Commander-Archive.digest.vol-fl
July 07, 2015 - October 02, 2015
                       Note that the check list is dated.  Transponder should be
      ON for all movement now that many airports have ASDE-X in operation.
                       This is for a pressurized model, disregard reference to an
      y of that.  I'm providing this help you develop a flow pattern that will wo
      rk in all Commanders and give you some operating ideas on your model.
                       Speeds are for a long-body model.
                       If this check list is found at the bottom of a crater with
       your airplane on top of it, I do not want to hear from your bereaved widow
       nor her attorney; it is only for use by people I have taught how to fly an
      d I'm not in that business at this time.
                       Watch the controversy that is caused by my advocating the
      pulling the aux hydraulic circuit breaker after gear retraction.  This will
       be educational for you and after the debate has flamed out, you can come t
      o your own conclusion.
      Wing Commander Gordon
                        Life is not simple anywhere. Probably less so elsewhere.
       " target="_blank">http://www.matronics.com/Navigator?Commander-List tp:/
      /forums.matronics.com _blank">http://www.matronics.com/contribution
       -= --> http://forums.matron=======
      http://forums.matronics.com
       href="http://www.matronics.com/Navigator?Commander-List" style="color:
       purple; text-decoration: underline;" class="">http://www.matronics.com/N
      avigator?Commander-List purple; text-decoration: underline;" class="">htt
      p://forums.matronics.com style="color: purple; text-decoration: underline
      ;" class="">http://www.matronics.com/contribution
From: "Barry Collman" <barry.collman@air-britain.co.uk>
Subject: AC680F Info
Date: Jul 07, 2015
Hello Keith and a big welcome to CommanderLand Glenn! The winglets are the genuine article, installed under STC SA1381GL on February 22nd 2005. I think they do have the recognition lights. Moe also had the Miller nose installed (STC SA585SW), in January 2002. Glenn, you=99ll have no doubt noticed that the 680F(P) isn=99t shown on the Type Certificate Data Sheet No. 2A4 as one of the specific Models. This is because the 680F(P) is treated as a Model 680F, the pressurisation system being considered an optional extra. You=99ll also no doubt have noticed that the Model shown on the s/n plate is =9C680F=9D. The 680F & 680F(P) shared the same Model unit number sequence in their serial numbers. For instance, there=99s the following examples: 680F-1202-106, a 680F 680F-1204-107, a 680F(P) 680F-1206-108, a 680F Best Regards, Barry Collman From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Keith S. Gordon Sent: 07 July 2015 00:49 Subject: Re: Commander-List: AC680F Info The winglets are aftermarket on all piston Commanders (and most Turbines). Hopefully they're AeroDyne (Commander Aero of Ohio) and not some of knock-offs that I've seen. Sir Barry should be able to tell you what's on (soon to be) your plane. AeroDyne (ala Dick Wartinger) had the winglets for the Aero Commanders tested in the wind tunnel at Wright-Patterson. According to Dick, it was determined they were "as good as could be" aerodynamically and are built by a shop with PMA approval that makes aircraft structural parts. Reports from owners vary -- some say they see a 5 KIAS increase in speed, some say they see nothing. Even Dick Wartinger said the real performance booster are the flap gap seals. Certainly there's a number of owners on the list that can give you their real world experience. They should not affect V speeds at all; no recertification flight testing was done to change the flight manual as far as I know. Bill Leff may have more insight, if he's listening in. By the way, do the winglets have reocognition lights? Those alone are worth the install price. in my opinion. Wing Commander Gordon -----Original Message----- From: Glenn Hancock <glennh(at)gmail.com> Sent: Mon, Jul 6, 2015 4:35 pm Subject: Re: Commander-List: AC680F Info Question: The 680Fp that I'm looking at has winglets. Did those come from the factory with those or aftermarket and if aftermarket, how do they effect the flying characteristics compared to the number in the manual? Thanks, Glenn On 7/6/15 3:55 PM, John Vormbaum wrote: I had a hydraulic failure in my 500B; a hard line in the wing root fractured. It would have been a flawless landing, but I was seduced by fluctuating hyd. pressure AFTER I put the gear down, and before the nose wheel locked. I thought I had enough pressure to cycle the gear.not the case. On the bright side, landing at Stockton, I held the nose off until I lost elevator authority, and veeeeerrry gently set it down on the nose wheel, which rolled for a bit and then collapsed while still going 5 knots or so. Only consequence was a damaged gear door and one broken bell crank. Directional control was never in doubt, and with both engines running, asymmetric thrust made it easy. I think Morris had me back in the air in a day or two. The two lessons I learned: 1) Once you put the gear handle down, after a hyd. failure, LEAVE IT THERE. This was actually beaten into me by Morris and others, but the beatings evidently didn=99t take. 2) A hydraulic failure in a Commander, even if slightly mismanaged, isn=99t a crisis unless you have to do some kind of high performance landing. With enough runway, it matters not. /John On Jul 6, 2015, at 12:27 PM, Nick Martin < nick(at)container.com> wrote: Wing Commander Gordon, We fly a 690A . After losing the Hydraulic accumulator in flight we pulled the breaker on the aux hydraulic and made a safe landing ..Since then our practice is to pull the aux hydraulic breaker before takeoff..Is there a reason to leave the breaker in before takeoff and pull later ? ( possibly steering and breaks )..thanks,Nick N674nm From: <mailto:owner-commander-list-server(at)matronics.com> owner-commander-list-server(at)matronics.com [ mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Keith S. Gordon Sent: Monday, July 06, 2015 12:06 PM Subject: Re: Commander-List: AC680F Info Bill, Glad your outcome was OK. Good bit of piloting there. Tom, your incident was heart breaking, especially since all of the work your put into your MR RPM. I've had 3 total hydraulic failures, (two in a 500A Colemill and one 680FLP) all turned out OK ... but I know the trick. To give credit where credit is due, Morris Kernick put the bee in my bonnet about disabling the electric aux hydraulic pump. He put it in very clear terms while I watched a Commander undergoing an annual at this hangar in Hayward 25+ years ago. I thought about what he told me and then looked at it through the perspective of Ted Smith's next design, the AeroStar. The 'Star did have a breaker type switch for the electric aux pump specifically to disable it it cruise. I think it should be a retrofit on all Commanders with electric aux hydraulic pumps. Wing Commander Gordon -----Original Message----- From: Tom Fisher < <mailto:tfisher(at)commandergroup.bc.ca> tfisher(at)commandergroup.bc.ca> commander-list(at)matronics.com> Sent: Mon, Jul 6, 2015 10:28 am Subject: Re: Commander-List: AC680F Info I wasn't so lucky with my 680FLP (Mr.RPM), I had zero pressure and with no flaps, brakes or steering landing was fine but near the end of the runway it rolled off the side of the runway and traversed a ditch which finished the plane for me. Tom On Sun, Jul 5, 2015 at 9:14 PM, William Boelte < n55bz(at)cox.net> wrote: Keith, About four years ago I experienced a complete hydraulic failure in the only remaining Grand Renaissance Shrike on the way to Fort Worth. The hydraulic pressure switch developed a leak so that the electric hydraulic pump would have eventually run dry. I noticed the hydraulic pressure fluctuate between about zero and 480 psi. I immediately pulled the Hyd. Pump CB and thought "Keith said to pull this after take off". I had done it regularly with my own Commander but had slipped into complacency. Since I did not know how much hydraulic fluid was left, I elected to make a no flap landing and save what little may be there for one last desperate brake attempt. As it turned out I was down to walking speed by the 6,000 ft turnoff using just aerodynamic braking. Incidentally the nose gear did not extend on its own on hydraulic pressure loss. It remained up and locked until I lowered the gear. I had to slow quite a bit and do two abrupt pull ups to get it down and locked. The landing and roll out were uneventful. Had I used your procedure, I would have lowered the flaps and had brakes and nose wheel steering available. Thank God for the 8,002' X 200' runway and that huge AeroCommander tail. I was able to hold the nose wheel up until about 30 kts. and the rudder made directional control easy. Kindest regards, Bill On Jul 5, 2015, at 6:09 PM, Keith S. Gordon < cloudcraft(at)aol.com> wrote: Glenn, This will amuse you -- probably force a few hundred questions as well. Note that the check list is dated. Transponder should be ON for all movement now that many airports have ASDE-X in operation. This is for a pressurized model, disregard reference to any of that. I'm providing this help you develop a flow pattern that will work in all Commanders and give you some operating ideas on your model. Speeds are for a long-body model. If this check list is found at the bottom of a crater with your airplane on top of it, I do not want to hear from your bereaved widow nor her attorney; it is only for use by people I have taught how to fly and I'm not in that business at this time. Watch the controversy that is caused by my advocating the pulling the aux hydraulic circuit breaker after gear retraction. This will be educational for you and after the debate has flamed out, you can come to your own conclusion. Wing Commander Gordon Life is not simple anywhere. Probably less so elsewhere. " target="_blank"> <http://www.matronics.com/Navigator?Commander-List> http://www.matronics.com/Navigator?Commander-List tp://forums.matronics.com _blank"> <http://www.matronics.com/contribution> http://www.matronics.com/contribution -= --> <http://forums.matronics.com/> http://forums.matron======= <http://forums.matronics.com/> <http://forums.matronics.com/> http://www.matronics.com/Navigator?Commander-List <http://forums.matronics.com/> http://forums.matronics.com <http://www.matronics.com/contribution> http://www.matronics.com/contribution href= "http://www.matronics.com/Navigator?Commander-List" style="color: purple; text-decoration: underline;" class="">http://www.matronics.com/Navigator?Commander-List purple; text-decoration: underline;" class="">http://forums.matronics.com style="color: purple; text-decoration: underline;" class="">http://www.matronics.com/contribution -= --> http://forums.matron======= <http://forums.matronics.com> <http://forums.matronics.com> <http://forums.matronics.com> <http://forums.matronics.com> Forum - Navigator to browse List Un/Subscription, Browse, Chat, FAQ, http://www.matronics.com/Navigator?Commander-List ________________________________________________________________________________
Date: Jul 09, 2015
Subject: Commander Spotting KHND
CiAgICAKVGhpcyBpcyBmb3IgU2lyIEJhcnJ5IChtb3N0bHkpLgpUaGlzIEFDNTAwIHdhaGVkIHVw IG9uIHRoZSBzaG9yZSBvZiBIZW5kZXJzb24gRXhlY3V0aXZlIEFpcnBvcnQgLyBMYXMgVmVnYXMs IE5ldmFkYS4KMyBibGFkZSBwcm9wcyEgwqDCoMKgRXhjZXB0IHRoZXkncmUgZmVhdGhlcmVkIG9u IHRoZSByaWdodCBzaWRlLiDCoFRoYXQgY2FuJ3QgYmUgZm9yIGEgZ29vZCByZWFzb24gY2FuIGl0 PwoKSy5TLkdvcmRvblNlbnQgb24gdGhlIEZsecKg8J+MkA= ________________________________________________________________________________
Date: Jul 09, 2015
Date: Jul 10, 2015
Hi Keith! Grateful thanks, especially for the s/n plate shot. Very much appreciated. I guess others might comment re the feathered prop? Very Best Regards, Barry From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of K.S.Gordon Sent: 10 July 2015 00:58 Subject: Commander-List: Commander Spotting KHND This is for Sir Barry (mostly). This AC500 wahed up on the shore of Henderson Executive Airport / Las Vegas, Nevada. 3 blade props! Except they're feathered on the right side. That can't be for a good reason can it? K.S.Gordon Sent on the Fly =F0=9F=8C=90 ________________________________________________________________________________
Date: Jul 14, 2015
Subject: New Purchase
Well, I wanted to let everyone know that I'm now the official owner of 680RR. We completed the pre-buy over the weekend with Morris and my new mechanic in Athens TN and found a few problems that need to be addressed. I was hoping to have it flying in time for the September Flyin but not sure I will. The hydraulic system failed when landing in Oklahoma on Sunday and our ferry permit ended on Sunday so had to leave it there while we get another permit. We found some extremely nice people that put it in their hanger and cooked us ribs and gave us beer for the night. The problem was found in the left rear wing nacelle. Morris found us the part and we should have it tomorrow. Hoping to get it going this weekend. Other issues we found are the props are not cycling very well at all and need to be rebuilt and the tops of the nacelles have a good number of patches on them and need to be torn off and redone. Hoping we don't find more problems once we take it apart. The left engine is leaking a ton of oil but it appears to mostly be coming from all the hoses. Its also leaking fuel from both engines but appears to be coming from the intake manifold rubber connections. The right side of the fuel tanks are leaking and we're not really sure where it's coming from. The skydrol lines are leaking a little in the connections but looks like we just need to replace the o-rings in the connection lines. The pressurization system is working but not very well and according to Morris is most likely the door and window seals having the wrong seals installed on them. There is also burnt oil on the #3 cylinder that we've cleaned and going to keep an eye on so time will tell on that one. I'm also going to have to replace the GPS and screen in the plane with something I can fly IFR with because it's all VFR only equipment and is really old. I'm extremely excited about my life long dream airplane being this close to my home base, but at the moment it appears I'm 4 or 5 months out before I'll really have it. If it was in annual I would go ahead and get signed off in it, but since we have to tear it down for that, it makes sense to try to do it all together. -- --glenn hancock You can't win an argument with an ignorant person. They'll just drag you down to their level and beat you with experience. ________________________________________________________________________________
Subject: Re: New Purchase
Date: Jul 14, 2015
Hi Glenn , I own a 680 commander and love it . I also want to tell you that t he Commander group is a fine bunch of people to be associated with . Morris has been a great resource for me , my go to guy ! I think you will find tha t all of the guys will rally around you and give you lots of support when ne eded. . I live in Brentwood , Tn . A suburb of Nashville. . If I can ever he lp in any way , just let me know . I am not that far away from Athens. .Go od luck with your Commander . Gil Walker 615-310-5030 cell Sent from my iPhone > On Jul 14, 2015, at 6:51 PM, Glenn Hancock wrote: > > Well, I wanted to let everyone know that I'm now the official owner of 680 RR. We completed the pre-buy over the weekend with Morris and my new mechan ic in Athens TN and found a few problems that need to be addressed. I was h oping to have it flying in time for the September Flyin but not sure I will. The hydraulic system failed when landing in Oklahoma on Sunday and our fer ry permit ended on Sunday so had to leave it there while we get another perm it. > > We found some extremely nice people that put it in their hanger and cooked us ribs and gave us beer for the night. The problem was found in the left r ear wing nacelle. Morris found us the part and we should have it tomorrow. Hoping to get it going this weekend. > > Other issues we found are the props are not cycling very well at all and n eed to be rebuilt and the tops of the nacelles have a good number of patches on them and need to be torn off and redone. Hoping we don't find more prob lems once we take it apart. > > The left engine is leaking a ton of oil but it appears to mostly be coming from all the hoses. Its also leaking fuel from both engines but appears to be coming from the intake manifold rubber connections. > > The right side of the fuel tanks are leaking and we're not really sure whe re it's coming from. > > The skydrol lines are leaking a little in the connections but looks like w e just need to replace the o-rings in the connection lines. > > The pressurization system is working but not very well and according to Mo rris is most likely the door and window seals having the wrong seals install ed on them. > > There is also burnt oil on the #3 cylinder that we've cleaned and going to keep an eye on so time will tell on that one. > > I'm also going to have to replace the GPS and screen in the plane with som ething I can fly IFR with because it's all VFR only equipment and is really o ld. > > I'm extremely excited about my life long dream airplane being this close t o my home base, but at the moment it appears I'm 4 or 5 months out before I' ll really have it. If it was in annual I would go ahead and get signed off i n it, but since we have to tear it down for that, it makes sense to try to d o it all together. > > -- > --glenn hancock > > You can't win an argument with an ignorant person. They'll just drag you d own to their level and beat you with experience. > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Jul 15, 2015
G'day Glenn, Welcome to Commanderland and congratulations on your purchase of 680RR - a lot of effort sustained to get it to the level of airworthiness that you have now - your work wilL make it even better... Enjoy Cheers Russell AC560E On Wednesday, July 15, 2015, Glenn Hancock wrote: > Well, I wanted to let everyone know that I'm now the official owner of > 680RR. We completed the pre-buy over the weekend with Morris and my new > mechanic in Athens TN and found a few problems that need to be addressed. > I was hoping to have it flying in time for the September Flyin but not sure > I will. The hydraulic system failed when landing in Oklahoma on Sunday and > our ferry permit ended on Sunday so had to leave it there while we get > another permit. > > We found some extremely nice people that put it in their hanger and cooked > us ribs and gave us beer for the night. The problem was found in the left > rear wing nacelle. Morris found us the part and we should have it > tomorrow. Hoping to get it going this weekend. > > Other issues we found are the props are not cycling very well at all and > need to be rebuilt and the tops of the nacelles have a good number of > patches on them and need to be torn off and redone. Hoping we don't find > more problems once we take it apart. > > The left engine is leaking a ton of oil but it appears to mostly be coming > from all the hoses. Its also leaking fuel from both engines but appears to > be coming from the intake manifold rubber connections. > > The right side of the fuel tanks are leaking and we're not really sure > where it's coming from. > > The skydrol lines are leaking a little in the connections but looks like > we just need to replace the o-rings in the connection lines. > > The pressurization system is working but not very well and according to > Morris is most likely the door and window seals having the wrong seals > installed on them. > > There is also burnt oil on the #3 cylinder that we've cleaned and going to > keep an eye on so time will tell on that one. > > I'm also going to have to replace the GPS and screen in the plane with > something I can fly IFR with because it's all VFR only equipment and is > really old. > > I'm extremely excited about my life long dream airplane being this close > to my home base, but at the moment it appears I'm 4 or 5 months out before > I'll really have it. If it was in annual I would go ahead and get signed > off in it, but since we have to tear it down for that, it makes sense to > try to do it all together. > > -- > --glenn hancock > > You can't win an argument with an ignorant person. They'll just drag you > down to their level and beat you with experience. > > * > > > * > > ________________________________________________________________________________
Date: Jul 15, 2015
Glenn Good to hear N680RR found a good owner who will take good care of her. Co ngratulations! Bob Steele ________________________________ From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-lis t-server(at)matronics.com] On Behalf Of Glenn Hancock Sent: Tuesday, July 14, 2015 7:52 PM Subject: Commander-List: New Purchase Well, I wanted to let everyone know that I'm now the official owner of 680R R. We completed the pre-buy over the weekend with Morris and my new mechan ic in Athens TN and found a few problems that need to be addressed. I was hoping to have it flying in time for the September Flyin but not sure I wil l. The hydraulic system failed when landing in Oklahoma on Sunday and our ferry permit ended on Sunday so had to leave it there while we get another permit. We found some extremely nice people that put it in their hanger and cooked us ribs and gave us beer for the night. The problem was found in the left rear wing nacelle. Morris found us the part and we should have it tomorrow . Hoping to get it going this weekend. Other issues we found are the props are not cycling very well at all and ne ed to be rebuilt and the tops of the nacelles have a good number of patches on them and need to be torn off and redone. Hoping we don't find more pro blems once we take it apart. The left engine is leaking a ton of oil but it appears to mostly be coming from all the hoses. Its also leaking fuel from both engines but appears to be coming from the intake manifold rubber connections. The right side of the fuel tanks are leaking and we're not really sure wher e it's coming from. The skydrol lines are leaking a little in the connections but looks like we just need to replace the o-rings in the connection lines. The pressurization system is working but not very well and according to Mor ris is most likely the door and window seals having the wrong seals install ed on them. There is also burnt oil on the #3 cylinder that we've cleaned and going to keep an eye on so time will tell on that one. I'm also going to have to replace the GPS and screen in the plane with some thing I can fly IFR with because it's all VFR only equipment and is really old. I'm extremely excited about my life long dream airplane being this close to my home base, but at the moment it appears I'm 4 or 5 months out before I' ll really have it. If it was in annual I would go ahead and get signed off in it, but since we have to tear it down for that, it makes sense to try t o do it all together. -- --glenn hancock You can't win an argument with an ignorant person. They'll just drag you d own to their level and beat you with experience. ________________________________________________________________________________
From: John Dendekker <john(at)carpenteravionics.com>
Date: Jul 15, 2015
Q29uZ3JhdHVsYXRpb25zIG9uIHlvdXIgbmV3IHB1cmNoYXNlIQ0KDQpCZXN0IFJlZ2FyZHMsDQpK b2huIERlbkRla2tlcg0Kd3d3LmNhcnBlbnRlcmF2aW9uaWNzLmNvbTxodHRwOi8vd3d3LmNhcnBl bnRlcmF2aW9uaWNzLmNvbS8+DQo4MDAuMzAwLjAzNTIgVG9sbCBGcmVlDQo2MTUuMzU1Ljk5NzAg b2ZmaWNlDQoNCkltYWdpbmUgdGhlIFBvc3NpYmlsaXRpZXMhDQoNCk5PVElDRTogVGhpcyBlbGVj dHJvbmljIHRyYW5zbWlzc2lvbiAoaW5jbHVkaW5nIGFueSByZWZlcmVuY2VkIG9yIGF0dGFjaGVk IG1hdGVyaWFscykgaXMgY292ZXJlZCBieSB0aGUgRWxlY3Ryb25pYyBDb21tdW5pY2F0aW9ucyBQ cml2YWN5IEFjdCwgMTggVS5TLkMuIFNlYy4gMjUxMC0yNTIxLCBhbmQgaXMgUFJJVklMRUdFRCwg V09SSyBQUk9EVUNULCBQUk9QUklFVEFSWSBhbmQvb3IgQ09ORklERU5USUFMLiBJdCBpcyBub3Qg aW50ZW5kZWQgZm9yIHRyYW5zbWlzc2lvbiB0bywgb3IgcmVjZWlwdCBieSwgYW55IHVuYXV0aG9y aXplZCBwZXJzb24uIElmIHlvdSBoYXZlIHJlY2VpdmVkIHRoaXMgdHJhbnNtaXNzaW9uIGluIGVy cm9yIHlvdSBhcmUgUFJPSElCSVRFRCBmcm9tIGRpc2Nsb3NpbmcsIGRpc3NlbWluYXRpbmcsIHJl cHJvZHVjaW5nLCB1c2luZyBvciByZWx5aW5nIHVwb24gaXQuIFBsZWFzZSBpbW1lZGlhdGVseSBk ZWxldGUgaXQgZnJvbSB5b3VyIHN5c3RlbSB3aXRob3V0IGNvcHlpbmcgYW5kIG5vdGlmeSB0aGUg c2VuZGVyIGJ5IHJldHVybiBlLW1haWwgb2YgdGhlIGVycm9uZW91cyByZWNlaXB0LiBUaGFuayB5 b3UuDQoNCkZyb206IG93bmVyLWNvbW1hbmRlci1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tIFtt YWlsdG86b3duZXItY29tbWFuZGVyLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb21dIE9uIEJlaGFs ZiBPZiBHbGVubiBIYW5jb2NrDQpTZW50OiBUdWVzZGF5LCBKdWx5IDE0LCAyMDE1IDY6NTIgUE0N ClRvOiBjb21tYW5kZXItbGlzdEBtYXRyb25pY3MuY29tDQpTdWJqZWN0OiBDb21tYW5kZXItTGlz dDogTmV3IFB1cmNoYXNlDQoNCldlbGwsIEkgd2FudGVkIHRvIGxldCBldmVyeW9uZSBrbm93IHRo YXQgSSdtIG5vdyB0aGUgb2ZmaWNpYWwgb3duZXIgb2YgNjgwUlIuICBXZSBjb21wbGV0ZWQgdGhl IHByZS1idXkgb3ZlciB0aGUgd2Vla2VuZCB3aXRoIE1vcnJpcyBhbmQgbXkgbmV3IG1lY2hhbmlj IGluIEF0aGVucyBUTiBhbmQgZm91bmQgYSBmZXcgcHJvYmxlbXMgdGhhdCBuZWVkIHRvIGJlIGFk ZHJlc3NlZC4gIEkgd2FzIGhvcGluZyB0byBoYXZlIGl0IGZseWluZyBpbiB0aW1lIGZvciB0aGUg U2VwdGVtYmVyIEZseWluIGJ1dCBub3Qgc3VyZSBJIHdpbGwuICBUaGUgaHlkcmF1bGljIHN5c3Rl bSBmYWlsZWQgd2hlbiBsYW5kaW5nIGluIE9rbGFob21hIG9uIFN1bmRheSBhbmQgb3VyIGZlcnJ5 IHBlcm1pdCBlbmRlZCBvbiBTdW5kYXkgc28gaGFkIHRvIGxlYXZlIGl0IHRoZXJlIHdoaWxlIHdl IGdldCBhbm90aGVyIHBlcm1pdC4NCg0KV2UgZm91bmQgc29tZSBleHRyZW1lbHkgbmljZSBwZW9w bGUgdGhhdCBwdXQgaXQgaW4gdGhlaXIgaGFuZ2VyIGFuZCBjb29rZWQgdXMgcmlicyBhbmQgZ2F2 ZSB1cyBiZWVyIGZvciB0aGUgbmlnaHQuICBUaGUgcHJvYmxlbSB3YXMgZm91bmQgaW4gdGhlIGxl ZnQgcmVhciB3aW5nIG5hY2VsbGUuICBNb3JyaXMgZm91bmQgdXMgdGhlIHBhcnQgYW5kIHdlIHNo b3VsZCBoYXZlIGl0IHRvbW9ycm93LiAgSG9waW5nIHRvIGdldCBpdCBnb2luZyB0aGlzIHdlZWtl bmQuDQoNCk90aGVyIGlzc3VlcyB3ZSBmb3VuZCBhcmUgdGhlIHByb3BzIGFyZSBub3QgY3ljbGlu ZyB2ZXJ5IHdlbGwgYXQgYWxsIGFuZCBuZWVkIHRvIGJlIHJlYnVpbHQgYW5kIHRoZSB0b3BzIG9m IHRoZSBuYWNlbGxlcyBoYXZlIGEgZ29vZCBudW1iZXIgb2YgcGF0Y2hlcyBvbiB0aGVtIGFuZCBu ZWVkIHRvIGJlIHRvcm4gb2ZmIGFuZCByZWRvbmUuICBIb3Bpbmcgd2UgZG9uJ3QgZmluZCBtb3Jl IHByb2JsZW1zIG9uY2Ugd2UgdGFrZSBpdCBhcGFydC4NCg0KVGhlIGxlZnQgZW5naW5lIGlzIGxl YWtpbmcgYSB0b24gb2Ygb2lsIGJ1dCBpdCBhcHBlYXJzIHRvIG1vc3RseSBiZSBjb21pbmcgZnJv bSBhbGwgdGhlIGhvc2VzLiAgSXRzIGFsc28gbGVha2luZyBmdWVsIGZyb20gYm90aCBlbmdpbmVz IGJ1dCBhcHBlYXJzIHRvIGJlIGNvbWluZyBmcm9tIHRoZSBpbnRha2UgbWFuaWZvbGQgcnViYmVy IGNvbm5lY3Rpb25zLg0KDQpUaGUgcmlnaHQgc2lkZSBvZiB0aGUgZnVlbCB0YW5rcyBhcmUgbGVh a2luZyBhbmQgd2UncmUgbm90IHJlYWxseSBzdXJlIHdoZXJlIGl0J3MgY29taW5nIGZyb20uDQoN ClRoZSBza3lkcm9sIGxpbmVzIGFyZSBsZWFraW5nIGEgbGl0dGxlIGluIHRoZSBjb25uZWN0aW9u cyBidXQgbG9va3MgbGlrZSB3ZSBqdXN0IG5lZWQgdG8gcmVwbGFjZSB0aGUgby1yaW5ncyBpbiB0 aGUgY29ubmVjdGlvbiBsaW5lcy4NCg0KVGhlIHByZXNzdXJpemF0aW9uIHN5c3RlbSBpcyB3b3Jr aW5nIGJ1dCBub3QgdmVyeSB3ZWxsIGFuZCBhY2NvcmRpbmcgdG8gTW9ycmlzIGlzIG1vc3QgbGlr ZWx5IHRoZSBkb29yIGFuZCB3aW5kb3cgc2VhbHMgaGF2aW5nIHRoZSB3cm9uZyBzZWFscyBpbnN0 YWxsZWQgb24gdGhlbS4NCg0KVGhlcmUgaXMgYWxzbyBidXJudCBvaWwgb24gdGhlICMzIGN5bGlu ZGVyIHRoYXQgd2UndmUgY2xlYW5lZCBhbmQgZ29pbmcgdG8ga2VlcCBhbiBleWUgb24gc28gdGlt ZSB3aWxsIHRlbGwgb24gdGhhdCBvbmUuDQoNCkknbSBhbHNvIGdvaW5nIHRvIGhhdmUgdG8gcmVw bGFjZSB0aGUgR1BTIGFuZCBzY3JlZW4gaW4gdGhlIHBsYW5lIHdpdGggc29tZXRoaW5nIEkgY2Fu IGZseSBJRlIgd2l0aCBiZWNhdXNlIGl0J3MgYWxsIFZGUiBvbmx5IGVxdWlwbWVudCBhbmQgaXMg cmVhbGx5IG9sZC4NCg0KSSdtIGV4dHJlbWVseSBleGNpdGVkIGFib3V0IG15IGxpZmUgbG9uZyBk cmVhbSBhaXJwbGFuZSBiZWluZyB0aGlzIGNsb3NlIHRvIG15IGhvbWUgYmFzZSwgYnV0IGF0IHRo ZSBtb21lbnQgaXQgYXBwZWFycyBJJ20gNCBvciA1IG1vbnRocyBvdXQgYmVmb3JlIEknbGwgcmVh bGx5IGhhdmUgaXQuICBJZiBpdCB3YXMgaW4gYW5udWFsIEkgd291bGQgZ28gYWhlYWQgYW5kIGdl dCBzaWduZWQgb2ZmIGluIGl0LCBidXQgc2luY2Ugd2UgaGF2ZSB0byB0ZWFyIGl0IGRvd24gZm9y IHRoYXQsIGl0IG1ha2VzIHNlbnNlIHRvIHRyeSB0byBkbyBpdCBhbGwgdG9nZXRoZXIuDQoNCi0t DQotLWdsZW5uIGhhbmNvY2sNCg0KWW91IGNhbid0IHdpbiBhbiBhcmd1bWVudCB3aXRoIGFuIGln bm9yYW50IHBlcnNvbi4gIFRoZXknbGwganVzdCBkcmFnIHlvdSBkb3duIHRvIHRoZWlyIGxldmVs IGFuZCBiZWF0IHlvdSB3aXRoIGV4cGVyaWVuY2UuDQoNCg0KDQoNCg0KDQpfLT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KDQpfLT0g ICAgICAgICAgLSBUaGUgQ29tbWFuZGVyLUxpc3QgRW1haWwgRm9ydW0gLQ0KDQpfLT0gVXNlIHRo ZSBNYXRyb25pY3MgTGlzdCBGZWF0dXJlcyBOYXZpZ2F0b3IgdG8gYnJvd3NlDQoNCl8tPSB0aGUg bWFueSBMaXN0IHV0aWxpdGllcyBzdWNoIGFzIExpc3QgVW4vU3Vic2NyaXB0aW9uLA0KDQpfLT0g QXJjaGl2ZSBTZWFyY2ggJiBEb3dubG9hZCwgNy1EYXkgQnJvd3NlLCBDaGF0LCBGQVEsDQoNCl8t PSBQaG90b3NoYXJlLCBhbmQgbXVjaCBtdWNoIG1vcmU6DQoNCl8tPQ0KDQpfLT0gICAtLT4gaHR0 cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9Db21tYW5kZXItTGlzdA0KDQpfLT0NCg0K Xy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT0NCg0KXy09ICAgICAgICAgICAgICAgLSBNQVRST05JQ1MgV0VCIEZPUlVNUyAtDQoNCl8t PSBTYW1lIGdyZWF0IGNvbnRlbnQgYWxzbyBhdmFpbGFibGUgdmlhIHRoZSBXZWIgRm9ydW1zIQ0K DQpfLT0NCg0KXy09ICAgLS0+IGh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQ0KDQpfLT0NCg0K Xy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT0NCg0KXy09ICAgICAgICAgICAgIC0gTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGUgLQ0K DQpfLT0gIFRoYW5rIHlvdSBmb3IgeW91ciBnZW5lcm91cyBzdXBwb3J0IQ0KDQpfLT0gICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAtTWF0dCBEcmFsbGUsIExpc3QgQWRtaW4uDQoNCl8tPSAg IC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uDQoNCl8tPT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQoNCg0K ________________________________________________________________________________
Subject: Re: Commander-List Digest: 0 Msgs - 02/03/15
Date: Jul 17, 2015
Dan, Presumably "arrivals day" will therefore be on the Wednesday, Sept 23rd? Or do the dates Sept 24-27 mean that arrivals day is the Thursday (24th)? Best Regards, Barry -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Dan Sent: 05 February 2015 04:11 Subject: Commander-List: Re: Commander-List Digest: 0 Msgs - 02/03/15 2015 TCFG FLY-IN, will be Sept 24-27 this year in Colorado Springs, CO. (KCOS) Yes that is a repeat of location, it is also a week later than usual. It has been moved a week later to take advantage of one of the four AOPA FLY-IN's that is being held at KCOS on Sept 26th. For info on AOPA's fly-in go to aopa.com/fly-ins. More info will be forth coming. I plan to make hotel arrangements soon, as I believe hotels will go fast. It is my understanding there will be a couple thousand people in attendance. Metzger said that since I screwed up last year I had to do it again, so bear with me. Any questions please email me. Dan Farmer Sent from my iPad > On Feb 4, 2015, at 12:59 AM, Commander-List Digest Server wrote: > > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete Commander-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the Commander-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&C hapter 15-02-03&Archive=Commander > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Ch apter 15-02-03&Archive=Commander > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > Commander-List Digest Archive > --- > Total Messages Posted Tue 02/03/15: 0 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > > > > > > > > > > ________________________________________________________________________________
Subject: Re: Commander-List Digest: 1 Msgs - 07/17/15
Date: Jul 18, 2015
SIR BARRY: arrival is the 24th, Thursday Sent from my iPad > On Jul 18, 2015, at 12:59 AM, Commander-List Digest Server wrote: > > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete Commander-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the Commander-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 15-07-17&Archive=Commander > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 15-07-17&Archive=Commander > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > Commander-List Digest Archive > --- > Total Messages Posted Fri 07/17/15: 1 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 06:15 AM - Re: Re: Commander-List Digest: 0 Msgs - 02/03/15 (Barry Collman) > > > > ________________________________ Message 1 _____________________________________ > > > From: "Barry Collman" <barry.collman@air-britain.co.uk> > Subject: RE: Commander-List: Re: Commander-List Digest: 0 Msgs - 02/03/15 > > > Dan, > > Presumably "arrivals day" will therefore be on the Wednesday, Sept > 23rd? > Or do the dates Sept 24-27 mean that arrivals day is the Thursday > (24th)? > > Best Regards, > Barry > > -----Original Message----- > From: owner-commander-list-server(at)matronics.com > [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Dan > Sent: 05 February 2015 04:11 > Subject: Commander-List: Re: Commander-List Digest: 0 Msgs - 02/03/15 > > > 2015 TCFG FLY-IN, will be Sept 24-27 this year in Colorado Springs, > CO. (KCOS) Yes that is a repeat of location, it is also a week later > than usual. It has been moved a week later to take advantage of one > of the four AOPA FLY-IN's that is being held at KCOS on Sept 26th. > For info on AOPA's fly-in go to aopa.com/fly-ins. > > More info will be forth coming. I plan to make hotel arrangements > soon, as I believe hotels will go fast. It is my understanding there > will be a couple thousand people in attendance. Metzger said that > since I screwed up last year I had to do it again, so bear with me. > Any questions please email me. > Dan Farmer > > > Sent from my iPad > >>> On Feb 4, 2015, at 12:59 AM, Commander-List Digest Server >> wrote: >> >> * >> >> ================================================ >> Online Versions of Today's List Digest Archive >> ================================================ >> >> Today's complete Commander-List Digest can also be found in either > of the >> two Web Links listed below. The .html file includes the Digest > formatted >> in HTML for viewing with a web browser and features Hyperlinked > Indexes >> and Message Navigation. The .txt file includes the plain ASCII > version >> of the Commander-List Digest and can be viewed with a generic text > editor >> such as Notepad or with a web browser. >> >> HTML Version: > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&C > hapter 15-02-03&Archive=Commander >> >> Text Version: > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Ch > apter 15-02-03&Archive=Commander >> >> >> ============================================== >> EMail Version of Today's List Digest Archive >> ============================================== >> >> >> ---------------------------------------------------------- >> Commander-List Digest Archive >> --- >> Total Messages Posted Tue 02/03/15: 0 >> ---------------------------------------------------------- >> >> >> Today's Message Index: >> ---------------------- > > > > > > > > > ________________________________________________________________________________
Date: Jul 18, 2015
Hi Dan, OK - I hope to schedule to arrive at COS on the Wednesday, probably circa 21:45 if I can get the same flights as last year. Best Regards, Barry -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Dan Sent: 18 July 2015 08:32 Subject: Commander-List: Re: Commander-List Digest: 1 Msgs - 07/17/15 SIR BARRY: arrival is the 24th, Thursday Sent from my iPad > On Jul 18, 2015, at 12:59 AM, Commander-List Digest Server wrote: > > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete Commander-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the Commander-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&C hapter 15-07-17&Archive=Commander > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Ch apter 15-07-17&Archive=Commander > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > Commander-List Digest Archive > --- > Total Messages Posted Fri 07/17/15: 1 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 06:15 AM - Re: Re: Commander-List Digest: 0 Msgs - 02/03/15 (Barry Collman) > > > > ________________________________ Message 1 _____________________________________ > > > From: "Barry Collman" <barry.collman@air-britain.co.uk> > Subject: RE: Commander-List: Re: Commander-List Digest: 0 Msgs - 02/03/15 > > > Dan, > > Presumably "arrivals day" will therefore be on the Wednesday, Sept > 23rd? > Or do the dates Sept 24-27 mean that arrivals day is the Thursday > (24th)? > > Best Regards, > Barry > > -----Original Message----- > From: owner-commander-list-server(at)matronics.com > [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Dan > Sent: 05 February 2015 04:11 > Subject: Commander-List: Re: Commander-List Digest: 0 Msgs - 02/03/15 > > > 2015 TCFG FLY-IN, will be Sept 24-27 this year in Colorado Springs, > CO. (KCOS) Yes that is a repeat of location, it is also a week later > than usual. It has been moved a week later to take advantage of one > of the four AOPA FLY-IN's that is being held at KCOS on Sept 26th. > For info on AOPA's fly-in go to aopa.com/fly-ins. > > More info will be forth coming. I plan to make hotel arrangements > soon, as I believe hotels will go fast. It is my understanding there > will be a couple thousand people in attendance. Metzger said that > since I screwed up last year I had to do it again, so bear with me. > Any questions please email me. > Dan Farmer > > > Sent from my iPad > >>> On Feb 4, 2015, at 12:59 AM, Commander-List Digest Server >> wrote: >> >> * >> >> ================================================ >> Online Versions of Today's List Digest Archive >> ================================================ >> >> Today's complete Commander-List Digest can also be found in either > of the >> two Web Links listed below. The .html file includes the Digest > formatted >> in HTML for viewing with a web browser and features Hyperlinked > Indexes >> and Message Navigation. The .txt file includes the plain ASCII > version >> of the Commander-List Digest and can be viewed with a generic text > editor >> such as Notepad or with a web browser. >> >> HTML Version: > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&C > hapter 15-02-03&Archive=Commander >> >> Text Version: > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Ch > apter 15-02-03&Archive=Commander >> >> >> ============================================== >> EMail Version of Today's List Digest Archive >> ============================================== >> >> >> ---------------------------------------------------------- >> Commander-List Digest Archive >> --- >> Total Messages Posted Tue 02/03/15: 0 >> ---------------------------------------------------------- >> >> >> Today's Message Index: >> ---------------------- > > > > > > > > > ________________________________________________________________________________
From: "Randy Dettmer, AIA" <rcdettmer(at)charter.net>
Subject: Commander Parts
Date: Jul 20, 2015
Hello Commander fans, We are trying to locate some lower fuselage skin panels for my 680F. Anybody know of available parts or a salvage plane somewhere..?? Models 500A & B, 560, or 680F will work. Thanks much. Randy Dettmer, AIA, NCARB logoRED-126x38@72dpi Dettmer Architecture 663 Hill Street San Luis Obispo, CA 93405 805 541 4864 / fax 805 541 4865 www.dettmerarchitecture.com ________________________________________________________________________________
Date: Jul 20, 2015
Subject: 680FP Speed Question
So I purchased the 680FP and had my mechanic fly it back to TN from NM. It was about a 600nm trip and I followed him in my 310Q with my wife and 3 year old son. We flew back at 9500 and he went up to 13500. I am not sure how he managed the engines or how he did anything for that matter, but what I was most interested in was his speed. I purchased this airplane with the understanding that it was at least a 200knot airplane. So we took off and proceeded to fly cross country for 3 hours. To my absolute disappointment he arrived 7 minutes ahead of me. He said he was doing 181MPH indicated which was basically the same speed I was doing in my 310 at a lower altitude. So my question is: Was I dupped and the 680Fp is the same speed as the 310Q? Except it burns twice as much gas. Or was he perhaps not flying it properly? I still love the plane and not changing my mind, just won't be quite as happy with it if it's that slow. It has flap gap seals and winglets although I'm not sure how much either adds to actual speed. He averaged about 55gph fuel burn compared to my 26gph. Even at 190kts he should have been indicating 220mph. Thanks, -- --glenn hancock You can't win an argument with an ignorant person. They'll just drag you down to their level and beat you with experience. ________________________________________________________________________________
Date: Jul 20, 2015
CiAgICAKR2xlbm4sClVzaW5nIElTQSBjb25kaXRpb25zIGZvciAxMyw1MDAnLCAxODEgSW5kaWNh dGVkIGlzIDIyMyBUcnVlLgpMb3RzIG9mIHF1ZXN0aW9ucyBuZWVkIHRvIGJlIGFuc3dlcmVkIGJl Zm9yZSBhIHBlcmZvcm1hbmNlIGNvbXBhcmlzb24gY2FuIGJlIG1hZGUuV2luZHMgYWxvZnQgYXQg Ym90aCBhbHRpdHVkZXNQb3dlciBzZXR0aW5nc0NsaW1iIGFuZCBkZXNjZW50IHByb2ZpbGVBdCB0 aGUgZW5kIG9mIHRoZSBkYXksIHlvdSBtaWdodCBmaW5kIHRoZSBDRTMxMCBoYXMgc2ltaWxhciBj cnVpc2UgcGVyZm9ybWFuY2UgdG8gaG93IHlvdSBvcGVyYXRlIHlvdXIgQ29tbWFuZGVyLgpXaGF0 IHdpbGwgc2VwYXJhdGUgdGhlIHNoZWVwIGZyb20gdGhlIGdvYXRzIGlzIHRoZSBsb2FkIHlvdSBj YW4gY2Fycnkgb2ZmIHRoYXQgMzAwMCcgZ3Jhc3Mgc3RyaXAgeW91IHdhbnQgdG8gYmFzZSBhdC4K Sy5TLkdvcmRvblNlbnQgb24gdGhlIEZsecKg8J+MkAoKLS0tLS0tLS0gT3JpZ2luYWwgbWVzc2Fn ZSAtLS0tLS0tLQpGcm9tOiBHbGVubiBIYW5jb2NrIDxnbGVubmhAR01BSUwuQ09NPiAKRGF0ZTog MjAvMDcvMjAxNSAgMjA6MjcgIChHTVQtMDc6MDApIApUbzogY29tbWFuZGVyLWxpc3RAbWF0cm9u aWNzLmNvbSAKU3ViamVjdDogQ29tbWFuZGVyLUxpc3Q6IDY4MEZQIFNwZWVkIFF1ZXN0aW9uIAoK U28gSSBwdXJjaGFzZWQgdGhlIDY4MEZQIGFuZCBoYWQgbXkgbWVjaGFuaWMgZmx5IGl0IGJhY2sg dG8gVE4gZnJvbSBOTS7CoCBJdCB3YXMgYWJvdXQgYSA2MDBubSB0cmlwIGFuZCBJIGZvbGxvd2Vk IGhpbSBpbiBteSAzMTBRIHdpdGggbXkgd2lmZSBhbmQgMyB5ZWFyIG9sZCBzb24uwqAgV2UgZmxl dyBiYWNrIGF0IDk1MDAgYW5kIGhlIHdlbnQgdXAgdG8gMTM1MDAuwqAgSSBhbSBub3Qgc3VyZSBo b3cgaGUgbWFuYWdlZCB0aGUgZW5naW5lcyBvciBob3cgaGUgZGlkIGFueXRoaW5nIGZvciB0aGF0 IG1hdHRlciwgYnV0IHdoYXQgSSB3YXMgbW9zdCBpbnRlcmVzdGVkIGluIHdhcyBoaXMgc3BlZWQu wqAgSSBwdXJjaGFzZWQgdGhpcyBhaXJwbGFuZSB3aXRoIHRoZSB1bmRlcnN0YW5kaW5nIHRoYXQg aXQgd2FzIGF0IGxlYXN0IGEgMjAwa25vdCBhaXJwbGFuZS4KU28gd2UgdG9vayBvZmYgYW5kIHBy b2NlZWRlZCB0byBmbHkgY3Jvc3MgY291bnRyeSBmb3IgMyBob3Vycy7CoCBUbyBteSBhYnNvbHV0 ZSBkaXNhcHBvaW50bWVudCBoZSBhcnJpdmVkIDcgbWludXRlcyBhaGVhZCBvZiBtZS7CoCBIZSBz YWlkIGhlIHdhcyBkb2luZyAxODFNUEggaW5kaWNhdGVkIHdoaWNoIHdhcyBiYXNpY2FsbHkgdGhl IHNhbWUgc3BlZWQgSSB3YXMgZG9pbmcgaW4gbXkgMzEwIGF0IGEgbG93ZXIgYWx0aXR1ZGUuClNv IG15IHF1ZXN0aW9uIGlzOiDCoFdhcyBJIGR1cHBlZCBhbmQgdGhlIDY4MEZwIGlzIHRoZSBzYW1l IHNwZWVkIGFzIHRoZSAzMTBRP8KgIEV4Y2VwdCBpdCBidXJucyB0d2ljZSBhcyBtdWNoIGdhcy7C oCBPciB3YXMgaGUgcGVyaGFwcyBub3QgZmx5aW5nIGl0IHByb3Blcmx5P8KgIEkgc3RpbGwgbG92 ZSB0aGUgcGxhbmUgYW5kIG5vdCBjaGFuZ2luZyBteSBtaW5kLCBqdXN0IHdvbid0IGJlIHF1aXRl IGFzIGhhcHB5IHdpdGggaXQgaWYgaXQncyB0aGF0IHNsb3cuwqAgSXQgaGFzIGZsYXAgZ2FwIHNl YWxzIGFuZCB3aW5nbGV0cyBhbHRob3VnaCBJJ20gbm90IHN1cmUgaG93IG11Y2ggZWl0aGVyIGFk ZHMgdG8gYWN0dWFsIHNwZWVkLsKgIEhlIGF2ZXJhZ2VkIGFib3V0IDU1Z3BoIGZ1ZWwgYnVybiBj b21wYXJlZCB0byBteSAyNmdwaC4KRXZlbiBhdCAxOTBrdHMgaGUgc2hvdWxkIGhhdmUgYmVlbiBp bmRpY2F0aW5nIDIyMG1waC4KClRoYW5rcywKCi0tIAotLWdsZW5uIGhhbmNvY2sKWW91IGNhbid0 IHdpbiBhbiBhcmd1bWVudCB3aXRoIGFuIGlnbm9yYW50IHBlcnNvbi7CoCBUaGV5J2xsIGp1c3Qg ZHJhZyB5b3UgZG93biB0byB0aGVpciBsZXZlbCBhbmQgYmVhdCB5b3Ugd2l0aCBleHBlcmllbmNl LgoKCgoKCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09Cl8tPSAgICAgICAgICAtIFRoZSBDb21tYW5kZXItTGlzdCBFbWFpbCBGb3J1 bSAtCl8tPSBVc2UgdGhlIE1hdHJvbmljcyBMaXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0byBicm93 c2UKXy09IHRoZSBtYW55IExpc3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRp b24sCl8tPSBBcmNoaXZlIFNlYXJjaCAmIERvd25sb2FkLCA3LURheSBCcm93c2UsIENoYXQsIEZB USwKXy09IFBob3Rvc2hhcmUsIGFuZCBtdWNoIG11Y2ggbW9yZToKXy09Cl8tPSAgIC0tPiBodHRw Oi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP0NvbW1hbmRlci1MaXN0Cl8tPQpfLT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpf LT0gICAgICAgICAgICAgICAtIE1BVFJPTklDUyBXRUIgRk9SVU1TIC0KXy09IFNhbWUgZ3JlYXQg Y29udGVudCBhbHNvIGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMhCl8tPQpfLT0gICAtLT4g aHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tCl8tPQpfLT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT0gICAgICAgICAgICAgLSBM aXN0IENvbnRyaWJ1dGlvbiBXZWIgU2l0ZSAtCl8tPSAgVGhhbmsgeW91IGZvciB5b3VyIGdlbmVy b3VzIHN1cHBvcnQhCl8tPSAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIC1NYXR0IERyYWxs ZSwgTGlzdCBBZG1pbi4KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmli dXRpb24KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT0KCg= ________________________________________________________________________________
Subject: Re: Commander Parts
Date: Jul 20, 2015
v\:* { BEHAVIOR: url(#default#VML) } o\:* { BEHAVIOR: url(#default#VML) } w\:* { BEHAVIOR: url(#default#VML) } .shape { BEHAVIOR: url(#default#VML) } Randy, be careful the rivet holes probably wont line up with yours. ----- Original Message ----- From: Randy Dettmer, AIA<mailto:rcdettmer(at)charter.net> Sent: Monday, July 20, 2015 2:29 PM Subject: Commander-List: Commander Parts Hello Commander fans, We are trying to locate some lower fuselage skin panels for my 680F. Anybody know of available parts or a salvage plane somewhere..?? Models 500A & B, 560, or 680F will work. Thanks much. Randy Dettmer, AIA, NCARB Dettmer Architecture 663 Hill Street San Luis Obispo, CA 93405 805 541 4864 / fax 805 541 4865 www.dettmerarchitecture.com ________________________________________________________________________________
Date: Jul 21, 2015
I'd have thought the best way to do it is get a sheetie and install new mate rial. The cost is probably going to be close and the job better done John Ives AC 685 VH NJT Sent from my iPad > On 21 Jul 2015, at 1:41 pm, lloyd silverman wrote: > > Randy, be careful the rivet holes probably wont line up with yours. > ----- Original Message ----- > From: Randy Dettmer, AIA > To: commander-list(at)matronics.com > Sent: Monday, July 20, 2015 2:29 PM > Subject: Commander-List: Commander Parts > > Hello Commander fans, > We are trying to locate some lower fuselage skin panels for my 680F. Anyb ody know of available parts or a salvage plane somewhere..?? Models 500A & B, 560, or 680F will work. Thanks much. > > Randy Dettmer, AIA, NCARB > > > > Dettmer Architecture > 663 Hill Street > San Luis Obispo, CA 93405 > 805 541 4864 / fax 805 541 4865 > www.dettmerarchitecture.com > ________________________________________________________________________________
Date: Jul 20, 2015
Ok that was funny, Lloyd. Thanks for the laugh! Sent from my iPad On Jul 20, 2015, at 8:43 PM, lloyd silverman wrote: Randy, be careful the rivet holes probably wont line up with yours. ----- Original Message ----- *From:* Randy Dettmer, AIA *To:* commander-list(at)matronics.com *Sent:* Monday, July 20, 2015 2:29 PM *Subject:* Commander-List: Commander Parts Hello Commander fans, We are trying to locate some lower fuselage skin panels for my 680F. Anybody know of available parts or a salvage plane somewhere..?? Models 500A & B, 560, or 680F will work. Thanks much. Randy Dettmer, AIA, NCARB *Dettmer Architecture* *663 Hill Street* *San Luis Obispo, CA 93405* *805 541 4864 / fax 805 541 4865* *www.dettmerarchitecture.com <http://www.dettmerarchitecture.com>* ________________________________________________________________________________
Date: Jul 20, 2015
Randy, I have two donors, one flp and a 690 I also have a Sheetmetal guy that can make the skins and circumferrentials from the templates you remove from the smaller frames. I also have the z brackets and z couplings. I have a full set of ldg gear. Pressurized windshields and side windows. Let me know if you need anything. 954-547-3002 Paul Gendron On Jul 20, 2015 2:32 PM, "Randy Dettmer, AIA" wrote: > Hello Commander fans, > > We are trying to locate some lower fuselage skin panels for my 680F. > Anybody know of available parts or a salvage plane somewhere..?? Models > 500A & B, 560, or 680F will work. Thanks much. > > > Randy Dettmer, AIA, NCARB > > > [image: logoRED-126x38@72dpi] > > > *Dettmer Architecture* > > *663 Hill Street* > > *San Luis Obispo, CA 93405* > > *805 541 4864 <805%20541%204864> / fax 805 541 4865 <805%20541%204865>* > > *www.dettmerarchitecture.com <http://www.dettmerarchitecture.com>* > > ________________________________________________________________________________
Date: Jul 21, 2015
Subject: Re: 680FP Speed Question
I haven't flown the FP, but 181 MPH indicated (IAS) at 13500 is 198 knots TAS. If you were under the impression that the airplane would INDICATE 200 knots at 13500, then that's simply not going to happen. That's 250+ KTAS. The seven minutes could be explained by higher head-winds at 13500, time-to-climb, more conservative descent, etc. If you're saying he was doing 181 (MPH) TRUE airspeed at 13500, then that seems also unlikely, as that's 158 Knots (KTAS), and you would likely have beaten him home. Net, if you're only 2 KTAS off book on a 50 year old airplane, sounds pretty good! AD -----Original Message----- From: Glenn Hancock <glennh(at)GMAIL.COM> Sent: Mon, Jul 20, 2015 9:29 pm Subject: Commander-List: 680FP Speed Question So I purchased the 680FP and had my mechanic fly it back to TN from NM. It was about a 600nm trip and I followed him in my 310Q with my wife and 3 year old son. We flew back at 9500 and he went up to 13500. I am not sure how he managed the engines or how he did anything for that matter, but what I was most interested in was his speed. I purchased this airplane with the understanding that it was at least a 200knot airplane. So we took off and proceeded to fly cross country for 3 hours. To my absolute disappointment he arrived 7 minutes ahead of me. He said he was doing 181MPH indicated which was basically the same speed I was doing in my 310 at a lower altitude. So my question is: Was I dupped and the 680Fp is the same speed as the 310Q? Except it burns twice as much gas. Or was he perhaps not flying it properly? I still love the plane and not changing my mind, just won't be quite as happy with it if it's that slow. It has flap gap seals and winglets although I'm not sure how much either adds to actual speed. He averaged about 55gph fuel burn compared to my 26gph. Even at 190kts he should have been indicating 220mph. Thanks, -- --glenn hancock You can't win an argument with an ignorant person. They'll just drag you down to their level and beat you with experience. ________________________________________________________________________________
Subject: Re: Commander-List Digest: 7 Msgs - 07/20/15
Date: Jul 21, 2015
> Randy, is that for your 680F that I have seen for sale? Keith and Lloyd, please see how your post came through all scrambled to me. Keith and I have have discussed this before, is anyone besides me receiving scrambled messages as shown below? Thanks, Dan > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete Commander-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the Commander-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 15-07-20&Archive=Commander > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 15-07-20&Archive=Commander > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > Commander-List Digest Archive > --- > Total Messages Posted Mon 07/20/15: 7 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 11:29 AM - Commander Parts (Randy Dettmer, AIA) > 2. 07:28 PM - 680FP Speed Question (Glenn Hancock) > 3. 08:19 PM - Re: 680FP Speed Question (K.S.Gordon) > 4. 08:39 PM - Re: Commander Parts (lloyd silverman) > 5. 08:44 PM - Re: Commander Parts (John Ives) > 6. 08:45 PM - Re: Commander Parts (John Vormbaum) > 7. 08:58 PM - Re: Commander Parts (Paul Gendron) > > > > ________________________________ Message 1 _____________________________________ > > > From: "Randy Dettmer, AIA" <rcdettmer(at)charter.net> > Subject: Commander-List: Commander Parts > > Hello Commander fans, > > We are trying to locate some lower fuselage skin panels for my 680F. > Anybody know of available parts or a salvage plane somewhere..?? Models > 500A & B, 560, or 680F will work. Thanks much. > > > Randy Dettmer, AIA, NCARB > > > logoRED-126x38@72dpi > > > Dettmer Architecture > > 663 Hill Street > > San Luis Obispo, CA 93405 > > 805 541 4864 / fax 805 541 4865 > > www.dettmerarchitecture.com > > > ________________________________ Message 2 _____________________________________ > > > Subject: Commander-List: 680FP Speed Question > From: Glenn Hancock <glennh(at)GMAIL.COM> > > So I purchased the 680FP and had my mechanic fly it back to TN from NM. It > was about a 600nm trip and I followed him in my 310Q with my wife and 3 > year old son. We flew back at 9500 and he went up to 13500. I am not sure > how he managed the engines or how he did anything for that matter, but what > I was most interested in was his speed. I purchased this airplane with the > understanding that it was at least a 200knot airplane. > > So we took off and proceeded to fly cross country for 3 hours. To my > absolute disappointment he arrived 7 minutes ahead of me. He said he was > doing 181MPH indicated which was basically the same speed I was doing in my > 310 at a lower altitude. > > So my question is: Was I dupped and the 680Fp is the same speed as the > 310Q? Except it burns twice as much gas. Or was he perhaps not flying it > properly? I still love the plane and not changing my mind, just won't be > quite as happy with it if it's that slow. It has flap gap seals and > winglets although I'm not sure how much either adds to actual speed. He > averaged about 55gph fuel burn compared to my 26gph. > > Even at 190kts he should have been indicating 220mph. > > > Thanks, > > > -- > --glenn hancock > > You can't win an argument with an ignorant person. They'll just drag you > down to their level and beat you with experience. > > ________________________________ Message 3 _____________________________________ > > > Subject: RE: Commander-List: 680FP Speed Question > From: "K.S.Gordon" <cloudcraft(at)aol.com> > > CiAgICAKR2xlbm4sClVzaW5nIElTQSBjb25kaXRpb25zIGZvciAxMyw1MDAnLCAxODEgSW5kaWNh > dGVkIGlzIDIyMyBUcnVlLgpMb3RzIG9mIHF1ZXN0aW9ucyBuZWVkIHRvIGJlIGFuc3dlcmVkIGJl > Zm9yZSBhIHBlcmZvcm1hbmNlIGNvbXBhcmlzb24gY2FuIGJlIG1hZGUuV2luZHMgYWxvZnQgYXQg > Ym90aCBhbHRpdHVkZXNQb3dlciBzZXR0aW5nc0NsaW1iIGFuZCBkZXNjZW50IHByb2ZpbGVBdCB0 > aGUgZW5kIG9mIHRoZSBkYXksIHlvdSBtaWdodCBmaW5kIHRoZSBDRTMxMCBoYXMgc2ltaWxhciBj > cnVpc2UgcGVyZm9ybWFuY2UgdG8gaG93IHlvdSBvcGVyYXRlIHlvdXIgQ29tbWFuZGVyLgpXaGF0 > IHdpbGwgc2VwYXJhdGUgdGhlIHNoZWVwIGZyb20gdGhlIGdvYXRzIGlzIHRoZSBsb2FkIHlvdSBj > YW4gY2Fycnkgb2ZmIHRoYXQgMzAwMCcgZ3Jhc3Mgc3RyaXAgeW91IHdhbnQgdG8gYmFzZSBhdC4K > Sy5TLkdvcmRvblNlbnQgb24gdGhlIEZsecKg8J+MkAoKLS0tLS0tLS0gT3JpZ2luYWwgbWVzc2Fn > ZSAtLS0tLS0tLQpGcm9tOiBHbGVubiBIYW5jb2NrIDxnbGVubmhAR01BSUwuQ09NPiAKRGF0ZTog > MjAvMDcvMjAxNSAgMjA6MjcgIChHTVQtMDc6MDApIApUbzogY29tbWFuZGVyLWxpc3RAbWF0cm9u > aWNzLmNvbSAKU3ViamVjdDogQ29tbWFuZGVyLUxpc3Q6IDY4MEZQIFNwZWVkIFF1ZXN0aW9uIAoK > U28gSSBwdXJjaGFzZWQgdGhlIDY4MEZQIGFuZCBoYWQgbXkgbWVjaGFuaWMgZmx5IGl0IGJhY2sg > dG8gVE4gZnJvbSBOTS7CoCBJdCB3YXMgYWJvdXQgYSA2MDBubSB0cmlwIGFuZCBJIGZvbGxvd2Vk > IGhpbSBpbiBteSAzMTBRIHdpdGggbXkgd2lmZSBhbmQgMyB5ZWFyIG9sZCBzb24uwqAgV2UgZmxl > dyBiYWNrIGF0IDk1MDAgYW5kIGhlIHdlbnQgdXAgdG8gMTM1MDAuwqAgSSBhbSBub3Qgc3VyZSBo > b3cgaGUgbWFuYWdlZCB0aGUgZW5naW5lcyBvciBob3cgaGUgZGlkIGFueXRoaW5nIGZvciB0aGF0 > IG1hdHRlciwgYnV0IHdoYXQgSSB3YXMgbW9zdCBpbnRlcmVzdGVkIGluIHdhcyBoaXMgc3BlZWQu > wqAgSSBwdXJjaGFzZWQgdGhpcyBhaXJwbGFuZSB3aXRoIHRoZSB1bmRlcnN0YW5kaW5nIHRoYXQg > aXQgd2FzIGF0IGxlYXN0IGEgMjAwa25vdCBhaXJwbGFuZS4KU28gd2UgdG9vayBvZmYgYW5kIHBy > b2NlZWRlZCB0byBmbHkgY3Jvc3MgY291bnRyeSBmb3IgMyBob3Vycy7CoCBUbyBteSBhYnNvbHV0 > ZSBkaXNhcHBvaW50bWVudCBoZSBhcnJpdmVkIDcgbWludXRlcyBhaGVhZCBvZiBtZS7CoCBIZSBz > YWlkIGhlIHdhcyBkb2luZyAxODFNUEggaW5kaWNhdGVkIHdoaWNoIHdhcyBiYXNpY2FsbHkgdGhl > IHNhbWUgc3BlZWQgSSB3YXMgZG9pbmcgaW4gbXkgMzEwIGF0IGEgbG93ZXIgYWx0aXR1ZGUuClNv > IG15IHF1ZXN0aW9uIGlzOiDCoFdhcyBJIGR1cHBlZCBhbmQgdGhlIDY4MEZwIGlzIHRoZSBzYW1l > IHNwZWVkIGFzIHRoZSAzMTBRP8KgIEV4Y2VwdCBpdCBidXJucyB0d2ljZSBhcyBtdWNoIGdhcy7C > oCBPciB3YXMgaGUgcGVyaGFwcyBub3QgZmx5aW5nIGl0IHByb3Blcmx5P8KgIEkgc3RpbGwgbG92 > ZSB0aGUgcGxhbmUgYW5kIG5vdCBjaGFuZ2luZyBteSBtaW5kLCBqdXN0IHdvbid0IGJlIHF1aXRl > IGFzIGhhcHB5IHdpdGggaXQgaWYgaXQncyB0aGF0IHNsb3cuwqAgSXQgaGFzIGZsYXAgZ2FwIHNl > YWxzIGFuZCB3aW5nbGV0cyBhbHRob3VnaCBJJ20gbm90IHN1cmUgaG93IG11Y2ggZWl0aGVyIGFk > ZHMgdG8gYWN0dWFsIHNwZWVkLsKgIEhlIGF2ZXJhZ2VkIGFib3V0IDU1Z3BoIGZ1ZWwgYnVybiBj > b21wYXJlZCB0byBteSAyNmdwaC4KRXZlbiBhdCAxOTBrdHMgaGUgc2hvdWxkIGhhdmUgYmVlbiBp > bmRpY2F0aW5nIDIyMG1waC4KClRoYW5rcywKCi0tIAotLWdsZW5uIGhhbmNvY2sKWW91IGNhbid0 > IHdpbiBhbiBhcmd1bWVudCB3aXRoIGFuIGlnbm9yYW50IHBlcnNvbi7CoCBUaGV5J2xsIGp1c3Qg > ZHJhZyB5b3UgZG93biB0byB0aGVpciBsZXZlbCBhbmQgYmVhdCB5b3Ugd2l0aCBleHBlcmllbmNl > LgoKCgoKCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 > PT09PT09PT09PT09Cl8tPSAgICAgICAgICAtIFRoZSBDb21tYW5kZXItTGlzdCBFbWFpbCBGb3J1 > bSAtCl8tPSBVc2UgdGhlIE1hdHJvbmljcyBMaXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0byBicm93 > c2UKXy09IHRoZSBtYW55IExpc3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRp > b24sCl8tPSBBcmNoaXZlIFNlYXJjaCAmIERvd25sb2FkLCA3LURheSBCcm93c2UsIENoYXQsIEZB > USwKXy09IFBob3Rvc2hhcmUsIGFuZCBtdWNoIG11Y2ggbW9yZToKXy09Cl8tPSAgIC0tPiBodHRw > Oi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP0NvbW1hbmRlci1MaXN0Cl8tPQpfLT09PT09 > PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpf > LT0gICAgICAgICAgICAgICAtIE1BVFJPTklDUyBXRUIgRk9SVU1TIC0KXy09IFNhbWUgZ3JlYXQg > Y29udGVudCBhbHNvIGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMhCl8tPQpfLT0gICAtLT4g > aHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tCl8tPQpfLT09PT09PT09PT09PT09PT09PT09PT09 > PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT0gICAgICAgICAgICAgLSBM > aXN0IENvbnRyaWJ1dGlvbiBXZWIgU2l0ZSAtCl8tPSAgVGhhbmsgeW91IGZvciB5b3VyIGdlbmVy > b3VzIHN1cHBvcnQhCl8tPSAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIC1NYXR0IERyYWxs > ZSwgTGlzdCBBZG1pbi4KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmli > dXRpb24KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 > PT09PT09PT09PT0KCg > > ________________________________ Message 4 _____________________________________ > > > From: "lloyd silverman" <lloydsss11(at)MSN.COM> > Subject: Re: Commander-List: Commander Parts > > v\:* { BEHAVIOR: url(#default#VML) } o\:* { BEHAVIOR: > url(#default#VML) } w\:* { BEHAVIOR: url(#default#VML) } .shape { > BEHAVIOR: url(#default#VML) } > > Randy, be careful the rivet holes probably wont line up with yours. > > > ----- Original Message ----- > > From: Randy Dettmer, AIA<mailto:rcdettmer(at)charter.net> > > > Sent: Monday, July 20, 2015 2:29 PM > > Subject: Commander-List: Commander Parts > > > Hello Commander fans, > > We are trying to locate some lower fuselage skin panels for my 680F. > Anybody know of available parts or a salvage plane somewhere..?? > Models 500A & B, 560, or 680F will work. Thanks much. > > > Randy Dettmer, AIA, NCARB > > > Dettmer Architecture > > 663 Hill Street > > San Luis Obispo, CA 93405 > > 805 541 4864 / fax 805 541 4865 > > www.dettmerarchitecture.com > > > ________________________________ Message 5 _____________________________________ > > > Subject: Re: Commander-List: Commander Parts > From: John Ives <seafever32(at)hotmail.com> > > I'd have thought the best way to do it is get a sheetie and install new mate > rial. The cost is probably going to be close and the job better done > > John Ives > AC 685 > VH NJT > > Sent from my iPad > >> On 21 Jul 2015, at 1:41 pm, lloyd silverman wrote: >> >> Randy, be careful the rivet holes probably wont line up with yours. >> ----- Original Message ----- >> From: Randy Dettmer, AIA >> To: commander-list(at)matronics.com >> Sent: Monday, July 20, 2015 2:29 PM >> Subject: Commander-List: Commander Parts >> >> Hello Commander fans, >> We are trying to locate some lower fuselage skin panels for my 680F. Anyb > ody know of available parts or a salvage plane somewhere..?? Models 500A & > B, 560, or 680F will work. Thanks much. >> >> Randy Dettmer, AIA, NCARB >> >> >> >> Dettmer Architecture >> 663 Hill Street >> San Luis Obispo, CA 93405 >> 805 541 4864 / fax 805 541 4865 >> www.dettmerarchitecture.com > > ________________________________ Message 6 _____________________________________ > > > From: John Vormbaum <john(at)vormbaum.com> > Subject: Re: Commander-List: Commander Parts > > Ok that was funny, Lloyd. Thanks for the laugh! > > Sent from my iPad > > On Jul 20, 2015, at 8:43 PM, lloyd silverman wrote: > > Randy, be careful the rivet holes probably wont line up with yours. > > ----- Original Message ----- > *From:* Randy Dettmer, AIA > *To:* commander-list(at)matronics.com > *Sent:* Monday, July 20, 2015 2:29 PM > *Subject:* Commander-List: Commander Parts > > Hello Commander fans, > > We are trying to locate some lower fuselage skin panels for my 680F. > Anybody know of available parts or a salvage plane somewhere..?? Models > 500A & B, 560, or 680F will work. Thanks much. > > > Randy Dettmer, AIA, NCARB > > > > > > *Dettmer Architecture* > > *663 Hill Street* > > *San Luis Obispo, CA 93405* > > *805 541 4864 / fax 805 541 4865* > > *www.dettmerarchitecture.com <http://www.dettmerarchitecture.com>* > > ________________________________ Message 7 _____________________________________ > > > Subject: Re: Commander-List: Commander Parts > From: Paul Gendron <rpmcommander(at)GMAIL.COM> > > Randy, I have two donors, one flp and a 690 I also have a Sheetmetal guy > that can make the skins and circumferrentials from the templates you remove > from the smaller frames. I also have the z brackets and z couplings. I have > a full set of ldg gear. Pressurized windshields and side windows. Let me > know if you need anything. 954-547-3002 Paul Gendron > On Jul 20, 2015 2:32 PM, "Randy Dettmer, AIA" > wrote: > >> Hello Commander fans, >> >> We are trying to locate some lower fuselage skin panels for my 680F. >> Anybody know of available parts or a salvage plane somewhere..?? Models >> 500A & B, 560, or 680F will work. Thanks much. >> >> >> Randy Dettmer, AIA, NCARB >> >> >> [image: logoRED-126x38@72dpi] >> >> >> *Dettmer Architecture* >> >> *663 Hill Street* >> >> *San Luis Obispo, CA 93405* >> >> *805 541 4864 <805%20541%204864> / fax 805 541 4865 <805%20541%204865>* >> >> *www.dettmerarchitecture.com <http://www.dettmerarchitecture.com>* > > > > > > > > ________________________________________________________________________________
Date: Jul 21, 2015
Hi Dan, Yes, it's my 68F that has been for sale. Not currently listed. It will likely be on the market again in about a year. I am using it too much now for business to sell. Randy Dettmer Architecture 663 Hill Street San Luis Obispo, CA 93405 805 541 4864 / fax 805 541 4865 www.dettmerarchitecture.com -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Dan Sent: Tuesday, July 21, 2015 5:49 AM Subject: Commander-List: Re: Commander-List Digest: 7 Msgs - 07/20/15 > Randy, is that for your 680F that I have seen for sale? Keith and Lloyd, please see how your post came through all scrambled to me. Keith and I have have discussed this before, is anyone besides me receiving scrambled messages as shown below? Thanks, Dan > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete Commander-List Digest can also be found in either of > the two Web Links listed below. The .html file includes the Digest > formatted in HTML for viewing with a web browser and features > Hyperlinked Indexes and Message Navigation. The .txt file includes > the plain ASCII version of the Commander-List Digest and can be viewed > with a generic text editor such as Notepad or with a web browser. > > HTML Version: > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&C > hapter 15-07-20&Archive=Commander > > Text Version: > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Ch > apter 15-07-20&Archive=Commander > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > Commander-List Digest Archive > --- > Total Messages Posted Mon 07/20/15: 7 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 11:29 AM - Commander Parts (Randy Dettmer, AIA) > 2. 07:28 PM - 680FP Speed Question (Glenn Hancock) > 3. 08:19 PM - Re: 680FP Speed Question (K.S.Gordon) > 4. 08:39 PM - Re: Commander Parts (lloyd silverman) > 5. 08:44 PM - Re: Commander Parts (John Ives) > 6. 08:45 PM - Re: Commander Parts (John Vormbaum) > 7. 08:58 PM - Re: Commander Parts (Paul Gendron) > > > > ________________________________ Message 1 > _____________________________________ > > > From: "Randy Dettmer, AIA" <rcdettmer(at)charter.net> > Subject: Commander-List: Commander Parts > > Hello Commander fans, > > We are trying to locate some lower fuselage skin panels for my 680F. > Anybody know of available parts or a salvage plane somewhere..?? Models > 500A & B, 560, or 680F will work. Thanks much. > > > Randy Dettmer, AIA, NCARB > > > logoRED-126x38@72dpi > > > Dettmer Architecture > > 663 Hill Street > > San Luis Obispo, CA 93405 > > 805 541 4864 / fax 805 541 4865 > > www.dettmerarchitecture.com > > > ________________________________ Message 2 > _____________________________________ > > > Subject: Commander-List: 680FP Speed Question > From: Glenn Hancock <glennh(at)GMAIL.COM> > > So I purchased the 680FP and had my mechanic fly it back to TN from > NM. It was about a 600nm trip and I followed him in my 310Q with my > wife and 3 year old son. We flew back at 9500 and he went up to > 13500. I am not sure how he managed the engines or how he did > anything for that matter, but what I was most interested in was his > speed. I purchased this airplane with the understanding that it was at least a 200knot airplane. > > So we took off and proceeded to fly cross country for 3 hours. To my > absolute disappointment he arrived 7 minutes ahead of me. He said he > was doing 181MPH indicated which was basically the same speed I was > doing in my > 310 at a lower altitude. > > So my question is: Was I dupped and the 680Fp is the same speed as > the 310Q? Except it burns twice as much gas. Or was he perhaps not > flying it properly? I still love the plane and not changing my mind, > just won't be quite as happy with it if it's that slow. It has flap > gap seals and winglets although I'm not sure how much either adds to > actual speed. He averaged about 55gph fuel burn compared to my 26gph. > > Even at 190kts he should have been indicating 220mph. > > > Thanks, > > > -- > --glenn hancock > > You can't win an argument with an ignorant person. They'll just drag > you down to their level and beat you with experience. > > ________________________________ Message 3 > _____________________________________ > > > Subject: RE: Commander-List: 680FP Speed Question > From: "K.S.Gordon" <cloudcraft(at)aol.com> > > CiAgICAKR2xlbm4sClVzaW5nIElTQSBjb25kaXRpb25zIGZvciAxMyw1MDAnLCAxODEgSW > 5kaWNh > dGVkIGlzIDIyMyBUcnVlLgpMb3RzIG9mIHF1ZXN0aW9ucyBuZWVkIHRvIGJlIGFuc3dlcm > VkIGJl > Zm9yZSBhIHBlcmZvcm1hbmNlIGNvbXBhcmlzb24gY2FuIGJlIG1hZGUuV2luZHMgYWxvZn > QgYXQg > Ym90aCBhbHRpdHVkZXNQb3dlciBzZXR0aW5nc0NsaW1iIGFuZCBkZXNjZW50IHByb2ZpbG > VBdCB0 > aGUgZW5kIG9mIHRoZSBkYXksIHlvdSBtaWdodCBmaW5kIHRoZSBDRTMxMCBoYXMgc2ltaW > xhciBj > cnVpc2UgcGVyZm9ybWFuY2UgdG8gaG93IHlvdSBvcGVyYXRlIHlvdXIgQ29tbWFuZGVyLg > pXaGF0 > IHdpbGwgc2VwYXJhdGUgdGhlIHNoZWVwIGZyb20gdGhlIGdvYXRzIGlzIHRoZSBsb2FkIH > lvdSBj > YW4gY2Fycnkgb2ZmIHRoYXQgMzAwMCcgZ3Jhc3Mgc3RyaXAgeW91IHdhbnQgdG8gYmFzZS > BhdC4K > Sy5TLkdvcmRvblNlbnQgb24gdGhlIEZsecKg8J+MkAoKLS0tLS0tLS0gT3JpZ2luYWwgbW > Sy5TLkdvcmRvblNlbnQgb24gdGhlIEZsecKg8J+Vzc2Fn > ZSAtLS0tLS0tLQpGcm9tOiBHbGVubiBIYW5jb2NrIDxnbGVubmhAR01BSUwuQ09NPiAKRG > F0ZTog > MjAvMDcvMjAxNSAgMjA6MjcgIChHTVQtMDc6MDApIApUbzogY29tbWFuZGVyLWxpc3RAbW > F0cm9u > aWNzLmNvbSAKU3ViamVjdDogQ29tbWFuZGVyLUxpc3Q6IDY4MEZQIFNwZWVkIFF1ZXN0aW > 9uIAoK > U28gSSBwdXJjaGFzZWQgdGhlIDY4MEZQIGFuZCBoYWQgbXkgbWVjaGFuaWMgZmx5IGl0IG > JhY2sg > dG8gVE4gZnJvbSBOTS7CoCBJdCB3YXMgYWJvdXQgYSA2MDBubSB0cmlwIGFuZCBJIGZvbG > xvd2Vk > IGhpbSBpbiBteSAzMTBRIHdpdGggbXkgd2lmZSBhbmQgMyB5ZWFyIG9sZCBzb24uwqAgV2 > UgZmxl > dyBiYWNrIGF0IDk1MDAgYW5kIGhlIHdlbnQgdXAgdG8gMTM1MDAuwqAgSSBhbSBub3Qgc3 > VyZSBo > b3cgaGUgbWFuYWdlZCB0aGUgZW5naW5lcyBvciBob3cgaGUgZGlkIGFueXRoaW5nIGZvci > B0aGF0 > IG1hdHRlciwgYnV0IHdoYXQgSSB3YXMgbW9zdCBpbnRlcmVzdGVkIGluIHdhcyBoaXMgc3 > BlZWQu > wqAgSSBwdXJjaGFzZWQgdGhpcyBhaXJwbGFuZSB3aXRoIHRoZSB1bmRlcnN0YW5kaW5nIH > RoYXQg > aXQgd2FzIGF0IGxlYXN0IGEgMjAwa25vdCBhaXJwbGFuZS4KU28gd2UgdG9vayBvZmYgYW > 5kIHBy > b2NlZWRlZCB0byBmbHkgY3Jvc3MgY291bnRyeSBmb3IgMyBob3Vycy7CoCBUbyBteSBhYn > NvbHV0 > ZSBkaXNhcHBvaW50bWVudCBoZSBhcnJpdmVkIDcgbWludXRlcyBhaGVhZCBvZiBtZS7CoC > BIZSBz > YWlkIGhlIHdhcyBkb2luZyAxODFNUEggaW5kaWNhdGVkIHdoaWNoIHdhcyBiYXNpY2FsbH > kgdGhl > IHNhbWUgc3BlZWQgSSB3YXMgZG9pbmcgaW4gbXkgMzEwIGF0IGEgbG93ZXIgYWx0aXR1ZG > UuClNv > IG15IHF1ZXN0aW9uIGlzOiDCoFdhcyBJIGR1cHBlZCBhbmQgdGhlIDY4MEZwIGlzIHRoZS > BzYW1l > IHNwZWVkIGFzIHRoZSAzMTBRP8KgIEV4Y2VwdCBpdCBidXJucyB0d2ljZSBhcyBtdWNoIG > dhcy7C > oCBPciB3YXMgaGUgcGVyaGFwcyBub3QgZmx5aW5nIGl0IHByb3Blcmx5P8KgIEkgc3RpbG > wgbG92 > ZSB0aGUgcGxhbmUgYW5kIG5vdCBjaGFuZ2luZyBteSBtaW5kLCBqdXN0IHdvbid0IGJlIH > F1aXRl > IGFzIGhhcHB5IHdpdGggaXQgaWYgaXQncyB0aGF0IHNsb3cuwqAgSXQgaGFzIGZsYXAgZ2 > FwIHNl > YWxzIGFuZCB3aW5nbGV0cyBhbHRob3VnaCBJJ20gbm90IHN1cmUgaG93IG11Y2ggZWl0aG > VyIGFk > ZHMgdG8gYWN0dWFsIHNwZWVkLsKgIEhlIGF2ZXJhZ2VkIGFib3V0IDU1Z3BoIGZ1ZWwgYn > VybiBj > b21wYXJlZCB0byBteSAyNmdwaC4KRXZlbiBhdCAxOTBrdHMgaGUgc2hvdWxkIGhhdmUgYm > VlbiBp > bmRpY2F0aW5nIDIyMG1waC4KClRoYW5rcywKCi0tIAotLWdsZW5uIGhhbmNvY2sKWW91IG > Nhbid0 > IHdpbiBhbiBhcmd1bWVudCB3aXRoIGFuIGlnbm9yYW50IHBlcnNvbi7CoCBUaGV5J2xsIG > p1c3Qg > ZHJhZyB5b3UgZG93biB0byB0aGVpciBsZXZlbCBhbmQgYmVhdCB5b3Ugd2l0aCBleHBlcm > llbmNl > LgoKCgoKCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT > 09PT09 > PT09PT09PT09PT09Cl8tPSAgICAgICAgICAtIFRoZSBDb21tYW5kZXItTGlzdCBFbWFpbC > BGb3J1 > bSAtCl8tPSBVc2UgdGhlIE1hdHJvbmljcyBMaXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0by > Bicm93 > c2UKXy09IHRoZSBtYW55IExpc3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3 > JpcHRp > b24sCl8tPSBBcmNoaXZlIFNlYXJjaCAmIERvd25sb2FkLCA3LURheSBCcm93c2UsIENoYX > QsIEZB > USwKXy09IFBob3Rvc2hhcmUsIGFuZCBtdWNoIG11Y2ggbW9yZToKXy09Cl8tPSAgIC0tPi > BodHRw > Oi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP0NvbW1hbmRlci1MaXN0Cl8tPQpfLT > 09PT09 > PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT > 09PQpf > LT0gICAgICAgICAgICAgICAtIE1BVFJPTklDUyBXRUIgRk9SVU1TIC0KXy09IFNhbWUgZ3 > JlYXQg > Y29udGVudCBhbHNvIGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMhCl8tPQpfLT0gIC > AtLT4g > aHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tCl8tPQpfLT09PT09PT09PT09PT09PT09PT > 09PT09 > PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT0gICAgICAgICAgIC > AgLSBM > aXN0IENvbnRyaWJ1dGlvbiBXZWIgU2l0ZSAtCl8tPSAgVGhhbmsgeW91IGZvciB5b3VyIG > dlbmVy > b3VzIHN1cHBvcnQhCl8tPSAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIC1NYXR0IE > RyYWxs > ZSwgTGlzdCBBZG1pbi4KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jb2 > ZSwgTGlzdCBBZG1pbi4KXy09ICAgLS0+50cmli > dXRpb24KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT > 09PT09 > PT09PT09PT09PT0KCg > > ________________________________ Message 4 > _____________________________________ > > > From: "lloyd silverman" <lloydsss11(at)MSN.COM> > Subject: Re: Commander-List: Commander Parts > > v\:* { BEHAVIOR: url(#default#VML) } o\:* { BEHAVIOR: > url(#default#VML) } w\:* { BEHAVIOR: url(#default#VML) } .shape { > BEHAVIOR: url(#default#VML) } > > Randy, be careful the rivet holes probably wont line up with yours. > > > ----- Original Message ----- > > From: Randy Dettmer, AIA<mailto:rcdettmer(at)charter.net> > > > Sent: Monday, July 20, 2015 2:29 PM > > Subject: Commander-List: Commander Parts > > > Hello Commander fans, > > We are trying to locate some lower fuselage skin panels for my 680F. > Anybody know of available parts or a salvage plane somewhere..?? > Models 500A & B, 560, or 680F will work. Thanks much. > > > Randy Dettmer, AIA, NCARB > > > Dettmer Architecture > > 663 Hill Street > > San Luis Obispo, CA 93405 > > 805 541 4864 / fax 805 541 4865 > > www.dettmerarchitecture.com > > > ________________________________ Message 5 > _____________________________________ > > > Subject: Re: Commander-List: Commander Parts > From: John Ives <seafever32(at)hotmail.com> > > I'd have thought the best way to do it is get a sheetie and install > new mate rial. The cost is probably going to be close and the job > better done > > John Ives > AC 685 > VH NJT > > Sent from my iPad > >> On 21 Jul 2015, at 1:41 pm, lloyd silverman wrote: >> >> Randy, be careful the rivet holes probably wont line up with yours. >> ----- Original Message ----- >> From: Randy Dettmer, AIA >> To: commander-list(at)matronics.com >> Sent: Monday, July 20, 2015 2:29 PM >> Subject: Commander-List: Commander Parts >> >> Hello Commander fans, >> We are trying to locate some lower fuselage skin panels for my 680F. >> Anyb > ody know of available parts or a salvage plane somewhere..?? Models 500A & > B, 560, or 680F will work. Thanks much. >> >> Randy Dettmer, AIA, NCARB >> >> >> >> Dettmer Architecture >> 663 Hill Street >> San Luis Obispo, CA 93405 >> 805 541 4864 / fax 805 541 4865 >> www.dettmerarchitecture.com > > ________________________________ Message 6 > _____________________________________ > > > From: John Vormbaum <john(at)vormbaum.com> > Subject: Re: Commander-List: Commander Parts > > Ok that was funny, Lloyd. Thanks for the laugh! > > Sent from my iPad > > On Jul 20, 2015, at 8:43 PM, lloyd silverman wrote: > > Randy, be careful the rivet holes probably wont line up with yours. > > ----- Original Message ----- > *From:* Randy Dettmer, AIA > *To:* commander-list(at)matronics.com > *Sent:* Monday, July 20, 2015 2:29 PM > *Subject:* Commander-List: Commander Parts > > Hello Commander fans, > > We are trying to locate some lower fuselage skin panels for my 680F. > Anybody know of available parts or a salvage plane somewhere..?? Models > 500A & B, 560, or 680F will work. Thanks much. > > > Randy Dettmer, AIA, NCARB > > > > > > *Dettmer Architecture* > > *663 Hill Street* > > *San Luis Obispo, CA 93405* > > *805 541 4864 / fax 805 541 4865* > > *www.dettmerarchitecture.com <http://www.dettmerarchitecture.com>* > > ________________________________ Message 7 > _____________________________________ > > > Subject: Re: Commander-List: Commander Parts > From: Paul Gendron <rpmcommander(at)GMAIL.COM> > > Randy, I have two donors, one flp and a 690 I also have a Sheetmetal > guy that can make the skins and circumferrentials from the templates > you remove from the smaller frames. I also have the z brackets and z > couplings. I have a full set of ldg gear. Pressurized windshields and > side windows. Let me know if you need anything. 954-547-3002 Paul > Gendron On Jul 20, 2015 2:32 PM, "Randy Dettmer, AIA" > > wrote: > >> Hello Commander fans, >> >> We are trying to locate some lower fuselage skin panels for my 680F. >> Anybody know of available parts or a salvage plane somewhere..?? Models >> 500A & B, 560, or 680F will work. Thanks much. >> >> >> Randy Dettmer, AIA, NCARB >> >> >> [image: logoRED-126x38@72dpi] >> >> >> *Dettmer Architecture* >> >> *663 Hill Street* >> >> *San Luis Obispo, CA 93405* >> >> *805 541 4864 <805%20541%204864> / fax 805 541 4865 >> <805%20541%204865>* >> >> *www.dettmerarchitecture.com <http://www.dettmerarchitecture.com>* > > > > > > > > ________________________________________________________________________________
Date: Jul 22, 2015
Sometimes scrambled here - would rather receive emails sunny side up! Sent from my iPhone > On 22 Jul 2015, at 1:19 am, Randy Dettmer, AIA wrote: > > > Hi Dan, > Yes, it's my 68F that has been for sale. Not currently listed. It will > likely be on the market again in about a year. I am using it too much now > for business to sell. > > Randy > > Dettmer Architecture > 663 Hill Street > San Luis Obispo, CA 93405 > 805 541 4864 / fax 805 541 4865 > www.dettmerarchitecture.com > > -----Original Message----- > From: owner-commander-list-server(at)matronics.com > [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Dan > Sent: Tuesday, July 21, 2015 5:49 AM > To: commander-list(at)matronics.com > Subject: Commander-List: Re: Commander-List Digest: 7 Msgs - 07/20/15 > > > >> Randy, is that for your 680F that I have seen for sale? > > Keith and Lloyd, please see how your post came through all scrambled to > me. Keith and I have have discussed this before, is anyone besides me > receiving scrambled messages as shown below? > Thanks, Dan >> >> ================================================= >> Online Versions of Today's List Digest Archive >> ================================================= >> >> Today's complete Commander-List Digest can also be found in either of >> the two Web Links listed below. The .html file includes the Digest >> formatted in HTML for viewing with a web browser and features >> Hyperlinked Indexes and Message Navigation. The .txt file includes >> the plain ASCII version of the Commander-List Digest and can be viewed >> with a generic text editor such as Notepad or with a web browser. >> >> HTML Version: >> >> >> http://www.matronics.com/digest/digestview.php?Style=82701&View=html&C >> hapter 15-07-20&Archive=Commander >> >> Text Version: >> >> >> http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Ch >> apter 15-07-20&Archive=Commander >> >> >> =============================================== >> EMail Version of Today's List Digest Archive >> =============================================== >> >> >> ---------------------------------------------------------- >> Commander-List Digest Archive >> --- >> Total Messages Posted Mon 07/20/15: 7 >> ---------------------------------------------------------- >> >> >> Today's Message Index: >> ---------------------- >> >> 1. 11:29 AM - Commander Parts (Randy Dettmer, AIA) >> 2. 07:28 PM - 680FP Speed Question (Glenn Hancock) >> 3. 08:19 PM - Re: 680FP Speed Question (K.S.Gordon) >> 4. 08:39 PM - Re: Commander Parts (lloyd silverman) >> 5. 08:44 PM - Re: Commander Parts (John Ives) >> 6. 08:45 PM - Re: Commander Parts (John Vormbaum) >> 7. 08:58 PM - Re: Commander Parts (Paul Gendron) >> >> >> >> ________________________________ Message 1 >> _____________________________________ >> >> >> From: "Randy Dettmer, AIA" <rcdettmer(at)charter.net> >> Subject: Commander-List: Commander Parts >> >> Hello Commander fans, >> >> We are trying to locate some lower fuselage skin panels for my 680F. >> Anybody know of available parts or a salvage plane somewhere..?? Models >> 500A & B, 560, or 680F will work. Thanks much. >> >> >> Randy Dettmer, AIA, NCARB >> >> >> logoRED-126x38@72dpi >> >> >> Dettmer Architecture >> >> 663 Hill Street >> >> San Luis Obispo, CA 93405 >> >> 805 541 4864 / fax 805 541 4865 >> >> www.dettmerarchitecture.com >> >> >> ________________________________ Message 2 >> _____________________________________ >> >> >> Subject: Commander-List: 680FP Speed Question >> From: Glenn Hancock <glennh(at)GMAIL.COM> >> >> So I purchased the 680FP and had my mechanic fly it back to TN from >> NM. It was about a 600nm trip and I followed him in my 310Q with my >> wife and 3 year old son. We flew back at 9500 and he went up to >> 13500. I am not sure how he managed the engines or how he did >> anything for that matter, but what I was most interested in was his >> speed. I purchased this airplane with the understanding that it was at > least a 200knot airplane. >> >> So we took off and proceeded to fly cross country for 3 hours. To my >> absolute disappointment he arrived 7 minutes ahead of me. He said he >> was doing 181MPH indicated which was basically the same speed I was >> doing in my >> 310 at a lower altitude. >> >> So my question is: Was I dupped and the 680Fp is the same speed as >> the 310Q? Except it burns twice as much gas. Or was he perhaps not >> flying it properly? I still love the plane and not changing my mind, >> just won't be quite as happy with it if it's that slow. It has flap >> gap seals and winglets although I'm not sure how much either adds to >> actual speed. He averaged about 55gph fuel burn compared to my 26gph. >> >> Even at 190kts he should have been indicating 220mph. >> >> >> Thanks, >> >> >> -- >> --glenn hancock >> >> You can't win an argument with an ignorant person. They'll just drag >> you down to their level and beat you with experience. >> >> ________________________________ Message 3 >> _____________________________________ >> >> >> Subject: RE: Commander-List: 680FP Speed Question >> From: "K.S.Gordon" <cloudcraft(at)aol.com> >> >> CiAgICAKR2xlbm4sClVzaW5nIElTQSBjb25kaXRpb25zIGZvciAxMyw1MDAnLCAxODEgSW >> 5kaWNh >> dGVkIGlzIDIyMyBUcnVlLgpMb3RzIG9mIHF1ZXN0aW9ucyBuZWVkIHRvIGJlIGFuc3dlcm >> VkIGJl >> Zm9yZSBhIHBlcmZvcm1hbmNlIGNvbXBhcmlzb24gY2FuIGJlIG1hZGUuV2luZHMgYWxvZn >> QgYXQg >> Ym90aCBhbHRpdHVkZXNQb3dlciBzZXR0aW5nc0NsaW1iIGFuZCBkZXNjZW50IHByb2ZpbG >> VBdCB0 >> aGUgZW5kIG9mIHRoZSBkYXksIHlvdSBtaWdodCBmaW5kIHRoZSBDRTMxMCBoYXMgc2ltaW >> xhciBj >> cnVpc2UgcGVyZm9ybWFuY2UgdG8gaG93IHlvdSBvcGVyYXRlIHlvdXIgQ29tbWFuZGVyLg >> pXaGF0 >> IHdpbGwgc2VwYXJhdGUgdGhlIHNoZWVwIGZyb20gdGhlIGdvYXRzIGlzIHRoZSBsb2FkIH >> lvdSBj >> YW4gY2Fycnkgb2ZmIHRoYXQgMzAwMCcgZ3Jhc3Mgc3RyaXAgeW91IHdhbnQgdG8gYmFzZS >> BhdC4K >> Sy5TLkdvcmRvblNlbnQgb24gdGhlIEZsecKg8J+MkAoKLS0tLS0tLS0gT3JpZ2luYWwgbW >> Sy5TLkdvcmRvblNlbnQgb24gdGhlIEZsecKg8J+Vzc2Fn >> ZSAtLS0tLS0tLQpGcm9tOiBHbGVubiBIYW5jb2NrIDxnbGVubmhAR01BSUwuQ09NPiAKRG >> F0ZTog >> MjAvMDcvMjAxNSAgMjA6MjcgIChHTVQtMDc6MDApIApUbzogY29tbWFuZGVyLWxpc3RAbW >> F0cm9u >> aWNzLmNvbSAKU3ViamVjdDogQ29tbWFuZGVyLUxpc3Q6IDY4MEZQIFNwZWVkIFF1ZXN0aW >> 9uIAoK >> U28gSSBwdXJjaGFzZWQgdGhlIDY4MEZQIGFuZCBoYWQgbXkgbWVjaGFuaWMgZmx5IGl0IG >> JhY2sg >> dG8gVE4gZnJvbSBOTS7CoCBJdCB3YXMgYWJvdXQgYSA2MDBubSB0cmlwIGFuZCBJIGZvbG >> xvd2Vk >> IGhpbSBpbiBteSAzMTBRIHdpdGggbXkgd2lmZSBhbmQgMyB5ZWFyIG9sZCBzb24uwqAgV2 >> UgZmxl >> dyBiYWNrIGF0IDk1MDAgYW5kIGhlIHdlbnQgdXAgdG8gMTM1MDAuwqAgSSBhbSBub3Qgc3 >> VyZSBo >> b3cgaGUgbWFuYWdlZCB0aGUgZW5naW5lcyBvciBob3cgaGUgZGlkIGFueXRoaW5nIGZvci >> B0aGF0 >> IG1hdHRlciwgYnV0IHdoYXQgSSB3YXMgbW9zdCBpbnRlcmVzdGVkIGluIHdhcyBoaXMgc3 >> BlZWQu >> wqAgSSBwdXJjaGFzZWQgdGhpcyBhaXJwbGFuZSB3aXRoIHRoZSB1bmRlcnN0YW5kaW5nIH >> RoYXQg >> aXQgd2FzIGF0IGxlYXN0IGEgMjAwa25vdCBhaXJwbGFuZS4KU28gd2UgdG9vayBvZmYgYW >> 5kIHBy >> b2NlZWRlZCB0byBmbHkgY3Jvc3MgY291bnRyeSBmb3IgMyBob3Vycy7CoCBUbyBteSBhYn >> NvbHV0 >> ZSBkaXNhcHBvaW50bWVudCBoZSBhcnJpdmVkIDcgbWludXRlcyBhaGVhZCBvZiBtZS7CoC >> BIZSBz >> YWlkIGhlIHdhcyBkb2luZyAxODFNUEggaW5kaWNhdGVkIHdoaWNoIHdhcyBiYXNpY2FsbH >> kgdGhl >> IHNhbWUgc3BlZWQgSSB3YXMgZG9pbmcgaW4gbXkgMzEwIGF0IGEgbG93ZXIgYWx0aXR1ZG >> UuClNv >> IG15IHF1ZXN0aW9uIGlzOiDCoFdhcyBJIGR1cHBlZCBhbmQgdGhlIDY4MEZwIGlzIHRoZS >> BzYW1l >> IHNwZWVkIGFzIHRoZSAzMTBRP8KgIEV4Y2VwdCBpdCBidXJucyB0d2ljZSBhcyBtdWNoIG >> dhcy7C >> oCBPciB3YXMgaGUgcGVyaGFwcyBub3QgZmx5aW5nIGl0IHByb3Blcmx5P8KgIEkgc3RpbG >> wgbG92 >> ZSB0aGUgcGxhbmUgYW5kIG5vdCBjaGFuZ2luZyBteSBtaW5kLCBqdXN0IHdvbid0IGJlIH >> F1aXRl >> IGFzIGhhcHB5IHdpdGggaXQgaWYgaXQncyB0aGF0IHNsb3cuwqAgSXQgaGFzIGZsYXAgZ2 >> FwIHNl >> YWxzIGFuZCB3aW5nbGV0cyBhbHRob3VnaCBJJ20gbm90IHN1cmUgaG93IG11Y2ggZWl0aG >> VyIGFk >> ZHMgdG8gYWN0dWFsIHNwZWVkLsKgIEhlIGF2ZXJhZ2VkIGFib3V0IDU1Z3BoIGZ1ZWwgYn >> VybiBj >> b21wYXJlZCB0byBteSAyNmdwaC4KRXZlbiBhdCAxOTBrdHMgaGUgc2hvdWxkIGhhdmUgYm >> VlbiBp >> bmRpY2F0aW5nIDIyMG1waC4KClRoYW5rcywKCi0tIAotLWdsZW5uIGhhbmNvY2sKWW91IG >> Nhbid0 >> IHdpbiBhbiBhcmd1bWVudCB3aXRoIGFuIGlnbm9yYW50IHBlcnNvbi7CoCBUaGV5J2xsIG >> p1c3Qg >> ZHJhZyB5b3UgZG93biB0byB0aGVpciBsZXZlbCBhbmQgYmVhdCB5b3Ugd2l0aCBleHBlcm >> llbmNl >> LgoKCgoKCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT >> 09PT09 >> PT09PT09PT09PT09Cl8tPSAgICAgICAgICAtIFRoZSBDb21tYW5kZXItTGlzdCBFbWFpbC >> BGb3J1 >> bSAtCl8tPSBVc2UgdGhlIE1hdHJvbmljcyBMaXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0by >> Bicm93 >> c2UKXy09IHRoZSBtYW55IExpc3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3 >> JpcHRp >> b24sCl8tPSBBcmNoaXZlIFNlYXJjaCAmIERvd25sb2FkLCA3LURheSBCcm93c2UsIENoYX >> QsIEZB >> USwKXy09IFBob3Rvc2hhcmUsIGFuZCBtdWNoIG11Y2ggbW9yZToKXy09Cl8tPSAgIC0tPi >> BodHRw >> Oi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP0NvbW1hbmRlci1MaXN0Cl8tPQpfLT >> 09PT09 >> PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT >> 09PQpf >> LT0gICAgICAgICAgICAgICAtIE1BVFJPTklDUyBXRUIgRk9SVU1TIC0KXy09IFNhbWUgZ3 >> JlYXQg >> Y29udGVudCBhbHNvIGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMhCl8tPQpfLT0gIC >> AtLT4g >> aHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tCl8tPQpfLT09PT09PT09PT09PT09PT09PT >> 09PT09 >> PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT0gICAgICAgICAgIC >> AgLSBM >> aXN0IENvbnRyaWJ1dGlvbiBXZWIgU2l0ZSAtCl8tPSAgVGhhbmsgeW91IGZvciB5b3VyIG >> dlbmVy >> b3VzIHN1cHBvcnQhCl8tPSAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIC1NYXR0IE >> RyYWxs >> ZSwgTGlzdCBBZG1pbi4KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jb2 >> ZSwgTGlzdCBBZG1pbi4KXy09ICAgLS0+50cmli >> dXRpb24KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT >> 09PT09 >> PT09PT09PT09PT0KCg >> >> ________________________________ Message 4 >> _____________________________________ >> >> >> From: "lloyd silverman" <lloydsss11(at)MSN.COM> >> Subject: Re: Commander-List: Commander Parts >> >> v\:* { BEHAVIOR: url(#default#VML) } o\:* { BEHAVIOR: >> url(#default#VML) } w\:* { BEHAVIOR: url(#default#VML) } .shape { >> BEHAVIOR: url(#default#VML) } >> >> Randy, be careful the rivet holes probably wont line up with yours. >> >> >> ----- Original Message ----- >> >> From: Randy Dettmer, AIA<mailto:rcdettmer(at)charter.net> >> >> >> Sent: Monday, July 20, 2015 2:29 PM >> >> Subject: Commander-List: Commander Parts >> >> >> Hello Commander fans, >> >> We are trying to locate some lower fuselage skin panels for my 680F. >> Anybody know of available parts or a salvage plane somewhere..?? >> Models 500A & B, 560, or 680F will work. Thanks much. >> >> >> Randy Dettmer, AIA, NCARB >> >> >> Dettmer Architecture >> >> 663 Hill Street >> >> San Luis Obispo, CA 93405 >> >> 805 541 4864 / fax 805 541 4865 >> >> www.dettmerarchitecture.com >> >> >> ________________________________ Message 5 >> _____________________________________ >> >> >> Subject: Re: Commander-List: Commander Parts >> From: John Ives <seafever32(at)hotmail.com> >> >> I'd have thought the best way to do it is get a sheetie and install >> new mate rial. The cost is probably going to be close and the job >> better done >> >> John Ives >> AC 685 >> VH NJT >> >> Sent from my iPad >> >>> On 21 Jul 2015, at 1:41 pm, lloyd silverman wrote: >>> >>> Randy, be careful the rivet holes probably wont line up with yours. >>> ----- Original Message ----- >>> From: Randy Dettmer, AIA >>> To: commander-list(at)matronics.com >>> Sent: Monday, July 20, 2015 2:29 PM >>> Subject: Commander-List: Commander Parts >>> >>> Hello Commander fans, >>> We are trying to locate some lower fuselage skin panels for my 680F. >>> Anyb >> ody know of available parts or a salvage plane somewhere..?? Models 500A > & >> B, 560, or 680F will work. Thanks much. >>> >>> Randy Dettmer, AIA, NCARB >>> >>> >>> >>> Dettmer Architecture >>> 663 Hill Street >>> San Luis Obispo, CA 93405 >>> 805 541 4864 / fax 805 541 4865 >>> www.dettmerarchitecture.com >> >> ________________________________ Message 6 >> _____________________________________ >> >> >> From: John Vormbaum <john(at)vormbaum.com> >> Subject: Re: Commander-List: Commander Parts >> >> Ok that was funny, Lloyd. Thanks for the laugh! >> >> Sent from my iPad >> >> On Jul 20, 2015, at 8:43 PM, lloyd silverman wrote: >> >> Randy, be careful the rivet holes probably wont line up with yours. >> >> ----- Original Message ----- >> *From:* Randy Dettmer, AIA >> *To:* commander-list(at)matronics.com >> *Sent:* Monday, July 20, 2015 2:29 PM >> *Subject:* Commander-List: Commander Parts >> >> Hello Commander fans, >> >> We are trying to locate some lower fuselage skin panels for my 680F. >> Anybody know of available parts or a salvage plane somewhere..?? Models >> 500A & B, 560, or 680F will work. Thanks much. >> >> >> Randy Dettmer, AIA, NCARB >> >> >> >> >> >> *Dettmer Architecture* >> >> *663 Hill Street* >> >> *San Luis Obispo, CA 93405* >> >> *805 541 4864 / fax 805 541 4865* >> >> *www.dettmerarchitecture.com <http://www.dettmerarchitecture.com>* >> >> ________________________________ Message 7 >> _____________________________________ >> >> >> Subject: Re: Commander-List: Commander Parts >> From: Paul Gendron <rpmcommander(at)GMAIL.COM> >> >> Randy, I have two donors, one flp and a 690 I also have a Sheetmetal >> guy that can make the skins and circumferrentials from the templates >> you remove from the smaller frames. I also have the z brackets and z >> couplings. I have a full set of ldg gear. Pressurized windshields and >> side windows. Let me know if you need anything. 954-547-3002 Paul >> Gendron On Jul 20, 2015 2:32 PM, "Randy Dettmer, AIA" >> >> wrote: >> >>> Hello Commander fans, >>> >>> We are trying to locate some lower fuselage skin panels for my 680F. >>> Anybody know of available parts or a salvage plane somewhere..?? Models >>> 500A & B, 560, or 680F will work. Thanks much. >>> >>> >>> Randy Dettmer, AIA, NCARB >>> >>> >>> [image: logoRED-126x38@72dpi] >>> >>> >>> *Dettmer Architecture* >>> >>> *663 Hill Street* >>> >>> *San Luis Obispo, CA 93405* >>> >>> *805 541 4864 <805%20541%204864> / fax 805 541 4865 >>> <805%20541%204865>* >>> >>> *www.dettmerarchitecture.com <http://www.dettmerarchitecture.com>* > > > > > > > > > > ________________________________________________________________________________
Date: Jul 21, 2015
All US emails arrive upside down for you, dont they Russell? Cheers from topside, /John > On Jul 21, 2015, at 2:26 PM, Russell Legg wrote: > > > Sometimes scrambled here - would rather receive emails sunny side up! > > Sent from my iPhone > >> On 22 Jul 2015, at 1:19 am, Randy Dettmer, AIA wrote: >> >> >> Hi Dan, >> Yes, it's my 68F that has been for sale. Not currently listed. It will >> likely be on the market again in about a year. I am using it too much now >> for business to sell. >> >> Randy >> >> Dettmer Architecture >> 663 Hill Street >> San Luis Obispo, CA 93405 >> 805 541 4864 / fax 805 541 4865 >> www.dettmerarchitecture.com >> >> -----Original Message----- >> From: owner-commander-list-server(at)matronics.com >> [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Dan >> Sent: Tuesday, July 21, 2015 5:49 AM >> To: commander-list(at)matronics.com >> Subject: Commander-List: Re: Commander-List Digest: 7 Msgs - 07/20/15 >> >> >> >>> Randy, is that for your 680F that I have seen for sale? >> >> Keith and Lloyd, please see how your post came through all scrambled to >> me. Keith and I have have discussed this before, is anyone besides me >> receiving scrambled messages as shown below? >> Thanks, Dan >>> >>> ================================================= >>> Online Versions of Today's List Digest Archive >>> ================================================= >>> >>> Today's complete Commander-List Digest can also be found in either of >>> the two Web Links listed below. The .html file includes the Digest >>> formatted in HTML for viewing with a web browser and features >>> Hyperlinked Indexes and Message Navigation. The .txt file includes >>> the plain ASCII version of the Commander-List Digest and can be viewed >>> with a generic text editor such as Notepad or with a web browser. >>> >>> HTML Version: >>> >>> >>> http://www.matronics.com/digest/digestview.php?Style=82701&View=html&C >>> hapter 15-07-20&Archive=Commander >>> >>> Text Version: >>> >>> >>> http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Ch >>> apter 15-07-20&Archive=Commander >>> >>> >>> =============================================== >>> EMail Version of Today's List Digest Archive >>> =============================================== >>> >>> >>> ---------------------------------------------------------- >>> Commander-List Digest Archive >>> --- >>> Total Messages Posted Mon 07/20/15: 7 >>> ---------------------------------------------------------- >>> >>> >>> Today's Message Index: >>> ---------------------- >>> >>> 1. 11:29 AM - Commander Parts (Randy Dettmer, AIA) >>> 2. 07:28 PM - 680FP Speed Question (Glenn Hancock) >>> 3. 08:19 PM - Re: 680FP Speed Question (K.S.Gordon) >>> 4. 08:39 PM - Re: Commander Parts (lloyd silverman) >>> 5. 08:44 PM - Re: Commander Parts (John Ives) >>> 6. 08:45 PM - Re: Commander Parts (John Vormbaum) >>> 7. 08:58 PM - Re: Commander Parts (Paul Gendron) >>> >>> >>> >>> ________________________________ Message 1 >>> _____________________________________ >>> >>> >>> From: "Randy Dettmer, AIA" <rcdettmer(at)charter.net> >>> Subject: Commander-List: Commander Parts >>> >>> Hello Commander fans, >>> >>> We are trying to locate some lower fuselage skin panels for my 680F. >>> Anybody know of available parts or a salvage plane somewhere..?? Models >>> 500A & B, 560, or 680F will work. Thanks much. >>> >>> >>> Randy Dettmer, AIA, NCARB >>> >>> >>> logoRED-126x38@72dpi >>> >>> >>> Dettmer Architecture >>> >>> 663 Hill Street >>> >>> San Luis Obispo, CA 93405 >>> >>> 805 541 4864 / fax 805 541 4865 >>> >>> www.dettmerarchitecture.com >>> >>> >>> ________________________________ Message 2 >>> _____________________________________ >>> >>> >>> Subject: Commander-List: 680FP Speed Question >>> From: Glenn Hancock <glennh(at)GMAIL.COM> >>> >>> So I purchased the 680FP and had my mechanic fly it back to TN from >>> NM. It was about a 600nm trip and I followed him in my 310Q with my >>> wife and 3 year old son. We flew back at 9500 and he went up to >>> 13500. I am not sure how he managed the engines or how he did >>> anything for that matter, but what I was most interested in was his >>> speed. I purchased this airplane with the understanding that it was at >> least a 200knot airplane. >>> >>> So we took off and proceeded to fly cross country for 3 hours. To my >>> absolute disappointment he arrived 7 minutes ahead of me. He said he >>> was doing 181MPH indicated which was basically the same speed I was >>> doing in my >>> 310 at a lower altitude. >>> >>> So my question is: Was I dupped and the 680Fp is the same speed as >>> the 310Q? Except it burns twice as much gas. Or was he perhaps not >>> flying it properly? I still love the plane and not changing my mind, >>> just won't be quite as happy with it if it's that slow. It has flap >>> gap seals and winglets although I'm not sure how much either adds to >>> actual speed. He averaged about 55gph fuel burn compared to my 26gph. >>> >>> Even at 190kts he should have been indicating 220mph. >>> >>> >>> Thanks, >>> >>> >>> -- >>> --glenn hancock >>> >>> You can't win an argument with an ignorant person. They'll just drag >>> you down to their level and beat you with experience. >>> >>> ________________________________ Message 3 >>> _____________________________________ >>> >>> >>> Subject: RE: Commander-List: 680FP Speed Question >>> From: "K.S.Gordon" <cloudcraft(at)aol.com> >>> >>> CiAgICAKR2xlbm4sClVzaW5nIElTQSBjb25kaXRpb25zIGZvciAxMyw1MDAnLCAxODEgSW >>> 5kaWNh >>> dGVkIGlzIDIyMyBUcnVlLgpMb3RzIG9mIHF1ZXN0aW9ucyBuZWVkIHRvIGJlIGFuc3dlcm >>> VkIGJl >>> Zm9yZSBhIHBlcmZvcm1hbmNlIGNvbXBhcmlzb24gY2FuIGJlIG1hZGUuV2luZHMgYWxvZn >>> QgYXQg >>> Ym90aCBhbHRpdHVkZXNQb3dlciBzZXR0aW5nc0NsaW1iIGFuZCBkZXNjZW50IHByb2ZpbG >>> VBdCB0 >>> aGUgZW5kIG9mIHRoZSBkYXksIHlvdSBtaWdodCBmaW5kIHRoZSBDRTMxMCBoYXMgc2ltaW >>> xhciBj >>> cnVpc2UgcGVyZm9ybWFuY2UgdG8gaG93IHlvdSBvcGVyYXRlIHlvdXIgQ29tbWFuZGVyLg >>> pXaGF0 >>> IHdpbGwgc2VwYXJhdGUgdGhlIHNoZWVwIGZyb20gdGhlIGdvYXRzIGlzIHRoZSBsb2FkIH >>> lvdSBj >>> YW4gY2Fycnkgb2ZmIHRoYXQgMzAwMCcgZ3Jhc3Mgc3RyaXAgeW91IHdhbnQgdG8gYmFzZS >>> BhdC4K >>> Sy5TLkdvcmRvblNlbnQgb24gdGhlIEZsecKg8J+MkAoKLS0tLS0tLS0gT3JpZ2luYWwgbW >>> Sy5TLkdvcmRvblNlbnQgb24gdGhlIEZsecKg8J+Vzc2Fn >>> ZSAtLS0tLS0tLQpGcm9tOiBHbGVubiBIYW5jb2NrIDxnbGVubmhAR01BSUwuQ09NPiAKRG >>> F0ZTog >>> MjAvMDcvMjAxNSAgMjA6MjcgIChHTVQtMDc6MDApIApUbzogY29tbWFuZGVyLWxpc3RAbW >>> F0cm9u >>> aWNzLmNvbSAKU3ViamVjdDogQ29tbWFuZGVyLUxpc3Q6IDY4MEZQIFNwZWVkIFF1ZXN0aW >>> 9uIAoK >>> U28gSSBwdXJjaGFzZWQgdGhlIDY4MEZQIGFuZCBoYWQgbXkgbWVjaGFuaWMgZmx5IGl0IG >>> JhY2sg >>> dG8gVE4gZnJvbSBOTS7CoCBJdCB3YXMgYWJvdXQgYSA2MDBubSB0cmlwIGFuZCBJIGZvbG >>> xvd2Vk >>> IGhpbSBpbiBteSAzMTBRIHdpdGggbXkgd2lmZSBhbmQgMyB5ZWFyIG9sZCBzb24uwqAgV2 >>> UgZmxl >>> dyBiYWNrIGF0IDk1MDAgYW5kIGhlIHdlbnQgdXAgdG8gMTM1MDAuwqAgSSBhbSBub3Qgc3 >>> VyZSBo >>> b3cgaGUgbWFuYWdlZCB0aGUgZW5naW5lcyBvciBob3cgaGUgZGlkIGFueXRoaW5nIGZvci >>> B0aGF0 >>> IG1hdHRlciwgYnV0IHdoYXQgSSB3YXMgbW9zdCBpbnRlcmVzdGVkIGluIHdhcyBoaXMgc3 >>> BlZWQu >>> wqAgSSBwdXJjaGFzZWQgdGhpcyBhaXJwbGFuZSB3aXRoIHRoZSB1bmRlcnN0YW5kaW5nIH >>> RoYXQg >>> aXQgd2FzIGF0IGxlYXN0IGEgMjAwa25vdCBhaXJwbGFuZS4KU28gd2UgdG9vayBvZmYgYW >>> 5kIHBy >>> b2NlZWRlZCB0byBmbHkgY3Jvc3MgY291bnRyeSBmb3IgMyBob3Vycy7CoCBUbyBteSBhYn >>> NvbHV0 >>> ZSBkaXNhcHBvaW50bWVudCBoZSBhcnJpdmVkIDcgbWludXRlcyBhaGVhZCBvZiBtZS7CoC >>> BIZSBz >>> YWlkIGhlIHdhcyBkb2luZyAxODFNUEggaW5kaWNhdGVkIHdoaWNoIHdhcyBiYXNpY2FsbH >>> kgdGhl >>> IHNhbWUgc3BlZWQgSSB3YXMgZG9pbmcgaW4gbXkgMzEwIGF0IGEgbG93ZXIgYWx0aXR1ZG >>> UuClNv >>> IG15IHF1ZXN0aW9uIGlzOiDCoFdhcyBJIGR1cHBlZCBhbmQgdGhlIDY4MEZwIGlzIHRoZS >>> BzYW1l >>> IHNwZWVkIGFzIHRoZSAzMTBRP8KgIEV4Y2VwdCBpdCBidXJucyB0d2ljZSBhcyBtdWNoIG >>> dhcy7C >>> oCBPciB3YXMgaGUgcGVyaGFwcyBub3QgZmx5aW5nIGl0IHByb3Blcmx5P8KgIEkgc3RpbG >>> wgbG92 >>> ZSB0aGUgcGxhbmUgYW5kIG5vdCBjaGFuZ2luZyBteSBtaW5kLCBqdXN0IHdvbid0IGJlIH >>> F1aXRl >>> IGFzIGhhcHB5IHdpdGggaXQgaWYgaXQncyB0aGF0IHNsb3cuwqAgSXQgaGFzIGZsYXAgZ2 >>> FwIHNl >>> YWxzIGFuZCB3aW5nbGV0cyBhbHRob3VnaCBJJ20gbm90IHN1cmUgaG93IG11Y2ggZWl0aG >>> VyIGFk >>> ZHMgdG8gYWN0dWFsIHNwZWVkLsKgIEhlIGF2ZXJhZ2VkIGFib3V0IDU1Z3BoIGZ1ZWwgYn >>> VybiBj >>> b21wYXJlZCB0byBteSAyNmdwaC4KRXZlbiBhdCAxOTBrdHMgaGUgc2hvdWxkIGhhdmUgYm >>> VlbiBp >>> bmRpY2F0aW5nIDIyMG1waC4KClRoYW5rcywKCi0tIAotLWdsZW5uIGhhbmNvY2sKWW91IG >>> Nhbid0 >>> IHdpbiBhbiBhcmd1bWVudCB3aXRoIGFuIGlnbm9yYW50IHBlcnNvbi7CoCBUaGV5J2xsIG >>> p1c3Qg >>> ZHJhZyB5b3UgZG93biB0byB0aGVpciBsZXZlbCBhbmQgYmVhdCB5b3Ugd2l0aCBleHBlcm >>> llbmNl >>> LgoKCgoKCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT >>> 09PT09 >>> PT09PT09PT09PT09Cl8tPSAgICAgICAgICAtIFRoZSBDb21tYW5kZXItTGlzdCBFbWFpbC >>> BGb3J1 >>> bSAtCl8tPSBVc2UgdGhlIE1hdHJvbmljcyBMaXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0by >>> Bicm93 >>> c2UKXy09IHRoZSBtYW55IExpc3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3 >>> JpcHRp >>> b24sCl8tPSBBcmNoaXZlIFNlYXJjaCAmIERvd25sb2FkLCA3LURheSBCcm93c2UsIENoYX >>> QsIEZB >>> USwKXy09IFBob3Rvc2hhcmUsIGFuZCBtdWNoIG11Y2ggbW9yZToKXy09Cl8tPSAgIC0tPi >>> BodHRw >>> Oi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP0NvbW1hbmRlci1MaXN0Cl8tPQpfLT >>> 09PT09 >>> PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT >>> 09PQpf >>> LT0gICAgICAgICAgICAgICAtIE1BVFJPTklDUyBXRUIgRk9SVU1TIC0KXy09IFNhbWUgZ3 >>> JlYXQg >>> Y29udGVudCBhbHNvIGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMhCl8tPQpfLT0gIC >>> AtLT4g >>> aHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tCl8tPQpfLT09PT09PT09PT09PT09PT09PT >>> 09PT09 >>> PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT0gICAgICAgICAgIC >>> AgLSBM >>> aXN0IENvbnRyaWJ1dGlvbiBXZWIgU2l0ZSAtCl8tPSAgVGhhbmsgeW91IGZvciB5b3VyIG >>> dlbmVy >>> b3VzIHN1cHBvcnQhCl8tPSAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIC1NYXR0IE >>> RyYWxs >>> ZSwgTGlzdCBBZG1pbi4KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jb2 >>> ZSwgTGlzdCBBZG1pbi4KXy09ICAgLS0+50cmli >>> dXRpb24KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT >>> 09PT09 >>> PT09PT09PT09PT0KCg >>> >>> ________________________________ Message 4 >>> _____________________________________ >>> >>> >>> From: "lloyd silverman" <lloydsss11(at)MSN.COM> >>> Subject: Re: Commander-List: Commander Parts >>> >>> v\:* { BEHAVIOR: url(#default#VML) } o\:* { BEHAVIOR: >>> url(#default#VML) } w\:* { BEHAVIOR: url(#default#VML) } .shape { >>> BEHAVIOR: url(#default#VML) } >>> >>> Randy, be careful the rivet holes probably wont line up with yours. >>> >>> >>> ----- Original Message ----- >>> >>> From: Randy Dettmer, AIA<mailto:rcdettmer(at)charter.net> >>> >>> >>> Sent: Monday, July 20, 2015 2:29 PM >>> >>> Subject: Commander-List: Commander Parts >>> >>> >>> Hello Commander fans, >>> >>> We are trying to locate some lower fuselage skin panels for my 680F. >>> Anybody know of available parts or a salvage plane somewhere..?? >>> Models 500A & B, 560, or 680F will work. Thanks much. >>> >>> >>> Randy Dettmer, AIA, NCARB >>> >>> >>> Dettmer Architecture >>> >>> 663 Hill Street >>> >>> San Luis Obispo, CA 93405 >>> >>> 805 541 4864 / fax 805 541 4865 >>> >>> www.dettmerarchitecture.com >>> >>> >>> ________________________________ Message 5 >>> _____________________________________ >>> >>> >>> Subject: Re: Commander-List: Commander Parts >>> From: John Ives <seafever32(at)hotmail.com> >>> >>> I'd have thought the best way to do it is get a sheetie and install >>> new mate rial. The cost is probably going to be close and the job >>> better done >>> >>> John Ives >>> AC 685 >>> VH NJT >>> >>> Sent from my iPad >>> >>>> On 21 Jul 2015, at 1:41 pm, lloyd silverman wrote: >>>> >>>> Randy, be careful the rivet holes probably wont line up with yours. >>>> ----- Original Message ----- >>>> From: Randy Dettmer, AIA >>>> To: commander-list(at)matronics.com >>>> Sent: Monday, July 20, 2015 2:29 PM >>>> Subject: Commander-List: Commander Parts >>>> >>>> Hello Commander fans, >>>> We are trying to locate some lower fuselage skin panels for my 680F. >>>> Anyb >>> ody know of available parts or a salvage plane somewhere..?? Models 500A >> & >>> B, 560, or 680F will work. Thanks much. >>>> >>>> Randy Dettmer, AIA, NCARB >>>> >>>> >>>> >>>> Dettmer Architecture >>>> 663 Hill Street >>>> San Luis Obispo, CA 93405 >>>> 805 541 4864 / fax 805 541 4865 >>>> www.dettmerarchitecture.com >>> >>> ________________________________ Message 6 >>> _____________________________________ >>> >>> >>> From: John Vormbaum <john(at)vormbaum.com> >>> Subject: Re: Commander-List: Commander Parts >>> >>> Ok that was funny, Lloyd. Thanks for the laugh! >>> >>> Sent from my iPad >>> >>> On Jul 20, 2015, at 8:43 PM, lloyd silverman wrote: >>> >>> Randy, be careful the rivet holes probably wont line up with yours. >>> >>> ----- Original Message ----- >>> *From:* Randy Dettmer, AIA >>> *To:* commander-list(at)matronics.com >>> *Sent:* Monday, July 20, 2015 2:29 PM >>> *Subject:* Commander-List: Commander Parts >>> >>> Hello Commander fans, >>> >>> We are trying to locate some lower fuselage skin panels for my 680F. >>> Anybody know of available parts or a salvage plane somewhere..?? Models >>> 500A & B, 560, or 680F will work. Thanks much. >>> >>> >>> Randy Dettmer, AIA, NCARB >>> >>> >>> >>> >>> >>> *Dettmer Architecture* >>> >>> *663 Hill Street* >>> >>> *San Luis Obispo, CA 93405* >>> >>> *805 541 4864 / fax 805 541 4865* >>> >>> *www.dettmerarchitecture.com <http://www.dettmerarchitecture.com>* >>> >>> ________________________________ Message 7 >>> _____________________________________ >>> >>> >>> Subject: Re: Commander-List: Commander Parts >>> From: Paul Gendron <rpmcommander(at)GMAIL.COM> >>> >>> Randy, I have two donors, one flp and a 690 I also have a Sheetmetal >>> guy that can make the skins and circumferrentials from the templates >>> you remove from the smaller frames. I also have the z brackets and z >>> couplings. I have a full set of ldg gear. Pressurized windshields and >>> side windows. Let me know if you need anything. 954-547-3002 Paul >>> Gendron On Jul 20, 2015 2:32 PM, "Randy Dettmer, AIA" >>> >>> wrote: >>> >>>> Hello Commander fans, >>>> >>>> We are trying to locate some lower fuselage skin panels for my 680F. >>>> Anybody know of available parts or a salvage plane somewhere..?? Models >>>> 500A & B, 560, or 680F will work. Thanks much. >>>> >>>> >>>> Randy Dettmer, AIA, NCARB >>>> >>>> >>>> [image: logoRED-126x38@72dpi] >>>> >>>> >>>> *Dettmer Architecture* >>>> >>>> *663 Hill Street* >>>> >>>> *San Luis Obispo, CA 93405* >>>> >>>> *805 541 4864 <805%20541%204864> / fax 805 541 4865 >>>> <805%20541%204865>* >>>> >>>> *www.dettmerarchitecture.com <http://www.dettmerarchitecture.com>* >> >> >> >> >> >> >> >> >> >> > > > > > ________________________________________________________________________________
Date: Jul 21, 2015
CiAgICAKU29tZW9uZSB1cHNpZGUgZG93biB3YW50cyB0aGVpciBlZ2dzIGFuZCB0ZXh0IHN1bm55 IHNpZGUgdXA/CgpLLlMuR29yZG9uU2VudCBvbiB0aGUgRmx5wqDwn4yQCgotLS0tLS0tLSBPcmln aW5hbCBtZXNzYWdlIC0tLS0tLS0tCkZyb206IFJ1c3NlbGwgTGVnZyA8YWVybzU2MGVAR01BSUwu Q09NPiAKRGF0ZTogMjEvMDcvMjAxNSAgMTU6MjYgIChHTVQtMDc6MDApIApUbzogY29tbWFuZGVy LWxpc3RAbWF0cm9uaWNzLmNvbSAKU3ViamVjdDogUmU6IENvbW1hbmRlci1MaXN0OiBSZTogQ29t bWFuZGVyLUxpc3QgRGlnZXN0OiA3IE1zZ3MgLSAwNy8yMC8xNSAKCi0tPiBDb21tYW5kZXItTGlz dCBtZXNzYWdlIHBvc3RlZCBieTogUnVzc2VsbCBMZWdnIDxhZXJvNTYwZUBnbWFpbC5jb20+CgpT b21ldGltZXMgc2NyYW1ibGVkIGhlcmUgLSB3b3VsZCByYXRoZXIgcmVjZWl2ZSBlbWFpbHMgc3Vu bnkgc2lkZSB1cCEKClNlbnQgZnJvbSBteSBpUGhvbmUKCj4gT24gMjIgSnVsIDIwMTUsIGF0IDE6 MTkgYW0sIFJhbmR5IERldHRtZXIsIEFJQSA8cmNkZXR0bWVyQGNoYXJ0ZXIubmV0PiB3cm90ZToK PiAKPiAtLT4gQ29tbWFuZGVyLUxpc3QgbWVzc2FnZSBwb3N0ZWQgYnk6ICJSYW5keSBEZXR0bWVy LCBBSUEiIDxyY2RldHRtZXJAY2hhcnRlci5uZXQ+Cj4gCj4gSGkgRGFuLAo+IFllcywgaXQncyBt eSA2OEYgdGhhdCBoYXMgYmVlbiBmb3Igc2FsZS7CoCBOb3QgY3VycmVudGx5IGxpc3RlZC7CoCBJ dCB3aWxsCj4gbGlrZWx5IGJlIG9uIHRoZSBtYXJrZXQgYWdhaW4gaW4gYWJvdXQgYSB5ZWFyLsKg IEkgYW0gdXNpbmcgaXQgdG9vIG11Y2ggbm93Cj4gZm9yIGJ1c2luZXNzIHRvIHNlbGwuwqAgCj4g Cj4gUmFuZHkKPiAKPiBEZXR0bWVyIEFyY2hpdGVjdHVyZQo+IDY2MyBIaWxsIFN0cmVldAo+IFNh biBMdWlzIE9iaXNwbywgQ0HCoCA5MzQwNQo+IDgwNSA1NDEgNDg2NCAvIGZheCA4MDUgNTQxIDQ4 NjUKPiB3d3cuZGV0dG1lcmFyY2hpdGVjdHVyZS5jb20KPiAKPiAtLS0tLU9yaWdpbmFsIE1lc3Nh Z2UtLS0tLQo+IEZyb206IG93bmVyLWNvbW1hbmRlci1saXN0LXNlcnZlckBtYXRyb25pY3MuY29t Cj4gW21haWx0bzpvd25lci1jb21tYW5kZXItbGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbV0gT24g QmVoYWxmIE9mIERhbgo+IFNlbnQ6IFR1ZXNkYXksIEp1bHkgMjEsIDIwMTUgNTo0OSBBTQo+IFRv OiBjb21tYW5kZXItbGlzdEBtYXRyb25pY3MuY29tCj4gU3ViamVjdDogQ29tbWFuZGVyLUxpc3Q6 IFJlOiBDb21tYW5kZXItTGlzdCBEaWdlc3Q6IDcgTXNncyAtIDA3LzIwLzE1Cj4gCj4gLS0+IENv bW1hbmRlci1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiBEYW4gPGRhbmllbGxmYXJtZXJAeWFob28u Y29tPgo+IAo+IAo+PiBSYW5keSzCoCBpcyB0aGF0IGZvciB5b3VyIDY4MEYgdGhhdCBJIGhhdmUg c2VlbiBmb3Igc2FsZT8KPiAKPsKgIEtlaXRoIGFuZCBMbG95ZCwgcGxlYXNlIHNlZSBob3cgeW91 ciBwb3N0IGNhbWUgdGhyb3VnaCBhbGwgc2NyYW1ibGVkIHRvCj4gbWUuwqAgS2VpdGggYW5kIEkg aGF2ZSBoYXZlIGRpc2N1c3NlZCB0aGlzIGJlZm9yZSwgaXMgYW55b25lIGJlc2lkZXMgbWUKPiBy ZWNlaXZpbmcgc2NyYW1ibGVkIG1lc3NhZ2VzIGFzIHNob3duIGJlbG93Pwo+IFRoYW5rcywgRGFu Cj4+IAo+PiA9PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PQo+PsKgIE9ubGluZSBWZXJzaW9ucyBvZiBUb2RheSdzIExpc3QgRGlnZXN0IEFyY2hpdmUgCj4+ ID09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09Cj4+IAo+ PiBUb2RheSdzIGNvbXBsZXRlIENvbW1hbmRlci1MaXN0IERpZ2VzdCBjYW4gYWxzbyBiZSBmb3Vu ZCBpbiBlaXRoZXIgb2YgCj4+IHRoZSB0d28gV2ViIExpbmtzIGxpc3RlZCBiZWxvdy7CoCBUaGUg Lmh0bWwgZmlsZSBpbmNsdWRlcyB0aGUgRGlnZXN0IAo+PiBmb3JtYXR0ZWQgaW4gSFRNTCBmb3Ig dmlld2luZyB3aXRoIGEgd2ViIGJyb3dzZXIgYW5kIGZlYXR1cmVzIAo+PiBIeXBlcmxpbmtlZCBJ bmRleGVzIGFuZCBNZXNzYWdlIE5hdmlnYXRpb24uwqAgVGhlIC50eHQgZmlsZSBpbmNsdWRlcyAK Pj4gdGhlIHBsYWluIEFTQ0lJIHZlcnNpb24gb2YgdGhlIENvbW1hbmRlci1MaXN0IERpZ2VzdCBh bmQgY2FuIGJlIHZpZXdlZCAKPj4gd2l0aCBhIGdlbmVyaWMgdGV4dCBlZGl0b3Igc3VjaCBhcyBO b3RlcGFkIG9yIHdpdGggYSB3ZWIgYnJvd3Nlci4KPj4gCj4+IEhUTUwgVmVyc2lvbjoKPj4gCj4+ IAo+PiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vZGlnZXN0L2RpZ2VzdHZpZXcucGhwP1N0eWxl PTgyNzAxJlZpZXc9aHRtbCZDCj4+IGhhcHRlcj0yMDE1LTA3LTIwJkFyY2hpdmU9Q29tbWFuZGVy Cj4+IAo+PiBUZXh0IFZlcnNpb246Cj4+IAo+PiAKPj4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29t L2RpZ2VzdC9kaWdlc3R2aWV3LnBocD9TdHlsZT04MjcwMSZWaWV3PXR4dCZDaAo+PiBhcHRlcj0y MDE1LTA3LTIwJkFyY2hpdmU9Q29tbWFuZGVyCj4+IAo+PiAKPj4gPT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09Cj4+wqAgRU1haWwgVmVyc2lvbiBvZiBUb2Rh eSdzIExpc3QgRGlnZXN0IEFyY2hpdmUgCj4+ID09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PQo+PiAKPj4gCj4+wqDCoMKgwqDCoMKgwqDCoMKgIC0tLS0tLS0t LS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0KPj7CoMKg wqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoCBDb21tYW5kZXIt TGlzdCBEaWdlc3QgQXJjaGl2ZQo+PsKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDC oMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoCAtLS0KPj7CoMKgwqDCoMKgwqDC oMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoCBUb3RhbCBNZXNzYWdlcyBQb3N0ZWQgTW9uIDA3LzIw LzE1OiA3Cj4+wqDCoMKgwqDCoMKgwqDCoMKgIC0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0t LS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0KPj4gCj4+IAo+PiBUb2RheSdzIE1lc3NhZ2Ug SW5kZXg6Cj4+IC0tLS0tLS0tLS0tLS0tLS0tLS0tLS0KPj4gCj4+wqDCoMKgIDEuIDExOjI5IEFN IC0gQ29tbWFuZGVyIFBhcnRzwqAgKFJhbmR5IERldHRtZXIsIEFJQSkKPj7CoMKgwqAgMi4gMDc6 MjggUE0gLSA2ODBGUCBTcGVlZCBRdWVzdGlvbsKgIChHbGVubiBIYW5jb2NrKQo+PsKgwqDCoCAz LiAwODoxOSBQTSAtIFJlOiA2ODBGUCBTcGVlZCBRdWVzdGlvbsKgIChLLlMuR29yZG9uKQo+PsKg wqDCoCA0LiAwODozOSBQTSAtIFJlOiBDb21tYW5kZXIgUGFydHPCoCAobGxveWQgc2lsdmVybWFu KQo+PsKgwqDCoCA1LiAwODo0NCBQTSAtIFJlOiBDb21tYW5kZXIgUGFydHPCoCAoSm9obiBJdmVz KQo+PsKgwqDCoCA2LiAwODo0NSBQTSAtIFJlOiBDb21tYW5kZXIgUGFydHPCoCAoSm9obiBWb3Jt YmF1bSkKPj7CoMKgwqAgNy4gMDg6NTggUE0gLSBSZTogQ29tbWFuZGVyIFBhcnRzwqAgKFBhdWwg R2VuZHJvbikKPj4gCj4+IAo+PiAKPj4gX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX1/C oCBNZXNzYWdlIDHCoCAKPj4gX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fXwo+ PiAKPj4gCj4+IFRpbWU6IDExOjI5OjM2IEFNIFBTVCBVUwo+PiBGcm9tOiAiUmFuZHkgRGV0dG1l ciwgQUlBIiA8cmNkZXR0bWVyQGNoYXJ0ZXIubmV0Pgo+PiBTdWJqZWN0OiBDb21tYW5kZXItTGlz dDogQ29tbWFuZGVyIFBhcnRzCj4+IAo+PiBIZWxsbyBDb21tYW5kZXIgZmFucywKPj4gCj4+IFdl IGFyZSB0cnlpbmcgdG8gbG9jYXRlIHNvbWUgbG93ZXIgZnVzZWxhZ2Ugc2tpbiBwYW5lbHMgZm9y IG15IDY4MEYuCj4+IEFueWJvZHkga25vdyBvZiBhdmFpbGFibGUgcGFydHMgb3IgYSBzYWx2YWdl IHBsYW5lIHNvbWV3aGVyZS4uPz/CoMKgIE1vZGVscwo+PiA1MDBBICYgQiwgNTYwLCBvciA2ODBG IHdpbGwgd29yay7CoCBUaGFua3MgbXVjaC4KPj4gCj4+IAo+PiBSYW5keSBEZXR0bWVyLCBBSUEs IE5DQVJCCj4+IAo+PiAKPj4gbG9nb1JFRC0xMjZ4MzhANzJkcGkKPj4gCj4+IAo+PiBEZXR0bWVy IEFyY2hpdGVjdHVyZQo+PiAKPj4gNjYzIEhpbGwgU3RyZWV0Cj4+IAo+PiBTYW4gTHVpcyBPYmlz cG8sIENBwqAgOTM0MDUKPj4gCj4+IDgwNSA1NDEgNDg2NCAvIGZheCA4MDUgNTQxIDQ4NjUKPj4g Cj4+IHd3dy5kZXR0bWVyYXJjaGl0ZWN0dXJlLmNvbQo+PiAKPj4gCj4+IF9fX19fX19fX19fX19f X19fX19fX19fX19fX19fX19fwqAgTWVzc2FnZSAywqAgCj4+IF9fX19fX19fX19fX19fX19fX19f X19fX19fX19fX19fX19fX18KPj4gCj4+IAo+PiBUaW1lOiAwNzoyODo0MyBQTSBQU1QgVVMKPj4g U3ViamVjdDogQ29tbWFuZGVyLUxpc3Q6IDY4MEZQIFNwZWVkIFF1ZXN0aW9uCj4+IEZyb206IEds ZW5uIEhhbmNvY2sgPGdsZW5uaEBHTUFJTC5DT00+Cj4+IAo+PiBTbyBJIHB1cmNoYXNlZCB0aGUg NjgwRlAgYW5kIGhhZCBteSBtZWNoYW5pYyBmbHkgaXQgYmFjayB0byBUTiBmcm9tIAo+PiBOTS7C oCBJdCB3YXMgYWJvdXQgYSA2MDBubSB0cmlwIGFuZCBJIGZvbGxvd2VkIGhpbSBpbiBteSAzMTBR IHdpdGggbXkgCj4+IHdpZmUgYW5kIDMgeWVhciBvbGQgc29uLsKgIFdlIGZsZXcgYmFjayBhdCA5 NTAwIGFuZCBoZSB3ZW50IHVwIHRvIAo+PiAxMzUwMC7CoCBJIGFtIG5vdCBzdXJlIGhvdyBoZSBt YW5hZ2VkIHRoZSBlbmdpbmVzIG9yIGhvdyBoZSBkaWQgCj4+IGFueXRoaW5nIGZvciB0aGF0IG1h dHRlciwgYnV0IHdoYXQgSSB3YXMgbW9zdCBpbnRlcmVzdGVkIGluIHdhcyBoaXMgCj4+IHNwZWVk LsKgIEkgcHVyY2hhc2VkIHRoaXMgYWlycGxhbmUgd2l0aCB0aGUgdW5kZXJzdGFuZGluZyB0aGF0 IGl0IHdhcyBhdAo+IGxlYXN0IGEgMjAwa25vdCBhaXJwbGFuZS4KPj4gCj4+IFNvIHdlIHRvb2sg b2ZmIGFuZCBwcm9jZWVkZWQgdG8gZmx5IGNyb3NzIGNvdW50cnkgZm9yIDMgaG91cnMuwqAgVG8g bXkgCj4+IGFic29sdXRlIGRpc2FwcG9pbnRtZW50IGhlIGFycml2ZWQgNyBtaW51dGVzIGFoZWFk IG9mIG1lLsKgIEhlIHNhaWQgaGUgCj4+IHdhcyBkb2luZyAxODFNUEggaW5kaWNhdGVkIHdoaWNo IHdhcyBiYXNpY2FsbHkgdGhlIHNhbWUgc3BlZWQgSSB3YXMgCj4+IGRvaW5nIGluIG15Cj4+IDMx MCBhdCBhIGxvd2VyIGFsdGl0dWRlLgo+PiAKPj4gU28gbXkgcXVlc3Rpb24gaXM6wqAgV2FzIEkg ZHVwcGVkIGFuZCB0aGUgNjgwRnAgaXMgdGhlIHNhbWUgc3BlZWQgYXMgCj4+IHRoZSAzMTBRP8Kg IEV4Y2VwdCBpdCBidXJucyB0d2ljZSBhcyBtdWNoIGdhcy7CoCBPciB3YXMgaGUgcGVyaGFwcyBu b3QgCj4+IGZseWluZyBpdCBwcm9wZXJseT/CoCBJIHN0aWxsIGxvdmUgdGhlIHBsYW5lIGFuZCBu b3QgY2hhbmdpbmcgbXkgbWluZCwgCj4+IGp1c3Qgd29uJ3QgYmUgcXVpdGUgYXMgaGFwcHkgd2l0 aCBpdCBpZiBpdCdzIHRoYXQgc2xvdy7CoCBJdCBoYXMgZmxhcCAKPj4gZ2FwIHNlYWxzIGFuZCB3 aW5nbGV0cyBhbHRob3VnaCBJJ20gbm90IHN1cmUgaG93IG11Y2ggZWl0aGVyIGFkZHMgdG8gCj4+ IGFjdHVhbCBzcGVlZC7CoCBIZSBhdmVyYWdlZCBhYm91dCA1NWdwaCBmdWVsIGJ1cm4gY29tcGFy ZWQgdG8gbXkgMjZncGguCj4+IAo+PiBFdmVuIGF0IDE5MGt0cyBoZSBzaG91bGQgaGF2ZSBiZWVu IGluZGljYXRpbmcgMjIwbXBoLgo+PiAKPj4gCj4+IFRoYW5rcywKPj4gCj4+IAo+PiAtLQo+PiAt LWdsZW5uIGhhbmNvY2sKPj4gCj4+IFlvdSBjYW4ndCB3aW4gYW4gYXJndW1lbnQgd2l0aCBhbiBp Z25vcmFudCBwZXJzb24uwqAgVGhleSdsbCBqdXN0IGRyYWcgCj4+IHlvdSBkb3duIHRvIHRoZWly IGxldmVsIGFuZCBiZWF0IHlvdSB3aXRoIGV4cGVyaWVuY2UuCj4+IAo+PiBfX19fX19fX19fX19f X19fX19fX19fX19fX19fX19fX8KgIE1lc3NhZ2UgM8KgIAo+PiBfX19fX19fX19fX19fX19fX19f X19fX19fX19fX19fX19fX19fCj4+IAo+PiAKPj4gVGltZTogMDg6MTk6NTIgUE0gUFNUIFVTCj4+ IFN1YmplY3Q6IFJFOiBDb21tYW5kZXItTGlzdDogNjgwRlAgU3BlZWQgUXVlc3Rpb24KPj4gRnJv bTogIksuUy5Hb3Jkb24iIDxjbG91ZGNyYWZ0QGFvbC5jb20+Cj4+IAo+PiBDaUFnSUNBS1IyeGxi bTRzQ2xWemFXNW5JRWxUUVNCamIyNWthWFJwYjI1eklHWnZjaUF4TXl3MU1EQW5MQ0F4T0RFZ1NX Cj4+IDVrYVdOaCAKPj4gZEdWa0lHbHpJREl5TXlCVWNuVmxMZ3BNYjNSeklHOW1JSEYxWlhOMGFX OXVjeUJ1WldWa0lIUnZJR0psSUdGdWMzZGxjbQo+PiBWa0lHSmwgCj4+IFptOXlaU0JoSUhCbGNt WnZjbTFoYm1ObElHTnZiWEJoY21semIyNGdZMkZ1SUdKbElHMWhaR1V1VjJsdVpITWdZV3h2Wm4K Pj4gUWdZWFFnCj4+IFltOTBhQ0JoYkhScGRIVmtaWE5RYjNkbGNpQnpaWFIwYVc1bmMwTnNhVzFp SUdGdVpDQmtaWE5qWlc1MElIQnliMlpwYkcKPj4gVkJkQ0IwIAo+PiBhR1VnWlc1a0lHOW1JSFJv WlNCa1lYa3NJSGx2ZFNCdGFXZG9kQ0JtYVc1a0lIUm9aU0JEUlRNeE1DQm9ZWE1nYzJsdGFXCj4+ IHhoY2lCago+PiBjblZwYzJVZ2NHVnlabTl5YldGdVkyVWdkRzhnYUc5M0lIbHZkU0J2Y0dWeVlY UmxJSGx2ZFhJZ1EyOXRiV0Z1WkdWeUxnCj4+IHBYYUdGMCAKPj4gSUhkcGJHd2djMlZ3WVhKaGRH VWdkR2hsSUhOb1pXVndJR1p5YjIwZ2RHaGxJR2R2WVhSeklHbHpJSFJvWlNCc2IyRmtJSAo+PiBs dmRTQmogCj4+IFlXNGdZMkZ5Y25rZ2IyWm1JSFJvWVhRZ016QXdNQ2NnWjNKaGMzTWdjM1J5YVhB Z2VXOTFJSGRoYm5RZ2RHOGdZbUZ6WlMKPj4gQmhkQzRLCj4+IFN5NVRMa2R2Y21SdmJsTmxiblFn YjI0Z2RHaGxJRVpzZWNLZzhKK01rQW9LTFMwdExTMHRMUzBnVDNKcFoybHVZV3dnYlcKPj4gU3k1 VExrZHZjbVJ2YmxObGJuUWdiMjRnZEdobElFWnNlY0tnOEorVnpjMkZuCj4+IFpTQXRMUzB0TFMw dExRcEdjbTl0T2lCSGJHVnViaUJJWVc1amIyTnJJRHhuYkdWdWJtaEFSMDFCU1V3dVEwOU5QaUFL UkcKPj4gRjBaVG9nIAo+PiBNakF2TURjdk1qQXhOU0FnTWpBNk1qY2dJQ2hIVFZRdE1EYzZNREFw SUFwVWJ6b2dZMjl0YldGdVpHVnlMV3hwYzNSQWJXCj4+IEYwY205dSAKPj4gYVdOekxtTnZiU0FL VTNWaWFtVmpkRG9nUTI5dGJXRnVaR1Z5TFV4cGMzUTZJRFk0TUVaUUlGTndaV1ZrSUZGMVpYTjBh Vwo+PiA5dUlBb0sgCj4+IFUyOGdTU0J3ZFhKamFHRnpaV1FnZEdobElEWTRNRVpRSUdGdVpDQm9Z V1FnYlhrZ2JXVmphR0Z1YVdNZ1pteDVJR2wwSUcKPj4gSmhZMnNnIAo+PiBkRzhnVkU0Z1puSnZi U0JPVFM3Q29DQkpkQ0IzWVhNZ1lXSnZkWFFnWVNBMk1EQnViU0IwY21sd0lHRnVaQ0JKSUdadmJH Cj4+IHh2ZDJWayAKPj4gSUdocGJTQnBiaUJ0ZVNBek1UQlJJSGRwZEdnZ2JYa2dkMmxtWlNCaGJt UWdNeUI1WldGeUlHOXNaQ0J6YjI0dXdxQWdWMgo+PiBVZ1pteGwgCj4+IGR5QmlZV05ySUdGMElE azFNREFnWVc1a0lHaGxJSGRsYm5RZ2RYQWdkRzhnTVRNMU1EQXV3cUFnU1NCaGJTQnViM1FnYzMK Pj4gVnlaU0JvCj4+IGIzY2dhR1VnYldGdVlXZGxaQ0IwYUdVZ1pXNW5hVzVsY3lCdmNpQm9iM2Nn YUdVZ1pHbGtJR0Z1ZVhSb2FXNW5JR1p2Y2kKPj4gQjBhR0YwIAo+PiBJRzFoZEhSbGNpd2dZblYw SUhkb1lYUWdTU0IzWVhNZ2JXOXpkQ0JwYm5SbGNtVnpkR1ZrSUdsdUlIZGhjeUJvYVhNZ2MzCj4+ IEJsWldRdSAKPj4gd3FBZ1NTQndkWEpqYUdGelpXUWdkR2hwY3lCaGFYSndiR0Z1WlNCM2FYUm9J SFJvWlNCMWJtUmxjbk4wWVc1a2FXNW5JSAo+PiBSb1lYUWcgCj4+IGFYUWdkMkZ6SUdGMElHeGxZ WE4wSUdFZ01qQXdhMjV2ZENCaGFYSndiR0Z1WlM0S1UyOGdkMlVnZEc5dmF5QnZabVlnWVcKPj4g NWtJSEJ5Cj4+IGIyTmxaV1JsWkNCMGJ5Qm1iSGtnWTNKdmMzTWdZMjkxYm5SeWVTQm1iM0lnTXlC b2IzVnljeTdDb0NCVWJ5QnRlU0JoWW4KPj4gTnZiSFYwIAo+PiBaU0JrYVhOaGNIQnZhVzUwYldW dWRDQm9aU0JoY25KcGRtVmtJRGNnYldsdWRYUmxjeUJoYUdWaFpDQnZaaUJ0WlM3Q29DCj4+IEJJ WlNCeiAKPj4gWVdsa0lHaGxJSGRoY3lCa2IybHVaeUF4T0RGTlVFZ2dhVzVrYVdOaGRHVmtJSGRv YVdOb0lIZGhjeUJpWVhOcFkyRnNiSAo+PiBrZ2RHaGwgCj4+IElITmhiV1VnYzNCbFpXUWdTU0Iz WVhNZ1pHOXBibWNnYVc0Z2JYa2dNekV3SUdGMElHRWdiRzkzWlhJZ1lXeDBhWFIxWkcKPj4gVXVD bE52IAo+PiBJRzE1SUhGMVpYTjBhVzl1SUdsek9pRENvRmRoY3lCSklHUjFjSEJsWkNCaGJtUWdk R2hsSURZNE1FWndJR2x6SUhSb1pTCj4+IEJ6WVcxbCAKPj4gSUhOd1pXVmtJR0Z6SUhSb1pTQXpN VEJSUDhLZ0lFVjRZMlZ3ZENCcGRDQmlkWEp1Y3lCMGQybGpaU0JoY3lCdGRXTm9JRwo+PiBkaGN5 N0MKPj4gb0NCUGNpQjNZWE1nYUdVZ2NHVnlhR0Z3Y3lCdWIzUWdabXg1YVc1bklHbDBJSEJ5YjNC bGNteDVQOEtnSUVrZ2MzUnBiRwo+PiB3Z2JHOTIgCj4+IFpTQjBhR1VnY0d4aGJtVWdZVzVrSUc1 dmRDQmphR0Z1WjJsdVp5QnRlU0J0YVc1a0xDQnFkWE4wSUhkdmJpZDBJR0psSUgKPj4gRjFhWFJs IAo+PiBJR0Z6SUdoaGNIQjVJSGRwZEdnZ2FYUWdhV1lnYVhRbmN5QjBhR0YwSUhOc2IzY3V3cUFn U1hRZ2FHRnpJR1pzWVhBZ1oyCj4+IEZ3SUhObCAKPj4gWVd4eklHRnVaQ0IzYVc1bmJHVjBjeUJo YkhSb2IzVm5hQ0JKSjIwZ2JtOTBJSE4xY21VZ2FHOTNJRzExWTJnZ1pXbDBhRwo+PiBWeUlHRmsg Cj4+IFpITWdkRzhnWVdOMGRXRnNJSE53WldWa0xzS2dJRWhsSUdGMlpYSmhaMlZrSUdGaWIzVjBJ RFUxWjNCb0lHWjFaV3dnWW4KPj4gVnliaUJqIAo+PiBiMjF3WVhKbFpDQjBieUJ0ZVNBeU5tZHdh QzRLUlhabGJpQmhkQ0F4T1RCcmRITWdhR1VnYzJodmRXeGtJR2hoZG1VZ1ltCj4+IFZsYmlCcAo+ PiBibVJwWTJGMGFXNW5JREl5TUcxd2FDNEtDbFJvWVc1cmN5d0tDaTB0SUFvdExXZHNaVzV1SUdo aGJtTnZZMnNLV1c5MUlHCj4+IE5oYmlkMCAKPj4gSUhkcGJpQmhiaUJoY21kMWJXVnVkQ0IzYVhS b0lHRnVJR2xuYm05eVlXNTBJSEJsY25OdmJpN0NvQ0JVYUdWNUoyeHNJRwo+PiBwMWMzUWcgCj4+ IFpISmhaeUI1YjNVZ1pHOTNiaUIwYnlCMGFHVnBjaUJzWlhabGJDQmhibVFnWW1WaGRDQjViM1Vn ZDJsMGFDQmxlSEJsY20KPj4gbGxibU5sCj4+IExnb0tDZ29LQ2w4dFBUMDlQVDA5UFQwOVBUMDlQ VDA5UFQwOVBUMDlQVDA5UFQwOVBUMDlQVDA5UFQwOVBUMDlQVDA5UFQKPj4gMDlQVDA5Cj4+IFBU MDlQVDA5UFQwOVBUMDlDbDh0UFNBZ0lDQWdJQ0FnSUNBdElGUm9aU0JEYjIxdFlXNWtaWEl0VEds emRDQkZiV0ZwYkMKPj4gQkdiM0oxCj4+IGJTQXRDbDh0UFNCVmMyVWdkR2hsSUUxaGRISnZibWxq Y3lCTWFYTjBJRVpsWVhSMWNtVnpJRTVoZG1sbllYUnZjaUIwYnkKPj4gQmljbTkzIAo+PiBjMlVL WHkwOUlIUm9aU0J0WVc1NUlFeHBjM1FnZFhScGJHbDBhV1Z6SUhOMVkyZ2dZWE1nVEdsemRDQlZi aTlUZFdKelkzCj4+IEpwY0hScCAKPj4gYjI0c0NsOHRQU0JCY21Ob2FYWmxJRk5sWVhKamFDQW1J RVJ2ZDI1c2IyRmtMQ0EzTFVSaGVTQkNjbTkzYzJVc0lFTm9ZWAo+PiBRc0lFWkIgCj4+IFVTd0tY eTA5SUZCb2IzUnZjMmhoY21Vc0lHRnVaQ0J0ZFdOb0lHMTFZMmdnYlc5eVpUb0tYeTA5Q2w4dFBT QWdJQzB0UGkKPj4gQm9kSFJ3Cj4+IE9pOHZkM2QzTG0xaGRISnZibWxqY3k1amIyMHZUbUYyYVdk aGRHOXlQME52YlcxaGJtUmxjaTFNYVhOMENsOHRQUXBmTFQKPj4gMDlQVDA5IAo+PiBQVDA5UFQw OVBUMDlQVDA5UFQwOVBUMDlQVDA5UFQwOVBUMDlQVDA5UFQwOVBUMDlQVDA5UFQwOVBUMDlQVDA5 UFQwOVBUCj4+IDA5UFFwZiAKPj4gTFQwZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0F0SUUxQlZGSlBUa2xE VXlCWFJVSWdSazlTVlUxVElDMEtYeTA5SUZOaGJXVWdaMwo+PiBKbFlYUWcgCj4+IFkyOXVkR1Z1 ZENCaGJITnZJR0YyWVdsc1lXSnNaU0IyYVdFZ2RHaGxJRmRsWWlCR2IzSjFiWE1oQ2w4dFBRcGZM VDBnSUMKPj4gQXRMVDRnCj4+IGFIUjBjRG92TDJadmNuVnRjeTV0WVhSeWIyNXBZM011WTI5dENs OHRQUXBmTFQwOVBUMDlQVDA5UFQwOVBUMDlQVDA5UFQKPj4gMDlQVDA5IAo+PiBQVDA5UFQwOVBU MDlQVDA5UFQwOVBUMDlQVDA5UFQwOVBUMDlQVDA5UFQwOVBUMDlQUXBmTFQwZ0lDQWdJQ0FnSUNB Z0lDCj4+IEFnTFNCTSAKPj4gYVhOMElFTnZiblJ5YVdKMWRHbHZiaUJYWldJZ1UybDBaU0F0Q2w4 dFBTQWdWR2hoYm1zZ2VXOTFJR1p2Y2lCNWIzVnlJRwo+PiBkbGJtVnkgCj4+IGIzVnpJSE4xY0hC dmNuUWhDbDh0UFNBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lDQWdJQ0FnSUNBZ0lDMU5ZWFIw SUUKPj4gUnlZV3hzCj4+IFpTd2dUR2x6ZENCQlpHMXBiaTRLWHkwOUlDQWdMUzArSUdoMGRIQTZM eTkzZDNjdWJXRjBjbTl1YVdOekxtTnZiUzlqYjIKPj4gWlN3Z1RHbHpkQ0JCWkcxcGJpNEtYeTA5 SUNBZ0xTMCs1MGNtbGkKPj4gZFhScGIyNEtYeTA5UFQwOVBUMDlQVDA5UFQwOVBUMDlQVDA5UFQw OVBUMDlQVDA5UFQwOVBUMDlQVDA5UFQwOVBUMDlQVAo+PiAwOVBUMDkKPj4gUFQwOVBUMDlQVDA5 UFQwS0NnPQo+PiAKPj4gX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX1/CoCBNZXNzYWdl IDTCoCAKPj4gX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fXwo+PiAKPj4gCj4+ IFRpbWU6IDA4OjM5OjUwIFBNIFBTVCBVUwo+PiBGcm9tOiAibGxveWQgc2lsdmVybWFuIiA8bGxv eWRzc3MxMUBNU04uQ09NPgo+PiBTdWJqZWN0OiBSZTogQ29tbWFuZGVyLUxpc3Q6IENvbW1hbmRl ciBQYXJ0cwo+PiAKPj4gdlw6KiB7IEJFSEFWSU9SOiB1cmwoI2RlZmF1bHQjVk1MKSB9IG9cOiog eyBCRUhBVklPUjogCj4+IHVybCgjZGVmYXVsdCNWTUwpIH0gd1w6KiB7IEJFSEFWSU9SOiB1cmwo I2RlZmF1bHQjVk1MKSB9IC5zaGFwZSB7Cj4+IEJFSEFWSU9SOiB1cmwoI2RlZmF1bHQjVk1MKSB9 wqAgPCEtLSAvKiBGb250IERlZmluaXRpb25zICovIEBmb250LWZhY2UgCj4+IHtmb250LWZhbWls eTpDYWxpYnJpOyBwYW5vc2UtMToyIDE1IDUgMiAyIDIgNCAzIDIgNDt9IEBmb250LWZhY2UgCj4+ IHtmb250LWZhbWlseTpUYWhvbWE7IHBhbm9zZS0xOjIgMTEgNiA0IDMgNSA0IDQgMiA0O30gLyog U3R5bGUgCj4+IERlZmluaXRpb25zICovIHAuTXNvTm9ybWFsLCBsaS5Nc29Ob3JtYWwsIGRpdi5N c29Ob3JtYWwge21hcmdpbjowaW47IAo+PiBtYXJnaW4tYm90dG9tOi4wMDAxcHQ7IGZvbnQtc2l6 ZToxMS4wcHQ7IAo+PiBmb250LWZhbWlseToiQ2FsaWJyaSIsInNhbnMtc2VyaWYiO30gYTpsaW5r LCBzcGFuLk1zb0h5cGVybGluayAKPj4ge21zby1zdHlsZS1wcmlvcml0eTo5OTsgY29sb3I6Ymx1 ZTsgdGV4dC1kZWNvcmF0aW9uOnVuZGVybGluZTt9IAo+PiBhOnZpc2l0ZWQsIHNwYW4uTXNvSHlw ZXJsaW5rRm9sbG93ZWQge21zby1zdHlsZS1wcmlvcml0eTo5OTsgCj4+IGNvbG9yOnB1cnBsZTsg dGV4dC1kZWNvcmF0aW9uOnVuZGVybGluZTt9IHAuTXNvQWNldGF0ZSwgbGkuTXNvQWNldGF0ZSwg Cj4+IGRpdi5Nc29BY2V0YXRlIHttc28tc3R5bGUtcHJpb3JpdHk6OTk7IG1zby1zdHlsZS1saW5r OiJCYWxsb29uIFRleHQgCj4+IENoYXIiOyBtYXJnaW46MGluOyBtYXJnaW4tYm90dG9tOi4wMDAx cHQ7IGZvbnQtc2l6ZTo4LjBwdDsgCj4+IGZvbnQtZmFtaWx5OiJUYWhvbWEiLCJzYW5zLXNlcmlm Ijt9IHNwYW4uRW1haWxTdHlsZTE3IAo+PiB7bXNvLXN0eWxlLXR5cGU6cGVyc29uYWwtY29tcG9z ZTsgZm9udC1mYW1pbHk6IkNhbGlicmkiLCJzYW5zLXNlcmlmIjsKPj4gY29sb3I6d2luZG93dGV4 dDt9IHNwYW4uQmFsbG9vblRleHRDaGFyIHttc28tc3R5bGUtbmFtZToiQmFsbG9vbiBUZXh0IAo+ PiBDaGFyIjsgbXNvLXN0eWxlLXByaW9yaXR5Ojk5OyBtc28tc3R5bGUtbGluazoiQmFsbG9vbiBU ZXh0IjsgCj4+IGZvbnQtZmFtaWx5OiJUYWhvbWEiLCJzYW5zLXNlcmlmIjt9IC5Nc29DaHBEZWZh dWx0IAo+PiB7bXNvLXN0eWxlLXR5cGU6ZXhwb3J0LW9ubHk7IGZvbnQtZmFtaWx5OiJDYWxpYnJp Iiwic2Fucy1zZXJpZiI7fSAKPj4gQHBhZ2UKPj4gV29yZFNlY3Rpb24xIHtzaXplOjguNWluIDEx LjBpbjsgbWFyZ2luOjEuMGluIDEuMGluIDEuMGluIDEuMGluO30KPj4gZGl2LldvcmRTZWN0aW9u MSB7cGFnZTpXb3JkU2VjdGlvbjE7fSAtLT4KPj4gCj4+IFJhbmR5LCBiZSBjYXJlZnVsIHRoZSBy aXZldCBob2xlcyBwcm9iYWJseSB3b250IGxpbmUgdXAgd2l0aCB5b3Vycy4KPj4gCj4+IAo+PiAt LS0tLSBPcmlnaW5hbCBNZXNzYWdlIC0tLS0tCj4+IAo+PiBGcm9tOiBSYW5keSBEZXR0bWVyLCBB SUE8bWFpbHRvOnJjZGV0dG1lckBjaGFydGVyLm5ldD4KPj4gCj4+IAo+PiBTZW50OiBNb25kYXks IEp1bHkgMjAsIDIwMTUgMjoyOSBQTQo+PiAKPj4gU3ViamVjdDogQ29tbWFuZGVyLUxpc3Q6IENv bW1hbmRlciBQYXJ0cwo+PiAKPj4gCj4+IEhlbGxvIENvbW1hbmRlciBmYW5zLAo+PiAKPj4gV2Ug YXJlIHRyeWluZyB0byBsb2NhdGUgc29tZSBsb3dlciBmdXNlbGFnZSBza2luIHBhbmVscyBmb3Ig bXkgNjgwRi7CoCAKPj4gQW55Ym9keSBrbm93IG9mIGF2YWlsYWJsZSBwYXJ0cyBvciBhIHNhbHZh Z2UgcGxhbmUgc29tZXdoZXJlLi4/P8KgwqAgCj4+IE1vZGVscyA1MDBBICYgQiwgNTYwLCBvciA2 ODBGIHdpbGwgd29yay7CoCBUaGFua3MgbXVjaC4KPj4gCj4+IAo+PiBSYW5keSBEZXR0bWVyLCBB SUEsIE5DQVJCCj4+IAo+PiAKPj4gRGV0dG1lciBBcmNoaXRlY3R1cmUKPj4gCj4+IDY2MyBIaWxs IFN0cmVldAo+PiAKPj4gU2FuIEx1aXMgT2Jpc3BvLCBDQcKgIDkzNDA1Cj4+IAo+PiA4MDUgNTQx IDQ4NjQgLyBmYXggODA1IDU0MSA0ODY1Cj4+IAo+PiB3d3cuZGV0dG1lcmFyY2hpdGVjdHVyZS5j b20KPj4gCj4+IAo+PiBfX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX8KgIE1lc3NhZ2Ug NcKgIAo+PiBfX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fCj4+IAo+PiAKPj4g VGltZTogMDg6NDQ6MjMgUE0gUFNUIFVTCj4+IFN1YmplY3Q6IFJlOiBDb21tYW5kZXItTGlzdDog Q29tbWFuZGVyIFBhcnRzCj4+IEZyb206IEpvaG4gSXZlcyA8c2VhZmV2ZXIzMkBob3RtYWlsLmNv bT4KPj4gCj4+IEknZCBoYXZlIHRob3VnaHQgdGhlIGJlc3Qgd2F5IHRvIGRvIGl0IGlzIGdldCBh IHNoZWV0aWUgYW5kIGluc3RhbGwgCj4+IG5ldyBtYXRlIHJpYWwuIFRoZSBjb3N0IGlzIHByb2Jh Ymx5IGdvaW5nIHRvIGJlIGNsb3NlIGFuZCB0aGUgam9iIAo+PiBiZXR0ZXIgZG9uZQo+PiAKPj4g Sm9obiBJdmVzCj4+IEFDIDY4NQo+PiBWSCBOSlQKPj4gCj4+IFNlbnQgZnJvbSBteSBpUGFkCj4+ IAo+Pj4gT24gMjEgSnVsIDIwMTUsIGF0IDE6NDEgcG0sIGxsb3lkIHNpbHZlcm1hbiA8bGxveWRz c3MxMUBNU04uQ09NPiB3cm90ZToKPj4+IAo+Pj4gUmFuZHksIGJlIGNhcmVmdWwgdGhlIHJpdmV0 IGhvbGVzIHByb2JhYmx5IHdvbnQgbGluZSB1cCB3aXRoIHlvdXJzLgo+Pj4gLS0tLS0gT3JpZ2lu YWwgTWVzc2FnZSAtLS0tLQo+Pj4gRnJvbTogUmFuZHkgRGV0dG1lciwgQUlBCj4+PiBUbzogY29t bWFuZGVyLWxpc3RAbWF0cm9uaWNzLmNvbQo+Pj4gU2VudDogTW9uZGF5LCBKdWx5IDIwLCAyMDE1 IDI6MjkgUE0KPj4+IFN1YmplY3Q6IENvbW1hbmRlci1MaXN0OiBDb21tYW5kZXIgUGFydHMKPj4+ IAo+Pj4gSGVsbG8gQ29tbWFuZGVyIGZhbnMsCj4+PiBXZSBhcmUgdHJ5aW5nIHRvIGxvY2F0ZSBz b21lIGxvd2VyIGZ1c2VsYWdlIHNraW4gcGFuZWxzIGZvciBteSA2ODBGLsKgIAo+Pj4gQW55Ygo+ PiBvZHkga25vdyBvZiBhdmFpbGFibGUgcGFydHMgb3IgYSBzYWx2YWdlIHBsYW5lIHNvbWV3aGVy ZS4uPz/CoMKgIE1vZGVscyA1MDBBCj4gJgo+PiBCLCA1NjAsIG9yIDY4MEYgd2lsbCB3b3JrLsKg IFRoYW5rcyBtdWNoLgo+Pj4gCj4+PiBSYW5keSBEZXR0bWVyLCBBSUEsIE5DQVJCCj4+PiAKPj4+ IDxpbWFnZTAwMS5naWY+Cj4+PiAKPj4+IERldHRtZXIgQXJjaGl0ZWN0dXJlCj4+PiA2NjMgSGls bCBTdHJlZXQKPj4+IFNhbiBMdWlzIE9iaXNwbywgQ0HCoCA5MzQwNQo+Pj4gODA1IDU0MSA0ODY0 IC8gZmF4IDgwNSA1NDEgNDg2NQo+Pj4gd3d3LmRldHRtZXJhcmNoaXRlY3R1cmUuY29tCj4+IAo+ PiBfX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX8KgIE1lc3NhZ2UgNsKgIAo+PiBfX19f X19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fCj4+IAo+PiAKPj4gVGltZTogMDg6NDU6 NDUgUE0gUFNUIFVTCj4+IEZyb206IEpvaG4gVm9ybWJhdW0gPGpvaG5Adm9ybWJhdW0uY29tPgo+ PiBTdWJqZWN0OiBSZTogQ29tbWFuZGVyLUxpc3Q6IENvbW1hbmRlciBQYXJ0cwo+PiAKPj4gT2sg dGhhdCB3YXMgZnVubnksIExsb3lkLiBUaGFua3MgZm9yIHRoZSBsYXVnaCEKPj4gCj4+IFNlbnQg ZnJvbSBteSBpUGFkCj4+IAo+PiBPbiBKdWwgMjAsIDIwMTUsIGF0IDg6NDMgUE0sIGxsb3lkIHNp bHZlcm1hbiA8bGxveWRzc3MxMUBtc24uY29tPiB3cm90ZToKPj4gCj4+wqAgUmFuZHksIGJlIGNh cmVmdWwgdGhlIHJpdmV0IGhvbGVzIHByb2JhYmx5IHdvbnQgbGluZSB1cCB3aXRoIHlvdXJzLgo+ PiAKPj4gLS0tLS0gT3JpZ2luYWwgTWVzc2FnZSAtLS0tLQo+PiAqRnJvbToqIFJhbmR5IERldHRt ZXIsIEFJQSA8cmNkZXR0bWVyQGNoYXJ0ZXIubmV0Pgo+PiAqVG86KiBjb21tYW5kZXItbGlzdEBt YXRyb25pY3MuY29tCj4+ICpTZW50OiogTW9uZGF5LCBKdWx5IDIwLCAyMDE1IDI6MjkgUE0KPj4g KlN1YmplY3Q6KiBDb21tYW5kZXItTGlzdDogQ29tbWFuZGVyIFBhcnRzCj4+IAo+PiBIZWxsbyBD b21tYW5kZXIgZmFucywKPj4gCj4+IFdlIGFyZSB0cnlpbmcgdG8gbG9jYXRlIHNvbWUgbG93ZXIg ZnVzZWxhZ2Ugc2tpbiBwYW5lbHMgZm9yIG15IDY4MEYuCj4+IEFueWJvZHkga25vdyBvZiBhdmFp bGFibGUgcGFydHMgb3IgYSBzYWx2YWdlIHBsYW5lIHNvbWV3aGVyZS4uPz/CoMKgIE1vZGVscwo+ PiA1MDBBICYgQiwgNTYwLCBvciA2ODBGIHdpbGwgd29yay7CoCBUaGFua3MgbXVjaC4KPj4gCj4+ IAo+PiBSYW5keSBEZXR0bWVyLCBBSUEsIE5DQVJCCj4+IAo+PiAKPj4gPGltYWdlMDAxLmdpZj4K Pj4gCj4+IAo+PiAqRGV0dG1lciBBcmNoaXRlY3R1cmUqCj4+IAo+PiAqNjYzIEhpbGwgU3RyZWV0 Kgo+PiAKPj4gKlNhbiBMdWlzIE9iaXNwbywgQ0HCoCA5MzQwNSoKPj4gCj4+ICo4MDUgNTQxIDQ4 NjQgLyBmYXggODA1IDU0MSA0ODY1Kgo+PiAKPj4gKnd3dy5kZXR0bWVyYXJjaGl0ZWN0dXJlLmNv bSA8aHR0cDovL3d3dy5kZXR0bWVyYXJjaGl0ZWN0dXJlLmNvbT4qCj4+IAo+PiBfX19fX19fX19f X19fX19fX19fX19fX19fX19fX19fX8KgIE1lc3NhZ2UgN8KgIAo+PiBfX19fX19fX19fX19fX19f X19fX19fX19fX19fX19fX19fX19fCj4+IAo+PiAKPj4gVGltZTogMDg6NTg6NDMgUE0gUFNUIFVT Cj4+IFN1YmplY3Q6IFJlOiBDb21tYW5kZXItTGlzdDogQ29tbWFuZGVyIFBhcnRzCj4+IEZyb206 IFBhdWwgR2VuZHJvbiA8cnBtY29tbWFuZGVyQEdNQUlMLkNPTT4KPj4gCj4+IFJhbmR5LCBJIGhh dmUgdHdvIGRvbm9ycywgb25lIGZscCBhbmQgYSA2OTAgSSBhbHNvIGhhdmUgYSBTaGVldG1ldGFs IAo+PiBndXkgdGhhdCBjYW4gbWFrZSB0aGUgc2tpbnMgYW5kIGNpcmN1bWZlcnJlbnRpYWxzIGZy b20gdGhlIHRlbXBsYXRlcyAKPj4geW91IHJlbW92ZSBmcm9tIHRoZSBzbWFsbGVyIGZyYW1lcy4g SSBhbHNvIGhhdmUgdGhlIHogYnJhY2tldHMgYW5kIHogCj4+IGNvdXBsaW5ncy4gSSBoYXZlIGEg ZnVsbCBzZXQgb2YgbGRnIGdlYXIuIFByZXNzdXJpemVkIHdpbmRzaGllbGRzIGFuZCAKPj4gc2lk ZSB3aW5kb3dzLiBMZXQgbWUga25vdyBpZiB5b3UgbmVlZCBhbnl0aGluZy4gOTU0LTU0Ny0zMDAy IFBhdWwgCj4+IEdlbmRyb24gT24gSnVsIDIwLCAyMDE1IDI6MzIgUE0sICJSYW5keSBEZXR0bWVy LCBBSUEiIAo+PiA8cmNkZXR0bWVyQGNoYXJ0ZXIubmV0Pgo+PiB3cm90ZToKPj4gCj4+PiBIZWxs byBDb21tYW5kZXIgZmFucywKPj4+IAo+Pj4gV2UgYXJlIHRyeWluZyB0byBsb2NhdGUgc29tZSBs b3dlciBmdXNlbGFnZSBza2luIHBhbmVscyBmb3IgbXkgNjgwRi4KPj4+IEFueWJvZHkga25vdyBv ZiBhdmFpbGFibGUgcGFydHMgb3IgYSBzYWx2YWdlIHBsYW5lIHNvbWV3aGVyZS4uPz/CoMKgIE1v ZGVscwo+Pj4gNTAwQSAmIEIsIDU2MCwgb3IgNjgwRiB3aWxsIHdvcmsuwqAgVGhhbmtzIG11Y2gu Cj4+PiAKPj4+IAo+Pj4gUmFuZHkgRGV0dG1lciwgQUlBLCBOQ0FSQgo+Pj4gCj4+PiAKPj4+IFtp bWFnZTogbG9nb1JFRC0xMjZ4MzhANzJkcGldCj4+PiAKPj4+IAo+Pj4gKkRldHRtZXIgQXJjaGl0 ZWN0dXJlKgo+Pj4gCj4+PiAqNjYzIEhpbGwgU3RyZWV0Kgo+Pj4gCj4+PiAqU2FuIEx1aXMgT2Jp c3BvLCBDQcKgIDkzNDA1Kgo+Pj4gCj4+PiAqODA1IDU0MSA0ODY0IDw4MDUlMjA1NDElMjA0ODY0 PiAvIGZheCA4MDUgNTQxIDQ4NjUgCj4+PiA8ODA1JTIwNTQxJTIwNDg2NT4qCj4+PiAKPj4+ICp3 d3cuZGV0dG1lcmFyY2hpdGVjdHVyZS5jb20gPGh0dHA6Ly93d3cuZGV0dG1lcmFyY2hpdGVjdHVy ZS5jb20+Kgo+IAo+IAo+IAo+IAo+IAo+IAo+IAo+IAo+IAo+IAoKCl8tPT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09Cl8tPcKgwqDCoMKg wqDCoMKgwqDCoCAtIFRoZSBDb21tYW5kZXItTGlzdCBFbWFpbCBGb3J1bSAtCl8tPSBVc2UgdGhl IE1hdHJvbmljcyBMaXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0byBicm93c2UKXy09IHRoZSBtYW55 IExpc3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sCl8tPSBBcmNoaXZl IFNlYXJjaCAmIERvd25sb2FkLCA3LURheSBCcm93c2UsIENoYXQsIEZBUSwKXy09IFBob3Rvc2hh cmUsIGFuZCBtdWNoIG11Y2ggbW9yZToKXy09Cl8tPcKgwqAgLS0+IGh0dHA6Ly93d3cubWF0cm9u aWNzLmNvbS9OYXZpZ2F0b3I/Q29tbWFuZGVyLUxpc3QKXy09Cl8tPT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09Cl8tPcKgwqDCoMKgwqDC oMKgwqDCoMKgwqDCoMKgwqAgLSBNQVRST05JQ1MgV0VCIEZPUlVNUyAtCl8tPSBTYW1lIGdyZWF0 IGNvbnRlbnQgYWxzbyBhdmFpbGFibGUgdmlhIHRoZSBXZWIgRm9ydW1zIQpfLT0KXy09wqDCoCAt LT4gaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tCl8tPQpfLT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT3CoMKgwqDCoMKgwqDC oMKgwqDCoMKgwqAgLSBMaXN0IENvbnRyaWJ1dGlvbiBXZWIgU2l0ZSAtCl8tPcKgIFRoYW5rIHlv dSBmb3IgeW91ciBnZW5lcm91cyBzdXBwb3J0IQpfLT3CoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDC oMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgIC1NYXR0IERyYWxsZSwgTGlzdCBBZG1p bi4KXy09wqDCoCAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbgpfLT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PQoKCgo ________________________________________________________________________________
Subject: Re: Commander-List Digest: 7 Msgs - 07/20/15
Date: Jul 22, 2015
Haha John - will come to terms with all of that someday!! Sent from my iPhone > On 22 Jul 2015, at 7:36 am, John Vormbaum wrote: > > > All US emails arrive upside down for you, dont they Russell? > > Cheers from topside, > > /John > > >> On Jul 21, 2015, at 2:26 PM, Russell Legg wrote: >> >> >> Sometimes scrambled here - would rather receive emails sunny side up! >> >> Sent from my iPhone >> >>> On 22 Jul 2015, at 1:19 am, Randy Dettmer, AIA wrote: >>> >>> >>> Hi Dan, >>> Yes, it's my 68F that has been for sale. Not currently listed. It will >>> likely be on the market again in about a year. I am using it too much now >>> for business to sell. >>> >>> Randy >>> >>> Dettmer Architecture >>> 663 Hill Street >>> San Luis Obispo, CA 93405 >>> 805 541 4864 / fax 805 541 4865 >>> www.dettmerarchitecture.com >>> >>> -----Original Message----- >>> From: owner-commander-list-server(at)matronics.com >>> [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Dan >>> Sent: Tuesday, July 21, 2015 5:49 AM >>> To: commander-list(at)matronics.com >>> Subject: Commander-List: Re: Commander-List Digest: 7 Msgs - 07/20/15 >>> >>> >>> >>>> Randy, is that for your 680F that I have seen for sale? >>> >>> Keith and Lloyd, please see how your post came through all scrambled to >>> me. Keith and I have have discussed this before, is anyone besides me >>> receiving scrambled messages as shown below? >>> Thanks, Dan >>>> >>>> ================================================= >>>> Online Versions of Today's List Digest Archive >>>> ================================================= >>>> >>>> Today's complete Commander-List Digest can also be found in either of >>>> the two Web Links listed below. The .html file includes the Digest >>>> formatted in HTML for viewing with a web browser and features >>>> Hyperlinked Indexes and Message Navigation. The .txt file includes >>>> the plain ASCII version of the Commander-List Digest and can be viewed >>>> with a generic text editor such as Notepad or with a web browser. >>>> >>>> HTML Version: >>>> >>>> >>>> http://www.matronics.com/digest/digestview.php?Style=82701&View=html&C >>>> hapter 15-07-20&Archive=Commander >>>> >>>> Text Version: >>>> >>>> >>>> http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Ch >>>> apter 15-07-20&Archive=Commander >>>> >>>> >>>> =============================================== >>>> EMail Version of Today's List Digest Archive >>>> =============================================== >>>> >>>> >>>> ---------------------------------------------------------- >>>> Commander-List Digest Archive >>>> --- >>>> Total Messages Posted Mon 07/20/15: 7 >>>> ---------------------------------------------------------- >>>> >>>> >>>> Today's Message Index: >>>> ---------------------- >>>> >>>> 1. 11:29 AM - Commander Parts (Randy Dettmer, AIA) >>>> 2. 07:28 PM - 680FP Speed Question (Glenn Hancock) >>>> 3. 08:19 PM - Re: 680FP Speed Question (K.S.Gordon) >>>> 4. 08:39 PM - Re: Commander Parts (lloyd silverman) >>>> 5. 08:44 PM - Re: Commander Parts (John Ives) >>>> 6. 08:45 PM - Re: Commander Parts (John Vormbaum) >>>> 7. 08:58 PM - Re: Commander Parts (Paul Gendron) >>>> >>>> >>>> >>>> ________________________________ Message 1 >>>> _____________________________________ >>>> >>>> >>>> From: "Randy Dettmer, AIA" <rcdettmer(at)charter.net> >>>> Subject: Commander-List: Commander Parts >>>> >>>> Hello Commander fans, >>>> >>>> We are trying to locate some lower fuselage skin panels for my 680F. >>>> Anybody know of available parts or a salvage plane somewhere..?? Models >>>> 500A & B, 560, or 680F will work. Thanks much. >>>> >>>> >>>> Randy Dettmer, AIA, NCARB >>>> >>>> >>>> logoRED-126x38@72dpi >>>> >>>> >>>> Dettmer Architecture >>>> >>>> 663 Hill Street >>>> >>>> San Luis Obispo, CA 93405 >>>> >>>> 805 541 4864 / fax 805 541 4865 >>>> >>>> www.dettmerarchitecture.com >>>> >>>> >>>> ________________________________ Message 2 >>>> _____________________________________ >>>> >>>> >>>> Subject: Commander-List: 680FP Speed Question >>>> From: Glenn Hancock <glennh(at)GMAIL.COM> >>>> >>>> So I purchased the 680FP and had my mechanic fly it back to TN from >>>> NM. It was about a 600nm trip and I followed him in my 310Q with my >>>> wife and 3 year old son. We flew back at 9500 and he went up to >>>> 13500. I am not sure how he managed the engines or how he did >>>> anything for that matter, but what I was most interested in was his >>>> speed. I purchased this airplane with the understanding that it was at >>> least a 200knot airplane. >>>> >>>> So we took off and proceeded to fly cross country for 3 hours. To my >>>> absolute disappointment he arrived 7 minutes ahead of me. He said he >>>> was doing 181MPH indicated which was basically the same speed I was >>>> doing in my >>>> 310 at a lower altitude. >>>> >>>> So my question is: Was I dupped and the 680Fp is the same speed as >>>> the 310Q? Except it burns twice as much gas. Or was he perhaps not >>>> flying it properly? I still love the plane and not changing my mind, >>>> just won't be quite as happy with it if it's that slow. It has flap >>>> gap seals and winglets although I'm not sure how much either adds to >>>> actual speed. He averaged about 55gph fuel burn compared to my 26gph. >>>> >>>> Even at 190kts he should have been indicating 220mph. >>>> >>>> >>>> Thanks, >>>> >>>> >>>> -- >>>> --glenn hancock >>>> >>>> You can't win an argument with an ignorant person. They'll just drag >>>> you down to their level and beat you with experience. >>>> >>>> ________________________________ Message 3 >>>> _____________________________________ >>>> >>>> >>>> Subject: RE: Commander-List: 680FP Speed Question >>>> From: "K.S.Gordon" <cloudcraft(at)aol.com> >>>> >>>> CiAgICAKR2xlbm4sClVzaW5nIElTQSBjb25kaXRpb25zIGZvciAxMyw1MDAnLCAxODEgSW >>>> 5kaWNh >>>> dGVkIGlzIDIyMyBUcnVlLgpMb3RzIG9mIHF1ZXN0aW9ucyBuZWVkIHRvIGJlIGFuc3dlcm >>>> VkIGJl >>>> Zm9yZSBhIHBlcmZvcm1hbmNlIGNvbXBhcmlzb24gY2FuIGJlIG1hZGUuV2luZHMgYWxvZn >>>> QgYXQg >>>> Ym90aCBhbHRpdHVkZXNQb3dlciBzZXR0aW5nc0NsaW1iIGFuZCBkZXNjZW50IHByb2ZpbG >>>> VBdCB0 >>>> aGUgZW5kIG9mIHRoZSBkYXksIHlvdSBtaWdodCBmaW5kIHRoZSBDRTMxMCBoYXMgc2ltaW >>>> xhciBj >>>> cnVpc2UgcGVyZm9ybWFuY2UgdG8gaG93IHlvdSBvcGVyYXRlIHlvdXIgQ29tbWFuZGVyLg >>>> pXaGF0 >>>> IHdpbGwgc2VwYXJhdGUgdGhlIHNoZWVwIGZyb20gdGhlIGdvYXRzIGlzIHRoZSBsb2FkIH >>>> lvdSBj >>>> YW4gY2Fycnkgb2ZmIHRoYXQgMzAwMCcgZ3Jhc3Mgc3RyaXAgeW91IHdhbnQgdG8gYmFzZS >>>> BhdC4K >>>> Sy5TLkdvcmRvblNlbnQgb24gdGhlIEZsecKg8J+MkAoKLS0tLS0tLS0gT3JpZ2luYWwgbW >>>> Sy5TLkdvcmRvblNlbnQgb24gdGhlIEZsecKg8J+Vzc2Fn >>>> ZSAtLS0tLS0tLQpGcm9tOiBHbGVubiBIYW5jb2NrIDxnbGVubmhAR01BSUwuQ09NPiAKRG >>>> F0ZTog >>>> MjAvMDcvMjAxNSAgMjA6MjcgIChHTVQtMDc6MDApIApUbzogY29tbWFuZGVyLWxpc3RAbW >>>> F0cm9u >>>> aWNzLmNvbSAKU3ViamVjdDogQ29tbWFuZGVyLUxpc3Q6IDY4MEZQIFNwZWVkIFF1ZXN0aW >>>> 9uIAoK >>>> U28gSSBwdXJjaGFzZWQgdGhlIDY4MEZQIGFuZCBoYWQgbXkgbWVjaGFuaWMgZmx5IGl0IG >>>> JhY2sg >>>> dG8gVE4gZnJvbSBOTS7CoCBJdCB3YXMgYWJvdXQgYSA2MDBubSB0cmlwIGFuZCBJIGZvbG >>>> xvd2Vk >>>> IGhpbSBpbiBteSAzMTBRIHdpdGggbXkgd2lmZSBhbmQgMyB5ZWFyIG9sZCBzb24uwqAgV2 >>>> UgZmxl >>>> dyBiYWNrIGF0IDk1MDAgYW5kIGhlIHdlbnQgdXAgdG8gMTM1MDAuwqAgSSBhbSBub3Qgc3 >>>> VyZSBo >>>> b3cgaGUgbWFuYWdlZCB0aGUgZW5naW5lcyBvciBob3cgaGUgZGlkIGFueXRoaW5nIGZvci >>>> B0aGF0 >>>> IG1hdHRlciwgYnV0IHdoYXQgSSB3YXMgbW9zdCBpbnRlcmVzdGVkIGluIHdhcyBoaXMgc3 >>>> BlZWQu >>>> wqAgSSBwdXJjaGFzZWQgdGhpcyBhaXJwbGFuZSB3aXRoIHRoZSB1bmRlcnN0YW5kaW5nIH >>>> RoYXQg >>>> aXQgd2FzIGF0IGxlYXN0IGEgMjAwa25vdCBhaXJwbGFuZS4KU28gd2UgdG9vayBvZmYgYW >>>> 5kIHBy >>>> b2NlZWRlZCB0byBmbHkgY3Jvc3MgY291bnRyeSBmb3IgMyBob3Vycy7CoCBUbyBteSBhYn >>>> NvbHV0 >>>> ZSBkaXNhcHBvaW50bWVudCBoZSBhcnJpdmVkIDcgbWludXRlcyBhaGVhZCBvZiBtZS7CoC >>>> BIZSBz >>>> YWlkIGhlIHdhcyBkb2luZyAxODFNUEggaW5kaWNhdGVkIHdoaWNoIHdhcyBiYXNpY2FsbH >>>> kgdGhl >>>> IHNhbWUgc3BlZWQgSSB3YXMgZG9pbmcgaW4gbXkgMzEwIGF0IGEgbG93ZXIgYWx0aXR1ZG >>>> UuClNv >>>> IG15IHF1ZXN0aW9uIGlzOiDCoFdhcyBJIGR1cHBlZCBhbmQgdGhlIDY4MEZwIGlzIHRoZS >>>> BzYW1l >>>> IHNwZWVkIGFzIHRoZSAzMTBRP8KgIEV4Y2VwdCBpdCBidXJucyB0d2ljZSBhcyBtdWNoIG >>>> dhcy7C >>>> oCBPciB3YXMgaGUgcGVyaGFwcyBub3QgZmx5aW5nIGl0IHByb3Blcmx5P8KgIEkgc3RpbG >>>> wgbG92 >>>> ZSB0aGUgcGxhbmUgYW5kIG5vdCBjaGFuZ2luZyBteSBtaW5kLCBqdXN0IHdvbid0IGJlIH >>>> F1aXRl >>>> IGFzIGhhcHB5IHdpdGggaXQgaWYgaXQncyB0aGF0IHNsb3cuwqAgSXQgaGFzIGZsYXAgZ2 >>>> FwIHNl >>>> YWxzIGFuZCB3aW5nbGV0cyBhbHRob3VnaCBJJ20gbm90IHN1cmUgaG93IG11Y2ggZWl0aG >>>> VyIGFk >>>> ZHMgdG8gYWN0dWFsIHNwZWVkLsKgIEhlIGF2ZXJhZ2VkIGFib3V0IDU1Z3BoIGZ1ZWwgYn >>>> VybiBj >>>> b21wYXJlZCB0byBteSAyNmdwaC4KRXZlbiBhdCAxOTBrdHMgaGUgc2hvdWxkIGhhdmUgYm >>>> VlbiBp >>>> bmRpY2F0aW5nIDIyMG1waC4KClRoYW5rcywKCi0tIAotLWdsZW5uIGhhbmNvY2sKWW91IG >>>> Nhbid0 >>>> IHdpbiBhbiBhcmd1bWVudCB3aXRoIGFuIGlnbm9yYW50IHBlcnNvbi7CoCBUaGV5J2xsIG >>>> p1c3Qg >>>> ZHJhZyB5b3UgZG93biB0byB0aGVpciBsZXZlbCBhbmQgYmVhdCB5b3Ugd2l0aCBleHBlcm >>>> llbmNl >>>> LgoKCgoKCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT >>>> 09PT09 >>>> PT09PT09PT09PT09Cl8tPSAgICAgICAgICAtIFRoZSBDb21tYW5kZXItTGlzdCBFbWFpbC >>>> BGb3J1 >>>> bSAtCl8tPSBVc2UgdGhlIE1hdHJvbmljcyBMaXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0by >>>> Bicm93 >>>> c2UKXy09IHRoZSBtYW55IExpc3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3 >>>> JpcHRp >>>> b24sCl8tPSBBcmNoaXZlIFNlYXJjaCAmIERvd25sb2FkLCA3LURheSBCcm93c2UsIENoYX >>>> QsIEZB >>>> USwKXy09IFBob3Rvc2hhcmUsIGFuZCBtdWNoIG11Y2ggbW9yZToKXy09Cl8tPSAgIC0tPi >>>> BodHRw >>>> Oi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP0NvbW1hbmRlci1MaXN0Cl8tPQpfLT >>>> 09PT09 >>>> PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT >>>> 09PQpf >>>> LT0gICAgICAgICAgICAgICAtIE1BVFJPTklDUyBXRUIgRk9SVU1TIC0KXy09IFNhbWUgZ3 >>>> JlYXQg >>>> Y29udGVudCBhbHNvIGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMhCl8tPQpfLT0gIC >>>> AtLT4g >>>> aHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tCl8tPQpfLT09PT09PT09PT09PT09PT09PT >>>> 09PT09 >>>> PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT0gICAgICAgICAgIC >>>> AgLSBM >>>> aXN0IENvbnRyaWJ1dGlvbiBXZWIgU2l0ZSAtCl8tPSAgVGhhbmsgeW91IGZvciB5b3VyIG >>>> dlbmVy >>>> b3VzIHN1cHBvcnQhCl8tPSAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIC1NYXR0IE >>>> RyYWxs >>>> ZSwgTGlzdCBBZG1pbi4KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jb2 >>>> ZSwgTGlzdCBBZG1pbi4KXy09ICAgLS0+50cmli >>>> dXRpb24KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT >>>> 09PT09 >>>> PT09PT09PT09PT0KCg >>>> >>>> ________________________________ Message 4 >>>> _____________________________________ >>>> >>>> >>>> From: "lloyd silverman" <lloydsss11(at)MSN.COM> >>>> Subject: Re: Commander-List: Commander Parts >>>> >>>> v\:* { BEHAVIOR: url(#default#VML) } o\:* { BEHAVIOR: >>>> url(#default#VML) } w\:* { BEHAVIOR: url(#default#VML) } .shape { >>>> BEHAVIOR: url(#default#VML) } >>>> >>>> Randy, be careful the rivet holes probably wont line up with yours. >>>> >>>> >>>> ----- Original Message ----- >>>> >>>> From: Randy Dettmer, AIA<mailto:rcdettmer(at)charter.net> >>>> >>>> >>>> Sent: Monday, July 20, 2015 2:29 PM >>>> >>>> Subject: Commander-List: Commander Parts >>>> >>>> >>>> Hello Commander fans, >>>> >>>> We are trying to locate some lower fuselage skin panels for my 680F. >>>> Anybody know of available parts or a salvage plane somewhere..?? >>>> Models 500A & B, 560, or 680F will work. Thanks much. >>>> >>>> >>>> Randy Dettmer, AIA, NCARB >>>> >>>> >>>> Dettmer Architecture >>>> >>>> 663 Hill Street >>>> >>>> San Luis Obispo, CA 93405 >>>> >>>> 805 541 4864 / fax 805 541 4865 >>>> >>>> www.dettmerarchitecture.com >>>> >>>> >>>> ________________________________ Message 5 >>>> _____________________________________ >>>> >>>> >>>> Subject: Re: Commander-List: Commander Parts >>>> From: John Ives <seafever32(at)hotmail.com> >>>> >>>> I'd have thought the best way to do it is get a sheetie and install >>>> new mate rial. The cost is probably going to be close and the job >>>> better done >>>> >>>> John Ives >>>> AC 685 >>>> VH NJT >>>> >>>> Sent from my iPad >>>> >>>>> On 21 Jul 2015, at 1:41 pm, lloyd silverman wrote: >>>>> >>>>> Randy, be careful the rivet holes probably wont line up with yours. >>>>> ----- Original Message ----- >>>>> From: Randy Dettmer, AIA >>>>> To: commander-list(at)matronics.com >>>>> Sent: Monday, July 20, 2015 2:29 PM >>>>> Subject: Commander-List: Commander Parts >>>>> >>>>> Hello Commander fans, >>>>> We are trying to locate some lower fuselage skin panels for my 680F. >>>>> Anyb >>>> ody know of available parts or a salvage plane somewhere..?? Models 500A >>> & >>>> B, 560, or 680F will work. Thanks much. >>>>> >>>>> Randy Dettmer, AIA, NCARB >>>>> >>>>> >>>>> >>>>> Dettmer Architecture >>>>> 663 Hill Street >>>>> San Luis Obispo, CA 93405 >>>>> 805 541 4864 / fax 805 541 4865 >>>>> www.dettmerarchitecture.com >>>> >>>> ________________________________ Message 6 >>>> _____________________________________ >>>> >>>> >>>> From: John Vormbaum <john(at)vormbaum.com> >>>> Subject: Re: Commander-List: Commander Parts >>>> >>>> Ok that was funny, Lloyd. Thanks for the laugh! >>>> >>>> Sent from my iPad >>>> >>>> On Jul 20, 2015, at 8:43 PM, lloyd silverman wrote: >>>> >>>> Randy, be careful the rivet holes probably wont line up with yours. >>>> >>>> ----- Original Message ----- >>>> *From:* Randy Dettmer, AIA >>>> *To:* commander-list(at)matronics.com >>>> *Sent:* Monday, July 20, 2015 2:29 PM >>>> *Subject:* Commander-List: Commander Parts >>>> >>>> Hello Commander fans, >>>> >>>> We are trying to locate some lower fuselage skin panels for my 680F. >>>> Anybody know of available parts or a salvage plane somewhere..?? Models >>>> 500A & B, 560, or 680F will work. Thanks much. >>>> >>>> >>>> Randy Dettmer, AIA, NCARB >>>> >>>> >>>> >>>> >>>> >>>> *Dettmer Architecture* >>>> >>>> *663 Hill Street* >>>> >>>> *San Luis Obispo, CA 93405* >>>> >>>> *805 541 4864 / fax 805 541 4865* >>>> >>>> *www.dettmerarchitecture.com <http://www.dettmerarchitecture.com>* >>>> >>>> ________________________________ Message 7 >>>> _____________________________________ >>>> >>>> >>>> Subject: Re: Commander-List: Commander Parts >>>> From: Paul Gendron <rpmcommander(at)GMAIL.COM> >>>> >>>> Randy, I have two donors, one flp and a 690 I also have a Sheetmetal >>>> guy that can make the skins and circumferrentials from the templates >>>> you remove from the smaller frames. I also have the z brackets and z >>>> couplings. I have a full set of ldg gear. Pressurized windshields and >>>> side windows. Let me know if you need anything. 954-547-3002 Paul >>>> Gendron On Jul 20, 2015 2:32 PM, "Randy Dettmer, AIA" >>>> >>>> wrote: >>>> >>>>> Hello Commander fans, >>>>> >>>>> We are trying to locate some lower fuselage skin panels for my 680F. >>>>> Anybody know of available parts or a salvage plane somewhere..?? Models >>>>> 500A & B, 560, or 680F will work. Thanks much. >>>>> >>>>> >>>>> Randy Dettmer, AIA, NCARB >>>>> >>>>> >>>>> [image: logoRED-126x38@72dpi] >>>>> >>>>> >>>>> *Dettmer Architecture* >>>>> >>>>> *663 Hill Street* >>>>> >>>>> *San Luis Obispo, CA 93405* >>>>> >>>>> *805 541 4864 <805%20541%204864> / fax 805 541 4865 >>>>> <805%20541%204865>* >>>>> >>>>> *www.dettmerarchitecture.com <http://www.dettmerarchitecture.com>* > > > > > > ________________________________________________________________________________
From: "William J Hamilton" <wjrhamilton(at)optusnet.com.au>
Subject: Commander Parts
Date: Jul 22, 2015
Randy, The best (and probably the cheapest) answer is to make them. Most of them are single curvature, only moderate radii. Any competent aircraft sheet metal worker should be able to do this. Donor airframe --- what condition is an equally old skin likely to be? Cheers, Bill Hamilton From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Randy Dettmer, AIA Sent: Tuesday, July 21, 2015 4:29 AM Subject: Commander-List: Commander Parts Hello Commander fans, We are trying to locate some lower fuselage skin panels for my 680F. Anybody know of available parts or a salvage plane somewhere..?? Models 500A & B, 560, or 680F will work. Thanks much. Randy Dettmer, AIA, NCARB Dettmer Architecture 663 Hill Street San Luis Obispo, CA 93405 805 541 4864 / fax 805 541 4865 www.dettmerarchitecture.com <http://www.dettmerarchitecture.com> ________________________________________________________________________________
Subject: Re: Commander Parts
Date: Jul 22, 2015
You probably already know this, but there is a Commander parts company in Cr eedmore N.C. I think the name is Twin Commander LLC. Ask for Brian. They hav e the dies from the factory. New stuff is pretty pricy. Don't know about the used stuff. Roland Gilliam. AC 500 6291B Sent from my iPad > On Jul 21, 2015, at 10:45 PM, William J Hamilton wrote: > > Randy, > The best (and probably the cheapest) answer is to make them. > Most of them are single curvature, only moderate radii. > Any competent aircraft sheet metal worker should be able to do this. > Donor airframe --- what condition is an equally old skin likely to be? > Cheers, > Bill Hamilton > > From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-li st-server(at)matronics.com] On Behalf Of Randy Dettmer, AIA > Sent: Tuesday, July 21, 2015 4:29 AM > To: commander-list(at)matronics.com > Subject: Commander-List: Commander Parts > > Hello Commander fans, > We are trying to locate some lower fuselage skin panels for my 680F. Anyb ody know of available parts or a salvage plane somewhere..?? Models 500A & B, 560, or 680F will work. Thanks much. > > Randy Dettmer, AIA, NCARB > > > > Dettmer Architecture > 663 Hill Street > San Luis Obispo, CA 93405 > 805 541 4864 / fax 805 541 4865 > www.dettmerarchitecture.com > ________________________________________________________________________________
Date: Jul 29, 2015
Subject: Fwd: need access
Posting this for a new member................ I am trying to sell my commander so if you know anyone that=99s inte rested please pass along my information. its a really unique 500B with poss ibly the best maintenance there is, plus $45,000 in new avionics. I really need to sell so I will look at all offers. www.n222le.weebly.com Scott J. Scott Dickey www.jtechsolutions.us www.dockingdrawer.com 12893 Alcosta Blvd. Ste M San Ramon, CA 94583 cell: 408-425-4393 jdickey(at)jtechsolutions.us On Jul 23, 2015, at 5:02 PM, yourtcfg(at)aol.com wrote: Scott, Sorry for the problems you experienced with the website. You have been set up with the following login information: Username: Scott Dickey Password: AeroScott900 You can change the password once you log in. Also, please join us on FB us ing the links on the front page of the website. We also have a chat list/f orum at Matronics.com (sign up for the Aero Commander group u nder other groups -- no charge to join). Hope you can join us at our Annual Fly-In to be held Sept 24-26 at Colorado Springs Colorado in conjunction with the AOPA regional conference. Thank you for your interest in the Twin Commander Flight Group. ~Jim & Sue Metzger Twin Commander Flight Group -----Original Message----- From: Scott Dickey < jdickey(at)jtechsolutions.us> To: yourtcfg < yourtcfg(at)aol.com> Sent: Thu, Jul 23, 2015 10:21 am Subject: need access Hi, I paid the $50 membership fee but the website did not take me to the page where I can create a new registration. Can you please help me out? Again, y ou have debited my account but I cannot join. Scott J. Scott Dickey www.jtechsolutions.us www.dockingdrawer.com 12893 Alcosta Blvd. Ste M San Ramon, CA 94583 cell: 408-425-4393 jdickey(at)jtechsolutions.us ________________________________________________________________________________
Date: Jul 30, 2015
Scott, may I publish your Commander's advertisement and videos on our Facebook Page? It has almost 1,000 Commander enthusiasts who liked the site and many more just looking around on a regular basis. It also has a wider international audience. Let me know. Thanks Nico www.facebook.com/commanderflight From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of yourtcfg(at)aol.com Sent: Wednesday, July 29, 2015 8:13 AM Subject: [matronics.com] Commander-List: Fwd: need access Posting this for a new member................ I am trying to sell my commander so if you know anyone that=99s interested please pass along my information. its a really unique 500B with possibly the best maintenance there is, plus $45,000 in new avionics. I really need to sell so I will look at all offers. www.n222le.weebly.com Scott J. Scott Dickey www.jtechsolutions.us www.dockingdrawer.com 12893 Alcosta Blvd. Ste M San Ramon, CA 94583 cell: 408-425-4393 jdickey(at)jtechsolutions.us On Jul 23, 2015, at 5:02 PM, yourtcfg(at)aol.com wrote: Scott, Sorry for the problems you experienced with the website. You have been set up with the following login information: Username: Scott Dickey Password: AeroScott900 You can change the password once you log in. Also, please join us on FB using the links on the front page of the website. We also have a chat list/forum at Matronics.com (sign up for the Aero Commander group under other groups -- no charge to join). Hope you can join us at our Annual Fly-In to be held Sept 24-26 at Colorado Springs Colorado in conjunction with the AOPA regional conference. Thank you for your interest in the Twin Commander Flight Group. ~Jim & Sue Metzger Twin Commander Flight Group -----Original Message----- From: Scott Dickey < jdickey(at)jtechsolutions.us> Sent: Thu, Jul 23, 2015 10:21 am Subject: need access Hi, I paid the $50 membership fee but the website did not take me to the page where I can create a new registration. Can you please help me out? Again, you have debited my account but I cannot join. Scott J. Scott Dickey www.jtechsolutions.us www.dockingdrawer.com 12893 Alcosta Blvd. Ste M San Ramon, CA 94583 cell: 408-425-4393 jdickey(at)jtechsolutions.us ________________________________________________________________________________
Date: Jul 30, 2015
Subject: Re: Fwd: need access
Nico, Scott isn't on the chat list, but he wouldn't have a problem with you posti ng. ~Sue Metzger -----Original Message----- From: Nico hMail <nico(at)nicsysco.com> Sent: Thu, Jul 30, 2015 3:29 pm Subject: RE: [matronics.com] Commander-List: Fwd: need access Scott, may I publish your Commander's advertisement and videos on our Faceb ook Page? It has almost 1,000 Commander enthusiasts who liked the site and many more just looking around on a regular basis. It also has a wider inter national audience. Let me know. Thanks Nico www.facebook.com/commanderflight From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-lis t-server(at)matronics.com] On Behalf Of yourtcfg(at)aol.com Sent: Wednesday, July 29, 2015 8:13 AM Subject: [matronics.com] Commander-List: Fwd: need access Posting this for a new member................ I am trying to sell my commander so if you know anyone that=99s inter ested please pass along my information. its a really unique 500B with possi bly the best maintenance there is, plus $45,000 in new avionics. I really n eed to sell so I will look at all offers. www.n222le.weebly.com Scott J. Scott Dickey www.jtechsolutions.us www.dockingdrawer.com 12893 Alcosta Blvd. Ste M San Ramon, CA 94583 cell: 408-425-4393 jdickey(at)jtechsolutions.us On Jul 23, 2015, at 5:02 PM, yourtcfg(at)aol.com wrote: Scott, Sorry for the problems you experienced with the website. You have been set up with the following login information: Username: Scott Dickey Password: AeroScott900 You can change the password once you log in. Also, please join us on FB us ing the links on the front page of the website. We also have a chat list/f orum at Matronics.com (sign up for the Aero Commander group under other gro ups -- no charge to join). Hope you can join us at our Annual Fly-In to be held Sept 24-26 at Colorado Springs Colorado in conjunction with the AOPA regional conference. Thank you for your interest in the Twin Commander Flight Group. ~Jim & Sue Metzger Twin Commander Flight Group -----Original Message----- From: Scott Dickey < jdickey(at)jtechsolutions.us> Sent: Thu, Jul 23, 2015 10:21 am Subject: need access Hi, I paid the $50 membership fee but the website did not take me to the page w here I can create a new registration. Can you please help me out? Again, yo u have debited my account but I cannot join. Scott J. Scott Dickey www.jtechsolutions.us www.dockingdrawer.com 12893 Alcosta Blvd. Ste M San Ramon, CA 94583 cell: 408-425-4393 jdickey(at)jtechsolutions.us < - The Commander-List Email Forum Use the Matronics List Features Nav igator to browse http://www.matronics.com/Navigator?Commander-List http://forums.matronics.com http://www.matronics.com/contribution ==== ________________________________________________________________________________
Date: Jul 30, 2015
What advertisement? I'm not familiar Scott Sent from my iPhone > On Jul 30, 2015, at 5:28 PM, Nico hMail wrote: > > Scott, may I publish your Commander's advertisement and videos on our Face book Page? It has almost 1,000 Commander enthusiasts who liked the site and m any more just looking around on a regular basis. It also has a wider interna tional audience. > > Let me know. > > Thanks > > Nico > > www.facebook.com/commanderflight > > > > From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-li st-server(at)matronics.com] On Behalf Of yourtcfg(at)aol.com > Sent: Wednesday, July 29, 2015 8:13 AM > To: commander-list(at)matronics.com > Subject: [matronics.com] Commander-List: Fwd: need access > > Posting this for a new member................ > > > I am trying to sell my commander so if you know anyone that=99s inte rested please pass along my information. its a really unique 500B with possi bly the best maintenance there is, plus $45,000 in new avionics. I really ne ed to sell so I will look at all offers. > > www.n222le.weebly.com > > > Scott > > J. Scott Dickey > www.jtechsolutions.us > www.dockingdrawer.com > 12893 Alcosta Blvd. Ste M > San Ramon, CA 94583 > cell: 408-425-4393 > jdickey(at)jtechsolutions.us > > > > > On Jul 23, 2015, at 5:02 PM, yourtcfg(at)aol.com wrote: > > Scott, > > Sorry for the problems you experienced with the website. You have been se t up with the following login information: > > Username: Scott Dickey > Password: AeroScott900 > > You can change the password once you log in. Also, please join us on FB u sing the links on the front page of the website. We also have a chat list/f orum at Matronics.com (sign up for the Aero Commander group under other grou ps -- no charge to join). > > Hope you can join us at our Annual Fly-In to be held Sept 24-26 at Colorad o Springs Colorado in conjunction with the AOPA regional conference. > > Thank you for your interest in the Twin Commander Flight Group. > > ~Jim & Sue Metzger > Twin Commander Flight Group > > > -----Original Message----- > From: Scott Dickey < jdickey(at)jtechsolutions.us> > To: yourtcfg < yourtcfg(at)aol.com> > Sent: Thu, Jul 23, 2015 10:21 am > Subject: need access > > Hi, > > I paid the $50 membership fee but the website did not take me to the page w here I can create a new registration. Can you please help me out? Again, you have debited my account but I cannot join. > > Scott > > J. Scott Dickey > www.jtechsolutions.us > www.dockingdrawer.com > 12893 Alcosta Blvd. Ste M > San Ramon, CA 94583 > cell: 408-425-4393 > jdickey(at)jtechsolutions.us > > > > > > > > < - The Commander-List Email Forum Use the Matronics List Features Na vigator to browse > http://www.matronics.com/Navigator?Commander-List > http://forums.matronics.com > http://www.matronics.com/contribution > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Jul 31, 2015
Thanks, Sue. From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of suemetzger(at)aol.com Sent: Thursday, July 30, 2015 5:04 PM Subject: Re: [matronics.com] Commander-List: Fwd: need access Nico, Scott isn't on the chat list, but he wouldn't have a problem with you posting. ~Sue Metzger -----Original Message----- From: Nico hMail <nico(at)nicsysco.com> Sent: Thu, Jul 30, 2015 3:29 pm Subject: RE: [matronics.com] Commander-List: Fwd: need access Scott, may I publish your Commander's advertisement and videos on our Facebook Page? It has almost 1,000 Commander enthusiasts who liked the site and many more just looking around on a regular basis. It also has a wider international audience. Let me know. Thanks Nico www.facebook.com/commanderflight From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com ] On Behalf Of yourtcfg(at)aol.com Sent: Wednesday, July 29, 2015 8:13 AM Subject: [matronics.com] Commander-List: Fwd: need access Posting this for a new member................ I am trying to sell my commander so if you know anyone that=99s interested please pass along my information. its a really unique 500B with possibly the best maintenance there is, plus $45,000 in new avionics. I really need to sell so I will look at all offers. www.n222le.weebly.com Scott J. Scott Dickey www.jtechsolutions.us www.dockingdrawer.com 12893 Alcosta Blvd. Ste M San Ramon, CA 94583 cell: 408-425-4393 jdickey(at)jtechsolutions.us On Jul 23, 2015, at 5:02 PM, yourtcfg(at)aol.com wrote: Scott, Sorry for the problems you experienced with the website. You have been set up with the following login information: Username: Scott Dickey Password: AeroScott900 You can change the password once you log in. Also, please join us on FB using the links on the front page of the website. We also have a chat list/forum at Matronics.com (sign up for the Aero Commander group under other groups -- no charge to join). Hope you can join us at our Annual Fly-In to be held Sept 24-26 at Colorado Springs Colorado in conjunction with the AOPA regional conference. Thank you for your interest in the Twin Commander Flight Group. ~Jim & Sue Metzger Twin Commander Flight Group -----Original Message----- From: Scott Dickey < jdickey(at)jtechsolutions.us> Sent: Thu, Jul 23, 2015 10:21 am Subject: need access Hi, I paid the $50 membership fee but the website did not take me to the page where I can create a new registration. Can you please help me out? Again, you have debited my account but I cannot join. Scott J. Scott Dickey www.jtechsolutions.us www.dockingdrawer.com 12893 Alcosta Blvd. Ste M San Ramon, CA 94583 cell: 408-425-4393 jdickey(at)jtechsolutions.us < - The Commander-List Email Forum Use the Matronics List Features Navigator to browse http://www.matronics.com/Navigator?Commander-List http://forums.matronics.com http://www.matronics.com/contribution -= --> http://forums.matron======= <http://www.matronics.com/Navigator?Commander-List> <http://www.matronics.com/Navigator?Commander-List> <http://www.matronics.com/Navigator?Commander-List> <http://www.matronics.com/Navigator?Commander-List> The Commander-List Email Forum - Matronics List Features Navigator to browse utilities such as List Un/Subscription, Search & Download, 7-Day Browse, Chat, FAQ, and much much more: http://www.matronics.com/Navigator?Commander-List ________________________________________________________________________________
Date: Jul 31, 2015
Sorry, Scott. It was an Aero Commander that Scott Dickey advertised. If you scroll down a bit on this email, you'll see it. I should have included his last name to be sure that my response is not confusing. Thanks Nico From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Scott Main Sent: Thursday, July 30, 2015 8:51 PM Subject: Re: [matronics.com] Commander-List: Fwd: need access What advertisement? I'm not familiar Scott Sent from my iPhone On Jul 30, 2015, at 5:28 PM, Nico hMail wrote: Scott, may I publish your Commander's advertisement and videos on our Facebook Page? It has almost 1,000 Commander enthusiasts who liked the site and many more just looking around on a regular basis. It also has a wider international audience. Let me know. Thanks Nico www.facebook.com/commanderflight From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of yourtcfg(at)aol.com Sent: Wednesday, July 29, 2015 8:13 AM Subject: [matronics.com] Commander-List: Fwd: need access Posting this for a new member................ I am trying to sell my commander so if you know anyone that=99s interested please pass along my information. its a really unique 500B with possibly the best maintenance there is, plus $45,000 in new avionics. I really need to sell so I will look at all offers. www.n222le.weebly.com Scott J. Scott Dickey www.jtechsolutions.us www.dockingdrawer.com 12893 Alcosta Blvd. Ste M San Ramon, CA 94583 cell: 408-425-4393 jdickey(at)jtechsolutions.us On Jul 23, 2015, at 5:02 PM, yourtcfg(at)aol.com wrote: Scott, Sorry for the problems you experienced with the website. You have been set up with the following login information: Username: Scott Dickey Password: AeroScott900 You can change the password once you log in. Also, please join us on FB using the links on the front page of the website. We also have a chat list/forum at Matronics.com (sign up for the Aero Commander group under other groups -- no charge to join). Hope you can join us at our Annual Fly-In to be held Sept 24-26 at Colorado Springs Colorado in conjunction with the AOPA regional conference. Thank you for your interest in the Twin Commander Flight Group. ~Jim & Sue Metzger Twin Commander Flight Group -----Original Message----- From: Scott Dickey < jdickey(at)jtechsolutions.us> Sent: Thu, Jul 23, 2015 10:21 am Subject: need access Hi, I paid the $50 membership fee but the website did not take me to the page where I can create a new registration. Can you please help me out? Again, you have debited my account but I cannot join. Scott J. Scott Dickey www.jtechsolutions.us www.dockingdrawer.com 12893 Alcosta Blvd. Ste M San Ramon, CA 94583 cell: 408-425-4393 jdickey(at)jtechsolutions.us < - The Commander-List Email Forum Use the Matronics List Features Navigator to browse http://www.matronics.com/Navigator?Commander-List http://forums.matronics.com http://www.matronics.com/contribution D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D nder-List"">http://www.matronics.com/Navigator?Commander-List D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D //forums.matronics.com D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ot;">http://www.matronics.com/contribution D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ________________________________________________________________________________
Date: Jul 31, 2015
ahh...wrong scott I own L26 55-4638 -----Original Message----- From: nicoCSS <nico(at)cybersuperstore.com> Sent: Fri, Jul 31, 2015 5:17 pm Subject: RE: [matronics.com] Commander-List: Fwd: need access Sorry, Scott. It was an Aero Commander that Scott Dickey advertised. If you scroll down a bit on this email, you'll see it. I should have included his last name to be sure that my response is not con fusing. Thanks Nico From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-lis t-server(at)matronics.com] On Behalf Of Scott Main Sent: Thursday, July 30, 2015 8:51 PM Subject: Re: [matronics.com] Commander-List: Fwd: need access What advertisement? I'm not familiar Scott Sent from my iPhone On Jul 30, 2015, at 5:28 PM, Nico hMail wrote: Scott, may I publish your Commander's advertisement and videos on our Faceb ook Page? It has almost 1,000 Commander enthusiasts who liked the site and many more just looking around on a regular basis. It also has a wider inter national audience. Let me know. Thanks Nico www.facebook.com/commanderflight From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-lis t-server(at)matronics.com] On Behalf Of yourtcfg(at)aol.com Sent: Wednesday, July 29, 2015 8:13 AM Subject: [matronics.com] Commander-List: Fwd: need access Posting this for a new member................ I am trying to sell my commander so if you know anyone that=99s inter ested please pass along my information. its a really unique 500B with possi bly the best maintenance there is, plus $45,000 in new avionics. I really n eed to sell so I will look at all offers. www.n222le.weebly.com Scott J. Scott Dickey www.jtechsolutions.us www.dockingdrawer.com 12893 Alcosta Blvd. Ste M San Ramon, CA 94583 cell: 408-425-4393 jdickey(at)jtechsolutions.us On Jul 23, 2015, at 5:02 PM, yourtcfg(at)aol.com wrote: Scott, Sorry for the problems you experienced with the website. You have been set up with the following login information: Username: Scott Dickey Password: AeroScott900 You can change the password once you log in. Also, please join us on FB us ing the links on the front page of the website. We also have a chat list/f orum at Matronics.com (sign up for the Aero Commander group under other gro ups -- no charge to join). Hope you can join us at our Annual Fly-In to be held Sept 24-26 at Colorado Springs Colorado in conjunction with the AOPA regional conference. Thank you for your interest in the Twin Commander Flight Group. ~Jim & Sue Metzger Twin Commander Flight Group -----Original Message----- From: Scott Dickey < jdickey(at)jtechsolutions.us> Sent: Thu, Jul 23, 2015 10:21 am Subject: need access Hi, I paid the $50 membership fee but the website did not take me to the page w here I can create a new registration. Can you please help me out? Again, yo u have debited my account but I cannot join. Scott J. Scott Dickey www.jtechsolutions.us www.dockingdrawer.com 12893 Alcosta Blvd. Ste M San Ramon, CA 94583 cell: 408-425-4393 jdickey(at)jtechsolutions.us < - The Commander-List Email Forum Use the Matronics List Features Nav igator to browse http://www.matronics.com/Navigator?Commander-List http://forums.matronics.com http://www.matronics.com/contribution D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D nder-List"">http://www.matronics.com/Navigator?Commander-List D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D //forums.matronics.com D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D ot;">http://www.matronics.com/contribution D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D http://www.matronics.com/Navigator?Commander-List http://forums.matronics.com http://www.matronics.com/contribution ==== ________________________________________________________________________________
Subject: windshield for 500B
Date: Aug 07, 2015
Time to replace the windshield on old 6290X. Any ideas where to pick one up? Thanks, Lloyd ________________________________________________________________________________
Subject: Commanders
Date: Aug 15, 2015
Folks, There are many Commander enthusiasts worldwide. As a small contribution to service the aviation community in general and the Aero Commander community in particular, I started an Aero Commander facebook page a while ago at www.facebook.com/commanderflight We are working closely with other Commander sites and service providers, oftentimes encouraging them to advertise on our FB page at no cost by posting stuff of interest. Oftentimes I'd browse sites for AC's for sale and just post those as stuff of interest. Our Facebook page is slowly creeping to the 1,000 likes mark, oftentimes gaining 100 likes in a week, depending on the content I publish. The all-time consistent record breaker is, of course, stuff about Bob Hoover. In a close second position is material about fancy flying, like the great video clip about landing on a sandbank that I published a couple of years ago. Thank you very much for everyone who make this a pleasure and keep on visiting our page regularly. We are still trying to work things so that we can attend the fly-in next month, but if we are not able, having a lot of photographs and videos would make the absence a bit more bearable. If we are able to make it, well, then we'll see you all there. It'll be the first fly-in without Moe? Many thanks, Nico ________________________________________________________________________________
Date: Aug 16, 2015
Subject: Re: Commanders
Hello Nico, We sincerely appreciate the opportunities that your website affords the worldwide Aero Commander community and it is a great way of keeping connected - thank you! It would be great to see you guys at the Flyin in late September at Colorado Springs. Moe will certainly be with us all in spirit - he and 680RR will be sorely missed. Hope toy see you soon! Russell On Sun, Aug 16, 2015 at 9:48 AM, nicoCSS wrote: > Folks, > > > There are many Commander enthusiasts worldwide. As a small contribution to > service the aviation community in general and the Aero Commander community > in particular, I started an Aero Commander facebook page a while ago at > www.facebook.com/commanderflight > > > We are working closely with other Commander sites and service providers, > oftentimes encouraging them to advertise on our FB page at no cost by > posting stuff of interest. Oftentimes I'd browse sites for AC's for sale > and just post those as stuff of interest. > > > Our Facebook page is slowly creeping to the 1,000 likes mark, oftentimes > gaining 100 likes in a week, depending on the content I publish. The > all-time consistent record breaker is, of course, stuff about Bob Hoover. > In a close second position is material about fancy flying, like the great > video clip about landing on a sandbank that I published a couple of years > ago. > > > Thank you very much for everyone who make this a pleasure and keep on > visiting our page regularly. > > > We are still trying to work things so that we can attend the fly-in next > month, but if we are not able, having a lot of photographs and videos would > make the absence a bit more bearable. If we are able to make it, well, then > we'll see you all there. > > > It'll be the first fly-in without Moe? > > > Many thanks, > > > Nico > > > * > > > * > > ________________________________________________________________________________
Date: Aug 16, 2015
This is Glenn Hancock, I'm the one that purchased Moe's airplane and am in the process of getting it flying again. I was hoping it just needed an annual but turned out it needed quite a bit of work. As a result I'll be missing the fly-in as well but hope to be there next year. I plan to take video and pictures during the annual and fixing up process and will post them once we get her going. The props and governors are at the shop now but hoping to get them back in the next couple weeks. The annual is in process now but having to replace a ton of seals and o-rings to stop skydrol leaks and engine oil. I hope to send pictures/videos of her flying sooner rather than later but at the moment it looks like at least 2 more months. Can't wait to start flying it!!! Glenn On Sat, Aug 15, 2015 at 8:29 PM, Russell Legg wrote: > Hello Nico, > > We sincerely appreciate the opportunities that your website affords the > worldwide Aero Commander community and it is a great way of keeping > connected - thank you! > > It would be great to see you guys at the Flyin in late September at > Colorado Springs. > > Moe will certainly be with us all in spirit - he and 680RR will be sorely > missed. > > Hope toy see you soon! > > Russell > > On Sun, Aug 16, 2015 at 9:48 AM, nicoCSS wrote: > >> Folks, >> >> >> >> There are many Commander enthusiasts worldwide. As a small contribution >> to service the aviation community in general and the Aero Commander >> community in particular, I started an Aero Commander facebook page a while >> ago at www.facebook.com/commanderflight >> >> >> >> We are working closely with other Commander sites and service providers, >> oftentimes encouraging them to advertise on our FB page at no cost by >> posting stuff of interest. Oftentimes I'd browse sites for AC's for sale >> and just post those as stuff of interest. >> >> >> >> Our Facebook page is slowly creeping to the 1,000 likes mark, oftentimes >> gaining 100 likes in a week, depending on the content I publish. The >> all-time consistent record breaker is, of course, stuff about Bob Hoover. >> In a close second position is material about fancy flying, like the great >> video clip about landing on a sandbank that I published a couple of years >> ago. >> >> >> >> Thank you very much for everyone who make this a pleasure and keep on >> visiting our page regularly. >> >> >> >> We are still trying to work things so that we can attend the fly-in next >> month, but if we are not able, having a lot of photographs and videos would >> make the absence a bit more bearable. If we are able to make it, well, then >> we'll see you all there. >> >> >> >> It'll be the first fly-in without Moe? >> >> >> >> Many thanks, >> >> >> >> Nico >> >> >> >> * >> >> " target="_blank">http://www.matronics.com/Navigator?Commander-List >> tp://forums.matronics.com <http://forums.matronics.com> >> _blank">http://www.matronics.com/contribution >> >> * >> >> > * > > > * > > -- --glenn hancock You can't win an argument with an ignorant person. They'll just drag you down to their level and beat you with experience. ________________________________________________________________________________
Date: Aug 17, 2015
G'day Glenn, Great that you have got your Commander into the shop and moving towards flight time. You would be most welcome to get along to the Flyin without your Commander - a lot of folk do from year to year... Cheers Russell On Mon, Aug 17, 2015 at 1:17 AM, Glenn Hancock wrote: > This is Glenn Hancock, I'm the one that purchased Moe's airplane and am in > the process of getting it flying again. I was hoping it just needed an > annual but turned out it needed quite a bit of work. As a result I'll be > missing the fly-in as well but hope to be there next year. I plan to take > video and pictures during the annual and fixing up process and will post > them once we get her going. The props and governors are at the shop now > but hoping to get them back in the next couple weeks. The annual is in > process now but having to replace a ton of seals and o-rings to stop > skydrol leaks and engine oil. > > I hope to send pictures/videos of her flying sooner rather than later but > at the moment it looks like at least 2 more months. > > Can't wait to start flying it!!! > > Glenn > > On Sat, Aug 15, 2015 at 8:29 PM, Russell Legg wrote: > >> Hello Nico, >> >> We sincerely appreciate the opportunities that your website affords the >> worldwide Aero Commander community and it is a great way of keeping >> connected - thank you! >> >> It would be great to see you guys at the Flyin in late September at >> Colorado Springs. >> >> Moe will certainly be with us all in spirit - he and 680RR will be sorely >> missed. >> >> Hope toy see you soon! >> >> Russell >> >> On Sun, Aug 16, 2015 at 9:48 AM, nicoCSS >> wrote: >> >>> Folks, >>> >>> >>> >>> There are many Commander enthusiasts worldwide. As a small contribution >>> to service the aviation community in general and the Aero Commander >>> community in particular, I started an Aero Commander facebook page a while >>> ago at www.facebook.com/commanderflight >>> >>> >>> >>> We are working closely with other Commander sites and service providers, >>> oftentimes encouraging them to advertise on our FB page at no cost by >>> posting stuff of interest. Oftentimes I'd browse sites for AC's for sale >>> and just post those as stuff of interest. >>> >>> >>> >>> Our Facebook page is slowly creeping to the 1,000 likes mark, oftentimes >>> gaining 100 likes in a week, depending on the content I publish. The >>> all-time consistent record breaker is, of course, stuff about Bob Hoover. >>> In a close second position is material about fancy flying, like the great >>> video clip about landing on a sandbank that I published a couple of years >>> ago. >>> >>> >>> >>> Thank you very much for everyone who make this a pleasure and keep on >>> visiting our page regularly. >>> >>> >>> >>> We are still trying to work things so that we can attend the fly-in next >>> month, but if we are not able, having a lot of photographs and videos would >>> make the absence a bit more bearable. If we are able to make it, well, then >>> we'll see you all there. >>> >>> >>> >>> It'll be the first fly-in without Moe? >>> >>> >>> >>> Many thanks, >>> >>> >>> >>> Nico >>> >>> >>> >>> * >>> >>> " target="_blank">http://www.matronics.com/Navigator?Commander-List >>> tp://forums.matronics.com <http://forums.matronics.com> >>> _blank">http://www.matronics.com/contribution >>> >>> * >>> >>> >> * >> >> " target="_blank">http://www.matronics.com/Navigator?Commander-List >> tp://forums.matronics.com <http://forums.matronics.com> >> _blank">http://www.matronics.com/contribution >> >> * >> >> > > > -- > --glenn hancock > > You can't win an argument with an ignorant person. They'll just drag you > down to their level and beat you with experience. > > * > > > * > > ________________________________________________________________________________
Subject: TCFG Fly In
Date: Aug 21, 2015
The Hilton Garden at KCOS emailed there concern about lack of reservations from our group. Indicating they are having lots of request for rooms because of AOPA's convention and want to release the rooms. Please go ahead and make your res ASAP. Also please email me. I am late in getting the usual registration forms out, will try this coming week. Hope to a lot of you soon. Dan ________________________________________________________________________________
Subject: KCOS Garden Hilton
Date: Aug 30, 2015
Tomorrow, August 31, 2015 is last day to receive TCFG group discount. ________________________________________________________________________________
Subject: TCFG FLY IN
Date: Sep 01, 2015
Please post on here or email me at daniellfarmer(at)yahoo.com if you are coming. The number in your party. If not WHY NOT. Post if you need a ride and where from. Please post if you would like a passenger. It would only be reasonable to help pay expenses, gas etc. I think the AOPA Venue will be very interesting. Thanks, Dan ________________________________________________________________________________
Subject: Re: Commander-List Digest: 0 Msgs - 09/18/15
Date: Sep 19, 2015
Is this medium dead? I hardly ever see it used. It seems like nearly everyone has moved to Facebook. If you are here don't forget the TCFG/ AOPA fly in this coming week. Dan Sent from my iPad > On Sep 19, 2015, at 12:59 AM, Commander-List Digest Server wrote: > > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete Commander-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the Commander-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 15-09-18&Archive=Commander > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 15-09-18&Archive=Commander > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > Commander-List Digest Archive > --- > Total Messages Posted Fri 09/18/15: 0 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > > > > > > > > > > ________________________________________________________________________________
Date: Sep 19, 2015
See you Thursday Daniel. We are headed to KBJC tomorrow. I am getting some mountain flying training on Monday with the Rocky Mountain Flying School. Tuesday we are flying to Aspen to visit friends for a few days and then to Colorado Springs on Thursday. Have my golf course painting ready! -----Original Message----- From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Dan Sent: Saturday, September 19, 2015 9:14 AM Subject: Commander-List: Re: Commander-List Digest: 0 Msgs - 09/18/15 Is this medium dead? I hardly ever see it used. It seems like nearly everyone has moved to Facebook. If you are here don't forget the TCFG/ AOPA fly in this coming week. Dan Sent from my iPad > On Sep 19, 2015, at 12:59 AM, Commander-List Digest Server wrote: > > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete Commander-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the Commander-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 15-09-18&Archive=Commander > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 15-09-18&Archive=Commander > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > Commander-List Digest Archive > --- > Total Messages Posted Fri 09/18/15: 0 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > > > > > > > > > > ________________________________________________________________________________
Date: Sep 19, 2015
Bob, I am doing a job at the Leadville Airport. We are moving the Avgas Ns JetA tanks next to the new hangar. Needs to be away from the runway. They give you a certificate for landing at the highest airport. 9927' I will be in KCOS on Thursday. Tylor Hall 505-400-8373 Sent from my iPad Tylor Hall 505-400-8373 > On Sep 19, 2015, at 7:22 AM, Steele, Bob wrote: > > > See you Thursday Daniel. We are headed to KBJC tomorrow. I am getting some mountain flying training on Monday with the Rocky Mountain Flying School. Tuesday we are flying to Aspen to visit friends for a few days and then to Colorado Springs on Thursday. > > Have my golf course painting ready! > > > -----Original Message----- > From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Dan > Sent: Saturday, September 19, 2015 9:14 AM > To: commander-list(at)matronics.com > Subject: Commander-List: Re: Commander-List Digest: 0 Msgs - 09/18/15 > > > Is this medium dead? I hardly ever see it used. It seems like nearly everyone has moved to Facebook. > If you are here don't forget the TCFG/ AOPA fly in this coming week. > Dan > > Sent from my iPad > >> On Sep 19, 2015, at 12:59 AM, Commander-List Digest Server wrote: >> >> * >> >> ================================================= >> Online Versions of Today's List Digest Archive >> ================================================= >> >> Today's complete Commander-List Digest can also be found in either of the >> two Web Links listed below. The .html file includes the Digest formatted >> in HTML for viewing with a web browser and features Hyperlinked Indexes >> and Message Navigation. The .txt file includes the plain ASCII version >> of the Commander-List Digest and can be viewed with a generic text editor >> such as Notepad or with a web browser. >> >> HTML Version: >> >> http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 15-09-18&Archive=Commander >> >> Text Version: >> >> http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 15-09-18&Archive=Commander >> >> >> =============================================== >> EMail Version of Today's List Digest Archive >> =============================================== >> >> >> ---------------------------------------------------------- >> Commander-List Digest Archive >> --- >> Total Messages Posted Fri 09/18/15: 0 >> ---------------------------------------------------------- >> >> >> Today's Message Index: >> ---------------------- > > > > > > > > > > ________________________________________________________________________________
Date: Sep 20, 2015
Tyler We will come over and supervise for a while! My wife's great grandfather was a 21 year old German immigrant in Leadville in the late 1800's. We have always wanted to visit and I always wanted to get the certificate. Bob Sent from my iPad > On Sep 19, 2015, at 7:32 PM, Tylor Hall wrote: > > > Bob, > I am doing a job at the Leadville Airport. > We are moving the Avgas Ns JetA tanks next to the new hangar. > Needs to be away from the runway. > They give you a certificate for landing at the highest airport. > 9927' > I will be in KCOS on Thursday. > Tylor Hall > 505-400-8373 > > Sent from my iPad > Tylor Hall > 505-400-8373 > >> On Sep 19, 2015, at 7:22 AM, Steele, Bob wrote: >> >> >> See you Thursday Daniel. We are headed to KBJC tomorrow. I am getting some mountain flying training on Monday with the Rocky Mountain Flying School. Tuesday we are flying to Aspen to visit friends for a few days and then to Colorado Springs on Thursday. >> >> Have my golf course painting ready! >> >> >> -----Original Message----- >> From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Dan >> Sent: Saturday, September 19, 2015 9:14 AM >> To: commander-list(at)matronics.com >> Subject: Commander-List: Re: Commander-List Digest: 0 Msgs - 09/18/15 >> >> >> Is this medium dead? I hardly ever see it used. It seems like nearly everyone has moved to Facebook. >> If you are here don't forget the TCFG/ AOPA fly in this coming week. >> Dan >> >> Sent from my iPad >> >>> On Sep 19, 2015, at 12:59 AM, Commander-List Digest Server wrote: >>> >>> * >>> >>> ================================================= >>> Online Versions of Today's List Digest Archive >>> ================================================= >>> >>> Today's complete Commander-List Digest can also be found in either of the >>> two Web Links listed below. The .html file includes the Digest formatted >>> in HTML for viewing with a web browser and features Hyperlinked Indexes >>> and Message Navigation. The .txt file includes the plain ASCII version >>> of the Commander-List Digest and can be viewed with a generic text editor >>> such as Notepad or with a web browser. >>> >>> HTML Version: >>> >>> http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 15-09-18&Archive=Commander >>> >>> Text Version: >>> >>> http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 15-09-18&Archive=Commander >>> >>> >>> =============================================== >>> EMail Version of Today's List Digest Archive >>> =============================================== >>> >>> >>> ---------------------------------------------------------- >>> Commander-List Digest Archive >>> --- >>> Total Messages Posted Fri 09/18/15: 0 >>> ---------------------------------------------------------- >>> >>> >>> Today's Message Index: >>> ---------------------- >> >> >> >> >> >> >> >> >> >> > > > > > ________________________________________________________________________________
Subject: How can we get a vital Commander forum?
Date: Sep 22, 2015
I'm not sure I'm doing it right. I've always logged into this forum that's hosted here at Matronics, even though I'm a TCFG member (I can't log in from the website). It's not really a forum, it's more of a list. I'm not sure that's the same forum you see if you log in from the TCFG website, or if I happened to stumble on some backdoor entry. In any case, all the posts look like a string of usenet list, with quotes embedded with weird chevrons etc in plain text. It all looks very 1994 and on code level. Is that how everyone else sees it to? I would suggest we start a proper forum, with topics, and where members have to use their own name. I would model it after the Beech Forum, which is exemplary. I would use that web host engine. I would also like to see more intermixing and intermingling between the turbine crowd and the piston crowd. Today there seems to be an abyss between the two - and no good place to find much information. The factory forum is pretty dead. If we could somehow combine them all in one place, we might get some real conversation going. I understand there's a lot of info that's embedded here in lists from the past that would not be easy to port to a forum, but as it is now, it's very hard to search on the Matronics list - one almost has more luck just Googling for it. Has there been any plans to port this forum or list to a fully blown forum? -------- Adam Read this topic online here: http://forums.matronics.com/viewtopic.php?p=447355#447355 ________________________________________________________________________________
Date: Sep 22, 2015
Subject: Re: How can we get a vital Commander forum?
G'day Adam, What cell number can I call you on? Cheers Russell On Tue, Sep 22, 2015 at 4:17 PM, stratobee wrote: > > I'm not sure I'm doing it right. I've always logged into this forum that's > hosted here at Matronics, even though I'm a TCFG member (I can't log in > from the website). It's not really a forum, it's more of a list. I'm not > sure that's the same forum you see if you log in from the TCFG website, or > if I happened to stumble on some backdoor entry. In any case, all the posts > look like a string of usenet list, with quotes embedded with weird chevrons > etc in plain text. It all looks very 1994 and on code level. Is that how > everyone else sees it to? > > I would suggest we start a proper forum, with topics, and where members > have to use their own name. I would model it after the Beech Forum, which > is exemplary. I would use that web host engine. > > I would also like to see more intermixing and intermingling between the > turbine crowd and the piston crowd. Today there seems to be an abyss > between the two - and no good place to find much information. The factory > forum is pretty dead. If we could somehow combine them all in one place, we > might get some real conversation going. > > I understand there's a lot of info that's embedded here in lists from the > past that would not be easy to port to a forum, but as it is now, it's very > hard to search on the Matronics list - one almost has more luck just > Googling for it. > > Has there been any plans to port this forum or list to a fully blown forum? > > -------- > Adam > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=447355#447355 > > ________________________________________________________________________________
Date: Sep 23, 2015
Adam I conquer with you completely, For one thing, most of Jim Bob's posting do not make it on the forum. How absurd is that? Last year, Moe was trying to communicate to Jim about the incoming Fly-in and Jim was trying to answer but was not being posted on the forum. It seems indeed that people in Commander land have more and more drifted to Facebook, where a casual post is fine, but there is no room for a discussion in that format. I dont' know if people have been communicating through the new TCFG web page, but it's been really a long time since I have seen a constructive conversation or inquiry about Commanders in this forum. I know that other pillars in this forum such as Keith Gordon and John Towner have had problems posting as well, and many posting show in the forum but we do not get it in our emails. When things get too quiet, I have to log on the forum to realize I have been missing a batch of strings! All that to say, I agree 100%, that the issue of a better platform discussion is necessary. The idea to join both the Turbo and piston Commanders discussions have been at the core of this group for a long time and the Twin Commander folks have tried to reach to the piston group as well, but it is obvious that a common forum where we could all discuss Aero Commanders would be beneficial for both groups. We should let the users then decide on where to participate but have the options open. I have heard of the site being moved somewhere else but the forum itself has stayed the same. On Tue, Sep 22, 2015 at 3:17 PM, stratobee wrote: > > I'm not sure I'm doing it right. I've always logged into this forum that's > hosted here at Matronics, even though I'm a TCFG member (I can't log in > from the website). It's not really a forum, it's more of a list. I'm not > sure that's the same forum you see if you log in from the TCFG website, or > if I happened to stumble on some backdoor entry. In any case, all the posts > look like a string of usenet list, with quotes embedded with weird chevrons > etc in plain text. It all looks very 1994 and on code level. Is that how > everyone else sees it to? > > I would suggest we start a proper forum, with topics, and where members > have to use their own name. I would model it after the Beech Forum, which > is exemplary. I would use that web host engine. > > I would also like to see more intermixing and intermingling between the > turbine crowd and the piston crowd. Today there seems to be an abyss > between the two - and no good place to find much information. The factory > forum is pretty dead. If we could somehow combine them all in one place, we > might get some real conversation going. > > I understand there's a lot of info that's embedded here in lists from the > past that would not be easy to port to a forum, but as it is now, it's very > hard to search on the Matronics list - one almost has more luck just > Googling for it. > > Has there been any plans to port this forum or list to a fully blown forum? > > -------- > Adam > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=447355#447355 > > ________________________________________________________________________________
Date: Sep 23, 2015
So, I'm glad someone brought this up as I'm new to the group and absolutely hating the 1990's communication method :-) I am a software engineer and own a software company that provides business systems to many different industries. Only point here is that I own a large amount of web servers and would be more than happy to host a new forum with the latest forum software we can find. We can setup a few admins on the group to help manage it and invite everyone we can find to participate in the talks. I looked around and found one such forum but there was no activity on it and I'm not sure why not. Maybe we can all just move over to their site and start using it instead of using this email list. My main complaint with this list is some conversations pop in out of nowhere with an obvious conversation that was going on but I only get a portion of it. Just my 2 cents, Glenn On Wed, Sep 23, 2015 at 3:56 AM, pbgtutubo . wrote: > Adam I conquer with you completely, > > For one thing, most of Jim Bob's posting do not make it on the forum. How > absurd is that? > > Last year, Moe was trying to communicate to Jim about the incoming Fly-in > and Jim was trying to answer but was not being posted on the forum. It > seems indeed that people in Commander land have more and more drifted to > Facebook, where a casual post is fine, but there is no room for a > discussion in that format. > > I dont' know if people have been communicating through the new TCFG web > page, but it's been really a long time since I have seen a constructive > conversation or inquiry about Commanders in this forum. > > I know that other pillars in this forum such as Keith Gordon and John > Towner have had problems posting as well, and many posting show in the > forum but we do not get it in our emails. When things get too quiet, I have > to log on the forum to realize I have been missing a batch of strings! > > All that to say, I agree 100%, that the issue of a better platform > discussion is necessary. > > The idea to join both the Turbo and piston Commanders discussions have > been at the core of this group for a long time and the Twin Commander folks > have tried to reach to the piston group as well, but it is obvious that a > common forum where we could all discuss Aero Commanders would be beneficial > for both groups. We should let the users then decide on where to > participate but have the options open. > > I have heard of the site being moved somewhere else but the forum itself > has stayed the same. > > > On Tue, Sep 22, 2015 at 3:17 PM, stratobee wrote: > >> >> I'm not sure I'm doing it right. I've always logged into this forum >> that's hosted here at Matronics, even though I'm a TCFG member (I can't log >> in from the website). It's not really a forum, it's more of a list. I'm not >> sure that's the same forum you see if you log in from the TCFG website, or >> if I happened to stumble on some backdoor entry. In any case, all the posts >> look like a string of usenet list, with quotes embedded with weird chevrons >> etc in plain text. It all looks very 1994 and on code level. Is that how >> everyone else sees it to? >> >> I would suggest we start a proper forum, with topics, and where members >> have to use their own name. I would model it after the Beech Forum, which >> is exemplary. I would use that web host engine. >> >> I would also like to see more intermixing and intermingling between the >> turbine crowd and the piston crowd. Today there seems to be an abyss >> between the two - and no good place to find much information. The factory >> forum is pretty dead. If we could somehow combine them all in one place, we >> might get some real conversation going. >> >> I understand there's a lot of info that's embedded here in lists from the >> past that would not be easy to port to a forum, but as it is now, it's very >> hard to search on the Matronics list - one almost has more luck just >> Googling for it. >> >> Has there been any plans to port this forum or list to a fully blown >> forum? >> >> -------- >> Adam >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=447355#447355 >> >> >> >> >> >> >> >> ========== >> br> ander-List" rel="noreferrer" target="_blank"> >> http://www.matronics.com/Navigator?Commander-List >> ========== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> ========== >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >> ========== >> >> >> >> > * > > > * > > -- --glenn hancock You can't win an argument with an ignorant person. They'll just drag you down to their level and beat you with experience. ________________________________________________________________________________
Date: Sep 23, 2015
Hi Russel. I can be reached on 310 383-2944. -------- Adam Read this topic online here: http://forums.matronics.com/viewtopic.php?p=447400#447400 ________________________________________________________________________________
Date: Sep 23, 2015
Hi Adam, Great - will call you tomorrow (Thursday). Cheers Russell On Wed, Sep 23, 2015 at 3:19 PM, stratobee wrote: > > Hi Russel. > > I can be reached on 310 383-2944. > > -------- > Adam > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=447400#447400 > > ________________________________________________________________________________
Date: Sep 24, 2015
Was looking at domains for it. Www.twincommanders.com is available, but it kind of suggest turbines are not welcome. Www.aerocommanders.com is available, and so is aerocommanderforum.com, but I'm not sure that was the correct manufacturing name for the models made under Rockwell and Gulfstream. Again, don't want to make anyone feel excluded. Thoughts? -------- Adam Read this topic online here: http://forums.matronics.com/viewtopic.php?p=447422#447422 ________________________________________________________________________________
From: Eric Williams <williams.ericlofton(at)GMAIL.COM>
Date: Sep 24, 2015
Aerocommanders.com and twincommanders.com sound good to me. > On Sep 24, 2015, at 19:35, stratobee wrote: > > > Was looking at domains for it. Www.twincommanders.com is available, but it kind of suggest turbines are not welcome. Www.aerocommanders.com is available, and so is aerocommanderforum.com, but I'm not sure that was the correct manufacturing name for the models made under Rockwell and Gulfstream. Again, don't want to make anyone feel excluded. > > Thoughts? > > -------- > Adam > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=447422#447422 > > > > > > > > > > ________________________________________________________________________________
Date: Sep 24, 2015
Registered www.twincommanders.com now. -------- Adam Read this topic online here: http://forums.matronics.com/viewtopic.php?p=447424#447424 ________________________________________________________________________________
Date: Sep 24, 2015
CiAgICAKTGV0IHVzIG5vdCBmb3JnZXQgdGhlIC5hZXJvIGRvbWFpbi4KS2VpdGggUyBHb3Jkb24K U2VudCBvbiB0aGUgZmx5IPCfjJAKCi0tLS0tLS0tIE9yaWdpbmFsIG1lc3NhZ2UgLS0tLS0tLS0K RnJvbTogRXJpYyBXaWxsaWFtcyA8d2lsbGlhbXMuZXJpY2xvZnRvbkBHTUFJTC5DT00+IApEYXRl OiAyNC8wOS8yMDE1ICAxNzo1NSAgKEdNVC0wODowMCkgClRvOiBjb21tYW5kZXItbGlzdEBtYXRy b25pY3MuY29tIApTdWJqZWN0OiBSZTogQ29tbWFuZGVyLUxpc3Q6IFJlOiBIb3cgY2FuIHdlIGdl dCBhIHZpdGFsIENvbW1hbmRlciBmb3J1bT8gCgotLT4gQ29tbWFuZGVyLUxpc3QgbWVzc2FnZSBw b3N0ZWQgYnk6IEVyaWMgV2lsbGlhbXMgPHdpbGxpYW1zLmVyaWNsb2Z0b25AZ21haWwuY29tPgoK QWVyb2NvbW1hbmRlcnMuY29tIGFuZCB0d2luY29tbWFuZGVycy5jb20gc291bmQgZ29vZCB0byBt ZS4gCgo+IE9uIFNlcCAyNCwgMjAxNSwgYXQgMTk6MzUsIHN0cmF0b2JlZSA8YWRhbUBhZGFtZnJp c2NoLmNvbT4gd3JvdGU6Cj4gCj4gLS0+IENvbW1hbmRlci1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5 OiAic3RyYXRvYmVlIiA8YWRhbUBhZGFtZnJpc2NoLmNvbT4KPiAKPiBXYXMgbG9va2luZyBhdCBk b21haW5zIGZvciBpdC4gV3d3LnR3aW5jb21tYW5kZXJzLmNvbSBpcyBhdmFpbGFibGUsIGJ1dCBp dCBraW5kIG9mIHN1Z2dlc3QgdHVyYmluZXMgYXJlIG5vdCB3ZWxjb21lLiBXd3cuYWVyb2NvbW1h bmRlcnMuY29tIGlzIGF2YWlsYWJsZSwgYW5kIHNvIGlzIGFlcm9jb21tYW5kZXJmb3J1bS5jb20s IGJ1dCBJJ20gbm90IHN1cmUgdGhhdCB3YXMgdGhlIGNvcnJlY3QgbWFudWZhY3R1cmluZyBuYW1l IGZvciB0aGUgbW9kZWxzIG1hZGUgdW5kZXIgUm9ja3dlbGwgYW5kIEd1bGZzdHJlYW0uIEFnYWlu LCBkb24ndCB3YW50IHRvIG1ha2UgYW55b25lIGZlZWwgZXhjbHVkZWQuCj4gCj4gVGhvdWdodHM/ Cj4gCj4gLS0tLS0tLS0KPiBBZGFtCj4gCj4gCj4gCj4gCj4gUmVhZCB0aGlzIHRvcGljIG9ubGlu ZSBoZXJlOgo+IAo+IGh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbS92aWV3dG9waWMucGhwP3A9 NDQ3NDIyIzQ0NzQyMgo+IAo+IAo+IAo+IAo+IAo+IAo+IAo+IAo+IAo+IAoKCl8tPT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09Cl8tPcKg wqDCoMKgwqDCoMKgwqDCoCAtIFRoZSBDb21tYW5kZXItTGlzdCBFbWFpbCBGb3J1bSAtCl8tPSBV c2UgdGhlIE1hdHJvbmljcyBMaXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0byBicm93c2UKXy09IHRo ZSBtYW55IExpc3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sCl8tPSBB cmNoaXZlIFNlYXJjaCAmIERvd25sb2FkLCA3LURheSBCcm93c2UsIENoYXQsIEZBUSwKXy09IFBo b3Rvc2hhcmUsIGFuZCBtdWNoIG11Y2ggbW9yZToKXy09Cl8tPcKgwqAgLS0+IGh0dHA6Ly93d3cu bWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/Q29tbWFuZGVyLUxpc3QKXy09Cl8tPT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09Cl8tPcKgwqDC oMKgwqDCoMKgwqDCoMKgwqDCoMKgwqAgLSBNQVRST05JQ1MgV0VCIEZPUlVNUyAtCl8tPSBTYW1l IGdyZWF0IGNvbnRlbnQgYWxzbyBhdmFpbGFibGUgdmlhIHRoZSBXZWIgRm9ydW1zIQpfLT0KXy09 wqDCoCAtLT4gaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tCl8tPQpfLT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT3CoMKgwqDC oMKgwqDCoMKgwqDCoMKgwqAgLSBMaXN0IENvbnRyaWJ1dGlvbiBXZWIgU2l0ZSAtCl8tPcKgIFRo YW5rIHlvdSBmb3IgeW91ciBnZW5lcm91cyBzdXBwb3J0IQpfLT3CoMKgwqDCoMKgwqDCoMKgwqDC oMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgIC1NYXR0IERyYWxsZSwgTGlz dCBBZG1pbi4KXy09wqDCoCAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlv bgpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PQoKCgo ________________________________________________________________________________
Date: Sep 25, 2015
So I'm a bit confused: 1) There is already a site at http://www.flightlevelsonline.com/phpBB/ that seems dedicated to commanders but no one seems to use it. I posted something there before finding this email list that to this day still has not been responded to. Why? 2) I have created a new forum at twincommandersgroup.com and plan to leave it up as long as you guys want to use it but I guess the question is, why does no one use the other one? Is this one going to get ignored as badly as it and why don't we all just move over there and stop using this email list? The forum can be set to send emails when new posts are made and it keeps all of the posts organized so people can go back and search old topics. Is anyone interested in using my forum, the other forum or is everyone stuck on the email list? Thanks, Glenn On Thu, Sep 24, 2015 at 8:55 PM, Eric Williams < williams.ericlofton(at)gmail.com> wrote: > williams.ericlofton(at)gmail.com> > > Aerocommanders.com and twincommanders.com sound good to me. > > > On Sep 24, 2015, at 19:35, stratobee wrote: > > > > > > Was looking at domains for it. Www.twincommanders.com is available, but > it kind of suggest turbines are not welcome. Www.aerocommanders.com is > available, and so is aerocommanderforum.com, but I'm not sure that was > the correct manufacturing name for the models made under Rockwell and > Gulfstream. Again, don't want to make anyone feel excluded. > > > > Thoughts? > > > > -------- > > Adam > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=447422#447422 > > > > > > > > > > > > > > > > > > > > > > -- --glenn hancock You can't win an argument with an ignorant person. They'll just drag you down to their level and beat you with experience. ________________________________________________________________________________
forum?
Date: Sep 25, 2015
The first time I posted this, it didn't get to the list Adam, I still "own" the www.aerocommander.com domain, which is forwarded to www.twincommander.org where TCFG's web page is located. I put "own" in quotes because it really is the property of TCFG, which I just put on my ICANN register to manage the domain's DNS entries. I also run/own the www.facebook.com/commanderflight facebook page. It is reasonably active, has more than 1,000 likes and the fans are from all over the globe. The best "reach" any posting had is the helicopter crash after an aerobatic maneuver, which stands at 89,000 and climbing by the thousands every day. The average is about 200-300 per posting. The facebook page accommodates posts from aviation in general but Aero Commanders in particular. Many of the articles, brochures, and other technical data were uploaded from the original CD's sent to me years ago by (I cannot recall) and are visible on the facebook page. There are tons of stuff there. The Metzger friends will be able to explain more about these resources as they have been intimately involved in shaping what these sites have become, not discounting others' contributions over the years. You will notice a distinct presence of turbines and piston Commanders there. If it can be used, I'll transfer it wherever it can be used productively. The burden of the annual cost of renewal will have to follow the domain, too. I kept it up for a generation and it is not really used in its current form. If there's anything I can do to help, just let me know. Thanks Nico From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Glenn Hancock Sent: Friday, September 25, 2015 7:08 AM Subject: [matronics.com] Re: Commander-List: Re: How can we get a vital Commander forum? So I'm a bit confused: 1) There is already a site at http://www.flightlevelsonline.com/phpBB/ that seems dedicated to commanders but no one seems to use it. I posted something there before finding this email list that to this day still has not been responded to. Why? 2) I have created a new forum at twincommandersgroup.com and plan to leave it up as long as you guys want to use it but I guess the question is, why does no one use the other one? Is this one going to get ignored as badly as it and why don't we all just move over there and stop using this email list? The forum can be set to send emails when new posts are made and it keeps all of the posts organized so people can go back and search old topics. Is anyone interested in using my forum, the other forum or is everyone stuck on the email list? Thanks, Glenn On Thu, Sep 24, 2015 at 8:55 PM, Eric Williams wrote: Aerocommanders.com and twincommanders.com sound good to me. > On Sep 24, 2015, at 19:35, stratobee wrote: > > > Was looking at domains for it. Www.twincommanders.com is available, but it kind of suggest turbines are not welcome. Www.aerocommanders.com is available, and so is aerocommanderforum.com, but I'm not sure that was the correct manufacturing name for the models made under Rockwell and Gulfstream. Again, don't want to make anyone feel excluded. > > Thoughts? > > -------- > Adam > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=447422#447422 > > br> ander-List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Commander-List FORUMS - eferrer" target="_blank">http://forums.matronics.com b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution -- --glenn hancock You can't win an argument with an ignorant person. They'll just drag you down to their level and beat you with experience. ________________________________________________________________________________
Subject: Jim Metzger and N222JS
Date: Sep 25, 2015
Jim Metzger was critically injured earlier this week when N222JS crashed on landing at Boise ID airport. The Saint Alphonsus Regional Medical Center in Boise said there is no person by that name in the hospital. Weird. I am trying to get hold of Sue to give us an update as we are very concerned and shocked at this accident. Keep Jim and Sue in your prayers. Read all about it with pictures and video: https://www.facebook.com/COMMANDERFLIGHT Nico From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Nico hMail Sent: Friday, September 25, 2015 1:05 PM Subject: RE: [matronics.com] Re: Commander-List: Re: How can we get a vital Commander forum? The first time I posted this, it didn't get to the list Adam, I still "own" the www.aerocommander.com domain, which is forwarded to www.twincommander.org where TCFG's web page is located. I put "own" in quotes because it really is the property of TCFG, which I just put on my ICANN register to manage the domain's DNS entries. I also run/own the www.facebook.com/commanderflight facebook page. It is reasonably active, has more than 1,000 likes and the fans are from all over the globe. The best "reach" any posting had is the helicopter crash after an aerobatic maneuver, which stands at 89,000 and climbing by the thousands every day. The average is about 200-300 per posting. The facebook page accommodates posts from aviation in general but Aero Commanders in particular. Many of the articles, brochures, and other technical data were uploaded from the original CD's sent to me years ago by (I cannot recall) and are visible on the facebook page. There are tons of stuff there. The Metzger friends will be able to explain more about these resources as they have been intimately involved in shaping what these sites have become, not discounting others' contributions over the years. You will notice a distinct presence of turbines and piston Commanders there. If it can be used, I'll transfer it wherever it can be used productively. The burden of the annual cost of renewal will have to follow the domain, too. I kept it up for a generation and it is not really used in its current form. If there's anything I can do to help, just let me know. Thanks Nico From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Glenn Hancock Sent: Friday, September 25, 2015 7:08 AM Subject: [matronics.com] Re: Commander-List: Re: How can we get a vital Commander forum? So I'm a bit confused: 1) There is already a site at http://www.flightlevelsonline.com/phpBB/ that seems dedicated to commanders but no one seems to use it. I posted something there before finding this email list that to this day still has not been responded to. Why? 2) I have created a new forum at twincommandersgroup.com and plan to leave it up as long as you guys want to use it but I guess the question is, why does no one use the other one? Is this one going to get ignored as badly as it and why don't we all just move over there and stop using this email list? The forum can be set to send emails when new posts are made and it keeps all of the posts organized so people can go back and search old topics. Is anyone interested in using my forum, the other forum or is everyone stuck on the email list? Thanks, Glenn On Thu, Sep 24, 2015 at 8:55 PM, Eric Williams wrote: Aerocommanders.com and twincommanders.com sound good to me. > On Sep 24, 2015, at 19:35, stratobee wrote: > > > Was looking at domains for it. Www.twincommanders.com is available, but it kind of suggest turbines are not welcome. Www.aerocommanders.com is available, and so is aerocommanderforum.com, but I'm not sure that was the correct manufacturing name for the models made under Rockwell and Gulfstream. Again, don't want to make anyone feel excluded. > > Thoughts? > > -------- > Adam > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=447422#447422 > > br> ander-List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Commander-List FORUMS - eferrer" target="_blank">http://forums.matronics.com b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution -- --glenn hancock You can't win an argument with an ignorant person. They'll just drag you down to their level and beat you with experience. http://www.matronics.com/Navigator?Commander-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
Subject: Re: Jim Metzger and N222JS
Date: Sep 25, 2015
Nico - I appreciate what has been done by you on Facebook, problem is I gave up Facebook two years ago and nothing, not even Commanders will make me come back. I'm also a reader of pretty much every flying forum there is, so what I want is only Commander specific stuff. I'm less interested in reading about aviation news in general, because I see it on all the other forums and websites too. But like Glenn said - maybe we should just use the one over at Flightlevels? I would like it to be under real names, but i suppose it works as is. Does anybody know who runs that board? -------- Adam Read this topic online here: http://forums.matronics.com/viewtopic.php?p=447452#447452 ________________________________________________________________________________
Subject: Re: [matronics.com] Re: How can we get a vital Commander for
Date: Sep 25, 2015
Nico - I appreciate what has been done by you on Facebook, problem is I gave up Facebook two years ago and nothing, not even Commanders will make me come back. I'm also a reader of pretty much every flying forum there is, so what I want is only Commander specific stuff. I'm less interested in reading about aviation news in general, because I see it on all the other forums and websites too. But like Glenn said - maybe we should just use the one over at Flightlevels? I would like it to be under real names, but i suppose it works as is. Does anybody know who runs that board? -------- Adam Read this topic online here: http://forums.matronics.com/viewtopic.php?p=447453#447453 ________________________________________________________________________________
Date: Sep 26, 2015
Hi Adam, I will call you soon to discuss the website and chatlist - I am sure we can improve on the status quo. Cheers Russell On Fri, Sep 25, 2015 at 11:54 PM, stratobee wrote: > > Nico - I appreciate what has been done by you on Facebook, problem is I > gave up Facebook two years ago and nothing, not even Commanders will make > me come back. I'm also a reader of pretty much every flying forum there is, > so what I want is only Commander specific stuff. I'm less interested in > reading about aviation news in general, because I see it on all the other > forums and websites too. > > But like Glenn said - maybe we should just use the one over at > Flightlevels? > I would like it to be under real names, but i suppose it works as is. Does > anybody know who runs that board? > > -------- > Adam > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=447452#447452 > > ________________________________________________________________________________
Date: Sep 26, 2015
What is the latest on Metzger ? Hope he is OK ? Gil Sent from my iPhone > On Sep 26, 2015, at 12:54 AM, "stratobee" wrote: > > > Nico - I appreciate what has been done by you on Facebook, problem is I gave up Facebook two years ago and nothing, not even Commanders will make me come back. I'm also a reader of pretty much every flying forum there is, so what I want is only Commander specific stuff. I'm less interested in reading about aviation news in general, because I see it on all the other forums and websites too. > > But like Glenn said - maybe we should just use the one over at Flightlevels? > I would like it to be under real names, but i suppose it works as is. Does anybody know who runs that board? > > -------- > Adam > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=447452#447452 > > > > > > > > > > ________________________________________________________________________________
Date: Sep 27, 2015
Nico, I also agree with Adam in that I absolutely hate Facebook. The problem is that it's simply a gossip center where people go to talk and post pictures and videos. It's not subject specific and trying to follow conversations or search for specific information is impossible. I would like to see a forum that is specific to our common interests and that we can control better. As I mentioned, I've already created a forum at twincommandergroup.com and created a few sections for conversations. There are a few things we all need to consider with a forum like this. 1) That more than one person be involved in the domain name so that when one of us passes on, the others can pickup the forum. One possible solution is that one of you has registered twincommanders.com. That could be pointed at my server and both domains would resolve to the same place for now but could be different later. 2) That the people involved have some sort of written agreement that if something were to happen to the person owning the server, that others can have it transferred to another server. 3) There are a couple options on the latter point, instead of me placing the forum on my own server I could just rent a server from one of the popular sites and we could place it there. You will get into disk size limits and other possible problems in that situation as well as costs involved that I'm more than happy to foot at the moment. I'm not rich but I do have the money to cover the server and operational costs. I just want somewhere that we can all gather and discuss what interests us about the Commanders family and not have to join an email list that I have a hard time keeping track of conversations or Facebook where I have to filter through everything. I'm also very very sorry to hear about Jim. The accident would seem to be some sort of catastrophic failure based on the accident report so far. I can't believe an engine failure would cause something like that unless power was added after the failure. I just purchased a 680F that I haven't begun to fly so am very interested in what happened. I hope he recovers and gets back to flying soon. Feel free to contact me at 770 490 7899 any time. Glenn On 9/25/15 8:45 PM, Nico hMail wrote: > > Jim Metzger was critically injured earlier this week when N222JS > crashed on landing at Boise ID airport. > > > > The Saint Alphonsus Regional Medical Center in Boise said there is no > person by that name in the hospital. Weird. > > > > I am trying to get hold of Sue to give us an update as we are very > concerned and shocked at this accident. Keep Jim and Sue in your prayers. > > > > Read all about it with pictures and video: > https://www.facebook.com/COMMANDERFLIGHT > > > > Nico > > > > > > > > *From:*owner-commander-list-server(at)matronics.com > [mailto:owner-commander-list-server(at)matronics.com] *On Behalf Of *Nico > hMail > *Sent:* Friday, September 25, 2015 1:05 PM > *To:* commander-list(at)matronics.com > *Subject:* RE: [matronics.com] Re: Commander-List: Re: How can we get > a vital Commander forum? > > > > The first time I posted this, it didn't get to the list > > > > Adam, > > > > I still "own" the www.aerocommander.com <http://www.aerocommander.com> > domain, which is forwarded to www.twincommander.org > <http://www.twincommander.org> where TCFG's web page is located. I put > "own" in quotes because it really is the property of TCFG, which I > just put on my ICANN register to manage the domain's DNS entries. > > > > I also run/own the www.facebook.com/commanderflight > <http://www.facebook.com/commanderflight> facebook page. It is > reasonably active, has more than 1,000 likes and the fans are from all > over the globe. The best "reach" any posting had is the helicopter > crash after an aerobatic maneuver, which stands at 89,000 and climbing > by the thousands every day. The average is about 200-300 per posting. > The facebook page accommodates posts from aviation in general but Aero > Commanders in particular. Many of the articles, brochures, and other > technical data were uploaded from the original CD's sent to me years > ago by (I cannot recall) and are visible on the facebook page. There > are tons of stuff there. The Metzger friends will be able to explain > more about these resources as they have been intimately involved in > shaping what these sites have become, not discounting others' > contributions over the years. You will notice a distinct presence of > turbines and piston Commanders there. > > > > If it can be used, I'll transfer it wherever it can be used > productively. The burden of the annual cost of renewal will have to > follow the domain, too. I kept it up for a generation and it is not > really used in its current form. > > > > If there's anything I can do to help, just let me know. > > > > Thanks > > > > Nico > > > > > > > > *From:*owner-commander-list-server(at)matronics.com > > [mailto:owner-commander-list-server(at)matronics.com] *On Behalf Of > *Glenn Hancock > *Sent:* Friday, September 25, 2015 7:08 AM > *To:* commander-list(at)matronics.com > *Subject:* [matronics.com] Re: Commander-List: Re: How can we get a > vital Commander forum? > > > > So I'm a bit confused: > > 1) There is already a site at > http://www.flightlevelsonline.com/phpBB/ that seems dedicated to > commanders but no one seems to use it. I posted something there > before finding this email list that to this day still has not been > responded to. Why? > > 2) I have created a new forum at twincommandersgroup.com > <http://twincommandersgroup.com> and plan to leave it up as long as > you guys want to use it but I guess the question is, why does no one > use the other one? Is this one going to get ignored as badly as it > and why don't we all just move over there and stop using this email list? > > The forum can be set to send emails when new posts are made and it > keeps all of the posts organized so people can go back and search old > topics. > > Is anyone interested in using my forum, the other forum or is everyone > stuck on the email list? > > Thanks, > > Glenn > > > > On Thu, Sep 24, 2015 at 8:55 PM, Eric Williams > > > wrote: > > > > > Aerocommanders.com and twincommanders.com <http://twincommanders.com> > sound good to me. > > > > On Sep 24, 2015, at 19:35, stratobee > wrote: > > > > > > > > Was looking at domains for it. Www.twincommanders.com > <http://Www.twincommanders.com> is available, but it kind of suggest > turbines are not welcome. Www.aerocommanders.com > <http://Www.aerocommanders.com> is available, and so is > aerocommanderforum.com <http://aerocommanderforum.com>, but I'm not > sure that was the correct manufacturing name for the models made under > Rockwell and Gulfstream. Again, don't want to make anyone feel excluded. > > > > Thoughts? > > > > -------- > > Adam > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=447422#447422 > > > > > > > > > > > > > > > > > > > > > > > ========== > br> ander-List" rel="noreferrer" > target="_blank">http://www.matronics.com/Navigator?Commander-List > ========== > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > ========== > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" target="_blank">http://www.matronics.com/contribution > ========== > > > -- > > --glenn hancock > > > > You can't win an argument with an ignorant person. They'll just drag > you down to their level and beat you with experience. > > > > * * > * * > * * > *http://www.matronics.com/Navigator?Commander-List* > * * > *http://forums.matronics.com* > * * > *http://www.matronics.com/contribution* > * * > * * > * * > * * > ** > ** > ** > ** > ** > *http://www.matronics.com/Navigator?Commander-List* > ** > ** > *http://forums.matronics.com* > ** > ** > ** > ** > *http://www.matronics.com/contribution* > ** > * * > * > > > * ________________________________________________________________________________
Date: Sep 27, 2015
Glen and Nico Jim is doing better and is going into surgery today some time. This is to put his hip back together. He was able to wiggle his toes and that is suppose to be good. The meeting here in Colorado Springs went well and people are now leaving to go home. Call me on my cell and I can tell you more. Tylor Hall tylorhall(at)mac.com ACN IBO Member 401 Monte Alto PL NE Albuquerque, NM 87123 505-247-3001 505-400-8373 Cell tylorhall.acndirect.com > On Sep 27, 2015, at 6:57 AM, Glenn Hancock wrote: > > Nico, > > I also agree with Adam in that I absolutely hate Facebook. The problem is that it's simply a gossip center where people go to talk and post pictures and videos. It's not subject specific and trying to follow conversations or search for specific information is impossible. I would like to see a forum that is specific to our common interests and that we can control better. > > As I mentioned, I've already created a forum at twincommandergroup.com and created a few sections for conversations. There are a few things we all need to consider with a forum like this. 1) That more than one person be involved in the domain name so that when one of us passes on, the others can pickup the forum. One possible solution is that one of you has registered twincommanders.com. That could be pointed at my server and both domains would resolve to the same place for now but could be different later. > > 2) That the people involved have some sort of written agreement that if something were to happen to the person owning the server, that others can have it transferred to another server. > > 3) There are a couple options on the latter point, instead of me placing the forum on my own server I could just rent a server from one of the popular sites and we could place it there. You will get into disk size limits and other possible problems in that situation as well as costs involved that I'm more than happy to foot at the moment. I'm not rich but I do have the money to cover the server and operational costs. I just want somewhere that we can all gather and discuss what interests us about the Commanders family and not have to join an email list that I have a hard time keeping track of conversations or Facebook where I have to filter through everything. > > I'm also very very sorry to hear about Jim. The accident would seem to be some sort of catastrophic failure based on the accident report so far. I can't believe an engine failure would cause something like that unless power was added after the failure. I just purchased a 680F that I haven't begun to fly so am very interested in what happened. I hope he recovers and gets back to flying soon. > > Feel free to contact me at 770 490 7899 any time. > > Glenn > > On 9/25/15 8:45 PM, Nico hMail wrote: >> Jim Metzger was critically injured earlier this week when N222JS crashed on landing at Boise ID airport. >> >> The Saint Alphonsus Regional Medical Center in Boise said there is no person by that name in the hospital. Weird. >> >> I am trying to get hold of Sue to give us an update as we are very concerned and shocked at this accident. Keep Jim and Sue in your prayers. >> >> Read all about it with pictures and video: https://www.facebook.com/COMMANDERFLIGHT >> >> Nico >> >> >> >> From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com ] On Behalf Of Nico hMail >> Sent: Friday, September 25, 2015 1:05 PM >> To: commander-list(at)matronics.com >> Subject: RE: [matronics.com] Re: Commander-List: Re: How can we get a vital Commander forum? >> >> The first time I posted this, it didn't get to the list >> >> Adam, >> >> I still "own" the www.aerocommander.com <http://www.aerocommander.com/> domain, which is forwarded to www.twincommander.org <http://www.twincommander.org/> where TCFG's web page is located. I put "own" in quotes because it really is the property of TCFG, which I just put on my ICANN register to manage the domain's DNS entries. >> >> I also run/own the www.facebook.com/commanderflight <http://www.facebook.com/commanderflight> facebook page. It is reasonably active, has more than 1,000 likes and the fans are from all over the globe. The best "reach" any posting had is the helicopter crash after an aerobatic maneuver, which stands at 89,000 and climbing by the thousands every day. The average is about 200-300 per posting. The facebook page accommodates posts from aviation in general but Aero Commanders in particular. Many of the articles, brochures, and other technical data were uploaded from the original CD's sent to me years ago by (I cannot recall) and are visible on the facebook page. There are tons of stuff there. The Metzger friends will be able to explain more about these resources as they have been intimately involved in shaping what these sites have become, not discounting others' contributions over the years. You will notice a distinct presence of turbines and piston Commanders there. >> >> If it can be used, I'll transfer it wherever it can be used productively. The burden of the annual cost of renewal will have to follow the domain, too. I kept it up for a generation and it is not really used in its current form. >> >> If there's anything I can do to help, just let me know. >> >> Thanks >> >> Nico >> >> >> >> From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com ] On Behalf Of Glenn Hancock >> Sent: Friday, September 25, 2015 7:08 AM >> To: commander-list(at)matronics.com >> Subject: [matronics.com] Re: Commander-List: Re: How can we get a vital Commander forum? >> >> So I'm a bit confused: >> >> 1) There is already a site at http://www.flightlevelsonline.com/phpBB/ <http://www.flightlevelsonline.com/phpBB/> that seems dedicated to commanders but no one seems to use it. I posted something there before finding this email list that to this day still has not been responded to. Why? >> >> 2) I have created a new forum at twincommandersgroup.com <http://twincommandersgroup.com/> and plan to leave it up as long as you guys want to use it but I guess the question is, why does no one use the other one? Is this one going to get ignored as badly as it and why don't we all just move over there and stop using this email list? >> >> The forum can be set to send emails when new posts are made and it keeps all of the posts organized so people can go back and search old topics. >> >> Is anyone interested in using my forum, the other forum or is everyone stuck on the email list? >> >> Thanks, >> >> Glenn >> >> On Thu, Sep 24, 2015 at 8:55 PM, Eric Williams > wrote: > >> >> Aerocommanders.com and twincommanders.com <http://twincommanders.com/> sound good to me. >> >> > On Sep 24, 2015, at 19:35, stratobee > wrote: >> > > >> > >> > Was looking at domains for it. Www.twincommanders.com <http://www.twincommanders.com/> is available, but it kind of suggest turbines are not welcome. Www.aerocommanders.com <http://www.aerocommanders.com/> is available, and so is aerocommanderforum.com <http://aerocommanderforum.com/>, but I'm not sure that was the correct manufacturing name for the models made under Rockwell and Gulfstream. Again, don't want to make anyone feel excluded. >> > >> > Thoughts? >> > >> > -------- >> > Adam >> > >> > >> > >> > >> > Read this topic online here: >> > >> > http://forums.matronics.com/viewtopic.php?p=447422#447422 <http://forums.matronics.com/viewtopic.php?p=447422#447422> >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> >> >> ========== >> br> ander-List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Commander-List <http://www.matronics.com/Navigator?Commander-List> >> ========== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com <http://forums.matronics.com/> >> ========== >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contribution <http://www.matronics.com/contribution> >> ========== >> >> >> >> >> >> -- >> --glenn hancock >> >> You can't win an argument with an ignorant person. They'll just drag you down to their level and beat you with experience. >> >> >> >> >> http://www.matronics.com/Navigator?Commander-List <http://www.matronics.com/Navigator?Commander-List> >> >> http://forums.matronics.com >> >> http://www.matronics.com/contribution <http://www.matronics.com/contribution> >> >> >> >> >> http://www.matronics.com/Navigator?Commander-List <http://www.matronics.com/Navigator?Commander-List> >> http://forums.matronics.com >> http://www.matronics.com/contribution <http://www.matronics.com/contribution> >> >> >> >> > > > <http://www.matronics.com/Navigator?Commander-List> <http://www.matronics.com/contribution> > ________________________________________________________________________________
Date: Sep 27, 2015
Glad to hear Jim is going to be OK . How did the accident happen ? Gil Sent from my iPhone > On Sep 27, 2015, at 10:24 AM, Tylor Hall wrote: > > Glen and Nico > Jim is doing better and is going into surgery today some time. This is to put his hip back together. > He was able to wiggle his toes and that is suppose to be good. > > The meeting here in Colorado Springs went well and people are now leaving t o go home. > > Call me on my cell and I can tell you more. > > Tylor Hall > tylorhall(at)mac.com > ACN IBO Member > 401 Monte Alto PL NE > Albuquerque, NM 87123 > 505-247-3001 > 505-400-8373 Cell > tylorhall.acndirect.com > > > > > >> On Sep 27, 2015, at 6:57 AM, Glenn Hancock wrote: >> >> Nico, >> >> I also agree with Adam in that I absolutely hate Facebook. The problem i s that it's simply a gossip center where people go to talk and post pictures and videos. It's not subject specific and trying to follow conversations o r search for specific information is impossible. I would like to see a foru m that is specific to our common interests and that we can control better. >> >> As I mentioned, I've already created a forum at twincommandergroup.com an d created a few sections for conversations. There are a few things we all n eed to consider with a forum like this. 1) That more than one person be involved in the domain name so that when one of us passes on, the other s can pickup the forum. One possible solution is that one of you has regist ered twincommanders.com. That could be pointed at my server and both domain s would resolve to the same place for now but could be different later. >> >> 2) That the people involved have some sort of written agreement that if s omething were to happen to the person owning the server, that others can hav e it transferred to another server. >> >> 3) There are a couple options on the latter point, instead of me placing t he forum on my own server I could just rent a server from one of the popular sites and we could place it there. You will get into disk size limits and o ther possible problems in that situation as well as costs involved that I 'm more than happy to foot at the moment. I'm not rich but I do have the mo ney to cover the server and operational costs. I just want somewhere that w e can all gather and discuss what interests us about the Commanders family a nd not have to join an email list that I have a hard time keeping track of c onversations or Facebook where I have to filter through everything. >> >> I'm also very very sorry to hear about Jim. The accident would seem to b e some sort of catastrophic failure based on the accident report so far. I c an't believe an engine failure would cause something like that unless power w as added after the failure. I just purchased a 680F that I haven't begun to fly so am very interested in what happened. I hope he recovers and gets ba ck to flying soon. >> >> Feel free to contact me at 770 490 7899 any time. >> >> Glenn >> >>> On 9/25/15 8:45 PM, Nico hMail wrote: >>> Jim Metzger was critically injured earlier this week when N222JS crashed on landing at Boise ID airport. >>> >>> The Saint Alphonsus Regional Medical Center in Boise said there is no pe rson by that name in the hospital. Weird. >>> >>> I am trying to get hold of Sue to give us an update as we are very conce rned and shocked at this accident. Keep Jim and Sue in your prayers. >>> >>> Read all about it with pictures and video: https://www.facebook.com/COM MANDERFLIGHT >>> >>> Nico >>> >>> >>> >>> From: owner-commander-list-server(at)matronics.com [mailto:owner-commander- list-server(at)matronics.com] On Behalf Of Nico hMail >>> Sent: Friday, September 25, 2015 1:05 PM >>> To: commander-list(at)matronics.com >>> Subject: RE: [matronics.com] Re: Commander-List: Re: How can we get a vi tal Commander forum? >>> >>> The first time I posted this, it didn't get to the list >>> >>> Adam, >>> >>> I still "own" the www.aerocommander.com domain, which is forwarded to ww w.twincommander.org where TCFG's web page is located. I put "own" in quotes b ecause it really is the property of TCFG, which I just put on my ICANN regis ter to manage the domain's DNS entries. >>> >>> I also run/own the www.facebook.com/commanderflight facebook page. It is reasonably active, has more than 1,000 likes and the fans are from all over the globe. The best "reach" any posting had is the helicopter crash after a n aerobatic maneuver, which stands at 89,000 and climbing by the thousands e very day. The average is about 200-300 per posting. The facebook page accomm odates posts from aviation in general but Aero Commanders in particular. Man y of the articles, brochures, and other technical data were uploaded from th e original CD's sent to me years ago by (I cannot recall) and are visible on the facebook page. There are tons of stuff there. The Metzger friends will b e able to explain more about these resources as they have been intimately in volved in shaping what these sites have become, not discounting others' cont ributions over the years. You will notice a distinct presence of turbines an d piston Commanders there. >>> >>> If it can be used, I'll transfer it wherever it can be used productively . The burden of the annual cost of renewal will have to follow the domain, t oo. I kept it up for a generation and it is not really used in its current f orm. >>> >>> If there's anything I can do to help, just let me know. >>> >>> Thanks >>> >>> Nico >>> >>> >>> >>> From: owner-commander-list-server(at)matronics.com [mailto:owner-commander- list-server(at)matronics.com] On Behalf Of Glenn Hancock >>> Sent: Friday, September 25, 2015 7:08 AM >>> To: commander-list(at)matronics.com >>> Subject: [matronics.com] Re: Commander-List: Re: How can we get a vital C ommander forum? >>> >>> So I'm a bit confused: >>> >>> 1) There is already a site at http://www.flightlevelsonline.com/phpBB/ t hat seems dedicated to commanders but no one seems to use it. I posted some thing there before finding this email list that to this day still has not be en responded to. Why? >>> >>> 2) I have created a new forum at twincommandersgroup.com and plan to lea ve it up as long as you guys want to use it but I guess the question is, why does no one use the other one? Is this one going to get ignored as badly a s it and why don't we all just move over there and stop using this email lis t? >>> >>> The forum can be set to send emails when new posts are made and it keeps all of the posts organized so people can go back and search old topics. >>> >>> Is anyone interested in using my forum, the other forum or is everyone s tuck on the email list? >>> >>> Thanks, >>> >>> Glenn >>> >>> On Thu, Sep 24, 2015 at 8:55 PM, Eric Williams wrote: @gmail.com> >>> >>> Aerocommanders.com and twincommanders.com sound good to me. >>> >>> > On Sep 24, 2015, at 19:35, stratobee wrote: >>> > > >>> > >>> > Was looking at domains for it. Www.twincommanders.com is available, bu t it kind of suggest turbines are not welcome. Www.aerocommanders.com is ava ilable, and so is aerocommanderforum.com, but I'm not sure that was the corr ect manufacturing name for the models made under Rockwell and Gulfstream. Ag ain, don't want to make anyone feel excluded. >>> > >>> > Thoughts? >>> > >>> > -------- >>> > Adam >>> > >>> > >>> > >>> > >>> > Read this topic online here: >>> > >>> > http://forums.matronics.com/viewtopic.php?p=447422#447422 >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> >>> >>> ========== >>> br> ander-List" rel="noreferrer" target="_blank">http://www.matronic s.com/Navigator?Commander-List >>> ========== >>> FORUMS - >>> eferrer" target="_blank">http://forums.matronics.com >>> ========== >>> b Site - >>> -Matt Dralle, List Admin. >>> rel="noreferrer" target="_blank">http://www.matronics.com/contributi on >>> ========== >>> >>> >>> >>> >>> >>> -- >>> --glenn hancock >>> >>> You can't win an argument with an ignorant person. They'll just drag yo u down to their level and beat you with experience. >>> >>> >>> >>> >>> http://www.matronics.com/Navigator?Commander-List >>> >>> http://forums.matronics.com >>> >>> http://www.matronics.com/contribution >>> >>> >>> >>> >>> http://www.matronics.com/Navigator?Commander-List >>> http://forums.matronics.com >>> http://www.matronics.com/contribution >>> >>> >>> >>> >> >> >> >> href="http://www.matronics.com/Navigator?Commander-List" class="">htt p://www.matronics.com/Navigator?Commander-List >> class="">http://forums.matronics.com >> class="">http://www.matronics.com/contribution >> > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Sep 27, 2015
Great to hear. Glenn On 09/27/2015 11:24 AM, Tylor Hall wrote: > Glen and Nico > Jim is doing better and is going into surgery today some time. This > is to put his hip back together. > He was able to wiggle his toes and that is suppose to be good. > > The meeting here in Colorado Springs went well and people are now > leaving to go home. > > Call me on my cell and I can tell you more. > > Tylor Hall > tylorhall(at)mac.com > ACN IBO Member > 401 Monte Alto PL NE > Albuquerque, NM 87123 > 505-247-3001 > 505-400-8373 Cell > tylorhall.acndirect.com <http://tylorhall.acndirect.com> > > >> On Sep 27, 2015, at 6:57 AM, Glenn Hancock > > wrote: >> >> Nico, >> >> I also agree with Adam in that I absolutely hate Facebook. The >> problem is that it's simply a gossip center where people go to talk >> and post pictures and videos. It's not subject specific and trying >> to follow conversations or search for specific information is >> impossible. I would like to see a forum that is specific to our >> common interests and that we can control better. >> >> As I mentioned, I've already created a forum at >> twincommandergroup.com <http://twincommandergroup.com> and created a >> few sections for conversations. There are a few things we all need >> to consider with a forum like this. 1) That more than one person be >> involved in the domain name so that when one of us passes on, the >> others can pickup the forum. One possible solution is that one of >> you has registered twincommanders.com <http://twincommanders.com>. >> That could be pointed at my server and both domains would resolve to >> the same place for now but could be different later. >> >> 2) That the people involved have some sort of written agreement that >> if something were to happen to the person owning the server, that >> others can have it transferred to another server. >> >> 3) There are a couple options on the latter point, instead of me >> placing the forum on my own server I could just rent a server from >> one of the popular sites and we could place it there. You will get >> into disk size limits and other possible problems in that situation >> as well as costs involved that I'm more than happy to foot at the >> moment. I'm not rich but I do have the money to cover the server and >> operational costs. I just want somewhere that we can all gather and >> discuss what interests us about the Commanders family and not have to >> join an email list that I have a hard time keeping track of >> conversations or Facebook where I have to filter through everything. >> >> I'm also very very sorry to hear about Jim. The accident would seem >> to be some sort of catastrophic failure based on the accident report >> so far. I can't believe an engine failure would cause something like >> that unless power was added after the failure. I just purchased a >> 680F that I haven't begun to fly so am very interested in what >> happened. I hope he recovers and gets back to flying soon. >> >> Feel free to contact me at 770 490 7899 any time. >> >> Glenn >> >> On 9/25/15 8:45 PM, Nico hMail wrote: >>> >>> Jim Metzger was critically injured earlier this week when N222JS >>> crashed on landing at Boise ID airport. >>> >>> The Saint Alphonsus Regional Medical Center in Boise said there is >>> no person by that name in the hospital. Weird. >>> >>> I am trying to get hold of Sue to give us an update as we are very >>> concerned and shocked at this accident. Keep Jim and Sue in your >>> prayers. >>> >>> Read all about it with pictures and video: >>> https://www.facebook.com/COMMANDERFLIGHT >>> >>> Nico >>> >>> *From:*owner-commander-list-server(at)matronics.com >>> [mailto:owner-commander-list-server(at)matronics.com] *On Behalf Of >>> *Nico hMail >>> *Sent:* Friday, September 25, 2015 1:05 PM >>> *To:* commander-list(at)matronics.com >>> *Subject:* RE: [matronics.com <http://matronics.com>] Re: >>> Commander-List: Re: How can we get a vital Commander forum? >>> >>> The first time I posted this, it didn't get to the list >>> >>> Adam, >>> >>> I still "own" the www.aerocommander.com >>> <http://www.aerocommander.com/> domain, which is forwarded to >>> www.twincommander.org <http://www.twincommander.org/> where TCFG's >>> web page is located. I put "own" in quotes because it really is the >>> property of TCFG, which I just put on my ICANN register to manage >>> the domain's DNS entries. >>> >>> I also run/own the www.facebook.com/commanderflight >>> <http://www.facebook.com/commanderflight> facebook page. It is >>> reasonably active, has more than 1,000 likes and the fans are from >>> all over the globe. The best "reach" any posting had is the >>> helicopter crash after an aerobatic maneuver, which stands at 89,000 >>> and climbing by the thousands every day. The average is about >>> 200-300 per posting. The facebook page accommodates posts from >>> aviation in general but Aero Commanders in particular. Many of the >>> articles, brochures, and other technical data were uploaded from the >>> original CD's sent to me years ago by (I cannot recall) and are >>> visible on the facebook page. There are tons of stuff there. The >>> Metzger friends will be able to explain more about these resources >>> as they have been intimately involved in shaping what these sites >>> have become, not discounting others' contributions over the years. >>> You will notice a distinct presence of turbines and piston >>> Commanders there. >>> >>> If it can be used, I'll transfer it wherever it can be used >>> productively. The burden of the annual cost of renewal will have to >>> follow the domain, too. I kept it up for a generation and it is not >>> really used in its current form. >>> >>> If there's anything I can do to help, just let me know. >>> >>> Thanks >>> >>> Nico >>> >>> *From:*owner-commander-list-server(at)matronics.com >>> >>> [mailto:owner-commander-list-server(at)matronics.com] *On Behalf Of >>> *Glenn Hancock >>> *Sent:* Friday, September 25, 2015 7:08 AM >>> *To:* commander-list(at)matronics.com >>> *Subject:* [matronics.com <http://matronics.com>] Re: >>> Commander-List: Re: How can we get a vital Commander forum? >>> >>> So I'm a bit confused: >>> >>> 1) There is already a site at >>> http://www.flightlevelsonline.com/phpBB/ that seems dedicated to >>> commanders but no one seems to use it. I posted something there >>> before finding this email list that to this day still has not been >>> responded to. Why? >>> >>> 2) I have created a new forum at twincommandersgroup.com >>> <http://twincommandersgroup.com/> and plan to leave it up as long as >>> you guys want to use it but I guess the question is, why does no one >>> use the other one? Is this one going to get ignored as badly as it >>> and why don't we all just move over there and stop using this email >>> list? >>> >>> The forum can be set to send emails when new posts are made and it >>> keeps all of the posts organized so people can go back and search >>> old topics. >>> >>> Is anyone interested in using my forum, the other forum or is >>> everyone stuck on the email list? >>> >>> Thanks, >>> >>> Glenn >>> >>> On Thu, Sep 24, 2015 at 8:55 PM, Eric Williams >>> >> > wrote: >>> >>> > >>> >>> Aerocommanders.com <http://Aerocommanders.com> and >>> twincommanders.com <http://twincommanders.com/> sound good to me. >>> >>> >>> > On Sep 24, 2015, at 19:35, stratobee >> > wrote: >>> > >>> > >>> > >>> > Was looking at domains for it. Www.twincommanders.com >>> <http://www.twincommanders.com/> is available, but it kind of >>> suggest turbines are not welcome. Www.aerocommanders.com >>> <http://www.aerocommanders.com/> is available, and so is >>> aerocommanderforum.com <http://aerocommanderforum.com/>, but I'm not >>> sure that was the correct manufacturing name for the models made >>> under Rockwell and Gulfstream. Again, don't want to make anyone feel >>> excluded. >>> > >>> > Thoughts? >>> > >>> > -------- >>> > Adam >>> > >>> > >>> > >>> > >>> > Read this topic online here: >>> > >>> > http://forums.matronics.com/viewtopic.php?p=447422#447422 >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> >>> >>> ========== >>> br> ander-List" rel="noreferrer" >>> target="_blank">http://www.matronics.com/Navigator?Commander-List >>> ========== >>> FORUMS - >>> eferrer" target="_blank">http://forums.matronics.com >>> <http://forums.matronics.com/> >>> ========== >>> b Site - >>> -Matt Dralle, List Admin. >>> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >>> ========== >>> >>> >>> >>> >>> -- >>> >>> --glenn hancock >>> >>> You can't win an argument with an ignorant person. They'll just >>> drag you down to their level and beat you with experience. >>> >>> ** >>> ** >>> ** >>> *http://www.matronics.com/Navigator?Commander-List* >>> ** >>> *http://forums.matronics.com * >>> ** >>> *http://www.matronics.com/contribution* >>> ** >>> ** >>> ** >>> ** >>> ** >>> ** >>> ** >>> ** >>> ** >>> *http://www.matronics.com/Navigator?Commander-List* >>> ** >>> ** >>> *http://forums.matronics.com* >>> ** >>> ** >>> ** >>> ** >>> *http://www.matronics.com/contribution* >>> ** >>> ** >>> ** >> >> *href="http://www.matronics.com/Navigator?Commander-List" >> class="">http://www.matronics.com/Navigator?Commander-List >> class="">http://forums.matronics.com >> class="">http://www.matronics.com/contribution * > > http://www.matronics.com/contribution ________________________________________________________________________________
Date: Sep 27, 2015
I don't disagree with you, guys. I use Facebook for several reasons, such as personal, business, political, religious and aviation. Personal: I have hooked up with family and friends whom I have had no possible chance of ever meeting again. Only that is cause for me to keep Facebook alive. Business: I spent a sizable amount of sweat and tears trying to keep my customer service with my customers on an almost-instant-response basis. We are looking at testing a "secret" site on Facebook, which is what I think we may consider for an Aero Commander forum, which is limited to subscribers only. Political: I believe that the world's liberty-loving people are under assault and I am doing my best to educate people to stand with me against the coming overthrow of democratic institutions and return the Occident to totalitarianism. Religious: besides the fact that I am a practicing Christian (a faulty one to boot) I have been teaching the Christian doctrine for a generation or so and Facebook turned out to be reaching more truth-seekers than with any other forum that I have ever used. Education in good moral values which sustain liberty, peace and prosperity only counts in quality if quantity gets to see it. I mention aviation last, because that is what this email is about. I cannot agree more with the Aero Commander sympathies expressed here. I owned a straight-500 and will always cherish the about 1,000 hours I put on her. However, aviation and nature in general is a fascinating matter to me, which is why I broadened the scope of my Facebook page on Aero Commanders. The helicopter flop and breakup into the ocean after an aerobatic maneuver gone bad, for example, reached almost 90,000 people! For an exchange of ideas, parts, and other AC concerns, I would agree that a generalized forum might be counterproductive, since the majority of the people visiting the facebook.com/commanderflight pages, might not be able to make a productive contribution anyway. We would want to see Morris, the Metzgers, Andy Downs, and Keith Gordon and many others become members of such a portal. That is why I want to suggest, before we spend money on servers, bandwidth and developing sites, let's see if a secret facebook site might serve our purpose, which takes care of the domain ownership, DNS records and costs of ownership. I belong to a secret page on some other forum and only invited members can participate, see the postings, and can be expelled for misbehavior and other counterproductive issues. It just prevents having another userid and password floating around for most folks. If TCFG would concur, I'll donate the www.aerocommander.com domain to whomever whishes to pursue the goal of a portal in which such a forum would be established. Just my take on things. Thanks for the feedback. Nico From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Glenn Hancock Sent: Sunday, September 27, 2015 5:58 AM Subject: [matronics.com] Re: Commander-List: Jim Metzger and N222JS Nico, I also agree with Adam in that I absolutely hate Facebook. The problem is that it's simply a gossip center where people go to talk and post pictures and videos. It's not subject specific and trying to follow conversations or search for specific information is impossible. I would like to see a forum that is specific to our common interests and that we can control better. As I mentioned, I've already created a forum at twincommandergroup.com and created a few sections for conversations. There are a few things we all need to consider with a forum like this. 1) That more than one person be involved in the domain name so that when one of us passes on, the others can pickup the forum. One possible solution is that one of you has registered twincommanders.com. That could be pointed at my server and both domains would resolve to the same place for now but could be different later. 2) That the people involved have some sort of written agreement that if something were to happen to the person owning the server, that others can have it transferred to another server. 3) There are a couple options on the latter point, instead of me placing the forum on my own server I could just rent a server from one of the popular sites and we could place it there. You will get into disk size limits and other possible problems in that situation as well as costs involved that I'm more than happy to foot at the moment. I'm not rich but I do have the money to cover the server and operational costs. I just want somewhere that we can all gather and discuss what interests us about the Commanders family and not have to join an email list that I have a hard time keeping track of conversations or Facebook where I have to filter through everything. I'm also very very sorry to hear about Jim. The accident would seem to be some sort of catastrophic failure based on the accident report so far. I can't believe an engine failure would cause something like that unless power was added after the failure. I just purchased a 680F that I haven't begun to fly so am very interested in what happened. I hope he recovers and gets back to flying soon. Feel free to contact me at 770 490 7899 any time. Glenn On 9/25/15 8:45 PM, Nico hMail wrote: Jim Metzger was critically injured earlier this week when N222JS crashed on landing at Boise ID airport. The Saint Alphonsus Regional Medical Center in Boise said there is no person by that name in the hospital. Weird. I am trying to get hold of Sue to give us an update as we are very concerned and shocked at this accident. Keep Jim and Sue in your prayers. Read all about it with pictures and video: https://www.facebook.com/COMMANDERFLIGHT Nico From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Nico hMail Sent: Friday, September 25, 2015 1:05 PM Subject: RE: [matronics.com] Re: Commander-List: Re: How can we get a vital Commander forum? The first time I posted this, it didn't get to the list Adam, I still "own" the www.aerocommander.com domain, which is forwarded to www.twincommander.org where TCFG's web page is located. I put "own" in quotes because it really is the property of TCFG, which I just put on my ICANN register to manage the domain's DNS entries. I also run/own the www.facebook.com/commanderflight facebook page. It is reasonably active, has more than 1,000 likes and the fans are from all over the globe. The best "reach" any posting had is the helicopter crash after an aerobatic maneuver, which stands at 89,000 and climbing by the thousands every day. The average is about 200-300 per posting. The facebook page accommodates posts from aviation in general but Aero Commanders in particular. Many of the articles, brochures, and other technical data were uploaded from the original CD's sent to me years ago by (I cannot recall) and are visible on the facebook page. There are tons of stuff there. The Metzger friends will be able to explain more about these resources as they have been intimately involved in shaping what these sites have become, not discounting others' contributions over the years. You will notice a distinct presence of turbines and piston Commanders there. If it can be used, I'll transfer it wherever it can be used productively. The burden of the annual cost of renewal will have to follow the domain, too. I kept it up for a generation and it is not really used in its current form. If there's anything I can do to help, just let me know. Thanks Nico From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Glenn Hancock Sent: Friday, September 25, 2015 7:08 AM Subject: [matronics.com] Re: Commander-List: Re: How can we get a vital Commander forum? So I'm a bit confused: 1) There is already a site at http://www.flightlevelsonline.com/phpBB/ that seems dedicated to commanders but no one seems to use it. I posted something there before finding this email list that to this day still has not been responded to. Why? 2) I have created a new forum at twincommandersgroup.com and plan to leave it up as long as you guys want to use it but I guess the question is, why does no one use the other one? Is this one going to get ignored as badly as it and why don't we all just move over there and stop using this email list? The forum can be set to send emails when new posts are made and it keeps all of the posts organized so people can go back and search old topics. Is anyone interested in using my forum, the other forum or is everyone stuck on the email list? Thanks, Glenn On Thu, Sep 24, 2015 at 8:55 PM, Eric Williams wrote: Aerocommanders.com and twincommanders.com sound good to me. > On Sep 24, 2015, at 19:35, stratobee wrote: > > > Was looking at domains for it. Www.twincommanders.com is available, but it kind of suggest turbines are not welcome. Www.aerocommanders.com is available, and so is aerocommanderforum.com, but I'm not sure that was the correct manufacturing name for the models made under Rockwell and Gulfstream. Again, don't want to make anyone feel excluded. > > Thoughts? > > -------- > Adam > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=447422#447422 > > br> ander-List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Commander-List FORUMS - eferrer" target="_blank">http://forums.matronics.com b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution -- --glenn hancock You can't win an argument with an ignorant person. They'll just drag you down to their level and beat you with experience. http://www.matronics.com/Navigator?Commander-List http://forums.matronics.com http://www.matronics.com/contribution http://www.matronics.com/Navigator?Commander-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
Date: Oct 02, 2015
So my 2 cents: First off I'm not that concerned with why people use Facebook nor do I want to argue its merits. I'm only concerned with being able to get in touch with like minded people about my Twin Commander. So to me, the question comes down to whether we want to post things to a blog of sorts or a forum. To understand the difference you'd only have to go to facebook and try to find a conversation that got started 2 months ago that you were participating in or going to a forum and doing the same. The forums are threaded for a reason and they keep track of an entire conversation in one easy to follow link. A blog is nothing more than a bunch of people posting comments about this that or the other and there is no easy way to search through history or to find a specific topic you might be interested in, and post a comment. I'm also not interested in how many followers anyone has on Facebook as those people don't fly and probably never have flown a Twin Commander. I'm only interested in the couple hundred people that are flying the planes today that can help me and that I might be able to help. I'm not saying having a Facebook page with lots of people watching videos isn't a good thing, it's just not what I'm interested in personally. This email list doesn't work and is too hard to keep track of conversations. It's also possible someone hits reply to a person instead of the group and the entire conversation goes offline for a bit then pops back in later with half the conversation missing. so there we are: :-) Glenn On 9/27/15 9:30 PM, Nico hMail wrote: > > I don't disagree with you, guys. > > > > I use Facebook for several reasons, such as personal, business, > political, religious and aviation. > > > > Personal: I have hooked up with family and friends whom I have had no > possible chance of ever meeting again. Only that is cause for me to > keep Facebook alive. > > > > Business: I spent a sizable amount of sweat and tears trying to keep > my customer service with my customers on an almost-instant-response > basis. We are looking at testing a "secret" site on Facebook, which is > what I think we may consider for an Aero Commander forum, which is > limited to subscribers only. > > > > Political: I believe that the world's liberty-loving people are under > assault and I am doing my best to educate people to stand with me > against the coming overthrow of democratic institutions and return the > Occident to totalitarianism. > > > > Religious: besides the fact that I am a practicing Christian (a faulty > one to boot) I have been teaching the Christian doctrine for a > generation or so and Facebook turned out to be reaching more > truth-seekers than with any other forum that I have ever used. > Education in good moral values which sustain liberty, peace and > prosperity only counts in quality if quantity gets to see it. > > > > I mention aviation last, because that is what this email is about. I > cannot agree more with the Aero Commander sympathies expressed here. I > owned a straight-500 and will always cherish the about 1,000 hours I > put on her. However, aviation and nature in general is a fascinating > matter to me, which is why I broadened the scope of my Facebook page > on Aero Commanders. The helicopter flop and breakup into the ocean > after an aerobatic maneuver gone bad, for example, reached almost > 90,000 people! > > > > For an exchange of ideas, parts, and other AC concerns, I would agree > that a generalized forum might be counterproductive, since the > majority of the people visiting the facebook.com/commanderflight > pages, might not be able to make a productive contribution anyway. We > would want to see Morris, the Metzgers, Andy Downs, and Keith Gordon > and many others become members of such a portal. > > > > That is why I want to suggest, before we spend money on servers, > bandwidth and developing sites, let's see if a secret facebook site > might serve our purpose, which takes care of the domain ownership, DNS > records and costs of ownership. I belong to a secret page on some > other forum and only invited members can participate, see the > postings, and can be expelled for misbehavior and other > counterproductive issues. It just prevents having another userid and > password floating around for most folks. > > > > If TCFG would concur, I'll donate the www.aerocommander.com domain to > whomever whishes to pursue the goal of a portal in which such a forum > would be established. > > > > Just my take on things. > > > > Thanks for the feedback. > > > > Nico > > > > > > > > *From:*owner-commander-list-server(at)matronics.com > [mailto:owner-commander-list-server(at)matronics.com] *On Behalf Of > *Glenn Hancock > *Sent:* Sunday, September 27, 2015 5:58 AM > *To:* commander-list(at)matronics.com > *Subject:* [matronics.com] Re: Commander-List: Jim Metzger and N222JS > > > > Nico, > > I also agree with Adam in that I absolutely hate Facebook. The > problem is that it's simply a gossip center where people go to talk > and post pictures and videos. It's not subject specific and trying to > follow conversations or search for specific information is > impossible. I would like to see a forum that is specific to our > common interests and that we can control better. > > As I mentioned, I've already created a forum at twincommandergroup.com > and created a few sections for conversations. There are a few things > we all need to consider with a forum like this. 1) That more than one > person be involved in the domain name so that when one of us passes > on, the others can pickup the forum. One possible solution is that > one of you has registered twincommanders.com. That could be pointed > at my server and both domains would resolve to the same place for now > but could be different later. > > 2) That the people involved have some sort of written agreement that > if something were to happen to the person owning the server, that > others can have it transferred to another server. > > 3) There are a couple options on the latter point, instead of me > placing the forum on my own server I could just rent a server from one > of the popular sites and we could place it there. You will get into > disk size limits and other possible problems in that situation as well > as costs involved that I'm more than happy to foot at the moment. I'm > not rich but I do have the money to cover the server and operational > costs. I just want somewhere that we can all gather and discuss what > interests us about the Commanders family and not have to join an email > list that I have a hard time keeping track of conversations or > Facebook where I have to filter through everything. > > I'm also very very sorry to hear about Jim. The accident would seem > to be some sort of catastrophic failure based on the accident report > so far. I can't believe an engine failure would cause something like > that unless power was added after the failure. I just purchased a > 680F that I haven't begun to fly so am very interested in what > happened. I hope he recovers and gets back to flying soon. > > Feel free to contact me at 770 490 7899 any time. > > Glenn > > On 9/25/15 8:45 PM, Nico hMail wrote: > > Jim Metzger was critically injured earlier this week when N222JS > crashed on landing at Boise ID airport. > > > > The Saint Alphonsus Regional Medical Center in Boise said there is > no person by that name in the hospital. Weird. > > > > I am trying to get hold of Sue to give us an update as we are very > concerned and shocked at this accident. Keep Jim and Sue in your > prayers. > > > > Read all about it with pictures and video: > https://www.facebook.com/COMMANDERFLIGHT > > > > Nico > > > > > > > > *From:*owner-commander-list-server(at)matronics.com > > [mailto:owner-commander-list-server(at)matronics.com] *On Behalf Of > *Nico hMail > *Sent:* Friday, September 25, 2015 1:05 PM > *To:* commander-list(at)matronics.com > > *Subject:* RE: [matronics.com] Re: Commander-List: Re: How can we > get a vital Commander forum? > > > > The first time I posted this, it didn't get to the list > > > > Adam, > > > > I still "own" the www.aerocommander.com > <http://www.aerocommander.com> domain, which is forwarded to > www.twincommander.org <http://www.twincommander.org> where TCFG's > web page is located. I put "own" in quotes because it really is > the property of TCFG, which I just put on my ICANN register to > manage the domain's DNS entries. > > > > I also run/own the www.facebook.com/commanderflight > <http://www.facebook.com/commanderflight> facebook page. It is > reasonably active, has more than 1,000 likes and the fans are from > all over the globe. The best "reach" any posting had is the > helicopter crash after an aerobatic maneuver, which stands at > 89,000 and climbing by the thousands every day. The average is > about 200-300 per posting. The facebook page accommodates posts > from aviation in general but Aero Commanders in particular. Many > of the articles, brochures, and other technical data were uploaded > from the original CD's sent to me years ago by (I cannot recall) > and are visible on the facebook page. There are tons of stuff > there. The Metzger friends will be able to explain more about > these resources as they have been intimately involved in shaping > what these sites have become, not discounting others' > contributions over the years. You will notice a distinct presence > of turbines and piston Commanders there. > > > > If it can be used, I'll transfer it wherever it can be used > productively. The burden of the annual cost of renewal will have > to follow the domain, too. I kept it up for a generation and it is > not really used in its current form. > > > > If there's anything I can do to help, just let me know. > > > > Thanks > > > > Nico > > > > > > > > *From:*owner-commander-list-server(at)matronics.com > > [mailto:owner-commander-list-server(at)matronics.com] *On Behalf Of > *Glenn Hancock > *Sent:* Friday, September 25, 2015 7:08 AM > *To:* commander-list(at)matronics.com > > *Subject:* [matronics.com] Re: Commander-List: Re: How can we get > a vital Commander forum? > > > > So I'm a bit confused: > > 1) There is already a site at > http://www.flightlevelsonline.com/phpBB/ that seems dedicated to > commanders but no one seems to use it. I posted something there > before finding this email list that to this day still has not been > responded to. Why? > > 2) I have created a new forum at twincommandersgroup.com > <http://twincommandersgroup.com> and plan to leave it up as long > as you guys want to use it but I guess the question is, why does > no one use the other one? Is this one going to get ignored as > badly as it and why don't we all just move over there and stop > using this email list? > > The forum can be set to send emails when new posts are made and it > keeps all of the posts organized so people can go back and search > old topics. > > Is anyone interested in using my forum, the other forum or is > everyone stuck on the email list? > > Thanks, > > Glenn > > > > On Thu, Sep 24, 2015 at 8:55 PM, Eric Williams > > wrote: > > > > > Aerocommanders.com and twincommanders.com > <http://twincommanders.com> sound good to me. > > > > On Sep 24, 2015, at 19:35, stratobee > wrote: > > > > > > > > Was looking at domains for it. Www.twincommanders.com > <http://Www.twincommanders.com> is available, but it kind of > suggest turbines are not welcome. Www.aerocommanders.com > <http://Www.aerocommanders.com> is available, and so is > aerocommanderforum.com <http://aerocommanderforum.com>, but I'm > not sure that was the correct manufacturing name for the models > made under Rockwell and Gulfstream. Again, don't want to make > anyone feel excluded. > > > > Thoughts? > > > > -------- > > Adam > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=447422#447422 > > > > > > > > > > > > > > > > > > > > > > > ========== > br> ander-List" rel="noreferrer" > target="_blank">http://www.matronics.com/Navigator?Commander-List > ========== > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > ========== > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" target="_blank">http://www.matronics.com/contribution > ========== > > > -- > > --glenn hancock > > > > You can't win an argument with an ignorant person. They'll just > drag you down to their level and beat you with experience. > > > > * * > > * * > > * * > > *http://www.matronics.com/Navigator?Commander-List* > > * * > > *http://forums.matronics.com* > > * * > > *http://www.matronics.com/contribution* > > * * > > * * > > * * > > * * > > *http://www.matronics.com/Navigator?Commander-List* > > *http://forums.matronics.com* > > *http://www.matronics.com/contribution* > > * * > > * * > > * * > > * * > > > > * *http://www.mat=====================http://forums.matronics.com - List Contribution Web generous > -Matt > http://www.matronics.com/c=> > * * <http://www.matronics.com/contribution> > <http://www.matronics.com/contribution> > http://www.matronics.com/contribution ________________________________________________________________________________
Date: Oct 02, 2015
Subject: Re: Jim Metzger and N222JS
I'm not saying having a Facebook page with lots of people watching video s isn't a good thing, it's just not what I'm interested in personally. This email list doesn't work and is too hard to keep track of conver sations. It's also possible someone hits reply to a person instead of t he group and the entire conversation goes offline for a bit then pops ba ck in later with half the conversation missing. so there we are: :-) And that's where I am, too. Keith S Gordon Life is not simple anywhere. Probably less so elsewhere. KHND RNAV Lead FAASTeam, Las Vegas NBAA Access Committee, Past Chairman Las Vegas Metroplex Co-Lead, NBAA Rep Las Vegas Airspace Users' Council, NBAA Rep Las Vegas Class B Redesign Committee, NBAA Rep -----Original Message----- From: Glenn Hancock <glennh(at)gmail.com> Sent: Fri, Oct 2, 2015 10:38 am Subject: Re: [matronics.com] Re: Commander-List: Jim Metzger and N222JS So my 2 cents: First off I'm not that concerned with why people use Facebook nor do I want to argue its merits. I'm only concerned with being able to get in touch with like minded people about my Twin Commander. So to me, the question comes down to whether we want to post things to a blog of sort s or a forum. To understand the difference you'd only have to go to fac ebook and try to find a conversation that got started 2 months ago that you were participating in or going to a forum and doing the same. The forums are threaded for a reason and they keep track of an entir e conversation in one easy to follow link. A blog is nothing more than a bunch of people posting comments about this that or the other and ther e is no easy way to search through history or to find a specific topic y ou might be interested in, and post a comment. I'm also not interested in how many followers anyone has on Facebook as those people don't fly and probably never have flown a Twin Commande r. I'm only interested in the couple hundred people that are flying the planes today that can help me and that I might be able to help. I'm not saying having a Facebook page with lots of people watching v ideos isn't a good thing, it's just not what I'm interested in personall y. This email list doesn't work and is too hard to keep track of conver sations. It's also possible someone hits reply to a person instead of t he group and the entire conversation goes offline for a bit then pops ba ck in later with half the conversation missing. so there we are: :-) Glenn On 9/27/15 9:30 PM, Nico hMail wrote: I don't disagree with you, guys. I use Facebook for several reasons, such as personal, business, political, religious and aviation. Personal: I have hooked up with family and friends whom I have h ad no possible chance of ever meeting again. Only that is cause for me to keep Facebook alive. Business: I spent a sizable amount of sweat and tears trying to keep my customer service with my customers on an almo st-instant-response basis. We are looking at testing a "secret" site on Facebook, which is what I think we may consider for an A ero Commander forum, which is limited to subscribers only. Political: I believe that the world's liberty-loving people are under assault and I am doing my best to educate people to stand with me against the coming overthrow of democratic in stitutions and return the Occident to totalitarianism. Religious: besides the fact that I am a practicing Christian (a faulty one to boot) I have been teaching the Christian doctrine for a generation or so and Facebook turned out to be reaching more truth-seekers than with any other forum that I have ever used. Education in good moral values which sustain libert y, peace and prosperity only counts in quality if quantity gets to see it. I mention aviation last, because that is what this email is about. I cannot agree more with the Aero Commander sympat hies expressed here. I owned a straight-500 and will always cher ish the about 1,000 hours I put on her. However, aviation and na ture in general is a fascinating matter to me, which is why I br oadened the scope of my Facebook page on Aero Commanders. The he licopter flop and breakup into the ocean after an aerobatic mane uver gone bad, for example, reached almost 90,000 people! For an exchange of ideas, parts, and other AC concerns, I would agree that a generalized forum might be counterproductive, since the majority of the people visiting the facebook.com /commanderflight pages, might not be able to make a productive c ontribution anyway. We would want to see Morris, the Metzgers, A ndy Downs, and Keith Gordon and many others become members of su ch a portal. That is why I want to suggest, before we spend money on servers, bandwidth and developing sites, let's see if a secret facebook site might serve our purpose, which takes care of the domain ownership, DNS records and costs of ownership. I belong to a secret page on some other forum and only invited members ca n participate, see the postings, and can be expelled for misbeha vior and other counterproductive issues. It just prevents having another userid and password floating around for most folks. If TCFG would concur, I'll donate the www.aerocommander.com domain to whomever whishes to pursue the goal of a portal in which such a forum would be established. Just my take on things. Thanks for the feedback. Nico From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On B ehalf Of Glenn Hancock Sent: Sunday, September 27, 2015 5:58 AM To: commander-list(at)matronics.com Subject: [matronics.com] Re: Commander-List: Jim Metzger and N222JS Nico, I also agree with Adam in that I absolutely hate Facebook. The problem is that it's simply a gossip center where people g o to talk and post pictures and videos. It's not subject specific and trying to follow conversations or search for specific informa tion is impossible. I would like to see a forum that is specific to our common interests and that we can control better. As I mentioned, I've already created a forum at twincomm andergroup.com and created a few sections for conversations. Ther e are a few things we all need to consider with a forum like this. 1) That more than one person be involved in the domain name so t hat when one of us passes on, the others can pickup the forum. On e possible solution is that one of you has registered twincommande rs.com. That could be pointed at my server and both domains would resolve to the same place for now but could be different later. 2) That the people involved have some sort of written ag reement that if something were to happen to the person owning the server, that others can have it transferred to another server. 3) There are a couple options on the latter point, instead of me placing the forum on my own server I could just rent a se rver from one of the popular sites and we could place it there. Y ou will get into disk size limits and other possible problems in t hat situation as well as costs involved that I'm more than happy t o foot at the moment. I'm not rich but I do have the money to cov er the server and operational costs. I just want somewhere that w e can all gather and discuss what interests us about the Commander s family and not have to join an email list that I have a hard tim e keeping track of conversations or Facebook where I have to filte r through everything. I'm also very very sorry to hear about Jim. The accident would seem to be some sort of catastrophic failure based on the accident report so far. I can't believe an engine failure would c ause something like that unless power was added after the failure. I just purchased a 680F that I haven't begun to fly so am very i nterested in what happened. I hope he recovers and gets back to f lying soon. Feel free to contact me at 770 490 7899 any time. Glenn On 9/25/15 8:45 PM, Nico hMail wrote: Jim Metzger was critically injured earlier this week when N222JS crashed on landing at Boise ID airport. The Saint Alphonsus Regional Medical Center in Boise said there is no person by that name in the hospital. Weird. I am trying to get hold of Sue to give us an update as we are very concerned and shocked at this accident. Keep Jim and Sue in your prayers. Read all about it with pictures and video: https://www.facebo ok.com/COMMANDERFLIGHT Nico From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Nico hMail Sent: Friday, September 25, 2015 1:05 PM To: commander-list(at)matronics.com Subject: RE: [matronics.com] Re: Command er-List: Re: How can we get a vital Commander forum? The first time I posted this, it didn't get to the list Adam, I still "own" the www.aerocommander.com domain, which is forward ed to www.twincommander.org where TCFG's web page is located. I put "own" in quotes because it really is the property of TCFG, w hich I just put on my ICANN register to manage the domain's DNS entries. I also run/own the www.facebook.com/commanderflight facebook pag e. It is reasonably active, has more than 1,000 likes and the fa ns are from all over the globe. The best "reach" any posting had is the helicopter crash after an aerobatic maneuver, which stan ds at 89,000 and climbing by the thousands every day. The averag e is about 200-300 per posting. The facebook page accommodates p osts from aviation in general but Aero Commanders in particular. Many of the articles, brochures, and other technical data were uploaded from the original CD's sent to me years ago by (I canno t recall) and are visible on the facebook page. There are tons of stuff there. The Metzger friends will be able to explain more about these resources as they have been intimately in volved in shaping what these sites have become, not discounting others' contributions over the years. You will notice a distinct presence of turbines and piston Commanders there. If it can be used, I'll transfer it wherever it can be used prod uctively. The burden of the annual cost of renewal will have to follow the domain, too. I kept it up for a generation and it is not really used in its current form. If there's anything I can do to help, just let me know. Thanks Nico From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Beh alf Of Glenn Hancock Sent: Friday, September 25, 2015 7:08 AM To: commander-list(at)matronics.com Subject: [matronics.com] Re: Commander-List: Re: How can we get a vital Commander forum? So I'm a bit confused: 1) There is already a site at http://www.flightlevel sonline.com/phpBB/ that seems dedicated to commande rs but no one seems to use it. I posted something t here before finding this email list that to this day still has not been responded to. Why? 2) I have created a new forum at twincommandersgroup.c om and plan to leave it up as long as you guys want to use it but I guess the question is, why does no one use the other one? Is this one going to get ignored as badly as it and why don't we all just move over there and stop using this email list? The forum can be set to send emails when new posts are made and it keeps all of the posts organized so people can go back and search old topics. Is anyone interested in using my forum, the other forum or is everyone stuck on the email list? Thanks, Glenn On Thu, Sep 24, 2015 at 8:55 PM, Eric Williams wrote: --> Commander-List message posted by: Eric Williams Aerocommanders.com and twincommanders.com so und good to me. > On Sep 24, 2015, at 19:35, stratobee wrote: > "stratobee" > > Was looking at domains for it. Www.twincommanders.com is available, but it kind of suggest turbines are not welcome. Www.aerocommanders.com is ava ilable, and so is aerocommanderforum.com, but I'm not su re that was the correct manufacturing name for the model s made under Rockwell and Gulfstream. Again, don't want to make anyone feel excluded. > > Thoughts? > > -------- > Adam > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=447422# 447422 > > > > > > > > > > ========== br> ander-List" rel="noreferrer" t arget="_blank">http://www.matronics.com/Navigator?Commander-List ========== FORUMS - eferrer" target="_blank">http://forums.matronics.com ========== b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matroni cs.com/contribution ========== -- --glenn hancock You can't win an argument with an ignorant person. They 'll just drag you down to their level and beat you with experience. http://www.matronics.com/Navigator?Commander-List http://forums.matronics.com http://www.matronics.com/contribution http://www.matronics.com/Navigator?Commander-List http://forums.matronics.com http://www.matronics.com/contribution http://www.mat==================== =http://forums.matronics.com - List Contribution Web generous =EF =BD -Matt http://www.matronics.com/c
July 07, 2015 - October 02, 2015
Commander-Archive.digest.vol-fl
