the >> Cessna >> 195 crash the week of Christmas. We want to keep his email address >> active for >> business reasons because a lot of clients have the >> address...however Gary seems >> to get a lot of emails from the commander chat list. How do we get >> his email >> address removed from the list? >> >> Thanks, >> Melissa >> >> Av. Ins. Brokers of NA >> http://www.flysafeinsurance.com/ >> 800-228-4283 >> 706-291-4077 office >> 706-238-1143 cell >> 706-232-3081 fax >> >> >> >> >> >> >> >> >> >> >> >> >> > > >_- ========================================= =================== >_- ========================================= =================== >_- ========================================= =================== > > > > > > > ________________________________________________________________________________
Subject: Re: Documentation +
Date: Jan 13, 2006
tf, have you rcd the stuff I sent you? mason ----- Original Message ----- From: Tom Fisher<mailto:tfisher(at)commandergroup.bc.ca> To: commander-list(at)matronics.com Sent: Saturday, December 10, 2005 7:57 PM Subject: Re: Commander-List: Documentation + Sorry about the blank send a second ago, cell: 604-649-9320 Tom F. ----- Original Message ----- From: "MASON Chevaillier" <kamala(at)msn.com<mailto:kamala(at)msn.com>> To: > Subject: RE: Commander-List: Documentation + > > tf, please forward your phone number i will call you on these. mason > > > >From: "Tom Fisher" <tfisher(at)commandergroup.bc.ca<mailto:tfisher(at)commandergroup.bc.ca>> > >Reply-To: commander-list(at)matronics.com > >To: > > >Subject: Commander-List: Documentation + > >Date: Sat, 10 Dec 2005 15:28:56 -0800 > > > >> > > > >Gents, > > > >I am looking for documentation in the for of drawings or lists of parts on > >the Mr. RPM conversion, one question that came up is that the data plate on > >the aircraft still has the wrong engines on it and we need to see the STC > >to > >determine if the data plate is required to be changed or not. > >Another item is that I have on each engine a plastic air line going from > >the > >fuel pump to the fuel pressure gauge that appears to be an automotive part. > >This too may be mentioned in the STC documentation. > > > >I last heard that Dick sold the MR.RPM rights to a couple of people who > >have > >not been able to supply me with information this summer as they were saying > >"everything is in boxes", and "not set up", any update on them? > > > >My local engineers are about to tackle the job of setting up the engines to > >spec. As I really dislike paying for their learning curve I would like to > >supply them with some form of documentation for this engine setup. > >Short of that I'll pay someone like Morris Kernik to come to Vancouver to > >teach my locals how to service this machine. > > > >I'll take all the responses I can get, I would like to get my plane back > >before the Christmas holidays.
December 14, 2005 - January 13, 2006
Commander-Archive.digest.vol-bv
