Commander-Archive.digest.vol-df
November 06, 2008 - December 11, 2008
      Gentlemen,
      Are there any active members that own a AC 680F?-- Im estimating a ferr
      y flight and need the best altitude/fuel burn and could really use your exp
      erience.
      thanks.
      wer
       - -http://www.matronics.com/contribution=0A=0A=0A
From: "Moe-rosspistons" <moe-rosspistons(at)hotmail.com>
Subject: Re: 680F cruise performance
Date: Nov 06, 2008
Hi Willis, I have a 680Fp which is the same as a 680F except that it has all of the pressurization equipment in the back. If you have enough oxygen fly between 16,000 and 18,000 ft., 100' f lean of peak, about 180 to 190 knots true air speed at about 42/44 gallons per hour. Do not try to fly below about 11,000 feet or your fuel burn will be 55 gallons per hour or more. If you feel uncomfortable flying lean of peak (which many do) then go 100 rich of peak and your fuel burn will be slightly more of course. Sometimes, running that much lean of peak causes the engines to run a little rough, however, you are so lean that the cyl temps will be cool and the engine basically "can't hurt its self". Moe Mills Proud Holder of The Golden Pedal Award N680RR 680Fp From: willis robison Sent: Wednesday, November 05, 2008 8:58 PM Subject: Commander-List: 680F cruise performance Gentlemen, Are there any active members that own a AC 680F? Im estimating a ferry flight and need the best altitude/fuel burn and could really use your experience. thanks. wer 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ________________________________________________________________________________
Date: Nov 06, 2008
Willis, Your plane wants to fly its best at 16,000 to 18,000 ft. Anything below this altitude and the fuel compsuntion vs. distance traveled suffers. The one exception is if the headwind at 10,000 is mild and the headwind at 18,000 is bad. Moe From: willis robison Sent: Thursday, November 06, 2008 7:01 AM Subject: RE: Commander-List: 680F cruise performance Thanks Randy, JB. Thats sounds reasonable for a low-level flight. Do you guys every fly on oxy? I would think your economy would be much better at a higher altitude. And with oodles of power to get there quickly, it should be a snap. I guess with the Time to climb and then let down, that may not be cost-effective. wer --- On Thu, 11/6/08, Randy Dettmer, AIA wrote: From: Randy Dettmer, AIA <rcdettmer(at)charter.net> Subject: RE: Commander-List: 680F cruise performance To: commander-list(at)matronics.com Date: Thursday, November 6, 2008, 6:29 AM I flight plan 10K to 12K at 190 knots true, and 52 to 55 gph in my 680F. Randy Dettmer, AIA, NCARB 680F / N6253X Dettmer Architecture 663 Hill Street San Luis Obispo, CA 93405 805 541 4864 / Fax 805 541 4865 www.dettmerarchitecture.com ------------------------------------------------------------------------ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of yourtcfg(at)aol.com Sent: Wednesday, November 05, 2008 11:10 PM To: commander-list(at)matronics.com Subject: Re: Commander-List: 680F cruise performance Above 10K, 200kts @55GPH. jb -----Original Message----- From: willis robison <drwer2(at)yahoo.com> To: commander-list(at)matronics.com Sent: Wed, 5 Nov 2008 8:58 pm Subject: Commander-List: 680F cruise performance Gentlemen, Are there any active members that own a AC 680F? Im estimating a ferry flight and need the best altitude/fuel burn and could really use your experience. thanks. wer > ------------------------------------------------------------------------ http://www.matronics.com/contribution ________________________________________________________________________________
Date: Nov 06, 2008
Thanks Moe, -makes a lot of sense.-- I would think that an IGSO engin e swinging +90" props would want to live where they- are most efficient. - no chance of +18k?- the supposed service ceiling is in the mid to uppper 20's I thought.- Im looking at a bare plane, no interior as its a former aerial survey craft. - wer --- On Thu, 11/6/08, Moe-rosspistons wrote: From: Moe-rosspistons <moe-rosspistons(at)hotmail.com> Subject: Re: Commander-List: 680F cruise performance Date: Thursday, November 6, 2008, 7:24 AM Willis, - Your plane wants to fly its best at 16,000 to 18,000 ft.- Anything below this altitude and the fuel compsuntion vs. distance traveled suffers.- Th e one exception is if the headwind at 10,000 is mild and the headwind at 18 ,000 is bad. - Moe From: willis robison Sent: Thursday, November 06, 2008 7:01 AM Subject: RE: Commander-List: 680F cruise performance Thanks Randy, JB.- Thats- sounds reasonable for a low-level flight. - Do you guys every fly on oxy?- I would think your economy would be much b etter at a higher altitude.- And with oodles of power to get there quickl y, it should be a snap.- I guess with the Time to climb and then let down , that may not be cost-effective. - wer --- On Thu, 11/6/08, Randy Dettmer, AIA wrote: From: Randy Dettmer, AIA <rcdettmer(at)charter.net> Subject: RE: Commander-List: 680F cruise performance Date: Thursday, November 6, 2008, 6:29 AM I flight plan 10K to 12K at 190 knots true, and 52 to 55 gph in my 680F. - Randy Dettmer, AIA, NCARB 680F / N6253X Dettmer Architecture 663 Hill Street San Luis Obispo, CA - 93405 805 541 4864 / Fax 805 541 4865 www.dettmerarchitecture.com From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-lis t-server(at)matronics.com] On Behalf Of yourtcfg(at)aol.com Sent: Wednesday, November 05, 2008 11:10 PM Subject: Re: Commander-List: 680F cruise performance Above 10K, 200kts @55GPH.- jb -----Original Message----- From: willis robison <drwer2(at)yahoo.com> Sent: Wed, 5 Nov 2008 8:58 pm Subject: Commander-List: 680F cruise performance Gentlemen, - Are there any active members that own a AC 680F?-- Im estimating a ferr y flight and need the best altitude/fuel burn and could really use your exp erience. - thanks. - wer - - > - -http://www.matronics.com/contribution< span> =0A=0A=0A ________________________________________________________________________________
Date: Nov 06, 2008
Willis, I generally never fly in class "A" airspace, therefore I can't say with authority. When I first purchased the plane about 10 years ago I tried flying in the the low 20's and it didn't seem to be worth the trouble. Since my bird is pressurized the oxygen tank is only 22 cubic feet which seems to last about an hour with four people and pressurized flight above about 21,000 ft. (can't remember exactly) is prohibited by placard, so the downsides of higher flight generally outnumber the upsides. The exception to my self imposed 17,999 foot rule is to get over weather and then descend ASAP. Moe From: willis robison Sent: Thursday, November 06, 2008 7:45 AM Subject: Re: Commander-List: 680F cruise performance Thanks Moe, makes a lot of sense. I would think that an IGSO engine swinging +90" props would want to live where they are most efficient. no chance of +18k? the supposed service ceiling is in the mid to uppper 20's I thought. Im looking at a bare plane, no interior as its a former aerial survey craft. wer --- On Thu, 11/6/08, Moe-rosspistons wrote: From: Moe-rosspistons <moe-rosspistons(at)hotmail.com> Subject: Re: Commander-List: 680F cruise performance To: commander-list(at)matronics.com Date: Thursday, November 6, 2008, 7:24 AM Willis, Your plane wants to fly its best at 16,000 to 18,000 ft. Anything below this altitude and the fuel compsuntion vs. distance traveled suffers. The one exception is if the headwind at 10,000 is mild and the headwind at 18,000 is bad. Moe From: willis robison Sent: Thursday, November 06, 2008 7:01 AM To: commander-list(at)matronics.com Subject: RE: Commander-List: 680F cruise performance Thanks Randy, JB. Thats sounds reasonable for a low-level flight. Do you guys every fly on oxy? I would think your economy would be much better at a higher altitude. And with oodles of power to get there quickly, it should be a snap. I guess with the Time to climb and then let down, that may not be cost-effective. wer --- On Thu, 11/6/08, Randy Dettmer, AIA wrote: From: Randy Dettmer, AIA <rcdettmer(at)charter.net> Subject: RE: Commander-List: 680F cruise performance To: commander-list(at)matronics.com Date: Thursday, November 6, 2008, 6:29 AM I flight plan 10K to 12K at 190 knots true, and 52 to 55 gph in my 680F. Randy Dettmer, AIA, NCARB 680F / N6253X Dettmer Architecture 663 Hill Street San Luis Obispo, CA 93405 805 541 4864 / Fax 805 541 4865 www.dettmerarchitecture.com ---------------------------------------------------------------- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of yourtcfg(at)aol.com Sent: Wednesday, November 05, 2008 11:10 PM To: commander-list(at)matronics.com Subject: Re: Commander-List: 680F cruise performance Above 10K, 200kts @55GPH. jb -----Original Message----- From: willis robison <drwer2(at)yahoo.com> To: commander-list(at)matronics.com Sent: Wed, 5 Nov 2008 8:58 pm Subject: Commander-List: 680F cruise performance Gentlemen, Are there any active members that own a AC 680F? Im estimating a ferry flight and need the best altitude/fuel burn and could really use your experience. thanks. wer > ---------------------------------------------------------------- http://www.matronics.com/contribution< span> ________________________________________________________________________________
Date: Nov 06, 2008
Willis, One further thought. Your plane will be MUCH lighter than N680RR. With all of the "stuff" that it has, most flights are made at near gross weight (about 8,000 lbs.), and the observations made in these emails are based on this. Your plane should be a rocket compared to N680RR Moe From: willis robison Sent: Thursday, November 06, 2008 7:45 AM Subject: Re: Commander-List: 680F cruise performance Thanks Moe, makes a lot of sense. I would think that an IGSO engine swinging +90" props would want to live where they are most efficient. no chance of +18k? the supposed service ceiling is in the mid to uppper 20's I thought. Im looking at a bare plane, no interior as its a former aerial survey craft. wer --- On Thu, 11/6/08, Moe-rosspistons wrote: From: Moe-rosspistons <moe-rosspistons(at)hotmail.com> Subject: Re: Commander-List: 680F cruise performance To: commander-list(at)matronics.com Date: Thursday, November 6, 2008, 7:24 AM Willis, Your plane wants to fly its best at 16,000 to 18,000 ft. Anything below this altitude and the fuel compsuntion vs. distance traveled suffers. The one exception is if the headwind at 10,000 is mild and the headwind at 18,000 is bad. Moe From: willis robison Sent: Thursday, November 06, 2008 7:01 AM To: commander-list(at)matronics.com Subject: RE: Commander-List: 680F cruise performance Thanks Randy, JB. Thats sounds reasonable for a low-level flight. Do you guys every fly on oxy? I would think your economy would be much better at a higher altitude. And with oodles of power to get there quickly, it should be a snap. I guess with the Time to climb and then let down, that may not be cost-effective. wer --- On Thu, 11/6/08, Randy Dettmer, AIA wrote: From: Randy Dettmer, AIA <rcdettmer(at)charter.net> Subject: RE: Commander-List: 680F cruise performance To: commander-list(at)matronics.com Date: Thursday, November 6, 2008, 6:29 AM I flight plan 10K to 12K at 190 knots true, and 52 to 55 gph in my 680F. Randy Dettmer, AIA, NCARB 680F / N6253X Dettmer Architecture 663 Hill Street San Luis Obispo, CA 93405 805 541 4864 / Fax 805 541 4865 www.dettmerarchitecture.com ---------------------------------------------------------------- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of yourtcfg(at)aol.com Sent: Wednesday, November 05, 2008 11:10 PM To: commander-list(at)matronics.com Subject: Re: Commander-List: 680F cruise performance Above 10K, 200kts @55GPH. jb -----Original Message----- From: willis robison <drwer2(at)yahoo.com> To: commander-list(at)matronics.com Sent: Wed, 5 Nov 2008 8:58 pm Subject: Commander-List: 680F cruise performance Gentlemen, Are there any active members that own a AC 680F? Im estimating a ferry flight and need the best altitude/fuel burn and could really use your experience. thanks. wer > ---------------------------------------------------------------- http://www.matronics.com/contribution< span> ________________________________________________________________________________
Date: Nov 06, 2008
Well, there will be ferry tanks for fuel and oil.- The size of which depe nds upon the route taken.- This is a special ferry operation that will ha ve extended tracks over long stretches of either water or some "not-so hosp itable" territory.- My initial estimate is for another 100 gal fuel and 2 0 gal oil. (780+ lbs) so the initial TOW may be near max.- - Naturally a more benign route would make this a lot easier.- - All Diamonds start out "In-The Rough".....its what you put into them that m ake them shine. - wer --- On Thu, 11/6/08, Moe-rosspistons wrote: From: Moe-rosspistons <moe-rosspistons(at)hotmail.com> Subject: Re: Commander-List: 680F cruise performance Date: Thursday, November 6, 2008, 8:17 AM Willis, - One further thought.- Your plane will be MUCH lighter than N680RR.- Wit h all of the "stuff" that it has, most flights are made at near gross weigh t (about 8,000 lbs.), and the observations made in these emails are based o n this. Your plane should be a rocket compared to N680RR - Moe - From: willis robison Sent: Thursday, November 06, 2008 7:45 AM Subject: Re: Commander-List: 680F cruise performance Thanks Moe, -makes a lot of sense.-- I would think that an IGSO engin e swinging +90" props would want to live where they- are most efficient. - no chance of +18k?- the supposed service ceiling is in the mid to uppper 20's I thought.- Im looking at a bare plane, no interior as its a former aerial survey craft. - wer --- On Thu, 11/6/08, Moe-rosspistons wrote: From: Moe-rosspistons <moe-rosspistons(at)hotmail.com> Subject: Re: Commander-List: 680F cruise performance Date: Thursday, November 6, 2008, 7:24 AM Willis, - Your plane wants to fly its best at 16,000 to 18,000 ft.- Anything below this altitude and the fuel compsuntion vs. distance traveled suffers.- Th e one exception is if the headwind at 10,000 is mild and the headwind at 18 ,000 is bad. - Moe From: willis robison Sent: Thursday, November 06, 2008 7:01 AM Subject: RE: Commander-List: 680F cruise performance Thanks Randy, JB.- Thats- sounds reasonable for a low-level flight. - Do you guys every fly on oxy?- I would think your economy would be much b etter at a higher altitude.- And with oodles of power to get there quickl y, it should be a snap.- I guess with the Time to climb and then let down , that may not be cost-effective. - wer --- On Thu, 11/6/08, Randy Dettmer, AIA wrote: From: Randy Dettmer, AIA <rcdettmer(at)charter.net> Subject: RE: Commander-List: 680F cruise performance Date: Thursday, November 6, 2008, 6:29 AM I flight plan 10K to 12K at 190 knots true, and 52 to 55 gph in my 680F. Randy Dettmer, AIA, NCARB 680F / N6253X Dettmer Architecture 663 Hill Street San Luis Obispo, CA - 93405 805 541 4864 / Fax 805 541 4865 www.dettmerarchitecture.com From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-lis t-server(at)matronics.com] On Behalf Of yourtcfg(at)aol.com Sent: Wednesday, November 05, 2008 11:10 PM Subject: Re: Commander-List: 680F cruise performance Above 10K, 200kts @55GPH.- jb -----Original Message----- From: willis robison <drwer2(at)yahoo.com> Sent: Wed, 5 Nov 2008 8:58 pm Subject: Commander-List: 680F cruise performance Gentlemen, - Are there any active members that own a AC 680F?-- Im estimating a ferr y flight and need the best altitude/fuel burn and could really use your exp erience. - thanks. - wer - - > - -http://www.matronics.com/contribution< span> =0A=0A=0A ________________________________________________________________________________
Date: Nov 06, 2008
Subject: evolution
This is great-BETTER THAN SANTA CLAUS.- You guys have convinced me about evolution.- I just buried a couple of aluminum cans.- In six billion ye ars I expect to have a new 500B.- In the mean time I ll keep my old one. - dan f - -=0A=0A=0A ________________________________________________________________________________
Date: Nov 06, 2008
Subject: Re: evolution
Or, you could pray for one and God will miracle you a brand new 500B. I'm sure that'll work, and much faster. Your comparison leaves a little to be desired, as aluminum is non-organic and can't evolve ;-). I'm sure God is laughing at both of us anyway, right now. /J PS: Isn't the sun due to blow up into a Red Giant in only 2 Billion years? Better hustle on those cans... Dan Farmer wrote: > This is great-*BETTER THAN SANTA CLAUS*. You guys have convinced me > about evolution. I just buried a couple of aluminum cans. In six > billion years I expect to have a new 500B. In the mean time I ll keep > my old one. > > dan f > > > > > * > > * ________________________________________________________________________________
Subject: James Bond
Date: Nov 06, 2008
I did notice too! seems a "modernized one" has wing tips... hey for a bond movie had to choose a refurbished one... seems also that they have plenty of planes flying in that movie too! I guess the only one who might have seen it is Barry since it was premiered on the other side of the pond... On Nov 6, 2008, at 1:03 AM, nico css wrote: > Has anyone seen the Commander in the James Bond movie trailer > Quantum of Solace? It appears very briefly in the background of one > of the scenes. > ________________________________________________________________________________
From: "Barry Collman" <barry.collman@air-britain.co.uk>
Date: Nov 06, 2008
Hi Willis, What's the Serial Number or "N" number of this former survey Commander? And, where's it being ferried from and to? Best Regards, Barry ----- Original Message ----- From: willis robison To: commander-list(at)matronics.com Sent: Thursday, November 06, 2008 5:03 PM Subject: Re: Commander-List: 680F cruise performance Well, there will be ferry tanks for fuel and oil. The size of which depends upon the route taken. This is a special ferry operation that will have extended tracks over long stretches of either water or some "not-so hospitable" territory. My initial estimate is for another 100 gal fuel and 20 gal oil. (780+ lbs) so the initial TOW may be near max. Naturally a more benign route would make this a lot easier. All Diamonds start out "In-The Rough".....its what you put into them that make them shine. wer --- On Thu, 11/6/08, Moe-rosspistons wrote: From: Moe-rosspistons <moe-rosspistons(at)hotmail.com> Subject: Re: Commander-List: 680F cruise performance To: commander-list(at)matronics.com Date: Thursday, November 6, 2008, 8:17 AM Willis, One further thought. Your plane will be MUCH lighter than N680RR. With all of the "stuff" that it has, most flights are made at near gross weight (about 8,000 lbs.), and the observations made in these emails are based on this. Your plane should be a rocket compared to N680RR Moe From: willis robison Sent: Thursday, November 06, 2008 7:45 AM To: commander-list(at)matronics.com Subject: Re: Commander-List: 680F cruise performance Thanks Moe, makes a lot of sense. I would think that an IGSO engine swinging +90" props would want to live where they are most efficient. no chance of +18k? the supposed service ceiling is in the mid to uppper 20's I thought. Im looking at a bare plane, no interior as its a former aerial survey craft. wer --- On Thu, 11/6/08, Moe-rosspistons wrote: From: Moe-rosspistons <moe-rosspistons(at)hotmail.com> Subject: Re: Commander-List: 680F cruise performance To: commander-list(at)matronics.com Date: Thursday, November 6, 2008, 7:24 AM Willis, Your plane wants to fly its best at 16,000 to 18,000 ft. Anything below this altitude and the fuel compsuntion vs. distance traveled suffers. The one exception is if the headwind at 10,000 is mild and the headwind at 18,000 is bad. Moe From: willis robison Sent: Thursday, November 06, 2008 7:01 AM To: commander-list(at)matronics.com Subject: RE: Commander-List: 680F cruise performance Thanks Randy, JB. Thats sounds reasonable for a low-level flight. Do you guys every fly on oxy? I would think your economy would be much better at a higher altitude. And with oodles of power to get there quickly, it should be a snap. I guess with the Time to climb and then let down, that may not be cost-effective. wer --- On Thu, 11/6/08, Randy Dettmer, AIA wrote: From: Randy Dettmer, AIA Subject: RE: Commander-List: 680F cruise performance To: commander-list(at)matronics.com Date: Thursday, November 6, 2008, 6:29 AM I flight plan 10K to 12K at 190 knots true, and 52 to 55 gph in my 680F. Randy Dettmer, AIA, NCARB 680F / N6253X Dettmer Architecture 663 Hill Street San Luis Obispo, CA 93405 805 541 4864 / Fax 805 541 4865 www.dettmerarchitecture.com ------------------------------------------------------ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of yourtcfg(at)aol.com Sent: Wednesday, November 05, 2008 11:10 PM To: commander-list(at)matronics.com Subject: Re: Commander-List: 680F cruise performance Above 10K, 200kts @55GPH. jb -----Original Message----- From: willis robison <drwer2(at)yahoo.com> To: commander-list(at)matronics.com Sent: Wed, 5 Nov 2008 8:58 pm Subject: Commander-List: 680F cruise performance Gentlemen, Are there any active members that own a AC 680F? Im estimating a ferry flight and need the best altitude/fuel burn and could really use your experience. thanks. wer > ------------------------------------------------------ http://www.matronics.com/contribution< span> ________________________________________________________________________________
Subject: Re: James Bond
Date: Nov 06, 2008
Hi All, Nope - not a big movie fan, so not seen the Commander! Best Regards, Barry ----- Original Message ----- From: peter bichier To: commander-list(at)matronics.com Sent: Thursday, November 06, 2008 5:37 PM Subject: Commander-List: James Bond I did notice too! seems a "modernized one" has wing tips... hey for a bond movie had to choose a refurbished one... seems also that they have plenty of planes flying in that movie too! I guess the only one who might have seen it is Barry since it was premiered on the other side of the pond... On Nov 6, 2008, at 1:03 AM, nico css wrote: Has anyone seen the Commander in the James Bond movie trailer Quantum of Solace? It appears very briefly in the background of one of the scenes. ________________________________________________________________________________
Date: Nov 06, 2008
I dont have the SN, but the tail No. is ZK-CDK of new zealand.- I havent decided to purchase it yet, Im still adding up all the expenses. - It may be cheaper just to immigrate to NZ.- Lovely place....and I really like the ocean too.- - wer --- On Thu, 11/6/08, Barry Collman <barry.collman@air-britain.co.uk> wrote: From: Barry Collman <barry.collman@air-britain.co.uk> Subject: Re: Commander-List: 680F cruise performance Date: Thursday, November 6, 2008, 10:22 AM Hi Willis, - What's the Serial Number or "N" number of this-former survey-Commander? And, where's it being ferried from and to? - Best Regards, Barry ----- Original Message ----- From: willis robison Sent: Thursday, November 06, 2008 5:03 PM Subject: Re: Commander-List: 680F cruise performance Well, there will be ferry tanks for fuel and oil.- The size of which depe nds upon the route taken.- This is a special ferry operation that will ha ve extended tracks over long stretches of either water or some "not-so hosp itable" territory.- My initial estimate is for another 100 gal fuel and 2 0 gal oil. (780+ lbs) so the initial TOW may be near max.- - Naturally a more benign route would make this a lot easier.- - All Diamonds start out "In-The Rough".....its what you put into them that m ake them shine. - wer --- On Thu, 11/6/08, Moe-rosspistons wrote: From: Moe-rosspistons <moe-rosspistons(at)hotmail.com> Subject: Re: Commander-List: 680F cruise performance Date: Thursday, November 6, 2008, 8:17 AM Willis, - One further thought.- Your plane will be MUCH lighter than N680RR.- Wit h all of the "stuff" that it has, most flights are made at near gross weigh t (about 8,000 lbs.), and the observations made in these emails are based o n this. Your plane should be a rocket compared to N680RR - Moe - From: willis robison Sent: Thursday, November 06, 2008 7:45 AM Subject: Re: Commander-List: 680F cruise performance Thanks Moe, -makes a lot of sense.-- I would think that an IGSO engin e swinging +90" props would want to live where they- are most efficient. - no chance of +18k?- the supposed service ceiling is in the mid to uppper 20's I thought.- Im looking at a bare plane, no interior as its a former aerial survey craft. - wer --- On Thu, 11/6/08, Moe-rosspistons wrote: From: Moe-rosspistons <moe-rosspistons(at)hotmail.com> Subject: Re: Commander-List: 680F cruise performance Date: Thursday, November 6, 2008, 7:24 AM Willis, - Your plane wants to fly its best at 16,000 to 18,000 ft.- Anything below this altitude and the fuel compsuntion vs. distance traveled suffers.- Th e one exception is if the headwind at 10,000 is mild and the headwind at 18 ,000 is bad. - Moe From: willis robison Sent: Thursday, November 06, 2008 7:01 AM Subject: RE: Commander-List: 680F cruise performance Thanks Randy, JB.- Thats- sounds reasonable for a low-level flight. - Do you guys every fly on oxy?- I would think your economy would be much b etter at a higher altitude.- And with oodles of power to get there quickl y, it should be a snap.- I guess with the Time to climb and then let down , that may not be cost-effective. - wer --- On Thu, 11/6/08, Randy Dettmer, AIA wrote: From: Randy Dettmer, AIA <rcdettmer(at)charter.net> Subject: RE: Commander-List: 680F cruise performance Date: Thursday, November 6, 2008, 6:29 AM #yiv78531060 UNKNOWN { FONT-FAMILY:Tahoma;panose-1:2 11 6 4 3 5 4 4 2 4;} #yiv78531060 #yiv772537251 #yiv679981899 #yiv872274376 #yiv872274376 P.MsoN ormal { FONT-SIZE:12pt;MARGIN:0in 0in 0pt;FONT-FAMILY:"Times New Roman";} #yiv78531060 #yiv772537251 #yiv679981899 #yiv872274376 LI.MsoNormal { FONT-SIZE:12pt;MARGIN:0in 0in 0pt;FONT-FAMILY:"Times New Roman";} #yiv78531060 #yiv772537251 #yiv679981899 #yiv872274376 DIV.MsoNormal { FONT-SIZE:12pt;MARGIN:0in 0in 0pt;FONT-FAMILY:"Times New Roman";} #yiv78531060 #yiv772537251 #yiv679981899 #yiv872274376 A:link { COLOR:blue;TEXT-DECORATION:underline;} #yiv78531060 #yiv772537251 #yiv679981899 #yiv872274376 SPAN.MsoHyperlink { COLOR:blue;TEXT-DECORATION:underline;} #yiv78531060 #yiv772537251 #yiv679981899 #yiv872274376 A:visited { COLOR:blue;TEXT-DECORATION:underline;} #yiv78531060 #yiv772537251 #yiv679981899 #yiv872274376 SPAN.MsoHyperlinkFol lowed { COLOR:blue;TEXT-DECORATION:underline;} #yiv78531060 #yiv772537251 #yiv679981899 #yiv872274376 P.MsoAutoSig { FONT-SIZE:12pt;MARGIN:0in 0in 0pt;FONT-FAMILY:"Times New Roman";} #yiv78531060 #yiv772537251 #yiv679981899 #yiv872274376 LI.MsoAutoSig { FONT-SIZE:12pt;MARGIN:0in 0in 0pt;FONT-FAMILY:"Times New Roman";} #yiv78531060 #yiv772537251 #yiv679981899 #yiv872274376 DIV.MsoAutoSig { FONT-SIZE:12pt;MARGIN:0in 0in 0pt;FONT-FAMILY:"Times New Roman";} #yiv78531060 #yiv772537251 #yiv679981899 #yiv872274376 PRE { FONT-SIZE:10pt;MARGIN:0in 0in 0pt;FONT-FAMILY:"Courier New";} #yiv78531060 #yiv772537251 #yiv679981899 #yiv872274376 SPAN.EmailStyle18 { COLOR:navy;FONT-FAMILY:Arial;} #yiv78531060 UNKNOWN { MARGIN:1in 1.25in;} #yiv78531060 #yiv772537251 #yiv679981899 #yiv872274376 DIV.Section1 { } I flight plan 10K to 12K at 190 knots true, and 52 to 55 gph in my 680F. Randy Dettmer, AIA, NCARB 680F / N6253X Dettmer Architecture 663 Hill Street San Luis Obispo, CA - 93405 805 541 4864 / Fax 805 541 4865 www.dettmerarchitecture.com From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-lis t-server(at)matronics.com] On Behalf Of yourtcfg(at)aol.com Sent: Wednesday, November 05, 2008 11:10 PM Subject: Re: Commander-List: 680F cruise performance Above 10K, 200kts @55GPH.- jb -----Original Message----- From: willis robison <drwer2(at)yahoo.com> Sent: Wed, 5 Nov 2008 8:58 pm Subject: Commander-List: 680F cruise performance Gentlemen, - Are there any active members that own a AC 680F?-- Im estimating a ferr y flight and need the best altitude/fuel burn and could really use your exp erience. - thanks. - wer - - > - -http://www.matronics.com/contribution< span> =0A=0A=0A ________________________________________________________________________________
Date: Nov 06, 2008
Hi Willis, OK - thanks for letting me know. As you know, it's a 680F, s/n 1289-132. So, that makes it the 1289th production Commander and the 132nd 680F built. It's been in New Zealand all its life, apart from an initial registration of N78395 and with just the one owner too, although they have had a couple of name changes and was initially owned jointly with the New Zealand Land & Survey Department Was initially Certificated August 23rd 1963. Should imagine it's been a well-maintained example, so sincerely hope everything works out well for you. If you'd like a suitable note endorsing its purchase to show "her indoors" . . . just ask ;-) Very Best Regards, Barry P.S. I think Bert Berry has also asked which one you are ferrying. He's a good source of info for me and he'll respect the privacy of the info if you tell him. ----- Original Message ----- From: willis robison To: commander-list(at)matronics.com Sent: Thursday, November 06, 2008 8:30 PM Subject: Re: Commander-List: 680F cruise performance I dont have the SN, but the tail No. is ZK-CDK of new zealand. I havent decided to purchase it yet, Im still adding up all the expenses. It may be cheaper just to immigrate to NZ. Lovely place....and I really like the ocean too. wer --- On Thu, 11/6/08, Barry Collman <barry.collman@air-britain.co.uk> wrote: From: Barry Collman <barry.collman@air-britain.co.uk> Subject: Re: Commander-List: 680F cruise performance To: commander-list(at)matronics.com Date: Thursday, November 6, 2008, 10:22 AM Hi Willis, What's the Serial Number or "N" number of this former survey Commander? And, where's it being ferried from and to? Best Regards, Barry ----- Original Message ----- From: willis robison To: commander-list(at)matronics.com Sent: Thursday, November 06, 2008 5:03 PM Subject: Re: Commander-List: 680F cruise performance Well, there will be ferry tanks for fuel and oil. The size of which depends upon the route taken. This is a special ferry operation that will have extended tracks over long stretches of either water or some "not-so hospitable" territory. My initial estimate is for another 100 gal fuel and 20 gal oil. (780+ lbs) so the initial TOW may be near max. Naturally a more benign route would make this a lot easier. All Diamonds start out "In-The Rough".....its what you put into them that make them shine. wer --- On Thu, 11/6/08, Moe-rosspistons wrote: From: Moe-rosspistons <moe-rosspistons(at)hotmail.com> Subject: Re: Commander-List: 680F cruise performance To: commander-list(at)matronics.com Date: Thursday, November 6, 2008, 8:17 AM Willis, One further thought. Your plane will be MUCH lighter than N680RR. With all of the "stuff" that it has, most flights are made at near gross weight (about 8,000 lbs.), and the observations made in these emails are based on this. Your plane should be a rocket compared to N680RR Moe From: willis robison Sent: Thursday, November 06, 2008 7:45 AM To: commander-list(at)matronics.com Subject: Re: Commander-List: 680F cruise performance Thanks Moe, makes a lot of sense. I would think that an IGSO engine swinging +90" props would want to live where they are most efficient. no chance of +18k? the supposed service ceiling is in the mid to uppper 20's I thought. Im looking at a bare plane, no interior as its a former aerial survey craft. wer --- On Thu, 11/6/08, Moe-rosspistons wrote: From: Moe-rosspistons Subject: Re: Commander-List: 680F cruise performance To: commander-list(at)matronics.com Date: Thursday, November 6, 2008, 7:24 AM Willis, Your plane wants to fly its best at 16,000 to 18,000 ft. Anything below this altitude and the fuel compsuntion vs. distance traveled suffers. The one exception is if the headwind at 10,000 is mild and the headwind at 18,000 is bad. Moe From: willis robison Sent: Thursday, November 06, 2008 7:01 AM To: commander-list(at)matronics.com Subject: RE: Commander-List: 680F cruise performance Thanks Randy, JB. Thats sounds reasonable for a low-level flight. Do you guys every fly on oxy? I would think your economy would be much better at a higher altitude. And with oodles of power to get there quickly, it should be a snap. I guess with the Time to climb and then let down, that may not be cost-effective. wer --- On Thu, 11/6/08, Randy Dettmer, AIA wrote: From: Randy Dettmer, AIA Subject: RE: Commander-List: 680F cruise performance To: commander-list(at)matronics.com Date: Thursday, November 6, 2008, 6:29 AM I flight plan 10K to 12K at 190 knots true, and 52 to 55 gph in my 680F. Randy Dettmer, AIA, NCARB 680F / N6253X Dettmer Architecture 663 Hill Street San Luis Obispo, CA 93405 805 541 4864 / Fax 805 541 4865 www.dettmerarchitecture.com ------------------------------------------------ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of yourtcfg(at)aol.com Sent: Wednesday, November 05, 2008 11:10 PM To: commander-list(at)matronics.com Subject: Re: Commander-List: 680F cruise performance Above 10K, 200kts @55GPH. jb -----Original Message----- From: willis robison <drwer2(at)yahoo.com> To: commander-list(at)matronics.com Sent: Wed, 5 Nov 2008 8:58 pm Subject: Commander-List: 680F cruise performance Gentlemen, Are there any active members that own a AC 680F? Im estimating a ferry flight and need the best altitude/fuel burn and could really use your experience. thanks. wer > ------------------------------------------------ http://www.matronics.com/contribution< span> 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ________________________________________________________________________________
Date: Nov 06, 2008
Thanks Barry, Ive copied him on this reply. - Ill let you know if it comes together.- - So far, it appears to be very well taken care of, with few real issues.- one engine is near TBO but doesnt appear to have any issues at all.- It m ay take the whole "village" to bring this one home.- As you can imagine, the shortes- and least expensive route is the friendliest, but the most u nforgiving.- The path "most traveled by", is almost 20k mi with more poli tical (and military) obstacles than environmental ones. - I dont have my hopes up yet; I prefer to let the numbers fall where they ma y. - thanks- wer - - - --- On Thu, 11/6/08, Barry Collman <barry.collman@air-britain.co.uk> wrote: From: Barry Collman <barry.collman@air-britain.co.uk> Subject: Re: Commander-List: 680F cruise performance Date: Thursday, November 6, 2008, 12:45 PM Hi Willis, - OK - thanks for letting me know. As you know, it's a 680F, s/n 1289-132. So, that makes it the 1289th production Commander and the 132nd 680F built. - It's been in New Zealand all its life, apart from an initial registration o f N78395 and with just the one owner too, although they have had a couple o f name changes and was initially owned jointly with the New Zealand Land & Survey Department - Was initially Certificated August 23rd 1963. - Should imagine it's been a well-maintained example, so sincerely hope every thing works out well for you. If you'd like a suitable note endorsing its purchase to show "her indoors" . . . just ask ;-) - Very Best Regards, Barry - P.S. I think Bert Berry has also asked which one you are ferrying. He's a good source of info for me and he'll respect the privacy of the info if you tell him. ----- Original Message ----- From: willis robison Sent: Thursday, November 06, 2008 8:30 PM Subject: Re: Commander-List: 680F cruise performance I dont have the SN, but the tail No. is ZK-CDK of new zealand.- I havent decided to purchase it yet, Im still adding up all the expenses. - It may be cheaper just to immigrate to NZ.- Lovely place....and I really like the ocean too.- - wer --- On Thu, 11/6/08, Barry Collman <barry.collman@air-britain.co.uk> wrote: From: Barry Collman <barry.collman@air-britain.co.uk> Subject: Re: Commander-List: 680F cruise performance Date: Thursday, November 6, 2008, 10:22 AM Hi Willis, - What's the Serial Number or "N" number of this-former survey-Commander? And, where's it being ferried from and to? - Best Regards, Barry ----- Original Message ----- From: willis robison Sent: Thursday, November 06, 2008 5:03 PM Subject: Re: Commander-List: 680F cruise performance Well, there will be ferry tanks for fuel and oil.- The size of which depe nds upon the route taken.- This is a special ferry operation that will ha ve extended tracks over long stretches of either water or some "not-so hosp itable" territory.- My initial estimate is for another 100 gal fuel and 2 0 gal oil. (780+ lbs) so the initial TOW may be near max.- - Naturally a more benign route would make this a lot easier.- - All Diamonds start out "In-The Rough".....its what you put into them that m ake them shine. - wer --- On Thu, 11/6/08, Moe-rosspistons wrote: From: Moe-rosspistons <moe-rosspistons(at)hotmail.com> Subject: Re: Commander-List: 680F cruise performance Date: Thursday, November 6, 2008, 8:17 AM Willis, - One further thought.- Your plane will be MUCH lighter than N680RR.- Wit h all of the "stuff" that it has, most flights are made at near gross weigh t (about 8,000 lbs.), and the observations made in these emails are based o n this. Your plane should be a rocket compared to N680RR - Moe - From: willis robison Sent: Thursday, November 06, 2008 7:45 AM Subject: Re: Commander-List: 680F cruise performance Thanks Moe, -makes a lot of sense.-- I would think that an IGSO engin e swinging +90" props would want to live where they- are most efficient. - no chance of +18k?- the supposed service ceiling is in the mid to uppper 20's I thought.- Im looking at a bare plane, no interior as its a former aerial survey craft. - wer --- On Thu, 11/6/08, Moe-rosspistons wrote: From: Moe-rosspistons <moe-rosspistons(at)hotmail.com> Subject: Re: Commander-List: 680F cruise performance Date: Thursday, November 6, 2008, 7:24 AM Willis, - Your plane wants to fly its best at 16,000 to 18,000 ft.- Anything below this altitude and the fuel compsuntion vs. distance traveled suffers.- Th e one exception is if the headwind at 10,000 is mild and the headwind at 18 ,000 is bad. - Moe From: willis robison Sent: Thursday, November 06, 2008 7:01 AM Subject: RE: Commander-List: 680F cruise performance Thanks Randy, JB.- Thats- sounds reasonable for a low-level flight. - Do you guys every fly on oxy?- I would think your economy would be much b etter at a higher altitude.- And with oodles of power to get there quickl y, it should be a snap.- I guess with the Time to climb and then let down , that may not be cost-effective. - wer --- On Thu, 11/6/08, Randy Dettmer, AIA wrote: From: Randy Dettmer, AIA <rcdettmer(at)charter.net> Subject: RE: Commander-List: 680F cruise performance Date: Thursday, November 6, 2008, 6:29 AM #yiv1909177027 #yiv78531060 UNKNOWN { FONT-FAMILY:Tahoma;panose-1:2 11 6 4 3 5 4 4 2 4;} #yiv1909177027 #yiv78531060 #yiv772537251 #yiv679981899 #yiv872274376 #yiv8 72274376 P.MsoNormal { FONT-SIZE:12pt;MARGIN:0in 0in 0pt;FONT-FAMILY:"Times New Roman";} #yiv1909177027 #yiv78531060 #yiv772537251 #yiv679981899 #yiv872274376 LI.Ms oNormal { FONT-SIZE:12pt;MARGIN:0in 0in 0pt;FONT-FAMILY:"Times New Roman";} #yiv1909177027 #yiv78531060 #yiv772537251 #yiv679981899 #yiv872274376 DIV.M soNormal { FONT-SIZE:12pt;MARGIN:0in 0in 0pt;FONT-FAMILY:"Times New Roman";} #yiv1909177027 #yiv78531060 #yiv772537251 #yiv679981899 #yiv872274376 A:lin k { COLOR:blue;TEXT-DECORATION:underline;} #yiv1909177027 #yiv78531060 #yiv772537251 #yiv679981899 #yiv872274376 SPAN. MsoHyperlink { COLOR:blue;TEXT-DECORATION:underline;} #yiv1909177027 #yiv78531060 #yiv772537251 #yiv679981899 #yiv872274376 A:vis ited { COLOR:blue;TEXT-DECORATION:underline;} #yiv1909177027 #yiv78531060 #yiv772537251 #yiv679981899 #yiv872274376 SPAN. MsoHyperlinkFollowed { COLOR:blue;TEXT-DECORATION:underline;} #yiv1909177027 #yiv78531060 #yiv772537251 #yiv679981899 #yiv872274376 P.Mso AutoSig { FONT-SIZE:12pt;MARGIN:0in 0in 0pt;FONT-FAMILY:"Times New Roman";} #yiv1909177027 #yiv78531060 #yiv772537251 #yiv679981899 #yiv872274376 LI.Ms oAutoSig { FONT-SIZE:12pt;MARGIN:0in 0in 0pt;FONT-FAMILY:"Times New Roman";} #yiv1909177027 #yiv78531060 #yiv772537251 #yiv679981899 #yiv872274376 DIV.M soAutoSig { FONT-SIZE:12pt;MARGIN:0in 0in 0pt;FONT-FAMILY:"Times New Roman";} #yiv1909177027 #yiv78531060 #yiv772537251 #yiv679981899 #yiv872274376 PRE { FONT-SIZE:10pt;MARGIN:0in 0in 0pt;FONT-FAMILY:"Courier New";} #yiv1909177027 #yiv78531060 #yiv772537251 #yiv679981899 #yiv872274376 SPAN. EmailStyle18 { COLOR:navy;FONT-FAMILY:Arial;} #yiv1909177027 #yiv78531060 UNKNOWN { MARGIN:1in 1.25in;} #yiv1909177027 #yiv78531060 #yiv772537251 #yiv679981899 #yiv872274376 DIV.S ection1 { } I flight plan 10K to 12K at 190 knots true, and 52 to 55 gph in my 680F. Randy Dettmer, AIA, NCARB 680F / N6253X Dettmer Architecture 663 Hill Street San Luis Obispo, CA - 93405 805 541 4864 / Fax 805 541 4865 www.dettmerarchitecture.com From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-lis t-server(at)matronics.com] On Behalf Of yourtcfg(at)aol.com Sent: Wednesday, November 05, 2008 11:10 PM Subject: Re: Commander-List: 680F cruise performance Above 10K, 200kts @55GPH.- jb -----Original Message----- From: willis robison <drwer2(at)yahoo.com> Sent: Wed, 5 Nov 2008 8:58 pm Subject: Commander-List: 680F cruise performance Gentlemen, - Are there any active members that own a AC 680F?-- Im estimating a ferr y flight and need the best altitude/fuel burn and could really use your exp erience. - thanks. - wer - - > - -http://www.matronics.com/contribution< span> 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D href='3D"http://www.matronics.com/contribution"'>http://www.matronics.com /contribution 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D href='3D"http://www.matronics.com/Navigator?Commander-List"'>http://www.m atronics.com/Navigator?Commander-List 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D href='3D"http://forums.matronics.com"'>http://forums.matronics.com 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D =0A=0A=0A ________________________________________________________________________________
Date: Nov 06, 2008
Subject: Re: possessed
I really wish I could have been here to get into this one. I can only echo your sentiments because they reflect my love and loyalty for this country as well. How did we get so many idiots in this country? I know our education system certainly leaves a lot to be desired but I just can`t understand the growing ignorance and lack of love for the BEST country on this planet! Perfect? No but has been the very BEST! I only hope we can get it back on track for our Grand Kids . I am so sorry I missed out. I`m proud of you. Prouid to beYour friend, Gil **************AOL Search: Your one stop for directions, recipes and all other Holiday needs. Search Now. -aol-search/?ncid=emlcntussear00000001) ________________________________________________________________________________
Date: Nov 06, 2008
Subject: Reminder
Dear Listers, Just a quick reminder that November is the annual List Fund Raiser. The Matronics Lists are 100% member supported and all of the operational costs are provided for my your Contributions during this time of the year. Your personal Contribution makes a difference and keeps all of the Matronics Email Lists and Forums completely ad-free. Please make your Contribution today to keep these services up and running! http://www.matronics.com/contribution Thank you in advance! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
From: "Bill Hamilton" <wjrhamilton(at)optusnet.com.au>
Subject: 680F cruise performance
Date: Nov 07, 2008
Guys, Have a look at ferrying around the Pacific rim, Kamchatka, Aleutians, Alaska, quite a few use it now, when the weather is right, 690's can do it on standard tanks. Hilo to anywhere on the California coast is a long stretch, about 2200nm. Cheers, Bill Hamilton From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of willis robison Sent: Friday, November 07, 2008 4:04 AM Subject: Re: Commander-List: 680F cruise performance Well, there will be ferry tanks for fuel and oil. The size of which depends upon the route taken. This is a special ferry operation that will have extended tracks over long stretches of either water or some "not-so hospitable" territory. My initial estimate is for another 100 gal fuel and 20 gal oil. (780+ lbs) so the initial TOW may be near max. Naturally a more benign route would make this a lot easier. All Diamonds start out "In-The Rough".....its what you put into them that make them shine. wer --- On Thu, 11/6/08, Moe-rosspistons wrote: From: Moe-rosspistons <moe-rosspistons(at)hotmail.com> Subject: Re: Commander-List: 680F cruise performance Date: Thursday, November 6, 2008, 8:17 AM Willis, One further thought. Your plane will be MUCH lighter than N680RR. With all of the "stuff" that it has, most flights are made at near gross weight (about 8,000 lbs.), and the observations made in these emails are based on this. Your plane should be a rocket compared to N680RR Moe From: willis <mailto:drwer2(at)yahoo.com> robison Sent: Thursday, November 06, 2008 7:45 AM Subject: Re: Commander-List: 680F cruise performance Thanks Moe, makes a lot of sense. I would think that an IGSO engine swinging +90" props would want to live where they are most efficient. no chance of +18k? the supposed service ceiling is in the mid to uppper 20's I thought. Im looking at a bare plane, no interior as its a former aerial survey craft. wer --- On Thu, 11/6/08, Moe-rosspistons wrote: From: Moe-rosspistons <moe-rosspistons(at)hotmail.com> Subject: Re: Commander-List: 680F cruise performance Date: Thursday, November 6, 2008, 7:24 AM Willis, Your plane wants to fly its best at 16,000 to 18,000 ft. Anything below this altitude and the fuel compsuntion vs. distance traveled suffers. The one exception is if the headwind at 10,000 is mild and the headwind at 18,000 is bad. Moe From: willis <mailto:drwer2(at)yahoo.com> robison Sent: Thursday, November 06, 2008 7:01 AM Subject: RE: Commander-List: 680F cruise performance Thanks Randy, JB. Thats sounds reasonable for a low-level flight. Do you guys every fly on oxy? I would think your economy would be much better at a higher altitude. And with oodles of power to get there quickly, it should be a snap. I guess with the Time to climb and then let down, that may not be cost-effective. wer --- On Thu, 11/6/08, Randy Dettmer, AIA wrote: From: Randy Dettmer, AIA <rcdettmer(at)charter.net> Subject: RE: Commander-List: 680F cruise performance Date: Thursday, November 6, 2008, 6:29 AM I flight plan 10K to 12K at 190 knots true, and 52 to 55 gph in my 680F. Randy Dettmer, AIA, NCARB 680F / N6253X Dettmer Architecture 663 Hill Street San Luis Obispo, CA 93405 805 541 4864 / Fax 805 541 4865 www.dettmerarchitecture.com _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of yourtcfg(at)aol.com Sent: Wednesday, November 05, 2008 11:10 PM Subject: Re: Commander-List: 680F cruise performance Above 10K, 200kts @55GPH. jb -----Original Message----- From: willis robison <drwer2(at)yahoo.com> Sent: Wed, 5 Nov 2008 8:58 pm Subject: Commander-List: 680F cruise performance Gentlemen, Are there any active members that own a AC 680F? Im estimating a ferry flight and need the best altitude/fuel burn and could really use your experience. thanks. wer > _____ http://www.matronics.com/contribution < span> ________________________________________________________________________________
Subject: Flight Levels magazine - Fall 2008 issue
Date: Nov 07, 2008
Hi Guys, On page 7 of the subject magazine there's a photo of N2621B, a Commander 520 s/n 133. The text says it's powered by "a pair of geared Lycoming 520-cubic-inch GO-435-C2B engines". Has anyone else spotted the (not deliberate) error? Best Regards, Barry ________________________________________________________________________________
Subject: Re: Flight Levels magazine - Fall 2008 issue
Date: Nov 07, 2008
Yep, I saw that too.? Maybe they should have you proof the next ome!!? jb The text says it's powered by "a pair of geared Lycoming 520-cubic-inch GO-435-C2B engines". -----Original Message----- From: Barry Collman <barry.collman@air-britain.co.uk> Sent: Fri, 7 Nov 2008 9:08 am Subject: Commander-List: Flight Levels magazine - Fall 2008 issue Hi Guys, ? On page 7 of the subject magazine there's a photo of N2621B, a Commander 520 s/n 133. ? The text says it's powered by "a pair of geared Lycoming 520-cubic-inch GO-435-C2B engines". ? Has anyone else spotted the (not deliberate) error? ? Best Regards, Barry ________________________________________________________________________________
Date: Nov 07, 2008
Well, if "ome" has 520 ci then they would produce 2x380x520/435 = 908 hp. - Wow, I wonder what the GTOW-would be!? - I've always been curious about the wing/loading for these AC.- They all h ave relatively the same wing structure. (longer wingtip for the 680/560's) yet with bigger engines, the FAA allowed higher gross weights.-- Was Ae ro Design able to argue that the original design was (under powered) or ove r designed?- Which was it and at what HP/gross is the maximum? - - - --- On Fri, 11/7/08, yourtcfg(at)aol.com wrote: From: yourtcfg(at)aol.com <yourtcfg(at)aol.com> Subject: Re: Commander-List: Flight Levels magazine - Fall 2008 issue Date: Friday, November 7, 2008, 5:12 PM Yep, I saw that too.- Maybe they should have you proof the next ome!!- jb The text says it's powered by "a pair of geared Lycoming 520-cubic-inch GO- 435-C2B engines". -----Original Message----- From: Barry Collman <barry.collman@air-britain.co.uk> Sent: Fri, 7 Nov 2008 9:08 am Subject: Commander-List: Flight Levels magazine - Fall 2008 issue Hi Guys, - On page 7 of the subject magazine there's a photo of N2621B, a Commander 52 0 s/n 133. - The text says it's powered by "a pair of geared Lycoming 520-cubic-inch GO- 435-C2B engines". - Has anyone else spotted the (not deliberate) error? - Best Regards, Barry =0A=0A=0A ________________________________________________________________________________
Date: Nov 08, 2008
Over designed I think.? The same airframe wing structure can carry as much as 8500 pounds, thought some Commanders are limited to 6000 gross.? The gross weight is determined by the FAA mandated single engine climb performance.? A model 680 has the same power as a 680E but a 500 pound lower gross.? Some 680s were extended to the?"E" wingspan and the gross went up to 7500 pounds.? jb Which was it and at what HP/gross is the maximum? -----Original Message----- From: willis robison <drwer2(at)yahoo.com> Sent: Fri, 7 Nov 2008 6:55 pm Subject: Re: Commander-List: Flight Levels magazine - Fall 2008 issue Well, if "ome" has 520 ci then they would produce 2x380x520/435 = 908 hp.? Wow, I wonder what the GTOW?would be!? ? I've always been curious about the wing/loading for these AC.? They all have relatively the same wing structure. (longer wingtip for the 680/560's) yet with bigger engines, the FAA allowed higher gross weights.?? Was Aero Design able to argue that the original design was (under powered) or over designed?? Which was it and at what HP/gross is the maximum? ? ? ? --- On Fri, 11/7/08, yourtcfg(at)aol.com wrote: From: yourtcfg(at)aol.com <yourtcfg(at)aol.com> Subject: Re: Commander-List: Flight Levels magazine - Fall 2008 issue Date: Friday, November 7, 2008, 5:12 PM Yep, I saw that too.? Maybe they should have you proof the next ome!!? jb The text says it's powered by "a pair of geared Lycoming 520-cubic-inch GO-435-C2B engines". -----Original Message----- From: Barry Collman <barry.collman@air-britain.co.uk> Sent: Fri, 7 Nov 2008 9:08 am Subject: Commander-List: Flight Levels magazine - Fall 2008 issue Hi Guys, ? On page 7 of the subject magazine there's a photo of N2621B, a Commander 520 s/n 133. ? The text says it's powered by "a pair of geared Lycoming 520-cubic-inch GO-435-C2B engines". ? Has anyone else spotted the (not deliberate) error? ? Best Regards, Barry ________________________________________________________________________________
Date: Nov 08, 2008
I think so too. - I was a spectator at a few "ultimate" load tests.- One for the A380.- -I was told that it-took 10x the "rated" load before failing.- They s aid they were pleased with the results so I guess it made it past FAA and J AR. --- On Sat, 11/8/08, yourtcfg(at)aol.com wrote: From: yourtcfg(at)aol.com <yourtcfg(at)aol.com> Subject: Re: Commander-List: Flight Levels magazine - Fall 2008 issue Date: Saturday, November 8, 2008, 10:33 AM Over designed I think.- The same airframe wing structure can carry as muc h as 8500 pounds, thought some Commanders are limited to 6000 gross.- The gross weight is determined by the FAA mandated single engine climb perform ance.- A model 680 has the same power as a 680E but a 500 pound lower gro ss.- Some 680s were extended to the-"E" wingspan and the gross went up to 7500 pounds.- jb Which was it and at what HP/gross is the maximum? -----Original Message----- From: willis robison <drwer2(at)yahoo.com> Sent: Fri, 7 Nov 2008 6:55 pm Subject: Re: Commander-List: Flight Levels magazine - Fall 2008 issue Well, if "ome" has 520 ci then they would produce 2x380x520/435 = 908 hp. - Wow, I wonder what the GTOW-would be!? - I've always been curious about the wing/loading for these AC.- They all h ave relatively the same wing structure. (longer wingtip for the 680/560's) yet with bigger engines, the FAA allowed higher gross weights.-- Was Ae ro Design able to argue that the original design was (under powered) or ove r designed?- Which was it and at what HP/gross is the maximum? - - - --- On Fri, 11/7/08, yourtcfg(at)aol.com wrote: From: yourtcfg(at)aol.com <yourtcfg(at)aol.com> Subject: Re: Commander-List: Flight Levels magazine - Fall 2008 issue Date: Friday, November 7, 2008, 5:12 PM Yep, I saw that too.- Maybe they should have you proof the next ome!!- jb The text says it's powered by "a pair of geared Lycoming 520-cubic-inch GO- 435-C2B engines". -----Original Message----- From: Barry Collman <barry.collman@air-britain.co.uk> Sent: Fri, 7 Nov 2008 9:08 am Subject: Commander-List: Flight Levels magazine - Fall 2008 issue Hi Guys, - On page 7 of the subject magazine there's a photo of N2621B, a Commander 52 0 s/n 133. - The text says it's powered by "a pair of geared Lycoming 520-cubic-inch GO- 435-C2B engines". - Has anyone else spotted the (not deliberate) error? - Best Regards, Barry > ================= =0A=0A=0A ________________________________________________________________________________
Date: Nov 08, 2008
Jim, I thought the wing & spar structures were the same on all the Commanders. They're not? I know the turbines are easily a 12,000-lb. wing, but I've been under the illusion that the wing on my 500B is essentially the same thing... /John willis robison wrote: > I think so too. > > I was a spectator at a few "ultimate" load tests. One for the > A380. I was told that it took 10x the "rated" load before failing. > They said they were pleased with the results so I guess it made it > past FAA and JAR. > > --- On *Sat, 11/8/08, yourtcfg(at)aol.com //* wrote: > > From: yourtcfg(at)aol.com <yourtcfg(at)aol.com> > Subject: Re: Commander-List: Flight Levels magazine - Fall 2008 issue > To: commander-list(at)matronics.com > Date: Saturday, November 8, 2008, 10:33 AM > > Over designed I think. The same airframe wing structure can carry > as much as 8500 pounds, thought some Commanders are limited to > 6000 gross. The gross weight is determined by the FAA mandated > single engine climb performance. A model 680 has the same power > as a 680E but a 500 pound lower gross. Some 680s were extended to > the "E" wingspan and the gross went up to 7500 pounds. jb > > Which was it and at what HP/gross is the maximum? > > > -----Original Message----- > From: willis robison <drwer2(at)yahoo.com> > To: commander-list(at)matronics.com > Sent: Fri, 7 Nov 2008 6:55 pm > Subject: Re: Commander-List: Flight Levels magazine - Fall 2008 issue > > Well, if "ome" has 520 ci then they would produce 2x380x520/435 > 908 hp. Wow, I wonder what the GTOW would be!? > > I've always been curious about the wing/loading for these AC. > They all have relatively the same wing structure. (longer wingtip > for the 680/560's) yet with bigger engines, the FAA allowed higher > gross weights. Was Aero Design able to argue that the original > design was (under powered) or over designed? Which was it and at > what HP/gross is the maximum? > > > > > > --- On *Fri, 11/7/08, yourtcfg(at)aol.com > />/* wrote: > > From: yourtcfg(at)aol.com <mailto:yourtcfg(at)aol.com> > > > Subject: Re: Commander-List: Flight Levels magazine - Fall > 2008 issue > To: commander-list(at)matronics.com > > Date: Friday, November 7, 2008, 5:12 PM > > Yep, I saw that too. Maybe they should have you proof the > next ome!! jb > > The text says it's powered by "a pair of geared Lycoming > 520-cubic-inch GO-435-C2B engines". > > > -----Original Message----- > From: Barry Collman <barry.collman@air-britain.co.uk > barry.collman@air-britain.co.uk>> > To: commander-list(at)matronics.com > > Sent: Fri, 7 Nov 2008 9:08 am > Subject: Commander-List: Flight Levels magazine - Fall 2008 issue > > Hi Guys, > > On page 7 of the subject magazine there's a photo of N2621B, a > Commander 520 s/n 133. > > The text says it's powered by "a pair of geared Lycoming > 520-cubic-inch GO-435-C2B engines". > > Has anyone else spotted the (not deliberate) error? > > Best Regards, > Barry > > * > > * > > * > > * > > > > > ------------------------------------------------------------------------ > > * > > * > ________________________________________________________________________________
Date: Nov 08, 2008
Gents, - The following was gleaned from the production data on the commander website and from the NACA archives. - There appears to be two variants of the commander wing; a- 44=92 and a 49 =92- Both variants use the NACA 23012 airfoil from root to tip.-- Thi s particular airfoil is know for its docile behavior and was widely used by other aircraft.- Most notably the Beech Staggerwing uses this airfoil as do other Beech Aircraft, but only in the outboard sections near the ailero ns.- The Commanders use a single airfoil from root to tip.- This was ch osen likely for its ease of manufacture.- From a manufacturing standpoint , adding 5=92 to the wingspan is easier to do by either lengthening the tip s outboard of the ailerons or increasing the engine/nacelle truss section. This could mean adding just one or two rib sections - The 49=92 wing is the archetype and is featured on all the piston twin comm anders except the so-called =93straight=94 560 and 680 models.- The 560 w as produced from 1954 to 1957 and the 680 ran from =9255 to =9258. - There is also a notable difference in the fuel capacity for the 44=92 560 w hich has 145 gals compared to the 500s which have 156 gallons normally.- All the Long range models of 560E, F and 680F, L,P have 223 gallons- appa rently using all the available bays inboard of the ailerons. - As for weight. It looks like the early models (round nacelle) had usefull l oads around 2100 lbs with variations trading up or down depending on HP and Service ceiling.- Twin Commander corporation has mentioned that they don =92t have model years, per-se; so this has allowed them to make production runs of a particular type using the same production space. - When the Streamlined Nacell was introduced, there was also a notable increa se in useful load. To about 2300 -to 3200 lbs.- This also improved thei r service ceiling from an average of 22 kft. To 28kft in the E and F models . - I/ve been chasing this trail during my search for the =93Right=94 Commander to buy.- Ive focused on a 680F for a lot of reasons, but mostly it has t he widest range of operating capability, short field, high(er) altitude and still have a modicum of efficiency for its type. (if you can keep your han d off the throttle). - wer --- On Sat, 11/8/08, John Vormbaum wrote: From: John Vormbaum <john(at)vormbaum.com> Subject: Re: Commander-List: Flight Levels magazine - Fall 2008 issue Date: Saturday, November 8, 2008, 1:29 PM Jim, I thought the wing & spar structures were the same on all the Commanders. They're not? I know the turbines are easily a 12,000-lb. wing, but I've been under the illusion that the wing on my 500B is essentially the same thing... /John willis robison wrote: > I think so too. > I was a spectator at a few "ultimate" load tests. One for the A380. I was told that it took 10x the "rated" load before failing. They said they were pleased with the results so I guess it made it past FAA and JAR. > > --- On *Sat, 11/8/08, yourtcfg(at)aol.com //* wrote: > > From: yourtcfg(at)aol.com <yourtcfg(at)aol.com> > Subject: Re: Commander-List: Flight Levels magazine - Fall 2008 issue > To: commander-list(at)matronics.com > Date: Saturday, November 8, 2008, 10:33 AM > > Over designed I think. The same airframe wing structure can carry > as much as 8500 pounds, thought some Commanders are limited to > 6000 gross. The gross weight is determined by the FAA mandated > single engine climb performance. A model 680 has the same power > as a 680E but a 500 pound lower gross. Some 680s were extended to > the "E" wingspan and the gross went up to 7500 pounds. jb > > Which was it and at what HP/gross is the maximum? > > > > > -----Original Message----- > From: willis robison <drwer2(at)yahoo.com> > To: commander-list(at)matronics.com > Sent: Fri, 7 Nov 2008 6:55 pm > Subject: Re: Commander-List: Flight Levels magazine - Fall 2008 issue > > Well, if "ome" has 520 ci then they would produce 2x380x520/435 > 908 hp. Wow, I wonder what the GTOW would be!? > I've always been curious about the wing/loading for these AC. They all have relatively the same wing structure. (longer wingtip > for the 680/560's) yet with bigger engines, the FAA allowed higher > gross weights. Was Aero Design able to argue that the original > design was (under powered) or over designed? Which was it and at > what HP/gross is the maximum? > > > --- On *Fri, 11/7/08, yourtcfg(at)aol.com > />/* wrote: > > From: yourtcfg(at)aol.com <mailto:yourtcfg(at)aol.com> > > > Subject: Re: Commander-List: Flight Levels magazine - Fall > 2008 issue > To: commander-list(at)matronics.com > > Date: Friday, November 7, 2008, 5:12 PM > > Yep, I saw that too. Maybe they should have you proof the > next ome!! jb > > The text says it's powered by "a pair of geared Lycoming > 520-cubic-inch GO-435-C2B engines". > > > > > -----Original Message----- > From: Barry Collman <barry.collman@air-britain.co.uk > barry.collman@air-britain.co.uk>> > To: commander-list(at)matronics.com > > Sent: Fri, 7 Nov 2008 9:08 am > Subject: Commander-List: Flight Levels magazine - Fall 2008 issue > > Hi Guys, > On page 7 of the subject magazine there's a photo of N2621B, a > Commander 520 s/n 133. > The text says it's powered by "a pair of geared Lycoming > 520-cubic-inch GO-435-C2B engines". > Has anyone else spotted the (not deliberate) error? > Best Regards, > Barry > > * > > * > > * > > * > > > > > ------------------------------------------------------------------------ > > * > > * > =0A=0A=0A ________________________________________________________________________________
Date: Nov 09, 2008
TXkgbW9uZXkgaXMgb24gdGhlIDU2MEYNCg0KU2VudCB2aWEgQmxhY2tCZXJyeSBieSBBVCZUDQoN Ci0tLS0tT3JpZ2luYWwgTWVzc2FnZS0tLS0tDQpGcm9tOiB3aWxsaXMgcm9iaXNvbiA8ZHJ3ZXIy QHlhaG9vLmNvbT4NCg0KRGF0ZTogU2F0LCA4IE5vdiAyMDA4IDE3OjA2OjU2IA0KVG86IDxjb21t YW5kZXItbGlzdEBtYXRyb25pY3MuY29tPg0KU3ViamVjdDogUmU6IENvbW1hbmRlci1MaXN0OiBG bGlnaHQgTGV2ZWxzIG1hZ2F6aW5lIC0gRmFsbCAyMDA4IGlzc3VlDQoNCg0KR2VudHMsDQqgDQpU aGUgZm9sbG93aW5nIHdhcyBnbGVhbmVkIGZyb20gdGhlIHByb2R1Y3Rpb24gZGF0YSBvbiB0aGUg Y29tbWFuZGVyIHdlYnNpdGUgYW5kIGZyb20gdGhlIE5BQ0EgYXJjaGl2ZXMuDQqgDQpUaGVyZSBh cHBlYXJzIHRvIGJlIHR3byB2YXJpYW50cyBvZiB0aGUgY29tbWFuZGVyIHdpbmc7IGGgIDQ0kiBh bmQgYSA0OZKgIEJvdGggdmFyaWFudHMgdXNlIHRoZSBOQUNBIDIzMDEyIGFpcmZvaWwgZnJvbSBy b290IHRvIHRpcC6goCBUaGlzIHBhcnRpY3VsYXIgYWlyZm9pbCBpcyBrbm93IGZvciBpdHMgZG9j aWxlIGJlaGF2aW9yIGFuZCB3YXMgd2lkZWx5IHVzZWQgYnkgb3RoZXIgYWlyY3JhZnQuoCBNb3N0 IG5vdGFibHkgdGhlIEJlZWNoIFN0YWdnZXJ3aW5nIHVzZXMgdGhpcyBhaXJmb2lsIGFzIGRvIG90 aGVyIEJlZWNoIEFpcmNyYWZ0LCBidXQgb25seSBpbiB0aGUgb3V0Ym9hcmQgc2VjdGlvbnMgbmVh ciB0aGUgYWlsZXJvbnMuoCBUaGUgQ29tbWFuZGVycyB1c2UgYSBzaW5nbGUgYWlyZm9pbCBmcm9t IHJvb3QgdG8gdGlwLqAgVGhpcyB3YXMgY2hvc2VuIGxpa2VseSBmb3IgaXRzIGVhc2Ugb2YgbWFu dWZhY3R1cmUuoCBGcm9tIGEgbWFudWZhY3R1cmluZyBzdGFuZHBvaW50LCBhZGRpbmcgNZIgdG8g dGhlIHdpbmdzcGFuIGlzIGVhc2llciB0byBkbyBieSBlaXRoZXIgbGVuZ3RoZW5pbmcgdGhlIHRp cHMgb3V0Ym9hcmQgb2YgdGhlIGFpbGVyb25zIG9yIGluY3JlYXNpbmcgdGhlIGVuZ2luZS9uYWNl bGxlIHRydXNzIHNlY3Rpb24uIFRoaXMgY291bGQgbWVhbiBhZGRpbmcganVzdCBvbmUgb3IgdHdv IHJpYiBzZWN0aW9ucw0KoA0KVGhlIDQ5kiB3aW5nIGlzIHRoZSBhcmNoZXR5cGUgYW5kIGlzIGZl YXR1cmVkIG9uIGFsbCB0aGUgcGlzdG9uIHR3aW4gY29tbWFuZGVycyBleGNlcHQgdGhlIHNvLWNh bGxlZCCTc3RyYWlnaHSUIDU2MCBhbmQgNjgwIG1vZGVscy6gIFRoZSA1NjAgd2FzIHByb2R1Y2Vk IGZyb20gMTk1NCB0byAxOTU3IGFuZCB0aGUgNjgwIHJhbiBmcm9tIJI1NSB0byCSNTguDQqgDQpU aGVyZSBpcyBhbHNvIGEgbm90YWJsZSBkaWZmZXJlbmNlIGluIHRoZSBmdWVsIGNhcGFjaXR5IGZv ciB0aGUgNDSSIDU2MCB3aGljaCBoYXMgMTQ1IGdhbHMgY29tcGFyZWQgdG8gdGhlIDUwMHMgd2hp Y2ggaGF2ZSAxNTYgZ2FsbG9ucyBub3JtYWxseS6gIEFsbCB0aGUgTG9uZyByYW5nZSBtb2RlbHMg b2YgNTYwRSwgRiBhbmQgNjgwRiwgTCxQIGhhdmUgMjIzIGdhbGxvbnOgIGFwcGFyZW50bHkgdXNp bmcgYWxsIHRoZSBhdmFpbGFibGUgYmF5cyBpbmJvYXJkIG9mIHRoZSBhaWxlcm9ucy4gDQqgDQpB cyBmb3Igd2VpZ2h0LiBJdCBsb29rcyBsaWtlIHRoZSBlYXJseSBtb2RlbHMgKHJvdW5kIG5hY2Vs bGUpIGhhZCB1c2VmdWxsIGxvYWRzIGFyb3VuZCAyMTAwIGxicyB3aXRoIHZhcmlhdGlvbnMgdHJh ZGluZyB1cCBvciBkb3duIGRlcGVuZGluZyBvbiBIUCBhbmQgU2VydmljZSBjZWlsaW5nLqAgVHdp biBDb21tYW5kZXIgY29ycG9yYXRpb24gaGFzIG1lbnRpb25lZCB0aGF0IHRoZXkgZG9uknQgaGF2 ZSBtb2RlbCB5ZWFycywgcGVyLXNlOyBzbyB0aGlzIGhhcyBhbGxvd2VkIHRoZW0gdG8gbWFrZSBw cm9kdWN0aW9uIHJ1bnMgb2YgYSBwYXJ0aWN1bGFyIHR5cGUgdXNpbmcgdGhlIHNhbWUgcHJvZHVj dGlvbiBzcGFjZS4NCqANCldoZW4gdGhlIFN0cmVhbWxpbmVkIE5hY2VsbCB3YXMgaW50cm9kdWNl ZCwgdGhlcmUgd2FzIGFsc28gYSBub3RhYmxlIGluY3JlYXNlIGluIHVzZWZ1bCBsb2FkLiBUbyBh Ym91dCAyMzAwIKB0byAzMjAwIGxicy6gIFRoaXMgYWxzbyBpbXByb3ZlZCB0aGVpciBzZXJ2aWNl IGNlaWxpbmcgZnJvbSBhbiBhdmVyYWdlIG9mIDIyIGtmdC4gVG8gMjhrZnQgaW4gdGhlIEUgYW5k IEYgbW9kZWxzLg0KoA0KSS92ZSBiZWVuIGNoYXNpbmcgdGhpcyB0cmFpbCBkdXJpbmcgbXkgc2Vh cmNoIGZvciB0aGUgk1JpZ2h0lCBDb21tYW5kZXIgdG8gYnV5LqAgSXZlIGZvY3VzZWQgb24gYSA2 ODBGIGZvciBhIGxvdCBvZiByZWFzb25zLCBidXQgbW9zdGx5IGl0IGhhcyB0aGUgd2lkZXN0IHJh bmdlIG9mIG9wZXJhdGluZyBjYXBhYmlsaXR5LCBzaG9ydCBmaWVsZCwgaGlnaChlcikgYWx0aXR1 ZGUgYW5kIHN0aWxsIGhhdmUgYSBtb2RpY3VtIG9mIGVmZmljaWVuY3kgZm9yIGl0cyB0eXBlLiAo aWYgeW91IGNhbiBrZWVwIHlvdXIgaGFuZCBvZmYgdGhlIHRocm90dGxlKS4gDQqgDQp3ZXINCg0K DQotLS0gT24gU2F0LCAxMS84LzA4LCBKb2huIFZvcm1iYXVtIDxqb2huQHZvcm1iYXVtLmNvbT4g d3JvdGU6DQoNCkZyb206IEpvaG4gVm9ybWJhdW0gPGpvaG5Adm9ybWJhdW0uY29tPg0KU3ViamVj dDogUmU6IENvbW1hbmRlci1MaXN0OiBGbGlnaHQgTGV2ZWxzIG1hZ2F6aW5lIC0gRmFsbCAyMDA4 IGlzc3VlDQpUbzogY29tbWFuZGVyLWxpc3RAbWF0cm9uaWNzLmNvbQ0KRGF0ZTogU2F0dXJkYXks IE5vdmVtYmVyIDgsIDIwMDgsIDE6MjkgUE0NCg0KLS0+IENvbW1hbmRlci1MaXN0IG1lc3NhZ2Ug cG9zdGVkIGJ5OiBKb2huIFZvcm1iYXVtIDxqb2huQHZvcm1iYXVtLmNvbT4NCg0KSmltLA0KDQpJ IHRob3VnaHQgdGhlIHdpbmcgJiBzcGFyIHN0cnVjdHVyZXMgd2VyZSB0aGUgc2FtZSBvbiBhbGwg dGhlIENvbW1hbmRlcnMuDQpUaGV5J3JlIG5vdD8gSSBrbm93IHRoZSB0dXJiaW5lcyBhcmUgZWFz aWx5IGEgMTIsMDAwLWxiLiB3aW5nLCBidXQgSSd2ZQ0KYmVlbiB1bmRlciB0aGUgaWxsdXNpb24g dGhhdCB0aGUgd2luZyBvbiBteSA1MDBCIGlzIGVzc2VudGlhbGx5IHRoZSBzYW1lDQp0aGluZy4u Lg0KDQovSm9obg0KDQp3aWxsaXMgcm9iaXNvbiB3cm90ZToNCj4gSSB0aGluayBzbyB0b28uDQo+ ICBJIHdhcyBhIHNwZWN0YXRvciBhdCBhIGZldyAidWx0aW1hdGUiIGxvYWQgdGVzdHMuICBPbmUg Zm9yIHRoZQ0KQTM4MC4gIEkgd2FzIHRvbGQgdGhhdCBpdCB0b29rIDEweCB0aGUgInJhdGVkIiBs b2FkIGJlZm9yZSBmYWlsaW5nLiANClRoZXkgc2FpZCB0aGV5IHdlcmUgcGxlYXNlZCB3aXRoIHRo ZSByZXN1bHRzIHNvIEkgZ3Vlc3MgaXQgbWFkZSBpdCBwYXN0IEZBQSBhbmQNCkpBUi4NCj4gDQo+ IC0tLSBPbiAqU2F0LCAxMS84LzA4LCB5b3VydGNmZ0Bhb2wuY29tIC88eW91cnRjZmdAYW9sLmNv bT4vKiB3cm90ZToNCj4gDQo+ICAgICBGcm9tOiB5b3VydGNmZ0Bhb2wuY29tIDx5b3VydGNmZ0Bh b2wuY29tPg0KPiAgICAgU3ViamVjdDogUmU6IENvbW1hbmRlci1MaXN0OiBGbGlnaHQgTGV2ZWxz IG1hZ2F6aW5lIC0gRmFsbCAyMDA4IGlzc3VlDQo+ICAgICBUbzogY29tbWFuZGVyLWxpc3RAbWF0 cm9uaWNzLmNvbQ0KPiAgICAgRGF0ZTogU2F0dXJkYXksIE5vdmVtYmVyIDgsIDIwMDgsIDEwOjMz IEFNDQo+IA0KPiAgICAgT3ZlciBkZXNpZ25lZCBJIHRoaW5rLiAgVGhlIHNhbWUgYWlyZnJhbWUg d2luZyBzdHJ1Y3R1cmUgY2FuIGNhcnJ5DQo+ICAgICBhcyBtdWNoIGFzIDg1MDAgcG91bmRzLCB0 aG91Z2h0IHNvbWUgQ29tbWFuZGVycyBhcmUgbGltaXRlZCB0bw0KPiAgICAgNjAwMCBncm9zcy4g IFRoZSBncm9zcyB3ZWlnaHQgaXMgZGV0ZXJtaW5lZCBieSB0aGUgRkFBIG1hbmRhdGVkDQo+ICAg ICBzaW5nbGUgZW5naW5lIGNsaW1iIHBlcmZvcm1hbmNlLiAgQSBtb2RlbCA2ODAgaGFzIHRoZSBz YW1lIHBvd2VyDQo+ICAgICBhcyBhIDY4MEUgYnV0IGEgNTAwIHBvdW5kIGxvd2VyIGdyb3NzLiAg U29tZSA2ODBzIHdlcmUgZXh0ZW5kZWQgdG8NCj4gICAgIHRoZSAiRSIgd2luZ3NwYW4gYW5kIHRo ZSBncm9zcyB3ZW50IHVwIHRvIDc1MDAgcG91bmRzLiAgamINCj4gDQo+ICAgICAgICAgV2hpY2gg d2FzIGl0IGFuZCBhdCB3aGF0IEhQL2dyb3NzIGlzIHRoZSBtYXhpbXVtPw0KPiANCj4gDQo+IA0K PiANCj4gICAgIC0tLS0tT3JpZ2luYWwgTWVzc2FnZS0tLS0tDQo+ICAgICBGcm9tOiB3aWxsaXMg cm9iaXNvbiA8ZHJ3ZXIyQHlhaG9vLmNvbT4NCj4gICAgIFRvOiBjb21tYW5kZXItbGlzdEBtYXRy b25pY3MuY29tDQo+ICAgICBTZW50OiBGcmksIDcgTm92IDIwMDggNjo1NSBwbQ0KPiAgICAgU3Vi amVjdDogUmU6IENvbW1hbmRlci1MaXN0OiBGbGlnaHQgTGV2ZWxzIG1hZ2F6aW5lIC0gRmFsbCAy MDA4IGlzc3VlDQo+IA0KPiAgICAgV2VsbCwgaWYgIm9tZSIgaGFzIDUyMCBjaSB0aGVuIHRoZXkg d291bGQgcHJvZHVjZQ0KMngzODB4NTIwLzQzNSA9DQo+ICAgICA5MDggaHAuICBXb3csIEkgd29u ZGVyIHdoYXQgdGhlIEdUT1cgd291bGQgYmUhPw0KPiAgICAgICAgICBJJ3ZlIGFsd2F5cyBiZWVu IGN1cmlvdXMgYWJvdXQgdGhlIHdpbmcvbG9hZGluZyBmb3IgdGhlc2UgQUMuDQogICAgVGhleSBh bGwgaGF2ZSByZWxhdGl2ZWx5IHRoZSBzYW1lIHdpbmcgc3RydWN0dXJlLiAobG9uZ2VyIHdpbmd0 aXANCj4gICAgIGZvciB0aGUgNjgwLzU2MCdzKSB5ZXQgd2l0aCBiaWdnZXIgZW5naW5lcywgdGhl IEZBQSBhbGxvd2VkIGhpZ2hlcg0KPiAgICAgZ3Jvc3Mgd2VpZ2h0cy4gICBXYXMgQWVybyBEZXNp Z24gYWJsZSB0byBhcmd1ZSB0aGF0IHRoZSBvcmlnaW5hbA0KPiAgICAgZGVzaWduIHdhcyAodW5k ZXIgcG93ZXJlZCkgb3Igb3ZlciBkZXNpZ25lZD8gIFdoaWNoIHdhcyBpdCBhbmQgYXQNCj4gICAg IHdoYXQgSFAvZ3Jvc3MgaXMgdGhlIG1heGltdW0/DQo+ICAgICAgICAgICAgICAgIA0KPiANCj4g ICAgIC0tLSBPbiAqRnJpLCAxMS83LzA4LCB5b3VydGNmZ0Bhb2wuY29tIDxtYWlsdG86eW91cnRj ZmdAYW9sLmNvbT4NCj4gICAgIC88eW91cnRjZmdAYW9sLmNvbSA8bWFpbHRvOnlvdXJ0Y2ZnQGFv bC5jb20+Pi8qIHdyb3RlOg0KPiANCj4gICAgICAgICBGcm9tOiB5b3VydGNmZ0Bhb2wuY29tIDxt YWlsdG86eW91cnRjZmdAYW9sLmNvbT4NCj4gICAgICAgICA8eW91cnRjZmdAYW9sLmNvbSA8bWFp bHRvOnlvdXJ0Y2ZnQGFvbC5jb20+Pg0KPiAgICAgICAgIFN1YmplY3Q6IFJlOiBDb21tYW5kZXIt TGlzdDogRmxpZ2h0IExldmVscyBtYWdhemluZSAtIEZhbGwNCj4gICAgICAgICAyMDA4IGlzc3Vl DQo+ICAgICAgICAgVG86IGNvbW1hbmRlci1saXN0QG1hdHJvbmljcy5jb20NCj4gICAgICAgICA8 bWFpbHRvOmNvbW1hbmRlci1saXN0QG1hdHJvbmljcy5jb20+DQo+ICAgICAgICAgRGF0ZTogRnJp ZGF5LCBOb3ZlbWJlciA3LCAyMDA4LCA1OjEyIFBNDQo+IA0KPiAgICAgICAgIFllcCwgSSBzYXcg dGhhdCB0b28uICBNYXliZSB0aGV5IHNob3VsZCBoYXZlIHlvdSBwcm9vZiB0aGUNCj4gICAgICAg ICBuZXh0IG9tZSEhICBqYg0KPiANCj4gICAgICAgICAgICAgVGhlIHRleHQgc2F5cyBpdCdzIHBv d2VyZWQgYnkgImEgcGFpciBvZiBnZWFyZWQNCkx5Y29taW5nDQo+ICAgICAgICAgICAgIDUyMC1j dWJpYy1pbmNoIEdPLTQzNS1DMkIgZW5naW5lcyIuDQo+IA0KPiANCj4gDQo+IA0KPiAgICAgICAg IC0tLS0tT3JpZ2luYWwgTWVzc2FnZS0tLS0tDQo+ICAgICAgICAgRnJvbTogQmFycnkgQ29sbG1h biA8YmFycnkuY29sbG1hbkBhaXItYnJpdGFpbi5jby51aw0KPiAgICAgICAgIDxtYWlsdG86YmFy cnkuY29sbG1hbkBhaXItYnJpdGFpbi5jby51az4+DQo+ICAgICAgICAgVG86IGNvbW1hbmRlci1s aXN0QG1hdHJvbmljcy5jb20NCj4gICAgICAgICA8bWFpbHRvOmNvbW1hbmRlci1saXN0QG1hdHJv bmljcy5jb20+DQo+ICAgICAgICAgU2VudDogRnJpLCA3IE5vdiAyMDA4IDk6MDggYW0NCj4gICAg ICAgICBTdWJqZWN0OiBDb21tYW5kZXItTGlzdDogRmxpZ2h0IExldmVscyBtYWdhemluZSAtIEZh bGwgMjAwOCBpc3N1ZQ0KPiANCj4gICAgICAgICBIaSBHdXlzLA0KPiAgICAgICAgICAgICAgICAg IE9uIHBhZ2UgNyBvZiB0aGUgc3ViamVjdCBtYWdhemluZSB0aGVyZSdzIGEgcGhvdG8gb2YNCk4y NjIxQiwgYQ0KPiAgICAgICAgIENvbW1hbmRlciA1MjAgcy9uIDEzMy4NCj4gICAgICAgICAgICAg ICAgICBUaGUgdGV4dCBzYXlzIGl0J3MgcG93ZXJlZCBieSAiYSBwYWlyIG9mIGdlYXJlZA0KTHlj b21pbmcNCj4gICAgICAgICA1MjAtY3ViaWMtaW5jaCBHTy00MzUtQzJCIGVuZ2luZXMiLg0KPiAg ICAgICAgICAgICAgICAgIEhhcyBhbnlvbmUgZWxzZSBzcG90dGVkIHRoZSAobm90IGRlbGliZXJh dGUpIGVycm9yPw0KPiAgICAgICAgICAgICAgICAgIEJlc3QgUmVnYXJkcywNCj4gICAgICAgICBC YXJyeQ0KPiANCj4gICAgICAgICAqDQo+IA0KPiAgICAgICAgICoNCj4gDQo+ICAgICAgICAgKg0K PiANCj4gICAgICAgICAqDQo+IA0KPiANCj4gICAgID4NCj4gICAgDQotLS0tLS0tLS0tLS0tLS0t LS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0N Cj4gDQo+ICAgICAqDQo+IA0KPiAgICAgKg0KPiANCg0KDQoNCg0KCgoKDQo ________________________________________________________________________________
Date: Nov 08, 2008
HI JOHN... Nope, when Commander built the first 690 series airplane, the used a completely different wing structure.? You can easily tell the change by looking at the airplane from the nose,?the higher gross turbines have a short center section that extends straight out?from the cabin, then the dihedral.? It is in effect a "gull wing". ? Lower gross airplanes, like yours and mine, have the dihedral at the center of the wing.? The reason for the change was to move the turbines out further from the cabin and allow for larger diameter propellers.? jb ? I thought the wing & spar structures were the same on all the Commanders. They're not? I know the turbines are easily a 12,000-lb. wing, but I've been under the illusion that the wing on my 500B is essentially the same thing...? ? -----Original Message----- From: John Vormbaum <john(at)vormbaum.com> Sent: Sat, 8 Nov 2008 1:29 pm Subject: Re: Commander-List: Flight Levels magazine - Fall 2008 issue ? Jim,? ? I thought the wing & spar structures were the same on all the Commanders. They're not? I know the turbines are easily a 12,000-lb. wing, but I've been under the illusion that the wing on my 500B is essentially the same thing...? ? /John? ? willis robison wrote:? > I think so too.? > > I was a spectator at a few "ultimate" load tests. One for the > A380. I was told that it took 10x the "rated" load before failing. > They said they were pleased with the results so I guess it made it > past FAA and JAR.? >? > --- On *Sat, 11/8/08, yourtcfg(at)aol.com //* wrote:? >? > From: yourtcfg(at)aol.com <yourtcfg(at)aol.com>? > Subject: Re: Commander-List: Flight Levels magazine - Fall 2008 issue? > To: commander-list(at)matronics.com? > Date: Saturday, November 8, 2008, 10:33 AM? >? > Over designed I think. The same airframe wing structure can carry? > as much as 8500 pounds, thought some Commanders are limited to? > 6000 gross. The gross weight is determined by the FAA mandated? > single engine climb performance. A model 680 has the same power? > as a 680E but a 500 pound lower gross. Some 680s were extended to? > the "E" wingspan and the gross went up to 7500 pounds. jb? >? > Which was it and at what HP/gross is the maximum?? >? >? >? >? > -----Original Message-----? > From: willis robison <drwer2(at)yahoo.com>? > To: commander-list(at)matronics.com? > Sent: Fri, 7 Nov 2008 6:55 pm? > Subject: Re: Commander-List: Flight Levels magazine - Fall 2008 issue? >? > Well, if "ome" has 520 ci then they would produce 2x380x520/435 =? > 908 hp. Wow, I wonder what the GTOW would be!?? > > I've always been curious about the wing/loading for these AC. > They all have relatively the same wing structure. (longer wingtip? > for the 680/560's) yet with bigger engines, the FAA allowed higher? > gross weights. Was Aero Design able to argue that the original? > design was (under powered) or over designed? Which was it and at? > what HP/gross is the maximum?? > > > >? >? > --- On *Fri, 11/7/08, yourtcfg(at)aol.com ? > />/* wrote:? >? > From: yourtcfg(at)aol.com <mailto:yourtcfg(at)aol.com>? > >? > Subject: Re: Commander-List: Flight Levels magazine - Fall? > 2008 issue? > To: commander-list(at)matronics.com? > ? > Date: Friday, November 7, 2008, 5:12 PM? >? > Yep, I saw that too. Maybe they should have you proof the? > next ome!! jb? >? > The text says it's powered by "a pair of geared Lycoming? > 520-cubic-inch GO-435-C2B engines".? >? >? >? >? > -----Original Message-----? > From: Barry Collman <barry.collman@air-britain.co.uk? > barry.collman@air-britain.co.uk>>? > To: commander-list(at)matronics.com? > ? > Sent: Fri, 7 Nov 2008 9:08 am? > Subject: Commander-List: Flight Levels magazine - Fall 2008 issue? >? > Hi Guys,? > > On page 7 of the subject magazine there's a photo of N2621B, a? > Commander 520 s/n 133.? > > The text says it's powered by "a pair of geared Lycoming? > 520-cubic-inch GO-435-C2B engines".? > > Has anyone else spotted the (not deliberate) error?? > > Best Regards,? > Barry? >? > *? >? > *? >? > *? >? > *? >? >? > >? > ------------------------------------------------------------------------? >? > *? >? > *? >? ? ? ? ________________________________________________________________________________
Date: Nov 08, 2008
I'll definitely take a close look the next time I see a 500-series and a 690-series airplane side by side! Thanks for the clarification & education on the particulars of Commander wings. /J yourtcfg(at)aol.com wrote: > HI JOHN... > Nope, when Commander built the first 690 series airplane, the used a > completely different wing structure. You can easily tell the change > by looking at the airplane from the nose, the higher gross turbines > have a short center section that extends straight out from the cabin, > then the dihedral. It is in effect a "gull wing". Lower gross > airplanes, like yours and mine, have the dihedral at the center of the > wing. The reason for the change was to move the turbines out further > from the cabin and allow for larger diameter propellers. jb > > > I thought the wing & spar structures were the same on all the > Commanders. They're not? I know the turbines are easily a > 12,000-lb. wing, but I've been under the illusion that the wing on > my 500B is essentially the same thing... > > > > -----Original Message----- > From: John Vormbaum <john(at)vormbaum.com> > To: commander-list(at)matronics.com > Sent: Sat, 8 Nov 2008 1:29 pm > Subject: Re: Commander-List: Flight Levels magazine - Fall 2008 issue > > > > > Jim, > > I thought the wing & spar structures were the same on all the > Commanders. They're not? I know the turbines are easily a 12,000-lb. > wing, but I've been under the illusion that the wing on my 500B is > essentially the same thing... > > /John > > willis robison wrote: > > I think so too. > > > I was a spectator at a few "ultimate" load tests. One for the > > A380. I was told that it took 10x the "rated" load before failing. > > They said they were pleased with the results so I guess it made it > > past FAA and JAR. > > > > --- On *Sat, 11/8/08, yourtcfg(at)aol.com > />/* wrote: > > > > From: yourtcfg(at)aol.com <mailto:yourtcfg(at)aol.com> <yourtcfg(at)aol.com > > > > Subject: Re: Commander-List: Flight Levels magazine - Fall 2008 issue > > To: commander-list(at)matronics.com > > Date: Saturday, November 8, 2008, 10:33 AM > > > > Over designed I think. The same airframe wing structure can carry > > as much as 8500 pounds, thought some Commanders are limited to > > 6000 gross. The gross weight is determined by the FAA mandated > > single engine climb performance. A model 680 has the same power > > as a 680E but a 500 pound lower gross. Some 680s were extended to > > the "E" wingspan and the gross went up to 7500 pounds. jb > > > > Which was it and at what HP/gross is the maximum? > > > > > > > > > > -----Original Message----- > > From: willis robison <drwer2(at)yahoo.com <mailto:drwer2(at)yahoo.com>> > > To: commander-list(at)matronics.com > > Sent: Fri, 7 Nov 2008 6:55 pm > > Subject: Re: Commander-List: Flight Levels magazine - Fall 2008 issue > > > > Well, if "ome" has 520 ci then they would produce 2x380x520/435 = > > 908 hp. Wow, I wonder what the GTOW would be!? > > > I've always been curious about the wing/loading for these AC. > > They all have relatively the same wing structure. (longer wingtip > > for the 680/560's) yet with bigger engines, the FAA allowed higher > > gross weights. Was Aero Design able to argue that the original > > design was (under powered) or over designed? Which was it and at > > what HP/gross is the maximum? > > > > > > > > > --- On *Fri, 11/7/08, yourtcfg(at)aol.com > > > > / > >/* wrote: > > > > From: yourtcfg(at)aol.com <mailto:yourtcfg(at)aol.com> > > > > >> > > Subject: Re: Commander-List: Flight Levels magazine - Fall > > 2008 issue > > To: commander-list(at)matronics.com > > > > > Date: Friday, November 7, 2008, 5:12 PM > > > > Yep, I saw that too. Maybe they should have you proof the > > next ome!! jb > > > > The text says it's powered by "a pair of geared Lycoming > > 520-cubic-inch GO-435-C2B engines". > > > > > > > > > > -----Original Message----- > > From: Barry Collman <barry.collman@air-britain.co.uk > barry.collman@air-britain.co.uk> > > barry.collman@air-britain.co.uk > barry.collman@air-britain.co.uk?>>> > > To: commander-list(at)matronics.com > > > > > Sent: Fri, 7 Nov 2008 9:08 am > > Subject: Commander-List: Flight Levels magazine - Fall 2008 issue > > > > Hi Guys, > > > On page 7 of the subject magazine there's a photo of N2621B, a > > Commander 520 s/n 133. > > > The text says it's powered by "a pair of geared Lycoming > > 520-cubic-inch GO-435-C2B engines". > > > Has anyone else spotted the (not deliberate) error? > > > Best Regards, > > Barry > > > > * > > > > * > > > > * > > > > * > > > > > > > > > > ------------------------------------------------------------------------ > > > > * > > > > * > > > > > > * > > * ________________________________________________________________________________
Date: Nov 08, 2008
I didn't know that. I'll be looking out for that too. -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of John Vormbaum Sent: Saturday, November 08, 2008 8:35 PM Subject: Re: Commander-List: Flight Levels magazine - Fall 2008 issue I'll definitely take a close look the next time I see a 500-series and a 690-series airplane side by side! Thanks for the clarification & education on the particulars of Commander wings. /J yourtcfg(at)aol.com wrote: > HI JOHN... > Nope, when Commander built the first 690 series airplane, the used a > completely different wing structure. You can easily tell the change > by looking at the airplane from the nose, the higher gross turbines > have a short center section that extends straight out from the cabin, > then the dihedral. It is in effect a "gull wing". Lower gross > airplanes, like yours and mine, have the dihedral at the center of the > wing. The reason for the change was to move the turbines out further > from the cabin and allow for larger diameter propellers. jb > > > I thought the wing & spar structures were the same on all the > Commanders. They're not? I know the turbines are easily a > 12,000-lb. wing, but I've been under the illusion that the wing on > my 500B is essentially the same thing... > > > > -----Original Message----- > From: John Vormbaum <john(at)vormbaum.com> > To: commander-list(at)matronics.com > Sent: Sat, 8 Nov 2008 1:29 pm > Subject: Re: Commander-List: Flight Levels magazine - Fall 2008 issue > > > > > Jim, > > I thought the wing & spar structures were the same on all the > Commanders. They're not? I know the turbines are easily a 12,000-lb. > wing, but I've been under the illusion that the wing on my 500B is > essentially the same thing... > > /John > > willis robison wrote: > > I think so too. > > > I was a spectator at a few "ultimate" load tests. One for the > > A380. I was told that it took 10x the "rated" load before failing. > > They said they were pleased with the results so I guess it made it > > past FAA and JAR. > > > > --- On *Sat, 11/8/08, yourtcfg(at)aol.com > />/* wrote: > > > > From: yourtcfg(at)aol.com <mailto:yourtcfg(at)aol.com> <yourtcfg(at)aol.com > > > > Subject: Re: Commander-List: Flight Levels magazine - Fall 2008 > > issue > > To: commander-list(at)matronics.com > > > > Date: Saturday, November 8, 2008, 10:33 AM > > > > Over designed I think. The same airframe wing structure can carry as > > much as 8500 pounds, thought some Commanders are limited to 6000 > > gross. The gross weight is determined by the FAA mandated single > > engine climb performance. A model 680 has the same power as a 680E > > but a 500 pound lower gross. Some 680s were extended to the "E" > > wingspan and the gross went up to 7500 pounds. jb > > > > Which was it and at what HP/gross is the maximum? > > > > > > > > > > -----Original Message----- > > From: willis robison <drwer2(at)yahoo.com <mailto:drwer2(at)yahoo.com>> > > To: commander-list(at)matronics.com > > > > Sent: Fri, 7 Nov 2008 6:55 pm > > Subject: Re: Commander-List: Flight Levels magazine - Fall 2008 > > issue > > > > Well, if "ome" has 520 ci then they would produce 2x380x520/435 > > 908 hp. Wow, I wonder what the GTOW would be!? > > > I've always been curious about the wing/loading for these AC. > > They all have relatively the same wing structure. (longer wingtip > > for the 680/560's) yet with bigger engines, the FAA allowed higher > > gross weights. Was Aero Design able to argue that the original > > design was (under powered) or over designed? Which was it and at > > what HP/gross is the maximum? > > > > > > > > > --- On *Fri, 11/7/08, yourtcfg(at)aol.com > > > > / > >/* wrote: > > > > From: yourtcfg(at)aol.com <mailto:yourtcfg(at)aol.com> > > > > >> > > Subject: Re: Commander-List: Flight Levels magazine - Fall > > 2008 issue > > To: commander-list(at)matronics.com > > > > > > > Date: Friday, November 7, 2008, 5:12 PM > > > > Yep, I saw that too. Maybe they should have you proof the next ome!! > > jb > > > > The text says it's powered by "a pair of geared Lycoming > > 520-cubic-inch GO-435-C2B engines". > > > > > > > > > > -----Original Message----- > > From: Barry Collman <barry.collman@air-britain.co.uk > barry.collman@air-britain.co.uk> > > barry.collman@air-britain.co.uk > barry.collman@air-britain.co.uk?>>> > > To: commander-list(at)matronics.com > > > > > > > Sent: Fri, 7 Nov 2008 9:08 am > > Subject: Commander-List: Flight Levels magazine - Fall 2008 issue > > > > Hi Guys, > > > On page 7 of the subject magazine there's a photo of N2621B, a > > Commander 520 s/n 133. > > > The text says it's powered by "a pair of geared Lycoming > > 520-cubic-inch GO-435-C2B engines". > > > Has anyone else spotted the (not deliberate) error? > > > Best Regards, > > Barry > > > > * > > > > * > > > > * > > > > * > > > > > > > > > > ---------------------------------------------------------------------- > -- > > > > * > > > > * > > > > > > * > > * ________________________________________________________________________________
From: "Barry Collman" <barry.collman@air-britain.co.uk>
Date: Nov 09, 2008
Hi All, A factory document in my collection titled "Aircraft Evolution", tells us the following about the Commander wings: Wing Drawing 5170000 - Models L-3805, 520 & 560. Wing Drawing 5170023 - Models 560A & 680. With the 32-inch wing tip extension - Models 560E, 680E, 720 & 500. Wing Drawing 5170045 - Models 500A, 500B, 680F, 680F(P) & 560F. Modified 5170045 for "8500lb" Wing - Models 500U & 500S. (Hence Certified in Utility & Standard category). Removed 32-inch wing tip extension - Models 680T, 680V, 680W & 681. Added 30 inches at wing center section - Models 690, 685, 690A & 690B. Added 30-inch wing tip extension - Models 690C, 695, 690D, 695A & 695B. I think the basic wing structure remained the same, the factory "simply" adding extensions either inboard or outboard. Capt. JimBob is, of course, right. The 15" inboard extension each side for the 685 and from the early 690 series did not have any dihedral. Very Best Regards, Barry ----- Original Message ----- From: yourtcfg(at)aol.com To: commander-list(at)matronics.com Sent: Sunday, November 09, 2008 3:04 AM Subject: Re: Commander-List: Flight Levels magazine - Fall 2008 issue HI JOHN... Nope, when Commander built the first 690 series airplane, the used a completely different wing structure. You can easily tell the change by looking at the airplane from the nose, the higher gross turbines have a short center section that extends straight out from the cabin, then the dihedral. It is in effect a "gull wing". Lower gross airplanes, like yours and mine, have the dihedral at the center of the wing. The reason for the change was to move the turbines out further from the cabin and allow for larger diameter propellers. jb I thought the wing & spar structures were the same on all the Commanders. They're not? I know the turbines are easily a 12,000-lb. wing, but I've been under the illusion that the wing on my 500B is essentially the same thing... -----Original Message----- From: John Vormbaum <john(at)vormbaum.com> To: commander-list(at)matronics.com Sent: Sat, 8 Nov 2008 1:29 pm Subject: Re: Commander-List: Flight Levels magazine - Fall 2008 issue Jim, I thought the wing & spar structures were the same on all the Commanders. They're not? I know the turbines are easily a 12,000-lb. wing, but I've been under the illusion that the wing on my 500B is essentially the same thing... /John willis robison wrote: > I think so too. > > I was a spectator at a few "ultimate" load tests. One for the > A380. I was told that it took 10x the "rated" load before failing. > They said they were pleased with the results so I guess it made it > past FAA and JAR. > > --- On *Sat, 11/8/08, yourtcfg(at)aol.com //* wrote: > > From: yourtcfg(at)aol.com <yourtcfg(at)aol.com> > Subject: Re: Commander-List: Flight Levels magazine - Fall 2008 issue > To: commander-list(at)matronics.com > Date: Saturday, November 8, 2008, 10:33 AM > > Over designed I think. The same airframe wing structure can carry > as much as 8500 pounds, thought some Commanders are limited to > 6000 gross. The gross weight is determined by the FAA mandated > single engine climb performance. A model 680 has the same power > as a 680E but a 500 pound lower gross. Some 680s were extended to > the "E" wingspan and the gross went up to 7500 pounds. jb > > Which was it and at what HP/gross is the maximum? > > > > > -----Original Message----- > From: willis robison <drwer2(at)yahoo.com> > To: commander-list(at)matronics.com > Sent: Fri, 7 Nov 2008 6:55 pm > Subject: Re: Commander-List: Flight Levels magazine - Fall 2008 issue > > Well, if "ome" has 520 ci then they would produce 2x380x520/435 = > 908 hp. Wow, I wonder what the GTOW would be!? > > I've always been curious about the wing/loading for these AC. > They all have relatively the same wing structure. (longer wingtip > for the 680/560's) yet with bigger engines, the FAA allowed higher > gross weights. Was Aero Design able to argue that the original > design was (under powered) or over designed? Which was it and at > what HP/gross is the maximum? > > > > > > --- On *Fri, 11/7/08, yourtcfg(at)aol.com > />/* wrote: > > From: yourtcfg(at)aol.com <mailto:yourtcfg(at)aol.com> > > > Subject: Re: Commander-List: Flight Levels magazine - Fall > 2008 issue > To: commander-list(at)matronics.com > > Date: Friday, November 7, 2008, 5:12 PM > > Yep, I saw that too. Maybe they should have you proof the > next ome!! jb > > The text says it's powered by "a pair of geared Lycoming > 520-cubic-inch GO-435-C2B engines". > > > > > -----Original Message----- > From: Barry Collman <barry.collman@air-britain.co.uk > barry.collman@air-britain.co.uk>> > To: commander-list(at)matronics.com > > Sent: Fri, 7 Nov 2008 9:08 am > Subject: Commander-List: Flight Levels magazine - Fall 2008 issue > > Hi Guys, > > On page 7 of the subject magazine there's a photo of N2621B, a > Commander 520 s/n 133. > > The text says it's powered by "a pair of geared Lycoming > 520-cubic-inch GO-435-C2B engines". > > Has anyone else spotted the (not deliberate) error? > > Best Regards, > Barry > > * > > * > > * > > * > > > > > ------------------------------------------------------------------------ > > * > > * > ________________________________________________________________________________
Date: Nov 09, 2008
WER, Barry this morning has added some drawing number detail to the wing history. I 'know' enough to perhaps comment, but not so much that I might not get it completely right..... So hopefully somebody will correct me where I'm in error..... Because of early problems with spars cracking caps the factory took different approaches to effecting a repair. Some of this I believe is also partly responsible for some changes in gross. The 500 series is a good case study. Our 500B has external heavy aluminum spar straps. They look like leaf springs. We have a lower gross than the 500U and 500S, which has longer internal strapping of the cap in stainless steel. The 'fix' created its own problem of galvanic corrosion between dissimilar metals, which remains an issue to this day. So we have a lower gross, but don't have the corrosion problem of the models with the higher gross. (The 500B is better looking too, in a full-figured kind of way!) Somebody correct me where I'm wrong. (And on this list, I can't imagine not being corrected if anyone thinks I'm wrong!) The wings are beautiful in a way books and figures can't convey. Take a look at the twist in the wing on its way outboard. My Dad spent a lot of time is mainly 680E's all over the world. He loved them, but I believe he thought the 680F the best of breed. Ok, now to see if I can get the bulldozer fixed. Sigh........ Steve ----- Original Message ----- From: willis robison To: commander-list(at)matronics.com Sent: Saturday, November 08, 2008 8:06 PM Subject: Re: Commander-List: Flight Levels magazine - Fall 2008 issue Gents, The following was gleaned from the production data on the commander website and from the NACA archives. There appears to be two variants of the commander wing; a 44=92 and a 49=92 Both variants use the NACA 23012 airfoil from root to tip. This particular airfoil is know for its docile behavior and was widely used by other aircraft. Most notably the Beech Staggerwing uses this airfoil as do other Beech Aircraft, but only in the outboard sections near the ailerons. The Commanders use a single airfoil from root to tip. This was chosen likely for its ease of manufacture. From a manufacturing standpoint, adding 5=92 to the wingspan is easier to do by either lengthening the tips outboard of the ailerons or increasing the engine/nacelle truss section. This could mean adding just one or two rib sections The 49=92 wing is the archetype and is featured on all the piston twin commanders except the so-called =93straight=94 560 and 680 models. The 560 was produced from 1954 to 1957 and the 680 ran from =9255 to =9258. There is also a notable difference in the fuel capacity for the 44=92 560 which has 145 gals compared to the 500s which have 156 gallons normally. All the Long range models of 560E, F and 680F, L,P have 223 gallons apparently using all the available bays inboard of the ailerons. As for weight. It looks like the early models (round nacelle) had usefull loads around 2100 lbs with variations trading up or down depending on HP and Service ceiling. Twin Commander corporation has mentioned that they don=92t have model years, per-se; so this has allowed them to make production runs of a particular type using the same production space. When the Streamlined Nacell was introduced, there was also a notable increase in useful load. To about 2300 to 3200 lbs. This also improved their service ceiling from an average of 22 kft. To 28kft in the E and F models. I/ve been chasing this trail during my search for the =93Right=94 Commander to buy. Ive focused on a 680F for a lot of reasons, but mostly it has the widest range of operating capability, short field, high(er) altitude and still have a modicum of efficiency for its type. (if you can keep your hand off the throttle). wer --- On Sat, 11/8/08, John Vormbaum wrote: From: John Vormbaum <john(at)vormbaum.com> Subject: Re: Commander-List: Flight Levels magazine - Fall 2008 issue To: commander-list(at)matronics.com Date: Saturday, November 8, 2008, 1:29 PM Jim, I thought the wing & spar structures were the same on all the Commanders. They're not? I know the turbines are easily a 12,000-lb. wing, but I've been under the illusion that the wing on my 500B is essentially the same thing... /John willis robison wrote: > I think so too. > I was a spectator at a few "ultimate" load tests. One for the A380. I was told that it took 10x the "rated" load before failing. They said they were pleased with the results so I guess it made it past FAA and JAR. > > --- On *Sat, 11/8/08, yourtcfg(at)aol.com //* wrote: > > From: yourtcfg(at)aol.com <yourtcfg(at)aol.com> > Subject: Re: Commander-List: Flight Levels magazine - Fall 2008 issue > To: commander-list(at)matronics.com > Date: Saturday, November 8, 2008, 10:33 AM > > Over designed I think. The same airframe wing structure can carry > as much as 8500 pounds, thought some Commanders are limited to > 6000 gross. The gross weight is determined by the FAA mandated > single engine climb performance. A model 680 has the same power > as a 680E but a 500 pound lower gross. Some 680s were extended to > the "E" wingspan and the gross went up to 7500 pounds. jb > > Which was it and at what HP/gross is the maximum? > > > > > -----Original Message----- > From: willis robison <drwer2(at)yahoo.com> > To: commander-list(at)matronics.com > Sent: Fri, 7 Nov 2008 6:55 pm > Subject: Re: Commander-List: Flight Levels magazine - Fall 2008 issue > > Well, if "ome" has 520 ci then they would produce 2x380x520/435 > 908 hp. Wow, I wonder what the GTOW would be!? > I've always been curious about the wing/loading for these AC. They all have relatively the same wing structure. (longer wingtip > for the 680/560's) yet with bigger engines, the FAA allowed higher > gross weights. Was Aero Design able to argue that the original > design was (under powered) or over designed? Which was it and at > what HP/gross is the maximum? > > > --- On *Fri, 11/7/08, yourtcfg(at)aol.com > />/* wrote: > > From: yourtcfg(at)aol.com <mailto:yourtcfg(at)aol.com> > > > Subject: Re: Commander-List: Flight Levels magazine - Fall > 2008 issue > To: commander-list(at)matronics.com > > Date: Friday, November 7, 2008, 5:12 PM > > Yep, I saw that too. Maybe they should have you proof the > next ome!! jb > > The text says it's powered by "a pair of geared Lycoming > 520-cubic-inch GO-435-C2B engines". > > > > > -----Original Message----- > From: Barry Collman <barry.collman@air-britain.co.uk > barry.collman@air-britain.co.uk>> > To: commander-list(at)matronics.com > > Sent: Fri, 7 Nov 2008 9:08 am > Subject: Commander-List: Flight Levels magazine - Fall 2008 issue > > Hi Guys, > On page 7 of the subject magazine there's a photo of N2621B, a > Commander 520 s/n 133. > The text says it's powered by "a pair of geared Lycoming > 520-cubic-inch GO-435-C2B engines". > Has anyone else spotted the (not deliberate) error? > Best Regards, > Barry > > * > > * > > * > > * > > > > > ------------------------------------------------------------------------ > > * > > * > ________________________________________________________________________________
Date: Nov 09, 2008
Hi All, The typical wing twist aspect is indeed interesting. Looking at the 560E, for example, the incidence at the wing root was 3 degrees. while that at the tip was minus 3.5 degrees. Looking at the 560A, for example, the incidence at the wing root was 3 degrees. while that at the tip was minus 1 degree. Best Regards, Barry ----- Original Message ----- From: Steve W To: commander-list(at)matronics.com Sent: Sunday, November 09, 2008 12:50 PM Subject: Re: Commander-List: Flight Levels magazine - Fall 2008 issue WER, Barry this morning has added some drawing number detail to the wing history. I 'know' enough to perhaps comment, but not so much that I might not get it completely right..... So hopefully somebody will correct me where I'm in error..... Because of early problems with spars cracking caps the factory took different approaches to effecting a repair. Some of this I believe is also partly responsible for some changes in gross. The 500 series is a good case study. Our 500B has external heavy aluminum spar straps. They look like leaf springs. We have a lower gross than the 500U and 500S, which has longer internal strapping of the cap in stainless steel. The 'fix' created its own problem of galvanic corrosion between dissimilar metals, which remains an issue to this day. So we have a lower gross, but don't have the corrosion problem of the models with the higher gross. (The 500B is better looking too, in a full-figured kind of way!) Somebody correct me where I'm wrong. (And on this list, I can't imagine not being corrected if anyone thinks I'm wrong!) The wings are beautiful in a way books and figures can't convey. Take a look at the twist in the wing on its way outboard. My Dad spent a lot of time is mainly 680E's all over the world. He loved them, but I believe he thought the 680F the best of breed. Ok, now to see if I can get the bulldozer fixed. Sigh........ Steve ----- Original Message ----- From: willis robison To: commander-list(at)matronics.com Sent: Saturday, November 08, 2008 8:06 PM Subject: Re: Commander-List: Flight Levels magazine - Fall 2008 issue Gents, The following was gleaned from the production data on the commander website and from the NACA archives. There appears to be two variants of the commander wing; a 44=92 and a 49=92 Both variants use the NACA 23012 airfoil from root to tip. This particular airfoil is know for its docile behavior and was widely used by other aircraft. Most notably the Beech Staggerwing uses this airfoil as do other Beech Aircraft, but only in the outboard sections near the ailerons. The Commanders use a single airfoil from root to tip. This was chosen likely for its ease of manufacture. From a manufacturing standpoint, adding 5=92 to the wingspan is easier to do by either lengthening the tips outboard of the ailerons or increasing the engine/nacelle truss section. This could mean adding just one or two rib sections The 49=92 wing is the archetype and is featured on all the piston twin commanders except the so-called =93straight=94 560 and 680 models. The 560 was produced from 1954 to 1957 and the 680 ran from =9255 to =9258. There is also a notable difference in the fuel capacity for the 44=92 560 which has 145 gals compared to the 500s which have 156 gallons normally. All the Long range models of 560E, F and 680F, L,P have 223 gallons apparently using all the available bays inboard of the ailerons. As for weight. It looks like the early models (round nacelle) had usefull loads around 2100 lbs with variations trading up or down depending on HP and Service ceiling. Twin Commander corporation has mentioned that they don=92t have model years, per-se; so this has allowed them to make production runs of a particular type using the same production space. When the Streamlined Nacell was introduced, there was also a notable increase in useful load. To about 2300 to 3200 lbs. This also improved their service ceiling from an average of 22 kft. To 28kft in the E and F models. I/ve been chasing this trail during my search for the =93Right=94 Commander to buy. Ive focused on a 680F for a lot of reasons, but mostly it has the widest range of operating capability, short field, high(er) altitude and still have a modicum of efficiency for its type. (if you can keep your hand off the throttle). wer --- On Sat, 11/8/08, John Vormbaum wrote: From: John Vormbaum <john(at)vormbaum.com> Subject: Re: Commander-List: Flight Levels magazine - Fall 2008 issue To: commander-list(at)matronics.com Date: Saturday, November 8, 2008, 1:29 PM Jim, I thought the wing & spar structures were the same on all the Commanders. They're not? I know the turbines are easily a 12,000-lb. wing, but I've been under the illusion that the wing on my 500B is essentially the same thing... /John willis robison wrote: > I think so too. > I was a spectator at a few "ultimate" load tests. One for the A380. I was told that it took 10x the "rated" load before failing. They said they were pleased with the results so I guess it made it past FAA and JAR. > > --- On *Sat, 11/8/08, yourtcfg(at)aol.com //* wrote: > > From: yourtcfg(at)aol.com <yourtcfg(at)aol.com> > Subject: Re: Commander-List: Flight Levels magazine - Fall 2008 issue > To: commander-list(at)matronics.com > Date: Saturday, November 8, 2008, 10:33 AM > > Over designed I think. The same airframe wing structure can carry > as much as 8500 pounds, thought some Commanders are limited to > 6000 gross. The gross weight is determined by the FAA mandated > single engine climb performance. A model 680 has the same power > as a 680E but a 500 pound lower gross. Some 680s were extended to > the "E" wingspan and the gross went up to 7500 pounds. jb > > Which was it and at what HP/gross is the maximum? > > > > > -----Original Message----- > From: willis robison <drwer2(at)yahoo.com> > To: commander-list(at)matronics.com > Sent: Fri, 7 Nov 2008 6:55 pm > Subject: Re: Commander-List: Flight Levels magazine - Fall 2008 issue > > Well, if "ome" has 520 ci then they would produce 2x380x520/435 > 908 hp. Wow, I wonder what the GTOW would be!? > I've always been curious about the wing/loading for these AC. They all have relatively the same wing structure. (longer wingtip > for the 680/560's) yet with bigger engines, the FAA allowed higher > gross weights. Was Aero Design able to argue that the original > design was (under powered) or over designed? Which was it and at > what HP/gross is the maximum? > > > --- On *Fri, 11/7/08, yourtcfg(at)aol.com > />/* wrote: > > From: yourtcfg(at)aol.com <mailto:yourtcfg(at)aol.com> > > > Subject: Re: Commander-List: Flight Levels magazine - Fall > 2008 issue > To: commander-list(at)matronics.com > > Date: Friday, November 7, 2008, 5:12 PM > > Yep, I saw that too. Maybe they should have you proof the > next ome!! jb > > The text says it's powered by "a pair of geared Lycoming > 520-cubic-inch GO-435-C2B engines". > > > > > -----Original Message----- > From: Barry Collman <barry.collman@air-britain.co.uk > barry.collman@air-britain.co.uk>> > To: commander-list(at)matronics.com > > Sent: Fri, 7 Nov 2008 9:08 am > Subject: Commander-List: Flight Levels magazine - Fall 2008 issue > > Hi Guys, > On page 7 of the subject magazine there's a photo of N2621B, a > Commander 520 s/n 133. > The text says it's powered by "a pair of geared Lycoming > 520-cubic-inch GO-435-C2B engines". > Has anyone else spotted the (not deliberate) error? > Best Regards, > Barry > > * > > * > > * > > * > > > > > ------------------------------------------------------------------------ > > * > > * > href="http://www.matronics.com/contribution">http://www.matronics.com/c href="http://www.matronics.com/Navigator?Commander-List">http://www.mat ronics.com/Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: Nov 09, 2008
Good Morning Steve, While I had the pleasure of flying several of the early model Aero Commanders forty-five to fifty years ago, I have NEVER worked on one and have absolutely NO knowledge as to how they are built. Nevertheless, may I make a comment? Just because the wing on two different models happens to look the same does not mean the strength is the same. Adding a full web to a spar that previously used a Warren or Pratt truss can makes a major difference as can increasing the skin thickness of a rib or a D-tube leading edge. The very earliest, lightest weight, and weakest Bonanza wing can be physically bolted on to a Twin Bonanza. All control surfaces will hook up properly with no problems at all. The only thing that won't work is the landing gear. Some method would have to be devised to keep the landing gear doors closed, but the airplane could be flown. The wing would not be as strong as is needed to meet the FAA requirements, but it would fly and only a close examination of the wing would reveal that there were small visible changes. May I not assume that the engineers who designed the Aero Commander used similar techniques to both lighten the structure where high loads were not required and beef the structure where high loads were to be carried? Happy Skies Old Bob AKA Bob Siegfried Ancient Aviator 628 West 86th Street Downers Grove, IL 60516 630 985-8502 Stearman N3977A Brookeridge Air Park LL22 In a message dated 11/9/2008 6:51:44 A.M. Central Standard Time, steve2(at)sover.net writes: Because of early problems with spars cracking caps the factory took different approaches to effecting a repair. Some of this I believe is also partly responsible for some changes in gross. The 500 series is a good case study. Our 500B has external heavy aluminum spar straps. They look like leaf springs. We have a lower gross than the 500U and 500S, which has longer internal strapping of the cap in stainless steel. The 'fix' created its own problem of galvanic corrosion between dissimilar metals, which remains an issue to this day. So we have a lower gross, but don't have the corrosion problem of the models with the higher gross. (The 500B is better looking too, in a full-figured kind of way!) **************AOL Search: Your one stop for directions, recipes and all other Holiday needs. Search Now. -aol-search/?ncid=emlcntussear00000001) ________________________________________________________________________________
Date: Nov 09, 2008
Subject: Re: Flight Levels magazine - Fall 2008 issue
Barry Collman wrote: > I think the basic wing structure remained the same, the factory > "simply" adding extensions either inboard or outboard. Barry, Do the drawings you have show the internal structure in detail? If so, I'd love to see them. Although the Commander wings appear to be virtually identical externally, I believe there are many structural differences internally. I certainly have not had the opportunity to compare the wings closely, but from my casual viewing through inspection holes, I believe there are very substantial and subtle upgrades in the strength of the structure as the line progressed. Chris ________________________________________________________________________________
Date: Nov 09, 2008
Chris, I don't have the actual Drawings, just a document detailing the basic changes from one Model to another, grouped by the wing detail. Best Regards, Barry ----- Original Message ----- From: "Chris" <cschuerm(at)cox.net> Sent: Sunday, November 09, 2008 3:10 PM Subject: Re: Commander-List: Flight Levels magazine - Fall 2008 issue | | Barry Collman wrote: | > I think the basic wing structure remained the same, the factory | > "simply" adding extensions either inboard or outboard. | | Barry, | Do the drawings you have show the internal structure in detail? If so, | I'd love to see them. Although the Commander wings appear to be | virtually identical externally, I believe there are many structural | differences internally. I certainly have not had the opportunity to | compare the wings closely, but from my casual viewing through inspection | holes, I believe there are very substantial and subtle upgrades in the | strength of the structure as the line progressed. | | Chris | | | | | | ________________________________________________________________________________
Date: Nov 09, 2008
Now,thats interesting.- The effect of increasing the "washout" is to (a). move the center of lift inboard, (b.) decrease overall lift and (c) improv e slow speed handling and stall characteristics.-These are subtle changes . -This change would not have a major effect on-MTOW but would place th e stress where the wing was stronger.- - I'd give anything to see any production drawings. - Thanks again Barry for being our Nexus. - Willis - --- On Sun, 11/9/08, Barry Collman <barry.collman@air-britain.co.uk> wrote: From: Barry Collman <barry.collman@air-britain.co.uk> Subject: Re: Commander-List: Flight Levels magazine - Fall 2008 issue Date: Sunday, November 9, 2008, 5:00 AM Hi All, - The typical wing twist aspect is indeed interesting. - Looking at the 560E, for example, the-incidence at the wing root-was 3 degrees. while that at the tip was minus 3.5 degrees. - Looking at the 560A, for example, the-incidence at the wing root-was 3 degrees. while that at the tip was minus-1 degree. - Best Regards, Barry ----- Original Message ----- From: Steve W Sent: Sunday, November 09, 2008 12:50 PM Subject: Re: Commander-List: Flight Levels magazine - Fall 2008 issue WER, - Barry this morning has added some drawing number detail to the wing history . - I 'know' enough to perhaps comment, but not so much that I might not get it completely right..... So hopefully somebody will correct me where I'm in e rror..... - Because of early problems with spars cracking caps the factory took differe nt approaches to effecting a repair. Some of this I believe is also partly responsible for some changes in gross. The 500 series is a good case study. Our 500B has external heavy aluminum spar straps. They look like leaf spri ngs. We have a lower gross than the 500U and 500S, which has longer interna l strapping of the cap in stainless steel. The 'fix' created its own proble m of galvanic corrosion between dissimilar metals, which remains an issue t o this day. So we have a lower gross, but don't have the corrosion problem of the models with the higher gross. (The 500B is better looking too, in a full-figured kind of way!) - Somebody correct me where I'm wrong. (And on this list, I can't imagine not being corrected if anyone thinks I'm wrong!) - The wings are beautiful-in a way-books and figures-can't convey. Take a look at the twist in the wing on its way outboard. - My Dad spent a lot of time is mainly 680E's all over the world. He loved th em, but I believe he thought the 680F the best of breed. - Ok, now to see if I can get the bulldozer fixed. Sigh........ - Steve- ----- Original Message ----- From: willis robison Sent: Saturday, November 08, 2008 8:06 PM Subject: Re: Commander-List: Flight Levels magazine - Fall 2008 issue Gents, - The following was gleaned from the production data on the commander website and from the NACA archives. - There appears to be two variants of the commander wing; a- 44=92 and a 49 =92- Both variants use the NACA 23012 airfoil from root to tip.-- Thi s particular airfoil is know for its docile behavior and was widely used by other aircraft.- Most notably the Beech Staggerwing uses this airfoil as do other Beech Aircraft, but only in the outboard sections near the ailero ns.- The Commanders use a single airfoil from root to tip.- This was ch osen likely for its ease of manufacture.- From a manufacturing standpoint , adding 5=92 to the wingspan is easier to do by either lengthening the tip s outboard of the ailerons or increasing the engine/nacelle truss section. This could mean adding just one or two rib sections - The 49=92 wing is the archetype and is featured on all the piston twin comm anders except the so-called =93straight=94 560 and 680 models.- The 560 w as produced from 1954 to 1957 and the 680 ran from =9255 to =9258. - There is also a notable difference in the fuel capacity for the 44=92 560 w hich has 145 gals compared to the 500s which have 156 gallons normally.- All the Long range models of 560E, F and 680F, L,P have 223 gallons- appa rently using all the available bays inboard of the ailerons. - As for weight. It looks like the early models (round nacelle) had usefull l oads around 2100 lbs with variations trading up or down depending on HP and Service ceiling.- Twin Commander corporation has mentioned that they don =92t have model years, per-se; so this has allowed them to make production runs of a particular type using the same production space. - When the Streamlined Nacell was introduced, there was also a notable increa se in useful load. To about 2300 -to 3200 lbs.- This also improved thei r service ceiling from an average of 22 kft. To 28kft in the E and F models . - I/ve been chasing this trail during my search for the =93Right=94 Commander to buy.- Ive focused on a 680F for a lot of reasons, but mostly it has t he widest range of operating capability, short field, high(er) altitude and still have a modicum of efficiency for its type. (if you can keep your han d off the throttle). - wer --- On Sat, 11/8/08, John Vormbaum wrote: From: John Vormbaum <john(at)vormbaum.com> Subject: Re: Commander-List: Flight Levels magazine - Fall 2008 issue Date: Saturday, November 8, 2008, 1:29 PM Jim, I thought the wing & spar structures were the same on all the Commanders. They're not? I know the turbines are easily a 12,000-lb. wing, but I've been under the illusion that the wing on my 500B is essentially the same thing... /John willis robison wrote: > I think so too. > I was a spectator at a few "ultimate" load tests. One for the A380. I was told that it took 10x the "rated" load before failing. They said they were pleased with the results so I guess it made it past FAA and JAR. > > --- On *Sat, 11/8/08, yourtcfg(at)aol.com //* wrote: > > From: yourtcfg(at)aol.com <yourtcfg(at)aol.com> > Subject: Re: Commander-List: Flight Levels magazine - Fall 2008 issue > To: commander-list(at)matronics.com > Date: Saturday, November 8, 2008, 10:33 AM > > Over designed I think. The same airframe wing structure can carry > as much as 8500 pounds, thought some Commanders are limited to > 6000 gross. The gross weight is determined by the FAA mandated > single engine climb performance. A model 680 has the same power > as a 680E but a 500 pound lower gross. Some 680s were extended to > the "E" wingspan and the gross went up to 7500 pounds. jb > > Which was it and at what HP/gross is the maximum? > > > > > -----Original Message----- > From: willis robison <drwer2(at)yahoo.com> > To: commander-list(at)matronics.com > Sent: Fri, 7 Nov 2008 6:55 pm > Subject: Re: Commander-List: Flight Levels magazine - Fall 2008 issue > > Well, if "ome" has 520 ci then they would produce 2x380x520/435 > 908 hp. Wow, I wonder what the GTOW would be!? > I've always been curious about the wing/loading for these AC. They all have relatively the same wing structure. (longer wingtip > for the 680/560's) yet with bigger engines, the FAA allowed higher > gross weights. Was Aero Design able to argue that the original > design was (under powered) or over designed? Which was it and at > what HP/gross is the maximum? > > > --- On *Fri, 11/7/08, yourtcfg(at)aol.com > />/* wrote: > > From: yourtcfg(at)aol.com <mailto:yourtcfg(at)aol.com> > > > Subject: Re: Commander-List: Flight Levels magazine - Fall > 2008 issue > To: commander-list(at)matronics.com > > Date: Friday, November 7, 2008, 5:12 PM > > Yep, I saw that too. Maybe they should have you proof the > next ome!! jb > > The text says it's powered by "a pair of geared Lycoming > 520-cubic-inch GO-435-C2B engines". > > > > > -----Original Message----- > From: Barry Collman <barry.collman@air-britain.co.uk > barry.collman@air-britain.co.uk>> > To: commander-list(at)matronics.com > > Sent: Fri, 7 Nov 2008 9:08 am > Subject: Commander-List: Flight Levels magazine - Fall 2008 issue > > Hi Guys, > On page 7 of the subject magazine there's a photo of N2621B, a > Commander 520 s/n 133. > The text says it's powered by "a pair of geared Lycoming > 520-cubic-inch GO-435-C2B engines". > Has anyone else spotted the (not deliberate) error? > Best Regards, > Barry > > * > > * > > * > > * > > > > > ------------------------------------------------------------------------ > > * > > * > href="http://www.matronics.com/contribution">http://www.matronics.com/chr ef="http://www.matronics.com/Navigator?Commander-List">http://www.matroni cs.com/Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/chr ef="http://www.matronics.com/Navigator?Commander-List">http://www.matroni cs.com/Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com =0A=0A=0A ________________________________________________________________________________
Date: Nov 09, 2008
Willis, My money is on reason "c". The washout on the Commanders was primarily to aid in low-speed handling; you want the wing root to stall before the tip so that you can maintain directional control. I've heard it cited that this is the reason that during his famous routine Bob Hoover was able to fly the airplane vertically to near-zero airspeed, but still have aileron authority and not drop a wing. I don't know if that's the honest truth, but we all know how well these airplanes do at low speed. I would think that using washout to decrease overall lift is inefficient; you could just use less wing and get better performance numbers, right? I'm sure someone will correct me if I'm wrong! /John willis robison wrote: > Now,thats interesting. The effect of increasing the "washout" is to > (a). move the center of lift inboard, (b.) decrease overall lift and > (c) improve slow speed handling and stall characteristics. These are > subtle changes. This change would not have a major effect on MTOW but > would place the stress where the wing was stronger. > > I'd give anything to see any production drawings. > > Thanks again Barry for being our Nexus. > > Willis > > > > --- On *Sun, 11/9/08, Barry Collman > /<barry.collman@air-britain.co.uk>/* wrote: > > From: Barry Collman <barry.collman@air-britain.co.uk> > Subject: Re: Commander-List: Flight Levels magazine - Fall 2008 issue > To: commander-list(at)matronics.com > Date: Sunday, November 9, 2008, 5:00 AM > > Hi All, > > The typical wing twist aspect is indeed interesting. > > Looking at the 560E, for example, the incidence at the wing > root was 3 degrees. while that at the tip was minus 3.5 degrees. > > Looking at the 560A, for example, the incidence at the wing > root was 3 degrees. while that at the tip was minus 1 degree. > > Best Regards, > Barry > > ----- Original Message ----- > *From:* Steve W > *To:* commander-list(at)matronics.com > > *Sent:* Sunday, November 09, 2008 12:50 PM > *Subject:* Re: Commander-List: Flight Levels magazine - Fall > 2008 issue > > WER, > > Barry this morning has added some drawing number detail to the > wing history. > > I 'know' enough to perhaps comment, but not so much that I > might not get it completely right..... So hopefully somebody > will correct me where I'm in error..... > > Because of early problems with spars cracking caps the factory > took different approaches to effecting a repair. Some of this > I believe is also partly responsible for some changes in > gross. The 500 series is a good case study. Our 500B has > external heavy aluminum spar straps. They look like leaf > springs. We have a lower gross than the 500U and 500S, which > has longer internal strapping of the cap in stainless steel. > The 'fix' created its own problem of galvanic corrosion > between dissimilar metals, which remains an issue to this day. > So we have a lower gross, but don't have the corrosion problem > of the models with the higher gross. (The 500B is better > looking too, in a full-figured kind of way!) > > Somebody correct me where I'm wrong. (And on this list, I > can't imagine not being corrected if anyone thinks I'm wrong!) > > The wings are beautiful in a way books and figures can't > convey. Take a look at the twist in the wing on its way outboard. > > My Dad spent a lot of time is mainly 680E's all over the > world. He loved them, but I believe he thought the 680F the > best of breed. > > Ok, now to see if I can get the bulldozer fixed. Sigh........ > > Steve > > ----- Original Message ----- > *From:* willis robison > *To:* commander-list(at)matronics.com > > *Sent:* Saturday, November 08, 2008 8:06 PM > *Subject:* Re: Commander-List: Flight Levels magazine - > Fall 2008 issue > > Gents, > > The following was gleaned from the production data on the > commander website and from the NACA archives. > > > > There appears to be two variants of the commander wing; a > 44 and a 49 Both variants use the NACA 23012 airfoil > from root to tip. This particular airfoil is know for > its docile behavior and was widely used by other > aircraft. Most notably the Beech Staggerwing uses this > airfoil as do other Beech Aircraft, but only in the > outboard sections near the ailerons. The Commanders use a > single airfoil from root to tip. This was chosen likely > for its ease of manufacture. From a manufacturing > standpoint, adding 5 to the wingspan is easier to do by > either lengthening the tips outboard of the ailerons or > increasing the engine/nacelle truss section. This could > mean adding just one or two rib sections > > > > The 49 wing is the archetype and is featured on all the > piston twin commanders except the so-called straight 560 > and 680 models. The 560 was produced from 1954 to 1957 > and the 680 ran from 55 to 58. > > > > There is also a notable difference in the fuel capacity > for the 44 560 which has 145 gals compared to the 500s > which have 156 gallons normally. All the Long range > models of 560E, F and 680F, L,P have 223 gallons > apparently using all the available bays inboard of the > ailerons. > > > > As for weight. It looks like the early models (round > nacelle) had usefull loads around 2100 lbs with variations > trading up or down depending on HP and Service ceiling. > Twin Commander corporation has mentioned that they dont > have model years, per-se; so this has allowed them to make > production runs of a particular type using the same > production space. > > > > When the Streamlined Nacell was introduced, there was also > a notable increase in useful load. To about 2300 to 3200 > lbs. This also improved their service ceiling from an > average of 22 kft. To 28kft in the E and F models. > > > > I/ve been chasing this trail during my search for the > Right Commander to buy. Ive focused on a 680F for a lot > of reasons, but mostly it has the widest range of > operating capability, short field, high(er) altitude and > still have a modicum of efficiency for its type. (if you > can keep your hand off the throttle). > > > > wer > > > --- On *Sat, 11/8/08, John Vormbaum //* > wrote: > > From: John Vormbaum <john(at)vormbaum.com> > Subject: Re: Commander-List: Flight Levels magazine - > Fall 2008 issue > To: commander-list(at)matronics.com > Date: Saturday, November 8, 2008, 1:29 PM > > > Jim, > > I thought the wing & spar structures were the same on all the Commanders. > They're not? I know the turbines are easily a 12,000-lb. wing, but I've > been under the illusion that the wing on my 500B is essentially the same > thing... > > /John > > willis robison wrote: > > I think so too. > > I was a spectator at a few "ultimate" load tests. One for the > A380. I was told that it took 10x the "rated" load before failing. > They said they were pleased with the results so I guess it made it past FAA and > JAR. > > > > --- On *Sat, 11/8/08, yourtcfg(at)aol.com //* wrote: > > > > From: yourtcfg(at)aol.com <yourtcfg(at)aol.com> > > Subject: Re: Commander-List: Flight Levels magazine - Fall 2008 issue > > To: commander-list(at)matronics.com > > Date: Saturday, November 8, 2008, 10:33 AM > > > > Over designed I think. The same airframe wing structure can carry > > as much as 8500 pounds, thought some Commanders are limited to > > 6000 gross. The gross weight is determined by the FAA mandated > > single engine climb performance. A model 680 has the same power > > as a 680E but a 500 pound lower gross. Some 680s were extended to > > the "E" wingspan and the gross went up to 7500 pounds. jb > > > > Which was it and at what HP/gross is the maximum? > > > > > > > > > > -----Original Message----- > > From: willis robison <drwer2(at)yahoo.com> > > To: commander-list(at)matronics.com > > Sent: Fri, 7 Nov 2008 6:55 pm > > Subject: Re: Commander-List: Flight Levels magazine - Fall 2008 issue > > > > Well, if "ome" has 520 ci then they would produce > 2x380x520/435 > > 908 hp. Wow, I wonder what the GTOW would be!? > > I've always been curious about the wing/loading for these AC. > They all have relatively the same wing structure. (longer wingtip > > for the 680/560's) yet with bigger engines, the FAA allowed higher > > gross weights. Was Aero Design able to argue that the original > > design was (under powered) or over designed? Which was it and at > > what HP/gross is the maximum? > > > > > > --- On *Fri, 11/7/08, yourtcfg(at)aol.com > > />/* wrote: > > > > From: yourtcfg(at)aol.com <mailto:yourtcfg(at)aol.com> > > > > > Subject: Re: Commander-List: Flight Levels magazine - Fall > > 2008 issue > > To: commander-list(at)matronics.com > > > > Date: Friday, November 7, 2008, 5:12 PM > > > > Yep, I saw that too. Maybe they should have you proof the > > next ome!! jb > > > > The text says it's powered by "a pair of geared > Lycoming > > 520-cubic-inch GO-435-C2B engines". > > > > > > > > > > -----Original Message----- > > From: Barry Collman <barry.collman@air-britain.co.uk > > barry.collman@air-britain.co.uk>> > > To: commander-list(at)matronics.com > > > > Sent: Fri, 7 Nov 2008 9:08 am > > Subject: Commander-List: Flight Levels magazine - Fall 2008 issue > > > > Hi Guys, > > On page 7 of the subject magazine there's a photo of > N2621B, a > > Commander 520 s/n 133. > > The text says it's powered by "a pair of geared > Lycoming > > 520-cubic-inch GO-435-C2B engines". > > Has anyone else spotted the (not deliberate) error? > > Best Regards, > > Barry > > > > * > > > > * > > > > * > > > > * > > > > > > > > > > ------------------------------------------------------------------------ > > > > * > > > > * > > > > > > > > * > > href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?Commander-List">http://www.matronics.com/Navigator?Commander-List > href="http://forums.matronics.com">http://forums.matronics.com > * > > * > > href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?Commander-List">http://www.matronics.com/Navigator?Commander-List > href="http://forums.matronics.com">http://forums.matronics.com > * > > * > > blank rel=nofollow>http://www.matronics.com/contribution > " target=_blank rel=nofollow>http://www.matronics.com/Navigator?Commander-List > =nofollow>http://forums.matronics.com > * > > > * > > * ________________________________________________________________________________
Date: Nov 09, 2008
I think you're right on the money John. Ill bet that was the intent and the other effects-were-probably insignificant-and- just trade offs. - wer. --- On Sun, 11/9/08, John Vormbaum wrote: From: John Vormbaum <john(at)vormbaum.com> Subject: Re: Commander-List: Flight Levels magazine - Fall 2008 issue Date: Sunday, November 9, 2008, 9:09 AM Willis, My money is on reason "c". The washout on the Commanders was primarily to aid in low-speed handling; you want the wing root to stall bef ore the tip so that you can maintain directional control. I've heard it cited that this is the reason that during his famous routine Bob Hoover was able to fly the airplane vertically to near-zero airspeed, but still have aileron authority and not drop a wing. I don't know if that's the honest truth, but we all know how well these airplanes do at low speed. I would think that using washout to decrease overall lift is inefficient; y ou could just use less wing and get better performance numbers, right? I'm sur e someone will correct me if I'm wrong! /John willis robison wrote: > Now,thats interesting. The effect of increasing the "washout" is to (a). move the center of lift inboard, (b.) decrease overall lift and (c) improve slow speed handling and stall characteristics. These are subtle cha nges. This change would not have a major effect on MTOW but would place the stre ss where the wing was stronger. I'd give anything to see any production drawings. > Thanks again Barry for being our Nexus. > Willis > > > --- On *Sun, 11/9/08, Barry Collman /<barry.collman@air-britain.co.uk>/* wrote: > > From: Barry Collman <barry.collman@air-britain.co.uk> > Subject: Re: Commander-List: Flight Levels magazine - Fall 2008 issue > To: commander-list(at)matronics.com > Date: Sunday, November 9, 2008, 5:00 AM > > Hi All, > The typical wing twist aspect is indeed interesting. > Looking at the 560E, for example, the incidence at the wing > root was 3 degrees. while that at the tip was minus 3.5 degrees. > Looking at the 560A, for example, the incidence at the wing > root was 3 degrees. while that at the tip was minus 1 degree. > Best Regards, > Barry > > ----- Original Message ----- > *From:* Steve W > *To:* commander-list(at)matronics.com > > *Sent:* Sunday, November 09, 2008 12:50 PM > *Subject:* Re: Commander-List: Flight Levels magazine - Fall > 2008 issue > > WER, > Barry this morning has added some drawing number detail to the > wing history. > I 'know' enough to perhaps comment, but not so much that I > might not get it completely right..... So hopefully somebody > will correct me where I'm in error..... > Because of early problems with spars cracking caps the factory > took different approaches to effecting a repair. Some of this > I believe is also partly responsible for some changes in > gross. The 500 series is a good case study. Our 500B has > external heavy aluminum spar straps. They look like leaf > springs. We have a lower gross than the 500U and 500S, which > has longer internal strapping of the cap in stainless steel. > The 'fix' created its own problem of galvanic corrosion > between dissimilar metals, which remains an issue to this day. > So we have a lower gross, but don't have the corrosion problem > of the models with the higher gross. (The 500B is better > looking too, in a full-figured kind of way!) > Somebody correct me where I'm wrong. (And on this list, I > can't imagine not being corrected if anyone thinks I'm wrong!) > The wings are beautiful in a way books and figures can't > convey. Take a look at the twist in the wing on its way outboard. > My Dad spent a lot of time is mainly 680E's all over the > world. He loved them, but I believe he thought the 680F the > best of breed. > Ok, now to see if I can get the bulldozer fixed. Sigh........ > Steve > ----- Original Message ----- > *From:* willis robison > *To:* commander-list(at)matronics.com > > *Sent:* Saturday, November 08, 2008 8:06 PM > *Subject:* Re: Commander-List: Flight Levels magazine - > Fall 2008 issue > > Gents, > The following was gleaned from the production data on the > commander website and from the NACA archives. > > > There appears to be two variants of the commander wing; a 44=92 and a 49=92 Both variants use the NACA 23012 airfoil > from root to tip. This particular airfoil is know for > its docile behavior and was widely used by other > aircraft. Most notably the Beech Staggerwing uses this > airfoil as do other Beech Aircraft, but only in the > outboard sections near the ailerons. The Commanders use a > single airfoil from root to tip. This was chosen likely > for its ease of manufacture. From a manufacturing > standpoint, adding 5=92 to the wingspan is easier to do by > either lengthening the tips outboard of the ailerons or > increasing the engine/nacelle truss section. This could > mean adding just one or two rib sections > > > The 49=92 wing is the archetype and is featured on all the > piston twin commanders except the so-called =93straight=94 56 0 > and 680 models. The 560 was produced from 1954 to 1957 > and the 680 ran from =9255 to =9258. > > > There is also a notable difference in the fuel capacity > for the 44=92 560 which has 145 gals compared to the 500s > which have 156 gallons normally. All the Long range > models of 560E, F and 680F, L,P have 223 gallons apparently using all the available bays inboard of the > ailerons. > > > As for weight. It looks like the early models (round > nacelle) had usefull loads around 2100 lbs with variations > trading up or down depending on HP and Service ceiling. Twin Commander corporation has mentioned that they don=92t > have model years, per-se; so this has allowed them to make > production runs of a particular type using the same > production space. > > > When the Streamlined Nacell was introduced, there was also > a notable increase in useful load. To about 2300 to 3200 > lbs. This also improved their service ceiling from an > average of 22 kft. To 28kft in the E and F models. > > > I/ve been chasing this trail during my search for the > =93Right=94 Commander to buy. Ive focused on a 680F for a lo t > of reasons, but mostly it has the widest range of > operating capability, short field, high(er) altitude and > still have a modicum of efficiency for its type. (if you > can keep your hand off the throttle). > > > wer > > > > --- On *Sat, 11/8/08, John Vormbaum //* > wrote: > > From: John Vormbaum <john(at)vormbaum.com> > Subject: Re: Commander-List: Flight Levels magazine - > Fall 2008 issue > To: commander-list(at)matronics.com > Date: Saturday, November 8, 2008, 1:29 PM > > > Jim, > > I thought the wing & spar structures were the same on all the Commanders. > They're not? I know the turbines are easily a 12,000-lb. wing, but I've > been under the illusion that the wing on my 500B is essentially the same > thing... > > /John > > willis robison wrote: > > I think so too. > > I was a spectator at a few "ultimate" load tests. One for the > A380. I was told that it took 10x the "rated" load before failing. They said they were pleased with the results so I guess it made it past FAA and > JAR. > > > --- On *Sat, 11/8/08, yourtcfg(at)aol.com //* wrote: > > > From: yourtcfg(at)aol.com > > Subject: Re: Commander-List: Flight Levels magazine - Fall 2008 issue > > To: commander-list(at)matronics.com > > Date: Saturday, November 8, 2008, 10:33 AM > > > Over designed I think. The same airframe wing structure can carry > > as much as 8500 pounds, thought some Commanders are limited to > > 6000 gross. The gross weight is determined by the FAA mandated > > single engine climb performance. A model 680 has the same power > > as a 680E but a 500 pound lower gross. Some 680s were extended to > > the "E" wingspan and the gross went up to 7500 pounds. jb > > > Which was it and at what HP/gross is the maximum? > > > > > > -----Original Message----- > > From: willis robison <drwer2(at)yahoo.com> > > To: commander-list(at)matronics.com > > Sent: Fri, 7 Nov 2008 6:55 pm > > Subject: Re: Commander-List: Flight Levels magazine - Fall 2008 issue > > > Well, if "ome" has 520 ci then they would produce > 2x380x520/435 > > 908 hp. Wow, I wonder what the GTOW would be!? > > I've always been curious about the wing/loading for these AC. > They all have relatively the same wing structure. (longer wingtip > > for the 680/560's) yet with bigger engines, the FAA allowed higher > > gross weights. Was Aero Design able to argue that the original > > design was (under powered) or over designed? Which was it and at > > what HP/gross is the maximum? > > > > --- On *Fri, 11/7/08, yourtcfg(at)aol.com > > />/* wrote: > > > From: yourtcfg(at)aol.com > > > > > Subject: Re: Commander-List: Flight Levels magazine - Fall > > 2008 issue > > To: commander-list(at)matronics.com > > > > Date: Friday, November 7, 2008, 5:12 PM > > > Yep, I saw that too. Maybe they should have you proof the > > next ome!! jb > > > The text says it's powered by "a pair of geared > Lycoming > > 520-cubic-inch GO-435-C2B engines". > > > > > > -----Original Message----- > > From: Barry Collman <barry.collman@air-britain.co.uk > > barry.collman@air-britain.co.uk>> > > To: commander-list(at)matronics.com > > > > Sent: Fri, 7 Nov 2008 9:08 am > > Subject: Commander-List: Flight Levels magazine - Fall 2008 issue > > > Hi Guys, > > On page 7 of the subject magazine there's a photo of > N2621B, a > > Commander 520 s/n 133. > > The text says it's powered by "a pair of geared > Lycoming > > 520-cubic-inch GO-435-C2B engines". > > Has anyone else spotted the (not deliberate) error? > > Best Regards, > > Barry > > > * > > > * > > > * > > > * > > > > > > > ------------------------------------------------------------------------ > > > * > > > * > > > > > > > > * > > href="http://www.matronics.com/contribution">http://www.matronics.com/chr ef="http://www.matronics.com/Navigator?Commander-List">http://www.matroni cs.com/Navigator?Commander-List > href="http://forums.matronics.com">http://forums.matronics.com > * > > * > > href="http://www.matronics.com/contribution">http://www.matronics.com/chr ef="http://www.matronics.com/Navigator?Commander-List">http://www.matroni cs.com/Navigator?Commander-List > href="http://forums.matronics.com">http://forums.matronics.com > * > > * > > blank rel=nofollow>http://www.matronics.com/contribution > " target=_blank rel=nofollow>http://www.matronics.com/Navigator?Commander-List > =nofollow>http://forums.matronics.com > * > > > * > > * =0A=0A=0A ________________________________________________________________________________
Date: Nov 09, 2008
Dozer fixed...... Whew. John, seems like there might be more factors at play with the washout? You could 'tune' a wing for best efficiency to fit anticipated speed, load and altitude, yes? At speed and low angles of attack, negative a couple degrees must be close to lift neutral (and less drag). Forgetting my book learning. Too tired to remember, too lazy to look it up. All things being equal, is the angle of attack increasing per altitude? Steve ----- Original Message ----- From: "John Vormbaum" <john(at)vormbaum.com> Sent: Sunday, November 09, 2008 12:09 PM Subject: Re: Commander-List: Flight Levels magazine - Fall 2008 issue > > Willis, > > My money is on reason "c". The washout on the Commanders was primarily to > aid in low-speed handling; you want the wing root to stall before the tip > so that you can maintain directional control. I've heard it cited that > this is the reason that during his famous routine Bob Hoover was able to > fly the airplane vertically to near-zero airspeed, but still have aileron > authority and not drop a wing. I don't know if that's the honest truth, > but we all know how well these airplanes do at low speed. > > I would think that using washout to decrease overall lift is inefficient; > you could just use less wing and get better performance numbers, right? > I'm sure someone will correct me if I'm wrong! > > /John > > willis robison wrote: >> Now,thats interesting. The effect of increasing the "washout" is to (a). >> move the center of lift inboard, (b.) decrease overall lift and (c) >> improve slow speed handling and stall characteristics. These are subtle >> changes. This change would not have a major effect on MTOW but would >> place the stress where the wing was stronger. I'd give anything to see >> any production drawings. >> Thanks again Barry for being our Nexus. >> Willis >> >> >> --- On *Sun, 11/9/08, Barry Collman /<barry.collman@air-britain.co.uk>/* >> wrote: >> >> From: Barry Collman <barry.collman@air-britain.co.uk> >> Subject: Re: Commander-List: Flight Levels magazine - Fall 2008 issue >> To: commander-list(at)matronics.com >> Date: Sunday, November 9, 2008, 5:00 AM >> >> Hi All, >> The typical wing twist aspect is indeed interesting. >> Looking at the 560E, for example, the incidence at the wing >> root was 3 degrees. while that at the tip was minus 3.5 degrees. >> Looking at the 560A, for example, the incidence at the wing >> root was 3 degrees. while that at the tip was minus 1 degree. >> Best Regards, >> Barry >> >> ----- Original Message ----- >> *From:* Steve W >> *To:* commander-list(at)matronics.com >> >> *Sent:* Sunday, November 09, 2008 12:50 PM >> *Subject:* Re: Commander-List: Flight Levels magazine - Fall >> 2008 issue >> >> WER, >> Barry this morning has added some drawing number detail to the >> wing history. >> I 'know' enough to perhaps comment, but not so much that I >> might not get it completely right..... So hopefully somebody >> will correct me where I'm in error..... >> Because of early problems with spars cracking caps the factory >> took different approaches to effecting a repair. Some of this >> I believe is also partly responsible for some changes in >> gross. The 500 series is a good case study. Our 500B has >> external heavy aluminum spar straps. They look like leaf >> springs. We have a lower gross than the 500U and 500S, which >> has longer internal strapping of the cap in stainless steel. >> The 'fix' created its own problem of galvanic corrosion >> between dissimilar metals, which remains an issue to this day. >> So we have a lower gross, but don't have the corrosion problem >> of the models with the higher gross. (The 500B is better >> looking too, in a full-figured kind of way!) >> Somebody correct me where I'm wrong. (And on this list, I >> can't imagine not being corrected if anyone thinks I'm wrong!) >> The wings are beautiful in a way books and figures can't >> convey. Take a look at the twist in the wing on its way outboard. >> My Dad spent a lot of time is mainly 680E's all over the >> world. He loved them, but I believe he thought the 680F the >> best of breed. >> Ok, now to see if I can get the bulldozer fixed. Sigh........ >> Steve >> ----- Original Message ----- >> *From:* willis robison >> *To:* commander-list(at)matronics.com >> >> *Sent:* Saturday, November 08, 2008 8:06 PM >> *Subject:* Re: Commander-List: Flight Levels magazine - >> Fall 2008 issue >> >> Gents, >> The following was gleaned from the production data on the >> commander website and from the NACA archives. >> >> >> There appears to be two variants of the commander wing; a 44 >> and a 49 Both variants use the NACA 23012 airfoil >> from root to tip. This particular airfoil is know for >> its docile behavior and was widely used by other >> aircraft. Most notably the Beech Staggerwing uses this >> airfoil as do other Beech Aircraft, but only in the >> outboard sections near the ailerons. The Commanders use a >> single airfoil from root to tip. This was chosen likely >> for its ease of manufacture. From a manufacturing >> standpoint, adding 5 to the wingspan is easier to do by >> either lengthening the tips outboard of the ailerons or >> increasing the engine/nacelle truss section. This could >> mean adding just one or two rib sections >> >> >> The 49 wing is the archetype and is featured on all the >> piston twin commanders except the so-called straight 560 >> and 680 models. The 560 was produced from 1954 to 1957 >> and the 680 ran from 55 to 58. >> >> >> There is also a notable difference in the fuel capacity >> for the 44 560 which has 145 gals compared to the 500s >> which have 156 gallons normally. All the Long range >> models of 560E, F and 680F, L,P have 223 gallons apparently >> using all the available bays inboard of the >> ailerons. >> >> >> As for weight. It looks like the early models (round >> nacelle) had usefull loads around 2100 lbs with variations >> trading up or down depending on HP and Service ceiling. Twin >> Commander corporation has mentioned that they dont >> have model years, per-se; so this has allowed them to make >> production runs of a particular type using the same >> production space. >> >> >> When the Streamlined Nacell was introduced, there was also >> a notable increase in useful load. To about 2300 to 3200 >> lbs. This also improved their service ceiling from an >> average of 22 kft. To 28kft in the E and F models. >> >> >> I/ve been chasing this trail during my search for the >> Right Commander to buy. Ive focused on a 680F for a lot >> of reasons, but mostly it has the widest range of >> operating capability, short field, high(er) altitude and >> still have a modicum of efficiency for its type. (if you >> can keep your hand off the throttle). >> >> >> wer >> >> >> >> --- On *Sat, 11/8/08, John Vormbaum //* >> wrote: >> >> From: John Vormbaum <john(at)vormbaum.com> >> Subject: Re: Commander-List: Flight Levels magazine - >> Fall 2008 issue >> To: commander-list(at)matronics.com >> Date: Saturday, November 8, 2008, 1:29 PM >> >> >> >> Jim, >> >> I thought the wing & spar structures were the same on all >> the Commanders. >> They're not? I know the turbines are easily a 12,000-lb. >> wing, but I've >> been under the illusion that the wing on my 500B is >> essentially the same >> thing... >> >> /John >> >> willis robison wrote: >> > I think so too. >> > I was a spectator at a few "ultimate" load tests. One >> for the >> A380. I was told that it took 10x the "rated" load >> before failing. They said they were pleased with the results so I guess >> it made it past FAA and >> JAR. >> > > --- On *Sat, 11/8/08, yourtcfg(at)aol.com >> //* wrote: >> > > From: yourtcfg(at)aol.com <yourtcfg(at)aol.com> >> > Subject: Re: Commander-List: Flight Levels >> magazine - Fall 2008 issue >> > To: commander-list(at)matronics.com >> > Date: Saturday, November 8, 2008, 10:33 AM >> > > Over designed I think. The same airframe wing >> structure can carry >> > as much as 8500 pounds, thought some Commanders are >> limited to >> > 6000 gross. The gross weight is determined by the >> FAA mandated >> > single engine climb performance. A model 680 has >> the same power >> > as a 680E but a 500 pound lower gross. Some 680s >> were extended to >> > the "E" wingspan and the gross went up to 7500 >> pounds. jb >> > > Which was it and at what HP/gross is the >> maximum? >> > > > > > -----Original Message----- >> > From: willis robison <drwer2(at)yahoo.com> >> > To: commander-list(at)matronics.com >> > Sent: Fri, 7 Nov 2008 6:55 pm >> > Subject: Re: Commander-List: Flight Levels >> magazine - Fall 2008 issue >> > > Well, if "ome" has 520 ci then they would produce >> 2x380x520/435 >> > 908 hp. Wow, I wonder what the GTOW would be!? >> > I've always been curious about the >> wing/loading for these AC. >> They all have relatively the same wing structure. >> (longer wingtip >> > for the 680/560's) yet with bigger engines, the FAA >> allowed higher >> > gross weights. Was Aero Design able to argue that >> the original >> > design was (under powered) or over designed? Which >> was it and at >> > what HP/gross is the maximum? >> > > > --- On *Fri, 11/7/08, >> yourtcfg(at)aol.com >> > />/* >> wrote: >> > > From: yourtcfg(at)aol.com >> >> > > >> > Subject: Re: Commander-List: Flight Levels >> magazine - Fall >> > 2008 issue >> > To: commander-list(at)matronics.com >> > >> > Date: Friday, November 7, 2008, 5:12 PM >> > > Yep, I saw that too. Maybe they should have >> you proof the >> > next ome!! jb >> > > The text says it's powered by "a pair of >> geared >> Lycoming >> > 520-cubic-inch GO-435-C2B engines". >> > > > > > -----Original Message----- >> > From: Barry Collman >> <barry.collman@air-britain.co.uk >> > barry.collman@air-britain.co.uk>> >> > To: commander-list(at)matronics.com >> > >> > Sent: Fri, 7 Nov 2008 9:08 am >> > Subject: Commander-List: Flight Levels >> magazine - Fall 2008 issue >> > > Hi Guys, >> > On page 7 of the subject magazine >> there's a photo of >> N2621B, a >> > Commander 520 s/n 133. >> > The text says it's powered by "a pair >> of geared >> Lycoming >> > 520-cubic-inch GO-435-C2B engines". >> > Has anyone else spotted the (not >> deliberate) error? >> > Best Regards, >> > Barry >> > > * >> > > * >> > > * >> > > * >> > > > > >> >> > ------------------------------------------------------------------------ >> > > * >> > > * >> > >> >> >> >> >> >> * >> >> >> href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?Commander-List">http://www.matronics.com/Navigator?Commander-List >> >> href="http://forums.matronics.com">http://forums.matronics.com >> * >> >> * >> >> >> href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?Commander-List">http://www.matronics.com/Navigator?Commander-List >> href="http://forums.matronics.com">http://forums.matronics.com >> * >> >> * >> >> blank rel=nofollow>http://www.matronics.com/contribution >> " target=_blank >> rel=nofollow>http://www.matronics.com/Navigator?Commander-List >> =nofollow>http://forums.matronics.com >> * >> >> >> * >> >> * > > > ________________________________________________________________________________
Subject: CARIBBEAN COMMANDER
Date: Nov 09, 2008
HI KIDS.. I will be off line for a couple of weeks.? I am leaving in the AM to fly to San Juan PR to do an annual inspection on a TCFG members airplane, N107VC, a 500B, S/N 001.? It is great airplane with new paint and air conditioning.? When I am finished, My wife Sue and I along with two other couples will depart for an? aerial?tour of? PR and then off to the island of vieques and on the St Thomas.? We will then head for the Island of Culebra.? There is the most wonderful beach in all of the Caribbean there.? After a swim and a snack on the water we will return to?the?Isla Grande airport.? The next day we will all board a cruse ship for a week in the Eastern Caribbean.? It should be a great time,? jb ________________________________________________________________________________
Date: Nov 09, 2008
That sounds like a good time, have fun. JimA _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of yourtcfg(at)aol.com Sent: Sunday, November 09, 2008 7:52 PM Subject: Commander-List: CARIBBEAN COMMANDER HI KIDS.. I will be off line for a couple of weeks. I am leaving in the AM to fly to San Juan PR to do an annual inspection on a TCFG members airplane, N107VC, a 500B, S/N 001. It is great airplane with new paint and air conditioning. When I am finished, My wife Sue and I along with two other couples will depart for an aerial tour of PR and then off to the island of vieques and on the St Thomas. We will then head for the Island of Culebra. There is the most wonderful beach in all of the Caribbean there. After a swim and a snack on the water we will return to the Isla Grande airport. The next day we will all board a cruse ship for a week in the Eastern Caribbean. It should be a great time, jb _____ Instant access to the latest & most popular FREE games ________________________________________________________________________________
Date: Nov 09, 2008
Take a lot of pictures and video, if you can, especially the flight parts. Work, work, work; it never ends, right? _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of yourtcfg(at)aol.com Sent: Sunday, November 09, 2008 5:52 PM Subject: Commander-List: CARIBBEAN COMMANDER HI KIDS.. I will be off line for a couple of weeks. I am leaving in the AM to fly to San Juan PR to do an annual inspection on a TCFG members airplane, N107VC, a 500B, S/N 001. It is great airplane with new paint and air conditioning. When I am finished, My wife Sue and I along with two other couples will depart for an aerial tour of PR and then off to the island of vieques and on the St Thomas. We will then head for the Island of Culebra. There is the most wonderful beach in all of the Caribbean there. After a swim and a snack on the water we will return to the Isla Grande airport. The next day we will all board a cruse ship for a week in the Eastern Caribbean. It should be a great time, jb _____ Instant access to the latest & most popular FREE games ________________________________________________________________________________
Date: Nov 10, 2008
Subject: Fund Raiser List of Contributors - Please Make A Contribution
Today! Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its sort of my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take a moment and assure that your name is on that List of Contributors (LOC)? As a number of members have pointed out over the years, the List seems at least - if not a whole lot more - valuable as a building/flying/recreating/entertainment tool as your typical magazine subscription! Please take minute and assure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics PO Box 347 Livermore CA 94551-0347 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
From: "Barry Collman" <barry.collman@air-britain.co.uk>
Subject: Re: CARIBBEAN COMMANDER
Date: Nov 10, 2008
Hi JimBob, "It should be a great time"? It should be far better than that ;-) I hope you and Sue have a truly memorable break and hopefully we'll hear all about the trip when you return home. Very Best Regards, Barry ----- Original Message ----- From: yourtcfg(at)aol.com To: commander-list(at)matronics.com Sent: Monday, November 10, 2008 1:52 AM Subject: Commander-List: CARIBBEAN COMMANDER HI KIDS.. I will be off line for a couple of weeks. I am leaving in the AM to fly to San Juan PR to do an annual inspection on a TCFG members airplane, N107VC, a 500B, S/N 001. It is great airplane with new paint and air conditioning. When I am finished, My wife Sue and I along with two other couples will depart for an aerial tour of PR and then off to the island of vieques and on the St Thomas. We will then head for the Island of Culebra. There is the most wonderful beach in all of the Caribbean there. After a swim and a snack on the water we will return to the Isla Grande airport. The next day we will all board a cruse ship for a week in the Eastern Caribbean. It should be a great time, jb ------------------------------------------------------------------------- ----- Instant access to the latest & most popular FREE games ________________________________________________________________________________
Date: Nov 10, 2008
Have a great cruise!! I notice this 500B has just popped up for sale. Cheers from Oz On 10/11/08 9:23 PM, "Barry Collman" <barry.collman@air-britain.co.uk> wrote: > Hi JimBob, > > "It should be a great time"? > It should be far better than that ;-) > > I hope you and Sue have a truly memorable break and hopefully we'll hear all > about the trip when you return home. > > Very Best Regards, > Barry >> >> ----- Original Message ----- >> >> From: yourtcfg(at)aol.com >> >> To: commander-list(at)matronics.com >> >> Sent: Monday, November 10, 2008 1:52 AM >> >> Subject: Commander-List: CARIBBEAN COMMANDER >> >> >> HI KIDS.. >> I will be off line for a couple of weeks. I am leaving in the AM to fly to >> San Juan PR to do an annual inspection on a TCFG members airplane, N107VC, a >> 500B, S/N 001. It is great airplane with new paint and air conditioning. >> When I am finished, My wife Sue and I along with two other couples will >> depart for an aerial tour of PR and then off to the island of vieques and >> on the St Thomas. We will then head for the Island of Culebra. There is >> the most wonderful beach in all of the Caribbean there. After a swim and a >> snack on the water we will return to the Isla Grande airport. The next day >> we will all board a cruse ship for a week in the Eastern Caribbean. It >> should be a great time, jb >> >> >> >> Instant access to the latest & most popular FREE games >> >> >> href="http://www.matronics.com/contribution">http://www.matronics.com/chref=" >> http://www.matronics.com/Navigator?Commander-List">http://www.matronics.com/N >> avigator?Commander-List >> href="http://forums.matronics.com">http://forums.matronics.com >> > > > ________________________________________________________________________________
Date: Nov 10, 2008
Hi JimBob, Forgot to mention this earlier, but say "Hello" to Jimmy from me! Seems ages since we last saw him. Best Regards, Barry ----- Original Message ----- From: yourtcfg(at)aol.com To: commander-list(at)matronics.com Sent: Monday, November 10, 2008 1:52 AM Subject: Commander-List: CARIBBEAN COMMANDER HI KIDS.. I will be off line for a couple of weeks. I am leaving in the AM to fly to San Juan PR to do an annual inspection on a TCFG members airplane, N107VC, a 500B, S/N 001. It is great airplane with new paint and air conditioning. When I am finished, My wife Sue and I along with two other couples will depart for an aerial tour of PR and then off to the island of vieques and on the St Thomas. We will then head for the Island of Culebra. There is the most wonderful beach in all of the Caribbean there. After a swim and a snack on the water we will return to the Isla Grande airport. The next day we will all board a cruse ship for a week in the Eastern Caribbean. It should be a great time, jb ------------------------------------------------------------------------- ----- Instant access to the latest & most popular FREE games ________________________________________________________________________________
Date: Nov 12, 2008
Subject: Please Make A Contribution To Support Your Lists
Dear Listers, There is no advertising income to support the Matronics Email Lists and Forums. The operation is supported 100% by your personal Contributions during the November Fund Raiser. Please make your Contribution today to support the continued operation and upgrade of these services. You can pick up a really nice gift for making your Contribution too! You may use a Credit Card or Paypal at the Matronics Contribution Site here: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle PO Box 347 Livermore, CA 94551-0347 Thank you in advance for your generous support! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
From: "Peter Bichier" <pbichie(at)UTNet.UToledo.Edu>
Date: Nov 12, 2008
OK, just looking at the published performances (Bert Berry's pamphlets, TCFG's): if (c) is true, how come it works for certain models and not others? the straight 560 for ex. has a shorter 50' take off (950') and landing (860') capabilities than the 560E Take off (1425') & landing (1500') or even comparing with the 560A (same fuselage lengh) which needs 1240' (Take off) & 1340' (landing)? so in this case, the 560A with shorter wings has shorter landing than its extended counter part (same applies for take off) however, the 680E did gain on shorter take off (1525' vs 1540 on the 680) but exactly same landing for both: 1625' as of the effect on speed: the 680 has a max speed of 230 mph instead of 225 for the 680E, so there it seems the extended wing has a detrimental effect on speed. [quote="drwer2"]Now,thats interesting. The effect of increasing the "washout" is to (a). move the center of lift inboard, (b.) decrease overall lift and (c) improve slow speed handling and stall characteristics.These are subtle changes. This change would not have a major effect onMTOW but would place the stress where the wing was stronger. I'd give anything to see any production drawings. Thanks again Barry for being our Nexus. Willis -------- 560 Dreamer Read this topic online here: http://forums.matronics.com/viewtopic.php?p=213776#213776 ________________________________________________________________________________
Subject: National Anthem
Date: Nov 13, 2008
I thought all on the list would enjoy this... http://www.nicsysco.com/media/nationalanthem.wmv Nico ________________________________________________________________________________
From: "Tom Fisher" <tfisher(at)commandergroup.bc.ca>
Subject: Re: National Anthem
Date: Nov 13, 2008
Beautiful, I always liked the U.S.A. anthem. Tom C-GISS ----- Original Message ----- From: nico css To: commander-list(at)matronics.com Sent: Thursday, November 13, 2008 9:38 PM Subject: Commander-List: National Anthem I thought all on the list would enjoy this... http://www.nicsysco.com/media/nationalanthem.wmv Nico ________________________________________________________________________________
Date: Nov 14, 2008
Subject: Fund Raiser Lagging Last Year By Over 30%...
As of the 13th, the Fund Raiser is currently about 30% behind last year in terms of the number of Contributions. Yet, oddly the number of messages posted per day is up by 10 to 20% on the average. It costs real money to run these Lists and they are supported 100% though your Contributions during the Fund Raiser. Won't you please take a minute right now to make your Contribution to keep these Lists up and running? Contribution Page: http://www.matronics.com/contribution Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Date: Nov 16, 2008
Subject: What's My Contribution Used For?
Dear Listers, Some have asked, "What's my Contribution used for?" and that's a good question. Here are just a few examples of what your direct List support enables. It provides for the very expensive, commercial-grade T1 Internet connection used on the List insuring maximum performance and minimal contention when accessing List services. It pays for the regular system hardware and software upgrades enabling the highest performance possible for services such as the Archive Search Engine, List Browser, and Forums. It pays for 19+ years worth of online archive data available for instant random search and access. And, it offsets the many hours spent writing, developing, and maintaining the custom applications that power this List Service such as the List Browse, Search Engine, Forums, Wiki and PhotoShare. But most importantly, your List Contribution enables a forum where you and your peers can communicate freely in an environment that is free from moderation, censorship, advertising, commercialism, SPAM, and computer viruses. How many places on the Internet can you make all those statements these days? It is YOUR CONTRIBUTION that directly enables these many aspects of these valuable List services. Please support it today with your List Contribution. Its one of the best investments you can make in your Sport... List Contribution Web Site: http://www.matronics.com/contribution Thank you for your support! Matt Dralle Email List Administrator ________________________________________________________________________________
Date: Nov 17, 2008
I think the early aircraft had shorter T.O. distance because the Flight Manual called for lifting off as soon as possible retract the gear then accelerate to VMC. They latter changed that to lift off above VMC which adds to the T.O. distance. Bill Leff **************Get the Moviefone Toolbar. Showtimes, theaters, movie news & p://toolbar.aol.com/moviefone/download.html?ncid=emlcntusdown00000001) ________________________________________________________________________________
From: "Robert S. Randazzo" <rsrandazzo(at)precisionmanuals.com>
Subject: Fuel Vent heat Test?
Date: Nov 17, 2008
Commanders- Does anyone have a fool-proof method for testing the fuel vent heaters? On a whim I decided to test them by turning on the battery, connecting the buses and activating the L/R Pitot and Fuel Vent heaters. Pitots heated up enough that you could fry an egg- but the fuel probes did not warm even slightly. This made me wonder if the fuel vent heaters are load-shed without a generator on-line? (Yes yes- sometimes I have trouble keeping the big airplane stuff and the Commander stuff segregated in my brain..you should have seen me flaring at an eyeball height of 70'.. HAHAHAH.. Oh boy..fortunately it turned out okay for everyone except my ego.) We're getting into the ugly part of the icing season out here- and I'm going to be making a bunch of trips over the mountains during the winter- so I want to make sure my ice survival equipment is in top working condition. Robert S. Randazzo N414C ________________________________________________________________________________
From: "Moe-rosspistons" <moe-rosspistons(at)hotmail.com>
Subject: Re: Fuel Vent heat Test?
Date: Nov 17, 2008
Robert, The fuel vent heaters and the lift detector (stall warning switch) have temperature control on them so that they will not feel hot to the touch. The fuel vent heaters (at least on my bird) do not feel hot on a cold day, however they are warmer than the surrounding under wing skin. If you get a definitive answer about testing please share. Quite some time ago I made a similar post and did not get a complete reply from anyone. Moe N680RR Proud Holder of The Golden Pedal Award From: Robert S. Randazzo Sent: Monday, November 17, 2008 2:20 AM Subject: Commander-List: Fuel Vent heat Test? Commanders- Does anyone have a fool-proof method for testing the fuel vent heaters? On a whim I decided to test them by turning on the battery, connecting the buses and activating the L/R Pitot and Fuel Vent heaters. Pitots heated up enough that you could fry an egg- but the fuel probes did not warm even slightly. This made me wonder if the fuel vent heaters are load-shed without a generator on-line? (Yes yes- sometimes I have trouble keeping the big airplane stuff and the Commander stuff segregated in my brain..you should have seen me flaring at an eyeball height of 70'.. HAHAHAH.. Oh boy..fortunately it turned out okay for everyone except my ego.) We're getting into the ugly part of the icing season out here- and I'm going to be making a bunch of trips over the mountains during the winter- so I want to make sure my ice survival equipment is in top working condition. Robert S. Randazzo N414C ________________________________________________________________________________
Date: Nov 17, 2008
Fill a cup with ice water and submerge the vents wait a few minutes and the n turn them on. Or remove the vent heaters and put them in the freezer=2C u sing an ohmeter see if there is continuity through the thermostats. From: moe-rosspistons(at)hotmail.comTo: commander-list(at)matronics.comSubject: R e: Commander-List: Fuel Vent heat Test?Date: Mon=2C 17 Nov 2008 06:51:26 -0 800 Robert=2C The fuel vent heaters and the lift detector (stall warning switch) have tem perature control on them so that they will not feel hot to the touch. The f uel vent heaters (at least on my bird) do not feel hot on a cold day=2C how ever they are warmer than the surrounding under wing skin. If you get a de finitive answer about testing please share. Quite some time ago I made a s imilar post and did not get a complete reply from anyone. Moe N680RR Proud Holder of The Golden Pedal Award From: Robert S. Randazzo Sent: Monday=2C November 17=2C 2008 2:20 AM Subject: Commander-List: Fuel Vent heat Test? Commanders- Does anyone have a fool-proof method for testing the fuel vent heaters? On a whim I decided to test them by turning on the battery=2C connecting th e buses and activating the L/R Pitot and Fuel Vent heaters. Pitots heated up enough that you could fry an egg- but the fuel probes did not warm even slightly. This made me wonder if the fuel vent heaters are load-shed without a genera tor on-line? (Yes yes- sometimes I have trouble keeping the big airplane stuff and the Commander stuff segregated in my brain=85.you should have see n me flaring at an eyeball height of 70=92.. HAHAHAH=85. Oh boy=85.fortunat ely it turned out okay for everyone except my ego=85) We=92re getting into the ugly part of the icing season out here- and I=92m going to be making a bunch of trips over the mountains during the winter- s o I want to make sure my ice survival equipment is in top working condition . Robert S. Randazzo N414C href="http://www.matronics.com/contribution">http://www.matronics.com/chr ef="http://www.matronics.com/Navigator?Commander-List">http://www.matroni cs.com/Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com _________________________________________________________________ Color coding for safety: Windows Live Hotmail alerts you to suspicious emai l. http://windowslive.com/Explore/Hotmail?ocid=TXT_TAGLM_WL_hotmail_acq_safe ty_112008 ________________________________________________________________________________
Date: Nov 17, 2008
Mike, Do you think that it would be OK just to spray them with a c02 fire extinguisher? Moe From: mike floyd Sent: Monday, November 17, 2008 7:06 AM Subject: RE: Commander-List: Fuel Vent heat Test? Fill a cup with ice water and submerge the vents wait a few minutes and then turn them on. Or remove the vent heaters and put them in the freezer, using an ohmeter see if there is continuity through the thermostats. ------------------------------------------------------------------------- ------- From: moe-rosspistons(at)hotmail.com Subject: Re: Commander-List: Fuel Vent heat Test? Date: Mon, 17 Nov 2008 06:51:26 -0800 Robert, The fuel vent heaters and the lift detector (stall warning switch) have temperature control on them so that they will not feel hot to the touch. The fuel vent heaters (at least on my bird) do not feel hot on a cold day, however they are warmer than the surrounding under wing skin. If you get a definitive answer about testing please share. Quite some time ago I made a similar post and did not get a complete reply from anyone. Moe N680RR Proud Holder of The Golden Pedal Award From: Robert S. Randazzo Sent: Monday, November 17, 2008 2:20 AM Subject: Commander-List: Fuel Vent heat Test? Commanders- Does anyone have a fool-proof method for testing the fuel vent heaters? On a whim I decided to test them by turning on the battery, connecting the buses and activating the L/R Pitot and Fuel Vent heaters. Pitots heated up enough that you could fry an egg- but the fuel probes did not warm even slightly. This made me wonder if the fuel vent heaters are load-shed without a generator on-line? (Yes yes- sometimes I have trouble keeping the big airplane stuff and the Commander stuff segregated in my brain=85.you should have seen me flaring at an eyeball height of 70=92.. HAHAHAH=85. Oh boy=85.fortunately it turned out okay for everyone except my ego=85) We=92re getting into the ugly part of the icing season out here- and I=92m going to be making a bunch of trips over the mountains during the winter- so I want to make sure my ice survival equipment is in top working condition. Robert S. Randazzo N414C href="http://www.matronics.com/contribution">http://www.matronics.com/c href="http://www.matronics.com/Navigator?Commander-List">http://www.mat ronics.com/Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com ww.matronics.com/contribution st">http://www.matronics.com/Navigator?Commander-List ronics.com ------------------------------------------------------------------------- ------- Color coding for safety: Windows Live Hotmail alerts you to suspicious email. Sign up today. ________________________________________________________________________________
Date: Nov 17, 2008
Never tried that let me know. Probably. From: moe-rosspistons(at)hotmail.comTo: commander-list(at)matronics.comSubject: R e: Commander-List: Fuel Vent heat Test?Date: Mon=2C 17 Nov 2008 07:14:13 -0 800 Mike=2C Do you think that it would be OK just to spray them with a c02 fire extingu isher? Moe From: mike floyd Sent: Monday=2C November 17=2C 2008 7:06 AM Subject: RE: Commander-List: Fuel Vent heat Test? Fill a cup with ice water and submerge the vents wait a few minutes and the n turn them on. Or remove the vent heaters and put them in the freezer=2C u sing an ohmeter see if there is continuity through the thermostats. From: moe-rosspistons(at)hotmail.comTo: commander-list(at)matronics.comSubject: R e: Commander-List: Fuel Vent heat Test?Date: Mon=2C 17 Nov 2008 06:51:26 -0 800 Robert=2C The fuel vent heaters and the lift detector (stall warning switch) have tem perature control on them so that they will not feel hot to the touch. The f uel vent heaters (at least on my bird) do not feel hot on a cold day=2C how ever they are warmer than the surrounding under wing skin. If you get a de finitive answer about testing please share. Quite some time ago I made a s imilar post and did not get a complete reply from anyone. Moe N680RR Proud Holder of The Golden Pedal Award From: Robert S. Randazzo Sent: Monday=2C November 17=2C 2008 2:20 AM Subject: Commander-List: Fuel Vent heat Test? Commanders- Does anyone have a fool-proof method for testing the fuel vent heaters? On a whim I decided to test them by turning on the battery=2C connecting th e buses and activating the L/R Pitot and Fuel Vent heaters. Pitots heated up enough that you could fry an egg- but the fuel probes did not warm even slightly. This made me wonder if the fuel vent heaters are load-shed without a genera tor on-line? (Yes yes- sometimes I have trouble keeping the big airplane stuff and the Commander stuff segregated in my brain=85.you should have see n me flaring at an eyeball height of 70=92.. HAHAHAH=85. Oh boy=85.fortunat ely it turned out okay for everyone except my ego=85) We=92re getting into the ugly part of the icing season out here- and I=92m going to be making a bunch of trips over the mountains during the winter- s o I want to make sure my ice survival equipment is in top working condition . Robert S. Randazzo N414C href="http://www.matronics.com/contribution">http://www.matronics.com/chr ef="http://www.matronics.com/Navigator?Commander-List">http://www.matroni cs.com/Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com ww.matronics.com/contribution st">http://www.matronics.com/Navigator?Commander-List ronics.com Color coding for safety: Windows Live Hotmail alerts you to suspicious emai l. Sign up today. href="http://www.matronics.com/contribution">http://www.matronics.com/chr ef="http://www.matronics.com/Navigator?Commander-List">http://www.matroni cs.com/Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com _________________________________________________________________ Stay up to date on your PC=2C the Web=2C and your mobile phone with Windows Live /9j/4AAQSkZJRgABAQEAYABgAAD/4QAiRXhpZgAASUkqAAgAAAABAABRBAABAAAAAAAAAAAAAAD/ 2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsLDBkSEw8UHRofHh0aHBwgJC4nICIsIxwcKDcpLDAxNDQ0 Hyc5PTgyPC4zNDL/2wBDAQkJCQwLDBgNDRgyIRwhMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIy MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjL/wAARCAPmAIEDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEA AAAAAAAAAAECAwQFBgcICQoL/8QAtRAAAgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJx FDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNk ZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJ ytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQF BgcICQoL/8QAtREAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMz UvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3 eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna 4uPk5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD16iiioOQKKKKACiiigAooooAKKKKACiii gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKr394mn6ddXsisyW8Lysq9SFBJA/Kmajq djpNt9pv7mO3iyFDOepPoOprnfGdvPrHhma90rWVjtoIJnlELb0uE2crkHHY/nQMg0j4m6Nq2pRW RhuLVpTtSSYrtLdhweM12lfNEkaDTIZAoD7iCfXr/hXuXhG08QQ2pudc1IXHnxIY4NvMWB1LepGM j1pJjsdLRRRTJCiiigAooooAKKKKACiiigAooooAKKKwp/FenpPp8dsftSXs5gEkbcIwIBznrywo uNK55b45v7fXfGMghuxLaxRKkZRsjIHzAenOfyrU8J3zj4eeKtPzn7KjsrezqVIx/wABP51keOdJ XQPGDSpAsdncKJIVjHA4wRz3zz+NZUDTrFdxWWovHBdgefGn8Y5IB59zUbMrcoy/8giH/fP9a988 L6je6noqTX+nNYyo3liNicsoAw3IHX+leFaioS1hhXJO4BR3OBj+or0Dxz4v1fRddh0/SZgkFrDG 8vyBix9GPpjHAxQmDPTqKoaNqP8AamhWeouqxmeESMoOQp780xNd06W8srWGfzXvUaSFoxlWVepz +Bx9DV3JsaJOFJAJIHQd64+D4iWIma11HTr6xu4m2zROgITPQ5yCQRg9P8a6e81Ox0/b9svIYC/3 Q7YJ/CvOPFcaza/qZibcJI4XBXkH5BjH1xUylZFQjzMXxPqWqx+KbryL+ZEt1EkIRyFClQeAOD1/ GvQNDvn1LQ7O7k/1kkYL+7Dgn8xXk/iKSXXA1zPALYJAkahWyTg8E/5FeieBdLi0rwnapHI7mf8A fuWxwx4wPbgUou7HNWSNnUdUsNJgWfULuK2iZtqtIep9BXGeNdTjvvDMHiHQ9WlU2M+1WhJAYsQC GB9Pcd/es/4s6nA0VnppilMkUomZiuEZSpGAfWuRXUvs3hfUdAS2mb7RcxzRSD7q4xkH8hTbJSOj 8F+LNXj8Qx6fq+rRvaSqzlrlxkNzgBjzyccdPSvWa8U8G6VY6t40EF5Cs0YtmkKEn7wIx0/Cva6c QkFFFFMk5PxpLeWd1o17Elw1tb3BeZYycH7uAR9NwGfWsHwXoL6rJHqEkzraWdyWigBz8/yn8B93 Pripv+EeL/J/bt4d3GDnn9aZZeELqCFlfVZYSWJ2wE7T79ua4vrlFu9z0fqGIStyno0kCzRtHLEs kbDDI65BHuDXj/xJ8O6foN3p97p9uIBOzb4V+7ldvI9OtdH/AMItP/0G73/vo/41x/jzS202Ky36 hNdMzN8sjfdHHOM/5xVwxVKpLli9TGpg6tKLnJaGHKhvEgnhIyrZG7p/nIqxqFzeahdahqF80bT3 C5by8gcLjv7YqDUZXitwY2KktgkemDXSw/D3ULq1hMmqx+U4VyNhzg89aqdSMFeTsTClOo7QV2bm l6veaf4O0ckTGxksZ0kZIsgPlgnzdvzq/wCCdAmlisNZmui0cSSLBAE+7lmB5/En8ahXwbbxaf8A ZINQvwoXCq8oKZ9xjpmnWnhaOK3WI6re7lzuEMoRRz2HOKw+vUdzp/s+vaxg+LjqVx4vuItQS2SN IcW5jbBKbjszk/eOeabPevczzXL27ReXBHHtJznYmCc/hW7f+E7RraWaS8vpXjjYr5koboM+lcfL eLZ6KrNHI+/cvyDOOvJq4Vo1dYkToSoaTOk0nwje69psN7LfpDDKxIjCEnaDj+nH4VqXGoXvhfUp bJFlNnJLbx2jSqTGseDvAOeD0/U1naDpV7eaHaXEWt39vHIm5YkkICjJ6ANU2o+F9Qu7dYzrVxcY cNsuXYqPccnnmj61Ri+W+oLB15LmtdM19QsrD4haJNDvltxbXTLFKCG+YDhsdwQw4/WvKmhnstRv NOnkWR7SQxGRc/NgkZ/SvRofDd3bxLFBrt9FGvRY2Kj8ga8vV5xqt9kNMzTnzJGbnO45Jz171dOv CrflexlVw9Si1zrc1/Dmqw+HdL13UIblF1ZtttaBsM2C2XbB68Ade4rpvAOt+J9Z1pra4vkmtLVm kuDJyzBuAoI9DkgdvyFcZpmman4gvp4LJoF+z/MfM4HXAPQ812ei+BZLGF5bjUpkupeZPszbVHJ4 z360VMTTp6Seo6WEqVdYrQ9P2t6H8qK4r/hHV/5/73/v83+NFZf2hS8zf+zK3dGssESsWCDOc1JR RXiHv3uFcV478N3utS2c2n2/myqCkhMiqFXqOpHcmu1orSlUdOXNEyrUo1oOEtjyi98Ga7JapHDY Z2sOPOTpg+rV6jZo8djbxyKFdY1DAHOCBzU1FaVsRKqkpdDKhhYUW3FvUgktY5HLsWyfQ0+KFIgd g69TnrUlFc51cztYjuIRcW0sBZlEiFCy9RkYyK5yXwehsfs8N2w93TPfPaunorSFWcPhZlUowqfE rlTTLM6fpsFqzhzGuNwGM809reRmJFwwBOcen61YoqG3J3ZpH3FaI2NSiBWYsR3NZI8LaIs8kwsE 8yQ5c7mwTnPTOO9bFFOM5R+F2JnCM/iVzL0nw/YaLJcSWSOrXBBfc27pnp+Zq41nGzFizZJz1qxR RKTk7yHBKCtHRFb7DF/ef8xRVmipL55dwooooJCiiigAooooAKKKKACiiigAooooAKKKKACiiigA ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACi iigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK KACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigA ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACi iigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK KACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigA ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACi iigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK KACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigA ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACi iigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK KACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigA ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACi iigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK KACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigA ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACi iigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK KACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigA ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACi iigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK KACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigA ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACi iigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK KACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigA ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACi iigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK KACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA//Z ________________________________________________________________________________
Date: Nov 17, 2008
1. The vent heaters-are not-generally controlled-by a switch, just th e breaker and an internal thermostat.- On smaller planes, its just a ligh t bulb. - 2.- $2.00 will buy you a can of electrical contact cleaner or just a can of compressed air (for cleaning computer parts). and a $10 volt-ohm-meter. - 3. Open the inspection port, you'll need access to the leads at the vent he ater. Disconnect the power lead and test between the power and the heater. - It should show an "open" circuit (if the temp is above ~40F). - 4.- Give the vent/heater body-a shot of cleaner to chill it down.....Th e heater has a thermostat which should close and the VOM should show power going to the heater.- (it should also feel warmer to the touch if only fo r the time it takes to warm up to ambient temp. - - Another way is to remove the vent heater and do the same test on a bench, i nside where its warmer. - If you are still unsure, spend the $65 to have your A/P do it and have him swear on a stack FAA manuals.- I prefer to wait in the customer lounge an d chat up the FBO secretary.... ---- - what was that saying...."Nothing in life is sure....less so..........- oh well, I forget." - wer --- On Mon, 11/17/08, Moe-rosspistons wrote: From: Moe-rosspistons <moe-rosspistons(at)hotmail.com> Subject: Re: Commander-List: Fuel Vent heat Test? Date: Monday, November 17, 2008, 7:14 AM Mike, - Do you think that it would be OK just to spray them with a c02 fire extingu isher? - Moe From: mike floyd Sent: Monday, November 17, 2008 7:06 AM Subject: RE: Commander-List: Fuel Vent heat Test? Fill a cup with ice water and submerge the vents wait a few minutes and the n turn them on. Or remove the vent heaters and put them in the freezer, usi ng an ohmeter see if there is continuity through the thermostats. From: moe-rosspistons(at)hotmail.com Subject: Re: Commander-List: Fuel Vent heat Test? Date: Mon, 17 Nov 2008 06:51:26 -0800 #yiv1515583433 .ExternalClass p.EC_MsoNormal, #yiv1515583433 .ExternalClass li.EC_MsoNormal, #yiv1515583433 .ExternalClass div.EC_MsoNormal {margin-bottom:.0001pt;font-size:11.0pt;font-family:'Calibri', 'sans-serif' ;} #yiv1515583433 .ExternalClass a:link, #yiv1515583433 .ExternalClass span.EC _MsoHyperlink {color:blue;text-decoration:underline;} #yiv1515583433 .ExternalClass a:visited, #yiv1515583433 .ExternalClass span .EC_MsoHyperlinkFollowed {color:purple;text-decoration:underline;} #yiv1515583433 .ExternalClass span.EC_EmailStyle17 {font-family:'Calibri', 'sans-serif';color:windowtext;} #yiv1515583433 .ExternalClass .EC_MsoChpDefault {} _filtered #yiv1515583433 {} #yiv1515583433 .ExternalClass div.EC_Section1 {} Robert, - The fuel vent heaters and the lift detector (stall warning switch) have tem perature control on them so that they will not feel hot to the touch.-The fuel vent heaters (at least on my bird) do not feel hot on a cold day, how ever they are warmer than the surrounding under wing skin.- If you get a definitive answer about testing please share.- Quite some time ago I made a similar post and did not get a complete reply from anyone. - Moe N680RR Proud Holder of The Golden Pedal Award From: Robert S. Randazzo Sent: Monday, November 17, 2008 2:20 AM Subject: Commander-List: Fuel Vent heat Test? Commanders- Does anyone have a fool-proof method for testing the fuel vent heaters? - On a whim I decided to test them by turning on the battery, connecting the buses and activating the L/R Pitot and Fuel Vent heaters. - Pitots heated up enough that you could fry an egg- but the fuel probes did not warm even slightly. - This made me wonder if the fuel vent heaters are load-shed without a genera tor on-line?-- (Yes yes- sometimes I have trouble keeping the big airpl ane stuff and the Commander stuff segregated in my brain=85.you should have seen me flaring at an eyeball height of 70=92.. HAHAHAH=85. Oh boy=85.fort unately it turned out okay for everyone except my ego=85) - We=92re getting into the ugly part of the icing season out here- and I=92m going to be making a bunch of trips over the mountains during the winter- s o I want to make sure my ice survival equipment is in top working condition . - Robert S. Randazzo N414C - href="http://www.matronics.com/contribution">http://www.matronics.com/chr ef="http://www.matronics.com/Navigator?Commander-List">http://www.matroni cs.com/Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com ww.matronics.com/contribution st">http://www.matronics.com/Navigator?Commander-List ronics.com Color coding for safety: Windows Live Hotmail alerts you to suspicious emai l. Sign up today. href="http://www.matronics.com/contribution">http://www.matronics.com/chr ef="http://www.matronics.com/Navigator?Commander-List">http://www.matroni cs.com/Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com =0A=0A=0A ________________________________________________________________________________
Date: Nov 17, 2008
Willis, et al- Thanks- these are all helpful. I'm not shy about having my shop looking at squawks. I do quite a bit of work with them on a few different airplanes- so I get top notch service and no BS whatsoever when it comes to billing or having someone stop by the hangar to look at something that catches my attention. By the same token- it occurred to me that I don't really know enough about those vent heaters to determine if they are working properly or not- so I thought it was important to correct my deficiency. Robert S. Randazzo N414C From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of willis robison Sent: Monday, November 17, 2008 7:48 AM Subject: Re: Commander-List: Fuel Vent heat Test? 1. The vent heaters are not generally controlled by a switch, just the breaker and an internal thermostat. On smaller planes, its just a light bulb. 2. $2.00 will buy you a can of electrical contact cleaner or just a can of compressed air (for cleaning computer parts). and a $10 volt-ohm-meter. 3. Open the inspection port, you'll need access to the leads at the vent heater. Disconnect the power lead and test between the power and the heater. It should show an "open" circuit (if the temp is above ~40F). 4. Give the vent/heater body a shot of cleaner to chill it down.....The heater has a thermostat which should close and the VOM should show power going to the heater. (it should also feel warmer to the touch if only for the time it takes to warm up to ambient temp. Another way is to remove the vent heater and do the same test on a bench, inside where its warmer. If you are still unsure, spend the $65 to have your A/P do it and have him swear on a stack FAA manuals. I prefer to wait in the customer lounge and chat up the FBO secretary.... ---- what was that saying...."Nothing in life is sure....less so.......... oh well, I forget." wer --- On Mon, 11/17/08, Moe-rosspistons wrote: From: Moe-rosspistons <moe-rosspistons(at)hotmail.com> Subject: Re: Commander-List: Fuel Vent heat Test? Date: Monday, November 17, 2008, 7:14 AM Mike, Do you think that it would be OK just to spray them with a c02 fire extinguisher? Moe From: mike <mailto:floydgm(at)hotmail.com> floyd Sent: Monday, November 17, 2008 7:06 AM Subject: RE: Commander-List: Fuel Vent heat Test? Fill a cup with ice water and submerge the vents wait a few minutes and then turn them on. Or remove the vent heaters and put them in the freezer, using an ohmeter see if there is continuity through the thermostats. _____ From: moe-rosspistons(at)hotmail.com Subject: Re: Commander-List: Fuel Vent heat Test? Date: Mon, 17 Nov 2008 06:51:26 -0800 Robert, The fuel vent heaters and the lift detector (stall warning switch) have temperature control on them so that they will not feel hot to the touch. The fuel vent heaters (at least on my bird) do not feel hot on a cold day, however they are warmer than the surrounding under wing skin. If you get a definitive answer about testing please share. Quite some time ago I made a similar post and did not get a complete reply from anyone. Moe N680RR Proud Holder of The Golden Pedal Award From: Robert S. Randazzo <mailto:rsrandazzo(at)precisionmanuals.com> Sent: Monday, November 17, 2008 2:20 AM Subject: Commander-List: Fuel Vent heat Test? Commanders- Does anyone have a fool-proof method for testing the fuel vent heaters? On a whim I decided to test them by turning on the battery, connecting the buses and activating the L/R Pitot and Fuel Vent heaters. Pitots heated up enough that you could fry an egg- but the fuel probes did not warm even slightly. This made me wonder if the fuel vent heaters are load-shed without a generator on-line? (Yes yes- sometimes I have trouble keeping the big airplane stuff and the Commander stuff segregated in my brain..you should have seen me flaring at an eyeball height of 70'.. HAHAHAH.. Oh boy..fortunately it turned out okay for everyone except my ego.) We're getting into the ugly part of the icing season out here- and I'm going to be making a bunch of trips over the mountains during the winter- so I want to make sure my ice survival equipment is in top working condition. Robert S. Randazzo N414C href="http://www.matronics.com/contribution">http://www.matronics.com/chref "http://www.matronics.com/Navigator?Commander-List">http://www.matronics.com /Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com ww.matronics.com/contribution st">http://www.matronics.com/Navigator?Commander-List ronics.com _____ Color coding for safety: Windows Live Hotmail alerts you to suspicious email. Sign up today. <http://windowslive.com/Explore/Hotmail?ocid=TXT_TAGLM_WL_hotmail_acq_safety _112008> href="http://www.matronics.com/contribution">http://www.matronics.com/chref "http://www.matronics.com/Navigator?Commander-List">http://www.matronics.com /Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: Nov 18, 2008
Subject: What Members Are Saying...
Dear Listers, November is the Annual Matronics List Fund Raiser. The Lists are supported solely through your generous Contributions during this time. Please make your Contribution today and pick up a really nice free gift at this same time: http://www.matronics.com/contribution Listers have been including some really nice comments regarding what the Lists mean to them along with their Contributions this year. I've included a few of them below. Please read them over and see if some perhaps echo your feelings as well. Thank you for your support this year! Matt Dralle Matronics Email List and Forum Administrator ------------------------------------------------------------------------------ Best bargain in the entire industry!! -Owen B Every year your lists are better, sure #1 in e-mail list in the world. -Gary G Thank you for an awesome site! -Ashley M Your lists are important to me and well worth paying for. -Calvin A Thank you for providing such and informative and ad free environment to learn by. -Myron H As always, a valuable and extremely useful resource. Stephen T As always, a great service. -Reade G Very much appreciate this site and the communications it has enabled between builders. -Larry M This service is worth every penny. -Robert S Great site! Thanks a ton for its functionality! -Peter B The RV-10 list feels like my community. -Dave S The lists are fantastic, a great source! -Jimmy Y I've learned a lot from the List. -Gabriel F A wonderful resource. -Gerald G Well done. -Richard N Years of good service. -William M Valuable service. -Keith H The site is quite helpful. -Jon M Very interesting List that I read form the beginning. -Alain L A well managed site. -Carl B Great service. -Svein Kare J Still the most useful program on the computer. -Fergus K Great contribution to my project! -Robert K Thanks for keeping a great list. -Dt G The List continues to provide excellent information. -Tony C This is a wonderful resource that has easily saved me a bunch on my build-time. -Ralph C Thank you for providing a great service. The Zenith builder's community would be in sad shape without the Zenith-List's. -Terrence P I really do get pleasure out of reading the List every day. -Bill V Great source of information. -Arthur V Thanks for a great service. Very enjoyable. -Louis B You know we all could not do without your support!! -James S Great resource! -Douglas D Thanks for the great service. -John B ________________________________________________________________________________
Date: Nov 18, 2008
Subject: fuel vent heat check
This is so easy.- Turn on the master switch, turn on the pitot/fuel vent heat switch now take about 2 minutes then put your lips on the vents like y ou were to suck a straw.- Be sure to do this before you suck on the pitot tube.- Otherwise your lips will be burned so bad you will never be able to feel the slight warmth from the vent.- If you really do this you deser ve what you get.- In all seriousness, my vents are always quite warm to t he touch in about 30 seconds after turning on the heat switch.- I serious ly doubt that airframes of this vintage and size have load shedding.- In the 1960's I don't think Boeing or Douglas was using auto load shedding.- I think it was called a flight engineer.- CHECK ESSENTIAL!!! - dan f=0A=0A=0A ________________________________________________________________________________
Subject: Re: fuel vent heat check
Date: Nov 18, 2008
Dan, Thanks for the advice! My fuel vent heaters spliced into the air speed indicator wires. Load shedding seems to be limited to pulling the circuit breaker or turning off the switch, except the stall warning horn, and it is hot wired. Moe N680RR Proud Holder of The Golden Pedal Award From: Dan Farmer Sent: Tuesday, November 18, 2008 7:05 AM Subject: Commander-List: fuel vent heat check This is so easy. Turn on the master switch, turn on the pitot/fuel vent heat switch now take about 2 minutes then put your lips on the vents like you were to suck a straw. Be sure to do this before you suck on the pitot tube. Otherwise your lips will be burned so bad you will never be able to feel the slight warmth from the vent. If you really do this you deserve what you get. In all seriousness, my vents are always quite warm to the touch in about 30 seconds after turning on the heat switch. I seriously doubt that airframes of this vintage and size have load shedding. In the 1960's I don't think Boeing or Douglas was using auto load shedding. I think it was called a flight engineer. CHECK ESSENTIAL!!! dan f 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ________________________________________________________________________________
Date: Nov 19, 2008
Moe, Then I guess that make you da flight engineer.- I assume when you say they are tied into your air speed you are talking about the pitot heat wires.- I do not know why you would have any other wires going to your static/pitot system unless someone has put in some type of air data system which seems unlikely. But when it comes to Commanders I must bow to the holder of the GOLDEN PEDA L!! dan 69U =0A=0A=0A ________________________________________________________________________________
Subject: Old WWII footage
Date: Nov 19, 2008
I found this on YouTube - mainly about Beaufighters, but there are some shots of a Boston/Havoc. http://www.youtube.com/watch?v=vsUdbzQCm_Y&feature=rec-HM-fresh+div God bless, Andrew ________________________________________________________________________________
Subject: And Bostons/Havocs in action
Date: Nov 19, 2008
http://www.youtube.com/watch?v=1AC8HoUvdW0 ________________________________________________________________________________
Date: Nov 20, 2008
Subject: Behind By 21% - Advertising May Be Needed...?
Dear Listers, The percentage of people making a Contribution to support the Lists this year is currently lagging behind last year by approximately 21%! I'm hoping that everyone is just waiting until the last minute to show their support... ;-) Please remember that it is solely your direct Contributions that keep these Lists up and running and most importantly - AD FREE! If the members don't want to support the Lists directly, then I will likely have to start adding advertisements to offset the costs of running the Lists. But I *really* don't want to have to start doing that. I really like the non-commercial atmosphere here and I think that a lot of the members appreciate that too. Please take a moment to make a Contribution today in support of the continued ad-free operation of all these Lists: http://www.matronics.com/contribution I want to send out a word of appreciation to all of the members that have already made their generous Contribution to support the Lists! Thank you! Matt Dralle Email List Administrator ________________________________________________________________________________
Date: Nov 22, 2008
Subject: LOC
Dear Listers, Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its sort of my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take a moment and assure that your name is on that List of Contributors (LOC)? As a number of members have pointed out over the years, the List seems at least - if not a whole lot more - valuable as a building/flying/recreating/entertainment tool as your typical magazine subscription! Please take minute and assure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by popping a personal check in the mail to: Matronics Email Lists c/o Matt Dralle PO Box 347 Livermore CA 94551-0347 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Email List Administrator ________________________________________________________________________________
Date: Nov 24, 2008
Subject: Value of the List...
If you look forward to checking your List email everyday (and a lot of you have written to say that you do!), then you're probably getting at least $20 or $30 worth of Entertainment from the Lists each year. You'd pay twice that for a subscription to some lame magazine or even just a single dinner out. Isn't the List worth at least that much to you? Won't you please take a minute to make your Contribution today and support the Lists? Contribution Page: http://www.matronics.com/contribution Again, I want to say THANK YOU to everyone that has made a Contribution thus far during this year's List Fund Raiser!! These Lists are made possible exclusively through YOUR generosity!! Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Date: Nov 24, 2008
HI KIDS.? I might suggest that all of yall with vent heaters contact John Towner.? He has an "approved into known icing", (which the fuel vent heaters are not) STCd fuel vent protector that installs in just a few minutes, just in front of the vent and eliminates the need for the troublesome electric units.? jb -----Original Message----- From: Moe-rosspistons <moe-rosspistons(at)hotmail.com> Sent: Tue, 18 Nov 2008 7:39 am Subject: Re: Commander-List: fuel vent heat check Dan, ? Thanks for the advice!? My fuel vent heaters?spliced into the air speed indicator wires.? Load shedding seems to be limited to pulling the circuit breaker or turning off the switch, except the stall warning horn, and it is hot wired. ? Moe N680RR Proud Holder of The Golden Pedal Award ? From: Dan Farmer Sent: Tuesday, November 18, 2008 7:05 AM Subject: Commander-List: fuel vent heat check This is so easy.? Turn on the master switch, turn on the pitot/fuel vent heat switch now take about 2 minutes then put your lips on the vents like you were to suck a straw.? Be sure to do this before you suck on the pitot tube.? Otherwise your lips will be burned so bad you will never be able to feel the slight warmth from the vent.? If you really do this you deserve what you get.? In all seriousness, my vents are always quite warm to the touch in about 30 seconds after turning on the heat switch.? I seriously doubt that airframes of this vintage and size have load shedding.? In the 1960's I don't think Boeing or Douglas was using auto load shedding.? I think it was called a flight engineer.? CHECK ESSENTIAL!!! ? dan f 3D============================================= href='3D"http://www.matronics.com/contribution"'http://www.matronics.com/contribution 3D============================================= href='3D"http://www.matronics.com/Navigator?Commander-List"'http://www.matronics.com/Navigator?Commander-List 3D============================================= href='3D"http://forums.matronics.com"'http://forums.matronics.com 3D============================================= ________________________________________________________________________________
Date: Nov 24, 2008
Jim, How was your Caribbean vacation? Give us the scoop! How's Jimmy doing? /John yourtcfg(at)aol.com wrote: > HI KIDS. I might suggest that all of yall with vent heaters contact > John Towner. He has an "approved into known icing", (which the fuel > vent heaters are not) STCd fuel vent protector that installs in just a > few minutes, just in front of the vent and eliminates the need for the > troublesome electric units. jb > > > -----Original Message----- > From: Moe-rosspistons <moe-rosspistons(at)hotmail.com> > To: commander-list(at)matronics.com > Sent: Tue, 18 Nov 2008 7:39 am > Subject: Re: Commander-List: fuel vent heat check > > *Dan,* > ** > *Thanks for the advice! My fuel vent heaters spliced into the air > speed indicator wires. Load shedding seems to be limited to pulling > the circuit breaker or turning off the switch, except the stall > warning horn, and it is hot wired.* > ** > *Moe* > *N680RR* > *Proud Holder of The Golden Pedal Award* > > > *From:* Dan Farmer > *Sent:* Tuesday, November 18, 2008 7:05 AM > *To:* commander-list-digest(at)matronics.com > > *Subject:* Commander-List: fuel vent heat check > > This is so easy. Turn on the master switch, turn on the pitot/fuel > vent heat switch now take about 2 minutes then put your lips on the > vents like you were to suck a straw. Be sure to do this before you > suck on the pitot tube. Otherwise your lips will be burned so bad you > will never be able to feel the slight warmth from the vent. If you > really do this you deserve what you get. In all seriousness, my vents > are always quite warm to the touch in about 30 seconds after turning > on the heat switch. I seriously doubt that airframes of this vintage > and size have load shedding. In the 1960's I don't think Boeing or > Douglas was using auto load shedding. I think it was called a flight > engineer. CHECK ESSENTIAL!!! > > dan f > > > * 3D============================================= href='3D"http://www.matronics.com/contribution"'http://www.matronics.com/contribution 3D============================================= href='3D"http://www.matronics.com/Navigator?Commander-List"'http://www.matronics.com/Navigator?Commander-List 3D============================================= href='3D" > > * ________________________________________________________________________________
Date: Nov 25, 2008
IT WAS GREAAAAAAAAAAAAAAT!!!? I did the annual on Jimmy's Commander then borrowed it to fly Sue and I and two other couples to Culebra.? Flamenco beach is the number two most beautiful beach in all the Caribbean and it really is.? We had lunch in town at a little place called the Dingy Dock where you can literally eat you hamburger in paradise while you soak your feet in the Caribbean.? There were half a dozen 4,to 5, long Tarpon fish under the dock.? They are really impressive fish and show bright silver when the sun shines on them.? I found a good size male iguana to chase into the water.? We the shopped around town a bit and headed for the beach.? There were a few "T" storms in the distance and had the water a bit disturbed.? The normally calm beach had 4 to 5 foot breakers and we had a total blast!!!? We spent two hours frolicking in the waves, body surfing and enjoying the wonderfully, warm water.? There is an old abandoned WW 2 tank on the next beach over and we walked over to it.? We then flew back to Isle Grande airport in air conditioned, Commander comfort and boarded the cruse ship the next day. A big thank you to TCFG member Sergio Molina for rounding up his jacks and a mule for the retract test.? Sergio operates a straight 500 on a 135?certificate and is a really nice guy.? While the ship was leaving the port of St Lucia, we were all standing on the deck and lo and behold, a 500B (short nose) entered the patter at the airport and landed!!? way cool.? Jimmy is doing great,? We got a tour of his new home in Old San Juan,? It is a truly amazing project.? It will be two years of work when complete in the spring and worth every day.? I am sure you will?be able to see it in an architectural magazine someday.? His wife and kids are well, although his wife was suffering from some back pain.? On another note.? Saw the 007 movie last night and there is a brief scene of a Commander , only in the background.? Also, My bride was watching "Wife Sw a p" a couple of days ago and there was several really good shots of Turbine, dash 10 in the story.? They episode was filmed in FL.? Sue and I are leaving a a couple of hours to fly triple 2 to Idaho for "T" day.? Then back to work delivering a 560E from Morris shop to FL.? jb How was your Caribbean vacation? Give us the scoop! How's Jimmy doing? -----Original Message----- From: John Vormbaum <john(at)vormbaum.com> Sent: Mon, 24 Nov 2008 8:31 am Subject: Re: Commander-List: fuel vent heat check ? Jim,? ? How was your Caribbean vacation? Give us the scoop! How's Jimmy doing?? ? /John? ? yourtcfg(at)aol.com wrote:? > HI KIDS. I might suggest that all of yall with vent heaters contact > John Towner. He has an "approved into known icing", (which the fuel > vent heaters are not) STCd fuel vent protector that installs in just a > few minutes, just in front of the vent and eliminates the need for the > troublesome electric units. jb? >? >? > -----Original Message-----? > From: Moe-rosspistons <moe-rosspistons(at)hotmail.com>? > To: commander-list(at)matronics.com? > Sent: Tue, 18 Nov 2008 7:39 am? > Subject: Re: Commander-List: fuel vent heat check? >? > *Dan,*? > ** > *Thanks for the advice! My fuel vent heaters spliced into the air > speed indicator wires. Load shedding seems to be limited to pulling > the circuit breaker or turning off the switch, except the stall > warning horn, and it is hot wired.*? > ** > *Moe*? > *N680RR*? > *Proud Holder of The Golden Pedal Award*? > >? > *From:* Dan Farmer ? > *Sent:* Tuesday, November 18, 2008 7:05 AM? > *To:* commander-list-digest(at)matronics.com > ? > *Subject:* Commander-List: fuel vent heat check? >? > This is so easy. Turn on the master switch, turn on the pitot/fuel > vent heat switch now take about 2 minutes then put your lips on the > vents like you were to suck a straw. Be sure to do this before you > suck on the pitot tube. Otherwise your lips will be burned so bad you > will never be able to feel the slight warmth from the vent. If you > really do this you deserve what you get. In all seriousness, my vents > are always quite warm to the touch in about 30 seconds after turning > on the heat switch. I seriously doubt that airframes of this vintage > and size have load shedding. In the 1960's I don't think Boeing or > Douglas was using auto load shedding. I think it was called a flight > engineer. CHECK ESSENTIAL!!!? > > dan f? >? >? > * 3D============================================= href='3D"http://www.matronics.com/contribution"'http://www.matronics.com/contribution 3D============================================= href='3D"http://www.matronics.com/Navigator?Commander-List"'http://www.matronics.com/Navigator?Commander-List 3D============================================= href='3D"? >? > *? ? ? ? ________________________________________________________________________________
Date: Nov 25, 2008
Wow Jim, sounds like you had a great time! I bet you feel refreshed after that. Poor guy, having to get back to "the grind" of flying Commanders hither and yon..... yourtcfg(at)aol.com wrote: > IT WAS GREAAAAAAAAAAAAAAT!!! I did the annual on Jimmy's Commander > then borrowed it to fly Sue and I and two other couples to Culebra. > Flamenco beach is the number two most beautiful beach in all the > Caribbean and it really is. We had lunch in town at a little place > called the Dingy Dock where you can literally eat you hamburger in > paradise while you soak your feet in the Caribbean. There were half a > dozen 4,to 5, long Tarpon fish under the dock. They are really > impressive fish and show bright silver when the sun shines on them. I > found a good size male iguana to chase into the water. We the shopped > around town a bit and headed for the beach. There were a few "T" > storms in the distance and had the water a bit disturbed. The > normally calm beach had 4 to 5 foot breakers and we had a total > blast!!! We spent two hours frolicking in the waves, body surfing and > enjoying the wonderfully, warm water. There is an o ld abandoned WW 2 > tank on the next beach over and we walked over to it. We then flew > back to Isle Grande airport in air conditioned, Commander comfort and > boarded the cruse ship the next day. A big thank you to TCFG member > Sergio Molina for rounding up his jacks and a mule for the retract > test. Sergio operates a straight 500 on a 135 certificate and is a > really nice guy. While the ship was leaving the port of St Lucia, we > were all standing on the deck and lo and behold, a 500B (short nose) > entered the patter at the airport and landed!! way cool. Jimmy is > doing great, We got a tour of his new home in Old San Juan, It is a > truly amazing project. It will be two years of work when complete in > the spring and worth every day. I am sure you will be able to see it > in an architectural magazine someday. His wife and kids are well, > although his wife was suffering from some back pain. On another > note. Saw t he 007 movie last night and there is a brief scene of a > Commander , only in the background. Also, My bride was watching "Wife > Swap" a couple of days ago and there was several really good shots of > Turbine, dash 10 in the story. They episode was filmed in FL. Sue > and I are leaving a a couple of hours to fly triple 2 to Idaho for "T" > day. Then back to work delivering a 560E from Morris shop to FL. jb > > How was your Caribbean vacation? Give us the scoop! How's Jimmy doing? > > > -----Original Message----- > From: John Vormbaum <john(at)vormbaum.com> > To: commander-list(at)matronics.com > Sent: Mon, 24 Nov 2008 8:31 am > Subject: Re: Commander-List: fuel vent heat check > > > > > Jim, > > How was your Caribbean vacation? Give us the scoop! How's Jimmy doing? > > /John > > yourtcfg(at)aol.com wrote: > > HI KIDS. I might suggest that all of yall with vent heaters contact > > John Towner. He has an "approved into known icing", (which the fuel > > vent heaters are not) STCd fuel vent protector that installs in just > a > few minutes, just in front of the vent and eliminates the need for > the > troublesome electric units. jb > > > > > > -----Original Message----- > > From: Moe-rosspistons <moe-rosspistons(at)hotmail.com > > > > To: commander-list(at)matronics.com > > Sent: Tue, 18 Nov 2008 7:39 am > > Subject: Re: Commander-List: fuel vent heat check > > > > *Dan,* > > ** > *Thanks for the advice! My fuel vent heaters spliced into the > air > speed indicator wires. Load shedding seems to be limited to > pulling > the circuit breaker or turning off the switch, except the > stall > warning horn, and it is hot wired.* > > ** > *Moe* > > *N680RR* > > *Proud Holder of The Golden Pedal Award* > > > > > *From:* Dan Farmer > > > *Sent:* Tuesday, November 18, 2008 7:05 AM > > *To:* commander-list-digest(at)matronics.com > > > > > > *Subject:* Commander-List: fuel vent heat check > > > > This is so easy. Turn on the master switch, turn on the pitot/fuel > > vent heat switch now take about 2 minutes then put your lips on the > > vents like you were to suck a straw. Be sure to do this before you > > suck on the pitot tube. Otherwise your lips will be burned so bad you > > will never be able to feel the slight warmth from the vent. If you > > really do this you deserve what you get. In all seriousness, my vents > > are always quite warm to the touch in about 30 seconds after turning > > on the heat switch. I seriously doubt that airframes of this vintage > > and size have load shedding. In the 1960's I don't think Boeing or > > Douglas was using auto load shedding. I think it was called a flight > > engineer. CHECK ESSENTIAL!!! > > > dan f > > > > > > * > 3D============================================= > href='3D"http://www.matronics.com/contribution"'http://www.matronics.com/contribution > 3D============================================= > href='3D"http://www.matronics.com/Navigator?Commander-List"'http://www.matronics.com/Navigator?Commander-List > 3D============================================= > href='3D" > > > > * > > > > * > > * ________________________________________________________________________________
Date: Nov 25, 2008
Subject: Commander engines available
FYI to any MrRPM owners. A friend of mine has a pair of good IO-720's for sale. They are the model used on the MRRPM conversions. These are a fairly rare upstack engine, so they would be a darn good thing to have on hand if you have them on your airplane. Contact me off-list if you want more info. Chris ________________________________________________________________________________
Date: Nov 26, 2008
Subject: Just A Few More Days...
Dear Listers, There are just a few more days left in this year's List Fund Raiser. There are some great gifts available when you make a qualifying Contribution and there's plenty still available. Don't forget that its *your* Contribution that keeps the computers running, the electricity turned on, and the computer room AC cooling! If you look forward to reading your List email each day, won't you please take a minute right now to make your personal Contribution? Credit Card or Paypal: http://www.matronics.com/contribution Personal Check: Matronics / Matt Dralle PO Box 347 Livermore, CA 94550 Thank you for your support! Matt Dralle ________________________________________________________________________________
Subject: Thanksgiving
Date: Nov 26, 2008
A reason to give thanks for a decent job. ________________________________________________________________________________
Subject: Over the Grand Canyon with no wings
Date: Nov 27, 2008
http://www.denverpost.com/breakingnews/ci_11066141 ________________________________________________________________________________
Date: Nov 28, 2008
Subject: Just 3 Days Left - Please Make Your List Contribution
Today! There are only three days left until the end of this year's List Fund Raiser. Please take a minute to show your support as so many others have this year and make sure YOUR name is on the forthcoming List of Contributors 2008! Its quick and easy using the secure web site with a credit card or PayPal: http://www.matronics.com/contribution or by sending your personal check to: Matronics Lists c/o Matt Dralle PO Box 347 Livermore, CA 94551-0347 (Please write your email address on the check!) Thank you in advance for your support of these List services! Matt Dralle Matronics Email and Forum Administrator ________________________________________________________________________________
Date: Nov 29, 2008
Subject: What Listers Have Been Saying
Wow! Many of the members making a List Support Contribution this year have been using the Comments field to leave a personal message about the Lists. Thank you! I have included a number of them below. Please read over a few and see if you perhaps can echo some of the same sentiments regarding the value of the Lists to you... There is only a couple more days left for this year's List Fund Raiser and we're still way behind previous years. If you've been waiting until the last minute to show your support, Now is the Time! Please make your Contribution and pick up a great gift at the same time! By Credit Card or Paypal: http://www.matronics.com/contribution or By Personal Check: Matronics / Matt Dralle PO Box 347 Livermore, CA 94550-7227 Thank you in advance!! Matt Dralle Email List and Forums Administrator Here is some of the great feedback members have been including along with their personal Contributions this year... Over the years, the info I have received from the RV-List has saved me thousands of dollars, and dozens of hours of time by helping me avoid bad purchases, pointing me at vendors with low prices and excellent support, and providing solutions to the typical head scratchers that you run into. Kevin H Valuable service. Best List(s) on the Internet! George A Please accept this token not as an indicator of what this list has been worth to me this past year. Lew G Great information and entertainment. Tim V Thanks again for another great year of service. This project would be beyond me if it were not for the list. Moreover, the friendships I have found are worth their weight in GOLD! Robert B Great support you provide to all the subscribers! Freddie H Read it every day. PF B Thanks for your excellent management of the Matronics Lists! Your services are head and shoulders above the rest. James M Without the "List", there would be no Kolb "community". Bill T Thanks, Matt, for a great service! I've been monitoring and using the lists since 1999. Richard D Thanks for such a terrific site and for all the work and effort you put into it. John R A great service year after year. John D ..another year of fantastic service. Jerry B This list is a great resource. Arden A Great list. James M Lists were a great help while building HRII N561FS. John S Great resources for both the beginner and experienced. George R Good service. Gary G The List is an invaluable resource! William C AeroElectric list is a great source of info and learning! Janice J Thank you, Matt for being there for us making it all happen on the List for so many years - Great JOB! Sam S Thank you for providing a great venue. You definitely hit the nail on the head with your solicitation asking if readers look forward to receiving the email digests. I certainly do and when I move from a dreamer to a builder, I expect the anticipation will only increase. Joe S Thanks for a Perfect working list. Hans-Peter R Great List Bryan K Such a great selection of valuable forums! David G Nice job! Walt E Good resource... Robert P Thank you for another great year! Scott S I could not do this without you... Robert D I believe I've been a list member for over a decade now. Thanks for the service! Tim L Great List Hendrik W ________________________________________________________________________________
Subject: My belated Thanksgiving
Date: Nov 29, 2008
Folks, I have not publicly stated my appreciation for all the blessings that we receive in this country this year; perhaps for no good reason. I received this piece from a friend and tennis buddy who mentioned that he thought I'd appreciate it. He was right. It also prompted me to say something publicly about it; even if it took a Frog (intended endearingly) to opine about it. Many years ago, it must have been during the Carter years, before we had the privilege of living here and getting to know the people that make up the core of this nation, the American soldier was considered a weakling, a maggot-infested, brainless, and doped coward with a loud mouth and no backbone. It was an unjust image created, or allowed at least, by the leadership over here that seems to have done everything to undermine their morale and their image. Back then - once in a while casual conversation would drift across the U.S. and its involvement in world affairs - the failed rescue attempt of the Iran-hostages was dominating the international news scene and the humiliation, hot on the heels of the Vietnam War, was the lay-observer's only source to cement the image of the U.S. warrior. How sad. I read the article below and realized, whether fact or fiction, the core of those band of brothers (no sexism intended) who keep democracy and liberty alive throughout the world was made up of people as described in this essay. They are the people who are totally consumed by the calling at hand. They are the people whom the enemy fears to the core. They are the people whom we oftentimes overlook in our prayers and support. When they act, after only a split-second of consideration, we sometimes condone people, whom we elected to their offices, to subject them to the forensic and sterile scrutiny of the law, sometimes stretching over months of analysis and psychological evaluations by ring-heads armed with PhDs, to see if they were worthy of being an American Soldier. In that attack many of them stand bravely, with hardly any defense against such an onslaught; not because of the severity of it but because from where and whom it comes. One of the pillars of strength of these brave warriors is family and homeland and to endure bitter onslaughts, which sometimes rival that of the enemy outside in their severity and injury, must be unimaginably destructive. That is why I want to give thanks to those men and women who are how this article depicts them. Who are more focused, as a way of life, than a top sportsman. Those brave warriors, better men than I, keep killer-threats out of our homeland, so that I may sit down with friends and family and celebrate Thanksgiving without concern for our safety. For their sakes I write tonight. On New Year's Eve, I plan to resolve that I will plead their case more audibly and more intensely to minimize the assaults from within. I have no doubt that they have the upper hand on those from the outside. Nico Subject: A NOS FRERES D'ARMES AMERICAINS All, A lot of people discount the French Army. I can tell you from personal observation of them when I was in Afghanistan, the troops were motivated and skilled, especially the one's with the patch that said "Lgion trangre". Any problem they had was a matter of national will. Here is an essay I copied from another site. I found it especially appropriate for Thanksgiving. My rough translation of the title - "Our American Brothers in Arms". To all of you who are down-range, keep the faith. Sincerely, Jim Potts Here is the original French article cab be read in French at URL: http://omlt3-kdk3.over-blog.com/article-22935665.html Here is (a) translation : //// START //// "We have shared our daily life with two US units for quite a while - they are the first and fourth companies of a prestigious infantry battalion whose name I will withhold for the sake of military secrecy. To the common man it is a unit just like any other. But we live with them and got to know them, and we henceforth know that we have the honor to live with one of the most renowned units of the US Army - one that the movies brought to the public as series showing "ordinary soldiers thrust into extraordinary events". Who are they, those soldiers from abroad, how is their daily life, and what support do they bring to the men of our OMLT every day? Few of them belong to the Easy Company, the one the TV series focuses on. This one nowadays is named Echo Company, and it has become the support company. They have a terribly strong American accent - from our point of view the language they speak is not even English. How many times did I have to write down what I wanted to say rather than waste precious minutes trying various pronunciations of a seemingly common word? Whatever state they are from, no two accents are alike and they even admit that in some crisis situations they have difficulties understanding each other. Heavily built, fed at the earliest age with Gatorade, proteins and creatine - they are all heads and shoulders taller than us and their muscles remind us of Rambo. Our frames are amusingly skinny to them - we are wimps, even the strongest of us - and because of that they often mistake us for Afghans. Here we discover America as it is often depicted : their values are taken to their paroxysm, often amplified by promiscuity lack of privacy and the loneliness of this outpost in the middle of that Afghan valley. Honor, motherland - everything here reminds of that : the American flag floating in the wind above the outpost, just like the one on the post parcels. Even if recruits often originate from the hearth of American cities and gang territory, no one here has any goal other than to hold high and proud the star spangled banner. Each man knows he can count on the support of a whole people who provides them through the mail all that an American could miss in such a remote front-line location : books, chewing gums, razorblades, Gatorade, toothpaste etc. in such way that every man is aware of how much the American people backs him in his difficult mission. And that is a first shock to our preconceptions : the American soldier is no individualist. The team, the group, the combat team are the focus of all his attention. And they are impressive warriors! We have not come across bad ones, as strange at it may seem to you when you know how critical French people can be. Even if some of them are a bit on the heavy side, all of them provide us everyday with lessons in infantry know-how. Beyond the wearing of a combat kit that never seem to discomfort them (helmet strap, helmet, combat goggles, rifles etc.) the long hours of watch at the outpost never seem to annoy them in the slightest. On the one square meter wooden tower above the perimeter wall they stand the five consecutive hours in full battle rattle and night vision goggles on top, their sight unmoving in the directions of likely danger. No distractions, no pauses, they are like statues nights and days. At night, all movements are performed in the dark - only a handful of subdued red lights indicate the occasional presence of a soldier on the move. Same with the vehicles whose lights are covered - everything happens in pitch dark even filling the fuel tanks with the Japy (JP-8) pump. And combat? If you have seen Rambo you have seen it all - always coming to the rescue when one of our teams gets in trouble, and always in the shortest delay. That is one of their tricks : they switch from T-shirt and sandals to combat ready in three minutes. Arriving in contact with the enemy, the way they fight is simple and disconcerting : they just charge! They disembark and assault in stride, they bomb first and ask questions later - which cuts any pussyfooting short. We seldom hear any harsh word, and from 5 AM onwards the camp chores are performed in beautiful order and always with excellent spirit. A passing American helicopter stops near a stranded vehicle just to check that everything is alright; an American combat team will rush to support ours before even knowing how dangerous the mission is - from what we have been given to witness, the American soldier is a beautiful and worthy heir to those who liberated France and Europe. To those who bestow us with the honor of sharing their combat outposts and who everyday give proof of their military excellence, to those who pay the daily tribute of America's army's deployment on Afghan soil, to those we owned this article, ourselves hoping that we will always remain worthy of them and to always continue hearing them say that we are all the same band of brothers". //// END //// ________________________________________________________________________________
Subject: Re: My belated Thanksgiving
Date: Nov 29, 2008
AND AMEN.=C2-=C2- jb -----Original Message----- From: nico css <nico(at)cybersuperstore.com> Sent: Sat, 29 Nov 2008 6:23 pm Subject: Commander-List: My belated Thanksgiving Folks, I have not publicly stated my appreciation for all the blessings that we eceive in this country this year; perhaps for no good reason. I received his piece from a friend and tennis buddy who mentioned that he thought I'd ppreciate it. He was right. It also prompted me to say something publicly bout it; even if it took a Frog (intended endearingly) to opine about it. Many years ago, it must have been during the Carter years, before we had the rivilege of living here and getting to know the people that make up the ore of this nation, the American soldier was considered a weakling, a aggot-infested, brainless, and doped coward with a loud mouth and no ackbone. It was an unjust image created, or allowed at least, by the eadership over here that seems to have done everything to undermine their orale and their image. Back then - once in a while casual conversation ould drift across the U.S. and its involvement in world affairs - the ailed rescue attempt of the Iran-hostages was dominating the international ews scene and the humiliation, hot on the heels of the Vietnam War, was the ay-observer's only source to cement the image of the U.S. warrior. How sad. read the article below and realized, whether f act or fiction, the core of hose band of brothers (no sexism intended) who keep democracy and liberty live throughout the world was made up of people as described in this essay. hey are the people who are totally consumed by the calling at hand. They re the people whom the enemy fears to the core. They are the people whom we ftentimes overlook in our prayers and support. When they act, after only a plit-second of consideration, we sometimes condone people, whom we elected o their offices, to subject them to the forensic and sterile scrutiny of he law, sometimes stretching over months of analysis and psychological valuations by ring-heads armed with PhD=99s, to see if they were worth y of eing an American Soldier. In that attack many of them stand bravely, with ardly any defense against such an onslaught; not because of the severity of t but because from where and whom it comes. One of the pillars of strength f these brave warriors is family and homeland and to endure bitter nslaughts, which sometimes rival that of the enemy outside in their everity and injury, must be unimaginably destructive. That is why I want to give thanks to those men and women who are how this rticle depicts them. Who are more focused, as a way of life, than a top portsman. Those brave warriors, better men than I, keep killer-threats out f our homeland, so that I may sit down with friends and family and elebrate Thanksgiving without concern for our safety. For their sakes I rite tonight. On New Year's Eve, I=2 0plan to resolve that I will plead their case more udibly and more intensely to minimize the assaults from within. I have no oubt that they have the upper hand on those from the outside. Nico ubject: A NOS FRERES D'ARMES AMERICAINS All, A lot of people discount the French Army. I can tell you from personal bservation of them when I was in Afghanistan, the troops were motivated and killed, especially the one's with the patch that said "L=C3=A9gion =C3=A9tra ng=C3=A8re". ny problem they had was a matter of national will. Here is an essay I copied from another site. I found it especially ppropriate for Thanksgiving. My rough translation of the title - "Our merican Brothers in Arms". To all of you who are down-range, keep the faith. Sincerely, Jim Potts Here is the original French article cab be read in French at URL: http://omlt3-kdk3.over-blog.com/article-22935665.html Here is (a) translation : //// START //// "We have shared our daily life with two US units for quite a while - they re the first and fourth companies of a prestigious infantry battalion whose ame I will withhold for the sake of military secrecy. To the common man it s a unit just like any other. But we live with them and got to know them, nd we henceforth know that we have the honor to live with one of the most enowned units of the US Army - one that the movies brought to the public as eries showing "ordinary soldiers thrust into extraordinary events". Who are hey, those soldiers from abroad, how is their daily l ife, and what support o they bring to the men of our OMLT every day? Few of them belong to the asy Company, the one the TV series focuses on. This one nowadays is named cho Company, and it has become the support company. They have a terribly strong American accent - from our point of view the anguage they speak is not even English. How many times did I have to write own what I wanted to say rather than waste precious minutes trying various ronunciations of a seemingly common word? Whatever state they are from, no wo accents are alike and they even admit that in some crisis situations hey have difficulties understanding each other. Heavily built, fed at the earliest age with Gatorade, proteins and creatine they are all heads and shoulders taller than us and their muscles remind s of Rambo. Our frames are amusingly skinny to them - we are wimps, even he strongest of us - and because of that they often mistake us for Afghans. Here we discover America as it is often depicted : their values are taken to heir paroxysm, often amplified by promiscuity lack of privacy and the oneliness of this outpost in the middle of that Afghan valley. Honor, otherland - everything here reminds of that : the American flag floating in he wind above the outpost, just like the one on the post parcels. Even if ecruits often originate from the hearth of American cities and gang erritory, no one here has any goal other than to hold high and proud the tar spangled banner. Each man knows he can count on=2 0the support of a whole eople who provides them through the mail all that an American could miss in uch a remote front-line location : books, chewing gums, razorblades, atorade, toothpaste etc. in such way that every man is aware of how much he American people backs him in his difficult mission. And that is a first hock to our preconceptions : the American soldier is no individualist. The eam, the group, the combat team are the focus of all his attention. And they are impressive warriors! We have not come across bad ones, as trange at it may seem to you when you know how critical French people can e. Even if some of them are a bit on the heavy side, all of them provide us veryday with lessons in infantry know-how. Beyond the wearing of a combat it that never seem to discomfort them (helmet strap, helmet, combat oggles, rifles etc.) the long hours of watch at the outpost never seem to nnoy them in the slightest. On the one square meter wooden tower above the erimeter wall they stand the five consecutive hours in full battle rattle nd night vision goggles on top, their sight unmoving in the directions of ikely danger. No distractions, no pauses, they are like statues nights and ays. At night, all movements are performed in the dark - only a handful of ubdued red lights indicate the occasional presence of a soldier on the ove. Same with the vehicles whose lights are covered - everything happens n pitch dark even filling the fuel tanks with the Japy (JP-8) pump. And combat? If you h ave seen Rambo you have seen it all - always coming to he rescue when one of our teams gets in trouble, and always in the shortest elay. That is one of their tricks : they switch from T-shirt and sandals to ombat ready in three minutes. Arriving in contact with the enemy, the way hey fight is simple and disconcerting : they just charge! They disembark nd assault in stride, they bomb first and ask questions later - which cuts ny pussyfooting short. We seldom hear any harsh word, and from 5 AM onwards the camp chores are erformed in beautiful order and always with excellent spirit. A passing merican helicopter stops near a stranded vehicle just to check that verything is alright; an American combat team will rush to support ours efore even knowing how dangerous the mission is - from what we have been iven to witness, the American soldier is a beautiful and worthy heir to hose who liberated France and Europe. To those who bestow us with the honor of sharing their combat outposts and ho everyday give proof of their military excellence, to those who pay the aily tribute of America's army's deployment on Afghan soil, to those we wned this article, ourselves hoping that we will always remain worthy of hem and to always continue hearing them say that we are all the same band f brothers". //// END //// - -= -- Please Support Your Lists=2 0This Month -- -= (And Get Some AWESOME FREE Gifts!) - -= November is the Annual List Fund Raiser. Click on -= the Contribution link below to find out more about -= this year's Terrific Free Incentive Gifts! - -= List Contribution Web Site: - -= --> http://www.matronics.com/contribution - -= Thank you for your generous support! - -= -Matt Dralle, List Admin. - -======================== -= - The Commander-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Commander-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ________________________________________________________________________________
Subject: "T" DAT TRIP
Date: Nov 29, 2008
HI KIDS. I just got back from a couple of nice flights in "triple 2, Jim & Sue"(our 680E).? Left Tuesday from 1W1, Camas Washington,?(the home drome) to S67 Nampa Idaho, my home town.? Sue and I and our two terriers, Pratt & Whitney, left about noon.? Climbed to 9.5 and set the power at 30.-X2500 for a true A/S of about 177 kts.? Ground speed was 179-181.? Nice flight, clear and a million, smoooooothe air.? Took 1:32.?? Came back today at 6.5, then 10.5, then down to 4.5.? I set a record of the lowest sustained ground speed ever at cruse power!!!!? 32kts(at)10.5, 32X2550.? Was cruising about as fast a a Cherokee and burning about the same fuel as a DC-3!!? Bouncy, touch a cloud and you got instant ice.? We stayed VFR and came up the Columbia River gorge at 2.5.? Very rough.? I set 22.5X2550 for an A/S of only 135 indicated for the turbulence.? GS 109kts.? Landed at home in the rain.? All in all a good trip, but The going was sure better than the coming!!? It takes about 7.5 hours to driv e the same trip, so it was still a good thing.? Hope everybody had a great "T" day,?remembering that the pilgrims were celebrating and thanking GOD for their blessings.? jb ________________________________________________________________________________
Date: Nov 30, 2008
Subject: Last "Official" Day Of The List Fund Raiser!
Dear Listers, Its November 30th and that means three things:.. 1) Today I am now officially 45 years old... 2) It marks that last "official" day of this year's List Fund Raiser! 3) Its the last day I will be bugging everyone for a whole year! If you use the Lists and enjoy the content and the no-advertising, no-spam, and no-censorship way in which they're run, please make a Contribution today to support their continued operation and upkeep. Your $20 or $30 goes a long way to keep the List bills paid. I will be posting the List of Contributors next week so make sure your name is on it! Thank you to everyone that has made a Contribution so far this year! It is greatly appreciated. http://www.matronics.com/contribution Best regards, Matt Dralle Email List and Forum Administrator ________________________________________________________________________________
From: "Tom Fisher" <tfisher(at)commandergroup.bc.ca>
Subject: Re: Last "Official" Day Of The List Fund Raiser!
Date: Nov 30, 2008
Matt, a $100.00 will be in the mail next week as soon as I get a bank money order so you don't have to deal with my funny colored (US spelling) money. Tom C-GISS ----- Original Message ----- From: "Matt Dralle" <dralle(at)matronics.com> Sent: Sunday, November 30, 2008 12:07 AM Subject: Commander-List: Last "Official" Day Of The List Fund Raiser! > > Dear Listers, > > Its November 30th and that means three things:.. > > 1) Today I am now officially 45 years old... > > 2) It marks that last "official" day of this year's List Fund > Raiser! > > 3) Its the last day I will be bugging everyone for a whole year! > > If you use the Lists and enjoy the content and the no-advertising, > no-spam, and no-censorship way in which they're run, please make a > Contribution today to support their continued operation and upkeep. Your > $20 or $30 goes a long way to keep the List bills paid. > > I will be posting the List of Contributors next week so make sure your > name is on it! > > Thank you to everyone that has made a Contribution so far this year! It > is greatly appreciated. > > http://www.matronics.com/contribution > > Best regards, > > Matt Dralle > Email List and Forum Administrator > > > ________________________________________________________________________________
From: "Moe-rosspistons" <moe-rosspistons(at)hotmail.com>
Date: Nov 30, 2008
I heartily second the AMEN. Also, this question probably seems terribly naive coming from someone who has been flying for almost 30 years, however please keep in mind that I lived in Southern California, and 99% of my long distance flying was done in the warmer months (during the racing season), and now I reside in cold country with no hangar. With the geared engines, at what temperature is it advisable to do an engine pre-heat before starting them? Moe N680RR Proud Holder of The Golden Pedal Award From: yourtcfg(at)aol.com Sent: Saturday, November 29, 2008 7:19 PM Subject: Re: Commander-List: My belated Thanksgiving AND AMEN. jb -----Original Message----- From: nico css <nico(at)cybersuperstore.com> Sent: Sat, 29 Nov 2008 6:23 pm Subject: Commander-List: My belated Thanksgiving Folks, I have not publicly stated my appreciation for all the blessings that we receive in this country this year; perhaps for no good reason. I received this piece from a friend and tennis buddy who mentioned that he thought I'd appreciate it. He was right. It also prompted me to say something publicly about it; even if it took a Frog (intended endearingly) to opine about it. Many years ago, it must have been during the Carter years, before we had the privilege of living here and getting to know the people that make up the core of this nation, the American soldier was considered a weakling, a maggot-infested, brainless, and doped coward with a loud mouth and no backbone. It was an unjust image created, or allowed at least, by the leadership over here that seems to have done everything to undermine their morale and their image. Back then - once in a while casual conversation would drift across the U.S . and its involvement in world affairs - the failed rescue attempt of the Iran-hostages was dominating the international news scene and the humiliation, hot on the heels of the Vietnam War, was the lay-observer's only source to cement the image of the U.S. warrior. How sad. I read the article below and realized, whether fact or fiction, the core of those band of brothers (no sexism intended) who keep democracy and liberty alive throughout the world was made up of people as described in this essay. They are the people who are totally consumed by the calling at hand. They are the people whom the enemy fears to the core. They are the people whom we oftentimes overlook in our prayers and support. When they act, after only a split-second of consideration, we sometimes condone people, whom we elected to their offices, to subject them to the forensic and sterile scrutiny of the law, sometimes stretching over months of analysis and psychological evaluations by ring-heads armed with PhD=99s, to see if they were worthy of being an American Soldier. In that attack many of them stand bravely, with hardly any defense against such an onslaught; not because of the severity of it but because from where and whom it comes. One of the pillars of strength of these brave warriors is family and homeland and to endure bitter onslaughts, which sometimes rival that of the enemy outside in their severity and injury, must be unimaginably destructive. That is why I want to give thanks to those men and women who are how this article depicts them. Who are more focused, as a way of life, than a top sportsman. Those brave warriors, better men than I, keep killer-threats out of our homeland, so that I may sit down with friends and family and celebrate Thanksgiving without concern for our safety. For their sakes I write tonight. On New Year's Eve, I plan to resolve that I will plead their case more audibly and more intensely to minimize the assaults from within. I have no doubt that they have the upper hand on those from the outside. Nico Subject: A NOS FRERES D'ARMES AMERICAINS All, A lot of people discount the French Army. I can tell you from personal observation of them when I was in Afghanistan, the troops were motivated and skilled, especially the one's with the patch that said "L=C3=A9gion =C3=A9trang=C3=A8re". Any problem they had was a matter of national will. Here is an essay I copied from another site. I found it especially appropriate for Thanksgiving. My rough translation of the title - "Our American Brothers in Arms". To all of you who are down-range, keep the faith. Sincerely, Jim Potts Here is the original French article cab be read in French at URL: http://omlt3-kdk3.over-blog.com/article-22935665.html Here is (a) translation : //// START //// "We have shared our daily life with two US units for quite a while - they are the first and fourth companies of a prestigious infantry battalion whose name I will withhold for the sake of military secrecy. To the common man it is a unit just like any other. But we live with them and got to know them, and we henceforth know that we have the honor to live with one of the most renowned units of the US Army - one that the movies brought to the public as series showing "ordinary soldiers thrust into extraordinary events". Who are they, those soldiers from abroad, how is their daily life, and what support do they bring to the men of our OMLT every day? Few of them belong to the Easy Company, the one the TV series focuses on. This one nowadays is named Echo Company, and it has become the support company. They have a terribly strong American accent - from our point of view the language they speak is not even English. How many times did I have to write down what I wanted to say rather than waste precious minutes trying various pronunciations of a seemingly common word? Whatever state they are from, no two accents are alike and they even admit that in some crisis situations they have difficulties understanding each other. Heavily built, fed at the earliest age with Gatorade, proteins and creatine - they are all heads and shoulders taller than us and their muscles remind us of Rambo. Our frames are amusingly skinny to them - we ar e wimps, even the strongest of us - and because of that they often mistake us for Afghans. Here we discover America as it is often depicted : their values are taken to their paroxysm, often amplified by promiscuity lack of privacy and the loneliness of this outpost in the middle of that Afghan valley. Honor, motherland - everything here reminds of that : the American flag floating in the wind above the outpost, just like the one on the post parcels. Even if recruits often originate from the hearth of American cities and gang territory, no one here has any goal other than to hold high and proud the star spangled banner. Each man knows he can count on the support of a whole people who provides them through the mail all that an American could miss in such a remote front-line location : books, chewing gums, razorblades, Gatorade, toothpaste etc. in such way that every man is aware of how much the American people backs him in his difficult mission. And that is a first shock to our preconceptions : the American soldier is no individualist. The team, the group, the combat team are the focus of all his attention. And they are impressive warriors! We have not come across bad ones, as strange at it may seem to you when you know how critical French people can be. Even if some of them are a bit on the heavy side, all of them provide us everyday with lessons in infantry know-how. Beyond the wearing of a combat kit that never seem to d iscomfort them (helmet strap, helmet, combat goggles, rifles etc.) the long hours of watch at the outpost never seem to annoy them in the slightest. On the one square meter wooden tower above the perimeter wall they stand the five consecutive hours in full battle rattle and night vision goggles on top, their sight unmoving in the directions of likely danger. No distractions, no pauses, they are like statues nights and days. At night, all movements are performed in the dark - only a handful of subdued red lights indicate the occasional presence of a soldier on the move. Same with the vehicles whose lights are covered - everything happens in pitch dark even filling the fuel tanks with the Japy (JP-8) pump. And combat? If you have seen Rambo you have seen it all - always coming to the rescue when one of our teams gets in trouble, and always in the shortest delay. That is one of their tricks : they switch from T-shirt and sandals to combat ready in three minutes. Arriving in contact with the enemy, the way they fight is simple and disconcerting : they just charge! They disembark and assault in stride, they bomb first and ask questions later - which cuts any pussyfooting short. We seldom hear any harsh word, and from 5 AM onwards the camp chores are performed in beautiful order and always with excellent spirit. A passing American helicopter stops near a stranded vehicle just to check that everything is alright; an American combat team will rush to support ours before even knowing how dangerous the mission is - from what we have been given to witness, the American soldier is a beautiful and worthy heir to those who liberated France and Europe. To those who bestow us with the honor of sharing their combat outposts and who everyday give proof of their military excellence, to those who pay the daily tribute of America's army's deployment on Afghan soil, to those we owned this article, ourselves hoping that we will always remain worthy of them and to always continue hearing them say that we are all the same band of brothers". //// END //// lank>http://www.matronics.com/contribution ====3D==================== target=_blank>http://www.matronics.com/Navigator?Commander-List ://forums.matronics.com ------------------------------------------------------------------------- ------- Tis the season to save your money! Get the new AOL Holiday Toolbar for money saving offers and gift ideas. ________________________________________________________________________________
Date: Nov 30, 2008
HI MOE (GPA holder) About 20F or so.=C2- I have started them in MUCH colder weather with no he at , but it is not the best thing for them.=C2- Keep the RPM as low as pra ctical for 30-40 seconds to make certain the blowers have oil, then smoothly advance the throttles to about 12-1500 RPM.=C2- Keep the cowl flaps close d (you should be parking with them closed anyway) and open them on climb out only as required.=C2- jb With the geared engines, at what temperature is it advisable to do=C2-an e ngine=C2-pre-heat before starting them? -----Original Message----- From: Moe-rosspistons <moe-rosspistons(at)hotmail.com> Sent: Sun, 30 Nov 2008 7:24 am Subject: Re: Commander-List: My belated Thanksgiving I heartily second the AMEN. =C2- Also, this question probably seems terribly naive coming from someone who ha s been flying for almost 30 years, however please keep in mind that I lived in Southern California, and 99% of my long distance flying was done in the w armer months (during the racing season), and now I reside=C2-in cold count ry with no hangar.=C2- With the geared engines, at what temperature is it advisable to do=C2-an engine=C2-pre-heat before starting them? =C2- Moe N680RR Proud Holder of The Golden Pedal Award =C2- From: yourtcfg(at)aol.com Sent: Saturday, November 29, 2008 7:19 PM Subject: Re: Commander-List: My belated Thanksgiving AND AMEN.=C2-=C2- jb -----Original Message----- From:20nico css Sent: Sat, 29 Nov 2008 6:23 pm Subject: Commander-List: My belated Thanksgiving Folks, I have not publicly stated my appreciation for all the blessings that we eceive in this country this year; perhaps for no good reason. I received his piece from a friend and tennis buddy who mentioned that he thought I'd ppreciate it. He was right. It also prompted me to say something publicly bout it; even if it took a Frog (intended endearingly) to opine about it. Many years ago, it must have been during the Carter years, before we had the rivilege of living here and getting to know the people that make up the ore of this nation, the American soldier was considered a weakling, a aggot-infested, brainless, and doped coward with a loud mouth and no ackbone. It was an unjust image created, or allowed at least, by the eadership over here that seems to have done everything to undermine their orale and their image. Back then - once in a while casual conversation ould drift across the U.S and its involvement in world affairs - the ailed rescue attempt of the Iran-hostages was dominating the international ews scene and the humiliation, hot on the heels of the Vietnam War, was the ay-observer's only source to cement the image of the U.S. warrior. How sad. read the article below and realized, whether fact or fiction, the core of hose band of brothers (n o sexism intended) who keep democracy and liberty live throughout the world was made up of people as described in this essay. hey are the people who are totally consumed by the calling at hand. They re the people whom the enemy fears to the core. They are the people whom we ftentimes overlook in our prayers and support. When they act, after only a plit-second of consideration, we sometimes condone people, whom we elected o their offices, to subject them to the forensic and sterile scrutiny of he law, sometimes stretching over months of analysis and psychological valuations by ring-heads armed with PhD=99s, to see if they were worth y of eing an American Soldier. In that attack many of them stand bravely, with ardly any defense against such an onslaught; not because of the severity of t but because from where and whom it comes. One of the pillars of strength f these brave warriors is family and homeland and to endure bitter nslaughts, which sometimes rival that of the enemy outside in their everity and injury, must be unimaginably destructive. That is why want to give thanks to those men and women who are how this rticle depicts them. Who are more focused, as a way of life, than a top portsman. Those brave warriors, better men than I, keep killer-threats out f our homeland, so that I may sit down with friends and family and elebrate Thanksgiving without concern for our safety. For their sakes I rite tonight. On New Year's Eve, I plan to resolve that I will plead their case more=0 Dudibly and more intensely to minimize the assaults from within. I have no oubt that they have the upper hand on those from the outside. Nico ubject: A NOS FRERES D'ARMES AMERICAINS All, A lot of people discount the French Army. I can tell you from personal bservation of them when I was in Afghanistan, the troops were motivated and killed, especially the one's with the patch that said "L=C3=A9gion =C3=A9tra ng=C3=A8re". ny problem they had was a matter of national will. Here is an essay I copied from another site. I found it especially ppropriate for Thanksgiving. My rough translation of the title - "Our merican Brothers in Arms". To all of you who are down-range, keep the faith. Sincerely, Jim Potts Here is the original French article cab be read in French at URL: http://omlt3-kdk3.over-blog.com/article-22935665.html Here is (a) translation : //// START //// "We have shared our daily life with two US units for quite a while - they re the first and fourth companies of a prestigious infantry battalion whose ame I will withhold for the sake of military secrecy. To the common man it s a unit just like any other. But we live with them and got to know them, nd we henceforth know that we have the honor to live with one of the most enowned units of the US Army - one that the movies brought to the public as eries showing "ordinary soldiers thrust into extraordinary events". Who are hey, those soldiers from abroad, how is their daily life, and what support o they bring to the men o f our OMLT every day? Few of them belong to the asy Company, the one the TV series focuses on. This one nowadays is named cho Company, and it has become the support company. They have a terribly strong American accent - from our point of view the anguage they speak is not even English. How many times did I have to write own what I wanted to say rather than waste precious minutes trying various ronunciations of a seemingly common word? Whatever state they are from, no wo accents are alike and they even admit that in some crisis situations hey have difficulties understanding each other. Heavily built, fed at the earliest age with Gatorade, proteins and creatine they are all heads and shoulders taller than us and their muscles remind s of Rambo. Our frames are amusingly skinny to them - we ar wimps, even he strongest of us - and because of that they often mistake us for Afghans. Here we discover America as it is often depicted : their values are taken to heir paroxysm, often amplified by promiscuity lack of privacy and the oneliness of this outpost in the middle of that Afghan valley. Honor, otherland - everything here reminds of that : the American flag floating in he wind above the outpost, just like the one on the post parcels. Even if ecruits often originate from the hearth of American cities and gang erritory, no one here has any goal other than to hold high and proud the tar spangled banner. Each man knows he can count on the support of a whole eople who provides them=2 0through the mail all that an American could miss in uch a remote front-line location : books, chewing gums, razorblades, atorade, toothpaste etc. in such way that every man is aware of how much he American people backs him in his difficult mission. And that is a first hock to our preconceptions : the American soldier is no individualist. The eam, the group, the combat team are the focus of all his attention. And they are impressive warriors! We have not come across bad ones, as trange at it may seem to you when you know how critical French people can e. Even if some of them are a bit on the heavy side, all of them provide us veryday with lessons in infantry know-how. Beyond the wearing of a combat it that never seem to d scomfort them (helmet strap, helmet, combat oggles, rifles etc.) the long hours of watch at the outpost never seem to nnoy them in the slightest. On the one square meter wooden tower above the erimeter wall they stand the five consecutive hours in full battle rattle nd night vision goggles on top, their sight unmoving in the directions of ikely danger. No distractions, no pauses, they are like statues nights and ays. At night, all movements are performed in the dark - only a handful of ubdued red lights indicate the occasional presence of a soldier on the ove. Same with the vehicles whose lights are covered - everything happens n pitch dark even filling the fuel tanks with the Japy (JP-8) pump. And combat? If you have seen Rambo you have seen it all - always20coming to he rescue when one of our teams gets in trouble, and always in the shortest elay. That is one of their tricks : they switch from T-shirt and sandals to ombat ready in three minutes. Arriving in contact with the enemy, the way hey fight is simple and disconcerting : they just charge! They disembark nd assault in stride, they bomb first and ask questions later - which cuts ny pussyfooting short. We seldom hear any harsh word, and from 5 AM onwards the camp chores are erformed in beautiful order and always with excellent spirit. A passing merican helicopter stops near a stranded vehicle just to check that verything is alright; an American combat team will rush to support ours efore even knowing how dangerous the mission is - from what we have been iven to witness, the American soldier is a beautiful and worthy heir to hose who liberated France and Europe. To those who bestow us with the honor of sharing their combat outposts and ho everyday give proof of their military excellence, to those who pay the aily tribute of America's army's deployment on Afghan soil, to those we wned this article, ourselves hoping that we will always remain worthy of hem and to always continue hearing them say that we are all the same band f brothers". //// END //// lank>http://www.matronics.com/contribution ===3D==================== targ et=_blank>http://www.matronics.com/Navigator?Commander-List //forums.matronics.com Tis the season to save your money! Get the new AOL Holiday Toolbar20for mone y saving offers and gift ideas. href="http://www.matronics.com/contribution">http://www.matronics.com/chre f="http://www.matronics.com/Navigator?Commander-List">http://www.matronics .com/Navigator?Commander-List ref="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/chre f="http://www.matronics.com/Navigator?Commander-List">http://www.matronics .com/Navigator?Commander-List ref="http://forums.matronics.com">http://forums.matronics.com - -= -- Please Support Your Lists This Month -- -= (And Get Some AWESOME FREE Gifts!) - -= November is the Annual List Fund Raiser. Click on -= the Contribution link below to find out more about -= this year's Terrific Free Incentive Gifts! - -= List Contribution Web Site: - -= --> http://www.matronics.com/contribution - -= Thank you for your generous support! - -= -Matt Dralle, List Admin. - -======================== -= - The Commander-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Commander-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ________________________________________________________________________________
Date: Dec 01, 2008
Subject: Fwd: Fw: Pilot talk.
---------- Forwarded message ---------- From: lloyd silverman <LLOYDSSS11(at)msn.com> Date: Mon, 1 Dec 2008 22:05:40 -0500 Subject: Fw: Pilot talk. ----- Original Message ----- From: lloyd silverman<mailto:LLOYDSSS11(at)MSN.COM> Cc: commander-list ; MARIO PINELLA ; PRAC01 bill ortiz ; ROBERT KLEIN ; steve zitrin ; STEW WESTCHESTER SIGN ; WALTER LEIGH Sent: Monday, December 01, 2008 10:00 PM Subject: Fw: Pilot talk. ----- Original Message ----- From: scott<mailto:sboyn(at)frontiernet.net> Cc: edmege(at)optonline.net Sent: Monday, December 01, 2008 9:27 PM Subject: Fwd: Pilot talk. c190guy(at)yahoo.com, turbohart(at)yahoo.com, thauser(at)madbbs.com, AdnilH99(at)aol.com, whiggins(at)satx.rr.com, delcar(at)zoominternet.net, PrintHut(at)aol.com, clarekeiser(at)sbcglobal.net, MonicaBobb24(at)aol.com, R5ThRCT(at)aol.com, mpliberto(at)cableone.net, markhambob(at)juno.com, MCCARDELLJE(at)aol.com, jmoertel(at)usatek.net, f.murphy(at)harrison.lib.ms.us, rneal27(at)cableone.net, MANassr(at)aol.com, neutzling1(at)sbcglobal.net, epetrovay(at)consultant.com, stitches1(at)alltel.net, R.portzer(at)cox.net, province(at)cableone.net, robertsdl(at)mindspring.com, roup66(at)hotmail.com, jeseward(at)cableone.net, skmetta(at)yahoo.com, Mstallone(at)cableone.net, BTgk2000(at)aol.com, ottoet1(at)windstream.net, ovthames(at)bellsouth.net, Tvarble1(at)bellsouth.net, caw4(at)Cableone.net, marilynwest55(at)hotmail.com, wheeles30(at)earthlink.net, fjw(at)datasync.com, jswohio(at)woh.rr.com Subject: Fwd: Pilot talk. Some new stuff.. Most pretty witty . nick ------------------------------------------------------------------------------ Life should be easier. So should your homepage. Try the NEW From: Howard Farr <howfarrout(at)sbcglobal.net<mailto:howfarrout(at)sbcglobal.net>> Date: November 30, 2008 11:27:46 PM EST To: "Scott J. Farr" > Subject: Pilot talk. Reply-To: howfarrout(at)sbcglobal.net I hope those of you who fly in the back of the airplane aware that pilots have a sense of humor. Well, they aren't all new... and probably not all real.....but some are. ------------------------ British Airways flight asks for push back clearance from terminal. Control Tower replies: 'And where is the world's most experienced airline going today without filing a flight plan?' ----------------------- ATC: 'Alitalia 345 continue taxi holding position 26 South via Tango check for workers along taxiway.' Ali 345: 'Taxi 26 Left a via Tango. Workers checked - all are working' ----------------------- ARN851: 'Halifax Terminal, Nova 851 with you out of 13,000 for 10,000, requesting runway 15.' Halifax Terminal (female): 'Nova 851 Halifax, the last time I gave a pilot what he wanted I was on penicillin for three weeks. Expect runway 06.' -------------------------- ACA1147: ' Moncton , Air Canada 1147, can you get the winds from 167 above us?' CZQM: 'As soon as I get a chance, I will.' (some time passes with continuous radio chatter) ACA1147: ' Moncton , 1147, what are his winds up there?' CZQM: 'Standby for that, please' (more radio chatter) ACA1147: ' Moncton , can you ask company 167 for his winds?' CZQM: 'Ok, 1147 and 167, I have a little too much to do for that sort of thing right now. I'll leave it up to you guys to go over to company frequency and pass winds.' ----------------------- Lost student pilot: 'Unknown airport with Cessna 150 circling overhead, identify yourself.' ----------------------- Tower: Have you got enough fuel or not? Pilot: Yes. Tower: Yes what?? Pilot: Yes, SIR --------------------------- ATC: 'Cessna G-ARER What are your intentions? ' Cessna: 'To get my Commercial Pilots Licence and Instrument Rating.' ATC: 'I meant in the next five minutes not years.' -------------------------- Controller: AF123, say call sign of your w ingman. Pilot: Uh... approach, we're a single ship. Controller: oh, oh sh$t! You have traffic! --------------------- O'Hare Approach: USA212, cleared ILS runway 32L approach, maintain 250 knots. USA212: Roger approach, how long do you need me to maintain that speed? O'Hare Approach: All the way to the gate if you can. USA212: Ah, OK, but you better warn ground control. ---------------------- ATC: Pan Am 1, descend to 3,000 ft on QNH 1019. Pan AM 1: Could you give that to me in inches? ATC: Pan Am 1, descend to 36,000 inches on QNH 1019 ------------------------ Cessna 152: 'Flight Level Three Thousand, Seven Hundred' Controller: 'Roger, contact Houston Space Center ' -------------------------- Beech Baron: Uh, ATC, verify you want me to taxi in front of the 747. ATC: Yeah, it's OK. He's not hungry. ------------------------- Student Pilot: 'I ' m lost; I'm over a big lake and heading toward the big E.' Controller: 'Make several 90 degree turns so I can identify you on radar.' (short pause)... Controller: 'Okay then. That big lake is the Atlantic Ocean . Suggest you turn to the big W immediately ..' -------------------- Pilot: 'Approach, Acme Flt 202, with you at 12,000' and 40 DME.' Approach: 'Acme 202, cross 30 DME at and maintain 8000'.' Pilot: 'Approach, 202's unable that descent rate.' Approach: 'What's the matter 202? Don't you have speed brakes?' Pilot: 'Yup. But they're for my mistakes. Not yours.' ----------------------------- Tower: '...and for your information, you were slightly to the left of the centerline on that approach.' Speedbird: 'That's correct; and, my First Officer was slightly to the right' ------------------------------- A deer is on the runway... so... Tower: Cessna XXX cleared for take-off. Student: 'What should I do? What shou ld I do?' Inst: 'What do you think you should do?' (think-think-think) Std: 'Maybe if I taxi toward him it'll scare him away.' Inst: 'That's a good idea.' (Taxi toward deer, but deer is macho, and holds position.) Tower: Cessna XXX cleared for take-off, runway NN. Std: 'What should I do? What should I do?' Inst: 'What do you think you should do?' (think-think-think) Std: 'Maybe I should tell the tower.' Inst: 'That's a good idea.' Std: Cessna XXX, uh, there's a deer down here on the runway (long pause) Tower: Roger XXX, hold your position. Deer on runawy NN cleared for immediate departure. (Two seconds, and then -- I presume by coincidence -- the deer bolts from the runway, and runs back into the woods.) Tower: Cessna XXX cleared for departure, runway NN.Caution wake turbulence, departing deer. It had to be tough keeping that Cessna rolling straight for take-off. ----------------------- Controller: 'USA353 (sic) contact Cleveland Center 135.60. (pause) Controller: 'USA353 contact Cleveland Center 135.60!' (pause) Controller: 'USA353 you're just like my wife you never listen!' Pilot: 'Center, this is USA553, maybe if you called her by the right name you'd get a better response!' -------------------- Pilot: 'Approach, Federated 303 with you at 8000' for vectors ILS, full stop. Approach: 'Unable Federated 303. The ILS is out of service.' Pilot: 'We'll take the VOR then.' Approach: 'Sir, the VOR's in alarm right now. Standby.' Pilot: 'OK, guess it'll have to be the ADF then.' Approach: '303, unable the ADF right now for traffic saturation.' Pilot: 'OK, approach. State my intentions.' ----------------------- BB: 'Barnburner 123, Request 8300 feet.' Bay Approach: 'Barnburner 123, say reason for requested altitude.' BB: 'Because the last 2 times I've been at 8500, I've nearly been run over by so me bozo at 8500 feet going the wrong way!' Bay: 'That's a good reason. 8300 approved.' ------------------------------ Pilot: Oakland Ground, Cessna 1234 at Sierra Academy . Taxi, Destination Stockton Ground: Cessna 1234, Taxi Approved, report leaving the airport ------------------------------------ Controller: 'FAR1234 confirm your type of aircraft. Are you an Airbus 330 or 340?' Pilot: 'A340 of course!' Controller: 'Then would you mind switching on the two other engines and give me 1000 feet per minute, please?' -------------------------- Tower (in Stuttgart ): 'Lufthansa 5680, reduce to 170 knots.' Pilot: 'This is here like Frankfurt . There is also only 210 and 170 knots...But we are flexible.' Tower: 'We too. Reduce to 173 knots.' --------------------------- Tower: 'Delta Zulu Romeo, turn r ight now and report your heading.' Pilot: 'Wilco. 341, 342, 343, 344, 345...' --------------------------------- Pilot Trainee: 'Tower, please speak slowly, I am a baby in English and lonely in the cockpit' --------------------------------- M?nchen II Tower: 'LH 8610 cleared for take-off.' Pilot (LH 8610): 'But we are not even landed.' Tower: Yes, who is then standing at 26 south ? ' Pilot (LH 8801): 'LH 8801.' Tower: 'OK, then you are cleared for take-off.' -------------------------------- Tower: 'Aircraft on final, go around, there's an aircraft on the runway!' Pilot Trainee: 'Roger' (pilot continues approach) Tower: 'Aircraft, I said GO AROUND!!!'! Pilot Trainee: 'Roger' The trainee doesn't react, lands the aircraft on the numbers, rolls to a twin standing in the middle of the runway, goes around the twin and continues to the taxiway. ------------------------ Tower: ' Mission 123, do you have problems?' Pilot: 'I t hi nk, I have lost my compass.' Tower: 'Judging the way you are flying, you lost the whole instrument panel!' ----------------------- Controller: 'CRX600, are you on course to SUL?' Pilot: 'More or less.' Controller: 'So proceed a little bit more to SUL.' ---------------------------- Pilot: 'Good morning, Frankfurt ground, KLM 242 request start up and push back, please.' Tower: 'KLM 242 expect start up in two hours.' Pilot: 'Please confirm: two hours delay?' Tower: 'Affirmative.' Pilot: 'In that case, cancel the good morning!' -- LLOYD ________________________________________________________________________________
Date: Dec 01, 2008
Subject:
Subject: Great Story A nice presentation of the Wrong Way Corrigan story. Another one from the Greatest Generation! You will love the music. <http://www.youtube.com/watch?v=ttIEtl7j7k0> http://www.youtube.com:80/watch?v=ttIEtl7j7k0 You will also enjoy the Dame Vera Lynn videos that show up after the Corrigan one. They Knighted Vera Lynn after the war hence her title Dame Vera Lynn. Jim Addington N444BD ________________________________________________________________________________
Subject: mander-List:
Date: Dec 01, 2008
Date: Mon=2C 1 Dec 2008 21:20:05 -0600From: jtaddington(at)verizon.netSubject: Commander-List: To: jtaddington(at)verizon.net Subject: Great Story A nice presentation of the Wrong Way Corrigan story. Another one from the G reatest Generation!You will love the music. http://www.youtube.com:80/wat ch?v=ttIEtl7j7k0 You will also enjoy the Dame Vera Lynn videos thatshow up after the Corrigan one. They Knighted Vera Lynn after the war hence her title Dame Vera Lynn. Jim Addington N444BDTHIS IS REALLY a great presentation!! Roland Gilliam _________________________________________________________________ Proud to be a PC? Show the world. Download the =93I=92m a PC=94 Messenger t hemepack now. ________________________________________________________________________________
Subject: Re: Corrigan
Date: Dec 02, 2008
It was a great privilege to meet Corrigan back when I was a younger fellow volunteering at an aviation museum at Mitchell Field. In the eighties there were still so many living pioneers of the early days. The exhibits and aircraft were great to be around, and we had a lot of silly fun working on airplanes and engines. (Don't kneel on an aluminum drip pan while polishing a P-47 if the polisher is metal and not grounded. When a W-670 is started up in the garage on a test stand, it is loud. Did I mention the smoke?) Lindbergh's Jenny, the replica Spirit of St. Loius that Jimmy Stewart flew, and tons of neat old stuff. Fairchild/Republic and Grumman were close by, and it seemed there was always a competion to see who could liberate the most restoraton supplies. The neatest thing though was to rub shoulders with barnstormers, war vets, Clipper Captains, maintenance guys. What a treasure. Steve Subject: RE: Commander-List: From: Nancy Gilliam (amg3636(at)hotmail.com) Date: Mon Dec 01 - 7:34 PM Date: Mon, 1 Dec 2008 07:34:48 PM PST To: jtaddington(at)verizon.net Subject: Great Story A nice presentation of the Wrong Way Corrigan story. Another one from the G reatest Generation!You will love the music. http://www.youtube.com:80/watch?v=ttIEtl7j7k0 You will also enjoy the Dame Vera Lynn videos thatshow up after the Corrigan one. They Knighted Vera Lynn after the war hence her title Dame Vera Lynn. Jim Addington N444BDTHIS IS REALLY a great presentation!! Roland Gilliam _________________________________________________________________ Proud to be a PC? Show the world. Download the =93I=92m a PC=94 Messenger t hemepack now. -------------------------------------------------------------------------------- ________________________________________________________________________________
Subject: Corrigan
Date: Dec 02, 2008
Wow! A personally autographed photograph. Now, that's impressive, Steve. -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Steve at Col-East Sent: Tuesday, December 02, 2008 1:17 PM Subject: Re: Commander-List: Corrigan It was a great privilege to meet Corrigan back when I was a younger fellow volunteering at an aviation museum at Mitchell Field. In the eighties there were still so many living pioneers of the early days. The exhibits and aircraft were great to be around, and we had a lot of silly fun working on airplanes and engines. (Don't kneel on an aluminum drip pan while polishing a P-47 if the polisher is metal and not grounded. When a W-670 is started up in the garage on a test stand, it is loud. Did I mention the smoke?) Lindbergh's Jenny, the replica Spirit of St. Loius that Jimmy Stewart flew, and tons of neat old stuff. Fairchild/Republic and Grumman were close by, and it seemed there was always a competion to see who could liberate the most restoraton supplies. The neatest thing though was to rub shoulders with barnstormers, war vets, Clipper Captains, maintenance guys. What a treasure. Steve Subject: RE: Commander-List: From: Nancy Gilliam (amg3636(at)hotmail.com) Date: Mon Dec 01 - 7:34 PM Date: Mon, 1 Dec 2008 07:34:48 PM PST To: jtaddington(at)verizon.net Subject: Great Story A nice presentation of the Wrong Way Corrigan story. Another one from the G reatest Generation!You will love the music. http://www.youtube.com:80/watch?v=ttIEtl7j7k0 You will also enjoy the Dame Vera Lynn videos thatshow up after the Corrigan one. They Knighted Vera Lynn after the war hence her title Dame Vera Lynn. Jim Addington N444BDTHIS IS REALLY a great presentation!! Roland Gilliam _________________________________________________________________ Proud to be a PC? Show the world. Download the =93I=92m a PC=94 Messenger t hemepack now. ---------------------------------------------------------------------------- ---- ________________________________________________________________________________
Date: Dec 04, 2008
Subject:
I got this from a friend and thought you might like it. Jim Addington N444BD For those of you old enough to remember Jimmy Stewart in "Strategic Air Command" in the 1950's, here is a clip from that movie. Like many of the other films of that period, Stewart played a major league baseball player in the Post WWII period who is called back to active duty service to join SAC. Anyway, whoever sent out this clip found some good pictures =0 A of the interiors and exterior of the B-36. Remember, "Six Turnin' and Four Burnin"".....the six props and the four jets that were hung out on the wing to help the production models get off the ground. The B-36 was designed during WWII when the US thought that England would be lost and we would be fighting the Germans from the US and Canada. It was designed to take the War to European cities from this side of the Atlantic. Last of the piston-engined bombers.a behemoth Worth it for the sound - six piston and four jet engines You will also see Jimmy Stewart on the jump seat..... Look at all those instruments and engine contr ols at the Flight Engineer station. Also note that the Co-Pilot controls the Jet engines while the Flight Engineer controls the pistons http://www.alexisparkinn.com/photogallery/Videos/2008-4-18-B-36-SAC-Video.wm v ________________________________________________________________________________
From: Bruce Campbell <brcamp(at)windows.microsoft.com>
Date: Dec 04, 2008
Subject:
It's a pity that movie isn't available on DVD, or even better, Blueray. Som e of the best flying footage ever shot. Most folks don't remember the B-36 (I do because it was actually used as a borate bomber for a short time, al ong with the B-29 which lasted considerably longer). The story is only so- so though it would be nice if folks remembered what things we like in the e arly 50s ( like the honour of getting to be a "retread".) and what kind of debt we owe to the people who served during that time (and later, while we are at it). Bruce From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-lis t-server(at)matronics.com] On Behalf Of Jim Addington Sent: Thursday, December 04, 2008 10:11 AM Subject: Commander-List: I got this from a friend and thought you might like it. Jim Addington N444BD For those of you old enough to remember Jimmy Stewart in "Strategic Air Command" in the 1950's, here is a clip from that movie. Like many of the other films of that period, Stewart played a major league baseball player in the Post WWII period who is called back to active duty service to join SAC. Anyway, whoever sent out this clip found some good pictures =0 A of the interiors and exterior of the B-36. Remember, "Six Turnin' and Four Burnin"".....the six props and the four jets that were hung out on the wing to help the production models get off the ground. The B-36 was designed during WWII when the US thought that England would be lost and we would be fighting the Germans from the US and Canada. It was designed to take the War to European cities from this side of the Atlantic. Last of the piston-engined bombers...a behemoth Worth it for the sound - six piston and four jet engines You will also see Jimmy Stewart on the jump seat..... Look at all those instruments and engine contr ols at the Flight Engineer station. Also note that the Co-Pilot controls the Jet engines while the Flight Engineer controls the pistons http://www.alexisparkinn.com/photogallery/Videos/2008-4-18-B-36-SAC-Video.w mv ________________________________________________________________________________
Subject:
Date: Dec 04, 2008
Great footage. How many of you recognized Col. Sherman Potter's voice (MASH 4077) in the background. Only after a second look did I recognize him; he sat right of Jimmy in the opening scenes. I was wondering whether setting max power on the jets so early was because they didn't have faith in them yet at the time or what. Perhaps today that would be the last thing they did. Nico _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Jim Addington Sent: Thursday, December 04, 2008 10:11 AM Subject: Commander-List: I got this from a friend and thought you might like it. Jim Addington N444BD For those of you old enough to remember Jimmy Stewart in "Strategic Air Command" in the 1950's, here is a clip from that movie. Like many of the other films of that period, Stewart played a major league baseball player in the Post WWII period who is called back to active duty service to join SAC. Anyway, whoever sent out this clip found some good pictures =0 A of the interiors and exterior of the B-36. Remember, "Six Turnin' and Four Burnin"".....the six props and the four jets that were hung out on the wing to help the production models get off the ground. The B-36 was designed during WWII when the US thought that England would be lost and we would be fighting the Germans from the US and Canada. It was designed to take the War to European cities from this side of the Atlantic. Last of the piston-engined bombers.a behemoth Worth it for the sound - six piston and four jet engines You will also see Jimmy Stewart on the jump seat..... Look at all those instruments and engine contr ols at the Flight Engineer station. Also note that the Co-Pilot controls the Jet engines while the Flight Engineer controls the pistons http://www.alexisparkinn.com/photogallery/Videos/2008-4-18-B-36-SAC-Video.wm v ________________________________________________________________________________
Subject: Re:
Date: Dec 04, 2008
I think he was early on the throttles because it took that long to spool up. Tom C-GISS ----- Original Message ----- From: nico css To: commander-list(at)matronics.com Sent: Thursday, December 04, 2008 1:29 PM Subject: RE: Commander-List: Great footage. How many of you recognized Col. Sherman Potter's voice (MASH 4077) in the background. Only after a second look did I recognize him; he sat right of Jimmy in the opening scenes. I was wondering whether setting max power on the jets so early was because they didn't have faith in them yet at the time or what. Perhaps today that would be the last thing they did. Nico ------------------------------------------------------------------------- ----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Jim Addington Sent: Thursday, December 04, 2008 10:11 AM To: Jim Addington Subject: Commander-List: I got this from a friend and thought you might like it. Jim Addington N444BD For those of you old enough to remember Jimmy Stewart in "Strategic Air Command" in the 1950's, here is a clip from that movie. Like many of the other films of that period, Stewart played a major league baseball player in the Post WWII period who is called back to active duty service to join SAC. Anyway, whoever sent out this clip found some good pictures =0 A of the interiors and exterior of the B-36. Remember, "Six Turnin' and Four Burnin"".....the six props and the four jets that were hung out on the wing to help the production models get off the ground. The B-36 was designed during WWII when the US thought that England would be lost and we would be fighting the Germans from the US and Canada. It was designed to take the War to European cities from this side of the Atlantic. Last of the piston-engined bombers.a behemoth Worth it for the sound - six piston and four jet engines You will also see Jimmy Stewart on the jump seat..... Look at all those instruments and engine contr ols at the Flight Engineer station. Also note that the Co-Pilot controls the Jet engines while the Flight Engineer controls the pistons http://www.alexisparkinn.com/photogallery/Videos/2008-4-18-B-36-SAC-Video .wmv href="http://www.matronics.com/contribution">http://www.matronics.com/c href="http://www.matronics.com/Navigator?Commander-List">http://www.mat ronics.com/Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: Dec 04, 2008
Subject: Re: mander-List:
Bruce Campbell wrote: > > Its a pity that movie isnt available on DVD > just fyi - it is available on dvd. http://www.nostalgiafilms.com/stairco19dvd.html ________________________________________________________________________________
Date: Dec 04, 2008
I got a ride in one out of Fort Worth when I was in collage. It was a fun trip and it sure had a distinct sound. Jim N444Bd _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Bruce Campbell Sent: Thursday, December 04, 2008 12:36 PM Subject: RE: Commander-List: It's a pity that movie isn't available on DVD, or even better, Blueray. Some of the best flying footage ever shot. Most folks don't remember the B-36 (I do because it was actually used as a borate bomber for a short time, along with the B-29 which lasted considerably longer). The story is only so-so though it would be nice if folks remembered what things we like in the early 50s ( like the honour of getting to be a "retread".) and what kind of debt we owe to the people who served during that time (and later, while we are at it). Bruce From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Jim Addington Sent: Thursday, December 04, 2008 10:11 AM Subject: Commander-List: I got this from a friend and thought you might like it. Jim Addington N444BD For those of you old enough to remember Jimmy Stewart in "Strategic Air Command" in the 1950's, here is a clip from that movie. Like many of the other films of that period, Stewart played a major league baseball player in the Post WWII period who is called back to active duty service to join SAC. Anyway, whoever sent out this clip found some good pictures =0 A of the interiors and exterior of the B-36. Remember, "Six Turnin' and Four Burnin"".....the six props and the four jets that were hung out on the wing to help the production models get off the ground. The B-36 was designed during WWII when the US thought that England would be lost and we would be fighting the Germans from the US and Canada. It was designed to take the War to European cities from this side of the Atlantic. Last of the piston-engined bombers.a behemoth Worth it for the sound - six piston and four jet engines You will also see Jimmy Stewart on the jump seat..... Look at all those instruments and engine contr ols at the Flight Engineer station. Also note that the Co-Pilot controls the Jet engines while the Flight Engineer controls the pistons http://www.alexisparkinn.com/photogallery/Videos/2008-4-18-B-36-SAC-Video.wm v bsp; (And Get Some AWESOME > http://www.matronics.com/consp; <http://www.matronics.com/contribution> -M============== Archive Search & Download, 7-Day Browse, Chat, FAQ,http://www.matro=================== - MATRONICS WEB FORUMS - http://forums.matronics.com ________________________________________________________________________________
Date: Dec 05, 2008
G'day Jim et al, These days in Oz a 'distinct sound' is a pair of geared lycomings...we still have a couple of Queenairs up north here treating us to such audio! Have a great weekend Cheers Russell ________________________________________________________________________________
Date: Dec 04, 2008
I am glad you said that because I thought that was him but was not sure, Jim _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of nico css Sent: Thursday, December 04, 2008 3:29 PM Subject: RE: Commander-List: Great footage. How many of you recognized Col. Sherman Potter's voice (MASH 4077) in the background. Only after a second look did I recognize him; he sat right of Jimmy in the opening scenes. I was wondering whether setting max power on the jets so early was because they didn't have faith in them yet at the time or what. Perhaps today that would be the last thing they did. Nico _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Jim Addington Sent: Thursday, December 04, 2008 10:11 AM Subject: Commander-List: I got this from a friend and thought you might like it. Jim Addington N444BD For those of you old enough to remember Jimmy Stewart in "Strategic Air Command" in the 1950's, here is a clip from that movie. Like many of the other films of that period, Stewart played a major league baseball player in the Post WWII period who is called back to active duty service to join SAC. Anyway, whoever sent out this clip found some good pictures =0 A of the interiors and exterior of the B-36. Remember, "Six Turnin' and Four Burnin"".....the six props and the four jets that were hung out on the wing to help the production models get off the ground. The B-36 was designed during WWII when the US thought that England would be lost and we would be fighting the Germans from the US and Canada. It was designed to take the War to European cities from this side of the Atlantic. Last of the piston-engined bombers.a behemoth Worth it for the sound - six piston and four jet engines You will also see Jimmy Stewart on the jump seat..... Look at all those instruments and engine contr ols at the Flight Engineer station. Also note that the Co-Pilot controls the Jet engines while the Flight Engineer controls the pistons http://www.alexisparkinn.com/photogallery/Videos/2008-4-18-B-36-SAC-Video.wm v href="http://www.matronics.com/contribution">http://www.matronics.com/chref "http://www.matronics.com/Navigator?Commander-List">http://www.matronics.com /Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: Dec 04, 2008
I think you are right because I think those were the same engines we had on the B-47 and it could trake up to 12 seconds to spool up from idle to 100 percent. Jim _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Tom Fisher Sent: Thursday, December 04, 2008 3:59 PM Subject: Re: Commander-List: I think he was early on the throttles because it took that long to spool up. Tom C-GISS ----- Original Message ----- From: nico <mailto:nico(at)cybersuperstore.com> css Sent: Thursday, December 04, 2008 1:29 PM Subject: RE: Commander-List: Great footage. How many of you recognized Col. Sherman Potter's voice (MASH 4077) in the background. Only after a second look did I recognize him; he sat right of Jimmy in the opening scenes. I was wondering whether setting max power on the jets so early was because they didn't have faith in them yet at the time or what. Perhaps today that would be the last thing they did. Nico _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Jim Addington Sent: Thursday, December 04, 2008 10:11 AM Subject: Commander-List: I got this from a friend and thought you might like it. Jim Addington N444BD For those of you old enough to remember Jimmy Stewart in "Strategic Air Command" in the 1950's, here is a clip from that movie. Like many of the other films of that period, Stewart played a major league baseball player in the Post WWII period who is called back to active duty service to join SAC. Anyway, whoever sent out this clip found some good pictures =0 A of the interiors and exterior of the B-36. Remember, "Six Turnin' and Four Burnin"".....the six props and the four jets that were hung out on the wing to help the production models get off the ground. The B-36 was designed during WWII when the US thought that England would be lost and we would be fighting the Germans from the US and Canada. It was designed to take the War to European cities from this side of the Atlantic. Last of the piston-engined bombers.a behemoth Worth it for the sound - six piston and four jet engines You will also see Jimmy Stewart on the jump seat..... Look at all those instruments and engine contr ols at the Flight Engineer station. Also note that the Co-Pilot controls the Jet engines while the Flight Engineer controls the pistons http://www.alexisparkinn.com/photogallery/Videos/2008-4-18-B-36-SAC-Video.wm v href="http://www.matronics.com/contribution">http://www.matronics.com/chref "http://www.matronics.com/Navigator?Commander-List">http://www.matronics.com /Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/chref "http://www.matronics.com/Navigator?Commander-List">http://www.matronics.com /Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: Dec 04, 2008
And a G'day to you Russell, Those six R-4360's with the exhaust going back through the props really made the ground vibrate. I hope it is warm down there, it is cold here. Hope you have a good week too. Jim -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of rlegg(at)austarnet.com.au Sent: Thursday, December 04, 2008 4:38 PM Subject: RE: Commander-List: G'day Jim et al, These days in Oz a 'distinct sound' is a pair of geared lycomings...we still have a couple of Queenairs up north here treating us to such audio! Have a great weekend Cheers Russell ________________________________________________________________________________
Date: Dec 04, 2008
From: "Deneal Schilmeister (MacbookPro)" <deneals(at)deneals.com>
On 12/4/08 4:42 PM, "Jim Addington" wrote: > I am glad you said that because I thought that was him but was not sure, > Jim I thought it was Officer Bill Gannon from =B3Dragnet.=B2 DS ________________________________________________________________________________
From: "Bill Hamilton" <wjrhamilton(at)optusnet.com.au>
Date: Dec 06, 2008
Folks, A lovely discontinuity error, if you look closely. After the co-pilot DV window is closed, calling the pre takeoff checklist, it then cuts to an external just before the aircraft rolls, and this window is still open. Cheers, Bill Hamilton From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Deneal Schilmeister (MacbookPro) Sent: Friday, December 05, 2008 12:03 PM Subject: Re: Commander-List: On 12/4/08 4:42 PM, "Jim Addington" wrote: I am glad you said that because I thought that was him but was not sure, Jim I thought it was Officer Bill Gannon from "Dragnet." DS ________________________________________________________________________________
Date: Dec 08, 2008
Subject: List of Contributors 2008
Dear Listers, This year's Fund Raiser has drawn to a close and I want to thank everyone that so generously made a contribution this year in support of the Matronics Email List and Forum operation. Your generosity keeps the wheels on this cart and I truly appreciate the many kind words of encouragement and financial reimbursement. If you haven't yet made a Contribution in support of this year's Fund Raiser, please feel free to do so. The great List Fund Raiser gifts will be available on the Contribution site for a little while longer, so hurry and make your Contribution today and still get your great gift! Once again, the URL for the Contribution web site is: http://www.matronics.com/contribution or by personal check to: Matronics / Matt Dralle PO Box 347 Livermore CA 94551-0347 I would like to thank Andy Gold of the Builder's Bookstore ( http://www.buildersbooks.com ), Jon Croke of HomebuiltHELP ( http://www.homebuilthelp.com ) and Bob Nuckolls of AeroElectric ( http://www.aeroelectric.com ) for their extremely generous support during this year's Fund Raiser through the contribution of discounted merchandise. These are great guys that support the aviation industry and I encourage each and every Lister to have a look at their products. Thank you Andy, Jon and Bob!! Your support is very much appreciated! And finally, below you will find a web link to the 2008 List of Contributors current as of 12/7/08! Have a look at this list of names as *these* are the people that make all of these List services possible! I can't thank each of you enough for your support and great feedback during this year's Fund Raiser! THANK YOU! http://www.matronics.com/loc/2008.html I will be shipping out all of the gifts around the end of December. In most cases, gifts will be shipped via US Postal Service. Once again, thank you for making this year's List Fund Raiser successful! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
From: "David Fitzgerald" <DavidFitzgerald(at)bigpond.com>
Subject: Twin Commander facebook group
Date: Dec 08, 2008
Hi Folks There was a distinct lack of Twin Commander facebook groups, so I created one! Please come and join up if you are on facebook! http://www.facebook.com/group.php?gid=38090073191#/group.php?gid=38090073191 Dave Dr David Fitzgerald BMedSci(Hons) MBBS(Hons) ACCAM DipAvMed(Otago) DavidFitzgerald(at)bigpond.com mob 0438 312973 ============================================== 2:59 PM ________________________________________________________________________________
Subject: Re: List of Contributors 2008
Date: Dec 08, 2008
Matt, Well I guess my bank money order did not get to you in time, I don't need to be on any list but wanted to make sure you received the money order. Tom. C-GISS ----- Original Message ----- From: "Matt Dralle" <dralle(at)matronics.com> Sent: Monday, December 08, 2008 12:23 AM Subject: Commander-List: List of Contributors 2008 > > Dear Listers, > > This year's Fund Raiser has drawn to a close and I want to thank everyone > that so generously made a contribution this year in support of the > Matronics Email List and Forum operation. Your generosity keeps the > wheels on this cart and I truly appreciate the many kind words of > encouragement and financial reimbursement. > > If you haven't yet made a Contribution in support of this year's Fund > Raiser, please feel free to do so. The great List Fund Raiser gifts will > be available on the Contribution site for a little while longer, so hurry > and make your Contribution today and still get your great gift! Once > again, the URL for the Contribution web site is: > > http://www.matronics.com/contribution > > > or by personal check to: > > Matronics / Matt Dralle > PO Box 347 > Livermore CA 94551-0347 > > > I would like to thank Andy Gold of the Builder's Bookstore ( > http://www.buildersbooks.com ), Jon Croke of HomebuiltHELP ( > http://www.homebuilthelp.com ) and Bob Nuckolls of AeroElectric ( > http://www.aeroelectric.com ) for their extremely generous support during > this year's Fund Raiser through the contribution of discounted > merchandise. These are great guys that support the aviation industry and > I encourage each and every Lister to have a look at their products. Thank > you Andy, Jon and Bob!! Your support is very much appreciated! > > > And finally, below you will find a web link to the 2008 List of > Contributors current as of 12/7/08! Have a look at this list of names as > *these* are the people that make all of these List services possible! I > can't thank each of you enough for your support and great feedback during > this year's Fund Raiser! > > THANK YOU! > > http://www.matronics.com/loc/2008.html > > > I will be shipping out all of the gifts around the end of December. In > most cases, gifts will be shipped via US Postal Service. > > Once again, thank you for making this year's List Fund Raiser successful! > > Best regards, > > Matt Dralle > Matronics Email List Administrator > > > ________________________________________________________________________________
Subject: Twin Commander parts wanted
Date: Dec 11, 2008
Hi =2C I need some parts for rebuilding my Twin Commander. It is a 680FL with Serial number 1355-34 The Twin commander will be for static display only =2C so the parts dont ne ed to be in airworthy condition. I hope that someone in this group has some spare parts to sell or trade =2C or knows someone who have. Here is my most wanted items for my 1963 model 680FL ___________________________________________________ Nose landing light installation containing: 1 ea 5800005-9 Doubler =2CLH 1 ea 5800005-10 Doubler =2CRH 1ea 5800005-11 Glass =2CLH
November 06, 2008 - December 11, 2008
Commander-Archive.digest.vol-df
