Commander-Archive.digest.vol-dr
April 26, 2010 - July 10, 2010
      THANKS NICO, PLUGS ALL LOOK CLEAN AFTER RUN.
        ----- Original Message -----
        From: cybersuperstore<mailto:nico(at)cybersuperstore.com>
        Sent: Monday, April 26, 2010 7:18 PM
        Subject: RE: Commander-List: VIBRATION AT 1400RPM
        Could it be a misfire? Injector or magneto?
      owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On
      Behalf Of lloyd silverman
        Sent: Monday, April 26, 2010 4:13 PM
        Subject: Re: Commander-List: VIBRATION AT 1400RPM
        THANKSDAN. IT'S THE RIGHT ENGINE ONLY. ILL CHECK COMPRESSION AND BLADE
      ANGLES.
          To:
      commander-list(at)matronics.com
          Sent: Monday, April 26, 2010 1:03 AM
          Doctor, it hurts when I do this.
          Umm.. Don't do that?
          DJW
          On Mon, Apr 26, 2010 at 12:25 AM,
      > wrote:
          > "Excessive" vibration will not be solved by dynamic balancing.
      Both
          > engines?? Check engine compression and propeller blade angles.
      Good luck.
          > jb
          > -----Original Message-----
          > From: lloyd silverman
          > To: commander-list
          > Sent: Sun, Apr 25, 2010 6:46 pm
          > Subject: Commander-List: VIBRATION AT 1400RPM
          > MY 500B WITH IO540'S HAS EXCESIVE VIBRATION AT 1400 RPM. ANY
      IDEAS, OR CAN U
          > RECOMMEND SOMEONE WHO CAN DYNAMICALY BALANC PROP IN NEW YORK AT
      MGJ.
          > THANKS,LLOYD
          > t"
      target=_blank>http://www.matronics.com/Navigator?Commander-List
          > tp://forums.matronics.com
          > _blank>http://www.matronics.com/contribution
          >nbsp;      Features Chat, http://www.matnbsp;     via the Web
      title=http://forums.matronics.com/
          _p;         generous bsp;
      title=http://www.matronics.com/contribution
      http://www.matronics.com/Navigator?Commander-Listhttp://forums.matronics.
      comhttp://www.matronics.com/contribution
      m/Navigator?Commander-List>
      on>
Date: Apr 26, 2010
Subject: Re: ACLU onslaught
>Did you know that the ACLU has filed a suit to have all military cross-shaped headstones removed Although it's believable that the aclu might pull such a stunt, this email is totally false. Y'all should check facts before posting such things. chris ________________________________________________________________________________
Subject: ACLU onslaught
Date: Apr 26, 2010
Why don't you (and you know who "you" are) stick to Twin Commander topics only and keep the B.S. politics off the site. I know it's a free country and free speech but we don't need it on this board. Don -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com]On Behalf Of Chris Sent: Monday, April 26, 2010 9:06 PM Subject: Re: Commander-List: ACLU onslaught >Did you know that the ACLU has filed a suit to have all military cross-shaped headstones removed Although it's believable that the aclu might pull such a stunt, this email is totally false. Y'all should check facts before posting such things. chris ________________________________________________________________________________
Subject: Re: VIBRATION AT 1400RPM
Date: Apr 26, 2010
JIM,THANKS FOR THE INFO. ILL LET U KNOW WHEN I FIND THE ANSWER. LLOYD ----- Original Message ----- From: Jim Addington<mailto:jtaddington(at)verizon.net> To: commander-list(at)matronics.com Sent: Monday, April 26, 2010 7:33 AM Subject: RE: Commander-List: VIBRATION AT 1400RPM I got my prop back from the prop shop and the vibration was bad enough to do damage to the spinner and back plate. We were 50 miles off show when we discovered it. I managed to get it home and took it back to the prop shop and found the blade they had replace was too long and out of pitch. Mine did not vibrate enough to notice but it sure did some damage. Jim Addington N444BD ------------------------------------------------------------------------- ----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of lloyd silverman Sent: Monday, April 26, 2010 6:13 PM To: commander-list(at)matronics.com Subject: Re: Commander-List: VIBRATION AT 1400RPM THANKSDAN. IT'S THE RIGHT ENGINE ONLY. ILL CHECK COMPRESSION AND BLADE ANGLES. ----- Original Message ----- From: Dan Wold<mailto:danwold(at)gmail.com> To: commander-list(at)matronics.com Sent: Monday, April 26, 2010 1:03 AM Subject: Re: Commander-List: VIBRATION AT 1400RPM > Doctor, it hurts when I do this. Umm.. Don't do that? Cheers, DJW On Mon, Apr 26, 2010 at 12:25 AM, > wrote: > "Excessive" vibration will not be solved by dynamic balancing. Both > engines?? Check engine compression and propeller blade angles. Good luck. > jb > > > > -----Original Message----- > From: lloyd silverman > > To: commander-list > > Sent: Sun, Apr 25, 2010 6:46 pm > Subject: Commander-List: VIBRATION AT 1400RPM > > MY 500B WITH IO540'S HAS EXCESIVE VIBRATION AT 1400 RPM. ANY IDEAS, OR CAN U > RECOMMEND SOMEONE WHO CAN DYNAMICALY BALANC PROP IN NEW YORK AT MGJ. > THANKS,LLOYD > > ========== > t" target=_blank>
http://www.matronics.com/Navigator?Commander-List > ========== > tp://forums.matronics.com > ========== > _blank>http://www.matronics.com/contribution > ========== > > > > >nbsp; Features Chat, http://www.matnbsp; via the Web title=http://forums.matronics.com/ href="http://forums.matronics.com">http://forums.matronics.com _p; generous bsp; title=http://www.matronics.com/contribution href="http://www.matronics.com/contribution">http://www.matronics.com/c ================ http://www.matronics.com/Navigator?Commander-Listhttp://forums.matronics. comhttp://www.matronics.com/contribution http://www.matronics.com/Navigator?Commander-List m/Navigator?Commander-List> http://www.matronics.com/contribution on> ________________________________________________________________________________
From: "Andrew & Bridget Watson" <andrew.bridget(at)telus.net>
Subject: Need some postal addresses
Date: Apr 26, 2010
Hello everybody, I finally received the paper copies of my book, Dragon in the Sky--it's a bit disappointing as not all the errors the publisher made were corrected. I did try to get a legal ruling to force them to make the changes, but was unsuccessful. To be honest, the errors are not major: the header page for Part Three is labelled Part Two, and there are a couple of places where the punctuation is missing due to (apparently) font incompatibilities. Nico van Niekerk, Tom Fisher, Don Girod and Bruce Campbell, please send me your postal addresses so I can send you your copies with my thanks for your help. Email me directly, please, at: andrew (dot) bridget (at) telus (dot) net - replace " (dot) " with a period and " (at) " with the @ symbol. Thanks! Best wishes, Andrew ________________________________________________________________________________
From: "cybersuperstore" <nico(at)cybersuperstore.com>
Date: Apr 26, 2010
I'll take my medicine. It was sent accidentally and I was duly slapped around by someone else who sent me the snopes on it. Sorry about that, folks. You must know I would never do something like that intentionally, right? -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of dfalik(at)sbcglobal.net Sent: Monday, April 26, 2010 6:18 PM Subject: RE: Commander-List: ACLU onslaught Why don't you (and you know who "you" are) stick to Twin Commander topics only and keep the B.S. politics off the site. I know it's a free country and free speech but we don't need it on this board. Don -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com]On Behalf Of Chris Sent: Monday, April 26, 2010 9:06 PM Subject: Re: Commander-List: ACLU onslaught >Did you know that the ACLU has filed a suit to have all military cross-shaped headstones removed Although it's believable that the aclu might pull such a stunt, this email is totally false. Y'all should check facts before posting such things. chris ________________________________________________________________________________
Subject: Trace Engines at AMT magizine
Date: Apr 28, 2010
Team, There is a very interesting article in Aircraft Maintenance Technology magazine. Cover photo of a trace engine test cell.
http://amtonline.com/ You can view the article on line. Tylor Hall ________________________________________________________________________________
Subject: Nice flying
Date: Apr 29, 2010
http://www.redbull.com/cs/Satellite/en_INT/Video/Two-become-one-021242830555 557 ________________________________________________________________________________
Date: May 04, 2010
Subject: Re: Now Operating LOP
Nico, the Radial engine heads are beefier. By the way, an IGSO-540-B1A uses a single fuel injector in the supercharger housing. The individual lines going to the cylinders are primer lines. It is impossible to put GAMI injectors on that engine. Lycoming has had a tradition of cracking cyl heads on many models. The same engine on the Queen Air ( IGSO-540-A1A ) uses a Bendix fuel servo but still uses a single injector. The problem is BMEP because of the low compression and high manifold pressures. There is no way to monitor BMEP on this engine. Bill Leff In a message dated 4/21/2010 8:20:12 P.M. Eastern Daylight Time, nico(at)cybersuperstore.com writes: Hi Bill, As someone who hasn't yet come to terms with pulling the mixtures to the cheap side of peak, I still wonder, if one could manage each cylinder separately such as with GAMI's, whether the IGSO-540's would sustain a good TBO. I realize it might not be practical as GAMI suggested, but theoretically, what would prevent these engines from working well LOP with GAMI's? I assume when you say that the Wright and P&W engines have "a lot more meat" on the radial cylinders, that there is more aluminum above the gudgeon pin to dissipate or handle the heat, right? But are the temperatures not coming down when running LOP? Thanks Nico ____________________________________ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of BillLeff1(at)aol.com Sent: Wednesday, April 21, 2010 4:39 PM Subject: Re: Was : Re: Commander-List: Now Operating LOP Hey guys, I have been flying IGSO-540's and IGO-540's ( I own 2 560F's ) and I would not even consider operating LOP. If you fly per the Commander manual you will be operating at peek. Everyone I know that operates that way goes through a lot of cylinders. The operators that fly 50-100 ROP have little trouble. Fuel is Cheep! As far as LOP operations, the P&W and Wright engines are designed for it, Lycomings are not. There is a lot more meat on the radial cylinders. I spoke with the folks at GAMI about injectors for the 560F. They said that the IGO-540 fuel and induction system could not be improve enough to justify the expense. One of my 560F's has over 7000 hours on it and the same person has done every overhaul. Also, with the exception of about 200 hours I have know every operator of the aircraft. It has had one in flight shutdown, That was a failed valve in the #1 cylinder and the engine was near TBO. We never ran lean. Oddly enough I started flying this 560F in 1971. In 1994 I bought it and am still flying it. What a great airplane! Bill Leff In a message dated 4/18/2010 8:31:50 A.M. Eastern Daylight Time, BobsV35B(at)aol.com writes: Good Morning Craig, My experience with any Aero Commander is now over fifty years old, but I do have a LOT of time operating various engines on the lean side of peak EGT. Back when I was flying early Aero Commanders and Twin Bonanzas I did occasionally run those engines on the lean side. It was only at low power settings and we did not have good instrumentation, but I observed no harm at the time. Further knowledge that I have acquired over the last sixty years has convinced me that LOP is the way to go IF you have good distribution. The way I checked for good distribution before modern engine analyzers were available was to lean for a power drop. If the airplane could be slowed down about ten MPH via running on the lean side with no roughness, I figured it was good enough to operate LOP. I am certainly no engine expert, but I did attend a course taught by Curtiss Wright engineers in the spring of 1954. They made the same points that are now presented by the GAMI folks. I am a believer, but you HAVE to find a method of assuring that each cylinder is operating at the proper mixture. If you have not yet done so, I urge you to attend one of the seminars held by folks from GAMI. If you can't attend in person, take the home study version, but going with a group of pilots is a lot more fun. (Been there twice and I was a believer in the process before the folks at GAMI were born! ) Happy Skies, Old Bob AKA Bob Siegfried Brookeridge Air Park Downers Grove, Illinois Stearman N3977A In a message dated 4/18/2010 12:37:23 A.M. Central Daylight Time, white_rhino_ps(at)yahoo.com writes: Sure is Nico. Just brought it up from San Diego last weekend. Been sorting out leaky new fuel cells and the usual squawks. After double clamping all the connector tubes, thought I had it whipped. Turns out those 10 cent cork access hole gaskets were leaking after being used a couple of times. A trip to Napa finally stopped the 5 dollar a gallon drip!!! Rebuilt engines are running well. Need to dial in the injectors. Talked to the GAMI folks and they have never done a IGO-540. Could be useful as I already have the GEM CHT/EGT monitor and the JPI dual fuel flow so I can see what is going on pretty well. Has anyone in the gang had experience with this yet? The idea of running them 50 degrees LOP makes me cringe! Annual coming late summer so I'm collecting the bits now. I need to replace the aux fuel valves and that should finish with those issues. Annual time with the nacelles down is the time for that! The donor plane has been a big help with parts and bits. My pals have noticed that the donor plane so far has been the best plane investment in Commanders I've made to date! Not a lot of air time this year due to work but I'm hoping the fall will see more action. I put 747H up for sale, but so far, it's all looky-loos.... Craig ____________________________________ From: cybersuperstore <nico(at)cybersuperstore.com> Sent: Sat, April 17, 2010 8:03:00 PM Subject: RE: Commander-List: Re: Commanders I lost my Outlook on my laptop and had to restore everything to a new desktop this past week. So, I am going through all the emails because the mail server lost the data that told it which email messages were already on my laptop and started downloading 10,000+ messages from more than a year ago. I am taking the opportunity to clean some of the trash out and sorting them back into their respected folders while I am at it. Yesterday I stopped over at Camarillo airport for a coffee and to walk around to see if I see familiar planes. And there was N747H, which I didn't thing anything of except to gawk into the windows and move on. Tonight I saw this message from almost a year ago. I am almost certain that I have seen 747H on the apron before, but cannot be sure. Craig, is she still under your command? Thanks Nico ____________________________________ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of craig kennedy Sent: Monday, July 06, 2009 10:45 AM Subject: Commander-List: Re: Commanders Hello gang, Just thought I would update the group that 560F N747H, stored for over a year in the middle of nowhere ( Paris , TX ), is running again with rebuilt engines and props. Richard Cam at Aeroquest did a great job getting all the problems sorted out. Just a few more days to tidy up the remaining issues and she should be up for fun and adventure. Maybe even a trip for the annual get together. Craig _http://www.matronics.com/Navigator?Commander-List_ (http://www.matronics.com/Navigator?Commander-List) _http://forums.matronics.com_ (http://forums.matronics.com/) _http://www.matronics.com/contribution_ (http://www.matronics.com/contribution) =================================== t href="http://www.matronics.com/Navigator?Commander-List">http://www.matronics.com/Navigator?Commander-List =================================== ms.matronics.com/">http://forums.matronics.com =================================== tp://www.matronics.com/contribution">http://www.matronics.com/contribution =================================== =================================== t href="http://www.matronics.com/Navigator?Commander-List">http://www.matronics.com/Navigator?Commander-List =================================== ms.matronics.com/">http://forums.matronics.com =================================== tp://www.matronics.com/contribution">http://www.matronics.com/contribution =================================== http://www.matronics.com/Navigator?Commander-List http://forums.matronics.com http://www.matronics.com/contribution (http://www.matronics.com/Navigator?Commander-List) (http://www.matronics.com/contribution) ________________________________________________________________________________
Date: May 04, 2010
75% power on a IGSO is not recommended. However as you indicated above 75% 150-200 rich is mandatory. On the IGO 540 I use 50 deg rich, on the IGSO I use 100 deg, rich. Bill Leff In a message dated 4/22/2010 12:25:41 A.M. Eastern Daylight Time, BobsV35B(at)aol.com writes: Good Evening Bill, I guess if you have that much experience with your engines and are happy with what you have there is no need to change. And I agree, operating at high power and Peak EGT is rarely a good idea. If that is what the Commander folks recommend, I am surprised. Fifty rich of peak EGT is about the hottest spot you could operate. Personally, if I wanted to use seventy-five percent power or more, I would run more like 150 to 200 rich of peak EGT. Once again, all of this assumes good distribution, if the distribution is poor 150 to 200 rich is the better compromise, but it ain't good! However, any engine can be operated lean of peak if it has well balanced fuel distribution. There are limits and there are conditions. There is absolutely nothing about a Pratt and Whitney or a Curtiss Wright that makes them capable of lean operations other than they have the means to get an even distribution of fuel to each cylinder. I have not ran any of the large geared Lycomings for many years, but they told us then and tell us now that we can't hurt the engine with the mixture control, so I always felt comfortable experimenting. When I found that I had good distribution, I would often run on the lean side of best power. If the power available was adequate for my needs, it not only saved fuel, but the engines ran cooler and cleaner just like those Curtiss Wright engineers said they would. Same thing goes for any engine. There is no magic and this information is not new. Lindbergh used it and it worked well for him. What is wrong with running cleaner and cooler? Happy Skies, Old Bob In a message dated 4/21/2010 6:40:13 P.M. Central Daylight Time, BillLeff1(at)aol.com writes: Hey guys, I have been flying IGSO-540's and IGO-540's ( I own 2 560F's ) and I would not even consider operating LOP. If you fly per the Commander manual you will be operating at peek. Everyone I know that operates that way goes through a lot of cylinders. The operators that fly 50-100 ROP have little trouble. Fuel is Cheep! As far as LOP operations, the P&W and Wright engines are designed for it, Lycomings are not. There is a lot more meat on the radial cylinders. I spoke with the folks at GAMI about injectors for the 560F. They said that the IGO-540 fuel and induction system could not be improve enough to justify the expense. One of my 560F's has over 7000 hours on it and the same person has done every overhaul. Also, with the exception of about 200 hours I have know every operator of the aircraft. It has had one in flight shutdown, That was a failed valve in the #1 cylinder and the engine was near TBO. We never ran lean. Oddly enough I started flying this 560F in 1971. In 1994 I bought it and am still flying it. What a great airplane! Bill Leff In a message dated 4/18/2010 8:31:50 A.M. Eastern Daylight Time, BobsV35B(at)aol.com writes: Good Morning Craig, My experience with any Aero Commander is now over fifty years old, but I do have a LOT of time operating various engines on the lean side of peak EGT. Back when I was flying early Aero Commanders and Twin Bonanzas I did occasionally run those engines on the lean side. It was only at low power settings and we did not have good instrumentation, but I observed no harm at the time. Further knowledge that I have acquired over the last sixty years has convinced me that LOP is the way to go IF you have good distribution. The way I checked for good distribution before modern engine analyzers were available was to lean for a power drop. If the airplane could be slowed down about ten MPH via running on the lean side with no roughness, I figured it was good enough to operate LOP. I am certainly no engine expert, but I did attend a course taught by Curtiss Wright engineers in the spring of 1954. They made the same points that are now presented by the GAMI folks. I am a believer, but you HAVE to find a method of assuring that each cylinder is operating at the proper mixture. If you have not yet done so, I urge you to attend one of the seminars held by folks from GAMI. If you can't attend in person, take the home study version, but going with a group of pilots is a lot more fun. (Been there twice and I was a believer in the process before the folks at GAMI were born! ) Happy Skies, Old Bob AKA Bob Siegfried Brookeridge Air Park Downers Grove, Illinois Stearman N3977A In a message dated 4/18/2010 12:37:23 A.M. Central Daylight Time, white_rhino_ps(at)yahoo.com writes: Sure is Nico. Just brought it up from San Diego last weekend. Been sorting out leaky new fuel cells and the usual squawks. After double clamping all the connector tubes, thought I had it whipped. Turns out those 10 cent cork access hole gaskets were leaking after being used a couple of times. A trip to Napa finally stopped the 5 dollar a gallon drip!!! Rebuilt engines are running well. Need to dial in the injectors. Talked to the GAMI folks and they have never done a IGO-540. Could be useful as I already have the GEM CHT/EGT monitor and the JPI dual fuel flow so I can see what is going on pretty well. Has anyone in the gang had experience with this yet? The idea of running them 50 degrees LOP makes me cringe! Annual coming late summer so I'm collecting the bits now. I need to replace the aux fuel valves and that should finish with those issues. Annual time with the nacelles down is the time for that! The donor plane has been a big help with parts and bits. My pals have noticed that the donor plane so far has been the best plane investment in Commanders I've made to date! Not a lot of air time this year due to work but I'm hoping the fall will see more action. I put 747H up for sale, but so far, it's all looky-loos.... Craig ____________________________________ From: cybersuperstore <nico(at)cybersuperstore.com> Sent: Sat, April 17, 2010 8:03:00 PM Subject: RE: Commander-List: Re: Commanders I lost my Outlook on my laptop and had to restore everything to a new desktop this past week. So, I am going through all the emails because the mail server lost the data that told it which email messages were already on my laptop and started downloading 10,000+ messages from more than a year ago. I am taking the opportunity to clean some of the trash out and sorting them back into their respected folders while I am at it. Yesterday I stopped over at Camarillo airport for a coffee and to walk around to see if I see familiar planes. And there was N747H, which I didn't thing anything of except to gawk into the windows and move on. Tonight I saw this message from almost a year ago. I am almost certain that I have seen 747H on the apron before, but cannot be sure. Craig, is she still under your command? Thanks Nico ____________________________________ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of craig kennedy Sent: Monday, July 06, 2009 10:45 AM Subject: Commander-List: Re: Commanders Hello gang, Just thought I would update the group that 560F N747H, stored for over a year in the middle of nowhere ( Paris , TX ), is running again with rebuilt engines and props. Richard Cam at Aeroquest did a great job getting all the problems sorted out. Just a few more days to tidy up the remaining issues and she should be up for fun and adventure. Maybe even a trip for the annual get together. Craig _http://www.matronics.com/Navigator?Commander-List_ (http://www.matronics.com/Navigator?Commander-List) _http://forums.matronics.com_ (http://forums.matronics.com/) _http://www.matronics.com/contribution_ (http://www.matronics.com/contribution) =================================== t href="http://www.matronics.com/Navigator?Commander-List">http://www.matronics.com/Navigator?Commander-List ==================================== ms.matronics.com/">http://forums.matronics.com ==================================== tp://www.matronics.com/contribution">http://www.matronics.com/contribution ==================================== =================================== t href="http://www.matronics.com/Navigator?Commander-List">http://www.matronics.com/Navigator?Commander-List ==================================== ms.matronics.com/">http://forums.matronics.com ==================================== tp://www.matronics.com/contribution">http://www.matronics.com/contribution ==================================== =================================== t href ="http://www.matronics.com/Navigator?Commander-List">http://www.matronics.com/Navigator?Commander-List ==================================== ms.matronics.com/">http://forums.matronics.com ==================================== tp://www.matronics.com/contribution">http://www.matronics.com/contribution ==================================== (http://www.matronics.com/Navigator?Commander-List) (http://www.matronics.com/contribution) ________________________________________________________________________________
Date: May 04, 2010
Hey Gordon, I am at Simcom at Westwind school. Yes, I an going to be flying one of those things again. My instructor is flying N300TC! Imagine that!!!!!!!!!! Bill In a message dated 4/22/2010 1:02:45 A.M. Eastern Daylight Time, cloudcraft(at)aol.com writes: Lycoming definitely advocated running the IGSO-540 Lean of Peak -- somewhere in the diaspora of Commander stuff in my garage I have an old Lycoming IGSO-540 operator's manual that shows the temperature-drop curves when running LoP. When I was interviewing Jay (forgot his last name), owner of Suburban Air Freight, for an article in an early Flight Group News (circa 1997), we discussed how they operated their fleet of AC-680-FLs. They ran Rich of Peak -- not because of engine cooling: It was to compensate for low lead AvGas. The engine was designed around a high lead content fuel and that lead lubricated the valve guides, which Jay said was their greatest cause of premature engine removal when running LoP. Here we have an argument for running RoP based on something far different than the engine temperature / heat dissipation controversy. That's something to consider if you're running the older engines born in the era of green colored AvGas. Wing Commander Gordon Life is not simple anywhere. Probably less so elsewhere. -----Original Message----- From: Jack B. Mills <moe-rosspistons(at)hotmail.com> Sent: Wed, Apr 21, 2010 7:22 pm Subject: Re: Was : Re: Commander-List: Now Operating LOP Nico, Due to the fact that the IGSO540 has only one injector nozzle which squirts directly into the supercharger impeller the mixture is pretty well atomized and even from cylinder to cylinder (at least it has been on all four engines that have been in my plane). If there is a difference in EGT from cylinder is is most likely because the flow or air fuel mixture is different due to valve job, intake port configuration, or some other imbalance in the air fuel mixture flow rate from cyl. to cyl. I am a huge fan of running LOP, as the cylinder head temps are much cooler. This of course does cut down on the horsepower. I sort of figgered this out back in the '80s when running my top fuel dragster. When I had some money the engine was run rich, made a lot of horsepower and consumed mountains of parts. When money was tight I simply ran it so lean that it couldn't hurt its self. Moe Mills N680RR 680Fp From: _cybersuperstore_ (mailto:nico(at)cybersuperstore.com) Sent: Wednesday, April 21, 2010 5:14 PM Subject: RE: Was : Re: Commander-List: Now Operating LOP Hi Bill, As someone who hasn't yet come to terms with pulling the mixtures to the cheap side of peak, I still wonder, if one could manage each cylinder separately such as with GAMI's, whether the IGSO-540's would sustain a good TBO. I realize it might not be practical as GAMI suggested, but theoretically, what would prevent these engines from working well LOP with GAMI's? I assume when you say that the Wright and P&W engines have "a lot more meat" on the radial cylinders, that there is more aluminum above the gudgeon pin to dissipate or handle the heat, right? But are the temperatures not coming down when running LOP? Thanks Nico ____________________________________ From: _owner-commander-list-server(at)matronics.com_ (mailto:owner-commander-list-server(at)matronics.com) [_mailto:owner-commander-list-server(at)matronics.com_ (mailto:owner-commander-list-server(at)matronics.com?) ] On Behalf Of _BillLeff1(at)aol.com_ (mailto:BillLeff1(at)aol.com) Sent: Wednesday, April 21, 2010 4:39 PM Subject: Re: Was : Re: Commander-List: Now Operating LOP Hey guys, I have been flying IGSO-540's and IGO-540's ( I own 2 560F's ) and I would not even consider operating LOP. If you fly per the Commander manual you will be operating at peek. Everyone I know that operates that way goes through a lot of cylinders. The operators that fly 50-100 ROP have little trouble. Fuel is Cheep! As far as LOP operations, the P&W and Wright engines are designed for it, Lycomings are not. There is a lot more meat on the radial cylinders. I spoke with the folks at GAMI about injectors for the 560F. They said that the IGO-540 fuel and induction system could not be improve enough to justify the expense. One of my 560F's has over 7000 hours on it and the same person has done every overhaul. Also, with the exception of about 200 hours I have know every operator of the aircraft. It has had one in flight shutdown, That was a failed valve in the #1 cylinder and the engine was near TBO. We never ran lean. Oddly enough I started flying this 560F in 1971. In 1994 I bought it and am still flying it. What a great airplane! Bill Leff In a message dated 4/18/2010 8:31:50 A.M. Eastern Daylight Time, _BobsV35B(at)aol.com_ (mailto:BobsV35B(at)aol.com) writes: Good Morning Craig, My experience with any Aero Commander is now over fifty years old, but I do have a LOT of time operating various engines on the lean side of peak EGT. Back when I was flying early Aero Commanders and Twin Bonanzas I did occasionally run those engines on the lean side. It was only at low power settings and we did not have good instrumentation, but I observed no harm at the time. Further knowledge that I have acquired over the last sixty years has convinced me that LOP is the way to go IF you have good distribution. The way I checked for good distribution before modern engine analyzers were available was to lean for a power drop. If the airplane could be slowed down about ten MPH via running on the lean side with no roughness, I figured it was good enough to operate LOP. I am certainly no engine expert, but I did attend a course taught by Curtiss Wright engineers in the spring of 1954. They made the same points that are now presented by the GAMI folks. I am a believer, but you HAVE to find a method of assuring that each cylinder is operating at the proper mixture. If you have not yet done so, I urge you to attend one of the seminars held by folks from GAMI. If you can't attend in person, take the home study version, but going with a group of pilots is a lot more fun. (Been there twice and I was a believer in the process before the folks at GAMI were born! ) Happy Skies, Old Bob AKA Bob Siegfried Brookeridge Air Park Downers Grove, Illinois Stearman N3977A In a message dated 4/18/2010 12:37:23 A.M. Central Daylight Time, _white_rhino_ps(at)yahoo.com_ (mailto:white_rhino_ps(at)yahoo.com) writes: Sure is Nico. Just brought it up from San Diego last weekend. Been sorting out leaky new fuel cells and the usual squawks. After double clamping all the connector tubes, thought I had it whipped. Turns out those 10 cent cork access hole gaskets were leaking after being used a couple of times. A trip to Napa finally stopped the 5 dollar a gallon drip!!! Rebuilt engines are running well. Need to dial in the injectors. Talked to the GAMI folks and they have never done a IGO-540. Could be useful as I already have the GEM CHT/EGT monitor and the JPI dual fuel flow so I can see what is going on pretty well. Has anyone in the gang had experience with this yet? The idea of running them 50 degrees LOP makes me cringe! Annual coming late summer so I'm collecting the bits now. I need to replace the aux fuel valves and that should finish with those issues. Annual time with the nacelles down is the time for that! The donor plane has been a big help with parts and bits. My pals have noticed that the donor plane so far has been the best plane investment in Commanders I've made to date! Not a lot of air time this year due to work but I'm hoping the fall will see more action. I put 747H up for sale, but so far, it's all looky-loos.... Craig ____________________________________ From: cybersuperstore <_nico(at)cybersuperstore.com_ (mailto:nico(at)cybersuperstore.com) > Sent: Sat, April 17, 2010 8:03:00 PM Subject: RE: Commander-List: Re: Commanders I lost my Outlook on my laptop and had to restore everything to a new desktop this past week. So, I am going through all the emails because the mail server lost the data that told it which email messages were already on my laptop and started downloading 10,000+ messages from more than a year ago. I am taking the opportunity to clean some of the trash out and sorting them back into their respected folders while I am at it. Yesterday I stopped over at Camarillo airport for a coffee and to walk around to see if I see familiar planes. And there was N747H, which I didn't thing anything of except to gawk into the windows and move on. Tonight I saw this message from almost a year ago. I am almost certain that I have seen 747H on the apron before, but cannot be sure. Craig, is she still under your command? Thanks Nico ____________________________________ From: _owner-commander-list-server(at)matronics.com_ (mailto:owner-commander-list-server(at)matronics.com) [_mailto:owner-commander-list-server(at)matronics.com_ (mailto:owner-commander-list-server(at)matronics.com?) ] On Behalf Of craig kennedy Sent: Monday, July 06, 2009 10:45 AM Subject: Commander-List: Re: Commanders Hello gang, Just thought I would update the group that 560F N747H, stored for over a year in the middle of nowhere ( Paris , TX ), is running again with rebuilt engines and props. Richard Cam at Aeroquest did a great job getting all the problems sorted out. Just a few more days to tidy up the remaining issues and she should be up for fun and adventure. Maybe even a trip for the annual get together. Craig _http://www.matronics.com/Navigator?Commander-List_ (http://www.matronics.com/Navigator?Commander-List) _http://forums.matronics.com_ (http://forums.matronics.com/) _http://www.matronics.com/contribution_ (http://www.matronics.com/contribution) =================================== t href="_http://www.matronics.com/Navigator?Commander-List_ (http://www.matronics.com/Navigator?Commander-List) ">_http://www.matronics.com/Navigator?Commander-List_ (http://www.matronics.com/Navigator?Commander-List) =================================== ms.matronics.com/">_http://forums.matronics.com_ (http://forums.matronics.com/) =================================== tp://_www.matronics.com/contribution_ (http://www.matronics.com/contribution) ">_http://www.matronics.com/contribution_ (http://www.matronics.com/contribution) =================================== =================================== t href="_http://www.matronics.com/Navigator?Commander-List_ (http://www.matronics.com/Navigator?Commander-List) ">_http://www.matronics.com/Navigator?Commander-List_ (http://www.matronics.com/Navigator?Commander-List) =================================== ms.matronics.com/">_http://forums.matronics.com_ (http://forums.matronics.com/) =================================== tp://_www.matronics.com/contribution_ (http://www.matronics.com/contribution) ">_http://www.matronics.com/contribution_ (http://www.matronics.com/contribution) =================================== http://www.matronics.com/Navigator?Commander-List http://forums.matronics.com http://www.matronics.com/contribution href="_http://www.matronics.com/Navigator?Commander-List_ (http://www.matronics.com/Navigator?Commander-List) ">_http://www.matronics.com/Navigator?Commander-List_ (http://www.matronics.com/Navigator?Commander-List) href="_http://forums.matronics.com_ (http://forums.matronics.com/) ">_http://forums.matronics.com_ (http://forums.matronics.com/) href="_http://www.matronics.com/contribution_ (http://www.matronics.com/contribution) ">_http://www.matronics.com/c_ (http://www.matronics.com/c) =================================== ator?Commander-List">http://www.matronics.com/Navigator?Commander-List =================================== ttp://forums.matronics.com =================================== ibution">http://www.matronics.com/contribution =================================== (http://www.matronics.com/Navigator?Commander-List) (http://www.matronics.com/contribution) ________________________________________________________________________________
Date: May 04, 2010
Forgot, you are right, we had better gas back then. If you follow the Commander POH you will be running at peek. Lycoming does show LOP operation. THEY ALSO SELL CYLINDERS!!!!!!!!!! lOTS OF THEM. You guys can argue and theorize all you want. But from a maintenance shop point of view. Run rich or carry cylinders with you! Bill Leff In a message dated 4/22/2010 1:02:45 A.M. Eastern Daylight Time, cloudcraft(at)aol.com writes: Lycoming definitely advocated running the IGSO-540 Lean of Peak -- somewhere in the diaspora of Commander stuff in my garage I have an old Lycoming IGSO-540 operator's manual that shows the temperature-drop curves when running LoP. When I was interviewing Jay (forgot his last name), owner of Suburban Air Freight, for an article in an early Flight Group News (circa 1997), we discussed how they operated their fleet of AC-680-FLs. They ran Rich of Peak -- not because of engine cooling: It was to compensate for low lead AvGas. The engine was designed around a high lead content fuel and that lead lubricated the valve guides, which Jay said was their greatest cause of premature engine removal when running LoP. Here we have an argument for running RoP based on something far different than the engine temperature / heat dissipation controversy. That's something to consider if you're running the older engines born in the era of green colored AvGas. Wing Commander Gordon Life is not simple anywhere. Probably less so elsewhere. -----Original Message----- From: Jack B. Mills <moe-rosspistons(at)hotmail.com> Sent: Wed, Apr 21, 2010 7:22 pm Subject: Re: Was : Re: Commander-List: Now Operating LOP Nico, Due to the fact that the IGSO540 has only one injector nozzle which squirts directly into the supercharger impeller the mixture is pretty well atomized and even from cylinder to cylinder (at least it has been on all four engines that have been in my plane). If there is a difference in EGT from cylinder is is most likely because the flow or air fuel mixture is different due to valve job, intake port configuration, or some other imbalance in the air fuel mixture flow rate from cyl. to cyl. I am a huge fan of running LOP, as the cylinder head temps are much cooler. This of course does cut down on the horsepower. I sort of figgered this out back in the '80s when running my top fuel dragster. When I had some money the engine was run rich, made a lot of horsepower and consumed mountains of parts. When money was tight I simply ran it so lean that it couldn't hurt its self. Moe Mills N680RR 680Fp From: _cybersuperstore_ (mailto:nico(at)cybersuperstore.com) Sent: Wednesday, April 21, 2010 5:14 PM Subject: RE: Was : Re: Commander-List: Now Operating LOP Hi Bill, As someone who hasn't yet come to terms with pulling the mixtures to the cheap side of peak, I still wonder, if one could manage each cylinder separately such as with GAMI's, whether the IGSO-540's would sustain a good TBO. I realize it might not be practical as GAMI suggested, but theoretically, what would prevent these engines from working well LOP with GAMI's? I assume when you say that the Wright and P&W engines have "a lot more meat" on the radial cylinders, that there is more aluminum above the gudgeon pin to dissipate or handle the heat, right? But are the temperatures not coming down when running LOP? Thanks Nico ____________________________________ From: _owner-commander-list-server(at)matronics.com_ (mailto:owner-commander-list-server(at)matronics.com) [_mailto:owner-commander-list-server(at)matronics.com_ (mailto:owner-commander-list-server(at)matronics.com?) ] On Behalf Of _BillLeff1(at)aol.com_ (mailto:BillLeff1(at)aol.com) Sent: Wednesday, April 21, 2010 4:39 PM Subject: Re: Was : Re: Commander-List: Now Operating LOP Hey guys, I have been flying IGSO-540's and IGO-540's ( I own 2 560F's ) and I would not even consider operating LOP. If you fly per the Commander manual you will be operating at peek. Everyone I know that operates that way goes through a lot of cylinders. The operators that fly 50-100 ROP have little trouble. Fuel is Cheep! As far as LOP operations, the P&W and Wright engines are designed for it, Lycomings are not. There is a lot more meat on the radial cylinders. I spoke with the folks at GAMI about injectors for the 560F. They said that the IGO-540 fuel and induction system could not be improve enough to justify the expense. One of my 560F's has over 7000 hours on it and the same person has done every overhaul. Also, with the exception of about 200 hours I have know every operator of the aircraft. It has had one in flight shutdown, That was a failed valve in the #1 cylinder and the engine was near TBO. We never ran lean. Oddly enough I started flying this 560F in 1971. In 1994 I bought it and am still flying it. What a great airplane! Bill Leff In a message dated 4/18/2010 8:31:50 A.M. Eastern Daylight Time, _BobsV35B(at)aol.com_ (mailto:BobsV35B(at)aol.com) writes: Good Morning Craig, My experience with any Aero Commander is now over fifty years old, but I do have a LOT of time operating various engines on the lean side of peak EGT. Back when I was flying early Aero Commanders and Twin Bonanzas I did occasionally run those engines on the lean side. It was only at low power settings and we did not have good instrumentation, but I observed no harm at the time. Further knowledge that I have acquired over the last sixty years has convinced me that LOP is the way to go IF you have good distribution. The way I checked for good distribution before modern engine analyzers were available was to lean for a power drop. If the airplane could be slowed down about ten MPH via running on the lean side with no roughness, I figured it was good enough to operate LOP. I am certainly no engine expert, but I did attend a course taught by Curtiss Wright engineers in the spring of 1954. They made the same points that are now presented by the GAMI folks. I am a believer, but you HAVE to find a method of assuring that each cylinder is operating at the proper mixture. If you have not yet done so, I urge you to attend one of the seminars held by folks from GAMI. If you can't attend in person, take the home study version, but going with a group of pilots is a lot more fun. (Been there twice and I was a believer in the process before the folks at GAMI were born! ) Happy Skies, Old Bob AKA Bob Siegfried Brookeridge Air Park Downers Grove, Illinois Stearman N3977A In a message dated 4/18/2010 12:37:23 A.M. Central Daylight Time, _white_rhino_ps(at)yahoo.com_ (mailto:white_rhino_ps(at)yahoo.com) writes: Sure is Nico. Just brought it up from San Diego last weekend. Been sorting out leaky new fuel cells and the usual squawks. After double clamping all the connector tubes, thought I had it whipped. Turns out those 10 cent cork access hole gaskets were leaking after being used a couple of times. A trip to Napa finally stopped the 5 dollar a gallon drip!!! Rebuilt engines are running well. Need to dial in the injectors. Talked to the GAMI folks and they have never done a IGO-540. Could be useful as I already have the GEM CHT/EGT monitor and the JPI dual fuel flow so I can see what is going on pretty well. Has anyone in the gang had experience with this yet? The idea of running them 50 degrees LOP makes me cringe! Annual coming late summer so I'm collecting the bits now. I need to replace the aux fuel valves and that should finish with those issues. Annual time with the nacelles down is the time for that! The donor plane has been a big help with parts and bits. My pals have noticed that the donor plane so far has been the best plane investment in Commanders I've made to date! Not a lot of air time this year due to work but I'm hoping the fall will see more action. I put 747H up for sale, but so far, it's all looky-loos.... Craig ____________________________________ From: cybersuperstore <_nico(at)cybersuperstore.com_ (mailto:nico(at)cybersuperstore.com) > Sent: Sat, April 17, 2010 8:03:00 PM Subject: RE: Commander-List: Re: Commanders I lost my Outlook on my laptop and had to restore everything to a new desktop this past week. So, I am going through all the emails because the mail server lost the data that told it which email messages were already on my laptop and started downloading 10,000+ messages from more than a year ago. I am taking the opportunity to clean some of the trash out and sorting them back into their respected folders while I am at it. Yesterday I stopped over at Camarillo airport for a coffee and to walk around to see if I see familiar planes. And there was N747H, which I didn't thing anything of except to gawk into the windows and move on. Tonight I saw this message from almost a year ago. I am almost certain that I have seen 747H on the apron before, but cannot be sure. Craig, is she still under your command? Thanks Nico ____________________________________ From: _owner-commander-list-server(at)matronics.com_ (mailto:owner-commander-list-server(at)matronics.com) [_mailto:owner-commander-list-server(at)matronics.com_ (mailto:owner-commander-list-server(at)matronics.com?) ] On Behalf Of craig kennedy Sent: Monday, July 06, 2009 10:45 AM Subject: Commander-List: Re: Commanders Hello gang, Just thought I would update the group that 560F N747H, stored for over a year in the middle of nowhere ( Paris , TX ), is running again with rebuilt engines and props. Richard Cam at Aeroquest did a great job getting all the problems sorted out. Just a few more days to tidy up the remaining issues and she should be up for fun and adventure. Maybe even a trip for the annual get together. Craig _http://www.matronics.com/Navigator?Commander-List_ (http://www.matronics.com/Navigator?Commander-List) _http://forums.matronics.com_ (http://forums.matronics.com/) _http://www.matronics.com/contribution_ (http://www.matronics.com/contribution) =================================== t href="_http://www.matronics.com/Navigator?Commander-List_ (http://www.matronics.com/Navigator?Commander-List) ">_http://www.matronics.com/Navigator?Commander-List_ (http://www.matronics.com/Navigator?Commander-List) =================================== ms.matronics.com/">_http://forums.matronics.com_ (http://forums.matronics.com/) =================================== tp://_www.matronics.com/contribution_ (http://www.matronics.com/contribution) ">_http://www.matronics.com/contribution_ (http://www.matronics.com/contribution) =================================== =================================== t href="_http://www.matronics.com/Navigator?Commander-List_ (http://www.matronics.com/Navigator?Commander-List) ">_http://www.matronics.com/Navigator?Commander-List_ (http://www.matronics.com/Navigator?Commander-List) =================================== ms.matronics.com/">_http://forums.matronics.com_ (http://forums.matronics.com/) =================================== tp://_www.matronics.com/contribution_ (http://www.matronics.com/contribution) ">_http://www.matronics.com/contribution_ (http://www.matronics.com/contribution) =================================== http://www.matronics.com/Navigator?Commander-List http://forums.matronics.com http://www.matronics.com/contribution href="_http://www.matronics.com/Navigator?Commander-List_ (http://www.matronics.com/Navigator?Commander-List) ">_http://www.matronics.com/Navigator?Commander-List_ (http://www.matronics.com/Navigator?Commander-List) href="_http://forums.matronics.com_ (http://forums.matronics.com/) ">_http://forums.matronics.com_ (http://forums.matronics.com/) href="_http://www.matronics.com/contribution_ (http://www.matronics.com/contribution) ">_http://www.matronics.com/c_ (http://www.matronics.com/c) =================================== ator?Commander-List">http://www.matronics.com/Navigator?Commander-List =================================== ttp://forums.matronics.com =================================== ibution">http://www.matronics.com/contribution =================================== (http://www.matronics.com/Navigator?Commander-List) (http://www.matronics.com/contribution) ________________________________________________________________________________
Date: May 04, 2010
Hey, Ken, While I am not a fan of LOP operations, If there is an engine and installation it might work on it would be the 500B/U/S. With proper baffling, those engines run so cool heat is not a problem. That is why Bob Hoover could cut his engines at full power and then restart them and immediately go back to full power for his air show. He rarely had to change cylinders. They just never got hot enough to crack. However, those airplanes need all the power they can get. LOP may cause a power loss that is un acceptable reduction of speed. Wonder how John Towner operates his flock (30+ aircraft) ? He has to squeeze every nickel out of his aircraft because his livelihood depends on it. Does he prefer to spend money on fuel or engines? Bill Leff In a message dated 4/22/2010 9:15:35 A.M. Eastern Daylight Time, KenWHyde(at)aol.com writes: Know this is about the IGSO540 & IGO540 but what are the thoughts of LOP on the narrow deck IO540's?? Thanks, Ken (http://www.matronics.com/Navigator?Commander-List) (http://www.matronics.com/contribution) ________________________________________________________________________________
Date: May 04, 2010
Yup, 25-50 deg is too lean. IGSO's require 100 deg. Bill Leff In a message dated 4/22/2010 1:23:18 A.M. Eastern Daylight Time, white_rhino_ps(at)yahoo.com writes: Interesting information by everyone. While I have detailed info for my IGO-540's, available by cylinder, for EGT, CHT, Fuel flow, and servo/distributor flow rate, the left can run LOP but the right can't without running rough. Why? I have err'd on the side of caution by just running ROP by 25 to 50 degrees as the fuel is MUCH cheaper than 2 more $$$$$$$ overhauls. Failures to date have been valve centric, but a surprising amount of heat damage in the pins, head, and heads was also noted. I like the idea, but I'd like to hit TBO and the big geared LYC's seem to dislike the method... I don't have a dog in the hunt regarding the the proven LOP methodology, but betting my money has proven to be more than I can afford! Craig ____________________________________ From: Keith S. Gordon <cloudcraft(at)aol.com> Sent: Wed, April 21, 2010 10:00:21 PM Subject: Re: Was : Re: Commander-List: Now Operating LOP Lycoming definitely advocated running the IGSO-540 Lean of Peak -- somewhere in the diaspora of Commander stuff in my garage I have an old Lycoming IGSO-540 operator's manual that shows the temperature-drop curves when running LoP. When I was interviewing Jay (forgot his last name), owner of Suburban Air Freight, for an article in an early Flight Group News (circa 1997), we discussed how they operated their fleet of AC-680-FLs. They ran Rich of Peak -- not because of engine cooling: It was to compensate for low lead AvGas. The engine was designed around a high lead content fuel and that lead lubricated the valve guides, which Jay said was their greatest cause of premature engine removal when running LoP. Here we have an argument for running RoP based on something far different than the engine temperature / heat dissipation controversy. That's something to consider if you're running the older engines born in the era of green colored AvGas. Wing Commander Gordon Life is not simple anywhere. Probably less so elsewhere. -----Original Message----- From: Jack B. Mills <moe-rosspistons(at)hotmail.com> Sent: Wed, Apr 21, 2010 7:22 pm Subject: Re: Was : Re: Commander-List: Now Operating LOP Nico, Due to the fact that the IGSO540 has only one injector nozzle which squirts directly into the supercharger impeller the mixture is pretty well atomized and even from cylinder to cylinder (at least it has been on all four engines that have been in my plane). If there is a difference in EGT from cylinder is is most likely because the flow or air fuel mixture is different due to valve job, intake port configuration, or some other imbalance in the air fuel mixture flow rate from cyl. to cyl. I am a huge fan of running LOP, as the cylinder head temps are much cooler. This of course does cut down on the horsepower. I sort of figgered this out back in the '80s when running my top fuel dragster. When I had some money the engine was run rich, made a lot of horsepower and consumed mountains of parts. When money was tight I simply ran it so lean that it couldn't hurt its self. Moe Mills N680RR 680Fp From: _cybersuperstore_ (mailto:nico(at)cybersuperstore.com) Sent: Wednesday, April 21, 2010 5:14 PM Subject: RE: Was : Re: Commander-List: Now Operating LOP Hi Bill, As someone who hasn't yet come to terms with pulling the mixtures to the cheap side of peak, I still wonder, if one could manage each cylinder separately such as with GAMI's, whether the IGSO-540's would sustain a good TBO. I realize it might not be practical as GAMI suggested, but theoretically, what would prevent these engines from working well LOP with GAMI's? I assume when you say that the Wright and P&W engines have "a lot more meat" on the radial cylinders, that there is more aluminum above the gudgeon pin to dissipate or handle the heat, right? But are the temperatures not coming down when running LOP? Thanks Nico ____________________________________ From: _owner-commander-list-server(at)matronics.com_ (mailto:owner-commander-list-server(at)matronics.com) [_mailto:owner-commander-list-server(at)matronics.com_ (mailto:owner-commander-list-server(at)matronics.com?) ] On Behalf Of _BillLeff1(at)aol.com_ (mailto:BillLeff1(at)aol.com) Sent: Wednesday, April 21, 2010 4:39 PM Subject: Re: Was : Re: Commander-List: Now Operating LOP Hey guys, I have been flying IGSO-540's and IGO-540's ( I own 2 560F's ) and I would not even consider operating LOP. If you fly per the Commander manual you will be operating at peek. Everyone I know that operates that way goes through a lot of cylinders. The operators that fly 50-100 ROP have little trouble. Fuel is Cheep! As far as LOP operations, the P&W and Wright engines are designed for it, Lycomings are not. There is a lot more meat on the radial cylinders. I spoke with the folks at GAMI about injectors for the 560F. They said that the IGO-540 fuel and induction system could not be improve enough to justify the expense. One of my 560F's has over 7000 hours on it and the same person has done every overhaul. Also, with the exception of about 200 hours I have know every operator of the aircraft. It has had one in flight shutdown, That was a failed valve in the #1 cylinder and the engine was near TBO. We never ran lean. Oddly enough I started flying this 560F in 1971. In 1994 I bought it and am still flying it. What a great airplane! Bill Leff In a message dated 4/18/2010 8:31:50 A.M. Eastern Daylight Time, _BobsV35B(at)aol.com_ (mailto:BobsV35B(at)aol.com) writes: Good Morning Craig, My experience with any Aero Commander is now over fifty years old, but I do have a LOT of time operating various engines on the lean side of peak EGT. Back when I was flying early Aero Commanders and Twin Bonanzas I did occasionally run those engines on the lean side. It was only at low power settings and we did not have good instrumentation, but I observed no harm at the time. Further knowledge that I have acquired over the last sixty years has convinced me that LOP is the way to go IF you have good distribution. The way I checked for good distribution before modern engine analyzers were available was to lean for a power drop. If the airplane could be slowed down about ten MPH via running on the lean side with no roughness, I figured it was good enough to operate LOP. I am certainly no engine expert, but I did attend a course taught by Curtiss Wright engineers in the spring of 1954. They made the same points that are now presented by the GAMI folks. I am a believer, but you HAVE to find a method of assuring that each cylinder is operating at the proper mixture. If you have not yet done so, I urge you to attend one of the seminars held by folks from GAMI. If you can't attend in person, take the home study version, but going with a group of pilots is a lot more fun. (Been there twice and I was a believer in the process before the folks at GAMI were born! ) Happy Skies, Old Bob AKA Bob Siegfried Brookeridge Air Park Downers Grove, Illinois Stearman N3977A In a message dated 4/18/2010 12:37:23 A.M. Central Daylight Time, _white_rhino_ps(at)yahoo.com_ (mailto:white_rhino_ps(at)yahoo.com) writes: Sure is Nico. Just brought it up from San Diego last weekend. Been sorting out leaky new fuel cells and the usual squawks. After double clamping all the connector tubes, thought I had it whipped. Turns out those 10 cent cork access hole gaskets were leaking after being used a couple of times. A trip to Napa finally stopped the 5 dollar a gallon drip!!! Rebuilt engines are running well. Need to dial in the injectors. Talked to the GAMI folks and they have never done a IGO-540. Could be useful as I already have the GEM CHT/EGT monitor and the JPI dual fuel flow so I can see what is going on pretty well. Has anyone in the gang had experience with this yet? The idea of running them 50 degrees LOP makes me cringe! Annual coming late summer so I'm collecting the bits now. I need to replace the aux fuel valves and that should finish with those issues. Annual time with the nacelles down is the time for that! The donor plane has been a big help with parts and bits. My pals have noticed that the donor plane so far has been the best plane investment in Commanders I've made to date! Not a lot of air time this year due to work but I'm hoping the fall will see more action. I put 747H up for sale, but so far, it's all looky-loos.... Craig ____________________________________ From: cybersuperstore <_nico(at)cybersuperstore.com_ (mailto:nico(at)cybersuperstore.com) > Sent: Sat, April 17, 2010 8:03:00 PM Subject: RE: Commander-List: Re: Commanders I lost my Outlook on my laptop and had to restore everything to a new desktop this past week. So, I am going through all the emails because the mail server lost the data that told it which email messages were already on my laptop and started downloading 10,000+ messages from more than a year ago. I am taking the opportunity to clean some of the trash out and sorting them back into their respected folders while I am at it. Yesterday I stopped over at Camarillo airport for a coffee and to walk around to see if I see familiar planes. And there was N747H, which I didn't thing anything of except to gawk into the windows and move on. Tonight I saw this message from almost a year ago. I am almost certain that I have seen 747H on the apron before, but cannot be sure. Craig, is she still under your command? Thanks Nico ____________________________________ From: _owner-commander-list-server(at)matronics.com_ (mailto:owner-commander-list-server(at)matronics.com) [_mailto:owner-commander-list-server(at)matronics.com_ (mailto:owner-commander-list-server(at)matronics.com?) ] On Behalf Of craig kennedy Sent: Monday, July 06, 2009 10:45 AM Subject: Commander-List: Re: Commanders Hello gang, Just thought I would update the group that 560F N747H, stored for over a year in the middle of nowhere ( Paris , TX ), is running again with rebuilt engines and props. Richard Cam at Aeroquest did a great job getting all the problems sorted out. Just a few more days to tidy up the remaining issues and she should be up for fun and adventure. Maybe even a trip for the annual get together. Craig _http://www.matronics.com/Navigator?Commander-List_ (http://www.matronics.com/Navigator?Commander-List) _http://forums.matronics.com/_ (http://forums.matronics.com/) _http://www.matronics.com/contribution_ (http://www.matronics.com/contribution) =================================== t href="_http://www.matronics.com/Navigator?Commander-List_ (http://www.matronics.com/Navigator?Commander-List) ">_http://www.matronics.com/Navigator?Commander-List_ (http://www.matronics.com/Navigator?Commander-List) =================================== _ms.matronics.com/_ (http://ms.matronics.com/) ">_http://forums.matronics.com_ (http://forums.matronics.com/) =================================== tp://_www.matronics.com/contribution_ (http://www.matronics.com/contribution) ">_http://www.matronics.com/contribution_ (http://www.matronics.com/contribution) =================================== =================================== t href="_http://www.matronics.com/Navigator?Commander-List_ (http://www.matronics.com/Navigator?Commander-List) ">_http://www.matronics.com/Navigator?Commander-List_ (http://www.matronics.com/Navigator?Commander-List) =================================== ms.matronics.com/">_http://forums.matronics.com_ (http://forums.matronics.com/) =================================== tp://_www.matronics.com/contribution_ (http://www.matronics.com/contribution) ">_http://www.matronics.com/contribution_ (http://www.matronics.com/contribution) =================================== _http://www.matronics.com/Navigator?Commander-List_ (http://www.matronics.com/Navigator?Commander-List) _http://forums.matronics.com_ (http://forums.matronics.com/) _http://www.matronics.com/contribution_ (http://www.matronics.com/contribution) href="_http://www.matronics.com/Navigator?Commander-List_ (http://www.matronics.com/Navigator?Commander-List) ">_http://www.matronics.com/Navigator?Commander-List_ (http://www.matronics.com/Navigator?Commander-List) href="_http://forums.matronics.com_ (http://forums.matronics.com/) ">_http://forums.matronics.com_ (http://forums.matronics.com/) href="_http://www.matronics.com/contribution_ (http://www.matronics.com/contribution) ">_http://www.matronics.com/c_ (http://www.matronics.com/c) =================================== ator?Commander-List">_http://www.matronics.com/Navigator?Commander-List_ (http://www.matronics.com/Navigator?Commander-List) =================================== ttp://forums.matronics.com =================================== ibution">_http://www.matronics.com/contribution_ (http://www.matronics.com/contribution) =================================== (http://www.matronics.com/Navigator?Commander-List) (http://www.matronics.com/contribution) ________________________________________________________________________________
Date: May 04, 2010
Date: May 04, 2010
Hey Gordon, I am at Simcom at Westwind school. Yes, I an going to be flyin g one of those things again. My instructor is flying N300TC! Imagine that !!!!!!!!!! Gadzooks! It's a small world (but I'd hate to have to paint it). On topic, I'm doing an R.O.N. at Fresno, California (KFAT) and have been reminiscing about how this was where I did my first dual cross-country in 1974 ... the it was one of the points of my solo long cross country ... and then as an instructor, I brought my students here for their first dua l X-C (it's 100.5 nm from Watsonville!) and then I started flying in here as a freight dog in an AeroCommander 680E in about 1978. And when I got to Pago Pago in 1994, there was that very same 680E, in Int er Island Air colors. Now we need to examine why our careers are built upon out of production ai rplanes. Maybe it's because the out of production airplanes are so good .... Wing Commander Gordon Life is not simple anywhere. Probably less so elsewhere. -----Original Message----- From: BillLeff1(at)aol.com Sent: Mon, May 3, 2010 10:10 pm Subject: Re: Was : Re: Commander-List: Now Operating LOP Hey Gordon, I am at Simcom at Westwind school. Yes, I an going to be flyin g one of those things again. My instructor is flying N300TC! Imagine that !!!!!!!!!! Bill In a message dated 4/22/2010 1:02:45 A.M. Eastern Daylight Time, cloudcraf t(at)aol.com writes: Lycoming definitely advocated running the IGSO-540 Lean of Peak -- somew here in the diaspora of Commander stuff in my garage I have an old Lycom ing IGSO-540 operator's manual that shows the temperature-drop curves wh en running LoP. When I was interviewing Jay (forgot his last name), owner of Suburban Ai r Freight, for an article in an early Flight Group News (circa 1997), we discussed how they operated their fleet of AC-680-FLs. They ran Rich of Peak -- not because of engine cooling: It was to compe nsate for low lead AvGas. The engine was designed around a high lead content fuel and that lead lu bricated the valve guides, which Jay said was their greatest cause of pr emature engine removal when running LoP. Here we have an argument for running RoP based on something far differen t than the engine temperature / heat dissipation controversy. That's so mething to consider if you're running the older engines born in the era of green colored AvGas. Wing Commander Gordon Life is not simple anywhere. Probably less so elsewhere. -----Original Message----- From: Jack B. Mills <moe-rosspistons(at)hotmail.com> Sent: Wed, Apr 21, 2010 7:22 pm Subject: Re: Was : Re: Commander-List: Now Operating LOP Nico, Due to the fact that the IGSO540 has only one injector nozzle which squi rts directly into the supercharger impeller the mixture is pretty well atomized and even from cylinder to cylinder (at least it has been on al l four engines that have been in my plane). If there is a difference in EGT from cylinder is is most likely because the flow or air fuel mixtur e is different due to valve job, intake port configuration, or some othe r imbalance in the air fuel mixture flow rate from cyl. to cyl. I am a huge fan of running LOP, as the cylinder head temps are much cooler. This of course does cut down on the horsepower. I sort of figgered th is out back in the '80s when running my top fuel dragster. When I had some money the engine was run rich, made a lot of horsepower and consum ed mountains of parts. When money was tight I simply ran it so lean tha t it couldn't hurt its self. Moe Mills N680RR 680Fp From: cybersuperstore Sent: Wednesday, April 21, 2010 5:14 PM Subject: RE: Was : Re: Commander-List: Now Operating LOP Hi Bill, As someone who hasn't yet come to terms with pulling the mixtures to the cheap side of peak, I still wonder, if one could manage each cylinder separately such as with GAMI's, whether the IGSO-540's would sustain a good TBO. I realize it might not be practical as GAMI suggested, but th eoretically, what would prevent these engines from working well LOP with GAMI's? I assume when you say that the Wright and P&W engines have "a lot more meat" on the radial cylinders, that there is more aluminum above the gu dgeon pin to dissipate or handle the heat, right? But are the temperatur es not coming down when running LOP? Thanks Nico From: owner-commander-list-server(at)matronics.com [mailto:owner-commander- list-server(at)matronics.com] On Behalf Of BillLeff1(at)aol.com Sent: Wednesday, April 21, 2010 4:39 PM Subject: Re: Was : Re: Commander-List: Now Operating LOP Hey guys, I have been flying IGSO-540's and IGO-540's ( I own 2 560F's ) and I would not even consider operating LOP. If you fly per the Comma nder manual you will be operating at peek. Everyone I know that operates that way goes through a lot of cylinders. The operators that fly 50-100 ROP have little trouble. Fuel is Cheep! As far as LOP operations, the P&W and Wright engines are designed for it , Lycomings are not. There is a lot more meat on the radial cylinders. I spoke with the folks at GAMI about injectors for the 560F. They said that the IGO-540 fuel and induction system could not be improve enough to justify the expense. One of my 560F's has over 7000 hours on it and the same person has done every overhaul. Also, with the exception of about 200 hours I have know every operator of the aircraft. It has had one in flight shutdown, That was a failed valve in the #1 cylinder and the engine was near TBO. We never ran lean. Oddly enough I started flying this 560F in 1971. In 1994 I bought it and am still flying it. What a great airplane! Bill Leff In a message dated 4/18/2010 8:31:50 A.M. Eastern Daylight Time, BobsV35 B(at)aol.com writes: Good Morning Craig, My experience with any Aero Commander is now over fifty years old, but I do have a LOT of time operating various engines on the lean side of peak EGT. Back when I was flying early Aero Commanders and Twin Bonanzas I did occasionally run those engines on the lean side. It was only at low power settings and we did not have good instrumentation, but I observ ed no harm at the time. Further knowledge that I have acquired over th e last sixty years has convinced me that LOP is the way to go IF you have good distribution. The way I checked for good distribution befor e modern engine analyzers were available was to lean for a power drop. If the airplane could be slowed down about ten MPH via running on the lean side with no roughness, I figured it was good enough to operate LOP. I am certainly no engine expert, but I did attend a course taught by Curtiss Wright engineers in the spring of 1954. They made the same points that are now presented by the GAMI folks. I am a believer, but you HAVE to find a method of assuring that each cylinder is operating at the proper mixture. If you have not yet done so, I urge you to attend one of the seminars held by folks from GAMI. If you can't attend in person, take the home study version, but going with a group of pilots is a lot more fun. (Been there twice and I was a believer in the process before the folks at GAMI were born! ) Happy Skies, Old Bob AKA Bob Siegfried Brookeridge Air Park Downers Grove, Illinois Stearman N3977A In a message dated 4/18/2010 12:37:23 A.M. Central Daylight Time, whit e_rhino_ps(at)yahoo.com writes: Sure is Nico. Just brought it up from San Diego last weekend. Been sorting out leaky new fuel cells and the usual squawks. After doubl e clamping all the connector tubes, thought I had it whipped. Turns out those 10 cent cork access hole gaskets were leaking after being used a couple of times. A trip to Napa finally stopped the 5 dolla r a gallon drip!!! Rebuilt engines are running well. Need to dial in the injectors. Talked to the GAMI folks and they have never don e a IGO-540. Could be useful as I already have the GEM CHT/EGT moni tor and the JPI dual fuel flow so I can see what is going on pretty well. Has anyone in the gang had experience with this yet? The idea of running them 50 degrees LOP makes me cringe! Annual coming late summer so I'm collecting the bits now. I need to replace the aux fuel valves and that should finish with those issue s. Annual time with the nacelles down is the time for that! The do nor plane has been a big help with parts and bits. My pals have not iced that the donor plane so far has been the best plane investment in Commanders I've made to date! Not a lot of air time this year due to work but I'm hoping the fall will see more action. I put 74 7H up for sale, but so far, it's all looky-loos.... Craig From: cybersuperstore <nico(at)cybersuperstore.com> Sent: Sat, April 17, 2010 8:03:00 PM Subject: RE: Commander-List: Re: Commanders I lost my Outlook on my laptop and had to restore everything to a ne w desktop this past week. So, I am going through all the emails beca use the mail server lost the data that told it which email messages were already on my laptop and started downloading 10,000+ messages from more than a year ago. I am taking the opportunity to clean som e of the trash out and sorting them back into their respected folder s while I am at it. Yesterday I stopped over at Camarillo airport for a coffee and to wa lk around to see if I see familiar planes. And there was N747H, whic h I didn't thing anything of except to gawk into the windows and mov e on. Tonight I saw this message from almost a year ago. I am almost certain that I have seen 747H on the apron before, but cannot be su re. Craig, is she still under your command? Thanks Nico From: owner-commander-list-server(at)matronics.com [mailto:owner-comman der-list-server(at)matronics.com] On Behalf Of craig kennedy Sent: Monday, July 06, 2009 10:45 AM Subject: Commander-List: Re: Commanders Hello gang, Just thought I would update the group that 560F N747H, stored for over a year in the middle of nowhere ( Paris , TX ), is running again with rebuilt engines and props. Richard Cam at Aeroquest did a great job getting all the problems sorted out. Just a few more days to tidy up the remaining issues and she should be up for fun and adventure. Maybe even a trip for the annua l get together. Craig http://www.matronics.com/Navigator?Commander-List http://forums.matronics.com http://www.matronics.com/contribution ======================== =========== t href="http://www.matronics.com/Navigator?Commander-List">http://www.ma tronics.com/Navigator?Commander-List ======================== =========== ms.matronics.com/">http://forums.matronics.com ======================== =========== tp://www.matronics.com/contribution">http://www.matronics.com/contribution ======================== =========== ======================== =========== t href="http://www.matronics.com/Navigator?Commander-List">http://www.ma tronics.com/Navigator?Commander-List ======================== =========== ms.matronics.com/">http://forums.matronics.com ======================== =========== tp://www.matronics.com/contribution">http://www.matronics.com/contribution ======================== =========== http://www.matronics.com/Navigator?Commander-List http://forums.matronics.com http://www.matronics.com/contribution href="http://www.matronics.com/Navigator?Commander-List">http://www.matr onics.com/Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ======================== =========== ator?Commander-List">http://www.matronics.com/Navigator?Commander-List ======================== =========== ttp://forums.matronics.com ======================== =========== ibution">http://www.matronics.com/contribution ======================== =========== ======================== =========== t href="http://www.matronics.com/Navigator?Commander-List">http://www.ma tronics.com/Navigator?Commander-List ======================== =========== ms.matronics.com/">http://forums.matronics.com ======================== =========== tp://www.matronics.com/contribution">http://www.matronics.com/contribution ======================== =========== ======================== =========== ======================== =========== ======================== =========== ======================== =========== ________________________________________________________________________________
Date: May 03, 2010
Subject: Re: Now Operating LOP
Hi Bill, I've had many conversations with John about how he runs his airplanes. I recall that he is a fan of LOP operations. He averages several hundred hours beyond TBO for all his engines, and saves gas money in the process. His airplanes seem to run very well and he's never mentioned an undue number of replacement cylinders. Incidentally, my "old" engine, which is at TBO, has always run beautifully LOP. My "new" engine, which was mid-time, never did...and a couple of years ago, after a decade running it ROP, it broke a ring, burned up a jug, and cracked the case, leading to an OH. My B model is turbonormalized and I cruise at 75% power. I'm a big fan of LOP operations, as the happy-lean engine seems to support. I'll be getting GAMIs for both engines soon. The IGSO-540 series may not be a candidate for LOP due to its fuel delivery method and higher stress condition, but the IO-540 direct drive engines seem custom made for it. Cheers, John sent by my DROID. Please pardon any typos. On May 3, 2010 10:59 PM, wrote: Hey, Ken, While I am not a fan of LOP operations, If there is an engine and installation it might work on it would be the 500B/U/S. With proper baffling, those engines run so cool heat is not a problem. That is why Bob Hoover could cut his engines at full power and then restart them and immediately go back to full power for his air show. He rarely had to change cylinders. They just never got hot enough to crack. However, those airplanes need all the power they can get. LOP may cause a power loss that is un acceptable reduction of speed. Wonder how John Towner operates his flock (30+ aircraft) ? He has to squeeze every nickel out of his aircraft because his livelihood depends on it. Does he prefer to spend money on fuel or engines? Bill Leff In a message dated 4/22/2010 9:15:35 A.M. Eastern Daylight Time, KenWHyde(at)aol.com writes: Know this is about the IGSO540 & IGO540 but what are the thoughts of LOP on the narrow deck IO540's?? Thanks, Ken > > =================================== > t href="http://www.matronics.com/Navigator?Commander-Lis... ________________________________________________________________________________
From: "Bill Hamilton" <wjrhamilton(at)optusnet.com.au>
Date: May 04, 2010
Folks, I certainly concur about the IO-540. Although in Pipers, not Commanders, and before GAMI, we operated a 260B Comanche and two Aztec, all fitted with EGT on all cylinders, and ran LOP based on the hottest cylinder. We also ran "Low RPM/High boost. We regularly obtained around 3000h TBO, after a top at 1000h, which eliminated burning valve seats. The fuel saving are quite dramatic, for the same HP output, the cruise altitudes usually meant that about 65% was all that was available. The difference between "high rpm/low boost" and running ROP, and the reverse plus LOP was the difference between a fuel flow in cruise of about 12.5 US GPH per engine v. about 9 US GPH. For an engine like the IO-540, even the oil looked different at a 50h oil/filter change, with LOP the oil was not a black goo, but closer to the original colour of fresh oil. By definition, running ROP or LOP is cooler than peak EGT, but as test cell and real world experience has shown, to maximise the chance of detonation, run a mixture about 50 degrees ROP. There are some amazing old wife's tales about LOP, particularly from A&Ps. We have even had the rubbish turn up, down here in AU, from the ATSB and as Coroner's Courts evidence. One smarter than the average Coroner decided that the only way to sort out the old wife's tales was to take his court to GAMI, and commission actual test cell verification. This completely disproved claims made in an ATSB report about a particular very controversial fatal. This really upset the "lean to rough running, the rich until it smooths out" brigade, who have no idea how variable the actual cylinder by cylinder distribution is in an engine that only has "standard" injectors. For any engine that can benefit from GAMIs, fitting them and a multi-point EGT, and running LOP is a very positive investment in ensuring long and reliable minimum cost life. To tear down an LOP operated IO-540 at 2000h, and find that the first run barrels are within limits to just deglaze and fit new rings helps make for a minimum cost overhaul. Regards, Bill Hamilton From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of John Vormbaum Sent: Tuesday, May 04, 2010 4:21 PM Subject: Re: Was : Re: Commander-List: Now Operating LOP Hi Bill, I've had many conversations with John about how he runs his airplanes. I recall that he is a fan of LOP operations. He averages several hundred hours beyond TBO for all his engines, and saves gas money in the process. His airplanes seem to run very well and he's never mentioned an undue number of replacement cylinders. Incidentally, my "old" engine, which is at TBO, has always run beautifully LOP. My "new" engine, which was mid-time, never did...and a couple of years ago, after a decade running it ROP, it broke a ring, burned up a jug, and cracked the case, leading to an OH. My B model is turbonormalized and I cruise at 75% power. I'm a big fan of LOP operations, as the happy-lean engine seems to support. I'll be getting GAMIs for both engines soon. The IGSO-540 series may not be a candidate for LOP due to its fuel delivery method and higher stress condition, but the IO-540 direct drive engines seem custom made for it. Cheers, John sent by my DROID. Please pardon any typos. On May 3, 2010 10:59 PM, wrote: Hey, Ken, While I am not a fan of LOP operations, If there is an engine and installation it might work on it would be the 500B/U/S. With proper baffling, those engines run so cool heat is not a problem. That is why Bob Hoover could cut his engines at full power and then restart them and immediately go back to full power for his air show. He rarely had to change cylinders. They just never got hot enough to crack. However, those airplanes need all the power they can get. LOP may cause a power loss that is un acceptable reduction of speed. Wonder how John Towner operates his flock (30+ aircraft) ? He has to squeeze every nickel out of his aircraft because his livelihood depends on it. Does he prefer to spend money on fuel or engines? Bill Leff In a message dated 4/22/2010 9:15:35 A.M. Eastern Daylight Time, KenWHyde(at)aol.com writes: Know this is about the IGSO540 & IGO540 but what are the thoughts of LOP on the narrow deck IO540's?? Thanks, Ken > > ========== > t href="http://www.matronics.com/Navigator?Commander-Lis... nt> ________________________________________________________________________________
Date: May 04, 2010
Bill, Do you use 50 ROP on coolest or hotest cylinder? Are you using CHT or EGT? Craig Sent via BlackBerry by AT&T -----Original Message----- From: BillLeff1(at)aol.com Date: Tue, 4 May 2010 01:07:34 Subject: Re: Was : Re: Commander-List: Now Operating LOP ________________________________________________________________________________
Date: May 04, 2010
Bill=2C What is your opnion as to mixture on my straight 500 with O540's?? Roland Gilliam AC 6291B From: BillLeff1(at)aol.com Date: Tue=2C 4 May 2010 01:15:17 -0400 Subject: Re: Was : Re: Commander-List: Now Operating LOP Forgot=2C you are right=2C we had better gas back then. If you follow the C ommander POH you will be running at peek. Lycoming does show LOP operation. THEY ALSO SELL CYLINDERS!!!!!!!!!! lOTS OF THEM. You guys can argue and th eorize all you want. But from a maintenance shop point of view. Run rich or carry cylinders with you! Bill Leff In a message dated 4/22/2010 1:02:45 A.M. Eastern Daylight Time=2C cloudcra ft(at)aol.com writes: Lycoming definitely advocated running the IGSO-540 Lean of Peak -- somewher e in the diaspora of Commander stuff in my garage I have an old Lycoming IG SO-540 operator's manual that shows the temperature-drop curves when runnin g LoP. When I was interviewing Jay (forgot his last name)=2C owner of Suburban Air Freight=2C for an article in an early Flight Group News (circa 1997)=2C we discussed how they operated their fleet of AC-680-FLs. They ran Rich of Peak -- not because of engine cooling: It was to compensa te for low lead AvGas. The engine was designed around a high lead content fuel and that lead lubri cated the valve guides=2C which Jay said was their greatest cause of premat ure engine removal when running LoP. Here we have an argument for running RoP based on something far different t han the engine temperature / heat dissipation controversy. That's somethin g to consider if you're running the older engines born in the era of green colored AvGas. Wing Commander Gordon Life is not simple anywhere. Probably less so elsewhere. -----Original Message----- From: Jack B. Mills <moe-rosspistons(at)hotmail.com> Sent: Wed=2C Apr 21=2C 2010 7:22 pm Subject: Re: Was : Re: Commander-List: Now Operating LOP Nico=2C Due to the fact that the IGSO540 has only one injector nozzle which squirts directly into the supercharger impeller the mixture is pretty well atomize d and even from cylinder to cylinder (at least it has been on all four engi nes that have been in my plane). If there is a difference in EGT from cyli nder is is most likely because the flow or air fuel mixture is different du e to valve job=2C intake port configuration=2C or some other imbalance in t he air fuel mixture flow rate from cyl. to cyl. I am a huge fan of runnin g LOP=2C as the cylinder head temps are much cooler. This of course does c ut down on the horsepower. I sort of figgered this out back in the '80s wh en running my top fuel dragster. When I had some money the engine was run rich=2C made a lot of horsepower and consumed mountains of parts. When mon ey was tight I simply ran it so lean that it couldn't hurt its self. Moe Mills N680RR 680Fp From: cybersuperstore Sent: Wednesday=2C April 21=2C 2010 5:14 PM Subject: RE: Was : Re: Commander-List: Now Operating LOP Hi Bill=2C As someone who hasn't yet come to terms with pulling the mixtures to the ch eap side of peak=2C I still wonder=2C if one could manage each cylinder sep arately such as with GAMI's=2C whether the IGSO-540's would sustain a good TBO. I realize it might not be practical as GAMI suggested=2C but theoretic ally=2C what would prevent these engines from working well LOP with GAMI's? I assume when you say that the Wright and P&W engines have "a lot more meat " on the radial cylinders=2C that there is more aluminum above the gudgeon pin to dissipate or handle the heat=2C right? But are the temperatures not coming down when running LOP? Thanks Nico From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-lis t-server(at)matronics.com] On Behalf Of BillLeff1(at)aol.com Sent: Wednesday=2C April 21=2C 2010 4:39 PM Subject: Re: Was : Re: Commander-List: Now Operating LOP Hey guys=2C I have been flying IGSO-540's and IGO-540's ( I own 2 560F's ) and I would not even consider operating LOP. If you fly per the Commander manual you will be operating at peek. Everyone I know that operates that wa y goes through a lot of cylinders. The operators that fly 50-100 ROP have l ittle trouble. Fuel is Cheep! As far as LOP operations=2C the P&W and Wright engines are designed for it =2C Lycomings are not. There is a lot more meat on the radial cylinders. I spoke with the folks at GAMI about injectors for the 560F. They said that the IGO-540 fuel and induction system could not be improve enough to justi fy the expense. One of my 560F's has over 7000 hours on it and the same person has done eve ry overhaul. Also=2C with the exception of about 200 hours I have know ever y operator of the aircraft. It has had one in flight shutdown=2C That was a failed valve in the #1 cylinder and the engine was near TBO. We never ran lean. Oddly enough I started flying this 560F in 1971. In 1994 I bought it and am still flying it. What a great airplane! Bill Leff In a message dated 4/18/2010 8:31:50 A.M. Eastern Daylight Time=2C BobsV35B @aol.com writes: Good Morning Craig=2C My experience with any Aero Commander is now over fifty years old=2C but I do have a LOT of time operating various engines on the lean side of peak EG T. Back when I was flying early Aero Commanders and Twin Bonanzas I did occasi onally run those engines on the lean side. It was only at low power setting s and we did not have good instrumentation=2C but I observed no harm at the time. Further knowledge that I have acquired over the last sixty years has convinced me that LOP is the way to go IF you have good distribution. The way I checked for good distribution before modern engine analyzers were ava ilable was to lean for a power drop. If the airplane could be slowed down a bout ten MPH via running on the lean side with no roughness=2C I figured it was good enough to operate LOP. I am certainly no engine expert=2C but I did attend a course taught by Curt iss Wright engineers in the spring of 1954. They made the same points that are now presented by the GAMI folks. I am a believer=2C but you HAVE to find a method of assuring that each cyli nder is operating at the proper mixture. If you have not yet done so=2C I u rge you to attend one of the seminars held by folks from GAMI. If you can't attend in person=2C take the home study version=2C but going with a group of pilots is a lot more fun. (Been there twice and I was a believer in the process before the folks at GAMI were born! ) Happy Skies=2C Old Bob AKA Bob Siegfried Brookeridge Air Park Downers Grove=2C Illinois Stearman N3977A In a message dated 4/18/2010 12:37:23 A.M. Central Daylight Time=2C white_r hino_ps(at)yahoo.com writes: Sure is Nico. Just brought it up from San Diego last weekend. Been sortin g out leaky new fuel cells and the usual squawks. After double clamping all the connector tubes=2C thought I had it whipped. Turns out those 10 cent cork access hole gaskets were leaking after being used a couple of times. A trip to Napa finally stopped the 5 dollar a gallon drip!!! Rebuilt engin es are running well. Need to dial in the injectors. Talked to the GAMI fo lks and they have never done a IGO-540. Could be useful as I already have the GEM CHT/EGT monitor and the JPI dual fuel flow so I can see what is goi ng on pretty well. Has anyone in the gang had experience with this yet? T he idea of running them 50 degrees LOP makes me cringe! Annual coming late summer so I'm collecting the bits now. I need to replace the aux fuel valves and that should finish with those issues. Annual time with the nacelles down is the time for that! The donor plane has been a b ig help with parts and bits. My pals have noticed that the donor plane so far has been the best plane investment in Commanders I've made to date! N ot a lot of air time this year due to work but I'm hoping the fall will see more action. I put 747H up for sale=2C but so far=2C it's all looky-loos. ... Craig From: cybersuperstore <nico(at)cybersuperstore.com> Sent: Sat=2C April 17=2C 2010 8:03:00 PM Subject: RE: Commander-List: Re: Commanders I lost my Outlook on my laptop and had to restore everything to a new deskt op this past week. So=2C I am going through all the emails because the mail server lost the data that told it which email messages were already on my laptop and started downloading 10=2C000+ messages from more than a year ago . I am taking the opportunity to clean some of the trash out and sorting th em back into their respected folders while I am at it. Yesterday I stopped over at Camarillo airport for a coffee and to walk arou nd to see if I see familiar planes. And there was N747H=2C which I didn't t hing anything of except to gawk into the windows and move on. Tonight I saw this message from almost a year ago. I am almost certain that I have seen 747H on the apron before=2C but cannot be sure. Craig=2C is she still under your command? Thanks Nico From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-lis t-server(at)matronics.com] On Behalf Of craig kennedy Sent: Monday=2C July 06=2C 2009 10:45 AM Subject: Commander-List: Re: Commanders Hello gang=2C Just thought I would update the group that 560F N747H=2C stored for over a year in the middle of nowhere ( Paris =2C TX )=2C is running again with reb uilt engines and props. Richard Cam at Aeroquest did a great job getting a ll the problems sorted out. Just a few more days to tidy up the remaining issues and she should be up for fun and adventure. Maybe even a trip for t he annual get together. Craig http://www.matronics.com/Navigator?Commander-Listhttp://forums.matroni cs.comhttp://www.matronics.com/contribution ======================== ============t href="http://www.matronics.com/Navi gator?Commander-List">http://www.matronics.com/Navigator?Commander-List= ==========ms.matronics.com/">http://forums.matronics.co m======================== ============tp://www.matronics.com/contribution">ht tp://www.matronics.com/contribution============= ======================= = ==========t href="http://www.matronics.com/Navigator? Commander-List">http://www.matronics.com/Navigator?Commander-List=== ========ms.matronics.com/">http://forums.matronics.com= ==========tp://www.matronics.com/contribution">http://w ww.matronics.com/contribution=============== ===================== http://ww w.matronics.com/Navigator?Commander-Listhttp://forums.matronics.comhttp://w ww.matronics.com/contribution href="http://www.matronics.com/Navigator?Commander-List">http://www.matro nics.com/Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ator?Commander-List">http://www.matronics.com/Navigator?Commander-List ttp://forums.matronics.com ibution">http://www.matronics.com/contribution t href="http://www.matronics.com/Navigator?Commander-List">http://www.mat ronics.com/Navigator?Commander-List ms.matronics.com/">http://forums.matronics.com tp://www.matronics.com/contribution">http://www.matronics.com/contribution _________________________________________________________________ The New Busy think 9 to 5 is a cute idea. Combine multiple calendars with H otmail. http://www.windowslive.com/campaign/thenewbusy?tile=multicalendar&ocid= PID28326::T:WLMTAGL:ON:WL:en-US:WM_HMP:042010_5 ________________________________________________________________________________
Subject: FW: A great lady dies
Date: May 03, 2010
Subject: Fw: A great lady dies Rest in Peace, and thank you, Mrs. Pamela Murphy. Dennis McCarthy Los Angeles Times on April 15, 2010 October 7, 1923 - April 8, 2010 Pamela Murphy, widow of WWII hero and actor, Audie Murphy, died peacefully at her home on April 8, 2010. She is survived by sons, Terry and James. Pam established her own distinctive 30 year career working as a patient liaison at the Sepulveda VA Hospital, where she was much beloved. Services will be held at Forest Lawn (Hollywood Hills) on Friday April 16 at 2:30PM <http://www.dailynews.com/portlet/article/html/imageDisplay.jsp?contentIt emRelationshipId=2961390> http://www.dailynews.com/portlet/article/html/imageDisplay.jsp?contentIte mRelationshipId=2961390 Pam Murphy, the widow of Audie Murphy, was involved in the Sepulveda VA hospital and care center over the course of 35 years, treating every veteran who visited the facility as if they were a VIP. Pam Murphy died last week at the age of 90. After Audie died, they all became her boys. Every last one of them. Any soldier or Marine who walked into the Sepulveda VA hospital and care center in the last 35 years got the VIP treatment from Pam Murphy. The widow of Audie Murphy =93 the most decorated soldier in World War II =93 would walk the hallways with her clipboard in hand making sure her boys got to see a specialist or doctor =94 STAT. If they didn't, watch out. Her boys weren't Medal of Honor recipients or movie stars like Audie, but that didn't matter to Pam. They had served their country. That was good enough for her. She never called a veteran by his first name. It was always "Mister." Respect came with the job. "Nobody could cut through VA red tape faster than Mrs. Murphy," said veteran Stephen Sherman, speaking for thousands of veterans she befriended over the years. "Many times I watched her march a veteran who had been waiting more than an hour right into the doctor's office. She was even reprimanded a few times, but it didn't matter to Mrs. Murphy. "Only her boys mattered. She was our angel." Last week, Sepulveda VA's angel for the last 35 years died peacefully in her sleep at age 90. "She was in bed watching the Laker game, took one last breath, and thatwas it," said Diane Ruiz, who also worked at the VA and cared for Pam in the last years of her life in her Canoga Park apartment. It was the same apartment Pam moved into soon after Audie died in a plane crash on Memorial Day weekend in 1971. Audie Murphy died broke, squandering million of dollars on gambling, bad investments, and yes, other women. "Even with the adultery and desertion at the end, he always remained my hero," Pam told me. She went from a comfortable ranch-style home in Van Nuys where she raised two sons to a small apartment - taking a clerk's job at the nearby VA to support herself and start paying off her faded movie star husband's debts. At first, no one knew who she was. Soon, though, word spread through the VA that the nice woman with the clipboard was Audie Murphy's widow. It was like saying Patton had just walked in the front door. Men with tears in their eyes walked up to her and gave her a hug. "Thank you," they said, over and over. The first couple of years, I think the hugs were more for Audie's memory as a war hero. The last 30 years, they were for Pam. She hated the spotlight. One year I asked her to be the focus of a Veteran's Day column for all the work she had done. Pam just shook her head no. "Honor them, not me," she said, pointing to a group of veterans down the hallway. "They're the ones who deserve it." The vets disagreed. Mrs. Murphy deserved the accolades, they said. Incredibly, in 2002, Pam's job was going to be eliminated in budget cuts. She was considered "excess staff." "I don't think helping cut down on veterans' complaints and showing them the respect they deserve, should be considered excess staff," she told me. Neither did the veterans. They went ballistic, holding a rally for her outside the VA gates. Pretty soon, word came down from the top of the VA. Pam Murphy was no longer considered "excess staff." She remained working full time at the VA until 2007 when she was 87. "The last time she was here was a couple of years ago for the conference we had for homeless veterans," said Becky James, coordinator of the VA's Veterans History Project. Pam wanted to see if there was anything she could do to help some more of her boys. Dennis McCarthy's column appears Tuesday, Thursday, Friday and Sunday. About Audie Murphy > http://www.warfoto.com/AudieMurphy.htm = <http://www.bandoo.com/wp/ie.php?plg=ie&ad2=0&subs=hotmail&elm=si gn> =EF=BB <http://www.bandoo.com/wp/ie.php?plg=ie&ad2=0&subs=hotmail&elm=si gn> _____ <http://www.spamfighter.com/len> . We are a community of 7 million users fighting spam. The Professional version does not have this message. ________________________________________________________________________________
Subject: VIBRATION
Date: May 04, 2010
HARRY, DYNAMIC BALANCE OF THE 500B RT ENGINE DID THE TRICK. NOTE THERE WAS A DIFFERENTIAL IN THE AMOUNT OF GREASE IN EACH BLADE HUB WHICH CORRECTING HELPED. IVE GOT ONE MORE PROBLEM ON THE RIGHT SIDE WHICH IS A PUZZLE . THE FUEL FLOW METER INDICATES 150pct OF NORMAL FOR ANY GIVEN POWER SETTING. ITS NOT THE METER AS I SWOPED LEFT WITH RIGHT AND THE PROBLEM FOLLOWED TO THE LEFT FLOW METER. ANY IDEAS WILL BE APPRECIATED. THANKS,LLOYD ________________________________________________________________________________
Subject: Re: VIBRATION
Date: May 05, 2010
Take out the injectors and have thim cleaned1 Harry ----- Original Message ----- From: lloyd silverman To: commander-list Sent: Tuesday, May 04, 2010 8:37 PM Subject: Commander-List: VIBRATION HARRY, DYNAMIC BALANCE OF THE 500B RT ENGINE DID THE TRICK. NOTE THERE WAS A DIFFERENTIAL IN THE AMOUNT OF GREASE IN EACH BLADE HUB WHICH CORRECTING HELPED. IVE GOT ONE MORE PROBLEM ON THE RIGHT SIDE WHICH IS A PUZZLE . THE FUEL FLOW METER INDICATES 150pct OF NORMAL FOR ANY GIVEN POWER SETTING. ITS NOT THE METER AS I SWOPED LEFT WITH RIGHT AND THE PROBLEM FOLLOWED TO THE LEFT FLOW METER. ANY IDEAS WILL BE APPRECIATED. THANKS,LLOYD ________________________________________________________________________________
Date: May 05, 2010
That is a carbureted engine. I I would run it 50-75 deg. rich. 50 if it is smooth. Bill In a message dated 5/4/2010 10:18:23 A.M. Eastern Daylight Time, amg3636(at)hotmail.com writes: Bill, What is your opnion as to mixture on my straight 500 with O540's?? Roland Gilliam AC 6291B ____________________________________ From: BillLeff1(at)aol.com Date: Tue, 4 May 2010 01:15:17 -0400 Subject: Re: Was : Re: Commander-List: Now Operating LOP Forgot, you are right, we had better gas back then. If you follow the Commander POH you will be running at peek. Lycoming does show LOP operation. THEY ALSO SELL CYLINDERS!!!!!!!!!! lOTS OF THEM. You guys can argue and theorize all you want. But from a maintenance shop point of view. Run rich or carry cylinders with you! Bill Leff In a message dated 4/22/2010 1:02:45 A.M. Eastern Daylight Time, cloudcraft(at)aol.com writes: Lycoming definitely advocated running the IGSO-540 Lean of Peak -- somewhere in the diaspora of Commander stuff in my garage I have an old Lycoming IGSO-540 operator's manual that shows the temperature-drop curves when running LoP. When I was interviewing Jay (forgot his last name), owner of Suburban Air Freight, for an article in an early Flight Group News (circa 1997), we discussed how they operated their fleet of AC-680-FLs. They ran Rich of Peak -- not because of engine cooling: It was to compensate for low lead AvGas. The engine was designed around a high lead content fuel and that lead lubricated the valve guides, which Jay said was their greatest cause of premature engine removal when running LoP. Here we have an argument for running RoP based on something far different than the engine temperature / heat dissipation controversy. That's something to consider if you're running the older engines born in the era of green colored AvGas. Wing Commander Gordon Life is not simple anywhere. Probably less so elsewhere. -----Original Message----- From: Jack B. Mills <moe-rosspistons(at)hotmail.com> Sent: Wed, Apr 21, 2010 7:22 pm Subject: Re: Was : Re: Commander-List: Now Operating LOP Nico, Due to the fact that the IGSO540 has only one injector nozzle which squirts directly into the supercharger impeller the mixture is pretty well atomized and even from cylinder to cylinder (at least it has been on all four engines that have been in my plane). If there is a difference in EGT from cylinder is is most likely because the flow or air fuel mixture is different due to valve job, intake port configuration, or some other imbalance in the air fuel mixture flow rate from cyl. to cyl. I am a huge fan of running LOP, as the cylinder head temps are much cooler. This of course does cut down on the horsepower. I sort of figgered this out back in the '80s when running my top fuel dragster. When I had some money the engine was run rich, made a lot of horsepower and consumed mountains of parts. When money was tight I simply ran it so lean that it couldn't hurt its self. Moe Mills N680RR 680Fp From: _cybersuperstore_ (mailto:nico(at)cybersuperstore.com) Sent: Wednesday, April 21, 2010 5:14 PM Subject: RE: Was : Re: Commander-List: Now Operating LOP Hi Bill, As someone who hasn't yet come to terms with pulling the mixtures to the cheap side of peak, I still wonder, if one could manage each cylinder separately such as with GAMI's, whether the IGSO-540's would sustain a good TBO. I realize it might not be practical as GAMI suggested, but theoretically, what would prevent these engines from working well LOP with GAMI's? I assume when you say that the Wright and P&W engines have "a lot more meat" on the radial cylinders, that there is more aluminum above the gudgeon pin to dissipate or handle the heat, right? But are the temperatures not coming down when running LOP? Thanks Nico ____________________________________ From: _owner-commander-list-server(at)matronics.com_ (mailto:owner-commander-list-server(at)matronics.com) [_mailto:owner-commander-list-server(at)matronics.com_ (mailto:owner-commander-list-server(at)matronics.com?) ] On Behalf Of _BillLeff1(at)aol.com_ (mailto:BillLeff1(at)aol.com) Sent: Wednesday, April 21, 2010 4:39 PM Subject: Re: Was : Re: Commander-List: Now Operating LOP Hey guys, I have been flying IGSO-540's and IGO-540's ( I own 2 560F's ) and I would not even consider operating LOP. If you fly per the Commander manual you will be operating at peek. Everyone I know that operates that way goes through a lot of cylinders. The operators that fly 50-100 ROP have little trouble. Fuel is Cheep! As far as LOP operations, the P&W and Wright engines are designed for it, Lycomings are not. There is a lot more meat on the radial cylinders. I spoke with the folks at GAMI about injectors for the 560F. They said that the IGO-540 fuel and induction system could not be improve enough to justify the expense. One of my 560F's has over 7000 hours on it and the same person has done every overhaul. Also, with the exception of about 200 hours I have know every operator of the aircraft. It has had one in flight shutdown, That was a failed valve in the #1 cylinder and the engine was near TBO. We never ran lean. Oddly enough I started flying this 560F in 1971. In 1994 I bought it and am still flying it. What a great airplane! Bill Leff In a message dated 4/18/2010 8:31:50 A.M. Eastern Daylight Time, _BobsV35B(at)aol.com_ (mailto:BobsV35B(at)aol.com) writes: Good Morning Craig, My experience with any Aero Commander is now over fifty years old, but I do have a LOT of time operating various engines on the lean side of peak EGT. Back when I was flying early Aero Commanders and Twin Bonanzas I did occasionally run those engines on the lean side. It was only at low power settings and we did not have good instrumentation, but I observed no harm at the time. Further knowledge that I have acquired over the last sixty years has convinced me that LOP is the way to go IF you have good distribution. The way I checked for good distribution before modern engine analyzers were available was to lean for a power drop. If the airplane could be slowed down about ten MPH via running on the lean side with no roughness, I figured it was good enough to operate LOP. I am certainly no engine expert, but I did attend a course taught by Curtiss Wright engineers in the spring of 1954. They made the same points that are now presented by the GAMI folks. I am a believer, but you HAVE to find a method of assuring that each cylinder is operating at the proper mixture. If you have not yet done so, I urge you to attend one of the seminars held by folks from GAMI. If you can't attend in person, take the home study version, but going with a group of pilots is a lot more fun. (Been there twice and I was a believer in the process before the folks at GAMI were born! ) Happy Skies, Old Bob AKA Bob Siegfried Brookeridge Air Park Downers Grove, Illinois Stearman N3977A In a message dated 4/18/2010 12:37:23 A.M. Central Daylight Time, _white_rhino_ps(at)yahoo.com_ (mailto:white_rhino_ps(at)yahoo.com) writes: Sure is Nico. Just brought it up from San Diego last weekend. Been sorting out leaky new fuel cells and the usual squawks. After double clamping all the connector tubes, thought I had it whipped. Turns out those 10 cent cork access hole gaskets were leaking after being used a couple of times. A trip to Napa finally stopped the 5 dollar a gallon drip!!! Rebuilt engines are running well. Need to dial in the injectors. Talked to the GAMI folks and they have never done a IGO-540. Could be useful as I already have the GEM CHT/EGT monitor and the JPI dual fuel flow so I can see what is going on pretty well. Has anyone in the gang had experience with this yet? The idea of running them 50 degrees LOP makes me cringe! Annual coming late summer so I'm collecting the bits now. I need to replace the aux fuel valves and that should finish with those issues. Annual time with the nacelles down is the time for that! The donor plane has been a big help with parts and bits. My pals have noticed that the donor plane so far has been the best plane investment in Commanders I've made to date! Not a lot of air time this year due to work but I'm hoping the fall will see more action. I put 747H up for sale, but so far, it's all looky-loos.... Craig ____________________________________ From: cybersuperstore <_nico(at)cybersuperstore.com_ (mailto:nico(at)cybersuperstore.com) > Sent: Sat, April 17, 2010 8:03:00 PM Subject: RE: Commander-List: Re: Commanders I lost my Outlook on my laptop and had to restore everything to a new desktop this past week. So, I am going through all the emails because the mail server lost the data that told it which email messages were already on my laptop and started downloading 10,000+ messages from more than a year ago. I am taking the opportunity to clean some of the trash out and sorting them back into their respected folders while I am at it. Yesterday I stopped over at Camarillo airport for a coffee and to walk around to see if I see familiar planes. And there was N747H, which I didn't thing anything of except to gawk into the windows and move on. Tonight I saw this message from almost a year ago. I am almost certain that I have seen 747H on the apron before, but cannot be sure. Craig, is she still under your command? Thanks Nico ____________________________________ From: _owner-commander-list-server(at)matronics.com_ (mailto:owner-commander-list-server(at)matronics.com) [_mailto:owner-commander-list-server(at)matronics.com_ (mailto:owner-commander-list-server(at)matronics.com?) ] On Behalf Of craig kennedy Sent: Monday, July 06, 2009 10:45 AM Subject: Commander-List: Re: Commanders Hello gang, Just thought I would update the group that 560F N747H, stored for over a year in the middle of nowhere ( Paris , TX ), is running again with rebuilt engines and props. Richard Cam at Aeroquest did a great job getting all the problems sorted out. Just a few more days to tidy up the remaining issues and she should be up for fun and adventure. Maybe even a trip for the annual get together. Craig _http://www.matronics.com/Navigator?Commander-List_ (http://www.matronics.com/Navigator?Commander-List) _http://forums.matronics.com_ (http://forums.matronics.com/) _http://www.matronics.com/contribution_ (http://www.matronics.com/contribution) =================================== t href="_http://www.matronics.com/Navigator?Commander-List_ (http://www.matronics.com/Navigator?Commander-List) ">_http://www.matronics.com/Navigator?Commander-List_ (http://www.matronics.com/Navigator?Commander-List) =================================== ms.matronics.com/">_http://forums.matronics.com_ (http://forums.matronics.com/) ========== tp://_www.matronics.com/contribution_ (http://www.matronics.com/contribution) ">_http://www.matronics.com/contribution_ (http://www.matronics.com/contribution) ========== =================================== t href="_http://www.matronics.com/Navigator?Commander-List_ (http://www.matronics.com/Navigator?Commander-List) ">_http://www.matronics.com/Navigator?Commander-List_ (http://www.matronics.com/Navigator?Commander-List) =================================== ms.matronics.com/">_http://forums.matronics.com_ (http://forums.matronics.com/) ========== tp://_www.matronics.com/contribution_ (http://www.matronics.com/contribution) ">_http://www.matronics.com/contribution_ (http://www.matronics.com/contribution) ========== http://www.matronics.com/Navigator?Commander-List http://forums.matronics.com http://www.matronics.com/contribution href="_http://www.matronics.com/Navigator?Commander-List_ (http://www.matronics.com/Navigator?Commander-List) ">_http://www.matronics.com/Navigator?Commander-List_ (http://www.matronics.com/Navigator?Commander-List) href="_http://forums.matronics.com_ (http://forums.matronics.com/) ">_http://forums.matronics.com_ (http://forums.matronics.com/) href="_http://www.matronics.com/contribution_ (http://www.matronics.com/contribution) ">_http://www.matronics.com/c_ (http://www.matronics.com/c) ========== ator?Commander-List">http://www.matronics.com/Navigator?Commander-List ========== ttp://forums.matronics.com ========== ibution">http://www.matronics.com/contribution ========== t href="http://www.matronics.com/Navigator?Commander-List">http://www.matronics.com/Navigator?Commander-List ms.matronics.com/">http://forums.matronics.com tp://www.matronics.com/contribution">http://www.matronics.com/contribution st">http://www.matronics.com/Navigator?Commander-List ronics.com ww.matronics.com/contribution ____________________________________ The New Busy think 9 to 5 is a cute idea. Combine multiple calendars with Hotmail. _Get busy._ (http://www.windowslive.com/campaign/thenewbusy?tile=multicalendar&ocid=PID28326::T:WLMTAGL:ON:WL:en-US:WM_HMP:042010_5) (http://www.matronics.com/Navigator?Commander-List) (http://www.matronics.com/contribution) ________________________________________________________________________________
Date: May 05, 2010
Ever hear of Max Conrad. He set many world distance records in a Comanche and Twin Comanche running over square. He would run 1500 rpm and all the MP he could get up to 24 inches. The only thing was he had to rely on Lycomin g to calculate the BMEP for him. It was very critical. Don't remember if he ran LOP. I doubt it. Bill In a message dated 5/4/2010 4:39:44 A.M. Eastern Daylight Time, wjrhamilton(at)optusnet.com.au writes: Folks, I certainly concur about the IO-540. Although in Pipers, not Commanders, and before GAMI, we operated a 260B Comanche and two Aztec, all fitted with EGT on all cylinders, and ran LOP based on the hottest cylinder. We also ran =9CLow RPM/High boost. We regularly obtained around 3000h TBO, after a top at 1000h, which eliminated burning valve seats. The fuel saving are quite dramatic, for the same HP output, the cruise altitudes usually meant that about 65% was all that was available. The difference between =9Chigh rpm/low boost=9D and running ROP, and the reverse plus LOP was the difference between a fuel flow in cruise of abou t 12.5 US GPH per engine v. about 9 US GPH. For an engine like the IO-540, even the oil looked different at a 50h oil/filter change, with LOP the oil was not a black goo, but closer to the original colour of fresh oil. By definition, running ROP or LOP is cooler than peak EGT, but as test cell and real world experience has shown, to maximise the chance of detonation, run a mixture about 50 degrees ROP. There are some amazing old wife=99s tales about LOP, particularly from A&Ps. We have even had the rubbish turn up, down here in AU, from the ATSB and as Coroner=99s Courts evidence. One smarter than the average Corone r decided that the only way to sort out the old wife=99s tales was to take hi s court to GAMI, and commission actual test cell verification. This completely disproved claims made in an ATSB report about a particular very controver sial fatal. This really upset the =9Clean to rough running, the rich until it smooths out =9D brigade, who have no idea how variable the actual cylinder by cylinder distribution is in an engine that only has =9Cstandard=9D inje ctors. For any engine that can benefit from GAMIs, fitting them and a multi-point EGT, an d running LOP is a very positive investment in ensuring long and reliable minimum cost life. To tear down an LOP operated IO-540 at 2000h, and find that the first run barrels are within limits to just deglaze and fit new rings helps make fo r a minimum cost overhaul. Regards, Bill Hamilton From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of John Vorm baum Sent: Tuesday, May 04, 2010 4:21 PM Subject: Re: Was : Re: Commander-List: Now Operating LOP Hi Bill, I've had many conversations with John about how he runs his airplanes. I recall that he is a fan of LOP operations. He averages several hundred hou rs beyond TBO for all his engines, and saves gas money in the process. His airplanes seem to run very well and he's never mentioned an undue number of replacement cylinders. Incidentally, my "old" engine, which is at TBO, has always run beautifully LOP. My "new" engine, which was mid-time, never did...and a co uple of years ago, after a decade running it ROP, it broke a ring, burned up a jug , and cracked the case, leading to an OH. My B model is turbonormalized and I cruise at 75% power. I'm a big fan of LOP operations, as the happy-lean engine seems to support. I'll be getting GAMIs for both engines soon. The IGSO-540 series may not be a candidate for LOP due to its fuel deliver y method and higher stress condition, but the IO-540 direct drive engines seem custom made for it. Cheers, John sent by my DROID. Please pardon any typos. On May 3, 2010 10:59 PM, <_BillLeff1(at)aol.com_ (mailto:BillLeff1(at)aol.com) > wrote: Hey, Ken, While I am not a fan of LOP operations, If there is an engine and installation it might work on it would be the 500B/U/S. With proper baffling, those engines run so cool heat is not a problem. That is why Bob Hoover could cut his engines at full power and then restart them and immediately go back to full power for his air show. He rarely had to change cylinders. They just never got hot enough to crack. However, those airplanes need all the power they can get. LOP may cause a power loss that is un acceptable reduction of speed. Wonder how John Towner operates his flock (30+ aircraft) ? He has to squeeze every nickel out of his aircraft because his livelihood depends on it. Does he prefer to spend money on fuel or engines? Bill Leff In a message dated 4/22/2010 9:15:35 A.M. Eastern Daylight Time, _KenWHyde(at)aol.com_ (mailto:KenWHyde(at)aol.com) writes: Know this is about the IGSO540 & IGO540 but what are the thoughts of LOP on the narrow deck IO540's?? Thanks, Ken > > ========== > t href="_http://www.matronics.com/Navigator?Commander-Lis._ (http://www.matronics.com/Navigator?Commander-Lis.) .. nt> http://www.matronics.com/Navigator?Commander-List http://forums.matronics.com http://www.matronics.com/contribution ======================== ============ (http://www.matronics.com/Navigator?Commander-List) ======================== ============ ======================== ============ (http://www.matronics.com/contribution) ======================== ============ ________________________________________________________________________________
Date: May 05, 2010
Good Morning Bill, Funny you should mention Max. We worked together for a short period of time when he was involved with a couple of other folks operating an FBO at Joliet, Illinois. We called it Max Conrad Aviation. We had many discussions as to how he operated in that long range cruise operation and it was always on the lean side IF good distribution could be obtained. He used a procedure similar to what I have advocated in that he would see how much airspeed he could lose before things got rough. With perfect distribution you can lean down until all cylinders quit firing and you wil l know that, at that particular power setting, you have perfect distribution. If the engine gets rough before the airspeed drops, distribution stinks. If while leaning you get a small increase in airspeed then a drop of ten MPH before the onset of roughness, distribution is pretty good. Max did a lot of experimentation using carburetor heat and other modes to find a point of good distribution. He did know enough about engines to realize that maximum power for any certain airflow was obtained at some point slightly richer than what we now call LOP. In those days, we did not have EGT gauges and we worked in reference to best power. As has been mentioned here often, best power comes well rich of peak EGT. The absolutely hottest place you can run any cylinder is fifty rich of pea k. At 65 percent power or below, that is fine. At a higher power you are pushing the engine very close to a bad operating range. When fuel distribution is bad, one cylinder may be at peak EGT, another might be running lean of peak EGT and another well rich of peak EGT. If distribution is bad and you really need the power, the engine should be run at least 150 rich of peak EGT. That will assure that all cylinders ar e getting enough fuel for the power desired. If you are looking for maximum range, as Max was, you tried to run on the lean side when at all practical. Max had it worked out where he could almo st always run well lean of what we would now call LOP. I always enjoyed talking to Max about lean side operations because he was one of the few pilots of that era who understood what we were doing and wh at were the problems that could be encountered. Happy Skies, Old Bob In a message dated 5/5/2010 1:35:57 P.M. Central Daylight Time, BillLeff1(at)aol.com writes: Ever hear of Max Conrad. He set many world distance records in a Comanche and Twin Comanche running over square. He would run 1500 rpm and all the MP he could get up to 24 inches. The only thing was he had to rely on Lycomin g to calculate the BMEP for him. It was very critical. Don't remember if he ran LOP. I doubt it. Bill In a message dated 5/4/2010 4:39:44 A.M. Eastern Daylight Time, wjrhamilton(at)optusnet.com.au writes: Folks, I certainly concur about the IO-540. Although in Pipers, not Commanders, and before GAMI, we operated a 260B Comanche and two Aztec, all fitted with EGT on all cylinders, and ran LOP based on the hottest cylinder. We also ran =9CLow RPM/High boost. We regularly obtained around 3000h TBO, after a top at 1000h, which eliminated burning valve seats. The fuel saving are quite dramatic, for the same HP output, the cruise altitudes usually meant that about 65% was all that was available. The difference between =9Chigh rpm/low boost=9D and running ROP, and the reverse plus LOP was the difference between a fuel flow in cruise of abou t 12.5 US GPH per engine v. about 9 US GPH. For an engine like the IO-540, even the oil looked different at a 50h oil/filter change, with LOP the oil was not a black goo, but closer to the original colour of fresh oil. By definition, running ROP or LOP is cooler than peak EGT, but as test cell and real world experience has shown, to maximise the chance of detonation, run a mixture about 50 degrees ROP. There are some amazing old wife=99s tales about LOP, particularly from A&Ps. We have even had the rubbish turn up, down here in AU, from the ATSB and as Coroner=99s Courts evidence. One smarter than the average Corone r decided that the only way to sort out the old wife=99s tales was to take hi s court to GAMI, and commission actual test cell verification. This completely disproved claims made in an ATSB report about a particular very controver sial fatal. This really upset the =9Clean to rough running, the rich until it smooths out =9D brigade, who have no idea how variable the actual cylinder by cylinder distribution is in an engine that only has =9Cstandard=9D inje ctors. For any engine that can benefit from GAMIs, fitting them and a multi-point EGT, an d running LOP is a very positive investment in ensuring long and reliable minimum cost life. To tear down an LOP operated IO-540 at 2000h, and find that the first run barrels are within limits to just deglaze and fit new rings helps make for a minimum cost overhaul. Regards, Bill Hamilton From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of John Vorm baum Sent: Tuesday, May 04, 2010 4:21 PM Subject: Re: Was : Re: Commander-List: Now Operating LOP Hi Bill, I've had many conversations with John about how he runs his airplanes. I recall that he is a fan of LOP operations. He averages several hundred hou rs beyond TBO for all his engines, and saves gas money in the process. His airplanes seem to run very well and he's never mentioned an undue number of replacement cylinders. Incidentally, my "old" engine, which is at TBO, has always run beautifully LOP. My "new" engine, which was mid-time, never did...and a couple of years ago, after a decade running it ROP, it broke a ring, burned up a ju g, and cracked the case, leading to an OH. My B model is turbonormalized and I cruise at 75% power. I'm a big fan of LOP operations, as the happy-lean engine seems to support. I'll be getting GAMIs for both engines soon. The IGSO-540 series may not be a candidate for LOP due to its fuel delivery method and higher stress condition, but the IO-540 direct drive engines seem custom made for it. Cheers, John sent by my DROID. Please pardon any typos. On May 3, 2010 10:59 PM, <_BillLeff1(at)aol.com_ (mailto:BillLeff1(at)aol.com) > wrote: Hey, Ken, While I am not a fan of LOP operations, If there is an engine and installation it might work on it would be the 500B/U/S. With proper baffling, those engines run so cool heat is not a problem. That is why Bob Hoover could cut his engines at full power and then restart them and immediately go back to full power for his air show. He rarely had to change cylinders. They just never got hot enough to crack. However, those airplanes need all the power they can get. LOP may cause a power loss that is un acceptable reduction of speed. Wonder how John Towner operates his flock (30+ aircraft) ? He has to squeeze every nickel out of his aircraft because his livelihood depends on it. Does he prefer to spend money on fuel or engines? Bill Leff In a message dated 4/22/2010 9:15:35 A.M. Eastern Daylight Time, _KenWHyde(at)aol.com_ (mailto:KenWHyde(at)aol.com) writes: Know this is about the IGSO540 & IGO540 but what are the thoughts of LOP on the narrow deck IO540's?? Thanks, Ken > > ========== > t href="_http://www.matronics.com/Navigator?Commander-Lis._ (http://www.matronics.com/Navigator?Commander-Lis.) .. nt> http://www.matronics.com/Navigator?Commander-List http://forums.matronics.com http://www.matronics.com/contribution ======================== =========== t href="http://www.matronics.com/Navigator?Commander-List">http://www.matr onics.com/Navigator?Commander-List ======================== ============ ms.matronics.com/">http://forums.matronics.com ========= ======================== === tp://www.matronics.com/contribution">http://www.matronics.com/contribution ======================== ============ ======================== ============ (http://www.matronics.com/Navigator?Commander-List) ======================== ============ ======================== ============ (http://www.matronics.com/contribution) ======================== ============ ________________________________________________________________________________
From: "cybersuperstore" <nico(at)cybersuperstore.com>
Date: May 05, 2010
I found this about Max. I just had to know more about him: http://soloflights.org/conrad_data_e.html Very interesting reading. There are links across the top of the page that contain more of the flights themselves. Nico _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of BobsV35B(at)aol.com Sent: Wednesday, May 05, 2010 12:29 PM Subject: Re: Was : Re: Commander-List: Now Operating LOP Good Morning Bill, Funny you should mention Max. We worked together for a short period of time when he was involved with a couple of other folks operating an FBO at Joliet, Illinois. We called it Max Conrad Aviation. We had many discussions as to how he operated in that long range cruise operation and it was always on the lean side IF good distribution could be obtained. He used a procedure similar to what I have advocated in that he would see how much airspeed he could lose before things got rough. With perfect distribution you can lean down until all cylinders quit firing and you will know that, at that particular power setting, you have perfect distribution. If the engine gets rough before the airspeed drops, distribution stinks. If while leaning you get a small increase in airspeed then a drop of ten MPH before the onset of roughness, distribution is pretty good. Max did a lot of experimentation using carburetor heat and other modes to find a point of good distribution. He did know enough about engines to realize that maximum power for any certain airflow was obtained at some point slightly richer than what we now call LOP. In those days, we did not have EGT gauges and we worked in reference to best power. As has been mentioned here often, best power comes well rich of peak EGT. The absolutely hottest place you can run any cylinder is fifty rich of peak. At 65 percent power or below, that is fine. At a higher power you are pushing the engine very close to a bad operating range. When fuel distribution is bad, one cylinder may be at peak EGT, another might be running lean of peak EGT and another well rich of peak EGT. If distribution is bad and you really need the power, the engine should be run at least 150 rich of peak EGT. That will assure that all cylinders are getting enough fuel for the power desired. If you are looking for maximum range, as Max was, you tried to run on the lean side when at all practical. Max had it worked out where he could almost always run well lean of what we would now call LOP. I always enjoyed talking to Max about lean side operations because he was one of the few pilots of that era who understood what we were doing and what were the problems that could be encountered. Happy Skies, Old Bob In a message dated 5/5/2010 1:35:57 P.M. Central Daylight Time, BillLeff1(at)aol.com writes: Ever hear of Max Conrad. He set many world distance records in a Comanche and Twin Comanche running over square. He would run 1500 rpm and all the MP he could get up to 24 inches. The only thing was he had to rely on Lycoming to calculate the BMEP for him. It was very critical. Don't remember if he ran LOP. I doubt it. Bill In a message dated 5/4/2010 4:39:44 A.M. Eastern Daylight Time, wjrhamilton(at)optusnet.com.au writes: Folks, I certainly concur about the IO-540. Although in Pipers, not Commanders, and before GAMI, we operated a 260B Comanche and two Aztec, all fitted with EGT on all cylinders, and ran LOP based on the hottest cylinder. We also ran "Low RPM/High boost. We regularly obtained around 3000h TBO, after a top at 1000h, which eliminated burning valve seats. The fuel saving are quite dramatic, for the same HP output, the cruise altitudes usually meant that about 65% was all that was available. The difference between "high rpm/low boost" and running ROP, and the reverse plus LOP was the difference between a fuel flow in cruise of about 12.5 US GPH per engine v. about 9 US GPH. For an engine like the IO-540, even the oil looked different at a 50h oil/filter change, with LOP the oil was not a black goo, but closer to the original colour of fresh oil. By definition, running ROP or LOP is cooler than peak EGT, but as test cell and real world experience has shown, to maximise the chance of detonation, run a mixture about 50 degrees ROP. There are some amazing old wife's tales about LOP, particularly from A&Ps. We have even had the rubbish turn up, down here in AU, from the ATSB and as Coroner's Courts evidence. One smarter than the average Coroner decided that the only way to sort out the old wife's tales was to take his court to GAMI, and commission actual test cell verification. This completely disproved claims made in an ATSB report about a particular very controversial fatal. This really upset the "lean to rough running, the rich until it smooths out" brigade, who have no idea how variable the actual cylinder by cylinder distribution is in an engine that only has "standard" injectors. For any engine that can benefit from GAMIs, fitting them and a multi-point EGT, and running LOP is a very positive investment in ensuring long and reliable minimum cost life. To tear down an LOP operated IO-540 at 2000h, and find that the first run barrels are within limits to just deglaze and fit new rings helps make for a minimum cost overhaul. Regards, Bill Hamilton From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of John Vormbaum Sent: Tuesday, May 04, 2010 4:21 PM Subject: Re: Was : Re: Commander-List: Now Operating LOP Hi Bill, I've had many conversations with John about how he runs his airplanes. I recall that he is a fan of LOP operations. He averages several hundred hours beyond TBO for all his engines, and saves gas money in the process. His airplanes seem to run very well and he's never mentioned an undue number of replacement cylinders. Incidentally, my "old" engine, which is at TBO, has always run beautifully LOP. My "new" engine, which was mid-time, never did...and a couple of years ago, after a decade running it ROP, it broke a ring, burned up a jug, and cracked the case, leading to an OH. My B model is turbonormalized and I cruise at 75% power. I'm a big fan of LOP operations, as the happy-lean engine seems to support. I'll be getting GAMIs for both engines soon. The IGSO-540 series may not be a candidate for LOP due to its fuel delivery method and higher stress condition, but the IO-540 direct drive engines seem custom made for it. Cheers, John sent by my DROID. Please pardon any typos. On May 3, 2010 10:59 PM, wrote: Hey, Ken, While I am not a fan of LOP operations, If there is an engine and installation it might work on it would be the 500B/U/S. With proper baffling, those engines run so cool heat is not a problem. That is why Bob Hoover could cut his engines at full power and then restart them and immediately go back to full power for his air show. He rarely had to change cylinders. They just never got hot enough to crack. However, those airplanes need all the power they can get. LOP may cause a power loss that is un acceptable reduction of speed. Wonder how John Towner operates his flock (30+ aircraft) ? He has to squeeze every nickel out of his aircraft because his livelihood depends on it. Does he prefer to spend money on fuel or engines? Bill Leff In a message dated 4/22/2010 9:15:35 A.M. Eastern Daylight Time, KenWHyde(at)aol.com writes: Know this is about the IGSO540 & IGO540 but what are the thoughts of LOP on the narrow deck IO540's?? Thanks, Ken > > ========== > t href="http://www.matronics.com/Navigator?Commander-Lis... nt> http://www.matronics.com/Navigator?Commander-List http://forums.matronics.com http://www.matronics.com/contribution =================================== t href="http://www.matronics.com/Navigator?Commander-List">http://www.matronic s.com/Navigator?Commander-List =================================== ms.matronics.com/">http://forums.matronics.com =================================== tp://www.matronics.com/contribution">http://www.matronics.com/contribution =================================== =================================== t href="http://www.matronics.com/Navigator?Commander-List">http://www.matronic s.com/Navigator?Commander-List =================================== ms.matronics.com/">http://forums.matronics.com =================================== tp://www.matronics.com/contribution">http://www.matronics.com/contribution =================================== ________________________________________________________________________________
Date: May 05, 2010
Wouldn't he run the risk of pre-ignition (detonation?) on 1500 x 24"? Although lower RPM would result in less fuel flow because less air is pumped, it does sound extreme. Even though Lycoming calculated the BMEP, one's hair still tends to stand on end. Interesting, though. Nico _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of BillLeff1(at)aol.com Sent: Wednesday, May 05, 2010 11:29 AM Subject: Re: Was : Re: Commander-List: Now Operating LOP Ever hear of Max Conrad. He set many world distance records in a Comanche and Twin Comanche running over square. He would run 1500 rpm and all the MP he could get up to 24 inches. The only thing was he had to rely on Lycoming to calculate the BMEP for him. It was very critical. Don't remember if he ran LOP. I doubt it. Bill In a message dated 5/4/2010 4:39:44 A.M. Eastern Daylight Time, wjrhamilton(at)optusnet.com.au writes: Folks, I certainly concur about the IO-540. Although in Pipers, not Commanders, and before GAMI, we operated a 260B Comanche and two Aztec, all fitted with EGT on all cylinders, and ran LOP based on the hottest cylinder. We also ran "Low RPM/High boost. We regularly obtained around 3000h TBO, after a top at 1000h, which eliminated burning valve seats. The fuel saving are quite dramatic, for the same HP output, the cruise altitudes usually meant that about 65% was all that was available. The difference between "high rpm/low boost" and running ROP, and the reverse plus LOP was the difference between a fuel flow in cruise of about 12.5 US GPH per engine v. about 9 US GPH. For an engine like the IO-540, even the oil looked different at a 50h oil/filter change, with LOP the oil was not a black goo, but closer to the original colour of fresh oil. By definition, running ROP or LOP is cooler than peak EGT, but as test cell and real world experience has shown, to maximise the chance of detonation, run a mixture about 50 degrees ROP. There are some amazing old wife's tales about LOP, particularly from A&Ps. We have even had the rubbish turn up, down here in AU, from the ATSB and as Coroner's Courts evidence. One smarter than the average Coroner decided that the only way to sort out the old wife's tales was to take his court to GAMI, and commission actual test cell verification. This completely disproved claims made in an ATSB report about a particular very controversial fatal. This really upset the "lean to rough running, the rich until it smooths out" brigade, who have no idea how variable the actual cylinder by cylinder distribution is in an engine that only has "standard" injectors. For any engine that can benefit from GAMIs, fitting them and a multi-point EGT, and running LOP is a very positive investment in ensuring long and reliable minimum cost life. To tear down an LOP operated IO-540 at 2000h, and find that the first run barrels are within limits to just deglaze and fit new rings helps make for a minimum cost overhaul. Regards, Bill Hamilton From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of John Vormbaum Sent: Tuesday, May 04, 2010 4:21 PM Subject: Re: Was : Re: Commander-List: Now Operating LOP Hi Bill, I've had many conversations with John about how he runs his airplanes. I recall that he is a fan of LOP operations. He averages several hundred hours beyond TBO for all his engines, and saves gas money in the process. His airplanes seem to run very well and he's never mentioned an undue number of replacement cylinders. Incidentally, my "old" engine, which is at TBO, has always run beautifully LOP. My "new" engine, which was mid-time, never did...and a couple of years ago, after a decade running it ROP, it broke a ring, burned up a jug, and cracked the case, leading to an OH. My B model is turbonormalized and I cruise at 75% power. I'm a big fan of LOP operations, as the happy-lean engine seems to support. I'll be getting GAMIs for both engines soon. The IGSO-540 series may not be a candidate for LOP due to its fuel delivery method and higher stress condition, but the IO-540 direct drive engines seem custom made for it. Cheers, John sent by my DROID. Please pardon any typos. On May 3, 2010 10:59 PM, wrote: Hey, Ken, While I am not a fan of LOP operations, If there is an engine and installation it might work on it would be the 500B/U/S. With proper baffling, those engines run so cool heat is not a problem. That is why Bob Hoover could cut his engines at full power and then restart them and immediately go back to full power for his air show. He rarely had to change cylinders. They just never got hot enough to crack. However, those airplanes need all the power they can get. LOP may cause a power loss that is un acceptable reduction of speed. Wonder how John Towner operates his flock (30+ aircraft) ? He has to squeeze every nickel out of his aircraft because his livelihood depends on it. Does he prefer to spend money on fuel or engines? Bill Leff In a message dated 4/22/2010 9:15:35 A.M. Eastern Daylight Time, KenWHyde(at)aol.com writes: Know this is about the IGSO540 & IGO540 but what are the thoughts of LOP on the narrow deck IO540's?? Thanks, Ken > > ========== > t href="http://www.matronics.com/Navigator?Commander-Lis... nt> http://www.matronics.com/Navigator?Commander-List http://forums.matronics.com http://www.matronics.com/contribution =================================== t href="http://www.matronics.com/Navigator?Commander-List">http://www.matronic s.com/Navigator?Commander-List =================================== ms.matronics.com/">http://forums.matronics.com =================================== tp://www.matronics.com/contribution">http://www.matronics.com/contribution =================================== ________________________________________________________________________________
Date: May 05, 2010
THANKS,LLOYD ----- Original Message ----- From: Harry Merritt<mailto:avtectwo(at)cfl.rr.com> To: commander-list(at)matronics.com Sent: Wednesday, May 05, 2010 7:27 AM Subject: Re: Commander-List: VIBRATION Take out the injectors and have thim cleaned1 Harry ----- Original Message ----- From: lloyd silverman<mailto:LLOYDSSS11(at)MSN.COM> To: commander-list Sent: Tuesday, May 04, 2010 8:37 PM Subject: Commander-List: VIBRATION HARRY, DYNAMIC BALANCE OF THE 500B RT ENGINE DID THE TRICK. NOTE THERE WAS A DIFFERENTIAL IN THE AMOUNT OF GREASE IN EACH BLADE HUB WHICH CORRECTING HELPED. IVE GOT ONE MORE PROBLEM ON THE RIGHT SIDE WHICH IS A PUZZLE . THE FUEL FLOW METER INDICATES 150pct OF NORMAL FOR ANY GIVEN POWER SETTING. ITS NOT THE METER AS I SWOPED LEFT WITH RIGHT AND THE PROBLEM FOLLOWED TO THE LEFT FLOW METER. ANY IDEAS WILL BE APPRECIATED. THANKS,LLOYD href="http://www.matronics.com/Navigator?Commander-List">http://www.mat ronics.com/Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c http://www.matronics.com/Navigator?Commander-List m/Navigator?Commander-List> http://www.matronics.com/contribution on> ________________________________________________________________________________
Subject: FUEL FLOW PROBLEM IN 500B
Date: May 06, 2010
HARRY, THE FUEL FLOWMETER PROBLEM IN THE RT ENGINE OF MY 500 B WAS TRACED TO A FRACTURED DIAPHRAM IN THE FUEL SPIDER. DO YOU HAVE ONE OR WHERE CAN I GET ONE. THANKS, LLOYD ________________________________________________________________________________
Subject:
Date: May 07, 2010
Welcome Guest ( Log <
http://www.asb.tv/forums/index.php?s=19f5ee3489ff4c67d680730ef66b50e7&act=L ogin&CODE=00> In | Register <http://www.asb.tv/forums/index.php?s=19f5ee3489ff4c67d680730ef66b50e7&act=R eg&CODE=00> ) <http://www.asb.tv/forums/index.php?showtopic=8470?utm_source=may_newsletter &utm_medium=email_asb&utm_term=&utm_content=f_105&utm_campaign=article5##> [X] My Assistant Loading. Please Wait...Loading. Please Wait... <http://www.asb.tv/forums/index.php?showtopic=8470?utm_source=may_newsletter &utm_medium=email_asb&utm_term=&utm_content=f_105&utm_campaign=article5##> X Site Message (Message will auto close in 2 seconds) > <http://www.asb.tv/forums/index.php?s=19f5ee3489ff4c67d680730ef66b50e7&act=i dx> ASB.TV Community > <http://www.asb.tv/forums/index.php?s=19f5ee3489ff4c67d680730ef66b50e7&showf orum=1> AirShowBuzz.com Community > <http://www.asb.tv/forums/index.php?s=19f5ee3489ff4c67d680730ef66b50e7&showf orum=13> Buzz-Worthy <http://www.asb.tv/forums/index.php?s=19f5ee3489ff4c67d680730ef66b50e7&act=p ost&do=reply_post&f=13&t=8470> Reply to this topic <http://www.asb.tv/forums/index.php?s=19f5ee3489ff4c67d680730ef66b50e7&act=p ost&do=new_post&f=13> Start new topic > Collings Foundation needs YOUR help to return F-105 to the sky! <http://www.asb.tv/forums/index.php?showtopic=8470?utm_source=may_newsletter &utm_medium=email_asb&utm_term=&utm_content=f_105&utm_campaign=article5#topi coptions#topicoptions> Options V V <http://www.asb.tv/forums/index.php?s=19f5ee3489ff4c67d680730ef66b50e7&act=u sercp&CODE=start_subs&method=topic&tid=8470> Track this topic V <http://www.asb.tv/forums/index.php?s=19f5ee3489ff4c67d680730ef66b50e7&act=F orward&f=13&t=8470> Email this topic V <http://www.asb.tv/forums/index.php?s=19f5ee3489ff4c67d680730ef66b50e7&act=P rint&client=printer&f=13&t=8470> Print this topic V <http://www.asb.tv/forums/index.php?s=19f5ee3489ff4c67d680730ef66b50e7&act=P rint&client=choose&f=13&t=8470> Download this topic V <http://www.asb.tv/forums/index.php?s=19f5ee3489ff4c67d680730ef66b50e7&act=u sercp&CODE=start_subs&method=forum&fid=13> Subscribe to this forum Display Modes V <http://www.asb.tv/forums/index.php?s=19f5ee3489ff4c67d680730ef66b50e7&showt opic=8470&mode=threaded> Switch to: Outline V <http://www.asb.tv/forums/index.php?s=19f5ee3489ff4c67d680730ef66b50e7&showt opic=8470&mode=linear> Standard V <http://www.asb.tv/forums/index.php?s=19f5ee3489ff4c67d680730ef66b50e7&showt opic=8470&mode=linearplus> Switch to: Linear+ <http://www.asb.tv/forums/index.php?s=19f5ee3489ff4c67d680730ef66b50e7&showu ser=502> MKopack <http://www.asb.tv/forums/index.php?s=19f5ee3489ff4c67d680730ef66b50e7&showu ser=502> View Member Profile postMay 2 2010, 04:21 PM Post <http://www.asb.tv/forums/index.php?showtopic=8470&view=findpost&p=160731> #1 <http://www.asb.tv/forums/index.php?s=19f5ee3489ff4c67d680730ef66b50e7&showu ser=502> Advanced Member *** Group: Members Posts: 1,043 Joined: 6-February 07 From: Raleigh, NC Member No.: 502 OK folks, I'm making the command decision to move this up to "Buzz-Worthy" so it gets more exposure. The Collings Foundation needs your help this week to make this happen. QUOTE We are trying to return an F-105 to flying condition. Representative Niki Tsongas (D-MA) has introduced legislation now being consider by House Armed Services Committee to transfer an F-105 to the Collings Foundation. There are 15 Medal of Honor winners and 120 former POW's who support this in addition to all us rank and file folks. We would appreciate your help, call Chairman Ike Skelton, Chairman of the House Armed Services Committee, and tell Chairman Skelton's staff that you want to be on record in support of Congresswomen Tsongas' Amendment to transfer the F-105 to the Collings foundation. Call 202-225-2876 and voice your support. The decision will be made this coming week. Details and other information at: http://collingsfoundation.org/enews/enewsletter_105.2010.htm According to Medal of Honor recipient and 6-year Prisoner of War Colonel Leo Thorsness (ret), "It is one thing to see "my" aircraft mounted on a pole or gathering dust in a museum, quite another to see it roar down the runway and take to the sky." I asked my friend Ed - a 100 Missions F-105 over North Vietnam patch wearer - what was the fastest he'd seen coming off a target clean. Here is his response: QUOTE The fastest I can remember coming off a target was seeing 750 knots indicated which is about 860 MPH. That wasn't "clean" however. I still had a pair of 450 gallon tanks, outboard pylons and the c/l MER. Typically we would be running about 600 knots indicated inbound and planning to rejoin off the target at 450 and head outbound at about 540. Those were very comfortable speeds in the jet which was rock-steady at high speed and low altitude. None of this was in A/B!!!! Who out there wouldn't want to walk into an airshow and see this ready to taxi? It's big, it's loud, it's fast, and it's bad. This ain't no sissy little fly-by-wire electric ballerina stealth jet. This is a heavyweight middle linebacker with a bad attitude, missing a couple of teeth, ready and willing to go anywhere and take on anything - right in their face. Route Pack VI? Hell yes, been there, let's go again. This is the F-105 Thunderchief! Reduced 42% <http://www.asb.tv/forums/index.php?s=19f5ee3489ff4c67d680730ef66b50e7&act=a ttach&type=post&id=54052> Attached Image 1024 x 733 (225.28K) Of 833 F-105's built, 382 were lost in Southeast Asia. It seems like the least we could to to put one more of these birds back up in the air as a tribute to those who originally flew her - and to the many who never made it home. I have no connections with the Collings Foundation at all, other than being a fan of the history that they share with us at airshows and airport visits, but with a little bit of effort we can all help make this happen. All it will take is a couple of phone calls from as many people that we can get. Time is of the essence though, the decision WILL be made THIS WEEK in Washington. Mike Kopack -------------------- mkopack@lucky-devils.net> Phantom Productions Aviation Photography <http://www.lucky-devils.net> Go to the top of the page <http://www.asb.tv/forums/index.php?showtopic=8470?utm_source=may_newsletter &utm_medium=email_asb&utm_term=&utm_content=f_105&utm_campaign=article5##> + <http://www.asb.tv/forums/index.php?s=19f5ee3489ff4c67d680730ef66b50e7&act=P ost&CODE=02&f=13&t=8470&qpid=160731> Quote Post <http://www.asb.tv/forums/index.php?s=19f5ee3489ff4c67d680730ef66b50e7&showu ser=2193> Perriwen <http://www.asb.tv/forums/index.php?s=19f5ee3489ff4c67d680730ef66b50e7&showu ser=2193> View Member Profile postMay 2 2010, 09:33 PM Post <http://www.asb.tv/forums/index.php?showtopic=8470&view=findpost&p=160761> #2 <http://www.asb.tv/forums/index.php?s=19f5ee3489ff4c67d680730ef66b50e7&showu ser=2193> Advanced Member *** Group: Members Posts: 544 Joined: 27-May 07 From: Tomball, TX Member No.: 2,193 Here's hoping.. Go to the top of the page <http://www.asb.tv/forums/index.php?showtopic=8470?utm_source=may_newsletter &utm_medium=email_asb&utm_term=&utm_content=f_105&utm_campaign=article5##> + <http://www.asb.tv/forums/index.php?s=19f5ee3489ff4c67d680730ef66b50e7&act=P ost&CODE=02&f=13&t=8470&qpid=160761> Quote Post ________________________________________________________________________________
Subject: Jim Addington's mother
Date: May 10, 2010
Commanderland; I'm sure yesterday was a sad Mother's Day for Jim Addington. On Thursday his 90 year old mother passed away. Jim is one of our own, if any of you wish to contact him personally, his email is jtaddington(at)verizon.net . God Bless, Don Viola Mae Wright Addington Rodolph, 90 of Denton, Texas passed away Thursday, May 6, 2010 at her residence, Lake Forest Good Samaritan in Denton. Viola Mae Wright was born in Springfield, Colorado, October 9, 1919, to Effie Pearl Tandy and Ross Allison Wright. She married James T. Addington in 1936. They had one son, James T. Addington, Jr. Viola married Joe W. Rodolph October 11, 1962, in Ardmore, Oklahoma. He preceded her in death July 21, 2004. Viola and Joe lived in Ardmore Oklahoma. Due to Joe's work they lived in Vernal Utah, Bakersfield California, and Woodward Oklahoma before settling in Corpus Christi, Texas. After Joe's death Viola moved to Denton, Texas to be near her son James and his family. She and Joe loved to travel. During their travels, they pursued their interest in history by visiting state capitols and historical markers along the way. As members of the First Baptist Church in Corpus Christi they belonged to the Baptist Church Hammer Slammers, traveling in their travel trailer to build churches from the ground up, in the South Texas area. Viola expressed her creative side in the flower shop she owned while living in Vernal Utah. She continued her love of flowers and plants while living in Corpus Christi with her garden. She loved to paint landscapes, sew and was an amazing cook. Everything she did was done very well. A memorial service celebrating Viola's life will be held at Gateway United Baptist Church, 2401 N. Bell Avenue, Denton Texas, Tuesday, May 11, 2010 at 11:00 A.M. with Buddy Owens, Minister, officiating. A private family burial will precede the service at Roselawn Memorial Park in Denton. The family wishes to thank Dr. Scott Simms, All Our Hearts caregivers, Accolade Home Health Care and Good Samaritan Lake Forest. Mrs. Rodolph is survived by sons, James T. Addington of Denton, Larry Rodolph(Averil) of Angel Fire New Mexico, daughters, JoDean Weaver(Gene) of Frisco, Texas and Linda Billings of Atlanta, Georgia, brothers, Sam Bruce Wright (Jean) and Tandy Allison Wright all of Corpus Christi, Texas. Grandchildren, Amanda Addington, Kim Woodruff, Grant Rodolph(Jenifer), Stacy Rodolph, Denise Cannefax(Alan) and Dagney Duck(Brandon). Great grandchildren, Caroline Kirkpatrick, Hunter Woodruff, Makenna and Whitney Rodolph, Conner and Lily Cannefax, Addison and Ainsley Duck and numerous nieces and nephews. She is preceded in death by her parents Effie Tandy and Ross Wright, husband Joe Rodolph, sister Dahlia Wright Rhyne and daughter-in-law Carol Lynn Addington. In lieu of flowers memorials may be made to Cumberland Presbyterian Children's Home or Denton Christian Preschool. ________________________________________________________________________________
Subject: This'll bend your mind
Date: May 13, 2010
Very well done. http://www.youtube.com/watch?v=YGvNKA-E3zI <http://www.youtube.com/watch?v=YGvNKA-E3zI&NR=1> &NR=1 ________________________________________________________________________________
From: "kitepilot(at)kitepilot.com" <kitepilot(at)kitepilot.com>
Subject: Re: This'll bend your XXXX wing... :)
Date: May 14, 2010
http://www.youtube.com/watch?v=0gWEi_TNKoI ET cybersuperstore writes: > Very well done. > > > > http://www.youtube.com/watch?v=YGvNKA-E3zI > <http://www.youtube.com/watch?v=YGvNKA-E3zI&NR=1> &NR=1 > > > > > > > > > ________________________________________________________________________________
Subject: This'll bend your XXXX wing... :)
Date: May 14, 2010
Wow! That's too close for my style, thanks. -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of kitepilot(at)kitepilot.com Sent: Friday, May 14, 2010 6:12 AM Subject: Re: Commander-List: This'll bend your XXXX wing... :) http://www.youtube.com/watch?v=0gWEi_TNKoI ET cybersuperstore writes: > Very well done. > > > > http://www.youtube.com/watch?v=YGvNKA-E3zI > <http://www.youtube.com/watch?v=YGvNKA-E3zI&NR=1> &NR=1 > > > > > > > > > ________________________________________________________________________________
From: "Andrew & Bridget Watson" <andrew.bridget(at)telus.net>
Subject: Different type of "Commanders"
Date: May 16, 2010
Enjoy. http://www.youtube.com/watch?v=xE1rE2vxUyM&NR=1 ________________________________________________________________________________
Subject: First Book: Where Vultures Roost on Sale
Date: May 17, 2010
If anybody is interested the publisher of my first book "Where Vultures Roost" is offering a 55% discount and free shipping within the USA on all books until Wednesday. "Where Vultures Roost" is the book which features the Shrike Commander. Usual cost is $19.95; shipping is usually $2.99 within the USA. Order here: http://www.publishamerica.net/product3239.html and put in the coupon code NoShip55 to get the 55% discount. It works out to be $8.98. If you have hassles ordering it, let me know. God bless, Andrew ________________________________________________________________________________
Date: May 20, 2010
Subject: George Yundt
From: "Deneal Schilmeister (MacbookPro)" <deneals(at)deneals.com>
If George Yundt is still on this list, can you contact me privately? -- Deneal Schilmeister deneals(at)deneals.com http://deneals.com ________________________________________________________________________________
From: "Jack B. Mills" <moe-rosspistons(at)hotmail.com>
Subject: Re: George Yundt
Date: May 20, 2010
George YundtFellow Commander Folks, Some Twin Commanders have Plexiglas inspection windows installed in the aft fuselage under the horizontal stabilizer where the factory had the louvered inspection plates. Are these done with an STC, a one time field inspection by the FAA, or as a non FAA approved modification? Also does anyone have a pilots side spare windshield for a 680Fp in good condition? part # 5360007-41. Apparently this same windshield was used on the 680FLp and 680T. Thanx! Moe Mills N680RR 680Fp From: Deneal Schilmeister (MacbookPro) Sent: Thursday, May 20, 2010 3:06 PM Subject: Commander-List: George Yundt If George Yundt is still on this list, can you contact me privately? -- Deneal Schilmeister deneals(at)deneals.com http://deneals.com ________________________________________________________________________________
Date: May 21, 2010
G'day Moe, Buddy Plaster (on this list) fitted the plexiglass windows to his 560E. Contact me off list if you need his email address. Cheers mate! Russell ________________________________________________________________________________
Date: May 21, 2010
G'day Mate, Unforntunately, the windshield on the pressurized planes is a lot thicker (make that more difficult to work with) than the non pressurized models and must be "as cast" rather than formed. Regards, Moe -------------------------------------------------- From: <rlegg(at)austarnet.com.au> Sent: Thursday, May 20, 2010 9:24 PM Subject: Re: Commander-List: George Yundt > > G'day Moe, > > Buddy Plaster (on this list) fitted the plexiglass windows to his 560E. > > Contact me off list if you need his email address. > > Cheers mate! > > Russell > > > ________________________________________________________________________________
Subject: Rotax First Engine Start
Date: May 26, 2010
I fired up the Rotax 912 ULS on my Van's RV-12 for a few moments this morning....it started right up...with throttle at full closed could not get rpm down to the 1800 or so I wanted at 'idle' it would not go less than 3,470 rpm so I shut it down and left it for tomorrow...family responsibilities only let me work on the plane for a few hours each day....a quick peek through the oil door at the right carb didn't show anything obvious, so I will have to await tomorrow to do some trouble shooting....I fully suspect some sort of carb problem...I recall carefully setting the controls and the stops when I installed the engine, but something isn't quite right. ________________________________________________________________________________
Date: May 26, 2010
Subject: Re: Rotax First Engine Start
Cool. I use one of those in my Commander Tug! ;-) ________________________________ From: John Fasching <n29cx(at)ridgeviewtel.us> Sent: Wed, May 26, 2010 1:15:38 PM Subject: Commander-List: Rotax First Engine Start I fired up the Rotax 912 ULS on my Van's RV-12 for a few moments this morning....it started right up...with throttle at full closed could not get rpm down to the 1800 or so I wanted at 'idle' it would not go less than 3,470 rpm so I shut it down and left it for tomorrow...family responsibilities only let me work on the plane for a few hours each day....a quick peek through the oil door at the right carb didn't show anything obvious, so I will have to await tomorrow to do some trouble shooting....I fully suspect some sort of carb problem...I recall carefully setting the controls and the stops when I installed the engine, but something isn't quite right. ________________________________________________________________________________
Subject: FW: Worst ever air disaster in Irish history !
Date: May 28, 2010
Reported in The Irish Times: Text Box: Ireland's Worst Ever Air Disaster DUBLIN - Ireland's worst ever air disaster occurred this morning when a two-seater Cessna light aircraft crashed into a cemetery. Irish search and rescue workers have recovered 1,826 bodies so far and expect that number to climb as digging continues into the night. -Reuters. ________________________________________________________________________________
From: "Tom Fisher" <tfisher(at)commandergroup.bc.ca>
Subject: Re: FW: Worst ever air disaster in Irish history !
Date: May 28, 2010
We had this joke using Neufies. T... ----- Original Message ----- From: cybersuperstore To: 'nico' Sent: Friday, May 28, 2010 11:36 AM Subject: Commander-List: FW: Worst ever air disaster in Irish history ! Reported in The Irish Times: ________________________________________________________________________________
Subject: When kids get good news
Date: May 28, 2010
<http://www.youtube.com/watch_popup?v=hkGzqpGx1KU> http://www.youtube.com/watch_popup?v=hkGzqpGx1KU ________________________________________________________________________________
Date: May 30, 2010
Subject: Re: When kids get good news
Thanks Nico. Morris On Fri, May 28, 2010 at 6:07 PM, cybersuperstore wrote: > > > http://www.youtube.com/watch_popup?v=hkGzqpGx1KU > > > > > > * > > * > > ________________________________________________________________________________
Date: May 30, 2010
WOW. Thanks for sharing that!! jb -----Original Message----- From: cybersuperstore <nico(at)cybersuperstore.com> Sent: Fri, May 28, 2010 6:07 pm Subject: Commander-List: When kids get good news http://www.youtube.com/watch_popup?v=hkGzqpGx1KU ======================== =========== -= - The Commander-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Commander-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Subject: AC500 Question or two
Date: Jun 06, 2010
I wanted to solicit some feedback on the AC500 (straight 500) birds. A whi le back we were looking to purchase a 500A or B. We had some issues and ar e tossing around the idea again. Anyway=2C there is a seemingly nice 500 f or sale on Controller.com. Keep in mind we currently have a 56' G35 Bonan za and are used to old airplanes. I wanted to know what kind of REAL WORLD performance figures does everyone see for the 500=2C 500A=2C and 500B? Any thing that would prohibit anyone for buying a straight 500? Feedback is gr eatly appreciated. My cell # is 936-577-1117 Thanks a million=2C Zac Armstrong All the world's great civilizations have followed the same path: from bonda ge to spiritual faith=3B from spiritual faith to courage=3B from courage to liberty=3B from liberty to abundance=3B from abundance to selfishness=3B f rom selfishness to complacency=3B from complacency to apathy=3B from apathy to dependence=3B from dependence back to bondage. If we are to be the exc eption to history=2C then we must break the cycle=2C for those who do not r emember the past are condemned to repeat it. -Based on statements/excepts from Sir Alexander Fraser Tytler and George Sa ntayana. _________________________________________________________________ Hotmail has tools for the New Busy. Search=2C chat and e-mail from your inb ox. http://www.windowslive.com/campaign/thenewbusy?ocid=PID28326::T:WLMTAGL:O N:WL:en-US:WM_HMP:042010_1 ________________________________________________________________________________
Subject: Re: AC500 Question or two
Date: Jun 06, 2010
ZAC, IVE OWNED A 500B FOR 28 YEARS.FANTASTIC AIRCRAFT BUT,,,, NEEDS TENDER LOVING CARE & $$$$ AS DOES ANY OLD AIRCRAFT.LOTS OF LUCK, LLOYD ----- Original Message ----- From: Zac Armstrong<mailto:transam403(at)hotmail.com> To: commander-list(at)matronics.com Sent: Sunday, June 06, 2010 2:52 PM Subject: Commander-List: AC500 Question or two I wanted to solicit some feedback on the AC500 (straight 500) birds. A while back we were looking to purchase a 500A or B. We had some issues and are tossing around the idea again. Anyway, there is a seemingly nice 500 for sale on Controller.com. Keep in mind we currently have a 56' G35 Bonanza and are used to old airplanes. I wanted to know what kind of REAL WORLD performance figures does everyone see for the 500, 500A, and 500B? Anything that would prohibit anyone for buying a straight 500? Feedback is greatly appreciated. My cell # is 936-577-1117 Thanks a million, Zac Armstrong All the world's great civilizations have followed the same path: from bondage to spiritual faith; from spiritual faith to courage; from courage to liberty; from liberty to abundance; from abundance to selfishness; from selfishness to complacency; from complacency to apathy; from apathy to dependence; from dependence back to bondage. If we are to be the exception to history, then we must break the cycle, for those who do not remember the past are condemned to repeat it. -Based on statements/excepts from Sir Alexander Fraser Tytler and George Santayana. <http://www.b-25yellowrose.com/membership/default.asp> ------------------------------------------------------------------------- ----- Hotmail has tools for the New Busy. Search, chat and e-mail from your inbox. Learn more.<http://www.windowslive.com/campaign/thenewbusy?ocid=PID28326::T:W LMTAGL:ON:WL:en-US:WM_HMP:042010_1> http://www.matronics.com/Navigator?Commander-List m/Navigator?Commander-List> http://www.matronics.com/contribution on> ________________________________________________________________________________
Date: Jun 06, 2010
Hi Zac, I had a straight 500 and put about 1,100 hours on it. I found it to be extremely reliable with low maintenance costs. At the same time I had a Twin Comanche and (still) believe that those two planes in combination afforded me the best capability in terms of speed and payload when I needed it. Once I needed a left undercarriage brake rotor and some other stuff, which cost a bundle to import from the U.S. (I lived in South Africa at the time). And one other time the hydraulic line that operated the hydraulic pressure gauge cracked and nearly made us into a flying molotoff cocktail. After the brake incident I learned to land and slow the AC down without touching the brakes. The 500 had extremely good loading capability provided one operates it at lower altitudes. In terms of pure functionality and a bit higher maintenance costs, a Miller converted 500A would seem to me to be the ultimate ship. I only have a few hours on the 500B and no time on the Shrike, so I'd rather not comment on them. You can see me playing with the AC here:
http://www.youtube.com/watch?v=-rcUM9MCPsA Nico _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of lloyd silverman Sent: Sunday, June 06, 2010 1:27 PM Subject: Re: Commander-List: AC500 Question or two ZAC, IVE OWNED A 500B FOR 28 YEARS.FANTASTIC AIRCRAFT BUT,,,, NEEDS TENDER LOVING CARE & $$$$ AS DOES ANY OLD AIRCRAFT.LOTS OF LUCK, LLOYD ----- Original Message ----- From: Zac Armstrong <mailto:transam403(at)hotmail.com> Sent: Sunday, June 06, 2010 2:52 PM Subject: Commander-List: AC500 Question or two I wanted to solicit some feedback on the AC500 (straight 500) birds. A while back we were looking to purchase a 500A or B. We had some issues and are tossing around the idea again. Anyway, there is a seemingly nice 500 for sale on Controller.com. Keep in mind we currently have a 56' G35 Bonanza and are used to old airplanes. I wanted to know what kind of REAL WORLD performance figures does everyone see for the 500, 500A, and 500B? Anything that would prohibit anyone for buying a straight 500? Feedback is greatly appreciated. My cell # is 936-577-1117 Thanks a million, Zac Armstrong All the world's great civilizations have followed the same path: from bondage to spiritual faith; from spiritual faith to courage; from courage to liberty; from liberty to abundance; from abundance to selfishness; from selfishness to complacency; from complacency to apathy; from apathy to dependence; from dependence back to bondage. If we are to be the exception to history, then we must break the cycle, for those who do not remember the past are condemned to repeat it. -Based on statements/excepts from Sir Alexander Fraser Tytler and George Santayana. <http://www.b-25yellowrose.com/images/null.gif> <http://www.b-25yellowrose.com/membership/default.asp> Commemorative Air Force - Yellow Rose - B-25 SQDN. _____ Hotmail has tools for the New Busy. Search, chat and e-mail from your inbox. Learn <http://www.windowslive.com/campaign/thenewbusy?ocid=PID28326::T:WLMTAGL:ON: WL:en-US:WM_HMP:042010_1> more. title=http://www.matronics.com/Navigator?Commander-List href="http://www.matronics.com/Navigator?Commander-List">http://www.matronic s.com/Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Jun 06, 2010
Oh, I burned 22 gph (Imperial gallons) on the 500 and exactly half that on the Twin Comanche. I once loaded 9 people into the 500 when we had to fly them out of Inhaca Island (off the east coast of Mozambique) in 1984. It was a non-event in terms of performance and comfort. There are other things that I did with the Commander that are not necessarily suitable to confess to. It is a worthy and honest ship which more than makes up for all its other idiosyncrasies. Nico _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of cybersuperstore Sent: Sunday, June 06, 2010 9:47 PM Subject: RE: Commander-List: AC500 Question or two Hi Zac, I had a straight 500 and put about 1,100 hours on it. I found it to be extremely reliable with low maintenance costs. At the same time I had a Twin Comanche and (still) believe that those two planes in combination afforded me the best capability in terms of speed and payload when I needed it. Once I needed a left undercarriage brake rotor and some other stuff, which cost a bundle to import from the U.S. (I lived in South Africa at the time). And one other time the hydraulic line that operated the hydraulic pressure gauge cracked and nearly made us into a flying molotoff cocktail. After the brake incident I learned to land and slow the AC down without touching the brakes. The 500 had extremely good loading capability provided one operates it at lower altitudes. In terms of pure functionality and a bit higher maintenance costs, a Miller converted 500A would seem to me to be the ultimate ship. I only have a few hours on the 500B and no time on the Shrike, so I'd rather not comment on them. You can see me playing with the AC here: http://www.youtube.com/watch?v=-rcUM9MCPsA Nico _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of lloyd silverman Sent: Sunday, June 06, 2010 1:27 PM Subject: Re: Commander-List: AC500 Question or two ZAC, IVE OWNED A 500B FOR 28 YEARS.FANTASTIC AIRCRAFT BUT,,,, NEEDS TENDER LOVING CARE & $$$$ AS DOES ANY OLD AIRCRAFT.LOTS OF LUCK, LLOYD ----- Original Message ----- From: Zac Armstrong <mailto:transam403(at)hotmail.com> Sent: Sunday, June 06, 2010 2:52 PM Subject: Commander-List: AC500 Question or two I wanted to solicit some feedback on the AC500 (straight 500) birds. A while back we were looking to purchase a 500A or B. We had some issues and are tossing around the idea again. Anyway, there is a seemingly nice 500 for sale on Controller.com. Keep in mind we currently have a 56' G35 Bonanza and are used to old airplanes. I wanted to know what kind of REAL WORLD performance figures does everyone see for the 500, 500A, and 500B? Anything that would prohibit anyone for buying a straight 500? Feedback is greatly appreciated. My cell # is 936-577-1117 Thanks a million, Zac Armstrong All the world's great civilizations have followed the same path: from bondage to spiritual faith; from spiritual faith to courage; from courage to liberty; from liberty to abundance; from abundance to selfishness; from selfishness to complacency; from complacency to apathy; from apathy to dependence; from dependence back to bondage. If we are to be the exception to history, then we must break the cycle, for those who do not remember the past are condemned to repeat it. -Based on statements/excepts from Sir Alexander Fraser Tytler and George Santayana. <http://www.b-25yellowrose.com/images/null.gif> <http://www.b-25yellowrose.com/membership/default.asp> Commemorative Air Force - Yellow Rose - B-25 SQDN. _____ Hotmail has tools for the New Busy. Search, chat and e-mail from your inbox. Learn <http://www.windowslive.com/campaign/thenewbusy?ocid=PID28326::T:WLMTAGL:ON: WL:en-US:WM_HMP:042010_1> more. title=http://www.matronics.com/Navigator?Commander-List href="http://www.matronics.com/Navigator?Commander-List">http://www.matronic s.com/Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c http://www.matronics.com/Navigator?Commander-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jun 06, 2010
From: Brock Lorber <blorber(at)southwestcirrus.com>
I've probably told this story, but when 400CH (680FL(P)) first came to Las Vegas, there was an Aero Star parked next to us. One day, the owner of the Aero Star walked up while I was adding a 5th (6th?) coat of wax and said, "that's a nice plane, but I like a little more speed." "Well, let's race," I said. He got an indignant look on his face and said something to the effect of, "oh, that plane will never keep up with mine." I smiled and said, "you didn't let me finish. The race is moving 8 people plus hunting gear from here to Del Rio, TX." cybersuperstore wrote: > I once loaded 9 people into the 500 when we had to fly > them out of Inhaca Island (off the east coast of Mozambique) in 1984. It was > a non-event in terms of performance and comfort. ________________________________________________________________________________
Date: Jun 06, 2010
You'll get them every time with that. -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Brock Lorber Sent: Sunday, June 06, 2010 11:01 PM Subject: Re: Commander-List: AC500 Question or two I've probably told this story, but when 400CH (680FL(P)) first came to Las Vegas, there was an Aero Star parked next to us. One day, the owner of the Aero Star walked up while I was adding a 5th (6th?) coat of wax and said, "that's a nice plane, but I like a little more speed." "Well, let's race," I said. He got an indignant look on his face and said something to the effect of, "oh, that plane will never keep up with mine." I smiled and said, "you didn't let me finish. The race is moving 8 people plus hunting gear from here to Del Rio, TX." cybersuperstore wrote: > I once loaded 9 people into the 500 when we had to fly > them out of Inhaca Island (off the east coast of Mozambique) in 1984. It was > a non-event in terms of performance and comfort. ________________________________________________________________________________
Date: Jun 07, 2010
Thanks! I know the GIO powered birds have alot more "umph"=2C especially w hen it comes to weight lifting capability. But=2C I don't want the extra h eadaches of the gear boxes as it is becoming harder and harder (not to ment ion more expensive) to find people to work on them! Great video. All the world's great civilizations have followed the same path: from bonda ge to spiritual faith=3B from spiritual faith to courage=3B from courage to liberty=3B from liberty to abundance=3B from abundance to selfishness=3B f rom selfishness to complacency=3B from complacency to apathy=3B from apathy to dependence=3B from dependence back to bondage. If we are to be the exc eption to history=2C then we must break the cycle=2C for those who do not r emember the past are condemned to repeat it. -Based on statements/excepts from Sir Alexander Fraser Tytler and George Sa ntayana. > From: nico(at)cybersuperstore.com > To: commander-list(at)matronics.com > Subject: RE: Commander-List: AC500 Question or two > Date: Sun=2C 6 Jun 2010 23:11:04 -0700 > tore.com> > > You'll get them every time with that. > > > -----Original Message----- > From: owner-commander-list-server(at)matronics.com > [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Brock Lor ber > Sent: Sunday=2C June 06=2C 2010 11:01 PM > To: commander-list(at)matronics.com > Subject: Re: Commander-List: AC500 Question or two > > > > I've probably told this story=2C but when 400CH (680FL(P)) first came to > Las Vegas=2C there was an Aero Star parked next to us. > > One day=2C the owner of the Aero Star walked up while I was adding a 5th > (6th?) coat of wax and said=2C "that's a nice plane=2C but I like a littl e > more speed." > > "Well=2C let's race=2C" I said. > > He got an indignant look on his face and said something to the effect > of=2C "oh=2C that plane will never keep up with mine." > > I smiled and said=2C "you didn't let me finish. The race is moving 8 > people plus hunting gear from here to Del Rio=2C TX." > > > cybersuperstore wrote: > > I once loaded 9 people into the 500 when we had to fly > > them out of Inhaca Island (off the east coast of Mozambique) in 1984. I t > was > > a non-event in terms of performance and comfort. > > > > > > > > =========== =========== =========== =========== > > > _________________________________________________________________ Hotmail is redefining busy with tools for the New Busy. Get more from your inbox. http://www.windowslive.com/campaign/thenewbusy?ocid=PID28326::T:WLMTAGL:O N:WL:en-US:WM_HMP:042010_2 ________________________________________________________________________________
Date: Jun 07, 2010
ZAC, You should sent the Serial No to Barry Coleman. He is our historian. He can give you a print out of who has owned the airplane from day one and all the 337 that are on file. It is like a CarFAX history of the airplane. If it is the one in Trade-a-plane at $22,000 it could be a good buy. Just don't overload it at high altitudes. Tylor Hall On Jun 7, 2010, at 7:55 AM, Zac Armstrong wrote: > Thanks! I know the GIO powered birds have alot more "umph", especially when it comes to weight lifting capability. But, I don't want the extra headaches of the gear boxes as it is becoming harder and harder (not to mention more expensive) to find people to work on them! Great video. > > All the world's great civilizations have followed the same path: from bondage to spiritual faith; from spiritual faith to courage; from courage to liberty; from liberty to abundance; from abundance to selfishness; from selfishness to complacency; from complacency to apathy; from apathy to dependence; from dependence back to bondage. If we are to be the exception to history, then we must break the cycle, for those who do not remember the past are condemned to repeat it. > > -Based on statements/excepts from Sir Alexander Fraser Tytler and George Santayana. > > > > > > > > > > > > > From: nico(at)cybersuperstore.com > > To: commander-list(at)matronics.com > > Subject: RE: Commander-List: AC500 Question or two > > Date: Sun, 6 Jun 2010 23:11:04 -0700 > > > > > > You'll get them every time with that. > > > > > > -----Original Message----- > > From: owner-commander-list-server(at)matronics.com > > [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Brock Lorber > > Sent: Sunday, June 06, 2010 11:01 PM > > To: commander-list(at)matronics.com > > Subject: Re: Commander-List: AC500 Question or two > > > > > > > > I've probably told this story, but when 400CH (680FL(P)) first came to > > Las Vegas, there was an Aero Star parked next to us. > > > > One day, the owner of the Aero Star walked up while I was adding a 5th > > (6th?) coat of wax and said, "that's a nice plane, but I like a little > > more speed." > > > > "Well, let's race," I said. > > > > He got an indignant look on his face and said something to the effect > > of, "oh, that plane will never keep up with mine." > > > > I smiled and said, "you didn't let me finish. The race is moving 8 > > people plus hunting gear from here to Del Rio, TX." > > > > > > cybersuperstore wrote: > > > I once loaded 9 people into the 500 when we had to fly > > > them out of Inhaca Island (off the east coast of Mozambique) in 1984. It > > was > > > a non-event in terms of performance and comfort. > > > > > > > > > > > >====================== > &g=================== > > > > > > > > Hotmail is redefining busy with tools for the New Busy. Get more from your inbox. See how. > > > > ________________________________________________________________________________
Date: Jun 07, 2010
> If it is the one in Trade-a-plane at $22,000 it could be a good buy. Seriously? I'd wager you could buy the nicest 500 on the planet and end up with a smaller investment than it would take to get that poor heap even marginally airworthy. Love to see the old gal get restored but sure looks to me like it probably a total corrosion pit, likely has junk engines and props, and would need a total rebuild if the airframe is even salvageable. chris ________________________________________________________________________________
Date: Jun 07, 2010
Sad, but looks to be bubbling nicely in the damp FL sun..... ________________________________ From: Chris <cschuerm(at)cox.net> Sent: Mon, June 7, 2010 5:28:27 PM Subject: Re: Commander-List: AC500 Question or two > If it is the one in Trade-a-plane at $22,000 it could be a good buy. Seriously? I'd wager you could buy the nicest 500 on the planet and end up with a smaller investment than it would take to get that poor heap even marginally airworthy. Love to see the old gal get restored but sure looks to me like it probably a total corrosion pit, likely has junk engines and props, and would need a total rebuild if the airframe is even salvageable. chris ________________________________________________________________________________
Date: Jun 07, 2010
Hay, be nice guys. How about 500 SG in Controller. It is even in Lic. Dec 2009. Nice radios. New interior in 2003, GPS, A/P It looks flyable. Corrosions ? it is parked inside for now. Tylor Hall On Jun 7, 2010, at 6:48 PM, craig kennedy wrote: > Sad, but looks to be bubbling nicely in the damp FL sun..... > > From: Chris <cschuerm(at)cox.net> > To: commander-list(at)matronics.com > Sent: Mon, June 7, 2010 5:28:27 PM > Subject: Re: Commander-List: AC500 Question or two > > > > > > ________________________________________________________________________________
Date: Jun 08, 2010
We were thinking about 500SG in CA=2C not the one for 22K. One thing I hav e learned from restoring our Bonanza is to start off with a nice airplane. I definitely won't be buying a 22K -500. I do also know that while a 500 is a lot cheaper initially=2C it does have some limitations (performance) a nd can eat a very large hole in a wallet (as with any airplane). All the world's great civilizations have followed the same path: from bonda ge to spiritual faith=3B from spiritual faith to courage=3B from courage to liberty=3B from liberty to abundance=3B from abundance to selfishness=3B f rom selfishness to complacency=3B from complacency to apathy=3B from apathy to dependence=3B from dependence back to bondage. If we are to be the exc eption to history=2C then we must break the cycle=2C for those who do not r emember the past are condemned to repeat it. -Based on statements/excepts from Sir Alexander Fraser Tytler and George Sa ntayana. From: tylorhall(at)mac.com Subject: Re: Commander-List: AC500 Question or two Date: Mon=2C 7 Jun 2010 19:21:51 -0600 Hay=2C be nice guys. How about 500 SG in Controller. It is even in Lic. Dec 2009. Nice radios. New interior in 2003=2C GPS=2C A/P It looks flyable. Corrosions ? it is parked inside for now. Tylor Hall On Jun 7=2C 2010=2C at 6:48 PM=2C craig kennedy wrote: Sad=2C but looks to be bubbling nicely in the damp FL sun..... From: Chris <cschuerm(at)cox.net> Sent: Mon=2C June 7=2C 2010 5:28:27 PM Subject: Re: Commander-List: AC500 Question or two href="http://www.matronics.com/Navigator?Commander-List">http://www.matro nics.com/Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/con tribution _________________________________________________________________ Hotmail has tools for the New Busy. Search=2C chat and e-mail from your inb ox. http://www.windowslive.com/campaign/thenewbusy?ocid=PID28326::T:WLMTAGL:O N:WL:en-US:WM_HMP:042010_1 ________________________________________________________________________________
Date: Jun 07, 2010
Zac, A straight 500 has 0-540 engines, carburetors and 250 HP, not the IO injected. That came in the 500B, U and S versions. The 500 A had the Cont. i0-470 260 HP, The Colmill conversion changed it up to the IO-520 Cont. Tylor Hall On Jun 7, 2010, at 6:48 PM, craig kennedy wrote: > Sad, but looks to be bubbling nicely in the damp FL sun..... > > From: Chris <cschuerm(at)cox.net> > To: commander-list(at)matronics.com > Sent: Mon, June 7, 2010 5:28:27 PM > Subject: Re: Commander-List: AC500 Question or two > > > > > > ________________________________________________________________________________
Subject: n409ac[1].pdf
Date: Jun 07, 2010
I wasn't aware that there is an Aero Commander 200D. Sir Barry? ________________________________________________________________________________
Date: Jun 07, 2010
Darn! Colemil, not Miller. _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Tylor Hall Sent: Monday, June 07, 2010 6:27 PM Subject: Re: Commander-List: AC500 Question or two Zac, A straight 500 has 0-540 engines, carburetors and 250 HP, not the IO injected. That came in the 500B, U and S versions. The 500 A had the Cont. i0-470 260 HP, The Colmill conversion changed it up to the IO-520 Cont. Tylor Hall On Jun 7, 2010, at 6:48 PM, craig kennedy wrote: Sad, but looks to be bubbling nicely in the damp FL sun..... _____ From: Chris <cschuerm(at)cox.net> Sent: Mon, June 7, 2010 5:28:27 PM Subject: Re: Commander-List: AC500 Question or two href="http://www.matronics.com/Navigator?Commander-List">http://www.matronic s.com/Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/contri bution ________________________________________________________________________________
Date: Jun 07, 2010
Miller made the long nose that Aero Commander copyed later. Tylor On Jun 7, 2010, at 8:05 PM, cybersuperstore wrote: > Darn! Colemil, not Miller. > > > From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Tylor Hall > Sent: Monday, June 07, 2010 6:27 PM > To: commander-list(at)matronics.com > Subject: Re: Commander-List: AC500 Question or two > > Zac, > A straight 500 has 0-540 engines, carburetors and 250 HP, not the IO injected. That came in the 500B, U and S versions. The 500 A had the Cont. i0-470 260 HP, The Colmill conversion changed it up to the IO-520 Cont. > > Tylor Hall > > > On Jun 7, 2010, at 6:48 PM, craig kennedy wrote: > > > Sad, but looks to be bubbling nicely in the damp FL sun..... > > From: Chris <cschuerm(at)cox.net> > To: commander-list(at)matronics.com > Sent: Mon, June 7, 2010 5:28:27 PM > Subject: Re: Commander-List: AC500 Question or two > > > > > href="http://www.matronics.com/Navigator?Commander-List">http://www.matronics.com/Navigator?Commander-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/contribution > > > > > > ________________________________________________________________________________
From: "Barry Collman" <barry.collman@air-britain.co.uk>
Subject: Re: n409ac[1].pdf
Date: Jun 08, 2010
Hi Nico, The Aero Commander 200 was formerly the Meyers 200. Rockwell acquired the Type in 1965, when they also acquired the Volair 10 (Aero Commander 100) and the Snow S-2 and CallAir A-9 Ag types. The Meyers/Aero Commander 200 was virtually hand-built and, as far as I know, has never had a single AD issued against it. Best Regards, Barry ----- Original Message ----- From: cybersuperstore To: commander-list(at)matronics.com Sent: Tuesday, June 08, 2010 2:43 AM Subject: Commander-List: n409ac[1].pdf I wasn't aware that there is an Aero Commander 200D. Sir Barry? ________________________________________________________________________________
Date: Jun 08, 2010
Subject: 500 lost
hi barry, i am advised that a 500 went into the atlantic on the way f rom the bahamas to the us. no details, but all of the commanders in the islands use N numbers. plane is lost. nothing in newspapers. do you happen to know which one it was? i doubt there is even a ntsb repor t. all of ours are accounted for and we are adding about two a year it seems. allan hoffman - ____________________________________________________________ Penny Stock Jumping 2000% Sign up to the #1 voted penny stock newsletter for free today! http://thirdpartyoffers.juno.com/TGL3131/4c0eb2426dcf327e9d2st04vuc ________________________________________________________________________________
Subject: Re: 500 lost
Date: Jun 08, 2010
Hi Al, Heard nothing here about it. Presumably it happened earlier today? Nothing on the FAA's preliminary report website, but will check what they post tomorrow, for accidents reported today. Best Regards, Barry ----- Original Message ----- From: alh1(at)juno.com To: commander-list(at)matronics.com Sent: Tuesday, June 08, 2010 10:11 PM Subject: [Norton AntiSpam] Commander-List: 500 lost hi barry, i am advised that a 500 went into the atlantic on the way from the bahamas to the us. no details, but all of the commanders in the islands use N numbers. plane is lost. nothing in newspapers. do you happen to know which one it was? i doubt there is even a ntsb report. all of ours are accounted for and we are adding about two a year it seems. allan hoffman - ____________________________________________________________ Penny Stock Jumping 2000% Sign up to the #1 voted penny stock newsletter for free today! AwesomePennyStocks.com ________________________________________________________________________________
From: "cybersuperstore" <nico(at)cybersuperstore.com>
Subject: 500 lost
Date: Jun 08, 2010
I was looking around to see if I could pick up something. Stumbled across this article, something I didn't know. http://www.check-six.com/Crash_Sites/Audie-Murphy-N601JJ.htm Nico _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of alh1(at)juno.com Sent: Tuesday, June 08, 2010 2:12 PM Subject: Commander-List: 500 lost hi barry, i am advised that a 500 went into the atlantic on the way from the bahamas to the us. no details, but all of the commanders in the islands use N numbers. plane is lost. nothing in newspapers. do you happen to know which one it was? i doubt there is even a ntsb report. all of ours are accounted for and we are adding about two a year it seems. allan hoffman - ____________________________________________________________ <http://thirdpartyoffers.juno.com/TGL3132/4c0eb2426dcf327e9d2st04vuc> Penny Stock Jumping 2000% Sign up to the #1 voted penny stock newsletter for free today! <http://thirdpartyoffers.juno.com/TGL3132/4c0eb2426dcf327e9d2st04vuc> AwesomePennyStocks.com ________________________________________________________________________________
Subject: 500 lost
Date: Jun 08, 2010
HI Nico, Already got that covered but thanks for the link, which provided some extra detail. Best Regards, Barry ----- Original Message ----- From: cybersuperstore To: commander-list(at)matronics.com Sent: Tuesday, June 08, 2010 11:25 PM Subject: [Norton AntiSpam] RE: Commander-List: 500 lost I was looking around to see if I could pick up something. Stumbled across this article, something I didn't know. http://www.check-six.com/Crash_Sites/Audie-Murphy-N601JJ.htm Nico ------------------------------------------------------------------------- ----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of alh1(at)juno.com Sent: Tuesday, June 08, 2010 2:12 PM To: commander-list(at)matronics.com Subject: Commander-List: 500 lost hi barry, i am advised that a 500 went into the atlantic on the way from the bahamas to the us. no details, but all of the commanders in the islands use N numbers. plane is lost. nothing in newspapers. do you happen to know which one it was? i doubt there is even a ntsb report. all of ours are accounted for and we are adding about two a year it seems. allan hoffman - ____________________________________________________________ Penny Stock Jumping 2000% Sign up to the #1 voted penny stock newsletter for free today! AwesomePennyStocks.com http://www.matronics.com/Navigator?Commander-Listhttp://forums.matronics. comhttp://www.matronics.com/contribution ________________________________________________________________________________
Subject: 500 lost
Date: Jun 08, 2010
Nico=2C I remember this crash well. It happened about 110 miles from my house in Gr eensboro N.C. I have the newspaper article somewhere. Roland Gilliam Carthage N.C. AC 500 6291 B From: nico(at)cybersuperstore.com Subject: RE: Commander-List: 500 lost Date: Tue=2C 8 Jun 2010 15:25:40 -0700 I was looking around to see if I could pick up something. Stumbled across t his article=2C something I didn't know. http://www.check-six.com/Crash_Sites/Audie-Murphy-N601JJ.htm Nico From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-lis t-server(at)matronics.com] On Behalf Of alh1(at)juno.com Sent: Tuesday=2C June 08=2C 2010 2:12 PM Subject: Commander-List: 500 lost hi barry=2C i am advised that a 500 went into the atlantic on the way fr om the bahamas to the us. no details=2C but all of the commanders in th e islands use N numbers. plane is lost. nothing in newspapers. do you h appen to know which one it was? i doubt there is even a ntsb report. all of ours are accounted for and we are adding about two a year it seems. al lan hoffman - ____________________________________________________________ Penny Stock Jumping 2000% Sign up to the #1 voted penny stock newsletter for free today! AwesomePennyStocks.com http://www.matronics.com/Navigator?Commander-Listh ttp://forums.matronics.comhttp://www.matronics.com/contribution _________________________________________________________________ Hotmail is redefining busy with tools for the New Busy. Get more from your inbox. http://www.windowslive.com/campaign/thenewbusy?ocid=PID28326::T:WLMTAGL:O N:WL:en-US:WM_HMP:042010_2 ________________________________________________________________________________
Date: Jun 08, 2010
>> A straight 500 has 0-540 engines Is there any STC tor a straight 500 engine? ET Tylor Hall writes: > Zac, > A straight 500 has 0-540 engines, carburetors and 250 HP, not the IO injected. That came in the 500B, U and S versions. The 500 A had the Cont. i0-470 260 HP, The Colmill conversion changed it up to the IO-520 Cont. > > Tylor Hall > > > On Jun 7, 2010, at 6:48 PM, craig kennedy wrote: > >> Sad, but looks to be bubbling nicely in the damp FL sun..... >> >> From: Chris <cschuerm(at)cox.net> >> To: commander-list(at)matronics.com >> Sent: Mon, June 7, 2010 5:28:27 PM >> Subject: Re: Commander-List: AC500 Question or two >> >> >> >> >> >> > ________________________________________________________________________________
Subject: 500 lost
Date: Jun 09, 2010
Nico, He grew up at Farmersville, Texas where my wife's family lived. They always told the story of a bully kid that tried to bully Audie and Audie just beat the tar out of him. He may have been small he had more fight in him than just about anybody. He is one of my hero's, thanks for the story. Jim _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of cybersuperstore Sent: Tuesday, June 08, 2010 5:26 PM Subject: RE: Commander-List: 500 lost I was looking around to see if I could pick up something. Stumbled across this article, something I didn't know. http://www.check-six.com/Crash_Sites/Audie-Murphy-N601JJ.htm Nico _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of alh1(at)juno.com Sent: Tuesday, June 08, 2010 2:12 PM Subject: Commander-List: 500 lost hi barry, i am advised that a 500 went into the atlantic on the way from the bahamas to the us. no details, but all of the commanders in the islands use N numbers. plane is lost. nothing in newspapers. do you happen to know which one it was? i doubt there is even a ntsb report. all of ours are accounted for and we are adding about two a year it seems. allan hoffman - ____________________________________________________________ <http://thirdpartyoffers.juno.com/TGL3132/4c0eb2426dcf327e9d2st04vuc> Penny Stock Jumping 2000% Sign up to the #1 voted penny stock newsletter for free today! <http://thirdpartyoffers.juno.com/TGL3132/4c0eb2426dcf327e9d2st04vuc> AwesomePennyStocks.com http://www.matronics.com/Navigator?Commander-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jun 09, 2010
Hi, There is just one STC, I believe, covering different engines on the straight 500. SA257CE, dated July 27th 1964, covers the "Installation of turbocharged Lycoming engines, model IO-540-A1A5 with Hartzell HC-A3VK-2/V7636D propellers in accordance with Riley Aeronautics, Inc. Bulletin 64-5. Riley Aeronautics, Inc. AFM Supplement dated July 27, 1964 required." This STC is now held by Rayjay Parts LLC., of 10 Harbor Island Drive, Key Largo, Florida 33037. Best Regards, Barry Collman ----- Original Message ----- From: <kitepilot(at)kitepilot.com> Sent: Wednesday, June 09, 2010 2:00 AM Subject: Re: Commander-List: AC500 Question or two | | >> A straight 500 has 0-540 engines | Is there any STC tor a straight 500 engine? | ET | | | | | Tylor Hall writes: | | > Zac, | > A straight 500 has 0-540 engines, carburetors and 250 HP, not the IO injected. That came in the 500B, U and S versions. The 500 A had the Cont. i0-470 260 HP, The Colmill conversion changed it up to the IO-520 Cont. | > | > Tylor Hall | > | > | > On Jun 7, 2010, at 6:48 PM, craig kennedy wrote: | > | >> Sad, but looks to be bubbling nicely in the damp FL sun..... | >> | >> From: Chris <cschuerm(at)cox.net> | >> To: commander-list(at)matronics.com | >> Sent: Mon, June 7, 2010 5:28:27 PM | >> Subject: Re: Commander-List: AC500 Question or two | >> | >> | >> | >> | >> | >> | > | | | | | ________________________________________________________________________________
Date: Jun 09, 2010
Dear Roland - Just saw in your comment that you are the owner of N6291B - I learned to fly in that a/c when it belonged to Mr. Phil Tuttle - Just wanted to say I often think about that 500 and wondered where she was - glad to see I know that now - and that she is in good hands - All my best John -----Original Message----- From: Roland Gilliam <amg3636(at)hotmail.com> Sent: Tue, Jun 8, 2010 7:57 pm Subject: RE: Commander-List: 500 lost Nico, I remember this crash well. It happened about 110 miles from my house in Greensboro N.C. I have the newspaper article somewhere. Roland Gilliam Carthage N.C. AC 500 6291 B From: nico(at)cybersuperstore.com Subject: RE: Commander-List: 500 lost Date: Tue, 8 Jun 2010 15:25:40 -0700 I was looking around to see if I could pick up something. Stumbled across this article, something I didn't know. http://www.check-six.com/Crash_Sites/Audie-Murphy-N601JJ.htm Nico From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-li st-server(at)matronics.com] On Behalf Of alh1(at)juno.com Sent: Tuesday, June 08, 2010 2:12 PM Subject: Commander-List: 500 lost hi barry, i am advised that a 500 went into the atlantic on the way fro m the bahamas to the us. no details, but all of the commanders in the islands use N numbers. plane is lost. nothing in newspapers. do you happen to know which one it was? i doubt there is even a ntsb report. all of ours are accounted for and we are adding about two a year it seem s. allan hoffman - ____________________________________________________________ Penny Stock Jumping 2000% Sign up to the #1 voted penny stock newsletter for free today! AwesomePennyStocks.com http://www.matronics.com/Navigator?Commander-List http://forums.matronics.com http://www.matronics.com/contribution st">http://www.matronics.com/Navigator?Commander-List onics.com w.matronics.com/contribution Hotmail is redefining busy with tools for the New Busy. Get more from your inbox. See how. ======================== =========== -= - The Commander-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Commander-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Subject: Model 520 needed
Date: Jun 14, 2010
Hi Guys, The guys who are restoring the L-3805 prototype Commander near Wiley Post airport, Bethany, are now looking for a Model 520 to restore for static display with the L-3805. The guys, Kenny Payton and Dennis Carter, are with the Francis Tuttle Technology Center. Both aircraft will be acquired by the City of Bethany and I understand that they will be displayed in a new museum that is to be built at Wiley Post. In light of the restoration team=99s sheet metal capabilities, airframe condition should not be of primary importance. So, does anybody know of, or can suggest what might be, a suitable candidate for them? Best Regards, Barry Collman ________________________________________________________________________________
Date: Jun 14, 2010
Subject: Re: Model 520 needed
Hi Barry, N200 (located in Florida) is for sale on Barnstormers...was damaged with a partial gear-up landing... It was being parted out but who knows...might be still reasonably complete. Contact Skip Cambre on 863 258 1775. Cheers from Oz Russell On 14/6/10 8:37 PM, "Barry Collman" <barry.collman@air-britain.co.uk> wrote : > Hi Guys, > > The guys who are restoring the L-3805 prototype Commander near Wiley Post > airport, Bethany, are now looking for a Model 520 to restore for static > display with the L-3805. > > The guys, Kenny Payton and Dennis Carter, are with the Francis Tuttle > Technology Center. > Both aircraft will be acquired by the City of Bethany and I understand th at > they will be displayed in a new museum that is to be built at Wiley Post. > > In light of the restoration team=B9s sheet metal capabilities, airframe > condition should not be of primary importance. > > So, does anybody know of, or can suggest what might be, a suitable candid ate > for them? > > Best Regards, > Barry Collman > > > > ________________________________________________________________________________
Date: Jun 14, 2010
Re: Commander-List: Model 520 neededHi Russell, Thanks for that! I've passed the details on to Bill McGinnis, who is in contact with Kenny & Dennis. Best Regards, Barry ----- Original Message ----- From: Russell Legg To: commander-list(at)matronics.com Sent: Monday, June 14, 2010 12:48 PM Subject: Re: Commander-List: Model 520 needed Hi Barry, N200 (located in Florida) is for sale on Barnstormers...was damaged with a partial gear-up landing... It was being parted out but who knows...might be still reasonably complete. Contact Skip Cambre on 863 258 1775. Cheers from Oz Russell On 14/6/10 8:37 PM, "Barry Collman" <barry.collman@air-britain.co.uk> wrote: Hi Guys, The guys who are restoring the L-3805 prototype Commander near Wiley Post airport, Bethany, are now looking for a Model 520 to restore for static display with the L-3805. The guys, Kenny Payton and Dennis Carter, are with the Francis Tuttle Technology Center. Both aircraft will be acquired by the City of Bethany and I understand that they will be displayed in a new museum that is to be built at Wiley Post. In light of the restoration team's sheet metal capabilities, airframe condition should not be of primary importance. So, does anybody know of, or can suggest what might be, a suitable candidate for them? Best Regards, Barry Collman ist Email Forum - r-List">http://www.matronics.com/Navigator?Commander-List ; - MATRONICS WEB FORUMS - matronics.com ;- List Contribution Web Site - ; -Matt Dralle, List Admin. ://www.matronics.com/contribution ________________________________________________________________________________
Date: Jun 20, 2010
There is a ferriable example in Hillsboro. I have seen the airplane. I believe it can be bought for a few thousand dollars. Anybody out there in a position to finance this?? jb -----Original Message----- From: Barry Collman <barry.collman@air-britain.co.uk> Sent: Mon, Jun 14, 2010 5:04 am Subject: Re: Commander-List: Model 520 needed Hi Russell, Thanks for that! I've passed the details on to Bill McGinnis, who is in contact with Kenny & Dennis. Best Regards, Barry ----- Original Message ----- From: Russell Legg Sent: Monday, June 14, 2010 12:48 PM Subject: Re: Commander-List: Model 520 needed Hi Barry, N200 (located in Florida) is for sale on Barnstormers...was damaged with a partial gear-up landing... It was being parted out but who knows...might be still reasonably complete . Contact Skip Cambre on 863 258 1775. Cheers from Oz Russell On 14/6/10 8:37 PM, "Barry Collman" <barry.collman@air-britain.co.uk> wrot e: Hi Guys, The guys who are restoring the L-3805 prototype Commander near Wiley Post airport, Bethany, are now looking for a Model 520 to restore for static display with the L-3805. The guys, Kenny Payton and Dennis Carter, are with the Francis Tuttle Tech nology Center. Both aircraft will be acquired by the City of Bethany and I understand tha t they will be displayed in a new museum that is to be built at Wiley Post . In light of the restoration team=99s sheet metal capabilities, airfr ame condition should not be of primary importance. So, does anybody know of, or can suggest what might be, a suitable candida te for them? Best Regards, Barry Collman ist Email Forum - r-List">http://www.matronics.com/Navigator?Commander-List ; - MATRONICS WEB FORUMS - matronics.com ;- List Contribution Web Site - ; -Matt Dralle, List Admin. ://www.matronics.com/contribution href="http://www.matronics.com/Navigator?Commander-List">http://www.matr onics.com/Navigator?Commander-List ref="http://forums.matronics.com">http://forums.matronics.com ref="http://www.matronics.com/contribution">http://www.matronics.com/c ======================== =========== -= - The Commander-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Commander-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Date: Jun 21, 2010
Hi JimBob, Have you got any contact details for this 520? An "N" number, or s/n? Best Regards, Barry ----- Original Message ----- From: yourtcfg(at)aol.com To: commander-list(at)matronics.com Sent: Monday, June 21, 2010 3:33 AM Subject: Re: Commander-List: Model 520 needed There is a ferriable example in Hillsboro. I have seen the airplane. I believe it can be bought for a few thousand dollars. Anybody out there in a position to finance this?? jb -----Original Message----- From: Barry Collman <barry.collman@air-britain.co.uk> To: commander-list(at)matronics.com Sent: Mon, Jun 14, 2010 5:04 am Subject: Re: Commander-List: Model 520 needed Hi Russell, Thanks for that! I've passed the details on to Bill McGinnis, who is in contact with Kenny & Dennis. Best Regards, Barry ----- Original Message ----- From: Russell Legg To: commander-list(at)matronics.com Sent: Monday, June 14, 2010 12:48 PM Subject: Re: Commander-List: Model 520 needed Hi Barry, N200 (located in Florida) is for sale on Barnstormers...was damaged with a partial gear-up landing... It was being parted out but who knows...might be still reasonably complete. Contact Skip Cambre on 863 258 1775. Cheers from Oz Russell On 14/6/10 8:37 PM, "Barry Collman" <barry.collman@air-britain.co.uk> wrote: Hi Guys, The guys who are restoring the L-3805 prototype Commander near Wiley Post airport, Bethany, are now looking for a Model 520 to restore for static display with the L-3805. The guys, Kenny Payton and Dennis Carter, are with the Francis Tuttle Technology Center. Both aircraft will be acquired by the City of Bethany and I understand that they will be displayed in a new museum that is to be built at Wiley Post. In light of the restoration team=99s sheet metal capabilities, airframe condition should not be of primary importance. So, does anybody know of, or can suggest what might be, a suitable candidate for them? Best Regards, Barry Collman ist Email Forum - r-List">http://www.matronics.com/Navigator?Commander-List ; - MATRONICS WEB FORUMS - matronics.com ;- List Contribution Web Site - ; -Matt Dralle, List Admin. ://www.matronics.com/contribution href="http://www.matronics.com/Navigator?Commander-List">http://www.mat ronics.com/Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c t" target=_blank>http://www.matronics.com/Navigator?Commander-List tp://forums.matronics.com _blank>http://www.matronics.com/contribution ________________________________________________________________________________
Subject: FW: Nominee for best paint job on an airliner
Date: Jun 21, 2010
Subject: Nominee for best paint job on an airliner _____ Kulula is a low-cost South- African airline that doesn't take itself too seriously. Check out their new livery. No this is not a joke - feel free to Google them - they did the design and artwork in house too.. make sure you check out the smaller print-especially for the "loo." especially for the 'loo'!! [] [] [] ________________________________________________________________________________
Date: Jun 22, 2010
Hi Jim,=0A=0AWhat price is exactly a few thousand dollars. Contact address? =0A=0AThanks,=0A=0AFrits=0A=0A=0A=0A=0A________________________________=0AF rom: "yourtcfg(at)aol.com" =0ATo: commander-list(at)matronics.c om=0ASent: Mon, June 21, 2010 4:33:42 AM=0ASubject: Re: Commander-List: Mod el 520 needed=0A=0AThere is a ferriable example in Hillsboro.=C2- I have seen the airplane.=C2- I believe it can be bought for a few thousand doll ars.=C2- Anybody out there in a position to finance this??=C2- jb=0A=0A =0A=0A=0A-----Original Message-----=0AFrom: Barry Collman <barry.collman@ai r-britain.co.uk>=0ATo: commander-list(at)matronics.com=0ASent: Mon, Jun 14, 20 10 5:04 am=0ASubject: Re: Commander-List: Model 520 needed=0A=0A=0AHi Russe ll,=0A=C2-=0AThanks for that!=0AI've passed the details on to Bill McGinn is, who is in contact with Kenny & Dennis.=0A=C2-=0ABest Regards,=0ABarry =0A----- Original Message ----- =0A>From: Russell Legg =0A>To: commander-li st(at)matronics.com =0A>Sent: Monday, June 14, 2010 12:48 PM=0A>Subject: Re: C ommander-List: Model 520 needed=0A>=0A>Hi Barry,=0A>=0A>N200 (located in Fl orida) is for sale on Barnstormers...was damaged with a partial gear-up lan ding...=0A>=0A>It was being parted out but who knows...might be still reaso nably complete.=0A>=0A>Contact Skip Cambre on 863 258 1775.=0A>=0A>Cheers f rom Oz=0A>=0A>Russell=0A>=0A>=0A>On 14/6/10 8:37 PM, "Barry Collman" .collman@air-britain.co.uk> wrote:=0A>=0A>=0A>Hi Guys,=0A>>=C2-=0A>>The g uys who are restoring the L-3805 prototype Commander near Wiley Post airpor t, Bethany, are now looking for a Model 520 to restore for static display w ith the L-3805.=0A>>=C2-=0A>>The guys, Kenny Payton and Dennis Carter, ar e with the Francis Tuttle Technology Center.=0A>>Both aircraft will be acqu ired by the City of Bethany and I understand that they will be displayed in a new museum that is to be built at Wiley Post.=0A>>=C2-=0A>>In light of the restoration team=99s sheet metal capabilities, airframe conditio n should not be of primary importance.=0A>>=C2-=0A>>So, does anybody know of, or can suggest what might be, a suitable candidate for them?=0A>>=C2 -=0A>>Best Regards,=0A>>Barry Collman=0A>>=0A>>=0A>>ist Email Forum -=0A> >r-List">http://www.matronics.com/Navigator?Commander-List=0A>>;=C2-=C2 -- MATRONICS WEB FORUMS -=0A>>matronics.com=0A>>;- List Contribution Web Site -=0A>>;=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2 -=C2-=C2-=C2-=C2-=C2-=C2--Matt Dralle, List Admin.=0A>>://www .matronics.com/contribution=0A>>=0A>>=0A>>=0A>=0A>=0A>=0A>href="http://ww w.matronics.com/Navigator?Commander-List">http://www.matronics.com/Navigato r?Commander-List=0A>href="http://forums.matronics.com/">http://forums.mat ronics.com=0A>href="http://www.matronics.com/contribution">http://www.mat ronics.com/c=0A>=0A=0A=0A================ =====================0At" target= _blank>http://www.matronics.com/Navigator?Commander-List====== ======0Atp://forums.matronics.com=0A========= ===0A_blank>http://www.matronics.com/contribution======= ==0A=0A=0A ________________________________________________________________________________
Date: Jun 21, 2010
Jim, just think..if they painted every American/United Airlines airliner like this, the captains would actually know what stuff in the airplane does! From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Jim Addington Sent: Monday, June 21, 2010 7:09 PM Subject: Commander-List: FW: Nominee for best paint job on an airliner Subject: Nominee for best paint job on an airliner _____ Kulula is a low-cost South- African airline that doesn't take itself too seriously. Check out their new livery. No this is not a joke - feel free to Google them - they did the design and artwork in house too.. make sure you check out the smaller print-especially for the "loo." especially for the 'loo'!! [] [] [] ________________________________________________________________________________
Date: Jun 22, 2010
At one time I knew what all those switches did, right after the oral it all went away. Jim A _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of John Vormbaum Sent: Tuesday, June 22, 2010 1:58 AM Subject: RE: Commander-List: FW: Nominee for best paint job on an airliner Jim, just think..if they painted every American/United Airlines airliner like this, the captains would actually know what stuff in the airplane does! From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Jim Addington Sent: Monday, June 21, 2010 7:09 PM Subject: Commander-List: FW: Nominee for best paint job on an airliner Subject: Nominee for best paint job on an airliner _____ Kulula is a low-cost South- African airline that doesn't take itself too seriously. Check out their new livery. No this is not a joke - feel free to Google them - they did the design and artwork in house too.. make sure you check out the smaller print-especially for the "loo." especially for the 'loo'!! [] [] [] ________________________________________________________________________________
From: "David Fitzgerald" <DavidFitzgerald(at)bigpond.com>
Subject: Fly-in 2010
Date: Jun 24, 2010
Hi list Has anyone got any preliminary news on when and where the fly-in might be this year? David Dr David Fitzgerald BMedSci(Hons) MBBS(Hons) DipAvMed(Otago) ACCAM(Monash) MHeathSci(OccMed) FAFOEM(RACP) Consultant Occupational Physician Occupational, Legal and Aviation Medicine DavidFitzgerald(at)bigpond.com Mob 0438 312973 ________________________________________________________________________________
Subject: Re: Fly-in 2010
From: "Peter Bichier" <pbichie(at)UTNet.UToledo.Edu>
Date: Jun 24, 2010
Hi Every one, I was just going over my photos of last week end when we had our "fly in" Thought of you guys and totally reminded me of fat nacelles... Look at the pictures in sequence, coincidence? take care, p. -------- 560 Dreamer Read this topic online here: http://forums.matronics.com/viewtopic.php?p=302340#302340 Attachments: http://forums.matronics.com//files/p6190867_copy_110.jpg http://forums.matronics.com//files/p6190921_copy_174.jpg ________________________________________________________________________________
Subject: Discount on upgrade
Date: Jun 25, 2010
http://www.aopa.org/aircraft/articles/2010/100618commanders.html?WT.mc_id=10 0625epilot <http://www.aopa.org/aircraft/articles/2010/100618commanders.html?WT.mc_id=1 00625epilot&WT.mc_sect=gan> &WT.mc_sect=gan Perhaps someone already posted this. Thanks Nico ________________________________________________________________________________
Date: Jun 26, 2010
HI FRITS. Did you ever solver your propeller problems with the 520?? I still have the props we talked about. Thanks!! jb -----Original Message----- From: Frits Abbing <fritsabbing(at)yahoo.com> Sent: Tue, Jun 22, 2010 7:22 am Subject: Re: Commander-List: Model 520 needed Hi Jim, What price is exactly a few thousand dollars. Contact address? Thanks, Frits From: "yourtcfg(at)aol.com" <yourtcfg(at)aol.com> Sent: Mon, June 21, 2010 4:33:42 AM Subject: Re: Commander-List: Model 520 needed There is a ferriable example in Hillsboro. I have seen the airplane. I believe it can be bought for a few thousand dollars. Anybody out there in a position to finance this?? jb -----Original Message----- From: Barry Collman <barry.collman@air-britain.co.uk> Sent: Mon, Jun 14, 2010 5:04 am Subject: Re: Commander-List: Model 520 needed Hi Russell, Thanks for that! I've passed the details on to Bill McGinnis, who is in contact with Kenny & Dennis. Best Regards, Barry ----- Original Message ----- From: Russell Legg Sent: Monday, June 14, 2010 12:48 PM Subject: Re: Commander-List: Model 520 needed Hi Barry, N200 (located in Florida) is for sale on Barnstormers...was damaged with a partial gear-up landing... It was being parted out but who knows...might be still reasonably complete . Contact Skip Cambre on 863 258 1775. Cheers from Oz Russell On 14/6/10 8:37 PM, "Barry Collman" <barry.collman@air-britain.co.uk> wrot e: Hi Guys, The guys who are restoring the L-3805 prototype Commander near Wiley Post airport, Bethany, are now looking for a Model 520 to restore for static display with the L-3805. The guys, Kenny Payton and Dennis Carter, are with the Francis Tuttle Tech nology Center. Both aircraft will be acquired by the City of Bethany and I understand tha t they will be displayed in a new museum that is to be built at Wiley Post . In light of the restoration team=99s sheet metal capabilities, airfr ame condition should not be of primary importance. So, does anybody know of, or can suggest what might be, a suitable candida te for them? Best Regards, Barry Collman ist Email Forum - r-List">http://www.matronics.com/Navigator?Commander-List ; - MATRONICS WEB FORUMS - matronics.com ;- List Contribution Web Site - ; -Matt Dralle, List Admin. ://www.matronics.com/contribution href="http://www.matronics.com/Navigator?Commander-List">http://www.matr onics.com/Navigator?Commander-List ref="http://forums.matronics.com/">http://forums.matronics.com ref="http://www.matronics.com/contribution">http://www.matronics.com/c ======================== =========== " target=_blank>http://www.matronics.com/Navigator?Commander-List== ======== p://forums.matronics.com ======================== blank>http://www.matronics.com/contribution========== http://www.matronics.com/Navigator?Commander-Listhttp://www.==== ================== ======================== ======================== ======================== ======================== ====================== ======================== ======================== ======================== ======================== ====================== ________________________________________________________________________________
From: "Dave Gerrish" <virginia.gerrish(at)verizon.net>
Subject: Landing gear strut lubricaton
Date: Jun 27, 2010
I have been reading the communications for a couple of years, but this is my first try at asking for input. Before every flight we wipe hydraulic fluid on the strut to make it less sticky and wipe off any grime. I had a mechanic at our airport (KHWY, Warrenton, Va.) suggest to me that a product I believe called DOW40 be sprayed on instead. His thought was that it kept the oleo slippery longer and did no harm to the internal seals. Does anyone have opinion or experience with this product. Sincerely, Dave Gerrish Co-owner, 500S, N47AC ________________________________________________________________________________
Date: Jun 27, 2010
Personally, I always thought that the only thing stickier than super glue is hydraulic fluid. I use Commander-Approved Strut Cleaning Fluid (i.e. some fuel from the sump, on a paper towel) to wipe down the struts before I fly. It gets them clean easily and evaporates quickly. I haven't heard of DOW40 but am curious to hear from anyone who has used it. Cheers, /John 500B N353CC From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Dave Gerrish Sent: Sunday, June 27, 2010 12:08 PM Subject: Commander-List: Landing gear strut lubricaton I have been reading the communications for a couple of years, but this is my first try at asking for input. Before every flight we wipe hydraulic fluid on the strut to make it less sticky and wipe off any grime. I had a mechanic at our airport (KHWY, Warrenton, Va.) suggest to me that a product I believe called DOW40 be sprayed on instead. His thought was that it kept the oleo slippery longer and did no harm to the internal seals. Does anyone have opinion or experience with this product. Sincerely, Dave Gerrish Co-owner, 500S, N47AC ________________________________________________________________________________
Date: Jun 27, 2010
Subject: Re: Landing gear strut lubricaton
Kerosene or diesel jg ________________________________________________________________________________
From: "Jack B. Mills" <moe-rosspistons(at)hotmail.com>
Date: Jun 27, 2010
I am with you, John, also this action keeps you from getting the $ 50,000.00 Fine (no joking) at Pensacola, Fl. for throwing the sumped avgas on the tarmack. On another note, are any of you able to keep insurance on a pressurized Commander, without having an instrument check ride at least once a year? After moving to Farmington, NM it is not necessary to stay instrument current, as we have two types of weather here....vis. at least 100 miles, or so bad that you don't want to Taxi. Also, since my retirement, most flying is just for fun, and if I must sit on the ground until the weather clears at MYF or somewhere, this only means that I have more time to enjoy the local stuff. My insurance carrier (AVEMCO) who has been good for many years, insists on the check ride only because of the pressurization. Also, because of the pressurization, a co-pilot will be needed when I turn 70. If someone has a good 680F or 680FL I would consider trading up, down, or sideways for my 680Fp, which has mid time engines, all the bells and whistles, is certified known icing, and is in really great shape except the paint job which could use some help. Due to the high density altitude here I can only consider forced induction with big horsepower. Moe Mills N680RR 680Fp From: John Vormbaum Sent: Sunday, June 27, 2010 4:55 PM Subject: RE: Commander-List: Landing gear strut lubricaton Personally, I always thought that the only thing stickier than super glue is hydraulic fluid. I use Commander-Approved Strut Cleaning Fluid (i.e. some fuel from the sump, on a paper towel) to wipe down the struts before I fly. It gets them clean easily and evaporates quickly. I haven't heard of DOW40 but am curious to hear from anyone who has used it. Cheers, /John 500B N353CC From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Dave Gerrish Sent: Sunday, June 27, 2010 12:08 PM Subject: Commander-List: Landing gear strut lubricaton I have been reading the communications for a couple of years, but this is my first try at asking for input. Before every flight we wipe hydraulic fluid on the strut to make it less sticky and wipe off any grime. I had a mechanic at our airport (KHWY, Warrenton, Va.) suggest to me that a product I believe called DOW40 be sprayed on instead. His thought was that it kept the oleo slippery longer and did no harm to the internal seals. Does anyone have opinion or experience with this product. Sincerely, Dave Gerrish Co-owner, 500S, N47AC http://www.matronics.com/Navigator?Commander-Listhttp://forums.matronics. comhttp://www.matronics.com/contribution ________________________________________________________________________________
Subject: Re: Landing gear strut lubricaton & IFR currency
Date: Jun 28, 2010
On the topic of wiping down struts: I'd like to get Morris Kernick's thou ghts on this. My thoughts are: AvGas, while a great solvent, does not lubricate the strut. WD40 (Witch Doctor 40) cleans and lubricates when its fresh, gets really gummy when it's old or cold and will roll an O ring fast. If you're not going to wipe down your struts with 5606 prior to each fligh t, find a substance that is compatible with the material the O ring is mad e from. I have no idea what that other substance would be. Moe: I had a client, Roy Everingham, who I trained in his AC-680F(P) who was not instrument rated. AVEMCO insisted on him removing the pressuriz ation equipment! I intervened and argued that a man in is 70s, flying from San Diego to Lak e Tahoe, would not be well served by lack of pressurization along that rou te. AVEMCO's answer was that statistically, a non-instrument rated pilot in a pressurized aircraft is going to be stuck on top of an overcast and (here 's the punch line) "We have the cancelled checks to prove it." We compromised. I said that rather than remove the pressurization system that he could disable it. That seemed to satisfy the agent. The answe r to your next question is, "No." You may have better luck with another underwriter -- but I doubt it. Insu rance companies do not like pressurized twins to be flown my non-instrumen t rated or instrument-current pilots. Alternatives? Self insure or get and stay current. Keith S Gordon Wing Commander Gordon Life is not simple anywhere. Probably less so elsewhere. -----Original Message----- From: Jack B. Mills <moe-rosspistons(at)hotmail.com> Sent: Sun, Jun 27, 2010 9:00 pm Subject: Re: Commander-List: Landing gear strut lubricaton I am with you, John, also this action keeps you from getting the $ 50,000. 00 Fine (no joking) at Pensacola, Fl. for throwing the sumped avgas on the tarmack. On another note, are any of you able to keep insurance on a pressurized Commander, without having an instrument check ride at least once a year? After moving to Farmington, NM it is not necessary to stay instrument cu rrent, as we have two types of weather here....vis. at least 100 miles, or so bad that you don't want to Taxi. Also, since my retirement, most flyi ng is just for fun, and if I must sit on the ground until the weather clea rs at MYF or somewhere, this only means that I have more time to enjoy the local stuff. My insurance carrier (AVEMCO) who has been good for many ye ars, insists on the check ride only because of the pressurization. Also, because of the pressurization, a co-pilot will be needed when I turn 70. If someone has a good 680F or 680FL I would consider trading up, down, or sideways for my 680Fp, which has mid time engines, all the bells and whis tles, is certified known icing, and is in really great shape except the pa int job which could use some help. Due to the high density altitude here I can only consider forced induction with big horsepower. Moe Mills N680RR 680Fp From: John Vormbaum Sent: Sunday, June 27, 2010 4:55 PM Subject: RE: Commander-List: Landing gear strut lubricaton Personally, I always thought that the only thing stickier than super glue is hydraulic fluid. I use Commander-Approved Strut Cleaning Fluid (i.e. some fuel from the sump, on a paper towel) to wipe down the struts before I fly. It gets them clean easily and evaporates quickly. I haven=99t heard of DOW40 but am curious to hear from anyone who ha s used it. Cheers, /John 500B N353CC From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-li st-server(at)matronics.com] On Behalf Of Dave Gerrish Sent: Sunday, June 27, 2010 12:08 PM Subject: Commander-List: Landing gear strut lubricaton I have been reading the communications for a couple of yea rs, but this is my first try at asking for input. Before every flight we wipe hydraulic fluid on the strut to make it less sticky and wipe off any grime. I had a mechanic at our airport (KHWY, Wa rrenton, Va.) suggest to me that a product I believe called DOW40 be spray ed on instead. His thought was that it kept the oleo slippery longer and did no harm to the internal seals. Does anyone have opinion or experienc e with this product. Sincerely, Dave Gerrish Co-owner, 500S, N47AC http://www.matronics.com/Navigator?Commander-List http://forums.matronics.com http://www.matronics.com/contribution href="http://www.matronics.com/Navigator?Commander-List">http://www.matr onics.com/Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ======================== =========== ======================== =========== ======================== =========== ======================== =========== ________________________________________________________________________________
Subject: ZS-CTC
Date: Jun 28, 2010
Hi Barry, I am sending this just in case you needed to know about her whereabouts. Scroll a little bit down. http://www.avcom.co.za/phpBB3/viewtopic.php?f=15 <http://www.avcom.co.za/phpBB3/viewtopic.php?f=15&t=64082> &t=64082 I knew Charles Prince in Zimbabwe fairly well. Thanks Nico ________________________________________________________________________________
Subject: Re: ZS-CTC
Date: Jun 28, 2010
Hi Nico, I think ZS-CTC has been resident at Charles Prince for many years. At least, it was noted there in 1994. However, grateful thanks for sending the link. Best Regards, Barry ----- Original Message ----- From: cybersuperstore To: commander-list(at)matronics.com Sent: Monday, June 28, 2010 8:42 AM Subject: Commander-List: ZS-CTC Hi Barry, I am sending this just in case you needed to know about her whereabouts. Scroll a little bit down. http://www.avcom.co.za/phpBB3/viewtopic.php?f=15&t=64082 I knew Charles Prince in Zimbabwe fairly well. Thanks Nico ________________________________________________________________________________
Subject: FW: The future of Honda
Date: Jun 28, 2010
Pretty cool! <http://www.flixxy.com/honda-u3-x-personal-mobility-device.htm> http://www.flixxy.com/honda-u3-x-personal-mobility-device.htm ________________________________________________________________________________
Subject: AV16B-1159
Date: Jun 29, 2010
Anyone know where I could get a fuel selector valve overhauled? ________________________________________________________________________________
Date: Jun 29, 2010
Keith, Thank you very much for the advice. Most likely I will self insure, as pressurization is a good thing here in the rare air high mesa country. Regards, Moe N680RR 680Fp From: Keith S. Gordon Sent: Sunday, June 27, 2010 10:05 PM Subject: Re: Commander-List: Landing gear strut lubricaton & IFR currency On the topic of wiping down struts: I'd like to get Morris Kernick's thoughts on this. My thoughts are: a.. AvGas, while a great solvent, does not lubricate the strut. b.. WD40 (Witch Doctor 40) cleans and lubricates when its fresh, gets really gummy when it's old or cold and will roll an O ring fast. c.. If you're not going to wipe down your struts with 5606 prior to each flight, find a substance that is compatible with the material the O ring is made from. a.. I have no idea what that other substance would be. Moe: I had a client, Roy Everingham, who I trained in his AC-680F(P) who was not instrument rated. AVEMCO insisted on him removing the pressurization equipment! I intervened and argued that a man in is 70s, flying from San Diego to Lake Tahoe, would not be well served by lack of pressurization along that route. AVEMCO's answer was that statistically, a non-instrument rated pilot in a pressurized aircraft is going to be stuck on top of an overcast and (here's the punch line) "We have the cancelled checks to prove it." We compromised. I said that rather than remove the pressurization system that he could disable it. That seemed to satisfy the agent. The answer to your next question is, "No." You may have better luck with another underwriter -- but I doubt it. Insurance companies do not like pressurized twins to be flown my non-instrument rated or instrument-current pilots. Alternatives? Self insure or get and stay current. Keith S Gordon Wing Commander Gordon Life is not simple anywhere. Probably less so elsewhere. -----Original Message----- From: Jack B. Mills <moe-rosspistons(at)hotmail.com> Sent: Sun, Jun 27, 2010 9:00 pm Subject: Re: Commander-List: Landing gear strut lubricaton I am with you, John, also this action keeps you from getting the $ 50,000.00 Fine (no joking) at Pensacola, Fl. for throwing the sumped avgas on the tarmack. On another note, are any of you able to keep insurance on a pressurized Commander, without having an instrument check ride at least once a year? After moving to Farmington, NM it is not necessary to stay instrument current, as we have two types of weather here....vis. at least 100 miles, or so bad that you don't want to Taxi. Also, since my retirement, most flying is just for fun, and if I must sit on the ground until the weather clears at MYF or somewhere, this only means that I have more time to enjoy the local stuff. My insurance carrier (AVEMCO) who has been good for many years, insists on the check ride only because of the pressurization. Also, because of the pressurization, a co-pilot will be needed when I turn 70. If someone has a good 680F or 680FL I would consider trading up, down, or sideways for my 680Fp, which has mid time engines, all the bells and whistles, is certified known icing, and is in really great shape except the paint job which could use some help. Due to the high density altitude here I can only consider forced induction with big horsepower. Moe Mills N680RR 680Fp From: John Vormbaum Sent: Sunday, June 27, 2010 4:55 PM Subject: RE: Commander-List: Landing gear strut lubricaton Personally, I always thought that the only thing stickier than super glue is hydraulic fluid. I use Commander-Approved Strut Cleaning Fluid (i.e. some fuel from the sump, on a paper towel) to wipe down the struts before I fly. It gets them clean easily and evaporates quickly. I haven=99t heard of DOW40 but am curious to hear from anyone who has used it. Cheers, /John 500B N353CC From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Dave Gerrish Sent: Sunday, June 27, 2010 12:08 PM Subject: Commander-List: Landing gear strut lubricaton I have been reading the communications for a couple of years, but this is my first try at asking for input. Before every flight we wipe hydraulic fluid on the strut to make it less sticky and wipe off any grime. I had a mechanic at our airport (KHWY, Warrenton, Va.) suggest to me that a product I believe called DOW40 be sprayed on instead. His thought was that it kept the oleo slippery longer and did no harm to the internal seals. Does anyone have opinion or experience with this product. Sincerely, Dave Gerrish Co-owner, 500S, N47AC http://www.matronics.com/Navigator?Commander-Listhttp://forums.matronics. comhttp://www.matronics.com/contribution href="http://www.matronics.com/Navigator?Commander-List">http://www.mat ronics.com/Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ator?Commander-List">http://www.matronics.com/Navigator?Commander-List ttp://forums.matronics.com ibution">http://www.matronics.com/contribution ________________________________________________________________________________
Subject: Re: AV16B-1159
Date: Jun 29, 2010
Yes Harry Merritt 321 267-3141 ----- Original Message ----- From: "Bill Kirkwood" <bkirkwoo(at)elp.rr.com> Sent: Tuesday, June 29, 2010 10:28 AM Subject: Commander-List: AV16B-1159 > > Anyone know where I could get a fuel selector valve overhauled? > > > > > > ________________________________________________________________________________
Subject: AC 680FLP Pressure reducer
Date: Jun 29, 2010
Hello, I am in need of an overhaul of a pressure reducer from the hydraulic system of an Aero Commander 680FLP, Mr. RPM conversion. The pump pressure is about 3,000 psi and the aircraft system works around 1,000 psi. Had the pressure go to 2,000 psi recently and broke a line. Most recent runup was OK but I don't trust it now. Have had two complete hydraulic failures this year, don't want any more. Maintenance guys have found someone to overhaul, but it's around $5,500 (ripoff price) and 45-60 days. I can't believe a pressure reducer is that complicated an item.. Does anyone have a pressure reducer for sale...sorry I don't have a part number at the moment. Experienced Commander folks will probably know what I need, but I can get the part #. Thanks, Ray Mansfield ________________________________________________________________________________
Subject: Re: AC 680FLP Pressure reducer
Date: Jun 29, 2010
yes harry merritt 321 267-3141 ----- Original Message ----- From: Ray Mansfield To: Commander List Sent: Tuesday, June 29, 2010 11:38 AM Subject: Commander-List: AC 680FLP Pressure reducer Hello, I am in need of an overhaul of a pressure reducer from the hydraulic system of an Aero Commander 680FLP, Mr. RPM conversion. The pump pressure is about 3,000 psi and the aircraft system works around 1,000 psi. Had the pressure go to 2,000 psi recently and broke a line. Most recent runup was OK but I don't trust it now. Have had two complete hydraulic failures this year, don't want any more. Maintenance guys have found someone to overhaul, but it's around $5,500 (ripoff price) and 45-60 days. I can't believe a pressure reducer is that complicated an item.. Does anyone have a pressure reducer for sale...sorry I don't have a part number at the moment. Experienced Commander folks will probably know what I need, but I can get the part #. Thanks, Ray Mansfield ________________________________________________________________________________
Date: Jun 30, 2010
Hi, I needed a pressure regulator for my 500S 3 years ago and the only on available was an overhauled one on a shelf in Indianna for $5000.00 PLUS a $3000.00 core charge if mine was rebuildable. Apparently there is only one place that rebuilds them and there are some parts in there that are not available any more and have to be "machined". Luckily mine was rebuildable and I was able to recover my core charge. Good luck. I still have half of a rear door hinge that cost me $950.00. I was able to have the broken one welded but was unable to return the new 1/2 because 2 weeks had elapsed. Don -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com]On Behalf Of Ray Mansfield Sent: Tuesday, June 29, 2010 11:39 AM To: Commander List Subject: Commander-List: AC 680FLP Pressure reducer Hello, I am in need of an overhaul of a pressure reducer from the hydraulic system of an Aero Commander 680FLP, Mr. RPM conversion. The pump pressure is about 3,000 psi and the aircraft system works around 1,000 psi. Had the pressure go to 2,000 psi recently and broke a line. Most recent runup was OK but I don't trust it now. Have had two complete hydraulic failures this year, don't want any more. Maintenance guys have found someone to overhaul, but it's around $5,500 (ripoff price) and 45-60 days. I can't believe a pressure reducer is that complicated an item.. Does anyone have a pressure reducer for sale...sorry I don't have a part number at the moment. Experienced Commander folks will probably know what I need, but I can get the part #. Thanks, Ray Mansfield ________________________________________________________________________________
Date: Jun 30, 2010
Thanks Don, appreciate the information. Ray M. From: dfalik(at)sbcglobal.net Sent: Wednesday, June 30, 2010 7:03 AM Subject: RE: Commander-List: AC 680FLP Pressure reducer Hi, I needed a pressure regulator for my 500S 3 years ago and the only on available was an overhauled one on a shelf in Indianna for $5000.00 PLUS a $3000.00 core charge if mine was rebuildable. Apparently there is only one place that rebuilds them and there are some parts in there that are not available any more and have to be "machined". Luckily mine was rebuildable and I was able to recover my core charge. Good luck. I still have half of a rear door hinge that cost me $950.00. I was able to have the broken one welded but was unable to return the new 1/2 because 2 weeks had elapsed. Don -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com]On Behalf Of Ray Mansfield Sent: Tuesday, June 29, 2010 11:39 AM To: Commander List Subject: Commander-List: AC 680FLP Pressure reducer Hello, I am in need of an overhaul of a pressure reducer from the hydraulic system of an Aero Commander 680FLP, Mr. RPM conversion. The pump pressure is about 3,000 psi and the aircraft system works around 1,000 psi. Had the pressure go to 2,000 psi recently and broke a line. Most recent runup was OK but I don't trust it now. Have had two complete hydraulic failures this year, don't want any more. Maintenance guys have found someone to overhaul, but it's around $5,500 (ripoff price) and 45-60 days. I can't believe a pressure reducer is that complicated an item.. Does anyone have a pressure reducer for sale...sorry I don't have a part number at the moment. Experienced Commander folks will probably know what I need, but I can get the part #. Thanks, Ray Mansfield href="http://www.matronics.com/Navigator?Commander-List">http://www.mat ronics.com/Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Jun 30, 2010
I have one Harry Merritt 321 267-3141 ----- Original Message ----- From: dfalik(at)sbcglobal.net To: commander-list(at)matronics.com Sent: Wednesday, June 30, 2010 8:03 AM Subject: RE: Commander-List: AC 680FLP Pressure reducer Hi, I needed a pressure regulator for my 500S 3 years ago and the only on available was an overhauled one on a shelf in Indianna for $5000.00 PLUS a $3000.00 core charge if mine was rebuildable. Apparently there is only one place that rebuilds them and there are some parts in there that are not available any more and have to be "machined". Luckily mine was rebuildable and I was able to recover my core charge. Good luck. I still have half of a rear door hinge that cost me $950.00. I was able to have the broken one welded but was unable to return the new 1/2 because 2 weeks had elapsed. Don -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com]On Behalf Of Ray Mansfield Sent: Tuesday, June 29, 2010 11:39 AM To: Commander List Subject: Commander-List: AC 680FLP Pressure reducer Hello, I am in need of an overhaul of a pressure reducer from the hydraulic system of an Aero Commander 680FLP, Mr. RPM conversion. The pump pressure is about 3,000 psi and the aircraft system works around 1,000 psi. Had the pressure go to 2,000 psi recently and broke a line. Most recent runup was OK but I don't trust it now. Have had two complete hydraulic failures this year, don't want any more. Maintenance guys have found someone to overhaul, but it's around $5,500 (ripoff price) and 45-60 days. I can't believe a pressure reducer is that complicated an item.. Does anyone have a pressure reducer for sale...sorry I don't have a part number at the moment. Experienced Commander folks will probably know what I need, but I can get the part #. Thanks, Ray Mansfield href="http://www.matronics.com/Navigator?Commander-List">http://www.mat ronics.com/Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Subject: If your ears were burning it is because.....................
Date: Jun 30, 2010
Monday afternoon there was a knock at my front door. When I opened it there stood Bill Bow. We spent the evening getting drunk and looking at Photos from the Oregon and South Carolina Flyins and talked about each and everyone of you who were there. -------- Milt Read this topic online here: http://forums.matronics.com/viewtopic.php?p=303155#303155 Attachments: http://forums.matronics.com//files/dcp_0220_115.jpg ________________________________________________________________________________
Subject: Re: If your ears were burning it is because.....................
Date: Jun 30, 2010
We spent the evening getting drunk and looking at Photos from the Oregon and South Carolina Flyins and talked about each and everyone of you who were there. How drunk were you Lads? Tipsy enough to say nice things about us or blo tto enough to tell the truth? Keith S. Gordon Wing Commander Gordon Life is not simple anywhere. Probably less so elsewhere. ________________________________________________________________________________
Date: Jun 30, 2010
We started Tipsy, got blotto and hell I can't remember anymore than that. [Embarassed] [Rolling Eyes] -------- Milt Read this topic online here: http://forums.matronics.com/viewtopic.php?p=303188#303188 ________________________________________________________________________________
Subject: FLY-IN
Date: Jul 02, 2010
HI KIDS...Well, I can finally officially announce that the 2010 Twin Comma nder fly-in will be held Sept 9-10-11, 2010 at Aero Air in Hillsboro Orego n. This is the site of our first flyin and a great facility. We already have some great speakers in mind and a fly out to the Evergreen museum in Mcminville OR, home of the Spruce Goose!!. We are also planning a dinner on a stern wheeler (TBA) and some other fun and informative stuff!!. Pla n to be there. We will be sending information on rooms and car rentals af ter the 4th. Hope to see you there!! jb. PS Jimmy Rodriguez and family, from San Juan PR, are in rout to visit Sue and I over the 4th, Can't wai t to see them. jb ________________________________________________________________________________
Date: Jul 01, 2010
Subject: Re: FLY-IN
Jim, put me on the list. I'm in for sure! Since we're all ME (and high wing) pilots, do you think they'd let us take the spruce goose for a spin? I'm sure that someone in the group has a seaplane rating... Say "hi" to Jimmy for me. I haven't seen him in a few years. Cheers, John PS: Wing Commander Gordon, your presence is required. The last time I saw you was the original Aero Air fly-in a decade ago, I think. Hillsboro is what, 45 minutes from Vegas in a Falcon? sent by my DROID. Please pardon any typos. On Jul 1, 2010 10:39 PM, wrote: HI KIDS...Well, I can finally officially announce that the 2010 Twin Commander fly-in will be held Sept 9-10-11, 2010 at Aero Air in Hillsboro Oregon. This is the site of our first flyin and a great facility. We already have some great speakers in mind and a fly out to the Evergreen museum in Mcminville OR, home of the Spruce Goose!!. We are also planning a dinner on a stern wheeler (TBA) and some other fun and informative stuff!!. Plan to be there. We will be sending information on rooms and car rentals after the 4th. Hope to see you there!! jb. PS Jimmy Rodriguez and family, from San Juan PR, are in rout to visit Sue and I over the 4th, Can't wait to see them. jb * * ________________________________________________________________________________
Subject: FLY-IN
Date: Jul 01, 2010
I will update the website accordingly. You deserve an update on what's happening on the site, too. We are doing some final testing on a new site that affords members and visitors many new features of the latest technology. Once we are ready to beta-test the site, I'll forward you a link where you can check it out and give your feedback. After having spent almost two years working on it (time didn't always cooperate) I am getting more excited about the site every day we are working on it. I sincerely hope that you would, too, once you see it. Thanks Nico _____ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of yourtcfg(at)aol.com Sent: Thursday, July 01, 2010 10:33 PM Subject: Commander-List: FLY-IN HI KIDS...Well, I can finally officially announce that the 2010 Twin Commander fly-in will be held Sept 9-10-11, 2010 at Aero Air in Hillsboro Oregon. This is the site of our first flyin and a great facility. We already have some great speakers in mind and a fly out to the Evergreen museum in Mcminville OR, home of the Spruce Goose!!. We are also planning a dinner on a stern wheeler (TBA) and some other fun and informative stuff!!. Plan to be there. We will be sending information on rooms and car rentals after the 4th. Hope to see you there!! jb. PS Jimmy Rodriguez and family, from San Juan PR, are in rout to visit Sue and I over the 4th, Can't wait to see them. jb ________________________________________________________________________________
Subject: Re: FLY-IN
Date: Jul 02, 2010
G'day Jim Great news and count this Ossie in!! Will look forward to Hillsboro...10 years on... Sure would be good to see a whole bunch of 'old hands'...and new folk too!! Cheers from Oz Russell ________________________________________________________________________________
Subject: Re: FLY-IN
Date: Jul 02, 2010
It will be great to see all of you as well!! Wont be long now. jb -----Original Message----- From: rlegg(at)austarnet.com.au Sent: Fri, Jul 2, 2010 2:02 am Subject: Re: Commander-List: FLY-IN G'day Jim Great news and count this Ossie in!! Will look forward to Hillsboro...10 years on... Sure would be good to see a whole bunch of 'old hands'...and new folk too! ! heers from Oz Russell ======================== =========== -= - The Commander-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Commander-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Subject: Re: FLY-IN
Date: Jul 02, 2010
THANKS NICO, for all you hard work!! Any chance you can make this years fly in?? jb -----Original Message----- From: cybersuperstore <nico(at)cybersuperstore.com> Sent: Thu, Jul 1, 2010 11:34 pm Subject: RE: Commander-List: FLY-IN I will update the website accordingly. You deserve an update on what's hap pening on the site, too. We are doing some final testing on a new site that affords members and vis itors many new features of the latest technology. Once we are ready to bet a-test the site, I'll forward you a link where you can check it out and gi ve your feedback. After having spent almost two years working on it (time didn't always cooperate) I am getting more excited about the site every day we are working on it. I sincerely hope that you would, too, once you see it. Thanks Nico From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-li st-server(at)matronics.com] On Behalf Of yourtcfg(at)aol.com Sent: Thursday, July 01, 2010 10:33 PM Subject: Commander-List: FLY-IN HI KIDS...Well, I can finally officially announce that the 2010 Twin Comma nder fly-in will be held Sept 9-10-11, 2010 at Aero Air in Hillsboro Orego n. This is the site of our first flyin and a great facility. We already have some great speakers in mind and a fly out to the Evergreen museum in Mcminville OR, home of the Spruce Goose!!. We are also planning a dinner on a stern wheeler (TBA) and some other fun and informative stuff!!. Pla n to be there. We will be sending information on rooms and car rentals af ter the 4th. Hope to see you there!! jb. PS Jimmy Rodriguez and family, from San Juan PR, are in rout to visit Sue and I over the 4th, Can't wai t to see them. jb http://www.matronics.com/Navigator?Commander-List http://forums.matronics.com http://www.matronics.com/contribution ======================== =========== -= - The Commander-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Commander-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Subject: Re: FLY-IN
Date: Jul 02, 2010
WILL DO. For those new to the list, Jimmy Rodriguez owns 500B, S/N 1 Yep , the very first 500B.. It resides with him in SJ, P.R. I travel there each year to do the annual inspection for him. He is a great guy and has a wonderful family. We are looking forward to their visit. jb "hi" to Jimmy for me. I haven't seen him in a few years. -----Original Message----- From: John Vormbaum <john(at)vormbaum.com> Sent: Thu, Jul 1, 2010 10:49 pm Subject: Re: Commander-List: FLY-IN Jim, put me on the list. I'm in for sure! Since we're all ME (and high wing) pilots, do you think they'd let us take the spruce goose for a spin? I'm sure that someone in the group has a sea plane rating... Say "hi" to Jimmy for me. I haven't seen him in a few years. Cheers, John PS: Wing Commander Gordon, your presence is required. The last time I saw you was the original Aero Air fly-in a decade ago, I think. Hillsboro is what, 45 minutes from Vegas in a Falcon? sent by my DROID. Please pardon any typos. On Jul 1, 2010 10:39 PM, wrote: HI KIDS...Well, I can finally officially announce that the 2010 Twin Comma nder fly-in will be held Sept 9-10-11, 2010 at Aero Air in Hillsboro Orego n. This is the site of our first flyin and a great facility. We already have some great speakers in mind and a fly out to the Evergreen museum in Mcminville OR, home of the Spruce Goose!!. We are also planning a dinner on a stern wheeler (TBA) and some other fun and informative stuff!!. Pla n to be there. We will be sending information on rooms and car rentals af ter the 4th. Hope to see you there!! jb. PS Jimmy Rodriguez and family, from San Juan PR, are in rout to visit Sue and I over the 4th, Can't wai t to see them. jb " target="_blank">http://www.matronics.com/Navigator?Commander-List p://forums.matronics.com blank">http://www.matronics.com/contribution ======================== =========== -= - The Commander-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Commander-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Subject: Re: FLY-IN
Date: Jul 02, 2010
J B and Group, Regrettably, I will not be able to attend the fly in this year. Many of you may agree that things have gone terribly wrong in our country in the last 18 months. After a lot of thought I felt that it was time for me to do more than just 'give my support' to someone who will help change the way things are going in our country. Tom Mullins (www.mullinsforcongress.com), a very conservative and Christian gentlemen from here in Farmington, NM is running for the US House of Representatives, and I am working full time (his only full time volunteer) in the campaign. I feel a deep sense of dedication to what I am doing. Our opponent votes with Nancy Pelosi 98.5% of the time, receives heaps of Union and PACT (including AOPA PACT) money and will probably outspend us by over five to one. The latest Magellan poll shows 42% for Tom and 43% for the opposition. Tom won the Republican primary by 72% to 28% even though the other Republican spent over twice as much on his campaign. The third congressional district here in New Mexico is larger than the entire state of Pennsylvania, so the amount of travel is almost unbelievable. Last week I drove over 2,500 miles in my truck with Tom, and don't expect to be back home for a couple of weeks. Many of our days start at 5:00 AM and end after 10:00 PM. Due to the lay out of the district flying just don't work for us most of the time. Certainly, it would be great to fly up there and be with all of my old friends but there just will not be time. Moe Mills N680RR 680Fp From: yourtcfg(at)aol.com Sent: Friday, July 02, 2010 8:31 AM Subject: Re: Commander-List: FLY-IN WILL DO. For those new to the list, Jimmy Rodriguez owns 500B, S/N 1 Yep, the very first 500B.. It resides with him in SJ, P.R. I travel there each year to do the annual inspection for him. He is a great guy and has a wonderful family. We are looking forward to their visit. jb "hi" to Jimmy for me. I haven't seen him in a few years. -----Original Message----- From: John Vormbaum <john(at)vormbaum.com> Sent: Thu, Jul 1, 2010 10:49 pm Subject: Re: Commander-List: FLY-IN Jim, put me on the list. I'm in for sure! Since we're all ME (and high wing) pilots, do you think they'd let us take the spruce goose for a spin? I'm sure that someone in the group has a seaplane rating... Say "hi" to Jimmy for me. I haven't seen him in a few years. Cheers, John PS: Wing Commander Gordon, your presence is required. The last time I saw you was the original Aero Air fly-in a decade ago, I think. Hillsboro is what, 45 minutes from Vegas in a Falcon? sent by my DROID. Please pardon any typos. On Jul 1, 2010 10:39 PM, wrote: HI KIDS...Well, I can finally officially announce that the 2010 Twin Commander fly-in will be held Sept 9-10-11, 2010 at Aero Air in Hillsboro Oregon. This is the site of our first flyin and a great facility. We already have some great speakers in mind and a fly out to the Evergreen museum in Mcminville OR, home of the Spruce Goose!!. We are also planning a dinner on a stern wheeler (TBA) and some other fun and informative stuff!!. Plan to be there. We will be sending information on rooms and car rentals after the 4th. Hope to see you there!! jb. PS Jimmy Rodriguez and family, from San Juan PR, are in rout to visit Sue and I over the 4th, Can't wait to see them. jb " target="_blank">http://www.matronics.com/Navigator?Commander-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution t" target=_blank>http://www.matronics.com/Navigator?Commander-List tp://forums.matronics.com _blank>http://www.matronics.com/contribution ________________________________________________________________________________
Subject: FLY-IN
Date: Jul 04, 2010
Moe, Good luck and God speed! We will certainly miss you - but your cause is worthy! Regards, Bob ________________________________ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Jack B. Mills Sent: Saturday, July 03, 2010 1:05 AM Subject: Re: Commander-List: FLY-IN J B and Group, Regrettably, I will not be able to attend the fly in this year. Many of you may agree that things have gone terribly wrong in our country in the last 18 months. After a lot of thought I felt that it was time for me to do more than just 'give my support' to someone who will help change the way things are going in our country. Tom Mullins (www.mullinsforcongress.com), a very conservative and Christian gentlemen from here in Farmington, NM is running for the US House of Representatives, and I am working full time (his only full time volunteer) in the campaign. I feel a deep sense of dedication to what I am doing. Our opponent votes with Nancy Pelosi 98.5% of the time, receives heaps of Union and PACT (including AOPA PACT) money and will probably outspend us by over five to one. The latest Magellan poll shows 42% for Tom and 43% for the opposition. Tom won the Republican primary by 72% to 28% even though the other Republican spent over twice as much on his campaign. The third congressional district here in New Mexico is larger than the entire state of Pennsylvania, so the amount of travel is almost unbelievable. Last week I drove over 2,500 miles in my truck with Tom, and don't expect to be back home for a couple of weeks. Many of our days start at 5:00 AM and end after 10:00 PM. Due to the lay out of the district flying just don't work for us most of the time. Certainly, it would be great to fly up there and be with all of my old friends but there just will not be time. Moe Mills N680RR 680Fp From: yourtcfg(at)aol.com Sent: Friday, July 02, 2010 8:31 AM Subject: Re: Commander-List: FLY-IN WILL DO. For those new to the list, Jimmy Rodriguez owns 500B, S/N 1 Yep, the very first 500B.. It resides with him in SJ, P.R. I travel there each year to do the annual inspection for him. He is a great guy and has a wonderful family. We are looking forward to their visit. jb "hi" to Jimmy for me. I haven't seen him in a few years. -----Original Message----- From: John Vormbaum <john(at)vormbaum.com> Sent: Thu, Jul 1, 2010 10:49 pm Subject: Re: Commander-List: FLY-IN Jim, put me on the list. I'm in for sure! Since we're all ME (and high wing) pilots, do you think they'd let us take the spruce goose for a spin? I'm sure that someone in the group has a seaplane rating... Say "hi" to Jimmy for me. I haven't seen him in a few years. Cheers, John PS: Wing Commander Gordon, your presence is required. The last time I saw you was the original Aero Air fly-in a decade ago, I think. Hillsboro is what, 45 minutes from Vegas in a Falcon? sent by my DROID. Please pardon any typos. On Jul 1, 2010 10:39 PM, wrote: HI KIDS...Well, I can finally officially announce that the 2010 Twin Commander fly-in will be held Sept 9-10-11, 2010 at Aero Air in Hillsboro Oregon. This is the site of our first flyin and a great facility. We already have some great speakers in mind and a fly out to the Evergreen museum in Mcminville OR, home of the Spruce Goose!!. We are also planning a dinner on a stern wheeler (TBA) and some other fun and informative stuff!!. Plan to be there. We will be sending information on rooms and car rentals after the 4th. Hope to see you there!! jb. PS Jimmy Rodriguez and family, from San Juan PR, are in rout to visit Sue and I over the 4th, Can't wait to see them. jb " target="_blank">http://www.matronics.com/Navigator?Commander-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution t" target=_blank>http://www.matronics.com/Navigator?Commander-List tp://forums.matronics.com _blank>http://www.matronics.com/contribution href="http://www.matronics.com/Navigator?Commander-List">http://www.mat r onics.com/Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
From: "Barry Collman" <barry.collman@air-britain.co.uk>
Subject: Re: FLY-IN
Date: Jul 04, 2010
Hi Moe, Indeed, you'll be sorely missed. But, this isn't a way out of being awarded the Golden Pedal Award again, is it? Very Best Regards, Barry ----- Original Message ----- From: Steele, Bob To: commander-list(at)matronics.com Sent: Sunday, July 04, 2010 4:02 PM Subject: RE: Commander-List: FLY-IN Moe, Good luck and God speed! We will certainly miss you - but your cause is worthy! Regards, Bob ------------------------------------------------------------------------- ----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Jack B. Mills Sent: Saturday, July 03, 2010 1:05 AM To: commander-list(at)matronics.com Subject: Re: Commander-List: FLY-IN J B and Group, Regrettably, I will not be able to attend the fly in this year. Many of you may agree that things have gone terribly wrong in our country in the last 18 months. After a lot of thought I felt that it was time for me to do more than just 'give my support' to someone who will help change the way things are going in our country. Tom Mullins (www.mullinsforcongress.com), a very conservative and Christian gentlemen from here in Farmington, NM is running for the US House of Representatives, and I am working full time (his only full time volunteer) in the campaign. I feel a deep sense of dedication to what I am doing. Our opponent votes with Nancy Pelosi 98.5% of the time, receives heaps of Union and PACT (including AOPA PACT) money and will probably outspend us by over five to one. The latest Magellan poll shows 42% for Tom and 43% for the opposition. Tom won the Republican primary by 72% to 28% even though the other Republican spent over twice as much on his campaign. The third congressional district here in New Mexico is larger than the entire state of Pennsylvania, so the amount of travel is almost unbelievable. Last week I drove over 2,500 miles in my truck with Tom, and don't expect to be back home for a couple of weeks. Many of our days start at 5:00 AM and end after 10:00 PM. Due to the lay out of the district flying just don't work for us most of the time. Certainly, it would be great to fly up there and be with all of my old friends but there just will not be time. Moe Mills N680RR 680Fp From: yourtcfg(at)aol.com Sent: Friday, July 02, 2010 8:31 AM To: commander-list(at)matronics.com Subject: Re: Commander-List: FLY-IN WILL DO. For those new to the list, Jimmy Rodriguez owns 500B, S/N 1 Yep, the very first 500B.. It resides with him in SJ, P.R. I travel there each year to do the annual inspection for him. He is a great guy and has a wonderful family. We are looking forward to their visit. jb "hi" to Jimmy for me. I haven't seen him in a few years. -----Original Message----- From: John Vormbaum <john(at)vormbaum.com> To: commander-list(at)matronics.com Sent: Thu, Jul 1, 2010 10:49 pm Subject: Re: Commander-List: FLY-IN Jim, put me on the list. I'm in for sure! Since we're all ME (and high wing) pilots, do you think they'd let us take the spruce goose for a spin? I'm sure that someone in the group has a seaplane rating... Say "hi" to Jimmy for me. I haven't seen him in a few years. Cheers, John PS: Wing Commander Gordon, your presence is required. The last time I saw you was the original Aero Air fly-in a decade ago, I think. Hillsboro is what, 45 minutes from Vegas in a Falcon? sent by my DROID. Please pardon any typos. On Jul 1, 2010 10:39 PM, wrote: HI KIDS...Well, I can finally officially announce that the 2010 Twin Commander fly-in will be held Sept 9-10-11, 2010 at Aero Air in Hillsboro Oregon. This is the site of our first flyin and a great facility. We already have some great speakers in mind and a fly out to the Evergreen museum in Mcminville OR, home of the Spruce Goose!!. We are also planning a dinner on a stern wheeler (TBA) and some other fun and informative stuff!!. Plan to be there. We will be sending information on rooms and car rentals after the 4th. Hope to see you there!! jb. PS Jimmy Rodriguez and family, from San Juan PR, are in rout to visit Sue and I over the 4th, Can't wait to see them. jb " target="_blank">http://www.matronics.com/Navigator?Commander-Listtp://f orums.matronics.com_blank">http://www.matronics.com/contribution t" target=_blank>http://www.matronics.com/Navigator?Commander-Listtp://for ums.matronics.com_blank>http://www.matronics.com/contribution href="http://www.matronics.com/Navigator?Commander-List">http://www.mat ronics.com/Navigator?Commander-Listhref="http://forums.matronics.com">h ttp://forums.matronics.comhref="http://www.matronics.com/contribution"> http://www.matronics.com/c http://www.matronics.com/Navigator?Commander-Listhttp://forums.matronics. comhttp://www.matronics.com/contribution ________________________________________________________________________________
Subject: Re: FLY-IN
Date: Jul 04, 2010
Barry, Bob and all, Since I will not be there perhaps it is time to "fess up" and admit that earlier in the year two sets of Commander rudder pedals were purchased, and as soon as my assistant gets back from vacation (only I am so incompetent that an assistant is required just to be retired) she is going to made three or four Golden Pedal awards. Originally the idea was to bring a couple of them to the fly in and we could auction them off for our charity auction and of course one would be kept by myself for bragging rights. Should these be shipped to J.B.? Regards, Moe N680RR 680Fp From: Barry Collman Sent: Sunday, July 04, 2010 8:15 AM Subject: Re: Commander-List: FLY-IN Hi Moe, Indeed, you'll be sorely missed. But, this isn't a way out of being awarded the Golden Pedal Award again, is it? Very Best Regards, Barry ----- Original Message ----- From: Steele, Bob To: commander-list(at)matronics.com Sent: Sunday, July 04, 2010 4:02 PM Subject: RE: Commander-List: FLY-IN Moe, Good luck and God speed! We will certainly miss you - but your cause is worthy! Regards, Bob ------------------------------------------------------------------------- ----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Jack B. Mills Sent: Saturday, July 03, 2010 1:05 AM To: commander-list(at)matronics.com Subject: Re: Commander-List: FLY-IN J B and Group, Regrettably, I will not be able to attend the fly in this year. Many of you may agree that things have gone terribly wrong in our country in the last 18 months. After a lot of thought I felt that it was time for me to do more than just 'give my support' to someone who will help change the way things are going in our country. Tom Mullins (www.mullinsforcongress.com), a very conservative and Christian gentlemen from here in Farmington, NM is running for the US House of Representatives, and I am working full time (his only full time volunteer) in the campaign. I feel a deep sense of dedication to what I am doing. Our opponent votes with Nancy Pelosi 98.5% of the time, receives heaps of Union and PACT (including AOPA PACT) money and will probably outspend us by over five to one. The latest Magellan poll shows 42% for Tom and 43% for the opposition. Tom won the Republican primary by 72% to 28% even though the other Republican spent over twice as much on his campaign. The third congressional district here in New Mexico is larger than the entire state of Pennsylvania, so the amount of travel is almost unbelievable. Last week I drove over 2,500 miles in my truck with Tom, and don't expect to be back home for a couple of weeks. Many of our days start at 5:00 AM and end after 10:00 PM. Due to the lay out of the district flying just don't work for us most of the time. Certainly, it would be great to fly up there and be with all of my old friends but there just will not be time. Moe Mills N680RR 680Fp From: yourtcfg(at)aol.com Sent: Friday, July 02, 2010 8:31 AM To: commander-list(at)matronics.com Subject: Re: Commander-List: FLY-IN WILL DO. For those new to the list, Jimmy Rodriguez owns 500B, S/N 1 Yep, the very first 500B.. It resides with him in SJ, P.R. I travel there each year to do the annual inspection for him. He is a great guy and has a wonderful family. We are looking forward to their visit. jb "hi" to Jimmy for me. I haven't seen him in a few years. -----Original Message----- From: John Vormbaum <john(at)vormbaum.com> To: commander-list(at)matronics.com Sent: Thu, Jul 1, 2010 10:49 pm Subject: Re: Commander-List: FLY-IN Jim, put me on the list. I'm in for sure! Since we're all ME (and high wing) pilots, do you think they'd let us take the spruce goose for a spin? I'm sure that someone in the group has a seaplane rating... Say "hi" to Jimmy for me. I haven't seen him in a few years. Cheers, John PS: Wing Commander Gordon, your presence is required. The last time I saw you was the original Aero Air fly-in a decade ago, I think. Hillsboro is what, 45 minutes from Vegas in a Falcon? sent by my DROID. Please pardon any typos. On Jul 1, 2010 10:39 PM, wrote: HI KIDS...Well, I can finally officially announce that the 2010 Twin Commander fly-in will be held Sept 9-10-11, 2010 at Aero Air in Hillsboro Oregon. This is the site of our first flyin and a great facility. We already have some great speakers in mind and a fly out to the Evergreen museum in Mcminville OR, home of the Spruce Goose!!. We are also planning a dinner on a stern wheeler (TBA) and some other fun and informative stuff!!. Plan to be there. We will be sending information on rooms and car rentals after the 4th. Hope to see you there!! jb. PS Jimmy Rodriguez and family, from San Juan PR, are in rout to visit Sue and I over the 4th, Can't wait to see them. jb " target="_blank">http://www.matronics.com/Navigator?Commander-Listtp://f orums.matronics.com_blank">http://www.matronics.com/contribution t" target=_blank>http://www.matronics.com/Navigator?Commander-Listtp://for ums.matronics.com_blank>http://www.matronics.com/contribution href="http://www.matronics.com/Navigator?Commander-List">http://www.mat ronics.com/Navigator?Commander-Listhref="http://forums.matronics.com">h ttp://forums.matronics.comhref="http://www.matronics.com/contribution"> http://www.matronics.com/c http://www.matronics.com/Navigator?Commander-Listhttp://forums.matronics. comhttp://www.matronics.com/contribution href="http://www.matronics.com/Navigator?Commander-List">http://www.mat ronics.com/Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Subject: Re: Fly-in 2010
Date: Jul 05, 2010
David, This year's Fly-in will be held at Hillsboro, Oregon (near Portland) Septe mber 9-12. More information will be posted on the site later this month. Hope you can join us. -----Original Message----- From: David Fitzgerald <DavidFitzgerald(at)bigpond.com> Sent: Wed, Jun 23, 2010 10:30 pm Subject: Commander-List: Fly-in 2010 Hi list Has anyone got any preliminary news on when and where the fly-in might be this year? David Dr David Fitzgerald BMedSci(Hons) MBBS(Hons) DipAvMed(Otago) ACCAM(Monash) MHeathSci(OccMed) FAFOEM(RACP) Consultant Occupational Physician Occupational, Legal and Aviation Medicine DavidFitzgerald(at)bigpond.com Mob 0438 312973 ======================== =========== -= - The Commander-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Commander-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Date: Jul 10, 2010
Subject: Re: FLY-IN
Fight the good fight Moe! Bill Leff In a message dated 7/4/2010 11:04:23 A.M. Eastern Daylight Time, Bob.Steele(at)kzf.com writes: Moe, Good luck and God speed! We will certainly miss you =93 but your cause is worthy! Regards, Bob ____________________________________ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Jack B. Mi lls Sent: Saturday, July 03, 2010 1:05 AM Subject: Re: Commander-List: FLY-IN J B and Group, Regrettably, I will not be able to attend the fly in this year. Many of you may agree that things have gone terribly wrong in our country in the last 18 months. After a lot of thought I felt that it was time for me to do more than just 'give my support' to someone who will help change the way things are going in our country. Tom Mullins (_www.mullinsforcongress.co m_ (http://www.mullinsforcongress.com/) ), a very conservative and Christian gentlemen from here in Farmington, NM is running for the US House of Representatives, and I am working full time (his only full time volunteer ) in the campaign. I feel a deep sense of dedication to what I am doing. Our opponent votes with Nancy Pelosi 98.5% of the time, receives heaps of Union and PACT (including AOPA PACT) money and will probably outspend us by over five to one. The latest Magellan poll shows 42% for Tom and 43% for the opposition. Tom won the Republican primary by 72% to 28% even though the other Republican spent over twice as much on his campaign. The third congressional district here in New Mexico is larger than the entire state of Pennsylvania, so the amount of travel is almost unbelieva ble. Last week I drove over 2,500 miles in my truck with Tom, and don't expect to be back home for a couple of weeks. Many of our days start at 5:00 AM and end after 10:00 PM. Due to the lay out of the district flying just don't work for us most of the time. Certainly, it would be great to fly up there and be with all of my old friends but there just will not be time. Moe Mills N680RR 680Fp From: _yourtcfg(at)aol.com_ (mailto:yourtcfg(at)aol.com) Sent: Friday, July 02, 2010 8:31 AM Subject: Re: Commander-List: FLY-IN WILL DO. For those new to the list, Jimmy Rodriguez owns 500B, S/N 1 Yep, the very first 500B.. It resides with him in SJ, P.R. I travel the re each year to do the annual inspection for him. He is a great guy and has a wonderful family. We are looking forward to their visit. jb "hi" to Jimmy for me. I haven't seen him in a few years. -----Original Message----- From: John Vormbaum <john(at)vormbaum.com> Sent: Thu, Jul 1, 2010 10:49 pm Subject: Re: Commander-List: FLY-IN Jim, put me on the list. I'm in for sure! Since we're all ME (and high wing) pilots, do you think they'd let us tak e the spruce goose for a spin? I'm sure that someone in the group has a seaplane rating... Say "hi" to Jimmy for me. I haven't seen him in a few years. Cheers, John PS: Wing Commander Gordon, your presence is required. The last time I saw you was the original Aero Air fly-in a decade ago, I think. Hillsboro is what, 45 minutes from Vegas in a Falcon? sent by my DROID. Please pardon any typos. On Jul 1, 2010 10:39 PM, <_yourtcfg(at)aol.com_ (mailto:yourtcfg(at)aol.com) > wrote: HI KIDS...Well, I can finally officially announce that the 2010 Twin Commander fly-in will be held Sept 9-10-11, 2010 at Aero Air in Hillsboro Oregon. This is the site of our first flyin and a great facility. We al ready have some great speakers in mind and a fly out to the Evergreen museum in Mcminville OR, home of the Spruce Goose!!. We are also planning a dinner on a stern wheeler (TBA) and some other fun and informative stuff!!. Plan to be there. We will be sending information on rooms and car rentals after the 4th. Hope to see you there!! jb. PS Jimmy Rodriguez and family, fr om San Juan PR, are in rout to visit Sue and I over the 4th, Can't wait to see them. jb " target="_blank">_http://www.matronics.com/Navigator?Commander-List_ (http://www.matronics.com/Navigator?Commander-List) tp://forums.matronics.com _blank">_http://www.matronics.com/contribution_ (http://www.matronics.com/contribution) t" target=_blank>http://www.matronics.com/Navigator?Commander-List tp://forums.matronics.com _blank>http://www.matronics.com/contribution href="ht tp://www.matronics.com/Navigator?Commander-List">http://www.matronics.com/ Navigator?Commander-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c http://www.matronics.com/Navigator?Commander-List http://forums.matronics.com http://www.matronics.com/contribution ======================== ============ (http://www.matronics.com/Navigator?Commander-List) ======================== ============ ======================== ============ (http://www.matronics.com/contribution) ======================== ============ ________________________________________________________________________________
Date: Jul 10, 2010
Subject: Re: FLY-IN
Man, I can't believe it. I will be in Hillsboro for the Air show two weeks before!. I will not be able to come back to the Fly in. Nuts! Bill Leff In a message dated 7/2/2010 12:39:53 P.M. Eastern Daylight Time, yourtcfg(at)aol.com writes: WILL DO. For those new to the list, Jimmy Rodriguez owns 500B, S/N 1 Yep, the very first 500B.. It resides with him in SJ, P.R. I travel there each year to do the annual inspection for him. He is a great guy and has a wonderful family. We are looking forward to their visit. jb "hi" to Jimmy for me. I haven't seen him in a few years. -----Original Message----- From: John Vormbaum <john(at)vormbaum.com> Sent: Thu, Jul 1, 2010 10:49 pm Subject: Re: Commander-List: FLY-IN Jim, put me on the list. I'm in for sure! Since we're all ME (and high wing) pilots, do you think they'd let us take the spruce goose for a spin? I'm sure that someone in the group has a seaplane rating... Say "hi" to Jimmy for me. I haven't seen him in a few years. Cheers, John PS: Wing Commander Gordon, your presence is required. The last time I saw you was the original Aero Air fly-in a decade ago, I think. Hillsboro is what, 45 minutes from Vegas in a Falcon? sent by my DROID. Please pardon any typos. On Jul 1, 2010 10:39 PM, <_yourtcfg(at)aol.com_ (mailto:yourtcfg(at)aol.com) > wrote: HI KIDS...Well, I can finally officially announce that the 2010 Twin Commander fly-in will be held Sept 9-10-11, 2010 at Aero Air in Hillsboro Oregon. This is the site of our first flyin and a great facility. We already have some great speakers in mind and a fly out to the Evergreen museum in Mcminville OR, home of the Spruce Goose!!. We are also planning a dinner on a stern wheeler (TBA) and some other fun and informative stuff!!. Plan to be there. We will be sending information on rooms and car rentals after the 4th. Hope to see you there!! jb. PS Jimmy Rodriguez and family, from San Juan PR, are in rout to visit Sue and I over the 4th, Can't wait to see them. jb " target="_blank">_http://www.matronics.com/Navigator?Commander-List_ (http://www.matronics.com/Navigator?Commander-List) tp://forums.matronics.com _blank">_http://www.matronics.com/contribution_ (http://www.matronics.com/contribution) =================================== t" target=_blank>http://www.matronics.com/Navigator?Commander-List ==================================== tp://forums.matronics.com ==================================== _blank>http://www.matronics.com/contribution ==================================== (http://www.matronics.com/Navigator?Commander-List) (http://www.matronics.com/contribution) ________________________________________________________________________________
Date: Jul 10, 2010
What is the part number? I may have one. Bill Leff In a message dated 6/30/2010 8:04:06 A.M. Eastern Daylight Time, dfalik(at)sbcglobal.net writes: Hi, I needed a pressure regulator for my 500S 3 years ago and the only on available was an overhauled one on a shelf in Indianna for $5000.00 PLUS a $3000.00 core charge if mine was rebuildable. Apparently there is only one place that rebuilds them and there are some parts in there that are not available any more and have to be "machined".
April 26, 2010 - July 10, 2010
Commander-Archive.digest.vol-dr
