Commander-Archive.digest.vol-cn
August 18, 2007 - September 29, 2007
      Nico
        _____
[mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Barry Collman Sent: Saturday, August 18, 2007 5:27 AM
Subject: Re: 500A IO-550 Conversion
Hi Nico, By clicking on "Aircraft Models > Piston Twins > 500A Colemill", I couldn't find a photo of the Colemill 500A (Colemill Super 300), but did find photos of the Merlyn 500B. (Aircraft Models > Piston Twins > 500B Merlyn). Let me know the registration of the Colemill 500A and I'll check it out. Merlyn Commanders The Merlyn 500B pictured is almost certainly s/n 1155-84, N6258X. While owned by Jerry W Rodgers and PG&E Inc., this had Lycoming TIO-540-J2B(D) 350hp engines with Hartzell HC-C4YR-2UF/FC6660 4-blade propellers, signed-off as installed on August 23rd 1995. These propellers are of 69.75 in. diameter, vs. the usual 80 in. of the standard 500A props. Must make for a quieter cabin, unless the increase in fuselage/prop clearance is eaten away by an extra blade being involved. There were Experimental - Market Survey Certificates issued on March 14th 1997 and June 11th 1997, before one in the Standard - Normal category was issued on October 7th 1997. Jerry kindly flew me from Nashville to Oklahoma City in this Commander after the Fly-In in June 1997. He had also attended the Fly-In held at San Antonio the previous year. I think there's now an STC for this, SA5969NM, covering the 500B, 500U & 500S. Model 500S serial numbers 3155, 3255 & 3319 have also had this engine installed. Model 500B serial numbers 999-30 and 1525-187 have had Lycoming TIO-540-AE2A(MC) 350hp engines with Hartzell HC-C3YR-2UF/FC8468 or FC8468-6 propellers installed. This enables a Gross weight increase to 7,200lb under STC SA01212SE. I would really like to get some performance figures for Commanders with these two engines. Colemill Commanders The 500A can be modified to a Colemill "Super 300" under STCs SA340SO and SA366SO. These also approve a GW increase from 6,000lb to 6,530lb. (Other 500A Models can have a GW increase from 6,000lb to 6,250lb if Service Change No. 50 is accomplished.) Of the 99 examples built of the 500A, at least 21 have been converted to 500B and 31 modified to Colemill "Super 300". Additionally, the first of these 99 was converted to the first Model 680F. (s/n 500A-871-1 to 680F-871-1). The Colemill conversion replaces the Continental IO-470-M 260hp engines with Continental IO-520-E 300hp engines. The original Hartzell HC-A2XF-2B/8433-4 propellers are also replaced, with Hartzell EHC-A3VF-2B/V7636D. Again, some performance feed-back for the Colemill examples will be welcome. Very Best Regards, Barry ----- Original Message -----
From: "nico css" < <mailto:nico(at)cybersuperstore.com>
nico(at)cybersuperstore.com> Sent: Saturday, August 18, 2007 5:13 AM Subject: RE: Commander-List: 500A IO-550 Conversion nico(at)cybersuperstore.com> | | Very interesting, Mike. | If you look on the TCFG website ( <http://www.aerocommander.com> www.aerocommander.com) click on Aircraft | Models > Piston Twins > 500 A Colemill, you will see that I posted a picture | of what I believed at the time to be of a 500A Colemill. The specs, however, | are of a straight 500A because I had nothing on the Colemill. | You will also see that there are some pictures of a 500B Merlyn with its | four-blade props and all. The specs on the Merlyn page are of a straight | 500B because I have nothing on the Merlyn either. (Does anyone have specs | and history on these models?) | Do you know whether what I have on the website are genuine Colemill and | Merlyn mods or are they experimental aircraft? Also, do you know how the | Merlyn would stack up against the Colemill, in your opinion? | Thanks | Nico | | -----Original Message----- | From: <mailto:owner-commander-list-server(at)matronics.com> owner-commander-list-server(at)matronics.com | [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of mike floyd | Sent: Friday, August 17, 2007 7:09 PM | To: Commander-List(at)matronics.com | Subject: Commander-List: 500A IO-550 Conversion | floydgm(at)hotmail.com> | | Merlyn Products currently has an IO-550 STC project in the works for the | 500A. Rumor has it anyway. | | Mike | Northern Commanders LLC | | _________________________________________________________________ | Find a local pizza place, movie theater, and more..then map the best route! | <http://maps.live.com/default.aspx?v=2&ss=yp.bars~yp.pizza~yp.movie%20theate r> http://maps.live.com/default.aspx?v=2&ss=yp.bars~yp.pizza~yp.movie%20theater | &cp=42.358996~-71.056691&style=r&lvl=13&tilt=-90&dir=0&alt=-1000&scene-060 | 7&encType=1&FORM=MGAC01 | | ========== | Commander-List browse | Archive and much href="http://www.matronics.com/Navigator?Commander-List">http://www.matronic s.com/Navigator?Commander-List | ========== | bsp; available via href="http://forums.matronics.com">http://forums.matronics.com | =========== ________________________________________________________________________________
From: "Barry Collman" <barry.collman@air-britain.co.uk>
Date: Aug 18, 2007
Hi Nico, Permission granted - no problem! Best Regards, Barry ----- Original Message ----- From: nico css To: commander-list(at)matronics.com Sent: Saturday, August 18, 2007 3:10 PM Subject: RE: Commander-List: 500A IO-550 Conversion Thanks, Barry. There's a lot of useful information from your bunker of Commander intelligence about these products. I would like to incorporate that into the website, with your permission. I posted my reply to Mike Floyd before I read your email. Thanks Nico ------------------------------------------------------------------------- ----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Barry Collman Sent: Saturday, August 18, 2007 5:27 AM To: commander-list(at)matronics.com Subject: Re: Commander-List: 500A IO-550 Conversion Hi Nico, By clicking on "Aircraft Models > Piston Twins > 500A Colemill", I couldn't find a photo of the Colemill 500A (Colemill Super 300), but did find photos of the Merlyn 500B. (Aircraft Models > Piston Twins > 500B Merlyn). Let me know the registration of the Colemill 500A and I'll check it out. Merlyn Commanders The Merlyn 500B pictured is almost certainly s/n 1155-84, N6258X. While owned by Jerry W Rodgers and PG&E Inc., this had Lycoming TIO-540-J2B(D) 350hp engines with Hartzell HC-C4YR-2UF/FC6660 4-blade propellers, signed-off as installed on August 23rd 1995. These propellers are of 69.75 in. diameter, vs. the usual 80 in. of the standard 500A props. Must make for a quieter cabin, unless the increase in fuselage/prop clearance is eaten away by an extra blade being involved. There were Experimental - Market Survey Certificates issued on March 14th 1997 and June 11th 1997, before one in the Standard - Normal category was issued on October 7th 1997. Jerry kindly flew me from Nashville to Oklahoma City in this Commander after the Fly-In in June 1997. He had also attended the Fly-In held at San Antonio the previous year. I think there's now an STC for this, SA5969NM, covering the 500B, 500U & 500S. Model 500S serial numbers 3155, 3255 & 3319 have also had this engine installed. Model 500B serial numbers 999-30 and 1525-187 have had Lycoming TIO-540-AE2A(MC) 350hp engines with Hartzell HC-C3YR-2UF/FC8468 or FC8468-6 propellers installed. This enables a Gross weight increase to 7,200lb under STC SA01212SE. I would really like to get some performance figures for Commanders with these two engines. Colemill Commanders The 500A can be modified to a Colemill "Super 300" under STCs SA340SO and SA366SO. These also approve a GW increase from 6,000lb to 6,530lb. (Other 500A Models can have a GW increase from 6,000lb to 6,250lb if Service Change No. 50 is accomplished.) Of the 99 examples built of the 500A, at least 21 have been converted to 500B and 31 modified to Colemill "Super 300". Additionally, the first of these 99 was converted to the first Model 680F. (s/n 500A-871-1 to 680F-871-1). The Colemill conversion replaces the Continental IO-470-M 260hp engines with Continental IO-520-E 300hp engines. The original Hartzell HC-A2XF-2B/8433-4 propellers are also replaced, with Hartzell EHC-A3VF-2B/V7636D. Again, some performance feed-back for the Colemill examples will be welcome. Very Best Regards, Barry ----- Original Message ----- From: "nico css" <nico(at)cybersuperstore.com> To: Sent: Saturday, August 18, 2007 5:13 AM Subject: RE: Commander-List: 500A IO-550 Conversion | | Very interesting, Mike. | If you look on the TCFG website (www.aerocommander.com) click on Aircraft | Models > Piston Twins > 500 A Colemill, you will see that I posted a picture | of what I believed at the time to be of a 500A Colemill. The specs, however, | are of a straight 500A because I had nothing on the Colemill. | You will also see that there are some pictures of a 500B Merlyn with its | four-blade props and all. The specs on the Merlyn page are of a straight | 500B because I have nothing on the Merlyn either. (Does anyone have specs | and history on these models?) | Do you know whether what I have on the website are genuine Colemill and | Merlyn mods or are they experimental aircraft? Also, do you know how the | Merlyn would stack up against the Colemill, in your opinion? | Thanks | Nico | | -----Original Message----- | From: owner-commander-list-server(at)matronics.com | [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of mike floyd | Sent: Friday, August 17, 2007 7:09 PM | To: Commander-List(at)matronics.com | Subject: Commander-List: 500A IO-550 Conversion | | | Merlyn Products currently has an IO-550 STC project in the works for the | 500A. Rumor has it anyway. | | Mike | Northern Commanders LLC | | _________________________________________________________________ | Find a local pizza place, movie theater, and more..then map the best route! | http://maps.live.com/default.aspx?v=2&ss=yp.bars~yp.pizza~yp.movie%20 theater | &cp=42.358996~-71.056691&style=r&lvl=13&tilt=-90&dir=0&alt=-1 000&scene-060 | 7&encType=1&FORM=MGAC01 | | ========== | Commander-List browse | Archive and much href="http://www.matronics.com/Navigator?Commander-List">http://www.mat ronics.com/Navigator?Commander-List | ========== | bsp; available via href="http://forums.matronics.com">http://forums.matronics.com | =========== ________________________________________________________________________________
Date: Aug 18, 2007
Subject: Random thoughts on Merlyn Products conversions
Merlyn products makes some great conversions. There are a couple being flown around here, including a 320-hp converted 500B and one of the original 350-hp 500B's with the 4-blade props. I've flown in both, and have PIC time in the 4-blade version. The 4-blade makes a very different sound than my stock 500B (of course, the props spin at 2,700 on takeoff, I think) and its efficiency really doesn't shine until you're up in the teens. The 320hp conversion feels like a stock 500B, except you can make 48" of MP on takeoff, like the 350hp. Being a low-compression engine, it also doesn't really show you what it's got until you're up over 10,000'. I think I might prefer the Merlyn 300hp conversion, which is a turbonormalized application (like my rayjays) on the IO-540-M1C5 (wide-deck) engines. This would give me most of the zip of the 320hp up high, but between 3,500 - 10,000, where I do most of my "local" flying, I wouldn't suffer any of the inefficiencies (think fuel consumption) that the boosted engines would. Plus, I still would get a gross weight increase. Hugh @ Merlyn really knows what he's doing. His single-turbo/mechanical wastegate is far, far better than the rayjay setup that I have in my airplane. You just push the throttle levers to the MP you want, whenever you want it. It also has a very nice blow-off valve to prevent you from overboosting the engine. All this in a package that is MUCH simpler than the rayjays it replaces; there's tons of room in the aft nacelle to still get at accessories & oil filters, unlike in my airplane with all the rayjay plumbing in the way. At some point I'm sure I'll buy one of Hugh's STC's for my airplane, although, with fuel the way it is, I'd like to see a diesel (jet-A) option for our airplanes. Maybe the Century 4.0 engine might be a potential retrofit, although I've heard that neither Century nor Twin Commander have expressed *any* interest whatsoever in supporting an STC effort... /J nico css wrote: > > Mike, > I visited Merlyn's website and found many interesting things, which answered > some of my questions. I am going to contact these folks for more information > and permission to publish some of their material on our website. > It appears as if these STC's are existing and flying mods. Perhaps if Bilbo > had known about these, he could have had his 500A dressed up in one of > these. > Thanks for introducing me to them. > Nico > > > -----Original Message----- > From: owner-commander-list-server(at)matronics.com > [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of mike floyd > Sent: Friday, August 17, 2007 9:35 PM > To: commander-list(at)matronics.com > Subject: RE: Commander-List: 500A IO-550 Conversion > > > I do not know the answers to all of your questions but here is the website I > > have found: > > http://www.merlynproducts.com/commander.html > > I am in Spokane right now and will find out on Monday what Merlyn is doing. > > Mike > Northern Commanders LLC > > _________________________________________________________________ > Find a local pizza place, movie theater, and more..then map the best route! > http://maps.live.com/default.aspx?v=2&ss=yp.bars~yp.pizza~yp.movie%20theater > &cp=42.358996~-71.056691&style=r&lvl=13&tilt=-90&dir=0&alt=-1000&scene-060 > 7&encType=1&FORM=MGAC01 > > > __________ NOD32 2469 (20070818) Information __________ > > > ________________________________________________________________________________
Date: Aug 15, 2007
From: W J R HAMILTON <wjrhamilton(at)optusnet.com.au>
Subject: Re: Engine Through-Stud Sheer...
Folks, Is an STC really necessary, has anybody explored a field upgrade. I say this, because several upgrades with which I have been involved in Australian (not AC) have been done on our (near) equivalent of a 377 field approval system, with the appropriate CAR 35 (DER) input. As a simplification, it is assumed that the extra power will be a "bonus", there was no attempt to re-certify any increased performance. This has avoided the need to re-determine Vmc figures etc., if the upgrade is a twin. I know it all sound a bit rough and ready, but there is little involved in putting the IO-520 in the 500A, I doubt that the IO-550 is much more of a bother, with a co-operative FAA man. Needless to say, one would be wise to have some carefully established "informal guidelines", if in fact you just happened to be "inadvertently" taking advantage of the additional HP, and one quit. Fortunately the wonderful engine out handling of Aero Commanders in general make this somewhat less fraught than some other manufacturer's products that started with IO-470, but have acquired IO-520 along the way. Cheers, Bill Hamilton At 03:24 AM 15/08/2007, you wrote: >Good idea about the 550... A guy in the hangar here has a Bonanza >with one and he loves it... I guess put out a call for all 12 of >the existing 500A owners left to see what interest might be shown ;) > > >David Owens >Aerial Viewpoint >N14AV >AC-500A-Colemill ________________________________________________________________________________
Subject: Re: Random thoughts on Merlyn Products conversions
Date: Aug 19, 2007
What happened to F. Lee Baily's 500B project where he was putting on the TIO-540s? Jim Addington 500A ----- Original Message ----- From: "John Vormbaum" <john(at)vormbaum.com> Sent: Saturday, August 18, 2007 2:00 PM Subject: Commander-List: Random thoughts on Merlyn Products conversions > > Merlyn products makes some great conversions. There are a couple being > flown around here, including a 320-hp converted 500B and one of the > original 350-hp 500B's with the 4-blade props. I've flown in both, and e > was putting have PIC time in the 4-blade version. The 4-blade makes a very > different sound than my stock 500B (of course, the props spin at 2,700 on > takeoff, I think) and its efficiency really doesn't shine until you're up > in the teens. The 320hp conversion feels like a stock 500B, except you can > make 48" of MP on takeoff, like the 350hp. Being a low-compression engine, > it also doesn't really show you what it's got until you're up over > 10,000'. > > I think I might prefer the Merlyn 300hp conversion, which is a > turbonormalized application (like my rayjays) on the IO-540-M1C5 > (wide-deck) engines. This would give me most of the zip of the 320hp up > high, but between 3,500 - 10,000, where I do most of my "local" flying, I > wouldn't suffer any of the inefficiencies (think fuel consumption) that > the boosted engines would. Plus, I still would get a gross weight > increase. > > Hugh @ Merlyn really knows what he's doing. His single-turbo/mechanical > wastegate is far, far better than the rayjay setup that I have in my > airplane. You just push the throttle levers to the MP you want, whenever > you want it. It also has a very nice blow-off valve to prevent you from > overboosting the engine. All this in a package that is MUCH simpler than > the rayjays it replaces; there's tons of room in the aft nacelle to still > get at accessories & oil filters, unlike in my airplane with all the > rayjay plumbing in the way. > > At some point I'm sure I'll buy one of Hugh's STC's for my airplane, > although, with fuel the way it is, I'd like to see a diesel (jet-A) option > for our airplanes. Maybe the Century 4.0 engine might be a potential > retrofit, although I've heard that neither Century nor Twin Commander have > expressed *any* interest whatsoever in supporting an STC effort... > > /J > > nico css wrote: >> >> >> Mike, >> I visited Merlyn's website and found many interesting things, which >> answered >> some of my questions. I am going to contact these folks for more >> information >> and permission to publish some of their material on our website. >> It appears as if these STC's are existing and flying mods. Perhaps if >> Bilbo >> had known about these, he could have had his 500A dressed up in one of >> these. >> Thanks for introducing me to them. Nico >> >> >> >> -----Original Message----- >> From: owner-commander-list-server(at)matronics.com >> [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of mike >> floyd >> Sent: Friday, August 17, 2007 9:35 PM >> To: commander-list(at)matronics.com >> Subject: RE: Commander-List: 500A IO-550 Conversion >> >> >> I do not know the answers to all of your questions but here is the >> website I >> >> have found: >> >> http://www.merlynproducts.com/commander.html >> >> I am in Spokane right now and will find out on Monday what Merlyn is >> doing. >> >> Mike >> Northern Commanders LLC >> >> _________________________________________________________________ >> Find a local pizza place, movie theater, and more..then map the best >> route! >> http://maps.live.com/default.aspx?v=2&ss=yp.bars~yp.pizza~yp.movie%20theater >> &cp=42.358996~-71.056691&style=r&lvl=13&tilt=-90&dir=0&alt=-1000&scene-060 >> 7&encType=1&FORM=MGAC01 >> >> >> >> >> >> >> >> >> >> >> __________ NOD32 2469 (20070818) Information __________ >> >> >> >> >> > > > ________________________________________________________________________________
Date: Aug 20, 2007
Hi Jim, Good question! I think this project was dubbed the "Hoover Hornet" and possibly involved a 500S Shrike, Serial Number 3253. As N808AC, this received an Experimental-Exhibition certificate on November 2nd 1995 (TT3,529.30) while owned by Palm Beach Roamer Inc., of West Palm Beach, Florida. Palm Beach Roamer Inc is owned by F Lee Bailey or his son, if I recall correctly. It was returned to Standard-Normal & Utility category on November 21st (TT3,538.30), but was again placed in the Experimental-Exhibition category on June 13th 1997 (TT3,713.00) although the aircraft had been sold to Aircraft Trading Center Inc., of Tequesta, Florida, on April 9th 1996. The Experimental Certificate was renewed on August 13th 1997 (TT3,719.40). In March 1998, the Shrike was sold in St Vincent & Grenadines as J8-VBE. However, the last time I checked the FAA records for this aircraft, there was no Form 337 covering a change of engine, but Hartzell HC-C3YR-2UF/FC8468-6R propellers were installed on July 22nd 1995 under Twin Commander's Custom Kit 67. I have earmarked this Shrike or a review of the records when I visit the FAA Records Center after the Fly-In. In the meantime, if anyone can add anything .......... Best Regards, Barry ----- Original Message ----- From: "Jim Addington" <jtaddington(at)charter.net> Sent: Sunday, August 19, 2007 6:11 PM Subject: Re: Commander-List: Random thoughts on Merlyn Products conversions | | What happened to F. Lee Baily's 500B project where he was putting on the | TIO-540s? | Jim Addington | 500A ________________________________________________________________________________
Date: Aug 20, 2007
Subject: AERO COMMANDER FORSALE ON EBAY
Anyone have any idea which one this is. It is obviously not a Shrike. Thanks, Bert _http://cgi.ebay.com/shrike-aero-commander_W0QQitemZ250156694670QQihZ015QQcate goryZ2563QQssPageNameZWDVWQQrdZ1QQcmdZViewItem_ (http://cgi.ebay.com/shrike-aero-commander_W0QQitemZ250156694670QQihZ015QQcategoryZ2563QQssPageNameZWDVWQQrd Z1QQcmdZViewItem) http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Date: Aug 20, 2007
Subject: prop governor body
Our 500B is down in Springfield, Mo with a bad prop governor. The prop shop in Dallas tells me will be hard to find. Does anyone have either a used prop governor (mainly need the body) or a source for a new or rebuilt prop governor for an IO540 from 1964 commander 500B? thanks ________________________________________________________________________________
Date: Aug 20, 2007
bf, call parts/gary @commander aero 888-881-5580. mason Date: Mon, 20 Aug 2007 15:52:05 -0500From: bobf(at)feldtman.comTo: commander-l ist(at)matronics.comSubject: Commander-List: prop governor body Our 500B is down in Springfield, Mo with a bad prop governor. The prop shop in Dallas tells me will be hard to find. Does anyone have either a used pr op governor (mainly need the body) or a source for a new or rebuilt prop go vernor for an IO540 from 1964 commander 500B? thanks ________________________________________________________________________________
Subject: Re: AERO COMMANDER FORSALE ON EBAY
Date: Aug 20, 2007
Hi Bert, I've sent the seller a question, asking what the Serial Number is. Best Regards, Barry ----- Original Message ----- From: BertBerry1(at)aol.com To: commander-list(at)matronics.com Sent: Monday, August 20, 2007 9:43 PM Subject: Commander-List: AERO COMMANDER FORSALE ON EBAY Anyone have any idea which one this is. It is obviously not a Shrike. Thanks, Bert http://cgi.ebay.com/shrike-aero-commander_W0QQitemZ250156694670QQihZ015QQ categoryZ2563QQssPageNameZWDVWQQrdZ1QQcmdZViewItem ------------------------------------------------------------------------- ----- AOL.com. ________________________________________________________________________________
Date: Aug 20, 2007
Me too, maybe we will get a reply. Sent via BlackBerry by AT&T -----Original Message----- From: "Barry Collman" <barry.collman@air-britain.co.uk> Date: Mon, 20 Aug 2007 22:14:27 To: Subject: Re: Commander-List: AERO COMMANDER FORSALE ON EBAY Hi Bert, I've sent the seller a question, asking what the Serial Number is. Best Regards, Barry ----- Original Message ----- From: BertBerry1(at)aol.com <mailto:BertBerry1(at)aol.com> Sent: Monday, August 20, 2007 9:43 PM Subject: Commander-List: AERO COMMANDER FORSALE ON EBAY Anyone have any idea which one this is. It is obviously not a Shrike. Thanks, Bert http://cgi.ebay.com/shrike-aero-commander_W0QQitemZ250156694670QQihZ015QQcategoryZ2563QQssPageNameZWDVWQQrdZ1QQcmdZViewItem ---------------- ________________________________________________________________________________
From: "Moe - Ross Racing Pistons" <moe(at)rosspistons.com>
Date: Aug 20, 2007
Hummmm....1958 Shrike, two bad engines, bent wing... -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of bertberry1(at)aol.com Sent: Monday, August 20, 2007 2:20 PM Subject: Re: Commander-List: AERO COMMANDER FORSALE ON EBAY Me too, maybe we will get a reply. Sent via BlackBerry by AT&T -----Original Message----- From: "Barry Collman" <barry.collman@air-britain.co.uk> Date: Mon, 20 Aug 2007 22:14:27 To: Subject: Re: Commander-List: AERO COMMANDER FORSALE ON EBAY Hi Bert, I've sent the seller a question, asking what the Serial Number is. Best Regards, Barry ----- Original Message ----- From: BertBerry1(at)aol.com <mailto:BertBerry1(at)aol.com> Sent: Monday, August 20, 2007 9:43 PM Subject: Commander-List: AERO COMMANDER FORSALE ON EBAY Anyone have any idea which one this is. It is obviously not a Shrike. Thanks, Bert http://cgi.ebay.com/shrike-aero-commander_W0QQitemZ250156694670QQihZ015QQcat egoryZ2563QQssPageNameZWDVWQQrdZ1QQcmdZViewItem <http://cgi.ebay.com/shrike-aero-commander_W0QQitemZ250156694670QQihZ015QQca tegoryZ2563QQssPageNameZWDVWQQrdZ1QQcmdZViewItem> ---------------- ________________________________________________________________________________
Date: Aug 21, 2007
Looks like a 560A to me.? It is a 560A, E or a 680.? Notice it has what appears to be a cowl flap on the LH engine nacelle??? jb -----Original Message----- From: Barry Collman <barry.collman@air-britain.co.uk> Sent: Mon, 20 Aug 2007 2:14 pm Subject: Re: Commander-List: AERO COMMANDER FORSALE ON EBAY Hi Bert, ? I've sent the seller a question, asking what the Serial Number is. ? Best Regards, Barry ----- Original Message ----- From: BertBerry1(at)aol.com Sent: Monday, August 20, 2007 9:43 PM Subject: Commander-List: AERO COMMANDER FORSALE ON EBAY Anyone have any idea which one this is.? It is obviously not a Shrike. ? Thanks, ? Bert ? ? http://cgi.ebay.com/shrike-aero-commander_W0QQitemZ250156694670QQihZ015QQcategoryZ2563QQssPageNameZWDVWQQrdZ1QQcmdZViewItem AOL.com. href="http://www.matronics.com/Navigator?Commander-List">http://www.matronics.com/Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________ ________________________________________________________________________________
From: "David Owens" <dowens(at)aerialviewpoint.com>
Date: Aug 21, 2007
Thats the JATO outlet... David Owens Aerial Viewpoint N14AV AC-500A-Colemill ________________________________________________________________________________
Date: Aug 21, 2007
Subject: prop spinner for a 680 commander
Hello Guys, looking for a prop spinner for my 680. I have the Metzger STC prop conversion ( three blade spinner only). Do appreciate your help. Gil http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Date: Aug 21, 2007
Hi Gill, I have a spare spinner for my 680F(p) with three blade props. If they are the same, we can probably do something. Regards, Moe _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of WINGFLYER1(at)aol.com Sent: Tuesday, August 21, 2007 8:04 AM Subject: Commander-List: prop spinner for a 680 commander Hello Guys, looking for a prop spinner for my 680. I have the Metzger STC prop conversion ( three blade spinner only). Do appreciate your help. Gil AOL.com. ________________________________________________________________________________
Date: Aug 21, 2007
JB; My commander is a '57 560E, and the front of the eng.cowl is much different than the picture. Also in the picture I notice what looks like a small possible intake hole above and slightly ahead of the cowl door. My 560E does not have either one of these. Also curious as to what the item is directly to the rear the cockpit door handle on the fuselage? Don ----- Original Message ----- From: yourtcfg(at)aol.com To: commander-list(at)matronics.com Sent: Tuesday, August 21, 2007 12:45 AM Subject: Re: Commander-List: AERO COMMANDER FORSALE ON EBAY Looks like a 560A to me. It is a 560A, E or a 680. Notice it has what appears to be a cowl flap on the LH engine nacelle?? jb -----Original Message----- From: Barry Collman <barry.collman@air-britain.co.uk> To: commander-list(at)matronics.com Sent: Mon, 20 Aug 2007 2:14 pm Subject: Re: Commander-List: AERO COMMANDER FORSALE ON EBAY Hi Bert, I've sent the seller a question, asking what the Serial Number is. Best Regards, Barry ----- Original Message ----- From: BertBerry1(at)aol.com To: commander-list(at)matronics.com Sent: Monday, August 20, 2007 9:43 PM Subject: Commander-List: AERO COMMANDER FORSALE ON EBAY Anyone have any idea which one this is. It is obviously not a Shrike. Thanks, Bert http://cgi.ebay.com/shrike-aero-commander_W0QQitemZ250156694670QQihZ015QQ categoryZ2563QQssPageNameZWDVWQQrdZ1QQcmdZViewItem ------------------------------------------------------------------------- --- AOL.com. href="http://www.matronics.com/Navigator?Commander-List">http://www.mat ronics.com/Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com ------------------------------------------------------------------------- ----- ------------------------------------------------------------------------- ----- 8/19/2007 7:27 AM ________________________________________________________________________________
Date: Aug 21, 2007
I got a response from the seller, he/she said that all they knew is that it was a 1958 Shrike.... and that it needed alot of work. They did promise to get back to me with more info shortly. As soon as I get that I'll let you know. Bert http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Date: Aug 21, 2007
In a message dated 21-Aug-07 10:32:34 Pacific Daylight Time, DonGirod(at)bellsouth.net writes: My commander is a '57 560E, and the front of the eng.cowl is much different than the picture. Also in the picture I notice what looks like a small possible intake hole above and slightly ahead of the cowl door. My 560E does not have either one of these. Also curious as to what the item is directly to the rear the cockpit door handle on the fuselage? Don, All, Just to throw this into a spin ... at the Nashville TCFG Fly-In (1997 I think) Gary Gadberry presented a slide show on the AirCenter Shrike Conversions. Just to stump the experts, he showed what turned out to be an AC-500, but with so many mods, it was difficult to know that right away. The AC-500 in his show was camouflaged by a Shrike nose, eyebrow windows, front door, 3 blade props, square rudder cap and perhaps tail stinger. (It also had a round nose tire, but it appears to have since been replaced with a semi-square one.) I wonder if this is that plane? The gizmo on the nacelle may be an ice detection light. The doo-dad aft of the door frame may be a logo plaque. Wing Commander Gordon http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Date: Aug 21, 2007
A little odd that it's listed as a battery operated radio controlled aircraft. Maybe that explains the cowling? Good news is that it's Almost Ready to Fly! A couple pieces of balsa and a new shrink covering should fix that wind damage right up. Bet the batteries will be expensive. Caveat emptor....... ----- Original Message ----- From: Don Girod To: commander-list(at)matronics.com Sent: Tuesday, August 21, 2007 1:28 PM Subject: Re: Commander-List: AERO COMMANDER FORSALE ON EBAY JB; My commander is a '57 560E, and the front of the eng.cowl is much different than the picture. Also in the picture I notice what looks like a small possible intake hole above and slightly ahead of the cowl door. My 560E does not have either one of these. Also curious as to what the item is directly to the rear the cockpit door handle on the fuselage? Don ----- Original Message ----- From: yourtcfg(at)aol.com To: commander-list(at)matronics.com Sent: Tuesday, August 21, 2007 12:45 AM Subject: Re: Commander-List: AERO COMMANDER FORSALE ON EBAY Looks like a 560A to me. It is a 560A, E or a 680. Notice it has what appears to be a cowl flap on the LH engine nacelle?? jb -----Original Message----- From: Barry Collman <barry.collman@air-britain.co.uk> To: commander-list(at)matronics.com Sent: Mon, 20 Aug 2007 2:14 pm Subject: Re: Commander-List: AERO COMMANDER FORSALE ON EBAY Hi Bert, I've sent the seller a question, asking what the Serial Number is. Best Regards, Barry ----- Original Message ----- From: BertBerry1(at)aol.com To: commander-list(at)matronics.com Sent: Monday, August 20, 2007 9:43 PM Subject: Commander-List: AERO COMMANDER FORSALE ON EBAY Anyone have any idea which one this is. It is obviously not a Shrike. Thanks, Bert http://cgi.ebay.com/shrike-aero-commander_W0QQitemZ250156694670QQihZ015QQ categoryZ2563QQssPageNameZWDVWQQrdZ1QQcmdZViewItem ------------------------------------------------------------------------- - AOL.com. href="http://www.matronics.com/Navigator?Commander-List">http://www.mat ronics.com/Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com ------------------------------------------------------------------------- --- href="http://www.matronics.com/Navigator?Commander-List">http://www.mat ronics.com/Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com ------------------------------------------------------------------------- --- Date: 8/19/2007 7:27 AM ________________________________________________________________________________
Date: Aug 21, 2007
Subject: Re: prop spinner for a 680 commander
Moe, how much do you want for the spinner? Thanks Gil http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Date: Aug 21, 2007
Hello All, I was on the verge of suggesting exactly what our excellent Wing Commander came up with - that the Commander in question was a Model 500, Serial Number 639, when the eBay seller sent me an email confirming that the Commander being offered is indeed this aircraft. I was also going to suggest the nacelle 'gizmo' was an ice detection light. Anyway, this is a unique Model 500, for which I have traced the following modifications: Lycoming IO-540-A1A5 turbocharged engines, with Hartzell HC-A3VK-2B/7636D 3-blade props (STC SA257CE) Engines installed in March 1964, STC issued July 1964, through Riley Aeronautics Corp., in Fort Lauderdale. mtow increased to 6,500lb from 6,000lb (STC SA377SO) - Sep67 'Shrike' tail cone assembly (STC SA3476WE) - Jun95 'Shrike' vertical tip assembly (STC SA3492WE) - Jun95 Miller nose cone (STC SA 585SW) - Jul95 Cockpit overhead windows (STC SA3516WE) - Jul95 I've found no record of when the front cabin door was installed though. Last known owner: D Wayne Durham, of Easley, SC (which ties-in with the Email address on eBay, and its location). Best Regards, Barry ----- Original Message ----- From: CloudCraft(at)aol.com To: commander-list(at)matronics.com Sent: Tuesday, August 21, 2007 6:47 PM Subject: Re: Commander-List: AERO COMMANDER FORSALE ON EBAY In a message dated 21-Aug-07 10:32:34 Pacific Daylight Time, DonGirod(at)bellsouth.net writes: My commander is a '57 560E, and the front of the eng.cowl is much different than the picture. Also in the picture I notice what looks like a small possible intake hole above and slightly ahead of the cowl door. My 560E does not have either one of these. Also curious as to what the item is directly to the rear the cockpit door handle on the fuselage? Don, All, Just to throw this into a spin ... at the Nashville TCFG Fly-In (1997 I think) Gary Gadberry presented a slide show on the AirCenter Shrike Conversions. Just to stump the experts, he showed what turned out to be an AC-500, but with so many mods, it was difficult to know that right away. The AC-500 in his show was camouflaged by a Shrike nose, eyebrow windows, front door, 3 blade props, square rudder cap and perhaps tail stinger. (It also had a round nose tire, but it appears to have since been replaced with a semi-square one.) I wonder if this is that plane? The gizmo on the nacelle may be an ice detection light. The doo-dad aft of the door frame may be a logo plaque. Wing Commander Gordon AOL.com. ________________________________________________________________________________
Date: Aug 21, 2007
Gil, If memory serves correctly I paid $ 350.00 each for them, several years ago and obviously don't want to loose money. I have two, one is polished and the other is hard anodized a really ugly Army green. Both appear to be in very good condition, although, the green one appears to be a little bit thicker around the screw holes, because it has not been polished. Your choice $ 350.00. Where do you live? Finding a good box to ship in might be a little bit of a problem. Moe _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of WINGFLYER1(at)aol.com Sent: Tuesday, August 21, 2007 11:19 AM Subject: Re: Commander-List: prop spinner for a 680 commander Moe, how much do you want for the spinner? Thanks Gil AOL.com. ________________________________________________________________________________
Date: Aug 21, 2007
In a message dated 21-Aug-07 12:39:36 Pacific Daylight Time, barry.collman@air-britain.co.uk writes: I was also going to suggest the nacelle 'gizmo' was an ice detection light. That makes me feel a wee bit more secure, Sir Barry! Thanks for the data on this very unique airplane. Someone should really contact the eBay seller and have them clean up their ad. Sir Barry, would you consent to having the details in your post uploaded to the eBay seller? For the sake of accuracy -- not to mention the value should go up -- I think this information should appear on eBay. Cheers, Wing Commander Gordon http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Date: Aug 21, 2007
Moe, Before you ship the spinner, I need to make sure it fits the Metzger STS conversion ( Three Bladed Prop. Is it the larger spinner(more than 14 inches and can the thicker one be polished up? Thanks Gil p.s. My address is as follows: Gil Walker 6104 Belle Rive Dr. Brentwood, Tn 37027 Trl. 615-373-5703 Cell 615-310 5030. If you will e-mail me your number I will call you and discuss. Thanks http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Date: Aug 21, 2007
Hi Keith, I have emailed Mr Durham again and suggested his Commander should not be advertised as a "1958 shrike aero commander", but a "1958 Model 500 Aero Commander, incorporating some 'Shrike' mods" or similar. It is s/n 639 (the 5th Model 500 built) and has been registered as N6226B since initially Certificated on July 29th 1958. (Damn! Forgot to send it a 40th Birthday card). I also suggested he list the mods I know about (there may be others I'm not aware of) in his 'Description'. I also asked: If the logs he has indicate when the front cabin door was installed (if he has any logs, of course). If he has been given any quotes for getting the aircraft repaired and airworthy. I noticed in its history (I have 76 records) that it was damaged on July 26th 1996 at Lafayette-Barwick Airport, Georgia. Turns out it was struck by another Commander 500 that had suffered a failed engine-driven hydraulic pump during taxi out. Pressure was therefore lost as a right hand turn was in progress and although an attempt was made to center the nosewheel and stop the aircraft using the emergency hand-operated pump, the attempt failed and the Commander parked next to it was struck. Was repaired on August 14th 1996. I have no data on the wind damage. Very Best Regards, Barry ----- Original Message ----- From: CloudCraft(at)aol.com To: commander-list(at)matronics.com Sent: Tuesday, August 21, 2007 8:47 PM Subject: Re: Commander-List: AERO COMMANDER FORSALE ON EBAY In a message dated 21-Aug-07 12:39:36 Pacific Daylight Time, barry.collman@air-britain.co.uk writes: I was also going to suggest the nacelle 'gizmo' was an ice detection light. That makes me feel a wee bit more secure, Sir Barry! Thanks for the data on this very unique airplane. Someone should really contact the eBay seller and have them clean up their ad. Sir Barry, would you consent to having the details in your post uploaded to the eBay seller? For the sake of accuracy -- not to mention the value should go up -- I think this information should appear on eBay. Cheers, Wing Commander Gordon ------------------------------------------------------------------------- ----- AOL.com. ________________________________________________________________________________
Date: Aug 21, 2007
In a message dated 21-Aug-07 13:23:31 Pacific Daylight Time, barry.coll man@air-britain.co.uk writes: It is s/n 639 (the 5th Model 500 built) and has been registered as N6226B since initially Certificated on July 29th 1958. (Damn! Forgot to send it a 40th Birthday card). Thanks for sending the note to the eBay seller. "Leave it to a Brit to teach us our own history." ... Spaulding Gray Not to worry about the birthday card. Remember we're - GMT here in the Colonies: it's only 2007, so we won't expect 40th birthday wishes until then. Wing Commander Gordon http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Date: Aug 21, 2007
Hi Keith, The date 'error' was simply a test to see if anyone reads my postings. (Gosh, that tongue really hurts against my cheek ..... and goodness me, why does my face look so red?) Streuth! I know time flies, but to think it was next year already .......... unforgivable. Now, where are my tablets. Best Regards, Barry ----- Original Message ----- From: CloudCraft(at)aol.com To: commander-list(at)matronics.com Sent: Tuesday, August 21, 2007 9:28 PM Subject: Re: Commander-List: AERO COMMANDER FORSALE ON EBAY In a message dated 21-Aug-07 13:23:31 Pacific Daylight Time, barry.collman@air-britain.co.uk writes: It is s/n 639 (the 5th Model 500 built) and has been registered as N6226B since initially Certificated on July 29th 1958. (Damn! Forgot to send it a 40th Birthday card). Thanks for sending the note to the eBay seller. "Leave it to a Brit to teach us our own history." ... Spaulding Gray Not to worry about the birthday card. Remember we're - GMT here in the Colonies: it's only 2007, so we won't expect 40th birthday wishes until then. Wing Commander Gordon ------------------------------------------------------------------------- ----- AOL.com. ________________________________________________________________________________
Date: Aug 21, 2007
Hi Keith, OK - so you spotted the year error. It's 2007, not 2008. But, I caught you out - it will be its 50th next year, not 40th. So, I was right it the first place, I did forget its 40th birthday. Won't forget its 50th though ;-) Now, where's my other tablets. Best Regards, Barry ----- Original Message ----- From: CloudCraft(at)aol.com To: commander-list(at)matronics.com Sent: Tuesday, August 21, 2007 9:28 PM Subject: Re: Commander-List: AERO COMMANDER FORSALE ON EBAY In a message dated 21-Aug-07 13:23:31 Pacific Daylight Time, barry.collman@air-britain.co.uk writes: It is s/n 639 (the 5th Model 500 built) and has been registered as N6226B since initially Certificated on July 29th 1958. (Damn! Forgot to send it a 40th Birthday card). Thanks for sending the note to the eBay seller. "Leave it to a Brit to teach us our own history." ... Spaulding Gray Not to worry about the birthday card. Remember we're - GMT here in the Colonies: it's only 2007, so we won't expect 40th birthday wishes until then. Wing Commander Gordon ------------------------------------------------------------------------- ----- AOL.com. ________________________________________________________________________________
Date: Aug 21, 2007
In a message dated 21-Aug-07 13:41:02 Pacific Daylight Time, barry.collman@air-britain.co.uk writes: Now, where's my other tablets. On top of Mount Sinai, I believe, Sir! Wing Commander Gordon http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Date: Aug 21, 2007
The phone number here at my office is 310.536.0100. Be sure to tell our receptionist that you are "from the airport" otherwise you will get the third degree. Regards, Moe _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of WINGFLYER1(at)aol.com Sent: Tuesday, August 21, 2007 12:58 PM Subject: Re: Commander-List: prop spinner for a 680 commander Moe, Before you ship the spinner, I need to make sure it fits the Metzger STS conversion ( Three Bladed Prop. Is it the larger spinner(more than 14 inches and can the thicker one be polished up? Thanks Gil p.s. My address is as follows: Gil Walker 6104 Belle Rive Dr. Brentwood, Tn 37027 Trl. 615-373-5703 Cell 615-310 5030. If you will e-mail me your number I will call you and discuss. Thanks _____ <http://discover.aol.com/memed/aolcom30tour/?ncid=AOLAOF00020000000982> . ________________________________________________________________________________
Date: Aug 21, 2007
Contacted the guy selling the plane. He is adamant it is a SHRIKE. Guess there is no arguing with someone who doesn't know what they do not know. -------- Milt 2003 F1 Rocket 2006 Radial Rocket Read this topic online here: http://forums.matronics.com/viewtopic.php?p=130195#130195 ________________________________________________________________________________
Date: Aug 22, 2007
Bert, Definately a rare & interesting bird, but not a shrike. Are those cowl flaps, maybe due to the addition of the Rayjays...? Can anyone get better pics & post here? Brent - N224HA -------------- Original message -------------- From: "N395V" <airboss(at)excaliburaviation.com> > > Contacted the guy selling the plane. He is adamant it is a SHRIKE. > > Guess there is no arguing with someone who doesn't know what they do not know. > > -------- > Milt > 2003 F1 Rocket > 2006 Radial Rocket > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=130195#130195 > > > > > > > > > >
Bert,
Brent - N224HA
ies su
Date: Aug 22, 2007
From: "sr14572(at)yahoo.com" <sr14572(at)yahoo.com>
and I bet he has a gold chain around his neck Contacted the guy selling the plane. He is adamant it is a SHRIKE. Guess there is no arguing with someone who doesn't know what they do not know. -------- Milt 2003 F1 Rocket 2006 Radial Rocket Read this topic online here: http://forums.matronics.com/viewtopic.php?p=130195#130195 --------------------------------- Boardwalk for $500? In 2007? Ha! ________________________________________________________________________________
Date: Aug 22, 2007
I asked the seller for more photos, we will see what happens. Bert http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Date: Aug 22, 2007
Moe, the prop numbers are as follows; Hartzell- HC-93Z20-2A/10151-8R Assymbly S/N 1124A Blade Clamp S/N A18122/T511 A19407T462 A19577/T427 Executive Propeller in Van Nuys did the over haul on 1-4-05 Hope this helps match your spinner with my props. Thanks Gil http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Date: Aug 23, 2007
You will have the spinner today Please Make check out to Mailing Address Avtec II, Inc. P.O. Box 2563 Titusville, FL 32781-2563 Shipping Address Avtec II, Inc. 480 N Williams Ave Titusville, FL 32796 Thanks Harry 321 267-3141 ----- Original Message ----- From: WINGFLYER1(at)aol.com To: commander-list(at)matronics.com Sent: Wednesday, August 22, 2007 10:47 PM Subject: Re: Commander-List: prop spinner for a 680 commander Moe, the prop numbers are as follows; Hartzell- HC-93Z20-2A/10151-8R Assymbly S/N 1124A Blade Clamp S/N A18122/T511 A19407T462 A19577/T427 Executive Propeller in Van Nuys did the over haul on 1-4-05 Hope this helps match your spinner with my props. Thanks Gil ------------------------------------------------------------------------- ----- ________________________________________________________________________________
Date: Aug 23, 2007
Will send check as requested. Thanks Gil http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Date: Aug 23, 2007
Let me know when it arrives Harry ----- Original Message ----- From: WINGFLYER1(at)aol.com To: commander-list(at)matronics.com Sent: Thursday, August 23, 2007 10:46 AM Subject: Re: Commander-List: prop spinner for a 680 commander Will send check as requested. Thanks Gil ------------------------------------------------------------------------- ----- AOL.com. ________________________________________________________________________________
Date: Aug 23, 2007
Will do. Thanks Gil http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Subject:
Date: Aug 23, 2007
anyone have a fuel shut off valve pn AV16B1159 and the O-rings S-0310-219F x4 to install. PCAA mason ________________________________________________________________________________
Subject: Trojan virus
Date: Aug 23, 2007
Folks, Don't open invitations to receive an e-card, or log on to any service you have not specifically requested, neither emails with a PDF attachment that is from someone you do not know. Here's the article discussing it in more detail. http://www.eweek.com/article2/0,1895,2174160,00.asp?kc=EWKNLSTE082307STR1 This particular Trojan virus morphs every couple of minutes into something different to avoid signature detection. If you receive a suspicious email from a familiar email address, do not open it, but rather send a new email (don't reply or forward the suspicious email - you would just be passing the virus on) to your acquaintance and ask to confirm whether the email was legitimate. The nastiness of this virus is that it gets your cooperation and consent to opt-in to their service, which allows them to sell your email address and bombard you with future emails. And for your effort you are rewarded with a very nasty virus. Thanks Nico ________________________________________________________________________________
Subject: Re:
Date: Aug 23, 2007
i do Harry 321 267-3141 ----- Original Message ----- From: MASON CHEVAILLIER To: commander-list Sent: Thursday, August 23, 2007 3:59 PM Subject: Commander-List: anyone have a fuel shut off valve pn AV16B1159 and the O-rings S-0310-219F x4 to install. PCAA mason ________________________________________________________________________________
Subject: mander-List:
Date: Aug 23, 2007
hm, tnx ur help. pls fwd two(2) each of the fuel shutoff valves part #AV1 6B1159 and required O-rings four(4) part#S-0310-219F to PRO AVIATION 221 AVIATION WAY #200 Fort Worth, Texas 76106. monday morn AM delivery. enc lose invoice for $400.00 and I will send you a "good" check to the return a ddress. thank you mason 817-517-4977 From: avtec2(at)bellsouth.netTo: commander-list(at)matronics.comSubject: Re: Comm ander-List: Date: Thu, 23 Aug 2007 16:27:11 -0400 i do Harry 321 267-3141 ----- Original Message ----- From: MASON CHEVAILLIER Sent: Thursday, August 23, 2007 3:59 PM Subject: Commander-List: anyone have a fuel shut off valve pn AV16B1159 and the O-rings S-0310-219F x4 to install. PCAA mason href="http://www.matronics.com/Navigator?Commander-List">http://www.matro nics.com/Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: Aug 23, 2007
Guys, When I saw this e-mail regarding the IO-550 conversion, I thought this is great...then I called a friend who bought a NEW Beech A36 with all the horns and whistles about 5 years ago and I ask him about the IO-550. The man knows engines...and he says "I It is the most disgusting, badly engineered piece of machinery that I can remember buying. I have had to replace at least three cylinders in 1000 hours and I am now having to replace the whole engine because corrosion has ruined the cylinders, camshafts and followers. All of this in spite of following Continental's book recommendations, Flight Safety's cooling rec's. and changing the oil every 25 hours. It is the worst aircraft engine I have ever owned and is the first that I've owned since new." "Can you believe corrosion on an engine that averages more than 150 hrs a year. (always hanger kept) It never actually broke down in flight!" A friend of his has a A36 plus a Baron...same engine..lots of problems, Baron making metal both engines. New airplanes guys. I'm sure others have heard the war stories. Hey, don't shoot me....I am just relaying the message. http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Subject: IGSO 540 Lyc ?
Date: Aug 23, 2007
All, I posted some messages earlier this year about shopping for a Commander (a newbee), and got some great comments, which I appreciate. Now, I've found an attractive plane with the IGSO 540s on them and am concerned about the cost of operating, maintenance and OH costs. Can anyone comment, goods and bads? Larry Olson St. Pete On Aug 8, 2007, at 3:56 PM, Bill Bow wrote: > Well, it is finished. As of Monday I became an ex-Commander > owner. I wish my 500A had been what it was represented as when I > bought it as I would still own it today. > > I had written up a long diatribe, venting my anger and disgust with > a few of those involved in the Commander community. However, I > have decided it would be counterproductive, and nobody really gives > a s---- anyway. I have made a lot of good friends on this list > some that I will probably never meet. I do believe there are a lot > more good guys here than gold diggers. > > I will always remember the supportive words of one person on this > list Commander ownership is not for everybody. > > Well, its not for me. > > Cheers, > > Bill Bow > > http://www.matronics.com/Navigator?Commander-List _- > =========================================================== ________________________________________________________________________________
Date: Aug 24, 2007
Hi Larry, Regarding the IGSO 540 Lycoming engines: After flying about 800 hours in my 6800F(p) with these engines, here are a few comments: They are the most expensive six cylinder engines to overhaul that Lycoming makes. Also, they are the shortest TBO. Figure about 1,200 hours if flown properly. Figure between $ 42,000.00 and $ 60,000.00 each for a good major. Do a quality overhaul with NEW cylinders. At the same time be sure to have the gear boxes completely rebuilt. The above figures should include a gear drive rebuild. If the engines are B1A engines with the 12 ignition coils mounted up on top, Continental has an STC to convert them to conventional mags. This will be a much more trouble free system, and less expensive than replace all of the low and high tension leads on the 12 coil set up. Lycoming no longer has the leads available. As far as driving a plane with these engines, a very special technique must be learned. Treat them right and they will do a good job for you. 380 HP per wing is a wonderful thing, and the "cool factor" can't be beat. As an example for special driving, 1. never push the propeller levers foreword when descending to land. Your GUMPS check becomes a GUMS check. If you push foreword on the propeller levers you will kill the planetary gears in short order. Never idle or taxi at below 1,200 RPM (1,500 preferred). If you do the Simmonds injection system will surge and you can hear the gear boxes rattling. Again this destroys them. In most cases (in most planes) do not use take off power to take off. Unless it is a short track, and the air is thin, or you are really heavy, the top of the green arc on both the RPM and Manifold Pressure will still give you more power than any one else has, and will extend the life of the engines big time. If you seek instruction (this sounds "tacky") go fly with someone who has paid the bills out of his (or her) own pocket for about 600 or more hours. These engines require very special handling. Given the special handling things will be just great! Having said all of the above, one additional comment should be made. Some time ago, I had an engine out on take off, 500 feet agl, fairly heavy, at night. After going to take off power on the good engine, and getting the inoperative engine's propeller feathered, it pretty much became a non event. With a smaller and weaker engine the results could have been quite different. Personally, I would not swap my IGSO 540's for all of the Continentals that you could stack in front of me. Moe Mills N680RR 680F(p) -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of asgroup(at)tampabay.rr.com Sent: Thursday, August 23, 2007 8:19 PM Subject: Commander-List: IGSO 540 Lyc ? All, I posted some messages earlier this year about shopping for a Commander (a newbee), and got some great comments, which I appreciate. Now, I've found an attractive plane with the IGSO 540s on them and am concerned about the cost of operating, maintenance and OH costs. Can anyone comment, goods and bads? Larry Olson St. Pete On Aug 8, 2007, at 3:56 PM, Bill Bow wrote: > Well, it is finished. As of Monday I became an ex-Commander > owner. I wish my 500A had been what it was represented as when I > bought it as I would still own it today. > > I had written up a long diatribe, venting my anger and disgust with > a few of those involved in the Commander community. However, I > have decided it would be counterproductive, and nobody really gives > a s---- anyway. I have made a lot of good friends on this list > some that I will probably never meet. I do believe there are a lot > more good guys here than "gold diggers". > > I will always remember the supportive words of one person on this > list "Commander ownership is not for everybody". > > Well, it's not for me. > > Cheers, > > Bill Bow > > http://www.matronics.com/Navigator?Commander-List _- > =========================================================== ________________________________________________________________________________
Subject: 500A IO-550 Conversion
Date: Aug 24, 2007
From: Bruce Campbell <brcamp(at)windows.microsoft.com>
The IO-550 had a recall just after I bought mine. They had a number of poorly nickelled cylinders and wanted everyone who bought one to get an inspection, then the bad cylinders would be replaced. I never thought that would work, since they didn't keep track of the serial numbers of the bad cylinders, or what engines they went on. I was, BTW, highly less than thrilled to be exposed to having my factory new engine turn into a field overhaul to new specs at 10 hours operation time. Continental was very clear they really didn't see that as their problem. The actual words of the TCM rep at Oshkosh were a very snarky "If you don't like it, sue us." It didn't come to that because the inspection showed no problem. I suspect he got some of those bad cylinders, and they didn't find them in the inspection, or something similar. Just to be clear, I don't personally recommend TCM engines, period. I think their customer orientation and business practices are very poor indeed. I *do* think that if you are using IO 520s that the IO 550 is a better deal from a number of directions, for essentially the same price. But, if you can upgrade from IO520s to current production Lycomings (500A to 500B conversion+STC(?)) that would be better still. Bruce From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of KenWHyde(at)aol.com Sent: Thursday, August 23, 2007 6:32 PM Subject: Re: Commander-List: 500A IO-550 Conversion Guys, When I saw this e-mail regarding the IO-550 conversion, I thought this is great...then I called a friend who bought a NEW Beech A36 with all the horns and whistles about 5 years ago and I ask him about the IO-550. The man knows engines...and he says "I It is the most disgusting, badly engineered piece of machinery that I can remember buying. I have had to replace at least three cylinders in 1000 hours and I am now having to replace the whole engine because corrosion has ruined the cylinders, camshafts and followers. All of this in spite of following Continental's book recommendations, Flight Safety's cooling rec's. and changing the oil every 25 hours. It is the worst aircraft engine I have ever owned and is the first that I've owned since new." "Can you believe corrosion on an engine that averages more than 150 hrs a year. (always hanger kept) It never actually broke down in flight!" A friend of his has a A36 plus a Baron...same engine..lots of problems, Baron making metal both engines. New airplanes guys. I'm sure others have heard the war stories. Hey, don't shoot me....I am just relaying the message. ________________________________ AOL.com. ________________________________________________________________________________
Date: Aug 24, 2007
Subject: Re: IGSO 540 Lyc ?
Wow Moe, nicely said! I think that about covers it.... /John Moe - Ross Racing Pistons wrote: > > Hi Larry, > > Regarding the IGSO 540 Lycoming engines: > > After flying about 800 hours in my 6800F(p) with these engines, here are a > few comments: > > They are the most expensive six cylinder engines to overhaul that Lycoming > makes. Also, they are the shortest TBO. Figure about 1,200 hours if flown > properly. Figure between $ 42,000.00 and $ 60,000.00 each for a good major. > Do a quality overhaul with NEW cylinders. At the same time be sure to have > the gear boxes completely rebuilt. The above figures should include a gear > drive rebuild. If the engines are B1A engines with the 12 ignition coils > mounted up on top, Continental has an STC to convert them to conventional > mags. This will be a much more trouble free system, and less expensive than > replace all of the low and high tension leads on the 12 coil set up. > Lycoming no longer has the leads available. > > As far as driving a plane with these engines, a very special technique must > be learned. Treat them right and they will do a good job for you. 380 HP > per wing is a wonderful thing, and the "cool factor" can't be beat. As an > example for special driving, 1. never push the propeller levers foreword > when descending to land. Your GUMPS check becomes a GUMS check. If you > push foreword on the propeller levers you will kill the planetary gears in > short order. Never idle or taxi at below 1,200 RPM (1,500 preferred). If > you do the Simmonds injection system will surge and you can hear the gear > boxes rattling. Again this destroys them. In most cases (in most planes) do > not use take off power to take off. Unless it is a short track, and the air > is thin, or you are really heavy, the top of the green arc on both the RPM > and Manifold Pressure will still give you more power than any one else has, > and will extend the life of the engines big time. > > If you seek instruction (this sounds "tacky") go fly with someone who has > paid the bills out of his (or her) own pocket for about 600 or more hours. > These engines require very special handling. Given the special handling > things will be just great! > > Having said all of the above, one additional comment should be made. Some > time ago, I had an engine out on take off, 500 feet agl, fairly heavy, at > night. After going to take off power on the good engine, and getting the > inoperative engine's propeller feathered, it pretty much became a non event. > With a smaller and weaker engine the results could have been quite > different. > > Personally, I would not swap my IGSO 540's for all of the Continentals that > you could stack in front of me. > > Moe Mills > N680RR > 680F(p) > > -----Original Message----- > From: owner-commander-list-server(at)matronics.com > [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of > asgroup(at)tampabay.rr.com > Sent: Thursday, August 23, 2007 8:19 PM > To: commander-list(at)matronics.com > Subject: Commander-List: IGSO 540 Lyc ? > > > All, > > I posted some messages earlier this year about shopping for a > Commander (a newbee), and got some great comments, which I appreciate. > > Now, I've found an attractive plane with the IGSO 540s on them and am > concerned about the cost of operating, maintenance and OH costs. > > Can anyone comment, goods and bads? > > > Larry Olson > St. Pete > > > On Aug 8, 2007, at 3:56 PM, Bill Bow wrote: > > >> Well, it is finished. As of Monday I became an ex-Commander >> owner. I wish my 500A had been what it was represented as when I >> bought it as I would still own it today. >> >> I had written up a long diatribe, venting my anger and disgust with >> a few of those involved in the Commander community. However, I >> have decided it would be counterproductive, and nobody really gives >> a s---- anyway. I have made a lot of good friends on this list >> some that I will probably never meet. I do believe there are a lot >> more good guys here than "gold diggers". >> >> I will always remember the supportive words of one person on this >> list "Commander ownership is not for everybody". >> >> Well, it's not for me. >> >> Cheers, >> >> Bill Bow >> >> http://www.matronics.com/Navigator?Commander-List _- >> =========================================================== >> > > > __________ NOD32 2481 (20070823) Information __________ > > > ________________________________________________________________________________
Date: Aug 24, 2007
I agree, I do the same on my 560F and would not change them AB http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Date: Aug 24, 2007
Moe, Thanks much. What kind of performance do you plan on? Speed, fuel consumption, range? Also, do you operate them lean of peak? Larry Olson St. Pete On Aug 24, 2007, at 10:41 AM, Moe - Ross Racing Pistons wrote: > > > Hi Larry, > > Regarding the IGSO 540 Lycoming engines: > > After flying about 800 hours in my 6800F(p) with these engines, > here are a > few comments: > > They are the most expensive six cylinder engines to overhaul that > Lycoming > makes. Also, they are the shortest TBO. Figure about 1,200 hours > if flown > properly. Figure between $ 42,000.00 and $ 60,000.00 each for a > good major. > Do a quality overhaul with NEW cylinders. At the same time be sure > to have > the gear boxes completely rebuilt. The above figures should include > a gear > drive rebuild. If the engines are B1A engines with the 12 ignition > coils > mounted up on top, Continental has an STC to convert them to > conventional > mags. This will be a much more trouble free system, and less > expensive than > replace all of the low and high tension leads on the 12 coil set up. > Lycoming no longer has the leads available. > > As far as driving a plane with these engines, a very special > technique must > be learned. Treat them right and they will do a good job for you. > 380 HP > per wing is a wonderful thing, and the "cool factor" can't be > beat. As an > example for special driving, 1. never push the propeller levers > foreword > when descending to land. Your GUMPS check becomes a GUMS check. > If you > push foreword on the propeller levers you will kill the planetary > gears in > short order. Never idle or taxi at below 1,200 RPM (1,500 > preferred). If > you do the Simmonds injection system will surge and you can hear > the gear > boxes rattling. Again this destroys them. In most cases (in most > planes) do > not use take off power to take off. Unless it is a short track, > and the air > is thin, or you are really heavy, the top of the green arc on both > the RPM > and Manifold Pressure will still give you more power than any one > else has, > and will extend the life of the engines big time. > > If you seek instruction (this sounds "tacky") go fly with someone > who has > paid the bills out of his (or her) own pocket for about 600 or more > hours. > These engines require very special handling. Given the special > handling > things will be just great! > > Having said all of the above, one additional comment should be > made. Some > time ago, I had an engine out on take off, 500 feet agl, fairly > heavy, at > night. After going to take off power on the good engine, and > getting the > inoperative engine's propeller feathered, it pretty much became a > non event. > With a smaller and weaker engine the results could have been quite > different. > > Personally, I would not swap my IGSO 540's for all of the > Continentals that > you could stack in front of me. > > Moe Mills > N680RR > 680F(p) > > -----Original Message----- > From: owner-commander-list-server(at)matronics.com > [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of > asgroup(at)tampabay.rr.com > Sent: Thursday, August 23, 2007 8:19 PM > To: commander-list(at)matronics.com > Subject: Commander-List: IGSO 540 Lyc ? > > > All, > > I posted some messages earlier this year about shopping for a > Commander (a newbee), and got some great comments, which I appreciate. > > Now, I've found an attractive plane with the IGSO 540s on them and am > concerned about the cost of operating, maintenance and OH costs. > > Can anyone comment, goods and bads? > > > Larry Olson > St. Pete > > > On Aug 8, 2007, at 3:56 PM, Bill Bow wrote: > >> Well, it is finished. As of Monday I became an ex-Commander >> owner. I wish my 500A had been what it was represented as when I >> bought it as I would still own it today. >> >> I had written up a long diatribe, venting my anger and disgust with >> a few of those involved in the Commander community. However, I >> have decided it would be counterproductive, and nobody really gives >> a s---- anyway. I have made a lot of good friends on this list >> some that I will probably never meet. I do believe there are a lot >> more good guys here than "gold diggers". >> >> I will always remember the supportive words of one person on this >> list "Commander ownership is not for everybody". >> >> Well, it's not for me. >> >> Cheers, >> >> Bill Bow >> >> http://www.matronics.com/Navigator?Commander-List _- >> =========================================================== > > ________________________________________________________________________________
Subject: Re: 500A IO-550 Conversion
Date: Aug 24, 2007
All, First, I must have missed it, but what airframes is the IO550 conversion for, and who offers the STC? Thx. Now, I must comment on the Continental vs. Lyc debate, and we could run this forever. But, I'm running a pair of IO550Cs in our Baron that have performed flawlessly over the last 800 hours since new. I've also got 1000s of hours behind the 520s and the Lyc TSIO 540s. They both have their goods and bads and issues. I've had fairly good luck with all of them. I did have to top the Lycs but I haven't had but a few cylinders of of the Continental 520 and 470s over ~5000 hours of operation, and most go beyond TBO. The Continentals seem to be more fuel efficient but the Lycs seems to be stronger. Just a feeling.... no data. Food for thought. Larry Olson St. Pete On Aug 24, 2007, at 12:51 PM, Bruce Campbell wrote: > The IO-550 had a recall just after I bought mine. They had a > number of poorly nickelled cylinders and wanted everyone who bought > one to get an inspection, then the bad cylinders would be > replaced. I never thought that would work, since they didnt keep > track of the serial numbers of the bad cylinders, or what engines > they went on. I was, BTW, highly less than thrilled to be exposed > to having my factory new engine turn into a field overhaul to new > specs at 10 hours operation time. Continental was very clear they > really didnt see that as their problem. The actual words of the > TCM rep at Oshkosh were a very snarky If you dont like it, sue > us. It didnt come to that because the inspection showed no > problem. > > > I suspect he got some of those bad cylinders, and they didnt find > them in the inspection, or something similar. > > > Just to be clear, I dont personally recommend TCM engines, > period. I think their customer orientation and business practices > are very poor indeed. I *do* think that if you are using IO 520s > that the IO 550 is a better deal from a number of directions, for > essentially the same price. But, if you can upgrade from IO520s to > current production Lycomings (500A to 500B conversion+STC(?)) that > would be better still. > > > Bruce > > > From: owner-commander-list-server(at)matronics.com [mailto:owner- > commander-list-server(at)matronics.com] On Behalf Of KenWHyde(at)aol.com > Sent: Thursday, August 23, 2007 6:32 PM > To: commander-list(at)matronics.com > Subject: Re: Commander-List: 500A IO-550 Conversion > > > Guys, > > > When I saw this e-mail regarding the IO-550 conversion, I thought > this is great...then I called a friend who bought a NEW Beech A36 > with all the horns and whistles about 5 years ago and I ask him > about the IO-550. The man knows engines...and he says "I It is the > most disgusting, badly engineered piece of machinery that I can > remember buying. I have had to replace at least three cylinders in > 1000 hours and I am now having to replace the whole engine because > corrosion has ruined the cylinders, camshafts and followers. All of > this in spite of following Continental's book recommendations, > Flight Safety's cooling rec's. and changing the oil every 25 hours. > It is the worst aircraft engine I have ever owned and is the first > that I've owned since new." > > "Can you believe corrosion on an engine that averages more than 150 > hrs a year. (always hanger kept) > > It never actually broke down in flight!" A friend of his has a A36 > plus a Baron...same engine..lots of problems, Baron making metal > both engines. New airplanes guys. I'm sure others have heard the > war stories. Hey, don't shoot me....I am just relaying the message. > > > AOL.com. > > http://www.matronics.com/Navigator?Commander-Listhttp:// > forums.matronics.com > http://www.matronics.com/Navigator?Commander-List_- > ============================================================ _- > forums.matronics.com_- > =========================================================== ________________________________________________________________________________
Date: Aug 24, 2007
Larry, I generally run full rich during climb out and decent. Generally, the plane seems to like about 15,000 through 17,999 altitudes. After leveling off at altitude, lean to 100'F. lean of peak. At that point the engine is running so lean that it can't hurt its self about 60 to 65% of total power or about 240 HP per side. Don't forget to go back to full rich before descending and be careful of the manifold pressure when descending as the pressure can come up pretty quick as the air gets thicker and it is very easy to over boost the engines. Also be careful on the ground when you advance the throttles, as you can over boost the engines big time! The Simmons injection system will keep the engines with about the right fuel/ air mixture going up and coming down. What type of plane are you considering? If you would like to talk some time call me at 31o.536.0100. Be sure to tell our receptionist that you are "from the airport" or you may get the old "he is currently not here and we don't expect him back for a few years" routine. Regards, Moe -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of asgroup(at)tampabay.rr.com Sent: Friday, August 24, 2007 11:28 AM Subject: Re: Commander-List: IGSO 540 Lyc ? Moe, Thanks much. What kind of performance do you plan on? Speed, fuel consumption, range? Also, do you operate them lean of peak? Larry Olson St. Pete On Aug 24, 2007, at 10:41 AM, Moe - Ross Racing Pistons wrote: > > > Hi Larry, > > Regarding the IGSO 540 Lycoming engines: > > After flying about 800 hours in my 6800F(p) with these engines, > here are a > few comments: > > They are the most expensive six cylinder engines to overhaul that > Lycoming > makes. Also, they are the shortest TBO. Figure about 1,200 hours > if flown > properly. Figure between $ 42,000.00 and $ 60,000.00 each for a > good major. > Do a quality overhaul with NEW cylinders. At the same time be sure > to have > the gear boxes completely rebuilt. The above figures should include > a gear > drive rebuild. If the engines are B1A engines with the 12 ignition > coils > mounted up on top, Continental has an STC to convert them to > conventional > mags. This will be a much more trouble free system, and less > expensive than > replace all of the low and high tension leads on the 12 coil set up. > Lycoming no longer has the leads available. > > As far as driving a plane with these engines, a very special > technique must > be learned. Treat them right and they will do a good job for you. > 380 HP > per wing is a wonderful thing, and the "cool factor" can't be > beat. As an > example for special driving, 1. never push the propeller levers > foreword > when descending to land. Your GUMPS check becomes a GUMS check. > If you > push foreword on the propeller levers you will kill the planetary > gears in > short order. Never idle or taxi at below 1,200 RPM (1,500 > preferred). If > you do the Simmonds injection system will surge and you can hear > the gear > boxes rattling. Again this destroys them. In most cases (in most > planes) do > not use take off power to take off. Unless it is a short track, > and the air > is thin, or you are really heavy, the top of the green arc on both > the RPM > and Manifold Pressure will still give you more power than any one > else has, > and will extend the life of the engines big time. > > If you seek instruction (this sounds "tacky") go fly with someone > who has > paid the bills out of his (or her) own pocket for about 600 or more > hours. > These engines require very special handling. Given the special > handling > things will be just great! > > Having said all of the above, one additional comment should be > made. Some > time ago, I had an engine out on take off, 500 feet agl, fairly > heavy, at > night. After going to take off power on the good engine, and > getting the > inoperative engine's propeller feathered, it pretty much became a > non event. > With a smaller and weaker engine the results could have been quite > different. > > Personally, I would not swap my IGSO 540's for all of the > Continentals that > you could stack in front of me. > > Moe Mills > N680RR > 680F(p) > > -----Original Message----- > From: owner-commander-list-server(at)matronics.com > [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of > asgroup(at)tampabay.rr.com > Sent: Thursday, August 23, 2007 8:19 PM > To: commander-list(at)matronics.com > Subject: Commander-List: IGSO 540 Lyc ? > > > All, > > I posted some messages earlier this year about shopping for a > Commander (a newbee), and got some great comments, which I appreciate. > > Now, I've found an attractive plane with the IGSO 540s on them and am > concerned about the cost of operating, maintenance and OH costs. > > Can anyone comment, goods and bads? > > > Larry Olson > St. Pete > > > On Aug 8, 2007, at 3:56 PM, Bill Bow wrote: > >> Well, it is finished. As of Monday I became an ex-Commander >> owner. I wish my 500A had been what it was represented as when I >> bought it as I would still own it today. >> >> I had written up a long diatribe, venting my anger and disgust with >> a few of those involved in the Commander community. However, I >> have decided it would be counterproductive, and nobody really gives >> a s---- anyway. I have made a lot of good friends on this list >> some that I will probably never meet. I do believe there are a lot >> more good guys here than "gold diggers". >> >> I will always remember the supportive words of one person on this >> list "Commander ownership is not for everybody". >> >> Well, it's not for me. >> >> Cheers, >> >> Bill Bow >> >> http://www.matronics.com/Navigator?Commander-List _- >> =========================================================== > > ________________________________________________________________________________
From: "Robert S. Randazzo" <rsrandazzo(at)precisionmanuals.com>
Date: Aug 24, 2007
Moe- Can I send our secretary's for training with yours? Robert Randazzo -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Moe - Ross Racing Pistons Sent: Friday, August 24, 2007 12:14 PM Subject: RE: Commander-List: IGSO 540 Lyc ? Larry, I generally run full rich during climb out and decent. Generally, the plane seems to like about 15,000 through 17,999 altitudes. After leveling off at altitude, lean to 100'F. lean of peak. At that point the engine is running so lean that it can't hurt its self about 60 to 65% of total power or about 240 HP per side. Don't forget to go back to full rich before descending and be careful of the manifold pressure when descending as the pressure can come up pretty quick as the air gets thicker and it is very easy to over boost the engines. Also be careful on the ground when you advance the throttles, as you can over boost the engines big time! The Simmons injection system will keep the engines with about the right fuel/ air mixture going up and coming down. What type of plane are you considering? If you would like to talk some time call me at 31o.536.0100. Be sure to tell our receptionist that you are "from the airport" or you may get the old "he is currently not here and we don't expect him back for a few years" routine. Regards, Moe -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of asgroup(at)tampabay.rr.com Sent: Friday, August 24, 2007 11:28 AM Subject: Re: Commander-List: IGSO 540 Lyc ? Moe, Thanks much. What kind of performance do you plan on? Speed, fuel consumption, range? Also, do you operate them lean of peak? Larry Olson St. Pete On Aug 24, 2007, at 10:41 AM, Moe - Ross Racing Pistons wrote: > > > Hi Larry, > > Regarding the IGSO 540 Lycoming engines: > > After flying about 800 hours in my 6800F(p) with these engines, > here are a > few comments: > > They are the most expensive six cylinder engines to overhaul that > Lycoming > makes. Also, they are the shortest TBO. Figure about 1,200 hours > if flown > properly. Figure between $ 42,000.00 and $ 60,000.00 each for a > good major. > Do a quality overhaul with NEW cylinders. At the same time be sure > to have > the gear boxes completely rebuilt. The above figures should include > a gear > drive rebuild. If the engines are B1A engines with the 12 ignition > coils > mounted up on top, Continental has an STC to convert them to > conventional > mags. This will be a much more trouble free system, and less > expensive than > replace all of the low and high tension leads on the 12 coil set up. > Lycoming no longer has the leads available. > > As far as driving a plane with these engines, a very special > technique must > be learned. Treat them right and they will do a good job for you. > 380 HP > per wing is a wonderful thing, and the "cool factor" can't be > beat. As an > example for special driving, 1. never push the propeller levers > foreword > when descending to land. Your GUMPS check becomes a GUMS check. > If you > push foreword on the propeller levers you will kill the planetary > gears in > short order. Never idle or taxi at below 1,200 RPM (1,500 > preferred). If > you do the Simmonds injection system will surge and you can hear > the gear > boxes rattling. Again this destroys them. In most cases (in most > planes) do > not use take off power to take off. Unless it is a short track, > and the air > is thin, or you are really heavy, the top of the green arc on both > the RPM > and Manifold Pressure will still give you more power than any one > else has, > and will extend the life of the engines big time. > > If you seek instruction (this sounds "tacky") go fly with someone > who has > paid the bills out of his (or her) own pocket for about 600 or more > hours. > These engines require very special handling. Given the special > handling > things will be just great! > > Having said all of the above, one additional comment should be > made. Some > time ago, I had an engine out on take off, 500 feet agl, fairly > heavy, at > night. After going to take off power on the good engine, and > getting the > inoperative engine's propeller feathered, it pretty much became a > non event. > With a smaller and weaker engine the results could have been quite > different. > > Personally, I would not swap my IGSO 540's for all of the > Continentals that > you could stack in front of me. > > Moe Mills > N680RR > 680F(p) > > -----Original Message----- > From: owner-commander-list-server(at)matronics.com > [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of > asgroup(at)tampabay.rr.com > Sent: Thursday, August 23, 2007 8:19 PM > To: commander-list(at)matronics.com > Subject: Commander-List: IGSO 540 Lyc ? > > > All, > > I posted some messages earlier this year about shopping for a > Commander (a newbee), and got some great comments, which I appreciate. > > Now, I've found an attractive plane with the IGSO 540s on them and am > concerned about the cost of operating, maintenance and OH costs. > > Can anyone comment, goods and bads? > > > Larry Olson > St. Pete > > > On Aug 8, 2007, at 3:56 PM, Bill Bow wrote: > >> Well, it is finished. As of Monday I became an ex-Commander >> owner. I wish my 500A had been what it was represented as when I >> bought it as I would still own it today. >> >> I had written up a long diatribe, venting my anger and disgust with >> a few of those involved in the Commander community. However, I >> have decided it would be counterproductive, and nobody really gives >> a s---- anyway. I have made a lot of good friends on this list >> some that I will probably never meet. I do believe there are a lot >> more good guys here than "gold diggers". >> >> I will always remember the supportive words of one person on this >> list "Commander ownership is not for everybody". >> >> Well, it's not for me. >> >> Cheers, >> >> Bill Bow >> >> http://www.matronics.com/Navigator?Commander-List _- >> =========================================================== > > __________ NOD32 2483 (20070824) Information __________ ________________________________________________________________________________
Subject: Re: mander-List:
Date: Aug 24, 2007
Shippe today for monday $ 449.75 i put a shipping lable in the packing list pouch to return the old valves Thanks ( i will get seat bolts tommorow Harry ----- Original Message ----- From: MASON CHEVAILLIER To: commander-list(at)matronics.com Sent: Thursday, August 23, 2007 4:59 PM Subject: RE: Commander-List: hm, tnx ur help. pls fwd two(2) each of the fuel shutoff valves part #AV16B1159 and required O-rings four(4) part#S-0310-219F to PRO AVIATION 221 AVIATION WAY #200 Fort Worth, Texas 76106. monday morn AM delivery. enclose invoice for $400.00 and I will send you a "good" check to the return address. thank you mason 817-517-4977 ------------------------------------------------------------------------- --- From: avtec2(at)bellsouth.net To: commander-list(at)matronics.com Subject: Re: Commander-List: Date: Thu, 23 Aug 2007 16:27:11 -0400 i do Harry 321 267-3141 ----- Original Message ----- From: MASON CHEVAILLIER To: commander-list Sent: Thursday, August 23, 2007 3:59 PM Subject: Commander-List: anyone have a fuel shut off valve pn AV16B1159 and the O-rings S-0310-219F x4 to install. PCAA mason href="http://www.matronics.com/Navigator?Commander-List">http://www.mat ronics.com/Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com " target=_blank>http://www.matronics.com/Navigator?Commander-List p://forums.matronics.com ________________________________________________________________________________
Date: Aug 24, 2007
Isn't this email net terrific? You can actually get information built upon experience here. Thanks, Moe. Wing Commander Gordon http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
From: "Moe - Ross Racing Pistons" <moe(at)rosspistons.com>
Date: Aug 24, 2007
Wing Commander Gordon, After reading your words of wit and wisdom for quite some time now, it seemed only fitting that I should finally write something other than my usual request for free technical information. Best regards, Moe _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of CloudCraft(at)aol.com Sent: Friday, August 24, 2007 5:51 PM Subject: Re: Commander-List: IGSO 540 Lyc ? Isn't this email net terrific? You can actually get information built upon experience here. Thanks, Moe. Wing Commander Gordon AOL.com. ________________________________________________________________________________
Subject: My new partner Ken
From: "brent-mueller(at)comcast.net" <aerocommander-560e(at)comcast.net>
Date: Aug 24, 2007
Hello everyone, Just wanted all to know, I have a new partner in the AC-560E. I am sure he will be surfing thru this good site & asking questions. Please give him a warm welcome. His name is Ken. Have a great weekend. Brent - N224HA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=130911#130911 ________________________________________________________________________________
Date: Aug 24, 2007
REALLY WELL SAID, GREAT ADVICE.? THANKS MOE!!!? jb -----Original Message----- From: Moe - Ross Racing Pistons <moe(at)rosspistons.com> Sent: Fri, 24 Aug 2007 7:41 am Subject: RE: Commander-List: IGSO 540 Lyc ? Hi Larry, Regarding the IGSO 540 Lycoming engines: After flying about 800 hours in my 6800F(p) with these engines, here are a few comments: They are the most expensive six cylinder engines to overhaul that Lycoming makes. Also, they are the shortest TBO. Figure about 1,200 hours if flown properly. Figure between $ 42,000.00 and $ 60,000.00 each for a good major. Do a quality overhaul with NEW cylinders. At the same time be sure to have the gear boxes completely rebuilt. The above figures should include a gear drive rebuild. If the engines are B1A engines with the 12 ignition coils mounted up on top, Continental has an STC to convert them to conventional mags. This will be a much more trouble free system, and less expensive than replace all of the low and high tension leads on the 12 coil set up. Lycoming no longer has the leads available. As far as driving a plane with these engines, a very special technique must be learned. Treat them right and they will do a good job for you. 380 HP per wing is a wonderful thing, and the "cool factor" can't be beat. As an example for special driving, 1. never push the propeller levers foreword when descending to land. Your GUMPS check becomes a GUMS check. If you push foreword on the propeller levers you will kill the planetary gears in short order. Never idle or taxi at below 1,200 RPM (1,500 preferred). If you do the Simmonds injection system will surge and you can hear the gear boxes rattling. Again this destroys them. In most cases (in most planes) do not use take off power to take off. Unless it is a short track, and the air is thin, or you are really heavy, the top of the green arc on both the RPM and Manifold Pressure will still give you more power than any one else has, and will extend the life of the engines big time. If you seek instruction (this sounds "tacky") go fly with someone who has paid the bills out of his (or her) own pocket for about 600 or more hours. These engines require very special handling. Given the special handling things will be just great! Having said all of the above, one additional comment should be made. Some time ago, I had an engine out on take off, 500 feet agl, fairly heavy, at night. After going to take off power on the good engine, and getting the inoperative engine's propeller feathered, it pretty much became a non event. With a smaller and weaker engine the results could have been quite different. Personally, I would not swap my IGSO 540's for all of the Continentals that you could stack in front of me. Moe Mills N680RR 680F(p) -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of asgroup(at)tampabay.rr.com Sent: Thursday, August 23, 2007 8:19 PM Subject: Commander-List: IGSO 540 Lyc ? All, I posted some messages earlier this year about shopping for a Commander (a newbee), and got some great comments, which I appreciate. Now, I've found an attractive plane with the IGSO 540s on them and am concerned about the cost of operating, maintenance and OH costs. Can anyone comment, goods and bads? Larry Olson St. Pete On Aug 8, 2007, at 3:56 PM, Bill Bow wrote: > Well, it is finished. As of Monday I became an ex-Commander > owner. I wish my 500A had been what it was represented as when I > bought it as I would still own it today. > > I had written up a long diatribe, venting my anger and disgust with > a few of those involved in the Commander community. However, I > have decided it would be counterproductive, and nobody really gives > a s---- anyway. I have made a lot of good friends on this list > some that I will probably never meet. I do believe there are a lot > more good guys here than "gold diggers". > > I will always remember the supportive words of one person on this > list "Commander ownership is not for everybody". > > Well, it's not for me. > > Cheers, > > Bill Bow > > http://www.matronics.com/Navigator?Commander-List _- > =========================================================== ________________________________________________________________________ Email and AIM finally together. You've gotta check out free AOL Mail! - http://mail.aol.com ________________________________________________________________________________
Date: Aug 24, 2007
Subject: fly-in
Nico, Wing Commander Gordon, Bill and everyone,=0A I truly regret that I will not be able as I previously stated to attend the fly-in. I hope I hav e not inconvenienced anyone who had planned to catch a ride with me. I am a corporate pilot and have been assigned a trip that is inescapable on those dates. I sure was looking forward to meeting all of you!=0AHave a great ti me and best regards,=0A =0ADonnie Rose =0A205/492-8444=0A=0A=0A =0A__ ___________________________________________________________________________ _______=0ATake the Internet to Go: Yahoo!Go puts the Internet in your pocke t: mail, news, photos & more. =0Ahttp://mobile.yahoo.com/go?refer=1GNXIC ________________________________________________________________________________
Date: Aug 25, 2007
Subject: Re: fly-in
In a message dated 24-Aug-07 21:03:12 Pacific Daylight Time, aquadiver99(at)yahoo.com writes: Nico, Wing Commander Gordon, Bill and everyone, I truly regret that I will not be able as I previously stated to attend the fly-in. I hope I have not inconvenienced anyone who had planned to catch a ride with me. I am a corporate pilot and have been assigned a trip that is inescapable on those dates. I sure was looking forward to meeting all of you! Exact same problem for me. Wing Commander Gordon http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Date: Aug 25, 2007
Moe; Sounds like a man after my own heart. 'Tacky' advice or not, I agree! I do believe in 'babying' my Commander and it's engines. Believe if I take care of them, they will take care of me. And nobody looks after your money like you do. Totally opposite of "drive it like you stole it". My 560E turned FIFTY this year, so need to treat it with lots of TLC. Even when it wasn't mine, I tried to treat them gently, think that has something to do with why in 20K hrs flying I have never lost an engine or had an emergency. Always saved them for the simulator. Tomorrow that could all change, but am a big believer in a gentle hand. Don > > > Hi Larry, > > Regarding the IGSO 540 Lycoming engines: > > After flying about 800 hours in my 6800F(p) with these engines, here are a > few comments: > > They are the most expensive six cylinder engines to overhaul that Lycoming > makes. Also, they are the shortest TBO. Figure about 1,200 hours if flown > properly. Figure between $ 42,000.00 and $ 60,000.00 each for a good > major. > Do a quality overhaul with NEW cylinders. At the same time be sure to > have > the gear boxes completely rebuilt. The above figures should include a gear > drive rebuild. If the engines are B1A engines with the 12 ignition coils > mounted up on top, Continental has an STC to convert them to conventional > mags. This will be a much more trouble free system, and less expensive > than > replace all of the low and high tension leads on the 12 coil set up. > Lycoming no longer has the leads available. > > As far as driving a plane with these engines, a very special technique > must > be learned. Treat them right and they will do a good job for you. 380 HP > per wing is a wonderful thing, and the "cool factor" can't be beat. As an > example for special driving, 1. never push the propeller levers foreword > when descending to land. Your GUMPS check becomes a GUMS check. If you > push foreword on the propeller levers you will kill the planetary gears in > short order. Never idle or taxi at below 1,200 RPM (1,500 preferred). If > you do the Simmonds injection system will surge and you can hear the gear > boxes rattling. Again this destroys them. In most cases (in most planes) > do > not use take off power to take off. Unless it is a short track, and the > air > is thin, or you are really heavy, the top of the green arc on both the RPM > and Manifold Pressure will still give you more power than any one else > has, > and will extend the life of the engines big time. > > If you seek instruction (this sounds "tacky") go fly with someone who has > paid the bills out of his (or her) own pocket for about 600 or more hours. > These engines require very special handling. Given the special handling > things will be just great! > > Having said all of the above, one additional comment should be made. Some > time ago, I had an engine out on take off, 500 feet agl, fairly heavy, at > night. After going to take off power on the good engine, and getting the > inoperative engine's propeller feathered, it pretty much became a non > event. > With a smaller and weaker engine the results could have been quite > different. > > Personally, I would not swap my IGSO 540's for all of the Continentals > that > you could stack in front of me. > > Moe Mills > N680RR > 680F(p) > > -----Original Message----- > From: owner-commander-list-server(at)matronics.com > [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of > asgroup(at)tampabay.rr.com > Sent: Thursday, August 23, 2007 8:19 PM > To: commander-list(at)matronics.com > Subject: Commander-List: IGSO 540 Lyc ? > > > All, > > I posted some messages earlier this year about shopping for a > Commander (a newbee), and got some great comments, which I appreciate. > > Now, I've found an attractive plane with the IGSO 540s on them and am > concerned about the cost of operating, maintenance and OH costs. > > Can anyone comment, goods and bads? > > > Larry Olson > St. Pete > > > On Aug 8, 2007, at 3:56 PM, Bill Bow wrote: > >> Well, it is finished. As of Monday I became an ex-Commander >> owner. I wish my 500A had been what it was represented as when I >> bought it as I would still own it today. >> >> I had written up a long diatribe, venting my anger and disgust with >> a few of those involved in the Commander community. However, I >> have decided it would be counterproductive, and nobody really gives >> a s---- anyway. I have made a lot of good friends on this list >> some that I will probably never meet. I do believe there are a lot >> more good guys here than "gold diggers". >> >> I will always remember the supportive words of one person on this >> list "Commander ownership is not for everybody". >> >> Well, it's not for me. >> >> Cheers, >> >> Bill Bow >> >> http://www.matronics.com/Navigator?Commander-List _- >> =========================================================== > > > -- > 4:04 PM > > ________________________________________________________________________________
Date: Aug 25, 2007
Good Luck. bilbo -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of brent-mueller(at)comcast.net Sent: Friday, August 24, 2007 11:01 PM Subject: Commander-List: My new partner Ken Hello everyone, Just wanted all to know, I have a new partner in the AC-560E. I am sure he will be surfing thru this good site & asking questions. Please give him a warm welcome. His name is Ken. Have a great weekend. Brent - N224HA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=130911#130911 ________________________________________________________________________________
Date: Aug 25, 2007
Welcome Ken! bilbo -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of brent-mueller(at)comcast.net Sent: Friday, August 24, 2007 11:01 PM Subject: Commander-List: My new partner Ken Hello everyone, Just wanted all to know, I have a new partner in the AC-560E. I am sure he will be surfing thru this good site & asking questions. Please give him a warm welcome. His name is Ken. Have a great weekend. Brent - N224HA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=130911#130911 ________________________________________________________________________________
Date: Aug 26, 2007
Good Evening Ken, Please do not consider this as being any effort to shoot the messenger! However, I very respectfully disagree with the gentleman's impression of the engine. I think it is far and away the best effort Continental has produced in the last fifty years. Having said that, I also feel Continental has suffered greatly from poor quality control of their products during the past fifteen years or so. The move from Michigan to Mobile resulted in the loss of a dedicated work force that has been hard to replace. If you have a chance to discuss this with the Continental management, they will agree that there have been some problems, but they are confident those bad times are behind them. There was a rash of cylinder problems in the nineties that most folks will agree was due to a practice of running the engine not rich enough when at high power settings. The 550 is capable of putting out a lot of power and it takes a lot of fuel to keep it cool at those high power settings. I like to set up a freshly majored 550 at around thirty-one to thirty-two GPH for the initial takeoff until such time as the fuel balance can be determined. Once it has been assured that the distribution between the cylinders is reasonable, I like to see about twenty-nine GPH for a sea level, standard conditions, takeoff. Unfortunately, most mechanics seem hesitant to push that much fuel through the engine. Rather than get into an argument as to how much fuel is needed to develop that sort of power, may I tell of my experience with the engine? I had one installed in my Bonanza at the height of Continental's problem time frame. It was in 1996. It was without doubt the best money I have ever spent on any airplane. The increase in performance was a LOT more than I had anticipated. That engine currently is ready to be replaced and it has never had any jug removed. It has suffered from the Continental valve leakage problems during it's regular compression check, but by following the Continental recommendations on using a calibrated orifice and checking low cylinders with a borescope, the engine has easily made it to TBO. I currently have another 550 being built up by a boutique engine shop to replace the factory remanufactured one that I first had installed. Since that time, two of our sons have purchased 550s that were rebuilt by a custom overhaul shop and both those engines have performed marvelously without suffering the low compression readings common with those 1990 through 1999 factory cylinders. It is my understanding that Continental had gone to the practice of using pre fit valves instead of seating them individually as had been done in the past. While that led to bad compression checks, it did not seem to cause any serious leakage under actual operating conditions. That is why Continental developed their special Service Bulletin which includes using the calibrated orifice and the borescope to ascertain the suitability of continued operation of the cylinders. There is no doubt that I can find you plenty of folks who will tell you that the 550 is no good. I can easily find you another couple of hundred users who think as I do. There is also no doubt that the engine does need to be set up properly. Most of the earlier Bonanza installations used an Altitude Compensating Fuel Pump. That system works great, but it takes a bit more care to be set up properly. Beech has quit using it. A few old line mechanics don't care to learn how to do the setup and that can cause problems. Continental has a very complete set of instructions and if they are followed by the operator, the Altitude Compensating Pump works great. No need to lean on takeoff at higher elevations and altitude changes can be made without the necessity of constant adjustment. We who have those pumps and have had then set up as Continental has advised have had great results. This has been a bit if a rambling discourse and for that I am sorry, but as in so many cases of opinions, it is hard to know where to start. As I said earlier, I consider it to be a great engine. It is light and powerful. When the fuel control is setup the way the manufacturer suggests, it works wonderfully. Those folks who chose to run high powers with lean mixtures have encountered problems, but those of us who have chosen to operate them within the design parameters have had excellent performance. In fact, we who operate them at lower powers on the lean side of peak EGT have had exceptional service from the engines. I would be happy to discuss specifics with anyone who has the time and the data to share. The IO-550-B is a marvelous engine! Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator Stearman N3977A Brookeridge Air Park LL22 Downers Grove, IL 60516 630 985-8503 In a message dated 8/23/2007 8:33:32 P.M. Central Daylight Time, KenWHyde(at)aol.com writes: Guys, When I saw this e-mail regarding the IO-550 conversion, I thought this is great...then I called a friend who bought a NEW Beech A36 with all the horns and whistles about 5 years ago and I ask him about the IO-550. The man knows engines...and he says "I It is the most disgusting, badly engineered piece of machinery that I can remember buying. I have had to replace at least three cylinders in 1000 hours and I am now having to replace the whole engine because corrosion has ruined the cylinders, camshafts and followers. All of this in spite of following Continental's book recommendations, Flight Safety's cooling rec's. and changing the oil every 25 hours. It is the worst aircraft engine I have ever owned and is the first that I've owned since new." "Can you believe corrosion on an engine that averages more than 150 hrs a year. (always hanger kept) It never actually broke down in flight!" A friend of his has a A36 plus a Baron...same engine..lots of problems, Baron making metal both engines. New airplanes guys. I'm sure others have heard the war stories. Hey, don't shoot me....I am just relaying the message. http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Date: Aug 27, 2007
hm, parts arrived this am. there is no paperwork with them? we discussed them being "yellow tagged"? i will advise what i am doing. tnx ur hlp. ma son From: avtec2(at)bellsouth.netTo: commander-list(at)matronics.comSubject: Re: Comm ander-List:Date: Fri, 24 Aug 2007 16:12:54 -0400 Shippe today for monday $ 449.75 i put a shipping lable in the packing list pouch to return the old valves Thanks ( i will get seat bolts tommorow Harry ----- Original Message ----- From: MASON CHEVAILLIER Sent: Thursday, August 23, 2007 4:59 PM Subject: RE: Commander-List: hm, tnx ur help. pls fwd two(2) each of the fuel shutoff valves part #AV1 6B1159 and required O-rings four(4) part#S-0310-219F to PRO AVIATION 221 AVIATION WAY #200 Fort Worth, Texas 76106. monday morn AM delivery. enc lose invoice for $400.00 and I will send you a "good" check to the return a ddress. thank you mason 817-517-4977 From: avtec2(at)bellsouth.netTo: commander-list(at)matronics.comSubject: Re: Comm ander-List: Date: Thu, 23 Aug 2007 16:27:11 -0400 i do Harry 321 267-3141 ----- Original Message ----- From: MASON CHEVAILLIER Sent: Thursday, August 23, 2007 3:59 PM Subject: Commander-List: anyone have a fuel shut off valve pn AV16B1159 and the O-rings S-0310-219F x4 to install. PCAA mason href="http://www.matronics.com/Navigator?Commander-List">http://www.matro nics.com/Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com " target=_blank>http://www.matronics.com/Navigator?Commander-List p://forums.matronics.com href="http://www.matronics.com/Navigator?Commander-List">http://www.matro nics.com/Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: Aug 28, 2007
If you dont want them send them back COD on Freight. Thanks Harry ----- Original Message ----- From: MASON CHEVAILLIER To: commander-list(at)matronics.com Sent: Monday, August 27, 2007 6:08 PM Subject: RE: Commander-List: hm, parts arrived this am. there is no paperwork with them? we discussed them being "yellow tagged"? i will advise what i am doing. tnx ur hlp. mason ------------------------------------------------------------------------- --- From: avtec2(at)bellsouth.net To: commander-list(at)matronics.com Subject: Re: Commander-List: Date: Fri, 24 Aug 2007 16:12:54 -0400 Shippe today for monday $ 449.75 i put a shipping lable in the packing list pouch to return the old valves Thanks ( i will get seat bolts tommorow Harry ----- Original Message ----- From: MASON CHEVAILLIER To: commander-list(at)matronics.com Sent: Thursday, August 23, 2007 4:59 PM Subject: RE: Commander-List: hm, tnx ur help. pls fwd two(2) each of the fuel shutoff valves part #AV16B1159 and required O-rings four(4) part#S-0310-219F to PRO AVIATION 221 AVIATION WAY #200 Fort Worth, Texas 76106. monday morn AM delivery. enclose invoice for $400.00 and I will send you a "good" check to the return address. thank you mason 817-517-4977 ------------------------------------------------------------------------ From: avtec2(at)bellsouth.net To: commander-list(at)matronics.com Subject: Re: Commander-List: Date: Thu, 23 Aug 2007 16:27:11 -0400 i do Harry 321 267-3141 ----- Original Message ----- From: MASON CHEVAILLIER To: commander-list Sent: Thursday, August 23, 2007 3:59 PM Subject: Commander-List: anyone have a fuel shut off valve pn AV16B1159 and the O-rings S-0310-219F x4 to install. PCAA mason href="http://www.matronics.com/Navigator?Commander-List">http://www.mat ronics.com/Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com " target=_blank>http://www.matronics.com/Navigator?Commander-List p://forums.matronics.com href="http://www.matronics.com/Navigator?Commander-List">http://www.mat ronics.com/Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com " target=_blank>http://www.matronics.com/Navigator?Commander-List p://forums.matronics.com ________________________________________________________________________________
Subject: Weird 747 shadow
Date: Aug 28, 2007
Look at google earth at this location: 26 02 03 S, 28 14 04 E ________________________________________________________________________________
From: "Barry Collman" <barry.collman@air-britain.co.uk>
Subject: Main gear
Date: Aug 28, 2007
Hi All, Can I just check something with you all. This is for a Model 500B specifically, but I assume the scenario covers other Models. After landing, with indication that all three gears are down-and-locked, the right-hand gear retracts. It seems fairly 'common' that this is usually because the PiC has selected the gear-up switch instead of the flaps-up switch. If so, is it the right-hand gear that actuates first? Presumably, if the PiC realises his error in time, he can prevent the left-hand gear actuating? Best Regards, Barry ________________________________________________________________________________
Subject: Main gear [bcc][faked-from][html-rem]
Date: Aug 28, 2007
From: "Brock Lorber" <blorber(at)southwestcirrus.com>
This is puzzle that is going to have an interesting answer. I'm following a rabbit's warren that leads me to believe that the hydraulic pumps at idle can't pump enough volume at idle to pull both legs over center simultaneously and that there is something about the right leg (placement of the cylinder?) that makes the right leg easier to pull over center than the left leg. Once it comes over center, the resistance is a lot lower on the right side, so the left leg won't come over center until the right leg fully retracts. -----Original Message----- From: owner-commander-list-server(at)matronics.com on behalf of Barry Collman Sent: Tue 8/28/2007 7:50 AM Subject: Commander-List: Main gear [bcc][faked-from][html-rem] Hi All, Can I just check something with you all. This is for a Model 500B specifically, but I assume the scenario covers other Models. After landing, with indication that all three gears are down-and-locked, the right-hand gear retracts. It seems fairly 'common' that this is usually because the PiC has selected the gear-up switch instead of the flaps-up switch. If so, is it the right-hand gear that actuates first? Presumably, if the PiC realises his error in time, he can prevent the left-hand gear actuating? Best Regards, Barry ________________________________________________________________________________
Date: Aug 28, 2007
Subject: Re: Main gear [bcc][faked-from][html-rem]
This is a question I hope I NEVER find the answer to on my 500B. That being said, I've heard of gear retracts happening on the ground. I'm certain that ONE engine by itself makes enough pressure to retract the gear at idle, as even during warmup at low RPM, my hydraulic system is steady at 1,000 PSI regardless of steering or flap actuation. As far as right vs. left, I don't know the answer to that one... /J Brock Lorber wrote: > This is puzzle that is going to have an interesting answer. I'm following a rabbit's warren that leads me to believe that the hydraulic pumps at idle can't pump enough volume at idle to pull both legs over center simultaneously and that there is something about the right leg (placement of the cylinder?) that makes the right leg easier to pull over center than the left leg. Once it comes over center, the resistance is a lot lower on the right side, so the left leg won't come over center until the right leg fully retracts. > > > -----Original Message----- > From: owner-commander-list-server(at)matronics.com on behalf of Barry Collman > Sent: Tue 8/28/2007 7:50 AM > To: commander-list(at)matronics.com > Subject: Commander-List: Main gear [bcc][faked-from][html-rem] > > Hi All, > > Can I just check something with you all. This is for a Model 500B specifically, but I assume the scenario covers other Models. > > After landing, with indication that all three gears are down-and-locked, the right-hand gear retracts. > It seems fairly 'common' that this is usually because the PiC has selected the gear-up switch instead of the flaps-up switch. > > If so, is it the right-hand gear that actuates first? > > Presumably, if the PiC realises his error in time, he can prevent the left-hand gear actuating? > > Best Regards, > Barry > > > __________ NOD32 2488 (20070828) Information __________ > > ________________________________________________________________________________
Date: Aug 28, 2007
Subject: Re: Weird 747 shadow
Nico, All I see there is a location between Pretoria and Johannesburg, of a house with a pool.....no shadow on my version. /J nico css wrote: > > Look at google earth at this location: 26 02 03 S, 28 14 04 E > > > > * > > > * > > > __________ NOD32 2488 (20070828) Information __________ > ________________________________________________________________________________
Date: Aug 28, 2007
I see the shadow you're talking about but haven't an explanation for it. It is a 747-400 in a left turn. bilbo -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of John Vormbaum Sent: Tuesday, August 28, 2007 1:15 PM Subject: Re: Commander-List: Weird 747 shadow Nico, All I see there is a location between Pretoria and Johannesburg, of a house with a pool.....no shadow on my version. /J nico css wrote: > > Look at google earth at this location: 26 02 03 S, 28 14 04 E > > > > * > > > * > > > __________ NOD32 2488 (20070828) Information __________ > ________________________________________________________________________________
Date: Aug 28, 2007
I have a 'possible' explanation for this. The Google Earth imagery are not conventional photos, but 'orthophotos'. That is the image is composed of zillions of photographs that are mosaicked together, and processed to correct them for tip and tilt of the camera, and to correct the scale of images versus the variations in height of the land. Lots of other stuff gets done to the images..... I'm actually processing an orthophoto right now at work. (I'm hard at work, honest.) The ortho images have a lot of blending and processing done to them to have them look any good across seams, and to correct for vignetting and uneven tone across them. Its quite a trick to get all these images to look any good all stuck together at once. It is possible that the 'weirdness' is due to a computer algorithm doing its best to make sense of this little image patch, and lighten up a dark area, and darken up a bright area. Or it's something else. Steve ----- Original Message ----- From: "Bill Bow" <bowing74(at)earthlink.net> Sent: Tuesday, August 28, 2007 1:22 PM Subject: RE: Commander-List: Weird 747 shadow > > I see the shadow you're talking about but haven't an explanation for it. > It > is a 747-400 in a left turn. > > bilbo > > -----Original Message----- > From: owner-commander-list-server(at)matronics.com > [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of John > Vormbaum > Sent: Tuesday, August 28, 2007 1:15 PM > To: commander-list(at)matronics.com > Subject: Re: Commander-List: Weird 747 shadow > > > Nico, > > All I see there is a location between Pretoria and Johannesburg, of a > house with a pool.....no shadow on my version. > > /J > > nico css wrote: >> >> Look at google earth at this location: 26 02 03 S, 28 14 04 E >> >> >> >> * >> >> >> * >> >> >> __________ NOD32 2488 (20070828) Information __________ >> > > > ________________________________________________________________________________
Subject: Main gear
Date: Aug 28, 2007
I have seen two times where it was the left main gear which had collapsed. One was a failure of the retract cylinder clevis in the top of the strut housing. And the other never did have a reasonable explaination. Mike _________________________________________________________________ Tease your brain--play Clink! Win cool prizes! http://club.live.com/clink.aspx?icid=clink_hotmailtextlink2 ________________________________________________________________________________
Date: Aug 28, 2007
John, Did you copy and paste the coordinates into google earth? It should be on the edge of a suburban neighborhood. Nico -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of John Vormbaum Sent: Tuesday, August 28, 2007 10:15 AM Subject: Re: Commander-List: Weird 747 shadow Nico, All I see there is a location between Pretoria and Johannesburg, of a house with a pool.....no shadow on my version. /J nico css wrote: > > Look at google earth at this location: 26 02 03 S, 28 14 04 E > > > > * > > > * > > > __________ NOD32 2488 (20070828) Information __________ > ________________________________________________________________________________
Date: Aug 28, 2007
Thanks, Steve. That makes the most sense. Nico -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Steve at Col-East Sent: Tuesday, August 28, 2007 11:48 AM Subject: Re: Commander-List: Weird 747 shadow I have a 'possible' explanation for this. The Google Earth imagery are not conventional photos, but 'orthophotos'. That is the image is composed of zillions of photographs that are mosaicked together, and processed to correct them for tip and tilt of the camera, and to correct the scale of images versus the variations in height of the land. Lots of other stuff gets done to the images..... I'm actually processing an orthophoto right now at work. (I'm hard at work, honest.) The ortho images have a lot of blending and processing done to them to have them look any good across seams, and to correct for vignetting and uneven tone across them. Its quite a trick to get all these images to look any good all stuck together at once. It is possible that the 'weirdness' is due to a computer algorithm doing its best to make sense of this little image patch, and lighten up a dark area, and darken up a bright area. Or it's something else. Steve ----- Original Message ----- From: "Bill Bow" <bowing74(at)earthlink.net> Sent: Tuesday, August 28, 2007 1:22 PM Subject: RE: Commander-List: Weird 747 shadow > > I see the shadow you're talking about but haven't an explanation for it. > It > is a 747-400 in a left turn. > > bilbo > > -----Original Message----- > From: owner-commander-list-server(at)matronics.com > [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of John > Vormbaum > Sent: Tuesday, August 28, 2007 1:15 PM > To: commander-list(at)matronics.com > Subject: Re: Commander-List: Weird 747 shadow > > > Nico, > > All I see there is a location between Pretoria and Johannesburg, of a > house with a pool.....no shadow on my version. > > /J > > nico css wrote: >> >> Look at google earth at this location: 26 02 03 S, 28 14 04 E >> >> >> >> * >> >> >> * >> >> >> __________ NOD32 2488 (20070828) Information __________ >> > > > ________________________________________________________________________________
Date: Aug 28, 2007
That time it worked....and that is quite the funky shadow/airplane. nico css wrote: > > John, > Did you copy and paste the coordinates into google earth? It should be on > the edge of a suburban neighborhood. > Nico > > > -----Original Message----- > From: owner-commander-list-server(at)matronics.com > [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of John > Vormbaum > Sent: Tuesday, August 28, 2007 10:15 AM > To: commander-list(at)matronics.com > Subject: Re: Commander-List: Weird 747 shadow > > > Nico, > > All I see there is a location between Pretoria and Johannesburg, of a > house with a pool.....no shadow on my version. > > /J > > nico css wrote: > >> Look at google earth at this location: 26 02 03 S, 28 14 04 E >> >> >> >> * >> >> >> * >> >> >> __________ NOD32 2488 (20070828) Information __________ >> >> > > > __________ NOD32 2488 (20070828) Information __________ > > > ________________________________________________________________________________
Date: Aug 28, 2007
> Look at google earth at this location: 26 02 03 S, 28 14 04 E Yes, very interesting - note that the ghosted image is above the 'clear' 747 - I wonder if it has something to do with a second photo taken immediately after the first; the 747 having moved on since the first? I'm sure there's a better explanation... God bless, Andrew ________________________________________________________________________________
Date: Aug 28, 2007
Hi Andrew. I don't think so, because the 747 would have to have drifted south without any forward movement. The shadows of the surrounding structures indicate that it's early morning, so in that respect the blue shadow is in the right place. What is a bit off, I would say, is that the shadow indicates that the sun is slightly south of the 747, which is impossible seeing that Johannesburg is 26 deg south and the sun never gets further south than 23.5 deg. However, if the shadow was moved due to manipulation of the satellite photographs, then it might not show where it actually was. Steve gave an excellent explanation: satellite photos are not regular photos but orthophotos, which are programmatically manipulated to make the individual satellite images fit seamlessly in one image, and perhaps some shift could have changed the color of the shadow. Steve I apologize if my paraphrasing what you said has lost the message. Who knows, but it is very interesting. Nico _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of andrew.bridget(at)telus.net Sent: Tuesday, August 28, 2007 5:05 PM Subject: Re: Commander-List: Weird 747 shadow > Look at google earth at this location: 26 02 03 S, 28 14 04 E Yes, very interesting - note that the ghosted image is above the 'clear' 747 - I wonder if it has something to do with a second photo taken immediately after the first; the 747 having moved on since the first? I'm sure there's a better explanation... God bless, Andrew ________________________________________________________________________________
Date: Aug 28, 2007
Hi, yes, Nico,I think Steve is likely right; I only read his post after I responded. Talk about opening my yap before I have all the info :-) Found some other aircraft with ghosted shadows. No I didn't scan Google Earth ... well I did look at O'Hare to see if there were any on approach/climbout, and at Vancouver, Toronto, Calgary, and ... but then I gave up and cheated by looking at http://www.gearthhacks.com/dlcat24/Aircraft-in-flight.htm Steve, given this, is it not possible that two photos are taken and then overlaid to give the 3D effect when one tilts the earth to a more horizontal plane? (pun unintended) This would explain the aircraft "moving on". In each of the ghosted shadows the ghost aircraft appears to be on (or slightly higher) than the clear aircraft. However, on a slower aircraft (like the helicopter, or aircraft on finals) there isn't any ghosting.This would add to the theory that the aircraft has moved on - only fast aircraft appear to be ghosted. Blessings Andrew ----- Original Message ----- From: nico css To: commander-list(at)matronics.com Sent: Tuesday, August 28, 2007 5:23 PM Subject: RE: Commander-List: Weird 747 shadow Hi Andrew. I don't think so, because the 747 would have to have drifted south without any forward movement. The shadows of the surrounding structures indicate that it's early morning, so in that respect the blue shadow is in the right place. What is a bit off, I would say, is that the shadow indicates that the sun is slightly south of the 747, which is impossible seeing that Johannesburg is 26 deg south and the sun never gets further south than 23.5 deg. However, if the shadow was moved due to manipulation of the satellite photographs, then it might not show where it actually was. Steve gave an excellent explanation: satellite photos are not regular photos but orthophotos, which are programmatically manipulated to make the individual satellite images fit seamlessly in one image, and perhaps some shift could have changed the color of the shadow. Steve I apologize if my paraphrasing what you said has lost the message. Who knows, but it is very interesting. Nico ------------------------------------------------------------------------- ----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of andrew.bridget(at)telus.net Sent: Tuesday, August 28, 2007 5:05 PM To: commander-list(at)matronics.com Subject: Re: Commander-List: Weird 747 shadow > Look at google earth at this location: 26 02 03 S, 28 14 04 E Yes, very interesting - note that the ghosted image is above the 'clear' 747 - I wonder if it has something to do with a second photo taken immediately after the first; the 747 having moved on since the first? I'm sure there's a better explanation... God bless, Andrew ________________________________________________________________________________
Subject: Oil Leak
Date: Aug 28, 2007
-Greetings- Our valve covers leak some. what is the very best solution to oil leaking valve covers. I was told silicon ones are the ones to use, we have cork now. If cork expands with the warm oil then flattens when not run for a bit, whats th advantage over silcone? Take Care, Brent Read this topic online here: http://forums.matronics.com/viewtopic.php?p=131505#131505 ________________________________________________________________________________
Date: Aug 29, 2007
Hi Andrew, It gets a little complicated...... The 3D effect is used by many companies to create the terrain model used by so many applications. It could be flight simulators, or GPS units with ground proximity in them.... What Google is doing is using that model to 'drape' their imagery over it to give you that 3D effect. I'll take a look at those examples when I am back at a fast modem, but I have another 'possible' explanation for what you are seeing. In order for an orthophoto to be scaled properly the original photo has to stretched and shrunk to fit the terrain. Think of the left side of a photo as having a mountain, and the right side with a valley. The two sides of one photo will have different scales...... This effect is further complicated by the fact that only in the center of the image is the camera looking directly down, vertically. For most of the image, the subject is at more and more of an angle off center. This 'looking off center' is not an insolvable problem as long as the object is draped onto the terrain model. But any object that stands proud from the terrain model is going to be put in the wrong place. The higher something is, and the further off perpendicular from under the camera, the more horizontal error will be introduced when the object is forced down to the terrain model. So tall buildings will appear misplaced. Aircraft could appear a great distance from where they should have been on the earth directly beneath them..... The simple answer is; every image pixel needs a proper elevation in order to be placed accurately in horizontal. As for multiple images causing ortho-weirdness, it does all the time. Things like a baseball field with way too many players and a bunch of other errors, some of them quite funny...... David Owens, on this list, I'm sure takes quite a lot of imagery destined for ortho photos also, with their Colemill 500A..... Steve ----- Original Message ----- From: andrew.bridget(at)telus.net To: commander-list(at)matronics.com Sent: Tuesday, August 28, 2007 8:58 PM Subject: Re: Commander-List: Weird 747 shadow Hi, yes, Nico,I think Steve is likely right; I only read his post after I responded. Talk about opening my yap before I have all the info :-) Found some other aircraft with ghosted shadows. No I didn't scan Google Earth ... well I did look at O'Hare to see if there were any on approach/climbout, and at Vancouver, Toronto, Calgary, and ... but then I gave up and cheated by looking at http://www.gearthhacks.com/dlcat24/Aircraft-in-flight.htm Steve, given this, is it not possible that two photos are taken and then overlaid to give the 3D effect when one tilts the earth to a more horizontal plane? (pun unintended) This would explain the aircraft "moving on". In each of the ghosted shadows the ghost aircraft appears to be on (or slightly higher) than the clear aircraft. However, on a slower aircraft (like the helicopter, or aircraft on finals) there isn't any ghosting.This would add to the theory that the aircraft has moved on - only fast aircraft appear to be ghosted. Blessings Andrew ----- Original Message ----- From: nico css To: commander-list(at)matronics.com Sent: Tuesday, August 28, 2007 5:23 PM Subject: RE: Commander-List: Weird 747 shadow Hi Andrew. I don't think so, because the 747 would have to have drifted south without any forward movement. The shadows of the surrounding structures indicate that it's early morning, so in that respect the blue shadow is in the right place. What is a bit off, I would say, is that the shadow indicates that the sun is slightly south of the 747, which is impossible seeing that Johannesburg is 26 deg south and the sun never gets further south than 23.5 deg. However, if the shadow was moved due to manipulation of the satellite photographs, then it might not show where it actually was. Steve gave an excellent explanation: satellite photos are not regular photos but orthophotos, which are programmatically manipulated to make the individual satellite images fit seamlessly in one image, and perhaps some shift could have changed the color of the shadow. Steve I apologize if my paraphrasing what you said has lost the message. Who knows, but it is very interesting. Nico ------------------------------------------------------------------------- --- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of andrew.bridget(at)telus.net Sent: Tuesday, August 28, 2007 5:05 PM To: commander-list(at)matronics.com Subject: Re: Commander-List: Weird 747 shadow > Look at google earth at this location: 26 02 03 S, 28 14 04 E Yes, very interesting - note that the ghosted image is above the 'clear' 747 - I wonder if it has something to do with a second photo taken immediately after the first; the 747 having moved on since the first? I'm sure there's a better explanation... God bless, Andrew href="http://www.matronics.com/Navigator?Commander-List">http://www.mat ronics.com/Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Subject: Oil Leak [bcc][faked-from]
Date: Aug 29, 2007
The very best solution to oil leaking valve covers is not over-torquing the screws that hold them on. When the screws are over-torqued, they pucker the thin metal and ruin the seal with any gaskets. Keep the cork gaskets and get new valve covers. Torque the screws (with star washers) exactly as published in the overhaul manual (~ 20 inch pounds, barely more than snug). Brock -----Original Message----- From: owner-commander-list-server(at)matronics.com on behalf of brent-mueller(at)comcast.net Sent: Tue 8/28/2007 9:21 PM Subject: Commander-List: Oil Leak [bcc][faked-from] -Greetings- Our valve covers leak some. what is the very best solution to oil leaking valve covers. I was told silicon ones are the ones to use, we have cork now. If cork expands with the warm oil then flattens when not run for a bit, whats th advantage over silcone? Take Care, Brent Read this topic online here: http://forums.matronics.com/viewtopic.php?p=131505#131505 3D======================== 3D========= 3D======================== 3D========= 3D======================== 3D========= ________________________________________________________________________________
Date: Aug 29, 2007
For what its worth, I think it has to do with shutter speed. Slower shutter speed which allows better detail. In addition, a lot of these are not sat photos but are aerial photos that are piece milled in. Bert Sent via BlackBerry by AT&T -----Original Message----- From: <andrew.bridget(at)telus.net> Date: Tue, 28 Aug 2007 17:58:54 To: Subject: Re: Commander-List: Weird 747 shadow Hi, yes, Nico,I think Steve is likely right; I only read his post after I responded. Talk about opening my yap before I have all the info :-) Found some other aircraft with ghosted shadows. No I didn't scan Google Earth... well I did look at O'Hare to see if there were any on approach/climbout, and at Vancouver, Toronto, Calgary, and ... but then I gave up andcheatedbylooking at http://www.gearthhacks.com/dlcat24/Aircraft-in-flight.htm Steve, given this, is it not possible that two photos are taken and then overlaid to give the 3D effect when one tilts the earth to a more horizontal plane? (pun unintended) This would explain the aircraft "moving on". In each of the ghosted shadows the ghostaircraft appears to beon (or slightly higher)than the clear aircraft. However, on a slower aircraft (like the helicopter, or aircraft on finals) there isn't any ghosting.This would add to the theory that the aircraft has moved on - only fast aircraft appear to beghosted. Blessings Andrew ----- Original Message ----- From: nico css Sent: Tuesday, August 28, 2007 5:23 PM Subject: RE: Commander-List: Weird 747 shadow Hi Andrew. I dont think so, because the 747 would have to have drifted south without any forward movement. The shadows of the surrounding structures indicate that its early morning, so in that respect the blue shadow is in the right place. What is a bit off, I would say, is that the shadow indicates that the sun is slightly south of the 747, which is impossible seeing that Johannesburg is 26 deg south and the sun never gets further south than 23.5 deg. However, if the shadow was moved due to manipulation of the satellite photographs, then it might not show where it actually was. Steve gave an excellent explanation: satellite photos are not regular photos but orthophotos, which are programmatically manipulated to make the individual satellite images fit seamlessly in one image, and perhaps some shift could have changed the color of the shadow. Steve I apologize if my paraphrasing what you said has lost the message. Who knows, but it is very interesting. Nico ---------------- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of andrew.bridget(at)telus.net Sent: Tuesday, August 28, 2007 5:05 PM Subject: Re: Commander-List: Weird 747 shadow > Look at google earth at this location: 26 02 03 S, 28 14 04 E Yes, very interesting - note that the ghosted image is above the 'clear' 747 - I wonder if it has something to do with a second photo taken immediately after the first; the 747 having moved on since the first? I'm sure there's a better explanation... God bless, ________________________________________________________________________________
Subject: Attending your first Fly-In?
Date: Aug 29, 2007
Hi All, If any Commander owner is attending their very first Fly-In, please let me know and bring along a personalised history of their Commander(s). Very Best Regards, Barry ________________________________________________________________________________
From: "David Owens" <dowens(at)aerialviewpoint.com>
Date: Aug 29, 2007
Actually, when you use some of the GEO software such as Leica Suite, and Imagine, some of the features you can choose to "merge" the images seamlessly allow you to "feather" the images, which makes the image progressively trsnsparent to the extent of the image... to appear more seamless between frames, as well as auto dodging, which will change the actual gamut of each image to match more or less creating another aspect of "seamless" as the eye can see... color and density assuming the images were captured at or near the same sun angle, weather etc. As for the "ghost" shadow, I think it was feathered below the image that was overlayed after, like you guys said... BAWK! David Owens Aerial Viewpoint N14AV AC-500A-Colemill ________________________________________________________________________________
Subject: Oil Leak
Date: Aug 29, 2007
Brent, The silicon, in my experience, are better than cork, however, first be sure that someone hasn't tightened the screws up so much that the valve covers are bent around the screw holes. This check can be done with a flat surface and a feeler gage. If you go to silicon, and do engine oil analysis, be sure to tell the analyzers. If you don't tell them, likely they will tell you that the engine is in trouble. Do not over tighten the screws no matter what type of gaskets you use. Moe N680RR 680F(p) -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of brent-mueller(at)comcast.net Sent: Tuesday, August 28, 2007 9:21 PM Subject: Commander-List: Oil Leak -Greetings- Our valve covers leak some. what is the very best solution to oil leaking valve covers. I was told silicon ones are the ones to use, we have cork now. If cork expands with the warm oil then flattens when not run for a bit, whats th advantage over silcone? Take Care, Brent Read this topic online here: http://forums.matronics.com/viewtopic.php?p=131505#131505 ________________________________________________________________________________
Subject: Oil Leak
Date: Aug 29, 2007
From: Bruce Campbell <brcamp(at)windows.microsoft.com>
When I went to silicon valve covers the oil leak problem was greatly reduced on the GO435s. There were still other leaks around some of the accessories that had to be dealt with, but it was then possible to isolate them. Eventually got it down to essentially no leaks. Bruce -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of brent-mueller(at)comcast.net Sent: Tuesday, August 28, 2007 9:21 PM Subject: Commander-List: Oil Leak -Greetings- Our valve covers leak some. what is the very best solution to oil leaking valve covers. I was told silicon ones are the ones to use, we have cork now. If cork expands with the warm oil then flattens when not run for a bit, whats th advantage over silcone? Take Care, Brent Read this topic online here: http://forums.matronics.com/viewtopic.php?p=131505#131505 ________________________________________________________________________________
Date: Aug 29, 2007
Would it hurt to apply a thin layer of grease on the cork before installation? That way the seal is not 'dry' and should prevent sweating. Or is it a no-no on aviation engines? Nico -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Brock Lorber Sent: Wednesday, August 29, 2007 5:47 AM Subject: RE: Commander-List: Oil Leak [bcc][faked-from] The very best solution to oil leaking valve covers is not over-torquing the screws that hold them on. When the screws are over-torqued, they pucker the thin metal and ruin the seal with any gaskets. Keep the cork gaskets and get new valve covers. Torque the screws (with star washers) exactly as published in the overhaul manual (~ 20 inch pounds, barely more than snug). Brock -----Original Message----- From: owner-commander-list-server(at)matronics.com on behalf of brent-mueller(at)comcast.net Sent: Tue 8/28/2007 9:21 PM Subject: Commander-List: Oil Leak [bcc][faked-from] -Greetings- Our valve covers leak some. what is the very best solution to oil leaking valve covers. I was told silicon ones are the ones to use, we have cork now. If cork expands with the warm oil then flattens when not run for a bit, whats th advantage over silcone? Take Care, Brent Read this topic online here: http://forums.matronics.com/viewtopic.php?p=131505#131505 3D======================== 3D========= 3D======================== 3D========= 3D======================== 3D========= ________________________________________________________________________________
Subject: Re: Oil Leak [bcc][faked-from]
Date: Aug 29, 2007
We use Hylomar on ours... David Owens Aerial Viewpoint N14AV AC-500A-Colemill ________________________________________________________________________________
Date: Aug 29, 2007
go to http://www.hylomar-usa.com/ for aviation specifics... David Owens Aerial Viewpoint N14AV AC-500A-Colemill ________________________________________________________________________________
Subject: Re: Attending your first Fly-In?
Date: Aug 29, 2007
Hello Barry, This will be my first fly-in. I am looking forward to meeting everyone. Thanks, Myron Ashley N620DR ----- Original Message ----- From: Barry Collman To: commander-list(at)matronics.com Sent: Wednesday, August 29, 2007 8:46 AM Subject: Commander-List: Attending your first Fly-In? Hi All, If any Commander owner is attending their very first Fly-In, please let me know and bring along a personalised history of their Commander(s). Very Best Regards, Barry ________________________________________________________________________________
Date: Aug 30, 2007
Hi Myron, Thanks for letting me know. I'll bring the history of your 500B (1116-66) with me. Very Best Regards, Barry ----- Original Message ----- From: Myron Ashley To: commander-list(at)matronics.com Sent: Thursday, August 30, 2007 1:16 AM Subject: Re: Commander-List: Attending your first Fly-In? Hello Barry, This will be my first fly-in. I am looking forward to meeting everyone. Thanks, Myron Ashley N620DR ----- Original Message ----- From: Barry Collman To: commander-list(at)matronics.com Sent: Wednesday, August 29, 2007 8:46 AM Subject: Commander-List: Attending your first Fly-In? Hi All, If any Commander owner is attending their very first Fly-In, please let me know and bring along a personalised history of their Commander(s). Very Best Regards, Barry href="http://www.matronics.com/Navigator?Commander-List">http://www.mat ronics.com/Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Subject:
Date: Aug 31, 2007
hope to see all in fredicksburg T82 in three (3) weeks. ________________________________________________________________________________
Subject: mander-List:
Date: Aug 31, 2007
hm, fwd via fed ex ystd pd. i will fwd ck to you for $50. for shipping to ftw. tnx ur hlp mason From: avtec2(at)bellsouth.netTo: commander-list(at)matronics.comSubject: Re: Comm ander-List:Date: Tue, 28 Aug 2007 09:15:19 -0400 If you dont want them send them back COD on Freight. Thanks Harry ----- Original Message ----- From: MASON CHEVAILLIER Sent: Monday, August 27, 2007 6:08 PM Subject: RE: Commander-List: hm, parts arrived this am. there is no paperwork with them? we discussed them being "yellow tagged"? i will advise what i am doing. tnx ur hlp. ma son From: avtec2(at)bellsouth.netTo: commander-list(at)matronics.comSubject: Re: Comm ander-List:Date: Fri, 24 Aug 2007 16:12:54 -0400 Shippe today for monday $ 449.75 i put a shipping lable in the packing list pouch to return the old valves Thanks ( i will get seat bolts tommorow Harry ----- Original Message ----- From: MASON CHEVAILLIER Sent: Thursday, August 23, 2007 4:59 PM Subject: RE: Commander-List: hm, tnx ur help. pls fwd two(2) each of the fuel shutoff valves part #AV1 6B1159 and required O-rings four(4) part#S-0310-219F to PRO AVIATION 221 AVIATION WAY #200 Fort Worth, Texas 76106. monday morn AM delivery. enc lose invoice for $400.00 and I will send you a "good" check to the return a ddress. thank you mason 817-517-4977 From: avtec2(at)bellsouth.netTo: commander-list(at)matronics.comSubject: Re: Comm ander-List: Date: Thu, 23 Aug 2007 16:27:11 -0400 i do Harry 321 267-3141 ----- Original Message ----- From: MASON CHEVAILLIER Sent: Thursday, August 23, 2007 3:59 PM Subject: Commander-List: anyone have a fuel shut off valve pn AV16B1159 and the O-rings S-0310-219F x4 to install. PCAA mason href="http://www.matronics.com/Navigator?Commander-List">http://www.matro nics.com/Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com " target=_blank>http://www.matronics.com/Navigator?Commander-List p://forums.matronics.com href="http://www.matronics.com/Navigator?Commander-List">http://www.matro nics.com/Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com " target=_blank>http://www.matronics.com/Navigator?Commander-List p://forums.matronics.com href="http://www.matronics.com/Navigator?Commander-List">http://www.matro nics.com/Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Subject: Re: mander-List:
Date: Aug 31, 2007
The total is $449.75 Plus the old valves Thanks Harry ----- Original Message ----- From: MASON CHEVAILLIER To: commander-list(at)matronics.com Sent: Friday, August 31, 2007 11:25 AM Subject: RE: Commander-List: hm, fwd via fed ex ystd pd. i will fwd ck to you for $50. for shipping to ftw. tnx ur hlp mason ------------------------------------------------------------------------- --- From: avtec2(at)bellsouth.net To: commander-list(at)matronics.com Subject: Re: Commander-List: Date: Tue, 28 Aug 2007 09:15:19 -0400 If you dont want them send them back COD on Freight. Thanks Harry ----- Original Message ----- From: MASON CHEVAILLIER To: commander-list(at)matronics.com Sent: Monday, August 27, 2007 6:08 PM Subject: RE: Commander-List: hm, parts arrived this am. there is no paperwork with them? we discussed them being "yellow tagged"? i will advise what i am doing. tnx ur hlp. mason ------------------------------------------------------------------------ From: avtec2(at)bellsouth.net To: commander-list(at)matronics.com Subject: Re: Commander-List: Date: Fri, 24 Aug 2007 16:12:54 -0400 Shippe today for monday $ 449.75 i put a shipping lable in the packing list pouch to return the old valves Thanks ( i will get seat bolts tommorow Harry ----- Original Message ----- From: MASON CHEVAILLIER To: commander-list(at)matronics.com Sent: Thursday, August 23, 2007 4:59 PM Subject: RE: Commander-List: hm, tnx ur help. pls fwd two(2) each of the fuel shutoff valves part #AV16B1159 and required O-rings four(4) part#S-0310-219F to PRO AVIATION 221 AVIATION WAY #200 Fort Worth, Texas 76106. monday morn AM delivery. enclose invoice for $400.00 and I will send you a "good" check to the return address. thank you mason 817-517-4977 -------------------------------------------------------------------- From: avtec2(at)bellsouth.net To: commander-list(at)matronics.com Subject: Re: Commander-List: Date: Thu, 23 Aug 2007 16:27:11 -0400 i do Harry 321 267-3141 ----- Original Message ----- From: MASON CHEVAILLIER To: commander-list Sent: Thursday, August 23, 2007 3:59 PM Subject: Commander-List: anyone have a fuel shut off valve pn AV16B1159 and the O-rings S-0310-219F x4 to install. PCAA mason href="http://www.matronics.com/Navigator?Commander-List">http://www.mat ronics.com/Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com " target=_blank>http://www.matronics.com/Navigator?Commander-List p://forums.matronics.com href="http://www.matronics.com/Navigator?Commander-List">http://www.mat ronics.com/Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com " target=_blank>http://www.matronics.com/Navigator?Commander-List p://forums.matronics.com href="http://www.matronics.com/Navigator?Commander-List">http://www.mat ronics.com/Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com " target=_blank>http://www.matronics.com/Navigator?Commander-List p://forums.matronics.com ________________________________________________________________________________
Date: Sep 01, 2007
Once again Moe, well said.? I also recommend replacing all of the screws with correct and new lycoming parts.? The screws will come with new lock washeres manufactured on them.? They are not expencive.? I have tried just about everything over the years and have found the silicone gaskets, properly torqued to flat valve covers using new screws works?the best.? One last thing, when you install the silicone gaskets, they should be completely dry.? No grease, oil or gasket sealer.? it will work.? jb -----Original Message----- From: Moe - Ross Racing Pistons <moe(at)rosspistons.com> Sent: Wed, 29 Aug 2007 7:37 am Subject: RE: Commander-List: Oil Leak Brent, The silicon, in my experience, are better than cork, however, first be sure that someone hasn't tightened the screws up so much that the valve covers are bent around the screw holes. This check can be done with a flat surface and a feeler gage. If you go to silicon, and do engine oil analysis, be sure to tell the analyzers. If you don't tell them, likely they will tell you that the engine is in trouble. Do not over tighten the screws no matter what type of gaskets you use. Moe N680RR 680F(p) -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of brent-mueller(at)comcast.net Sent: Tuesday, August 28, 2007 9:21 PM Subject: Commander-List: Oil Leak -Greetings- Our valve covers leak some. what is the very best solution to oil leaking valve covers. I was told silicon ones are the ones to use, we have cork now. If cork expands with the warm oil then flattens when not run for a bit, whats th advantage over silcone? Take Care, Brent Read this topic online here: http://forums.matronics.com/viewtopic.php?p=131505#131505 ________________________________________________________________________ Email and AIM finally together. You've gotta check out free AOL Mail! - http://mail.aol.com ________________________________________________________________________________
Date: Sep 01, 2007
HI JOHN, hows life??. I have been around three different "on the ground" retracts.? The first was a straight 560 in Caldwell Idaho, next was a 690B grand Renaissance with dash 10s (ouch) and the last a straight 500.? In every case the pilot started an engine with the gear handle UP.? There is no squat switch so you are correct, up they come.? In all three cases the gear collapsed on the side that was started, resulting in a propeller strike in every case.? I assume that this is because the gear most close to the operating hyd pump moves first??? Anyway, it can does and will happen again.? Like you, I cant say why there would be a trend for one gear over the other, probably a coincidence.? jb That being said, I've heard of gear retracts happening on the ground. I'm certain that ONE engine by itself makes enough pressure to retract the gear at idle, as even during warmup at low RPM, my hydraulic system is steady at 1,000 PSI regardless of steering or flap actuation.? ? As far as right vs. left, I don't know the answer to that one...? -----Original Message----- From: John Vormbaum <john(at)vormbaum.com> Sent: Tue, 28 Aug 2007 10:09 am Subject: Re: Commander-List: Main gear [bcc][faked-from][html-rem] ? This is a question I hope I NEVER find the answer to on my 500B. That being said, I've heard of gear retracts happening on the ground. I'm certain that ONE engine by itself makes enough pressure to retract the gear at idle, as even during warmup at low RPM, my hydraulic system is steady at 1,000 PSI regardless of steering or flap actuation.? ? As far as right vs. left, I don't know the answer to that one...? ? /J? ? Brock Lorber wrote:? > This is puzzle that is going to have an interesting answer. I'm following a rabbit's warren that leads me to believe that the hydraulic pumps at idle can't pump enough volume at idle to pull both legs over center simultaneously and that there is something about the right leg (placement of the cylinder?) that makes the right leg easier to pull over center than the left leg. Once it comes over center, the resistance is a lot lower on the right side, so the left leg won't come over center until the right leg fully retracts.? >? >? > -----Original Message-----? > From: owner-commander-list-server(at)matronics.com on behalf of Barry Collman? > Sent: Tue 8/28/2007 7:50 AM? > To: commander-list(at)matronics.com? > Subject: Commander-List: Main gear [bcc][faked-from][html-rem]? > > Hi All,? >? > Can I just check something with you all. This is for a Model 500B specifically, but I assume the scenario covers other Models.? >? > After landing, with indication that all three gears are down-and-locked, the right-hand gear retracts.? > It seems fairly 'common' that this is usually because the PiC has selected the gear-up switch instead of the flaps-up switch.? >? > If so, is it the right-hand gear that actuates first?? >? > Presumably, if the PiC realises his error in time, he can prevent the left-hand gear actuating?? >? > Best Regards,? > Barry? >? >? >? >? > __________ NOD32 2488 (20070828) Information __________? >? > ? ? ? ________________________________________________________________________ Email and AIM finally together. You've gotta check out free AOL Mail! - http://mail.aol.com ________________________________________________________________________________
Subject: FUEL BOOST PUMP 500B
Date: Sep 02, 2007
IM TIRED OF WAITING WEEKS FOR A BOOST PUMP OVERHAUL. ANYONE KNOW WHERE I CAN GET A SPARE.fOR 500B SN 1189. -------- LLOYD SILVERMAN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=132357#132357 ________________________________________________________________________________
Date: Sep 02, 2007
Subject: Re: FUEL BOOST PUMP 500B
Good luck! I had mine rebuilt this past year, and it took quite a while. Now they are fine - but other problems have arisen. Best of luck bobf On 9/2/07, lloyd silverman wrote: > > lloydsss(at)gmail.com> > > IM TIRED OF WAITING WEEKS FOR A BOOST PUMP OVERHAUL. ANYONE KNOW WHERE I > CAN GET A SPARE.fOR 500B SN 1189. > > -------- > LLOYD SILVERMAN > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=132357#132357 > > ________________________________________________________________________________
Subject: Fly-In and Conference
Date: Sep 02, 2007
Well folks, the Fly-In is right around the corner and we can't wait to see everyone again and hear about your Commander adventures.? Be sure to get your registrations in on time so we can have an accurate count for the caterers.? Also, if you have any suggested changes for the Directory please let us know ASAP.? Hope everyone is having a great Labor Day Weekend and getting in some Commander time. jb ________________________________________________________________________ Email and AIM finally together. You've gotta check out free AOL Mail! - http://mail.aol.com ________________________________________________________________________________
Date: Sep 02, 2007
WHO DID THE OVERHAUL?? THANKS,LLOYD -------- LLOYD SILVERMAN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=132403#132403 ________________________________________________________________________________
Date: Sep 02, 2007
My local A&P at Summitt aviation in Temple Texas. Didn't look hard to do bobf On 9/2/07, lloyd silverman wrote: > > lloydsss(at)gmail.com> > > WHO DID THE OVERHAUL?? THANKS,LLOYD > > -------- > LLOYD SILVERMAN > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=132403#132403 > > ________________________________________________________________________________
Date: Sep 03, 2007
These guys did well for me. http://www.aircraftaccessoriesofok.com bilbo -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of lloyd silverman Sent: Sunday, September 02, 2007 1:33 PM Subject: Commander-List: FUEL BOOST PUMP 500B IM TIRED OF WAITING WEEKS FOR A BOOST PUMP OVERHAUL. ANYONE KNOW WHERE I CAN GET A SPARE.fOR 500B SN 1189. -------- LLOYD SILVERMAN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=132357#132357 ________________________________________________________________________________
Date: Sep 03, 2007
Anyone ever tried to get a field approval for an external boost pump? I went through 2 boost pumps on my 560 and 3 on the 685. These damned things are terribly problematic. -------- Milt 2003 F1 Rocket 2006 Radial Rocket Read this topic online here: http://forums.matronics.com/viewtopic.php?p=132475#132475 ________________________________________________________________________________
Date: Sep 03, 2007
I BELEIVE CENTRAL AIR HAS AN STC OR FIELD APPROVAL ON 5OOB. I KNOW SEVERAL COMMANDER DRIVERS WHO ONLY TURN ON BOOST PUMPS TO START ENGINES, NEVER DURING FLIGHT. NOT A SAFE IDEA,BUT PUMPS LAST LONGER..... -------- LLOYD SILVERMAN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=132492#132492 ________________________________________________________________________________
Date: Sep 03, 2007
"Not a safe idea?" A little boost pump trivia. The Pratt and Whitney powered Douglas DC-8 was designed to take off and land with the boost pumps off. Supposedly, Douglas felt if you wrecked it at least the boost pumps wouldn't be pumping fuel into the fire. I'm not sure why they thought you would have electrical power for the pumps to run though. The end. bilbo -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of lloyd silverman Sent: Monday, September 03, 2007 10:51 AM Subject: Commander-List: Re: FUEL BOOST PUMP 500B I BELEIVE CENTRAL AIR HAS AN STC OR FIELD APPROVAL ON 5OOB. I KNOW SEVERAL COMMANDER DRIVERS WHO ONLY TURN ON BOOST PUMPS TO START ENGINES, NEVER DURING FLIGHT. NOT A SAFE IDEA,BUT PUMPS LAST LONGER..... -------- LLOYD SILVERMAN Read this topic online here: http://forums.matronics.com/viewtopic.php?p=132492#132492 ________________________________________________________________________________
Date: Sep 03, 2007
In a message dated 03-Sep-07 08:39:36 Pacific Daylight Time, bowing74(at)earthlink.net writes: A little boost pump trivia. And a bit more ... Remember when Cessna 300 and 400 series had HI/LO boost pumps that were pressure switch activated? If fuel pressure dropped below a certain value, the pump would kick into HI output. More engine failures were caused by engine flooding than anything else and Cessna had the pressure switches removed. Wing Commander Gordon http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Date: Sep 03, 2007
Too much of a good thing. bilbo _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of CloudCraft(at)aol.com Sent: Monday, September 03, 2007 11:46 AM Subject: Re: Commander-List: Re: FUEL BOOST PUMP 500B In a message dated 03-Sep-07 08:39:36 Pacific Daylight Time, bowing74(at)earthlink.net writes: A little boost pump trivia. And a bit more ... Remember when Cessna 300 and 400 series had HI/LO boost pumps that were pressure switch activated? If fuel pressure dropped below a certain value, the pump would kick into HI output. More engine failures were caused by engine flooding than anything else and Cessna had the pressure switches removed. Wing Commander Gordon AOL.com. ________________________________________________________________________________
From: "Moe - Ross Racing Pistons" <moe(at)rosspistons.com>
Date: Sep 03, 2007
Milt, Where was the fuel pump on your 685? I would have assumed that it was in the same place as my 680 (in the nacelle). They are a little hard to get to but not in the tank. Moe -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of N395V Sent: Monday, September 03, 2007 5:39 AM Subject: Commander-List: Re: FUEL BOOST PUMP 500B Anyone ever tried to get a field approval for an external boost pump? I went through 2 boost pumps on my 560 and 3 on the 685. These damned things are terribly problematic. -------- Milt 2003 F1 Rocket 2006 Radial Rocket Read this topic online here: http://forums.matronics.com/viewtopic.php?p=132475#132475 ________________________________________________________________________________
Date: Sep 08, 2007
Subject: New Realtime Spell Checker Added To Matronics Forums!
Dear Listers, Today 9/8/2007 I have added a new real-time spell checker function to all of the BBS Forums at Matronics. When you reply or create a new message on the Forums, you will notice that misspelled words will be high-lighted in yellow. If you left-click on the word, you will be prompted with a drop-down list of suggested spellings. http://forums.matronics.com Enjoy! Matt Dralle Matornics Email List and Forum Administrator ________________________________________________________________________________
From: "Tom Fisher" <tfisher(at)commandergroup.bc.ca>
Subject: Re: New Realtime Spell Checker Added To Matronics Forums!
Date: Sep 09, 2007
Boy you know who needs that. Tom... ----- Original Message ----- From: "Matt Dralle" <dralle(at)matronics.com> Sent: Saturday, September 08, 2007 12:46 PM Subject: Commander-List: New Realtime Spell Checker Added To Matronics Forums! > > Dear Listers, > > Today 9/8/2007 I have added a new real-time spell checker function to all > of the BBS Forums at Matronics. When you reply or create a new message on > the Forums, you will notice that misspelled words will be high-lighted in > yellow. If you left-click on the word, you will be prompted with a > drop-down list of suggested spellings. > > http://forums.matronics.com > > Enjoy! > > Matt Dralle > Matornics Email List and Forum Administrator > > > ________________________________________________________________________________
Subject: 2007 Fly-In
Date: Sep 10, 2007
Hey Y'All, The Fly-In is only 10 days away.? YeeHaw!? Texas, here we come.? There's still room for you -- just let us know you're coming so we can let the caterers know how much food to prepare.? See y'all there (just practicing my "Texas talk".) Capt Jim Bob ________________________________________________________________________ Email and AIM finally together. You've gotta check out free AOL Mail! - http://mail.aol.com ________________________________________________________________________________
Date: Sep 10, 2007
Subject: Re: 2007 Fly-In
I'll try to come by car! My AC500B is down for repairs in Springfield MO - Will be looking at selling her soon after the right engine overhaul. Bob Feldtman N500GW On 9/10/07, yourtcfg(at)aol.com wrote: > > Hey Y'All, > > The Fly-In is only 10 days away. *YeeHaw! Texas, here we come*. > > There's still room for you -- just let us know you're coming so we can let > the caterers know how much food to prepare. > > See y'all there (just practicing my "Texas talk".) > > Capt Jim Bob > ------------------------------ > Email and AIM finally together. You've gotta check out free AOL Mail<http://o.aolcdn.com/cdn.webmail.aol.com/mailtour/aol/en-us/index.htm?ncid=AOLAOF00020000000970> > ! > > > * > > * > > ________________________________________________________________________________
Date: Sep 10, 2007
Would like to make it... Have been sorting out a strange problem with the Commander, hopefully we'll "get er done" tomorrow or the next day. I think one of the pilots and myself are going to try and show at least for enough time to meet you guys, and mabey get in a round of golf before getting back to DWH... We will see!!! David Owens Aerial Viewpoint N14AV AC-500A-Colemill ________________________________________________________________________________
Date: Sep 16, 2007
Hello Jim, I now have a final head count. My son (10yrs) and myself will be traveling to the fly in. My wife and daughter backed out. I will give you a check when I arrive. Was there someone that had a 500B in Springfield MO that was going to drive? I could stop in Springfield and pick them up. Thanks, Myron Ashley N620DR ----- Original Message ----- From: yourtcfg(at)aol.com To: commander-list(at)matronics.com Sent: Monday, September 10, 2007 3:11 PM Subject: Commander-List: 2007 Fly-In Hey Y'All, The Fly-In is only 10 days away. YeeHaw! Texas, here we come. There's still room for you -- just let us know you're coming so we can let the caterers know how much food to prepare. See y'all there (just practicing my "Texas talk".) Capt Jim Bob ------------------------------------------------------------------------- ----- Email and AIM finally together. You've gotta check out free AOL Mail! ________________________________________________________________________________
Date: Sep 17, 2007
Subject: Re: Commander-List Digest: 1 Msgs - 09/16/07
As Jim knows I have once again had to cancel our plans to come to the fly-in. I have two hotel rooms reserved at the hangar hotel and a car reserved. I will be letting them go unless anyone wants a room or car and have been unable to get one. dan farmer 719 332 5601 Commander-List Digest Server wrote: * ================================================= Online Versions of Today's List Digest Archive ================================================= Today's complete Commander-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the Commander-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 07-09-16&Archive=Commander Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 07-09-16&Archive=Commander =============================================== EMail Version of Today's List Digest Archive =============================================== ---------------------------------------------------------- Commander-List Digest Archive --- Total Messages Posted Sun 09/16/07: 1 ---------------------------------------------------------- Today's Message Index: ---------------------- 1. 08:44 AM - Re: 2007 Fly-In (Myron Ashley) ________________________________ Message 1 _____________________________________ From: "Myron Ashley" Subject: Re: Commander-List: 2007 Fly-In Hello Jim, I now have a final head count. My son (10yrs) and myself will be traveling to the fly in. My wife and daughter backed out. I will give you a check when I arrive. Was there someone that had a 500B in Springfield MO that was going to drive? I could stop in Springfield and pick them up. Thanks, Myron Ashley N620DR ----- Original Message ----- From: yourtcfg(at)aol.com Sent: Monday, September 10, 2007 3:11 PM Subject: Commander-List: 2007 Fly-In Hey Y'All, The Fly-In is only 10 days away. YeeHaw! Texas, here we come. There's still room for you -- just let us know you're coming so we can let the caterers know how much food to prepare. See y'all there (just practicing my "Texas talk".) Capt Jim Bob ------------------------------------------------------------------------- ----- Email and AIM finally together. You've gotta check out free AOL Mail! --------------------------------- ________________________________________________________________________________
Date: Sep 17, 2007
Folks, my things are not lining up either. Although I didn't reserve anything because matters were very fluid at the onset, I was still hoping that I might get to go at the last minute. I wish all of you a very insightful and pleasant weekend. Would someone take a lot of pics and video for the website? Stay safe, y'all, and make an equal number of take-offs and landings. Nico _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Dan Farmer Sent: Monday, September 17, 2007 2:16 PM Subject: Commander-List: Re: Commander-List Digest: 1 Msgs - 09/16/07 As Jim knows I have once again had to cancel our plans to come to the fly-in. I have two hotel rooms reserved at the hangar hotel and a car reserved. I will be letting them go unless anyone wants a room or car and have been unable to get one. dan farmer 719 332 5601 Commander-List Digest Server wrote: * ================================================= Online Versions of Today's List Digest Archive ================================================= Today's complete Commander-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the Commander-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 07-09-16&Archive=Commander Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 2007-09-16&Archive=Commander =============================================== EMail Version of Today's List Digest Archive =============================================== ---------------------------------------------------------- Commander-List Digest Archive --- Total Messages Posted Sun 09/16/07: 1 ---------------------------------------------------------- Today's Message Index: ---------------------- 1. 08:44 AM - Re: 2007 Fly-In (Myron Ashley) ________________________________ Message 1 _____________________________________ From: "Myron Ashley" Subject: Re: Commander-List: 2007 Fly-In Hello Jim, I now have a final head count. My son (10yrs) and myself will be traveling to the fly in. My wife and daughter backed out. I will give you a check when I arrive. Was there someone that had a 500B in Springfield MO that was going to drive? I could stop in Springfield and pick them up. Thanks, Myron Ashley N620DR ----- Original Message ----- From: yourtcfg(at)aol.com Sent: Monday, September 10, 2007 3:11 PM Subject: Commander-List: 2007 Fly-In Hey Y'All, The Fly-In is only 10 days away. YeeHaw! Texas, here we come. There's still room for you -- just let us know you're coming so we can let the caterers know how much food to prepare. See y'all there (just practicing my "Texas ________________________________________________________________________________
Date: Sep 18, 2007
DAN, How about reconsidering your plans and showing up?????=C2- It wont be the same without you.=C2- The Aussies are already here and having a great time!!=C2- We can talk about crop dusting??=C2- Come on, you already ha ve the reservations.=C2- jb -----Original Message----- From: nico css <nico(at)cybersuperstore.com> Sent: Mon, 17 Sep 2007 9:41 pm Subject: RE: Commander-List: Re: Commander-List Digest: 1 Msgs - 09/16/07 Folks, my things are not lining up either. Although I didn=99t reserve anything because matters were very fluid at the onset, I was still hoping t hat I might get to go at the last minute. =C2- I wish all of you a very insightful and pleasant weekend. Would someone take a lot of pics and video for the website? =C2- Stay safe, y=99all, and make an equal number of take-offs and landings . =C2- Nico =C2- =C2- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list -server(at)matronics.com] On Behalf Of Dan Farmer Sent: Monday, September 17, 2007 2:16 PM Subject: Commander-List: Re: Commander-List Digest: 1 Msgs - 09/16/07 =C2- As Jim knows I have once again had to cancel our plans to come to the fly-in .=C2- I have two hotel rooms reserved at the hangar hotel and a car reserv ed.=C2- I will be letting them go unless anyone=C2- wants a room or car and have been unable to get one.=C2- =C2- dan farmer 719 332 5601 Commander-List Digest Server wrote: * Online Versions of Today's List Digest Archive Today's complete Commander-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the Commander-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Cha pter 07-09-16&Archive=Commander Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chap ter 07-09-16&Archive=Commander ====================== EMail Version of Today's List Digest Archive ====================== ---------------------------------------------------------- Commander-List Digest Archive --- Total Messages Posted Sun 09/16/07: 1 ---------------------------------------------------------- Today's Message Index: ---------------------- 1. 08:44 AM - Re: 2007 Fly-In (Myron Ashley) ________________________________ Message 1 _________________________________ ____ From: "Myron Ashley" Subject: Re: Commander-List: 2007 Fly-In Hello Jim, I now have a final head count. My son (10yrs) and myself will be traveling to the fly in. My wife and daughter backed out. I will give you a check when I arrive. Was there someone that had a 500B in Springfield MO that was going to drive? I could stop in Springfield and pick them up. Thanks, Myron Ashley N620DR ----- Original Message ----- From: yourtcfg(at)aol.com Sent: Monday, September 10, 2007 3:11 PM Subject: Commander-List: 2007 Fly-In Hey Y'All, The Fly-In is only 10 days away. YeeHaw! Texas, here we come. There's still room for you -- just let us know you're coming so we can let the caterers know how much food to prepare. See y'all there (just practicing my "Texas =C2- =C2- =C2- -= - The Commander-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as the Subscriptions page, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: -= --> http://www.matronics.com/Navigator?Commander-List -======================== -= - NEW MATRONICS WEB FORUMS - -= Same great content now also available via the Web Forums! -= --> http://forums.matronics.com -======================== ________________________________________________________________________ Email and AIM finally together. You've gotta check out free AOL Mail! - http ://mail.aol.com ________________________________________________________________________________
Date: Sep 23, 2007
Subject: Re: Commander-List Digest: 0 Msgs - 09/22/07
What a TERRIFIC group of people. Teresa and I had such a great time. Thanks to all dan farmer Commander-List Digest Server wrote: * ================================================= Online Versions of Today's List Digest Archive ================================================= Today's complete Commander-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the Commander-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 07-09-22&Archive=Commander Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 07-09-22&Archive=Commander =============================================== EMail Version of Today's List Digest Archive =============================================== ---------------------------------------------------------- Commander-List Digest Archive --- Total Messages Posted Sat 09/22/07: 0 ---------------------------------------------------------- Today's Message Index: ---------------------- --------------------------------- Tonight's top picks. What will you watch tonight? Preview the hottest shows on Yahoo! TV. ________________________________________________________________________________
Date: Sep 23, 2007
So sad that I couldn't be with you all. At one time I just wanted to "the hell with it all" and go, but looking back it wouldn't have been wise. So, I am already looking forward to next year. If anyone has taken some video or pictures and notes, forward them to me and let's publish them on the website. Thanks Nico _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Dan Farmer Sent: Sunday, September 23, 2007 5:26 PM Subject: Commander-List: Re: Commander-List Digest: 0 Msgs - 09/22/07 What a TERRIFIC group of people. Teresa and I had such a great time. Thanks to all dan farmer Commander-List Digest Server wrote: * ================================================= Online Versions of Today's List Digest Archive ================================================= Today's complete Commander-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the Commander-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML _____ Tonight's top picks. What will you watch tonight? ">Preview the hottest shows on Yahoo! TV. ________________________________________________________________________________
From: "Robert S. Randazzo" <rsrandazzo(at)precisionmanuals.com>
Date: Sep 23, 2007
Commanders- My sentiments match Nico's. I know I said this last year too, but.. N414C will be done in time for next year's fly-in- so count on me being there! (No really- this time I actually expect it to be ready!) Supposed to test fly on Monday. Can you believe it took 6 weeks to get parts from TCM to fix the left engine? Jeez.. Hopefully it'll fly well- and we can run it over to Stockton to have the wingspar inspected- then actually USE the airplane for it's intended purpose. I'll keep you posted. Robert From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of nico css Sent: Sunday, September 23, 2007 10:30 PM Subject: RE: Commander-List: Re: Commander-List Digest: 0 Msgs - 09/22/07 So sad that I couldn't be with you all. At one time I just wanted to "the hell with it all" and go, but looking back it wouldn't have been wise. So, I am already looking forward to next year. If anyone has taken some video or pictures and notes, forward them to me and let's publish them on the website. Thanks Nico _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Dan Farmer Sent: Sunday, September 23, 2007 5:26 PM Subject: Commander-List: Re: Commander-List Digest: 0 Msgs - 09/22/07 What a TERRIFIC group of people. Teresa and I had such a great time. Thanks to all dan farmer Commander-List Digest Server wrote: * Online Versions of Today's List Digest Archive Today's complete Commander-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the Commander-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML _____ Tonight's top picks. What will you watch tonight? ">Preview the hottest shows on Yahoo! TV. __________ NOD32 2540 (20070919) Information __________ ________________________________________________________________________________
Date: Sep 24, 2007
all at T82, enjoyed it, hope everyone had a safe trip home. I look forward to next year. sorry i missed the festivities of sat. nt. mason Date: Sun, 23 Sep 2007 17:26:19 -0700From: daniellfarmer(at)yahoo.comSubject: Commander-List: Re: Commander-List Digest: 0 Msgs - 09/22/07To: commander-l ist(at)matronics.com What a TERRIFIC group of people. Teresa and I had such a great time. Thanks to all dan farmerCommander-List Digest Server wrote : *======================== =Online Versions of Today's List Digest Archive======== =================Today's complete Command er-List Digest can also be found in either of the two Web Links listed belo w. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .t xt file includes the plain ASCII version of the Commander-List Digest and c an be viewed with a generic text editor such as Notepad or with a web brows er. HTML Tonight's top picks. What will you watch tonight? ">Preview the hottest sho ws on Yahoo! TV. ________________________________________________________________________________
Subject: 2007 TCFG Fky-In
Date: Sep 24, 2007
Despite some weather delays (2 hour stopoever in Durango, Colorado waiting for a storm to pass through and a lot of flying around stuff) we made it home in time to have a late dinner and sleep in our own bed lat night.? Total trip time was around 13 hours with about 9.5 hours of flying time.? Had to make an extra fuel stop one hour from home.? The old gal ran well all the way and Russel (from Australia) was able to get a good bit of flying time from the captain seat!? Richard, the other ozzie flew it most of the way to T82.? Wonderful to have them on board with us.? We want to thank all of you who took time out of your busy schedules to attend the event.? We enjoyed seeing old commander friends and meeting new ones. As Dan said, it is a terrific group of people who not only fly great airplanes, but know how to have fun.? For those of you who missed the event you missed out on a fantastic venue -- the Hangar Hotel is truely someplace every pilot should visit.? There were 14 beautiful looking tall-tailed birds sitting on the ramp right outside the hotel entrance and approximately 40 people in attendance!? Not only that, there were great speakers and a visit to the Pacific War museum where we witnessed a re-enactment of a Pacific War battle.? And, as always the auction was lots of fun with a few practical jokes thrown in!? Barry Collman, our historian came prepared and entertained us with a litany of jokes during the event (thanks Barry).? Make plans to attend next year as it will be the 60th anniversary of the flight of the prototye Commander and it would be wonderful to fill the ramp up with Commanders.? We're in the initial stages of planning and getting permission, etc., but hoping we'll be able to hold it in Oklahoma City (Wiley Post), the birthplace of the Commander.? Anyway, thanks again to all who attended and we look forward to seeing the rest of you next year.? Cheers, Jim & Sue Metzger ________________________________________________________________________ Email and AIM finally together. You've gotta check out free AOL Mail! - http://mail.aol.com ________________________________________________________________________________
Date: Sep 24, 2007
Sue and Jim (Notice I put her name first). Thanks for a great get together! I was home yesterday about 1:30. Had to go up to 20,000 feet just east of Tucson for weather. Moe _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of yourtcfg(at)aol.com Sent: Monday, September 24, 2007 8:17 AM Subject: Commander-List: 2007 TCFG Fky-In Despite some weather delays (2 hour stopoever in Durango, Colorado waiting for a storm to pass through and a lot of flying around stuff) we made it home in time to have a late dinner and sleep in our own bed lat night. Total trip time was around 13 hours with about 9.5 hours of flying time. Had to make an extra fuel stop one hour from home. The old gal ran well all the way and Russel (from Australia) was able to get a good bit of flying time from the captain seat! Richard, the other ozzie flew it most of the way to T82. Wonderful to have them on board with us. We want to thank all of you who took time out of your busy schedules to attend the event. We enjoyed seeing old commander friends and meeting new ones. As Dan said, it is a terrific group of people who not only fly great airplanes, but know how to have fun. For those of you who missed the event you missed out on a fantastic venue -- the Hangar Hotel is truely someplace every pilot should visit. There were 14 beautiful looking tall-tailed birds sitting on the ramp right outside the hotel entrance and approximately 40 people in attendance! Not only that, there were great speakers and a visit to the Pacific War museum where we witnessed a re-enactment of a Pacific War battle. And, as always the auction was lots of fun with a few practical jokes thrown in! Barry Collman, our historian came prepared and entertained us with a litany of jokes during the event (thanks Barry). Make plans to attend next year as it will be the 60th anniversary of the flight of the prototye Commander and it would be wonderful to fill the ramp up with Commanders. We're in the initial stages of planning and getting permission, etc., but hoping we'll be able to hold it in Oklahoma City (Wiley Post), the birthplace of the Com mander. Anyway, thanks again to all who attended and we look forward to seeing the rest of you next year. Cheers, Jim & Sue Metzger _____ Email and AIM finally together. You've gotta check out free AOL Mail <http://o.aolcdn.com/cdn.webmail.aol.com/mailtour/aol/en-us/index.htm?ncid=A OLAOF00020000000970> ! ________________________________________________________________________________
Date: Sep 24, 2007
Same story here... We test flew 14AV on Sunday... finally ready to fly. 2 new cyl after "something" roamed around in the engine and caused a bent valve. Never found the culprit, but lots of other stuff got looked at until the borescope revealed the damage. Sad deal. David Owens Aerial Viewpoint N14AV AC-500A-Colemill ________________________________________________________________________________
Date: Sep 24, 2007
Subject: Re: 2007 TCFG Fky-In
Jim, I was very sorry to miss the event this year. In all the time I've owned my airplane, this is the first Fly-in that I haven't been able to make...but it was for a good reason! I've attached a picture of what I believe is the TCFG's youngest Commander passenger right now; Reece Elizabeth was born on 9/8/07. I am already looking forward to next year's event. In the meantime, a hearty "Cheers!" to all my Commander friends whom I was unable to see this year, especially those who come across oceans to make the event; Russell, Richard, Sir Barry......hope to see you next year! /John yourtcfg(at)aol.com wrote: > Despite some weather delays (2 hour stopoever in Durango, Colorado > waiting for a storm to pass through and a lot of flying around stuff) > we made it home in time to have a late dinner and sleep in our own bed > lat night. Total trip time was around 13 hours with about 9.5 hours > of flying time. Had to make an extra fuel stop one hour from home. > The old gal ran well all the way and Russel (from Australia) was able > to get a good bit of flying time from the captain seat! Richard, the > other ozzie flew it most of the way to T82. Wonderful to have them on > board with us. > > We want to thank all of you who took time out of your busy schedules > to attend the event. We enjoyed seeing old commander friends and > meeting new ones. As Dan said, it is a terrific group of people who > not only fly great airplanes, but know how to have fun. > > For those of you who missed the event you missed out on a fantastic > venue -- the Hangar Hotel is truely someplace every pilot should > visit. There were 14 beautiful looking tall-tailed birds sitting on > the ramp right outside the hotel entrance and approximately 40 people > in attendance! Not only that, there were great speakers and a visit > to the Pacific War museum where we witnessed a re-enactment of a > Pacific War battle. And, as always the auction was lots of fun with a > few practical jokes thrown in! Barry Collman, our historian came > prepared and entertained us with a litany of jokes during the event > (thanks Barry). Make plans to attend next year as it will be the 60th > anniversary of the flight of the prototye Commander and it would be > wonderful to fill the ramp up with Commanders. We're in the initial > stages of planning and getting permission, etc., but hoping we'll be > able to hold it in Oklahoma City (Wiley Post), the birthplace of the > Com mander. > > Anyway, thanks again to all who attended and we look forward to seeing > the rest of you next year. > > Cheers, > Jim & Sue Metzger > > > ------------------------------------------------------------------------ > Email and AIM finally together. You've gotta check out free AOL Mail > <http://o.aolcdn.com/cdn.webmail.aol.com/mailtour/aol/en-us/index.htm?ncid=AOLAOF00020000000970>! > * > > > * > > > __________ NOD32 2521 (20070911) Information __________ > ________________________________________________________________________________
Date: Sep 24, 2007
John, What a gorgeous reason to stay away. That was worth not going. What a beautiful child. Keep your shotgun oiled! Nico -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of John Vormbaum Sent: Monday, September 24, 2007 10:27 AM Subject: Re: Commander-List: 2007 TCFG Fky-In Jim, I was very sorry to miss the event this year. In all the time I've owned my airplane, this is the first Fly-in that I haven't been able to make...but it was for a good reason! I've attached a picture of what I believe is the TCFG's youngest Commander passenger right now; Reece Elizabeth was born on 9/8/07. I am already looking forward to next year's event. In the meantime, a hearty "Cheers!" to all my Commander friends whom I was unable to see this year, especially those who come across oceans to make the event; Russell, Richard, Sir Barry......hope to see you next year! /John yourtcfg(at)aol.com wrote: > Despite some weather delays (2 hour stopoever in Durango, Colorado > waiting for a storm to pass through and a lot of flying around stuff) > we made it home in time to have a late dinner and sleep in our own bed > lat night. Total trip time was around 13 hours with about 9.5 hours > of flying time. Had to make an extra fuel stop one hour from home. > The old gal ran well all the way and Russel (from Australia) was able > to get a good bit of flying time from the captain seat! Richard, the > other ozzie flew it most of the way to T82. Wonderful to have them on > board with us. > > We want to thank all of you who took time out of your busy schedules > to attend the event. We enjoyed seeing old commander friends and > meeting new ones. As Dan said, it is a terrific group of people who > not only fly great airplanes, but know how to have fun. > > For those of you who missed the event you missed out on a fantastic > venue -- the Hangar Hotel is truely someplace every pilot should > visit. There were 14 beautiful looking tall-tailed birds sitting on > the ramp right outside the hotel entrance and approximately 40 people > in attendance! Not only that, there were great speakers and a visit > to the Pacific War museum where we witnessed a re-enactment of a > Pacific War battle. And, as always the auction was lots of fun with a > few practical jokes thrown in! Barry Collman, our historian came > prepared and entertained us with a litany of jokes during the event > (thanks Barry). Make plans to attend next year as it will be the 60th > anniversary of the flight of the prototye Commander and it would be > wonderful to fill the ramp up with Commanders. We're in the initial > stages of planning and getting permission, etc., but hoping we'll be > able to hold it in Oklahoma City (Wiley Post), the birthplace of the > Com mander. > > Anyway, thanks again to all who attended and we look forward to seeing > the rest of you next year. > > Cheers, > Jim & Sue Metzger > > > ------------------------------------------------------------------------ > Email and AIM finally together. You've gotta check out free AOL Mail > <http://o.aolcdn.com/cdn.webmail.aol.com/mailtour/aol/en-us/index.htm?ncid=A OLAOF00020000000970>! > * > > > * > > > __________ NOD32 2521 (20070911) Information __________ > ________________________________________________________________________________
Date: Sep 24, 2007
Congratulations John!? We missed you and I know you're missing a certain award plaque you usually win!?? Hope to see you in Oklahoma City next year as we bring the birds back to Commander's birthplace.? jb -----Original Message----- From: John Vormbaum <john(at)vormbaum.com> Sent: Mon, 24 Sep 2007 10:27 am Subject: Re: Commander-List: 2007 TCFG Fky-In Jim,? ? I was very sorry to miss the event this year. In all the time I've owned my airplane, this is the first Fly-in that I haven't been able to make...but it was for a good reason! I've attached a picture of what I believe is the TCFG's youngest Commander passenger right now; Reece Elizabeth was born on 9/8/07.? ? I am already looking forward to next year's event. In the meantime, a hearty "Cheers!" to all my Commander friends whom I was unable to see this year, especially those who come across oceans to make the event; Russell, Richard, Sir Barry......hope to see you next year!? ? /John? ? yourtcfg(at)aol.com wrote:? > Despite some weather delays (2 hour stopoever in Durango, Colorado > waiting for a storm to pass through and a lot of flying around stuff) > we made it home in time to have a late dinner and sleep in our own bed > lat night. Total trip time was around 13 hours with about 9.5 hours > of flying time. Had to make an extra fuel stop one hour from home. > The old gal ran well all the way and Russel (from Australia) was able > to get a good bit of flying time from the captain seat! Richard, the > other ozzie flew it most of the way to T82. Wonderful to have them on > board with us. >? > We want to thank all of you who took time out of your busy schedules > to attend the event. We enjoyed seeing old commander friends and > meeting new ones. As Dan said, it is a terrific group of people who > not only fly great airplanes, but know how to have fun. >? > For those of you who missed the event you missed out on a fantastic > venue -- the Hangar Hotel is truely someplace every pilot should > visit. There were 14 beautiful looking tall-tailed birds sitting on > the ramp right outside the hotel entrance and approximately 40 people > in attendance! Not only that, there were great speakers and a visit > to the Pacific War museum where we witnessed a re-enactment of a > Pacific War battle. And, as always the auction was lots of fun with a > few practical jokes thrown in! Barry Collman, our historian came > prepared and entertained us with a litany of jokes during the event > (thanks Barry). Make plans to attend next year as it will be the 60th > anniversary of the flight of the prototye Commander and it would be > wonderful to fill the ramp up with Commanders. We're in the initial > stages of planning and getting permission, etc., but hoping we'll be > able to hold it in Oklahoma City (Wiley Post), the birthplace of the > Com mande r. >? > Anyway, thanks again to all who attended and we look forward to seeing > the rest of you next year. >? > Cheers,? > Jim & Sue Metzger? >? >? > ------------------------------------------------------------------------? > Email and AIM finally together. You've gotta check out free AOL Mail > <http://o.aolcdn.com/cdn.webmail.aol.com/mailtour/aol/en-us/index.htm?ncid=AOLAOF00020000000970>!? > *? >? >? > *? >? >? > __________ NOD32 2521 (20070911) Information __________? >? ________________________________________________________________________ Email and AIM finally together. You've gotta check out free AOL Mail! - http://mail.aol.com ________________________________________________________________________________
Date: Sep 24, 2007
Thanks Nico, this is girl #2 for us, so me & my shotgun will be plenty busy in a few years! Can't wait to see you all next year in OK. /J nico css wrote: > > John, > What a gorgeous reason to stay away. That was worth not going. What a > beautiful child. Keep your shotgun oiled! > Nico > > > -----Original Message----- > From: owner-commander-list-server(at)matronics.com > [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of John > Vormbaum > Sent: Monday, September 24, 2007 10:27 AM > To: commander-list(at)matronics.com > Subject: Re: Commander-List: 2007 TCFG Fky-In > > Jim, > > I was very sorry to miss the event this year. In all the time I've owned > my airplane, this is the first Fly-in that I haven't been able to > make...but it was for a good reason! I've attached a picture of what I > believe is the TCFG's youngest Commander passenger right now; Reece > Elizabeth was born on 9/8/07. > > I am already looking forward to next year's event. In the meantime, a > hearty "Cheers!" to all my Commander friends whom I was unable to see > this year, especially those who come across oceans to make the event; > Russell, Richard, Sir Barry......hope to see you next year! > > /John > > yourtcfg(at)aol.com wrote: > >> Despite some weather delays (2 hour stopoever in Durango, Colorado >> waiting for a storm to pass through and a lot of flying around stuff) >> we made it home in time to have a late dinner and sleep in our own bed >> lat night. Total trip time was around 13 hours with about 9.5 hours >> of flying time. Had to make an extra fuel stop one hour from home. >> The old gal ran well all the way and Russel (from Australia) was able >> to get a good bit of flying time from the captain seat! Richard, the >> other ozzie flew it most of the way to T82. Wonderful to have them on >> board with us. >> >> We want to thank all of you who took time out of your busy schedules >> to attend the event. We enjoyed seeing old commander friends and >> meeting new ones. As Dan said, it is a terrific group of people who >> not only fly great airplanes, but know how to have fun. >> >> For those of you who missed the event you missed out on a fantastic >> venue -- the Hangar Hotel is truely someplace every pilot should >> visit. There were 14 beautiful looking tall-tailed birds sitting on >> the ramp right outside the hotel entrance and approximately 40 people >> in attendance! Not only that, there were great speakers and a visit >> to the Pacific War museum where we witnessed a re-enactment of a >> Pacific War battle. And, as always the auction was lots of fun with a >> few practical jokes thrown in! Barry Collman, our historian came >> prepared and entertained us with a litany of jokes during the event >> (thanks Barry). Make plans to attend next year as it will be the 60th >> anniversary of the flight of the prototye Commander and it would be >> wonderful to fill the ramp up with Commanders. We're in the initial >> stages of planning and getting permission, etc., but hoping we'll be >> able to hold it in Oklahoma City (Wiley Post), the birthplace of the >> Com mander. >> >> Anyway, thanks again to all who attended and we look forward to seeing >> the rest of you next year. >> >> Cheers, >> Jim & Sue Metzger >> >> >> ------------------------------------------------------------------------ >> Email and AIM finally together. You've gotta check out free AOL Mail >> >> > <http://o.aolcdn.com/cdn.webmail.aol.com/mailtour/aol/en-us/index.htm?ncid=A > OLAOF00020000000970>! > >> * >> >> >> * >> >> >> __________ NOD32 2521 (20070911) Information __________ >> >> > > > __________ NOD32 2521 (20070911) Information __________ > > > ________________________________________________________________________________
Subject: Fwd: Follow up
Date: Sep 24, 2007
It would be great to ave 100 Commanders on the ramp for this event, so plan hope all of you are already planning to attend.? The Fly-In is usually held the 3rd weekend of September and once the date has been firmed up we will let you know.? -----Original Message----- From: John Towner <johntowner(at)centralairsouthwest.com> Cc: Dan Farmer ; Bob Steele ; Barry Collman ; Bob & Stan Perkins ; Andrew Towner Sent: Mon, 24 Sep 2007 3:37 pm Subject: Follow up Jim, Thanks for the great e-mail and glad you made it home all safe.? The "Hangar Hotel" I agree was a great venue and I second the motion for PWA next year.? I think I told you we use to have an office at PWA and I can help with many of the details.? Our trip from T82-PWA yesterday with Andrew, Anthony, and Sir Barry was all good.? When we arrived the PWA restaurant was open and Ken Hale (85 years young) met us with his friend.? Ken was head of engineering at Commander until he retired in 1988 and had many stories about Ted Smith and many interesting Commander events. On the way enroute I showed Barry Ken's signature in our AFM and then on arrival Andrew ask Mr Hale to sign it again.? We had a great visit having lunch in the PWA restaurant and afterwards Anthony and Andrew got the big I-Mac and showed Ken the Commander flying on the computer explaining "blade element theory" and I think Ken really got a chuckle out of the showing.? I mentioned to Barry at lunch that the Commander "jigs" are at the approach end of runway 35 with grass and weeds growing up around them and Ken confirmed this and Barry wanted to go see them almost instantly and Ken promised him they would drive down to 50th street and view them after we took off.? Mr Hale told some very interesting stories I had never heard and all in all it was a wonderful experience. One early suggestion.? The best hotel close to PWA is the Waterford Hotel about 3 miles from PWA east on 63rd street and it would be a great place to have the TCFG folks stay next year.? Also Ken said they are moving the 1st Commander from the trade school to a park about 1 mile from PWA and that would be a great Saturday field trip for next year, maybe going through the old factory. Keep in touch and again thank Sue for all of her help and the TCFG get together this year was special.? I would like to try another mailing to all AC owners for the 60th anniversary and it would be a great thing to have about 100 Commanders lined up on the ramp at PWA next year (also Southwest Airlines flies to OKC and it is very easy to get to PWA/OKC from just about anywhere in the USA as you know).? In 1992 we had a company Saturday get together at PWA (1st time all of our Commanders were at the same place at the same time) and it was a special event (Bob Hoover came and did an air show for us under one condition, that we have a party afterwards) and that is what happened. PS-For some silly reason I can't e-mail to the TCFG web site and if you want to share my note with the other AOK with me. YOUR FRIEND, John Towner ________________________________________________________________________ Email and AIM finally together. You've gotta check out free AOL Mail! - http://mail.aol.com ________________________________________________________________________________
From: "brent-mueller(at)comcast.net" <aerocommander-560e(at)comcast.net>
Date: Sep 24, 2007
time and $ are both very demanding at this time ok, there killing me...: ) Looking forward to next years, food for thought... if anyone were close to the Minneapolis, MN metro area, we'd be obliged on having you over. (ANE) Take Care... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=136275#136275 Attachments: http://forums.matronics.com//files/img_0101_197.jpg ________________________________________________________________________________
Date: Sep 25, 2007
Subject: Poor Planning
John VB Your poor planning -as you might know- was a subject of conversation amongst a few of us more enlightened in the group. To help you out for next years event it happens in Sept so you might want to keep your zipper up for all of December and most of Jan. Family Planning --------------------------------- Need a vacation? Get great deals to amazing places on Yahoo! Travel. ________________________________________________________________________________
Date: Sep 25, 2007
Congratulations, John! ________________________________________________________________________________
Date: Sep 25, 2007
Subject: Re: Poor Planning
Ha! Thanks for the advice! Dan Farmer wrote: > John VB > > Your poor planning -as you might know- was a subject of conversation > amongst a few of us more enlightened in the group. To help you out > for next years event it happens in Sept so you might want to keep your > zipper up for all of December and most of Jan. > > Family Planning > > to amazing places on Yahoo! Travel. > > * > > > * > > > __________ NOD32 2521 (20070911) Information __________ > ________________________________________________________________________________
Date: Sep 25, 2007
Subject:
I want to go on the record and say that I for one had a terrific time at the fly in. Jim Addington N444BD ________________________________________________________________________________
From: "Matthew J. Hawkins" <hawkins(at)cms.udel.edu>
Date: Sep 26, 2007
Subject: Pressure Carburetor?
All- Anybody have a good shop they'd recommend that's familiar with working on/overhauling the older pressure carburetors? We sent the left carb on N2760B out to one shop - and it came back better in some ways - but mixture is either full rich or idle cut-off. No adjustment in between. We've gone through the cabling and linkage and all looks good. We think it's internal to the carburetor at this point. Not sure, but the shop we used may have messed something up. Engines are G0-480-D1A's Thoughts? Recommendations? Matt By the way, on our previous problem (engine skip/roughness when reducing power through 21" manifold pressure) was exactly as one of you suggested - improperly adjusted carb heat linkage. Many thanks on that one! ******************** Matthew Hawkins Director, Marine Ops R/V HUGH R. SHARP 302-645-4341 FAX: 302-645-4006 hawkins(at)udel.edu ________________________________________________________________________________
Date: Sep 26, 2007
Subject: Re: Pressure Carburetor?
Matt, Isn't that exactly how a pressure carb is supposed to work? It's automatic mixture control with altitude. IIRC, you leave the levers in full rich for all segments of the flight and the carbs do the rest. Sounds like the shop did a fine job on your overhaul. Cheers, /John Matthew J. Hawkins wrote: > > All- > > Anybody have a good shop they'd recommend that's familiar with working on/overhauling the older pressure carburetors? We sent the left carb on N2760B out to one shop - and it came back better in some ways - but mixture is either full rich or idle cut-off. No adjustment in between. > > We've gone through the cabling and linkage and all looks good. We think it's internal to the carburetor at this point. Not sure, but the shop we used may have messed something up. > > Engines are G0-480-D1A's > > Thoughts? Recommendations? > > Matt > > By the way, on our previous problem (engine skip/roughness when reducing power through 21" manifold pressure) was exactly as one of you suggested - improperly adjusted carb heat linkage. Many thanks on that one! > > ******************** > Matthew Hawkins > Director, Marine Ops > R/V HUGH R. SHARP > 302-645-4341 > FAX: 302-645-4006 > hawkins(at)udel.edu > > > __________ NOD32 2521 (20070911) Information __________ > > > ________________________________________________________________________________
Date: Sep 26, 2007
Hmmm - now I'm going to have to show my (our) ignorance here! Maybe the right one is what needs to be corrected! The right WILL lean out as you adjust the mixture control. Anybody else have thoughts? Matt -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of John Vormbaum Sent: Wednesday, September 26, 2007 2:08 PM Subject: Re: Commander-List: Pressure Carburetor? Matt, Isn't that exactly how a pressure carb is supposed to work? It's automatic mixture control with altitude. IIRC, you leave the levers in full rich for all segments of the flight and the carbs do the rest. Sounds like the shop did a fine job on your overhaul. Cheers, /John Matthew J. Hawkins wrote: > --> > > All- > > Anybody have a good shop they'd recommend that's familiar with working > on/overhauling the older pressure carburetors? We sent the left carb > on N2760B out to one shop - and it came back better in some ways - but > mixture is either full rich or idle cut-off. No adjustment in > between. > > We've gone through the cabling and linkage and all looks good. We > think it's internal to the carburetor at this point. Not sure, but the > shop we used may have messed something up. > > Engines are G0-480-D1A's > > Thoughts? Recommendations? > > Matt > > By the way, on our previous problem (engine skip/roughness when > reducing power through 21" manifold pressure) was exactly as one of > you suggested - improperly adjusted carb heat linkage. Many thanks on > that one! > > ******************** > Matthew Hawkins > Director, Marine Ops > R/V HUGH R. SHARP > 302-645-4341 > FAX: 302-645-4006 > hawkins(at)udel.edu > > > __________ NOD32 2521 (20070911) Information __________ > > ________________________________________________________________________________
Date: Sep 26, 2007
They don't call them Bendix auto pressure carbs. for nothing! I have been told that when I level off, say 8K or above, to pull it back gently then push it back to full rich. So that is what I do. Don ----- Original Message ----- From: "Matthew J. Hawkins" <hawkins(at)cms.udel.edu> Sent: Wednesday, September 26, 2007 2:39 PM Subject: RE: Commander-List: Pressure Carburetor? > > > Hmmm - now I'm going to have to show my (our) ignorance here! Maybe the > right one is what needs to be corrected! The right WILL lean out as you > adjust the mixture control. > > Anybody else have thoughts? > > Matt > > -----Original Message----- > From: owner-commander-list-server(at)matronics.com > [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of John > Vormbaum > Sent: Wednesday, September 26, 2007 2:08 PM > To: commander-list(at)matronics.com > Subject: Re: Commander-List: Pressure Carburetor? > > > Matt, > > Isn't that exactly how a pressure carb is supposed to work? It's automatic > mixture control with altitude. IIRC, you leave the levers in full rich for > all segments of the flight and the carbs do the rest. Sounds like the shop > did a fine job on your overhaul. > > Cheers, > > /John > > Matthew J. Hawkins wrote: >> --> >> >> All- >> >> Anybody have a good shop they'd recommend that's familiar with working >> on/overhauling the older pressure carburetors? We sent the left carb >> on N2760B out to one shop - and it came back better in some ways - but >> mixture is either full rich or idle cut-off. No adjustment in >> between. >> >> We've gone through the cabling and linkage and all looks good. We >> think it's internal to the carburetor at this point. Not sure, but the >> shop we used may have messed something up. >> >> Engines are G0-480-D1A's >> >> Thoughts? Recommendations? >> >> Matt >> >> By the way, on our previous problem (engine skip/roughness when >> reducing power through 21" manifold pressure) was exactly as one of >> you suggested - improperly adjusted carb heat linkage. Many thanks on >> that one! >> >> ******************** >> Matthew Hawkins >> Director, Marine Ops >> R/V HUGH R. SHARP >> 302-645-4341 >> FAX: 302-645-4006 >> hawkins(at)udel.edu >> >> >> >> >> >> >> __________ NOD32 2521 (20070911) Information __________ >> >> >> >> >> > > > -- > 9/26/2007 12:12 PM > > ________________________________________________________________________________
Date: Sep 26, 2007
In a message dated 26-Sep-07 11:08:51 Pacific Daylight Time, john(at)vormbaum.com writes: Isn't that exactly how a pressure carb is supposed to work? It's automatic mixture control with altitude Kinda. The "Auto Lean" should lean with an increase in altitude and vice versa. These can also be manually leaned and sometimes need to be if the auto lean isn't working. Evidence of auto lean not working is fogging of one (or both) exhausts, excessive carbon or black soot in the stacks after a flight. I once flew an AC-680E with one shot diaphragm and had to hold the mixture of that engine in a lean position for as much as I could between California and Florida. The mixture control would not stay where I wanted it in the manual leaned position and that got tedious. Upon delivery, the pressure carbs got sent to a rebuild shop with Mr. Kernick's direction. The idea is to have properly operating pressure carbs that lean / enrichen automatically. By the way, those of you with pressure carbs, when you shut down the engine, do not leave the mixtures in idle cut off. This will stretch out and dry out the diaphragms. So put them back in full rich when your Commander is sleeping. Wing Commander Gordon ________________________________________________________________________________
Date: Sep 26, 2007
I heard that, if you have neoprene gaskets,diaphrams etc. installed @ carburator over-haul, you can then leave the mixture in the off position. It seems that I also heard that a bullitin was issued recommending that neoprene be installed. Any one know for sure about this? Thanks Gil- Wingflyer ________________________________________________________________________________
Date: Sep 26, 2007
HI MATT.? It sounds to me like the carb is working properly.? You should never manually lean your carbs except in case of emergency (like WCG described).? Many years ago I bought a 560A and as I flew it home I literally read the flight manual, on my lap,?since I had no idea how to fly the thing.? The manual states that is is possible to manually?lean the airplane above 10,000 feet.? So, as I crossed the Rocky Mts, at 12Kt, I decided to lean the engines.? They were running perfect, but I just could not leave well enough alone.? Well, I learned a couple of things about Commanders!!? First, you don't need to lean the stinking carbs!!? Second, whenever you do anything to a twin engine airplane, do it?one engine at a time.? I reached for the mixture levers and moved them back about 1/2 way.? Nothing happened??? As I continued to pull them back a bit more, BOTH engines quit cold!!? The silence was defining.? It only took about one millisecond to get the mixtures back forward. If you read the lettering on your power quadrant, you will notice that the mixtures are not labeled "rich" & "lean".? Instead, they say "normal" & "idle cut off" (Stop & go). I think you new carb is working great and I wonder why the old carb will allow you to lean it??? jb -----Original Message----- From: Matthew J. Hawkins <hawkins(at)cms.udel.edu> Sent: Wed, 26 Sep 2007 9:43 am Subject: Commander-List: Pressure Carburetor? All- Anybody have a good shop they'd recommend that's familiar with working on/overhauling the older pressure carburetors? We sent the left carb on N2760B out to one shop - and it came back better in some ways - but mixture is either full rich or idle cut-off. No adjustment in between. We've gone through the cabling and linkage and all looks good. We think it's internal to the carburetor at this point. Not sure, but the shop we used may have messed something up. Engines are G0-480-D1A's Thoughts? Recommendations? Matt By the way, on our previous problem (engine skip/roughness when reducing power through 21" manifold pressure) was exactly as one of you suggested - improperly adjusted carb heat linkage. Many thanks on that one! ******************** Matthew Hawkins Director, Marine Ops R/V HUGH R. SHARP 302-645-4341 FAX: 302-645-4006 hawkins(at)udel.edu ________________________________________________________________________ Email and AIM finally together. You've gotta check out free AOL Mail! - http://mail.aol.com ________________________________________________________________________________
Date: Sep 26, 2007
The only gaskets available are neopream, (orenge)? You shoud still leave the mix forward (and the fuel "on") when parked for an extended time, overnight or longer.? The reason is the diaphrams are streched when pulled to idel cut off and will quiclky take a "set" if left there.? Leave the fuel on to "flood" the inside of the carb with fuel to keep all of the pars properly lubed.? Also, although not officialy sanctiond, you will likly find a can of Mavel mistery Oil in the hangar of an experianced, presure carb owner.? Used in the fuel system it will lube the inside of the carbs.? jb -----Original Message----- From: WINGFLYER1(at)aol.com Sent: Wed, 26 Sep 2007 7:13 pm Subject: Re: Commander-List: Pressure Carburetor? I heard that, if you have neoprene gaskets,diaphrams etc. installed?@ carburator over-haul, you can then leave the mixture in the off position. It seems that I also heard that a bullitin was issued recommending that neoprene be installed. Any one know for sure about this? Thanks Gil- Wingflyer See what's new a_blank">Make AOL Your Homepage. ________________________________________________________________________ Email and AIM finally together. You've gotta check out free AOL Mail! - http://mail.aol.com ________________________________________________________________________________
Date: Sep 26, 2007
Jb- Good story. Made more so by the fact that you'll admit to having done something that most of us would attribute to "a friend was flying a commander.." Rob From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of yourtcfg(at)aol.com Sent: Wednesday, September 26, 2007 7:39 PM Subject: Re: Commander-List: Pressure Carburetor? HI MATT. It sounds to me like the carb is working properly. You should never manually lean your carbs except in case of emergency (like WCG described). Many years ago I bought a 560A and as I flew it home I literally read the flight manual, on my lap, since I had no idea how to fly the thing. The manual states that is is possible to manually lean the airplane above 10,000 feet. So, as I crossed the Rocky Mts, at 12Kt, I decided to lean the engines. They were running perfect, but I just could not leave well enough alone. Well, I learned a couple of things about Commanders!! First, you don't need to lean the stinking carbs!! Second, whenever you do anything to a twin engine airplane, do it one engine at a time. I reached for the mixture levers and moved them back about 1/2 way. Nothing happened?? As I continued to pull them back a bit more, BOTH engines quit cold!! The silence was defining. It only took about one millisecond to get the mixtures back forward. If you read the lettering on your power quadrant, you will notice that the mixtures are not labeled "rich" & "lean". Instead, they say "normal" & "idle cut off" (Stop & go). I think you new carb is working great and I wonder why the old carb will allow you to lean it?? jb -----Original Message----- From: Matthew J. Hawkins <hawkins(at)cms.udel.edu> Sent: Wed, 26 Sep 2007 9:43 am Subject: Commander-List: Pressure Carburetor? All- Anybody have a good shop they'd recommend that's familiar with working on/overhauling the older pressure carburetors? We sent the left carb on N2760B out to one shop - and it came back better in some ways - but mixture is either full rich or idle cut-off. No adjustment in between. We've gone through the cabling and linkage and all looks good. We think it's internal to the carburetor at this point. Not sure, but the shop we used may have messed something up. Engines are G0-480-D1A's Thoughts? Recommendations? Matt By the way, on our previous problem (engine skip/roughness when reducing power through 21" manifold pressure) was exactly as one of you suggested - improperly adjusted carb heat linkage. Many thanks on that one! ******************** Matthew Hawkins Director, Marine Ops R/V HUGH R. SHARP 302-645-4341 FAX: 302-645-4006 hawkins(at)udel.edu _____ Email and AIM finally together. You've gotta check out free AOL Mail <http://o.aolcdn.com/cdn.webmail.aol.com/mailtour/aol/en-us/index.htm?ncid=A OLAOF00020000000970> ! __________ NOD32 2554 (20070926) Information __________ ________________________________________________________________________________
Date: Sep 27, 2007
jb- What a GREAT description of what we've seen! Thanks so much for passing th is on. Somehow something so obvious and important has escaped us until now . Guess we've had so many things to deal with on this overhaul that this f inally rose to the "top of the pile". Both engines only have about 12-15 hours on them and seem to be running ric h - plugs fouling until getting up to temp. We could lean the right side o ut enough to get a good mag check, but left wouldn't lean - though we had l ess problems with the left mags than the right. So this is what lead us to my question. Thinking about going with the wire-type plugs that don't foul. Good idea? Sounds like the left side is doing what it's supposed to do. Right side ma y still not be working properly with "auto lean" but sounds like it's not n ecessarily a danger - just need to be aware of it for now. We'll get it lo oked at - but at least we understand (now) what the carbs are supposed to b e doing. Many thanks to all of you! Matt -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-lis t-server(at)matronics.com] On Behalf Of yourtcfg(at)aol.com Sent: Wednesday, September 26, 2007 10:39 PM Subject: Re: Commander-List: Pressure Carburetor? HI MATT. It sounds to me like the carb is working properly. You should never manual ly lean your carbs except in case of emergency (like WCG described). Many years ago I bought a 560A and as I flew it home I literally read the flight manual, on my lap, since I had no idea how to fly the thing. The manual s tates that is is possible to manually lean the airplane above 10,000 feet. So, as I crossed the Rocky Mts, at 12Kt, I decided to lean the engines. T hey were running perfect, but I just could not leave well enough alone. We ll, I learned a couple of things about Commanders!! First, you don't need to lean the stinking carbs!! Second, whenever you do anything to a twin en gine airplane, do it one engine at a time. I reached for the mixture lever s and moved them back about 1/2 way. Nothing happened?? As I continued to pull them back a bit more, BOTH engines quit cold!! The silence was defin ing. It only took about one millisecond to get the mixtures back forward. If you read the lettering on your power quadrant, you will notice that the mixtures are not labeled "rich" & "lean". Instead, they say "normal" & "id le cut off" (Stop & go). I think you new carb is working great and I wonder why the old carb will al low you to lean it?? jb -----Original Message----- From: Matthew J. Hawkins <hawkins(at)cms.udel.edu> Sent: Wed, 26 Sep 2007 9:43 am Subject: Commander-List: Pressure Carburetor? l.edu> All- Anybody have a good shop they'd recommend that's familiar with working on/overhauling the older pressure carburetors? We sent the left carb on N2 760B out to one shop - and it came back better in some ways - but mixture is eit her full rich or idle cut-off. No adjustment in between. We've gone through the cabling and linkage and all looks good. We think it 's internal to the carburetor at this point. Not sure, but the shop we used ma y have messed something up. Engines are G0-480-D1A's Thoughts? Recommendations? Matt By the way, on our previous problem (engine skip/roughness when reducing po wer through 21" manifold pressure) was exactly as one of you suggested - improp erly adjusted carb heat linkage. Many thanks on that one! ******************** Matthew Hawkins Director, Marine Ops R/V HUGH R. SHARP 302-645-4341 FAX: 302-645-4006 hawkins(at)udel.edu ________________________________ Email and AIM finally together. You've gotta check out free AOL Mail! ________________________________________________________________________________
Date: Sep 27, 2007
Good Morning Matt, May I add a caveat or two? I have no knowledge at all concerning the specific pressure carburetors with which your airplane is equipped, but there are many pressure carburetors that DO need to be manually leaned. The ubiquitous Bendix PS5c is one such pressure carburetor. It has no AMC (Automatic Mixture Control) unit involved in it's operation. The degree of automation for pressure carburetors varies from having an electric switch to turn the whole shebang OFF or ON to having additional settings for Takeoff, Climb, Auto Lean, Auto Rich, and Idle Cutoff. The number of variations is only limited by the desires of the engine user and the fuel control designer. The vast majority of the pressure carburetors in use can benefit from manual leaning under many conditions. However, such manually leaning is generally only recommended when the operator has adequate instrumentation and time available to evaluate the effects of that manual leaning process. Prior to the introduction of turbojet powered aircraft to the airline industry, I spent fourteen years flying big round engines that were equipped with "Pressure Carburetors". I also had a flight engineer whose primary job was using the manual leaning capability of the pressure carburetors to gain the greatest efficiency possible for our operations. I would suggest that anyone who is interested in manual leaning first equip their engine with a modern engine monitor and a good electronic fuel flow measurement device, then learn to properly interpret what that information is telling us. Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator Stearman N3977A Brookeridge Air Park LL22 Downers Grove, IL 60516 630 985-8503 In a message dated 9/27/2007 6:35:00 A.M. Central Daylight Time, hawkins(at)cms.udel.edu writes: What a GREAT description of what we've seen! Thanks so much for passing this on. Somehow something so obvious and important has escaped us until now. Guess we've had so many things to deal with on this overhaul that this finally rose to the "top of the pile". ________________________________________________________________________________
Date: Sep 27, 2007
Let's slow down and think about this for a bit. Unfortunately most of the original TC drivers mechanics and designers are long gone and we have to rely on word of mouth OWTs and seat of the pants in flying these things but sometimes careful analysis of common sense and known physics can be helpful. It is called a MIXTURE control, not an on/off control. And it is there for a reason. This says that as you move the lever it alters the fuel air ratio. It does this by tightening a diaphragm which lessens the automatic input from the aneroid barometer and it also slides a precision needle valve in and out of it's seat adjusting the fuel air mixture/ratio. The pressure carb also alters the fuel air ratio based on the changing altitude/ ambient pressure as you climb/descend. While this takes some of the workload off the pilot we all know mixture should be adjusted relative to peak EGT. Pressure carbs adjusting for altitude only get a close approximation to getting the mixture to where the engine is happy and efficient. With AVGAS at $4+ a gallon efficient is becoming very important. Also the accuracy of the mixture is only as good as the tech that rebuilds or calibrates the carb. I do not believe there is anyone left alive who can do this properly on a commander. Last I knew there was only one working test bench left in existence. If your carbs were not done on this bench and Jet A or deisel was not used for calibration then they are NOT working correctly. Much has been said about "stretching" the diaphragm. This should convince you that the mixture lever does more than turn things on or off. The reason to leave it full rich at shutdown is twofold. 1. The diaphragm will dry out and age quickly if you do this, 2. The mixture control also moves a needle valve that is fully seated against a brass boss in the ICO position. If left in ICO the needle valve will leave an indent in the brass boss and leak. The correct way to lean a normally aspirated pressure carb in a Twin Commander is...... When at altitude (over 5000') and you have full throttle and the props set, pull the throttle back till you get the 1st visible decrease in manifold pressure. then advance the throttle to max Manifold pressure obtainable. The manual and many old timers would now say you are leaned. But you have that nice red lever that puts tension on a diaphragm and moves a needle valve both of which adjust fuel air ratio. Now why was it put there? So in the best of all worlds you have an engine monitor that monitors all your EGTs and CHTs as well as a fuel flow indicator for each engine. Then you can lean to peak if under 65% power (which you will be under at altitude) or if you are a wuss lean somwhere ROP or if a real man try to go LOP if the engine remains smooth. If you do not have the fancy gizmos then lean till the engine gets rough then push it a skosh forward. In my 560 this invariably saved me 2.5 GPH per engine at cruise or 5 GPH total. at 300 hrs a year this adds up to mucho deniro. In the super charged versions your throttle will be set at wherever you set it for cruise so just lean till rough then enrichen. In the supercharged versions you need to be cautious and remain ROP as you most likely will be above 65% power and can cause harm at peak and LOP. To remain ROP do not dally when the engine gets rough bump that red rascal forward about an eighth of an inch quickly. A caveat is the 560Fs for some reason the engine/carb combination on these setups will often do as JB described that is they go from cruise to silence. I suspect this has more to do with poor rebuild or calibration and maintenance than the setup it self. I have found after several years of playing with LOP operations using engine analyzers that if your goal is efficiency and safe operation while running ROP then the lean to rough and a skosh forward on the mixture control will put your mixture lever in exactly the same place the fancy expensive engine monitor will have you put it by using their auto lean algorithms. If you like to play with LOP and have FI and a super or turbocharger do not even attempt it without an engine analyzer. If you lean correctly and control temps correctly not only does this save fuel but more importantly in these old birds it will greatly prolong engine life. Well that was a long post and I hope helpful. The short answer to the original post is your carbs (statistically) are most likely not calibrated correctly and while they may be safe I would not assume so. I cannot remember the shop or tech that can do it but the name Czarnecki in Oklahoma rings a bell as does the word "precision" in the shop name. One of the old timers should be able to steer you there. It may also be listed somewhere in the old Commander list archives that I believe Nico is the keeper of. -------- Milt 2003 F1 Rocket 2006 Radial Rocket Read this topic online here: http://forums.matronics.com/viewtopic.php?p=136751#136751 ________________________________________________________________________________
Date: Sep 27, 2007
As an aside to this thread but same subject I am currently flying an M14PF (Russian Radial) that has a pressure carb and no mixture control. These are great engines but the carbs are hard to come by and there are no parts available to rebuild them. There is nobody who can calibrate the and no equipment or instructions to calibrate them with. Not a good scenario. So I put an Airflow Performance INc. ( http://www.airflowperformance.com/html/site_html.html ) Throttle body on it that has a mixture control. The throttle body is a close 1st cousin to a pressure carb and a step up on the evolutionary ladder to fuel injection. The thing is simplicity itself and required no engine mods or adjustments. It jives me additional HP and full control of mixture at all altitudes. Now I would never suggest violation of FARs but if I still owned a Twin Commander I would be sorely tempted to slap a couple of these on as opposed to rebuilding those old pressure carbs. They make several modes for Lycomings. (experimental of course) In the pictures attached below the throttle body can be seen with a blue elbow attached to it. -------- Milt 2003 F1 Rocket 2006 Radial Rocket Read this topic online here: http://forums.matronics.com/viewtopic.php?p=136761#136761 Attachments: http://forums.matronics.com//files/img_1832_small_148.jpg http://forums.matronics.com//files/img_1909_small_634.jpg ________________________________________________________________________________
Date: Sep 27, 2007
Milt, When I leave the mixture forward The right carb on my 680 leaks about a gallon or two over night. Since I am a new 680 owner I am trying to learn as much as I can. Any info would be helpful. Thanks Gil Wingflyer. ________________________________________________________________________________
Date: Sep 27, 2007
Had a problem with the left engine not starting easy, spitting , spurttering and running rough. After the first so called mechanic adjusted and rebuilt the carb on my 680 another mechanic found the problem. The intake manifold gaskets needed to be replaced. Cured the problem. Sometimes all the adjusting and re-building may not be the true answer. You have to check it ALL. Gil ________________________________________________________________________________
Date: Sep 26, 2007
Thanks for the info. When I leave the mixture rich on my 680, fuel leaks out of the right carb. Know of any fix for the leaking. Thanks Gil ________________________________________________________________________________
Date: Sep 28, 2007
Caulk. bb _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of WINGFLYER1(at)aol.com Sent: Wednesday, September 26, 2007 10:56 PM Subject: Re: Commander-List: Pressure Carburetor? Thanks for the info. When I leave the mixture rich on my 680, fuel leaks out of the right carb. Know of any fix for the leaking. Thanks Gil _____ See what's new at AOL.com and ________________________________________________________________________________
Date: Sep 29, 2007
HI MATT Yes, fine wire plugs are worth the money, I have them in both?my airplanes.? Also, All Commanders left the factory with fine wire plugs, even in 1956.? You have two adjustments on your carbs.? If they are rich on the ground, they are probably rich in flight.? There is an idle mix adj at the throttle arm (see you maint manual) and an "off idle" adj.? Both will need to be "tweeked" if the carbs have been off the airplane.? Call me at 360-903-6901, I talk faster than i type.? jb Thinking about going with the wire-type plugs that don't foul.? Good idea?? -----Original Message----- From: Matthew J. Hawkins <hawkins(at)cms.udel.edu> Sent: Thu, 27 Sep 2007 4:33 am Subject: RE: Commander-List: Pressure Carburetor? jb- ? What a?GREAT description of what we've seen!? Thanks so much for passing this on.? Somehow something so obvious and important has escaped us until now.? Guess we've had so many things to deal with on this overhaul that this finally rose to the "top of the pile". ? Both engines only have about 12-15 hours on them and seem to be running rich - plugs fouling until getting up to temp.? We could lean the?right side out enough to get a good mag check, but?left wouldn't lean - though we had less problems with the left mags than the right.? So this is what?lead us to my question. ? Thinking about going with the wire-type plugs that don't foul.? Good idea?? ? Sounds like the left side is doing what it's supposed to do.? Right side may still not be working properly with "auto lean" but sounds like it's not necessarily a danger - just need to be aware of it for now.? We'll get it looked at - but at least we understand (now) what the carbs are supposed to be doing. ? Many thanks to all of you! ? Matt -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of yourtcfg(at)aol.com Sent: Wednesday, September 26, 2007 10:39 PM Subject: Re: Commander-List: Pressure Carburetor? HI MATT.? It sounds to me like the carb is working properly.? You should never manually lean your carbs except in case of emergency (like WCG described).? Many years ago I bought a 560A and as I flew it home I literally read the flight manual, on my lap,?since I had no idea how to fly the thing.? The manual states that is is possible to manually?lean the airplane above 10,000 feet.? So, as I crossed the Rocky Mts, at 12Kt, I decided to lean the engines.? They were running perfect, but I just could not leave well enough alone.? Well, I learned a couple of things about Commanders!!? First, you don't need to lean the stinking carbs!!? Second, whenever you do anything to a twin engine airplane, do it?one engine at a time.? I reached for the mixture levers and moved them back about 1/2 way.? Nothing happened??? As I continued to pull them back a bit more, BOTH engines quit cold!!? The silence was defining.? It only took about one millisecond to get the mixtures back forward. If you read the lettering on your power quadrant, you will notice that the mixtures are not labeled "rich" & "lean".? Instead, they say "normal" & "idle cut off" (Stop & go). I think you new carb is working great and I wonder why the old carb will allow you to lean it??? jb -----Original Message----- From: Matthew J. Hawkins <hawkins(at)cms.udel.edu> Sent: Wed, 26 Sep 2007 9:43 am Subject: Commander-List: Pressure Carburetor? All- Anybody have a good shop they'd recommend that's familiar with working on/overhauling the older pressure carburetors? We sent the left carb on N2760B out to one shop - and it came back better in some ways - but mixture is either full rich or idle cut-off. No adjustment in between. We've gone through the cabling and linkage and all looks good. We think it's internal to the carburetor at this point. Not sure, but the shop we used may have messed something up. Engines are G0-480-D1A's Thoughts? Recommendations? Matt By the way, on our previous problem (engine skip/roughness when reducing power through 21" manifold pressure) was exactly as one of you suggested - improperly adjusted carb heat linkage. Many thanks on that one! ******************** Matthew Hawkins Director, Marine Ops R/V HUGH R. SHARP 302-645-4341 FAX: 302-645-4006 hawkins(at)udel.edu Email and AIM finally together. You've gotta check out free AOL Mail! ">http://www.matronics.com/Navigator?Commander-List ics.com ________________________________________________________________________ Email and AIM finally together. You've gotta check out free AOL Mail! - http://mail.aol.com ________________________________________________________________________________
Date: Sep 29, 2007
Sorry Milt, but you are wrong.? Your straight 560?may have?had manually leaning carbs, the?AUTO lean carbs need to be left in the "normal" position for all flight and ground operations.? They are NOT to be routinely?adjusted in flight.??That is why the factory lab;ed the quadrant "normal & Idle cut off" rather than "rich & lean".? jb??? -----Original Message----- From: N395V <airboss(at)excaliburaviation.com> Sent: Thu, 27 Sep 2007 6:42 am Subject: Commander-List: Re: Pressure Carburetor? Let's slow down and think about this for a bit. Unfortunately most of the original TC drivers mechanics and designers are long gone and we have to rely on word of mouth OWTs and seat of the pants in flying these things but sometimes careful analysis of common sense and known physics can be helpful. It is called a MIXTURE control, not an on/off control. And it is there for a reason. This says that as you move the lever it alters the fuel air ratio. It does this by tightening a diaphragm which lessens the automatic input from the aneroid barometer and it also slides a precision needle valve in and out of it's seat adjusting the fuel air mixture/ratio. The pressure carb also alters the fuel air ratio based on the changing altitude/ ambient pressure as you climb/descend. While this takes some of the workload off the pilot we all know mixture should be adjusted relative to peak EGT. Pressure carbs adjusting for altitude only get a close approximation to getting the mixture to where the engine is happy and efficient. With AVGAS at $4+ a gallon efficient is becoming very important. Also the accuracy of the mixture is only as good as the tech that rebuilds or calibrates the carb. I do not believe there is anyone left alive who can do this properly on a commander. Last I knew there was only one working test bench left in existence. If your carbs were not done on this bench and Jet A or deisel was not used for calibration then they are NOT working correctly. Much has been said about "stretching" the diaphragm. This should convince you that the mixture lever does more than turn things on or off. The reason to leave it full rich at shutdown is twofold. 1. The diaphragm will dry out and age quickly if you do this, 2. The mixture control also moves a needle valve that is fully seated against a brass boss in the ICO position. If left in ICO the needle valve will leave an indent in the brass boss and leak. The correct way to lean a normally aspirated pressure carb in a Twin Commander is...... When at altitude (over 5000') and you have full throttle and the props set, pull the throttle back till you get the 1st visible decrease in manifold pressure. then advance the throttle to max Manifold pressure obtainable. The manual and many old timers would now say you are leaned. But you have that nice red lever that puts tension on a diaphragm and moves a needle valve both of which adjust fuel air ratio. Now why was it put there? So in the best of all worlds you have an engine monitor that monitors all your EGTs and CHTs as well as a fuel flow indicator for each engine. Then you can lean to peak if under 65% power (which you will be under at altitude) or if you are a wuss lean somwhere ROP or if a real man try to go LOP if the engine remains smooth. If you do not have the fancy gizmos then lean till the engine gets rough then push it a skosh forward. In my 560 this invariably saved me 2.5 GPH per engine at cruise or 5 GPH total. at 300 hrs a year this adds up to mucho deniro. In the super charged versions your throttle will be set at wherever you set it for cruise so just lean till rough then enrichen. In the supercharged versions you need to be cautious and remain ROP as you most likely will be above 65% power and can cause harm at peak and LOP. To remain ROP do not dally when the engine gets rough bump that red rascal forward about an eighth of an inch quickly. A caveat is the 560Fs for some reason the engine/carb combination on these setups will often do as JB described that is they go from cruise to silence. I suspect this has more to do with poor rebuild or calibration and maintenance than the setup it self. I have found after several years of playing with LOP operations using engine analyzers that if your goal is efficiency and safe operation while running ROP then the lean to rough and a skosh forward on the mixture control will put your mixture lever in exactly the same place the fancy expensive engine monitor will have you put it by using their auto lean algorithms. If you like to play with LOP and have FI and a super or turbocharger do not even attempt it without an engine analyzer. If you lean correctly and control temps correctly not only does this save fuel but more importantly in these old birds it will greatly prolong engine life. Well that was a long post and I hope helpful. The short answer to the original post is your carbs (statistically) are most likely not calibrated correctly and while they may be safe I would not assume so. I cannot remember the shop or tech that can do it but the name Czarnecki in Oklahoma rings a bell as does the word "precision" in the shop name. One of the old timers should be able to steer you there. It may also be listed somewhere in the old Commander list archives that I believe Nico is the keeper of. -------- Milt 2003 F1 Rocket 2006 Radial Rocket Read this topic online here: http://forums.matronics.com/viewtopic.php?p=136751#136751 ________________________________________________________________________ Email and AIM finally together. You've gotta check out free AOL Mail! - http://mail.aol.com ________________________________________________________________________________
Date: Sep 29, 2007
HI MILT.? I am not picking on you, but need to make one other correction.? This may be why you were saving gas by manully leaaning you carbs.? On normally asperated engins, equiped with auto lean carbs, it is important to retard the throttls in cruse.? These carbs are equiped with a enrichment valve that is opened at throttle settings above 80%.? This feature uses fuel to cool the engine durring climb and high power settinsg.? Once you reach you cruse altitude, you should retard the throttls as far as possible and still maintane the desired MP.? This closes the enrichment valve and alows the carb to adjust the mix properly.? If the throttle is left fully forward, the ericment valve will reamin open, defeating a portion of the auto lean circut.? jb When at altitude (over 5000') and you have full throttle and the props set, -----Original Message----- From: N395V <airboss(at)excaliburaviation.com> Sent: Thu, 27 Sep 2007 6:42 am Subject: Commander-List: Re: Pressure Carburetor? Let's slow down and think about this for a bit. Unfortunately most of the original TC drivers mechanics and designers are long gone and we have to rely on word of mouth OWTs and seat of the pants in flying these things but sometimes careful analysis of common sense and known physics can be helpful. It is called a MIXTURE control, not an on/off control. And it is there for a reason. This says that as you move the lever it alters the fuel air ratio. It does this by tightening a diaphragm which lessens the automatic input from the aneroid barometer and it also slides a precision needle valve in and out of it's seat adjusting the fuel air mixture/ratio. The pressure carb also alters the fuel air ratio based on the changing altitude/ ambient pressure as you climb/descend. While this takes some of the workload off the pilot we all know mixture should be adjusted relative to peak EGT. Pressure carbs adjusting for altitude only get a close approximation to getting the mixture to where the engine is happy and efficient. With AVGAS at $4+ a gallon efficient is becoming very important. Also the accuracy of the mixture is only as good as the tech that rebuilds or calibrates the carb. I do not believe there is anyone left alive who can do this properly on a commander. Last I knew there was only one working test bench left in existence. If your carbs were not done on this bench and Jet A or deisel was not used for calibration then they are NOT working correctly. Much has been said about "stretching" the diaphragm. This should convince you that the mixture lever does more than turn things on or off. The reason to leave it full rich at shutdown is twofold. 1. The diaphragm will dry out and age quickly if you do this, 2. The mixture control also moves a needle valve that is fully seated against a brass boss in the ICO position. If left in ICO the needle valve will leave an indent in the brass boss and leak. The correct way to lean a normally aspirated pressure carb in a Twin Commander is...... When at altitude (over 5000') and you have full throttle and the props set, pull the throttle back till you get the 1st visible decrease in manifold pressure. then advance the throttle to max Manifold pressure obtainable. The manual and many old timers would now say you are leaned. But you have that nice red lever that puts tension on a diaphragm and moves a needle valve both of which adjust fuel air ratio. Now why was it put there? So in the best of all worlds you have an engine monitor that monitors all your EGTs and CHTs as well as a fuel flow indicator for each engine. Then you can lean to peak if under 65% power (which you will be under at altitude) or if you are a wuss lean somwhere ROP or if a real man try to go LOP if the engine remains smooth. If you do not have the fancy gizmos then lean till the engine gets rough then push it a skosh forward. In my 560 this invariably saved me 2.5 GPH per engine at cruise or 5 GPH total. at 300 hrs a year this adds up to mucho deniro. In the super charged versions your throttle will be set at wherever you set it for cruise so just lean till rough then enrichen. In the supercharged versions you need to be cautious and remain ROP as you most likely will be above 65% power and can cause harm at peak and LOP. To remain ROP do not dally when the engine gets rough bump that red rascal forward about an eighth of an inch quickly. A caveat is the 560Fs for some reason the engine/carb combination on these setups will often do as JB described that is they go from cruise to silence. I suspect this has more to do with poor rebuild or calibration and maintenance than the setup it self. I have found after several years of playing with LOP operations using engine analyzers that if your goal is efficiency and safe operation while running ROP then the lean to rough and a skosh forward on the mixture control will put your mixture lever in exactly the same place the fancy expensive engine monitor will have you put it by using their auto lean algorithms. If you like to play with LOP and have FI and a super or turbocharger do not even attempt it without an engine analyzer. If you lean correctly and control temps correctly not only does this save fuel but more importantly in these old birds it will greatly prolong engine life. Well that was a long post and I hope helpful. The short answer to the original post is your carbs (statistically) are most likely not calibrated correctly and while they may be safe I would not assume so. I cannot remember the shop or tech that can do it but the name Czarnecki in Oklahoma rings a bell as does the word "precision" in the shop name. One of the old timers should be able to steer you there. It may also be listed somewhere in the old Commander list archives that I believe Nico is the keeper of. -------- Milt 2003 F1 Rocket 2006 Radial Rocket Read this topic online here: http://forums.matronics.com/viewtopic.php?p=136751#136751 ________________________________________________________________________ Email and AIM finally together. You've gotta check out free AOL Mail! - http://mail.aol.com ________________________________________________________________________________
Date: Sep 29, 2007
I was wondering if anyone was paying attention. Nope the 560 had pressure carbs. It is odd that you have a lever that moves 4-5 inches and moves things inside the carb for just on and off. Seems it would have been simpler to just out an on/off valve at the carb inlet. I had a Cessna that had a mixture controlo labelled only open and idle cutoff. It was certainly there to control mixture. -------- Milt 2003 F1 Rocket 2006 Radial Rocket Read this topic online here: http://forums.matronics.com/viewtopic.php?p=137167#137167 ________________________________________________________________________________
Date: Sep 29, 2007
The following is a reprint from "Light Plane Maintenance" Discussing aircraft mixture control systems. It is lengthy but a good read, especially the section on pressure carbs and leaning method by type of fuel distribution system. As you can see from the article pressure carbs require manual mixture adjustment to get the most out of your engine. JB I think you are a bit premature with the use of the word "wrong" I do not doubt that you and many Commander pilots and many older pilots were taught that the mixture control on PS5 pressure carbs is simply an on off switch. That concept is just plain wrong and needs to be questioned rather than just passed on as gospel. In the old days fuel was a cheap coolant and leaving a pressure carb at full rich was acceptable practice. It even made its way into some manuals although I do not recall seeing it in a commander manual. Mr Bendix did not attach the mixture control to a "METERING NEEDLE VALVE" for the purpose of on and off. If on/off were his intent he would have put a ball valve on the carb inlet. This concept is just as dated as Don't run oversquare MP>RPM/1000 Rapid throttle reduction causes shock cooling.. Data clearly shows flight into precipitation causes greater mor rapid cooling. Do not run LOP.. Once again date clearly refutes this. Any way the article follows. Mixture Control by LIGHT PLANE MAINTENANCE staff Part 1 - Mixture Control Systems Here we go again, another article on mixture management destined to tell me things I already know. Well, maybe. It's entirely possible that some information will seem repetitious, but, then again, redundancy in aviation isn't such a bad thing either. judging from some reader questions, such a revisit to the topic is warranted. Mixture Control is written from the pilot's perspective, by a professional test-pilot, and is designed to answer the why, when, where and how of mixture control and proper leaning procedure for various fuel delivery systems. It is an encyclopedia of fuel management. To the layman, it translates into verse as "How to avoid burning a hole in your wallet". Inspite of the proliferation of digital instrumentation, the Basic EGT is still an outstanding instrument for monitoring Fuel Flow vs Percent Power. Most of the material in this article is based on this basic level of instrumentation and control. Units of measurement remain in the original Imperial units (oF, for example) because over 60% of aircraft in use are more than 50 years old. Air-Fuel Ratios/Distribution In general terms, mixture is defined as the ratio of air to fuel by weight (or more accurately, mass). Most engines will burn air-fuel ratios of 8:1 to 18: 1. Eight-to-one being very rich and eighteen-to-one being very lean. The "chemically correct" (otherwise known as stoichiometric) mixture is about 15:1. This is the mixture ratio where you would expect to find peak EGT in a perfect burn, but atomization inefficiencies put the peak EGT ratio probably closer to 13 or 14 to 1. You might say, "So what's this gobbledygook about ratios? I don't have a direct air-fuel ratio indicator in my plane." That's true, but it will help in understanding the different leaning procedures on different fuel metering/distributing systems. The most common fuel distribution systems found in general aviation are: carburetor, pressure carb, Continental fuel injection, and Bendix fuel injection. A brief explanation of the operating principles of each system will be important in understanding the flight management portion of the pilot's duties. Carburetor The carburetor is a fairly simple device that meters fuel according to the pressure difference between the downstream side of the fuel jet and the net pressure of the fuel in the float bowl (affected by net bowl vent and bowl fuel head pressure). This is accomplished using Bernoulli's Principle (venturi in the carb throat) and is affected most by the volume of air flow through the carburetor. The system is, therefore, not very good at compensating for changes in air density (weight) caused by any factor, most noticeably, altitude. The fuel jet (main jet as it's sometimes called) is calibrated to give the correct rich mixture for the particular engine at full power, sea level, on a standard day. A variable valve in series between the float bowl and the calibrated jet most usually accomplishes mixture control. (Although some accomplish mixture control functions by varying the bowl vent pressure, either way, the result is the same). Pressure Carburetor Don't let it fool you. The name implies similarity to the aforementioned carburetor but the similarity ends there (as anyone who has had to pay for one will tell you). The pressure carburetor is a fairly complex unit that controls fuel/air ratios by sensing pressure differences in a venturi and ram air pressure in what's called a bullet (for what it does to your pocket book if you have to replace the bellows inside). The ram-air pressure is highly dependent on air density (weight) and is therefore much better at altitude compensation than the carburetor. Mixture is controlled by manual adjustment of an internal air control valve that varies fuel discharge pressure. This is essentially a single-point fuel injection system [similar to the Throttle-Body Injection (TBI) system used in GM Astro Vans, etc] Continental Fuel Injection in the naturally aspirated engines (except the 10 & G10-550) this system is purely mechanical. It determines fuel/air ratios solely by reference to pump RPM, throttle, and mixture valve position. It, therefore, has no way of sensing density altitude whatsoever. Once the pilot sets up the engine for a particular air density (altitude), minor throttle and RPM adjustments will not require a mixture adjustment. Properly adjusted and rigged, this system provides correct rich mixture for the particular engine at full power and climb at sea level only. Any operation at altitude requires the pilot to manually control the mixture to the optimum setting for the particular MAP and RPM. This is important; any significant change in air density (generally altitude) requires a corresponding mixture adjustment by the pilot. Turbocharged versions of the Continental Fuel Injection System use an aneroid to sense upper deck pressure and adjust fuel pressure, hence fuel now, accordingly, and therefore don't require the constant adjustment with air density changes. The GIO and I0-550 use a similar aneroid but sense ambient air (hence altitude) instead of upper deck pressure. Bendix Fuel Injection These systems are very similar, in operation and design, to the pressure carburetor (including cost, ouch). Enhancements have been made, however, that make them more accurate and easier to operate. This injection system, like the pressure carburetor, is a fairly complex unit, which controls fuel-air ratios by sensing pressure differences in a venturi and ram air pressure in the bullet. Most of these systems, however, do not have the AMC (automatic mixture control) bellows in the bullet. This makes the unit somewhat sensitive to air density (weight) changes, providing some altitude compensation. However, manual mixture control is still required by the pilot at altitude for optimum performance. A few of the Bendix Servos do have the AMC bellows in the bullet (some turbocharged engines) and compensate almost totally for the air density changes encountered from sea level to as high as 30,000 feet and sometimes higher. Operation Block to Block So how do these differences in systems affect the way you operate the engine, in particular the mixture? Let's go over four basic engine operation phases and how to operate each system in each phase. The four operational phases covered will include; taxi & run-up, takeoff & climb, cruise, and descent & landing. First, though, let's look at the basic mixture requirements of each phase from an operational standpoint. Taxi & Run-up The main consideration on taxi and run-up mixture control is smooth operation and the prevention of spark plug fouling. A properly leaned engine can easily mean the difference between a good mag check and a bad one. Fouled plugs or an overly rich mixture will decrease power and cause bad mag checks. Ground leaning will help keep the plugs clean. Takeoff and Climb NOTE: All properly adjusted, supercharged and turbocharged engines are to be at full rich for takeoff. There are two major concerns in adjusting and monitoring the mixture in takeoff (full power operations) and climb mode. Power and Exhaust Gas Temperature (EGT) or Turbine Inlet Temperature (TIT). Best Power mixture comes at about 125oF. Most general aviation engines have the capability to carry away the heat generated at Best Power mixtures up to about 70-75 percent power. Above this power setting, very few, if any, of the engines and engine installations we operate can use this mixture setting because of the high levels of heat energy being passed through the engine. This is especially true for takeoff and climb. The higher RPM and manifold pressures increase the heat passing through the engine in a given time frame (i.e. more combustion and exhaust scavenge events per second), putting more heat into the engine. There are two ways to decrease this heat and cool things down. Reduce power (fewer combustion-exhaust scavenge events) or cool the charge in the combustion and exhaust events. The idea of takeoff and climb is power, therefore, the first option is not so desirable. By default, the other option becomes the method of choice-cooling the combustion-exhaust event. This is done nowadays by enriching the mixture. Some of the "tried and true" will remember ADI systems (Anti Detonant Injection-usually a mixture of water and alcohol) in some of the old round engines and V-12s. ADI does the same thing as enriching the mixture. At high or emergency power settings, ADI fluid was injected into the intake air. Some models of the R-2800 (e.g. F4-U and P-47D) could pull about 80 in. Hg MAP with the ADI system engaged and only about 55-60 in. Hg with it off. It got them an extra 300 to 400 horsepower when it was needed most. Contrary to popular belief, actual EGT or TIT temperatures are important to monitor, especially at takeoff and climb. Many an engine has annealed the rings because combustion temperatures got too hot. Rings are annealed (lose their hardness) by prolonged and elevated temperatures. As temperatures in an iron alloy (used in piston rings) increase, the time to anneal the alloy decreases. Therefore, the less time spent at elevated temperatures, the better. In practical engine operating terms, keep CHT's below 400oF and TIT's below 1425oF for this phase. EGT temps will vary according to probe placement, but a good rule of thumb in climb settings is to set the mixture 200oF rich of the peak mixture temperature you would get at the 70 percent power setting. This will give good power but adequate cooling for climb. Those of you running intercooler systems on your turbocharged engine take note: If your fuel system does not fully compensate for changes in air density, the fuel system must be set up again after installation of the intercooler. Fuel systems that do not sense air density from the intercooler will run the mixture too lean in takeoff end climb (in the neighborhood of 1500oF or higher) and will anneal the rings in 50 to 100 hours (oil consumption starts to go up and compressions start to drop). These systems must be set to give a full fuel flow at an equivalent full power MAP (generally 3-4 in. Hg below redline). This compensates for the higher air density brought by the intercooler. I have brought many a plane back to the shop to pull all six cylinders for this very reason. Cruise Best Power is used mainly in cruise when you want speed and is shown in power charts under the "Best Power" curve. There is also a "Best Economy" curve that is a leaner mixture used with the same power setting and gives slightly less power than the "Best Power" setting (by experience, somewhere around 2-3 percent lower fuel flow or 3 to 5 knot airspeed loss). The name is as implied. It gives the best economy for the chosen power setting but also gives higher EGTs. "Best Economy" mixture settings generally are not given for power settings above 65 percent because of the potential for preignition and detonation. Safe EGT levels vary directly with the engine power setting. At low power settings (65 percent and less) the mixture may be adjusted to give best economy because of the engine's ability to carry away the heat energy' at these lower settings. At higher power settings, the mixture is adjusted to allow for extra fuel to help cool the engine. This is because of the engine's inability to carry away the heat energy developed at lean mixtures with high power settings (70 percent and higher). This is also the reason most operating handbooks specify seemingly overly rich mixtures for climb and high cruise power settings, especially on the larger engines. Descent and Landing Descent is similar to climb in that the mixture must be watched closely in systems which don't compensate well for changes in air density (carburetors and naturally aspirated Continental Fuel Injection systems). The main problem here is the reverse of climb: mixture becoming too lean as air density increases with a decrease in altitude. In descents to the pattern altitude from 10,000 to 12,000 feet, if the mixture is not increased, opening of the throttle at level-off can be accompanied by spits and sputters and possibly an engine that quits from fuel starvation. Good rule of thumb here: set the mixture to maintain the same EGT/TIT as cruise minus 50oF to the rich side in high power descents (65 percent or higher) and smooth engine running in low power descents (50-60 percent). If you don't have an EGT gauge, enrich the mixture to keep the engine smooth plus a little extra, as you enter the pattern or level off. Most normal descents are accomplished at low power (50-60 percent) where running close to peak EGT (25oF) isn't a problem because of the lower temps. A smooth engine is a happy engine and temps are kept up to help stave off the "shock" cooling gremlin. Density compensating systems will do a much better job of mixture control in descent but still need monitoring and an occasional adjustment. For landing, the mixture should be set for a position that will allow for full power operation for the particular system. This is to provide sufficient fuel for an immediate response if a go-around or evasive maneuver is needed. Flight and Mixture Control In [the next section], we'll go through these four flight phases for each particular fuel system. Keep in mind the time delay (5-10 seconds) for an EGT or TIT system reading to stabilize wherever accurate mixture adjustments are required. Also note that it is important to have your EGT or TIT gauge calibrated regularly. Have it checked at each annual if possible, and sooner if you fly more than 150 hours between inspections. This is especially important for turbocharged engines and naturally aspirated engines that fly regularly at altitudes below 5,000 feet MSL. Or those of you who have Lycoming engines, it wouldn't be a bad idea to get a copy of S.I. 1094D, fuel mixture leaning procedure, and look over the procedures for your particular engine. You'll find that this Instruction will vary substantially from the POH or Airplane Flight Manual for larger, high-horsepower engines. 2. Mixture Control by Type [In Part 1] we gave a general mixture operational overview. In parttwo of this effort, we will detail the power settings and leaning procedures for each fuel system type in various flight modes. Note that this was written by a very experienced test pilot of GA aircraft, but mixture management is still an area of some debate. Carburetors Note: The following advice is for naturally aspirated engines only. All turbocharged and turbo-normalized, carbureted engines must be at full rich for takeoff. Taxi and Runup: Leaning during taxi is sometimes required to prevent plug fouling and/or to provide smooth operation, especially at highaltitude airports. At altitude (3000 feet and higher), leaning is definitely required to get an accurate mag check. Rich mixtures can give mag drops of 200 RPM and of only 75 to 100 RPM when leaned. To find the best mixture for mag checks, lean until the engine gets rough then enrichen back to highest RPM. Readjust the throttle to the mag-check RPM and do your check. Some carburetor systems provide some challenges to this simple procedure in cold weather. The most common example that comes to mind is the 0-470 in the C180 and C182. This is a great engine/airframe combination but can get cantankerous in very cold weather. The carburetor sits down away from the engine where it can't pick up much heat. Therefore, it will ice up a little easier and in very cold weather (low teens and subzero) has some problem getting the fuel to atomize once it is distributed into the induction airflow. This can cause lean mixtures of sufficient magnitude to give really rotten mag drops; bad enough to fool some into thinking that the mag has just gone south with the geese. The best way to compensate for this malady is to pull the carb heat on, lean the mixture as previously described, adjust throttle to the mag check RPM and try again, all with carb heat "on." The mag drop will be a little higher than normal (125-150 instead of 75-100), but will be smooth if everything with the mags is okay. This is to be expected because of the hotter induction air (causing lower engine power) with carb heat in the "on" position. (Carb heat in for TO.) Takeoff and Climb: Leaning for takeoff (non-turbo) is a very important pre-takeoff item at high-altitude airports (higher than 3,000 feet). Unfortunately this is a practice still not exercised by some. Proper leaning at takeoff will shorten takeoff rolls and increase climb rates. At the high-altitude airports in the Rockies, for example, proper leaning can mean the difference between a successful takeoff or ending up in the trees at the end of the runway. Proper high-altitude leaning can shorten takeoff rolls by 500 feet and increase climb rates by 200-300 feet per minute. Leaning should be accomplished just before the takeoff roll. At full or near full throttle, lean to peak RPM then enrichen only slightly (barely enough to see an RPM drop, no more than 25). This will be best power for takeoff, plus just a little extra fuel for cooling (cooling isn't quite as much of a problem because of the lower temperatures produced at the lower power found at higher altitudes). The same procedure should be used for fixed-pitch or constant-speed props. If an EGT is used, it should be set for about 150oF rich of peak. At sea level, of course, go full rich. Climb is not much different. The idea here is to keep the mixture at best power plus about 50oF Mixture adjustment (re-leaning) is required about every 2,000 feet of altitude change for maximum performance and smooth operation above 5,000 feet density altitude. As altitude increases, and engine power decreases to 65 percent or lower, the mixture can be leaned much closer to peak EGT (within 50oF). This will help maintain power at the lower settings where best power mixture gets closer to peak EGT. Cruise: This is the easy part. Set cruise power and lean to 50-75oF rich of peak for settings of 65 percent or greater and 25-50oF rich of peak for settings below 65 percent. This will give you the best mixture setting for longevity of your engine and good performance for cruise. As always, if the engine gets rough before you reach peak EGT, enrichen the mixture until the engine gets smooth again and then enrichen a little more. This is also the procedure to follow if you don't have an EGT gauge. This will put you slightly on the rich side of peak EGT. If your engine is turbocharged (TR182, for example) run 75oF rich of peak TIT at 65 percent power or greater, and 50oF rich of peak below 65 percent. Anything above 75 percent power, should be at least 200oF rich of peak or full rich, and no hotter than 1500 F, whichever comes first. Running at peak EGT anywhere above 55 percent power is not recommended because of uneven fuel distribution and this high temperature operating zone has the smallest margin for mixture errors. Again, some engines can be very difficult in subzero (Fahrenheit) weather. You may have to fly your 0-470 with the carb heat on just to get the mixture to atomize and the engine to run smooth. This is where a Carb Air Temp gauge comes in real handy. Descent and Landing: Since the carburetor is rotten at air density sensing, the mixture will need to be enriched every 2,000 feet or so during the descent. If you have an EGT gauge, you can enrichen the EGT 50oF lower than cruise and maintain this EGT all the way to the pattern. Once you level Off, enrichen the mixture to the approximate position (by your own experience) that you would need if you were taking off at the same airport. From here on out, the mixture can stay where it is until shutdown. Pressure Carburetors Taxi and runup isn't much different than normal carbureted engines. Lean for smooth running to prevent plug fouling and follow the same runup procedures. At mag-check RPM, lean the mixture until the engine gets rough or loses RPM, whichever comes first, then enrichen back to highest RPM. Readjust the throttle to the mag-check RPM and do your check. Takeoff and Climb: For all high-power operations (75 percent power or greater) below 5,000 feet density altitude, the mixture control should be full rich. All takeoffs (except density altitudes of about 8,000 feet or higher) should also be full rich. The pressure carb is pretty good at sensing actual air density and adjusting mixture accordingly for fulland high-power. For climbing at higher density altitudes where power is limited to below 75 percent, the mixture can be leaned. For long cylinder/piston/ring life, keep EGTs at 1425oF or lower, preferably around 1350oF and do not exceed 400oF cylinder head temp. Cruise: Setup cruise mixture to no less than 50oF rich of peak at power settings of 65-70 percent and 75 to 100oF rich at 70-75 percent power. If you don't have an EGT, run book settings plus one-half to one gallon per hour more to extend cylinder life. In all cases hold CHTs no more than 400oF. At power settings of 50-65 percent some manufacturers will allow you to run at peak EGT. This may be okay for 50-55 percent, but it will prove easier on your engine (and pocket book) to run, at minimum, 50oF rich of peak at 60-65 percent. For supercharged or turbocharged engines add 25oF to the above EGT/TIT figures at minimum. Descent: For descent, subtract 50oF from the cruise EGT-TIT by enriching the mixture. The AMC bellows should keep the air-fuel ratio pretty stable throughout the entire descent. Some slight adjustment may be required occasionally, but a healthy pressure carb will compensate for air density changes, hence altitude, marvelously. Before applying power at level off, or once in the pattern, enrich the mixture to the setting needed for full power at that density altitude. Some leaning may be required for taxi at high density altitude airports. Lean as you would for taxi before takeoff unless extra cooling before shutdown is required. Continental Fuel Injection Taxi and runup will be almost exactly the same as carbureted engines due to this system's lack of air density sensing capability. Lean for smooth running during taxi and lean the same as the carburetors for runupset mag-check RPM, lean until the engine looses RPM, then enrichen back to highest RPM. Readjust the throttle to the mag check RPM and do your check. During this procedure the engine should lose RPM before it gets rough. If it doesn't this is usually an indication that the system needs a little attention (dirty nozzles or injector line obstructions). This is true of injected engines in any flight phase. If it's really noticeable (like a low frequency rumble or panel vibration that comes and goes), it would be a good idea to get it checked out before you go any further. Obstructions in a line or nozzle can destroy a cylinder in less than an hour and may even cause complete piston failure in the takeoff or climb phase. Takeoff and Climb: Naturally aspirated engines, as stated in the description, have no air density sensing mechanism (exceptions are the 10 and GIO-550, addressed later). For takeoffs from sea level to 3,000 feet density altitude, use full rich mixture. For takeoff at density altitudes of 4,000 feet or higher, adhere to the altitude fuel flow settings on the face of the fuel flow gauge. If its not marked, consult the POH. Be sure to use density altitude. Using only pressure altitude will give inaccurate air-fuel ratios on all but standard temperature days. If for some reason your flow gauge or POH doesn't give these figures (some old installations don't) lean as follows: Just before takeoff, at full or near full throttle, lean to peak RPM then enrichen 2-1/2 to 3 gallons per hour (if your gauge is calibrated only in psi, enrichen two psi). If you have an EGT, enrich 150oF rich of peak. If your en- gine reaches red-line (constant-speed prop) before you get to full throttle, pull the throttle back to 100 RPM below red-line and follow the above procedure. This will give you best power for takeoff and climb for the first one or two thousand feet. For best climb performance, the mixture will need to be monitored and adjusted every 1,000 feet. If you have an EGT gauge, keep the EGT at the same temperature it was on take-off. This will give you good perfor- mance and an economical climb up to about 10,000 feet. At this point re- check peak and adjust for about 50oF rich of peak for 10,000 feet and higher. The I0- and GIO-550 series engines have a bellows similar to the aneroid bellows on the turbocharged fuel pumps that compensate for changes in air pressure. If set up properly, these 550 systems do a pretty good job of mixture control and are left at the full-rich position for takeoff and climb until well above 12-13,000 feet. EGTs on these engines generally run in the low 1400s for takeoff and climb and, therefore, don't need leaning even on fairly hot days. The little extra fuel pumped in this case will be needed to help cool the en- gine anyway. The turbocharged Continental fuel system is flown like all other turbo- charged-supercharged systems, with one exception. Set full rich for take- off, but for climb, the engine may be leaned to the climb settings on the fuel flow gauge face. For top-end longevity, however, keep climb TITs at or under 1400 degrees F This may give you a fuel flow setting of one to one and a half gallons per hour higher than book but will pay off in the long run. Cruise: Cruise is not much differ- ent for any naturally aspirated, fuel injected engine or pressure carburetor equipped engine but it is worth repeating here. Set up cruise mixture to no less than 50oF rich of peak at power settings of 65-70 percent and 75 to 100oF rich at 70-75 percent power. If you don't have an EGT, run book settings plus one-half to one gallon per hour more to extend cylinder life. In all cases, hold CHTs to no more than 400oF. At power settings of 50-65 percent some manufacturers will allow you to run at peak EGT. This may be OK for 50-55 percent, but it will prove easier on your engine Land pocKet book) to run 50oF rich of peak at 60-65 percent. For turbocharged engines add 25oF to the above EGT-TIT figures. The 10-550 series is again an exception here. The book allows the engine to be run lean of peak at low power settings. The fuel system is designed for the very accurate fuel distribution required for this type of operation, but must be maintained well to keep the engine healthy. Remember, with the standard Continental fuel injection system on naturally aspirated engines, any altitude change will require a corresponding mixture adjustment. The Continental engine in the early Piper Malibu (TSIO-520-BE) is an exception to all of the above. This engine is run either full rich or lean of peak, no in between. Run it by the POH. Descent and Landing: For descent, enrichen the mixture about 50 F and maintain the same EGT while descending. Remember, the metering assembly is leaning the mixture when you pull back the throttle to maintain the same manifold pressure, so you will need a corresponding mixture adjustment to keep the EGT the same. Upon pattern entry, the mixture should be enriched to the approximate position for a full power setting at that air density (pressure altitude and temperature), in case full power is needed. Bendix Fuel Injection Taxi and Runup: A number of engines with this fuel system like to foul plugs while taxiing. At the lower RPMs, a fuel valve attached to the throttle valve system sets the fuel-air ratio. The fuel servo does not sense air density or flow until the engine gets to about 1,700-2,000 RPM. This necessitates manual leaning until approximately 2,000 RPM at which point the throttle valve rotates fully open and allows the servo to regulate the fuel-air ratio. Leaning the mixture to peak RPM during taxi and runup will keep the plugs clean and give accurate mag checks at runup. Takeoff and Climb: This system compensates pretty well for changes in air density, especially the models with the AMC (Automatic Mixture Control) (almost exactly the same as the pressure carb). Most Bendix systems on naturally aspirated engines, however, have no AMC, [just a simple, pitot-like sensor] to sense ram air pressure in the induction. This still gives an accurate enough reference for determining air density and does a pretty good job of controlling air-fuel ratios. Still, some minor mixture adjustments must still be made for altitude operations (4,000 feet and higher). Just before [entering] the runway, or just before the takeoff roll, run up to full or near full power and lean to peak EGT or until the RPM drops slightly. Enrichen the mixture 200oF (if you have an EGT) or one and one-half GPH for four-cylinder engines and two to three GPH for sixcylinder engines. This setting will give best power and cooling combination for takeoff and climb. During climb, the servo will compensate fairly well for air density changes. A minor mixture adjustment every 2,000 to 3,000 feet will be needed to keep the EGT at the same temperature until cruise altitude is reached. Again, cruise is not much different for any naturally aspirated, fuel injected or pressure carb equipped engine. Set up cruise mixture as described previously in this article. When changing altitudes during cruise with this system, no mixture adjustments should need to be made unless the change is more than about 2,000 feet. Descent and Landing: This is also the same as other injected engines except mixture adjustments during descent are not as frequent as with the Continental system. Enrichen the mixture 50 F just before descent and adjust to keep it the same until level off. Throttle adjustments for descents will need to be made only about every 2,000 feet. If you don't have an EGT installed, enrichen one gallon per hour for four cylinder engines or one and one half GPH for six cylinders and maintain the same MAP and fuel flow for descent. Once in the pattern, adjust the mixture to the approximate position for a full power setting at that air density (pressure altitude and temperature) in case full power is needed. Lean for taxi if at high altitude. Lean of Peak Operation Most pilot operational handbooks do not address LOP operation. Lycoming ' particularly, does not like it-although they authorize operating at peak EGT in many engines at a limited power level. Continental is less against it, since they designed the 10-550BE used in the original Malibus to operate this way, and have comments on LOP operation in some of their fuel injected engine handbooks. Most carbureted engines will not operate very well LOP if at all due to less than optimum fuel flows to the individual cylinders. That said, LOP is a viable option for fuel injected engines-even turbos with the proper engine monito~ing instrumentation (engine monitors) and proper pilot technique. When done properly, LOP can extend engine life with cooler operating temps compared to running at high power rich of peak. But again, proper operational training is key. One source of such training is offered by Advanced Pilot Seminars, www.advancedpilot.com. Ph 888359-4264 (this is the phone number for GAMI, in Ada, Oklahoma who hosts the seminars). POH Discrepancies A note about the differences between this article and what you will see in most POHs. The fuel flows given in the above advice, as most of you have probably noticed, are a bit richer (higher) than the POH numbers. The manufacturers, in an effort to give us better performing aircraft, have usually used numbers that allow for the most performance and/ or the greatest range for a given flight profile (see illustration below). However, these numbers often do not lend themselves to long engine life. There is unfortunately a battle between the marketing department and the engineering department in a given aircraft manufacturer, and the marketing people usually prevail. Don't believe for a minute that the numbers listed by the competition don't significantly influence what ends up in the POH. Some of the numbers may well be actually obtained by a test pilot in a perfect airplane with a perfect engine. Then all the other parameters are extrapolated mathematically. If you look at the engine maker's fuel flow, and other important engine operational numbers (as opposed to the airplane manufacturer) in their performance charts you are more likely to see fuel flow numbers significantly higher for a given percent of power. Excess fuel in aircraft engines plays a significant role in cooling the cylinders at high power settings. There is a high engine longevity price for marginally higher cruise speeds and climb rates. Remembering who pays that price will help you get the life you want from your engine, if you fly (not fry) with care. Reprinted courtesy of LIGHT PLANE MAINTENANCE * APRIL/MAY 2004 To subscribe to LIGHT PLANE MAINTENANCE magazine, send an email to lightplane[at]palmcoastd.com (replace "[at]" with "@" when ready to mail in order to reduce spam on the airways) -------- Milt 2003 F1 Rocket 2006 Radial Rocket Read this topic online here: http://forums.matronics.com/viewtopic.php?p=137185#137185 ________________________________________________________________________________
Subject: Re: Pressure Carburetor?
Date: Sep 29, 2007
Back to the original post is an excerpt from the old commander archives and Republic CB Archives by Chris Schuerman with a blurb on the PS%. Chris too believes the mixture control should not be touched. When I asked him why he said "someone told me". At the end of Chris's post are contacts for calibration of your pressure carb. The excerpt is in pdf format as an attachment -------- Milt 2003 F1 Rocket 2006 Radial Rocket Read this topic online here: http://forums.matronics.com/viewtopic.php?p=137187#137187 Attachments: http://forums.matronics.com//files/ps_5bdpercent20opspercent20big_148.pdf ________________________________________________________________________________
Date: Sep 29, 2007
> HI MILT. I am not picking on you, but need to make one other correction. Not to worry JB I have a thick skin especially when my espousings are based on science and data. This is quite an important topic for any bathtub commander owner and neededs to be thoroughly discussed. -------- Milt 2003 F1 Rocket 2006 Radial Rocket Read this topic online here: http://forums.matronics.com/viewtopic.php?p=137190#137190 ________________________________________________________________________________
Date: Sep 29, 2007
Good Evening Milt, I am beginning to wonder if the Commander list has decided that I do not belong here. I mentioned a lot of what has been discussed here a few days ago, but there has not been a single comment made either disagreeing with what I said or agreeing with my position. Nevertheless, my thick skin allows me to try again! The PS5c has always needed to be manually leaned and it is definitely a "Pressure Carburetor." There was mention in the attachment of the Advanced Pilot's Seminar at Ada, Oklahoma. I also would agree that attendance at that program is well worthwhile, but I am amazed that the author recommends running any engine fifty rich of peak after attending that course. Fifty rich of peak is OK for those cases were it is needed to get adequate power to operate the airplane, but at any other time, fifty rich of peak EGT is about the hottest place the engine can be operated. It is a bit below best power which is why it is recommended so often by the sales department of any manufacturer, but it is certainly NOT a place that would automatically be easy on the engine. I think the author will agree that running cool is a good idea. The engine can be run coolest by running well lean of peak. Whether or not that most desirable of operations can be conducted is dependent on the quality of the fuel distribution between the various cylinders. Thus the need for balanced injectors! Lindbergh was messing with that with his three throat carburetor before leaving for Paris. This is not new stuff and it is not rocket science. During the last fifty years, there have been many attempts to dumb up the operation of our engines. That is why you see the various setups that tell the pilot to run the engine at full rich and to only touch the mixture when he/she wants to shut it down. While all those efforts have been admirable, we still do not have any fuel control unit that works that well. If someone does not feel they can spend the time attending the two and half day class at Ada, they should try the home study course. If they don't want to pay the price to take the home study course, they should at least read the free stuff written and freely presented by one of the instructors, John Deakin. He has written a complete set of articles about everything that has been discussed in this thread and presented it free to all as a series of articles on AvWeb. Contact him at: _jdeakin(at)advancedpilot.com and_ (mailto:jdeakin(at)advancedpilot.com%20and) he will happily tell you where to download all of his articles free of charge! The knowledge is there. It just needs to be studied by anyone planning to operate any high powered piston engine. Incidentally, I'll bet you will find Chris S. will agree with my assessment! Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator Stearman N3977A Brookeridge Air Park LL22 Downers Grove, IL 60516 630 985-8503 In a message dated 9/29/2007 7:08:44 P.M. Central Daylight Time, airboss(at)excaliburaviation.com writes: At the end of Chris's post are contacts for calibration of your pressure carb. The excerpt is in pdf format as an attachment ________________________________________________________________________________
Date: Sep 29, 2007
HI MILT Sorry, but I stand by my statement.? Manually leaning a properly adjusted pressure carb is, wrong.? As I had stated in an earlier post (and as said?in the referenced article), it is possible to do it, but why??? Properly adjusted, the AMC unit does a great job.? I just flew my 680E 2800nm, 16hrs to the fly-in in TX? I fueled the outboard tanks and after about an?hour on the main, switched?to them? They ran 1.5 hours and just as I was reaching for the selector?switch, the LH engine sputtered.? I no sooner switched that engine tha the RH sputtered.? The point is, with properly adj carbs, they are consistent enough to use exactly he same amount of fuel.? Not science, but?imperical information.? I have flown many bathtub Commanders and have yet to fly one with an EGT.? Short of that installation, leaning the carbs would be a random guess at best.? Is it possible to squeeze a couple of extra gallons per?hour out of your engines, maybe.? But if your Commander operating budget is so cramped that three or four GPH will make a difference, I strongly suggest you sell your Commander.? BTW, I don't believe that running over square is bad, (it happens on every TO), or that you can shock cool and engine with the throttle (rapid mixture change will however) or that running LOP is bad in a normally aspirated engine.? But manually leaning you AMC carbs is a bad idea, not?recomended by the manufacture of the carb, engine or airframe?and completely?unnecessary;-)??jb??? -----Original Message----- From: N395V <airboss(at)excaliburaviation.com> Sent: Sat, 29 Sep 2007 5:01 pm Subject: Commander-List: Re: Pressure Carburetor? The following is a reprint from "Light Plane Maintenance" Discussing aircraft mixture control systems. It is lengthy but a good read, especially the section on pressure carbs and leaning method by type of fuel distribution system. As you can see from the article pressure carbs require manual mixture adjustment to get the most out of your engine. JB I think you are a bit premature with the use of the word "wrong" I do not doubt that you and many Commander pilots and many older pilots were taught that the mixture control on PS5 pressure carbs is simply an on off switch. That concept is just plain wrong and needs to be questioned rather than just passed on as gospel. In the old days fuel was a cheap coolant and leaving a pressure carb at full rich was acceptable practice. It even made its way into some manuals although I do not recall seeing it in a commander manual. Mr Bendix did not attach the mixture control to a "METERING NEEDLE VALVE" for the purpose of on and off. If on/off were his intent he would have put a ball valve on the carb inlet. This concept is just as dated as Don't run oversquare MP>RPM/1000 Rapid throttle reduction causes shock cooling.. Data clearly shows flight into precipitation causes greater mor rapid cooling. Do not run LOP.. Once again date clearly refutes this. Any way the article follows. Mixture Control by LIGHT PLANE MAINTENANCE staff Part 1 - Mixture Control Systems Here we go again, another article on mixture management destined to tell me things I already know. Well, maybe. It's entirely possible that some information will seem repetitious, but, then again, redundancy in aviation isn't such a bad thing either. judging from some reader questions, such a revisit to the topic is warranted. Mixture Control is written from the pilot's perspective, by a professional test-pilot, and is designed to answer the why, when, where and how of mixture control and proper leaning procedure for various fuel delivery systems. It is an encyclopedia of fuel management. To the layman, it translates into verse as "How to avoid burning a hole in your wallet". Inspite of the proliferation of digital instrumentation, the Basic EGT is still an outstanding instrument for monitoring Fuel Flow vs Percent Power. Most of the material in this article is based on this basic level of instrumentation and control. Units of measurement remain in the original Imperial units (oF, for example) because over 60% of aircraft in use are more than 50 years old. Air-Fuel Ratios/Distribution In general terms, mixture is defined as the ratio of air to fuel by weight (or more accurately, mass). Most engines will burn air-fuel ratios of 8:1 to 18: 1. Eight-to-one being very rich and eighteen-to-one being very lean. The "chemically correct" (otherwise known as stoichiometric) mixture is about 15:1. This is the mixture ratio where you would expect to find peak EGT in a perfect burn, but atomization inefficiencies put the peak EGT ratio probably closer to 13 or 14 to 1. You might say, "So what's this gobbledygook about ratios? I don't have a direct air-fuel ratio indicator in my plane." That's true, but it will help in understanding the different leaning procedures on different fuel metering/distributing systems. The most common fuel distribution systems found in general aviation are: carburetor, pressure carb, Continental fuel injection, and Bendix fuel injection. A brief explanation of the operating principles of each system will be important in understanding the flight management portion of the pilot's duties. Carburetor The carburetor is a fairly simple device that meters fuel according to the pressure difference between the downstream side of the fuel jet and the net pressure of the fuel in the float bowl (affected by net bowl vent and bowl fuel head pressure). This is accomplished using Bernoulli's Principle (venturi in the carb throat) and is affected most by the volume of air flow through the carburetor. The system is, therefore, not very good at compensating for changes in air density (weight) caused by any factor, most noticeably, altitude. The fuel jet (main jet as it's sometimes called) is calibrated to give the correct rich mixture for the particular engine at full power, sea level, on a standard day. A variable valve in series between the float bowl and the calibrated jet most usually accomplishes mixture control. (Although some accomplish mixture control functions by varying the bowl vent pressure, either way, the result is the same). Pressure Carburetor Don't let it fool you. The name implies similarity to the aforementioned carburetor but the similarity ends there (as anyone who has had to pay for one will tell you). The pressure carburetor is a fairly complex unit that controls fuel/air ratios by sensing pressure differences in a venturi and ram air pressure in what's called a bullet (for what it does to your pocket book if you have to replace the bellows inside). The ram-air pressure is highly dependent on air density (weight) and is therefore much better at altitude compensation than the carburetor. Mixture is controlled by manual adjustment of an internal air control valve that varies fuel discharge pressure. This is essentially a single-point fuel injection system [similar to the Throttle-Body Injection (TBI) system used in GM Astro Vans, etc] Continental Fuel Injection in the naturally aspirated engines (except the 10 & G10-550) this system is purely mechanical. It determines fuel/air ratios solely by reference to pump RPM, throttle, and mixture valve position. It, therefore, has no way of sensing density altitude whatsoever. Once the pilot sets up the engine for a particular air density (altitude), minor throttle and RPM adjustments will not require a mixture adjustment. Properly adjusted and rigged, this system provides correct rich mixture for the particular engine at full power and climb at sea level only. Any operation at altitude requires the pilot to manually control the mixture to the optimum setting for the particular MAP and RPM. This is important; any significant change in air density (generally altitude) requires a corresponding mixture adjustment by the pilot. Turbocharged versions of the Continental Fuel Injection System use an aneroid to sense upper deck pressure and adjust fuel pressure, hence fuel now, accordingly, and therefore don't require the constant adjustment with air density changes. The GIO and I0-550 use a similar aneroid but sense ambient air (hence altitude) instead of upper deck pressure. Bendix Fuel Injection These systems are very similar, in operation and design, to the pressure carburetor (including cost, ouch). Enhancements have been made, however, that make them more accurate and easier to operate. This injection system, like the pressure carburetor, is a fairly complex unit, which controls fuel-air ratios by sensing pressure differences in a venturi and ram air pressure in the bullet. Most of these systems, however, do not have the AMC (automatic mixture control) bellows in the bullet. This makes the unit somewhat sensitive to air density (weight) changes, providing some altitude compensation. However, manual mixture control is still required by the pilot at altitude for optimum performance. A few of the Bendix Servos do have the AMC bellows in the bullet (some turbocharged engines) and compensate almost totally for the air density changes encountered from sea level to as high as 30,000 feet and sometimes higher. Operation Block to Block So how do these differences in systems affect the way you operate the engine, in particular the mixture? Let's go over four basic engine operation phases and how to operate each system in each phase. The four operational phases covered will include; taxi & run-up, takeoff & climb, cruise, and descent & landing. First, though, let's look at the basic mixture requirements of each phase from an operational standpoint. Taxi & Run-up The main consideration on taxi and run-up mixture control is smooth operation and the prevention of spark plug fouling. A properly leaned engine can easily mean the difference between a good mag check and a bad one. Fouled plugs or an overly rich mixture will decrease power and cause bad mag checks. Ground leaning will help keep the plugs clean. Takeoff and Climb NOTE: All properly adjusted, supercharged and turbocharged engines are to be at full rich for takeoff. There are two major concerns in adjusting and monitoring the mixture in takeoff (full power operations) and climb mode. Power and Exhaust Gas Temperature (EGT) or Turbine Inlet Temperature (TIT). Best Power mixture comes at about 125oF. Most general aviation engines have the capability to carry away the heat generated at Best Power mixtures up to about 70-75 percent power. Above this power setting, very few, if any, of the engines and engine installations we operate can use this mixture setting because of the high levels of heat energy being passed through the engine. This is especially true for takeoff and climb. The higher RPM and manifold pressures increase the heat passing through the engine in a given time frame (i.e. more combustion and exhaust scavenge events per second), putting more heat into the engine. There are two ways to decrease this heat and cool things down. Reduce power (fewer combustion-exhaust scavenge events) or cool the charge in the combustion and exhaust events. The idea of takeoff and climb is power, therefore, the first option is not so desirable. By default, the other option becomes the method of choice-cooling the combustion-exhaust event. This is done nowadays by enriching the mixture. Some of the "tried and true" will remember ADI systems (Anti Detonant Injection-usually a mixture of water and alcohol) in some of the old round engines and V-12s. ADI does the same thing as enriching the mixture. At high or emergency power settings, ADI fluid was injected into the intake air. Some models of the R-2800 (e.g. F4-U and P-47D) could pull about 80 in. Hg MAP with the ADI system engaged and only about 55-60 in. Hg with it off. It got them an extra 300 to 400 horsepower when it was needed most. Contrary to popular belief, actual EGT or TIT temperatures are important to monitor, especially at takeoff and climb. Many an engine has annealed the rings because combustion temperatures got too hot. Rings are annealed (lose their hardness) by prolonged and elevated temperatures. As temperatures in an iron alloy (used in piston rings) increase, the time to anneal the alloy decreases. Therefore, the less time spent at elevated temperatures, the better. In practical engine operating terms, keep CHT's below 400oF and TIT's below 1425oF for this phase. EGT temps will vary according to probe placement, but a good rule of thumb in climb settings is to set the mixture 200oF rich of the peak mixture temperature you would get at the 70 percent power setting. This will give good power but adequate cooling for climb. Those of you running intercooler systems on your turbocharged engine take note: If your fuel system does not fully compensate for changes in air density, the fuel system must be set up again after installation of the intercooler. Fuel systems that do not sense air density from the intercooler will run the mixture too lean in takeoff end climb (in the neighborhood of 1500oF or higher) and will anneal the rings in 50 to 100 hours (oil consumption starts to go up and compressions start to drop). These systems must be set to give a full fuel flow at an equivalent full power MAP (generally 3-4 in. Hg below redline). This compensates for the higher air density brought by the intercooler. I have brought many a plane back to the shop to pull all six cylinders for this very reason. Cruise Best Power is used mainly in cruise when you want speed and is shown in power charts under the "Best Power" curve. There is also a "Best Economy" curve that is a leaner mixture used with the same power setting and gives slightly less power than the "Best Power" setting (by experience, somewhere around 2-3 percent lower fuel flow or 3 to 5 knot airspeed loss). The name is as implied. It gives the best economy for the chosen power setting but also gives higher EGTs. "Best Economy" mixture settings generally are not given for power settings above 65 percent because of the potential for preignition and detonation. Safe EGT levels vary directly with the engine power setting. At low power settings (65 percent and less) the mixture may be adjusted to give best economy because of the engine's ability to carry away the heat energy' at these lower settings. At higher power settings, the mixture is adjusted to allow for extra fuel to help cool the engine. This is because of the engine's inability to carry away the heat energy developed at lean mixtures with high power settings (70 percent and higher). This is also the reason most operating handbooks specify seemingly overly rich mixtures for climb and high cruise power settings, especially on the larger engines. Descent and Landing Descent is similar to climb in that the mixture must be watched closely in systems which don't compensate well for changes in air density (carburetors and naturally aspirated Continental Fuel Injection systems). The main problem here is the reverse of climb: mixture becoming too lean as air density increases with a decrease in altitude. In descents to the pattern altitude from 10,000 to 12,000 feet, if the mixture is not increased, opening of the throttle at level-off can be accompanied by spits and sputters and possibly an engine that quits from fuel starvation. Good rule of thumb here: set the mixture to maintain the same EGT/TIT as cruise minus 50oF to the rich side in high power descents (65 percent or higher) and smooth engine running in low power descents (50-60 percent). If you don't have an EGT gauge, enrich the mixture to keep the engine smooth plus a little extra, as you enter the pattern or level off. Most normal descents are accomplished at low power (50-60 percent) where running close to peak EGT (25oF) isn't a problem because of the lower temps. A smooth engine is a happy engine and temps are kept up to help stave off the "shock" cooling gremlin. Density compensating systems will do a much better job of mixture control in descent but still need monitoring and an occasional adjustment. For landing, the mixture should be set for a position that will allow for full power operation for the particular system. This is to provide sufficient fuel for an immediate response if a go-around or evasive maneuver is needed. Flight and Mixture Control In [the next section], we'll go through these four flight phases for each particular fuel system. Keep in mind the time delay (5-10 seconds) for an EGT or TIT system reading to stabilize wherever accurate mixture adjustments are required. Also note that it is important to have your EGT or TIT gauge calibrated regularly. Have it checked at each annual if possible, and sooner if you fly more than 150 hours between inspections. This is especially important for turbocharged engines and naturally aspirated engines that fly regularly at altitudes below 5,000 feet MSL. Or those of you who have Lycoming engines, it wouldn't be a bad idea to get a copy of S.I. 1094D, fuel mixture leaning procedure, and look over the procedures for your particular engine. You'll find that this Instruction will vary substantially from the POH or Airplane Flight Manual for larger, high-horsepower engines. 2. Mixture Control by Type [In Part 1] we gave a general mixture operational overview. In parttwo of this effort, we will detail the power settings and leaning procedures for each fuel system type in various flight modes. Note that this was written by a very experienced test pilot of GA aircraft, but mixture management is still an area of some debate. Carburetors Note: The following advice is for naturally aspirated engines only. All turbocharged and turbo-normalized, carbureted engines must be at full rich for takeoff. Taxi and Runup: Leaning during taxi is sometimes required to prevent plug fouling and/or to provide smooth operation, especially at highaltitude airports. At altitude (3000 feet and higher), leaning is definitely required to get an accurate mag check. Rich mixtures can give mag drops of 200 RPM and of only 75 to 100 RPM when leaned. To find the best mixture for mag checks, lean until the engine gets rough then enrichen back to highest RPM. Readjust the throttle to the mag-check RPM and do your check. Some carburetor systems provide some challenges to this simple procedure in cold weather. The most common example that comes to mind is the 0-470 in the C180 and C182. This is a great engine/airframe combination but can get cantankerous in very cold weather. The carburetor sits down away from the engine where it can't pick up much heat. Therefore, it will ice up a little easier and in very cold weather (low teens and subzero) has some problem getting the fuel to atomize once it is distributed into the induction airflow. This can cause lean mixtures of sufficient magnitude to give really rotten mag drops; bad enough to fool some into thinking that the mag has just gone south with the geese. The best way to compensate for this malady is to pull the carb heat on, lean the mixture as previously described, adjust throttle to the mag check RPM and try again, all with carb heat "on." The mag drop will be a little higher than normal (125-150 instead of 75-100), but will be smooth if everything with the mags is okay. This is to be expected because of the hotter induction air (causing lower engine power) with carb heat in the "on" position. (Carb heat in for TO.) Takeoff and Climb: Leaning for takeoff (non-turbo) is a very important pre-takeoff item at high-altitude airports (higher than 3,000 feet). Unfortunately this is a practice still not exercised by some. Proper leaning at takeoff will shorten takeoff rolls and increase climb rates. At the high-altitude airports in the Rockies, for example, proper leaning can mean the difference between a successful takeoff or ending up in the trees at the end of the runway. Proper high-altitude leaning can shorten takeoff rolls by 500 feet and increase climb rates by 200-300 feet per minute. Leaning should be accomplished just before the takeoff roll. At full or near full throttle, lean to peak RPM then enrichen only slightly (barely enough to see an RPM drop, no more than 25). This will be best power for takeoff, plus just a little extra fuel for cooling (cooling isn't quite as much of a problem because of the lower temperatures produced at the lower power found at higher altitudes). The same procedure should be used for fixed-pitch or constant-speed props. If an EGT is used, it should be set for about 150oF rich of peak. At sea level, of course, go full rich. Climb is not much different. The idea here is to keep the mixture at best power plus about 50oF Mixture adjustment (re-leaning) is required about every 2,000 feet of altitude change for maximum performance and smooth operation above 5,000 feet density altitude. As altitude increases, and engine power decreases to 65 percent or lower, the mixture can be leaned much closer to peak EGT (within 50oF). This will help maintain power at the lower settings where best power mixture gets closer to peak EGT. Cruise: This is the easy part. Set cruise power and lean to 50-75oF rich of peak for settings of 65 percent or greater and 25-50oF rich of peak for settings below 65 percent. This will give you the best mixture setting for longevity of your engine and good performance for cruise. As always, if the engine gets rough before you reach peak EGT, enrichen the mixture until the engine gets smooth again and then enrichen a little more. This is also the procedure to follow if you don't have an EGT gauge. This will put you slightly on the rich side of peak EGT. If your engine is turbocharged (TR182, for example) run 75oF rich of peak TIT at 65 percent power or greater, and 50oF rich of peak below 65 percent. Anything above 75 percent power, should be at least 200oF rich of peak or full rich, and no hotter than 1500 F, whichever comes first. Running at peak EGT anywhere above 55 percent power is not recommended because of uneven fuel distribution and this high temperature operating zone has the smallest margin for mixture errors. Again, some engines can be very difficult in subzero (Fahrenheit) weather. You may have to fly your 0-470 with the carb heat on just to get the mixture to atomize and the engine to run smooth. This is where a Carb Air Temp gauge comes in real handy. Descent and Landing: Since the carburetor is rotten at air density sensing, the mixture will need to be enriched every 2,000 feet or so during the descent. If you have an EGT gauge, you can enrichen the EGT 50oF lower than cruise and maintain this EGT all the way to the pattern. Once you level Off, enrichen the mixture to the approximate position (by your own experience) that you would need if you were taking off at the same airport. >From here on out, the mixture can stay where it is until shutdown. Pressure Carburetors Taxi and runup isn't much different than normal carbureted engines. Lean for smooth running to prevent plug fouling and follow the same runup procedures. At mag-check RPM, lean the mixture until the engine gets rough or loses RPM, whichever comes first, then enrichen back to highest RPM. Readjust the throttle to the mag-check RPM and do your check. Takeoff and Climb: For all high-power operations (75 percent power or greater) below 5,000 feet density altitude, the mixture control should be full rich. All takeoffs (except density altitudes of about 8,000 feet or higher) should also be full rich. The pressure carb is pretty good at sensing actual air density and adjusting mixture accordingly for fulland high-power. For climbing at higher density altitudes where power is limited to below 75 percent, the mixture can be leaned. For long cylinder/piston/ring life, keep EGTs at 1425oF or lower, preferably around 1350oF and do not exceed 400oF cylinder head temp. Cruise: Setup cruise mixture to no less than 50oF rich of peak at power settings of 65-70 percent and 75 to 100oF rich at 70-75 percent power. If you don't have an EGT, run book settings plus one-half to one gallon per hour more to extend cylinder life. In all cases hold CHTs no more than 400oF. At power settings of 50-65 percent some manufacturers will allow you to run at peak EGT. This may be okay for 50-55 percent, but it will prove easier on your engine (and pocket book) to run, at minimum, 50oF rich of peak at 60-65 percent. For supercharged or turbocharged engines add 25oF to the above EGT/TIT figures at minimum. Descent: For descent, subtract 50oF from the cruise EGT-TIT by enriching the mixture. The AMC bellows should keep the air-fuel ratio pretty stable throughout the entire descent. Some slight adjustment may be required occasionally, but a healthy pressure carb will compensate for air density changes, hence altitude, marvelously. Before applying power at level off, or once in the pattern, enrich the mixture to the setting needed for full power at that density altitude. Some leaning may be required for taxi at high density altitude airports. Lean as you would for taxi before takeoff unless extra cooling before shutdown is required. Continental Fuel Injection Taxi and runup will be almost exactly the same as carbureted engines due to this system's lack of air density sensing capability. Lean for smooth running during taxi and lean the same as the carburetors for runupset mag-check RPM, lean until the engine looses RPM, then enrichen back to highest RPM. Readjust the throttle to the mag check RPM and do your check. During this procedure the engine should lose RPM before it gets rough. If it doesn't this is usually an indication that the system needs a little attention (dirty nozzles or injector line obstructions). This is true of injected engines in any flight phase. If it's really noticeable (like a low frequency rumble or panel vibration that comes and goes), it would be a good idea to get it checked out before you go any further. Obstructions in a line or nozzle can destroy a cylinder in less than an hour and may even cause complete piston failure in the takeoff or climb phase. Takeoff and Climb: Naturally aspirated engines, as stated in the description, have no air density sensing mechanism (exceptions are the 10 and GIO-550, addressed later). For takeoffs from sea level to 3,000 feet density altitude, use full rich mixture. For takeoff at density altitudes of 4,000 feet or higher, adhere to the altitude fuel flow settings on the face of the fuel flow gauge. If its not marked, consult the POH. Be sure to use density altitude. Using only pressure altitude will give inaccurate air-fuel ratios on all but standard temperature days. If for some reason your flow gauge or POH doesn't give these figures (some old installations don't) lean as follows: Just before takeoff, at full or near full throttle, lean to peak RPM then enrichen 2-1/2 to 3 gallons per hour (if your gauge is calibrated only in psi, enrichen two psi). If you have an EGT, enrich 150oF rich of peak. If your en- gine reaches red-line (constant-speed prop) before you get to full throttle, pull the throttle back to 100 RPM below red-line and follow the above procedure. This will give you best power for takeoff and climb for the first one or two thousand feet. For best climb performance, the mixture will need to be monitored and adjusted every 1,000 feet. If you have an EGT gauge, keep the EGT at the same temperature it was on take-off. This will give you good perfor- mance and an economical climb up to about 10,000 feet. At this point re- check peak and adjust for about 50oF rich of peak for 10,000 feet and higher. The I0- and GIO-550 series engines have a bellows similar to the aneroid bellows on the turbocharged fuel pumps that compensate for changes in air pressure. If set up properly, these 550 systems do a pretty good job of mixture control and
August 18, 2007 - September 29, 2007
Commander-Archive.digest.vol-cn
