Europa-Archive.digest.vol-bq
December 31, 2000 - January 26, 2001
      #417
Date: Dec 31, 2000
Subject: ve from list
Remove from E-mail list ________________________________________________________________________________
Subject: fuel tank
Date: Dec 31, 2000
Hi! Raimo. Happy New Year. Whilst I'm a MK I builder I find myself surprised to hear that the XS tank expands since I thought they started supplying tanks with an improved compound that doesn't expand. However I would just fill it (having blocked off the holes !) with fuel and let it stand for a while just in case it expands at all (MK I builders had to make a restraining frame whilst this went on ). Useful tip for cutting the holes in the tank is it use a soldering iron to melt the holes into shape, then it removes any likelihood of swarf and static problems . (Still better flush it out though prior to installing .) Also make sure the tank is fitted well HIGH (fuselage right way up) to ensure the wing spars don't clash with it . On the question of cut out marks , yes the fuselage split line was difficult to see, it may be possible that a piece of paper , here and there, with a pencil to take a "rubbing " will highlight it better, then join up the resultant marks . Whatever, do a dummy assembly prior to cutting too much off. If you get a light in a suitable position you will find the C/L crosses although they are very feint. Hopefully this makes useful help for you. All in my humble opinion of course ! Regards Bob Harrison G-PTAG Kit 337 Europa/Jabiru 3300 Trike/Mono -----Original Message----- On Behalf Of RWM-SYSTEMS Sent: 31 December 2000 01:16 Subject: fuel tank Hi on this year, In the manual they say (page 10-2 issue 2/ XS) "tank will expand over of period of 3-4 weeks once fuel is introduced and this should take place before tank is installed into cockpit module". What is that meaning? Should I fill the tank with something over mounth before istalling or what? Also, "trim lines are to be found on the mouldings but are difficult to see" (page 11-1). Can not see any trim lines, no small crosses on the aircraft centreline. Trim lines for windscreen are 12-13 mm, for door 20 mm. How much for the bottom moulding??? Raimo Toivio #417 ________________________________________________________________________________
Subject: g Peel Ply on lay ups (was Ailerons - URGENT)
Date: Dec 31, 2000
Thanks for all the tips on how to prevent warping of the ailerons. In the end the 5 minute epoxy blobs did hold everything pretty tight. It ended up with 1.0 degree washout instead of 1.1, I will settle for that ! On the subject of covering the whole layup with peel ply, in Burt Rutan's book "Moldless Composite Homebuilt Sandwich Aircraft Construction" he suggests this is a bad idea as it "... adds weight" because "It fills the weave 100% with epoxy so it should only be used where it will serve its purpose of bonding or transitioning plies. Do not get carried away and peel ply any more than necessary." ________________________________________________________________________________
Date: Dec 31, 2000
Subject: address for Martin Tuck
Does, anyone have a current web address for Martin Tuck? The Europa Club web site's link is of no help. It points to an invalid site. Also, I am preparing to do the wing root fairings on the Classic. Anybody out their who has gone before me have any words of wisdom? I am not too keen on using the method outlined in the manual since the gap between the root end of the wing and the side of fuselage varies quite a bit. Seems like a lot of work trying to cut up foam blocks and then glue them in place and finally sand them to the desired shape. Happy New Year to all! Thanks Erich A028 Lost Wages, NV Opps that Las Vegas, NV ________________________________________________________________________________
Date: Dec 31, 2000
From: Graham Singleton <grasingleton(at)avnet.co.uk>
Subject: Re: Using Peel Ply on lay ups (was Ailerons -
URGENT) >On the subject of covering the whole layup with peel ply, in Burt Rutan's >book "Moldless Composite Homebuilt Sandwich Aircraft Construction" he >suggests this is a bad idea as it "... adds weight" because "It fills the >weave 100% with epoxy so it should only be used where it will serve its >purpose of bonding or transitioning plies. Do not get carried away and peel >ply any more than necessary." This has to be true. Think about it, there's no way the peel ply will go down between the fibres of the top ply of glass. Graham ________________________________________________________________________________
Date: Dec 31, 2000
Subject: Re: Web address for Martin Tuck
>Also, I am preparing to do the wing root fairings on the Classic. >Anybody out their who has gone before me have any words of wisdom? I am >not too keen on using the method outlined in the manual since the gap >between the root end of the wing and the side of fuselage varies quite a >bit. You could buy some pre moulded fillets as for the XS from Europa or my version for the Classic, I think either would fit but shipping cost for mine would be expensive. A better way to make your own is to use modelling clay to make fillets then lay up 3 plies of BID onto that. Take them off when cured , remove the clay then glue them back on to the wing. Graham ________________________________________________________________________________
Date: Dec 31, 2000
Hi Erich, My Europa website address is: http://ourworld.cs.com/MJKTuck Sorry I haven't updated it for a little while but having recently got married my spare time is now spent helping fix up the house, etc. Still get to fly my Europa though - have around 60 hours on it now, but it has been pretty cold here of late and haven't flown it for a few weeks. Regards Martin Tuck N152MT Wichita, Kansas ________________________________________________________________________________
Date: Dec 31, 2000
Subject: ery Charging
Hi Folks, Happy New Year! My Europa has been sitting dormant in a hanger in sub-zero temperatures for about 3 weeks now. Its supposed to warm up next week. I want to trickle charge the battery overnight without undoing all the wiring. I know you are supposed to disconnect a car battery when charging - something about damaging the alternator - should I do the same for my Europa's battery? Any comments would be appreciated. Regards Martin Tuck N152MT Wichita, Kansas Date: Thu, 1 Feb 2001 20:22:25 GMT From: Majordomo(at)lists.flyer.co.uk Subject: Majordomo file: list 'europa' file 'europa.0101' -- ________________________________________________________________________________
Subject: Battery Charging
Date: Jan 01, 2001
Hi! Martin . Happy new Year 2001. Seems like yesterday we were wishing everyone Happy 2000 ! IMHO. I've never specifically disconnected a car battery to charge it ! Mostly have just connected to the correct terminals and left it charging overnight. Just the same when using a "jump" start battery. (Only needed to disconnect battery's when welding, to protect the alternator.) I have an isolator solenoid which disconnects the system on a master switch so my system is probably different to yours. (Jabiru permanent magnet alternator , also I have a field oil pressure switch to connect the regulator to live when the engine runs which if all the system was left on for a long period would burn out the magnet windings) I would be surprised if your system was permanently live ? Otherwise the battery would drop it's charge over night I think you need to examine your actual system to establish what is factual. Hope this gives you a few pointers. Best regards Bob Harrison G-PTAG -----Original Message----- On Behalf Of MJKTuck(at)cs.com Sent: 31 December 2000 19:42 Subject: Battery Charging Hi Folks, Happy New Year! My Europa has been sitting dormant in a hanger in sub-zero temperatures for about 3 weeks now. Its supposed to warm up next week. I want to trickle charge the battery overnight without undoing all the wiring. I know you are supposed to disconnect a car battery when charging - something about damaging the alternator - should I do the same for my Europa's battery? Any comments would be appreciated. Regards Martin Tuck N152MT Wichita, Kansas ________________________________________________________________________________
Subject: fuel tank
Date: Dec 31, 2000
Good grief!! Almost two years ago, while preparing to install my fuel tank, Europa confirmed that the then current production tanks do NOT require any conditioning prior to installation. I was informed at that time that there would be a revision to the manual deleting the instructions about doing so. Manual revisions seem to have a rather low priority. On my fuselage many of the trim lines were likewise "difficult to see" mainly because there were none. This was especially true of the cockpit module. The mating parts of the fuselage top and bottom will overlap by about 20mm so cut accordingly; note, however, that there is a bit of a joggle that is not part of the joined surfaces so use that as a reference from which to measure the 20mm. Perhaps it would be best to cut oversize and then perform a trial fit of the top to bottom to verify that there is a 20mm bond zone along the entire length of the bond. In the cockpit module it is more difficult to judge where to cut without the scribe lines, but only at the footwells is it critical where you cut. The horizontal cut at the forward end of the cockpit module is the aft end of the floor (installed later) upon which the ruder pedals are mounted so this cut must be horizontal, and also at the right height to keep the floor level. I left it high and trimmed as required when it was time to install the floor, which is perhaps the preferred way to do this since the location of the floor determines the location of the horizontal axes of the rudder pedal shafts. The manual implies that these are not related and fails to caution about the elevation of the floor being important. I suppose that is based on the obviously erroneous assumption that there are scribe lines in the moldings. If you have a tri-gear you MUST have the crosses to locate the fuselage centerline and to find FS70 in order to locate the main gear axles. I urge you to address this with the factory before you proceed if yours is a tri-gear; for the monowheel I don't know the consequences of missing crosses. Best regards, Rob Housman A070 -----Original Message----- On Behalf Of RWM-SYSTEMS Sent: Saturday, December 30, 2000 5:16 PM Subject: fuel tank Hi on this year, In the manual they say (page 10-2 issue 2/ XS) "tank will expand over of period of 3-4 weeks once fuel is introduced and this should take place before tank is installed into cockpit module". What is that meaning? Should I fill the tank with something over mounth before istalling or what? Also, "trim lines are to be found on the mouldings but are difficult to see" (page 11-1). Can not see any trim lines, no small crosses on the aircraft centreline. Trim lines for windscreen are 12-13 mm, for door 20 mm. How much for the bottom moulding??? Raimo Toivio #417 ________________________________________________________________________________
Subject: pa Club Site APPEAL
Date: Jan 01, 2001
Dear All I am putting the final touches to the Club site before submission to the committee. I would be most grateful if anyone who has a home site they would like linked to the club site would kindly send me the URL. Also details of any associated sites that they feel would be of interest to Europa builders. Also welcome would be photographs, videos, anecdotes and statistics of finished and part finished aircraft for submission to the Gallery section. Videographs can be in any format and on any medium. (well almost) Happy New Year to everyone. Dennis ________________________________________________________________________________
From: "Gregory, Mike" <M.J.Gregory(at)cranfield.ac.uk>
Subject: of Peel Ply
Date: Jan 01, 2001
If you wish to find out whether the use of peel ply adds weight in the form of extra resin to your wet lay up, tried this simple experiment: Prepare the lay up, ensuring that the glass cloth is fully wetted out, but using no more resin than usual. Instead of leaving it to dry in air, immediately cover it with a sheet of peel ply, using a brush or squeegee to eliminate air and wet out the peel ply as far as possible, but without adding any extra resin. Allow to cure, then peel off the ply and examine the surface. You will find that a large proportion of the area has the smooth surface to be expected from use of peel ply, but it is likely that there will be a few rough patches where there was insufficient resin. The peel ply itself will now contain resin which would otherwise have remained as part of the lay up. This demonstrates that the peel ply can both remove excess resin and provide a smoother surface. Adding more resin to ensure that the peel ply is fully wetted out and no rough patches are left is likely to add less weight than that of the resin removed, so that a fully smooth surface is possible with no weight gain using peel ply. The disadvantages of using a peel ply to cover large surface areas are: the difficulty (especially for novices) of ensuring that the glass cloth is fully wetted out and there are no trapped air bubbles; the extra material cost and effort during lay up; and the possibility of contamination with some types of peel ply that contain release agents. Some people have expressed concern that peel ply may draw too much resin out of the lay up and weaken it. Remember, however, that any resin in excess of that needed to wet out the glass fibres is excess weight and does not add strength. High technology processes, such as those using autoclaves under pressure, seek to maximise the fibre/resin ratio. Problems with hand lay ups using peel ply are more likely to result from inadequate wetting out before the peel ply was applied, rather than too much resin being drawn out of the finished lay up by the peel ply. Although peel plies are often used to cover areas which will subsequently be bonded, it is important that the cured surface is properly abraded to ensure that it is chemically active. The following advice was received from those professionally involved in composites: "The peel ply problem is probably not contamination if it is a corona treated polyester. These rely on the slick glazed surface after corona discharge treatment to enable them to be removed. However the same slick surface is cast into the laminate bonding surface. That is why it won't stick. "The problem is that many people believe that you need a clean surface for adhesion. That is true, but it is also not sufficient. The secret to bonding success is to have a chemically active surface, so that chemical bonds can be formed between the adhesive and the substrate. (For metals, it is essential that the chemically active surface is resistant to the formation of hydrated oxides because this is the most common cause of disbonding.) Simply removing a peel ply is not sufficient to provide the chemical activity. The only reason these things appear to work in the short term is that there is a small amount of fracture of the resin which occurs at weave cross-overs, and that small fracture surface is chemically active. "Unfortunately, in service water migrates along the bond interface through the chemically inactive sites, and this leads to disbonding. "I suggest you get a copy of Hart-Smith, L.J., Redmond, G, and DAVIS, M.J., The Curse of the Nylon Peel Ply, 41st. Int SAMPE Symp. and Exhib., Anaheim 25-28 Mar 1996" I hope this lump of information doesn't give anyone indigestion after their New Year revels. Remember that there is a large safety factor in the design of composite bonds for amateur construction, so that a less than perfect lay up is still likely to be more than strong enough to keep your aeroplane together. Fly safely and have a happy New Year Mike Europa Club Safety Officer ________________________________________________________________________________
Date: Jan 01, 2001
Subject: led by Epoxy
Hello all... Having only just recently received a new kit, I find I am puzzled by the various epoxy types. I've continued reading the construction manual. I am puzzled about the mention of epoxy with regard to the installation of the rivets on control surfaces. For the rudder, it just says 'epoxy' and 'flox'. It doesn't specify which epoxy. The same thing for the trim tabs. Then, in the discussion about attaching the trim tab rivets to the tail (page 4-6), it specifically mentions the 'rapid epoxy' and 'flox'. Which epoxy is used for attaching the rivets to the rudder and to the trim tabs? If not the 'rapid epoxy', then why does it say to use the rapid type when attaching the trim tabs to the tail? Then, on page 7-7 in the discussion about attaching the hinges to the ailerons, it just say to follow the same principle as that of the rudder and anti-servo tabs. It just says attach them to the inside of each aileron flange with flox and pop-rivets. Again, it does not specify which epoxy. In fact it doesn't even mention epoxy, it just says flox. Should one assume that if only the word epoxy or flox is used, that the use of Aeropoxy is intended? Will the use of Redux, or Rapid Epoxy always be specified if they are to be used? If I am supposed to be using Aeropoxy, then my building is 'on hold' because I have not received it yet. Have a Happy New Year everyone! Jeff ________________________________________________________________________________
From: "flying" <paul-d.stewart.fly(at)virginnet.co.uk>
Subject: bulkhead
Date: Jan 01, 2001
I'm just about to bond in the rear bulkhead to the lower fuselage moulding. I've seen in a classic fuselage prior to fitting the rear bulkhead, builders doing a splash layup from the bulkhead onto the upper fuselage moulding (fin) with a view to then attaching it to the upper moulding with redux when the two canoes are joined. Anyone done it on an XS ? If so any details, particularly about how to get the exact position of the bulkhead in the upper moulding and how difficult is bonding in the bulkhead when the upper moulding is on anyway? Also some one recently said there were some tips about fitting the torque tube in the archive - anyone any idea roughly when? Paul Stewart #432 ________________________________________________________________________________
Subject: bulkhead - KAK virus within it.
Date: Jan 02, 2001
Folks The detailed email contains the Kak virus, have advised the sender. Regards Peter ********************************************** Email: peter(at)nexgen.co.nz Peter Armstrong NexGen Communications Limited Auckland New Zealand "Tomorrows Communications Today" ********************************************** -----Original Message----- Behalf Of flying Subject: rear bulkhead This file: "Unknown0890.data" was infected with the: "WScript.KakWorm.dr" virus. The file was quarantined by Norton AntiVirus. Tuesday, January 02, 2001 09:17 ________________________________________________________________________________
Subject: s detected
Date: Jan 01, 2001
Hi. This is just a heads-up. I just received the following notice from a scanner running on my server: Date: Mon, 1 Jan 2001 12:00:48 -0800 (PST) The VBS_KAKWORM.A virus has been detected in e-mail traffic addressed to you. Walt Hobbs Santa Monica, CA, USA ________________________________________________________________________________
Subject: virus advice re previous message
Date: Jan 02, 2001
Re previous message, I who should no better because I am in the industry, also forwarded it to this group, my apologies. Dammnation, this one is clean Peter ________________________________________________________________________________
Subject: Puzzled by Epoxy
Date: Jan 01, 2001
Jeff: Epoxy is Aeropoxy. Flox is is always the Aeropoxy mixed with cotton (at least in my plane) Redux is for the bonding of structural mechanical parts; Fuselages, wing lids, etc. The five minute epoxy is typically used for odds and ends where a quick rapid cure is desired. I believe it is called out in all instances.It isn't a big deal not in any structural apps. They do not get into all the details later on in the manual as the assumption is that you will pick up the routine. You may want to pick up a Rutan book and do a couple of the small little one day hands on projects detailed therin. About a year ago in Sport Aviation there were several consecutive articles by Ron Alexander on the details in using epoxy and fiberglass. The Europa doesn't have anything really special, it is pretty routine. Read some other reference material and do some other hands on work in addition to the Europa chock. The point is to teach your hands the routine with the material and get a feel on how it works. The Aero Poxy gets drop shipped from the manufacturer to your door step. It shouldn't hold you up as you should be spending a good deal of time inventorying your goods and putting all the hardware and pieces in little drawers and cabinets and shelves with part numbers marked on the outside so you can concentrate on building and not looking for parts 2 years later that you thought were put somewhere. I did every one of my parts except for a small piece of additional sheet. "I'll just lay this right in the pantry behind where I keep the epoxy so I'll know where its at". Well after tearing the house apart and ordering a replacement part I found it about 2 minutes after the new part arrived. Have fun building Steve Hagar A143 Mesa, AZ > [Original Message] > From: JLW <jeffw(at)Telebyte.net> > Date: 1/1/01 8:48:32 AM > Subject: Puzzled by Epoxy > > Hello all... > > Having only just recently received a new kit, I find I am puzzled by > the various epoxy types. I've continued reading the construction > manual. I am puzzled about the mention of epoxy with regard to the > installation of the rivets on control surfaces. For the rudder, it just > says 'epoxy' and 'flox'. It doesn't specify which epoxy. The same > thing for the trim tabs. Then, in the discussion about attaching the > trim tab rivets to the tail (page 4-6), it specifically mentions the > 'rapid epoxy' and 'flox'. Which epoxy is used for attaching the rivets > to the rudder and to the trim tabs? If not the 'rapid epoxy', then why > does it say to use the rapid type when attaching the trim tabs to the > tail? Then, on page 7-7 in the discussion about attaching the hinges to > the ailerons, it just say to follow the same principle as that of the > rudder and anti-servo tabs. It just says attach them to the inside of > each aileron flange with flox and pop-rivets. Again, it does not > specify which epoxy. In fact it doesn't even mention epoxy, it just > says flox. Should one assume that if only the word epoxy or flox is > used, that the use of Aeropoxy is intended? Will the use of Redux, or > Rapid Epoxy always be specified if they are to be used? If I am > supposed to be using Aeropoxy, then my building is 'on hold' because I > have not received it yet. > > Have a Happy New Year everyone! > > Jeff > --- Steve Hagar --- hagargs(at)earthlink.net ________________________________________________________________________________
Date: Jan 01, 2001
Subject: Re: [RE: Puzzled by Epoxy]
I bought the Composite Practice Kit from Aircraft Spruce. It comes with a Rutan manual, foam, epoxy, glass and a bunch of stuff to learn and practice basic layup procedures. It goes into more details than what you would need for the Europa, but the information is well worth it. Even if you bought the fast-build kit, I would not attempt to mess with any parts of the Europa until I have tried atleast a few practice layups. "Steve Hagar" wrote: Jeff: Epoxy is Aeropoxy. Flox is is always the Aeropoxy mixed with cotton (at least in my plane) Redux is for the bonding of structural mechanical parts; Fuselages, wing lids, etc. The five minute epoxy is typically used for odds and ends where a quick rapid cure is desired. I believe it is called out in all instances.It isn't a big deal not in any structural apps. They do not get into all the details later on in the manual as the assumption is that you will pick up the routine. You may want to pick up a Rutan book and do a couple of the small little one day hands on projects detailed therin. About a year ago in Sport Aviation there were several consecutive articles by Ron Alexander on the details in using epoxy and fiberglass. The Europa doesn't have anything really special, it is pretty routine. Read some other reference material and do some other hands on work in addition to the Europa chock. The point is to teach your hands the routine with the material and get a feel on how it works. The Aero Poxy gets drop shipped from the manufacturer to your door step. It shouldn't hold you up as you should be spending a good deal of time inventorying your goods and putting all the hardware and pieces in little drawers and cabinets and shelves with part numbers marked on the outside so you can concentrate on building and not looking for parts 2 years later that you thought were put somewhere. I did every one of my parts except for a small piece of additional sheet. "I'll just lay this right in the pantry behind where I keep the epoxy so I'll know where its at". Well after tearing the house apart and ordering a replacement part I found it about 2 minutes after the new part arrived. Have fun building Steve Hagar A143 Mesa, AZ > [Original Message] > From: JLW <jeffw(at)Telebyte.net> > Date: 1/1/01 8:48:32 AM > Subject: Puzzled by Epoxy > > Hello all... > > Having only just recently received a new kit, I find I am puzzled by > the various epoxy types. I've continued reading the construction > manual. I am puzzled about the mention of epoxy with regard to the > installation of the rivets on control surfaces. For the rudder, it just > says 'epoxy' and 'flox'. It doesn't specify which epoxy. The same > thing for the trim tabs. Then, in the discussion about attaching the > trim tab rivets to the tail (page 4-6), it specifically mentions the > 'rapid epoxy' and 'flox'. Which epoxy is used for attaching the rivets > to the rudder and to the trim tabs? If not the 'rapid epoxy', then why > does it say to use the rapid type when attaching the trim tabs to the > tail? Then, on page 7-7 in the discussion about attaching the hinges to > the ailerons, it just say to follow the same principle as that of the > rudder and anti-servo tabs. It just says attach them to the inside of > each aileron flange with flox and pop-rivets. Again, it does not > specify which epoxy. In fact it doesn't even mention epoxy, it just > says flox. Should one assume that if only the word epoxy or flox is > used, that the use of Aeropoxy is intended? Will the use of Redux, or > Rapid Epoxy always be specified if they are to be used? If I am > supposed to be using Aeropoxy, then my building is 'on hold' because I > have not received it yet. > > Have a Happy New Year everyone! > > Jeff > --- Steve Hagar --- hagargs(at)earthlink.net ________________________________________________________________________________
Subject: pump suction
Date: Jan 01, 2001
We have recently run the fuel and oil flow checks required for commissioning our new 912S, and found a problem with the depression at the oil pump inlet. The maximum specified value is 4.4 inches at full throttle, but we get about 5 inches at 2500rpm, and 11 inches with the throttle open. We have checked the oil pickup from the reservoir, and found no restrictions, so all that remains in the flow path to the pump inlet is the oil cooler and two hoses. Oil pressure and temperature are both normal at all times, so whatever restriction may be present is not enough to decrease the flow of oil to the engine. Has anyone experienced a similar problem with the XS oil cooler? Any suggestions? If we knew how much flow we should expect for a given pressure differential between the reservoir and the pump inlet, we might have a better chance of finding the obstruction. Dave DeFord, A135 ________________________________________________________________________________
Date: Jan 01, 2001
Andrew. Great idea. Thanks! Andrew Sarangan wrote: > I bought the Composite Practice Kit from Aircraft Spruce. It comes with a > Rutan manual, foam, epoxy, glass and a bunch of stuff to learn and practice > basic layup procedures. It goes into more details than what you would need for > the Europa, but the information is well worth it. Even if you bought the > fast-build kit, I would not attempt to mess with any parts of the Europa until > I have tried atleast a few practice layups. > ________________________________________________________________________________
From: "John Cliff" <john(at)crixbinfield.freeserve.co.uk>
Date: Jan 02, 2001
Forwarded from the bounce bin. Message is from "Cliff Shaw" *************************************************** Martin Good you ask about trickle charging. I am now working on a charger for Bob;' Europa, Beep Beep, that will do just that. We picked up a 600ma plug in the wall 12 volt charger. I tested it with a multimeter and it does charge around 1/2 amp when the battery is down. That would be OK for a overnight "kick" but too much to leave on for weeks at a time. I am installing a 30 ohm resister in series with the charge line to the battery to reduce the charge rate to 50 or 60 ma. I think this is much better for long term use. The voltage on the battery with the trickle should be not more than 14.2 volts. I will be happier with 13.8 volts. It voltage depends on the battery and the temperature. I hope this helps. Use this info with your desecration, it comes from my experience, not an engineer degree. Have fun Cliff Shaw ________________________________________________________________________________
Subject: Re: Ailerons - URGENT
Date: Jan 02, 2001
Forwarded from the bounce bin. Message is from "Kenneth S. Whiteley" *************************************************************** In message <000401c071c1$e493eb60$f4fecbc1@tinypc>, Keith Tallent writes >Just finished my first aileron layup everything went well... >went to weigh them down in the jigs but then had second thoughts on the best >way to do this! >I was just going to lay a sheet of plastic over the whole lot and put some >large books on it but then I panicked about the plastic affecting the layup >quality... Don't lay polyethylene sheeting directly onto a lay-up. It will cause resin to be sucked up through the glass-cloth to take up the volume contraction of the curing resin, leaving voids underneath the glass. Ideally don't put anything on top of the lay-up, but if you must, use peel ply. You can use polyethylene sheeting on top of the peel-ply. Ken Whiteley (19) ________________________________________________________________________________
Date: Jan 02, 2001
Subject: Re: Oil pump suction
My 914 manual words it as follows: "At full throttle operation the depression at pump inlet must be 4,4 p.s.i. below ambient pressure." Unless you mistyped inches and you did measure PSI, and w/o doing the math that sounds about right. That translation also sounds like they mean 4.4 PSI minimum. Regards, Fred F., A063 Dave DeFord wrote: > > We have recently run the fuel and oil flow checks required for commissioning > our new 912S, and found a problem with the depression at the oil pump inlet. > The maximum specified value is 4.4 inches at full throttle, but we get about > 5 inches at 2500rpm, and 11 inches with the throttle open. We have checked > the oil pickup from the reservoir, and found no restrictions, so all that > remains in the flow path to the pump inlet is the oil cooler and two hoses. > Oil pressure and temperature are both normal at all times, so whatever > restriction may be present is not enough to decrease the flow of oil to the > engine. Has anyone experienced a similar problem with the XS oil cooler? > Any suggestions? If we knew how much flow we should expect for a given > pressure differential between the reservoir and the pump inlet, we might > have a better chance of finding the obstruction. ________________________________________________________________________________
Date: Jan 02, 2001
Subject: Re: Battery Charging
What you have there is fine. For a few bucks more ($20 at a Target store here), there's a little "maintainer" that pulses current into the batt and flashes a LED. Long time between flashes means approaching full charge, and eventually stops until some discharge occurs again. Regards, Fred F., A063 > > Martin > > Good you ask about trickle charging. I am now working on a charger for Bob;' > Europa, Beep Beep, that will do just that. > > We picked up a 600ma plug in the wall 12 volt charger. I tested it with a > multimeter and it does charge around 1/2 amp when the battery is down. That > would be OK for a overnight "kick" but too much to leave on for weeks at a > time. I am installing a 30 ohm resister in series with the charge line to > the battery to reduce the charge rate to 50 or 60 ma. I think this is much > better for long term use. The voltage on the battery with the trickle should > be not more than 14.2 volts. I will be happier with 13.8 volts. It voltage > depends on the battery and the temperature. > > I hope this helps. Use this info with your desecration, it comes from my > experience, not an engineer degree. > > Have fun > Cliff Shaw ________________________________________________________________________________
Date: Jan 02, 2001
Good explanation except that some of the structural bonding is done with Araldite 420 (called Redux 420 in the manual) mixed with flox. Flox is cotton, not a mixture of cotton and epoxy. Best regards, Rob Housman A070 -----Original Message----- On Behalf Of Steve Hagar Sent: Monday, January 01, 2001 7:25 PM Subject: RE: Puzzled by Epoxy Jeff: Epoxy is Aeropoxy. Flox is is always the Aeropoxy mixed with cotton (at least in my plane) Redux is for the bonding of structural mechanical parts; Fuselages, wing lids, etc. The five minute epoxy is typically used for odds and ends where a quick rapid cure is desired. I believe it is called out in all instances.It isn't a big deal not in any structural apps. They do not get into all the details later on in the manual as the assumption is that you will pick up the routine. You may want to pick up a Rutan book and do a couple of the small little one day hands on projects detailed therin. About a year ago in Sport Aviation there were several consecutive articles by Ron Alexander on the details in using epoxy and fiberglass. The Europa doesn't have anything really special, it is pretty routine. Read some other reference material and do some other hands on work in addition to the Europa chock. The point is to teach your hands the routine with the material and get a feel on how it works. The Aero Poxy gets drop shipped from the manufacturer to your door step. It shouldn't hold you up as you should be spending a good deal of time inventorying your goods and putting all the hardware and pieces in little drawers and cabinets and shelves with part numbers marked on the outside so you can concentrate on building and not looking for parts 2 years later that you thought were put somewhere. I did every one of my parts except for a small piece of additional sheet. "I'll just lay this right in the pantry behind where I keep the epoxy so I'll know where its at". Well after tearing the house apart and ordering a replacement part I found it about 2 minutes after the new part arrived. Have fun building Steve Hagar A143 Mesa, AZ > [Original Message] > From: JLW <jeffw(at)Telebyte.net> > Date: 1/1/01 8:48:32 AM > Subject: Puzzled by Epoxy > > Hello all... > > Having only just recently received a new kit, I find I am puzzled by > the various epoxy types. I've continued reading the construction > manual. I am puzzled about the mention of epoxy with regard to the > installation of the rivets on control surfaces. For the rudder, it just > says 'epoxy' and 'flox'. It doesn't specify which epoxy. The same > thing for the trim tabs. Then, in the discussion about attaching the > trim tab rivets to the tail (page 4-6), it specifically mentions the > 'rapid epoxy' and 'flox'. Which epoxy is used for attaching the rivets > to the rudder and to the trim tabs? If not the 'rapid epoxy', then why > does it say to use the rapid type when attaching the trim tabs to the > tail? Then, on page 7-7 in the discussion about attaching the hinges to > the ailerons, it just say to follow the same principle as that of the > rudder and anti-servo tabs. It just says attach them to the inside of > each aileron flange with flox and pop-rivets. Again, it does not > specify which epoxy. In fact it doesn't even mention epoxy, it just > says flox. Should one assume that if only the word epoxy or flox is > used, that the use of Aeropoxy is intended? Will the use of Redux, or > Rapid Epoxy always be specified if they are to be used? If I am > supposed to be using Aeropoxy, then my building is 'on hold' because I > have not received it yet. > > Have a Happy New Year everyone! > > Jeff > --- Steve Hagar --- hagargs(at)earthlink.net ________________________________________________________________________________
Date: Jan 02, 2001
Subject: Re: Puzzled by Epoxy
<< Which epoxy is used for attaching the rivets to the rudder and to the trim tabs? If not the 'rapid epoxy', then why does it say to use the rapid type when attaching the trim tabs to the tail? >> Initially, I too thought the choice of which epoxy to use for flox in bedding the hinges was arbitrary, so I chose to use Aeropoxy since it gave a longer working time than the 5 minute epoxy. This turned out to be a mistake -- the Aeropoxy is relatively thin and as the rivets were installed the flox exuded pure epoxy which ran into the hinges. To recover, once the epoxy began to set up I added a drop of oil onto the hinge pin and then worked the affected hinges back and forth every hour or so for several hours. The 5 minute epoxy is much thicker so as the flox is compressed it doesn't exude a liquid which can enter the hinges along the pins and lock them permanently. John A044 ________________________________________________________________________________
Subject: Re: WARNING * Oil line Failures
Date: Jan 02, 2001
01/02/2001 12:24:50 PM Miles, how does the stainless steel braid and the teflon resist heat? It's heat that's the culprit and causing the problems. Regards, Garry Stout N4220S (813) 878-3929 FAX (813) 878-5651, Internet ID Garrys(at)att.com ________________________________________________________________________________
Subject: fuel tank
Date: Jan 02, 2001
Fuselage Builders, I found the line finally quite easily by highlighting it directly by pencil. Also the small crosses every 10" by using powerful light. It is really invisible but it is there. I can feel it also by fingertip. This very useful tip came from Bob Harrison! Raimo Toivio OH-XRT XS Mono ----- Original Message ----- From: Rob Housman <robh@hyperion-ef.com> Subject: RE: fuel tank > Good grief!! > > Almost two years ago, while preparing to install my fuel tank, Europa > confirmed that the then current production tanks do NOT require any > conditioning prior to installation. I was informed at that time that there > would be a revision to the manual deleting the instructions about doing so. > Manual revisions seem to have a rather low priority. > > On my fuselage many of the trim lines were likewise "difficult to see" > mainly because there were none. This was especially true of the cockpit > module. The mating parts of the fuselage top and bottom will overlap by > about 20mm so cut accordingly; note, however, that there is a bit of a > joggle that is not part of the joined surfaces so use that as a reference > from which to measure the 20mm. Perhaps it would be best to cut oversize > and then perform a trial fit of the top to bottom to verify that there is a > 20mm bond zone along the entire length of the bond. > > In the cockpit module it is more difficult to judge where to cut without the > scribe lines, but only at the footwells is it critical where you cut. The > horizontal cut at the forward end of the cockpit module is the aft end of > the floor (installed later) upon which the ruder pedals are mounted so this > cut must be horizontal, and also at the right height to keep the floor > level. I left it high and trimmed as required when it was time to install > the floor, which is perhaps the preferred way to do this since the location > of the floor determines the location of the horizontal axes of the rudder > pedal shafts. The manual implies that these are not related and fails to > caution about the elevation of the floor being important. I suppose that is > based on the obviously erroneous assumption that there are scribe lines in > the moldings. > > If you have a tri-gear you MUST have the crosses to locate the fuselage > centerline and to find FS70 in order to locate the main gear axles. I urge > you to address this with the factory before you proceed if yours is a > tri-gear; for the monowheel I don't know the consequences of missing > crosses. > > > Best regards, > > Rob Housman > A070 > > > -----Original Message----- > On Behalf Of RWM-SYSTEMS > Subject: fuel tank > > Hi on this year, > > In the manual they say (page 10-2 issue 2/ XS) "tank will expand over of > period of 3-4 weeks once fuel is introduced and this should take place > before tank is installed into cockpit module". > > What is that meaning? > > Should I fill the tank with something over mounth before istalling or what? > > Also, "trim lines are to be found on the mouldings but are difficult to see" > (page 11-1). Can not see any trim lines, no small crosses on the aircraft > centreline. > > Trim lines for windscreen are 12-13 mm, for door 20 mm. How much for the > bottom moulding??? > > Raimo Toivio > #417 > > > > ________________________________________________________________________________
Date: Jan 02, 2001
Also, always when charging, remember safety. There can be explosive vapours from the battery and accidents. Maybe it is better to assembly the minus-terminal of the charger to the ground - not direct into battery minus-pole to avoid possible sparking. When helping with other battery, I connect plus-terminal cable first to the weak battery then to the strong battery. After that, minus cable to the strong battery (helper) and finally to the ground (metal part of the engine far away from the battery). In this country it is almost everyday task to help somebody with battery in the winter-time. Also planes on the frozen lakes. Wishes, Raimo Toivio OH-XRT, OH-CVK, OH-BLL ----- Original Message ----- From: Fred Fillinger <fillinger(at)ameritech.net> Subject: Re: Battery Charging > What you have there is fine. For a few bucks more ($20 at a Target > store here), there's a little "maintainer" that pulses current into > the batt and flashes a LED. Long time between flashes means > approaching full charge, and eventually stops until some discharge > occurs again. > > Regards, > Fred F., A063 > > > > > Martin > > > > Good you ask about trickle charging. I am now working on a charger for Bob;' > > Europa, Beep Beep, that will do just that. > > > > We picked up a 600ma plug in the wall 12 volt charger. I tested it with a > > multimeter and it does charge around 1/2 amp when the battery is down. That > > would be OK for a overnight "kick" but too much to leave on for weeks at a > > time. I am installing a 30 ohm resister in series with the charge line to > > the battery to reduce the charge rate to 50 or 60 ma. I think this is much > > better for long term use. The voltage on the battery with the trickle should > > be not more than 14.2 volts. I will be happier with 13.8 volts. It voltage > > depends on the battery and the temperature. > > > > I hope this helps. Use this info with your desecration, it comes from my > > experience, not an engineer degree. > > > > Have fun > > Cliff Shaw ________________________________________________________________________________
Subject: lines
Date: Jan 02, 2001
Should I read the manual more carefully? They say just right "use a pencil to highlight the lines" (page 11-1 XS). I did not understand what means "highlight" when reading. No I do. It is concrete order. Funny Building! Raimo Toivio #417 ________________________________________________________________________________
Subject: Fairings
Date: Jan 03, 2001
Also, I am preparing to do the wing root fairings on the Classic. Anybody out their who has gone before me have any words of wisdom? Go and buy a set of Graham Singleton's fairings. It cuts the work down to a couple of afternoons and they fit very nicely. Do remember that if you make a socket for the fairings on the fuselage side then leave enough space for the fairings to slide over the edge of the socket. Pulling 3g without the ability of the fairing to slide out of the socket results in rather alarming noises when it does pop out over the lip. My heart has now stopped pounding and some day we'll get around to fixing the starboard fairing on UBD which now has a section chipped out of it. Tony ________________________________________________________________________________
Subject: Re: Europa Mail - rivets
Date: Jan 02, 2001
----- Original Message ----- From: John Cliff <john(at)crixbinfield.freeserve.co.uk> Subject: Re: Europa Mail - rivets > This response to my forwarded mail on rivetting was sent to me, and is now > posted to the List, thanks Ben. It is from > BCLERX(at)aol.com > > ************************************************************** > > Hi > > Offhand, I would say get larger rivets and re-drill to fit the new rivets. > Any standard rivet has an "oversize" rivet to match when the original smaller > rivet is drilled out for some reason. Each rivet hole is usually drilled with > a specific numbered drill and the hole size will need to be within certain > tolerances. Look in a supply catalog (Aircraft Spruce, etc) and they'll have > charts for rivet diameter and hole size. I'm no rivet expert and don't know > how oversized your rivet holes are. I'm sure an experienced builder will > advise on the exchange. But I'd feel better with a larger rivet and properly > sized holes. I also replaced all my cheap hardware store pop rivets with > aircraft quality (Cherrymax) rivets. More expensive, but its my ass in the > seat on the first flight. > > Ben > Cheers: There wasy humerous article on commercial rivetting several years ago in the Air and Space Museum mag. It was written by an old hand in the game and his description of the "tap talk" twixt rivetter and bucker was most entertaining - they, being separated by a long wing, were reduced to 'discussing' the success of each rivet by a series of taps - if I remember - one tap from the bucker = "another short burst", two taps = "Ok, go to next rivet", and three taps = "too far gone, drill out and replace with new rivet". The sequence of one, one, one, and a hesitant three would drive the rivetter to round the corner and punching the bucker's lights out. On occasion, the drilling out of a faulty rivet would require the next size rivet to 'true' the larger hole. In order to hide the event from the inspector, the rivetter would keep a secret hoard of oversize rivets with undersize heads - thus avoiding a bad rep with the inspector. If I have this corrctly, they were called "Lockheed" rivets at Boeing, "Boeing" rivets at Douglas and "Douglas" rivets at Lockheed! No, I don't know where these can be bought.............. Happy Landings, Ferg A064 ________________________________________________________________________________
Date: Jan 02, 2001
> I chose to use Aeropoxy since it gave a longer >working time than the 5 minute epoxy. This turned out to be a mistake -- the >Aeropoxy is relatively thin and as the rivets were installed the flox exuded >pure epoxy which ran into the hinges. Annoying, John, to say the least. The way I always did it was to let the flox cure before pulling the rivets. I use skin pins, not Clecos, to hold the flanges in place. That way the hinge will not be distorted if the flange is not straight. If this is done with the hinges still fixed to the straight edge the hinges remain coaxial. (if that's the right word) Concentric maybe {?:-) Graham ________________________________________________________________________________
Date: Jan 02, 2001
Subject: Re: Wing Fairings
>Do remember that if you make a socket for the fairings on the fuselage side >then leave enough space for the fairings to slide over the edge of the >socket. Pulling 3g without the ability of the fairing to slide out of the >socket results in rather alarming noises when it does pop out over the lip. That's funny, I never had that happen, but maybe I never pulled 3 G. The fillets are designed to be flexible enough to accommodate the small amount of movement at the wing root under load. It would be nice if someone could tell us what deflection to expect per G. I must try and work it out. I guess I do need to include a sketch of the chamfer on the edges to make them ride over the edges of the sockets. Graham ________________________________________________________________________________
Subject: Wing Fairings
Date: Jan 02, 2001
Hi! All. Grahams' fairings are excellent . Just remember though that you must finish filling the fuselage sides prior to locating them on the wings with the whole set up assembled with lift pins and spa pins in place, otherwise be prepared for much pushing to get the spa pins engaged !!!! Regards and Happy New Year to all. Bob Harrison G-PTAG -----Original Message----- On Behalf Of Graham Singleton Sent: 02 January 2001 22:08 Subject: Re: Wing Fairings >Do remember that if you make a socket for the fairings on the fuselage side >then leave enough space for the fairings to slide over the edge of the >socket. Pulling 3g without the ability of the fairing to slide out of the >socket results in rather alarming noises when it does pop out over the lip. That's funny, I never had that happen, but maybe I never pulled 3 G. The fillets are designed to be flexible enough to accommodate the small amount of movement at the wing root under load. It would be nice if someone could tell us what deflection to expect per G. I must try and work it out. I guess I do need to include a sketch of the chamfer on the edges to make them ride over the edges of the sockets. Graham ________________________________________________________________________________
Subject: n techniques
Date: Jan 02, 2001
Cowabunga 2001 Finally, the next millenium has arrived. Imho 3 (cubed) Surface finish stability can be compromised by too thin of a surface structure. A miraculously light, single layup, peel plyed surface can be thin enough to crumble when flexed. Alotta paint won't defend much against this. This is because you cannot then fill the weave behind the "bubble" stretched across the pockets in the weave. This, of course, is for layups onto something, foam, where you will not wish to access the backside of the weave. If the surface is meaninglessly thin then cracks might develop. Having the space in the weave to build a microballoon filler base is the norm. Using a form for this now is where you could save time. Theory- I suspect that perhaps a thin board, wood panelling or 5mm acrylic sheet, with peelply underneath, to provide a moulding surface, might provide a most excellent microballon filler layer surface result. That should provide for the least amount of primer, and the sanding of primer, and a smooth finish. My prebuilt elevators, flaps, ailerons and rudder need 'surfacing'. I'll let yall know how it goes. Nic-xs145 ________________________________________________________________________________
Date: Jan 02, 2001
Graham. Thanks for the response. You didn't mention which epoxy you used however. There are a couple places in the manual (XS) where it just says epoxy, and another where it specifically mentions 'rapid' epoxy. Does it matter a lot? Also, it mentions applying a coat of pure epoxy (without flox) to the hinge first, then putting on epoxy with the flox. Perhaps there is supposed to be a short period for the epoxy to cure slightly, before putting on the flox coat. I suppose this is to assure good adhesion to the hinge. Any comments on this? Jeff A191 Graham Singleton wrote: > > I chose to use Aeropoxy since it gave a longer > >working time than the 5 minute epoxy. This turned out to be a mistake -- the > >Aeropoxy is relatively thin and as the rivets were installed the flox exuded > >pure epoxy which ran into the hinges. > > Annoying, John, to say the least. > The way I always did it was to let the flox cure before pulling the rivets. > I use skin pins, not Clecos, to hold the flanges in place. That way the > hinge will not be distorted if the flange is not straight. If this is done > with the hinges still fixed to the straight edge the hinges remain coaxial. > (if that's the right word) Concentric maybe {?:-) > > Graham > ________________________________________________________________________________
Date: Jan 02, 2001
I bonded the fairings to the fuselage side, rather than the wing root. Results: probably about the same amount of work (unless you buy the pre-molded), better visual appearance, cleaner fairing adjacent to the flap (did not add the extension to the flaps), and easier one-man rigging. I just don't know yet if there any "in service" down sides to come. But I can report it is do-able. Regards, Fred F., A063 ________________________________________________________________________________
Date: Jan 02, 2001
Subject: Re: Resin techniques
I can't comment on the theory, but microballoons/laminating resin as a surfacer is obsolete. Use PolyFiber's SuperFil. Besides the micro being significantly heavier, it's a bear to sand, and the pinholes endemic to the stuff will drive you nuts when priming. Been there done that! Regards, Fred F., A063 Nic wrote: > .... > If the surface is meaninglessly thin then cracks might develop. > Having the space in the weave to build a microballoon filler base is the > norm. > Using a form for this now is where you could save time. > > Theory- > I suspect that perhaps a thin board, wood panelling or 5mm acrylic sheet, > with peelply underneath, to provide a moulding surface, might provide a most > excellent microballon filler layer surface result. > That should provide for the least amount of primer, and the sanding of > primer, and a smooth finish. > .... ________________________________________________________________________________
Subject: er still.
Date: Jan 02, 2001
Thanx Fred. Right on. I'll check it out. Nic ________________________________________________________________________________
Date: Jan 02, 2001
Subject: ook Question
Hello, What kind of construction logs do you guys maintain for the Europa? The FAA specifically mentions logs, signatures and photographs. I would prefer to keep a journal on my computer, perhaps even as a website like several others have done, but I am not sure if the such a log would satisfy the FAA. Does anyone have experience with this? CFII Europa #A178 ________________________________________________________________________________
Subject: 2
Date: Jan 02, 2001
I expect an extensive, high resolution graphic image catalog, of way too many images every session, will suffice. There are many fine digital cameras/motion recorders to be had. I'll have witnesses and newspaper headlines in them, just to be sure. Nic sx145 ________________________________________________________________________________
Date: Jan 03, 2001
Subject: Re: Logbook Question
I've never heard of any instance where FAA denied certification solely for this reason. FAA says (in AC 20-27D) that the log is to show "construction has been accomplished in accordance with acceptable workmanship methods..." Like a visual inspection of the A/C can't. I believe what they really want is proof you built it, not a hired gun. It also helps them where there's multiple builders, to show the full amateur-built trail and who should be given the repairman's certificate if one is requested. I use M$ Word and a digital camera. Anything done on computer can be printed out, signing/dating each page (as AC 20-7D suggests). Regards, Fred F., A063 Andrew Sarangan wrote: > > Hello, > > What kind of construction logs do you guys maintain for the Europa? The FAA > specifically mentions logs, signatures and photographs. I would prefer to keep > a journal on my computer, perhaps even as a website like several others have > done, but I am not sure if the such a log would satisfy the FAA. Does anyone > have experience with this? > > CFII > Europa #A178 ________________________________________________________________________________
Date: Jan 03, 2001
>Skin Pins? What are these? I don't see any in the ACS catalog... >Shaun Simpkins They're the English equivalent to Clecos. They have a split threaded hook, so that the closing tension/gap is adjusted with a thread instead of a spring loaded hook, and need not be excessive. Graham ________________________________________________________________________________
Subject: wks
Date: Jan 03, 2001
01/03/2001 08:17:11 AM I couldn't resist forwarding this along to our Europa team. Apologies if you've seen it before. >"Squawks" are problem listings that pilots generally leave for >maintenance crews to fix before the next flight. Here are some >squawks submitted by US Air Force pilots and the replies from >the maintenance crews. > >(P)=PROBLEM (S)=SOLUTION > >(P) Left inside main tire almost needs replacement >(S) Almost replaced left inside main tire > >(P) Test flight OK, except autoland very rough >(S) Autoland not installed on this aircraft > >(P) #2 Propeller seeping prop fluid >(S) #2 Propeller seepage normal - #1 #3 and #4 propellers >lack normal seepage > >(P) Something loose in cockpit >(S) Something tightened in cockpit > >(P) Evidence of leak on right main landing gear >(S) Evidence removed > >(P) DME volume unbelievably loud >(S) Volume set to more believable level > >(P) Dead bugs on windshield >(S) Live bugs on order > >(P) Autopilot in altitude hold mode produces a 200 fpm >descent >(S) Cannot reproduce problem on ground > >(P) IFF inoperative >(S) IFF always inoperative in OFF mode >(IFF-Identification Friend or Foe) > >(P) Friction locks cause throttle levers to stick >(S) That's what they're there for > >(P) Number three engine missing >(S) Engine found on right wing after brief search > >(P) Aircraft handles funny >(S) Aircraft warned to straighten up, "fly right" and be >serious > >(P) Target Radar hums >(S) Reprogrammed Target Radar with the lyrics > Regards, Garry Stout N4220S (813) 878-3929 FAX (813) 878-5651, Internet ID Garrys(at)att.com ________________________________________________________________________________
Subject: rFil vs. Expancell...
Date: Jan 03, 2001
Several posters have opted for Superfill instead of the factory-supplied Expancell for final filling. What are the differences between these two products and what are the advantages to Superfill? Thinking WAY ahead... Thanks - Shaun Simpkins A207 ________________________________________________________________________________
Date: Jan 03, 2001
<< Just remember though that you must finish filling the fuselage sides prior to locating them on the wings with the whole set up assembled with lift pins and spa pins in place, otherwise be prepared for much pushing to get the spa pins engaged !!!! >> During construction, I fitted the lift pin sockets and wing fairings in place with the fuselage level, building the fairings per the manual. Now, in order to insert/remove the pip pins through the rear lift pins on the trailer a helper must push the wing tip forward slightly -- the fuselage is a bit nose up on the trailer which seems to cause this. John N44EU ________________________________________________________________________________
From: "Joseph Lamand" <joseph_lamand(at)hotmail.com>
Subject: pa Fast Build Kit
Date: Jan 03, 2001
Dear Europa Builders I am looking into a Europa XS fast-build kit. The fast-build comes with all stage 1 glass work completed. The standard Europa XS is on the FAA approved list, but the fast-build kit is not on the list. The company personnel once told me that the reason they did not get this on the list is because of the extra cost involved in having it reinspected by the FAA. Apparently this is how almost all Europa kits are sold now. They don't think I should have any trouble proving the 'major portion' rule. I like the fast-build idea, but I am a little concerned about this. I would like to hear from others who are building the fast-build kit. ________________________________________________________________________________
From: "ami mcfadyean" <ami(at)mcfadyean.freeserve.co.uk>
Date: Jan 03, 2001
-----Original Message----- From: Graham Singleton <grasingleton(at)avnet.co.uk> >>It would be nice if someone could >tell us what deflection to expect per G<< The deflection of the fuselage sides under the loads passed into them by the forward wing lift pins is 0.21 degrees per `g`. Don`t know how much the wings flex though. Duncan McFadyean ________________________________________________________________________________
Date: Jan 03, 2001
Have you tried to get the whole aircraft onto a monowheel trailer without the wings touching or being perilously close to the fairings? Duncan McFadyean -----Original Message----- From: Fred Fillinger <fillinger(at)ameritech.net> Date: Wednesday, January 03, 2001 1:11 AM Subject: Re: Wing Fairings >I bonded the fairings to the fuselage side, rather than the wing >root. Results: probably about the same amount of work (unless you buy >the pre-molded), better visual appearance, cleaner fairing adjacent to >the flap (did not add the extension to the flaps), and easier one-man >rigging. > >I just don't know yet if there any "in service" down sides to come. >But I can report it is do-able. > >Regards, >Fred F., A063 > ________________________________________________________________________________
Subject: Re: SuperFil vs. Expancell...
Date: Jan 03, 2001
Expancel can, if you have the patience, be applied much lighter than Superfil. And its loads cheaper and sands easier. Downside is its too soft and marks easily; pinholes can be cured with Smoothprime or other primer-filler worked-in with a roller. Duncan mcFadyean -----Original Message----- From: Shaun Simpkins <shauns(at)hevanet.com> Date: Wednesday, January 03, 2001 3:11 PM Subject: SuperFil vs. Expancell... Several posters have opted for Superfill instead of the factory-supplied Expancell for final filling. What are the differences between these two products and what are the advantages to Superfill? Thinking WAY ahead... Thanks - Shaun Simpkins A207 ________________________________________________________________________________
Date: Jan 03, 2001
Not a problem. Should have mentioned I have the Tri-gear, and do not contemplate a trailer given affordability of hangar space here. Regards, Fred F., A063 > Have you tried to get the whole aircraft onto a monowheel trailer without > the wings touching or being perilously close to the fairings? > > Duncan McFadyean > > -----Original Message----- > >I bonded the fairings to the fuselage side, rather than the wing > >root. Results: probably about the same amount of work (unless you buy > >the pre-molded), better visual appearance, cleaner fairing adjacent to > >the flap (did not add the extension to the flaps), and easier one-man > >rigging. > > > >I just don't know yet if there any "in service" down sides to come. > >But I can report it is do-able. > > > >Regards, > >Fred F., A063 ________________________________________________________________________________
Date: Jan 03, 2001
I started my project in the UK under the PFA then moved out here to Wichita with my job. I visited the local FAA office and asked then what I needed to give them in terms of paperwork and they asked if I finished it yet. I said no, and they said basically don't bother us until you have - then we'll inspect it. I followed the advice in a little book which tells you how to certify a homebuilt (in the US) and that said a simple log of what you did - with dates is sufficient - together with meeting the FAA regs, etc. Also you should consider asking an EAA tech councilor to inspect parts before closeup (although this isn't mandatory). A photographic record is also very helpful to show at final inspection as you can sit down and help answer any questions they might have. Remember the Europa manual is very high quality compared to other manufacturers so notes in the manual would be acceptable. Anyhow, by the time I had finished a new person had started at the local office and when I went in to say 'OK I'm finished' they were surprised they had no idea I was building it, wanted to know who my DAR was for inspections during the build etc - which kind of made me gulp. They also took one look at my PFA builders log I had been using and said words to the effect 'what the heck is this?' They made me write all the entries out again in a 'proper FAA logbook' along with insisting on separate engine logbook and propeller logbook (which my little book said was not required for homebuilts. At the end of the day though they led me through the final processes of inspection out at the hanger and we spent around 2 hours (in 90 deg plus temps) doing that. She was most interested in the way the rudder cables seemed 'loose' and rattled around the bottom of the fuselage when no-one was sitting in it. I had to get in and show how they tautened when you rest your feet on the pedals. The only question she had was who was going to do the maintenance on it and I said I was. No you can't, you're not authorized. But I've built it - I know every nut/bolt and flox joint. No sorry not after I give you its ticket - not without a repairmans certificate. But she then explained that I could get one of those by going back to the FAA office and filling in the paperwork - and that is basically all there was to it although I was prepared (with the photo album) to answer questions of me if they really wanted to. In short, get with your FAA office first and make sure you understand exactly what they are going to be expecting - because the process seems to differ and some expectations are more than others - and get it in writing if necessary. As long as you meet the requirements for placarding etc. as laid out in the book I mentioned you should be OK. Its worth it!!! Regards Martin Tuck N152MT Wichita, KS ________________________________________________________________________________
Subject: be switching circuit.
Date: Jan 03, 2001
I am using an Aeroflash signal strobe/nav light assembly out on the wingtips. This installation uses two power supplies, one for each of the double flash units. Since I am planning on installing the Rotax and not putting on an aux alternator I will not be pushing alot of amps. These lights are pretty hungry. The question I have is this. Has anyone come up with a switching circuit so that one power supply can be used to alternately flash each wingtip. I see no reason to have both strobes flashing simultaneously. With the right timing this should effectively reduce the strobe amp draw by on half. Is my thinking right on this? Can I get some help out there on this? Thanks. Steve Hagar A143 Mesa,Az -- Steve Hagar --- hagargs(at)earthlink.net ________________________________________________________________________________
Subject: Re: Strobe switching circuit.
Date: Jan 03, 2001
Steve, Was up flying just a few days ago and it was approacing dusk so I had the strobes (the aeroflash units) and the nav lites on. I also had both GPS's, radio, cd player, intercom, and all the other stuff - microEncoder, microMonitor, electric Horizon, electric Turn & Bank, electric fuel guage and the alternator was keeping up just fine. I haven't had any problems with the current draw at all - except the landing lites which I use sparingly. Bob Jacobsen A131 From: "Steve Hagar" <hagargs(at)earthlink.net> >Subject: Strobe switching circuit. >Date: Wed, 3 Jan 2001 21:11:7 -0800 > >I am using an Aeroflash signal strobe/nav light assembly out on the >wingtips. This installation uses two power supplies, one for each of the >double flash units. Since I am planning on installing the Rotax and not >putting on an aux alternator I will not be pushing alot of amps. These >lights are pretty hungry. The question I have is this. Has anyone come up >with a switching circuit so that one power supply can be used to >alternately flash each wingtip. I see no reason to have both strobes >flashing simultaneously. With the right timing this should effectively >reduce the strobe amp draw by on half. Is my thinking right on this? Can >I get some help out there on this? >Thanks. > >Steve Hagar >A143 >Mesa,Az > >-- Steve Hagar >--- hagargs(at)earthlink.net > > ________________________________________________________________________________
Subject: pa Article in US Aviator
Date: Jan 03, 2001
Hi All, There is a really nice Europa article by "Zoom Campbell" in the final issue of US Aviator. It can be found at; www.av8r.net Bob Jacobsen A131 ________________________________________________________________________________
Date: Jan 04, 2001
ami mcfadyean wrote: > Expancel can, if you have the patience, be applied much lighter than > Superfil. And its loads cheaper and sands easier. Downside is its too soft > and marks easily; pinholes can be cured with Smoothprime or other > primer-filler worked-in with a roller. > > Duncan mcFadyean > > -----Original Message----- > From: Shaun Simpkins <shauns(at)hevanet.com> > Date: Wednesday, January 03, 2001 3:11 PM > Subject: SuperFil vs. Expancell... > > Several posters have opted for Superfill instead of the factory-supplied > Expancell for final filling. What are the differences between these two > products and what are the advantages to Superfill? > > Thinking WAY ahead... > Thanks - > > Shaun Simpkins > A207 > Having coverered the flaps, fin and stabilators with expancell (or whatever it was that the factory supplied in 1997) before switching to superfill (for the ailerons) my opinion is that the cost of superfill is worth it if you are interested in saving time. In my experience the superfill sands considerably easier. There are other advantages such as consistancy of the consistancy of the mix (couldn't think of a clearer way to put it). What it means in practice is that each batch of superfill sets to the same hardness as other batches. Others have mentioned further merits (lightness for one). Jonathan & Carla (kit 330) ________________________________________________________________________________
Date: Jan 04, 2001
Subject: DOWNS
Just about to close my wings up. Has anyone fitted tiedown strong points in the wing?. Building XS Trike or maybe taildragger with speed kit. Thanks.... Dave Park dvdpar(at)aol.com ________________________________________________________________________________
Date: Jan 04, 2001
>The deflection of the fuselage sides under the loads passed into them by the >forward >wing lift pins is 0.21 degrees per `g`. Don`t know how much the wings flex >though. > >Duncan McFadyean Thanks for that, Duncan. The wing deflection is probably largely due to the bending of the spar stubs between the two spar pins. All very complicated and too many variables. I will ask Andy next time I have access to his ear. Graham ________________________________________________________________________________
Date: Jan 04, 2001
From: Klaus Dietrich <Klaus.Dietrich(at)oracle.com>
Tony Krzyzewski , Erich D Trombley , europa(at)avnet.co.uk
we made a static load test on the assembled plane at 3,8 g and the deflection of the wing at 3,8g was 45 cm measured at the wing tip. I have also Graham's moldings and no problems or cracks during the +400 hrs flown... Klaus Graham Singleton wrote: > > >The deflection of the fuselage sides under the loads passed into them by the > >forward > >wing lift pins is 0.21 degrees per `g`. Don`t know how much the wings flex > >though. > > > >Duncan McFadyean > > Thanks for that, Duncan. The wing deflection is probably largely due to the > bending of the spar stubs between the two spar pins. All very complicated > and too many variables. > I will ask Andy next time I have access to his ear. > Graham > ________________________________________________________________________________
Subject: Re: TIE DOWNS
Date: Jan 04, 2001
You might want to talk to Dennis Vories. He added tiedowns to the outriggers and the tail spring in a simple and clever way. Monowheel, but adaptable to a trike. Not sure if any additional reinforcements were required - these areas are already plenty strong. Shaun A207 ----- Original Message ----- From: <DvdPar(at)aol.com> Subject: TIE DOWNS > Just about to close my wings up. Has anyone fitted tiedown strong points in > the wing?. Building XS Trike or maybe taildragger with speed kit. > > Thanks.... Dave Park dvdpar(at)aol.com > ________________________________________________________________________________
Date: Jan 04, 2001
45 CENTImeters????!!!! -----Original Message----- Behalf Of Klaus Dietrich Subject: Re: Wing Fairings we made a static load test on the assembled plane at 3,8 g and the deflection of the wing at 3,8g was 45 cm measured at the wing tip. I have also Graham's moldings and no problems or cracks during the +400 hrs flown... Klaus Graham Singleton wrote: >The deflection of the fuselage sides under the loads passed into them by the >forward >wing lift pins is 0.21 degrees per `g`. Don`t know how much the wings flex >though. > >Duncan McFadyean Thanks for that, Duncan. The wing deflection is probably largely due to the bending of the spar stubs between the two spar pins. All very complicated and too many variables. I will ask Andy next time I have access to his ear. Graham ________________________________________________________________________________
Date: Jan 04, 2001
From: Peter J BARWICK <peter.j.barwick(at)hsbc.com>
Subject: Re: : Re: Strobe switching circuit.
Steve, I had a look at the Aeroflash web site where it says that the power supplies provide 450 volts dc to a capacitor which is parallel to and discharged through the xenon flash tube when it is triggered. This raises a few issues:- - you could end up with both tubes in parallel with the one capacitor leading to odd timing or even neither of the tubes working. - the power supply will probably be some sort of inverter circuit which will only draw a small residual current once the capacitor is charged up, so the current saving will be limited. - there is a definite time lag between the xenon tube flashing and the capacitor re-charging for the next flash. There may not be enough time to get to 450 v before the other tube is triggered. - you will end up with long cable runs with 450 volts on them (even when everything is switched off) - cannot be too safe! - with removable wings, these long cables need to have some plugs and sockets involved. Again with 450 volts on them, assembly/disassembly could be hazardous. All in all, I would suggest that you do not pursue this idea. Regards, Peter Barwick ******************************************************************** This message and any attachments are confidential to the ordinary user of the e-mail address to which it was addressed and may also be privileged. If you are not the addressee you may not copy, forward, disclose or use any part of the message or its attachments and if you have received this message in error, please notify the sender immediately by return e-mail and delete it from your system. Internet communications cannot be guaranteed to be secure or error-free as information could be intercepted, corrupted, lost, arrive late or contain viruses. The sender therefore does not accept liability for any errors or omissions in the context of this message which arise as a result of Internet transmission. Any opinions contained in this message are those of the author and are not given or endorsed by the HSBC Group company or office through which this message is sent unless otherwise clearly indicated in this message and the authority of the author to so bind the HSBC entity referred to is duly verified. ******************************************************************** ________________________________________________________________________________
Date: Jan 04, 2001
I used mostly Expancell (FairLite ?) as supplied by Europa. Micro and Superfill were also used in relatively minor amounts. I used micro along the wing spar where there was a narrow but fairly thick layer required, near 1/8 inch in some places. Micro was also used for the filler on the wing walks with the idea that it would be less prone to denting on inadvertent contact with shoes. Superfill was used as a spot filler in small areas after most of the filling was complete, mostly because it was easy to mix in small amounts. West epoxy was used along with their low temperature hardner to allow working at low workshop temperatures of 50F or so. Cabosil (15% by volume) was added to the micro and Expancell fillers to improve spreading, as suggested long ago by Graham. Some impressions of the various fillers and their characteristics: Micro is very hard, more difficult to spread than Expancell, and takes a long time to sand. Avoid applying more than necessary to minimize any sanding required. Expancell is much easier to sand than micro. By varying the amount of filler vs epoxy the ease of spreading can be adjusted; a very thin layer with a nice feather edge can be applied smoothly when a slightly wetter batch is mixed. I used multiple thin layers to get to the required thickness in some areas -- this to reduce the required sanding by avoiding excess buildup. Superfill was used to finish up some areas, especially around the windshield, cowl, and fin joint. I found it more difficult to smoothly spread Superfill than Expancell, probably because of the inability to adjust the mix as was done with Expancell as well as the low workshop temperatures (around 60-65F by the time Superfill was used). The filler in the Superfill I received seemed coarser than the fill particles from Europa, sometimes resulting in fine lines in the surface as the filler was spread. Overall, I preferred the Expancell filler with West epoxy for its ease of use and sandability. However, workshop temperatures may have affected the apparent characteristics. John N44EU ________________________________________________________________________________
Subject: Return Hose & Stall Warning Device
Date: Jan 04, 2001
Posted on behalf of Nigel Charles, who is again being denied access by the server ! *********************************************************************** 'There is some concern over the ability of the existing rubber oil return hose (in the Rotax engine installation) to withstand the extremes of temperature created by the nearby exhaust silencer even when protected with firesleeve. It has been suggested that Teflon hose might be the answer as it can withstand temperature up to 200C as opposed to the normal limit of 130C for the usual rubber hose. I have noticed in a specialist spares catalogue that silicon hoses can withstand temperatures up to 300C. Is there any reason why this type of hose should not be used instead?' 'I have just bought the ACI Stall Warning device and very good it looks too. Although it is very easy to mount the sensor onto the Europa wing, routeing the cable and positioning the sounder looks to be more difficult, particularly retrospectively on a Classic wing. Please could anyone who has done this give me details how they went about it.' Nigel Charles ________________________________________________________________________________
Date: Jan 04, 2001
Like any gov't agency at field office level, they come in all varieties of competence and attitude. Part 91 does require separate airframe/engine/prop logbooks for all aircraft. I thought the entries therein are minimal, though, but often missed by builders -- W&B, your own airworthiness inspection as manufacturer for approving flight test, transponder/encoder certification, and even ELT test/battery due date if they got fussy. But they wanted _all_ construction minutia transferred to the ship's maintenance logs? They were dead wrong too on any interim inspection by a DAR or anybody, and a Repairman's Certificate is not required to do maintenance, just the annual. I suppose one could study the FAR's and homebuilding Advisory Circulars several times over, to prepare for these people. But after 30 years with the federal gubment, I've never heard any of the governed come up with a tactful enough way of correcting your errors. You still get irked. Only gubment can know its Regs. Regards, Fred F., A063 MJKTuck(at)cs.com wrote: > ... > I followed the advice in a little book which tells you how to certify a > homebuilt (in the US) and that said a simple log of what you did - with > dates is sufficient - together with meeting the FAA regs, etc. > ... > [FAA] wanted to know who my DAR was for inspections during the build etc - > which kind of made me gulp. They also took one look at my PFA builders > log I had been using and said words to the effect 'what the heck is this?' > They made me write all the entries out again in a 'proper FAA logbook' > along with insisting on separate engine logbook and propeller logbook > (which my little book said was not required for homebuilts. > ... > The only question she had was who was going to do the maintenance on it > and I said I was. No you can't, you're not authorized.... - not > without a repairmans certificate. ________________________________________________________________________________
Date: Jan 05, 2001
That's funny, I never had that happen, but maybe I never pulled 3 G. The fillets are designed to be flexible enough to accommodate the small amount of movement at the wing root under load. It would be nice if someone could tell us what deflection to expect per G. I must try and work it out. I should have mentioned that UBD does not use Graham's fairings. Apologies Graham if anyone construed that from my email. UBD has hand made fairings and a rather sharp lip on the socket. Tony ________________________________________________________________________________
Date: Jan 04, 2001
In my experience the superfill sands considerably >easier. >Jonathan & Carla (kit 330) > Depends how richly you mix the Expancel; if lean and light it sands very easily, albeit with a high risk of scratching. The other points you raise I agree with (i.e. consistency, time saving etc) Duncan McFadyean ________________________________________________________________________________
Date: Jan 04, 2001
Were the fairings fitted at the time of the load test? And how much did the root of the wing deflect relative to the fuselage? Duncan McFadyean -----Original Message----- From: Klaus Dietrich <Klaus.Dietrich(at)oracle.com> Subject: Re: Wing Fairings >we made a static load test on the assembled plane at 3,8 g and the deflection of >the wing at 3,8g was 45 cm measured at the wing tip. >I have also Graham's moldings and no problems or cracks during the +400 hrs >flown... >Klaus > ________________________________________________________________________________
Date: Jan 04, 2001
Subject: el!
High guys, (I'm still on one) Yesterday John Brownlow flew the Wilksch diesel powered Europa properly for the first time. I was late arriving at the airfield, I got lost and wasted half an hour driving around the Buckinghamshire countryside. Muttering. I finally called Mark on his mobile to ask where they were on the airfield and was the airplane flying. "Look Up" was the reply, and there it was. Bill Wynne's long awaiting Europa a thousand feet above my head with it's engine making a lovely smooth growl, slightly louder than a Rotax but I could still hear the airframe wind noise. After shutting down John quietly gave us the results of this early test flight. Good acceleration, short take off run. Rater of climb at least as good as any 912 Europa with a VP prop. Pressures and temperatures were all controllable. The oil temperature got a little high on climb out around 100 deg. C at 800 feet but reducing power a little halted the rise. Cruise at 2,100 rpm, 1600 ft. stabilized at 125 kts. which I thought was pretty good at the weight on the day. John was pleased with this first indication of good things to come. Mark, Martin and Phillip, who've worked so hard for this, were there, as was Dan, their new colleague. They were all delighted with the behaviour of their engine on these first three flights. I was just glad to be there, pleased I'd been invited and delighted that it all went so well. The Wilksch team is small, dedicated and has a well matched and powerful blend of skills that should ensure success in this venture. They also all have two ears and one mouth, and use them in that proportion. So often one meets brilliant innovators who are oblivious to any wisdom from elsewhere, the old Not Invented Here syndrome. Not these guys. It won't be easy but I can't recollect meeting a group of people who work together as well as these four . A privilege to know them. Graham ________________________________________________________________________________
Date: Jan 04, 2001
Subject: el
I forgot to mention, this engine is derated to 80HP for the early part of the program. Graham ________________________________________________________________________________
Date: Jan 05, 2001
JohnJMoran(at)aol.com wrote: >.... > I used micro along the > wing spar where there was a narrow but fairly thick layer required, near 1/8 > inch in some places. > .... Exactly what I did. Poly Fiber says SuperFil is good to 1/4", but any subsequent cracks will pain me deeply. I swiped a not-too-dry micro layer on that depression at the spar (Mk 1), prior to the Super Fil, on the theory that the laminating resin is elastically similar to the underlying laminate. Good to hear others ain't takin' no chances. Got a reinforcing message there when seeing how much flex there is those wings. Totally agree also on your other observations re SuperFil vs. FairLite. Regards, Fred F, A063 ________________________________________________________________________________
Date: Jan 05, 2001
For U.S. builders, the following was just posted to rec.aviation.homebuilt. It counts as a "sample of one," the logical fault that besets business managers, according to Prof. Tom Peters, of fame in the "Excellence" series of management theory texts. But FWIW.... (and a computer programmer don't understand about nonvolatile backup?) Regards, Fred F., A063 -------- I used to keep mine on the computer along with pictures, text, and receipts. I could print the entire thing and present it however I wanted. Then my hard drive tanked. Being a computer programmer, I was caught totally by surprise, and lost EVERYTHING!!! A quick call to the FAA FSDO answered the following questions: 1) What should I do? ANS: Take pictures of where I am at and create an entry stating what I had done. 2) What do I really need? ANS: Not daily or even weekly updates, just accomplishments (i.e. I finished the bulkheads on 6/20/2000). Pictures showing that YOU accomplished 51% of the building. Basically, I was also told that during the inspection, there should be enough discussion so that the inspector will be able to tell that you built it. Take that for what it is worth, it was one guy in the FAA office. Rob -------- ________________________________________________________________________________
Date: Jan 03, 2001
I always use an inexpensive automatic charger made by Gunsons. Available in the UK for around 20 from Argos. I use it on all the Gas RC batteries we sell as well as my own batteries on cars and aircraft. It delivers a high charge to bring the battery up to charge and then reduces the charge automatically until it virtually switches off. Far better than a trickle charge and hardly any more expensive. Jerry LTS(at)avnet.co.uk http://www.avnet.co.uk/touchdown ----- Original Message ----- From: John Cliff <john(at)crixbinfield.freeserve.co.uk> Subject: RE: Battery Charging > Forwarded from the bounce bin. Message is from > "Cliff Shaw" > > *************************************************** > > Martin > > Good you ask about trickle charging. I am now working on a charger for Bob;' > Europa, Beep Beep, that will do just that. > > We picked up a 600ma plug in the wall 12 volt charger. I tested it with a > multimeter and it does charge around 1/2 amp when the battery is down. That > would be OK for a overnight "kick" but too much to leave on for weeks at a > time. I am installing a 30 ohm resister in series with the charge line to > the battery to reduce the charge rate to 50 or 60 ma. I think this is much > better for long term use. The voltage on the battery with the trickle should > be not more than 14.2 volts. I will be happier with 13.8 volts. It voltage > depends on the battery and the temperature. > > I hope this helps. Use this info with your desecration, it comes from my > experience, not an engineer degree. > > Have fun > Cliff Shaw > > ________________________________________________________________________________
From: "David Cripps" <david.cripps(at)spsystems.com>
Subject: Battery Charging
Date: Jan 05, 2001
I have also used this same Gunson charger in automatic mode on my aircraft battery (normal lead acid)and found it to be quick and effective. However, I have always disconnected the aircraft cables from both the +ve and -ve terminals of the battery prior to charging. Is this strictly necessary? One other question concerns auxiliary power sockets for those occasions where the battery has run down for some reason and you're far from a battery charger. How do people wire such sockets up to the battery? Is it simply direct to the terminals? What sort of socket do you use and where do you mount it? Could such sockets also be used for trickle or fast charging the battery without having to take the cowls off? Any thoughts most welcome. David GBWJH -----Original Message----- From: owner-europa(at)aztec.houxou.com Subject: Re: Battery Charging I always use an inexpensive automatic charger made by Gunsons. Available in the UK for around 20 from Argos. I use it on all the Gas RC batteries we sell as well as my own batteries on cars and aircraft. It delivers a high charge to bring the battery up to charge and then reduces the charge automatically until it virtually switches off. Far better than a trickle charge and hardly any more expensive. Jerry LTS(at)avnet.co.uk http://www.avnet.co.uk/touchdown ----- Original Message ----- From: John Cliff <john(at)crixbinfield.freeserve.co.uk> Subject: RE: Battery Charging > Forwarded from the bounce bin. Message is from > "Cliff Shaw" > > *************************************************** > > Martin > > Good you ask about trickle charging. I am now working on a charger for Bob;' > Europa, Beep Beep, that will do just that. > > We picked up a 600ma plug in the wall 12 volt charger. I tested it with a > multimeter and it does charge around 1/2 amp when the battery is down. That > would be OK for a overnight "kick" but too much to leave on for weeks at a > time. I am installing a 30 ohm resister in series with the charge line to > the battery to reduce the charge rate to 50 or 60 ma. I think this is much > better for long term use. The voltage on the battery with the trickle should > be not more than 14.2 volts. I will be happier with 13.8 volts. It voltage > depends on the battery and the temperature. > > I hope this helps. Use this info with your desecration, it comes from my > experience, not an engineer degree. > > Have fun > Cliff Shaw > > ________________________________________________________________________________
Date: Jan 05, 2001
I have fitted an auxiliary socket for this purpose. Best to fit it as close as possible to the battery, and wire it direct to the battery using at least the same size cable used for the starter motor supply. Our battery is in the engine compartment, so I mounted the socket on top of the foot well right next to the battery,. I made a small access door in the upper cowl on the same lines as the ones used for oil and water checks. It came in very useful last winter when I had to make some sub zero starts on an ageing battery. There are charging plug and sockets available, as used on electric fork lift trucks, which are rated at 100+ amps, these are ideal to carry the starting current required for a jump start. Look out for the smaller versions of these though, some of them are far to big and heavy for the job. I can't see any reason why the battery should be totally disconnected for charging, especially as the master switch should effectively cut the connection to the rest of the electric's. Jim > I have also used this same Gunson charger in automatic mode on my aircraft > battery (normal lead acid)and found it to be quick and effective. However, > I have always disconnected the aircraft cables from both the +ve and -ve > terminals of the battery prior to charging. Is this strictly necessary? > > One other question concerns auxiliary power sockets for those occasions > where the battery has run down for some reason and you're far from a battery > charger. How do people wire such sockets up to the battery? Is it simply > direct to the terminals? What sort of socket do you use and where do you > mount it? Could such sockets also be used for trickle or fast charging the > battery without having to take the cowls off? > > Any thoughts most welcome. > > David > GBWJH > > -----Original Message----- > From: owner-europa(at)aztec.houxou.com > Subject: Re: Battery Charging > > > I always use an inexpensive automatic charger made by Gunsons. Available in > the UK for around 20 from Argos. I use it on all the Gas RC batteries we > sell as well as my own batteries on cars and aircraft. It delivers a high > charge to bring the battery up to charge and then reduces the charge > automatically until it virtually switches off. Far better than a trickle > charge and hardly any more expensive. > > Jerry > > LTS(at)avnet.co.uk > http://www.avnet.co.uk/touchdown > ----- Original Message ----- > From: John Cliff <john(at)crixbinfield.freeserve.co.uk> > Subject: RE: Battery Charging > > > > Forwarded from the bounce bin. Message is from > > "Cliff Shaw" > > > > *************************************************** > > > > Martin > > > > Good you ask about trickle charging. I am now working on a charger for > Bob;' > > Europa, Beep Beep, that will do just that. > > > > We picked up a 600ma plug in the wall 12 volt charger. I tested it with a > > multimeter and it does charge around 1/2 amp when the battery is down. > That > > would be OK for a overnight "kick" but too much to leave on for weeks at a > > time. I am installing a 30 ohm resister in series with the charge line to > > the battery to reduce the charge rate to 50 or 60 ma. I think this is > much > > better for long term use. The voltage on the battery with the trickle > should > > be not more than 14.2 volts. I will be happier with 13.8 volts. It voltage > > depends on the battery and the temperature. > > > > I hope this helps. Use this info with your desecration, it comes from my > > experience, not an engineer degree. > > > > Have fun > > Cliff Shaw > > > > > > ________________________________________________________________________________
Date: Jan 05, 2001
Subject: Re: trim lines
Hi Raimo, In this case, 'highlight' means to make more visible. If you rub a pencil tip over the trim lines the pencil lead will make the trim line more obvious to see; a bit like brass rubbing (if that doesn't add to your confusion!). Best Regards Andy Draper Technical Manager e-mail andy@europa-aircraft.com >>> "RWM-SYSTEMS" 02/01/01 20:11:00 >>> Should I read the manual more carefully? They say just right "use a pencil to highlight the lines" (page 11-1 XS). I did not understand what means "highlight" when reading. No I do. It is concrete order. Funny Building! Raimo Toivio #417 ________________________________________________________________________________
From: "John Cliff" <john(at)crixbinfield.freeserve.co.uk>
Subject: stance with a mysterious reinforcement...
Date: Jan 05, 2001
Forwarded from the bounce bin. Message is from "Shaun Simpkins" *********************************************************** All: On the starboard side of the rearmost section of the central tunnel of my XS cockpit module is a circular reinforcement about 5" in diameter. This area is not mentioned in the builder's manual. It is placed facing the fuel valve hard point in such a way as to suggest that it is where an access panel for the valve is to be placed. But it would seem that the flap drive rod would run right across the opening. Can anyone tell me what this area is for? Thanks - Shaun Simpkins A207 ________________________________________________________________________________
Date: Jan 05, 2001
JohnJMoran(at)aol.com wrote: > Superfill was used to finish up some areas, especially around the > windshield, cowl, and fin joint. I found it more difficult to smoothly spread > Superfill than Expancell, probably because of the inability to adjust the mix > as was done with Expancell as well as the low workshop temperatures (around > 60-65F by the time Superfill was used). The filler in the Superfill I > received seemed coarser than the fill particles from Europa, sometimes > resulting in fine lines in the surface as the filler was spread. > > Overall, I preferred the Expancell filler with West epoxy for its ease of use > and sandability. However, workshop temperatures may have affected the > apparent characteristics. > > John N44EU I agree with John that the temperature required for Superfill is a downside. On the container both the working and cure time are stated at 77F. Jonathan & Carla (kit 330) ________________________________________________________________________________
Date: Jan 05, 2001
Now that several opinions are in, perhaps I can summarize what's been said since I started the thread. 1. Superfil has better consistency than Expancel + Epoxy, but this is user dependent. 2. Superfil mix ratio can't be changed. 3. Superfil must be applied and cured at fairly high temps (77F) 4. Superfil sands easily, but not necessarily any easier than Expancel 5. Superfil is harder and therefore more resistant to denting than Expancel, but is somewhat rougher and may not offer as smooth a fill 6. Superfil is lighter than Expancel+Epoxy 7. Superfil may save some time 8. Superfil is not good for thick buildups beyond 1/8" So from this, there isn't a clear win for either option. The issue of lightness and durability seems most germaine, so let me follow these opinions. 1. Just how much filler are we talking about on a typical XS? 1 Gallon? 2. How much lighter is Superfil than Expancel+Epoxy? Poly-Fiber quotes Superfil at 3.7lbs/gal. 3. How much lighter in total? A few ounces? Several pounds? 4. Expancel is heat-expanded gas-filled plastic spheres. We get the expanded stuff. Does Expancel suffer further expansion under post cure/use? Does Superfil? Thanks - Shaun Simpkins A207 ----- Original Message ----- From: "Jonathan Moyle" <jmoyle(at)epo.org> Subject: Re: SuperFil vs. Expancell... > > > JohnJMoran(at)aol.com wrote: > > > Superfill was used to finish up some areas, especially around the > > windshield, cowl, and fin joint. I found it more difficult to smoothly spread > > Superfill than Expancell, probably because of the inability to adjust the mix > > as was done with Expancell as well as the low workshop temperatures (around > > 60-65F by the time Superfill was used). The filler in the Superfill I > > received seemed coarser than the fill particles from Europa, sometimes > > resulting in fine lines in the surface as the filler was spread. > > > > Overall, I preferred the Expancell filler with West epoxy for its ease of use > > and sandability. However, workshop temperatures may have affected the > > apparent characteristics. > > > > John N44EU > > I agree with John that the temperature required for Superfill is a downside. On > the container both the working and cure time are stated at 77F. > > Jonathan & Carla (kit 330) > > ________________________________________________________________________________
Date: Jan 05, 2001
For my two cents guys, The only way you can get expancel to sand "way easier" is to mix it resin rich which in turn spreads easy, sands easy, is more dent resistant, and is much heavier than Superfill. Cure times are based mainly on the epoxy and not the additives we add to it. Most epoxies will not cure below 65 degrees F. A little heat applied with a hair dryer will assist in spreadability greatly with either product. You can do thicker lay-ups with Superfill but you need to put a layer of glass every 1/8 in. for reinforcement. Not a bad idea with ANY filler actually. With that all said, both products work well, although my experience has been for second or third applications, Superfill leaves a better "edge".What I mean is it doesn't try to soak into the first layer of filler leaving you with a hard edge around the application. I still do all of my primary filling with expancel and top it with Superfill. Nuff said. Jim Thursby ----- Original Message ----- From: "Shaun Simpkins" <shauns(at)hevanet.com> Subject: Re: SuperFil vs. Expancell... > Now that several opinions are in, perhaps I can summarize what's been said > since I started the thread. > > 1. Superfil has better consistency than Expancel + Epoxy, but this is user > dependent. > 2. Superfil mix ratio can't be changed. > 3. Superfil must be applied and cured at fairly high temps (77F) > 4. Superfil sands easily, but not necessarily any easier than Expancel > 5. Superfil is harder and therefore more resistant to denting than Expancel, > but is somewhat > rougher and may not offer as smooth a fill > 6. Superfil is lighter than Expancel+Epoxy > 7. Superfil may save some time > 8. Superfil is not good for thick buildups beyond 1/8" > > So from this, there isn't a clear win for either option. The issue of > lightness and durability seems > most germaine, so let me follow these opinions. > > 1. Just how much filler are we talking about on a typical XS? 1 Gallon? > 2. How much lighter is Superfil than Expancel+Epoxy? Poly-Fiber quotes > Superfil at 3.7lbs/gal. > 3. How much lighter in total? A few ounces? Several pounds? > 4. Expancel is heat-expanded gas-filled plastic spheres. We get the > expanded stuff. Does Expancel > suffer further expansion under post cure/use? Does Superfil? > > Thanks - > Shaun Simpkins > A207 > ----- Original Message ----- > From: "Jonathan Moyle" <jmoyle(at)epo.org> > Subject: Re: SuperFil vs. Expancell... > > > > > > > > JohnJMoran(at)aol.com wrote: > > > > > Superfill was used to finish up some areas, especially around the > > > windshield, cowl, and fin joint. I found it more difficult to smoothly > spread > > > Superfill than Expancell, probably because of the inability to adjust > the mix > > > as was done with Expancell as well as the low workshop temperatures > (around > > > 60-65F by the time Superfill was used). The filler in the Superfill I > > > received seemed coarser than the fill particles from Europa, sometimes > > > resulting in fine lines in the surface as the filler was spread. > > > > > > Overall, I preferred the Expancell filler with West epoxy for its ease > of use > > > and sandability. However, workshop temperatures may have affected the > > > apparent characteristics. > > > > > > John N44EU > > > > I agree with John that the temperature required for Superfill is a > downside. On > > the container both the working and cure time are stated at 77F. > > > > Jonathan & Carla (kit 330) > > > > > > ________________________________________________________________________________
Subject: Re: Assistance with a mysterious reinforcement...
Date: Jan 05, 2001
Hi John As a result of speaking to Neville at the factory some months ago, I fitted an inspection panel in my XS tunnel - exactly where you describe. Neville said at the time that they were to start including one in later cockpit modules. Mine is No. 359, btw. You are quite correct - the flap push/pull rod does cross this area but one can still get at the hoses. Regards, Ron Jones. ________________________________________________________________________________
Subject:
Date: Jan 05, 2001
For computer data storage, u can't beat a CD Writer. Except maybe with a CD ReWriter. Get a cheap CD burner and copy it all anyways. Make a stack of them. It's easy. It's cheap. Give 'em to your friends and family. Then you won't have to sweat it later. Nic xs145 :) ________________________________________________________________________________
Date: Jan 05, 2001
Poly-Fiber quotes >Superfil at 3.7lbs/gal. >Shaun Simpkins >A207 Thats incredibly heavy. For comparison, water is 10lbs/gallon (imp) or Blue foam 0.32lbs/gal (more than ten times lighter than Superfil!). Expancel can be mixed at 1.16lbs/gal but is fun to apply at this density (the recipe for which is 17ml epoxy + 15ml fume silica + 17ml Q-cel + 120ml Expancel. All volumes are bulked/loose. High-shear mixing needed (strong wrists) until putty-like and the placed filler "sealed down" with a hot spatula before it sets). Primer-fillers are typically 20 to 25 lbs/gal (dry film density). The moral is that the foam cores need to be perfect to avoid having to fill any more than necessary and the use of primer-filler should be minimised. Duncan McFadyean ________________________________________________________________________________
Date: Jan 05, 2001
The original poster of this question may have been me. Thanks. Since then, Paul Stewart sent me some pictures of an Andair installation he and Graham have been working on that places the selector valve on the raised foot of the tunnel on the pilot's side. After sitting in my cockpit module and making the obligatory airplane noises while studying the problem, I think this may be - ergonomically - the optimum location for the valve, esp. if you are using the Andair valve. The factory position encourages you to use your left (flying) hand in a reach-across action to actuate the valve, whereas the tunnel foot position requires you to use your right (nonflying) hand in a simpler motion. The Andair valve also requires that you raise a lock knob to turn the selector, which is far easier to do when it's flat on the floor. And it's easier to read as well. Disadvantages: you have to drill another access hole in the floor behind the wheel wheel to access the connectors. I believe that makes 4 holes - two for the outlets, one for the gascolator, one for the selector? Bob Jacobsen may have another opinion on this...Bob? Shaun Simpkins A207 ----- Original Message ----- From: "jronjones" <jronjones(at)msn.com> Subject: Re: Assistance with a mysterious reinforcement... > Hi John > > As a result of speaking to Neville at the factory some months ago, I fitted > an inspection panel in my XS tunnel - exactly where you describe. Neville > said at the time that they were to start including one in later cockpit > modules. Mine is No. 359, btw. > You are quite correct - the flap push/pull rod does cross this area but > one can still get at the hoses. > > Regards, > Ron Jones. > > ________________________________________________________________________________
Date: Jan 05, 2001
Would someone verify my calculations that Superfill is like plastic wood, in the sense that it weighs about 28 lbs/ft3, the same as Spruce? Its advertised as 3.68 lbs/US gallon. So if my density conversion is correct, then anyone putting 1/8'th of an inch above the spar is adding the equivalent of a 1/8'th inch wooden spar cap - as far as weight is concerned - without any structural benefit whatsoever. Another cut on this is to say that it weighs about 0.8 lbs/yd sq when 1mm thick. Richard Mole > -----Original Message----- > From: Shaun Simpkins [SMTP:shauns(at)hevanet.com] > Sent: Friday, January 05, 2001 3:13 PM > To: Jonathan Moyle; Europa club > Subject: Re: SuperFil vs. Expancell... > > Now that several opinions are in, perhaps I can summarize what's been said > since I started the thread. > > 1. Superfil has better consistency than Expancel + Epoxy, but this is user > dependent. > 2. Superfil mix ratio can't be changed. > 3. Superfil must be applied and cured at fairly high temps (77F) > 4. Superfil sands easily, but not necessarily any easier than Expancel > 5. Superfil is harder and therefore more resistant to denting than > Expancel, > but is somewhat > rougher and may not offer as smooth a fill > 6. Superfil is lighter than Expancel+Epoxy > 7. Superfil may save some time > 8. Superfil is not good for thick buildups beyond 1/8" > > So from this, there isn't a clear win for either option. The issue of > lightness and durability seems > most germaine, so let me follow these opinions. > > 1. Just how much filler are we talking about on a typical XS? 1 Gallon? > 2. How much lighter is Superfil than Expancel+Epoxy? Poly-Fiber quotes > Superfil at 3.7lbs/gal. > 3. How much lighter in total? A few ounces? Several pounds? > 4. Expancel is heat-expanded gas-filled plastic spheres. We get the > expanded stuff. Does Expancel > suffer further expansion under post cure/use? Does Superfil? > > Thanks - > Shaun Simpkins > A207 > ________________________________________________________________________________
Date: Jan 05, 2001
Apologies. There`s a misprint in my posting below; measured density of Expancel was 3.16 lbs/gal (or 2.65lbs/US gal for comparison with Superfil). Duncan McFadyean -----Original Message----- From: ami mcfadyean <ami(at)mcfadyean.freeserve.co.uk> Europa club Date: Friday, January 05, 2001 9:10 PM Subject: Re: SuperFil vs. Expancell... > > Poly-Fiber quotes >>Superfil at 3.7lbs/gal. > >>Shaun Simpkins >>A207 > > >Thats incredibly heavy. > For comparison, water is 10lbs/gallon (imp) or Blue foam 0.32lbs/gal (more >than ten times lighter than Superfil!). >Expancel can be mixed at 1.16lbs/gal but is fun to apply at this density >(the recipe for which is 17ml epoxy + 15ml fume silica + 17ml Q-cel + 120ml >Expancel. All volumes are bulked/loose. High-shear mixing needed (strong >wrists) until putty-like and the placed filler "sealed down" with a hot >spatula before it sets). > >Primer-fillers are typically 20 to 25 lbs/gal (dry film density). > >The moral is that the foam cores need to be perfect to avoid having to fill >any more than necessary and the use of primer-filler should be minimised. > >Duncan McFadyean > ________________________________________________________________________________
Date: Jan 06, 2001
You can do thicker lay-ups with Superfill but you need to put a layer of glass every 1/8 in. for reinforcement. Not a bad idea with ANY filler actually. I am using deck cloth from A/S for this purpose. Wherever I have a thick layer of Superfil I lay on a layer of this cloth. It only weight 1 1/4 oz per yard. Tony ________________________________________________________________________________
Date: Jan 05, 2001
In re: density calculation At 7.481 gal/cu ft your conversion is correct, although, out of ignorance I can't comment on the plastic wood comparison. One of my reference texts shows white fir at 28.1 lb/cu ft, white pine at 34 lb/cu ft, and several others (hardwoods, not conifers) at higher density. Spruce is not listed but you are probably correct (and if not it's close enough). Best regards, Rob Housman A070 -----Original Message----- On Behalf Of R.H.Mole(at)open.ac.uk Sent: Friday, January 05, 2001 1:27 PM Subject: RE: SuperFil vs. Expancell... Would someone verify my calculations that Superfill is like plastic wood, in the sense that it weighs about 28 lbs/ft3, the same as Spruce? Its advertised as 3.68 lbs/US gallon. So if my density conversion is correct, then anyone putting 1/8'th of an inch above the spar is adding the equivalent of a 1/8'th inch wooden spar cap - as far as weight is concerned - without any structural benefit whatsoever. Another cut on this is to say that it weighs about 0.8 lbs/yd sq when 1mm thick. Richard Mole > -----Original Message----- > From: Shaun Simpkins [SMTP:shauns(at)hevanet.com] > Sent: Friday, January 05, 2001 3:13 PM > To: Jonathan Moyle; Europa club > Subject: Re: SuperFil vs. Expancell... > > Now that several opinions are in, perhaps I can summarize what's been said > since I started the thread. > > 1. Superfil has better consistency than Expancel + Epoxy, but this is user > dependent. > 2. Superfil mix ratio can't be changed. > 3. Superfil must be applied and cured at fairly high temps (77F) > 4. Superfil sands easily, but not necessarily any easier than Expancel > 5. Superfil is harder and therefore more resistant to denting than > Expancel, > but is somewhat > rougher and may not offer as smooth a fill > 6. Superfil is lighter than Expancel+Epoxy > 7. Superfil may save some time > 8. Superfil is not good for thick buildups beyond 1/8" > > So from this, there isn't a clear win for either option. The issue of > lightness and durability seems > most germaine, so let me follow these opinions. > > 1. Just how much filler are we talking about on a typical XS? 1 Gallon? > 2. How much lighter is Superfil than Expancel+Epoxy? Poly-Fiber quotes > Superfil at 3.7lbs/gal. > 3. How much lighter in total? A few ounces? Several pounds? > 4. Expancel is heat-expanded gas-filled plastic spheres. We get the > expanded stuff. Does Expancel > suffer further expansion under post cure/use? Does Superfil? > > Thanks - > Shaun Simpkins > A207 > ________________________________________________________________________________
Date: Jan 05, 2001
Calculations seem good, but the situation on the Mk 1 spar is more accurately described as thick cloth overlaps that have to faired out, plus the fact that the foam cores are just a bit narrower than the spar. On mine, the depression generally was about 1/16", but tapered quickly moving fore/aft. The amount of filler used is most dependent upon the visual result desired, followed by techniques used to minimize sanding. The above mess at the spar will take much more filler if one desires the preserve the curvature of the airfoil at the spar area to the extent that the gloss coat shows no distortion (requires a dial indicator tool to achieve). Or you can just get it smooth to the swipe of the hand. A 24" sanding spline will take more filler than a 12", but the better result might be desired. Go really wild and use a 48" metal straightedge to check you work, preselect a spot for the fly-in trophy, but order up more filler. On my wings and flying surfaces, the glass fibers are just about visible through the SuperFil on about 40% of the surface area, so the average thickness is likely less than than 1 mm (ignoring the spar problem). This implies also that you have to be careful about trying to sand off too much, because sand through glass fiber and the structure has unknown integrity. Something has to be used, and it appears nothing is lighter than SuperFil, except as pointed out here, other formulations that are about as dry as practically possible. But too dry and you run the risk that there's insufficient epoxy for a good bond a few years down the road. Or maybe not, who knows. You might also value ease of use, as especially on the Mark 1, the job is no stroll in the park. Just like Bondo on an auto repair, its the many finishing passes that take the time and energy. XS builders have a break in that should 1 gal. be enough, subtract what winds up in the ShopVac, and relative weight comparison of any lightweight filler comes down to a few ounces. Just opinions mindya, but no longer a virgin in this area. Regards, Fred F., A063 Richard Mole wrote: > > Would someone verify my calculations that Superfill is like plastic wood, in > the sense that it weighs about 28 lbs/ft3, the same as Spruce? > > Its advertised as 3.68 lbs/US gallon. So if my density conversion is > correct, then anyone putting 1/8'th of an inch above the spar is adding the > equivalent of a 1/8'th inch wooden spar cap - as far as weight is concerned > - without any structural benefit whatsoever. Another cut on this is to say > that it weighs about 0.8 lbs/yd sq when 1mm thick. ________________________________________________________________________________
Date: Jan 06, 2001
Subject: Some Measurements
Hi All, Need some help. I want to bring in my fresh air behind the panel in a near straight shot to the eyeball vents. Can someone with the classic MK-1 912S engine installation take a look tell me how much room between the engine or carbs and the firewall. I am interested in the area that is 12 inches from each outside edge of the fuselage directly on top of the footwell shelf. I am thinking about putting a flange or maybe an RV style heater box on each side right in this area and I'm not ready to install the engine yet. Maybe there's someone out there that has their cowlings off right now. Would it be sound design to think about feeding in fresh air to the cabin from a common chin placed NACA scoop that might feed cool air to a carb box, or would a carb cool air box inlet have to be on top of the cowl like the XS? I'm actually working on my panel with the eyeball vent supply ducts but it's funny how so many things "hinge" on each other. Thanks. Troy ________________________________________________________________________________
From: "Roger Sheridan" <rogersheridan(at)btinternet.com>
Subject: Sight Gauge Tubing
Date: Jan 06, 2001
I had been planning to use polyurethane tubing for this, but the sample piece I just removed from my fuel can is badly discoloured and slightly expanded after 2 months exposure to auto fuel - not ideal. Has anybody identified a material that does not degrade in this way? Thanks for any feedback. Rog Sheridan. ________________________________________________________________________________
Subject: Fuel Sight Gauge Tubing
Date: Jan 06, 2001
Hi! Roger. I read something about this recently ..... the original tubing Europa supplied has been superceded by a different specification tubing . The new specification happens to be slightly smaller in diameter and must replace all the larger diameter on first annual inspection. Hopefully this will promote someone to make a authoritative statement . I know that I'm a bit miffed about it, this will be the third time of reworking the damn fuel pipes, plus I used the redundant type in my special seat back sight gauge. ! Regards Bob Harrison, G-PTAG -----Original Message----- On Behalf Of Roger Sheridan Sent: 06 January 2001 16:48 Subject: Fuel Sight Gauge Tubing I had been planning to use polyurethane tubing for this, but the sample piece I just removed from my fuel can is badly discoloured and slightly expanded after 2 months exposure to auto fuel - not ideal. Has anybody identified a material that does not degrade in this way? Thanks for any feedback. Rog Sheridan. ________________________________________________________________________________
Date: Jan 06, 2001
<005c01c0773a$414abf00$d51abc3e@default> >while studying the problem, I think this may be - ergonomically - the >optimum location for the valve, >esp. if you are using the Andair valve. > the tunnel foot position requires you to use your right (nonflying) >hand in a simpler motion. >The Andair valve also requires that you raise a lock knob to turn the >selector, which is far easier to >do when it's flat on the floor. And it's easier to read as well. >Disadvantages: you have to drill another access hole in the floor behind >the wheel wheel to access the connectors. IMHO it makes more sense to fit a removeable bulkhead at the rear of the wheel slot. I made it curved to wrap round the wheel. It pays at a later date, flying from muddy fields, to have a mudguard above the wheel so don't make it so tight there's no room for it. Graham ________________________________________________________________________________
Date: Jan 06, 2001
Hi! Again Roger. Just got my brain into gear !!! The TECH TALK section in the Europa Aircraft News Dec. 2000 has an item on the blessed pipes ! However it reads like you are OK with Polyurethane ? The correct hose from Europa is 10mm dia. The 12mm dia is PVC and no longer suitable. Regards again . Bob Harrison G-PTAG -----Original Message----- On Behalf Of Bob.Harrison Sent: 06 January 2001 20:45 Subject: RE: Fuel Sight Gauge Tubing Hi! Roger. I read something about this recently ..... the original tubing Europa supplied has been superceded by a different specification tubing . The new specification happens to be slightly smaller in diameter and must replace all the larger diameter on first annual inspection. Hopefully this will promote someone to make a authoritative statement . I know that I'm a bit miffed about it, this will be the third time of reworking the damn fuel pipes, plus I used the redundant type in my special seat back sight gauge. ! Regards Bob Harrison, G-PTAG -----Original Message----- On Behalf Of Roger Sheridan Sent: 06 January 2001 16:48 Subject: Fuel Sight Gauge Tubing I had been planning to use polyurethane tubing for this, but the sample piece I just removed from my fuel can is badly discoloured and slightly expanded after 2 months exposure to auto fuel - not ideal. Has anybody identified a material that does not degrade in this way? Thanks for any feedback. Rog Sheridan. ________________________________________________________________________________
Date: Jan 06, 2001
Good point, Graham. The removeable bulkhead, together with the starboard tunnel access hole now provided with the XS cockpit modules, should give all the accessibility needed for the valve. And, perhaps, the rudder pulleys as well. Shaun ----- Original Message ----- From: "Graham Singleton" <grasingleton(at)avnet.co.uk> Subject: Re: Assistance with a mysterious reinforcement... > >while studying the problem, I think this may be - ergonomically - the > >optimum location for the valve, > >esp. if you are using the Andair valve. > > the tunnel foot position requires you to use your right (nonflying) > >hand in a simpler motion. > >The Andair valve also requires that you raise a lock knob to turn the > >selector, which is far easier to > >do when it's flat on the floor. And it's easier to read as well. > >Disadvantages: you have to drill another access hole in the floor behind > >the wheel wheel to access the connectors. > > IMHO it makes more sense to fit a removeable bulkhead at the rear of the > wheel slot. I made it curved to wrap round the wheel. It pays at a later > date, flying from muddy fields, to have a mudguard above the wheel so don't > make it so tight there's no room for it. > > Graham > > ________________________________________________________________________________
Subject: Site probems
Date: Jan 06, 2001
Hi All, For the folks who occasionally browse my WEB site you may have noticed that it has appears to not have been updated for some time. Unfortunately I have had an ongoing saga because the ISP has changed owners. The new owner migrated it to another machine and its been pretty well down hill from there. I am now at the stage where I can update it, but you will need to use the URL including the index page in order to view the most recent updates. http://pma.obtero.net/index.html You may also need to manually refresh pages to ensure that you are looking at the most recent version. Hopefully between myself and the ISP we will have it straightened out soon. Cheers, Paul (363) ________________________________________________________________________________
From: "flying" <paul-d.stewart.fly(at)virginnet.co.uk>
Date: Jan 07, 2001
A curved bulkhead following the line of the rear curve of the tunnel certainly leaves more space around the fuel selector area than the original plywood one suggested in the manual. Made up a template from roofing lead (not nicked I promise) tapped onto place with a mallet, layed up 3 plies of bid over clingfilm and finally layed up a couple of brackets to take ancor nuts for fixing. I've got a couple of pics if anyone is interested. regards Paul Stewart ----- Original Message ----- From: Shaun Simpkins <shauns(at)hevanet.com> Subject: Re: Assistance with a mysterious reinforcement... > Good point, Graham. The removeable bulkhead, together with the starboard > tunnel access hole now provided with the XS cockpit modules, should give all > the accessibility needed for the valve. And, perhaps, the rudder pulleys as > well. > > Shaun > ----- Original Message ----- > From: "Graham Singleton" <grasingleton(at)avnet.co.uk> > Subject: Re: Assistance with a mysterious reinforcement... > > > > >while studying the problem, I think this may be - ergonomically - the > > >optimum location for the valve, > > >esp. if you are using the Andair valve. > > > the tunnel foot position requires you to use your right (nonflying) > > >hand in a simpler motion. > > >The Andair valve also requires that you raise a lock knob to turn the > > >selector, which is far easier to > > >do when it's flat on the floor. And it's easier to read as well. > > >Disadvantages: you have to drill another access hole in the floor behind > > >the wheel wheel to access the connectors. > > > > IMHO it makes more sense to fit a removeable bulkhead at the rear of the > > wheel slot. I made it curved to wrap round the wheel. It pays at a later > > date, flying from muddy fields, to have a mudguard above the wheel so > don't > > make it so tight there's no room for it. > > > > Graham > > > > > ________________________________________________________________________________
Date: Jan 07, 2001
Subject: d (5 minute) epoxy mixing ratio
Hello all. The construction manual as well as other separate information is quite specific about the mixing ratios of the Araldite 420, but I have not seen specific information about the Araldite 2012, more commonly known as 'Rapid' or 5 minute epoxy. The Araldite 2012 epoxy as supplied in the kit, comes in a box with two equal sized tubes. I have not been able to locate any information regarding the mixing ration of this product. It doesn't say on the box, nor with the literature that comes with the epoxy. I also could not locate it on the Araldite web site. Should one assume that since it comes in equal sized tubes, that it is supposed to be a 50/50 mixed product? I glued some test pieces of steel and other things together (with a little flox) using a 50/50 mix. It seems to have worked, and the working time was in the 5 - 8 minute range. After that, it got quite rigid quite fast! Jeff A191 ________________________________________________________________________________
Date: Jan 07, 2001
Subject: Re: Rapid (5 minute) epoxy mixing ratio - Thanks
Thanks Chris & Susan. Not too long after I sent my message, I did some more general searching around the web and found a couple charts that show a 100:100/100:100 (whatever that means) mix. I took that to mean 50/50. Someone suggested that if 5 minutes isn't enough working time, that you can go to just about any large hobby store and get a 'slower' epoxy, such as 15 minutes. It's still reasonably quick, but gives you a little more time to 'get things right'. I noticed with the 5 minute stuff that you have better get it right soon, or you're in deep bandini. Jeff A191 Chris and Susan Beck wrote: > Hi, Jeff. The 2012 is indeed 50/50 mix ratio. It seems to be pretty good > stuff. We just ran out, so I bought some 5-minute stuff from Wicks > Aircraft. Looks about the same, but it came in plastic bottles and isn't > quite as thick. > > Have fun! > > Chris A159 > > JLW wrote: > > > Hello all. > > > > The construction manual as well as other separate information is > > quite specific about the mixing ratios of the Araldite 420, but I have > > not seen specific information about the Araldite 2012, more commonly > > known as 'Rapid' or 5 minute epoxy. The Araldite 2012 epoxy as supplied > > in the kit, comes in a box with two equal sized tubes. I have not been > > able to locate any information regarding the mixing ration of this > > product. It doesn't say on the box, nor with the literature that comes > > with the epoxy. I also could not locate it on the Araldite web site. > > Should one assume that since it comes in equal sized tubes, that it is > > supposed to be a 50/50 mixed product? I glued some test pieces of steel > > and other things together (with a little flox) using a 50/50 mix. It > > seems to have worked, and the working time was in the 5 - 8 minute > > range. After that, it got quite rigid quite fast! > > > > Jeff A191 > > ________________________________________________________________________________
Date: Jan 07, 2001
Oh, one more thing. Here is the link to one of the charts I've seen on the stuff. They have charts like this on many of the Araldite 2000 series products, as well as numerous others. They're all pdf files, so they print nicely. If you back up one directory, you'll see a large number of pdf files in multiple languages. Chris and Susan Beck wrote: > Hi, Jeff. The 2012 is indeed 50/50 mix ratio. It seems to be pretty good > stuff. We just ran out, so I bought some 5-minute stuff from Wicks > Aircraft. Looks about the same, but it came in plastic bottles and isn't > quite as thick. > > Have fun! > > Chris A159 > ________________________________________________________________________________
Subject: Rapid (5 minute) epoxy mixing ratio - Thanks
Date: Jan 08, 2001
100:100/100:100 means 100 parts to 100 parts by weight, 100 parts to 100 parts by volume. Tony ________________________________________________________________________________
Date: Jan 07, 2001
I found a time & hassle saving tip for using this stuff. Buy 5-minute epoxy that comes in a dual syringe. When used up (5-minute epoxy for the Europa is nonstructural), use it for the Araldite 2012. Easy 50/50 mix and less mess. When refilling, just keep it straight which side gets the resin and which the hardener! Regards, Fred F., A063 ________________________________________________________________________________
Date: Jan 08, 2001
Subject: Re: Fuel Sight Gauge Tubing
The new tubing fits nicely into a "deep-gap slotted optoswitch" (RS part no.194-4030, around 4). The tubing is almost transparent to IR but the focussing action when fuel is present gives a dramatic increase in output current - enough to light an LED. So here is a cheap easily fitted low-level indicator for your front-of-tank-mounted sight gauge, where (at least on the pilot's side) it is difficult to read below 10 ltrs. You can run it on a PP3 battery, and a few more components will give an audible alarm via your interecom aux. socket. Of course fitting some more will lead you to a discrete digital fuel gauge, but covering up all the tubing rather defeats the "reliability" of a sight gauge. It will also work along the fuel line as a bubble/ leak detector - a subject close to my heart since my landings-out two years ago. But I have not been able to substantiate the earlier theory that the time delay is due to bubble accretion at a high spot. Experiments show bubbles in this size of tubing (with fuel flowing at the standard rate) behaving a most extraordinary way. Chaos seems to be the norm, with some stationary, some slow moving, sometimes coalescing, while small ones fly past larger ones and so on. Must try to take a video sometime. BTW the new tubing still goes brown ! Graham G-EMIN ________________________________________________________________________________
Subject: - Ailerons again!
Date: Jan 08, 2001
Forwarded from the bounce bin. Message is from "Keith Tallent" ******************************************************* It's me again...boy will I be glad to see the end of these big wet layups! After turning over the first lay-up, removing the trailing edge support block and peel ply, I have a couple of problems. For problem details, photos and questions, click on this link... http://www.thehangar.co.uk/help.htm I would be grateful for any advice supplied. regards Keith Tallent Kit No 221 XS Tri-Gear G-SAMY ________________________________________________________________________________
Subject: HLP - Ailerons again!
Date: Jan 09, 2001
I may as well be first to tell you - there are no images on that page. Tony -----Original Message----- From: owner-europa(at)aztec.houxou.com Subject: HLP - Ailerons again! Forwarded from the bounce bin. Message is from "Keith Tallent" ******************************************************* It's me again...boy will I be glad to see the end of these big wet layups! After turning over the first lay-up, removing the trailing edge support block and peel ply, I have a couple of problems. For problem details, photos and questions, click on this link... http://www.thehangar.co.uk/help.htm I would be grateful for any advice supplied. regards Keith Tallent Kit No 221 XS Tri-Gear G-SAMY ________________________________________________________________________________
Date: Jan 08, 2001
Subject: trim switch swap
Anyone got one of the older type MAC trim switches they would like to swap for the latest type? New ones have a more positive feel, but as they are about 1.1" deep (vs about .6" deep) they won'y fit in my sticktop housing.... Cheers Miles ________________________________________________________________________________
Date: Jan 09, 2001
Subject: Re: HLP - Ailerons again!
Try again Tony. The pics were there when I looked. Unfortunately I don't know the answers. Rob Tony Krzyzewski wrote: > > I may as well be first to tell you - there are no images on that page. > > Tony > > -----Original Message----- > From: owner-europa(at)aztec.houxou.com > Subject: HLP - Ailerons again! > > Forwarded from the bounce bin. Message is from > "Keith Tallent" > > ******************************************************* > > It's me again...boy will I be glad to see the end of these big wet layups! > > After turning over the first lay-up, removing the trailing edge support > block and peel ply, I have a couple of problems. > > For problem details, photos and questions, click on this link... > http://www.thehangar.co.uk/help.htm > > I would be grateful for any advice supplied. > > regards > > Keith Tallent > Kit No 221 > XS Tri-Gear G-SAMY > > ________________________________________________________________________________
Date: Jan 08, 2001
Subject: Re: [Re: HLP - Ailerons again!]
I just tried again and finally got to the pics. We just went through this step yesterday. I just filled in the "trough" with some dry micro before laying up the uni plies. At most, the micro is about 3/16" wide, and I made no attempt to fully blend in the foam/glass transition. These cores were not very good with regard to the trailing edges, having a very poor matchup. The rest of the t.e. will get blended with filler at the paint stage to make it look pretty. It turned out pretty well, tho. FINALLY, we see the end of the layup tunnel!!! Chris A159 Rob Waters wrote: > Try again Tony. The pics were there when I looked. Unfortunately I don't > know the answers. > > Rob > > Tony Krzyzewski wrote: > > > > I may as well be first to tell you - there are no images on that page. > > > > Tony > > > > -----Original Message----- > > From: owner-europa(at)aztec.houxou.com > > Subject: HLP - Ailerons again! > > > > Forwarded from the bounce bin. Message is from > > "Keith Tallent" > > > > ******************************************************* > > > > It's me again...boy will I be glad to see the end of these big wet layups! > > > > After turning over the first lay-up, removing the trailing edge support > > block and peel ply, I have a couple of problems. > > > > For problem details, photos and questions, click on this link... > > http://www.thehangar.co.uk/help.htm > > > > I would be grateful for any advice supplied. > > > > regards > > > > Keith Tallent > > Kit No 221 > > XS Tri-Gear G-SAMY > > > > ________________________________________________________________________________
Subject: ents of List Messages
Date: Jan 08, 2001
This is going to sound stupid, but .... I suggest that you don't start the subject of your message to the List with the word 'Help' , nor the start of any paragraph in the body of the message. The server software appears to scan the subject and bounce (reject) messages whose subjects start with 'Help' (Help is a majordomo command). I don't know if any other command keywords will cause the same effect though I suspect there are some. John Cliff Europa Club List Forum minder ________________________________________________________________________________
Date: Jan 08, 2001
Hi! Rob /Tony /Keith IMHO ...1).... fill the worst places with dry micro to ensure no air bubbles(making sure no dry micro on the trailing edge bond area), then overlay with a wet flox mix prior to top lay up. You will need to fill the "register" on the other side with filler when you prepare for painting. 2) If you wish your ailerons to flow level with the finished wing DON'T sand any off the profile.! Tony ..... Thanks for the Modem cable info . Do I require one with socket one end and plug the other or sockets both ends or plugs both ends ? Regards Bob Harrison G-PTAG -----Original Message----- On Behalf Of Rob Waters Sent: 08 January 2001 19:03 Cc: europa(at)avnet.co.uk Subject: Re: HLP - Ailerons again! Try again Tony. The pics were there when I looked. Unfortunately I don't know the answers. Rob Tony Krzyzewski wrote: > > I may as well be first to tell you - there are no images on that page. > > Tony > > -----Original Message----- > From: owner-europa(at)aztec.houxou.com > Subject: HLP - Ailerons again! > > Forwarded from the bounce bin. Message is from > "Keith Tallent" > > ******************************************************* > > It's me again...boy will I be glad to see the end of these big wet layups! > > After turning over the first lay-up, removing the trailing edge support > block and peel ply, I have a couple of problems. > > For problem details, photos and questions, click on this link... > http://www.thehangar.co.uk/help.htm > > I would be grateful for any advice supplied. > > regards > > Keith Tallent > Kit No 221 > XS Tri-Gear G-SAMY > > ________________________________________________________________________________
Date: Jan 08, 2001
Keith .... Sorry about this I forgot to answer you question on the peel ply.... 3) Obviously it looks tidier not to leave it in but it will be buried after filling and painting anyway ! Get the ladies eyebrow tweezers out and try to get what you can , it can't be weaker than the polystyrene anyway !!!! Regards Bob H G-PTAG -----Original Message----- Sent: 08 January 2001 20:39 Cc: europa(at)avnet.co.uk Subject: RE: HLP - Ailerons again! Hi! Rob /Tony /Keith IMHO ...1).... fill the worst places with dry micro to ensure no air bubbles(making sure no dry micro on the trailing edge bond area), then overlay with a wet flox mix prior to top lay up. You will need to fill the "register" on the other side with filler when you prepare for painting. 2) If you wish your ailerons to flow level with the finished wing DON'T sand any off the profile.! Tony ..... Thanks for the Modem cable info . Do I require one with socket one end and plug the other or sockets both ends or plugs both ends ? Regards Bob Harrison G-PTAG -----Original Message----- On Behalf Of Rob Waters Sent: 08 January 2001 19:03 Cc: europa(at)avnet.co.uk Subject: Re: HLP - Ailerons again! Try again Tony. The pics were there when I looked. Unfortunately I don't know the answers. Rob Tony Krzyzewski wrote: > > I may as well be first to tell you - there are no images on that page. > > Tony > > -----Original Message----- > From: owner-europa(at)aztec.houxou.com > Subject: HLP - Ailerons again! > > Forwarded from the bounce bin. Message is from > "Keith Tallent" > > ******************************************************* > > It's me again...boy will I be glad to see the end of these big wet layups! > > After turning over the first lay-up, removing the trailing edge support > block and peel ply, I have a couple of problems. > > For problem details, photos and questions, click on this link... > http://www.thehangar.co.uk/help.htm > > I would be grateful for any advice supplied. > > regards > > Keith Tallent > Kit No 221 > XS Tri-Gear G-SAMY > > ________________________________________________________________________________
Subject: Oil Return Hose & Stall Warning Device
Date: Jan 08, 2001
In my experience, silicone rubber products swell horribly when exposed to petroleum. Never tried hot petroleum, but it's got to be worse! Pops A036 -----Original Message----- From: owner-europa(at)aztec.houxou.com Subject: Oil Return Hose & Stall Warning Device Posted on behalf of Nigel Charles, who is again being denied access by the server ! *********************************************************************** 'There is some concern over the ability of the existing rubber oil return hose (in the Rotax engine installation) to withstand the extremes of temperature created by the nearby exhaust silencer even when protected with firesleeve. It has been suggested that Teflon hose might be the answer as it can withstand temperature up to 200C as opposed to the normal limit of 130C for the usual rubber hose. I have noticed in a specialist spares catalogue that silicon hoses can withstand temperatures up to 300C. Is there any reason why this type of hose should not be used instead?' 'I have just bought the ACI Stall Warning device and very good it looks too. Although it is very easy to mount the sensor onto the Europa wing, routeing the cable and positioning the sounder looks to be more difficult, particularly retrospectively on a Classic wing. Please could anyone who has done this give me details how they went about it.' Nigel Charles ________________________________________________________________________________
Date: Jan 08, 2001
Keith Tallent wrote -- > PROBLEM 2 > Aileron trailing edge after removal of peel ply - two or three strands of > peel ply left at foam edge. Consider taking all your blue peel ply to a trash can and verifying the law of gravity. You should be able to buy 1", 2.7 oz or so proper Dacron peel ply (get some 2" while yer at it -- will come in handy). None of those annoying stands coming off the edges either. I get it from Wicks Airraft here in the US. Regards, Fred F., A063 ________________________________________________________________________________
Date: Jan 09, 2001
Dear Shaun, You are right - it is for the access panel from the fuel valve. Note also that the D panel that goes at the back of the cockpit contains, in the section that is cut out and thrown away, a triangular shaped reinforced section. This is big enough to cut out 3 access panels, one for the fual valve as above, and two for the panels under the fuel tank outlets. Kind regards Roger Bull Technical Support ________________________________________________________________________________
Date: Jan 09, 2001
Subject:
Hi All, At risk of exposure of my lack of electical engineering ability, I am posting the planned circuit protection device ratings I am planning to use. I appeal to you experts in this field to correct any that need to be. I realize that the load pushed the limit of the Rotax alternator but these are not the actual loads, and I may make some adjustments to type equipment. I also realize they are not what is shown in every case on the Europa schematic, but some of them are left up to the builder anyway. What am I doing wrong by using these values of fuses or breakers? Thanks for all your opinions. Troy RC Allen Attitude Indicator------------------------------------3 Turn Coordinator(imported)(like RC Allen) --------------3 AV-10 Engine monitor------------------------------------------1.5 Michell Electric Tach (redundant to monitor------------1 Skysport Capacitance Fuel gage---------------------------1 Fuel Pump(at)T.O.& Lnd (Facet)-----------------------------5 Comm.Radio-------------------------------------------------------5 Transponder--------------------------------------------------------5 Alt. Encoder--------------------------------------------------------2 Trim, Pitch(MAC)------------------------------------------------ 1 AeroFlash Strobe------------------------------------------------ 5 AeroFlash Nav/Tail Lite Combo ---------------------------- 7.5 Landing Lite(55w)-----------------------------------------------10 Instrument Lites---------------------------------------------------2 Aux Panel Outlet-------------------------------------------------5 ________________________________________________________________________________
Date: Jan 09, 2001
Subject: rnator Breaker
Hi Again, I have notice some have used an a.c. breaker on the panel instead of the 30 amp slow blow fuse inder the cowl. I have a 35 amp a.c. breaker that I bought at the swap meet at Sun n Fun a few years ago. The following information is printed on the side. 35A a.c. S-1360-35 MP-1600Y-35 Mechanical Products Is this an aircraft breaker or for industrial or either? Does anyone have any idea if this is ok to use for the alternator? Thanks, Troy ________________________________________________________________________________
2001 08:17:48 pm"
Date: Jan 09, 2001
From: Brian Rauchfuss - PCD <brauchfu(at)pcocd2.intel.com>
> Keith Tallent wrote -- > > > PROBLEM 2 > > Aileron trailing edge after removal of peel ply - two or three strands of > > peel ply left at foam edge. > > Consider taking all your blue peel ply to a trash can and verifying > the law of gravity. You should be able to buy 1", 2.7 oz or so proper > Dacron peel ply (get some 2" while yer at it -- will come in handy). > None of those annoying stands coming off the edges either. I get it > from Wicks Airraft here in the US. I bought some of that - and regretted using it. It is thicker than the blue peel ply (I assume the 2.7 oz is the thickness I got from Wicks), so that when I used it on the inside of a flange it caused it to have a tiny air gap adjacent to it and the flange bulges out slightly. Currently I use the Dacron for all outside applications and the blue peel ply for anything which could affect shape. Brian > Regards, > Fred F., A063 > ________________________________________________________________________________
Subject: Re: amps
9, 2001 11:24:43 am"
Date: Jan 09, 2001
I looks like you are matching the circuit breaker/fuse to the item which is drawing the load. This is one way to do it, but the way that I was taught was to match the fuse to the wire which is feeding the current. After all, the purpose of a fuse or circuit breaker is to prevent electrical fire in the event of a short. It is not really important if the intercom is drawing a bit more than 0.5 A, for example, but it is important if the intercom is drawing so much current that the wires overheat. The advantage of matching the fuse to the feed wire is you will not have any nuisance trips and there will be a smaller variety of fuses. The advantage of matching the fuse to the expected load is the ability to detect when a device is drawing a small amount of current greater than expected. Finding this out is usually not worth having the circuit breaker or fuse trip during flight. Brian > Hi All, > > At risk of exposure of my lack of electical engineering ability, I am posting > the planned circuit protection device ratings I am planning to use. I appeal > to you experts in this field to correct any that need to be. I realize that > the load pushed the limit of the Rotax alternator but these are not the > actual loads, and I may make some adjustments to type equipment. I also > realize they are not what is shown in every case on the Europa schematic, but > some of them are left up to the builder anyway. What am I doing wrong by > using these values of fuses or breakers? > Thanks for all your opinions. > Troy > > RC Allen Attitude Indicator------------------------------------3 > Turn Coordinator(imported)(like RC Allen) --------------3 > AV-10 Engine monitor------------------------------------------1.5 > Michell Electric Tach (redundant to monitor------------1 > Skysport Capacitance Fuel gage---------------------------1 > Fuel Pump(at)T.O.& Lnd (Facet)-----------------------------5 > Comm.Radio-------------------------------------------------------5 > Transponder--------------------------------------------------------5 > Alt. Encoder--------------------------------------------------------2 > Trim, Pitch(MAC)------------------------------------------------ 1 > AeroFlash Strobe------------------------------------------------ 5 > AeroFlash Nav/Tail Lite Combo ---------------------------- 7.5 > Landing Lite(55w)-----------------------------------------------10 > Instrument Lites---------------------------------------------------2 > Aux Panel Outlet-------------------------------------------------5 > ________________________________________________________________________________
From: "Gregory, Mike" <M.J.Gregory(at)cranfield.ac.uk>
Subject: Alternator Breaker
Date: Jan 09, 2001
Hello Troy Under no circumstances should you use the AC (alternating current) rating for a circuit breaker in a DC (direct current) electrical system. The reason for this is that the alternating current reduces to zero twice per cycle (ie 100 or 120 times the second, so that any arc that forms as the contacts separate will be extinguished within a few milliseconds. This allows the breaker to break a much larger current, and do this repeatedly before the contacts are damaged. The same value of direct current may continue to arc across the contacts if they are not designed to to handle it -- at worst, the contacts may fuse together and at best the breaker will have a short life in terms of the number of trips before it fails. Unless you know for certain the DC rating of a contactor or circuit breaker, do not assume that an AC breaker will handle any useful level of DC load, however large its AC rating. Brian Rauchfuss's advice is sound -- rate the fuse or breaker to protect the wiring. I assume that "starter" refers to the starter relay: the starter itself should be connected by the shortest route of heavy duty cable with no fuse or breaker. Fly safely Mike Europa Club Safety Officer -----Original Message----- From: TroyMaynor(at)aol.com Subject: Alternator Breaker Hi Again, I have notice some have used an a.c. breaker on the panel instead of the 30 amp slow blow fuse inder the cowl. I have a 35 amp a.c. breaker that I bought at the swap meet at Sun n Fun a few years ago. The following information is printed on the side. 35A a.c. S-1360-35 MP-1600Y-35 Mechanical Products Is this an aircraft breaker or for industrial or either? Does anyone have any idea if this is ok to use for the alternator? Thanks, Troy ________________________________________________________________________________
Subject: amps
Date: Jan 10, 2001
The thing to remember is that the fuse protects the wiring, not the device on the end. 1/ Work out the current draw of the device. 2/ Select a wire size that can handle the current 3/ Select the protection appropriate to the wire size. For the Europa use the following current ratings... Wire size Maximum Current 24 4 22 5 20 7 18 9 16 11 14 14 12 19 10 26 Use a fuse equal to or lower than the maximum current rating. eg a 3A fuse would protect any wire size of 24AWG or larger diameter. The basic concept is that the fuse should blow before the wire. The table above is for 'short' wire runs. With the possible exception of position lights on the end of the wing tips there are no long wire runs in the Europa. For the position lights it would probably pay to go to the next larger wire size than is required. I am running mine with 18AWG. Hope this helps Tony ________________________________________________________________________________
From: "hedley brown" <hedley(at)hedleybrown.flyer.co.uk>
Subject: New Virus
Date: Jan 09, 2001
----- Original Message ----- From: brianelliot <brianelliot(at)onetel.net.uk> ; Bob Ridley ; Hedley Brown ; Jennifer, Peter Oxenham <101641.242(at)compuserve.com>; Ros Anderson Subject: New Virus > There is a new virus - WOBBLER. It will arrive on e-mail titled CALIFORNIA. > IBM and AOL have announced that it is very powerful, more so than Melissa; > there is no remedy. > It will eat all your information on the hard drive and also destroys > Netscape Navigator and > Microsoft Internet Explorer. > Do not open anything with this title and please pass this message on to all > your contacts and anyone > who uses your e-mail facility. > Not many people seem to know about this yet, so propagate it as fast as > possible. > If you receive an e-mail titled "Win a Holiday" DO NOT open it. It will > erase everything on your > hard drive. > Forward this letter out to as many people as you can. > This is a new, very malicious virus and not many prople know about it. > This information was announced from Microsoft > > (I received this news from the USA via my brother-in law, so I thought you > ought to know. > > Brian. ________________________________________________________________________________
Subject: Virus - Wobbler is a HOAX
Date: Jan 10, 2001
From the Symantec Web Site....... Wobbler Hoax Category: Hoax The following two messages have been sent out by email. They are both versions of the same hoax. This "virus" does not exist. The hoax message includes one of the following "warnings": Dear All, For your reference, take necessary precautions. If you receive an email with a file called California, do not open the file. The file contains WOBBLER virus. WARNING This information was announced yesterday morning from IBM; AOL states that this is a very dangerous virus, much worse than "Melissa", and that there is NO remedy for it at this time. Some very sick individual has succeeded in using the reformat function from Norton Utilities causing it to completely erase all documents on the hard drive. It has been designed to work with Netscape Navigator and Microsoft Internet Explorer. It destroys Macintosh and IBM compatible computers. This is a new, very malicious virus and not many people know about it. Second sample of hoax message "warning": VIRUS ALERT If you receive an email with a file called "California" do not open the file. The file contains the virus. This information was announced yesterday morning by IBM. The report says that "this is a very dangerous virus, much worse than "Melissa" and there is NO remedy for it at this time. Some very sick individual has succeeded in using the reformat function from Norton Utilities causing it to completely erase all documents on the hard drive. It has been designed to work with Netscape Navigator and Microsoft Internet Explorer. It destroys Macintosh and IBM compatible computers. This is a new, very malicious virus and not many people know about it at this time. Please pass this warning to everyone in your address book and share it with all your online friends asap so that the destruction it can cause may be minimized. EVERYONE PLEASE... Before passing on virus messages, do us all a favour and check with one of the major virus protection sites, www.symantec.com or www.mcafee.com to check that it's not a hoax. Thanks Tony ________________________________________________________________________________
Date: Jan 09, 2001
Subject: Re: amps
Very well stated, Tony. Picking fuse/breaker ratings with respect to the device's nominal current draw may not allow for inrush current. More pertinent to fast-acting fuses verses breakers, and often true of motors and avionics -- on the test bench I've seen some spirited inrush on things like transponders or avionics with DC-DC converters for displays. OTOH, if wire size selection has been conservative, I'd use caution in placing too high a fuse/breaker rating on something that's really expensive. Sometimes an avionics mfr. will specify even 16 ga. be used on the 14V line, even though the box draws, say, 1.3 A. But if the fault inside were to kick the draw to just below a 10-amp fuse/breaker, you could be slowly cooking component$ inside that are not initially defective and frying traces off a PCB board. 5-amp here would make me feel better in this example, even less if the mfr. says so (e.g., 3-amp for the King KT-76/78 xponder that draws 1.8 A max, 1.1 standby, but just maybe not a fast-acting). Regards, Fred F., A063 Tony Krzyzewski wrote: > > The thing to remember is that the fuse protects the wiring, not the device > on the end. > > 1/ Work out the current draw of the device. > 2/ Select a wire size that can handle the current > 3/ Select the protection appropriate to the wire size. > > For the Europa use the following current ratings... > > Wire size Maximum Current > 24 4 > 22 5 > 20 7 > 18 9 > 16 11 > 14 14 > 12 19 > 10 26 > > Use a fuse equal to or lower than the maximum current rating. eg a 3A fuse > would protect any wire size of 24AWG or larger diameter. > > The basic concept is that the fuse should blow before the wire. > > The table above is for 'short' wire runs. With the possible exception of > position lights on the end of the wing tips there are no long wire runs in > the Europa. For the position lights it would probably pay to go to the next > larger wire size than is required. I am running mine with 18AWG. > > Hope this helps > > Tony ________________________________________________________________________________
Date: Jan 09, 2001
That might have been an anomaly, as I've hadn't experienced that anywhere and am about done with glassing. But plausible due to it's thickness (Aircraft Spruce's stuff is 1.7 oz., but n/a in 1" rolls last I looked). If you're referring to the part of the flange that will later accept a hinge (or anything one wants to cure flat), I added a layer of poly film and a strip of aluminum from the scrap box, lightly clamped if appropriate. Now I see why it seemed to make sense at the time! Regards, Fred F., A063 Brian Rauchfuss wrote -- > I bought some of that - and regretted using it. It is thicker than the > blue peel ply (I assume the 2.7 oz is the thickness I got from Wicks), so > that when I used it on the inside of a flange it caused it to have a tiny > air gap adjacent to it and the flange bulges out slightly. Currently I use > the Dacron for all outside applications and the blue peel ply for anything` > which could affect shape. ________________________________________________________________________________
Date: Jan 09, 2001
Subject: ron instruction clarification
Hello all... I've noticed a slight 'possible' discrepancy or at least a curiosity with regard to the placement of the aileron hinges, and the placement of the reinforcement for them. On Page 7-4, figure 7 there is a measurement of 117 cm (46") from the root of the aileron. That measurement is supposed to be the center of the location of the 20 cm reinforcement. On Page 7-8, figure 14 there is another measurement of 117 cm, except it is shown to be starting from 13 cm (1") further outboard from the root. The measurement is supposed to be the center of the location for the 127 mm (5") hinge. Am I the only one to have found that to be somewhat of a curious difference between the two measurements? I find that if I start the measurement for the outboard hinge an extra inch outboard as in figure 14 that the hinge is just barely still on the reinforcement. Jeff A191 ________________________________________________________________________________
From: "David Cripps" <david.cripps(at)spsystems.com>
Subject: return hose
Date: Jan 10, 2001
Following on from the recent discussions on this subject, I have looked at my hoses which seem fine at the moment. However, it seems prudent to have some spare hose to hand. Unfortunately I cannot easily read the specification printed on the return hose, except that it says '13mm' and has a 'Burst Pressure' which is unreadable. This oil return hose also looks to be made of a slightly different material to the other oil hoses (these seem to have a more textured and less smooth feel). Are they all actually meant to be the same spec. and does anyone know the exact current specification of these hoses (diameters and temperature/pressure rating)? Was there a final conclusion to the best material for such a hose (Teflon, Silicon, rubber etc)? Many thanks in advance. David Cripps GBWJH ________________________________________________________________________________
Date: Jan 10, 2001
From: Peter J BARWICK <peter.j.barwick(at)hsbc.com>
Subject: Re: : Re: amps
The fuse is there to protect BOTH the device and the wiring. It should NEVER exceed the rating set by the device manufacturer which will usually have a bit in reserve. > Picking fuse/breaker ratings with respect to the device's nominal > current draw may not allow for inrush current. Use an anti-surge or Slo-Blo fuse. > OTOH, if wire size selection has been conservative, I'd use caution > in placing too high a fuse/breaker rating on something that's really > expensive. Sometimes an avionics mfr. will specify even 16 ga. be > used on the 14V line, even though the box draws, say, 1.3 A. But if > the fault inside were to kick the draw to just below a 10-amp > fuse/breaker, you could be slowly cooking component$ inside that are > not initially defective and frying traces off a PCB board. I agree absolutely, but not just the expensive equipment. I've seen clouds of fumes coming out of a ham transmitter than had been fitted with a 10 amp fuse after the original 5 amp fuse had blown. I don't know how toxic the fumes were but they certainly reduced visibility. Please, take great care. Peter Barwick ******************************************************************** This message and any attachments are confidential to the ordinary user of the e-mail address to which it was addressed and may also be privileged. If you are not the addressee you may not copy, forward, disclose or use any part of the message or its attachments and if you have received this message in error, please notify the sender immediately by return e-mail and delete it from your system. Internet communications cannot be guaranteed to be secure or error-free as information could be intercepted, corrupted, lost, arrive late or contain viruses. The sender therefore does not accept liability for any errors or omissions in the context of this message which arise as a result of Internet transmission. Any opinions contained in this message are those of the author and are not given or endorsed by the HSBC Group company or office through which this message is sent unless otherwise clearly indicated in this message and the authority of the author to so bind the HSBC entity referred to is duly verified. ******************************************************************** ________________________________________________________________________________
From: "John Cliff" <john(at)crixbinfield.freeserve.co.uk>
Date: Jan 10, 2001
Forwarded from the bounce bin. Message is from Nigel Charles <72016.3721(at)compuserve.com> **************************************************************** Message text written by "Chuck Popenoe" >In my experience, silicone rubber products swell horribly when exposed to petroleum. Never tried hot petroleum, but it's got to be worse! < This is for use with engine oil not gasoline. The silicone tubing I am looking at is used in competition cars for oil piping so it should be able to cope provided it doesn't get above 300C. Does anyone else have any useful input on this one? Nigel Charles ________________________________________________________________________________
Date: Jan 10, 2001
Subject: est for info from builders in Switzerland
If there's anyone out there who can give me some advice on the regulatory atmosphere regarding homebuilts in CH I'd be grateful if you could email me on tsears(at)mmm.com . Thanks Trevor Sears ________________________________________________________________________________
Subject: Re: Oil return hose
Date: Jan 10, 2001
01/10/2001 08:37:37 AM Since I was the one who started this thread, I thought I'd share my summarized thoughts with everyone. I believe that the ultimate solution would be to remove the sump banjo fitting, cut off the tip of the fitting, and weld on a male threaded fitting. Utilizing this threaded fitting I would then fabricate a steel oil return line and route it up to the oil reservoir. Once getting past the heat sources (turbo unit and exhaust manifolds) I would mate a conventional flexible hose to the steel hose for the last 3 or 4 inches before the line connects to the oil reservoir. This is necessary to absorb engine vibrations. With this setup, it's impossible to "burn" the oil line. Now, that's not what I did. After much research and lots of advice from fellow Europa flyers, I determined that a flexible hose made by AeroQuip........model #666, would suffice. This hose is made of teflon and is covered with a stainless steel mesh. It is supposedly rated to 350 degrees (F). I further wrapped the hose with a 1/4 inch thick flexible firewall insulating material which I believe is asbestos filler with a silver foil material on each side. My friend Marvin Alvarez says he put his welding torch to this material..........about 2,000 degrees (F), and it didn't burn. I've only put a couple of hours on the plane since making this mod, but so far, so good. Another Europa pilot in California has used the AeroQuip hose alone, with no further insulation, and has successfully flown 200 hours with no problems. How this whole problem started is as follows. Rotax supplies a fine, high quality oil return hose to be used for this application. Due to the unique oil line routing (to the reservoir) recommended by Europa, a 120 degree bend in the hose is required just as the hose exits the sump banjo fitting. Europa supplies a substitute hose which is pre-molded with the 120 degree bend molded in......and instructs that their hose be used rather than the Rotax (straight) hose. Unfortunately, the Europa supplied hose is totally unsuitable for that application. It has no heat resistance and isn't even internally reinforced. It's a plain rubber hose more suitable for a douche bag than for a critical aircraft engine component in a high temperature environment. I suggest all Europa builders/flyers replace this hose immediately. Shame on Europa for not issuing a warning / mandatory mod on this........years ago. Regards, Garry Stout N4220S (813) 878-3929 FAX (813) 878-5651, Internet ID Garrys(at)att.com ________________________________________________________________________________
Date: Jan 10, 2001
Subject: Re: Aileron instruction clarification
Thanks Edward. I agree the root hinge starts one inch from the root. But, in terms of the 117 cm measurement, I'm betting the drawing in figure 14 is incorrect. I'd like someone at Europa to corroborate that. In my book it clearly shows the 117 cm measurement starting one inch out from where it was shown in figure 7. Jeff Edward Lockhart wrote: > I don't have the latest update of the manual here in the house but the Sept > 97 pages show that the outboard hinge should be centred on a point 117cm / > 46" from the root end of the aileron. > > The 13mm / 0.5" line [sept 97 manual] in fig 14 marks the limit of the > inboard aileron, i.e. it should at least 13mm from the aileron root. > > I'd put the hinge where the reinforcement is and when you do the aileron > hinge reinforcement layups on the wing in chapt. 8, make sure the layups are > aligned to the aileron. ________________________________________________________________________________
Subject: Oil return hose
Date: Jan 10, 2001
Hi! Gary. No problems like this on the 3300 Jabiru !!!!!? Pleased you didn't go for the steel pipe alone since it sounds like a good oil "BOILER" !!!?? Regards Bob Harrison G-PTAG -----Original Message----- On Behalf Of Garry Stout Sent: 10 January 2001 13:38 Cc: europa(at)avnet.co.uk Subject: Re: Oil return hose ________________________________________________________________________________
Date: Jan 10, 2001
Subject: Re: Memo: Re: amps
Peter J BARWICK wrote: > > The fuse is there to protect BOTH the device and the wiring. It > should NEVER exceed the rating set by the device manufacturer which > will usually have a bit in reserve. And there's always mysterious exceptions. On one Narco transponder, they spec 1.6A transmit, but to use a 1.5A circuit breaker. Likely that's 1.6A at it's max reply rate of 1200/second, which is impossible. But the box has a pwr out pin for an encoder, and they forgot to tell you to allow for that! UPSAT settles the issue with a fusible link on the board, cause they just know even a professional installer might spot an unused 5A breaker and.... The best example for concern here might be that electric fuel pump. Experiments on the effect of boiling fuel inside of it are best left to laboratory conditions rather than in flight. Regards, Fred F., A063 ________________________________________________________________________________
Date: Jan 10, 2001
Subject: Re: amps
Hi Troy, Do you have a copy of Bob Nuckolls' 'The Aeroelectric Connection" ? If not, I can highly recommend it. It goes over aircraft electrics philosophy very thoroughly and gives all the steps for wire sizing and good practise. It also confirms basic steps as (i) size wire based on user amps, acceptable voltage drop and wire length (there and back for composite planes) and (ii) size breaker or fuse based on wire size. Copies are available at http://www.aeroelectric.com/Catalog/AECcatalog.html. Cheers, John A099, N262WF <<< TroyMaynor(at)aol.com wrote: > Hi All, > > At risk of exposure of my lack of electical engineering ability, I am posting > the planned circuit protection device ratings I am planning to use. >>> ________________________________________________________________________________
Subject: Re: New Virus - Wobbler is a HOAX
Date: Jan 10, 2001
Sorry ....h ----- Original Message ----- From: Tony Krzyzewski <tonyk(at)kaon.co.nz> Subject: New Virus - Wobbler is a HOAX > >From the Symantec Web Site....... > > Wobbler Hoax > Category: Hoax > > > The following two messages have been sent out by email. They are both > versions of the same hoax. This "virus" does not exist. > > The hoax message includes one of the following "warnings": > > Dear All, For your reference, take necessary precautions. If you receive an > email with a file called California, do not open the file. The file contains > WOBBLER virus. WARNING This information was announced yesterday morning from > IBM; AOL states that this is a very dangerous virus, much worse than > "Melissa", and that there is NO remedy for it at this time. Some very sick > individual has succeeded in using the reformat function from Norton > Utilities causing it to completely erase all documents on the hard drive. It > has been designed to work with Netscape Navigator and Microsoft Internet > Explorer. It destroys Macintosh and IBM compatible computers. This is a new, > very malicious virus and not many people know about it. > > Second sample of hoax message "warning": > > VIRUS ALERT If you receive an email with a file called "California" do not > open the file. The file contains the virus. This information was announced > yesterday morning by IBM. The report says that "this is a very dangerous > virus, much worse than "Melissa" and there is NO remedy for it at this time. > Some very sick individual has succeeded in using the reformat function from > Norton Utilities causing it to completely erase all documents on the hard > drive. It has been designed to work with Netscape Navigator and Microsoft > Internet Explorer. It destroys Macintosh and IBM compatible computers. This > is a new, very malicious virus and not many people know about it at this > time. Please pass this warning to everyone in your address book and share it > with all your online friends asap so that the destruction it can cause may > be minimized. > > --------------------------------------- > > EVERYONE PLEASE... > > Before passing on virus messages, do us all a favour and check with one of > the major virus protection sites, www.symantec.com or www.mcafee.com to > check that it's not a hoax. > > Thanks > > Tony ________________________________________________________________________________
Subject: Re: amps
Date: Jan 10, 2001
I have been deluded by my simple mind into thinking that a 5-amp contact breaker for dc circuits would break at 5 amps regardless of whether it was rated at 12 or 24 amps. Not so. Having installed 11 of them from a motor trader's catalogue, with the great advantage that they were exchangeable with spade-type motor fuses, I was warned that because they were deemed suitable also for 24-volt circuits they might not break at the right amperage. I was incredulous - amps are amps.... relative to wire thickness that's what makes the heat that breaks the fuse or clicks the breaker, surely. No; they broke contact at twice the rated current, by which time my trial variable-length of hotwire was glowing brightly. Had to resort to good 'ole fuses and write off 110.00. Still don't understand the physics. Ah., well.... ----- Original Message ----- From: Fred Fillinger <fillinger(at)ameritech.net> Subject: Re: amps > Very well stated, Tony. Picking fuse/breaker ratings with respect to > the device's nominal current draw may not allow for inrush current. > More pertinent to fast-acting fuses verses breakers, and often true of > motors and avionics -- on the test bench I've seen some spirited > inrush on things like transponders or avionics with DC-DC converters > for displays. > > OTOH, if wire size selection has been conservative, I'd use caution in > placing too high a fuse/breaker rating on something that's really > expensive. Sometimes an avionics mfr. will specify even 16 ga. be > used on the 14V line, even though the box draws, say, 1.3 A. But if > the fault inside were to kick the draw to just below a 10-amp > fuse/breaker, you could be slowly cooking component$ inside that are > not initially defective and frying traces off a PCB board. 5-amp here > would make me feel better in this example, even less if the mfr. says > so (e.g., 3-amp for the King KT-76/78 xponder that draws 1.8 A max, > 1.1 standby, but just maybe not a fast-acting). > > Regards, > Fred F., A063 > > Tony Krzyzewski wrote: > > > > The thing to remember is that the fuse protects the wiring, not the device > > on the end. > > > > 1/ Work out the current draw of the device. > > 2/ Select a wire size that can handle the current > > 3/ Select the protection appropriate to the wire size. > > > > For the Europa use the following current ratings... > > > > Wire size Maximum Current > > 24 4 > > 22 5 > > 20 7 > > 18 9 > > 16 11 > > 14 14 > > 12 19 > > 10 26 > > > > Use a fuse equal to or lower than the maximum current rating. eg a 3A fuse > > would protect any wire size of 24AWG or larger diameter. > > > > The basic concept is that the fuse should blow before the wire. > > > > The table above is for 'short' wire runs. With the possible exception of > > position lights on the end of the wing tips there are no long wire runs in > > the Europa. For the position lights it would probably pay to go to the next > > larger wire size than is required. I am running mine with 18AWG. > > > > Hope this helps > > > > Tony ________________________________________________________________________________
Date: Jan 10, 2001
Subject: amp: Sit, Stay
Yes - and we all know how impossible it is to get the device running after the "factory-installed smoke" has escaped..... Cheers, Al At Wednesday 01:09 AM1/10/2001, Peter J BARWICK wrote: >I've seen >clouds of fumes coming out of a ham transmitter than had been fitted >with a 10 amp fuse after the original 5 amp fuse had blown. ________________________________________________________________________________
Date: Jan 10, 2001
Subject: Re: amps
> I am posting >the planned circuit protection device ratings I am planning to use It's important to realize that the fuse/breaker rating is chosen to match the wire size of the outgoing circuit. The wire size is previously chosen to safely supply the expected current drain of the devices it feeds. The fault that will cause your protection device to operate is just as likely to be a short to earth (common) part-way along the wiring harness, as an internal fault in a black box. So, I believe you need to include in this table the wire sizes you intend to use for connecting each of the proposed loads, before informed comment can be made on the correctness of your choices. Good question, though! regards Rowland | PFA 16532 EAA 168386 Young Eagles Flight Leader 017623 | Europa builder #435 G-ROWI ________________________________________________________________________________
Subject: amps
Date: Jan 10, 2001
But, Hedley, did you also test them in a 24v circuit? It's helpful to look at a manufacturer's catalogue to see for the expected trip characteristics of a particular circuit breaker should be. These will depend on whether its operation is magnetic or thermal, or combined magnetic/thermal. While you are correct in thinking that the trip current should be independent of the circuit voltage, how quickly it trips will depend on the rate at which the current rises and the current level reached. For example, a typical thermal circuit breaker, rated at up to 240 V 50 Hz AC/28 V DC, is quoted as having typical trip times in seconds at 23 degrees C. of: 100% -- no trip 200% -- 10-60 300% -- 3.5-14 400% -- 2-7 500% -- 1.5-5 600% -- 1-3.5 This means that you would see your test wire glowing at 200% rated current for up to a minute before the breaker trips. As your test wire heats up, its resistance would increase and reduce the current unless you slide the tapping to maintain a constant current. If the current dips below 200%, the trip time would even greater. Hope this helps Mike Europa Club Safety Officer -----Original Message----- From: hedley brown Subject: Re: amps I have been deluded by my simple mind into thinking that a 5-amp contact breaker for dc circuits would break at 5 amps regardless of whether it was rated at 12 or 24 amps. Not so. Having installed 11 of them from a motor trader's catalogue, with the great advantage that they were exchangeable with spade-type motor fuses, I was warned that because they were deemed suitable also for 24-volt circuits they might not break at the right amperage. I was incredulous - amps are amps.... relative to wire thickness that's what makes the heat that breaks the fuse or clicks the breaker, surely. No; they broke contact at twice the rated current, by which time my trial variable-length of hotwire was glowing brightly. Had to resort to good 'ole fuses and write off 110.00. Still don't understand the physics. Ah., well.... ________________________________________________________________________________
Date: Jan 10, 2001
Subject: Re: amps
hedley brown wrote: > > I have been deluded by my simple mind into thinking that a 5-amp contact > breaker for dc circuits would break at 5 amps regardless of whether it was > rated at 12 or 24 amps. Not so. Having installed 11 of them from a motor > trader's catalogue, with the great advantage that they were exchangeable > with spade-type motor fuses, I was warned that because they were deemed > suitable also for 24-volt circuits they might not break at the right > amperage. I was incredulous - amps are amps.... relative to wire thickness > that's what makes the heat that breaks the fuse or clicks the breaker, > surely. No; they broke contact at twice the rated current, by which time my > trial variable-length of hotwire was glowing brightly. Had to resort to good > 'ole fuses and write off 110.00. Still don't understand the physics. Ah., > well.... Hedley, did you give 'em enough time to pop at rated current? Seems I remember among Bob Nuckoll's many fine epistles some data on this, and it's measured in many seconds. He's anti-breaker anyway, as the advantage of being able to easily reset them is actually the problem. I agree especially for modern avionics. The scenario is: a 50-cent diode fails and creates havoc in the supply voltage to the integrated circuits. The breaker pops before anything else is damaged. Reset the breaker, and a $300 IC cooks. Reset it again (duh!!) and.... Regards, Fred F., A063 ________________________________________________________________________________
Date: Jan 11, 2001
Subject: HOSE ROUTING, EUROPA XS
Further to previous comments the following may be useful to those of you with the XS engine installations. The two oil hoses which run underneath the engine, one from the banjo fitting and the other from the oil pump, (C06), should be routed to pass over the water hose of the starboard rear cylinder to ensure maximum distance from the turbo charger/ exhaust system. These hoses should run just underneath the starter motor and pass through the ring mounting before going to the oil tank or oil cooler respectively. Regards Andy Draper Technical Manager ________________________________________________________________________________
Subject: ing in the cockpit module
Date: Jan 11, 2001
Hoping to bond the cockpit module into the canoe this weekend - with some trepidation. Anyone got any hits, tips or major disasters to avoid. Second thing, I did a trial fitting of the wings to the cockpit module the other day (used the dummy spar to set the bushes etc.) - very relieved to find it all lines up but how much clearance have folk got between the stbd spar and the bolts connecting aileron push rods to CS8 - seems awful close. ________________________________________________________________________________
Subject: Re: OIL HOSE ROUTING, EUROPA XS
Date: Jan 11, 2001
amazing....pure fluke....for once I got it right first time.... h ----- Original Message ----- From: Andy Draper <andy@europa-aircraft.com> Subject: OIL HOSE ROUTING, EUROPA XS > Further to previous comments the following may be useful to those of you with the XS engine installations. > > The two oil hoses which run underneath the engine, one from the banjo fitting and the other from the oil pump, (C06), should be routed to pass over the water hose of the starboard rear cylinder to ensure maximum distance from the turbo charger/ exhaust system. These hoses should run just underneath the starter motor and pass through the ring mounting before going to the oil tank or oil cooler respectively. > > Regards > > Andy Draper > Technical Manager > ________________________________________________________________________________
Date: Jan 11, 2001
Subject: Re: bonding in the cockpit module
Paul, The manual doesn't make this real clear but make sure in you get the module square to the fuselage. Trial fit it and make some marks/lines so it gets glued in the correct position. The module determines the wing position. You don't want one wing lower or further back than the other. If the module is a little off it makes for a bigger deviation out at the wing tips. I used the deck of the seat back rest behind the head rests as one datum plane. The fuselage flange (after being trimmed properly) just aft of the firewall as another, and the tailplane torque tube (which you haven't put in yet) as the third. You want all three parallel. The top surface of the foot wells are not as good as both the surfaces slope moving forward and are hard to see when you site with the other planes to see if they are parallel. Do compare the foot well to the other three surfaces though. You put the Redux glue on the module and then drop it in place. The glue will try to rub off on the fuselage as you slide the module in place. Best to have several hands to help spread the fuselage sides and assist lowering the module in place. I used a simple block and tackle overhead to assist lowering the module. I hooked the sling to the module in the head rest cut openings and guided the front of the module by hand. Before gluing check where the module contacts the fuselage and where there are gaps as you will want the glue to fill all the places it is supposed to contact the fuselage. I used self tapping screws sparingly (only 10 to 15) to draw the module to the fuselage. Realize that whether you use screws, rivets or clecos it potentially locally dimples the fuselage skin or can even more significantly deforms the fuselage shape. You want the module glued in but with out much deformation of the fuselage. I didn't draw down the screws tight if there was a space there as that would for sure dimple the outer skin. The Redux glue holds well even filling a space of 1/4 inch. Hopefully you won't have any spaces that large. I also found that the way you support the fuselage hull changes its shape. I used a sling or strap around the fuselage right at the rear of where the module goes as that let the fuselage bottom stay closest to its unloaded shape. I supported the front of the fuselage with two bolts through the fselage sides at the firewall to fuselage union. It is rather stiff there and not prone to deforming with any supporting methods. I used about 3/4 can of the Redux glue and had some clean up of glue that oozed from the joints. Make sure you use enough flox in the glue so it doesn't run. Too much flox in the glue is better than too little. Easiest to mix in many containers as opposed one or just a few. You might have someone measuring and mixing as you go. The temperature was about 80 deg F and I had plenty of time with out the Redux going off but that could be a concern. The Redux was setting up when I was through positioning and was cleaning up the ooze from the joints. You need to trim off a portion of the rear of the module which I don't believe is in the current manual yet. If this section is not trimmed before gluing, it will have to be trimmed later to put in the baggage compartment bulkhead. I can send you a picture of this area trimmed if you wish. I felt the same way about the spars clearance. Hopefully I won't discover a problem later. Good luck, Bill McClellan A164 flying wrote: > Hoping to bond the cockpit module into the canoe this weekend - with > some trepidation. Anyone got any hits, tips or major disasters to > avoid. Second thing, I did a trial fitting of the wings to the cockpit > module the other day (used the dummy spar to set the bushes etc.) - > very relieved to find it all lines up but how much clearance have folk > got between the stbd spar and the bolts connecting aileron push rods > to CS8 - seems awful close. regards Paul Stewart #432 ________________________________________________________________________________
Subject: bonding in the cockpit module
Date: Jan 11, 2001
Definitely worry about the spar clearance - I found it necessary to "modify" the aileron bellcrank faces to clear the bolts. The use of a hoist to lower the cockpit module is very convenient (a 2X4 of the right length will fit nicely into both headrests and is at a good location for reasonably good balance). I used essentially the same scheme Bill describes to hang the module and to spread and to support the fuselage - I can assure you that it makes the task much simpler. Having at least one other set of hands is likewise very helpful. Trimming the extra material from the rear of the cockpit module is a very good idea. I blindly followed the manual only to realize when it was time to install the baggage compartment bulkhead that it was rather tedious to make the required cut after bonding (especially since some of it was bonded to the fuselage sides!) Best regards, Rob Housman A070 -----Original Message----- Behalf Of Bill McClellan Subject: Re: bonding in the cockpit module Paul, The manual doesn't make this real clear but make sure in you get the module square to the fuselage. Trial fit it and make some marks/lines so it gets glued in the correct position. The module determines the wing position. You don't want one wing lower or further back than the other. If the module is a little off it makes for a bigger deviation out at the wing tips. I used the deck of the seat back rest behind the head rests as one datum plane. The fuselage flange (after being trimmed properly) just aft of the firewall as another, and the tailplane torque tube (which you haven't put in yet) as the third. You want all three parallel. The top surface of the foot wells are not as good as both the surfaces slope moving forward and are hard to see when you site with the other planes to see if they are parallel. Do compare the foot well to the other three surfaces though. You put the Redux glue on the module and then drop it in place. The glue will try to rub off on the fuselage as you slide the module in place. Best to have several hands to help spread the fuselage sides and assist lowering the module in place. I used a simple block and tackle overhead to assist lowering the module. I hooked the sling to the module in the head rest cut openings and guided the front of the module by hand. Before gluing check where the module contacts the fuselage and where there are gaps as you will want the glue to fill all the places it is supposed to contact the fuselage. I used self tapping screws sparingly (only 10 to 15) to draw the module to the fuselage. Realize that whether you use screws, rivets or clecos it potentially locally dimples the fuselage skin or can even more significantly deforms the fuselage shape. You want the module glued in but with out much deformation of the fuselage. I didn't draw down the screws tight if there was a space there as that would for sure dimple the outer skin. The Redux glue holds well even filling a space of 1/4 inch. Hopefully you won't have any spaces that large. I also found that the way you support the fuselage hull changes its shape. I used a sling or strap around the fuselage right at the rear of where the module goes as that let the fuselage bottom stay closest to its unloaded shape. I supported the front of the fuselage with two bolts through the fselage sides at the firewall to fuselage union. It is rather stiff there and not prone to deforming with any supporting methods. I used about 3/4 can of the Redux glue and had some clean up of glue that oozed from the joints. Make sure you use enough flox in the glue so it doesn't run. Too much flox in the glue is better than too little. Easiest to mix in many containers as opposed one or just a few. You might have someone measuring and mixing as you go. The temperature was about 80 deg F and I had plenty of time with out the Redux going off but that could be a concern. The Redux was setting up when I was through positioning and was cleaning up the ooze from the joints. You need to trim off a portion of the rear of the module which I don't believe is in the current manual yet. If this section is not trimmed before gluing, it will have to be trimmed later to put in the baggage compartment bulkhead. I can send you a picture of this area trimmed if you wish. I felt the same way about the spars clearance. Hopefully I won't discover a problem later. Good luck, Bill McClellan A164 flying wrote: Hoping to bond the cockpit module into the canoe this weekend - with some trepidation. Anyone got any hits, tips or major disasters to avoid. Second thing, I did a trial fitting of the wings to the cockpit module the other day (used the dummy spar to set the bushes etc.) - very relieved to find it all lines up but how much clearance have folk got between the stbd spar and the bolts connecting aileron push rods to CS8 - seems awful close. regards Paul Stewart #432 ________________________________________________________________________________
Date: Jan 12, 2001
Make sure the spread between the seat bulkhead front and back is correct per the manual. This affects the position of the back of the baggage bin which, if incorrect, will be impacted by the flap actuating arm on retraction. and Remember that the seat back is the angle of incidence of the wings. Get this at 2.5 degrees to the watermark reference and life will be much more pleasant later on. Of course this does assume that you got the spars rigged parallel to the seat back when you did the initial setup with the cockpit module out of the aircraft. Tony ________________________________________________________________________________
Date: Jan 11, 2001
Hi! Paul.(from a MK l Builder to an XS ......!) Make sure the top moulding is pulled well back onto the firewall to ensure the empenage to fin area is well overlapping . I needed to have a piece of 3/4" ply across the inside of the start of the fin then drilled through the lot to insert a long piece of 3/16" threaded bar right through to enable the lot to be tightened up together.I put a good smearing of redux on both flanges before mating together, don't allow the over-riding flange to ride up the register of the other anywhere, as it makes for lots of filling later. Make good use of a hand held light behind the joint to judge the thickness of the joint along the whole length of the overlap to ensure there is a bond over the entire overlap and flanges , don't squeeze all the redux out . Make an effort to trowel off all excess redux. On the spa clearance , my "old man " always said "a miss is as good as a mile "! There isn't a lot of clearance because I notice mine always only just clears when we do the rigging.! We have often missed the the starboard socket with the PORT SPAR THEN IT JAMS AGAINST THE SAID BOLT HEADS BFN Bob Harrison G-PTAG. -----Original Message----- From: owner-europa(at)aztec.houxou.com Subject: bonding in the cockpit module Hoping to bond the cockpit module into the canoe this weekend - with some trepidation. Anyone got any hits, tips or major disasters to avoid. Second thing, I did a trial fitting of the wings to the cockpit module the other day (used the dummy spar to set the bushes etc.) - very relieved to find it all lines up but how much clearance have folk got between the stbd spar and the bolts connecting aileron push rods to CS8 - seems awful close. regards Paul Stewart #432 ________________________________________________________________________________
Date: Jan 12, 2001
Hi! Paul. Serves me right for jumping in too quickly ! I see from ensuing messages that it's the module you are fixing in ,not the fuselage top ! Save my notes for when you need it.! (and dream on !) The tip about the light still applies , I made sure to omit redux where the control tubes pass through . I also had a dummy run , marked out where the redux was needed on the bottom of the canoe and applied redux to both surfaces . As Bill suggests trowel excess redux into any gaps , less weight and stronger to do this than deform the members and need loads of filler on the outside. Also make sure the aileron actuating plates clear the canoe floor when operated. Have you fitted the rudder cable pulleys,easier now (Bolt heads behind the pulleys) Europa won't thank me but have you checked the position of the aluminium hard point inserts for lift pin locations, in the canoe? Ours were out of place and when you drill through you are unable to verify that there is adequate metal around the holes.(much easier to reposition them without the module in place, believe me I've been there !) Regards Bob Harrison G-PTAG -----Original Message----- From: owner-europa(at)aztec.houxou.com Subject: RE: bonding in the cockpit module Hi! Paul.(from a MK l Builder to an XS ......!) Make sure the top moulding is pulled well back onto the firewall to ensure the empenage to fin area is well overlapping . I needed to have a piece of 3/4" ply across the inside of the start of the fin then drilled through the lot to insert a long piece of 3/16" threaded bar right through to enable the lot to be tightened up together.I put a good smearing of redux on both flanges before mating together, don't allow the over-riding flange to ride up the register of the other anywhere, as it makes for lots of filling later. Make good use of a hand held light behind the joint to judge the thickness of the joint along the whole length of the overlap to ensure there is a bond over the entire overlap and flanges , don't squeeze all the redux out . Make an effort to trowel off all excess redux. On the spa clearance , my "old man " always said "a miss is as good as a mile "! There isn't a lot of clearance because I notice mine always only just clears when we do the rigging.! We have often missed the the starboard socket with the PORT SPAR THEN IT JAMS AGAINST THE SAID BOLT HEADS BFN Bob Harrison G-PTAG. -----Original Message----- From: owner-europa(at)aztec.houxou.com Subject: bonding in the cockpit module Hoping to bond the cockpit module into the canoe this weekend - with some trepidation. Anyone got any hits, tips or major disasters to avoid. Second thing, I did a trial fitting of the wings to the cockpit module the other day (used the dummy spar to set the bushes etc.) - very relieved to find it all lines up but how much clearance have folk got between the stbd spar and the bolts connecting aileron push rods to CS8 - seems awful close. regards Paul Stewart #432 ________________________________________________________________________________
Date: Jan 12, 2001
Forwarded from the bounce bin. Message is from Nigel Charles <72016.3721(at)compuserve.com> ********************************************************* Message text written by "Garry Stout" > Rotax supplies a fine, high quality oil return hose to be used for this application. Due to the unique oil line routing (to the reservoir) recommended by Europa, a 120 degree bend in the hose is required just as the hose exits the sump banjo fitting. Europa supplies a substitute hose which is pre-molded with the 120 degree bend molded in....< Thanks for your input. I don't understand the 120 degree bend. On my 'Classic' Europa the banjo fitting is rotated aft and the hose routed towards the rear engine mounts. Having spoken to Neville at Europa he thinks that Silicone hose might be the best 'flexible' solution but agrees with your idea of a rigid return pipe. I am looking into the Silicone product as I do not have welding capabilities. Nigel Charles ________________________________________________________________________________
Date: Jan 13, 2001
I found it surprisingly easy - as did Neville, who was helping me. The tricks are: 1/ decent fuselage jig that holds the bottom half rigid (essential, I believe) 2/ remove the module side pieces "seat front to seat back" and "seat front to rudder pedal bulkhead" - replace later with 3 x bid (approved by Andy) 3/ sort out position - all I needed was 2 x AN3 bolts pulling the module as far forward as possible, 2 X skin pins just forward of the aft bulkhead about 4" down, and a wide ratchet strap pulling down on the seat headrest tops via a 3 X 4 and a couple of eye bolts. - mark positions with guide lines/tape 4/ pure redux on bond areas in shell, redux/flox on flanges of cockpit module (thicker where appropriate) - spread shell slightly when dropping module in: went in with no fuss, took about 10 minutes to settle into position, another hour to clean up the ooze... Total time from mixing redux to going to the pub - about 2 1/2 hours - 1/2 hour was standing there going ooh aah.... No big deal if you are prepared - 2 people essential, 3 or 4 would be nice. Might be able to find a pic - not that it shows much..... good luck! Miles ________________________________________________________________________________
Subject: on Hose.
Date: Jan 12, 2001
Hi Everyone, Has anyone else tried to use metal sheathed teflon hose for the oil return pipe under the Rotax?. Following the thread on the web site, I decided to try and source some suitable hose and found some that sounded just right [ spec. to 232Deg C., 103Bar operating pressure] at a local Aeroquip supplier. This has to be swaged onto the fittings at each end, so they tried to source fittings that matched the Rotax ones, but with limited success. Although the threads matched, they were for higher pressure applications, so the walls were thicker resulting in a smaller bore. In the end I got them to swage the teflon hose onto my supplied fittings, and it looked good. There were two problems though. Firstly the hose won't twist at all, so the angles of the fittings have to be very accurately set before swageing. Secondly the hose is quite stiff and although the min bend radius is quoted as 165mm, which should be tight enough, the hose tends to go quite lumpy and out of shape as it is fed through the tight spaces. These lumps and and slight kinks don't go away when the hose is straightened. Does anyone know if this is likely to be a problem under the temperatures and pressures of normal operation?. Is it going to get worse with the vibration?. Is the flow going to be at all restricted? Many Thanks, Paddy Clarke # 404 ________________________________________________________________________________
Date: Jan 13, 2001
I found it convenient to add a kitchen cabinet type handle to the top of the tunnel about 2 inches back from the front flange. This to simplify lowering the seat module into place. The handle remained there until cutout of the firewall allowed access to the screws to remove it. We had 3 people involved to mix and spread the Redux. Then a couple neighbors came over to augment the work force to 5 temporarily while installing the seat module. One person held the front handle plus one at each rear corner of the seat module. Two helpers spread the canoe sides while the seat module was lowered into place. Cleanup of the Redux which extruded was memorable for the mess involved - it had begun to set up by the time the seat module was completely secured and became difficult to remove. John N44EU ________________________________________________________________________________
Subject: ing cables to the instrument panel
Date: Jan 13, 2001
Hi All, I was wondering what folks were doing for cable routing from the back of the fuselage forward to the instrument panel. Could some of you share with me your ideas. Thanks, Paul Builder 363 http://pma.obtero.net ________________________________________________________________________________
Date: Jan 14, 2001
Subject: ileron hinge rivets...
Hello all... I've begun working on the placing the hinges on the aileron. I've run into a situation. The hinge rivets on the trailing edge end up very near the base of the V shaped are where the hinges are being installed. (Pg. 7-7) There is room enough (depth wise) for the hinges once installed and compressed, but there is not enough room for them prior to compression. In other words, the rivets on the trailing edge side of the hinge cannot be shoved all the way in their respective holes because the rivet bottoms out before it is fully seated. So, I'm trying to figure out the best way to get around this problem. It seems to be something one cannot 'get around' but something to deal with. The only thing I can see to do would be to drill slightly into the area of the V that the rivets run into. The only problem with that is will be necessary to shove some epoxy into the 1/8" holes. I think the depth of these little 1/8" holes would also be around 1/8". So, we're not talking about much. Am I the only one to have encountered this? Or, is it a 'normal' situation dealt with such as I have suggested? Does someone have a different or better way to solve this? Jeff A191 ________________________________________________________________________________
Subject: XS Aileron hinge rivets...
Date: Jan 14, 2001
Hi! Jeff As a Mk 1 builder In My Humble Opinion..... Your solution sound good, Only use a FLOX MIX NOT JUST EPOXY and pop the rivet whilst wet Lets face it you aren't going to get the rivets in any other way ! Regards Bob Harrison Kit 337 G-PTAG -----Original Message----- On Behalf Of JLW Sent: 14 January 2001 19:15 Subject: XS Aileron hinge rivets... Hello all... I've begun working on the placing the hinges on the aileron. I've run into a situation. The hinge rivets on the trailing edge end up very near the base of the V shaped are where the hinges are being installed. (Pg. 7-7) There is room enough (depth wise) for the hinges once installed and compressed, but there is not enough room for them prior to compression. In other words, the rivets on the trailing edge side of the hinge cannot be shoved all the way in their respective holes because the rivet bottoms out before it is fully seated. So, I'm trying to figure out the best way to get around this problem. It seems to be something one cannot 'get around' but something to deal with. The only thing I can see to do would be to drill slightly into the area of the V that the rivets run into. The only problem with that is will be necessary to shove some epoxy into the 1/8" holes. I think the depth of these little 1/8" holes would also be around 1/8". So, we're not talking about much. Am I the only one to have encountered this? Or, is it a 'normal' situation dealt with such as I have suggested? Does someone have a different or better way to solve this? Jeff A191 ________________________________________________________________________________
Date: Jan 14, 2001
Subject: Re: Routing cables to the instrument panel
<> Paul, my standard europa fin antenna cable and the transponder cable come through some lightweight oval conduit up the port side, both then plug into sockets mounted under the port side panel. Trim servo cables, strobe and capacitance fuel gauge cables come up the starboard side, same type of conduit, but are taken to the firewall and through into the engine compartment. Fuel pump cables up the inside of the tunnel, through the firewall into the engine compartment too. With all cables requiring connection to the panel now in the engine compartment, you only need one multi-plug to bring them all neatly back through the firewall and into the panel itself. I used a zip type push plug with a ring connector that screws the two halves together and locks with a nice click to it. chus, dave g-bxum kit67 ________________________________________________________________________________
Subject: Routing cables to the instrument panel
Date: Jan 14, 2001
Hi! Paul. I used domestic box section plastic conduit , the type that has a lid, that way you can do some "add too's " later !!!! You can bend it with a heat gun quite easily I had two larger ones down the P1 side under the door cill , and a smaller section one on the starboard side. Then to route behind the panel I used lots of the larger spiral wrap. Regards Bob Harrison G-PTAG Kit 337 -----Original Message----- On Behalf Of Paul McAllister Sent: 14 January 2001 03:35 Subject: Routing cables to the instrument panel Hi All, I was wondering what folks were doing for cable routing from the back of the fuselage forward to the instrument panel. Could some of you share with me your ideas. Thanks, Paul Builder 363 http://pma.obtero.net ________________________________________________________________________________
Date: Jan 14, 2001
From: Graham Singleton <grasingleton(at)avnet.co.uk>
Subject: Re: XS Aileron hinge rivets...
> I've begun working on the placing the hinges on the aileron. I've >run into a situation. The hinge rivets on the trailing edge end up very >near the base of the V shaped are where the hinges are being installed. >(Pg. 7-7) There is room enough (depth wise) for the hinges once >installed and compressed, but there is not enough room for them prior to >compression. I think we've all had this problem and got round it one way or another. However, IMHO it is best to fit the hinges on first using skin pins and let the flox cure with the hinges still fixed to the straight edge, before pulling the rivets. This way you won't distort the hinges if the flange is not perfectly flat. Less likely for resin to be squashed out of the flox and into the hinge pins this way too. Graham ________________________________________________________________________________
Date: Jan 14, 2001
Hi Paul, One item which I found quite useful is some self-adhesive plastic wire channel which has a snap cover. It comes in various sizes and can be found at << http://www.rockler.com/findit.cfm?page=32 >>. Cheers, John A099, N262WF Paul McAllister wrote: > Hi All, > > I was wondering what folks were doing for cable routing from the back of the > fuselage forward to the instrument panel. Could some of you share with me > your ideas. > > Thanks, Paul > Builder 363 > http://pma.obtero.net > ________________________________________________________________________________
Date: Jan 14, 2001
Paul, I glassed in a piece of 1" lightweight plastic conduit under the door lip on each side. It has the added advantage of making the lower door frame stronger so when you slide in & out of the cockpit it won't crack. To hold the wires in the tailcone Cliff found some of the lightweight peel and stick plastic holders for cable ties. You just stick them on and then run a cable tie through them - works great and is very light and easy to add wires. Later Bob Jacobsen A131 From: "Paul McAllister" <pma(at)obtero.net> >Subject: Routing cables to the instrument panel >Date: Sat, 13 Jan 2001 21:34:54 -0600 > >Hi All, > >I was wondering what folks were doing for cable routing from the back of >the >fuselage forward to the instrument panel. Could some of you share with me >your ideas. > >Thanks, Paul >Builder 363 >http://pma.obtero.net > > ________________________________________________________________________________
Date: Jan 14, 2001
Subject: ron Length
Hi All, We're putting the hinges on our XS ailerons. We cheated (lazy) and purchased the prebuilt Stage 1 kit so the ailerons came precovered. We noticed that the ailerons are 60.825 long measured along the hinge flange. The opening in the wing is 60.5 long without leaving any clearance at either end of the aileron. Are we supposed to cut off some of the aileron or how do we make them fit in the openings? We're rather do surgery to the tip end as the root close outs and their bolts are completed. Thanks for all the help we get from this list. Jim & Heather Butcher A185 ________________________________________________________________________________
Date: Jan 14, 2001
Why not use the banjo fitting that is supplied with the engine and cut off the barb. Weld on a short length of hydraulic tubong (seamless steel) and have it long enough to get from under the engine and muffler and then reweld the barbed end on the tubing. Support it with a strap to the engine fro vibration insulation. Then use the supplied tubing to complete the run to the oil tank. That is the way I'm going to solve the "fried oil line" problem. I will also use fire sleeve around the pipe to keep the temps of the steel line low enough to allow it to keep in spec. (around a max. of 190 to 200 deg. F.) This would sure solve the problem. I'm glad Gary and I concur, as he and I spent a bit of time going over the many small problems that we have solved our own way. I cannot hardly wait untill my beast in to the air to try out my other ideas. (40A alternator, cowl flaps, air exit naca vent on the back of the a/c with a controlable flap to let air out at a controllable rate, rudder trim that mounts inside the a/c and weighs 1#, using the Rotax intake manifold with modifications to allow it to be used with the europa mount-needs extensive mods-and moving the air pick-up down into the air inlet for the turbo cavity below the oil tank.) By the way, only make the steel pipe long enough to get it out from under the engine. Keep a reasonable length flex line to the tank for vibration control Jim A058 St. Petersburg Fl. writes: > Following on from the recent discussions on this subject, I have > looked at > my hoses which seem fine at the moment. However, it seems prudent > to have > some spare hose to hand. Unfortunately I cannot easily read the > specification printed on the return hose, except that it says '13mm' > and has > a 'Burst Pressure' which is unreadable. This oil return hose also > looks to > be made of a slightly different material to the other oil hoses > (these seem > to have a more textured and less smooth feel). Are they all > actually meant > to be the same spec. and does anyone know the exact current > specification of > these hoses (diameters and temperature/pressure rating)? > > Was there a final conclusion to the best material for such a hose > (Teflon, > Silicon, rubber etc)? > > Many thanks in advance. > > David Cripps > GBWJH > > The Europa List is supported by Aviators Network UK - > info(at)avnet.co.uk ________________________________________________________________________________
Subject: Aileron Length
Date: Jan 14, 2001
Jim: This must be pretty typical asboth my ailerons were the same way ans I built them myself. I would suggest that you fit up your flaps and then position your aileron in. After lining every thing up as good as possible make judgement call as to which side to trim to give you the smallest gap either at the wing tip or the flap interface. Just sand off a little at a time as its alot easer than going back and having to add on. You may want/have to take a little off each end to get the nicest fit. Remember this is a custom job, fit. . . sand . . . fit . . etc. Have fun Steve Hagar A143 Mesa, AZ > [Original Message] > From: <PreDial(at)aol.com> > Date: 1/14/01 6:53:03 PM > Subject: Aileron Length > > Hi All, > > We're putting the hinges on our XS ailerons. We cheated (lazy) and purchased > the prebuilt Stage 1 kit so the ailerons came precovered. We noticed that > the ailerons are 60.825 long measured along the hinge flange. The opening in > the wing is 60.5 long without leaving any clearance at either end of the > aileron. Are we supposed to cut off some of the aileron or how do we make > them fit in the openings? We're rather do surgery to the tip end as the root > close outs and their bolts are completed. > > Thanks for all the help we get from this list. > > Jim & Heather Butcher A185 --- Steve Hagar --- hagargs(at)earthlink.net ________________________________________________________________________________
Date: Jan 15, 2001
Subject: Re: Aileron Length
Hi Steve, Do not make the fit to the flaps too tight as the wings will deflect in flight and cause them to touch. I had to file mine for clearence after the first flight. Barry Tennant D-EHBT Steve Hagar schrieb: > > Jim: > > This must be pretty typical asboth my ailerons were the same way ans I > built them myself. I would suggest that you fit up your flaps and then > position your aileron in. After lining every thing up as good as possible > make judgement call as to which side to trim to give you the smallest gap > either at the wing tip or the flap interface. Just sand off a little at a > time as its alot easer than going back and having to add on. You may > want/have to take a little off each end to get the nicest fit. Remember > this is a custom job, fit. . . sand . . . fit . . etc. > > Have fun > Steve Hagar > A143 > Mesa, AZ > > > [Original Message] > > From: <PreDial(at)aol.com> > > Date: 1/14/01 6:53:03 PM > > Subject: Aileron Length > > > > Hi All, > > > > We're putting the hinges on our XS ailerons. We cheated (lazy) and > purchased > > the prebuilt Stage 1 kit so the ailerons came precovered. We noticed > that > > the ailerons are 60.825 long measured along the hinge flange. The > opening in > > the wing is 60.5 long without leaving any clearance at either end of the > > aileron. Are we supposed to cut off some of the aileron or how do we > make > > them fit in the openings? We're rather do surgery to the tip end as the > root > > close outs and their bolts are completed. > > > > Thanks for all the help we get from this list. > > > > Jim & Heather Butcher A185 > > --- Steve Hagar > --- hagargs(at)earthlink.net > ________________________________________________________________________________
Subject: HLP - Ailerons again!
Date: Jan 15, 2001
Message from Tony Renshaw renshaw(at)ozemail.com.au *************************** > John, > Just remember that the glass fibres individually, whether when viewed in > plan view or side elevation, must not experience a deviation of more than > 1/25!! This is all you need to know to maintain strength. So for your > aileron problem I would think it best to countour the foam such that the > top skin dips down and then mates nicely with the trailing edge of the > first skin. Dips are OK!! They are structurally strong and easily filled. > You could go down the other path of filling with dry micro but just > remember to key sand it for the skin when you cover it up. This is also > easy and maintains the imperative rule "1:25 MAX". Don't forget this at any > stage and whatever fudges you make will be OK. Dont worry about the > threads. Pull out the ones you can and forget the others. After a closeout, > filler and paint it isn't worth the time!! I say this from someone who has > swetted about these things too. We have to maintain a momentum similar to > what a professional would do if contracted to build our kits behind our > backs. Would these omitions etc compromise strength? If not, keep going. > Reg > Tony Renshaw(#0236) ________________________________________________________________________________
Subject: o and transponders
Date: Jan 15, 2001
Forwarded from the bounce bin. Message is from "Patrick" *************************************************** Guess I'd better re-introduce myself since I've not been on this group for a couple of years. Built kit 69 G-PATZ mono classic and been happily flying for a bit over a year. Not as much as I'd hoped but then again optimism was always my weakness. And now for my request for help. Can anyone recommend someone in U.K. who can put the smoke back in a Garmin Transponder. After only 70 hours it decided to give up and fry a couple of components on the board. Quite upset the best weekend's flying weather for ages! Still in spite of the expensive scent had a great weekend's flying that was much needed. Withdrawal symptoms were beginning to hurt. Any advice or info would be very much appreciated Patrick Griffin ________________________________________________________________________________
Date: Jan 15, 2001
> After lining every thing up as good as possible >make judgement call as to which side to trim to give you the smallest gap >either at the wing tip or the flap interface. Just sand off a little at a >time as its alot easer than going back and having to add on. You may >want/have to take a little off each end to get the nicest fit. Remember >this is a custom job, fit. . . sand . . . fit . . etc. > > Are we supposed to cut off some of the aileron or how do we >make them fit in the openings? We're rather do surgery to the tip end >as the >root close outs and their bolts are completed. Don't forget also, that the flap moves outboard as it is raised due to the geometry of the dihedral. The clearance between flap tip and aileron root needs to be checked with the plane rigged and the gear up. Graham ________________________________________________________________________________
From: "Rob Housman" <ROB-HOUSMAN(at)worldnet.att.net>
Date: Jan 15, 2001
The (optional) Europa supplied wiring harness has all power leads going forward along the joint between the upper and lower fuselage moldings, so I have routed all antenna cables in the corresponding location on the port side. Best regards, Rob Housman A070 ________________________________________________________________________________
From: "Dr. Christoph Both" <christoph.both(at)acadiau.ca>
Date: Jan 15, 2001
Subject: er forward and old engine installation kit
Dear Europa builders: I am building the styro MK-1 version and by far prefer the old engine installation before the XS cowl came along. Can you please comment ont he following questins: 1) I like to move the rudder pedals as much as possible forward. With the old engine installation I understand that the engine might be a bit lower and closer to the firewall than with the XS. Has someone moved the pedals forward and how much is possible before you hit the engine? 2) It seems that EUROPA has ceased to produce a MK-1 "classic" engine installation kit, mainly because they cannot produce the two radiators as required. Besides the notion that some of the many MK-1 builders might require possible replacement in the future the old kit is not offered any more. Is someone considering going XS firewall forward and selling your old kit to me? Please let me know, reasonable offers accepted. Thanks, Christoph Both UK #223, Wolfville, Nova Scotia, Canada ________________________________________________________________________________
Subject: Rudder forward and old engine installation kit
Date: Jan 15, 2001
Hi! Christopher, I have top and bottom Mk 1 Cowls available since my a/c is Jabiru way ! I haven't taken particular care how I've stored them but they are quite tidy and unused. Make a reasonable offer and arrange the carrier and you are welcome. Regarding your rudder pedal question I very much doubt you can get any further forward than that dimension in the manual. Just measured mine to be 3.75" centre line aft of the inside of the footwell. However I know Europa extended some footwells by about 2" but I think they were experimenting with some heel toe brakes /rudder pedals on a trike and the extension was for clearance of the additional mechanism forward of the rudder pedal. You didn't make it clear if your fuselage is Mk1 or XS if it's XS then you may have the extended foot wells (above) and therefore you would need to canvas Neville or Andy's opinion at Europa with regards to engine clearance. Regards Bob Harrison G-PTAG (Europa /Jabiru 3300) -----Original Message----- On Behalf Of Dr. Christoph Both Sent: 15 January 2001 16:26 Subject: Rudder forward and old engine installation kit Dear Europa builders: I am building the styro MK-1 version and by far prefer the old engine installation before the XS cowl came along. Can you please comment ont he following questins: 1) I like to move the rudder pedals as much as possible forward. With the old engine installation I understand that the engine might be a bit lower and closer to the firewall than with the XS. Has someone moved the pedals forward and how much is possible before you hit the engine? 2) It seems that EUROPA has ceased to produce a MK-1 "classic" engine installation kit, mainly because they cannot produce the two radiators as required. Besides the notion that some of the many MK-1 builders might require possible replacement in the future the old kit is not offered any more. Is someone considering going XS firewall forward and selling your old kit to me? Please let me know, reasonable offers accepted. Thanks, Christoph Both UK #223, Wolfville, Nova Scotia, Canada ________________________________________________________________________________
Subject: ranger tank - tip
Date: Jan 15, 2001
For those of you using the long range tank or those considering fitting the same Hi folks! you might be interested in the following mod. The extra tank feed is only by siphon so if the main tank is not empty then the extra tank will always have a cosiderable amount of fuel in it making it not so convenient to use for short periods. Many of us received last year a higher capacity fuel pump from Europa. I have fitted the old pump in the feed line from the extra tank to the main tank. After flight (or during flight) just pump the remaining fuel from the extra into the main tank and take the empty tank with you!! I do not know if you UK guys will need a PFA mod for something like this. Best regards Barry Tennant ________________________________________________________________________________
Subject: Re: Long ranger tank - tip
Date: Jan 15, 2001
01/15/2001 01:07:42 PM Hi folks, regarding long range fuel tanks, has anyone with a trigear come up with a long range fuel tank? As you know, the space for the monowheel long range tank is take up with the main gear leg structure. Regards, Garry N4220S (813) 878-3929 FAX (813) 878-5651, Internet ID Garrys(at)att.com ________________________________________________________________________________
From: "Alan Stewart" <alan.stewart(at)blueyonder.co.uk>
Date: Jan 15, 2001
Interesting and practical Barry, In my personal experience, I've found a far more pressing limitation to endurance. The solution is generally found in the application of a rather primitive but effective, empty plastic soft drink bottle purchased from the local supermarket. Accuracy is vital when used. The embarrasment factor is high, especially on landing at a busy airfield. ...... just excuse the contents as a rather obscure beverage that proved distasteful and dump in the nearest drain soon after landing. Alan ----- Original Message ----- From: "Tennant" <Tennant@t-online.de> Subject: Long ranger tank - tip For those of you using the long range tank or those considering fitting the same Hi folks! you might be interested in the following mod. The extra tank feed is only by siphon so if the main tank is not empty then the extra tank will always have a cosiderable amount of fuel in it making it not so convenient to use for short periods. Many of us received last year a higher capacity fuel pump from Europa. I have fitted the old pump in the feed line from the extra tank to the main tank. After flight (or during flight) just pump the remaining fuel from the extra into the main tank and take the empty tank with you!! I do not know if you UK guys will need a PFA mod for something like this. Best regards Barry Tennant ________________________________________________________________________________
Date: Jan 16, 2001
Subject: pective on oil pipes.
On only has to look up the thermal conductivity tables to see that if you need to resist incoming radiation/convection, rubber/plastic etc. is a non-starter compared with metals. Take an area or 10cm x 1cm (typical of the area exposed to the exhaust pipe) and a wall thickness of 1mm, a steel pipe would develop only 14 deg.C across its wall for every incident kW. As 1kW is an overestimate of what really arrives (we only have 60kw max. from engine and most of that is either defeating drag or or going out of the radiatior) there is never going to be any thermal problem (apart from some local rise in oil temperature before it reaches the oil cooler and goes the way of all heat ). By contrast rubbers are 500 times worse and will fry under such intensity. Large wall thickness too. Copper is 5.5 times, Al. 3.3 times better than steel. There is no need for elaborate thermal calculations of the arrival energy at the pipe. A thermocouple (or simpler, blobs of Thermal paints) can give advance warning of such problems. Since reporting in-flight failure of the original system in April 99 (the first ?) I have run with a metal pipe between rubber end pieces at the cool ends, with no deterioration. Graham C. G-EMIN ________________________________________________________________________________
Date: Jan 16, 2001
In a message dated 15/01/2001 20:55:25 GMT Standard Time, alan.stewart(at)blueyonder.co.uk writes: << In my personal experience, I've found a far more pressing limitation to endurance. >> Did you consider a funnel/pipe to the floor ? Look for Europas with vapour trails. The hole also comes in handy for flour bomb releasing. I once won a prize for the furthest miss when the slipstream blew it out before take-off (the flour that is (:-))). Graham C. G-EMIN ________________________________________________________________________________
Subject: Re: Wanted
Date: Jan 16, 2001
I am a slow builder of kit 244 and have much appreciated the hints and tips on this forum. However I would like to get flying sooner than I can finish my example, therefore I would like to purchase a tricycle Europa with current permit to fly. I promise a good home. So please e-mail me or telephone +44 (0)1892 835049 Or write Nettlestead Lodge Maidstone Road Paddock Wood Kent TN12 6DA Regards Steve Lamb ________________________________________________________________________________
Date: Jan 16, 2001
Subject: Re: RE: Aileron Length
>The flap should not move outboard as it is raised. If anything, there >should be a slight movement inboard as the hinge centres are progressively >further from the wing the further inboard you go. > >If the flaps are found to move outboard during retraction it is because >there is inadequate clearance between the flap root and the operating tube >which runs through the fuselage. >Ensure that the flaps and this tube don't come into contact with each >other until the flaps are up or within 5 degrees down maximum. >Andy Draper Thanks Andy, absolutely right. Wooly thinking I guess. My incomplete thought was the flap will move out, but only if the flap cross tube is too long. IOW adjust the length of the flap tube, not the flap. Sorry folks!. Graham ________________________________________________________________________________
From: "Nigel Graham" <nigel_graham(at)intercept.com>
Date: Jan 16, 2001
> ----- Original Message ----- > In my personal experience, I've found a far more pressing limitation to > endurance. > ...... just excuse the contents as a rather obscure beverage that proved > distasteful and dump in the nearest drain soon after landing. > > Alan For God's sake man ....don't throw it away. This stuff has been sold for years in the States as Budwiser Lite! Nigel ________________________________________________________________________________
Date: Jan 16, 2001
Subject: Re: [Re: Long ranger tank - tip]
Hear, hear!! Ditto for Coors Light, Miller Lite, etc. etc. ad nauseum. Lite beer is a cruel joke. Fortunately, living in Wisconsin has its benefits other than lots of snow and good cheese. Good BEER! We have no shortage of local breweries that make some of the finest beers in the world, one of my newest favorites is the New Glarus Brewing Co. Ahhh, a taste of summer in Wisconsin: Bratwurst on the grill, with some early sweet corn roasting in the husk next to the brats, and a cold glass of handcrafted beer. Top it off with some ice cream for dessert. YUMMY! I just keep telling myself - summer is coming, summer is coming.... Sorry about the OT post. I couldn't resist Nigel's comments. Chris "Nigel Graham" wrote: > For God's sake man ....don't throw it away. > This stuff has been sold for years in the States as Budwiser Lite! > > Nigel > > ________________________________________________________________________________
Date: Jan 16, 2001
In article <000c01c07f2a$6108e220$67e81f3e@AlanStewart>, alan.stewart(at)blueyonder.co.uk (Alan Stewart) wrote: > Interesting and practical Barry, > > In my personal experience, I've found a far more pressing limitation to > endurance. > > The solution is generally found in the application of a rather > primitive but > effective, > empty plastic soft drink bottle purchased from the local supermarket. > > Accuracy is vital when used. The embarrasment factor is high, > especially on > landing > at a busy airfield. > > ...... just excuse the contents as a rather obscure beverage that proved > distasteful and > dump in the nearest drain soon after landing. > > Alan > > ----- Original Message ----- > From: "Tennant" <Tennant@t-online.de> > Subject: Long ranger tank - tip > > > For those of you using the long range tank or those considering fitting > the > same > Hi folks! > > you might be interested in the following mod. > > The extra tank feed is only by siphon so if the main tank is not empty > then > the > extra tank will always have a cosiderable amount of fuel in it making > it not > so > convenient to use for short periods. > > Many of us received last year a higher capacity fuel pump from Europa. I > have > fitted the old pump in the feed line from the extra tank to the main > tank. > > After flight (or during flight) just pump the remaining fuel from the > extra > into > the main tank and take the empty tank with you!! > > I do not know if you UK guys will need a PFA mod for something like > this. > > Best regards > > Barry Tennant I suppose for those of us with low bladder capacity the answer would be to buy two tanks one connected to the fuel system and the other..... Paul Atkinson ps best to make sure that they cant be connected the rong way. ________________________________________________________________________________
Date: Jan 16, 2001
Paul/Liz This proposal is nothing to do with "The Mile High Club has it ? For a while my imagination got the better of me then I remember needing to get my arms down to top up the trike brakes by having the rest of my body upside down on the P1 seat. ! Really, I'm too old for these kind of antics......... which ever ...... prefer some comfort these days !!!!!! Regards to all Bob Harrison G-PTAG (16 hours complete, awaiting PFA final permit!) -----Original Message----- On Behalf Of Paul & Liz Atkinson ________________________________________________________________________________
Date: Jan 16, 2001
Subject: New member
Hi all; It seems a long time ago that I put my deposit/order in for my new monowheel XS kit. It was November after I attended the workshop out in Corona, California taught by Kim Prout. Since then I've put in a beautiful, gleaming white floor (by Hard Deck Coatings), have installed a new 200 amp panel, have installed additional light circuits and finally installed additional electrical circuits. I've been accumulating tools mostly off of E-bay. The ones I have left to buy are a mystery to me...no idea what they are by the name on the tool list given me. I trust it'll become more apparent what I need once I actually start building. Any ideas on what I might do to pass the time awaiting my March arrival of my "newborn"?? Enjoying this web site....have printed out many letters describing solutions to certain problem procedures. Thanks to all...hope to meet you in the upcoming months and years Paul Boulet, Malibu, California ________________________________________________________________________________
Date: Jan 16, 2001
From: Steve & Eileen Genotte <gopack(at)sprintmail.com>
Grahamclk(at)aol.com wrote: > > In a message dated 15/01/2001 20:55:25 GMT Standard Time, > alan.stewart(at)blueyonder.co.uk writes: > > << In my personal experience, I've found a far more pressing limitation to > endurance. >> > > Did you consider a funnel/pipe to the floor ? Look for Europas with > vapour trails. Yet another thing to have to worry about in case of a gear-up landing! I'd be sure to add a line to my checklist about stowing all delicate items before entering the pattern. Steve G. ________________________________________________________________________________
Date: Jan 16, 2001
...and to which delicate item do you refer? -----Original Message----- On Behalf Of Steve & Eileen Genotte Sent: Tuesday, January 16, 2001 1:25 PM Cc: alan.stewart(at)blueyonder.co.uk; Tennant(at)t-online.de; europa(at)avnet.co.uk Subject: Re: Long ranger tank - tip Grahamclk(at)aol.com wrote: > > In a message dated 15/01/2001 20:55:25 GMT Standard Time, > alan.stewart(at)blueyonder.co.uk writes: > > << In my personal experience, I've found a far more pressing limitation to > endurance. >> > > Did you consider a funnel/pipe to the floor ? Look for Europas with > vapour trails. Yet another thing to have to worry about in case of a gear-up landing! I'd be sure to add a line to my checklist about stowing all delicate items before entering the pattern. Steve G. ________________________________________________________________________________
Subject: RE: New member
Date: Jan 16, 2001
200 AMPS!!! Are you using 7.5kW xenon searchlight lamps for illumination? I know its a little cooler at the beach than where I am but you certainly can't be contemplating heating your shop electrically (heck, if you actually use all that power you'll need a/c instead just to overcome the waste heat). But seriously, whatever are you contemplating? I hope that nice new white floor is NOT in your soon to be Europa workshop. My (plain old concrete) garage, er, workshop floor is looking so shabby after countless epoxy drippings that I need to do something to improve its looks once the project is completed. It no longer looks good enough to park cars on it. At least with the monowheel you won't be using Bondo to hold fixturing (for the main gear installation) to the concrete - that left two large "dimples" where the Bondo bonded much better than the Europa manual suggests. As for passing time until March, I've got this mostly complete XS Tri-Gear in my "hanger" in Irvine, and you are welcome to hone your building skills anytime you'd like. Best regards, Rob Housman A070 -----Original Message----- On Behalf Of PBoulet(at)aol.com Sent: Tuesday, January 16, 2001 12:19 PM Cc: europa(at)avnet.co.uk Subject: RE: New member Hi all; It seems a long time ago that I put my deposit/order in for my new monowheel XS kit. It was November after I attended the workshop out in Corona, California taught by Kim Prout. Since then I've put in a beautiful, gleaming white floor (by Hard Deck Coatings), have installed a new 200 amp panel, have installed additional light circuits and finally installed additional electrical circuits. I've been accumulating tools mostly off of E-bay. The ones I have left to buy are a mystery to me...no idea what they are by the name on the tool list given me. I trust it'll become more apparent what I need once I actually start building. Any ideas on what I might do to pass the time awaiting my March arrival of my "newborn"?? Enjoying this web site....have printed out many letters describing solutions to certain problem procedures. Thanks to all...hope to meet you in the upcoming months and years Paul Boulet, Malibu, California ________________________________________________________________________________
Date: Jan 16, 2001
That's best left to the individual to decide, no? :-) Steve G. Rob Housman wrote: > > ...and to which delicate item do you refer? > > -----Original Message----- > On Behalf Of Steve & Eileen Genotte > Cc: alan.stewart(at)blueyonder.co.uk; Tennant(at)t-online.de; europa(at)avnet.co.uk > Subject: Re: Long ranger tank - tip > > Grahamclk(at)aol.com wrote: > > > > In a message dated 15/01/2001 20:55:25 GMT Standard Time, > > alan.stewart(at)blueyonder.co.uk writes: > > > > << In my personal experience, I've found a far more pressing limitation to > > endurance. >> > > > > Did you consider a funnel/pipe to the floor ? Look for Europas with > > vapour trails. > > Yet another thing to have to worry about in case of a gear-up landing! > I'd be sure to add a line to my checklist about stowing all delicate > items before entering the pattern. > > Steve G. ________________________________________________________________________________
Date: Jan 16, 2001
Don't the brats muck up the grill with all that fat a skin dripping all over the place? You Americans sure like your white goods on the large side. I'd have to cut my brats into tiny pieces to get them any where near the grill. Jerry LTS(at)avnet.co.uk http://www.avnet.co.uk/touchdown ----- Original Message ----- From: Chris Beck <EuropaChris(at)netscape.net> ; Tennant Subject: Re: [Re: Long ranger tank - tip] > Hear, hear!! Ditto for Coors Light, Miller Lite, etc. etc. ad nauseum. > > Lite beer is a cruel joke. Fortunately, living in Wisconsin has its benefits > other than lots of snow and good cheese. Good BEER! We have no shortage of > local breweries that make some of the finest beers in the world, one of my > newest favorites is the New Glarus Brewing Co. > > Ahhh, a taste of summer in Wisconsin: Bratwurst on the grill, with some early > sweet corn roasting in the husk next to the brats, and a cold glass of > handcrafted beer. Top it off with some ice cream for dessert. YUMMY! > > I just keep telling myself - summer is coming, summer is coming.... > > Sorry about the OT post. I couldn't resist Nigel's comments. > > Chris > > > "Nigel Graham" wrote: > > > For God's sake man ....don't throw it away. > > This stuff has been sold for years in the States as Budwiser Lite! > > > > Nigel > > > > > > http://home.netscape.com/webmail ________________________________________________________________________________
Subject: p oil line.
Date: Jan 16, 2001
This industry is rampant with rookies and ignance. So many obvious things under looked over such a long time. A qualified designer should have at least an American A&P, or better yet, the British 2 year version. (I can't remember what its called. Damn fine it is.) Still, we endeavor to persevere. The oh-so-weenie choice of cheap oil hose should be a warning. Try to learn about this stuff for yourself. Books are cheap. Advice is cheaper still. I don't have a Rotax, so I don't know. (Actually, as an A&P, I do know) However, High voltage breakers require that high voltage be used for correct servo action at rated amps, or more precisely, rated watts. A finer point to be sure, but there everywhere. Like leaving a breaker out after it pops in flight. Like beer without rice in it. imho 3 Equivalent take off to landing ratios forever Nic xs145 ________________________________________________________________________________
Date: Jan 17, 2001
In article <000c01c07ff2$9daabf00$12e286d4@e6n8y8>, ptag.dev(at)ukonline.co.uk (Bob.Harrison) wrote: > This proposal is nothing to do with "The Mile High Club has it ? Bob Of course not! Various medical conditions and lack of imagination stopped such a thing entering my mind. But good luck to anyone who wants to give it a try. Any volunteers? Paul ________________________________________________________________________________
Date: Jan 17, 2001
Tennant , europa(at)avnet.co.uk
Nigel Graham wrote: > > > ----- Original Message ----- > > > In my personal experience, I've found a far more pressing limitation > to > > endurance. > > ...... just excuse the contents as a rather obscure beverage that > proved > > distasteful and dump in the nearest drain soon after landing. > > > > Alan > > For God's sake man ....don't throw it away. > This stuff has been sold for years in the States as Budwiser Lite! > > Only when it's been watered down........ ________________________________________________________________________________
Date: Jan 17, 2001
"Bob.Harrison" wrote: > > Paul/Liz > This proposal is nothing to do with "The Mile High Club has it ? For a while > my imagination got the better of me then I remember needing to get my arms > down to top up the trike brakes by having the rest of my body upside down on > the P1 seat. ! Really, I'm too old for these kind of antics......... I'd like to point out that the rules of the mile high club include that that you are witnessed by another (non participating) member of the crew, and that requires a 3 seater (or at least 3 occupants) as a minimum.. ________________________________________________________________________________
From: "John Cliff" <john(at)crixbinfield.freeserve.co.uk>
Subject: white floor
Date: Jan 17, 2001
Forwarded from the bounce bin. Meessage is from Ferg Kyle. *********************************************************** Paul: I wish I'd done that. This is of course to confirm with your Authority that you have done 51% of tye build. The proof is (1) photos of the progress, (2) a log giving details and dates and (3) a galaxy of epoxy and associated blobs on the floor, each annotated as to chapter and page, plus date, as samples and proof of site. I call that planning. Happy landings! Ferg ________________________________________________________________________________
Subject: pa now in Squadron Service
Date: Jan 17, 2001
A nice picture of G-KITS has been taken by Hal Perkins and is in the Miscellaneous Items section of the List Support Website at http://www.crixbinfield.freeserve.co.uk/europa.htm John Cliff Europa Club List Forum minder ________________________________________________________________________________
Date: Jan 17, 2001
Subject: Re: [RE: New member]
Sounds like all this might be a bit of an overkill in workshop preparation. The floor does not have to be impeccably clean. As long as it is reasonably clean, and you can walk around the shop without having to trip over things, that should suffice. A 200 Amp panel is definitely way too much. My entire house is serviced by a 150 Amp panel. The Europa does not call for anything more than light power tools. However, do install lots of lights in the shop. I installed five flourescent fixtures, and wired in a 20 Amp circuit with a few extra outlets. You also need a large sturdy table. An 8x4 should work well. I made a fabulously stable table for under $50. If you want the details, send me an email. My recommendation about tools would be to wait until you need the tools. Buy them as you go. It is hard to know what tools you might need too far ahead of time. Find a local hardware store (Lowes, Home Depot) and get to know them. Don't go overboard on tools. You can end up spending way too much. Some tools you might only need once, and you should borrow these from others. If you are killing time waiting for your kit to arrive, I would recommend that you buy the "Composite Practice Kit" from Aircraft Spruce and spend a few days with it. It is highly educational. PBoulet(at)aol.com wrote: Hi all; It seems a long time ago that I put my deposit/order in for my new monowheel XS kit. It was November after I attended the workshop out in Corona, California taught by Kim Prout. Since then I've put in a beautiful, gleaming white floor (by Hard Deck Coatings), have installed a new 200 amp panel, have installed additional light circuits and finally installed additional electrical circuits. I've been accumulating tools mostly off of E-bay. The ones I have left to buy are a mystery to me...no idea what they are by the name on the tool list given me. I trust it'll become more apparent what I need once I actually start building. Any ideas on what I might do to pass the time awaiting my March arrival of my "newborn"?? Enjoying this web site....have printed out many letters describing solutions to certain problem procedures. Thanks to all...hope to meet you in the upcoming months and years Paul Boulet, Malibu, California ________________________________________________________________________________
Subject: tifying Alu and Steel parts
Date: Jan 17, 2001
All: I'm perusing my pack of parts, preparing to properly proof them against corrosion (sorry, couldn't keep up the alliteration), and wonder how one determines the difference between Aluminum, Steel, and Stainless Steel. Aside from the obvious weight difference between Alu and Steel, there appears to be a distinct grain to the surface of steel parts, but not a clear difference between regular and Stainless steel. In the tail kit, for example: XTW12 - aluminum, by weight and lack of grain XTW09 - steel, regular? by weight and grain TP16 - steel, but Steve G. sez it's stainless XA2 - aluminum Any hints? Thanks, Shaun Simpkins ________________________________________________________________________________
Subject: Re: Identifying Alu and Steel parts
Date: Jan 17, 2001
Assuming you do not want to use any quick and dirty chemical tricks, here's how to distinguish... In my kit (a tri-gear, so I've not seen any tailwheel components) all Al (most, if not all, is 6061 alloy) and steel (4130 is the only steel alloy used) tubes had mill markings to identify the material. This is the surest way to determine what's what. If you are lacking clear markings, then.... If its bright and shiny (or at least clean looking) it's either Al or SS, because all of the 4130 is dark, almost black. If there is any doubt use a magnet since neither the Al nor the SS used in the kit is magnetic. As I recall the only SS tube in the kit is the tailplane torque tube (not having my inventory handy at the office I can't check but it is probably TP16) as are its associated components. If there are other SS parts, then note that Al has both lower density and lower Young's modulus so it will feel lighter than SS and will be less stiff in bending. The color and luster are also different, so find the longest fattest piece of metal tube in your inventory and note its appearance. It's Al. So are all of the bell cranks. Once you have identified one piece of each material you will be able to identify all others because the appearance of each metal is unique. Best regards, Rob Housman A070 Subject: Identifying Alu and Steel parts All: I'm perusing my pack of parts, preparing to properly proof them against corrosion (sorry, couldn't keep up the alliteration), and wonder how one determines the difference between Aluminum, Steel, and Stainless Steel. Aside from the obvious weight difference between Alu and Steel, there appears to be a distinct grain to the surface of steel parts, but not a clear difference between regular and Stainless steel. In the tail kit, for example: XTW12 - aluminum, by weight and lack of grain XTW09 - steel, regular? by weight and grain TP16 - steel, but Steve G. sez it's stainless XA2 - aluminum Any hints? Thanks, Shaun Simpkins ________________________________________________________________________________
Subject: floor surfacing
Date: Jan 17, 2001
Dig that nice floor. I work on one and it's 'most excellent'. I can find a circlip or tiny anything on it. Smooth, flat, hard I haven't spilled resin on it yet, but hope it will separate by modest means. Rubber standing pads are good for around the central table Very comfy. Be happy! nic xs145 ________________________________________________________________________________
Date: Jan 18, 2001
Subject: Re: Fw: RE: New member
Great advice Shaun....thanks for the suggestions Paul ________________________________________________________________________________
Date: Jan 18, 2001
Subject: Re: RE: New member
tennant@t-online.de Hi Rob; Thanks for your reply....was feeling a little lonely! As for the 200 amps I needed to upgrade my old 70 amp panel so this bigger panel has room to spare! As far as the white garage floor I installed it with expensive material from a company in Texas called "Hard Coat or Hard Deck" They have a display ad in Trade a Plane if you want to look them up. They guarantee the concrete underneath will chip before the coating comes off. And even if it did, the reflective quality of white is fabulous and if it gets damaged so what! Thanks too for your invite to Irvine. I'm in a cast at the moment (torn tendon) so won't be going anywhere for awhile....just hope I heal up before my XS arrives in March. Regards, Paul Boulet ________________________________________________________________________________
Date: Jan 18, 2001
tennant@t-online.de Thanks for the info Andrew. I'll definitely buy the composite practice kit even though we got some practice in the Sport Air workshop. I'll also put off buying the remainder of my tools until it appears I actually need them. Finally, the 200 amp panel was to upgrade my entire home...not just the garage. Thanks again for your comments, Paul Boulet ________________________________________________________________________________
Date: Jan 18, 2001
Subject: Re: Shop floor surfacing
Thanks for the happy words. Not many seem to realize the advantage of a white shop floor. Not to mention I probably have 30 hours of work into prepping and installing this 4 layer processed coating. Good news too....I already own the rubber cushiion floor pads and you're right...they do wonders for standing at long time intervals Regards, Paul ________________________________________________________________________________
Date: Jan 18, 2001
Subject: ing panel glueing
Having recently completed this task here are some tips that will help avoid some possible problems. In the manual is a clear method of applying weights to the panel while it is glueing. What the manual doesn't say is how much glue to apply to the respective parts. After applying generous (I thought ) amounts to both wing ribs and the panel and letting it cure there appeared to be large gaps (as much as 2-3mm) between the panel and ribs in places. It was possible to locate these gaps by pushing hard with the thumb on the panel along the position of the ribs. The fix suggested by the factory is to drill holes along the rib positions and inject redux into the gap. Drilling the holes confirmed the size of the gaps. Luckily the position of the ribs was marked on the top surface of the panel. Obviously it is best to avoid this situation. At the factory they have done so many wings that experience has taught them how much glue to apply. Clearly just applying weights to force the panel to contact the ribs would just distort the smooth surface requiring bricks worth of filler. My suggestion is to test for the existence of gaps in a dry run and apply the glue accordingly. Another possibility is to use a string to detect the low ribs. Prehaps there are other suggestions. Jonathan & Carla (kit 330 - Netherlands) ________________________________________________________________________________
Subject: Shop floor surfacing
Date: Jan 18, 2001
Hi! All I seem to be getting multiple copies again ! Is anyone else ? Regards Bob Harrison G-PTAG -----Original Message----- On Behalf Of PBoulet(at)aol.com Sent: 18 January 2001 07:25 Subject: Re: Shop floor surfacing Thanks for the happy words. Not many seem to realize the advantage of a white shop floor. Not to mention I probably have 30 hours of work into prepping and installing this 4 layer processed coating. Good news too....I already own the rubber cushiion floor pads and you're right...they do wonders for standing at long time intervals Regards, Paul ________________________________________________________________________________
Date: Jan 18, 2001
Yep - about half the time. ss ----- Original Message ----- From: "Bob.Harrison" <ptag.dev(at)ukonline.co.uk> Subject: RE: Shop floor surfacing > Hi! All > I seem to be getting multiple copies again ! Is anyone else ? > Regards > Bob Harrison G-PTAG ________________________________________________________________________________
Date: Jan 18, 2001
>. Aside from the obvious weight difference between Alu and Steel, there >appears to be a distinct grain to the surface of steel parts, but not a >clear difference between regular and Stainless steel. The only SS bits are the TP5 & 6. The TP4 torque tube is 4130, but plated, SS is not strong enough. It is worth trying not to scratch the plating , it will allow rusting to start. Use a magnet as suggested, to identify 4130 or ally. Graham ________________________________________________________________________________
Date: Jan 18, 2001
As an add-on to this question, what are the preferred methods of corrosion protection for the various metal types? SL, A208 > -----Original Message----- > From: Shaun Simpkins [SMTP:shauns(at)hevanet.com] > Sent: Wednesday, January 17, 2001 4:16 PM > To: europa(at)avnet.co.uk > Subject: Identifying Alu and Steel parts > > All: > > I'm perusing my pack of parts, preparing to properly proof them against > corrosion (sorry, couldn't keep up the alliteration), and wonder how one > determines the difference between Aluminum, Steel, and Stainless Steel. > Aside from the obvious weight difference between Alu and Steel, there > appears to be a distinct grain to the surface of steel parts, but not a > clear difference between regular and Stainless steel. > In the tail kit, for example: > XTW12 - aluminum, by weight and lack of grain > XTW09 - steel, regular? by weight and grain > FL7 - aluminum? > TP16 - steel, but Steve G. sez it's stainless > XA2 - aluminum > Any hints? > > Thanks, > > Shaun Simpkins ________________________________________________________________________________
"Leisch, Steven" at "Jan 18, 2001 08:42:47 am"
Date: Jan 18, 2001
From: Brian Rauchfuss - PCD <brauchfu(at)pcocd2.intel.com>
> As an add-on to this question, what are the preferred methods of corrosion > protection for the various metal types? > > SL, A208 On aluminum I used Alumiprep (an cleaner) and then Alodyne (a conversion coating). I then painted it with primer to prevent the Alodyne coating from being scratched. On steel I just used the primer after cleaning with alcohol (which takes a little of the black coating off, so I made sure I didn't overdo it). I did nothing for stainless steel. Another option for aluminum is to have it anodized by a professional. You have to make sure you get the correct type of anodizing, but I don't remember which type. The best primer for steel is zinc chromate, but this is toxic and difficult to get, so I just used a regular metal primer. I have scratched it a couple times, so I will have to clean those sections and reapply. What do people recommend as a good, tough primer? Brian ________________________________________________________________________________
Date: Jan 18, 2001
A newer kitbuilder than me! I've just bent people's ears on this subject, which probably should be granted FAQ status. Thanks all. A single paragraph in the builder's manual definitely allows for a "learning experience". You should check back through the Europa Club archives, and the Hints and Tips compendium. But this is what I've decided to do. Please be aware that I am NOT an expert on the subject and am only presenting what I've learned. BB members please chime in. Aluminum parts to be wholly or partially bonded into the structure: Alodining. Chemical conversion process that improves the bond and has lower risk of debonding than scuff sanding naked Alu. The surface needs to be thoroughly cleaned of the native oxide. Alumprep and Alumiwash are both good possibilities, as is a good scrubbing with an Ajax slurry. Folks who know have some real issues with acid etch pretreatments. Other Aluminum parts: Alodining, then painting. Some longer parts may need to use the Thursby cap and slosh technique with epoxy primer or Zinc Chromate/Zinc Oxide. Steel parts: Many folks have had their parts plated. The part needs to be baked after pretreatment to avoid embrittlement. Epoxy primer? Stainless Steel: not sure. Just paint? Shaun Simpkins A207 ----- Original Message ----- From: "Leisch, Steven" <Leisch(at)CSD.com> Subject: RE: Identifying Alu and Steel parts > As an add-on to this question, what are the preferred methods of corrosion > protection for the various metal types? > > SL, A208 > > > -----Original Message----- > > From: Shaun Simpkins [SMTP:shauns(at)hevanet.com] > > Subject: Identifying Alu and Steel parts > > > > All: > > > > I'm perusing my pack of parts, preparing to properly proof them against > > corrosion (sorry, couldn't keep up the alliteration), and wonder how one > > determines the difference between Aluminum, Steel, and Stainless Steel. > > Aside from the obvious weight difference between Alu and Steel, there > > appears to be a distinct grain to the surface of steel parts, but not a > > clear difference between regular and Stainless steel. > > In the tail kit, for example: > > XTW12 - aluminum, by weight and lack of grain > > XTW09 - steel, regular? by weight and grain > > FL7 - aluminum? > > TP16 - steel, but Steve G. sez it's stainless > > XA2 - aluminum > > Any hints? > > > > Thanks, > > > > Shaun Simpkins > ________________________________________________________________________________
Date: Jan 18, 2001
I can recommend powder coating for many of the metal parts, steel or aluminium. It is not cheap but when done by a professional company, it is very tough and almost indestructible. I have had to grind it off in some places and it is hard work. Gloss finish is very good. There are various powder choices but polyester is an all purpose finish usually available in black, white and assorted other colours if desired. Cheers, John ________________________________________________________________________________
Subject: Re: bonding in the cockpit module
at "Jan 11, 2001 02:01:33 pm"
Date: Jan 18, 2001
flying > Trimming the extra material from the rear of the cockpit module is a very > good idea. I blindly followed the manual only to realize when it was time > to install the baggage compartment bulkhead that it was rather tedious to > make the required cut after bonding (especially since some of it was bonded > to the fuselage sides!) > > > Best regards, > > Rob Housman > A070 How do you know where to trim here? This is the only place I couldn't find any trim lines. I was planning on trimming it when I could put the top on and be sure that I was cutting it right. Brian > You need to trim off a portion of the rear of the module which I don't > believe is in the current manual yet. If this section is not trimmed before > gluing, it will have to be trimmed later to put in the baggage compartment > bulkhead. I can send you a picture of this area trimmed if you wish. > I felt the same way about the spars clearance. Hopefully I won't discover a > problem later. > Good luck, > Bill McClellan > A164 ________________________________________________________________________________
Subject: bonding in the cockpit module
Date: Jan 18, 2001
Good question, but there is a very easy answer; I would have said the answer is obvious but for the fact that it wasn't so obvious to me when I bonded the cockpit module without trimming it. I did mutter "Duh!" to myself when I realized what I had done (or, rather, not done). The baggage compartment rear bulkhead zig-zag panel overlaps the corresponding panel at the aft end of the cockpit module so the more or less vertical part of the cockpit module must be removed by trimming it flush with the top of the central tunnel. Because there is a corner radius from the baggage compartment floor into the recesses in the cockpit module it will be necessary to remove a slight bit more from the cockpit module, but if you cut it flush you can trim the remainder later when you are ready to bond in the baggage compartment bulkhead. If you really trust your judgment, do a trial fit of the bulkhead into the cockpit module prior to bonding the cockpit module into the canoe, and cut to fit at that stage. Either way, if you examine the baggage compartment bulkhead it will become quite clear what needs to be removed. Best regards, Rob Housman A070 -----Original Message----- On Behalf Of Brian Rauchfuss - PCD Sent: Thursday, January 18, 2001 3:00 PM Cc: Bill McClellan; Europa; flying Subject: Re: bonding in the cockpit module > Trimming the extra material from the rear of the cockpit module is a very > good idea. I blindly followed the manual only to realize when it was time > to install the baggage compartment bulkhead that it was rather tedious to > make the required cut after bonding (especially since some of it was bonded > to the fuselage sides!) > > > Best regards, > > Rob Housman > A070 How do you know where to trim here? This is the only place I couldn't find any trim lines. I was planning on trimming it when I could put the top on and be sure that I was cutting it right. Brian > You need to trim off a portion of the rear of the module which I don't > believe is in the current manual yet. If this section is not trimmed before > gluing, it will have to be trimmed later to put in the baggage compartment > bulkhead. I can send you a picture of this area trimmed if you wish. > I felt the same way about the spars clearance. Hopefully I won't discover a > problem later. > Good luck, > Bill McClellan > A164 ________________________________________________________________________________
Subject: iple deliveries
Date: Jan 19, 2001
> Hi! All > I seem to be getting multiple copies again ! Is anyone else ? > Regards > Bob Harrison G-PTAG Not I . Nothing this server software does would surprise me. If you have changed your subscription address recently, or re-subscribed as the same address that might cause this sort of thing. Otherwise, who knows ? (A few apparent duplicate posts are actually duplicate sends, with slightly different times on them, caused by author's brain fade or finger trouble or by thier own ISP getting muddled.) John Cliff Europa Club List Forum minder ________________________________________________________________________________
Subject: Re: XS wing panel glueing
Date: Jan 19, 2001
Forwarded from the bounce bin. Message is from "Fergkyle" ****************************************************** Jonathan: I've got Classic foam wings, but perhaps a hint on similar 'gluing' would be useful. I bought several thicknesses of cushion foam from an upholstery outlet, from 1/4in (6mm) to 1-1/4in (32mm). Since I cannot envision building a vacuum bag rig for pressing bits together, I have taken to applying the epoxy, positioning the parts together (with peelply and/or polythene plastic sheeting as req'd), then overlying the foam cushion then a stiffening board/panel plus perhaps spars to even out the pressure below, then topped with weights (an old transformer and an electric motor or two, unused resin cans, etc). I've found that the even pressure (a) gets rid of bubbles and sinusses, (b) sqeezes excess into the peelply or away to the side for trimming, and (c) tends to duplicate the magic of factory bagging. The inspector seems pleased with the results........ Comments from the experts welcome. Of course, it means working out how to produce the required pressure throughout, or where indicated, and ensuring there's no squeezing into unwanted materials, The polythene sheeting is suitably cheap but may be reused, and the other equipment should be near to hand for the job. You might want to research the canny scheme brought up by another builder, in which he applied pressure to his cockpit insertion to the lower fuselage by 'hanging' the bottom and applying tightened cartage straps to overhanging wood beams to press together parts without disturbing their shapes. Happy Landings Ferg ________________________________________________________________________________
Subject: New member
Date: Jan 19, 2001
Forwarded from the bounce bin. Message is from Nigel Charles <72016.3721(at)compuserve.com> *********************************************************** Message text written by INTERNET:PBoulet(at)aol.com >Any ideas on what I might do to pass the time awaiting my March arrival of my "newborn"??< If you haven't bought all your tools yet I would recommend the following if you haven't got them already: Permagrit tools for work on GRP Accurate digital scales for weighing epoxy and Redux Digital level for setting up fling surfaces Dremel for all sorts of uses Thermometer with % humidity indication (NB max humidity for epoxy layups 70%) Regards Nigel Charles ________________________________________________________________________________
Date: Jan 19, 2001
Subject: pa Mod 58
All Europa aircraft are subject to a new mandatory modification, Mod 58, which entails the replacement of the tailplane anti-servo tab's drive pin plates. We are sending out this modification as quickly as manufacture of the new parts allows, starting with those of you who are flying Europas. If you are flying your Europa and have not received this modification before the end of January, please contact us. Before next flight it is strongly advised that you carefully check the exposed part of the tab drive pin lates for cracks. If you find evidence of cracking, DO NOT FLY. Cracking of this component is likely if your aircraft has been subject to excessive vibrations caused by an out of balance propeller or difficulty in engine starting for example. ________________________________________________________________________________
From: "Kesterton, Donald" <KestertonD(at)logica.com>
Subject: aring Classic Wings for Filling
Date: Jan 19, 2001
I would appreciate some advice on the preparation of the Europa Classic flying surfaces prior to filling. Yes I'm one of the really slow builders, but still enjoying it!! My question concerns just how much sanding of the surface is acceptable to create an adequate surface key for the filler, taking into account that the glass fibres are on or very close to the surface, and the surface preparation is for filler which adds no structural strength, rather than say a bid lay-up. If I was preparing for a lay-up I would sand to a dull surface finish with say 80 to 180 grade aluminium oxide paper. For filler however this seems a bit excessive and would possibly damage the glass cloth strands. How much sanding of the classic flying surfaces would you advise? What surface finish should I be aiming for before application of filler? I know what the manual says but I want to be sure I don't damage my wings!! Regards Donald Kesterton G-PATS Builder No 216 ________________________________________________________________________________
Date: Jan 19, 2001
From: Graham Singleton <grasingleton(at)avnet.co.uk>
Subject: [c-a] IFR and these VFR airplanes....
I thought that this was worth a read. Hope you agree. Graham >[The Canard Aviators's Mailing list] > >vacuum pump with one directional gyro being electrical. (Either the DG >or the Turn needle)" and " Have Fun, Fly Safely" -> > >Hard IFR on one engine with no radar, no de-ice, and no real instrument >redundancy (an electric turn co-ordinator won't hack it in anything but >very still air) is a formula for shredded fiber glass and a short life. > >We are conditioned by the FAA and industry to accept as a norm for IFR >flight this junk instrument equipment in general aviation. How many of >you would put your wife and kids on a commercial airliner operating with >vacuum gyros on a $300 pump? Why is it OK in an experimental airplane >or any other general aviation machine? We do it because it is legal - >not because it is safe. > >OK, so you're a gung-ho young ace pilot and this is something you must >do. (been there) > >Go with a good auto pilot with its own electric gyro, learn to trust it, >and use every feature of it. Let it be the back up to the vacuum >system. It is a good co-pilot that will go a long way in keeping you >ahead of the game when things get tense - like the destination just went >below minimums and ATC says standby while 50 other airplanes are in the >same fix. The very best IFR pilot can be easily overwhelmed in bad, bad >weather with equipment not designed to be there. (I kid you not, the >rain can be so loud you can't hear the radios and the turbulence so bad >you can't see the instruments - your head is shaking so much) > >Be smart - set the minimums at a 1000-3, no ice, no TRSA's and no night. > And practice, practice, practice. One IFR flight a month isn't enough. > Good IFR pilots do it often, not much of anything else, and get regular >check rides. > >Think VFR in these little airplanes - there is no such thing as cheap, >safe, IFR flight. ________________________________________________________________________________
Date: Jan 19, 2001
Subject: Re: Preparing Classic Wings for Filling
k> >How much sanding of the classic flying surfaces would you advise? What >surface finish should I be aiming for before application of filler? I know >what the manual says but I want to be sure I don't damage my wings!! > >Donald Kesterton >G-PATS Builder No 216 Hi Don, You might try those foam pads with grit bonded on. they conform nicely and will touch more surface than stiff paper. They do wear out quickly and you need to keep grease and perspiration off them and the glass. This technique was recommended by a US Navy composites advisor at Sun n Fun a year or tow ago. He had tested and found better adhesion than he got with 60 grit. Do a test and decide! Graham ________________________________________________________________________________
Date: Jan 19, 2001
Subject: Matthew Russell Ltd taking over Harry Luck premises
I've received a note from Matthew Russell indicating that his company is now taking over the 4200 sq ft workshop previously used by Harry Luck Ltd for aircraft build and support operations. They are described as "Manufacturer in wood, metal, and glassfibre" and offer instrument panel installation & accessories, aircraft finishing, and upholstery. Harry Luck will be a consultant to the new company. A Matthew Russell Ltd catalogue of electrical wiring and other components is available free on request. Matthew Russell Ltd 24 Greenlands Road Pickering North Yorkshire YO18 8BQ 01653 668169 I have no connection with or experience of either of the companies mentioned - this message is provided for information only, not as a recommendation. regards Rowland | Rowland Carson Europa Club Membership Secretary | Europa 435 G-ROWI PFA #16532 EAA #168386 ________________________________________________________________________________
Subject: lstery
Date: Jan 19, 2001
Hi All, I have been searching through the postings and can't seem to find much on the topic of upholstery. I was wondering if I make my own seat cushions and maybe a bit of upholstery over the tunnel whether I should try and get it figured out before I glue the top on. I had in mind painting most of the interior with speckle finish, possibly covering the tunnel and making the seats. I was wondering if anyone has any patterns ? I'd be interested in anyones ideas on this topic. Thanks, Paul McAllister Builder 363 - http://pma.obtero.net ________________________________________________________________________________
Date: Jan 19, 2001
From: Peter van Schoonhoven <pvans(at)pacifier.com>
Subject: Re: Upholstery
It would be nice if an established upholstery shop could make a standard package like they do for the RV builders. Cleaveland Tools does a fantastic job making seat cushions specially designed for the RV series, and they sell extra material so you can customize sidewalls, etc. I bought a set for my RV3 and could not be happier. ( Gotta fly something while building, right?_) I spoke to them at Oshkosh last summer and they said they would do it if there was enough interest. So if there is more interest, we need to individually call them and ask, so they realize there is a market. http://www.cleavelandtool.com/ Order by phone at: 1-800-368-1822 Questions by phone at: 515-432-6794 Order by Fax at: 515-432-7804 Order by E-Mail at: Orders(at)cleavelandtool.com There's my idea. I would rather pay a few hundred dollars for a professional to do this than to sort it out myself. Saves time too, Comments welcome. >Hi All, > >I have been searching through the postings and can't seem to find much on >the topic of upholstery. I was wondering if I make my own seat cushions and >maybe a bit of upholstery over the tunnel whether I should try and get it >figured out before I glue the top on. > >I had in mind painting most of the interior with speckle finish, possibly >covering the tunnel and making the seats. I was wondering if anyone has any >patterns ? I'd be interested in anyones ideas on this topic. > > >Thanks, > >Paul McAllister >Builder 363 - http://pma.obtero.net > ________________________________________________________________________________
Subject: Upholstery
Date: Jan 20, 2001
There are upholstery kits advertised in The Europa Club magazine... "from 425 we also have available SEATS SELF FIT UPHOLSTERY KITS UPHOLSTERY MATERIAL Tel: 01751 474623" I don't know what they are like but it might be worth giving them a call and see if they have a catalogue or samples. regards Keith > -----Original Message----- > From: owner-europa(at)aztec.houxou.com > Schoonhoven > Subject: Re: Upholstery > > > It would be nice if an established upholstery shop could make > a standard > package like they do for the RV builders. Cleaveland Tools > does a fantastic > job making seat cushions specially designed for the RV > series, and they > sell extra material so you can customize sidewalls, etc. I > bought a set for > my RV3 and could not be happier. ( Gotta fly something while > building, > right?_) > > I spoke to them at Oshkosh last summer and they said they > would do it if > there was enough interest. So if there is more interest, we need to > individually call them and ask, so they realize there is a market. > > http://www.cleavelandtool.com/ > > > Order by phone at: 1-800-368-1822 > Questions by phone at: 515-432-6794 > Order by Fax at: 515-432-7804 > Order by E-Mail at: Orders(at)cleavelandtool.com > > There's my idea. I would rather pay a few hundred dollars for a > professional to do this than to sort it out myself. Saves time too, > Comments welcome. > > > >Hi All, > > > >I have been searching through the postings and can't seem to > find much on > >the topic of upholstery. I was wondering if I make my own > seat cushions and > >maybe a bit of upholstery over the tunnel whether I should > try and get it > >figured out before I glue the top on. > > > >I had in mind painting most of the interior with speckle > finish, possibly > >covering the tunnel and making the seats. I was wondering > if anyone has any > >patterns ? I'd be interested in anyones ideas on this topic. > > > > > >Thanks, > > > >Paul McAllister > >Builder 363 - http://pma.obtero.net > > > >_____________________________________________________________ > _________ > >The Europa List is supported by Aviators Network UK - > info(at)avnet.co.uk > > > The Europa List is supported by Aviators Network UK - > info(at)avnet.co.uk ________________________________________________________________________________
Date: Jan 20, 2001
Oregon Aero in Scappoose, OR makes excellent temperfoam seats for Europas. Shaun A207 ----- Original Message ----- From: "Keith Tallent" <ktallent(at)avnet.co.uk> ; "'Europa'" Subject: RE: Upholstery > There are upholstery kits advertised in The Europa Club magazine... > "from 425 > we also have available > SEATS > SELF FIT UPHOLSTERY KITS > UPHOLSTERY MATERIAL > Tel: 01751 474623" > > I don't know what they are like but it might be worth giving them a call and > see if they have a catalogue or samples. > > regards > Keith > > > -----Original Message----- > > From: owner-europa(at)aztec.houxou.com > > Schoonhoven > > Subject: Re: Upholstery > > > > > > It would be nice if an established upholstery shop could make > > a standard > > package like they do for the RV builders. Cleaveland Tools > > does a fantastic > > job making seat cushions specially designed for the RV > > series, and they > > sell extra material so you can customize sidewalls, etc. I > > bought a set for > > my RV3 and could not be happier. ( Gotta fly something while > > building, > > right?_) > > > > I spoke to them at Oshkosh last summer and they said they > > would do it if > > there was enough interest. So if there is more interest, we need to > > individually call them and ask, so they realize there is a market. > > > > http://www.cleavelandtool.com/ > > > > > > Order by phone at: 1-800-368-1822 > > Questions by phone at: 515-432-6794 > > Order by Fax at: 515-432-7804 > > Order by E-Mail at: Orders(at)cleavelandtool.com > > > > There's my idea. I would rather pay a few hundred dollars for a > > professional to do this than to sort it out myself. Saves time too, > > Comments welcome. > > > > > > > > >Hi All, > > > > > >I have been searching through the postings and can't seem to > > find much on > > >the topic of upholstery. I was wondering if I make my own > > seat cushions and > > >maybe a bit of upholstery over the tunnel whether I should > > try and get it > > >figured out before I glue the top on. > > > > > >I had in mind painting most of the interior with speckle > > finish, possibly > > >covering the tunnel and making the seats. I was wondering > > if anyone has any > > >patterns ? I'd be interested in anyones ideas on this topic. > > > > > > > > >Thanks, > > > > > >Paul McAllister > > >Builder 363 - http://pma.obtero.net > > > > > >_____________________________________________________________ > > _________ > > >The Europa List is supported by Aviators Network UK - > > info(at)avnet.co.uk > > > > > > The Europa List is supported by Aviators Network UK - > > info(at)avnet.co.uk > > ________________________________________________________________________________
Date: Jan 19, 2001
I had all my aluminium brackets, spacers and general bits hard gold anodised. It cost around 40 to have about 200 bits done. Where they are to be bonded I remove the anodising. I have done the same thing again on my new kit. I didn't have high stress bits like the wing attach brackets anodised as I am uncertain if this reduces the strength. However I am sure that an anodised bracket is more airworthy than one which is corroded. I also use alodining after scrubbing with Ajax. I have used clear laquer on some parts treated in this way. I am lucky that on the Ban-bi kit the steel parts come already plated or painted. Jerry LTS(at)avnet.co.uk http://www.avnet.co.uk/touchdown ----- Original Message ----- From: John Wigney <johnwigney(at)worldnet.att.net> Subject: Re: Identifying Alu and Steel parts > I can recommend powder coating for many of the metal parts, steel or > aluminium. It is not cheap but when done by a professional company, it > is very tough and almost indestructible. I have had to grind it off in > some places and it is hard work. Gloss finish is very good. There are > various powder choices but polyester is an all purpose finish usually > available in black, white and assorted other colours if desired. > > Cheers, John > ________________________________________________________________________________
Date: Jan 19, 2001
For theose who don't want to go to great expence on floor coverings. I put an old carpet down in my garage before building my aircraft. Keeps your feet a little warmer in the winter in the UK and protects things you may drop. Cost me nothing. Jerry LTS(at)avnet.co.uk http://www.avnet.co.uk/touchdown ----- Original Message ----- From: Nic <tgynz(at)cts.com> Subject: Shop floor surfacing > Dig that nice floor. > I work on one and it's 'most excellent'. > I can find a circlip or tiny anything on it. > Smooth, flat, hard > I haven't spilled resin on it yet, but hope it will separate by modest > means. > Rubber standing pads are good for around the central table > Very comfy. > > Be happy! > nic xs145 > > ________________________________________________________________________________
Subject: ANE IS BORN
Date: Jan 21, 2001
Hello all I was wondering if anyone had a copy of the series "A PLANE IS BORN" . Which was showing in the UK around Christmas time. Thanks Ray Mc Donnell ________________________________________________________________________________
Date: Jan 21, 2001
Subject: lstry
Oregon Aero in Scappoose, OR has a website: http://www.oregonaero.com/ Rob ________________________________________________________________________________
Date: Jan 21, 2001
Subject: Re: A PLANE IS BORN
Hi all, I too would be interested in getting hold of tapes of A Plane Is Born should some be available. A picture is worth a thousand words sometimes. Craig A205 ________________________________________________________________________________
Subject: Re: Fwd: [c-a] IFR and these VFR airplanes....
Date: Jan 22, 2001
Forwarded from the bounce bin. Message is from "Fergkyle" ***************************************************** > I thought that this was worth a read. Hope you agree. > > Graham My God, Graham.... That's the most profound pronouncement I've seen on this net! The 'been there' remark brought back all the terrors of the night in black weather, a screw-up in the ATC, icing, and a lost soul with no compass and the sweat seeping into the collar. Lord, get me out of here and I'll never do this again. A flying suit soaked in white salt and wool socks that stick to your skin. Even a hot bath doesn't eliminate the shaking. ....and that was in an expensive, carefully maintained ship of the line. If nothing else convinces the uninitiated of the folly of reliance on single elements of a complex exercise - the words , "Think VFR in these little airplanes - there is no such thing as cheap, safe, IFR flight." .......should! Nice choice!! HAPPY landings Ferg A064 ________________________________________________________________________________
Subject: XS wing panel glueing
Date: Jan 22, 2001
Forwarded from the bounce bin. Message is from "RWM-SYSTEMS" <raimo.toivio@rwm-systems.fi> **************************************************** I have completed this task also few moments ago and I had similar presentiments. I decided to put few blobs of micro on the ribs there and there and test glue the skin. Of cource I put some tape on the underside of the skin to prevent real glueing. Doing this I got wonderful knowledge how much to put Redux-flox-mixture everywhere. The gap was 0-5 mm (really, maximum cap 5 mm). I did not like the idea to spoil the aerofoil shape. That is why I did not put weights on the ribs - only on the spar, trailing edge, tip and the root. I can be sure: my skins are well glued. Raimo #417 Finland ________________________________________________________________________________
Date: Jan 22, 2001
Subject: re upgrades question
Hi, I just started work on the XS kit, and I would appreciate answers to a few questions. My plan is to install very minimal stuff in the Europa - just the basic VFR instruments and no gyros. I am also thinking of not installing wingtip or landing lights. However, I want to leave all these as future upgrades. Is that possible? For example, can I pull the entire instrument panel out and install a brand new one? Is that possible once the cockpit module and the fuselage are bonded? Also, what measures can I take now, so that in the future I can install wingtip lights, strobes, landing lights and an angle of attack indicator? Some people recommended that I install a conduit through the wing so that I can run wires or plumbing at a later date. Are there any other techniques? On a related note, can I legally replace an airspeed indicator with an angle of attack indicator? CFII Europa #A178 ________________________________________________________________________________
Date: Jan 22, 2001
Subject: Re: Future upgrades question
Andrew Sarangan wrote: > Hi, > > I just started work on the XS kit, and I would appreciate answers to a few > questions. My plan is to install very minimal stuff in the Europa - just the > basic VFR instruments and no gyros. I am also thinking of not installing > wingtip or landing lights. However, I want to leave all these as future > upgrades. Is that possible? For example, can I pull the entire instrument > panel out and install a brand new one? Is that possible once the cockpit > module and the fuselage are bonded? Also, what measures can I take now, so > that in the future I can install wingtip lights, strobes, landing lights and > an angle of attack indicator? Some people recommended that I install a conduit > through the wing so that I can run wires or plumbing at a later date. Are > there any other techniques? > > On a related note, can I legally replace an airspeed indicator with an angle > of attack indicator? > > CFII > Europa #A178 > > Hi Andrew, I strongly recommend running some type of conduit through the wings, not only for tip lights/strobes, but for the pitot/static lines. The manual has you run the pitot/static lines through the wing ribs with grommets at the ribs. This would make it verrrry difficult to replace these clear plastic lines at a later date. I used 1/2 inch plastic pipe (the thin walled black stuff used for drip sprinkler systems) for conduit to each wing tip as well as the pitot/static area (both sides), allowing for installation of an AOA head on the starboard outrigger brackets at a later date. The instrument panel will have to be installed so that it can be removed at a later date for maintainance, debugging, etc. I used aluminum sub-panels for the instrumets that could be replaced with others at some later date. Terry Seaver Pleasanton, CA A135 ________________________________________________________________________________
Subject: Future upgrades question
Date: Jan 22, 2001
The panel is removable as a unit so it can be replaced at any time with a new one if you wish. It can be withdrawn through the cockpit door - without anything installed it is easy to handle but I would expect it to be a bit more difficult with all instruments and avionics installed (mine is still "empty"). Consider using the appropriate connectors behind the panel for pneumatic lines and electrical wires so that removal will not be complicated by having to disconnect everything wire by wire or tube by tube. You have received good advice regarding installation of a conduit for future lighting in the wing tips - this is a "must have" item because there is no way to fish the wires through the wing ribs otherwise. My conduit is aft of the spar (the only available location unless you have a 12 foot long drill bit) so it required a right angle turn to route the wires forward to the recessed lights. I recommend that you fabricate a junction box at the right angle turn to facilitate pulling the wires - a junction box cover (mine is on the bottom of the wing) can be fitted like those used for the access ports in the fuselage near the elevator trim servo. I have installed the Proprietary Software Systems, Inc. AOA indicator ( http://www.angleofattack.com/ ) which requires ports mounted inside of the wing surfaces. Had I not installed lights within the wing tip there would not have been any way to reach inside of the wing (forward of the spar) in order to mount the port hardware. It is impossible to reach around the outboard end of the spar from the aft side of the spar even before closing the wing, so the cutout I made for the lights gave me just enough of an opening for my hand to reach the preferred location for the AOA ports. Once the wing is closed, in the absence of a cutout of some sort, you will not be able to mount anything inside the wing. A separate conduit will be required for the pneumatic lines unless a single conduit is sufficiently large for all wires and tubes. I know from trying that a 1/2 inch diameter tube is not large enough for both the electrical and the AOA pneumatic lines so I recommend installing a separate conduit for each (if you use the same AOA). If your wings have not yet been shipped you should special order wings without the wing tip molding installed because this will make the addition of everything within the wingtips much easier. This clever idea is not mine but I highly recommend it, having done the job the hard way. I don't have a copy of the FARs handy but as I recall an airspeed indicator is required equipment. Best regards, Rob Housman A070 -----Original Message----- On Behalf Of Andrew Sarangan Sent: Monday, January 22, 2001 10:46 AM Subject: Future upgrades question Hi, I just started work on the XS kit, and I would appreciate answers to a few questions. My plan is to install very minimal stuff in the Europa - just the basic VFR instruments and no gyros. I am also thinking of not installing wingtip or landing lights. However, I want to leave all these as future upgrades. Is that possible? For example, can I pull the entire instrument panel out and install a brand new one? Is that possible once the cockpit module and the fuselage are bonded? Also, what measures can I take now, so that in the future I can install wingtip lights, strobes, landing lights and an angle of attack indicator? Some people recommended that I install a conduit through the wing so that I can run wires or plumbing at a later date. Are there any other techniques? On a related note, can I legally replace an airspeed indicator with an angle of attack indicator? CFII Europa #A178 ________________________________________________________________________________
Date: Jan 22, 2001
The first item listed as required equipment for VFR flight in FAR 91.205 (b) is the airspeed indicator. Best regards, Rob Housman A070 -----Original Message----- On Behalf Of Andrew Sarangan Sent: Monday, January 22, 2001 10:46 AM Subject: Future upgrades question Hi, I just started work on the XS kit, and I would appreciate answers to a few questions. My plan is to install very minimal stuff in the Europa - just the basic VFR instruments and no gyros. I am also thinking of not installing wingtip or landing lights. However, I want to leave all these as future upgrades. Is that possible? For example, can I pull the entire instrument panel out and install a brand new one? Is that possible once the cockpit module and the fuselage are bonded? Also, what measures can I take now, so that in the future I can install wingtip lights, strobes, landing lights and an angle of attack indicator? Some people recommended that I install a conduit through the wing so that I can run wires or plumbing at a later date. Are there any other techniques? On a related note, can I legally replace an airspeed indicator with an angle of attack indicator? CFII Europa #A178 ________________________________________________________________________________
Date: Jan 22, 2001
Subject: Re: [RE: Future upgrades question]
Hello I know that the FAR requires an airspeed indicator. My question was whether an AOA indicator can be substituted for it. After all, the AOA gives a more accurate measurement of critical airspeeds (Vsl, Vso, Vno, Vne and Va) than the conventional airspeed indicator. One can also calibrate the AOA in terms of airspeeds and call it an Airspeed+AOA indicator. However, I do not know whether the FAA will accept that as a valid substitute. Does the FAR say that the airspeed must be driven by a pitot-static system? Thanks! "Rob Housman" <robh@hyperion-ef.com> wrote: The first item listed as required equipment for VFR flight in FAR 91.205 (b) is the airspeed indicator. Best regards, Rob Housman A070 ________________________________________________________________________________
Date: Jan 22, 2001
Hi, Andrew -- I wasn't aware that any AOA system provided indications for Vno, Vne, and Va, much less accurate ones (small AOA at those speeds). As to an FAR, there's none for homebuilts vis-a-vis the ASI. However, FAR 23.1323(a) requires that an ASI be a pitot pressure instrument by inference, and while Part 23 does not apply to a homebuilt, the FAA can pull out any Reg. or Advisory Circular if needed to define what airworthiness is. The further problem is that the FAA inspector will very likely consider the ASI required by Part 91 as being of the usual sort. Guvmint employees are just like that (I was one, not FAA, but arguably same genetic defect). Regards, Fred F., A063 Andrew Sarangan wrote: > > Hello > > I know that the FAR requires an airspeed indicator. My question was whether an > AOA indicator can be substituted for it. After all, the AOA gives a more > accurate measurement of critical airspeeds (Vsl, Vso, Vno, Vne and Va) than > the conventional airspeed indicator. One can also calibrate the AOA in terms > of airspeeds and call it an Airspeed+AOA indicator. However, I do not know > whether the FAA will accept that as a valid substitute. Does the FAR say that > the airspeed must be driven by a pitot-static system? > > Thanks! ________________________________________________________________________________
Date: Jan 23, 2001
Subject: nsey Air Rally 2001
I've received an invitation from the Guernsey Aero Club for the Europa Club to participate in their 30th International Air Rally, on 14 - 16 Sep 2001. There is an optional nav competition, and the promise of a great social weekend. Their website gives full info & pix from last year's event at <http://www.guernseyaeroclub.com>. There will also be a stand at the PFA Rally promoting the event. There are trophies for the largest number of participants from one club or organisation. (Remember we're trying to get more Europas than Jodels at the PFA Rally this year - we could do it again in Guernsey!) Further details available from the Aero Club manager Brent Baigent on 01481 265267, mobile 07781 115460, fax 01481 263830, e-mail . Guernsey Aero Club La Planque Lane Forest Guernsey Channel Islands GY8 0DT regards Rowland | Rowland Carson Europa Club Membership Secretary | Europa 435 G-ROWI PFA #16532 EAA #168386 ________________________________________________________________________________
Date: Jan 23, 2001
>I wasn't aware that any AOA system provided indications for Vno, Vne, >and Va, much less accurate ones (small AOA at those speeds). They don't, but AoA is the critical factor , particularly near the stall and doesn't vary with weight. Didn't the Air Force go to AoA as the primary flight instrument in combat aircraft after losing a few F4s? I remember Burt Rutan did spin testing on those with spin recovery parachute attached. The chute let go on one occasion and they had to eject. Graham ________________________________________________________________________________
Date: Jan 23, 2001
Subject: Re: [Re: [RE: Future upgrades question]]
That's a good point. Even though theoretically AOA is a better concept than airspeed, it may be hard to measure it accurately, especially at cruise speeds and beyond. Nevertheless, I am still not convinced that this is not possible. A single instrument calibrated in terms of AOA and airspeed does not seem like a far-fetched idea. Fred Fillinger wrote: Hi, Andrew -- I wasn't aware that any AOA system provided indications for Vno, Vne, and Va, much less accurate ones (small AOA at those speeds). As to an FAR, there's none for homebuilts vis-a-vis the ASI. However, FAR 23.1323(a) requires that an ASI be a pitot pressure instrument by inference, and while Part 23 does not apply to a homebuilt, the FAA can pull out any Reg. or Advisory Circular if needed to define what airworthiness is. The further problem is that the FAA inspector will very likely consider the ASI required by Part 91 as being of the usual sort. Guvmint employees are just like that (I was one, not FAA, but arguably same genetic defect). Regards, Fred F., A063 Andrew Sarangan wrote: > > Hello > > I know that the FAR requires an airspeed indicator. My question was whether an > AOA indicator can be substituted for it. After all, the AOA gives a more > accurate measurement of critical airspeeds (Vsl, Vso, Vno, Vne and Va) than > the conventional airspeed indicator. One can also calibrate the AOA in terms > of airspeeds and call it an Airspeed+AOA indicator. However, I do not know > whether the FAA will accept that as a valid substitute. Does the FAR say that > the airspeed must be driven by a pitot-static system? > > Thanks! ________________________________________________________________________________
From: "hedley brown" <hedley(at)hedleybrown.flyer.co.uk>
Date: Jan 23, 2001
Advice - dont. It'll only depress you. ----- Original Message ----- From: Craig M Ellison <ellisonair(at)juno.com> Subject: Re: A PLANE IS BORN > Hi all, > > I too would be interested in getting hold of tapes of A Plane Is Born > should some be available. A picture is worth a thousand words sometimes. > > Craig > A205 ________________________________________________________________________________
From: "Rob Housman" <ROB-HOUSMAN(at)worldnet.att.net>
Date: Jan 23, 2001
...and if the a/c has a tailhook it also has an AOA indicator. Best regards, Rob Housman A070 ----- Original Message ----- From: "Graham Singleton" <grasingleton(at)avnet.co.uk> Subject: Re: [RE: Future upgrades question] > >I wasn't aware that any AOA system provided indications for Vno, Vne, > >and Va, much less accurate ones (small AOA at those speeds). > > They don't, but AoA is the critical factor , particularly near the stall > and doesn't vary with weight. Didn't the Air Force go to AoA as the primary > flight instrument in combat aircraft after losing a few F4s? I remember > Burt Rutan did spin testing on those with spin recovery parachute attached. > The chute let go on one occasion and they had to eject. > > Graham > ________________________________________________________________________________
Subject: Guernsey Air Rally 2001
Date: Jan 23, 2001
Hi! All and Rowland. Can't resist this :- You aren't likely to get a big number if you limit the "flyouts" to max.8No. !!!!?? I may be interested but already signed up for two or three trips with ST Aviation , one to Prague one to Paris and probably one to Morocco !!! Regards Bob Harrison G-PTAG -----Original Message----- On Behalf Of Rowland & Wilma Carson Sent: 23 January 2001 10:26 Subject: Guernsey Air Rally 2001 I've received an invitation from the Guernsey Aero Club for the Europa Club to participate in their 30th International Air Rally, on 14 - 16 Sep 2001. There is an optional nav competition, and the promise of a great social weekend. Their website gives full info & pix from last year's event at <http://www.guernseyaeroclub.com>. There will also be a stand at the PFA Rally promoting the event. There are trophies for the largest number of participants from one club or organisation. (Remember we're trying to get more Europas than Jodels at the PFA Rally this year - we could do it again in Guernsey!) Further details available from the Aero Club manager Brent Baigent on 01481 265267, mobile 07781 115460, fax 01481 263830, e-mail . Guernsey Aero Club La Planque Lane Forest Guernsey Channel Islands GY8 0DT regards Rowland | Rowland Carson Europa Club Membership Secretary | Europa 435 G-ROWI PFA #16532 EAA #168386 ________________________________________________________________________________
Date: Jan 23, 2001
<> Bob, are you saying you are willing to organise Europa club participation in the Guernsey Air Rally this year? The Club fly-in coordinator can give you some advice on planning and bookings, or ask me after 3 june... chus, dave g-bxum kit67 ________________________________________________________________________________
Date: Jan 23, 2001
Subject: bushes.
I have just had occasion to "suspend" my Europa to replace a tyre. During this it was apparent that the (mono) wheel could be be moved up and down about 3/8" without anything else moving. This was traced to elongation of the LGO5 bushes, which have gone elliptical by at least 20 thou. I have already found another builder who has replaced them. IMHO they would be better in a harder material than phosphor bronze; after all there is no continuous rotation, but they have to withstand the thump of our landings - and maybe airstream buffeting repetitively loads them too. Graham C. G-EMIN ________________________________________________________________________________
Subject: Re: Guernsey Air Rally 2001
Date: Jan 23, 2001
I entered the Guernsey Rally 6 or 7 times when I was the proud owner of a PA28-180 some time ago and have a cabinet full of silverware to remind me of the successes I had. It is a fabulous experience and the nav. exercises are straight forward but really do exercise the mind. If my aeroplane is ready (and I'm not too far past it !) I would love to enter once again. The hospitality is superb (and the booze is cheap !) Highly recommended ! Regards to all, Ron Jones. ________________________________________________________________________________
Date: Jan 23, 2001
Hi! Dave . Perhaps you misunderstood me . I haven't a clue ,I'm not ashamed to admit it but we "juniors" "novices" "whatever" are not likely to ever be in that capability until we have piggy backed on one or two trips and at 8 a go it's going to be a long time coming round ? I don't feel that the "leader " should have to concern himself with the "what to do items when there" , the last thing I want is to be organized by someone else having arrived at the destination , I think "do your own thing " should be the order of the day otherwise I can well understand you would be overwhelmed by wet nursing and pampering to everyone's whim. However the flight details ,customs , route and general essentials of the return Journey etc. I would think are essential for the novice such as me. My a/c has to go to Bavaria before 50 hours are up , for propeller balance analysis, Kevin Pearce of ST Aviation is going with me so hopefully I may be more use after that trip ! (Incidentally what is significant about the 3rd of June ?) Best regards Bob H.G-PTAG -----Original Message----- On Behalf Of DaveBuzz(at)aol.com Sent: 23 January 2001 19:21 Subject: RE: Guernsey Air Rally 2001 <> Bob, are you saying you are willing to organise Europa club participation in the Guernsey Air Rally this year? The Club fly-in coordinator can give you some advice on planning and bookings, or ask me after 3 june... chus, dave g-bxum kit67 ________________________________________________________________________________
Date: Jan 23, 2001
Not really far-fetched, but maybe preferable still as separate instruments. I've heard that an AOA indicator is not only fairly standard now on bizjets and airline transports, but the pilots really like it. A Flight Options pilot told me today that on his BeechJet the AOA indicator is on the glare shield. Very useful for take-off/landing (don't have to fuss over the charts which compute key indicated airspeeds), but also at high flight levels where one AOA reading to remember, under all weight and atmospheric conditions, keeps you out of deep stall. I ran NASA's FoilSim program on the issue, and it appears that AOA is less than 1/2 as sensitive (to airspeed changes) at 150 MPH than at 60 MPH, using Europa weight, wing area and similar airfoil. The program is now a Java applet on nasa.gov, in the education section of Glenn Research Center, and targeted to young students, but I figure they should have the math right! Regards, Fred F., A063, N3EU Andrew Sarangan wrote: > > That's a good point. Even though theoretically AOA is a better concept than > airspeed, it may be hard to measure it accurately, especially at cruise speeds > and beyond. Nevertheless, I am still not convinced that this is not possible. > A single instrument calibrated in terms of AOA and airspeed does not seem like > a far-fetched idea. ________________________________________________________________________________
Subject: Sim @ NASA
Date: Jan 23, 2001
FoilSim from nasa. www,grc,nasa,gov/www/k-12/foilsim/index,html www,grc,nasa,gov/www/k-12/foilsim/manual/mainhlp,htm Nic ________________________________________________________________________________
Subject: Sim II
Date: Jan 23, 2001
It might be easier not to get your own copy. FoilSim 2 runs at this locale www,grc,nasa,gov/www/k-12/airplane/foil2,html Nic- ________________________________________________________________________________
Subject: FoilSim @ NASA
Date: Jan 24, 2001
Could this web address be published correctly, I have replaced the , with . and get a 404 error page not found. Regards Peter Armstrong -----Original Message----- From: owner-europa(at)aztec.houxou.com Subject: FoilSim @ NASA FoilSim from nasa. www,grc,nasa,gov/www/k-12/foilsim/index,html www,grc,nasa,gov/www/k-12/foilsim/manual/mainhlp,htm Nic ________________________________________________________________________________
Date: Jan 23, 2001
From: "Peter Saitta, AIA Principal" <saitta(at)netmagic.net>
Subject: Re: FoilSim @ NASA
try http://www.lerc.nasa.gov/WWW/K-12/aerosim/ Peter Peter Armstrong wrote: > > Could this web address be published correctly, I have replaced the , with . > and get a 404 error page not found. > > Regards > > Peter Armstrong > > -----Original Message----- > From: owner-europa(at)aztec.houxou.com > Subject: FoilSim @ NASA > > FoilSim from nasa. > > www,grc,nasa,gov/www/k-12/foilsim/index,html > > www,grc,nasa,gov/www/k-12/foilsim/manual/mainhlp,htm > > Nic > > ________________________________________________________________________________
Date: Jan 24, 2001
In article <3A6E215D.965FD6B1(at)ameritech.net>, fillinger(at)ameritech.net (Fred Fillinger) wrote: > I've heard that an AOA indicator is not only fairly > standard now on bizjets and airline transports, but the pilots really > like it. I think most airliners use AOA but don't show it to the pilot. The data is fed to computers which then shout at you when you get too slow! I flew an aircraft many years ago with an AOA indicator and it quickly became indispensable. I have missed one ever since. You can virtually ignore the ASI in the circuit and know that as long as you follow what it is telling you, you will not stall, whatever configuration you are in. You can also fly safely and confidently at lower speeds than most would consider safe with just an ASI. Perhaps one day the "powers that be" will allow that an AOA and a GPS give you all the info you really need for VFR. Paul Atkinson ________________________________________________________________________________
Date: Jan 24, 2001
<4.3.2.7.2.20010123123731.00baa1e0(at)post.avnet.co.uk> >...and if the a/c has a tailhook it also has an AOA indicator. Now why would a glider tug need AoA?!? I had heard BTW that one German Europa has been towing gliders for a year or two. Graham ________________________________________________________________________________
Date: Jan 23, 2001
>That's a good point. Even though theoretically AOA is a better concept than >airspeed, it may be hard to measure it accurately, especially at cruise speeds >and beyond. Nevertheless, I am still not convinced that this is not possible. >A single instrument calibrated in terms of AOA and airspeed does not seem like >a far-fetched idea. It probably is feasible but it would need some way of adjusting the airspeed to readout according to weight, which is changing all the time. AoA at landing speed would be accurate and tells you immediately if something has changed whereas the ASI is 20 seconds behind it. That is the real advantage. You may not need extreme accuracy for cruise and climb speeds. I think you need AoA for operating near the ground or maneuvering and ASI for navigating. Graham ________________________________________________________________________________
From: "John Cliff" <john(at)crixbinfield.freeserve.co.uk>
Subject:
Date: Jan 24, 2001
Forwarded from bounce bin. Message is from "Fergkyle" ************************************************************* Cheers: If I remember correctly, the L-1011 TriStar "Alpha Angle" system (AoA) became active at first flap selection, through to landing - mostly for guaranteeing proper attitude for approach with changing flap selections. Lockheed told us it was not worth running at cruise (although it might have saved a few reputations in autoflight regime into turbulence). I think it was the small rate of change of angle with higher speeds whut done it. Happy landings Ferg ________________________________________________________________________________
Date: Jan 24, 2001
hello Bob, I appreciate that a bit of experience is useful before running any fly-out, but the bottom line is someone will put in time and effort to organise (ie research and book accomodation, give suggestions for routes, generally offer to arrange paperwork for the group such as permissions required for overseas flying, and liase with the destination airfield/customs/ (b)eurocrats(!) etc), and the paperwork and problems do go up exponentially. If someone wants to organise a fly out its not unreasonable to expect a limit - they want to enjoy the event too! Unfortunately you sometimes find a large variation in peoples accomodation expectations, and it is naturally easier with a smaller group. There is the club trip to France later in the year, and I plan to visit Epinal in July, to which your quite welcome to fly down with me, but bring a tent and sleeping bag! When are you planning to visit Bavaria, and where? 3 june, check the next club mag, it'll be my first 'organisational attempt' - gotta start sometime... chus, dave ps. O | | Guernsey?????????????? / |__/ ;-) ________________________________________________________________________________
Subject: shot
Date: Jan 24, 2001
Please ignore this. John Cliff ________________________________________________________________________________
Subject: Re: Test shot
Date: Jan 24, 2001
Impossible ----- Original Message ----- From: "John Cliff" <ve3lvo(at)rac.ca> Subject: Test shot > Please ignore this. > > John Cliff > > ________________________________________________________________________________
Date: Jan 24, 2001
Subject: and ASI
I agree that AOA info is useful, but not at the expense of an airspeed indicator. Since the government desk jockeys require as ASI, its not even worth wasting bandwidth here talking about it. Keep in mind that trying to calibrate an AOA in terms of aispeed limits (Vne, maneuvering speed, flap limits) only works at a fixed weight and 1G flight. It does give wing "performance" (stall, Clmax,Vx, Vy) info regardless of weight and G loading, which is why its a great instrument. You still need an ASI to give you the amount of energy available (with varying weight and G loading, AOA won't give you this info). ASI and AOA give you different information. ASI can give you AOA info at 1G and corrected for weight variations. AOA can be interpolated to give speed info (at 1G and a fixed weight). You can fly the wing at max efficiency by using AOA, but if you're going to push the envelope, I'd rather know how much energy (airspeed) I have available. Any fighter pilot will tell you that AOA is great, but not at the expense of an ASI. A good pilot can "feel" if he's at the correct AOA, and certainly can feel where the stall begins. Bottom line: Keep the ASI (you need it to know how fast you're going and for energy management). Add AOA if you want to fly the plane efficiently (but you can get the same info from the ASI). Tape a piece of string to the wingtip trailing edge for a cheap AOA indicator. If you want to avoid stalling, go out and practice stalls till you get a good feel for your machine (you need to do this even with an AOA indicator). Get a book (about the size of a magazine. Easy and quick to read) by Bob Wander called "Glider Polars and Speed To Fly". You'll learn more about how a wing works in an evening of reading than any instructor can teach you. I highly recommend it for all pilots. I'm ex- Air Force (supersonic and heavy jets) and now fly a B-777. In my spare time I also fly sailplanes (cross country racing), bizjets, and teach air combat and aerobatics in a SF-260 and Extra 300L (where I find an AOA indicator would be of little use since I can feel where I need to be). The Europa is my first kit plane. Ben Clerx #A144 Southern California ________________________________________________________________________________
Date: Jan 24, 2001
Subject: Re: AOA and ASI
Soaring magazines such as "Soaring" and perhaps "Gliding" would have it. The SSA bookstore would have it (www.ssa.org). Or direct from the author (www.bobwander.com) Ben ________________________________________________________________________________
Date: Jan 24, 2001
Subject: rney Fly-In 8-9-10 Jun 2001
I just discovered I received another announcement of a CI event a little while back, and forgot to broadcast it. The accommodation there is strictly limited, so early application is recommended. You need to book an arrival slot to help them with surface arrangements. The Alderney Flying Club invite you to their Annual Fly-In on 8th, 9th & 10th June 2001. There are 26 cups and other prizes to be won in various competitions, and social functions on the Fri & Sat nights with good food & live music. For full information and booking form with accommodation list, contact: Ralph Burridge Wingspan 1 Rue Genet Alderney Channel Islands GY9 3DX phone/fax 01481 822297 e-mail regards Rowland | Rowland Carson Europa Club Membership Secretary | Europa 435 G-ROWI PFA #16532 EAA #168386 ________________________________________________________________________________
Date: Jan 24, 2001
> You aren't likely to get a big number if you limit the >"flyouts" to max.8No. !!!!?? Bob - I think this raises the question of what level of "organisation" is appropriate for Europa Club "fly-out" events. (BTW, don't shoot the messenger! I am posting the info because my name is advertised as first point of contact for the Club (chiefly 'cos we hope the majority of people wanting to contact the membership secretary will be potential new members). I opted to post the info on the "public" list rather than just send it to the Club Committee, to give the maximum number of people the most notice of the event. It's up to the Social Co-ordinators whether they choose to make any formal provisions for any specific event organised by a third party, or simply let people go along individually, as to any other fly-in. They might want to conduct a poll on this forum to get evidence of likely participation.) The touring events run up to now have been limited to relatively low numbers simply to make the logistics manageable. The Club has organized accommodation and transpsort, as well as some activities, at the remote end. But, just thinking aloud, it seems that there could be a market for a different flavour of tour where an experienced pilot helps others with the admin and other complications of going foreign, but participants are left to their own devices about rooms, surface transport, entertainment, etc. However, I can see some problems that might arize. The leader might say "I'm staying at the XYZ motel in Slobbodia but they only have N rooms and I don't know the names of any other hotels". Obviously this could lead to some folk getting a poorer deal than others where facilites are limited. And how should the leader deal with folk who get lost on the ground (as opposed to in the air, which we _all _ do)? Should the other 19 aircrafts' takeoff on the next leg be delayed because pilot #20 hasn't turned up and nobody knows where she/he was staying the night? How many people are looking for this sort of experience? Replies to Peter Kember or one of the other Social Co-ordinators, NOT me! regards Rowland | Rowland Carson Europa Club Membership Secretary | Europa 435 G-ROWI PFA #16532 EAA #168386 ________________________________________________________________________________
Date: Jan 24, 2001
The blighter seems too good to be true. Consoling oneself with the thought that we are isolated, unsponsored and solitary {most of us) which he was far from being, is scant consolation. Odious comparisons with one's own slow and faulty performance are inevitable. I'll have to do a video called "A complain is borne" to cheer you up a bit......H ----- Original Message ----- From: Ray Mc Donnell <raymc(at)idt.net> Subject: Re: A PLANE IS BORN > Why ???,will it depress me > > ----- Original Message ----- > From: "hedley brown" <hedley(at)hedleybrown.flyer.co.uk> > Cc: ; > Subject: Re: A PLANE IS BORN > > > > Advice - dont. It'll only depress you. > > ----- Original Message ----- > > From: Craig M Ellison <ellisonair(at)juno.com> > > Cc: > > Subject: Re: A PLANE IS BORN > > > > > > > Hi all, > > > > > > I too would be interested in getting hold of tapes of A Plane Is Born > > > should some be available. A picture is worth a thousand words > sometimes. > > > > > > Craig > > > A205 > > > > ________________________________________________________________________________
Date: Jan 24, 2001
Subject: training for monowheel
Those folk with long memories will recall I asked for responses on the likely uptake of a monowheel training course, an initiative of the PFA Coaching Scheme in association with the Europa Factory. I am pleased to reproduce below the text of a letter received by The Europa Club from Cliff Piper of the PFA. A similar announcement will appear shortly in "Popular Flying". = = = = = = = = = = = = = = = = = = Europa Training Weekend Europa Aircraft has generously agreed to join with the PFA in a training weekend Sywell on 12th - 13th May 2001. This is a preliminary announcement and some details remain to be finalised but arrangements provisionally are as follows . 1, Two mono-wheel aircraft will be available and two PFA coaches each day in addition to Andy Draper from Europa aircraft. 2, The course is aimed at Europa builders who are close to completion and restricted to the monowheel version. 3, Training will include some experience on a hard runway at Hinton, weather permitting. 4, Numbers will be restricted to six, 3 on Saturday and 3 on Sunday each candidate can expect about two hours flying (this will also qualify for the one hour coaching flight for licence revalidation as a bonus). 5, The fee will be approx 100 to cover the fuel and expenses and does not include accommodation or food. 6, Accommodation is available at the Sywell Motel at about 45 per night and has a good selection of food but this must be arranged personally by the candidate. 7, It is not intended that this training will be sufficient to reach an adequate standard on the aircraft, but should be considered as a primer for a Pilot Coaching Scheme conversion course. 8, If you wish to take advantage of this excellent opportunity contact Penny Sharpe for a provisional booking but do not forward cash at this stage. Cliff Piper Chairman PCS = = = = = = = = = = = = = = = = = = regards Rowland | Rowland Carson Europa Club Membership Secretary | Europa 435 G-ROWI PFA #16532 EAA #168386 ________________________________________________________________________________
Subject: Sim
Date: Jan 24, 2001
I just learned that "foilsim" needs to be "FoilSim". A little somethin' every day. Nic ________________________________________________________________________________
Subject: site??
Date: Jan 25, 2001
Apologies this is not strictly a europa question, but does anyone have a website address or details of european agents for Grob the German Glider manufacturer. I have an address for the US agents: Grob Systems, Inc., 1070 Navajo Drive, Bluffton, OH 45817 But I would like some European contact details. Cheers Paul Sweeting Paul R. Sweeting - Hyder UNIX Support. * P.O. Box 110, Blwch SP 110, Technology Drive, Ffordd Dechnoleg, Bridgend Science Park, Parc Gwyddioniaeth, Bridgend. Penybont Ar Ogwr. CF31 3UJ. CF31 3UJ. * Tel:+44(0)1656 765119 Mobile:+44(0)7901 855607 ********************************************************************** The information contained in this message is intended for the named recipients only. It may contain privileged and confidential information and if you are not the addressee or the person responsible for delivering this to the addressee, you may not copy, distribute or take action in reliance on it. If you have received this message in error, please notify us immediately by a reversed charge telephone call to +44 (0) 1656 765 000 ********************************************************************** ________________________________________________________________________________
Date: Jan 25, 2001
Subject: red block
There is another feature of the mono undercarriage which is apparent only with the aircraft suspended. The damper block has enormous hysteresis with hours of recovery time. Years ago Ron Swinden supplied me with a compression curve when I had illusions of using it's Hook's "constant" for auto-loading - (you can't, it isn't !) This means that unless you park your aircraft with the weight off the wheel !, the "pre-compression" you put in during construction is just not there and the bolts go slack. So there is shock to the system, as about 3/8" slack is taken up on first arrival. Another bit of precious prop. to ground spacing lost. Perhaps later blocks are different, but many must be flying like mine. Graham C G-EMIN ________________________________________________________________________________
Subject: Re: u/c red block
Date: Jan 25, 2001
So let me understand here. Parking the plane compresses the damper, which retains its compressed shape for any length flight. Hence, the undercarriage is undamped for the first 3/8" of wheel travel. Don't the shock absorbers in the later undercarriages (XS and others) contribute some shock absorption? Or do they operate in extension only? Shaun A207 ----- Original Message ----- From: <Grahamclk(at)aol.com> Subject: u/c red block > There is another feature of the mono undercarriage which is apparent only > with the aircraft suspended. The damper block has enormous hysteresis with > hours of recovery time. Years ago Ron Swinden supplied me with a compression > curve when I had illusions of using it's Hook's "constant" for auto-loading - > (you can't, it isn't !) > > This means that unless you park your aircraft with the weight off the wheel > !, the "pre-compression" you put in during construction is just not there and > the bolts go slack. So there is shock to the system, as about 3/8" slack is > taken up on first arrival. Another bit of precious prop. to ground spacing > lost. > > Perhaps later blocks are different, but many must be flying like mine. > > Graham C G-EMIN > > ________________________________________________________________________________
Date: Jan 25, 2001
In a message dated 25/01/2001 22:29:44 GMT Standard Time, shauns(at)hevanet.com writes: << Parking the plane compresses the damper, which retains its compressed shape for any length flight. Hence, the undercarriage is undamped for the first 3/8" of wheel travel. >> Yes Shaun, that's exactly it. Dampers on the Classic weren't obligatory though I do have them so probably nothing is going to break. However it doesn't alter the fact that the undercarriage cannot behave as designed. Perhaps we should pre-compress them some more ? Only Europa can decide. Perhaps the biggest shock is when your inspector says "why are these bolts so loose !" Graham G-EMIN ________________________________________________________________________________
Date: Jan 26, 2001
But isn't this resolved with the newer undercarriage black block as shipped with the current kit? Tony << Parking the plane compresses the damper, which retains its compressed shape for any length flight. Hence, the undercarriage is undamped for the first 3/8" of wheel travel. >> ________________________________________________________________________________
Date: Jan 25, 2001
All I can say after the landing I made on Tuesday is that the performace of the undercarriage suspension is "impressive"!!!! Bob Jacobsen N165BB From: "Tony Krzyzewski" <tonyk(at)kaon.co.nz> >Subject: RE: u/c red block >Date: Fri, 26 Jan 2001 12:20:44 +1300 > >But isn't this resolved with the newer undercarriage black block as shipped >with the current kit? > >Tony > ><< Parking the plane compresses the damper, which > retains its compressed shape for any length flight. Hence, the > undercarriage is undamped for the first 3/8" of wheel travel. >> > ________________________________________________________________________________
Date: Jan 25, 2001
From: Steve & Eileen Genotte <gopack(at)sprintmail.com>
Bob Jacobsen wrote: > > All I can say after the landing I made on Tuesday is that the performace of > the undercarriage suspension is "impressive"!!!! One of those landings which falls under the category of "Seismic Event"? Steve G. ________________________________________________________________________________
Subject: vs,ASI
Date: Jan 26, 2001
Forwarded from the bounce bin. Message is from "Fergkyle" ********************************************** Ben: This isn't an argument with what you say in essence but let meask you a couple easy ones: 1. You and I are ex-AF, and I started on wooden jets in 1951 and progressed(?) through a number of others, then Army Co-op then transports. But are you telling me you never lost a buddy who pulled too tight in a fighter break with an inside wind? ...that you never saw a demo pilot stall out in vertical manoeuvre?They all had ASIs but no AoA. 2. Would you agree that USN doesn't always piddle away millions on unnecessary hardware. I said 'always', heh, heh. I had to be convinced of the value of an AoA but now see the advantage of not having to bumble about revising my driftdown speed according to present weight - I can just pick the ideal AoA no matter weight, temp or density alt. I believe the AoA tells you instantly what your lift is doing and the ASI tells me where I went wrong 10 seconds ago. Thass my experience. How do you like the 777? Happy Landings Ferg A064 ________________________________________________________________________________
Subject: ttle airline humor
Date: Jan 26, 2001
Forwarded from the bounce bin. Message is from Al Fuller ************************************************ Passengers on a small commuter plane are waiting for the flight to leave and they're getting a little impatient. But the airport staff has assured them that the pilots will be there soon and the flight can take off immediately there after. The entrance opens and two men walk up the aisle, dressed in pilot's uniforms-both are wearing dark glasses. One is using a seeing-eye dog, and the other is tapping his way up the aisle with a white tipped cane. Nervous laughter spreads through the cabin as the men enter the cockpit. The door closes, and the engines start up. The passengers begin glancing around, nervously, searching for some sign that this is just a little practical joke. None is forthcoming. The plane moves faster and faster down the runway and people at the windows realize that they're headed straight for the edge of the water at the end of the airport's property. It begins to look as though the plane will never take off, but will plow into the water!! Panicked screams fill the cabin, but at that moment, the plane lifts smoothly into the air. The passengers relax and laugh a little sheepishly. Soon they have all retreated into their magazines, secure in the knowledge that the plane is in good hands. Up in the cockpit, the co-pilot turns to the pilot and says, "You know, Bob, one of these days, they're going to scream too late, and we're all gonna die. --------------------------------------------------- OK, lets see: Amateurs built the ark, professionals built the Titanic and experts build the Space Shuttle. Hummmmmmm.... Alfonso C. Fuller, Jr. Date: Jan 26, 2001
From: Graham Singleton <grasingleton(at)avnet.co.uk>
>But isn't this resolved with the newer undercarriage black block as shipped >with the current kit? > >Tony > ><< Parking the plane compresses the damper, which > retains its compressed shape for any length flight. Hence, the > undercarriage is undamped for the first 3/8" of wheel travel. >> I'm still confused. Do you mean elastomeric spring when you say damper? The dampers (hydraulic) were fitted to stop the bounce caused by the spring. Graham ________________________________________________________________________________
Date: Jan 26, 2001
europa(at)avnet.co.uk In a message dated 25/01/2001 23:18:54 GMT Standard Time, tonyk(at)kaon.co.nz writes: << But isn't this resolved with the newer undercarriage black block as shipped with the current kit? >> Could well be - you only have to tighten one up in a vice to check. Or if already installed you should find the plate spacing is less than it was set to, and the bolts loose. Graham ________________________________________________________________________________
Date: Jan 26, 2001
In a message dated 26/01/2001 12:39:11 GMT Standard Time, grasingleton(at)avnet.co.uk writes: << Do you mean elastomeric spring when you say damper >> Yes, sorry I do. As I understand it the hydraulic dampers are rebound only, but of course the tyre compliance will lessen direct shocks to the bearings even if the elastomer is not filling the space any more. Don't know if the current black block behaves this way, but AFAIK there has been no suggestion of replacing the red one. Graham C ________________________________________________________________________________
Date: Jan 26, 2001
Subject: Re: AoA vs,ASI
Hi Ferg I'm not saying that AOA isn't required. I just wouldn't substitute it for an ASI and try to convince the FAA (or other goverment equal) that I don't need to install an ASI. AOA is a valuable tool, especially where max performing the plane is required (flying out of windshear at 0.9 Cl). They are more useful in jets that require lots of altitude to recover from a stall than in light planes that recover much quicker. But for stall recognition, nearly all aircraft (particularly jets) give the pilot adaquate warning approaching the stall without having to refer to AOA. When you stall, you'll know it. AOA would be useful in recovering with minimum altitude loss. Therefore, AOA is more for flying at max performance (at a given, fixed angle of attack), like consistant approaches to a carrier deck. Don't get me wrong. I love AOA indicators. But I also love my ASI since it tells me my energy state. Anyone going without an ASI, thinking that AOA will give all the info they seek, will be disappointed. Certainly, add an AOA to your ASI. All I'm saying is that AOA in a light plane isn't the same "bang for the buck" as in a jet or other high performance plane (read that as high wing loading). To answer your question on the B-777 (which also has an AOA indicator); its a REALLY nice plane to fly. If all future planes handle this well, then aviation has a bright future. Anyone out there that can fly a Europa can easily fly and land a B-777. Its the only plane I've been able to grease on EVERY landing (so far). They make 'em easy to fly so that us ex-Air Force types don't break them. Ben Clerx ________________________________________________________________________________
Date: Jan 26, 2001
>. But for stall recognition, nearly all >aircraft (particularly jets) give the pilot adaquate warning approaching the >stall without having to refer to AOA. When you stall, you'll know it. If you stall a Europa or similar high performance small aircraft, (Lancair, Glasair, BanBi etc) below 100 feet it may well be too late. All the ones I have test stalled have dropped a wing. Some violently. (all except the XS I flew which was more docile) > Therefore, AOA is more for flying at max performance (at a given, fixed > angle of attack), like >consistant approaches to a carrier deck. Or consistent approaches to short dirt fields. Take off from small farm strips is usually a max performance job, here in UK anyway. I still insist AoA tells you what is going to happen, ASI tells you what happened 20 seconds ago. AoA must be a better way. Graham ________________________________________________________________________________
From: "Cafe St Tropez" <mail(at)cafesttropez.com.au>
Subject:
Date: Jan 27, 2001
I am new on the list, building an Europa in Australia. Is someone can help me to choose between the AOA sport and professional. Is the professional worth the difference in price. Jean-claude Smitka jc(at)cafesttropez.com.au ________________________________________________________________________________
Subject: ine fuel filters (surplus to requirement)
Date: Jan 27, 2001
Hi! Builders. I have a coupe of Europa Supplied fuel filters and new elements all AS NEW but smell of fuel ! to dispose of. Anyone not yet fixed up with filters please be advised they come cheap from me ! Bob Harrison. G-PTAG ________________________________________________________________________________
Subject: Re: In line fuel filters (surplus to requirement)
Date: Jan 27, 2001
So have I - totally unused and in the original packaging.Any offer gladly accepted......H ----- Original Message ----- From: Bob.Harrison <ptag.dev(at)ukonline.co.uk> Subject: In line fuel filters (surplus to requirement) > Hi! Builders. > I have a coupe of Europa Supplied fuel filters and new elements all AS NEW > but smell of fuel ! to dispose of. > Anyone not yet fixed up with filters please be advised they come cheap from > me ! > Bob Harrison. G-PTAG > ________________________________________________________________________________
Subject: Re: AOA
Date: Jan 27, 2001
I talked to the head of Proprietary Software Systems about this. From a
December 31, 2000 - January 26, 2001
Europa-Archive.digest.vol-bq
