Engines-Archive.digest.vol-aq
March 21, 2007 - May 02, 2008
      Probably just as important, the angle valve engines are designed for
      more cooling, both in the cylinder head design, and with oil squirt
      nozzles spraying oil on the bottom side of the pistons. The weight
      increase is unfortunate, as it somewhat degrades the performance
      increase. I would think that the angle valve cylinders would be more
      desirable for turbocharging, with the better heat dissipation
      capability. The one factory TIO540 with parallel valve cylinders that
      I am familiar with, had to be retrofitted with oil cooled valve guides
      to make the valve stems and guides last.
      On 3/20/07, Dan Rogers  wrote:
      > Thank you, Gary and Bill,
      > I have now studied the Lycoming website engine lists and can see a clear
      > relationship between comp ratio, engine width and weight.  There is also
      > power corelation, but because of turbo and various RPM combinations, it
      > is not as clear cut.
      > Thanks again,
      > Dan
      > Gary Casey wrote:
      > > I'm not "the" Lycoming expert, but as far as I can tell everything with
      > > a power rating of 300 or more has the angle-valve cylinders.  A
      > > sure-fire way to tell is to look at the Lycoming spec sheet on their
      > > website and the parallel-valve engines are narrower.  Other than that
      > > the model numbers don't give much of a clue unless you just know which
      > > is which.  As Bill said, the angle-valve heads flow better.  The
      > > naturally-aspirated versions have a 8.7 compression ratio vs. the 8.5 of
      > > the parallel-valve engine, and that also helps to produce slightly more
      > > power.  With more space between the valves the angle-valve engine
      > > requires less pressure drop for cooling, theoretically reducing cooling
      > > drag.  But they are heavier, to the tune of 4 or 5 pounds per cylinder
      > > and the angle-valve engines don't have the same reputation for longevity
      > > as the parallel-valve engines.  An expert told me that there is nothing
      > > to be gained by porting and polishing the angle-valve cylinder, while
      > > the parallel-valve version can be ported to achieve almost the same
      > > airflow as the angle-valve cylinder.
      > > Gary Casey
      > > Parallel-valve IO-540 with 10:1 compression dyno tested at 305 hp
Subject: Re: Lycoming Cylinder question
From: "Jon A. Delamarter" <jdelamarter(at)lycoming.textron.com>
Date: Mar 21, 2007
Dan: Here's a brief overview I wrote for the new Lycoming website. Let me know if I can help with more details. Parallel Valve Cylinder The intake and exhaust valves of a parallel valve cylinder are mounted in parallel to one another in the cylinder head and share a common rocker shaft which is retained by the rocker cover. This arrangement gives the parallel valve cylinders rocker cover its distinctive parallel or square shape; parallel valve rocker covers are also distinguished from angle valve rocker covers by their greater thickness. Parallel valve cylinders are utilized on carbureted and some lower output, lightweight fuel injected engines. Most parallel valve 4 cylinder engines do not incorporate a counterweighted crankshaft which further contributes to their relative lightweight. Angle Valve Cylinder The intake and exhaust valves of an angle valve cylinder are mounted at angles to one another in the cylinder head. Angle valve cylinders utilize separate rocker shafts for intake and exhaust rockers; the rocker shafts are held in the cylinder head by separate retaining plates. This arrangement gives the angle valve cylinders rocker cover its distinctive angle shape; angle valve rocker covers are also distinguished from parallel valve rocker covers by their lesser thickness. Utilized on high output engines. Angle valve engines are heavier and slightly wider than their parallel valve counterparts but are capable of safely and efficiently producing more horsepower due to increased head density and improved head design. Angle valve engines incorporate counterweighted crankshafts which reduce torsional vibration. -------- Jon A. Delamarter Thunderbolt Manager Lycoming Engines Read this topic online here: http://forums.matronics.com/viewtopic.php?p=102066#102066 ________________________________________________________________________________
Subject: Re: New Lycoming Website
Date: Mar 21, 2007
That is the intent. > [quote="Float Flyr"]About time!!!!! > > Thanks. I'll be watching! What I'd like to see is a control by wire piston > engine. One control for everything. > > Noel > > > > > > -- > -------- Jon A. Delamarter Thunderbolt Manager Lycoming Engines Read this topic online here: http://forums.matronics.com/viewtopic.php?p=102067#102067 ________________________________________________________________________________
Date: Mar 21, 2007
That last sentence needs a bit of qualification. A large number of angle valve engines do NOT have counterweighted crankshafts. In particular, the IO-360-A1A, used extensively from 1964-1976. On 3/21/07, Jon A. Delamarter wrote: Angle valve engines incorporate counterweighted crankshafts which reduce torsional vibration. > ________________________________________________________________________________
Date: Mar 21, 2007
Touche'! You are absolutely correct. See what over-generalization gets me? I should have said "most" angle valve engines incorporate counter-weighted crankshafts. Hmm, I see I already have to edit my new website. Thanks for keeping me straight! > > apilot2(at)gmail.com wrote: > > That last sentence needs a bit of qualification. A large number of > > angle valve engines do NOT have counterweighted crankshafts. In > > particular, the IO-360-A1A, used extensively from 1964-1976. > > > > On 3/21/07, Jon A. Delamarter wrote: > > Angle valve engines incorporate counterweighted crankshafts which > > reduce torsional vibration. > > > > > > > > > > > > > > -------- Jon A. Delamarter Thunderbolt Manager Lycoming Engines Read this topic online here: http://forums.matronics.com/viewtopic.php?p=102079#102079 ________________________________________________________________________________
Date: Mar 21, 2007
Is this already on the Lycoming website?? If so I didn't find it when I went looking for this info! Dan R Jon A. Delamarter wrote: > > Dan: > > Here's a brief overview I wrote for the new Lycoming website. Let me know if I can help with more details. > > ________________________________________________________________________________
Date: Mar 21, 2007
Dan: Yes it is, but you're not going to see it unless you go through the engine configurator on the Thunderbolt microsite. www.lycoming.com/thunderbolt If you go through and configure a Thunderbolt engine, there is an option on the final page to view a printable version of the estimate. The bottom of the estimate has a ton of data. The info I posted is only a small portion. You always have the option of emailing me directly at jdelamarter(at)lycoming.textron.com. I don't have all the answers, but I work with the folks that have most of them! Kind regards, > [quote="drogers(at)maf.org"]Is this already on the Lycoming website?? If so I didn't find it when I > went looking for this info! -------- Jon A. Delamarter Thunderbolt Manager Lycoming Engines Read this topic online here: http://forums.matronics.com/viewtopic.php?p=102167#102167 ________________________________________________________________________________
Subject: EPiC
Date: Mar 22, 2007
I just found an article from 2000 that talks about a new FADEC (EPiC) that Lycoming hoped to have certified within the year. Is this the follow-on to the LASAR to which you referred? Gary -----Original Message----- From: jdelamarter(at)lycoming.textron.com Sent: Wed, 21 Mar 2007 6:46 AM Subject: Engines-List: Re: Lycoming Cylinder question ________________________________________________________________________ from AOL at AOL.com. ________________________________________________________________________________
Subject: Ram Engines...Good? or Bad?
Date: Mar 24, 2007
I asked this on the Kitfox list because that is what I am building and contemplating a EA81 - Ram Conversion. The question is: What is the general concensus on Ram Engines and the EA81? Does anyone have any experience with Ron and what are your thoughts of his product? I am looking for an engine with good power that will get me in and out of the backcountry in my Series 7 Kiftox. I like the looks of his website and the specs on his engines...can anyone tell me if he really is getting 140 hp out of the EA81 and does it really come in at ~200 lbs installed? If so, it seems that it should outperform any Rotax hands down! Anyone with any insight/experience/flight time with one of his engines, your comments and advice is greatly appreciated. Thanks, Darin Hawkes Kitfox Series 7 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=102714#102714 ________________________________________________________________________________
Subject: Re: Ram Engines...Good? or Bad?
Date: Mar 25, 2007
If Ram is the same company that has an engine series for the twin Cessna's, then I've got plenty of time behind there product with no problems Paul Rice RV8, getting close to flying http://www.matronics.com/Navigator?Engines-List Navigator?Engines-List> ________________________________________________________________________________
Date: Mar 25, 2007
Paul, That is a different company. There is a Ram Engines that deals in certificated engines. I am looking for information specifically about the Ram Engines that overhauls and builds subaru engines for the experimental market. Thanks though for the reply. Darin Read this topic online here:
http://forums.matronics.com/viewtopic.php?p=102772#102772 ________________________________________________________________________________
Date: Mar 25, 2007
From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
If your looking for an endorsement of Ram Performance then I can tell you that Ron Carr I probably the most knowlegable guy in the country as far as the EA 81 engine goes. Ron came up with the only bullet proof way to ensure valve giudes will not fall out of the heads on these motors. I wrote an article on the subject for Kitplanes magazine (August last year I think). Do a Google search on my name and you will find many web postings on the whole sorry saga...But Ron fixed it (and many other engines) for good. His quality work is of the highest standard. http://www.ramengines.com/ Frank Hinde -----Original Message----- From: owner-engines-list-server(at)matronics.com [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of darinh Sent: Sunday, March 25, 2007 8:08 AM Subject: Engines-List: Re: Ram Engines...Good? or Bad? Paul, That is a different company. There is a Ram Engines that deals in certificated engines. I am looking for information specifically about the Ram Engines that overhauls and builds subaru engines for the experimental market. Thanks though for the reply. Darin Read this topic online here: http://forums.matronics.com/viewtopic.php?p=102772#102772 ________________________________________________________________________________
Date: Mar 25, 2007
Just to bang on a bit more about Ram, I personally would not go anywhere else for an EA81 conversion. I did and I was very very sorry..! After Ron sorted it it was (and still is in the hands of its new owner) perfectly reliable. I will be out of town next week but if you want to email me directly I would be glad to give you phone number and we can talk directly. There is nothing worse than wondering if the engine is about to quit on you when all you can see is trees, believe me I know! Frank 601 HDS 400 hours when I sold it last year. -----Original Message----- From: owner-engines-list-server(at)matronics.com [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of darinh Sent: Saturday, March 24, 2007 8:04 PM Subject: Engines-List: Ram Engines...Good? or Bad? I asked this on the Kitfox list because that is what I am building and contemplating a EA81 - Ram Conversion. The question is: What is the general concensus on Ram Engines and the EA81? Does anyone have any experience with Ron and what are your thoughts of his product? I am lookingy) for an engine with good power that will get me in and out of the backcountry in my Series 7 Kiftox. I like the looks of his website and the specs on his engines...can anyone tell me if he really is getting 140 hp out of the EA81 and does it really come in at ~200 lbs installed? If so, it seems that it should outperform any Rotax hands down! Anyone with any insight/experience/flight time with one of his engines, your comments and advice is greatly appreciated. Thanks, Darin Hawkes Kitfox Series 7 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=102714#102714 ________________________________________________________________________________
Date: Mar 25, 2007
For more info on EA 81's go to the Zenith list and the Stratus list on Matronics....Lots and lots of discussion on those lists about various conversions. Cheers Frank -----Original Message----- From: owner-engines-list-server(at)matronics.com [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of darinh Sent: Sunday, March 25, 2007 8:08 AM Subject: Engines-List: Re: Ram Engines...Good? or Bad? Paul, That is a different company. There is a Ram Engines that deals in certificated engines. I am looking for information specifically about the Ram Engines that overhauls and builds subaru engines for the experimental market. Thanks though for the reply. Darin Read this topic online here: http://forums.matronics.com/viewtopic.php?p=102772#102772 ________________________________________________________________________________
Date: Mar 25, 2007
Hi Darin I have no knowledge of that conversion. I'd be skeptical of 140 hp unless it has a turbo though. In general the EA81 is an excellent engine. Chuck Kondas has an entertaining book about his stock junkyard EA81 turbo that he broke 1,000 hours with. The bigger question might be "do you want to fly behind an engine that is tweaked that much"? Might be fine if you can find a few RAM users with several hundred flight hours. There are a couple of Subaru lists on yahoo that you might want to search. I've heard RAM mentioned from time to time. In my mind if you want 100+ true hp., I'd look at a larger engine for reliability. Guys who actually weigh their entire EA81 installations come out more like 250 lbs with a redrive but no turbo which means they can't outperform a 912S and in some cases have nose heavy airplanes. I am very pleased with my soob but I'll be the first to admit that a conversion almost always costs more than a used rotax or Lyc. and takes longer. Maintenance and operating costs should be lower than a Lyc. but you won't be asking an FBO to fix it for you and that engine has been out of production for a long time now. Insurance may be an issue for you with a conversion but I had no trouble. Ken internally stock ej22, derated to 120 hp, estimated 320 lbs installed, 60 flight hours, single lever EFI engine control, quiet muffler, no preheat required, no shock cooling issues, no expensive AD's, 4 to 5.5 USgph depending on how fast I go but it prefers unleaded no alcohol fuel. darinh wrote: > >I asked this on the Kitfox list because that is what I am building and contemplating a EA81 - Ram Conversion. The question is: What is the general concensus on Ram Engines and the EA81? Does anyone have any experience with Ron and what are your thoughts of his product? I am looking for an engine with good power that will get me in and out of the backcountry in my Series 7 Kiftox. I like the looks of his website and the specs on his engines...can anyone tell me if he really is getting 140 hp out of the EA81 and does it really come in at ~200 lbs installed? If so, it seems that it should outperform any Rotax hands down! > >Anyone with any insight/experience/flight time with one of his engines, your comments and advice is greatly appreciated. > >Thanks, > >Darin Hawkes >Kitfox Series 7 > > ________________________________________________________________________________
Date: Mar 25, 2007
I have a RAM 140 engine in a Zenith 601 XL. Yes it put out 141 HP on a dyno, Very strong and smooth Richard N601ZT ________________________________________________________________________________
From: "Southern Reflections" <purplemoon99(at)bellsouth.net>
Date: Mar 25, 2007
Okay, Darin, let's talk about the RAM engine. First of all, the only part of that engine that is Subaru is the block, crank shaft, and cam shaft. After that all of the other parts have been improved by Ron over the last 25 years including reworking the block putting more pins in it, cutting more oil journals, etc. It has cast aluminum forged pistons, new main and rod bearings, new water pump, new oil pump, stainless steel new intake valves, stainless steel exhaust valves, high performance valve springs, reground cam and lifters, extra bushings on the mains, extra oiling to the thrust main that is also teflon coated, flowed dual port heads, tuned exhaust and a lot more goodies. It really isn't a Subaru anymore; it's a RAM. I just purchased one six months ago and it's climbing at over 1800 fpm on my 601XL. (you need to run a Prince PT Prop) It is one fine engine. My engine is not 140 hp; mine is 130 hp. The engine block and internal parts are the same as the 140; the 140 has electronic fuel injection and mine has a throttle body. (I suggest the electronic fuel injection; it's much better) There are a lot more goodies in the engine that make it a lot better than I've stated. If you really want to know about it, go to his website at info(at)ramengines.com I'm very happy with mine. Although I would like to add this, if you're thinking seriously of buying a RAM engine, you need to give him plenty of lead time as he is not spitting these engines out. Just remember, Ron is a custom engine builder. And, as far as I can tell, he is the BEST out there, bar none. As far as the weight, mine does weigh under 200 lbs. and I'm sure it would blow the wings off of a 912S and I don't have a turbo. If you think you want a turbo engine, Ron has a 200 hp turbo that can compete with anything out there. THANKS. Joe N101HD P.S. The last test flight mine jumped off the ground at 150 ft. ----- Original Message ----- From: "darinh" <gerns25(at)netscape.net> Sent: Saturday, March 24, 2007 11:03 PM Subject: Engines-List: Ram Engines...Good? or Bad? > > I asked this on the Kitfox list because that is what I am building and > contemplating a EA81 - Ram Conversion. The question is: What is the > general concensus on Ram Engines and the EA81? Does anyone have any > experience with Ron and what are your thoughts of his product? I am > looking for an engine with good power that will get me in and out of the > backcountry in my Series 7 Kiftox. I like the looks of his website and > the specs on his engines...can anyone tell me if he really is getting 140 > hp out of the EA81 and does it really come in at ~200 lbs installed? If > so, it seems that it should outperform any Rotax hands down! > > Anyone with any insight/experience/flight time with one of his engines, > your comments and advice is greatly appreciated. > > Thanks, > > Darin Hawkes > Kitfox Series 7 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=102714#102714 > > > ________________________________________________________________________________
Date: Mar 26, 2007
Joe, How does Ram compare with Eggenfeller? In a message dated 3/25/2007 6:49:58 P.M. Eastern Daylight Time, purplemoon99(at)bellsouth.net writes: --> Engines-List message posted by: "Southern Reflections" Okay, Darin, let's talk about the RAM engine. First of all, the only part of that engine that is Subaru is the block, crank shaft, and cam shaft. After that all of the other parts have been improved by Ron over the last 25 years including reworking the block putting more pins in it, cutting more oil journals, etc. It has cast aluminum forged pistons, new main and rod bearings, new water pump, new oil pump, stainless steel new intake valves, stainless steel exhaust valves, high performance valve springs, reground cam and lifters, extra bushings on the mains, extra oiling to the thrust main that is also teflon coated, flowed dual port heads, tuned exhaust and a lot more goodies. It really isn't a Subaru anymore; it's a RAM. I just purchased one six months ago and it's climbing at over 1800 fpm on my 601XL. (you need to run a Prince PT Prop) It is one fine engine. My engine is not 140 hp; mine is 130 hp. The engine block and internal parts are the same as the 140; the 140 has electronic fuel injection and mine has a throttle body. (I suggest the electronic fuel injection; it's much better) There are a lot more goodies in the engine that make it a lot better than I've stated. If you really want to know about it, go to his website at info(at)ramengines.com I'm very happy with mine. Although I would like to add this, if you're thinking seriously of buying a RAM engine, you need to give him plenty of lead time as he is not spitting these engines out. Just remember, Ron is a custom engine builder. And, as far as I can tell, he is the BEST out there, bar none. As far as the weight, mine does weigh under 200 lbs. and I'm sure it would blow the wings off of a 912S and I don't have a turbo. If you think you want a turbo engine, Ron has a 200 hp turbo that can compete with anything out there. THANKS. Joe N101HD P.S. The last test flight mine jumped off the ground at 150 ft. ----- Original Message ----- From: "darinh" <gerns25(at)netscape.net> Sent: Saturday, March 24, 2007 11:03 PM Subject: Engines-List: Ram Engines...Good? or Bad? > > I asked this on the Kitfox list because that is what I am building and > contemplating a EA81 - Ram Conversion. The question is: What is the > general concensus on Ram Engines and the EA81? Does anyone have any > experience with Ron and what are your thoughts of his product? I am > looking for an engine with good power that will get me in and out of the > backcountry in my Series 7 Kiftox. I like the looks of his website and > the specs on his engines...can anyone tell me if he really is getting 140 > hp out of the EA81 and does it really come in at ~200 lbs installed? If > so, it seems that it should outperform any Rotax hands down! > > Anyone with any insight/experience/flight time with one of his engines, > your comments and advice is greatly appreciated. > > Thanks, > > Darin Hawkes > Kitfox Series 7 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=102714#102714 > > > ________________________________________________________________________________
Date: Mar 26, 2007
Egg does not do the EA 81 motor I believe. Frank. ________________________________ From: owner-engines-list-server(at)matronics.com [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of NYTerminat(at)aol.com Sent: Sunday, March 25, 2007 11:02 PM Subject: Re: Engines-List: Ram Engines...Good? or Bad? Joe, How does Ram compare with Eggenfeller? In a message dated 3/25/2007 6:49:58 P.M. Eastern Daylight Time, purplemoon99(at)bellsouth.net writes: Okay, Darin, let's talk about the RAM engine. First of all, the only part of that engine that is Subaru is the block, crank shaft, and cam shaft. After that all of the other parts have been improved by Ron over the last 25 years including reworking the block putting more pins in it, cutting more oil journals, etc. It has cast aluminum forged pistons, new main and rod bearings, new water pump, new oil pump, stainless steel new intake valves, stainless steel exhaust valves, high performance valve springs, reground cam and lifters, extra bushings on the mains, extra oiling to the thrust main that is also teflon coated, flowed dual port heads, tuned exhaust and a lot more goodies. It really isn't a Subaru anymore; it's a RAM. I just purchased one six months ago and it's climbing at over 1800 fpm on my 601XL. (you need to run a Prince PT Prop) It is one fine engine. My engine is not 140 hp; mine is 130 hp. The engine block and internal parts are the same as the 140; the 140 has electronic fuel injection and mine has a throttle body. (I suggest the electronic fuel injection; it's much better) There are a lot more goodies in the engine that make it a lot better than I've stated. If you really want to know about it, go to his website at info(at)ramengines.com I'm very happy with mine. Although I would like to add this, if you're thinking seriously of buying a RAM engine, you need to give him plenty of lead time as he is not spitting these engines out. Just remember, Ron is a custom engine builder. And, as far as I can tell, he is the BEST out there, bar none. As far as the weight, mine does weigh under 200 lbs. and I'm sure it would blow the wings off of a 912S and I don't have a turbo. If you think you want a turbo engine, Ron has a 200 hp turbo that can compete with anything out there. THANKS. Joe N101HD P.S. The last test flight mine jumped off the ground at 150 ft. ----- Original Message ----- From: "darinh" <gerns25(at)netscape.net> To: Sent: Saturday, March 24, 2007 11:03 PM Subject: Engines-List: Ram Engines...Good? or Bad? > > I asked this on the Kitfox list because that is what I am building and > contemplating a EA81 - Ram Conversion. The question is: What is the > general concensus on Ram Engines and the EA81? Does anyone have any > experience with Ron and what are your thoughts of his product? I am > looking for an engine with good power that will get me in and out of the > backcountry in my Series 7 Kiftox. I like the looks of his website and > the specs on his engines...can anyone tell me if he really is getting 140 > hp out of the EA81 and does it really come in at ~200 lbs installed? If > so, it seems that it should outperform any Rotax hands down! > > Anyone with any insight/experience/flight time with one of his engines, > your comments and advice is greatly appreciated. > > Thanks, > > Darin Hawkes > Kitfox Series 7 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=102714#102714 > > > > > > > > > > the es Day --> - NEW MATRONICS WEB FORUMS - bsp; --> ===================== ________________________________ AOL now offersle="http://www.aol.com?ncid=AOLAOF00020000000339" href="http://www.aol.com?ncid=AOLAOF00020000000339" target="_blank">AOL.com. ________________________________________________________________________________
Date: Mar 26, 2007
Thanks guys, I have been looking at the Egg H6 which comes with an optional turbo rated 180-210 HP. I would like to compare that with the RAM product for weight etc. Time to do more research. -----Original Message----- From: owner-engines-list-server(at)matronics.com [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of Hinde, Frank George (Corvallis) Sent: Monday, March 26, 2007 10:29 AM To: engines-list(at)matronics.com Subject: RE: Engines-List: Ram Engines...Good? or Bad? Egg does not do the EA 81 motor I believe. Frank. ________________________________ From: owner-engines-list-server(at)matronics.com [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of NYTerminat(at)aol.com Sent: Sunday, March 25, 2007 11:02 PM To: engines-list(at)matronics.com Subject: Re: Engines-List: Ram Engines...Good? or Bad? Joe, How does Ram compare with Eggenfeller? In a message dated 3/25/2007 6:49:58 P.M. Eastern Daylight Time, purplemoon99(at)bellsouth.net writes: Reflections" Okay, Darin, let's talk about the RAM engine. First of all, the only part of that engine that is Subaru is the block, crank shaft, and cam shaft. After that all of the other parts have been improved by Ron over the last 25 years including reworking the block putting more pins in it, cutting more oil journals, etc. It has cast aluminum forged pistons, new main and rod bearings, new water pump, new oil pump, stainless steel new intake valves, stainless steel exhaust valves, high performance valve springs, reground cam and lifters, extra bushings on the mains, extra oiling to the thrust main that is also teflon coated, flowed dual port heads, tuned exhaust and a lot more goodies. It really isn't a Subaru anymore; it's a RAM. I just purchased one six months ago and it's climbing at over 1800 fpm on my 601XL. (you need to run a Prince PT Prop) It is one fine engine. My engine is not 140 hp; mine is 130 hp. The engine block and internal parts are the same as the 140; the 140 has electronic fuel injection and mine has a throttle body. (I suggest the electronic fuel injection; it's much better) There are a lot more goodies in the engine that make it a lot better than I've stated. If you really want to know about it, go to his website at info(at)ramengines.com I'm very happy with mine. Although I would like to add this, if you're thinking seriously of buying a RAM engine, you need to give him plenty of lead time as he is not spitting these engines out. Just remember, Ron is a custom engine builder. And, as far as I can tell, he is the BEST out there, bar none. As far as the weight, mine does weigh under 200 lbs. and I'm sure it would blow the wings off of a 912S and I don't have a turbo. If you think you want a turbo engine, Ron has a 200 hp turbo that can compete with anything out there. THANKS. Joe N101HD P.S. The last test flight mine jumped off the ground at 150 ft. ----- Original Message ----- From: "darinh" <gerns25(at)netscape.net> To: Sent: Saturday, March 24, 2007 11:03 PM Subject: Engines-List: Ram Engines...Good? or Bad? > > I asked this on the Kitfox list because that is what I am building and > contemplating a EA81 - Ram Conversion. The question is: What is the > general concensus on Ram Engines and the EA81? Does anyone have any > experience with Ron and what are your thoughts of his product? I am > looking for an engine with good power that will get me in and out of the > backcountry in my Series 7 Kiftox. I like the looks of his website and > the specs on his engines...can anyone tell me if he really is getting 140 > hp out of the EA81 and does it really come in at ~200 lbs installed? If > so, it seems that it should outperform any Rotax hands down! > > Anyone with any insight/experience/flight time with one of his engines, > your comments and advice is greatly appreciated. > > Thanks, > > Darin Hawkes > Kitfox Series 7 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=102714#102714 > > > > > > > > > > the es Day --> - NEW MATRONICS WEB FORUMS - bsp; --> ===================== ________________________________ AOL now offersle="http://www.aol.com?ncid=AOLAOF00020000000339" href="http://www.aol.com?ncid=AOLAOF00020000000339" target="_blank">AOL.com. href="http://www.matronics.com/Navigator?Engines-List">http://www.matro n ics.com/Navigator?Engines-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: Apr 01, 2007
Thanks guys for the great input! The more I learn about Ram, the more I am leaning in that direction. If the engine indeed produces 140 hp, which it sounds like it does, and it weighs under 200 lbs, then if should for sure fly the wings of a similar bird powered by a 912S. Thanks again for the info. Darin Read this topic online here: http://forums.matronics.com/viewtopic.php?p=104383#104383 ________________________________________________________________________________
Date: Apr 02, 2007
From: "DEAN PSIROPOULOS" <dean.psiropoulos(at)verizon.net>
Subject: Lycoming tach drive cover.
I'm using a VM-1000 engine monitor that has a hall sensor screwed into the magneto for tachometer measurements. So...I'm not using the Lycoming tachometer drive in the accessory case and ordered a cover to place over it. It's just a small aluminum cap with female threads and a knurled outer surface to provide a good finger grip. Since it does not have facets like a nut, I assume one is not supposed to put a wrench on it to tighten. My question is, is hand tight good enough to keep this cover from vibrating off? If not should I use something like locktight to make sure it doesn't come off? Or should I just put some torque seal on it and monitor it? What happens if this cover were to fall off with the engine running? Would I lose oil out the hole and if so how fast would it run out? Thanks for the help. Dean Psiropoulos RV-6A N197DM Closing on first flight. ________________________________________________________________________________
Date: Apr 02, 2007
Subject: Re: Lycoming tach drive cover.
In a message dated 4/2/2007 12:36:48 AM Central Daylight Time, dean.psiropoulos(at)verizon.net writes: My question is, is hand tight good enough to keep this cover from vibrating off? If not should I use something like locktight to make sure it doesn't come off? Or should I just put some torque seal on it and monitor it? What happens if this cover were to fall off with the engine running? Would I lose oil out the hole and if so how fast would it run out? Hi Dean- Used the same contrivance on my O-320. IIRC, I wrapped some tape around it and gave it a good snuggin' with an "Alabama ratchit rench" (small Channellocks) and it is still on the plane with no leaks after 400 hours. Caint say about the leaking if it fell off as mine hasn't... Mark ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Date: Apr 02, 2007
Drill a hole (1/16") in the edge of the cap, through the kernelled part, if it doesn't already have one and lock wire it in place. Is there an "O" ring associated with this cap? If so make sure the hole you may have to drill is outside the "O" ring seal. Noel > -----Original Message----- > From: owner-engines-list-server(at)matronics.com > [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of > DEAN PSIROPOULOS > Sent: Monday, April 02, 2007 3:02 AM > To: engines-list(at)matronics.com > Subject: Engines-List: Lycoming tach drive cover. > > > > > I'm using a VM-1000 engine monitor that has a hall sensor > screwed into the > magneto for tachometer measurements. So...I'm not using the Lycoming > tachometer drive in the accessory case and ordered a cover to > place over it. > It's just a small aluminum cap with female threads and a knurled outer > surface to provide a good finger grip. Since it does not > have facets like a > nut, I assume one is not supposed to put a wrench on it to tighten. My > question is, is hand tight good enough to keep this cover > from vibrating > off? If not should I use something like locktight to make > sure it doesn't > come off? Or should I just put some torque seal on it and > monitor it? What > happens if this cover were to fall off with the engine > running? Would I > lose oil out the hole and if so how fast would it run out? > Thanks for the > help. > > Dean Psiropoulos > RV-6A N197DM > Closing on first flight. > > > > > > > > > > ________________________________________________________________________________
Date: Apr 29, 2007
Subject: Engine Lord Mounts
I bought the Van's Lord mount kit for my IO-390 (same dimensions as IO-360). For anyone who's installed their engine, to what value did you torque the 7/16 engine mounting bolts? Did you use 475 inch pounds? Did you use coarse thread torque or fine thread? Thanks, Stan Sutterfield ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Subject: Re: Engine Lord Mounts
Date: Apr 30, 2007
Hi Stan, You will have trouble getting a torque wrench onto these bolts, and it may be of limited use. The rubber mounts must be compressed such that the bolt is tight on the inner spacer (this limits the amount of compression). The compression of the rubber will add to your torque reading also. I've only installed a couple of enginmes, but in each case did the bolts up tight on the spacer then as required to get the cotter pins in. regards, Grant ----- Original Message ----- From: Speedy11(at)aol.com To: engines-list(at)matronics.com Sent: Monday, April 30, 2007 9:03 AM Subject: Engines-List: Engine Lord Mounts I bought the Van's Lord mount kit for my IO-390 (same dimensions as IO-360). For anyone who's installed their engine, to what value did you torque the 7/16 engine mounting bolts? Did you use 475 inch pounds? Did you use coarse thread torque or fine thread? Thanks, Stan Sutterfield ------------------------------------------------------------------------- ----- See what's free at AOL.com. ________________________________________________________________________________
Date: Apr 30, 2007
Grant, Thanks for your reply, I'm torquing the engine bolts by torquing the bolt head - since I can't get to the nut. It's the only way I can figure to torque them. The rubbers are compressed and the spacers seated. I just want to make sure I'm torquing the correct amount. Mahlon, any comment on this? Stan Hi Stan, You will have trouble getting a torque wrench onto these bolts, and it may be of limited use. The rubber mounts must be compressed such that the bolt is tight on the inner spacer (this limits the amount of compression). The compression of the rubber will add to your torque reading also. I've only installed a couple of enginmes, but in each case did the bolts up tight on the spacer then as required to get the cotter pins in. regards, Grant ----- Original Message ----- From: Speedy11(at)aol.com Sent: Monday, April 30, 2007 9:03 AM Subject: Engines-List: Engine Lord Mounts I bought the Van's Lord mount kit for my IO-390 (same dimensions as IO-360). For anyone who's installed their engine, to what value did you torque the 7/16 engine mounting bolts? Did you use 475 inch pounds? Did you use coarse thread torque or fine thread? Thanks, Stan Sutterfield ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Date: Apr 30, 2007
X-mailer: Pegasus Mail for Windows (4.41) Ah, the luxury of cotter pins....but not on my io520. 40-42 lb ft and no retention other than torque....... I think mine were 1/2, works out to 550-600 lb in. 7/16 would be 400-450 lb in. The internal spacers will limit compression. No oil on threads for torque.... > For anyone who's installed their engine, to what value did you torque > the 7/16 engine mounting bolts? > Did you use 475 inch pounds? Did you use coarse thread torque or fine > thread? Jim Baker 580.788.2779 Elmore City, OK ________________________________________________________________________________
Date: May 01, 2007
Subject: Re: Engines-List Digest: 3 Msgs - 04/30/07
Jim, Thanks for your response. It is exactly the info I needed. I have planned a torque of 475 inch pounds, so it appears I'm in the ball park. Stan Sutterfield Ah, the luxury of cotter pins....but not on my io520. 40-42 lb ft and no retention other than torque....... I think mine were 1/2, works out to 550-600 lb in. 7/16 would be 400-450 lb in. The internal spacers will limit compression. No oil on threads for torque.... ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Date: May 02, 2007
Subject: Aeroshell 100
Question... I have always used Aeroshell with great results. But , lately I have been hearing things from customers that perform oil analysis routinely that the "new" Aeroshell formulation causes higher copper results in their oil analysis. I had one tell me that once he changed over to Phillips that the next 2 oil analysis results both showed copper back to normal . Has anyone had any info on Shell changing the formulation? Thanks, Walt ________________________________________________________________________________
Date: May 02, 2007
Symptoms can be problematic. He might want to change back once more to see if copper goes up again. Then switch if necessary. I doubt either oil would cause abnormal wear. If it is an experimental engine you can run what you want. Keep in mind unless you have an engine modified for unleaded you must run at least a semi-synthetic if you go in that direction. Rick -----Original Message----- From: owner-engines-list-server(at)matronics.com [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of Walt Murphy Sent: Wednesday, May 02, 2007 7:12 AM Subject: Engines-List: Aeroshell 100 Question... I have always used Aeroshell with great results. But , lately I have been hearing things from customers that perform oil analysis routinely that the "new" Aeroshell formulation causes higher copper results in their oil analysis. I had one tell me that once he changed over to Phillips that the next 2 oil analysis results both showed copper back to normal . Has anyone had any info on Shell changing the formulation? Thanks, Walt ________________________________________________________________________________
Date: May 02, 2007
Subject: Re: Aeroshell 100
The problem is caused by the additive Aeroshell uses to meet the Lycoming AD requirement. They used to use TCP, but it is now TPP. As I understand it, there is not a problem with straight Aeroshell (not Plus) and not with Exxon or Phillips. I don't know if there is any concern with the higher copper numbers. You might email Blackstone for their opinion, and then write Shell and see if they have a comment. On 5/2/07, Walt Murphy wrote: > > Question... I have always used Aeroshell with great results. But , > lately I have been hearing things from customers that perform oil > analysis routinely that the "new" Aeroshell formulation causes higher > copper > results in their oil analysis. I had one tell me that once he changed > over to Phillips that the next 2 oil analysis results both showed copper > back to normal . > Has anyone had any info on Shell changing the formulation? > > Thanks, > Walt > > ________________________________________________________________________________
From: "Larry L. Tompkins, P.E." <tompkinsl(at)integra.net>
Date: May 03, 2007
Are you using 100 Plus? My understanding is that this is not a problem. The copper is in the oil anti-scuff additive and not coming from your engine. Larry ________________________________________________________________________________
Date: May 03, 2007
I think thats what it is....I just went for the cheapest AD oil. I have not gotten around to doing oil analysis and I'm not totally convinced of the benefit...Will have to think some more on this as its about the right time to be doing it. Frank IO360 7a 150 hours ________________________________ From: owner-engines-list-server(at)matronics.com [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of Larry L. Tompkins, P.E. Sent: Thursday, May 03, 2007 8:26 AM Subject: Re: Engines-List: Aeroshell 100 Are you using 100 Plus? My understanding is that this is not a problem. The copper is in the oil anti-scuff additive and not coming from your engine. Larry ________________________________________________________________________________
Date: May 03, 2007
There is not very much copper in the Lycoming engines. Piston pin bushings, rocker arm bushings, couple of idler gear bushings. Only other place to be concerned would be the rod bearings and if they are down into the copper, idle oil pressure with the oil hot will tell you that story. Monty Barrett -----Original Message----- From: owner-engines-list-server(at)matronics.com [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of Hinde, Frank George (Corvallis) Sent: Thursday, May 03, 2007 10:06 AM Subject: RE: Engines-List: Aeroshell 100 I think thats what it is....I just went for the cheapest AD oil. I have not gotten around to doing oil analysis and I'm not totally convinced of the benefit...Will have to think some more on this as its about the right time to be doing it. Frank IO360 7a 150 hours ________________________________ From: owner-engines-list-server(at)matronics.com [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of Larry L. Tompkins, P.E. Sent: Thursday, May 03, 2007 8:26 AM Subject: Re: Engines-List: Aeroshell 100 Are you using 100 Plus? My understanding is that this is not a problem. The copper is in the oil anti-scuff additive and not coming from your engine. Larry href="http://www.matronics.com/Navigator?Engines-List">http://www.matro n ics.com/Navigator?Engines-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: May 03, 2007
ya know, every once in a while one person will have a problem with something and suddenly it's a crisis. I've been using 15w-50 for 15 years and never had anything out of the ordinary occur. I can fly all year long (highs of 115 and lows of 10; desert you know) on the same oil. I've got customers who fly 20 hours a year and customers who fly 200 hours a year. They all use 15w-50. None of them ahve ever had the sludge, rust, corrosion, or varnish problems my hangar neighbors have had using single grade oil. The multi-grade is still the best oil for the engine. -----Original Message----- From: tompkinsl(at)integra.net Sent: Thu, 3 May 2007 8:25 AM Subject: Re: Engines-List: Aeroshell 100 Are you using 100 Plus? My understanding is that this is not a problem. The copper is in the oil anti-scuff additive and not coming from your engine. Larry ________________________________________________________________________ from AOL at AOL.com. =0 ________________________________________________________________________________
Subject: 4371 magneto
Date: May 03, 2007
About a month ago I got a new 4371 to install on a customers plane. When I installed the nut, it locked up the whole impulse coupling mechanism. I took some measurements on the new one and compared it to the old one. It had been manufactured wrong. When I tried to return it (to Aircraft Spruce), I was given a run-around for 3 days. They wanted me to talk to someone in the technical department at Unison to see if I'd installed it in the plane wrong. They (Aircraft Spruce ) couldn't believe I found a manufacturing defect BEFORE it was installed. I made 30 phone calls to Unison over two days and never got a reply back. Aircraft Spruce finally just sent me a new mag (I'd already returned the first new mag). I got the second new mag yesterday. It's also F'd U. I called Unison 5 times yesterday without anyone answering my call. I finally got Aircraft Spruce to go through their supplier. Gee, they found out that pretty much all of the mags made since GE took over have been manufactured wrong. In the mean time, the next batch of mags is due in June. I took a bunch of pics showing the defect just in case someone wanted to see it. Sending them now to Aircraft Spruce. ________________________________________________________________________ from AOL at AOL.com. ________________________________________________________________________________
Date: May 03, 2007
I would like to see the pictures... s_korney(at)hotmail.com Best... Steve ----Original Message Follows---- From: teamgrumman(at)aol.com Subject: Engines-List: 4371 magneto Date: Thu, 03 May 2007 14:28:29 -0400 About a month ago I got a new 4371 to install on a customers plane. When I installed the nut, it locked up the whole impulse coupling mechanism. I took some measurements on the new one and compared it to the old one. It had been manufactured wrong. When I tried to return it (to Aircraft Spruce), I was given a run-around for 3 days. They wanted me to talk to someone in the technical department at Unison to see if I'd installed it in the plane wrong. They (Aircraft Spruce ) couldn't believe I found a manufacturing defect BEFORE it was installed. I made 30 phone calls to Unison over two days and never got a reply back. Aircraft Spruce finally just sent me a new mag (I'd already returned the first new mag). I got the second new mag yesterday. It's also F'd U. I called Unison 5 times yesterday without anyone answering my call. I finally got Aircraft Spruce to go through their supplier. Gee, they found out that pretty much all of the mags made since GE took over have been manufactured wrong. In the mean time, the next batch of mags is due in June. I took a bunch of pics showing the defect just in case someone wanted to see it. Sending them now to Aircraft Spruce. ________________________________________________________________________ from AOL at AOL.com. _________________________________________________________________ Download Messenger. Join the im Initiative. Help make a difference today. http://im.live.com/messenger/im/home/?source=TAGHM_APR07 ________________________________________________________________________________
Date: May 04, 2007
Subject: O-200 questions...
Hi all. A couple of questions from a newbie... I have an O-200 with ECi cylinders on my C-150M. With the cowls off today, I noticed #3 has a boss for a CHT probe. I don't have a CHT gauge in the aircraft but became curious about a couple of things: 1. Why #3 (stbd front) instead of #1 or #2? Seems that you'd want to be looking at one of the aft (hotter) cylinders? Was this just a flub by the fellow that topped the engine? 2. Should I add a CHT gauge? What are the pros/cons for doing so that you folks have come across? Thanks for the insight! D ________________________________________________________________________________
Date: May 06, 2007
Higher copper numbers are of no harm. Your (every) engine manufacturer masks off areas that they dont want to be hardened with a copper oxide. There is something that has changed in the aeroshell that causes the copper to wash off.. there is no harm as there is regular steel or iron left behind.... all it is is a coating for manufacturing processes. As far as the lycoming rep is concerned, there are no copper wear parts in these engines. Charles ----- Original Message ----- From: "Walt Murphy" <waltmurphy(at)charter.net> Sent: Wednesday, May 02, 2007 10:12 AM Subject: Engines-List: Aeroshell 100 > > Question... I have always used Aeroshell with great results. But , lately > I have been hearing things from customers that perform oil analysis > routinely that the "new" Aeroshell formulation causes higher copper > results in their oil analysis. I had one tell me that once he changed over > to Phillips that the next 2 oil analysis results both showed copper back > to normal . > Has anyone had any info on Shell changing the formulation? > > Thanks, > Walt > > > ________________________________________________________________________________
Date: May 07, 2007
> I'm not sure I understand the comment about "no copper wear parts" in Lycoming engines. I'd bet there is some copper in the main and rod bearings and the wrist pin plugs are brass (they used to be aluminum until Lycoming ran into trouble with excessive wear of these items. So they can wear). All the bushings for the accessory shafts are, as far as I know, brass. They may, as mentioned below, use copper in the heat treating process, but I've not heard of that before. No one seems to know if there is copper in the oil, so if it were my engine I'd still be mildly concerned. Gary Casey > > Higher copper numbers are of no harm. Your (every) engine > manufacturer > masks off areas that they dont want to be hardened with a copper > oxide. > There is something that has changed in the aeroshell that causes > the copper > to wash off.. there is no harm as there is regular steel or iron left > behind.... all it is is a coating for manufacturing processes. As > far as > the lycoming rep is concerned, there are no copper wear parts in these > engines. > > > Charles > > ----- Original Message ----- > From: "Walt Murphy" <waltmurphy(at)charter.net> > Sent: Wednesday, May 02, 2007 10:12 AM > Subject: Engines-List: Aeroshell 100 ________________________________________________________________________________
Subject: Fw: [Fwd: FW: DON'T GET GAS ON MAY 15]]
Date: May 07, 2007
off sub. it,s one way to tell them we matter. Joe N101HD ----- Original Message ----- From: <toads(at)bellsouth.net> ; ; ; ; ; Sent: Monday, May 07, 2007 11:04 AM Subject: [Fwd: [Fwd: FW: DON'T GET GAS ON MAY 15]] >> >> From: <munchm(at)bellsouth.net> >> Date: 2007/05/07 Mon AM 11:03:02 EDT >> To: >> Subject: [Fwd: FW: DON'T GET GAS ON MAY 15] >> >> > >> > From: "Jones, Pam" <PJones(at)albanyorthopedics.com> >> > Date: 2007/04/26 Thu AM 10:02:34 EDT >> > To: "April Swain \(E-mail\)" , >> > "Bubba Ivey \(E-mail\)" , >> > "Chris Norman \(E-mail\)" , >> > "Eva Dilley \(E-mail\)" , >> > "Gene Jones \(E-mail\)" , >> > "HERMAN KORPI \(E-mail\)" , >> > "Jean Slaton \(E-mail\)" , >> > "Kyle Nichols \(E-mail\)" , >> > "Laura Bragg \(E-mail\)" , >> > "LEE PAVLIK \(E-mail\)" , >> > "Leigh Ivey \(E-mail\)" , >> > "Leslie South \(E-mail\)" , >> > "Lexi Schloshberg \(E-mail\)" , >> > "Micele Harrison \(E-mail\)" , >> > "MICHELLE SLATON \(E-mail\)" , >> > "MICHELLE SLATON \(E-mail\)" , >> > "MICHELLE SLATON \(E-mail 2\)" , >> > "MICHELLE SLATON \(E-mail 2\)" , >> > "MICHELLE SLATON \(E-mail 3\)" , >> > "MICHELLE SLATON \(E-mail 3\)" , >> > "Mindy Snyder \(E-mail\)" , >> > "MISSY BRENTON \(E-mail\)" , >> > "PAM JONES \(E-mail\)" , >> > "Peggy Munch \(E-mail\)" , >> > "Randy Nelson \(E-mail\)" , >> > "SHERRY TRUESDALE \(E-mail\)" , >> > "SIDNEY BOLTON \(E-mail\)" , >> > "Stephanie Mock \(E-mail\)" , >> > "SUSAN PITTMAN \(E-mail\)" , >> > "Teresa Loden \(E-mail\)" <tkl_@bellsouth.net>, >> > "Traci Dorer \(E-mail\)" , >> > "VICKY WILLIAMS \(E-mail\)" , >> > "ZACH TRUESDALE \(E-mail\)" , >> > "ZACH TRUESDALE \(E-mail 2\)" >> > Subject: FW: DON'T GET GAS ON MAY 15 >> > >> > >> > -----Original Message----- >> > From: cocosmother(at)aol.com [mailto:cocosmother(at)aol.com] >> > Sent: Tuesday, April 24, 2007 11:25 PM >> > To: downhomegirl2(at)msn.com; monicaalanna(at)earthlink.net; >> > dellison(at)cconnect.net; amylazz(at)twcny.rr.com; swampgal(at)ec.rr.com; >> > myhunney(at)cox.net; thdrn2000(at)yahoo.com >> > Subject: Fwd: DON'T GET GAS ON MAY 15 >> > >> > >> > >> > >> > -----Original Message----- >> > From: MartinsMother(at)aol.com >> > To: amauripuddin2(at)yahoo.com; ronandrade52@hotmail; Ccbike6064(at)aol.com; >> > Cocosmother(at)aol.com; LADYDIANAGOLD(at)aol.com; Grgoatcynthia(at)aol.com; >> > Chhmmy(at)aol.com; HerbsZeppelin(at)aol.com; PJSmom103(at)aol.com; >> > bprice(at)ec.rr.com >> > Sent: Tue, 24 Apr 2007 11:09 PM >> > Subject: Fwd: FW: DON'T GET GAS ON MAY 15 >> > >> > >> > >> > >> > >> > >> > _____ >> > >> > See what's free at AOL.com >> > <http://www.aol.com/?ncid=AOLAOF00020000000503> . >> > Attached Message >> > From: Ddufaul(at)aol.com >> > To: flyboy422(at)cox.net; Alltin64(at)aol.com; aussieel(at)fastol.com; >> > DCBOO(at)aol.com; rowsetbout(at)bellsouth.net; MartinsMother(at)aol.com; >> > rwcoleman1(at)cox.net; carolyn2358(at)yahoo.com; angeleys01550(at)aim.com; >> > Ldeedee5(at)aol.com; ebonair1(at)comcast.net; Emilyh4004(at)aol.com; >> > Cwftuna33(at)aol.com; gallopgirl(at)cfl.rr.com; GinLo(at)webtv.net; >> > HOPRUBY(at)aol.com; Jpitchman33(at)aol.com; NLatai1872(at)aol.com; >> > lincoln9(at)verizon.net; DeerRose(at)aol.com; Teeshirt10(at)aol.com; >> > Mmstricklen(at)aol.com; Misty5ft3(at)aol.com; njsingleton(at)comcast.net; >> > Sunsetpearl(at)aol.com; ritacrabbe(at)yahoo.com; rosebud(at)microd.com; >> > Rrandall8(at)aol.com; PMSAVKO(at)aol.com; Shirleysaw37(at)aol.com; >> > Aruba177(at)cs.com; WBeau91045(at)aol.com; dwigersma(at)cfl.rr.com; >> > Ctdreamer4u(at)aol.com >> > Subject: Fwd: FW: DON'T GET GAS ON MAY 15 >> > Date: Tue, 24 Apr 2007 8:22 AM >> > >> > >> > >> > >> > _____ >> > >> > See what's free at AOL.com >> > <http://www.aol.com/?ncid=AOLAOF00020000000503> . >> > Attached Message >> > From: chip1time(at)yahoo.com >> > To: ayrsue(at)aol.com; beka3507(at)wmconnect.com; d_przywara(at)msn.com; >> > Ddufaul(at)aol.com; genoh222(at)aol.com; geraldlapier(at)bellsouth.net; >> > jamesmagoon(at)aol.com; jerseyjack(at)cfl.rr.com; kjhpelon(at)yahoo.com; >> > natwo7(at)aol.com; oclark8284(at)aol.com; rcorson959(at)yahoo.com; >> > rickofwonder(at)yahoo.com; sandylazar2148(at)yahoo.com; skatuler89(at)aol.com; >> > Steadwellganehm(at)aol.com; vinnyjmuso(at)yahoo.com >> > Subject: Fwd: FW: DON'T GET GAS ON MAY 15 >> > Date: >> > Note: forwarded message attached. >> > >> > >> > >> > >> > >> > __________________________________________________ >> > >> > >> > >> > >> > >> > Attached Message >> > From: Herbcinsq(at)aol.com >> > To: snaeb(at)hughes.net; DMBSWD(at)aol.com; brandysaucier(at)sbcglobal.net; >> > chip1time(at)yahoo.com; jcredit(at)snet.net; gcredit(at)snet.net; >> > Dlang(at)greggentinc.com; Ecmcja(at)aol.com; Edye.gucwa(at)uconn.edu; >> > gebar(at)webtv.net; Johnhession7(at)aol.com; gmhyer29(at)msn.com; >> > JMortellit(at)aol.com; renee.kinne(at)verizon.net; KWOLFE(at)travelers.com; >> > Edlinlac(at)aol.com; rmleddy(at)webtv.net; Kiowallama(at)aol.com; >> > mbrewer(at)ktechonline.com; MisssM(at)webtv.net; klamdiga(at)webtv.net; >> > Ollisalmeda(at)aol.com; r-j-rogers(at)postoffice.worldnet.att.net; >> > mischiefstang(at)gmail.com; sswiatek(at)cfl.rr.com; thestens(at)sbcglobal.net; >> > Cs0238(at)aim.com; bthompson(at)plasticdesign.com >> > Subject: Fwd: FW: DON'T GET GAS ON MAY 15 >> > Date: >> > >> > >> > >> > >> > _____ >> > >> > See what's free at AOL.com >> > <http://www.aol.com/?ncid=AOLAOF00020000000503> . >> > Attached Message >> > From: bclark@nashincp-m.com >> > To: nan2623(at)hotmail.com; nash_channelside(at)verizon.net; >> > Herbcinsq(at)aol.com; hdumars(at)hotmail.com; jamieeslinger(at)aol.com; >> > JBrokaw@nashincp-m.com; jhyatt@nashincp-m.com; >> > JCaruthers(at)nashincp-m.com; Maria.Johnson(at)bovislendlease.com; >> > jim.morton(at)bovislendlease.com; lbroczkowski(at)synagro.com; >> > beslinger(at)cfl.rr.com; crespojohanna(at)aol.com; CMiddleton(at)nashincp-m.com; >> > ckey(at)foundersins.com; cindy(at)ustconline.com; cedarbrook(at)adelphia.net; >> > dcaruthers(at)nashincp-m.com; dumars51wv(at)aol.com; DMears(at)nashincp-m.com; >> > dwallace(at)nashincp-m.com; matt(at)mccallcomm.com; matt(at)mccallcomm.com; >> > MMizell@nashincp-m.com; MPaxton@nashincp-m.com; >> > ssellers(at)merrittproperties.com; SPennington(at)nashincp-m.com; >> > lsellers(at)Kroll.com; lbroczkowski(at)synagro.com; LWeeks(at)nashincp-m.com; >> > dcaruthers@nashincp-m.com >> > Subject: FW: DON'T GET GAS ON MAY 15 >> > Date: >> > >> > >> > Subject: DON'T GET GAS ON MAY 15 >> > NO GAS...On May 15th 2007 >> > > Don't pump gas on may 15th >> > > ...in April 1997, there was a "gas out" conducted nationwide in >> > > protest >> > >of gas prices. Gasoline prices dropped 30 cents a gallon overnight. >> > > >> > >On May 15th 2007, all internet users are to not go to a gas station in >> > >protest of high gas prices. Gas is now over $3.00 a gallon in most >> > >places. >> > > >> > >There are 73,000,000+ American members currently on the internet >> > >network, >> > >and the average car takes about 30 to 50 dollars to fill up. >> > > >> > >If all users did not go to the pump on the 15th, it would take >> > >$2,292,000,000.00 (that's almost 3 BILLION) out of the oil companys >> > >pockets >> > >for just one day, so please do not go to the gas station on May 15th >> > >and >> > >lets try to put a dent in the Middle Eastern oil industry for at least >> > >one >> > >day. >> > > >> > >If you agree (which I cant see why you wouldnt) resend this to all >> > >your >> > >contact list. With it saying, ''Don't pump gas on May 15th" >> > >> > _____ >> > >> > Ahhh...imagining that irresistible "new car" smell? >> > Check out new cars at Yahoo! Autos. >> > _____ >> > >> > from AOL at <http://www.aol.com?ncid=AOLAOF00020000000437> AOL.com. >> > >> > >> > >> >> > > ________________________________________________________________________________
Date: May 21, 2007
Subject: Sniffle valve
I am installing a Lycoming sniffle valve (included in Vans FWF kit) to an Aerosport IO-360 and would like to confirm its inteded operation. I "think" it is basically a check valve that should open when manifold pressure is equal to atmospheric (engine not running) to drain any fuel pooled in the sump. Engine running, it should close when manifold pressure drops. The valve I have flows freely when blowing into the sump side, but still passes a bit of air when blown into from the tube side, which I surmise would constitute a small vacuum leak and possible leaner than normal operation. Is this normal? Thanks- Mark ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Subject: Re: Sniffle valve
Date: May 22, 2007
I assume most Lycoming installations (at least the 3 that I have owned) just use a simple drain, so there is a "leak" the size of the tube when the engine is running. The idle speed and mixture adjustments compensate, so no one seems to worry. A sniffle valve would presumably reduce that leak, but apparently isn't necessary. Gary Casey > > I am installing a Lycoming sniffle valve (included in Vans FWF kit) > to an > Aerosport IO-360 and would like to confirm its inteded operation. > I "think" it > > is basically a check valve that should open when manifold pressure > is equal to > > atmospheric (engine not running) to drain any fuel pooled in the > sump. Engine > > running, it should close when manifold pressure drops. The valve I > have > flows freely when blowing into the sump side, but still passes a > bit of air when > > blown into from the tube side, which I surmise would constitute a > small vacuum > > leak and possible leaner than normal operation. > > Is this normal? > > Thanks- > Mark ________________________________________________________________________________
Date: May 22, 2007
The engines I'm familiar with all call for a sniffle valve, that looks like a standard AN 90 degree fitting. I don't know how well it is supposed to seal after fuel and gunk have drained through it for a few years. On 5/22/07, Gary Casey wrote: > > I assume most Lycoming installations (at least the 3 that I have > owned) just use a simple drain, so there is a "leak" the size of the > tube when the engine is running. The idle speed and mixture > adjustments compensate, so no one seems to worry. A sniffle valve > would presumably reduce that leak, but apparently isn't necessary. > Gary Casey > > > > > I am installing a Lycoming sniffle valve (included in Vans FWF kit) > > to an > > Aerosport IO-360 and would like to confirm its inteded operation. > > I "think" it > > > > is basically a check valve that should open when manifold pressure > > is equal to > > > > atmospheric (engine not running) to drain any fuel pooled in the > > sump. Engine > > > > running, it should close when manifold pressure drops. The valve I > > have > > flows freely when blowing into the sump side, but still passes a > > bit of air when > > > > blown into from the tube side, which I surmise would constitute a > > small vacuum > > > > leak and possible leaner than normal operation. > > > > Is this normal? > > > > Thanks- > > Mark > > ________________________________________________________________________________
Date: May 22, 2007
If you have a small leak at the " sniffle " valve it will only effect you at idle and can be compensated with idle mixture adjustment. At WOT the engine doesn't care as long as the leak is small. A big hole is another story. Monty Barrett BPE, Inc. -----Original Message----- From: owner-engines-list-server(at)matronics.com [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of Fiveonepw(at)aol.com Sent: Monday, May 21, 2007 4:56 PM Subject: Engines-List: Sniffle valve I am installing a Lycoming sniffle valve (included in Vans FWF kit) to an Aerosport IO-360 and would like to confirm its inteded operation. I "think" it is basically a check valve that should open when manifold pressure is equal to atmospheric (engine not running) to drain any fuel pooled in the sump. Engine running, it should close when manifold pressure drops. The valve I have flows freely when blowing into the sump side, but still passes a bit of air when blown into from the tube side, which I surmise would constitute a small vacuum leak and possible leaner than normal operation. Is this normal? Thanks- Mark ________________________________ See what's free at AOL.com <http://www.aol.com?ncid=AOLAOF00020000000503> . ________________________________________________________________________________
Subject: IO-360 Engine, Instruments, Ignition
Date: May 22, 2007
My Glasair has reached a new stage of construction, I have dis-assembled it for final work in the interior of the fuselage and painting. I have taken so long to build this thing, I can now afford different choices for certain components I could not afford when I started. What that means to all of you is the opportunity to get some bargains on components I will not use when I do the final assembly on my airplane. E-mail me at douglas.dodson(at)pobox.com for more information or photos of any of the equipment. IO-360-B1E: assembled engine, overhauled several years ago but never run, most but not all accessories included (most would suffice for core value) Lycoming core value on this engine is $10,500. I'm asking $12,000. Elector-Air electronic ignition system w/ hall effect pickup. Included is the full system and instruction manual. Never used. $400 Buy the engine and you can have this. VM 1000 system for an IO-360. This is brand new, most of the components have not been removed from the original packaging. A few of the senders were installed but never used. It sells new for about $3000. I'm asking $1900. Included is the DPU, display, all senders including fuel flow, wiring, and the manual. I also have the fuel level system which is a separate display capable of indicating for 3 tanks, and one 8' probe. This can be yours for $350 (probe retail new is $500 all by itself). I also have an ACK A-30 altitude encoder and a Rapco vacuum pump cooling kit. Buy something else and you can have these for a beer and the cost of shipping. Douglas L. Dodson, Jr. Glasair II-S FT Flight Test Engineer, CFI-A,G ________________________________________________________________________________
Subject: Easy - too easy
Date: Jun 23, 2007
My old math teacher said " When it's easy, be wise, do it twice." Example: 30c x 2 = 60, minus 10% (60-6=56), 56 + 32 = 86F Do it in your head easy Second time, I don't think so. Cheers, Ferg ________________________________________________________________________________
Subject: Re: Easy - too easy
Date: Jun 24, 2007
Right, Larry, Basically, the topic was an easy way to convert. However you can see the arithmatic fialed and although the answer was correct, the math wasn't. I was just noting that the easier the arithmatic, the greater the need to do it twice..... Cheers, Ferg Read this topic online here: http://forums.matronics.com/viewtopic.php?p=120344#120344 ________________________________________________________________________________
Date: Jun 24, 2007
I'm afraid I miss the point. This is indeed the easiest way to mentally convert from C to F, and is so quick that you can do it as fast as you say it. JimC ----- Original Message ----- Subject: Re: Engines-List: Easy - too easy > > Hi Folks, > Guess I missed most of this thread. Are we trying to mentally > convert Fahrenheit to Centigrade ? > >> My old math teacher said " When it's easy, be wise, do it twice." >> >> Example: >> 30c x 2 = 60, >> minus 10% (60-6=56), >> 56 + 32 = 86F > Do it in your head easy > Second time, I don't think so. > Cheers, Ferg ________________________________________________________________________________
Date: Jun 24, 2007
The first time I've seen it expressed that way Noel VO1 PL > -----Original Message----- > From: owner-engines-list-server(at)matronics.com > [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of > Fergus Kyle > Sent: Saturday, June 23, 2007 11:58 PM > To: engines > Subject: Engines-List: Easy - too easy > > > > My old math teacher said " When it's easy, be wise, do it twice." > > Example: > 30c x 2 = 60, > minus 10% (60-6=56), > 56 + 32 = 86F > > Do it in your head easy > > Second time, I don't think so. > Cheers, Ferg > > > > > > > ________________________________________________________________________________
Subject: Centigrade to Fahrenheit
Date: Jun 24, 2007
I was taught, eh, by two Canadians, eh to double the Centigrade, eh, and add it to 32 to get Fahrenheit, eh. Easy, eh? Not exact but close enough, eh? Michael, eh What two Canadians, eh? The Mackenzie Brothers, of course, eh? ________________________________________________________________________________
Date: Jun 24, 2007
60 - 6 *IS NOT* 56, but rather equals 54, no??? And 56 + 32 = 88, and not 86. But it looks like two wrongs can make things right after all..... > Example: > 30c x 2 = 60, > minus 10% (60-6=56), > 56 + 32 = 86F > > Do it in your head easy > > Second time, I don't think so. > Cheers, Ferg ________________________________________________________________________________
Date: Jun 24, 2007
It's the way I've always done it. JimC ----- Original Message ----- From: "Noel Loveys" <noelloveys(at)yahoo.ca> Sent: Sunday, June 24, 2007 12:35 PM Subject: RE: Engines-List: Easy - too easy > > The first time I've seen it expressed that way > > Noel > ________________________________________________________________________________
Subject: Re: Centigrade to Fahrenheit
Date: Jun 24, 2007
No. It can be pretty far off. For example, for 100 C it would give 232 F and would be too high by 20 F, giving 232 instead of 212. The correct answer would be 200-20+32 = 212. It takes perhaps one second longer to do the exact conversion. JimC ----- Original Message ----- From: "Michael" <cubflyr(at)comcast.net> Sent: Sunday, June 24, 2007 2:06 PM Subject: Engines-List: Centigrade to Fahrenheit > > I was taught, eh, by two Canadians, eh to double the Centigrade, eh, and > add > it to 32 to get Fahrenheit, eh. Easy, eh? Not exact but close enough, eh? > > Michael, ________________________________________________________________________________
Date: Jun 24, 2007
(9/5C) +32=F (F-32)(5/9)=C That's the way I was shown... A bit bulky for doing without paper or a calculator. Yours is definitely easier. I tried it on -40C =-40F, 0C=32F, 20C=68F, 100C=212F all worked correctly. Noel > -----Original Message----- > From: owner-engines-list-server(at)matronics.com > [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of jrc > Sent: Sunday, June 24, 2007 6:41 PM > To: engines-list(at)matronics.com > Subject: Re: Engines-List: Easy - too easy > > > > It's the way I've always done it. > JimC > ----- Original Message ----- > From: "Noel Loveys" <noelloveys(at)yahoo.ca> > To: > Sent: Sunday, June 24, 2007 12:35 PM > Subject: RE: Engines-List: Easy - too easy > > > > > > > The first time I've seen it expressed that way > > > > Noel > > > > > > > > ________________________________________________________________________________
Date: Jun 24, 2007
Just to add what Jim left out, the -20 came from the 100+100 0 (-10%=-20) or 180+32=212. Another example: 0+0=0, 0-10%(0)=0, +32, and 15+15=30-10%(3)=27+32=59. So the formula is: ((Deg.C*2)-10%)+32=Deg.F Mike -----Original Message----- From: owner-engines-list-server(at)matronics.com [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of jrc Sent: Sunday, June 24, 2007 2:15 PM Subject: Re: Engines-List: Centigrade to Fahrenheit No. It can be pretty far off. For example, for 100 C it would give 232 F and would be too high by 20 F, giving 232 instead of 212. The correct answer would be 200-20+32 = 212. It takes perhaps one second longer to do the exact conversion. JimC ----- Original Message ----- From: "Michael" <cubflyr(at)comcast.net> Sent: Sunday, June 24, 2007 2:06 PM Subject: Engines-List: Centigrade to Fahrenheit > > I was taught, eh, by two Canadians, eh to double the Centigrade, eh, and > add > it to 32 to get Fahrenheit, eh. Easy, eh? Not exact but close enough, eh? > > Michael, -- 3:15 PM -- 3:15 PM ________________________________________________________________________________
Date: Jun 25, 2007
Now try it backwards... to get back to Cent. Best... Steve ----Original Message Follows---- From: "Noel Loveys" <noelloveys(at)yahoo.ca> Subject: RE: Engines-List: Easy - too easy Date: Sun, 24 Jun 2007 19:29:33 -0230 (9/5C) +32=F (F-32)(5/9)=C That's the way I was shown... A bit bulky for doing without paper or a calculator. Yours is definitely easier. I tried it on -40C =-40F, 0C=32F, 20C=68F, 100C=212F all worked correctly. Noel > -----Original Message----- > From: owner-engines-list-server(at)matronics.com > [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of jrc > Sent: Sunday, June 24, 2007 6:41 PM > To: engines-list(at)matronics.com > Subject: Re: Engines-List: Easy - too easy > > > > It's the way I've always done it. > JimC > ----- Original Message ----- > From: "Noel Loveys" <noelloveys(at)yahoo.ca> > To: > Sent: Sunday, June 24, 2007 12:35 PM > Subject: RE: Engines-List: Easy - too easy > > > > > > > The first time I've seen it expressed that way > > > > Noel > > > > > > > > _________________________________________________________________ Like puzzles? Play free games & earn great prizes. Play Clink now. http://club.live.com/clink.aspx?icid=clink_hotmailtextlink2 ________________________________________________________________________________
Date: Jun 24, 2007
One example will show it only gets you within 10%. -40F=-40C -40-32/2=-36 does not equal -40. On 6/24/07, steve korney wrote: > > > Now try it backwards... to get back to Cent. > > > Best... Steve > > > ----Original Message Follows---- > From: "Noel Loveys" <noelloveys(at)yahoo.ca> > Reply-To: engines-list(at)matronics.com > To: > Subject: RE: Engines-List: Easy - too easy > Date: Sun, 24 Jun 2007 19:29:33 -0230 > > > (9/5C) +32=F > > (F-32)(5/9)=C > > That's the way I was shown... A bit bulky for doing without paper or a > calculator. Yours is definitely easier. I tried it on -40C =-40F, 0C=32F, > 20C=68F, 100C=212F all worked correctly. > > Noel > > > -----Original Message----- > > From: owner-engines-list-server(at)matronics.com > > [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of jrc > > Sent: Sunday, June 24, 2007 6:41 PM > > To: engines-list(at)matronics.com > > Subject: Re: Engines-List: Easy - too easy > > > > > > > > It's the way I've always done it. > > JimC > > ----- Original Message ----- > > From: "Noel Loveys" <noelloveys(at)yahoo.ca> > > To: > > Sent: Sunday, June 24, 2007 12:35 PM > > Subject: RE: Engines-List: Easy - too easy > > > > > > > > > > > > The first time I've seen it expressed that way > > > > > > Noel > > > > > > > > > > > > > > > > > > _________________________________________________________________ > Like puzzles? Play free games & earn great prizes. Play Clink now. > http://club.live.com/clink.aspx?icid=clink_hotmailtextlink2 > > ________________________________________________________________________________
Date: Jun 24, 2007
That's because it's exactly the same equation, just configured differently. 9/5X is the same as 2X-2X/10. Both equal 1.8X JimC ----- Original Message ----- From: "Noel Loveys" <noelloveys(at)yahoo.ca> Sent: Sunday, June 24, 2007 3:59 PM Subject: RE: Engines-List: Easy - too easy > > (9/5C) +32=F > > (F-32)(5/9)=C > > That's the way I was shown... A bit bulky for doing without paper or a > calculator. Yours is definitely easier. I tried it on -40C =-40F, > 0C=32F, > 20C=68F, 100C=212F all worked correctly. > > Noel ________________________________________________________________________________
Date: Jun 24, 2007
Rule of thumb is easiest. Double it and add 30. Normally accurate within 1-2 degrees. Opposite for converting back. -----Original Message----- From: owner-engines-list-server(at)matronics.com [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of jrc Sent: Sunday, June 24, 2007 9:22 PM Subject: Re: Engines-List: Easy - too easy That's because it's exactly the same equation, just configured differently. 9/5X is the same as 2X-2X/10. Both equal 1.8X JimC ----- Original Message ----- From: "Noel Loveys" <noelloveys(at)yahoo.ca> Sent: Sunday, June 24, 2007 3:59 PM Subject: RE: Engines-List: Easy - too easy > --> > > (9/5C) +32=F > > (F-32)(5/9)=C > > That's the way I was shown... A bit bulky for doing without paper or a > calculator. Yours is definitely easier. I tried it on -40C =-40F, > 0C=32F, 20C=68F, 100C=212F all worked correctly. > > Noel ________________________________________________________________________________
Date: Jun 24, 2007
Should read 2X-(2X/10)+ 32=F. Math in brackets is done first. Hey, I do remember something from high school. :D Dave --- jrc wrote: > > > That's because it's exactly the same equation, just > configured differently. > 9/5X is the same as 2X-2X/10. Both equal 1.8X > JimC > > ----- Original Message ----- > From: "Noel Loveys" <noelloveys(at)yahoo.ca> > To: > Sent: Sunday, June 24, 2007 3:59 PM > Subject: RE: Engines-List: Easy - too easy > > > > > > > (9/5C) +32=F > > > > (F-32)(5/9)=C > > > > That's the way I was shown... A bit bulky for > doing without paper or a > > calculator. Yours is definitely easier. I tried > it on -40C =-40F, > > 0C=32F, > > 20C=68F, 100C=212F all worked correctly. > > > > Noel > > > > > browse > Subscriptions page, > FAQ, > http://www.matronics.com/Navigator?Engines-List > > Web Forums! > > > > > Moody friends. Drama queens. Your life? Nope! - their life, your story. Play Sims Stories at Yahoo! Games. http://sims.yahoo.com/ ________________________________________________________________________________
Date: Jun 25, 2007
Thanks Ferg, That's an annoying little piece of arithmetic. When it's not critical, and when I can accept an answer within 2 or 3 degrees I use something I learned from a friend in Toronto. I simply take F. subtract 30 and divide by 2 to get C. Or take C. double it and add 30. Works a lot of the time for me. > > Right, Larry, > Basically, the topic was an easy way to convert. However > you can see the arithmatic fialed and although the answer was > correct, the math wasn't. I was just noting that the easier the > arithmatic, the greater the need to do it twice..... > Cheers, Ferg > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=120344#120344 > > > > > > > > > > > > ________________________________________________________________________________
Date: Jun 25, 2007
Lets try that, using 100C (the boiling point of water). 2*100+30=230F The correct answer is 212F The error is 28F. Is that close enough? (it's slightly more than 1-2 degrees) The exact answer requires only one more substraction. JimC ----- Original Message ----- > Rule of thumb is easiest. Double it and add 30. Normally accurate within > 1-2 degrees. Opposite for converting back. ________________________________________________________________________________
Date: Jun 25, 2007
The brackets are optional, not required. 2X-(2X/10) is the same as 2(X-X/10) is the same as 2X-2X/10 is the same as 2X(1-0.1) is the same as 1.8X Personally, I think its easiest to just do the thing in your head. :-) JimC ----- Original Message ----- From: "Dave Nellis" <truflite(at)yahoo.com> Sent: Sunday, June 24, 2007 8:30 PM Subject: Re: Engines-List: Easy - too easy > > Should read 2X-(2X/10)+ 32=F. Math in brackets is > done first. Hey, I do remember something from high > school. :D > > Dave ________________________________________________________________________________
Date: Jun 25, 2007
Let's try the UK version: C to F = double it, less 10%, add 32 Eg 100C x 2 = 200 - 10% = 180 + 32 = 212F That's pretty close for me! F to C slightly less accurate F less 32, add 10%, halve it Eg 212 - 32 = 180, add 10% = 198, halve it = 99C Still good enough for me! Kind regards Peter Grant - UK Sportcruiser #4 (waiting) +++++++++++++++++++++++++++++++ 10 The Sidings, Horncastle, Lincs LN9 5UA England Tel: +44 1507 523180 Fax: +44 1507 525888 Mob: +7774 923160 ++++++++++++++++++++++++++++++++ This email may contain confidential information; if you have received it in error please delete it from your system and inform the sender. Outgoing messages are scanned by AVG 7 Professional. -----Original Message----- From: owner-engines-list-server(at)matronics.com [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of jrc Sent: 25 June 2007 17:20 Subject: Re: Engines-List: Easy - too easy Lets try that, using 100C (the boiling point of water). 2*100+30=230F The correct answer is 212F The error is 28F. Is that close enough? (it's slightly more than 1-2 degrees) The exact answer requires only one more substraction. JimC ----- Original Message ----- > Rule of thumb is easiest. Double it and add 30. Normally accurate within > 1-2 degrees. Opposite for converting back. ________________________________________________________________________________
Date: Jun 26, 2007
You guys are arguing from the standpoint that the formula is an approximation. It is an exact conversion, Why? Because between freezing and boiling there are 100 Centigrade degrees and 180 Fahrenheit degrees. The ratio is 9/5. Centigrade freezing starts at "0" Fahrenheit starts at 32. So lets convert 20 C to Fahrenheit . 20 x 9/5 = 36 (The number of Fahrenheit degrees) since Fahrenheit begins at 32 adding 32 to 36 gives us 68F. Doubling 20 and subtracting 10 percent is just an easier way than multiplying by 9 and dividing by 5. Martin Sobel ________________________________________________________________________________
Date: Jun 26, 2007
Ummh, no. I think I specifically said that doubling less 10% was an exact conversion. Some of the other guys prefer using approximations. I agree with you. JimC ----- Original Message ----- From: "Martin Sobel" <rv8vator(at)comcast.net> Sent: Tuesday, June 26, 2007 9:08 AM Subject: Re: Engines-List: Re: Easy - too easy > > You guys are arguing from the standpoint that the formula is an > approximation. It is an exact conversion, Why? > > Because between freezing and boiling there are 100 Centigrade degrees and > 180 Fahrenheit degrees. The ratio is 9/5. Centigrade freezing starts at > "0" > Fahrenheit starts at 32. > > So lets convert 20 C to Fahrenheit . > > 20 x 9/5 = 36 (The number of Fahrenheit degrees) since Fahrenheit begins > at > 32 adding 32 to 36 gives us 68F. > > Doubling 20 and subtracting 10 percent is just an easier way than > multiplying by 9 and dividing by 5. > > Martin Sobel > > > ________________________________________________________________________________
Subject: JUST MY POINT
Date: Jun 27, 2007
Hello, The recent spate of calculations and replies, regarding the simplest of arithmetic seems to have escaped the purpose of my original statement - that the simpler the calc, the more times you do it to confirm. Simple sums involve rather more mental assumptions as a way to to achieve the end. It's theses assumptions that often obscure the accuracy. Whether brackets are mandatory or optional is of no consequence to my proiposal. Take Centigrade (Celsius) double it, subtract ten percent and add 32, Then do it again. Or do it another way: take ninety percent of double Celsius and add 32. Watch out for minusses though: -40C; -80C; -80C-(-8) is -72; -72+32; -40F The extra security is acquiring the same answer twice................ Ferg ________________________________________________________________________________
Date: Jun 27, 2007
How things change! When I was in school, about ten million years ago, We were told the answer wasn't important but how we got it was. As a result only about 5% of the answer on any math problem was attributed to actually getting the right answer. Now days, no one, especially myself, gives a fiddlers d#$% about how the correct answer is achieved, only that it is the correct answer. For most problems though a calculation is good enough for government work. I don't think any one really cares if a mile is 1.61 kilometres or one nautical mile is 1.15 mi ( I had to get out the old whiz wheel to check that one). Its easy to do a one and two-thirds or a 1.1X calculation, pardon the expression, on the fly. That's my story and I'm sticking to it....... Unless suitably bribed of course. Noel > -----Original Message----- > From: owner-engines-list-server(at)matronics.com > [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of > Fergus Kyle > Sent: Wednesday, June 27, 2007 5:02 PM > To: engines > Subject: Engines-List: JUST MY POINT > > > > Hello, > The recent spate of calculations and replies, regarding > the simplest > of arithmetic seems to have escaped the purpose of my > original statement - > that the simpler the calc, the more times you do it to confirm. > Simple sums involve rather more mental assumptions as a > way to to > achieve the end. It's theses assumptions that often obscure > the accuracy. > Whether brackets are mandatory or optional is of no consequence to my > proiposal. > Take Centigrade (Celsius) double it, subtract ten > percent and add > 32, Then do it again. Or do it another way: take ninety > percent of double > Celsius and add 32. Watch out for minusses though: -40C; > -80C; -80C-(-8) is > -72; -72+32; -40F > The extra security is acquiring the same answer > twice................ > Ferg > > > > > > > ________________________________________________________________________________
Subject: carb or fuel injection? turbo?
Date: Jul 06, 2007
Does anybody have any insight on pros/cons of carberator versus fuel injection? How about adding a turbo? Lycoming's website for 360 engines (see link below) lists the turbocharged injected engine at 800hours (40%) less TBO plus 100lbs additional weight for only 20HP gained. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=122513#122513 ________________________________________________________________________________
Date: Jul 06, 2007
Could it be that the turbo is designed primarily to maintain full power at altitude? Or possibly to allow the engine to operate at far greater altitudes. Consider also the removal of carb heat and the possibility of icing. Noel > -----Original Message----- > From: owner-engines-list-server(at)matronics.com > [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of T22 > Sent: Friday, July 06, 2007 1:38 PM > To: engines-list(at)matronics.com > Subject: Engines-List: carb or fuel injection? turbo? > > > > > Does anybody have any insight on pros/cons of carberator > versus fuel injection? How about adding a turbo? Lycoming's > website for 360 engines (see link below) lists the > turbocharged injected engine at 800hours (40%) less TBO plus > 100lbs additional weight for only 20HP gained. > > > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=122513#122513 > > > > > > > > > > > ________________________________________________________________________________
Date: Jul 06, 2007
Subject: Re: carb or fuel injection? turbo?
Injected eliminates carb heat issues and almost all induction icing issues. It's also more efficient and seems to be pretty much universal on higher performance engines although it is more expensive. On a IO-360 the turbocharging is actually turbo-normalizing which means that it allows you to develop more horsepower at higher altitudes. The only stock turbochargers I'm aware of have a fixed waste gate which is not particularly effective. There is an stc'd turbo charger made by Rajay for the IO-360 that is much better but it's also about $10,000 last time I looked several years ago. There are also substantially higher maintenance costs associated with turbo charging although I think your 800 hour TBO is probably on the turbo and not the entire engine. The bottom line for me was that a turbo might be worth the added expense and complexity if you live in the mountains of the West or regularily fly out there but not for me living in the flat lands of the Midwest. If I did get a turbo it would not be the one with a fixed waste gate. I'd spend the bucks for a Rajay. just my 2 cents. John T22 wrote: > >Does anybody have any insight on pros/cons of carberator versus fuel injection? How about adding a turbo? Lycoming's website for 360 engines (see link below) lists the turbocharged injected engine at 800hours (40%) less TBO plus 100lbs additional weight for only 20HP gained. > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=122513#122513 > > > > ________________________________________________________________________________
Date: Jul 06, 2007
John et al, I would note that if you like to fly high the turbo/super will help you get there faster with reduced power loss and consistent climb. Even if you live in the east or mid-west there is a cost to the climb. My old Piper with the O-320 was a great plane, but you'd spend the weeks paycheck in fuel getting to 10k and if it was the middle of summer, you'd have to flatten out every 10-15 so you wouldn't melt the heads. There are plenty of advantages and, as John said a cost to turbo systems. I am building a Lancair Legacy and will use a supercharged Subaru. Superchargers have their own pros and cons. The greatest advantage of the supercharger is the no-lag response and minimal heat issues. On the turbo systems, the exhaust system is complex and ouch - it gets very hot which leads to shorter life and more $$$ on exhaust pipe. If you go with the Subaru turbo, you can actually loose the exhaust system and just use a short pipe. The people with the most experience in Lycoming turbos' has to be Lancair. You just don't buy these of the shelf. They will sell you a TNIO-390X with for 40k. All of their machine work is done on the premises. They do great work. My Subaru which will also put out 210-220 HP FWF is about $25k. -----Original Message----- From: owner-engines-list-server(at)matronics.com [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of John Grosse Sent: Friday, July 06, 2007 2:17 PM Subject: Re: Engines-List: carb or fuel injection? turbo? Injected eliminates carb heat issues and almost all induction icing issues. It's also more efficient and seems to be pretty much universal on higher performance engines although it is more expensive. On a IO-360 the turbocharging is actually turbo-normalizing which means that it allows you to develop more horsepower at higher altitudes. The only stock turbochargers I'm aware of have a fixed waste gate which is not particularly effective. There is an stc'd turbo charger made by Rajay for the IO-360 that is much better but it's also about $10,000 last time I looked several years ago. There are also substantially higher maintenance costs associated with turbo charging although I think your 800 hour TBO is probably on the turbo and not the entire engine. The bottom line for me was that a turbo might be worth the added expense and complexity if you live in the mountains of the West or regularily fly out there but not for me living in the flat lands of the Midwest. If I did get a turbo it would not be the one with a fixed waste gate. I'd spend the bucks for a Rajay. just my 2 cents. John T22 wrote: >--> > >Does anybody have any insight on pros/cons of carberator versus fuel >injection? How about adding a turbo? Lycoming's website for 360 >engines (see link below) lists the turbocharged injected engine at >800hours (40%) less TBO plus 100lbs additional weight for only 20HP >gained. > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=122513#122513 > > > > ________________________________________________________________________________
Date: Jul 06, 2007
In a message dated 7/6/2007 3:25:11 P.M. Eastern Daylight Time, longg(at)pjm.com writes: The people with the most experience in Lycoming turbos' has to be Lancair. You just don't buy these of the shelf. They will sell you a TNIO-390X with for 40k. All of their machine work is done on the premises. They do great work. My Subaru which will also put out 210-220 HP FWF is about $25k. Is that for the Eggenfeller package? ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Date: Jul 07, 2007
I would like to add that another option is an Ellison Throttle Body Injector 'carburettor'. If well set up, you can lean as well as FI without the cost, weight and complexity of FI. The CAFE Mooney runs an IO-360-A1B6 with an Ellison rather than FI. Check their 'site for details. An Ellison also means only a low pressure fuel pump is needed, thus less cost again, and no fuel return line is needed, so plumbing is easier also. Carb heat is recommended with them, but they are less susceptible to icing than a standard carb, and you need/should have alternate air with FI anyway. Just to be clear, FI as used on aircraft is not EFI as used on cars. FI is all mechanical. Grant Piper ----- Original Message ----- From: "T22" <stone37house-airplane(at)yahoo.com> Sent: Saturday, July 07, 2007 2:07 AM Subject: Engines-List: carb or fuel injection? turbo? > > > Does anybody have any insight on pros/cons of carberator versus fuel > injection? How about adding a turbo? Lycoming's website for 360 engines > (see link below) lists the turbocharged injected engine at 800hours (40%) > less TBO plus 100lbs additional weight for only 20HP gained. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=122513#122513 > > > ________________________________________________________________________________
Date: Jul 06, 2007
Is the Ellison system also what used to be referred to as a pressure carburettor? Noel > -----Original Message----- > From: owner-engines-list-server(at)matronics.com > [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of > Grant Piper > Sent: Friday, July 06, 2007 8:29 PM > To: engines-list(at)matronics.com > Subject: Re: Engines-List: carb or fuel injection? turbo? > > > > > I would like to add that another option is an Ellison > Throttle Body Injector > 'carburettor'. If well set up, you can lean as well as FI > without the > cost, weight and complexity of FI. The CAFE Mooney runs an > IO-360-A1B6 > with an Ellison rather than FI. Check their 'site for details. An > Ellison also means only a low pressure fuel pump is needed, > thus less cost > again, and no fuel return line is needed, so plumbing is > easier also. Carb > heat is recommended with them, but they are less susceptible > to icing than a > standard carb, and you need/should have alternate air with FI anyway. > > Just to be clear, FI as used on aircraft is not EFI as used > on cars. FI is > all mechanical. > > Grant Piper > > ----- Original Message ----- > From: "T22" <stone37house-airplane(at)yahoo.com> > To: > Sent: Saturday, July 07, 2007 2:07 AM > Subject: Engines-List: carb or fuel injection? turbo? > > > > > > > > Does anybody have any insight on pros/cons of carberator > versus fuel > > injection? How about adding a turbo? Lycoming's website > for 360 engines > > (see link below) lists the turbocharged injected engine at > 800hours (40%) > > less TBO plus 100lbs additional weight for only 20HP gained. > > > > > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=122513#122513 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
From: "Southern Reflections" <purplemoon99(at)bellsouth.net>
Date: Jul 06, 2007
If you are running a subaru, and thinking about supercharger you should talk to Ron at RAM ,If anybody knows supercharging a subaru it would be Ron.. Joe N101HD 601 XL ----- Original Message ----- From: <longg(at)pjm.com> Sent: Friday, July 06, 2007 3:21 PM Subject: RE: Engines-List: carb or fuel injection? turbo? > > John et al, > I would note that if you like to fly high the turbo/super will > help you get there faster with reduced power loss and consistent climb. > Even if you live in the east or mid-west there is a cost to the climb. > My old Piper with the O-320 was a great plane, but you'd spend the weeks > paycheck in fuel getting to 10k and if it was the middle of summer, > you'd have to flatten out every 10-15 so you wouldn't melt the heads. > There are plenty of advantages and, as John said a cost to turbo > systems. I am building a Lancair Legacy and will use a supercharged > Subaru. Superchargers have their own pros and cons. The greatest > advantage of the supercharger is the no-lag response and minimal heat > issues. On the turbo systems, the exhaust system is complex and ouch - > it gets very hot which leads to shorter life and more $$$ on exhaust > pipe. If you go with the Subaru turbo, you can actually loose the > exhaust system and just use a short pipe. > The people with the most experience in Lycoming turbos' has to > be Lancair. You just don't buy these of the shelf. They will sell you a > TNIO-390X with for 40k. All of their machine work is done on the > premises. They do great work. My Subaru which will also put out 210-220 > HP FWF is about $25k. > > > -----Original Message----- > From: owner-engines-list-server(at)matronics.com > [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of John > Grosse > Sent: Friday, July 06, 2007 2:17 PM > To: engines-list(at)matronics.com > Subject: Re: Engines-List: carb or fuel injection? turbo? > > > Injected eliminates carb heat issues and almost all induction icing > issues. It's also more efficient and seems to be pretty much universal > on higher performance engines although it is more expensive. On a IO-360 > > the turbocharging is actually turbo-normalizing which means that it > allows you to develop more horsepower at higher altitudes. The only > stock turbochargers I'm aware of have a fixed waste gate which is not > particularly effective. There is an stc'd turbo charger made by Rajay > for the IO-360 that is much better but it's also about $10,000 last time > > I looked several years ago. There are also substantially higher > maintenance costs associated with turbo charging although I think your > 800 hour TBO is probably on the turbo and not the entire engine. > > The bottom line for me was that a turbo might be worth the added expense > > and complexity if you live in the mountains of the West or regularily > fly out there but not for me living in the flat lands of the Midwest. If > > I did get a turbo it would not be the one with a fixed waste gate. I'd > spend the bucks for a Rajay. > > just my 2 cents. > > John > > T22 wrote: > >>--> >> >>Does anybody have any insight on pros/cons of carberator versus fuel >>injection? How about adding a turbo? Lycoming's website for 360 >>engines (see link below) lists the turbocharged injected engine at >>800hours (40%) less TBO plus 100lbs additional weight for only 20HP >>gained. >> >> >> >> >> >> >>Read this topic online here: >> >>http://forums.matronics.com/viewtopic.php?p=122513#122513 >> >> >> >> >> >> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Jul 06, 2007
No. Pressure carbs were most commonly used on Bonanzas. They are a very sophisticated carb that functions like an altitude compensated throttle body injection. Several erroneous pieces of info already mentioned. The difference between a 180hp O-360 and 200 hp IO-360 is about 35 lbs, not 100. The injected engine will run LOP, most with stock injectors. A carb won't without some extra effort to vaporize the fuel and that takes heat, which reduces power. The difference in TBO is ZERO, NADA,ZIP. Both are 2000 hour TBO. The difference in power is most felt for takeoff and climb, much less in cruise. A throttle body injection like the Ellison is susceptible to throttle icing, and won't have as good mixture distribution as a port injection system like the Bendix. Bendix system is very simple, no user adjustments beyond idle speed and mixture, minimal maintenance, very reliable. KM A&P/IA On 7/6/07, Noel Loveys wrote: > > Is the Ellison system also what used to be referred to as a pressure > carburettor? > > Noel > > > -----Original Message----- > > From: owner-engines-list-server(at)matronics.com > > [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of > > Grant Piper > > Sent: Friday, July 06, 2007 8:29 PM > > To: engines-list(at)matronics.com > > Subject: Re: Engines-List: carb or fuel injection? turbo? > > > > > > > > > > I would like to add that another option is an Ellison > > Throttle Body Injector > > 'carburettor'. If well set up, you can lean as well as FI > > without the > > cost, weight and complexity of FI. The CAFE Mooney runs an > > IO-360-A1B6 > > with an Ellison rather than FI. Check their 'site for details. An > > Ellison also means only a low pressure fuel pump is needed, > > thus less cost > > again, and no fuel return line is needed, so plumbing is > > easier also. Carb > > heat is recommended with them, but they are less susceptible > > to icing than a > > standard carb, and you need/should have alternate air with FI anyway. > > > > Just to be clear, FI as used on aircraft is not EFI as used > > on cars. FI is > > all mechanical. > > > > Grant Piper > > > > ----- Original Message ----- > > From: "T22" <stone37house-airplane(at)yahoo.com> > > To: > > Sent: Saturday, July 07, 2007 2:07 AM > > Subject: Engines-List: carb or fuel injection? turbo? > > > > > > > > > > > > > Does anybody have any insight on pros/cons of carberator > > versus fuel > > > injection? How about adding a turbo? Lycoming's website > > for 360 engines > > > (see link below) lists the turbocharged injected engine at > > 800hours (40%) > > > less TBO plus 100lbs additional weight for only 20HP gained. > > > > > > > > > > > > > > > > > > > > > Read this topic online here: > > > > > > http://forums.matronics.com/viewtopic.php?p=122513#122513 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jul 07, 2007
Hi Noel, No, it uses a diaphram that opens with airflow to supply fuel to the metering tube with many small holes in it extending acroos the carb. throat. A flat slide (the throttle) uncovers the tube, and thus more holes, as you open the throttle. The mixture is adjusted by rotating the metering tube so that the holes face into the airflow (full lean) or ~90 to the airflow (full rich). There is also a separate simple mixture circuit for idle adjustment. There is no float bowl, so it doesn't care which way up it is. It will work with gravity or low pressure (2-6psi) fuel supply. They are susceptible to hiccups with hot fuel vaporising on the ground due to having no float bowl to separate the fuel from the vapour, but I have found it clears immediately high power/fuel flow is demanded. Hot starts are excellent cf. FI. I think they are a good thing, but there aren't a great number of people using them so there is little corporate knowledge out there about them. I like the lightness and simplicity, and will live with the odd hiccup when hot. Grant Piper ----- Original Message ----- From: "Noel Loveys" <noelloveys(at)yahoo.ca> Sent: Saturday, July 07, 2007 9:56 AM Subject: RE: Engines-List: carb or fuel injection? turbo? > > Is the Ellison system also what used to be referred to as a pressure > carburettor? > > Noel > >> -----Original Message----- >> From: owner-engines-list-server(at)matronics.com >> [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of >> Grant Piper >> Sent: Friday, July 06, 2007 8:29 PM >> To: engines-list(at)matronics.com >> Subject: Re: Engines-List: carb or fuel injection? turbo? >> >> >> >> >> I would like to add that another option is an Ellison >> Throttle Body Injector >> 'carburettor'. If well set up, you can lean as well as FI >> without the >> cost, weight and complexity of FI. The CAFE Mooney runs an >> IO-360-A1B6 >> with an Ellison rather than FI. Check their 'site for details. An >> Ellison also means only a low pressure fuel pump is needed, >> thus less cost >> again, and no fuel return line is needed, so plumbing is >> easier also. Carb >> heat is recommended with them, but they are less susceptible >> to icing than a >> standard carb, and you need/should have alternate air with FI anyway. >> >> Just to be clear, FI as used on aircraft is not EFI as used >> on cars. FI is >> all mechanical. >> >> Grant Piper >> >> ----- Original Message ----- >> From: "T22" <stone37house-airplane(at)yahoo.com> >> To: >> Sent: Saturday, July 07, 2007 2:07 AM >> Subject: Engines-List: carb or fuel injection? turbo? >> >> >> > >> > >> > Does anybody have any insight on pros/cons of carberator >> versus fuel >> > injection? How about adding a turbo? Lycoming's website >> for 360 engines >> > (see link below) lists the turbocharged injected engine at >> 800hours (40%) >> > less TBO plus 100lbs additional weight for only 20HP gained. >> > >> > >> > >> > >> > >> > >> > Read this topic online here: >> > >> > http://forums.matronics.com/viewtopic.php?p=122513#122513 >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Jul 07, 2007
Subject: Timing a Lycoming 0-290-D
We would appreciate input on timing a Lycoming 0-290-D that is using Bendix mags. The info says to use 18 degrees, however I've heard someone say to use 25 instead-----Comments please. ************************************** See what's free at http://www.aol.com. ________________________________________________________________________________
Date: Jul 07, 2007
Subject: Re: Timing a Lycoming 0-290-D
Use what is on the data plate. On 7/7/07, WRBYARS(at)aol.com wrote: > > > We would appreciate input on timing a Lycoming 0-290-D that is using Bendix > mags. The info says to use 18 degrees, however I've heard someone say to use > 25 instead-----Comments please. > > > ________________________________ > See what's free at AOL.com. > > ________________________________________________________________________________
Date: Jul 08, 2007
Thanks I'll Google Elliston and have a closer look. Noel > -----Original Message----- > From: owner-engines-list-server(at)matronics.com > [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of > Grant Piper > Sent: Saturday, July 07, 2007 5:59 AM > To: engines-list(at)matronics.com > Subject: Re: Engines-List: carb or fuel injection? turbo? > > > > > Hi Noel, > > No, it uses a diaphram that opens with airflow to supply fuel to the > metering tube with many small holes in it extending acroos > the carb. throat. > A flat slide (the throttle) uncovers the tube, and thus more > holes, as you > open the throttle. The mixture is adjusted by rotating the > metering tube > so that the holes face into the airflow (full lean) or ~90 > to the airflow > (full rich). There is also a separate simple mixture > circuit for idle > adjustment. There is no float bowl, so it doesn't care > which way up it is. > It will work with gravity or low pressure (2-6psi) fuel > supply. They are > susceptible to hiccups with hot fuel vaporising on the ground > due to having > no float bowl to separate the fuel from the vapour, but I > have found it > clears immediately high power/fuel flow is demanded. Hot starts are > excellent cf. FI. I think they are a good thing, but there > aren't a great > number of people using them so there is little corporate > knowledge out there > about them. I like the lightness and simplicity, and will > live with the > odd hiccup when hot. > > Grant Piper > > > ----- Original Message ----- > From: "Noel Loveys" <noelloveys(at)yahoo.ca> > To: > Sent: Saturday, July 07, 2007 9:56 AM > Subject: RE: Engines-List: carb or fuel injection? turbo? > > > > > > > Is the Ellison system also what used to be referred to as a pressure > > carburettor? > > > > Noel > > > >> -----Original Message----- > >> From: owner-engines-list-server(at)matronics.com > >> [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of > >> Grant Piper > >> Sent: Friday, July 06, 2007 8:29 PM > >> To: engines-list(at)matronics.com > >> Subject: Re: Engines-List: carb or fuel injection? turbo? > >> > >> > >> > >> > >> I would like to add that another option is an Ellison > >> Throttle Body Injector > >> 'carburettor'. If well set up, you can lean as well as FI > >> without the > >> cost, weight and complexity of FI. The CAFE Mooney runs an > >> IO-360-A1B6 > >> with an Ellison rather than FI. Check their 'site for > details. An > >> Ellison also means only a low pressure fuel pump is needed, > >> thus less cost > >> again, and no fuel return line is needed, so plumbing is > >> easier also. Carb > >> heat is recommended with them, but they are less susceptible > >> to icing than a > >> standard carb, and you need/should have alternate air with > FI anyway. > >> > >> Just to be clear, FI as used on aircraft is not EFI as used > >> on cars. FI is > >> all mechanical. > >> > >> Grant Piper > >> > >> ----- Original Message ----- > >> From: "T22" <stone37house-airplane(at)yahoo.com> > >> To: > >> Sent: Saturday, July 07, 2007 2:07 AM > >> Subject: Engines-List: carb or fuel injection? turbo? > >> > >> > >> > > >> > > >> > Does anybody have any insight on pros/cons of carberator > >> versus fuel > >> > injection? How about adding a turbo? Lycoming's website > >> for 360 engines > >> > (see link below) lists the turbocharged injected engine at > >> 800hours (40%) > >> > less TBO plus 100lbs additional weight for only 20HP gained. > >> > > >> > > >> > > >> > > >> > > >> > > >> > Read this topic online here: > >> > > >> > http://forums.matronics.com/viewtopic.php?p=122513#122513 > >> > > >> > > >> > > >> > > >> > > >> > > >> > > >> > > >> > > >> > > >> > > >> > >> > >> > >> > >> > >> > >> > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Subject: moronic starlet
Date: Jul 10, 2007
ghpqgd olnopqe snujk xmbys ________________________________________________________________________________
Date: Jul 10, 2007
Subject: Re: prop bolts
Date: Jul 28, 2007
My instruction manual said 60-65 ft-lb, clean and dry. They put emphasis on the threads being dry, not lubricated. If the threads are lubricated the proper torque would be lower, but I don't know how low. This was for an Aerocomposites prop on an IO-540, but I believe the hubs and bolts are the same for all Lycomings with constant-speed props. Gary Casey >> >> Can anyone tell me what the tourque on prop bolts should be? IO360 >> w/ alum prop. >> >> Thanks >> >> Dan Stanton >> 90% done 90% to go >> 801, IO360 ________________________________________________________________________________
Date: Jul 28, 2007
If you accidentally get some oil or grease in the threads you can wash it out with a bit of MEK. Noel > -----Original Message----- > From: owner-engines-list-server(at)matronics.com > [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of > Gary Casey > Sent: Saturday, July 28, 2007 9:44 AM > To: engines-list(at)matronics.com > Subject: Engines-List: Re: prop bolts > > > > My instruction manual said 60-65 ft-lb, clean and dry. They put > emphasis on the threads being dry, not lubricated. If the threads > are lubricated the proper torque would be lower, but I don't > know how > low. This was for an Aerocomposites prop on an IO-540, but I > believe > the hubs and bolts are the same for all Lycomings with > constant-speed > props. > > Gary Casey > > >> > >> Can anyone tell me what the tourque on prop bolts should > be? IO360 > >> w/ alum prop. > >> > >> Thanks > >> > >> Dan Stanton > >> 90% done 90% to go > >> 801, IO360 > > > > > > ________________________________________________________________________________
Date: Jul 29, 2007
Don, I0360 and O320 share the same prop. Assuming yours to be 3/8" bolt diameter, the torque is 24 to 25 lbf.ft. Bolts must be dry, non lubricated. Got this piece of info from Sensenich themselves. Cheers, Miguel Azevedo PA22/20 ************************************** Get a sneak peek of the all-new AOL at http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Subject: prop bolts
Date: Jul 29, 2007
Keep the lockwire nice and tight too. Noel -----Original Message----- From: owner-engines-list-server(at)matronics.com [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of AzevedoFlyer(at)aol.com Sent: Sunday, July 29, 2007 8:18 PM Subject: Re: Engines-List: prop bolts Don, I0360 and O320 share the same prop. Assuming yours to be 3/8" bolt diameter, the torque is 24 to 25 lbf.ft. Bolts must be dry, non lubricated. Got this piece of info from Sensenich themselves. Cheers, Miguel Azevedo PA22/20 _____ <http://discover.aol.com/memed/aolcom30tour/?ncid=AOLAOF00020000000982> . ________________________________________________________________________________
Date: Jul 30, 2007
Please double check this. They usuallly do not share the same prop. Among other things, the bolt hole diameter in the O and IO-360's is usually larger. JimC ----- Original Message ----- From: AzevedoFlyer(at)aol.com To: engines-list(at)matronics.com Sent: Sunday, July 29, 2007 4:47 PM Subject: Re: Engines-List: prop bolts Don, I0360 and O320 share the same prop. Assuming yours to be 3/8" bolt diameter, the torque is 24 to 25 lbf.ft. Bolts must be dry, non lubricated. Got this piece of info from Sensenich themselves. Cheers, Miguel Azevedo PA22/20 ------------------------------------------------------------------------- ----- ________________________________________________________________________________
Date: Jul 30, 2007
Jim, You are absolutely right! What I checked was 0320-150 hp and 0320-160hp (high compression)! Those two use the same prop. Maybe I got sidetracked by 160hp and 0360! I am sorry I fed the list a mistaken info and charged Sensenich for it! Must be one of those senior moments... Hope no damage was done. Miguel Azevedo PA22/20-150 -----Original Message----- From: jrc <jrccea(at)bellsouth.net> Sent: Mon, 30 Jul 2007 11:07 am Subject: Re: Engines-List: prop bolts Please double check this.? They usuallly do not share the same prop.? Among other things, the bolt hole diameter in the O and IO-360's is usually larger. JimC ----- Original Message ----- From: AzevedoFlyer(at)aol.com Sent: Sunday, July 29, 2007 4:47 PM Subject: Re: Engines-List: prop bolts Don, I0360 and O320 share the same prop. Assuming yours to be 3/8" bolt diameter, the torque is 24 to 25 lbf.ft. Bolts must be dry, non lubricated. Got this piece of info from Sensenich themselves. Cheers, Miguel Azevedo PA22/20 href="http://www.matronics.com/Navigator?Engines-List">http://www.matronics.com/Navigator?Engines-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________ ________________________________________________________________________________
Date: Jul 30, 2007
None here. I have more and more of those senior moments myself. Good to know I don't have a monopoly on it. Jim ----- Original Message ----- From: azevedoflyer(at)aol.com To: engines-list(at)matronics.com Sent: Monday, July 30, 2007 4:52 PM Subject: Re: Engines-List: prop bolts Jim, You are absolutely right! What I checked was 0320-150 hp and 0320-160hp (high compression)! Those two use the same prop. Maybe I got sidetracked by 160hp and 0360! I am sorry I fed the list a mistaken info and charged Sensenich for it! Must be one of those senior moments... Hope no damage was done. Miguel Azevedo PA22/20-150 -----Original Message----- From: jrc <jrccea(at)bellsouth.net> To: engines-list(at)matronics.com Sent: Mon, 30 Jul 2007 11:07 am Subject: Re: Engines-List: prop bolts Please double check this. They usuallly do not share the same prop. Among other things, the bolt hole diameter in the O and IO-360's is usually larger. JimC ----- Original Message ----- From: AzevedoFlyer(at)aol.com To: engines-list(at)matronics.com Sent: Sunday, July 29, 2007 4:47 PM Subject: Re: Engines-List: prop bolts Don, I0360 and O320 share the same prop. Assuming yours to be 3/8" bolt diameter, the torque is 24 to 25 lbf.ft. Bolts must be dry, non lubricated. Got this piece of info from Sensenich themselves. Cheers, Miguel Azevedo PA22/20 ------------------------------------------------------------------------- --- href="http://www.matronics.com/Navigator?Engines-List">http://www.matro nics.com/Navigator?Engines-List href="http://forums.matronics.com">http://forums.matronics.com ------------------------------------------------------------------------- ----- ________________________________________________________________________________
Date: Aug 05, 2007
Subject: Oil thermostatic by pass valves.
Question: Does anyone know just exactly how far the vern a therm ( by pass valve ) is supposed to stretch when at temperature? We have an oil temp problem and the by pass valve was replaced. ( ECI PMA replacement part ) . It did not solve the problem. Looking at the NEW part there was NO wear mark at all on the seating face of the valve. Placing it into a cup of boiling water it grew 0.107 from the ambient length. I also measured another ( old Lycoming part ) it grew 0.180 Also when I look at the ECI part in the oil filter adapter housing , it sits deeper than the Lycoming part. ( It appears that the ECI part would need to "grow" over 1/4 inch to make contact compared to maybe 1/16 to 1/8 inch on the Lycoming part. Thanks, Walt ________________________________________________________________________________
Subject: Re: Oil thermostatic by pass valves.
Date: Aug 05, 2007
Walt...................Lycoming Engines, 652 Oliver St., Williamsport, Pa. 17701.........570-323-6181..........Ask for "SUPPORT CENTER." 0800-1700 EDT, Mon-Fri...I'm sure the engineers will have an answer for you.....................................www.lycoming.textron.com/index.jsp CHEERS!!!! and good luck.............Gene Smith. ----- Original Message ----- From: "Walt Murphy" <waltmurphy(at)charter.net> Sent: Sunday, August 05, 2007 2:09 PM Subject: Engines-List: Oil thermostatic by pass valves. > > Question: > > Does anyone know just exactly how far the vern a therm ( by pass valve ) > is supposed to stretch when at temperature? > > We have an oil temp problem and the by pass valve was replaced. ( ECI > PMA replacement part ) . It did not solve the problem. Looking at the > NEW part there was NO wear mark at all on the seating face of the valve. > Placing it into a cup of boiling water it grew 0.107 from the ambient > length. I also measured another ( old Lycoming part ) it grew 0.180 > > Also when I look at the ECI part in the oil filter adapter housing , it > sits deeper than the Lycoming part. ( It appears that the ECI part would > need to "grow" over 1/4 inch to make contact compared to maybe 1/16 to > 1/8 inch on the Lycoming part. > > Thanks, > Walt > > ________________________________________________________________________________
Subject: Missed email mesages
Date: Aug 07, 2007
I must apologize, but my server 'ra.ca' had lost control of its machinery this last weekend and in the process of countering spam lost all emails to me from Saturday 04AUG to yesterday, Monday 07Aug. 7, 07 inclusive. If you had sent me critical advice or legal information during that period, I will not have got it and cannot therefore respond.......... Sorry Ferg ________________________________________________________________________________
Subject: orbiting cup
Date: Aug 10, 2007
nlme wupyk csjlwvg ygkfviq ________________________________________________________________________________
Date: Aug 10, 2007
Subject: Rear-entry sump
Date: Aug 11, 2007
I have left over from my last project a rear-entry sump for a IO-540 spread-valve engine. I believe it originally came from a Malibu. It is in new condition and includes all intake tubes and the adaptor for the throttle body (straight, not angled). I paid too much for it when I thought I could use it, but I'm willing to let it go for any reasonable price. Gary Casey ________________________________________________________________________________
Subject: Starter Wanted
Date: Aug 16, 2007
A friend of mine is searching for a starter for his project. Think he said it was for a GO-430 Lycoming. He needs a serviceable Bendix 397-4-B starter. Any one help on this one? __________________ -------- Pat Long RV-4, N120PL Bay City, MI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=129539#129539 ________________________________________________________________________________
Date: Aug 17, 2007
That's better known as an Eclipse E-80 starter. I've got one on the GO-480 in my Navion. I just had mine O/H'd by S&T Aircraft Accessories in New Braunfels, TX. They will be very expensive buying thru a shop. Normal O/H is $750 - mine was ~$1500 due to some broken parts. Try to find one at a salvage yard or private - it will likely be much cheaper. The GO's (435 & 480) were used on Helio's, SeeBee's, Twin Bo's, Queen Airs, Twin Commanders, Navions and others. The E-80 was also used on Continental E-series engines and a bunch of radials but you can't use that version.. There are MANY variations of the E-80 so it's important to get the right one. The Lycoming version turns the opposite of most other applications. They call it right hand turning. The Lyc's model numbers are even numbers. The Continental/radial types have odd model numbers. The motor can be rewired to turn either direction but the clutch and dogs are direction specific so you can't really convert. The clutch dogs are another variable. Mine has 3. The GO-435 probably does too but there are other possibilities - I've heard up to 10 dogs. The clutch also gets a torque setting unique to each engine type. That at least can be reset to whatever the GO-435 needs. There are also different style clutches but they are compatible. My "C" clutch has a rubber seal rather than the leather seal of the "B" and "A". My data plate is stamped as a model 10C. Then there is voltage - they come in both 12 and 24 which I believe can be changed (not totally sure of that.) Once he goes to install it, there are both positive and negative studs. Normally there is an insulating washer only on the positive. It does not ground only thru the case like modern starters. I was told the clutch housing is magnesium and won't carry the current. Regardless of the reason, plan on a separate ground strap - it won't work without it. If you need to run it on the bench to determine pos vs neg, just bump it. DO NOT let it spin up, it can come apart without a load on it. Unfortunately there is no alternative starter for the GO-480 or GO-435. The downside is it's old and heavy but otherwise it's a good starter. BTW, what's your friend's project? Regards, Greg Young - Houston (DWH) RV-6 N6GY - project Phoenix Navion N5221K - just an XXL RV-6A _____ From: owner-lycomingengines-list-server(at)matronics.com [mailto:owner-lycomingengines-list-server(at)matronics.com] On Behalf Of PGLong(at)aol.com Sent: Friday, August 17, 2007 6:47 AM Subject: LycomingEngines-List: Starter Wanted A friend of mine is searching for a starter for his project. Think he said it was for a GO-430 Lycoming. He needs a serviceable Bendix 397-4-B starter. This starter mounts on the accessory case. Any one help on this one? __________________ -------- Pat Long RV-4, N120PL Bay City, MI _____ "http://discover.aol.com/memed/aolcom30tour/?ncid=AOLAOF00020000000982" \nAOL.com. "http://www.matronics.com/Navigator?LycomingEngines-List"http://www.matronic s.com/Navigator?LycomingEngines-List 4:55 PM 4:55 PM ________________________________________________________________________________
Subject: magneto problem
Date: Aug 26, 2007
I just fired up my Lyc 540 for the first time configured with Electro air ignition on one set of plugs and a Slick mag on the other. I noticed the mag was not firing. I verified this with a strobe gun. I plan on replacing the unit which has been dormant for about 4 years, just sitting on the back of my engine. Anyone know of what might have gone wrong with this new unit, or how I might get it fixed? Thanks, Jim Stone Harmon Rocket II Louisville KY ________________________________________________________________________________
Subject: Re: magneto problem
Date: Aug 26, 2007
The mag wasn't firing or the CDI (the other "mag")? I have used dual LSE CDI's for over 200 hours with no problems so far. If it's the CDI not working, perhaps time to move up to LSE's. Wayne ----- Original Message ----- From: Jim Stone To: engines-list(at)matronics.com Sent: Sunday, August 26, 2007 3:37 AM Subject: Engines-List: magneto problem I just fired up my Lyc 540 for the first time configured with Electro air ignition on one set of plugs and a Slick mag on the other. I noticed the mag was not firing. I verified this with a strobe gun. I plan on replacing the unit which has been dormant for about 4 years, just sitting on the back of my engine. Anyone know of what might have gone wrong with this new unit, or how I might get it fixed? Thanks, Jim Stone Harmon Rocket II Louisville KY ________________________________________________________________________________
Date: Aug 26, 2007
If a mag doesn't fire at all, it is grounded or the points aren't openning. On 8/26/07, Jim Stone wrote: > > I just fired up my Lyc 540 for the first time configured with Electro air > ignition on one set of plugs and a Slick mag on the other. I noticed the > mag was not firing. I verified this with a strobe gun. I plan on replacing > the unit which has been dormant for about 4 years, just sitting on the back > of my engine. Anyone know of what might have gone wrong with this new unit, > or how I might get it fixed? > Thanks, > Jim Stone > Harmon Rocket II > Louisville KY > > * > > > * > > ________________________________________________________________________________
Date: Aug 26, 2007
Is it an impulse coupled Mag? Did you check the gap on the points? Some times crawlies can get in there an hold the points open.... That's where the term bugs in the system comes from. When the engine was mothballed you didn't happen to put an extra ground on the P-Lead? I usually will put my own "Lock out on the P-Lead if I'm going to work on an engine. Noel -----Original Message----- From: owner-engines-list-server(at)matronics.com [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of Jim Stone Sent: Sunday, August 26, 2007 8:07 AM Subject: Engines-List: magneto problem I just fired up my Lyc 540 for the first time configured with Electro air ignition on one set of plugs and a Slick mag on the other. I noticed the mag was not firing. I verified this with a strobe gun. I plan on replacing the unit which has been dormant for about 4 years, just sitting on the back of my engine. Anyone know of what might have gone wrong with this new unit, or how I might get it fixed? Thanks, Jim Stone Harmon Rocket II Louisville KY ________________________________________________________________________________
Date: Aug 26, 2007
Jim,=0AAs an A&P I will let you in on a secret don't take the magnet apart until you take the ignition harness off of it and let it sit open for 24 ho urs because it may have some moisture. I would also get yourself a timing b ox and hook it up to the magnet and turn the engine over to see if the poin ts open and close and are not grounded. Make sure you P lead is not grounde d when your ignition is on. If no results come from those procedures only t hen would I open the mag. They usually mechanically do not fail from sittin g. Only real thing that could happen is moisture in it and if they dry out normally they will work fine. If not the points usually need replacing and is a very simple producer that only requires a small amount of tooling and some time. You have to be careful and take your time doing it but its nothi ng you can't do yourself. =0A =0AGabe Kremer=0A =0ACell (217)357-1444=0A=0A =0A=0A----- Original Message ----=0AFrom: Jim Stone <jrstone(at)insightbb.com> =0ATo: engines-list(at)matronics.com=0ASent: Sunday, August 26, 2007 5:37:02 A M=0ASubject: Engines-List: magneto problem=0A=0A=0AI just fired up my Lyc 5 40 for the first time configured with Electro air ignition on one set of pl ugs and a Slick mag on the other. I noticed the mag was not firing. I ve rified this with a strobe gun. I plan on replacing the unit which has been dormant for about 4 years, just sitting on the back of my engine. Anyone know of what might have gone wrong with this new unit, or how I might get i t fixed?=0AThanks,=0AJim Stone=0AHarmon Rocket II=0ALouisville KY=0A=0A=0A_ -======================== -======================== ==0A=0A=0A =0A_____________________________________________________ _______________________________=0AChoose the right car based on your needs. Check out Yahoo! Autos new Car Finder tool.=0Ahttp://autos.yahoo.com/carf inder/ ________________________________________________________________________________
Date: Sep 08, 2007
Subject: New Realtime Spell Checker Added To Matronics Forums!
Dear Listers, Today 9/8/2007 I have added a new real-time spell checker function to all of the BBS Forums at Matronics. When you reply or create a new message on the Forums, you will notice that misspelled words will be high-lighted in yellow. If you left-click on the word, you will be prompted with a drop-down list of suggested spellings. http://forums.matronics.com Enjoy! Matt Dralle Matornics Email List and Forum Administrator ________________________________________________________________________________
Date: Sep 11, 2007
Subject: (no subject)
unsubsribe ________________________________________________________________________________
Subject: removing the oil filler tube
Date: Sep 16, 2007
Howdy all. I have a Lycoming O-320 E3D engine that I am installing in an RV9A. I am trying to remove the baffles. There is one screw that sits right behind the oil filler tube. To get to this screw I am going to have to take off the oil filler tube, which on this engine is plastic. I presume that this is a normal right hand thread and not left hand. I cannot get a spanner or wrench onto the bottom of the tube, but there is a "nut" about half up the tube. All my efforts so far have only succeeded in deforming the tube and the wrench slipping off. I am too scared of cracking this tube to grip it with vice grips, does anyone have a solution to this problem?? Thanks, Mick ________________________________________________________________________________
Subject: Re: removing the oil filler tube
Date: Sep 16, 2007
Can you not reach the screw behind the filler tube with an offset screwdriver? JimC ________________________________________________________________________________
Date: Sep 16, 2007
I'll assume you removed the safety wire at the base of the filler tube that is supposed to keep it from coming off?? Yes, is is normal right hand threads and usually comes loose just from folks tightening dipstick too tight and then wrenching to remove dipstick. On 9/15/07, Mick Muller wrote: > > > > > Howdy all. I have a Lycoming O-320 E3D engine that I am installing in an > RV9A. I am trying to remove the baffles. There is one screw that sits > right > behind the oil filler tube. To get to this screw I am going to have to > take > off the oil filler tube, which on this engine is plastic. I presume that > this is a normal right hand thread and not left hand. I cannot get a > spanner or wrench onto the bottom of the tube, but there is a "nut" about > half up the tube. All my efforts so far have only succeeded in deforming > the > tube and the wrench slipping off. I am too scared of cracking this tube to > grip it with vice grips, does anyone have a solution to this problem?? > Thanks, > Mick > > ________________________________________________________________________________
Date: Sep 17, 2007
jrccea(at)bellsouth.net wrote: > Can you not reach the screw behind the filler tube with an offset > screwdriver? > JimC Unless its a different kind of screwdriver, no. the offset would have to be about 40 degrees, which makes it difficult to turn. I only have about an inch and a quarter between the head of the screw and the filler pipe., and its recessed. If I can't get the filler pipe off, I am looking for a small universal joint that will take a flat head bit. Mick Read this topic online here: http://forums.matronics.com/viewtopic.php?p=134792#134792 ________________________________________________________________________________
Date: Sep 17, 2007
For that sort of thing, I generally use a hex-head screwdriver tip that is about 3/4 inch long (tip from a multi-tip screwdriver), and a 1/4 inch boxend wrench to turn it. You might have to bend the handle of the wrench a little. JimC ----- Original Message ----- From: "mullokintyre" <mmul6471(at)bigpond.net.au> Sent: Monday, September 17, 2007 3:08 AM Subject: Engines-List: Re: removing the oil filler tube > > > > jrccea(at)bellsouth.net wrote: >> Can you not reach the screw behind the filler tube with an offset >> screwdriver? >> JimC > > Unless its a different kind of screwdriver, no. the offset would have to > be about 40 degrees, which makes it difficult to turn. I only have about > an inch and a quarter between the head of the screw and the filler pipe., > and its recessed. If I can't get the filler pipe off, I am looking for a > small universal joint that will take a flat head bit. > Mick > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=134792#134792 > > > ________________________________________________________________________________
Date: Sep 17, 2007
Subject: running vacuum pump without load, bad idea?
Is it harmful t run the engine with the vacuum pump attached to the engine but the suction end free to pull in air, what is the best way to ground run engine with no load on vacuum pump? thanks skip ________________________________________________________________________________
Date: Sep 17, 2007
I don't suppose some where along the line some doofus put Locktite on the threads of the filler tube because it was a difficult spot to lockwire??? Noel ________________________________________________________________________________
Date: Sep 17, 2007
Vacuum pumps are generally vane pumps designed for large volume that the instruments they power require. Lab vacuum pumps are designed to evacuate air from small volumes. Running shouldn't hurt but I'd put a filter on the intake end to keep grit out. Noel -----Original Message----- From: owner-engines-list-server(at)matronics.com [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of CardinalNSB(at)aol.com Sent: Monday, September 17, 2007 11:38 AM Subject: Engines-List: running vacuum pump without load, bad idea? Is it harmful t run the engine with the vacuum pump attached to the engine but the suction end free to pull in air, what is the best way to ground run engine with no load on vacuum pump? thanks skip _____ Make AOL Your Homepage. ________________________________________________________________________________
Subject: Ring Flutter?
Date: Oct 10, 2007
What is piston "Ring Flutter"?? I have an IO360. Just how concerned shoul d I be? Fred K _________________________________________________________________ Help yourself to FREE treats served up daily at the Messenger Caf=E9. Stop by today. http://www.cafemessenger.com/info/info_sweetstuff2.html?ocid=TXT_TAGLM_Oc tWLtagline ________________________________________________________________________________
Date: Oct 10, 2007
Subject: Re: Ring Flutter?
Fredrick Kerfoot a crit : > > What is piston "Ring Flutter"?? I have an IO360. > Ring flutter is an uncontrolled vibration of the piston rings when pressure against the cylinder wall and rpm are inadequate. > Just how concerned should I be? In my opinion, no need to lose sleep over ring flutter on a Lyc. Best regards, -- Gilles http://contrails.free.fr ________________________________________________________________________________
Date: Oct 10, 2007
I would be concerned...I suggest you check your engine timing...Also if your fuel is old, it has lost some of it's volatility, and I would drain it and replace it with "fresh" gasoline...Are you burning Auto Gas?..The book says that 360 needs 100LL (all of them, 160 and above require it.)....................Good Luck.......................CHEERS!!!!.............................Gene Smith. ----- Original Message ----- From: Fredrick Kerfoot To: engines-list(at)matronics.com Sent: Wednesday, October 10, 2007 6:37 AM Subject: Engines-List: Ring Flutter? What is piston "Ring Flutter"?? I have an IO360. Just how concerned should I be? Fred K ------------------------------------------------------------------------- ----- Help yourself to FREE treats served up daily at the Messenger Caf=E9. Stop by today! ________________________________________________________________________________
Date: Oct 10, 2007
There are autogas STC's available for the 160. JimC ----- Original Message ----- From: Gene Smith To: engines-list(at)matronics.com Sent: Wednesday, October 10, 2007 9:38 AM Subject: Re: Engines-List: Ring Flutter? I would be concerned...I suggest you check your engine timing...Also if your fuel is old, it has lost some of it's volatility, and I would drain it and replace it with "fresh" gasoline...Are you burning Auto Gas?..The book says that 360 needs 100LL (all of them, 160 and above require it.)....................Good Luck.......................CHEERS!!!!.............................Gene Smith. ________________________________________________________________________________
Date: Oct 10, 2007
I guess I just don't see how you relate a question about theoretical ring flutter with engine timing or age of fuel. I'm missing the connection. Actually a 180 only requires 91-96 or 91 mogas with STC. Only the 160 and the 200hp versions need the extra octane. On 10/10/07, Gene Smith wrote: > > I would be concerned...I suggest you check your engine timing...Also if > your fuel is old, it has lost some of it's volatility, and I would drain it > and replace it with "fresh" gasoline...Are you burning Auto Gas?..The boo k > says that 360 needs 100LL (all of them, 160 and above require > it.)....................Good > Luck.......................CHEERS!!!!.............................Gene > Smith. > > ----- Original Message ----- > *From:* Fredrick Kerfoot > *To:* engines-list(at)matronics.com > *Sent:* Wednesday, October 10, 2007 6:37 AM > *Subject:* Engines-List: Ring Flutter? > > > What is piston "Ring Flutter"?? I have an IO360. Just how concerned > should I be? > > Fred K > > ------------------------------ > Help yourself to FREE treats served up daily at the Messenger Caf=E9. Sto p > by today!<http://www.cafemessenger.com/info/info_sweetstuff2.html?ocid= TXT_TAGLM_OctWLtagline> > > * > > href="http://www.matronics.com/Navigator?Engines-List">http://www.matro nics.com/Navigator?Engines-List > href="http://forums.matronics.com">http://forums.matronics.com > * > > * > =========== matronics.com/Navigator?Engines-List =========== =========== > > * > > ________________________________________________________________________________
Subject: Re: Engines-List Digest: 5 Msgs - 10/10/07
Date: Oct 11, 2007
I'm not a certified engine expert (although I am probably certifiable in other catagories...:-), but in my experience "ring flutter" is something the engine builder will use to explain broken rings found after a teardown. The owner will then nod and pay the bill. Presumably the the ring starts to vibrate away from the cylinder wall in waves. Some will say it can happen at very high piston speeds or with a cylinder that is badly worn - or if the cylinder pressure is rapidly changing as in a detonation event. Regardless, it is the result of something bad, not the cause of it. How someone can diagnose "ring flutter" without having torn down the engine I don't know. I certainly wouldn't lose any sleep over it, but at the same time keeping the timing correct will maintain a margin against detonation. Most naturally-aspirated aircraft engines have a robust margin anyway, except when overheating while running on one mag. Gary Casey > > From: Fredrick Kerfoot <fredkt46(at)hotmail.com> > Subject: Engines-List: Ring Flutter? > > > What is piston "Ring Flutter"?? I have an IO360. Just how > concerned shoul > d I be? > > Fred K ________________________________________________________________________________
Date: Oct 11, 2007
Finally, someone who paying attention. Ring flutter is very rare. Especially at less than 2700 rpm. Piston ring seal depends on a balance of four forces: combustion pressure, ring inertia, the rings radial expansion pressure and crankcase pressure. Ring flutter is uncontrolled oscillation due to an imbalance of those forces. Once a pistons rings go into flutter, their ability to scrape oil off the cylinder wall as the piston moves downward is impaired, blow-by increases and oil consumption rises dramatically. The combination of high rpm and low crankcase pressure typical of low engine loads causes those four forces to become imbalanced. The small amount time the engine sees regular, high-rpm, light-load operation, is rare. Even so, if that happens, you may experience ring flutter and high oil consumption, but not likely. -----Original Message----- From: Kelly McMullen <apilot2(at)gmail.com> Sent: Wed, 10 Oct 2007 6:43 pm Subject: Re: Engines-List: Ring Flutter? I guess I just don't see how you relate a question about theoretical ring flutter with engine timing or age of fuel. I'm missing the connection. Actually a 180 only requires 91-96 or 91 mogas with STC. Only the 160 and the 200hp versions need the extra octane. On 10/10/07, Gene Smith wrote: I would be concerned...I suggest you check your engine timing...Also if your fuel is old, it has lost some of it's volatility, and I would drain it and replace it with "fresh" gasoline...Are you burning Auto Gas?..The book says that 360 needs 100LL (all of them, 160 and above require it.)....................Good Luck.......................CHEERS!!!!.............................Gene Smith. ----- Original Message ----- From: Fredrick Kerfoot To: engines-list(at)matronics.com Sent: Wednesday, October 10, 2007 6:37 AM Subject: Engines-List: Ring Flutter? What is piston "Ring Flutter"?? I have an IO360. Just how concerned should I be? Fred K Help yourself to FREE treats served up daily at the Messenger Caf. Stop by today! href="http://www.matronics.com/Navigator?Engines-List"> http://www.matronics.com/Navigator?Engines-List href="http://forums.matronics.com"> http://forums.matronics.com -= the many List utilities such as the Subscriptions page, ronics.com/Navigator?Engines-List" target="_blank" onclick="return top.js.OpenExtLink(window,event,this)"> http://www.matronics.com/Navigator?Engines-List k" onclick="return top.js.OpenExtLink(window,event,this)"> http://forums.matronics.com ========== ________________________________________________________________________ Email and AIM finally together. You've gotta check out free AOL Mail! - http://mail.aol.com ________________________________________________________________________________
Date: Oct 11, 2007
Subject: Knock sensors?
We've had knock sensors on cars for many years that retard timing in the event of detonation to keep engines running at peak fuel efficiency. Since it is almost impossible to detect thru conventional aircraft engine instrumentation that I'm aware of, or audibly, (such as in cars) that such a device would be very useful in planes, but I've never heard of such a critter. I'm kinda guessing that it is difficult in an air-cooled engine or because of the large cylinder displacement. Anyone aware of any attempts to do this on Lycs or Conts? Mark Phillips ________________________________________________________________________________
Subject: Re: Knock sensors?
Date: Oct 12, 2007
I read years ago that knock sensors were tried but didn't work because with the piston slap that is present in air cooled aircraft engines makes it difficult for the sensor to determine the difference between piston slap and 'knock.' -----Original Message----- From: Fiveonepw(at)aol.com Sent: Thu, 11 Oct 2007 8:08 pm Subject: Engines-List: Knock sensors? We've had knock sensors on cars for many years that retard timing in the event of detonation to keep engines running at peak fuel efficiency. Since it is almost impossible to detect thru conventional aircraft engine instrumentation that I'm aware of, or audibly, (such as in cars) that such a device would be very useful in planes, but I've never heard of such a critter. I'm kinda guessing that it is difficult in an air-cooled engine or because of the large cylinder displacement. Anyone aware of any attempts to do this on Lycs or Conts? Mark Phillips ------------------------------------------------------------ See what's new ________________________________________________________________________ Email and AIM finally together. You've gotta check out free AOL Mail! - http://mail.aol.com ________________________________________________________________________________
Subject: Ring flutter?
Date: Oct 12, 2007
Piston Ring flutter: `....seems to me we had the same problem on the Super Connie (Old Bob may comment here). This aircraft was named the largest 3-engined airliner on the Atlantic. So. on pain of death no Driver, Airframe, would ever reduce the Brake Mean Effective Pressure (BMEP) below 90 with the RPM at cruise or descent because the condition would induce 'ring flutter' and an earlier engine change was inevitable. I suspect my employer's profit was based more on engine changes than seat mileage. Cheers, Ferg ________________________________________________________________________________
Date: Oct 12, 2007
Subject: Engine stand
I just received my new IO-360 from Aero Sport Power and I need to add things like the fuel servo, governor, etc. I am considering the Aircraft Tool Supply engine stand but I am really concerned about the engine being top heavy and unstable on that stand. Is this concern justified? Is there an alternative to this style of tripod stand? Also, is it better to install the baffle kit with the engine on the stand or should I wait until it is mounted on the airframe? Thanks, Doug Waddingham Centennial, CO ________________________________________________________________________________
Date: Oct 12, 2007
Doug, Wouldn't it be easier to install the servo and prop governor after the engine is already hung on the airframe instead of having to work around these during the install? As for the baffles, I would wait until it's hung for sure. Allen BPE, Inc. -----Original Message----- From: owner-engines-list-server(at)matronics.com [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of Doug Waddingham Sent: Friday, October 12, 2007 8:16 AM Subject: Engines-List: Engine stand I just received my new IO-360 from Aero Sport Power and I need to add things like the fuel servo, governor, etc. I am considering the Aircraft Tool Supply engine stand but I am really concerned about the engine being top heavy and unstable on that stand. Is this concern justified? Is there an alternative to this style of tripod stand? Also, is it better to install the baffle kit with the engine on the stand or should I wait until it is mounted on the airframe? Thanks, Doug Waddingham Centennial, CO ________________________________________________________________________________
From: "Larry L. Tompkins, P.E." <tompkinsl(at)integra.net>
Date: Oct 12, 2007
Some time ago I spoke to a long-time engineering friend who has spent his entire (40-yr.) career in automotive engine development. My understanding? is that automobile engine knock sensors are block mounted and detect vibration in engines that compared to aircraft engines run quite smooth. Our engines are s*** shakers, have individual cylinders. His conclusion was that automotive typeknock sensors would probably NOT work in aircraft engines. I consider him very knowledgable as well as an excellent engineer. Larry Tompkins ________________________________________________________________________________
Date: Oct 12, 2007
Knock sensors are tuned to specific frequency bands depending upon the engine they're used on. Any engine with such large jugs that they have to have 2 plugs per cylinder just to fire all the fuel/air mixture packs a whale of a wollop when it fires. This power ulse wollop is so much larger than the majority of engine knocks that the use of a knock sensor is fruitless. It's also why some props will not work with some engines. David M. ----- Original Message ----- From: Larry L. Tompkins, P.E. To: engines-list(at)matronics.com Sent: Friday, October 12, 2007 2:03 PM Subject: Re: Engines-List: Knock sensors? Some time ago I spoke to a long-time engineering friend who has spent his entire (40-yr.) career in automotive engine development. My understanding? is that automobile engine knock sensors are block mounted and detect vibration in engines that compared to aircraft engines run quite smooth. Our engines are s*** shakers, have individual cylinders. His conclusion was that automotive typeknock sensors would probably NOT work in aircraft engines. I consider him very knowledgable as well as an excellent engineer. Larry Tompkins ________________________________________________________________________________
Subject: corvair engine
Date: Oct 12, 2007
Hi all, I'm interested in building a Corvair conversion. Have WWs manual. I'm having a tough time finding an engine where I live in central Texas. The junk yards say "no". For those who have pursued working on a Corvair conversion, where have you found your cores? I'm not really interested in buying a rebuilt one. Thanks Read this topic online here: http://forums.matronics.com/viewtopic.php?p=139652#139652 ________________________________________________________________________________
Date: Oct 12, 2007
Here's a few choices, oct 11, 2007 Steven dinieri Iflyrv10.com 1965 Engine Chevy Corvair 000632018 $325 Auto Salvage Center USA-WI(Neshkoro) E-mail 1-877-666-9632 518 1966 Engine Chevy Corvair (6-164)- 166,000 A 07I-33 $300 Trails End Auto and Truck Salvage, Inc. USA-IA(Des-Moines) Request_Quote 1-800-717-6505 Request_Insurance_Quote 761 1965 Engine Chevy Corvair MAYBE 1963 MODEL YEAR NAP $300 Archies Auto Recyclers USA-IN(Merrillville) E-mail 1-219-769-2441 / 1-888-886-0118 443 1965 Engine Chevy Corvair COMPLET,87654014 87654014 $300 Hy-Way Service, LLC USA-ME(Milford) E-mail 1-877-884-4568 / 1-207-827-5568 531 1965 Engine Chevy Corvair STUCK,98765015 98765015 $300 Hy-Way Service, LLC USA-ME(Milford) E-mail 1-877-884-4568 / 1-207-827-5568 531 1965 Engine Chevy Corvair call for dates and pricing 10,000 A NOF $Call Denison Auto Parts USA-OH(Cleveland) E-mail 1-800-328-9001 186 1965 Engine Chevy Corvair turbo motor- call for dates andpricing 10,000 A NOF $Call Denison Auto Parts USA-OH(Cleveland) E-mail 1-800-328-9001 186 1965 Engine Chevy Corvair PARTS [300-05164A] (STORE:1) 182965 $Call East West Auto Parts, Inc. USA-OK(Tulsa) E-mail 1-800-447-2886 1019 1965 Engine Chevy Corvair RWD,4SP,ITS,(1964),1 2289017 12289017 $Call Feezle Auto Wrecking USA-PA(Enon-Valley) E-mail 1-724-336-5512 171 1965 Engine Chevy Corvair 4-1BBL,140,C O R E,T07I2RN ZZF043 $Call McLambs Auto Shop and Salvage USA-NC(Fuquay-Varina) Request_Quote 1-800-882-0111 Request_Insurance_Quote 522 1965 Engine Chevy Corvair 67 164,110HP,RB CODE,SMOKES,RUN COR M04723 $Call All American Classics USA-WA(Vancouver) E-mail 1-800-955-4999 2131 1966 Engine Chevy Corvair -(6-164)-,65K 2446 $Call North Smithfield Auto Recycling, Inc. USA-RI(North-Smithfield) Request_Quote 1-401-766-5422 Request_Insurance_Quote 384 1967 Engine Chevy Corvair FLAT-6 CYL,164 CID,NEEDS CRANKED BC0230 $Call A-1-A Auto Parts, Inc. USA-FL(Lakeland) Request_Quote 1-800-922-9676 Request_Insurance_Quote 1061 1965 Engine Chevy Corvair 658912 $Call Al's Auto Salvage, LLC USA-OK(Oklahoma-City) E-mail 866-392-9782 1121 1969 Engine Chevy Corvair (6-164)-ASK ME 1041 $Call PorFor Auto USA-CA(Los-Angeles) Request_Quote 1-323-589-2162 Request_Insurance_Quote 2196 -----Original Message----- From: owner-engines-list-server(at)matronics.com [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of SockPuppet61 Sent: Friday, October 12, 2007 8:06 PM Subject: Engines-List: corvair engine --> Hi all, I'm interested in building a Corvair conversion. Have WWs manual. I'm having a tough time finding an engine where I live in central Texas. The junk yards say "no". For those who have pursued working on a Corvair conversion, where have you found your cores? I'm not really interested in buying a rebuilt one. Thanks Read this topic online here: http://forums.matronics.com/viewtopic.php?p=139652#139652 ________________________________________________________________________________
Date: Oct 12, 2007
Maybe we should try again! Piston slap is a repeatable, rpm-correlated event. Detonation has a high frequency and fast-decaying "signature". Can be easily tracked and filtered. Never had problems with these two. Aircooled engines complicate things a bit because of the finning which radiate vibration in a very ample spectrum. Despite the apparent complexity, I am sure someone can develop a reliable knock sensor for aircooled engines. What about PORSCHE engines? The problem might reside more in the lack of a large enough market for such product than anything else. -----Original Message----- From: teamgrumman(at)aol.com Sent: Fri, 12 Oct 2007 3:05 am Subject: Re: Engines-List: Knock sensors? ? I read years ago that knock sensors were tried but didn't work because with the piston slap that is present in air cooled aircraft engines makes it difficult for the sensor to determine the difference between piston slap and 'knock.'? ? -----Original Message-----? From: Fiveonepw(at)aol.com? Sent: Thu, 11 Oct 2007 8:08 pm? Subject: Engines-List: Knock sensors?? ? ? ? ? ? We've had knock sensors on cars for many years that retard timing in the event of detonation to keep engines running at peak fuel efficiency.? Since it is almost impossible to detect thru conventional aircraft engine instrumentation that I'm aware of, or audibly, (such as in cars) that such a device would be very useful in planes, but I've never heard of such a critter.? I'm kinda guessing that it is difficult in an air-cooled engine or because of the large cylinder displacement.?? ?? Anyone aware of any attempts to do this on Lycs or Conts?? ?? Mark Phillips? ? ? ------------------------------------------------------------? See what's new? ? ? ? ? ________________________________________________________________________? Email and AIM finally together. You've gotta check out free AOL Mail! - http://mail.aol.com? ? ? ________________________________________________________________________ Email and AIM finally together. You've gotta check out free AOL Mail! - http://mail.aol.com ________________________________________________________________________________
Date: Oct 12, 2007
X-mailer: Pegasus Mail for Windows (4.41) > I read years ago that knock sensors were tried but didn't work because > with the piston slap that is present in air cooled aircraft engines > makes it difficult for the sensor to determine the difference between > piston slap and 'knock.' Can't speak to the whole issue but... I live a short ways from GAMI at Ada, OK. While over there one day I asked about their electronic ignition. They're using an optical sensor (laser pulsed into the cylinder via a fiber optic cable situated on an offset spark plug). The regular 18 mm plug has the cylinder offset axially from the center and the fiber optic is positioned on the other side. The laser detects the onset of detonation through some sophisticated algorithims looking at charge density and flame front propagation (as they explained it to me). GAMI chose the nastiest engine known in terms of detonation sensitivity, a TSIO 540. They can virtually feed this beast almost anything combustible and it runs without complaint. They even demonstarte changing fuel types during a full power test cell run and you'd never know anything had changed except by watching the timing and EGT changes on the data screen. Its been a year or so since I saw it in operation and don't know their current status for certification testing. Jim Baker 580.788.2779 '71 SV, 492TC Elmore City, OK ________________________________________________________________________________
Date: Oct 12, 2007
Subject: Re: corvair engine
I have just what your looking for if you want a core engine and I have some books and info on them also I have a 6 cylinder Corvair engine Email me at _ElleryWeld(at)aol.com_ (mailto:ElleryWeld(at)aol.com) if your interested Ellery ________________________________________________________________________________
Date: Oct 12, 2007
Porsche air cooled six cylanders have one on each side mounted on a bar that is bolted to three cylinders. They work good. ----- Original Message ----- From: azevedoflyer(at)aol.com To: engines-list(at)matronics.com Sent: Friday, October 12, 2007 8:25 PM Subject: Re: Engines-List: Knock sensors? Maybe we should try again! Piston slap is a repeatable, rpm-correlated event. Detonation has a high frequency and fast-decaying "signature". Can be easily tracked and filtered. Never had problems with these two. Aircooled engines complicate things a bit because of the finning which radiate vibration in a very ample spectrum. Despite the apparent complexity, I am sure someone can develop a reliable knock sensor for aircooled engines. What about PORSCHE engines? The problem might reside more in the lack of a large enough market for such product than anything else. -----Original Message----- From: teamgrumman(at)aol.com To: engines-list(at)matronics.com Sent: Fri, 12 Oct 2007 3:05 am Subject: Re: Engines-List: Knock sensors? I read years ago that knock sensors were tried but didn't work because with the piston slap that is present in air cooled aircraft engines makes it difficult for the sensor to determine the difference between piston slap and 'knock.' -----Original Message----- From: Fiveonepw(at)aol.com To: engines-list(at)matronics.com Sent: Thu, 11 Oct 2007 8:08 pm Subject: Engines-List: Knock sensors? We've had knock sensors on cars for many years that retard timing in the event of detonation to keep engines running at peak fuel efficiency. Since it is almost impossible to detect thru conventional aircraft engine instrumentation that I'm aware of, or audibly, (such as in cars) that such a device would be very useful in planes, but I've never heard of such a critter. I'm kinda guessing that it is difficult in an air-cooled engine or because of the large cylinder displacement. Anyone aware of any attempts to do this on Lycs or Conts? Mark Phillips ------------------------------------------------------------ See what's new ________________________________________________________________________ Email and AIM finally together. You've gotta check out free AOL Mail! - http://mail.aol.com ------------------------------------------------------------------------- ----- Email and AIM finally together. You've gotta check out free AOL Mail! ________________________________________________________________________________
Date: Oct 12, 2007
From: "DEAN PSIROPOULOS" <dean.psiropoulos(at)verizon.net>
I'm not aware of anyone who's tried this on a big bore aircraft engine and I've been wondering why also. My 1981 Turbocharged Trans Am had a rather simple knock sensing system. There was a piezo-electric sensor screwed into the engine block. The signal from the sensor was amplified and converted to digital to be analyzed by the microprocessor in the crude engine controllers of the time. If the engine started knocking the microcontroller would detect the spike in the voltage of the piezo sensor and send a signal to the distributor to retard the spark. This wouldn't be real easy to do with magneto ignition but folks like e-mag/p-mag and Lightspeed should be able to incorporate the amplifier and A/D convertor into their boxes and sell them along with a commercially available piezo sensor. One would have to find a suitable place on the crankcase to solidly mount the sensor but there is no reason it shouldn't work. Even if the sensor output could be sent to a display that helped the pilot identify detonation would be better than no detection at all. Then more of us could run mogas with better piece of mind and stop using it if we get a bad batch. Dean Psiropoulos RV-6A IO-360 ____________________ Original Message _______________________________ From: Fiveonepw(at)aol.com Subject: Engines-List: Knock sensors? We've had knock sensors on cars for many years that retard timing in the event of detonation to keep engines running at peak fuel efficiency. I'm kinda guessing that it is difficult in an air-cooled engine or because of the large cylinder displacement. Anyone aware of any attempts to do this on Lycs or Conts? Mark Phillips ________________________________________________________________________________
Date: Oct 12, 2007
Aircooled Porsche's are somewhat around 1/2 Liter per Cylinder (~3Liter / 6Cyl.), whereas the 360cid Lycoming's cylinder volume's are nearly TRIPLE that... Different smoothness for sure... ----- Original Message ----- From: John D. Heath To: engines-list(at)matronics.com Sent: Friday, October 12, 2007 8:34 PM Subject: Re: Engines-List: Knock sensors? Porsche air cooled six cylanders have one on each side mounted on a bar that is bolted to three cylinders. They work good. ----- Original Message ----- From: azevedoflyer(at)aol.com To: engines-list(at)matronics.com Sent: Friday, October 12, 2007 8:25 PM Subject: Re: Engines-List: Knock sensors? Maybe we should try again! Piston slap is a repeatable, rpm-correlated event. Detonation has a high frequency and fast-decaying "signature". Can be easily tracked and filtered. Never had problems with these two. Aircooled engines complicate things a bit because of the finning which radiate vibration in a very ample spectrum. Despite the apparent complexity, I am sure someone can develop a reliable knock sensor for aircooled engines. What about PORSCHE engines? The problem might reside more in the lack of a large enough market for such product than anything else. -----Original Message----- From: teamgrumman(at)aol.com To: engines-list(at)matronics.com Sent: Fri, 12 Oct 2007 3:05 am Subject: Re: Engines-List: Knock sensors? I read years ago that knock sensors were tried but didn't work because with the piston slap that is present in air cooled aircraft engines makes it difficult for the sensor to determine the difference between piston slap and 'knock.' -----Original Message----- From: Fiveonepw(at)aol.com To: engines-list(at)matronics.com Sent: Thu, 11 Oct 2007 8:08 pm Subject: Engines-List: Knock sensors? We've had knock sensors on cars for many years that retard timing in the event of detonation to keep engines running at peak fuel efficiency. Since it is almost impossible to detect thru conventional aircraft engine instrumentation that I'm aware of, or audibly, (such as in cars) that such a device would be very useful in planes, but I've never heard of such a critter. I'm kinda guessing that it is difficult in an air-cooled engine or because of the large cylinder displacement. Anyone aware of any attempts to do this on Lycs or Conts? Mark Phillips ------------------------------------------------------------ See what's new ________________________________________________________________________ Email and AIM finally together. You've gotta check out free AOL Mail! - http://mail.aol.com ------------------------------------------------------------------------- --- Email and AIM finally together. You've gotta check out free AOL Mail! href="http://www.matronics.com/Navigator?Engines-List">http://www.matro nics.com/Navigator?Engines-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Subject: Re: Engines-List Digest: 14 Msgs - 10/12/07
Date: Oct 13, 2007
I've heard this before, but consider this: The piston rings run at no load half the time regardless of manifold pressure (BMEP). During the exhaust and intake strokes the pressure is very low, so if the rings were going to flutter why don't they do it then? Gary > > From: "Fergus Kyle" <VE3LVO(at)rac.ca> > Subject: Engines-List: Ring flutter? > > > Piston Ring flutter: > `....seems to me we had the same problem on the Super Connie (Old > Bob may comment here). This aircraft was named the largest 3-engined > airliner on the Atlantic. So. on pain of death no Driver, Airframe, > would > ever reduce the Brake Mean Effective Pressure (BMEP) below 90 with > the RPM > at cruise or descent because the condition would induce 'ring > flutter' and > an earlier engine change was inevitable. > I suspect my employer's profit was based more on engine changes than > seat mileage. > Cheers, Ferg ________________________________________________________________________________
Subject: Re: Ring flutter?
Date: Oct 13, 2007
On Oct 13, 2007, at 5:27 AM, Gary Casey wrote: > I've heard this before, but consider this: The piston rings run at > no load half the time regardless of manifold pressure (BMEP). > During the exhaust and intake strokes the pressure is very low, so > if the rings were going to flutter why don't they do it then? > Gary > >> >> From: "Fergus Kyle" <VE3LVO(at)rac.ca> >> Subject: Engines-List: Ring flutter? >> >> >> Piston Ring flutter: >> `....seems to me we had the same problem on the Super Connie (Old >> Bob may comment here). This aircraft was named the largest 3-engined >> airliner on the Atlantic. So. on pain of death no Driver, >> Airframe, would >> ever reduce the Brake Mean Effective Pressure (BMEP) below 90 with >> the RPM >> at cruise or descent because the condition would induce 'ring >> flutter' and >> an earlier engine change was inevitable. >> I suspect my employer's profit was based more on engine changes than >> seat mileage. >> Cheers, Ferg > ________________________________________________________________________________
Date: Oct 13, 2007
I suspect you are right - the market is very, very small. The knock sensor itself usually is tuned to respond to the knock frequency of a particular engine and the frequency of a large-bore aircraft engine is almost certainly a lot different than a car engine, preventing the use of a cheap readily available sensor. Any knock control system is software-intensive, with the algorithm being carefully worked out during lots of experimentation (running on the dyno for lots of hours). At high power settings the knock is often undetectable as it is drowned out by the other noises (the car engine systems that I was familiar with years ago essentially shut off at high load and relied on the timing acquired during light load operation). And then the real kicker is that on an aircraft system you want some kind of fault tolerance - how do you protect against some fault in the system that over-advances the spark? What do you use to check it? The combination of all these things will, in my opinion, prevent the use of a vibration-based knock system in an aircraft engine for some time. The optical system is perhaps a different matter. Gary Casey > > Subject: Re: Engines-List: Knock sensors? > From: azevedoflyer(at)aol.com > > > Maybe we should try again! > Piston slap is a repeatable, rpm-correlated event. Detonation has a > high frequency > and fast-decaying "signature". Can be easily tracked and filtered. > Never had > problems with these two. Aircooled engines complicate things a bit > because > of the finning which radiate vibration in a very ample spectrum. > Despite the apparent > complexity, I am sure someone can develop a reliable knock sensor for > aircooled engines. What about PORSCHE engines? > The problem might reside more in the lack of a large enough market > for such product > than anything else. ________________________________________________________________________________
Date: Oct 13, 2007
Dean and All, No question that an electronic means of knock detection is the preferred route, given its sensitivity and ease of integration to the electronic ECU. For altogether different reasons, I developed (...and have a Form 337 granted by FAA) what I call an Engine Health Monitor Indicator (EHMI) and have it in my instrument panel. Among several other factors, detonation beyond light (light as defined as a ping or two here and there or continuous, barely audible in a test cell) will cause ring flutter. Flutter will change blowby emission. The EHMI monitors (passively) the blowby emitted. On a modified meter, there are bands colored Green / Yellow and Red. During take off you have the worst condition in which detonation could become a problem. That sets your upper limit of your Green band. If, at any time, you see a trend towards this upper value, for sure something is steadily deteriorating and you should do something about it regardless of the source. You know it is affecting your PCU (power cylinder unit), so its bad news. The great thing about monitoring BBY is that it is the first variable to indicate something going wrong. For example, our engines are prone to ring and valve sticking. If a ring is intermittently stuck in its groove, not even JPI exhaust temperature indicators will catch it, as exhaust temps will remain the same. But the BBY will be affected...and EHMI will catch it! I've been flying with this indicator in my plane for the last two years. I can tell when oil reaches the upper parts of the cylinder after a cold, long inactivity. I can tell when oil has reached an ideal operating temperature. I can use it as a leaning indication instrument. I can tell if a plug has shorted or I left mags on Left or Right and not in BOTH. I can distinguish between Left and Right mags firing. I can...(still learning...) The guys at the local FAA FISDO were sufficiently impressed to say "...you have turned $4-$5K instruments out there obsolete! Yours should be a required instrument in every new piston engined plane". Felt complimented! Anyway, this is not a commercial/propaganda email. Purpose is to say that if we satisfy ourselves with less than perfection, something can be done on the cheap to improve engine health monitiring. Sorry for the lengthy mail. Just got carried away I guess. Miguel PA22/20-150 N8714D ________________________________________________________________________________
Date: Oct 13, 2007
thanks. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=139830#139830 ________________________________________________________________________________
Date: Oct 14, 2007
Very interesting. Does it measure pressure or flow? At my day job we build both for large engines, typically multi-thousand hp mining truck engines. The flow is still measured by pressure - pressure drop in a venturi. I agree, one nice thing about measuring crankcase pressure is that it is totally non-invasive and doesn't affect the base engine operation at all. Having such a thing would have stopped me from taking off when a ring broke on my IO-360. Turns out I was stopped by someone driving up and blocking my way, telling me I was blowing smoke (come to think of it, I've had people tell me that a number of times..:-). Gary Casey > > From: AzevedoFlyer(at)aol.com > Subject: Re: Engines-List: Knock sensors > > Dean and All, > No question that an electronic means of knock detection is the > preferred > route, given its sensitivity and ease of integration to the > electronic ECU. For > > altogether different reasons, I developed (...and have a Form 337 > granted by > FAA) what I call an Engine Health Monitor Indicator (EHMI) and have > it in my > instrument panel. > The EHMI monitors > (passively) the blowby emitted. On a modified meter, there are > bands colored > Green / Yellow and Red. During take off you have the worst > condition in which > (snip) > Miguel > PA22/20-150 > N8714D ________________________________________________________________________________
Date: Oct 14, 2007
Date: Oct 14, 2007
Gary, It translates pressure measured through a modified Pitot Tube into flow. Thanks, Miguel ________________________________________________________________________________
Date: Oct 14, 2007
In a message dated 10/12/2007 8:27:32 PM Central Daylight Time, azevedoflyer(at)aol.com writes: Aircooled engines complicate things a bit because of the finning which radiate vibration in a very ample spectrum. >>> Based on my meager understanding of knock sensor physics in automotive applications, this was my primary suspicion- how to isolate specific "knock" signatures when you have several hundred fins vibrating in multiple frequencies and harmonics of same. If Lycosaurs were falling from the sky due to detonation at the hands of efficiency-desparate pilots, I'd believe market and/or regulatory pressure would force development of such a system. Perhaps when domestic airplane fuel hits European price$ and truly efficient operation becomes a defining market factor, this technology will develop and we'll have a new paradigm: LOD operation vs. LOP, just like in your average run-of-the-mill ten-year-old Nissan Sentra.... With the astonishing capacity of modern digital processing, I can't understand how an on-board processor couldn't sample vibratation sendor data from multiple points, compare that against know "safe" data, then somehow annunciate a potentially unsafe condition and/or make appropriate adjustments to whatever engine-management scenario a pilot may employ in the ultimate interest of maximizing efficiency. Here's hoping that if observers from the Lycoming/Continental intelligentsia have comments, they'd chime in here, even if covertly. Appreciate the discussion- Mark ________________________________________________________________________________
Date: Oct 14, 2007
if efficiency were truly a concern, they'd all convert to fuel injection. If that, then the pilot would have no control over anything except which way to point -- and would not need it. The computer would control LOP etc. David M. ----- Original Message ----- From: Fiveonepw(at)aol.com To: engines-list(at)matronics.com Sent: Sunday, October 14, 2007 10:14 PM Subject: Re: Engines-List: Knock sensors? In a message dated 10/12/2007 8:27:32 PM Central Daylight Time, azevedoflyer(at)aol.com writes: Aircooled engines complicate things a bit because of the finning which radiate vibration in a very ample spectrum. >>> Based on my meager understanding of knock sensor physics in automotive applications, this was my primary suspicion- how to isolate specific "knock" signatures when you have several hundred fins vibrating in multiple frequencies and harmonics of same. If Lycosaurs were falling from the sky due to detonation at the hands of efficiency-desparate pilots, I'd believe market and/or regulatory pressure would force development of such a system. Perhaps when domestic airplane fuel hits European price$ and truly efficient operation becomes a defining market factor, this technology will develop and we'll have a new paradigm: LOD operation vs. LOP, just like in your average run-of-the-mill ten-year-old Nissan Sentra.... With the astonishing capacity of modern digital processing, I can't understand how an on-board processor couldn't sample vibratation sendor data from multiple points, compare that against know "safe" data, then somehow annunciate a potentially unsafe condition and/or make appropriate adjustments to whatever engine-management scenario a pilot may employ in the ultimate interest of maximizing efficiency. Here's hoping that if observers from the Lycoming/Continental intelligentsia have comments, they'd chime in here, even if covertly. Appreciate the discussion- Mark ________________________________________________________________________________
Date: Oct 15, 2007
Surely ion sensing of detonation as Saab has been doing (with electronic ignition) is cheaper to develop and more precise. Could be it will soon be time to advance into the last century with these engines. Ken Fiveonepw(at)aol.com wrote: > In a message dated 10/12/2007 8:27:32 PM Central Daylight Time, > azevedoflyer(at)aol.com writes: > > Aircooled engines complicate things a bit because of the finning > which radiate vibration in a very ample spectrum. > > >>> > > Based on my meager understanding of knock sensor physics in automotive > applications, this was my primary suspicion- how to isolate specific > "knock" signatures when you have several hundred fins vibrating in > multiple frequencies and harmonics of same. If Lycosaurs were falling > from the sky due to detonation at the hands of efficiency-desparate > pilots, I'd believe market and/or regulatory pressure would force > development of such a system. Perhaps when domestic airplane fuel > hits European price$ and truly efficient operation becomes a defining > market factor, this technology will develop and we'll have a new > paradigm: LOD operation vs. LOP, just like in your average > run-of-the-mill ten-year-old Nissan Sentra.... > > With the astonishing capacity of modern digital processing, I can't > understand how an on-board processor couldn't sample vibratation > sendor data from multiple points, compare that against know "safe" > data, then somehow annunciate a potentially unsafe condition and/or > make appropriate adjustments to whatever engine-management scenario a > pilot may employ in the ultimate interest of maximizing efficiency. > > Here's hoping that if observers from the Lycoming/Continental > intelligentsia have comments, they'd chime in here, even if covertly. > > Appreciate the discussion- > Mark ________________________________________________________________________________
Date: Oct 15, 2007
Wrong. Most aircraft engines being sold today are fuel injected........mechanical, continuous flow. No computer involved, pilot controls the mixture. For computer control, you have to develop a mixture map for each variety of engine. Ain't gonna happen. Not to mention that TCM and Lycoming oppose LOP operations, so they wouldn't design for it. On 10/14/07, David M. wrote: > > > if efficiency were truly a concern, they'd all convert to fuel injection. > If that, then the pilot would have no control over anything except which way > to point -- and would not need it. The computer would control LOP etc. > > David M. > > > ----- Original Message ----- > From: Fiveonepw(at)aol.com > To: engines-list(at)matronics.com > Sent: Sunday, October 14, 2007 10:14 PM > Subject: Re: Engines-List: Knock sensors? > > > In a message dated 10/12/2007 8:27:32 PM Central Daylight Time, > azevedoflyer(at)aol.com writes: > Aircooled engines complicate things a bit because of the finning which > radiate vibration in a very ample spectrum. > >>> > > Based on my meager understanding of knock sensor physics in automotive > applications, this was my primary suspicion- how to isolate specific "knock" > signatures when you have several hundred fins vibrating in multiple > frequencies and harmonics of same. If Lycosaurs were falling from the sky > due to detonation at the hands of efficiency-desparate pilots, I'd believe > market and/or regulatory pressure would force development of such a system. > Perhaps when domestic airplane fuel hits European price$ and truly efficient > operation becomes a defining market factor, this technology will develop and > we'll have a new paradigm: LOD operation vs. LOP, just like in your average > run-of-the-mill ten-year-old Nissan Sentra.... > > With the astonishing capacity of modern digital processing, I can't > understand how an on-board processor couldn't sample vibratation sendor data > from multiple points, compare that against know "safe" data, then somehow > annunciate a potentially unsafe condition and/or make appropriate > adjustments to whatever engine-management scenario a pilot may employ in the > ultimate interest of maximizing efficiency. > > Here's hoping that if observers from the Lycoming/Continental intelligentsia > have comments, they'd chime in here, even if covertly. > > Appreciate the discussion- > Mark > > ________________________________________________________________________________
Date: Oct 15, 2007
speaking only as an outsider there are two things that I see regarding the use of knock sensors. First the engines are basically high volume low compression so they are not overly prone to knocking. Sure it can/does occur but not as often as on higher compression engines. The second point is any knocking would be fairly low in amplitude compared with a higher revving high CR engine. Even so I think it is obvious that a knock sensor can be developed to operate efficiently on these air-cooled engines. I'll bet they could even install knock sensors in the crank shafts that way sensors could do double duty as a form of torque meter as well as knock sensor. Noel -----Original Message----- From: owner-engines-list-server(at)matronics.com [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of Fiveonepw(at)aol.com Sent: Monday, October 15, 2007 12:45 AM Subject: Re: Engines-List: Knock sensors? In a message dated 10/12/2007 8:27:32 PM Central Daylight Time, azevedoflyer(at)aol.com writes: Aircooled engines complicate things a bit because of the finning which radiate vibration in a very ample spectrum. >>> Based on my meager understanding of knock sensor physics in automotive applications, this was my primary suspicion- how to isolate specific "knock" signatures when you have several hundred fins vibrating in multiple frequencies and harmonics of same. If Lycosaurs were falling from the sky due to detonation at the hands of efficiency-desparate pilots, I'd believe market and/or regulatory pressure would force development of such a system. Perhaps when domestic airplane fuel hits European price$ and truly efficient operation becomes a defining market factor, this technology will develop and we'll have a new paradigm: LOD operation vs. LOP, just like in your average run-of-the-mill ten-year-old Nissan Sentra.... With the astonishing capacity of modern digital processing, I can't understand how an on-board processor couldn't sample vibratation sendor data from multiple points, compare that against know "safe" data, then somehow annunciate a potentially unsafe condition and/or make appropriate adjustments to whatever engine-management scenario a pilot may employ in the ultimate interest of maximizing efficiency. Here's hoping that if observers from the Lycoming/Continental intelligentsia have comments, they'd chime in here, even if covertly. Appreciate the discussion- Mark _____ See what's new at AOL.com and Navigator and http://www.matronics.com/Navigator?Engines-List the Web =========== ________________________________________________________________________________
Date: Oct 15, 2007
Miguel, Thought about taking it commercial? Sounds possible. Gary On Oct 14, 2007, at 11:56 PM, Engines-List Digest Server wrote: > > > From: AzevedoFlyer(at)aol.com > Subject: Re: Engines-List: Re: Knock sensors > > Gary, > It translates pressure measured through a modified Pitot Tube into > flow. > Thanks, > Miguel > ________________________________________________________________________________
Date: Oct 15, 2007
I've seen the term LOP used a few times..... But have no idea what it means. Noel > -----Original Message----- > From: owner-engines-list-server(at)matronics.com > [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of > Kelly McMullen > Sent: Monday, October 15, 2007 9:51 AM > To: engines-list(at)matronics.com > Subject: Re: Engines-List: Knock sensors? > > > > > Wrong. Most aircraft engines being sold today are fuel > injected........mechanical, continuous flow. No computer involved, > pilot controls the mixture. For computer control, you have to develop > a mixture map for each variety of engine. Ain't gonna happen. Not to > mention that TCM and Lycoming oppose LOP operations, so they wouldn't > design for it. > ________________________________________________________________________________
Date: Oct 15, 2007
LOP=lean of peak, ROP=rich of peak Regards, Greg Young > -----Original Message----- > From: owner-engines-list-server(at)matronics.com > [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of > Noel Loveys > Sent: Monday, October 15, 2007 8:43 AM > To: engines-list(at)matronics.com > Subject: RE: Engines-List: Knock sensors? > > > > I've seen the term LOP used a few times..... But have no idea > what it means. > > Noel ________________________________________________________________________________
Date: Oct 15, 2007
In a message dated 10/15/2007 8:52:18 AM Central Daylight Time, noelloveys(at)yahoo.ca writes: I've seen the term LOP used a few times..... But have no idea what it means. >>> Normally for injected engines- stands for Lean Of Peak. If using an EGT gauge, leaning the mixture will cause EGTs to rise to a maximum, then begin to fall until there is too little fuel to sustain combustion and the engine will begin to run rough. ROP means Rich Of Peak. Most carbureted engines have less even fuel distribution to each cylinder and the leanest cylinder will begin to mis-fire before an EGT drop is usefully noted. This is a real rough cut on the topic and there is a WHOLE lot more to this- look for articles by John Deakin (sp?) on AvWeb for better info than you found here! Mark ________________________________________________________________________________
Date: Oct 15, 2007
Yes Gary. However, right now I do not have the time! Maybe a few years from now when I retire? FAA people that supervised development is most enthusiastic and want me to proceed to an STC and get it into the marked. From their point of view, safety is greatly enhanced and that is enough incentive for them... Cheers, Miguel ________________________________________________________________________________
Date: Oct 13, 2007
Gary, Baring gross factors like excessively worn groove or mismatched axial clearance between ring and groove, ring flutter results from inertial forces + pressure unbalance between the top face and lower face of the ring. Mostly, it restricts itself to the first compression ring but I've seen the 2nd and occasionally even the 3rd (oil ring) undergoing flutter. For this unbalancing to occur, some gas has to leak into and pressurize the inter ring (1st - 2nd) cavity. Along the expansion stroke, this stagnation pressure becomes higher than the pressure acting over the top of the 1st ring. When this occurs, the 1st ring lifts from its lower face contact with the groove. How flutter progresses from this point onwards can become a very complex process. On the other hand, if you ran an engine without any load on it at high revs, inertia will become predominant and lift the 1st ring, causing flutter. In a plane, such a situation might conceivably occur if you dive with throttle closed and the propeller drives the engine to a sufficiently high revs. Lastly, flutter refers to a rapid oscillation of the ring in the groove. Not to a normal change of lateral face contact of the ring with the groove. This last is usually precluded by either ring geometry (torsion) or by adhesive forces generated by oil surface tension. Cheers, Miguel N8714D PA22/20-150 ________________________________________________________________________________
Date: Oct 16, 2007
Thanks... I had heard of LOP before long enough ago to have completely forgotten. When in technical school we were always told to lean ROP Noel > -----Original Message----- > From: owner-engines-list-server(at)matronics.com > [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of > Greg Young > Sent: Monday, October 15, 2007 7:35 PM > To: engines-list(at)matronics.com > Subject: RE: Engines-List: Knock sensors? > > > > LOP=lean of peak, ROP=rich of peak > > Regards, > Greg Young > > > > -----Original Message----- > > From: owner-engines-list-server(at)matronics.com > > [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of > > Noel Loveys > > Sent: Monday, October 15, 2007 8:43 AM > > To: engines-list(at)matronics.com > > Subject: RE: Engines-List: Knock sensors? > > > > > > > > I've seen the term LOP used a few times..... But have no idea > > what it means. > > > > Noel > > > > > > ________________________________________________________________________________
Date: Oct 16, 2007
From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
LOP is the most efficient place to run the motor. From my reading of the Lycoming power chart it has about a 10% reduction in the BSFC in LOP vs ROP (BSFC =.45 at 50F LOP and .5 at 80F ROP). Rumour has it that the only way the old Howard Hughes Connies made it across the Atlantic was to run the motors LOP. Its about the only place I run my motor apart from take off and landing. Frank RV7a TMX IO360 -----Original Message----- From: owner-engines-list-server(at)matronics.com [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of Noel Loveys Sent: Tuesday, October 16, 2007 7:22 AM Subject: RE: Engines-List: Knock sensors? Thanks... I had heard of LOP before long enough ago to have completely forgotten. When in technical school we were always told to lean ROP Noel ________________________________________________________________________________
Date: Oct 16, 2007
The Wright 3350 engines in Super Connies and also the B-29 were operated LOP. The FE had the most important job on the flight crew. As I remember, The FE also had a set of throttles. Monty Barrett -----Original Message----- From: owner-engines-list-server(at)matronics.com [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of Hinde, Frank George (Corvallis) Sent: Tuesday, October 16, 2007 9:04 AM Subject: RE: Engines-List: Knock sensors? LOP is the most efficient place to run the motor. From my reading of the Lycoming power chart it has about a 10% reduction in the BSFC in LOP vs ROP (BSFC =.45 at 50F LOP and .5 at 80F ROP). Rumour has it that the only way the old Howard Hughes Connies made it across the Atlantic was to run the motors LOP. Its about the only place I run my motor apart from take off and landing. Frank RV7a TMX IO360 -----Original Message----- From: owner-engines-list-server(at)matronics.com [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of Noel Loveys Sent: Tuesday, October 16, 2007 7:22 AM Subject: RE: Engines-List: Knock sensors? Thanks... I had heard of LOP before long enough ago to have completely forgotten. When in technical school we were always told to lean ROP Noel ________________________________________________________________________________
Date: Oct 16, 2007
In many years of aircraft ( and other engines, some of which are very high speed ), I don't think I have ever encountered a positive ring flutter situation. The ring damage I have seen other than excessive groove clearance has been caused by not enough end gap, high power being used before cylinders were up to the proper temperature, ( 300 F ) and detonation. An interesting observation is that a large percentage of new piston rings are NOT FLAT, but have a wavy surface. A couple of manufactures' go to great lengths to insure the surfaces a absolutely flat. They use very sophisticated equipment to inspect for this condition. Pressure is always present behind the rings during the compression, power strokes and even thru the blowdown period of exhaust. Pressure is what makes the ring seal. I agree that the pressure behind the 2nd ring is not as high as the top ring. High engine speed, high forward speed and low manifold pressure is more likely to damage counterweights on the crank; that is the big danger with operating an engine in this manner. Also dangerous is the fact that the cylinder barrel and head will cool at a much faster rate with the above mentioned operating procedure than the piston, which leads to the barrel shrinking down on the piston. I have seen piston top lands with metal " pulled " . This phenomenon is usually referred to as " shock cooling ". The current design piston rings are semi-keystone ( half wedge ) which are designed to move in and out radially so not to " stick " in the groove and to help the ring seal when the cylinder is NOT up to temperature. Older designs were full keystone. Some engines still use full keystone rings. Some piston rings also have an angle cut on the inboard edge to allow some " twisting " of the ring and is used for a couple of purposes; 1. to place a sharp corner of the ring to the barrel face for oil scavenging, 2. to reduce barrel wear because the tension of the ring is somewhat reduced when the ring is " twisted ", 3. to allow the ring to " hydroplane " over an oil film. Plasma filled rings are rarely twisted. In fact, a plasma filled ring should be installed with great care so as NOT to twist the ring. Monty Barrett -----Original Message----- From: owner-engines-list-server(at)matronics.com [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of AzevedoFlyer(at)aol.com Sent: Saturday, October 13, 2007 7:00 PM Subject: Re: Engines-List: Re: Ring flutter? Gary, Baring gross factors like excessively worn groove or mismatched axial clearance between ring and groove, ring flutter results from inertial forces + pressure unbalance between the top face and lower face of the ring. Mostly, it restricts itself to the first compression ring but I've seen the 2nd and occasionally even the 3rd (oil ring) undergoing flutter. For this unbalancing to occur, some gas has to leak into and pressurize the inter ring (1st - 2nd) cavity. Along the expansion stroke, this stagnation pressure becomes higher than the pressure acting over the top of the 1st ring. When this occurs, the 1st ring lifts from its lower face contact with the groove. How flutter progresses from this point onwards can become a very complex process. On the other hand, if you ran an engine without any load on it at high revs, inertia will become predominant and lift the 1st ring, causing flutter. In a plane, such a situation might conceivably occur if you dive with throttle closed and the propeller drives the engine to a sufficiently high revs. Lastly, flutter refers to a rapid oscillation of the ring in the groove. Not to a normal change of lateral face contact of the ring with the groove. This last is usually precluded by either ring geometry (torsion) or by adhesive forces generated by oil surface tension. Cheers, Miguel N8714D PA22/20-150 ________________________________ See ________________________________________________________________________________
Date: Oct 16, 2007
I talked with one of the local pilots who was a flight engineer on the Connies.? They not only operated the engine LOP, they increase the manifold pressure to recover the power lost by operating LOP. As Don described it, the sequence went like this to set the cruise power mixture and power setting.? (They used a power gauge.) When they leveled out at cruise altitude, the power gauge?showed a number with the initially rich mixture setting.? They would calculate?a reduced?power setting?by subtracting 10% or 15% (depending on the supercharger blower being in high or low blower) from the original power setting. They would lean the mixture.? As the mixture is leaned, the power gauge would show an?increase in power, and then show a?decrease in power. When they got to the lower?calculated power setting, they had the mixture set. Now they increased the manifold pressure until they reached the original power setting. Sounds simple.? Just do this smoothly on four engines at the same?time.? :-) For our normally aspirated engines, the capability of obtaining the power recovery isn't there. I suspect the same power reduction and fuel fow reduction could be done running Best Economy and reducing the manifold pressure.? Someone interested in doing a test program? Regards, Jim Ayers -----Original Message----- From: Monty Barrett Sr <MONTY(at)bpaengines.com> Sent: Tue, 16 Oct 2007 8:25 am Subject: RE: Engines-List: Knock sensors? The Wright 3350 engines in Super Connies and also the B-29 were operated LOP. The FE had the most important job on the flight crew. As I remember, The FE also had a set of throttles. Monty Barrett -----Original Message----- From: owner-engines-list-server(at)matronics.com [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of Hinde, Frank George (Corvallis) Sent: Tuesday, October 16, 2007 9:04 AM Subject: RE: Engines-List: Knock sensors? LOP is the most efficient place to run the motor. From my reading of the Lycoming power chart it has about a 10% reduction in the BSFC in LOP vs ROP (BSFC =.45 at 50F LOP and .5 at 80F ROP). Rumour has it that the only way the old Howard Hughes Connies made it across the Atlantic was to run the motors LOP. Its about the only place I run my motor apart from take off and landing. Frank RV7a TMX IO360 -----Original Message----- From: owner-engines-list-server(at)matronics.com [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of Noel Loveys Sent: Tuesday, October 16, 2007 7:22 AM Subject: RE: Engines-List: Knock sensors? Thanks... I had heard of LOP before long enough ago to have completely forgotten. When in technical school we were always told to lean ROP Noel ________________________________________________________________________ Email and AIM finally together. You've gotta check out free AOL Mail! - http://mail.aol.com ________________________________________________________________________________
Subject: ENMA Tigre 125hp .. anyone know of parts source/manuals?
Date: Oct 24, 2007
Hi, I have a biplane with an ENMA Tigre engine, it looks pretty complete except for a plug that goes in to one of the magneto's. Saw someone had made up a gasket set for it, but otherwise have not seen any parts or manuals available. Read that it was built under license from DeHavilland and is about the same as a Gypsy Major. Anyone have any good sources of information. (Other than the Bucker Jungmann sites.. already found those.) Thanks, Jim Read this topic online here: http://forums.matronics.com/viewtopic.php?p=141466#141466 ________________________________________________________________________________
Date: Nov 01, 2007
Subject: November is Matronics Email List Fund Raiser Month!
Dear Listers, You've probably noticed that there are no banner ads or pop-up windows or spam from any of the List and Forum services at Matronics. These include, for example: The Email List Postings - http://www.matronics.com/listbrowse The Email List Forum Site - http://forums.matronics.com The List Wiki - http://wiki.matronics.com The List Search Engine - http://www.matronics.com/search This is because I have always enjoyed a List experience that was completely about the sport we enjoy - airplanes - and not about advertising! But running a high performance, highly available service like this isn't free and a fair amount of money in terms of computer upgrades, business-class Internet connectivity, and electricity. Consequently, many similar sites turn to advertising to support these costs. Advertising that you have to look at each and every time you read an email message or browse the their web site. Rather than subject my List community to another constant commercial bombardment, I have chosen to hold a PBS-like fund raiser each year in November to support the continued operation and upgrade of the List services. It's solely through the Contributions of List members that the Lists and Forums continue to be possible! During the month, I will be sending out a Fund Raiser reminder message every few days and I ask for your patience and understanding during the month throughout these regular messages. Think of them as PBS' Pledge Breaks... :-) To minimize the impact of the Fund Raiser on the List community, I implemented a new feature late last year specifically related to making Contributions. If you are an Email List subscriber, once you make a Contribution using the online web site, you will no longer receive the email from me regarding the Fund Raiser! There are a couple of exceptions to this, however. If someone replies to a Contribution message I've sent, you might receive that. Additionally, the messages will always be posted to the Forums site. To a first order, however, once you make a Contribution, you won't get my email messages about the Fund Raiser for the rest of the month. For Contributions by check, the squelch will take effect once the check is received. There is a whole new line up of really great Contribution gifts this year! When you make a qualifying Contribution, you can select one of the many free gifts that are available during the Fund Raiser. These gifts are provided through the generous support of a number of our industry's leading supporters including: Bob Nuckolls - AeroElectric - http://www.aeroelectric.com Andy Gold - Builder's Bookstore - http://www.buildersbooks.com Jon Croke - HomebuiltHELP - http://www.homebuilthelp.com Please visit these guy's respective sites, as they have some great products to offer and are generously supporting the Matronics List Fund Raiser. You can make your List Contribution using any one of three secure methods this year including using a credit card, PayPal, or by personal check. From the Contribution site, you can select any one of this year's free gifts with a qualifying Contribution amount. The Contribution page is pretty loooonnnnng this year in order to list great selection of great gifts available so be sure to scroll all the way to the bottom of the web page to see everything that's available! Please make a List Support Contribution: http://www.matronics.com/contribution I would like to thank everyone in advance for their generous support! Your Contributions truely keep this operation afloat! Thank you, Matt Dralle Matronics Email List Forum Administrator ________________________________________________________________________________
Date: Nov 04, 2007
Subject: List Fund Raiser
Dear Listers, Just a reminder that November is the Matronics Email List Fund Raiser month. I've got a bunch of really nice incentive gifts this year. There's really something for everyone! Please make a Contribution today: http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 07, 2007
Subject: What Listers Are Saying...
November is Matronics List Fund Raiser month and a number people been sending some really nice comments regarding the Lists. I thought I'd share a few below. The Lists are completely supported by your Contributions. All of the bills for new hardware, connectivity, and electricity are paid by the generous support of the List members. Please make your Contribution today to support the continued operation of the List and Forums: http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List Administrator ================= What Listers Are Saying ================ Flying and building is much safer with this List!! Robert D. Thanks for having and maintaining such a great resource to all of us builders and flyers. Wayne E. Love the fact that you haven't caved to advertising! Peter J. ..a great resource!! Robert C. Not building at the moment, but the Lists keeps me right up to date with what's going on. Chris D. The web forum has been running great. James O. I enjoy this [List] site very much... Paul C. This is a great list! Albert G. ..a valuable resource! Roger C. I am deployed to Pakistan right now, and being able to go on-line and keep up with the aircraft discussions helps keep the aircraft building dream alive in my mind! Gregory C. ..fantastic service! Roger M. ..clearly a work of passion! Mike C. It is a great service to us! Kevin C. The list is a wonderful resource... Ralph O. [The Lists] have been the single greatest resource in building my RV-9A and now my RV-10. Albert G. ..a valuable and always improving service. Dick S. STILL THE BEST BARGAIN AROUND!! Owen B. ..such a valuable tool. Jon M. [The Lists] have been an invaluable resource for me as a Zenith homebuilder. David G. The opportunity to meet (on line at least) many other interesting builders and to make some new friends is truly appreciated. Albert G. ________________________________________________________________________________
Date: Nov 09, 2007
Subject: If You Got This Email, You Haven't Made A Contribution Yet!
:-) Dear Listers, If you received this particular Matronics List Email message, its because you haven't yet made a Contribution to support your Lists! Implemented for the first time last year, the Matronics system selectively sends out the Contribution messages to those that forgot to whip out the 'ol credit card this year to support the continued operation and upgrade of the Matronics Email Lists! Don't you wish PBS worked that way? :-) You heard that right. Once you make your Contribution, these support requests messages during November will suddenly stop coming to your personal email inbox! I wanted to implement something like this for a number of years, but it was always such a daunting task to modify the back-end List processing code, that I just kept putting it off. Finally last year, I just decided to bite the bullet and put the code-pounding time it to make it work. A few days later, bam! A working system! I really do appreciate each and every one of your individual Contributions to support the Lists. It is your support that enables me to upgrade the hardware and software that are required to run a List Site like this. It also goes to pay for the commercial-grade Internet connection and to pay the rather huge electric bill to keep the computer gear running and the air conditioner powered up. I run ALL of the Matronics Email List and Forums sites here locally which allows me to control and monitor every aspect of the system for the utmost in reliably and performance. Your personal Contribution matters because when combined with other Listers such as yourself, it pays the bills to keep this site up and running. I accept exactly ZERO advertising dollars for the Matronics Lists sites. I can't stand the pop-up ads and all other commercialism that is so prevalent on the Internet these days and I particularly don't want to have it on my Email List site. If you appreciate the ad-free, grass-roots, down-home feel of the Matronics Email Lists, please make a Contribution to keep it that way!! http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List Administrator [Please note the following regarding the selective posting system. There are certain circumstances where you might still see a Contribution related message. These situations include if someone replies to one of the messages, or when using the List Browse feature, or when accessing List message via the Forum. Since most of these are anonymous public access methods, there is no simple way to filter them.] ________________________________________________________________________________
From: "Bob & Toodie Marshall" <rtmarshall(at)osbtown.com>
Subject: Lycoming EGT, IO 540
Date: Nov 09, 2007
Hi all, At overhaul I had the cylinders flow balanced, the engine runs very well, very smooth. Considering the rising fuel costs, I have been considering attempting to run the engine LOP, I have been unsuccessful as the richest cylinder peaks last and by then the other cylinders are running rough. I use the AFP fuel injection system which performs flawlessly and have moved nozzles around to effect egt changes which have been effective to a point, where cyl #6 runs 100 degrees cooler than the others. My question? Is 100 degrees a significant number when compared to the other five cylinders?The engine builders out there who are making real HP see the different relationships on cooling effects and cylinder balancing and the induction system. Question #2 does cold air induction help to make the lycoming run more evenly balanced in respect to temps. #3 Is it possible that the stock lycoming intake system generates to much internal turbulence which effects the individual cylinder performance? Thanks for any info and taking the time to answer. Bob ________________________________________________________________________________
Subject: Re: Lycoming EGT, IO 540
Date: Nov 09, 2007
Have you moved the thermocouples around too, to assure that your 100 degree difference isn't due to a thermocouple difference? JimC ----- Original Message ----- From: Bob & Toodie Marshall To: Engines-List Digest Server Sent: Friday, November 09, 2007 12:22 PM Subject: Engines-List: Lycoming EGT, IO 540 My question? Is 100 degrees a significant number when compared to the other five cylinders? ________________________________________________________________________________
Date: Nov 10, 2007
Bob, 100 deg? EGT or CHT? What you are trying to do is to get each cylinder to peak at the same time. What you=92re looking for is the delta between when each cylinder peaks. In a perfect world all the cylinders should peak at the same time at the same temperature. That never happens because of many factors; cooling effect, induction difference, valve opening, ect. It is very common to see on a well setup engine peak deltas around 30~60 deg. between each other. The CHT by itself is for limit purposes and the EGT is to help find when each cylinder peaks. I hope this helps. Mike Larkin -----Original Message----- From: owner-engines-list-server(at)matronics.com [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of jrc Sent: Friday, November 09, 2007 5:09 PM Subject: Re: Engines-List: Lycoming EGT, IO 540 Have you moved the thermocouples around too, to assure that your 100 degree difference isn't due to a thermocouple difference? JimC ----- Original Message ----- From: HYPERLINK "mailto:rtmarshall(at)osbtown.com"Bob & Toodie Marshall Digest Server Sent: Friday, November 09, 2007 12:22 PM Subject: Engines-List: Lycoming EGT, IO 540 My question? Is 100 degrees a significant number when compared to the other five cylinders? "http://www.matronics.com/contribution"http://www.matronics.com/contribu tion "http://www.matronics.com/Navigator?Engines-List"http://www.matronics.co m/Navigator?Engines-List "http://forums.matronics.com"http://forums.matronics.com 10/2/2007 11:10 AM 10/2/2007 11:10 AM ________________________________________________________________________________
Date: Nov 10, 2007
Bob, First, it would be good to know which version of the IO-540 you have since the angle-valve and parallel-valve engines have quite different intake systems. The angle-valve engines have an intake system that is quite good in that the tubes are well matched, have a reasonable tuning benefit and don't absorb too much heat from the oil. The parallel-valve engine, on the other hand, were designed for carburetion and have much of the intake system buried in the oil sump, transferring more heat and limiting the freedom of design. Generally, though, the air distribution of these engines is pretty good. The first thing to do when sorting out air/fuel distribution questions is to measure it using the "lean sweep" method. Starting well rich, record all exhaust temperatures and fuel flow (it's handy to record CHT's and flight data as well, but it is not necessary for good results). Lean the engine a step at a time - the finer the steps the better, although it will start to take too long if done to the extreme. After all cylinders have peaked continue to go lean until you get at least 2 or 3 data points on the lean side of the leanest cylinder. The biggest problem I've had is not waiting long enough for all the variables to stabilize before recording the data. It is good to do the exercise a few times to make detection of bogus data points easier. Plot the temperature of each cylinder against fuel flow all on the same chart. Pick what appears to be the "best fit" straight line on the rich side and another on the lean side, extending them until they cross. That is the fuel flow at which that cylinder peaks. Do not just pick the highest temperature and call that the peak as the temperatures have a tendency to round off near the peak, making the true peak hard to find. Do that for all cylinders and measure the spread of fuel flow between the leanest and richest cylinders. Ideally, it should be less than 2%, but 3 or 4% is probably okay. If the spread is more you should do something about it. An easier way is to ship all the data off to GAMI and they will give you an expert opinion. Back to your questions: 1 - 100 degrees is significant, but there may not be much you can do about it. The thermocouple readings can be affected by cooling air flow on the outside of the pipe as well as orientation of the probe itself. Exhaust flow inside the tube is not uniform around the diameter - all probes should be the same distance down from the cylinder and inserted from the same angle. The temperature of the cylinder itself will affect the measurement. My hottest cylinder also has the highest EGT reading - does one cause the other, or is it coincidence? Hard to say. Why, then would one be different that the other? There are three fundamental factors on EGT - mixture (you're going to take that out of the equation), Compression ratio (all cylinders are the same, right?), and spark timing (hard to imagine the timing for one cylinder being different than the others). That pretty much brings it back to measurement errors unless the exhaust valve is leaking a lot. 2 - The temperature of the inlet air won't have much effect on air/ fuel distribution. It's possible that ram air will have a deleterious effect on smoothness, however. If the manifold pressure at the intake port becomes higher than the upper plenum pressure it's possible that some fuel could come out the air bleed vents, although this usually leaves a tell-tale stain around the injector. I could also make the atomization of the injector suffer and that in turn could create a cycle-to-cycle variation in fuel flow, making the engine feel rough. A good injected engine should be able to be leaned so much that the power is way down and still be running smoothly. Not all are that way. 3. - Intake turbulence itself is probably beneficial to mixing the air and fuel unless one intake runner is different than another. Lycoming engines are typically pretty good in this regard, but again, I have no idea which type you have. Just as an aside, I've messed around trying to figure out the best air/fuel ratio to run. It all depends on the ratio of your desire for speed to the size of your wallet. Speed is good, but fuel flow is bad. As a first shot I used the same equation some people (CAFE, I think) use - multiply mph by mpg. The peak is the optimum place to run if speed is just as important as fuel economy (how do you decide? It's your own choice). This turns out to be TAS^2/GPH. I found the optimum was just lean of peak. Going as far lean as possible didn't help, although usually it didn't make it much worse either. Going rich was like falling off a cliff. Fuel flow goes way up, but air speed doesn't. What you really want to put into the equation is ground speed, so that will change the shape of the curve for every flight. The optimum with a headwind is on the rich side and with a tailwind it is more on the lean side. FWIW, Gary Casey > > From: "Bob & Toodie Marshall" <rtmarshall(at)osbtown.com> > Subject: Engines-List: Lycoming EGT, IO 540 > > Hi all, At overhaul I had the cylinders flow balanced, the engine runs > very well, very smooth. Considering the rising fuel costs, I have been > considering attempting to run the engine LOP, I have been unsuccessful > as the richest cylinder peaks last and by then the other cylinders are > running rough. I use the AFP fuel injection system which performs > flawlessly and have moved nozzles around to effect egt changes which > have been effective to a point, where cyl #6 runs 100 degrees cooler > than the others. My question? Is 100 degrees a significant number when > compared to the other five cylinders?The engine builders out there who > are making real HP see the different relationships on cooling effects > and cylinder balancing and the induction system. Question #2 does > cold > air induction help to make the lycoming run more evenly balanced in > respect to temps. #3 Is it possible that the stock lycoming intake > system generates to much internal turbulence which effects the > individual cylinder performance? Thanks for any info and taking the > time > to answer. Bob ________________________________________________________________________________
Subject: temps
Date: Nov 10, 2007
Hi, all the probes are same distance from flange and close to same clocking. As I see this each cylinder is an engine in itself and the difference in temp is probably from air induction/fuel differences. Maybe Barrett (BPE) Or someone else who does a lot of Dyno work has seen this?thanks for the input. Bob ________________________________________________________________________________
Date: Nov 10, 2007
First read John Deakins series of articles on engine operation on the Avweb.com site. Differences in EGT are likely more to do with temp probe instalation. Your goal is to get all the EGT's to peak(regardless of the temp) at the same throttle position. It one cyl has not peaked and the others are in lean missfire, Your FI may not be flawless. The induction system is well designed. Unless your engine builder left a tool or a rag in there, that is not your problem. Go back and redo the nozzles. DO NOT try to achieve an even temp. Once they all achieve their peak temp at the same throttle position you should be able to get as much as 150 degrees lean of peak before missfire. Bob ----- Original Message ----- From: Bob & Toodie Marshall To: Engines-List Digest Server Sent: Friday, November 09, 2007 10:22 AM Subject: Engines-List: Lycoming EGT, IO 540 Hi all, At overhaul I had the cylinders flow balanced, the engine runs very well, very smooth. Considering the rising fuel costs, I have been considering attempting to run the engine LOP, I have been unsuccessful as the richest cylinder peaks last and by then the other cylinders are running rough. I use the AFP fuel injection system which performs flawlessly and have moved nozzles around to effect egt changes which have been effective to a point, where cyl #6 runs 100 degrees cooler than the others. My question? Is 100 degrees a significant number when compared to the other five cylinders?The engine builders out there who are making real HP see the different relationships on cooling effects and cylinder balancing and the induction system. Question #2 does cold air induction help to make the lycoming run more evenly balanced in respect to temps. #3 Is it possible that the stock lycoming intake system generates to much internal turbulence which effects the individual cylinder performance? Thanks for any info and taking the time to answer. Bob ________________________________________________________________________________
Date: Nov 11, 2007
From: "DEAN PSIROPOULOS" <dean.psiropoulos(at)verizon.net>
Subject: Magneto P-leads
I did a test on my magneto P-leads (one mag on left side, electronic on right side)with an ohm meter. Thinking that when the key switch is in the off position, the resistance across the p-leads should measure close to dead short and, it does. By the same logic, I thought that when the mag was ungrounded the resistance across the p-leads (I used a shielded wire with the shield grounded at the magneto through the key switch, no local grounding). But when I measured across the p-leads at the magneto the resistance only went from 0.2 ohms to 0.4 ohms when I turned the key. Not an appreciable increase in resistance but it was consistent (happens every time) and measurable. I thought maybe I had a faulty key switch but not so, I removed one p-lead from the mag and made the same measurement and the resistance with the key in that mag's position read infinite. I suspect that there is some thing about magnetos I don't know and that this is not a problem but would like to be sure. Anybody ever done this test? Did you get the same results? Thanks. Dean RV-6A N197DM closer to 1st flight. ________________________________________________________________________________
Date: Nov 11, 2007
----- Original Message ----- From: "Gary Casey" <glcasey(at)adelphia.net> Sent: Saturday, November 10, 2007 6:47 AM Subject: Engines-List: Re: Lycoming EGT, IO 540 > questions is to measure it using the "lean sweep" method. Starting well > rich, record all exhaust temperatures and fuel flow (it's handy to record > CHT's and flight data as well, but it is not necessary for good results). > Lean the engine a step at a time - the finer the steps the better, > although it will start to take too long if done to the extreme. After > all cylinders have peaked continue to go lean until you get at least 2 or > 3 data points on the lean side of the leanest cylinder. The biggest > problem I've had is not waiting long It should be the richest cylinder, since it will be the last cylinder to go lean. I have GAMI's on my converted O-360A1A to an EXP IO-360 and find the only time I can't run LOP is at high altitude and hot temperatures. For some reason (even after engine overhaul and new intake tubes), it gets too rough before the richest cylinder is 25F LOP. Wayne ________________________________________________________________________________
Date: Nov 11, 2007
Bob's comment brings up a question I have. I've got a parallel-valve IO-540 with 10:1 compression and electronic ignition on the top plugs, mag on the bottom, timing set at 22. The cylinders are very closely matched for air/fuel, within about 1.5%. When I lean the engine LOP the temperatures drop just a little before it goes rough and sometimes go flat or back up, so I typically operate just barely LOP. I don't have a good explanation for this behavior unless my ram air induction is working so well that the injectors have no air flow in them to atomize the fuel. However, I don't see any fuel stains around the injectors, so there apparently isn't any fuel coming out the vents. There is no way the engine would run 150 LOP as Bob suggests below. Any ideas on why this engine seems to operate different than the norm? Gary Casey > ....Once they all achieve > their peak temp at the same throttle position you should be able to > get > as much as 150 degrees lean of peak before missfire. > > Bob ________________________________________________________________________________
Date: Nov 11, 2007
Subject: Re: Magneto P-leads
Was the P lead connected to the magneto when you measured resistance to ground? If so, and the points were closed, you were measuring resistance of the points. You need the P lead off the mag, or the points open to get a good resistance reading. I've seen a couple instances, (with old P-leads) of the internal insulation cracking and grounding to shield, but not too likely with relatively new wiring. On Nov 11, 2007 12:59 AM, DEAN PSIROPOULOS wrote: > dean.psiropoulos(at)verizon.net> > > > I did a test on my magneto P-leads (one mag on left side, electronic on > right side)with an ohm meter. Thinking that when the key switch is in the > off position, the resistance across the p-leads should measure close to > dead > short and, it does. By the same logic, I thought that when the mag was > ungrounded the resistance across the p-leads (I used a shielded wire with > the shield grounded at the magneto through the key switch, no local > grounding). But when I measured across the p-leads at the magneto the > resistance only went from 0.2 ohms to 0.4 ohms when I turned the key. Not > an appreciable increase in resistance but it was consistent (happens every > time) and measurable. I thought maybe I had a faulty key switch but not > so, > I removed one p-lead from the mag and made the same measurement and the > resistance with the key in that mag's position read infinite. I suspect > that there is some thing about magnetos I don't know and that this is not > a > problem but would like to be sure. Anybody ever done this test? Did you > get > the same results? Thanks. > > Dean > RV-6A N197DM > closer to 1st flight. > > ________________________________________________________________________________
Date: Nov 11, 2007
I run an IO-360 angle valve engine. It will run nicely lean of peak to about 60-70 lean of peak. At that point EGT can start back up or the engine start to quit. You are right...you only need 10-20 LOP if you are running 70% or less power. As your power goes up, you need to be leaner, maybe 30-40 LOP at 75% or higher. Unless you have a turbo, you are unlikely to run much over 85% LOP, so forget about much leaner. The turbo guys will cruise up to 90 LOP on a big Continental. The Lyc turbo 540, at least as used in the Mooney TLS Bravo generally won't run LOP without turbine inlet temps going above redline. It is one of the few engines that simply doesn't like LOP. On Nov 11, 2007 7:02 AM, Gary Casey wrote: > > Bob's comment brings up a question I have. I've got a parallel-valve > IO-540 with 10:1 compression and electronic ignition on the top > plugs, mag on the bottom, timing set at 22. The cylinders are very > closely matched for air/fuel, within about 1.5%. When I lean the > engine LOP the temperatures drop just a little before it goes rough > and sometimes go flat or back up, so I typically operate just barely > LOP. I don't have a good explanation for this behavior unless my > ram air induction is working so well that the injectors have no air > flow in them to atomize the fuel. However, I don't see any fuel > stains around the injectors, so there apparently isn't any fuel > coming out the vents. There is no way the engine would run 150 LOP > as Bob suggests below. Any ideas on why this engine seems to operate > different than the norm? > > Gary Casey > > > ....Once they all achieve > > their peak temp at the same throttle position you should be able to > > get > > as much as 150 degrees lean of peak before missfire. > > > > Bob > > ________________________________________________________________________________
Date: Nov 11, 2007
Gary, One problem I see with your setup is the electronic ignition with a fixed timing mag. I see why you went this way but you should be aware that when both systems fire, the first one is more or less the only one that counts. So in order to get optimum performance you must know exactly when you electronic ignition fires and it must be the same as the mag at cruse and higher power or your working against yourself. In other words for performance a single ignition system. Just a thought, Mike Larkin -----Original Message----- From: owner-engines-list-server(at)matronics.com [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of Gary Casey Sent: Sunday, November 11, 2007 7:03 AM Subject: Engines-List: Re: Lycoming EGT, IO 540 Bob's comment brings up a question I have. I've got a parallel-valve IO-540 with 10:1 compression and electronic ignition on the top plugs, mag on the bottom, timing set at 22. The cylinders are very closely matched for air/fuel, within about 1.5%. When I lean the engine LOP the temperatures drop just a little before it goes rough and sometimes go flat or back up, so I typically operate just barely LOP. I don't have a good explanation for this behavior unless my ram air induction is working so well that the injectors have no air flow in them to atomize the fuel. However, I don't see any fuel stains around the injectors, so there apparently isn't any fuel coming out the vents. There is no way the engine would run 150 LOP as Bob suggests below. Any ideas on why this engine seems to operate different than the norm? Gary Casey > ....Once they all achieve > their peak temp at the same throttle position you should be able to > get > as much as 150 degrees lean of peak before missfire. > > Bob 10/2/2007 11:10 AM 10/2/2007 11:10 AM ________________________________________________________________________________
Subject: 540 EGT
Date: Nov 11, 2007
The EGT questions on my 540 could have many answers and I have now a lot to look at, Since the winters are long here in the high Sierra Nevada mountains this will give me enough info to continue forward. To all the guys who responded, Thank you all very much. Bob ________________________________________________________________________________
Date: Nov 11, 2007
Subject: Post Mortem - Matronics List Pummeled By Spam...
Dear Listers, Over a 3-day period, Thursday 11/8 though Saturday 11/10, the Matronics Lists were pummeled with over 450,000 spam emails causing posting delays and a few duplicate messages. Yeah, I really said nearly half a million spams! The good news is that I don't believe a single one of them actually made it to the Lists thanks to the aggressive List filtering code and the Barracuda spam filter. The bad news was that it caused quite a back log of email messages starting Friday and continuing until late Saturday when I noticed that delivery seemed a bit sluggish. By about 11pm on Saturday night, I had managed to get the backlog cleared out of the spam filter by temporarily adjusting some of the filtering. A check of the queues this morning, and everything looks like its working great and there are no incoming filtering delays and spam levels appear to be back to "normal". There were a number of people asking what was going on, so I thought that I'd send out a follow up post mortem on the event... November is the annual List Fund Raiser. Your contribution directly enables me to buy systems like the Barracuda spam filter that keep the List free of that garbage. Please make a contribution to support your Lists! http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 11, 2007
Gary... What brand of electronic ignition do you have....? I would think the EI wo uld have a lot more advance then the mag at almost any manifold pressure ot her then maybe sea level... Best... Steve > From: glcasey(at)adelphia.net > Subject: Engines-List: Re: Lycoming EGT, IO 540 > Date: Sun, 11 Nov 2007 06:02:45 -0800 > To: engines-list(at)matronics.com > > > Bob's comment brings up a question I have. I've got a parallel-valve > IO-540 with 10:1 compression and electronic ignition on the top > plugs, mag on the bottom, timing set at 22. The cylinders are very > closely matched for air/fuel, within about 1.5%. When I lean the > engine LOP the temperatures drop just a little before it goes rough > and sometimes go flat or back up, so I typically operate just barely > LOP. I don't have a good explanation for this behavior unless my > ram air induction is working so well that the injectors have no air > flow in them to atomize the fuel. However, I don't see any fuel > stains around the injectors, so there apparently isn't any fuel > coming out the vents. There is no way the engine would run 150 LOP > as Bob suggests below. Any ideas on why this engine seems to operate > different than the norm? > > Gary Casey > > > ....Once they all achieve > > their peak temp at the same throttle position you should be able to > > get > > as much as 150 degrees lean of peak before missfire. > > > > Bob > > =========== =========== =========== =========== > > > _________________________________________________________________ Climb to the top of the charts!- Play Star Shuffle:- the word scramble challenge with star power. http://club.live.com/star_shuffle.aspx?icid=starshuffle_wlmailtextlink_oc t ________________________________________________________________________________
Date: Nov 12, 2007
Dean, I'm a little confused about which resistance you are concerned about, but here is what you can expect to measure: If the switch is disconnected from the mag, a reading of the resistance from the P- lead terminal to ground will be either (with the points closed) essentially zero, or (with the points open) almost zero. The circuit inside the mag is from ground through the primary ignition coil winding to the points and back to ground. The P-lead is connected to the connection between the coil and points. If the mag is rotated so the points are closed only the point resistance is in the circuit, which should measure as zero. When the mag is turned so the points are open the only connection to ground is through the coil primary winding, which will measure at something very low, but not zero. It will probably be less than 1 ohm. I use this difference to set the timing, eliminating the need for the "buzz box" that mechanics normally use. You can, if you like, check the connected ignition switch by turning the mag until the points are open (ignition switch has to be in the "on" position to know this) and watching the resistance of the P-lead to ground while turning the switch on and off - there should be a small but noticeable change in resistance. Oh, and when the switch is in the "R" position the right mag is on (switch is open) and the left mag is off (shorted to ground). Hope I didn't confuse things more. Gary > > From: "DEAN PSIROPOULOS" <dean.psiropoulos(at)verizon.net> > Subject: Engines-List: Magneto P-leads > > > I did a test on my magneto P-leads (one mag on left side, > electronic on > right side)with an ohm meter. Thinking that when the key switch is > in the > off position, the resistance across the p-leads should measure > close to dead > short and, it does. By the same logic, I thought that when the mag > was > ungrounded the resistance across the p-leads (I used a shielded > wire with > the shield grounded at the magneto through the key switch, no local > grounding). But when I measured across the p-leads at the magneto the > resistance only went from 0.2 ohms to 0.4 ohms when I turned the > key. Not > an appreciable increase in resistance but it was consistent > (happens every > time) and measurable. I thought maybe I had a faulty key switch but > not so, > I removed one p-lead from the mag and made the same measurement and > the > resistance with the key in that mag's position read infinite. I > suspect > that there is some thing about magnetos I don't know and that this > is not a > problem but would like to be sure. Anybody ever done this test? > Did you get > the same results? Thanks. > > Dean > RV-6A N197DM > closer to 1st flight. ________________________________________________________________________________
Date: Nov 12, 2007
Not at all, The EI's will have both less and more advance depending on manifold pressure. Mags are set at 25deg which is a compromise between poor starting, high power operation and economy cruise. Pretty much all EI's run at about 25 DEG at full power but can advance to 40deg plus at low manifold pressure. I wonder if this engine is truly running balanced...what does "withing 1.5%" mean?....If it means the cylinders flow the same amount of air on the bench then this is meaningless as far as blancing the injectors. Each cylinder needs to get to peak EGT at the same fuel flow (mine is about 0.5GPH between richest and leanest)....Nothing else matters...If the cylinder don't all peak at the same fuel flow (or close to it) the engine will not run LOP very well. I think what we have here is some cylinders running ROP while the others are runnin so LOP that the flame is going out...I.e well LOP. Frank RV7a IO360 ________________________________ From: owner-engines-list-server(at)matronics.com [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of steve korney Sent: Sunday, November 11, 2007 3:49 PM Subject: RE: Engines-List: Re: Lycoming EGT, IO 540 Gary... What brand of electronic ignition do you have....? I would think the EI would have a lot more advance then the mag at almost any manifold pressure other then maybe sea level... Best... Steve > From: glcasey(at)adelphia.net > Subject: Engines-List: Re: Lycoming EGT, IO 540 > Date: Sun, 11 Nov 2007 06:02:45 -0800 > To: engines-list(at)matronics.com > > > Bob's comment brings up a question I have. I've got a parallel-valve > IO-540 with 10:1 compression and electronic ignition on the top > plugs, mag on the bottom, timing set at 22. The cylinders are very > closely matched for air/fuel, within about 1.5%. When I lean the > engine LOP the temperatures drop just a little before it goes rough > and sometimes go flat or back up, so I typically operate just barely > LOP. I don't have a good explanation for this behavior unless my > ram air induction is working so well that the injectors have no air > flow in them to atomize the fuel. However, I don't see any fuel > stains around the injectors, so there apparently isn't any fuel > coming out the vents. There is no way the engine would run 150 LOP > as Bob suggests below. Any ideas on why this engine seems to operate > different than the norm? > > Gary Casey > > > ....Once they all achieve > > their peak temp at the same throttle position you should be able to > > get > > as much as 150 degrees lean of peak before missfire. > > &======================== > > > ________________________________ Climb to the top of the charts! Play Star Shuffle: the word scramble challenge with star power. Play Now! <http://club.live.com/star_shuffle.aspx?icid=starshuffle_wlmailtextlink _ oct> ________________________________________________________________________________
Date: Nov 13, 2007
Subject: List of Contributors
Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its sort of my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take a moment and assure that your name is on that List of Contributors (LOC)? As a number of members have pointed out over the years, the List seems at least - if not a whole lot more - valuable as a building/flying/recreating/entertainment tool as your typical magazine subscription! Please take minute and assure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by popping a personal check in the mail to: Matt Dralle / Matronics PO Box 347 Livermore CA 94551-0347 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 13, 2007
Thanks for the replies. The ignition is the Lightspeed Plasma III, which I'm sure you all know is a capacitive discharge wasted-spark system. The "III" as far as I know is sort of a double polarity system that presumably strikes the arc twice, once in each direction. I'm not a fan of CD systems, but I think they work ok - they're just much more electrically complex than an inductive system. I haven't had any luck extracting the advance curve from Claus and I'm not sure why it seems to be a secret. He sells a monitor system that provides a panel readout of advance, but I don't have that. My timing settings were static. I set the mag (no impulse coupling) at 22 degrees and attempted to set the Lightspeed at about the same value. During runup the rpm drops are about equal, confirming that the Lightspeed timing is about the same as the mag. I had no luck trying to rig a timing light to check the advance. I understand that at rpms below something like 2000 there is no "vacuum" advance in the Lightspeed, so it should be producing a spark at the base timing. I should have done mag checks at altitude, but I haven't. My assumption is that at higher rpm and the low manifold pressures at altitude the Lightspeed provides a more advanced timing. Does anyone have information about the advance characteristics of the Lightspeed unit? The "1.5%" I was talking about is the difference in fuel flow between when the leanest and richest cylinders peak. Frank says that his is within 0.5GPH - assuming the fuel flow of the IO360 is about 10GPH that works out to 5% difference, significantly worse that what my engine data indicates. The 1.5% number I stated actually ranged from 0.8% to 3% depending on which of the 10 or so tests I look at. The standard deviation hangs around 0.7% indicating the data is reasonably well behaved. And, while the cylinders were presumably "ported and flow balanced" I have no idea as to whether the air distribution is precise. However, it is unlikely that the air distribution would be poor AND the injectors mismatched to exactly compensate. Therefore, I am reasonably confident that both air and fuel distribution are very close. My next test will be one to determine if the injector atomization plays a part. I plan to do a lean sweep at full throttle followed by another with the throttle closed enough to reduce the manifold pressure by 1 inch. That should be enough to induce at least some air flow through the injectors. Gary On Nov 12, 2007, at 11:56 PM, Engines-List Digest Server wrote: > > Subject: RE: Engines-List: Re: Lycoming EGT, IO 540 > From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com> > > Not at all, The EI's will have both less and more advance depending on > manifold pressure. Mags are set at 25deg which is a compromise between > poor starting, high power operation and economy cruise. > > Pretty much all EI's run at about 25 DEG at full power but can advance > to 40deg plus at low manifold pressure. > > I wonder if this engine is truly running balanced...what does "withing > 1.5%" mean?....If it means the cylinders flow the same amount of > air on > the bench then this is meaningless as far as blancing the injectors. > > Each cylinder needs to get to peak EGT at the same fuel flow (mine is > about 0.5GPH between richest and leanest)....Nothing else matters...If > the cylinder don't all peak at the same fuel flow (or close to it) the > engine will not run LOP very well. > > I think what we have here is some cylinders running ROP while the > others > are runnin so LOP that the flame is going out...I.e well LOP. > > > Frank RV7a IO360 > ________________________________________________________________________________
Subject: Raven/Suzuki 1300
Date: Nov 13, 2007
Hi, I'm building a CH701 and have WW conversion manual, so I'm eagerly waiting for WWs 701 Corvair project results... but I'm still keeping my eyes open for other possible fits for the 701. Does anyone have anything good or bad to say(with explanations) about the Raven 1300 cc Suzuki engine combo? Kevin Read this topic online here: http://forums.matronics.com/viewtopic.php?p=145835#145835 ________________________________________________________________________________
Subject: Re: Raven/Suzuki 1300
Date: Nov 13, 2007
Hi Kevin, I have a Raven svs1300 redrive Suzuki engine in my CH701. Although I have taxied it, it has not flown. My flight papers should arrive in a couple of days (finally). My first flight will be this weekend. About all that I can tell you now is that it is very smooth running on those engine mounts and with the belt redrive. -- Ray Read this topic online here: http://forums.matronics.com/viewtopic.php?p=145883#145883 ________________________________________________________________________________
Date: Nov 14, 2007
Congrats on the new plane! can't wait to hear from you. -------- Kevin Read this topic online here: http://forums.matronics.com/viewtopic.php?p=145900#145900 ________________________________________________________________________________
From: "Russell Lassetter" <rblassett(at)alltel.net>
Subject: Construction/Restoration
Date: Nov 14, 2007
Hello all, I would like to offer my aircraft construction/restoration services to the group. I have a 40' X 60' hangar in NE Georgia and have a lifetime of experience with various aircraft. I can construct large projects for $15.00 per hour with first-class workmanship. Please email me directly or give me a call. Russ Lassetter 202 Aviation Blvd. Cleveland, GA 30528 706-348-7514 rblassett(at)alltel.net ________________________________________________________________________________
Date: Nov 15, 2007
Subject: Value of the List...
If you look forward to checking your List email everyday (and a lot of you have written to say that you do!), then you're probably getting at least 0 or 0 worth of Entertainment from the Lists each year. You'd pay twice that for a subscription to some lame magazine or even a dinner out. Isn't the List worth at least that much to you? Wouldn't it be great if you could pay that amount and get a well-managed media source free of advertising, SPAM, and viruses? Come to think of it, you do... :-) Won't you please take a minute to make your Contribution today and support the Lists? Contribution Page: http://www.matronics.com/contribution Again, I want to say THANK YOU to everyone that has made a Contribution thus far during this year's List Fund Raiser!! These Lists are made possible exclusively through YOUR generosity!! Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Subject: Re: Value of the List...
Date: Nov 15, 2007
Unscribe ----- Original Message ----- From: "Matt Dralle" <dralle(at)matronics.com> Sent: Thursday, November 15, 2007 2:15 AM Subject: Engines-List: Value of the List... > > If you look forward to checking your List email everyday (and a lot of you > have written to say that you do!), then you're probably getting at least 0 > or 0 worth of Entertainment from the Lists each year. You'd pay twice that > for a subscription to some lame magazine or even a dinner out. Isn't the > List worth at least that much to you? Wouldn't it be great if you could > pay that amount and get a well-managed media source free of advertising, > SPAM, and viruses? Come to think of it, you do... :-) > > Won't you please take a minute to make your Contribution today and support > the Lists? > > Contribution Page: > > http://www.matronics.com/contribution > > Again, I want to say THANK YOU to everyone that has made a Contribution > thus far during this year's List Fund Raiser!! These Lists are made > possible exclusively through YOUR generosity!! > > Thank you for your support! > > Matt Dralle > Email List Admin. > > > ________________________________________________________________________________
Date: Nov 18, 2007
Subject: Please Make a Contribution to Support Your Lists...
Just a reminder that November is the Annual List Fund Raiser. Please make a Contribution today to support the continued operation and upgrade of these great List services!! And pick up a really nice free gift with your qualifying Contribution too! The Contribution Site is fast and easy: http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 20, 2007
Subject: [Please Read] Why I Have A Fund Raiser...
Dear Listers, Each year I like to explain why I have a Fund Raiser and also take the opportunity to express why I think the List Services here provide a superior experience over the commercial equivalents. I use the List Fund Raiser each year to offset the costs involved with running a high performance email list site such as this one. With the annual support from the List members through the PBS-like Fund Raiser, I have found I can run the entire site without having to inflect any of the members with those annoying banner ads flashing up all the time trying to sell little-blue-pills or other garbage nobody wants or needs. From the comments I've received over the years regarding the Lists, the great majority of the members really appreciate the non-commercialism of my List systems and don't mind my 'go-team-go' banter once a year during November to encourage members to support the Lists. I believe that the Lists services that I provide here offer many benefits over the commercial equivalents in a number of ways. The first feature I believe to be significant is that you cannot receive a computer v*rus from any of these Lists directly. Each incoming message is filtered and dangerous attachments stripped off prior to posting. I also provide a Photo and File Share feature that allows members to share files and bitmaps with other members and everyone can be assured that these files will be prescanned for any sort of v*rus before they are posted. More recently, I have enabled limited posting of a number of file formats including pictures and PDFs. Another very important feature of this system in my opinion is the extensive List Archives that are available for download, browsing, and searching. The Archives go all the way back to the very beginning of each List and with the very fast Search Engine, the huge size of some of the Archives is a non-issue in quickly finding the data you're looking for. And added just a couple of years ago is the new Email List Forum that allows members who prefer the Web BBS-style of List interaction. The beauty of the new List Forums is that they contain the exact same content that is distributed via email. Messages posted via email are cross-posted to the respective Forum and vice versa. The Forums also allow for another convenient method of sharing pictures and other files (http://forums.matronics.com ). Additionally, added recently is the List Wiki that allows members to build their own "Online List Encyclopedia" of sorts, documenting various aspects of their project for all to share ( http://wiki.matronics.com ). I've been running email Lists and services under the matronics.com domain since about 1989 starting with RV-List and 30 guys I knew and who where also building RVs. It has grown into nearly 70 different aviation-related Email Lists and an associated web site that receives over 34,000,000 hits each year!! Additionally, the List Email system forwarded well over 77,000 postings last year, accounting for an unbelievable 33,000,000 (yes, that's 33 MILLION) email messages delivered to Matronics List subscribers! I think there's a lot of value in supporting a service that has gone the long haul and is still providing and improving a high quality service all _without any advertising budget_! I have to admit running these Lists is a labor of love and I hope it shows in the quality of the experience that you receive when you get a List Email Message, Search the Archives, use the List Browser, or surf the Forums and Wiki sites. The Lists will be here for a long time to come. If you just want to lurk a while for free, that's great and I encourage you to do so. If you use, appreciate, and receive value from these Lists, then please support them during the Annual List Fund Raiser! List Contribution Web Site: http://www.matronics.com/contribution Thank you, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 22, 2007
Subject: What Are You Thankful For...?
Dear Listers, Here in the United States, Thursday is our National day of Thanksgiving. Many of us will be traveling to be with our families and friends to share in generous feasts of plenty and giving thanks for many blessings that have been bestowed upon us. Many Listers have expressed over the last couple of weeks how thankful they are for the Email Lists and Forums here on the Matronics servers and for all of the assistance and comradery they have experienced being a part of the Lists. One of my favorite kind of comments is when write to me and says something like, "Its the first thing I do in the morning while I'm having my morning coffee!". That's a wonderful tribute to the purpose and function of these Lists. Its always great to hear I'm not the only one that jumps out of bed each morning to check my List email!! Won't you take a minute today and show your appreciation for these Lists and for their continued operation and upgrade? The List Contribution Site is: http://www.matronics.com/contribution Thank you in advance for your kind consideration, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 24, 2007
Subject: Comments
Dear Listers, Below are a few more of the nice comments Listers have been making along with their Contributions in support of the Lists this year. Please make your Contribution today to support the continued operation and upgrade of these services. Remember, there is _no advertising budget_ to keep these Lists funded. It is solely through your generosity that they continue. Please make a Contribution: http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List and Forum Administrator ------------------------------What Listers Are Saying------------------------------ The list has been invaluable in the building of my Zenith CH701. George R Thanks for keeping the lists a non-commercial venue for us to gather and share knowledge. Neal G What a fantastic resource! Ralph C It's a pretty cheep troubleshooting tool with and unlimited resource of personal knowledge. Bruce G A full house of Info & Ideas... Ellery B I really enjoy the Piet list. Steven D The Lists are an indispensable resource for those of us building OBAM aircraft. Bret S ..a great service. Frank D ..all in all it is a great resource if you ask specific questions. Richard S Your list has really helped me in my first build. Michael W Always a pleasure to support this great resource... Richard W I enjoy the lists very much, they are very beneficial. Bob L Great place to chat with other builders and Flyers. Ellery B Your lists are a great service to builders and owners! Richard D A real good place for someone that is starting to get interested into flying without investing any money at first. Ellery B The list has been an great help to my building process. David B I'm close to finishing my Zenith 601 thanks to you and the Zenith List. Jeff D ________________________________________________________________________________
Date: Nov 26, 2007
Subject: Make Sure You're Listed! List of Contributors Published
Dec 1! Dear Listers, The List of Contributors (LOC) is just around the corner! On December 1st I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. As a number of people have pointed out in their Contribution comments, these Lists seems at least as valuable of a building/flying/recreating tool as a typical your magazine subscription! And how interactive is a magazine, after all? Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matronics / Matt Dralle PO Box 347 Livermore CA 94551-0347 USA (Please include your email address on the check!) I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 27, 2007
Subject: [Please Read] What are "The Lists" and Who's This Matt Dralle?
Dear Listers, Who is Matt Dralle and what exactly are these Lists? Well, I've been working in the information technology industry for nearly 25 years primarily in computer networking design and implementation. I have also done extensive work in web development and CGI design during that time, along with some embedded system development as well. I started the Matronics Email Lists back in 1990 with about 30 fellow RV builders from around the world. Since that time, I have added 63 other kinds of aircraft related Lists to the line up and numerous other List related services such as the Forums, Wiki, Archives and Search Engine just to name a few. For flexibility and reliability, I have chosen to run all of my own servers here locally. Other List-related systems include a 1 Gigabit, fully switched network infrastructure, a commercial-grade Netscreen firewall, a Barracuda spam filter, a local T1 Internet router, and a commercial-grade business T1 Internet connection with full static addressing. The computer servers found here include a quad-processor Xeon Linux server for List web services, a dual-processor Xeon Linux system dedicated to the email processing List functions, and another P4 Linux system serving as a remote storage disk farm for the archives, databases, and for an on-line hard drive-based backup system with 3.2 Terra Bytes of storage! This entire system is protected by three large, commercial-grade uninterrupted power supply (UPS) systems that assure the Lists are available even during a local power outage! Speaking of power, imagine how much electricity it takes to run all of these systems. One month last Summer, I had a staggering $1368 bill for electricity alone! I recently upgraded all of the computer racking infrastructure including new power feeds and dedicated air conditioning for the room that serves as the Computer Center for the Matronics Email Lists. Last year I added another rack to house the MONSTER quad-processor web system that didn't quite fit into the first rack! Here's a composite photo of the List Computer Center before the addition of the second rack: http://www.matronics.com/MattDralle-ListComputerCenter.jpg As you can see, I take running these Lists very seriously and I am dedicated to providing an always-on, 24x7x365 experience for each and every Lister. But building and running this system isn't cheap. As I've stated before, I don't support any of these systems with commercial advertising on the Lists. It is supported 100% through List member Contributions! That means you... and you... and YOU! To that end, I hold a List Fund Raiser each November and ask that members make a small Contribution to support the continued operation and upgrade of this ever-expanding system. Its solely YOUR Contributions that keeps it running! Won't you please take a moment to make a Contribution to support these Lists! http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matronics / Matt Dralle PO Box 347 Livermore CA 94551-0347 USA (Please include your email address on the check!) There are some great gifts available with qualifying Contribution levels too! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 28, 2007
Subject: Wow! A Ton of Comments!
Dear Listers, I've been getting a ton of great comments from Listers along with their List Support Contributions lately! I've shared a bunch more below. Please read over some of them and see what your fellow Listers think of the Lists and Forums. There are just a couple more days left before the official end of this year's Fund Raiser. Please make a Contribution today to support the continued upgrade and operation of these services. There are still lots of awesome gifts available, so browse the extensive selection and pickup a nice item along with your qualifying Contribution. http://www.matronics.com/contribution Thank you in advance for your generous support! It is very much appreciated! Best regards, Matt Dralle Matronics Email List Administrator ----------- What Listers Are Saying About The Lists ----------- In the big picture, you are most certainly saving lives. The fact that you do it at a very good level of service, quality, and simplicity is just icing on the cake. We all owe you a debt of gratitude. Bruce M Can't go a single day without reading my lists. Even when I am overseas. Terry W Best list ever. No comparison. Johann J I get the digest for the two lists I subscribe to each morning -- they go great with my coffee! I can't tell you how much I've learned from this great service... Mark S ..great lists, best on the Net! Robert S It is very nice to enjoy a SPAM free list. Ken L You run a great list. Makes a builder feel like there's lots of help out there for the asking, and it's appreciated. Steve T The list is a very valuable resource. Thomas S You run a good list. James G Thanks for a great forum. Jimmy Y Thanks for a well-maintained list(s). Michael M Great job! Worth every penny! Stephen T Helps me learn and think about issues I didn't know I didn't know. Martin H I find the list very useful... Robert F What you do provides me with daily contact with a passion of my life, aviation. Wendell M ..the list it is very valuable information. Dwayne H ..a great service to homebuilders. Andrew H I have learned quite a lot from reading the Forums. I have been reading at the forum pages and I like the way it works. Ron L [The List] makes a builder feel like there's lots of help out there for the asking, and it's appreciated. Steve T The list service many purposes, not the least of which is motivation to join my fellow RVer in completing my project and getting in the air. John S Thanks for running a great site. Its simplicity is its greatness. Don't know how I would have been successful without it. Timothy F ..terrific service to experimental and general aviation. James F You have a well run operation. I am happy to support what you do. Mark S A wonderful service to the GA community. David M Great list - let's keep it ad-free! Ben C They have been of great help, learning and friendship for all the members Worldwide. Great job of yours, a little idea that grew really big and wonderful. Gary G ..a thoroughly enjoyable and informative List. John W A GREAT LEARNING TOOL!! Dwayne Y This is a very well-run list and it is a valuable resource for the Pietenpol enthusiast. Graham H Thanks for running this great site - helps those of us on the east of the pond keep in touch. Malcolm H Thanks for the major contribution to my continuing education program. Oldbob S I'm just getting started in the building process & find Matronics to be the most valuable site. Scott D Without the information and encouragement from the listers my project would have been sitting in the corner of my shop collecting dust long ago. Now it's almost ready for final assemble and covering. Edward G Great List. No Ads, just RV-10 builders. Keep it going. Rick E Wonderful source of info for building & flying... Graham H The Yak-list is a superb single source to get answers to questions on the operation of these aircraft. Craig W This list is valuable to everyone and your hard work is very much appreciated. Jim S ________________________________________________________________________________
Date: Nov 28, 2007
Matt - I don't use your lists because I am not really computer literate an d can't figure out how to simply go to your sites and view the recent posts . I don't want my computer loaded up with posts so I don't get them from y ou any more. If you want to tell me how to sign on and then view posts on your lists (as I can do with the other net) then please advise me how to se t up my computer to do that. If that isn;t possible then you may remove me from all of the lists that I signed up for as I don't use them. Thanks, E d Eliot> Date: Wed, 28 Nov 2007 00:28:39 -0800> To: engines-list@matronics. com> From: dralle(at)matronics.com> Subject: Engines-List: Wow! A Ton of Comme om>> > Dear Listers,> > I've been getting a ton of great comments from List ers along with their List Support Contributions lately! I've shared a bunch more below. Please read over some of them and see what your fellow Listers think of the Lists and Forums.> > There are just a couple more days left b efore the official end of this year's Fund Raiser. Please make a Contributi on today to support the continued upgrade and operation of these services.> > There are still lots of awesome gifts available, so browse the extensive selection and pickup a nice item along with your qualifying Contribution.> > http://www.matronics.com/contribution> > Thank you in advance for your g enerous support! It is very much appreciated!> > Best regards,> > Matt Dral le> Matronics Email List Administrator> > > ----------- What Listers Are Sa ying About The Lists -----------> > In the big picture, you are most certai nly saving lives. > The fact that you do it at a very good level of service , > quality, and simplicity is just icing on the cake. We > all owe you a d ebt of gratitude.> Bruce M> > Can't go a single day without reading my list s. Even > when I am overseas.> Terry W> > Best list ever. No comparison.> J ohann J> > I get the digest for the two lists I subscribe to each > morning -- they go great with my coffee! I can't tell > you how much I've learned from this great service... > > Mark S> > ..great lists, best on the Net!> R obert S> > It is very nice to enjoy a SPAM free list.> Ken L> > You run a g reat list. Makes a builder feel like there's > lots of help out there for t he asking, and it's > appreciated.> Steve T> > The list is a very valuable resource.> Thomas S> > You run a good list.> James G> > Thanks for a great forum.> Jimmy Y> > Thanks for a well-maintained list(s).> Michael M> > Grea t job! Worth every penny!> Stephen T> > Helps me learn and think about issu es I didn't know I> didn't know.> Martin H> > I find the list very useful.. .> Robert F> > What you do provides me with daily contact with a passion > of my life, aviation.> Wendell M> > ..the list it is very valuable informat ion.> Dwayne H> > ..a great service to homebuilders.> Andrew H> > I have le arned quite a lot from reading the Forums. I > have been reading at the for um pages and I like the way > it works.> Ron L> > [The List] makes a builde r feel like there's lots of > help out there for the asking, and it's appre ciated.> > Steve T> > The list service many purposes, not the least of whic h is > motivation to join my fellow RVer in completing my project > and get ting in the air.> John S> > Thanks for running a great site. Its simplicity is its> greatness. Don't know how I would have been successful> without it .> Timothy F> > ..terrific service to experimental and general aviation.> > James F> > You have a well run operation. I am happy to support what> you do. > Mark S> > A wonderful service to the GA community.> David M> > Great list - let's keep it ad-free!> Ben C> > They have been of great help, learn ing and friendship > for all the members Worldwide. Great job of yours, a > little idea that grew really big and wonderful.> > Gary G> > ..a thoroughl y enjoyable and informative List.> > John W> > A GREAT LEARNING TOOL!!> Dwa yne Y> > This is a very well-run list and it is a valuable resource> for th e Pietenpol enthusiast.> Graham H> > Thanks for running this great site - h elps those of> us on the east of the pond keep in touch.> Malcolm H> > Than ks for the major contribution to my continuing> education program.> Oldbob S> > I'm just getting started in the building process & find> Matronics to be the most valuable site.> Scott D> > Without the information and encourag ement from the listers > my project would have been sitting in the corner o f my shop > collecting dust long ago. Now it's almost ready for final > ass emble and covering.> Edward G> > Great List. No Ads, just RV-10 builders. K eep it> going.> Rick E> > Wonderful source of info for building & flying... > > Graham H> > The Yak-list is a superb single source to get answers to> q uestions on the operation of these aircraft.> Craig W> > This list is valua ble to everyone and your hard work is > very much appreciated.> Jim S> > > ==> > > _________________________________________________________________ Share life as it happens with the new Windows Live.Download today it's FREE ! http://www.windowslive.com/share.html?ocid=TXT_TAGLM_Wave2_sharelife_1120 07 ________________________________________________________________________________
Date: Nov 29, 2007
Subject: Just Two Days Left...
Dear Listers, There are just a couple days left for this year's List Fund Raiser. Over all, participation has been good, but things have been pretty slow this week for some reason. If you've been putting off making your Contribution until the last minute, this is it! The last minute, that is... :-) Please remember that there isn't any sort of commercial advertising on the Lists and the *only* means of keeping these Lists running is through your Contributions during this Fund Raiser. Please make a Contribution today! http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 30, 2007
Subject: [Please Read] - Last Official Day of List Fund Raiser!
Dear Listers, Its November 30th and that means a couple of things. Its my 44th birthday for one, but I'm trying to forget about that... But, it also means that its that last official day of the Matronics Email List Fund Raiser! If you been drooling over one of the really sweet free gifts that are available this year with a qualifying Contribution, then now is the time to jump on one!! If you've been meaning to make a Contribution, but just keep putting it off, then now is the time! I will be posting the List of Contributors in a few days, so you'll probably want to be known as a person that supported the Lists! Rather than the guy that, er, ah, forgot (or whatever)... :-) I want to thank everyone that has so generously made a Contribution so far this year in support of our Lists. It is your generosity that keeps this operation a float and I don't ever forget it. Hopefully everyone will feel the same. The List Contribution page is fast and easy. Please support our habit by making your Contribution right now: http://www.matronics.com/contribution Thank you all in advance! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Dec 05, 2007
Ray, Can you give us an idea of how LOUD that Suzuki/Raven is as a combination? Can you sit in the cockpit without headphones? Do headphones do a good job of making things quiet and comfortable? Thanks, Mike Read this topic online here: http://forums.matronics.com/viewtopic.php?p=150640#150640 ________________________________________________________________________________
Date: Dec 05, 2007
Sorry Mike, never flown that engine personally. It would of course depend on what plane too. As for me, I would not pilot any plane without my headphones. I just like things a quiet as possible and I like in-flight music. Tracy On Dec 5, 2007 4:10 PM, mikef wrote: > > Ray, > > Can you give us an idea of how LOUD that Suzuki/Raven is as a combination? > Can you sit in the cockpit without headphones? Do headphones do a good > job of making things quiet and comfortable? > > Thanks, > > Mike > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=150640#150640 > > ________________________________________________________________________________
Date: Dec 06, 2007
Subject: Matronics List Fund Raiser - 2007 List of Contributors
Dear Listers, I would like to thank everyone that made a Contribution in support of the Lists this year! It was really nice to hear all great comments people had regarding the Lists! As I have said many times before, running these Lists is a labor of love. Your generosity during the List Fund Raiser underscores the great sentiments people have made regarding the Lists. If you haven't yet made a Contribution in support of this year's Fund Raiser please feel free to do so. The great List Fund Raiser gifts will be available on the Contribution site for just a little while longer, so hurry and make your Contribution and get your great gift! Once again, the URL for the Contribution web site is: http://www.matronics.com/contribution I would like to thank Andy Gold of the Builder's Bookstore ( http://www.buildersbooks.com ), Jon Croke of Homebuilt HELP ( http://www.homebuilthelp.com ) and Bob Nuckolls of AeroElectric ( http://www.aeroelectric.com ) for their extremely generous support during this year's Fund Raiser through the contribution of discounted merchandise. These are great guys that support the aviation industry and I encourage each and every Lister to have a look at their products. Thank you Andy, Jon and Bob!! Your support is very much appreciated! And finally, below you will find a web link to the 2007 List of Contributors current as of 12/6/07! Have a look at this list of names as these are the people that make all of these List services possible! I can't thank each of you enough for your support and great feedback during this year's Fund Raiser! THANK YOU! http://www.matronics.com/loc/2007.html I will be shipping out all of the gifts in the next few weeks and hope to have everything out by the end of the month. In most cases, gifts will be shipped via US Postal Service. Once again, thank you for making this year's List Fund Raiser successful! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
From: "jkrowe.1(at)netzero.net" <jkrowe.1(at)netzero.net>
Date: Dec 09, 2007
Subject: E-Mag & P-Mag Reliability
I am about ready to order my engine and considering using an E-mag and P -mag instead of slick mags. I was wanting to see if anybody has comment s about how they like them and if they have had any problems. I talked to someone this weekend and they said they heard that they have had some bugs and concerned about the reliability. I would aprreciate any input . Thanks, Jason _____________________________________________________________ Security Camera for your small business. Click Now! http://thirdpartyoffers.netzero.net/TGL2221/fc/Ioyw6i4tTgAVvLfYvFW35tkhL xc9kWhjAMPFvCWUkH8CPM47WjESEZ/ ________________________________________________________________________________
Subject: Subaru
Date: Dec 29, 2007
I just got a call from an old flying buddy. We were on the same squadron in 1965. His son is parting a Subaru and wonders if someone wants the engine - good shape for what it's worth. Unfamiliar with the endeavour, so not sure if these are rebuilt for homebuilt aircraft. Would that mean anything to people? Otherwise it's into the dump. Season's compliments, Ferg Kyle, Europa monowheel VE3LVO(at)rac.ca ________________________________________________________________________________
Subject: Re: Subaru
Date: Dec 29, 2007
Some people are. There is even a Yahoo group about it. Where is the engine? What condition? Are all the computers, wiring harnesses and etc available? David ----- Original Message ----- From: "Fergus Kyle" <VE3LVO(at)rac.ca> Sent: Saturday, December 29, 2007 10:58 AM Subject: Engines-List: Subaru > > I just got a call from an old flying buddy. We were on the same squadron in > 1965. His son is parting a Subaru and wonders if someone wants the engine - > good shape for what it's worth. Unfamiliar with the endeavour, so not sure > if these are rebuilt for homebuilt aircraft. > Would that mean anything to people? Otherwise it's into the dump. > Season's compliments, > Ferg Kyle, Europa monowheel > VE3LVO(at)rac.ca > > > -- 12/28/2007 11:51 AM > > ________________________________________________________________________________
Subject: Ford Model A aero mod?
Date: Jan 04, 2008
Hi, I am working on a Pietenpol Aircamper and in my search for Ford Model A motor to power it with I came across sort of a strange motor. It is an air/oil cooled Model A conversion. I got a copy of an old article from a guy that was published back in the 1960's and, based on pictures in the article, it looks like this motor might be a Claude Sessions conversion from the 1930's. Claude Sessions, who was from Illinois, turned the modification over to Lightening Aircraft Motor Company of St. Paul, MN. They then passed it on to Universal Aircraft of Ft. Worth, TX. That seems to be the only trace of history I can find on this thing. Anyone out there ever hear of anything like this? I'm interested in the history of the motor and what it was used on and if this was a successful engine or a flop. Thanks, Matt Read this topic online here: http://forums.matronics.com/viewtopic.php?p=155989#155989 ________________________________________________________________________________
From: "Richard & Martha Neilsen" <NeilsenRM(at)comcast.net>
Subject: Re: Ford Model A aero mod?
Date: Jan 05, 2008
Matt This will seem like it coming from left field but might you consider a redrive VW as a engine for your Pietenpol? My understanding is that the Pietenpol is the ultimate experimental. It has had any number of engines with low cost being the general theme. I have a friend that has a continental powered Pietenpol and is helping another friend finish a Ford powered Pietenpol. We have discussed the redrive VW and it looks like a good match for the plane. It might be a bit overpowered and light but that isn't usually a problem in aviation. I have a Kolb MKIIIC with a Redrive VW and it is a wonderful low-cost power plant. There are a bunch of WWI replica airplanes that are using the redrive VWs and they have been very happy with the cost, power and reliability. Just thought you might find this interesting. Rick Neilsen ----- Original Message ----- From: "MF" <ferrari(at)lakenet.com> Sent: Friday, January 04, 2008 3:16 PM Subject: Engines-List: Ford Model A aero mod? > > Hi, > I am working on a Pietenpol Aircamper and in my search for Ford Model A > motor to power it with I came across sort of a strange motor. It is an > air/oil cooled Model A conversion. I got a copy of an old article from a > guy that was published back in the 1960's and, based on pictures in the > article, it looks like this motor might be a Claude Sessions conversion > from the 1930's. Claude Sessions, who was from Illinois, turned the > modification over to Lightening Aircraft Motor Company of St. Paul, MN. > They then passed it on to Universal Aircraft of Ft. Worth, TX. That seems > to be the only trace of history I can find on this thing. > Anyone out there ever hear of anything like this? > I'm interested in the history of the motor and what it was used on and if > this was a successful engine or a flop. > > Thanks, > > Matt > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=155989#155989 > > > ________________________________________________________________________________
Date: Jan 05, 2008
A VW won't be overpowered on a Pietenpol :-) JimC ----- Original Message ----- From: "Richard & Martha Neilsen" <NeilsenRM(at)comcast.net> Sent: Saturday, January 05, 2008 11:48 AM Subject: Re: Engines-List: Ford Model A aero mod? > It might be a bit overpowered and light but that isn't > usually a problem in aviation. ________________________________________________________________________________
Date: Jan 05, 2008
I know several guys who have flown or will fly a Pietenpol with a Corvair. Seems to work great! Dan jrc wrote: > > A VW won't be overpowered on a Pietenpol :-) > JimC > > ----- Original Message ----- From: "Richard & Martha Neilsen" > > To: > Sent: Saturday, January 05, 2008 11:48 AM > Subject: Re: Engines-List: Ford Model A aero mod? > > >> It might be a bit overpowered and light but that isn't usually a >> problem in aviation. > > > > > > ________________________________________________________________________________
Date: Jan 08, 2008
Thanks to all for your replies. I have had a couple of Ford guys contact me off the forum. I have some info on the way regarding this type of conversion and if I learn anything good I'll post it here. I'm pretty sure I want to go with the Ford. I saw a Ford powered Piet years ago and filed that away in the gotta-have-one-someday box. The motor I picked up is interesting from a historical and mechanical perspective but I intend to go with the more traditional Ford conversion. I think I'll go through this air/oil cooled motor to see what makes it go, but I don't think I'll fly it. If any of you think of anything else, I'm all ears. Thanks again! Matt Read this topic online here: http://forums.matronics.com/viewtopic.php?p=156830#156830 ________________________________________________________________________________
Date: Jan 29, 2008
Ray, Does Raven supply the motor mount for the 701 or did you have to fabricate you own? What cowl are you using? Bryan Ekholm -------- Bryan Ekholm Read this topic online here: http://forums.matronics.com/viewtopic.php?p=161055#161055 ________________________________________________________________________________
Date: Jan 29, 2008
Raven has engine mounts available. -------- Kevin N701DZ Reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=161213#161213 ________________________________________________________________________________
Date: Feb 03, 2008
Subject: Homebrew Injection Systems, Steep Approaches
Hi alternate engine aficiondos, Thanks for recommending some interesting web sites.  There is no shortage of ideas out there.  I will be using a homebrew, constant flow injection system with no electronics. The core idea came from the book "Jungle Pilot" by Nate Saint. Three power settings will do the job --- takeoff, cruise, and approach. A blip-switch on the stick will enable zero thrust operations.  A light wooden propeller on a high compression engine will quit turning if the pilot slows it too much.  Mustn't let that happen. A little open cockpit parasol monoplane (Pietenpol) peels off into a steep slip to clear the tall spruce trees guarding a river gravel bar where the king salmon run.  Brppp, brppp, brppp sounds are trumpeting from the short Allison style stacks.  How cool is that?  Not much vertical surface aft of the aerodynamic center, large control surfaces, ignition interrupt to zero thrust -- the Piet can descend fast enough to get in plenty of trouble...don't let it bite you. Happy landings, Mike Fisher Talkeetna, Alaska Subject: Re: Pietenpol-List: Steep Approaches, Homebrew Injection Got any more details on that injection system? Sounds intriguing. Hi alternate engine aficionados, The injection system is only a concept at this point. Throttle body injection or carburetor results in wet manifold.  Intake port, multi-point injection keeps the manifold dry. --- Huge difference in Cyl. to Cyl. charge balance and icing resistance -- greatly favors dry manifold.  There is no need for sequential port injection at power settings much above an idle.   Many have adapted a carburetor to engines designed for injection.  This works better on systems that were originally throttle body.   I will be working on the 1.9L inverted Ford constant-flow, multi-point system whenever I get the dry sump oiling system operational. Mike Fisher ________________________________________________________________________________
Subject: Coolant temp on a 914
Date: Feb 27, 2008
Good-day, In my writhing to complete the wiring for this project, I dimly recall the need to add a coolant temp sensor and indicator to the stack - and that someone had volunteered a source for same. I believe the sensor lay in one of the coolant lines but not sure where. I am begging for info on this topic (as I have for many before it) and would appreciate any reply. Cheers, Ferg PS: Am wiring in a Dynon EMS-D10 screen. ________________________________________________________________________________
Date: Feb 28, 2008
Subject: Re: Engines-List Digest: 1 Msgs - 02/27/08
I don't have an answer to your question but I might be able to steer you to a place that does. Go to the "Zenith-List" on Matronics here. That sight is VERY active. I'm new so I have been monitoring this sight also. Your post on here is the first one I've seen in two months of watching. Hopefully, the nice people over on Zenith will be more than willing to share any ideas and answers they might have. Hope this helps you out. Larry H Engines-List Digest Server wrote: * ================================================= Online Versions of Today's List Digest Archive ================================================= Today's complete Engines-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the Engines-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 08-02-27&Archive=Engines Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 08-02-27&Archive=Engines =============================================== EMail Version of Today's List Digest Archive =============================================== ---------------------------------------------------------- Engines-List Digest Archive --- Total Messages Posted Wed 02/27/08: 1 ---------------------------------------------------------- Today's Message Index: ---------------------- 1. 12:26 PM - Coolant temp on a 914 (Fergus Kyle) ________________________________ Message 1 _____________________________________ From: "Fergus Kyle" Subject: Engines-List: Coolant temp on a 914 Good-day, In my writhing to complete the wiring for this project, I dimly recall the need to add a coolant temp sensor and indicator to the stack - and that someone had volunteered a source for same. I believe the sensor lay in one of the coolant lines but not sure where. I am begging for info on this topic (as I have for many before it) and would appreciate any reply. Cheers, Ferg PS: Am wiring in a Dynon EMS-D10 screen. --------------------------------- Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. ________________________________________________________________________________
Subject: Needley engine
Date: Mar 05, 2008
Does anyone know anything about this engine? http://www.needleyengines.com The engine on the site is 52 hp and 105ft-lbs @ 2750 and 2550rpm. But they state that they are working on a 4 cylinder 80 hp version. Since its a low rpm engine the torque should be high enough to look into for a 701. My question comes about, be cause the site was last updated in 2005 ,they don't answer the phone and their email bounces. Google searches barley bring up anything. I know it sound like belly up to me too, but its interesting enough to ask around. Thanks Kevin -------- Kevin N701DZ Reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=167778#167778 ________________________________________________________________________________
Date: Mar 29, 2008
Subject: Two New Lists Added to the Matronics Lineup!
Dear Listers, I've added two new Email Lists to the Matronics List and Forum lineup today. These include the Rans-List and RV12-List. Please surf over to the Matronics List Subscription page and sign up for these new Lists if they are of interest to you: http://www.matronics.com/subscribe Full support on the Forums, List Browse, Archives, etc. is available. Rans-List: http://www.matronics.com/Navigator?Rans-List RV12-List http://www.matronics.com/Navigator?RV12-List Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
From: "Mike Schuler" <mike.schuler(at)sympatico.ca>
Subject: Engine mounts
Date: Apr 26, 2008
Is there any advantage using one type of dynafocal ring over another? I plan to install an IO-360 into a Falco. Thanks, Mike Schuler ________________________________________________________________________________
Date: Apr 26, 2008
Subject: Re: Engine mounts
Mike Schuler wrote: > > Is there any advantage using one type of dynafocal ring over another? > > I plan to install an IO-360 into a Falco. > > Thanks, > > Mike Schuler > Not sure what you're asking. The ring has to fit the engine. Type 1 is by far the most common; type 2 was used on a few twins that had extended hub props to streamline the engine nacelles better. The difference is the point within the engine where the angles of the mounting bolts converge to a point. It's supposed to be at the cg of the engine/prop assembly. The 'ears' on the engine are cut differently for the type 1 & type 2 mounts. If you're buying a used engine, you *might* stumble upon an engine that came off a twin with type 2 ears, but they are relatively rare. If you're buying new, you'd probably have to beg to get one. As an example of how rare they are, Van's A/C no longer supplies type 2 mounts for their kits, & they probably sell more Lyc powered kits than all the other kit makers combined. Does that help? Charlie ________________________________________________________________________________
Date: Apr 26, 2008
Subject: Four New Email Lists At Matronics!!
Dear Listers, I have added four new Lists to the Matronics line up today. These include the following categories: Citabria-List Citabria, Decathlon, Scout, and Champ Zenith601-List Zenair Zodiac CH 601 Zenith640-List Zenair Zodiac CH 640 Zenith701801-List Zenair STOL CH 701 and CH 801 All services are enabled and now available including Search, Browse, Digest, Archives, Forums, Chat, etc., etc. etc...: Citabria: http://www.matronics.com/navigator?citabria-list Zenith601: http://www.matronics.com/navigator?zenith601-list Zenith640: http://www.matronics.com/navigator?zenith640-list Zenith701801: http://www.matronics.com/navigator?zenith701801-list To subscribe, go to the Matronics Email List Subscription Form: http://www.matronics.com/subscribe To check the new Lists out on the Matronics Forum go here: http://forums.matronics.com Enjoy the new Lists!! Don't forget me during the Fund Raiser! :-) Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: crooks at Performance Engines
Date: Apr 30, 2008
Well, it's time I go public. Ron Munson / Performance Engines has owed me and promised to pay me back my $20,000 deposit for over two years now. I read Matt Throckmorton's account of his dealings with Mike Moore and mine is a very similar story. Bottom line here, no matter how you slice it Ron Munson is a liar and a cheat and should be in jail; let alone receive any orders from any of us or anyone else. His "salesman" Stuart Featherstone falls into the same category. I've tried being nice talking with him, I've had an attorney send nice letters, I've had an attorney send threatening letters, I've had a collections agency work to get my money back. So far, no joy. Apparently Ron Munson has moved his banking to Nevada while maintaining operations in California; making it more difficult and expensive to go after him. Anyone with any ideas on what to do with this crook ?? I have no intention of letting this go J. _________________ Larry E. James Bellevue, WA Super Decathlon Rocket (under construction) ________________________________________________________________________________
Subject: Re: crooks at Performance Engines
Date: Apr 30, 2008
hire Uncle Guido. you'll get something back, anyway. David M. ----- Original Message ----- From: Larry James To: rv-list(at)matronics.com ; rocket-list(at)matronics.com ; engines-list(at)matronics.com ; lancair-list(at)matronics.com Sent: Wednesday, April 30, 2008 4:34 PM Subject: Engines-List: crooks at Performance Engines Well, it's time I go public. Ron Munson / Performance Engines has owed me and promised to pay me back my $20,000 deposit for over two years now. I read Matt Throckmorton's account of his dealings with Mike Moore and mine is a very similar story. Bottom line here, no matter how you slice it Ron Munson is a liar and a cheat and should be in jail; let alone receive any orders from any of us or anyone else. His "salesman" Stuart Featherstone falls into the same category. I've tried being nice talking with him, I've had an attorney send nice letters, I've had an attorney send threatening letters, I've had a collections agency work to get my money back. So far, no joy. Apparently Ron Munson has moved his banking to Nevada while maintaining operations in California; making it more difficult and expensive to go after him. Anyone with any ideas on what to do with this crook ?? I have no intention of letting this go J. _________________ Larry E. James Bellevue, WA Super Decathlon Rocket (under construction) ------------------------------------------------------------------------- ----- Checked by AVG. 4/29/2008 6:27 PM ________________________________________________________________________________
Date: Apr 30, 2008
Larry, Man! I know your pain. Not with that slime ball but with a carbon canopy rip off for a RV. Contact the better business bureau. Contact the sherrifs dept. (where you live and where he lives )file a robbery/theft report. If this happened over the internet contact the FBI. Raise hell. Get his phone number and publish it. Find out if there are others like you. Gang up on him. Hammer away and keep hammering, make his life a living hell. Grab ahold of him and shake until you get your money back. Never, ever, never, ever quit. I did all of the above and more and finally got a refund, which was probably some other poor suckers money but... Mike ----- Original Message ----- From: Larry James <larry(at)ncproto.com> Date: Wednesday, April 30, 2008 1:37 pm Subject: Engines-List: crooks at Performance Engines > Well, it's time I go public. Ron Munson / Performance Engines has > owed me > and promised to pay me back my $20,000 deposit for over two years > now. I > read Matt Throckmorton's account of his dealings with Mike Moore > and mine is > a very similar story. Bottom line here, no matter how you slice it Ron > Munson is a liar and a cheat and should be in jail; let alone > receive any > orders from any of us or anyone else. His "salesman" Stuart > Featherstonefalls into the same category. I've tried being nice > talking with him, I've > had an attorney send nice letters, I've had an attorney send > threateningletters, I've had a collections agency work to get my > money back. So far, no > joy. Apparently Ron Munson has moved his banking to Nevada while > maintaining operations in California; making it more difficult and > expensiveto go after him. Anyone with any ideas on what to do with > this crook ?? I > have no intention of letting this go J. > _________________ > Larry E. James > Bellevue, WA > Super Decathlon > Rocket (under construction) > > ________________________________________________________________________________
From: "Southern Reflections" <purplemoon99(at)bellsouth.net>
Date: Apr 30, 2008
Put a add on barnstormers,under light sport and expermental.... ,that good for openers,but most of all NEVER let the a-hole up !!! get your money back .Barnstormers.com Joe N101HD 601XL/RAM ----- Original Message ----- From: Michael Ice To: engines-list(at)matronics.com Sent: Wednesday, April 30, 2008 7:35 PM Subject: Re: Engines-List: crooks at Performance Engines Larry, Man! I know your pain. Not with that slime ball but with a carbon canopy rip off for a RV. Contact the better business bureau. Contact the sherrifs dept. (where you live and where he lives )file a robbery/theft report. If this happened over the internet contact the FBI. Raise hell. Get his phone number and publish it. Find out if there are others like you. Gang up on him. Hammer away and keep hammering, make his life a living hell. Grab ahold of him and shake until you get your money back. Never, ever, never, ever quit. I did all of the above and more and finally got a refund, which was probably some other poor suckers money but... Mike ----- Original Message ----- From: Larry James <larry(at)ncproto.com> Date: Wednesday, April 30, 2008 1:37 pm Subject: Engines-List: crooks at Performance Engines To: rv-list(at)matronics.com, rocket-list(at)matronics.com, engines-list(at)matronics.com, lancair-list(at)matronics.com > Well, it's time I go public. Ron Munson / Performance Engines has > owed me > and promised to pay me back my $20,000 deposit for over two years > now. I > read Matt Throckmorton's account of his dealings with Mike Moore > and mine is > a very similar story. Bottom line here, no matter how you slice it Ron > Munson is a liar and a cheat and should be in jail; let alone > receive any > orders from any of us or anyone else. His "salesman" Stuart > Featherstonefalls into the same category. I've tried being nice > talking with him, I've > had an attorney send nice letters, I've had an attorney send > threateningletters, I've had a collections agency work to get my > money back. So far, no > joy. Apparently Ron Munson has moved his banking to Nevada while > maintaining operations in California; making it more difficult and > expensiveto go after him. Anyone with any ideas on what to do with > this crook ?? I > have no intention of letting this go J. > _________________ > Larry E. James > Bellevue, WA > Super Decathlon > Rocket (under construction) > > ________________________________________________________________________________
Date: Apr 30, 2008
Is this the company? NO ARCHIVE Joe Motis Contact Performance Engines Inc. 1935 McKinley Ave Ste C La Verne, CA 91750 Phone (909) 593-5008 Fax (909) 593-3774 e-mail _info(at)PerformanceEngines.com_ (mailto:info(at)PerformanceEngines.com) Customer Support We are experiencing an overwhelming amount of phone calls and questions. Your business is very important to us and in the interest of serving you better and answering your questions regarding delivery dates, special requests and scheduleing in a precise and timely manner, we ask that you send your questions in an e-mail to _info(at)PerformanceEngines.com_ (mailto:info(at)PerformanceEngines.com) . We promise to respond to all inquiries within 24 hours. Thank you for your understanding, Stuart Featherstone, Sales Manager **************Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos. (http://autos.aol.com/used?NCID=aolcmp00300000002851) ________________________________________________________________________________
Date: May 01, 2008
Yes.... That's Ron Munson on the far left..... Best... Steve From: Joemotis(at)aol.com Date: Wed, 30 Apr 2008 21:10:28 -0400 Subject: Re: Engines-List: crooks at Performance Engines Is this the company? NO ARCHIVE Joe Motis Contact Performance Engines Inc. 1935 McKinley Ave Ste C La Verne, CA 91750
March 21, 2007 - May 02, 2008
Engines-Archive.digest.vol-aq
