Continental-Archive.digest.vol-ae
March 26, 2010 - July 29, 2013
> I pulled these numbers from the TCM website for my engine. So I was sure they
must be flow matched to each intake tube/cylinder.
> 15A 632147-1178 NOZZLE TUNED CYL. # 1 4 I0240B4B 69_321
> 15B 632147-2178 NOZZLE TUNED CYL. # 2 4 I0240B4B 69_321
> 15C 632147-3178 NOZZLE TUNED CYL. # 3 1 I0240B4B 69_321
> 15D 632147-4178 NOZZLE TUNED CYL. # 4 1 I0240B4B 69_321
> Yesterday I removed the four injectors only to find that all four are stamped
10J (one, zero, Juliet). They are all the same! Are the 10J a one size fits all
injector for this engine? Why did my EGTs change after the injectors were cleaned
and returned to service?
> The A&P says it doesnt matter. However, I usually run LOP at altitude. Now, once
I get the hottest cylinder LOPIve got one that really cool and get an occasional
lean burn misfire (a rough spot). BeforeI could lean the engine (at 75%)
all the way from peak to nothing (too lean to run) and my EGTs stayed really
close to each other.
> I sure wish I had never allowed the A&P to remove the injectors in the first
placewasnt the original problem anyway!
> Any insight into this mystery would be appreciated.
> Travis
> Travis Rayner
> Mobile, AL
> Skystar Vixen, N-789DF
> Continental IO-240, Prince P-Tip Prop
> ADI-II Autopilot
> AnyWhereMap Navigation with weather
> www.enotam.net (My Flying Info Website)
> http://forums.matronics.com/viewtopic.php?p=291797#291797
Subject: | Re: Fuel Injector Questions for io-240 |
Barry,
Thanks for the reply. I will try to find the fluid to mentioned. Sounds simple!
Do you have any idea why the TCM website would be showing four different injector
numbers for my engine...none of which are in mine?
Thanks again!
Travis :)
Travis Rayner
Mobile, AL
ADI-II Autopilot
http://forums.matronics.com/viewtopic.php?p=291823#291823
Travis:
I'm not sure but here are a few passable reasons:
design change
change in material
sub-contractor specific part number
change in tracking system
change in fuel pressure due to a change in pumps
different size supply lines
a hidden AD
HP ... Maybe there is a HP increase with larger orifices
different orifice if the cylinders are over bored
These are just guesses. Give them a call.
Barry
On Fri, Mar 26, 2010 at 1:30 PM, FlyboyTR wrote:
> Barry,
> Thanks again!
> Travis :)
> Travis Rayner
> Mobile, AL
> ADI-II Autopilot
Barry,
Excellent points. Thanks. I found the Hoppes #9. I'll give it a try and see
how it does! Thanks again!
Travis :D
Travis Rayner
Mobile, AL
ADI-II Autopilot
http://forums.matronics.com/viewtopic.php?p=291880#291880
Subject: | Low-time Continental A-65 for sale |
Good evening all,
We have a Continental A-65 for sale if any might be interested. We bought it for
our Pietenpol project, but we are now selling it in order to purchase a flying
Piet. Here is the info on the engine:
We purchased it from a couple in Florida last year; they had removed it from their
Cub to install a larger engine. The engine has logs back to day one (6-11-46),
with 1505TT, and 709SMOH (majored in '57). It was removed from the J-3 in
2002. It looks like part of the reason for it's low time is that the Cub it was
attached to was damaged in a storm in '69, and didn't get rebuilt until '93.
Other than that the logs are pretty uneventful. The engine is complete, except
for the carb and magneto harnesses. Apparently they swapped those items out
on to the replacement engine. Here is a pic:
http://dl.dropbox.com/u/2314248/IMG_1200resize.jpg
That's how it sits right now, in the shipping crate and ready to go. The mags are
in the box in the image, they are Bendix mags, and I have no reason to doubt
that they work; they worked fine when the engine was removed from the airplane.
We are asking $3,000 for it, which is exactly the amount we paid for it.
If you might be interested in either please email me and we can discuss further.
Have a good evening!
Ryan
rmueller23(at)gmail.com
http://forums.matronics.com/viewtopic.php?p=292306#292306
Subject: | Re: Low-time Continental A-65 for sale |
Giday, Ryan....small world, eh? My buddies plane in fact is not a Piet, but a Grega
GN-1 Aircamper.
Keep in touch if interested. He's keen to sell.
David Stroud Ottawa, Canada
Christavia C-FDWS
Fairchild 51 replica
under construction C-FYXV
----- Original Message -----
Sent: Monday, March 29, 2010 8:38 PM
Subject: Continental-List: Low-time Continental A-65 for sale
> Good evening all,
for our Pietenpol project, but we are now selling it
> in order to purchase a flying Piet. Here is the info on the engine:
their Cub to install a larger engine. The engine has
> logs back to day one (6-11-46), with 1505TT, and 709SMOH (majored in '57). It
was removed from the J-3 in 2002. It looks like part
> of the reason for it's low time is that the Cub it was attached to was damaged
> '93. Other than that the logs are pretty uneventful. The engine is complete,
except for the carb and magneto harnesses. Apparently
> they swapped those items out on to the replacement engine. Here is a pic:
are in the box in the image, they are Bendix mags,
> and I have no reason to doubt that they work; they worked fine when the engine
was removed from the airplane. We are asking $3,000
> Ryan
Checked by AVG - www.avg.com
OK Travis, since I do not work at TCM anymore, I can give you the true answer.
First, obtain TCM publication FI-02 (Dec 2007). It describes the injector numbering
system and the benefits of Position Tuned Injector Nozzles (especially at
lean of peak fuelings). Second, check with them if a set of nozzles has been
released for the IO240B3B engine. It exists, I am just not sure if it has been
released for production yet. Third, on the IO240B engines, the fuel pump set-up
is very sensitive to dirt and changes in temperature/altitude. You may have
to reset it several times during the year. You also may want to increase you
idle speed slightly.
BMW powered Kolb Mk 3 Classic
Tucson, AZ
http://forums.matronics.com/viewtopic.php?p=299272#299272
Tim,
Thanks for the info. I have been unable to locate the publication you mentioned.
Do you have a link to it? Thanks!
Travis :)
Travis Rayner
Mobile, AL
ADI-II Autopilot
http://forums.matronics.com/viewtopic.php?p=299571#299571
They put a copy of this book with each engine shipped. Go to TCM in Mobile and
ask Loren for one or go to Fairhope airport and ask Ron for one.
Tucson, AZ
http://forums.matronics.com/viewtopic.php?p=299675#299675
Subject: | Re: Continental-List Digest: 0 Msgs - 06/25/10 |
Has any one here used the Aero Carb on an 0200 experimental? Please share your
insight
Brett
On Jun 26, 2010, at 2:55 AM, Continental-List Digest Server
wrote:
Today's complete Continental-List Digest can also be found in either of the
of the Continental-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 10-06-25&Archive=Continental
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 10-06-25&Archive=Continental
Continental-List Digest Archive
Total Messages Posted Fri 06/25/10: 0
Today's Message Index:
Subject: | PLEASE READ - List Fund Raiser Kickoff! |
Dear Listers,
Each November I hold a PBS-like fund raiser to support the continued operation
and upgrade of the List services at Matronics. It's solely through the Contributions
of List members that these Matronics Lists are possible. There is NO
advertising to support the Lists. You might have noticed the conspicuous lack
of flashing banners and annoying pop-ups on the Matronics Email List email messages
and web site pages including:
* Matronics List Forums http://forums.matronics.com
* Matronics List List Wiki http://wiki.matronics.com
* Matronics List Search Engine http://www.matronics.com/search
* Matronics List Browser http://www.matronics.com/listbrowse
You don't find advertising on any of these pages because I believe in a List experience
that is completely about the sport we all enjoy - namely Airplanes and
not about annoying advertisements.
During the month of November I will be sending out List messages every couple of
days reminding everyone that the Fund Raiser is underway. I ask for your patience
and understanding during the Fund Raiser and throughout these regular messages.
The Fund Raiser is only financial support mechanism I have to pay all
of the bills associated with running these Lists. Your personal Contribution
counts!
Once again, this year I've got a terrific line up of free gifts to go along with
the various Contribution levels. Most all of these gifts have been provided
by some of the vary members and vendors that you'll find on Matronics Lists and
have been either donated or provided at substantially discounted rates.
This year, these generous people include:
* Bob Nuckolls of the AeroElectric Connection http://www.aeroelectric.com
* Andy Gold of the Builder's Bookstore http://www.buildersbooks.com
* Jon Croke of HomebuiltHELP http://www.homebuilthelp.com
These are extremely generous guys and I encourage you to visit their respective
web sites. Each one offers a unique and very useful aviation-related product
line. I would like publicly to thank Bob, Andy, and Jon for their generous support
of the Lists again this year!!
You can make your List Contribution using any one of three secure methods including
using a credit card, PayPal, or by personal check. All three methods afford
you the opportunity to select one of this year's free gifts with a qualifying
Contribution amount!!
To make your Contribution, please visit the secure site below:
I would like to thank everyone in advance for their generous financial AND moral
support over the years!
RV-8 Builder and Flyer
Subject: | November List Fund Raiser |
There is an automatic "squelch button" of sorts for the Fund Raiser messages.
Here's how it works... As soon as a List member makes a Contribution through
the Matronics Fund Raiser web site, they will instantly cease to receive these
Fund Raiser messages for the rest of the month! Its just that simple.
I really do appreciate each and every one of your individual Contributions to support
the Lists. It is your support that enables me to upgrade the hardware
and software that are required to run a List Site such as this one. It also goes
to pay for the commercial-grade Internet connection and to pay the huge electric
bill to keep the computer gear running and the air conditioner powered
on. I run all of the Matronics Email List and Forums sites here locally which
allows me to control and monitor every aspect of the system for the utmost in
reliably and performance.
Your personal Contribution matters because, when combined with other Listers such
as yourself, it pays the bills to keep this site up and running. I accept
exactly ZERO advertising dollars for the Matronics Lists sites. I can't stand
the pop-up ads and all other commercials that are so prevalent on the Internet
these days and I particularly don't want to have it on my Email List sites.
If you appreciate the ad-free, grass-roots, down-home feel of the Matronics Email
Lists, please make a Contribution to keep it that way!!
Thank you!
[Note that there are certain circumstances where you might still see a Contribution
related message. For example, if someone replies to one of the messages,
when using the List Browse feature, or when accessing List message via the Forum.
The system keys on the given email address and since most of these are anonymous
public access methods, there is no simple way to filter them.]
Dear Listers,
A quick reminder that November is the annual List Fund Raiser. The Matronics Lists
are 100% member supported and all of the operational costs are provided for
my your Contributions during this time of the year.
Your personal Contribution makes a big difference and keeps all of the Matronics
Email Lists and Forums completely ad-free.
Please make your Contribution today to keep these services up and running!
Thank you in advance!
Matronics Email List and Forum Administrator
Subject: | Please Make A Contribution To Support Your Lists |
Dear Listers,
There is no advertising income to support the Matronics Email Lists and Forums.
The operation is supported 100% by your personal Contributions during the November
Fund Raiser.
Please make your Contribution today to support the continued operation and upgrade
of these services. You can pick up a really nice gift for making your Contribution
too!
You may use a Credit Card or Paypal at the Matronics Contribution Site here:
or, you can send a personal check to the following address:
Matronics / Matt Dralle
581 Jeannie Way
Livermore, CA 94550
Thank you in advance for your generous support!
Subject: | Coming Soon - The List of Contributors - Please Make |
A Contribution Today!
Each year at the end of the List Fund Raiser, I post a message acknowledging everyone
that so generously made a Contribution to support the Lists. Its my way
of publicly thanking everyone that took a minute to show their appreciation
for the Lists.
Please take a moment and assure that your name is on that List of Contributors
(LOC)! As a number of members have pointed out over the years, the List seems
at least as valuable a building / entertainment tool as your typical magazine
subscription!
Assure that your name is on this year's LOC! Show others that you appreciate the
Lists. Making a Contribution to support the Lists is fast and easy using your
Credit card or Paypal on the Secure Web Site:
or by dropping a personal check in the mail to:
Matt Dralle / Matronics
581 Jeannie Way
Livermore CA 94550
I would like to thank everyone that has so generously made a Contribution thus
far in this year's List Fund Raiser! Remember that its YOUR support that keeps
these Lists going and improving! Don't forget to include a little comment about
how the Lists have helped you!
Best regards,
Subject: | Please Support The Lists... |
Dear Listers,
Just a reminder that November is the Matronics Email List Fund Raiser month. There
are some very nice incentive gifts to choose from as well!
Please make your Contribution today at:
581 Jeannie Way
Livermore CA 94550
Thank you!
Subject: | Please Make A Contribution... |
Dear Listers,
Subject: | List Fund Raiser & Some Very Nice Comments... |
Dear Listers,
I've been getting some really nice comments from Listers along with their List
Support Contributions. I've shared some of them below. Please read them over
and see what your fellow Listers think of the Lists and Forums.
Please make a Contribution today to support the continued upgrade and operation
of these services.
There are lots of sweet gifts available, so browse the extensive selection and
pickup a nice item along with your qualifying Contribution.
Contribution Web Site:
Or drop a personal check in the mail to:
581 Jeannie Way
Livermore CA 94550
Thank you in advance for your generous support! It is very much appreciated!
Best regards,
You are providing a great service. Thanks so very much.
David L
Keep up the good work! A great website - wish I'd found it earlier!
Bob S
Thanks for providing a site for information.
Jim S
Thanks again for providing a great service to our community!
Alex M
Thanks and keep up the good work!
Robert B.
Great forum!
David S
Thanks for providing the Kolb List for the last 12 years.
John H
Long time lurker, it's a great resource...many thanks.
Ian C
Your work and effort are greatly appreciated.
Nicolas L
Thank you very much for keeping the list going!
Svein J
Thank you for your support to the community.
Valin T
I am a long time subscriber and a slow builder because of
work and two moves, but still enjoy the process and your
list.
CL M
Thanks for providing this service. It can't be beat!
Thomas W
I'm no longer a builder or flier but I like to keep in touch with
the List - which is the best organised list I've seen on the Internet.
Gerry C
Matt, you are doing a GREAT service to the community of KOLB
Builders and Flyers.
John B
I've been flying for almost two years and still find these Lists as a great
resource for information.....now I get to answer a question once-in-a-while too.
Ralph C
Thanks for this great service.
Dale E
I couldn't keep on building without the support I get from this List.
Thomas S
This is a great service to all of us.
Michael W
I am no longer actively building, but I really like to keep up with what's
going on, and I especially like to follow Bob Nuckolls - and your RV-8.
Terrence W
I really appreciate your work and consider the lists to be a great value.
Christopher R
Thanks Matt for a great resource!
Geoff T
Many thanks for providing this service. I love it.
William V
One of the best Internet Deals going...
Owen B
Thanks for the great site.
Danny S
A valuable resource.
George A
Thanks for running a great list.
Ted P
Subject: | What's My Contribution Used For? |
Dear Listers,
Some have asked, "What's my Contribution used for?" and that's a good question.
Here are just a few examples of what your direct List support enables. It provides
for the very expensive, commercial-grade T1 Internet connection used on
the List insuring maximum performance and minimal contention when accessing List
services. It pays for the regular system hardware and software upgrades enabling
the highest performance possible for services such as the Archive Search
Engine, List Browser, and Forums. It pays for narly 20 years (yeah, I really
said *20* years) worth of online archive data available for instant random search
and access. And, it offsets the many hours spent writing, developing, and
maintaining the custom applications that power this List Service such as the List
Browse, Search Engine, Forums, and Wiki.
But most importantly, your List Contribution enables a forum where you and your
peers can communicate freely in an environment that is free from moderation,
censorship, advertising, commercialism, SPAM, and computer viruses. How many places
on the Internet can you make all those statements these days? It is YOUR
CONTRIBUTION that directly enables these many aspects of these valuable List
services. Please support it today with your List Contribution. Its one of the
best investments you can make in your Sport...
List Contribution Web Site:
581 Jeannie Way
Livermore CA 94550
Thank you for your support!
Email List Administrator
Subject: | Just A Few Days Left; Well Behind Last Year... |
Dear Listers,
There are just a few more days left of this year's List Fund Raiser. Response
has been good so far, but we're well behind last year at this point. If you've
been waiting until the last minute to make your Contribution, now might be good
time to show your support and maybe pick up a nice gift as well!
Please remember that there is no commercial advertising on these Lists and the
*only* means of keeping them running is through your Contributions during this
Fund Raiser. If it weren't for your individual Contributions, these Lists could
easily become economically infeasible and simply cease to exist.
You probably can't even take the family out to dinner for $20 these days, but your
individual Contribution of the same amount makes a huge difference in keeping
the List services alive.
Please make a Contribution today with a Credit Card or Paypal:
Or, drop a personal check in the mail to:
581 Jeannie Way
Livermore CA 94550
Thank you!
Subject: | Make Sure You're Listed! List of Contributors Published |
in December!
Dear Listers,
The List of Contributors (LOC) is just around the corner! In December I post a
list of everyone that so generously made a Contribution to support the Lists.
Its my way of publicly thanking everyone that took a minute to show their appreciation
for the Lists.
Won't you take minute and assure that your name is on the upcoming LOC? Tell others
that you appreciate the Lists. Making a Contribution to support the Lists
is fast and easy using your Visa, MasterCard, or Paypal account:
581 Jeannie Way
Livermore CA 94550
USA
far during this year's List Fund Raiser! Remember that its YOUR support that
keeps these Lists running and improving! Don't forget to include a little comment
about how the Lists have
helped you!
Thank you!
Subject: | Contributions Down By 17%... |
Dear Listers,
As of today, Contributions to the Matronics List Fund Raiser are lagging behind
last year at this time by roughly 17%. I have a Fund Raiser each year simply
to cover my operating costs for the Lists. I *do not* accept any advertising
income to support the Lists and rely solely on the Contributions of members to
keep the expenses paid.
I run all of my own servers and they are housed here locally, and the Internet
connection is a commercial-grade, T1 connection with public address space. I
also maintain a full backup system that does nightly backups of all List-related
data so that in the event of a server crash or worse, all of the Lists and
the many years of List archive data could be restored onto a new server in a matter
of hours.
All of this costs a fair amount of money, not to mention a significant amount of
my personal time. I have a Fund Raiser each year to cover these costs and I
ask that members that feel they receive a benefit from my investments make a
modest Contribution each year to support the continued operation and upgrade of
these services.
If you enjoy the Lists, please make a Contribution today. I also offer some incentive
gifts for larger Contribution levels. At the Contribution Web Wite, you
can use a credit card, Paypal, or personal check to show your support for the
continuation of these services:
581 Jeannie Way
Livermore CA 94550
USA
Subject: | Just A Few More Days To Make Your List Contribution... |
There is less than a week left in this year's List Fund Raiser and only a few short
days to grab one of the great Contribution Gifts available this year. Support
is still significantly lagging behind last year at this point but hopefully
it will pick up here towards the end. Please remember that it is solely the
Contributions of List members that keeps the Lists up and running as there
is no commercialism or advertising on the Matronics Lists and Forums.
The List Contribution web site is secure, fast, and easy and you can use a credit
card, Paypal, or a personal check:
581 Jeannie Way
Livermore CA 94550
USA
I want to thank everyone that has already made a generous contribution to support
the Lists!
Thank you!
Matronics EMail List and Forum Administrator
Subject: | What Are You Thankful For...? |
Dear Listers,
Here in the United States, Thursday is our National day of Thanksgiving. Many
of us will be traveling to be with our families and friends to share in generous
feasts of plenty and giving thanks for the many blessings that have been bestowed
upon us.
Many Listers have expressed over the last couple of weeks how thankful they are
for the Email Lists and Forums here on the Matronics servers and for all of the
assistance and comradery they have experienced being a part of the Lists.
One of my favorite comments is when someone writes to me and says something like,
"Its the first thing I do in the morning while I'm having my morning coffee!".
That's a wonderful tribute to the purpose and function of these Lists.
Its always great to hear I'm not the only one that jumps out of bed each morning
to check my List email!!
Won't you take a minute today and show your appreciation for these Lists and for
their continued operation and upgrade?
The List Contribution Site is:
581 Jeannie Way
Livermore CA 94550
USA
Thank you in advance for your kind consideration,
Subject: | No "Black Friday" For List Fund Raiser... |
Dear Listers,
Curiously, even though the number of List subscriptions are significantly up this
year, support during this year's Fund Raiser is still substantially behind
last year. There are only a couple more days left in November and the end of
the Fund Raiser is quickly approaching.
I have always preferred a non-commercial List experience as many, many members
have also expressed that they do as well. However, if the yearly fund raiser
cannot generate sufficient funds to keep the bills paid, other sources of income
might be required including some sort of advertising. Please don't let that
happen! Your personal Contribution of $20 or $30 goes a long ways to keeping
the operation a float.
Please make sure your name is on this year's List of Contributors published in
December.
The Contribution site is secure, quick, and easy:
581 Jeannie Way
Livermore CA 94550
USA
Thank you in advance for your support!
Subject: | Just Three Days Left & Some Very Nice Comments... |
Dear Listers,
There are just three days left in this year's List Fund Raiser. Won't you take
a monment and make a quick Contribution today to support the continued upgrade
and operation of these Forum services.
I've received some more really nice comments from Listers along with their List
Support Contributions, and I've share a few below.
There are some sweet gifts available this year, so browse the selections and pickup
581 Jeannie Way
Livermore CA 94550
USA
Best regards,
Great resource, keep it coming...
Marten V.
Thanks for maintaining these essential lists!
Rumen D.
Great Service!
Douglas D.
Thanks for this great service!
Peter T.
Thanks for your enduring support of homebuilding communications!
Daniel M.
You do a great job and provide a valuable service.
Mark B.
It's really a great source I have used a lot.
Robert K.
Reading the RV-10 list is part of my morning routine...
Perry C.
Great job running these lists.
Edward T.
Thanks for doing a tough job.
Mic T.
Your List was such a great resource for me when I built in "98".
Ron V.
Its a very useful forum.
Dave F.
Really enjoy your list...
William D.
Great service,
Gerald T.
The list still is a valuable source of information and there
are many worthwhile postings.
Graham H.
The list has seen me through an RV-9A, RV-10, and now an RV-12.
Albert G.
Thanks for a great resource!
Barry H.
Thank you for maintaining this excellent site.
Bill W.
The Matronics Email list are an invaluable service.
William C.
I appreciate the RV-10 list.
Vijay P.
Thanks for a great list and all of the work you do.
Ian W.
Thanks for keeping up this very useful list.
George R.
The list is excellent and I find it very handy for any problems
I come up against during construction.
Greg W.
The lists are an important part of my day. I've met lots of people
and made lots of friends.
Dave S.
It's really a great source I haved used a lot.
Robert K.
I read the Pietenpol List everyday.
PF B.
Subject: | Make Sure You're Listed! |
Dear Listers,
The List of Contributors (LOC) is just around the corner with just two more days
in this year's Fund Raiser! Later in December I will post a list of everyone
that so generously made a Contribution to support the Lists this year. Its
for the Lists.
Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard,
or Paypal account:
Or, by dropping a personal check in the mail to:
581 Jeannie Way
Livermore CA 94550
Thank you!
Subject: | FS Fine Wire Spark Plugs |
I have six Auburn HSR-83P fine wire spark plugs for sale. All are new, never installed
or used. One tube has been opened to inspect the plug and the other five
tubes are still sealed from the factory.
$40 each plus shipping. If you want all six, I will pay shipping anywhere in the
US.
David Maib
RV-10 #40559
http://forums.matronics.com/viewtopic.php?p=321580#321580
Subject: | [Please Read] - Last Official Day of List Fund Raiser! |
Dear Listers,
Its November 30th and that means at least two things. For better or worse, its
my 47th birthday! But it also means that its that last official day of the
Matronics Email List Fund Raiser! If you been drooling over one of the really
nice gifts that are available this year with a qualifying Contribution, then
now is the time to jump on one!!
If you've been meaning to make a Contribution this month but have been putting
it off for some reason, NOW is the time!
I will be posting the List of Contributors in a few days, so you'll probably want
to be known as a person that supported the Lists!
I want to thank everyone that has so generously made a Contribution this year in
support of our Lists. It is your generosity that keeps this operation running
and I don't ever forget it. Hopefully everyone feels the same.
The List Contribution Web Site is fast and easy. Please support our habit by making
your Contribution right now:
581 Jeannie Way
Livermore CA 94550
Thank you to all in advance!
Subject: | 2010 List of Contributors |
Dear Listers,
The 2010 Matronics Email List and Forum Fund Raiser officially ended a couple of
weeks ago and its time that I publish this year's List of Contributors. Its
the people on this list that directly make the Email Lists and Forums possible.
Their generous contributions keep the servers and Internet connection up and
running.
You can still show your support this year and pick up a great gift at the same
time. The Contribution Web Site is fast, easy, and secure:
581 Jeannie Way
Livermore CA 94550
I also want to thank Bob, Jon, and Andy for their generous support through the
supply of great gifts this year!! These guys have some great products and I encourage
you to visit their respective web sites:
Bob Nucklolls - AeroElectric - www.aeroelectric.com
Jon Croke - HomebuiltHELP - www.homebuilthelp.com
Andy Gold - The Builder's Bookstore - www.buildersbooks.com
And finally, I'm proud to present The 2010 Fund Raiser List of Contributors:
http://www.matronics.com/loc/2010.html
Thanks again to everyone that made a Contribution this year!!
Can someone please help me identify this engine?
I have fond a four cyl. Continental (air craft?) engine with the following number
on the rear of block "WA
531457"
Thankss for your time and help!
P.W.
http://forums.matronics.com/viewtopic.php?p=327207#327207
I am about to start a rebuild of an A-65 for an experimental airplane. I
have the manual but need extra help. Is there anybody out there in
Continental land.
Dave
Subject: | Re: A-65 rebuild |
Dave,
I wish. getting ready to rebuild an O200. This seems to be a desert.
Tommy
Maybe we can help each other. Who knows, maybe others will become
interested. Are you going to use your engine in an experimental?
Dave
my replies aren't getting posted to Matronics, so here's what I wrote:
Hi Dave,
I have a very limited background working on engines and such as a young man. On Ebay, you can find a Continental Overhaul Manual for your engine. The last one I saw went for about $20.00. You can also get everything about the engine on one CD for a couple of dollars on EBay. It has the manual, Service Bulletins, ADs, etc. It pretty much has everything you need to know to tear down, inspect and rebuild your engine. We took ours apart and sent the case, crank and cam to Aircraft Specialties Services in Tulsa (www.aircraft-specialties.com) for inspection. I'm supposed to take the cylinders to a place in Newnan, GA next week. The problem I've had so far is how to properly disassemble the engine. I have a friend who has lots of experience rebuilding a/c engines and he gave me a lot of valuable pointers, plus advice on what to have checked and who to send it to. I'm sure when it comes time to put everything back together, my friend is going to save me from a major catastrophe.
We plan to put the engine in a Kitfox Super Sport. I'm also working on getting
it ready to do the first mount of the wings, plus looking for a new hangar since
our home airport closed last summer. I'm building the plane in my garage,
but when we start putting the wings on, I'm going to have to put it in a hangar
somewhere. I live in Anniston, AL.
Here's a link to our website. You can see pictures of the disassembly under the Engine tab. http://www.rickscafe.us . Click on the Southern Aircraft Works link.
Tommy Walker
N8701 - Anniston, AL
http://forums.matronics.com/viewtopic.php?p=332899#332899
Hi Dave,
getting it ready to do the first mount of the wings, plus looking for a new
hangar since our home airport closed last summer. I'm building the plane in
my garage, but when we start putting the wings on, I'm going to have to put
it in a hangar somewhere. I live in Anniston, AL.
Works link.
> Dave
From: | "Randy L. Thwing" <n4546v(at)mindspring.com> |
There is probably plenty of help when you are ready for it, but please
don't ask something like:
"Please send me everything you know about rebuilding small
Continentals".
No one has time to write novels.
If you ask one or two questions at a time, you will probably get plenty
of answers and advice.
Two weeks ago, we had engine start of a very thorough OH of a O-200 we
did for our first issue C-150. Everything good so far.
Go slow, be thorough and methodical and don't do anything that you
wouldn't want to explain to a IA.
I'll ask the first question of Dave & Tommy:
What cylinders do you intend to use? Rebuild yours, of buy new?
Randy, Las vegas
To: continental-list(at)matronics.com
Sent: Sunday, March 06, 2011 7:51 AM
Subject: Re: Continental-List: A-65 rebuild
Dave,
Tommy
03/04/11 19:34:00
Hi Randy,
I think I remember you from the Zenith list. Right?
I now see that my post got posted twice. I sent it via email and when I checked
it hadn't been added so I copied it and pasted. Just deleted the first reply.
Cylinders....
We hope to use our cylinders. It all depends on how the inspection goes. If I
could find a good deal on cylinders like I did on new ones from TCM a few years
ago, I would go for it. But if these check out we will use them. They are
steel cylinders with no oversize. The engine had 240 hrs SMOH when it had a
prop strike. We are waiting to hear about Crank and case....
Tommy Walker
http://forums.matronics.com/viewtopic.php?p=332905#332905
I would also like to use the cyls I have. I bought 3 A-65's with the idea
of building one good engine. I realize some things will have to be rebuilt
or replaced. Have one engine torn down and have some good pieces. It was an
a-75 with the waffle pistons. I have one set of working Bendix SF4 Mags And
a completely rebuilt Stromberg carb. One engine has a couple chrome cyl's
on it.
I have to Mic the inside of the cyl's and see what I have. If over
Standard bore, I can bore out the cyl's out .015. New pistons and rings required.
Parts for that about $500????? I don't have any idea what the bore job
would cost.
Dave
From: | "Jack Phillips" <pietflyr(at)bellsouth.net> |
Where are you?
Jack Phillips
Raleigh, NC
_____
From: owner-continental-list-server(at)matronics.com
[mailto:owner-continental-list-server(at)matronics.com] On Behalf Of
SENTUCHOWS(at)aol.com
Sent: Sunday, March 06, 2011 10:42 AM
Subject: Continental-List: A-65 rebuild
Continental land.
Dave
Hendersonville NC.
Dave
If you are looking for information this: http://www.bowersflybaby.com/tech/
fenton.htm is a good place to spend a few hours. It will answer many of the
questions about small Continentals. After that if you have any specific qu
estions I'll see what I can do.
Deems Herring A&P=2C IA=2C O-200 owner
Hello Tommy:
Yes, I am on most of the ZA lists. We have corresponded before.
The following contains many facts and a lot of my opinions. It is worth
exactly what you are paying for it.
If you have a O-200 that is used in a certified aircraft, with original
Continental cylinders identified by casting numbers, they are subject to
cylinder head cracking.
O-200's specs call for ignition timing of 28 degrees BTDC and a redline of
2800 rpm. Because of the head cracking problem, there is a three decades
old AD that requires the timing to be retarded to 24 degrees BTDC. This
decreases horsepower in an effort to alleviate the cylinder head cracking.
Is this cracking a result of cylinder head design geometery or the fact that
these cylinders were designed to run on 80 octane fuel which is no longer
available? I can't answer that. I do know that the cylinder head cracking
is real and does occur often.
These same cylinders are used on most the small Continental 4 cylinder
engines as well as the C-145/O-300 six cylinder engines. As the O-200 is
the only one that has the 2800 RPM redline, this AD doesn't apply to the
other engines as they don't turn as fast. Does that mean turning at a lower
RPM won't cause head cracking? That has not been my experience.
Two years ago, we overhauled a C-145 six cylinder for our flying club 1958
C-172. The removed cylinders, along with several cylinders offered to us
for sale "for rebuild" in total, eleven had cracked cylinder heads.
These can all be rebuilt, the heads welded etc. but what do you have then?
Regardless of rebuild, they are still subjec to the AD in a O-200.
How long will they last?
Our decision was to buy modern designed ECI cylinders whch are engineered to
run on 100 octane avgas.
In experimental use, you don not have to comply with this AD, but does that
make any difference in reliability?
Continental now produces a newer design cylinder that relieves one from the
AD for the O-200. I have been told, that the ECI cylinders have valve
rotators installed and the Continental cylinders do not. I don't know if
that is true.
Again, this AD does not apply to other engines like the A-65.
The decision then, is how does the cylinder rebuild price, of the older
design, compare with buying new design cylinders?
Our decision was based on two things:
1. To buy a cylinder of a newer design to avoid head cracking, and
eliminate the AD to allow a full 100 HP.
2. To buy a cylinder designed to use 100 octane avgas.
There's some info. I'm sure other experienced people will comment.
Randy L. Thwing, Las Vegas
Sent: Sunday, March 06, 2011 8:50 AM
Subject: Continental-List: Re: A-65 rebuild
> Hi Randy,
> checked it hadn't been added so I copied it and pasted. Just deleted the
> first reply.
> Cylinders....
> If I could find a good deal on cylinders like I did on new ones from TCM a
> few years ago, I would go for it. But if these check out we will use
> them. They are steel cylinders with no oversize. The engine had 240 hrs
> SMOH when it had a prop strike. We are waiting to hear about Crank and
> case....
> Tommy Walker
07:35:00
Randy, thanks for the valuable information.
However, I just got hit with some bad news this morning. The flange on my O200
crank is cracked and not repairable. So, it is back to square one for me.
I hate to throw away my investment in this engine, so I am searching for a replacement.
Anyone have a lead on a crank?
Tommy Walker in Alabama
Tommy Walker
http://forums.matronics.com/viewtopic.php?p=333063#333063
There's lots of valuable info there Deems, thanks for the link. See my post above
if you have any leads.
[quote="dsleepy47"]If you are looking for information this: http://www.bowersflybaby.com/tech/fenton.htm is a good place to spend a few hours. It will answer many of the questions about small Continentals. After that if you have any specific questions I'll see what I can do.
Deems Herring A&P, IA, O-200 owner
> [b]
Tommy Walker
http://forums.matronics.com/viewtopic.php?p=333064#333064
Good Stuff Monty:
Is or was (say post ww2) there any small certified engine crank (horizontal
opposed) that was manufactured with the prop flange welded to the crank?
Randy, Las Vegas
Sent: Monday, March 07, 2011 12:47 PM
Subject: RE: Continental-List: Re: A-65 rebuild
> Hey, Man,
> A cracked flange is a serious defect. I wouldn't mess with it 1/2
> second. Fixing something in a race car shop is a whole bunch different
> than fixing something for an aircraft. 3 or 4 reasons readily come to
> mind. 1. Race car can just pull into the pits. 2. The materials may
> be and probably are different. The 0-200 crankshaft is forged from AISI
> 4340, not the best welding material in the world. Too much carbon in
> the base metal and it's nitrided. 3. Do you have any idea what happens
> with control issues introduced when you sling a prop off ? 4. How much
> is your safety worth ?
> A serviceable tagged crankshaft from a reputable shop would probably
> cost $2100 or so.
> Monty Barrett
> Barrett Precision Engines, Inc.
> Over 40 years in the aircraft engine business.
Tommy=2C did I miss something? are you rebuilding an A-65 or an O-200?
The problem with the original cylinders is the threads where the liner thre
ads into the head. If you didn't know the steel liners are threaded at the
top and they screw into the aluminum heads. the way the threads are made in
the aluminum of the old style cylinders creates a stress concentration poi
nt and the cylinders crack at the end of the threads and it is possible for
the head to separate from the rest of the cylinder. The newer style cylind
ers have a different thread design. This is different from the cracking in
the area of the valves which all small continentals are susceptible too and
which can be repaired but do not expect repaired heads to last as long as
they did before the repair. I would not consider head repairs on cylinders
you do not have a 100% accurate history on. Here are some pictures of the k
ind of cracks that lead to separation: http://www.sacskyranch.com/eng82.htm
and here is another place with good information on the O-200.
Deems
> From: n4546v(at)mindspring.com
> Subject: Re: Continental-List: Re: A-65 rebuild
> Date: Sun=2C 6 Mar 2011 19:53:52 -0800
ing.com>
> Hello Tommy:
> Yes=2C I am on most of the ZA lists. We have corresponded before.
> If you have a O-200 that is used in a certified aircraft=2C with original
> Continental cylinders identified by casting numbers=2C they are subject t
o
All, the crank was tested at a well known service shop in Tulsa. I trust their
findings, so I'm going to search for rebuilt or new crank. I've had prices
of 3100 and 2800 for new, so that's probably where I'm headed unless a good deal
on a used one pops up.
While the engine is going in an experimental, I don't want to trust anything to
chance as far as the engine goes. I just got bit on this used O200 purchase.
Thanks, there's a lot of good information on the posts here. You guys have lots
more information that I hope to access (one question at a time as suggested
by Randy :) ).
Tommy Walker
http://forums.matronics.com/viewtopic.php?p=333152#333152
Deems, I'm the one building the O200. Dave is building an A65. Looking for
a crank.
Tommy
On Mon, Mar 7, 2011 at 8:16 PM, Deems Herring wrote:
> Tommy, did I miss something? are you rebuilding an A-65 or an O-200?
> threads into the head. If you didn't know the steel liners are threaded at
> the top and they screw into the aluminum heads. the way the threads are made
> in the aluminum of the old style cylinders creates a stress concentration
> point and the cylinders crack at the end of the threads and it is possible
> for the head to separate from the rest of the cylinder. The newer style
> cylinders have a different thread design. This is different from the
> cracking in the area of the valves which all small continentals are
> susceptible too and which can be repaired but do not expect repaired heads
> to last as long as they did before the repair. I would not consider head
> repairs on cylinders you do not have a 100% accurate history on. Here are
> some pictures of the kind of cracks that lead to separation:
> http://www.sacskyranch.com/eng82.htm and here is another place with good
> Deems
> > Date: Sun, 6 Mar 2011 19:53:52 -0800
> > Hello Tommy:
Sorry Tommy I guess I got lost with the subject line.
Try here: http://www.barnstormers.com/index.php and do a couple of searches
for Continental or O-200=2C Tom Romanchik should have some ads there. All
I know about him is that I have purchased a few O-200 parts from him and th
ey have been as described and fairly priced=2C not cheap. YMMV
Good hunting.
Deems
Date: Tue=2C 8 Mar 2011 07:52:49 -0600
Deems=2C I'm the one building the O200. Dave is building an A65. Looking
for a crank.
Thanks=2C
Tommy
On Mon=2C Mar 7=2C 2011 at 8:16 PM=2C Deems Herring
Subject: | I want to buy an A65 but.... |
Hello,
I am new in this group, I am building a Pietenpol and I want to buy an A65 for
it; I live at 1100 kms from the actual owneer (I live in Uruguay), so, what do
you think about this engine I am talking to buy?. I found it in Branstorm, I
think I will have no problems, but ...... it is a little bit of money and may
be some one of you can giv me a little hand chosing one.
The engine is this one (), I talk with the seller (by mail) and its seem to be
evrything ok, this is what she said:
>Here are the picture of the A-65.
>The year of the engine is 1943. It has 358 SMOH (hours since major
>overhaul).
>It comes with 3 sets of logbooks. It is ready to bolt on.
>For shipping I would need your address to get a quote.
>Thank you
I do not opretend you decide for me, but it will be comfortable fot me listen a
therth voice.
In anyway, thank you.
Mario Giacummo
http://forums.matronics.com/viewtopic.php?p=333477#333477
http://forums.matronics.com//files/m1_177.jpeg
http://forums.matronics.com//files/m2_204.jpeg
just a follow up re our O200 crank:
Aircraft Specialties Services has my case/crank/cam. They sent the case to Crankcase
Services and it is being checked for defects.
If the case checks ok, then we will probably buy a new crank from Aircraft Specialties.
We will probably buy our rings, bearings, etc from them too.
If not, we are going to consider other options.
Thanks for all the comments. I learned a lot.
Tommy Walker
http://forums.matronics.com/viewtopic.php?p=333542#333542
Subject: | Re: I want to buy an A65 but.... |
Mario, Sounds OK to me. I don't think anyone could advise you as to
purchase the engine or not. I think you are on your own.
Dave
Hey Tommy, Good luck with your project.
Dave
I know, it was nonsense question.
regards
http://forums.matronics.com/viewtopic.php?p=333547#333547
Is there a way to hook up a tachometer to an A-65 without using a
mechanical tach? Maybe a tach generator and an electric tach? Any ideas are welcome.
Dave
Would tiny tach fit the bill? I know several who have those.
New Standard TT2A Tiny-Tach <http://www.tinytach.com/tinytach/gasoline.php>
=99
- Simple to operate - reliable and economical
- RPM adjustable from 1 spark per 2 revolutions to 8 sparks per
revolution
- Faster 1/2 second RPM update time
- 0 to 19,999 RPM display
- Total run time tracking and recording
- Job timer to track and record intervals and then reset to "0"
- Single coax cable to carry signal without EMF interference
http://www.tinytach.com/tinytach/index.php
How are you coming along with the 0-200?
Dave
Hi Dave,
Well our crank was bad and we are buying a new one. Couldn't find a yellow
tagged crank for a good price so we sprang for a new one. There's a big
hole in my checkbook right now.
Our case had a crack and is being prepared by a company in Tulsa. The cam
is being ground and I'm waiting to hear about it. It looks like we will be
able to rebuild the engine with new rings, bearings and gaskets, plus
overhaul the Marvel carburetor. The mags appear to be good. Probably put
in new wire harness.
We are going to SNF next week and hopefully pick up a few deals. Looking
for a prop, instruments, radio, etc.
When it's all over I will have about 9K in this engine which I bought from
Wentworth for 4k. But, we should be in good shape barring any gotchas!
How is your project coming along?
Tommy
_____
Sent: Wednesday, March 23, 2011 5:12 PM
Subject: Continental-List: Hey Tommy
Dave
I have a Marvel carb with a broken flange on the throttle body. I'm trying to
find someone to repair it. Talked with one shop and got a price. I'm trying
to see what else is available. I'm going to try attaching a picture. If you
can help or if you know someone who has the skills to weld this up, please let
me know.
Would also consider buying a used throttle body section if one can be had.
Thanks for any help.
Tommy Walker
http://forums.matronics.com/viewtopic.php?p=336830#336830
http://forums.matronics.com//files/dsc00306_127.jpg
http://forums.matronics.com//files/dsc00309_136.jpg
Subject: | Your E-mail; please phone if you need an immediate response. |
Your e-mail generated this automated response. This auto response does not mean
your e-mail arrived in whole or in part. It does mean that your e-mail or anything
related, if received, is awaiting reading.
We attempt to respond to all e-mails as quickly as possible. Please phone (866)
747-1747, (918) 747-1747 or (918) 629-3685 should you need immediate verification
of a status, have immediate action taken or need any other type of immediate
response.
Hi folks and Randy, :)
How can I tell if my cylinders meet the specs for the new cylinders Randy calls
out in his email from a couple of months ago?.... See below.
Thanks!
Tommy Walker
http://forums.matronics.com/viewtopic.php?p=338943#338943
Go here: http://150cessna.tripod.com/c150o200ainsp.html
Deems
> From: twalker(at)cableone.net
> Date: Wed=2C 4 May 2011 17:54:01 -0700
net>
> Hi folks and Randy=2C :)
calls out in his email from a couple of months ago?.... See below.
> Thanks!
o
f
> 2800 rpm. Because of the head cracking problem=2C there is a three decade
s
hat
> the only one that has the 2800 RPM redline=2C this AD doesn't apply to th
e
er
> Tommy Walker
> N8701 - Anniston=2C AL
Subject: | Re: Marvel MA-3SPA |
Tommy,
I had a fellow in San Antonio rebuild a C-90 for me last fall. Great guy, Dan Martinez.
My carb, an MA-3SPA, was missing a few items inside It had apparently
been put on just for looks to help sell the core. I ended up buying a rebuilt
MA-3SPA. He has a lot of stuff, & could possibly help you. I know you have my
email, so feel free to email me and I'll give you his ph#.
Jimmy Y
building a CH750
flying my Kolb FS
having fun with both.
Jimmy Young
Missouri City, TX
Kolb FS II/HKS 700
http://forums.matronics.com/viewtopic.php?p=339499#339499
Hi Jimmy,
Long time no type! Hope you are doing well and getting that 750 work done.
Thanks for the heads up on the guy in TX with the carb parts.
Can you believe, a man in Georgia emailed me and said he had a throttle body for
that carb that he didn't need. He sent it to me free.... I paid the postage
plus a little to help him for his trouble.
Internet friends are some of the best kind aren't they?
Tommy
Tommy Walker
http://forums.matronics.com/viewtopic.php?p=339501#339501
response.
Subject: | Impulse coupling |
I have an 0-200 going on my homebuilt aircraft. With the electric
starter is an impulse coupling on one magneto necessary?
Subject: | Re: Impulse coupling |
YES - Most definitely!
And if you want to save yourself a from getting stranded when your SINGLE
impulse fails... Install DUAL impulse Mags.
Cost is the same for both mags, non & impulse all you require is:
Impulse Mag Gear - $75
Gasket - $2
Longer Studs - $6
Adapter Ring - $20
Barry
On Thu, Jun 2, 2011 at 5:58 PM, Zimmermans <jezim@pro-ns.net> wrote:
> I have an 0-200 going on my homebuilt aircraft. With the electric starter
Subject: | PLEASE READ - 2011 List Fund Raiser Kickoff - 21 Years |
Strong!!
Dear Listers,
This year marks 21 years of the Email Lists and Forums at Matronics! I've been
running these forums for nearly half my life! I've made some great friends over
the years and had countless email and personal conversations with builders
about aircraft building and flying. What a great community of people! The advice,
support, and friendship has be invaluable over the years.
To support the continued operation and upgrade of the List servers, each November
I hold a PBS-like fund raiser. It is solely through the Contributions of List
members that these Matronics Lists are possible. There is NO advertising
to support the Lists. You might have noticed the conspicuous lack of flashing
banners and annoying pop-ups on the Matronics Email List email messages and web
that is completely about the sport we all enjoy - airplanes!
During the month of November, I will be sending out List messages every couple
of days reminding everyone that the Fund Raiser is underway. I ask for your patience
messages. The Fund Raiser is only financial support mechanism I have to pay all
counts!
Once again, this year we've got another terrific line up of free gifts to go along
with the various Contribution levels. Many of these gifts have been provided
and they have been either donated or provided at substantially discounted rates.
line. I would like publicly to thank Bob, and Andy for their generous support
RV-8 Builder (and Rebuilder) and Flyer
RV-6 Rebuilder and Flyer
RV-4 Builder
Dear Listers,
581 Jeannie Way
Livermore CA 94550
Thank you!
Subject: | Fund Raiser List of Contributors - Please Make A Contribution |
Today!
that so generously made a Contribution to support the Lists. Its sort of
for the Lists.
Won't you take a moment and assure that your name is on that List of Contributors
(LOC)? As a number of members have pointed out over the years, the List seems
at least - if not a whole lot more - valuable as a building/flying/recreating/entertainment
tool as your typical magazine subscription!
Please take minute and assure that your name is on this year's LOC! Show others
that you appreciate the Lists. Making a Contribution to support the Lists is
fast and easy using your Credit card or Paypal on the Secure Web Site:
581 Jeannie Way
Livermore CA 94550
Best regards,
Subject: | Make A List Contribution - It's Your Personal Squelch |
Button...
the Matronics Fund Raiser web site, their email address is automatically added
to this year's Contributor List and they instantly cease to receive further Fund
Raiser messages for the rest of the month! Its just that simple! :-)
reliably and performance. Your personal Contribution matters because, when combined
with other Listers such as yourself, it pays the bills to keep this site
up and running. I accept exactly ZERO advertising dollars for the Matronics
Lists sites. I can't stand the pop-up ads and all other commercials that are
so prevalent on the Internet these days and I particularly don't want to have
Thank you!
Dear Listers,
Just a quick reminder that November is the annual List Fund Raiser. The Matronics
Lists are 100% member supported and all of the operational costs are provided
for my your Contributions during this time of the year.
Your personal Contribution makes a difference and keeps all of the Matronics Email
Dear Listers,
Fund Raiser.
too!
581 Jeannie Way
Livermore, CA 94550
in December!
Dear Listers,
for the Lists.
581 Jeannie Way
Livermore CA 94550
USA
about how the Lists have helped you!
Thank you!
Subject: | What's Your Contribution Used For? |
Dear Listers,
You might have wondered at some pointd, "What's my Contribution used for?" Here
are just a few examples of what your direct List support enables... It provides
for the expensive, commercial-grade Internet connection used on the List.
It pays for the regular system hardware and software upgrades enabling the highest
performance possible for List services such as the Archive Search Engine,
List Browser, and the Web Forums. It pays for over 21 years (yeah, I really
said *21* years) worth of on line archive data available for instant search
and access. And, it offsets the many hours spent writing, developing, and maintaining
It is YOUR CONTRIBUTION that directly enables these aspects of Matronics List services.
best investments you can make in your Sport!
581 Jeannie Way
Livermore, CA 94550
Dear Listers,
are some very nice incentive gifts to choose from as well! Your Contributions
alone keep these services up and running.
581 Jeannie Way
Livermore CA 94550
Thank you!
Subject: | The Value of a Forum... |
If you look forward to checking your List email everyday (and a lot of you have
written to say that you do!), then you're probably getting at least $20 or $30
worth of Entertainment from the Lists each year. You'd pay twice that for a
subscription to some magazine or even a dinner out. Arn't the Lists worth at
least that much to you? Wouldn't it be great if you could pay that same amount
and get a well-managed media source free of advertising, SPAM, and viruses?
Come to think of it, you do...
Won't you take a minute to make your Contribution today and support YOUR Lists?
Please make a Contribution today at:
581 Jeannie Way
Livermore CA 94550
Again, I want to say THANK YOU to everyone that has made a Contribution thus far
during this year's List Fund Raiser!! These Lists are made possible exclusively
through YOUR generosity!!
Email List Admin.
Subject: | Make Sure You're Listed -- List of Contributors Published |
Dec 1!
Dear Listers,
The List of Contributors (LOC) is just around the corner! On December 1st I post
a list of everyone that so generously made a Contribution to support the Lists.
appreciation for the Lists.
As a number of people have pointed out in their Contribution comments, the Lists
are a whole lot more valuable than your typical magazine subscription!
581 Jeannie Way
Livermore CA 94550
Thank you!
Subject: | Contributions Down By 20%... |
Dear Listers,
last year at this time by roughly 20%. I have a Fund Raiser each year simply
data so that in the event of a server crash, all of the Lists and the many
years of List archive data could be restored onto a new server in a matter of
hours.
these services.
gifts for larger Contribution levels. At the Contribution Web Site, you
581 Jeannie Way
Livermore CA 94550
card, Paypal:
581 Jeannie Way
Livermore CA 94550
the Lists!
Thank you!
Subject: | Please Make A Contribution Today... |
Dear Listers,
A quick reminder that November is the annual List Fund Raiser and the List of Contributors
is quickly approching. The Matronics Lists are 100% member supported
and all of the operational costs are provided for by your Contributions during
581 Jeannie Way
Livermore CA 94550
Subject: | Just Two Days Left - Still Way Behind... |
Dear Listers,
There are just two more days left in this years List Fund Raiser. Over the last
few weeks I have received some really nice comments from members on what the
Lists have meant to them. I have included some of them below. Please read over
the comments and ponder on your own feelings about the Lists and the support
and camaraderie you have found here.
We are still way behind last year in terms of the number of contributions. I really
want to keep providing these services to the homebuilt community, but it
take resources. Since there's no advertising budget or deep pockets to keep
the operation a float, its solely your generosity during the Fund Raiser that
keeps things going. Please make a Contribution today.
If you've been putting off showing your support for the Lists, now is the time
to do it!
Make a contribution with a Credit Card or though PayPal at that Matronics Contribution
web site:
Or, drop a check in the mail:
581 Jeannie Way
Livermore, CA 94550
==================== A Few List Member Comments =====================
I get a lot of useful information and satisfaction from belonging to
your groups. Somehow you foster a great sense of community without
the baggage that accompanies other lists.
Dave S.
We do appreciate you running the lists spam and advertising free.
Jeff P.
I am celebrating my first flight day and you and the lists deserve
a thanks since without it my build would have taken twice as long.
Chris L.
I enjoy the list. Have my morning coffee with it!
Buddy M.
Your lists are the best investment of my time and money, bar none,
when it comes to interfacing with my fellow amateur builders.
Owen B.
Keep it going!! Thanks for taking over.
Wallace J.
I enjoy the Pietenpol List a lot.
Malcolm Z.
Thanks for your great site! As a new CJ-6 owner, your web site is an
invaluable resource.
Ken B.
Great informational source.
Fred S.
Thanks for doing this!
Lance G.
Thank you for the service i do enjoy the many hours I use on line with
the banter/ serious technical items.
Noel G.
Thanks for the years of builder support.
Roy H.
Great forum!
Roger C.
Thank you VERY MUCH, Matt, for carrying on with this great service.
The "Europa" community really appreciates it. All the best, Svein - now
celebrating 10 years as a subscriber, I think!
Svein J.
Matt, I'm building a much nicer and safer airplane because of your efforts.
Robert D.
21 years for you 9 years for me on the Zenith lists. Could not imagine
building and flying without Matronics.
Brian U.
Thanks for ALL the hard work and time you put into maintaining these
forums. As an EAA Tech counselor I recommend them often.
Paul M.
This Pietenpol list is a huge part of the motivation that keeps me working
on my project. This has been a great place for meeting like minded folks
and getting help for the difficult parts.
Thomas S.
Thanks for the excellent service Matt.
Frank S.
Matt, I'm a Sonex building, but I have to say that the Piet group is without
a doubt the most interesting.
Ken M.
I can't tell you how much I appreciate the Piet List. This is one of my sanity
lifelines!
Daniel H.
Your site has provided us over the years with excellent connections to others
for advice. Good job!
Bob M.
Kolb List is my #1 source!
Henry V.
Matt, you do a great job with this site. I've been with it since the
beginning!
John M.
I am very grateful for all of your excellent work on the List.
Arthur L.
Thank you for the service you provide us all!
Nicholas C.
Dear Listers,
Its November 30th and that means a couple of things. Its my birthday again, 48
of them, in fact! But it also means that its that last official day of the
Matronics Email List Fund Raiser! If you been jones'n over one of those really
nice incentive gifts now is the time to jump on one!!
Below are a few more of the nice comments from Listers I've received this year.
Please read them over and see if you don't agree.
581 Jeannie Way
Livermore CA 94550
==================== A Few More List Member Comments =====================
I never would have ended up with the great flying airplane I have without
the help of people on the Pietenpol list. Thanks for giving us the medium
to communicate our questions, tips and suggestions.
Matt P.
Thanks for the hard work and maintaining the site commercial free. Good
luck for the future and this site has been a source of great friendship.
Peter B.
It is a great resource.
Jim G.
Thanks so much for your continuing support of the homebuilt community.
Gerald A.
You are doing an outstanding job running the list's. Keep it going.
Bill V.
Thanks for keeping this valuable information source going. Best of all
the forums.
George A.
Another Great year on the RV-List!
Thomas E.
Still the best source of information (& opinion) for builders on a wide
range of issues.
Martin H.
Matt, thanks for hosting and maintaining the lists!
Rumen D.
Bryan R.
Thanks for your continuing interest in Van's RV8 kitplanes.
Peter C.
I'm no longer building or flying but like to keep in touch with the current
generation of builders. Best wishes to a great list system.
Gerry C.
A great list that is most useful for builders.
Graham H.
Thanks for this wonderful tool!
Ralph C.
Thanks for a great service to the experimental aviation community.
Douglas D.
Great topics and loads of useful info keep the subject matter relevant.
George H.
Thanks for keeping this going.
Richard R.
Great facility and well managed.
Victor F.
Thanks for a great service.
John D.
Thank you for you time and efforts they have made Aviation a better
place for everyone.
Jim W.
I still enjoy getting the list in the morning.
Don M.
You provide a great resource.
David M.
You have probably saved a few necks over the years.
Robert F.
Thank you for being there.
Benjamin B.
You perform a great service.
Bruce M.
Thank you for providing this invaluable resource.
William D.
Subject: | Hardware Failure - Matronics Web Servers Currently Offline |
failure and is currently not available. Replacement hardware has been ordered
and should arrive on Tuesday 12/6/2011. All services should be restored
shortly there after.
During the outage, the Matronics Forums, Wiki, and other web-based List services
will NOT be available.
However, during the outage, all normal EMAIL based sevices WILL be available so
you may continue to post messages to the various lists without an issue.
I am so sorry for any inconvenience this web server outage has caused...
Subject: | Matronics Web Services Restored! |
Dear Listers,
web services have been fully restored including the Web Forums, List Browse,
Archive Search, Wiki, and AeroElectric web sites. It was quite an ordeal getting
the replacement boards for the server, but things went back together tonight
and are up and running nicely. The first company I ordered the boards from
originally called me a day later to say that, whoops, they really didn't have
them in stock after all... Fortunately, I was able to locate some through
a different source and had then over-nighted and they arrived today.
Thank you for your patience and consideration though the whole thing!
The List Contribution web site is also back on line for those wishing to make a
donation to the effort:
Best regards,
Matronics List Administrator
Subject: | Pre oiling new rebuild |
I have a fresh rebuilt 0-200 that I want to pressure oil before the
first startup. Where is the best place to hook the pressure line in?
The oil filter, oil pressure sender, oil temp sender or one of the plugs
in the front of the case? Also, how about 30 weight break-in oil this
time of the year in Minnesota? 20 degrees F. Thanks
jezim@pro-ns.net
Subject: | Re: Pre oiling new rebuild |
J:
I use the OIL COOLER threads.
I want to do this but have not had the chance: Remove one of the Oil Plugs
on the front of the engine. Pump the oil in at the Oil Cooler and SEE if
the oil reaches the front of the engine.
As for the type of oil: 20W-50 Multi grade. Are yo breaking in the engine?
If so Philips makes a recommended 20W-50 Non-AD oil.
BUT! Times they are a changing... Some Mfg. now recommend 20W-50 AD oil
for break-in. And that is the way I went. No Problem... 550+ Hrs since
new.
Barry
On Wed, Dec 14, 2011 at 11:50 AM, Zimmermans <jezim@pro-ns.net> wrote:
> I have a fresh rebuilt 0-200 that I want to pressure oil before the first
> startup. Where is the best place to hook the pressure line in? The oil
> filter, oil pressure sender, oil temp sender or one of the plugs in the
> front of the case? Also, how about 30 weight break-in oil this time of the
> year in Minnesota? 20 degrees F. Thanks jezim@pro-ns.net
From: | "Peter W Johnson" <vk3eka(at)bigpond.net.au> |
Hi,
I used the oil pressure sender line. 30 weight sounds good to me but it is a
little warmer in Australia :-)
Cheers
Peter
Wonthaggi Australia
[mailto:owner-continental-list-server(at)matronics.com] On Behalf Of Zimmermans
Sent: Thursday, 15 December 2011 3:50 AM
Subject: Continental-List: Pre oiling new rebuild
That's amazing. I was just about to ask the same question about my A-65.
Dave
-----Original Message-----
Sent: Wed, Dec 14, 2011 11:52 am
I have a fresh rebuilt 0-200 that I want to pressure oil before the first s
tartup. Where is the best place to hook the pressure line in? The oil filt
er, oil pressure sender, oil temp sender or one of the plugs in the front o
f the case? Also, how about 30 weight break-in oil this time of the year in
-= -- Please Support Your Lists This Month --
-= (And Get Some AWESOME FREE Gifts!)
-= November is the Annual List Fund Raiser. Click on
-= the Contribution link below to find out more about
-= this year's Terrific Free Incentive Gifts provided
-= by:
-= * AeroElectric www.aeroelectric.com
-= * The Builder's Bookstore www.buildersbooks.com
-= * HomebuiltHELP www.homebuilthelp.com
-= List Contribution Web Site:
-= --> http://www.matronics.com/contribution
-= Thank you for your generous support!
-= -Matt Dralle, List Admin.
-= - The Continental-List Email Forum -
-= Use the Matronics List Features Navigator to browse
-= the many List utilities such as List Un/Subscription,
-= Archive Search & Download, 7-Day Browse, Chat, FAQ,
-= Photoshare, and much much more:
-= --> http://www.matronics.com/Navigator?Continental-List
-= - MATRONICS WEB FORUMS -
-= Same great content also available via the Web Forums!
-= --> http://forums.matronics.com
-= - List Contribution Web Site -
What did you use as a pressure source? I am starting a C85 in January.
Lyle
Date: Wed=2C 14 Dec 2011 12:15:08 -0500
Subject: Re: Continental-List: Pre oiling new rebuild
J:
BUT! Times they are a changing... Some Mfg. now recommend 20W-50 AD oil fo
r break-in. And that is the way I went. No Problem... 550+ Hrs since ne
w.
Barry
er=2C oil pressure sender=2C oil temp sender or one of the plugs in the fro
nt of the case? Also=2C how about 30 weight break-in oil this time of the y
Hi,
I used an old gas cylinder (5 pounds ish!) with a schrader valve
incorporated in the top of the cylinder and a hose connecting to the oil
pressure outlet on the engine. I used a small compressor to pressurise the
cylinder pumping oil into all engine cavities.
All worked well.
Cheers
Peter
[mailto:owner-continental-list-server(at)matronics.com] On Behalf Of Lyle Fast
Sent: Thursday, 15 December 2011 10:43 AM
Subject: RE: Continental-List: Pre oiling new rebuild
Lyle
_____
Date: Wed, 14 Dec 2011 12:15:08 -0500
J:
BUT! Times they are a changing... Some Mfg. now recommend 20W-50 AD oil for
break-in. And that is the way I went. No Problem... 550+ Hrs since new.
Barry
_blank>www.aeroelectric.com
/" target=_blank>www.buildersbooks.com
=_blank>www.homebuilthelp.com
=_blank>http://www.matronics.com/contribution
List" target=_blank>http://www.matronics.com/Navigator?Continental-List
Peter:
Did you remove the remove the front oil plug to see if the oil made it all
the way up front?
Barry
On Thu, Dec 15, 2011 at 2:14 AM, Peter W Johnson wrote:
> Hi,****
> cylinder pumping oil into all engine cavities.****
> All worked well.****
> Cheers****
> Peter****
> *From:* owner-continental-list-server(at)matronics.com [mailto:
> owner-continental-list-server(at)matronics.com] *On Behalf Of *Lyle Fast
> *Sent:* Thursday, 15 December 2011 10:43 AM
> *To:* continental-list(at)matronics.com
> *Subject:* RE: Continental-List: Pre oiling new rebuild****
> Lyle
> From: flyadive(at)gmail.com
> J: ****
> I use the OIL COOLER threads.****
> Plugs on the front of the engine. Pump the oil in at the Oil Cooler and
> SEE if the oil reaches the front of the engine.****
> engine? If so Philips makes a recommended 20W-50 Non-AD oil.****
> new.****
> Barry****
> On Wed, Dec 14, 2011 at 11:50 AM, Zimmermans <jezim@pro-ns.net> wrote:****
> year in Minnesota? 20 degrees F. Thanks jezim@pro-ns.net ****
> *_blank>www.aeroelectric.com*
> */" target=_blank>www.buildersbooks.com*
> *=_blank>www.homebuilthelp.com*
> *=_blank>http://www.matronics.com/contribution*
> *List" target=_blank>http://www.matronics.com/Navigator?Continental-List*
> *ttp://forums.matronics.com*
> *www.aeroelectric.com*
> *www.buildersbooks.com*
> *www.homebuilthelp.com*
> *http://www.matronics.com/contribution*
> *http://www.matronics.com/Navigator?Continental-List*
> *http://forums.matronics.com*
That sounds about right=2C I'll see if I can find a clean one.
What are people thinking about ground run ups during break in? This engine
has not run since rebuild and won't fly till next summer. I would like to p
rove it runs=2C tune it and do some static runs with the new prop out side
my shop in cool/cold conditions. I can monitor CHT and have been thinking a
bout auxiliary cooling air for these runs. I understand low rpm running is
not good but what about static runs at close to 70% rpm/power?
Lyle
Date: Thu=2C 15 Dec 2011 18:14:20 +1100
Hi=2C
I used an old gas cylinder (5 pounds ish!) with a schrader valve incorporat
ed in the top of the cylinder and a hose connecting to the oil pressure out
let on the engine. I used a small compressor to pressurise the cylinder pu
All worked well.
Cheers
Peter
From: owner-continental-list-server(at)matronics.com [mailto:owner-continental
Sent: Thursday=2C 15 December 2011 10:43 AM
Lyle
J:
w.
Barry
ear in Minnesota? 20 degrees F. Thanks jezim@pro-ns.net _bl
ank>www.aeroelectric.com/" target=_blank>www.buildersbooks.com=_blank>w
ww.homebuilthelp.com=_blank>http://www.matronics.com/contributionList" ta
rget=_blank>http://www.matronics.com/Navigator?Continental-Listttp://foru
ms.matronics.com=_blank>http://www.matronics.com/contribution www.aeroe
lectric.comwww.buildersbooks.comwww.homebuilthelp.comhttp://www.matronics.c
om/contributionhttp://www.matronics.com/Navigator?Continental-Listhttp://fo
rums.matronics.comhttp://www.matronics.com/contribution
Lyle:
Ground Run-Up are NOT recommended.
Engine shops have CLUBS (Small Diameter Props usually made of wood to keep
them light) for ground run-ups.
A standard prop will not reach the required RPM and the engine will not
reach break-in temperatures.
You also will not cool the engine properly.
More damage will be done ground running than flying for 300 hours. <-- Rule
of thumb.
I have installed and broken in about 6 engines - I NEVER ran the engine on
the ground for more time than to adjust idle, mixture and movement of
cables.
GO FLY!
Barry
On Thu, Dec 15, 2011 at 10:47 AM, Lyle Fast wrote:
> That sounds about right, I'll see if I can find a clean one.
> prove it runs, tune it and do some static runs with the new prop out side
> about auxiliary cooling air for these runs. I understand low rpm running is
> Lyle
> From: vk3eka(at)bigpond.net.au
> Date: Thu, 15 Dec 2011 18:14:20 +1100
> Hi,
> All worked well.
> Cheers
> Peter
> Lyle
> J:
> new.
> Barry
Barry=2C
Nice clear answer=2C nothing wishy washy about that!
Thanks=2C Lyle
Date: Thu=2C 15 Dec 2011 11:31:23 -0500
Lyle:
A standard prop will not reach the required RPM and the engine will not rea
of thumb.
the ground for more time than to adjust idle=2C mixture and movement of cab
les.
GO FLY!
Barry
On Thu=2C Dec 15=2C 2011 at 10:47 AM=2C Lyle Fast wr
ote:
Lyle
Hi=2C
All worked well.
Cheers
Peter
Lyle
J:
w.
Barry
_blank">www.aeroelectric.com
.com" target="_blank">www.buildersbooks.com
st" target="_blank">http://www.matronics.com/Navigator?Continental-List
Barry,
No, I just pumped oil into the pressure gauge hole and all worked perfectly
after.
Cheers
Peter
[mailto:owner-continental-list-server(at)matronics.com] On Behalf Of FLYaDIVE
Sent: Friday, 16 December 2011 1:31 AM
Peter:
the way up front?
Barry
wrote:
Hi,
All worked well.
Cheers
Peter
Lyle
_____
J:
Barry
Hey Peter are you VK3EKA?
I'm WB2ZDH
OK, on the pre-oil. As I said, I never tried it but I think it would be a
great way to verify that the oil is getting all around.
Another TRICK. Install an oil temp probe in the 1/8" NPT thread in the
front of the case. You will get REAL temp reading that really mean
something. They will be of the FRONT bearing. I have heard of 25 Deg
F differences between the front and rear of the case.
Barry
On Fri, Dec 16, 2011 at 1:14 AM, Peter W Johnson wrote:
> Barry,****
> perfectly after.****
> Cheers****
> Peter****
> owner-continental-list-server(at)matronics.com] *On Behalf Of *FLYaDIVE
> *Sent:* Friday, 16 December 2011 1:31 AM
> *Subject:* Re: Continental-List: Pre oiling new rebuild****
> Peter:****
> the way up front?****
> Barry****
> wrote:****
> Hi,****
> Cheers****
> Peter****
> Lyle
> J: ****
> new.****
> Barry****
> *_blank>www.aeroelectric.com*****
> */" target=_blank>www.buildersbooks.com*****
> *=_blank>www.homebuilthelp.com*****
> *=_blank>http://www.matronics.com/contribution*****
> *List" target=_blank>http://www.matronics.com/Navigator?Continental-List*****
> *ttp://forums.matronics.com*****
> *www.aeroelectric.com*****
> *www.buildersbooks.com*****
> *www.homebuilthelp.com*****
> *http://www.matronics.com/contribution*****
> *http://www.matronics.com/Navigator?Continental-List*****
> *http://forums.matronics.com*****
> *_blank">www.aeroelectric.com*
> *.com" target="_blank">www.buildersbooks.com*
> *="_blank">www.homebuilthelp.com*
> *_blank">http://www.matronics.com/contribution*
> *st" target="_blank">http://www.matronics.com/Navigator?Continental-List*
> *tp://forums.matronics.com*
Subject: | 2011 List of Contributors |
Dear Listers,
The 2011 Matronics Email List and Forum Fund Raiser officially ended a couple of
running!
Matt Dralle / Matronics
581 Jeannie Way
Livermore CA 94550
Bob Nucklolls - AeroElectric - http://www.aeroelectric.com
Jon Croke - HomebuiltHELP - http://www.homebuilthelp.com
Andy Gold - The Builder's Bookstore - http://www.buildersbooks.com
And finally, I'm proud to present The 2011 Fund Raiser List of Contributors:
http://www.matronics.com/loc/2011.html
Matronics Email List and Forum Administrator
This is what I came up with(see photo) about $20 at the hardware store=2C c
lean=2C will hold a gallon=2C goes 40# plus on hand pump=2C hose attached.
Should be useful for all kinds of engines that don't run often around my pl
ace.
Lyle
Hi=2C
All worked well.
Cheers
Peter
Lyle
J:
w.
Barry
_blank>www.aeroelectric.com/" target=_blank>www.buildersbooks.com=_b
lank>www.homebuilthelp.com=_blank>http://www.matronics.com/contributionLi
st" target=_blank>http://www.matronics.com/Navigator?Continental-Listttp:
//forums.matronics.com=_blank>http://www.matronics.com/contribution www
.aeroelectric.comwww.buildersbooks.comwww.homebuilthelp.comhttp://www.matro
nics.com/contributionhttp://www.matronics.com/Navigator?Continental-Listhtt
p://forums.matronics.comhttp://www.matronics.com/contribution
/9j/4R/5RXhpZgAASUkqAAgAAAAMAA4BAgAgAAAAngAAAA8BAgAFAAAAvgAAABABAgAIAAAAxAAA
ABIBAwABAAAAAQAAABoBBQABAAAAzAAAABsBBQABAAAA1AAAACgBAwABAAAAAgAAADEBAgASAAAA
3AAAADIBAgAUAAAA7gAAABMCAwABAAAAAgAAAGmHBAABAAAAHgEAAKXEBwAcAAAAAgEAAJAQAAAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgAFNPTlkAAERTQy1XMzAASAAAAAEAAABIAAAA
AQAAAEN5YmVyLXNob3QgVmlld2VyADIwMTI6MDE6MTYgMTA6NTE6MjIAUHJpbnRJTQAwMzAwAAAC
AAIAAQAAAAEBAQAAABwAmoIFAAEAAAB0AgAAnYIFAAEAAAB8AgAAIogDAAEAAAACAAAAJ4gDAAEA
AACgAAAAAJAHAAQAAAAwMjIxA5ACABQAAACEAgAABJACABQAAACYAgAAAZEHAAQAAAABAgMAApEF
AAEAAACsAgAABJIKAAEAAAC0AgAABZIFAAEAAAC8AgAAB5IDAAEAAAAFAAAACJIDAAEAAAAAAAAA
CZIDAAEAAAAYAAAACpIFAAEAAADEAgAAfJIHAKYNAADMAgAAAKAHAAQAAAAwMTAwAaADAAEAAAAB
AAAAAqAEAAEAAABYAgAAA6AEAAEAAAAgAwAABaAEAAEAAAByEAAAAaQDAAEAAAAAAAAAAqQDAAEA
AAAAAAAAA6QDAAEAAAAAAAAABqQDAAEAAAAAAAAACKQDAAEAAAAAAAAACaQDAAEAAAAAAAAACqQD
AAEAAAAAAAAAAAAAAAoAAACQAQAAHAAAAAoAAAAyMDEyOjAxOjE2IDIyOjQwOjI1ADIwMTI6MDE6
MTYgMjI6NDA6MjUACAAAAAEAAAAAAAAACgAAADAAAAAQAAAAPwAAAAoAAABTT05ZIERTQyAAAAAi
AAAgBwABAAAAAAAAAAGQBwCUAAAAdgQAAAKQBwDIAAAACgUAAAOQBwDIAAAA0gUAAASQBwCAAAAA
mgYAAAWQBwB6AAAAGgcAAAaQBwD8AAAAlAcAAAeQBwDIAAAAkAgAAAiQBwDIAAAAWAkAAACgBAAB
AAAAAwAAgAGgAQABAAAAIwAAAAKgAQABAAAAEwAAAAChBwCkAAAAIAoAAAGhBwDYAQAAxAoAAACi
BwDEAwAAnAwAAACjBwAAAAAAAAAAAAGjBwAAAAAAAAAAAACkBwAAAAAAAAAAACCwAgAJAAAAYBAA
AECwAwABAAAAAAAAAEGwAwABAAAAAAAAAEKwAwABAAAAAQAAAEOwAwABAAAAAQAAAESwAwABAAAA
AQAAAEWwAwABAAAAAAAAAEawAwABAAAAAAAAAEewAwABAAAAAQAAAEiwCAABAAAAAAAAAEmwAwAB
AAAAAAAAAEqwAwABAAAAAAAAAEuwAwABAAAAAAAAAEywBQABAAAAahAAAE2wAwABAAAAAAAAAE6w
AwABAAAAAAAAAAAAAAABD3AAAAgAVADCAAAAJ/kAACf5AACKEgAAAADsAAAAAAAAAOwA01tk/wAA
AAAAldnsFv/+K9xe01bzAIj/+P/8ANIwW4gEBSIwW4gEBSIwcAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAQAAAAABwAIoF
QgAAADBwCHBLcEtwE3ATADBWQwVrAAAAAAAAAABwZIpCAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAB9UgAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADTAV4IfQAFAAAA
2P4AAAAAAIE6SgAAOQDEOQAAAAAI3Ny9AFMAwgCvALAAlgCHAFMAUgFKAQAIJAEAAQABAAEA8mQ7
90+Tf5O9vb29AADTk+oeldHNR4gfIGhpuDCa/+wAHABTz/V4dDKbQGlmgX4BVgBUAHcAxeIn7zi3
E7cT71MEInR0DwEO8Pbw9uJl71Lw9pRc4DjgOLcTAQC3E/D2CADYG1aCGwfcRmwBVjTNJwDvUjO7
7h/EAAAAAAAAAAAAAAAAAAAAAAAAAL29vb29vb29vb29vb29vb29AAAAAADc3LxfEAgBCOMIywjE
CDMIOAg4CDgIOGoAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAJUAOQB/AE0AlQA5AH8A
TQAAAAjjKAAIyxUACMQ/AAgz0AAI4ygACMsVAAjEPwAIM9D////z////o////0T///9VAAAAAAAA
AEoAAAAACAEAAQAAAAAAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABAAEAAAAAAAEAAQABAAAA
QABAAEAAANNhw0VI7k5GOHXER7t9CF4AQAEAAABA//8A/wAAAADEAAAAOdMAAHr/AADNqkcAAAAA
AAAAAAAAAAAAAAAAAAABAAAAAADX8gAA5y0AAARRAADnFwAA58wAAAWaAACICAAAknkAAIE/AAAM
cAAAkr8AAGnOAAAF/wAABUgAAFwLAAAvuQAAxWgAACSXAACgLAAAMJgAAGm8AAACxQAAGu8AAOIv
AAArrgAAlWsAAC+iAAAwFgAAAjQAAF3JAAC7AwAA1w0AAGpLAAC38AAAKIUAAOLNAACIOQAAzacA
AIoiAAAM8QAA8HQAACiPAAAFRAAAVtIAAFbPAADNKwAAIDgAAIFrAACI7A7qcHBw6g7qcIGVgXDq
cIEkOCSBcHCVOEo4lXBwgSQ4JIFw6nCBlYFw6g7qcHBw6g4AAAAIAIi9uwIoELuxiFkAAACjknNs
ApVlbFKScQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAM02IO+BRSAu
BVEAAACjtvjXJ5Is13ppBgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AIhjiAmIEoiNiC4AAACjikJwBHATcD1wZAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAABsAAAAA1PU0AHQIDgC6q6YAMZMmAAAihQCBxBkAiPAAAOrQ3ADXqAAAAGVCAIHE
GQCI8AAA6tDcANeoAAAAZUIIAAABDjBwYLvC2AEBYH8k43mWJI4kuuJ14uNg9gLPAjh5E+8T4mLi
wnlU4jLwYfBX8FfvE/D2725Mw0zDTBDiU+KT4E8kU+JSGnQaf+/uJGGO3O/Q8E9MwkzcJGJ5YTPC
75Ma3EzCTE6HZYdUxCMAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAyiGsKe63gxoZmyYMcAA7On9K
Yx8sxYcDBsLsGBE0sRoEdeow3eC1BBxVoRgnhZoxbasmFMGPOhbQmqcF0FjYFN+QrzdDGaEBhSxa
BSN0rBY1tm4UH4i6F4y1kw2CjF8CAX5tFdGybjg25mErVFmhdzYXJ3E5OgZ3u/tdevIRoUf4RCVF
UtuOS3T8lWjZMakWkhGcM3OZeAN+1mc8Pd/HB7egmRXKQKwp2ieINjsgjth7ADN6f2ffyyikhwMG
4HoMFTSxGinJPjDKytNEGKoTGC8H+nFtfEUU3aVUFtRlFQXY2rhU3kfMNksRrQ2GLHIFcH+sHnW2
bhQfgxofzLWZDYKNzzBBLgkV0bluMPzobitUXaEVVHVGEWZuWCGmpwYgqkz1LdgaeR3Kjd0aOrfd
LJt6lxRVsbwzCY94D37WZzMt9/AE96uZFWsSNxwNMcsFhmTsOOWblAXf4YcOGVslMbO6TywETIMr
G8aTMiGPGxQudTI8/JUsHNy+1hys6yQsIPK2A1ZmpTYxSu8sNkldDeTYywiX3mUL/TZ0CZMn5CL8
zE0jCuncKq2Q3APX1SYxZ+LzFvgJwBD1RCg0+kkmHyyJfApLk8Qdayl5Bg/lkAIHAtcbY/LtAvDA
XSzWoaoEITVSEXsVZDcLaRo6HhBECHCcegjPhvId6XCSFhcgEQOcF8Y3AG6bK40mASnEZQshLs7I
HBFLUzqJW9o6M3xlKYsiHQsgUA0y4tHsNfd+WzbeY1glfPiZCemZxwTdHKUn4xYxGqC3LwNW8JsV
EG7uK0z5sQvNAX86w3qSFQnZpQC6GXo6MdxTAans9h8gPVsjado3Kuy1uwoKlqQjyUCsKe63gxow
DTpMcAA7OnRKa18sxYcDBsLsGBE0sRoiyTZwwMrbBByqExgkB/IxZnxNVN2lVBbfZR1F09qwFN9H
zDZPFa0NjSx6RXF0rBbQKZ4M+hfrJ2kqaD1nEj4ApLH4JTASbjLZdp8HscZQOVR1RjWFxVgpw6cG
IJ76PSWTWnv3Cs3dGjG338SbcZcWlbC8MwmLeA911mXzLPzwDLSomRVrGTcUTTrLCEZk7DjlkJQN
n+qHDNlaJTGzvk8sBEeDKxvMkzphjBsULn4yNLyeLBzcvtYcrOAkJGD5tgNWZ6U2MUrvLDZCXQ3k
2csIl91lC/02dAmTLOQqvMxNIwri3CLtkNwD19UmMWfi8xb4AsAQ9UUoNPpJJh8siXwKS5PEHWsp
eQYP5ZACBwLXG2Py7QLwwF0s1qGqBCE1UhF7FWQ3C2kaOh4QRAhwnHoIz4byHelwkhYXIBEDnBfG
NwBumyuNJgEpxGULIS7OyBwRS1M6iVvaOjN8ZSmLIh0LIFANMuLR7DX3fls23mNYJXz4mQnpmccE
3RylJ+MWMRqgty8DVvCbFRBu7itM+bELzQF/OsN6khUJ2aUAuhl6OjHcUwGp7PYfID1bI2naNyrs
tbsKCpakI8kagzV/xr8fjQpqDfXN1DZwLTMcGnACJ3lMjioRsF4aTzZyHmh8kwPLcUkDub6PKPdd
gysXw9YyI4l5LRPxsioYXKwQwcWEONqMxjh17ecjUCm6IGZ2VS/9vtYLDVQHG9P3QgrBp9sLABeX
GQ9h0SW+oJUA99pQExAETBLizQYPPLJFKLjTeS4Xa6M6fsDLDyfEbzel/10SxtroEsr1jDjLsYQL
H7pFBnwpcBibgAYI/JKSLieLKQ5GtLsLPE45IeccNziw/hIxqdtfBpGkJDmrOaIp9aQFM/qGWBOn
TnwmQ9oUM9UAixrebTEEMm1nDjNqLS0UTTAYS9V1B4UKgCGdi6k17H+eOD2RHxBc3XwjGylEDLz9
TyJNMfcgHNcNK9qoTQAqjrMHzByIH/9NMCO7PLMFCOBrFBPNrgcseGEXPpdhFCsbDAHx858hjP3I
LcQ6viH8i7Yz1/aQB7erxQYbEms0K6qfNQH5RjmL8vIRStYZBgqnMyx9xJUXr60RGgUT+AVSn7wQ
zy0ZJP1LYgOsTnYFvqnqMOmBihm7pNUgcmexHH61UwNgsYQXHwZ0NzFqRxH+xDwb0FfrHowuTyy6
uLohs40sCjE+uxCodzobynYWEkH43BYIRuoJ7t2XG+dspjLru/06jXn+OlN0YW5kYXJkAAAKAAAA
CgAAAAIAAQACAAQAAABSOTgAAgAHAAQAAAAwMTAwAAAAAAcAAwEDAAEAAAAGAAAAEgEDAAEAAAAB
AAAAGgEFAAEAAADqEAAAGwEFAAEAAADyEAAAKAEDAAEAAAACAAAAAQIEAAEAAAD6EAAAAgIEAAEA
AAD3DgAAAAAAAEgAAAABAAAASAAAAAEAAAD/2P/bAIQABgQFBgUEBgYFBgcHBggKEAoKCQkKFA4P
DBAXFBgYFxQWFhodJR8aGyMcFhYgLCAjJicpKikZHy0wLSgwJSgpKAEHBwcKCAoTCgoTKBoWGigo
KCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgo/8AAEQgAeACg
AwEhAAIRAQMRAf/EAaIAAAEFAQEBAQEBAAAAAAAAAAABAgMEBQYHCAkKCxAAAgEDAwIEAwUFBAQA
AAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3
ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWm
p6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6AQADAQEB
AQEBAQEBAAAAAAAAAQIDBAUGBwgJCgsRAAIBAgQEAwQHBQQEAAECdwABAgMRBAUhMQYSQVEHYXET
IjKBCBRCkaGxwQkjM1LwFWJy0QoWJDThJfEXGBkaJicoKSo1Njc4OTpDREVGR0hJSlNUVVZXWFla
Y2RlZmdoaWpzdHV2d3h5eoKDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXG
x8jJytLT1NXW19jZ2uLj5OXm5+jp6vLz9PX29/j5+v/aAAwDAQACEQMRAD8A+VKKACigD1D4XM40
O4AwUNy2VIyD8q12g06wuIyk9jEFJyfK+Tn14rJ1NeWSui4tx1izzrxXYJba5e2+nxSyhVjZEI3M
MjnpWGtrqW04sLknpu8pvxreLVkkTJuTuyUDU4mJa0uUB6fK4q7pM+oTagtspkWcgsgmZsfiDTlJ
WaZVNSTUkdF/ZviMYJlswf4cZ5p66f4sbo1lj/PtXn81E9flxHRoX+zfFvrZn/P0qKW08WxncTae
mRiq5qJPJifIpzL4p5DLbn6bawPFSayumxnVI0WDzQAVI+9g+ntmrg6V/dMKyr8j5tjlKK6Dzgoo
AKKACigD1P4VrnQbg/8AT03/AKAld3HIq9TXLP4mUcrDMi/EuViRtMK9/wDYruI7iJm+Rxu9jVye
3oIuLcyhdpYOvcMM5rgvFGxfiHo87QhIXjSNtgwD+8IP6EVtCXPpLUE3D4Wd7DYWRVVWU7VOVVxj
H41cWwt4495ICjqSRjFc88JpzQ1X4nqUcwUvdno/wHRWCXkIkskadB1aIBh+hrI1iCGx2/az5W/7
ocoM46/xe4rF0XvZ/cdnt0tLr7/+AYsjWXJVye/BTn/x6uM+KBQ+G7Ypv5ulPIH9x/c1VOCUkc+I
nzU5bfeeW0V2njBRQAUUAFFAHqXwsfboFwP+nlv/AEBK6KG2a6uJMttAOK5J/EykYviDSUsdYtr2
QyGCQbS6ttIkAbA9eR/Kq9vp/iO+kuH0yeYxxkZ/ejKh+Uzjvtz+VdlJXimS1dnQ6f4T8VXchL6u
sSYGf35BHr6fzrsLH4am4+wvrWqXM7WgRy8b/eYHdk7s8fjW6j8gskdDONGtN6JBeXTIOZIY87fz
OD+VXNNvVi09rzT2hFuhy0oTa4x1Vl7HkfnTioopqxnXXiS8mXEMhjO7dvU4f6cYGPwrJ8X6RZeJ
vs+oakrPIq4UvkjeeGzg88Kn506U49UZzlJ3OG1LwrOhLQWlrcLj/lioBHH904rhfHWmxWdjE627
wymRVcMpXHynsfpXZUdOdKTRxwc4zSZxNFeSdwUUAFFABRQB6J8OnCaNPlsf6Q3f/ZWtC61S5sbu
TypmCtyOAf51yy+JlIrz6zd3UXlXmyaInO0jv6/Wum8A3Uiwatp+nBYGngExDHIYowz1/wBksfzr
ak2nZDVr6mN4Z8UXGoNqD6lKJWkYIqucqqAYCgdMYr0PwvrU4sprNdv2NFV1VcARqGG7HoNuatN8
7FF6o6I3dxBdvb2wjeBGby5V+UMOqn8QAa0/COk3XiNvEdrAV/eQxSkngGVScD2yP5CuqezH0Obn
0e8gumt5baVZg20oVOc1c1mA6ZpdtYyv/pe9pZUznyy2BtPuAo/PHUGsIprUzZhiYjrXD/GSYyeF
7VST/wAfinn/AHHp82ljNLU8aoqDUKKACigAooA6fwxctDYSKDgGUn9BWs0gmwX5xXNJe82aLY2P
Dfhm61yCWW2aKOKE/O7k/XAA61JH4j0yxuIJo3uI5o1OC8WzzFIKkDGeCCRz6100qS0nJ2IlJrZE
3hjwxY3bXtzY3nnWTkPGEIDJnOVYdRjiuq8OadNpIlupQyrtKsqgyAAnvgc8e1bqlDSSeotb+Q6P
xhoenJNKJJpreMmMo0YOw+i7j7n1PNbvh34v32m6e8Ph7w7BaQudwlu5iWc/3iACf1rNzRo5qxBq
3xh8aSAM0doY16i0G1//AB4HP0FYFv4gg1VTcec+9zlxJ94H0NK6toZSdyylyG+5IrfjmuN+LMhf
w5bA/wDP2p/8cejoQtzyaipNAooAKKACigDa0U4tm/3z/IVprI3asJbmi2Nzwxr17oV0ZLVsxvgS
RE8N/wDX969As9U0PVY1kk02xaQ8ESW6Ej9K3pVGvdBRUjqtAt7NHDWWnWkR9Y4FX+QrA8beJJ72
5m05GaK3gJWTPG4jqPpXTUk4U9Opk7N2PLdBsftt1PdzHdbxzsYk7M2eW/lXWKcrXG9wAmse8t/s
+rWt1CdomkEMw6A7uFJ/HFVDV2EzRJrmfiA7NosKlmK/aFOCf9lqSEtzz6iqLCigAooAKKANrRR/
orf75/kK0lFYy3NFsdP4W0CTVn3sSlspwWxyx9BXpOj+DrUOhQlAO1aUoczuUvdVz0zw/pUNrGAP
m+oqh4y+HmjeKLWRSj2ly5yZoDgsevzDoa9VRjOPLI45XTujxvUvDsvha+n0yWV51jIMcrJs3KVG
MDJ6cj8Kqxng15lVWm0aJ3VxSazdecx6VcSD70YDrn1BBH6iojuBNbv5ltE4GNyBsenFc74+/wCQ
PD/13H/oLVXUS3OBoplhRQAUUAFFAG1o3/Hq3++f5CtO1ja4uooU+9I4Qfiaxe5otj3bw/YRWltD
BGMIigCursdsbACuqluXU2OmsZwqDFbljEZOTwMZrvpnHM4P4uaTHc6G16ijzrQ7s9ypOCP5H8K8
VX7tcWLjad+4QegVh+KZC9rFYxH99dSBAPRc5JrmW5ZpgCNFVeAowK5rx4c6TD/13H/oLU0JbnB0
VRYUUAFFABRQBtaMf9Ff/fP8hW94bIGu2Rbp5orF/Eax6HuNk+0DFbNrNyK66RVU27KfGK6aHUf9
HVRwRXfA4pGJ41lZ/Cer7AGf7LIVB7nacV84W+qwN8k7C3mH3kkOMH61zYyN2rDgJe6xaW6/K/nS
n7scXzFj+FVNOtZnun1DUABcsNscY6RL6fWuK1lqWX3aua8btnS4v+uw/wDQWoQlucRRVFhRQAUU
AFFAGppcmyBhj+L+grY0u4WPULZ+RtlU/rWL3NYnuVpJ8i1rWsnSuqmXURrW86xrudgFAySTWfZe
Ijrd06WEwt9JhcRS3pODK5ONkf4nlvy9a7Yvocckaep6pYXfhvV4NMmWdYIHWRlYsA231714pcRR
SjEsaOP9pc1z4t+8rCgV44YYCTDFGhPUqoFDvXHuUQPJXO+MmzpsX/XYfyamgW5x1FUWFFABRQAU
UAaGn/6k/wC9V1DtYEdQc1k9zRbHvGnPvt4mByGUGtm1ropmtQ4X4jf2mdY8uy+1vBLahGji3FSd
xzwOKo2/h/xNcabGuya1srdSx85vLSPHOdv584roipN6HK2ludr4LsWsPhhq+oTMxFzE4iBGMoMg
HHuS34Yrz17tSO4rPEq3L6GaerIWuUP8VRNMp6MPzrlGRM9YXixs6fH/ANdR/I00NHJ0VRYUUAFF
ABRQBoaf/qT/AL3+FW6ze5otj2TwNdi90C1OctGvlt9Rx/LFdfa1tTNZ6oXVr6+0+KOewsDfqDiS
JGCuPQjPX6e9ZcVl4j8aTpDq8B0fQQcyQB8zXA/ukjoPy/GuyN37qOOXc9MmsrVtLWxaCI2gURiE
qNu0dBivL/GHw2ZVkuvDpLDq1o55H+4T1+h5qcTHmYoR9255TcrJBM8U6PHKh2sjjBU+hFV2euAq
xHvI6E1l+IXLWSAkn94P5Gmh2OeoqhhRQAUUAFFAFu0l2RkYzzW7pekahqW029s4jP8Ay0f5V/Pv
+FZzairs1pxc3ZHofgm1bQ5Ht7ibes5B4GFVv/r/AOFeg2x5FPD1OfU6KtPkSRr2p6Vt2favSps4
JoeZ3lvGj27UjAwT1b6e3apVkx0z6ZrObvK5cFoZXiDwNp3jCGQ3QFtdouEuYx84PYMO4+vP0r5u
1LS72w1C4s54JPNgkaJsKcEg4OKwqQ2kK2uhWNld/wDPtN/3wayvEVvPFZI0sMiL5gGWUgZwaySH
ZnO0UxBRQAUUAFFAHrfwd0PTb7SJ767tY57lLpo1LjcAoVDwPXJPavSbqzjbKqnTqAOn+fesJq71
PQo+7FWM640iFoz+eMZOfao44NVhdWt5lZV6xvg/n/8ArqIxlB3ibNxmrSOt015HijMkTo56rtJw
a6K2BUDdx689Pqa9OnPS55s4WdiyGPICYB7Yzn/PvTCm5ju4X1zjH4/0FS3qCRZt2e3ZTGTn9SPp
6fWvJfi94cubXVm1xXkWyvHUMqP9yTb6ehwT+dO3OrCvyu5w63inCpux3OeB7Vh/ECUNpMChiczh
uf8AdapcfdbQnLocBRWJIUUAFFABRQB7b8ETnwreIOpvH9/4E7V6EjKhJDlnUdMHA/oPwzU8p2Ql
7qLSQKTkqcntjr/X+VXoYIQyEJwOvcj+gq4xHKRfTYI+uAex6D+pNWVlwOc57ev5dBWhkySOYMny
lRk8k9Pz71PGkkjAcnJ6kc/gO1NK5L0NFIobRcy/M+c7c/zNcP8AFl2vvC7qTwsyN7Dt/WuhR5Ym
Dd2eKssaAKMcelc/46wdKiIGP34/9BasZP3WOxw1Fc4BRQB//9n/2wCEAAMCAgMCAgMDAwMEAwME
BQgFBQQEBQoHBwYIDAoMDAsKCwsNDhIQDQ4RDgsLEBYQERMUFRUVDA8XGBYUGBIUFRQBAwQEBQQF
CQUFCRQNCw0UFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQU
FP/AABEIAyACWAMBIQACEQEDEQH/xAGiAAABBQEBAQEBAQAAAAAAAAAAAQIDBAUGBwgJCgsQAAIB
AwMCBAMFBQQEAAABfQECAwAEEQUSITFBBhNRYQcicRQygZGhCCNCscEVUtHwJDNicoIJChYXGBka
JSYnKCkqNDU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6g4SFhoeIiYqSk5SV
lpeYmZqio6Slpqeoqaqys7S1tre4ubrCw8TFxsfIycrS09TV1tfY2drh4uPk5ebn6Onq8fLz9PX2
9/j5+gEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoLEQACAQIEBAMEBwUEBAABAncAAQIDEQQF
ITEGEkFRB2FxEyIygQgUQpGhscEJIzNS8BVictEKFiQ04SXxFxgZGiYnKCkqNTY3ODk6Q0RFRkdI
SUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqCg4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqys7S1
tre4ubrCw8TFxsfIycrS09TV1tfY2dri4+Tl5ufo6ery8/T19vf4+fr/2gAMAwEAAhEDEQA/APPo
0PSrCxg9a7VpqQNuNPtryIxXEMdxEeCkihgfqDXJ6x8GPCOubml0mO3c/wAdqxiI+gHy/pV2Ul7w
RqThtscLrX7LFnNufStamgPaK7iDj/vpcY/I1x+ofsz+JbPdskivE6Ztjk/kxBrnnRe8DrpTpVHa
b5fyNbSbO98E2cNre2FzmPgNPuizj2xWzD8ULuwVSlpEkeejMSa+f5J0Z66bn1caanBcr0/yDVPi
VqV/DtFvb7cZ3KDuGfxrhbzTP7Wlae6LO+Tjn1pOo3Lm6m0aCtbcf/ZMUkcccil1j4Tc7cD86lTT
LWCFYVjjSPJJ+UZOeDz1rP2sr6GzoxcOWWxT1S4jsNLuI4Cqwk7yi4wzdBXAyyNDfJKrZbhs16WG
u4ts+dzBRjUUY7WNvVrH+0I47k3TQDZx6VgX9rfabEk32uR4X6EMa9SUFbQ8O+uxr2epXOtaHJDF
Ky3cHIKnBYVV8Oa9Ot01tczMRJxuY8g1nbZlc2pA2tajpWr7J52lEbYw3cVd8RatqFnNFcW9wwtp
0DKPQ9xRqrhfQmuNcvLnQ0vLaTbLEcS8Zo8P+JLzUIJ7d5c3O0tE3v6U9egaEeieMr+bUI7e8kyj
HZ6YNOvPG2r6ZqMlpJJ+6V+gyCV/P0pqUl1FZaGlrHjzVdFeBrSRhbzR7g24gg9+9XJPiRq1no8O
oWU8gZm2zDeev4GrjVqJ6PYXLFktl8Vdam024vo7qb7ZEcsvmHketWdH+Muva1Iyz3bCaNN0fA5x
2PHNWsRW2UtyfZxum0WNN/aA8QX88djO8cSs+N5giZgR05KZ/Wp5v2ivEGn30tnJFZSojbd8llAx
/wDQK0WMrLr+QvZro397/wAy/qfx91TRXgBs7C6SZQ+9rGDH5bOtT3X7QeoQ6fDqL6dpVysrY8s6
dCAp/BapYup1t9yNLT3U2vmy3a/tFXN1ptxd/wBi6KUiGWhGnIKm0b9oYa4zonh7Q4ZFXdhrIjp6
fPT+uTb+GP3IfNWW1WX3lCT9pG1jlKT+F9NYKcfLbuuefUSVqaT8TNF8bFfs+mLpV0uPljkZoz+D
EkH8fwrlxUoVqcouCT7rQ78Hi8RTrRc6jav1NzcGZiRnsKkGUQYHGa+J8j9A8xclZACcJn+ZpGRU
SQ9Qe1AWuyGVh5aDa3PSmSRrJNGCMEDPHFaLcndWC1vIhI+9gB0IrWt7hGCYbIolHqyYu+lzQWRO
EQl22ntwMds1C0UiW0hKZ3cc+9Z+pcWtuw9F2qcjj07UscSqMHjmloBMcM4469s1FIoWMHru61XS
wkiPzF8sqBxnvTPMUMByOKCulybzl5yO+OaQS7uf73WkMZcZ5YDBx2pPJ+0FMtggfjWlkQ3qRrCG
aRmy2Oc1LHCI3iYgBc4PNJpJibNLWFWSdccEIoH5VQ8xfIIIPzehwai2w1sQzSNDHtAJHTrVKZWm
YDac96pLUWqRu6fK10xU/KmzA/AYA/nViRh94HL/AHTn3NaGMdNStMqbSSADUDCNlhTnnn+tZdBv
cFhCzbgu4fXkVQjY+ZMzIV5x+dUPZaCLGqqwOCvY+hqtdW4dNhHHb/P400LyKTRm3kVdu4Dnntnt
RJfKrYRfqcdDWvKmTew0SnynwtIzGSPH3cDGP8/WnZLUXM3a41EZWVlJGM/4UUaDSZ3dt4mDcSRf
ipzWra61ZzY/ebD7jFfQU8ZCatLRn5zKm4mlBJHKo2urD2NWVj65r0E09jn9SURg8k09I85zVLuS
x3lhlKugZTxg8g1h6p8OfDesBhPpNurNyWhHlHPr8uM/jRKKkrSRvSr1KLvTdjmdS+BGnXEe3T9Q
nsznpKolX9MEfrXJ6h8EvENirfZ2gv0PI8uTa3Hs2P0Jry6uAUveps+jwucRdo1l8zktW8M6toqn
7bYXNuAeGkiIU/RuhrFmxxkZycn2ryZ0Z037yPfjUhUjzQd0YXiWNIdOcp3Irjbrho88fLXfhr+z
Pmcw/jJeR2mqabHcfDC3vUP76N8Mfxx/UU+PS7XVfBmixuQklxL5bSE/d+YgGve5U2vNI8Ha77Nn
H+HbseHPFca3Q/cpKYZ1H93ODVj4gaTDoPiZ/sb77WUCWJgemeo/PNc9r0X3TKbtNLuanjjS7a88
N6Nr9oc/aF8qde6uP/rg/pT9P02HxF8MdQlD5vtMlEgXuYyOf5N+lbOK55W2a/QV7JXKXw2jj1S6
vdMlIC3EJK5/vD/6xP5VDo/hu+0fVra6uImS1WcRyOOyk4JqadNzipLoJySumyp4z03+wvFNxFGf
l3LIpHvz/PNbnxR8NHTrvR7xXUxX9kk4ORxkA/yIpygkp+TFzfD5kmraIr/DHSNalw0f2prY7TyC
Mn+gqr4ftbe98J6pHK3ldGiLA9euP0p8i5reX6FNtarv+ovw60T+1r+7tlYNDJE6lu2QCwP5A1X8
GeH31HX9sDeZHCyiV16BSwXP5sPzqYwTUPX/ACDmV2mV77RX0/xfLaqcst1tQdyN3FX/AB/4buNP
8Q3aCGSRY1VmkVcgZAPWj2ekkujHGTk0g8Z2P2XQ/D8jY3TW5b8MLj+dOk0SRfhtHqEigRtd+XGT
34Of5GqcFzSXZf5EqWiYzwroslz4Z1+82/uLdFDH3OcUnw40d9S1uUJwkULSO3YKCBn9aUKfvQXc
blo32GaCT4j8RR2sqo0MhYBSvUYPetLwto89l45vtHiDCVC6qO/HI/SqUPaRUn3sPm5XZHsDLKkK
xyS7JwfnHuOop5uPmjRpSqjv3NfDzjyzcezP02DUqalfdIeZRuOZMrjA9qU3P+iltwznj3rJ7bGq
ehHNdKyp84XHrRHdI9ww8zoM9a0tpoS2r2uQhoCkmdrEHOBWhbzRQxooPlcA9eOacuZoS5UW4Z4R
ES0quCcfe7g4q/PqUckUUfnBgTnr6CsmnexV4dyo2qRKi5mUDdg/MO1KNYt9qMZVxjPWrjFkucO5
YXWLVpcCZAyrwCw70v26Btn75AMFhlhS5X1Qe0h3Iv7StC203MWfTeKia/tQ+ftcP03ChRa6EurD
uNk1K0mjC/aI8nkjcDxU8WpWbQDEseScE7hgVfLK2xPtoLqL/aFnJwLmLk4++OP1qNdSg8yY+dCN
oxjzB9PWjlfVE+2g+pLFeW7KM3MOScH94PrUs11bGMj7YjKvTLr/AEqlddBe0g9bh/aFpMEAuogf
TeMmpri4tYlUmeLaB97ePxqeVvoHtY9ym+oWa43zLjOSxcc1DHqll5z5uY1AGPmcen/1xWii+qJ9
rG25PBrFnarIq3CHGCDv4/z1qAeJoGY75UUZ5O4dOxocHLUn2sEtya41W12kfaU54G5h9TUf9qWy
zBvtCdML82c1Hs2aOtCWiY5b+MKx85SeR94VHDqcHl4M8e89RuFRy62sHtIaJyGyXUTRki4jOTnO
4cVRm1a1TdmaM8f3hWiTeyIdSHcypvEERkVUdXDc7s0iaim0EyKyk7jz04rRwasiPbKTsmWlvI5I
1G4ZOSQD1pv2yIbQZAOe54zS5XYtTja7Y5r6GFnLSoMcfeH+fWilyOw/bwho2dDGo4x0qdUxnHNa
LU+FkWIWdWBViD1zWjb6rdw8LIWHo3NbU6s6fwszlFS0Zq2viaRV/exK4x1U4Nalv4itZfvhoz/t
CvUpY1OynoczptP3TSt7q3mGY5lb8atrEMcc16UZqSTTMLbj1TrUixnvzWoug8JnI25U8EVhat8P
PDmuKftekWzOf+Wsa+W35rjP40nFSVpamtGtUou9N2PF/j18I9J8M+DZ9X06W4jKTRqbeRgy4Zsc
HAI69818y3jbmXjoMV584RpycY6I75YiWJtUnvsdrYn7R8L7uMnkTk/+g0y9jbT/AIf6LdIeROW5
9ia9F6pSX8qOFbtef6HGeKPm1D7SvImAfPvVnWbr+1NEspmO6WEbGPtXN/Ml1L7MXTr57rwzd2DM
21WEiDtnv/Km+EtSktZbu1DkRXERRh2P+eaqMveiJx0aK3hq8fSdegkVirI5UkH14rqNe8eRi1ub
AwsZ2OA/8PJzmrp1fZU2u5M4uUk10MLxrqB1K8guCfmaJQf1pfEmsT6rpOkrO5kFtD5UeewAAx+g
rOo/el5lR6XJZtcmk8Ax6YXLW6XXmhewbGK3PCPiq2i8MS288B8y2DHIHDA5NbUans53a6Gc4uSs
u5zPhHVpNN1WaeI7D5Tge2Rj+tM8I6lJYeIoJ0YqFcuefSsYy1ivP/I0kt2TWuoSX3jaK6c7t12H
P03Zr0u6+I2l3kWqRXL7LpmKBCM7xgAY/wA9q6qFaNPmcupE4t2t0OG8eao17c2VsD+7tYVjUemA
B/ICp/EGtSr4T0jR/uwwgzbfVmJOT+ZrKUneZUdojo9dbS/AMmmRHab6YSy+pAxgfp+tHhrV28O+
GNYnTie9X7OjdCFwckfn+lHNqn2QW0afVh8OpFsdTlv5ACIo9i/7zcfyz+ddZptzJb/HYT7cNKpY
/wDfr/EV0U/4cbdxPWT9DnfGHjjUYfFerxLKwRLuUBdx4G81iSeOtSlwWmdsdMseK8WdGHO3Y9iO
Nqxio3F/4TbUSM+cwPsxoPjPUmXaZ2I9NxrP2MOxf1yq+pG3iq/k6zNxwMsaT/hJr/tK2frVeyjp
oT9Zqb3E/wCEmv8AcP3jZHvQ3iS/Zt3mnPuafs4IlYmp1I28SXvH71h+NRv4kvTkea34mn7KPYze
JmH/AAkV2cZlb86VfEF1t/1rfnT9nEf1ib1bBdeuf+epzR/blyOfNNDguwvbztuL/bl1j/WnFN/t
y6/56mq5V1RPtp9wbWLls/vmP40Nq9wy48w0+VWD2surFTWrlcgTMKb/AGtOxJ8ylyoPayHf21cq
eJGFJ/bNz/z2Yd+tLlQ/bSXUDrVyf+WrfnTTq1x/fNPlSB1pPqH9r3GP9a350f2xchhiVh9DRyon
2srbh/bVxgjzWx9ab/a1wc5kNLlQe1l3D+2Ljp5hpF1edQcSEUcqD20u4f2zc8fvD+dH9tXDD/WN
S5UL2jF/tq5/57N+dJ/bVyuMSsD7Gnyor2shP7auVY/vD+dOXX7pQR5jAn3pcqEq0kL/AMJJd4x5
zY+tK3iS8cKPOfAPGWNJxRXtpMa/iK6Od0zE98saKOUl1W3ufW0UY2jIzmp44zmvB1J3JVj+U9qm
WMZFULUmVfbNSiPgHHWqFsySNSpJHFX7e+uYVG2VhW8Zypu8WRKKluadv4inTaJEV/wwa07fxBA3
31MZ/MV6dPGdJo53R7GjDfQTqPLkU598GrYUHkV6UakZpOLOdprc8w/aTh3fCnUT6SQn/wAiLXxJ
ef6wc1x1v4h10fg/ryOz0fI+Ht7nkeY2PrgUvii4Mfwr0UKRnzCfwJau7/l3/wBu/qTfX5nAT3H2
jT493LJT7GXfYzwnp1xXHfUoZpMxjmkXPDLio7OQ29+CDgZxQnsIVmMeoFgf4s0awfNvhIOrAGi+
jQ7ajtQk86OD2XFPvJN2n26d1ob1YDnlxo/l9PnzS6dN5OnXQz94U+oEWkgKs7H+7ik0nK3EkgON
qmhdAJdJkEd/5x/hyaZbqZtW81ufn3U10AsXchvNTySTkipL+c3l8q7sgEKKE9Rj9SkEkkcScqqh
RTtTuAlvBaqfljXJ9zVStq0Ha5JHqA061t7cfeZw7Y+or0W5Y2Pxg0yYcF7cHPvtYf0rqpPS3mjO
X6M8+8YxtN421vjk3UjfmxNUP7OkIHHNcM7czR1U4uSuJ9jfn5efpUiWDbRxzWTZvGBKunvt5GKk
XS32g7T+VTc29m0tiRdDuXBdIXZR1IU4FQNp7oDxT5kZypTvqjPmiKsOKjkXJ6Vp6HO46DGXGPWm
4NBDHKOadg5oGu47G6k8s+tFxWHbOaNtBpy2E2c5oC9+lIm2twZTxik2n607hy3DYce9Gw9zmkFm
JtNBTOKLhy3E2NxTWzxikTZ3DB60bTTvYLajWXpzSbTjrSFYQ5yCKTac0gsGGNN5NA9Q5zSBmZh2
oF1A9Txk0UD1PteNPmyBxViNe4rwPU0TRKELfWpVj5I60+gEwT8PapY0561pyiT7kqp+BqRY+lHq
TfuSpGcipFT2prYTumiVV21agupoeUlZfx4rWE3HZktXOH+PesTTfDHUopCCrPEM9/8AWKa+PL9Q
siHP3lzXbCbqXchwXKrHV6Lz8P8AUMkkb247fdp/iePzPhlo2OzD/wBmr19qfyMOvzPPrYKy4zn2
pLVjHI46VxI1EiJhufSkb5bjPvmjpckWXPnFqLn5mQ9sUDFlGdnpih2LJGKGIdJIfs4HbNIrbLPb
3JqhjoD5ds467qLdvLhf/apdRDrb5Fdup6VJbN5bM3fpVJ7AOt2xKXPWi3bEzSHnHSqW4xySbrgv
2Xmmf8fE53HHOanQCK5VvtOWOdvoa9Z1pz/wm3hW5zuM1uPm/D/7Kumj8L9UZz6fM6ix+ENprGqX
GpPdN5l1mTyyowOcGugg+Clv5OGlXp3XkfrXzmIx3LVlG2zPs8Ll0fYx13RA3wGtnw4vivH8MY/x
pv8AwoW2jOf7Qz9U6/rXN/aD7Hcsth3LE3wX023tSxvGZl5XgD8Ksx+EIIIUiWGHZkbcxDPHr61D
xblujqp4NRb5SfWvC8up2a27XckEP/POBdoPsR3rCl+EdlcAIs8i8dgKqOL5FojKWXqpK8nqUpv2
f7KTk3lz+Cr/AIVC/wCz3YRoWNxeSew2j+laLMZbWOd5NRavdjv+GeNLwFa9ulfu2F/LpSp+zhps
inGoXQ/4Cv8AhT/tKX8pP9i0f5mSp+zPYspP9pXAHui07/hmax3IBqN0244O2Nfl96qOYybtymcs
lpLZsk/4ZisdzY1O6XBxkxqQab/wzHaFcjVZx/2xX/Gr/tB3+Ej+x6X8zIB+zXaeYy/2rM3/AGyA
/rTz+zLCemrSY/65D/Gj+0P7o3k9PpJkTfs0xKxH9qSf9+R/jR/wzPDkk6vIB2/0cf8AxVL+0P7o
/wCxofzMb/wzLHyRrTAf9e+f/ZqZJ+zSij5dYb33W/8A9lR/aCf2Rf2NH+dkDfs1ybgBrC+37g//
ABVMb9mu4XONXjP/AGxP+NP+0Yv7JDyWz0n+BXb9nC6XGNVi5P8AzxP+NVbj9nm+gz/xMYAB3MZq
lmEH9kj+xn/P+BAv7P8AfyNhNStmP+61RTfs/wCqoD/p1qecfxf4Vax9PsZyyap0kVZPgPrEa8XV
qfxb/CoJPghrEYJ+0Wv03N/hT+u0uxCyer/MipJ8HtbXo1uw/wCuh/wqJvhFrwzhIT/20rT63S7m
LyrEX6EH/Cq9eZiFgjJH/TQUw/CnxF2tFY5/hlX/ABo+tUb2uZvLcRbYib4XeJAD/wAS5iPZ1/xq
Fvhv4hTg6c/4Mp/rVfWKX8xDy/Edhv8AwrvxBnjTJT+X+NRt8P8AX1wP7KufwTNP21P+Yj+z8R/K
QN4J11OulXR+kRP9KKr2lP8AmRP1LEL7B9govcjFToteL8jjW5KsY57VMo2nNUgvoSqvtxUix8Z6
Va7EkirzUyr69O1MWxKin1wKeq45p9QZIqn05p6pRuI87+PTKvw5vs9fMjH/AI+K+SL9t0id8LXZ
R2KjsdXoZP8AwgmqgdPmP/joq/4gZR8NPDzMu9FkGV9RhuK91W5L+X6nNvL5nnEkaR3JaIMEzkA1
LeLC1wZIAwVuSCMYPeuHSxrbUS8WF2jeLduwNwPrS3UcLxwsmfNAwwxT01FqJLHG1qhG7zQeRih0
ikslzuEynpjg09AF8uJrE5YiYN0x2/zmlWOJrN9zFZQePekA2OONrJ1Y4kByOOtNWKNrV1YkOCCt
MB0MaNaurPhx90etOt4o/ssu99sg+6CDzTALdU8iTcdrY+WltY0MUhZwrAcAjrQraBqSWfl+RMHO
1wMr70lqIzbz7mw+Plz+tCasPUbbqhhm3MFbGVz61BGVZXy+04zk+tK6GVyxZhXq2qSfv/ANz3KK
p59kroo7P5fmZSR9A+HrGKXQbdnyJ8sEI6jk10Co3y7x27V8TjP94mn3f5n6Zgv93pv+6i2unLMM
7jilXQWkmCKcrg8HiuNI9Dm1Mu8WNWnhZJdyZG7AIz+dV4gqqMoDgetazg4uzMaVRTXMth9v5dxb
pOibo3J2Pzg4OD+uamTy1OTHz60qkXSnyyNKMlXgpxLiAOoOwY7VIpGPuVindm1rEfk+ZIAEUdqu
JaBeCtVclx1u2PkX90VxzinWqBVyT34NaJmT0dizKgUHjjrUESfKSRmp5tbFciaQxoVOWxknjNOi
TcpDL5Zz35J96uOuoStHYVrXcoc5x9Kf9lxGGz8retD91hGzWon2WPbyDz7VD9kVW/iwenFZ83cr
luI9vHkHn8qT7Km09vwpxkrBKLuQ/ZY2YZPP0qK8tYWXB5+opqSWpMoN7GDb2MUF5K7SZTtkYq5J
bwNklh+VXKSvdEqLiVprSHaPnAFVZrS1Cje4J+lKMiXfZFZtPt2A2sKik0uPkAiquTfqyMaWvPIN
RjSTHk579qq4r9BPsLKTzTG0kM3Tn2p3uTaz2LMelhU2kc+tSLpo24DAHpQNN9ieHTT03qo6c0Ua
AmuxbjKtjnmrC/fxnOa7elz82W5NGuV6VKq54NaaCdydQfpUir1HFOwiVVB4xinovTNBJIF4qRVz
x6UaMNiRRmpFXqBTW4Hmn7QzeX8N7odN08Q/8ez/AEr5KvOXX124rsofCy0zrtHVV+H+qN1OWGP+
AivWvgno9h4g0zSbbULWG9hWBnEcyBhkHg4/GvZk2qLt/L+pzX9+/n+h63/wrDwpuyNAsM/9cRTG
+E/hKRct4fsf+/QFeCqsjo9pPuNb4R+D5MA+H7IDGf8AVUsfwl8Hqwb/AIR2wY57xCqVaW4e0n3L
kfwv8D4Ik8J6cRnqsWDV2L4S/Dm4QKfDFjH9Yzx+Rr0KWKg9JowlKqtpFmP4EfDqdfk8N2LLn+HP
+NSn9nv4eSLtPhm1x7Fh/WvRjySV0jL29aOjYf8ADO/w96/8I1bD8W/xprfs4fD5uvhu3x7O/wD8
VWijHsJ4ms3o/wAEJ/wzj8OzgHw3AB7SOP8A2aqN9+y/4BuiTBpf2VvRXZl/InP60pU4zVrWNKWM
nTknJJr0MK//AGW9BiGYNMtrkDptkZG/InH61zuofAfw9pnN3oHkjOAzs4B/HPNfO4nDYqjrB3R9
dhcVg8Stkn5oy7f4TeDbrUDFHp8Urhd3lrI3A/A1ov8ABHwsdpGiJgf9NG/xrx6mIxEXZux7NLD0
JrRJ/IrXXwR8MN00VAO/7xv8a+c/Hvhu00XxhqdjBF5MMUuEjyeAQD3+tdeBrzqTcZvoeVm+Hp06
MZxVnc5ZoVXOBXompSf8Uz4NuO8dwE3D6nj/AMdr6ag/i/rqj46XS59F+FVum0NJ4SuFdl+YdOBS
Xmo3TErvAP8AeHavjcal9an6s/SMD/ulN+SLWm69dRwoGdTj+PFdha/aL20WVTncPTFcUo2d0d8L
PRirpE32SVmjVcqSTjmuV8mNldCflOQeeaFJt3ZpypRaQQ2MNjbiK2BVBztHSrduyyYBU06rcnzS
erKoRjFWSsi9Cq7cZxSxxjn1+tZbGr3LVuvzbgPxxVvG5uv5UwsmSSWqsv3SWqKK1EajcMAdOKiX
MppofKuVrqPgH2iQpzkdKsR2Z3MjKVIrdr3rmEZe6C26QsQ46dqjlhV2yo/KknZ8qHy82o6GFGVg
Tk46Uz7NGF+93pz7hT93QXy16Z7VGyIMZByB2rHU6ENbZ17HiopIwASDnNEdhbsiWJfMJIzUV/DF
I6r2I55xVLYzcve0MC4t44bhE2kBzwTz+NPkVPWkK6ImjgA+cgD3qpI1pMHVHVmj64OSKtX6Etpa
dxkMSEDad2B1zTVt9xG1uaro2Y9VcmW1aMgja/1FV2t3bJp8yeguWw37O44J4o8l2+6ePrSK3ZaS
JygGTmnxW8rSAdQT6VUfeaQtFe5r3lvbx7EQDO3njmiuycYXOSnKTjdmFF8w/nU8RIxk1rufnhPG
xHFTxyAGqTsSWFkDcD+dWEYBfeq5gJVqRV4HpV7k2dyQLgYqXb8wpaDJAvrTlXDYoSBs8y/aJUt8
N5/X7RH/ADr5HufmkGfSu7D/AAsqO2h1elyj/hAdTHcsR+G0V7P+zqS0WnAcj7O/869advYv/D+p
z68z9f0Pf1XvSqnFfPGgu335pNm3FHkMCvzYxSYxyD0o9ABWZeQSD7Vdt9Yu7dgRLuH+1zWsKsoO
8SXFS3NKDxOcfvYs47qa0bXXbWYcyeWf9rivYo4uMrKWhySpyWxoxzJMvDrIPVTmpNobpxXoxkpb
HOBiI5B4pCvBVhlTwR2IrW+gtdzHk8G6HLdNcDTYIrhhtMsC+WT9dvB/Gqk/gmNR/o1wwz/DKM/q
P8K83FYGninzPRnu4HNqmGtGavExr/wnf2zFhD5y9jEd36df0r4p+N1o9r8T9bjlVkfdGSrDBGY0
NeDRwVTC1m5LSx72OxtHGYVOk9brQ83k+8RjHNdrqDFvhzorjkw3f/sz/wCNe5Q2l6Hy8uh9RfDT
N94bmiPBMuR26qP8KbrmkvayDK5B9K+Sx+mLn6n6Jl+uDpvyK9lYySQkDcxznaB+leheGcf2WgbA
IO3A5IrjdrXOyK966Nu72Q2Eqk5BQ8HiuCk09GbOMc1hLc7qezRJBp4STJbII6VdjsYY1Y7eex9K
rcFGysiSGwRkZgeKdDYoM54bNLYq/My21ki8LUq2oC/Mdpx1pXaVynrsWLXYY2jJ3E+3NPOnrIcc
gd60XvJMy+FkZ0tIeYmORVmGzkkbc0h/LGavXYh2SuMfSzLPjzth6HccVehsYorYh3B44IYA5rSn
CzbMqktEkjGmhMbtjIb2ORTFtWZurda55bnXFaInWyJwQcGo/sJVgd2fpUqzC/Yj+wt8wLfTIqF7
VlbkAjPPNO3Ybb3GSQ4Xjr7VTliO7LLzjHWlurEbFSax87llJx05qD+zEGeCTRstBbojltFWPDpu
XpgisddHht1meEOAwIK54HtW0ZWWhg1eSb6DLdZY8qACnbcM1LIzgZChTjrioluUtERr5nOD+tM/
fKcjpRoiPMnWKZlDFciiSQxj7uDVS2M4NtgsmWHy47e9aMEn2eNHGC9aU1fUmd9u4rOZiWb72OTR
Wct9TSKVjNjT5asKvI4r0lqj8x2HquRz+dTrGeccU15j9CWNPUc1MvTFV5C6kiswwamWQ8H8KL2E
TIw55qZWDcHiqUgJUIOBnrUnXvmn6AebftCLu+Gt1/12i/8AQhXyBecTEe1dmH+FlLudLYA/8IJf
tnjeR+g/xr2/9nGJmg02QjCeQ6/jXsT/AIT/AMJzP4vn+h9AhaULkV88bC8/jSbd30oFuGznPSjb
x70aXGhpU/pSbDQFrCYx0pffrVdAJIp5ISCjsp9jitC38Q3kIwZA4/2hW9KvOnsZypqS1NG18VI3
EsZXtuWtW31u0uMfvV3ejcV7VHFwno9DjnRlHValv5GwyNwenpTtrLwDn37V3qzWhj5sbu3ZOMV8
K/tYW5g+M2pyY/11tbyf+Qwv/stc2K+BI2w/xNo8PmGJGx612EkfmfCrfnPlXn5cr/jXLR6+h2y2
T8z6l+CayXmgzSRruG2FjwcDcpP9DXY6xdW11asE2SMvB55UivmMzozWInNLTT8kff5TWhLC04X1
1M7SNE/tKYLHIYe5JOKpww6z4b8aRFLjOgnIlhcbvmOMEHPH/wBevNhKLWp6MotO8XqmdrqlpJeW
32u1njlt8fMGOMDFZMdmGjDOoGelYyizupyXQfHYLIpEhBIOQRW3p9nDLGJPIRo/utuz/kGtqer1
MZaIT+zLaFmUbgn8PP8AOlawhnVSBsx+dTNrZFwu2mxBpayN8u7I9am/stGjJZ8kDrWaWmps5aab
leGzCyExKTt7gVpxvtUL5O5j0wT+eKuGmxjU9407XS4FdRcMIwRu9xVHVJrYt/ogbavUkdfeu2XK
qdupxRc51F/KQaesmqXSqQWxxnGa09W0sxr8q7Y1HLMoHNKMb03JlyajUUTnxZNIfWhbB957H3Fc
PU9DpYb9maPOWAqLy2ZvvYA96FYT8iGTIcj5j6YqpIvmBsMV+tCeouXTUhbKjG7k+uKY1rv5LYPW
n5si6WhBJGIflJY1FtWRiF+lS7dB6kdxFuUDBqtNDsjPHb0p9CG+5Rt4EuM7Gw6nBG3FRX1hNlME
nB5wa0VluZt8yGfZX6lMDseKXy9zAOOO9JWuJ3toWpPs+wRxbmOOR71WMS7cEgEjpVVGr+6TTTWr
I4bWNpMM3yDrg81ZZU25X7oPUHpWkXFRJcZc3kSbCgBP3T36iiiLVtUXysoov5VMqhh6V2rRH5ky
RY857cVMo69qaRBKg/E1Iq/LmmBMq7iM/wCeakHHNO1xXHhTUi/dpjJFHQ+op6nAxmjUDz349Zf4
b3w9JIj/AOPivj+8x5x9hXdQ2ZUdjpLN9vgK+x0MjD9BXtn7OcsjR6auQUFs5Ax7169T+D/27+pz
fafr+h9DY9BSj9a+dNR2O/el2j8aY+gmM8dKTaM4oQCY/Gjb8xoQxCvSk55o6i6icUYHToatXGJ7
dDS7uaadmImgvJ4WzHKy/Q1pW/ii7hI37ZB+tdtLEzp7bGE6akacPiy2lXEqNH3yORXx9+2D5M3x
QtLiF96SaXESR6iSUfyArvqYiNan5mdKnKE/I+fpfvMc11+mt5/wx1aPP+ruFcZ/4B/hSo7teTOi
S2PrL9k+8aTRriMkEvZ278d9oYH/ANCFe532i6fqNuIJ7WMIuSPLGw5PqRjP41686cK0OSaumcUM
RUw1X2lN2aMv/hCrW3+azkZG6AScjtxxXP6/4U1G4WVVtvOUjhozu5+nXP4V8nisllG8qGq7H2+B
z+nV93Ee6/wI/DvhfW7exljl029MbA4/cNz+laS+FtZmkRJLG8CDp/o78fpXi/VKvNys+m+s0eXm
TFbwbq4mZF067YH/AKYucfpV2PwrrcdqIhZXRQnOzyH6/lWaw9VNux0e2oyik2NXwbrLDI0y65HP
7pv8Kv2/gzVG4fTbor22xHr+VKOFqXu0VLEUrWUkWovCerW6kLpF1vP/AC08lmx+lQDwnqcJIexv
GXHP7hv8K1eGm1axisRTTb5ik+g6hDI221uVB45iYH+VMXRrpWLiOXI7MhrP6vNdDV1IS1bL8kEt
1boGMkIXrwRn8aq3UMaQhUJ/xrScJvoYwsmkTaCyWtwCylR9M1e1qNZ497y+aDwAnUU1zKnYUo/v
uY5z7KFPCnrnmpJoEYLgN+IrkVOVr2O920IJLEyDofbiofs69QrfjUOMl0LTXQgmiU5AXB6VRnt2
6Ae1NRZm7FRrF34K/jT1sei80+VkOxHJZjLcGqLWrwtlSwI560WexI2SRnOCuDTWgaQcZzRyStoZ
8yHR2gU/vBncPSoLi1DNwSD9aJRdyVa1x8dqWjCkZol0rZbsSMn+9RyMfMtjNMLwtnrg8e1VbkSz
SkouPoP1pRpTfQ0Uo9WTW2nO22Vwy7ASPfPapoLN4d79d3O3tW6o1LLQx9pFu1yNHNurIMkE85op
OnNOzQ4tPW5XRcZ4ANTxrtPWu5LSx+Yj1Xb2qZFz7CnYklUcdKeoHrzVWAlUcDninq3Ayc0gHrgY
FSbhjFAhysOadu6dPpVdReh5/wDHRt3w31Dv88f4fOtfH98Ntww7Yrsw3wspbHQ2+P8AhBb3/fP8
hXtX7ObYj0055+zv/OvXqfwn/hOf7T9f0PoRJz0FOW4HftXzpsrD1uB0zT1mGSetWAvmKcE0FvQi
mgF+lBG6joMCpPFIRjtigXkJikZdzdKrzATvz1pfrT8wGkdaaVPFUhB6V8zftUw7fFGjzdnsyh/B
2P8A7NWsH7wI8EmX5j+ddd4XTzvA/iRMZCoH+nBOf0r1KC977yZbH0X+yNrEVtbxrLKER7Jl9eRI
MfoDX1DDcRzLlJFk+hzXrRqRso9TzakXzN9CTdS5HU8Vsmc+hLDeTQZCSsAecbsCrsWv3cKOoIcs
MZcn+hFZzo06m6OiniKlHZ6GddeKPE8fNsunSr2DCVWP/j+P1rNvPH3itHzJaWSZGDhZcfo9eBi4
Tw/vRjzI+sy/2WO92VTll2E/4T7xRJHtEGnhc53NHKT/AOh0sPxC8VxqwWDTGzx80Uv6fPXjvMEt
4n0H9jvbn/Asp8S/F4YMLbSTgY27JQP/AEKpo/iZ4uWNl/s7TWz12zyg/wAjVf2hDsZyyifSp+Ao
+MPiu1AhfQLaTceHXUZQf/RZqyvxo8SQw4l8Llu+6PUsn9UFafXKLWv5GX9m4iO0k/vIf+F46irB
ZvC2oP67LmF8/nipLf43I4Im8I6ox9Stucf+PULE0JaXB4HG01da/MkX446X/H4S1Q/9usJx/wCP
VWuPjhpLMAPDWqRD/rwiP/s1P2tD+ZDVDHr7L+8qSfGzSeVGgaivpnT4/wDGoH+OWjptB0LUARxz
p0f+NL2lDuh+yx21n95Efjz4a6T6Xcxj/pppgP8AKnf8Lq8BzR/PbrG2ed+nyAfoKP3MtmiVLG09
0yKT4reAG28W/vmzlqvJ8WPAA3FhFt7f6DJ6fStOSlYj6xim9n9xXPxY8BMo+aBTjn/Q5BVaT4ke
BZG+aS19j5EoqfZ0nqNYjFro/uKUnxI8FeWwP2VsdABMpb8eaitviB4GkYmRbdeO9xJ/8TR7Kj3F
9cxS0a/Alk+IXw8jjIaG3dgcbRcSD/2Wqp8f+A8graxBf+vp/wD4mtfZ07bmDxeJb+EZN8RvA4k2
rbWzY7/aJB/7LUUnxA8EbVIt7YsTyv2qQY/8dqfZUe4PFYq1kvzBfiB4NCEiGFWz08+Q/wDstNk+
JnhNY2xDCcEYUrK+c/gKrko33F9Zxb0SM+6+MXh+x/1GmK46/LY55/4EaqTftBafGwNvpFwfTbax
Lz+Rqfa0I9SvY42om3csR/tJW/G/RdQY452xwn/2WpU/aU0ZnxLol/szgeZaQt29hVxrUXpcylQx
kLaP7xl5+0N4VmjBGiThuvzacgIopuVN9Rf7ZFbM56PtzkVOg6eleOjw/QkVTUi9/erAcMilLfWn
0sKwLJ0HSnrIFwKQhwf86esmOBVeouug9ZPz6U7zB0zQPrY4L43yD/hXt+B3eP8A9DFfI2oH/SDx
2FduH2aY03Y3Ubb4Juh0BY/zFeyfs8zbY9Mz/wA8JB+tetU/hP8AwmC+J+p795h/Cnece+OtfOo0
DzqXzmHK0eYC/aSqjBp63h701oNkyXQ6ZOKtJMre5p3DzH/jRtH4GtPQPUNvAzSd6QdBMZ68e9Jt
5yavcQY6UmKfkA3aOlfOf7V8O278Ny/3kuFz9DGf61dP40CPnabh/wAK7HwGnneH/E0Y6tbf+yvX
r4fSov66EzV42PVP2Yb4N9kiJ4xMn6Fq+lY5Hj5UsrexrLEOzi/JELqaFtr93b4Bk8wejc1pW/io
cCaDn+8h/pW1HFSjpPVHPOipfCaUOtWdxjbIFJ7NxV3IYAryPUGvVp1Iz1izjnFxeoZ+YUqttbjj
1rfpqQnyu6GyQxSjlcfjjFJ9li2ELw3Ysa8bFZXSr3lDRn0uBz2vh7Qq+9H8R1rpbS7n8yMbf4Gb
BP0qwIWiYhU8zPQ4zXyOIwNTDfGj73C5hRxj/dMpXEFx5mTE35dKryRzSMA/yk8DIry9T2fdXvCS
afcpljHxUa2czjlcY9ql3NI2JYbCXIYjj6U2S1HIOOtMnqQSWGPu81UazLMfkqrNg2VZtNbqUwao
zaeI+QmT7jrQlqCZANOR8koM/SopdHTAbYrc9wK64U5T0SOWU7MryaTGMZt1I/3RVS40eFlz9mTG
ePlFZ1Kcqb5XuNSUtihPoNoy5Nuo/wCACq/9hWm0bbeMe2wVHvXsK6K0mgWu7Jt48f7gqI6Pa9fs
8Y5/uCj3jNIgfRbRiR5Ef/fIqvBoVq0nzQpn02ikuawabkzaXbIQv2dfb5atNpsEduzrEo45wtEb
oVlojk/EE0yr+4TbGvLM3XFSabZpceWxhJ3jh+1bSilTuiYSfO4vY249LVDnyhn2ps2nq3AirFb3
NJWsPn0uGOJSEw/XiitublM4vTVFpFqRO2BXZ10PzN7kq5288d6ePmxiqW9hC8ZHekYjnnHei6YE
KyDP3hTvPXu1K/YB32hP7w6U77VGF+8KXMAv22P+9R9vTgE/SndBrucH8a7xJfAd2in5jJH/AOhC
vlK95uW/nXfh9mwvobczeX4HmGfvNz+Yr1f4B6gEh0wk8LHIn869ia9x2/lML6v1Pdv7XUfzpP7a
U+lfMc2ptYQ60vc0h1peeeBVJprQdhra0OBmrVvqQl75oTFYtx3IODnIq/bzFup5qiS2rHaP8ad5
xbOaE7FdBwm49KdvHHari+gb7ChgzHsKCB25rXfQQdvU01l46UyQ2gd+K8Q/aO8L6h4ok0aPT7SW
5FnHNLMY0JCKxQAk/wDATXbhqMq9RQihXtqz5k1HS5be6eJlO6MYYeldP4HjbT9D8QXMqkRi3259
8McV6FKnKM9RTkuXQ7H9me88vVLZd3IuCv8A30uK+sj82K5sRqoegluxcEH3oGeM9etcqGLjmpoL
uWDmN2U+xrWMnHYmSTVmaEPiS5h4fbIB/eHNaMPiSCTAdGjPtzXpUsW1pM5JUesTQt9QguB+7lVi
e2easBj9BXpxnGaumcdnHRjt54BqSK4aE/I5HpTnCNRcsldF0qs6MueDsy3/AGtOEONhb1Zc/pXI
+KfEPi2xTzdN8OWeshegjv8AyXP/AAB0wP8Avo18/WySnOV6crH1uH4iqxjy1Vd9zzvXv2ptW8My
CLV/Ad3ZSYx+/kKKT7MVww+lUdN/a6sJJne60O8jRhgLHIrBensCa8qpk06fU9iOeOVrx09To9K/
ai0BlffYXwU9Mwqcf+PVbs/2ktP1KYRQ+Gb+eUnCiIKxP0HWpp5JiKl+U61nC05YNnovh2/8V+Kt
hsfhj4odJBkSyWBjT/vpsD9a9L0H4K+OtaVDN4UOlK3e9vIOPqI3Yj8q2lk7paVKi+WonnEEveR1
tv8AsxaioLapqmn2MQGWkjBkC/8AfWys/Vfh58LfC9uZdZ8cW1yy8MlpKhbP+4iyt3p08JQg7L3m
c8s2rVP4MNO7/q34mFZ+OPgRplxn7PeasmdqzLbyAH3G+RM/98VFqHxo8DanrthpnhC1j8My3Esc
LahfaTayeXlwN4JBOPXJr2KVCUV8NonkV8XWm/enfyV/0Oa/ask8I/BvxXpljqV7HapcafHLHLKh
LTNucO7EDBZnDMf970xXg0nxt+HbEIuu2Y92yP5ivFzHD1qlb2qXxJP8D2sJmFCnRjTnKzSIm+LX
w/m6a/YH6yAVGvxK8CmT5de07/v+v+NeX9XrL7J2/wBoYdr40SL8QPBNx8v9tad1/wCfhf8AGnr4
i8KSZ8vUrFyfSdf8aHSqp/CNYyi9poQaj4fYErd2zDt+9X/GmTXWi4UrLCSf7rg1l7OUd0zT61Tl
tJCrJprYwVz9apXl1DbyNGjAgj8KjldzRVU0rGRdaXb65G0cjhMHgrwRToNFijXyROCq4ABqdbcv
RGkakU2zYsNPhj+9NjHHBq9Jp8LgHcDU26s0TUkUdUhhtrOaQfMVXgUVrTtJe8YTlKL0MlB8xqZA
e/eus/POtx/I57Um7r2p6E3M+4uGjzzxWfLqRwTurP0K3KDawVbIP61H/bTHnOaNQ2FXWmLHntSf
2s3TPNCQCnVnOOT1o/tOQjrxmmoj2OO+Kl80vhOZSeDIn86+e7r/AFre9ejhtIslWN24X/ig5Djv
zz/tCr/wh8VLpl2tq77SH3p7g8MK9vS8U9mjmf2rdz6Gh1BbiNZI5PMRuQympFuW688mvnJ0ZQk4
tHRGXMk0KLlicDNP85uM8ikqcuwBvduDmrljcNHIMk4NCpz7DlodJayZUeladq/ODV+zn2IujTh+
deBk07acZxxS9nLZILoaw2g9vWhVZ1+UFj7VrHD1pbQf3E80UtyxDY3cn3YJG4/hQmrEej6k7YWz
nY56eWa6YZfi5PSDIdakvtInXQdT/wCfGYfVamh8NanMMC0J+rKP5mu6OWYv+QxeKoJfGi1Z+D72
a5VJzDaJ/E8s6cD6buaz/jJ4m03wl4ZTw7oNqst7eqDc6rcEbBjthSeBn8favo8uwksHGVWpbmen
yOGvWjXapwenU+Rb/wAL2ttM8Qdb6aZt0k/QMf6CuP8AiFqUOh6H/Y1m29p33TSDp0GQPyA+g96x
xcoRp2idFFScryNT9nO42a5jdt8u5hk/XmvsgdRjrXz9f4YM7OrFxRtPGK5lsMPwoUDjtVIQEZ6+
lHOemKoQ/cR/9arMOo3FvwkrY9OtawnKLuiJRT0Zow67MMeZGG/2l4NbmjtLrTbLO1ubmQdVgiaQ
/wDjoNezQqzq7r5nFLD21izq7P4e6/dLn+zpIRjJ+0MsJ/JyDXSeGfgnr3iTcYAkccbbWaSOXGfY
7Np+oJrplUpw+KRdPC1Jrmtod3b/ALLifYS+ta1BBbtxLFJCu3b7lmx+YridZ/Zt/Zp0mbz9f1TT
ZLnqy2d5sB+qQf8A664J5hGOkI3f3/gephsLV3pq/wCQWN9+zB4Hwuk+D4dZkTBDHTnuMkd83J/z
mumtv2nLKxjFj4J+GExhcAKqhbZPxSNCPTvWMpYvErXRfcvuR6XsZS0nO/ktf+AWNQ+JXxw16SOP
w74TsrNSdrSSWLqV9w8j7SPwqvJ8PP2hvF0n/Ez8XQaNAR9y3nWHHHP+pXP5mslQpQ1rTv5Ir9xS
6JPz95/5GVqn7IGoarMkniz4jI+7gtOTK574DSMK09L/AGbfhdpkiw3Piy41Ex8GKB04PvtDYrqh
WhHShTMKmIjJK6b9f8jbtvhJ8FfCrPd/2ZNeleT5zyMD+BI/wr5k/ag1TRpPGdpdaBpNvo1hFbiF
Et4wm4hidzY6tz19AKtzryV56LsYqu5Xj3PL/wBtDUZ/HX7Nfwi8VTzNdXtjPf6Hd3DHJJVkeEE9
SfLBr4KuWbc1LER/d0/R/wDpTMqvxXK5duadDBLMw2KSa4IxcnZGTfU1IdFuZFAfcB6Vow6HcR4I
RhngZ716dPDu3MzllUT0IGjlViMsMe9GJeCsj/TJrZUnLoZcyQqy3kTBllmB7bWIq2mqaqMA3t0o
9PNb/Gl9U5nqhqu4rRk6+KtbtWOzU7tTj/ns3+NLF428QK+9dXuww7mUn+dYSwdLrBGyxVW2k394
o+JPie3wItaulAOR89Tr8XvGERGNcnbH94Kf6VySwNCT1gdUcfiIrSoyX/hdHi6RSkup+YpHO6FP
8KKw/s3Dp/CdCzTFNfGfUK/NU8fqK+YtqZ31H/y9TUb/AC59Kt2FqZWojrgVgTMVJ9Kz63HcyJ2K
sTnp61FubcefzqkL1JF3tyc+1OwThSefensVfQeqsOO1PCtjHOKnUk5X4mxt/wAIvKO3mLk/jXhF
4o87HtXpYbZgtjsLa1WXwLtYcSEg/nXnM1vcaTeZUsrKcq68fjXr1E7RfkYK13buemeCfife2W3z
yYdvJnZN0ZI/vKQRmvR/+GhFVQHfR93GWFimT9eK66WIio62v5q5hOm76X+TILj9ogSR7Td6cMdl
sI//AImrOkfG7Ub6G4ktp7SSCM4D/YowRxz/AA1vHFNu0WvuRn7Lun95mN+0xLE7K1yr7eBttEA/
lUmm/tFNqN8kH2hlaTCqzQoBn04FTHG3la4/Yre34j9b+O1xpepR2s93MsjclouAuad4j+Nl34f8
gT3t3N543ARykcevX3qniLKTvsCpLTQsap8YpdG0W01SS7vLhJiPLRZ2BIPPrUtj49n8Z2qXaald
W1q3zOfNIcHPIyc4HH61XPGUuVepSjZXtoZ9/wDEC88GzO91qNzqWnspMTGXLqwGQpI4IPrjipvD
fxlHiDSL64Aubc2Y3yRtMWBXBOf0pe3cZ+zuHs01zJFXwn8ZJfFNxcReTJAY13gNJu3LmqvhX4xy
+JtafT/svlLyY23ZJx6+lRHEc3LpuDp/gYetfHC8s9SubdLBJEikZQ7ucnB9PqKg0f43319qltDP
axpFJIFzGxyueMisPrUlK1jT2ezuenWcet+JfEx06xih8v7N9pN1cbwmQwXZkA88g49KrfELS9e8
A6TbX90bG7jnuUtRHCX3AsrNnkdPl/WlUxvJV9mkXGmuRNy1OP1HVruaxPnxpDKDkeWSGH45rgPG
CmSztpDyd7A/lTxDcldk01ZHSfAuSSPXbnYM7UV/yYf419v/AN4A9D0rgrfw4fMpbsUDuORil2ni
uVIYu0g8irmm6Lf6szLY2Vxesv8ADbQtIfyUGuiFKdT4UJ6bmrZ+AtavJPLW0WOXvFNMiSD/AIAz
Bv0ro7H4Ha7e7GYYDEL5awSrIGJAxiVUUnJHRu9dSoRj8cvu1DldrpD7rwH4U8Maxa6Z4l8W2enX
05A+y3FzHbzDkAnA80EDnJ46VY0/V/gfpP8Ax/eJRqSKrMTDBdSvwoYDcgVOh6kdiO1aKUI/w4X9
dTWFCUnq7f13Zu23xm+EGlbBoeh3+rusfmefLawW2AQRt37S+4ZH6+lb1t+0xpjNFBpXgSa9nfoL
y5efGB6BQCKvlxFX4nZHVCjC9qa5n5a/i/8AI6aH4pfFPXrUyaN4Dm012OFaLTtnHs0nGKjbwv8A
tAeOrgG41FvDVnt24e5RGJ6k4j6enes/Z0oP95K5vyqnrNpf+TP/ACHN+ym93NHdeMfHrXM0fUPI
Xx9N7DH5VhX3hf8AZ/8ADmoLJqOrX2u3PI2IzbOOvQKO/rTddQX7qGhaquo9NbdZP8l/w5M3xs+F
Hg9Uj0L4fLchQNs17GoyPUFg5NdBoP7TlzrOm3E2l6Rp+kww4XAQt6Yxgj19O1ONOpWdps5a1SyX
NK/4ITxR8cNZh0i6um1sWhFv+6jRVRt54B4Hv/8AWry2X4uXdi1wPEHiK5ubM7VWWW6JdWYtng8b
eMdfWuyjh4RV2jz51XtA5+T4npcXyWcWoxNBb7UMvmBychTgED3HPr9K63RPEDw5WEY847senGcV
6MIp7HHKT6nVXGoxtCY58NvXA445HJNeLfHjTVuPD4uwj/uXABXkAn1rnqx91nVh37ybPOvEWlp4
y/Yh+IFgsJlufDWv2WtIxHKpOv2dsflzXwN/ZdxdTbIo2Yk4FYVouVCDXRtfk/1Oms0rN9v6/M29
O8A3Ejgz8DqQvNdVpnhVI8Rw2zSH2XJNb4fCy+I8upWS0PQvCPhbStBs7i88R6DLcwXCFLctN5Lx
y4yrD+8vqMV6Lovhrw1b+GPEmi6pYx6hrdxaqlhNageVA7AMpLeo6GvV9m1DR/0nr95w8/vpNf8A
ButPSx47b/DWDSZhLfTpNchzthRu47n8aVvDKW93nZEgbLA7AMV1RoxtexzTqu6SfqTto7wsu0xn
6AH+VRz2ccwCS2yTc9GXNV7OMuhPtpRe5m3nhbSrhjutWiHqjEYrNb4aw3mIrG5YOx4WQD+fFc0q
HU3p1k9HoZOu/CjV9AVXurdkR13IxBww9Qe9cvNoslv/AKyNl+tYTwttUdEaqeg9dFa4yI1LDH60
VyOl3No1NNGfW8VxzgjrU63A4r80Wu57WzJ1mVl4PNNZsqaoChf4ZTz2Nc/dbQQOKjW9iloZF0u7
tiolAZen0NPYNSxHGWFSCIA89KEwRIsIXHHFSrCv6099RbJiXmmW+pWr29xGJYXGHVq+cPiD4d/4
RfxNcWg3GBgJImbup/8Ar5H4V2YeXvWDzN3RYxe+CE2/ehlKt+eR/OqMWkR30ginjDjPcdK+lUVO
MfQ5E7N+p7hD4H0y/wDCiaWbUQ208KB/JAUkjBznHXIrC/4Z98M5BeO8bt/rv/rV80q0oNo69Wjx
j4jeC7Pwv4j1SztBIsNv5RRWbJwyqT+pNX/AEIOlX6f3sZ+mDXs4Z3lF90c89jN/4RW0kZgQ272N
c5pMJi1q128bZl/nVSiotWC9zoPiVam38SKWXBaJD/OrPxKQPb6HKOd1tzx7L/jWktFMj+Uk8WMZ
Ph34ePZWIz/31WjpuoTab8LY7qFRkSNEx9Msev51przO38v+RO+/cbBfHxJ4Ju7mSNR9jjYP7sVI
XA+hJ+oqj8NJP+JR4ij7Pb4wPo1EdakX3Kd1FpCfCM7dcvBjg2rf+hLUPwzIj8bRj2k/kamG1P1G
/tGzrumxfbrtysajczEsBjqa4nQ4ZF1a0eNC7LIrYUZ6HNZ1PjKWx9t/Ctg2h3ORx55/9BWsL9oZ
f+KR0k8EDV4D/wCOyV59b/fPmi46RPENWl8xnUfjXNeJ7NpYdPto0aSVg0xVRnjOF/k36V61QmEb
6I7/AOAngXVrzUrl4dMvJmd44cQwOxCluWOB0GBX3Bp/wj8T39rFcCz8lJBnZc5t3XJwo/ehQSe2
0muepT9ooq9rG8qFSDvNWuamjfCqa6uo7e71Gzt5CQXXzTlUIJzu2FCfl6bu9df/AMIL4G8NzQrq
eqpd+czIscayNJHtGSxYFVb6YxxW9Ojyr4bvzMZcq2dzQXU/h3oCgxWd1qsoGVZYYbR16EDeg3H8
fWs2++L2m/aWjs/C1ndwL8yjUGM7A85+bIJP19K3cZSXvsIpt+7/AJslt/ir4812SKHQ9NlChSBH
p9gH2A8YUhTjPrmuW8YfBj44/FDLXN3qGm2bHP8AxMtRW3TI4GVLZHIB+72px9nHSRr7Jp803b1/
yMmz/YdX7emp+IfHvh/Sbjd8/wBkD3Lq2ckk4UE5NdvY/s4/B/w7bzza54t1fW5E/eeXaKlvGQM4
A3BvQ857VfM9qcbepbq0lbRyfmL4Z8W/BjQLiQ6J8Oftl1D8ofU7h5DIc4GAQUPbNem2/wAc71bV
o/Dmi6Xou1sCO3t1BIzyM9PxxUexnV+OQp4qTVnt22X4Hn3xC/aM8ZWdu7WeoTPPMGW3jjIUB/cK
BkDr+Fcp4T+JPim9tSdZ164lvDIzTPLcMFPDEY/ABenU1rHDwi9jB1Hy6aHb2OvXOoSXkUt5GH5Z
JppML3xnnIzzz7CvKtQ+H48QXNveaeyrF5bMsBffJMyj5xHjqT2AzzWrgp6CpSd7b3PQLX4A6/qG
g2Z8R3dj4P0qHLCbWJgs0hx2jBycehINa0Oh/Cfws0LT+KdW1e5jG1xpNmsMbY9n/wAa4Z4uNOTV
NczPRjSpQgufXzbsvlbVizeJ/hM8rhx4rZSoQGRbZ1UD0HavJ/i94H8O+PNLhg8N+J5rJoSzCHVd
PKqwJBCl43c9R/c71pTxdSp7tSOhzTeGi1L/ANJv+v8AmjxnSNL8QfDfVo7y+tmutOSURS30ZMlu
m4cEnGVOMkbgDx04r6Hso/tS2F7o5mkspIFnLZBRiQMkd8DHWvWw7dnF9DzsVGPMpRd0zb03Vm1Y
vGfvwtsbI446kc+tN+J9hDe/DvUIVVvN2F8epXOcfQVNZaNCoS1R5t+zpbN4k0T4o+DCFZNb8K3T
RK33muIcNEB69XP4V80aF8PFmv3RLfcgOM45J9qWGSnSa7P81/wDbFe7GL9f0PTbn4c6JounWy6x
PFaRkb2iiQtJ/wACxyOtOt/HGjeHtDbTvDmg+deHP/E0uEClT6qAM/nXqU4e7Z7Hh1Kj5vd1Z59q
VnPe3P2vVrl7qQnPzNnHfAHpVz/hNo9L0u6sbW1iLzgKZmX5091I6eldkYc2myOGdR03pucnPI00
gdT845JJrYKsuj/aZiXUttHbNdElaxzR1d7mYbiKFdyjcvXhqo3GpIzHyk5rBJyZ0uUYR21KUztI
CSeaf4fmc6nENwwDyCe1b20OXmbZ2vjW6W+0+0hMjN5RI8sngZ7+2a4STSRMxXblT27VUY+7ZjlU
1vEr+JfCkVp4d+3WyslwsgVo0Hy4x1+uQPzorjqUvedjthLmSZ7HGemTmpV46V+Lp9z7AcG74x9K
RpD0BqrhYp30xVc1zF5dHzDx71N+4l3KM0xk+YAipbeCRwB1GafL3K5jXttNZozwfarkejM2Pajr
cE+xaj0Hcc5J+tWY/D4Xt700rCLCaCvpx715H+0d4If+wbTXLePJtH8qfA6RsQAT9GwP+BVvS92U
QueVfDvUgslxYSH5Zl3Kp7sByPy/lXRRwmG6JbgCvqqL5qSOSekj6T0SG1t/C9he3MkcEH2aN3kk
YBR8o5JpLPxJ4avbqK1t9Xs57iVgiRxyhiT2AxXzfs5zk1BHRzdj5x/aIs/svj/V1UYBt7d/0x/S
uW+Hsh8q7VT83y/1r1cLeLhczlrFi3XntNMOY3yQdoxg1xlhcSRahGWwzB8EsM8561rU0kmNLodH
8S+dXt2zn9yP/QjU3jY+ZouhOOT5P/sq1pLeZmtLIk15fO+GOjt1KzEH83q9ZQeb8Gb9j/yyuh/N
f8atL3n/AIf0F007lfwLatL4B8VuJSFSLJjHc4JB/Q1B8M13RaynZrf/ABpR3gEtpCfClvL8RTLn
Aa3YH8xUHgFTF41j68eZn/vlqmPww9f8inq2jqtW0ee+ku4I0Z5pshY8ZYk+gqx4L/Zg+KfiS8sp
LHwVq8UUzgx3F3AbaJv+2kmF/Ws6jSlZHdTwtSceZ+6u70PtL4Z/s4fEXSdHkS+07TbBZ3Escl5q
sIUg4GcqWGMc9a0vGX7P3h7V5tI0fxr8Q9N06Nm+3lNLtzNsKAhVMm/qctxs/hrL2EqlZ1NgXsKS
s5c77LT8WOg+Af7PuktCkdzrvifUGUSPa3UpQOhBwUaIR85A4J7EV6HpVx8J/BeoQJoPw2s5mhBK
vqCJMy46YZl3gj/e6V6CouWstSJYqfw04qK8t/vOhT4zeKLjH9h6Pb2tsx3JHZ2m4IuOoJBI5Iqz
J/wsHxlM0NzFqEk8nKrMWCIMDI5wB6+1dChGJzcspPmk/vJ7f4Oa+q/vZrXTwpIcyzDjrxgd6t2/
wZ0ZrmJtS8RySSkg7LKIt1O3HXA6j8M0X10LSil3NR/ht8O9DJL297fs3I+03G0NhSeg57VbtdQ0
PQkSTS/DumwHPEkkIkbrjgtmueUrvU6IuVvd0Gar8RtbZilteNZ2wyAkAEYxn0X/AD1rjtY1jX76
Ga3iuWKTZR5y4LAHPzEHqfp61VKUYu7MqlKTRyd5pt2NHEFlbXU11DIVPntw8fJyCeM5x371lTeH
ry3s2jmW2KeUQXjBG1chiMjGTn15PPrXpRd0cclZmRa280Fnbh2jWJnK+TjCNznkHGM8V1vhu8Fr
5Ml0kmZGLSeWu7HdR/nn60kraieugzUtPgvL6S4W383a7GLerL5cmR83POccfnWbqWm3K3Fqqr++
eUu8zHjYW6D6Anjjrmi93ZD6amvong9dWunsZmkhDbmmkeVUitLdCredKx4CnIGfoMEmtnU/jFZe
ExFbeEbeObULeI2//CRXNuok25yVt4jkRofU5Y98cV5mLqOK9nF7/kd1KSpw9o+u39f1+J5prHir
UfEF5Jeajez3lzIctJcSF2P4n+VZT3J3dc15600Ryyk5u8iIzfjTPOPByc+1XcxElm+0RGKTEsTd
UcZBwcj9QKv6L4y1PwsrRg/bbJiqeS6jMMZwr7cf7IJx613UcRKnLUzcbrlPSrOWw0/QzqVkzXNp
Oga3fnAkPCrnvuYqMds12Enh8XmgyWtxIbmZ4GB3YOGK8gegJr3KlmrmdKTUkz58/Z1v38I/tNeE
BKcwPfy6dJGTwwmR4R/48ymu38Q+GrXw34q1S2js4I5ba4kgJWMDO1iuf061wYduF7Pt+p2Y/WEW
jkPEnhj+2CzQeTGx/hdSc/j/APWrzXxB4T17T1ciyZ4F/itRvP6c/pXr0q0ZO0zwnF2908v1rUZ4
2KBJFYHB8wEGqumabc3cM0jFssCUY+o5r0ozdzz5U9LGSsl9bszOu5Adu7FbdnrivY/Y53/ds24B
gflb1qZVbtpijDlSkUvJjkkHlyI3qQ1aNjocd1J5TOqEjOS4Aq/aqPqTyOXoVdQ0+OxjYoQ5B2kB
hkVmW+2O4SUxlWBzXRGWlzCSs7Hp/jrS7bUNO0zUrBMh7ZBJxjLAc/j/AIVwqzGOZF2jmtNopMcr
Sd0PuNVM2nvakfKW5B70Vpy9UYxnKx6ArfdzxUqk8Yr8A0tofpC8x4PbtSN91qrS6BLUpXiho2yO
K5XUFIfI7UCQWsIkX+VblpYptGBmtLk+Zu2Nmu31q/HbgYwOaLBqWI4wvFWYlHUjBppdA62LEeMA
HFcT8bJrq3+Guq/ZYFnV0EdxkZKRMcFgPbI+gye1VHdAt7HxnazyaffJLGcPE2RXremzw6rYwzDp
Iu7Pp6j86+nwclK8WY1FtI9Y1q98L+LfhDFoH2ifR7yFE824a6IWRgQPuHdlCSDgYx17V5nY6Xr3
giQW1j4wgu7ZhmNrS7OI8Z4zxivbqUaSl7XDz5G90cMajacK0b/IyPG1rd62HkvL59Tu5o1Vrlpf
MIAPC5P+eaxfBOjzaXdXkU4UBkDKc+hx/WvKdOSq3udSlFxstDVk0O9jmcfZRKjfdIbGR+Vcivw9
1eS9LC3Cruzu3DA5qJUpSeiNFKKW5v8AjLwXda3c280BX5E2FWOO+c1Z1rwXNq2kafawMoltkCEs
cA8AE/mK2dFycvMjmSSuaEvgOW48G2+k+dGJoX3+Y2duck/1rb8N/C3UdQ8Fz+HbWOW+nvZdyNaR
NJlsrgLgc/dH51MlCm7zl0sdFOjUrK8Ivf5HefD39kfxlb+HdWsbq0itYL6MCSe5uI4vLUqQMoWL
jgk/d7Vp+Af2QNN0e+uba++IWlyXUuYpItLtJLnYoOM5cxD16E/1rCMpS5fZrY39nQp8yqyu30X+
Zu2H7N/w48B7JYo/E2r6k7eWZfPghhRCAd7Iqudpx0DZ966XxF4I8J+Br7T08KfDzQp820Tz32oR
tePK7HLkrIxTGAcYA5PSqjhptWky/rcYP91FL8X97NX/AISzxSp2aDYQ6QsSbRHpVmtohBJIBVcc
YbHPbFbHgvwP8TNYiD3qapIM7IpXLIM4GDubhhj17nNddOiovRHJKUqnvVHf1NrUvgV4umk2Xurm
O1uGVYka7DeU4IG4hSRjGM+lV7L9m+w09b24n8ZNb6jKVUW8duwUbskfPuOMNnjvj3rVRVk3uTzR
V0tUen/D34I+BrWFrlINS8RXsEyxyyzXQ8lo0JX/AGWHOcZPcetelLrvg3Q7kWEPhSyt77aD5jjz
UlTbzhjzkE9D155qW3oohKcvQj0nxrcf2lM1lLZwwRybIovKCYwSdoxzkhe/60N4pvNUaad7idJU
A3KuVK/w/N7ciqtdmfmU3upLreLi4UIgEjNjhztx9c1BaXD3GnzXavDYaZb8S6peOEt0xn5QerMM
fdUE81zVpKmzpoxdReRw998ZvB9rqjadpGmav8Qte24jtLJGijOT2RMuR7lhnHQVDcfG7WtJh3ao
fBvw7ZRk22oXEEl0mOMMiebLn1yBXlucnqevGjaKcnbyW/8AX3Ia37VkZjBHxM8GTbm4X+y78qOO
nEWP0q1Y/tBHW5Ni2/w/8XBiFEem6otneMSOyTLEzHg8A0oynGxLo0vsykvxXzs2aifEjwNc366b
q6av8PNYkwyW2tQMYJO42OeSP9oFhWvr3hvUbGOG6DJc2EuDDcQyeZbSjORgjj3wea9WjVa3PMrU
Xe0lr0ts/Q8/17w7B5caeWziN2dVA4GAMNnH0/Kq/wBmYRyGZlCtsCAAKMqMdMDrg/pXp3utDg+H
cg055b1bzNpNbGFwVunAWNlHcDPXPGOuDXSafpX265s7K+t5opXmSGIRbm8xtzDBYHaBnJyccc9B
S+DVlJczsjlPiF4ytrhW0HQXH9iQuGnu4xtOozKMec3+wCPkXoBz1PHA56HOK+fnJzk2+ptUld2W
yFLHA54pm7p2qEc4Z/KmdKaFuJjv+FOGW+lWvMl36Gp4Z8Tx+DzNHcW6z6PdTxyXK4yYipyJFGM8
dSB9etfQui6hA3kzRst3ZyYZZozwVIyCPXivcwtRzp8r6GUviufLfxHuJPBPxk/tWKHypLPUIdRi
VenyOrr+q/rXvP7QflaP8VtaGD5Vy0d3G69GWRFbI/Et+VZKXs27+f5o7sUueirep55HfQzEbXXP
pUmeevFaxkpao8OzRn6p4f0zXIyl/YwXY6DzEBI+h6iufb4Y6TDJC1nvtUjYnyfvoc9Rzz+tdFOt
Knp0E0pbnmfi74Ma3b2IOmiO9ZZCxWJgrEY44OOfpmvJ9Ri1TR7zyNQ0+ezbptmiKE/mOa7PaRrO
8dzJUuVJozZLyITBPu89RUzXD7d8DE7euTWkKmtmZSpkVvqUkk2JTu9a6mD7NceVuZcN09q9NbI8
12TbZ3/24Q+G7TTImWXyssCTzz2FcDqlm1neF8EA9BXUvf8AUzk+WPkVJmE8Jb5UZfzNFOScHYmF
pq6PRU6YqYdznmvwHZH6RrcfwOnSlY++eM9KeoeTKd10JxXM3qlmOT3wKA62JNPjGf6V0lmAIxnH
4U49ED2NqzXCj09aurjkkY5rQnUlVRUir0P509xEqc8daZc2sV9bS29xGJoJUaOSNuQykYIP50ID
w74ifs26VHol7qHh1rqO+gjaRbV38xJAOSoyM5xnHPWvHfAur/vDZSPkNynPtyK9jB1LyVwl7yZ3
U1wzKIm5jGQKp22lxZZTIzZ9MV7rld6nMonpvgD4Vaf4o0l7u5vLmBkmMYWPb0ABzyPeuI+Kmjwf
D34haVpto7T2l3aq7tPjcGMjKcEY/uivN+sy9v7NLQvlXLc7/wADWfhu/sEjvknu7+Sby4obUMxP
AAzjgcnucV6Fc/COGzeESaDBaCWXyj9q1MSMh7hktjMUP+y+0/rgqVMQ6zhTOmlSjKnzyaSX3/16
2ItS+EOkad4Zh1XUpre2lugGitbHc0irz8zM7HH08sn1ArOs/Dngo3Sw2WlT3joVZ5NSuZZFPJBA
8nyuOmOK6I061vemHPTi7Rjf1/q35nqGgeLPBPh/SobmDQ9J0+/2GLEdggk3nBDF1XzM8cDdnBI5
qjqWua7441ZIodR1K92n/R5Tb5GwEZQsfYrgD3zXJXw85yShselhcUledVXfQ17vwD4s1jRY31K8
trea4YI6SXKvIV7KACTwBwMcA03wL8G7Zb6S0ufEcSs0x8hYIXSVGIzw2BuPt0r08LTcKSUjzMVO
EqzlDY7/AEP4Y+H9QtLaeaa9aQoFaGYBMODhvXjOQPX8a3tN8K6dHp4efQ4vOQttny8nyhztLZGA
SOoFXJtSTWxEbcrWzNuztbpIjJbSQ2SMAWWGEL8ox6fjWxa6xqG23jecXH7xcRu2NqMQSD6kDv61
bu1uY+7e7KGv6pLHq7WkUItrIE+UkTqqk8bizdMkHt61z+pab5N0YNPSNFuW+WSPDosibWVSfoSe
R2FX0J1vubPh20u7fwqLDVDHHNdN5k14hKM65VgM55J2gfnwazdS0mfTfEUvkbZ4iiqSgLNCOMbB
ng4x+OTSW42bVlpcMI32sOJlkGZJCdyjpnP4/Xj2puseINL8OQztO7QKqgXAnf7yjuWzx9c9qynU
UFc0jBzdkctf+N7HSfCZ8VeKt9j4ZmJfStGEhW61bHSSQ8GODsMcv7Dr5v4w1bUvE9jBr/xHvbrS
PD5RW0zwjpeIJpITym/AxbwkdMguw5A/irzta07HtRjHDw5n0/P/AIH9bnmOp+NPEvjC1uNJ8OwR
+FvCrEqLDRVMEcq5wGlkzvmPu7HrXP2/wPN43765bc3JXbwOemc11KCWi3OOdVyu5Fi/+C1nbxhD
PIjdM9c/SuS1b4MywOTb3nAO7bIOw6VLhLqZc0b3tYNJ8deNvAVu1g90NT0DOW0fVEF3ZuB6I33D
/tIVPvX0N8Afj4GuhZ+HJ2smmGLrwTqknnwXa9zaSNyWxn923z+jP0ojJfCzTWzjLbf/AIP+Z9Hx
2uleONBk1zw5uNrF/wAf2m3AzcWbYwRzyU/Ud/bitV0GMRhgZVjZucD8sH8QOlddOTjeLOSpHm96
xvWtulzDHuRSFO4xsgx2PTFZHxa1MeBPDjJZXe2/1iNrNIEGDBAFQzs3PVgyIOPuvJ36Fepam2Z0
1ys8EW+PepVuYmXBJFeGpvqJrQVXRgMHNKy571pe5FtBGWjkAH86ogTGef6ULkHjpVIXTQXaCpU4
Ixgj+leufs363F9puvDN80k6WiGazUNg+S2QV5H8B/IYruwcnGdu5Mtjzv8AbC8OvpHjLT57eLyo
JbVVBJzuZSQx9evavQfivdN4m8C/DDxU2TJqPh2G3mb1mgJRz+bVtU1k/wCvM7pJOhp2R5TIcZxx
zzUkd5LHja7Y9K44ycdUeU4qW5bh1p14dM+uKuRatA467D/tCuuFbpIwlC2qLUcyyKSrA1HdWtvf
QmK4giuIm4KSoGU/ga6VLqjLVHCa/wDAvwjr25vsLafOf+Wlk2wf98nK/pXnOtfs26pp7NJouqQ3
keOYblTEx9sjIP6V1RrXVpjSV0zgfEfw717w6pkvNLuYgDzIF3J/30Misy1ZI2jk3HaOor2MLUco
bnnYqlySuX4dYksriRkYsmflrSh8b2t/b+VexiRl+6yj5h/jXdvqnqckVbpoylZwi91GEIVaJ24H
cfWitZSlKzHTjGF4noyfKevGKkRufTmvwK2h+gPck3DPPencEc9KadmBWnXKkVzmpId5B6jgU1vY
T0DTW+bH5V0djny8VS3Gzas+gxnFXlyoIPStFYklX7uKfyCMd6BEin5hUitg5zVC1K+trdS6PepY
MI74wOLdm6CTadufxxXwtr1vqeg+JJX1C1ksL/zPNeJ4/LwSc5AAAx9OPSuzDStdDsehaXqUerWU
cynG5ex5B6EVZhj8hi5PQ+tfTqzimjk1u0eofCf4neFfDWi3tprWs/Y71rgvHCIjIWBVR2PqK8y/
aE8VaZ4r8U6NqOlTtNHbweTJ5iFDneWGM+xrzq1Gmp+0hK76mkJTk7NWR0f7H/w3k+KXxi0vw2t4
Y4b6dTPJuwfLyC+Cf4toOPev0X+JX7NOv6fZy6doutzDw/ooWPZc4DtG2SrfKBuI3EZ46+1deHko
Rdt3/wABHZVjGVOCfm/8jxW6+G7m4C3tzJM0Q27F2/NyORg9MDGDg1Q0Hwb4YguPns2UXDgDzJiw
fByWILALjn9KUajjTTktSnTi6rUHpv8AIQaxZRSTRadpi2McDlFmjt1/eLzudmAzwox35xWxosia
rskH2qHYFVzyI92GB47YGOvrWybkYS93coa5Z3cd/JNO5t72Not8kmWMijAHupxjn3rqV1RNN8P3
WpTC3tnvMAm4kVSh5557YI79quL5UZyfNY0dD+MHhTR7OC3vby61WGZt2/T4HmMRADDlQeM8de1a
OjftFaNpsjRPpuqtDI2zebViAm0ckE56/j7VxyxVKOjZfs5PyKOkfH74fa0yx2HjeB7qS5kH2O8k
EUtvgY2fMeRkdhnJOTW/DqkFqxnfdeCRi2CCrleokz0x7D0rehJctk7k1W5S2sdnq2kxX3h+2ubX
JVpPmV1+gxnORncefb8Kwo2tbu/srbYsdrcYaNcD5F27ed3UgFj0zkjvXSpJ6GLVtTprPRIzbqt2
GSeIMC3CeYPu/icAflU83laIs9zCsQS6ZFRpCBnPb9cD6VlKSgrvY1jF1HyrcZqUkWn6PFcq5Dby
QshAPTp9OwrxaxmsPiBr2ueJ9eQDwJ4YZWugpOdVus/ubbPddwBPoFz6Vw1p2PQwsHzOXY5lvEFz
4n1K4+J3i+BLt5JmXQNEkUfZ8IdonZf+eUZARF6M4PUKayNQ0u+8XXkmq+JJ2u1mkadbeRss7EY3
O3etsPHlgm92GKn7/Ktomvo39n3F4toQsYjxu28AAnsP6V6bpGhnVr1Lqw0+3fSoGNn57ssYkYRb
yz4BI+VGbIGeSMmupLWxwXfU47xRZrb6xPp91HGt5bhEPl8q3yghh65GD+NW9e+DeqPbyB1s5WQM
reXLyHXcDHzjcwKtwPQ1NilY8vv/AAKqh7cxNMh5CBMnGMmvLPF3w1n8Oumo2O7ZncGjOGjOcg5H
TH9K56keZcyN6bs+VnvX7Nfx5v8AxBrUUVzdt/wmVrGScnA1q3X7ysP+e6qM5H+sA/vDn6c8U6LZ
6tp9t4h0tdulXZJManJtpMZK/Q847ZH0roi+aCl8v8jJ6S5f6/roVNLjja0YSlTcOoKk5+9yMZ9+
OteCfGm+luPHl3aSPvGnRpZg5/jA3yj6iV5F+iisMVL90kY21bOBP5GmbsY9q8ZCHqxVgegqRZ3i
OM/nVp2CxKt8205GRUgvEZeeK0U+5HKSeYjKcH6U7aPWtUyNhTnI7103wx1Z9B+JHhy9RI33XK2k
glOFKS/JzyOjFG6/w1vRbjNMiW1j0T9tjwqsfhvwrqTFpmBaCR2PRj82P1rntJ83Uv2TfCxdSZND
1y6sAx5/dygzg/mQPwrsk7yf9eR6P/LnTt/mebv96mewFcm+x5F+4lHTPakC7DhK6H5WI71Zj1Sa
PAJ3CtYzlHYzlFMuQ6srffG0+1W47yKRflcZ9O9dkKsZGLi42JCFbHtXN698OvDniPf9s0uDzH6y
wjy3+uVxn8c11U6kqcuaDIltZ7Hn+r/s6WzKzaVqskQ7Q3Sbh9Nw5/SvPNa+B/iLR5DJ9ia6iB/1
lofMGPp1/SvXo4yMrKejOKdDdw+4s2Phv+y7aGSWGaOUnIyvJor2qcuaN7nmVqfLKzRej1YsAMCr
UeqL0Iwc1+CdD9F6k39oL9D2qSLUF6N0pavUCOW+TnBHQ1gahfR+Y2Tz9au1hLch0+6VpRhgPaut
01gVwDjn8qUXZlPXU2rP5gOnpV5WwAD1rQmw5W69805WCr9KpE+Y5ZB+FPWZRnJGKV0MUXMfUsK+
dv2kPBupapr1trVlaS3lp9mWKRoFLlGVmPIHIGCOenFa0pWkilueUeEdYbT7hrWUlVY8Z7Gusurx
vLbYccZH1r6WjLmpnPOLUjj5dIl1i1cw20s0q53PGhJB9yKkuLWa70a3D/8AHwmM7uvFZyjqy10Z
7X4MaT4V2HgbXdMnks9UhvBNPdRnaw8wBhz/ALOwfr61+yM3i6TX/Bdv5Uq3yXGm+dLeRx/69/JD
bxtOOo9sdKeFj7SLk+jLqS9yK9T451y4BuGhuJkJlOC3UZIIGPxI5rzzUNQvbLU7ezjtnuNNlhO/
YSVDEgbk445xz9a9CRMNXuFvqH/CO3y2927vZFvs/mMTuCgD5cYxnHOfbmvpJPg7bHwPDq2m3Km5
8tbhnkO4Hu7D04yfwovpcU/PqfGfxo/ag0L4c61c6V4c8nxNre0w3N1MfMhiYH+9nDMMVqeEWTxF
4e0fWtST7bqF3aRTtLcEvsZkDEID90ZPQV4+NrNx5YPQULx16nTLMNoHT0FHnA9+DXilHyz8U/gD
4p1Pxtq2oaFYx3VhdzfaFP2iOMhmALjDMP4i34Vc+HOk/Hf4ZXiS+H5rqyQIY/Ikv4JItp6jYzkD
6jB969CnWUUrPU0aT3eh9o/Cv43apqvhlrD4iaVDol8pTbqFlN56uAWLbwMlOT2LDr0r2TRbGwuU
iv1lWUOqywTIQdyHkHrgDHTHHtXs0K8akboxnHXR3RsTawt5cYnWNY5GG1R1GDwf5flXHfF7Ur+D
w/YJpsMsuoT3SwQPHjZ5hVgvmZBwvX8hWWJjz02l1O3BPkrxb6HnfxS8eajo3gX7Gl095rN9cfYx
hizJJ0lAJAJAyMcdCKk8ceFpre58FfBXTbkWNjpcX9o+I7mMYxcOnm3Dkjr5UXArip80oqM/Q9Xl
jCTlHbV/d/w5j22l3nj7xXfzNYy29jZsIrPTo8uttbxoFiQdfuqASe7Enqa7HwTHo2ueIFsNTt5p
munhtrVUcqA7SojE47hWZh2yBmvctaSj2PAlLTmNv4kaHa6h4VXWLC2hhiszHiS3hVB5LERMhwOW
SZD152zCr/wo8YWFv4bi0e5sbya5S5+0xfZk3eeWZEZQApJIj3sfYGn1ZnZtHFeMcXviy11C0Wa9
tY7azaW52FPOKosW8BucEpjnvXqGofEDS5FvLu8iuraUie4juZLFgsu1rhdi7QeU86NCx9zmobL5
XsjK+Hel2GuWt5dQOss0f7plGY2iBBJY9SoAU847ivNfjV4dg03UGlhhRYbiaRGSPtt++ff5y6j/
AHKF2YXPlvX9Ju/Bfii11nTLiSyuIphPBcQna0cikEEH8q/TL9nHXbb4xfDFtWtooxYahGYtQtY8
D7HepjftXsDkSL6fKO1YU5KnGcX/AF2Nq32ai7mZaaZJb+JE0qYbZ1vEhcDoCG2nHsf8K+YPHl4d
S8beIrsnd9o1K5n/AAaZmH86xxLvCJlJWT9f8zn9vHNJtx+VeX6GQmMseelK3OD+FPcBp/Ciq6gK
Mqo55qRbhl6HFV6EepNHeNwDipmviI3ZCVkUbkb0I5B/PFbwnqrkOOqZ9T/tWW8Gr/AW01O2f7Qy
NFcqByQrAEnH4ivJfhZeJqn7Mvjq1fIk0/U7K6TH+2wj/LGa75N8/wDXc7Yr9ymecSZ6npUZ9jXM
eVYTcOfrQMEVW4rB+PNJjHemSKDjpSbvSnsLpYsRXssZ+WQ49DVqPV2H3l3euK3hUcdzNxTbZbj1
KKTq+0471OsisOGyPrXTGaktDKzW5DdWNrf4FxbxygdC6gkfj2orojWqQVoyIcVLdHzQsfSp1j7M
M5r82uz6Zkix5HXn3pPnB71QiGZm24/WuX1q4cM2Rj3qlqLYxoNVkhbIkIINdLpPjR4WAZxj/aol
G+xR0Vr48WM5cLgf3TWgvxAhZRzzUu6BIcfHEDdHG7qOcU0+MkYYEny/WmrhYb/wljPyH+mKYfFD
tnDe4pcrvYBP+Ekc5+c/nSf29IwxnIzjrVJOO4eZzXiLw3ovifc97Zx+e3C3EQCyg+u4dfxzXFXn
gO9ssrbTLdwg4XedsmPfsfrXpYbEey9x7EPXcz4fDWsWcj+TbyRl+DsYAH9aih8E6xNcRBoPLhJG
9mdeBnnvXoSxFO10xJcp6L4th+2eHpYQdvlbXTHbaR/TNfpb+yzq48QfA/wXqUKAowazuxGwZVIA
Hze5UjORWmWSVpxfUUot0k+zPnr4seKrTwz8QNT0rV4ZLSOH5ElWP7wY8hfUY/iHOQR2Nebz/EDS
GjvYrbVbh4bVgbGRchhuIJ7DdggDGeOa7pVFojSMGS6dqFxJIkktqt4Y4FlZlcMWRjln3f3j05Oe
cV598cv2r/EFrBL8MPDOrXVpptvLJFqFzHcbmZiSWt0ZSfkUlhkHnp06xUlyxsuoSSTTfQ+TtPUN
q8gYZ4Jr7j+Gsgb4e+HfawhH5IK8bEfAvUy63OjaQLnuKjM3AHQGvOuX1I/tXzdef0povtp696oQ
n9pBcgketdT8O/iGPCerQxXUztokrjzocbvKJP30HbnqB1yT169WHqOnNPoPyPoeG6tbqGCZJPOy
A0UwbIK/wkeuRzmmalqUixhFHGTtcdc8/wD16997AvI8a8Jxjx9+1Z4X0q++bStEzfTBiCu2JPPb
P/fKj8KvW+uPqXh/x74zkZk1HVrlbRZdmWBnkaeQD6JAE+klcVFOVeC8z2Ze5hpNdl+LNbwb4mh8
H/Y1v5HSK6Gya6iP7yE9VlA7kNg46EAir2tab/ZPjTS9a0KW18pzFfS3MWXs4JRLtfY3G5AxRjt+
6HAPSvW5uZnhW6dDZktxqmhSSXjtGsM0cl5ZogigS3cG3lIhXCh4JgTuxuxtJJrFj8UP4Puob2Zo
Yr2yltriSNzkK8Be2mTA55Xa59cGh2Q90yOS9gtbG3e53JHPDGluyocbFvFkHv8A6ti3PPOK3NW1
DTrx7XQ7if7Nc+R9lljmjZPKebUEmfJI/wCeSgn/AHq56MuaCb31/M9fNKUKGKapqytFr5xTLukf
2fdWOr63dwxrIqz3ADjaYrm6mKIh90WLdjturz3xpfSapNE09y97MqlTJIei5PH5kn8TWttTym+h
45460f8AtKxmtGUB1Xcox0+lezf8EzviN/YvjbW/BtxNiDVoPtMEbdBcRdQPcoWz/uCuepHVrujZ
a07dj6s+JFgdP8e6ROscUStNHI8hO0nY4HYHJ2hPzr4q8dae2leNfENm4Ia21G5h/wC+ZWUfyrlr
O9OJEtY39Dn2H+fxpD2HSuDcwE29QaXaSpA+tUvIBNtJtBWmIXb0ApOlCYvMQdc9DUm3ch9cVa3A
+qPi1G9n+zNZQTrh/wCy7RW+XnIWMYzXjfwbxb/Bf4qySD5PI0/aT03G6AH869ifx/13Oinf2S9f
8jgGvD35py3i55/WvPUzz+UesqMOT+tPz9MVafYzfmN564zRnvVdSegnOeO1OyN1WTsN4zTtx6UA
KCelOSVlPysR+NVzNCtcsR6lIow3zUVr7QXJfY8AjUrwD/WrCD5sYr4Xc9y1iRV2/XqPUUH5hyOK
qPdjKtwMk5xXK64vzNxVrcixyzg7mHeq8auWOCSfStUWWwLlVO3OO1LJJNHn5icjrRYm5WbUJFY5
LY7UjaxIv8XXtVuIW5h8fiCVWOJGx+lW4fFEwwN2RjpT5ddRWL0HinP3hz7VoW/iOE4BO3vS5ehL
bRch1KKb/lp9OasCYHo3Pbml5MV9Bdzblz61IJPxFPdDuwuoxcW0sfZlKn2r6n/ZR8YXU37PMWma
d4hOh6hpXiGUSwQ4866SWIbEXcCv3lOS3HT2rqw7aTs+35noYTlbamr/ANWOK+Ml74h8XeB/EM/j
HSfL1+3k8y0uJkFvOV3ZDbcY6BunXJ71474H8QC/vxNqEdnZpEfNmnvgCkrAAfd4JJJGevJruptz
lGUjtrKFHnjDVdP+AQfFf4mJ4a8Hy3OjCG0vtU/cK0DZ8sKSHcA/d42gcdSTnK18qaSzPqyZOSWr
qqyvNW6Hgyvd3LdlldecEYPzAivs34Z6iI/AOhKzZK2qjrntXn4n4F6iR0D6qFORz+NV31YbuD7Y
rzfMtFeTVBjOahbUixyevtVoRH9uPB7H0pn2w9zWsV1JPY/gj49lmz4Zuf3hAaSxdnxjGS0Xv3Yf
8CHpXsestI0Hl5YPsA3Dpx2r3Kcueki47ninwJvy3xQ+MWqjBm03wvqsqNjo2PLU/lXQ/Duzk1T4
R+Hyd0iza1qFxI3UEQxWyKPbBdhx6mqwMeatF+TPUxXu4dr0MPxZdB75IN+VhQZXGBkgE/0rrfhb
4yt54JPCN7LDLJIkt3pkMjrkTCNt8OGYApKm5CvvxzXUpcup5VuZlKTxZNrGi37W13JZyQHEkIkH
762kCRsWYYLt8kQbs33sDnMHjDVDr+l6TagSXN5a2bRTbEVlK5JTBUk8LgEEDkE85p3uNb6Enhk3
Wv8Aw70We1tx9qtrtoBAg+YkrGF2oeWJKk4Gepq/rGrX0Hjhda1m2xetKtxLDGRGdwwB67WyoJBH
X61hQ2fq/wAz3M41qwfVwh/6SjBvtUN9q13PEot0ublpvIjPyrliQB9M4FR324RuZPnLcD6+tdHQ
8HqctrbRw+TuZ2mdtuNnAXHWub/Zh1hPB/7VHhJoGYLNq4t5Afu4mzFx/wB91hU+KL7nRSV4yR+j
/wARNSHiPw7oGsIBG8jYJiOdrMGBwf8AtlXyx+0RoosPiZfXsS4tdWii1KLv/rF/ec/9dVkrmrR5
YW7MjeFvL9f+CeYtH+dMde2OK8+xgIV56ZFCrt560CDjn0oK+3emAm3Pam7fQ0CHbNxH9K1vDvh2
58Sa1ZaXaRs9xeTJBGoGeWOK1p6ySJd+h9Oftb28fhv4X21t5jAXc6RRqw5CAA8HHTAFeJ+DWOj/
ALOvjBycLquq6fYqc8nyzJOR/wCOL+des3zLn8v1OmPu00jzR81H/F7V5BxibjgEUqXDrkBqpaEP
UnF6Rz1qRbtG68c9a0jLuZ8r6EodW6HvTvetk77EMTnOO9LkfjVkik9OR+FH40+gCfrRUlKL6HiE
f3hU6rjOeDXxq7Hs9Ryr7jmnbTtJPXFO+lhXuQXGG5Arl/EELbW/xq9ib6nHzZVm54Paobe4EcuS
OPet0PU2LXUItvRQe+aW8uYpYwcjNJ7k7GJcFNx5rOmxkgVrAexGFHB5zS7fzq+pbWhMrNx6VLHK
ykenWn1IaVi0t2yYAP8AnFWotUmVcbunQ0kluRpYvQ+IJVXJJbFaEXiFTyy+5qA2L8esQTDhsV3f
7OE2mxeNtfgu4xLdbY7nTd2NonMyqAc9vm/xrqwsVOrGJ2YWo6Tk/I99/a+8Arp+leH7rVp1N3fW
SxSXEgO7z4nLNlugBWRFzjtnFfJcdvf+LNY0iBoS8LssWYY9xeQ8gYGCzHge/Fe1Wjaq+UdG9SEV
HfoeUfFjVBfeJ9atUZHttOm+wxNESUYRsVZlyAcM+9hnnDAV55pbbdUjI67q5pPmldHHK/M7ly3O
PEPuSa+oPh/qDjwbpKlsbYcfkxxXJifg+ZKdtToDet0JOaYtyTnJxXn7grtDhOeMnI7U7zstx1qk
LrYFk4APFLv2jGfcZrRdwbLmn31xp95Bd2kvk3MMiyRSf3WByD+dfYEevf8ACTeE7S+tguL6GObk
/c6bh06gg16mDleLiOJ4H+zHcC4+KXxw0mXPm3fhjVEXHO7bIG4/Cvoj9i/wNB8QPglcQmXa+lav
fxqrfePmxwMv05WtsLU9i+fsn+Z62LXNTa8zwzxRC8OtXCupUkjIbr0FY8lnEtz9pSBVueF89Rhz
6DPWu62h5eqdiDU9Wt9Fs5Lm6IijQYL4JJzjA/OtDwb4ydVvJtOkcBlNvNuj4dTglefXHPfrQrsn
Y6zw74yurrwX4hlDrb3kOoIzNCxj/dnfu6c9Sv4YHSuT8QeN2hvpbbZLNcRzLC+9QwGeS+7IPTjn
P4VhR1lJef8Ake/mkWo0J96cfwuv0NiFhNJGYyHBPDL/ABfSte8tHtdouI2DEZ+bjA+ldaPA6nJe
L5YFjtljwszPkN7fnXHfCfS5Lr9qPww0TECPXrSQ+4WVWP6A1zVt4ep24fXm9D9GvAuny618J/Dk
Uyu0/mGU7uSBum4/8e/WuV/ae+Fb3Hw/0vW7aP8A0jR2MVwqr/ywkIwf+Avj/v4xqMQ1eUfNnOtb
LufJr2u2oGj+bp26ivLsYjGjJ56VH5ZGBUiDYdo96CpOO5pgIV3daBGT25phYljh6V9H/se/D9tX
8YT+I7iPNrpUZERYcGdwQPyXcfbK1tDqwRX/AG4fGEOseJNL8P25WX+zY2llwf8Alq+Pl/AY/OvO
/iDAfCfww8BeFmGy6mil1++j77piEgz7iNH/AO+hXf8ADRuayeiR5e/zVGemeleYcu4zANJVJkie
xp315pC8hQ3SniZk6Hj0q4toh+ZIt4e4z9KlF0pIB4rdSM+Uk3KV+U0v0rVCFDfNk0UrXBStoeJR
4+hqVWB618bqe0rLcd5i9uQDS+Z15/CmIhmkXYScZrG1WMSxnjHeriu5Jw19CUOAOe9ZNwDuBrcF
ewizN0BpGunXjJq0lcbImmZm9R7U3a7cgEk1a0ActvI3RakS3kXBxj+tK9xXF8vbjjkHFSKp6H8v
Sq5r7CJPvYBFKqhuORx2pCWgpXBGOnQ81JsK9f4elHM7pC6Eqsy47j8q6/4R3cFr8TtHFyWW3uiY
XwATz06++K6sK7V4PzNafxW8j9IP2rvClpqvwj0e9CG6dGCRzFiS4dPm6/8AXNTzivlj9mHwnJo/
xOvvFSxTQad4X0u912SOQFQzwQO0eRk9GK4617eIbvKa8/yOvLknOMWfBN7cPeR380zF5pJN7u3c
k5JrF02Ty9SQ4B+bvXB8KijgqS55uT6suL8viAdvmr6N8BTAeEdNHojdP941jiPg+ZkdCtwdtOjm
boRn0rz4xVi2yXfyMetSI+5g2c5qhWRKM5OaenzADqvamiTRtoR685r6R+B8r6h8PJbWNg0lldzH
DY+WMornr1GWf8a9DCSSm15FxVzyP4L30PgP9uq3tb79zpPiB5tOYvwrrdQlR37uRX0/+whqT+Cv
iB8QPh5eDZcRyG5QMMZeFzFJj1yGQ/hW8dU15P8AO56tZXpP5HCftLeGP+EV+I2roF2xtKZIx22v
864+gbH4GvN9HszqkM9vEA1wQJEJbGcA5UfXP6V6EW5RTPOl8TZheIvDE2s6b5cpmtvmDRzBT8rD
kGpfC/huPQrdk80TySHc7LGIweMfdBrRPoRY6jwPYS3E3imwt497yRCVBtyc5Xmo7zw1aXVwktxa
q1yI1V2YZ5Cjg9jXNSuqs1/WyPex8ubB4SX91r7pSLduhsrpHCiRkOQrDg06/wBVmupt053tjB4w
APTFdfQ+eOd1K0OpaxaKyD7PCd8hzjCjn+nP/wBeqPwZjhPxM1rxIGIj0exuroMvIMzr5EPP/XWZ
K55+9VhE76GkJyP05+EGltpvgHRY5Y9sn2dXw3Vdw3ke2CxH4V1uoafb6rY3FldxLPa3EbRSxt0Z
WGCD+FefWlzVJPzOFNxaa6Hwp8aPg/c/DnxFNEiNLpc5L2twe6/3T/tDofz715dcWnlseM5qJR6o
0mrPTZlRoc8Ywc1H9n/U1nYyF+y5yKb5B9KYB5HzdOaetqW6DmgRraB4bvNe1O2sbG2e5u7hwkcU
YyWJr7x02LS/2ffg/H9pdf8AQoN8rf8APe4YZP5nj6D2reMfdS7sFufFHg7Spfi78VDqGszGPT/O
k1PU7h+Fit0y8hJ7fKMfU1z3xA8ZzfEDxdqevSxG3S7k/cW548iBQFij9iEVQcd81113aFv6/rQJ
tHMHvio+vtXmGIn6UnvTJ3QY+ak/i9qtEsO+aF70AxduM45oyadxWFDbehqRbhtuCc1abROliRbr
1GR6UVspi5TxJZvU4NP84n8K+P8AU9hrUXz+hzSfaOq570b6FO2hHJP29aqXEgKnJz2qkyJROW1q
22sSB1rnZFPQit0JooSMVYgUzdhhnOK3H0uW7corKDV6No8HI+mKTuQ97jhJHkgDnvmkaZeRgCkL
yK7SfN0/GjdnbmrtYpgPpinLx+IoI03JAd2Mc05fmx29aQdCRepHQVZ0vUpNE1zStSjIV7W5jlBZ
Qw4bPQ8Gt6b5Zp+ZdL40fr5rFsnjD9nVoPtH9peXarcx3SwhFIYBwMDoRjBA4r5i8JX8GmfD34zG
Er9sbwTqiD5SDgIAxB/z0r6CuvdmvJnTgbxqxa6M/MLzN1rd/gf1rHtj/pyH/arz30OEuOx/tpT3
3c17J4O1qa10K2TO5FDAD/gRP9ayr/CxdjpYfFCllWQYBOM9q1Ydft5Od+Oa4LBuaEF9DJjEg9wD
VtZA2Ohx0/KkmDLMbBsYJJq5bRlQD1zWita4ehrW6btu3ivcfgHJssddTZx5kDKSOMkPkfoK68L/
ABC47nlX7YmmXWjah4b8aaaWinsp0jaZD8ySKd6MfxDD8K9S8cfFh/CfjD4bftC6BH5mkeIo0bVY
Y+Qk6r5V5CR64yw9SM12RtGWu3+Z6tueCXdf1+CPW/j/AKxa/E64iv44oyEgRoLiA/JdWkg8yGUZ
9A+DjPU+lfP02iPaxgQTrCoHPAbvyPavVqU1RSjHqkzx6UnKPvb7GpDfGOyZ5reO6gJG/eh7cAbx
yMZq3D4UbUI5J9N8wNGm+WC6Rl2qckENjBHB9OlYfDsbW7mh4DgvLzU7JdIs1gvJykd1NdQqIdq+
YXDMx+YMDHgYGNh/Hp5vh7Pfa5JiT7LbsrOJJwcnDxqQAwXHMqYzxweazpy5qkn6HqYhP6rRi3/N
+f8AwTB8ZeF7fw9YxXFvqC38jkFjGm1EHpkEhsgr0PfjI5rjFffMHboetdS8jx3uc38VPE0fgvwn
cOpMOo6sTBbRsRu8sD5pcDoOgGfWvQf2Yfh299pfh7SrlD9s8RXEepXsZHzx2MW4RKfd2MkmP9iI
9xXNGX7xy7HdH3aFu5+k2loIbKJeBkZAHHHt/nvVuvLe5wPcxPGHhDTvG2hz6ZqUW+KQZRwPmjbs
y+9fGvxS+CGq+BLpi6G5smP7q6jHykeh9D7VpHVcptH348vVHllxpskZOV5quLNs/czUtWMRRasv
bH1qWbTyrbkG6PrkdqXKFh0Wnlv4fxrovC/gPUvFGpR2WmWUl3cPwEQZwPUnoB7nitYU+ZkH2J8K
vhHo3wg0N9TvnhOqmLddX0pAWFcZKIT0Hqep/SvmL9of4ySfE/xEulWLyLpFu5SCNF/1rZPzn3xW
8P3k+ZbbI0jZJtnM+ONST4c+Gv8AhA9OZX1q/jjuPEd2pBMKfejsVPrwGk/BecnHl8h6+lTipe8o
roYu5Cx4xUecDjtXGSLwe9J268UCE4Uf54obIx3FO73IcRDRzg4qkKWqF54o6k0yROeecYpT0FUC
8xNvPWilzM0T0PDVuPlGOlO+1bcnPevl/I9Rdxn2wNgg9c96Yb75uDmjyY+UY18T1x9Khe6HPPWn
ZAveKF5IsisrHPFcveKFY9s1tEz8zNuMbvpxVdjg810IvoSq/AqeOYqvXPNUyGKZSen5UvmHIPbN
A2Lu544qZW6DGKDOwJ+ea0tP0/7Z7UulybGhJ4dfbuC8GopNFkXqDjHpRe24Ir/Y5I8npVW+hY2c
hIPAqou7uXHSSZ+oX7BnjL/hYnwX1fT9QMl0bW0jhQkj92mwrgc5IUoD/wACOO9fPeh6lfN8ctR+
H8kPlprunaloDBxkMbm2kijPtiRlr6Z3qK3dfmjrw8VGu/I/OyWN7cXkMiFJEyrKwwQQeRWRA2Lt
T05rzuxwyXK2mW5mxqyHvkV6l4b3Po8HPr/M1hW+H5kmvgnANShmBHr2rjfQXQsRylW+UkHpxV+H
VLiEjDttHOKNbgkacPiCZTg8n+ddHpviIMiBxgnrVfDsI6ax1iB1XnpXvPwR2Q+G9RvC2FubgRR+
+1Vyfb75H5124HWo/QvUl+KHh+Dxx4Z1XQL4fLPGyibqwcHKv6cEZ614V+zR4jtpB4m+AXj24Fjp
2tzFtKu5/uWGpqMRsCeiSDCn1yOmTXZU0n6nqUZe56HoXwx8V6z4L1C5+DXi+M2WvaPNJHodzcth
ZEY5NoT3Vj80ZzzuK9xXQ3dpPfxzTBXs51+SWFxkbh/D9frXpQn7XDrvH8jzqlP2VdpbSKFnrsmm
2rW0qg7eNpX73NaGr+L57i+urkWtujXTtLskhAKBvNBVcdj5rEnqSBzWbWlw1K/hnxVd6l43bXJP
La30+4tobyC3hBmcSNu+QhcjCK3O4dAPQVL44XWfDuvXej6vqDXU6CN5QJi45QMoOe4DD+nHNK8e
ez3OmXO6MU3ortfOyf5IzNS+wW8Nktlem8mmi3Tr5TJ5TZ+7k/e/Co7q80vwfo517xBLt06Fjtty
uWu3APyIMjJz36DFOUuSLkznjHnkoo8q8Nabc/Gjxfd+NvFcElt4R01ljhtYzjz2GTFZxHuzYyzD
7q7m7AH9Df2d/hpf6av/AAkeuQrb63rCiRrVF2C1tQAETb2+VVUL/CAuPukVxx92m292d1X3fd7H
0dbyGYhsEAcD/wDVViuJ6HmMKgvrG31K1ktruCO4t5Bho5FBU/hRsCbTujxrxp+zHpOsO8+jT/YJ
G58iXLJ+B6j9a8w1D9mzxHZTFUsxcL2eJwwNdClGe+jN7xnrszE1D4Ga/aLl9JuT/uxE/wAqr2Pw
P8U38ypDol2A3G6SMxr+bYFaqMd7oycWeneDf2VJPkm1+8WBept7Y73+hboP1r1xR4S+D2iOsSQ2
C7c7FO6ec9vc/wAhWcp83uQ2ISPmL44fGvV/F11HpOJLDT5AWitbYF2dh03EdTz9P515frd5B8J/
KM/2TUPiJMu6109kEkOjIRkXNxzgzY+5Efu5DH0rupqNOHN0RTvFHm4nZmlmmnku7qeRpp7iY5km
kY5Z2PckkmmtMOTXlyblJtnMN3K2ef1pOo4PHeswvcaQPxpM9e1NE7BzmkbHTtQS7pagxPrzS/w8
1QXE3Gl9eKZN1cOv0o4+tUC3uIaKllfI+dvthbrkcUz7Ucda+a6Hq+Y37SfXvStdDnvSsVqNa4GT
zio5Lgdc4PpT6oroVpZg2euayr4eYrHFaxM3vcyXBY4wfpUTRntXRe7DZIl8vgHn8qaW21T1J0F3
npUkal8KKHoEl0JApXAPBpwb9KNkS9WCt82cV0vhptzEMaUloT1O3t4QY1P/ANerMmkxzRLhefas
JbAjAv8ASfLJ+XjtxWFd6f8Au3THUH+VXFrYrdHu/wCwj8XD8PfG11Y31w0OnSQv5wWQg/I6uAF6
NnBBGOhPTmvRfjpBJoHxit/GOj3CxjzUvITsBIYMCw/BlPT0r6+jb2MKj6M0Uv33qj4p/ao0DTtE
+OHi2fRjGdF1eX+2LLyzlUS4HmNF9Y5GkiPvGa8RiP8ApC465rzZx5HysxqPmm33Ld0calGfpXqP
hM7tGjOeQxH61z1vh+ZBux/L1PHt6U9VG5RzXDHUCwqg9TzU8a54JzzmnqLoTRr6HvWhbFlYc5AP
HNFgN2xkbfjoM4r6b+HviSDS/hzotu9rGv8ArpfPU/NMrO20nnA69+cYr0sBH3pPyL3R1LXEcsLP
afPFdR7yhIKqNwXqR1BHX0r56/aD+EsniaE63pkfl67YoGYIcG4jABA/317HvnHpXdVjfU6qErM0
vAvjjSP2svC2n+D/ABZew6P8WdIQW+k65enYmqxLnFvO3USg9GPX65z0Gn/Fe/8AD9xc+CvifBLp
Ou2oNumuXCk78cAT4BJOQMSjIP8AF/erCjUdOfN0e52VKaq07LeP5f1p9xPq2tSeH5raHX7b7RYX
C5tdTtWVvOXsyuCVdfcGtS20218QBWsb9JcAKEuDsYe3PautyUXvocPI7XaK0Hw51/T9Y/tbRJ7m
yvHUI8trIjpIueNwOVPOCM+gPatZvh1rFxNcXuuX0dq0jGSe9vbhcscAZYk+gA9sAdKu9OPvtk2l
L3UjlNe+JXgzwe0kWjQz+K9ZUFUjAaO2DdOT95voODXIXnhXWfG2r2niD4nXstjbsoax8P2gC3Ek
R6LFCc+VGenmP1xxvPFccqjrySS0O6lS9mrvc+wPgj8FJov7N8V+MtNh02xsl2+HvCMK4WBeD5sw
IyWPyszNkk4J42pX0/pLNJjcpae4YM7qTgc9s9AP8knJNzd9tkYVWdfGqquEG0dBUlcB54UUAFRz
XMNspaaVIlHVnYAfrQBm3HivS7dSftQmx18hTJ/6CDXM6p8XLCyk8qC2aaTP/LSVEH1wu5v/AB2t
FDvoaRptlNfGV/ritLPef2FpgOGuYo1HHs8hBOemFTIJrzbx1d6VNYzXKH7FpZz5viPXphDEfo7Y
LE9AqAmt4K+i0RrGLjsfNPi74xxabqU0Pw7DS3flmB/F+owYdF7izhbOw/8ATR8t1wF615bBCtnv
bzJJ55WMs1xM5eSZycs7seSSecmqq1L+4jnqNLRCM3fOOaa0jKepxXIYCfaCG46077Sc8jHoKETa
z0BboZxUqzBuMiixPqOEwNG8HBzmixNxc9u1HahDFHvS570xeYDFJn86oAbgg0UPyGldanzB9ox3
NDT/AP6818y0z1fIb9p4460G4Ixn9KZS1G/aPbH40hm7k800IYzdDn8aqyEdqpaCZXaFWbpz6mpY
7UNzxitPMkWS2Cx54I6dKy5o8NitIvqCEVTurVsbUNjuacnZXYn2Eubfax4qmuPXFNWaBdw9D3ro
vDLbZ/6US2F5nodkg8lRjNakOOMZxXIxlXULVZY245rl761IdhgdelVENLGJbi68Na1b6vaXb2du
8yxSzQjLxMQcNj3G4V9L6lql94n+HOlQ3ULNd6VCvlSyKVM0JXg4xwRgcc96+pwd6mHlF+RbkouE
vkfO/wAZvAp8TWdxqmnSPPqOmWm+4s9vJh5ZmX125yQO249q+Z1+WYH3rmlNTd0wxFN05K63LN1/
x+x/hXqfg+TdoqDgbWYfrWNXWJym6i9/0qaPqO2Oma47ATKO+O9WkX7o7/3qS2uBZVduOcgirVuN
sg496A2NfTWFxqltp6eV5l4WiVplyq5U/MeR09c8de1e76HHqmg6TbpcQCRGl8sSQTecqx4+8csc
MTjH0xxgV7eBiox13Zcn7it0Os0+6mkRcxCNI1LtuZSwGM7x3wRx+FTlVu43ZcbD8ygnkfl9K75r
QIyPF/ip8A7bxpt1bQpRpmusokEqZCT5AKk9weR83bFGh/tCStp1n4C/aI8OT6/p9n+7svEdsQup
Wq4wCsv3Z0xzgnPAznGK86UOX0Z6cJu6cd0d14d+DviptNfU/gT460vx9oHMsugzGLzFGScTWk+B
u/2gA3XFb+iftGat8NpRp/xI+BMMLKcNPFFJbLj/AGI5QQR/20xWTjzLQ6eT2j/duz7dV/n6o9S0
X9ur4H2MYZvhtq9pcgAlV021cH8TNXP/ABK/bc0b4p6PL4Y8OeAfElxaz4VrO3ENv53cAmPzGA+g
qPZyloZxw1bmUm7/AHnKeCPgH8SvEBF7o3gbSvhbpeMvq+sEveondi8uXX2ZEQ+4r3P4d/CPwl8N
Zv7VsGbxx4pkkEj65fKwtkb+8nJMjdw2SDjh1NdUVb3IblTla7vf8l5LzPZPDekzajdSXV08k8sj
AmaQjPsBgYA9gMck+9dnpYGmyM8xSGMZ+aRgOOOeTzWko2jyo8mc+Zif8J34ftZJRJrdu7rnMUbB
2H4LVG8+L2kW/lrBa6hfNI4jTyrfaGYnAA3kZJPTHWuV03u9CIwlLZDbrxj4mZTMmhWmk2Sjc1zq
14E2juSoxx+NZ1940Fisrax450ex8tN7W2koss2B1wp3MefRaPcjtqaKC6alDS/iZ4O1hAbfVtf8
QzlivkQW10zD2ZI0VRx603VPiRpOix+c/hm00hcbhL4jvrWwOPXDMzj8QDVQTqLmvZG7oVFLlenp
/wAA8t8Y/tReFYZEt73V/D0zDLPHYWl5qYGDwFk/dRH/AL6xXg2tftUaZo/iS+utJ0zUddExRoI5
NllsYAg7Y4xMxXpgBgevNVKEdLdDdKFKLUnv/W3/AAStfftPfEXW9RW70vRNG8MOFG2+uIGu7le3
BneQj8FX61xPiHUtT8X6oNS8TazeeIb8dJL6QsqZ5wi5wq+w49qTq22OGpVi9IKxUaTtnA9KgZuc
Yyc1znGyN27Hp2qM8ZxmmTcZ9Ox/Omk8gHqaEZ7Bu5BPWk3d84p3DzHiRlJwcCj7Q31FNC31JRcf
KCeuaelyOmeaPQnVbki3AbGKd5ykcUwH7lY8Gk4z171QJi9aKRXNY+UPtHbOfam/aPlHrivmraWP
WQebuB5oaU54OR0NVr1Eu4CTg4/Cl8z5QG9aOpV+47zgVPbmmewGKpIQqxt65qVV+XrjHWi4uo12
JU56VlTfKxwQa0iC3uEI+ZeeK39PUAAAU5LTUzdyLVMK3Tt+dZDD5eOM1cdg0Wgm0/St7w7nzsZ5
60S2uCPR9PYbRxit6z068uFBhtZpQenlxk/yrFU5z0irjLw8H6xdDCafMCf74C/zNU7j4UeILtif
s8cQPP7yUcflmu6lga0tWrEOcVuY+tfCmex0+dL/AFzQ7b5cmGa9CFscgfMBg+h7V2/wf8YQ6r4N
Okx2xl1LT08y5lZw5ntyAEePd90ENyB3B+le9gqfsJcknuTOSnT06al/U9Fl8P3seo2aFYcB4pHT
lQc/KRz+XQ18m/Gj4Qnw7eS67okRfRJW3TRLgm2cnsB/yzJPBx8ucHsTlUoqLkkjoqTdWMWeV3h/
0iI+wr6S+CfgHw74o8Di71LxdFol4LqSP7NJb78qApDA7h1yfyqaOH+sNwOKclFXZ6RB8CfDt3g2
/j2ykLY/5ZJz/wCRavx/sz/avmtfE1vcL6i2yMfhIa1/s1J7k+2iDfsyaoCAmu6fnPBmV0H6BqyN
W/Z/8UaShkWTTL5F/it75FB/7+7Kp5RNxvTepi8VTT945z/hA/EAzs0i6uNp2t9lXz1+mY9w7VSm
0u8s7hIZrSaCdshY5kKMfpuxXmSwVanL3o6HRTnGppF3Op8D+FNW1K4hkkMdpFBdeakmxd0i/cZd
xXdtwG4zjmvetc1C2s/CelxadJ5i791w+35ickYPPTO7j6V7caajZLoaOVlYwv7WkjjdPP3TYxGC
Dgg9QPQdOPpWroT3kdw2Ym2oN7spPyr6n2ywrSWpKtsdBEsuqXHyKz7WLFpM7cZxz+PFYuv+E9P1
i3aDUbS3u0Iw0Mqq69+o7EdOOlYSjpZnRGTjK6OA1L9n3w3HcWmpeFL3VvCmphs77G4JjU5+8Nxy
PwYD2Fd54X8X/tA+GYTBYfEuHX7SH5TD4hshNkYGQWO5jwR3rjlTs/dO6NWMl762O20z4mfFSSRP
7Q0P4Xu+cNczaNMWHoT8y/nXWWnxo8XWKmK78XaDoKDgxaHpCR556AyNL/IfhQqbe7Np16XLazfq
9DUh8SXviaEh7XXPEc2Mia6d/KXBzuBJAQdOijNdBZ6zq9jGys2jaJAhzI1zcl3z1xhec81SnGnp
E4pyclaTsihqHxk8M6NHI+t/EthwQ9vpkaRkdOhLBscjtmsaL9pb4aSXyWVhpOq+MLqRGkhlvLgl
CoySS+MKvB+83ApXqVNtDJWXwoo3H7aFrpP26Cy03wZ4cMLlVme/jv2LD2tTK2cEfeUf0rzv4gft
kW/jC3slutc1S+ktis6JpuixJAswzhlaeWORcZ4byyRUKNJX53c3UOSSlNnjGuftKwTxObubVLy7
GQX1rXzLG3OQTHDHC/1UyN9a5Zf2prrS7h7iyudOtrsgL51tpSXEgwMfLJdiV1PurD8KtVmm+SNg
lWhG3IjM1T9q7xLqjMZde124DDBWbUZEjI9DGrbcdeMY5rjbr4xajKS0P2eHdySqHd+ef6VFrdTO
VapLRvTyL/hj47TaXdQxavp9nqVl5mZGaDMyqTztIZQT6Bsj6V7h/wALC8FXVil/o2vQvpxC745l
EdzbH0lgHz/8CiWSMd3FdD9nVShJcr7/AOf+ZxuEknKLv5FuDUItQt0urW4iu7ZjhZreQSRt7Bgc
ZpGk4xXFUpypy5ZGEZKSuiFpNzfQ0z1PfNQMazZyRTc9efegkTJyOw70w8YJ6/rQHWwEenNNYjb3
PrTRHqKWxzjjFJ+G00ah2EHzCk/h/liqRF7ailirZzil85lxk96ob2JFuTwe/TOKVbwrjPFPyEn1
RMt4Gzz+dFIevQ+TPM96VZPWvnvQ9mw8SfKfypFkABFG9wtsKGJzg0obPvQG+xJ5nzAZ5PNKD+lB
HUljbNShlZfQ0tR3K8hxxWdNy3WtYMESW69K3LJ9oHH4VM9SWRagd2eKveH/AId+JfE2z+ztEvLi
N+k3l7I/++2wv611UKM6ukVcmXc9K0P9ljXbxUl1a/t9NTg+XGDM/wBDyAPwJrvdH+AnhfwyhmvJ
ri8MY3M9xMEQAdT8oGB9TXs0sCoq9QnnV9CHUvi58Ovh/b+d9nDwhigntbdW3kdQrMQXxxnbnGRm
rOl/tUeBdZXy9PkvJboglbdrcIxx/wACxXdBwptQirHNKTacjnNc+MviHXJ5YdL+z6eAM4QCR1BP
G5mBGSAei9vxrnG/tm9uBcajqU2oSdhModU/3Q+7afcYr6HDYSzU5O7PKrYi6aM3T/hnolrIpj0e
1znJaSISH82yah1p2+H+taXeafeW0FzIxSCFiBn+8jL0CEjjPRsHoxIrGYaEMO3FWtqGFxTdZJ6p
ntfhPxMPHXhudFhaQbdkySNzFIDyCOq446+hrNbQpNHVhLB/o7AriRQylSMYIPBHXrXz1T37VF1P
ep+6nTPnv4nfAfTLm8huPC19HBeSAk6XdtsRyDz5Up+UdR8rYx1zjiuu+AMOoaB9q8J6zpGo6XfR
yNdGS4hKRhSFAGTwQdpwRwe1b5TUj9bslvocWZUZxoc23U97h8N2txGvmrFLntIgb885qxD4J0Yl
XFuIZB0e2byyPpjiv0J0ISWqPjliJxehxPxT+FkV19kZ9X1j7PdMUBt76VHjIUnJXOwjjGdvBI9c
180+OPD+n+H/ABJd6dBpllrRjYFZ9Z18BzkA4ZRJEQea+dx1KNF3Su/N2PZwdaVRJbeiO6+C9j4o
0TxBbTJ4fsdA05ct/oV1M/nkqSvLTyDbnBJA6dOte43XiOO4mc6pL9pvmwHbcdiqcgKoBwF56d+C
c9a8StiJVaSpSVrPoevRoKlUdVO7aLXhsJZxyeYUsYkR5HwAEbnJLHoPrntWy263hmhkRonmHmDJ
HzZ5B9+2PWuSLfPY7JL3UyGx0l5rhFb7zffCDI/Tua7jTVWzWZZljSOQYdWUKWX0Pftn8a0lZLch
bj5Psttpk8VofnmmX5R3Vdx/niqsDTSK223dyOPMlOAfauWVRLzOhR7uxfJmjjjWe5s7VF+6SNxH
PQdjVW8vtLt5UjutduBKzqhFqVXk+/P+NczqSk/dL92K7nM3vivwHbx+fdX8N/C0mxZrjV1A3DHG
FYdPpTW+Mnw40O3cJJbzPICjx2GnSzy4IwQZJVVT17NS/wATK5nbQ5nxX+17D9o22dvql1aqflN7
ex2S4AHVVEvB5GMjoD7V4J4q+PupazqTXVx4ljtELBvs9oHnXIAzkszZ6fT2qeZbQRlKSS11OF1H
4kadJMsokvr2cIU8xQsG4EnOdm0nO48kE4OOgrPXxtLcMDa6VbwkDAkmJkIHpniod5bsTqSTuiSb
xJqlwqh73YOyRIBj2z1q3Bo+s6sARZ312D0aTdtP4txWkVTp6sylJyZo2/w/12RVxpkcQ/25U/oa
tf8ACvdcVFY2dt06eaKPrEOxL82V7jwJrUf39IWQdcxSpn64zWFqXh+WxB+1WV1ZY43SRnb+dCqU
56PQacumpjyWcm3MMqyjrgHms2aaW3bDhlPvVSjb0KUjT8O+Oda8I3RudI1Gexkbh/Kb5ZB6Op+V
x7MCK9t8G/tH2eo7bbxHbLYXBAAvbVSYW92Tqh9xkeyiq5lUioS+X9djCcNeaJ63a3kF9Ak9tLHP
DINySRsGVh6gin7izHHAB6VxOLi+Vmd7q6Atk88Hnik4PAODSG9xjE8ClYlv60xebEOfy6Cmt97r
16UyQHoeKbuy3PSmGl0hR+dNP3cH+dNEtCnnqc0mfT6UxrshP9n8KB0OeDimIaPTt1oosNJHyr5n
SlEnzda8A9rbcUSccmnbsjrQLQXfjj+VO3gn71G60JvYk8wMoPpT1b5c0rC66kituye1SKwK8Gjp
YkgkPOelU5BmT8auNthroT24+Yd67TwT4QvvGF99ksxtAwZZ2B2xrnqfX6VpCHPJRDrc+l/Afwp8
N+GFjl+xi/vgcm6u1DEH1RTwv4c+9evW+m3ElmZo4NkQ+bJGM/419lhqajFQpo5aj+1I5XVdSlhY
qTt56Yr50/aF8cT6fqOmafLNINPmjaUqh43g4BZe4AxUVZcqJ5XJaHzTqF3ZX+pSStdWF2Sf9ZOk
+76YIIH0HFRx6lBZESW11HaTrwJLWxQsOOxJBrjUo35r6mdpWskbNn8VrjSYWZt93PjHn4ELH6gb
gfyrotE+P6QqBdwyvjqTGu4/8CDAf+O16lDNPZaSV0clXBqa0Z01v8fNAmhPmK8LduGb/wBlrg/G
XjPTvEs8kouwy4wqkEH9RXTiszpYilyRVjnw+DqUKnM9TS+Gfxcl8O61BJLdiK5UCMXLt8kyDgJL
we3AfqO+R0+ttB8e6R40s2h3LbTsAGt5mAPzYwVPQg9iODXiU5JxcT3Hd2kcbqPwrVobhJpzdEyt
JG0sQR0LDse46dMVLZ2es+G7G2VLu4QuN/lSETW7kcZ2OCpb1OM81nRhKhNOL/4c9DEVo4mHK11/
DqdHp/jy5hRBe+HbS77GSwvXtT9SHSYE+wCj6dK0R43tGtXZIryxfORtEc2PbPGfrhc+1fS0s3xM
VyySZ89PK8PU96LaOOvLZfE3mvf67rS/KQ32aeK2UjuP9WzgY9JBVbQPht4T8OytdafoNrHOORK5
adsk53B5GY5PqCK8etWqV581V3fY9Olh6eHhalGxuMI5rmJZWRLh22woTyx7YH4VdtvBsl1Gk62s
kpckNIyEZA4PUcj3rmdZJ2ub+ydrmr/wgs7bV8tnjK7HV8Y2nqCPStZdLt9KsZJb+/itIoxsUSd8
DjBPfjp7Vn7bmd4rUbVo8r2OSuPix4b0maUG6nn2HDNCjGPPZS33QcZ/AGsTUP2kbWzW1isNJ8y5
kXckKyLO3BOM7S5GT2IB5qG5S1Zml2OV1f41ePLy4lZLGHTU3HabpVtlYZ6/vGXJ/wCA/hWJrnxj
1xrGCK48TWGnyxDMjI5llc5JwMIEA9Pm7dahSSCVl8TH3XizVPFGkwK2pXE1q4JEkKJbM5JB3Fj5
jdQOAVGOKpalJe6pZ29pfXc11aW2PLhnmkkVCF2ghS23OOM4zXPKu9jN1El7qKtvo8EbcKEHooC5
/KuO8afEaw8P77PSo4rq/HDSsu5I/wDE1lHmmyeZ9WeQX+pXOpXDT3U7TSsckt/nikt7V7gZBwM9
66kI63wz4F1HXmH2O0ZkBwZ5PljH49/wzXpuh/B+0t1DaldPdN1McI8tB7Z6n9KxnV5dI7gztdL8
P6bo6j7JZwwH+8q5b8Sea0N/fPv1rnvfcm+morN056A0eZxyvtTXcn1AtgnjIxQOTk09LahcwdW8
HaPqxZp7ONZG/wCW0I2MD65FcRr3wruY9xsJlvY+vkzYV/wbof0rop1XB2ewXuea6n4fls7h4zHJ
bTr1glGDWO+YZNsgKtXQ0l7y2KTutT0v4R614nhvhY+HmTU45Ms+lyTKhfjOY9xGHOMDb1OBg8Cv
XdB+ID6u0qRebFcQMUuLO5TbNC4OCrKeQQcirqxvFPr+n/AMHFq7W1/xN+HxU65EsSkeqmrsfii0
dfmzGQeRXCpdA6FtNUtZuRKu4ds4qdZhIPlYEjnINWrMl+Y4kHgUE4YkfWn0FvuJ/Prmm7s5Hf1p
rUTdtQ9O1NH1xVAL/EOaAeT6ijfQm9hG5yD0NN+baMck9afQrdgflZhmijmE4uR8m+YQcdqXd2rw
T2d0PEnApVc4HNGuwhyt82AeTTlbdjoO9BWpIr//AF6k35BFHYnyJFbjgZNS7jtz+WKzdiepFI3N
U34Prit4gtNSxat82Tx6mve/2ab4PqOq2OFDTJHIGb/ZLDH/AI9XThf4yB3sfRD6bPbx+cAGCDJV
T2rqvDPioSR/ZpyApG0Zr67Dy5J+px1FzR9DD8eaCwL3EIyp5OK+Nf2nEf8AtDRGP9yZcfQp/jWW
OjaV1sOi7xPCfCvhK88X+IE0uw8v7TJuYea+1cKCTk49BXoN7+zrrum6Pd39zqOnIlvE0rRxPI7H
AzjlAP1rzYwvG9zS1zyPU7c2u5CcnNUreucLWZPztpKa3EIrEV13hX4hXvh9UtpgL6wU5EEpOY/d
G6qf0PcU4ycXdDPoz4d/HC01CxhsoZ4XdeFhuiY5UHcAE7H+ox9K+jfhn8YfA9vdLYeMvDLalp5B
WF3d7d4+PXID59vz7V0yk5q8dzWOjud7qH/DOXiiRv7N8R6nocinLQFRIq5OMZO7gE9cnrXJXHhz
4P8A2m6h0/xi+ozRhgVjkVGOB1/1RyMnt61zxqzR0+sTmLuDwRZySSW+rNcRhggVirNu257AZ5yO
lNs/FPg+Fo0BE1xN8oLtxn2Hf8BWl6lR3sZ3S2MbxBb+T4gsta0bww99MF8sTHdtiB7hXwB9R6/j
TLjxV43VraDTtClKb9zNLfxHPy46B2OOBwV4xXNDA15Vb7I7JYml7JXlr+R2Ufhf4g30CXkul6Zp
WY9nn3UzzS4PYBvJHpwCeg9K4PVPgXqGoySPqWtXeoM7mQr5qwRKxOeEVGYD6P8AjX0EcFyLVniv
Ewk/d1KUfwNs7CPNy1n8vOY7NpT35/0mSZc/RRXneuMn265tLa+u209WKrGsohRscE7Igin8q4cc
o0YJR3Y1UctGeH/Fl0t9asrS3URIsQdlTuSx6+vTvXISZZkUHuBXn0/4Y9ZH0Fosf2XRbGHGCkKA
/kKtlgNzMQAoySePeuJ2TYt0eUeP/iY900mnaRIUgHyy3K9X9QvoPfvXmTvzyctXXTjyx1KNHQ9B
vNcvEgtYGmmY8Ko/UnsK9t8H/COz0uNJ9VK3tx1EI/1S/X+9+PFTUnZW6gehKFjjVY1CKowFUYA/
CpGxhs1ybEsNxXtSHAUcdKq5N+gb+ff1pVbJHPPeqATdnrwRS7hjHv8ApSv0ENY84P4Uh+Zgcde9
Go+hm6zoNhr0Hl3sCyf3W6Mp9Qe1eSeNPhzcaSrTpuvLHqJVH7yMf7QHUe4rpo1OX3ZbMLnArLda
HdLNC7KB9117j0Nev6L4ntviJbRTS3Y03xTZx7YtUZj80ajhLjvLEAP9YcvGBzvQZTWTcH6G8LSv
F7M6fQ/ELX00+nahD9g1q1O24s3PPQHcp6MpBBBGQQQRxzW0wGG/r6Vz1IpO6OZxa0Y3lcEduOuK
kjvJYfuOyj2NSn1J0asWrfxFcwnmTfj1HWr0PixxjzI9w7kdapS7kdNC/F4ktZDzlcH0q5DqtrNw
syj61omIsearYIYEexpfWqQl3D73pQ3Q9v1qtLi2QNhlOOabuPPHNMF3Fx82cd6KllXPkfdjFKrf
Nk/SvEsexfUdu/8Ar0u709aYMkVj+FL0pJa2EPVx6Y96lVu45o66BaxIrDt1qRWPrUWuLoMkYbuK
qyHt0Nax0JY6KbHT8q7P4YeNx4P8W2l5K222Y+XNj+6e/wCBwfwrWm+WakO9j7p0vUYNQsYJo3Dp
IgZZEPBBHBqaaxhmYOCN/Zuhr6WnURjKD3Ro2tw62jW9wnnxEYzu5r57/aL+B2t+Ohpc/hu3juWt
2l8yKWdIjhguMFiAfu+tejUX1imorc5Yfu53ex4D4e+BnxP8D+Jo9Sj8J3jvH5ihrfZcD5lK9I2b
1pnjK18cm3nGq6VrcJKni5s5YlH0BUCvOlhq9OPw/cXzxk7Jnh2qrcLMyzxtG+eQ6kGqtvGa8/kl
F2aNmncs+W3pzSGM+lKzFZjQlSx27ucKNx9AKeo1FvZGnY+G9ZvgRZaZe3MmOBBbu5/QV6j4J0H4
yWyrHpGieJHiwAFuLKTysen7xcCtIxlukX7N7M9i8O+AfjdNHuufAWjbZMbpZp7eGRuc87ZM/pXo
Xh34J+PJMG58OeF9MVuW3apMT78JEw/WuynCfVDbUd5nf6L8A7yNj9pl0O2XqfI08zHP1cr+eK7L
T/hBa26BX1W8Ve6W4jhQ/gF/rXoU4tHJOUempuWvwx8PR7fNtDdMve4ld8/UE4rft9GsNNh2W1tF
Ag6LGgUfpXZCKOScm0Zuowx4OMCuT1WWG3U7ioq5szp7ngXxX+JKvJNo+mSbjkpPPGc49VUj9TXk
Ikzk9cCvjMZW9rVdtkd8Y2R4p8Sp/tHjSYE58qNF/TP9awrWMXGpW8Q5y4H5kVcF+7TL6n0F/q4y
RwoH8q8s+IHjxtQ83TdPkxbdJpV/5aew9v5/SuOnFTdxrY84kkwMJ+ddD4L8EXviy+VIl2Qr/rZm
HyoP8fau2TS1EfQvh3wzYeGbEW9nGFJxvlb77n3/AMK2BxxjBrzdW+Zi30QoYLwc575pc7snr7VU
dwYdfWk35U00T5huxnGDR/D0NUwF/Hj1poYHFLUGBycdQOtAxjrQhO7RG2fXj0pGGcggYIxT0tcW
p5t44+G6SRS3ulxDBy0tmvQ+rJ6H2/KvIC1zod9Fc2sskTIwZJUJVkI/ka64S54a7o1W519xrF14
jhi12wk8nU9NQefbR9owf9ZGOyZPKDhc8DbwvqfgvxbB4r0sS4WO7jwk0Oeh9R7GonrH0HNbSR0B
+7noc0gUDnpWJghq/NuHU5yKZtPTnFHTUS3uJz1o37QDu259KNSW2tSVbyWEgq7Dt1qzH4gvLcg+
YzL3Dc1fNYajdF+LxVLyJI1c9TjirsPiqB1y6MvtWnNcnl0uy7DrVlNgrMoOf4uKtrIkmMMp+hq1
K6JSQu73opu72GrW1PkTd3NKrfUV4vmez5ihiV9aeG7VNw8h4bvn2p24+tMOg7d/nNPDYz6UMnoP
3Z+lO88L1oe1g0WxE9wTzULSZBzxVBfS7BXPOKVWOfxqluR0PdvgX8cl8Lwx6DrcpGmlv9HumyfI
J/hb/Y9+306fTttrCTRJIkivGwDKynIYdiD3r1KM/dsbJ3L0Oqf7VXE1LPfOa9CnVZlOmiRbxV5A
ANSx6m8ZysrL/usRXoQrSWzOKVJPdBPqj3ShZX80DtIA/wDOsu40zS7zJn0rTZz6y2ULfzWt3iZ9
WZqio7GbP4J8K3GS/hrRWJOT/wAS6H/4mmw+BfClv/qvC+hp7rpkAP57K5/a3d7amnI7WuyaPwb4
ejbKaJpyHtttUH8hWja6bp1of3Nlbxf7saj+lLmT1Ks1pc1IZo1GAAB9KtxXSLx0pKSFyl2O+HHN
WotQ960UieUtxX5bpVuK4dh7e9ap3IehP9sEa5Jqjea0FUjcDXRF2MJK5zOra03zYNeC/Fn4oNbt
Lpemy7rrpNMD/qx6D/a/lXBjK/sqTfVmlOOtjxaON5Mck55qdbcdcZPWvj3ozrR4J42k83xtqrf3
XCfkAP6VV8LQ/avFmnx9d1wg/wDHhXpR/hoR3HxO8afZ/M0eyk/eYxcSKen+wPf1/L1ryaaYs21a
inHlXqB0HgzwfceKNQEKZS3X5pZMcKP8a+htD0q00PT4rO0jEUKc+5Pck+tZ1ZbRBmoJOcZx9ad0
5zkD3rms1oLqOVh8p6nvQ3v+HFHoNiFj69TQPUdaq9nclah1wen1o7/jgd6tXvdhvsC559M0ZHA7
Dg8UXFstRGPT2Pam5HzZ4xR0Er3Bmzx68cUm7OAT+NGyH0sNxxjODXm/xH8DC6jm1Szizxm4hUfe
HdwPX19a0pS5Wrgr3seQWt1c+G9SiubWQpJGd0bjkH2I6EHoQeCDiuj0fxVFoviUatYRrBbyj99a
ZO1QfvKp9M/dz04z3NdLi02jW942Pd9Pv4dSs4rq3cSwTLlWWp93r1NcvXUwsNbHbmjdtye+Kl6k
iHHU/h/9em8Y9j2qu4uiQfebHamlSPbFIE9RMnduz9aTJ4xT2Gw/hx94GnJcSRKCpKsvTmmCLcPi
C7tyoMpI4HzCir52ibI+fMggUZ+bpXlnr31FXPIBpy+/SlfoxDhzxTlbsf50+gEiyUm7sOpo9Rb6
oDJ09ajLnqOlL1FYQk+vFKee/NaoY8U5ffnNIjcl53e9erfCn40XXg0xabqTPdaOThccvb+6+q/7
P5e+9OXLIpaH0ppevWuqWkV3Z3CXFvMu5JUOVYVqQag3r+td8Zamy95FtL5sAZqUX23vXXGoYuIf
b+OuKb/aGW61rzGfKKNQz3pw1ADvS5h2HrfL3apFvh2NVzEtE8d4vrVmG6BxzVpksux3A9avw3A4
71vHUyZejvFX0FTHUsKBmuqJgVri+Zh1wKyL7UNqnLVfMRY8W+KvxUOnmTS9MkDXrDEko/5ZD2P9
7+VeJKrSMzsSzNySec896+Xx1b2lS3RHTFNItpDweOKk8vb1xxXl9NTTzPnDxI3meKtYb/p6kH/j
xrO0vUpdL1L7XCcSxk7GIzg+tepb92kT1KNxcM7EsxZ2O4setX/DPh+48RalFa2yku5yWPRV7k0S
0V+wz6H0Hw/b+HdNitbZcY5dz1du5Naaknp1z0rhbu7snfYsJITwfwqVGyOv40geg7aMHnHv2p+4
jBxk5waNdh+Ym0FgO1GfUcdqfYnYbyO+D0o3H0+tHQFoL6Dv2pMBmz0wc9aLLYQnUDP0o3Y560wE
yW9M4pGPt+dNC1sNb7o44ApjAlSDjFLcL2PGPid4LTTbg3NumLK4Y7Qo4ik9Poe3415ojNEzI3Y4
Ndqd4xkVHVHtvwWvHvNE1GAPu+xlJWTP3Y3YJu+gcop95F969CXcvbPtV4il7Pln0kr/AKMx5rtr
s7fr+oje/rzSMcNjp6VwFA+e35U3d7YqidgPfAJ449aTpnt60hiLz159qN2M55HsKrzFsJ91Qep7
Uhzj3pjY3YG4PrnJopM0iro8Hz0wcGl3c81wep6CHZ79zS5peYh4+8eaXr70wFVvXimmTdS13CzE
z83J+lC5PNVZBsOGOM808LketNd2JajhjgEc05VqhehKv3Rk4NOUml5Adj4F+IWo+C7n9yxnsZDm
W1ZsKfceh96+h/Dfjyy8Q2a3VnLuXoytwyH0YV10p3VmaU30OnttZSRR83NXlvg2Oc/jXRGVjZxu
PF1nvSNcdBmt1IysJ9oPTrS/aD3NUTboLHcH161YjuD61aZNrFmOc8c1bimORzW8dzORfguCOpq7
FdHFdUDnZajnYkCrkTHHPNdCM2Vr6+SFTk4rxT4q/FU6bv07TZAb1uHkHIiB/wDZq58TV9jTb6kp
XdjxKHdcSF2Jdm5JY5JPrmtCKIbQcdetfJy10Z0E23qPSjaOmMA1lzajPmPVJPO1rUpS33rmRs/8
CNY8jbdx7V7K+FCILeF7y4SNFLuxwAOpPavo34feDE8K6SPNQfb5wDM390dQo+n865q7923cVzpm
WmrkGuPorgtx8bZwR0xmp1JOaE+oEowN3IxSr8uc5z2q9kSI2Wwen1pW+X35p3GDd+4PQU3nr19O
aCeof054pAQeR0oWomwX7uf6UdM/nR0DoNP3s9qRqoPQMZyQPwHSmHjPtQGxn61pUWs6bPZzrmOR
cE9wex+oNfOXijR5tJvpo5lxNG2x8dD6H8RXTS95OPzHG9zqPgf4rtPCvxA0qbUmb+x7tmsNRVep
tZlMcpHuFbcPRlB7V73rGj3nhvWdS0a+ZWvtOuHtZXUcOVPDj2ZcMPZhXr1oqrl8Jfyya+TV/wAz
jfu4iS7pP7r3/QqfQDntmkLYJ4ya8DRHSrgTtb2xTc9TyeaXQT7MTgKeOe1Ix65/nVLzJdkgb7oz
n/CkLDjnG7ihDvZA3Tim8biCM/jVIfUbnv270Uadyua2x4L+PFOVjkivPPSvoOXinqfbmi1gT6i+
lG7bigWo3dnr0zSr6/zoKWw4L+dL6Y60a2J6jl4xxx3p3TPHenfuIftJGaeoBxziqJY9e5PBqRQQ
oBp20Vh7D1yxrU0bWrzQ7xLi0maKQdcdGHoR3FC0fmTez0PYPCPxIj1gLFIfs933jJ4b3X/Cu7s/
EG4DnIrrjK6TO6MlJXNGLXByC2farSawr8bsVtFicWTf2kPXntT1vgRnNaoyaJFvBke1WY7wdM1v
Eh7FqK5z35q/DLurpijnZftyzEDnFalrCWrqiYs1LeEL1FLeXItYSfb1roiYydjxL4rfFX+y/M0/
T3D3rcPICCIR/wDFV4U8j3EjPI5d3O5mY8knnJr5zHVvaT5VsjWCsi7YryBjmtFQOP1rzNTTQVvv
Hj86Vs7T9MVHkB8q30u64n29XlY/qazpD5j7R0FesthHqnwZ8Gi4mOs3Kfu4TtgVh1f+9+H8/pXs
20dc5z1rirPmlZdCVqRyLjB4wDUTKQxHbrWWnUYoY7h3qVc88du9MRMvUHp7U/rmhXaFohAvryOa
GAGeCBVbjELDrj60Y9OlNbCDPzdcGk52kfmKSVtyWDZPTrRj5TxgEdKNwvqR/qKUnOD3xVLbUTYg
IP0xTdx5IGD/ADoH6ibevPzV5l8WvDokSLUUXhh5E+P/AB1v6fiK0py94Fpojx2LMMxUjDqfWvsv
xBcS+JvAvw98d7cjWNP/ALG1CTOf9OsxsRyfWSAL+MLV7+G9/CV6XWyf3HLXVqtOXqv1/QwBj6HO
f1pvOAOh7V86b+TEP3snik3fNwMDPSmuwNdRrfp7DtSEdQOOafXyFpsBzt45PUf1pvGRkYH0/Cpf
dB0sxewOc8fjTW+6D37VQxP4qKmW4+VSPBecU5TXEekuwq9xTgwP4CjdD0QZ4z29aOM5pggycdOK
cvtRbS6Fcdzznmlx0PWgl33HqOufrUgHbODn8aY9tCQJTto544oTE9iRV9T1HWnBeQOKpNkvuPXt
2qVPyFJ6i3J4JWjkV1OGByGBrv8Awr47kRkt7w7uMCT1+tXGVnY2pPlkjv7fVo7iMMjgntzVyK8P
ZvxzXXGVjul2LkN0/XJq1FcOW6nFbxdzmki9CzetaEG5scnFdkNTnZq2sfb3ras4MYrpiYNmzaw9
OK1raMYFdUYtmMpFtVPSuX+Ik1zpvhPV72E7JILaR0PoQpwfzrrcWqbkuiOKU9Uj5AlZ55Gkdy7s
xYsTkk+ppPrxzXw3XXc7/UvWv3sk9q0R0PbFS9ykO+hGM1U1XUItN0+4vJn2RQoXcn2FSI+WJpcs
z4wM8VP4e0aXXNTt7OAZllcKPz616uyGfUGk6XDoumW1lAoWOFAoOOpHUn681c53HPHtivKb3bJ6
jWUtjjkj1qORdrcGnfXUeqI+Nx7gcVIrDcOuR709xdCdWPH508/OD9PWmtEJq+gvLemO9B578UAN
5B6YFHPJ681b7BvsJx+PvQOPftS6aitcT7vejnk9fah7BsN2j0zSH2PNPpYl7CFSvakwfT9KB7u4
049+tZ2vaWur6Td2b9JkKgnsex/A4qk3dC6nzVrVu9vd5cbWyVYejDg19k/s83Vv43/Yx+ImhFd2
q+Gb6PW7U8ZXahlyP+AQ3Sf9twK+iwGtSUO6/wAjOtG/Jfuctbzpd20cyHcsihlPsRTmb5u/vXzz
Vmx9bjWO0EfpSMB2Oc0kGvUTrjJz60jcNnrg4qihpz/k0rDj9KnqJicelNyVU1T94NOgmfmzRQ79
CXHm2Z4Rt6ChetcKPV8w9Kdu/CkPcB+dL168Udg8xVP6U9V9qA6DttBxz9cUCZIvHWnqMZ9aoRLj
vmnqpXnGRQJ7aD1XHTtT1XJ5p7EdB6rx7VJtoVtxeQ9VO3NW7Hi4jBzgmluiofEjq7K6mt1G1zg1
u2mtzqo+bmrhK+5704dEbllrztjIH9a3LTVjJjK4r0oHnVNDYs77IHFbdpNuxwa9CEWzglI27JWb
GBXRWFvI2OM13wpHI5nQWemytg7a27TRW6scV6FOmcc6hsW+jouOMmuU+MVmkPw18RHAH+gy/wDo
JreqrU5ehyxfvJnxMsJUDjPuKiI+f3r87a1R7UtdGWbb657VpL8uf85qb9B2MrxJ4msvDOnvd3TZ
A4SMfekPPAryzx/8Qk8UaLb2tkGhWRt06swzx0U+2efwFbUqbk02M81ZQzbem2vSfghYxtr007x5
dbdihPblQT+RNdlTSLaF6nto+UY70KSrZzn3rzOlxdRGHpxxnjvTGUfdxxVPV6CvqQ9Ce1Kq7elL
zDyJoz0/lU38PJqkMVR8w4+tI2cdO1GlwEPoeuO1H8IHUg1fmSJ97pSfdxxwPSpWwCUnt3IyKeoI
P4jTW+U0WuTsKrdO3FNPy5x/9agNNxvX5fx4pGPoMelNAuh4N8U9KFlr14QMJJtnT8eG/wDHga9h
/YburzUde8Z+HLVWf+19DmiI/hDjBhJHfM3lL/wM+te3l8uWvBk1dYfd+aKXgG+Nx4cgjkJD27NA
wbqMHgH8MV0G0fiODXmVouM5IXkxT65waZ1PWudDE29zSHLZz06U9rjtqJyfXjigkdD160+uhK1D
btWm9c5H400HUTtx1oov3LR4T6GjaDzXBoekG3OaXntRYELjrgYpVz0PWmTqKuKeO3PPtR6Ahy8d
6UH8qrqCYqg7gRUsf5UC1uSr9CT71MvWkrC8h6qeo64qQjpjnijzJHKDipFUjJxxVW6oXqPVD6Va
tUZpk2qW55wM1Jcb8ysdTDGWUYrRt4MYNTDc+ke1jZsLXc2cd66TT7PkZ5r2aCPJrvodNp+njium
0/TwccdK9mmmePM6jTdOHpxXU6ZYAYwO1ejA4pO50tnakAcVsWtnwPWuuJyM0o7YL25rl/iN4bfx
R4U1TSopFhkurd4kkYZCsRwSPSqnHmi49yI6NM+RvFPwR8V+FoJLifTTeWidbrT285MepAG5R7lR
XnckZZsZz6V8JWw1ShK00ezGamrxJrdT2GDnmsnx14gPh3w1czI225kHlRc87j3/AAHP4VyKN5JF
6ngq3Ut0BFcM0y543Mcj1pq2e5C8ZyCdqg9TXqKOmg7np3wh+GeleMrTW59ekktbXTrbzmMbBGDF
woGSDjqfyrT8LxaPovj6707R1uGtVjeGKSaUOSoIbJwAM8dq9DEUYRwnM/iOWMpe0t0PQznccggm
lx1A/HPavmNkdHURuMce1MK9MdKFcW25ExHNNXg+gq12AmXnjoamXBOeg61G2iAXpk9O/SjnoRV2
S3Aa3TB+lKCdp47U7oBrdz04oap0tYiSdgOSPemt1APXr07VS0smOzEPOetNbC496VxCfe5/Wjd8
x7iqW1hJWVxGHYH8qTd07Yo1Y+ljzL4y6fvjsroJwweBiPzX+RrB/Zx8UXfhH4xeGL2zwZFvYwVb
dhhuBGQpGcEAgHIyBwa9PBytUpvzCov3ckux7F4m0JfBXxq+I3huMBYLTV5ngVegiZyUx7bClP8A
4j3x7Vjim/byXmErXYmcZ+tH3f5VydQ0tcGxkf1pjMzKD0pLfUUr20EfHaj684qhbaoG6Ck/H9KE
HUb3/wAKKmQa9DwzAwM0qj0/WuI9Vbh9aAPlx2oTF1sAG09/enDkg9KaFsxVXd9aVe/akCVtRw96
eB6daaE+4uDkevSpVwM96a0QiaNSe/NTKv40uhLJF746n2qRVHpS8gZIqHmrNrayXUixRI0sjHAV
RkmjtYaXQ7bQvhtLMBNqMnlL/wA8Y/vH6ntXR3Wi21jaG3s4FhQjDFR8zfU9TVS7I9LD0lH4jIi0
xo+x6mrtvakNgDNEE7noS2NzT7M7hXU6bZ9OK9qjfQ8mudRptr0OK6fT7UdDXrU79Dyqlr3Om023
6YWum0+HpxXowOGdkdDaQ9OK17aBmxhSa6os52jRj0+Rh9w4pW0vzCFxkmtTIlHhLZCWQ7W68CvL
viB8BvD/AIs8yW90xYb1uft1niKXJ7kgYf8A4EDWdejCtDlkgp1OV6Hzf43/AGfte8ItJPYKdYsA
c7oUxMo/2o+//ASfoK+Ufi/qj3mvLp67hHZDDKeP3h68ewwPzr4+phZUatnsevCSkrnDLGVjY9+g
qxHHtkUfwxjJ+tbx0aK3L0/mPHaWHG2R/MkwOfU10ujeIrbT76K7itMXhG1pN5Ibnuv09K61JSUo
1FdGUovTldj2OBjJCjsgR2AZl9CR0qTPccDNfMNatG3QThWpH+b6etKwr3IZMbh6k4qNcY600w6k
yEHIBwKmVQFIpdAHr79KOvAPH0p+TDUMhuMdelNPoDnPNFtdR9Ax1GevFAbAJ6imyRp5I/MUm49e
fSmtRdRO9JzkdxSvcYj/AHf50jZ56f41Tewr2Gt3IGPWkx8x9KlbWZK1OQ+J9v8AaPCskgGTDIkm
f+BBT+jV5V8KNeTwf8XPCury48rT9YtbmTd0KpMrMPyBrvw+jj6mj+E+kvjjGLX9oaW937m1bR7O
dyOcuII0Y/i0TGs5snNa49WruxDalJP0GHG3360ledtuIMjcc/jTdw6dTVXEr2sxp9RnNLx+FT1C
3cCv4Zpo+bP5UxCDluOaKT1KjFnhg4py8sOK4T0r9xcHHPIoZetCHcT8eKXj6GndNaCS11HD7vTm
nc4Ix7VW5Iv6inLnPGOtHS5XXUfjue9Sqo49DzQtidiZf075qZR8wNL1JJkB59KfGvHt60aCfY6b
w34MvPEUiyBGgtu8rDr/ALo7161oPg200WICCLD4+aRhlm/GtIxZ2U6dveZsf2e3QD2pkmhtIORW
/s7nZz6Ef/CMluNnerNv4Uy2SnSrjS7BKroa1v4XIGQP0rasvD8i4yK9ClE8+pK50Fhobr2/Gujs
NHfjAxXqUzz5HSafo7jk8V0+m6bGmC/T2rtgzlmr6HT2cVnCBiMsfetSG8jj4SEflXVFo5pK5JJM
90eyj2q7aqkYz/F61tGRjKOmhfWYMpzVS8tUmU8VVzJROX1TQkkU/JweM14F8ZP2WfC3xMMlzcWf
2PU8YF9a/JL7buzfiDWFWnGorM6qc3E+TPHf7FfjLw2z3Oi+X4isYskpFiO4H/ACcH8D+FeIXfhz
UNFvfsup2FxYXO7MkdzE0bDHsRXjVMO4M74yUldFO3/eXlzcY4UbF+p/+tmt7wdpo1LxHZxEZjDb
mGOw5x+gH41zv3acpFX1se3HkjPPvTlHt7V896l6jBkYzz9KG9sih+QlsQtnr1xURbPUY7ZFHUm5
Mp3N1z9KnXrzxTbKsOX7uRyetHQ5pbiF7Hjp70n65FC2GN/iGeaT27+9MQEfKMHnNJu9OnamloSI
340M20DP0pJFDfrzmkYnqfrR1DTYYfypG68jk1XmZaNGN4ytxN4X1Mbc/wCjuQPcDP8ASvm29by9
RYg9SCDXRS2No7WPo7xvr41rxB8NNQYhpbjRfJkYHqUlmTr37Vscr1rrzB81W5hHRL0Qnp2IoyFH
pg4rzdyrrcTkNgcjtSMfQ596VtR30E9D0HSjBIPanokL0DkZxyabk+mc1SDsN44GcGips3sacx4f
jmlHWuJWPRFx0pfal5CuIR6jjvSLjccimrIT3FHbinj170+hPkh6qGHrxSqPypK41rqSr0qSNRzn
jnmq6i82WFX5cZxUiAcc45pSd7kLUljQscDk+gr0rwR8M3vvLvNSjKRnlIOhPu3t7VpBXNqUOeXk
ew6boccMaKiBVXgKBgCtmPTUUciuhHfe5MlihIwvNWo9LEh6cV0xRjJ9C/Foytj5ea0rfRU4wBnt
xXXCHQwlI07fRUXHyitW30VP7uT1rshE5JS7mpa6Mi4+Wte105VxgYrqijnZrW9kABWpbWoGO1bR
MmacMIFXYYx9K2TIsWY1AqwjbelaxkYSiP8AO680vnepxWyZjYjlwwrLvLBZM8VQLRmHeaPtbzEG
G9RXN+Ivh/4f8aWzW2t6Ta3ykYPnQq+PzFSoqSsyuZx1R4T49/YX8G6g0s+i3N3osjneVhO+Ld67
Gz+hFfL2ofDy4+E/xfm8NXV0l8VtROlwi7N6MOMrk4IKkYz2zXk4+hGnSbiddKo56M6v0AyOaNwJ
IB5Jr5A6/UU9x7f0pACG65HvQvMRCy59u1Q5znGcGhdxWRLGRtHFWIzn8MUWsNMX7oBx0pffGBQk
HqJ0xkfpSdfzpLUV9AXGOR09KSqVluDQhH4rSk4yevOKaF5DMnPB4pOrHnPalskF76DcZ7Z70h4P
t0PFO6YhrMQKTd17g+1FmhPoijraCTRtQUYO63kH/jpr5h1Pi9U/7Iropu8X8jSJ6la6i1w/w5TO
fJhlj/O4c/1r1XPAOM5rbFNynf0Mtkg3Zx/Kg/d5HWuPYQH0zim9c/XNHmVsrCbRnBHFA4zincSE
524Bzmkwdo9BRYY04DEc/jRS5hb7niHFGS3auBK+56t+gtKWwOOpp9mLpoCjOcUnJIOee4qiRev0
pynt2osJd0OXjkcipF+tMB6+n6VKvqPxoFuyZW6CpYl3cYyTwOKNwsev/Dn4ceQI7/UYszn5o4W/
g9z7/wAq9dsbHbtAFdEUehTjyRNqGERqKm27j9K3ihy0LMFvntWlb2/euqCuc8malvb4/CtK3txx
612ROaRpW8PrWlBH81dETBs0IE6djWjCo44roiZMvwrV+HtWiZBfh9KtR/rWiZBMp7VKprRMzluJ
ux9KPetYyMmh4Y4yaXZu6itbmdhLizEgzj9Kwr7TyjZUc00SZd3IFjKvwexr8/f2htNm0/8AaWtr
yZGj/tCxLBSc/ceaH/2kD+NcOYLmw8jagnzXKvO3jpSHuB9K+Ma6I9BXAD1PbFNbtmpXkFrETngj
P61ET2IxSvoD7D4fn46VYTG4k0PcQ8H67aOQD6U72B3G5PHehu4H4VL30H6idsd8UNwuc5qtHqT0
Bx3pGA6Y4HSlvYYw+3HFCt27U+hPaw1m4Pp7UN64zinoLyG7t3X1700gbj3HrRqg3ZU1c/8AEpvD
2WF85+hr5f1Ns3Kn/YFbQ2ZpE7HwrdGbXvCse/5Y/wAcZlYmvdQcrg/j7VpW1ehlIX0wPek3Dpg8
1y+YRETPGOMHmj17n/PFF09BjT93rmkPOQPSmLbcCNuSD06UjY4JH1qr6j2SE70VEr3KWh4hwPc0
pboO1cJ6WnQN3QD1pck9qaEr7Ct97gUg4OafkLYP4fehc01sT1uSRnjp+FOzmmnrcbs9B644PSpf
w5p69A0sPVuletfC7wD5nl6tfRk94I2H/jx/p+dXGLNKK5pHtVjZhQvFbEMYjUdq3ieh5FuOMkVZ
jiHNbR3MHsXYY+e9aNvHt5FdcDGRpQLWjCo611xOWW5oQr+XStCFelbIxZehWr0IO7npWyM2aEPb
NX4VrREF6FfarSrirRNiRelKGHGeK0RDHfe5p61pczJAu6pEBWtUzJom4ZcY5qldQ7s8VojMwdQs
FkVgy9favjP9sL4a6la+KPCXi2ygM2l2INhduCWaLfO8iu3+zulZc9sqK5cXHmoyRpT0keXsu3/C
mso25H16V8Oei/Iae2PTkUnfrnFAehHIOv8AjVdvvc8UIbXclT7p9anX5ff1paMl36Dv0ycml+8M
GlqAnU+9B/SjlAOMAe+Kb/FgdfXNFugtbA2eo6Yo429frVLshiHtge9NbGM54pgho7YGKT+HFJku
w3cBxijg4A6U9RRXVGT4ok8rw7qT8grbyH/x018z6k3+kt/sqo/Stqfws0jvc6P4dbrjxXpanor5
/AZNfQ3fufairKzRElqJu/DFI3zdT9KxWpMtw/iyOnrTd3+PvQkrgrikc+2M03dlsH04pk36IT1H
Y0jduM+lO6K1eg3ndz3opMaR4luoHbFcK2PUDjml4GaZOi1AE5HNL3PpTW4ncX3NHHPtQMXg8jnm
njnvxVCHKc4qTcfXFG7sCO3+Gvg0+JNSE0qZsbchn9Hbsv8Aj/8AXr6L06yESKFGOMAdq2itDtop
KNzagiCqMdauRqWxmt0asuwx8dKtRx7smtYmMty7DH0OBWhbx8e9dUTBmhbx4xWhCu3BHNdUTmka
MK7hV6FenetkYl+FehxV6FPmFa3IL8CdK04Yxj0q7k2Lka4PTnpU4GKtCFoz0rVGbHBvyp4IFaIz
ZIre3NTL+ZrRGTHj9KjlH41oZlC4hzmua8Q6JbaxY3FpdRJPBMhR43GVZSOQRVtcyF5o+Jfil8P5
vh/4kltMO9jNmW2mbnK/3T7jp+R71xfOMn1/CvhcRTdOo4eZ6UZc0UxMc8cGk2jr/WuW5ZDJ1x3z
yarn7x7dqd+omiSMj1qZfU0WS1Fcc3P50FskcZOOmKGCYoYY4NJ/MDtRrqGoZO7ijG0/3h34o0Vg
eoijbkj1oPzYPTP5VKaDXoG3tngU3uBV7BqxPu9PWm89OgpPYTQzJx/Sggbc+lMVznfiDN9n8H6i
2cFkCD/gTBf618437iS4lwOQcVtD4TWJ2Pwjt/O8WQHtHGz/AKY/rXvR6EjqaU3rYiW4hx370Lj8
KyWmhF+ocZxnimjAUFjk9/pTHsxG/X0oU/5FHkStw7jHHGQaY2Bx27012H0uIc9Bx29aKZS73PEQ
T0o4GK8/W56egHjgml9+1MXqHPrRuPNMn1F3cdaN/wCtN7XK8hVbHX6U4MB9O9CJeg5SRg1oaRp0
2r6jBZwLvllcKB6e9UCvsfT3hDw3DoGl21nCPuD5mxyzdya661h24NbxSPSWisXEGWAHTPWr0MfI
xWqFcvwx9PSrcMO6t4mMi9BBV+GHnpXVE55GhDH8o7Yq9CvTjFdETCRehUdMirsPX3rZGJehq9F2
rQkvw/jWhbtwKokuxn5R61MMdRVoQGk3fnWyMmKGHr0qRSe/WtUjNsljJ49anXPWtEZSJFH4UjLx
WiIK0kfUVnXUO4dKpEs8w+MHw8i8ceGbi1CKL2MGS2kb+GQdBn0PQ/Wvii6tZLKeSCZGimjYo8bD
lWHBB+hzXzeaU+WaqLqdlCV1YgOe9J+GO9eFutDp1uQSdMZx6GoW+8aE9dQdx6/d7exqfPYjFIXk
Jx26Yp3tmmxJDeT9KVnwentSVmF7Bjnrg9KX7oHWkl0GvMarZ68ig4UZ7elDYoq2gvqOPbmmSZI9
xVaIW+gFjjHSmswI/LikkrXQxq9CDx3FN7fhximidzhPi5eiHQba33czT8/7qgn+eK8EmbcxboWO
f1reC91GsdEeo/A+zMmoX9yRwkQjB+pz/SvYeNp55qJfGZPWTsIGz1HFHUZ7g1nfqPQa2GyT+fpR
/DnJp7kPcbjrz9KX2AzS3Y10E6fWmt6VXUN0NOPugc0Ur2LSTPEV+lHvXBsejug4Ydc0dqoOgueB
60hbmnrcQhPak3UD7DwSTmnbuM9adloG+49T2r2b4JeFTsl1eZPnf93Dn0/iP9PwrWOrNKcby1Pb
7O3CqK01j2rgGt0dxcghyRjjitG3hz25q0jNvQ0IbcDFXYogoHFbxMWW4Y+nFW4V6cc10R8jGRdj
9OtWo27Yrpic0i7ERwauRtWsTItwmr8XatESXYWPFXoXqyC7HJ0qwrfl2q0FxxYdO9M3H6VtEzYo
zUq5reJkyxGp71ZRfxrVGDJgntS+WcVRGlyCRaqTR7geKQzH1C3DKQRmvkj9pLwGNE16HXbWMLbX
58ucKOBMBwf+BAfmp9a8/MKbnQbXQ1pS5ZW7nie3d34o53HsfevkEd5XfuD0pgXn9aWvUB6jaMY/
SnnuDTTXUSE+6c0i556Y+tHUWod8ULnBz+lK1hascp7j60vQZH5UJFAfm6ZBzz7U3J5wfx/pSjdb
g2Ifm4HX6UEHccj8qr1J03BsjBzn6Uwnbzjilpsgva4cNnkE03aNuM80X6B5njvxm1MNqUNspyLe
AnH+05/wA/OvJ872HauqPwo1irHu/wAGdP8AsnhmS4b5TcSn8gMD9c13rfK3tXPL4mZS11D7zHB+
lJ0xUrsTJdhuP4e1I3IyKrsK3UI89aTO09KB7JBu59+9NbuemfaiwLzG/wARDE8UU7EtN7HiQOPc
UnYZFeeevsBHcetBan1sG4m75vejd1qlcWlhuffmjP4U1foG45eOKcCDxTD0NHRdNl1bUrazi/1k
zhR7c8mvrHw1pEWl6fb20S7Y4lCD6CtYo6aK0Ont02rVyCPd15rZHRuaEMYGBWhCnQCtERLQvwrz
wK0I0+XpWyMyZVwanj9ccV0RMJFiLjFWo29+K6YnLItxNwKtxNitkZPQvQkcVfibirRJchP5Vaje
tEQy3HJwKnSQirQiUSdPSgNWsTNki/pU0fY10RMpbFyJfarsEe4foa2Rzk6w9OM0vl9eMUEdStMt
U5l9sUFbmdcR59688+Kfg+Pxd4Vv9OYDfImY3/uSDlT+YFTUjzwcSk+VpnwtcQyW0zwTJ5csbFHV
uzA4IP0IIqBmBGe3rXwUlytpnpogkxj6dKRV/HPFTr1Jt3JQCFPrTmztxmkwdxG+7046cUnTCkd6
GD0sGSfzpOfmJOe1O4dNBfU9aBjAxzUrVB1F3Edj6U3057cU1uVpYD3pPfGOaOhn1QN39/Wk6HGe
DTC2mgznkHBHb1pH+VSemB1pDXY+bPHGrNrGsXdyDuE0rMv+4vyr+grnIIzJIqgZOcYrstayNj6f
8M6aNJ8P2NpwGjiUNj+8eT+pNafbkcdK5JdWYbqw1jjB6fSjcO56mmgEPT1pvOOBg96BNaDW/rR7
c015h6iYJ47kU2RjjHP0o2DYafXPHTpRTuUkjxUH+VI2K889T1Gt2pKqL7k6iemOaGIFMb0GdT0p
emfT1p30sHkPDdMU5M09hHqXwP0H7ZrM+ouuVt1CJx/E3X8h/Ovoqyh+UY7VvFOyO2kvdNONclR2
FaECgY9K1NNFoXYVPYVehWtF5EM0YE9K0I1G0d/Y1aItoSY6U9D+VdMDnnuSq3arMZ5xXVE5ZFuJ
vwNXIWGBxWyMi9B1HrV6E1aIL8R4qdGAqkSSpJ71MknzYJreJBNHJ+BqaPJrWJDLMadKsxJ04reJ
lI0LeOtOC34rToc71J/Jx2x7VFJHjqOKESU5gOlUZMVQ0U5l/GsfUrcSRsCM0IpnxN8fvDI8N+P7
iaNNtvfr9pTAwA2cOPrkZ/4FXmTN8vv7dK+IxkOWvJeZ6NOV4pkR+9ycjtRGnrXLsX6k6k4B65pW
wPcZ60tHqD0GbRtGB9aOG579vwovd6kbCY2+9DdfepV2X0Djgd/pRw3B7VRNh2S3vSdscfjR0DrY
GA49KP4fw/CkhtDWx2H1pCwwfYUPzJ66DF7461zPxD1kaN4ZudrYnnHkReuW6n8Bk1aV5DifOWoT
ebctg/Kvyj6Cuh+GuinW/FVohGYo286TP91ecfyFdMnuyndRPowAClHYY5xXJu9TOw3p1GKRscnq
MUegaDWPpg0m/rij1Hew0t7YFJuAx+tURboKTyOaYW7dO9Ul1F5MZu5479aKWpaseL03g1wHqSQE
5HqKb9fzp+aExOOc1G2CefShXCwfd96Ucn61SWgeQ4EfhUkfPeqEfSfwf0Yad4WtWZcSXH79v+Bd
P0Ar1K1UKvFdC8z0Yr3S9brn61fizxVoZbj5xV23H61ojM1LbtV+OqQdB/OaAePTiuqCOWXckX5u
9WY2NdUUcki1G2O9XI2+atkZstwucVoQye9WQXoXHA6VYVq0JJA/Ge1PV/wNbRM2WI2NXIMmtokG
hCm72q3GuMVsjCRfgXnite1iLD7uTTeiMuhaaEFff9KqXI2g4GPpURepJk3B+YkVRkroBFebljjv
WfdLlTSRR85/tT+Gxd+GLfVET95Yzjc2Odj/ACkf99bPyr5Wkk3H618pmUeWvfujspP3Bm7Le1TJ
97PSvIZ0dSTPXnil/HJ+tMb3uB+7wOeuKb15H1qVuSJ79+tJ07dDT2sPUP4R60g5UkmgWw75tp4x
jrTcHFNNbA0KrcfTpQuQanoHWwit14pp+deDR01EN4X+deJfFzxML3V2to2zDZgxr7yEfMfwHH51
tBe9cqJ5gcM3HFe2/BXw/wDY9Jn1KRMPcHy4z3Cg8n8T/Kqk/dY59Eek/wAI55zR+nOKwM72Grwx
470hwMk1W6EvdGcbQScY5oZvp60bi8mRbvU96NxFMYqt3x3600tzntmmMZ90c/h60VOj3RJ419aa
fWuBLueuwOOfSmDGaoNLiGom+lNaiDsD1py46dzVE9R649Kt6bbG9vIbdfvSuqD6k4oV7j06H114
dtEtbOCJBhY0Cj8BiuljO0KAOvtXWj0+ljQt8DH0q3H8tNE+Rai7Veh7YNaozehpQNV+Nhj+VUhD
93WjcDiummc0x8bc1YRsV1xOVlmNutWo23VsjJl2J6uxSY+laozLsUvTNWY5PeqRPkSo1SKe/pWs
SGW4juNadqN2K3RmbFrDuAwMmrkdqccCruZstQw4OMYrUs/lPBpy2MSzJMFB45xxWbczBu1TTiSZ
M7dewqnI3WukSKz1UuFyOlT1LPPfitoI8QeDdXsduXmtnVM/3sZU/nivgaRvmr5/NFaUZHTh9mhq
ZDAYzVhWHr2r596I6mSJhv54NOPp+NR1F6jRjGR196M54HIoejBCFiQR3PbFIT1PvT0sMb644pf4
fTPGR/OquG4ZPpnml/h569qjroLdCEY5x070fdIJJB9aoBvAznr2pgYc8E/jRe6ZD3MHxn4hHh3R
ZrhSDcN8kK+rH/DrXzZq12bi5bLF8HJY9STyT+db0/huaxViXw/pMut6pa2cIJeZwvHYdz+VfTum
2MWlWEFpCNscCBF/CpqbImT1sWV7cc560h+6PftWN0RbqMP/AOukfFV6h5sYzdumfWm7vyxigLdR
vC9PSmk8Aepp9BCdcf5xRn5cDmmERu4ZHPeis5FLY8c4yc0ma4+h62w1gKNozzT8ybjG4qI5prcT
FparW2gWHc11Hw6shfeLtOjIyFk3/wDfIz/Srj0KgryPqvSx8q/StiFvn/lXQtj0XqX4farceask
tRnp61dgbvWqMi9C3y1bjlK4rREkgl3U5Xrpgc0mTK3p9asRt3610ROZlmNuM+9WY26YrZGZbjfi
rcUnQVqjJlqOarKTc9a0RBOkuasRt7/lWqIZetjuYEda2rFdxFbIg6SxiX5SeO+av+WvY59jUu9x
jpFC4PSmCYxtwea1jqjnloONyGU/NzVS4m+UnNaRRmZ08vXn86qs3XvVgiFm9arzdKRRg6zGHt3H
XINfnv4w0v8AsnxRq1kBtWC7mjUf7IcgfpivDzT4Is6KHUyFXaQPyp4bDYr5vodXQljOMZHSn8tg
8g+1ZPfUfQQHqfzpenBqhJCcHpSsO2OafqHUZgbsdQaFXjg57DNF+4W00Ewe3NHcdfUijqHQFzuy
emOlJn1+lFncXQQnafWonmWONnJCoAck8UgPA/iR4wOu6k7QufskWY7cev8Aef8AGuA++3rmuzl5
UkaR2Pafg34T+x2z6xcJiSUbIAR0Xufx6fhXp7fLj0rmm9TN73GmT5jzimswzx25zU7sV+wzcQ2B
yD1pu7vnIo1fQLkfQjJyKRmJyauyMrsbkjJzmk3etGhd9AzTcjr0FGgrvYRsHGenQUVFuxZ4/RtG
a4Xset5CHnPrTetO9idBjVEavbUQDin8Uw9B6jK13vwbtfO8WK3/ADziZv5D+tOJrBe+rH0vp4wo
OK1LfpXTFnf3L8PHNXI+pyK1REuxZi6gVajfvnA9q1Riy5E+KsK27ABrSNzN7Eyt71IG79q6Y7GM
idWqaNq3ic0ty3E3WrEbVrEyLEbnmrMT/lW8TNlqOT1qykma0RBZjfNWYm5HPFaohmjavW7p77sC
tTM6SzOVHatKPG2pYxs0nymqM03NawMpEDXOBjNQvcfLW5iVZJKh8z2pjQxjmoJG4qStzI1IZjbN
fDPxrsRZ/E7XFHCvIkn5xqT+ua8jM43or1NqOjZwpXp+tJ03fyr5c6wU96kVvfHapYbjh83uad91
gCOKT8gS01Dnp2Io4xzUeYxOhIP1pOwGTnOacdWFugh7/nRn5ev40xW0EPXjgYpPp+PNHMKzWgxj
26n3rzT4peMhDHJpNrLhiP8ASpFPQf3Pqe9aU1eSHE8Rurk3UpboOgHoK6DwH4Sl8UazHEFYW6fP
K/8AdUf17VtKXU0ei0Po63hitbeKGFAkcahVUdgOAKcxHNc3XQxWjGs21jxn60xj69KZPmIT1phO
TjtRu9A0Q1sdqbkc00G4xmx7e1G7AGcnmm09xIRWzweKbnrn1ot2DqNbjqKKQ9DyLd60vXPNef6n
sb7hxtOBntmm+namidNCNsbaiHp0rR6gtBfQ4pRR5BYepx0PavT/AIGqp1y8cj5vIwP++hmtI73N
qfxI+h9PPyD0rVh447VvE7i7H6cGrUbe1aIzZYjPvVmNq1iZMsqw4z0qwknvW0TGROj55zUysPwr
eJhImVqsRt2roic8tyxG/arEb7e9bIz6liNs47VZRvmrRbkFmN/yqxG9bLYyLMb1bjk6YPNaIhmh
bSd627GXDD1rVEHR2dxjvWpHPgYznPFJoCCS4xms+eb36VrEiRVafnrUTTZNbIxGNJTfM96B9BN1
QyGgNjMv/umvhb9pLWBo/wAajZXUbQ299ZRSW9w64R5AWV03HgkAJ9Nw9RXl5lHmoM2o/GcS33eD
nnmmtk55ya+QOzZhtpFYfWgXQeGxz2709WBxkZFHQNmLu49qPrU6bFbsXJ7/AIUmflA7D0p2QmxD
3HfHQ03qT2pi9Rv8WO/elPy0aWTFqcX4+8cx6DbtZ2rBtRkXOe0S/wB4+/oK8C1fUTdTModnG4ln
Y8sT1JroguWF+5qiHSdNn1a8jtreMySyMFCivo/wb4Xg8J6OlsgVrlgGmkA+83p9BU1HZWE3rY3S
27pxjg00sR7jtWOmxm7jNwXk8/h7U33qiVd6DPQ44ppbnAqfNC1uRue4yBSdFx371XQWzDG7Geg7
UzgcdaY37rBuDx0zSN7/AIUx6DWPzA9KKlocXbQ8jJ5pT06V5567EPpSNzgYpruLoRsetRd/eqJe
4q9u9OyKrqHQVR6GvUPgfxrF5/1yH/oQrSKNKfxo+hLBvkXmteE+1dEdz0Zbl6NsCrKfN2rRGTJo
+GznOasL7VrHQyfYsRtU6tW6MGTo3Sp0bnrxWyVjFkysasRn8q3RiTo3pVlWP4VrEyZYjap0b862
iZssxt+NWEbitUQWY2q1FIa0RmXoJO2cCtaznO4VrEh6m9aXXHXitBbwYBzirF1I5LokdapzXB3H
Bq0QV2m685pvmVaJF39qN1Ag3VG5HWgnyM68PyHNfnh+214gm0n4tfZTCl9p11o8JltJSQFkEs4S
WNhyki54I6jKkFSQeLGRbpOxvRdpnlnw/wDiPFqUcen6jKEuV+VJnP3/AGPvXoW4cHuK+OqR5ZHa
xBjr60dMnGR14qF5kjlOAMgmgHIIzxS6DHj8xilGcc8VIbWsHf8AQ0nTJ60LYYm716e9NJ4/nT2Z
NhGbGcnP4VxPjf4hR6IrWWnss+oY+ZuqQ/X39quMeZ8o1d6s8K1jVmu5pcytI8jbpZmOWdu5qjb2
r3UyxRqzu5wFAzk11Sd3ZGi2Pevhv4CXwzai7uUB1CVcc/8ALMen1rtuOpB9K5JO70Mt2NJ6/SmA
9jSWxL2uM6/KOvSm8jI60D2sIDuGc01mG70p+gN2IyQfb1ApPxprsRvawHoTxmmc5GetNdh+Yd80
3+XanuK4wsV7d6KnXuUjyZfm570KA2a4NmeturiFvSkz60O1g6DG57c1DmqiJ73HLg4HvTx39Kau
LoOTselej/BWYL4guEJ+9BkD/gS1cXymlL40fQ+nv8o9a2oTuA7V0RPRZbjbFWY26VujOROjdqnj
britUYMsI1Tq3TNaxMmTK351MjEc5/CuiOhzvyLEbHpU0bZxWyMmWI2qzG3y9fzrVGTJ0fGB2qxG
1bRM2WY2qdWrVGbLEb9OatRv0Ga0RHQuQybcHir9tN0FaIk1be5IxzV5Lo9zWhIjXB6A5qJpsjrV
kMZ5h9aXzKsgk3cetODUIB26oZD71RLM2+k2xn6V+cv7c0M3/C2rW52kwNpkUYbqMiSUkfkRXJiX
y022a0/iPmqa1Eh82M+XL6+tejeH/F2reHbG0Ot28lzps42wX8LCQAgZKlhn5gOqnDAc4xXzOIpd
j0F70T0ax1C21S2Wa1mSaJujxnP5+lT+ua83qQ9Nw5xyKXPXvxSWt7j21Qqj5fal3jbjsaS7ia0F
yWpCTtGDkikt7ALwepzUF5eQafbvNcSJDEgyzyNgCmtxpaWPLPF3xQkvVkt9JZre26PeNwzD/ZHb
69a8p1DVDJmOIkIerHq3ua64R9nHXdmiWhTs7GW+nSKJGkdzgKoySa90+Hvw7j8PRpe3qLJfsMqp
5EX/ANes5PlQpdjvOOmOB2pvTqcZrDfYztbcYW/KmsSck9zVEsYyn6nvTcsCAKOo/ITngZzimE/h
7UJmbGDHGRk03r79xTvcWyFz2/Wm53fXNFu5TE3D14prNxz0poBGYdc0UJFcyieR9qX19a889cCB
xQWOfWkJojbr1qNuvSrF1sLTh+lUC6ki8V3HwluPJ8XQjOPMjdP0z/SqLp2U0fSGmt+7GTmtu3Pv
1rpR6DZejqeNhk9hWqM2TpU8bGtkYyJ1bpUyN+FbRMXuTo3yjmplbvitomL3J42xU6NXRExZYjbF
WEbpWiM2TI+e9WI259K2TM2WFarMbZ71qtjNlhG6VZjatCCzE3OKuwy7cc1pcmxehn461bS4zg5r
Qz1H+d3zR5lUSHmcU9Wq/MlEqvT1amL1HM2BUErfhTJMvUHzGeea+Nf2mLK31Lxsba5iEsZs48gj
n7z9K87MNKF/NG1L4z5U8WeA7nRGae2BntDyGHVfY/41jaRr9/opnjtZjGk6+XNBIoeKVf7rowKs
P94HB56149OpGtCzOvWL5jW8G3GlafHcefq2paLf5zBcW8KXNs3H3JYyVZRn+NS5/wBg9a3NH+L1
ushg1SHaynHn22dre+1sED/OK461LlNNJq52+l+JNM1gA2l7DMcfdDYb8jzWjmuJ6PUmzE3fLkUv
y/8A1qAF3bTn249ahvNQttPh865njgi/vyMFH60hpHD658WLS33xaVCb6UceawKxj+przTxF4mut
VmE2p3JuGX7kKjCL9B/jXbSp8q55Dsum5y95fS3vBXCdlFW9D8M33iC8SC1gMj/oB6k9qmT5ndl7
I9z8E+AbTwnCJTtnv2GGmxwvsv8AjXUeuOMiuVyu9TG+vqI2cg96RjuByeanoLqM3cEYyDTeq56U
eoWGsemOppmB1zyKdxW1G/xEg96Yx5J/Kr6kvoIw6U3cCCCelSHWwhbc3rTT3PXmquN6iH5cjNMb
leuM+lO+hK03G+3f1oppJiPJh25pc+9ed0PaEHTNLyzEeopIBrdR6YqMn5sVVxWs7i8mnY4Hp3qo
7iHrzgdq6f4ezfZ/FunNnALlfzBH9auLV7MqPxJo+nNMb92uOlbtuxCjvXTFHpy3uaEXTg1YU4rV
GbJYz+FTq3fPNaIykTKT1qZWP+FbruYSJlbvVhG6VqtrmDuSq1WEOevSuiOpiyxG3Sp42H0rRMzZ
PG3vViNs1sjJk6NnHarMbc9cVsQyzGasRsO3WrILKNVmN+R3qydS1HJjmrMcnTmrRLXYlWTOOacJ
PwrREdB/mU5ZR64qrkj1uBUyTBqsnzJt2RUUuMcUwRmXq/KfSvj79on/AJKIeOBaRj/x568rMv4D
9TSl8Z5a0YZSr4YHg5ri/EXw5ttS3TWZW3nPOw8Kf8K+Zp1PZyv0Ozc891Lw7faTJsmgZeeuOD9D
3/CsqSKN+HTI/wBoV7EXGol2J9CH7BGMGORoz7GtOz17XdMUC11SUKP4WYkfkciuaeHTLUro1Yvi
R4mhxmWCb/ejX+mKsL8VvEHGbWzJz12n/wCKrm+rMb5Rl38RfEN5GVWS3suPvQpk/wDj2cVy99ee
fJ5t5dSXk3rK5atY0I01eQc3NojNuNQnuFxAmxP72Kjt9DubqQZVmboO+azk3N6GiSR3fhn4R3F9
ibUnNlD/AM81AMjf/E/j+Veo6TpNnoloLezt1gjGM46sfUnvXJUfRGMpc2iLjMDjHHak3d6zDQYT
8uCfakJz8tIXQZ93uKazDbx3p7j0sNLd+lNcED+tNaEX5tRvOTz7mkLds8ZpMOhHu+bHak3bfaq9
QvuNZtxppbbx1x3pkvcOajLcgUJ3QLpcazbccfhRT26hfueT7s4pf5159tND2d3cM0u6l1BtXGt+
lMIwOKtdwFTpjrTxVeZFxy5rW8N3H2bXLCY8bJ0J/wC+hTja5UXsfU+jMCozx05rfh4wK6onp7o0
o2xjNWFPfrVoTJFNTLWqMJXuTIamQgZ54reNzGRMjVMrnj0rYwehYVvxqaM5raJhIsRt2qwjdjWs
TNk8bVMre9brzM2WEboKtK2K1RFixG2OKsxsPWrRJPG31qxG/oa0RmWUerCtVonroSrJjHPFL54X
vWiIewjXSr/FWbqXiK10u3kuLq5jtreMbnllcKqj1JPSnewleR57fftF+H4biSDTYNQ1ydTtEdhb
E+Z820ldxG4Z4yAeldv4b8ePqQiF14f1rSxJL5SG4tCw6gBjsLFQfVgMd8UoyuXKNtzuVPy01vWt
jAzbz7hNfHP7QjB/iROPS2iH/oVeXmX8A2o/Hc8y570jfeB618jsdhFNbxXMflyxrIhP3XGRXN6p
4A0++3PGDC2M7eoz/P8AWtaVaVN6B6nK33wxuoyWiKv/ALh/xrDuvBuo2rEGJ/rivTp14T8iLWKU
mi3sfBjb8jUf9m3RY4Rjj2NacytuXbyK82i30zc71X8qvab8P726dcQSFT/EV4/PpXDUle7NdI6n
a6T8MY41zcMIznop3Hr+Q/Wur0rw/Y6N81tCEkGQZG5b8+34VzTqX0RnKV9C+zcCms1YWZCegm7d
g8nPam0+gaCMd3I6dKjZtwIHUCqE/IRm6Gk9sfjU7ANLbR3oLHGO1O4uug0vx0qNjznsOvNNXQnd
jM4yc4waT+LB6UB6Dc+9JuGfej1C3MrjRnjB4pOCvWmNaDGb5hzzRT6DueUBqVuD1rz1uetYNxx6
0q9M0IFpuDEcZFMPyn8Kduwr9QWnjnnv6VQLYcvbNWbZjHLGwPIINC3uJH1R4fm862jk/vKDXT2r
ZxmuyJ6fQ0IW5B9ulW1q0LoS+1SRn09K1iZSJ1PHWpV6dK2RjJdydGqZa2RjInR+elTI2DxxW8TC
RPGxHbtViNuRWsTNk6NViM5bGa1RkTK3T+tWo2+UVstCWWI2xViM8j0rRGZaRvlzU6txVIhlhWxU
izcda0RArXQHtVO41RYxycelXsI8c+KX7Q1j4QtZItLWPVdQ3+SFEmIo3x/ERyfov0JFcb4T+G/j
H42XkGteMtQuLDRt2+CxTKF8dGSM8KMZ+Zsk/TmsHJ1HbobWUUfSnhPwVpfhW1W3020S2TGGblnf
/eY5J69zx2rq7eELjjpXXFHM3dlr7ozUbt1rQz6XM+++7+FfGnx+Yt8SL0ekUX/oNeVmX8D5mtH4
jzhu3P1pOO+D618kdr03F3DBpn3WPbmkIVvl9PrTSQSD92h+QyGS2imB3xIc9cqDUP8AZ1pg/wCj
Q5HrGP8ACnqFx0dvDCdyQoh6fKoH8qfxtXjj/CnuLyEz+ftRnb70MFa+owt8vFM3EL1/OkShGY8H
OBSFuSew5p+QDAOuDRu55+lK4eQ31/SmNnyxRbqLUbnOM01m+Y0aDGbu5OKCx69cmgndDSdynNIz
DnFO4PUjZu2R+VB54xVeYajQwAFJnqKNytRrdhjNFAWfQ8nVuTS55HFeej12KWI/GgNhgpFNIL9R
SduOaT17UiQXnFSLjqTmqEhwXdUsePlPvVJj9T6X8A3RuNB05zyTAmfrtArurbjH0BrqS10PST0L
0Z9+asq3QVomBMretSq20cVqjJkqHr61NGc1qjCROnaplPtWxiSqxqeNvxrZGT7liM+lWUfmtVuY
kyNViNs1siGTxtxU8bZX61sjMtxt05qZc8cnA7etWiCyjflUyN17VomQS+btxzximyXYQcmtERbQ
5bxZ4807wrps19qN3HaW0Yy0khwPoPUn0r5I+KX7SWseOLo6X4e8/TtLkOwspxPcHOMcfdHsOT3P
auetV5fdRrCP2mev/An4BTw2dlq/i6Pzp1czW2lyZKQlsfO4JwW4HGOMDPPA+mbOzWNRx0ropw5V
Yxk3fU04YwuAB0qyhx7CuowQsrBVJqvFMs670bcjcg0xFS/b92e9fGHxxl8z4kan7LGM/wDAFryM
0/gr1NqHxHn+7HPak9SfpXyfmdegh7Yx0obn3pFdRu75OuM00nPfp3qltcgQthffNMZgTQITd6jn
vTCe+aNrhrohDnA54pNx20XXQW2g0/Lz1psjZ6ijsymJx938KYWYkjFC8wt2GbvbpS5HNBFu4xj0
4waGpegRvezGM3ynjFIWy2Rx/SqsPbQiZsZHc+1Nz8o7Ggm1tEBY/dphbv1+tO12O+g1mBpM9eaF
2DpcTPYjmmtJ69aasO9lqJuGcUVNuxas0eOidl75FPW6PcVx2PVvcct0GGSOKkWdC1FiehIrq3vR
jBOKBMcPTvTx1BpvQfmPVqkXOfSnsrgfQXwpuvO8MWPtuX8mNenWjBh74xXVHuelHYvQfdH61OuP
StQbJ1bGMnFSrleOpq0Y6kq/M1TIfXpWqMmTq3ocmplY49K2RiyZexA4qZD3rWNzJ9yeM/lVhCK3
iY9CxGwFTRt71ojNlhDViM1urEMsxtU8bEdTVkE6yYU0/wA0KorRGZXudQWNeT2rzL4o/GnSvh/Y
M1xL5966/ubONhvf39lz/Ef1PFOUlGN2CVz438d/ETXfidqoe+mJTfiCzhzsjz2A7nGOepr6b/Zv
/Z5Xw5b2niLxBD5mqsoktrWRf+PYHkMw/v47fw/XpyYePtJc8jSpLlVkfT9lbhFGK04a9ZbnIWFa
pNxAHeqRHoVNSvUtbWSR22oilix7AVneC5mm8I6JI/DvYwM31Mak/rVdSNbXJ9UYLC3OK+L/AIyM
X+I2q8jny/8A0WteJmrtSXqdFFanEKR0NN5Ga+Wersjr8xNue+famnjnqepo62FsNPvTR0POBTV0
tRbjW6HHamluuTTE/IazDrnNMY/L6EVQPyEz3/zim7ieR3FSGrEZuKQ/MuenekF9Rppu7PU0+grj
c7uOPSm7u1FtR31uNZunqKZvC807diW7MTJ6nim7skfWlfsHXUbk7jxn1qPnt9aEtLDYZzyfWmsc
5x+dNMFsNZujHrSM233ouJaJjclcfSkzjA6HrVegDdxJxRS0QXXU8bzt+tLXHrY9ddgHpTlo8hC7
sUokYYGTTGpD1uGXHOalF2fTNHmHoTJdr1IxU6TKzcGqWm4HuXwXuhLoTIDny52X9Af6163atit4
now0imacTdeKsKTx2rRMbJ1b8amVueK0jqYvckX5m61KjfjW6Mpak6t+dTofTmtYmTJVzU0bdK2i
ZMnU9KsRn1rRGckTxtUyN1HatkYssJ1FWI2rWJHUsq2BU0bevWtVsZsf5wXvVG81FYh97GP1rVGf
U8J+NH7QcHg9JNN0po7vWWG0gnKW+e7Y6n/Z/OvkvVNXvPEmqSXt7cyXc0zEvJI2Sef0HtXnVqrl
LlRvGNlc+qP2aPgOLOO18U65bkXLDfZWci/6sHpKwP8AFjoO3X0x9W2MIhTgV6dGHLBXOWcrs0oZ
BVtJB2rqRixzXAUZzVSbVooVJd1VQMkk8D3qiVq7HF/GHxJ/Y/w38QXcb4k+xSJEQcZd1Kpg+7MK
7jQ7f7FpNnbdBDCkePooH9KfUXRFbWG/dMBXxr8Y8L8RtVHvGP8AyEleHmmtM6aPc4hscnjFI2K+
XWl7nSIDjoOtM+8fagW+gw557mkduPfFWLS2hF0yM0HpnHOOaL6E6jcjp3PrTP4QMfjQCG55APWk
9yeaQ/MYzEYBpWbjGaeyDYaW/AUgK84qUC8yLd3HHrik3cEfpVE3dr9xpbqc0xs7T2OaNAvzCBvm
5FM4weaTC+w3nPXimnHrTWgXG7sHJ780gbPPYnrTsHXQazZP8qTcO/NJWCPxajWO5sg4NJu4zT7A
t9A3c9BRSYzxzOKM1yWPWv0Cgfzp9AQ5ehoo1FoL/jTlzTH5jhkdqkVjTBHsvwIus2+oQk4KyI35
gj+gr3O0bGOfzreJ6MLONjUibtirIbnNaLsP1JUbpUqsG69a1iZSJge+MVOp6HFaoyuSofxqdG+b
PetTF+ZMD0qdTWsTNk6NU0fXoTWqMmWI6nVq2joZsnRuM9anjkHFbR10MSXzPl68etL523qfxraK
M2Ub7VEhUsTjFfNPxw/aI+wtcaL4dn33gyk94hyIvVUPdvft9ekVanJEcY3dz5ma6mvbgvI7SSE5
LMcknqcn1r6E/Zw+A48VTQ+INegL6VC3+j28gIFw4PJPqgI/H6Zrhw8HUnfsaTdkfadjbrbxhQNo
AwAKpeLvGVj4M0G81W/Z1tLVPMkMa7mx04Hfmvdb5UcKXMznvhD8aLL4rw6pPY2c1nBZSpEPtDAu
+4E5IHC9PU16PJqSwqSTiinLmSYpqzOH8WfGLQPDt01nc6nCL5YnmNqjBpAiIWZiB90YU8n0r43+
Jn7RniX4oSDTrWH+ydEuJdiwxkl5iP4Xfv8AeGVHHTrWFarZqK6m9OHVn0P8V5HsfDHgTwcsgebU
NQsNPkBPWOMqWP5qv519IQt+7B9q7E73Zyy0SM7UV8xSO3Svjb4zn/i5Wtjp88X/AKKSvFzJXpX8
zal8RxDAnjpzzSc5P+FfLM6vMazdh9elJu4PoTRZ9RXGHP0qPPzcdKpeQdRvXOPypuR0FUGr2Ge9
N3HpSuidxOvf6Uw89eKd0K2l2J3PNN54wM+tJjFb65z7VHkDOD3o3Wg2hp9j1FR8HOT0ouSxu7cB
70m8560WDWI1juGeg9Kj3du3rR0FfS4hYc0jNt46CqsCT3GHHvik/T0p3FZ7jWYLwBSbjgg0uw1b
cbuHTGD2pGYk8ins7iQh4zyTRSKUPM8e/i6Up/I1yHrh/D70q9aaJ6jsevFBp76BsLn8KXJ3dKS6
FPUevfmnL7GnqTuepfAu5A1a+i/vxq35HH9a+hbPLRito36no0vgRqwsaspg4rXzK3JgSM09e3NW
jORPG2c9qnU8ZraJlIlVuc1OpraJi2TIcVYU81qZvsTKe1TrWqMXuTqehqRWwK2iZS1F+0BeppVv
l5+atombJfty44NU77VkgTcWxitk1a5kfLfxw+Pr3rT6HoNxth5S4vYzy3UFEPp6t+VfOryeYQCe
a8qtU5pG6jZHqvwL+FMvxJ15DOrpo9qwa6l6bu4Rfc4/AZ9q+89DsbbSbOC2t4kgghQJHGnAVQMA
CvUwkOWN+5zVXqa7Xyxx9cV5J+0HqYm+GXiFEIybZjn2BBP8q6ajXIzOC9489/Y11YR6P4lAZSqy
wHj1xJ/9as/4qfHjXtQ+JjeGNK1AWGjW8irdz2uPNdQN0x39V2gMOMHg1h7T2dKJoo+8zw3/AISC
fULHxf4luHJudQf7LHnrumcs/wD5DR1/4FXVfCfQf7Y+JXgjR3UGO0Rb+4UDI3HM3P1QRCuKm3Kp
FP8Arqaz92LPe9S1RvF37UnhLS0LPb6NE1w+3oJCpfn8Fj/OvrCPmMD2r2aeqbOGW6RWuI/lJNfF
/wAZGDfE7Xef+WiD/wAhJXl5n7tBPzLo/EcQfY9+KYSc+9fK6Pc63drQUnDdaYc5HOR6UB5kTNjj
Hamn05quhPYaW4xnB69KjJznPWgFsJ1H8qjJPcc0rdCfMRm4phb5RjPFPzDdWBm+YDoKZ3GCaF5h
dgT39KjzjgfXrQGo3O3r3phbBPvRsO+w3d15pvmYJ4696ojm0sM7dKTdycDFGgdLWGgj8M0hIapu
7lJ3GM3zY6GhjnPamT0Gs3XjjFN3Hk00l1HvsJx9B15pNwZTk1QdLibjnIJzRUuMXuGvQ8hHXNAy
ea5baXPX3dgPpTs0kw0Ae54o5FMLDhxyaXJyQetPQNRR65pwIzTvck9B+DNwI/FRTOPMgYfkQf6V
9KWLfuUOa2i+h6NH4DXgycVbX7uO1ampIpx1p6/pVJGRNG3+FTxt781rExZMjetTq3IraJiTx1Or
VqtTJk8fv0qdf1raO5kyZflGOtNkbYOvatUYnmvxm+IV/wCA/DH9o6fFBNP5yRkXAYqFOcnAI9B3
714BN+034zuS8kSWUccfzN5dsxCjOOcscckVlKo4uw0lY9S+D/x5uvHFxNp+p20cN9FGZVmt+EZQ
QDkEnB5H/wBauO+Pnxrlkafw/o05HGy8uEP5xqf5n8PWtZVb07ojlsz54YvN0DMfQc10PhX4e654
m1O3gg067WOWQKbhoHESA9WLYxgVxRi5NIpn2d8Pbzwt4H06y8N6fqVk12qkmJZkM0rAZdyoOc8H
6AYrL1b9qvwpp8k8NvJdXcsSOQVi2KzKOFBbB5PGcV7ftY00kc3I5PU4/wAG/tS6t4n1DU7e8sbO
GNLSW5tlhZt25FLbGJ65A64HSvALrUPEfxEvNY1S6vmkkt7WS7laZzjyweUQc468DpxXHWquokka
xjyM9b/Zj16Lw74W8Z3srfJbrDK/PYLKf6V5La6tNcWPibX7p/8ASrtvs6yf9NJmJfH/AABZB+NT
UleEF5Ak7tli4s3m0vwvoMQ2yX0pvJPYyMI0z9FUn6NXtP7OMkFx4s8ZeL5SI7G1iaKKRuiITlef
aOMD8a1w9vaK/T/IiprC39bnSfsnXz+Lvix4s8WXR2q0ZCliML5jjaMn0RMfhX2vbjdGD7V6dGzg
rHJU0m2JdJhGPtXxF8YH3fErXu/78f8AoC15+bfwY+v6BQ+NnGUxs844r5HyO3ZiE/MPfrTXxgjN
Ul0FoRE5x/OkPUjP407C1Im5prNnGKYulhrEetNY7ck/Q0mL7Q3dj69DTN3zc80+th6Dc+3FM3fn
mq6An3EZuueKbu6Z9MVKsTrdDeab06dqb2BMZyvfIzzTM8c9KaSYtgZgpOPWmlirfrSWxa7jA3Wm
luSPxoM+mgjHOCOvam554OKaZWttBm4mgt8vPXNIfqGfu8UzcfpzzVdgANzRUsE3bQ8jH3c4pd1c
3TU9UOewpR6daNbgg9BS5p7sQuaXBoSsPdCml9+lPoL0Ot+F9x9l8aacScBiyfmpr6n0tt0IrWJ3
0PgNiFuAehq0D8uc1rE2JFqUGrRD1JY+n1qdP1rVGEiePPep0rdGTJkbHt+FWF61quxkyePj3qdS
PwrRdzCRKGqOY4UjNbxMmeJ/tKR+Z8Ob9sAmOWJuf+uij+tfMvguU/YfE8Qzg6XKT/wFlOf0rkqa
zGjU+Ctxt8WSRidrbzbSZfNX7yZX7w9x15qrfeOV0u8MHhuCO1iRipvZYllubk92ZmBIBPOBip5+
WCsG+50Hw58df294ktbXXLO1v7lm/wBHvWt0EsTgZHIAyOO/Sqnwu8TarffEbTFvL+6vBmQbbiYt
j92wzz/StIz2FYh+Ety1r8ULEGTAV5VPPqjiq/w3sbPVPiNbWd7Cl1AXlzHKNykqjEZHfkU+yYir
8OWEHjGWJQButrpAM/8ATF8U/wCGrZsfF6gkhtDuDz9VNEd18xMqaH4lk0fwB4js4ztbUZbaHd6q
vmMw/LA/GiazZtP8N6NCubi7b7TIvfdI2yMH6KuR/v1XNzWXog2Nqe8ibxPr+pROpt9LtWt7Yr04
At4yPfnd+BrsY9Y/4QX9nxLSIhL/AMSXcnTg+QMK34fLj/gdb05cqlJdjOSu0jpvg34dv28H6RZx
W6yDXr6SUwyD5bhYdiLHkgjJLykcds8bcj9BdKtTa2EEJfzGjjVC56tgYzXrYaLUFc4q0tdBb7/V
HvXwz8Wm3fEjX2/6eSPyUCvPzf8Agx9Qw/xM5BmGcU3dxyPzr5JneMJHrTd354pkkZ+6MVGzVXUT
Y2Rie2DTS2cgnB4pPyFfV3Iy/Jz0pM+9PyEtBu4n61Huy3pxmlezGnYaPT9aax7ZBFUnqTcRmzjm
mnt2qFoxuQwt1pC3QYFWkK+quNPqenSm7vlNC2DbcYzeowKaWH9KOw9bjWbb05pG+79aS0VwsNLf
Nj9KaT82afW4LsN3f/rpC3A7CmNbagWx19KaW4HOaYtExNx6UUgdjyb0ozz0rlW1j1RfpS8dehoH
sH3RzSjhsGmJoXrjHSnU7CAUZ6UdQ1Nvwjcm18TaXLnG25jz9Nwz+lfWujyboeK1idtBvlZuQN8t
W1rU6OpIuOmeKkXAB657VaM2Sr931zUy81pFmbJ19KsJ25raJzsnTr+FTpjrWqMydTx61YXAz61t
Exb7kq8cVFcf6s+oreJizyD9oGHzfhxrAxkKiNx7SKf6V8heH9ci0OTUxKrsLqymtl2AcM4wCc9s
1xVfjGtjq/g3oT3mqXGoNLGsVvDIpj3gu5ZSOF64569KyfhXJ5fjrTQ3ILMM+5UilFfCAzwn/ovx
Es1xjbfBCPT58Vb+HebX4oWKM25hdPGTjvhhRHoLyLHw/YQ/FqBduP8ATJU5HT74q18N/wBx8W4V
ztIuZ1/RxWsfsrzJ6Gd4DQJ8SmjIOM3Sf+Q3FHwvBaPxQgHH9h3XB7cKaI62+YMxF06XULrR9IjL
ebOysV/25CMf+OhDXUabfJceMta1tB/oekwubf0GwCKD/wAeKH86UfMbMjw6txrEA0OygaS6vruN
mkyT8qhgAfbLbif9kVseNtTHiDxJZ6bZP5un6ZEmn223+MJwzgerNk/lWkb8iXexL3bP0r+EfgmP
wh4J0TSxGEe1tUSTH9/GX/8AHia9CWPy0wBxivp4xstDyJO5Svz+7bivhP4pSb/iBrxzx9rcflx/
SvGzf+FH1/Q3w+5ye/pTSxBx+dfI+TO4a31pjNyeeOtPfYm4wtmmNj5h0p2aAYzfKBTG7YOeKrTo
LW1mMJz0OOKbu68A9qXUPIYW29aaWxnj5qYO2zGliuQKTPQgY9RSI6jOF/rSM/vzS8ytNhm4joe9
Nz1NUK+1xpbrimM3bODTtZFPuJu3N1FN3deM0vIWvQRunHpTQ3Y9KXUdxn8OfSkLDnFPUUV1Buvo
KYWzTEL/ABU3d8pyaLjt3EXqe/FFJS7jaT3PJt3btS81zs9Qd/Kip1AXvkml/iqtRjh/WjpTQvQO
uc0Z96q6uBp+H1Q63YiQ4jM6biOw3CvrnRSVUoeCvBq0dlDa5vwH8TV1OnNaK51aD14IGakU96tG
bJlPGamjHTFaIxZYT3NSr+dbxsYyLEYHFWI/TvWxkyePjGDU61qtGYSJVX1qOX7prZGLPMPjZbmb
4f68MbiLSRunouf6V8aeFNEi8Q6/HYzsyJIjlWTg5CEjr7iuWqveQK70LPw1untfG2lBXKeZL5ZA
PUMMEH86l8A5t/iDpqknK3Wz5fckVnDohvcLVha/E4AnGzVSo/7+1d8LqIvi5bqB01RgP+/hFEen
qBZ8M5tvjNGp4xqjryf+mjCrPg1Wi+NQAB/5CU6f+POK2juvUl9iv4Mtmj+MHkD5P9MuIzn6ODTf
hDLZx6/e2l9P9miv7KayV9rN8zgAcf40Q0a+YPUzPDlhruv+Jprrw/p9xdXSBnVbeEuYkbKjoOMA
gA+1dP4g8D6j8O/CdvpepRpBq+tXKubZXDMsMY4U44yXccc/dFbU6cmuZ7EOavZHqXxF/sn4P/Dy
ysbC1t4PE17apbPcoi+bjAMrFh7nH4j0ri/2XPAreOPizpCSxb7Wxb7bPxxtTlQfq20fjXTyp4iM
F0Mb8tJy7n6d6fCIoVFWmr3kecZupHETc1+fPxI1Jv8AhYPiMq2V/tCcflIwrws4dqUfU6cPa7Oa
GptyCvTpTv7WX+JeDxwa+UdjrWruP/tCJhycfUUv2qI4O9SO3NK7WgW00FZ1P8QP0NMLDjBp6iV9
xjeoOc0wnH1oF5jePfFM3DbkGnfqh9dRN2KbuG76UdLi0ZG3tzSbup6dqFqEmNPUYGOaazbh+tPR
7B0Gs+WpGb/69HkLR6kf1NIW55o8g/QTd7fpTSd3IpddQTvoNNM9DnNPQegHH1FNzjmpvrYfS4ik
lvfFJkcjvVCVmIzY4pO3XOe1NdBq3UarfMTRSsO55SPrS1h5Hp7iml71AeQv0pcVVwsKCKXv9Kqw
AuKOKXmK62JrdzHNGynaynIIr7E0uTLbz1YBufcZq4s7cO9GjoYcVcQd62OkkXHHOKkXPHFWT0JU
796mj/WtYmL30LC8Hipl7Cto2MGWIxViNfxrVMwZOvWp09hW0TGRMvpTJRuU9q3WmpmcD8Urb7R4
L12PGS1jOOOf+WZr4w+GbEePtMGfvOy8jrlWFctbWaEloU/BEXk+PNLjxjbeIv8A49irWgx/ZfiZ
bJ0CaoF6YxiXFYrp6jexY1K3Nv8AFS4A7aoW7/8APTNSzTQ6D8XJrm4by4INWaSRsfdUSkn8v6VW
1n5gXdAmh1D4x2lzbN50Fxq6tGxUjcrTZBwfY1v+HdFn/wCGgPJRHbGtPu2qTgGU+nbmtqcXK1u5
LaR3ngL4DeKpPjJLrM2lPaaTFqc8puZ2VPMQs+Cq9TkEc4xzXovgr9jvTdA8Xf2zeanLfW0M5mtr
HyggXnKh2ydwHsBnFejSwy0bOSdW97Hs2n+DdI8J2Usemaba6fEx3MttCsYY+pwOTXyP8QdQi8Wf
Hmee52jQ/DgVriZgAqiP5m57kuduO/pXTW91JGdPW9jyTx942uviB4quNUuCVRjsghJyI4weB9e5
9zX2v+xD8OToPgu48Q3EWLnVnAhLDlYUJH6tn8AK48H+8rSqG1d8sFE+qYVwMUr/AJ17p5xkaq2I
Xz6V+b3jS6F34w12YHIkv7hxj3lY14Ocfw4rzOjD7sxzJkGm7ht9+1fKpWR2rvsBYrxnJzSbvens
xX7jWkKnBOP6U03Ei9HOMVS1Ftcd/aEi9G4pBqUnJ4qfIS1Q4arydy07+0oz1yPQU9kU9bh9sjZR
h+/epFuEJPzg5oFYTcG6MBzSbuho0QtRpbHf8aTIz7e/ansNrQbu+XI5prN2PXtQTboR7vlA6Ujc
rnvR1HbuITj+lIx+bA/Gl1I13GN3Oc8cGk3d/ajY08xvr/Wm/wA6PUBM4+oo5z7daL6WCwhO4U1j
t4A5FNO2gWW4nPU0U7orl7nlS+1OyPSubqen0F6cdRS+/pQu4ri0DPrQgY709KB3Paj0CyQg70ua
e+5I5WIYV9XfDTUota8E6VcI26WOIQyjPIKfL/IA/jWi0O3D7tHc27fKO/FXk5WtDs6ko5Of51Iv
WrRmyZe3b6VMnb9K1RgydevPNTp+dbxMWWE/Cp14rVbmTJ1xtGKsL9K1iYMmSlZeM4roiZHO+LNN
a+0a9hAz5kLp+YIr4d+GOi3k3xB0Tbazf8faBv3Z4Gee386wqRbkrC2NTUvhf4r0Px9ctZaDqN4t
veGaKaG1do3XduUhgMdMZ9K6XxP8AfFl5qn9u6HYSst432n7NK6w3FtITkqQxA4boQfSoVKTWguZ
I7L4T/sz6wfEEeu+LCsTRv5y2u8SSSSZyGcjIxnngkn2rq/EH7I+n+KPFl1qzaxcW1vdS+bJbJCG
bcfvYcngH6cZrrhQvFXM5SPQvDn7N3gzQ9Wi1KHSd13CUaJpJXKxsuMELnGeM5PfmvTdM8K2OnyS
y29nDBJK26R44wpc+rEdT9a7qdNRVkc7fc24LFY8cAVO0SovTFdkdDnlc5vxRe/ZbCd0Ad1QkLkD
Jx0r87fiR4oij83w/ps4uEM7XGpXyHi8uiSWx/sKSQPz964MbPlj6nTQV2V/hL4BuviL4z07RbUN
m4kBeUDIjjHLOfoK/VXwnoVt4f0i00+ziEVrbRLFEg7KBgCqy+HLT5u5OIleVjoRkcUyT7pr1jiM
HxFci20+4kJ4VGJ/AZr8zbi4a6uJJmHzSMXP4nNfPZv9g6cPvcjVvxzzS7sZHavmTq13E3dAPWkL
A8+9F2OytqNJ3KP71RPx2o6hcjyQfU0metDElYYW5OKjLdKBuwK5A5pCx49KW2o99BPNbbgNTvtU
ikHeeKroA5b6Qrg8+tO/tJwDkA0PsJDl1JWUgginfbI+546VN+V2JS0FFxHtGG9xQXXs30qkHkKz
D8qTOSaV9A1Y3r04pvqaT12D0DPzDHPrSbhzT6hsNDfNxQzZXHfNDCwm7tj6U1m5zRbuUtrMTdRT
QO/Q8r44p2e1c56Yv8P60opgxetO6dqFd2E9A3cUc81T0DdiZ46Uu7g0BsxV7Yr3r9n/AFItot7Z
7uY592PYgf4GqTZ00Je+e2WrfL71fU8Y6VqjvZMPTpUq9fWrRl0JV7cVOtaIykmTxnJqdT0rZbmP
Qmj4xxVhMdK2RhJk8dWFrZGLuTRj8KlUA9a2iZsRoAwIxTF01ew4rVJbmbLEemx/3atw6eoxx+Fb
JGbL0NmAw4wKuw2qjHHNaozZcihHFWo19q1iZMc0gFZ+o6gtvG25uMda2WxjJa6Hx3+01+0Nk3Hh
nw9cgzHMd7dxNkIOhjU+vqe3Tr0+WLVWmcYGTmvBxdT2lSy2R6NOPJE+/v2NPhA3hbw03iXUIduo
6og8hWHMUHUfixwfoFr6ptk2rX0FGPJTUTzZy5pNlkVFKepFbmZ538Y9W/sj4e+IroHDR2MxB99h
A/Wvzr3c/Tmvms2fvQR1UdhQ2fwpWY9+K+et0OrYTd6dPSkDdc8ilo0FlsNZjgUxmz1NVohDSRtq
NnO0+tLXYV+pHu9sUhYY689aYasbuyvoaTcfqKRVhD3zSBgoGRxQtUGm4zO7PpTcjNP0AQn5qDjp
S6gu4m7tSeYV6H8qXoP1HrdSL0fNOW+cE55pgu44ahuXkfjTvtyEHqD3p2J5fuHi7jYcHGaVZk2/
eH51O4DgwbGDj0pGYlsZ70wtYTPHrSZ3Ln9KroFxG9aKNEF2tjy1aWuZ33PTQ768Gl7UdAtqKppe
T0NFxCqPX8aQ81W7Hsh3vSUK6YPsOX0xXp3wI1RbPxFdWrtgXEWR/vKf8Cao0o/Grn0xbx/KrA5z
1q6pxjitEeo0WF/KpVrS5k11Jo6mXnqK0iZSJk4GKnX0xW8TnZOuOOPerCCtkYsmRemKsR9a2iYy
LC5Bx2qZR1rWPkZsmVR2qRQN1bxMrFmNR9KtR49K2Rmy1F61PH6VojMsqwVR/Kka4CjOa2iZszNR
1qO1jZmcKMcmvkX9oD9p7fJNoXhi43E5S51CI8L2KRn1/wBrt255GVer7OBVOHM7s+VJHNxKxJPX
ucmvdv2XvgjN8TPFEd7ewsNAsHD3DEcTN1EQPv39vqK8fCw9pVTfTU6a0rRP0j0mzS1hSONAiKoC
qowAB0H0rYj+WvqEuh5Q/P51BO2FrQk5DxXoFn4ss30nUITcWdz8skKsRvGc4457V5z4l/ZP8G6x
ZvHZWsujXgBCzQSs2D7qxIP6V4mNSlUs9rHZRpKUL9T5d+J3wZ1/4YXjfboPtGns2I7+EExt7N/d
Psf1rgmO3/Gvma1J05W6Gyb67oQ5xTWbp6VjEsYzcA5phbpSE9hueCD+dNPoKezDQjzyM9Mdaa33
etJjjbYTJ4BH1pGPTtQC0VhnWjcVPtTC12JuzzjrTC3PuaS3DURsdOtGRxxT3HpbQjPr0o9qNwfc
T+Lp+VNLHJ+lMrQbnj9KRmwAQeaetw6aibuBR5lJBaweaw4z0qQXUi/xZoYWHC+kzyM4qRdQ2qOP
rzT0Fyh9uVtpwRzRS0Jkn0POeKX7re9Y6noi9ulOHUUumg/UXvSr8ufWgA+8c0euKaFuG7il/Cne
+odQzXQ+AtU/snxXptwThBKFY/7LfKf0NUioP3kfXumzZiX3ArXjbOPWqWx6zLC/Njjg1Kn171qi
GTKAOKnjHTFWjJkydRU65NbROaWhMn3asKc9q3RkyZDVhD0FbmMidM9+amXOcVrEyehJu44GK57x
d4uTwpDY3U3lrbSXkdvO8hwI1clQ3/fRX8M1stCNDpre8DY5zV+KYZ6VtHUxZaSYY61ILgL3raJi
yKbUljU5PAFcV47+K2jeCNNa61S+jtlwdiE5eQgdFXqT0rRyUFdijFydj43+MH7SOr+Pjcadp+/T
NFY7SgP72Zf9sjoP9kfjmvFtzTN6818/WrOrK53Rio6I9A+EPwl1X4reJotN0+No4FIa6umGVhj9
T7+g7mv0z+HXgXTfAfhuy0fS4fKtLZMDP3mJ6sx7knmvYwNLljzPdnDWneVux3EKhQKtLXqnL6D/
AMKrXHC00ySjayGzkmnMvkjGN2ccd+apw6iGlKxl5cnIkYY/L1rwMVL96z1qEf3aLOq6LFqmnmC/
tEntJ1KtHIAwYd8g18w/Fv8AZMKifVPCB45dtMkbj/tmx/kfzrjqRVWPKxVIa8y3R8x6ppt5pF5J
aXttJa3MZw8MqlWB+lVD3PevHcXB8rIjLm1Q1mAxgVExHr9KixVuwxn3EEc0xvl74ovYBjNSFvlz
1qtASGswOOKQsPToan1K9RrN8p9RTd273o6CvcTd1FJuGKaKuIzccimsRyfaqWohvbOfrSbutTqO
4mefxpp46UeQbjT+VAOcjHSm9h3G/jgZpSTyDR6B6jScMPTFJk546U0x6i+uaCflOOTQIZuFFOxW
5xX3jTvTFc3Q7RaVecc0hLXQdjpzRVbbhugopKXQlicdjRkdMVVx6C/w1JC5jkDA4I9KtCXc+u/A
esDWfDun3YbJkiXd/vYwR+YNdpbsCuehxVI9lO6Lkfzc4wvapkq0RImj9/Wpk/8ArVojGRKvsKnU
DHpXRE55akyVOlamTdidKsLntWyMWTpUy/rW0TEVua81+OWkTa98NtetYNxmSHz41XqWjYSAD3O3
H41ctrk2PMvg3+0taNp9tpHie5FtdQqI47587JFHA3nscdzwa+gtO8VW1/Ak1vcR3ETDKyROGU/Q
jrV0aiaJlHqXm8SRRISXAA65OK4zxR8dvCvhVXW81q2Eq/8ALCFxJJ/3yuT+ddLqKKuYqm5M8I8e
ftfXd4JLfw3ZfZ1YY+13nzOPog4/Mn6V4Br/AIo1LxLfNd6lezXtw55kmcsRz0HoPYcV5VbEOeiO
mMVFaGP8zMeOfWvRfhD8Gtb+KmtR2thCYrJGH2m9kB8uFfr3b0X+XWsqNP2s0iakuWNz9FfhT8LN
I+Gnh+DS9KgCKvzSzNjzJ37s57n+VelW8YXH+FfUxjypJHmX7lyM1MpxViHdfeo5F+Uj8Kokx7nS
ftV4JLhljiA+Td8xbrnC1oW6paqDBD5TAD95NhnH07D9a+bqvmqSbPap+7BIqXmtRRkqXa4l6H5i
35k1bs4ZtQhbdDmPbuPcAfWs1uUzg/iZ8EfD/wASLNlv7byrwDEV5DxKh+vcex4r4w+KfwL8Q/C+
4mkuoDe6UWwmoQr8nsHH8J/T3rnrUvaRut0ck1yu62PNGU96jb6V5WxQyRscdajZt2aYmN6EAU3P
B6n1oBDSeme9JuxjHWn0K12G7uM5pGbnHv2oSQraCMe1IzcYPap63Q+lmNyNpJNNDYzx9aNwSsJu
64Ipu7vjNUhjcjJo3d+1F+4kNLHccc/jQzZotqUNbFG7qD1pjE7UL3P40WuxCbtzZ/Ck7EimNBux
RSvJAcZR6cdKwTOy2g5c96XlR61LfQa3DnNO9MdKrS4tUg9hQeppILtiYpePw7VW4kLj9aF9ulF+
oWse/wDwA1xbjR7nTXb57d96/wC63/1wfzr2u3bIFaR8z1qesUzShPr0qwud2RxWkRSJl7A96mjb
/JrRGUidfrUyD2raPmYyJVGasL+dbowZMp5qxH79fetYmL3J48L7VMK3i9TOSFZeOtZ2qWYuIWQj
IIxWujRmfB3xo+G9x8PfFUyxRN/Zd07S2kuPlAJyU+q/ywa4e31i9sQfs91Nbk9TE5X+VeXrTloU
noOuvEWpXi4uL64uB1/ezMw/U1Q3u3+eamU5S3YwWNt2KsQ2bTMqqCxYgADvnpUxjzOyC9ke/fBv
9lXV/G0kOo68s2jaQTkIyYnmH+yD90f7RH0FfcPgvwPpng/SLbTtKs47K0hHyxxLjJ9Se5Pcnmvo
sLR9nHXc8+pPnemx2VrHtA4q7HXoeZhYsL6VKpzVDHrwaSQ4BJ6YpSdkEdzFn1mCF3S3Q3Enfy8c
H3NVVjvtYTJYpHjLqDsCDPcmvmZSvI9qK0VzWstLtLKJRxeupyowVjH49W/D86sXV8IIQbiYJGOi
L8qD6D/Jo2EUV1xZpQscRwRwW4z74q7e6ZDqFu1vfWyvHMnzRyKCCp9QaqLJce58t/Gf9kMSmfVv
BwWJ+WfTXOEb/rmf4T7Hj6V8n6tpd3o19NaX1vLa3ULbZIZlKup9wa4K9Kz5kcq918r2KTYJAqI8
Zrg11Ktcbu96Zu24oHuhGakBHpR6B1Gc/wBaTvTW1g6ibtxNNb7wOeKSVnZAIeQAaN2fyp6DEpnv
TT0D1Gtj/CjP50NaBqN9frRux06UeQ+gmc8A5pPXNGyATjPpS52nnmgYm4elJxjNMPMRjxRT5uXQ
drnGr604fXFc+p2eQtL7jpTa0DqC0vtUgxeaSqEHTjFJ700Ji9MUo449KroNHc/B/Xv7E8ZWoZys
N1+4b6nG0/nj86+q7OTcqk+lCPSoO8LGvb5wM96uJ/8AqrVGjJguWBqRf0rSJjIlXk1OprZGD1Jk
6mrEfrW8TF9iWOrEZHf861iZMsIdtTrxW6MWPC7qZNCWU469q3VjNnMeMPAmm+MNJm0/U7VLq3kH
Ibgg9iCOQR6ivmfxp+yTqtlJJNoF3HfQclba6OyUe277rfpXPUo82pPMee3HwB8c274fw7c4HeNk
cf8AjrGrOm/s6+PNQm2JoEsYzjfNIkaj82FcsaEmx86PTPCP7Ger3kkcmuarBZxbvmhtUMrkem44
AP519EfDv9n/AMJ+AzHLYaYkt6v/AC+XX72X6gnhfwAr06OHUNWc8pc256xZ2KxrgD6cVrW8YTtX
po5y5H2qzHVCJ17dqkHerRLRIKivFEkDISoRuGLsFAB471lWlaDZpSV2ilaWVnahfIh+0HpkgpGP
oOp/Sn3EMEc/2u5ZfMwFHYAegWvnkrHrFS41iaZvLtoTGD/G68/gKSHS0aTffTskhGdpG6Vh7L2H
vwKV77FWsa1vFFEC9vD5Bzne5DSf4D8PzqC41iG3n2BmnnY/dU5P4nt+NVsQPt76S9ZlEQ2hSW2v
nbj1rgfif8E/DfxSsD9ttfKvVBEd7BhZY/x/iHsc1Wj3Mpw5lY+KPix8A/EnwvnkmngOoaVn5L+3
U7QO29f4T+nvXl7DDdK8irS9nLyMYu+j3GMOeOuKY2do9awL21G7ucjims3ocUJK4xN3U5ppYcc0
dRrzE3Z6daD93k0XAbnikJ560aNsEI3y55ph+vvVB0EZu/akH3j70nsAhz0PrSZ59BT0GJnpjpS9
6AE/ipN3QEZpAKvpSDsB1pghMn8zRRZNajvbc40fpThj6VgdnUdjI96UZGKW4ttQB7UDnpTdhC9x
RnGaOg9w+vFIenvVCsB9acG7/lT1DaRNbzNBMkiNtdWDBh2r6/8AAuvp4h8P2F8CC0kQ3j0YcMPz
zTWqO7D9UdpZtnrWiq8cGrWjsdLHrUy9q1Mn3JFHY9akj3eZndlcY24/WtomDuixHwBipkreJi1q
Trx1qxH+dbRMn5E8f0qZPpWyMGTpUiru/pW0TNjvJ3c0n2NH6jmtkZDl01GOCuKtw6ai/wANaIi5
oQWgXtWhDGF6CtUyC7EoHSrKHvWqM2ixHzVlPc1YrEy54qZfyq13I8iQfWs/UtQtrPDXEipz8oJ5
J+neuTEv3Dpox94xpPEc102LaLyE6ebKPmb6L/j+VXLTSXR1uL2Rvn6K3Ln6L2/lXiPsj0lsazQx
yRBYo2tgeDISDIR9eg49PzqjPfWml7kgUzz9WWP5mPux/wAaNhblPzr7WG2rlEP/ACzhyD+Jqey0
qC3UGV2mcciCLhR/vPj+VSncdi55rxxsZpEjhHIjQbIx9fX6n9Kqw6rFIwWNWnz/AMtFGF/CqJJ7
hYryNbW/tQ0NyrBQ65DDuD+dfNfxm/Y8tdVjn1XwWyWd1yz6a/ET/wC4f4T7dPpTlFVIuLOepB6S
ifIOuaHf+HdQmsdSs5bK7hO14Zl2sD/h71mM3TFePKDi+WXQmMuZXQxm5GOtIf8AJqOhSG9+uBTW
YfhR10GIe3OKQt69RRsMTd6cUlMQ3O3I6UdGoGMOKOOgPFN7BuJmj+EYOaQCZo9+h70ugw/lRuwR
jsafqITO7J70dDTGkNZjwKKljOQ5p34VnY6mw59aX35ofYGHUUq0w9A3fzpeDmp8hrUTr9aX+dPy
ATHPpRxT9Ceo7cRk17l+zv4mDfa9Fmf5l/fwA+nAYfyP51S2OihL37H0NYYYA1pj7oxVI9FruSBe
1OXAPWtYmDJVxxUy9q2RgyVOM1OjVvExZOv3qsR/NWyMn3J4+46VOvQc1sjBk0eQDVhOcVqiGSqO
OKnVc9RXQjNosRrjGetWI6tGbLUagD3qyi/ga1RDLMfSrMfpWiIJ426VYU1ZDJ17VLuHerQtxSx2
8DPoK5dtBmmvZbrUVVJWY7YY28yTGeOCAF4x1NefinokdeH0uy9HD9lC79tlHnj+OQ/VyOPwA+tT
XGv2dj+7jY3E/aOP5m+p9PxrztEdivIotcalrUoQEoh6QW+d2Pdv8MVetbKC1VY1j8+RescJwgP+
0/8Ahk1FubUrYtTWfmKXuWWOLgmGPiPj19fxrPm1yFnMVmvmEcGTBCD8cc/hQ9CVdiJp0l/MDczj
ywQd8hCRj6f5JrbjtLezIW3i88gf66QYUf7q9/xxTigY29u4YwstzNufoGbr9AB/SoodWV3AELgn
oGXmi+ot9zjvid8H/DfxY01oNUsgl0oIiu4wFlib1B7jPY8V8N/GH9nvxH8J7iSeWJtR0Vm+TUIF
OFGeA4/hP6e9ZV6ftI3W6OWS9m+Zbf1qeUNwTnrUbdq8lmo3dyBSfzpiG7uvbFJu74o9AEzyc96Q
tuI7U/MYmeBSfxcc0XAbn1opBawm7GKTPWlYd+wmehzSMevc9aYC896KewkIPvUbutAxPeimPQ5D
+VOxWGp1aC8d+aM0t0Ao65pffiiwbCetLmnIOocCkbpR3DrYXPXNFHoO6EPPetjwvr03hrXbPUYD
88EgbH94dx+I4q1uOL5ZJn2r4Z1KHV9Mtby3cPDMiyI2exFdDH93OacWeu11JFHHvTl961RjIkX2
4qWM7SDW0TnaJl96njreJiyePHHFTpnditomLRYWp19q2iZPsTR9Knj5FbIy6FhamjznNaxIZZj9
xViPrWyM2WV7VYiJ78GrTIa0LUbdKnjNaonYsx9euanTtVozJ0apB61XQRFd5mjCB2TJALKcGs+b
VbXTFEcSmeXP+ri5Ofc9B+NeZXleR3UlaJlXE9/r07QlCidPKiPbHdv8KuaZpdtaBUUC4K8eXb8I
P95/8M1xfEdPwqxptamVs3EwjgAwLeL5Y/8AgX978agudeis1EVnF9pPQFeEH49/oKZO5Tj0691o
+feThbdeWjb5Ix9f/r1bWziX/j0TfIMfvpBiJfovVv0HvUWuUtC7KtvbkXN3PvZFwHcgKv8AujoP
wrPuNemvG22UZSLOPPkHX/dXqfxoegLXcLSz8kG4uXKE8LJcnJY+igck+wFbVnL5bB4Lfyjj/Wz4
Mh+g6L+p+lOPdg7DLy8ht2zK/wA7dB1Jpjx2mu2klvcRLJFIuGjlUEEHsQaa3sQ1dHyv8dP2N45l
n1nwQqwS4LyaUSAj+vln+E+x4+lfH+qaTeaPfTWd9bS2l1CSkkMyFWU+hBrjxFLlfOjmXuvlZSOe
Oe1MyeO9cBohN3zUhJ+tAxN354phb059KAtYX2PApvNN6B6iZ/CkP3uDRYA9qTdt5HJoQxM+vSg+
3NCEANJuzQyhelJyR+NAhD94cUUXGcpilwfqKw6M69LisDg4pKaE7i8+tCjqKB2DGKOcE0ri6BQD
1pjDdSGmt2AvarVjptzqMnl20DzP6KM0OSirtlRi5NKKPqD4ByXul6C+l6iVEkbmSFd2SEPVfzyf
xr2KJjgYrOnUU7tbHtShKEVGW5OtOxz+FdcTlkh/HFSL8oHGa2iYS7kydqmU8DiuiJhJFmPpU6N0
rSJmyZe/ep1reJg0Txk/4VYj/Wt13RmyeOp1JHStEQyxHViPmtombLMeOKsR1aIZZTnFWI61RDLM
fzVOnNWiPMnUetO3bVyTgU72QJHHa1rRW7cTXLCEHCW8PBb/AHiOfyxUOj65HezG3SzcjGQsJAC/
7x7fgDXkVPebZ3x91JM6JtPFyM3EoWLqYIvkjx/tD+L8abJrsaxGLTohMy/KG+7Gv4/4VjsaWuVj
pV5qhaa7mLqoyc/JEmPr/U1e0+O1jkxbo164AHnSZWH8O5/Dj3pJX3GXrmGPcJ7uQMI+Qp+WNPov
QfXrVKTU5LkH7DGJFPHnOcL9R3P+eab7sV7jP7LLIbi9lDAEfvpjtVT6Af5NWI5GkbFpBtUcfabh
f/QU/q35VFtbsexPttdPZrm4kDTkYM0rZb6D0HsKpza7NdSeVbIYYzx5rr83TsO3402w31ZNFpsF
q3m3UpiaQZVny0kh/wBkdT/KrGn3krCRBbrBE+P9aQZTj1xwv0GfrQlbVjZbe8iU7HlUE8bSa8/+
KXwD8NfF6wK39sIL9R+6v7cBZU/HuPY1po9Gc9SHMrHwv8ZP2efE3wfunkvLf7dpDNiLUbdTs9g4
/gP14968pb5eOleTWounK3Qzpyb0e6I25pMYODWBoN3bhSBtuKXkMTtSfzqvUBC2fak6/SpjtcYi
/SgU+ohe+KTgUbjEztx+VLnK4pAHtj8aRj+VPVDD2PrRUNodjgxqDj0oXUmA5XPpV8i2Nuck/tQr
j5cn0pf7VHAKc0vZ22Fz3HjU1JwVwaet+jGpcOpSkhwvUbrxS/ao6OV3HdCrcR4OG5pfOT1qeVlC
h0boea3dD8G6tr7KbW1bYf8AlrJ8qfn3/ConKNJc0jWFOVWSjHc9D8L/AAcga5I1B2uWTBdVyqfn
1NeiR6LpehW4ihjihjUfcQAV4VavKs7dD6XDYWOHWurI4fES6fcpJaR4KnOTxXr+jalHqdnFcRHK
uuceh7iu3BS3THiYaXNRWBp6/ez1r2Y7HjyQ9akU5xitUYslXtVha6InPImQ/jVlPyzW0TEmVuuO
KnTr/KtkZNE8dWFNbRM2Tx1OnpWy3M2WUqeOtEQy1HViP5SO/wBa0RDLUXf0qwlaLchllB1qdT6c
dq0JZKp9q5zxxrbaXpRhiZkuJ/kVkPKr3P8AT8aib0Y4vuefxSTXkyRIFy/G7qx+p612mlraaNa+
TAjz3LDLyJwgPuf8K86o1GNisPepJzYuj283iDUzE0zXW0DCYxGP8fxrqFsYrGYwrB9qmUY3ZxEv
49T+H51z2PQ6iyWLMqy3twbjYdyoSFjj+ijjj1OT71Vk1Axx7bSQXJYkiVyAgyeBwOcf0okxJXK6
2bXCvPeSiRE5MkuFiT354FWYZEZQbLbeN086QERL7gdW/QUl3YxVhQSvc3tx9olTgtIRtj9lHRar
3WrG9ZVtEGwHPnPkD/gI7/yqW+oJXGRaI0n+k3km2NTzcztgD2A/oK1IVVWH2GELtOPtVyuWPuid
vq35VaWl2BIy2lkz3M8mZW+/PMcu3tn+lZNxqk14zfZl8iIHBkYfMfoP8aUgjvdjtE8PTrO0sjsI
H5M0udzH0XPJr0LSdFNyqLBG6xr1ZhgmnCLJm+po6z4S0zUtMmsr+KO8hlUpJDIgZWB7HNfm9+15
+zXF8IdVi13QY3/4Rm+k2GHk/ZJTyFz/AHTzj0xj0rXEU+am7bnI1ZqZ80t1603kZxXz5uIW75pv
brTATjt1obB/KjoAnvSZoXYBOM/SjngfhQAvrTW+7zSGKvbJ4pN3J9KfUS0At+lJnsaLgITzRS5V
Iq9jzzHtmhlDEVoUNKjqCM0qqTnvTF1AqwHJzT4128kYoGS0c0iiW2t5LqRY4Y2kkY4CopJP4Cu+
8MfBbXNcKyXCf2fbtzulGXx/u/44rlr4iNBXlv2OrD4eeIlaOx674Z+Cei6Gokli+1zDnzLjDYPs
OgrqGaz0ndGoV8cBUHIr5urWlWlzSPq6FGFGKjFEL6lJLC3kL5akdVrLa1kuGckbnP8AnrURaTOt
KwLpYjwX5BHQf411Hg7xBHpd6LGRwkUh+XP8LV1Yadpozqx54NHpkUgZQRz3qda+kj5Hz0iTFPSt
kYEyHIqePHrmtUYMmT61YVq6YowZYj5welTR+taxZkyaM1ZVj2rZGROnsKsR9s/jWqIZPH196sof
wrZGZYjzn0q1H+taLYksx/pU8K7c8nk555q1sQWo/TpU8fQdhViHySrBC8jsFRBkk9B714R4i8dN
4i1e5ls0lnhjOyOTyn8vA9GxgnPpXPWnyoap86sbvgnTF1p45C7S3KE7oVYoufXHcdetei28EKr5
MC/a5EGPk4hXtgv3+i/nXnPV3Z200oRtEmtPDNvHeG8nKiYY2Rxr5cUYHov17nJqS88RBWaKyjNz
IvBcEeWPYt3/AAzRzaAldmYsdxqkxa4uGmaP7yKNscY68/4mtXT/ACmUlIvthBwsjcRD/wCK/Dj3
qNZas10WhUv4VkvVuL5t3l8orHbHH9F6CmS+JBN8mmp5pHHnMMRD6H+L8KLi3Fgs3vts1y/nsh3F
3+SNPw6fnU9vdQXGGsYRdspx9okBEI7ZA6v/AC96F3YMsyhldbi9uGlKjJaQ4VPoOgH0rOuvET3U
gi09PlbI+0SD5OPT1puXVismQR6JPfXJmlkeXjBml+VV+np+FdNpllFAqna07rx5kgwM+w/xqI66
sb7HWaLpqXbiSX52X+JhyB6V0zSLbqI4vkQeneu+nGyuc0ndlaVyxOTXn/xs8AxfEr4Y6/oMiK0l
xbN5DN/DKBlG/BgK10Ikrpo/IC8tntLiSGWMxyIxRlYYIIPIPvVU/XFfMSjyyafQuLuk0Mydx55z
Rj5faoGJntQcc807jGZ5OOaXpQC7CHp6Cjtk0hiHr7UcMvvR5CEz2PFG7tjFJbaAJ7Gkz3xVAgPP
aiovYrl5jz/dULEljnpWoxOlWI87cnkUwQ/aN2e1PwPSkVoami+GdT8QzeXp9lLdHOCUX5R9T0Fe
p+F/2dby4Cy6xcCJTz5MHJ/Fj/QV59fFKl7sdWejhsHKs7vSJ694e+Hei+F7cfZrOOI93blz9SeT
WxJeQWqhIk3nPXtXgzk6kuaR9NTpxpxUILQgnkuLpTj5Qeo6CoU0sKwyAxxnnpWdja62D7DHbqzO
wVevoKqXd5HGAIl3f7vAqepSZi3l87LwDtPYVQjtZ5ZcgFQTwfStou2pquyPXPB+tteWMcM7hrmN
QrH+8Oxrq4pN2D+or6OhPngmeBWhyTaJ0YVKp/Ku1HDIkXpip427YzW8TnkTxmrCfrW0WZMnQ7lq
dORz0rZaGD1J48cZqwnt1raJmTI3T1qzGf8ACt0ZFiP61Zjz9KtMgsxHPFWY/wBK0RJZjPT1qzHz
WiIJ4/vVZTrVCRmeIGa6hFjHG0rS8Oo/u964bxFZR2tnBa2kbXse7ZNDaruSFMHkt0644FcFV80j
qh7sbmdp8KRyD5QIsjMeSFbB4z613tn40sZV+x6cglvFHMSABUz6np+XNRUtFaGWHk6l+Yl0+zv9
Y2x3lx9smX70cKbIuvcZzx7n8K2WtbWzCIi/bJMcJCcRL9W/oM1itdTr6jpY/tSj7SU8pekKDCD8
O/41mX/imGENBYR/aJV4LKcRr7Fv8KBL3mY8Wn3GuXO693XYU58kDES++O/1NbNq9qG2W8Rvpl4O
w4hX2L9/oufqKzSuaMr6hYy6pJi6kDQxnIiUlIl/AdT9c1ZttaieHyNPia4dflLgbY1x6n+gzSTB
pIrW+kXWr3J+2P8AalX5gn3Yk/D+pq3PJbQwrb2TJdTNnEn/ACxjPqP7xzjpx71S7sLXNG3jlCxm
6m891GN+Aqj6DtV201C1mkKxzK5U4+XkA/WmjN6nZaPMEtuOp960DIGjXNejD4Tme5Fu6/So2IbI
I+UiqEz8uP2nPhJfeGfjJ4jSyhjSxup/tsO5scSfMeMf3tw/CvJJvBOqxNzHEc+jivBxKSqyNqdO
TirLYiuvB+q2YzJbL+DioYvDeoXCnbGmV/hZwD+tcZp7ObdrE3/CG6srAfZlJY44kX/Gn/8ACC62
f+XH/wAiL/jTSTYnTktbDW8D63nH2AnnHDr/AI0n/CEa2CM2JOf9tf8AGlawlCfYRvBeuKTnT2+m
9f8AGoz4O1k/8w9/puX/ABppByTW6Gt4R1hRk2EmPqP8aV/CGsKjN9gkKg9cj/Gk0r7hyTfQZ/wi
esMu4WEhH1H+NC+EtY/58ZPzFCV1oDjJPYRvCOrx8GxcfRlP9aB4Q1lsEWEh/Ef41SjcOWS3Q5fB
utKcHT5D9CP8aKfJ5itLojybHy/hUbRnPqKChViz1FWFjPQDP0pDR2vhP4Q+JPFjI1vYPBbH/lvc
fIuPYdT+Ve2+Df2YdPsPLm1eRtRm4Oz7sY/DqfxP4V5tbEbxpnsYfB8zU6m3Y9Sh8Oab4dgEUEMU
ESLwkagY/AVXa/luJPLtYMAHBL8H8q8nke7PejZKyKl5ptx52+aViSP9UOT+VSrpipEgRNhByd4B
NTyqO473Qk0kFmf3jZfqM81nTam7bikez3Y9fwrGxqkUprkyYDfNIeAtK2lSzqCcRg8+tKxdwbSY
bWFtx3EDlnrIuNQRMrGCc/xYwKSWppEhsdYnsbyO4jlYMp4Xt7givX9B1qLVrFJo8jIwynqD6V6+
EqfZODGU9OY147jp2NWlkDdeRXtRZ4krWuTxv0yanUj0raJzyROpx2qwrV0RZjInjbj1NWE5reJg
yeP7wA9Knj7Z4NbJmUiynfjmp461iQWY/uirMfNaIgsRDkE1ai+9WiJsWUqyv3hWqIZPH2qcN5aE
9T2ok9ASuyo1rNqC7LyQeST/AKmIbVP+8erfy9qhudUttPzbQxCaRR/q4wOPqegrzpvqdUV0Max8
NR6tdCa5WNvNfIt4QcA9Rk//AKq6G08K6Tpd2JUtxNd/887c/KnHc9B+HPtXOrmnKloi7No8t/M0
lxKYocY+y252Rn/ePVvx49qzbzVIbeRbO3TzpU4KQkfIPf0/GqctASuznLDUrzxBrU1g0bm3ReVi
JYMc9CfTrXRQaTZWcohlRZ5RgfZbdvu/7zDhfp1pLXUp2WxaOny3DFLqRVtscWsIwg+p6t+P5VFq
GuWekr9nhjE83/PKLHy/U9BWmnUz1ZkpHLqlx+/mMiMcraw52fierfy9q1wg00CNIvtNwOEtYjtV
f95ug+nJ9qztctto0Bbm8WE3hVAhLeRCSE/4Fz82PeqGqa1Y283kW8TXl2BxDFjj6seBVadSdb+R
Ra3vtSuNs5Z1HS3i4QfX+9W3pWn21r5iuRNKh5hhPC+zN0H05NSve1Kb7G/o2uwTGXayjY2x1GRt
I7c/5NdDaXAmhVs5716NF3VjjmrakzSdDjApjelaCPln9szwj5r6Jr0S8fNaTEe/zJ/Jvzr5YaxD
TKztnaOK8nFL3ztoyfKJfecqbooVm/2WbFUb7RRcRDYmx26+1cUopq50a3M4WOo2bFYz5qLyAetW
LXxFJDhbpCv+9WeiHd7M2otQguowVIJ71PGwk5U5rXpqLXckMeVJ/pTF2Ar2/rTjG+4nKxI0a+Xz
yO9R7MJ0zkYHpUTjYqLGRAOGUL9aVVHpxV0opp3M6jDywu3Kr1/OnxRrl1HBzWiS5tBa21ZYhhYA
kjNFXJLqCeh8bbTxVvT9LutUukt7S3kuZ26RxIWJ/AV5zko6szjFyaSPXPBn7MniHX9kupFdLgY8
pw8mPw4H5/hX0D4J/Z58OeEljl+zLcXK8m4uDub688D8MV5dSu6r5Y7Ht4fC+z9+e53eyxsF2QRi
Ujsg6fjVZlvb59tvG/skY6/U1jy9EenfS7BdDWP/AF7hnPO2LDH8T0FWjbxW6FY41iHdh1/OrcOX
1JvzGHfSwR5SJlaU89M/nWPeXEzZCrj0C8k1ySi2zeL0M2PQJprje7OhPVTkmrr6H+7buf1qOSy8
yua5labbyafHI98UE0h+WJfmK+2e/rUsl1LIv7tdnOMsM/pWUkuhqtrlGSzaaSRXkMjYyVY5P4Dt
VWTw3LcITIvlr+tRtqNMpTaPDpXzPuJ6fMcmtDRfEw0m4XajGFjh/wDGtKU3GaZpKPPBpnokOoJN
Gro4ZGGQwqWPVWhIzyK+ljK6ufOzja6NOz1SGcABxu9O9akTjseM10RkcsolmNt31zVmNua6Ys5W
u5NHVmM561vExZYj5qxH0zitomTLEfSrEfY9a2RmyylWo60RBYjFWY8/jWiILUfpVhO1aklmFd30
qK71a2syy582YDIhQZY/h6VnOVkVGN2ZE0epasxE/wDoyPx9ntnJY89347en51p6boUFrLsnfhzk
WsYBb/6w9zXA3dnVHQ3YtLV4Wgx5NqT/AKqMkFuf4m6n6DAovNQstHjEOArKMLDEOfwHYVDBe8Y0
002qcyytBA//ACwjb5jz3bt+FPm0m0sbdEY+T/ELeFQZX9SR2+pxWfxGuqLdrpshh2W8aabaP96K
H77j/af/AAxSXV3Y6HGqBcvn5YolyfrgfzqjPc5+/vL3Um2Fms4ycLFC2Xf6nt+H51Jb6NHCyLNi
MkjMMeC+CeuP8aS952NPhRJa2t3cSSrHCNOtlcqEHMkwHGS+eB7DH1NO1LXrfw/CgI82UjC28Iy5
+g/rWsrdDKPvaHM6lqd7rV5Cs9xJp8ZOFt4XwxPT5mHXr0H51u6aLfSo4baZTG6qP3EagySe+PT3
NZJ3NHtY14I769yJMWFsT/qYXJd1/wBt/wCgwPrU+oTWmm6eIA6wKRtVY8ZJ9AK00tcz32K2jwCE
+YlqvzD70vzOR/IfQV2OnaoIpUgkjEJVQ21fQ5x/I1vSnZmU43NrzkkjJU5XqDStJ09xXWZHm37Q
Xhl/FHwp123gTfdwwm6txjJ3x/MB+OMfjX5pXHjaVTkBGavKx8nBxaPSwcVO6Y2HxlI2T8gNTDxi
27lVP414vtnsek6Ca0GyeOiuVaFcezU2x8RW2qXCQPF984znNaRqcxlKiormZpyaS0Db4GaMj0qe
G6vLY7jH5ynjcvBrZeZxy0L8fiBYtqyRtg/eDcUq3cMgGeCemK6IaGTaloPW+W3b5zvQnGatMyTR
hkbjkgDnFDs3YuN7ambb3ytesuTnGCK01YfNwelVRFUK15qC+YIFX95gYFS2fmR3P7wAqw7etH2r
A/hNI3EcKhmbaPeitpWvYzV7HHeDP2Sot6S63ePdY5MMA8tPoT1P4Yr3LQfhzofgux2WVpa2a45+
UDd7k9TXytSUqru9ux9DQw8aPmzdTV4dwhtIQxxneRgCp4dHvdWOZflT+8x2p7fWrjDsdDfLr1NK
PQLGyRi5N1J325Rf8TSSKiQlMJHGvOFG0Vo0o6IzjeW5izapB53kwL5r+o+6PTmqV1YXeoblXcy4
5VOAPqa53FyehtdRM7+xx5wQBpdvUx8J9N3f8AaveSixtGsCQKRzt6n6k1fLyrQXNd6mVcalZWRK
KTLJ/dj5/WqEn2i+4GV7iOPk/jXM1fQ3Wm4yPw/jLynaP7oO5/8A61SR6UVkfbHsHZsZJ/HtWTp2
9Sua5A1lb2EjuiqJG+/tHzNVPULy4I2QqsOedzDP6Vzvc1KM2kedteXl27tyfwFZd54fkkbCqY1H
fuai1tzSMi1Y6p/YCiORiYfQnkH2rUbxJZNHv89UOM4bivQw9e0bSOavR5nzxRial46s7VS0cpkb
ts6fnVPTfjFr1reRqLCO9smODvfYyj13c5/KuyFe0rdDilR01R6ho/xI0zUdod2tJccibhc+ma7K
zvY7yNWjdWzz8pBz9K9SlVjPY8ytRdMvxnpnmrMbflXctTgkWV5AqxGetbRM2WY88VPH94etboyL
cfarUZ6VaILC+g+lWE9+K2RJaj9cVOnPFMgivrxgpt7cM0jcEryRmrmmeGxbxqbmT7NuOdoGZH/D
/GsJvmdjaOiNqO3VYjFDGbeLu2cyP9T2/CqzNY6CuZZVhVmCqCcs7Ht6k1i12LuZM/iia5uPJh/0
aM9GYgyMM+nQD9fpV200EQwmeZlhR2zuY5d/p3Nc8ryZsrJIu2xeFj9ltxap/wA9JMNIx/ko+nNR
3F9ZaHE8ty6pvbPTLMf5k09hb6GVfeIJ73iENa25/iI/eEH27fj+VQrZwWNu1xI62kL9ZpTlnP8A
Nqh3loXsTW0P2zabSJrYZz9qlAMh4xlQeF71oeVb6WJJ5pV6fNI5yx+pNWtCN9EYl5ql1qkzCxb7
JbLy0z4LOP8AZHb6n8qzV8PpaytcyD7PE5+a5mJJb8f4j7VDfNoikuUvxxnci2sEiZG4XUqfvP8A
gI6L9Tk09YH09WnJWNc/NLM3zN7sx60X0sg0Fl8RXd/a7NPiC5X/AI+ZRjn2X+p4+tP0nw5Jbxm8
1CfJUEy3U7AKB/T8Pyq03LRCaUUbNnetOzJp0RjiH/L5On3v9xD/ADb8qsWrRw+dLJIxYH55ZScn
gc5P17cVrp0MfJF2z8QW6sFSbdn1Bwa3YrxLleGw3XbXVTldGUo8o66jW4t5I3G4MCCDX5J/GT4c
3/gr4m+ItISL/R4LxzBg/wDLJjuT/wAdIrHFw56Rrh6ns53OHOk6irH5GH41C1nqMfPlufWvDdI9
KOJfQjEV9IxBgkJ+lXtHivrfUoH8tkCsCSRxSjTsxTr8yseqW98rxrnuOc09rgKpQfhXY7X1Oe/c
akouY9jpuPemtZhlCohVgOtEb9CJJPUrQ6HcxyShp2eKTPyN2NS2lvc2R2FNqL0wabi0wi3p1Et7
dobwzBjuIxV83jMzI3HHUdauHu3aHK8tGZjWLDUBdJMxAG0qTwfetLTmFtGF3Mecjcc9amOkrsjW
xFfNPeX+JB+4UZ+91P0oqJOV9GdMY3R9EtJczgrAnlZ6Ki5akTw3K0hkvZ9j9Nn35CPcdvxrwYx5
t9j33JLRbm5p9hBp9uPKtlEnUyTAO3+FSXF4qtumk5xgD/CtebSyM+tzLe58yYyIgTjHmSdcfSo1
06XUAJD8yE/fkO1az5XLYtvlLEGk2tsQdhumAyT91M9uOpFQ3Ucrysbh0W0wMRYwqkHrjpW2kdIk
X194xL3VxGxS3j81VHLdAKx2gvtakEah3BPPl8L+NQo30RtdKN2aNt4Rt7YbppPMbvHFj9W/wqz/
AGeqxuiRJFG3VUGM/U9TU8qgrIlSb1ZVc28OVX94y/wx1nXDXFx8sUZXnlIhk/nWDj2N/UhXQ3Vi
JP3bnkoBuf8AH0/GlXQ5VYtsWIf99N+f+FZezUdepSnzFeaKCxyZWG/svVjWVc3k8zkJF5S9MtyT
XK4vc2TsZtxoKzReY/ybjwzck/QVmXHha6kUjZ5cbdWYc/l2qFCyuzRTv7plSeE7a3XczYIPVzya
rPDHGxSI79o61pGb6kchVMZeQiSRl4+lanhtdQ0u/F7p1xcxFePvssR9yveuqlXcXcxqUlI978J+
KE1y3VJ9sV4o+eMdG9x/hXUx9M96+mo1FUimfNV6bpyaLUfarERyBXZHU5NizH+tWIuOlbJmLLcO
PWrUY/KrJLCtjFTq4GO9aJkEqvjqcCrghk4MrfZYcA7nB3N/ujvTk7IcVdmjZwsmBbR+QhHM0gzK
307LVua4tNHtWnuZwiAfNJI3P5msfNl/FoigniT+0lBtMRQN0mk+8fov+NQTaTJIDOZAkIH7y6nP
P0H+ArFvmdkaW5d0S2drZRQpLChmmYAmSRcEehCnv9fyqeCKHS1e6u7gnIy09w3P69B7dKckkhXb
ZTv/ABA1wjR2qYi6GaQYB91HeoLbR2kxdSBpyvW4uCCqD+n4Vz7vQ2WiLyhIn/0CCOaY/euJh8g9
lXv+NOuNGh843947S3ITG9jwo7gDsKrpYk5V/GBZ3isI2codpmmGF/D1psdnd67MJlZ5XAyWfARf
fngVjdt2NbKOpt6fZfZYyloBeTHrM/EKe4/vfy966KOzRo1kuX8+RRwzADb9B2raKWxjJ3MfUvEs
as0FhD9qmU4Lf8s0+revsOay7exudSu0e7DXsn8K4/dp/ur6+5yaT10Q0lHc3LW1gjmeONRc3IHO
0Yjjb/abufYfpViHSXklWe+uWuZV+4gG2KP/AHU/qcn3rWKtoRJ2H32sQWiGKMedL/cT+p7VjSWd
5qm1rg+bIx+WNMlF/wAfqaUn0Qkrbl6309YZwkhNxOnJjjHyqf8Abb19hzXQLubBPynr8nAH0qoX
iKWpehumVV8z51/vDqPrXxx+2x4XGm+KtK1+GNTFfwGGRgP+WidPzU/+O12S96m7GEdJK58zMV2g
7Dn3oS3R2BI4rxeVs7lJRWhYjt4lQfKB9KlWOMKD5fze1aez6EuSsWIQCwAG0Zq6tv8AMC3610Rp
33MnPsToqqenFXImVlPAHpWijykXZSvtctrJgrNvc9FXk1mLrRvZnVcpj2rnnK+iN49+pdt9zNkf
d+lW2SOZh2PTNaQjoS5dSy1jF5YVRg96q3Ft5cZdByp71o4IzTfUpw3BuZmVfvLwc0Vzr3lc6Obl
0PqZbiSFhGq+RGw5MXGPqScms/8AtyyhlkitiLi5ySViHf3PSvnXLoj6NJbmfNquqXjBDi0G3cVi
Bdz6jOK1bO1diElJibPII3v0zyO34mlFc2o5SWyNS3tYoMPHFtkHRnwx/LoKr3l9b2Xz3Eg3E8dy
SfQVfNpZEJXd+pjzeJJpmMdrB5Kj/lrN1PuF/PrVX+ybzVGR55CQCTulbYv4DvQk5WsP4Vc0F0ey
tSuUa8cdQfkjH4dT+lF5MVjw7JHEvRFAVRx6Vv8ACrIzV27sxpdcgVsW+bl/9n7o981WKz6tcbRu
kZuPLi4UfWsHd7G91Hc1bTw/FAF8yQBB/wAsYACfxbp+Wa0JII/L8u3iW2j7hOp+p6mq5VFeZndy
d3sZd1LbWeUX53H8KDJqgoub5gpxCjHG1eWNYuOhutELceCSu15G+yI3JzzIfoKhv9PstJs2k8vy
goy08uC/4DoDUuHItQUnN2WxzR8UaTpsmzy5GBHyzScl2P8ACO+aVtWuL6FmTT2hUfxSHJ/If1rl
lFvU30iYVx4dvNSV7iW3aBVG7zJOB9B+dUY/Cd5Mh+zR7h1MzjA/AdTUeza3L9ougHwxHpUZmug0
rKOrDj8qis/EELW7tDAwjUlVyMDisLNm1+ZasmsNamaZblJDHIjZXyzjmvY/BHi6LxJavG7L9rh2
iUduc4I/I17OAqNPkZ5eOpKUOZdDrl/OrMZr6SNj5xlpPmUcVPF0rUwLUPT2q0nOa1WpDRJ5ixrl
221dtrO4uFV/L8iAnmab5fyHU07hY0dPV4UP2eNhLuwLi4ALbfVVBwPx5qxI0GnqZ7uQ7jyZJDkn
6mk2PyRXk1qS8hAsFPln/ltIMD8B3qmvhQa1EJbz/SBDh2lnbEa49ewrCXvOxtH3TXht7eJ1NnFH
dyKMec6kRr9B1b+VUr611SGcXMl5DMV6faOFQewAx/Kpd1ohp2eu5XXxVLMqQ28Kyv0+0lSsJPty
SfwoWwl1G6jZ86hIpyN4/dxf7QHT+dS77AkWvJtPtC7Wa/mAI/d8Qrz3bv0PStSS1+0PG8+XCD5Y
1JCL0/h6fiamOg2ynd63Dp6tFAPtNyP4I+g9ye1c5cNqeqMou5BIQSfJhyqeoHJ5/Gk5aWGtEXV0
2O3dEmj8ybbkWsYzz23Hoo/Wt220qWbabl0jgH3baHIQfX1/GlFCkxdS16y02PyS2ZSMLFFjd+Xa
ufl1a61SXyroeVbbsLFE+C3H8RHJ/D9ap6MEtDWtNGW1aAzH7PBgmO3jGZG+g7D68Vsrbs8JhCLa
25/5ZREgsP8Aabqfp0qoq3qKTG3moWej24MriIDhVUZJ+gFYF5qF9rQKJm0tWH3Vb9631I6fh+dD
lZWFFdWTWtpBo9qrXatawsfkVctJIx/uqOTWi1vcXeVVnsrMjBjjbEj/AO846D2X8zTj36g/Inmu
rTRbPJKwxJ0C/wAgPWs6TWbvUYyYgbSE9Cw+dh9O386JSsJR6mnpcDw7ZJZvLjLYDydW9h6mua+L
fwvtfix4Y/syeaSylSTz7eZQG2SAEDI7ggnNdFOXKtTGab2PhP4jfDHXfhjrBsNbttgYnyLqMExT
D1U+vseRXJnhhhj+dTKKjsRGTktdyX+EZNTQyKq/eHAoVluPVuw/7UqKW68dqmTUjKvyqenSr577
CS1sx5uJRHubA9ST0rKvvEDtvit3z23DtXPUk0rGkVdmXaq25S5LP3JPNdBY2wCb2+9WVKPM22aS
ly6GlHP5a4WrtvIvHfNehFJnPLUleTaDnrVKa7Zsxt06ioqdyoa6GR9qWx1ASqvyN1orkhaOjOjf
ofS8kN5q6gyBnTOSqZVAPc/41f0vSLYQgpl2z92DAA+rEfTpmvm4w6s+llLojXjtlt2YptgDDG1S
cnr1J57msttettIUx3EkcszOQiW6HhewPXH1OKvmJUSJ9UvNU3RxD7LngADc9Sf2IYWElz+7kK91
LyH8P8aiK5htpaIW3thbo7JbBZs4Esp3tj1A6KfzpLjyrIG4uZsuRjdIxJ+g/wDrVtzKK02Js27m
JceJ/OLC1iYAdZZBx+A71mw6Rd6nNJOzSzKeWkmO2NR7dqHeWiHpDU1bfR7Tyw4Z7p+hJzGn4cZP
6VqW/wDo9uI8hYR1VRgfj6/jVaRVkRZyepTvNagj4gzcEHnZjH4mqka3eqTZ82QKwx5MI/qOTSu3
saLTVmtDoUUcYW4cQ9/Kj+Zj9SOBV2NY7KMeQiwxj7zfxn6n/Crso+pF+b0OH8U+MDpN5ve6kcOM
JaxR7nY5HPr/AE5rB1C6ufFEYUxMquvyiQ7m9xgcCuaV3odMdNSxoXg+48wTTw/Zl6edcEjPrjP9
K7O20VrZttvDHIWH+vn6A/7Kd/qTWsaaW5lKpzXSLMnh2Da095MZpBk+ZMeF+g6AfSsG61CGOUxW
dtJdDbkzdIgc9M9z9KynDqyoyKjeH31oBSrXbf3Y1wgPof8A65rM1LwCTMEC5Y8lI/uj6muaVG+r
N1UtoU1+H0kb7nUuoORGvC//AF61NLvv+Edu1AT2aNF6j0pU7wmmOVqkXFno+l61Z6hCpjmUNj/V
ucMPbFaX2iONiC4+ma+phNNXPm6lKUXZolTUIlx849aW48RWVigeWXHYDHJ+nrW/tIpanP7NvREc
fi7zv9TZykdjJx/LNbeiWWta4ouJGisbHu5UjP0J6/hUxm5OyHKEYK71Z1Njp0dqhFsrNMR/x9XA
yR/uqf61ZWEW6eZNcPIyjBmmYZPvnp/SutbHM9zPbWZWuJRZB3TAAlcDYD7dz/LisfTY31vVb2OF
JLm7hKvJKyERrxjqeO31rGTbdkbRtFXZ1uj2NraxyGL/AEuRmzt5EQP17/hxVySGS6b9+4ZR/wAs
14jX6LStZE311M3UdeFuBHaR/aJ84wuAq+5NZMljdarIgvM3soIIgjGI1PuO/wCNQ30RSXKi+yxW
sgiljae6Xpa25B2n0duij9avQ2F5I+bl9lv/AA2kPEY/3u7fjx7UttQuN1TWrfSVCoVa5YYjiAzn
8B2rMuNRv7/YJSsEb/8ALOEncR7t2/D86jm7Fpdy+dPhtY4nnU28WQAka7nc+mP6mtOOEzRMI4zZ
xNwdrZkYe57fh+dUl95DaI7yaz0S1E0uIoo8D5RzXNah40l1CY29kfs0QOGlYfPj2GOPx/Kpk0kV
GPNqy9ofhw3H74A7GO55pjx9cnrXR29nFbuPs8e1u1xIBuH+6O31NKKvqEtdCyscNqHdnyW5aSQ8
n6msDV/E5VvKsgGPQzMMqPoOprSTUUJR5ndlXTdIk1KR5AWupOczSdvbPQCuh0/ToLFQYQs84485
x8g+g7/Xp9aiCcndjlJbCtbqsjSynzZR/wAtZOWx6Z9Kyb/xEsYaKyAmkHG/+FT7nv8AQVcnbUzj
HmZQ0/SZru6MsrPdXB5Jk5Cf7o7VrRqu5UgRbyZTh358mM+/94+w496iN5astmzDYqG+1XD+ZIq4
82TACj0A6AfSljvprwg2MPmRf893OFb/AHR3+vSulXMHbdjPF3gHTviF4Zm0nXrNLq1lTngB4m7O
rdiPWvzs+MHwt1D4S+MbjR7wmWD/AFtrdYwJoSeD9R0I9R7iunl5oo572lc4njrn2NMkIQfKSfWs
nGxW4hmyOuBWnZSIq7+CDUxSTKuYuua4ZmMMJ2oOtULWJpiGIwK5KnvysjeL5Y6mzbwiFQ2OetXl
uP3eP4a7KcOU53K7uPtr4KuMZx71egufM+YDbzW8FroQ33LyXPUnjtVO+nxwD1zU1VoyqZhapMd0
Tdg1Fee48zOhyZ9cTa9psF/Fpd7fxtdGMyrbsMAIONxAGAPrTrjxDDCuyxj+0sOMpwg/H0+lfPvu
fUKPUy2/tTWLhIndmZicQxjav59/xNalr4Zit2USEEDnybYAj8W6D8KlRuryE5LZG3b2vkxNHEqw
I3Xyx8x+rdar3d1a6bGxklVeMkdTTEkcreeMFuLgw2y+Xzy8nXHrikXR7q8YTzOYhIMAzHLN67V6
0knLQp2galloVvbrxDvkB4aXkfUKP61LdWYwJJWwV6Fug+npWt0lZGe7uzNmunClbePzSP424X/E
1VisLvUgBMTKf4kjBEY/+t9aSuyrpIsWem2izOJJzMFAAhhXC5/3+hHTpmrtrHNHuTesMJPEMC7R
+LdTWytFW6mWsteg2+1CGxiIU7pu0ajcfyFYmoLeao0eZGtY85IVsk/0H61jLsbx0VyOx8JxXW58
LCucPPNy7cenU9q0NH8L2PhlkazGN7g7rnBJY9gM8Z9K0jHl1e5k5c2i2J9U1ix0mZrvVnKjdtSR
zu9Og7f/AFqguvG8LbfsFtJPGybvtDDYgz068n8BTbsi4q9rGTFNqOrX8EMdrLqSOCXmd9sUXOck
dD/9auns9Ls/tGLrzbt16rGdsQ9t3f8AChRW7E5Xbii9FJbahH5MbxLbxNzbwEBVPUZx3+tRXV9Z
2/yqPOYcbIxn9e1DswimiIWMurcSfLE33IYup+pq1YeFbSSMpMY4th2vGBmQ1Kp3B1LbGlD4RiXA
tYUhizxIPmkP49vwpt14ZsdLUyO2xu7E5LV1x8jll72j3KUlncXQKwq1tB/z1kXk/Qf41t6T8OFl
Anc7F24e5uG+X9f6VvGPM7HLN8q0Oo0vQrPS2QQQ/aXzuM8i4UfRf8a29mZDJI2T2Ldh6DsBXoQi
oo4Z3bKF1riRztHar5suMbs/IKzGs9R1yRTMGlRTkxpkKPy/qaU59EEY2V2btrZW0a5ZWnnB3GGJ
gEz/ALTD+Qq5ErSJhlAgJ4t4V2oAPUdz7mktBsS+16300CPBaXH+rQZP/wBasaSS81aYbmdIu0MX
Q/U9TSlLsEY21ZsQ6LDbxIZ38oDkW6DLn8O341NIJ5/3MGLG1Iw/ln94/wBW/wAKSFruCW1npceF
2w7emBjP+NULvWLm+BhtsWkfeVhlz9B2qZPlRUFfVkGn+G2EJkLrDu+9cTdz/M1r2+liwt0FmA0p
PzXEy8j/AHR2/GojHqXJ30Jra1ht1eYvuZuXmkOWP1JrLuPEk014tvYQ+dHg7rrIEansPUnr09Kd
7bitdkK6TNdz+ZK8lxO3I3dB7AdhVhfD1u0cwj2yTuDggfIrdMn1wewrPl5tWO5uafZSwW8SXEiz
SRrjcqhVH0HaqOs+JrTSYyNyy3A6RqeR9fSt9kZpOTMWO6l1qU+a4Y5BSFTlfy71r2fh+JJGN1kk
f8slI3A+/oPrWXxs0fuo2jaKyqjbUhXlYVHyg+vufrUV9qUFip3t83ZR1NbXtqZWu9DnrrVJtTyh
Hlxn+FTnP1NW7fS7e1jVrgLEWHyxRr+8f6D+tZfG/I1+HQ0dPt5JkKFPstuRj7ODkt7s3f6dKsXV
9b6eUt44zcXTDKW8Q5+p/uj3NbRRk7fIks9Jm1JftGpFZNvK2iZ8ofX+8frx7VvHZb24LosagYx6
CuqCOeTuWdLWSZTI3yQdt3Vv8BXgn7aHguLxB8OpNWSBXu9LdZQ4HzCMkK4z6YIP/Aa64rRIwerZ
8CZHOB0qNWzkdAetcnqVe2xHNsX6VRudZEKeTCPm7elYynyplxjd3KdjZvNJvcnHXnvW/GscCrhe
MYrGiteZl1H0JJpi20KMDHemgN5eCW2j0rqvrYx2WhNH8smNu0YrRhk2xjHAropolk/njHXB9DUF
5N8hOc1Uvhdio3RzuqTtt2jopzRXlzWuh0Xdj6rtdIu9UuUvJ/uKuJJp12fL7cc/h610lnZwiNTF
A9wOD5swMSD/AID94/jivBjHW8j6Vy6RNeONzAGmJcLwI4wFX8v8aoat4ps9IULGDdSZC+XDg4+v
PFJ9mCXYyYtcv9YKmN1RWx+4t8s30J/+sKc+jysrfbT5LHIMcZ3yf4D8TSUGxylbREuh6KlhITDA
kGBguw3SH33dvwrTma009d08ih2PBb7xP9aNNugvUzj4k+1SyRW0W3Z955eMfhTrfT5NWZpdryhD
gvIdqD3yeKSjzbFOXLuX102NIyEj+0SDA3OSsY9/U/p9aG0uSSPbcSh1/wCeaKEjH4d/xzWukVZE
ayd2Yuo30NnI1vCDNPjO2MZx9a5KH7at5vaedlmbHlqTnrjFS9ZKxtF8qdzoYdGuIZi0yJaW+N2w
ZMjcen+NTwWl9NOn2eMWcQ+YSnDyN+fA/WtlHl3MObmL9vpcWn25e9lV5MktLJwTzmqFxfSyfLZp
hM8yyEgf8BHU02EWZ1roNzrmrKZITcvEPlnmUbU9x2Brej8K2sMymeT7fJySF+WMegJ6n8KmMb6y
CVTW0TRjsvMjKMVWHPyxoMKP8fxqjcatbwSSW8CfapF4ZY+g9iavlJW5m2uitKyiOEW8O/cbWzG0
MTxliMZrobLQILectcMLfjasMXLnr/D2/GnGPMKU1FWR0ljaeR/qIfs69N2cvj3Pb8Kne3stPTzJ
mUFv73JY+w7muhR0MLu5El9PcZW1iMMf99xz+A/xqza+H2ulE5G8hSGuLjoPXr0/CtI07szlOyLV
vZ29qxEMZvJVbmWYFYh9F6t/KtCK1aSQzzSO7cEKx+VfoOgraKS2MG9dTG1TXNUTV7WLTY4JrYbv
tAfPHpgjj8Oa1ra3vNTlXzh5o7RIvy//AF/xp83RCslqzVj0i3tJFWYB3xnyIeue249BVyMSTZjc
rFEOPJjGFP1J61VrEb6kN5cW2m4USDcekSjk1kot1cKqj/RIc/6uNtzHvy3+H51DlYFHqyzb+EUZ
Xkmf7PCc4Yglj9O5q/plnNZQtHE+3d1m2gOR7D+H9aIprVg3cla2hsYS5fp8zM7ZP4k1m3erOyqL
NMKeDK/T8B3qnKyEot7kNrYz3pZgrSSD70rnhffPYVe02GHz2eP/AEmU/Iskq4jGM/dB5b+VRre7
G0jXSzfcpmlad1GQ7AAD6AdKp3muW8DPChM8y8GNRjH1PSnew1G5nNFcajhrgDyyP9QOVPv7/jWp
b6bFAyrMNgxuWFB8x/w/Gs17zuPbREs1vLMxIbyIQMCGPo3+8e/8qfcXtrpttumYIB/Djk/QVroR
vojA1TXL3UMx23+iwnjJPzn/AArLGjvdImVCxnrLj06+5NZtuWhrpE6PQNMFkpeKJoGJIMkmDI3v
xwua1Xmisoycqg6sTgfjWnwoy+I5+88TS3jNFZHA6Gduf++R3+tU7DT7y4upVZmYvwZpDxj1PtUt
uTsilaKOnsNPhsI18n97J3mYcD6Dv+NPdLWxY3E7qhY8yyHkn0z/AErRLl0M9WV47681ptlmj2dm
CQbh1xI/+6pHH1P5HrXQ6ToMNjD8qBiTkuclmPqxPJNdEI3MJPojSbOPLiQu+ccdB9fSpo9PKyef
cuJHxgJj5V+g712RjYwk+wtxebQccD2rz34rlNY8A+I7VhvEthOuD/uH+taozPzLkXazqPWq8zIq
nccGuSXuvUaV0jIvr5pAYoefem6fpDyyAv8Ad7150nzy0OpWijpLWwAYBRkCluEWNiO9dygowujl
cnKRVUj5lc8HpU9uwZOvXmsudc1ma290SNtsnJzzWgsbPjDduK6IPVpGTVtRzH938y4P1qAqWXnk
VbvsC7mReQmSNhjn6UV50tzsp6o+17HULd7MXLs8ca8BrkbGGDjoelVpvEQnYLZQvKCcb2G1T7+t
eG5H0cYoqzyajfsVWNrg90DbEUdzn/GqCeG0munnubia8cn5IYPkiUehfHP69azSvrIHLpE3bHTG
ij25S3j7R2qlP++m6mi+1bT9FjxI6qQOI0GT+QrWTuiIrXQ5iTxZqd0XQRQ2qMx8tlyzFc8E54Bq
rNa3UMazTtKWlbCtIcsckn5R1IrPl5jVtROm0TRpY2UrbknA/eXWMA46hB1/4ER9K6aO3EEY8yTc
UGcnAA+gHArfZWRhfmd2Zd54giXctrGbt14+U4XPpmsi4n1DWPkYsgb/AJZwjgf1NZmqJbfR4osr
PJ8+MeTBgsc+vpUU3hO51W6spVkl06O2l8wLbylWkxxhz3HsPSmly69SXK+x08ltp+kwhp5EVm7u
cs5x+ZNc9qHiRWkEVjFtJOPMkB4/4D/jWhHmUX0+Qxte3UrmNT/rrjgA+ij/AArasdHtoRG2x7ts
BsNlUH9TTj3kEpdEaslqZmDMxVdu1Y1G1QPoP61lzahHZs0cf+lyj+GPoPqa19SI+RmnT9R1SZg9
zMqOfltYl4H4gZOfrj2rasfChttwvQIwuNscZzIfX6UKPMKU7aI3bO1B2my3WkSFkbaBvc+7Yz+V
TXF1Y6NErTukWeOmSxP863ikYb6GdJr1zcytHbp5EI/5aSDk/Qdvxq3pOhzXDC4LNISMtcTsMAfX
t06CiOrshykkjctY4IZv9Hia7bvJJ8sQPsOrfpWwbdrgq8ztIQMBeiL9FHFdC2scsvMz7/WLS2jM
MbCSZ+AseCAfc1haXpmoSKqXupTXy7jiNcL1PfAGcfhUybuaR91ao34dNh09kW7bZJ1EEI3St+HY
cd621aaWMRxL9jtsYMcZ+dv95uv5U4+76kS1t2IpdStNFh/ekIOyjkn8Ky7rUL7VFyjfYrfOR0Mj
D+QpOXQcVZ3YQaS6RyXcri3t1G6SaUE5/wAa0LO+L8Wdv+7H/L1OMkn1Ve34/lQtNxN8xfit/s6G
aeZn45aRsk/iay5PEhVmS2Rrg5I3nAUH698VbdkQtXdlFRNqVwBK3mzZyF/hB9h/Wtuzsba3hXzE
aebPMKkYX6n8O1Qld3ZbeljThtvOk/eNtiUfLbx8Rr+Hc+5ovL6DT1UsxDHooGSfwqn3M7GDJrFz
qEhgjVrdD/ED8359qtWWgyCHccQRsQfMc8n1471l8Rp8JpWsItQWhOH5HmHrj2Hal+2xwbyRk5yT
/U1psRuZGoeJGfMVnh2P/LQj5fw9aoWNnLql0VZjPKOSWONo9fYVEm27I0Xuq7N+00m2t8E/6TKP
4j/q1/8Aiv5Vb+xx+Z5udz9mwOPp6VcY2MWzM1TXIrNmjjk8yfHEajOPr6Vy999o1Jl+1SMVzlIl
7/41nN9DaCtubuj6Cf8AW3Ay3G2FeCR7+ldFBp4ZAsgGwHcsQHyqf6n3NawiYTld6FO/1qG3mNra
Rm9vu8UZ4T3Y9hSab4bmvJku9XcXUwfdFHt/dxe6j19zz9K2jG5Enyq3U6WNI7dQAQgPtWlY2s9w
gLfuIj1OPmP09K66cbO5zSeljQkuI7eIJGqqo7Csm61DqSSBXSZGLcaiJQQrVz3iJTNoOpR55e3k
X81NMD8x766CTPsHOazzDJdN83FeRWm5TaR004pJMuw6ai++O9XbeH94QDn8KimrBLzNHZ5fTjjN
Ub2FtwPZq7ZOyMbIjW3Jj3d+1OaLEakZ5HIrLkW7DmHQQCTp0/zxWr5Zjj3FRjHrWkY21E3ciZVl
wwBI9qik+YHA2mrbQW0ujPuopFmUgfJjmiuWSuzaO259XW2i3upbJHlxGW5luOFA74/+tWquhx2Z
HlMLmYE7WYFYh+AOW/Svn4x5VzSPppS5pWRo/Z2mjUTybgOigBUH/AR/WsfVPFGl6SPLe5jLgZCg
gDg+vTvVMmKvojnLvxBqGqXSpA2IiOUt2ycHoc47/hRHaw26j7ZKLeQj5IFHmTNn/ZHr6nFEYuW4
pSUdtzW0/wAPyyXRlgi+yR/89JiJJW/A/Kv61tw6RZaS7Xs0zJLj55p5Cc9+5qrdEQrvVlV/GD3F
55emWyzW2wk3UzFRu7ALjJ/Soo7e61SQm8b7TMCdoQbUUZ9P8aVnsjTRamklnb28irIzTzqCTHD0
H1b+gos2fUZJoSj28KdIkBAI9S38VPSOi3JXvK7JNRvLbw/bxxwmNJXYBEKM2eRkAKM5xmszVvEl
3NsFsv2GLn743SHjsM4H45+lALTVmZa+HrjWpTLtMC/ekvJjlmyemeuPYcVtx+FVs4ymn/PcYz9q
uBkD/dXv+NXbTUi93psbWnaPuYT3jtcTLwrSYwOnQAY7VPdalCrbLdBPJ0JX7o/GjzY1voVPs8+o
M6SFpznHkRjC/wD160bHwn5EvmTosC940ALn2HpVpOW5nKVtjXaGOzhxABap/E+BvP1NZ9xc29nb
+czGFM4DScFvwPNbXMl5ECX17cFEhiEMLn/XMvzDjritC28HvcFZd7zuPvTTYwB/ICqtzCcuUvW+
jwWvKKt2+c7mXCD1wO9WZLdn/eTDzmUZVThVX6DoKvbYz31Zz/jC4vLjS3ttCuQmpPjayfwjI6nt
TvCun6zHpcMGsap9vugfmWEbe/3ScAn9KtTVrW1ItK+pqarYppNmZp0eEEYW1gjMkr/RR0+pwK09
BvGi09GeD7DNMOfm3SLntuxwaS93V7j+LQpM2neHZGkkkVWY/NJIcsSenzd6WTxBc6hGBZRG3RuP
OmXH4he9Tfcvl2bG6fpMtxveUGeVuXuZhgKPTPpWtYrFCrx2iC4lX5RJIuIlPsOrfyqox+0yJS6F
6y09iAbu4e7cdHkxgewAAAH4Uy81y1s2aOFPPnA+6nQfU9q103ZlZyZgXU11q1yBMzMhP+qi+6P8
a07bS47dR9rlCD+GGMZc/X0H1rNa7mj00RpWsgeJo0iSCHGCF5Y/VqjmvrXTIMkrGi8cEDFX0Mra
2RVh1+4vmdIovIhxhZX4ZvcD/GlhsUn3MmWb+OZz/Mmsm+bQ1so6liG3ihkVoj57/wDPRvu/gO9W
ZrqWSMkygy443cgfgKuKshO5iat4kihV7eB2aQDBCDp+NYn2ybUMK8rYzxGOc/X1rKUruxoo6Gku
hTWKRSTwvNIWA+zRth8HuT/CPrXU2tiIoVUjZEAf3S9D/vHua2jHuYylfYh1bUotPtziRUPQLnk/
Qd65yTWr3UFMUY+zqBt3fxt/h0qZS1HGOl2M0Lw9dBvNmVYkzhnLHH/1zXVR6XFHgQKY+MGb/lof
p/dojF7ilJN6bFiR7XRbXfK4jjHqeSf6ms5ZNT8TT+Vbs2m2GPmkIxM49h/CP1+lbJdDPZczOk0v
w3Z6WuYEKseSxOST6n396vwxySTeXCvmS+nZfcntXXGOpyuXc1rPS4tPw8zedMOmfur9KS7vuGJN
dUVoZdbsw7m+wvXmsS+uWlbG7A9KoRUDbVxmob5fNs7hSc7kYfmDTJ6n5l39skVy3GSDRHGPLJ6H
tXi1NKjfmdkb8qRJDEwIz93PNXYoVWTHQU6eruyZablxVJY8ZAqG5j8wDPVea6be7dmfoV5MqMdv
ak2/K4A5PQ1L0DqSaZGGPzc7a1FVWUgqCoJ4raNnEnqVLrBhXyN0RVvTg1Ubfj5xtJJ59axfustb
DJIzIuNuaKei3G/I+wGmTJlncDYOrngfT0qjeeJIre3d7ceYQPvN938PWvnHLqfTqPQxI4LvxFdb
zNNcHGDFESIgP93PJ+tVdS+Gya1eR/a7gjZ1W2w/Poc8Dt/hVU4u/MzOpL7MdzptH8MxaDaLBbJs
Rf7h+c565br+Aq6tnpumqZvKhhZhy20Bj9fWrZmlf1Ml/El68k6W1mltEh+S5mfIZcDnbxjmq9pp
tzrMhnJkmVPvz3A2xD3BPGMelJLm0Rbkoo0bLTEB/dp9umXgeVlIB9SeT+Aq7/ZVw22W7nWJI+RF
b/Invx3/ABqttiVK+5zFl8WtCvdSnsLGK4uHiO0yQxZVsc8eo9+lbjapeXSncwsoW6KoBlPsTyB+
tTaxS8h9npsiKrYWBXO0yyks5z29T9BW3b+H7K3kdoU8+4IJWSYcDPcL3P1rSKtqzOcubRDrHQzb
3Ek08zyuzb9z/wAPHT2outbt4ZRHbo08mfvLgKPx79O1J6jiZ8klzcNI91OREP8AlknyoAOv1/Gr
dxcaZpNskmp3aW6EgmJBuJBwOSOB/wDr9KqEeYU20tDqbG4jEI+zRpDG653LyzD3NJLew2sO+SQK
B3bnNaMyS7GJe6tPetvtlaGFesj9W+i/4/lXMNHqNxrH2sRuLW3x9oe4bICkcN6Dn06URXMyuZR0
Z3OmwQTNE5Ml5MuGTBMcS+x6FvpXSTSSEIJZFLNwsf3Vz7D8K2j2RhK97yKVxqMVjuJDPMesaDJH
+ArA1CO71m6T7TI0EC52wRHlunU/4VLdtC433NHR9BngmEkqC1gI+85wz8dh1NdCbxrW0c2Vu0bq
D87kGRsenZa0j7upnK0vQqyzRW8byzkKcZLyHn6k1hzas82xbOMMpbmaUEKPcDqaTexUV1FstDW6
vFlKNdXL/wDLR/4SPQdFraNvbWaqGBv7nqI4x+7U/wC0/T8qIxvqyZS1F8q5v7eGO9MeIzkRxLtj
HPHGecepp15rVvpaiEOWnYfLGgyx98VXN3ElrYzprm/1VhJKfs0HRYo3OWz/AHj/AIfnWlZ6KtvC
kszJaQMOnc/Qd6WswbtoidZDxFYRm2T+KaQAyN9PSlijhsY3dyoPVpG6n3JquvkSzB1Dxkr3EdrY
OjNIdomcEJ+Hr+FXdL0d57gS3DPdzY4LDhT7DoKXkP4Ub6WNvbspJEsi9YUPAPuafNC90QZyvlg5
WIDCj/H8aFHoJt7lPUNSt9PjXe+SeFjjGSfoK4zUNPPiDUobifzLIRjiNZCHZQc4Yg9M+lRJ9i4r
qbUWh71VjiGA9GbqfZfU1o6Xo/2N2eJWh3f8tJDmQ/T+7/OiMdbk82ljUXFnCed3OSWP9axtS8ZH
y2jsFWVl4aVvuD1x6n6VrflRCjzamPDYjVbwTjN1fsuDJ/d9vYfT8a6HR7F7Xy22x3MpPOOI0HqT
3P0/OoSu7sctFY6UxsyqztnaMDsB9BWbda2Szw6fGLqYcNIf9Wn1Pc+w5ro1MdN2O03w+TMLu9dr
u5U5QyD5Vz/dXtXUW6rHHk7VIHGa2hHUylLqXrfS7i8bcxNvberfeNXlaDT4fLgQIDyT3J9TXXGN
kc7dzOu9RxklqxrvUi3StUSZk9yWzzVKZyuT1qhEW889qGk3QvnoR/SgR+cGuQNHq12mPuysuT7G
q0duFXJ6H0rxaivVdu53LRIsJCV744qRFWM535JrSCSd2ZMnWUsxIGBVQzCSQgZ4rR33JtYbNJwO
GxntSR4OQAR2qVqJvWxPCwimwVPzVJ9qYPgDH41quxIySbgjCioLiNmUDzAvcZH6VnKz2LQ1ZAxK
HOfWis1e25TZ79b+JBqVmt4I52QAM0lwhCD8O1bmnG11ZtjQPfKrYfKmOH8CeW/CvEUUnqfRuTkr
xZ2UMMX2YQ7Y4IR1hhG1T9fX8ajutWsNLj2mREwMLGvU/StWzFRd7IyLrXJLtXiTFpu4BPLn/Cl0
nQ5pQX5KEY+03bfyzyahJydkW7QV7mpb6NbxMNwN4RzulXamc9l6n8cVf+yyXkmZeUQfux0VfXCg
ACtUuVWRzu7d5GVeeI4fD9zHbyp5oncIDDywY9N3tVLULy41KcxvJ5NsePKtxyfq/wDQCsb6HRy2
s+5VsPB9lZqubaOwjV92xFw78dcDlifetezhNwz/AGa2W3UN/r5sPL9QvRT9c1pGKjqyG+i2Ga3N
feGoJL2y08avcv8AfaScI3bueOnv2qbRfFUuqaZby29k5u3bEqXDbRGc8gHHzY7Y6+tVddRWQ6aG
TUL8iWea5mHAgQlUAP8Asg8/jWja6PHbSj7XcLDtHFtDgsfY+lSo3euw3JpWW5T1y5uEvIYLe122
7nYygjAB53N3PT9asaf5UOZbpkULzlgM59qa3G4rlsizNrD3C+XaYjUnmSQZP1A/xp1lppuJFUpJ
LJtYmaTJRR7noPpWtm3oZaRWpakhfn+z9t0wyrZXCL7jP3hz19qmjsTNbAXMv2qcqqucBRwOCQPx
qrW0RPN1Zb+32GhqkE02+Vz8kY5Y/gP61VutavLqTcB9mhHUfxfie34fnWnwoz3epC+sWWmpGdRu
IrBXOA7AncScDHGTya6PT2Em6SG3MI3fLLPguw9QOg/Wq5GkpS6kOS2RdZTvMkj7jjJZzzWRceJR
JmG0i8+Xpv8A4F/Hv+FN6IpamJNY3+o3EbsXupcgiNfuqevSuggt4rBR9oDXNw3SCEDj2J7VnHXV
lSktkW1S6uyBMVgt15EFuNoP+8ep/lSX2p2WlIPPmSEDopYA59h3rQy5W3ZHP3uvXmpMIrQ/ZYuh
mZPnb6DoPx/KrWk6KZmLLuAH355mP5k1i7ydkbaRRtKdoWO1jWQ9Tcyjj/gK/wBT+tSrahHMsztL
J3ZjW9uxiZFx4vhW4e1tB9ruVbaQh4T6noKge1fUJSb6Xzm6rbofkH1Hf8ahu+g7cvqX49NtbMp9
sG0ZyqAbn+gA6D3NbNvIWtxHGn2WM8EKcs31arSsQxl1dW+lQtJPMkMa88tgCudn1yfXw620T29v
ni4mJBOO6r/U4qJOxcV1ZLYaRLJI32XdcygfMzt/M9hW7aaSsaow23FyDncx/dJ9P738qUI31Cc+
hoQ2cduwmnfzpsY82TGR7D0H0rP1TxFb6arqX8+Un5Ikxkce3Tp1PrW0tFqZRTkzBkkn1nDTuY48
4EMZwD7N6/54q4nhsyQlZQViZTgLwx+g7D3rnV5M2k+XYvaNps6q8Utslpa7VCxxnLN1zvbv24rS
vtTsdFgVXZQxGEhUZZuOgFdSRz7uyKkNvf8AiCRGu2NrYnkWsRO5x23MD+g/OuisdOS1gCxxrHGv
G1BgAe1aRVyJP7jSt4XmOyFPNcdf7q/U1r2dlFYnzJSs8/qfur9BXZTjY5ZO4Xuplh96sS6vycgE
YraxJl3F0WzzVGSUscDmmIgLccnFQt9aYiKRgqEcc0xWO088GgR8DeLLBk8TatH023kwx9HPFZ/2
HbgcZFedKC55HTq1qJcR7Yzu/Sq3l7T0OKgnoTxIdmSeMVnRhgZOM/NgUpvYqNyyIxsz69aqzuI5
8KcDGab0jdC0HKSx+U/N70zd+9JkkVBn1ofQEuw6S4jUnYNzerdKiWaSTGOajm6IfyJxas0LNnJ6
5NFU01sS5H0/pHhr7PpsMOoTC7WMDbHtARceg/xrUF3Bajy0UO44EcY6f4V4z1dz6FLsZ2o32osr
KZBarjpGcn8T/hXPW3gu5u9TXULm6W1T+FZBuZ/ovWpinJjcuVadTsP7Bk+0W7Wx8sRtvaSX52f6
L0HWtO7vbfRo2uby5EZbA8yZskn0x/QVrsvIy1la+5zl78ULax08yQL9ulQASS7DHED+OT+FU7Dx
5ceJrJjAxncADyLVSMn6nqKb20HC27Hf8I7NJfW0tzdLZrChZbRV3zN2Jxn09ateI/GVl4Hs4Jfs
0iGYhQ+A8xwOvPC/h61EUob7l39q7dDS0fxXpl3pKaiZBCszbTJcthi3TGT1P0qbVfElxNbmDSQP
tL9J5E+RR3OO5/SqYrLfoNt7a51aOJLtzfTgYZEXCk9CdvStS3gjt5hFvMzLj9zb8leM8t0HWhRu
+YmcktEXbtZLhdkjmzjT5gtuxUk/7TDk9fauWeRbO9EiFimMKWyec+tOUtAgrGm9xdX06sIguAP3
jDk454FKujzSSblWR5MHdI54H49uopJN7D5lH0L2n6Lb6Za5eVrpcBhtyQCD0J6t0/HNdL5TzKvn
fMg6L0UfhXRtojDrdjZtas9NR1Zw8+P9WnLH8B2rlvEWoNq2nokjSWNnuEj4YiQbWBDEjp0/Wnfl
sK13fqUrbwrftMtzbj9yHEi3lycjgcqxJyc9upr0G3lhiX/R4N82cG4uO/rtX/H8qu/VkfFotjIv
PC+kX2sJq+o4lu4Pm8+WQgDA446D8q2brWLchY4d0zDp5ZIAPbkfyqudyirkRp2d0Z7G41R5Fmbf
z8kaZC/z5qSKFdJx9tf52bCW9uhaTHv6Dg9aztzGrfKbUPnzQ+Wi/Y4Sfuwsd7D/AGm61K32axiD
PsiRehPFa27mNr6I5668UNeTSfZYnWNflEzYAb3Uf/qqpp/hsX10blkknmb70krE4/PgD6Vh8TN/
hiayxQ2rrDbxC6nB5b/lkv4961ILORsPcS7sfdjHyov0FaxSMW38xbrVrTT1AeRd56IvJP4VzWoX
t1r2Q7PaWYb7kbYZx7n09qbkrFRi1qy7Z6RDaQqcpY22fvN0J9h3J9quzTmGPy7KMKDw1xIoL57Y
HQdvelFW1ZOj9CC3R7YNI37yRss7N1Y1UXxhceXLGtusku/anlklAP8Aab1FS5WLjFS3GeRNf3CP
cv8AaZ+qxAZVT6gf1rct9Pa1x9qGW/54p94j1P8AdqYpy1YSdtDXtY1mjIwkcQOTDF0z/tH+I/Wr
V1fRWcZeRljVR3roT0OezvZHNaprVzqUZS2VreLOPMYfM30Hb8aqaXoLXEbiNeG+/JIc/mTzWMry
ehurRidHpOmw6exCoZXX/ls4wM/7I/rWruUbpXIUdWY1rFcqsYuTkYdxqtxqkyx6ZhYd3zXUn3ff
aO/8qu6VoA0+4Mkw+0TzD55pOWP09B7Crje+pEn9k342is8KR83ZVGSfQVqWumSXKEyjyISfu92+
tdtONzmlI0FaOzjCRgKoHas651DazEGukxMm5vN3es6S6PIB460wK7TZ9zUTP2piK8khYgZpC23m
gRBI2786N3GM8UwPin4gW32fxxrkRUhvtkrdOxckfzrA2FV5AwOTmvMqP3pHckmlYyP7Ra9eXy4W
2qxUs3H40adcSXAlE1v5ag/KSc5rlTcmaPlS0Q26vNgxjAHpVVbgfOw4U/rV3bZnokRrdNCdpPyk
8VHIxZiRyT0pyloZb7ke1xg7sYPTPX2oktzKy7jkE9u1Gsg6FiOzXuc+1WAoXAXGPSt1BRRHM72J
fMJj24yelFKXqUmrbH0JrGtHT7cSX95sIBJt7cdf6/jxV3wzcW+o2a3QlCIxyIVO5/yFeFFNs+jk
7R0R0ot2uI9qxiBDwWOGcj69B+FW4bWCzXcQFOOXY8/nWpztGRrXjKKzt5F02I3dyvHT5FPqTXK/
8I5d+KriKfUJJLuXOVjI+QccgKP6mpbvoi/hV2T6x4DVrJ4bjU2t0JXy7MBRgjtwOPxNVvCetaF4
WmawF7bw3EjbHkizkn0L+vTpW6utFuYWctXsegi5srSPzWaNFbq7Ec/jXMeIrOx8UrsksBJEp4mn
yAPcAHPb2rGa6G8V9ofpfg6IeUIrb7Y8RzD5hBWP3UHhfr1rpbfTYC3ls5uSOGW3OAh5x83+FVGN
9ZbESlZ+7uazWcbWYtRCtvb42tDGxww/2j1NZ1/c2fh2aO8mupIoFXyktIxkOSeMKBkmruRFditq
2onUJkMCMkKjJdxjd+FS2Wmi6dfLjed8ZMkjYC/nwPwrNe87I2fuxV2a9nY22mrgH7ZIrfdTPlev
3u/4UXM095MftLrFbLyIgMJWtre6jLd8zIJtQtrAJOJt8ag7IoAWaTjsO9Vrz7Zr1jLEzvp0Eq8j
cGlwe2QcKfz/AApofmN8OeE4dHtGSBRBCqfNdSuRjvksTk9/zrd0saZqVtFc2rx6oMsBMxJiz0OB
/F071pFPdmUnfQ0XXYq+a2VAAXceFHoB2rA1G80fSNSFx9pZrsrt8pJCcjPUgcYpOLerLg2tiDUL
NNUaOa5T7QpYAQwjoMg5Y9xwK3LWGK3hzdutog5SJRl2H+yBSiubQlvsWFmLM0Von2GMjl92ZmH1
/hqzbiCwh+Z1wo+8x/PJq076ENaWMzUfF000Lx6ZDgj5ftEo+T8B3/lWBbR6vqkha6lFz82NsYJH
8uKmUr6ItR5NTb0+ygsxNFM4urtTj7NCcAHr8xPStry57mMCRgkeMeTFwv4+v40RVloTJ3dyV5Lb
ToRLKyx44FZVxq8moKYrcmGHODI/Ln6Dt+NXK1rExTvchs/D7MGEEecnLzOeTj1Jq7bpDCBHCi3s
in/WuMwo3r/tH9KiMbMqUua6uK2l7rs3NzJJPLjAZ24Uew6D8KTUNegtcRITLORlY05Y/wCAq33I
j7xiMl3cDfe3D7MhvIhcgd+GI6j2rXtdOa6CPJILKzTgRsvLcdh1NYP3nY2+HX7jetLeK0XNrEYy
wIMj8yEE/oOO1TSFEhLHPr1ro6WMDl9P8X3V4915dkI4lfarNkHI4JPr2xipIWk1a6AkLTOOVB6L
24FZc3RGrikzpIdOiiVVk3TSA4McZwB9T2/CtGO3kk27seWv3YkACjnj8a1jGxzy1G3+rwaf+6RG
urth8sEY5+p9B7mqkOl3WqTifUW3R9UtUOIx9eMsfrx7VstWRblXma7W4VCAAqj07fSrdjDNdN5c
ERK9POb7q+/vW1ON2YydkbljpsOm5d2M9weTI+CfoPQVLcajwea7oqxzPXVmTdagecGsua8JyetM
RRluCx5NV2k6igRGXxTWm29DVAQfaQzECmtJ2oAiaQfrTVlHOTT6CsfMn7QGkf2R4wF4oCx30W/p
/Evyn9Nv514/Jfbs4fP0ry60ffO6n8KZTW4LNgtgdae8vkxsS2ecjis4R5VcJSuYdzcMzMWP3qej
BoQoOeKwTd7hbQTDMo+bNSR7sbRn61pGLuQ9NywthJuDSAoDyPWpYrcyLgDC10RjrZmVx0lq0OGU
k5HNRsu3bgnrjOKctrC0THx2skgJLYHU0Vfs1LUevRH/2Q=
I am looking for a couple of servicable O-200 ( used ) Cams with fuel pump lobes.
We could use a Part number 40585 cam with AC Pump 9867 or a Part number 643067
cam with AC pump 9076.
These engines are on low wing Experimental aircraft and we want to have a mechanical
pump. We are now using 2 batteries and 2 electric pumps.
Also has anyone heard of an auto fuel pump with one of the same part numbers mentioned
above. An old timer
( older than me ) said he used to get them at an auto parts house off the shelf.
Thanks for any info you may provide.
Bobby
Bobby:
I can't help on the parts. But, the Automotive fuel pumps - Check out
FACET Pumps. They use to make for aircraft but I think they now make
automotive USED in Experimental aircraft.
http://www.aircraftspruce.com/catalog/eppages/facetpumps.php
Barry
> lobes.
> 643067 cam with AC pump 9076.
> mechanical pump. We are now using 2 batteries and 2 electric pumps.
> numbers mentioned above. An old timer
> shelf.
> Bobby
I have assembled my O 200 and was told by. Aircraft Specialty to use "Hylom
ar AEROGRADE" and silk thread to put the case together. I now have several
friends questioning if this is acceptable to use. I called Penn Yan Aero
who has never heard of this. Anybody have any experience with this or shou
ld I rebuild the engine before I start to fly it?
From: | "F. Tim Yoder" <ftyoder(at)yoderbuilt.com> |
Subject: | Re: O 200 CASE SEAL |
I believe that is what Cont. recommends and that is the system I used in
the early 90's. Hylomar works well on the valve covers also.
----- Original Message -----
To: continental-list(at)matronics.com
Sent: Monday, February 27, 2012 4:08 PM
Subject: Continental-List: O 200 CASE SEAL
"Hylomar AEROGRADE" and silk thread to put the case together. I now
have several friends questioning if this is acceptable to use. I called
Penn Yan Aero who has never heard of this. Anybody have any experience
with this or should I rebuild the engine before I start to fly it?
Glenn:
That is SCARY! Penn Yan does not know about that process... That is what
happens when you replace OLD FARTS with Young Whipper-Snappers. The
Knowledge goes out the door.
Hylomar AEROGRADE is just one of the High Temp RTV's being used. This is
NOT the High Temp you get at Home Depot.
This is a sealant/adhesive that can handle the Full Range of Temps, The
vibration and The OIL.
As for the silk thread... Well, that is old and not that good a process.
The thread moves - kinks and causes leaks.
It is left out with the new sealant.
Also check out HINKLE Adhesives/Sealants.
Give a call to Continental or Lycomming, they have approved the process
years ago.
Barry
> "Hylomar AEROGRADE" and silk thread to put the case together. I now have
> several friends questioning if this is acceptable to use. I called Penn
> Yan Aero who has never heard of this. Anybody have any experience with
Subject: | Re: Continental-List Digest: 3 Msgs - 02/27/12 |
GM #1052943 Gasket Maker works. Aviable at you Chevy dealer.
From: "Continental-List Digest Server" <continental-list(at)matronics.com>
Sent: Tuesday, February 28, 2012 1:55
Subject: Continental-List Digest: 3 Msgs - 02/27/12
> Online Versions of Today's List Digest Archive
> Today's complete Continental-List Digest can also be found in either of
> the
> two Web Links listed below. The .html file includes the Digest formatted
> in HTML for viewing with a web browser and features Hyperlinked Indexes
> and Message Navigation. The .txt file includes the plain ASCII version
> of the Continental-List Digest and can be viewed with a generic text
> editor
> such as Notepad or with a web browser.
> HTML Version:
> http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 12-02-27&Archive=Continental
> Text Version:
> http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 12-02-27&Archive=Continental
> EMail Version of Today's List Digest Archive
> Continental-List Digest Archive
> Total Messages Posted Mon 02/27/12: 3
> Today's Message Index:
> 1. 03:09 PM - O 200 CASE SEAL (GLENN JOHNSON)
> 2. 03:33 PM - Re: O 200 CASE SEAL (F. Tim Yoder)
> 3. 03:48 PM - Re: O 200 CASE SEAL (FLYaDIVE)
> ________________________________ Message 1
> From: GLENN JOHNSON <gljno10(at)hotmail.com>
> "Hylom
> several
> ________________________________ Message 2
> From: "F. Tim Yoder" <ftyoder(at)yoderbuilt.com>
> Subject: Re: Continental-List: O 200 CASE SEAL
> From: GLENN JOHNSON
> ________________________________ Message 3
> From: FLYaDIVE <flyadive(at)gmail.com>
> Glenn:
> years ago.
> Barry
> No virus found in this message.
> Checked by AVG - www.avg.com
If your engine has a data plate you can go to http://www.genuinecontinenta
l.aero/ and register for customer support. If your engine is still listed u
nder a previous owner you will need to call but they are very helpful. Once
you are registered you have online access to the current SIL's and SB's ap
plicable to your engine. Look at the current revision of SIL 99=2C "CURRENT
LISTING OF SEALANTS=2C LUBRICANTS=2C & ADHESIVES AUTHORIZED BY TCM.". Ther
e may be thousands of compounds and techniques that work but for things lik
e this I see no advantage to deviating from OEM recommendations.
Deems
> > "Hylom
> > several
ero
hou
From: | "Dortch, Steven D MAJ NG NG NGB" <steven.d.dortch(at)us.army.mil> |
I have piddled around with Continentals for years but am certainly no expert.
I have seen the silk string used many times. I would not disassemble the engine
unless you get a leak or problem. The silk thread was accepted practice for
decades and while it may not be accepted as modern practice by Penn Yan, it should
be fine.
BTW I have a problem with PENN YAN never having heard of this. It was done for
decades and though they don't do it now. they should have seen and heard of it.
Make me suspicious of their experience.
Blue Skies,
Steve D.
Date: Tuesday, February 28, 2012 10:47
Subject: RE: Continental-List: Re: Continental-List Digest: 3 Msgs - 02/27/12
> http://www.genuinecontinental.aero/ and register for customer
> support. If your engine is still listed under a previous owner you
> will need to call but they are very helpful. Once you are
> applicable to your engine. Look at the current revision of SIL 99,
> "CURRENT LISTING OF SEALANTS, LUBRICANTS, & ADHESIVES AUTHORIZED BY
> TCM.". There may be thousands of compounds and techniques that work
> but for things like this I see no advantage to deviating from OEM
> recommendations.Deems
> > > "Hylom
> > > several
It's hard to argue with the manufacturer. I had my IO-550B o/h'd not long ago and
stopped by the shop when my mechanic was prepping the case halves for assembly.
He had the two halves coated with different sealants, one was Permatex (I
think) and the other some purple high tech type. Plus there was a silk thread.
When I asked he explained that it was specifically called out that way by Continental
in the manual. It's too weird for Cont. not to have had a reason. He's
a stickler for following the book. RTFM, YMMV, etc...
Greg Young
-----Original Message-----
From: owner-continental-list-server(at)matronics.com [mailto:owner-continental-list-server(at)matronics.com] On Behalf Of Dortch, Steven D MAJ NG NG NGB
Sent: Tuesday, February 28, 2012 11:38 AM
Subject: Re: RE: Continental-List: Re: Continental-List Digest: 3 Msgs - 02/27/12
be fine.
Blue Skies,
Steve D.
> http://www.genuinecontinental.aero/ and register for customer support.
> If your engine is still listed under a previous owner you will need to
> call but they are very helpful. Once you are registered you have
> online access to the current SIL's and SB's applicable to your engine.
> Look at the current revision of SIL 99, "CURRENT LISTING OF SEALANTS,
> LUBRICANTS, & ADHESIVES AUTHORIZED BY TCM.". There may be thousands of
> compounds and techniques that work but for things like this I see no
> advantage to deviating from OEM recommendations.Deems
> > > "Hylom
> > > several
Called TCM today and the whole truth is follow SIL99-2B which calls for loctite
515 as well as permatex #3 with the silk thread. I was told that what happens
is the case will not hold the torque on the bolts causing the case to eventually
loosen up and we know what happens then. He also said good luck getting
it apart!
Thanks for all who posted as it lead me to follow my instinct and call the manufacturer
601XL N676L FLYING PHASE I
CHESAPEAKE VA
http://forums.matronics.com/viewtopic.php?p=367485#367485
I'm sorry, I do not recall; is this engine going on an experimental or a GA
aircraft?
I'm sure you know where I'm going...
My next suggestion would be to call Lycoming or another engine shop and ask
what they use? My O-320 Lycoming was assembled at an engine shop with ONLY
a RVT sealant/adhesive. This was done back in 2000 and I have not seen any
leaks.
The FAA does NOT care what sealant you use. And if they did the must have
approved a few different sealants for all the different engine manufactures
out there. Next point - Since YOU are are the engine shop YOU are the
one certifying the engine and you are the one standing behind the warranty.
Do what YOU feel works best. As long as it is an approved sealant who
cares which one! Only You!
Barry
> loctite 515 as well as permatex #3 with the silk thread. I was told that
> what happens is the case will not hold the torque on the bolts causing the
> case to eventually loosen up and we know what happens then. He also said
> good luck getting it apart!
> manufacturer
> CHESAPEAKE VA
From: | "John Cammarano" <jcappraiser(at)sbcglobal.net> |
Subject: | Staggered magneto timing. |
Can anyone tell me why magneto timing was staggered - 29 & 32 degrees
BTDC on the older Continental A75 & A80 & not equal (30 & 30) like on
the A65. What is the reason / advantage? Thanks.
A friend has an O-470-M on a Bearhawk and it has a oil consumption rate of a quart
per hour. It was worse than this before he honed the cylinders and installed
new rings. He also lapped the valves while it was down. He has 35 hrs. on the
new rings and still on mineral oil. Can anyone tell me what may be wrong or
what we can do to slow down the oil consumption.
Bobby:
Without seeing the engine and the cylinder bore I can only guess...
I'm guessing three (3) things;
1 - That the Cross-Hatch pattern in the cylinders are honed away.
2 - That he used the wrong Rings... Chrome Cylinders get steel rings.
Steel cylinders get chrome rings.
3 - Rings put in up-side down.
You can visually inspect with a bore scope for the hatch pattern.
Trying to figure out what rings were uses can only be done by reading the
paperwork for the order placed. And hopping that the correct rings were
supplied.
And if the rings were installed up-side down - - - Pull the cylinder off.
Barry
> a quart per hour. It was worse than this before he honed the cylinders and
> installed new rings. He also lapped the valves while it was down. He has 35
> hrs. on the new rings and still on mineral oil. Can anyone tell me what may
> be wrong or what we can do to slow down the oil consumption.
From: | "Monty Barrett Sr" <MONTY(at)bpaengines.com> |
If the top compression ring is upside down it won't go together. This
ring is 1/2 keystone ( tapered on one edge ). Bottom ring wide edge
faces up. Part numbers also go up. However, I have seen rings marked
wrong.
If chrome cylinders FLYaDIVE is correct. Never-Chrome on Chrome. IF
they are chrome they will not have a cross hatch.
If they are chrome they will either be fractured chrome ( channel chrome
) or " Cermi-Chrome ". They could also be Nickel-silicon ( Cermi-Nil
). The same statement about ring face material applies.
I would have a real good look at the pistons, particularly the ring
grooves. Rings have to seal there also. Cylinders can also get out of
round in the ring travel and also " washboard ". Caused from too much
heat and is usually the result of poor baffling.
Monty Barrett
Barrett Precision Engines, Inc.
FLYaDIVE
Sent: Thursday, May 03, 2012 3:06 PM
Subject: Re: Continental-List: O-470
Bobby:
guess...
away.
rings. Steel cylinders get chrome rings.
pattern.
reading the paperwork for the order placed. And hopping that the correct
rings were supplied.
cylinder off.
Barry
consumption rate of a quart per hour. It was worse than this before he
honed the cylinders and installed new rings. He also lapped the valves
while it was down. He has 35 hrs. on the new rings and still on mineral
oil. Can anyone tell me what may be wrong or what we can do to slow down
st"
target="_blank">http://www.matronics.com/Navigator?Continental-List
Guys
Thanks for all the input. If we find out what is causing it I will post.
Bobby
Subject: | Magneto Switch ? |
I have a 0-200 Continental engine in my Kitfox with Slick 4301 magnetos.
I=99m using a key start switch just like a Cessna 150
installation. My question is on the switch jumper. Some references say
with dual impulse couplings one needs a jumper across terminal 1, others
say not to use it. What have others done? Thanks Jim jezim@pro-ns.net
Subject: | Re: Magneto Switch ? |
Jim:
If you have DUAL Impulse coupling Mags then you DO NOT use the jumper.
BUT! I would suggest: Use a separate Push Start for the switch just like
Grumman's have. The Mag Switch would be Left - Right & BOTH ... You would
start on BOTH and and use the separate Push Button and you eliminate a AD
issue... Yes, I know experimental, no AD but the problem still exists with
the switch AND it gives you options if the switch should fail.
Barry
> I=92m using a key start switch just like a Cessna 150 installation. My
> question is on the switch jumper. Some references say with dual impulse
> couplings one needs a jumper across terminal 1, others say not to use it.
Subject: | O200 Vacuum Pump cover |
I have an O200 with a vacuum pump. I don't plan to use any vacuum gauges so I
want to take it off to save weight. Is there a plate or cover that I could get
to seal off the engine. Also are there any gears or whatever that need to be
removed when the pump is taken off?
Any help appreciated.
Tommy Walker in Alabama
Building - Kitfox SS w/O200
Tommy Walker
N8701 - Anniston, AL
http://forums.matronics.com/viewtopic.php?p=372635#372635
Subject: | Re: O200 Vacuum Pump cover |
Tom:
Yes, there is an OFFICIAL plate but since you are experminental you could
make your own. I would use 0.125" aluminum 6061 or 7075 with a gasket.
And since you are sealing it almost permanently use a slight smear of Hi
Temp RTV.
NO - There aren't any gears to remove.
Barry
On Tue, May 8, 2012 at 12:57 PM, Tommy Walker wrote:
> twalker(at)cableone.net>
> so I want to take it off to save weight. Is there a plate or cover that I
> could get to seal off the engine. Also are there any gears or whatever
> that need to be removed when the pump is taken off?
> Thanks,
> Tommy Walker
Thanks Barry. I got lots of 0.125 and will fabricate me up one of the
plates.
On Tue, May 8, 2012 at 3:29 PM, FLYaDIVE wrote:
> Tom:
> Temp RTV.
> Barry
>> Thanks,
>> Tommy Walker
>> List" target="_blank">http://www.matronics.com/Navigator?Continental-List
>> le, List Admin.
>> ="_blank">http://www.matronics.com/contribution
Subject: | valve cover screw oil leak |
Four or five valve cover screws are leaking oil on my C85. It has the red silicone
gaskets. The screws are really tight now and still leak a fair amount. It's
on a certified plane. Is there some thing legal that can be used to halt the
leak? I have Tight Seal on hand.
Eric in SW Michigan
http://forums.matronics.com/viewtopic.php?p=374463#374463
Subject: | Re: valve cover screw oil leak |
Eric:
You answered your own question and I quote: " The screws are really tight
now and still leak a fair amount." REALLY TIGHT is what is causing it.
Start by:
1 - Removing the cover and the gasket
2 - Cleaning the cylinder face and cover face well, use SCOTCHBRITE and MEK
3 - Wipe down the silicone gasket with a QUICK wipe of MEK.
4 - By pulling on the gasket as you go all the way around - LOOK - for
nicks and tares, especially around the screw holes. If found replace that
gasket.
5 - Install the gasket on the cleaned surfaces of the cylinder & cover.
6 - MY TRICK - Totally legal - Use RED Loctite on the threads of the
screws. Yes, RED Loctite.
7 - Tighten the screws in a STAR PATTERN - Tighten the cover to a uniform
height - Just enough to show compression of the gasket.
8 - Unfortunately torque values do not work because the gasket squishes.
But, do not go "really tight". It's a case of experience. You now have
the experience of what NOT TO DO! I'm sure you will figure out the rest.
Barry
> silicone gaskets. The screws are really tight now and still leak a fair
> amount. It's on a certified plane. Is there some thing legal that can be
> used to halt the leak? I have Tight Seal on hand.
> Eric in SW Michigan
Subject: | warp propeller on 65hp |
hi all,
is anyone using a warp on a 65 hp cont.? i know a builder with a 70 ' 2 blade
and am wondering what degree of pitch should be used. what kind of climb performance
and rpm are you seeing?
thanks in advance, bob noffs
http://forums.matronics.com/viewtopic.php?p=377270#377270
Subject: | Re: warp propeller on 65hp |
I used a 3 blade on a IO-240, 125 hp. I think I set it at 15deg. to start
and ended up about 18 deg.
Set it in that range and check your static rpm. I would think 2300 would
work.
Warp Drive could probably get you close.
Sent: Wednesday, July 04, 2012 11:55 AM
Subject: Continental-List: warp propeller on 65hp
> hi all,
> blade and am wondering what degree of pitch should be used. what kind of
> climb performance and rpm are you seeing?
Subject: | PLEASE READ - Matronics Email List Fund Raiser During |
November!
Dear Listers,
Each November I hold a PBS-like fund raiser to support the continued operation
and upgrade of the Email List and Fourm Services at Matronics. It's through solely
through the Contributions of List members that these Matronics Lists are
possible.
You have probably noticed that there are no banner ads or pop-up windows on any of the Matronics Lists or related web sites such as the Forums site http://forums.matronics.com , Wiki site http://wiki.matronics.com , or other related pages such as the List Search Engine http://www.matronics.com/search , List Browse http://www.matronics.com/listbrowse , etc. This is because I believe in a List experience that is completely about the sport we all enjoy - namely Airplanes and not about annoying advertisements.
During the month of November I will be sending out List messages every couple of
days reminding everyone that the Fund Raiser is underway. I ask for your patience
and understanding during the Fund Raiser and throughout these regular messages.
The Fund Raiser is only financial support mechanism I have to pay all
of the bills associated with running these lists. Your personal Contribution
counts!
Once again, this year I've got a terrific line up of free gifts to go along with
the various Contribution levels. Most all of these gifts have been provided
by some of the vary members and vendors that you'll find on Matronics Lists and
have been either donated or provided at substantially discounted rates.
This year, these generous people include:
Bob Nuckolls of the AeroElectric Connection http://www.aeroelectric.com
Andy Gold of the Builder's Bookstore http://www.buildersbooks.com
Jon Croke of HomebuiltHELP http://www.homebuilthelp.com
These are very generous guys and I encourage you to visit their respective web
sites. Each one offers a unique and very useful aviation-related product line.
I would like publicly to thank Bob, Andy, and Jon for their generous support
of the Lists again this year!!
Please make your List Contribution using any one of three secure methods including
using a credit card, PayPal, or by personal check. All three methods afford
you the opportunity to select one of this year's free gifts with a qualifying
Contribution amount!!
To make your Contribution, please visit the secure site:
I would like to thank everyone in advance for their generous financial AND moral
support over the years!
Thank you for your support!
RV-4/RV-6/RV-8 Builder/Rebuilder/Pilot
Subject: | Please Make A Contribution To Support Your Lists |
Dear Listers,
There is no advertising income to support the Matronics Email Lists and Forums.
The operation is supported 100% by your personal Contributions during the November
Fund
Raiser.
Please make your Contribution today to support the continued operation and upgrade
of these services. You can pick up a really nice gift for making your Contribution
too!
You may use a Credit Card or Paypal at the Matronics Contribution Site here:
or, you can send a personal check to the following address:
Matronics / Matt Dralle
581 Jeannie Way
Livermore, CA 94550
Thank you in advance for your generous support!
Matronics Email List and Forum Administrator
Subject: | Coming Soon - The List of Contributors - Please Make |
A Contribution Today!
Each year at the end of the List Fund Raiser, I post a message acknowledging everyone
that so generously made a Contribution to support the Lists. Its my way
of publicly thanking everyone that took a minute to show their appreciation
for the Lists.
Please take a moment and assure that your name is on that List of Contributors
(LOC)! As a number of members have pointed out over the years, the List seems
at least as valuable a building / entertainment tool as your typical magazine
subscription!
Make sure that your name is on this year's LOC! Show others that you appreciate
the Lists. Making a Contribution to support the Lists is fast and easy using
your Credit card or Paypal on the Secure Web Site:
or by dropping a personal check in the mail to:
Matt Dralle / Matronics
581 Jeannie Way
Livermore CA 94550
I would like to thank everyone that has so generously made a Contribution thus
far in this year's List Fund Raiser! Remember that its YOUR support that keeps
these Lists going and improving! Don't forget to include a little comment about
how the Lists have helped you!
Best regards,
Subject: | A Message From AeroElectric's Bob Nuckolls... |
Dear Listers,
The well known Bob Nuckolls of the AeroElectric posted a great message Monday on
the AeroElectric-List regarding the Matronics Lists and the importance of supporting
the operation during the Fund Raiser. Please take a minute to read Bob's
commentary below, reposted to the other Matronics Lists with his permission...
Date: Mon, 05 Nov 2012 08:58:41 -0600
Subject: AeroElectric-List: Re: Please Make A Contribution Today!
> acknowledging everyone that so generously made a Contribution to
> support the Lists. Its my way of publicly thanking everyone that
> took a minute to show their appreciation for the Lists.
I will add my voice to this suggestion. It's
easy to enjoy the benefits of what's available to us
off-the-shelves at the corner mega-marts. It's
seldom that we give pause to learn and understand the
processes and tools that made it possible to reach out
and select from dozens of options.
This, and all civil societies, runs on talent, energy
and mobility. Mobility exploited by thousands of hands,
machines and transportation that figure into the
'infrastructure' that puts the boxes of Wheaties and
Pop Tarts on the shelves.
See "I pencil" http://tinyurl.com/36xkhq
Any break in that chain of time, talent and resources
at least interrupts if not totally halts flow of
that benefit. Matt's room full of byte-thrashers is
like the natural gas pumping station a few miles from
my house. If those pumps stop, who ever is expecting
the furnace to come on at the other end of the pipe
is at risk for reduced service and/or higher costs
for that service.
Matt's yearly endeavor to keep his pumps running is
a trivial burden on the members of the Lists
but of incalculable value to those who participate
on them. No donation is too small.
We go to a fly-in a willingly chuck a few bucks into
the coffee can at the drinks and donuts table, let's
chuck a few bucks into Matt's coffee can too. 50,000
pounds of value doesn't get to the shelves on time
if one 18-wheeler runs out of gas. The T-bytes of
data flow we all enjoy don't get from your keyboard
to the screens of others unless Matt pays the light
bill and strokes the machines to keep them happy.
No, $5 won't get you a free copy of the 'Connection
or a fuel sampler but it will go toward the assurance
that logging onto your favorite List will open
doors that you would be sorely missed should you find
that hitting the return key doesn't produce the
expected response.
$5 from every List customer on Matt's system will
go a very long way to keeping the byte-pumps running.
$More$ will go a long way to upgrading the size
and quality of the machines as the old ones get
long in the tooth. No matter what size of donation
you choose . . . please do it now . . .
too!
581 Jeannie Way
Livermore, CA 94550
Subject: | Make A List Contribution - It's Your Personal Squelch |
Button...
There is an automatic "squelch button" of sorts for the Fund Raiser messages.
Here's how it works... As soon as a List member makes a Contribution through
the Matronics Fund Raiser web site, their email address is automatically added
to this year's Contributor List and they instantly cease to receive further Fund
Raiser messages for the rest of the month! Its just that simple! :-)
I really do appreciate each and every one of your individual Contributions to support
the Lists. It is your support that enables me to upgrade the hardware
and software that are required to run a List Site such as this one. It also goes
to pay for the commercial-grade Internet connection and to pay the huge electric
bill to keep the computer gear running and the air conditioner powered
on. I run all of the Matronics Email List and Forums sites here locally which
allows me to control and monitor every aspect of the system for the utmost in
reliably and performance. Your personal Contribution matters because, when combined
with other Listers such as yourself, it pays the bills to keep this site
up and running. I accept exactly ZERO advertising dollars for the Matronics
Lists sites. I can't stand the pop-up ads and all other commercials that are
so prevalent on the Internet these days and I particularly don't want to have
it on my Email List sites.
If you appreciate the ad-free, grass-roots, down-home feel of the Matronics Email
Lists, please make a Contribution to keep it that way!!
581 Jeannie Way
Livermore, CA 94550
Thank you!
[Note that there are certain circumstances where you might still see a Contribution
related message. For example, if someone replies to one of the messages,
when using the List Browse feature, or when accessing List message via the Forum.
The system keys on the given email address and since most of these are anonymous
public access methods, there is no simple way to filter them.]
Subject: | Please Support The Lists... |
Dear Listers,
Just a reminder that November is the Matronics Email List Fund Raiser month. There
are some very nice incentive gifts to choose from as well!
Please make your Contribution today at:
581 Jeannie Way
Livermore CA 94550
Thank you!
Subject: | What's Your Contribution Used For? |
Dear Listers,
You might have wondered at some pointd, "What's my Contribution used for?" Here
are just a few examples of what your direct List support enables... It provides
for the expensive, commercial-grade Internet connection used on the List.
It pays for the regular system hardware and software upgrades enabling the highest
performance possible for List services such as the Archive Search Engine,
List Browser, and the Web Forums. It pays for the over 22 years of on-line
archive data always available for instant search and access. And, it offsets
the many hours spent writing, developing, and maintaining the custom applications
that power these List Service such as the List Browse, Search Engine, Forums,
and Wiki.
But most importantly, your List Contribution enables a forum where you and your
peers can communicate freely in an environment that is free from moderation,
censorship, advertising, commercialism, SPAM, and computer viruses.
It is YOUR CONTRIBUTION that directly enables all these aspects of Matronics List
services. Please support it today with your List Contribution. Its one of
the best investments you can make in your Sport!
List Contribution Web Site:
581 Jeannie Way
Livermore, CA 94550
Email List Administrator
Subject: | Make Sure You're Listed! List of Contributors Published |
in December!
Dear Listers,
The List of Contributors (LOC) is just around the corner! In December I post a
list of everyone that so generously made a Contribution to support the Lists.
Its my way of publicly thanking everyone that took a minute to show their appreciation
for the Lists.
Won't you take minute and assure that your name is on the upcoming LOC? Tell others
that you appreciate the Lists. Making a Contribution to support the Lists
is fast and easy using your Visa, MasterCard, or Paypal account:
Or, by dropping a personal check in the mail to:
581 Jeannie Way
Livermore CA 94550
far during this year's List Fund Raiser! Remember that its YOUR support that
keeps these Lists running and improving! Don't forget to include a little comment
about how the Lists have helped you!
Thank you!
Subject: | Who is Matt Dralle & What Are The Lists? |
Dear Listers,
Who is Matt Dralle and what exactly are these Lists anyway? I've been working
in the Information Technology industry for over 28 years, primarily in computer
networking design and implementation and more recently as an embedded software
engineer. I have also done a fair amount of work in web design and development.
I started the Matronics Email Lists way back in 1990 shortly after I started building
my RV-4 with about 30 fellow RV builders from around the world. Since
that time, I have added many other types of aircraft related Lists to the line
up and numerous other List related services such as the Forums, Wiki, Archives
and Search Engine just to name a few.
For flexibility and reliability, I have chosen to run all of my own servers locally.
Other List-related systems include a 1 Gigabit, fully switched network
infrastructure, a commercial-grade Netscreen firewall, a Barracuda spam filter,
a local T1 Internet router, and a bonded dual T1 commercial-grade business Internet
connection with full static addressing.
The computer servers include a dual quad-core Linux server for List web services
with 24GB of memory, a quad -core Linux system dedicated to the email processing
List functions, and another standalone Linux system serving as a remote storage
disk farm for the archives, databases, and for an on-line hard drive-based
backup system with multi-terra byts of online storage. This entire system
is protected by three large, commercial-grade uninterrupted power supply systems
(UPS) that assure the Lists are available even during a local power outage!
Speaking of power, imagine how much electricity it takes to run all of these
systems. On the average, the elctric bill is in the neighborhood of $7000-$8000/yr
and the newly upgraded dual-T1 Internet connection runs roughly $6000/yr.
A while back, I upgraded all of the computer racking infrastructure including new
power feeds and dedicated air conditioning for the room that serves as the
Computer Center for the Matronics Email Lists and followed that upgrade up with
a second rack upgrade to house the MONSTER web system that didn't quite fit
into the first rack! Here's a composite photo of the List Computer Center prior
to the addition of the second rack:
http://www.matronics.com/MattDralle-ListComputerCenter.jpg
As you can see, I take running these Lists very seriously and I am dedicated to
providing an always-on, 24x7x365 experience for each and every Lister.
But building and running this system isn't cheap. As I've mentioned many times
before, I don't use commercial advertisments to support any of these systems.
It is supported 100% through List member Contributions! That means you...
and you... and YOU!
To that end, I hold a List Fund Raiser each November and ask that members make
a Contribution to support the continued operation and upgrade of this ever-expanding
system. Its solely YOUR Contributions that keeps it running!
Please make a Contribution today to support these Lists!
581 Jeannie Way
Livermore CA 94550
Thank you!
Dear Listers,
A quick reminder that November is the annual Matronics List Fund Raiser. The Lists
are 100% member supported and all of the operational costs are covered solely
through your Contributions during this time of the year.
*Your* personal Contribution makes a difference and keeps all of the Matronics
Email Lists and Forums completely ad-free.
Please make your Contribution today to keep these services up and running for another
great year!
Use a credit card or your PayPal account here:
Or, by sending a personal check to:
581 Jeannie Way
Livermore CA 94550
Thank you in advance!
Subject: | Some Nice Comments... |
Dear Listers,
I've been getting some very nice comments from Listers along with their List Support
Contributions. I've shared a number of them below. Please read them over
and see what your fellow Listers think of the Lists and Forums.
Please make a Contribution today to support the continued upgrade and operation
of these services.
There are lots of sweet gifts available this year, so please browse the nice selection
and pickup something fun with your qualifying Contribution!
You may use a credit card or your PayPal account here:
Or feel free to send a personal check to:
581 Jeannie Way
Livermore CA 94550
Thank you in advance for your generous support! It is very much appreciated!
Best regards,
-------------------- What Listers Are Saying About The Lists --------------------
I have been flying my Pietenpol for a month now and am
enjoying the fruits of ten hard years of work. I seriously
doubt it would ever have been finished but for the help,
encouragement and friendships I've received and made through
the Pietenpol list.
Douwe B
Outstanding service to the flying community.
George A
Matt, I look forward to support each others projects,
Glenn B
Great list!!! Thanks for all your efforts!
Roger C
Thank you for keeping up the lists. Without it i would never
have completed my aircraft.
Stan S
Keep up the good work my friend. I don't think I could ever
finish my Pietenpol Air Camper without the help I get from
this List.
Tom S
Thank you for keeping these list alive.
Lee V
The List is invaluable!!
Svein J
Thanks for continuing to provide the list service!
Earl S
You have a really GREAT service. Thankyou so much I've been on
for nearly 30 years and I still check-in every morning.
John B
I rely fully on the lists which govern my every decision. The
flexibility provides the security I seek.
Fergus K
My RV 7 Finally flies... 7 years of Matronics.com certainly
helped.
Martin H
Great service here, thanks! I am just getting back to a
project I dropped for a few years, great to see your site
and all the folks again!
James C
Thanks for the great site.
Robert U
The Rotax list is good and the AeroElectric list outstanding!
Jay H
Thank you for a great resource!
Jack T
Thanks for your great record of outstanding service to the
homebuilding community!
Larry W
This service is invaluable.
Michael W
You're doing a great job Matt.
Robert D
Thanks for all your work, its a great asset to all.
John F
Thank you for your time & effort Matt!
Ted W
Matt, been a follower since 2005 on the -10 list, now
starting an -8. Keep up the great work!
John M
Still my favorite place to hang out.
William W
I'm not a Piet builder, but this is the most informative and
congenial list I've ever run across. Please forgive my
lurking-I learn a LOT here!
Ken M
Many thanks for keeping this alive, keep pushing!
Adrian C
Thanks! Please keep r going!
Rich Z
Many thanks for your hard work.
Robert C
Thanks for the Lists! I probably need to subscribe to a few
more...
John M
Been a quick 14 years. Think I subscribed to the Kolb
List in 1998, when I got my first computer. Thanks for
keeping everything running smoothly for all these years.
John H
Great resource - thank you.
David M
I don't post very much, but get the postings, a lot of really
practical info.
John N
Great job Matt, thanks for all you do.
Roger M
Thanks for ANOTHER great year, Matt! True grassroots
experimental aviation has been pushed aside in many ways.
But the List represents the evolution of this great
tradition of home-building. One man, the plans, the tools,
and the List - that's all you need to build the dream!
Robert B
This message board is a real help to my project and creating
friendships.
John S
Many thanks for your continuing excellent work.
Mike G
Thank you for your work Matt. Your lists have helped me a
great deal during the construction of my plane.
Hal B
Nice List
Van E
These lists are priceless for builders.
Ronald C
Thanks for keeping me in touch with the Pulsar community.
Otto S
Thanks for keeping up this great warbird sight!!
Yak Ron
Thanks for providing all the lists for so many years.
H H
Thanks for all that you do. Your dedication is much appreciated!
Warren H
Best service on the internet!
Owen B
I have learned so much from the "list".
Nick C
Great Service You Are Providing!
Giffen M
Thanks so much for maintaining these great resources.
Dave S
I no longer fly due to age and health problems, but I still
enjoy the reading from other pilots.
Dallas S
This is a wonderful site.
Robert B
Useful service over the last year - thanks.
Om T
Subject: | "Black Friday" For List Fund Raiser...? |
Dear Listers,
The number of List subscriptions are up by a fair amount this year, but support
during this year's Fund Raiser is substantially behind last year, and there's
only about a week left until the end of the Fund Raiser. I have always preferred
a non-commercial List experience as many, many members have also expressed
that they do as well. However, if the yearly fund raiser cannot generate sufficient
funds to keep the bills paid, other sources of income might be required
including some sort of advertising. Please don't let that happen! Your personal
Contribution of $20 or $30 goes a long ways to keeping this operation a
float.
Please make sure your name is on this year's List of Contributors!
The List Contribution site is secure, quick, and easy:
Or, drop a personal check in the mail to:
581 Jeannie Way
Livermore CA 94550
Thank you in advance for your support!
Subject: | Just A Few More Days To Make Your List Contribution... |
There is less than a week left in this year's List Fund Raiser and only a few short
days to grab one of the great Contribution Gifts available this year. Support
is still significantly lagging behind last year at this point but hopefully
it will pick up here towards the end. Please remember that it is solely the
Contributions of List members that keeps the Lists up and running as there
is no commercialism or advertising on the Matronics Lists and Forums.
The List Contribution web site is secure, fast, and easy and you can use a credit
card, Paypal, or a personal check:
581 Jeannie Way
Livermore CA 94550
I want to thank everyone that has already made a generous contribution to support
the Lists!
Thank you!
Matronics EMail List and Forum Administrator
Subject: | Contributions Down By 23%... |
Dear Listers,
As of today, Contributions to the Matronics List Fund Raiser are lagging behind
last year at this time by roughly 23%. I have a Fund Raiser each year simply
to cover my operating
costs for the Lists. I *do not* accept any advertising income to support the Lists
and rely solely on the Contributions of members to keep the expenses paid.
I run all of my own servers and they are housed here locally, and the Internet
connection is a commercial-grade, dual T1 connection with public address space.
I also maintain a full
backup system that does nightly backups of all List-related data so that in the
event of a server crash, all of the Lists and the many years of List archive
data could be restored
onto a new server in a matter of hours.
All of this costs a fair amount of money, not to mention a significant amount of
my personal time. I have a Fund Raiser each year to cover these costs and I
ask that members that
feel they receive a benefit from my investments make a modest Contribution each
year to support the continued operation and upgrade of these services.
If you enjoy the Lists, please make a Contribution today. I also offer some incentive
gifts for larger Contribution levels. At the Contribution Web Site, you
can use a credit card,
Paypal, or personal check to show your support for the continuation of these services:
581 Jeannie Way
Livermore CA 94550
Subject: | Make Sure You're Listed! List of Contributors Coming |
in December!
Dear Listers,
There's just a couple more days left in this year's List Fund Raiser and that means
the List of Contributors (LOC) is just around the corner! In December I
post a list of everyone that so generously made a Contribution to support the
Lists. Its my way of publicly thanking everyone that took a minute to show their
581 Jeannie Way
Livermore CA 94550
Thank you!
Subject: | Just 3 Days Left - Please Make Your List Contribution |
Today!
There are only three days left until the end of this year's List Fund Raiser.
Please take a minute to show your support as so many others have this year and
make sure YOUR name is on the forthcoming List of Contributors!
Its quick and easy using the secure web site with a credit card or PayPal:
or by sending your personal check to:
Matronics Lists c/o Matt Dralle
581 Jeannie Way
Livermore, CA 94550
Thank you in advance for your support of these List services!
Matronics Email and Forum Administrator
Subject: | Just Two Days Left! - Still Behind... |
Dear Listers,
There are just two more days left in this years List Fund Raiser. Over the last
couple of weeks I have received some more really nice comments from members
on what the Lists have meant to them. I have included a few more of them below.
Please read over the comments and ponder on your own feelings about the Lists
and the support and camaraderie you have found here.
We are still behind last year in terms of the number of contributions. I really
want to keep providing these services to the homebuilt community, but it take
resources. Since there's no advertising budget or deep pockets to keep the
operation a float, its solely your generosity during the Fund Raiser that keeps
things going. Please make a Contribution today.
If you've been putting off showing your support for the Lists, now is the time
to do it!
Make a contribution with a Credit Card or though PayPal at that Matronics Contribution
web site:
Or, drop a check in the mail:
581 Jeannie Way
Livermore, CA 94550
==================== A Few List Member Comments =====================
the Pietenpol list.
Douwe B
Hey-Long time subscriber, zero-time contributor. Just a
note of thanks. This is first time I have the resources to
contribute. Thanks for carrying a lightweight for years and
a special thanks for your time and effort.
Billy R
My 601 hd is flying with the help with the listers.
Noel G
A very useful facility.
Graeme B
..great site!
Robert C
Great Pietenpol site!
Don Y
Not active but always interested in keeping up. Enjoy
when I can.
Richard R
Dave and Tim from Aircrafters just want to reiterate our
thanks for hosting the lists.
Tim F.
I don't have a lot to give at this time of year, but I
hope my contribution helps none the less. I really enjoy
the message board.
Mark C
Thanks to your continued work on maintaining these lists.
Ralph C
The lists and the various contributors have been a great
help while I was building and also now that I'm flying.
Albert G
Very helpful tools for the homebuilder.
Vaughn T
We appreciate your great help!
Richard H
Many of our customers have expressed to us that you
provide them with an invaluable service - and we agree!
Bill B
I Fly a Quicksilver GT400 but love to read what the Kolb
boys have to say and it was on your list that I found out
about the Yamaha product Ring Free,, now called engine med,
that shit works.. no carbon in my rings or any to speak of
with the use of the Yamaha product with a premix 503 with
over 300 hrs of use.. thanks to your Kolb bulletin board.
Robert B
You are providing a valuable service that helps a lot of
people through information sharing. When I built my
Pietenpol over 40 years ago we were largely on our own,
working without a resource like this list.
Graham H
Thanks for the opportunity to link us all, keep the good work!
Peter B
Subject: | [Please Read] - Last Official Day of List Fund Raiser! |
Dear Listers,
Its November 30th and that always means a couple of things. Its my birthday again;
number 49 actually! But it also means that its that last official day of
the Matronics Email List Fund Raiser! If you been thinking about picking up
one of those really nice incentive gifts now is the time to jump on it!!
If you've been meaning to make a Contribution this month but have been putting
it off for some reason, NOW is the time!
I will be posting the List of Contributors in a few days, so you'll probably want
to be known as a person that supported the Lists!
I want to thank everyone that has so generously made a Contribution this year in
support of our Lists. It is your generosity that keeps this operation running
and I don't ever forget it.
The List Contribution Web Site is fast and easy. Please support our habit by making
your Contribution right now:
581 Jeannie Way
Livermore CA 94550
Thank you to all in advance!
FOR SALE
EGT PROBE
MICRO-1000
K TYPE
90 Deg smooth bend mounting tube
GROUNDED
CLAMP MOUNTING for the exhaust pipes
ACS PRICE $56 EA ---> $224 <--- This is HIGH
All 4 probes $180 <--- SAVE
Probes were used for less than one (1) hour
Let me know what type of connector end you require I will install them for
you FREE.
Need a Male - Female Connector ends? Will install for FREE and supply the
mating end for FREE.
Barry
Subject: | 2012 List of Contributors |
Dear Listers,
The 2012 Matronics Email List and Forum Fund Raiser officially ended about a week
ago and its time that I publish this year's List of Contributors. It is the
people on this list that directly make the Email Lists and Forums possible!
Their generous Contributions keep the servers and Internet connection up and
running!
You can still show your support this year and pick up a great gift at the same
time. The Contribution Web Site is fast, easy, and secure:
581 Jeannie Way
Livermore CA 94550
I also want to thank Bob, Jon, and Andy for their generous support through the
supply of great gifts this year!! These guys have some excellent products and
I encourage you to visit their respective web sites:
Bob Nucklolls - AeroElectric - http://www.aeroelectric.com
Jon Croke - HomebuiltHELP - http://www.homebuilthelp.com
Andy Gold - The Builder's Bookstore - http://www.buildersbooks.com
And finally, I'm proud to present The 2012 Fund Raiser List of Contributors:
http://www.matronics.com/loc/2012.html
Thanks again to everyone that made a Contribution this year!!
Subject: | AvGas Available at local MoGas Stations |
Gang:
I was just informed of an article in the NEWARK STAR LEDGER (NEWARK, NJ
NEWSPAPER), Page 21.
Gas Stations being shut down because they are selling AVIATION GAS!!!
Too bad I did not know which station were selling it... I would have loaded
up! Especially at $3.60 a Gallon. <-- High Test. Maybe it was in the
REGULAR Pumps at $3.26 a Gallon???
But, the questions have to be asked:
1 - If there is so much control over AvGas <--- So they say as to keep
prices high. Where was the control on the delivery?
2 - Was AvGAs put into uncontrolled MoGas delivery vehicles?
3 - Was MoGas put into uncontrolled AvGas delivery vehicles?
4 - Have the Controlled Delivery Vehicles now been contaminated with MoGas?
5 - OMG ! ! ! ... What will our Ever Vigilant EPA do now that LEAD is being
burned by surface vehicles? And...
6 - Who picks up the $TAB$ on the destroyed Catalytic Converters. <--- NJ
in all their wisdom has done away with automobile inspection. Except
for EMISSIONS TESTING. So, if your car fails and you don't even know you
had a load of AvGas who pays for the repairs??? AND even if you do know...
WHO PAYS!
No coffee as yet so these are the only questions I can come up with at this
time.
Maybe you have a few to ask?
Barry
Subject: | A follow up to the AvGas MoGas Mix Up |
Six NJ Gas Stations Mistakenly Fed
100LL<http://www.avweb.com/avwebflash/news/100LL_delivered_new_jersey_gas_stations_lead_fuel_207840-1.html>
(Dec 12 2012)
The state of New Jersey confirmed Wednesday that six automotive gas
stations received and sold leaded aviation fuel to drivers before the
mistake was discovered and the sales were shut down. The fuel was delivered
by eight tankers between Dec. 5 and Dec. 7 to six gas stations owned by the
same company. In a statement from the Division of Consumer Affairs, the
fuel was not directly identified as 100LL. The agency said the fuel was
"rated at 104.7 octane compared to 93 octane for super unleaded," and
contained "a small amount of lead." It was mistakenly sold to motorists as
super unleaded. According to the agency, it "should not cause damage to
vehicles engines." Click through for a link to the release from Consumer
Affairs and a list of affected stations.
This is from the AV WEB site:
http://www.avweb.com/cgi-bin/texis/scripts/avweb-search/search.html?query=aviation+gas&x=43&y=11
They think it will not affect the engine... The engine NO! But
the Catalytic Converter and maybe the O2 Sensor and the MAP Sensor?
Barry
Subject: | EGT PROBES FOR SALE |
EGT PROBES FOR SALE
4 EA. ONLY ONE (1) HOUR OF USE.
MICRO 1000 EGT PROBE CLAMP ON STYLE
P/N: 015-059 W 18003
THESE PROBES ARE GROUNDED - THEY WORK WITH ANY GROUNDED GAUGE SYSTEM
EP130 EGT Probe (Clamp-On Type) ACS P/N: 10-01471 ACS PRICE = $57.75
<-- NOT YOUR COST
THESE PROBES WERE USED FOR ONE (1) HOUR AND THEM REMOVED.
THEY WERE USED ONLY FOR BENCH RUNNING OF A REBUILT ENGINE.
YOUR COST: $47.75 EACH <--- THATS LIKE A 18.6% DISCOUNT - FOR ONE (1)
HOUR OLD PROBES.
PLUS SHIPPING: WHATEVER IT COST ME IT COST YOU - NO - ADD ON FEE.
Subject: | Great Flight - Bad Freq's |
Gang:
Maybe this is slightly related to the FAA inspector and the POH issue.
Saturday, I had a Great Flight out to Nantucket (KACK) for
the Daffodil Festival. But it did not start out that way.
I was flying out of Solberg (N51) in NJ. They have a VOR right on the
field that has been down for maintenance for a while and there is a RCO for
NY TRACON either in the VOR building or very close by. Well, I tried about
6 times while on the ground to contact NYAPCH... Three times on each radio
- No luck - Then I tried once more, after I got to pattern altitude - No
luck - So I changed frequency to 132.8 - No luck, of course I tried a few
times on each Comm. Then switch frequencies to 126.4 and 127.8 - NO LUCK!
While all of this radio work was going on I slowed down the plane and
stayed at 2500' so as not to bust the NY Class B. I was flying with Susan
and she suggested I contact Morristown (KMMU) since, we were getting close
to their airspace. GREAT SUGGESTION! When I contacted them I explained I
could NOT raise NY APCH on any of the frequencies, they told me to
"stand-by". . . . . . . . . . They said, try 120.4, now that frequency is
NOT on my Cheat Sheet of 10 frequencies. I gave them a call and BINGO!
Not the fuel - ATC Answered. I Requested my heading and an altitude of
5500' - They cleared me into Class B, on my heading and to my requested
altitude.
So, what went wrong with the other four frequencies and the 19 times of
trying to contact them?
And how does this relate to the POH issue?
It was suggested that the FAA is protesting the obama Budget Cuts - This
could be their own version of the Blue Flu or an obama Backfire. Now, we
all pick on the FAA at some point or another. But, if this is what is
truly happening, the FAA could use our help and it is time that us GA
pilots stand behind the FAA. Matter of fact, we should do something. If
this is the way it is NOW before the tower closings it will only get worse
once the towers are closed... Flight Following FORGET IT! Remember the
Pay As You Go proposal that was voted down? If the towers close, how do
you think they will get the money to reopen them? PAY AS YOU GO! ! !
So, who should I call, who should I be writing my letters to?
*Barry*
*PS: GANG - Put that frequency on your Cheat Sheet.*
*VOR (SBJ) - Still Down - They are transmitting voice and radial signal -
But, there is NO Morse Code. You know what that means!*
*=93Chop=92d Liver=94*
*"The reason Benjamin Franklin was such a great inventor was everything lay
before him. The reason why we don't have great inventors today is,
everyone is trying to reinvent the wheel"*
Subject: | Re: Continental-List Digest: 1 Msgs - 04/28/13 |
Hi Barry,
"So, who should I call, who should I be writing my letters to?"
You should not have taken off because you could not contact ATC via RCO. Call FSS
on the phone and get a freq. Here's how it works.
Call FSS on the phone before you take off and file a flight plan. When you file,
FSS will give you a frequency to use to open your flight plan after take off.
To pop up and to expect service is akin to butting in line. Find your CFI and
ask how this works if you still have questions.
I don't want my Airport Improvement Program (AIP) fund fees to pay for tower staffing.
Towers are for airlines. Airlines and their passengers have twisted Congress's
arm to force the FAA to take my money from my AIP fund to staff their
towers so they can make their money and operate with no inconvenience to themselves.
Meanwhile, my airport won't be able to fix the damn potholes in the taxiways.
The sequester is supposed to be inconvenient. That's the point.
Eric
>Today's complete Continental-List Digest can also be found in either of the
>of the Continental-List Digest and can be viewed with a generic text editor
>HTML Version:
> http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 13-04-28&Archive=Continental
>Text Version:
> http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 13-04-28&Archive=Continental
> Total Messages Posted Sun 04/28/13: 1
> 1. 08:03 PM - Great Flight - Bad Freq's (FLYaDIVE)
>________________________________ Message 1 _____________________________________
>Subject: Continental-List: Great Flight - Bad Freq's
>Gang:
>altitude.
>*Barry*
Eric:
You are misinformed. To start with I am the one asking who should I
contact. First off will be both my congressmen and representatives.
Unfortunately NJ had Lautenberg (D), he is very anti-aviation. Sorry to
say this but NJ congressman affect the Nations policies.
Second: A S&R flight plan was filed on the ground. But that has NOTHING to
do with accessing the Class B. Filing a S&R has NOTHING to do with the
decision of taking off or not taking off, there is NO reason why one should
not take off. The more used method is to file on the ground and ACTIVATE
in the air. The other method is to file on the ground and give them a
AIRBORNE time when the S&R is to be a ACTIVATED. This is just like in the
IFR procedure when you are given a Clearance By time. The very strong
point to remember is: If you FAIL to be airborne within 15 minutes AFTER
your prescribed time you MUST close the flight plan. Failure to do so will
activate the S&R part and you will be FINED. So, do you see
the difference between a S&R and just getting clearance into the Class B?
So, "Find your CFI and ask how this works if you still have questions."
Third: You are not keeping up with what is happening to GA. The AIP does
NOT affect all airports. You have to apply for it and MANY airports prefer
to keep the government out of their business, Solberg is one of them - They
are privately owned. That does NOT mean they are a private airport!
Fourth: Towers - Think about why towers were put in place? They were put
there because that airport became busy - It also might be located very
close to another busy airport (see KMMU & KCDW) AND they are designed to
control air traffic departing and arriving as well as ground control.
Don't confuse Towers with ATC.
Fifth: Towers - Our economy stinks. People are out of work. AND YOU want
to accept the obama Budget Cuts the obama backfire... I backfire also but
I call it a FART! And you want to:
* ALLOW the government to put MORE people out of work?
* ALLOW the government to PURPOSELY make the sky dangerous?
Where do you thing that is going? Its going to the elimination of GA!
What do you think the media is going to do with the first Mid-Air Accident
that happens over a closed Tower Airport, especially when there is a school
or hospital below? I can see it now - ELIMINATE G.A. - - These people
should NOT have pilot licenses - - - O! My GOD! The Children on the
ground, the people in the hospitals. <--- Can you open your eyes and see!
* ALLOW the government to put PEOPLE in danger - People - Maybe your family
and friends to fly in Commercial airliners and not have control towers.
AND don't forget about those Commercial Captains - - - They were once
students and CFI's. You want put ALL these people in danger just so the
government can make things "inconvenient"!
Eric, I'm sorry I don't know how to be polite here, I know I am not PC, nor
will I ever be PC. But, Eric - Get your head out of your asshole and think
and look what is going on!
Oh, If your airport is part of the AIP, and the potholes and not getting
fixed... ASK WHY NOT! They have the money! And, if money is still the
issue - Offer to pass a petition around to all the pilot/owners requesting
them to pay higher tie-down fees or raise the gas prices. I'm sure they
will LOVE you.
Gas prices - My airport is getting at least $2.00 per gallon OVER the
wholesale price. And have you noticed in the past month MoGas has
decreased $0.50 per gallon. Why not AvGas?
Any man or woman that successfully runs a household can balance the Nation
budget. It is simple - Don't spend more than you make! O! But wait, the
Nation does not MAKE anything - Except POTHOLES.
Sorry Gang, I did not want to turn this into a political thing. I didn't!
Not in the way Eric did. But, I will not turn my cheek and get slapped
with the loss of GA.
Barry
On Mon, Apr 29, 2013 at 9:33 AM, Eric Schlanser wrote:
> eschlanser(at)yahoo.com>
> Hi Barry,
> Call FSS on the phone and get a freq. Here's how it works.
> file, FSS will give you a frequency to use to open your flight plan after
> take off. To pop up and to expect service is akin to butting in line. Find
> tower staffing. Towers are for airlines. Airlines and their passengers have
> twisted Congress's arm to force the FAA to take my money from my AIP fund
> to staff their towers so they can make their money and operate with no
> inconvenience to themselves. Meanwhile, my airport won't be able to fix the
> damn potholes in the taxiways. The sequester is supposed to be
> Eric
> the
> editor
> >HTML Version:
> >Text Version:
> >Gang:
> for
> about
> radio
> >altitude.
> >*Barry*
> lay
Subject: | continental r975-c1 |
need a complete engine or the crank shaft...anyone?
Keith McKinley
700HS
X26 Sebastian, FL
http://forums.matronics.com/viewtopic.php?p=403151#403151
Subject: | Carb ice, or vapor lock? |
Don't know if many folks are still monitoring this list, but if so I've got a question.
Two weekends ago, I flew my Zenith 750, powered by a Cont. C-90, from Houston to
Arlington TX. I arrived at 10 am, had it topped off and parked it on the ramp.
Came back at 3 pm to depart. It was 102 degrees, and dew point approx. 65 degrees.
The plane had been parked outside in the sun for 5 hrs. Took off and climbed
to 2500' msl and was running at around 2350 rpm. Decided to climb up to
4000' to get in some cooler air.
About 12 minutes into the flight, the engine began to stumble and sputter, losing
rpm & power enough that I prepared for an off-field landing. Had a nice site
picked and made, and began to pump the throttle to see if the accelerator pump
could get some fuel going. Helped a little, but continued to stumble for the
next 15 minutes. I was able to maintain altitude and made it to another airport
about 11 miles away. My CHT's were climbing & peaked around 410 degrees,
even though I could only maintain 2000 - 2200 rpm. They normally stay between
335 & 360 when running 2350 rpm. My EGT's were climbing as well. This indicates
to me that I was running lean, if I am correct. I do have a mixture control,
but I leave it on full rich all the time and only use it to kill the engine
at the end of a flight. Just about the time I had that airport made, the engine
began to run normal & all temps returned to normal. I landed and began to try
& figure out what had happened.
My first mistake was, I never tried to pull my carb heat when the problem first
showed up. I f I had used my carb heat, I may have found the problem was carb
ice but at the time, I was more focused on landing off-field. I know it is possible
to develop carb ice in any weather, but after a year of flying this plane
over 200 hrs it has never stumbled once. This was the hottest weather I had
ever flown the plane in. I sumped the gascolator and all the tank sumps, no evidence
of water. I pulled the gascolator off and checked the fuel screen, it
was clean & no debri was in the bowl. I ended up spending the night in Dallas
after taking it back up that evening for a 20 minute full-power flight around
the pattern, during which time it ran perfect. Next morning, I departed for Houston
and the engine ran fine all the way home.
I began to suspect the possibility of vapor lock. I've got an ACS metal gascolator
on the firewall, located low. It has no heat shield or blast tube cooling.
From the gascolator to the MA3SPA carb, I've got a SS braided 3/8" fuel line
with firesleeve. I was running straight 100 LL fuel.
Last weekend I had an annual done on the plane. We checked the 2 screens on the
carb, both were clean. Compression testing showed 79/80, 79/80, 78/80, 78/80.
The engine was completely rebuilt in 2011 and had a total of 205 hrs of perfect
performance prior to this incident. I discussed it with my A&P and he suggested
either carb ice or vapor lock.
My question is, based on the high ambient temps, is carb ice a realistic possibility,
or is vapor lock the more likely cause? I have flown in much more carb
ice-prone WX over the past year than that particular day, and have never experienced
it. I have since wrapped my gascolator with a foil backed fiberglass insulated
blanket as a precaution. Any thoughts from more experienced pilots would
be appreciated.
Regards & thanks -
Jimmy Young
Houston TX
Zenith CH750, Cont. C-90
http://forums.matronics.com/viewtopic.php?p=405454#405454
Subject: | Re: Carb ice, or vapor lock? |
Very interesting Jimmy. I would like to hear others reply. I'm still
trying to get my O200 Kitfox finished.
As you know I built two 701s.
Tommy,
Sent from my Xoom Tablet
> got a question.
> Houston to Arlington TX. I arrived at 10 am, had it topped off and parked
> it on the ramp. Came back at 3 pm to depart. It was 102 degrees, and dew
> point approx. 65 degrees. The plane had been parked outside in the sun for
> 5 hrs. Took off and climbed to 2500' msl and was running at around 2350
> rpm. Decided to climb up to 4000' to get in some cooler air.
> losing rpm & power enough that I prepared for an off-field landing. Had a
> nice site picked and made, and began to pump the throttle to see if the
> accelerator pump could get some fuel going. Helped a little, but continued
> to stumble for the next 15 minutes. I was able to maintain altitude and
> made it to another airport about 11 miles away. My CHT's were climbing &
> peaked around 410 degrees, even though I could only maintain 2000 - 2200
> rpm. They normally stay between 335 & 360 when running 2350 rpm. My EGT's
> were climbing as well. This indicates to me that I was running lean, if I
> am correct. I do have a mixture control, but I leave it on full rich all
> the time and only use it to kill the engine at the end of a flight. Just
> about the time I had that airport made, the engine began to run normal &
> all temps returned to normal. I landed and began to try & figure out what
> had happened.
> first showed up. I f I had used my carb heat, I may have found the problem
> was carb ice but at the time, I was more focused on landing off-field. I
> know it is possible to develop carb ice in any weather, but after a year of
> flying this plane over 200 hrs it has never stumbled once. This was the
> hottest weather I had ever flown the plane in. I sumped the gascolator and
> all the tank sumps, no evidence of water. I pulled the gascolator off and
> checked the fuel screen, it was clean & no debri was in the bowl. I ended
> up spending the night in Dallas after taking it back up that evening for a
> 20 minute full-power flight around the pattern, during which time it ran
> perfect. Next morning, I departed for Houston and the engine ran fine all
> the way home.
> gascolator on the firewall, located low. It has no heat shield or blast
> tube cooling. From the gascolator to the MA3SPA carb, I've got a SS braided
> 3/8" fuel line with firesleeve. I was running straight 100 LL fuel.
> on the carb, both were clean. Compression testing showed 79/80, 79/80,
> 78/80, 78/80. The engine was completely rebuilt in 2011 and had a total of
> 205 hrs of perfect performance prior to this incident. I discussed it with
> my A&P and he suggested either carb ice or vapor lock.
> possibility, or is vapor lock the more likely cause? I have flown in much
> more carb ice-prone WX over the past year than that particular day, and
> have never experienced it. I have since wrapped my gascolator with a foil
> backed fiberglass insulated blanket as a precaution. Any thoughts from more
> experienced pilots would be appreciated.
> Regards & thanks -
> Jimmy Young
> Houston TX
From: | "bigdog(at)bentwing.com" <bigdog(at)bentwing.com> |
I'm based at Hooks in Houston but back in the late 70's I had a Taylorcraft with
an A-65 based at Clover Field (now Pearland Intergalactic). Returning from a
run to the beach near Matagorda Island I had a similar experience. It was a hot
summer day with high humidity like we've had this week. While I did pull carb
heat I didn't leave it on long enough. With the power continuing to drop I
managed to limp into Lake Jackson and had the engine stop on the runway. By the
time I could get some tools to remove the cowling the ice had evaporated and
there was no evidence of other problems. I started up and flew home without problems.
That was the only time it's ever happened to me. The A & C-series are
known for susceptibility to carb ice and I learned afterward that it's possible
even on hot days. I would not discount carb ice. I fly behind an IO-550B now
so don't have the issue but I'm restoring an L-2 and will need to contend with
it again when that is flying.
Greg Young
-----Original Message-----
From: owner-continental-list-server(at)matronics.com [mailto:owner-continental-list-server(at)matronics.com] On Behalf Of Jimmy Young
Sent: Saturday, July 27, 2013 9:26 PM
Subject: Continental-List: Carb ice, or vapor lock?
be appreciated.
Regards & thanks -
Jimmy Young
Houston TX
From: | "Jim Baker" <jim.baker(at)windstream.net> |
X-mailer: Pegasus Mail for Windows (4.61)
When ice accumulates, that richens the mixture, not leans it. EGT and CHT
would decrease.
http://www.stinsonclub.org/newBB3/viewtopic.php?f=4&t=215
http://flighttraining.aopa.org/students/presolo/skills/carbicing.html
Each time a normally aspirated, four-cycle engine (which describes the engines
in most trainers and simple four-place aircraft) completes two crankshaft
revolutions, it draws a volume of air equal to the engine's displacement (less
small losses because of throttle position and system friction) through the
carburetor. Given a constant throttle position, this volume essentially remains
the same whether the carburetor is wide open or clogged with ice.
If the carburetor venturi is constricted because of ice, the velocity of the flow
must increase because the amount of air flowing to the cylinders is constant.
This increase in velocity is much more significant than the small decrease in
mass flow caused by the restriction in the venturi because of ice.
An increase in velocity, Bernoulli says, will cause a further decrease in static
pressure within the venturi, which means the ambient static pressure acting on
the fuel in the float bowl will push more fuel through the metering jet, resulting
in
a richer mixture.
If your EGTs and CHTs went up, I'd look for another cause.
Send reply to: continental-list(at)matronics.com
question.
to Arlington TX. I arrived at 10 am, had it topped off and parked it on the ramp.
degrees. The plane had been parked outside in the sun for 5 hrs. Took off and
climbed to 2500' msl and was running at around 2350 rpm. Decided to climb up
pump could get some fuel going. Helped a little, but continued to stumble for
the next 15 minutes. I was able to maintain altitude and made it to another airport
try & figure out what had happened.
possible to develop carb ice in any weather, but after a year of flying this plane
evidence of water. I pulled the gascolator off and checked the fuel screen, it
Houston and the engine ran fine all the way home.
insulated blanket as a precaution. Any thoughts from more experienced pilots
> Regards & thanks -
> Jimmy Young
> Houston TX
Jim Baker
Elmore City, OK
580.788.2779 home
405.426.5377 cell
Hi Jim:
There are quite a few questions and comments I have to go through:
1 - Did you check your Spark Plugs?
2 - Did you check your Timing? <--- Major issue after an Annual.
3 - WHY DID YOU NOT LEAN? <--- You should be leaning ALL the time. Lean
avery aggressively while taxing - So much so - THAT - If you forget to go
full rich on take-off the engine will die. You CANNOT hurt the engine and
it will prevent lead fouling of the plugs and save you a little taxi gas.
4 - Keeping with the leaning subject - As you altitude increases you will
be running way too rich. This could cause a reduction in HP as well as
carbon & lead fouling. Extra rich also lowers the temp in the carb which
will increase your possibilities of Carb Ice.
5 - I am not a fan of Gascolators - Just way too many issues with them - I
do believe very strongly in - IN LINE fuel filters. BUT! I doubt it the
Gascolator was the culprit.
6 - ALL your fuel lines should be heat shielded... Well, as much as
physically possible.
7 - Vapor Lock - Is easy to prevent. It starts with fuel system design
What size fuel line are you using? What is the fuel line made from? How
do you have the fuel line routed? How is the overall cooling under the cowl?
8 - From you statement of: "They normally stay between 335 & 360 when
running 2350 rpm. My EGT's were climbing as well. This indicates to me that
I was running lean, if I am correct." Well you are correct. A CHT of 410
F is above normal IF you compare it to past operations. What were the EGT
readings at the time? I'd bet below 1400 F probably more like 1320 F.
SOoooo what would cause leaning? NOT VAPOR LOCK! With vapor lock you
loose gas flow and the EGT & CHT goes DOWN. NOT CARB ICE! With carb ice
you loose fuel flow and EGT & CHT goes DOWN. If CHT goes Down and EGT goes
Up --- LQQK at fouled plugs or poor spark. If RPM cannot be maintained and
CHT goes Up ---LQQK at AIR LEAKS... Carb, Intake Tubes.
9 - You did not mention OIL TEMPS?
OK - Enough for now. Let's hear back from you on these basic checks.
*Barry*
Yes. they looked good, tannish to greyish in color, not fouled.
Did that at annual. 26 & 28 degrees, same as first flight 1 year previous.
No good reason, other than I've been advised that unless I'm flying above 5000'
regularly, I don't need to. I usually fly at less than 3000' msl most of the
time.
> 5 - I am not a fan of Gascolators - Just way too many issues with them - I dobelievevery
strongly in - IN LINE fuel filters. BUT! I doubt it the Gascolator
was theculprit.
Ok, but what then separates water from your fuel?
> 6 - ALL your fuel lines should be heat shielded... Well, as much as physically
possible.
> 7 - Vapor Lock - Is easy to prevent. It starts with fuel systemdesign What size
fuel line are you using? What is the fuel line made from? How do you have the
Lines are 3/8" Aeroquip rubber hose with AN socketless fittings, except FWF it's
3/8" Aeroquip SS braided hose with firesleeve. They are routed straight from
the wing tanks to a tee, to a shut off valve, to the FW bulkhead pass-thru, to
the gascolator, and on to the carb. Pretty standard and straight-forward. You
ask "how is the overall cooling under the cowl? I've got temp strips on the
mags and the firewall. They have topped out between 160 & 180 degrees. Don't really
know how one could keep that area cool, as it's purpose is to exhaust engine
heat. I have considered running blast tubes to my mags.
> 8 - From you statement of: "They normally stay between 335 & 360 when running
2350 rpm. My EGT's were climbing as well. This indicates to me that I was running
lean, if I am correct." Well you are correct. A CHT of 410 F is above normal
IF youcompareit to past operations. What were the EGT readings at the time?
I'd bet below 1400 Fprobablymore like 1320 F. SOoooo what would cause leaning?
NOT VAPOR LOCK! With vapor lock you loose gas flow and the EGT & CHT goes DOWN.
NOT CARB ICE! With carb ice you loose fuel flow and EGT & CHT goes DOWN.
If CHT goes Down and EGT goes Up --- LQQK at fouled plugs or poor spark. If RPM
cannot be maintained and CHT goes Up ---LQQK at AIR LEAKS... Carb, Intake Tubes.
My egt's each register a little different temps in cruise, but they always stay
consistent. I had my hands full flying the plane so I wasn't taking notes, but
I do recall when the cht alarm light went off I noticed the highest egt was
1440 or so which is about 75-100 degrees higher than it would normally be. So,
I had both higher cht's and egt's occuring at the same time my engine was stumbling
& performing poorly. These higher CHT & EGT's may have been partly caused
by my having a pitch-up attitude & slow airspeed, trying to hold altitude at
low power output for an extended period of time while I was nursing my way to
the other airport. This would have obviously reduced the volume of cooling air
to the engine. I've noticed when doing slow flight at 1800 & 1900 rpm, my cht's
will get up in the mid 300's similar to full cruise due to the same lack
of cooling air volume.
I've got a question for you on this section. You said "With vapor lock, you loose
gas flow and the cht & egt go down." Seems to me the opposite would occur,
since you'd have the same air volume and less gas, thus a leaned out condition.
What am I missing there?
They never exceeded 210. On a hot summer day they will settle in between 200 &
210 at cruise. In the Texas winter, O/T runs 180 -195. I do not have an oil cooler.
I appreciate the input, & please let me know what any or all of you think on these
comments. I'm still leaning towards vapor lock. Yesterday, I made a foil-faced
insulation blanket and wrapped my gascolator with it. Tied it off with cable
ties.
Jimmy Y
Houston
http://forums.matronics.com/viewtopic.php?p=405528#405528
Five hours in the Texas sun, I would put money on the vapor lock theory.
Your engine compartment was thoroughly heat-soaked.
March 26, 2010 - July 29, 2013
Continental-Archive.digest.vol-ae
